RV10-Archive.digest.vol-ev
July 22, 2009 - August 09, 2009
Subject: Aux fuel tanks
Date: Jul 22, 2009
I was not suggesting that the 10 routinely be operated above the Van's suggested gross of 2700. It is certainly possible to operate the aircraft with considerable additional fuel on board, subject to CG, weight and structural considerations. I have set the gross for my 10 at 2800 pounds; primarily because I never want , in case of incident, to argue with FAA or insurance company, about being over gross. Having on several occasions landed a Cessna in IMC carrying a load of ice, I know it is possible to encounter conditions with payloads which are not workable. My point is that with proper planning and good judgment there are many options in the safe use of these aircraft. If one plans ahead, the versatility can be dramatically improved without significant penalty -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, July 22, 2009 4:11 PM Subject: Re: RV10-List: Aux fuel tanks The Alaskan gross wt rule is NOT available to anyone, anytime. It requires FSDO approval, generally for commercial freight, fuel and fire fighting operations. It also has consequences. A Beech 1900, IIRC crashed in Homer, a little over gross, with a load of ice picked up on approach. It is one thing to use for tankering fuel, like trans-oceanic flight where there is no intent to land overgross, and quite another to both takeoff and land overgross. One also does not know how much an acceptable flight envelope exists above the published forward and aft limits, how much narrower the range might be. Yes, you can experiment with your experimental, declare a higher gross than Van's recommends and play test pilot. Unfortunately, one -10 has already been lost, along with the builder, by making hasty changes to what was already a non-standard variant. We really need to minimize risks, lest our favorite aircraft become uninsurable. On Wed, Jul 22, 2009 at 3:29 PM, David McNeill wrote: > If you must have extra fuel and you are SB wings, then the obvious > solution is to enlargethe main tanks by moving the outboard bulkhead > out a bay or two. The CG won't shift and the wing will place less > bending moment on the spar and center carry through. Even certified > aircraft can be successfully flown and landed 10% over gross given the > FAAs own rules for Alaska operations. My understanding is that Alaska > operations will almost always have lower than standard temperatures > and therefore more power available to lift the load. The 10 is not > power limited. My 10 lifted off KPRC at 5000 MSL @ 80F in 1500 ft > ground roll at weight of 2750. Distance was calculated by the tower staff. > ________________________________ > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris and > Susie > Sent: Wednesday, July 22, 2009 2:29 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Aux fuel tanks > > Dick we have just come back from a 42 hour trip in outback Australia. > Most of the time we were fine with fuel but as another has pointed out > fuel in some areas can be extremely expensive. An extra hour range > would be great here. The option of filling further on would be great. > I have spoken to an engineer at Vans regarding making the the outer > bay of wing also fuel and his response was like other RV's it actually > strengthens the wing however other areas have to be considered like > Max weight. He would not put anything on paper. > An extra hour would be good but I don't know about an extra 60 gallons > unless you few at gross weight or under but you know what people would do! > With two 10's with gear leg collapses We do not want to fly over gross. > So Yes I would add an extra 1 hour of fuel if I were to build again > for out back flying. > > Chris > > ----- Original Message ----- > From: Richard Gurley > To: rv10-list(at)matronics.com > Sent: Wednesday, July 22, 2009 9:06 AM > Subject: RV10-List: Aux fuel tanks > > It has been a few years now that some of you have been flying. Has > anyone installed or wish they have installed aux fuel tanks. I am > currently planning the items to be installed my wings and was > wondering what the consensus was. > > > Thank you in advance. > > > Dick Gurley > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matroni > cs.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/ > c > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matroni > cs.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/ > c > > ________________________________________________________________________________
Subject: OGD or SLC
Date: Jul 23, 2009
Any suggestions for an overnight,which is preferable for a 10 enroute to osh-OGD or SLC ? -----Original Message----- From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> Sent: Tue, Jul 21, 2009 11:34 am Subject: RE: RV10-List: Re: OSH RV-10 HQ Open For Business! This is the coolest I remember at this time of year in recent history. We actually had a high in the 60's last weekend and they are forecasting it to drop back into the 70's again after today with lows in the 50's. Haven't had rain in around 3 weeks until the last couple days so the ground is like concrete. Of course the weather gods have noticed that Airventure is starting up so all bets are off for the next 12 days. They are forecasting over 2 inches of rain tonight about 60 miles NW of OSH and around .5" to 1" for around here. I've been sitting in my workshop watching it get steadily darker here. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert Brunkenhoefer Sent: Tuesday, July 21, 2009 11:50 AM Subject: Re: RV10-List: Re: OSH RV-10 HQ Open For Business! whats the weather like? robert On Jul 20, 2009, at 9:38 PM, bcondrey wrote: > > > > For those wondering about attendance, from what we can see in Camp > Scholler it looks like there are more people here than at this time > last year. > > Weather conditions have been very dry here - grass is long and a > little crunchy. Fortunately, Michael Sausen has again dropped off a > lawn mower for use. > > WiFi appears to be working great for me so far. Others have > reported issues so we'll just have to see. > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254043#254043 > > load, 7-Day Browse, Chat, FAQ, ________________________________________________________________________________
Subject: Re: OGD or SLC
Date: - - - , 20-
Ogden is nice and less busy. There is a nice FBO on the south side called Kemp Jet Services. The manager's name is Russ. They also have hangar space and a nice deli/restaurant inside. Ogden city is not as nice as SLC in my opinion. thirty to forty minute drive to downtown SLC. When are you coming out? ----- Original Message ----- From: pilotdds(at)aol.com To: rv10-list(at)matronics.com Sent: Thursday, July 23, 2009 8:07 AM Subject: RV10-List: OGD or SLC Any suggestions for an overnight,which is preferable for a 10 enroute to osh-OGD or SLC ? -----Original Message----- From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> To: rv10-list(at)matronics.com Sent: Tue, Jul 21, 2009 11:34 am Subject: RE: RV10-List: Re: OSH RV-10 HQ Open For Business! This is the coolest I remember at this time of year in recent history. We actually had a high in the 60's last weekend and they are forecasting it to drop back into the 70's again after today with lows in the 50's. Haven't had rain in around 3 weeks until the last couple days so the ground is like concrete. Of course the weather gods have noticed that Airventure is starting up so all bets are off for the next 12 days. They are forecasting over 2 inches of rain tonight about 60 miles NW of OSH and around .5" to 1" for around here. I've been sitting in my workshop watching it get steadily darker here. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert Brunkenhoefer Sent: Tuesday, July 21, 2009 11:50 AM Subject: Re: RV10-List: Re: OSH RV-10 HQ Open For Business! whats the weather like? robert On Jul 20, 2009, at 9:38 PM, bcondrey wrote: > > > For those wondering about attendance, from what we can see in Camp > Scholler it looks like there are more people here than at this time > last year. > > Weather conditions have been very dry here - grass is long and a > little crunchy. Fortunately, Michael Sausen has again dropped off a > lawn mower for use. > > WiFi appears to be working great for me so far. Others have > reported issues so we'll just have to see. > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254043#254043 > > ________________________________________________________________________________
Date: Jul 23, 2009
If you fly into SLC I will drag you out to my shop to buck rivits. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254480#254480 ________________________________________________________________________________
From: "Richard Barnes" <rickbarnes(at)highlanddental.com>
Date: Jul 23, 2009
Subject: OGD or SLC
Michael, When are you coming through the area? We are at Bountiful Skypark (KBTF). It's between Ogden and SLC. Easy in and out. We might have a place for you to stay at the airport. Let us know. Rick From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Thursday, July 23, 2009 8:08 AM Subject: RV10-List: OGD or SLC Any suggestions for an overnight,which is preferable for a 10 enroute to osh-OGD or SLC ? -----Original Message----- From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> Sent: Tue, Jul 21, 2009 11:34 am Subject: RE: RV10-List: Re: OSH RV-10 HQ Open For Business! This is the coolest I remember at this time of year in recent history. We actually had a high in the 60's last weekend and they are forecasting it to drop back into the 70's again after today with lows in the 50's. Haven't had rain in around 3 weeks until the last couple days so the ground is like concrete. Of course the weather gods have noticed that Airventure is starting up so all bets are off for the next 12 days. They are forecasting over 2 inches of rain tonight about 60 miles NW of OSH and around .5" to 1" for around here. I've been sitting in my workshop watching it get steadily darker here. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of Robert Brunkenhoefer Sent: Tuesday, July 21, 2009 11:50 AM Subject: Re: RV10-List: Re: OSH RV-10 HQ Open For Business! whats the weather like? robert On Jul 20, 2009, at 9:38 PM, bcondrey wrote: > > > > For those wondering about attendance, from what we can see in Camp > Scholler it looks like there are more people here than at this time > last year. > > Weather conditions have been very dry here - grass is long and a > little crunchy. Fortunately, Michael Sausen has again dropped off a > lawn mower for use. > > WiFi appears to be working great for me so far. Others have > reported issues so we'll just have to see. > > Bob > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254043#254043 > > > > > > > > > > ________________________________________________________________________________
Subject: plan confusion
Date: Jul 23, 2009
Section 28-2 step 2. What are they talking about????? The nutplates are already installed on the fwd fuselage ribs. The angles have nutplates installed in the next few steps. The plans tell me to Machine Cntrsnk the inside of the fwd fuse ribs for a 426ad3 rivet. There are no holes for this??? The angle attaches using 30 size holes. -------- Cust. #40936 A&P, ATP typed CE-525(s), CE-500 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254487#254487 ________________________________________________________________________________
Subject: OSH
Date: Jul 23, 2009
The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. ________________________________________________________________________________
Date: Jul 23, 2009
BTF would be my choice if lodging is acceptable, and you don't mind making your approach over refinery. Ogden is nice. On Thu, Jul 23, 2009 at 7:59 AM, Richard Barnes wrote: > Michael, > > > When are you coming through the area? We are at Bountiful Skypark (KBTF). > Its between Ogden and SLC. Easy in and out. We might have a place for > you to stay at the airport. Let us know. > > > Rick > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com > Sent: Thursday, July 23, 2009 8:08 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: OGD or SLC > > > Any suggestions for an overnight,which is preferable for a 10 enroute to > osh-OGD or SLC ? > > > -----Original Message----- > From: RV Builder (Michael Sausen) <rvbuilder(at)sausen.net> > To: rv10-list(at)matronics.com > Sent: Tue, Jul 21, 2009 11:34 am > Subject: RE: RV10-List: Re: OSH RV-10 HQ Open For Business! > > > > > > This is the coolest I remember at this time of year in recent history. We > > actually had a high in the 60's last weekend and they are forecasting it to > drop > > back into the 70's again after today with lows in the 50's. Haven't had > rain in > > around 3 weeks until the last couple days so the ground is like concrete. > Of > > course the weather gods have noticed that Airventure is starting up so all > bets > > are off for the next 12 days. They are forecasting over 2 inches of rain > > tonight about 60 miles NW of OSH and around .5" to 1" for around here. I've > > been sitting in my workshop watching it get steadily darker here. > > > Michael > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] > > On Behalf Of Robert Brunkenhoefer > > Sent: Tuesday, July 21, 2009 11:50 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Re: OSH RV-10 HQ Open For Business! > > > whats the weather like? robert > > On Jul 20, 2009, at 9:38 PM, bcondrey wrote: > > >> > > >> > >> For those wondering about attendance, from what we can see in Camp > >> Scholler it looks like there are more people here than at this time > >> last year. > >> > >> Weather conditions have been very dry here - grass is long and a > >> little crunchy. Fortunately, Michael Sausen has again dropped off a > >> lawn mower for use. > >> > >> WiFi appears to be working great for me so far. Others have > >> reported issues so we'll just have to see. > >> > >> Bob > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=254043#254043 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > ________________________________________________________________________________
Subject: Re: OSH
Date: Jul 23, 2009
Dave, A lot of the people camping at OSH are already on their way - give me a call and I can run through the info that I've got and give you direct contact info. 402 651 0402 Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254516#254516 ________________________________________________________________________________
Subject: Re: OSH
Date: Jul 23, 2009
We will be leaving thurs morning.Do you want remainder of the week? -----Original Message----- From: David McNeill <dlm46007(at)cox.net> Sent: Thu, Jul 23, 2009 11:29 am Subject: RV10-List: OSH The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using?all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested? a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. ________________________________________________________________________________
Subject: OGD or SLC
Date: Jul 23, 2009
I always RON at Brigham City (BMC) north of SLC. Airport is just north of town, really nice people, courtesy car, nearby motels but main attraction for me is Maddox restaurant on south edge of town. Great steaks. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jul 24, 2009
We talked at length with Vans on this issue. From memory, the wing has been designed to have some flex in it, outboard of the main tanks. While you can replace the leading edge further outboard with another tank, it stops that part of the wing from flexing. This then gives rise to a hinge point between the two tanks and creates point loads / stresses that the spar was not designed for at a center point in the wing. That's not to say it can't be done, but they do not advise it. Short term and low turbulence it would probably be ok. Long term....... It is not often that you need to carry 4 people & a whole pile of extra fuel. Vans recommendation to me was tip tanks & a ferry tank. The plane is designed for those loads. You can put a Turtlepac 66 Gal ferry tank, sitting as close to the front seats as possible. It leaves little room for baggage, but it gives you 60+66 gal = 126 gal @ 8.5 gph LOP = nearly 15 hours. How big is your bladder?? The other thing to remember is that for most of your flying you will probably be carrying around the extra weight for no gain. A removable ferry tank is probably the best way to go. Neil ________________________________________________________________________________
Subject: OSH
Date: Jul 23, 2009
If they don't want it, I'll take it. Steve Mills RV-10 630-308-7476 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Thursday, July 23, 2009 4:17 PM Subject: Re: RV10-List: OSH We will be leaving thurs morning.Do you want remainder of the week? -----Original Message----- From: David McNeill <dlm46007(at)cox.net> Sent: Thu, Jul 23, 2009 11:29 am Subject: RV10-List: OSH The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. ________________________________________________________________________________
Subject: Re: plan confusion
Date: Jul 23, 2009
Jesse, I finally figures it out. Van's changed the fuel valve and forgot to change a lot of pages in the manual. I looked far enough ahead in section 36 to show the proper holes. There are NO nutplates now that connect the angle to the fwd fuselage ribs. Thanks -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254526#254526 ________________________________________________________________________________
Subject: OSH
Date: Jul 23, 2009
go ahead , my wife will stay in house if we come. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steve Mills Sent: Thursday, July 23, 2009 2:42 PM Subject: RE: RV10-List: OSH If they don't want it, I'll take it. Steve Mills RV-10 630-308-7476 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Thursday, July 23, 2009 4:17 PM Subject: Re: RV10-List: OSH We will be leaving thurs morning.Do you want remainder of the week? -----Original Message----- From: David McNeill <dlm46007(at)cox.net> Sent: Thu, Jul 23, 2009 11:29 am Subject: RV10-List: OSH The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: OSH
Date: Jul 23, 2009
Thanks. My wife has changed her mind and will stay in house if we come. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Thursday, July 23, 2009 2:17 PM Subject: Re: RV10-List: OSH We will be leaving thurs morning.Do you want remainder of the week? -----Original Message----- From: David McNeill <dlm46007(at)cox.net> Sent: Thu, Jul 23, 2009 11:29 am Subject: RV10-List: OSH The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. ________________________________________________________________________________
Date: Jul 23, 2009
At least you are working on that section. Some of us are still on quick build hold. ;-( Kelly 40866 On Thu, Jul 23, 2009 at 3:04 PM, Strasnuts wrote: > > Jesse, I finally figures it out. Van's changed the fuel valve and forgot to change a lot of pages in the manual. I looked far enough ahead in section 36 to show the proper holes. There are NO nutplates now that connect the angle to the fwd fuselage ribs. > > Thanks > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254526#254526 > > ________________________________________________________________________________
Subject: Re: OSH
Date: Jul 23, 2009
Its yours Steve-Jim 728DD -----Original Message----- From: Steve Mills <millstees(at)ameritech.net> Sent: Thu, Jul 23, 2009 2:42 pm Subject: RE: RV10-List: OSH If they don't want it, I'll take it. ? Steve Mills RV-10 630-308-7476 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Thursday, July 23, 2009 4:17 PM Subject: Re: RV10-List: OSH We will be leaving thurs morning.Do you want remainder of the week? -----Original Message----- From: David McNeill <dlm46007(at)cox.net> Sent: Thu, Jul 23, 2009 11:29 am Subject: RV10-List: OSH The wife and kids suggest that they would like to come to OSH (after I though that this year, I would not attend). Anybody in RV10 headquarters not using?all their nights if they consider camping. I seem to remember somebody also had rooms in a house. Also someone suggested? a good place for motor home rentals. My dates there are flexible, any 2 or 3 days. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 23, 2009
Subject: Re: OSH
I'll be leaving Wednesday afternoon. Anyone want the remainder call me. Dave Lammers 319-551-2832 Steve Mills wrote: > If they don't want it, I'll take it. > > Steve Mills RV-10 > 630-308-7476 > > ------------------------------------------------------------------------ > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *pilotdds(at)aol.com > *Sent:* Thursday, July 23, 2009 4:17 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: OSH > > We will be leaving thurs morning.Do you want remainder of the week? > > > -----Original Message----- > From: David McNeill <dlm46007(at)cox.net> > To: rv10-list(at)matronics.com > Sent: Thu, Jul 23, 2009 11:29 am > Subject: RV10-List: OSH > > The wife and kids suggest that they would like to come to OSH (after I > though that this year, I would not attend). Anybody in RV10 > headquarters not using all their nights if they consider camping. I > seem to remember somebody also had rooms in a house. Also someone > suggested a good place for motor home rentals. My dates there are > flexible, any 2 or 3 days. > * > > > * > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * ________________________________________________________________________________
Subject: OGD or SLC
Date: Jul 23, 2009
Depending on where you are coming from and what route you are taking, BMC is a great choice if want to avoid the Class B around SLC. You can avoid it getting into Ogden....little bit harder for Bountiful and SLC #2. I am out of Ogden and think it is great....sorry I don't have any extra hanger space to offer....Unless you are coming through in the next day or so. I am in Las Vegas and my hanger is empty..... Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, July 23, 2009 3:24 PM Subject: RE: RV10-List: OGD or SLC I always RON at Brigham City (BMC) north of SLC. Airport is just north of town, really nice people, courtesy car, nearby motels but main attraction for me is Maddox restaurant on south edge of town. Great steaks. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jul 23, 2009
From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
Subject: Aux Fuel Tanks
If my memory is correct, some of the early aircraft were found to be flaming coffins in a crash due to fuel tanks located right behind the pilot rupturing. I would be very concerned about putting a fuel tank in the baggage compartment for that reason. In a crash you could suddenly find yourself in a gasoline shower with the slightest spark turning the cockpit into an inferno. Dave -- ~~~~~~~~~~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA ~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Jul 24, 2009
Subject: Re: Aux Fuel Tanks
This opinion, and memory, relies heavily on truthiness<http://en.wikipedia.org/wiki/Truthiness>. The fact is that any impact sufficient to rupture an in cabin tank is most likely not survivable by the occupants due to blunt force trauma. Secondly, impact sufficient to rupture a cabin tank will also have caused more damage to the wing tanks which is only a few inches from the cabin. Lastly there are many current certified aircraft (as well as the RV-12) that have fuselage fuel tanks or STCs for fuselage fuel tanks. There is an STC for a permanent baggage area fuel tank for the Cardinal RG that I currently fly. Most commercial airlines have wing center tanks under the cabin. In a past RVAtor article, Van's (Ken Krueger) has stated if builders must add additional tanks, they would prefer fuselage based tanks, rather than additional wing tanks. Your concern regarding a "gasoline shower" is only valid if you are worried about having an "excellent kadabra." William Curtis 40237 http://wcurtis.nerv10.com/ On Fri, Jul 24, 2009 at 1:27 AM, Dave Fritzsche (Building) < fritzsch(at)eskimo.com> wrote: > fritzsch(at)eskimo.com> > > If my memory is correct, some of the early aircraft were found to be > flaming coffins in a crash due to fuel tanks located right behind the pilot > rupturing. I would be very concerned about putting a fuel tank in the > baggage compartment for that reason. In a crash you could suddenly find > yourself in a gasoline shower with the slightest spark turning the cockpit > into an inferno. > Dave > > -- > ~~~~~~~~~~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > ~~~~~~~~~~~~~~~~~~~~~~~ > > ________________________________________________________________________________
Subject: Oil question
Date: Jul 24, 2009
Every year at this time, attendees begin looking for cheapest fuel and cheap oil for their long pilgrimage to/from Aviation Mecca. Some have mentioned offline about Sky geeks. Check out www.oil-store.com Cheaper than the geeks and you can get it in the easier to transport and pour 1 gal jugs. Also delivered right to your door. Cheers, [John C] forwarded from another of my friends. ________________________________________________________________________________
Date: Jul 24, 2009
The RV-12 has just received FAA certification as a Light Sport and complete kits are now being readied for shipment to those who have passion for such things. Just a note before shifting entirely into RV-10 issues for OSH. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Thursday, July 23, 2009 10:27 PM Subject: RV10-List: Aux Fuel Tanks If my memory is correct, some of the early aircraft were found to be flaming coffins in a crash due to fuel tanks located right behind the pilot rupturing. I would be very concerned about putting a fuel tank in the baggage compartment for that reason. In a crash you could suddenly find yourself in a gasoline shower with the slightest spark turning the cockpit into an inferno. Dave -- ~~~~~~~~~~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA ~~~~~~~~~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Jul 24, 2009
Subject: Re: OSH
Saw a white and red RV-10 taxi in on the OSH365 web cam a few minutes ago. Kind of neat, although not much traffic right now. ________________________________________________________________________________
Date: Jul 24, 2009
Subject: Inbound
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
We departed O22 in the Sierra foothills this morning at 0530, made one stop in Brigham City, UT for gas, and are now overnighting in Aberdeen. We should be in tomorrow before noon. 1076 miles in 10 hours...cool. -- Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Subject: Re: Inbound
Date: Jul 24, 2009
Dave, I'd say the numbers are disappointing -- unless you spent a fair amount of time on the ground at the fuel stop. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254638#254638 ________________________________________________________________________________
Date: Jul 24, 2009
Oh yeah, two hour time difference...8 hours...and I was happy with 10! Dave On Fri, Jul 24, 2009 at 6:23 PM, Bob Turner wrote: > > Dave, > > I'd say the numbers are disappointing -- unless you spent a fair amount of > time on the ground at the fuel stop. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254638#254638 > > -- Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: Jul 24, 2009
Subject: Re: IFR route to OSH from Southeast
If IFR, you can file whatever you want but it is probably easier to just put Direct KOSH in your flight plan because they are going to give you what they want anyhow. Last time I went in IFR from the East, they had everyone lined up going PMM MKG FAK KOSH and even had me and 3 other planes in a hold at 30 miles on the 296 radial of the MKG VOR-yes this is over the lake. Three planes 1,000 feet apart over the lake in a hold. Weather was IMC and they needed to space traffic. Was uneventful however. If you go VFR, suggest under the Class B (< 3000 FT.) up the Chicago lake coast--CGT NILES LAIRD HEDOT RIPON FISKE KOSH. This can get busy, especially if later in the week as other planes are returning from OSH, but it also offers a nice view of the Chicago skyline. William 40237 http://wcurtis.nerv10.com/ On Fri, Jul 24, 2009 at 7:37 PM, Dave Leikam wrote: > > Thunderbirds are in Milwaukee also. > > Dave Leikam > RV-10 #40496 > N89DA > Muskego, WI > > ----- Original Message ----- From: "Linn Walters" < > pitts_pilot(at)bellsouth.net> > To: > Sent: Friday, July 24, 2009 3:39 PM > Subject: Re: RV10-List: IFR route to OSH from Southeast > > >> >> John, I fly out over the lake .... (all three times) ..... but check the >> notams ..... Thunderbirds are at Chicago. >> Linn >> >> John Testement wrote: >> >>> I am planning my flight from VA and deciding whether to go West of >>> Chicago airspace (way out of the way) or fly over the lake. If anyone has >>> experience or advice on the best route to OSH from the Southeast, your >>> comments would be welcome. >>> >>> >>> John Testement >>> >>> N311RV >>> >>> Richmond, VA >>> >>> ________________________________________________________________________________
Date: Jul 24, 2009
Yeah, that's only about 100 Kts. I made it from eastern PA to New Orleans (~960nm) in my 145kt Cardinal in about 7 hours flying time. William http://wcurtis.nerv10.com/ On Fri, Jul 24, 2009 at 9:23 PM, Bob Turner wrote: > > Dave, > > I'd say the numbers are disappointing -- unless you spent a fair amount of > time on the ground at the fuel stop. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254638#254638 > > ________________________________________________________________________________
Subject: Navworx ADS600
Date: Jul 25, 2009
Anybody seen any deals on this at OSH; I presume they have a booth. http://www.navworx.com/ads600-displays.html ________________________________________________________________________________
Subject: Re: Navworx ADS600
Date: Jul 25, 2009
They have a booth at OSH. I didn't hear well enough if it was hangar B or D that they were in, so you'll have to check the guide, but they're here. Tim On Jul 25, 2009, at 12:27 PM, "David McNeill" wrote: > Anybody seen any deals on this at OSH; I presume they have a booth. > http://www.navworx.com/ads600-displays.html > > ________________________________________________________________________________
Date: Jul 25, 2009
but I am not; can someone on their travels visit the booth for any specials? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Saturday, July 25, 2009 11:10 AM Subject: Re: RV10-List: Navworx ADS600 They have a booth at OSH. I didn't hear well enough if it was hangar B or D that they were in, so you'll have to check the guide, but they're here. Tim On Jul 25, 2009, at 12:27 PM, "David McNeill" wrote: Anybody seen any deals on this at OSH; I presume they have a booth. <http://www.navworx.com/ads600-displays.html> http://www.navworx.com/ads600-displays.html ________________________________________________________________________________
Subject: More fun with rebuilt engines
Date: Jul 26, 2009
I attempted to unbugger a couple of spark plug holes on my rebuilt engine (not yet run) using a chip chaser. It's obvious that a couple of holes need new heli-coils as the chip chaser wouldn't go in easily and some of the heli-coil came out. Any advice on how to proceed? I've not done this sort of thing before and like most things I'm sure it's not a big deal the second time around. There's a Lyco SB 1043A on heli-coil replacement, but I haven't been able to find it using internet search. This link has a couple of repair kit options (some are expen$sive). http://www.skygeek.com/heli-coil-screw-thread-inserts.html Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254807#254807 ________________________________________________________________________________
Subject: Re: More fun with rebuilt engines
Date: Jul 26, 2009
I think most chip chasers are generally not recommended for this use. For next time, Snap-On (who else?) makes a very special tool for cleaning out spark plug helicoils. You turn an internal bolt and the whole thing collapses inwards. You can then insert it into the cylinder, turn the bolt the other way and expand it back out, then clean the threads from inside to the outside as you screw it out. This works when it's the outside of the hole that's the problem (as from cross threading and forcing plugs in). It also carries the gunk out of the cylinder, instead of into it. I've never removed a helicoil myself, but cylinder shops do this all the time. And yes, there are special insertion tools for putting in new ones. The one thing I do know is that when you're all done and break off the insertion tang, you want to be sure there is no sharp point left on the inside, where it could act as a glow plug and cause pre-ignition. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254819#254819 ________________________________________________________________________________
Subject: RV10 HQ in full swing
Date: Jul 26, 2009
For all you folks who are around OSH, come on by the HQ! The food is fantastic...thanks to Bog, Gary, and crew. For those missing out...what the heck are you missing this for!?!? Tim ________________________________________________________________________________
Subject: Re: RV10 HQ in full swing
Date: Jul 26, 2009
As one of the new guys - this would be a great opportunity for me to meet the people behind the screen names on the list :) . Won't be getting in until next Thursday but will try to stop by either Thursday or Friday evening. Regards, Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254840#254840 ________________________________________________________________________________
Date: Jul 26, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Expect another event Fri evening! Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Sun Jul 26 19:16:16 2009 Subject: RV10-List: Re: RV10 HQ in full swing As one of the new guys - this would be a great opportunity for me to meet the people behind the screen names on the list :) . Won't be getting in until next Thursday but will try to stop by either Thursday or Friday evening. Regards, Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254840#254840 ________________________________________________________________________________
Date: Jul 26, 2009
I changed my mind and will be there Thursday morning through Saturday air show. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Sunday, July 26, 2009 7:23 PM Subject: Re: RV10-List: Re: RV10 HQ in full swing --> Expect another event Fri evening! Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com Sent: Sun Jul 26 19:16:16 2009 Subject: RV10-List: Re: RV10 HQ in full swing As one of the new guys - this would be a great opportunity for me to meet the people behind the screen names on the list :) . Won't be getting in until next Thursday but will try to stop by either Thursday or Friday evening. Regards, Bill Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254840#254840 ________________________________________________________________________________
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jul 26, 2009
I'll be there from Thursday onwards with my wife (first time Osh for her). Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? Cheers Michael & Irene wellenzohn.net -------- RV-10 builder (avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254861#254861 ________________________________________________________________________________
Date: Jul 27, 2009
Absolutely? We're up to 800 sq ft of shade and have plenty of seats. I imagine you'd also find that the chocolate would be a hit. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Sun Jul 26 23:55:24 2009 Subject: RV10-List: Re: RV10 HQ in full swing I'll be there from Thursday onwards with my wife (first time Osh for her). Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? Cheers Michael & Irene wellenzohn.net -------- RV-10 builder (avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254861#254861 ________________________________________________________________________________
Date: Jul 27, 2009
Is the shuttle service from the main display area to Camp Scholler frequent? Where are most of the 10s parked? Condrey, Bob (US SSA) wrote: > > Absolutely? We're up to 800 sq ft of shade and have plenty of seats. I imagine you'd also find that the chocolate would be a hit. > > Bob > > ----- Original Message ----- > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> > To: rv10-list(at)matronics.com > Sent: Sun Jul 26 23:55:24 2009 > Subject: RV10-List: Re: RV10 HQ in full swing > > > I'll be there from Thursday onwards with my wife (first time Osh for her). > Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). > Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? > > Cheers > Michael & Irene > > wellenzohn.net > > -------- > RV-10 builder (avionics, wiring) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254861#254861 > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 27, 2009
Regular shuttles run constantly. Yellow shuttle stops at Theater in the Woods. From there it's a 5 minute walk to our HQ. The -10s are parked just west of the red shuttle warbird stop. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Mon Jul 27 05:31:36 2009 Subject: Re: RV10-List: Re: RV10 HQ in full swing Is the shuttle service from the main display area to Camp Scholler frequent? Where are most of the 10s parked? Condrey, Bob (US SSA) wrote: > > Absolutely? We're up to 800 sq ft of shade and have plenty of seats. I imagine you'd also find that the chocolate would be a hit. > > Bob > > ----- Original Message ----- > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> > To: rv10-list(at)matronics.com > Sent: Sun Jul 26 23:55:24 2009 > Subject: RV10-List: Re: RV10 HQ in full swing > > > I'll be there from Thursday onwards with my wife (first time Osh for her). > Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). > Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? > > Cheers > Michael & Irene > > wellenzohn.net > > -------- > RV-10 builder (avionics, wiring) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254861#254861 > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 27, 2009
You guys are killing us.....- at least those of us that can't make it thi s year....- My wife and I went last year for our first times.... flew com mercially.... and I think there were around 110 RV10's flying... now one ye ar later, I think the number is around 220.- So depending on how you work the numbers we'll either add another 110, or double the 220.... at any rat e I suspect we'll have at least-over 300 flying 10's by next years Osh. - Count us in for next year for sure. Don & Kim McDonald --- On Mon, 7/27/09, Condrey, Bob (US SSA) wro te: From: Condrey, Bob (US SSA) <bob.condrey(at)baesystems.com> Subject: Re: RV10-List: Re: RV10 HQ in full swing Date: Monday, July 27, 2009, 3:55 AM stems.com> Absolutely?- We're up to 800 sq ft of shade and have plenty of seats.- I imagine you'd also find that the chocolate would be a hit. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server@matronic s.com> Sent: Sun Jul 26 23:55:24 2009 Subject: RV10-List: Re: RV10 HQ in full swing > I'll be there from Thursday onwards with my wife (first time Osh for her). Would it be OK to find some rest in the HQ since my wife broke her foot 4 d ays ago). Is there any need for Swiss chocolate or other stuff which I can easily bri ng from Switzerland for you guys? Cheers Michael & Irene wellenzohn.net -------- RV-10 builder (avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=254861#254861 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jul 27, 2009
RV10 HQ. Same place as last year? Have an IFR in for 12z Thursday. Where are the 10s parking? Easy out for Sat evening? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, July 27, 2009 5:32 AM Subject: Re: RV10-List: Re: RV10 HQ in full swing Is the shuttle service from the main display area to Camp Scholler frequent? Where are most of the 10s parked? Condrey, Bob (US SSA) wrote: > --> > > Absolutely? We're up to 800 sq ft of shade and have plenty of seats. I imagine you'd also find that the chocolate would be a hit. > > Bob > > ----- Original Message ----- > From: owner-rv10-list-server(at)matronics.com > > To: rv10-list(at)matronics.com > Sent: Sun Jul 26 23:55:24 2009 > Subject: RV10-List: Re: RV10 HQ in full swing > > --> > > I'll be there from Thursday onwards with my wife (first time Osh for her). > Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). > Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? > > Cheers > Michael & Irene > > wellenzohn.net > > -------- > RV-10 builder (avionics, wiring) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254861#254861 > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: Robert Brunkenhoefer <rebrunk42(at)gmail.com>
Date: Jul 27, 2009
should i fly in to osh instead of fond du lac? will be arriving after 5 pm. robert On Jul 27, 2009, at 8:15 AM, David McNeill wrote: > > RV10 HQ. Same place as last year? Have an IFR in for 12z Thursday. > Where are > the 10s parking? Easy out for Sat evening? > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly > McMullen > Sent: Monday, July 27, 2009 5:32 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV10 HQ in full swing > > > Is the shuttle service from the main display area to Camp Scholler > frequent? > Where are most of the 10s parked? > > Condrey, Bob (US SSA) wrote: >> --> >> >> Absolutely? We're up to 800 sq ft of shade and have plenty of >> seats. I > imagine you'd also find that the chocolate would be a hit. >> >> Bob >> >> ----- Original Message ----- >> From: owner-rv10-list-server(at)matronics.com >> >> To: rv10-list(at)matronics.com >> Sent: Sun Jul 26 23:55:24 2009 >> Subject: RV10-List: Re: RV10 HQ in full swing >> >> --> >> >> I'll be there from Thursday onwards with my wife (first time Osh >> for her). >> Would it be OK to find some rest in the HQ since my wife broke her >> foot 4 > days ago). >> Is there any need for Swiss chocolate or other stuff which I can >> easily > bring from Switzerland for you guys? >> >> Cheers >> Michael & Irene >> >> wellenzohn.net >> >> -------- >> RV-10 builder (avionics, wiring) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=254861#254861 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 27, 2009
i am flying in wednesday to fond du lac. will stay through saturday. am i invited to the festivities? i am a rookie at this. robert brunkenhoefer n661G rv10 165 hrs.flying and loving every minute of it On Jul 27, 2009, at 8:44 AM, Don McDonald wrote: > You guys are killing us..... at least those of us that can't make > it this year.... My wife and I went last year for our first > times.... flew commercially.... and I think there were around 110 > RV10's flying... now one year later, I think the number is around > 220. So depending on how you work the numbers we'll either add > another 110, or double the 220.... at any rate I suspect we'll have > at least over 300 flying 10's by next years Osh. Count us in for > next year for sure. > Don & Kim McDonald > > --- On Mon, 7/27/09, Condrey, Bob (US SSA) > wrote: > > From: Condrey, Bob (US SSA) <bob.condrey(at)baesystems.com> > Subject: Re: RV10-List: Re: RV10 HQ in full swing > To: rv10-list(at)matronics.com > Date: Monday, July 27, 2009, 3:55 AM > > > > > Absolutely? We're up to 800 sq ft of shade and have plenty of > seats. I imagine you'd also find that the chocolate would be a hit. > > Bob > > ----- Original Message ----- > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com > > > To: rv10-list(at)matronics.com > Sent: Sun Jul 26 23:55:24 2009 > Subject: RV10-List: Re: RV10 HQ in full swing > > > > > I'll be there from Thursday onwards with my wife (first time Osh for > her). > Would it be OK to find some rest in the HQ since my wife broke her > foot 4 days ago). > Is there any need for Swiss chocolate or other stuff which I can > easily bring from Switzerland for you guys? > > Cheers > Michael & Irene > > wellenzohn.net > > -------- > RV-10 builder (avionics, wiring) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=25t; http://www.matronics.com/contri=============== > > ________________________________________________________________________________
Date: Jul 27, 2009
WWVwLCBzdG9wIGJ5IGFueXRpbWUuIEFsbCAtMTAgZmx5ZXJzLCBidWlsZGVycyBhbmQgImFsbW9z dCIgYnVpbGRlcnMgd2VsY29tZS4NCg0KQm9iDQoNCiAgX19fX18gIA0KDQpGcm9tOiBvd25lci1y djEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbT4gDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20gPHJ2MTAtbGlzdEBtYXRy b25pY3MuY29tPiANClNlbnQ6IE1vbiBKdWwgMjcgMDc6MjI6MTkgMjAwOQ0KU3ViamVjdDogUmU6 IFJWMTAtTGlzdDogUmU6IFJWMTAgSFEgaW4gZnVsbCBzd2luZyANCg0KDQppIGFtIGZseWluZyBp biB3ZWRuZXNkYXkgdG8gZm9uZCBkdSBsYWMuIHdpbGwgc3RheSB0aHJvdWdoIHNhdHVyZGF5LiBh bSBpIGludml0ZWQgdG8gdGhlIGZlc3Rpdml0aWVzPyBpIGFtIGEgcm9va2llIGF0IHRoaXMuIHJv YmVydCBicnVua2VuaG9lZmVyICBuNjYxRyBydjEwIDE2NSBocnMuZmx5aW5nIGFuZCBsb3Zpbmcg ZXZlcnkgbWludXRlIG9mIGl0DQoNCk9uIEp1bCAyNywgMjAwOSwgYXQgODo0NCBBTSwgRG9uIE1j RG9uYWxkIHdyb3RlOg0KDQoNCllvdSBndXlzIGFyZSBraWxsaW5nIHVzLi4uLi4gIGF0IGxlYXN0 IHRob3NlIG9mIHVzIHRoYXQgY2FuJ3QgbWFrZSBpdCB0aGlzIHllYXIuLi4uICBNeSB3aWZlIGFu ZCBJIHdlbnQgbGFzdCB5ZWFyIGZvciBvdXIgZmlyc3QgdGltZXMuLi4uIGZsZXcgY29tbWVyY2lh bGx5Li4uLiBhbmQgSSB0aGluayB0aGVyZSB3ZXJlIGFyb3VuZCAxMTAgUlYxMCdzIGZseWluZy4u LiBub3cgb25lIHllYXIgbGF0ZXIsIEkgdGhpbmsgdGhlIG51bWJlciBpcyBhcm91bmQgMjIwLiAg U28gZGVwZW5kaW5nIG9uIGhvdyB5b3Ugd29yayB0aGUgbnVtYmVycyB3ZSdsbCBlaXRoZXIgYWRk IGFub3RoZXIgMTEwLCBvciBkb3VibGUgdGhlIDIyMC4uLi4gYXQgYW55IHJhdGUgSSBzdXNwZWN0 IHdlJ2xsIGhhdmUgYXQgbGVhc3Qgb3ZlciAzMDAgZmx5aW5nIDEwJ3MgYnkgbmV4dCB5ZWFycyBP c2guICBDb3VudCB1cyBpbiBmb3IgbmV4dCB5ZWFyIGZvciBzdXJlLg0KRG9uICYgS2ltIE1jRG9u YWxkDQoNCi0tLSBPbiBNb24sIDcvMjcvMDksIENvbmRyZXksIEJvYiAoVVMgU1NBKSA8Ym9iLmNv bmRyZXlAYmFlc3lzdGVtcy5jb20+IHdyb3RlOg0KDQoNCg0KCUZyb206IENvbmRyZXksIEJvYiAo VVMgU1NBKSA8Ym9iLmNvbmRyZXlAYmFlc3lzdGVtcy5jb20+DQoJU3ViamVjdDogUmU6IFJWMTAt TGlzdDogUmU6IFJWMTAgSFEgaW4gZnVsbCBzd2luZw0KCVRvOiBydjEwLWxpc3RAbWF0cm9uaWNz LmNvbQ0KCURhdGU6IE1vbmRheSwgSnVseSAyNywgMjAwOSwgMzo1NSBBTQ0KCQ0KCQ0KCS0tPiBS VjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJDb25kcmV5LCBCb2IgKFVTIFNTQSkiIDxib2Iu Y29uZHJleUBiYWVzeXN0ZW1zLmNvbSA8aHR0cDovL3VzLm1jNTM3Lm1haWwueWFob28uY29tL21j L2NvbXBvc2U/dG89Ym9iLmNvbmRyZXlAYmFlc3lzdGVtcy5jb20+ID4NCgkNCglBYnNvbHV0ZWx5 PyAgV2UncmUgdXAgdG8gODAwIHNxIGZ0IG9mIHNoYWRlIGFuZCBoYXZlIHBsZW50eSBvZiBzZWF0 cy4gIEkgaW1hZ2luZSB5b3UnZCBhbHNvIGZpbmQgdGhhdCB0aGUgY2hvY29sYXRlIHdvdWxkIGJl IGEgaGl0Lg0KCQ0KCUJvYg0KCQ0KCS0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCglGcm9t OiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPGh0dHA6Ly91cy5tYzUzNy5t YWlsLnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPW93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbT4gIDxvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPGh0dHA6Ly91 cy5tYzUzNy5tYWlsLnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPW93bmVyLXJ2MTAtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbT4gPg0KCVRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSA8aHR0cDov L3VzLm1jNTM3Lm1haWwueWFob28uY29tL21jL2NvbXBvc2U/dG89cnYxMC1saXN0QG1hdHJvbmlj cy5jb20+ICA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20gPGh0dHA6Ly91cy5tYzUzNy5tYWlsLnlh aG9vLmNvbS9tYy9jb21wb3NlP3RvPXJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPiA+DQoJU2VudDog U3VuIEp1bCAyNiAyMzo1NToyNCAyMDA5DQoJU3ViamVjdDogUlYxMC1MaXN0OiBSZTogUlYxMCBI USBpbiBmdWxsIHN3aW5nDQoJDQoJLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIk1p Y2hhZWwgV2VsbGVuem9obiIgPHJ2LTEwQHdlbGxlbnpvaG4ubmV0IDxodHRwOi8vdXMubWM1Mzcu bWFpbC55YWhvby5jb20vbWMvY29tcG9zZT90bz1ydi0xMEB3ZWxsZW56b2huLm5ldD4gPg0KCQ0K CUknbGwgYmUgdGhlcmUgZnJvbSBUaHVyc2RheSBvbndhcmRzIHdpdGggbXkgd2lmZSAoZmlyc3Qg dGltZSBPc2ggZm9yIGhlcikuDQoJV291bGQgaXQgYmUgT0sgdG8gZmluZCBzb21lIHJlc3QgaW4g dGhlIEhRIHNpbmNlIG15IHdpZmUgYnJva2UgaGVyIGZvb3QgNCBkYXlzIGFnbykuDQoJSXMgdGhl cmUgYW55IG5lZWQgZm9yIFN3aXNzIGNob2NvbGF0ZSBvciBvdGhlciBzdHVmZiB3aGljaCBJIGNh biBlYXNpbHkgYnJpbmcgZnJvbSBTd2l0emVybGFuZCBmb3IgeW91IGd1eXM/DQoJDQoJQ2hlZXJz DQoJTWljaGFlbCAmIElyZW5lDQoJDQoJd2VsbGVuem9obi5uZXQNCgkNCgktLS0tLS0tLQ0KCVJW LTEwIGJ1aWxkZXIgKGF2aW9uaWNzLCB3aXJpbmcpDQoJIzUxMQ0KCQ0KCQ0KCQ0KCQ0KCVJlYWQg dGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCgkNCglodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20v dmlld3RvcGljLnBocD9wPTI1dDsgPGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9w aWMucGhwP3A9MjU0ODYxIzI1NDg2MT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaT09 PT09PT09PT09PT09PT0NCgkNCgkNCgkNCgk8aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmln YXRvcj9SVjEwLUxpc3Q+IA0KCTxodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JW MTAtTGlzdD4gDQoNCjxodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlz dD4gDQoNCgkNCgkNCglocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JW MTAtTGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCglo cmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbQ0KCWhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24iPmh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCgkNCgkNCg0KDQoNCg0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8t PSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0 cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBT ZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAg IC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2 YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJp YnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3Qg QWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Jul 27, 2009
Same location for HQ - 55th and Lindbergh. -10s are parked just west and north across the taxiway relative to prior years. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Mon Jul 27 06:15:09 2009 Subject: RE: RV10-List: Re: RV10 HQ in full swing RV10 HQ. Same place as last year? Have an IFR in for 12z Thursday. Where are the 10s parking? Easy out for Sat evening? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, July 27, 2009 5:32 AM Subject: Re: RV10-List: Re: RV10 HQ in full swing Is the shuttle service from the main display area to Camp Scholler frequent? Where are most of the 10s parked? Condrey, Bob (US SSA) wrote: > --> > > Absolutely? We're up to 800 sq ft of shade and have plenty of seats. I imagine you'd also find that the chocolate would be a hit. > > Bob > > ----- Original Message ----- > From: owner-rv10-list-server(at)matronics.com > > To: rv10-list(at)matronics.com > Sent: Sun Jul 26 23:55:24 2009 > Subject: RV10-List: Re: RV10 HQ in full swing > > --> > > I'll be there from Thursday onwards with my wife (first time Osh for her). > Would it be OK to find some rest in the HQ since my wife broke her foot 4 days ago). > Is there any need for Swiss chocolate or other stuff which I can easily bring from Switzerland for you guys? > > Cheers > Michael & Irene > > wellenzohn.net > > -------- > RV-10 builder (avionics, wiring) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=254861#254861 > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 27, 2009
Bob, if i fly i to osh instead of fld will i be directed to park near you . robert On Jul 27, 2009, at 9:28 AM, Condrey, Bob (US SSA) wrote: > Yep, stop by anytime. All -10 flyers, builders and "almost" builders > welcome. > > Bob > > > From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com > > > To: rv10-list(at)matronics.com > Sent: Mon Jul 27 07:22:19 2009 > Subject: Re: RV10-List: Re: RV10 HQ in full swing > > i am flying in wednesday to fond du lac. will stay through saturday. > am i invited to the festivities? i am a rookie at this. robert > brunkenhoefer n661G rv10 165 hrs.flying and loving every minute of it > On Jul 27, 2009, at 8:44 AM, Don McDonald wrote: > >> You guys are killing us..... at least those of us that can't make >> it this year.... My wife and I went last year for our first >> times.... flew commercially.... and I think there were around 110 >> RV10's flying... now one year later, I think the number is around >> 220. So depending on how you work the numbers we'll either add >> another 110, or double the 220.... at any rate I suspect we'll have >> at least over 300 flying 10's by next years Osh. Count us in for >> next year for sure. >> Don & Kim McDonald >> >> --- On Mon, 7/27/09, Condrey, Bob (US SSA) > > wrote: >> >> From: Condrey, Bob (US SSA) <bob.condrey(at)baesystems.com> >> Subject: Re: RV10-List: Re: RV10 HQ in full swing >> To: rv10-list(at)matronics.com >> Date: Monday, July 27, 2009, 3:55 AM >> >> > >> >> Absolutely? We're up to 800 sq ft of shade and have plenty of >> seats. I imagine you'd also find that the chocolate would be a hit. >> >> Bob >> >> ----- Original Message ----- >> From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com >> > >> To: rv10-list(at)matronics.com >> Sent: Sun Jul 26 23:55:24 2009 >> Subject: RV10-List: Re: RV10 HQ in full swing >> >> > >> >> I'll be there from Thursday onwards with my wife (first time Osh >> for her). >> Would it be OK to find some rest in the HQ since my wife broke her >> foot 4 days ago). >> Is there any need for Swiss chocolate or other stuff which I can >> easily bring from Switzerland for you guys? >> >> Cheers >> Michael & Irene >> >> wellenzohn.net >> >> -------- >> RV-10 builder (avionics, wiring) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=25t; http://www.matronics.com/contri=============== >> >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> > > ________________________________________________________________________________
Subject: Flight Test - cart before horse?
Date: Jul 27, 2009
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Maybe I'm getting the cart before the horse, but did anyone make something like kneeboard-size flight test cards for your test period? Can I borrow your format, if yes? TDT Tim Dawson-Townsend 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jul 27, 2009
V29yZCBmcm9tIHRoZSBwbGFuZSBwYXJraW5nIGd1eXMgaXMgdGhhdCB0aGVyZSBpcyBzdWNoIGEg bGFyZ2UgdHVybm91dCB0aGF0IHRoYXQgbWF5IGhhdmUgdG8gc2h1dCBkb3duIHRoZSBmaWVsZCBz b29uISBUaGV5J3JlIG5vdyBwYXJraW5nIDIgcGxhY2UgUlZzIGluIHRoZSAtMTAgYXJlYS4uLg0K DQpCb2INCg0KICBfX19fXyAgDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbSA8b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPiANClRvOiBydjEw LWxpc3RAbWF0cm9uaWNzLmNvbSA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20+IA0KU2VudDogTW9u IEp1bCAyNyAwODowMjowMiAyMDA5DQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBSZTogUlYxMCBI USBpbiBmdWxsIHN3aW5nIA0KDQoNCkJvYiwgaWYgaSBmbHkgaSB0byBvc2ggaW5zdGVhZCBvZiBm bGQgd2lsbCBpIGJlIGRpcmVjdGVkIHRvIHBhcmsgbmVhciB5b3UgLiByb2JlcnQNCg0KT24gSnVs IDI3LCAyMDA5LCBhdCA5OjI4IEFNLCBDb25kcmV5LCBCb2IgKFVTIFNTQSkgd3JvdGU6DQoNCg0K CVllcCwgc3RvcCBieSBhbnl0aW1lLiBBbGwgLTEwIGZseWVycywgYnVpbGRlcnMgYW5kICJhbG1v c3QiIGJ1aWxkZXJzIHdlbGNvbWUuDQoJDQoJQm9iDQoNCg0KICBfX19fXyAgDQoNCglGcm9tOiBv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPG93bmVyLXJ2MTAtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbT4gDQoJVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIDxydjEwLWxp c3RAbWF0cm9uaWNzLmNvbT4gDQoJU2VudDogTW9uIEp1bCAyNyAwNzoyMjoxOSAyMDA5DQoJU3Vi amVjdDogUmU6IFJWMTAtTGlzdDogUmU6IFJWMTAgSFEgaW4gZnVsbCBzd2luZyANCgkNCg0KCWkg YW0gZmx5aW5nIGluIHdlZG5lc2RheSB0byBmb25kIGR1IGxhYy4gd2lsbCBzdGF5IHRocm91Z2gg c2F0dXJkYXkuIGFtIGkgaW52aXRlZCB0byB0aGUgZmVzdGl2aXRpZXM/IGkgYW0gYSByb29raWUg YXQgdGhpcy4gcm9iZXJ0IGJydW5rZW5ob2VmZXIgIG42NjFHIHJ2MTAgMTY1IGhycy5mbHlpbmcg YW5kIGxvdmluZyBldmVyeSBtaW51dGUgb2YgaXQNCgkNCglPbiBKdWwgMjcsIDIwMDksIGF0IDg6 NDQgQU0sIERvbiBNY0RvbmFsZCB3cm90ZToNCg0KDQpZb3UgZ3V5cyBhcmUga2lsbGluZyB1cy4u Li4uICBhdCBsZWFzdCB0aG9zZSBvZiB1cyB0aGF0IGNhbid0IG1ha2UgaXQgdGhpcyB5ZWFyLi4u LiAgTXkgd2lmZSBhbmQgSSB3ZW50IGxhc3QgeWVhciBmb3Igb3VyIGZpcnN0IHRpbWVzLi4uLiBm bGV3IGNvbW1lcmNpYWxseS4uLi4gYW5kIEkgdGhpbmsgdGhlcmUgd2VyZSBhcm91bmQgMTEwIFJW MTAncyBmbHlpbmcuLi4gbm93IG9uZSB5ZWFyIGxhdGVyLCBJIHRoaW5rIHRoZSBudW1iZXIgaXMg YXJvdW5kIDIyMC4gIFNvIGRlcGVuZGluZyBvbiBob3cgeW91IHdvcmsgdGhlIG51bWJlcnMgd2Un bGwgZWl0aGVyIGFkZCBhbm90aGVyIDExMCwgb3IgZG91YmxlIHRoZSAyMjAuLi4uIGF0IGFueSBy YXRlIEkgc3VzcGVjdCB3ZSdsbCBoYXZlIGF0IGxlYXN0IG92ZXIgMzAwIGZseWluZyAxMCdzIGJ5 IG5leHQgeWVhcnMgT3NoLiAgQ291bnQgdXMgaW4gZm9yIG5leHQgeWVhciBmb3Igc3VyZS4NCkRv biAmIEtpbSBNY0RvbmFsZA0KDQotLS0gT24gTW9uLCA3LzI3LzA5LCBDb25kcmV5LCBCb2IgKFVT IFNTQSkgPGJvYi5jb25kcmV5QGJhZXN5c3RlbXMuY29tPiB3cm90ZToNCg0KDQoNCglGcm9tOiBD b25kcmV5LCBCb2IgKFVTIFNTQSkgPGJvYi5jb25kcmV5QGJhZXN5c3RlbXMuY29tPg0KCVN1Ympl Y3Q6IFJlOiBSVjEwLUxpc3Q6IFJlOiBSVjEwIEhRIGluIGZ1bGwgc3dpbmcNCglUbzogcnYxMC1s aXN0QG1hdHJvbmljcy5jb20NCglEYXRlOiBNb25kYXksIEp1bHkgMjcsIDIwMDksIDM6NTUgQU0N CgkNCgkNCgktLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiQ29uZHJleSwgQm9iIChV UyBTU0EpIiA8Ym9iLmNvbmRyZXlAYmFlc3lzdGVtcy5jb20gPGh0dHA6Ly91cy5tYzUzNy5tYWls LnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPWJvYi5jb25kcmV5QGJhZXN5c3RlbXMuY29tPiA+DQoJ DQoJQWJzb2x1dGVseT8gIFdlJ3JlIHVwIHRvIDgwMCBzcSBmdCBvZiBzaGFkZSBhbmQgaGF2ZSBw bGVudHkgb2Ygc2VhdHMuICBJIGltYWdpbmUgeW91J2QgYWxzbyBmaW5kIHRoYXQgdGhlIGNob2Nv bGF0ZSB3b3VsZCBiZSBhIGhpdC4NCgkNCglCb2INCgkNCgktLS0tLSBPcmlnaW5hbCBNZXNzYWdl IC0tLS0tDQoJRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIDxodHRw Oi8vdXMubWM1MzcubWFpbC55YWhvby5jb20vbWMvY29tcG9zZT90bz1vd25lci1ydjEwLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb20+ICA8b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3Mu Y29tIDxodHRwOi8vdXMubWM1MzcubWFpbC55YWhvby5jb20vbWMvY29tcG9zZT90bz1vd25lci1y djEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+ID4NCglUbzogcnYxMC1saXN0QG1hdHJvbmlj cy5jb20gPGh0dHA6Ly91cy5tYzUzNy5tYWlsLnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPXJ2MTAt bGlzdEBtYXRyb25pY3MuY29tPiAgPHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIDxodHRwOi8vdXMu bWM1MzcubWFpbC55YWhvby5jb20vbWMvY29tcG9zZT90bz1ydjEwLWxpc3RAbWF0cm9uaWNzLmNv bT4gPg0KCVNlbnQ6IFN1biBKdWwgMjYgMjM6NTU6MjQgMjAwOQ0KCVN1YmplY3Q6IFJWMTAtTGlz dDogUmU6IFJWMTAgSFEgaW4gZnVsbCBzd2luZw0KCQ0KCS0tPiBSVjEwLUxpc3QgbWVzc2FnZSBw b3N0ZWQgYnk6ICJNaWNoYWVsIFdlbGxlbnpvaG4iIDxydi0xMEB3ZWxsZW56b2huLm5ldCA8aHR0 cDovL3VzLm1jNTM3Lm1haWwueWFob28uY29tL21jL2NvbXBvc2U/dG89cnYtMTBAd2VsbGVuem9o bi5uZXQ+ID4NCgkNCglJJ2xsIGJlIHRoZXJlIGZyb20gVGh1cnNkYXkgb253YXJkcyB3aXRoIG15 IHdpZmUgKGZpcnN0IHRpbWUgT3NoIGZvciBoZXIpLg0KCVdvdWxkIGl0IGJlIE9LIHRvIGZpbmQg c29tZSByZXN0IGluIHRoZSBIUSBzaW5jZSBteSB3aWZlIGJyb2tlIGhlciBmb290IDQgZGF5cyBh Z28pLg0KCUlzIHRoZXJlIGFueSBuZWVkIGZvciBTd2lzcyBjaG9jb2xhdGUgb3Igb3RoZXIgc3R1 ZmYgd2hpY2ggSSBjYW4gZWFzaWx5IGJyaW5nIGZyb20gU3dpdHplcmxhbmQgZm9yIHlvdSBndXlz Pw0KCQ0KCUNoZWVycw0KCU1pY2hhZWwgJiBJcmVuZQ0KCQ0KCXdlbGxlbnpvaG4ubmV0DQoJDQoJ LS0tLS0tLS0NCglSVi0xMCBidWlsZGVyIChhdmlvbmljcywgd2lyaW5nKQ0KCSM1MTENCgkNCgkN CgkNCgkNCglSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoJDQoJaHR0cDovL2ZvcnVtcy5t YXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0yNXQ7IDxodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20vdmlld3RvcGljLnBocD9wPTI1NDg2MSMyNTQ4NjE+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmk9PT09PT09PT09PT09PT09DQoJDQoJDQoJDQoJPGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0PiANCgk8aHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9SVjEwLUxpc3Q+IA0KDQo8aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmln YXRvcj9SVjEwLUxpc3Q+IA0KDQoJCWhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/UlYxMC1MaXN0Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAt TGlzdA0KCQlocmVmPSJodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbQ0KCQlocmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoJCQ0KCQkNCg0KDQoJ aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCglocmVmPSJodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KCWhy ZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24iPmh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9jb250cmlidXRpb24NCgkNCg0KCQ0KCQ0KCV8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoJXy09ICAgICAgICAg IC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoJXy09IFVzZSB0aGUgTWF0cm9uaWNzIExp c3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KCV8tPSB0aGUgbWFueSBMaXN0IHV0aWxp dGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KCV8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCglfLT0gUGhvdG9zaGFyZSwgYW5k IG11Y2ggbXVjaCBtb3JlOg0KCV8tPQ0KCV8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5j b20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KCV8tPQ0KCV8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoJXy09ICAgICAgICAgICAgICAg LSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoJXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2 YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQoJXy09DQoJXy09ICAgLS0+IGh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQ0KCV8tPQ0KCV8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoJXy09ICAgICAgICAgICAgIC0gTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGUgLQ0KCV8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3Vz IHN1cHBvcnQhDQoJXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxl LCBMaXN0IEFkbWluLg0KCV8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJp YnV0aW9uDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCgkNCgkNCg0K ________________________________________________________________________________
Date: Jul 27, 2009
WW91J2xsIGJlIGRpcmVjdGVkIHRvIHRoZSBSVi0xMCBwYXJraW5nIGFyZWEuIEkgZGlkbid0IGZs eSBpbiB0aGlzIHllYXIgLSBwbGFuZSBpcyBpbiB0aGUgcGFpbnQgc2hvcC4gDQoNCkJvYg0KDQog IF9fX19fICANCg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIDxv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IA0KVG86IHJ2MTAtbGlzdEBtYXRy b25pY3MuY29tIDxydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4gDQpTZW50OiBNb24gSnVsIDI3IDA4 OjAyOjAyIDIwMDkNClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFJlOiBSVjEwIEhRIGluIGZ1bGwg c3dpbmcgDQoNCg0KQm9iLCBpZiBpIGZseSBpIHRvIG9zaCBpbnN0ZWFkIG9mIGZsZCB3aWxsIGkg YmUgZGlyZWN0ZWQgdG8gcGFyayBuZWFyIHlvdSAuIHJvYmVydA0KDQpPbiBKdWwgMjcsIDIwMDks IGF0IDk6MjggQU0sIENvbmRyZXksIEJvYiAoVVMgU1NBKSB3cm90ZToNCg0KDQoJWWVwLCBzdG9w IGJ5IGFueXRpbWUuIEFsbCAtMTAgZmx5ZXJzLCBidWlsZGVycyBhbmQgImFsbW9zdCIgYnVpbGRl cnMgd2VsY29tZS4NCgkNCglCb2INCg0KDQogIF9fX19fICANCg0KCUZyb206IG93bmVyLXJ2MTAt bGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25p Y3MuY29tPiANCglUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20gPHJ2MTAtbGlzdEBtYXRyb25p Y3MuY29tPiANCglTZW50OiBNb24gSnVsIDI3IDA3OjIyOjE5IDIwMDkNCglTdWJqZWN0OiBSZTog UlYxMC1MaXN0OiBSZTogUlYxMCBIUSBpbiBmdWxsIHN3aW5nIA0KCQ0KDQoJaSBhbSBmbHlpbmcg aW4gd2VkbmVzZGF5IHRvIGZvbmQgZHUgbGFjLiB3aWxsIHN0YXkgdGhyb3VnaCBzYXR1cmRheS4g YW0gaSBpbnZpdGVkIHRvIHRoZSBmZXN0aXZpdGllcz8gaSBhbSBhIHJvb2tpZSBhdCB0aGlzLiBy b2JlcnQgYnJ1bmtlbmhvZWZlciAgbjY2MUcgcnYxMCAxNjUgaHJzLmZseWluZyBhbmQgbG92aW5n IGV2ZXJ5IG1pbnV0ZSBvZiBpdA0KCQ0KCU9uIEp1bCAyNywgMjAwOSwgYXQgODo0NCBBTSwgRG9u IE1jRG9uYWxkIHdyb3RlOg0KDQoNCllvdSBndXlzIGFyZSBraWxsaW5nIHVzLi4uLi4gIGF0IGxl YXN0IHRob3NlIG9mIHVzIHRoYXQgY2FuJ3QgbWFrZSBpdCB0aGlzIHllYXIuLi4uICBNeSB3aWZl IGFuZCBJIHdlbnQgbGFzdCB5ZWFyIGZvciBvdXIgZmlyc3QgdGltZXMuLi4uIGZsZXcgY29tbWVy Y2lhbGx5Li4uLiBhbmQgSSB0aGluayB0aGVyZSB3ZXJlIGFyb3VuZCAxMTAgUlYxMCdzIGZseWlu Zy4uLiBub3cgb25lIHllYXIgbGF0ZXIsIEkgdGhpbmsgdGhlIG51bWJlciBpcyBhcm91bmQgMjIw LiAgU28gZGVwZW5kaW5nIG9uIGhvdyB5b3Ugd29yayB0aGUgbnVtYmVycyB3ZSdsbCBlaXRoZXIg YWRkIGFub3RoZXIgMTEwLCBvciBkb3VibGUgdGhlIDIyMC4uLi4gYXQgYW55IHJhdGUgSSBzdXNw ZWN0IHdlJ2xsIGhhdmUgYXQgbGVhc3Qgb3ZlciAzMDAgZmx5aW5nIDEwJ3MgYnkgbmV4dCB5ZWFy cyBPc2guICBDb3VudCB1cyBpbiBmb3IgbmV4dCB5ZWFyIGZvciBzdXJlLg0KRG9uICYgS2ltIE1j RG9uYWxkDQoNCi0tLSBPbiBNb24sIDcvMjcvMDksIENvbmRyZXksIEJvYiAoVVMgU1NBKSA8Ym9i LmNvbmRyZXlAYmFlc3lzdGVtcy5jb20+IHdyb3RlOg0KDQoNCg0KCUZyb206IENvbmRyZXksIEJv YiAoVVMgU1NBKSA8Ym9iLmNvbmRyZXlAYmFlc3lzdGVtcy5jb20+DQoJU3ViamVjdDogUmU6IFJW MTAtTGlzdDogUmU6IFJWMTAgSFEgaW4gZnVsbCBzd2luZw0KCVRvOiBydjEwLWxpc3RAbWF0cm9u aWNzLmNvbQ0KCURhdGU6IE1vbmRheSwgSnVseSAyNywgMjAwOSwgMzo1NSBBTQ0KCQ0KCQ0KCS0t PiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJDb25kcmV5LCBCb2IgKFVTIFNTQSkiIDxi b2IuY29uZHJleUBiYWVzeXN0ZW1zLmNvbSA8aHR0cDovL3VzLm1jNTM3Lm1haWwueWFob28uY29t L21jL2NvbXBvc2U/dG89Ym9iLmNvbmRyZXlAYmFlc3lzdGVtcy5jb20+ID4NCgkNCglBYnNvbHV0 ZWx5PyAgV2UncmUgdXAgdG8gODAwIHNxIGZ0IG9mIHNoYWRlIGFuZCBoYXZlIHBsZW50eSBvZiBz ZWF0cy4gIEkgaW1hZ2luZSB5b3UnZCBhbHNvIGZpbmQgdGhhdCB0aGUgY2hvY29sYXRlIHdvdWxk IGJlIGEgaGl0Lg0KCQ0KCUJvYg0KCQ0KCS0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCglG cm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPGh0dHA6Ly91cy5tYzUz Ny5tYWlsLnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPW93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbT4gIDxvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPGh0dHA6 Ly91cy5tYzUzNy5tYWlsLnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPW93bmVyLXJ2MTAtbGlzdC1z ZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gPg0KCVRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSA8aHR0 cDovL3VzLm1jNTM3Lm1haWwueWFob28uY29tL21jL2NvbXBvc2U/dG89cnYxMC1saXN0QG1hdHJv bmljcy5jb20+ICA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20gPGh0dHA6Ly91cy5tYzUzNy5tYWls LnlhaG9vLmNvbS9tYy9jb21wb3NlP3RvPXJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPiA+DQoJU2Vu dDogU3VuIEp1bCAyNiAyMzo1NToyNCAyMDA5DQoJU3ViamVjdDogUlYxMC1MaXN0OiBSZTogUlYx MCBIUSBpbiBmdWxsIHN3aW5nDQoJDQoJLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog Ik1pY2hhZWwgV2VsbGVuem9obiIgPHJ2LTEwQHdlbGxlbnpvaG4ubmV0IDxodHRwOi8vdXMubWM1 MzcubWFpbC55YWhvby5jb20vbWMvY29tcG9zZT90bz1ydi0xMEB3ZWxsZW56b2huLm5ldD4gPg0K CQ0KCUknbGwgYmUgdGhlcmUgZnJvbSBUaHVyc2RheSBvbndhcmRzIHdpdGggbXkgd2lmZSAoZmly c3QgdGltZSBPc2ggZm9yIGhlcikuDQoJV291bGQgaXQgYmUgT0sgdG8gZmluZCBzb21lIHJlc3Qg aW4gdGhlIEhRIHNpbmNlIG15IHdpZmUgYnJva2UgaGVyIGZvb3QgNCBkYXlzIGFnbykuDQoJSXMg dGhlcmUgYW55IG5lZWQgZm9yIFN3aXNzIGNob2NvbGF0ZSBvciBvdGhlciBzdHVmZiB3aGljaCBJ IGNhbiBlYXNpbHkgYnJpbmcgZnJvbSBTd2l0emVybGFuZCBmb3IgeW91IGd1eXM/DQoJDQoJQ2hl ZXJzDQoJTWljaGFlbCAmIElyZW5lDQoJDQoJd2VsbGVuem9obi5uZXQNCgkNCgktLS0tLS0tLQ0K CVJWLTEwIGJ1aWxkZXIgKGF2aW9uaWNzLCB3aXJpbmcpDQoJIzUxMQ0KCQ0KCQ0KCQ0KCQ0KCVJl YWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCgkNCglodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b20vdmlld3RvcGljLnBocD9wPTI1dDsgPGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3 dG9waWMucGhwP3A9MjU0ODYxIzI1NDg2MT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aT09PT09PT09PT09PT09PT0NCgkNCgkNCgkNCgk8aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9SVjEwLUxpc3Q+IA0KCTxodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9y P1JWMTAtTGlzdD4gDQoNCjxodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAt TGlzdD4gDQoNCgkJaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEw LUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQoJCWhy ZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tDQoJCWhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24iPmh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCgkJDQoJCQ0KDQoNCglodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KCWhyZWY9Imh0dHA6Ly9mb3J1bXMu bWF0cm9uaWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoJaHJlZj0iaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29t L2NvbnRyaWJ1dGlvbg0KCQ0KDQoJDQoJDQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCglfLT0gICAgICAgICAgLSBUaGUgUlYx MC1MaXN0IEVtYWlsIEZvcnVtIC0NCglfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJl cyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoJXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2gg YXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoJXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KCV8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNo IG1vcmU6DQoJXy09DQoJXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/UlYxMC1MaXN0DQoJXy09DQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCglfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklD UyBXRUIgRk9SVU1TIC0NCglfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZp YSB0aGUgV2ViIEZvcnVtcyENCglfLT0NCglfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tDQoJXy09DQoJXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCglfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlv biBXZWIgU2l0ZSAtDQoJXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEN CglfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRt aW4uDQoJXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCglf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KCQ0KCQ0KDQo ________________________________________________________________________________
Date: Jul 27, 2009
What sucks is that I'm a sales guy and this is the last week of our fiscal quarter. So yeah, I'm working. I've got 1 more transaction that I'm tracking and if I can get it in early this week, I'm buying the next airline ticket to Chicago or Milwaukee or someplace close. If I get to head that way, I'll send an e-mail and let you know. I plan on traveling with a 1 man tent, a few days of clothes, sunscreen, toiletries, and rain gear all stuffed in a backpack. Hopefully things will work out and I can get there. :) Phil -----Original Message----- From: Tim Olson [mailto:Tim(at)MyRV10.com] Sent: Sunday, July 26, 2009 6:47 PM Subject: RV10-List: RV10 HQ in full swing For all you folks who are around OSH, come on by the HQ! The food is fantastic...thanks to Bog, Gary, and crew. For those missing out...what the heck are you missing this for!?!? Tim ________________________________________________________________________________
Date: Jul 27, 2009
Tim, In my opinion you can't start thinking about the first flight too early, mostly because it's fun and motivating. There's also the element that you'll be better prepared. Anyway, I've attached the flight test cards that I received as a First Flight Advisor. If you have someone that is currently an advisor nearby you might be able to get something more recent as my info is somewhat dated. I also attached some gouge I found for an RV-6 just to get some thoughts going. Good luck and enjoy planning that first flight, Marcus 40286 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Monday, July 27, 2009 11:08 AM Subject: RV10-List: Flight Test - cart before horse? Maybe I'm getting the cart before the horse, but did anyone make something like kneeboard-size flight test cards for your test period? Can I borrow your format, if yes? TDT Tim Dawson-Townsend 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jul 29, 2009
Just an update.... My order came in this morning and I've already booked a flight into Milwaukee. I'm leaving Houston a 7AM. See you in Oshkosh! Phil -----Original Message----- From: Perry, Phil Sent: Monday, July 27, 2009 11:48 AM Subject: RE: RV10-List: RV10 HQ in full swing What sucks is that I'm a sales guy and this is the last week of our fiscal quarter. So yeah, I'm working. I've got 1 more transaction that I'm tracking and if I can get it in early this week, I'm buying the next airline ticket to Chicago or Milwaukee or someplace close. If I get to head that way, I'll send an e-mail and let you know. I plan on traveling with a 1 man tent, a few days of clothes, sunscreen, toiletries, and rain gear all stuffed in a backpack. Hopefully things will work out and I can get there. :) Phil -----Original Message----- From: Tim Olson [mailto:Tim(at)MyRV10.com] Sent: Sunday, July 26, 2009 6:47 PM Subject: RV10-List: RV10 HQ in full swing For all you folks who are around OSH, come on by the HQ! The food is fantastic...thanks to Bog, Gary, and crew. For those missing out...what the heck are you missing this for!?!? Tim ________________________________________________________________________________
Subject: Auto Power
Date: Jul 30, 2009
Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~=03 ________________________________________________________________________________
Subject: Re: Auto Power
Date: Jul 29, 2009
sore subject right now Below is the report I pulled from VAF- http://www.vansairforce.com/community/showthread.php?t=38462&page=10 gipsowh Join Date: Jan 2005 Location: Conroe, Texas Posts: 41 Gear Collapse Incident ------------------------------------------------------------------------- - Yes, its true, N730WL was damaged Thursday afternoon during a test flight and subsequent emergency landing. Pilot, Bud Warren and I were taking the 10 for a flight around the airport to check out a high operating temperature problem. We took off after a long taxi and climbed normally, however the engine temperature kept climbing even after leveling off. For unknown reasons the engine seemed to quit making power. Bud skillfully banked back toward the runways. Not a good situation. A discussion with Bud today leads me to believe that the high engine temperature may have exceeded an operating parameter in the ECM and the engine reverted to a low power setting. This has yet to be confirmed but obviously needs to be addressed if this is indeed the problem. Bud managed to get the airplane back to the airport sacrificing altitude and speed without stalling. Incredible job by Bud to get us back to the runway. However, once over the runway, we were too slow and the plane mushed onto the runway rather hard. We bounced and skidded to a stop on the collapsed main gear. Fortunately, there was no fire and Bud and I were able to get out of the 10 without any injuries, Thank God. Unfortunately, there was considerable damage to the main landing gear and the prop was destroyed. The steps kept the bottom of the fuselage off the runway while we skidded, so no noticeable damage to the fuselage skin or tail. The wings didn't hit the ground but there is some minor damage from the gear folding up. I haven't looked at the landing gear mounts yet or the spar. So I don't know at this ten seconds the full extent of the damage. This project has been five years in the making and this is a tough pill for me to swallow. I really appreciate the concerns voiced. Will try and keep you posted on any new developments or findings. __________________ Bill Gipson N730WL LS1 Geareddrives powered RV-10 Conroe, Texas From: Paul Walter Sent: Wednesday, July 29, 2009 7:45 PM Subject: RV10-List: Auto Power Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~=03 ________________________________________________________________________________
Date: Jul 30, 2009
Yeah there's one in Texas.....it dead sticked in and fold ed the gear about two weeks ago......We just got back f rom Osh via Texas to Las Vegas....all Lycoming powered. Never missed a beat.... Sent via BlackBerry by AT&T -----Original Message----- From: "Paul Walter" <pdwalter(at)bigpond.net.au> Date: Thu, 30 Jul 2009 12:45:34 Subject: RV10-List: Auto Power This is a multi-part message in MIME format. ________________________________________________________________________________
Subject: Auto Power
Date: Jul 30, 2009
Paul is asking about the real performance numbers. Here they are Paul. Alternative Engine Up Front Savings $15,000 Additional R&D 1,000 hours Since we work for nothing-additional cost = $0.00 Cost to build Alt. Engine RV-10 $160,000-$225,000 Resale Value of Alt. Engine RV-10 $80,000 (plus Liability Waver Signed, Witnessed & Notarized, twice) Paul, everyone wants and hopes for a viable alternative engine RV or for that matter just about any experimental airplane to be successful using readily available automotive type engines. Unfortunately the category has been littered with planes that never flew and even worse ones that did fly. Some even making it all the way back to the airport. My advice is that unless you are an aeronautical engineer that prefers building to flying construct a plans built aircraft. Saving $ on an alternative engine will be the most expensive path you can take. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pascal Sent: Wednesday, July 29, 2009 8:20 PM Subject: Re: RV10-List: Auto Power sore subject right now Below is the report I pulled from VAF- http://www.vansairforce.com/community/showthread.php?t=38462&page=10 gipsowh <http://www.vansairforce.com/community/member.php?u=190> Join Date: Jan 2005 Location: Conroe, Texas Posts: 41 <http://www.vansairforce.com/community/showthread.php?t=38462&page=10 > Gear Collapse Incident ________________________________ Yes, its true, N730WL was damaged Thursday afternoon during a test flight and subsequent emergency landing. Pilot, Bud Warren and I were taking the 10 for a flight around the airport to check out a high operating temperature problem. We took off after a long taxi and climbed normally, however the engine temperature kept climbing even after leveling off. For unknown reasons the engine seemed to quit making power. Bud skillfully banked back toward the runways. Not a good situation. A discussion with Bud today leads me to believe that the high engine temperature may have exceeded an operating parameter in the ECM and the engine reverted to a low power setting. This has yet to be confirmed but obviously needs to be addressed if this is indeed the problem. Bud managed to get the airplane back to the airport sacrificing altitude and speed without stalling. Incredible job by Bud to get us back to the runway. However, once over the runway, we were too slow and the plane mushed onto the runway rather hard. We bounced and skidded to a stop on the collapsed main gear. Fortunately, there was no fire and Bud and I were able to get out of the 10 without any injuries, Thank God. Unfortunately, there was considerable damage to the main landing gear and the prop was destroyed. The steps kept the bottom of the fuselage off the runway while we skidded, so no noticeable damage to the fuselage skin or tail. The wings didn't hit the ground but there is some minor damage from the gear folding up. I haven't looked at the landing gear mounts yet or the spar. So I don't know at this ten seconds the full extent of the damage. This project has been five years in the making and this is a tough pill for me to swallow. I really appreciate the concerns voiced. Will try and keep you posted on any new developments or findings. __________________ Bill Gipson N730WL LS1 Geareddrives powered RV-10 Conroe, Texas From: Paul Walter <mailto:pdwalter(at)bigpond.net.au> Sent: Wednesday, July 29, 2009 7:45 PM Subject: RV10-List: Auto Power Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~ ________________________________ href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 30, 2009
On 07/30/2009 01:44 AM, Robin Marks wrote: > > Paul is asking about the real performance numbers. Here they are Paul. > I get a chuckle every time I read posts like this. I can just picture a few years back people saying something along the lines of "You mean those two Wright brothers are going to make an airplane out of bicycle parts, and they've designed their own engine to run it? They must be crazy!" Randy Crothers, like the Wright brothers, has had his share of heartache getting a good system working, but back in March he posted on VAF some performance numbers for his Subaru STi powered RV7A. Here is part of his post: "I kept dialing the boost back down and lowering the RPMs to try to stay right at the RV7A VNE speed of 200 Knots TAS. I found I could maintain this speed with the following settings: 4600 RPMs, 42.6" MAP, Fuel flow showed 11.2 GPH with an A/F mixture of about 12.3:1, I was keeping it pretty rich to to make sure I had detonation margin. OAT was 28F, Oil T 200F, PSRU T 165F, Coolant T 196F, Intake Air T 99F. Altitude 8800'. I estimate I kept these settings in place for a good 40 minutes and finally had to back out of it to descend down below the clouds and duck under the class B airspace I have to deal with. I stayed out on the West side of Puget Sound and turned to the East down toward Olympia WA. I guess this engine could make pretty good use of a faster airframe like a Lancair, or maybe a Glasair etc. So there you have it, I can cruise at VNE for extended periods of time at 4600 RPMs and 43" MAP." It may have cost him more than a straight Lycoming installation since he has done a bunch of experimenting with various parts, however, someone could come along and duplicate his working setup for far less money. We don't have much of a resale market history for RV-10s, but on average other aircraft do not seem to sell for any less due to different engines being installed (Glastar, Zenith 601, for example). In fact, for some airframes, an auto engine is actually preferred (KR2s, Hummelbird, Sonerai, Sonex, etc). An auto engine is certainly not for everyone, but IMHO it is not the doom and gloom that Robin describes in his message. You definitely want to do your research before going down that path, though. "Two roads diverged in a wood, and I, I took the one less traveled by, and that has made all the difference." --Robert Frost -Dj ________________________________________________________________________________
Date: Jul 30, 2009
[quote="pdwalter(at)bigpond.net.a"]Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~ > [b] Paul, The youtube video you mentioned is probably one of two. Todd Swezey out of Savannah with an LS2, or Bill Gipson out of Texas with an LS1. They both have run-up videos on youtube. This is probably not the best forum to ask that question - most of the guys here are married to their Lycosaurs. I would suggest you go to www.vansairforce.com and visit the Alternative Engines Forum. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255212#255212 ________________________________________________________________________________
Subject: Auto Power
Date: Jul 30, 2009
DJ, My posts usually have a large component of tongue in cheek and this one was no different however my main point is not that it is impossible to develop a successful alternative engine for the -10 but more that it is very expensive and time consuming beyond compare. I say this as one of the first to make a simple modification by adding the James Plenum & Cowl. This seemingly simple change has probably cost us 500+ hours of development and we are still dealing with the ramifications of this small variant. I think I was clear that one needs real knowledge & skill to take that leap and even if you were to develop a successful platform your resale value may be significantly lower. In reading a Wright Brothers biography I remember a favorite quote of Wilbur Wright the original alternative engine builder: "I don't have time for a wife and an airplane." Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Thursday, July 30, 2009 7:21 AM Subject: Re: RV10-List: Auto Power On 07/30/2009 01:44 AM, Robin Marks wrote: > > Paul is asking about the real performance numbers. Here they are Paul. > I get a chuckle every time I read posts like this. I can just picture a few years back people saying something along the lines of "You mean those two Wright brothers are going to make an airplane out of bicycle parts, and they've designed their own engine to run it? They must be crazy!" Randy Crothers, like the Wright brothers, has had his share of heartache getting a good system working, but back in March he posted on VAF some performance numbers for his Subaru STi powered RV7A. Here is part of his post: "I kept dialing the boost back down and lowering the RPMs to try to stay right at the RV7A VNE speed of 200 Knots TAS. I found I could maintain this speed with the following settings: 4600 RPMs, 42.6" MAP, Fuel flow showed 11.2 GPH with an A/F mixture of about 12.3:1, I was keeping it pretty rich to to make sure I had detonation margin. OAT was 28F, Oil T 200F, PSRU T 165F, Coolant T 196F, Intake Air T 99F. Altitude 8800'. I estimate I kept these settings in place for a good 40 minutes and finally had to back out of it to descend down below the clouds and duck under the class B airspace I have to deal with. I stayed out on the West side of Puget Sound and turned to the East down toward Olympia WA. I guess this engine could make pretty good use of a faster airframe like a Lancair, or maybe a Glasair etc. So there you have it, I can cruise at VNE for extended periods of time at 4600 RPMs and 43" MAP." It may have cost him more than a straight Lycoming installation since he has done a bunch of experimenting with various parts, however, someone could come along and duplicate his working setup for far less money. We don't have much of a resale market history for RV-10s, but on average other aircraft do not seem to sell for any less due to different engines being installed (Glastar, Zenith 601, for example). In fact, for some airframes, an auto engine is actually preferred (KR2s, Hummelbird, Sonerai, Sonex, etc). An auto engine is certainly not for everyone, but IMHO it is not the doom and gloom that Robin describes in his message. You definitely want to do your research before going down that path, though. "Two roads diverged in a wood, and I, I took the one less traveled by, and that has made all the difference." --Robert Frost -Dj ________________________________________________________________________________
Date: Jul 30, 2009
On 07/30/2009 11:36 AM, Robin Marks wrote: > > > In reading a Wright Brothers biography I remember a favorite quote of > Wilbur Wright the original alternative engine builder: I dont have > time for a wife and an airplane. > Good one! Another favorite: "My Ex-Wife told me it was her or the airplane. I sure do miss her!" *grin* -Dj ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 30, 2009
Subject: Auto Power
Ah yes, that always lurking disease, Aviation Induced Divorce Syndrome. That one can sneak up on you fast, especially for the dedicated builder. :D -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Thursday, July 30, 2009 10:54 AM Subject: Re: RV10-List: Auto Power On 07/30/2009 11:36 AM, Robin Marks wrote: > > > In reading a Wright Brothers biography I remember a favorite quote of > Wilbur Wright the original alternative engine builder: "I don't have > time for a wife and an airplane." > Good one! Another favorite: "My Ex-Wife told me it was her or the airplane. I sure do miss her!" *grin* -Dj ________________________________________________________________________________
Date: Jul 30, 2009
Hmm, I disagree that this isn't a good forum to discuss this. While many of us have chosen the path of least resistance, this is still a worthwhile discussion. I look at it this way, the experimental category has basically branched unofficially into two sub categories which are "homebuilt" and "experimental". Most of us in the RV-10 world fall into the homebuilt category and yes, this list is geared primarily to that crowd. Many people think I am anti-auto conversion but that couldn't be farther from the truth. I looked very closely at Egg's offering but came to the conclusion it wasn't ready for primetime without a lot of after the fact engineering on my part. Anyone who can confidently standup and claim it is a true bolt on, firewall forward package for the RV-10 is really just trying to justify their decision. I also have personal feelings on the type of person Egg is and, in my opinion, I wouldn't want to do business with someone of his questionable ethics. I saw the geared drives package run last year at OSH, and they are there again this year, and was really impressed with the direction it was going. It appears to be a well thought out design with lots of potential. The failure of what I would call the proof of concept -10 in the last couple weeks sounds to me like an ECU problem vs a fundamental design flaw and I think they can bounce back from it fairly quickly should that prove to have been the problem. I also think this package has the most potential to be the first, real, FWF package in the -10 that isn't a Lyc. I hope they do get there. I also feel the rotary's have a lot of potential and hopefully Mistral will get there one of these days. But what all three of these have shown is that it is not a simple task to move an engine that was designed for auto use into an airplane. Most of the truly successful conversions are of the air cooled, low RPM type as used in many of the aircraft cited previously. Yes, Egg has had a measure of success in the smaller RV series, but most people that have used his FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced. Yes there will always be the homebuilders that see the experimental category as a way to get what they want at a reduced cost and potentially have a hoot building at the same time, but the experimental side needs to exist also in order to keep pushing the envelope. I ultimately made the decision to go with a "standard" IO-540 because I decided I didn't want to be in the experimental group with my family on board. This doesn't make it a right or wrong decision, just my decision and everyone needs to come to their own decision without worrying about the background noise out there. We all need to remember these are certified as an "experimental" for a reason. If you are worried that one of these experimenters are going to screw with your homebuilt resale value or increase your insurance premiums, I would suggest you reevaluate whether you made the right decision to build your own aircraft. I knew the experimental part of the group would be there and it was something I took into account when I made the decision to build. If other people out there didn't, it is certainly not the experimenters fault and you should just suck it up at this point as it is what you have made the decision to be a part of. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Thursday, July 30, 2009 9:40 AM Subject: RV10-List: Re: Auto Power [quote="pdwalter(at)bigpond.net.a"]Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~ > [b] Paul, The youtube video you mentioned is probably one of two. Todd Swezey out of Savannah with an LS2, or Bill Gipson out of Texas with an LS1. They both have run-up videos on youtube. This is probably not the best forum to ask that question - most of the guys here are married to their Lycosaurs. I would suggest you go to www.vansairforce.com and visit the Alternative Engines Forum. John -------- #40572 QB Fuselage, wings finished. Finish Kit started. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255212#255212 ________________________________________________________________________________
Date: Jul 30, 2009
On 07/30/2009 12:23 PM, RV Builder (Michael Sausen) wrote: > FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced. > And as with any engine package, if we learn from those that went before us, we can cut that $time$ and extra dollars down considerably. Installations today take much less time than those done previously, because we can duplicate the successful installations of those that spent that time in the past doing the experimentation. There is a "recipe for success" that has been worked out over the years so that builders doing installations today have significantly higher chances of a non-issue installation compared to installations even as recent as a couple of years ago. It is not quite as turnkey as a typical Lyc installation, but the gap has narrowed considerably, and is getting narrower every year. -Dj ________________________________________________________________________________
Date: Jul 30, 2009
deej(at)deej.net wrote: > On 07/30/2009 11:36 AM, Robin Marks wrote: > Good one! Another favorite: "My Ex-Wife told me it was her or the > airplane. I sure do miss her!" *grin* > -Dj Or the tee shirt I saw at Osh Tuesday "Got a plane for my wife. Best trade I ever made" -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255235#255235 ________________________________________________________________________________
Date: Jul 30, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: MT Prop Controller
I'm searching the archives for information on re-aligning the actuating arm on the controller and I've found a few items. However, am I supposed to have some documentation on the controller as part of my Van's/Lycoming engine package? Any guidance appreciated. Bill "baffling the engine while dreaming of Oshkosh" Watson ________________________________________________________________________________
Date: Jul 30, 2009
Subject: Re: MT Prop Controller
Bill, I got documentation with mine (180hp 6A) - I'll try to remember to dig it out this weekend and zap it to you. Alternatively, check out the MT website - they may have it online.... Ralph -----Original Message----- >From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> >Sent: Jul 30, 2009 3:04 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: MT Prop Controller > > >I'm searching the archives for information on re-aligning the actuating >arm on the controller and I've found a few items. > >However, am I supposed to have some documentation on the controller as >part of my Van's/Lycoming engine package? > >Any guidance appreciated. > >Bill "baffling the engine while dreaming of Oshkosh" Watson > > ________________________________________________________________________________
Date: Jul 30, 2009
Hey Bill, Until someone gives you the technical details, the process is astoundingly simple: cut the safety wire that connects the straight blade screws around the perimiter of the governor face, LOOSEN (do not remove) the screws, then rotate the whole arm/face mechanism to the position you want, retighten and safety wire. The screws provide a friction fit for the face plate so that it can be adjusted. If you already know all that and are asking about the position to lock it down, we looked at the position the control cable was coming from and aligned it so that halfway between stops was at 90 degrees. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting done! On with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255265#255265 ________________________________________________________________________________
Date: Jul 30, 2009
Besides the hassle of engineering a different engine package, and making a cowl for it, even if it is "turn-key" there isn't anyone besides Continental that has an engine in the horsepower range with anywhere near as good fuel consumption specifics at total installed wt even close. TCM is a little better on fuel and smoothness, at a cost of at least 60lbs heavier. For all the hand wringing about old technology, you simply are not gaining much with an auto engine in technology. Yes automatic ignition advance. Liquid cooling has been around aircraft engines since before WWII and generally rejected for weight and space and leakage issues. Timed fuel injection is a very minuscule gain over continuous mechanical. Most German cars still use continuous mechanical. So don't be fooled by the siren song of newer technology...most of it has been tried and rejected on reliability, weight or cost effectiveness. While on engines, how many have considered the negatives of going with a brand new untested engine at the same time as a brand new untested airframe? Because of breakin issues, you don't have luxury of any taxi testing, nor much prop testing etc. To avoid cylinder glazing you need to get in the air quickly with minimal ground runs to check for leaks first. With a used certified engine, you don't have to worry about break-in or infant mortality, and can focus on testing your airframe. Just a thought. On Thu, Jul 30, 2009 at 12:07 PM, Dj Merrill wrote: > > On 07/30/2009 12:23 PM, RV Builder (Michael Sausen) wrote: >> FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced. >> > > And as with any engine package, if we learn from those that went > before us, we can cut that $time$ and extra dollars down considerably. > Installations today take much less time than those done previously, > because we can duplicate the successful installations of those that > spent that time in the past doing the experimentation. There is a > "recipe for success" that has been worked out over the years so that > builders doing installations today have significantly higher chances of > a non-issue installation compared to installations even as recent as a > couple of years ago. It is not quite as turnkey as a typical Lyc > installation, but the gap has narrowed considerably, and is getting > narrower every year. > > -Dj > > ________________________________________________________________________________
Date: Jul 31, 2009
No ofence but we have heard it all before. Not the place where you want to go experimental with wife and kids on board. Search the archives on every RV forum regards Chris ----- Original Message ----- From: "Dj Merrill" <deej(at)deej.net> Sent: Friday, July 31, 2009 12:20 AM Subject: Re: RV10-List: Auto Power > > On 07/30/2009 01:44 AM, Robin Marks wrote: >> >> Paul is asking about the real performance numbers. Here they are Paul. >> > > > > I get a chuckle every time I read posts like this. I can just > picture a few years back people saying something along the lines of "You > mean those two Wright brothers are going to make an airplane out of > bicycle parts, and they've designed their own engine to run it? They > must be crazy!" > > Randy Crothers, like the Wright brothers, has had his share of > heartache getting a good system working, but back in March he posted on > VAF some performance numbers for his Subaru STi powered RV7A. Here is > part of his post: > > "I kept dialing the boost back down and lowering the RPMs to try to stay > right at the RV7A VNE speed of 200 Knots TAS. I found I could maintain > this speed with the following settings: > 4600 RPMs, 42.6" MAP, Fuel flow showed 11.2 GPH with an A/F mixture of > about 12.3:1, I was keeping it pretty rich to to make sure I had > detonation margin. OAT was 28F, Oil T 200F, PSRU T 165F, Coolant T 196F, > Intake Air T 99F. Altitude 8800'. I estimate I kept these settings in > place for a good 40 minutes and finally had to back out of it to descend > down below the clouds and duck under the class B airspace I have to deal > with. I stayed out on the West side of Puget Sound and turned to the > East down toward Olympia WA. > I guess this engine could make pretty good use of a faster airframe like > a Lancair, or maybe a Glasair etc. > So there you have it, I can cruise at VNE for extended periods of time > at 4600 RPMs and 43" MAP." > > It may have cost him more than a straight Lycoming installation > since he has done a bunch of experimenting with various parts, however, > someone could come along and duplicate his working setup for far less > money. We don't have much of a resale market history for RV-10s, but on > average other aircraft do not seem to sell for any less due to different > engines being installed (Glastar, Zenith 601, for example). In fact, > for some airframes, an auto engine is actually preferred (KR2s, > Hummelbird, Sonerai, Sonex, etc). > > An auto engine is certainly not for everyone, but IMHO it is not the > doom and gloom that Robin describes in his message. You definitely want > to do your research before going down that path, though. > > "Two roads diverged in a wood, and I, I took the one less traveled by, > and that has made all the difference." --Robert Frost > > -Dj > > > ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 6:04 PM, Kelly McMullen wrote: > > Besides the hassle of engineering a different engine package, and > making a cowl for it, even if it is "turn-key" there isn't anyone Hi Kelly, I think you missed the point of my post that you replied to. If you are duplicating someone else's setup that seems to be working, you aren't doing any engineering of your own. You are just assembling the same as with a Lycoming and copying the engineering that someone else has already done. Pre-made cowls are available for purchase if you do not want to take the time to make the modifications to the stock cowling. These were not available a few years ago, but they are today. Things have progressed a long ways since the "old days". > besides Continental that has an engine in the horsepower range with > anywhere near as good fuel consumption specifics at total installed wt > even close. I bet Randy Crothers would beg to differ with you with his Subaru STi installation. > So don't be fooled by the siren song of newer technology...most of it > has been tried and rejected on reliability, weight or cost > effectiveness. I'm sure some experimentation has shown that some technologies don't work, and they phase out. The engine systems in cars of today aren't even the same as they were 5 years ago in some cases. Progress is being made all the time, and new technology replacing old. Who would consider buying a car that uses magnetos these days? Things change, technology improves, old stuff is phased out. Even Lycoming has their new FADEC system, and magnetos and carbs of today will be phased out over time as new technology replaces them. It is inevitable. > > To avoid cylinder glazing you need > to get in the air quickly with minimal ground runs to check for leaks > first. Not necessary with today's auto engines. > With a used certified engine, you don't have to worry about break-in > or infant mortality, and can focus on testing your airframe. Just a > thought. No worries about break in with a modern car engine, either. Things have changed from the days of old. -Dj ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 5:37 PM, Chris and Susie wrote: > > No ofence but we have heard it all before. Not the place where you want > to go experimental with wife and kids on board. > Search the archives on every RV forum Hi Chris, no offense taken, and none intended. There are thousands of experimental aircraft flying with auto engines, taking their wife, kids, and best friends along with no more fears than with the Lycoming engines. Different strokes for different folks, but not as doom and gloom as you indicate. Take some time to Google Sonex, KR2, Soneraii, Hummelbird, etc and Corvair, Subaru EA-81, and VW engines conversions. You will find lots of successful auto conversions. You will also finds not so successful ones, along with not so successful Lycoming installations as well. In particular, look for things within the last 2 years and compare to the old days to see the differences. -Dj ________________________________________________________________________________
Date: Jul 30, 2009
Kelly, Not to be nosy, but don't you work for, or represent, an engine manufacturer? If I am mistaken, I apologize. John Kelly McMullen wrote: > Besides the hassle of engineering a different engine package, and > making a cowl for it, even if it is "turn-key" there isn't anyone > besides Continental that has an engine in the horsepower range with > anywhere near as good fuel consumption specifics at total installed wt > even close. TCM is a little better on fuel and smoothness, at a cost > of at least 60lbs heavier. For all the hand wringing about old > technology, you simply are not gaining much with an auto engine in > technology. Yes automatic ignition advance. Liquid cooling has been > around aircraft engines since before WWII and generally rejected for > weight and space and leakage issues. Timed fuel injection is a very > minuscule gain over continuous mechanical. Most German cars still use > continuous mechanical. > So don't be fooled by the siren song of newer technology...most of it > has been tried and rejected on reliability, weight or cost > effectiveness. > > While on engines, how many have considered the negatives of going with > a brand new untested engine at the same time as a brand new untested > airframe? Because of breakin issues, you don't have luxury of any taxi > testing, nor much prop testing etc. To avoid cylinder glazing you need > to get in the air quickly with minimal ground runs to check for leaks > first. > With a used certified engine, you don't have to worry about break-in > or infant mortality, and can focus on testing your airframe. Just a > thought. > > On Thu, Jul 30, 2009 at 12:07 PM, Dj Merrill wrote: > > > > > > > On 07/30/2009 12:23 PM, RV Builder (Michael Sausen) wrote: > > > FWF package will tell you they were putting in extensive time and effort to get through various issues in order to get a fully functional power plant that could rival a Lyc. And if you look at the amount of $time$ and extra dollars put in, odds are that savings in fuel and maint will be greatly reduced. > > > > > > > And as with any engine package, if we learn from those that went > > before us, we can cut that $time$ and extra dollars down considerably. > > Installations today take much less time than those done previously, > > because we can duplicate the successful installations of those that > > spent that time in the past doing the experimentation. There is a > > "recipe for success" that has been worked out over the years so that > > builders doing installations today have significantly higher chances of > > a non-issue installation compared to installations even as recent as a > > couple of years ago. It is not quite as turnkey as a typical Lyc > > installation, but the gap has narrowed considerably, and is getting > > narrower every year. > > > > -Dj > > > > > > > > > > > > > > > -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255284#255284 ________________________________________________________________________________
Date: Jul 31, 2009
DJ that may be the case in the US but diferent here with RV's . The resale here is shocking with anything other than Lyco etc As you say each to there own Chris ----- Original Message ----- From: "Dj Merrill" <deej(at)deej.net> Sent: Friday, July 31, 2009 8:33 AM Subject: Re: RV10-List: Auto Power > > On 7/30/2009 5:37 PM, Chris and Susie wrote: >> >> No ofence but we have heard it all before. Not the place where you want >> to go experimental with wife and kids on board. >> Search the archives on every RV forum > > Hi Chris, no offense taken, and none intended. There are thousands of > experimental aircraft flying with auto engines, taking their wife, kids, > and best friends along with no more fears than with the Lycoming > engines. Different strokes for different folks, but not as doom and > gloom as you indicate. > > Take some time to Google Sonex, KR2, Soneraii, Hummelbird, etc and > Corvair, Subaru EA-81, and VW engines conversions. You will find lots > of successful auto conversions. You will also finds not so successful > ones, along with not so successful Lycoming installations as well. In > particular, look for things within the last 2 years and compare to the > old days to see the differences. > > -Dj > > > ________________________________________________________________________________
Date: Jul 30, 2009
It is a bit of a sore subject here, as one RV-10 builder with Eggenfeller engine augered in just hours before he planned to take family on a trip in it. Some his fault, some engine's fault, as it was a botched deadstick landing after loss of power. Only speculative what caused loss of power. None-the-less, another experimental pilot deceased, loss of a friend, with impacts on our insurance. On Thu, Jul 30, 2009 at 5:33 PM, Dj Merrill wrote: > > On 7/30/2009 5:37 PM, Chris and Susie wrote: >> >> No ofence but we have heard it all before. Not the place where you want >> to go experimental with wife and kids on board. >> Search the archives on every RV forum > > Hi Chris, no offense taken, and none intended. There are thousands of > experimental aircraft flying with auto engines, taking their wife, kids, > and best friends along with no more fears than with the Lycoming > engines. Different strokes for different folks, but not as doom and > gloom as you indicate. > > Take some time to Google Sonex, KR2, Soneraii, Hummelbird, etc and > Corvair, Subaru EA-81, and VW engines conversions. You will find lots > of successful auto conversions. You will also finds not so successful > ones, along with not so successful Lycoming installations as well. In > particular, look for things within the last 2 years and compare to the > old days to see the differences. > > -Dj > > ________________________________________________________________________________
Date: Jul 30, 2009
On Thu, Jul 30, 2009 at 5:28 PM, Dj Merrill wrote: Show me a pre-molded cowling for RV-10 for any alternative engine..haven't seen any. > I bet Randy Crothers would beg to differ with you with his Subaru STi > installation. > Show me the data, reliable, .041 lb/hp./hr or better, 2000 hr TBO. No one has yet. > > I'm sure some experimentation has shown that some technologies don't > work, and they phase out. The engine systems in cars of today aren't > even the same as they were 5 years ago in some cases. Progress is being > made all the time, and new technology replacing old. Who would consider > buying a car that uses magnetos these days? Things change, technology > improves, old stuff is phased out. Even Lycoming has their new FADEC > system, and magnetos and carbs of today will be phased out over time as > new technology replaces them. It is inevitable. Right. Magnetos need no external power and are totally reliable with reasonable maintenance intervals. There is no other system that provides that. EMag and Pmag are less than perfect in reliability and unavailable for 6 cyl. Electronic ignition and FADEC die without power. Even the Diamond diesel crashed with loss of power taking out FADEC. No FADEC provides optimum fuel mixture management. They are designed for lazy pilots. No one is talking carburetor. No FADEC does any better than available fuel injection properly managed. None of what you are citing is NEW. It just combines systems designed over 50 years ago. Fuel injection and turbocharging were all available by 1960 in GA engines. Nothing since adds 5% to power, economy or reliability. You simply aren't telling us anything we haven't seen before. Kelly A&P/IA EAA Tech Counselor ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 7:31 PM, Kelly McMullen wrote: > Some his fault, some engine's fault, as it was > a botched deadstick landing after loss of power. Only speculative what > caused loss of power. Hi Kelly, I knew Dan from multiple email and in-person chats. I was in the tent site next to him the Oshkosh prior to the accident. It indeed was a sad loss, and I was mortified when I heard about it. However, if you read the preliminary NTSB report, and the series of emails exchanged on this list, VAF and some of the other mailing lists, it seems pretty clear (to me at least) that as unfortunate as this accident was, it seemed to be primarily builder induced, and had nothing to do with the type of engine that was installed. I am of the opinion that it could easily have been prevented had proper tools and techniques been used, and the proper time and training employed to learn the systems on the airplane prior to flying it. We ALL learned an expensive and valuable lesson that if we see any builder taking shortcuts, we need to speak up, and speak up loudly, regardless of any hurt feelings. I heard plenty of comments around the RV10 campsite at OSH that year about some of the issues seen with his airplane, and no one, myself included, spoke up about it. That is a lesson we must NEVER forget. -Dj ________________________________________________________________________________
Date: Jul 30, 2009
I have NO idea where you got that idea. I am retired, RV-10 builder, A&P/IA and Tech Counselor. Never worked for engine manufacturer in my life. I was in one career a certified emissions technician on autos, raced cars before switching hobbies to aviation many years ago. On Thu, Jul 30, 2009 at 6:13 PM, johngoodman wrote: > > Kelly, > Not to be nosy, but don't you work for, or represent, an engine manufacturer? If I am mistaken, I apologize. > John > ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 7:40 PM, Kelly McMullen wrote: > Show me a pre-molded cowling for RV-10 for any alternative > engine..haven't seen any. <http://www.eggenfellneraircraft.com/Products.htm> $1495, professionally made by Zach Chase, as well known and respected craftsman in the fiberglass community, with tons of Glasair, Glastar, Sportsman and other aircraft under his belt. > >> I bet Randy Crothers would beg to differ with you with his Subaru STi >> installation. >> > Show me the data, reliable, .041 lb/hp./hr or better, 2000 hr TBO. No > one has yet. If you are truly interested, I invite you to contact Randy directly and inquire about his installation to find out about the HP being produced, weight of the overall installation, and other details that you may be interested in. There is no need for me to be the middle man, which would be detrimental to your fact finding mission. > Right. Magnetos need no external power and are totally reliable with > You simply aren't telling us anything we haven't seen before. I am one hundred percent certain we are not locked into magneto technology (or any technology) in the aviation world from now until the end of time. Just this year we have three (?) companies that brought all electric aircraft to OSH. In another 50 years it is not unrealistic to believe there will be lots more, or perhaps some even newer, better technology available and in widespread use. Technology improves, things change, and old tech is phased out. This is inevitable. -Dj ________________________________________________________________________________
Date: Jul 30, 2009
On Thu, Jul 30, 2009 at 7:16 PM, Dj Merrill wrote: > <http://www.eggenfellneraircraft.com/Products.htm> $1495, > professionally made by Zach Chase, as well known and respected craftsman > in the fiberglass community, with tons of Glasair, Glastar, Sportsman > and other aircraft under his belt. > OK, One exists. Pardon me if I insult anyone, but that appearance is butt ugly, compared to James cowl or Vans cowl. >>> I bet Randy Crothers would beg to differ with you with his Subaru STi >>> installation. >>> >> Show me the data, reliable, .041 lb/hp./hr or better, 2000 hr TBO. No >> one has yet. I am not willing to take the time to search the world for someone that might have a one off producing those fuel specifics. If there were one, that made enough since, they would have the ear of the aircraft manufacturers. Porsche tried, and failed miserably with their PFM engine. No, I don't think Subaru or their tuners are smarter than Porsche. > > >> Right. Magnetos need no external power and are totally reliable with > >> You simply aren't telling us anything we haven't seen before. > > I am one hundred percent certain we are not locked into magneto > technology (or any technology) in the aviation world from now until the > end of time. Just this year we have three (?) companies that brought > all electric aircraft to OSH. In another 50 years it is not unrealistic > to believe there will be lots more, or perhaps some even newer, better > technology available and in widespread use. We may not be locked into magnetos, but there is no more reliable way to have independently powered ignition out there today. Every battery powered system has failure points, and you can waste lots of time building redundant power systems that are heavier, and no more efficient. There simply is not more than 5% power available by using the latest variable timing electronic ignition, over fixed timing magnetos, and the electronics simply are not as reliable. That has been fact for many years and hasn't changed. Loss of power on Dan Lloyd's plane is very likely from electrical failure, whether builder induced or not. Had he been more careful, it might have gone a few years without a failure, maybe not. I'm not interested in a 220hp engine for a plane the size of the -10 anyway. If that were sufficient, I could mount up a TCM IO-360 like 220RV and dismiss all the development and vendor issues with Eggenfeller. ________________________________________________________________________________
Date: Jul 30, 2009
Kelly, As I said in my post, I apologize if it was not correct. I just remember you making posts about Barrett, or somebody like that. I also remember that you were the one who got me on to NAPA 7220 primer. Best primer advice I've ever gotten. No harm intended. John Kelly McMullen wrote: > I have NO idea where you got that idea. I am retired, RV-10 builder, > A&P/IA and Tech Counselor. Never worked for engine manufacturer in my > life. I was in one career a certified emissions technician on autos, > raced cars before switching hobbies to aviation many years ago. > > On Thu, Jul 30, 2009 at 6:13 PM, johngoodman wrote: > > > > > > > Kelly, > > Not to be nosy, but don't you work for, or represent, an engine manufacturer? If I am mistaken, I apologize. > > John > > > > > > > -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255307#255307 ________________________________________________________________________________
Date: Jul 30, 2009
Thanks Ralph. I went (back) to the MT site and found the manual. Printed it but not read yet but I'm sure I have whatever is available. Thanks! Ralph E. Capen wrote: > > Bill, > > I got documentation with mine (180hp 6A) - I'll try to remember to dig it out this weekend and zap it to you. > > Alternatively, check out the MT website - they may have it online.... > > Ralph > > -----Original Message----- > >> From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> >> Sent: Jul 30, 2009 3:04 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: MT Prop Controller >> >> >> I'm searching the archives for information on re-aligning the actuating >> arm on the controller and I've found a few items. >> >> However, am I supposed to have some documentation on the controller as >> part of my Van's/Lycoming engine package? >> >> Any guidance appreciated. >> >> Bill "baffling the engine while dreaming of Oshkosh" Watson >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 9:03 PM, Kelly McMullen wrote: > One exists. Pardon me if I insult anyone, but that appearance is butt > ugly, compared to James cowl or Vans cowl. No insult taken. Beauty is always in the eye of the beholder, and aesthetics is always a personal choice. I've always thought the A-10 "Warthog" aircraft were very cool looking, but I know others that think they are butt ugly. > I am not willing to take the time to search the world for someone that > might have a one off producing those fuel specifics. If there were *shrug* I can only point you to the source, I can't make you actually go get the data and read it. If you decide you are interested enough, you now have a potential place to find out more about it. > We may not be locked into magnetos, but there is no more reliable way > to have independently powered ignition out there today. I haven't researched every single ignition source that is available today, so I can't really comment whether this is true or not. It is entirely possible there are ignition sources that are more reliable than magnetos, but I don't know. What about the three electric power aircraft that are being shown at OSH this year? Are their electronic ignition sources more reliable than magnetos? Are they more efficient? > over fixed timing magnetos, and > the electronics simply are not as reliable. That has been fact for > many years and hasn't changed. I'm not sure I am willing to accept this at face value. Typically in the computing world, the MTBF of electronics is much higher than that of physical devices that have moving parts. Do you have reliability data on the electronics in the latest ignition systems versus magnetos that you'd be willing to share with us? > I'm not interested in a 220hp engine for a plane the size of the -10 anyway. The current Subaru STi is putting out 305 hp in the car. I don't know exactly what Randy's STi system is putting out for HP, but I bet if you contacted him he might share that info with you... :-) -Dj ________________________________________________________________________________
Date: Jul 30, 2009
On Thu, Jul 30, 2009 at 8:57 PM, Dj Merrill wrote: >> I am not willing to take the time to search the world for someone that >> might have a one off producing those fuel specifics. If there were > > *shrug* I can only point you to the source, I can't make you actually > go get the data and read it. If you decide you are interested enough, > you now have a potential place to find out more about it. You are free to make your choices. How many are flying with the STi engine in what airframes? What are the fuel specifics? What is the weight. If you make others go search that info, maybe it isn't worth advertising how "good" it is. >> > I'm not sure I am willing to accept this at face value. Typically in > the computing world, the MTBF of electronics is much higher than that of > physical devices that have moving parts. Do you have reliability data > on the electronics in the latest ignition systems versus magnetos that > you'd be willing to share with us? > Simple. No 12 V power, electronic is dead, no backup. To be independent you need two separate systems and batteries. Find me one battery as light a magneto that can power an ignition as long as you need. >> I'm not interested in a 220hp engine for a plane the size of the -10 anyway. > > The current Subaru STi is putting out 305 hp in the car. I don't know > exactly what Randy's STi system is putting out for HP, but I bet if you > contacted him he might share that info with you... :-) Why don't you show us how good it is? Can it do it without a failure prone PSRU? Horsepower delivered to the prop?? If the product is so good, I'm sure others want to know details. Color me skeptical. ________________________________________________________________________________
Subject: Auto Power
Date: Jul 30, 2009
Paul, I have a rotary powered RV10 in phase 1 with about 20 hours on it. So far no major issues. It's the RX8 two-rotor engine with a small super charger. It's producing about 238 hp and closely matches Van's estimates for the 235 hp engine. No fuel flow data yet but should be between .45 and .55 BSFC. I'm running richer because of the super charger and the 100 +F degree days here in Texas. But I'm also running 93 octane auto fuel so it's a little easier on the wallet than 100LL. My FWF probably coast about 18K but I made several items several times. My engine was a 0 time crate engine and I paid $5000 for it with several mod's mostly to remove internals not needed for aviation. Several others are putting 3 rotor, 20B's in RV-10's. They will see between 260 and 300 hp depending on intake design and porting. There's also a nice twin turbo Subaru RV-10 that should be close to completion. He's a second- time RV and Subaru offender. Ross? If you have an interest you should do the research. Then if anyone can talk you out of it you shouldn't do it. If someone can talk you into it then you also shouldn't do it. It will add years to your build time and may not save you any money. Saving money on the engine block is not a good reason to pursue an alternative. The total cost of ownership and flying can be less expensive then a Lyc. http://www.flyrotary.com/ <http://www.flyrotary.com/> is a good resource for learning about auto conversions. Its rotary related but things like cooling and fuel systems have almost become standard regardless of the alternative engine. Our rotary group has had several first flights this year. I am very fortunate to have two other flying rotary's here in Austin TX. One Lancair ES and an RV-7A. I will not debate the merits of alternative engines on this site but I will debunk a few things that were stated as absolute. BSFC better than .41. Piston and rotary engines average about .5 BSFC. But who cares if you run at least 50% auto fuel. Alternative engine FWF's are heaver. While this is usually true it's not set in stone. There are a few flying examples of lighter installations. 2000 hr TBO. Who cares if you can buy 3-4 new engines for the price of a lyc overhaul. We have several rotaries with over 1000 hrs. One should be close to 3000. I have no data on the Chevy's or Subi's. RV-10 Cowl. Egg's got one for the Subi. Extreme Composites has a base cowl for the Rotary. You have to add your own cooling inlets. This allows the builder more options for heat exchanger placement. Not sure who makes the subi cowl but Extreme composites makes cowls for the F1 rocket and other aviation fiberglass parts. I will also confirm a few things that have been said and add a few more. Your FWF will likely take more time than the airframe. Your personal Phase 1 will likely be more than 100 hrs. Flight testing will carry more risk. Your electrical system needs to be bullet proof. Your resale value will be lower. No problem if you plan to keep the plane at least 10 years. The money you save on fuel will make up most of the difference. Your own your own for service and repairs. No dropping it off at the repair shop. Dan's accident was a tragedy and a blow to everyone on this list. But lyc's and cont's also fail. The rotary powered lancair ES driver here in Austin keeps a chunk of steel in is hanger. If ask him why he chose to put an alternative engine in his plane he will hand it to you. It's what's left of a Lyc piston that exited the cowl. Fortunately they had turned back to the airport about 30 seconds before the engine came apart. Just made the runway. We have another rotary owner with the same story. Bobby Hughes ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Walter Sent: Wednesday, July 29, 2009 8:46 PM Subject: RV10-List: Auto Power Hello to the group, I came across an aluminum block V8 powered RV 10 on utube recently. It was still a way off flying but had the engine running. I was wondering if anyone in the U.S. actually has a flying example of this type of engine installation and if so how the performance numbers stack up compared to a Lycoming etc. Paul ~=03 ________________________________________________________________________________
Date: Jul 30, 2009
On 7/30/2009 10:30 PM, Kelly McMullen wrote: > You are free to make your choices. How many are flying with the STi > engine in what airframes? > What are the fuel specifics? What is the weight. If you make others go > search that info, maybe it isn't worth advertising how "good" it is. I have no idea. You seemed interested, so I was simply trying to help you find the information you seek. If you are interested in the STi information, I'd recommend that you contact Randy Crothers and ask him about his setup. He posts frequently on the VAF forums, and I could probably locate his e-mail address for you or anyone that may want it. Just for clarification, I'm not advertising for anything. I am merely trying to clarify some potential mis-information, and help point people to sources for information if they are interested in finding out more. > Simple. No 12 V power, electronic is dead, no backup. To be > independent you need two separate systems and batteries. Find me one > battery as light a magneto that can power an ignition as long as you > need. Okay, no fuel, piston engine goes dead. So which is more reliable, the electric engine, or the piston engine? The two failure modes we just mentioned tell us nothing about how reliable either engine package might be. All they tell us is that without the source of fuel for the engine (electrons for the electric engine, gasoline for the piston engine), the engine does not run. The electric engine needs power to run (ie, electricity). The piston engine needs gasoline, air, and power (spark). On the surface it would seem that needing 3 things to run versus 1 thing to run would make the piston engine less reliable. In other words, the chances that 1 out of the 3 things would fail might be higher than just one thing failing. But that is misleading as well. We need to know what is the reliability of each of the individual items, and then calculate them all together to get a better idea of overall reliability. The piston engine also has significantly more moving parts than the electric engine. More moving parts generally means a higher chance of one of those parts failing, but that doesn't paint the whole picture either. The electric engine might have a single part that has an MTBF of 10 hours, for example. We can't really tell anything about the reliability of the piston engine, the electric engine, or the various options available for piston engines without having the reliability data for each part, and calculating the assembled engine package as a whole. Without that critical data, all of this is just speculation from both of us. > Why don't you show us how good it is? Can it do it without a failure > prone PSRU? Horsepower delivered to the prop?? If the product is so > good, I'm sure others want to know details. Color me skeptical. If you are the one interested, why would you ask me to do this work for you? I've offered what help I can and tried to give some potential sources for the information that you seek. If you are interested, you should satisfy your curiosity for yourself, and I'll try to offer what information I can. If you are not interested, I don't see how asking others to do this work is of any benefit. -Dj ________________________________________________________________________________
Subject: GRT EIS Probes
Date: Jul 31, 2009
From: "McGann, Ron" <Ron.McGann(at)thalesgroup.com.au>
G'day all, I have the GRT EIS installed. I have an intermittent connection on one of my EGT probes (EGT #2 bounces wildly from actual Temp to 0). Anybody know whether 0 degrees indicated is an Open Circuit or Short to ground condition on the EGT wires? Cheers, Ron VH-XRM, Flying in Oz DISCLAIMER:---------------------------------------------------------------- ----------- This e-mail transmission and any documents, files and previous e-mail messa ges attached to it are private and confidential. They may contain proprietary o r copyright material or information that is subject to legal professional privilege. Th ey are for the use of the intended recipient only. Any unauthorised viewing, use, dis closure, copying, alteration, storage or distribution of, or reliance on, this messa ge is strictly prohibited. No part may be reproduced, adapted or transmitted with out the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by re turn email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be d eemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attac hed are error or virus free. --------------------------------------------------------------------------- ----------- ________________________________________________________________________________
Subject: Re: Auto Power
Date: Jul 30, 2009
On Jul 30, 2009, at 11:00 PM, Jesse Saint wrote: > > Anybody know of a good primer to use Sherwin Williams 988 http://www.sherwin-automotive.com/products/show_product.cfm?product=7565 :-) -Dj > ________________________________________________________________________________
Date: Jul 31, 2009
On Thu, Jul 30, 2009 at 10:49 PM, Bobby J. Hughes wrote: > Paul, > I have a rotary powered RV10 in phase 1 with about 20 hours on it. So far no > major issues. Its the RX8 two-rotor engine with a small super charger. Its > producing about 238 hp and closely matches Vans estimates for the 235 hp > engine. No fuel flow data yet but should be between .45 and .55 BSFC. Im > running richer because of the super charger and the 100 +F degree days here > in Texas. But Im also running 93 octane auto fuel so its a little easier > on the wallet than 100LL. So can a Lyc. run on mogas. Good luck finding it in most parts of the country without ethanol. > BSFC better than .41. Piston and rotary engines average about .5 BSFC. But > who cares if you run at least 50% auto fuel. It is called range. Higher fuel consumption equals significantly shorter fuel range, unless you put in aux tanks with that debate. > 2000 hr TBO. Who cares if you can buy 3-4 new engines for the price of a > lyc overhaul. We have several rotaries with over 1000 hrs. One should be > close to 3000. I have no data on the Chevys or Subis. Who wants to change engines every 1000-1500 hours? Who pays for that labor? But lycs > and conts also fail. The rotary powered lancair ES driver here in Austin > keeps a chunk of steel in is hanger. If ask him why he chose to put an > alternative engine in his plane he will hand it to you. Its whats left of > a Lyc piston that exited the cowl. Fortunately they had turned back to the > airport about 30 seconds before the engine came apart. Just made the > runway.We have another rotary owner with the same story. Lycoming pistons and Continental pistons are aluminum, not steel. Only the TCM has a steel insert for the ring land. Tell him to try a new story or new name to the part. Perhaps it was a steel connecting rod....improper inspection/assembly...no engine is immune from that. Engines don't fail catastrophically unless not built right to start, or over stressed by turbos/superchargers or drastically improper operation/maintenance. ________________________________________________________________________________
Subject: RV-10 OSH Event Reminder
Date: Jul 31, 2009
Just a reminder to those at OSH that we're having the big cookout tonight. Smoked brisket, fresh sweet corn, beans, strawberry shortcake and ice cream! starting around 6:00, nothing to bring except possibly a chair. We'll have a plate out to collect some $ if you'd like to contribute. Even if you don't eat or are running late feel free to stop by - very difficult to find a larger collection of RV-10 flyers and builders in one spot. There are usually people out talking until at least 10:30 or 11:00. Location is Camp Scholler, 55th and Lindbergh which is about a 5 minute walk from either the Theater in the Woods gate or the Fly Market gate. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255344#255344 ________________________________________________________________________________
Subject: Auto Power
Date: Jul 31, 2009
So can a Lyc. run on mogas. Good luck finding it in most parts of the country without ethanol. None locally yet but the fuel system is ethanol safe. No vapor pressure issues so far. It is called range. Higher fuel consumption equals significantly shorter fuel range, unless you put in aux tanks with that debate. Personal range is about 3 hours. Plane can go much further than me. Lycoming pistons and Continental pistons are aluminum, not steel. Only the TCM has a steel insert for the ring land. Tell him to try a new story or new name to the part. Perhaps it was a steel connecting rod....improper inspection/assembly...no engine is immune from that. Engines don't fail catastrophically unless not built right to start, or over stressed by turbos/superchargers or drastically improper operation/maintenance. Your correct. Pistons are aluminum and rotors are steel. So I should have said ball of aluminum. It was also a trainer so maintenance should have been perfect right? Who wants to change engines every 1000-1500 hours? Who pays for that labor? It would be about a three day task with my airframe and I would do it myself. As I said, you can't just drop it off at the shop. Bobby (back to lurking) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, July 31, 2009 5:38 AM Subject: Re: RV10-List: Auto Power On Thu, Jul 30, 2009 at 10:49 PM, Bobby J. Hughes wrote: > Paul, > I have a rotary powered RV10 in phase 1 with about 20 hours on it. So > far no major issues. It's the RX8 two-rotor engine with a small super > charger. It's producing about 238 hp and closely matches Van's > estimates for the 235 hp engine. No fuel flow data yet but should be > between .45 and .55 BSFC. I'm running richer because of the super > charger and the 100 +F degree days here in Texas. But I'm also > running 93 octane auto fuel so it's a little easier on the wallet than 100LL. So can a Lyc. run on mogas. Good luck finding it in most parts of the country without ethanol. > BSFC better than .41. Piston and rotary engines average about .5 > BSFC. But who cares if you run at least 50% auto fuel. It is called range. Higher fuel consumption equals significantly shorter fuel range, unless you put in aux tanks with that debate. > 2000 hr TBO. Who cares if you can buy 3-4 new engines for the price > of a lyc overhaul. We have several rotaries with over 1000 hrs. One > should be close to 3000. I have no data on the Chevy's or Subi's. Who wants to change engines every 1000-1500 hours? Who pays for that labor? But lyc's > and cont's also fail. The rotary powered lancair ES driver here in > Austin keeps a chunk of steel in is hanger. If ask him why he chose to > put an alternative engine in his plane he will hand it to you. It's > what's left of a Lyc piston that exited the cowl. Fortunately they had > turned back to the airport about 30 seconds before the engine came > apart. Just made the runway.We have another rotary owner with the same story. Lycoming pistons and Continental pistons are aluminum, not steel. Only the TCM has a steel insert for the ring land. Tell him to try a new story or new name to the part. Perhaps it was a steel connecting rod....improper inspection/assembly...no engine is immune from that. Engines don't fail catastrophically unless not built right to start, or over stressed by turbos/superchargers or drastically improper operation/maintenance. ________________________________________________________________________________
Date: Jul 31, 2009
Subject: Re: RV-10 OSH Event Reminder
Big Thanks to Bob. Great hospitality all week. Sorry I can't be there as my return flight leaves Rockford early this afternoon. Was great meeting some of the names seen here and seeing the pieces Geoff is developing for the interior. On Fri, Jul 31, 2009 at 7:13 AM, bcondrey wrote: > > Just a reminder to those at OSH that we're having the big cookout tonight. Smoked brisket, fresh sweet corn, beans, strawberry shortcake and ice cream! > > starting around 6:00, nothing to bring except possibly a chair. We'll have a plate out to collect some $ if you'd like to contribute. > > Even if you don't eat or are running late feel free to stop by - very difficult to find a larger collection of RV-10 flyers and builders in one spot. There are usually people out talking until at least 10:30 or 11:00. > > Location is Camp Scholler, 55th and Lindbergh which is about a 5 minute walk from either the Theater in the Woods gate or the Fly Market gate. > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255344#255344 > > ________________________________________________________________________________
Date: Jul 31, 2009
On 07/31/2009 07:38 AM, Kelly McMullen wrote: > So can a Lyc. run on mogas. Good luck finding it in most parts of the > country without ethanol. One minor difference is that both Mazda and Subaru have designed and support their engines running on gasoline with a 10% ethanol blend. Lycoming does not yet support their engine running on gasoline w/ ethanol, although it will likely burn it just fine. > It is called range. Higher fuel consumption equals significantly > shorter fuel range, unless you put in aux tanks with that debate. At OSH this year a company is demonstrating their new gas/electric hybrid aircraft engine. Another example of automotive inspired ideas being modified for use in aviation. It supposedly gives an additional 40 hp for takeoff. No idea if it helps with gas mileage, but I can see adaptions of it where it might. Very cool stuff! It just gets better every year! :-) > Who wants to change engines every 1000-1500 hours? Who pays for that > labor? > An auto engine overhaul is about 1/10 the cost of a Lycoming overhaul, so I would overhaul engines every 1000 hours versus 2000 hours. I think that works out to something like at least $15k savings for every 2000 hours? That will buy lots of fuel, even at .5 BSFC. :-) Even better, if I can put in a brand new engine every 1000 hours instead of an overhauled engine every 2000 hours, that attracts me even more. It is about $5k for a new auto engine, and somewhere around $20k to overhaul a Lyc to new specs. Presuming the auto engine would even need to be replaced at 1000 hours, that is still about a $10k cost savings, and you get a new engine instead of a "used" one. I suppose the same person that pays for the labor to replace the Lyc every 2000 hours would pay for the auto engine replacement every 1000. Would there be another choice for having someone else pay with either the Lyc or auto engine? -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: Re. GRT EIS Probe
Date: Jul 31, 2009
Hi Ron, I had the same problem; mine was a bad crimp on the D-Sub pin in the connector to the EIS box. You should have continuity from the pin to ground. GRT troubleshooting guide explains how to check it out. Blue Skys Barry. Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Jul 31, 2009
Hey Bobby - Thanks for contributing with the information. Of course the argument will rage on, but I applaud true experimentation and innovation. As with anything, there are pros and cons, and the bonus of building is that we get to make those decisions, do research, and have debates. I ended up going Lyc, but in the beginning, I was 100% positive that I'd be doing something alternative. After much soul searching and research, I made the decision that was best for me. A big part of the decision was the time investment. My girlfriend would rather be flying than sitting around while I tinker, and in her mind there's already been too much tinkering! Anyway, I hope to see your bird around sometime. I appreciate you coming out from lurking to add some info. cj On Jul 30, 2009, at 8:49 PM, Bobby J. Hughes wrote: > Paul, > > I have a rotary powered RV10 in phase 1 with about 20 hours on it. > So far no major issues. It=92s the RX8 two-rotor engine with a small > super charger. It=92s producing about 238 hp and closely matches > Van=92s estimates for the 235 hp engine. No fuel flow data yet but > should be between .45 and .55 BSFC. I=92m running richer because of > the super charger and the 100 +F degree days here in Texas. But > I=92m also running 93 octane auto fuel so it=92s a little easier on the > wallet than 100LL. My FWF probably coast about 18K but I made > several items several times. My engine was a 0 time crate engine > and I paid $5000 for it with several mod=92s mostly to remove > internals not needed for aviation. Several others are putting 3 > rotor, 20B=92s in RV-10=92s. They will see between 260 and 300 hp > depending on intake design and porting. There=92s also a nice twin > turbo Subaru RV-10 that should be close to completion. He=92s a > second- time RV and Subaru offender. Ross? > > If you have an interest you should do the research. Then if anyone > can talk you out of it you shouldn=92t do it. If someone can talk you > into it then you also shouldn=92t do it. It will add years to your > build time and may not save you any money. Saving money on the > engine block is not a good reason to pursue an alternative. The > total cost of ownership and flying can be less expensive then a > Lyc. http://www.flyrotary.com/ is a good resource for learning > about auto conversions. Its rotary related but things like cooling > and fuel systems have almost become standard regardless of the > alternative engine. Our rotary group has had several first flights > this year. I am very fortunate to have two other flying rotary=92s > here in Austin TX. One Lancair ES and an RV-7A. > > I will not debate the merits of alternative engines on this site > but I will debunk a few things that were stated as absolute. > > BSFC better than .41. Piston and rotary engines average about .5 > BSFC. But who cares if you run at least 50% auto fuel. > > Alternative engine FWF=92s are heaver. While this is usually true > it=92s not set in stone. There are a few flying examples of lighter > installations. > > 2000 hr TBO. Who cares if you can buy 3-4 new engines for the > price of a lyc overhaul. We have several rotaries with over 1000 > hrs. One should be close to 3000. I have no data on the Chevy=92s or > Subi=92s. > > RV-10 Cowl. Egg=92s got one for the Subi. Extreme Composites has a > base cowl for the Rotary. You have to add your own cooling inlets. > This allows the builder more options for heat exchanger placement. > Not sure who makes the subi cowl but Extreme composites makes cowls > for the F1 rocket and other aviation fiberglass parts. > > > I will also confirm a few things that have been said and add a few > more. > > Your FWF will likely take more time than the airframe. > Your personal Phase 1 will likely be more than 100 hrs. > Flight testing will carry more risk. > Your electrical system needs to be bullet proof. > Your resale value will be lower. No problem if you plan to keep the > plane at least 10 years. The money you save on fuel will make up > most of the difference. > Your own your own for service and repairs. No dropping it off at > the repair shop. > Dan=92s accident was a tragedy and a blow to everyone on this list. > But lyc=92s and cont=92s also fail. The rotary powered lancair ES > driver here in Austin keeps a chunk of steel in is hanger. If ask > him why he chose to put an alternative engine in his plane he will > hand it to you. It=92s what=92s left of a Lyc piston that exited the > cowl. Fortunately they had turned back to the airport about 30 > seconds before the engine came apart. Just made the runway. We have > another rotary owner with the same story. > > > Bobby Hughes > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Paul Walter > Sent: Wednesday, July 29, 2009 8:46 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Auto Power > > > Hello to the group, > > I came across an aluminum block V8 powered RV 10 on utube recently. > It was still a way off flying but had the engine running. I was > wondering if anyone in the U.S. actually has a flying example of > this type of engine installation and if so how the performance > numbers stack up compared to a Lycoming etc. > > Paul > ~=03 > > > href="http://www.matronics.com/Navigator?RV10-List">http:// > www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Date: Jul 31, 2009
On Fri, Jul 31, 2009 at 11:01 AM, Dj Merrill wrote: > One minor difference is that both Mazda and Subaru have designed and > support their engines running on gasoline with a 10% ethanol blend. > Lycoming does not yet support their engine running on gasoline w/ > ethanol, although it will likely burn it just fine. Lycoming and Continental don't support mogas with ethanol because the FAA prohibits its use, for good reason. Higher vapor pressure than pure mogas, by at least a full point, and very absorbtive of any humidity/moisture. Also, mogas does attack some formulations of Proseal. I'm sure you want to redo your tanks. > An auto engine overhaul is about 1/10 the cost of a Lycoming > overhaul, so I would overhaul engines every 1000 hours versus 2000 > hours. I think that works out to something like at least $15k savings > for every 2000 hours? That will buy lots of fuel, even at .5 BSFC. :-) Good luck on doing a full, competent overhaul for $2000. I've done enough auto engines to know that isn't happening today. I can certainly do a Lycoming for less than $20K unless major components are worn out. > I suppose the same person that pays for the labor to replace the Lyc > every 2000 hours would pay for the auto engine replacement every 1000. > Would there be another choice for having someone else pay with either > the Lyc or auto engine? Whether you pay for the labor or do it yourself, you are still looking at a good 40 hours worth of work. No where are you accounting for the cost of overhauling the PSRU every 500 hours or so, and the cost of removing and installing it. The choice is certainly yours, just don't go in with blinders. ________________________________________________________________________________
Date: Jul 31, 2009
On 07/31/2009 02:31 PM, Kelly McMullen wrote: > Lycoming and Continental don't support mogas with ethanol because the > FAA prohibits its use, for good reason. > Automotive gasoline with ethanol is not prohibited by the FAA in experimental aircraft. > Higher vapor pressure than pure mogas, by at least a full point, and > very absorbtive of any humidity/moisture. > If using automotive fuel, you are supposed to test every time to ensure you are using a good "batch". A pain, but not difficult or time consuming, and it is rare to get a batch that does not pass. With the full recirculating fuel system in an automotive conversion, the humidity/moisture is not as much of a concern as with the Lycoming. By the time you are ready to crank the engine, the fuel pumps have already remixed the fuel and it just gets burned, same as in the car. When flying, the fuel is constantly being remixed as well, so less concern of separation at altitude. > Also, mogas does attack some formulations of Proseal. I'm sure you > want to redo your tanks. > No worries about that in my Sportsman - one piece tanks, no proseal! :-) The fuel system components and engine in my aircraft are all compatible with the use of automotive fuel containing ethanol. I do not know about compatibility with Proseal, so anyone contemplating the use of mogas with ethanol in tanks using proseal should research it and verify. It is possible that those already running automotive conversions in their RVs have done this, so that may be a good place to start the research. > Good luck on doing a full, competent overhaul for $2000. I've done > enough auto engines to know that isn't happening today. > I can certainly do a Lycoming for less than $20K unless major > components are worn out. > Even if it were 3k for the engine overhaul, still a far cry from $15k to $20k. > Whether you pay for the labor or do it yourself, you are still looking > at a good 40 hours worth of work. > No where are you accounting for the cost of overhauling the PSRU every > 500 hours or so, and the cost of removing and installing it. > Curious, where are you getting the 500 hours for TBO of the PSRU? Also, where did you get the 1000 hours for overhauling an automotive engine? I'm very interested in any data that you have that would validate those TBO figures. Thanks! The cost of removing and reinstalling the auto engine from the airframe, in terms of dollars or time, is about the same as with the Lyc, so I'd consider that a wash. If I'm replacing the engine and PSRU (not overhauling them), it is simply a matter of reinstalling, so no time spent on the overhaul itself. If overhauling, the time involved should also be similar to the time to overhaul the Lyc, so again a wash. A brand new PSRU is about $4500. I do not know the cost of the overhaul, but let's say maybe $3k to replace the internals. If you have a more exact number we can recalculate. If we estimate high at a $3k engine overhaul and $3k PSRU overhaul, that is a total of about $6k. So you could overhaul the automotive setup 3 times for approximately the same cost as overhauling the Lyc once. -Dj ________________________________________________________________________________
Date: Aug 01, 2009
I wish I could have been there. I didn't get home until about 9pm last night. After the late start with a dead battery (thanks Jim and Steve), then it took about 1.5 hours to get around Indy at rush hour. It was a great week. I met many new friends and saw many old ones. It was a great week! Thanks to Bob, Gary, Susan, and Brenda for handling all the logistics and hospitality!! Most know that I left early to pick up my son who has been off at AFROTC Field training for the last month or so. He just gave us a call and we found out he got the Distinguished Graduate and Top Gun awards. Needless to say, we are proud of his accomplishments. It's been a great week for our family..... Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bcondrey Sent: Friday, July 31, 2009 8:13 AM Subject: RV10-List: RV-10 OSH Event Reminder Just a reminder to those at OSH that we're having the big cookout tonight. Smoked brisket, fresh sweet corn, beans, strawberry shortcake and ice cream! starting around 6:00, nothing to bring except possibly a chair. We'll have a plate out to collect some $ if you'd like to contribute. Even if you don't eat or are running late feel free to stop by - very difficult to find a larger collection of RV-10 flyers and builders in one spot. There are usually people out talking until at least 10:30 or 11:00. Location is Camp Scholler, 55th and Lindbergh which is about a 5 minute walk from either the Theater in the Woods gate or the Fly Market gate. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255344#255344 ________________________________________________________________________________
Subject: GRT AHRS Mounting and CG
Date: Aug 01, 2009
Anyone have a feeling about how far it is acceptable to mount the AHRS from the CG? When does the "lever affect" really kick-in? I would like to put it on a shelf like others have done - one bay behind the battery bay, with the magnetometers there too. What do those in the know think? Thank You Chris Lucas #40072 ________________________________________________________________________________
Date: Aug 01, 2009
I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers. Dick Gurley -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Saturday, August 01, 2009 10:53 AM Subject: RV10-List: GRT AHRS Mounting and CG Anyone have a feeling about how far it is acceptable to mount the AHRS from the CG? When does the "lever affect" really kick-in? I would like to put it on a shelf like others have done - one bay behind the battery bay, with the magnetometers there too. What do those in the know think? Thank You Chris Lucas #40072 ________________________________________________________________________________
Subject: Re: GRT AHRS Mounting and CG
Date: Aug 01, 2009
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
V29uJ3QgYmUgYSBwcm9ibGVtLg0KDQpCb2INCg0KICBfX19fXyAgDQoNCkZyb206IG93bmVyLXJ2 MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSA8b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tPiANClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSA8cnYxMC1saXN0QG1hdHJv bmljcy5jb20+IA0KU2VudDogU2F0IEF1ZyAwMSAwNzo1Mjo1MCAyMDA5DQpTdWJqZWN0OiBSVjEw LUxpc3Q6IEdSVCBBSFJTIE1vdW50aW5nIGFuZCBDRyANCg0KDQpBbnlvbmUgaGF2ZSBhIGZlZWxp bmcgYWJvdXQgaG93IGZhciBpdCBpcyBhY2NlcHRhYmxlIHRvIG1vdW50IHRoZSBBSFJTIGZyb20g dGhlIENHPyBXaGVuIGRvZXMgdGhlIOKAnGxldmVyIGFmZmVjdOKAnSByZWFsbHkga2ljay1pbj8N Cg0KSSB3b3VsZCBsaWtlIHRvIHB1dCBpdCBvbiBhIHNoZWxmIGxpa2Ugb3RoZXJzIGhhdmUgZG9u ZSAgLSBvbmUgYmF5IGJlaGluZCB0aGUgYmF0dGVyeSBiYXksIHdpdGggdGhlIG1hZ25ldG9tZXRl cnMgdGhlcmUgdG9vLiBXaGF0IGRvIHRob3NlIGluIHRoZSBrbm93IHRoaW5rPw0KDQpUaGFuayBZ b3UNCg0KQ2hyaXMgTHVjYXMNCg0KIzQwMDcyDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgIC0g VGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMg c3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25s b2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBt dWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdh dG9yP1JWMTAtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1Mg V0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0 aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNp dGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAg IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg= ________________________________________________________________________________
Date: Aug 01, 2009
rngurley wrote: > I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers. > > Dick Gurley > > -- Darn! When I asked them the same question at Sun 'n fun they didn't blink an eye when I said I would mount both on a tray behind the battery bay. If you look at their installation documentation for both, they have to be within 0.5 degrees of each other in all orientations. Talk about CYA. I'm calling on Monday! John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255561#255561 ________________________________________________________________________________
Date: Aug 01, 2009
I mounted the magnetometers up high in the bay with the batteries and have no issue - been flying over a year. YMMV. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Sat Aug 01 15:25:03 2009 Subject: RV10-List: Re: GRT AHRS Mounting and CG rngurley wrote: > I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers. > > Dick Gurley > > -- Darn! When I asked them the same question at Sun 'n fun they didn't blink an eye when I said I would mount both on a tray behind the battery bay. If you look at their installation documentation for both, they have to be within 0.5 degrees of each other in all orientations. Talk about CYA. I'm calling on Monday! John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255561#255561 ________________________________________________________________________________
Date: Aug 01, 2009
Dick, SO your saying they told you the AHRS itself could interfere with the magnetometer performance? That seems odd. I wouldn't think much is going on electrically in the AHRS plus it had that thick Al housing. Let us know what they say John Goodman if you get a call in to GRT on Monday. I'll call Tuesday to see if we get a third answer!! I think I am going to press forward based on the input from folks already in operation (I kinda just finished the mounting this evening anyway). When it comes time, I'll give it all a thorough check out and move things later if I have to. It is very convenient to have it all on the shelf instead of having to run more wires out the wing etc. Thanks for the inputs. -Chris #40072 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Gurley Sent: Saturday, August 01, 2009 4:55 PM Subject: RE: RV10-List: GRT AHRS Mounting and CG I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers. Dick Gurley -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Saturday, August 01, 2009 10:53 AM Subject: RV10-List: GRT AHRS Mounting and CG Anyone have a feeling about how far it is acceptable to mount the AHRS from the CG? When does the "lever affect" really kick-in? I would like to put it on a shelf like others have done - one bay behind the battery bay, with the magnetometers there too. What do those in the know think? Thank You Chris Lucas #40072 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: DIY Panel Labeling $20.00
Date: Aug 01, 2009
RV-List, I thought I would share a sweet way to do your own panel labeling that is fast, inexpensive and great looking. In fact your graphic choices are nearly unlimited. I had the unfortunate situation where the graphics on my panel we not acceptable. I paid to reshoot the panel and decided to label some of the items myself. I had considered using clear labels and a Dymo style label maker like I used with my RV-6A. The results were actually quite good but with limited choices in font selection, size and spacing. The ideal system would be to use my graphics software to design the correct labels and then transfer them to my panel in Decal form. With a little research I sourced: Color Laser Water Slide Decal Paper by papoilio. www.papoilio.com I purchased the large pack of 10 sheets ($13.00) in case I screwed up but I only needed one sheet as I was able to fit duplicate labels all on a single page. I designed my labels in Adobe Illustrator because it is a vector based program making the text and borders ultra crisp. I also happen to own a Minolta Magicolor 2400W color laser printer which gave me excellent results. If my printer didn't work well my plan was to run a thumb drive down to Kinkos and use their large Color Laser Printer but there was no need after I output and tested the first sheet. If you are OK with Black graphics any Laser Printer will do. From here the process was straight forward, trim, soak in bowl of water for 15 seconds, don't spill the bowl of water in the plane (hardest step), place the decal on a pre-moistened portion of your panel and properly position. Do the next decal while the first one is drying. I purchased a special rubber squeegee and floating agent at the same time I purchased the paper but never found the need to use them. If you are confident you only need the 5 sheet pack your cost may be as low as $10.00. For high wear areas they suggest a clear coat over the decal but these are in a low touch location and they seem pretty durable to me. With your own graphic designs your panel labeling choices are virtually unlimited including photographs or multi color process: (note: labels below are fuzzy due to .jpg conversion) Robin ________________________________________________________________________________
Date: Aug 02, 2009
Subject: Re: DIY Panel Labeling $20.00
Robin,=0Ais this the stuff? your link wasn't working.=0Ahttp://www.papilio. com/laser%20water%20slide%20decal%20paper.html=0Ajohn=0A=0A=0A_____________ ___________________=0AFrom: Robin Marks <robin1(at)mrmoisture.com>=0ATo: rv10- list(at)matronics.com; rv-list(at)matronics.com=0ASent: Saturday, August 1, 2009 11:12:14 PM=0ASubject: RV10-List: DIY Panel Labeling $20.00=0A=0A =0ARV-Lis t,=0A I=0Athought I would share a sweet way to do your own panel labeling that is fast,=0Ainexpensive and great looking. In fact your graph ic choices are nearly=0Aunlimited. =0A I=0Ahad the unfortunate s ituation where the graphics on my panel we not acceptable.=0AI paid to resh oot the panel and decided to label some of the items myself. I=0Ahad consid ered using clear labels and a Dymo style label maker like I used with=0Amy RV-6A. The results were actually quite good but with limited choices in fon t=0Aselection, size and spacing. The ideal system would be to use my graphi cs software=0Ato design the correct labels and then transfer them to my pan el in Decal form.=0AWith a little research I sourced:=0A =0AColor=0ALaser W ater Slide Decal Paper by papoilio. www.papoilio.com =0A =0A I =0Apurchased the large pack of 10 sheets ($13.00) in case I screwed up but I only=0Aneeded one sheet as I was able to fit duplicate labels all on a si ngle page. I=0Adesigned my labels in Adobe Illustrator because it is a vect or based program making=0Athe text and borders ultra crisp. I also happen t o own a Minolta Magicolor=0A2400W color laser printer which gave me excelle nt results. If my printer didn=99t=0Awork well my plan was to run a t humb drive down to Kinkos and use their large Color=0ALaser Printer but the re was no need after I output and tested the first sheet.=0AIf you are OK w ith Black graphics any Laser Printer will do. =0A From=0Ahere t he process was straight forward, trim, soak in bowl of water for 15=0Asecon ds, don=99t spill the bowl of water in the plane (hardest step), plac e=0Athe decal on a pre-moistened portion of your panel and properly positio n. Do=0Athe next decal while the first one is drying.=0A I=0Apur chased a special rubber squeegee and floating agent at the same time I=0Apu rchased the paper but never found the need to use them. If you are confiden t=0Ayou only need the 5 sheet pack your cost may be as low as $10.00. =0A For=0Ahigh wear areas they suggest a clear coat over the decal bu t these are in a low=0Atouch location and they seem pretty durable to me. =0A =0A =0AWith=0Ayour own graphic designs your panel labeling choices are virtually unlimited including=0Aphotographs or multi color process:=0A(note :=0Alabels below are fuzzy due to .jpg conversion)=0A =0ARobin ________________________________________________________________________________
Subject: Re: > Re: GRT AHRS Mounting and CG
Date: Aug 02, 2009
I have GRT dual AHRS and MAGS mounted above the battery and after 150 hrs have had no problems. The individual AHRS are as close to centerline as I could get them, and the MAGS are as far outboard as I could get them. Blue Skys Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Aug 02, 2009
WWVzIGl0IGlzLiBNeSBwYWNrYWdpbmcgaGFzIGEgZGlmZmVyZW50IHBob3RvIG9uIGl0IGJ1dCB0 aGUgZGVzY3JpcHRpb24gaXMgaWRlbnRpY2FsLg0KDQpBcyBzdGF0ZWQgSSBhbSB2ZXJ5IHBsZWFz ZWQgd2l0aCB0aGUgcmVzdWx0cyBidXQgSSBkaWQgcmVjZWl2ZSBhIHNtYWNrIGRvd24gZnJvbSBT dGVpbiBzdGF0aW5nIHRoYXQgb3ZlciB0aW1lIGFuZCBleHBvc3VyZSB0byBVViB0aGUgbGFiZWxz IHdvbuKAmXQgbGFzdCBhcyBsb25nIGFuZCBhcmUgbm90IGFzIGR1cmFibGUgcHJvZmVzc2lvbmFs bHkgcHJpbnRlZCBsYWJlbHMgYW5kIGhlIHN1Z2dlc3RlZCBvbmUgY2FuIGNyZWF0ZSB0aGUgZXhh Y3Qgc2FtZSBncmFwaGljcyBhbmQgZW1haWwgdGhlbSB0byBhIHBhbmVsIHNob3AgbGlrZSBoaXMg YW5kIHRoZXkgd2lsbCBwcmludCBkZWNhbHMgb24gaGlnaCBxdWFsaXR5IFRoZXJtYWwgUHJpbnRl cnMgd2hpY2ggYXBwYXJlbnRseSBvZmZlciBiZXR0ZXIgVVYgcHJvdGVjdGlvbiBhbmQgdXNlIHdh dGVycHJvb2YgaW5rcy4gU3RlaW4gc3RhdGVzIG1vc3QgcGxhY2VzIG9ubHkgY2hhcmdlICQyMC4w MCBwZXIgc2hlZXQuIA0KDQpJIHJlYWxseSBsaWtlZCBkb2luZyBpdCDigJxpbiBob3VzZeKAnSBh bmQgbXkgdGVzdCBsYWJlbHMgc2VlbSBkdXJhYmxlIGVub3VnaCAobXVjaCBiZXR0ZXIgdGhhbiBJ IGV4cGVjdGVkKSBwbHVzIEkgc2VlIG5vIGlzc3VlcyBsYWJlbGluZyBzbWFsbCBpdGVtcyBsaWtl IGNpcmN1aXQgYnJlYWtlcnMgYW5kIEkgZG91YnQgVVYgaXMgYSBzaWduaWZpY2FudCBpc3N1ZSBm b3IgbXkgaGFuZ2FyZWQgcGxhbmUuIFdpdGggdGhlIHVsdGltYXRlIGZhbGwgYmFjayB0aGF0IEkg Y2FuIHJlcHJpbnQgdGhlIHJlcGxhY2UgdGhlIGRlY2FscyBmb3Igbm90aGluZyBtb3JlIHRoYW4g bXkgdGltZSBpZiBuZWVkIGJlLiANCg0KVGhhdCBiZWluZyBzYWlkIFN0ZWluIGlzIGV4Y2VwdGlv bmFsbHkga25vd2xlZGdlYWJsZSBhbmQg4oCcYmVlbiB0aGVyZSwgZG9uZSB0aGF04oCdIHNvIEkg d291bGQgc3VnZ2VzdCBidWlsZGVycyBsb29raW5nIGZvciBhIG1vcmUgcGVybWluYXRlIHNvbHV0 aW9uIGZvbGxvdyBoaXMgYWR2aWNlLiBFc3BlY2lhbGx5IGJlbmVmaWNpYWwgYmVjYXVzZSBpdCBo YXMgbm8gYWRkaXRpb25hbCBleHBlbnNlLg0KDQogDQoNClN0ZWlu4oCZcyBub3RlOg0KDQogDQoN ClRoaXMgaXMgc2ltaWxhciB0byB3aGF0IG1vc3Qgb2YgdXMgcGFuZWwgc2hvcHMgZG8gbm93LCBi dXQgdGhlciBhcmUgYSBmZXcgbW9yZSB0aGluZ3MgdG8gY29uc2lkZXIuICBGaXJzdCwgaWYgeW91 IGRvbid0IGNsZWFyY29hdCB0aGVtIHRoZSB0cnV0aCBpcyB0aHJ1IHdpbGwgY29tZSBvZmYsIHlv dSdsbCBzZWUgdGhlIGRlY2FscyBpbiB0aGUgc3VuLCBhbmQgdGhleSBhcmUgbm90IHZlcnkgZHVy YWJsZSBvbmNlIHRoZXkgY3VyZS4gIFNlY29uZCwgbGFzZXIgaW5rcyBkb24ndCBob2xkIHVwIHdl bGwgcmVnYXJkaW5nIHV2IGFuZCBodW1pZGl0eS4gVGhpcmQsIGluIG9yZGVyIHRvIHRyeSBhbmQg Z2V0IHdoaXRlICh5b3UgY2FuJ3QgcHJpbnQgd2hpdGUgb24gYSBsYXNlcikgeW91IGhhdmUgdG8g dHJ5IGFuZCB1c2UgZGFyayBib3JkZXJzIGZvciBldmVyeXRoaW5nLiBUaGF0J3Mgb2sgb24gbGFy Z2UgZm9udHMsIGJ1dCBnZXRzIGEgYml0IGtsdXR6eSBvbiBzbWFsbCBsYWJlbHMgb3IgbGFyZ2Ug cm93cyBvZiB0aGluZ3MgbGlrZSBzd2l0Y2hlcyAmIGNiJ3MuDQoNCiANCg0KSSB3b3VsZCBzdWdn ZXN0IGlmIHlvdSB3YW50IHRvIGdvIHRoaXMgcm91dGUgeW91IGp1c3QgYnV5IGEgc2hlZXQgb2Yg cHJpbnRlZCBkZWNhbHMgZnJvbSBvbmUgb2YgdGhlIHNob3BzICh0aGVyZSBhcmUgYSBudW1iZXIg b2YgdXMpIHRoYXQgcHJpbnQgdGhlIGRlY2FscyB3aXRoIGhpZ2ggcXVhbGl0eSAoYW5kIGhpZ2gg YnVjaykgdGhlcm1hbCBwcmludGVycy4gIFlvdSBnZXQgZ29vZCB1diBhbmQgd2F0ZXJwcm9vZiBp bmtzIHRoYXQgY2FuIHN0aWxsIGJlIHByaW50ZWQgaW4gY29sb3JzLCBidXQgYWxzbyBpbiBwdXJl IHdoaXRlIGFzIHdlbGwgYXMgbWV0YWxsaWMgZm9pbHMgdG9vLiBNb3N0IHBsYWNlcyBzdGlsbCBv bmx5IGNoYXJnZSBhYm91dCAkMjAgcGVyIHNoZWV0IG9mIGRlY2Fscy4NCg0KIA0KDQpSb2Jpbidz IHNvbHV0aW9uIGlzIGEgZ29vZCBzdGFydC4uLmJ1dCB3aWhvdXQgZ29vZCBpbmtzIGFuZCBhIGNs ZWFyY29hdCB0aGUgbG9uZyB0ZXJtIHJlc3VsdCB3aWxsIGJlIGxlc3MgdGhhbiBzdGVsbGFyLiAg V2UndmUgdHJpZWQgYWxtb3N0IGV2ZXJ5IHNvbHV0aW9uIG92ZXIgdGhlIHllYXJzIGFuZCBoYXZl IGxlYXJuZWQgdGhlIGhhcmQgd2F5LiANCg0KIA0KDQpNeSAyIGNlbnRzIGFzIHVzdWFsIChmcm9t IE9TSCkhDQoNCiANCg0KQ2hlZXJzLA0KDQpTdGVpbg0KDQogDQoNCiANCg0KRnJvbTogb3duZXIt cnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNl cnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgSm9obiBIdXJzdA0KU2VudDogU3VuZGF5 LCBBdWd1c3QgMDIsIDIwMDkgMTowNiBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpT dWJqZWN0OiBSZTogUlYxMC1MaXN0OiBESVkgUGFuZWwgTGFiZWxpbmcgJDIwLjAwDQoNCiANCg0K Um9iaW4sDQppcyB0aGlzIHRoZSBzdHVmZj8geW91ciBsaW5rIHdhc24ndCB3b3JraW5nLg0KaHR0 cDovL3d3dy5wYXBpbGlvLmNvbS9sYXNlciUyMHdhdGVyJTIwc2xpZGUlMjBkZWNhbCUyMHBhcGVy Lmh0bWwNCmpvaG4NCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCg0KRnJvbTog Um9iaW4gTWFya3MgPHJvYmluMUBtcm1vaXN0dXJlLmNvbT4NClRvOiBydjEwLWxpc3RAbWF0cm9u aWNzLmNvbTsgcnYtbGlzdEBtYXRyb25pY3MuY29tDQpTZW50OiBTYXR1cmRheSwgQXVndXN0IDEs IDIwMDkgMTE6MTI6MTQgUE0NClN1YmplY3Q6IFJWMTAtTGlzdDogRElZIFBhbmVsIExhYmVsaW5n ICQyMC4wMA0KDQpSVi1MaXN0LA0KDQogICAgICAgICAgICBJIHRob3VnaHQgSSB3b3VsZCBzaGFy ZSBhIHN3ZWV0IHdheSB0byBkbyB5b3VyIG93biBwYW5lbCBsYWJlbGluZyB0aGF0IGlzIGZhc3Qs IGluZXhwZW5zaXZlIGFuZCBncmVhdCBsb29raW5nLiBJbiBmYWN0IHlvdXIgZ3JhcGhpYyBjaG9p Y2VzIGFyZSBuZWFybHkgdW5saW1pdGVkLiANCg0KICAgICAgICAgICAgSSBoYWQgdGhlIHVuZm9y dHVuYXRlIHNpdHVhdGlvbiB3aGVyZSB0aGUgZ3JhcGhpY3Mgb24gbXkgcGFuZWwgd2Ugbm90IGFj Y2VwdGFibGUuIEkgcGFpZCB0byByZXNob290IHRoZSBwYW5lbCBhbmQgZGVjaWRlZCB0byBsYWJl bCBzb21lIG9mIHRoZSBpdGVtcyBteXNlbGYuIEkgaGFkIGNvbnNpZGVyZWQgdXNpbmcgY2xlYXIg bGFiZWxzIGFuZCBhIER5bW8gc3R5bGUgbGFiZWwgbWFrZXIgbGlrZSBJIHVzZWQgd2l0aCBteSBS Vi02QS4gVGhlIHJlc3VsdHMgd2VyZSBhY3R1YWxseSBxdWl0ZSBnb29kIGJ1dCB3aXRoIGxpbWl0 ZWQgY2hvaWNlcyBpbiBmb250IHNlbGVjdGlvbiwgc2l6ZSBhbmQgc3BhY2luZy4gVGhlIGlkZWFs IHN5c3RlbSB3b3VsZCBiZSB0byB1c2UgbXkgZ3JhcGhpY3Mgc29mdHdhcmUgdG8gZGVzaWduIHRo ZSBjb3JyZWN0IGxhYmVscyBhbmQgdGhlbiB0cmFuc2ZlciB0aGVtIHRvIG15IHBhbmVsIGluIERl Y2FsIGZvcm0uIFdpdGggYSBsaXR0bGUgcmVzZWFyY2ggSSBzb3VyY2VkOg0KDQogDQoNCkNvbG9y IExhc2VyIFdhdGVyIFNsaWRlIERlY2FsIFBhcGVyIGJ5IHBhcG9pbGlvLiB3d3cucGFwb2lsaW8u Y29tIA0KDQogDQoNCiAgICAgICAgICAgIEkgcHVyY2hhc2VkIHRoZSBsYXJnZSBwYWNrIG9mIDEw IHNoZWV0cyAoJDEzLjAwKSBpbiBjYXNlIEkgc2NyZXdlZCB1cCBidXQgSSBvbmx5IG5lZWRlZCBv bmUgc2hlZXQgYXMgSSB3YXMgYWJsZSB0byBmaXQgZHVwbGljYXRlIGxhYmVscyBhbGwgb24gYSBz aW5nbGUgcGFnZS4gSSBkZXNpZ25lZCBteSBsYWJlbHMgaW4gQWRvYmUgSWxsdXN0cmF0b3IgYmVj YXVzZSBpdCBpcyBhIHZlY3RvciBiYXNlZCBwcm9ncmFtIG1ha2luZyB0aGUgdGV4dCBhbmQgYm9y ZGVycyB1bHRyYSBjcmlzcC4gSSBhbHNvIGhhcHBlbiB0byBvd24gYSBNaW5vbHRhIE1hZ2ljb2xv ciAyNDAwVyBjb2xvciBsYXNlciBwcmludGVyIHdoaWNoIGdhdmUgbWUgZXhjZWxsZW50IHJlc3Vs dHMuIElmIG15IHByaW50ZXIgZGlkbuKAmXQgd29yayB3ZWxsIG15IHBsYW4gd2FzIHRvIHJ1biBh IHRodW1iIGRyaXZlIGRvd24gdG8gS2lua29zIGFuZCB1c2UgdGhlaXIgbGFyZ2UgQ29sb3IgTGFz ZXIgUHJpbnRlciBidXQgdGhlcmUgd2FzIG5vIG5lZWQgYWZ0ZXIgSSBvdXRwdXQgYW5kIHRlc3Rl ZCB0aGUgZmlyc3Qgc2hlZXQuIElmIHlvdSBhcmUgT0sgd2l0aCBCbGFjayBncmFwaGljcyBhbnkg TGFzZXIgUHJpbnRlciB3aWxsIGRvLiAgDQoNCiAgICAgICAgICAgIEZyb20gaGVyZSB0aGUgcHJv Y2VzcyB3YXMgc3RyYWlnaHQgZm9yd2FyZCwgdHJpbSwgc29hayBpbiBib3dsIG9mIHdhdGVyIGZv ciAxNSBzZWNvbmRzLCBkb27igJl0IHNwaWxsIHRoZSBib3dsIG9mIHdhdGVyIGluIHRoZSBwbGFu ZSAoaGFyZGVzdCBzdGVwKSwgcGxhY2UgdGhlIGRlY2FsIG9uIGEgcHJlLW1vaXN0ZW5lZCBwb3J0 aW9uIG9mIHlvdXIgcGFuZWwgYW5kIHByb3Blcmx5IHBvc2l0aW9uLiBEbyB0aGUgbmV4dCBkZWNh bCB3aGlsZSB0aGUgZmlyc3Qgb25lIGlzIGRyeWluZy4NCg0KICAgICAgICAgICAgSSBwdXJjaGFz ZWQgYSBzcGVjaWFsIHJ1YmJlciBzcXVlZWdlZSBhbmQgZmxvYXRpbmcgYWdlbnQgYXQgdGhlIHNh bWUgdGltZSBJIHB1cmNoYXNlZCB0aGUgcGFwZXIgYnV0IG5ldmVyIGZvdW5kIHRoZSBuZWVkIHRv IHVzZSB0aGVtLiBJZiB5b3UgYXJlIGNvbmZpZGVudCB5b3Ugb25seSBuZWVkIHRoZSA1IHNoZWV0 IHBhY2sgeW91ciBjb3N0IG1heSBiZSBhcyBsb3cgYXMgJDEwLjAwLiANCg0KICAgICAgICAgICAg Rm9yIGhpZ2ggd2VhciBhcmVhcyB0aGV5IHN1Z2dlc3QgYSBjbGVhciBjb2F0IG92ZXIgdGhlIGRl Y2FsIGJ1dCB0aGVzZSBhcmUgaW4gYSBsb3cgdG91Y2ggbG9jYXRpb24gYW5kIHRoZXkgc2VlbSBw cmV0dHkgZHVyYWJsZSB0byBtZS4NCg0KIA0KDQogDQoNCiANCg0KV2l0aCB5b3VyIG93biBncmFw aGljIGRlc2lnbnMgeW91ciBwYW5lbCBsYWJlbGluZyBjaG9pY2VzIGFyZSB2aXJ0dWFsbHkgdW5s aW1pdGVkIGluY2x1ZGluZyBwaG90b2dyYXBocyBvciBtdWx0aSBjb2xvciBwcm9jZXNzOg0KDQoo bm90ZTogbGFiZWxzIGJlbG93IGFyZSBmdXp6eSBkdWUgdG8gLmpwZyBjb252ZXJzaW9uKQ0KDQog DQoNCiANCg0KUm9iaW4NCg0KTm8gdmlydXMgZm91bmQgaW4gdGhpcyBpbmNvbWluZyBtZXNzYWdl Lg0KQ2hlY2tlZCBieSBBVkcgLSB3d3cuYXZnLmNvbQ0KVmVyc2lvbjogOC41LjM5MiAvIFZpcnVz IERhdGFiYXNlOiAyNzAuMTMuMzgvMjI3NCAtIFJlbGVhc2UgRGF0ZTogMDgvMDIvMDkgMDU6NTY6 MDANCg0K ________________________________________________________________________________
Subject: Congrats on OSH 09
Date: Aug 02, 2009
Let me be the first to congratulate Joe Czachorowski of Wilmington, Delaware on his N87FT which wowed the judges and won the Bronze Lindy for Kit Champion yesterday. My personal favorite was Mark Chamberlain's Scheme Designer paint job on N104ML from Temecula, CA. There were lots of great RV-10s on display. Honorable mention should go to Deems Davis on N519PJ from Arizona, for getting into the social scene so fast he forgot to post the Green "Judge ME" sticker soon enough, and his work should not be overlooked. John Cox #600 ________________________________________________________________________________
Date: Aug 03, 2009
I would support this. My AHRS and magnetometer are located in the 'standard' position on a tray above and aft of the battery. I thought it was magnetically benign, but about 10 mins into every flight my displays suffer the 'leans' by about 5degs. Still trying to get to the bottom of the issue. GRT seem to be fairly sure that there is some magnetic interference there. I will be moving the magnetometer to the wingtip shortly. I reckon magnetometer installation is a chook raffle (crapshoot to you guys up north). AHRS on the tray and magnetomoeters in the wingtip should be standard IMHO. Cheers, Ron VH-XRM Flying in oz -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Gurley Sent: Sunday, 2 August 2009 6:55 AM Subject: RE: RV10-List: GRT AHRS Mounting and CG I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers. Dick Gurley -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Saturday, August 01, 2009 10:53 AM Subject: RV10-List: GRT AHRS Mounting and CG Anyone have a feeling about how far it is acceptable to mount the AHRS from the CG? When does the "lever affect" really kick-in? I would like to put it on a shelf like others have done - one bay behind the battery bay, with the magnetometers there too. What do those in the know think? Thank You Chris Lucas #40072 DISCLAIMER:--------------------------------------------------------------------------- This e-mail transmission and any documents, files and previous e-mail messages attached to it are private and confidential. They may contain proprietary or copyright material or information that is subject to legal professional privilege. They are for the use of the intended recipient only. Any unauthorised viewing, use, disclosure, copying, alteration, storage or distribution of, or reliance on, this message is strictly prohibited. No part may be reproduced, adapted or transmitted without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by return email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be deemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attached are error or virus free. -------------------------------------------------------------------------------------- ________________________________________________________________________________
Subject: Re: OSH - Looking to share camping for tent
Date: Aug 03, 2009
try to choose the sierra tent its has a good quality ________________ Event tents (http://www.buyshade.com) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255733#255733 ________________________________________________________________________________
Subject: Flap Bulge - Leading Edge
Date: Aug 03, 2009
Lessons for Oshkosh.... A while back we noticed the nose of our flaps bulges slightly below the bottom wing skin. The bulge is not consistent along the length of the flap. While at Oshkosh I compared our flaps to other examples and found that this is a fairly common problem (if it can be called a problem). All of the aircraft with retracted flaps I looked at had the problem, except one (Vans demo RV-10). I did not look at all of the examples on display. I talked to Ken K. about this, he seemed surprised. I asked if it would be OK to hand form the leading edge to eliminate the bulge, he said that would be good. He also said we could bend the bottom wing skin down a bit. We had quick build wings (including the flaps). Just passing along the observation. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Subject: Forward Slips
Date: Aug 03, 2009
I would like to pass along a flight test experience I had. I initiated a slip at 85 knots (note well below Va) (zero degree flap setting), the rudder pedal was fairly hard to push, however as it approached what I would guess to be just beyond the middle of its travel the 'tone' of the airframe changed, and the rudder became much easier to apply, the airplane 'jerked' further into the slip, and felt as if it was going to swap ends. It did not roll much, just an abrupt yaw. I then had to apply opposite rudder to return back to neutral. I did not get to the rudder stop. The rudder almost felt as if it went 'over center'. Weight & Balance during this test 2510 LBS @ 112.7". Note I was using pitch to maintain airspeed, and aileron to control heading (or track). After this happened I spoke with a few others who are flying, no one had performed this maneuver. I then spoke with Ken K. about this while at Oshkosh. He said he had experienced the same thing, although he entered it quickly by stomping the rudder pedal to the floor. He could not explain exactly what was causing the problem, he thought it might be dihedral stability. I told him the I suppose the right answer is "don't do that", he quickly replied that maneuver may be required if the flap motor was lost, and you were forced to slow down and land without flaps. I also spoke with Alex D. about this, he has also experienced the same thing, he said it is worse when you have -3 degrees reflex, and still there at 0 degrees. I have done this with one and two notches of 'real' flaps and was able to do full slips. Ken K. asked me (with a smile) if I had enough 'guts' to get the rudder all the way to the floor to see how far it went, I didn't. At least not before understanding what is going on, and if this is limited to our copy. After experiencing this I have a few takeaways. 1) Expect the unexpected, I hate surprises, imagine the surprise while performing a fairly standard maneuver and getting a result never experienced before. 2) Don't do that.... 3) Share what is learned even at the risk of what replies are sure to come. I say don't do that but I believe Ken has a valid argument, at very least we should all understand what our aircraft behave like even if the maneuver is at the fringe of what we would normally expect to perform. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Subject: Repairmen's Certificate
Date: Aug 03, 2009
Just thought I would pass long my experience getting the Repairmen's Certificate for our RV-10. We used Joe Norris who works for EAA in Oshkosh as our DAR and Tech Counselor. Joe said that he does not issue the Repairmen's Certificate, and I had to go to the FSDO to get the cert. While in Oshkosh (since we are local) I got in touch with the Milwaukee FSDO on the field. He offered to go over and look at the airplane with me, and ask a few questions about the construction. This amounted to comparing our paperwork to the data plates, and asking which part we built first. He did comment that our "Experimental" marking was 'marginal' at best. We have it located in the baggage bulkhead, which is somewhat blocked by the rear seat headrests. He didn't demand that we fix it, he said if Joe thought it was OK, then it is OK. I said we would move the markings to the door, as 'marginal' isn't acceptable to me, he was very happy to hear this. BTW, regarding the "Experimental" marking..... We had Flightline Interiors do our interior, wonderful product, wonderful people. As I said we had our experimental marked on the baggage bulkhead, during our DAR inspection we had to make a new experimental marking because all of the letters embroidered on the bulkhead were not 2" tall. The capitol letters were taller, the lower-case letters were too short. It was in a 'fancy' font, but that wasn't a problem. Abby made good and re-did the piece, so it looks like we now have a take three on the markings. The next day I brought my laptop into the office and showed him pictures of the build, he wanted to see me actually working, not posing with parts. He also wanted to see me working at all of the stages to prove I was involved from beginning to end. He looked up the RV-10 quickbuild in the database to verify it meets the 51% rule. He asked how I planned to inspect the airplane, and what checklists I had for the inspections. He wanted to hear that our part 43 checklist was modified to include unique maintenance features of our model. He asked me to bring along the builders log, but did not review it. He issued the certificate on the spot. Kinda cool, he even filled out the application overnight, I only had to double check the info, and sign my name. This guy was great! I had thought that the Repairmen's Certificate was issued at the same time as the inspection, but that was not the case for us, just passing along the experience. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Date: Aug 03, 2009
Jason, If the FAA makes the airworthiness inspection you can get the Repairman's certificate at the same time. A DAR cannot issue it. I had my Pietenpol Air Camper (which I flew to OSH this year - it was the green one with yellow wings parked right in front of the Brown Arch) inspected by the FSDO and they issued my repairman's certificate at the same time as the Airworthiness Certificate. That certificate is worth a lot - about $1500 a year in annual Condition Inspection costs. Jack Phillips, Raleigh NC Pietenpol NX899JP RV-10 # 40610 (still working on wings - slow build) _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com Sent: Monday, August 03, 2009 9:41 AM Subject: RV10-List: Repairmen's Certificate Just thought I would pass long my experience getting the Repairmen's Certificate for our RV-10. We used Joe Norris who works for EAA in Oshkosh as our DAR and Tech Counselor. Joe said that he does not issue the Repairmen's Certificate, and I had to go to the FSDO to get the cert. While in Oshkosh (since we are local) I got in touch with the Milwaukee FSDO on the field. He offered to go over and look at the airplane with me, and ask a few questions about the construction. This amounted to comparing our paperwork to the data plates, and asking which part we built first. He did comment that our "Experimental" marking was 'marginal' at best. We have it located in the baggage bulkhead, which is somewhat blocked by the rear seat headrests. He didn't demand that we fix it, he said if Joe thought it was OK, then it is OK. I said we would move the markings to the door, as 'marginal' isn't acceptable to me, he was very happy to hear this. BTW, regarding the "Experimental" marking..... We had Flightline Interiors do our interior, wonderful product, wonderful people. As I said we had our experimental marked on the baggage bulkhead, during our DAR inspection we had to make a new experimental marking because all of the letters embroidered on the bulkhead were not 2" tall. The capitol letters were taller, the lower-case letters were too short. It was in a 'fancy' font, but that wasn't a problem. Abby made good and re-did the piece, so it looks like we now have a take three on the markings. The next day I brought my laptop into the office and showed him pictures of the build, he wanted to see me actually working, not posing with parts. He also wanted to see me working at all of the stages to prove I was involved from beginning to end. He looked up the RV-10 quickbuild in the database to verify it meets the 51% rule. He asked how I planned to inspect the airplane, and what checklists I had for the inspections. He wanted to hear that our part 43 checklist was modified to include unique maintenance features of our model. He asked me to bring along the builders log, but did not review it. He issued the certificate on the spot. Kinda cool, he even filled out the application overnight, I only had to double check the info, and sign my name. This guy was great! I had thought that the Repairmen's Certificate was issued at the same time as the inspection, but that was not the case for us, just passing along the experience. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Subject: Re: Repairmen's Certificate
Date: Aug 03, 2009
That's a FSDO that has nothing better to do...It.should only be a interview with the recommendation letter from the DAR....I don't need another inspection...heck they wouldn't even talk to me about doing the airworthiness inspection. I hope my request is less of a hassle than yours Rick Sked N246RS Sent via BlackBerry by AT&T -----Original Message----- From: jason.kreidler(at)regalbeloit.com Date: Mon, 3 Aug 2009 08:40:55 Subject: RV10-List: Repairmen's Certificate This is a multipart message in MIME format. ________________________________________________________________________________
Date: Aug 03, 2009
Mark The link to the web site does not work could you please resend the linl Thanks John G. Cumins 40864 Elevator assymb. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Saturday, August 01, 2009 8:12 PM Subject: RV10-List: DIY Panel Labeling $20.00 RV-List, I thought I would share a sweet way to do your own panel labeling that is fast, inexpensive and great looking. In fact your graphic choices are nearly unlimited. I had the unfortunate situation where the graphics on my panel we not acceptable. I paid to reshoot the panel and decided to label some of the items myself. I had considered using clear labels and a Dymo style label maker like I used with my RV-6A. The results were actually quite good but with limited choices in font selection, size and spacing. The ideal system would be to use my graphics software to design the correct labels and then transfer them to my panel in Decal form. With a little research I sourced: Color Laser Water Slide Decal Paper by papoilio. www.papoilio.com I purchased the large pack of 10 sheets ($13.00) in case I screwed up but I only needed one sheet as I was able to fit duplicate labels all on a single page. I designed my labels in Adobe Illustrator because it is a vector based program making the text and borders ultra crisp. I also happen to own a Minolta Magicolor 2400W color laser printer which gave me excellent results. If my printer didn't work well my plan was to run a thumb drive down to Kinkos and use their large Color Laser Printer but there was no need after I output and tested the first sheet. If you are OK with Black graphics any Laser Printer will do. From here the process was straight forward, trim, soak in bowl of water for 15 seconds, don't spill the bowl of water in the plane (hardest step), place the decal on a pre-moistened portion of your panel and properly position. Do the next decal while the first one is drying. I purchased a special rubber squeegee and floating agent at the same time I purchased the paper but never found the need to use them. If you are confident you only need the 5 sheet pack your cost may be as low as $10.00. For high wear areas they suggest a clear coat over the decal but these are in a low touch location and they seem pretty durable to me. With your own graphic designs your panel labeling choices are virtually unlimited including photographs or multi color process: (note: labels below are fuzzy due to .jpg conversion) Robin ________________________________________________________________________________
Date: Aug 03, 2009
If you use a DAR, you must apply in person for the Repairman's cert. If you use the Feds, they can issue it without appearing in person. Tim Olson - RV-10 N104CD jason.kreidler(at)regalbeloit.com wrote: > > Just thought I would pass long my experience getting the Repairmen's > Certificate for our RV-10. We used Joe Norris who works for EAA in > Oshkosh as our DAR and Tech Counselor. Joe said that he does not issue > the Repairmen's Certificate, and I had to go to the FSDO to get the > cert. While in Oshkosh (since we are local) I got in touch with the > Milwaukee FSDO on the field. He offered to go over and look at the > airplane with me, and ask a few questions about the construction. This > amounted to comparing our paperwork to the data plates, and asking which > part we built first. He did comment that our "Experimental" marking was > 'marginal' at best. We have it located in the baggage bulkhead, which > is somewhat blocked by the rear seat headrests. He didn't demand that > we fix it, he said if Joe thought it was OK, then it is OK. I said we > would move the markings to the door, as 'marginal' isn't acceptable to > me, he was very happy to hear this. > > BTW, regarding the "Experimental" marking..... We had Flightline > Interiors do our interior, wonderful product, wonderful people. As I > said we had our experimental marked on the baggage bulkhead, during our > DAR inspection we had to make a new experimental marking because all of > the letters embroidered on the bulkhead were not 2" tall. The capitol > letters were taller, the lower-case letters were too short. It was in a > 'fancy' font, but that wasn't a problem. Abby made good and re-did the > piece, so it looks like we now have a take three on the markings. > > The next day I brought my laptop into the office and showed him pictures > of the build, he wanted to see me actually working, not posing with > parts. He also wanted to see me working at all of the stages to prove I > was involved from beginning to end. He looked up the RV-10 quickbuild > in the database to verify it meets the 51% rule. He asked how I planned > to inspect the airplane, and what checklists I had for the inspections. > He wanted to hear that our part 43 checklist was modified to include > unique maintenance features of our model. He asked me to bring along > the builders log, but did not review it. He issued the certificate on > the spot. Kinda cool, he even filled out the application overnight, I > only had to double check the info, and sign my name. This guy was great! > > I had thought that the Repairmen's Certificate was issued at the same > time as the inspection, but that was not the case for us, just passing > along the experience. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > * > > > * ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Aug 03, 2009
Hmm, very interesting. Back when I used to fly skydivers the forward slip was a SOP for getting down from altitude without shock cooling the engine and the slips were sometimes so aggressive that it wasn't uncommon to unpor t the fuel tank with the reduced fuel that jump ships carry. It's somethin g I do sometimes without even thinking about it and that would have been qu ite the surprise. Thanks for sharing with us. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com Sent: Monday, August 03, 2009 8:10 AM Subject: RV10-List: Forward Slips I would like to pass along a flight test experience I had. I initiated a slip at 85 knots (note well below Va) (zero degree flap setti ng), the rudder pedal was fairly hard to push, however as it approached wha t I would guess to be just beyond the middle of its travel the 'tone' of th e airframe changed, and the rudder became much easier to apply, the airplan e 'jerked' further into the slip, and felt as if it was going to swap ends. It did not roll much, just an abrupt yaw. I then had to apply opposite r udder to return back to neutral. I did not get to the rudder stop. The ru dder almost felt as if it went 'over center'. Weight & Balance during this test 2510 LBS @ 112.7". Note I was using pitch to maintain airspeed, and aileron to control heading (or track). After this happened I spoke with a few others who are flying, no one had pe rformed this maneuver. I then spoke with Ken K. about this while at Oshkos h. He said he had experienced the same thing, although he entered it quick ly by stomping the rudder pedal to the floor. He could not explain exactly what was causing the problem, he thought it might be dihedral stability. I told him the I suppose the right answer is "don't do that", he quickly re plied that maneuver may be required if the flap motor was lost, and you wer e forced to slow down and land without flaps. I also spoke with Alex D. about this, he has also experienced the same thin g, he said it is worse when you have -3 degrees reflex, and still there at 0 degrees. I have done this with one and two notches of 'real' flaps and w as able to do full slips. Ken K. asked me (with a smile) if I had enough 'guts' to get the rudder all the way to the floor to see how far it went, I didn't. At least not befor e understanding what is going on, and if this is limited to our copy. After experiencing this I have a few takeaways. 1) Expect the unexpected, I hate surprises, imagine the surprise while performing a fairly standard m aneuver and getting a result never experienced before. 2) Don't do that... . 3) Share what is learned even at the risk of what replies are sure to co me. I say don't do that but I believe Ken has a valid argument, at very least w e should all understand what our aircraft behave like even if the maneuver is at the fringe of what we would normally expect to perform. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Date: Aug 03, 2009
Good info for builders not yet complete. Along the way on my build, I had scores of pictures taken of me working on various sections as well as documentation of how I ran things. Put it all together into a power point presentation with text boxes, arrows, etc, and took that to the FSDO when I went for my repairman's certificate. Also took my flight checklist and the annual condition checklists for his review. Made issuing my certificate a breeze. grumpy N184JM On Aug 3, 2009, at 8:40 AM, jason.kreidler(at)regalbeloit.com wrote: > > Just thought I would pass long my experience getting the Repairmen's > Certificate for our RV-10. We used Joe Norris who works for EAA in > Oshkosh as our DAR and Tech Counselor. Joe said that he does not > issue the Repairmen's Certificate, and I had to go to the FSDO to > get the cert. While in Oshkosh (since we are local) I got in touch > with the Milwaukee FSDO on the field. He offered to go over and > look at the airplane with me, and ask a few questions about the > construction. This amounted to comparing our paperwork to the data > plates, and asking which part we built first. He did comment that > our "Experimental" marking was 'marginal' at best. We have it > located in the baggage bulkhead, which is somewhat blocked by the > rear seat headrests. He didn't demand that we fix it, he said if > Joe thought it was OK, then it is OK. I said we would move the > markings to the door, as 'marginal' isn't acceptable to me, he was > very happy to hear this. > > BTW, regarding the "Experimental" marking..... We had Flightline > Interiors do our interior, wonderful product, wonderful people. As > I said we had our experimental marked on the baggage bulkhead, > during our DAR inspection we had to make a new experimental marking > because all of the letters embroidered on the bulkhead were not 2" > tall. The capitol letters were taller, the lower-case letters were > too short. It was in a 'fancy' font, but that wasn't a problem. > Abby made good and re-did the piece, so it looks like we now have a > take three on the markings. > > The next day I brought my laptop into the office and showed him > pictures of the build, he wanted to see me actually working, not > posing with parts. He also wanted to see me working at all of the > stages to prove I was involved from beginning to end. He looked up > the RV-10 quickbuild in the database to verify it meets the 51% > rule. He asked how I planned to inspect the airplane, and what > checklists I had for the inspections. He wanted to hear that our > part 43 checklist was modified to include unique maintenance > features of our model. He asked me to bring along the builders log, > but did not review it. He issued the certificate on the spot. > Kinda cool, he even filled out the application overnight, I only had > to double check the info, and sign my name. This guy was great! > > I had thought that the Repairmen's Certificate was issued at the > same time as the inspection, but that was not the case for us, just > passing along the experience. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > ________________________________________________________________________________
Date: Aug 03, 2009
The AHRS can be mounted on the standard tray next to the battery however the magnetometer must be at least 24" (IIRC) from the contactors and AP servo both of which are strong sources of magnetic energy. I found that a shelf about 3" below the top of the tailcone, attached to the J channel stringers works great. I did look into mounting a shelf across the longerons but my testing with a simple compass in that location showed large variations as things were switched on/off and the AP servo exercised. Just a few inches higher made a huge difference. Wingtips would also be an excellent location. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255783#255783 ________________________________________________________________________________
Date: - - - , 20-
great write up Thanks ----- Original Message ----- From: jason.kreidler(at)regalbeloit.com To: rv10-list(at)matronics.com Sent: Monday, August 03, 2009 7:40 AM Subject: RV10-List: Repairmen's Certificate Just thought I would pass long my experience getting the Repairmen's Certificate for our RV-10. We used Joe Norris who works for EAA in Oshkosh as our DAR and Tech Counselor. Joe said that he does not issue the Repairmen's Certificate, and I had to go to the FSDO to get the cert. While in Oshkosh (since we are local) I got in touch with the Milwaukee FSDO on the field. He offered to go over and look at the airplane with me, and ask a few questions about the construction. This amounted to comparing our paperwork to the data plates, and asking which part we built first. He did comment that our "Experimental" marking was 'marginal' at best. We have it located in the baggage bulkhead, which is somewhat blocked by the rear seat headrests. He didn't demand that we fix it, he said if Joe thought it was OK, then it is OK. I said we would move the markings to the door, as 'marginal' isn't acceptable to me, he was very happy to hear this. BTW, regarding the "Experimental" marking..... We had Flightline Interiors do our interior, wonderful product, wonderful people. As I said we had our experimental marked on the baggage bulkhead, during our DAR inspection we had to make a new experimental marking because all of the letters embroidered on the bulkhead were not 2" tall. The capitol letters were taller, the lower-case letters were too short. It was in a 'fancy' font, but that wasn't a problem. Abby made good and re-did the piece, so it looks like we now have a take three on the markings. The next day I brought my laptop into the office and showed him pictures of the build, he wanted to see me actually working, not posing with parts. He also wanted to see me working at all of the stages to prove I was involved from beginning to end. He looked up the RV-10 quickbuild in the database to verify it meets the 51% rule. He asked how I planned to inspect the airplane, and what checklists I had for the inspections. He wanted to hear that our part 43 checklist was modified to include unique maintenance features of our model. He asked me to bring along the builders log, but did not review it. He issued the certificate on the spot. Kinda cool, he even filled out the application overnight, I only had to double check the info, and sign my name. This guy was great! I had thought that the Repairmen's Certificate was issued at the same time as the inspection, but that was not the case for us, just passing along the experience. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler ________________________________________________________________________________
Subject: Re: Forward Slips
Date: Aug 03, 2009
I do slips all the time in the 10 but it's always with flaps, so the difference here is the lack of flaps. I will have to try it without just to see the effect. For standard ops though you would have flaps if you're doing a slip....so it's emergency ops that make this something to explore Tim On Aug 3, 2009, at 9:55 AM, "RV Builder (Michael Sausen)" wrote: > Hmm, very interesting. Back when I used to fly skydivers the > forward slip was a SOP for getting down from altitude without shock > cooling the engine and the slips were sometimes so aggressive that > it wasn=99t uncommon to unport the fuel tank with the reduced fuel tha > t jump ships carry. It=99s something I do sometimes without even thin > king about it and that would have been quite the surprise. Thanks f > or sharing with us. > > > Michael > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com > Sent: Monday, August 03, 2009 8:10 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Forward Slips > > > I would like to pass along a flight test experience I had. > > I initiated a slip at 85 knots (note well below Va) (zero degree > flap setting), the rudder pedal was fairly hard to push, however as > it approached what I would guess to be just beyond the middle of its > travel the 'tone' of the airframe changed, and the rudder became > much easier to apply, the airplane 'jerked' further into the slip, > and felt as if it was going to swap ends. It did not roll much, > just an abrupt yaw. I then had to apply opposite rudder to return > back to neutral. I did not get to the rudder stop. The rudder > almost felt as if it went 'over center'. Weight & Balance during > this test 2510 LBS @ 112.7". Note I was using pitch to maintain > airspeed, and aileron to control heading (or track). > > After this happened I spoke with a few others who are flying, no one > had performed this maneuver. I then spoke with Ken K. about this > while at Oshkosh. He said he had experienced the same thing, > although he entered it quickly by stomping the rudder pedal to the > floor. He could not explain exactly what was causing the problem, > he thought it might be dihedral stability. I told him the I suppose > the right answer is "don't do that", he quickly replied that > maneuver may be required if the flap motor was lost, and you were > forced to slow down and land without flaps. > > I also spoke with Alex D. about this, he has also experienced the > same thing, he said it is worse when you have -3 degrees reflex, and > still there at 0 degrees. I have done this with one and two notches > of 'real' flaps and was able to do full slips. > > Ken K. asked me (with a smile) if I had enough 'guts' to get the > rudder all the way to the floor to see how far it went, I didn't. > At least not before understanding what is going on, and if this is > limited to our copy. > > After experiencing this I have a few takeaways. 1) Expect the > unexpected, I hate surprises, imagine the surprise while performing > a fairly standard maneuver and getting a result never experienced > before. 2) Don't do that.... 3) Share what is learned even at the > risk of what replies are sure to come. > > I say don't do that but I believe Ken has a valid argument, at very > least we should all understand what our aircraft behave like even if > the maneuver is at the fringe of what we would normally expect to > perform. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Aug 03, 2009
I found it as Robin intended, but at http://www.papilio.com/index.html 3M has an aerosol lacquer which can be sprayed over the finished product to extend its life and resistance to humidity. it's a DIY project. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Monday, August 03, 2009 8:24 AM Subject: RE: RV10-List: DIY Panel Labeling $20.00 Mark The link to the web site does not work could you please resend the linl Thanks John G. Cumins 40864 Elevator assymb. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Saturday, August 01, 2009 8:12 PM Subject: RV10-List: DIY Panel Labeling $20.00 RV-List, I thought I would share a sweet way to do your own panel labeling that is fast, inexpensive and great looking. In fact your graphic choices are nearly unlimited. I had the unfortunate situation where the graphics on my panel we not acceptable. I paid to reshoot the panel and decided to label some of the items myself. I had considered using clear labels and a Dymo style label maker like I used with my RV-6A. The results were actually quite good but with limited choices in font selection, size and spacing. The ideal system would be to use my graphics software to design the correct labels and then transfer them to my panel in Decal form. With a little research I sourced: Color Laser Water Slide Decal Paper by papoilio. www.papoilio.com I purchased the large pack of 10 sheets ($13.00) in case I screwed up but I only needed one sheet as I was able to fit duplicate labels all on a single page. I designed my labels in Adobe Illustrator because it is a vector based program making the text and borders ultra crisp. I also happen to own a Minolta Magicolor 2400W color laser printer which gave me excellent results. If my printer didn't work well my plan was to run a thumb drive down to Kinkos and use their large Color Laser Printer but there was no need after I output and tested the first sheet. If you are OK with Black graphics any Laser Printer will do. >From here the process was straight forward, trim, soak in bowl of water for 15 seconds, don't spill the bowl of water in the plane (hardest step), place the decal on a pre-moistened portion of your panel and properly position. Do the next decal while the first one is drying. I purchased a special rubber squeegee and floating agent at the same time I purchased the paper but never found the need to use them. If you are confident you only need the 5 sheet pack your cost may be as low as $10.00. For high wear areas they suggest a clear coat over the decal but these are in a low touch location and they seem pretty durable to me. With your own graphic designs your panel labeling choices are virtually unlimited including photographs or multi color process: (note: labels below are fuzzy due to .jpg conversion) Robin ________________________________________________________________________________
Date: Aug 03, 2009
http://www.papilio.com/ Specific Item I used: http://www.papilio.com/laser%20water%20slide%20decal%20paper.html Where I purchased: http://www.texascraft.com/hps/home.php?cat=267 Interesting I now see they make a Bake On version that is more durable & suitable for Dishwasher cleaning. I wonder if one could use a hair dryer or heat gun to fix the label to the panel. I also see they offer temporary tattoo paper so I can sport photos of my RV-10 on my massive biceps. J Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Monday, August 03, 2009 8:24 AM Subject: RE: RV10-List: DIY Panel Labeling $20.00 Mark The link to the web site does not work could you please resend the linl Thanks John G. Cumins 40864 Elevator assymb. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Saturday, August 01, 2009 8:12 PM Subject: RV10-List: DIY Panel Labeling $20.00 RV-List, I thought I would share a sweet way to do your own panel labeling that is fast, inexpensive and great looking. In fact your graphic choices are nearly unlimited. I had the unfortunate situation where the graphics on my panel we not acceptable. I paid to reshoot the panel and decided to label some of the items myself. I had considered using clear labels and a Dymo style label maker like I used with my RV-6A. The results were actually quite good but with limited choices in font selection, size and spacing. The ideal system would be to use my graphics software to design the correct labels and then transfer them to my panel in Decal form. With a little research I sourced: Color Laser Water Slide Decal Paper by papoilio. www.papoilio.com I purchased the large pack of 10 sheets ($13.00) in case I screwed up but I only needed one sheet as I was able to fit duplicate labels all on a single page. I designed my labels in Adobe Illustrator because it is a vector based program making the text and borders ultra crisp. I also happen to own a Minolta Magicolor 2400W color laser printer which gave me excellent results. If my printer didn't work well my plan was to run a thumb drive down to Kinkos and use their large Color Laser Printer but there was no need after I output and tested the first sheet. If you are OK with Black graphics any Laser Printer will do. >From here the process was straight forward, trim, soak in bowl of water for 15 seconds, don't spill the bowl of water in the plane (hardest step), place the decal on a pre-moistened portion of your panel and properly position. Do the next decal while the first one is drying. I purchased a special rubber squeegee and floating agent at the same time I purchased the paper but never found the need to use them. If you are confident you only need the 5 sheet pack your cost may be as low as $10.00. For high wear areas they suggest a clear coat over the decal but these are in a low touch location and they seem pretty durable to me. With your own graphic designs your panel labeling choices are virtually unlimited including photographs or multi color process: (note: labels below are fuzzy due to .jpg conversion) Robin Checked by AVG - www.avg.com 08/02/09 17:56:00 ________________________________________________________________________________
Subject: Re: GRT AHRS Mounting and CG
Date: Aug 03, 2009
> SO your saying they told you the AHRS itself could interfere with the magnetometer performance? That seems odd. I wouldnt think much is going on electrically in the AHRS plus it had that thick Al housing. Let us know what they say John Goodman if you get a call in to GRT on Monday. Ill call Tuesday to see if we get a third answer!! I called, but only a few are back from Oshkosh. Left a message for a call back. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255809#255809 ________________________________________________________________________________
Date: Aug 03, 2009
OK, I got a call back from Jeff at GRT. It is true that the AHRS interferes with the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for the AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board.... John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255821#255821 ________________________________________________________________________________
Date: Aug 03, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I'm exactly 18" from closest edge of AHRS to closest edge of Magnetometer. I tried to maximize the distance from the pitch AP servo and the Strobe flash unit. I recall some previous posts on be careful with the AHRS around the pitch trim unit in the rear of the tail cone. It's further forward than you think and I recall it being difficult to setup the 18" clearance. Let's hear some more flying experiences with the GRTs. Bill "Firewall Forward" Watson johngoodman wrote: > > OK, > I got a call back from Jeff at GRT. It is true that the AHRS interferes with the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for the AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board.... > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=255821#255821 > > > ________________________________________________________________________________
Date: Aug 03, 2009
To a certain extent I agree! as far as the certificate, no need to show them the plane. I was at a recent FAA safety event and I spoke with the local FSDO rep, he kindly told me to keep good records of what I did, have pictures that show me working on something, be ready to answer what I was doing in a picture with details and be ready to tell them what I plan to do for maintenance, the checklist I'll follow and a few questions on how to repair issues, like an oil leak, mostly just to see if I have an idea of what the certificate involves from me. Sounds to me that Jason had an interested FSDO person, I have no issue with the FAA giving me feedback this way in a kind way versus an inspection at a field and be told I violate some FAA regs. Anyone who reads the AOPA legal section by Jodice knows that the FAA and NTSB are doing weird things to anyone who is in violation of some rules. I can see this being an issue by a group of local FSDO "inspectors" looking to justify their jobs at a local flyin. Most of these guys care, take their feedback as a kind offer whenever possible not as another inspection, because you really don=92t want to have to deal with what might happen if you are inspected. Nice write-up BTW Jason! Pascal From: ricksked(at)embarqmail.com Sent: Monday, August 03, 2009 7:12 AM Subject: Re: RV10-List: Repairmen's Certificate That's a FSDO that has nothing better to do...It.should only be a interview with the recommendation letter from the DAR....I don't need another inspection...heck they wouldn't even talk to me about doing the airworthiness inspection. I hope my request is less of a hassle than yours Rick Sked N246RS Sent via BlackBerry by AT&T ------------------------------------------------------------------------- ------- From: jason.kreidler(at)regalbeloit.com Date: Mon, 3 Aug 2009 08:40:55 -0500 Subject: RV10-List: Repairmen's Certificate Just thought I would pass long my experience getting the Repairmen's Certificate for our RV-10. We used Joe Norris who works for EAA in Oshkosh as our DAR and Tech Counselor. Joe said that he does not issue the Repairmen's Certificate, and I had to go to the FSDO to get the cert. While in Oshkosh (since we are local) I got in touch with the Milwaukee FSDO on the field. He offered to go over and look at the airplane with me, and ask a few questions about the construction. This amounted to comparing our paperwork to the data plates, and asking which part we built first. He did comment that our "Experimental" marking was 'marginal' at best. We have it located in the baggage bulkhead, which is somewhat blocked by the rear seat headrests. He didn't demand that we fix it, he said if Joe thought it was OK, then it is OK. I said we would move the markings to the door, as 'marginal' isn't acceptable to me, he was very happy to hear this. BTW, regarding the "Experimental" marking..... We had Flightline Interiors do our interior, wonderful product, wonderful people. As I said we had our experimental marked on the baggage bulkhead, during our DAR inspection we had to make a new experimental marking because all of the letters embroidered on the bulkhead were not 2" tall. The capitol letters were taller, the lower-case letters were too short. It was in a 'fancy' font, but that wasn't a problem. Abby made good and re-did the piece, so it looks like we now have a take three on the markings. The next day I brought my laptop into the office and showed him pictures of the build, he wanted to see me actually working, not posing with parts. He also wanted to see me working at all of the stages to prove I was involved from beginning to end. He looked up the RV-10 quickbuild in the database to verify it meets the 51% rule. He asked how I planned to inspect the airplane, and what checklists I had for the inspections. He wanted to hear that our part 43 checklist was modified to include unique maintenance features of our model. He asked me to bring along the builders log, but did not review it. He issued the certificate on the spot. Kinda cool, he even filled out the application overnight, I only had to double check the info, and sign my name. This guy was great! I had thought that the Repairmen's Certificate was issued at the same time as the inspection, but that was not the case for us, just passing along the experience. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler http://www.matronics.com/contribution =========== ~=B2=03 ________________________________________________________________________________
Date: Aug 03, 2009
Subject: Re: OSH Photos - Jim Combs
Tim, You can post these. Please! Thanks, Jim C ________________________________________________________________________________
Date: Aug 03, 2009
Ok, I'll rethink too then. Thanks Chris #40072 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Monday, August 03, 2009 2:31 PM Subject: RV10-List: Re: GRT AHRS Mounting and CG OK, I got a call back from Jeff at GRT. It is true that the AHRS interferes with the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for the AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board.... John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255821#255821 ________________________________________________________________________________
Subject: RV-10's at OSH Lineup
Date: Aug 03, 2009
Here is the bunch as I saw it Tuesday. I think it was about 3 rows of 6 at one point, plus two across the way and two over near the brown arch. -Chris #40072 ________________________________________________________________________________
Date: Aug 04, 2009
Subject: Re: RV-10's at OSH Lineup
Thanks Chris, they're posted. Tim Chris wrote: > Here is the bunch as I saw it Tuesday. I think it was about 3 rows of 6 > at one point, plus two across the way and two over near the brown arch. > > -Chris > > #40072 > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > ________________________________________________________________________________
From: Robert Brunkenhoefer <rebrunk42(at)gmail.com>
Subject: Wing root fairings
Date: Aug 04, 2009
Where can I get wing root fairings like I saw on the rv10 over by the warbirds ?Robert flawless flying back to corpus christi with big detours for weather. Sent from my iPhone Robert E. Brunkenhoefer Brunkenhoefer Law Firm, P.C. 520 Lawrence St. Corpus Christi, Texas 78401 Phone: 361-888-8808 Facsimile: 361-888-6753 robert(at)brunklaw.com ________________________________________________________________________________
Subject: US Customs
Date: Aug 04, 2009
Hi All While making the flight to KOSH, I have the chance to meet a very helpful CBP officer who also provided the attached document. It lists key links for info about how to cross the border and not get a F18 escort. Cheers Les ________________________________________________________________________________
Date: Aug 04, 2009
I think that was Jesse's plane. Check with him. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert Brunkenhoefer Sent: Tuesday, August 04, 2009 8:17 AM Subject: RV10-List: Wing root fairings Where can I get wing root fairings like I saw on the rv10 over by the warbirds ?Robert flawless flying back to corpus christi with big detours for weather. Sent from my iPhone Robert E. Brunkenhoefer Brunkenhoefer Law Firm, P.C. 520 Lawrence St. Corpus Christi, Texas 78401 Phone: 361-888-8808 Facsimile: 361-888-6753 robert(at)brunklaw.com ________________________________________________________________________________
Subject: Re: Wing root fairings
Date: Aug 04, 2009
how do i contact jesse?robert On Aug 4, 2009, at 9:47 AM, RV Builder (Michael Sausen) wrote: > > > > I think that was Jesse's plane. Check with him. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Robert Brunkenhoefer > Sent: Tuesday, August 04, 2009 8:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Wing root fairings > > > > > Where can I get wing root fairings like I saw on the rv10 over by the > warbirds ?Robert flawless flying back to corpus christi with big > detours for weather. > > Sent from my iPhone > > Robert E. Brunkenhoefer > Brunkenhoefer Law Firm, P.C. > 520 Lawrence St. > Corpus Christi, Texas 78401 > Phone: 361-888-8808 > Facsimile: 361-888-6753 > robert(at)brunklaw.com > > ________________________________________________________________________________
Subject: Testing fuel tank with 100LL
Date: Aug 04, 2009
Hi All=2C Has anyone had fuel leaks on tanks that have passed the air pressure test? Here's why I ask. I built and air tested (per Van's instructions) my tanks two years ago and they tested fine. I am now getting ready to paint before the first flight and am wondering if it is worth the hassle to fill the fue l tanks with 100LL and let them set to check for leaks before painting. Any help would be greatly appreciated. Vern Smith #324 (hence forth know as N44QT=3B finishing) _________________________________________________________________ Get free photo software from Windows Live http://www.windowslive.com/online/photos?ocid=PID23393::T:WLMTAGL:ON:WL:e n-US:SI_PH_software:082009 ________________________________________________________________________________
Date: Aug 04, 2009
Jesse is on this list- jesse(at)saintaviation.com; I am intrigued to see photos of the fairings in question. Pascal -------------------------------------------------- From: "Robert Brunkenhoefer" <rebrunk42(at)gmail.com> Sent: Tuesday, August 04, 2009 8:36 AM Subject: Re: RV10-List: Wing root fairings > > > how do i contact jesse?robert > On Aug 4, 2009, at 9:47 AM, RV Builder (Michael Sausen) wrote: > >> > > >> >> I think that was Jesse's plane. Check with him. >> >> Michael >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of Robert >> Brunkenhoefer >> Sent: Tuesday, August 04, 2009 8:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Wing root fairings >> >> > > >> >> Where can I get wing root fairings like I saw on the rv10 over by the >> warbirds ?Robert flawless flying back to corpus christi with big >> detours for weather. >> >> Sent from my iPhone >> >> Robert E. Brunkenhoefer >> Brunkenhoefer Law Firm, P.C. >> 520 Lawrence St. >> Corpus Christi, Texas 78401 >> Phone: 361-888-8808 >> Facsimile: 361-888-6753 >> robert(at)brunklaw.com >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 04, 2009
Yes. I have a leak on the top of my right tank. In the walk area. Only leaks with full tanks. Took months for the leak to appear. It is under my 3m walk area and is minor, so I have done nothing to fix it. Also, I flew 410RV (Vans number 1) for my transition training and it also had leaks in the same area. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith Sent: Tuesday, August 04, 2009 9:51 AM Subject: RV10-List: Testing fuel tank with 100LL Hi All, Has anyone had fuel leaks on tanks that have passed the air pressure test? Here's why I ask. I built and air tested (per Van's instructions) my tanks two years ago and they tested fine. I am now getting ready to paint before the first flight and am wondering if it is worth the hassle to fill the fuel tanks with 100LL and let them set to check for leaks before painting. Any help would be greatly appreciated. Vern Smith #324 (hence forth know as N44QT; finishing) _____ Get free photo software from Windows Live Click here. <http://www.windowslive.com/online/photos?ocid=PID23393::T:WLMTAGL:ON:WL:en- US:SI_PH_software:082009> ________________________________________________________________________________
Date: Aug 04, 2009
Guys- I have not been following this thread so my comments may have already been covered. - The-best place to locate a magnometer (and/or-the AHRS if they do not i nterfer with one another) -is on a shelf-that spans the fuselage latera lly between the three longeron bolts that secure the aft seat belt attachme nt. This location has four good advantages: - I have measured the magnetic interference and this location is the farthest distance from the autopilot elevator servo and the elevator trim servo. Do not underestimate the interference from the little trim servo - it is more of a problem than the autopilot. - A shelf in this orientation is automatically aligned with the pitch and rol l-axis. - If the sensor contains accelerometers or rate gyros it will function more a ccurately along the centerline of the fuselage than a wing tip. - This location is far from the baggage compartment and the unpredictable mag netic forces contained in the unpredictable baggage. - Also - you will never get a sensor accurately aligned in a wing tip. I just had a good example of how the wing will move about-between ground and ai r. - Bill DeRouchey N939SB - - - --- On Mon, 8/3/09, Chris wrote: From: Chris <toaster73(at)embarqmail.com> Subject: RE: RV10-List: Re: GRT AHRS Mounting and CG Date: Monday, August 3, 2009, 7:36 PM Ok, I'll rethink too then. Thanks Chris #40072 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Monday, August 03, 2009 2:31 PM Subject: RV10-List: Re: GRT AHRS Mounting and CG OK, I got a call back from Jeff at GRT. It is true that the AHRS interferes wit h the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for th e AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board.... John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255821#255821 le, List Admin. ________________________________________________________________________________
Subject: OSH Wrap Up
Date: Aug 04, 2009
Unfortunately I didn't make Oshkosh before the majority of the folks started departing, but I still had a chance to visit a few RV-10's and meet some builders too. Oh yeah, Oshkosh is huge and it took me 2 days to find 55th and Lindbergh. So that didn't help either. I had a chance to talk with Bob Condrey before he packed up and headed out. Spent some time with Adrian Moses, and also spent a few hours with David McNeil picking his brain on Saturday. Lots of fun and a few lessons learned. It's a great way to share some ideas, tips, and gotchas all at once. We'll make it earlier in the week next year! Phil ________________________________________________________________________________
Date: Aug 04, 2009
I thought I was leak free until painting the airplane with over 100 hours on it. Turns out there was a very slight leak from 2 rivets that went unnoticed with the pressure test as well as flying. Unfortunately it doesn't take much fuel to trash the paint. I'd recommend you do anything you can to verify no leaks to prevent pain and suffering later on. Marcus From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith Sent: Tuesday, August 04, 2009 11:51 AM Subject: RV10-List: Testing fuel tank with 100LL Hi All, Has anyone had fuel leaks on tanks that have passed the air pressure test? Here's why I ask. I built and air tested (per Van's instructions) my tanks two years ago and they tested fine. I am now getting ready to paint before the first flight and am wondering if it is worth the hassle to fill the fuel tanks with 100LL and let them set to check for leaks before painting. Any help would be greatly appreciated. Vern Smith #324 (hence forth know as N44QT; finishing) _____ Get free photo software from Windows Live Click here. <http://www.windowslive.com/online/photos?ocid=PID23393::T:WLMTAGL:ON:WL:en- US:SI_PH_software:082009> ________________________________________________________________________________
Subject: Re: Testing fuel tank with 100LL
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Aug 04, 2009
I would absolutely test the tanks before installing them. We have quick-build tanks with leaking rivets on both sides. It seems as though all of the leaking rivets occur in the same locations. I hesitate to call it a design flaw, but it is definitely an opportunity for design improvement. We tried the green loctite fix with no success. This topic went around a while back and someone mentioned they applied heat, and maybe pressure, or vacuum. Who was that, and how did you do it? This was one of the face to face conversations I wanted to have with Vans at the show. After talking to Ken K. he suggested we remove the tanks, cut an access hole in the back of the tank, repair the rivets, patch the hole, and reinstall the tanks. WOW!! Has anyone removed a tank after the bottom skin was on? Is it even possible to get at the bolts going through the spar? At first glance it didn't seem like it was possible. I need to get into the aircraft or auto racing industry I could save a ton of time and effort if I could just dismiss quality problems. OK, so I think I have fixed the blame, now it is time to fix the problem. Green loctite didn't seem to work, someone had suggested thinning pro-seal 50% with MEK, applying a slight vacuum to the tank and letting it cure. I have heard some used a Cherrymax rivet with pro-seal, I am not familiar with which rivet to use. Anyone with any ideas? Test those tanks!! Do not sit or set anything heavy on the inboard side of the tanks. Quick-build workmanship is not guaranteed, not trying to bash Van's, I love this airplane!! But if I bought a $50k car, the gas tank wouldn't leak, and if it did it wouldn't be my problem. To those of you going slow-build, read this every time you question your decision, at least the mistakes are your own. OK, rant off, thanks for listening. Jason Kreidler N44YH - Flying #40617 4 Partner Build Wayne Elsner - Tony Kolar - Kyle Hokel - Jason Kreidler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256046#256046 ________________________________________________________________________________
Date: Aug 04, 2009
Yes it is possible to remove the tanks. They work the same as Piper Cherokee tanks. Fortunately I have had no problems with the QB tanks although I did not remove them as Vans/plans suggested, figuring that why disturb what someone else had already tested. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Tuesday, August 04, 2009 3:27 PM Subject: RV10-List: Re: Testing fuel tank with 100LL --> I would absolutely test the tanks before installing them. We have quick-build tanks with leaking rivets on both sides. It seems as though all of the leaking rivets occur in the same locations. I hesitate to call it a design flaw, but it is definitely an opportunity for design improvement. We tried the green loctite fix with no success. This topic went around a while back and someone mentioned they applied heat, and maybe pressure, or vacuum. Who was that, and how did you do it? This was one of the face to face conversations I wanted to have with Vans at the show. After talking to Ken K. he suggested we remove the tanks, cut an access hole in the back of the tank, repair the rivets, patch the hole, and reinstall the tanks. WOW!! Has anyone removed a tank after the bottom skin was on? Is it even possible to get at the bolts going through the spar? At first glance it didn't seem like it was possible. I need to get into the aircraft or auto racing industry I could save a ton of time and effort if I could just dismiss quality problems. OK, so I think I have fixed the blame, now it is time to fix the problem. Green loctite didn't seem to work, someone had suggested thinning pro-seal 50% with MEK, applying a slight vacuum to the tank and letting it cure. I have heard some used a Cherrymax rivet with pro-seal, I am not familiar with which rivet to use. Anyone with any ideas? Test those tanks!! Do not sit or set anything heavy on the inboard side of the tanks. Quick-build workmanship is not guaranteed, not trying to bash Van's, I love this airplane!! But if I bought a $50k car, the gas tank wouldn't leak, and if it did it wouldn't be my problem. To those of you going slow-build, read this every time you question your decision, at least the mistakes are your own. OK, rant off, thanks for listening. Jason Kreidler N44YH - Flying #40617 4 Partner Build Wayne Elsner - Tony Kolar - Kyle Hokel - Jason Kreidler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256046#256046 ________________________________________________________________________________
Date: Aug 04, 2009
jkreidler wrote: > > > I would absolutely test the tanks before installing them. We have > quick-build tanks with leaking rivets on both sides. It seems as > though all of the leaking rivets occur in the same locations. I > hesitate to call it a design flaw, but it is definitely an > opportunity for design improvement. > > We tried the green loctite fix with no success. This topic went > around a while back and someone mentioned they applied heat, and > maybe pressure, or vacuum. Who was that, and how did you do it? Could have been me. Use minor vacuum ..... put the vacuum hose in the filler, plug the vents, and have someone hold a rag around the filler/hose joint ..... you don't want to seal it!!! Causes tanks to shrink funny! > This was one of the face to face conversations I wanted to have with > Vans at the show. After talking to Ken K. he suggested we remove the > tanks, cut an access hole in the back of the tank, repair the rivets, > patch the hole, and reinstall the tanks. WOW!! Has anyone removed a > tank after the bottom skin was on? Is it even possible to get at the > bolts going through the spar? At first glance it didn't seem like it > was possible. > > I need to get into the aircraft or auto racing industry I could save > a ton of time and effort if I could just dismiss quality problems. > OK, so I think I have fixed the blame, now it is time to fix the > problem. Green loctite didn't seem to work, someone had suggested > thinning pro-seal 50% with MEK, applying a slight vacuum to the tank > and letting it cure. I have heard some used a Cherrymax rivet with > pro-seal, I am not familiar with which rivet to use. Anyone with any > ideas? The green Loctite should work ...... use the vacuum to suck some MEK into the leak to clean it. If the MEK disappears in large quantities, the hole may be too large for the green Loctite trick. In that case I'd try the thinned MEK/vacuum step. Failing that, I'd use the Cherry rivet fix before I removed the tank, cut a hole .... a big leak waiting to happen .... > > Test those tanks!! Do not sit or set anything heavy on the inboard > side of the tanks. Quick-build workmanship is not guaranteed, not > trying to bash Van's, I love this airplane!! But if I bought a $50k > car, the gas tank wouldn't leak, and if it did it wouldn't be my > problem. To those of you going slow-build, read this every time you > question your decision, at least the mistakes are your own. OK, rant > off, thanks for listening. Either way .... your workmanship or theirs ..... the leaks are still there. It's a problem when you drill a hole and then fill it with a rivet, cover it with sealant ..... where you can ..... and hope for the best. Your 50K car has a two piece tank with rolled edges .... and yes, they do sometimes leak. Usually not bad enough to notice a stain on the garage floor .... until the warranty expires!!! However, and I speak from experience ..... auto fuel doesn't leave a stain like 100LL so it's really easy to overlook it.Linn > > Jason Kreidler N44YH - Flying #40617 4 Partner Build Wayne Elsner - > Tony Kolar - Kyle Hokel - Jason Kreidler > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256046#256046 > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2009
I had the chance to try this today (I normally only slip with flaps down). What Jason describes is the early onset to a departure from controlled flight (depart) due to loss of directional stability. Much worse slipping to the left than to the right due to engine torque (tends to try to depart underneath.....not good). At 90 kts I could not get it to come close to departing with full rudder and opposite aileron, but as I slowed 80 kts, you can definitely get it to depart if you don't know what the seat of your pants is telling you (I did literally scores of intentional departure from controlled flight maneuvers in my A-7D days in the AF). You can quickly break the departure by simply unloading back pressure on the stick (in the A-7, we released the stick altogether until the airplane recovered itself (usually very nose low). The departure happens when the rudder loses effectiveness, compounded by the wing low and opposite rudder. Somewhere in my early RV days, I was told that if you want to slip the an RV, you need to make sure the nose is well below the horizon to ensure that you do not lose rudder effectiveness. This is especially true of the earlier RV models and their even shorter height rudder than the -10. Avoid level attitude or nose up slips. I would encourage each of you -10 owners to practice the no flap slip (above 5,000' AGL in to have a comfortable recovery margin in case you do inadvertently depart the bird). You need to feel for yourselves the approach to departure feel that you get through the seat of your pants. Trim your airplane up for hands off at about 100 kts, power setting idle, then start your slip maneuver near level flight attitude. Once you feel that yaw in the seat of your pants, simply release release the rudder while simultaneously releasing stick back pressure to the neutral position. Then remember the secret to a slip in the -10: keep the nose low and use about 90 kts no flap and 80 kts with flaps. Hope this helps out grumpy N184JM On Aug 3, 2009, at 8:10 AM, jason.kreidler(at)regalbeloit.com wrote: > > I would like to pass along a flight test experience I had. > > I initiated a slip at 85 knots (note well below Va) (zero degree > flap setting), the rudder pedal was fairly hard to push, however as > it approached what I would guess to be just beyond the middle of its > travel the 'tone' of the airframe changed, and the rudder became > much easier to apply, the airplane 'jerked' further into the slip, > and felt as if it was going to swap ends. It did not roll much, > just an abrupt yaw. I then had to apply opposite rudder to return > back to neutral. I did not get to the rudder stop. The rudder > almost felt as if it went 'over center'. Weight & Balance during > this test 2510 LBS @ 112.7". Note I was using pitch to maintain > airspeed, and aileron to control heading (or track). > > After this happened I spoke with a few others who are flying, no one > had performed this maneuver. I then spoke with Ken K. about this > while at Oshkosh. He said he had experienced the same thing, > although he entered it quickly by stomping the rudder pedal to the > floor. He could not explain exactly what was causing the problem, > he thought it might be dihedral stability. I told him the I suppose > the right answer is "don't do that", he quickly replied that > maneuver may be required if the flap motor was lost, and you were > forced to slow down and land without flaps. > > I also spoke with Alex D. about this, he has also experienced the > same thing, he said it is worse when you have -3 degrees reflex, and > still there at 0 degrees. I have done this with one and two notches > of 'real' flaps and was able to do full slips. > > Ken K. asked me (with a smile) if I had enough 'guts' to get the > rudder all the way to the floor to see how far it went, I didn't. > At least not before understanding what is going on, and if this is > limited to our copy. > > After experiencing this I have a few takeaways. 1) Expect the > unexpected, I hate surprises, imagine the surprise while performing > a fairly standard maneuver and getting a result never experienced > before. 2) Don't do that.... 3) Share what is learned even at the > risk of what replies are sure to come. > > I say don't do that but I believe Ken has a valid argument, at very > least we should all understand what our aircraft behave like even if > the maneuver is at the fringe of what we would normally expect to > perform. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > ________________________________________________________________________________
Date: Aug 04, 2009
When you say departure ..... does it want to enter a spin??? What is the elevator position in all this??? Nose high (aft stick) and cross-controlled rudder/aileron is pretty much asking for a spin. And guaranteed to get you one. Which begs the question .... anyone have experience with spins in the -10?? Reply off-list if you're sensitive to flaming! Linn ..... aerobatics is the most fun thing you can do with your clothes on!!! Miller John wrote: > I had the chance to try this today (I normally only slip with flaps down). > > What Jason describes is the early onset to a departure from controlled > flight (depart) due to loss of directional stability. Much worse > slipping to the left than to the right due to engine torque (tends to > try to depart underneath.....not good). > > At 90 kts I could not get it to come close to departing with full rudder > and opposite aileron, but as I slowed 80 kts, you can definitely get it > to depart if you don't know what the seat of your pants is telling you > (I did literally scores of intentional departure from controlled flight > maneuvers in my A-7D days in the AF). You can quickly break the > departure by simply unloading back pressure on the stick (in the A-7, we > released the stick altogether until the airplane recovered itself > (usually very nose low). > > The departure happens when the rudder loses effectiveness, compounded by > the wing low and opposite rudder. > > Somewhere in my early RV days, I was told that if you want to slip the > an RV, you need to make sure the nose is well below the horizon to > ensure that you do not lose rudder effectiveness. This is especially > true of the earlier RV models and their even shorter height rudder than > the -10. Avoid level attitude or nose up slips. > > I would encourage each of you -10 owners to practice the no flap slip > (above 5,000' AGL in to have a comfortable recovery margin in case you > do inadvertently depart the bird). You need to feel for yourselves the > approach to departure feel that you get through the seat of your pants. > > Trim your airplane up for hands off at about 100 kts, power setting > idle, then start your slip maneuver near level flight attitude. Once > you feel that yaw in the seat of your pants, simply release release the > rudder while simultaneously releasing stick back pressure to the neutral > position. > > Then remember the secret to a slip in the -10: keep the nose low and use > about 90 kts no flap and 80 kts with flaps. > > Hope this helps out > grumpy > N184JM > ________________________________________________________________________________
Date: Aug 04, 2009
I did not let it depart. It would probably develop into a spin after the departure if the controls were held (aft stick, left or right aileron with opposite rudder). The elevator was holding back pressure to keep the at entry condition relative to the horizon. grumpy N184JM On Aug 4, 2009, at 8:55 PM, Linn Walters wrote: > > > > > When you say departure ..... does it want to enter a spin??? What > is the elevator position in all this??? Nose high (aft stick) and > cross-controlled rudder/aileron is pretty much asking for a spin. > And guaranteed to get you one. Which begs the question .... anyone > have experience with spins in the -10?? Reply off-list if you're > sensitive to flaming! > Linn ..... aerobatics is the most fun thing you can do with your > clothes on!!! > > Miller John wrote: >> I had the chance to try this today (I normally only slip with flaps >> down). >> What Jason describes is the early onset to a departure from >> controlled flight (depart) due to loss of directional stability. >> Much worse slipping to the left than to the right due to engine >> torque (tends to try to depart underneath.....not good). >> At 90 kts I could not get it to come close to departing with full >> rudder and opposite aileron, but as I slowed 80 kts, you can >> definitely get it to depart if you don't know what the seat of your >> pants is telling you (I did literally scores of intentional >> departure from controlled flight maneuvers in my A-7D days in the >> AF). You can quickly break the departure by simply unloading back >> pressure on the stick (in the A-7, we released the stick altogether >> until the airplane recovered itself (usually very nose low). >> The departure happens when the rudder loses effectiveness, >> compounded by the wing low and opposite rudder. >> Somewhere in my early RV days, I was told that if you want to slip >> the an RV, you need to make sure the nose is well below the horizon >> to ensure that you do not lose rudder effectiveness. This is >> especially true of the earlier RV models and their even shorter >> height rudder than the -10. Avoid level attitude or nose up slips. >> I would encourage each of you -10 owners to practice the no flap >> slip (above 5,000' AGL in to have a comfortable recovery margin in >> case you do inadvertently depart the bird). You need to feel for >> yourselves the approach to departure feel that you get through the >> seat of your pants. Trim your airplane up for hands off at about >> 100 kts, power setting idle, then start your slip maneuver near >> level flight attitude. Once you feel that yaw in the seat of your >> pants, simply release release the rudder while simultaneously >> releasing stick back pressure to the neutral position. >> Then remember the secret to a slip in the -10: keep the nose low >> and use about 90 kts no flap and 80 kts with flaps. >> Hope this helps out >> grumpy >> N184JM > > ________________________________________________________________________________
Date: Aug 05, 2009
That may be (aerobatics) but my insurance is null and void past 90 degrees angle of bank. or inverted..so Linn when you get here remember that or we will talk!!! He said with a big smile!!!! Sent via BlackBerry by AT&T -----Original Message----- From: Linn Walters <pitts_pilot(at)bellsouth.net> Date: Tue, 04 Aug 2009 21:55:04 Subject: Re: RV10-List: Forward Slips When you say departure ..... does it want to enter a spin??? What is the elevator position in all this??? Nose high (aft stick) and cross-controlled rudder/aileron is pretty much asking for a spin. And guaranteed to get you one. Which begs the question .... anyone have experience with spins in the -10?? Reply off-list if you're sensitive to flaming! Linn ..... aerobatics is the most fun thing you can do with your clothes on!!! Miller John wrote: > I had the chance to try this today (I normally only slip with flaps down). > > What Jason describes is the early onset to a departure from controlled > flight (depart) due to loss of directional stability. Much worse > slipping to the left than to the right due to engine torque (tends to > try to depart underneath.....not good). > > At 90 kts I could not get it to come close to departing with full rudder > and opposite aileron, but as I slowed 80 kts, you can definitely get it > to depart if you don't know what the seat of your pants is telling you > (I did literally scores of intentional departure from controlled flight > maneuvers in my A-7D days in the AF). You can quickly break the > departure by simply unloading back pressure on the stick (in the A-7, we > released the stick altogether until the airplane recovered itself > (usually very nose low). > > The departure happens when the rudder loses effectiveness, compounded by > the wing low and opposite rudder. > > Somewhere in my early RV days, I was told that if you want to slip the > an RV, you need to make sure the nose is well below the horizon to > ensure that you do not lose rudder effectiveness. This is especially > true of the earlier RV models and their even shorter height rudder than > the -10. Avoid level attitude or nose up slips. > > I would encourage each of you -10 owners to practice the no flap slip > (above 5,000' AGL in to have a comfortable recovery margin in case you > do inadvertently depart the bird). You need to feel for yourselves the > approach to departure feel that you get through the seat of your pants. > > Trim your airplane up for hands off at about 100 kts, power setting > idle, then start your slip maneuver near level flight attitude. Once > you feel that yaw in the seat of your pants, simply release release the > rudder while simultaneously releasing stick back pressure to the neutral > position. > > Then remember the secret to a slip in the -10: keep the nose low and use > about 90 kts no flap and 80 kts with flaps. > > Hope this helps out > grumpy > N184JM > ________________________________________________________________________________
Date: Aug 04, 2009
Sir Grumpy, What exactly do you mean by "Depart"? Is it an uncommanded YAW or ???? I don't understand that term. Jim Combs (N312F) --------------------------------------------------------------------------------------------------------- I had the chance to try this today (I normally only slip with flaps down). What Jason describes is the early onset to a departure from controlled flight (depart) due to loss of directional stability. Much worse slipping to the left than to the right due to engine torque (tends to try to depart underneath.....not good). At 90 kts I could not get it to come close to departing with full rudder and opposite aileron, but as I slowed 80 kts, you can definitely get it to depart if you don't know what the seat of your pants is telling you (I did literally scores of intentional departure from controlled flight maneuvers in my A-7D days in the AF). You can quickly break the departure by simply unloading back pressure on the stick (in the A-7, we released the stick altogether until the airplane recovered itself (usually very nose low). The departure happens when the rudder loses effectiveness, compounded by the wing low and opposite rudder. Somewhere in my early RV days, I was told that if you want to slip the an RV, you need to make sure the nose is well below the horizon to ensure that you do not lose rudder effectiveness. This is especially true of the earlier RV models and their even shorter height rudder than the -10. Avoid level attitude or nose up slips. I would encourage each of you -10 owners to practice the no flap slip (above 5,000' AGL in to have a comfortable recovery margin in case you do inadvertently depart the bird). You need to feel for yourselves the approach to departure feel that you get through the seat of your pants. Trim your airplane up for hands off at about 100 kts, power setting idle, then start your slip maneuver near level flight attitude. Once you feel that yaw in the seat of your pants, simply release release the rudder while simultaneously releasing stick back pressure to the neutral position. Then remember the secret to a slip in the -10: keep the nose low and use about 90 kts no flap and 80 kts with flaps. Hope this helps out grumpy N184JM On Aug 3, 2009, at 8:10 AM, jason.kreidler(at)regalbeloit.com wrote: > > I would like to pass along a flight test experience I had. > > I initiated a slip at 85 knots (note well below Va) (zero degree > flap setting), the rudder pedal was fairly hard to push, however as > it approached what I would guess to be just beyond the middle of its > travel the 'tone' of the airframe changed, and the rudder became > much easier to apply, the airplane 'jerked' further into the slip, > and felt as if it was going to swap ends. It did not roll much, > just an abrupt yaw. I then had to apply opposite rudder to return > back to neutral. I did not get to the rudder stop. The rudder > almost felt as if it went 'over center'. Weight & Balance during > this test 2510 LBS @ 112.7". Note I was using pitch to maintain > airspeed, and aileron to control heading (or track). > > After this happened I spoke with a few others who are flying, no one > had performed this maneuver. I then spoke with Ken K. about this > while at Oshkosh. He said he had experienced the same thing, > although he entered it quickly by stomping the rudder pedal to the > floor. He could not explain exactly what was causing the problem, > he thought it might be dihedral stability. I told him the I suppose > the right answer is "don't do that", he quickly replied that > maneuver may be required if the flap motor was lost, and you were > forced to slow down and land without flaps. > > I also spoke with Alex D. about this, he has also experienced the > same thing, he said it is worse when you have -3 degrees reflex, and > still there at 0 degrees. I have done this with one and two notches > of 'real' flaps and was able to do full slips. > > Ken K. asked me (with a smile) if I had enough 'guts' to get the > rudder all the way to the floor to see how far it went, I didn't. > At least not before understanding what is going on, and if this is > limited to our copy. > > After experiencing this I have a few takeaways. 1) Expect the > unexpected, I hate surprises, imagine the surprise while performing > a fairly standard maneuver and getting a result never experienced > before. 2) Don't do that.... 3) Share what is learned even at the > risk of what replies are sure to come. > > I say don't do that but I believe Ken has a valid argument, at very > least we should all understand what our aircraft behave like even if > the maneuver is at the fringe of what we would normally expect to > perform. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > ________________________________________________________________________________
Date: Aug 05, 2009
Great info....always stood behind the stabilized approach method and the slip is always in the back of my mind...my -10 will drop a wing in a deep stall if you don't dance on the rudder...as will most airplanes....played hard coming back from OSH with the rudder coupled with the ailerons trying to hold track in 40 kt cross winds...aircraft tracked very well but never fully hands off.. Sent via BlackBerry by AT&T -----Original Message----- From: Miller John <gengrumpy(at)aol.com> Date: Tue, 4 Aug 2009 20:38:49 Subject: Re: RV10-List: Forward Slips ________________________________________________________________________________
Date: Aug 04, 2009
ricksked(at)embarqmail.com wrote: > > That may be (aerobatics) but my insurance is null and void past 90 > degrees angle of bank. or inverted..so Linn when you get here > remember that or we will talk!!! He said with a big smile!!!! Sent > via BlackBerry by AT&T > Hi Rick! I have my Pitts to give me my aerobatic fix. Does your insurance really have the 90 degree prohibition?? I have no clue what my insurance says .... underwritten by Mexican company! I have no wish to get wild in the -10. I've seen enough examples of what happens when you fly out of the category!!! Linn Still thinking of renting the car. ________________________________________________________________________________
Date: Aug 04, 2009
Good points Bill. I decided to make the shelf for the magnetometers just ahead of the seat belt attach. I am putting another shelf forward of that slightly aft of the battery to hold the AHRS. Both units will be completely aligned though separated based on GRT's inputs that the AHRS can cause some disturbance in the magnetometer. -Chris Lucas #40072 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey Sent: Tuesday, August 04, 2009 1:40 PM Subject: RE: RV10-List: Re: GRT AHRS Mounting and CG Guys- I have not been following this thread so my comments may have already been covered. The best place to locate a magnometer (and/or the AHRS if they do not interfer with one another) is on a shelf that spans the fuselage laterally between the three longeron bolts that secure the aft seat belt attachment. This location has four good advantages: I have measured the magnetic interference and this location is the farthest distance from the autopilot elevator servo and the elevator trim servo. Do not underestimate the interference from the little trim servo - it is more of a problem than the autopilot. A shelf in this orientation is automatically aligned with the pitch and roll axis. If the sensor contains accelerometers or rate gyros it will function more accurately along the centerline of the fuselage than a wing tip. This location is far from the baggage compartment and the unpredictable magnetic forces contained in the unpredictable baggage. Also - you will never get a sensor accurately aligned in a wing tip. I just had a good example of how the wing will move about between ground and air. Bill DeRouchey N939SB --- On Mon, 8/3/09, Chris wrote: From: Chris <toaster73(at)embarqmail.com> Subject: RE: RV10-List: Re: GRT AHRS Mounting and CG Date: Monday, August 3, 2009, 7:36 PM <http://us.mc344.mail.yahoo.com/mc/compose?to=toaster73@embarqmail.com> > Ok, I'll rethink too then. Thanks Chris #40072 -----Original Message----- From: owner-rv10-list-server(at)matronics.com <http://us.mc344.mail.yahoo.com/mc/compose?to=owner-rv10-list-server@matroni cs.com> [mailto:owner-rv10-list-server(at)matronics.com <http://us.mc344.mail.yahoo.com/mc/compose?to=owner-rv10-list-server@matroni cs.com> ] On Behalf Of johngoodman Sent: Monday, August 03, 2009 2:31 PM <http://us.mc344.mail.yahoo.com/mc/compose?to=rv10-list@matronics.com> Subject: RV10-List: Re: GRT AHRS Mounting and CG <http://us.mc344.mail.yahoo.com/mc/compose?to=johngoodman@earthlink.net> > OK, I got a call back from Jeff at GRT. It is true that the AHRS interferes with the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for the AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board.... John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=255821#25582/www.matronics.com/N avigator?RV10-List <http://forums.matronics.com/viewtopic.php?p=255821#255821> " target=_blank>http://www.matronicatronics.com/" ; -Matt Dralle, List Admin========= ________________________________________________________________________________
Subject: Re: Forward Slips
Date: Aug 04, 2009
Depart means just that - the airplane "departs" from controlled flight - usually violently unlike a stall because it is often (but not always) induced by cross controls to start with. Longitudinal stability (controlled by the vertical stabilizer and rudder) is lost and the airplane then yaws followed by a rolling moment and possible tumbling (especially pronounced in swept wing aircraft). Straight wing aircraft usually snap roll rather than tumble. Which way it rolls depends on any roll input compounded by torque effects of the engine. Had I held my left slip controls in for a second or two longer in today, it would have snap rolled underneath with a forward pitching moment to boot. Impossible to recover from in the traffic pattern. The loss of longitudinal stability is seen as yaw (if you're watching the ball - which I hope you are not when doing this maneuver). the Yaw is most quickly felt through the seat of the pants - going sideways in the seat. Whenever you get this feeling in the seat of your pants, your first response must be to release back stick pressure and neutralize ailerons and rudder. That will keep the departure from happening. Having to dig back a few years into my fighter pilot past for this..... grumpy N184JM On Aug 4, 2009, at 9:16 PM, Jim wrote: > Sir Grumpy, > > What exactly do you mean by "Depart"? Is it an uncommanded YAW > or ???? > > I don't understand that term. > > Jim Combs (N312F) > > --------------------------------------------------------------------------------------------------------- > > I had the chance to try this today (I normally only slip with flaps > down). > > What Jason describes is the early onset to a departure from controlled > flight (depart) due to loss of directional stability. Much worse > slipping to the left than to the right due to engine torque (tends to > try to depart underneath.....not good). > > At 90 kts I could not get it to come close to departing with full > rudder and opposite aileron, but as I slowed 80 kts, you can > definitely get it to depart if you don't know what the seat of your > pants is telling you (I did literally scores of intentional departure > from controlled flight maneuvers in my A-7D days in the AF). You can > quickly break the departure by simply unloading back pressure on the > stick (in the A-7, we released the stick altogether until the airplane > recovered itself (usually very nose low). > > The departure happens when the rudder loses effectiveness, compounded > by the wing low and opposite rudder. > > Somewhere in my early RV days, I was told that if you want to slip the > an RV, you need to make sure the nose is well below the horizon to > ensure that you do not lose rudder effectiveness. This is especially > true of the earlier RV models and their even shorter height rudder > than the -10. Avoid level attitude or nose up slips. > > I would encourage each of you -10 owners to practice the no flap slip > (above 5,000' AGL in to have a comfortable recovery margin in case you > do inadvertently depart the bird). You need to feel for yourselves > the approach to departure feel that you get through the seat of your > pants. > > Trim your airplane up for hands off at about 100 kts, power setting > idle, then start your slip maneuver near level flight attitude. Once > you feel that yaw in the seat of your pants, simply release release > the rudder while simultaneously releasing stick back pressure to the > neutral position. > > Then remember the secret to a slip in the -10: keep the nose low and > use about 90 kts no flap and 80 kts with flaps. > > Hope this helps out > grumpy > N184JM > > > On Aug 3, 2009, at 8:10 AM, jason.kreidler(at)regalbeloit.com wrote: > > > > > I would like to pass along a flight test experience I had. > > > > I initiated a slip at 85 knots (note well below Va) (zero degree > > flap setting), the rudder pedal was fairly hard to push, however as > > it approached what I would guess to be just beyond the middle of its > > travel the 'tone' of the airframe changed, and the rudder became > > much easier to apply, the airplane 'jerked' further into the slip, > > and felt as if it was going to swap ends. It did not roll much, > > just an abrupt yaw. I then had to apply opposite rudder to return > > back to neutral. I did not get to the rudder stop. The rudder > > almost felt as if it went 'over center'. Weight & Balance during > > this test 2510 LBS @ 112.7". Note I was using pitch to maintain > > airspeed, and aileron to control heading (or track). > > > > After this happened I spoke with a few others who are flying, no one > > had performed this maneuver. I then spoke with Ken K. about this > > while at Oshkosh. He said he had experienced the same thing, > > although he entered it quickly by stomping the rudder pedal to the > > floor. He could not explain exactly what was causing the problem, > > he thought it might be dihedral stability. I told him the I suppose > > the right answer is "don't do that", he quickly replied that > > maneuver may be required if the flap motor was lost, and you were > > forced to slow down and land without flaps. > > > > I also spoke with Alex D. about this, he has also experienced the > > same thing, he said it is worse when you have -3 degrees reflex, and > > still there at 0 degrees. I have done this with one and two notches > > of 'real' flaps and was able to do full slips. > > > > Ken K. asked me (with a smile) if I had enough 'guts' to get the > > rudder all the way to the floor to see how far it went, I didn't. > > At least not before understanding what is going on, and if this is > > limited to our copy. > > > > After experiencing this I have a few takeaways. 1) Expect the > > unexpected, I hate surprises, imagine the surprise while performing > > a fairly standard maneuver and getting a result never experienced > > before. 2) Don't do that.... 3) Share what is learned even at the > > risk of what replies are sure to come. > > > > I say don't do that but I believe Ken has a valid argument, at very > > least we should all understand what our aircraft behave like even if > > the maneuver is at the fringe of what we would normally expect to > > perform. > > > > Thanks, Jason Kreidler > > > > N44YH - Flying > > 4 Partner Build #40617 > > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > > > > > > > ________________________________________________________________________________
Subject: Forward Slips
Date: Aug 04, 2009
Agree. Only really aggressive slip was from 400 AGL on a one mile final out of an RNAV 6 in weather to minimums. Flaps were reflexed or perhaps zero, KIAS was 100 and power was at idle and prop full forward. Since I was flying from the right seat the nose went left and down, ailerons right, Slip continued to at least 20 degrees nose left until about 50 AGL. Touchdown was about 2000 ft down a 5000 ft runway in moderate rain. The left seat pilot was admonishing me not to skid; the prop in flat pitch and engine at idle were enough to slow and stop. My advice is that in any slip get the nose down, the objective is to lose the altitude without a significant increase in airspeed. You definitely don't want the stall one wing and it is likely that the airspeed indication will not be accurate. It is more accurate because of the static ports on each side of the aircraft but the airflow to the pitot will be skewed. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John Sent: Tuesday, August 04, 2009 6:39 PM Subject: Re: RV10-List: Forward Slips I had the chance to try this today (I normally only slip with flaps down). What Jason describes is the early onset to a departure from controlled flight (depart) due to loss of directional stability. Much worse slipping to the left than to the right due to engine torque (tends to try to depart underneath.....not good). At 90 kts I could not get it to come close to departing with full rudder and opposite aileron, but as I slowed 80 kts, you can definitely get it to depart if you don't know what the seat of your pants is telling you (I did literally scores of intentional departure from controlled flight maneuvers in my A-7D days in the AF). You can quickly break the departure by simply unloading back pressure on the stick (in the A-7, we released the stick altogether until the airplane recovered itself (usually very nose low). The departure happens when the rudder loses effectiveness, compounded by the wing low and opposite rudder. Somewhere in my early RV days, I was told that if you want to slip the an RV, you need to make sure the nose is well below the horizon to ensure that you do not lose rudder effectiveness. This is especially true of the earlier RV models and their even shorter height rudder than the -10. Avoid level attitude or nose up slips. I would encourage each of you -10 owners to practice the no flap slip (above 5,000' AGL in to have a comfortable recovery margin in case you do inadvertently depart the bird). You need to feel for yourselves the approach to departure feel that you get through the seat of your pants. Trim your airplane up for hands off at about 100 kts, power setting idle, then start your slip maneuver near level flight attitude. Once you feel that yaw in the seat of your pants, simply release release the rudder while simultaneously releasing stick back pressure to the neutral position. Then remember the secret to a slip in the -10: keep the nose low and use about 90 kts no flap and 80 kts with flaps. Hope this helps out grumpy N184JM On Aug 3, 2009, at 8:10 AM, jason.kreidler(at)regalbeloit.com wrote: I would like to pass along a flight test experience I had. I initiated a slip at 85 knots (note well below Va) (zero degree flap setting), the rudder pedal was fairly hard to push, however as it approached what I would guess to be just beyond the middle of its travel the 'tone' of the airframe changed, and the rudder became much easier to apply, the airplane 'jerked' further into the slip, and felt as if it was going to swap ends. It did not roll much, just an abrupt yaw. I then had to apply opposite rudder to return back to neutral. I did not get to the rudder stop. The rudder almost felt as if it went 'over center'. Weight & Balance during this test 2510 LBS @ 112.7". Note I was using pitch to maintain airspeed, and aileron to control heading (or track). After this happened I spoke with a few others who are flying, no one had performed this maneuver. I then spoke with Ken K. about this while at Oshkosh. He said he had experienced the same thing, although he entered it quickly by stomping the rudder pedal to the floor. He could not explain exactly what was causing the problem, he thought it might be dihedral stability. I told him the I suppose the right answer is "don't do that", he quickly replied that maneuver may be required if the flap motor was lost, and you were forced to slow down and land without flaps. I also spoke with Alex D. about this, he has also experienced the same thing, he said it is worse when you have -3 degrees reflex, and still there at 0 degrees. I have done this with one and two notches of 'real' flaps and was able to do full slips. Ken K. asked me (with a smile) if I had enough 'guts' to get the rudder all the way to the floor to see how far it went, I didn't. At least not before understanding what is going on, and if this is limited to our copy. After experiencing this I have a few takeaways. 1) Expect the unexpected, I hate surprises, imagine the surprise while performing a fairly standard maneuver and getting a result never experienced before. 2) Don't do that.... 3) Share what is learned even at the risk of what replies are sure to come. I say don't do that but I believe Ken has a valid argument, at very least we should all understand what our aircraft behave like even if the maneuver is at the fringe of what we would normally expect to perform. Thanks, Jason Kreidler N44YH - Flying 4 Partner Build #40617 Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler =================================== tp://www.matronics.com/Navigator?RV10-List =================================== nics.com =================================== w.matronics.com/contribution =================================== = ________________________________________________________________________________
Date: Aug 04, 2009
It is called a crossed controlled stall; the aircraft will snap over and go vertical in less than a second because one wing is producing lift and the other is stalled. At low altitude always fatal. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Sent: Tuesday, August 04, 2009 7:16 PM Subject: Re: RV10-List: Forward Slips Sir Grumpy, What exactly do you mean by "Depart"? Is it an uncommanded YAW or ???? I don't understand that term. Jim Combs (N312F) ---------------------------------------------------------------------------- ----------------------------- I had the chance to try this today (I normally only slip with flaps down). What Jason describes is the early onset to a departure from controlled flight (depart) due to loss of directional stability. Much worse slipping to the left than to the right due to engine torque (tends to try to depart underneath.....not good). At 90 kts I could not get it to come close to departing with full rudder and opposite aileron, but as I slowed 80 kts, you can definitely get it to depart if you don't know what the seat of your pants is telling you (I did literally scores of intentional departure from controlled flight maneuvers in my A-7D days in the AF). You can quickly break the departure by simply unloading back pressure on the stick (in the A-7, we released the stick altogether until the airplane recovered itself (usually very nose low). The departure happens when the rudder loses effectiveness, compounded by the wing low and opposite rudder. Somewhere in my early RV days, I was told that if you want to slip the an RV, you need to make sure the nose is well below the horizon to ensure that you do not lose rudder effectiveness. This is especially true of the earlier RV models and their even shorter height rudder than the -10. Avoid level attitude or nose up slips. I would encourage each of you -10 owners to practice the no flap slip (above 5,000' AGL in to have a comfortable recovery margin in case you do inadvertently depart the bird). You need to feel for yourselves the approach to departure feel that you get through the seat of your pants. Trim your airplane up for hands off at about 100 kts, power setting idle, then start your slip maneuver near level flight attitude. Once you feel that yaw in the seat of your pants, simply release release the rudder while simultaneously releasing stick back pressure to the neutral position. Then remember the secret to a slip in the -10: keep the nose low and use about 90 kts no flap and 80 kts with flaps. Hope this helps out grumpy N184JM On Aug 3, 2009, at 8:10 AM, jason.kreidler(at)regalbeloit.com wrote: > > I would like to pass along a flight test experience I had. > > I initiated a slip at 85 knots (note well below Va) (zero degree > flap setting), the rudder pedal was fairly hard to push, however as > it approached what I would guess to be just beyond the middle of its > travel the 'tone' of the airframe changed, and the rudder became > much easier to apply, the airplane 'jerked' further into the slip, > and felt as if it was going to swap ends. It did not roll much, > just an abrupt yaw. I then had to apply opposite rudder to return > back to neutral. I did not get to the rudder stop. The rudder > almost felt as if it went 'over center'. Weight & Balance during > this test 2510 LBS @ 112.7". Note I was using pitch to maintain > airspeed, and aileron to control heading (or track). > > After this happened I spoke with a few others who are flying, no one > had performed this maneuver. I then spoke with Ken K. about this > while at Oshkosh. He said he had experienced the same thing, > although he entered it quickly by stomping the rudder pedal to the > floor. He could not explain exactly what was causing the problem, > he thought it might be dihedral stability. I told him the I suppose > the right answer is "don't do that", he quickly replied that > maneuver may be required if the flap motor was lost, and you were > forced to slow down and land without flaps. > > I also spoke with Alex D. about this, he has also experienced the > same thing, he said it is worse when you have -3 degrees reflex, and > still there at 0 degrees. I have done this with one and two notches > of 'real' flaps and was able to do full slips. > > Ken K. asked me (with a smile) if I had enough 'guts' to get the > rudder all the way to the floor to see how far it went, I didn't. > At least not before understanding what is going on, and if this is > limited to our copy. > > After experiencing this I have a few takeaways. 1) Expect the > unexpected, I hate surprises, imagine the surprise while performing > a fairly standard maneuver and getting a result never experienced > before. 2) Don't do that.... 3) Share what is learned even at the > risk of what replies are sure to come. > > I say don't do that but I believe Ken has a valid argument, at very > least we should all understand what our aircraft behave like even if > the maneuver is at the fringe of what we would normally expect to > perform. > > Thanks, Jason Kreidler > > N44YH - Flying > 4 Partner Build #40617 > Tony Kolar - Kyle Hokel - Wayne Elsner - Jason Kreidler > > ________________________________________________________________________________
Subject: mounting steps
Date: Aug 04, 2009
I'm in the process of mounting steps on a QB, the steps were pre-drilled and according to the drawings the weld should be flush with the skin, which it isn't, and the measurement from rear spar should be 45 1/2, which it's about 46 with fuselage leveled. I could either let it go as is, move step to correct position and re-drill 90 deg from previous hole, or order new steps and align with existing hole. What are your experiences as to how your steps came out in relation to plans? Dave Ford -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256093#256093 ________________________________________________________________________________
Date: Aug 04, 2009
Folks, MEK is a poor second choice for thinning proseal. Toluene is the correct thinner. However, rather than messing with thinning, just buy one cartridge of A-2 compound, as it is already the correct consistency for brushing. Perhaps $20. In fact, the Mooney method for tank sealing is to do fillets and gap seals with B compound, then brush A compound over the fillets and all rivet heads, nutplates, bolts, etc. That is followed by a "cherry juice" top coat that is brushed on, two coats, to protect the proseal from effects of fuel, ethanol, and most anything else that gets in there. So Vans approach of only using B-2 with no access panel is a minimalist approach. My Mooney has 4 access plates in the design, and yes, there is a different access panel version of proseal. jkreidler wrote: This topic went around a while back and someone mentioned they applied heat, and maybe pressure, or vacuum. > OK, so I think I have fixed the blame, now it is time to fix the problem. Green loctite didn't seem to work, someone had suggested thinning pro-seal 50% with MEK, applying a slight vacuum to the tank and letting it cure. > Jason Kreidler > N44YH - Flying #40617 > 4 Partner Build > Wayne Elsner - Tony Kolar - Kyle Hokel - Jason Kreidler > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256046#256046 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2009
Miller John wrote: > Depart means just that - the airplane "departs" from controlled flight - > usually violently unlike a stall because it is often (but not always) > induced by cross controls to start with. > > Longitudinal stability (controlled by the vertical stabilizer and > rudder) is lost and the airplane then yaws followed by a rolling moment > and possible tumbling (especially pronounced in swept wing aircraft). > Straight wing aircraft usually snap roll rather than tumble. Which way > it rolls depends on any roll input compounded by torque effects of the > engine. Hmmm .... the airplane shouldn't snap roll unless the rudder and elevator is applied aggressively. Read "shouldn't" again. If one wing doesn't stall, then the snap roll doesn't occur. > > Had I held my left slip controls in for a second or two longer in today, > it would have snap rolled underneath with a forward pitching moment to > boot. Impossible to recover from in the traffic pattern. I'm curious .... do you have the experience (I think you do)to try this at altitude? The fact that a common forward slip morphs into some other flight regime is troubling to me. > > The loss of longitudinal stability is seen as yaw (if you're watching > the ball - which I hope you are not when doing this maneuver). the Yaw > is most quickly felt through the seat of the pants - going sideways in > the seat. > > Whenever you get this feeling in the seat of your pants, your first > response must be to release back stick pressure and neutralize ailerons > and rudder. That will keep the departure from happening. > > Having to dig back a few years into my fighter pilot past for this..... The mental picture of an A7 in a slip causes me some chuckles. Did you really??? When I read the original poster of the rudder thread my thoughts were that the rudder was blanked by the wing somehow .... but I'd just have to be there. Interesting thread. Linn > > grumpy > N184JM ________________________________________________________________________________
Date: Aug 04, 2009
Begin forwarded message: > From: Miller John <gengrumpy(at)aol.com> > Date: August 4, 2009 10:24:28 PM CDT > To: Linn Walters > Subject: Re: RV10-List: Forward Slips > > Over 4,000 hrs in single seat fighters, 1,700 in the A-7. Taught > departure training for years. A-7 would depart at 400 kts (very > violent, often tumbling end over end) or it would depart at 150 kts > - very slow motion-like, with near vertical (down) nose position to > start recovery. High speed departures (after tumbling) rarely had > nose down more than 30 degrees or so. > > Today, there was no "aggressive" rudder or elevator input - merely > held what i had as airspeed bled off. > > Slipped fighters all the time, even though we had speed brakes. > With the swept wing fast movers, you ALWAYS kept the nose low and > the speed up if you did a slip...... > > Don't think there's an airplane I've flown that I didn't routinely > slip when needed......just keep the nose low! > > On Aug 4, 2009, at 10:01 PM, Linn Walters wrote: > >> > >> >> Miller John wrote: >>> Depart means just that - the airplane "departs" from controlled >>> flight - usually violently unlike a stall because it is often (but >>> not always) induced by cross controls to start with. Longitudinal >>> stability (controlled by the vertical stabilizer and rudder) is >>> lost and the airplane then yaws followed by a rolling moment and >>> possible tumbling (especially pronounced in swept wing aircraft). >>> Straight wing aircraft usually snap roll rather than tumble. >>> Which way it rolls depends on any roll input compounded by torque >>> effects of the engine. >> Hmmm .... the airplane shouldn't snap roll unless the rudder and >> elevator is applied aggressively. Read "shouldn't" again. If one >> wing doesn't stall, then the snap roll doesn't occur. >>> Had I held my left slip controls in for a second or two longer in >>> today, it would have snap rolled underneath with a forward >>> pitching moment to boot. Impossible to recover from in the >>> traffic pattern. >> I'm curious .... do you have the experience (I think you do)to try >> this at altitude? The fact that a common forward slip morphs into >> some other flight regime is troubling to me. >>> The loss of longitudinal stability is seen as yaw (if you're >>> watching the ball - which I hope you are not when doing this >>> maneuver). the Yaw is most quickly felt through the seat of the >>> pants - going sideways in the seat. >>> Whenever you get this feeling in the seat of your pants, your >>> first response must be to release back stick pressure and >>> neutralize ailerons and rudder. That will keep the departure from >>> happening. >>> Having to dig back a few years into my fighter pilot past for >>> this..... >> The mental picture of an A7 in a slip causes me some chuckles. Did >> you really??? >> >> When I read the original poster of the rudder thread my thoughts >> were that the rudder was blanked by the wing somehow .... but I'd >> just have to be there. Interesting thread. >> Linn >>> grumpy >>> N184JM >> >> >> >> > ________________________________________________________________________________
Subject: Re: mounting steps
Date: Aug 04, 2009
Hi Dave, From what I remember of a conversation with Vans, the step position relative to the rear spar has more to do with clearing the flaps when extended than anything else. If your step is canted a bit further aft than specified, I don't think you have a problem. You don't say how far from flush the weld is to the skin. Mine stopped at the edge of the widest edge of the weld bead... which didn't seem all that "flush." Jeff Carpenter 40304 Doors. Ugh! On Aug 4, 2009, at 8:01 PM, rvdave wrote: > > I'm in the process of mounting steps on a QB, the steps were pre- > drilled and according to the drawings the weld should be flush with > the skin, which it isn't, and the measurement from rear spar should > be 45 1/2, which it's about 46 with fuselage leveled. I could > either let it go as is, move step to correct position and re-drill > 90 deg from previous hole, or order new steps and align with > existing hole. What are your experiences as to how your steps came > out in relation to plans? > > Dave Ford > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=256093#256093 > > ________________________________________________________________________________
Date: Aug 05, 2009
I wouldn't worry about it too much. Some of the weld will be visible but no big deal. As long as you clear the flaps, it should be fine. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256122#256122 ________________________________________________________________________________
Date: Aug 05, 2009
> I have heard some used a Cherrymax rivet with pro-seal, I am not familiar with which rivet to use. Anyone with any ideas? Check out blind rivets at Aircraft Spruce. The AN 41H is a good example of a closed end blind rivet. I think Cherrymax has it as BSPQ-41. Higher numbers, such as 42, 43, etc, are grip length. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256124#256124 ________________________________________________________________________________
Date: Aug 05, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: GRT AHRS Mounting and CG
I'm sticking with my already completed installation. I built a shelf across the longerons just aft of the bay containing the AP servo. The magnetometers are mounted on the left side to maximize the distance from the servo and the strobe power unit mounted on the right wall. I purchased Van's AHRS shelf which mounts on the floor next to the AP servo. The GRT AHRS holes are pre-drilled and the shelf appears to be properly aligned. This puts the Magnetometers and AHRS exactly 18" apart. The Magnetometers are 23" from the AP servo and 24+ from the stobe power unit. I hope it all works well. Chris wrote: > > Good points Bill. I decided to make the shelf for the magnetometers > just ahead of the seat belt attach. I am putting another shelf forward > of that slightly aft of the battery to hold the AHRS. Both units will > be completely aligned though separated based on GRTs inputs that the > AHRS can cause some disturbance in the magnetometer. > > -Chris Lucas > > #40072 > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill > DeRouchey > *Sent:* Tuesday, August 04, 2009 1:40 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Re: GRT AHRS Mounting and CG > > Guys- > > I have not been following this thread so my comments may have already > been covered. > > The best place to locate a magnometer (and/or the AHRS if they do not > interfer with one another) is on a shelf that spans the fuselage > laterally between the three longeron bolts that secure the aft seat > belt attachment. This location has four good advantages: > > I have measured the magnetic interference and this location is the > farthest distance from the autopilot elevator servo and the elevator > trim servo. Do not underestimate the interference from the little trim > servo - it is more of a problem than the autopilot. > > A shelf in this orientation is automatically aligned with the pitch > and roll axis. > > If the sensor contains accelerometers or rate gyros it will function > more accurately along the centerline of the fuselage than a wing tip. > > This location is far from the baggage compartment and the > unpredictable magnetic forces contained in the unpredictable baggage. > > Also - you will never get a sensor accurately aligned in a wing tip. I > just had a good example of how the wing will move about between ground > and air. > > Bill DeRouchey > > N939SB > ________________________________________________________________________________
Subject: proseal
Date: Aug 05, 2009
Hi guys I came home with a quart of Proseal and hardener from Airventure and recall people putting the Proseal in a freezer to extend its shelf life. The expiry date is Nov 2009, and since I won't be starting the tail section until at least Sept, I am wondering if it's unopened, if it matters? Also did anyone freeze the hardener as well? Thx in advance....... Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Aug 05, 2009
> I'm sticking with my already completed installation. > > I built a shelf across the longerons just aft of the bay containing the > AP servo. The magnetometers are mounted on the left side to maximize the > distance from the servo and the strobe power unit mounted on the right wall. > > I purchased Van's AHRS shelf which mounts on the floor next to the AP > servo. The GRT AHRS holes are pre-drilled and the shelf appears to be > properly aligned. > > This puts the Magnetometers and AHRS exactly 18" apart. The > Magnetometers are 23" from the AP servo and 24+ from the stobe power unit. > > I hope it all works well. The Van's AHRS shelf sounds like a possibility. Van's drawing shows it on the left side, can it be mounted on the right? I've already got the A/P servo on that side. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256132#256132 ________________________________________________________________________________
Subject: Re: proseal
Date: Aug 05, 2009
I do not know about the freezer, it is not water based. Refer might be preferred if there is no smell. I do know that I had Van's 2 oz kit (bought last Oct) in my very cold garage all winter, and have used it with good results all this summer. Garage is in the 40's most of the winter. -------- OSH '09 or Bust (busted) be there someday Q/B Kit - end game Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256143#256143 ________________________________________________________________________________
Date: Aug 05, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Rick; I do keep the proseal in the freezer. I have used it about a year over exp date for non essential areas. I wouldn't hesitate using it on the trailing edges/to bond the rudder/elevator if it was a little over the exp date. I would not use it for the tanks. All you have to do is look at the recent posts with all the trouble one has to go thru if you have a leaking tank. Some have even repainted their airplanes. Messes up the paint scheme which can take months to develop. Dr Fred. Sandra & Rick Lark wrote: > > Hi guys > > I came home with a quart of Proseal and hardener from Airventure and > recall > people putting the Proseal in a freezer to extend its shelf life. > > The expiry date is Nov 2009, and since I won't be starting the tail > section > until at least Sept, I am wondering if it's unopened, if it matters? > Also > did anyone freeze the hardener as well? > > Thx in advance....... > > Rick > #40956 > Southampton, Ont > > ________________________________________________________________________________
Subject: proseal
Date: Aug 05, 2009
I would recommend keeping it cool at least, you will need it later in the project and it will keep for a long time if it is kept out of the heat. In the winter I kept my in the garage and in the spring, summer and fall, I kept it in the refrigerator. I did not have any problem with it setting up. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sandra & Rick Lark Sent: Wednesday, August 05, 2009 7:06 AM Subject: RV10-List: proseal Hi guys I came home with a quart of Proseal and hardener from Airventure and recall people putting the Proseal in a freezer to extend its shelf life. The expiry date is Nov 2009, and since I won't be starting the tail section until at least Sept, I am wondering if it's unopened, if it matters? Also did anyone freeze the hardener as well? Thx in advance....... Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: Testing fuel tank with 100LL
Date: Aug 05, 2009
Cherrymax are "approved" replacements for solid AD rivets where the rivet can not be bucked. They are significantly more costly than the blind rivets supplied with the kit. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Wednesday, August 05, 2009 5:18 AM Subject: RV10-List: Re: Testing fuel tank with 100LL --> > I have heard some used a Cherrymax rivet with pro-seal, I am not familiar with which rivet to use. Anyone with any ideas? Check out blind rivets at Aircraft Spruce. The AN 41H is a good example of a closed end blind rivet. I think Cherrymax has it as BSPQ-41. Higher numbers, such as 42, 43, etc, are grip length. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256124#256124 ________________________________________________________________________________
Subject: Re: Fuel tank leaks
Date: Aug 05, 2009
I saw several aircraft at OSH with fuel leaks and I have a very small one on mine too. After studying the issue, I think that the problem for some of the tanks that test solid at first and then develop leaks later is that most people put the wing walk non skid too far forward (myself included). There are no extra ribs in the fuel tank like there is in the wing itself. Thus it will flex more if stepped on. Thus causing leaks. I mentioned this to Ken Kreuger and he had also come to this conclusion. I think that the long term solution is to add a few extra ribs in the tank to take up the stress as it is very difficult not to step on the forward part of the wing while helping folks into the rear seat if it is their first ride. Also one could label the tank as a non step area. Thoughts on this? Gary Specketer 40274 ________________________________________________________________________________
Subject: For reference
Date: Aug 05, 2009
For future reference, the wheel kit supplied with the 10 is Cleveland kit 199104A consisting of brake assembly 30-59A and wheel assembly 40-59A. A 40-59A chrome is available. Cleveland publishes a product catalog which is illustrated with part numbers. Rapco also makes some replacement parts for Cleveland wheels/brakes; their part numbers start with RA and then the Cleveland number. Of course the nose wheel is from Matco and may be either their 501.25 or 511.25 depending on whether you switched the uninstalled Van's supplied nose wheel with Matco for a more appropriate one. Matco also sells the RV10 axle which fixes the fork scoring problem in the Vans design. ________________________________________________________________________________
Date: Aug 05, 2009
I did not put the wing walk forward on the tank because it invites feet...Is this leaking mainly on the QB's? Rick Sked ------Original Message------ From: gary Sender: owner-rv10-list-server(at)matronics.com ReplyTo: Rv Sent: Aug 5, 2009 8:43 AM Subject: RE: RV10-List: Re: Fuel tank leaks I saw several aircraft at OSH with fuel leaks and I have a very small one on mine too. After studying the issue, I think that the problem for some of the tanks that test solid at first and then develop leaks later is that most people put the wing walk non skid too far forward (myself included). There are no extra ribs in the fuel tank like there is in the wing itself. Thus it will flex more if stepped on. Thus causing leaks. I mentioned this to Ken Kreuger and he had also come to this conclusion. I think that the long term solution is to add a few extra ribs in the tank to take up the stress as it is very difficult not to step on the forward part of the wing while helping folks into the rear seat if it is their first ride. Also one could label the tank as a non step area. Thoughts on this? Gary Specketer 40274 Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Aug 05, 2009
My QBs were done 3/2005 and we never stand on the tanks; no leaks at 190 TT. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com Sent: Wednesday, August 05, 2009 10:39 AM Subject: Re: RV10-List: Re: Fuel tank leaks I did not put the wing walk forward on the tank because it invites feet...Is this leaking mainly on the QB's? Rick Sked ------Original Message------ From: gary Sender: owner-rv10-list-server(at)matronics.com ReplyTo: Rv Sent: Aug 5, 2009 8:43 AM Subject: RE: RV10-List: Re: Fuel tank leaks I saw several aircraft at OSH with fuel leaks and I have a very small one on mine too. After studying the issue, I think that the problem for some of the tanks that test solid at first and then develop leaks later is that most people put the wing walk non skid too far forward (myself included). There are no extra ribs in the fuel tank like there is in the wing itself. Thus it will flex more if stepped on. Thus causing leaks. I mentioned this to Ken Kreuger and he had also come to this conclusion. I think that the long term solution is to add a few extra ribs in the tank to take up the stress as it is very difficult not to step on the forward part of the wing while helping folks into the rear seat if it is their first ride. Also one could label the tank as a non step area. Thoughts on this? Gary Specketer 40274 Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Aug 05, 2009
One other thing; I have had two occasions to buy replacement parts and found Vans prices to be much better than Aircraft Spruce and others. Probably should check there first. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Wednesday, August 05, 2009 10:30 AM Subject: RV10-List: For reference For future reference, the wheel kit supplied with the 10 is Cleveland kit 199104A consisting of brake assembly 30-59A and wheel assembly 40-59A. A 40-59A chrome is available. Cleveland publishes a product catalog which is illustrated with part numbers. Rapco also makes some replacement parts for Cleveland wheels/brakes; their part numbers start with RA and then the Cleveland number. Of course the nose wheel is from Matco and may be either their 501.25 or 511.25 depending on whether you switched the uninstalled Van's supplied nose wheel with Matco for a more appropriate one. Matco also sells the RV10 axle which fixes the fork scoring problem in the Vans design. ________________________________________________________________________________
Date: Aug 05, 2009
Doesn't have to be in the freezer .... just keep it cold. The hardener is the part that goes bad with age. I've tested really old Proseal with fresh hardener and it cured. Linn Sandra & Rick Lark wrote: > > Hi guys > > I came home with a quart of Proseal and hardener from Airventure and recall > people putting the Proseal in a freezer to extend its shelf life. > > The expiry date is Nov 2009, and since I won't be starting the tail section > until at least Sept, I am wondering if it's unopened, if it matters? Also > did anyone freeze the hardener as well? > > Thx in advance....... > > Rick > #40956 > Southampton, Ont > > > > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Aug 05, 2009
Subject: proseal
I put leftover proseal from my tanks in the freezer for 3-4 years now. I needed to use some for the cabin top riveting recently and actually threw both parts in the microwave to warm up enough to mix (I wouldn't recommend this for any large qty) and had no problems with it. Setup just like it was new. YMMV and I would recommend a test batch for any that is past the recommended date. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sandra & Rick Lark Sent: Wednesday, August 05, 2009 8:06 AM Subject: RV10-List: proseal Hi guys I came home with a quart of Proseal and hardener from Airventure and recall people putting the Proseal in a freezer to extend its shelf life. The expiry date is Nov 2009, and since I won't be starting the tail section until at least Sept, I am wondering if it's unopened, if it matters? Also did anyone freeze the hardener as well? Thx in advance....... Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Aug 05, 2009
johngoodman wrote: > > > >> I'm sticking with my already completed installation. >> >> I built a shelf across the longerons just aft of the bay containing the >> AP servo. The magnetometers are mounted on the left side to maximize the >> distance from the servo and the strobe power unit mounted on the right wall. >> >> I purchased Van's AHRS shelf which mounts on the floor next to the AP >> servo. The GRT AHRS holes are pre-drilled and the shelf appears to be >> properly aligned. >> >> This puts the Magnetometers and AHRS exactly 18" apart. The >> Magnetometers are 23" from the AP servo and 24+ from the stobe power unit. >> >> I hope it all works well. >> > > > The Van's AHRS shelf sounds like a possibility. Van's drawing shows it on the left side, can it be mounted on the right? I've already got the A/P servo on that side. > John > I think it is left side only unless they made a right side. Did you install something other than TruTrak? My TruTrak servo is on the right. ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Aug 05, 2009
Gary, you are right on. I can't say for sure, but it seems to me that the majority of the leaking rivets are the end rivets that hold the T1011 Tank Stiffeners on the top inboard tank skin. This would make sense as this is where the stress concentration would be if the tank were stepped on. These stiffeners do not tie into the ribs, if they did, the problem MIGHT go away. While we did not use the tank as a step I can not confirm that it was never stood on during construction, I know it was sat on. If I were standing on it I could tell you how many foot pounds of force it saw, two, the units for measuring the force exerted by sitting must be different. Any takers?? Not standing or sitting, or placing anything heavy on the tank may very well save builders from this rather annoying problem. Just my engineering opinion. Jason Kreidler N44YH - Flying - #40617 4 Partner Build - Sheboygan Falls, WI Wayne Elsner, Kyle Hokel, Tony Kolar, Jason Kreidler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256256#256256 ________________________________________________________________________________
Date: Aug 05, 2009
Subject: RV Smoke Systems
Dear Listers, Last week, someone posted a couple of pictures of 37 RVs flying in formation at OSH this year. Very cool, btw. But what caught my eye was how many of them had smoke systems installed. I found the following at ACS which looks interesting, but kind of big for an RV-8: http://www.aircraftspruce.com/catalog/appages/sa102-103.php Is this what people are using? Where would one mount this system in an RV-8? Behind the baggage area? In the engine compartment? Seems really cool to have one of these systems, but are they just a big pain in the ass to maintain? Thanks for the thoughts, Matt Dralle RV-8 #82880 N998RV FWF Starts This Weekend! ________________________________________________________________________________
From: Robert Brunkenhoefer <rebrunk42(at)gmail.com>
Subject: stephen saint's wing root fairing
Date: Aug 06, 2009
how do i get a wing root fairing like the one on N256H registered to stephen saint? robert brunkenhoefer. 160 + hrs and enjoying it. 661G ________________________________________________________________________________
Subject: Gretz GA-1000 Cracked
Date: Aug 06, 2009
I just found a 1"x1/8" crack along the bottom seam of my GA-1000 heated pitot. I have 150hr on the plane and 10-15hr using the heat on the pitot. Talked to Warren Gretz and the best he could come up with was to patch it with J&B Weld. Emailed the new producers of the GA-1000 but no response. It still heats up, but I'm going to replace it. Just wanted to give everyone a heads up. Blue Skys Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Aug 06, 2009
Given the fact that it's just a thermoplastic with basically an embedded element and thermistor, you should be able to fix it just fine with some JB Weld or similar. IMHO Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Barry Marz Sent: Thursday, August 06, 2009 1:54 PM Subject: RV10-List: Gretz GA-1000 Cracked I just found a 1"x1/8" crack along the bottom seam of my GA-1000 heated pitot. I have 150hr on the plane and 10-15hr using the heat on the pitot. Talked to Warren Gretz and the best he could come up with was to patch it with J&B Weld. Emailed the new producers of the GA-1000 but no response. It still heats up, but I'm going to replace it. Just wanted to give everyone a heads up. Blue Skys Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Subject: Seatbelt countersink
Date: Aug 06, 2009
Anyone have a list for the seatbelt countersink? I am just about to the point where I will need to buy it if I can't get my hands on one. Thanks. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256434#256434 ________________________________________________________________________________
Date: Aug 06, 2009
I had to have my pitot replaced via warranty. It had a short between one of the thermistor leads and ground. Andrew takes awhile to respond. I got the impression that he only reads his email on a periodic basis. I found I got a quicker response by giving him a call. Just remember that he's 14 hours ahead. He's good to deal with, just not responsive via email. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Thursday, August 06, 2009 3:52 PM Subject: RE: RV10-List: Gretz GA-1000 Cracked Given the fact that it's just a thermoplastic with basically an embedded element and thermistor, you should be able to fix it just fine with some JB Weld or similar. IMHO Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Barry Marz Sent: Thursday, August 06, 2009 1:54 PM Subject: RV10-List: Gretz GA-1000 Cracked I just found a 1"x1/8" crack along the bottom seam of my GA-1000 heated pitot. I have 150hr on the plane and 10-15hr using the heat on the pitot. Talked to Warren Gretz and the best he could come up with was to patch it with J&B Weld. Emailed the new producers of the GA-1000 but no response. It still heats up, but I'm going to replace it. Just wanted to give everyone a heads up. Blue Skys Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Subject: cowl on front baffle photos
Date: Aug 07, 2009
Does anyone have cowl-on photos that show the air inlets... with the rubber air seal fabric material covering the sides and upper air inlet ramps? I've seen plenty of photos where the cowl is off, but hardly any closeups with the top/bottom cowl halves in place. Thanks in advance, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256493#256493 ________________________________________________________________________________
Subject: Re: More fun with rebuilt engines
Date: Aug 07, 2009
I had an A&P make a house call to replace two helicoils in my IO540. It took about 1.5 hours to complete both including sucking / flushing out thread debris. Some rather interesting (clever) tools were required for the install that I'd not seen before. Good learning experience. Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256501#256501 ________________________________________________________________________________
Subject: tires
Date: Aug 07, 2009
Anyone running 600-6 mains or the standard 15/600-6? I bought 600-6s prior to looking at the tires to be removed. Did not notice any handling difference. ________________________________________________________________________________
Date: Aug 07, 2009
Subject: Door seal info
It was great seeing everyone @ OSH this year, and a special thanks to Gary,Bob and all who set up RV10 HQ and organized the dinners. Judy and I returned yesterday after continuing on to Long Island NY from OSH. Several people inquired about the door seals on N519PJ. 1st I should acknowledge Sheril Hilton and Robin Marks for their innovation on this idea, and Ed Hayden for kicking me in the pants to 'quit thinking about it and just Do It!' I'm very happy with the results. The door seal material is available from McMaster Carr McMaster Carr p/n 1120A311 http://www.mcmaster.com/#1120a311/=3390lx I bought a 100ft roll and sold 30 ft to another -10 builder. I've got enough left over to do 2 more doors. I cut up an initial 12 ft section into pieces of various size/lengths to use during the trial and error process of removing the cabin cover 'curved edge' fiberglass to provide the right clearance between the cabin cover and the closed door. Like Ed H. I found that it was necessary to glue the seal on, and after experimenting with several 'contact like cements' I ended up using Pro Seal, which works great. If you scan down this page http://deemsrv10.com/Homelogindex.html you will find several entries which describe the process I used to close out the door hinges to complete the seal. I helped another -10 builder here in AZ to do the same. Deems Davis N519PJ http://deemsrv10.com/ ________________________________________________________________________________
Date: Aug 08, 2009
Subject: Crimpers
Listers, Can anyone offer up an opinion as to what would be a good choice of a crimper for wire terminals? Would like to start with the ring terminals and then work up to the pins for DB connectors. Ed Godfrey 40717 ________________________________________________________________________________
Date: Aug 08, 2009
Subject: Re: Crimpers
I'd go to http://www.steinair.com/ for things electrical. Linn Ed Godfrey wrote: > > Listers, > Can anyone offer up an opinion as to what would be a good choice of a > crimper for wire terminals? Would like to start with the ring terminals > and then work up to the pins for DB connectors. > > Ed Godfrey > 40717 > > > > > ________________________________________________________________________________
Subject: Crimpers
Date: Aug 08, 2009
If you're not in a real hurry, you can usually get a good deal on AMP and DMC crimpers on Ebay. Just set a firm price when you start bidding. Occasionally, the bidding goes crazy. It did take me 4-6 weeks to get all the positioners I needed for the DMC. You'll want the AMP 59250 Red Blue Certi-Crimp T-Head Hand Crimper for terminals and the Daniels AFM8 Crimp tool for the DB25s. You can see the DMC tool and the various positioners on Stein's site. Pictures of both are on my Kitlog site (http://www.mykitlog.com/users/display_log.php?user=rleffler&project=260&cat egory=2196&log=46591&row=1) I was able to pick up both in good condition for about $80 each. There are crimpers that are less expensive, but these are what most of the professional shops use. bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Saturday, August 08, 2009 1:44 PM Subject: Re: RV10-List: Crimpers I'd go to http://www.steinair.com/ for things electrical. Linn Ed Godfrey wrote: > > Listers, > Can anyone offer up an opinion as to what would be a good choice of a > crimper for wire terminals? Would like to start with the ring terminals > and then work up to the pins for DB connectors. > > Ed Godfrey > 40717 > > > > > ________________________________________________________________________________
Subject: MAP sensor on GRT EIS?
Date: Aug 09, 2009
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Can anyone say if the Manifold Pressure sensor little box on a GRT EIS set up gets fed with 12 volts or 5 vollts? TDT Tim Dawson-Townsend 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Aug 09, 2009
12 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Sunday, August 09, 2009 1:31 AM Subject: RV10-List: MAP sensor on GRT EIS? Can anyone say if the Manifold Pressure sensor little box on a GRT EIS set up gets fed with 12 volts or 5 vollts? TDT Tim Dawson-Townsend 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Subject: Re: MAP sensor on GRT EIS?
Date: Aug 09, 2009
12v, attached is the install info. Bob N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256769#256769 Attachments: http://forums.matronics.com//files/grtmap_122.pdf ________________________________________________________________________________
Date: Aug 09, 2009
12v, attached is the install info. Bob N442PM Read this topic online here: http://forums.matronics.com/viewtopic.php?p=256770#256770 Attachments: http://forums.matronics.com//files/grtmap_122.pdf ________________________________________________________________________________
Subject: Trim indicator
Date: Aug 09, 2009
All: Testing the trim (Safety-Trim) and trim indicator (Ray Allen), I got just one lit bar, at the far end of the indicator range. (can't tell yet whether it's the "up" or "down" end) Checking things, somehow I was applying 24 volts to the indictor power! I fixed that, but the result is the same. Do you think I "toasted" the indicator and now it will only show that one lit bar at the end of the scale, or is there some debugging I can do
July 22, 2009 - August 09, 2009
RV10-Archive.digest.vol-ev
