RV10-Archive.digest.vol-fa
September 14, 2009 - September 25, 2009
      Shouldn't be a problem.  Just get good twist on the wires.  There are
      several places on my RV-4 with that large a gap in the safety wire.  I
      assume the bolts are going into threads on the mount?  If nuts are used,
      just use locknuts (all-metal, due to temperature considerations in the
      engine compartment).
      Jack Phillips
      #40610
      Wings
      -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: Monday, September 14, 2009 1:50 PM
Subject: Safety wiring the alternator
I'm fitting up the alternator and it's belt tensioning bracket (a 40amp from B&C). The bolts are drilled for safety wire but the 2 bolts are like 8" apart. Do I just run the safety wire between the 2 bolts? Seems long but there are no other obvious tie-off points. Bill "FWF" Watson ________________________________________________________________________________
Date: Sep 14, 2009
Subject: Re: Safety wiring the alternator
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
I usually put a 1/16" hole in the bracket to tie the other end of the safety wire to. Dave On Mon, Sep 14, 2009 at 10:50 AM, Bill Mauledriver Watson < MauleDriver(at)nc.rr.com> wrote: > MauleDriver(at)nc.rr.com> > > I'm fitting up the alternator and it's belt tensioning bracket (a 40amp > from B&C). The bolts are drilled for safety wire but the 2 bolts are like > 8" apart. Do I just run the safety wire between the 2 bolts? Seems long > but there are no other obvious tie-off points. > > Bill "FWF" Watson > > -- Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Subject: Infinity grip wiring.
Date: Sep 14, 2009
Thanks Don That looks like the way to go. I was heading down that path as well. Geoff Geoff Combs President Aerosport Modeling & Design 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, September 14, 2009 12:01 PM Subject: Re: RV10-List: Infinity grip wiring. Geoff, here's what I did... really simple. Don McDonald --- On Sun, 9/13/09, aerosport1 wrote: From: aerosport1 <g.combs(at)aerosportmodeling.com> Subject: RV10-List: Infinity grip wiring. Date: Sunday, September 13, 2009, 4:42 PM http://us.mc537.mail.yahoo.com/mc/compose?to=g.combs@aerosportmodeling .com> > I am looking for some good ways to simplify the wiring between the Infinity grips, Trim servos, Efis display and safety trim. I have seen some photos that showed using sub D plugs or other types that had a junction box or strip under the seats. Any help or ideas out there. Photos would be great. Thanks Geoff N829GW -------- Geoff Combs RV-10 QB N829GW Finishing Read this topic online here: http://forums.matronics.com/vibsp; <http://forums.matronics.com/viewtopic.php?p=262837#262837> --> <http://www.matronics.com/Navigator?RV10-List> http://foru - List Contribution We -Matt Dralle, Listm/contribution" target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Sep 14, 2009
I drilled small holes in the large steel arm holding the alternator and used shorter safety wire runs.... Sent from my iPhone On Sep 14, 2009, at 2:01 PM, "Jack Phillips" wrote: > > > > Shouldn't be a problem. Just get good twist on the wires. There are > several places on my RV-4 with that large a gap in the safety wire. I > assume the bolts are going into threads on the mount? If nuts are > used, > just use locknuts (all-metal, due to temperature considerations in the > engine compartment). > > Jack Phillips > #40610 > Wings > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill > Mauledriver > Watson > Sent: Monday, September 14, 2009 1:50 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Safety wiring the alternator > > > > I'm fitting up the alternator and it's belt tensioning bracket (a > 40amp > from B&C). The bolts are drilled for safety wire but the 2 bolts are > like 8" apart. Do I just run the safety wire between the 2 bolts? > Seems long but there are no other obvious tie-off points. > > Bill "FWF" Watson > > ________________________________________________________________________________
Subject: Aztec baffle for Rv-10
Date: Sep 14, 2009
I am getting an overhauled Aztec Engine (IO-540-C4B5.) and it comes with the baffles. Anyone know if I can use the baffles from the Aztec on a RV-10 even if it meant doing modifications? thanks! Pascal ________________________________________________________________________________
Date: Sep 14, 2009
Subject: Re: Wiring diagram for Slick Start with 2 Slick Mags
You arrive at this goofy situation, because the certified aircraft the RV-10 engine is derived from, the Comanche 250/260, AFAIK, came with Bendix mags and Bendix vibrator, for "shower of sparks" setup. After Lycoming became a division of Textron, it just wouldn't do to purchase magnetos from a division of Teledyne Continental...Bendix. So they had to switch to Unison Slick. There are enough differences, that when Unison came out with SlickStart, they had to make a separate Bendix version to use with Bendix mags. My understanding is the Bendix version is no longer made. You do have the option of getting the appropriate Bendix vibrator, instead of the Slick Start...but not a lot cheaper. Probably more history than you wanted. On Mon, Sep 14, 2009 at 6:54 AM, Bill Mauledriver Watson wrote: I'm now aware of 2 distinctly different > service letters, several versions of the Slick Start unit itself (pin 2 is > labeled but gone), and for SL2-96, there's a revision E and F that are > distinctly different. Handling all these legacy setups in the certified > aircraft environment looks really challenging for the manufacturers. > > For anyone with a stock 540 from Vans, with 2 Slick mags (no electronic > ignition), and the standard key switch from Spruce, it appears you need to > add the Slick Start module to the setup (which is not included in the FWF > kit nor with the engine, nor is it doc'd anywhere I've found), and you need > to wire it as described below. At least that's the conclusion I've come to > with a lot of help from quite a few. > > Thanks all, > Bill "developing a true fondness for my Lycosaur and its legacy > technologies" Watson > > Rene wrote: >> >> >> OK, I am no expert....but this is my best guess......... >> >> Pin one grounds the Left mag capacitor stud for starting...... >> Pin two does nothing >> Pin three provides excitation voltage to the retard breaker whenever the >> starter is engaged. >> Vin powers the unit only when the starter is engaged >> GND ....ground for the unit. >> >> When using a standard off, right, left, both, start.....starter switch, >> the >> right mag is grounded when the key is in the start position. Note, the >> note >> to jumper the GND and R... "JUMPER Use when lef mag is retard or breaker >> mag >> or has impulse coupling." (See install of acs A-510-2 ignition switch. >> >> On back of key switch. >> >> L goes to Left mag capacitor (used to ground left mag) >> LR (Not used) >> R goes to Right mag capacitor (used to ground Right mag) >> S goes to start solenoid >> BO (Not used) >> Bat goes to battery >> GND to ground >> >> I will see if I can dig up the key wiring......I remember seeing it >> somewhere. >> >> Rene' >> 801-721-6080 >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill >> Mauledriver >> Watson >> Sent: Sunday, September 13, 2009 8:08 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Wiring diagram for Slick Start with 2 Slick Mags >> >> >> >> I found this which describes my configuration exactly >> http://alturl.com/dgvt >> The only difference between what is described above and Fig 3 on page 12 >> of SL2-96 is the connection of terminal 3 to the "left mag retard breaker >> terminal". >> >> Any thoughts? I'm still staring at this stuff. >> >> Bill "otherwise cruising along with the FWF work" Watson >> >> >> Dave Saylor wrote: >> >>> >>> Bill, >>> >>> Table 2 sucks. They make it sound like those are all the possible >>> combinations, but my setup, for example, isn't listed in Table 2. I have >>> zero impulse couplings, zero start vibrators, one regular mag, and one >>> retard mag. I wired mine like Figure 3 on page 12 of this version: >>> >>> b2b.unisonindustries.com/pdf/marketing_literature/SL2-96(E).pdf >>> >> >> >> <http://b2b.unisonindustries.com/pdf/marketing_literature/SL2-96%28E%29.pdf> >> >>> >>> I couldn't find anything that talks about a jumper, but if you point it >>> out I might be able to help clarify that. I suspect that they want it to >>> ground the other mag during start. >>> >>> There's another pub from Unison that says not to connect the same >>> SlickStart to both mags. I guess they found a possible failure that can >>> ground both mags at the same time, or at least they're guarding against the >>> possibility. Good insurance, and mine starts fine on one mag. >>> >>> Dave >>> >>> On Sat, Sep 12, 2009 at 6:21 PM, Bill Mauledriver Watson >>> > wrote: >>> >>> > >>> >>> Yes, Freak'n Fabulous that FAB is. >>> >>> Dave, I know this will end up with a pretty simple install but I >>> can't get through the installation directions in SL2-96 which is >>> all that came with the unit. Table 2 on page 7 of 39 has a table >>> that I'm having trouble getting past. I can't figure out which >>> one applies... and one option (that probably doesn't apply) shows >>> a jumper that's required on the starter switch. >>> >>> I'm going to get my head wrapped around this at some point but >>> sure would like to cheat first... >>> >>> Bill "drinking coffee and looking forward to a full build day" Watson >>> >>> Dave Saylor wrote: >>> >>> Bill, >>> >>> The SlickStart doesn't really connect to the start switch. It >>> gets power from the start relay, and the rest of the wiring is >>> to the mags. >>> >>> The installation instructions don't even have a diagram, just >>> a "connect this wire here" kind of thing. I can get you a >>> copy on Monday if you need it. If you're trying to get a jump >>> on the install, just run a wire from the start solenoid to the >>> SlickStart, and a ground. The rest is pretty easy. >>> >>> F stands for fab, right? >>> >>> Dave "always enjoying Bill's tag lines" Saylor >>> >>> On Fri, Sep 11, 2009 at 3:59 PM, Bill Mauledriver Watson >>> >>> >> >>> wrote: >>> >>> >>> >> >>> >>> Does anyone have a wiring diagram for 2 Slick Mags, one with >>> retard, Slick Start, and a key switch they'd be willing to >>> share? >>> Or something at least close. >>> >>> Thanks >>> Bill "starting the Vetterman exhaust install while still >>> trying to >>> finish the F-Air-Box" Watson >>> and enjoying a fine NC weekend! >>> >>> >>> >>> >>> >>> >>> >>> >>> ========== >>> arget="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >>> >>> >>> >>> -- Dave Saylor >>> AirCrafters LLC >>> 140 Aviation Way >>> Watsonville, CA 95076 >>> 831-722-9141 Shop >>> 831-750-0284 Cell >>> * >>> >>> >>> * >>> >>> >>> >>> >>> ========== >>> arget="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >>> >>> >>> >>> -- >>> Dave Saylor >>> AirCrafters LLC >>> 140 Aviation Way >>> Watsonville, CA 95076 >>> 831-722-9141 Shop >>> 831-750-0284 Cell >>> * >>> >>> >>> * >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 14, 2009
Subject: Re: Aztec baffle for Rv-10
I wouldn't bank on it. Baffling above the engine is made to fit the specific cowling. The Aztec cowl is very bulbous, compared to the RV cowl. If you don't mind doing a LOT of cutting and fitting, you could do it, but not a real productive use of your time. You can of course use the intercylinder baffles on the bottom of the cylinders. On Mon, Sep 14, 2009 at 12:57 PM, Pascal wrote: > I am getting an overhauled Aztec Engine (IO-540-C4B5.) and it comes with the > baffles. Anyone know if I can use the baffles from the Aztec on a RV-10 even > if it meant doing modifications? > thanks! > > Pascal > > ________________________________________________________________________________
Subject: Do you have a Mac?
Date: Sep 14, 2009
I need to find a couple folks to test a new RV-10 related site. We've come across an issue and need to validate whether or not it's a common Mac issue or localized to one user. If you have a Mac, want to get a sneak peak, and help us identify this issue, please email me off list. Thanks, Bob ________________________________________________________________________________
Date: Sep 14, 2009
Drilled #40 holes in the arm about 2" from the bolt. Just did it this past weekend. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263063#263063 ________________________________________________________________________________
Subject: Re: Planning Questions
Date: Sep 14, 2009
Here are a couple photos to show what I said earlier. The blue tubing is for oxygen. Bulkhead fittings are used for plug-in points. The bottle sits on the baggage compartment floor and connects with its own bulkhead fitting. The bottle is portable for ease of filling and for use in the 6. Separate your wires to minimize interference and run them where ever you need to. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263081#263081 Attachments: http://forums.matronics.com//files/010_2_reduced_409.jpg http://forums.matronics.com//files/001reduced_290.jpg ________________________________________________________________________________
Subject: New Service bulletin for GNS 480(CNX80)
Date: Sep 14, 2009
I got this email from Garmin today and I thought I would pass it along. Sheldon Olesen N475PV 108 hrs ________________________________________________________________________________
Subject: Re: Infinity grip wiring.
Date: Sep 14, 2009
I used a D-sub connector. This area tends to collect dirt with time so if you use the terminal strip then consider covering it in some way. Connectors are less susceptible to environmental contamination. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263083#263083 ________________________________________________________________________________
Date: Sep 14, 2009
I forgot to mention one item that made my wiring much neater and easier to manage. That product is "Click Bond" - the small zip tie attach points are an awesome product. I spent about $100 on the very pricy attach points - worth every cent. If they are good enough for Boeing and Northrop - they are good enuf for me. -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263095#263095 Attachments: http://forums.matronics.com//files/p7052343_484.jpg ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Sep 15, 2009
I did something similar. The stock adhesive backing is notorious for letting go over time on zip tie pads so I pulled the backing off of regular hardware store pads and used Goop to secure them instead. As long as both surfaces are clean, I wouldn't expect them to come off very easily. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Monday, September 14, 2009 11:24 PM Subject: RV10-List: Re: Planning Questions I forgot to mention one item that made my wiring much neater and easier to manage. That product is "Click Bond" - the small zip tie attach points are an awesome product. I spent about $100 on the very pricy attach points - worth every cent. If they are good enough for Boeing and Northrop - they are good enuf for me. -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263095#263095 Attachments: http://forums.matronics.com//files/p7052343_484.jpg ________________________________________________________________________________
Subject: Re: Do you have a Mac?
Date: Sep 15, 2009
I'm a mac guy, i'd be happy to check out the issue, Safari and firefox. On Sep 14, 2009, at 19:57, "Bob Leffler" wrote: > I need to find a couple folks to test a new RV-10 related site. We > =99ve come across an issue and need to validate whether or not it=99s > a common Mac issue or localized to one user. If you have a Mac, w > ant to get a sneak peak, and help us identify this issue, please ema > il me off list. > > > Thanks, > > > Bob > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 4425 (20090914) __________ > > The message was checked by ESET NOD32 Antivirus. > > ________________________________________________________________________________
Date: Sep 15, 2009
Scuff the area where the click bond is to be placed. Clean with acetone (both surfaces) Epoxy in place. Never off. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Tuesday, September 15, 2009 5:39 AM Subject: RE: RV10-List: Re: Planning Questions --> I did something similar. The stock adhesive backing is notorious for letting go over time on zip tie pads so I pulled the backing off of regular hardware store pads and used Goop to secure them instead. As long as both surfaces are clean, I wouldn't expect them to come off very easily. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Monday, September 14, 2009 11:24 PM Subject: RV10-List: Re: Planning Questions I forgot to mention one item that made my wiring much neater and easier to manage. That product is "Click Bond" - the small zip tie attach points are an awesome product. I spent about $100 on the very pricy attach points - worth every cent. If they are good enough for Boeing and Northrop - they are good enuf for me. -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263095#263095 Attachments: http://forums.matronics.com//files/p7052343_484.jpg ________________________________________________________________________________
Subject: Re: LOP (Lean of Peak) Injector Tuning
Date: Sep 15, 2009
which James cowl? The regular one or the one for cold air induction? they're slightly different.. just helped my buddy go through the hoops of getting the injectors tuned, and results seem to be good.. this is on a -10 /w James cowl + BPE cold air engine.. (2 mags... for now) -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263230#263230 ________________________________________________________________________________
Date: Sep 15, 2009
Phil, These holes are too big to enlarge and in an awkward location. Use what is there: get a good fitting rubber grommet to protect the wires then start filling them up. If you run out of space, drill another hole. Don't sweat it at this point. Everyone's distribution will be somewhat different so don't try to copy exactly. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263244#263244 ________________________________________________________________________________
Date: Sep 15, 2009
Phil, I asked Van's about enlarging the side holes, and they said up to 1" would be OK. I used a Greenlee punch from the electrical dept. of Home Depot. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263256#263256 ________________________________________________________________________________
Date: Sep 16, 2009
I thought I responded to this already, but I guess not. I'm a Mac guy all the way back to the 128k back in 1984. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263412#263412 ________________________________________________________________________________
Date: Sep 16, 2009
From: bruce breckenridge <bbreckenridge(at)gmail.com>
I started with a Mac Plus in 1985/6. I always wanted to turn it into an aquarium, but the $120 I spent on 4meg of RAM kept me from tearing the guts out. Finally sold it for $35. MS Flight Simulator 1.0 kept me entertained when not doing school work! Bruce Breckenridge Wings in Limbo On Wed, Sep 16, 2009 at 3:22 PM, johngoodman wrote: > > I thought I responded to this already, but I guess not. I'm a Mac guy all > the way back to the 128k back in 1984. > John > > -------- > #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & > Panel delivery soon. > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263412#263412 > > ________________________________________________________________________________
Subject: clone Chelton
Date: Sep 17, 2009
Hi Tim Cloned the card but no joy - any suggestions. The IDU works fine with the other card. What's the best / most foolproof way to clone it? Neil ________________________________________________________________________________
Subject: Re: clone Chelton
Date: Sep 17, 2009
I used norton ghost....if you can find someone with the PCMCIA to IDE adapters. On Sep 17, 2009, at 2:48 AM, Neil & Sarah Colliver wrote: > > > > Hi Tim > > Cloned the card but no joy - any suggestions. The IDU works fine > with the other card. What's the best / most foolproof way to clone it? > > Neil > > ________________________________________________________________________________
Date: Sep 17, 2009
For the wintel world, DriveImage XML is a good free alternative to the Symantec products. http://www.runtime.org/driveimage-xml.htm Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 17, 2009 4:32 AM Subject: Re: RV10-List: clone Chelton I used norton ghost....if you can find someone with the PCMCIA to IDE adapters. On Sep 17, 2009, at 2:48 AM, Neil & Sarah Colliver wrote: > > > > Hi Tim > > Cloned the card but no joy - any suggestions. The IDU works fine > with the other card. What's the best / most foolproof way to clone it? > > Neil > > ________________________________________________________________________________
Subject: Andair Valves
Date: Sep 17, 2009
There's a discussion on VAF about the Andair fuel valves and it raised a question on my part. First, I didn't realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port. What model number and configurations did you use? I'd like to get mine on order and get it put on the shelf. Also, what's the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I'd like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil ________________________________________________________________________________
Date: Sep 17, 2009
speckter(at)comcast.net wrote: > I have the standard inlets, but based on this list and Alan Barrett's > recommendation I put a small air dam in front of the front injector. > Raining down here this week so have not flown. Will keep you posted. > > Gary Specketer > > -- Gary, Any chance of you posting a picture or sending me one. Plane gets out of the paint shop this weekend if WX cooperates and balancing is one of the items on my to-do list. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263496#263496 ________________________________________________________________________________
Date: Sep 17, 2009
Phil, You already got several answers on VAF. Do a quick search and you'll find more of the same here. FS20x7 w/ extender is what is needed for the RV-10. No, you don't want a duplex. That is for returning fuel to both tanks, which is not required nor recommended on the IO-540. Don at Airflow recommends running the purge line to a tee under the right seat just before the fuel valve. This is used for hot starts. Just set the valve to the left tank and hot fuel goes back to the right tank. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Thursday, September 17, 2009 8:24 AM Subject: RV10-List: Andair Valves There's a discussion on VAF about the Andair fuel valves and it raised a question on my part. First, I didn't realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port. What model number and configurations did you use? I'd like to get mine on order and get it put on the shelf. Also, what's the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I'd like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil ________________________________________________________________________________
Date: Sep 17, 2009
Subject: Re: Andair Valves
Phil, Your guess about the duplex valve is correct - dedicated return lines to source tank. I had QB tanks on my 6A and put a fitting in the side forward of the fuel guage sender all the way in to the second bay. Wasn't a big deal at all. When I got my duplex valve, I didn't know about the gozillion configurations and would have ordered it with -4 fittings for the purge lines and plumbed it back to the tank that way - had I known. I got the one that has all(6) AN6 fittlngs - I don't have the part number - but like I said, I would have done one set of AN6 and one set of AN4 had I known. My FI is from AFP and the line from the servo to the purge valve, spider, and back to the valve is a -4. It converts to a -6 line right before the valve. Check your FI system - you might be able to simplify yours like I could have..... BTW, I oriented my valve such that it points to the left fuel guage when drawing from the left tank and points to the right fuel guage when drawing from the right tank. It was a PITB to put together - but real simple in flight. I attached a photo - during construction - hope it isn't stripped off. More pics if you want. Ralph -----Original Message----- >From: "Perry, Phil" <Phil.Perry(at)netapp.com> >Sent: Sep 17, 2009 8:23 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: Andair Valves > >There's a discussion on VAF about the Andair fuel valves and it raised a >question on my part. > > > >First, I didn't realize there were so many versions of a Andair fuel >valves. And you have to know which fittings you want on each port. > > > >What model number and configurations did you use? I'd like to get mine >on order and get it put on the shelf. > > > >Also, what's the difference between the regular Andair valve and the >duplex valve? My guess is that the duplex valve has a dedicated return >line to send fuel back to the originating tank. > > > >I'd like to return the fuel to the original tank, that sounds great. >Except I will be using QB wings with the fuel tanks already assembled >and sealed. Does this mean I am not a candidate for a duplex (return to >source) valve? > > > >Thanks > >Phil > > > > > > > > > ________________________________________________________________________________
Date: Sep 17, 2009
I installed the Andair duplex valve in my -10. I also have the QB wings. No t really a problem vis-a-vis the wings if you install any fittings BEFORE y ou install the float level valve. After that it's doable but harder. Subject: RV10-List: Andair Valves Date: Thu=2C 17 Sep 2009 05:23:35 -0700 From: Phil.Perry(at)netapp.com There=92s a discussion on VAF about the Andair fuel valves and it raised a question on my part. First=2C I didn=92t realize there were so many versions of a Andair fuel va lves. And you have to know which fittings you want on each port. What model number and configurations did you use? I=92d like to get mine o n order and get it put on the shelf. Also=2C what=92s the difference between the regular Andair valve and the d uplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I=92d like to return the fuel to the original tank=2C that sounds great. E xcept I will be using QB wings with the fuel tanks already assembled and se aled. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil _________________________________________________________________ Ready for Fall shows? Use Bing to find helpful ratings and reviews on digit al tv's. http://www.bing.com/shopping/search?q=digital+tv's&form=MSHNCB&publ=W LHMTAG&crea=TEXT_MSHNCB_Vertical_Shopping_DigitalTVs_1x1 ________________________________________________________________________________
Date: Sep 17, 2009
I would have definitely changed out the original valve that Vans wassending. Now they send a nicer valve that doesn't look like the one in my 1965 motor home. I won't be changing this one out since it has a detent and looks a lot better. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263505#263505 ________________________________________________________________________________
Date: Sep 17, 2009
Not sure I understand why folks want to do things the hard way. Precision injection...no return at all. AFP...return for purge only...minimal flow, just tee into tank line like Bob Leffler suggested. You do not actively return fuel to any tank when the engine is running, unlike Continental engines with TCM injection that return fuel all the time, so no need to worry which tank your purge returns to. Danny Riggs wrote: > I installed the Andair duplex valve in my -10. I also have the QB wings. > Not really a problem vis-a-vis the wings if you install any fittings > BEFORE you install the float level valve. After that it's doable but harder. > > ------------------------------------------------------------------------ > Subject: RV10-List: Andair Valves > Date: Thu, 17 Sep 2009 05:23:35 -0700 > From: Phil.Perry(at)netapp.com > To: rv10-list(at)matronics.com > > Theres a discussion on VAF about the Andair fuel valves and it raised a > question on my part. > > > > First, I didnt realize there were so many versions of a Andair fuel > valves. And you have to know which fittings you want on each port. > > > > What model number and configurations did you use? Id like to get mine > on order and get it put on the shelf. > > > > Also, whats the difference between the regular Andair valve and the > duplex valve? My guess is that the duplex valve has a dedicated return > line to send fuel back to the originating tank. > > > > Id like to return the fuel to the original tank, that sounds great. > Except I will be using QB wings with the fuel tanks already assembled > and sealed. Does this mean I am not a candidate for a duplex (return to > source) valve? > > > > Thanks > > Phil > > > > > > > > > > * > > ttp://www.matronics.com/Navigator?RV10-List > ronics.com > ww.matronics.com/contribution > > * > > > ------------------------------------------------------------------------ > Ready for Fall shows? Use Bing to find helpful ratings and reviews on > digital tv's. Click here. > <http://www.bing.com/shopping/search?q=digital+tv> > > * > > > * ________________________________________________________________________________
Date: Sep 17, 2009
I thought the exact same thing--that the new stock valve was much better than the older style. It was better. Mine lasted about 300 hours. I replaced it with an Andair, and I'm really glad I did. Night and day. We work on a lot of planes with a lot of different valves. The Andairs are bulletproof and worth what they charge. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Sep 17, 2009 at 7:07 AM, Strasnuts wrote: > > I would have definitely changed out the original valve that Vans > wassending. Now they send a nicer valve that doesn't look like the one in > my 1965 motor home. I won't be changing this one out since it has a detent > and looks a lot better. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263505#263505 > > ________________________________________________________________________________
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com>
Date: Sep 17, 2009
Kelly McMullen and Bob Leffler (and Don Rivera at Airflow Performance!) have it right. There is no need to use the Andair duplex valve. None. No benefit... just extra plumbing, fittings and complexity. I have the purge setup in my 7A plumbed through an Andair valve with a 1/4" line plumbed to a tee fitting in the left tank line (between the tank and the valve). When using the purge valve for a hot start, you put the fuel selector to the setting, firewall the throttle and mixture setting, pull the purge cable to open the purge valve (closing off fuel flow to the injectors) and engage the boost pump for 30 seconds. During this time, cool fuel is being pumped from the tank to the fuel servo, up to the spider (where the purge valve is located), through a fire sleeved return line to a steel bulkhead fitting at the firewall, where the 1/4" line runs back to that tee in the left fuel tank line and back into the left tank. 30 seconds of pumping cool fuel through that 1/4" line will only move about a cup of fuel, but that is sufficient to accomplish the purpose. After I count to 30, (with boost pump still engaged) push close the purge valve for a couple of seconds (your now putting fuel out to the injector lines) and pull open again. Reset the throttle and mixture to full rich mixture and 1/8" throttle, engage the starter and begin closing the purge valve and the engine is now running. Don't bother with a duplex valve, listen to Don, who builds the system. Bob Brown -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, September 17, 2009 7:32 AM Subject: Re: RV10-List: Andair Valves Not sure I understand why folks want to do things the hard way. Precision injection...no return at all. AFP...return for purge only...minimal flow, just tee into tank line like Bob Leffler suggested. You do not actively return fuel to any tank when the engine is running, unlike Continental engines with TCM injection that return fuel all the time, so no need to worry which tank your purge returns to. Danny Riggs wrote: > I installed the Andair duplex valve in my -10. I also have the QB wings. > Not really a problem vis-a-vis the wings if you install any fittings > BEFORE you install the float level valve. After that it's doable but harder. > > ------------------------------------------------------------------------ > Subject: RV10-List: Andair Valves > Date: Thu, 17 Sep 2009 05:23:35 -0700 > From: Phil.Perry(at)netapp.com > To: rv10-list(at)matronics.com > > There's a discussion on VAF about the Andair fuel valves and it raised a > question on my part. > > > > First, I didn't realize there were so many versions of a Andair fuel > valves. And you have to know which fittings you want on each port. > > > > What model number and configurations did you use? I'd like to get mine > on order and get it put on the shelf. > > > > Also, what's the difference between the regular Andair valve and the > duplex valve? My guess is that the duplex valve has a dedicated return > line to send fuel back to the originating tank. > > > > I'd like to return the fuel to the original tank, that sounds great. > Except I will be using QB wings with the fuel tanks already assembled > and sealed. Does this mean I am not a candidate for a duplex (return to > source) valve? > > > > Thanks > > Phil > > > > > > > > > > * > > ttp://www.matronics.com/Navigator?RV10-List > ronics.com > ww.matronics.com/contribution > > * > > > ------------------------------------------------------------------------ > Ready for Fall shows? Use Bing to find helpful ratings and reviews on > digital tv's. Click here. > <http://www.bing.com/shopping/search?q=digital+tv> > > * > > > * ________________________________________________________________________________
Date: Sep 17, 2009
When you install the Andair valves , don't forget to segment the tunnel cover for future access. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday, September 17, 2009 6:19 AM Subject: RE: RV10-List: Andair Valves I installed the Andair duplex valve in my -10. I also have the QB wings. Not really a problem vis-a-vis the wings if you install any fittings BEFORE you install the float level valve. After that it's doable but harder. _____ Subject: RV10-List: Andair Valves Date: Thu, 17 Sep 2009 05:23:35 -0700 From: Phil.Perry(at)netapp.com There's a discussion on VAF about the Andair fuel valves and it raised a question on my part. First, I didn't realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port. What model number and configurations did you use? I'd like to get mine on order and get it put on the shelf. Also, what's the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I'd like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil ttp://www.matronics.com/Navigator?RV10-List ronics.com ww.matronics.com/contribution _____ Ready for Fall shows? Use Bing to find helpful ratings and reviews on digital tv's. Click <http://www.bing.com/shopping/search?q=digital+tv> here. ________________________________________________________________________________
Date: Sep 17, 2009
David, Please elaborate... It appears to me with the remote extension, the remote selector comes off easily and isn't a problem with the tunnel cover. Thanks, bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Thursday, September 17, 2009 1:03 PM Subject: RE: RV10-List: Andair Valves When you install the Andair valves , don't forget to segment the tunnel cover for future access. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday, September 17, 2009 6:19 AM Subject: RE: RV10-List: Andair Valves I installed the Andair duplex valve in my -10. I also have the QB wings. Not really a problem vis-a-vis the wings if you install any fittings BEFORE you install the float level valve. After that it's doable but harder. _____ Subject: RV10-List: Andair Valves Date: Thu, 17 Sep 2009 05:23:35 -0700 From: Phil.Perry(at)netapp.com There's a discussion on VAF about the Andair fuel valves and it raised a question on my part. First, I didn't realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port. What model number and configurations did you use? I'd like to get mine on order and get it put on the shelf. Also, what's the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I'd like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil ttp://www.matronics.com/Navigator?RV10-List ronics.com ww.matronics.com/contribution _____ Ready for Fall shows? Use Bing to find helpful ratings and reviews on digital tv's. Click <http://www.bing.com/shopping/search?q=digital+tv> here. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Re: Info and Question on Van's FWF Kit (including hoses)
Date: Sep 17, 2009
I've seen mention of the MAP hose (VA-119) yet that is not part of the Van's list for the FWF kit. Have people been adding that to their lists? Thx Pascal -------------------------------------------------- From: "John Cumins" <jcumins(at)jcis.net> Sent: Thursday, September 10, 2009 10:48 AM Subject: RE: RV10-List: Info and Question on Van's FWF Kit (including hoses) > > You need to make sure that the SS hoses have the molded file sleeve as > part > of the hose when there made. It cost a bit more but very important in the > fwf area for all hoses that pass fluids thru then. I would also make the > MAP > hose SS just to make all hoses the same. This is what I did on our > Saratoga > and it was worth the cost. > > John G. Cumins > President > > JC'S Interactive Systems > 2499 B1 Martin Rd > Fairfield Ca 94533 > 707-425-7100 > 707-425-7576 Fax > > Your Total Technology Solution Provider > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder > (Michael Sausen) > Sent: Thursday, September 10, 2009 10:20 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Info and Question on Van's FWF Kit (including > hoses) > > > > While they may be SS covered Teflon, I'm betting that they are not fire > sleeved so take that into account when comparing aftermarkets with Van's. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of nukeflyboy > Sent: Thursday, September 10, 2009 11:45 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Info and Question on Van's FWF Kit (including hoses) > > > I have been reading the posts about engines hoses and wondering about what > to get and what to leave out in Van's FWF kit. Another RV-10 builder > recently got the kit and I noticed that the hoses looked like teflon > coated > stainless steel braid. I emailed Van's to find out and this is what they > sent me. Included is the current inventory of the kit. > > start of Van's note: > > 1) The Fuel and Oil lines in the RV-10 Firewall Forward kits > are teflon coated with stainless steel braid. > > > (2) The Vibration mount we sell are made in the USA by > "Vibration Isolation Products". > > > (3) I have the list of the RV-10 Firewall Forward kit below for > you. > > > Best Regards > Van's > > > FF-10 IO-540 F.WALL FWD.KIT IO-540 > > > 3.00 CT A-740 BLACK PUSH PULL CABLE BLACK > 2.00 DUCT CBT-5/8 COOLING BLAST TUBE > 2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP > 1.00 EA CV HOSE 7545 BREATHER HOSE -540 > 6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT > 4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY > 1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540 > 1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT > 1.00 FAB-360/540 FLTRD A/BOX-360 FI320 > 1.00 FF-1005 BREATHER TUBE > 1.00 IE VMP INSTALL KIT FITTINGS/HOSES > 1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING > 1.00 VA-102 FUEL PRES. HOSE 15.5 > 1.00 VA-133 OIL PRESS. HOSE 27.25 > 1.00 VA-135 OIL COOLER HOSE 16.5 > 1.00 VA-168 SENDER MOUNT > 1.00 VA-186 OIL COOLER BOX ASSY. > 1.00 VA-187 4" FLANGED DUCT > 1.00 VA-190 OIL COOLER HOSE 27" > 1.00 BAF-10-540 BAFFLE KIT IO-540 > 1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE > 1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!! > 1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG > 1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT > 1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE > 1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT > 1.00 BAG 516 RIVET AN426AD3-3.5 > 1.00 BAG 517 RIVET AN426AD3-4 > 1.00 BAG 518 RIVET AN426AD4-4 > 1.00 BAG 519 RIVET AN426AD4-5 > 1.00 BAG 520 MISC. AN BOLTS > 1.00 BAG 521 MISC. WASHERS > 1.00 BAG 522-1 MISC. FITTINGS/CLAMPS > 1.00 BAG 523-1 FITTINGS/MISC. > 1.00 BAG 524 MISC. CLAMPS > 1.00 BAG 525-1 MISC/BEARINGS > 1.00 BAG 526-1 CABIN HEAT SHUTTLE HW > 1.00 PT-062X1/4X24" HIGH PRESSURE > 1.00 CT BLK THROTTLE 47.5 10 (I(O)-540) > 1.00 CT BLUE VPROP 72.5 10 (I(O)-540)FWD GOV > 1.00 CT RED VMIXTURE 51.5 10 (I(O)-540) > 1.00 VA-182-PC KIT THR/MIX BKT IO VERT > 1.00 VA-189 FUEL LINE IO-540 25.5 > 1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD > 1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN > 1.00 VA-138 FUEL SUPPLY HOSE 14.0 > > end of Van's note > > First of all it is good to see that they have switched to teflon/SS hoses > for the fuel and oil lines. > > I am not familiar with the "Vibration Isolation Products" engine mount. > Is > anyone? It is a division of Pacific Molded Technologies in California. > Do > you recommend that I stick with Lord Mounts? > > So far it looks like I will stick with Van's hoses and just about > everything > else but will drop a couple items. I have another source for a Plane > Power > alternator so I will drop it. (They are good alternators and I recommend > that you use them.) I bought an AirFlow oil cooler from Alex and will > drop > it from the kit. I still need to make up my mind on the engine mounts and > throttle quadrant. > > Any other thoughts? > > -------- > Dave Moore > RV-6 flying > RV-10 QB - cabin top/fiberglass hell > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=262432#262432 > > > ________________________________________________________________________________
Date: Sep 17, 2009
When I received my kit, the tunnel cover was one piece. It is very unhandy for removal. We segmented the one piece into three. firewall to aft of fuel selector, then to back of seats , then to aft of flap motor. we also used CS screws with internal hex head on the center piece to be able remove without removing flap torque tube covers and front seats. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Thursday, September 17, 2009 11:33 AM Subject: RE: RV10-List: Andair Valves David, Please elaborate... It appears to me with the remote extension, the remote selector comes off easily and isn't a problem with the tunnel cover. Thanks, bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Thursday, September 17, 2009 1:03 PM Subject: RE: RV10-List: Andair Valves When you install the Andair valves , don't forget to segment the tunnel cover for future access. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday, September 17, 2009 6:19 AM Subject: RE: RV10-List: Andair Valves I installed the Andair duplex valve in my -10. I also have the QB wings. Not really a problem vis-a-vis the wings if you install any fittings BEFORE you install the float level valve. After that it's doable but harder. _____ Subject: RV10-List: Andair Valves Date: Thu, 17 Sep 2009 05:23:35 -0700 From: Phil.Perry(at)netapp.com There's a discussion on VAF about the Andair fuel valves and it raised a question on my part. First, I didn't realize there were so many versions of a Andair fuel valves. And you have to know which fittings you want on each port. What model number and configurations did you use? I'd like to get mine on order and get it put on the shelf. Also, what's the difference between the regular Andair valve and the duplex valve? My guess is that the duplex valve has a dedicated return line to send fuel back to the originating tank. I'd like to return the fuel to the original tank, that sounds great. Except I will be using QB wings with the fuel tanks already assembled and sealed. Does this mean I am not a candidate for a duplex (return to source) valve? Thanks Phil ttp://www.matronics.com/Navigator?RV10-List ronics.com ww.matronics.com/contribution _____ Ready for Fall shows? Use Bing to find helpful ratings and reviews on digital tv's. Click <http://www.bing.com/shopping/search?q=digital+tv> here. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 17, 2009
Dave, What part of the new Van's fuel valve broke after 300 hours? -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263575#263575 ________________________________________________________________________________
Date: Sep 17, 2009
I took it apart twice trying to figure out why it didn't feel crisp and smooth. After the first time, maybe 250 hours (guessing) I put it back together and it didn't feel any different. From that point it just kept getting tighter and less precise. I tried one more time. I never did find anything that looked wrong, but it sure didn't feel as nice as when it was new. I looked at buying a new one since I could buy many Vans valves for the cost of an Andair. But I eventually figured the effort would catch up to me, maybe the thing would fail at a bad time, and the tunnel was all apart so I just bit the bullet. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Sep 17, 2009 at 1:13 PM, Strasnuts wrote: > > Dave, What part of the new Van's fuel valve broke after 300 hours? > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263575#263575 > > ________________________________________________________________________________
Date: Sep 17, 2009
I don't like the sound of failing at a bad time. Thanks for the quick reply. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263583#263583 ________________________________________________________________________________
Subject: Screws in Canopy
Date: Sep 17, 2009
Hi I notice that there are a number of screws in the canopy doors as well as in the canopy itself. I am wondering what people are doing with respect to these screws prior to painting. Are they being glassed over or left as is? Inquiring minds need to know Les #40643 - Still in f/g hell ________________________________________________________________________________
Subject: Re: Seatbelt countersink
Date: Sep 17, 2009
HI I received the mythical, magical, wandering seatbelt countersink today. Does anyone need it? If so I will send it to you otherwise I will send it back to Lew (unless Lew wants me to hold onto it until someone else needs it). Cheers Les #40643 - still in f/g hell -----Original Message----- From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: August-19-09 9:06 AM Cc: 'Lew Gallagher' Subject: RE: RV10-List: Re: Seatbelt countersink Hi Tim Would you add me to the distribution list for the mythical, magical, wandering countersink. It is about time it made the trip north of the 49th! Cheers Les Kearney 5015 - 154 ST NW Edmonton, Alberta T6H 5P1 ________________________________________________________________________________
Subject: Re: Screws in Canopy
Date: Sep 17, 2009
Those of us from the Glastar world have about 100 screws to cover up in the glass work, a small patch of light weight fiberglass cloth over each screw is the way to make them go away with proper body work. -Bob Newman ----- Original Message ----- From: Les Kearney To: rv10-list(at)matronics.com Sent: Thursday, September 17, 2009 6:49 PM Subject: RV10-List: Screws in Canopy Hi I notice that there are a number of screws in the canopy doors as well as in the canopy itself. I am wondering what people are doing with respect to these screws prior to painting. Are they being glassed over or left as is? Inquiring minds need to know Les #40643 - Still in f/g hell ________________________________________________________________________________
Date: Sep 17, 2009
don't cover them unless you are sure that you will never have to remove them again. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob-tcw Sent: Thursday, September 17, 2009 4:47 PM Subject: Re: RV10-List: Screws in Canopy Those of us from the Glastar world have about 100 screws to cover up in the glass work, a small patch of light weight fiberglass cloth over each screw is the way to make them go away with proper body work. -Bob Newman ----- Original Message ----- From: Les Kearney <mailto:kearney(at)shaw.ca> Sent: Thursday, September 17, 2009 6:49 PM Subject: RV10-List: Screws in Canopy Hi I notice that there are a number of screws in the canopy doors as well as in the canopy itself. I am wondering what people are doing with respect to these screws prior to painting. Are they being glassed over or left as is? Inquiring minds need to know Les #40643 - Still in f/g hell href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Date: Sep 17, 2009
Les=2C Please add me to the list and next if that works: Mike Lefever 3235 S. Oleander Drive Chandler AZ 85248 thanks > From: kearney(at)shaw.ca > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Seatbelt countersink > Date: Thu=2C 17 Sep 2009 17:10:58 -0600 > > > HI > > I received the mythical=2C magical=2C wandering seatbelt countersink toda y. Does > anyone need it? If so I will send it to you otherwise I will send it back to > Lew (unless Lew wants me to hold onto it until someone else needs it). > > Cheers > > Les > #40643 - still in f/g hell > > -----Original Message----- > From: Les Kearney [mailto:kearney(at)shaw.ca] > Sent: August-19-09 9:06 AM > To: 'Dawson-Townsend=2CTimothy' > Cc: 'Lew Gallagher' > Subject: RE: RV10-List: Re: Seatbelt countersink > > Hi Tim > > Would you add me to the distribution list for the mythical=2C magical=2C > wandering countersink. It is about time it made the trip north of the 49t h! > > Cheers > > Les Kearney > 5015 - 154 ST NW > Edmonton=2C Alberta > T6H 5P1 > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Sep 18, 2009
Also David forgot to mention what he told me and I totally agree with....stainless countersink washers on all glass to metal fasteners points...spreads the load and stops the composite from cracking and spreads the load ... Rick Sked N246RS Sent via BlackBerry by AT&T -----Original Message----- From: "David McNeill" <dlm46007(at)cox.net> Date: Thu, 17 Sep 2009 17:40:08 Subject: RE: RV10-List: Screws in Canopy This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Sep 17, 2009
I'll second Davids suggestion. During the final phase you will have several reasons to reopen the tunnel. Segmenting it can make the process easier and allow for more direct access. This is PARTICULARLY true if you plan to install a center console on top of the tunnel, or some quadrant configurations. Deems Davis David McNeill wrote: > When I received my kit, the tunnel cover was one piece. It is very > unhandy for removal. We segmented the one piece into three. firewall > to aft of fuel selector, then to back of seats , then to aft of flap > motor. we also used CS screws with internal hex head on the center > piece to be able remove without removing flap torque tube covers and > front seats. > > ------------------------------------------------------------------------ > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler > *Sent:* Thursday, September 17, 2009 11:33 AM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Andair Valves > > David, > > Please elaborate > > It appears to me with the remote extension, the remote selector comes > off easily and isnt a problem with the tunnel cover. > > Thanks, > > bob > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *David McNeill > *Sent:* Thursday, September 17, 2009 1:03 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Andair Valves > > When you install the Andair valves , don't forget to segment the > tunnel cover for future access. > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Danny Riggs > *Sent:* Thursday, September 17, 2009 6:19 AM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Andair Valves > > I installed the Andair duplex valve in my -10. I also have the QB > wings. Not really a problem vis-a-vis the wings if you install any > fittings BEFORE you install the float level valve. After that it's > doable but harder. > > ------------------------------------------------------------------------ > > Subject: RV10-List: Andair Valves > Date: Thu, 17 Sep 2009 05:23:35 -0700 > From: Phil.Perry(at)netapp.com > To: rv10-list(at)matronics.com > > Theres a discussion on VAF about the Andair fuel valves and it raised > a question on my part. > > First, I didnt realize there were so many versions of a Andair fuel > valves. And you have to know which fittings you want on each port. > > What model number and configurations did you use? Id like to get mine > on order and get it put on the shelf. > > Also, whats the difference between the regular Andair valve and the > duplex valve? My guess is that the duplex valve has a dedicated return > line to send fuel back to the originating tank. > > Id like to return the fuel to the original tank, that sounds great. > Except I will be using QB wings with the fuel tanks already assembled > and sealed. Does this mean I am not a candidate for a duplex (return > to source) valve? > > Thanks > > Phil > > * * > * * > *ttp://www.matronics.com/Navigator?RV10-List* > *ronics.com* > *ww.matronics.com/contribution* > * * > > ------------------------------------------------------------------------ > > Ready for Fall shows? Use Bing to find helpful ratings and reviews on > digital tv's. Click here. > <http://www.bing.com/shopping/search?q=digital+tv> > > * * > * * > *href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List* > *href="http://forums.matronics.com">http://forums.matronics.com* > *href="http://www.matronics.com/contribution">http://www.matronics.com/c* > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * ________________________________________________________________________________
Subject: Rivet direction?
Date: Sep 17, 2009
Hello RV-10 builders, I have just started building. I pretty much jumped right in with both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder. I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which way to orient the rivets? It isn't really clear in the plans, I think they should probably all go the same direction so the side I countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it matter? I know for the trailing edges I should alternate direction to help keep things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD ________________________________________________________________________________
Date: Sep 17, 2009
Mike You are next on the list. It should be in the mail tomorrow. Cheers Les PS: Thanks Lew for making this happen. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roxanne and Mike Lefever Sent: September-17-09 7:12 PM Subject: RE: RV10-List: Re: Seatbelt countersink Les, Please add me to the list and next if that works: Mike Lefever 3235 S. Oleander Drive Chandler AZ 85248 thanks > From: kearney(at)shaw.ca > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Seatbelt countersink > Date: Thu, 17 Sep 2009 17:10:58 -0600 > > > HI > > I received the mythical, magical, wandering seatbelt countersink today. Does > anyone need it? If so I will send it to you otherwise I will send it back to > Lew (unless Lew wants me to hold onto it until someone else needs it). > > Cheers > > Les > #40643 - still in f/g hell > > -----Original Message----- > From: Les Kearney [mailto:kearney(at)shaw.ca] > Sent: August-19-09 9:06 AM > To: 'Dawson-Townsend,Timothy' > Cc: 'Lew Gallagher' > Subject: RE: RV10-List: Re: Seatbelt countersink > > Hi Tim > > Would you add me to the distribution list for the mythical, magical, > wandering countersink. It is about time it made the trip north of the 49th! > > Cheers > > Les Kearney > 5015 - 154 ST NW > Edmonton, Al > > > ________________________________________________________________________________
Subject: Re: Rivet direction?
Date: Sep 18, 2009
Sam, With 470 rivets you should try to place the head on the thicker material... Direction has a lot to do with access but if you look real close at the plans it shows direction...learn well here because later you're on your own.... Rick Sked N246RS, flyin Tech counselor to be Sent via BlackBerry by AT&T -----Original Message----- From: "Sam Clark" <helosammy(at)gmail.com> Date: Thu, 17 Sep 2009 21:51:26 Subject: RV10-List: Rivet direction? This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Sep 17, 2009
Hi Rick Do you have a source / part # for the stainless counter sunk washers? These Tinnerman washers are similar to ones used on my Cherokee f/g tail cone but they are not glassed in. See link http://www.airpartsinc.com/products/ss-tinnerman-c-s-washers.htm Are these what you are suggesting? Cheers Les ________________________________________________________________________________
Date: Sep 18, 2009
Spruce sells them in number 6, 8 and upper sizes...I bought larger ones for the seatbelts and main axel bolts on the pants....but if I recall Wicks. Sells them too...they really make a difference in wear and in appearance. I'm getting ready to paint my pants and fairings and plan to mold them into the glass...got the idea from Deems who helped a friend do the same.. Sent via BlackBerry by AT&T -----Original Message----- From: "Les Kearney" <kearney(at)shaw.ca> Date: Thu, 17 Sep 2009 20:18:57 Subject: RE: RV10-List: Screws in Canopy This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Sep 17, 2009
Aircraft spruce http://www.aircraftspruce.com/search/search.php?query=04-00398 <http://www.aircraftspruce.com/search/search.php?query=04-00398&search=1> &search=1 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Thursday, September 17, 2009 7:19 PM Subject: RE: RV10-List: Screws in Canopy Hi Rick Do you have a source / part # for the stainless counter sunk washers? These Tinnerman washers are similar to ones used on my Cherokee f/g tail cone but they are not glassed in. See link http://www.airpartsinc.com/products/ss-tinnerman-c-s-washers.htm Are these what you are suggesting? Cheers Les ________________________________________________________________________________
Date: Sep 17, 2009
Spruce has 2 different kinds... I use the stainless ones... page 96 of the 2008/09 catalog, part # 04-00397, 00392 and 00398.- If you want some of t he Tinnerman countersunk washers, I'll make someone a special deal on some. ...- the stainless ones are shinier. Don McDonald --- On Thu, 9/17/09, Les Kearney wrote: From: Les Kearney <kearney(at)shaw.ca> Subject: RE: RV10-List: Screws in Canopy Date: Thursday, September 17, 2009, 7:18 PM Hi Rick - Do you have a source / part # for the stainless counter sunk washers? -Th ese Tinnerman washers are similar to ones used on my Cherokee f/g tail cone but they are not glassed in. See link http://www.airpartsinc.com/products/ ss-tinnerman-c-s-washers.htm Are these what you are suggesting? - Cheers - Les =0A=0A=0A ________________________________________________________________________________
Date: Sep 17, 2009
Hi Rick For clarity, I take it you are referring to the shop (formed) head being on the thicker material. The "button" or factory head holds the thinner material. I only mention this because I remember getting confused about the terminology when I started building. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com Sent: September-17-09 8:05 PM Subject: Re: RV10-List: Rivet direction? Sam, With 470 rivets you should try to place the head on the thicker material... Direction has a lot to do with access but if you look real close at the plans it shows direction...learn well here because later you're on your own.... Rick Sked N246RS, flyin Tech counselor to be Sent via BlackBerry by AT&T _____ From: "Sam Clark" Date: Thu, 17 Sep 2009 21:51:26 -0400 Subject: RV10-List: Rivet direction? Hello RV-10 builders, I have just started building. I pretty = much jumped right in with both feet and it seems to be going well so far. I = have finished the vert stab and am getting ready to start riveting the = rudder. I started on the horizontal stab spars while waiting for a replacement = rudder stiffener and have come across a bit of a perplexing question, how do I = know which way to orient the rivets? It isn't really clear in the = plans, I think they should probably all go the same direction so the side I = countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it = matter? I know for the trailing edges I should alternate direction to help keep = things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD ________________________________________________________________________________
Date: Sep 17, 2009
Sam Here are a couple of things I did to get perfectly straight trailing edges on my rudder and elevators. Pix 44 shows how I ensured that the trailing edge wedge was glued securely to the rudder skin (step 1 page 7-9 of the plans). I reversed one wedge on top of the wedge to be glued - this gave a flat surface to cleco. To ensure the wedge was straight and flat, I then held both wedges in place with some scrap aluminum angle that was clecoed to every hole in the skin. Pix 39 shows it all clecoed from below). Pix 201 shows (end on) shows how I clecoed another piece of angle to the other side when it came time to glue the other side of the rudder on. The angle ensured that the rudder was glued perfectly straight without any bowing. Pix 199 shows an elevator trailing edge all clecoed while the glue was curing. After the glue cured, I back riveted the trailing edge as per the plans. In my case didn't bother alternating the rivets as the trailing edges were all glued straight. Cheers Les #40643 - Living in f/g hell ________________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sam Clark Sent: September-17-09 7:51 PM Subject: RV10-List: Rivet direction? Hello RV-10 builders, I have just started building. I pretty much jumped right in with both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder. I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which way to orient the rivets? It isn't really clear in the plans, I think they should probably all go the same direction so the side I countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it matter? I know for the trailing edges I should alternate direction to help keep things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD ________________________________________________________________________________
Date: Sep 17, 2009
I'm not sure you got your question answered. There are about 30-40 screws that bolt the cabin top to the fuselage. These will never come out again, assuming you followed the plans and epoxied the bugger in place. I am filling them in with micro-balloons. On the roof of the cabin top are 4 screws that bolt the window brace, 16 on the hinges, and 2 for the front seat harnesses. I will leave these alone, just in case. I use washers under countersunk screws in thin fiberglass (spinner, fairings, etc.) but see no need for them in the thick glass on the cabin top. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263643#263643 ________________________________________________________________________________
Date: Sep 17, 2009
Rick Did you embed these in the doors as well and then glass over them? Did you cover the screw heads? Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com Sent: September-17-09 8:44 PM Subject: Re: RV10-List: Screws in Canopy Spruce sells them in number 6, 8 and upper sizes...I bought larger ones for the seatbelts and main axel bolts on the pants....but if I recall Wicks. Sells them too...they really make a difference in wear and in appearance. I'm getting ready to paint my pants and fairings and plan to mold them into the glass...got the idea from Deems who helped a friend do the same.. Sent via BlackBerry by AT&T _____ From: "Les Kearney" Date: Thu, 17 Sep 2009 20:18:57 -0600 Subject: RE: RV10-List: Screws in Canopy ________________________________________________________________________________
Subject: Re: Glastar flyer/ RV10 builder
Date: Aug 23, 2009
David, I think John Jessen has a Glastar. John: n212pj(at)gmail.com Paul Grimstad rv10 450 ----- Original Message ----- From: David McNeill To: rv10-list(at)matronics.com Sent: Sunday, August 23, 2009 2:36 PM Subject: RV10-List: Glastar flyer/ RV10 builder IIRC there was an RV10 builder who was flying a Glastar for fun while building. If he will identify himself off list I will send pictures of the use of an RV10 nose fork on the Glastar to improve rough/soft field performance. Just completed the Glastar mod this morning to 15/600-5 main wheels and a 500-5 nose wheel. N46007 RV10 190TT N48007 Glastar 515TT ________________________________________________________________________________
Date: Sep 17, 2009
Thanks Dave The ones I am really interested are the 6 in the door that hold the guide blocks and the door mechanism. The screws in the door openings I plan to glass in as you suggest. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of nukeflyboy Sent: September-17-09 9:32 PM Subject: RV10-List: Re: Screws in Canopy I'm not sure you got your question answered. There are about 30-40 screws that bolt the cabin top to the fuselage. These will never come out again, assuming you followed the plans and epoxied the bugger in place. I am filling them in with micro-balloons. On the roof of the cabin top are 4 screws that bolt the window brace, 16 on the hinges, and 2 for the front seat harnesses. I will leave these alone, just in case. I use washers under countersunk screws in thin fiberglass (spinner, fairings, etc.) but see no need for them in the thick glass on the cabin top. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263643#263643 ________________________________________________________________________________
Date: Sep 18, 2009
There's a photo about 6 posts up. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263740#263740 ________________________________________________________________________________
Date: Sep 18, 2009
Subject: CB-1002-H Governor Bracket Installation Photos...?
Dear Listers, Van's turned me on to a bracket for the RV-10 called the CB-1002-H which is a bracket for mounting the governor control cable on front mounted governors. Does anyone have some good pictures of how this bracket is installed? Maybe even a scan of the baffling installation OP sheet where the RV-10 baffling is described? Since the IO-390 has a front mounted governor similar to the IO-540 used on the RV-10, some of these baffling pieces seem to work. Any docs you could provide would be most appreciated! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog Engine Baffling... ________________________________________________________________________________
Subject: Re: CB-1002-H Governor Bracket Installation Photos...?
Date: Sep 18, 2009
Matt, See if this helps. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263786#263786 Attachments: http://forums.matronics.com//files/baffle_346.jpg ________________________________________________________________________________
Date: Sep 18, 2009
Hope this helps...lower left of the photo. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, September 18, 2009 10:58 PM rv7-list(at)matronics.com Subject: RV10-List: CB-1002-H Governor Bracket Installation Photos...? Dear Listers, Van's turned me on to a bracket for the RV-10 called the CB-1002-H which is a bracket for mounting the governor control cable on front mounted governors. Does anyone have some good pictures of how this bracket is installed? Maybe even a scan of the baffling installation OP sheet where the RV-10 baffling is described? Since the IO-390 has a front mounted governor similar to the IO-540 used on the RV-10, some of these baffling pieces seem to work. Any docs you could provide would be most appreciated! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog Engine Baffling... ________________________________________________________________________________
Date: Sep 19, 2009
Dave, Now that I am ordering my Andair valve which an fittings work the best with the ten. Do the banjo fittings work well? -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263822#263822 ________________________________________________________________________________
Subject: Brake line exit holes
Date: Sep 19, 2009
I think I really screwed up this morning. 28-5 Step 4 "Enlarge the two pre-punched brake line pilot holes to 5/8 diameter" These are the holes where the brake lines exit the bottom skin at each landing gear mount. I drilled the hole in the skins out to 5/8" just as the plans indicated. While I was there (keep in mind this is a QB), I decided to install the brake line hardware too as described on 36-2. The AN fitting doesn't fit through the corresponding hole on the landing gear mount. After looking at the directions, it says (a second time) to enlarge the hole to 5/8". I can only assume they're talking about the corresponding hole in the landing gear, to make room for the AN fitting. So now I have a 5/8" hole in the bottom skin and in the landing gear mount. This is the point where shock set in. I'll bet I wasn't supposed to drill the landing gear mount to 5/8" and I'll bet the fitting is supposed to mount to the landing gear - and pass through the skin untouched. Now I have a really nice hole that my AN fitting will push right through. Not to mention a weak point near a very critical structural component that gets abused (the landing gear). I think I just bought myself a lot of work, a new right main gear mount, and a lot of stress. Someone tell me I didn't.... Phil ________________________________________________________________________________
Date: Sep 19, 2009
Subject: Re: Rivet direction? Important comment!!!!
Hey guys, can we follow the new guys lead (gosh, it's kind of nice NOT to b e the new guy anymore) and put our address and maybe a phone number on the bottom of each email.=C2- It sure would make it easier to contact each ot her for both direct questions/responses, and linking up on cross country fl ights.=C2- What do ya think? Don McDonald Lincoln CA=C2- LHM 916-801-8402 --- On Thu, 9/17/09, Sam Clark wrote: From: Sam Clark <helosammy(at)gmail.com> Subject: RV10-List: Rivet direction? Date: Thursday, September 17, 2009, 6:51 PM Hello RV-10 builders, =C2- I have just started building.=C2- I pretty much jumped right in wi th both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder.=C2- I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which w ay to orient the rivets?=C2- It isn=99t really clear in the plans, I think they should probably all go the same direction so the side I counte rsink gives a pretty good clue to the direction a flush rivet goes.=C2- A m I correct in thinking they all go the same direction or does it matter? =C2- I know for the trailing edges I should alternate direction to help k eep things straight.=C2- Any insight would help, thanks in advance. =C2- Sam Clark Lexington Park, MD =C2- =0A=0A=0A ________________________________________________________________________________
Subject: Re: Brake line exit holes
Date: Sep 19, 2009
Phil, Took a (crappy) picture of my brake line exit. The fitting mounts to the landing gear bracket and just goes through the skin. Hopefully someone has a good idea for a fix. It ain't fun to take the landing gear bracket out. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263829#263829 Attachments: http://forums.matronics.com//files/brake_exit_141.jpg ________________________________________________________________________________
Subject: Rivet direction? Important comment!!!!
Date: Sep 19, 2009
I usually contact offlist if I offer the telephone number; putting them out each time will provide a lot of unwanted calls from outside the list. If you doubt, just Google an RV10 topic and watch the RV10list emails pop up. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Saturday, September 19, 2009 8:58 AM Subject: Re: RV10-List: Rivet direction? Important comment!!!! Hey guys, can we follow the new guys lead (gosh, it's kind of nice NOT to be the new guy anymore) and put our address and maybe a phone number on the bottom of each email. It sure would make it easier to contact each other for both direct questions/responses, and linking up on cross country flights. What do ya think? Don McDonald Lincoln CA LHM 916-801-8402 --- On Thu, 9/17/09, Sam Clark wrote: From: Sam Clark <helosammy(at)gmail.com> Subject: RV10-List: Rivet direction? Date: Thursday, September 17, 2009, 6:51 PM Hello RV-10 builders, I have just started building. I pretty much jumped right in with both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder. I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which way to orient the rivets? It isn't really clear in the plans, I think they should probably all go the same direction so the side I countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it matter? I know for the trailing edges I should alternate direction to help keep things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 19, 2009
Don; I might suggest we use Tim Olson's builder (secure) site for this. Anything that we publish here remains in the public domain for a long time. The numbers (address and phone) are on his site already. If you don=99t have access (for builders and fliers only) contact Tim. Great idea however! Pascal From: Don McDonald Sent: Saturday, September 19, 2009 8:58 AM Subject: Re: RV10-List: Rivet direction? Important comment!!!! Hey guys, can we follow the new guys lead (gosh, it's kind of nice NOT to be the new guy anymore) and put our address and maybe a phone number on the bottom of each email. It sure would make it easier to contact each other for both direct questions/responses, and linking up on cross country flights. What do ya think? Don McDonald Lincoln CA LHM 916-801-8402 --- On Thu, 9/17/09, Sam Clark wrote: From: Sam Clark <helosammy(at)gmail.com> Subject: RV10-List: Rivet direction? To: rv10-list(at)matronics.com Date: Thursday, September 17, 2009, 6:51 PM Hello RV-10 builders, I have just started building. I pretty much jumped right in with both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder. I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which way to orient the rivets? It isn=99t really clear in the plans, I think they should probably all go the same direction so the side I countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it matter? I know for the trailing edges I should alternate direction to help keep things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 19, 2009
Since none of us have a perfect plane, I would not get too concerned. If it were me, I would take a thick aluminum plate - put the proper sized hole in the plate for the AN fitting - then epoxy the plate in place. At this point in the build - this kind of error will drive you crazy - a year from now it will be long forgotten. Also look at the silver lining to this screw up - you will be much more motivated to make nice soft landings after you are flying....... -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263835#263835 ________________________________________________________________________________
Date: Sep 19, 2009
No need for the very expensiver banjo fittings. Use the 90 degree Elbow fittings (AN-6,JIC-6) on the side and male AN-6 on the bottom outlet with a FS20x 7T valve. William http://wcurtis.nerv10.com/ On Sat, Sep 19, 2009 at 11:32 AM, Strasnuts wrote: > > Dave, > Now that I am ordering my Andair valve which an fittings work the best with > the ten. Do the banjo fittings work well? > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263822#263822 > > ________________________________________________________________________________
Date: Sep 19, 2009
Don, A better idea is to encourage everyone to register on Tim=99s site, where contact information is secure. I have no problem if any new RV-10 builder gives me a call looking to get questions answered, but I prefer to not post my unlisted phone number on a public forum. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Saturday, September 19, 2009 11:58 AM Subject: Re: RV10-List: Rivet direction? Important comment!!!! Hey guys, can we follow the new guys lead (gosh, it's kind of nice NOT to be the new guy anymore) and put our address and maybe a phone number on the bottom of each email. It sure would make it easier to contact each other for both direct questions/responses, and linking up on cross country flights. What do ya think? Don McDonald Lincoln CA LHM 916-801-8402 --- On Thu, 9/17/09, Sam Clark wrote: From: Sam Clark <helosammy(at)gmail.com> Subject: RV10-List: Rivet direction? Date: Thursday, September 17, 2009, 6:51 PM Hello RV-10 builders, I have just started building. I pretty much jumped right in with both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder. I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which way to orient the rivets? It isn=99t really clear in the plans, I think they should probably all go the same direction so the side I countersink gives a pretty good clue to the direction a flush rivet goes. Am I correct in thinking they all go the same direction or does it matter? I know for the trailing edges I should alternate direction to help keep things straight. Any insight would help, thanks in advance. Sam Clark Lexington Park, MD get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List =nofollow>http://forums.matronics.com blank rel=nofollow>http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 19, 2009
Subject: Re: Andair Valves
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Other builders might have more to say here. I didn't use the banjos, just AN hardware in the threaded ports. I ended up moving my valve forward from the the stock position about 6 inches so none of my mounting details would apply to a standard build. I moved it so I wouldn't have to take out a bunch of the existing plumbing--I just extended what was there from the stock valve. Now that it's forward a little, almost directly under the quadrant, I like the placement because it gives a little more room. But, it doesn't fall quite as easily to hand, which was nice about the stock position. There's been a lot of discussion on the valve install. Some are using hoses instead of the long, complex tubes. I'd consider that too, which would make the fitting selection easier. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sat, Sep 19, 2009 at 8:32 AM, Strasnuts wrote: > > Dave, > Now that I am ordering my Andair valve which an fittings work the best with > the ten. Do the banjo fittings work well? > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263822#263822 > > ________________________________________________________________________________
Date: Sep 19, 2009
Beautiful bracketry. John Cox -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Brian Sent: Friday, September 18, 2009 9:24 PM Subject: RE: RV10-List: CB-1002-H Governor Bracket Installation Photos...? Hope this helps...lower left of the photo. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Friday, September 18, 2009 10:58 PM rv8-list(at)matronics.com; rv7-list(at)matronics.com Subject: RV10-List: CB-1002-H Governor Bracket Installation Photos...? Dear Listers, Van's turned me on to a bracket for the RV-10 called the CB-1002-H which is a bracket for mounting the governor control cable on front mounted governors. Does anyone have some good pictures of how this bracket is installed? Maybe even a scan of the baffling installation OP sheet where the RV-10 baffling is described? Since the IO-390 has a front mounted governor similar to the IO-540 used on the RV-10, some of these baffling pieces seem to work. Any docs you could provide would be most appreciated! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog Engine Baffling... ________________________________________________________________________________
Date: Sep 19, 2009
Hi If you have enlarged a hole in the gear mount, you can avoid having to get a new one by getting a welding shop to fill in the hole. You can then redrill to the correct size. Cheers Les #40643 -living in f/g hell _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: September-19-09 9:27 AM Subject: RV10-List: Brake line exit holes I think I really screwed up this morning. 28-5 Step 4 "Enlarge the two pre-punched brake line pilot holes to 5/8 diameter" These are the holes where the brake lines exit the bottom skin at each landing gear mount. I drilled the hole in the skins out to 5/8" just as the plans indicated. While I was there (keep in mind this is a QB), I decided to install the brake line hardware too as described on 36-2. The AN fitting doesn't fit through the corresponding hole on the landing gear mount. After looking at the directions, it says (a second time) to enlarge the hole to 5/8". I can only assume they're talking about the corresponding hole in the landing gear, to make room for the AN fitting. So now I have a 5/8" hole in the bottom skin and in the landing gear mount. This is the point where shock set in. I'll bet I wasn't supposed to drill the landing gear mount to 5/8" and I'll bet the fitting is supposed to mount to the landing gear - and pass through the skin untouched. Now I have a really nice hole that my AN fitting will push right through. Not to mention a weak point near a very critical structural component that gets abused (the landing gear). I think I just bought myself a lot of work, a new right main gear mount, and a lot of stress. Someone tell me I didn't.. Phil ________________________________________________________________________________
Date: Sep 19, 2009
U29ycnkgYWJvdXQgZ29pbmcgZGFyayBmb3IgYSBmZXcgaG91cnMuIEkgcmVhbGl6ZSBhIGZldyBv ZiB5b3UgcmVwbGllZC4gDQpUaGUgaW50ZXJuZXQgY29ubmVjdGlvbiB3ZW50IGRvd24gYXMgc29v biBhcyBJIHNlbnQgdGhlIGZpcnN0IG1lc3NhZ2UgYW5kIGl0IHN0aWxsIGhhc24ndCByZXR1cm5l ZC4gDQoNCkJ1dCBteSBibGFja2JlcnJ5IGlzIHdvcmtpbmcgYXQgbGVhc3QuIE9uY2UgdGhlIGNv bm5lY3Rpb24gY29tZXMgYmFjaywgSSdsbCBzb3J0IHRocm91Z2ggdGhlIHJlcGxpZXMuIA0KDQpQ aGlsDQoNCg0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpGcm9tOiBQZXJy eSwgUGhpbCANClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSA8cnYxMC1saXN0QG1hdHJvbmlj cy5jb20+IA0KU2VudDogU2F0IFNlcCAxOSAwODoxMzoxMCAyMDA5DQpTdWJqZWN0OiBCcmFrZSBs aW5lIGV4aXQgaG9sZXMgDQoNCg0KDQpJIHRoaW5rIEkgcmVhbGx5IHNjcmV3ZWQgdXAgdGhpcyBt b3JuaW5nLg0KDQogDQoNCjI4LTUgU3RlcCA0DQoNCiANCg0KIkVubGFyZ2UgdGhlIHR3byBwcmUt cHVuY2hlZCBicmFrZSBsaW5lIHBpbG90IGhvbGVzIHRvIDUvOCBkaWFtZXRlciINCg0KIA0KDQpU aGVzZSBhcmUgdGhlIGhvbGVzIHdoZXJlIHRoZSBicmFrZSBsaW5lcyBleGl0IHRoZSBib3R0b20g c2tpbiBhdCBlYWNoIGxhbmRpbmcgZ2VhciBtb3VudC4NCg0KIA0KDQpJIGRyaWxsZWQgdGhlIGhv bGUgaW4gdGhlIHNraW5zIG91dCB0byA1LzgiIGp1c3QgYXMgdGhlIHBsYW5zIGluZGljYXRlZC4g IFdoaWxlIEkgd2FzIHRoZXJlIChrZWVwIGluIG1pbmQgdGhpcyBpcyBhIFFCKSwgSSBkZWNpZGVk IHRvIGluc3RhbGwgdGhlIGJyYWtlIGxpbmUgaGFyZHdhcmUgdG9vIGFzIGRlc2NyaWJlZCBvbiAz Ni0yLiAgVGhlIEFOIGZpdHRpbmcgZG9lc27igJl0IGZpdCB0aHJvdWdoIHRoZSBjb3JyZXNwb25k aW5nIGhvbGUgb24gdGhlIGxhbmRpbmcgZ2VhciBtb3VudC4NCg0KIA0KDQpBZnRlciBsb29raW5n IGF0IHRoZSBkaXJlY3Rpb25zLCBpdCBzYXlzIChhIHNlY29uZCB0aW1lKSB0byBlbmxhcmdlIHRo ZSBob2xlIHRvIDUvOOKAnS4gICBJIGNhbiBvbmx5IGFzc3VtZSB0aGV54oCZcmUgdGFsa2luZyBh Ym91dCB0aGUgY29ycmVzcG9uZGluZyBob2xlIGluIHRoZSBsYW5kaW5nIGdlYXIsIHRvIG1ha2Ug cm9vbSBmb3IgdGhlIEFOIGZpdHRpbmcuDQoNCiANCg0KU28gbm93IEkgaGF2ZSBhIDUvOOKAnSBo b2xlIGluIHRoZSBib3R0b20gc2tpbiBhbmQgaW4gdGhlIGxhbmRpbmcgZ2VhciBtb3VudC4gDQoN CiANCg0KVGhpcyBpcyB0aGUgcG9pbnQgd2hlcmUgc2hvY2sgc2V0IGluLiAgSeKAmWxsIGJldCBJ IHdhc27igJl0IHN1cHBvc2VkIHRvIGRyaWxsIHRoZSBsYW5kaW5nIGdlYXIgbW91bnQgdG8gNS84 4oCdIGFuZCBJ4oCZbGwgYmV0IHRoZSBmaXR0aW5nIGlzIHN1cHBvc2VkIHRvIG1vdW50IHRvIHRo ZSBsYW5kaW5nIGdlYXIg4oCTIGFuZCBwYXNzIHRocm91Z2ggdGhlIHNraW4gdW50b3VjaGVkLg0K DQogDQoNCk5vdyBJIGhhdmUgYSByZWFsbHkgbmljZSBob2xlIHRoYXQgbXkgQU4gZml0dGluZyB3 aWxsIHB1c2ggcmlnaHQgdGhyb3VnaC4gICAgTm90IHRvIG1lbnRpb24gYSB3ZWFrIHBvaW50IG5l YXIgYSB2ZXJ5IGNyaXRpY2FsIHN0cnVjdHVyYWwgY29tcG9uZW50IHRoYXQgZ2V0cyBhYnVzZWQg KHRoZSBsYW5kaW5nIGdlYXIpLg0KDQogDQoNCkkgdGhpbmsgSSBqdXN0IGJvdWdodCBteXNlbGYg YSBsb3Qgb2Ygd29yaywgYSBuZXcgcmlnaHQgbWFpbiBnZWFyIG1vdW50LCBhbmQgYSBsb3Qgb2Yg c3RyZXNzLg0KDQogDQoNClNvbWVvbmUgdGVsbCBtZSBJIGRpZG7igJl04oCmLg0KDQogDQoNClBo aWwNCg0KIA0KDQogDQoNCg= ________________________________________________________________________________
Date: Sep 19, 2009
Thanks again Dave, I can get mine on order now. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263856#263856 ________________________________________________________________________________
Date: Sep 19, 2009
Ok, no telephone numbers.... but boy would it be nice if we new where everybody was from. Don Lincoln, CA LHM -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263864#263864 ________________________________________________________________________________
Subject: Re: GPS Antenna Placement
Date: Sep 19, 2009
Guys... I've mounted my GPS antenna on top of the cabin with the small ovhd console from Dave Saylor hiding the wiring. This is a TNC connector. The cabin top is about an inch and half thick here. Question is what connector. I've ordered a right angle TNC connector from Stein but it's too short and won't fit through to the antenna. I've searched around on the web looking for a right angle connector with a longer leg but haven't stumbled across one. Then it just hit me that a maybe straight TNC connector would be perfect since I believe I have enough room for the RG400 to bend. Or a straight extension would probably work but it'd be another joint in the mix. SO... those who've mounted the gps antenna on the top of the console, what have you used for connector and where'd you get it if it is a right angle connector. Thanks, Doug Glued the windows in this morning while it was cool. Windscreen maybe in the morning before church.... getting there. -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263867#263867 ________________________________________________________________________________
Date: Sep 19, 2009
I think the info is in Tim's site for builders with a builder number. It would be nice if Tim's site could be sorted alphabetically as finding someone there, one has to know the kits status to find the particular builder. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Saturday, September 19, 2009 2:24 PM Subject: RV10-List: Re: Rivet direction? Important comment!!!! --> Ok, no telephone numbers.... but boy would it be nice if we new where everybody was from. Don Lincoln, CA LHM -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263864#263864 ________________________________________________________________________________
Date: Sep 19, 2009
I opened up the hole to make room for the right angle and then goudges out about 1/4" of the foan and filled it with flox. Here's a picture: http://deemsrv10.com/album/Final%20Assembly/slides/DSC07129.html Deems Davis www.deemsrv10.com N519PJ n277dl wrote: > > Guys... > I've mounted my GPS antenna on top of the cabin with the small ovhd console from Dave Saylor hiding the wiring. This is a TNC connector. The cabin top is about an inch and half thick here. > > Question is what connector. I've ordered a right angle TNC connector from Stein but it's too short and won't fit through to the antenna. I've searched around on the web looking for a right angle connector with a longer leg but haven't stumbled across one. > > Then it just hit me that a maybe straight TNC connector would be perfect since I believe I have enough room for the RG400 to bend. > > Or a straight extension would probably work but it'd be another joint in the mix. > > SO... those who've mounted the gps antenna on the top of the console, what have you used for connector and where'd you get it if it is a right angle connector. > > Thanks, > Doug > > Glued the windows in this morning while it was cool. Windscreen maybe in the morning before church.... getting there. > > -------- > Doug > "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263867#263867 > > > ________________________________________________________________________________
Date: Sep 19, 2009
I would agree that it would be nice to download the info in a xml or excel file periodically. However, ctrl-f works pretty good to find a specific builder or somebody in the same geographic area. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Saturday, September 19, 2009 5:59 PM Subject: RE: RV10-List: Re: Rivet direction? Important comment!!!! I think the info is in Tim's site for builders with a builder number. It would be nice if Tim's site could be sorted alphabetically as finding someone there, one has to know the kits status to find the particular builder. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of partner14 Sent: Saturday, September 19, 2009 2:24 PM Subject: RV10-List: Re: Rivet direction? Important comment!!!! --> Ok, no telephone numbers.... but boy would it be nice if we new where everybody was from. Don Lincoln, CA LHM -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263864#263864 ________________________________________________________________________________
Subject: Aerosport Prodducts
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Sep 19, 2009
Hey everyone I would like to announce a new website for RV-10 products. Some items on the website are not available yet but will be soon. I am in the final days of completing my RV-10 and we need to make sure everything is correct before we release them for purchase. The website is www.aerosportproducts.com I welcome your comments on the products as well as any suggestions you might have. Also I would like to Thank Bob Leffler for doing the site I feel he did a great job . Thanks Bob Geoff -------- Geoff Combs RV-10 QB N829GW Finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263890#263890 ________________________________________________________________________________
Date: Sep 19, 2009
I just used straight. Tim On Sep 19, 2009, at 4:59 PM, "n277dl" wrote: > > Guys... > I've mounted my GPS antenna on top of the cabin with the small > ovhd console from Dave Saylor hiding the wiring. This is a TNC > connector. The cabin top is about an inch and half thick here. > > Question is what connector. I've ordered a right angle TNC > connector from Stein but it's too short and won't fit through to the > antenna. I've searched around on the web looking for a right angle > connector with a longer leg but haven't stumbled across one. > > Then it just hit me that a maybe straight TNC connector would be > perfect since I believe I have enough room for the RG400 to bend. > > Or a straight extension would probably work but it'd be another > joint in the mix. > > SO... those who've mounted the gps antenna on the top of the > console, what have you used for connector and where'd you get it if > it is a right angle connector. > > Thanks, > Doug > > Glued the windows in this morning while it was cool. Windscreen > maybe in the morning before church.... getting there. > > -------- > Doug > "Fools" are always more creative than process people and > will always find ways to ruin a perfectly good set of processes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263867#263867 > > ________________________________________________________________________________
Subject: GPS antenna
Date: Sep 20, 2009
My RV8 has numerous antennas mounted under fairings, wingtips, cowling, etc. and everything works great with full signal strength on the GPS's. My plan is to build a small bracket that sticks forward of the baggage bulkhead and mount all the GPS antennas there. The shelf will be above the removable scalloped panels about 2 inches below the inside of the canopy, and will not impede the ability to easily remove the upper panel . The coax cables will 90 degree aft thru the bulkhead and the magic electrons will happily travel thru the canopy top into space. The antennas will be so far up that they are out of the way of baggage, and you won't even see them unless you tried. Someone could even put a cover over them if wanted. Now no ugly antennas on the cabin top and I can put all the gps/ nexrad/ etc stuff I want. OK, so what's the catch? What I miss? Chris Hukill still sanding doors and canopy need a snow shovel to clean up all the dust ________________________________________________________________________________
Subject: Riveting wing skin
Date: Sep 20, 2009
I'm close to riveting my first QB wing skin. Is the consensus of the brain trust that it is easier to do flat on a table or upright in a stand? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263994#263994 ________________________________________________________________________________
Date: Sep 20, 2009
I did mine upright in the wing stand. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Sunday, September 20, 2009 3:58 PM Subject: RV10-List: Riveting wing skin I'm close to riveting my first QB wing skin. Is the consensus of the brain trust that it is easier to do flat on a table or upright in a stand? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263994#263994 ________________________________________________________________________________
Date: Sep 20, 2009
Did mine flat on the table. Used two people. No problem. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Sunday, September 20, 2009 1:58 PM Subject: RV10-List: Riveting wing skin I'm close to riveting my first QB wing skin. Is the consensus of the brain trust that it is easier to do flat on a table or upright in a stand? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263994#263994 ________________________________________________________________________________
Date: Sep 20, 2009
I did my wing upright, singlehanded. =C2-Worked well -- Sent from my Palm Pr=C4=93 Bob Leffler wrote: I did mine upright in the wing stand. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Sunday, September 20, 2009 3:58 PM Subject: RV10-List: Riveting wing skin I'm close to riveting my first QB wing skin. Is the consensus of the brain trust that it is easier to do flat on a table or upright in a stand? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263994#263994 ________________________________________________________________________________
Date: Sep 20, 2009
Phil: We Phil's can hang together, as we make the same mistakes. Look at the photo attached, which shows how I put a small piece of .035 or .041 with the correct smaller hole in it, on top of the gear leg flange, put the fitting thru, and 'twas fixed. the slightly oversize hole in that flange won't cause a problem. Can't recall whether there is a washer on the underside or not, but the fitting is solidly attached to the plane now. Phil White #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264005#264005 Attachments: http://forums.matronics.com//files/brake_line_hole_patch_sml_198.jpg ________________________________________________________________________________
Date: Sep 20, 2009
Subject: Re: Riveting wing skin
good luck getting a consensus here.. everyone has what works for them and that is different for everyone. Try a way and see if it works well for you , if not, try another way. John On Sun, Sep 20, 2009 at 5:09 PM, Bill Watson wrote: > I did my wing upright, singlehanded. Worked well > > -- Sent from my Palm Pr=C4=93 > > ------------------------------ > Bob Leffler wrote: > > > I did mine upright in the wing stand. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa > Sent: Sunday, September 20, 2009 3:58 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Riveting wing skin > > > I'm close to riveting my first QB wing skin. > > Is the consensus of the brain trust that it is easier to do flat on a tab le > > or upright in a stand? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263994#263994 > > > ============ ============ ============ =========== > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Sep 21, 2009
T2ggdGhhdCdzIGhlbHBmdWwhISEgIkdvb2QgbHVjayIgV1RGISEgIEkgd2Fzbid0IGdvaW5nIHRv IHJlc3BvbmQsIGJ1dCBBLWhvbGUgY2hlY2sgaW50ZXJ2ZW50aW9uLiAgSSBkaWQgaXQgc29sbyBv biB0aGUgd2luZyBzdGFuZC4uLi53b3JrZWQgZ3JlYXQuLi4gVGFrZSB5b3VyIHRpbWUuLi4uLmZv ciB0aG9zZSBzdGlsbCBidWlsZGluZyB0aGlzIGlzIHN1cmUgZnVuIHRvIGZseS4uLmtlZXAgcG91 bmRpbmcuLi5hbmQgd2lyaW5nIGFuZCBwYWludGluZy4gRXRjLiwgZXRjLC4uLi4uDQoNClJpY2sg Uy4NCk4yNDZSUw0KRmx5aW5nDQpTZW50IHZpYSBCbGFja0JlcnJ5IGJ5IEFUJlQNCg0KLS0tLS1P cmlnaW5hbCBNZXNzYWdlLS0tLS0NCkZyb206IEpvaG4gVHJvbGxpbmdlciA8am9obkB0cm9sbGlu Z2Vycy5jb20+DQoNCkRhdGU6IFN1biwgMjAgU2VwIDIwMDkgMjA6MDc6MDMgDQpUbzogPHJ2MTAt bGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogUml2ZXRpbmcgd2lu ZyBza2luDQoNCg0KZ29vZCBsdWNrIGdldHRpbmcgYSBjb25zZW5zdXMgaGVyZS4uIGV2ZXJ5b25l IGhhcyB3aGF0IHdvcmtzIGZvciB0aGVtIGFuZA0KdGhhdCBpcyBkaWZmZXJlbnQgZm9yIGV2ZXJ5 b25lLiAgVHJ5IGEgd2F5IGFuZCBzZWUgaWYgaXQgd29ya3Mgd2VsbCBmb3IgeW91LA0KaWYgbm90 LCB0cnkgYW5vdGhlciB3YXkuDQoNCkpvaG4NCg0KT24gU3VuLCBTZXAgMjAsIDIwMDkgYXQgNTow OSBQTSwgQmlsbCBXYXRzb24gPG1hdWxlZHJpdmVyQG5jLnJyLmNvbT4gd3JvdGU6DQoNCj4gSSBk aWQgbXkgd2luZyB1cHJpZ2h0LCBzaW5nbGVoYW5kZWQuICBXb3JrZWQgd2VsbA0KPg0KPiAtLSBT ZW50IGZyb20gbXkgUGFsbSBQcsSTDQo+DQo+IC0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0t LQ0KPiBCb2IgTGVmZmxlciB3cm90ZToNCj4NCj4gLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3Rl ZCBieTogIkJvYiBMZWZmbGVyIiA8cnZAdGhlbGVmZmxlcnMuY29tPg0KPg0KPiBJIGRpZCBtaW5l IHVwcmlnaHQgaW4gdGhlIHdpbmcgc3RhbmQuDQo+DQo+IEJvYg0KPg0KPg0KPiAtLS0tLU9yaWdp bmFsIE1lc3NhZ2UtLS0tLQ0KPiBGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb20NCj4gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9u IEJlaGFsZiBPZiB3b3hvZnN3YQ0KPiBTZW50OiBTdW5kYXksIFNlcHRlbWJlciAyMCwgMjAwOSAz OjU4IFBNDQo+IFRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiBTdWJqZWN0OiBSVjEwLUxp c3Q6IFJpdmV0aW5nIHdpbmcgc2tpbg0KPg0KPiAtLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVk IGJ5OiAid294b2Zzd2EiIDx3b3hvZkBhb2wuY29tPg0KPg0KPiBJJ20gY2xvc2UgdG8gcml2ZXRp bmcgbXkgZmlyc3QgUUIgd2luZyBza2luLg0KPg0KPiBJcyB0aGUgY29uc2Vuc3VzIG9mIHRoZSBi cmFpbiB0cnVzdCB0aGF0IGl0IGlzIGVhc2llciB0byBkbyBmbGF0IG9uIGEgdGFibGUNCj4NCj4g b3IgdXByaWdodCBpbiBhIHN0YW5kPw0KPg0KPiBUaGFua3MgaW4gYWR2YW5jZS4NCj4NCj4gLS0t LS0tLS0NCj4gTXlyb24gTmVsc29uDQo+IE1lc2EsIEFaDQo+IEVtcCBjb21wbGV0ZWQsIGxlZ2Fj eSBidWlsZCBmdXNlIGluIHByb2dyZXNzDQo+DQo+DQo+DQo+DQo+IFJlYWQgdGhpcyB0b3BpYyBv bmxpbmUgaGVyZToNCj4NCj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5w aHA/cD0yNjM5OTQjMjYzOTk0DQo+DQo+DQo+DQo+DQo+DQo+DQo+DQo+DQo+ID09PT09PT09PT09 PSA9PT09PT09PT09PT0gPT09PT09PT09PT09ID09PT09PT09PT09PQ0KPg0KPg0KPg0KPiAqDQo+ DQo9PT09PT09PT09PT0NCj09PT09PT09PT09PQ0KPT09PT09PT09PT09DQo9PT09PT09PT09PT0N Cj4gKg0KPg0KPg0KDQo ________________________________________________________________________________
Date: Sep 20, 2009
jeez, Rick - could you tell me what primer I should use? On Sun, Sep 20, 2009 at 5:33 PM, wrote: > Oh that's helpful!!! "Good luck" WTF!! I wasn't going to respond, but > A-hole check intervention. I did it solo on the wing stand....worked > great... Take your time.....for those still building this is sure fun to > fly...keep pounding...and wiring and painting. Etc., etc,..... > > Rick S. > N246RS > Flying ________________________________________________________________________________
Date: Sep 20, 2009
Upright in wing cradle. One person. See Deem's site for pictures of how to hold skins with safety wire. Dave Leikam ----- Original Message ----- From: "woxofswa" <woxof(at)aol.com> Sent: Sunday, September 20, 2009 2:57 PM Subject: RV10-List: Riveting wing skin > > I'm close to riveting my first QB wing skin. > > Is the consensus of the brain trust that it is easier to do flat on a > table or upright in a stand? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=263994#263994 > > > ________________________________________________________________________________
Date: Sep 20, 2009
Subject: Painting The Baffling...
Dear Listers, I had been planning on black anodizing the various engine baffling pieces in keeping with my black-n-chrome theme under the hood. But I'm noticing that the pieces are getting pretty scratched up during all of this extra fitting that's necessary for the IO-390. Since the pieces can't be run through a surfacer first because of the bends, I'm rethinking how good anodizing is really going to look. I know we're not suppose to power coat the 2024-T3 because the curing heat required can un-T3 the 2024, but does it really matter for the baffling? Its not really structural, per say. And if power coating is alright, what effects will the engine compartment heat have on the power coating? There's probably a high-temp power coat, but it would likely require a higher curing temp, and that get's us back to the first sentence of this paragraph... Power coating the baffling would definitely look pretty cool. Has anyone ever chromed their baffling? That would look super cool. Can you chrome 2024-T3? How much would that cost compared to power coating? Am I fussing too much under the hood? ;-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com FWF Baffling, Intake, and Governor... ________________________________________________________________________________
Date: Sep 21, 2009
Lol....Kill...brushed on!!!! Sent via BlackBerry by AT&T -----Original Message----- From: Nate Lewis <nlewis(at)wildblue.net> Date: Sun, 20 Sep 2009 18:04:13 Subject: Re: RV10-List: Riveting wing skin jeez, Rick - could you tell me what primer I should use? On Sun, Sep 20, 2009 at 5:33 PM, wrote: > Oh that's helpful!!! "Good luck" WTF!! I wasn't going to respond, but > A-hole check intervention. I did it solo on the wing stand....worked > great... Take your time.....for those still building this is sure fun to > fly...keep pounding...and wiring and painting. Etc., etc,..... > > Rick S. > N246RS > Flying ________________________________________________________________________________
Date: Sep 21, 2009
I meant Kilz.....fwiw doing the bottom skins is not easy but saying the group is wishy washy and not worthy of having good feedback about how to do it is BS James McClow 40195...I think Sent via BlackBerry by AT&T -----Original Message----- From: Nate Lewis <nlewis(at)wildblue.net> Date: Sun, 20 Sep 2009 18:04:13 Subject: Re: RV10-List: Riveting wing skin jeez, Rick - could you tell me what primer I should use? On Sun, Sep 20, 2009 at 5:33 PM, wrote: > Oh that's helpful!!! "Good luck" WTF!! I wasn't going to respond, but > A-hole check intervention. I did it solo on the wing stand....worked > great... Take your time.....for those still building this is sure fun to > fly...keep pounding...and wiring and painting. Etc., etc,..... > > Rick S. > N246RS > Flying ________________________________________________________________________________
Date: Sep 20, 2009
Thanks for the input. I didn't realize that I had breached "Ginger vs Mary Ann territory. :) For some silly reason I thought there would be a clear cut logic based reason for one particular way. Maybe I'll do one one way and the other the other and give a detailed pro/con for the next schmuck down the line. On second thought, the safety wire in the stand sounds intriguing. That's it. I'm going to do it on the stand. (unless I do it on the table). -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264077#264077 ________________________________________________________________________________
Date: Sep 20, 2009
40191 but boy do I miss his Life Web Cam. John Cox From: ricksked(at)embarqmail.com Sent: Sun 9/20/2009 8:22 PM Subject: Re: RV10-List: Riveting wing skin I meant Kilz.....fwiw doing the bottom skins is not easy but saying the gro up is wishy washy and not worthy of having good feedback about how to do it is BS James McClow 40195...I think Sent via BlackBerry by AT&T From: Nate Lewis Date: Sun, 20 Sep 2009 18:04:13 -0700 Subject: Re: RV10-List: Riveting wing skin jeez, Rick - could you tell me what primer I should use? On Sun, Sep 20, 2009 at 5:33 PM, wrote: Oh that's helpful!!! "G= ood luck" WTF!! I wasn't going to respond, but A -hole check interv= ention. I did it solo on the wing stand....worked gre at... Take your time..= ...for those still building this is sure fun to f ly...keep pounding...and w= iring and painting. Etc., etc,..... Rick S. N246RS Flying =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =C2=C2=B7=BA~=B0=C3=AD=C2=B2,=C3=9E=C3=99=C3=8A%=C2=A2=C2=BD 4=C3=93M4}=C2=A7=1Er=B9=C2=AB=B0=C3=AA=C3=A7{=07(=C2=BA=C2=B8 =C5=BE=C2=AD8^E]t.+-=12f=C2=A2=9DZ+=C2=BAe,z=C3=98^1=C2=ABk=C2=A2x=C5 =93=C2=B0=C2=B8=C2=AC=C2=B4W=C5=A1=C2=B6=C3=AA=C3=9E=C2=B0=C3'=C2=AF=C5 -=06=C2=AD=C2=A2=C2=BBhn=C2=BA0=C2=B1=C3=ABazf=C2=A7=C3=88=C2=B8=C2=AC=C2 =B6=C3=ABb=93+bz=C3=8B.r=16=C2=AC.+-R=7F=C3=92=C2=B9=C2=BB=1C=C2=AE*m =C5-=B0=C3=C2=AD=C3=88b=C2=BD=C3=A4=C5=BEj=C2=B7!=0E=C5=92' =93-=C2=9D=C3=AC6=C2=B2=06=C2=BA0=C2=B1=C3-=C2=A1j=C3=91@@=C3 =B8h=C2=B6=B9!j=C2=B7=C5=A1=C2=9D=C3=99=C2=AEr=19=C2=AEr=19=C2=A8=C2 =AD=C3=C2=A1=C2=AD=C3=A7=C3=A1=C2=B6=C3=9A=7F=C3 0=84=A2=C2=ABk=C2 =A2x=C5=93=C2=B1=C3=8A&=C3=BC=C3'=C2=AF=C5-=06=C2=AD=C2=A2=C2=B4U=C3=97 B=C3=A2=C2=B2=C3=98m=C2=B6=C5=B8=C3=C3=83 &j=C3=9A=C3=A8=C5=BE',r =B0=C25=C2=AB=C3=A2=C2=81=C2=ABh=C2=AD=15u=C3=90=C2=B8=C2=AC=C2=B7=C3=B6 =C5=92=014N4=82=AC=99X@E9=15 I&=C2z =C3=9Ej=C3=97(=C5=BE=C3=97 =C2=A7=C2=B5=C2=A9l=C2=A1=C2=AB=C3=9A=C5-V=BA=A2=C3=AB=C3=A2j =C3=98^Y=C3=C3=85=C2=A2=C2=BB=C2=C2=B1=C2=A8ky=C3=B8m=C2=B6=C5=B8=C3 ~=C5-=C3=AE=C5=A1=C3=89=C5=A1=C2=B6=C2=BA'=B0=C3=8B=1C=C2=A2hm =C2=B6=C5=B8=C3~=C5-=C3=AE=C5=A1=C3=89=C5=A1=C2=B6=C2=BA'=B0=C3 =8B=1C=C2=A2o=C3=9A.+- =B0=C3=AD=C2=AE&=C3=AE=C2=B6*'Y=C3=C3=92=C5 -=C3=97=9C=C2=A9=C3=A4=C3=8A=B9=C5=B8=C2=A2=C2=BC=C2 =A8=C2=BA=C2=B8=1E=C2=9D=C3=AA=C3=A8=C2=BA=C3=8B.=C2=C5=A1+=C2=B4=C3=86 =C2=AD=C2=B4:=C3=9A=93W=B9=C5-=C3=8B@vh=C2=A7j=1A=C3=9E~=1Bm =C2=A7=C3=C3=B0=C3=83 =C5=A1=C2=B6=C2=BA'=B0=C3=8B=1C=C2=A2o=C3=9C =C2=A2{k=B0=C2=BB=C2=AD=C5-=B0=C3=A1=C2=B6=C3=9A=7F=C3 0 =84=A2=C2=ABk=C2=A2x=C5=93=C2=B1=C3=8A&=C3=BD=C3=8A'=C2=B6=C2=B8 =BA=C2=BA=C3=98=C2=A8=C5=B8=C3=B6=C2o=C3=B7=C3=A8=C5=BE=C3=9F=C3=A9=C2 =AD=C3=AF=C3=9B=C2=A1=C3=9C=C2-=C3=99=C2=A5 ________________________________________________________________________________
Subject: Re: Painting The Baffling...
Date: Sep 20, 2009
Matt, I can't answer your question about powder coating, but I have experience with painting and anodizing. I painted the baffles on my Pitts with Imron, and they still look good 25 years later. I had a local shop anodize the baffles on my -10 for $75. I did buff out the deepest scratches and tooling marks first with Scotchbrite. None of the marks showed through the anodize. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264080#264080 ________________________________________________________________________________
Date: Sep 21, 2009
I wouldn't worry about powder coating the baffling for reasons cited. I'm making modifications to my RV-4 baffling and am using 5052 cause I have some lying around and it sure is easier to form. I wouldn't anodize because, over-time you will have to take the stuff off a couple of times and it will get scratched. At least with paint or powder if you do scratch it you can touch it up easier than having to send the whole piece out for re-anodizing. That would get expensive with all the lot charges. Richard Bibb 972-771-2598 972-835-5979 mobile -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, September 20, 2009 10:02 PM rv10-list(at)matronics.com Subject: RV10-List: Painting The Baffling... Dear Listers, I had been planning on black anodizing the various engine baffling pieces in keeping with my black-n-chrome theme under the hood. But I'm noticing that the pieces are getting pretty scratched up during all of this extra fitting that's necessary for the IO-390. Since the pieces can't be run through a surfacer first because of the bends, I'm rethinking how good anodizing is really going to look. I know we're not suppose to power coat the 2024-T3 because the curing heat required can un-T3 the 2024, but does it really matter for the baffling? Its not really structural, per say. And if power coating is alright, what effects will the engine compartment heat have on the power coating? There's probably a high-temp power coat, but it would likely require a higher curing temp, and that get's us back to the first sentence of this paragraph... Power coating the baffling would definitely look pretty cool. Has anyone ever chromed their baffling? That would look super cool. Can you chrome 2024-T3? How much would that cost compared to power coating? Am I fussing too much under the hood? ;-) Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com FWF Baffling, Intake, and Governor... ________________________________________________________________________________
Date: Sep 21, 2009
I haven't riveted skins on a -10 wing yet but on my RV-4 I did one in the stand and one on a table. I preferred the table as gravity held the rivets in place before I got the gun on them and I avoided picking up all that fell on the floor. Also, there used to be a school of thought to slightly heat the skins before final riveting so that, as they cooled post riveting, they would be tighter. Not sure if that actually works but I did rivet one set of -4 wings horizontal on saw horses outside in the sun and they turned out nice. Had to be careful not to get burned as the skins sure got warm in a hurry. Since you are in Arizona you might not want to try that. Obviously it turns out to be a personal preference and at least no one has started a flame war on this one yet - skirmish perhaps but hardly classified as a minor engagement let alone full hostilities. Richard Bibb 972-771-2598 972-835-5979 mobile -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Sunday, September 20, 2009 2:58 PM Subject: RV10-List: Riveting wing skin I'm close to riveting my first QB wing skin. Is the consensus of the brain trust that it is easier to do flat on a table or upright in a stand? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=263994#263994 ________________________________________________________________________________
Date: Sep 21, 2009
Wow, did not mean to get you all riled up, I just was trying to let they gu y know that there is not one approach to doing this. I myself set it up righ t on the bench, but as you can see other people did it other ways. I was trying to let the builder know that it is ok to try out different technique s and find out which worked best for them. The one thing that is nice about this group is they all bring their unique way of solving a problem and give other builders options that they might not have thought of or tried. On Sun, Sep 20, 2009 at 8:33 PM, wrote: > Oh that's helpful!!! "Good luck" WTF!! I wasn't going to respond, but > A-hole check intervention. I did it solo on the wing stand....worked > great... Take your time.....for those still building this is sure fun to > fly...keep pounding...and wiring and painting. Etc., etc,..... > > Rick S. > N246RS > Flying > > Sent via BlackBerry by AT&T > > ------------------------------ > *From*: John Trollinger > *To*: > *Subject*: Re: RV10-List: Riveting wing skin > good luck getting a consensus here.. everyone has what works for them and > t= hat is different for everyone.=C2- Try a way and see if it wor ks well > for= you, if not, try another way. > > John > > On Sun, Sep 20, 2009 at 5:09 PM, Bill Watson wro > te: > > I did my wing upright, singlehanded. =C2-Worked well > > <= span> -- Sent from my Palm Pr=C4=93 > > ------------------------------ > Bob Leffler wrote: > > --> RV10-List me= ssage posted by: "Bob Leffler" > > I did mine upright in the wing stand. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa > Sent: Sunday, September 20, 2009 3:58 PM > To: rv10-l= ist(at)matronics.com > Subject: RV10-List: Riveting wing skin > > > I'm close to riveting my first QB wing skin. > > Is the consensus of the brain trust that it is easier to do flat on a t > able > or upright in a stand? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=3D263994#263= 994 > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > * get=3D"_blank">http://www.matronics.com/Navigator?RV10-List tp://fo rums.matronics.com _blank">http://www.matronics.com/contribution * > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D * > > ________________________________________________________________________________
Date: Sep 21, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Acutally, I thought I discerned a pattern - on the bench for 2 people and upright for 1. FWIW, I can't imagine how 1 person does it on the bench but I'm sure someone did. Another thanks to Deems for the safety wire pics. I forgot where I saw that but it worked like a charm. Like so many jobs, it's very satisfying once it's done. Note that you may need to file down the leading edge of the skin just a bit so that it clears the leading edge skins when it's riveted on. Bill woxofswa wrote: > > Thanks for the input. I didn't realize that I had breached "Ginger vs Mary Ann territory. :) > > For some silly reason I thought there would be a clear cut logic based reason for one particular way. Maybe I'll do one one way and the other the other and give a detailed pro/con for the next schmuck down the line. > > On second thought, the safety wire in the stand sounds intriguing. > > That's it. I'm going to do it on the stand. (unless I do it on the table). > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264077#264077 > > > ________________________________________________________________________________
Date: Sep 21, 2009
Actually I was able to do my RV-4 wings by myself on the bench. I have long arms and was able to reach from the rear spar to the front to buck the row of rivets where the skin attaches to the front spar. It wasn't really all that much of a stretch as I recall. I don't think the -10 wing will be all that different in that regard. Richard Bibb 972-771-2598 972-835-5979 mobile -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: Monday, September 21, 2009 7:22 AM Subject: Re: RV10-List: Re: Riveting wing skin Acutally, I thought I discerned a pattern - on the bench for 2 people and upright for 1. FWIW, I can't imagine how 1 person does it on the bench but I'm sure someone did. Another thanks to Deems for the safety wire pics. I forgot where I saw that but it worked like a charm. Like so many jobs, it's very satisfying once it's done. Note that you may need to file down the leading edge of the skin just a bit so that it clears the leading edge skins when it's riveted on. Bill woxofswa wrote: > > Thanks for the input. I didn't realize that I had breached "Ginger vs Mary Ann territory. :) > > For some silly reason I thought there would be a clear cut logic based reason for one particular way. Maybe I'll do one one way and the other the other and give a detailed pro/con for the next schmuck down the line. > > On second thought, the safety wire in the stand sounds intriguing. > > That's it. I'm going to do it on the stand. (unless I do it on the table). > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264077#264077 > > > ________________________________________________________________________________
Date: Sep 21, 2009
I wish someone would summarize the old primer wars arguments(reader's digest style, so to speak), just so that the newbies, and not so newbies could decide which way to go, without a need to relight the arguments, and whether those of us that didn't bother to research could decide whether we need to give up our corroding parts carcass and start over. ;-)) On Mon, Sep 21, 2009 at 12:29 AM, woxofswa wrote: > > Thanks for the input. I didn't realize that I had breached "Ginger vs Mary Ann territory. :) > > For some silly reason I thought there would be a clear cut logic based reason for one particular way. Maybe I'll do one one way and the other the other and give a detailed pro/con for the next schmuck down the line. > > On second thought, the safety wire in the stand sounds intriguing. > > That's it. I'm going to do it on the stand. (unless I do it on the table). > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264077#264077 > > ________________________________________________________________________________
Date: Sep 21, 2009
On 09/20/2009 11:02 PM, Matt Dralle wrote: > Has anyone ever chromed their baffling? That would look super cool. Can you chrome 2024-T3? How much would that cost compared to power coating? > > I've seen chrome colored baffling. I can't tell you if it was chromed, or just chrome colored paint, but it did indeed look super cool. :-) -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Sep 21, 2009
I don't have my documentation with me this morning and I can't seem to find Section 4 on Tim's site. Does anyone know if the main gear mounts are 4130? I think I've found an aircraft welder who can patch the hole for me, but I'd like to be certain of the material first. Thanks, Phil -----Original Message----- From: Phil White [mailto:philwhite9(at)aol.com] Sent: Sunday, September 20, 2009 4:20 PM Subject: RV10-List: Re: Brake line exit holes Phil: We Phil's can hang together, as we make the same mistakes. Look at the photo attached, which shows how I put a small piece of .035 or .041 with the correct smaller hole in it, on top of the gear leg flange, put the fitting thru, and 'twas fixed. the slightly oversize hole in that flange won't cause a problem. Can't recall whether there is a washer on the underside or not, but the fitting is solidly attached to the plane now. Phil White #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264005#264005 Attachments: http://forums.matronics.com//files/brake_line_hole_patch_sml_198.jpg ________________________________________________________________________________
Date: Sep 21, 2009
You can't chrome aluminum.... Richard Bibb 972-771-2598 972-835-5979 mobile -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Monday, September 21, 2009 9:09 AM Subject: Re: RV10-List: Painting The Baffling... On 09/20/2009 11:02 PM, Matt Dralle wrote: > Has anyone ever chromed their baffling? That would look super cool. Can you chrome 2024-T3? How much would that cost compared to power coating? > > I've seen chrome colored baffling. I can't tell you if it was chromed, or just chrome colored paint, but it did indeed look super cool. :-) -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Sep 21, 2009
Got the answer for those who are wondering. (Or for those who might search the archives later.) 1) Yes, it is 4130. 2) Unfortunately the mount has been heat treated. So touching the thing with a welder is not a good idea for fear of weakening the structure. 3) Van's doesn't believe there is a structural issue with the hole, but they're running it by engineering to check. 4) The proposed solution from Van's is to insert a bushing into the hole and then a large flat washer on top to hold it into position. Once we reach a resolution, I'll send the fix for the archives. Phil -----Original Message----- From: Perry, Phil Sent: Monday, September 21, 2009 9:27 AM Subject: RE: RV10-List: Re: Brake line exit holes I don't have my documentation with me this morning and I can't seem to find Section 4 on Tim's site. Does anyone know if the main gear mounts are 4130? I think I've found an aircraft welder who can patch the hole for me, but I'd like to be certain of the material first. Thanks, Phil -----Original Message----- From: Phil White [mailto:philwhite9(at)aol.com] Sent: Sunday, September 20, 2009 4:20 PM Subject: RV10-List: Re: Brake line exit holes Phil: We Phil's can hang together, as we make the same mistakes. Look at the photo attached, which shows how I put a small piece of .035 or .041 with the correct smaller hole in it, on top of the gear leg flange, put the fitting thru, and 'twas fixed. the slightly oversize hole in that flange won't cause a problem. Can't recall whether there is a washer on the underside or not, but the fitting is solidly attached to the plane now. Phil White #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264005#264005 Attachments: http://forums.matronics.com//files/brake_line_hole_patch_sml_198.jpg ________________________________________________________________________________
Date: Sep 21, 2009
I did it laid down horizontally; one person, short arms. Whatever works for you. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264183#264183 ________________________________________________________________________________
Date: Sep 21, 2009
I used a clear coat on my RV-6 baffles and 9 flying years later it does not look that good. It has yellowed somewhat and the baffles do move around a bit leaving rub marks. I don't know if paint holds up better but it sounds like it. I recall that it took a lot of persuasion to get the baffles in place, which will scratch any paint. You also need to RTV the gaps. I don't know why you would need to remove the baffles frequently. I have not ever and don't anticipate it for another 10 years. Whatever you use needs to hold up to bugs and heat. The engine paint does not hold up well either (at least Lycoming gray) so it will look good under the hood for only a short time. Unless you are building a show plane I would not worry much about it. Few people will ever see it. If you are building a show plane then go nuts (like the rest) and get it gold plated. Or better yet use carbon fibers and make a pressure cowl, then gold plate that. Or better yet write a big check and have someone else do it. Sorry about that last comment - I could not help myself. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264192#264192 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Sep 21, 2009
I powder coated them after they were built. Not my idea but a have seen I few do this and they look great and seem to hold up well. Geoff Geoff Combs President Aerosport Modeling & Design 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of nukeflyboy Sent: Monday, September 21, 2009 4:00 PM Subject: RV10-List: Re: Painting The Baffling... I used a clear coat on my RV-6 baffles and 9 flying years later it does not look that good. It has yellowed somewhat and the baffles do move around a bit leaving rub marks. I don't know if paint holds up better but it sounds like it. I recall that it took a lot of persuasion to get the baffles in place, which will scratch any paint. You also need to RTV the gaps. I don't know why you would need to remove the baffles frequently. I have not ever and don't anticipate it for another 10 years. Whatever you use needs to hold up to bugs and heat. The engine paint does not hold up well either (at least Lycoming gray) so it will look good under the hood for only a short time. Unless you are building a show plane I would not worry much about it. Few people will ever see it. If you are building a show plane then go nuts (like the rest) and get it gold plated. Or better yet use carbon fibers and make a pressure cowl, then gold plate that. Or better yet write a big check and have someone else do it. Sorry about that last comment - I could not help myself. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264192#264192 ________________________________________________________________________________
From: Robert Brunkenhoefer <rebrunk42(at)gmail.com>
Subject: operators handbook rv10
Date: Sep 21, 2009
i have a io540 , afs 3500, trutrak dgsv, and 1 lightspeed ignition w/ backup alternator. does anyone out there have a handbook i can adapt for my little 661G ? ________________________________________________________________________________
Date: Sep 21, 2009
Gotcha Bob... Pascal already updated me on the list on Tim's site.=C2- Ma ybe we should provide some directions as to how their info can be updated. =C2- I know several that are on the list without updated info, and some t hat aren't even on the list. Thanks again, Don --- On Sat, 9/19/09, Bob Leffler wrote: From: Bob Leffler <rv(at)thelefflers.com> Subject: RE: RV10-List: Rivet direction? Important comment!!!! Date: Saturday, September 19, 2009, 9:39 AM Don, =C2- A better idea is to encourage everyone to register on Tim=99s site, w here contact information is secure.=C2- I have no problem if any new RV-1 0 builder gives me a call looking to get questions answered, but I prefer t o not post my unlisted phone number on a public forum. =C2- Bob =C2- =C2- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Don McDonald Sent: Saturday, September 19, 2009 11:58 AM Subject: Re: RV10-List: Rivet direction? Important comment!!!! =C2- Hey guys, can we follow the new guys lead (gosh, it's kind of nice NOT to b e the new guy anymore) and put our address and maybe a phone number on the bottom of each email.=C2- It sure would make it easier to contact each ot her for both direct questions/responses, and linking up on cross country fl ights.=C2- What do ya think? Don McDonald Lincoln CA=C2- LHM 916-801-8402 --- On Thu, 9/17/09, Sam Clark wrote: From: Sam Clark <helosammy(at)gmail.com> Subject: RV10-List: Rivet direction? Date: Thursday, September 17, 2009, 6:51 PM Hello RV-10 builders, =C2- I have just started building.=C2- I pretty much jumped right in wi th both feet and it seems to be going well so far. I have finished the vert stab and am getting ready to start riveting the rudder.=C2- I started on the horizontal stab spars while waiting for a replacement rudder stiffener and have come across a bit of a perplexing question, how do I know which w ay to orient the rivets?=C2- It isn=99t really clear in the plans, I think they should probably all go the same direction so the side I counte rsink gives a pretty good clue to the direction a flush rivet goes.=C2- A m I correct in thinking they all go the same direction or does it matter? =C2- I know for the trailing edges I should alternate direction to help k eep things straight.=C2- Any insight would help, thanks in advance. =C2- Sam Clark Lexington Park, MD =C2- =C2- =C2-get=_blank rel=nofollow>http://www.matronics.com/Na vigator?RV10-List=nofollow>http://forums.matronics.comblank rel=nofollo w>http://www.matronics.com/contribution =C2- =C2- =C2-http://www.matronics.com/Navigator?RV10-Listhttp://foru ms.matronics.comhttp://www.matronics.com/contribution =C2- =0A=0A=0A ________________________________________________________________________________
Date: Sep 21, 2009
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Matt; I don't see any reason why the baffling wouldn't hold up being powder coated. I think it would look cool. It also would be easier to clean the front dams where they get all bugged up. It's just money...... Dr Fred. 515FW. ________________________________________________________________________________
Subject: Re: RV10 Interior
Date: Sep 22, 2009
You may want to check out Geoff's website and see all the new interior panels and overhead console. These weren't shown at Oshkosh. His website is: www.aerosportproducts.com. bob -------- Bob Leffler N410BL - Wings RV-10 #40684 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264388#264388 ________________________________________________________________________________
Date: Sep 22, 2009
Bob You did a great job on the web site. John G. Cumins 40864 Trim Tabs soon to be emp. Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rleffler Sent: Tuesday, September 22, 2009 3:01 PM Subject: RV10-List: Re: RV10 Interior You may want to check out Geoff's website and see all the new interior panels and overhead console. These weren't shown at Oshkosh. His website is: www.aerosportproducts.com. bob -------- Bob Leffler N410BL - Wings RV-10 #40684 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264388#264388 ________________________________________________________________________________
Date: Sep 22, 2009
I used the new web site email address to communicate to the company. Haven' t gotten any response back. Anybody know if they are home? Really nice look ing panels. I want some!! > From: jcumins(at)jcis.net > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: RV10 Interior > Date: Tue=2C 22 Sep 2009 16:27:01 -0700 > > > Bob > > You did a great job on the web site. > > John G. Cumins > 40864 Trim Tabs soon to be emp. > > > Your Total Technology Solution Provider > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rleffler > Sent: Tuesday=2C September 22=2C 2009 3:01 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: RV10 Interior > > > You may want to check out Geoff's website and see all the new interior > panels and overhead console. These weren't shown at Oshkosh. His webs ite > is: www.aerosportproducts.com. > > bob > > -------- > Bob Leffler > N410BL - Wings > RV-10 #40684 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264388#264388 > > > > > > > > > > > > =========== =========== =========== =========== > > > =0A _________________________________________________________________=0A Microsoft brings you a new way to search the web. Try Bing=99 now=0A http://www.bing.com?form=MFEHPG&publ=WLHMTAG&crea=TEXT_MFEHPG_Core_ta gline_try bing_1x1 ________________________________________________________________________________
Subject: Ice
Date: Sep 22, 2009
Any 10 encounters with ice that can be shared. I plan to take a late fall trip and might encounter. Having flown (reluctantly) some ice in my C177RG over the past 30 years, it would be nice to know how the 10 reacts with rime or clear? ________________________________________________________________________________
Subject: Heater Boxes / Firewall Sealer
Date: Sep 23, 2009
I installed my aluminum heater boxes and even held them into position with proseal - per the plans. Now I'm having second thoughts for a couple of reasons. 1) They're aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel. 2) The proseal has a flashpoint of ~200 degrees. I plan on popping these boxes off and replacing with stainless boxes. Q) What material did you use to seal them? I could use Red RTV, but I'm thinking firewall sealer (brand?) is a better option. I'm also thinking of installing a thermal barrier between the boxes and the firewall. Maybe just a bed of firewall sealer, or a box-sized square of thermal insulation. Q) Anyone else do that? Thanks, Phil ________________________________________________________________________________
Date: Sep 23, 2009
Subject: Re: Heater Boxes / Firewall Sealer
Phil, The stainless boxes I installed came with a small tube of sealer that was r ated to 1,600 degrees.=C2- I think some RTV is rated to 600 degrees.=C2 - Can't remember what firewall proseal is rated, but all of these are bet ter than regular proseal. Don't forget to install the two nutplates on the heater boxes for the cable s before installation. Sean Blair COS ----- Original Message ----- From: "Phil Perry" <Phil.Perry(at)netapp.com> Sent: Wednesday, September 23, 2009 8:53:22 AM GMT -07:00 US/Canada Mountai n Subject: RV10-List: Heater Boxes / Firewall Sealer I installed my aluminum heater boxes and even held them into position with proseal =93 per the plans. Now I=99m having second thoughts for a couple of reasons. 1) =C2-=C2-=C2-=C2-=C2- They=99re aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel . 2) =C2-=C2-=C2-=C2-=C2- The proseal has a flashpoint of ~200 degr ees. I plan on popping these boxes off and replacing with stainless boxes. Q) What material did you use to seal them?=C2- I could use Red RTV, but I =99m thinking firewall sealer (brand?) is a better option. =C2- I=99m also thinking of installing a thermal barrier between the boxes and the firewall.=C2- Maybe just a bed of firewall sealer, or a box-size d square of thermal insulation. Q) Anyone else do that? Thanks, Phil == ________________________________________________________________________________
Date: Sep 23, 2009
Phil; A couple of weeks ago we went through a thread on the benefits of SS. I mentioned for the exact reason you covered that having SS is a good investment. To save you the time- http://www.planeinnovations.com/new%20heater.htm. The heater bypass comes with a seal so you don't need to worry about RTV. I have a pair and it's a great product! Pascal From: Perry, Phil Sent: Wednesday, September 23, 2009 7:53 AM Subject: RV10-List: Heater Boxes / Firewall Sealer I installed my aluminum heater boxes and even held them into position with proseal - per the plans. Now I'm having second thoughts for a couple of reasons. 1) They're aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel. 2) The proseal has a flashpoint of ~200 degrees. I plan on popping these boxes off and replacing with stainless boxes. Q) What material did you use to seal them? I could use Red RTV, but I'm thinking firewall sealer (brand?) is a better option. I'm also thinking of installing a thermal barrier between the boxes and the firewall. Maybe just a bed of firewall sealer, or a box-sized square of thermal insulation. Q) Anyone else do that? Thanks, Phil ________________________________________________________________________________
Date: - - - , 20-
I just used the sealant that comes with the stainless parts from plane innovations. ----- Original Message ----- From: Perry, Phil To: rv10-list(at)matronics.com Sent: Wednesday, September 23, 2009 8:53 AM Subject: RV10-List: Heater Boxes / Firewall Sealer I installed my aluminum heater boxes and even held them into position with proseal - per the plans. Now I'm having second thoughts for a couple of reasons. 1) They're aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel. 2) The proseal has a flashpoint of ~200 degrees. I plan on popping these boxes off and replacing with stainless boxes. Q) What material did you use to seal them? I could use Red RTV, but I'm thinking firewall sealer (brand?) is a better option. I'm also thinking of installing a thermal barrier between the boxes and the firewall. Maybe just a bed of firewall sealer, or a box-sized square of thermal insulation. Q) Anyone else do that? Thanks, Phil ________________________________________________________________________________
Subject: Re: Ice
Date: Sep 23, 2009
You probably won't like my answer since my 10 is not flying, but knowing if a plane (not made for icing) does kind of okay is probably best not knowing. There have been several Cirrus aircraft that was legal for inadvertent icing encounter and crashed from it. Now the new Cirrus are certified for known icing. I fly a Citation Jet for a company and maybe I don't know enough but you never can tell how much ice is going to accumulate on the aircraft. I personally believe it is a very hard question to answer and to try not to get in icing. If you think the plane will do okay in it, it may persuade you to stay in it. Having said all of that I have been in icing in a plane not made for it. I got out of it as soon as I could. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264537#264537 ________________________________________________________________________________
Date: Sep 23, 2009
I used a thick (1/8 in) silicone gasket under the heater box. This idea came from Tim (I think) as an unverified way to minimize heat transfer into the tunnel. Sounded like a good idea. Since the sealant is not part of the fire barrier per se, I don't think it matters a lot. High temp RTV should work fine. -------- Dave Moore RV-6 flying RV-10 QB - cabin top/fiberglass hell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264542#264542 ________________________________________________________________________________
Date: Sep 23, 2009
Mine came with the attachments, I think Paul updated them. Call Paul at Plane innovations and ask him. From: dogsbark(at)comcast.net Sent: Wednesday, September 23, 2009 8:19 AM Subject: Re: RV10-List: Heater Boxes / Firewall Sealer Phil, The stainless boxes I installed came with a small tube of sealer that was rated to 1,600 degrees. I think some RTV is rated to 600 degrees. Can't remember what firewall proseal is rated, but all of these are better than regular proseal. Don't forget to install the two nutplates on the heater boxes for the cables before installation. Sean Blair COS ----- Original Message ----- From: "Phil Perry" <Phil.Perry(at)netapp.com> Sent: Wednesday, September 23, 2009 8:53:22 AM GMT -07:00 US/Canada Mountain Subject: RV10-List: Heater Boxes / Firewall Sealer I installed my aluminum heater boxes and even held them into position with proseal =93 per the plans. Now I=99m having second thoughts for a couple of reasons. 1) They=99re aluminum and should they melt, there is a great hole to blast a fire up the tunnel and over the fuel. 2) The proseal has a flashpoint of ~200 degrees. I plan on popping these boxes off and replacing with stainless boxes. Q) What material did you use to seal them? I could use Red RTV, but I=99m thinking firewall sealer (brand?) is a better option. I=99m also thinking of installing a thermal barrier between the boxes and the firewall. Maybe just a bed of firewall sealer, or a box-sized square of thermal insulation. Q) Anyone else do that? Thanks, Phil get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Ice
Date: Sep 23, 2009
Having flown a Cessna in the Midwest (OK,MO,IL,IN) during all seasons. One sets some ground rules. If one is going to fly during the winter in the Midwest the aircraft is going to accept minimal icing or accept some very hazardous VFR underneath. My rules are no continuous flight in icing conditions. No flight near freezing rain. I do accept that I may have to endure 3-5 minutes of climb in IMC to get on top. I may have to accept 3-5 minutes of ice on the approach. Of course the approach must be certainty (well above minimums). I also refuse clearances that will take me into icing until I am ready. SGF approach once offered a lower altitude at 30NM out. My then current temperature was a +2C and the SGF surface temperature was -8C. I refused the descent until vectored and cleared for the ILS approach about 7NM out). At 120KIAS to the marker and then 90KIAS, my exposure to ice would be about 4 minutes. Conditions on the surface were 500 and 2. Yes I picked up some ice during the approach but the runway was long the approach speed was +20KIAS above normal landing speed. I now live in the mountainous west where MEAs are very high and would guarantee icing in IMC except for a few summer months. The rules out here are VFR underneath unless the freezing levels are above freezing at the planned altitude. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Wednesday, September 23, 2009 8:54 AM Subject: RV10-List: Re: Ice You probably won't like my answer since my 10 is not flying, but knowing if a plane (not made for icing) does kind of okay is probably best not knowing. There have been several Cirrus aircraft that was legal for inadvertent icing encounter and crashed from it. Now the new Cirrus are certified for known icing. I fly a Citation Jet for a company and maybe I don't know enough but you never can tell how much ice is going to accumulate on the aircraft. I personally believe it is a very hard question to answer and to try not to get in icing. If you think the plane will do okay in it, it may persuade you to stay in it. Having said all of that I have been in icing in a plane not made for it. I got out of it as soon as I could. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264537#264537 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Fuel Flow Transducer Move
Date: Sep 23, 2009
For those that moved the fuel flow transducer between the servo and the spider, how and where exactly did you mount it? Pictures would be even better! Thanks -Mike Kraus RV-4 Flying RV-10 FWF and Wiring Sent from my iPhone ________________________________________________________________________________
Date: Sep 23, 2009
Another vote here for Paul at: http://www.planeinnovations.com/new%20wheelpant.htm Paul is great and VERY helpful. I consider the heater valves a must option -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264663#264663 ________________________________________________________________________________
Date: Sep 23, 2009
Have these too! I know the manufacturer of these personally and he makes quality products. Think there was a hinge cover in development, waiting for my order to arrive but I think I'll be equally happy with that product as well. Pascal -------------------------------------------------- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Wednesday, September 23, 2009 9:26 PM Subject: RV10-List: Re: Heater Boxes / Firewall Sealer > > Another vote here for Paul at: > > http://www.planeinnovations.com/new%20wheelpant.htm > > Paul is great and VERY helpful. I consider the heater valves a must option > > -------- > OSH '10 or Bust > Q/B Kit - phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264663#264663 > > > ________________________________________________________________________________
Subject: Re: Fuel Flow Transducer Move
Date: Sep 24, 2009
n223rv(at)wolflakeairport wrote: > For those that moved the fuel flow transducer between the servo and > the spider, how and where exactly did you mount it? Pictures would be > even better! > Here is a link to a picture where I put mine. It is where AFS recommends putting it. http://www.wingscc.com/N2GB/FF4-FuelSystem/100_3208.html -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264676#264676 ________________________________________________________________________________
Subject: FireWall Engine Side Paint?
Date: Sep 24, 2009
F.Y.I. => I am wondering if the engine side of the Firewall will get hot. I noticed that nobody paints the engine side of the Firewall except me. (I did not like bare stainless steel) My question is I applied a shinny epoxy that has a 200 degree F. upper heat temp. I am thinking unless I want to smell cooked or "burnt" paint I need to remove this low temp. paint and replace with a 1200 degree F. or greater barbeque or engine block type paint. Am I on the right track removing the paint or am I O.K. with the 200 degree paint. -------- Conrad Booze Sr. Engineer P. O. Box 7028 Warner Robins, GA. 31095 (478)-335-4264 conradbooze(at)cox.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264680#264680 ________________________________________________________________________________
Date: Sep 24, 2009
As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 ________________________________________________________________________________
Subject: Chargers
Date: Sep 24, 2009
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
What are folks following for a battery-charging philosophy? I am using Odyssey PC680s (who isn't?), and was wondering if folks are trickle charging all the time when you're in the hangar, only when not expecting to fly for a while, or only when it's winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Chargers
My plane has a Sony AM/FM/CD/MP3 player in it that sucks juice all the time. I use a BatteryHawk that SafeAir1 sells to keep my PC680 charged almost all of the time. I haven't tried going a week without it yet......It's a smart trickle charger that I built in during construction..... Ralph RV6A N822AR @ N06 37 hrs Collecting RV10 parts on the side..... -----Original Message----- >From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero> >Sent: Sep 24, 2009 12:25 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Chargers > >What are folks following for a battery-charging philosophy? I am using >Odyssey PC680s (who isn't?), and was wondering if folks are trickle >charging all the time when you're in the hangar, only when not expecting >to fly for a while, or only when it's winter, etc. > > > >Please share your thoughts. > > >TDT > > > > >Tim Dawson-Townsend > >Aurora Flight Sciences > >tdt(at)aurora.aero > >617-500-4812 (office) > >617-905-4800 (mobile) > > > ________________________________________________________________________________
Date: Sep 24, 2009
I have about 430 hours with the transducer in the plans location. No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 ________________________________________________________________________________
Date: Sep 24, 2009
I left mine in the standard position. I see very minor fluctuations....I do not think it is a problem. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 10:05 AM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 ________________________________________________________________________________
Subject: Chargers
Date: Sep 24, 2009
I am using a 925, and have a trickle charger. I only use it when I am leaving the master switch on (without the engine running J) for an extended period of time. I have not had a problem starting even on very cold days. Rene' Felker RV-10 N423CF Flying 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Thursday, September 24, 2009 10:26 AM Subject: RV10-List: Chargers What are folks following for a battery-charging philosophy? I am using Odyssey PC680s (who isn't?), and was wondering if folks are trickle charging all the time when you're in the hangar, only when not expecting to fly for a while, or only when it's winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Sep 24, 2009
I think the general consensus is that is works fine in the standard location (tunnel) if you can accept some variability in flow indications when the electric fuel pump is on. With that being said, mine sits BEFORE the flow divider on top of the air box in the picture below. It is not flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE the servo and very stable. http://wcurtis.nerv10.com/90Electrical/EL2g.html William http://wcurtis.nerv10.com/ On Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard wrote: > > As an informal survey for the rest of us, it would be interesting to get > feedback from those that have left it where Van's originally suggested. Are > any of you having any trouble with the transducer in that location? > > How many people have moved the unit because of inaccurate readings or other > problems? > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264706#264706 > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Sep 24, 2009
Subject: Chargers
I'm using the BatteryMinder 12248 for my Odyssey batteries. There was a write-up in one of the mags a few months back comparing different chargers and this one looked to be the best. It will charge any style lead acid bat tery and also desulphates. They will say on their site that you should get their "special" charger for Odyssey batteries but it only has a single pro file in it for Odyssey AGM batteries. I spent a bunch of time looking at the information on the "special" charg er vs. the 12248 which will charge flooded, AGM, and gel batteries and coul d not find a difference in the Odyssey vs. the AGM profiles that made it wo rthwhile. I also run the Odyssey in my motorcycle and ATV but I wanted the options and I have been very happy with it. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Thursday, September 24, 2009 11:26 AM Subject: RV10-List: Chargers What are folks following for a battery-charging philosophy? I am using Ody ssey PC680s (who isn't?), and was wondering if folks are trickle charging a ll the time when you're in the hangar, only when not expecting to fly for a while, or only when it's winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Sep 24, 2009
I was just thinking about that yesterday and came across this. "Unlike conventional batteries that need to be recharged every six to twelv e weeks, the Odyssey battery will maintain up to 50% state of charge after 2 yrs if stored at room temperature (77=BAF). At temperatures lower than 77 =B0F, storage times will be even longer" http://www.aircraftspruce.com/catalog/elpages/odysseydry.php William http://wcurtis.nerv10.com/ On Thu, Sep 24, 2009 at 12:25 PM, Dawson-Townsend,Timothy < tdawson-townsend(at)aurora.aero> wrote: > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isn=92t?), and was wondering if folks are trickle cha rging > all the time when you=92re in the hangar, only when not expecting to fly for a > while, or only when it=92s winter, etc. > > > Please share your thoughts. > > > TDT > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Sep 24, 2009
I leave my birds on the trickle charge almost all of the time ..... exception is when I'm in a hurry to lock up or just plain forget. Linn Dawson-Townsend,Timothy wrote: > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isnt?), and was wondering if folks are trickle > charging all the time when youre in the hangar, only when not expecting > to fly for a while, or only when its winter, etc. > > > > Please share your thoughts. > > > TDT > > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * > > > * ________________________________________________________________________________
Date: Sep 24, 2009
No problem with the Vans location. Engine is certified IO540D4A5. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 9:05 AM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 ________________________________________________________________________________
Subject: Chargers
Date: Sep 24, 2009
no trickle charger but I use 1 or 2 680s in parallel for starting. 2 680s turn prop rapidly. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Thursday, September 24, 2009 9:26 AM Subject: RV10-List: Chargers What are folks following for a battery-charging philosophy? I am using Odyssey PC680s (who isn't?), and was wondering if folks are trickle charging all the time when you're in the hangar, only when not expecting to fly for a while, or only when it's winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Sep 24, 2009
Been using battery tender on both of my PC 680's constantly as recommended in light plane maintenance magazine. Their research convinced me to keep mine plugged up when not flying. grumpy N184JM On Sep 24, 2009, at 11:25 AM, Dawson-Townsend,Timothy wrote: > What are folks following for a battery-charging philosophy? I am > using Odyssey PC680s (who isn=92t?), and was wondering if folks are > trickle charging all the time when you=92re in the hangar, only when > not expecting to fly for a while, or only when it=92s winter, etc. > > Please share your thoughts. > > TDT > > > Tim Dawson-Townsend > Aurora Flight Sciences > tdt(at)aurora.aero > 617-500-4812 (office) > 617-905-4800 (mobile) > > ________________________________________________________________________________
Date: Sep 24, 2009
Here's a noob question for you guys (I'm in the "prebuild/investigation" phase of my RV-10 ;-).... It sounds like you guys have a battery charger as standard equipment. Why i s this? Does the battery that goes in the RV-10 not hold a charge? Or is there some kind of current leak? I've got a Warrior atm and we have no problem going weeks w/o running it an d it always cranks up just fine. Just wondering.....I've only been on this list for about 3 days and have already learned so much. Thanks, Ande Boyer Huntsville, AL On Thu, Sep 24, 2009 at 11:25 AM, Dawson-Townsend,Timothy < tdawson-townsend(at)aurora.aero> wrote: > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isn=92t?), and was wondering if folks are trickle cha rging > all the time when you=92re in the hangar, only when not expecting to fly for a > while, or only when it=92s winter, etc. > > > Please share your thoughts. > > > TDT > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > * > =========== =========== =========== =========== > * > > -- "Pilots are a rare kind of human. They leave the ordinary surface of the world, to purify their soul in the sky, and they come down to earth, only after receiving the communion of the infinite." - Jos=E9 Maria Velasco Ibar ra ________________________________________________________________________________
Date: Sep 24, 2009
I'm still in the shop but my GRTs have an "always on" circuit I guess for the clock. So I plan to generally stay on trickle. I installed an internal jack in the baggage compartment for this purpose. Bill "building the engine sensing birds nest" Watson Dawson-Townsend,Timothy wrote: > > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isnt?), and was wondering if folks are trickle > charging all the time when youre in the hangar, only when not > expecting to fly for a while, or only when its winter, etc. > > Please share your thoughts. > > > TDT > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > * > > > * ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Engine Sensing wire birds nest - any good pics on wire management
I'm putting in the EGT and CHT lines and it looks pretty straight forward. I have the sensor leads in place but I'm wondering exactly how to route and clamp the lines from the GRT coming through the firewall to hook up to the sensor leads. Anyone have a picture of how they did it? I've been searching but can't quite find a good pic of that part. Seems straight forward but looking for additional ideas. Thanks Scott S. for the good photos of your engine compartment.... very clean like the rest of your ship! Bill "taming the latest birds nest" Watson ________________________________________________________________________________
Date: Sep 24, 2009
In my case it is not a battery leak per se....rather something that is always on...... -----Original Message----- >From: Ande Boyer <ande.boyer(at)gmail.com> >Sent: Sep 24, 2009 1:23 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Chargers > >Here's a noob question for you guys (I'm in the "prebuild/investigation" >phase of my RV-10 ;-).... > >It sounds like you guys have a battery charger as standard equipment. Why is >this? Does the battery that goes in the RV-10 not hold a charge? Or is >there some kind of current leak? > >I've got a Warrior atm and we have no problem going weeks w/o running it and >it always cranks up just fine. > >Just wondering.....I've only been on this list for about 3 days and have >already learned so much. > >Thanks, >Ande Boyer >Huntsville, AL > > >On Thu, Sep 24, 2009 at 11:25 AM, Dawson-Townsend,Timothy < >tdawson-townsend(at)aurora.aero> wrote: > >> What are folks following for a battery-charging philosophy? I am using >> Odyssey PC680s (who isnt?), and was wondering if folks are trickle charging >> all the time when youre in the hangar, only when not expecting to fly for a >> while, or only when its winter, etc. >> >> >> >> Please share your thoughts. >> >> >> TDT >> >> >> >> Tim Dawson-Townsend >> >> Aurora Flight Sciences >> >> tdt(at)aurora.aero >> >> 617-500-4812 (office) >> >> 617-905-4800 (mobile) >> >> >> >> * >> >=========== >=========== >=========== >=========== >> * >> >> > > >-- >"Pilots are a rare kind of human. They leave the ordinary surface of the >world, to purify their soul in the sky, and they come down to earth, only >after receiving the communion of the infinite." - Jos Maria Velasco Ibarra ________________________________________________________________________________
Date: Sep 24, 2009
You better quit investigating ..... it'll cost ya!!! The reasons for using trickle chargers varies amongst the users. For me, I don't mount the charger in the airplane .... I like the mobility of using them elsewhere. For me, the reason I use the trickle charger on all my flooded/gel batteries is to prolong their use. The desulfator option is important, and you should pay the price. The RV-10 is no different .... battery wise .... than any vehicle that doesn't get daily/weekly use ....... leaving the trickle charger off will shorten it's useful life. IMHO, of course. Linn Ande Boyer wrote: > Here's a noob question for you guys (I'm in the "prebuild/investigation" > phase of my RV-10 ;-).... > > It sounds like you guys have a battery charger as standard equipment. > Why is this? Does the battery that goes in the RV-10 not hold a charge? > Or is there some kind of current leak? > > I've got a Warrior atm and we have no problem going weeks w/o running it > and it always cranks up just fine. > > Just wondering.....I've only been on this list for about 3 days and have > already learned so much. > > Thanks, > Ande Boyer > Huntsville, AL > ________________________________________________________________________________
Date: Sep 24, 2009
Van's location with no issues on an IO-540-C4B5. I get some minor fluctuations (.2 gph) at times. I only notice this when adjusting to LOP operations. Not nearly bothersome enough to consider moving it at this point in time. If I had steam gauges instead of a digital readout, I doubt that I would even notice it at all. David Maib 40559 Flying/150 hours On Sep 24, 2009, at 1:06 PM, David McNeill wrote: No problem with the Vans location. Engine is certified IO540D4A5. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 9:05 AM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 ________________________________________________________________________________
Date: Sep 24, 2009
wcurtis(at)nerv10.com wrote: > I think the general consensus is that is works fine in the standard location (tunnel) if you can?accept some variability in flow indications when the electric fuel pump is on.? With that being said, mine sits BEFORE the flow divider on top of the air box in the picture below.? It is not flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE the servo and?very stable. > ? > http://wcurtis.nerv10.com/90Electrical/EL2g.html (http://wcurtis.nerv10.com/90Electrical/EL2g.html) > ? > William William, If the transducer in your picture is from AFS, contact them. Mine leaked around the gasket on the cover plate. There was a recall from the mfg and they replaced mine right away. That was my only real problem during my fly off. Took me some time to identify where the leak was coming from. The transducer in my picture is the old one. The new one does not have that little filled slot on the cover. I am sure glad I had moved the transducer from the tunnel to north of the firewall. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264743#264743 ________________________________________________________________________________
Date: Sep 24, 2009
Ande, No current or voltage demands. The Rv is no =C2- different than any other aircraft except most don't meet the requirments of a certified aircraft, t hey exceed them! . The reason most of us have chargers is the time we spent setting up the avionics, doing systems checks, learning the new equipment etc etc,,,,in other words lots of battery time doing that. Plus most of us tend to be tool hogs so it's another good excuse to blow 50 bucks on antoeh r piece of equipment. Rick Sked N246RS Air officially under butt ----- Original Message ----- From: "Ande Boyer" <ande.boyer(at)gmail.com> Sent: Thursday, September 24, 2009 10:23:47 AM GMT -08:00 US/Canada Pacific Subject: Re: RV10-List: Chargers Here's a noob question for you guys (I'm in the "prebuild/investigation" ph ase of my RV-10 ;-).... It sounds like you guys have a battery charger as standard equipment. Why i s this? Does the battery that goes in the RV-10 not hold a charge?=C2- Or is there some kind of current leak? I've got a=C2-Warrior atm and we have no problem going weeks w/o running it and it always cranks up just fine. Just wondering.....I've only been on this list for about 3 days and have al ready learned so much. Thanks, Ande Boyer Huntsville, AL =C2- On Thu, Sep 24, 2009 at 11:25 AM, Dawson-Townsend,Timothy < tdawson-townsen d(at)aurora.aero > wrote: What are folks following for a battery-charging philosophy?=C2- I am usin g Odyssey PC680s (who isn=99t?), and was wondering if folks are trick le charging all the time when you=99re in the hangar, only when not e xpecting to fly for a while, or only when it=99s winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) get="_blank">http://www.matronics.com/Navigator?RV10-List ttp://forums.ma tronics.com _blank">http://www.matronics.com/contribution -- "Pilots are a rare kind of human. They leave the ordinary surface of the wo rld, to purify their soul in the sky, and they come down to earth, only aft er receiving the communion of the infinite." - Jos=C3=A9 Maria Velasco Ibar ra == ________________________________________________________________________________
Date: Sep 24, 2009
Hi Ande, The care and feeding of batteries (especially as panels are less likely to have vacuum pump instruments) is an important part of safe flying. An RV-10, with a long distance from the battery to the starter, requires a well charged battery to start. Most of us aren't able to fly consistently, so a trickle charger is appealing. However, all trickle chargers are not created equally, and one that over charges will damage the battery. If you are not a member of the Aeroelectric list (aeroelectric-list(at)matronics.com ) moderated by Bob Nuckolls, I suggest you become one. There is a mountain of discussion of this issue in the archives over there and the knowledge you'll gain is well worth the time spent. Jeff Carpenter 40304... still fitting doors and windows On Sep 24, 2009, at 10:23 AM, Ande Boyer wrote: > Here's a noob question for you guys (I'm in the "prebuild/ > investigation" phase of my RV-10 ;-).... > > It sounds like you guys have a battery charger as standard > equipment. Why is this? Does the battery that goes in the RV-10 not > hold a charge? Or is there some kind of current leak? > > I've got a Warrior atm and we have no problem going weeks w/o > running it and it always cranks up just fine. > > Just wondering.....I've only been on this list for about 3 days and > have already learned so much. > > Thanks, > Ande Boyer > Huntsville, AL > > > On Thu, Sep 24, 2009 at 11:25 AM, Dawson-Townsend,Timothy > wrote: > What are folks following for a battery-charging philosophy? I am > using Odyssey PC680s (who isn=92t?), and was wondering if folks are > trickle charging all the time when you=92re in the hangar, only when > not expecting to fly for a while, or only when it=92s winter, etc. > > > Please share your thoughts. > > > TDT > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > ttp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > -- > "Pilots are a rare kind of human. They leave the ordinary surface of > the world, to purify their soul in the sky, and they come down to > earth, only after receiving the communion of the infinite." - Jos=E9 > Maria Velasco Ibarra > > ________________________________________________________________________________
Date: Sep 24, 2009
Question, Why the teflon tape or pipe sealent? Why aluminum fitting into th e transducer? JP instruments and I suggest never ever use that stuff on the transducer. A nd it would be a lot better if you had a straight out fitting from the tran sducer. Not the ninety. Good book to read Is the JPI installation manual. I think it''s the second page where it says, read this first. But that just my opinion and we all have one. -Patrick Thyssen But then I too made a mistake and bought OP Equiptment And now I'm fixing t hat. Dual 430w and garmin G500. Now I know they will work.-- --- On Thu, 9/24/09, William Curtis wrote: From: William Curtis <wcurtis(at)nerv10.com> Subject: Re: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 11:56 AM I think the general consensus is that is works fine in the standard locatio n (tunnel) if you can-accept some variability in flow indications when th e electric fuel pump is on.- With that being said, mine sits BEFORE the f low divider on top of the air box in the picture below.- It is not flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE the ser vo and-very stable.=0A=0A-=0Ahttp://wcurtis.nerv10.com/90Electrical/EL2 g.html=0A-=0AWilliam=0Ahttp://wcurtis.nerv10.com/=0A -=0AOn Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard wr ote: =0A As an informal survey for the rest of us, it would be interesting to get fe edback from those that have left it where Van's originally suggested. -Ar e any of you having any trouble with the transducer in that location? =0A How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 =0At Un/Subscription, =0Awww.matronics.com/Navigator?RV10-List" target="_blank">http://www.matr onics.com/Navigator?RV10-List =0Aronics.com/" target="_blank">http://forums.matronics.com =0AMatt Dralle, List Admin. =0A==== =0A =0A=0A ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Chargers
Nope, just standard equipment in my shop. Using it regularly can just be c hocked up to preventative maint. A fully charged battery will outlive one that is allowed to sit at a reduced capacity every time. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Ande Boyer Sent: Thursday, September 24, 2009 12:24 PM Subject: Re: RV10-List: Chargers Here's a noob question for you guys (I'm in the "prebuild/investigation" ph ase of my RV-10 ;-).... It sounds like you guys have a battery charger as standard equipment. Why i s this? Does the battery that goes in the RV-10 not hold a charge? Or is t here some kind of current leak? I've got a Warrior atm and we have no problem going weeks w/o running it an d it always cranks up just fine. Just wondering.....I've only been on this list for about 3 days and have al ready learned so much. Thanks, Ande Boyer Huntsville, AL On Thu, Sep 24, 2009 at 11:25 AM, Dawson-Townsend,Timothy > wrote: What are folks following for a battery-charging philosophy? I am using Ody ssey PC680s (who isn't?), and was wondering if folks are trickle charging a ll the time when you're in the hangar, only when not expecting to fly for a while, or only when it's winter, etc. Please share your thoughts. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) get="_blank">http://www.matronics.com/Navigator?RV10-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution -- "Pilots are a rare kind of human. They leave the ordinary surface of the wo rld, to purify their soul in the sky, and they come down to earth, only aft er receiving the communion of the infinite." - Jos=E9 Maria Velasco Ibarra ________________________________________________________________________________
Subject: Window trim - inside
Date: Sep 24, 2009
Group... Linda and I glued the windows and wind screen in permanently last weekend using Weldon 10. Worked much easier with cooler temps ... below 70 in the garage early in the morning than when we did the doors a few months back. (I put one bottle of weld10 in the fridge overnight and it seemed to be even a little slower to set up) These turned out pretty well. On the outside of the windows, I'll use some lite weight cloth to fair the transition from plexi to fiberglass. What are the options on the inside of the windows where the weldon - plexi - fiberglass cabin frame meet? Mine's not terrible and I attempted to smooth out the fair with weldon but it could be smoother and more consistent. Is there any kind of caulking that will smooth the transition? Thanks, Doug -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264780#264780 ________________________________________________________________________________
Date: Sep 24, 2009
Guess you did not read the caption above the photo regarding the aluminum fitting. NPT fittings benefit from sealant, AN fittings do not. The inlet to the flow transducer is NPT. As far as the 90 degree fitting out from the transducer, well that's what I have now on the Cardinal and it works just fine. The instrument I have in the Cardinal is Electronics International, the OEM for the "red cube" transducer so no, I never read nor plan to read the JPI manual. William http://wcurtis.nerv10.com/ On Thu, Sep 24, 2009 at 2:47 PM, Patrick Thyssen wrote: > Question, Why the teflon tape or pipe sealent? Why aluminum fitting into > the transducer? > JP instruments and I suggest never ever use that stuff on the transducer. > And it would be a lot better if you had a straight out fitting from the > transducer. Not the ninety. Good book to read Is the JPI installation > manual. I think it''s the second page where it says, read this first. > But that just my opinion and we all have one. > Patrick Thyssen > > But then I too made a mistake and bought OP Equiptment And now I'm fixing > that. > Dual 430w and garmin G500. Now I know they will work. > > > --- On *Thu, 9/24/09, William Curtis * wrote: > > > From: William Curtis <wcurtis(at)nerv10.com> > Subject: Re: RV10-List: Re: Fuel Flow Transducer Move > To: rv10-list(at)matronics.com > Date: Thursday, September 24, 2009, 11:56 AM > > I think the general consensus is that is works fine in the standard > location (tunnel) if you can accept some variability in flow indications > when the electric fuel pump is on. With that being said, mine sits BEFORE > the flow divider on top of the air box in the picture below. It is not > flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE > the servo and very stable. > > http://wcurtis.nerv10.com/90Electrical/EL2g.html > > William > http://wcurtis.nerv10.com/ > > > On Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard http://mc/compose?to=nick@nleonard.com> > > wrote: > >> > >> >> As an informal survey for the rest of us, it would be interesting to get >> feedback from those that have left it where Van's originally suggested. Are >> any of you having any trouble with the transducer in that location? >> >> How many people have moved the unit because of inaccurate readings or >> other problems? >> >> -------- >> Nick Leonard >> RV-10 (40015) Finish >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=264706#264706 >> t Un/Subscription, >> www.matronics.com/Navigator?RV10-List" target="_blank"> >> http://www.matronics.com/Navigator?RV10-List >> ronics.com/" target="_blank">http://forums.matronics.com >> Matt Dralle, List Admin. >> ==== >> >> >> >> >> > *http://www.matronics.com/Navigator?RV10-Lisk" href="http://forums.matronics.com">http://forums.matronics.com > gt; <http://www.matronics.com/======%3Cbr%3E%3Cbr%3E%3C/font%3E%3C/b%3E%3Cfont+color=>* > > * > > * > > ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Window trim - inside
For window interior, maybe Geoff Coombs from Aerosport Products ( www.aerosportproducts.com) can be convinced to add close-out rings to his product suite. They would, cover the Weld-On fiberglass edge, cover the edges of any headliner, and they would match the other interior plastic panels that he offers. For those that have not glued in the windows yet, tongue depressors and Dixie cups worked great. I used these and applied a thin layer to the fiberglass then the window and then put into position--no crazing, no leaking. Also, you can get a Pint kit of Weld-On #10 from eplastics.com, Enough to do ALL windows at a very good price. http://www.eplastics.com/Plastic/Multipurpose-Glue/WELD-ON-GLUE-IPS10-PT William Curtis http://wcurtis.nerv10.com/ On Thu, Sep 24, 2009 at 3:48 PM, n277dl wrote: > > Group... > Linda and I glued the windows and wind screen in permanently last weekend > using Weldon 10. Worked much easier with cooler temps ... below 70 in the > garage early in the morning than when we did the doors a few months back. > (I put one bottle of weld10 in the fridge overnight and it seemed to be > even a little slower to set up) > > These turned out pretty well. On the outside of the windows, I'll use some > lite weight cloth to fair the transition from plexi to fiberglass. > > What are the options on the inside of the windows where the weldon - plexi > - fiberglass cabin frame meet? Mine's not terrible and I attempted to > smooth out the fair with weldon but it could be smoother and more > consistent. Is there any kind of caulking that will smooth the transition? > > Thanks, > Doug > > -------- > Doug > "Fools" are always more creative than process people and will always find > ways to ruin a perfectly good set of processes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264780#264780 > > ________________________________________________________________________________
Date: Sep 24, 2009
I watched the discussion on AeroElectric and read lots of things at other places about charging my Odyssey PC925, and spent a bunch of time reading before I bought a charger. Michael's right, that 12248 would eb a great way to go, and it's supposely got a great voltage curve for charging the Odyssey. What I did for myself though was a little different. I got a larger charger, that costs a bit more. I had been looking for Odyssey specific chargers, and wanted to make sure I did the best I could to charge at the right voltage. There is an Odyssey labeled charger that looks exactly like the Schumacher Speed Charge 1200A, which WalMart also sells. The difference I think is that the Odyssey doesn't have the variety of charging profiles. I got one off Ebay really really cheap, and got one at WalMart too, so now I use them at home and at the hangar. Here is a link: http://store.schumachermart.com/sc-1200a.html A few weeks ago I got fired up to verify that this was really the same, so I sent Schumacher an email asking if they had the same charge curve, and they said they were the same. I'm assuming I'd use AGM mode, so that's what I've been using. It's more expensive of a charger than you have to have, but it can charge other batteries too. I plug mine in sometimes if I have a big trip coming up, and want to ensure I've got a perfect charge, and I charge it during the winter when I don't fly as often. In the summer though, I generally don't charge it. I suppose I connect the charger maybe 10 times a year. Tim Olson - RV-10 N104CD RV Builder (Michael Sausen) wrote: > Im using the BatteryMinder 12248 for my Odyssey batteries. There was > a write-up in one of the mags a few months back comparing different > chargers and this one looked to be the best. It will charge any style > lead acid battery and also desulphates. They will say on their site > that you should get their special charger for Odyssey batteries but it > only has a single profile in it for Odyssey AGM batteries. > > > > I spent a bunch of time looking at the information on the special > charger vs. the 12248 which will charge flooded, AGM, and gel batteries > and could not find a difference in the Odyssey vs. the AGM profiles that > made it worthwhile. I also run the Odyssey in my motorcycle and ATV but > I wanted the options and I have been very happy with it. > > > > Michael > > > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *Dawson-Townsend,Timothy > *Sent:* Thursday, September 24, 2009 11:26 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Chargers > > > > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isnt?), and was wondering if folks are trickle > charging all the time when youre in the hangar, only when not expecting > to fly for a while, or only when its winter, etc. > > > > Please share your thoughts. > > > TDT > > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * * > > * * > > ; - The RV10-List Email Forhref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.=============== > > < Same great content also available via the Web Forums! > > href="http://forums.matronics.com">http://forums.matronics.comhttp://www.matronics.com/con > > * * > > * > > > * ________________________________________________________________________________
Date: Sep 24, 2009
As others have noted with the transducer installed in the tunnel prior to the mech fuel pump and after the elect boost pump, you WILL see errroneous readings during the period the elect fuel pump is operated. From my experience you will ALSO see significant fluctuations in the fuel flows. (+/- .5 gph) during the normal course of operations this sin't too much of an issue. However if you are trying to balance your fuel injectors or troubleshooting a fuel system issue and want to collect accurate datam to a .1 of a gph, you will get VERY frustrated. Save yourself some frustration and mount it between the servo and the distribution spider. Deems Davis www.deemsrv10.com N519PJ Nick Leonard wrote: > > As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? > > How many people have moved the unit because of inaccurate readings or other problems? > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264706#264706 > > > ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Engine Sensing wire birds nest - any good pics on wire
management You can find some pictures in this album : http://deemsrv10.com/album/Sec%20FFPS%20Probes%20and%20Sensors/index.html Deems Davis N519PJ Bill Mauledriver Watson wrote: > > > I'm putting in the EGT and CHT lines and it looks pretty straight > forward. I have the sensor leads in place but I'm wondering exactly > how to route and clamp the lines from the GRT coming through the > firewall to hook up to the sensor leads. > > Anyone have a picture of how they did it? I've been searching but > can't quite find a good pic of that part. Seems straight forward but > looking for additional ideas. > > Thanks Scott S. for the good photos of your engine compartment.... > very clean like the rest of your ship! > > Bill "taming the latest birds nest" Watson > > ________________________________________________________________________________
Date: Sep 25, 2009
From: "McGann, Ron" <Ron.McGann(at)thalesgroup.com.au>
Only 40 hours but same experience as Marcus. Only irregluarity comes when the boost pump is engaged but the totaliser function always appears to reflect remaining fuel to within a gallon or so. Ron McGann Head of Engineering Security Solutions & Services Aerospace Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Friday, 25 September 2009 2:45 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move I have about 430 hours with the transducer in the plans location. No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 DISCLAIMER:--------------------------------------------------------------------------- This e-mail transmission and any documents, files and previous e-mail messages attached to it are private and confidential. They may contain proprietary or copyright material or information that is subject to legal professional privilege. They are for the use of the intended recipient only. Any unauthorised viewing, use, disclosure, copying, alteration, storage or distribution of, or reliance on, this message is strictly prohibited. No part may be reproduced, adapted or transmitted without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by return email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be deemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attached are error or virus free. -------------------------------------------------------------------------------------- ________________________________________________________________________________
Subject: Re: Ice
Date: Sep 24, 2009
One should never consider even being dispatched, if there were a chance for icing conditions. I fly for a living and I would never fly my RV-10 near ice. period How many lessons do we need to look back at to understand it is not worth the risk. Just me 2 cents, fly safe and have fun Thane States 321BY ----- Original Message ----- From: "Strasnuts" <sean(at)braunandco.com> Sent: Wednesday, September 23, 2009 11:54 AM Subject: RV10-List: Re: Ice > > You probably won't like my answer since my 10 is not flying, but knowing > if a plane (not made for icing) does kind of okay is probably best not > knowing. There have been several Cirrus aircraft that was legal for > inadvertent icing encounter and crashed from it. Now the new Cirrus are > certified for known icing. I fly a Citation Jet for a company and maybe I > don't know enough but you never can tell how much ice is going to > accumulate on the aircraft. I personally believe it is a very hard > question to answer and to try not to get in icing. If you think the plane > will do okay in it, it may persuade you to stay in it. Having said all of > that I have been in icing in a plane not made for it. I got out of it as > soon as I could. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264537#264537 > > > ________________________________________________________________________________
Date: Sep 24, 2009
A very smart friend of mone turned me on to a charger called a "Battery Min der".=C2- Look it up online.=C2- Cost around $50.=C2- Not only trickl e charges, but sends out pulses that keep sulfides from forming.=C2- The friends 210 has not replaced his battery in over 10 years... whereas before they seemed to last 3 or 4 years.=C2- I use them on cars=C2-stored, mo torcycles, boats, and my plane. Don McDonald Plane parked.... on the boat......... wishing I was flying!=C2- --- On Thu, 9/24/09, Linn Walters wrote: From: Linn Walters <pitts_pilot(at)bellsouth.net> Subject: Re: RV10-List: Chargers Date: Thursday, September 24, 2009, 10:03 AM I leave my birds on the trickle charge almost all of the time ..... excepti on is when I'm in a hurry to lock up or just plain forget. Linn Dawson-Townsend,Timothy wrote: > What are folks following for a battery-charging philosophy?=C2- I am us ing Odyssey PC680s (who isn=99t?), and was wondering if folks are tri ckle charging all the time when you=99re in the hangar, only when not expecting to fly for a while, or only when it=99s winter, etc. > >=C2- > Please share your thoughts. > > > TDT > >=C2- > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > >=C2- > * > > > * S WEB FORUMS - on Web Site - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. =0A=0A=0A ________________________________________________________________________________
Subject: Chargers
Date: Sep 24, 2009
Avoid using the Battery Tender on sealed aircraft batteries. It chewed up two Concorde=99s in less than a year before I wised up (afterwards I also switched to the PC925). I would recommend going with a charger that was specifically designed for that type of battery: http://www.batteryminders.com/specials.php Brian RV-10 N104BS Nashville, TN From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Thursday, September 24, 2009 6:54 PM Subject: Re: RV10-List: Chargers A very smart friend of mone turned me on to a charger called a "Battery Minder". Look it up online. Cost around $50. Not only trickle charges, but sends out pulses that keep sulfides from forming. The friends 210 has not replaced his battery in over 10 years... whereas before they seemed to last 3 or 4 years. I use them on cars stored, motorcycles, boats, and my plane. Don McDonald Plane parked.... on the boat......... wishing I was flying! --- On Thu, 9/24/09, Linn Walters wrote: From: Linn Walters <pitts_pilot(at)bellsouth.net> Subject: Re: RV10-List: Chargers Date: Thursday, September 24, 2009, 10:03 AM <http://us.mc537.mail.yahoo.com/mc/compose?to=pitts_pilot@bellsouth.net > > I leave my birds on the trickle charge almost all of the time ..... exception is when I'm in a hurry to lock up or just plain forget. Linn Dawson-Townsend,Timothy wrote: > What are folks following for a battery-charging philosophy? I am using Odyssey PC680s (who isn=99t?), and was wondering if folks are trickle charging all the time when you=99re in the hangar, only when not expecting to fly for a while, or only when it=99s winter, etc. > > > Please share your thoughts. > > > TDT > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero <http://us.mc537.mail.yahoo.com/mc/compose?to=tdt@aurora.aero> http://us.mc537.mail.yahoo.com/mc/compose?to=tdt@aurora.aero> > > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > =========== ________________________________________________________________________________
Date: Sep 24, 2009
This is going to be the way I secure my charger to my battery. Only the best for my RV-10. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264861#264861 Attachments: http://forums.matronics.com//files/cid_bb830754_a37e_47b7_8a1a_8aa9c2caae31_599.jpg ________________________________________________________________________________
Date: Sep 24, 2009
-I'LL STAND BY MY STATEMENT WITH THE ADDED INSERT, EI MAKE INSTALLATION M ANUALS ALSO. THEY REFERENCE AC43-13 ALSO. YOUR LOSS FOR NOT READING EVERYTH ING YOU CAN. YOU WOULD LEARN A LOT MORE. -PATRICK THYSSEN --- On Thu, 9/24/09, William Curtis wrote: From: William Curtis <wcurtis(at)nerv10.com> Subject: Re: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 3:10 PM Guess you did not read the caption above the photo regarding the aluminum f itting.- NPT fittings benefit from sealant, AN fittings do not.- The in let to the flow transducer is NPT.- As far as the 90 degree fitting out f rom the transducer, well that's what I have now on=0A the Cardinal and it w orks just fine.- The instrument I have in the Cardinal is Electronics Int ernational, the OEM for the "red cube" transducer so no, I never read nor p lan to read the JPI manual.=0A=0A-=0AWilliam=0Ahttp://wcurtis.nerv10.com/ =0AOn Thu, Sep 24, 2009 at 2:47 PM, Patrick Thyssen w rote: =0A=0A=0A=0A=0AQuestion, Why the teflon tape or pipe sealent? Why aluminum fitting into the transducer? JP instruments and I suggest never ever use that stuff on the transducer. A nd it would be a lot better if you had a straight out fitting from the tran sducer. Not the ninety. Good book to read Is the JPI installation manual. I think it''s the second page where it says, read this first. =0ABut that just my opinion and we all have one. -Patrick Thyssen But then I too made a mistake and bought OP Equiptment And now I'm fixing t hat. Dual 430w and garmin G500. Now I know they will work.-- =0A --- On Thu, 9/24/09, William Curtis wrote: =0A From: William Curtis <wcurtis(at)nerv10.com> Subject: Re: RV10-List: Re: Fuel Flow Transducer Move =0ATo: rv10-list(at)matronics.com Date: Thursday, September 24, 2009, 11:56 AM =0A=0A=0AI think the general consensus is that is works fine in the standar d location (tunnel) if you can-accept some variability in flow indication s when the electric fuel pump is on.- With that being said, mine sits BEF ORE the flow divider on top of the air box in the picture below.- It is n ot flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFOR E the servo and-very stable.=0A=0A-=0Ahttp://wcurtis.nerv10.com/90Elect rical/EL2g.html=0A-=0AWilliam=0Ahttp://wcurtis.nerv10.com/=0A -=0AOn Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard wr ote: =0A As an informal survey for the rest of us, it would be interesting to get fe edback from those that have left it where Van's originally suggested. -Ar e any of you having any trouble with the transducer in that location? =0A How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish =0A Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 =0At Un/Subscription, www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matroni cs.com/Navigator?RV10-List =0Aronics.com/" target="_blank">http://forums.matronics.com Matt Dralle, List Admin. ==== =0A http://www.matronics.com/Navigator?RV10-Lisk" href="http://forums.matroni cs.com">http://forums.matronics.com gt; =0A=0A=0A=0A get="_blank">http://www.matronics.com/Navigator?RV10-List ttp://forums.matronics.com _blank">http://www.matronics.com/contribution =0A=0A Contribution Web Site - ________________________________________________________________________________
Date: Sep 24, 2009
Good discussion on fuel flow transducer mounting. Mine is between the engine boost pump and servo, working good @ 180 hours with very stable readings. IMHO they are better left free floating in the line where ever mounted in the engine compartment rather than hard mounted to the engine. I think hard mounting would transmit engine vibration directly into the sensor and might shorten it's life. Hard mounting also adds some additional heat input. The Flowscan instructions suggest floating in the line and wrapping with fire sleeve. Dick Sipp RV10 N110DV 180 hours ________________________________________________________________________________
Subject: Re: Ice
Date: Sep 24, 2009
As an A&P I have examined/studied the TKS, boots and bleed air solutions to the icing problem. The question is how much ice is too much. In the Midwest in the winter, a pilot might as well put the aircraft in storage if they only fly cross country in CAVU VFR in the mid western winter. As a CFII I am not suggesting that anyone challenge a strong winter storm; I do know that after the winter storm front passes that there is usually considerable overcast conditions behind the front where the overcast may be relatively low and may only be 1-2 thousand feet thick, Perhaps 1-2 minutes climb in the RV10. If the temperatures are below freezing then the overcast will probably contain rime ice which may or may not adhere to the aircraft. Once on top the ice will begin to sublimate away even though the temperatures are below freezing. A trip in the blue skies in smooth air is preferred over bumping along under the overcast (probable limited visibility) with potential of encountering some tall TV antennas. In OK there are two (1400 AGL and 1900 AGL) near Tulsa and three (all 1500 AGL) near the ILS into OK city. So poking around VFR underneath can also be hazardous. Lest we think that the heavy iron icing systems will save us; I can relate a personal experience of a pilot mechanic from Mesa AZ about three years ago. He was a pilot and mechanic flying a Aero commander twin turboprop with full de icing boots into Cortez Colorado. The aircraft was certified for known ice and he flew into icing in SW Colorado. The icing was severe and on his approach into Cortez his circle to land maneuver produced a stall spin and a crash near the airport. The SAR people found large amount of ice on the airframe. On that same day, same time a corporate jet at the flight levels encountered severe icing in the same area and made it to safety using its anti ice/deice systems. It did experience over $1M of aircraft damage due to ice striking the aircraft as the ice was leaving the aircraft In the 1970s I was scheduled to leave JEFF CO airport north of Denver in the winter. There was a major winter storm moving through. KS and MO had sleet and freezing rain. My father was complaining about needing to get back to work on Monday. He wanted to rent a car and drive to Peoria IL. I told him we were not flying since I did not want to die today. The next day we left and traveled East at about 11000 enroute. By MKC I could see the remnants of an overcast below me at about 3000 MSL. Upon our arrival in the Peoria area I informed my parents that we would probably pick up a little ice since we had to descend through a thin overcast into 3MY. Upon landing I parked and my parents deplaned. Mom said we did not get any ice. I took her over to the wing and had her place her hand on it as the heat of her hand melted the thin ice layer and water dripped on the ground. My point: Systems will not save you; judgment will. If you are not going to store the aircraft from October to April, then you will need to develop some judgment about what is flyable and what is not. An IFR rating and the ability to use it will be very helpful; ATC will give you any assistance you request short of flying the aircraft for you if you are on an IFR clearance. You may not get their attention if VFR unless you precede your call with a MAYDAY. Study the 1228H accident last week. Look at the NTSB report; look at the pilot data on the FAA files. Sometimes judgment develops from anothers accident. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Thursday, September 24, 2009 4:29 PM Subject: Re: RV10-List: Re: Ice One should never consider even being dispatched, if there were a chance for icing conditions. I fly for a living and I would never fly my RV-10 near ice. period How many lessons do we need to look back at to understand it is not worth the risk. Just me 2 cents, fly safe and have fun Thane States 321BY ----- Original Message ----- From: "Strasnuts" <sean(at)braunandco.com> Sent: Wednesday, September 23, 2009 11:54 AM Subject: RV10-List: Re: Ice > > You probably won't like my answer since my 10 is not flying, but > knowing if a plane (not made for icing) does kind of okay is probably > best not knowing. There have been several Cirrus aircraft that was > legal for inadvertent icing encounter and crashed from it. Now the > new Cirrus are certified for known icing. I fly a Citation Jet for a > company and maybe I don't know enough but you never can tell how much > ice is going to accumulate on the aircraft. I personally believe it > is a very hard question to answer and to try not to get in icing. If > you think the plane will do okay in it, it may persuade you to stay in > it. Having said all of that I have been in icing in a plane not made > for it. I got out of it as soon as I could. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264537#264537 > > > ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Fuel Flow Transducer Move
One thing I have just thought about and correct me if I'm wrong. From the f uel pump to the fuel pressure sending unit is up hill or above the fuel pum p. This being said if you get air in your hoses going to your pressure tran sducer from- being hot [vapor] then you could have a problem as to what i t is reporting. By having a compression of air instead of solid liquid. -Lets hear from the engineers. Patrick Thyssen Engine pickled again!!! for new instrument panel -Oh how I love OP --- On Thu, 9/24/09, McGann, Ron wrote: From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 5:28=0A PM au> Only 40 hours but same experience as Marcus.- Only irregluarity comes when the boost pump is engaged but the totaliser function always appears to reflect remaining fuel to within a gallon or so. Ron McGann Head of Engineering Security Solutions & Services Aerospace Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Friday, 25 September 2009 2:45 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move I have about 430 hours with the transducer in the plans location.- No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit=0A because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 DISCLAIMER:---------------------------------------------------------------- ----------- This e-mail transmission and any documents, files and previous e-mail messa ges attached to it are private and confidential. They may contain proprietary o r copyright material or information that is subject to legal professional privilege. Th ey are for the use of the intended recipient only.- Any unauthorised viewing, use, d isclosure, copying, alteration, storage or distribution of, or reliance on, this messa ge is strictly prohibited. No part may be reproduced,=0A adapted or transmitted w ithout the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by re turn email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be d eemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attac hed are error or virus free. --------------------------------------------------------------------------- ----------- le, List Admin. ________________________________________________________________________________
Subject: Re: Ice
Date: Sep 24, 2009
I've poked through fairly small clouds in the Citation over the Wasatch Mountains over Utah and picked up enough ice to create snail trails past the heated leading edge and cover the windshield despite the bleed air. The windshield gets covered a lot of the time but the leading edges usually take care of the ice on the wings. It took a short time to accumulate past the leading edge in this circumstance and I sure as hell wouldn't want to be in a plane without anti-ice or boots. This was during one hold on a gps approach that was about three total minutes in the cloud. After I did my missed, Salt Lake wanted me to go back to the hold and I told them unable due to severe icing. ----- Original Message ----- From: "David McNeill" <dlm46007(at)cox.net> Sent: Thursday, September 24, 2009 8:57 PM Subject: RE: RV10-List: Re: Ice > > As an A&P I have examined/studied the TKS, boots and bleed air solutions > to > the icing problem. The question is how much ice is too much. In the > Midwest > in the winter, a pilot might as well put the aircraft in storage if they > only fly cross country in CAVU VFR in the mid western winter. As a CFII I > am > not suggesting that anyone challenge a strong winter storm; I do know that > after the winter storm front passes that there is usually considerable > overcast conditions behind the front where the overcast may be relatively > low and may only be 1-2 thousand feet thick, Perhaps 1-2 minutes climb in > the RV10. If the temperatures are below freezing then the overcast will > probably contain rime ice which may or may not adhere to the aircraft. > Once > on top the ice will begin to sublimate away even though the temperatures > are > below freezing. A trip in the blue skies in smooth air is preferred over > bumping along under the overcast (probable limited visibility) with > potential of encountering some tall TV antennas. In OK there are two (1400 > AGL and 1900 AGL) near Tulsa and three (all 1500 AGL) near the ILS into OK > city. So poking around VFR underneath can also be hazardous. > > Lest we think that the heavy iron icing systems will save us; I can relate > a > personal experience of a pilot mechanic from Mesa AZ about three years > ago. > He was a pilot and mechanic flying a Aero commander twin turboprop with > full > de icing boots into Cortez Colorado. The aircraft was certified for known > ice and he flew into icing in SW Colorado. The icing was severe and on his > approach into Cortez his circle to land maneuver produced a stall spin and > a > crash near the airport. The SAR people found large amount of ice on the > airframe. On that same day, same time a corporate jet at the flight levels > encountered severe icing in the same area and made it to safety using its > anti ice/deice systems. It did experience over $1M of aircraft damage due > to > ice striking the aircraft as the ice was leaving the aircraft > > In the 1970s I was scheduled to leave JEFF CO airport north of Denver in > the > winter. There was a major winter storm moving through. KS and MO had sleet > and freezing rain. My father was complaining about needing to get back to > work on Monday. He wanted to rent a car and drive to Peoria IL. I told him > we were not flying since I did not want to die today. The next day we left > and traveled East at about 11000 enroute. By MKC I could see the remnants > of > an overcast below me at about 3000 MSL. Upon our arrival in the Peoria > area > I informed my parents that we would probably pick up a little ice since we > had to descend through a thin overcast into 3MY. Upon landing I parked and > my parents deplaned. Mom said we did not get any ice. I took her over to > the > wing and had her place her hand on it as the heat of her hand melted the > thin ice layer and water dripped on the ground. > > My point: Systems will not save you; judgment will. If you are not going > to > store the aircraft from October to April, then you will need to develop > some > judgment about what is flyable and what is not. An IFR rating and the > ability to use it will be very helpful; ATC will give you any assistance > you > request short of flying the aircraft for you if you are on an IFR > clearance. > You may not get their attention if VFR unless you precede your call with a > MAYDAY. Study the 1228H accident last week. Look at the NTSB report; look > at the pilot data on the FAA files. Sometimes judgment develops from > anothers accident. > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States > Sent: Thursday, September 24, 2009 4:29 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Ice > > > One should never consider even being dispatched, if there were a chance > for > icing conditions. I fly for a living and I would never fly my RV-10 near > ice. period How many lessons do we need to look back at to understand it > is > not worth the risk. > Just me 2 cents, fly safe and have fun > Thane States > 321BY > ----- Original Message ----- > From: "Strasnuts" <sean(at)braunandco.com> > To: > Sent: Wednesday, September 23, 2009 11:54 AM > Subject: RV10-List: Re: Ice > > >> >> You probably won't like my answer since my 10 is not flying, but >> knowing if a plane (not made for icing) does kind of okay is probably >> best not knowing. There have been several Cirrus aircraft that was >> legal for inadvertent icing encounter and crashed from it. Now the >> new Cirrus are certified for known icing. I fly a Citation Jet for a >> company and maybe I don't know enough but you never can tell how much >> ice is going to accumulate on the aircraft. I personally believe it >> is a very hard question to answer and to try not to get in icing. If >> you think the plane will do okay in it, it may persuade you to stay in >> it. Having said all of that I have been in icing in a plane not made >> for it. I got out of it as soon as I could. >> >> -------- >> Cust. #40936 >> RV-10 SB Fuselage >> N801VR reserved >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=264537#264537 >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Sep 24, 2009
Pressure is pressure, it's just the compressibility that is different. If the vapor were at 50psi, it would push down on the fuel at 50psi, and up on the fuel pressure sender at 50psi, and the fuel would transfer that pressure to the engine at 50psi. Doesn't matter if it's vapor, or what is in the line...it's just a diaphragm that is displaying pressure. Think of a manometer..it's using air and liquid to show air pressure, but inside the manometer is both air and liquid. It's all the same when it's pushing out against something else. If you have a pot of steaming water and you plug it, the steam will build up pressure, and if you puncture the bottom of the pot, the water will come out at whatever pressure the steam is at. So no, it shouldn't have an effect on the pressure reading. Tim Olson - RV-10 N104CD Patrick Thyssen wrote: > One thing I have just thought about and correct me if I'm wrong. From > the fuel pump to the fuel pressure sending unit is up hill or above the > fuel pump. This being said if you get air in your hoses going to your > pressure transducer from being hot [vapor] then you could have a > problem as to what it is reporting. > By having a compression of air instead of solid liquid. > Lets hear from the engineers. > > Patrick Thyssen > Engine pickled again!!! for new instrument panel > Oh how I love OP > > --- On *Thu, 9/24/09, McGann, Ron //* wrote: > > > From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au> > Subject: RE: RV10-List: Re: Fuel Flow Transducer Move > To: rv10-list(at)matronics.com > Date: Thursday, September 24, 2009, 5:28 PM > > > > Only 40 hours but same experience as Marcus. Only irregluarity comes > when the boost pump is engaged but the totaliser function always appears > to reflect remaining fuel to within a gallon or so. > > Ron McGann > > Head of Engineering > Security Solutions & Services > Aerospace > > Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper > Sent: Friday, 25 September 2009 2:45 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Fuel Flow Transducer Move > > > I have about 430 hours with the transducer in the plans location. No > real > issues although I do notice a slight FF drop when I turn the boost pump > off. > So far it has been very accurate and consistent. > > Marcus > 40286 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard > Sent: Thursday, September 24, 2009 12:05 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Fuel Flow Transducer Move > > > As an informal survey for the rest of us, it would be interesting to get > feedback from those that have left it where Van's originally suggested. > Are > any of you having any trouble with the transducer in that location? > > How many people have moved the unit because of inaccurate readings or > other > problems? > > -------- > Nick Leonard > RV-10 (40015) Finish > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=264706#264706 > > > > > > > > > > > > > > > > > > > > DISCLAIMER:--------------------------------------------------------------------------- > This e-mail transmission and any documents, files and previous > e-mail messages > attached to it are private and confidential. They may contain > proprietary or copyright > material or information that is subject to legal professional > privilege. They are for > the use of the intended recipient only. Any unauthorised viewing, > use, disclosure, > copying, alteration, storage or distribution of, or reliance on, > this message is > strictly prohibited. No part may be reproduced, adapted or > transmitted without the > written permission of the owner. If you have received this > transmission in error, or > are not an authorised recipient, please immediately notify the > sender by return email, > delete this message and all copies from your e-mail system, and > destroy any printed > copies. Receipt by anyone other than the intended recipient should > not be deemed a > waiver of any privilege or protection. Thales Australia does not > warrant or represent > that this e-mail or any documents, files and previous e-mail > messages attached are > error or virus free. > --------------------------------------------------------------------k" > href="http://www.matronics.com/Navigator?RV10-List">http://www.matroni="_blank" > href="http://forums.matronics.com">http://forums.matronics.co > -Matt Dralle, List blank" > href="http://www.matronics.com/contribution">http://www.matronics.================== > > > > * > > > * ________________________________________________________________________________
Date: Sep 24, 2009
Subject: Re: Chargers
Kinda reminded me of Aerosonic simulator last December when we went to talk to them. -Patrick Thyssen --- On Thu, 9/24/09, Strasnuts wrote: From: Strasnuts <sean(at)braunandco.com> Subject: RV10-List: Re: Chargers Date: Thursday, September 24, 2009, 9:17 PM This is going to be the way I secure my charger to my battery.- Only the best for my RV-10. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264861#264861 Attachments: http://forums.matronics.com//files/cid_bb830754_a37e_47b7_8a1a_8aa9c2caae31 _599.jpg le, List Admin. ________________________________________________________________________________
Date: Sep 25, 2009
That big old red hose goes to, you guessed it, the fuel pump on another eng ine I changed on a super Decath this year. There must be a reason for these things. -So I might think about putting a good cooling hose to help out on coolin g fuel. Patrick Thyssen --- On Thu, 9/24/09, Patrick Thyssen wrote: From: Patrick Thyssen <jump2(at)sbcglobal.net> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 10:17 PM One thing I have just thought about and correct me if I'm wrong. From the f uel pump to the fuel pressure sending unit is up hill or above the fuel pum p. This being said if you get air in your hoses going to your pressure tran sducer from- being hot [vapor] then you could have a problem as to what i t is reporting. By having a compression of air instead of solid liquid. -Lets hear from the engineers. Patrick Thyssen Engine pickled again!!! for new instrument panel -Oh how I love OP --- On Thu, 9/24/09, McGann, Ron wrote: From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au> Subject: RE: RV10-List: Re: Fuel Flow Transducer=0A Move Date: Thursday, September 24, 2009, 5:28=0A PM au> Only 40 hours but same experience as Marcus.- Only irregluarity comes when the boost pump is engaged but the totaliser function always appears to reflect remaining fuel to within a gallon or so. Ron McGann Head of Engineering Security Solutions & Services Aerospace Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Friday, 25 September 2009 2:45 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move I have about 430 hours with the transducer in the plans location.- No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in=0A that location? How many people have moved the unit=0A because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 DISCLAIMER:---------------------------------------------------------------- ----------- This e-mail transmission and any documents, files and previous e-mail messa ges attached to it are private and confidential. They may contain proprietary o r copyright material or information that is subject to legal professional privilege. Th ey are for the use of the intended recipient only.- Any unauthorised viewing, use, d isclosure, copying, alteration, storage or distribution of, or reliance on, this messa ge is strictly prohibited. No part may=0A be reproduced,=0A adapted or transmitte d without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by re turn email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be d eemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attac hed are error or virus free. --------------------------------------------------------------------k" href ="http://www.matronics.com/Navigator?RV10-List">http://www.matroni="_bl ank" href="http://forums.matronics.com">http://forums.matronics.co - - - - - - - - - - - - -Matt Dralle, List=0Ablank" hre f="http://www.matronics.com/contribution">http://www.matronics.=== =============== =0A ________________________________________________________________________________
Date: Sep 25, 2009
Here is another picture of a fuel pump on M7-235 Maule I changed earlier th is year. big red hose for airconditioning of fuel pump. Patrick Thyssen --- On Thu, 9/24/09, Patrick Thyssen wrote: From: Patrick Thyssen <jump2(at)sbcglobal.net> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 10:17 PM One thing I have just thought about and correct me if I'm wrong. From the f uel pump to the fuel pressure sending unit is up hill or above the fuel pum p. This being said if you get air in your hoses going to your pressure tran sducer from- being hot [vapor] then you could have a problem as to what i t is reporting. By having a compression of air instead of solid liquid. -Lets hear from the engineers. Patrick Thyssen Engine pickled again!!! for new instrument panel -Oh how I love OP --- On Thu, 9/24/09, McGann, Ron wrote: From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au> Subject: RE: RV10-List: Re: Fuel Flow Transducer=0A Move Date: Thursday, September 24, 2009, 5:28=0A PM au> Only 40 hours but same experience as Marcus.- Only irregluarity comes when the boost pump is engaged but the totaliser function always appears to reflect remaining fuel to within a gallon or so. Ron McGann Head of Engineering Security Solutions & Services Aerospace Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Friday, 25 September 2009 2:45 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move I have about 430 hours with the transducer in the plans location.- No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in=0A that location? How many people have moved the unit=0A because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 DISCLAIMER:---------------------------------------------------------------- ----------- This e-mail transmission and any documents, files and previous e-mail messa ges attached to it are private and confidential. They may contain proprietary o r copyright material or information that is subject to legal professional privilege. Th ey are for the use of the intended recipient only.- Any unauthorised viewing, use, d isclosure, copying, alteration, storage or distribution of, or reliance on, this messa ge is strictly prohibited. No part may=0A be reproduced,=0A adapted or transmitte d without the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by re turn email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be d eemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attac hed are error or virus free. --------------------------------------------------------------------k" href ="http://www.matronics.com/Navigator?RV10-List">http://www.matroni="_bl ank" href="http://forums.matronics.com">http://forums.matronics.co - - - - - - - - - - - - -Matt Dralle, List=0Ablank" hre f="http://www.matronics.com/contribution">http://www.matronics.=== =============== =0A ________________________________________________________________________________
Date: Sep 25, 2009
Ditto. Don McDonald --- On Thu, 9/24/09, Rene Felker wrote: From: Rene Felker <rene(at)felker.com> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 9:49 AM I left mine in the standard position.- I see very minor fluctuations....I do not think it is a problem. Rene' Felker RV-10 N423CF Flying 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 10:05 AM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested.- Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Sep 25, 2009
Patrick, Which statement(s) do you stand by? -Reading a 12 year old publication from JPI which documents the installation of a Flowscan transducer, NOT an EI red cube transducer? -Not using sealant on NPT fittings? ---really? why do you and JPI suggest not using sealant on NPT fittings? -Use of aluminum fittings on the transducer? You do realize that the EI red cube transducer is made of aluminum, right? Because I said I did not read the JPI manual, does not mean I did not read the EI or AFS installation manuals which are MUCH more updated. Why don't YOU take a look at the EI installation manual. You will find no such admonishment on using aluminum or 90 degree fittings. In fact, on page 5 you will see 45 degree and 90 degree fittings as approved for installation with the red cube. Here is a link to the EI fuel flow installation instructions. http://buy-ei.com/Information/II%20-%20FP-5.pdf William http://wcurtis.nerv10.com On Thu, Sep 24, 2009 at 10:40 PM, Patrick Thyssen wrote: > I'LL STAND BY MY STATEMENT WITH THE ADDED INSERT, EI MAKE INSTALLATION > MANUALS ALSO. THEY REFERENCE AC43-13 ALSO. YOUR LOSS FOR NOT READING > EVERYTHING YOU CAN. YOU WOULD LEARN A LOT MORE. > PATRICK THYSSEN > > > --- On *Thu, 9/24/09, William Curtis * wrote: > > > From: William Curtis <wcurtis(at)nerv10.com> > Subject: Re: RV10-List: Re: Fuel Flow Transducer Move > To: rv10-list(at)matronics.com > Date: Thursday, September 24, 2009, 3:10 PM > > Guess you did not read the caption above the photo regarding the aluminum > fitting. NPT fittings benefit from sealant, AN fittings do not. The inlet > to the flow transducer is NPT. As far as the 90 degree fitting out from the > transducer, well that's what I have now on the Cardinal and it works just > fine. The instrument I have in the Cardinal is Electronics International, > the OEM for the "red cube" transducer so no, I never read nor plan to read > the JPI manual. > > William > http://wcurtis.nerv10.com/ > > On Thu, Sep 24, 2009 at 2:47 PM, Patrick Thyssen wrote: > >> Question, Why the teflon tape or pipe sealent? Why aluminum fitting >> into the transducer? >> JP instruments and I suggest never ever use that stuff on the transducer. >> And it would be a lot better if you had a straight out fitting from the >> transducer. Not the ninety. Good book to read Is the JPI installation >> manual. I think it''s the second page where it says, read this first. >> But that just my opinion and we all have one. >> Patrick Thyssen >> >> But then I too made a mistake and bought OP Equiptment And now I'm fixing >> that. >> Dual 430w and garmin G500. Now I know they will work. >> >> >> --- On *Thu, 9/24/09, William Curtis * wrote: >> >> >> From: William Curtis <wcurtis(at)nerv10.com> >> Subject: Re: RV10-List: Re: Fuel Flow Transducer Move >> To: rv10-list(at)matronics.com >> Date: Thursday, September 24, 2009, 11:56 AM >> >> I think the general consensus is that is works fine in the standard >> location (tunnel) if you can accept some variability in flow indications >> when the electric fuel pump is on. With that being said, mine sits BEFORE >> the flow divider on top of the air box in the picture below. It is not >> flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE >> the servo and very stable. >> >> http://wcurtis.nerv10.com/90Electrical/EL2g.html >> >> William >> http://wcurtis.nerv10.com/ >> >> >> >> On Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard http://mc/compose?to=nick@nleonard.com> >> > wrote: >> >>> > >>> >>> As an informal survey for the rest of us, it would be interesting to get >>> feedback from those that have left it where Van's originally suggested. Are >>> any of you having any trouble with the transducer in that location? >>> >>> How many people have moved the unit because of inaccurate readings or >>> other problems? >>> >>> -------- >>> Nick Leonard >>> RV-10 (40015) Finish >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=264706#264706 >>> t Un/Subscription, >>> www.matronics.com/Navigator?RV10-List" target="_blank"> >>> http://www.matronics.com/Navigator?RV10-List >>> ronics.com/" target="_blank">http://forums.matronics.com >>> Matt Dralle, List Admin. >>> ==== >>> >>> >>> >>> >>> >> *http://www.matronics.com/Navigator?RV10-Lisk" href="http://forums.matronics.com">http://forums.matronics.com >> >> gt; <http://www.matronics.com/======%3Cbr%3E%3Cbr%3E%3C/font%3E%3C/b%3E%3Cfont+color=>* >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> ttp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> > ** > > * > > * > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Sep 25, 2009
Subject: Chargers
That seems to be the truth behind the marketing fluff. The "special" Odyssey chargers are no different from a multipurpose charger with an AGM mode. The main thing being that the AGM's are charged at 14.6 volts optimally. I also think that it's a must to have the desulphate capability to get the most life out of your battery, especially if you are regularly charging/discharging as in when you are playing with avionics. I would guess the Schumacher has it but can't tell for sure. Here's the link to the 12248: http://www.batteryminders.com/batterycharger/catalog/BatteryMINDer-12-Volt-2-4-or-8-Amp-Charger-Maintainer-Desulf-p-16133.html You can see the charging profiles under the "More Info" tab and in the instructions. There is a wealth of info in the instruction manual even if you don't use their chargers. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 24, 2009 4:24 PM Subject: Re: RV10-List: Chargers I watched the discussion on AeroElectric and read lots of things at other places about charging my Odyssey PC925, and spent a bunch of time reading before I bought a charger. Michael's right, that 12248 would eb a great way to go, and it's supposely got a great voltage curve for charging the Odyssey. What I did for myself though was a little different. I got a larger charger, that costs a bit more. I had been looking for Odyssey specific chargers, and wanted to make sure I did the best I could to charge at the right voltage. There is an Odyssey labeled charger that looks exactly like the Schumacher Speed Charge 1200A, which WalMart also sells. The difference I think is that the Odyssey doesn't have the variety of charging profiles. I got one off Ebay really really cheap, and got one at WalMart too, so now I use them at home and at the hangar. Here is a link: http://store.schumachermart.com/sc-1200a.html A few weeks ago I got fired up to verify that this was really the same, so I sent Schumacher an email asking if they had the same charge curve, and they said they were the same. I'm assuming I'd use AGM mode, so that's what I've been using. It's more expensive of a charger than you have to have, but it can charge other batteries too. I plug mine in sometimes if I have a big trip coming up, and want to ensure I've got a perfect charge, and I charge it during the winter when I don't fly as often. In the summer though, I generally don't charge it. I suppose I connect the charger maybe 10 times a year. Tim Olson - RV-10 N104CD RV Builder (Michael Sausen) wrote: > I'm using the BatteryMinder 12248 for my Odyssey batteries. There was > a write-up in one of the mags a few months back comparing different > chargers and this one looked to be the best. It will charge any style > lead acid battery and also desulphates. They will say on their site > that you should get their "special" charger for Odyssey batteries but it > only has a single profile in it for Odyssey AGM batteries. > > > > I spent a bunch of time looking at the information on the "special" > charger vs. the 12248 which will charge flooded, AGM, and gel batteries > and could not find a difference in the Odyssey vs. the AGM profiles that > made it worthwhile. I also run the Odyssey in my motorcycle and ATV but > I wanted the options and I have been very happy with it. > > > > Michael > > > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *Dawson-Townsend,Timothy > *Sent:* Thursday, September 24, 2009 11:26 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Chargers > > > > What are folks following for a battery-charging philosophy? I am using > Odyssey PC680s (who isn't?), and was wondering if folks are trickle > charging all the time when you're in the hangar, only when not expecting > to fly for a while, or only when it's winter, etc. > > > > Please share your thoughts. > > > TDT > > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * * > > * * > > ; - The RV10-List Email Forhref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.=============== > > < Same great content also available via the Web Forums! > > href="http://forums.matronics.com">http://forums.matronics.comhttp://www.matronics.com/con > > * * > > * > > > * ________________________________________________________________________________
Date: Sep 25, 2009
You can get a similar cooling shroud for the pump on the 360/540 series fro m here.... http://www.aircraftspruce.com/catalog/eppages/fuelpumps.php Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Patrick Thyssen Sent: Friday, September 25, 2009 2:35 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Here is another picture of a fuel pump on M7-235 Maule I changed earlier th is year. big red hose for airconditioning of fuel pump. Patrick Thyssen --- On Thu, 9/24/09, Patrick Thyssen wrote: From: Patrick Thyssen <jump2(at)sbcglobal.net> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 10:17 PM One thing I have just thought about and correct me if I'm wrong. From the f uel pump to the fuel pressure sending unit is up hill or above the fuel pum p. This being said if you get air in your hoses going to your pressure tran sducer from being hot [vapor] then you could have a problem as to what it is reporting. By having a compression of air instead of solid liquid. Lets hear from the engineers. Patrick Thyssen Engine pickled again!!! for new instrument panel Oh how I love OP --- On Thu, 9/24/09, McGann, Ron wrote: From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au> Subject: RE: RV10-List: Re: Fuel Flow Transducer Move Date: Thursday, September 24, 2009, 5:28 PM au> Only 40 hours but same experience as Marcus. Only irregluarity comes when the boost pump is engaged but the totaliser function always appears to reflect remaining fuel to within a gallon or so. Ron McGann Head of Engineering Security Solutions & Services Aerospace Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper Sent: Friday, 25 September 2009 2:45 AM Subject: RE: RV10-List: Re: Fuel Flow Transducer Move I have about 430 hours with the transducer in the plans location. No real issues although I do notice a slight FF drop when I turn the boost pump off. So far it has been very accurate and consistent. Marcus 40286 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nick Leonard Sent: Thursday, September 24, 2009 12:05 PM Subject: RV10-List: Re: Fuel Flow Transducer Move As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested. Are any of you having any trouble with the transducer in that location? How many people have moved the unit because of inaccurate readings or other problems? -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264706#264706 DISCLAIMER:---------------------------------------------------------------- ----------- This e-mail transmission and any documents, files and previous e-mail messa ges attached to it are private and confidential. They may contain proprietary o r copyright material or information that is subject to legal professional privilege. Th ey are for the use of the intended recipient only. Any unauthorised viewing, use, dis closure, copying, alteration, storage or distribution of, or reliance on, this messa ge is strictly prohibited. No part may be reproduced, adapted or transmitted with out the written permission of the owner. If you have received this transmission in error, or are not an authorised recipient, please immediately notify the sender by re turn email, delete this message and all copies from your e-mail system, and destroy any printed copies. Receipt by anyone other than the intended recipient should not be d eemed a waiver of any privilege or protection. Thales Australia does not warrant or represent that this e-mail or any documents, files and previous e-mail messages attac hed are error or virus free. --------------------------------------------------------------------k" href ="http://www.matronics.com/Navigator?RV10-List">http://www.matroni="_bl ank" href="http://forums.matronics.com">http://forums.matronics.co -Matt Dralle, List blank" href="http://www.matronics.co m/contribution">http://www.matronics.============ ====== ________________________________________________________________________________
Subject: Chargers
Date: Sep 25, 2009
It appears that the best price is: http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200326706 _200326706?cm_mmc=housefile-_-recd-_-phone-_-conf -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Friday, September 25, 2009 6:52 AM Subject: RE: RV10-List: Chargers --> That seems to be the truth behind the marketing fluff. The "special" Odyssey chargers are no different from a multipurpose charger with an AGM mode. The main thing being that the AGM's are charged at 14.6 volts optimally. I also think that it's a must to have the desulphate capability to get the most life out of your battery, especially if you are regularly charging/discharging as in when you are playing with avionics. I would guess the Schumacher has it but can't tell for sure. Here's the link to the 12248: http://www.batteryminders.com/batterycharger/catalog/BatteryMINDer-12-Volt-2 -4-or-8-Amp-Charger-Maintainer-Desulf-p-16133.html You can see the charging profiles under the "More Info" tab and in the instructions. There is a wealth of info in the instruction manual even if you don't use their chargers. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 24, 2009 4:24 PM Subject: Re: RV10-List: Chargers I watched the discussion on AeroElectric and read lots of things at other places about charging my Odyssey PC925, and spent a bunch of time reading before I bought a charger. Michael's right, that 12248 would eb a great way to go, and it's supposely got a great voltage curve for charging the Odyssey. What I did for myself though was a little different. I got a larger charger, that costs a bit more. I had been looking for Odyssey specific chargers, and wanted to make sure I did the best I could to charge at the right voltage. There is an Odyssey labeled charger that looks exactly like the Schumacher Speed Charge 1200A, which WalMart also sells. The difference I think is that the Odyssey doesn't have the variety of charging profiles. I got one off Ebay really really cheap, and got one at WalMart too, so now I use them at home and at the hangar. Here is a link: http://store.schumachermart.com/sc-1200a.html A few weeks ago I got fired up to verify that this was really the same, so I sent Schumacher an email asking if they had the same charge curve, and they said they were the same. I'm assuming I'd use AGM mode, so that's what I've been using. It's more expensive of a charger than you have to have, but it can charge other batteries too. I plug mine in sometimes if I have a big trip coming up, and want to ensure I've got a perfect charge, and I charge it during the winter when I don't fly as often. In the summer though, I generally don't charge it. I suppose I connect the charger maybe 10 times a year. Tim Olson - RV-10 N104CD RV Builder (Michael Sausen) wrote: > I'm using the BatteryMinder 12248 for my Odyssey batteries. There > was a write-up in one of the mags a few months back comparing > different chargers and this one looked to be the best. It will charge > any style lead acid battery and also desulphates. They will say on > their site that you should get their "special" charger for Odyssey > batteries but it only has a single profile in it for Odyssey AGM batteries. > > > > I spent a bunch of time looking at the information on the "special" > charger vs. the 12248 which will charge flooded, AGM, and gel > batteries and could not find a difference in the Odyssey vs. the AGM > profiles that made it worthwhile. I also run the Odyssey in my > motorcycle and ATV but I wanted the options and I have been very happy with it. > > > > Michael > > > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of > *Dawson-Townsend,Timothy > *Sent:* Thursday, September 24, 2009 11:26 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Chargers > > > > What are folks following for a battery-charging philosophy? I am > using Odyssey PC680s (who isn't?), and was wondering if folks are > trickle charging all the time when you're in the hangar, only when not > expecting to fly for a while, or only when it's winter, etc. > > > > Please share your thoughts. > > > TDT > > > > Tim Dawson-Townsend > > Aurora Flight Sciences > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > > > * * > > * * > > ; - The RV10-List Email Forhref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. =============== > > < Same great content also available via the Web Forums! > > href="http://forums.matronics.com">http://forums.matronics.comhttp://w > ww.matronics.com/con > > * * > > * > > > * ________________________________________________________________________________
Subject: Door hinges
Date: Sep 25, 2009
A heads up on the door hinges. If you read the plans carefully, you'll find a confusing error. They show the left door hinges with the proper parts call out. When the plans say to repeat the steps for the right door, if you where to use the same parts call out, they would be reversed. It was obvious that something was wrong, but I wasn't sure which door was wrong. I called Scott at Vans and he went out to the company's RV10 and took pictures and emailed me them. The call out for the left door is correct, that is the lower part of the hinge should face the center of the door, as the plans show. The right door should just mirror image the left, although the part numbers are reversed. Better safe than sorry, so I always check when something doesn't compute. Thanks to Scott for his prompt help, and not laughing at me for requiring clarification for something as probably obvious to most. Chris Hukill Trying to close the door on all this fiberglass work! ________________________________________________________________________________
Subject: Re: Door hinges
Date: Sep 25, 2009
have fun getting the doors to fit now! From: Chris Hukill Sent: Friday, September 25, 2009 8:27 AM Subject: RV10-List: Door hinges A heads up on the door hinges. If you read the plans carefully, you'll find a confusing error. They show the left door hinges with the proper parts call out. When the plans say to repeat the steps for the right door, if you where to use the same parts call out, they would be reversed. It was obvious that something was wrong, but I wasn't sure which door was wrong. I called Scott at Vans and he went out to the company's RV10 and took pictures and emailed me them. The call out for the left door is correct, that is the lower part of the hinge should face the center of the door, as the plans show. The right door should just mirror image the left, although the part numbers are reversed. Better safe than sorry, so I always check when something doesn't compute. Thanks to Scott for his prompt help, and not laughing at me for requiring clarification for something as probably obvious to most. Chris Hukill Trying to close the door on all this fiberglass work! ________________________________________________________________________________
Date: Sep 25, 2009
I was checking the Schumacher manual today on the SC-1200A and it does show that it has a desulphate mode. Doesn't look like it's used as part of a normal charge cycle though. I'm not totally sure of the details on it. I did remember that the one that is often mentioned on Aeroelectric is the one referred to in these 2 clippings from 2008 that i'll repost: --------------------- "Yeah, I saw those a couple of days ago at WallyWorld. I've got one of the older versions and did extensive testing that showed this little guy was about 2x faster than the Battery-Minder/Battery-Tender wall-wart crowd (0.8A versus 1.5A recharge) and equally as "smart" with at less than 2/3 the price. My favorite of the small guys. Bob . . . " "New number is SEM-1562A old # was WM-1562A" ---------------------- Tim RV Builder (Michael Sausen) wrote: > > > That seems to be the truth behind the marketing fluff. The "special" > Odyssey chargers are no different from a multipurpose charger with an > AGM mode. The main thing being that the AGM's are charged at 14.6 > volts optimally. > > I also think that it's a must to have the desulphate capability to > get the most life out of your battery, especially if you are > regularly charging/discharging as in when you are playing with > avionics. I would guess the Schumacher has it but can't tell for > sure. Here's the link to the 12248: > > http://www.batteryminders.com/batterycharger/catalog/BatteryMINDer-12-Volt-2-4-or-8-Amp-Charger-Maintainer-Desulf-p-16133.html > > > You can see the charging profiles under the "More Info" tab and in > the instructions. There is a wealth of info in the instruction > manual even if you don't use their chargers. > > Michael > > -----Original Message----- From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Thursday, September 24, 2009 4:24 PM To: > rv10-list(at)matronics.com Subject: Re: RV10-List: Chargers > > > I watched the discussion on AeroElectric and read lots of things at > other places about charging my Odyssey PC925, and spent a bunch of > time reading before I bought a charger. Michael's right, that 12248 > would eb a great way to go, and it's supposely got a great voltage > curve for charging the Odyssey. > > What I did for myself though was a little different. I got a larger > charger, that costs a bit more. I had been looking for Odyssey > specific chargers, and wanted to make sure I did the best I could to > charge at the right voltage. There is an Odyssey labeled charger > that looks exactly like the Schumacher Speed Charge 1200A, which > WalMart also sells. The difference I think is that the Odyssey > doesn't have the variety of charging profiles. I got one off Ebay > really really cheap, and got one at WalMart too, so now I use them at > home and at the hangar. > > Here is a link: > > http://store.schumachermart.com/sc-1200a.html > > A few weeks ago I got fired up to verify that this was really the > same, so I sent Schumacher an email asking if they had the same > charge curve, and they said they were the same. I'm assuming I'd use > AGM mode, so that's what I've been using. It's more expensive of a > charger than you have to have, but it can charge other batteries too. > > > I plug mine in sometimes if I have a big trip coming up, and want to > ensure I've got a perfect charge, and I charge it during the winter > when I don't fly as often. In the summer though, I generally don't > charge it. I suppose I connect the charger maybe 10 times a year. > > Tim Olson - RV-10 N104CD > > > > RV Builder (Michael Sausen) wrote: >> I'm using the BatteryMinder 12248 for my Odyssey batteries. There >> was a write-up in one of the mags a few months back comparing >> different chargers and this one looked to be the best. It will >> charge any style lead acid battery and also desulphates. They will >> say on their site that you should get their "special" charger for >> Odyssey batteries but it only has a single profile in it for >> Odyssey AGM batteries. >> >> >> >> I spent a bunch of time looking at the information on the "special" >> charger vs. the 12248 which will charge flooded, AGM, and gel >> batteries and could not find a difference in the Odyssey vs. the >> AGM profiles that made it worthwhile. I also run the Odyssey in my >> motorcycle and ATV but I wanted the options and I have been very >> happy with it. >> >> >> >> Michael >> >> >> >> *From:* owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of >> *Dawson-Townsend,Timothy *Sent:* Thursday, September 24, 2009 11:26 >> AM *To:* rv10-list(at)matronics.com *Subject:* RV10-List: Chargers >> >> >> >> What are folks following for a battery-charging philosophy? I am >> using Odyssey PC680s (who isn't?), and was wondering if folks are >> trickle charging all the time when you're in the hangar, only when >> not expecting to fly for a while, or only when it's winter, etc. >> >> >> >> Please share your thoughts. >> >> >> TDT >> >> >> >> Tim Dawson-Townsend >> >> Aurora Flight Sciences >> >> tdt(at)aurora.aero >> >> 617-500-4812 (office) >> >> 617-905-4800 (mobile) >> >> >> >> * * >> >> * * >> >> ; - The RV10-List Email >> Forhref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.=============== >> >> >> < Same great content also available via the Web Forums! >> >> href="http://forums.matronics.com">http://forums.matronics.comhttp://www.matronics.com/con >> >> >> * * >> >> * >> >> >> * > > > > > > > > > > > ________________________________________________________________________________
Date: Sep 25, 2009
Hi Save yourself some grief and fit you doors with the seals on. The geometry changes after the seals are in place. Cheers Les #40643 - Living in f/g hell _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: September-25-09 10:11 AM Subject: Re: RV10-List: Door hinges have fun getting the doors to fit now! From: Chris Hukill <mailto:cjhukill(at)cox.net> Sent: Friday, September 25, 2009 8:27 AM Subject: RV10-List: Door hinges A heads up on the door hinges. If you read the plans carefully, you'll find a confusing error. They show the left door hinges with the proper parts call out. When the plans say to repeat the steps for the right door, if you where to use the same parts call out, they would be reversed. It was obvious that something was wrong, but I wasn't sure which door was wrong. I called Scott at Vans and he went out to the company's RV10 and took pictures and emailed me them. The call out for the left door is correct, that is the lower part of the hinge should face the center of the door, as the plans show. The right door should just mirror image the left, although the part numbers are reversed. Better safe than sorry, so I always check when something doesn't compute. Thanks to Scott for his prompt help, and not laughing at me for requiring clarification for something as probably obvious to most. Chris Hukill Trying to close the door on all this fiberglass work! href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Sep 25, 2009
Hi Again For clarity - I mean after the hinges are installed and you are working on fitting the door so that the gaps etc are correct. ..L _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: September-25-09 10:40 AM Subject: RE: RV10-List: Door hinges Hi Save yourself some grief and fit you doors with the seals on. The geometry changes after the seals are in place. Cheers Les #40643 - Living in f/g hell _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: September-25-09 10:11 AM Subject: Re: RV10-List: Door hinges have fun getting the doors to fit now! From: Chris Hukill <mailto:cjhukill(at)cox.net> Sent: Friday, September 25, 2009 8:27 AM Subject: RV10-List: Door hinges A heads up on the door hinges. If you read the plans carefully, you'll find a confusing error. They show the left door hinges with the proper parts call out. When the plans say to repeat the steps for the right door, if you where to use the same parts call out, they would be reversed. It was obvious that something was wrong, but I wasn't sure which door was wrong. I called Scott at Vans and he went out to the company's RV10 and took pictures and emailed me them. The call out for the left door is correct, that is the lower part of the hinge should face the center of the door, as the plans show. The right door should just mirror image the left, although the part numbers are reversed. Better safe than sorry, so I always check when something doesn't compute. Thanks to Scott for his prompt help, and not laughing at me for requiring clarification for something as probably obvious to most. Chris Hukill Trying to close the door on all this fiberglass work! href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Sep 25, 2009
I too looked very carefully at this section, before deciding the instructions are correct. You'll notice they refer to the hinges as "left" and "right", not fore and aft. The "left" and "right" are correct for both doors (as you face them); obviously, "fore" and "aft" are reversed as you move to the right hand door. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=264968#264968 ________________________________________________________________________________
Subject: Chargers
Date: Sep 25, 2009
If using the BM 12248, each battery on board will have to be maintained separately, since it appears to need to sense the voltage of the battery. The easiest way it seems to do this is establish a DC receptacles that uses ring terminals across the battery posts. Then alternate as required
September 14, 2009 - September 25, 2009
RV10-Archive.digest.vol-fa
