RV10-Archive.digest.vol-ej
March 10, 2009 - March 30, 2009
Subject: Top COMM antenna
Date: Mar 10, 2009
so you disconnect each time the cowl is removed? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of James McGrew Sent: Tuesday, March 10, 2009 3:54 PM Subject: Re: RV10-List: Top COMM antenna Michael, I glassed a VHF comm antenna into the cowling. It is oriented vertically and works great. More details and pictures from my previous post are located here: http://forums.matronics.com/viewtopic.php?t=6664 -Jim N312JE On Tue, Mar 10, 2009 at 5:02 AM, Michael Wellenzohn wrote: Hi guys, I want to mount a com antenna on top. The tape comm antenna I understand is not an option for the -10. Now COMMANT has a veriation of models: Which one can you suggest? http://www.comant.com/showproduct.aspx?CN=44 <http://www.comant.com/showproduct.aspx?CN=44&SCN=59> &SCN=59 Looking forward for your thoughts. Cheers Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234006#234006 t Un/Subscription, www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List ronics.com/" target="_blank">http://forums.matronics.com Matt Dralle, List Admin. ==== ________________________________________________________________________________
Date: Mar 10, 2009
Subject: Re: Top COMM antenna
I said cowling... I meant cabin top. It is not removed quite as often as the cowling. -Jim N312JE On Tue, Mar 10, 2009 at 6:58 PM, David McNeill wrote: > so you disconnect each time the cowl is removed? > > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *James McGrew > *Sent:* Tuesday, March 10, 2009 3:54 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Top COMM antenna > > Michael, > > I glassed a VHF comm antenna into the cowling. It is oriented vertically > and works great. More details and pictures from my previous post are located > here: http://forums.matronics.com/viewtopic.php?t=6664 > > -Jim > N312JE > > On Tue, Mar 10, 2009 at 5:02 AM, Michael Wellenzohn > wrote: > >> rv-10(at)wellenzohn.net> >> >> Hi guys, >> >> I want to mount a com antenna on top. >> The tape comm antenna I understand is not an option for the -10. >> >> Now COMMANT has a veriation of models: >> Which one can you suggest? >> >> http://www.comant.com/showproduct.aspx?CN=44&SCN=59 >> >> Looking forward for your thoughts. >> >> Cheers >> Michael >> >> -------- >> RV-10 builder (engine, prop, finishing) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=234006#234006 >> t Un/Subscription, >> www.matronics.com/Navigator?RV10-List" target="_blank"> >> http://www.matronics.com/Navigator?RV10-List >> ronics.com/" target="_blank">http://forums.matronics.com >> Matt Dralle, List Admin. >> ==== >> >> >> >> > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Mar 10, 2009
From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
Subject: 24 Volt Electrical System
Are there any RV-10s that are running on a 24 volt electrical system? Dave -- ~~~~~~~~~~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA ~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Subject: Real airplanes fly 24 volts
Date: Mar 11, 2009
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
We've got a 24 volt system, like all REAL airplanes! : ) Or like people who are pushed that way by their avionics. But it does make for fun poking around to try and find the appropriate 24 volt contactors, etc. . . . TDT 40025 Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Mar 11, 2009
Subject: Re: Real airplanes fly 24 volts
Ah yes, *those* real aircraft that require real aircraft parts at unreal pricing with unreal supply chains. 8-) Dawson-Townsend,Timothy wrote: > > We've got a 24 volt system, like all REAL airplanes! : ) > > > > Or like people who are pushed that way by their avionics. > > > > But it does make for fun poking around to try and find the appropriate > 24 volt contactors, etc. . . . > > > TDT > > 40025 > > > > Tim Dawson-Townsend > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * > > > * -- ________________________________________________________________________________
Date: Mar 11, 2009
Subject: Re: 24 Volt Electrical System
I will be running dual Oddessy batteries for both=C2-12 and 24 volts in m y 10.=C2- Same thing I did on the Cozy MKIV.=C2- I want 24V cranking th e engine and=C2-then have the flexibility to mix 12/24 volt as needed.=C2 - With the batteries wired=C2-together, I tapped the buss bar that conn ects them for my 12V supply.=C2- Some state that one of the batteries wil l drain first and the other will become a donner battery, killing the batte ry in short order.=C2- Has not happened yet in the Cozy.=C2- There is a battery equalizer that will solve the problem but it costs about $275 that will prevent this. .=C2- One guy just flip-flops his batteries at every oil change and states he never has had any problems.=C2- I made a very sl ight modification to the Van's battery tray in the kit and dual Oddessy's f it perfectly.=C2- I also added a second master solenoid.=C2- One for 12 volts and the other for 24.=C2- My engine is currently set up for 12 vol ts (its out of a Maule) so I will need to swap out the starter and alternat or. ----- Original Message ----- From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com> Sent: Wednesday, March 11, 2009 1:37:47 AM GMT -05:00 US/Canada Eastern Subject: RV10-List: 24 Volt Electrical System mo.com> Are there any RV-10s that are running on a 24 volt electrical system? Dave -- ~~~~~~~~~~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA ~~~~~~~~~~~~~~~~~~~~~~~ =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Mar 11, 2009
SW50ZXJlc3RpbmcgaWRlYSAoZHVhbCAxMi8yNCkgSSB3aXNoIEkgaGFkIGNvbnNpZGVyZWQgaXQg ZHVyaW5nIG15IGJ1aWxkLiBUaGUgRzkwMFggY2FuIGJlIHNldCB1cCBmb3IgMTJWIGJ1dCB0aGUg ZHVhbCAxOFcgQ09NTeKAmXMgcmVxdWlyZSAyNFYgc28gd2l0aG91dCBrbm93aW5nIG9mIGFub3Ro ZXIgb3B0aW9uIEkgaGFkIHRvIGJ1eSB0d28gVmVyeSBIZWF2eSBhbmQgVmVyeSBFeHBlbnNpdmUg dXAgY29udmVydGVycy4gSSBoYXRlZCBhZGRpbmcgdGhhdCBleHRyYSB3ZWlnaHQgJiBidWxrIHRv IG15IHBsYW5lLiBJIGRvIGhvd2V2ZXIgbGlrZSB0aGUgcG93ZXIgJiBjbGFyaXR5IG9mIHRoZSBH YXJtaW4gMThXIGNvbW1zLg0KDQogDQoNClJvYmluDQoNCiANCg0KIA0KDQpGcm9tOiBvd25lci1y djEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBkYXZpZHNvdXRwb3N0QGNvbWNhc3QubmV0 DQpTZW50OiBXZWRuZXNkYXksIE1hcmNoIDExLCAyMDA5IDY6MDIgQU0NClRvOiBydjEwLWxpc3RA bWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogMjQgVm9sdCBFbGVjdHJpY2Fs IFN5c3RlbQ0KDQogDQoNCkkgd2lsbCBiZSBydW5uaW5nIGR1YWwgT2RkZXNzeSBiYXR0ZXJpZXMg Zm9yIGJvdGggMTIgYW5kIDI0IHZvbHRzIGluIG15IDEwLiAgU2FtZSB0aGluZyBJIGRpZCBvbiB0 aGUgQ296eSBNS0lWLiAgSSB3YW50IDI0ViBjcmFua2luZyB0aGUgZW5naW5lIGFuZCB0aGVuIGhh dmUgdGhlIGZsZXhpYmlsaXR5IHRvIG1peCAxMi8yNCB2b2x0IGFzIG5lZWRlZC4gIFdpdGggdGhl IGJhdHRlcmllcyB3aXJlZCB0b2dldGhlciwgSSB0YXBwZWQgdGhlIGJ1c3MgYmFyIHRoYXQgY29u bmVjdHMgdGhlbSBmb3IgbXkgMTJWIHN1cHBseS4gIFNvbWUgc3RhdGUgdGhhdCBvbmUgb2YgdGhl IGJhdHRlcmllcyB3aWxsIGRyYWluIGZpcnN0IGFuZCB0aGUgb3RoZXIgd2lsbCBiZWNvbWUgYSBk b25uZXIgYmF0dGVyeSwga2lsbGluZyB0aGUgYmF0dGVyeSBpbiBzaG9ydCBvcmRlci4gIEhhcyBu b3QgaGFwcGVuZWQgeWV0IGluIHRoZSBDb3p5LiAgVGhlcmUgaXMgYSBiYXR0ZXJ5IGVxdWFsaXpl ciB0aGF0IHdpbGwgc29sdmUgdGhlIHByb2JsZW0gYnV0IGl0IGNvc3RzIGFib3V0ICQyNzUgdGhh dCB3aWxsIHByZXZlbnQgdGhpcy4gLiAgT25lIGd1eSBqdXN0IGZsaXAtZmxvcHMgaGlzIGJhdHRl cmllcyBhdCBldmVyeSBvaWwgY2hhbmdlIGFuZCBzdGF0ZXMgaGUgbmV2ZXIgaGFzIGhhZCBhbnkg cHJvYmxlbXMuICBJIG1hZGUgYSB2ZXJ5IHNsaWdodCBtb2RpZmljYXRpb24gdG8gdGhlIFZhbidz IGJhdHRlcnkgdHJheSBpbiB0aGUga2l0IGFuZCBkdWFsIE9kZGVzc3kncyBmaXQgcGVyZmVjdGx5 LiAgSSBhbHNvIGFkZGVkIGEgc2Vjb25kIG1hc3RlciBzb2xlbm9pZC4gIE9uZSBmb3IgMTIgdm9s dHMgYW5kIHRoZSBvdGhlciBmb3IgMjQuICBNeSBlbmdpbmUgaXMgY3VycmVudGx5IHNldCB1cCBm b3IgMTIgdm9sdHMgKGl0cyBvdXQgb2YgYSBNYXVsZSkgc28gSSB3aWxsIG5lZWQgdG8gc3dhcCBv dXQgdGhlIHN0YXJ0ZXIgYW5kIGFsdGVybmF0b3IuDQoNCiANCiANCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxp dGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYg RG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBt dWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9O YXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJP TklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUg dmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBX ZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09 ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0K Xy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQog DQo ________________________________________________________________________________
Subject: Remembrance of Mark Ritter
Date: Mar 11, 2009
Today is the One year anniversary of Mark Ritter's "Gone West" flight. Mark was a valued contributor on this list and we shared several memorable discussions "offline" over the months and years. Attached is a picture of Mark's Scheme Designer paint job. Each loss to our group is a painful one, but I reflect on the valued lesson Mark left behind for me. Friends share observations with friends. As a retired Pilot Examiner, I without fail would include an Oral question for both Private and Commercial applicants from FAR 61.53 and often would query the use of "Over the Counter" medications. Years later the FAA expanded our responsibility to include a Task from the Area of Operations in the PTS, of Preflight Preparation. I would always delve into Aeromedical Factors. Applicants knew they would be getting questions on the recognition and remediation on hypoxia and hyperventilation. Sometimes a distracter to induce potential vertigo would be included. Today, in the Air Carrier Maintenance arena - Human Factors are the big FAA push. Fatigue/Distractions/Complacency/the list goes on to make up the Dirty Dozen. Mark was not my first friend to be lost to potential medical issues. Another pilot Bob McCann "Went West" making a similar solo flight in connection to that simple "Pilot's Pancake Breakfast" just an hour away. The Search and Rescue effort brought scores of pilots into the mix with the CAP (and a topic I won't go into here). We each benefit by our candid discussion with friends when we observe something out of the ordinary then do something more than silent observation. We each carry the financial cost of increased insurance rates after their passing. Let's all hope that Mark's passing is the beginning of a long and extended period of Safe Flights in the RV-10 that are devoid of medical issues. I remember an incident in A&P school where another friend, Alan Johnson (retired AF crew chief) seemed just a bit unusually stresses over our Bendix Pressure Carb Fuel Metering Class. I let Alan know repeatedly that he just did not look his Rosey self. Green and Grey with perspiration were not typical school colors. Alan reluctantly visited a doctor after class that day. Seems his smoking, drinking and sedentary lifestyle required an immediate quadruple bypass. Although Alan left that class and the program, the years have passed gently. Today Alan can be found on the ramp of airports in Arizona with his Canon capturing the aircraft he loves. Let's spend a minute, think of Mark and others who have passed and reflect on the value of sharing our observations. I don't have an answer for you on those who pilots who cognitively fly into bad weather or disregard clear and concise information to the contrary in attempting flight with known aircraft problems. May 2009... and Beyond continue the pattern... and that Mark be our last loss. I know we're are all one day closer. <> John Cox #600 ________________________________________________________________________________
Subject: Adel Pliers
Date: Mar 11, 2009
Here are the shots I promised. One is a range of cheapo tools, another is a modified Canon Plug pliers, another is the use of the ole busted hacksaw blade. They should be self explanatory. They are designed to work in Tight spaces to which the really cool $86 pair will not fit. The blade is grooved with a 3" Harbor Freight cutoff wheel to accept 6,8 or 10-32 Adel Screws and MS attachment nuts. Your fingertips will love you. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Friday, March 06, 2009 2:39 PM Subject: RE: RV10-List: Adel Pliers No. However a simple piece of hacksaw blade and your pencil grinder can make an Adel lock tool which is easy to install, easy to remove and just plain slick. Discarded Medical Forceps work on the cheap. If you are doing triple stacked or quad stacked Adels for a living then maybe the tool will prove itself. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of johngoodman Sent: Fri 3/6/2009 11:39 AM Subject: RV10-List: Adel Pliers Has anybody tried out these Adel Clamp Pliers from Wicks? If so, are they worth the money? John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=233494#233494 http://www.matronic - -> http://forums.matronics.com p; - List Contribution bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c =============== ________________________________________________________________________________
Subject: Aviation Consumer
Date: Mar 11, 2009
Here is a quote from an Aviation Consumer article reprinted at Avweb: As far as we're concerned, the data that indicates that correctly executed lean-of-peak operation both saves fuel and lowers EGTs and CHTs IS INARGUABLE, and people who claim otherwise don't know what they're talking about. We can't make it any plainer than this. http://www.avweb.com/news/airman/are_you_wasting_avgas_196816-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234234#234234 ________________________________________________________________________________
Date: Mar 11, 2009
David, I assume you are using two PC680s? davidsoutpost(at)comcast. wrote: > I will be running dual Oddessy batteries for both 12 and 24 volts in my 10. Same thing I did on the Cozy MKIV. I want 24V cranking the engine and then have the flexibility to mix 12/24 volt as needed. With the batteries wired together, I tapped the buss bar that connects them for my 12V supply. Some state that one of the batteries will drain first and the other will become a donner battery, killing the battery in short order. Has not happened yet in the Cozy. There is a battery equalizer that will solve the problem but it costs about $275 that will prevent this. . One guy just flip-flops his batteries at every oil change and states he never has had any problems. I made a very slight modification to the Van's battery tray in the kit and dual Oddessy's fit perfectly. I also added a second master solenoid. One for 12 volts and the other for 24. My engine is currently set up for 12 volts (its out of a Maule) so I will need to swap out the starter and alternator. > > --- -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234237#234237 ________________________________________________________________________________
Date: Mar 11, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I actually bought a set of Adel Pliers at OSH a couple years ago and after a couple times using them I went back to the fly market/Harbor Freight hemostats and needle nose vise grips as shown in John's pix. Bob N442PM (flying) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Wednesday, March 11, 2009 3:20 PM Subject: RE: RV10-List: Adel Pliers Here are the shots I promised. One is a range of cheapo tools, another is a modified Canon Plug pliers, another is the use of the ole busted hacksaw blade. They should be self explanatory. They are designed to work in Tight spaces to which the really cool $86 pair will not fit. The blade is grooved with a 3" Harbor Freight cutoff wheel to accept 6,8 or 10-32 Adel Screws and MS attachment nuts. Your fingertips will love you. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Friday, March 06, 2009 2:39 PM Subject: RE: RV10-List: Adel Pliers No. However a simple piece of hacksaw blade and your pencil grinder can make an Adel lock tool which is easy to install, easy to remove and just plain slick. Discarded Medical Forceps work on the cheap. If you are doing triple stacked or quad stacked Adels for a living then maybe the tool will prove itself. John Cox _____ From: owner-rv10-list-server(at)matronics.com on behalf of johngoodman Sent: Fri 3/6/2009 11:39 AM Subject: RV10-List: Adel Pliers Has anybody tried out these Adel Clamp Pliers from Wicks? If so, are they worth the money? John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=233494#233494 http://www.matronic - -> http://forums.matronics.com p; - List Contribution bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c =============== http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: More LOP
Date: Mar 11, 2009
Here are a few more articles: Why does proper leaning procedure seem to be such a confusing subject for pilots when it's so darn easy? http://www.avweb.com/news/savvyaviator/savvy_aviator_59_egt_cht_and_leaning_198162-1.html Here's an amazing number: Merely by operating engines lean of peak, aircraft owners are saving themselves more than $30 million a year. That's a big number. Will Lycoming ever embrace the idea? http://www.avweb.com/blogs/insider/AVwebInsiderBlog_TheGreatLeaningWar_198048-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234241#234241 ________________________________________________________________________________
Date: Mar 11, 2009
Doesn't the 24V avionics cost more but do the same as 12V? I do not know? On 3/11/09, Robin Marks wrote: > Interesting idea (dual 12/24) I wish I had considered it during my build. > The G900X can be set up for 12V but the dual 18W COMMs require 24V so > without knowing of another option I had to buy two Very Heavy and Very > Expensive up converters. I hated adding that extra weight & bulk to my > plane. I do however like the power & clarity of the Garmin 18W comms. > > > Robin > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > davidsoutpost(at)comcast.net > Sent: Wednesday, March 11, 2009 6:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: 24 Volt Electrical System > > > I will be running dual Oddessy batteries for both 12 and 24 volts in my 10. > Same thing I did on the Cozy MKIV. I want 24V cranking the engine and then > have the flexibility to mix 12/24 volt as needed. With the batteries wired > together, I tapped the buss bar that connects them for my 12V supply. Some > state that one of the batteries will drain first and the other will become a > donner battery, killing the battery in short order. Has not happened yet in > the Cozy. There is a battery equalizer that will solve the problem but it > costs about $275 that will prevent this. . One guy just flip-flops his > batteries at every oil change and states he never has had any problems. I > made a very slight modification to the Van's battery tray in the kit and > dual Oddessy's fit perfectly. I also added a second master solenoid. One > for 12 volts and the other for 24. My engine is currently set up for 12 > volts (its out of a Maule) so I will need to swap out the starter and > alternator. > > -- Sent from my mobile device ________________________________________________________________________________
Subject: Re: More LOP
Date: Mar 11, 2009
This was supposed to be in reply in another thread but I started a topic by accident. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234243#234243 ________________________________________________________________________________
Subject: Re: Aviation Consumer On LOP
Date: Mar 11, 2009
This was supposed to be in reply in another thread but I started a topic by accident. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234242#234242 ________________________________________________________________________________
Subject: Re: Advance pilot seminar (lean of peak)
Date: Mar 11, 2009
Here is a quote from an Aviation Consumer article reprinted at Avweb: As far as we're concerned, the data that indicates that correctly executed lean-of-peak operation both saves fuel and lowers EGTs and CHTs IS INARGUABLE, and people who claim otherwise don't know what they're talking about. We can't make it any plainer than this. http://www.avweb.com/news/airman/are_you_wasting_avgas_196816-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234246#234246 ________________________________________________________________________________
Date: Mar 11, 2009
Here are a few more articles: Why does proper leaning procedure seem to be such a confusing subject for pilots when it's so darn easy? http://www.avweb.com/news/savvyaviator/savvy_aviator_59_egt_cht_and_leaning_198162-1.html Here's an amazing number: Merely by operating engines lean of peak, aircraft owners are saving themselves more than $30 million a year. That's a big number. Will Lycoming ever embrace the idea? http://www.avweb.com/blogs/insider/AVwebInsiderBlog_TheGreatLeaningWar_198048-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234247#234247 ________________________________________________________________________________
Date: Mar 11, 2009
And here are 3 articles from John Deakin of Advanced Pilot Seminars. Where Should I Run My Engine? (Part 1) http://www.avweb.com/news/pelican/182179-1.html Where Should I Run My Engine? (Part 2 The Climb) http://www.avweb.com/news/pelican/182176-1.html Where Should I Run My Engine? (Part 3 -- Cruise) http://www.avweb.com/news/pelican/182583-1.html Where Should I Run My Engine? (Part 4 -- Descent) http://www.avweb.com/news/pelican/183094-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234249#234249 ________________________________________________________________________________
Date: Mar 11, 2009
Here is a Power Point from APS describing leaning procedures. If you have Power Point it will open up in it. If not, Google Power Point Viewer and you can find a file from Microsoft that will let you view it. And no, I don't work for APS. Just trying to bust the myth that LOP is bad. http://www.avweb.com/other/Leaning.pps Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234253#234253 ________________________________________________________________________________
Date: Mar 11, 2009
And a related article: Pelican's Perch #84: Don't Set Mixture with CHT http://www.avweb.com/news/pelican/pelicans_perch_84_mixture_cht_194816-1.html Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234254#234254 ________________________________________________________________________________
Date: Mar 11, 2009
Yes,,,dual 680's. ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Wednesday, March 11, 2009 5:04:36 PM GMT -05:00 US/Canada Eastern Subject: RV10-List: Re: 24 Volt Electrical System David, I assume you are using two PC680s? davidsoutpost(at)comcast. wrote: > I will be running dual Oddessy batteries for both 12 and 24 volts in my 1 0.=C3=AF=C2=C2=BD Same thing I did on the Cozy MKIV. =C2-I want 24V cr anking the engine and then have the flexibility to mix 12/24 volt as needed . =C2-With the batteries wired together, I tapped the buss bar that conne cts them for my 12V supply. =C2-Some state that one of the batteries will drain first and the other will become a donner battery, killing the batter y in short order. =C2-Has not happened yet in the Cozy. =C2-There is a battery equalizer that will solve the problem but it costs about $275 that will prevent this. . =C2-One guy just flip-flops his batteries at every o il change and states he never has had any problems. =C2-I made a very sli ght modification to the Van's battery tray in the kit and dual Oddessy's fi t perfectly. =C2-I also added a second master solenoid. =C2-One for 12 volts and the other for 24. =C2-My engine is currently set up for 12 volt s (its out of a Maule) so I will need to swap out the starter and alternato r. > > --- -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234237#234237 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Mar 11, 2009
I am not sure either but if there is a difference, I think that it would be small,,,,certainly not enough to change=C2- my plans.=C2-=C2- This w ill give=C2-me a lot of flexibility in my electrical system.=C2- Worked great in the Cozy and no messing with=C2-voltage converters. ----- Original Message ----- From: "Mike Much" <mkmuch(at)gmail.com> Sent: Wednesday, March 11, 2009 5:13:16 PM GMT -05:00 US/Canada Eastern Subject: Re: RV10-List: 24 Volt Electrical System Doesn't the 24V avionics cost more but do the same as 12V? I do not know? On 3/11/09, Robin Marks wrote: > Interesting idea (dual 12/24) I wish I had considered it during my build. > The G900X can be set up for 12V but the dual 18W COMM=99s require 2 4V so > without knowing of another option I had to buy two Very Heavy and Very > Expensive up converters. I hated adding that extra weight & bulk to my > plane. I do however like the power & clarity of the Garmin 18W comms. > > > > Robin > > > > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > davidsoutpost(at)comcast.net > Sent: Wednesday, March 11, 2009 6:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: 24 Volt Electrical System > > > > I will be running dual Oddessy batteries for both 12 and 24 volts in my 1 0. > Same thing I did on the Cozy MKIV. =C2-I want 24V cranking the engine a nd then > have the flexibility to mix 12/24 volt as needed. =C2-With the batterie s wired > together, I tapped the buss bar that connects them for my 12V supply. =C2 -Some > state that one of the batteries will drain first and the other will becom e a > donner battery, killing the battery in short order. =C2-Has not happene d yet in > the Cozy. =C2-There is a battery equalizer that will solve the problem but it > costs about $275 that will prevent this. . =C2-One guy just flip-flops his > batteries at every oil change and states he never has had any problems. =C2-I > made a very slight modification to the Van's battery tray in the kit and > dual Oddessy's fit perfectly. =C2-I also added a second master solenoid . =C2-One > for 12 volts and the other for 24. =C2-My engine is currently set up fo r 12 > volts (its out of a Maule) so I will need to swap out the starter and > alternator. > > > > > -- Sent from my mobile device =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
From: "david b. jones" <d.j.goneflyin(at)earthlink.net>
Subject: FW: Remembrance of Mark Ritter
Date: Mar 11, 2009
-----Original Message----- From: david b. jones [mailto:d.j.goneflyin(at)earthlink.net] Sent: Wednesday, March 11, 2009 7:51 PM Subject: Remembrance of Mark Ritter Hello my fellow RV-10 owners, I looked for several years for a paint scheme for my RV-10. I thought well maybe I could take a partial design from several Airplanes that I liked and put something together. Mark Ritter put a picture of his RV-10 on the internet one time and I fell In love with his paint job. I called Mark and complimented him of a terrific paint scheme. My first question was would he give Me permission to copy it. Mark was very gracious and said OK. After having mine painted at GLO-Custom in North Dallas, I sent Mark Several pictures and he enjoyed seeing them . Mark was a class person and someone I will remember every time I open my hangar doors. People like Mark don't come along very often and I appreciated seeing him remembered. Sincerely, David Jones N331DJ ________________________________________________________________________________
Date: Mar 11, 2009
Bob, Where we you when I started down this life of building 4 airplanes ago?! Great pictures, nothing beats a simple/cheap approach. I'll certainly use these a lot on my next project. Thanks, Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Wednesday, March 11, 2009 5:05 PM Subject: RE: RV10-List: Adel Pliers I actually bought a set of Adel Pliers at OSH a couple years ago and after a couple times using them I went back to the fly market/Harbor Freight hemostats and needle nose vise grips as shown in John's pix. Bob N442PM (flying) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Wednesday, March 11, 2009 3:20 PM Subject: RE: RV10-List: Adel Pliers Here are the shots I promised. One is a range of cheapo tools, another is a modified Canon Plug pliers, another is the use of the ole busted hacksaw blade. They should be self explanatory. They are designed to work in Tight spaces to which the really cool $86 pair will not fit. The blade is grooved with a 3" Harbor Freight cutoff wheel to accept 6,8 or 10-32 Adel Screws and MS attachment nuts. Your fingertips will love you. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Friday, March 06, 2009 2:39 PM Subject: RE: RV10-List: Adel Pliers No. However a simple piece of hacksaw blade and your pencil grinder can make an Adel lock tool which is easy to install, easy to remove and just plain slick. Discarded Medical Forceps work on the cheap. If you are doing triple stacked or quad stacked Adels for a living then maybe the tool will prove itself. John Cox _____ From: owner-rv10-list-server(at)matronics.com on behalf of johngoodman Sent: Fri 3/6/2009 11:39 AM Subject: RV10-List: Adel Pliers Has anybody tried out these Adel Clamp Pliers from Wicks? If so, are they worth the money? John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=233494#233494 http://www.matronic--> http://forums.matronics.com p; - List Contribution bsp; -Matt Dralle, List href="http://www.matronics.com/contribution">http://www.matronics.com/c==== =========== http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Mar 12, 2009
Marcus, based on what I know and what was also mentioned before the com antenna needs to be as much vertical as possible. So how does your installation on the cabin ceiling work then? Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234318#234318 ________________________________________________________________________________
Date: Mar 12, 2009
Another consideration is the radiation from the antenna. IIRC correctly the intensity varies inversely with the square of the distance between the pilot and the source. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Wellenzohn Sent: Thursday, March 12, 2009 3:36 AM Subject: RV10-List: Re: Top COMM antenna --> Marcus, based on what I know and what was also mentioned before the com antenna needs to be as much vertical as possible. So how does your installation on the cabin ceiling work then? Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234318#234318 ________________________________________________________________________________
Date: Mar 12, 2009
Subject: Re: Remembrance of Mark Ritter
John- Thanks for the great post. Bill DeRouchey N939SB, flying --- On Wed, 3/11/09, John Cox wrote: From: John Cox <johnwcox(at)pacificnw.com> Subject: RV10-List: Remembrance of Mark Ritter Date: Wednesday, March 11, 2009, 10:17 AM Today is the One year anniversary of Mark Ritter's "Gone West" flight.=C2 - Mark was a valued contributor on this list and we shared several memora ble discussions "offline" over the months and years.=C2- Attached is a pi cture of Mark's Scheme Designer paint job.=C2- Each loss to our group is a painful one, but I reflect on the valued lesson Mark left behind for me. =C2- Friends share observations with friends. As a retired Pilot Examiner, I without fail would include an Oral question for both Private and Commercial applicants from FAR 61.53 and often would q uery the use of "Over the Counter" medications.=C2- Years later the FAA e xpanded our responsibility to include a Task from the Area of Operations in the PTS, of Preflight Preparation.=C2- I would always delve into Aeromed ical Factors.=C2- Applicants knew they would be getting questions on the recognition and remediation on hypoxia and hyperventilation.=C2- Sometime s a distracter to induce potential vertigo would be included. Today, in the Air Carrier Maintenance arena - Human Factors are the big FAA push.=C2- Fatigue/Distractions/Complacency/the list goes on to make up the Dirty Doze n. Mark was not my first friend to be lost to potential medical issues.=C2- Another pilot Bob McCann "Went West" making a similar solo flight in connec tion to that simple "Pilot's Pancake Breakfast" just an hour away.=C2- Th e Search and Rescue effort brought scores of pilots into the mix with the C AP (and a topic I won't go into here).=C2- We each benefit by our candid discussion with friends when we observe something out of the ordinary then do something more than silent observation.=C2- We each carry the financia l cost of increased insurance rates after their passing.=C2- Let's all ho pe that Mark's passing is the beginning of a long and extended period of Sa fe Flights in the RV-10 that are devoid of medical issues. I remember an incident in A&P school where another friend, Alan Johnson (re tired AF crew chief) seemed just a bit unusually stresses over our Bendix P ressure Carb Fuel Metering Class.=C2- I let Alan know repeatedly that he just did not look his Rosey self.=C2- Green and Grey with perspiration we re not typical school colors. Alan reluctantly visited a doctor after class that day.=C2- Seems his smoking, drinking and sedentary lifestyle requir ed an immediate quadruple bypass. Although Alan left that class and the pro gram, the years have passed gently. Today Alan can be found on the ramp of airports in Arizona with his Canon capturing the aircraft he loves. Let's spend a minute, think of Mark and others who have passed and reflect on the value of sharing our observations. I don't have an answer for you on those who pilots who cognitively fly into bad weather or disregard clear and concise information to the contrary in attempting flight with known aircraft problems.=C2- May 2009 and Beyond continue the pattern and that Mark be our last loss.=C2- I know we're are all one day closer. <> John Cox #600 ________________________________________________________________________________
Date: Mar 12, 2009
Does anyone have VSWR values for the do it yourself COM antennas? if you ar e near Prescott stop-bye and I'll measure it for you. - Bill DeRouchey N939SB, flying --- On Thu, 3/12/09, David McNeill wrote: From: David McNeill <dlm46007(at)cox.net> Subject: RE: RV10-List: Re: Top COMM antenna Date: Thursday, March 12, 2009, 5:41 AM Another consideration is the radiation from the antenna. IIRC correctly the intensity varies inversely with the square of the distance between the pilo t and the source. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Wellenzohn Sent: Thursday, March 12, 2009 3:36 AM Subject: RV10-List: Re: Top COMM antenna --> Marcus, based on what I know and what was also mentioned before the com antenna needs to be as much vertical as possible. So how does your installation on the cabin ceiling work then? Michael -------- RV-10 builder (engine, prop, finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234318#234318 ________________________________________________________________________________
Subject: cowl to fuse gap
Date: Mar 13, 2009
My upper and lower cowl halves have been drilled and the hinges are clecoed in place. The upper cowl to fuse gap is right at 1/16" - this seems "too wide". I'm wondering if the gap might grow over time as the parts break in? It would be lots easier to add micro now before riveting the hinges. I left a bit more material on the bottom cowl to allow for final fitting (20-20 hindsight). The horizontal split hinge gaps are about 1/32" as specified in the plans. It's odd how Vans is pretty explicit about the horizontal hinge gaps, but not about the cowl-to-fuse ones. Thanks, Jay #40011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234431#234431 ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Date: Mar 13, 2009
Remember that you will have paint on both sides of the gap. John Testement N311RV -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jayb Sent: Friday, March 13, 2009 11:19 AM Subject: RV10-List: cowl to fuse gap My upper and lower cowl halves have been drilled and the hinges are clecoed in place. The upper cowl to fuse gap is right at 1/16" - this seems "too wide". I'm wondering if the gap might grow over time as the parts break in? It would be lots easier to add micro now before riveting the hinges. I left a bit more material on the bottom cowl to allow for final fitting (20-20 hindsight). The horizontal split hinge gaps are about 1/32" as specified in the plans. It's odd how Vans is pretty explicit about the horizontal hinge gaps, but not about the cowl-to-fuse ones. Thanks, Jay #40011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234431#234431 Checked by AVG - www.avg.com 05:59:00 ________________________________________________________________________________
Subject: Re: Flightline AC system for sale
Date: Mar 13, 2009
The system is sold, thanks for the interest & emails of those who responded. Dave -------- Dave Ford RV6 flying RV10 building Lake City, MI based at CAD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234522#234522 ________________________________________________________________________________
Subject: Re: RV -10 Partner Wanted Final Assembly NJ
Date: Mar 14, 2009
I Have added a couple of Photos. Thanks -------- Frank Dombroski RV-10 N46WD final assembly RV-8 N84FD final assembly N40 Sky Manor Airport Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234550#234550 Attachments: http://forums.matronics.com//files/26jan09_frank_finish_fiberglass_008_194.jpg http://forums.matronics.com//files/30jan09fandj_002_183.jpg http://forums.matronics.com//files/26jan09_frank_finish_fiberglass_001_958.jpg ________________________________________________________________________________
Subject: Repo Man
Date: Mar 14, 2009
In today's NY Times. This is one benefit to pay as you build. Robin http://www.nytimes.com/2009/03/14/business/14repo.html?pagewanted=1&th&e mc=th ________________________________________________________________________________
Subject: Report on cabin cover and rear window install
Date: Mar 14, 2009
The windows are in and the cabin cover is installed ! Last week I asked some questions about installing the rear windows before installing the cabin cover. After the research was done I decided that installing the windows with the cabin cover off the fuselage was the way I would do it. I also built a custom overhead console into the canopy to bring fresh air in from overhead along with some map lighting. My design for the overhead console include no access cover for the door hinges as well as complete integration of the center window strut mounting point. So some important questions had to be answered about this construction technique. Well I am now happy to say that I can answer them. 1) Yes you can bed the nuts and washers for the door hinges in an epoxy/structural filler mix so that the hinges can be mounted blindly. But make sure that you back the screws out shortly after the epoxy cures to ensure you haven't got any epoxy on the screw threads. 2) Yes you can mount the front window strut to the canopy cover and mold it into an overhead console before installing the canopy cover permanently, however you must measure carefully to ensure it is at the proper angle, otherwise it wont go together. 3) In my opinion, putting the windows in with the cabin cover off the fuselage is the way to go. I was able to rotate the cover so gravity did most of the work holding the window in. Additionally, the dripping of weld-on on the inside went straight to the floor and not all over the inside of the window. 4) When putting the cabin cover on I used some wood blocks of various thicknesses sitting of the door sills to progressively low the canopy into place, this allowed me to finesse the front strut into the fuselage mounting hole. This worked like a charm. It also allowed me to put down epoxy/flox mix on the door sill and tank sealant on the rear rivet line with the canopy just 3/4" about its final resting spot, this made handling and fitting a non-event. So here's a link to my web album showing the progress. The last 20 or so pictures shows the details. http://picasaweb.google.com/rcnewman64/FiberglassWork02?feat=directlink Bob Newman #40176 www.tcwtech.com ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: W-1013A aileron hinge brackets warped
Date: Mar 14, 2009
I started work on the rear wing spars today and noticed that the w-1013a aileron hinge brackets are warped. With them lying flat on the table there's 1/16-3/32" gap in the center off the table on all 4 of them. Has anybody else run into this problem. Looks like it might have happened when they were "stamped" out. Obviously I'll wait 'til monday and see what Vans has to say but does anybody else have any thoughts on this. Surely it's not wise to use them like this, or is it??? Anyhow, pictures are attached. Thanks in advance, Bill Britton RV-10 #40137 ________________________________________________________________________________
Subject: Re: W-1013A aileron hinge brackets warped
Date: - - - , 20-
I would say, treat it as the horizontal tabs that stick up from the tailcone, beat on them in a vice with a rubber mallet to straighten them. ----- Original Message ----- From: Bill and Tami Britton To: rv10-list(at)matronics.com Sent: Saturday, March 14, 2009 1:10 PM Subject: RV10-List: W-1013A aileron hinge brackets warped I started work on the rear wing spars today and noticed that the w-1013a aileron hinge brackets are warped. With them lying flat on the table there's 1/16-3/32" gap in the center off the table on all 4 of them. Has anybody else run into this problem. Looks like it might have happened when they were "stamped" out. Obviously I'll wait 'til monday and see what Vans has to say but does anybody else have any thoughts on this. Surely it's not wise to use them like this, or is it??? Anyhow, pictures are attached. Thanks in advance, Bill Britton RV-10 #40137 ________________________________________________________________________________
Date: Mar 14, 2009
I vaguely remember the same issue (I'm kit #40176), I reasonably sure I "flatened" them back out with a little vise and clamp action. -Bob Newman ----- Original Message ----- From: Bill and Tami Britton To: rv10-list(at)matronics.com Sent: Saturday, March 14, 2009 3:10 PM Subject: RV10-List: W-1013A aileron hinge brackets warped I started work on the rear wing spars today and noticed that the w-1013a aileron hinge brackets are warped. With them lying flat on the table there's 1/16-3/32" gap in the center off the table on all 4 of them. Has anybody else run into this problem. Looks like it might have happened when they were "stamped" out. Obviously I'll wait 'til monday and see what Vans has to say but does anybody else have any thoughts on this. Surely it's not wise to use them like this, or is it??? Anyhow, pictures are attached. Thanks in advance, Bill Britton RV-10 #40137 ________________________________________________________________________________
Date: Mar 14, 2009
Mine were like your's, I straightened them. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234600#234600 ________________________________________________________________________________
Date: Mar 14, 2009
Subject: RV-10 emp kit - finished - for sale
I have purchased another kit, so have my completed emp kit for sale. Workmanship is excellent - 1 small ding in one wing from storage hiccup - easy to fill. Save yourself 250 hours by buying this kit already done. Contact me for more details and photos. It's in Berkeley, CA. Asking $4900 or best offer. Simon ________________________________________________________________________________
Subject: Drilling into stainless aileron counterbalance
Date: Mar 15, 2009
I'm wearing out my #40 drill bits pretty quickly trying to drill the #40 holes between the skin and stainless counterbalance. Any hints as to what type of drill bit I should get in order to knock this out quicker would be great. Thanks. Andy Johnson Poquoson, VA ________________________________________________________________________________
Date: Mar 14, 2009
Subject: Re: Drilling into stainless aileron counterbalance
Make sure you're drilling with enough pressure... especially through stainl ess and steel....- going to slow will burn the drill up fast.- Put the pedal to the metal!- Don --- On Sat, 3/14/09, Andrew Johnson wrote: From: Andrew Johnson <noconwud(at)earthlink.net> Subject: RV10-List: Drilling into stainless aileron counterbalance Date: Saturday, March 14, 2009, 10:33 PM I'm wearing out my #40 drill bits pretty quickly trying to drill the #40 ho les between the skin and stainless counterbalance.- Any hints as to what type of drill bit I should get in order to knock this out quicker would be great.- Thanks. Andy Johnson Poquoson, VA le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Mar 15, 2009
Are you using Boelube? I only used it for the s.s. or really thick al. parts. And there is a difference in drill bits, some work better/longer. I haven't tried a bit sharpener yet, might be worth getting, I'm sure someone has and will chime in. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234641#234641 ________________________________________________________________________________
Date: Mar 15, 2009
I have a Drill Doctor and it works really well to sharpen dull bits. There may be others which work as well. Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: "doctornigel" <nschultz3(at)cfl.rr.com> Sent: Sunday, March 15, 2009 4:32 AM Subject: RV10-List: Re: Drilling into stainless aileron counterbalance > > Are you using Boelube? I only used it for the s.s. or really thick al. > parts. And there is a difference in drill bits, some work better/longer. I > haven't tried a bit sharpener yet, might be worth getting, I'm sure > someone has and will chime in. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=234641#234641 > > > ________________________________________________________________________________
Subject: Re: Report on cabin cover and rear window install
Date: Mar 15, 2009
Bob, Great photos! Thanks for sharing. I really like those modified ribs on the sub-panel you made - I did some snooping. Are you a machinist? That's awfully nice work. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=234731#234731 ________________________________________________________________________________
Date: Mar 16, 2009
Drilling stainless steel works best with high bit pressure and low temperature, which requires lubrication and SLOW bit speed and if the piece is thick enough, frequent cooling breaks. Paul Hahn ________________________________________________________________________________
Date: Mar 17, 2009
Subject: 2nd Brake lining replacement
This weekend I replaced my brake linings for the 2nd time. The 1st set lasted 170 hours, the 2nd went about 270. With even more self-discipline I would think I could get over 300, but I wouldn't expect that on your first set, for sure. I also just ordered my replacement spares for the next time around, and decided to add to my original write-up on brake replacement. http://www.myrv10.com/N104CD/maintenance/20061104/index.html Towards the bottom of the page you can find more info I compiled regarding spare brake parts, and an update about Rapco replacement linings. (Basically the aren't making them yet, and may never...or may take a long time if they decide to) Anyway, there is more info there for you all that may help some day. I also re-balanced my tires and found that they had stayed about the same as when I previously balanced them. I just adjusted them very slightly. The new tires are wearing pretty well. At 115 hours or so on these retreads, one tire looks really good. The other has a flat spot that is pilot induced, and is wearing a little heavier on the outside as before. Still a long way from flipping them though, so I'm guessing 300hrs per pair might be about right. -- Tim Olson - RV-10 N104CD - Flying ________________________________________________________________________________
Date: Mar 17, 2009
Subject: Fun with Andair valve and scat tube
I got creative with my fuel line rounting to leave some space under the valve to run the scat tube. See the picture here: http://kochman.net/N819K/wp-content/uploads/2009/03/img_5098.jpg My intent is to run the scat tube by the valve under the valve and rudder cable on the right side (left when looking at the picture). I will likely wrap the scat tube in the heat reflective material to minimize heat around the fuel lines. Note: the fuel line from the valve to filter is not shown in the picture, but goes straight down and thus should not interfere. Anyone see a problem with this? Thanks... -Rob -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com>
Date: Mar 17, 2009
Looks like you've got more room than I do, I planned to make a fiberglass plenum going from one 2" scat to two 1" scat, then another plenum back into 2" on the aft side of the spar.for sure it would be more work, but I wasn't smart enough to turn one of the Andair fittings 90 degrees.mine are both vertical so I have less room to work with unless I go back in and totally replumb. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 17, 2009 9:37 AM Subject: RV10-List: Fun with Andair valve and scat tube I got creative with my fuel line rounting to leave some space under the valve to run the scat tube. See the picture here: http://kochman.net/N819K/wp-content/uploads/2009/03/img_5098.jpg My intent is to run the scat tube by the valve under the valve and rudder cable on the right side (left when looking at the picture). I will likely wrap the scat tube in the heat reflective material to minimize heat around the fuel lines. Note: the fuel line from the valve to filter is not shown in the picture, but goes straight down and thus should not interfere. Anyone see a problem with this? Thanks... -Rob -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: 3 degree reflex
Date: Mar 17, 2009
Can anyone tell me where to find the information in the plans on how to set the 3 degree reflex or is it already set when you have the flaps retracted all the way. I can see no way to move them higher because of the bracket that holds the skin between the wing and the cabin. It also has a stopping point because of the overlapping wing skins. [Question] [Question] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235023#235023 ________________________________________________________________________________
Date: Mar 17, 2009
Yes...All the way up is the reflex position Steve Mills N750SM (reserved) RV-10 40486 Slow-build Eggenfellner E-6TI Naperville, Illinois Finishing kit, engine install -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hsdexo Sent: Tuesday, March 17, 2009 4:21 PM Subject: RV10-List: 3 degree reflex Can anyone tell me where to find the information in the plans on how to set the 3 degree reflex or is it already set when you have the flaps retracted all the way. I can see no way to move them higher because of the bracket that holds the skin between the wing and the cabin. It also has a stopping point because of the overlapping wing skins. [Question] [Question] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235023#235023 ________________________________________________________________________________
Date: Mar 17, 2009
Subject: Re: 3 degree reflex
All the way up is the 3 deg. reflex. Dave hsdexo wrote: > > Can anyone tell me where to find the information in the plans on how to set the 3 degree reflex or is it already set when you have the flaps retracted all the way. I can see no way to move them higher because of the bracket that holds the skin between the wing and the cabin. It also has a stopping point because of the overlapping wing skins. [Question] [Question] > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235023#235023 > > > > > > > > > > > -- Dave Hertner President Effectus AeroProducts Inc. Kit Aircraft Component Manufacturing Machining - Fabrication - Laser/Water-Jet Cutting Blog: http://www.kitaircraftmods.com Email: davehertner@effectus-aeroproducts.com Phone: (519) 933-2055 ________________________________________________________________________________
Date: Mar 17, 2009
Subject: Re: Fun with Andair valve and scat tube
you mean like this? : http://deemsrv10.com/album/Final%20Assembly/slides/DSC07074.html http://deemsrv10.com/album/Final%20Assembly/slides/DSC07075.html http://deemsrv10.com/album/Final%20Assembly/slides/DSC07076.html Deems Davis # 406 'Its all done....finally!!!!! http://deemsrv10.com/ Bob and Karen Brown wrote: > > Looks like youve got more room than I do, I planned to make a > fiberglass plenum going from one 2 scat to two 1 scat, then another > plenum back into 2 on the aft side of the sparfor sure it would be > more work, but I wasnt smart enough to turn one of the Andair > fittings 90 degreesmine are both vertical so I have less room to work > with unless I go back in and totally replumb. > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman > *Sent:* Tuesday, March 17, 2009 9:37 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Fun with Andair valve and scat tube > > I got creative with my fuel line rounting to leave some space under > the valve to run the scat tube. See the picture here: > > http://kochman.net/N819K/wp-content/uploads/2009/03/img_5098.jpg > > My intent is to run the scat tube by the valve under the valve and > rudder cable on the right side (left when looking at the picture). I > will likely wrap the scat tube in the heat reflective material to > minimize heat around the fuel lines. Note: the fuel line from the > valve to filter is not shown in the picture, but goes straight down > and thus should not interfere. > > Anyone see a problem with this? Thanks... > > -Rob > > > -- > Rob Kochman > RV-10 Wings > Woodinville, WA (near Seattle) > http://kochman.net/N819K > > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Mar 18, 2009
Thanks guys for the help. [Laughing] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235090#235090 ________________________________________________________________________________
Subject: Tailcone Question
Date: Mar 18, 2009
I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Date: Mar 18, 2009
I clecoed all of mine together, but left a space for the saw horses all the way around. This way I could sit the tailcone on the saw horses and roll it side-to-side so I could get access to the required area. You may be asking because you don't have a rivet partner and you're trying to shoot and buck at the same time. I managed to get a highly unskilled helper in my wife. She dropped the rivets in the hole and held them (flush side) in position with a bucking bar. I shot them from the backside with a back-rivet set. Looks great and she didn't have to develop any skills shooting or bucking. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Wednesday, March 18, 2009 12:43 PM Subject: RV10-List: Tailcone Question I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Subject: Re: Tailcone Question
Date: - - - , 20-
Thanks for the quick reply, I have done 99.9% of the build on my own so far. My wife is making most of the money so I will get a cheaper helper It's getting to the point where I NEED some more hands! ----- Original Message ----- From: "Perry, Phil" <Phil.Perry(at)netapp.com> Sent: Wednesday, March 18, 2009 12:22 PM Subject: RE: RV10-List: Tailcone Question > > I clecoed all of mine together, but left a space for the saw horses all > the way around. > > This way I could sit the tailcone on the saw horses and roll it > side-to-side so I could get access to the required area. > > You may be asking because you don't have a rivet partner and you're > trying to shoot and buck at the same time. I managed to get a highly > unskilled helper in my wife. She dropped the rivets in the hole and > held them (flush side) in position with a bucking bar. I shot them from > the backside with a back-rivet set. Looks great and she didn't have to > develop any skills shooting or bucking. > > Phil > > > -----Original Message----- > From: Strasnuts [mailto:sean(at)braunandco.com] > Sent: Wednesday, March 18, 2009 12:43 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tailcone Question > > > I am just starting to rivet the tailcone. I need to know if I can start > riveting one side skin and the bottom skin without clecoing (is that > even a word?) the other side skin in place. It seems like I can but > should I? > > > Thanks > > -------- > A&P, ATP > typed CE-525(s), CE-500 > RV-10 emp started!!!! > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235111#235111 > > > ________________________________________________________________________________
Date: Mar 18, 2009
Phil Thanks for letting us know that trick. I am sure my wife can do the same thing, I also have a very large flat steel plate that I use for back riveting and it works great I am sure it will work for this. Thanks again. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Wednesday, March 18, 2009 11:22 AM Subject: RE: RV10-List: Tailcone Question I clecoed all of mine together, but left a space for the saw horses all the way around. This way I could sit the tailcone on the saw horses and roll it side-to-side so I could get access to the required area. You may be asking because you don't have a rivet partner and you're trying to shoot and buck at the same time. I managed to get a highly unskilled helper in my wife. She dropped the rivets in the hole and held them (flush side) in position with a bucking bar. I shot them from the backside with a back-rivet set. Looks great and she didn't have to develop any skills shooting or bucking. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Wednesday, March 18, 2009 12:43 PM Subject: RV10-List: Tailcone Question I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Date: Mar 18, 2009
I did a lot of my tail cone by myself. I made small back rivet table (stacked boards) and left as many clecos in as possible and then just stuck my head in and started riveting. As you start filling rivet holes it gets easier since you don't have as many clecos in to get in the way (hitting the table). I left both side skins on in fear that I would get the bulkheads out of line somehow..... Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Wednesday, March 18, 2009 12:22 PM Subject: RE: RV10-List: Tailcone Question I clecoed all of mine together, but left a space for the saw horses all the way around. This way I could sit the tailcone on the saw horses and roll it side-to-side so I could get access to the required area. You may be asking because you don't have a rivet partner and you're trying to shoot and buck at the same time. I managed to get a highly unskilled helper in my wife. She dropped the rivets in the hole and held them (flush side) in position with a bucking bar. I shot them from the backside with a back-rivet set. Looks great and she didn't have to develop any skills shooting or bucking. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Wednesday, March 18, 2009 12:43 PM Subject: RV10-List: Tailcone Question I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Subject: IO-540 for sale
Date: Mar 18, 2009
Thunderbolt IO-540 engine for sale. Details available upon request. Crated and ready to ship. Email off line or call. Paul Grimstad Portland, Or. 503-849-2123 ________________________________________________________________________________
Date: Mar 18, 2009
Having just been there and done that, I didn't have both side skins on while riveting and everything came out fine. I think the plans start you on the bottom skin IIRC and you really have to have the frames in place with the stiffeners, you won't be able to easily get the frames over the stiffeners once riveted. I put my clecoes on the inside of the skins and did as many rivets as possible by back riveting. This worked great, just be sure there is no gap between the stiffener and skin and that you're solid on the back riveting plate. Once the top skins go on, it really helps to have a ten year old (or petite spouse) to sit inside and buck rivets for you. Someone else mentioned this a while ago and offered their ten year old for rent, luckily I had one available! Hope this helps. Kent #40710 waiting for wing kit >>> "Strasnuts" 3/18/2009 1:43 PM >>> I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Date: Mar 18, 2009
I'd really like to get one of those ten year olds - how much do they cost? In a more serious vein, this is a good time to think about a couple of Adel Clamp mounts in the aft tailcone area while it's easy to get to it. Even if you run conduit back there, you'll need some way to hold the conduit in place - Adel Clamps. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235130#235130 ________________________________________________________________________________
Date: Mar 18, 2009
That is exactly how Mary and I did ours. Worked fantastic and looks great. David Maib 40559 On Mar 18, 2009, at 2:22 PM, Perry, Phil wrote: I clecoed all of mine together, but left a space for the saw horses all the way around. This way I could sit the tailcone on the saw horses and roll it side-to-side so I could get access to the required area. You may be asking because you don't have a rivet partner and you're trying to shoot and buck at the same time. I managed to get a highly unskilled helper in my wife. She dropped the rivets in the hole and held them (flush side) in position with a bucking bar. I shot them from the backside with a back-rivet set. Looks great and she didn't have to develop any skills shooting or bucking. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Wednesday, March 18, 2009 12:43 PM Subject: RV10-List: Tailcone Question I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? Thanks -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235111#235111 ________________________________________________________________________________
Date: Mar 18, 2009
This is an outstanding suggestion, and one which I wish I had thought about before finishing the tailcone. Still won't be too hard to do before the tailcone is mounted to the fuse. I wish Van's had put some suggestions in the plans for doing this. You need some wires for the lights, plus the elevator trim at a minimum, is there anything else (magnetometer etc) that might go back there? Looking at some builders sites (Deem's comes to mind) I found some pictures of what they did that gave me some ideas, but I like the conduit idea best as it should provide the best protection for the wire. On a related note, I wonder if anyone has installed one of these integrated position/strobes in the rudder: http://www.aircraftspruce.com/catalog/elpages/posistrobe.php (manufacturer at http://www.aveoaviationlights.com/) Looks pretty cool, no external HV power supply. Kind of expensive though. I looked at the drawings for the light and measured the flat spot on the rudder fairing, the light is exactly the right size. Maybe that's standard for these lights (e.g. the same as the A625 light that Van's sells)? Kent Ogden #40710 Waiting for wing kit >>> "johngoodman" 3/18/2009 3:28 PM >>> I'd really like to get one of those ten year olds - how much do they cost? In a more serious vein, this is a good time to think about a couple of Adel Clamp mounts in the aft tailcone area while it's easy to get to it. Even if you run conduit back there, you'll need some way to hold the conduit in place - Adel Clamps. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235130#235130 ________________________________________________________________________________
Date: Mar 18, 2009
I built a shelf for my magnetometer, about 1/2 way back in the tailcone (see picture), and it would of been lots easier to do while building the tailcone. Simply mount it on the top longeron, and it will be very close to level. You can the fine-tune the level and direction, when you install the magnetometer. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kent Ogden Sent: Wednesday, March 18, 2009 3:47 PM Subject: RV10-List: Re: Tailcone Question This is an outstanding suggestion, and one which I wish I had thought about before finishing the tailcone. Still won't be too hard to do before the tailcone is mounted to the fuse. I wish Van's had put some suggestions in the plans for doing this. You need some wires for the lights, plus the elevator trim at a minimum, is there anything else (magnetometer etc) that might go back there? Looking at some builders sites (Deem's comes to mind) I found some pictures of what they did that gave me some ideas, but I like the conduit idea best as it should provide the best protection for the wire. On a related note, I wonder if anyone has installed one of these integrated position/strobes in the rudder: http://www.aircraftspruce.com/catalog/elpages/posistrobe.php (manufacturer at http://www.aveoaviationlights.com/) Looks pretty cool, no external HV power supply. Kind of expensive though. I looked at the drawings for the light and measured the flat spot on the rudder fairing, the light is exactly the right size. Maybe that's standard for these lights (e.g. the same as the A625 light that Van's sells)? Kent Ogden #40710 Waiting for wing kit >>> "johngoodman" 3/18/2009 3:28 PM >>> I'd really like to get one of those ten year olds - how much do they cost? In a more serious vein, this is a good time to think about a couple of Adel Clamp mounts in the aft tailcone area while it's easy to get to it. Even if you run conduit back there, you'll need some way to hold the conduit in place - Adel Clamps. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235130#235130 &~2=03 ________________________________________________________________________________
Date: Mar 18, 2009
V29ybGRzIGxhcmdlc3QgZHVuY2UgY2FwLiAgOikNCg0KX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fX18NCg0KRnJvbTogQm9iIGFuZCBLYXJlbiBCcm93biBbbWFpbHRvOmJrYnJvd25AbWlu ZXRmaWJlci5jb21dIA0KU2VudDogV2VkbmVzZGF5LCBNYXJjaCAxOCwgMjAwOSA0OjQ5IFBNDQpU bzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IFRhaWxj b25lIFF1ZXN0aW9uDQoNCg0KDQpXZSBzdG9vZCB0aGUgY29uZSBvbiBlbmQsIHN1cHBvcnRlZCBp dCBoaWdoIGVub3VnaCBJIGNvdWxkIHN0YW5kIG9uIGEgc3Rvb2wuICBJIHN0b29kIGluc2lkZSAo d2l0aCBoZWFyaW5nIHByb3RlY3Rpb24hKSBhbmQgYSByaXZldCBndW4sIG15IHdpZmUgdXNlZCBh IGJ1Y2tpbmcgYmFyIHRvIGJhY2sgcml2ZXQgZnJvbSB0aGUgb3V0c2lkZS4gIFdvcmtlZCBsaWtl IGEgY2hhbXDigKZidXQgZG9u4oCZdCBsb3NlIHlvdXIgYmFsYW5jZSEhDQoNCiANCg0KRG8gbm90 IGFyY2hpdmUNCg0KIA0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFs ZiBPZiBLZW50IE9nZGVuDQpTZW50OiBXZWRuZXNkYXksIE1hcmNoIDE4LCAyMDA5IDExOjU2IEFN DQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFRh aWxjb25lIFF1ZXN0aW9uDQoNCiANCg0KSGF2aW5nIGp1c3QgYmVlbiB0aGVyZSBhbmQgZG9uZSB0 aGF0LCBJIGRpZG4ndCBoYXZlIGJvdGggc2lkZSBza2lucyBvbiB3aGlsZSByaXZldGluZyBhbmQg ZXZlcnl0aGluZyBjYW1lIG91dCBmaW5lLiAgSSB0aGluayB0aGUgcGxhbnMgc3RhcnQgeW91IG9u IHRoZSBib3R0b20gc2tpbiBJSVJDIGFuZCB5b3UgcmVhbGx5IGhhdmUgdG8gaGF2ZSB0aGUgZnJh bWVzIGluIHBsYWNlIHdpdGggdGhlIHN0aWZmZW5lcnMsIHlvdSB3b24ndCBiZSBhYmxlIHRvIGVh c2lseSBnZXQgdGhlIGZyYW1lcyBvdmVyIHRoZSBzdGlmZmVuZXJzIG9uY2Ugcml2ZXRlZC4NCg0K IA0KDQpJIHB1dCBteSBjbGVjb2VzIG9uIHRoZSBpbnNpZGUgb2YgdGhlIHNraW5zIGFuZCBkaWQg YXMgbWFueSByaXZldHMgYXMgcG9zc2libGUgYnkgYmFjayByaXZldGluZy4gIFRoaXMgd29ya2Vk IGdyZWF0LCBqdXN0IGJlIHN1cmUgdGhlcmUgaXMgbm8gZ2FwIGJldHdlZW4gdGhlIHN0aWZmZW5l ciBhbmQgc2tpbiBhbmQgdGhhdCB5b3UncmUgc29saWQgb24gdGhlIGJhY2sgcml2ZXRpbmcgcGxh dGUuDQoNCiANCg0KT25jZSB0aGUgdG9wIHNraW5zIGdvIG9uLCBpdCByZWFsbHkgaGVscHMgdG8g aGF2ZSBhIHRlbiB5ZWFyIG9sZCAob3IgcGV0aXRlIHNwb3VzZSkgdG8gc2l0IGluc2lkZSBhbmQg YnVjayByaXZldHMgZm9yIHlvdS4gIFNvbWVvbmUgZWxzZSBtZW50aW9uZWQgdGhpcyBhIHdoaWxl IGFnbyBhbmQgb2ZmZXJlZCB0aGVpciB0ZW4geWVhciBvbGQgZm9yIHJlbnQsIGx1Y2tpbHkgSSBo YWQgb25lIGF2YWlsYWJsZSENCg0KIA0KDQpIb3BlIHRoaXMgaGVscHMuDQoNCiANCg0KS2VudA0K DQojNDA3MTAgd2FpdGluZyBmb3Igd2luZyBraXQNCg0KPj4+ICJTdHJhc251dHMiIDxzZWFuQGJy YXVuYW5kY28uY29tPiAzLzE4LzIwMDkgMTo0MyBQTSA+Pj4NCi0tPiBSVjEwLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6ICJTdHJhc251dHMiIDxzZWFuQGJyYXVuYW5kY28uY29tPg0KDQpJIGFtIGp1 c3Qgc3RhcnRpbmcgdG8gcml2ZXQgdGhlIHRhaWxjb25lLiAgSSBuZWVkIHRvIGtub3cgaWYgSSBj YW4gc3RhcnQgcml2ZXRpbmcgb25lIHNpZGUgc2tpbiBhbmQgdGhlIGJvdHRvbSBza2luIHdpdGhv dXQgY2xlY29pbmcgKGlzIHRoYXQgZXZlbiBhIHdvcmQ/KSB0aGUgb3RoZXIgc2lkZSBza2luIGlu IHBsYWNlLiAgSXQgc2VlbXMgbGlrZSBJIGNhbiBidXQgc2hvdWxkIEk/DQoNCg0KVGhhbmtzDQoN Ci0tLS0tLS0tDQpBJmFtcDtQLCBBVFANCnR5cGVkIENFLTUyNShzKSwgQ0UtNTAwDQpSVi0xMCBl bXAgc3RhcnRlZCEhISENCk44MDFWUiByZXNlcnZlZA0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMg b25saW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhw P3A9MjM1MTExIzIzNTExMQ0KDQoNCg0KDQoNCg0KDQo9PT09PT09PT09PQ0KUlYxMC1MaXN0IEVt YWlsIEZvcnVtIC0NCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYx MCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj09PT09PT09 PT09DQpic3A7ICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpocmVmPSJodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPT09PT09PT09PT0N CmJzcDsgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpic3A7ICAgICAgICAgICAgICAg ICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0K PT09PT09PT09PT0NCg0KDQoNCg0KwqbCt+KAun7igLDDrcKyLMOeIA0KX19fX19fX19fX19fX19f X19fX19fX19fX19fX19fX18NCg0KZyjigJPFoMOTTcOTR3HConrDgcKuIA0KDQoNCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUg TWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9z aGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNv IGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Mar 18, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
my 2 more cents.... I did as much of the riveting solo as possible. An approx 1'x2'x3/8" back rivet plate made most of that possible. It was all cleco'd together from the beginning Some of the rivets in the top deck required some 2 person riveting. Contrary to most, I found it easiest to teach my mate to operate the gun when back riveting or flush riveting. The bar can be harder to handle and definitely does the damage... and I want to be the one that does the damage. Strasnuts wrote: > > I am just starting to rivet the tailcone. I need to know if I can start riveting one side skin and the bottom skin without clecoing (is that even a word?) the other side skin in place. It seems like I can but should I? > > > Thanks > > -------- > A&P, ATP > typed CE-525(s), CE-500 > RV-10 emp started!!!! > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235111#235111 > > > ________________________________________________________________________________
Subject: Re: Quick Build Factory
Date: Mar 18, 2009
I just called Vans and was told that they just moved the factory, and some law required them to fire the workers and then rehire them, that the same company and people are building the kits and that the end of April/beginning of may is when I should get my kit. I wonder if I call another person if I'll get another story? What is up, I hate to react to something without being able to check it out, I certainly want my QB to be put together by someone who has as much experience as able. Can someone findout for sure? I would go with Slo build if there is a doubt and I could switch. If anyone else hears or calls please post. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235157#235157 ________________________________________________________________________________
Date: Mar 18, 2009
I was given essentially the same story when I placed my QB order about a month ago. However a few days earlier I was told July. It really would be nice to have accurate info, just to plan other work. On Wed, Mar 18, 2009 at 3:16 PM, doctornigel wrote: > > I just called Vans and was told that they just moved the factory, and some law required them to fire the workers and then rehire them, that the same company and people are building the kits and that the end of April/beginning of may is when I should get my kit. I wonder if I call another person if I'll get another story? What is up, I hate to react to something without being able to check it out, I certainly want my QB to be put together by someone who has as much experience as able. Can someone findout for sure? I would go with Slo build if there is a doubt and I could switch. If anyone else hears or calls please post. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235157#235157 > > ________________________________________________________________________________
Date: Mar 18, 2009
I too wish I had built a shelf for my dual magnetometers back then. I built and discarded one I tried to build to hug the very top of the cone after the fuse was all together.. The challenge is figuring out an optimal location relative to all the magnetic fields to be installed later. 1) the elevator trim motor, 2) the pitch trim motor, 3) the strobe power unit (which assume kicks of some field). I Installed my tray further forward in the same bay and biased to the left side of the cone to put it equidistant from the 2 trim motors. Of course, the unit may not be as sensitive as suggested. Somewhere down the line some one will have a documented a serviceable location for the various brands and configs. Steve Mills wrote: > I built a shelf for my magnetometer, about 1/2 way back in the > tailcone (see picture), and it would of been lots easier to do while > building the tailcone. Simply mount it on the top longeron, and it > will be very close to level. You can the fine-tune the level and > direction, when you install the magnetometer. > > ________________________________________________________________________________
Date: Mar 18, 2009
Date: Mar 18, 2009
I would second Rene's recommendation to back rivet the tail cone. I was able to back rivet the entire cone, minus about 6 rivets in the narrowest aft-most portion. A suggestion that I have not seen mentioned before is that I would recommend back riveting the F-1047B-R,L and C stiffeners to the F-1075 skin before clecoing the skin to the bulkheads. It is much easier to do this with the skin flat on your bench. Just leave the rivet holes open where the stiffeners cross the bulkheads. I had some concern that I would not be able to get the stiffeners into the corresponding bulkhead slots, but with a little flexing of the stiffeners it worked out fine. And saved a lot of riveting inside the tail cone. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235187#235187 ________________________________________________________________________________
Date: Mar 18, 2009
I too back riveted almost the entire tail cone and all the side and bottom skins (except for those few...) wherever I can figure out a way to back rivet, I do!! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Wednesday, March 18, 2009 6:30 PM Subject: RV10-List: Re: Tailcone Question I would second Rene's recommendation to back rivet the tail cone. I was able to back rivet the entire cone, minus about 6 rivets in the narrowest aft-most portion. A suggestion that I have not seen mentioned before is that I would recommend back riveting the F-1047B-R,L and C stiffeners to the F-1075 skin before clecoing the skin to the bulkheads. It is much easier to do this with the skin flat on your bench. Just leave the rivet holes open where the stiffeners cross the bulkheads. I had some concern that I would not be able to get the stiffeners into the corresponding bulkhead slots, but with a little flexing of the stiffeners it worked out fine. And saved a lot of riveting inside the tail cone. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235187#235187 ________________________________________________________________________________
Date: Mar 19, 2009
I did the saw horse method, turning the tailcone over and from side-to-side as required. I did as much as I could solo and then recruited my wife to shoot while I bucked. Came out fine. -------- Todd Stovall 728TT (reserved) RV-10 Empacone Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235217#235217 ________________________________________________________________________________
Date: Mar 19, 2009
Subject: Installing SJ RV10 mainwheel pants
Does anyone have pictures of their RV10 SJ mainwheel pant installation? I am getting ready to start instaling a set of SJ RV10 mainwheel pants on my oversize RV6A mains. I have the RV6 wheelpant hardware and want to be sure that the RV10 hardware is not more appropriate. I would also like to see the stock RV10 wheelpant installation dosumentation - if someone is willing (or already has) to scan it for me. Thanks, Ralph ________________________________________________________________________________
Date: Mar 19, 2009
I'm sure the Deems does. If he doesn't have a picture, nobody does. Let me know if you need the url. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, March 19, 2009 10:53 AM Subject: RV10-List: Installing SJ RV10 mainwheel pants Does anyone have pictures of their RV10 SJ mainwheel pant installation? I am getting ready to start instaling a set of SJ RV10 mainwheel pants on my oversize RV6A mains. I have the RV6 wheelpant hardware and want to be sure that the RV10 hardware is not more appropriate. I would also like to see the stock RV10 wheelpant installation dosumentation - if someone is willing (or already has) to scan it for me. Thanks, Ralph ________________________________________________________________________________
Date: Mar 19, 2009
Found his site - I'll poke around there...... Thanks! -----Original Message----- >From: Bob Leffler <rv(at)thelefflers.com> >Sent: Mar 19, 2009 1:20 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants > > >I'm sure the Deems does. If he doesn't have a picture, nobody does. Let me know if you need the url. > >Bob > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Thursday, March 19, 2009 10:53 AM >To: RV10-list >Subject: RV10-List: Installing SJ RV10 mainwheel pants > > >Does anyone have pictures of their RV10 SJ mainwheel pant installation? > >I am getting ready to start instaling a set of SJ RV10 mainwheel pants on my oversize RV6A mains. I have the RV6 wheelpant hardware and want to be sure that the RV10 hardware is not more appropriate. > >I would also like to see the stock RV10 wheelpant installation dosumentation - if someone is willing (or already has) to scan it for me. > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Mar 19, 2009
Just a quibble: two 1" lines will not "maintain the flow volume" of one 2" line, since the cross sectional area varies as the square of the diameter (e.g., two 1" lines provide half the cross sectional area as a single 2" line). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235256#235256 ________________________________________________________________________________
Subject: Re: IO-540 for sale
Date: Mar 19, 2009
I'm interested. Myron Woxof(at)aol.com 602 421-2868 -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235258#235258 ________________________________________________________________________________
Date: Mar 19, 2009
I am not aware of any 10 yet featuring the James Wheel Pant Mod. I would be surprised if Deems or Robin went that route. Let us all know what you find. Barnaby Wainfan of Kitplanes Mag, did a presentation at OSH '08 on how poor the massive, bulbous style is for drag reduction. I was even more enlightened that the leg fairings can create so much loss of speed - I thought they were okay. There was an interesting post that was never resolved (in the archives) on the need for additional rudder trim as a result of the nose fairing trailing edges resting canted off the longitudinal axis in flight. Deems site is a great documentary on the Stock VANS wheel pant install. Good Luck with the performance improvement. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, March 19, 2009 10:53 AM Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants Found his site - I'll poke around there...... Thanks! -----Original Message----- >From: Bob Leffler <rv(at)thelefflers.com> >Sent: Mar 19, 2009 1:20 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants > > >I'm sure the Deems does. If he doesn't have a picture, nobody does. Let me know if you need the url. > >Bob > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Thursday, March 19, 2009 10:53 AM >To: RV10-list >Subject: RV10-List: Installing SJ RV10 mainwheel pants > > >Does anyone have pictures of their RV10 SJ mainwheel pant installation? > >I am getting ready to start instaling a set of SJ RV10 mainwheel pants on my oversize RV6A mains. I have the RV6 wheelpant hardware and want to be sure that the RV10 hardware is not more appropriate. > >I would also like to see the stock RV10 wheelpant installation dosumentation - if someone is willing (or already has) to scan it for me. > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Mar 19, 2009
Um9iaW4gd2VudCB3aXRoIHRoZSBzdGFuZGFyZCB3aGVlbCBwYW50cyBhbGwgYXJvdW5kLiBXZSBk aWQgbW9kaWZ5IHRoZSBub3NlIHdoZWVsIHBhbnQgaW50ZXJzZWN0aW9uIGFmdGVyIHNlZWluZyBz b21lb25lIGVsc2UncyBkZXNpZ24gYXQgT1NILiBJIGhhdmUgbmV2ZXIgbGlrZWQgdGhlIOKAnGZp c2ggaG9va+KAnSBvbiBteSA2QS4gRGlkbuKAmXQgaGF2ZSB0byB3b3JyeSBhYm91dCBpdCBvbiBt eSAtNC4NCg0KIA0KDQogDQoNCiANCg0KUm9iaW4NCg0KRG8gTm90IEFyY2hpdmUNCg0KIA0KDQot LS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29t XSBPbiBCZWhhbGYgT2YgSm9obiBDb3gNClNlbnQ6IFRodXJzZGF5LCBNYXJjaCAxOSwgMjAwOSAx MjoxMCBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSRTogUlYxMC1M aXN0OiBJbnN0YWxsaW5nIFNKIFJWMTAgbWFpbndoZWVsIHBhbnRzDQoNCiANCg0KLS0+IFJWMTAt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkpvaG4gQ294IiA8am9obndjb3hAcGFjaWZpY253LmNv bT4NCg0KIA0KDQpJIGFtIG5vdCBhd2FyZSBvZiBhbnkgMTAgeWV0IGZlYXR1cmluZyB0aGUgSmFt ZXMgV2hlZWwgUGFudCBNb2QuICBJIHdvdWxkIGJlIHN1cnByaXNlZCBpZiBEZWVtcyBvciBSb2Jp biB3ZW50IHRoYXQgcm91dGUuICBMZXQgdXMgYWxsIGtub3cgd2hhdCB5b3UgZmluZC4gIEJhcm5h YnkgV2FpbmZhbiBvZiBLaXRwbGFuZXMgTWFnLCBkaWQgYSBwcmVzZW50YXRpb24gYXQgT1NIICcw OCBvbiBob3cgcG9vciB0aGUgbWFzc2l2ZSwgYnVsYm91cyBzdHlsZSBpcyBmb3IgZHJhZyByZWR1 Y3Rpb24uICBJIHdhcyBldmVuIG1vcmUgZW5saWdodGVuZWQgdGhhdCB0aGUgbGVnIGZhaXJpbmdz IGNhbiBjcmVhdGUgc28gbXVjaCBsb3NzIG9mIHNwZWVkIC0gSSB0aG91Z2h0IHRoZXkgd2VyZSBv a2F5LiAgVGhlcmUgd2FzIGFuIGludGVyZXN0aW5nIHBvc3QgdGhhdCB3YXMgbmV2ZXIgcmVzb2x2 ZWQgKGluIHRoZSBhcmNoaXZlcykgb24gdGhlIG5lZWQgZm9yIGFkZGl0aW9uYWwgcnVkZGVyIHRy aW0gYXMgYSByZXN1bHQgb2YgdGhlIG5vc2UgZmFpcmluZyB0cmFpbGluZyBlZGdlcyByZXN0aW5n IGNhbnRlZCBvZmYgdGhlIGxvbmdpdHVkaW5hbCBheGlzIGluIGZsaWdodC4NCg0KIA0KDQpEZWVt cyBzaXRlIGlzIGEgZ3JlYXQgZG9jdW1lbnRhcnkgb24gdGhlIFN0b2NrIFZBTlMgd2hlZWwgcGFu dCBpbnN0YWxsLiAgR29vZCBMdWNrIHdpdGggdGhlIHBlcmZvcm1hbmNlIGltcHJvdmVtZW50Lg0K DQogDQoNCkpvaG4gQ294DQoNCiANCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0NCg0KRnJv bTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYx MC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgUmFscGggRS4gQ2FwZW4N Cg0KU2VudDogVGh1cnNkYXksIE1hcmNoIDE5LCAyMDA5IDEwOjUzIEFNDQoNClRvOiBydjEwLWxp c3RAbWF0cm9uaWNzLmNvbQ0KDQpTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBJbnN0YWxsaW5nIFNK IFJWMTAgbWFpbndoZWVsIHBhbnRzDQoNCiANCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogIlJhbHBoIEUuIENhcGVuIiA8cmVjYXBlbkBlYXJ0aGxpbmsubmV0Pg0KDQogDQoNCkZv dW5kIGhpcyBzaXRlIC0gSSdsbCBwb2tlIGFyb3VuZCB0aGVyZS4uLi4uLg0KDQogDQoNClRoYW5r cyENCg0KIA0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KDQo+RnJvbTogQm9iIExlZmZs ZXIgPHJ2QHRoZWxlZmZsZXJzLmNvbT4NCg0KPlNlbnQ6IE1hciAxOSwgMjAwOSAxOjIwIFBNDQoN Cj5UbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NCg0KPlN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6 IEluc3RhbGxpbmcgU0ogUlYxMCBtYWlud2hlZWwgcGFudHMNCg0KPiANCg0KPi0tPiBSVjEwLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJCb2IgTGVmZmxlciIgPHJ2QHRoZWxlZmZsZXJzLmNvbT4N Cg0KPiANCg0KPkknbSBzdXJlIHRoZSBEZWVtcyBkb2VzLiAgSWYgaGUgZG9lc24ndCBoYXZlIGEg cGljdHVyZSwgbm9ib2R5IGRvZXMuICBMZXQgbWUga25vdyBpZiB5b3UgbmVlZCB0aGUgdXJsLg0K DQo+IA0KDQo+Qm9iDQoNCj4gDQoNCj4gDQoNCj4tLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0K DQo+RnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3du ZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgUmFscGggRS4g Q2FwZW4NCg0KPlNlbnQ6IFRodXJzZGF5LCBNYXJjaCAxOSwgMjAwOSAxMDo1MyBBTQ0KDQo+VG86 IFJWMTAtbGlzdA0KDQo+U3ViamVjdDogUlYxMC1MaXN0OiBJbnN0YWxsaW5nIFNKIFJWMTAgbWFp bndoZWVsIHBhbnRzDQoNCj4gDQoNCj4tLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAi UmFscGggRS4gQ2FwZW4iIDxyZWNhcGVuQGVhcnRobGluay5uZXQ+DQoNCj4gDQoNCj5Eb2VzIGFu eW9uZSBoYXZlIHBpY3R1cmVzIG9mIHRoZWlyIFJWMTAgU0ogbWFpbndoZWVsIHBhbnQgaW5zdGFs bGF0aW9uPw0KDQo+IA0KDQo+SSBhbSBnZXR0aW5nIHJlYWR5IHRvIHN0YXJ0IGluc3RhbGluZyBh IHNldCBvZiBTSiBSVjEwIG1haW53aGVlbCBwYW50cyBvbiBteSBvdmVyc2l6ZSBSVjZBIG1haW5z LiAgSSBoYXZlIHRoZSBSVjYgd2hlZWxwYW50IGhhcmR3YXJlIGFuZCB3YW50IHRvIGJlIHN1cmUg dGhhdCB0aGUgUlYxMCBoYXJkd2FyZSBpcyBub3QgbW9yZSBhcHByb3ByaWF0ZS4NCg0KPiANCg0K Pkkgd291bGQgYWxzbyBsaWtlIHRvIHNlZSB0aGUgc3RvY2sgUlYxMCB3aGVlbHBhbnQgaW5zdGFs bGF0aW9uIGRvc3VtZW50YXRpb24gLSBpZiBzb21lb25lIGlzIHdpbGxpbmcgKG9yIGFscmVhZHkg aGFzKSB0byBzY2FuIGl0IGZvciBtZS4NCg0KPiANCg0KPlRoYW5rcywNCg0KPlJhbHBoDQoNCj4g DQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoNCj4gDQoN CiANCg0KIA0KDQogDQoNCiANCg0KIA0KDQogDQoNCiANCg0KIA0KDQogDQoNCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8t PSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRoZSBN YXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoNCl8tPSB0aGUgbWFu eSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQpfLT0gQXJj aGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQoNCl8tPSBQ aG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KXy09DQoNCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoN Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0gU2FtZSBn cmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09DQoN Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KXy09DQoNCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoN Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCg0KXy09ICBU aGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCg0KXy09ICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0gICAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQogDQoNCiANCg0K IA0KDQo ________________________________________________________________________________
Date: Mar 19, 2009
We're installing both the James wheel pants, and one of my partners is a fiberglass guru...so we'll see how he does on those. We're also doing a different style of rudder trim, more like what the Lancair uses, in fact, it was built by one of my partners who's built Lancairs (I only helped him with some metal bends). As soon as it's finished (almost!!), I'll see if I'm smart enough to post pics here. It uses a cut out section of the original rudder (with the extrusion in it), that is then reinforced with a Z piece and some other pieces sandwiched together with an extruded hinge section. It definitely looks spiffy, but it has not been for the faint of sheet metal talent. There have been lots of hours involved...and helping a lot was to have a complete working model of the Lancair rudder trim system on the desk while we were building this. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Thursday, March 19, 2009 12:10 PM Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants I am not aware of any 10 yet featuring the James Wheel Pant Mod. I would be surprised if Deems or Robin went that route. Let us all know what you find. Barnaby Wainfan of Kitplanes Mag, did a presentation at OSH '08 on how poor the massive, bulbous style is for drag reduction. I was even more enlightened that the leg fairings can create so much loss of speed - I thought they were okay. There was an interesting post that was never resolved (in the archives) on the need for additional rudder trim as a result of the nose fairing trailing edges resting canted off the longitudinal axis in flight. Deems site is a great documentary on the Stock VANS wheel pant install. Good Luck with the performance improvement. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, March 19, 2009 10:53 AM Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants Found his site - I'll poke around there...... Thanks! -----Original Message----- >From: Bob Leffler <rv(at)thelefflers.com> >Sent: Mar 19, 2009 1:20 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Installing SJ RV10 mainwheel pants > > >I'm sure the Deems does. If he doesn't have a picture, nobody does. Let me know if you need the url. > >Bob > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ralph E. Capen >Sent: Thursday, March 19, 2009 10:53 AM >To: RV10-list >Subject: RV10-List: Installing SJ RV10 mainwheel pants > > >Does anyone have pictures of their RV10 SJ mainwheel pant installation? > >I am getting ready to start instaling a set of SJ RV10 mainwheel pants on my oversize RV6A mains. I have the RV6 wheelpant hardware and want to be sure that the RV10 hardware is not more appropriate. > >I would also like to see the stock RV10 wheelpant installation dosumentation - if someone is willing (or already has) to scan it for me. > >Thanks, >Ralph > > ________________________________________________________________________________
Date: Mar 19, 2009
And a good quibble it is...I know that, but my point was that going from one 2" line to a single 1" line may not provide enough heat...I was just trying to "fit between" the pieces I have and that's why I proposed the idea. I haven't started doing anything on it, still scratching my head... Thanks for the clarity and observation! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Thursday, March 19, 2009 11:53 AM Subject: RV10-List: Re: Fun with Andair valve and scat tube Just a quibble: two 1" lines will not "maintain the flow volume" of one 2" line, since the cross sectional area varies as the square of the diameter (e.g., two 1" lines provide half the cross sectional area as a single 2" line). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235256#235256 ________________________________________________________________________________
Date: Mar 19, 2009
Date: Mar 19, 2009
Subject: Re: Fun with Andair valve and scat tube - amount of air/heat
to cabin? Bob, regarding the amount of heat. .... I've spoken with a couple of builder/fliers that have told me that there is MORE than a sufficient amount of heat supplied into the cabin. One builder went far as to put a reducer in the baffle opening that supplies air to his heat exchangers. This would be a good topic to hear from some other fliers as to their experience. Deems Bob and Karen Brown wrote: > > And a good quibble it is...I know that, but my point was that going from one > 2" line to a single 1" line may not provide enough heat...I was just trying > to "fit between" the pieces I have and that's why I proposed the idea. I > haven't started doing anything on it, still scratching my head... > > Thanks for the clarity and observation! > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Thursday, March 19, 2009 11:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Fun with Andair valve and scat tube > > > Just a quibble: two 1" lines will not "maintain the flow volume" of one 2" > line, since the cross sectional area varies as the square of the diameter > (e.g., two 1" lines provide half the cross sectional area as a single 2" > line). > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235256#235256 > > > ________________________________________________________________________________
Date: Mar 19, 2009
to cabin? > When's > that bird gonna fly? > As soon as the FAA sends me my medical cert. :-) Deems > ________________________________________________________________________________
Subject: Leaning and cruising.
Date: Mar 19, 2009
Another example of using the low power cruise to take advantage of the 30kt tailwind. ________________________________________________________________________________
Date: Mar 19, 2009
Just some pictures of our trip to Branson using the lean function of the GRT EFIS. Fuel flows were in the 9-10 gph range with power percentages between 50-60%. I still haven't determined how fast it goes. The kids voted for Disneyland but as senior voting member I voted to spend in a red state rather than Calieeforneea. While touring the shows with my brother in law, he related that although the Branson area had voted to replace an aging bridge that our grand children will instead pickup the bill whether or not they ever visit Branson. ________________________________________________________________________________
Date: Mar 19, 2009
MAY BE DUPLICATE Just some pictures of our trip to Branson using the lean function of the GRT EFIS. Fuel flows were in the 9-10 gph range with power percentages between 50-60%. I still haven't determined how fast it goes. The kids voted for Disneyland but as senior voting member I voted to spend in a red state rather than Calieeforneea. While touring the shows with my brother in law, he related that although the Branson area had voted to replace an aging bridge that our grand children will instead pickup the bill whether or not they ever visit Branson. ________________________________________________________________________________
Date: Mar 19, 2009
Ok, now I am really confused... Why didn't you want to visit California because of how the state voted? And when you took a family vote only the senior vote counted. How very red state of you... (all in fun) David, my real question is how did you get CHT/EGT's to read on both the Chelton & GRT? Also am I reading that right on the GRT there is a fuel left/right that don't seem to add up to the total. 22/19 (L/R) 45.6 Total. I ask because this is the 3rd or 4th time I noticed this on peoples EMS photo posts. You have to love 9-10 GPH and 169 ground speed. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Thursday, March 19, 2009 5:31 PM Subject: RV10-List: Leaning and cruising Just some pictures of our trip to Branson using the lean function of the GRT EFIS. Fuel flows were in the 9-10 gph range with power percentages between 50-60%. I still haven't determined how fast it goes. The kids voted for Disneyland but as senior voting member I voted to spend in a red state rather than Calieeforneea. While touring the shows with my brother in law, he related that although the Branson area had voted to replace an aging bridge that our grand children will instead pickup the bill whether or not they ever visit Branson. ________________________________________________________________________________
Date: Mar 20, 2009
Subject: Re: Leaning and cruising
David, FYI, most of the numbers look pretty good but, the oil temp appears to be a little low. Oil temps should ideally be in the 175-180 range (to evaporate the condensation from the oil). Some guys who regularly fly (LOP, or in cooler climates) rig a flap (controllable from the cockpit) to limit the airflow across the oil cooler to regulate the oil temperature. ____________________________________________________________ Digital Photography - Click Now. http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTDvmRThqnVQwCwB2PKUED4SPgZIKbuyrPf98QhlHjRrzWhxL9V4Ks/ ________________________________________________________________________________
Date: Mar 20, 2009
Myron, Thanks for your interest. Great engine for the RV-10. Paul Grimstad, 503-849-2123 ----- Original Message ----- From: "woxofswa" <woxof(at)aol.com> Sent: Thursday, March 19, 2009 12:02 PM Subject: RV10-List: Re: IO-540 for sale > > I'm interested. > Myron > Woxof(at)aol.com > 602 421-2868 > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235258#235258 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 19, 2009
Subject: XM Radio
Date: Mar 20, 2009
I was using XM for weather on the trip March 14 to the Midwest. worked fine. ON the return March 19, the system failed to come up after takeoff from the Midwest. I stopped in TX to refresh and it worked again. Does anyone else have these problems? Why does the XM sight provide a self refresh transaction on the net? I am considering cancelling XM and using the Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a safety of flight issue, in that expecting NEXRAD data when encountering adverse weather and being surprised, is not funny. Anybody else have this problem???? ________________________________________________________________________________
Subject: Re: XM Radio
Date: - - - , 20-
Sometimes our citation WSI fails the same way and then I notice they did an upgrade or modification. I have to reboot the system and then it works fine. Sometimes it needs 15 minutes of run time and then reboot. It doesn't start working until the second flight. ----- Original Message ----- From: David McNeill To: rv10-list(at)matronics.com Sent: Friday, March 20, 2009 3:39 PM Subject: RV10-List: XM Radio I was using XM for weather on the trip March 14 to the Midwest. worked fine. ON the return March 19, the system failed to come up after takeoff from the Midwest. I stopped in TX to refresh and it worked again. Does anyone else have these problems? Why does the XM sight provide a self refresh transaction on the net? I am considering cancelling XM and using the Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a safety of flight issue, in that expecting NEXRAD data when encountering adverse weather and being surprised, is not funny. Anybody else have this problem???? ________________________________________________________________________________
Subject: XM Radio
Date: Mar 20, 2009
The problem seems to be with XM where a reboot does not solve the problem. ONLY A STOP AT AN FBO WITH INTERNET CONNECTION AND AN XM REFRESH TRANSACTION WHILE KEYING IN THE RADIO ID.. Is the TIS/FIS going to be any better? Too bad I did not install a STRIKEFINDER.. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano Sent: Friday, March 20, 2009 3:25 PM Subject: Re: RV10-List: XM Radio Sometimes our citation WSI fails the same way and then I notice they did an upgrade or modification. I have to reboot the system and then it works fine. Sometimes it needs 15 minutes of run time and then reboot. It doesn't start working until the second flight. ----- Original Message ----- From: David McNeill <mailto:dlm46007(at)cox.net> Sent: Friday, March 20, 2009 3:39 PM Subject: RV10-List: XM Radio I was using XM for weather on the trip March 14 to the Midwest. worked fine. ON the return March 19, the system failed to come up after takeoff from the Midwest. I stopped in TX to refresh and it worked again. Does anyone else have these problems? Why does the XM sight provide a self refresh transaction on the net? I am considering cancelling XM and using the Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a safety of flight issue, in that expecting NEXRAD data when encountering adverse weather and being surprised, is not funny. Anybody else have this problem???? href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 20, 2009
I have had XM weather for 3 years on my 396 and never have had any issues.... Sent from my iPhone On Mar 20, 2009, at 7:00 PM, "David McNeill" wrote: > The problem seems to be with XM where a reboot does not solve the > problem. ONLY A STOP AT AN FBO WITH INTERNET CONNECTION AND AN XM > REFRESH TRANSACTION WHILE KEYING IN THE RADIO ID.. Is the TIS/FIS > going to be any better? Too bad I did not install a STRIKEFINDER.. > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Seano > Sent: Friday, March 20, 2009 3:25 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: XM Radio > > Sometimes our citation WSI fails the same way and then I notice they > did an upgrade or modification. I have to reboot the system and > then it works fine. Sometimes it needs 15 minutes of run time and > then reboot. It doesn't start working until the second flight. > ----- Original Message ----- > From: David McNeill > To: rv10-list(at)matronics.com > Sent: Friday, March 20, 2009 3:39 PM > Subject: RV10-List: XM Radio > > I was using XM for weather on the trip March 14 to the Midwest. > worked fine. ON the return March 19, the system failed to come up > after takeoff from the Midwest. I stopped in TX to refresh and it > worked again. Does anyone else have these problems? Why does the XM > sight provide a self refresh transaction on the net? I am > considering cancelling XM and using the Navworx box on the Chelton > to get TIS and FIS info... I told XM that it is a safety of flight > issue, in that expecting NEXRAD data when encountering adverse > weather and being surprised, is not funny. Anybody else have this > problem???? > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Date: Mar 20, 2009
SGFkIGV4YWN0bHkgdGhlIHNhbWUgcHJvYmxlbSBvbiBleGFjdGx5IHRoZSBzYW1lIGRhdGUuIChB ZnRlcm5vb24gaWYgSSByZWNhbGwgY29ycmVjdGx5KQ0KDQpBIHJlYm9vdCBmaXhlZCBpdCBmb3Ig bWUgdGhvdWdoLiANCg0KUGhpbA0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X18NCg0KRnJvbTogRGF2aWQgTWNOZWlsbCANClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSAN ClNlbnQ6IEZyaSBNYXIgMjAgMTQ6Mzk6MjcgMjAwOQ0KU3ViamVjdDogUlYxMC1MaXN0OiBYTSBS YWRpbyANCg0KDQpJIHdhcyB1c2luZyBYTSBmb3Igd2VhdGhlciBvbiB0aGUgdHJpcCBNYXJjaCAx NCB0byB0aGUgTWlkd2VzdC4gd29ya2VkIGZpbmUuIE9OIHRoZSByZXR1cm4gTWFyY2ggMTksIHRo ZSBzeXN0ZW0gZmFpbGVkIHRvIGNvbWUgdXAgYWZ0ZXIgdGFrZW9mZiBmcm9tIHRoZSBNaWR3ZXN0 LiBJIHN0b3BwZWQgaW4gVFggdG8gcmVmcmVzaCBhbmQgaXQgd29ya2VkIGFnYWluLiBEb2VzIGFu eW9uZSBlbHNlIGhhdmUgdGhlc2UgcHJvYmxlbXM/IFdoeSBkb2VzIHRoZSBYTSBzaWdodCBwcm92 aWRlIGEgc2VsZiByZWZyZXNoIHRyYW5zYWN0aW9uIG9uIHRoZSBuZXQ/IEkgYW0gY29uc2lkZXJp bmcgY2FuY2VsbGluZyBYTSBhbmQgdXNpbmcgdGhlIE5hdndvcnggYm94IG9uIHRoZSBDaGVsdG9u IHRvIGdldCBUSVMgYW5kIEZJUyBpbmZvLi4uIEkgdG9sZCBYTSB0aGF0IGl0IGlzIGEgc2FmZXR5 IG9mIGZsaWdodCBpc3N1ZSwgaW4gdGhhdCBleHBlY3RpbmcgTkVYUkFEIGRhdGEgd2hlbiBlbmNv dW50ZXJpbmcgYWR2ZXJzZSB3ZWF0aGVyIGFuZCBiZWluZyBzdXJwcmlzZWQsIGlzIG5vdCBmdW5u eS4gQW55Ym9keSBlbHNlIGhhdmUgdGhpcyBwcm9ibGVtPz8/Pw0KDQoNCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmlj cyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0 aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNo ICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFu ZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlv biBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0K Xy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWlu Lg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCg0K ________________________________________________________________________________
Subject: Gear leg faring hinges
Date: Mar 20, 2009
The manual doesn't state which hinge material to use on the gear legs. I have my hinges installed on the firewall for the cowl to fuse junction=2C but I have not done the cowl halves yet. I have (three=2C 3 footers) steel .063 steel hinges remaining and (three=2C 6 footers) aluminum hinges left. Whats what??? Thanks=2C John G. NO Not archive ________________________________________________________________________________
Subject: Section 11
Date: Mar 20, 2009
Just wondering if I should attach the horizontal and vertical or wait until the plane is closer to being finished. Also should I wait for the fiberglass tips too. I just finished my tailcone and my wing is already here. I would think Van's would put it off until the end if it was more convenient. -------- A&P, ATP typed CE-525(s), CE-500 RV-10 emp started!!!! N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235463#235463 ________________________________________________________________________________
Date: Mar 20, 2009
Is this on the AV-300's, the new receivers that you see these problems? My old AV-100 was fairly spotty, but my AV-300 has been flawless. Also, with WSI, once you're activated you don't have to go to any website to refresh. Some people may remember that last year I flew the NavWorx system on my Chelton. It worked for both Wx and TIS-B right out of the box. The only problem is that FIS-B (ADS-B Weather) doesn't have great coverage all over the US yet. Shortly I will be testing the box again to provide only traffic, so that I can maintain my WSI for Wx yet get both TIS-A and TIS-B traffic. If that works, I'll be all set and will just use it that way until FIS-B coverage is all over the US. You can cover so many miles in an RV-10 in a day that having only scattered regions where Wx is available wouldn't be any fun. Tim Seano wrote: > Sometimes our citation WSI fails the same way and then I notice they did > an upgrade or modification. I have to reboot the system and then it > works fine. Sometimes it needs 15 minutes of run time and then reboot. > It doesn't start working until the second flight. > > ----- Original Message ----- > *From:* David McNeill > *To:* rv10-list(at)matronics.com > *Sent:* Friday, March 20, 2009 3:39 PM > *Subject:* RV10-List: XM Radio > > I was using XM for weather on the trip March 14 to the Midwest. > worked fine. ON the return March 19, the system failed to come up > after takeoff from the Midwest. I stopped in TX to refresh and it > worked again. Does anyone else have these problems? Why does the XM > sight provide a self refresh transaction on the net? I am > considering cancelling XM and using the Navworx box on the Chelton > to get TIS and FIS info... I told XM that it is a safety of flight > issue, in that expecting NEXRAD data when encountering adverse > weather and being surprised, is not funny. Anybody else have this > problem???? > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Subject: Re: Section 11
Date: Mar 20, 2009
numerous ways to look at this. What I did was "built" the vertical and horizontal but did not match drill the fiberglass parts. Now that I am at the finishing kit about to put the gear on, I went back and finished off the fiberglass pieces with the added experience of the canopy and doors. With that said here are the ways to look at this 1) if you have time waiting for the next kit and you're ready to do it, finish off all but riveting on the fiberglass. 2) If you have the next kit and are ready to keep going, come back to it later , if it's in a garage do it before raising the fusellage up on the gear 3) You can do it at the hangar when all is done and you are finishing up everything As far as convenient, you need to decide how accessible everything is now- if you can readily work on the parts on a bench that would work, having it on the fusellage worked better for me, height wise, having it on the gear would have had it higher and been more difficult to reach as I did while it was lower, plus at the end of the build I didn't see wanting to have to get this done, one main reason is the fiberglass requires some work to make it fit the way I want it and waiting for flox, plys, etc to cure is not something I wanted to do at a airport that is 1 hour away from me. I have seen and talked to numerous builders each did section 11 and 12 at different times, it really doesn't matter, do it when it's best for you. Pascal #40720 -------------------------------------------------- From: "Strasnuts" <sean(at)braunandco.com> Sent: Friday, March 20, 2009 6:59 PM Subject: RV10-List: Section 11 > > Just wondering if I should attach the horizontal and vertical or wait > until the plane is closer to being finished. Also should I wait for the > fiberglass tips too. I just finished my tailcone and my wing is already > here. I would think Van's would put it off until the end if it was more > convenient. > > -------- > A&P, ATP > typed CE-525(s), CE-500 > RV-10 emp started!!!! > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235463#235463 > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Mar 21, 2009
Subject: XM Radio
I think the key in all this is it has nothing to do with the transmission but in how the receiving equipment is acting. If you are going in and essentially sending a reactivation signal, your equipment is probably the issue and not the XM signal. This is equivalent to blaming a web site provider for not being accessible if your ISP is down. I believe that Sirius/XM occasionally reauthorizes receives but the receiver shouldn't time out before receives a new authorization assuming it's used with some regularity. Either way I would complain to your hardware manufacturer first. My $0.02 Michael > > ----- Original Message ----- > *From:* David McNeill > *To:* rv10-list(at)matronics.com > *Sent:* Friday, March 20, 2009 3:39 PM > *Subject:* RV10-List: XM Radio > > I was using XM for weather on the trip March 14 to the Midwest. > worked fine. ON the return March 19, the system failed to come up > after takeoff from the Midwest. I stopped in TX to refresh and it > worked again. Does anyone else have these problems? Why does the XM > sight provide a self refresh transaction on the net? I am > considering cancelling XM and using the Navworx box on the Chelton > to get TIS and FIS info... I told XM that it is a safety of flight > issue, in that expecting NEXRAD data when encountering adverse > weather and being surprised, is not funny. Anybody else have this > problem???? > ________________________________________________________________________________
Date: Mar 21, 2009
When I was flying for a living, we had numerous instances where WSI would not refresh and we had to call WSI and have them do some kind of reboot. Then we would have to wait a half hour or so. This is NOT the case with the WSI I have in my RV with the AV-350. It has been flawless since initializing back in October. Don't know what the difference is, but I am pleased with the service. I am following Tim's work with the NavWorx system. Sounds pretty cool. David Maib 40559 On Mar 20, 2009, at 11:09 PM, Tim Olson wrote: Is this on the AV-300's, the new receivers that you see these problems? My old AV-100 was fairly spotty, but my AV-300 has been flawless. Also, with WSI, once you're activated you don't have to go to any website to refresh. Some people may remember that last year I flew the NavWorx system on my Chelton. It worked for both Wx and TIS-B right out of the box. The only problem is that FIS-B (ADS-B Weather) doesn't have great coverage all over the US yet. Shortly I will be testing the box again to provide only traffic, so that I can maintain my WSI for Wx yet get both TIS-A and TIS-B traffic. If that works, I'll be all set and will just use it that way until FIS-B coverage is all over the US. You can cover so many miles in an RV-10 in a day that having only scattered regions where Wx is available wouldn't be any fun. Tim Seano wrote: > Sometimes our citation WSI fails the same way and then I notice > they did an upgrade or modification. I have to reboot the system > and then it works fine. Sometimes it needs 15 minutes of run time > and then reboot. It doesn't start working until the second flight. > ----- Original Message ----- > *From:* David McNeill > *To:* rv10-list(at)matronics.com > *Sent:* Friday, March 20, 2009 3:39 PM > *Subject:* RV10-List: XM Radio > I was using XM for weather on the trip March 14 to the Midwest. > worked fine. ON the return March 19, the system failed to come up > after takeoff from the Midwest. I stopped in TX to refresh and it > worked again. Does anyone else have these problems? Why does > the XM > sight provide a self refresh transaction on the net? I am > considering cancelling XM and using the Navworx box on the Chelton > to get TIS and FIS info... I told XM that it is a safety of flight > issue, in that expecting NEXRAD data when encountering adverse > weather and being surprised, is not funny. Anybody else have this > problem???? > * > href="http://www.matronics.com/Navigator?RV10-List">http:// > www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > * > * > * ________________________________________________________________________________
Subject: XM Radio
Date: Mar 21, 2009
If that is the case then the XM reauthorization should retry as the aircraft hardware is not ON 90+% of the time. Other XM receivers i.e. car radios have considerably more ON time than aircraft weather systems even though mine is ON whenever I am flying. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Saturday, March 21, 2009 4:59 AM Subject: RE: RV10-List: XM Radio --> I think the key in all this is it has nothing to do with the transmission but in how the receiving equipment is acting. If you are going in and essentially sending a reactivation signal, your equipment is probably the issue and not the XM signal. This is equivalent to blaming a web site provider for not being accessible if your ISP is down. I believe that Sirius/XM occasionally reauthorizes receives but the receiver shouldn't time out before receives a new authorization assuming it's used with some regularity. Either way I would complain to your hardware manufacturer first. My $0.02 Michael > > ----- Original Message ----- > *From:* David McNeill > *To:* rv10-list(at)matronics.com > *Sent:* Friday, March 20, 2009 3:39 PM > *Subject:* RV10-List: XM Radio > > I was using XM for weather on the trip March 14 to the Midwest. > worked fine. ON the return March 19, the system failed to come up > after takeoff from the Midwest. I stopped in TX to refresh and it > worked again. Does anyone else have these problems? Why does the XM > sight provide a self refresh transaction on the net? I am > considering cancelling XM and using the Navworx box on the Chelton > to get TIS and FIS info... I told XM that it is a safety of flight > issue, in that expecting NEXRAD data when encountering adverse > weather and being surprised, is not funny. Anybody else have this > problem???? > ________________________________________________________________________________
Subject: Composite Class for RV-10s May 9-10 2009
Date: Mar 21, 2009
AirCrafters will be holding our "Composites for RV-10s" class again May 9 & 10 (Saturday and Sunday), 2009. More information is available here: http://www.aircraftersllc.com/seminars.htm We will cover all of the composite parts, including the fitting of a cabin top. The class consists of equal parts lecture and hands-on work. Wear old clothes! Although the cabin top and doors are specific to RV-10s, the class is a good primer for any aircraft-related composite work. Please email or call if you would like us to fit your top during the class--no charge! (This will be our fifth top fitting) Again, rides will be available in our RV-10, weather permitting. Class size is limited to 15 builders. Cost is $350. We get a lot of very positive feedback, so sign up early! Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: - - - , 20-
Thanks Pascal, That is the info I needed. ----- Original Message ----- From: "pascal" <pascal(at)rv10builder.net> Sent: Friday, March 20, 2009 11:51 PM Subject: Re: RV10-List: Section 11 > > numerous ways to look at this. > What I did was "built" the vertical and horizontal but did not match drill > the fiberglass parts. Now that I am at the finishing kit about to put the > gear on, I went back and finished off the fiberglass pieces with the added > experience of the canopy and doors. > With that said here are the ways to look at this > 1) if you have time waiting for the next kit and you're ready to do it, > finish off all but riveting on the fiberglass. > 2) If you have the next kit and are ready to keep going, come back to it > later , if it's in a garage do it before raising the fusellage up on the > gear > 3) You can do it at the hangar when all is done and you are finishing up > everything > > As far as convenient, you need to decide how accessible everything is now- > if you can readily work on the parts on a bench that would work, having it > on the fusellage worked better for me, height wise, having it on the gear > would have had it higher and been more difficult to reach as I did while > it was lower, plus at the end of the build I didn't see wanting to have to > get this done, one main reason is the fiberglass requires some work to > make it fit the way I want it and waiting for flox, plys, etc to cure is > not something I wanted to do at a airport that is 1 hour away from me. > I have seen and talked to numerous builders each did section 11 and 12 at > different times, it really doesn't matter, do it when it's best for you. > Pascal > #40720 > > -------------------------------------------------- > From: "Strasnuts" <sean(at)braunandco.com> > Sent: Friday, March 20, 2009 6:59 PM > To: > Subject: RV10-List: Section 11 > >> >> Just wondering if I should attach the horizontal and vertical or wait >> until the plane is closer to being finished. Also should I wait for the >> fiberglass tips too. I just finished my tailcone and my wing is already >> here. I would think Van's would put it off until the end if it was more >> convenient. >> >> -------- >> A&P, ATP >> typed CE-525(s), CE-500 >> RV-10 emp started!!!! >> N801VR reserved >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=235463#235463 >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Gear leg faring hinges
Date: Mar 21, 2009
John, I just finished my landing gear fairings last week. I used the 3 foot sections. Haven't started on the cowling yet but it looks to me like that is where I'd used the 6 foot sections. Tom H. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235575#235575 ________________________________________________________________________________
Date: Mar 21, 2009
The problem you describe is an XM chip issue. If the XM doesn't see a satellite for a while it drops the connection to stop theft. This was set up long before weather when it was basically a radio only service. It happens with the cheap XM and the 'certified' XM like I have in my RV. Real pain in the but ... however the refresh only takes seconds .. especially if you're airborne with you request it. I've never seen it stop working in flight .. it's always after the aircraft has been hangered for a while. As I understand it there is really no fix for it, although the weather folks have been talking for some time that there may be a way. David W. Schaefer RV-6A N142DS "Nerdgasm" TMX-IO360 Dual-LightSpeed Plasma IIIs, Hartzell Blended Airfoil, GRT EFIS www.n142ds.com On Fri, Mar 20, 2009 at 4:39 PM, David McNeill wrote: > I was using XM for weather on the trip March 14 to the Midwest. worked > fine. ON the return March 19, the system failed to come up after takeoff > from the Midwest. I stopped in TX to refresh and it worked again. Does > anyone else have these problems? Why does the XM sight provide a self > refresh transaction on the net? I am considering cancelling XM and using the > Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a > safety of flight issue, in that expecting NEXRAD data when encountering > adverse weather and being surprised, is not funny. Anybody else have this > problem???? > > * > > * > > ________________________________________________________________________________
Date: Mar 21, 2009
Just finished the cowling and it takes a hinge 39" long for the sides . So 36" must be for the legs. I did not realize that hinges were used on the leg fairings, hope I still have hinges left, haven't checked inventory box lately. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235581#235581 ________________________________________________________________________________
Subject: Wind screen fairing
Date: Mar 22, 2009
An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Subject: Re: Vans RV-10 Parking Brake kit
Date: Mar 21, 2009
wcurtis(at)nerv10.com wrote: > Can someone tell me what is in this kit that they are charging $179? > > William > http://nerv10.com/ If you're like me - devastated and losing sleep because I forgot about the parking brake until after I had already installed the complete brake system according to the plans - the David Ward adapter kit from Van's is FANTASTIC!. Simply drill out eight rivets (i.e. remove the bracket that mounts the AN brake fittings to the firewall) and rivet this beautifully machined anodized bracket in the same holes. No drilling through stainless steel. All countersinking already done and nutplates already installed. It comes with all the right fittings and hardware with no trial and error, and no research required, and no modification to my brake lines that I proudly fabricated exactly per plans. Well worth the price IMHO. I did miss out on the satisfaction of solving the parking brake challenge on my own. Kudos to David Ward, whoever and where ever you are! -------- Chase Snodgrass Presidio, Texas www.flybigbend.com Simultaneous RV-10 twins under construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235594#235594 ________________________________________________________________________________
Subject: Vetterman Exhaust system - Page FF6-2 frm 2007
Date: Mar 22, 2009
After twenty months I finally opened my box of exhaust parts and -oppps - it does not match the drawing on pg FF6-2................. My Vetterman exhaust manifold has two tail pipes instead of the two manifolds combining into one tailpipe. Is this the new program for the IO540 engine????? Is there a replacement Pg FF6-2 etc that shows the install of this two pipe system? - Anybody with info or pics???? -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235596#235596 ________________________________________________________________________________
Subject: Sony e-reader and ifr charts
Date: Mar 22, 2009
There was a mention of Sony ereader and PDF Approach Plates a while ago which sparked my interest. I fly a few times a year from SE Florida to New Mexico and carry a suitcase full of approach plates. My favorites are Florida which is so thick that you cannot fold it over and Texas, with three books in all. If you do not know where your destination is (geographically in Texas) on the chart you do not know which book to open to find the plate. I bought the ereader 505 for $ 269, including shipping, form Amazon with generous return policy. After downloading the entire US charts from http://readerplates.com ($10, no subscription required), I found that while magnify the plate, the orientation of the plate changes from portrait to landscape. This requires turning the reader 90 degrees to view the chart. Although I can read the chart without magnifying it, I found this to be a disadvantage. I solved the problem as shown in the following pics ( I hope that I have not clogged someone's download files with these pics). First picture shows an aluminum plate with couple of heavy duty velcro strips (they are about 3/16" thick), a hole I drilled and counter-sunk in the plate and the knee pad, the ereader and a plastic coffee can lid that provides the friction. Friction mechanism, courtesy of my smarter friends. The second and the third pictures how they assemble. The forth picture shows the velcro on the back of ereader. I placed it based on my needs. You may place it anywhere you think will work for you. Also, the screw holding the assembly has to be cut very short with a low profile lock washer to fit under the ereader. The next pictures show the different orientations. With the push of one button and flip of a finger, the ereader goes into landscape magnification mode. I flew an approach yesterday and believe that this is a good alternative to carrying a lot of charts short of upgrading my now three year old (outdated!) equipment. I plan to print the plates for my destination and the alternate from AOPA site and carry the ereader for unexpected diversion. The folks at readerplates.com are very responsive. The organization, the magnification and navigation of the plates are easy and logical. I am sure people with machine shops and smarter folks can come up with better solution. IMG_2079.JPG IMG_2080.JPG IMG_2081.JPG IMG_2082.JPG IMG_2083.JPG IMG_2084.JPG ________________________________________________________________________________
Subject: Re: Wind screen fairing
Date: Mar 22, 2009
I glassed mine, and would do so again. It seems to me that it would be at least as much work, if not more, to trim the metal fairing to a good fit. I would make one change from Van's instructions. If you make all pieces of your layup full length it is going to be pretty thick at the door opening, and will be difficult to get a smooth transition to the door. I have seen several -10s with a noticeable bulge in this area. I made the first 4 layers of my layup full length, then cut each additional layer 1" shorter than the previous layer on each end. No bulge. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235666#235666 ________________________________________________________________________________
Date: Mar 22, 2009
Piece of cake. Follow Van's instructions to the letter and it's easy...just takes time, that's all (two days?). And the transition from top to plexy will be smoooooth as glass (pun intended). This is my second. Built a 'nine' too. Chuck From: Dave Leikam Sent: Saturday, March 21, 2009 10:06 PM Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Date: Mar 22, 2009
This was asked a while ago by william and he was asking how it can justify so much money when one can do the same thing for far less. No disagreement that a parking brake is needed, and doing it oneself can be accomplished for far less without major work. Pascal -------------------------------------------------- From: "westexflyboy" <airplanedriver(at)gmail.com> Sent: Saturday, March 21, 2009 10:59 PM Subject: RV10-List: Re: Vans RV-10 Parking Brake kit > > > wcurtis(at)nerv10.com wrote: >> Can someone tell me what is in this kit that they are charging $179? >> >> William >> http://nerv10.com/ > > > If you're like me - devastated and losing sleep because I forgot about the > parking brake until after I had already installed the complete brake > system according to the plans - the David Ward adapter kit from Van's is > FANTASTIC!. Simply drill out eight rivets (i.e. remove the bracket that > mounts the AN brake fittings to the firewall) and rivet this beautifully > machined anodized bracket in the same holes. No drilling through > stainless steel. All countersinking already done and nutplates already > installed. It comes with all the right fittings and hardware with no > trial and error, and no research required, and no modification to my brake > lines that I proudly fabricated exactly per plans. Well worth the price > IMHO. I did miss out on the satisfaction of solving the parking brake > challenge on my own. > > Kudos to David Ward, whoever and where ever you are! > > -------- > Chase Snodgrass > Presidio, Texas > www.flybigbend.com > Simultaneous RV-10 twins under construction > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235594#235594 > > > ________________________________________________________________________________
Date: Mar 22, 2009
Subject: Re: Vetterman Exhaust system - Page FF6-2 frm 2007
Mike, the brackets that support the exhaust to the motor mount are really w impy... I think I made up an extra set out of stainless.- Plus they need to be bent upward to support the exhaust properly. Don McDonald- #40636 Airworthiness inspection on Monday! --- On Sun, 3/22/09, AirMike wrote: From: AirMike <Mikeabel(at)Pacbell.net> Subject: RV10-List: Vetterman Exhaust system - Page FF6-2 frm 2007 Date: Sunday, March 22, 2009, 12:33 AM After twenty months I finally opened my box of exhaust parts and -oppps - i t does not match the drawing on pg FF6-2................. My Vetterman exhaust manifold has two tail pipes instead of the two manifol ds combining into one tailpipe. Is this the new program for the IO540 engin e????? Is there a replacement Pg FF6-2 etc that shows the install of this two pipe system? -- Anybody with info or pics???? -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235596#235596 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Subject: Exhaust system torque values - etc - Vetterman 2 stack
Date: Mar 22, 2009
The info is pretty slim on the installation of the Vetterman dual stack system. Vans plans say to torque the exhaust nuts to 100-140 in/lbs Vetterman's sheet says to torque the nuts to 140-180 in/lbs Any idea which is preferred????? Also Vans says to use anti-seize on the nuts. Any suggestions for what this product is ..........??????? -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235672#235672 ________________________________________________________________________________
Date: Mar 22, 2009
I would have considered the mlskunkworks fairing but it was not available when I did my windscreen. It seems like it would save some work on the front end and might be pretty nice in the event you ever have to remove your windshield. David Maib 40559 On Mar 22, 2009, at 1:22 PM, Chuck Weyant wrote: Piece of cake. Follow Van's instructions to the letter and it's easy...just takes time, that's all (two days?). And the transition from top to plexy will be smoooooth as glass (pun intended). This is my second. Built a 'nine' too. Chuck From: Dave Leikam Sent: Saturday, March 21, 2009 10:06 PM Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http:// www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 22, 2009
I am not asking as much from the standpoint of difficulty, as I am asking for functionality regarding cracking and potential windshield removal issues later. Thanks for the replies so far! Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Chuck Weyant To: rv10-list(at)matronics.com Sent: Sunday, March 22, 2009 12:22 PM Subject: Re: RV10-List: Wind screen fairing Piece of cake. Follow Van's instructions to the letter and it's easy...just takes time, that's all (two days?). And the transition from top to plexy will be smoooooth as glass (pun intended). This is my second. Built a 'nine' too. Chuck From: Dave Leikam Sent: Saturday, March 21, 2009 10:06 PM To: RV-10 matronics Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 22, 2009
Thanks - Tim - John - Don for the help - the pictures really help -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235699#235699 ________________________________________________________________________________
Date: Mar 22, 2009
For those of us cheapskates - you can do it youself. Maybe not as elegant as the Ward kit , but still effective and cheeeeeeaaap http://forums.matronics.com/viewtopic.php?t=41575&highlight=matco See my post of 3/31/08 -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235700#235700 ________________________________________________________________________________
Subject: Re: Exhaust system torque values - etc - Vetterman 2 stack
Date: Mar 22, 2009
Antiseize keeps the nuts from becoming permanently corroded to the exhaust studs. Look at Permatex 133A and similar products. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235712#235712 ________________________________________________________________________________
Subject: Nav/Strobe Lights
Date: Mar 22, 2009
I'm starting to shop for Nav/Strobe lights and these Aveoflash units sold by Spruce seem interesting. Does anyone have any experience with these? Is there something else out there that is a sure bet? Jeff Carpenter 40304 http://www.aircraftspruce.com/catalog/elpages/aveoFlash.php ________________________________________________________________________________
Date: Mar 22, 2009
I'm interested in this as well. One of the areas that's been a concern for me is replacing the windshield. I recently replaced the windshield on my Cherokee, which was a pretty straightforward job and didn't really mess up the paint job. At some point in time, I imagine that the RV-10 windshield will need to be replaced due to cracks, scratches, or crazing. It make take 10-20 years for the windshield to get that bad, but I think it's just a question of time. It would be nice to talk to any RV-10 builder that has installed these fairings to get their opinion. Has anyone asked M L Blue Skunk for reference RV-10 builder's names? bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Sunday, March 22, 2009 2:56 PM Subject: Re: RV10-List: Wind screen fairing I am not asking as much from the standpoint of difficulty, as I am asking for functionality regarding cracking and potential windshield removal issues later. Thanks for the replies so far! Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Chuck Weyant <mailto:chuck(at)chuckdirect.com> Sent: Sunday, March 22, 2009 12:22 PM Subject: Re: RV10-List: Wind screen fairing Piece of cake. Follow Van's instructions to the letter and it's easy...just takes time, that's all (two days?). And the transition from top to plexy will be smoooooth as glass (pun intended). This is my second. Built a 'nine' too. Chuck From: Dave Leikam <mailto:daveleikam(at)wi.rr.com> Sent: Saturday, March 21, 2009 10:06 PM Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: Aileron pushrod holes
Date: Mar 22, 2009
Today I started working on the rear wing spars. The instructions show a "squared" hole to be cut into the W-1007D doubler plate however the hole in my rear spar is actually a "teardrop" shape. Am I to modify the hole in the spar or simply copy the shape in the spar? A picture is attached. Also, the doubler plates overhang the slot cut into the spar (slot is for the flap brackets I assume) just a little. Do I need to trim the doubler plates to the slot in the spar?? Another picture is attached. ________________________________________________________________________________
Subject: Re: Nav/Strobe Lights
Date: Mar 22, 2009
Yeah, those look pretty interesting - a bit pricey. I went with Kuntzleman's triple magnum. Good price and they look great powered up in the shop. Give me a year & I'll tell you how they look in the air. http://www.kestrobes.com/cat3.htm It seems like there are new LED lights coming out every month. I noticed that Kuntzleman even has LED landing lights. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235734#235734 ________________________________________________________________________________
Date: Mar 22, 2009
Just off of memory. The teardrop is an improvement so the rivet from the aileron connecting rod can not get caught. Match the holes...just my old memory at work. If you check the archives I think you can find some discussion on the interference problem. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton Sent: Sunday, March 22, 2009 5:43 PM Subject: RV10-List: Aileron pushrod holes Today I started working on the rear wing spars. The instructions show a "squared" hole to be cut into the W-1007D doubler plate however the hole in my rear spar is actually a "teardrop" shape. Am I to modify the hole in the spar or simply copy the shape in the spar? A picture is attached. Also, the doubler plates overhang the slot cut into the spar (slot is for the flap brackets I assume) just a little. Do I need to trim the doubler plates to the slot in the spar?? Another picture is attached. ________________________________________________________________________________
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com>
Date: Mar 22, 2009
I'd just reiterate my input that.I cannot imagine a cleaner intersection on these RV's (4,6,7,8,9,10) than what is already out there. I just cannot. The fleet has not had these problems to much of a degree and, especially when the windows are secured with adhesive (I used sikaflex on my 7A). You say 10 or 20 years, I have owned a lot of airplanes that had windscreens older than that which remained serviceable.so I think to some degree it depends what you're willing to fly behind. I'm not saying don't go for sheet metal fairing solution, but understand that when you apply solutions to (what I'd consider in this case) non problems, sometimes you get less than what you started with, especially with thousands of flying examples using a technique that is well known, easily accomplished and well documented. That would seem to be the case here.but I have not seen an installation with a metal fairing, only hundreds done the glass/micro/layup way. I am biased, I guess, I think they look great, and in fact are in my opinion one of the big selling points of the basic RV design. Bob Brown From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Sunday, March 22, 2009 3:54 PM Subject: RE: RV10-List: Wind screen fairing I'm interested in this as well. One of the areas that's been a concern for me is replacing the windshield. I recently replaced the windshield on my Cherokee, which was a pretty straightforward job and didn't really mess up the paint job. At some point in time, I imagine that the RV-10 windshield will need to be replaced due to cracks, scratches, or crazing. It make take 10-20 years for the windshield to get that bad, but I think it's just a question of time. It would be nice to talk to any RV-10 builder that has installed these fairings to get their opinion. Has anyone asked M L Blue Skunk for reference RV-10 builder's names? bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Sunday, March 22, 2009 2:56 PM Subject: Re: RV10-List: Wind screen fairing I am not asking as much from the standpoint of difficulty, as I am asking for functionality regarding cracking and potential windshield removal issues later. Thanks for the replies so far! Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ----- Original Message ----- From: Chuck Weyant <mailto:chuck(at)chuckdirect.com> Sent: Sunday, March 22, 2009 12:22 PM Subject: Re: RV10-List: Wind screen fairing Piece of cake. Follow Van's instructions to the letter and it's easy...just takes time, that's all (two days?). And the transition from top to plexy will be smoooooth as glass (pun intended). This is my second. Built a 'nine' too. Chuck From: Dave Leikam <mailto:daveleikam(at)wi.rr.com> Sent: Saturday, March 21, 2009 10:06 PM Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
From: "John Testement" <jwt(at)roadmapscoaching.com>
Subject: N311RV First Flight!
Date: Mar 22, 2009
N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond, VA ________________________________________________________________________________
Date: Mar 22, 2009
Congrats John! I am about a month behind you and working through the finishing details. Keep us updated on the fly off! Byron South GA N253RV Assigned -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Sunday, March 22, 2009 9:26 PM Subject: RV10-List: N311RV First Flight! N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond, VA ________________________________________________________________________________
Date: Mar 22, 2009
Subject: Re: N311RV First Flight!
Congrats John!!!!!- I guess there's several of us right behind you.- I managed a couple of-somewhat high speed taxis today, and have the airwort hiness inspection tomorrow.- So Deem's is ready, Byron Gillespie is ready , I'm ready, anyone else out there within a month or so ready? Don McDonald #40636 --- On Sun, 3/22/09, John Testement wrote: From: John Testement <jwt(at)roadmapscoaching.com> Subject: RV10-List: N311RV First Flight! Date: Sunday, March 22, 2009, 6:26 PM N311RV took to the air today for an uneventful, and therefore successful, f irst flight. As everyone else says, it flies hands off. What a great plane! - Airborne photos to come. John Testement N311RV #40321 Richmond , VA -=0A=0A=0A ________________________________________________________________________________
Date: Mar 23, 2009
Affirmative - just waiting to have our Aussie instrument and radio ADs signed off (tomorrow hopefully), with final airworthiness inspection next weekend. Cheers, Ron McGann 40187/VH-XRM South Australia ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of building_partner(at)yahoo.com Sent: Monday, 23 March 2009 1:27 PM Subject: Re: RV10-List: N311RV First Flight! Congrats John!!!!! I guess there's several of us right behind you. I managed a couple of somewhat high speed taxis today, and have the airworthiness inspection tomorrow. So Deem's is ready, Byron Gillespie is ready, I'm ready, anyone else out there within a month or so ready? Don McDonald #40636 --- On Sun, 3/22/09, John Testement wrote: From: John Testement <jwt(at)roadmapscoaching.com> Subject: RV10-List: N311RV First Flight! To: rv10-list(at)matronics.com Date: Sunday, March 22, 2009, 6:26 PM N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond , VA <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> "Warning: The information contained in this email and any attached files is confidential to BAE Systems Australia. If you are not the intended recipient, any use, disclosure or copying of this email or any attachments is expressly prohibited. If you have received this email in error, please notify us immediately. VIRUS: Every care has been taken to ensure this email and its attachments are virus free, however, any loss or damage incurred in using this email is not the sender's responsibility. It is your responsibility to ensure virus checks are completed before installing any data sent in this email to your computer." ________________________________________________________________________________
Date: Mar 22, 2009
Knowing how those first flights feel, I hope you've enjoyed the rest of your day. Congratulations of the highest order, every person who completes a homebuilt is at least persistent, that's a guarantee! Enjoy and stay safe, Bob Brown From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Sunday, March 22, 2009 6:26 PM Subject: RV10-List: N311RV First Flight! N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond, VA ________________________________________________________________________________
Date: Mar 22, 2009
Well Done John!!!! Beautiful looking aircraft! Congratulations! Deems Davis # 406 'Its all done....someday soon http://deemsrv10.com/ John Testement wrote: > > N311RV took to the air today for an uneventful, and therefore > successful, first flight. As everyone else says, it flies hands off. > What a great plane! > > > > Airborne photos to come. > > John Testement > N311RV > #40321 > Richmond, VA > > > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Mar 23, 2009
Agreed! Fantastic! Robin ------- Well Done John!!!! Beautiful looking aircraft! Congratulations! Deems Davis # 406 'Its all done....someday soon http://deemsrv10.com/ John Testement wrote: > > N311RV took to the air today for an uneventful, and therefore > successful, first flight. As everyone else says, it flies hands off. > What a great plane! > > > > Airborne photos to come. > > John Testement > N311RV > #40321 > Richmond, VA > > > > ------------------------------------------------------------------------ > > ------------------------------------------------------------------------ > > ------------------------------------------------------------------------ > ________________________________________________________________________________
Date: Mar 22, 2009
Congrats John... it's come a long way since I saw it in your basement... beautiful plane... you should be proud. Jeff On Mar 22, 2009, at 6:26 PM, John Testement wrote: > N311RV took to the air today for an uneventful, and therefore > successful, first flight. As everyone else says, it flies hands > off. What a great plane! > > > Airborne photos to come. > > John Testement > N311RV > #40321 > Richmond, VA > > > ________________________________________________________________________________
Subject: Re: Missing index holes in doors
Date: Mar 23, 2009
It is unfortunate that the Repeat Offenders and new Van kit builders believe the Vans parts to be acceptable. The developments in solvents, cements, potting compounds and substrates are easily a decade ahead of what is "Vans - State of the Art". How is that man??? _________________ blanchard grinding (http://www.preciseplate.com) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235775#235775 ________________________________________________________________________________
Date: Mar 23, 2009
You obviously never have seen some of my posts on the subject. :) Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of precisedix Sent: Monday, March 23, 2009 3:08 AM Subject: RV10-List: Re: Missing index holes in doors It is unfortunate that the Repeat Offenders and new Van kit builders believe the Vans parts to be acceptable. The developments in solvents, cements, potting compounds and substrates are easily a decade ahead of what is "Vans - State of the Art". How is that man??? _________________ blanchard grinding (http://www.preciseplate.com) ________________________________________________________________________________
Date: Mar 23, 2009
Nice plane! Exciting times! I'm only 3+ years behind u... www.2muchflying.com On 3/22/09, John Testement wrote: > N311RV took to the air today for an uneventful, and therefore successful, > first flight. As everyone else says, it flies hands off. What a great plane! > > > Airborne photos to come. > > John Testement > N311RV > #40321 > Richmond, VA > > -- Sent from my mobile device ________________________________________________________________________________
Date: Mar 23, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Congratulations, John Sweet looking airplane. Looks like you have done a great job. Dr Fred. ________________________________________________________________________________
Date: Mar 23, 2009
Dave, we installed a metal fairing that Bud Warren fabricated. He had done it before and was up to the challenge. I think it came out quite nice. May save a paint job down the road should the windshield need replacement. The installation was the easy part. Bud spent several hours fashioning the fairing from a piece of sheet metal. This job is for the experienced, not a novice or else you will probably be disappointed. Bill Gipson N720WL LS1 powered RV-10 Conroe, Texas From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam Sent: Sunday, March 22, 2009 12:07 AM Subject: RV10-List: Wind screen fairing An aluminum fairing is available for the RV-10 wind screen. Has anyone installed one of these? For those who have glassed in their wind screen, would you use a fairing if you had to do it again? http://www.mlblueskunk.com/Windscreen_Fairings.html Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Subject: Max X-wind speed to taxi
Date: Mar 23, 2009
I spent several hours yesterday at the hanger re-arranging it to receive the fuselage for final assembly. The winds were 25 gusting to 35 and today it will be higher. The wind was almost straight down the runway. This started me to thinking, I will have up to a quarter mile taxing to/from the runway at 90 deg to the wind. Question: what is the max x-wind you have taxied your 10 in with no problems and what do you use as your limit? This is my first airplane with a free castering nose gear and I am wondering how much of a problem this will create. -------- Gary Blankenbiller RV10 - # 40674 Final Finishing - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235796#235796 ________________________________________________________________________________
Date: Mar 23, 2009
It was 11 knots gusting to 22 Saturday and I had no problem..... Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman Sent: Monday, March 23, 2009 7:58 AM Subject: RV10-List: Max X-wind speed to taxi I spent several hours yesterday at the hanger re-arranging it to receive the fuselage for final assembly. The winds were 25 gusting to 35 and today it will be higher. The wind was almost straight down the runway. This started me to thinking, I will have up to a quarter mile taxing to/from the runway at 90 deg to the wind. Question: what is the max x-wind you have taxied your 10 in with no problems and what do you use as your limit? This is my first airplane with a free castering nose gear and I am wondering how much of a problem this will create. -------- Gary Blankenbiller RV10 - # 40674 Final Finishing - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235796#235796 ________________________________________________________________________________
Date: Mar 23, 2009
Subject: Re: Aileron pushrod holes
That is the shape of the hole in my quick build wings. I will send you a photo off list. Larry Rosen #356 Bill and Tami Britton wrote: > Today I started working on the rear wing spars. The instructions show > a "squared" hole to be cut into the W-1007D doubler plate however the > hole in my rear spar is actually a "teardrop" shape. Am I to modify > the hole in the spar or simply copy the shape in the spar? A picture > is attached. > > Also, the doubler plates overhang the slot cut into the spar (slot is > for the flap brackets I assume) just a little. Do I need to trim the > doubler plates to the slot in the spar?? Another picture is attached. ________________________________________________________________________________
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Mar 23, 2009
40271 - soon to be 410EG goes to paint this week. All parts have been fit in the shop. Seats are in the engine cranks and the pannel is a no smoking zone. Final assembly in 2 -3 weeks. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235818#235818 ________________________________________________________________________________
Date: Mar 23, 2009
Subject: Re: XM Radio
I have implemented XM using the Spruce XM receiver and my own software. Ear ly on I had sporatic problems resetting the box when there was an extensive delay in data reception. It made the box appear dead until next boot. - Another user had problems when stopping and restarting his subscription and getting the timing right for reception of the "refresh". Another significa nt outage I had was because the whole XM system went down and I needed a "r efresh". Once these problems were resolved it has not failed once in the la st 12 months and comes up briskly with the first nextrad image within 5 min utes. - We need to focus problems on the exact piece of equipment talking to the XM receiver and the mfg of the XM receiver, and the software version in the X M receiver. The specification for this communication is a guarded secret th at-nobody will share (with me)-so there is-much room for errors with reverse engineering.- If you have a copy please contact me. - Also, when the-network "refresh" is activated it will not begin for appro x 30 minutes and times out after 3 hours - so you need to get the timing an d antenna reception right. - None of these comments nor the lack of a clear problem definition surprise me. - Bill DeRouchey N939SB, flying - - --- On Sat, 3/21/09, David Schaefer wrote: From: David Schaefer <n142ds(at)gmail.com> Subject: Re: RV10-List: XM Radio Date: Saturday, March 21, 2009, 7:22 PM The problem you describe is an XM chip issue.- If the XM doesn't see a sa tellite for a while it drops the connection to stop theft.- This was set up long before weather when it was basically a radio only service.- It ha ppens with the cheap XM and the 'certified' XM like I have in my RV.- Rea l pain in the but ... however the refresh only takes seconds .. especially if you're airborne with you request it.- I've never seen it stop working in flight .. it's always after the aircraft has been hangered for a while. - As I understand it there is really no fix for it, although the weather folks have been talking for some time that there may be a way. David W. Schaefer RV-6A N142DS -"Nerdgasm" TMX-IO360 Dual-LightSpeed Plasma IIIs, Hartzell Blended Airfoil, GRT EFIS www.n142ds.com On Fri, Mar 20, 2009 at 4:39 PM, David McNeill wrote: I was using XM for weather on the trip March 14 to the Midwest. worked fine . ON the return March 19, the system failed-to come up after takeoff from the Midwest. I stopped in TX to refresh and it worked again. Does anyone e lse have these problems? Why does the XM sight provide a self refresh trans action on the net? I am considering cancelling XM and using the Navworx box on the Chelton to get TIS and FIS info... I told XM that it is a safety of flight issue, in that expecting NEXRAD data when encountering adverse weat her and being surprised, is not funny. Anybody else have this problem???? get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 23, 2009
Yesterday at KWVI, AWOS was saying 17 gusting to 24. I taxied out with almost a direct crosswind with no problem. It was the first time I noticed that I had to use bit of differential braking to go down the taxi way. The nose wanted to point into the wind, and adding rudder didn't help. But a touch of brake steered it back to centerline. I was taxiing 020, and the wind was about 250. I turned 080 to use runway 26 for takeoff. When I turned to taxi downwind, the stick gave me a pretty stiff push. Keeping it centered took more thought and effort than keeping the nose straight. After working with 17 knots, I wouldn't hesitate to taxi with a 20 knot crosswind. Just hold on to the stick! Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com N921AC 345 hours -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman Sent: Monday, March 23, 2009 6:58 AM Subject: RV10-List: Max X-wind speed to taxi I spent several hours yesterday at the hanger re-arranging it to receive the fuselage for final assembly. The winds were 25 gusting to 35 and today it will be higher. The wind was almost straight down the runway. This started me to thinking, I will have up to a quarter mile taxing to/from the runway at 90 deg to the wind. Question: what is the max x-wind you have taxied your 10 in with no problems and what do you use as your limit? This is my first airplane with a free castering nose gear and I am wondering how much of a problem this will create. -------- Gary Blankenbiller RV10 - # 40674 Final Finishing - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235796#235796 ________________________________________________________________________________
Date: Mar 23, 2009
I have had several problems with the wind, most of them traced to my owning a Piper Archer with steerable nose wheel for many years and not anticipati ng what might happen if the nose wheel can flop about. - I have learned (and probably learn again) that this aircraft desperately wa nts to weather vane.-I have approached the last transit parking place wit h the nose pointed downwind, got out and watched the plane make a nice quic k 90 degree turn. - Taxiing will be slow-in a cross wind because although the braking will ef fectively steer the plane it will also stop the plane. Here is where you do not appreciate the leverage and force the wind exerts on the aft side of t he fuse/tail. - In a high wind condition the takeoff technique is exactly opposite of my Ar cher. Assume the crosswind is from the right. With the Archer I could start the takeoff roll with some right rudder (nose wheel) and the aircraft poin ting slightly to the right. When I tried this with the RV-10 the-wind on the aft fuse rotated the plane clockwise-accelerating it to the right. I almost lost it. Now in these same conditions I am ready to slam in a non-in ituitive hard left rudder. - I find the castering wheel very different. Instead of focusing on where I p oint the nose I focus on where the wind will push my tail. - Bill DeRouchey N939SB, flying --- On Mon, 3/23/09, Rene Felker wrote: From: Rene Felker <rene(at)felker.com> Subject: RE: RV10-List: Max X-wind speed to taxi Date: Monday, March 23, 2009, 7:17 AM It was 11 knots gusting to 22 Saturday and I had no problem..... Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman Sent: Monday, March 23, 2009 7:58 AM Subject: RV10-List: Max X-wind speed to taxi I spent several hours yesterday at the hanger re-arranging it to receive th e fuselage for final assembly.- The winds were 25 gusting to 35 and today i t will be higher.- The wind was almost straight down the runway. This started me to thinking, I will have up to a quarter mile taxing to/fro m the runway at 90 deg to the wind. Question: what is the max x-wind you have taxied your 10 in with no problem s and what do you use as your limit?- This is my first airplane with a free castering nose gear and I am wondering how much of a problem this will create. -------- Gary Blankenbiller RV10 - # 40674 Final Finishing - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235796#235796 le, List Admin. ________________________________________________________________________________
Date: Mar 23, 2009
Subject: Re: Max X-wind speed to taxi
I can't answer your question for the -10 ..... I'm still building .... but I have many hours in my Grumman (AA-1B) with similar nosegear. Bear in mind that the -10 is bigger so ....... Power and good brakes will whip any crosswind .... short of hurricanes and tornadoes! :-P so taxiing shouldn't be a problem. Once you master the cross-controlled landing, it's a piece of cake ...... just remember that there's a rudder back there and use it. You'll be amazed at the number of 'high time pilots' that forget to move the rudder!!! When you get a landing in a high crosswind .... write it down. That's your demonstrated crosswind capability and should be in your aircraft handbook. Keep it updated!!! My Grumman manual has a notation: Demonstrated crosswind component 36 MPH, Nov. 10, 1999. Having said all that, I don't think I'd go looking for a high number just to say I did it!!! Linn orchidman wrote: > > I spent several hours yesterday at the hanger re-arranging it to receive the fuselage for final assembly. The winds were 25 gusting to 35 and today it will be higher. The wind was almost straight down the runway. > > This started me to thinking, I will have up to a quarter mile taxing to/from the runway at 90 deg to the wind. > > Question: what is the max x-wind you have taxied your 10 in with no problems and what do you use as your limit? This is my first airplane with a free castering nose gear and I am wondering how much of a problem this will create. > > -------- > Gary Blankenbiller > RV10 - # 40674 > Final Finishing - SB > (N2GB registered) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235796#235796 > > > > ------------------------------------------------------------------------ > > > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Mar 24, 2009
Thanks all for your comments. I have not seen this covered in the past and I am within a little more then a month of my transition training and this has crossed my mind more then once. It is sounding like this is going to be a very good year for -10 first flights. It shouldn't be a problem filling up more then 2 rows at Osh this year. :D -------- Gary Blankenbiller RV10 - # 40674 Final Finishing - SB (N2GB registered) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235935#235935 ________________________________________________________________________________
Date: Mar 24, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Wow! Sweet. Inspirational. Congratulations!! John Testement wrote: > > N311RV took to the air today for an uneventful, and therefore > successful, first flight. As everyone else says, it flies hands off. > What a great plane! > > > > Airborne photos to come. > > John Testement > N311RV > #40321 > Richmond, VA > ________________________________________________________________________________
Date: Mar 24, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Congratulations John! Bob _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Testement Sent: Sunday, March 22, 2009 8:26 PM Subject: RV10-List: N311RV First Flight! N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond, VA ________________________________________________________________________________
Subject: doors
Date: Mar 24, 2009
Let me pass on the report I got from an RV-10 owner concerning the "Lose of Door in Flight" situation. The part I like was the statement 'the plane flew fine.' Albert Gardner Yuma, AZ "After the P seals are added to the doors it can be rather hard to close them. Since the rear latch is difficult to see and you pull the door closed from the forward edge the rear pin is the most likely to not be engaged. My passenger failed to close it properly and I did not check it before take-off. Immediately after rotation and within 200' of the ground there was a loud bang and it became very noisy and windy. The plane flew fine, I kept it to about 90kts, did a 180 and landed without further incident. The door pulled through the bolts at the hinge and the gas strut broke loose both at the door and cabin attach points. The door halves had mostly delaminated, the window was broken, and the inner shell had broken through at the curve but was easily repairable. There was no damage to the empennage." ________________________________________________________________________________
Subject: doors
Date: Mar 24, 2009
Congrats Don. I am sure your inspection will go off with out a hitch. When I get to the doors I will sure come visit you for advise. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, March 23, 2009 9:48 PM Subject: Re: RV10-List: doors If I was going o do them again,,,, GOD forbid, I would insert a strengthening plate aft of the door handle. Then you'd have something to actually fasten a strap to. My 2 cents. Don McDonald Received the FAA's blessing today with an airworthiness cert!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --- On Mon, 3/23/09, linn wrote: From: linn <pitts_pilot(at)bellsouth.net> Subject: RV10-List: doors Date: Monday, March 23, 2009, 7:00 PM <http://us.mc01g.mail.yahoo.com/mc/compose?to=pitts_pilot@bellsouth.net> > OK, speaking of doors ..... has anyone suffered damage because the wind caught the doors? Any other concerns with the doors??? Any 'fixes' that you'd do when you're assembling the doors??? I'm getting ready to do mine ..... educate me!!! Linn Tim Olson wrote: <http://us.mc01g.mail.yahoo.com/mc/compose?to=Tim@myrv10.com> > When the winds are 20+, taxi isn't the worry, > holding the doors when you open them is a bigger concern. > > Tim Olson - RV-10 N104CD - Flying > do not --> http://www.matronics.com/Navigator?RV10-List sp; --> ht <http://forums.matronics.com/> - List Contribution Web Site; &nb; http://======================= <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Mar 24, 2009
Subject: doors
Passed already... yesterday.- then took the FAA inspector, Dilly, out for a bbq dinner.- Great guy, unbelievable that he's a govt employee.- Bas ically inspected my plane on his own time.- Now for finishing my flight t raining.- Headed to Dallas this weekend for RV10 training and the hp endo rcement with Alex.- The ducks are lining up! Sure, come on up anytime.-- Don --- On Tue, 3/24/09, John Cumins wrote: From: John Cumins <jcumins(at)jcis.net> Subject: RE: RV10-List: doors Date: Tuesday, March 24, 2009, 8:56 AM Congrats Don.- I am sure your inspection will go off with out a hitch. - When I get to the doors I will sure come visit you for advise. - John G. Cumins President - JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax - Your Total Technology Solution Provider From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server@ matronics.com ] On Behalf Of Don McDonald Sent: Monday, March 23, 2009 9:48 PM Subject: Re: RV10-List: doors - If I was going o do them again,,,, GOD forbid,- I would insert a strength ening plate aft of the door handle.- Then you'd have something to actuall y fasten a strap to. My 2 cents. Don McDonald Received the FAA's blessing today with an airworthiness cert!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --- On Mon, 3/23/09, linn wrote: From: linn <pitts_pilot(at)bellsouth.net> Subject: RV10-List: doors Date: Monday, March 23, 2009, 7:00 PM OK, speaking of doors ..... has anyone suffered damage because the wind cau ght the doors?- Any other concerns with the doors???- Any 'fixes' that you'd do when you're assembling the doors???- - I'm getting ready to do mine ..... educate me!!! Linn Tim Olson wrote: the winds are 20+, taxi isn't the worry, > holding the doors when you open them is a bigger concern. > > Tim Olson - RV-10 N104CD - Flying > do not -----> http://www.matronics.com/Navigator?RV10-List sp;---> ht - - - - ---- List Contribution Web Site; - - - - - - - - - - &nb; http://========== ============= - - - -http://www.matronics.com/Navigator?RV10-Listhttp://forums.matron ics.comhttp://www.matronics.com/contribution - =0A=0A=0A ________________________________________________________________________________
Date: Mar 24, 2009
Larry at Vetterman informed me that the bolt that he supplies with the exhaust kit are stainless steel and have a higher torque value than the Vans bolts. He said torque to about 150# is fine. With the SS bolts he said the anti seize is not needed -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235981#235981 ________________________________________________________________________________
Subject: doors
Date: Mar 24, 2009
Congrats, wish I was going to Dallas with you. But in due time hehe. 50000 more rivits to go. Chat soon. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Tuesday, March 24, 2009 9:31 AM Subject: RE: RV10-List: doors Passed already... yesterday. then took the FAA inspector, Dilly, out for a bbq dinner. Great guy, unbelievable that he's a govt employee. Basically inspected my plane on his own time. Now for finishing my flight training. Headed to Dallas this weekend for RV10 training and the hp endorcement with Alex. The ducks are lining up! Sure, come on up anytime. Don --- On Tue, 3/24/09, John Cumins wrote: From: John Cumins <jcumins(at)jcis.net> Subject: RE: RV10-List: doors Date: Tuesday, March 24, 2009, 8:56 AM Congrats Don. I am sure your inspection will go off with out a hitch. When I get to the doors I will sure come visit you for advise. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider _____ From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com ] On Behalf Of Don McDonald Sent: Monday, March 23, 2009 9:48 PM Subject: Re: RV10-List: doors If I was going o do them again,,,, GOD forbid, I would insert a strengthening plate aft of the door handle. Then you'd have something to actually fasten a strap to. My 2 cents. Don McDonald Received the FAA's blessing today with an airworthiness cert!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! --- On Mon, 3/23/09, linn wrote: From: linn <pitts_pilot(at)bellsouth.net> Subject: RV10-List: doors Date: Monday, March 23, 2009, 7:00 PM <http://us.mc01g.mail.yahoo.com/mc/compose?to=pitts_pilot@bellsouth.net> pitts_pilot(at)bellsouth.net> OK, speaking of doors ..... has anyone suffered damage because the wind caught the doors? Any other concerns with the doors??? Any 'fixes' that you'd do when you're assembling the doors??? I'm getting ready to do mine ..... educate me!!! Linn Tim Olson wrote: <http://us.mc01g.mail.yahoo.com/mc/compose?to=Tim@myrv10.com> Tim(at)myrv10.com> When the winds are 20+, taxi isn't the worry, > holding the doors when you open them is a bigger concern. > > Tim Olson - RV-10 N104CD - Flying > do not --> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List sp; --> <http://forums.matronics.com/> ht - List Contribution Web Site; &nb; <http://www.matronics.com/contribution> http://======================= http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 24, 2009
So, the question is before the group... What are the Pros and the Cons of u sing Copper Loctite with the improved S. steel fasteners? John Cox From: AirMike Sent: Tue 3/24/2009 9:41 AM Subject: RV10-List: Re: Exhaust system torque values - etc - Vetterman 2 st ack Larry at Vetterman informed me that the bolt that he supplies with the exha ust kit are stainless steel and have a higher torque value than the Vans bo lts. He said torque to about 150# is fine. With the SS bolts he said the an ti seize is not needed -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235981#235981 ________________________________________________________________________________
Subject: Baggage Area & Door Straps
Date: Mar 24, 2009
Is there a maximum weight limit on what can go in the baggage area.... I know all of us have spent some time in/on/sprawled in that area, but is there a structural limit.... assuming that whatever weight you put back there keeps you in an ok situation as far as weight and balance. Also, has anyone found a source for a decent strap to fasten to the door to not only use to pull the doors down, but also pull them fully closed. Thanks Don McDonald #40636 Airworthiness done, flight training not quite -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235998#235998 ________________________________________________________________________________
Date: Mar 24, 2009
I think you would have a c/g issue causing the tail to hit the ground long before there is a structural issue. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Tuesday, March 24, 2009 2:55 PM Subject: RV10-List: Baggage Area & Door Straps Is there a maximum weight limit on what can go in the baggage area.... I know all of us have spent some time in/on/sprawled in that area, but is there a structural limit.... assuming that whatever weight you put back there keeps you in an ok situation as far as weight and balance. Also, has anyone found a source for a decent strap to fasten to the door to not only use to pull the doors down, but also pull them fully closed. Thanks Don McDonald #40636 Airworthiness done, flight training not quite -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=235998#235998 ________________________________________________________________________________
Date: Mar 24, 2009
Subject: Re: Baggage Area & Door Straps
I think vans says the baggage area is rated at 100lbs. Of course, I've sat back there a few times doing work, so in a NON-flying situation I'm sure it's not a structural limit. But while flying it would be a CG or perhaps structural limit. Much more than that and you'd start to risk tipping it onto it's tail anyway though. Tim Olson - RV-10 N104CD - Flying partner14 wrote: > > > Is there a maximum weight limit on what can go in the baggage > area.... I know all of us have spent some time in/on/sprawled in that > area, but is there a structural limit.... assuming that whatever > weight you put back there keeps you in an ok situation as far as > weight and balance. Also, has anyone found a source for a decent > strap to fasten to the door to not only use to pull the doors down, > but also pull them fully closed. Thanks > > Don McDonald #40636 Airworthiness done, flight training not quite > > -------- Don A. McDonald 40636 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235998#235998 > ________________________________________________________________________________
Date: Mar 24, 2009
I see what you guys are saying, but if you had two 220 pounders in the fron t seats, with noone in the rear seats, my guess (I'm not at the hanger) is that if you put 150 pounds in the baggage area, you wouldn't come close to flipping the plane on it's back, and should still be way within CG limits. - Not that I'm planning on piling it up or anything! Don --- On Tue, 3/24/09, Tim Olson wrote: From: Tim Olson <Tim(at)MyRV10.com> Subject: Re: RV10-List: Baggage Area & Door Straps Date: Tuesday, March 24, 2009, 1:00 PM I think vans says the baggage area is rated at 100lbs. Of course, I've sat back there a few times doing work, so in a NON-flying situation I'm sure it's not a structural limit.- But while flying it would be a CG or perhaps structural limit.- Much more than that and you'd start to risk tipping it onto it's tail anyway though. Tim Olson - RV-10 N104CD - Flying partner14 wrote: > > > Is there a maximum weight limit on what can go in the baggage > area.... I know all of us have spent some time in/on/sprawled in that > area, but is there a structural limit.... assuming that whatever > weight you put back there keeps you in an ok situation as far as > weight and balance. Also, has anyone found a source for a decent > strap to fasten to the door to not only use to pull the doors down, > but also pull them fully closed. Thanks > > Don McDonald #40636 Airworthiness done, flight training not quite > > -------- Don A. McDonald 40636 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235998#235998 > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Mar 24, 2009
Don't forget it's 100 (or 150) lbs times the maximum g-load under flight conditions that the structure has to support. Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236028#236028 ________________________________________________________________________________
Date: Mar 24, 2009
>From page two of the weight and balance section of the manual: Baggage compartment load limit 150lbs. and is determined by the structural limits of the baggage floor. I recently re-weighed my 10 after painting and interior were completed. 1701 lbs and a CG of 108.6. This was about 25 lbs. more than I was hoping for but appears to be about average for the fleet. Looking at many of the reported weights below 1650 in Dan's table I am thinking many of these are initial weights sans paint and or interiors. If not, my hat is off to anyone completing a 10 with paint and interior at under 1650. Dick Sipp N110DV 40065 120 hours ----- Original Message ----- From: "partner14" <building_partner(at)yahoo.com> Sent: Tuesday, March 24, 2009 2:55 PM Subject: RV10-List: Baggage Area & Door Straps > > Is there a maximum weight limit on what can go in the baggage area.... I > know all of us have spent some time in/on/sprawled in that area, but is > there a structural limit.... assuming that whatever weight you put back > there keeps you in an ok situation as far as weight and balance. > Also, has anyone found a source for a decent strap to fasten to the door > to not only use to pull the doors down, but also pull them fully closed. > Thanks > > Don McDonald > #40636 > Airworthiness done, flight training not quite > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235998#235998 > > > ________________________________________________________________________________
Subject: Elevator level
Date: Mar 24, 2009
Anyone have a good reference point to zero the level to measure elevator travel? I can only think of trying to use a ruler across the middle of the airfoil across the chord line. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236055#236055 ________________________________________________________________________________
From: "Edwin L (Ted) French" <ted_french(at)telus.net>
Date: Mar 24, 2009
I found a couple of good looking dog leashes at our local pet store. Had them shortened with a small loop at the door end, installed with a pin to a piece of c channel. Looks good and works well. Ted C-FXCS flying On 24-Mar-09, at 11:55 AM, partner14 wrote: > > > > > Is there a maximum weight limit on what can go in the baggage > area.... I know all of us have spent some time in/on/sprawled in > that area, but is there a structural limit.... assuming that > whatever weight you put back there keeps you in an ok situation as > far as weight and balance. > Also, has anyone found a source for a decent strap to fasten to the > door to not only use to pull the doors down, but also pull them > fully closed. > Thanks > > Don McDonald > #40636 > Airworthiness done, flight training not quite > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=235998#235998 > > ________________________________________________________________________________
Subject: Re: Elevator level
Date: Mar 25, 2009
Sorry about the stupid question. Hugo enlightened me. It was a long day. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236069#236069 ________________________________________________________________________________
Date: Mar 25, 2009
I always liked the way the Columbia has its door strap attached. I will do something similar on my doors. Probably using a nylon strap, like that found on luggage. I may wrap the strap in my interior fabric. Attached is a photo of the Columbia door strap. Larry Rosen #356 ________________________________________________________________________________
Date: Mar 25, 2009
Space Cadet wrote: > Don't forget it's 100 (or 150) lbs times the maximum g-load under flight conditions that the structure has to support. > > Dwight Just what I was going to say. It's when that 150lbs. becomes 300lbs. or greater under G loads and causes the structure to fail. That's why there is a limitation. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236103#236103 ________________________________________________________________________________
Date: Mar 25, 2009
Thanks guys for all your comments.- The FAA inspector thought there shoiu ld be some limit posted.... and now I'm off to the doggie store to find a l eash suitable for my door strap.- I'm figuring I can attach a plate to th e door then attach the strap. - I also assume if we were flying at, or close to max gross, or with a few ex tra bags in the back, that we would fly our aircraft accordingly.... no ste ep banks, inverted flight, etc. - Thanks again, you guys are great.... except you Pascal......... just kiddin g! - Don McDonald - Pascal, you making any trips to Spruce in the near future? --- On Wed, 3/25/09, BrianNC wrote: From: BrianNC <EMINI2000(at)yahoo.com> Subject: RV10-List: Re: Baggage Area & Door Straps Date: Wednesday, March 25, 2009, 8:45 AM Space Cadet wrote: > Don't forget it's 100 (or 150) lbs times the maximum g-load under flight conditions that the structure has to support.- > > Dwight Just what I was going to say. It's when that 150lbs. becomes 300lbs. or gre ater under G loads and causes the structure to fail. That's why there is a limitation. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236103#236103 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Mar 25, 2009
John, congratulations on your first flight and an very beautiful aircraft. =0A=0AWishing you safe, clear and smooth skies.=0A=0ARegards=0A=0APatrick P ulis=0ARV-10 #40299- VH-XPP=0AAdelaide, South Australia=0A=0A=0A=0A=0A___ _____________________________=0AFrom: John Testement <jwt@roadmapscoaching. com>=0ATo: rv10-list(at)matronics.com=0ASent: Monday, 23 March, 2009 11:56:16 AM=0ASubject: RV10-List: N311RV First Flight!=0A=0A=0AN311RV took to the ai r today for an uneventful, and therefore successful, first flight. As every one else says, it flies hands off. What a great plane!=0A-=0AAirborne pho tos to come.=0AJohn Testement=0AN311RV=0A#40321=0ARichmond , VA=0A=0A=0A The new Internet Explorer 8 optimised for Yahoo!7: Faster, Safer, Easier . ________________________________________________________________________________
Date: Mar 26, 2009
Subject: door ajar wiring diagram
we have the van's wiring kit for the door ajar warning system but have misp laced the wiring diagram. - does anyone have a link to a source or a copy they can email me? psbonner(at)yahoo.com =0A=0A=0A ________________________________________________________________________________
Date: Mar 26, 2009
Emailed directly to you (4.5MB attachment). Bob N442PM (flying) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of paul bonner Sent: Thursday, March 26, 2009 9:07 AM Subject: RV10-List: door ajar wiring diagram we have the van's wiring kit for the door ajar warning system but have misplaced the wiring diagram. does anyone have a link to a source or a copy they can email me? psbonner(at)yahoo.com ________________________________________________________________________________
Date: Mar 26, 2009
I used a protractor with a weighted indicator that moves as you rotate the device. Easy way to measure moving parts. Here's a link to the one I have at Home Depot Aircraft Supply: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 051&langId=-1&catalogId=10053&productId=100165800 Well worth the $9 Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Tuesday, March 24, 2009 11:21 PM Subject: RV10-List: Elevator level Anyone have a good reference point to zero the level to measure elevator travel? I can only think of trying to use a ruler across the middle of the airfoil across the chord line. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236055#236055 ________________________________________________________________________________
Date: Mar 26, 2009
I purchased an electronic level from the aviation department of home depot. Cost a little under $40 before tax. I though it was well worth it. Used on tail...flaps....magnetometer placement... made it all a lot easier. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Thursday, March 26, 2009 8:40 AM Subject: RE: RV10-List: Elevator level I used a protractor with a weighted indicator that moves as you rotate the device. Easy way to measure moving parts. Here's a link to the one I have at Home Depot Aircraft Supply: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 051&langId=-1&catalogId=10053&productId=100165800 Well worth the $9 Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Tuesday, March 24, 2009 11:21 PM Subject: RV10-List: Elevator level Anyone have a good reference point to zero the level to measure elevator travel? I can only think of trying to use a ruler across the middle of the airfoil across the chord line. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236055#236055 ________________________________________________________________________________
Date: Mar 26, 2009
It's been a while but I think I layed a straight edge across the top of the elevator and the horizontal stab, in the most consistent place I could. Then that was zero. From there, at the time, I used this $4 Dial-gauge angle finder from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 Surprisingly it worked pretty good. But these days, I found something way cooler....something that is just my style. http://www.teego.com/multilevel.html A level app for the iPhone/iPod Touch. This thing is super accurate, and dirt cheap if you own the device. Tim Olson - RV-10 N104CD - Flying Marcus Cooper wrote: > > I used a protractor with a weighted indicator that moves as you rotate the > device. Easy way to measure moving parts. Here's a link to the one I have > at Home Depot Aircraft Supply: > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 > 051&langId=-1&catalogId=10053&productId=100165800 > > > Well worth the $9 > > Marcus > 40286 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > Sent: Tuesday, March 24, 2009 11:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Elevator level > > > Anyone have a good reference point to zero the level to measure elevator > travel? I can only think of trying to use a ruler across the middle of the > airfoil across the chord line. > > -------- > Cust. #40936 > A&P, ATP > typed CE-525(s), CE-500 > RV-10 tailcone finished > N801VR reserved > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 26, 2009
Ditto... Craftsman Digital Level for me. Placed it on the elevator and pressed the "0" button. That was now the starting point. Then I could rotate the elevator to confirm the travel. Once I finished, I was curious as to why this was such a big deal. I think it's nearly impossible to mess up the elevator travel. I suppose it's a good thing to check, but mine were spot-on by .1 of a degree. :) -----Original Message----- From: Rene Felker [mailto:rene(at)felker.com] Sent: Thursday, March 26, 2009 10:11 AM Subject: RE: RV10-List: Elevator level I purchased an electronic level from the aviation department of home depot. Cost a little under $40 before tax. I though it was well worth it. Used on tail...flaps....magnetometer placement... made it all a lot easier. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Thursday, March 26, 2009 8:40 AM Subject: RE: RV10-List: Elevator level I used a protractor with a weighted indicator that moves as you rotate the device. Easy way to measure moving parts. Here's a link to the one I have at Home Depot Aircraft Supply: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeI d=10 051&langId=-1&catalogId=10053&productId=100165800 Well worth the $9 Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Tuesday, March 24, 2009 11:21 PM Subject: RV10-List: Elevator level Anyone have a good reference point to zero the level to measure elevator travel? I can only think of trying to use a ruler across the middle of the airfoil across the chord line. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236055#236055 ________________________________________________________________________________
Date: Mar 26, 2009
This is also what I used. Works great for leveling the plane when working o n wheel pants and weight and balance. Here is a link to the tool: http://www.homedepot.com/webapp/wcs/stores/serv let/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId =100653598 Vern Smith (#324 finishing) > From: rene(at)felker.com > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Elevator level > Date: Thu=2C 26 Mar 2009 09:11:17 -0600 > > > I purchased an electronic level from the aviation department of home depo t. > Cost a little under $40 before tax. I though it was well worth it. Used o n > tail...flaps....magnetometer placement... made it all a lot easier. > > Rene' Felker > RV-10 N423CF Flying > 801-721-6080 > =========== =========== =========== > > > _________________________________________________________________ Hotmail=AE is up to 70% faster. Now good news travels really fast. http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_70faster_03200 9 ________________________________________________________________________________
Date: Mar 26, 2009
GS-Air in Rochester , MN https://ssl.perfora.net/gs-air.com/sess/utn;jsessionid=1549cbab3a82607/shopdata/index.shopscript nice guy - good prices (1/2 of Whelen) - looks like good quality Note: Whelen's warranty is only for 6 months I held off to get my strobes because of this outrageously short warranty, then I got my stuff from GS-Air. Nice guy - good warranty - reasonable -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236229#236229 ________________________________________________________________________________
Date: Mar 26, 2009
Wow = way to go. any comments on the paint system - looks great -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236230#236230 ________________________________________________________________________________
Date: Mar 26, 2009
Thanks everyone, I bought the 40$ Ridgid digital level from Home Depot and it worked great. I installed the elevators and they came out really close. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 tailcone finished N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236231#236231 ________________________________________________________________________________
Date: Mar 26, 2009
I thought the elevator travel was limited by the stops in the tail of the fuselage? The elevator horns contacted the stops. I don't recall having to measure the elevator travel at all with a angle finder. I may be wrong about this. Jim C N312F - Flying Olson It's been a while but I think I layed a straight edge across the top of the elevator and the horizontal stab, in the most consistent place I could. Then that was zero. >From there, at the time, I used this $4 Dial-gauge angle finder from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 Surprisingly it worked pretty good. But these days, I found something way cooler....something that is just my style. http://www.teego.com/multilevel.html A level app for the iPhone/iPod Touch. This thing is super accurate, and dirt cheap if you own the device. Tim Olson - RV-10 N104CD - Flying Marcus Cooper wrote: > --> RV10-List message posted by: "Marcus Cooper" > > I used a protractor with a weighted indicator that moves as you rotate > the > device. Easy way to measure moving parts. Here's a link to the one I > have > at Home Depot Aircraft Supply: > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 > 051&langId=-1&catalogId=10053&productId=100165800 > > > Well worth the $9 > > Marcus > 40286 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > Sent: Tuesday, March 24, 2009 11:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Elevator level > > > Anyone have a good reference point to zero the level to measure elevator > travel? I can only think of trying to use a ruler across the middle of > the > airfoil across the chord line. > > -------- > Cust. #40936 > A&P, ATP > typed CE-525(s), CE-500 > RV-10 tailcone finished > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > - The RV10-List Email Forum - Features Navigator to browse Un/Subscription, Chat, FAQ, --> http://www.matronics.com/Navigator?RV10-List - MATRONICS WEB FORUMS - available via the Web Forums! http://forums.matronics.com - List Contribution Web Site - generous support! Admin. ________________________________________________________________________________
Date: Mar 26, 2009
Maybe it's been too long Jim! Before my first flight I created the following list of alignments and rechecked all. Elevator alignment is on page 11-6. Bob N442PM (flying) Elevator alignments 11-2 Up/Down Travel 11-6 limit stops 11-7 aft tube rod end bearing adjustment 39-10 control stick elevator neutral adjustment Aileron Alignment 23-7 neutral position 23-8 bellcrank neutral position 23-9 aileron to flap alignment 44-4 control stick aileron neutral adjustment Elevator trim alignment 11-10 deflection spec & adjustment Rudder alignment 11-7 limit stops Control Sticks 39-9 Control stick parallel alignment Flap Alignment 44-5 Flap full up position alignment _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com Sent: Thursday, March 26, 2009 1:46 PM Subject: Re: RV10-List: Elevator level I thought the elevator travel was limited by the stops in the tail of the fuselage? The elevator horns contacted the stops. I don't recall having to measure the elevator travel at all with a angle finder. I may be wrong about this. Jim C N312F - Flying It's been a while but I think I layed a straight edge across the top of the elevator and the horizontal stab, in the most consistent place I could. Then that was zero. >From there, at the time, I used this $4 Dial-gauge angle finder from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 Surprisingly it worked pretty good. But these days, I found something way cooler....something that is just my style. http://www.teego.com/multilevel.html A level app for the iPhone/iPod Touch. This thing is super accurate, and dirt cheap if you own the device. Tim Olson - RV-10 N104CD - Flying Marcus Cooper wrote: > > I used a protractor with a weighted indicator that moves as you rotate > the > device. Easy way to measure moving parts. Here's a link to the one I > have > at Home Depot Aircraft Supply: > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeI d=10 > 051&langId=-1&catalogId=10053&productId=100165800 > > > Well worth the $9 > > Marcus > 40286 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > Sent: Tuesday, March 24, 2009 11:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Elevator level > > > Anyone have a good reference point to zero the level to measure elevator > travel? I can only think of trying to use a ruler across the middle of > the > airfoil across the chord line. > > -------- > Cust. #40936 > A&P, ATP > typed CE-525(s), CE-500 > RV-10 tailcone finished > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > ________________________________________________________________________________
Date: Mar 26, 2009
Aw shoot....I was talking trim deflection. You're right. For elevators I just lined up the horns with the HS. Tim On Mar 26, 2009, at 1:45 PM, jim(at)CombsFive.Com wrote: > I thought the elevator travel was limited by the stops in the tail > of the fuselage? The elevator horns contacted the stops. I don't > recall having to measure the elevator travel at all with a angle > finder. > > I may be wrong about this. > > Jim C > N312F - Flying > > > It's been a while but I think I layed a straight edge across the top > of the elevator and the horizontal stab, in the most consistent > place I could. Then that was zero. > From there, at the time, I used > this $4 Dial-gauge angle finder from Harbor Freight. > http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 > > Surprisingly it worked pretty good. > > But these days, I found something way cooler....something that is > just my style. > http://www.teego.com/multilevel.html > > A level app for the iPhone/iPod Touch. This thing is super accurate, > and dirt cheap if you own the device. > > Tim Olson - RV-10 N104CD - Flying > > > Marcus Cooper wrote: > > > > > I used a protractor with a weighted indicator that moves as you > rotate > > the > > device. Easy way to measure moving parts. Here's a link to the one I > > have > > at Home Depot Aircraft Supply: > > > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 > > 051&langId=-1&catalogId=10053&productId=100165800 > > > > > > Well worth the $9 > > > > Marcus > > 40286 > > -----Original Message----- > > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > > Sent: Tuesday, March 24, 2009 11:21 PM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Elevator level > > > > > > Anyone have a good reference point to zero the level to measure > elevator > > travel? I can only think of trying to use a ruler across the > middle of > > the > > airfoil across the chord line. > > > > -------- > > Cust. #40936 > > A&P, ATP > > typed CE-525(s), CE-500 > > RV-10 tailcone finished > > N801VR reserved > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 26, 2009
If I remember correctly. You need to check and adjust elevator travel once the linkage all the way to the stick is established. I was having my stick, with infinity grip, hit the panel and thus tried to solve that problem by adjusting the linkage..so It may have been different to me. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com Sent: Thursday, March 26, 2009 12:46 PM Subject: Re: RV10-List: Elevator level I thought the elevator travel was limited by the stops in the tail of the fuselage? The elevator horns contacted the stops. I don't recall having to measure the elevator travel at all with a angle finder. I may be wrong about this. Jim C N312F - Flying It's been a while but I think I layed a straight edge across the top of the elevator and the horizontal stab, in the most consistent place I could. Then that was zero. >From there, at the time, I used this $4 Dial-gauge angle finder from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 Surprisingly it worked pretty good. But these days, I found something way cooler....something that is just my style. http://www.teego.com/multilevel.html A level app for the iPhone/iPod Touch. This thing is super accurate, and dirt cheap if you own the device. Tim Olson - RV-10 N104CD - Flying Marcus Cooper wrote: > > I used a protractor with a weighted indicator that moves as you rotate > the > device. Easy way to measure moving parts. Here's a link to the one I > have > at Home Depot Aircraft Supply: > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10 > 051&langId=-1&catalogId=10053&productId=100165800 > > > Well worth the $9 > > Marcus > 40286 > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > Sent: Tuesday, March 24, 2009 11:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Elevator level > > > Anyone have a good reference point to zero the level to measure elevator > travel? I can only think of trying to use a ruler across the middle of > the > airfoil across the chord line. > > -------- > Cust. #40936 > A&P, ATP > typed CE-525(s), CE-500 > RV-10 tailcone finished > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > ________________________________________________________________________________
Date: Mar 26, 2009
That is awesome for you to write this up Bob...I can't remember back that far well anymore but I just followed the plans... Your write up is a great quick reference! Tim On Mar 26, 2009, at 1:57 PM, "Condrey, Bob (US SSA)" wrote: > Maybe it=99s been too long Jim! Before my first flight I created the > following list of alignments and rechecked all. Elevator alignment > is on page 11-6. > > > Bob > > N442PM (flying) > > > Elevator alignments > > > 11-2 > > Up/Down Travel > > > 11-6 > > limit stops > > > 11-7 > > aft tube rod end bearing adjustment > > > 39-10 > > control stick elevator neutral adjustment > > > Aileron Alignment > > > 23-7 > > neutral position > > > 23-8 > > bellcrank neutral position > > > 23-9 > > aileron to flap alignment > > > 44-4 > > control stick aileron neutral adjustment > > > Elevator trim alignment > > > 11-10 > > deflection spec & adjustment > > > Rudder alignment > > > 11-7 > > limit stops > > > Control Sticks > > > 39-9 > > Control stick parallel alignment > > > Flap Alignment > > > 44-5 > > Flap full up position alignment > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of jim(at)CombsFive.Com > Sent: Thursday, March 26, 2009 1:46 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Elevator level > > > I thought the elevator travel was limited by the stops in the tail > of the fuselage? The elevator horns contacted the stops. I don't > recall having to measure the elevator travel at all with a angle > finder. > > I may be wrong about this. > > Jim C > N312F - Flying > > > It's been a while but I think I layed a straight edge across the top > of the elevator and the horizontal stab, in the most consistent > place I could. Then that was zero. > >=46rom there, at the time, I used > this $4 Dial-gauge angle finder from Harbor Freight. > http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34214 > > Surprisingly it worked pretty good. > > But these days, I found something way cooler....something that is > just my style. > http://www.teego.com/multilevel.html > > A level app for the iPhone/iPod Touch. This thing is super accurate, > and dirt cheap if you own the device. > > Tim Olson - RV-10 N104CD - Flying > > > Marcus Cooper wrote: > > > > > I used a protractor with a weighted indicator that moves as you > rotate > > the > > device. Easy way to measure moving parts. Here's a link to the one I > > have > > at Home Depot Aircraft Supply: > > > > http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId= 10 > > 051&langId=-1&catalogId=10053&productId=100165800 > > > > > > Well worth the $9 > > > > Marcus > > 40286 > > -----Original Message----- > > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > > Sent: Tuesday, March 24, 2009 11:21 PM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Elevator level > > > > > > Anyone have a good reference point to zero the level to measure > elevator > > travel? I can only think of trying to use a ruler across the > middle of > > the > > airfoil across the chord line. > > > > -------- > > Cust. #40936 > > A&P, ATP > > typed CE-525(s), CE-500 > > RV-10 tailcone finished > > N801VR reserved > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=236055#236055 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ________________________________________________________________________________
Subject: N311RV First Flight!
Date: Mar 27, 2009
Hi John, what a fantastic result!! - looks great, nice design and colour also Evan and Tania Andrews VH-OSH flying Brisbane, Australia -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of John Testement Sent: Monday, 23 March 2009 11:26 AM To: rv10-list(at)matronics.com Subject: RV10-List: N311RV First Flight! N311RV took to the air today for an uneventful, and therefore successful, first flight. As everyone else says, it flies hands off. What a great plane! Airborne photos to come. John Testement N311RV #40321 Richmond, VA E-mail message checked by Spyware Doctor (6.0.0.386) Database version: 5.12010 http://www.pctools.com/spyware-doctor-antivirus/ E-mail message checked by Spyware Doctor (6.0.0.386) Database version: 5.12050 http://www.pctools.com/en/spyware-doctor-antivirus/ ________________________________________________________________________________
Subject: Fuel & Oil line torque values - help ???
Date: Mar 26, 2009
I was told to use a high temp permatex thread sealer on the fuel and oil lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor hoses. What are the torque values on these aeroquip hoses (fuel & oil)???? Also - Alert note......................I got my FWF kit in the summer of '07. My VA190 hose was of the wrong diameter. I would suggest that people who got their FWF kits about then check the hose to make sure that it was right. I sent back the defective hose and Gus very kindly sent me the proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller exterior nut - it is the wrong size. -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236318#236318 ________________________________________________________________________________
Subject: Rv-10 Carbon panels
Date: Mar 26, 2009
I was asked to post when carbon panels were available. The panels are for sale at this time. They are available thru Steinair or Direct from myself. Pricing is available on Steinair or call 614-834-5227 day or 614-519-4439eve. Price for entire set is $1150.00. -------- Build QB RV-10 N829GW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236317#236317 Attachments: http://forums.matronics.com//files/carbonrv10_111.jpg http://forums.matronics.com//files/carbonpanel_151.jpg ________________________________________________________________________________
Subject: Re: Rv-10 Carbon panels
Date: Mar 27, 2009
sign me up..... what's the lead time. steve iflyrv10.com -------------------------------------------------- From: "geoff Combs" <g.combs58(at)yahoo.com> Sent: Thursday, March 26, 2009 11:05 PM Subject: RV10-List: Rv-10 Carbon panels > > I was asked to post when carbon panels were available. The panels are > for sale at this time. They are available thru Steinair or Direct from > myself. Pricing is available on Steinair or call 614-834-5227 day or > 614-519-4439eve. Price for entire set is $1150.00. > > -------- > Build QB RV-10 N829GW > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236317#236317 > > > > > Attachments: > > http://forums.matronics.com//files/carbonrv10_111.jpg > http://forums.matronics.com//files/carbonpanel_151.jpg > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2009
Subject: Re: Fuel & Oil line torque values - help ???
Aviation 37 degree flare fittings should need no sealant. On Thu, Mar 26, 2009 at 10:05 PM, AirMike wrote: > > I was told to use a high temp permatex thread sealer on the fuel and oil lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor hoses. > What are the torque values on these aeroquip hoses (fuel & oil)???? > > Also - Alert note......................I got my FWF kit in the summer of '07. My VA190 hose was of the wrong diameter. I would suggest that people who got their FWF kits about then check the hose to make sure that it was right. I sent back the defective hose and Gus very kindly sent me the proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller exterior nut - it is the wrong size. > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236318#236318 > > ________________________________________________________________________________
Date: Mar 27, 2009
Normal Lead time is 10-12 days. I have one in stock at this time. Geoff -------- Build QB RV-10 N829GW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=236340#236340 ________________________________________________________________________________
Date: Mar 27, 2009
Geoff, Do you have a drawing of the panel, preferably an autocad dwg, that you could send me? Larry Rosen ________________________________________________________________________________
Date: Mar 27, 2009
http://www.vansaircraft.com/pdf/Torque_Spec_Aluminum_Fittings.pdf Pascal -------------------------------------------------- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Thursday, March 26, 2009 7:05 PM Subject: RV10-List: Fuel & Oil line torque values - help ??? > > I was told to use a high temp permatex thread sealer on the fuel and oil > lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor > hoses. > What are the torque values on these aeroquip hoses (fuel & oil)???? > > Also - Alert note......................I got my FWF kit in the summer of > '07. My VA190 hose was of the wrong diameter. I would suggest that people > who got their FWF kits about then check the hose to make sure that it was > right. I sent back the defective hose and Gus very kindly sent me the > proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller > exterior nut - it is the wrong size. > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=236318#236318 > > > ________________________________________________________________________________
Date: Mar 27, 2009
AirMike, I've had the below page up since before 2007 and while I love to support Vans, builder should EXCLUDE all the hoses from the Vans FWF kit and instead order the all Teflon hose kit with integral fire-sleeve from aircrafthose.com. You get much better hoses for less than or about the same price as the non fire-sleeve hoses in the Vans kit. http://nerv10.com/wcurtis/20Engine/hose.html William http://nerv10.com/wcurtis/ -------- Original Message -------- > > I was told to use a high temp permatex thread sealer on the fuel and oil lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor hoses. > What are the torque values on these aeroquip hoses (fuel & oil)???? > > Also - Alert note......................I got my FWF kit in the summer of '07. My VA190 hose was of the wrong diameter. I would suggest that people who got their FWF kits about then check the hose to make sure that it was right. I sent back the defective hose and Gus very kindly sent me the proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller exterior nut - it is the wrong size. > > -------- > OSH '08 or Bust (busted) be there in "09 > Q/B Kit - wiring and FWF ________________________________________________________________________________
Date: Mar 27, 2009
Geoff you mentioned you did it in Solidworks. Will you allow that program output to be printed for placement of other devices? Will you price separately the console and lower unit for Old Men who cry? As I said before your price was dead on. I love the competition, quality improvement and pricing. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, March 27, 2009 7:56 AM Subject: Re: RV10-List: Re: Rv-10 Carbon panels Geoff, Do you have a drawing of the panel, preferably an autocad dwg, that you could send me? Larry Rosen ________________________________________________________________________________
Date: Mar 27, 2009
No disagreement in having the firesleeve hoses, however, just to clarify, the price gap is very significant when all added up- close to $200 on $569 of Aircrafthose.com hoses. That difference in based on the webstore and not the kit credits one would receive, so there may be an even larger gap. Van's runs the hoses they have in the kit in their own aircraft. They have shown no issues thus far, with that said if someone thinks manifold and oil cooler hoses need the extra firesleeve protection that is money well spent going with the aircrafthose.com setup. Here is the breakdown on my numbers: PHT Van's price VA119/ 111417-4S0214 30.76 17 VA-102/ 124J001-4CR0154 68.36 15.50 VA-133/ 124J001-4CR0272 79.12 18.25 VA-138/ 124J001-6CR0140 78.14 63.30 VA-189/ 124J002-6CR0254 104.96 100.50 VA-135/ 124J001-8CR0164 95.68 64.40 VA-190/ 124J001-8CR0270 111.92 97.65 ------------------------------------------------------------------------------------------ total $568.94 $376.60 Delivery is 2 to 3 days Van's hoses page: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1238176072-388-450&browse=engines&product=hoses Pascal -------------------------------------------------- From: "William Curtis" <wcurtis(at)nerv10.com> Sent: Friday, March 27, 2009 8:42 AM Subject: re: RV10-List: Fuel & Oil line torque values - help ??? > > AirMike, > > I've had the below page up since before 2007 and while I love to support > Vans, builder should EXCLUDE all the hoses from the Vans FWF kit and > instead order the all Teflon hose kit with integral fire-sleeve from > aircrafthose.com. You get much better hoses for less than or about the > same price as the non fire-sleeve hoses in the Vans kit. > > http://nerv10.com/wcurtis/20Engine/hose.html > > William > http://nerv10.com/wcurtis/ > > -------- Original Message -------- >> >> I was told to use a high temp permatex thread sealer on the fuel and oil > lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor > hoses. >> What are the torque values on these aeroquip hoses (fuel & oil)???? >> >> Also - Alert note......................I got my FWF kit in the summer of > '07. My VA190 hose was of the wrong diameter. I would suggest that people > who got their FWF kits about then check the hose to make sure that it was > right. I sent back the defective hose and Gus very kindly sent me the > proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller > exterior nut - it is the wrong size. >> >> -------- >> OSH '08 or Bust (busted) be there in "09 >> Q/B Kit - wiring and FWF > > > ________________________________________________________________________________
Date: Mar 27, 2009
I believe the consoles will be/are available separately from the panel - at least I've priced them that way! Cheers, Stein >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of John Cox >Sent: Friday, March 27, 2009 12:30 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Re: Rv-10 Carbon panels > > >Geoff you mentioned you did it in Solidworks. Will you allow that >program output to be printed for placement of other devices? Will you >price separately the console and lower unit for Old Men who cry? As I >said before your price was dead on. I love the competition, quality >improvement and pricing. > >John Cox > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen >Sent: Friday, March 27, 2009 7:56 AM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Re: Rv-10 Carbon panels > > >Geoff, >Do you have a drawing of the panel, preferably an autocad dwg, that you >could send me? > >Larry Rosen > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Mar 27, 2009
Here are the .DWG file for the panel cut outs Geoff Combs President Aerosport Modeling & Design 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Friday, March 27, 2009 1:30 PM Subject: RE: RV10-List: Re: Rv-10 Carbon panels Geoff you mentioned you did it in Solidworks. Will you allow that program output to be printed for placement of other devices? Will you price separately the console and lower unit for Old Men who cry? As I said before your price was dead on. I love the competition, quality improvement and pricing. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, March 27, 2009 7:56 AM Subject: Re: RV10-List: Re: Rv-10 Carbon panels Geoff, Do you have a drawing of the panel, preferably an autocad dwg, that you could send me? Larry Rosen ________________________________________________________________________________
Date: Mar 27, 2009
Geoff I am totally impressed with your product. I am a long ways from needing one but when the fuselage is done ready for the panel I will for sure look you up. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs Sent: Friday, March 27, 2009 1:13 PM Subject: RE: RV10-List: Re: Rv-10 Carbon panels Here are the .DWG file for the panel cut outs Geoff Combs President Aerosport Modeling & Design 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Friday, March 27, 2009 1:30 PM Subject: RE: RV10-List: Re: Rv-10 Carbon panels Geoff you mentioned you did it in Solidworks. Will you allow that program output to be printed for placement of other devices? Will you price separately the console and lower unit for Old Men who cry? As I said before your price was dead on. I love the competition, quality improvement and pricing. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen Sent: Friday, March 27, 2009 7:56 AM Subject: Re: RV10-List: Re: Rv-10 Carbon panels Geoff, Do you have a drawing of the panel, preferably an autocad dwg, that you could send me? Larry Rosen ________________________________________________________________________________
Date: Mar 27, 2009
Ok here is my 2 cents worth. All hoses fwd of the firewall that transport flammable liquids must have fire sleeve. I have seen when a fire starts with out fire sleeve and it is a lot worse then hoses with fire sleeve. And the additional cost for Teflon hoses with fire sleeve is the best way to go. There longer live and do not require a time in service change like the rubber hoses do. I have seen several rubber hoses break due to people not changing them and it usually means a off air port landing not a good thing. My butt and the airplane is worth the difference in Teflon - vs- rubber hoses and always include fire sleeve on all fluid hoses. We all will have over $100k invested in our projects why scrimp on something that has the potential of causing loss of aircraft or loss of life. That's just plane stupid. OK That's my 2 cents worth John Cumins A&P Horz stab assy. N864FN reverved ----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Friday, March 27, 2009 12:03 PM Subject: Re: RV10-List: Fuel & Oil line torque values - help ??? No disagreement in having the firesleeve hoses, however, just to clarify, the price gap is very significant when all added up- close to $200 on $569 of Aircrafthose.com hoses. That difference in based on the webstore and not the kit credits one would receive, so there may be an even larger gap. Van's runs the hoses they have in the kit in their own aircraft. They have shown no issues thus far, with that said if someone thinks manifold and oil cooler hoses need the extra firesleeve protection that is money well spent going with the aircrafthose.com setup. Here is the breakdown on my numbers: PHT Van's price VA119/ 111417-4S0214 30.76 17 VA-102/ 124J001-4CR0154 68.36 15.50 VA-133/ 124J001-4CR0272 79.12 18.25 VA-138/ 124J001-6CR0140 78.14 63.30 VA-189/ 124J002-6CR0254 104.96 100.50 VA-135/ 124J001-8CR0164 95.68 64.40 VA-190/ 124J001-8CR0270 111.92 97.65 ---------------------------------------------------------------------------- -------------- total $568.94 $376.60 Delivery is 2 to 3 days Van's hoses page: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1238176072-388-450&bro wse=engines&product=hoses Pascal -------------------------------------------------- From: "William Curtis" <wcurtis(at)nerv10.com> Sent: Friday, March 27, 2009 8:42 AM Subject: re: RV10-List: Fuel & Oil line torque values - help ??? > > AirMike, > > I've had the below page up since before 2007 and while I love to support > Vans, builder should EXCLUDE all the hoses from the Vans FWF kit and > instead order the all Teflon hose kit with integral fire-sleeve from > aircrafthose.com. You get much better hoses for less than or about the > same price as the non fire-sleeve hoses in the Vans kit. > > http://nerv10.com/wcurtis/20Engine/hose.html > > William > http://nerv10.com/wcurtis/ > > -------- Original Message -------- >> >> I was told to use a high temp permatex thread sealer on the fuel and oil > lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor > hoses. >> What are the torque values on these aeroquip hoses (fuel & oil)???? >> >> Also - Alert note......................I got my FWF kit in the summer of > '07. My VA190 hose was of the wrong diameter. I would suggest that people > who got their FWF kits about then check the hose to make sure that it was > right. I sent back the defective hose and Gus very kindly sent me the > proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller > exterior nut - it is the wrong size. >> >> -------- >> OSH '08 or Bust (busted) be there in "09 >> Q/B Kit - wiring and FWF > > > ________________________________________________________________________________
Date: Mar 27, 2009
Pascal, I won't dispute your math but in Aug '07 I received a $584.60 credit from Van's for excluding the hoses in the Firewall Forward kit and then paid $450 to aircrafthost.com for the better hoses in their RV-10 kit. This amount excluded the VA-189 hose since this was included with my TMX-IO-540. These were the prices then, I guess Van's has reduced the prices on the FWF kit hoses considerably. IMHO, the kit from aircrafthose.com is still much better and arguably worth the additional $200. IE VMP INSTALL KIT FITTINGS/HOSES (VA-119, AN924-4D, ED SPACER, PT 094X156) $55.00 VA-102 FUEL PRES. HOSE 15.5 $51.00 VA-133 OIL PRESS. HOSE 27.25 $61.00 VA-135 OIL COOLER HOSE 16.5 $83.00 VA-190 OIL COOLER HOSE 27" $130.00 VA-138 FUEL SUPPLY HOSE 14.0 $78.50 VA-189 FUEL LINE IO-540 25.5 $126.10 Ya pays your money and ya takes your chances. William http://nerv10.com/wcurtis/ -------- Original Message -------- > X-Rcpt-To: > X-SmarterMail-TotalSpamWeight: 0 > > > No disagreement in having the firesleeve hoses, however, just to clarify, > the price gap is very significant when all added up- close to $200 on $569 > of Aircrafthose.com hoses. > That difference in based on the webstore and not the kit credits one would > receive, so there may be an even larger gap. > Van's runs the hoses they have in the kit in their own aircraft. They have > shown no issues thus far, with that said if someone thinks manifold and oil > cooler hoses need the extra firesleeve protection that is money well spent > going with the aircrafthose.com setup. > Here is the breakdown on my numbers: > > PHT Van's price > > VA119/ 111417-4S0214 30.76 17 > VA-102/ 124J001-4CR0154 68.36 15.50 > VA-133/ 124J001-4CR0272 79.12 18.25 > VA-138/ 124J001-6CR0140 78.14 63.30 > VA-189/ 124J002-6CR0254 104.96 100.50 > VA-135/ 124J001-8CR0164 95.68 64.40 > VA-190/ 124J001-8CR0270 111.92 97.65 > ---------------------------------------------------------------------------- -------------- > total > $568.94 $376.60 > > Delivery is 2 to 3 days > > Van's hoses page: > http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1238176072-388-450&bro wse=engines&product=hoses > > Pascal > > -------------------------------------------------- > From: "William Curtis" <wcurtis(at)nerv10.com> > Sent: Friday, March 27, 2009 8:42 AM > To: > Subject: re: RV10-List: Fuel & Oil line torque values - help ??? > > > > > AirMike, > > > > I've had the below page up since before 2007 and while I love to support > > Vans, builder should EXCLUDE all the hoses from the Vans FWF kit and > > instead order the all Teflon hose kit with integral fire-sleeve from > > aircrafthose.com. You get much better hoses for less than or about the > > same price as the non fire-sleeve hoses in the Vans kit. > > > > http://nerv10.com/wcurtis/20Engine/hose.html > > > > William > > http://nerv10.com/wcurtis/ > > > > -------- Original Message -------- > >> > >> I was told to use a high temp permatex thread sealer on the fuel and oil > > lines (VA190, VA135 etc) to the oil cooler
