RV10-Archive.digest.vol-fc
September 28, 2009 - October 04, 2009
Subject: door
Date: Sep 28, 2009
IDENTIFICATION Regis#: 78MU Make/Model: EXP Description: RV-10 Date: 09/26/2009 Time: 1827 Event Type: Incident Highest Injury: None Mid Air: N Missing: N Damage: Minor LOCATION City: JEFFERSON CITY State: MO Country: US DESCRIPTION AIRCRAFT ON TAKEOFF, PASSENGER DOOR SEPARATED FROM AIRCRAFT, LANDED WITHOUT INCIDENT, JEFFERSON CITY, MO INJURY DATA Total Fatal: 0 # Crew: 1 Fat: 0 Ser: 0 Min: 0 Unk: # Pass: 1 Fat: 0 Ser: 0 Min: 0 Unk: # Grnd: Fat: 0 Ser: 0 Min: 0 Unk: WEATHER: SCT029 BKN045 260/08G15 10SM A2995 ttp://www.matronics.com/Navigator?RV10-List ronics.com ww.matronics.com/contribution _____ Insert movie times and more without leaving HotmailR. See how. <http://windowslive.com/Tutorial/Hotmail/QuickAdd?ocid=TXT_TAGLM_WL_HM_Tutor ial_QuickAdd_062009> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List a>http://forums.matronics.com ======== = _blank">http://www.matronics.com/contribution ________________________________________________________________________________
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com>
Subject: Door bulge
Date: Sep 29, 2009
Makes one wonder if a spring loaded latch pin engaging through the sill vertically at the center of the door would help. Visualize a door latch, that is flat on one side (to facilitate latching) and rounded on the other. It would make getting out of the plane a "two-latch" affair, but may prevent the in-air mating of a door to the horizontal stab... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah Colliver Sent: Tuesday, September 29, 2009 10:36 AM Subject: RV10-List: Door bulge Here is an air to air pic + enlargement. Speed was only about 110 knts max as the photo ship was a C182. On the ground the door is perfectly flush all around, with no visible bulge at the leading edge, nor at the bottom. In flight I have not noticed it moving out, but we have a thick lining material there. But the bulge is definitely visible in these pics. Our pins go right into the frame as per Vans instructions, but it serves as a reminder to ensure that the front pins have plenty of engagement. We also have the Vans door warning system and that hasn't illumintated in flight. Nor is there any feeling of a draught at all, so the seals obviously do their job well. Neil ________________________________________________________________________________
Date: Sep 29, 2009
Subject: Re: Door bulge
One RV-10 at OSH had just what you suggest. Owner had door come open and off before rotation, and was able to abort, and door did not hit anything to damage airframe. He was not about to have a second event, so put latch with clevis pins vertically through bottom of each door. I don't think I got a picture, but if I look, I can get the tail number. Bob and Karen Brown wrote: > > Makes one wonder if a spring loaded latch pin engaging through the sill > vertically at the center of the door would help. Visualize a door latch, > that is flat on one side (to facilitate latching) and rounded on the other. > It would make getting out of the plane a "two-latch" affair, but may prevent > the in-air mating of a door to the horizontal stab... > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah > Colliver > Sent: Tuesday, September 29, 2009 10:36 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Door bulge > > Here is an air to air pic + enlargement. > > Speed was only about 110 knts max as the photo ship was a C182. > > On the ground the door is perfectly flush all around, with no visible > bulge at the leading edge, nor at the bottom. > > In flight I have not noticed it moving out, but we have a thick lining > material there. But the bulge is definitely visible in these pics. Our > pins go right into the frame as per Vans instructions, but it serves > as a reminder to ensure that the front pins have plenty of engagement. > We also have the Vans door warning system and that hasn't illumintated > in flight. > > Nor is there any feeling of a draught at all, so the seals obviously > do their job well. > > Neil > > > > > > ________________________________________________________________________________
Subject: Re: High Oil temps
Date: Sep 29, 2009
Group... Trying to understand how prevalent of a problem high oil temps are with the -10. I've purchased the 2006x from Airflow. I'm in Iowa so definitely don't have the temps of AZ but daughter is in San Antonio and make that trip a few times a year. It'd sure be easier to deal with now while building instead of later if I'm going to have to. Thoughts? Doug -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265651#265651 ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Sep 29, 2009
Doug, I live in Omaha and almost always see oil temps of 195-197. I flew down to San Antonio in mid August and saw 210 during climbout down there but the temp came down during cruise. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Tue Sep 29 22:23:48 2009 Subject: RV10-List: Re: High Oil temps Group... Trying to understand how prevalent of a problem high oil temps are with the -10. I've purchased the 2006x from Airflow. I'm in Iowa so definitely don't have the temps of AZ but daughter is in San Antonio and make that trip a few times a year. It'd sure be easier to deal with now while building instead of later if I'm going to have to. Thoughts? Doug -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265651#265651 ________________________________________________________________________________
Subject: Door bulge
Date: Sep 29, 2009
Here it is. Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Tuesday, September 29, 2009 7:58 PM Subject: Re: RV10-List: Door bulge One RV-10 at OSH had just what you suggest. Owner had door come open and off before rotation, and was able to abort, and door did not hit anything to damage airframe. He was not about to have a second event, so put latch with clevis pins vertically through bottom of each door. I don't think I got a picture, but if I look, I can get the tail number. Bob and Karen Brown wrote: > > Makes one wonder if a spring loaded latch pin engaging through the sill > vertically at the center of the door would help. Visualize a door latch, > that is flat on one side (to facilitate latching) and rounded on the other. > It would make getting out of the plane a "two-latch" affair, but may prevent > the in-air mating of a door to the horizontal stab... > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Neil & Sarah > Colliver > Sent: Tuesday, September 29, 2009 10:36 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Door bulge > > Here is an air to air pic + enlargement. > > Speed was only about 110 knts max as the photo ship was a C182. > > On the ground the door is perfectly flush all around, with no visible > bulge at the leading edge, nor at the bottom. > > In flight I have not noticed it moving out, but we have a thick lining > material there. But the bulge is definitely visible in these pics. Our > pins go right into the frame as per Vans instructions, but it serves > as a reminder to ensure that the front pins have plenty of engagement. > We also have the Vans door warning system and that hasn't illumintated > in flight. > > Nor is there any feeling of a draught at all, so the seals obviously > do their job well. > > Neil > > > > > > ________________________________________________________________________________
Subject: Re: door
Date: Sep 29, 2009
Thanks DLM and David -- either a tapped screw or cotter key is better than what I've got now and I will replace them. R.e. the bulging door problem, I like the idea of the baggage door type lock in the middle of the doors, rotating into a slot in the bottom sill -- if that can be operated from the inside, that would do double duty. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting done! On with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265664#265664 ________________________________________________________________________________
Subject: Re: door
Date: Sep 29, 2009
I don't recall who had the bulging door but it may be due to insufficient epoxy inside the two halves of the door. No one else seems to have the bulging door problem and it would seem that the door is flexing outward, probably because of insufficient stiffness in the lower door , fore to aft. Another possibility is that the door is too wide for the opening and although the pins engage, they are not a single pin and therefore bow outward at the latch mechanism. Another possibility for the outward flex is insufficient stiffness and a low pressure area since if the fuselage is viewed from above the entire fuselage does have an airfoil shape. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Tuesday, September 29, 2009 8:37 PM Subject: RV10-List: Re: door Thanks DLM and David -- either a tapped screw or cotter key is better than what I've got now and I will replace them. R.e. the bulging door problem, I like the idea of the baggage door type lock in the middle of the doors, rotating into a slot in the bottom sill -- if that can be operated from the inside, that would do double duty. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting done! On with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265664#265664 ________________________________________________________________________________
Date: Sep 30, 2009
N220RV - the factory Continental equipped RV10 has a nice latch system. I do not know when it was installed but it is a spring loaded mid door latch -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265684#265684 Attachments: http://forums.matronics.com//files/p8122689_213.jpg ________________________________________________________________________________
Date: Sep 30, 2009
Doug, I built my airplane in MN and now live in FL. I will see temps around 200 degrees in climb to altitude in FL summer temps. Temps come back down to 180-185 in cruise. I have the 2006x oil cooler. Prolonged slow flight will also cause temps to slowly come back up to around 200. David Maib 40559 Flying On Sep 29, 2009, at 10:23 PM, n277dl wrote: Group... Trying to understand how prevalent of a problem high oil temps are with the -10. I've purchased the 2006x from Airflow. I'm in Iowa so definitely don't have the temps of AZ but daughter is in San Antonio and make that trip a few times a year. It'd sure be easier to deal with now while building instead of later if I'm going to have to. Thoughts? Doug -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265651#265651 ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
The strap, made out of the right material, is strong enough for secondary. It has been tested on a strap made out of leather with 2.5 layers stitched together. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Sep 29, 2009, at 5:54 PM, John Jessen wrote: > Sad to see that the door issue has come back to the fore. If I > recall, this was on my list of issues that got slammed awhile back. > Looking forward to a tested solution that involves both a primary > and secondary latch, such as autos have. Would the strap be strong > enough for secondary? Not sure. I think Tim James has designed > such. John Cox, do you remember Tim's solution? Maybe I can get > out to his hanger and take some pics. > > John J > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Monday, September 28, 2009 2:50 PM > To: rv10-list(at)matronics.com > Subject: Re: FW: RV10-List: door > > It's really essential that everyone have some improved way of > keeping the doors closed: our metal door blocks are one way, buy > you could also make your own, get Rivetheads, use a strap or > something. This is happening a LOT and it's only a matter of time > until the results are very bad. > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Mon, Sep 28, 2009 at 2:02 PM, David McNeill > wrote: > > > I believe you may be referring to 416EC; I think the number has now > been changed and the aircraft sold. I don't rely on a system. I > close the doors and check the pins both fore and aft, both sides, > when we load and before takeoff. > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Danny Riggs > Sent: Monday, September 28, 2009 12:21 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: door > > That kinda sucks! I've been working on the door latches over the > weekend and thinking about the last time I saw this happen. The > landing was real firm and the front end was twisted up to the > firewall. > > From: dlm46007(at)cox.net > To: rv10-list(at)matronics.com > Subject: RV10-List: door > Date: Mon, 28 Sep 2009 11:30:43 -0700 > > > IDENTIFICATION > Regis#: 78MU Make/Model: EXP Description: RV-10 > Date: 09/26/2009 Time: 1827 > > Event Type: Incident Highest Injury: None Mid Air: N > Missing: N > Damage: Minor > > LOCATION > City: JEFFERSON CITY State: MO Country: US > > DESCRIPTION > AIRCRAFT ON TAKEOFF, PASSENGER DOOR SEPARATED FROM AIRCRAFT, > LANDED WITHOUT > INCIDENT, JEFFERSON CITY, MO > > INJURY DATA Total Fatal: 0 > # Crew: 1 Fat: 0 Ser: 0 Min: > 0 Unk: > # Pass: 1 Fat: 0 Ser: 0 Min: > 0 Unk: > # Grnd: Fat: 0 Ser: 0 Min: > 0 Unk: > > WEATHER: SCT029 BKN045 260/08G15 10SM A2995 > > > ttp://www.matronics.com/Navigator?RV10-List > ronics.com > ww.matronics.com/contribution > > > Insert movie times and more without leaving Hotmail=AE. See how. > > > href="http://www.matronics.com/Navigator?RV10-List">http:// > www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > > > a>http://forums.matronics.com > ======== > = > _blank">http://www.matronics.com/contribution > > > href="http://www.matronics.com/Navigator?RV10-List">http:// > www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
My build partner, a glass guy, put one layer of carbon fiber in between the door halves. It's very stiff now...but still considering the middle latch option... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Tuesday, September 29, 2009 9:08 PM Subject: RE: RV10-List: Re: door I don't recall who had the bulging door but it may be due to insufficient epoxy inside the two halves of the door. No one else seems to have the bulging door problem and it would seem that the door is flexing outward, probably because of insufficient stiffness in the lower door , fore to aft. Another possibility is that the door is too wide for the opening and although the pins engage, they are not a single pin and therefore bow outward at the latch mechanism. Another possibility for the outward flex is insufficient stiffness and a low pressure area since if the fuselage is viewed from above the entire fuselage does have an airfoil shape. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Tuesday, September 29, 2009 8:37 PM Subject: RV10-List: Re: door Thanks DLM and David -- either a tapped screw or cotter key is better than what I've got now and I will replace them. R.e. the bulging door problem, I like the idea of the baggage door type lock in the middle of the doors, rotating into a slot in the bottom sill -- if that can be operated from the inside, that would do double duty. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Painting done! On with wiring and avionics. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265664#265664 ________________________________________________________________________________
Subject: Re: Before Closing Up The Bottom Skins?
Date: Sep 30, 2009
Pat, I did the same thing Bill did, except my wife shot the rivets, so I didn't need the safety wire thing. My cradle looks just like his. Bill's advice on trimming the skins so they don't touch is the most important part. It took about a dozen frustrating fittings and filings before I riveted. No oil canning. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265708#265708 ________________________________________________________________________________
Date: Sep 30, 2009
Is this Van's answer to their door design? I think they should make this modification available to all builders as a standard build item. Has anyone talked with Van's about this mod? Rick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265710#265710 ________________________________________________________________________________
Date: Sep 30, 2009
Subject: Re: door
Jesse, Do you have a picture of the strap (in its installed and functioning position) that you could post? Dave Lammers Jesse Saint wrote: > The strap, made out of the right material, is strong enough for > secondary. It has been tested on a strap made out of leather with 2.5 > layers stitched together. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Sep 29, 2009, at 5:54 PM, John Jessen wrote: > >> Sad to see that the door issue has come back to the fore. If I >> recall, this was on my list of issues that got slammed awhile back. >> Looking forward to a tested solution that involves both a primary and >> secondary latch, such as autos have. Would the strap be strong >> enough for secondary? Not sure. I think Tim James has designed >> such. John Cox, do you remember Tim's solution? Maybe I can get out >> to his hanger and take some pics. >> >> John J >> >> ------------------------------------------------------------------------ >> *From:* owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Dave Saylor >> *Sent:* Monday, September 28, 2009 2:50 PM >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: FW: RV10-List: door >> >> It's really essential that everyone have some improved way of keeping >> the doors closed: our metal door blocks are one way, buy you could >> also make your own, get Rivetheads, use a strap or something. This >> is happening a LOT and it's only a matter of time until the results >> are very bad. >> >> Dave Saylor >> AirCrafters LLC >> 140 Aviation Way >> Watsonville, CA 95076 >> 831-722-9141 Shop >> 831-750-0284 Cell >> >> >> On Mon, Sep 28, 2009 at 2:02 PM, David McNeill > > wrote: >> >> >> >> >> >> I believe you may be referring to 416EC; I think the number has >> now been changed and the aircraft sold. I don't rely on a system. >> I close the doors and check the pins both fore and aft, both >> sides, when we load and before takeoff. >> ------------------------------------------------------------------------ >> *From:* owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com >> ] *On Behalf Of >> *Danny Riggs >> *Sent:* Monday, September 28, 2009 12:21 PM >> *To:* rv10-list(at)matronics.com >> *Subject:* RE: RV10-List: door >> >> That kinda sucks! I've been working on the door latches over >> the weekend and thinking about the last time I saw this happen. >> The landing was real firm and the front end was twisted up to the >> firewall. >> >> ------------------------------------------------------------------------ >> From: dlm46007(at)cox.net <mailto:dlm46007(at)cox.net> >> To: rv10-list(at)matronics.com >> Subject: RV10-List: door >> Date: Mon, 28 Sep 2009 11:30:43 -0700 >> >> >> IDENTIFICATION >> Regis#: 78MU Make/Model: EXP Description: RV-10 >> Date: 09/26/2009 Time: 1827 >> >> Event Type: Incident Highest Injury: None Mid Air: N >> Missing: N >> Damage: Minor >> >> LOCATION >> City: JEFFERSON CITY State: MO Country: US >> >> DESCRIPTION >> AIRCRAFT ON TAKEOFF, PASSENGER DOOR SEPARATED FROM AIRCRAFT, >> LANDED WITHOUT >> INCIDENT, JEFFERSON CITY, MO >> >> INJURY DATA Total Fatal: 0 >> # Crew: 1 Fat: 0 Ser: 0 Min: >> 0 Unk: >> # Pass: 1 Fat: 0 Ser: 0 Min: >> 0 Unk: >> # Grnd: Fat: 0 Ser: 0 Min: >> 0 Unk: >> >> WEATHER: SCT029 BKN045 260/08G15 10SM A2995 >> >> * >> >> ttp://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> >> ronics.com <http://ronics.com/> >> ww.matronics.com/contribution <http://ww.matronics.com/contribution> >> >> * >> >> >> ------------------------------------------------------------------------ >> Insert movie times and more without leaving Hotmail. See how. >> <http://windowslive.com/Tutorial/Hotmail/QuickAdd?ocid=TXT_TAGLM_WL_HM_Tutorial_QuickAdd_062009> >> >> >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com ">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> a>http://forums.matronics.com >> ======== >> = >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> * > > * > > > * ________________________________________________________________________________
Date: Sep 30, 2009
Hi Does anyone have a pix of the N220RV mid door latch? I'd like to see how Van's handled this issue. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: September-30-09 4:25 AM Subject: RV10-List: Re: Door bulge N220RV - the factory Continental equipped RV10 has a nice latch system. I do not know when it was installed but it is a spring loaded mid door latch -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265684#265684 Attachments: http://forums.matronics.com//files/p8122689_213.jpg ________________________________________________________________________________
Subject: QB Feedback
Date: Sep 30, 2009
Thought I'd share Scott's response. It was well received. I have a couple of more build misses that I'll forgot to include and I will be adding them to the list and resending to the group. Phil Phil, Really appreciate the input! We'll get the missing inventory out to you asap and I'll forward the info you've provided to our QC guys and to the assembly crew in the Philippines. If you need help with specific 'fix' options for any of the items you listed, please let us know. Thanks again, Scott at Van's From: Perry, Phil Sent: Tuesday, September 29, 2009 1:39 PM Subject: RE: RV10-List: QB Feedback Attached are two photos of four offenses. Baggage Seal photo shows: The longeron extending into the baggage door opening. The baggage door seal angles (top of baggage door) - not trimmed. 1084 and Control Column mount photo shows: The 1084B's missing. The bottom half is riveted to the floor The control column brackets without the hatched area removed. From: Richard Bibb [mailto:rbibb(at)tomet.net] Sent: Tuesday, September 29, 2009 12:14 PM Subject: RE: RV10-List: QB Feedback It is obvious from reading Phil's feedback that Van's subcontractor does not have even a rudimentary QC System in place. It is also obvious that Van's doesn't have much of a QC process in place either from an incoming inspection standpoint as some of the items could not be missed with even the most cursory inspection of the items (thinking longeron length). Excuses can be imagined centered around the ramp up of the new subcontractor location and the emphasis to clear backlog of unhappy customers, neither of which is good enough in my opinion. In my business (fabricating aerospace parts) this would result in a rejection and me having to remake the item to spec. I realize this is a different world but this level of sloppiness is unacceptable IMO. Glad I'm building a slow-build. Don't get me wrong I love Van's but this doesn't live up to the standard I'm used to seeing from them. Richard Bibb 972-771-2598 972-835-5979 mobile http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
From: Robert Brunkenhoefer <rebrunk42(at)gmail.com>
Subject: Re: door
Date: Sep 30, 2009
have you a photo of this arrangement? On Sep 30, 2009, at 6:30 AM, Jesse Saint wrote: > The strap, made out of the right material, is strong enough for > secondary. It has been tested on a strap made out of leather with > 2.5 layers stitched together. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > Cell: 352-427-0285 > Fax: 815-377-3694 > > On Sep 29, 2009, at 5:54 PM, John Jessen wrote: > >> Sad to see that the door issue has come back to the fore. If I >> recall, this was on my list of issues that got slammed awhile >> back. Looking forward to a tested solution that involves both a >> primary and secondary latch, such as autos have. Would the strap >> be strong enough for secondary? Not sure. I think Tim James has >> designed such. John Cox, do you remember Tim's solution? Maybe I >> can get out to his hanger and take some pics. >> >> John J >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com >> ] On Behalf Of Dave Saylor >> Sent: Monday, September 28, 2009 2:50 PM >> To: rv10-list(at)matronics.com >> Subject: Re: FW: RV10-List: door >> >> It's really essential that everyone have some improved way of >> keeping the doors closed: our metal door blocks are one way, buy >> you could also make your own, get Rivetheads, use a strap or >> something. This is happening a LOT and it's only a matter of time >> until the results are very bad. >> >> Dave Saylor >> AirCrafters LLC >> 140 Aviation Way >> Watsonville, CA 95076 >> 831-722-9141 Shop >> 831-750-0284 Cell >> >> >> On Mon, Sep 28, 2009 at 2:02 PM, David McNeill >> wrote: >> >> >> >> >> I believe you may be referring to 416EC; I think the number has now >> been changed and the aircraft sold. I don't rely on a system. I >> close the doors and check the pins both fore and aft, both sides, >> when we load and before takeoff. >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com >> ] On Behalf Of Danny Riggs >> Sent: Monday, September 28, 2009 12:21 PM >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: door >> >> That kinda sucks! I've been working on the door latches over the >> weekend and thinking about the last time I saw this happen. The >> landing was real firm and the front end was twisted up to the >> firewall. >> >> From: dlm46007(at)cox.net >> To: rv10-list(at)matronics.com >> Subject: RV10-List: door >> Date: Mon, 28 Sep 2009 11:30:43 -0700 >> >> >> IDENTIFICATION >> Regis#: 78MU Make/Model: EXP Description: RV-10 >> Date: 09/26/2009 Time: 1827 >> >> Event Type: Incident Highest Injury: None Mid Air: N >> Missing: N >> Damage: Minor >> >> LOCATION >> City: JEFFERSON CITY State: MO Country: US >> >> DESCRIPTION >> AIRCRAFT ON TAKEOFF, PASSENGER DOOR SEPARATED FROM AIRCRAFT, >> LANDED WITHOUT >> INCIDENT, JEFFERSON CITY, MO >> >> INJURY DATA Total Fatal: 0 >> # Crew: 1 Fat: 0 Ser: 0 Min: >> 0 Unk: >> # Pass: 1 Fat: 0 Ser: 0 Min: >> 0 Unk: >> # Grnd: Fat: 0 Ser: 0 Min: >> 0 Unk: >> >> WEATHER: SCT029 BKN045 260/08G15 10SM A2995 >> >> >> >> ttp://www.matronics.com/Navigator?RV10-List >> ronics.com >> ww.matronics.com/contribution >> >> >> Insert movie times and more without leaving Hotmail=AE. See how. >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> >> >> a>http://forums.matronics.com >> ======== >> = >> _blank">http://www.matronics.com/contribution >> >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >> > > ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
we use the strap on every flight--works great, and rumor has it that someone tried it in flight, and it worked!!! It's VERY simple--a little like the camera strap that you put on your camera--leather with loops on each end. Thread around the gear support below seat --bring other end up and place over door latch. Make it short/long enough that it will not let door open much, but enough for air when taxing. Mine is short enough so that you almost have to have the handle in 'open position' to get strap on(being careful to not bang pins on side of plane,) and then rotate handle, strap is in position with door open about 2 inches. I also go thru all the steps to make sure door is shut, but I like safety factor. I think there is a lot of pressure trying to open door. Cirrus's have had doors open, but their hinges keep the doors from flying off. Only downside is in accident you would like to have it off before landing, but balancing the risk/benefit ratio, I like it. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265775#265775 ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
we use the strap on every flight--works great, and rumor has it that someone tried it in flight, and it worked!!! It's VERY simple--a little like the camera strap that you put on your camera--leather with loops on each end. Thread around the gear support below seat --bring other end up and place over door latch. Make it short/long enough that it will not let door open much, but enough for air when taxing. Mine is short enough so that you almost have to have the handle in 'open position' to get strap on(being careful to not bang pins on side of plane,) and then rotate handle, strap is in position with door open about 2 inches. I also go thru all the steps to make sure door is shut, but I like safety factor. I think there is a lot of pressure trying to open door. Cirrus's have had doors open, but their hinges keep the doors from flying off. Only downside is in accident you would like to have it off before landing, but balancing the risk/benefit ratio, I like it. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265776#265776 ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
we use the strap on every flight--works great, and rumor has it that someone tried it in flight, and it worked!!! It's VERY simple--a little like the camera strap that you put on your camera--leather with loops on each end. Thread around the gear support below seat --bring other end up and place over door latch. Make it short/long enough that it will not let door open much, but enough for air when taxing. Mine is short enough so that you almost have to have the handle in 'open position' to get strap on(being careful to not bang pins on side of plane,) and then rotate handle, strap is in position with door open about 2 inches. I also go thru all the steps to make sure door is shut, but I like safety factor. I think there is a lot of pressure trying to open door. Cirrus's have had doors open, but their hinges keep the doors from flying off. Only downside is in accident you would like to have it off before landing, but balancing the risk/benefit ratio, I like it. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265777#265777 ________________________________________________________________________________
Date: Sep 30, 2009
Many thanks John, I learned that aspect of the skin joints when I did the t op skin at the point where the fuel tanks were installed, requiring a sligh t trim to ensure no oil canning.=0A=0AMany thanks from downunder for all th e great responses.=0A=0ARegards=0A=0APat=0A=0A=0A=0A=0A____________________ ____________=0AFrom: johngoodman <johngoodman(at)earthlink.net>=0ATo: rv10-lis t(at)matronics.com=0ASent: Wednesday, 30 September, 2009 11:58:38 PM=0ASubject : RV10-List: Re: Before Closing Up The Bottom Skins?=0A=0A--> RV10-List mes sage posted by: "johngoodman" =0A=0APat,=0AI did the same thing Bill did, except my wife shot the rivets, so I didn't need the safety wire thing. My cradle looks just like his. Bill's advice on trim ming the skins so they don't touch is the most important part. It took abou t a dozen frustrating fittings and filings before I riveted. No oil canning .=0AJohn=0A=0A--------=0A#40572 QB Fuselage, wings finished. Finish Kit pro gressing. Engine & Panel delivery soon.=0AN711JG reserved=0A=0A=0A=0A =0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic. ====0A=0A=0A ___________________________________________________ _______________________________=0AGet more done like never before with Yaho o!7 Mail.=0ALearn more: http://au.overview.mail.yahoo.com/ ________________________________________________________________________________
Subject: Re: door
Date: Sep 30, 2009
I concurr there is a lot of force trying to open the door. There is a low pressure area outside the window and the fresh air vents are increasing the pressure inside; There is also consdierable area for the air prtessure to work on the door One more reason to make sure that your pins have a full circufence through the metal at the fore/aft door sides. Flexing of the door may retract the pins slightly. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lbgjb10 Sent: Wednesday, September 30, 2009 3:00 PM Subject: RV10-List: Re: door we use the strap on every flight--works great, and rumor has it that someone tried it in flight, and it worked!!! It's VERY simple--a little like the camera strap that you put on your camera--leather with loops on each end. Thread around the gear support below seat --bring other end up and place over door latch. Make it short/long enough that it will not let door open much, but enough for air when taxing. Mine is short enough so that you almost have to have the handle in 'open position' to get strap on(being careful to not bang pins on side of plane,) and then rotate handle, strap is in position with door open about 2 inches. I also go thru all the steps to make sure door is shut, but I like safety factor. I think there is a lot of pressure trying to open door. Cirrus's have had doors open, but their hinges keep the doors from flying off. Only downside is in accident you would like to have it off before landing, but balancing the risk/benefit ratio, I like it. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265777#265777 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Oct 01, 2009
Subject: door
I think this is important but not critical to extend through the upright if you are using one of the aftermarket block sets. Mine do happen to prot rude a little through the upright but every instance of door separation see ms to have been related to incomplete latching or the nylon tearing out. I f you are using aftermarket pin blocks and shear those, you have bigger iss ues. :P If you are going with the stock setup it would certainly help to go through the uprights not only for strength and engagement but also as an indicator as you will probably be much more likely to notice that it is un latched. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Chris Sent: Monday, September 28, 2009 7:23 PM Subject: RE: RV10-List: door More 2 cents...Remember to make sure the door pins go all the way through t he upright F-1005 and F-1042. I have mine such that there is solid pin (wit h no taper) engaged in the hole in these uprights. That is a lot of strengt h in shear with this, so as long as the door and latch is closed properly i t is not going anywhere. Now if the door can flex in the middle thereby pul ling those out such as if the cabin were pressurized that could be a proble m. -Chris #40072 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of gary Sent: Monday, September 28, 2009 6:54 PM Subject: RE: RV10-List: door I disagree that it will take more than metal blocks to solve this. I switc hed to the metal blocks and have very solid latch on mine. Connect the pro ximity switch circuit to your EFIS alarm system, and it will scream at you when you advance the throttle and don't have all 4 pins locked. The soluti on is not difficult or expensive. Gary Specketer ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of John Cumins Sent: Monday, September 28, 2009 6:44 PM Subject: RE: RV10-List: door Ok here comes my 2 cents. It appears that there could be some type of desi gn change, better locking longer door pins, longer throw on the pins or a a ir dam of some kind that forces the door shut and not let it open with a ai r load in or. Has any Lanceairs lost any doors in flight. Looking at the Cirius doors it is almost impossible to loose on of theirs from the looks of it. I think when I get to that point I will have to take a harder look at this and see if I can build in more safety into this. I do agree that the door should not come off and cause a major damage or loss of aircraft due to a d oor opening. It is time to put some major brain cells into this issue. I think it will t ake more than metal door blocks to really get this resolved. I am open to any and all ideas. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Monday, September 28, 2009 3:22 PM Subject: RE: RV10-List: door Hi These door departures are really quite troublesome. It would be interesting to now the following about each of the incidents to date. * When did the door departure occur (i.e. on takeoff, during climb out, cruise etc)? * Was the Van door warning installed * What kind of door blocks were being used (Van's nylon, Rivethead, Ifly RV10 etc)? * Were any other "secondary" latches / straps etc being used? The 416EC incident seems to indicate that the nylon blocks are definitely n ot the way to go when installing doors. Anyway, in my not so humble opinion, an improperly unlatched door should no t result in a near death experience in a light single. Cheers Les #40643 - living in f/g hell. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of David McNeill Sent: September-28-09 3:03 PM Subject: FW: RV10-List: door I believe you may be referring to 416EC; I think the number has now been ch anged and the aircraft sold. I don't rely on a system. I close the doors an d check the pins both fore and aft, both sides, when we load and before tak eoff. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Danny Riggs Sent: Monday, September 28, 2009 12:21 PM Subject: RE: RV10-List: door That kinda sucks! I've been working on the door latches over the weekend and thinking about the last time I saw this happen. The landing was real f irm and the front end was twisted up to the firewall.[http://gfx2.hotmail.c om/mail/w4/pr01/ltr/emoticons/smile_sad.gif] ________________________________ From: dlm46007(at)cox.net Subject: RV10-List: door Date: Mon, 28 Sep 2009 11:30:43 -0700 IDENTIFICATION Regis#: 78MU Make/Model: EXP Description: RV-10 Date: 09/26/2009 Time: 1827 Event Type: Incident Highest Injury: None Mid Air: N Missing: N Damage: Minor LOCATION City: JEFFERSON CITY State: MO Country: US DESCRIPTION AIRCRAFT ON TAKEOFF, PASSENGER DOOR SEPARATED FROM AIRCRAFT, LANDED WITHO UT INCIDENT, JEFFERSON CITY, MO INJURY DATA Total Fatal: 0 # Crew: 1 Fat: 0 Ser: 0 Min: 0 Unk : # Pass: 1 Fat: 0 Ser: 0 Min: 0 Unk : # Grnd: Fat: 0 Ser: 0 Min: 0 Unk : WEATHER: SCT029 BKN045 260/08G15 10SM A2995 ttp://www.matronics.com/Navigator?RV10-List ronics.com ww.matronics.com/contribution ________________________________ Insert movie times and more without leaving Hotmail(r). See how.<http://win dowslive.com/Tutorial/Hotmail/QuickAdd?ocid=TXT_TAGLM_WL_HM_Tutorial_Quic kAdd_062009> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Woodward Governor - need help
Date: Oct 01, 2009
I acquired a reconditioned Woodward Governor (mdl: 210582) for my I/O 540 C2C with a Hoffman prop. The prop and governor came off of an I/O 540 engine. This model has an oil AN fitting on the top, I'm assuming for an oil input (return?). It has the normal screened oil races on the mounting plate and I have mounted it on the front of the engine. I am trying to determine what to do with this AN oil fitting, assuming a hose is require to somewhere on the engine? I have tried to search the web for any installation manuals or other sources of information, without success. Does anyone have any information or knowledge on this style of governor? Any help would be appreciated. Thanks, Nick -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265857#265857 ________________________________________________________________________________
Date: Oct 01, 2009
Subject: Power and Drag for the Common Man
I just saw this. http://www.eaa.org/experimenter/articles/2009-08_drag.asp Has anyone else considered doing this for their -10? Could be interesting. Deems Davis www.deemsrv10.com N519PJ ________________________________________________________________________________
Subject: Re: Woodward Governor - need help
Date: Oct 01, 2009
My engine (IO540-C4B5) came with a gov like that but the cowling wouldn't fit so I had to buy the smaller Czech gov from the group buy on Van's Airforce website. Kevin Belue RV10 flying Sent from my iPhone On Oct 1, 2009, at 10:41 AM, "Nick Leonard" wrote: > > I acquired a reconditioned Woodward Governor (mdl: 210582) for my I/ > O 540 C2C with a Hoffman prop. The prop and governor came off of an > I/O 540 engine. This model has an oil AN fitting on the top, I'm > assuming for an oil input (return?). It has the normal screened oil > races on the mounting plate and I have mounted it on the front of > the engine. > > I am trying to determine what to do with this AN oil fitting, > assuming a hose is require to somewhere on the engine? I have tried > to search the web for any installation manuals or other sources of > information, without success. > > Does anyone have any information or knowledge on this style of > governor? Any help would be appreciated. > > Thanks, > > Nick > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=265857#265857 > > ________________________________________________________________________________
Date: Oct 01, 2009
ooo, that's not good news. So do you have any install info on how it was supposed to be connected (the AN fitting on top)? Has anyone else tried to deal with this? Thanks Kevin for sharing. -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265886#265886 ________________________________________________________________________________
Date: Oct 01, 2009
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Nick, I initially tried a "serviceable" Woodward governor. It didn't have a fitting on top like you're describing but it did have what looked like a pipe plug. I think it was a cover for some kind of bench adjustment--nothing I would ever have to change. The plug interfered with the cowl, so I cored the de-cored the top skin and with that it just barely fit. I probably was contacting under some conditions. I replaced it after about 75 hours because it started leaking pretty badly. I got the gov from Van's and it's been trouble free. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Oct 1, 2009 at 11:12 AM, Nick Leonard wrote: > > ooo, that's not good news. So do you have any install info on how it was > supposed to be connected (the AN fitting on top)? > > Has anyone else tried to deal with this? > > Thanks Kevin for sharing. > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=265886#265886 > > ________________________________________________________________________________
Date: Oct 01, 2009
To those challenged with high oil temps on your RV-10, Airflow Systems (not Airflow Performance, a common mistake) offers the use of our digital manometer for free for one week to RV-10 owners and others (you pay freight and insurance both ways). This is available even if you do not have one of our 2006X or 2008X oil coolers. With the help of many RV-10 owners we have found the following from our testing: The stock RV-10 and James cowl do not have the desired pressure differential for optimum cylinder and oil cooling, as supplied. Adding louvers on the side of the cowl offers the biggest improvement in pressure differential for the effort, appearance is a personal issue. The stock Vans inlets are larger than necessary for stock engines, exit area flow needs improvement if you are going to use all of the RV-10s performance potential. We have reduced the inlet area on a -10 in Texas with no adverse effects. It has side louvers and (our) air conditioning. The biggest problems come from the tightest plenums. The air must have an area to slow down and build pressure to improve the differential. There is room for improvement in the Vans oil cooler installation which forces the air through 360 degrees of direction changes. NACA ducts are not optimal for oil coolers. Normally I stay off the forums as a supplier but I see a lot of suggestions that we have already tested and I offer this info as a time saver. After today I will not be able to answer emails until Tuesday. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265903#265903 ________________________________________________________________________________
Date: Oct 01, 2009
To add to my previous post, we tried the lips on the cowl exit, with zero benefit, on two different aircraft. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265907#265907 ________________________________________________________________________________
Date: Oct 02, 2009
Nick, get rid of the Woodward...parts and info are hard to come by and therefore expensive to overhaul or repair. Suggest the MT, McCauley or PCU5000 governor replacements. John 40315 VH-XIO ----- Original Message ----- From: "Nick Leonard" <nick(at)nleonard.com> Sent: Friday, October 02, 2009 1:41 AM Subject: RV10-List: Woodward Governor - need help > > I acquired a reconditioned Woodward Governor (mdl: 210582) for my I/O 540 > C2C with a Hoffman prop. The prop and governor came off of an I/O 540 > engine. This model has an oil AN fitting on the top, I'm assuming for an > oil input (return?). It has the normal screened oil races on the mounting > plate and I have mounted it on the front of the engine. > > I am trying to determine what to do with this AN oil fitting, assuming a > hose is require to somewhere on the engine? I have tried to search the > web for any installation manuals or other sources of information, without > success. > > Does anyone have any information or knowledge on this style of governor? > Any help would be appreciated. > > Thanks, > > Nick > > -------- > Nick Leonard > RV-10 (40015) Finish > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=265857#265857 > > > ________________________________________________________________________________
Date: Oct 01, 2009
Subject: Re: Copperstate RV10 nest
Myron, how come this is the last RV10 nest at Copperstate????-- We book ed to many "getaways" already,,, so we're not going to be able to make it.. ...- I would have liked to put in my book that I attended all the RV10 ne sts held.... in this case, that would be both of them. Don McDonald --- On Sun, 9/27/09, woxofswa wrote: From: woxofswa <woxof(at)aol.com> Subject: RV10-List: Copperstate RV10 nest Date: Sunday, September 27, 2009, 8:20 PM The second (and last), annual RV10 nest at Copperstate is a go. Should be set up by Friday morning through Sat night for a shady place to r elax. Carne Asada mid day Saturday until its gone.- Would like to get a rough h ead count for planning purposes. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265270#265270 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Oct 01, 2009
Subject: Control column mounts
Wow, I thought this would have been a simple question, but no response. Perhaps it was lost in the regular mail, so I'll send this again: I'm about at this step, and Phil's QB feedback prompted this question from me: Is there any reason (other than to save weight) for trimming the control column mounts? Would it cause interference problems with anything later? Here's the step (copied from Phil's email) 28-4 Step #1) Radius the corners and remove material from the middle of both control column mounts. (Remove hatched area). -Jim 40384 ________________________________________________________________________________
Date: Oct 01, 2009
Kevin, John and Dave; Thanks for the feedback. Between the issues of fitting the governor and finding any kind of installation documentation, I'm coming to the realization that my great buy on a three bladed prop and governor (plus having them overhauled) wasn't as good a buy as I had hoped for. I'm checking to see if the MT Governor that Van's offers will work with this prop. I have emails into both MT and Hoffman. Thanks again for responding. Nick -------- Nick Leonard RV-10 (40015) Finish Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265934#265934 ________________________________________________________________________________
Date: Oct 01, 2009
Bill, thanks for surfacing on the RV10 forum and the offer of the manometer. That is MOST Generous. One question you leave hanging is why would the High pressure plenum of a James Cowl be less or equal than a stock High Pressure Vans? I would think the enclosed pressure plenum would help in several ways. Your most notable comment is the 360 degrees of convoluted distortions of airflow so the cooler could be mounted on the firewall. The design reasoning was the high number of cracked rear metal baffles in the other Vans lineup. I would surmise that you support a rear metal baffle mount with your units. Airflow contains energy and the management and extraction of that unit is a valued pursuit. I am a fan of LoPresti and hence a strong advocate for controllable outflow of the low pressure side to configure for differing angles of attack. They are also strong proponents of tweaking with the manometer. Thanks again. John Cox #40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill@airflow Sent: Thursday, October 01, 2009 12:54 PM Subject: RV10-List: Re: High Oil temps To those challenged with high oil temps on your RV-10, Airflow Systems (not Airflow Performance, a common mistake) offers the use of our digital manometer for free for one week to RV-10 owners and others (you pay freight and insurance both ways). This is available even if you do not have one of our 2006X or 2008X oil coolers. With the help of many RV-10 owners we have found the following from our testing: The stock RV-10 and James cowl do not have the desired pressure differential for optimum cylinder and oil cooling, as supplied. Adding louvers on the side of the cowl offers the biggest improvement in pressure differential for the effort, appearance is a personal issue. The stock Vans inlets are larger than necessary for stock engines, exit area flow needs improvement if you are going to use all of the RV-10s performance potential. We have reduced the inlet area on a -10 in Texas with no adverse effects. It has side louvers and (our) air conditioning. The biggest problems come from the tightest plenums. The air must have an area to slow down and build pressure to improve the differential. There is room for improvement in the Vans oil cooler installation which forces the air through 360 degrees of direction changes. NACA ducts are not optimal for oil coolers. Normally I stay off the forums as a supplier but I see a lot of suggestions that we have already tested and I offer this info as a time saver. After today I will not be able to answer emails until Tuesday. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265903#265903 ________________________________________________________________________________
Date: Oct 01, 2009
Plenums can be very useful, we are working on one for the RV-10 now, as are others. The issue is the volume in the plenum. Ideally you want the air to enter through a small inlet, trade velocity for increased pressure, and exit into a low pressure area that tries to accelerate the air to ambient velocity as it exits. Compare the volume of some of the aftermarket plenums to Van's volume above the cylinders, and the related performance, and you can see that not all plenums are improvements. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265943#265943 ________________________________________________________________________________
Subject: Another QB 10 Issue - Longeron Length (again)
Date: Oct 01, 2009
Since I found some mid-fuse longerons that were too long, I thought I'd double check the primary ones that attach to the tailcone. Checking the lengths on those was something I never thought about doing. Good thing I did - or so I think. Attached is a photo of the right side longeron. The line in the photo is where I believe the longeron should be cut (49 23/32") per 29-2 Step #1. As you can see, the longerons are more than 4" too long. Which brings me to two interesting questions. 1) For those of you who have slow-built and not attached to the tailcone yet; How far do yours stick out past the side skin? Is my mark close to right? 2) I wonder how many other folks missed this step and now have an RV-10 QB's with the tailcone and fwd fuse attached at the wrong point. Phil ________________________________________________________________________________
Subject: Re: Control column mounts
Date: Oct 01, 2009
Looking at my pictures, I don't think there is anything that would get in the way. Not sure why you don't want to remove it. I didn't have any problems removing the material and then finishing it. I would suggest following the plans. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265961#265961 ________________________________________________________________________________
Date: Oct 01, 2009
The Woodward will work. There is only a flush plug on top and no hoses atta ched anywhere. However, mine just started leaking about a teaspoon every 5- 10 hours. I'll remove it at next oil change and make a decision to replace it with an MT or not. Probably follow Dave S and scrap it. - Bill DeRouchey N939SB 315 trouble-free hours prior to leak --- On Thu, 10/1/09, John Dunne wrote: From: John Dunne <acs(at)acspropeller.com.au> Subject: Re: RV10-List: Woodward Governor - need help Date: Thursday, October 1, 2009, 2:07 PM Nick, get rid of the Woodward...parts and info are hard to come by and ther efore expensive to overhaul or repair. Suggest the MT, McCauley or PCU5000 governor replacements. John 40315 VH-XIO ----- Original Message ----- From: "Nick Leonard" <nick(at)nleonard.com> Sent: Friday, October 02, 2009 1:41 AM Subject: RV10-List: Woodward Governor - need help > > I acquired a reconditioned Woodward Governor (mdl:- 210582) for my I/O 540 C2C with a Hoffman prop.- The prop and governor came off of an I/O 54 0 engine.- This model has an oil AN fitting on the top, I'm assuming for an oil input (return?).- It has the normal screened oil races on the moun ting plate and I have mounted it on the front of the engine. > > I am trying to determine what to do with this AN oil fitting, assuming a hose is require to somewhere on the engine?- I have tried to search the w eb for any installation manuals or other sources of information, without su ccess. > > Does anyone have any information or knowledge on this style of governor? Any help would be appreciated. > > Thanks, > > Nick > > -------- > Nick Leonard > RV-10 (40015) Finish > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=265857#265857 > > > > > > > > > > > le, List Admin. ________________________________________________________________________________
Date: Oct 01, 2009
You might talk to a prop shop first, maybe even a couple. Woodwards used to be the gold standard for governors. See what they say about inspect and reseal or overhaul. On Thu, Oct 1, 2009 at 7:05 PM, Bill DeRouchey wrote: > The Woodward will work. There is only a flush plug on top and no hoses > attached anywhere. However, mine just started leaking about a teaspoon every > 5-10 hours. I'll remove it at next oil change and make a decision to replace > it with an MT or not. Probably follow Dave S and scrap it. > > Bill DeRouchey > N939SB > 315 trouble-free hours prior to leak > > ________________________________________________________________________________
Date: Oct 02, 2009
I have the James Plenum and as a last ditch effort added ~25% more volume to our plenum based on the greater volume concept and found ZERO improvement. Obviously we have the aerodynamic knowledge of most 12 year olds but I did expect to see some improvement or at least some change. I believe we borrowed Bill's manometer which was extremely helpful in sorting out DP issues. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill@airflow Sent: Thursday, October 01, 2009 4:58 PM Subject: RV10-List: Re: High Oil temps Plenums can be very useful, we are working on one for the RV-10 now, as are others. The issue is the volume in the plenum. Ideally you want the air to enter through a small inlet, trade velocity for increased pressure, and exit into a low pressure area that tries to accelerate the air to ambient velocity as it exits. Compare the volume of some of the aftermarket plenums to Van's volume above the cylinders, and the related performance, and you can see that not all plenums are improvements. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=265943#265943 Checked by AVG - www.avg.com 10/01/09 18:23:00 ________________________________________________________________________________
Date: Oct 02, 2009
Phil, If I read your measurements correctly, I think you're spot on. My tailcone is mounted, but it was easy to measure since that longeron is on top and not covered by a skin. My measurement was 2-7/16". Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Thursday, October 01, 2009 9:01 PM Subject: RV10-List: Another QB 10 Issue - Longeron Length (again) Since I found some mid-fuse longerons that were too long, I thought I'd double check the primary ones that attach to the tailcone. Checking the lengths on those was something I never thought about doing. Good thing I did - or so I think. Attached is a photo of the right side longeron. The line in the photo is where I believe the longeron should be cut (49 23/32") per 29-2 Step #1. As you can see, the longerons are more than 4" too long. Which brings me to two interesting questions. 1) For those of you who have slow-built and not attached to the tailcone yet; How far do yours stick out past the side skin? Is my mark close to right? 2) I wonder how many other folks missed this step and now have an RV-10 QB's with the tailcone and fwd fuse attached at the wrong point. Phil ________________________________________________________________________________
Date: Oct 02, 2009
Thanks Bob... I just threw the tape on there just to give you a sense of scale. I went out and measured from the skins edge to the line and I'm 1/16" shorter than yours. I'll add a 1/16th to it. Just didn't want to cut those things until I verified they really needed to be cut. That explains why they didn't pre-drill those pilot holes for attachment too.. Thanks, Phil From: Bob Leffler [mailto:rv(at)thelefflers.com] Sent: Friday, October 02, 2009 5:43 AM Subject: RE: RV10-List: Another QB 10 Issue - Longeron Length (again) Phil, If I read your measurements correctly, I think you're spot on. My tailcone is mounted, but it was easy to measure since that longeron is on top and not covered by a skin. My measurement was 2-7/16". Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Thursday, October 01, 2009 9:01 PM Subject: RV10-List: Another QB 10 Issue - Longeron Length (again) Since I found some mid-fuse longerons that were too long, I thought I'd double check the primary ones that attach to the tailcone. Checking the lengths on those was something I never thought about doing. Good thing I did - or so I think. Attached is a photo of the right side longeron. The line in the photo is where I believe the longeron should be cut (49 23/32") per 29-2 Step #1. As you can see, the longerons are more than 4" too long. Which brings me to two interesting questions. 1) For those of you who have slow-built and not attached to the tailcone yet; How far do yours stick out past the side skin? Is my mark close to right? 2) I wonder how many other folks missed this step and now have an RV-10 QB's with the tailcone and fwd fuse attached at the wrong point. Phil ________________________________________________________________________________
Date: Oct 02, 2009
Subject: Window Glue
I thought I would share my experience with an alternative glue for adheri ng the windows. Based on a recommendation from Geoff Combs, I picked up so me Lord 7545A/E urethane adhesive rather than using the Weldon 10 we are al l familiar with. I did follow the standard process with the rear windows and after that ex perience, along with forgetting my shims in the rush, I thought I would loo k into the alternatives. After not really finding anything definitive from the existing alternatives like Sikaflex I basically resigned myself to use Weldon for the doors. As I got within a couple weeks of doing the door wi ndows Geoff had mentioned to me that he used something else for the window adhesive that was very much suited for the task and didn't have the quick c ure times and viscosity issues of Weldon. I had forgot about it until he h ad a brief blurb in one of his post a couple weeks back. So I got more det ails from him and found a distributor that I could get the 50ML two part ca rtridge. The stuff is comparable in price to the Weldon at about $13 a kit and each 50ML kit will do a window easily. There is an additional cost in that you need a gun which is about $30 but it will work with any two part, 1:1, gun packaged product. Each pak also comes with a self mixing dispens ing nozzle so you just stick it in the gun, put the nozzle on, and squeeze. Extra tips are less than a buck and if you don't use the whole cartridge you just chuck the tip and put the cap back on. I'm sure many of you are saying that you've heard this before but this st uff is GREAT! It looks and acts similar to the Weldon but you get upwards of 30min working time and it doesn't even sag! This stuff is made specific ally as a structural adhesive for plastics so it seems to be an excellent p roduct for this application. Not wanting to completely trust what I read I decided to a little non-sci entific destructive testing. I didn't have a piece of scrap fiberglass any more but I did have plenty of scrap plexi from trimming the windows so I to ok two pieces and glued an overlap of about 1.5x1.5 inch on two pieces of s crap. Cure time for this stuff is about 24 hours but I let it sit for abou t a week. This stuff doesn't get as rock hard as Weldon but it isn't flexi ble either. I took the glued piece and put it in the vise on its edge and tried to separate it in full edge shear (not really sure how to describe it but was the most difficult way to break it) and the plexi broke clear of t he glue joint. I then turned it flat and tried to peel it apart and again the plexi broke away from the glue joint. So far the glue joint hasn't bud ged. I then took a hammer and beat the crap out of the remaining square wh ich was basically just the glued area. After several whacks with the frami ng hammer I was finally able to get it to break into 3 pieces without ANY s eparation of the glue joint. I've attached a few pictures below so you can see what I'm talking about. The initial swag I took at how many cartridges I would need was a little high so I have four extras that I can sell to anyone that is interested. I was thinking $16 each would cover the cost and shipping and I can send you my gun to use as long as you send it back in a reasonable amount of time. Here is a link to the distributor I got it from. This page also has a li nk to the gun you need and extra tips if you want them. Keep in mind each pack comes with one tip too. http://chemical-concepts.com/products.php?sid=192&limit Here is a technical datasheet on 7545A: http://www.glue4you.com/PDF/Lord7545_TN001.pdf If you want two or four of the unopened packs I have just drop me a email d irectly. Michael ________________________________________________________________________________
Date: Oct 02, 2009
In his case, the QB guys have already installed it, without removing material. I see no interference issues, just a little extra weight. But I'm not flying yet! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266088#266088 ________________________________________________________________________________
Date: Oct 02, 2009
Thought I'd share this piece of knowledge with the QB group too. Check the torque values of all your QB installed AN3 hardware. I started sneaking up on mine the other night to see what value they were tourqed to. Any guesses???? 85 inches. Phil -----Original Message----- From: Bob Turner [mailto:bobturner(at)alum.rpi.edu] Sent: Friday, October 02, 2009 12:39 PM Subject: RV10-List: Re: Control column mounts In his case, the QB guys have already installed it, without removing material. I see no interference issues, just a little extra weight. But I'm not flying yet! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266088#266088 ________________________________________________________________________________
Date: Oct 02, 2009
If they start turning at 85 in-lbs, that doesn't mean they were torqued to 85, correct? Isn't extra torque required to "break free"? On Fri, Oct 2, 2009 at 11:06 AM, Perry, Phil wrote: > > Thought I'd share this piece of knowledge with the QB group too. > > Check the torque values of all your QB installed AN3 hardware. I > started sneaking up on mine the other night to see what value they were > tourqed to. > > Any guesses???? > > > 85 inches. > > > Phil > > > -----Original Message----- > From: Bob Turner [mailto:bobturner(at)alum.rpi.edu] > Sent: Friday, October 02, 2009 12:39 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Control column mounts > > > In his case, the QB guys have already installed it, without removing > material. > > I see no interference issues, just a little extra weight. But I'm not > flying yet! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266088#266088 > > -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: Door-I'm the guy.
Date: Oct 02, 2009
A friend told me that I made your discussions. I lost the door on takeoff last week. A fly-in was finishing up when a pilot friend asked me for a ride in my RV 10. I had had it parked on the ramp most of the day for static display. I'm a Urologist and was on call, but staying in the local area would still not put me more than 30 min from the hospital if I got called for an emergency. We taxied out for a quick spin. I'm very aware of the door problem and have a double check for the door. I personally close both doors on both sides and check security front and aft both visually and with hand pressure. When we got in I checked his side as I usually do and closed my own door. I keep the passenger seat forward and it makes it difficult to hand pressure check the aft pin because of the closeness of the seat to the door. Visually it looked fine. During taxi I of course got paged and this distracted me from the flying. I handled the page and we continued taxi. The passenger is a pilot who built, flew and ultimately sold an RV 6. I'm suspicious this made me a bit cavalier about pre flight steps. We had already done our run up sequence and started our takeoff roll fairly quickly. We had lifted off and were climbing at about 80-90 knots when the door shifted out. It happened very quickly, went on out, twisted on the hinges and departed. It did not strike the airframe. We continued the climb, did a go round, and landed uneventfully. Except for the noise the aircraft handled without problems. We retrieved the door and there is surprisingly little damage. The plexiglass has two cracks about 3-4 inches. Interestingly enough the complete hinge assembly remained attached to the airframe. The attach point to the door is doubled firbeglass and the fibreglass layer attached to the hinge stayed with the hinge. The bolts pulled thru the outer door fibreglass skin. The paint remained intact and there is almost no visible damage to the outer skin of the door. The other aircraft with the hard landing had similar findings after I reviewed his pictures. The door departed because the aft pin wasn't engaged. No aircraft component failed. I have the lights installed for the doors, but could have missed this with the distractions. I had to readjust them in the past because the pin is close enough to the magnetic reed that it sensed the door closed even with the pin outside the engagement block. I think the best way to manage this is to hand pressure check the engagement of the pin as well as visually check it. My visual check wasn't enough. The handle on the door is almost directly over the front pin, so pulling shut the door seats that easily. When the door swings in, it is very easy for the aft door to twist and not slip properly into the aircraft door frame. Rotating the door handle gives a secure tight feel even when the aft pin is not engaged, but just simply sliding outside the doorframe on the aircraft skin. The front pin pulls it tight. Once rolling, I assume the positive pressure from the vents internally on the door, combined with the negative pressure on the door surface eventually overwhelms the front pin and at that point it goes very quickly. Both of us in the aircraft were experienced pilots, and as well the aircraft really never got above 90-100 knots, or above 1000 ft AGL. Should the pin hold enough to get to altitude or 160 knots, I'm not sure what would happen, as the wind effect is impressive. Again, the aircraft handled fine. Hopefully this note will help others to avoid this event. As far as suggested solutions to manage this problem, I am not convinced that the safety wire technique would work effectively, but I certainly would encourage it. For a urologist, scrotal reconstructions pay very well. Please be sure your health insurance is current. ________________________________________________________________________________
Date: Oct 02, 2009
Congratulations on landing safely; perhaps a way could be found on the interior faade to allow "feeling" the pins. Fortunately I chose not to have the faade so I feel the pins, each side, fore and aft, twice; pins are check after loading and before takeoff and I do it. I have missed the passenger door rear pin once (after loading) but caught it immediately by feeling the pins fore and aft. I have not installed the light system. I don't intend to install the safety wire since at 65 I still use mine. I have two back seat options ages 10 and 13. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Koonce Sent: Friday, October 02, 2009 4:20 PM Subject: RV10-List: Door-I'm the guy. A friend told me that I made your discussions. I lost the door on takeoff last week. A fly-in was finishing up when a pilot friend asked me for a ride in my RV 10. I had had it parked on the ramp most of the day for static display. I'm a Urologist and was on call, but staying in the local area would still not put me more than 30 min from the hospital if I got called for an emergency. We taxied out for a quick spin. I'm very aware of the door problem and have a double check for the door. I personally close both doors on both sides and check security front and aft both visually and with hand pressure. When we got in I checked his side as I usually do and closed my own door. I keep the passenger seat forward and it makes it difficult to hand pressure check the aft pin because of the closeness of the seat to the door. Visually it looked fine. During taxi I of course got paged and this distracted me from the flying. I handled the page and we continued taxi. The passenger is a pilot who built, flew and ultimately sold an RV 6. I'm suspicious this made me a bit cavalier about pre flight steps. We had already done our run up sequence and started our takeoff roll fairly quickly. We had lifted off and were climbing at about 80-90 knots when the door shifted out. It happened very quickly, went on out, twisted on the hinges and departed. It did not strike the airframe. We continued the climb, did a go round, and landed uneventfully. Except for the noise the aircraft handled without problems. We retrieved the door and there is surprisingly little damage. The plexiglass has two cracks about 3-4 inches. Interestingly enough the complete hinge assembly remained attached to the airframe. The attach point to the door is doubled firbeglass and the fibreglass layer attached to the hinge stayed with the hinge. The bolts pulled thru the outer door fibreglass skin. The paint remained intact and there is almost no visible damage to the outer skin of the door. The other aircraft with the hard landing had similar findings after I reviewed his pictures. The door departed because the aft pin wasn't engaged. No aircraft component failed. I have the lights installed for the doors, but could have missed this with the distractions. I had to readjust them in the past because the pin is close enough to the magnetic reed that it sensed the door closed even with the pin outside the engagement block. I think the best way to manage this is to hand pressure check the engagement of the pin as well as visually check it. My visual check wasn't enough. The handle on the door is almost directly over the front pin, so pulling shut the door seats that easily. When the door swings in, it is very easy for the aft door to twist and not slip properly into the aircraft door frame. Rotating the door handle gives a secure tight feel even when the aft pin is not engaged, but just simply sliding outside the doorframe on the aircraft skin. The front pin pulls it tight. Once rolling, I assume the positive pressure from the vents internally on the door, combined with the negative pressure on the door surface eventually overwhelms the front pin and at that point it goes very quickly. Both of us in the aircraft were experienced pilots, and as well the aircraft really never got above 90-100 knots, or above 1000 ft AGL. Should the pin hold enough to get to altitude or 160 knots, I'm not sure what would happen, as the wind effect is impressive. Again, the aircraft handled fine. Hopefully this note will help others to avoid this event. As far as suggested solutions to manage this problem, I am not convinced that the safety wire technique would work effectively, but I certainly would encourage it. For a urologist, scrotal reconstructions pay very well. Please be sure your health insurance is current. ________________________________________________________________________________
Date: Oct 02, 2009
Subject: AFS - Alternator Warning
I am flying with an AFS 3500EE EFIS / Engine Monitor. Yesterday the airplane was being flown and the fuse blew on the alternator field circuit causing the alternator go off line. Turns out the alternator AMPS warning is OFF by default and no warning was heard. It wasn't until the battery was low that an audible / visual alert was presented on the EFIS. Not sure just how long it took for the battery to get to the low voltage warning condition. I have copied the flight data from the EFIS and will review the data to see just how long it took. The EFIS went to backup battery during the flight and the flight was terminated with no other problems. This is just a heads up to those flying with the AFS EFIS to check the alternator AMPS setting in the configuration pages should you want an immediate warning for alternator current. Knowing you have a problem sooner than later is desirable. I did not have the alternator lamp wired (Didn't think I needed it with the EFIS audible alerts). I will be adding this to the panel in the near future. I love the EFIS, I just missed getting this setting correct. Jim Combs (N312F - 110+ hours) ________________________________________________________________________________
Date: Oct 02, 2009
IMOP make the pins longer and build up the interior of the cabin top so tha t when the door is closed with the pins engaged=2C the cabin top is touchin g the inside of the door. That way there is no guess work involved as there would be if one is guestimating the gap between cabin top flange and insid e surface of the door=2C especially alone the entire bottom edge of the cab in top/door interface. My pins go 1/4inch beyond the two aluminum fuselage frames=2C for and aft f rames. John #409=2C the lager=2C just finished an RC foam sloper so I could have t hat feeling of entirely completing something. > From: dlm46007(at)cox.net > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Door-I'm the guy. > Date: Fri=2C 2 Oct 2009 16:49:53 -0700 > > > Congratulations on landing safely=3B perhaps a way could be found on the > interior fa=E7ade to allow "feeling" the pins. Fortunately I chose not to have > the fa=E7ade so I feel the pins=2C each side=2C fore and aft=2C twice=3B pins are > check after loading and before takeoff and I do it. I have missed the > passenger door rear pin once (after loading) but caught it immediately by > feeling the pins fore and aft. I have not installed the light system. I > don't intend to install the safety wire since at 65 I still use mine. I h ave > two back seat options ages 10 and 13. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Koonce > Sent: Friday=2C October 02=2C 2009 4:20 PM > To: RV10-List(at)matronics.com > Subject: RV10-List: Door-I'm the guy. > > > A friend told me that I made your discussions. I lost the door on takeof f > last week. > > A fly-in was finishing up when a pilot friend asked me for a ride in my R V > 10. I had had it parked on the ramp most of the day for static display. > I'm a Urologist and was on call=2C but staying in the local area would st ill > not put me more than 30 min from the hospital if I got called for an > emergency. We taxied out for a quick spin. I'm very aware of the door > problem and have a double check for the door. I personally close both do ors > on both sides and check security front and aft both visually and with han d > pressure. When we got in I checked his side as I usually do and closed m y > own door. I keep the passenger seat forward and it makes it difficult to > hand pressure check the aft pin because of the closeness of the seat to t he > door. Visually it looked fine. During taxi I of course got paged and th is > distracted me from the flying. I handled the page and we continued taxi. > The passenger is a pilot who built=2C flew and ultimately sold an RV 6. > I'm suspicious this made me a bit cavalier about pre flight steps. We ha d > already done our run up sequence and started our takeoff roll fairly > quickly. We had lifted off and were climbing at about 80-90 knots when t he > door shifted out. It happened very quickly=2C went on out=2C twisted on the > hinges and departed. It did not strike the airframe. We continued the > climb=2C did a go round=2C and landed uneventfully. Except for the noise the > aircraft handled without problems. We retrieved the door and there is > surprisingly little > damage. The plexiglass has two cracks about 3-4 inches. > Interestingly enough the complete hinge assembly remained attached to the > airframe. The attach point to the door is doubled firbeglass and the > fibreglass layer attached to the hinge stayed with the hinge. The bolts > pulled thru the outer door fibreglass skin. The paint remained intact an d > there is almost no visible damage to the outer skin of the door. The oth er > aircraft with the hard landing had similar findings after I reviewed his > pictures. > > The door departed because the aft pin wasn't engaged. No aircraft compon ent > failed. I have the lights installed for the doors=2C but > could have missed this with the distractions. I had to readjust them > in the past because the pin is close enough to the magnetic reed that > it sensed the door closed even with the pin outside the engagement block. I > think the best way to manage this is to hand pressure check the engagemen t > of the pin as well as visually check it. My visual check wasn't enough. > The handle on the door is almost directly over > the front pin=2C so pulling shut the door seats that easily. When the > door swings in=2C it is very easy for the aft door to twist and not slip > properly into the aircraft door frame. Rotating the door handle gives a > secure tight feel even when the aft pin is not engaged=2C but just simply > sliding outside the doorframe on the aircraft skin. The front pin pulls it > tight. Once rolling=2C I assume the positive pressure from the vents > internally on the door=2C combined with the negative pressure on the door > surface eventually overwhelms the front pin and at that point it goes ver y > quickly. > > Both of us in the aircraft were experienced pilots=2C and as well the > aircraft really never got above 90-100 knots=2C or above 1000 ft AGL. > Should the pin hold enough to get to altitude or 160 knots=2C I'm not sur e > what would happen=2C as the wind effect is impressive. Again=2C the airc raft > handled fine. Hopefully this note will help others to avoid this event. > > As far as suggested solutions to manage this problem=2C I am not convince d > that the safety wire technique would work effectively=2C but I certainly would > encourage it. For a urologist=2C scrotal reconstructions pay very well. > Please be sure your health insurance is current. > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Oct 02, 2009
You might want to find that piece of fiberglass and do the same test with t he plexi to fiberglass and then also make sure you test it where the gab be tween the to is almost 1/8 of an inch. Make sure it still is as strong. No doubt it is great stuff=2C but just be sure. > From: rvbuilder(at)sausen.net > To: rv10-list(at)matronics.com > Date: Fri=2C 2 Oct 2009 10:30:16 -0500 > Subject: RV10-List: Window Glue > > I thought I would share my experience with an alternative glue for adhe ring the windows. Based on a recommendation from Geoff Combs=2C I picked u p some Lord 7545A/E urethane adhesive rather than using the Weldon 10 we ar e all familiar with. > > I did follow the standard process with the rear windows and after that experience=2C along with forgetting my shims in the rush=2C I thought I wou ld look into the alternatives. After not really finding anything definitiv e from the existing alternatives like Sikaflex I basically resigned myself to use Weldon for the doors. As I got within a couple weeks of doing the d oor windows Geoff had mentioned to me that he used something else for the w indow adhesive that was very much suited for the task and didn't have the q uick cure times and viscosity issues of Weldon. I had forgot about it unti l he had a brief blurb in one of his post a couple weeks back. So I got mo re details from him and found a distributor that I could get the 50ML two p art cartridge. The stuff is comparable in price to the Weldon at about $13 a kit and each 50ML kit will do a window easily. There is an additional c ost in that you need a gun which is about $30 but it will work with any two part=2C 1:1=2C gun packaged product. Each pak also comes with a self mixi ng dispensing nozzle so you just stick it in the gun=2C put the nozzle on =2C and squeeze. Extra tips are less than a buck and if you don't use the whole cartridge you just chuck the tip and put the cap back on. > > I'm sure many of you are saying that you've heard this before but this stuff is GREAT! It looks and acts similar to the Weldon but you get upward s of 30min working time and it doesn't even sag! This stuff is made specif ically as a structural adhesive for plastics so it seems to be an excellent product for this application. > > Not wanting to completely trust what I read I decided to a little non-s cientific destructive testing. I didn't have a piece of scrap fiberglass a nymore but I did have plenty of scrap plexi from trimming the windows so I took two pieces and glued an overlap of about 1.5x1.5 inch on two pieces of scrap. Cure time for this stuff is about 24 hours but I let it sit for ab out a week. This stuff doesn't get as rock hard as Weldon but it isn't fle xible either. I took the glued piece and put it in the vise on its edge an d tried to separate it in full edge shear (not really sure how to describe it but was the most difficult way to break it) and the plexi broke clear of the glue joint. I then turned it flat and tried to peel it apart and agai n the plexi broke away from the glue joint. So far the glue joint hasn't b udged. I then took a hammer and beat the crap out of the remaining square which was basically just the glued area. After several whacks with the fra ming hammer I was finally able to get it to break into 3 pieces without ANY separation of the glue joint. I've attached a few pictures below so you c an see what I'm talking about. > > The initial swag I took at how many cartridges I would need was a littl e high so I have four extras that I can sell to anyone that is interested. I was thinking $16 each would cover the cost and shipping and I can send y ou my gun to use as long as you send it back in a reasonable amount of time . > > Here is a link to the distributor I got it from. This page also has a link to the gun you need and extra tips if you want them. Keep in mind eac h pack comes with one tip too. > > http://chemical-concepts.com/products.php?sid=192&limit > > Here is a technical datasheet on 7545A: > > http://www.glue4you.com/PDF/Lord7545_TN001.pdf > > If you want two or four of the unopened packs I have just drop me a email directly. > Michael > > ________________________________________________________________________________
Date: Oct 02, 2009
concur on pin length; I advised Vans earlier that their supplied pins already cut to length were barely sufficient if they were placed exactly where the Van's engineers wanted them. Actual placement can vary by 1/4" depending on where the builder located the pins in the latch mechanism recess in the door. Full circumference should be seen inside , at a minimum, the fuselage door post when the pin is in the locked position _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Friday, October 02, 2009 6:09 PM Subject: RE: RV10-List: Door-I'm the guy. IMOP make the pins longer and build up the interior of the cabin top so that when the door is closed with the pins engaged, the cabin top is touching the inside of the door. That way there is no guess work involved as there would be if one is guestimating the gap between cabin top flange and inside surface of the door, especially alone the entire bottom edge of the cabin top/door interface. My pins go 1/4inch beyond the two aluminum fuselage frames, for and aft frames. John #409, the lager, just finished an RC foam sloper so I could have that feeling of entirely completing something. > From: dlm46007(at)cox.net > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Door-I'm the guy. > Date: Fri, 2 Oct 2009 16:49:53 -0700 > > > Congratulations on landing safely; perhaps a way could be found on the > interior fa=E7ade to allow "feeling" the pins. Fortunately I chose not to have > the fa=E7ade so I feel the pins, each side, fore and aft, twice; pins are > check after loading and before takeoff and I do it. I have missed the > passenger door rear pin once (after loading) but caught it immediately by > feeling the pins fore and aft. I have not installed the light system. I > don't intend to install the safety wire since at 65 I still use mine. I have > two back seat options ages 10 and 13. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Koonce > Sent: Friday, October 02, 2009 4:20 PM > To: RV10-List(at)matronics.com > Subject: RV10-List: Door-I'm the guy. > > > A friend told me that I made your discussions. I lost the door on takeoff > last week. > > A fly-in was finishing up when a pilot friend asked me for a ride in my RV > 10. I had had it parked on the ramp most of the day for static display. > I'm a Urologist and was on call, but staying in the local area would still > not put me more than 30 min from the hospital if I got called for an > emergency. We taxied out for a quick spin. I'm very aware of the door > problem and have a double check for the door. I personally close both doors > on both sides and check security front and aft both visually and with hand > pressure. When we got in I checked his side as I usually do and closed my > own door. I keep the passenger seat forward and it makes it difficult to > hand pressure check the aft pin because of the closeness of the seat to the > door. Visually it looked fine. During taxi I of course got paged and this > distracted me from the flying. I handled the page and we continued taxi. > The passenger is a pilot who built, flew and ultimately sold an RV 6. > I'm suspicious this made me a bit cavalier about pre flight steps. We had > already done our run up sequence and started our takeoff roll fairly > quickly. We had lifted off and were climbing at about 80-90 knots when the > door shifted out. It happened very quickly, went on out, twisted on the > hinges and departed. It did not strike the airframe. We continued the > climb, did a go round, and landed uneventfully. Except for the noise the > aircraft handled without problems. We retrieved the door and there is > surprisingly little > damage. The plexiglass has two cracks about 3-4 inches. > Interestingly enough the complete hinge assembly remained attached to the > airframe. The attach point to the door is doubled firbeglass and the > fibreglass layer attached to the hinge stayed with the hinge. The bolts > pulled thru the outer door fibreglass skin. The paint remained intact and > there is almost no visible damage to the outer skin of the door. The other > aircraft with the hard landing had similar findings after I reviewed his > pictures. > > The door departed because the aft pin wasn't engaged. No aircraft component > failed. I have the lights installed for the doors, but > could have missed this with the distractions. I had to readjust them > in the past because the pin is close enough to the magnetic reed that > it sensed the door closed even with the pin outside the engagement block. I > think the best way to manage this is to hand pressure check the engagement > of the pin as well as visually check it. My visual check wasn't enough. > The handle on the door is almost directly over > the front pin, so pulling shut the door seats that easily. When the > door swings in, it is very easy for the aft door to twist and not slip > properly into the aircraft door frame. Rotating the door handle gives a > secure tight feel even when the aft pin is not engaged, but just simply > sliding outside the doorframe on the aircraft skin. The front pin pulls it > tight. Once rolling, I assume the positive pressure from the vents > internally on the door, combined with the negative pressure on the door > surface eventually overwhelms the front pin and at that point it goes very > quickly. > > Both of us in the aircraft were experienced pilots, and as well the > aircraft really never got above 90-100 knots, or above 1000 ft AGL. > Should the pin hold enough to get to altitude or 160 knots, I'm not sure > what would happen, as the wind effect is impressive. Again, the aircraft > handled fine. Hopefully this note will help others to avoid this event. > > As far as suggested solutions to manage this problem, I am not convinced > that the safety wire technique would work effectively, but I certainly would > encourage it. For a urologist, scrotal reconstructions pay very well. > Please be sure your health insurance i======================== > ========== > > > ________________________________________________________________________________
Subject: Re: Door-I'm the guy.
Date: Oct 03, 2009
VGhhdCdzIHJlYWxseSBob3cgYSBwcm9wZXJseSBmaXQgZG9vciBzaG91bGQgYmUuLi5JTUhPLi4u RldJVy4uLnlvdSBjYW4ndCBsYXRjaCBteSBkb29ycyB3aXRoIGEgcGluIG91dCBvZiB0aGUgc29j a2V0IA0KDQpSaWNrIFNrZWQNCk4yNDZSUw0KU2VudCB2aWEgQmxhY2tCZXJyeSBieSBBVCZUDQoN Ci0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBKb2huIEdvbnphbGV6IDxpbmRpZ29v bmxhdGlnb0Btc24uY29tPg0KDQpEYXRlOiBGcmksIDIgT2N0IDIwMDkgMTg6MDk6MTggDQpUbzog UlYgMTAgZ3JvdXA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSRTogUlYxMC1M aXN0OiBEb29yLUknbSB0aGUgZ3V5Lg0KDQoNCg0KSU1PUCBtYWtlIHRoZSBwaW5zIGxvbmdlciBh bmQgYnVpbGQgdXAgdGhlIGludGVyaW9yIG9mIHRoZSBjYWJpbiB0b3Agc28gdGhhdCB3aGVuIHRo ZSBkb29yIGlzIGNsb3NlZCB3aXRoIHRoZSBwaW5zIGVuZ2FnZWQsIHRoZSBjYWJpbiB0b3AgaXMg dG91Y2hpbmcgdGhlIGluc2lkZSBvZiB0aGUgZG9vci4gVGhhdCB3YXkgdGhlcmUgaXMgbm8gZ3Vl c3Mgd29yayBpbnZvbHZlZCBhcyB0aGVyZSB3b3VsZCBiZSBpZiBvbmUgaXMgZ3Vlc3RpbWF0aW5n IHRoZSBnYXAgYmV0d2VlbiBjYWJpbiB0b3AgZmxhbmdlIGFuZCBpbnNpZGUgc3VyZmFjZSBvZiB0 aGUgZG9vciwgZXNwZWNpYWxseSBhbG9uZSB0aGUgZW50aXJlIGJvdHRvbSBlZGdlIG9mIHRoZSBj YWJpbiB0b3AvZG9vciBpbnRlcmZhY2UuDQpNeSBwaW5zIGdvIDEvNGluY2ggYmV5b25kIHRoZSB0 d28gYWx1bWludW0gZnVzZWxhZ2UgZnJhbWVzLCBmb3IgYW5kIGFmdCBmcmFtZXMuDQpKb2huICM0 MDksIHRoZSBsYWdlciwganVzdCBmaW5pc2hlZCBhbiBSQyBmb2FtIHNsb3BlciBzbyBJIGNvdWxk IGhhdmUgdGhhdCBmZWVsaW5nIG9mIGVudGlyZWx5IGNvbXBsZXRpbmcgc29tZXRoaW5nLg0KDQo+ IEZyb206IGRsbTQ2MDA3QGNveC5uZXQNCj4gVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQo+ IFN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IERvb3ItSSdtIHRoZSBndXkuDQo+IERhdGU6IEZyaSwg MiBPY3QgMjAwOSAxNjo0OTo1MyAtMDcwMA0KPiANCj4gLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBv c3RlZCBieTogIkRhdmlkIE1jTmVpbGwiIDxkbG00NjAwN0Bjb3gubmV0Pg0KPiANCj4gQ29uZ3Jh dHVsYXRpb25zIG9uIGxhbmRpbmcgc2FmZWx5OyBwZXJoYXBzIGEgd2F5IGNvdWxkIGJlIGZvdW5k IG9uIHRoZQ0KPiBpbnRlcmlvciBmYedhZGUgdG8gYWxsb3cgImZlZWxpbmciIHRoZSBwaW5zLiBG b3J0dW5hdGVseSBJIGNob3NlIG5vdCB0byBoYXZlDQo+IHRoZSBmYedhZGUgc28gSSBmZWVsIHRo ZSBwaW5zLCBlYWNoIHNpZGUsIGZvcmUgYW5kIGFmdCwgdHdpY2U7IHBpbnMgYXJlDQo+IGNoZWNr IGFmdGVyIGxvYWRpbmcgYW5kIGJlZm9yZSB0YWtlb2ZmIGFuZCBJIGRvIGl0LiBJIGhhdmUgbWlz c2VkIHRoZQ0KPiBwYXNzZW5nZXIgZG9vciByZWFyIHBpbiBvbmNlIChhZnRlciBsb2FkaW5nKSBi dXQgY2F1Z2h0IGl0IGltbWVkaWF0ZWx5IGJ5DQo+IGZlZWxpbmcgdGhlIHBpbnMgZm9yZSBhbmQg YWZ0LiAgSSBoYXZlIG5vdCBpbnN0YWxsZWQgdGhlIGxpZ2h0IHN5c3RlbS4gSQ0KPiBkb24ndCBp bnRlbmQgdG8gaW5zdGFsbCB0aGUgc2FmZXR5IHdpcmUgc2luY2UgYXQgNjUgSSBzdGlsbCB1c2Ug bWluZS4gSSBoYXZlDQo+IHR3byBiYWNrIHNlYXQgb3B0aW9ucyBhZ2VzIDEwIGFuZCAxMy4NCj4g DQo+IC0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQo+IEZyb206IG93bmVyLXJ2MTAtbGlzdC1z ZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KPiBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEpvaG4gS29vbmNlDQo+IFNlbnQ6IEZyaWRheSwgT2N0 b2JlciAwMiwgMjAwOSA0OjIwIFBNDQo+IFRvOiBSVjEwLUxpc3RAbWF0cm9uaWNzLmNvbQ0KPiBT dWJqZWN0OiBSVjEwLUxpc3Q6IERvb3ItSSdtIHRoZSBndXkuDQo+IA0KPiAtLT4gUlYxMC1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiBKb2huIEtvb25jZSA8am9obkBqcGtvb25jZS5uZXQ+DQo+IA0K PiBBIGZyaWVuZCB0b2xkIG1lIHRoYXQgSSBtYWRlIHlvdXIgZGlzY3Vzc2lvbnMuICBJIGxvc3Qg dGhlIGRvb3Igb24gdGFrZW9mZg0KPiBsYXN0IHdlZWsuDQo+IA0KPiBBIGZseS1pbiB3YXMgZmlu aXNoaW5nIHVwIHdoZW4gYSBwaWxvdCBmcmllbmQgYXNrZWQgbWUgZm9yIGEgcmlkZSBpbiBteSBS Vg0KPiAxMC4gIEkgaGFkIGhhZCBpdCBwYXJrZWQgb24gdGhlIHJhbXAgbW9zdCBvZiB0aGUgZGF5 IGZvciBzdGF0aWMgZGlzcGxheS4NCj4gSSdtIGEgVXJvbG9naXN0IGFuZCB3YXMgb24gY2FsbCwg YnV0IHN0YXlpbmcgaW4gdGhlIGxvY2FsIGFyZWEgd291bGQgc3RpbGwNCj4gbm90IHB1dCBtZSBt b3JlIHRoYW4gMzAgbWluIGZyb20gdGhlIGhvc3BpdGFsIGlmIEkgZ290IGNhbGxlZCBmb3IgYW4N Cj4gZW1lcmdlbmN5LiAgV2UgdGF4aWVkIG91dCBmb3IgYSBxdWljayBzcGluLiAgSSdtIHZlcnkg YXdhcmUgb2YgdGhlIGRvb3INCj4gcHJvYmxlbSBhbmQgaGF2ZSBhIGRvdWJsZSBjaGVjayBmb3Ig dGhlIGRvb3IuICBJIHBlcnNvbmFsbHkgY2xvc2UgYm90aCBkb29ycw0KPiBvbiBib3RoIHNpZGVz IGFuZCBjaGVjayBzZWN1cml0eSBmcm9udCBhbmQgYWZ0IGJvdGggdmlzdWFsbHkgYW5kIHdpdGgg aGFuZA0KPiBwcmVzc3VyZS4gIFdoZW4gd2UgZ290IGluIEkgY2hlY2tlZCBoaXMgc2lkZSBhcyBJ IHVzdWFsbHkgZG8gYW5kIGNsb3NlZCBteQ0KPiBvd24gZG9vci4gIEkga2VlcCB0aGUgcGFzc2Vu Z2VyIHNlYXQgZm9yd2FyZCBhbmQgaXQgbWFrZXMgaXQgZGlmZmljdWx0IHRvDQo+IGhhbmQgcHJl c3N1cmUgY2hlY2sgdGhlIGFmdCBwaW4gYmVjYXVzZSBvZiB0aGUgY2xvc2VuZXNzIG9mIHRoZSBz ZWF0IHRvIHRoZQ0KPiBkb29yLiAgVmlzdWFsbHkgaXQgbG9va2VkIGZpbmUuICBEdXJpbmcgdGF4 aSBJIG9mIGNvdXJzZSBnb3QgcGFnZWQgYW5kIHRoaXMNCj4gZGlzdHJhY3RlZCBtZSBmcm9tIHRo ZSBmbHlpbmcuICBJIGhhbmRsZWQgdGhlIHBhZ2UgYW5kIHdlIGNvbnRpbnVlZCB0YXhpLg0KPiBU aGUgcGFzc2VuZ2VyIGlzIGEgcGlsb3Qgd2hvIGJ1aWx0LCBmbGV3IGFuZCB1bHRpbWF0ZWx5IHNv bGQgYW4gUlYgNi4gICANCj4gSSdtIHN1c3BpY2lvdXMgdGhpcyBtYWRlIG1lIGEgYml0IGNhdmFs aWVyIGFib3V0IHByZSBmbGlnaHQgc3RlcHMuICBXZSBoYWQNCj4gYWxyZWFkeSBkb25lIG91ciBy dW4gdXAgc2VxdWVuY2UgYW5kIHN0YXJ0ZWQgb3VyIHRha2VvZmYgcm9sbCBmYWlybHkNCj4gcXVp Y2tseS4gIFdlIGhhZCBsaWZ0ZWQgb2ZmIGFuZCB3ZXJlIGNsaW1iaW5nIGF0IGFib3V0IDgwLTkw IGtub3RzIHdoZW4gdGhlDQo+IGRvb3Igc2hpZnRlZCBvdXQuICBJdCBoYXBwZW5lZCB2ZXJ5IHF1 aWNrbHksIHdlbnQgb24gb3V0LCB0d2lzdGVkIG9uIHRoZQ0KPiBoaW5nZXMgYW5kIGRlcGFydGVk LiAgSXQgZGlkIG5vdCBzdHJpa2UgdGhlIGFpcmZyYW1lLiAgV2UgY29udGludWVkIHRoZQ0KPiBj bGltYiwgZGlkIGEgZ28gcm91bmQsIGFuZCBsYW5kZWQgdW5ldmVudGZ1bGx5LiAgRXhjZXB0IGZv ciB0aGUgbm9pc2UgdGhlDQo+IGFpcmNyYWZ0IGhhbmRsZWQgd2l0aG91dCBwcm9ibGVtcy4gIFdl IHJldHJpZXZlZCB0aGUgZG9vciBhbmQgdGhlcmUgaXMNCj4gc3VycHJpc2luZ2x5IGxpdHRsZSAg DQo+IGRhbWFnZS4gIFRoZSBwbGV4aWdsYXNzIGhhcyB0d28gY3JhY2tzIGFib3V0IDMtNCBpbmNo ZXMuICAgDQo+IEludGVyZXN0aW5nbHkgZW5vdWdoIHRoZSBjb21wbGV0ZSBoaW5nZSBhc3NlbWJs eSByZW1haW5lZCBhdHRhY2hlZCB0byB0aGUNCj4gYWlyZnJhbWUuICBUaGUgYXR0YWNoIHBvaW50 IHRvIHRoZSBkb29yIGlzIGRvdWJsZWQgZmlyYmVnbGFzcyBhbmQgdGhlDQo+IGZpYnJlZ2xhc3Mg bGF5ZXIgYXR0YWNoZWQgdG8gdGhlIGhpbmdlIHN0YXllZCB3aXRoIHRoZSBoaW5nZS4gIFRoZSBi b2x0cw0KPiBwdWxsZWQgdGhydSB0aGUgb3V0ZXIgZG9vciBmaWJyZWdsYXNzIHNraW4uICBUaGUg cGFpbnQgcmVtYWluZWQgaW50YWN0IGFuZA0KPiB0aGVyZSBpcyBhbG1vc3Qgbm8gdmlzaWJsZSBk YW1hZ2UgdG8gdGhlIG91dGVyIHNraW4gb2YgdGhlIGRvb3IuICBUaGUgb3RoZXINCj4gYWlyY3Jh ZnQgd2l0aCB0aGUgaGFyZCBsYW5kaW5nIGhhZCBzaW1pbGFyIGZpbmRpbmdzIGFmdGVyIEkgcmV2 aWV3ZWQgaGlzDQo+IHBpY3R1cmVzLg0KPiANCj4gVGhlIGRvb3IgZGVwYXJ0ZWQgYmVjYXVzZSB0 aGUgYWZ0IHBpbiB3YXNuJ3QgZW5nYWdlZC4gIE5vIGFpcmNyYWZ0IGNvbXBvbmVudA0KPiBmYWls ZWQuICBJIGhhdmUgdGhlIGxpZ2h0cyBpbnN0YWxsZWQgZm9yIHRoZSBkb29ycywgYnV0ICANCj4g Y291bGQgaGF2ZSBtaXNzZWQgdGhpcyB3aXRoIHRoZSBkaXN0cmFjdGlvbnMuICAgSSBoYWQgdG8g cmVhZGp1c3QgdGhlbSAgDQo+IGluIHRoZSBwYXN0IGJlY2F1c2UgdGhlIHBpbiBpcyBjbG9zZSBl bm91Z2ggdG8gdGhlIG1hZ25ldGljIHJlZWQgdGhhdCAgIA0KPiBpdCBzZW5zZWQgdGhlIGRvb3Ig Y2xvc2VkIGV2ZW4gd2l0aCB0aGUgcGluIG91dHNpZGUgdGhlIGVuZ2FnZW1lbnQgYmxvY2suICBJ DQo+IHRoaW5rIHRoZSBiZXN0IHdheSB0byBtYW5hZ2UgdGhpcyBpcyB0byBoYW5kIHByZXNzdXJl IGNoZWNrIHRoZSBlbmdhZ2VtZW50DQo+IG9mIHRoZSBwaW4gYXMgd2VsbCBhcyB2aXN1YWxseSBj aGVjayBpdC4gIE15IHZpc3VhbCBjaGVjayB3YXNuJ3QgZW5vdWdoLg0KPiBUaGUgaGFuZGxlIG9u IHRoZSBkb29yIGlzIGFsbW9zdCBkaXJlY3RseSBvdmVyICANCj4gdGhlIGZyb250IHBpbiwgc28g cHVsbGluZyBzaHV0IHRoZSBkb29yIHNlYXRzIHRoYXQgZWFzaWx5LiAgIFdoZW4gdGhlICANCj4g ZG9vciBzd2luZ3MgaW4sIGl0IGlzIHZlcnkgZWFzeSBmb3IgdGhlIGFmdCBkb29yIHRvIHR3aXN0 IGFuZCBub3Qgc2xpcA0KPiBwcm9wZXJseSBpbnRvIHRoZSBhaXJjcmFmdCBkb29yIGZyYW1lLiAg Um90YXRpbmcgdGhlIGRvb3IgaGFuZGxlIGdpdmVzIGENCj4gc2VjdXJlIHRpZ2h0IGZlZWwgZXZl biB3aGVuIHRoZSBhZnQgcGluIGlzIG5vdCBlbmdhZ2VkLCBidXQganVzdCBzaW1wbHkNCj4gc2xp ZGluZyBvdXRzaWRlIHRoZSBkb29yZnJhbWUgb24gdGhlIGFpcmNyYWZ0IHNraW4uICBUaGUgZnJv bnQgcGluIHB1bGxzIGl0DQo+IHRpZ2h0LiAgT25jZSByb2xsaW5nLCBJIGFzc3VtZSB0aGUgcG9z aXRpdmUgcHJlc3N1cmUgZnJvbSB0aGUgdmVudHMNCj4gaW50ZXJuYWxseSBvbiB0aGUgZG9vciwg Y29tYmluZWQgd2l0aCB0aGUgbmVnYXRpdmUgcHJlc3N1cmUgb24gdGhlIGRvb3INCj4gc3VyZmFj ZSBldmVudHVhbGx5IG92ZXJ3aGVsbXMgdGhlIGZyb250IHBpbiBhbmQgYXQgdGhhdCBwb2ludCBp dCBnb2VzIHZlcnkNCj4gcXVpY2tseS4NCj4gDQo+IEJvdGggb2YgdXMgaW4gdGhlIGFpcmNyYWZ0 IHdlcmUgZXhwZXJpZW5jZWQgcGlsb3RzLCBhbmQgYXMgd2VsbCB0aGUgIA0KPiBhaXJjcmFmdCBy ZWFsbHkgbmV2ZXIgZ290IGFib3ZlIDkwLTEwMCBrbm90cywgb3IgYWJvdmUgMTAwMCBmdCBBR0wu ICAgDQo+IFNob3VsZCB0aGUgcGluIGhvbGQgZW5vdWdoIHRvIGdldCB0byBhbHRpdHVkZSBvciAx NjAga25vdHMsIEknbSBub3Qgc3VyZQ0KPiB3aGF0IHdvdWxkIGhhcHBlbiwgYXMgdGhlIHdpbmQg ZWZmZWN0IGlzIGltcHJlc3NpdmUuICBBZ2FpbiwgdGhlIGFpcmNyYWZ0DQo+IGhhbmRsZWQgZmlu ZS4gIEhvcGVmdWxseSB0aGlzIG5vdGUgd2lsbCBoZWxwIG90aGVycyB0byBhdm9pZCB0aGlzIGV2 ZW50Lg0KPiANCj4gQXMgZmFyIGFzIHN1Z2dlc3RlZCBzb2x1dGlvbnMgdG8gbWFuYWdlIHRoaXMg cHJvYmxlbSwgSSBhbSBub3QgY29udmluY2VkDQo+IHRoYXQgdGhlIHNhZmV0eSB3aXJlIHRlY2hu aXF1ZSB3b3VsZCB3b3JrIGVmZmVjdGl2ZWx5LCBidXQgSSBjZXJ0YWlubHkgd291bGQNCj4gZW5j b3VyYWdlIGl0LiAgRm9yIGEgdXJvbG9naXN0LCBzY3JvdGFsIHJlY29uc3RydWN0aW9ucyBwYXkg dmVyeSB3ZWxsLg0KPiBQbGVhc2UgYmUgc3VyZSB5b3VyIGhlYWx0aCBpbnN1cmFuY2UgaXMgY3Vy cmVudC4NCj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPT09PT09PT09PT09DQo9PT09 PT09PT09PT0NCj09PT09PT09PT09PQ0KPT09PT09PT09PT09DQo+IA0KPiANCj4gDQogCQkgCSAg IAkJICANCg= ________________________________________________________________________________
Subject: charger 12248
Date: Oct 02, 2009
Just received it tonight. Will report later. One immediate observation; for each battery behind the closeout, a separate sensor wire is required and 12V cigarette plugs must be placed in the top where it is not necessary to remove the rear cover to maintain the batteries. ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Oct 02, 2009
Recommend you set the EFIS (or whatever engine monitoring system being used) to alarm on low voltage. With the alternator on line your buss voltage will be between 13.8 and 14.1 volts. A fully charged battery is significantly below this level. Setting a low voltage alarm at say 13.4 volts will immediate tell you your alternator is off line. Assuming a typical battery installation, and now knowing as soon as the alternator fails, you should have ample battery reserve for continued flight to a convenient place to land and get the alternator fixed. Carl Froehlich RV-8A (500 hrs) RV-10 (fuselage fiberglass work) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Sent: Friday, October 02, 2009 8:28 PM Subject: RV10-List: AFS - Alternator Warning I am flying with an AFS 3500EE EFIS / Engine Monitor. Yesterday the airplane was being flown and the fuse blew on the alternator field circuit causing the alternator go off line. Turns out the alternator AMPS warning is OFF by default and no warning was heard. It wasn't until the battery was low that an audible / visual alert was presented on the EFIS. Not sure just how long it took for the battery to get to the low voltage warning condition. I have copied the flight data from the EFIS and will review the data to see just how long it took. The EFIS went to backup battery during the flight and the flight was terminated with no other problems. This is just a heads up to those flying with the AFS EFIS to check the alternator AMPS setting in the configuration pages should you want an immediate warning for alternator current. Knowing you have a problem sooner than later is desirable. I did not have the alternator lamp wired (Didn't think I needed it with the EFIS audible alerts). I will be adding this to the panel in the near future. I love the EFIS, I just missed getting this setting correct. Jim Combs (N312F - 110+ hours) ________________________________________________________________________________
Date: Oct 02, 2009
Correction to previous post. Sensor will not be required for most situations. For any battery behind the closeout, the most feasible charging will take place with a 12V cigarette receptacle adjacent to or in the top piece; each connector will have ring terminals on the battery terminals. I have 2 680s there and will need two receptacles. A single cigarette plug can be matched to the special connector and plugged into the battery to be maintained. Concorde batteries fall to the gel category, Odyssey are AGM and I hope we don't have any unsealed batteries in the aircraft. ________________________________________________________________________________
Date: Oct 02, 2009
Subject: Re: charger 12248
Not sure which Concorde batteries you are referring to David. The RG series are all AGM. The CB series are wet cell. The battery Van's suggests is an RG-25 which is AGM. I don't happen to know of any they sell for aircraft that are gel cell, maybe there are some. On Fri, Oct 2, 2009 at 9:01 PM, David McNeill wrote: > Correction to previous post. Sensor will not be required for most > situations. For any battery behind the closeout, the most feasible charging > will take place with a 12V cigarette receptacle adjacent to or in the top > piece; each connector will have ring terminals on the battery terminals. I > have 2 680s there and will need two receptacles. A single cigarette plug can > be matched to the special connector and plugged into the battery to be > maintained. Concorde batteries fall to the gel category, Odyssey are AGM and > I hope we don't have any unsealed batteries in the aircraft. ________________________________________________________________________________
Date: Oct 03, 2009
I just finished installing the door latch last week and I can readily see what I think is the problem. the door is flexible fore and aft, and the rear end tends to shift out of the frame when closing. And The gasket wants to push the door out. I opened and closed about 100 times from the outside and consistently the rear end wants to ride out. To me it seems the alternate pull handle near the rear of the door is a very safe and operational fix, and a careful visual check of the rear door frame to be sure it has seated firmly against the gasket. then operate the handle to extend the pins. Also, you can pick up a few fractional inches of pin extension by sliding the rack gear out one or 2 teeth on the cog before assembly, just as long as you have full retraction. Just my 2 cents. -------- Claude KAYS airport Building RV 10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266223#266223 ________________________________________________________________________________
Subject: Re: Another QB 10 Issue - Longeron Length (again)
Date: Oct 03, 2009
I had to trim the longeron, but not that much. I cut off about one inch or less. possibly my kit had shorter longerons to begin with. -------- Claude KAYS airport Building RV 10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266224#266224 ________________________________________________________________________________
Date: Oct 03, 2009
I tested them a couple of ways. 1) I crept up on the torque values until I could get it to budget. - 85 inches 2) I marked a few nuts (before I touched them) so I knew where they started. a. Then backed them off to neutral b. Torque back to 25 inches They were all at around 1 flat too far. From: Rob Kochman [mailto:rv10rob(at)gmail.com] Sent: Friday, October 02, 2009 5:51 PM Subject: Re: RV10-List: Re: Control column mounts If they start turning at 85 in-lbs, that doesn't mean they were torqued to 85, correct? Isn't extra torque required to "break free"? On Fri, Oct 2, 2009 at 11:06 AM, Perry, Phil wrote: Thought I'd share this piece of knowledge with the QB group too. Check the torque values of all your QB installed AN3 hardware. I started sneaking up on mine the other night to see what value they were tourqed to. Any guesses???? 85 inches. Phil -----Original Message----- From: Bob Turner [mailto:bobturner(at)alum.rpi.edu] Sent: Friday, October 02, 2009 12:39 PM Subject: RV10-List: Re: Control column mounts In his case, the QB guys have already installed it, without removing material. I see no interference issues, just a little extra weight. But I'm not flying yet! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266088#266088 tilities such as List Un/Subscription, www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List ronics.com/" target="_blank">http://forums.matronics.com Matt Dralle, List Admin. ==== -- Rob Kochman RV-10 Wings Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Oct 03, 2009
John, I'm glad that all ended well without major damage to you plane or person. I've had doors come open on Beechcraft planes I've owned but the door hinges forward so other than an annoyance it's not such a big deal like it is on an RV10. For whatever it's worth, because of all the issues that have occurred with doors coming open, I never allow a passenger to close the door. I stay outside of the airplane until the passengers are loaded in, then I close the passenger door from the outside myself and assure that I have a positive lock and can obviously see that the pins are in. Once in and started I have the warning lights at the top of the panel and that is part of my check. I know for me, because of all the incidences, the doors are one of my top pre-takeoff checks. Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: AFS - Alternator Warning
Date: Oct 03, 2009
Glad this ended nicely - I have mine set so that it alarms if my RPM's go over 1500. Since I have two alternators, my checklist is to bring the backup online first and look for its light. When I bring the primary online the secondary light goes out. Battery backup is a wonderful safety feature. ----- Original Message ----- From: Jim To: rv10-list(at)matronics.com Sent: Friday, October 02, 2009 8:27 PM Subject: RV10-List: AFS - Alternator Warning I am flying with an AFS 3500EE EFIS / Engine Monitor. Yesterday the airplane was being flown and the fuse blew on the alternator field circuit causing the alternator go off line. Turns out the alternator AMPS warning is OFF by default and no warning was heard. It wasn't until the battery was low that an audible / visual alert was presented on the EFIS. Not sure just how long it took for the battery to get to the low voltage warning condition. I have copied the flight data from the EFIS and will review the data to see just how long it took. The EFIS went to backup battery during the flight and the flight was terminated with no other problems. This is just a heads up to those flying with the AFS EFIS to check the alternator AMPS setting in the configuration pages should you want an immediate warning for alternator current. Knowing you have a problem sooner than later is desirable. I did not have the alternator lamp wired (Didn't think I needed it with the EFIS audible alerts). I will be adding this to the panel in the near future. I love the EFIS, I just missed getting this setting correct. Jim Combs (N312F - 110+ hours) ________________________________________________________________________________
Date: Oct 03, 2009
> I never allow a passenger to close the door. It's a sad day when a pilot cannot allow a passenger to close his own door. I guess cracking the door open during long taxis on hot days is out. The door design is flawed and needs to be changed. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266251#266251 ________________________________________________________________________________
Date: Oct 03, 2009
You know, when I was at Oshkosh I paid the $50 so I could get a demo ride in the -10. I'd just bought a partially finished kit and figured I really ought to make sure I liked the airplane. Not being a rookie and all I did think it a bit odd that I wasn't allowed to latch the door.... I'd love to re-engineer that latch and offer a after-market fix for this but my fuselage kit just shipped so I'm a ways away from even thinking about the doors but when I do I hope to come up with something more foolproof. I'm thinking some sort of bottom latch that engages at the sill such that, even in the event of it not being completely clamped down the door could only partially open even under air loads. But there's a lot of work to get this right and I might be too impatient to put in the effort required. Safe to say I'll do something more than the basic stock arrangement. Time will tell... Richard Bibb 972-771-2598 972-835-5979 mobile -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, October 03, 2009 8:49 AM Subject: RV10-List: Re: Door-I'm the guy. > I never allow a passenger to close the door. It's a sad day when a pilot cannot allow a passenger to close his own door. I guess cracking the door open during long taxis on hot days is out. The door design is flawed and needs to be changed. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266251#266251 ________________________________________________________________________________
Date: Oct 03, 2009
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
John, Thanks so much for your account of the episode. I was starting to get a little bored with my routine: I push on the back of each door just before take-off. Now I know I'll stick with that checklist item for good. What type of door seal do you have? I wrote a few days ago that I think the Van's bulb seal does a disservice to being able to effectively close the door. I have foam seals that IMO work much better. Another point is that if the pins are installed per the plans, the bevels get installed with the long edge outboard. Presumably, that ensures more engagement with the fuselage uprights since the long edge of the pin is outboard, contacting metal. But that arrangement also helps the pins miss the hole unless the door is pulled all the way in during latching. When I re-rigged my doors I turned the bevel around to face "angled edge out", so that the pins would be more likely to engage. The bevel then helps pull the door in, even if the door isn't quite closed. Since I also installed metal guide blocks at the same time, I was sure I was getting a good, solid, metal-on-metal pin engagement. You did a great job Flying The Plane. Even the other -10 that had the tail strike seemed to land well enough. We should take away from this that a lost door clearly doesn't have to result in an accident if we remember to fly the plane. ******Shameless plug warning****** Insurance pays (AirCrafters) well for door repairs, too, in case you don't want to do it yourself--I never do MY own surgery ;-) Best Regards, Dave Saylor AirCrafters LLC ________________________________________________________________________________
Date: Oct 03, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: Door-I'm the guy - how about those seals?
Dave, I'm getting ready to re-search the list for seal information so I can finish off my doors. I know you've mentioned your preference for foam seals over the Van's bulb type. I know others have used other bulb type seals. What do you think the trade-offs are for the foam seal? Does it work well relative to rain? What exactly did you use? Thanks Bill "trying to figure out what to do next and hoping it doesn't involve sanding fiberglass" Watson Dave Saylor wrote: > John, > > Thanks so much for your account of the episode. I was starting to get > a little bored with my routine: I push on the back of each door just > before take-off. Now I know I'll stick with that checklist item for good. > > What type of door seal do you have? I wrote a few days ago that I > think the Van's bulb seal does a disservice to being able to > effectively close the door. I have foam seals that IMO work much better. > > Another point is that if the pins are installed per the plans, the > bevels get installed with the long edge outboard. Presumably, that > ensures more engagement with the fuselage uprights since the long edge > of the pin is outboard, contacting metal. But that arrangement also > helps the pins miss the hole unless the door is pulled all the way in > during latching. When I re-rigged my doors I turned the bevel around > to face "angled edge out", so that the pins would be more likely to > engage. The bevel then helps pull the door in, even if the door isn't > quite closed. Since I also installed metal guide blocks at the same > time, I was sure I was getting a good, solid, metal-on-metal pin > engagement. > > You did a great job Flying The Plane. Even the other -10 that had the > tail strike seemed to land well enough. We should take away from this > that a lost door clearly doesn't have to result in an accident if we > remember to fly the plane. > > ******Shameless plug warning****** > > Insurance pays (AirCrafters) well for door repairs, too, in case you > don't want to do it yourself--I never do MY own surgery ;-) > > Best Regards, > > Dave Saylor > AirCrafters LLC > > > * > > > * ________________________________________________________________________________
Subject: Door-I'm the guy - how about those seals?
Date: Oct 03, 2009
Bill Many builders have used the McMaster Carr edge grip seals (see http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I could use some as "sacrificial seals" while I was doing the initial fit of my doors. That way I could ensure that the doors didn't become more difficult to close after the seals were installed. Apparently the door geometry can change after seals are installed so it is best to fit the doors with them. Whatever seals you plan on using, I recommend that be on the doors when fitting. Using the above seals will require f/g work - Oh Joy! Cheers Les #409643 - Living in f/g hell -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: October-03-09 10:06 AM Subject: Re: RV10-List: Door-I'm the guy - how about those seals? Dave, I'm getting ready to re-search the list for seal information so I can finish off my doors. I know you've mentioned your preference for foam seals over the Van's bulb type. I know others have used other bulb type seals. What do you think the trade-offs are for the foam seal? Does it work well relative to rain? What exactly did you use? Thanks Bill "trying to figure out what to do next and hoping it doesn't involve sanding fiberglass" Watson Dave Saylor wrote: > John, > > Thanks so much for your account of the episode. I was starting to get > a little bored with my routine: I push on the back of each door just > before take-off. Now I know I'll stick with that checklist item for good. > > What type of door seal do you have? I wrote a few days ago that I > think the Van's bulb seal does a disservice to being able to > effectively close the door. I have foam seals that IMO work much better. > > Another point is that if the pins are installed per the plans, the > bevels get installed with the long edge outboard. Presumably, that > ensures more engagement with the fuselage uprights since the long edge > of the pin is outboard, contacting metal. But that arrangement also > helps the pins miss the hole unless the door is pulled all the way in > during latching. When I re-rigged my doors I turned the bevel around > to face "angled edge out", so that the pins would be more likely to > engage. The bevel then helps pull the door in, even if the door isn't > quite closed. Since I also installed metal guide blocks at the same > time, I was sure I was getting a good, solid, metal-on-metal pin > engagement. > > You did a great job Flying The Plane. Even the other -10 that had the > tail strike seemed to land well enough. We should take away from this > that a lost door clearly doesn't have to result in an accident if we > remember to fly the plane. > > ******Shameless plug warning****** > > Insurance pays (AirCrafters) well for door repairs, too, in case you > don't want to do it yourself--I never do MY own surgery ;-) > > Best Regards, > > Dave Saylor > AirCrafters LLC > > > * > > > * ________________________________________________________________________________
Date: Oct 03, 2009
I was not referring to the RGs; I have several old Concordes; also instructions say if uncertain assume GEL and 2A charge. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, October 02, 2009 9:25 PM Subject: Re: RV10-List: charger 12248 Not sure which Concorde batteries you are referring to David. The RG series are all AGM. The CB series are wet cell. The battery Van's suggests is an RG-25 which is AGM. I don't happen to know of any they sell for aircraft that are gel cell, maybe there are some. On Fri, Oct 2, 2009 at 9:01 PM, David McNeill wrote: > Correction to previous post. Sensor will not be required for most > situations. For any battery behind the closeout, the most feasible > charging will take place with a 12V cigarette receptacle adjacent to > or in the top piece; each connector will have ring terminals on the > battery terminals. I have 2 680s there and will need two receptacles. > A single cigarette plug can be matched to the special connector and > plugged into the battery to be maintained. Concorde batteries fall to > the gel category, Odyssey are AGM and I hope we don't have any unsealed batteries in the aircraft. ________________________________________________________________________________
Date: Oct 03, 2009
glad good piloting allowed for a good outcome. I agree with Wayne--except for my copilot/cobuilder, (and even sometimes with her) I always close the door from the outside. easy to see that things are ok. We also use safety straps. with my door ajar for taxi, it's cool enough. Does seem to me that someone could engineer much longer pins, and have a double set, fore and aft. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266291#266291 ________________________________________________________________________________
Date: Oct 03, 2009
I had to close the doors on my C177RG for 29 years. The aft pin was pulled in the same way as the 10 and if not careful of the feel, the passenger could just keep pushing on the handle and shear the latch pin it which case the door had to disassembled to be locked and the aircraft flown to where it could await a new part from Cessna. Also I have never been asked by a crew member aboard the Boeings to close a door. A friend and I discussed a design this morning that would not only pin the aft door frame with sufficient length but would also put a vertical pin in the door sill. Since we have unfinished door on the inside, another friend and I will discuss the mechanics of a real fix tomorrow AM during the regular breakfast flight. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, October 03, 2009 6:49 AM Subject: RV10-List: Re: Door-I'm the guy. --> > I never allow a passenger to close the door. It's a sad day when a pilot cannot allow a passenger to close his own door. I guess cracking the door open during long taxis on hot days is out. The door design is flawed and needs to be changed. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266251#266251 ________________________________________________________________________________
Date: Oct 03, 2009
Les, what has your experience been so far with the edge seals? I guess I should order some of it to test myself. It seems like I can forsee a few fitting issues. The edge of my fiberglass door frames seem to vary from 1/8" up to 1/4". The lower parts of the door frame are thinner and the upper parts, esp. around the top forward corner and top aft corners have thicker edges. Did you have any edge fitting issues? Which Type 3 seals did you use again? Edge A B and C dimensions? Thanks! Jae 40533 Les Kearney wrote: > > Bill > > Many builders have used the McMaster Carr edge grip seals (see > http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I > could use some as "sacrificial seals" while I was doing the initial fit of > my doors. That way I could ensure that the doors didn't become more > difficult to close after the seals were installed. Apparently the door > geometry can change after seals are installed so it is best to fit the doors > with them. Whatever seals you plan on using, I recommend that be on the > doors when fitting. > > Using the above seals will require f/g work - Oh Joy! > > Cheers > > Les > #409643 - Living in f/g hell > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver > Watson > Sent: October-03-09 10:06 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Door-I'm the guy - how about those seals? > > > > Dave, I'm getting ready to re-search the list for seal information so I > can finish off my doors. I know you've mentioned your preference for > foam seals over the Van's bulb type. I know others have used other bulb > type seals. > > What do you think the trade-offs are for the foam seal? Does it work > well relative to rain? > > What exactly did you use? > > Thanks > Bill "trying to figure out what to do next and hoping it doesn't involve > sanding fiberglass" Watson > > Dave Saylor wrote: > >> John, >> >> Thanks so much for your account of the episode. I was starting to get >> a little bored with my routine: I push on the back of each door just >> before take-off. Now I know I'll stick with that checklist item for good. >> >> What type of door seal do you have? I wrote a few days ago that I >> think the Van's bulb seal does a disservice to being able to >> effectively close the door. I have foam seals that IMO work much better. >> >> Another point is that if the pins are installed per the plans, the >> bevels get installed with the long edge outboard. Presumably, that >> ensures more engagement with the fuselage uprights since the long edge >> of the pin is outboard, contacting metal. But that arrangement also >> helps the pins miss the hole unless the door is pulled all the way in >> during latching. When I re-rigged my doors I turned the bevel around >> to face "angled edge out", so that the pins would be more likely to >> engage. The bevel then helps pull the door in, even if the door isn't >> quite closed. Since I also installed metal guide blocks at the same >> time, I was sure I was getting a good, solid, metal-on-metal pin >> engagement. >> >> You did a great job Flying The Plane. Even the other -10 that had the >> tail strike seemed to land well enough. We should take away from this >> that a lost door clearly doesn't have to result in an accident if we >> remember to fly the plane. >> >> ******Shameless plug warning****** >> >> Insurance pays (AirCrafters) well for door repairs, too, in case you >> don't want to do it yourself--I never do MY own surgery ;-) >> >> Best Regards, >> >> Dave Saylor >> AirCrafters LLC >> >> >> >> * >> >> >> * >> > > > ________________________________________________________________________________
Subject: RV10 Mark 1 Door Interlock
Date: Oct 03, 2009
Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell ________________________________________________________________________________
Date: Oct 03, 2009
Jae I used part # 1120A313 - (3/16 grip with a 3/8" bulb). I used a Dremel with a small drum sander to even up the flanges for the seals. Some places the f/g was hugely thick and others almost perfect. I found that it was difficult to get an even line where I had to notch into the flange due to thickness. After I had fitted the seals, I covered the seal flange with packing tape, put in place and filled any gaps with superfill. The result was a clean edge where the notch meets the edge of the seal. I hope that is clear, if not I will see if I took any pix. Although fitting the doors with the seals in place was a lot of work but the end result is that I have a consistent seal around the doors. Now the doors open and close without a lot of effort. I can't image doing this, then fitting seals, and then adjusting again due to the seal changing the geometry. Here is the single most important think I did to get the doors to close easily. I found that the pressure of the seals on the bottom of the door made closing hard. There is little leverage at the bottom of the door to compress the seals. To fix, I pushed the bottom of the f/g door frame in board about 1/8". This reduces the amount of compression on the door seal at the bottom of the door made closing much, much easier. I didn't final drill the door opening holes (#19 & #12) until after I finished fitting the doors. This made adjusting the position of the door frame very simple. (It easier to fill & move small #30 hole than #19 & # 12 holes). In a couple of places I moved the door flange by building up the back side and then removing material from the face. None of this was hard, it was just time consuming. And I just love f/g dust. Cheers Les #40643 - living in f/g hell -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang Sent: October-03-09 12:11 PM Subject: Re: RV10-List: Door-I'm the guy - how about those seals? Les, what has your experience been so far with the edge seals? I guess I should order some of it to test myself. It seems like I can forsee a few fitting issues. The edge of my fiberglass door frames seem to vary from 1/8" up to 1/4". The lower parts of the door frame are thinner and the upper parts, esp. around the top forward corner and top aft corners have thicker edges. Did you have any edge fitting issues? Which Type 3 seals did you use again? Edge A B and C dimensions? Thanks! Jae 40533 Les Kearney wrote: > > Bill > > Many builders have used the McMaster Carr edge grip seals (see > http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I > could use some as "sacrificial seals" while I was doing the initial fit of > my doors. That way I could ensure that the doors didn't become more > difficult to close after the seals were installed. Apparently the door > geometry can change after seals are installed so it is best to fit the doors > with them. Whatever seals you plan on using, I recommend that be on the > doors when fitting. > > Using the above seals will require f/g work - Oh Joy! > > Cheers > > Les > #409643 - Living in f/g hell > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver > Watson > Sent: October-03-09 10:06 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Door-I'm the guy - how about those seals? > > > > Dave, I'm getting ready to re-search the list for seal information so I > can finish off my doors. I know you've mentioned your preference for > foam seals over the Van's bulb type. I know others have used other bulb > type seals. > > What do you think the trade-offs are for the foam seal? Does it work > well relative to rain? > > What exactly did you use? > > Thanks > Bill "trying to figure out what to do next and hoping it doesn't involve > sanding fiberglass" Watson > > Dave Saylor wrote: > >> John, >> >> Thanks so much for your account of the episode. I was starting to get >> a little bored with my routine: I push on the back of each door just >> before take-off. Now I know I'll stick with that checklist item for good. >> >> What type of door seal do you have? I wrote a few days ago that I >> think the Van's bulb seal does a disservice to being able to >> effectively close the door. I have foam seals that IMO work much better. >> >> Another point is that if the pins are installed per the plans, the >> bevels get installed with the long edge outboard. Presumably, that >> ensures more engagement with the fuselage uprights since the long edge >> of the pin is outboard, contacting metal. But that arrangement also >> helps the pins miss the hole unless the door is pulled all the way in >> during latching. When I re-rigged my doors I turned the bevel around >> to face "angled edge out", so that the pins would be more likely to >> engage. The bevel then helps pull the door in, even if the door isn't >> quite closed. Since I also installed metal guide blocks at the same >> time, I was sure I was getting a good, solid, metal-on-metal pin >> engagement. >> >> You did a great job Flying The Plane. Even the other -10 that had the >> tail strike seemed to land well enough. We should take away from this >> that a lost door clearly doesn't have to result in an accident if we >> remember to fly the plane. >> >> ******Shameless plug warning****** >> >> Insurance pays (AirCrafters) well for door repairs, too, in case you >> don't want to do it yourself--I never do MY own surgery ;-) >> >> Best Regards, >> >> Dave Saylor >> AirCrafters LLC >> >> >> >> * >> >> >> * >> > > > ________________________________________________________________________________
Date: Oct 03, 2009
Hi I am not sure if my post below didn't come through due to the size of the attachment. I have shrunk the sketch so perhaps this will work now. Cheers Les _____ From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: October-03-09 12:12 PM Subject: RV10 Mark 1 Door Interlock Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell ________________________________________________________________________________
Date: Oct 03, 2009
This is similar to what Mike and I were discussing this morning. Except that the vertical piece would also be a beveled pin of the same material and the rear pin and vertical pin would be driven on a cam where the vertical pin would precede the rear pin slightly so that the vertical pin would pull in the rear portion of the door and the cam would also allow greater penetration of the rear vertical piece. failure of the vertical piece to insert would prevent closing the handle but closing it would ensure that both rear pins are inserted. People still do the same thing. Both inside and outside there is but one handle action to open/close the door. This said I will still close and check the doors. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 11:12 AM Subject: RV10-List: RV10 Mark 1 Door Interlock Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Oct 03, 2009
I'll second pretty much everything that Les said as I'm sure would Deems, Rick, etc. It's not a trivial task to switch to the edge seals but, IMHO, the end result is much better than the factory setup. I spent probably an additional 20 hours getting the edge sanded down and built back up in the right spots to get a good fit and I still have some of the extra pressure to overcome as Les describes on the bottom of the door. Without the seals my doors drop into place and lock with no effort. With the seals on, well, I need to work on that. :) Once I get my doors back from Abby I'll probably look closer at that again and try and reduce some of the pressure. One other thing I did was to slice the little barb off from the inside of the seal. This greatly improved the fit on the door frame. For anyone that thinks venturing from the plans method is straight forward, think again. When it's all said and done I probably have at least 130 hours into my doors from beginning to end. These types of mods probably contributed about 40 hours to it. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 2:09 PM Subject: RE: RV10-List: Door-I'm the guy - how about those seals? Jae I used part # 1120A313 - (3/16 grip with a 3/8" bulb). I used a Dremel with a small drum sander to even up the flanges for the seals. Some places the f/g was hugely thick and others almost perfect. I found that it was difficult to get an even line where I had to notch into the flange due to thickness. After I had fitted the seals, I covered the seal flange with packing tape, put in place and filled any gaps with superfill. The result was a clean edge where the notch meets the edge of the seal. I hope that is clear, if not I will see if I took any pix. Although fitting the doors with the seals in place was a lot of work but the end result is that I have a consistent seal around the doors. Now the doors open and close without a lot of effort. I can't image doing this, then fitting seals, and then adjusting again due to the seal changing the geometry. Here is the single most important think I did to get the doors to close easily. I found that the pressure of the seals on the bottom of the door made closing hard. There is little leverage at the bottom of the door to compress the seals. To fix, I pushed the bottom of the f/g door frame in board about 1/8". This reduces the amount of compression on the door seal at the bottom of the door made closing much, much easier. I didn't final drill the door opening holes (#19 & #12) until after I finished fitting the doors. This made adjusting the position of the door frame very simple. (It easier to fill & move small #30 hole than #19 & # 12 holes). In a couple of places I moved the door flange by building up the back side and then removing material from the face. None of this was hard, it was just time consuming. And I just love f/g dust. Cheers Les #40643 - living in f/g hell -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang Sent: October-03-09 12:11 PM Subject: Re: RV10-List: Door-I'm the guy - how about those seals? Les, what has your experience been so far with the edge seals? I guess I should order some of it to test myself. It seems like I can forsee a few fitting issues. The edge of my fiberglass door frames seem to vary from 1/8" up to 1/4". The lower parts of the door frame are thinner and the upper parts, esp. around the top forward corner and top aft corners have thicker edges. Did you have any edge fitting issues? Which Type 3 seals did you use again? Edge A B and C dimensions? Thanks! Jae 40533 Les Kearney wrote: > > Bill > > Many builders have used the McMaster Carr edge grip seals (see > http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I > could use some as "sacrificial seals" while I was doing the initial fit of > my doors. That way I could ensure that the doors didn't become more > difficult to close after the seals were installed. Apparently the door > geometry can change after seals are installed so it is best to fit the doors > with them. Whatever seals you plan on using, I recommend that be on the > doors when fitting. > > Using the above seals will require f/g work - Oh Joy! > > Cheers > > Les > #409643 - Living in f/g hell > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver > Watson > Sent: October-03-09 10:06 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Door-I'm the guy - how about those seals? > > > > Dave, I'm getting ready to re-search the list for seal information so I > can finish off my doors. I know you've mentioned your preference for > foam seals over the Van's bulb type. I know others have used other bulb > type seals. > > What do you think the trade-offs are for the foam seal? Does it work > well relative to rain? > > What exactly did you use? > > Thanks > Bill "trying to figure out what to do next and hoping it doesn't involve > sanding fiberglass" Watson > > Dave Saylor wrote: > >> John, >> >> Thanks so much for your account of the episode. I was starting to get >> a little bored with my routine: I push on the back of each door just >> before take-off. Now I know I'll stick with that checklist item for good. >> >> What type of door seal do you have? I wrote a few days ago that I >> think the Van's bulb seal does a disservice to being able to >> effectively close the door. I have foam seals that IMO work much better. >> >> Another point is that if the pins are installed per the plans, the >> bevels get installed with the long edge outboard. Presumably, that >> ensures more engagement with the fuselage uprights since the long edge >> of the pin is outboard, contacting metal. But that arrangement also >> helps the pins miss the hole unless the door is pulled all the way in >> during latching. When I re-rigged my doors I turned the bevel around >> to face "angled edge out", so that the pins would be more likely to >> engage. The bevel then helps pull the door in, even if the door isn't >> quite closed. Since I also installed metal guide blocks at the same >> time, I was sure I was getting a good, solid, metal-on-metal pin >> engagement. >> >> You did a great job Flying The Plane. Even the other -10 that had the >> tail strike seemed to land well enough. We should take away from this >> that a lost door clearly doesn't have to result in an accident if we >> remember to fly the plane. >> >> ******Shameless plug warning****** >> >> Insurance pays (AirCrafters) well for door repairs, too, in case you >> don't want to do it yourself--I never do MY own surgery ;-) >> >> Best Regards, >> >> Dave Saylor >> AirCrafters LLC >> >> >> >> * >> >> >> * >> > > > ________________________________________________________________________________
Subject: Re: Copperstate RV10 nest
Date: Oct 03, 2009
Don, No worries. I am borrowing from my employer, SWA and its umpteenth and last chili cookoffs that it has every year. (this year was thirty something). For Copperstate, next year will be the third and last. My only struggle will be that blessed year and beyond when I have to get both "RV's" there. Regardless of my participation, I hope it becomes an annual tradition that lasts as long as the show itself does. -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266321#266321 ________________________________________________________________________________
Subject: Re: RV10 Mark 1 Door Interlock
Date: Oct 03, 2009
I'm receiving my finish kit next week and will look over the door latches. I have flown in RV-10's and I've seen all of the discussions. I am building my plane in my father's machine shop. Maybe I will try something different. If anyone has good ideas for the latch before bonding the doors, I'm listening. Could you put the latch more in the middle of the door and machine a new part on the inside that could move a third pin through the bottom of the door? -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266330#266330 ________________________________________________________________________________
Date: Oct 03, 2009
David I thought about a cam but couldn't see how to make it work because of the interference with the long tubes in the door. I am interested in seeing what you have in mind; I am always looking to borrow better ideas. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: October-03-09 2:27 PM Subject: RE: RV10-List: RV10 Mark 1 Door Interlock This is similar to what Mike and I were discussing this morning. Except that the vertical piece would also be a beveled pin of the same material and the rear pin and vertical pin would be driven on a cam where the vertical pin would precede the rear pin slightly so that the vertical pin would pull in the rear portion of the door and the cam would also allow greater penetration of the rear vertical piece. failure of the vertical piece to insert would prevent closing the handle but closing it would ensure that both rear pins are inserted. People still do the same thing. Both inside and outside there is but one handle action to open/close the door. This said I will still close and check the doors. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 11:12 AM Subject: RV10-List: RV10 Mark 1 Door Interlock Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell ________________________________________________________________________________
Date: Oct 03, 2009
Here is what I used.....I think they work great....I am not that picky thou... http://www.rvtraining.com/html/atp/rv10_door_seals.html Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 1:09 PM Subject: RE: RV10-List: Door-I'm the guy - how about those seals? Jae I used part # 1120A313 - (3/16 grip with a 3/8" bulb). I used a Dremel with a small drum sander to even up the flanges for the seals. Some places the f/g was hugely thick and others almost perfect. I found that it was difficult to get an even line where I had to notch into the flange due to thickness. After I had fitted the seals, I covered the seal flange with packing tape, put in place and filled any gaps with superfill. The result was a clean edge where the notch meets the edge of the seal. I hope that is clear, if not I will see if I took any pix. Although fitting the doors with the seals in place was a lot of work but the end result is that I have a consistent seal around the doors. Now the doors open and close without a lot of effort. I can't image doing this, then fitting seals, and then adjusting again due to the seal changing the geometry. Here is the single most important think I did to get the doors to close easily. I found that the pressure of the seals on the bottom of the door made closing hard. There is little leverage at the bottom of the door to compress the seals. To fix, I pushed the bottom of the f/g door frame in board about 1/8". This reduces the amount of compression on the door seal at the bottom of the door made closing much, much easier. I didn't final drill the door opening holes (#19 & #12) until after I finished fitting the doors. This made adjusting the position of the door frame very simple. (It easier to fill & move small #30 hole than #19 & # 12 holes). In a couple of places I moved the door flange by building up the back side and then removing material from the face. None of this was hard, it was just time consuming. And I just love f/g dust. Cheers Les #40643 - living in f/g hell -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang Sent: October-03-09 12:11 PM Subject: Re: RV10-List: Door-I'm the guy - how about those seals? Les, what has your experience been so far with the edge seals? I guess I should order some of it to test myself. It seems like I can forsee a few fitting issues. The edge of my fiberglass door frames seem to vary from 1/8" up to 1/4". The lower parts of the door frame are thinner and the upper parts, esp. around the top forward corner and top aft corners have thicker edges. Did you have any edge fitting issues? Which Type 3 seals did you use again? Edge A B and C dimensions? Thanks! Jae 40533 Les Kearney wrote: > > Bill > > Many builders have used the McMaster Carr edge grip seals (see > http://www.mcmaster.com/#1120a732/=3wg8ba (type 3 seals). I bought lots so I > could use some as "sacrificial seals" while I was doing the initial fit of > my doors. That way I could ensure that the doors didn't become more > difficult to close after the seals were installed. Apparently the door > geometry can change after seals are installed so it is best to fit the doors > with them. Whatever seals you plan on using, I recommend that be on the > doors when fitting. > > Using the above seals will require f/g work - Oh Joy! > > Cheers > > Les > #409643 - Living in f/g hell > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver > Watson > Sent: October-03-09 10:06 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Door-I'm the guy - how about those seals? > > > > Dave, I'm getting ready to re-search the list for seal information so I > can finish off my doors. I know you've mentioned your preference for > foam seals over the Van's bulb type. I know others have used other bulb > type seals. > > What do you think the trade-offs are for the foam seal? Does it work > well relative to rain? > > What exactly did you use? > > Thanks > Bill "trying to figure out what to do next and hoping it doesn't involve > sanding fiberglass" Watson > > Dave Saylor wrote: > >> John, >> >> Thanks so much for your account of the episode. I was starting to get >> a little bored with my routine: I push on the back of each door just >> before take-off. Now I know I'll stick with that checklist item for good. >> >> What type of door seal do you have? I wrote a few days ago that I >> think the Van's bulb seal does a disservice to being able to >> effectively close the door. I have foam seals that IMO work much better. >> >> Another point is that if the pins are installed per the plans, the >> bevels get installed with the long edge outboard. Presumably, that >> ensures more engagement with the fuselage uprights since the long edge >> of the pin is outboard, contacting metal. But that arrangement also >> helps the pins miss the hole unless the door is pulled all the way in >> during latching. When I re-rigged my doors I turned the bevel around >> to face "angled edge out", so that the pins would be more likely to >> engage. The bevel then helps pull the door in, even if the door isn't >> quite closed. Since I also installed metal guide blocks at the same >> time, I was sure I was getting a good, solid, metal-on-metal pin >> engagement. >> >> You did a great job Flying The Plane. Even the other -10 that had the >> tail strike seemed to land well enough. We should take away from this >> that a lost door clearly doesn't have to result in an accident if we >> remember to fly the plane. >> >> ******Shameless plug warning****** >> >> Insurance pays (AirCrafters) well for door repairs, too, in case you >> don't want to do it yourself--I never do MY own surgery ;-) >> >> Best Regards, >> >> Dave Saylor >> AirCrafters LLC >> >> >> >> * >> >> >> * >> > > > ________________________________________________________________________________
Date: Oct 03, 2009
Someone else has already suggested this, but I've thought about it and like it: You can get 90% of the way to a better latch by simply removing the racks from the handle mechanism, and substituting longer ones (about an inch longer). They should be so long that the 'door open' position of the inside handle is now nearly full aft, or maybe even more. What this does is gives you much more pin engagement - over an inch, instead of 1/4", of solid pin thru the door frame. This may be enough to hold the door even if one pin "missed" and is outside the door. Thoughts? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266334#266334 ________________________________________________________________________________
Subject: Mounting engine
Date: Oct 03, 2009
Easy question: Is it posible without too much effort to mount the engine without using the taperred cylindrical bolt substitutes? Getting ready to rent an engine hoist and can see not being able o get the engine mounted unless I have these in my bag of tricks. Thanks John G. ________________________________________________________________________________
Date: Oct 03, 2009
I haven't discussed with the engineer yet but first glance suggests that because the low placement of the rear pin that a twin gear/cam would be required near the aft end; this would require locating the door penetration pin higher in the rear door frame. I do agree that whatever solution that is to be implemented, it must remain a single motion lever (3 pin, fore,aft, down) to open the door whether inside or out. Also its apparent that any change will necessitate a large 4" by 4"? access panel attached to the door by screws for installation and adjustment _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 3:58 PM Subject: RE: RV10-List: RV10 Mark 1 Door Interlock David I thought about a cam but couldn't see how to make it work because of the interference with the long tubes in the door. I am interested in seeing what you have in mind; I am always looking to borrow better ideas. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: October-03-09 2:27 PM Subject: RE: RV10-List: RV10 Mark 1 Door Interlock This is similar to what Mike and I were discussing this morning. Except that the vertical piece would also be a beveled pin of the same material and the rear pin and vertical pin would be driven on a cam where the vertical pin would precede the rear pin slightly so that the vertical pin would pull in the rear portion of the door and the cam would also allow greater penetration of the rear vertical piece. failure of the vertical piece to insert would prevent closing the handle but closing it would ensure that both rear pins are inserted. People still do the same thing. Both inside and outside there is but one handle action to open/close the door. This said I will still close and check the doors. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 11:12 AM Subject: RV10-List: RV10 Mark 1 Door Interlock Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Mounting engine
Date: Oct 03, 2009
Hey John, Our engine aligned very easily just using the final bolts. I use an engine leveler between the hoist and the engine to get the angle just right. I did find that typically three of the four went in with no problem, the the fourth took some jiggling. Eventually we found which three made the fourth easier. With the engine leveler set, and the pattern followed, we can put it on and take it off with ease. Later, - Lew ----- Original Message ----- From: John Gonzalez To: RV 10 group Sent: Saturday, October 03, 2009 7:46 PM Subject: RV10-List: Mounting engine Easy question: Is it posible without too much effort to mount the engine without using the taperred cylindrical bolt substitutes? Getting ready to rent an engine hoist and can see not being able o get the engine mounted unless I have these in my bag of tricks. Thanks John G. ________________________________________________________________________________
Date: Oct 03, 2009
Here's a link to something similar. The vertical pin would need latch inside the fiberglass door frame. The cam \ gears would need to be offset inward. http://www.express-builder.com/forum/messages/2/80.html?1138244699 Pics at the bottom of page. Bobby Hughes ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill Sent: Saturday, October 03, 2009 2:27 PM Subject: RE: RV10-List: RV10 Mark 1 Door Interlock This is similar to what Mike and I were discussing this morning. Except that the vertical piece would also be a beveled pin of the same material and the rear pin and vertical pin would be driven on a cam where the vertical pin would precede the rear pin slightly so that the vertical pin would pull in the rear portion of the door and the cam would also allow greater penetration of the rear vertical piece. failure of the vertical piece to insert would prevent closing the handle but closing it would ensure that both rear pins are inserted. People still do the same thing. Both inside and outside there is but one handle action to open/close the door. This said I will still close and check the doors. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Saturday, October 03, 2009 11:12 AM Subject: RV10-List: RV10 Mark 1 Door Interlock Hi I am been fretting over the -10 door opening events ever since I first heard about them. I don't think an unlatched door should be catastrophic nor do I think we should rely solely on memory (doing a check) to be our first and last line of defence. I have on a couple of occasions, left my Cherokee door unlatched on takeoff. It was at worst a minor inconvenience and I have since mastered the art of latching it in flight (safely). All that being said, I have been trolling the archives looking for various solutions. None seemed to fit my *must* requirements which are: * Any interlock should be operable from the outside of the aircraft. This is a huge safety issue - I don't want to be trapped in an a/c after an accident. * It should not operate if the doors are not aligned correctly for proper latching (this would prevent misaligned doors from being appearing to be closed when not) * It should not make door operation more difficult (i.e. stiffer / harder to latch / more steps) * It should be easily installed * It should be mechanically simple A very nice to have requirement is that it should operate is that it should automagically operate when the door is closed. Attached is a side view sketch of a design that came about after I saw how Steve Deniri integrated his billet handles into the -10 door. Basically it involves a 1/8" "knife blade" piece of AL (steel?) that drop into a notch in the door sill as the door is latched. There is a guide block embedded in the door that would cause the blade to swing down the door is latched or swing up as it is unlatched. For those who haven't seen Steve's system, he uses a saddle which is pop rivettted to the door tubes to cause a lever to be moved when the door tubes moved. My thought is that the if the receiving slot in the door sill is just a little oversized as compared to the knife blade, the should be little or no more extra effort required to latch / unlatch the door. I would also ensure that the blade could not be forced down into the receiving slot if the door was open too far for the door pins to engage the door locks. This just a matter of alignment and positioning. The receiving block would be attached to the inside of the door using threaded screws. I would think that if the receiving block was made of sandwiched 1/4" thick AL, fabrication wouldn't be too difficult. After noodling the sketch for a while, I think it would be best if this was installed in the aft 1/3 of the door, mirror image of what is shown. That way if the door was being pushed back, the knife blade would not be pulled out of the door sill notch. Anyway, I am just a dumb ^*%^ accountant and not an engineer. I would appreciate any comments before I try to fab a prototype of the RV10 Mark 1 Door Interlock. Cheers Les #40643 - Happily distracted from f/g hell ________________________________________________________________________________
Date: Oct 03, 2009
I don't know what they rent for, but these days they go for about $130 at Pep Boys, etc. On Sat, Oct 3, 2009 at 4:46 PM, John Gonzalez wrote: > Easy question: > Is it posible without too much effort to mount the engine without using the > taperred cylindrical bolt substitutes? > Getting ready to rent an engine hoist and can see not being able o get the > engine mounted unless I have these in my bag of tricks. > Thanks > John G. > > ________________________________________________________________________________
Date: Oct 03, 2009
Since Don is too busy I'll go in his place.. Well I was actually going anyway. We should be arriving at around 5pm on Friday the 23rd, try to figure out where to camp and be around until 13:30ish on Saturday. If anyone will be at the campground let me know so I can hook up with you on Friday. Look forward to meeting everyone there. Pascal -------------------------------------------------- From: "woxofswa" <woxof(at)aol.com> Sent: Saturday, October 03, 2009 2:18 PM Subject: RV10-List: Re: Copperstate RV10 nest > > Don, > > No worries. I am borrowing from my employer, SWA and its umpteenth and > last chili cookoffs that it has every year. (this year was thirty > something). > > For Copperstate, next year will be the third and last. > > My only struggle will be that blessed year and beyond when I have to get > both "RV's" there. > > Regardless of my participation, I hope it becomes an annual tradition that > lasts as long as the show itself does. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266321#266321 > > > ________________________________________________________________________________
Date: Oct 03, 2009
I have always thought a round geared crank style door lock that would allow for extending pins an unlimited length into the door frame and fuselage completely eliminating the concerns related to the door pins barely engaging. Not that dissimilar to a bank vault which has locking pins extending in all directions. My concept would require a cranking motion to both engage and disengage the door pins. I have a multi geared version of this concept in my mind but it seems like most things in aviation are best left as simple as possible. In this concept the rotating knob can be located in a number of different locations on the door. The handle can be as simple as an old VW window crank or as premium as a milled stainless steel disk with spring loaded self retracting crank handle. I do not know if this is an appropriate mechanism for door latching or if it has some negative implications in the event of an emergency extraction. For those that are still concerned about three pins holding the door in place I have a deluxe model in mind. J Robin ________________________________________________________________________________
Subject: Door-I'm the guy.
Date: Oct 04, 2009
John, I use my door for cracking open for cooling on hot days while taxing. You get plenty of air flow through just one door. I wedge my hand in behind the door handle to able to old it tight enough. It works fine that way. Wayne Edgerton N602WT Subject: Re: Door-I'm the guy. From: "johngoodman" <johngoodman(at)earthlink.net> > I never allow a passenger to close the door. It's a sad day when a pilot cannot allow a passenger to close his own door. I guess cracking the door open during long taxis on hot days is out. The door design is flawed and needs to be changed. John -------- #40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon. N711JG reserved ________________________________________________________________________________
Date: Oct 04, 2009
Photos? Thanks, Jay rebrunk42(at)gmail.com wrote: > I put a plastic door pull near the aft part of the door by the aft pin > to insure a firm and solid closure. > > Sent from my iPhone > > Robert E. Brunkenhoefer > Brunkenhoefer Law Firm, P.C. > 520 Lawrence St. > Corpus Christi, Texas 78401 > Phone: 361-888-8808 > Facsimile: 361-888-6753 > robert(at)brunklaw.com > > On Oct 2, 2009, at 7:10 PM, ricksked(at)embarqmail.com wrote > -- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266372#266372 ________________________________________________________________________________
Date: Oct 04, 2009
Along similar lines, how about a small bell crank attached to one of the rods to extend/retract a vertical pin? Just food for thought. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266377#266377 ________________________________________________________________________________
Date: Oct 04, 2009
A bell crank should provide an inward offset that would keep the vertical pin throw short. The vertical pin would mate into an aluminum guide like the ones some of us are using. The guide would be place inward of the lower fiberglass door frame and bolted to the aluminum. This should allow for easy retrofit and small alignment adjustments. A small cover \ access plate would be needed to cover the bell crank gears in the door shell and hide the vertical pin. Something like a large rudder cable fairing would work for the plate. Bobby -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tsts4 Sent: Sunday, October 04, 2009 7:18 AM Subject: RV10-List: Re: RV10 Mark 1 Door Interlock Along similar lines, how about a small bell crank attached to one of the rods to extend/retract a vertical pin? Just food for thought. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266377#266377 ________________________________________________________________________________
Date: Oct 04, 2009
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I used the final mounting bolts. Very easy. Just don't try it with the prop on it. I used the 2 ton harbor freight hoist for <130$ on sale plus the load leveler. Their smaller hoist would work too. You know you have the right setup when you get this kind of warning (see photo). I too would suggest buying one if feasible. The HF hoist folds up to take very little horizontal space. It's great for mounting/demounting the prop and avoiding another rental. I left the engine suspended (with safeties) for about 6 months at one point. That appeared to damage the jack and had to replace it for a few more $$$. So rentals can make sense. Bill "dreaming of evenly spaced cu's from horizon to horizon" Watson Kelly McMullen wrote: > > I don't know what they rent for, but these days they go for about $130 > at Pep Boys, etc. > > On Sat, Oct 3, 2009 at 4:46 PM, John Gonzalez wrote: > >> Easy question: >> Is it posible without too much effort to mount the engine without using the >> taperred cylindrical bolt substitutes? >> Getting ready to rent an engine hoist and can see not being able o get the >> engine mounted unless I have these in my bag of tricks. >> Thanks >> John G. >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 04, 2009
Robin, I knew you were going to pipe in with something cool. The Citation, being pressurized, has 12 pins that engage into the outer door structure. It has the bellcrank style with all of the pushrods coming from the center of the door. The pins are pointed at the ends and the holes in the outer structure are adjustable. If you made the pins slanted they could pull the door tight against the seal. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266402#266402 ________________________________________________________________________________
Subject: rudder pedal position
Date: Oct 04, 2009
I'm wondering which position to install my rudder pedals. I am 5'10". Anyone out there no the height limits for fore and aft positions? -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266408#266408 ________________________________________________________________________________
Date: Oct 04, 2009
From: "Masys, Daniel R" <dan.masys(at)Vanderbilt.Edu>
>Subject: RV10-List: Re: Door-I'm the guy. >From: "johngoodman" <johngoodman(at)earthlink.net> > >It's a sad day when a pilot cannot allow a passenger to close his own door. I guess >cracking the door open during long taxis on hot days is out. >The door design is flawed and needs to be changed. >John I always close the passenger's door on my RV-10, either from the inside or outside, but realized that it is just part of the flight safety routines developed over 39 years of flying in a variety of GA airplanes. The first airplanes I ever owned were a Cessna 172 and then a 182, and I didn't let passengers close those doors either (usually because they would slam them too hard, and then I wouldn't be sure the locking mechanism had gone over center unless I felt it myself). I don't know any Beech or Cirrus drivers who let their passengers close the doors without assistance either. Passengers, especially new ones, seem to actually like the care and attention the pilot pays to the door they are sitting next to. With respect to the -10 doors, two observations: 1. I added a Stanley screen door pull at the lower rear corner of each door (from the aviation aisle at Home Depot) and it works great to pull the rear part of the door in during latching. Have the standard magnetic proximity switches from Vans and two indicator lights on the panel, with the pins set so that if they are as little as 3/16 inch from full closed position the red lights come on. 2. The door seals do tend to deform the doors, so I always store the plane (even though it is hangared) with the doors latched. Over the course of the last couple of years flying the -10 I have noticed that temperature affects the stiffness and bend of the doors, so regardless of the type of seals there is no 'final' fitting that you do and then are done worrying about the doors. If you've closed them once, you've closed them once and they may not feel exactly the same the next time. Just my $0.02. YMMV. -Dan Masys RV-10 N104LD 260 hrs. RV-12 N124LD Empennage and tailcone done :) ________________________________________________________________________________
Subject: Re: rudder pedal position
Date: Oct 04, 2009
I am 5'10" and the forward position seems to work out fine for me. My seat cushion sits about 1" aft of being even with the vertical face of the footwell. Unless you are a very short pilot I would be hard pressed to see why you would use the aft position. Even then you could use a spacer of wood or aluminum to extend the pedals aft. -------- OSH '10 or Bust Q/B Kit - phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266413#266413 ________________________________________________________________________________
Date: Oct 04, 2009
You gonna let anyone under 5'6" or so be on the pedals? If not, I'd go forward and reap the cg loading and rear seat space benefits. But, if you may want anyone 5'6" or less to fly it, I'd seriously look at going with the aft location. I just know that 5'2-4" won't work with the forward position very well. Tim On Oct 4, 2009, at 11:20 AM, "Strasnuts" wrote: > > I'm wondering which position to install my rudder pedals. I am > 5'10". Anyone out there no the height limits for fore and aft > positions? > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266408#266408 > > ________________________________________________________________________________
Date: Oct 04, 2009
http://www.myrv10.com/N104CD/upgrades/20090503/index.html Yep, that's what I had to do for the little woman. Tim On Oct 4, 2009, at 11:39 AM, "AirMike" wrote: > > I am 5'10" and the forward position seems to work out fine for me. > My seat cushion sits about 1" aft of being even with the vertical > face of the footwell. Unless you are a very short pilot I would be > hard pressed to see why you would use the aft position. Even then > you could use a spacer of wood or aluminum to extend the pedals aft. > > -------- > OSH '10 or Bust > Q/B Kit - phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266413#266413 > > ________________________________________________________________________________
Date: Oct 04, 2009
Subject: Re: Door-I'm the guy - how about those seals?
Thanks Les for that description. I suspected there would be more work involved than just cutting and slipping on the seal, but there is definitely more work than even I had hoped. It's not entirely surprising, though, just from looking at my own door frame and realizing just how little uniformity there is. Jae > ________________________________________________________________________________
Subject: Door-I'm the guy - how about those seals?
Date: Oct 04, 2009
Jae It is a bit of work. For me, what was time consuming was figuring out what to do, doing it and then realizing I had to correct something as my assumptions were wrong. I can't believe doing as per plans would be any easier. Moving the door frame inboard was a key factor in making the doors easy to close. Using white grease on the door mechanism also removed a great deal of closing resistance when operating the mechanism. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jae Chang Sent: October-04-09 11:33 AM Subject: Re: RV10-List: Door-I'm the guy - how about those seals? Thanks Les for that description. I suspected there would be more work involved than just cutting and slipping on the seal, but there is definitely more work than even I had hoped. It's not entirely surprising, though, just from looking at my own door frame and realizing just how little uniformity there is. Jae > ________________________________________________________________________________
Date: Oct 04, 2009
Thanks, My little woman is 5'6" . If she can't fit I will have her wear her hooker boots. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266433#266433 ________________________________________________________________________________
Date: Oct 04, 2009
Did she get those so you could get your G900 dream panel this year? ;) Tim On Oct 4, 2009, at 1:39 PM, "Strasnuts" wrote: > > Thanks, > > My little woman is 5'6" . If she can't fit I will have her wear her > hooker boots. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266433#266433 > > ________________________________________________________________________________
Date: Oct 04, 2009
My woman is 5'2 but we call them 'Ho-Ho' shoes. They will work. Cowboy RV-10 #40950 Tailcone N516TK Sent from my iPhone On Oct 4, 2009, at 8:39 PM, "Strasnuts" wrote: > > Thanks, > > My little woman is 5'6" . If she can't fit I will have her wear her > hooker boots. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=266433#266433 > > ________________________________________________________________________________
Date: Oct 04, 2009
Thanks Sean, Not too many comments on the practicality (and simplicity) of this design. Does anyone see any glairing problems or issues with this concept? It seems (to me) like a simpler package than the standard vans unit or the aftermarket door handles. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Sunday, October 04, 2009 9:03 AM Subject: RV10-List: Re: RV10 Mark 1 Door Interlock Robin, I knew you were going to pipe in with something cool. The Citation, being pressurized, has 12 pins that engage into the outer door structure. It has the bellcrank style with all of the pushrods coming from the center of the door. The pins are pointed at the ends and the holes in the outer structure are adjustable. If you made the pins slanted they could pull the door tight against the seal. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266402#266402 Checked by AVG - www.avg.com 10/04/09 06:20:00 ________________________________________________________________________________
Date: Oct 04, 2009
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Bill, What do you think the trade-offs are for the foam seal? Does it work well > relative to rain? > > What exactly did you use? > > I can't recall leaving the plane out in heavy rain for very long, but we've flown through some pretty heavy downpours and done lots of washings. I can't remember seeing any water inside...that feels like I'm overstating, but I certainly don't have any leaks worth trying to fix. The downside to the foam seals is that they look a little tacky, especially on the bottom edge where I built them out using a couple layers. I think Les may have built out his fuselage edges to come closer to the door, which would improve that area by a ton. I was looking at the way the doors close yesterday. I could post a video if someone wants it. The doors just come right down to within about an inch of closing, and it just takes a very slight effort to pull in and latch. It's all because of the seal, which since it takes a set, doesn't interfere with the door closing. It's just not part of the equation. I have the McMaster P/N at work, along with some pictures. I'll send those out on Monday. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Subject: A new builder on the block
Date: Oct 04, 2009
Team Ten, My tail kit is on the way, I've discovered Matronics, life is good. Mike Strube MikeInIrving Irving, Texas mike.strube at gmail.com -------- Mike Strube Irving, Tx mike.strube at gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266475#266475 ________________________________________________________________________________
Date: Oct 04, 2009
Subject: Re: A new builder on the block
Sir Mike, Welcome aboard. It's a great airplane and the forum is excellent! What is your builder number? We are always wanting to know how many of these machines are in the construction pipe line. Jim Combs (N312F - 120 Hours) -------------------------------------------------------------------------------------------------------------------- Team Ten, My tail kit is on the way, I've discovered Matronics, life is good. Mike Strube MikeInIrving Irving, Texas mike.strube at gmail.com -------- Mike Strube Irving, Tx mike.strube at gmail.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266475#266475 - The RV10-List Email Forum - Features Navigator to browse Un/Subscription, Chat, FAQ, --> http://www.matronics.com/Navigator?RV10-List - MATRONICS WEB FORUMS - available via the Web Forums! http://forums.matronics.com - List Contribution Web Site - generous support! Admin. ________________________________________________________________________________
Date: Oct 04, 2009
Robin, I'll take two of the deluxe models!!!!!!!!!!--- My wife and I laughed our selves silly... thanks. Don and Kim McDonald --- On Sat, 10/3/09, Robin Marks wrote: From: Robin Marks <robin1(at)mrmoisture.com> Subject: RE: RV10-List: Re: RV10 Mark 1 Door Interlock Date: Saturday, October 3, 2009, 7:06 PM I have always thought a round geared crank style door lock that would allow for extending pins an unlimited length into the door- frame and fuselage completely eliminating the concerns related to the door pins barely engagi ng. Not that dissimilar to a bank vault which has locking pins extending in all directions. My concept would require a cranking motion to both engage and disengage the door pins. I have a multi geared version of this concept in my mind but it seems like most things in aviation are best left as simpl e as possible. In this concept the rotating knob can be located in a number of different l ocations on the door. The handle can be as simple as an old VW window crank or as premium as a milled stainless steel disk with spring loaded self ret racting crank handle. I do not know if this is an appropriate mechanism for door latching or if it has some negative implications in the event of an e mergency extraction. - - For those that are still concerned about three pins holding the door in pla ce I have a deluxe model in mind. J - Robin=0A=0A=0A ________________________________________________________________________________
Subject: skin pimples
Date: Oct 04, 2009
As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets. When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface. Is there a prescribed way to deal with said pimples? -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266508#266508 ________________________________________________________________________________
Subject: Re: skin pimples
Date: Oct 05, 2009
Tell the neighbor thanks but no thanks..... Pop them back in with a body hammer and fill them prior to paint.... ------Original Message------ From: woxofswa Sender: owner-rv10-list-server(at)matronics.com ReplyTo: Rv Sent: Oct 4, 2009 7:00 PM Subject: RV10-List: skin pimples As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets. When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface. Is there a prescribed way to deal with said pimples? -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266508#266508 Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Oct 04, 2009
I'm sure there are better methods but I got every little bump and wave out of my skins by pushing the other end of a sharpie against the aluminum. Use the edge of the back of the marker (not a fine point). It is just soft enough plastic to work with the aluminum. Don't hammer on the skin unless you back it up with a lead shot bag or similar. If you back up the skin with something hard you will thin the aluminum and oil-can it. I think most people just make sure it is an innee and not an outee and fill it in before painting with filler. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266513#266513 ________________________________________________________________________________
Subject: Same basement, different project...how time flies
Date: Oct 04, 2009
Was looking through some photographs and thought to myself=2C who knew I wo uld be building planes in my basement. Bill Watson=2C how do you like that first pic? Endless Cu's in a line=2C how about endless gliders on an assembly line. JOhn /9j/4R95RXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAOAAAA0gEyAAIAAAAUAAAA4AE8AAIAAAAQAAAA9AITAAMAAAABAAIAAIdpAAQA AAABAAABBAAAB6ogICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNgAyMDA5OjEwOjA0IDIwOjUwOjA5AE1hYyBPUyBYIDEwLjQuOQAAIYKaAAUAAAABAAAC loKdAAUAAAABAAACnogiAAMAAAABAAIAAIgnAAMAAAABADIAAJAAAAcAAAAEMDIyMJADAAIAAAAU AAACppAEAAIAAAAUAAACupEBAAcAAAAEAQIDAJECAAUAAAABAAACzpIEAAoAAAABAAAC1pIFAAUA AAABAAAC3pIHAAMAAAABAAUAAJIIAAMAAAABAAAAAJIJAAMAAAABABkAAJIKAAUAAAABAAAC5pJ8 AAcAAAQ2AAAC7pKGAAcAAAB9AAAHJKAAAAcAAAAEMDEwMKABAAMAAAABAAEAAKACAAQAAAABAAAK IKADAAQAAAABAAAGwKMAAAcAAAABAwAAAKMBAAcAAAABAQAAAKQBAAMAAAABAAAAAKQCAAMAAAAB AAAAAKQDAAMAAAABAAAAAKQEAAUAAAABAAAHoqQFAAMAAAABABwAAKQGAAMAAAABAAAAAKQIAAMA AAABAAAAAKQJAAMAAAABAAAAAKQKAAMAAAABAAAAAKQMAAMAAAABAAAAAAAAAAAAAAAKAAABLAAA ABwAAAAKMjAwNTowMzoxMSAwMToyNDoyOQAyMDA1OjAzOjExIDAxOjI0OjI5AAAAAAQAAAABAAAA AAAAAAoAAAAeAAAACgAAADoAAAAKTmlrb24AAgAAAElJKgAIAAAAGAABAAcABAAAAAACAAACAAMA AgAAAAAAAAADAAIABgAAAC4BAAAEAAIABwAAADQBAAAFAAIADQAAADwBAAAGAAIABwAAAEoBAAAH AAIABwAAAFIBAAAIAAIACAAAAFoBAAAKAAUAAQAAAGIBAAAPAAIABwAAAGoBAAAQAAcA7gEAAHIB AAARAAQAAQAAAMIDAACAAAIADgAAAGADAACCAAIADQAAAG4DAACFAAUAAQAAAHwDAACGAAUAAQAA AIQDAACIAAcABAAAAAAAAACPAAIAEAAAAIwDAACUAAgAAQAAAAAAAACVAAIABQAAAJwDAACbAAEA AgAAAAAAAACcAAIAFAAAAKIDAACdAAMAAQAAAAAAAACeAAcACgAAALYDAAAAAAAAQ09MT1IARklO RSAgAABBVVRPICAgICAgICAAAEFVVE8gIAAAQUYtQyAgAABOT1JNQUwgAFAjAADoAwAAQVVUTyAg AAAFAgAAAAAAAAAA/wEAABlhEjEAAG+1AAAibgAAciAAAORAAADkQAAAcmcAAIHRAGQAgwAyAB0A AEQBAAAHLwAAFmsAAAAAHhYAAAAAAAAGAAAAAAAAAEEUAABIAhfJAEAWawAAEtsAJAYwAAAAAAAA AAAAAAAAIiIiIiIiIiIiIiIiIiIiIhEREREBawOhA+0BhgICAc8B1gIAAQLwYAABA1IAAAAPAB4A EAAFAAUAAAAAAB4AEAAAAAAAAAAAAIMBRwHUAmADCgICAS8CAgJhAAAMEwz1AAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIiIkAAD5AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAEMAVKBkMF0gEQA+QAAACBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAEMAVKBkMF0gAAAAAAAAAACTkMCw3uDIcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAB3d3d3HSYYIB0hEB4OFzwAdQERAgACXQAAABgARgOTIi1dAGQLImQk FyMZKQHVAX8BqwJzAAAARgALAC8BzwHWZmZmZgAAAAgAAAAJAAAACkFVVE8gICAgICAgICAAT0ZG ICAgICAgICAgAAAAAAAAAAAAAGQAAABkAAAAICAgICAgICAgICAgICAgAE9GRiAAACAgICAgICAg ICAgICAgICAgICAAAAAAAAAAAAAAAAAABwADAQMAAQAAAAYAAAAaAQUAAQAAABwEAAAbAQUAAQAA ACQEAAAoAQMAAQAAAAIAAAABAgQAAQAAABM2AAACAgQAAQAAALtBAAATAgMAAQAAAAIAAAAAAAAA LAEAAAEAAAAsAQAAAQAAAAAAAAAAAAAAICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgAAAAAAAAAABkAAcBAwADAAAAAQAGAAABGgAFAAAA AQAACAQBGwAFAAAAAQAACAwBKAADAAAAAQACAAACAQAEAAAAAQAACBQCAgAEAAAAAQAAF10CEwAD AAAAAQABAAAAAAAAASwAAAABAAABLAAAAAEAAP/Y/+AAEEpGSUYAAQEBAEgASAAA//4ADEFwcGxl TWFyawr/2wCEAAcFBQYFBQcGBgYIBwcIChELCgkJChQPDwwRGBUZGRcVFxcaHSUgGhwjHBcXISwh IycoKioqGR8uMS0pMSUpKigBBwgICgkKEwsLEygbFxsoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKP/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkK CwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiEx QQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNU VVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6 wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwAB AgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpD REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ip qrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAGoAoAMB IgACEQEDEQH/2gAMAwEAAhEDEQA/ALcDZrQhbtWZbkkcVp26E9q19qLlL8AzjitW1ti/aq1jas5G FNdbpmlHaCwwPpUOsylEp2unFscVr22kHA3VJJqGn6e3lNIJJh/yyiG5vxx0/Gojqd5dcRItpGe5 +Z/8B+tJSlINC21jb26bpZFQDuTiqjwLOcQRsV/vtwP8as22nOzCR0aR/wDnpKc/ln+laSWeB8zf gtbRajq2SzIttDik3+ZIxYY6dKc/hxCD+9Ht8mP61pv/AKMfLhTGfmLMOO/H160+5l8lQcA5Pc44 7mq9tO+jIcTzu+s7mKaRCigKxGQ2c1lzeYvWmaj4oFzPLKCFV3LBc525PSsafWw2ec1SxE3uPkRo STkd6rPdkd6yZdVBqq+oZqvbsXKjZe9Pr+tRNfH1rF+1hj1xUyszjIFTKvYagXZLwmq0l3nuajMc h/hb8qb9nkbqD+VZPED5BklxnvVaWYke1TT2jjZ1GWA6U59LcDJ4/Gs3iUPkZiw+JjHjitG38cGE /wCqU/U1wEYM0fzF27GqV1GkeB5LAE8kDrXIpxbsbuDR7NafFVrUDbp8Tkdy5r0PQpPE3iuyhu5E +yWcyhlVSYlIwCDn7x+o4NfLVvbg5z5jp2GeBXZ6F8TfFnh3S4dK0zU2t7S3JEcRto327mJPLIT1 JPJpqUV0DlZ9OWXhiC3QLI49SkS7Rnv9f0rTZbHS4GnkaG2hT70sjBQvbljXy7qXxP8AGGoIi3Hi C5jCnj7PiA846mMDP41y93fSXM7T3FzJcTOxZ5JXLMx9STyabrrohqk3ufWN98QfCunuEn1u2ZiM /uMzD8SgIB9q5u++NOhwo32OyvLmQHADhY0I9c5J/SvnNXV9wI79lB4/pTNm85fOd2c4JBz71k8Q UqJ7XqPxqvpp0a10ixjSPlftJaVlb1BBXH5VyGreONX1zYuqXaXCx8p+5RSD9QAfwrz+SC1Cs3sc kjNVp7KKVRIWO7bj5lyQAMD9OKlV77j9idq2qhj1FMOoqf4vpzXFQ2cAGSSDnsKeQqMNs0ygLgnf 29Kf1gPYHYG/Qj7w/OkF3GesgH51y8U3kh9srHeuPmwSPpVYs46XD9epJ5o+sB7E9A01ba8uY4ft SKzdMq3br2r0G08PWyW4KO922PuQxHcfpuwK8J03U9Q0e9t9QsbmSO5gk3xOAG2kdyDwR/jXYf8A C7vHaj5tWX6/ZIR/7JQqkZfFcl02tj1qDwupUE6dqCEjvbg/+zUN4TnZwsWmXMinqZCI/wD2U/zr yOH44+NCXEuuYZRlV+yQYY9gfk6etZ2pfGbxjeIFm125jA5HkqkBP/fAFaxjTfczba3PXPEfhmPR tPW+vbL7NFHMnzyXSNnnoFABPfgemegNcY/jnSbS7W3bTYXR1yszBgM/3T8x5/8Ar15nf+O9Y1SW NdS1m+u4UbpPKZdmepUMcZ/LNLNdaZcJzrlscjlXtJCfocJj9TQ4q+i0Ju+4y2MMtoxUlWU8qelU nMPKtnnttJqvBqgjUbIWGTyfMIP8qHvxM3yx9DydxP4Vm4u+xv7RW3JLF40dwwOCeMrUizmIgBGP IPzDHHeqwe6YGW2t0ZFB3uUbA9eRShLtZ3N0iJ8uQuNpAz7jpTabJU0jRN0SXypPQduP8+9LJdPG A3lIRvxk81nuzR+W0mSDnO3GOvHTJPT+fWlee3klKuxwzcKjbXOc45I9uuKn2RbrLoaounYcGFcY 56Yz+FRxXjJM6tIhXIOVAP8AOs37TFbFYUu455XYfOpb5eDxkjjOen0qB5VMgyDI5bngkDnrnp70 lR6Cdfsjfa6RmXNww65A47e1RyXVrGitvkmGcjbzVSFXRvLcEMGKnI9yKS+VrOGCAHOY85x2LPWT pK9i/aslOowSFYwkpkzkAnj+dULnUIY5XUGRmB2spOMetJb4kuoz0JOB+VZUshmmdz1di351rClF sznWkkaqalAigeW3oPn4qaC9juRlIjtVtp3N1/L6isu2068vAzW1pNOF+8Yo2fH1wK07CxltkeG6 t5ImZlyHBU4JxnB5/wD1U5UoxRMa0pE5Vyc+UoB9QxqOSLjPy9OcRnj9a0zH5a7QrNgdd3+JqNo4 3G35kHcVKSBzkZT2rtkngZ4+Ufzpgs/lG5sD3Y5rSdm80oHZh2BXt+VJujfjzArA9WxiruTdmCxt juBZwQcc96PPtlH3t2PRaqyHM0h9XJ/WmYrflMeYuIu8kYIwfXFSxIEZ8YC5ySfXFV43wo6DI7mr ttevbAlVi2/7UCv/AOhA0mUKXeKL9xPs+9lFJGeBjGBilS5m+xqoYtPvZmLHsQMDP1FT2+sT3TmK VrNAz7VUafFubtwwXINWIVaKXYzJBtk3hpWRWI6YGCGXvxkjpx3qbpXuUlfYhsnmnfyo5JUlKMQw bGGCkjnr1x3pIdEupLtIDaNJehPNGH3M/JJxzyflb5RzwTWzFrE4Lx2+q3IkxkCKSWQjHPGRjpnP PTNWNmualtMtjqGoPF+9/wBPhCoAOOC5I7n9e2ay9q7l8hkR+FZneF3s4LM+Zt3ySlSrAHhkLFh0 /u9cevLntrXTpZYrm8eSUH5fKj/dsFPI3HBBwePkPbsc16fb+G7jVLKK5tpBaapMxYwaphlLkdA0 Toqr15K5x1A6Vy3ivwNfWUto93cJKWlVZFjsRbgIwJ3FwDk/KoAOeox7imm7S2Dltscx9vtFQRJH 5jtszM5J2H5dxXBAwTu6qcA47bjf1HQ7nVJbP+ypbbUC0QiCRTqjlkyxwshUnhs8D61lSW1yL+3S RItkW2MyRqAGUMFyc9Tnj3qRvFsmmzw2kFlp13Fbyt5gvNPilDkkDacruA4PRhwR0xTaTfuhdpaj p/D+qaPdxLfWFzahZAC00RVSSCRg4weORjqOaw4Egt9SjjnBaNRhgBnkA9vrivX9L+IN0umDUU0Q XqzeUhsLa4kWIFfkRURi+0dFCoF4YdcAilb3Wi+KpriW48FXEHluftU0UwWV58sWVmfZwM8/Pkkp 8v8AdNY3B2Zyc8kN+CsMiP5RjYcEqWByBwOPxxxnmuWtruXT2nhAwQR5nI4wcfTvXr9l4a8L6ZfO sNy83nIyrFdTrGg4JyCoViQM4y2PXNZ1p8NIHimnt7+31KKSZZYZRtblS2QWwwbORnoDjkdMEZWv zbCcdNNzg7fX42QrLCivj7698dB/P86W41O38hmikzKwwqgnOT/hW/qnhjxBHc3UUOiw7HuPPU26 L9njJ67VccjGP4Rg5xx154+DvEEsu06bcpgE7mU4wDtHPOenHtz0xV2g9SNS3FIzxmbzdoQcnKqW 7cDqfoM06/drEQmXbEZohKmcZZW6EflWHdabNp6+W24PI5Gx1KfdPOdwGP8A9ecUuoSzRtDGbeEx fZ1VQMsADlsgkkg5OeD6CjlT2ZpG3ULuyxD9sgIkTrIEP3Cenv2P5HtWfuFXraW5is3t7dZVErK0 3ksRuAzgNx1+bscdOCaqTPb5+SSQLgkIyg4bPTORnjHOB9K0T6Eyp9UEl1JIxG5OOFCrgEfzrQht XOwtL98c9eCPb61YPh7UrVZ5NU0q70+BhuMklmwC/MMcsOOSBnPfFV4HLKAhJAyPMb+nrRJW2IXm QXMH2eQIz7kIJwBjj/8AWBV/QJY1kVmgim8vKBZVDA8g5wR2yfyqpc5uzG2NuO4PBzTYJmtAGHyu jZ6dc8D+tRJXjYuLsz16xtml0uNLJ7QxlhJtjiMexsZI68jJyARjofSoru41S2Yy3DSxBuC6YUOc YAJXg8DpXn9t4ru7W7t2hjjQxjacDc3Qg4J4GR0yD+Nesm6Sayuc28V6k8JAj8z93ODnjPO3jGGX nPIwQDWKw8pRuae0Rw97rD6dIZlWCSRmDgNN5Tk8cgn7x6c5GMDrXWaH8R7ea0EmpOFhCs3nAEso HUFAM+vIHccd68qvvDxtLWS7LFY87kjJJO0tgDdhQfrjqK1NC8M+I9Qt3itrCaG0uFjLvOoiRlYc MC3LDHPy54PTkZqFGKXclzZ6nfeFNK1KH7RpxjtWkAZHgVWiYcYIXpjA/hI5Oea8z1P4c63baq0r afcXVvLKWVrZ/NjBYnGW2jZyD98DgZ6c13nhHQW8IqXvdXDq53SWcZzEWHGSzfMeMfd2njnOBW+n irRsgtqNqq4OC0qgce+cDp3xVxpON2JyueTQteaLFe6VLcWti4L7obi1JkK7M55YIcrjtg++edvW NTVXhE2pPfSXEayR7TuabIOAqgnqwKj3x25rvrjQ9E1u4TUbm3t7lpbcRxzhRMNmSy7QTt5J6jnB 61nalourrDHHp01ssCoV8pUKsoAwFX+EdsduMVEoRe8noUm1sjjry1k0jUTb20ymZVO2SIl8qcjI OOh9wKoxK8dylyx3yRSBiQAw3A5755/HI+tNurTXdFuPOv8Aw/LOBEJXuUUSEHb82XXIAB3DnnH5 0/R9X0QTtMyNukZUKGXy1Pr2OcevHU8jJrklTknpsbKUWtS3Yf2dG9yBJf2L3LbpJbK7aIbt3XaM Dpkc5+mTmryXnibQ5nm0XxrdpbSJxbXsgu0J4OSsg2A8DqMjpk1ZkGh3CI6xs8ca8NDyZSCchjkc 44yOhPoMVjNaqZSlvJKhAzhlJXOcBQR1PI7U+ecdL3FyxlrsO0/xB4pvtctYb3W7e5jlk3SZt4wz qMbgAFHOM9+AM9qs+LdVt9D3FdK028jm/wBYr2e04BBGcMQw69cYOPWk0pZBqMAZAIVDO1xnKZGV wCOrZyMDnrWEiaxr+lnV7jU0sPLfaJEZoxIBjG4AEHliPz4rem3JXkjN2T0MptY8LyW5FnpV5p0z gLK8F+67weqnKuNp649h71JZHSksrm3SNWndyVecDeATwCSATx+BOTx2xYde8QRRmWK+uGjQ4LmQ kZx7nmo9U1q81mKFr+5eaWL5QcgIeuSAABnoCR14rWUL6JkKVuh9QaiWFuJHSOaDP722kRWWRcMN vzdMk8nI6DOBmvBPH1utjqZ8uN4LSQsIoUREIIPzqxABBGQOhBwME17FpV9/aaLJtmkJQ+YJHLLn I9DgZG7tkjrgEBvEvFT3Otavd3K3889ss7iBbl2IC7yABnpgdR9fXn0K0I30WplqtGVLSCOa1iYA 7duOfbj+Yp9xap5W5RvK8bT3z06c8dahsLgx25ibaoibBP1PepXvULEZL8fwjP69K4He5XQty3sD 6VLCtr9lYbcqqgK5yOfXPHf8zW5o3jnTNH0xbS6N1NcQEKsaru3LjsT2HTn8OMAcZdXcuMLbEg9+ v8qpPdMTmRZEz1OMVrTbhsJu56Zb+M49TiElppltaTCQO8u0NJ8rZU5wOvvVzUYtdv45LifXp4rQ Dc0MEYRwB1AYc54715ppzlZAbMt5uOxAz9c54rsrLVLucSQXMwhwg2sh3Ek5yTuHrg9PzrOcqjaS ehpHl6oktNH0rUA7PeXksiY+e6wxOc8Zxz6/iPwZP/Z9g/kKEdiPukA5A74/D8x61napdC+uUs4J pfmDK0iSlQuOen8RwCMe/wCXN3Wm3Gm7vmJR24dOMjnIPp1qZUuaTd2l23/HQanyrY68eNZIFU2b yRswI82OPbn2yea0rT4w+JNFld47Owu4vLMYF7B5oXH8QK7cnA6nI+tef2V9LatuQjnrkZDfUdDW r/bAmAWWCIx8ZKDawOcnnpz6Y+mOtUqahsiXNy3PQrb442V0zLqOjywsxBX7J5bknvwQmB7Amt7+ 1PA/iaVkuG0+edFC/wCmQ+W4BzwpcA+vQ8V4s8FndSsSvX+IjBPuR+v9a2tE0tra/sGiVTB5mXYH BU9Bx1p+6K7PTp/hnoLlJNPlvNNk2lS9vNvXnodrdev94Zx1HWud1PwH4htwrwz22qLGwKgEwTgc ZAzle/Unt09eX1/XNRjkuJdNmurCONcmWGRo2mRi2xzyCQTntxx06Vp6f8SPEVvbwySXNvfmSFSf NiGEboc7NvP1zROnFO7Ku1oQT2eoaUzxahZ6hYoAd0zDfGpbGF3gFWBGAR2IAGPmBx9Z8QwxgraR KImCiSPGEbH3ffAOcDtnv1rt7P4y25k8rUtJkQKuDJbSByWH+ycYHX+I/jU0t/8ADrxX8s8ltbTS jzZPPU2zZ7hn4UnnoGOT61n7JXuJu9vI8Yle61OTMkq4UfdJ2gE+nbtUUcRWOTC7nwCGHbnH4V6d qfwk8y3hn0DU0mt5MOhnIIYc/MsiDB5A7evNcdLo+qeHmkbU7d7ZiQqsyq+c54DAkHPXGe1aN2Qt 2e132vnTMQLMPtl0wjhJI3Ek4AUZ5OW68AA5rx3xTJdjxBqcBRi0crscLwEySG9hgg/Q1YuZZJ7y eSWRpH+2ou5yScDOBn04qbx9DFa6rqS28aQqJn4jUKP9YR2rvqz9nK3UxiubU5Cab7LcsBtk7E9f mwM/kcjPenNcTsEkcKka9QCAT/WoIB+8T/roP6VoTRobdvkXjd2+tcbeupZqadp6X0SymdtrAEKo 2gY6/X61eGjQr92JW756n8zWd4d+ewfd822Y4z24B/nVHVbiZmljM0hTeRtLHHGMcVhZuVrmmiVx 0iw/2pBHp/L7xvMfQ88/pmuo8naiyIBgDqOfx/z61z3hcAQXEgA3jOG7jg966BWP2aTk/eP8qU24 tW6DirmJHJuuRKJPImTjOCduARjn9asXV09xNY/aowkYY7nXlXOOD7Y6n+Xasucn7ZLyfvKf/HRV 63AZirDKlHbB6ZCNg05OzuUldBe6IoHmwOpB5G0fKf8APrWRh4iMgpkcV0GhsTdyRkkpsJ2npnI5 xUOtogkfCgYXI4+tVCb2ZEoroZcd2UYbgD6mt2y1U2yLJCqStG6vhic9enHTP0rD1NFS9dVUKu1T gDA+6DSWTETxEEg715/GtrJmd7GtfnSbhDF5l28e0IGuSC0Yx/CRnpgADpWMrJDIWt3kRdoCsq/P 2OCM4PP16dBS3RLTy5JPzd6hH3Ae/NElYd3J6jHmlklLp952JPHrz3p8sgERLKsjrySOg5/Wnyki 1Jzzvxn2wKp5JtTk9/61C1Kehdsrm9tGF1a3E1tKwI3xOUOPQY7VeufEmq3Nq1reXTXETAAiRQW4 II+bGT071Vtf+PZfbj+dVpv9YaEyT//Z//4ADEFwcGxlTWFyawr/2wCEAAEBAQEBAQEBAQECAgEC AgMCAgICAgMDAwIDBAQEBAQEBAQEBQYFBAUGBQQEBQcFBgYGBwcHBAUHCAcHCAYHBwcBAgICAgIC AwICAwcFBAUHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH B//EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQz YnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm 5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGx wQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpz dHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAZACWAMBIQACEQEDEQH/2gAMAwEAAhEDEQA/AO9t yhKjPXnj+f61s2xJUhwc53e/r6e3Wvr1KyTOJW0SRuW5VQATyBycfn9PpW9biNnxgdO4HPT/AD0q +bqmVZ7m7CAcdsn6gflkVtQgK+CQTx/nj6U+brFk2uzYhkYYAJPt6+tbUDbwB/F3z/X/ACarn0si ku5rQv8AdAXPvkf5/wA+9aUBZ/mDYUH+ftQ5hyq5tQZyAV5zwOvXtW9bRsUPr3B/h9/8+tR7RLRG iR0NtCHBJjGDnLFc45rftbQJjDNj03EiolUW9yuW+x0NtbykhdoI7Z4P+f8APet23t5GwZYjg9/b NYurZ3Gkjo7W1SQ+2Nvvj2roLLS3Eg4yvfvUOurb6lWZ01rp4XgDk8cnmuig0xiVwD796wdZPUpR 6m3b6Rkfd5J5z3Fb1to/3MrggcfKelYzxCKUbo3oNCJ2DZ045FbUegscYTJ71g6zYWNJNDY4IWrC 6C2QfLoVTXcOVjW0N9hO39OlUp9HK5bYc966ITvomJo52801gGzHxmuPv7Py85HIP616mFlZ6mU9 NTkrxQMtg4HHWssFGcBenFfQ4dOVro4KrSextW+i3V0AUjJHsKuDwneMXzF2HSvSShBJSkcrtfUR /CVzksY+lUpvDdwoA8vjoTVLkk9JE2XQxJ/D83zAr+nWuS1TTHhVsj5h2P8AjVWcbIXZM84vvkMh PGfUfhXK3NwAep4znnoKdvIlb3Ziy3YDEouD3/z6VmveswwBg54OOPai9tGUl1uZst++ckYOc9v0 rMe+Zt524TjPbFQ5pBdFF7wk57n6HP8Ah/8AWqnNfH+JgSeTj/P1rP2l9hpbWKTXxUgK3HUf/q/E 1VbUGGG3cdCc1HPG1kCStcqvqLDLNj69zmqR1HaZMSADqf8APc9PWk5DUXe5TlvlV+ZDt7e1VbjU htHz/NgEkAcd6zdRbjtbcpvqOMHecHk5b0z+XFUG1aRMgS+wH/1u9Q5/MNE7lWTXJFDK5B4zwe/B /Gqz+IeOwzx7HH/1/wCdZuTY9Vdkf9upwrSYI4we/SoTrSHaDNw2ByP/AK9ZOVth2b1sMfWIgkgV +M9mP5f59apNqqvuKtk46Z5xxx71Lne6G4XuVJNRJUB34znAx/T8ay57jcThuTn8/wDP+eKmUrIp RsjJnuMJkcHPzZ/PtWdJefNhXweenQ49/wCVRKXQdtTGnvmVgu8bs4HQk+/+elUZ9Tdcc9+eR+lY ubfUdkzGudQZuFb5cDHGOeBn+VZct1K+4BsP1ccc+vt6c1Dnra5Sir2Mp7jbhg56Zwp/z/k1lTXS Yk3nOe+AMc8/41n7Tld2x2slczpbgYGGbOecnv1NZs8y7MbxnkZ9D7e/+e1Q5omybu9jMurxkL5b nr8x64/Tv/nFYMt2dyovIJ+7zx7j0NZ87tvuVy9Uzn7u4XAULz16f5PrVLz1/ufo3/xVZyrWd2r3 HbsfYNpKQoKkbh1HAHHv+fPTityCRmbPYe/XPWueNTuzoS0NyBwT6+wPH4f59a3racPGq5G3u2c4 GD/9etFU7DUb6G/ayjDZPv1/nWxbuCzAt7Ejn8s03PluFtTYtpBuBz90jI5/P/Pp7VuQyL1LAZxn P4d/rVKot2NJ23NmAkA7icZ4/wA/hW/bIMD+52A9en9aiVTS6HbozftockZ/r/j+ldNZ24+XAHtn jsOtZ+0KR09hasQOfn9cf5x2rq7Oy5XOdvrj1rGdSzNEjrLPTy2AwGO3y/Wuqs9NztAXBx19zXPK rZFJI6uy0hCOU6nuPb/69dLa6GucmMgk9Qa5pVehaj9xqv4cmkEctrJ+8QEhGHDfUiuq0XRNQkH+ mW/ynpzkmuV1ZqWj0NFFW1O9s/DhIB8o4ODnHNdbZ+GTtXMX6UnUfUXKvtHSW/hkEghcCty38Nfw hML34pOb2uDXY04/DAH8PT1FWP8AhG1Xqn1NCk+5LK8vh5QMFQPwrBvdGgjBMgHrW9KburEM891d bKAMDIo+teWarfWALIjB2JxhetfWZbQqVbOxyVqqiiKw8F6v4i2m00xhAePMkG0f4mvTfDPwS8NL fWNp4mv9klw3lxFMLlz0Az3r1sRjIYOEqeGXNUSforI4WpTd5bHs6fs5+HYFIs9bvY2xxllIH4Yr LuvgBqoYmw8X/L2WW2B/UGvEhxNKUr4mgn6OwOhrdM5q8+CXxEhJFrf6dOvX5w6H+Rrj734XfE21 zv8AC8E+Opt7hcH/AL6xXqYfO8rqaSlKm/NXX4GUqU1szjdR8J+L7QMLvwLfLwSfKj3/APoNeHeO tQ0zw/BI2uWFzat/02gdf6V72Fq0sSmsNWjN9k9fu3MnGolqj5i1Xx94buJXFrL5hz2U+orjbvxD azOPKTALY6Z+lRPExjpIqFOT1MWfUnblYwOPSsqa7mYA7iOc8dh1rlniovdm3sX1KPmyNIN7bUJG T1x+HfFULiVldxztBxkg4xWTrruCpWehmvPgMDwAD+IqpJcKMLu9Bz16/r1/SpVa7aHyW0sUpZMu vLbcY4P+B/zxWbLK7fNkjJ4/z/n9KftVs2Pl02KEl4qlvnyAcZA7/wD1/wDGs6S7Kgshww7H/P8A nml7VN2bE1exnvey7cHHTr68d/X61Ve9w24nhe4HSk5rUhxb3epRk1GLoXyc5PPH4YqhJqQAI3nc CQMnkHik526jUbWZTbVdyqcZIPr+P8/8iqTX6bl4AwOBu6df6YqZT0L5bblf7am7AfjOevJ9ce1V mu9ucscjnk4/z+NZOd+o1ro9iq96y8IehyCcc59qqS6nLHkMzAfhz/nj1rNyWoK7IBrbbcMmSq8Y zj05xUEutqu0OQMtn6/h/nrWbnJbu5elrspyanFhSXUMSR79R0P4VnNf/LuDZb8+eP8AP41m6nS4 +TZmZLeAggygnIJyfr+Of/r1mTXTF2AHXgknOc1nKbeiY+XS5my3bru67hzjBH1781lS3j/LlwB9 7J/+vWbl3Gl1tYzZbw8qcg9gB/L0rPnvl25ZuOOcdCT/AIVDnuKy3SMxr8Ehj0ALE9f5/Ws2a5TD KpxH27dTx9B1qedbhaRRuLgMOH6nP0A7c/jWJdSt8xXncv5f5x/OolNblpfzdDHnndRI2RnHU/Qj 8O1Zn2ub/noP++jWPM3sNxT6/l/wT7OtJI28vcMgc/X/ABrpIdpAwAWzzz36dBXNzmyWhv25GRtY D16n9elbkAA2984yR1H5fStFPS17l+pr27lcYPv/AJ/z3regbHBz06USnpcLdjXtyyqVIJGcDHGB /n+lbduC2cHHRfxqeez8gt3OjtIixTBIIAB/z+ddJaxuNuR168D2/H/9VRKpuOx1FoittXb09Qef 8/411um2ZfaZH4ycA84/pjis3WstS0mzvNPs0YL5YyB1OM8+ldpp2mjAXZnPf29+K55VuZastR6I 7bT9MyDleCAfSu1stI3YyvPXp1rCVRstQZ2WnaLuIG3j0rt9P0LOMoMdOe/+cVi5F2tojtrDQM4I jGcdK7ax0BeMoPpWbldjtbbc62y8PrkHy+/oK6m10MLtBj+hxSvcl+ZvQaNGAMoMfStJNMhTHy8D 2p3JfmT/AGaBAS3Sse9vbGzRmkkAA96uNyHY8j8U/Erw9pKuWvE3DPAYV4Nq/wATdZ8Rym08OWck jMcZCnH5/jX0eVZVOu/a1dIructWty+6tyHTfAXjDW2Fx4iuTBCeiRnLY9PQV7D4b+G/hzRoo5or LzJ+pkl+Zq96vi4UKfsMI9Nm+r/4ByqLqSvM9CNmYreRbQKkm0hMr8oPbI9Kf4btrWfxdZC/tg86 Qh0LZKI+DyueAR/WvHlN+xqyi/e5X+RpKNrJbHutGfevnRCHnPpUJHOBTREu4x/utjr7ivI/jBaQ ah8NfFkI0mK4lms3h2ugONwwT07dfwrswUnDE0pqVrSX5kWvKx+Nl38FI7ZZvLgAlIJBK5x/jWNL 8NEt4wJYl3gAk7eBx7+9ejPNJzqSbe56KopKxg3XgyOAnamR7Ad65a78N+TkeX0HXH61dPG82rZD gluczd6PsXA6diBz/n/GudubMDc3l4OO3OK6I4ly6kOFrswLqHZzt7+/P+c1iylY1AblT64/p/nm t412+pDjq7mLcShNxzwSMDP+c1jXFztUgnC+xzir9oRKKtYyZrrYTGF68fQ+9UJriQqQBzjp+Wa0 9pfYnl1sZMs/Zjgg+vTHes+a5LHJlOQOBn/Oap1NdQ5ehmyXSkkHgMOSOeOg71Se6TduDnB5/wAn 86XtN7MSjZ6IpteBuCRsz0z1/wA8/nVA3THPzfr1GP8AH+VS526g430RWe+XJk8whewxwc4/XioH 1DIOT1BHHb6D9aylV7spRVtdyo9/ICWLYdRjAPT6H9KqPqQJGCMZOOvFZOs7bjSu1Yz5b/eQoJ69 j+X+fpVWW/DuoySMZ+YfdIA461LncfLo2yjLeErvJ9z3z/Kqct3KWYq2Wxn6e/6//rqOdSaQ7WM+ XUXXI3fMR3I9cVnSaqSCfwAPUenXrwDUOVthWu0VjqLOBlvyP61Wmut5CqSMfTn/AD/k1lOsr2Ks 7XM6W7jCsWlGSN2Bx37Z61lSz7MMHBPTBHX/AB4qPaIfKkjNmuXlV2iIGPyH+fSqMk5ZcAE/jwf8 8/rRKdtUONivJOdgKqCRz0x6dMdqzLmRsAmQZxk8/wCcd/yrnc+7HYx7ncxG5sOMkA9x9M+361Uw 390f98//AF6fNB6tmFTmTsm/krn2na/IFIIwOpJ6jjpXSWm7grn0J6j/AD/jXJzLc7LI6C3kC7lA APXOMZHfNb1uxJxkgZ7jpVKdrjsbUJ2r8ykgAgZz+X863rdVJGPu+h4z+tS6th2Ny3IJH/PQdOB+ ldDahTtcLyRg8jp2/Gl7TSzYWOntvMx8gG32OCc/oa6exQsfmB+uOvNRKr2ZdkdhYQBxkZwT37f4 13umWTOF+T8/WsZVPIuK1uei6ZYcL8vB9v8APvXo2m6Uey/hisJT7miR6BpmkNhSI+R0GPyrv9N0 Z/kwvGPespTVzW1kd5p+gysAQmAT26A13+m6Ed3zIKlyvomLY7ex0ZV25Tp+ldbaaYihcqM0r9EQ /wATobeyCgfKOnpWokCpjJ96dyWwkmhhGWcD8a5HW/G+jaNE0tzdxqB6sBVxTk7IhuyPnDxd+0lo dm72ukubi56BYwTzXkcniT4pePmAt4Gs9Pf+OQ4OPYdf5V9XlmTxjBYrGaR6LuclWrrywOv0D4NW zyR3Ov3cl5cZ3EMSE/Kvc9I8N6fpcSRWlqkajjCqBXo4nHc0fY0laC6GMabvzSOlW3VQduM/SrUU e1FAA39wOa82Uro2tYwb3xLoNrqMGhXWrRw6pOWjSM5JVgCeeCB+NaVhpUl7f6Rs1KaKZJI28yJg C2xtxByMYbG0j0NaSU6FPnnT0aur9VqZO0r2ex7qOlNYdMH61851JewhGeO1RbfnyapEspu0jXEs TR/uABg56+tcX8QpWsvBmuywqflgb7oyR2/rXTRX72ml1aM/tI/PHWb63UyEn5h7da8t1a9tf3hz lq4E2pM9h+R5zqV7Fg49Dzn3rzzUNQj+bZ15z79cV2UpMze5w19dqA+Gyx6e3+ea4y+ulyWyNmOR muuNR7XIaOPvb5fmQv8ANx+nNcvd3jFDgHGck+5rpjUe1yGuhz1zdnft7Dk5/wDrf5/OsWW6AGC5 BxyMfSt1U7kyhcyZdQAIO/kemc459ay5tRU4dZMDOcZ6HtVqpLQlx1My6vIictMdvvn/AD2rAuNS jYHJJyOMY698ZrRVNUTboZUuqBiBvJAPyjnjGf8A6/Ss19U2ljtOe/qOtVztaB3uUX1ZupI3E+9U ZdROWVsHtnJAz/nFTKbYnG7uRi9bs2SeCD3zTDclznKjJGAOjHpx/KueVS7KSbbRBJdOSAshHqM8 HJ5/z+FU3uJZSAgAUA9T1/8Ar1nz7dikm0rkIlkyOQHBzheR6VC82T947i3IB5/Cs5VuVasajcz3 nL9T2JyW/XH/ANftVVpmYDBGRxweMD/JrN1tNR8id9CjLI7qDjIPGM4waznfahJwDtI68g1DrruH Jd6Ge90rjO3qcc5Iz/hVaSRxIdj8ZH3jnP0HpWTrX3Go20SKslzIwLMxwc9AB9elZV1OUDbRgck/ XPH+f/r1Kqa2YcphyXxDnBxk8cHr+f61OJSWwp6DuQeauU7O99CUrvQJJlU5AzGSP4x3/p04rKuJ lIKjqONpJIPOP8/SsfbJLQqzsZFzIpYLg7W5Bz0AxUOI/wDnqP0pSrtWSROqPte0cZC554x7jH4H 9K6K3kwTGACQep6HH5/5/CsYzurXNktNDprZoxncO5A7/wAjxW3BIp2qcZzngD/Pb/OaHMaNu2dX OQuCD2B/lXRWwUuFYE5OOD0/KhyW5VtDes03EEdOw9O9dPZJlh36nA/T+f8AOs3NspK51VjGGK4X k5HTrXb6fbnMe7O7AJ6c/XNS5MdtjuNPsgwU7eC30x+Pv/hXpOkWP3VKg9gTwf8APFZSehrGy0Z6 lounZ8v5ef516lpOk5KlV5xjiueT3ZqkrHqGkaLnB2fpXpGm6GAEYLk9DxWfM+o9ldnoOn6QF2Hy x164rsrHS0GMLz34pp2Whm3bU6a3sFRRkdq1EjjjAywz65q1oTYq3Wr2VlGXlmUKPcV4v4z+O/g/ wrFM15qsXmD+ENyfarpwnUkoQV2zOTUbs+S/En7T/iTxNO9h4I0iabJK+btwo98muZs/BfxC8bS/ afFutSR27HPkQt/Xp7V9jgMto4KKr4vWfRdvU5JzlP3YrQ9m8J/DDQtFnVYdOV3CjdM/zNn8f6V7 bY6db2yhVQcdOKvFYudaVr6CjBJG9EqqABjGc5FXlbI56VyF+hIJAOB1pVW4ugYYYmLHjCA5P0xV qyXNImzeiHxeGJrJpJ30mYM43S3DxF26Y5IyTxXpGi+GrBEtNRFzJI+A6cbF6enX9a48XjZSvyar a/T0SHCiowOjbg4PWmV5qOV72FxUbdxTEQuoOM9a5XxgM+FfEfHP2KYj/vg1vR/iw9V+ZHVM/GfW fGMPmShpTneRz6Z/+vXmupeLonLETAjpjdj1rmmuWpJebPWb6nCah4qgJOJwR1IBz7Vwd/4kjLEJ jAAA+n+cVrFrYh9jl7zxBHtbLAde/T/GuUu/EMGcStkk54PTrXTG0bEs5ybWY3QiPGCevXNY0moy Odu/AHOc9Bjv+dbqbF5GDd6mASWnXcvYdv0/r61h3GpxNkhyzYOcY56ev+eK1i76k6GDe6ou0FFV fqecn/Jrm59TJUszDP6n/PNac1kifeMe51JQ5OTjJB54/wA9KyZ9QKghWxnn5ce/6/41XPdku616 GfLfZVRnkAr2x+NZ8t2Nqhn3N36Dmm5IVtNCjJdLhlEvIPZjwaq/a8jI5bklu2D2P/6qTmrWHyjk uc4I4wNp7D/9VWluFYKu7pxyfb/P5VzTqrsXyoQz5wVP8uf89c1C1w/IDcZ745/zxXPKqi+UjkfB UfePX6mqDz/KVOd57Z68cn1FYOsnswsyv56Bgcks3OMcZz/nmqcrhkLZwTg8nkf/AF6l1ZdhtEBL b1UHAyTwf8/X+tZwZd3HzAk/N3/zz/nArKUm0h2Su0ROSzMQM+hznceePyFVXUu33G4wOowec496 l1Fa47dUVDHgs38YJ7dx2rGuo8KMjj6Dn161PtXcOU44yMZFKj5cgAbvu10cdsxQFUI4Bz68YwB3 /wDr0qlbYUY3ewySxdiWBI3Ln6enf3rNms5UB2sSpx97HPp0GP8AIrN1UU4NGNcWcyK6hfm6jJ4O Oo/XrWZ9nuv+fdf++/8A7Kj2qfUlxPt6yMmFbdznoOnvXQWqqCPmGM85HPTqf896tOxS7nSW5xhj yvT/AOt+dbluzuQRHgfhS5mO19TpLRmGc8gHrjiuhtQzsArFRnqPWi90XY62yjxsJ4zz0rrdPh3s B1xxz3qeawJHa2FsBtJA9Ov8q7vTbUKI+P3fQ445qHMpLU9H0mwLbR5Y25AHbFeraJpDP5OEII9e 1YyqWuapdD2vw/4fL7SV5yB9elevaJ4bHy/Jxj06VzyndmvKeoaVoDDaCh213thozKAdv4CknfVk Sf3HW2lgqDpWupht1y7AD3NaJ63Zl5nOa1440PQ4XmvL6NFUE8sBXyZ8Rv2xvBnh0y2emXRur7lR HB8xJ59P881vh6VXF1FTpRuROSjqz5g1T4ufGb4pSvHpFs2naW3AkkJ3kHvitjw38Dze3KX/AIqv pr27OGxKx2g9+K+uw1HD5ZD3feq9+3ocr5qnkj6Q0HwhpejxIltaRooHRVAGK9Bs7eCHGwcYrKrX nVbbZVkkbUDybyrEeXgBfp6e9a0coBAJyf8AZqFqGxr2dre3rBLW1Zm9FUk12tj4L1SbDXTrEnfJ 3H8h/jTqVqdBe/q+39bAlrqddZ+D9LtsNMGlfvuOB+Q/xrpILW3tl2W8CIvoqgV5VbEVKz956dh2 J6zNX1iw0Oxm1HUJdtsmMkDJYngADuSeAK529Ukrt7IpK54bquu3HiGQ32mSTwLJIVRN5VuigZwc Z4zj3p/wuXxVZzaXpfim/mkvFRzJ5kpcOeSOT17V7M4KnQlCSXMrfgnf8bGXLCWtj3qR4YsbkJJ6 BVJ/lWCt7dXOoJbtpxgtfLdt0sqb3IwOEXPHPUkHpxXgyxHLUjCCvd6mnsYSi29D5t8Q/GDxXo2v 6XpkGlwT2c93LBI5Rx5SojsGJzjkqB+NfPHx0/bSvfh14gk8A3Hg2G4S+0cXAuheNGYjL5iY2bCG wVzncPpXvSp0aNNVrPTX8bHNLDLmspH5M6r42eeSVmuhySQBnFcVdeLcnIm3Ag9zkmvLb5pOUuup 1eRy1z4rl4GefzP/ANYVzt14jfzHL3IVsDAHf19PQ1rG5Jztz4hgcY89mPcc89+grn7jxJGkQKgg nux6fTFbxV1diMe48VEDDXIBAxwDk/jWDc+JAVdxK/PbPb19v/1VrddBPQ52fxGqqRuO3Ax838/w /wA9ayZvEr7m3SjAPQHP+f8A9VXdX1ZNjKl8RlmOZN3uSe+f8/rWVJ4iUEMcc8jj+lNVF3CxTPiB CcAAnGc46/n0rPl1+J85xn3PSq9r5Csyk2tQ/OzN8ucnLdf8elU31aPGd+AeSQT096XtL3fULFY6 hlW2kbuDnOCRxj+tNS+beCp4IxgE5x/k1LldXQLuaUcjtz5eTjvj+vf/AOvWkk25VITaCM575B/z +Vck56s0SJCSoHmAAjnqfSmhmzxIBk54yO9cspNtorYgJJLF+Sx5+v8An+lRvjLAHB7n/P8A9b9a hy5dEOz2GSxLjmTA9BnnFU5YNwcb/k/oBUqr2DlIBZO7EsxA54JXv1x/nvSJpX3/AJ2KnnBJB/Os 5VlcpRuthjacqyJtU7SdwGSR/M/59KabPbgFCCCR79DWLqqyVy1B9CBrM52tyT02gnP4j9PwrK1P TmFq8gQ7TnGQf/r1Ptfe1DlW5yMmizRwx3QbG5gQepHQ9z+ldjZ6M3lpgnGPYc/4f/WrOtXjypph CFmy5/Y+AFAJyMjH5Z9Pf8TUT6PGOMD2wOD1x+FcjrNGyjpqipLokWxk2gEg847Y/wA/yrP/ALAg 9F/N6iWIn9nUfsov+l+p7vallDZznHfjtXU2wcYDAFCvc9/8k17Tmupy8tjorWNyqLtwM5zux/nv XT2sEpwSMDI5x69P8/Sk5dS4xdzqbO0LBQynp0x/L8+v0rq7K1IKqG5PGSM7uP5fjS51sNp32Ous rJQUK9QMjPb3/Wu007TxwMHJPHB/z2qHNdykrK7R3mlaarqgKZUdMD+Wc16TpOjl9h25H0/rWUp9 GXFdT1jRtBYlcJx3969s8O+HXYRgqSDzyOtc8pq1rmkV9x754e8OFdhaLnjtXsOlaHIir+7HpWW7 shydtDurPThEo3DAHtV+S6s7OMyTOFAGcmtLpGT1PH/HPx68DeCbaaXU9YhjK5yPMFfCfjn9uO/1 64k0r4aaNNfTsSqyqpCL77q6cHhauNnaGkVu+hlOSgvM8ck0P4z/ABOuftHjLxI9pZOSfs1u5zj0 Jr1rwh8F/DmgiOf7GJbn+KWUlmY+5PNfRRrUMHS9jhFr1l1f/AMGnJ80j6A0bSbOziTy4VGOO3Fd jblVKBOnBrOFSU5Xb1DyNaBiSozz6V1mlaNqmpNtsbKWRj3VCQPr6V2RhdOT0iurBq56ZpPwy1OR VbULhYU/ug7m/IcfrXomneB9DsArPE00v96Q8Z+g/rmuarjFG8MP9/8AkB1kUEMCCOCJUjHRVUAD 8qlrz223dsAopABrznx1aW+pal4H0i8m2W1xqEoUbsCWVLaeRVx/Fwrvj/YzW+Gsq6m+ib+ai2vx QNNppHnulWUdlewaU75lhuWRtp9Mf4V31lGo8XWLBsnynyM5xwa9PEtylOVt03+BjHeKXZnpVcpr Ykt9W0G4iUeXJLJDM3fBjdlx7ZWvJoxjKdpLo/ydvxNjxeHTra7TxCZIlLedIFJXlevIr8QP2/8A VItJ+L3h5yxEh0CBdqkYwJZuf8+levX97DTV9kvzREX77X9bHwBdeMV27OOBuOTjGB/niuYu/GSy EZuht745yOSOT/nmvHi0r3NPMwbvxjAu5VuCW56sB7VgXXjKORmLEDnPAH8q1i+xLva5ztz4xO0H OM993SsS78UPgor9AON3JrRSXe4WMiXxC8jOBKevBPbvj8sVly6/M7Fd/uecfpVczl0EZT62WUDz CG7A5zxxVSXV3kI2Hg5yR6c0J33BLoylJqjbmZGOMY56Yz9fQmqT6i2w+ZINpOQBg/r+PvVcy7is VjemVSC+VP8AtEflTXuCw+/nPy9TkdKOdaXYWbK8twy7WMjAtgkEnr+fH+TURvV3EKAAFxjr9c// AKuxo9r1Cz7iDUwgDhskZwMfj1/Cpk1hVCHnsemPfP61lKpduw0kdBa3rT7cLuHHGe9dLbidwuFA zkjHf3/pXHOr3ZcY67GiljO4XKnJHccE9e/86tLpU5BJ+7wef4v61zyxCW5qqbGnRp+SG+vNQf2T Om3Gd3sB7Dr+PXvzUe3i9WyvZvdEL6Rc9CjY3HIJPP8AhUf9mvuD+Ww9QGPOOe1TKrorMOVrZEx0 1Y9vz7Rx0zketSLpsoP3yW6ZC+v9K53W7opRuX4dKRgFW2Ynd7/5/wAM1P8A2NKWJ+ygIADyw47/ AONc8q3mWoeRaGlkbW+zZJHPHf6j/PNV7/TbE2s/nxsE2HcSpAQYGT/M/jWDqu6akWoI+ZtM8T29 14r8PaDqd0yeH7i5aGyvzDIIL+YNhIxJjblugOcMeB2z9ax+HItgChdvQjd/n0qcZVhGryR23/HX 7noFOm18aNGPwxbyfMzkkngBc57dqhl8LQKGPlM2M4yOvH+elcDrSl5G/I2rszZfDibgoiGT0yAd vT/OKT/hFpP7sf8A3wf8Kl4hxdmxWgtzkbLWgyAHG05weeOOgxXX2WtKzKyqm7bnA+99PzzX0/Po cKOtsdVWQgBewJPt/wDW/rXZ2OpROy70JBGRxwD9KTqWdmXFNep2VjdJJtGOR04P0/LrXb6e6/KS /PQ5/HPt/wDqqXU6FWZ3+mqHMZUgjHUg16RpFmW2DqAAMH+n+FZOpcaj7yueq6LpPmBCY+OBjH6/ 59q9f0DQt5i/demRWLqatGtuiPcPD/hoHZ+64OP4ema968OeGwChMfI9qz5nux/CtT2rSNIhhRCy joOtbd7rOj6ND5t3cRxoo5LMAKrmUI3bMZXb0PlH4s/tmfC74cxTxzeIIZL9eFhjbLMfoK/Prxf+ 1j8a/i7M9l8PdFksdJfOLu6Vl4PGQOtduDwcsU/bVny0l+PoZSlb3Y7nMeHPgHrPim4XWviP4iud RvC25o3kIiB5z8o619M6F4U8N+FLWO20+xiiVeAFQCvaniI8qo0I8sF0/wAzLka957nW2WoxeYFR Mn0x1rvLEPKFXJGeOh5rJRlJpJajeqPR/D3hLxBrTqmn6ZNKufvBDgA+p6CvbtD+CuqP5cmr30cC Y5jT52H1xx+tejGFPCRTxDvL+Vb/AD7fmQ1bVnrWkfDjwvpIU/Y/PmHO6Y5/8dGB+hruIoYYEWKC JUjHRUUAD8BXJWxFSu/edl0S2Qm7klFYCCigAooAQ9DiuM8b+GZvF2gS6dZai1jrkMqXmnXypuNn dRHdG5XI3oeUdMjfG7pkBjShWlRrwmo3Xb9H67DVup+dWqaJ+3xB8QdUudG8O6RDFO4Ek9tLbPp0 uMfvEE0gmTOScEZ68dK+8vhN4f8AiNo+hGb4q63pt94rkbk6XavFBbp/dDOd0hPUthR0AHGT9Xmt XJFgIfVKrqYiajsmlCKWqk2leXS0Vbd32vnGj7PWUr9rfqeqPIE+9X5uftnfG747fBKSz1Xw/wCA ZNf+Hf22O/W906ORrrTwImSS3nRM5TcTIkuBw4Q8plvmsBiMKsdGliZcqd0m9Fe2l/JmnJKUXybn 58w/8FlfBGiH+ydd+CerJqMsgWUW90qkk9WKyqmODnAJr8xv2ov2m5fj38T9S8a6fpUljoXkx2lj ZuwaWGFFyN5BILFmYnHrjnv6WOr0owlRpz5pO12tl/VjGlCpdzlt+J8vTeKpcsp3HjGd3U8/p1/w rNuPEjMHEa5AH8RAwOf8/jXk3tobu+iMqXX3JBGAOFzg8kdelZUuuTNuDy9eScY9T3/wpptaitYz ptZJZWEhxuABU/eH+celVm1f5RtbPuM44/HNVz63G0isdVzglmx25A+p/wA+tU5tZRS2MHOMDqf5 ketP2nVC5diq+qygAq2Dzknv0/8A1flUR1SQg5UH15POPX/Papc2+onvqQHUkKknGckZ3jgZ/wA+ tVW1NOMkdwRz/LijnApjUlX5Q3A46Z7/AOfX/Cq2ruMlGbAGfm4/lRzisRDVJMKuQWHJ+Y9+5/z3 pDdyFQuAo5BAHIH4cUnN7DUejFF1KG37zkj+Ijk5Na9iJJG+Zzx7cE/lWcp6XY476HoWi28k5TB9 8HHr1/SvVtM0sBFVnTB7bhzx7f8A6q86vXs7bnVCHXodbb6PC5JFwFX0OT/Tv9a1IvD24MyNIT0H y/1//XXBLEOz0N+U1rfwvKw/d2cpIyOgwTz/AD/pV2Hwze+YG/s4FsZy55OP8/yrF11u5FcmhOPC GoyBmeyhUg+vb2/Kpv8AhDLgEeasI642oCfXvWTxEV9psapu12MXwlCCQzuVz2jABx+Gf0qz/wAI zYwj5rclTxhv/rYqHXl3t+JXJFGfcaVawZ8qyQ/L1BOf1P4Vnvb3TACHTeMEKSmepNRzN/EwcbJ2 RX8rUEyr26AHnlR/XpXEeOvD+seIfCniHRLeXbJd2klsGQLwGBU8cEjB/LNEakYy5t9Qts2eAa34 P12bwd8LtA8ZT+QjTWcJjtY/OxNbzwIpMhZWi8xdxDDeysACuDur6ttfNgWNY4Y8cZ4LFf0rfH4d UfYqN7ON/N3evpsZUZud1fZmpFdazJuEMK56/LFjuP8AP40sul+J7oHaWUk85ArzbQi25bnT7zVz IufBviGeQ7rxwCM4z/n8/wD61U/+EG17/n7k/wC+j/hUyqUo6OJLhd3bPj2x8UxLgefjg9Xzg9T/ ACrrLLxYi7SJwG7Zf3zmvrrK11uefF6WZ11j40h/5+QccZ3Ac12um+OIx5ZFxxx1bt2zWbi79hrQ 7zS/HcTGPFzlTx14Hbrx/nNenaZ47t9se+4Ut0xkVlKDesUWn2PUNH8facCN90nHHPevaPDnjvRH ZAbtd3AOSBWEtNWaRlZnvnhrxloL7CbuLnH8Q4r6G8M+KvDpMY+2xc++K5pS5WaXPdNG8Y+E4Y1a XUIAPdxit/UPj18OvC1rJcX/AIitI1QbjmZQMCodZbLcUlofGvxR/wCCm/grR5pND+HtvLrOuHKp HZrvXPQZYcAe9fI+ufFb9pf42ubjXvEQ8P8Ahp2Aa3tm3z7CcDJzgDnn8a9TCYHbEY3bpHv6nPKd /dh956L4H+BXgPRrldR1KVtQ1hjlrm8k812Pfk8D6CvpvT7fQ9Mt0jtIYwFI+6AO9d068qrUVols uwlGx0FvdN88US8s52+9eheGfhj4s8XzI2n6LcTRFhlxGVjX6u3A/OvQweEqVYufwwW8nsv+D2S1 Jcb3b0Ppjwn+zJcxCGXXb+G3GBmOFfMf6E8KPqCa9/0D4TeCdACNFpYuJx/y0ujvP/fPC/pXVLEU 6C5MItes3v8A9ur7K89/Qyc7aRPR44o4UWKGNUjUYVVAAA9gKfXE227szCikAUUAFFABRQAVFPPB bRST3EyRwINzO7BVUDuSeAKTaSu3oCTeiPlbx/8At0fsffDKxvb7xZ+0Z4VH2eXyZ7bTNUj1S7if oQ1rY+dOMd/k4718RfEb/guB+xp4NmubXwtF4m8TSLGWiuNO0uK1tnfsrG+lhnUZwCRA3XvXn1sz w9LSD5n5bff/AJXOmGFqPWfurz3+7c/OX4r/APBwJ8RtYsWsfhT8EtC0S4LFTc6zqVxqxdCcAokS WgRgMHkyD+dfDOl/8Fe/2oZvE9zqvj7xa+r6HLlTpsIis4oFY4OzylycDoH3HIHI5z81i1Ux9SU6 sraaJbf8F/1Y7KUadJqKV/N/oj5M+IPxV/4WN4vuddtr6WaCa8uLwCTzD5PmvkId3cKAOBgdBnqa MviUH59yljxjv0/Wvo8vvDDpPQ5a6vO+xkT69EyMVU4xnP446ccVnya3bHG7AzznA/ya7udGOy3K zatak7WYbeRyT/nHHeqs9/aNgoV644Ofy9KrmsKz6FSW/tiqkE4P1598f59KrveWjBiQ5PP8fb60 uZXFZqxXe5tm3Ehg3KqQ2Pr1HPGen9Kp/aowzr5hx1zuz+XsKOZILEazKwKiQ4UkY44PT6/5NVhJ GxUea/PYjp/hS509AtcgkDZCtNkj/P58UzIBJMg5J6tjH+eee9HOnqO3QazHyzlhkjGABkH/ADim SGRco0pw2Oq9Dz6VDqbajsPEhLYJJ6dOdw6/0qcMQ3Q+Zzn3Hrn/AD2qfaeY+TtsX4I5G2jB2d8D OP8AJHSuu0u1aSREZDwd2Nv07dv/ANdZTqtaFRhdo918JaFbTvD5sRzz94cdvTj8/evpbw/4Js5o Y2W2QqDg5XIP44968HF4monvodtOnFo9OsfAsClDshVs9fKGf1FdTbfD6ST7twCM4X7o/T8O1ea8 Q3rI6ORGvB8L5pDuEx246Bv04FaUXwyhhOPOZl7jDH9T+PFQ6zT0RXJZFiPwFgfu7V2xwSIjTj8P r0MrLpZI9SpIA69h1o55W1YcrtsPX4fayzME0JWG4YDA8j/69B+GviSTLL4Yj3dNwxgH1PH0oT1+ ILMkHwj8eSAiHRIzk7gF7/pTD8BviFe43eHgR2ADMTxznofWmlD+YnlewkX7K/jO6l3z6MyjPTZj p361tR/skeJWjUf2Rh8jJG3PHPHX9ap1lFqz2/Elw0tfc+APG3wX+L/gXVdK8BR+ErmX4gza0V8N 28ojaG8D+b82SwVlKqNxJyuC3VcH9UNM/Y5uEtLc6o9vHOEXzcSYG7Az9Oa9TOq1CVTDTpTu5Rb0 2tze7+v3HNhY8kpxk7al6X9l7wLpQMms+MLG2TABMt5Cm3/vo8c5rKn8Dfs2aCSmrfGLw/HMpwV/ tS2LZA54BJ46/jXkQhWq6Qpt+ibOl1IdzNl1f9kbTE85vHkd2o5H2S0uLoEeg8mNs5yKq/8ACefs if8AQUuv/Cd1T/5HrojluZTV1QdvO36szeKpxbVz+UeDxoBgPdEY6Hd17/0P5VpDx0Qvy3BIz03Y 9e/b9K+t5Y22PNi5djTi+IWBvEpO0cliO369h+X1rTt/ifcQFvLmAycAEn8f8+9Cj0LW2ppW3xe1 GA5W7IOCAfb0x35/rWzF8a9aiYiO8IIzyW57/wCH86PZ3Jv2NiP48axDgrfMSSRgEjbx69PxxW1a /tG+KLYKVvnUgZBLEH249sUvq8Ow+e2tzp7X9qvxfagj+23XHzDEnI/HPt6U5/21fiHH5YstccMu MHcwB6joT6/qPwqHhKV/eD2kilP+2N8YboFY/Fc6pjOC7Y+o5ya2fh/8UfGnxK1y+03xJ4iu7q3E YkU/aSNh3AEbc5IIJ57YHrW1DDUKUuZQ18wlJvRn6HfCnSLHSYIzZWyKcgkhO+B36n15zzX1/oVp fX6R2sQkIc8AZPPXgdatQqV6yjTi5N9DSKVkkfX3w1+AHxX8aiCXR/DN01ielxMPKhIH+2+Afzzi vuXwR+xfdQRwy+MvFCoMhmt7JS5PsXbAB+gYV60MFhsB72N9+p/z7XT/ABy6f4Vr3sOco099X2Pq jwv8Efhr4TEbWHhyOa6X/ltefvmPvhvlH4KK9VREjVUjQKgGAAMACsa+Jq4hrndorZLRL0X67vqz llNyeo+iuckKKACigAooAz9V1fStC0+71fW9Tt7PSrdDLPc3UyRRQoOSzu5CqB6k18jePP8AgoT+ xZ8OYLa48QftGeHLiOUlV/sO4k1ogjruGmpOY/8AgWKxq4ijRV6krfn9xpClUqaxjp36fefD3xH/ AOC5v7LXheLXLfwJ4Q8TeItVt+LKRobWwsNQb2meV7iNfdrbPtXwl8Q/+C//AMUruZP+FbfBrw3p Fr5ZWRdZu7zVJC/qkkTWiqB6GNq8utmr1VCPzf8AkdUMLCL/AHsr+S/zf+XzPgn4j/8ABX39tPxz b3+mXHxru9P0y6beIdDs7PTntvRY7m1iS5UD3lJPqa+FfHv7RnxN+JOoQ6t8QfiDrOu6mihI7rWN Sub2ZF4woed2bH4+9eZUq1q0r1JN/wBdtjojaOlOKivx+/f8TyC88XXszSK05ZCO7Z9+uc89KxJN SvLhlBSQqerenOMevenClKeqQna15MqTDUlQyNEVAHzZfn8v89ar2CGZlEspJX+HPHpjnr1rpp4a SlHnZHPpY7mHVreziSFCVjYYyCAQSM9fx/Wg67G/HmggZxgg7vp6dK9WLUUkjlcZXsQ/29IQAsww CSPcZ79+1MbXZHEWT75A6HjPfBqnLsHIhh1mUgHehbv049f6fkaautMVBMw8vcPmHY8k/wCeaFUX cvkXUcdVkPBmA49SfT06/X3qM6wxIWSbHJz8hGPepdTsJRjsVF1fbtLyliORgdgfSo01FW+8ctgY yMc9ulS521L5ewo1J1HyS4BGCckEjPf27/UUxL0vnYMgjJJbtj/P61Lq66bDUb9B32qQKuT+7xzz jb6f4VZjuJJPlCZBOWO4fh9B/jUuq11C1/dJ1nlLhhw+MHn8uf0/CrcMdy2Dt55IYdD0469/6Vk6 7XUXKum5rw6ddtuKpk5Gc9j9Ov8An6Vv2mg38ocLEcsAFyev+c+/asnW6oFA7TS/BerXXlj7Nk4y Plwa9z8GfCLW9Umi3afKOxIQ/wBetY1K6UWaxgr2ufefwt/Zknv/ACWubaZQfQkV9s+Gv2TERF22 jtF23uRz+A//AF14VevKU7WVjtgoxSbPXtO/ZX2gAaXbD3csTx9RXUW37N8WnJulewhTHPmNxj8x XPrLSUhupCPUztU8JfC7w0JG8UfE/wAJ6eq8Mb3UrWHb353yDFcrH4n/AGWS3lxfHvwhcSjgpp2p Wtw+fZYWc5/Ct6eCr1F+6pzl8n/kZvEQSKUnxN/Zf0xzCfF2o3UgPWx8L6zOv/fUVsV/WmP8bv2f 4gDp+geJb1skDZoMtuTzjGLrysfWu2nk+Nnr7K3q0v1uYvFwXUyR+0b8NoJStl8DfFTICAJZ00iN MevF2zenbI54pJ/2mLSL/kDfAt3b/p81aOE/+Q4pP511xyHE/bqRX3v9EZSxkehjv+1D43bd9l+D Oj24ByDJrE02OvVRbp/P1rAuf2k/jZIj/YvD/hq16Y32N1MQM8j/AF65+v8AOuqOQ0v+XlZv0SX5 3MZYuT2Rzl38av2hNRiYjxdYWYKkhrHRoF2n/tqZK5DUPFnx31SFhcfGTWAD/wA+8Gnw9sHBjt1I rrhlGXQ3g5erf5Kxn7eoz4j8c3HxCvNf8PS+KPHWr6lfx+IbW2iu7rUZRcWsTzRIwikUq0QwzMfL 29zxk1634sm8A6BAJfGviySUkH5NR1O4uXk4/uyOzMenbtV4eFCkoxVJaJpabJSel36kVJSU3Z7n yP44/aD+CnhG11G48PeA0v7iBGIJgji8wgE4BYbsfh3r5k+BX/BR3wP8ar3XtL0rwxYaZf6e6RyW 10z/AMWcH5E5GVb346V0urGUHLn2aWnmZTlKMU3qfYa/Huz8mKS3/sd2Lcxq86Y/NMfkaf8A8NAH /nw0j/wJn/8Aia3Spraf4GTqRW6/I/nJj152I4AO3jgnjnnPtwf/ANVWV1+RTjaem3GO2M9+2Oa4 HLoj0oxs7MkHiBiVyfn6+u04H5de/pUyeIXUcjJ44Y9M4547f4U+dfIOXTQVfEcpwq5A55B69P8A PtzUw8SSfw5wABvzndnv6VoqlnqhezT39C3F4nJCoD8oHAAGRj6/lxUqeJp5Fxllz23euB/U0Oeh KhsSpr6A/vJcnHU85x9Pf+lXY9fVQ3lsgJBJB46Y7cf5AoVRX12Got6Mv22sFjueUeZnPOOTxzj8 f0r7g/Yc8AeMvi98V9a8P+DNM+1ahb+H7rUrsbkXybWKS3V5ctgHDSIMDcTuGB1rpw69pU5L9H+Q nBxZ/XH+zT/wS+vF0nS9e+L/AI3RVkRJlsNFAk8yNlBGbhlCA56hUcehHBr9VvAX7O/wd+G0Nunh nwRaC6jAAurpPtExI/i3SZ2n/dCj2rto432NJ08HHkb3l9p+Sf2V6avq+gVKvK3Cn9/9f8Oe1AAA ADAFLXKcwUUAFFABWXrWuaL4c0y81vxDrFrYaNboZLi7vbiOCGBB1Z5HIVQPUkUm1FXbsNJt2SPj X4hf8FI/2Gfhj9l/4ST9pXw5OZt2waFNLreCOoc6YlwIj2+fbXwV8R/+C+f7LPhuPWLX4efD/wAV eIdXt5DHbSXKWem2F7g43LMZZp0B7brYHnkCuKpmFCF1D3n5bfedUMHUes/dX4/d/nY+F/iH/wAH CHxg1G8B+GPwf8LaRpRiZXj1ea91W4D9nSaKS0jA5HytC3418B/EX/grf+2x8QrSbTdT+P2qWViZ TKg0OO10iSPn7gnsIoZmUDgBnbpk5PNeXWx2Jq6L3V5f57nTChSha0bvz/y/4c+IPG3x4+IHjzWZ /EHjTxpqmseIWAD3uqX8t3cSccAyyszHqep7muAl8U6jc9ZGLEdyx7jj+f8AOuVQnJ82po73XMzP l1bUX+/NlscZPUf/AFqqPOWx59xwMErjO79a2jh39oSte6KpntlBSVnZcd2A74/+v0qsNQ02NsiL LjH3znOPbp0+lbxpU4LRCfNazZB/bUaKdihQCB8o6+n0qGTXXUlixGD1zgZ/z0rbnS6EOOjKz6yG GwkDB6k8Dp7/AMqoDVIUdi0wB7sF6nJ/oOnam6i6k8utiI61aYz9pKtkcAdR64/z0oXW7UMymQEA dcnBq/a9bktNuyQh12IK3lydyckkKozx9ab/AG3GQf3y57c8jn2GPaodVbXKUdLDP7dAUEvlSCOv tx+v+e1INdRd0hn5GOh6DHP8v1qHVim9RcjWiRGmtpu4uDktgBj/AIVF/bsKoqtMAckEA/449u56 ml7XXQOTe49vEcJ/5bLgkY+7xjt0pf8AhJIQzKGJc4ycDjv26jk0pVAS0Q1fFEbnepJbrnBIP/6u v5U7/hKBtEPIBOc9Mfl1/wDr0ufe6HqmRnxiiZyhbGc4xyPT3/Cnf8J2ASFhO8fwgEkD/OPyqXJ6 Ar21RIPiHLEBm2JwcEYGTzj/AD/k1bT4nX0DN5VsCB0xjn29DWb94bVzTh+L+s2yp5dim7pnjnH0 +lblr8fPGFqQ1vY2uTz8yk4B9sispQi7XlYa0R2ek/tUfE60Mb2p0xSMkF7bcOOOmc/5+tfdn7On xq+NnxF8PX+rf8J3Fpc8OoSWaHT9H098BYoXBzcxSDd+9xjaegyOa1wuCwteso1HJrXrb8jKpUnT jex9u+Gtf+O7lN37Q3iZ48/NGlnoMHbs1vYRsOg716xb6V8QNZ8ttR+L3jmV+STB4w1i0HX+7azx r+QFetDK8vi/3eFTfneX5t/kc/t6snfmOqtfhdqF6BHqHiHxNqEZzkal4k1a7DHpz587gmp4P2av DF5dC6b4c2VxdHkyy6dFJIT/ALzqT6/nXpUMrxT/AN3wtl5Rt+SHeo1q2eoaR+zbqOI00X4cSKq/ dEGntjn02r9K9FsP2YviPMFa1+HmoA/d5spFz+aiul5ZjF/FcY/4pxX5sXI+p02l/sj/ABdmmuHH guZVYjaJdiADkYAcjFdna/sX/Fqfa0mgwxkc/PeW4/DhiaX1CjG6q4uC9OaX/pKa/EXLFW1N+1/Y Y+I9xk3M2nxE/wB+5z/6Cprdg/YB8Tyukl34o01P7wUzNn/yGKpUcthpOvOX+GP/AMk1+QXgup1N n+wBHgfbvGsKnv5do7/zYV0Vt+wD4RXAvPGc7juEslXP5yGqVTLIPShKXrJL8FF/mJyh2Oktv2Df hMsfl3uq6nKvorQoP1Rq3W/Yx+AmkWkt5qMd4tjbxmSWWe9REjRQSzMQoAAAJJzjiqhjKaly0cHC 72vzSf5pfgHOtlE/l3/4KPfGv4A6X8SpvDP7O9zOfDFm6NfXhlLi5vY2Y77csAyoMj1yw3DAwK/I vxF8WpLyee4+0Syzscl5pCWJPqW5J575r53OuahjqmHTSa+K2yk9Wl6PT1uVVdpa76HiHifx6buK 4TzBhs5AB/Xn+dfmv4r0fxL8J/iY3xS8DRbtNmbN/bK2Nyscv14OSMg8YIrjw/vc1O+6/wCGMbqS cT7J8JftKWmv6VDcWd3uyoLgn5o/YjqK6j/hekf/AD1/Sm/aR0sYSim9T5kh8dWSmFZfDMYtz0YX TdT24XnkAf5zVS58a+ZqNwun6DB9iDgfvLmYmMHAB4AwT1x7+1CqvTSx9G8NJac34GX4g+IV1p8A i0zQYLq9KFhsebaD1A+YDOAAT/8Aqrj7D4m69fwyfatH0+wKncJJ2u5AwwTn90jZwcdh1/LSmk23 J/gc86VRRvH5mDqPxK8dRyOlpY2LW6MBlVnxMxHYMAQRz1HoMHrUx+J3im1tJZr7ToHuPlCQbZIN 5Ib5izAqcEKcZHQ1ulT1buYqFWzvv8jIg+Kvju6jQ2Fhp6EtsZZpmJPA5UIBj+Lk59PrZsfi74vj XUG1h9Jtlij/AHMYNwWuz/cBRWCnofm2jgcih+x5+V3D2OJ5VK6t6os2Xx51IeX53hu1fCksf7SC 7jxyFMZ28cdSO/HfV/4Xdr0zxtaaTYxgMMpJeltyHnaCqAfj+nqqlSktk/uLp0K0t5R+81D8WPG3 mRzxafpv2IMDh/NyBgADdnrn2ru/B3x88Y2HiHTrrQ9Tg0u+iYxvc2V7MH2sCrLlCpAIJUjPIbBB Bq8HVpVK8Em/iX5mk6FSDXPJWuf6yf7M1tp9n8BPhNa6Vrw1TT49Cs44b8SrJ9qjWJVRt68NlQOR weor3Su2Mudc/fU8+urV6iS6v8wopmRS1DUtO0iyutT1W/htdOgQyz3FxKsccKAZLM7EBQBySTiv hT4m/wDBUf8A4J7/AAktbO88W/tZ+EJ4p5WgRfD1+2vujr1EqaSty0P1kCj3rKpWpUlepKxpClUq fAv8vv2Pzb+L3/ByV+xR4Jj12z+Gvgzxb4s1i3X/AEKdoLPS9MvmPTM8sr3US+7WZP8As1+avxM/ 4OgfjdrVyD8Hv2fvCWh6aIikq63eX+uTiQ9HSWFrBEA5+Von5GcnkV5lbNLJqlHbqzupYGN/3kr+ S/z/AOB8z81fit/wXJ/4KL/EbT72yvfjpqFjp32gzxroFpb6M1vjgRi50+OG4dRnO15GB7mvhLxF +1j8b/ifrGp+JfGviWfVfEtwB9ov9Wu7q5uLjgAb5ZpGd+OASTgZFeZXqVq0faVajflp+R2U6LjP khGyf3/N7mEnxS8aXrKjG0RQq8qWLeh+Vn78f/qqvJ8UvEUcvk3MNoNr9PJmxKh7g+Z1z9enfrWF PlXNaT/I2lh3FKz3PTvBXiyTWlurrU7a28qKFkRYlmLyTHAQlGlUFR8xYBlJ4AK9a4Sb40X8NzNb LoWmGRCwJWG4LLgkEZM5B78Y/GuybjCjSqRW++qMI05OrODk9PLuc7dfHvVbW3hmg0qHzNzrOs0H yALjBXa4KlvmBBPHy46nE+j/ABo8QTySTPHalQ/z27wsAeeRlWDAZPcmirXcI88NEOhR5pcs5O/o VNT/AGhfFhS5t4vC2hRjOwSpHqG5R0yu65IBJOeVNZVp8avFz2qym1sZJ2TaQ8MqKOR8w2ycHr7d eO1c9TGPRxOmGBlzvnbtbyLGofHPxTDtP9haOGKsj7YLxgjjkcC5HPGOTjjpXAj4+eNJZhcJpGnf KWXyvsVwqt8uVOPtJYj5ePmXJPOBjDp4y8by/r8BVcBLnUYzf3BafGzxmY7zdaadnjBe1nGxsgnp Pz/QfjVDUf2iPGlgYZI/DOiSgtyJbTUG9RyUvUwTx34+h4SxnNV5f1X+QpYBKlzKTv6B4m/aF1i/ 8P6LbaX4NtrHxGLhjeXWJ5IblSFKqkDvuQDqWMrZ6YG3LcPdfHL4j2TiNtO0aVwgwZLW7PPT+C4U gd+O5HBrR4mMpRuvuf8AwCPqUuV+/r6ENt+0j8Srdlju/B3haY5xumg1jJBOeiXo5HPbpV+2/ag1 rBFz4Y8KIAOCYdX3kgjr/pnzd+ijtz1zpKqmn7KLf3EQw0lK1eol/XoW3/aI12ZYmsfD3h6WXrII 4tSjLLgEBd90SM9+vTjHaI/HzxIjw3l1omlLYbMSLGbxG3cjktIw9+V7da5p4l/Cou/bQ6o4ON21 U07lmf49aigYy+H7ARtyhEs5xjGScHnH/wBepbT46XaTLHqeiWxQlW/c3DBipzk5KN39jnI+tTDE zbUer8v+COeCUVdT0Jrj41LICkWibJWyyM92MAZ9NgPAPc479q59fjjqEdy8UuiwyWeCAiXRQqO+ WZSM89OPT0q41ldtmLwjUV7yLx+N1yLlDDoQhiLYLPeiQknOORGuMcDOOtWl+MWoSHbHoavIVPzf aCgwccj92c8g+n5CideCV0xxwkpaSJf+Fu6lz5ui4UddtwDkdc52DH0x+VfWnhjwtPrvhzRdfW9c yXVvFcNHCiNs3KGILFlBxnH8h2rTDSjWm6d9kZYmj9XSlJbnFfEOe08DaS+pT6hJIxuTbxwiNA0q gAs4O4/KCVUn39wD4NF8aEeYKLWQwbjkpsLBeg+UkYPUgE81GIqqlLk5ugUcO6sVJLfY3Ifi1pTK zPNeggEkrbxEDAzx+8BP4VCfitpzySn/AEkW+cAyxqHPOBwsjeme9cjxN0u/9eRq8G1ZNEX/AAuL Q0REka5WQgg/uCARkd934+1aln8WNKuGQRzPsyRG+wAZHHOT+uf6ZU6zSu1/wxLwsk1obn/Cw9Kd 5GN2dh5DH+PPPHPtX7q/8EPfFfwa+MXxcuP2c/ij4Gl1i01jUbg2Esl/JHBPcyWP2oIyRAMixW2i 6i5Yuwka6RSibA7Onj6tJ+1w7tNdzHEYRxpXktEf2R+DP2DP2XfB0UA034aRMsePLWS+vSij08vz fLP/AHz0r3nT/gp8INLREsfhjoSBehOl27Efiyk193hcXjKdJNVbN63jpv5rU8Vy1fLodfZ+E/C2 nYNh4bsICP8AnjZxJ/6CorcSGGIbYolUeiqBVVK9es71ajk/Nt/mS5Se7JKMVkIKKAGs6KCWcAep Nc1q/jfwX4fhe41/xdpdjbqMtJeahBCqj1JdgBQtdilGT2R5HqP7W37KekSSRat+018PrWRDh1uP GejxlT05DTjFc1dft0fsUWSs91+178MVUDJ/4rzRD+guPatFRrPVU39zK9jV6wf3HlviH/gqZ/wT v8LrI+r/ALYHgjYvU2urLd/l9nD5HB5Ffl1/wUs/4LEfskeKf2ZvE3gb9mn9oGw1/wAf6ncw293b afbX0bRWGGaVt80KKRu8pSA2fm5xXflrjhMbSxeJVoU25atLWKbW/mka0qUozjKW3qvyvc/kd8Se M73xEY73T75J7W4Jdn3hmjPTkdcivIdVutWLH7HaTyx/xbYSB09COvr/APrr8++sOvXnUqS1bbd+ 9wqRu9Nzi7yHxW6yNBZSZ6ZIPB4NcBqmh63PbvFchfmzlW4I74KkenHNb0q1OLupGLpvofPHib4S +LdJvG8SeAbpba+BDyWvnjyp+vbJwSK5zZ+0V/z4Wv8A4Ef/AF67lVw9TWcnf0E6TbvsejaFrupy TB4jATt2hfLUEDvxgZI9RW+76xNdTXgnjWZwNxSPhv8AezzkY6+/SvLq4tqTilofSwoqaUrm1A+t xzRFp183ICbkwM+x5FUNVlu5F8u7WENj5RNBjGehBBPXpjPOParp5m4pR5SamBUl7r7mVHawGNpH t+A+7f5Z6nn7vPA656VQ8QXKXMU0W8IQNpIjLhwB1wQMd/Xiun+0+aS905ngLRbuea6XY/br2O3B RZZg/lukOMsPXHGMHpjuenWn3vgS7msRHNOpQswbNtzntyPf+la1sxa05dfX1MqWXqf2jkJvht5a Iy3zG42u4RosfdP1Ixz09q7fw78KbORIbu4vpQwCSBRGGJ+menPH/wCusp4+Tp3tr6mlHAw9rZvY 9P8A+FZ6cEmO6UROdxRgvzDORgDpjnv+XFY1p8NLGz1METSKhJIy/QHOO3bn/A1y0cbUhdra34nZ iMLTnKDe5+vP7Mn/AAWD/wCCjX7HXgDRvhF8NfjDa3/w9tYBBpNjr+mWmof2VCvCpBJKolVAMBY2 dkUAKoAGK6L4x/8ABZn/AIKffFDS49H8Tftb61p1h54uEXwxBZaBMg/u/aNJt7ad05+68rDjnJ5r eONm7crspNtr13t29DCphYOUpSiubv8A8DYX9n3/AILGf8FF/wBnmHUNC8IfHu91XQ7+6mvZ18TR Q6wVnkwzyLLepJMjNjdsDlNzOxXcxJ9B+IH/AAWk/wCClnxD8N3WleKv2qNTs9KnKuP+EesdM0W5 i54C3Wm21tcqBzx5vPelPGVk3GnK1/z/AE8xRw0H79SCuuv/AANvwPinxr8afiZ8abtvFHxO+K+u eIvEQjMYv9Y1a4vbox4OF864keRcdst2rxe8S3azuprm4meQL92STjhsfw9z07d+K8/21SU2p736 +p1OjCSV3p/Wxnm20prIeVETGqfxMSwwPU+/PIB7j2Zpstvb28/2eALO+Ai8845yQAcHPr+FZynU kpKT6nTClFNPsY2qreXFrcIMKmDjE4Knnr8wGR27daksGEVpJsuizDeyqpOxPlB25Xd6+3NP2jdP l8x+zj7RzL+nalK9sZoYmbA+YiYsD1zjPPp27e9Rz36XFzbrHYfK2dzCYnA4555zn+VY8zhOWv8A Vi+W8VJnfx+IrjRtEu7KzsoIYif+PwhpJDz2bcMY9Cp744rjfIikmkmgk3MVyGEkgz3HPB7598n6 VEsVUnSVN6RV9hRw9ONR1XuzMvV02WFLWfYjuWG0uSWxwcDrkH2P61Do8FhHNNBFIvn5wyqxJIPI GOfXn86ydWooO+25oqdNe8txuq2Vw0CjbucjAGC7MP8AgGePoT/OotLMa2RRoJXJO3AjBDE8eox6 cVEpycLo2jH3tGX76w3myiuIybiT5eF37QRzyRgfTBqjL4cn/eItqfIz98R/eOOmfwPp0+lYus9E pWNLQTuzLt9KvGnKnR5I/mw2UO3pxgdDxnqT9OKzL/Trd5WeOFZJkB3ZzlWyMDpjr7enOOrTlzr3 tCvd5dDgZrLVLq88uWxlDBiQpQbXOOobqMD+ftWNrnhnVLd7aWdJZAVIZtpBY8g9wOv9PTFdqnTj KEU0zllGpLmk1qYdzb39r5Tm3ZQpUgFXxjKnjrlTg9OMGsKHSDFql9cyJECeFMsZC/7WG24/HuQa 6IVEoy5Hrbp6mUqfPJcy2fX59zr7G1upRMqR2wgQkBl2+4zwOOx+g9Bzp3Pha+mgY/2duhKhgFR2 Utk9wMen61zVKsYytza+Z0wjdNNbj7rwhqRiYRaXk7flJB6HPYf54xSHwZrHmuxsXKcFQVI2Dv19 Pes4YiKatLUKkFJNFKTwvqsc6stmfMVGHBIKd+cc4/wrAPhPxALl55bZ/se0MMKQc5A646Yz0962 jXpK95GUoNtWNKz8MeILiURWthNISpwsali59lHX/wDV1rXh8O64kYhgsCZMHdgDAPPH04x/jU1K tNpa7lxVmxo8NeIJBPavZOqqwbahK7vy4/xr3vwR8UfFPgrwjdeHLPThNKrMLWeV3b7MSOQVOQQD yoOMEnORkU6OJjQnzRkrf5mGJoe2hZ97/wBfI8lv9E+IfizxH4hvNR0SSE2qG7uEYLEI0QKZTtcj HLZ2A8Z9jjgzpl5b3KM1uUJYHcw5A6ZHX0Aqqs435ua/+Y4JWsuhrW9jcM7CMfeXJ6ZB4x0696cb W5ZjA24yDBKlWwc5GP7pJB9PfFc8asVdW1LkrtGaNNZpC0kY8nJwTnjOScfmD0NWI7JIbaC5W5Dx mQoGBYcAAnt6kHr361pz6dyWrNdCVUjKFjPlmAO0HqPXJ6fka9j+BHx0+K/7NnxL8K/F/wCB/jy6 0Lx9pF19qsru3EUiq5imgbfDMrxSK0NzPEwdWyk7j+I0W5oODW+hjUhzxcZH7U+Df+Djf/gpFomp WU2s/GDQtTt2+VbG/wDC2kLHMdpzk28MUv8AtcOOQOMZB9Tv/wDg49/4KAahEfK8Y+GrGVsEmz8M 2bbMdcecJBg9ec16OFzHF4anGlKXMltfe225wywGGbdofi/8zkbz/g4Y/wCCi8g3w/HWziKqSwTw l4eOOvOGsyeOO46Vzeof8HB//BSOS1kL/tCxxKcgMnhPw4hOOuMWQP412xzfETVuVfj/AJmMsLh4 LSmvm3/meC+Kv+C4X/BRLxE1w97+1T4iiDcD+z3gsdp4+6LWOPHWvIz/AMFUf+Cjt7cRTxftZfEe RCBMjReN9URAPlwGXzwDyVyMd/eu2nmNTl/eNL5HNWg9PZQWvkht9+3r/wAFJ/HSW2maj+038QI/ mCK1z421PEnJ3MQtwWYBeeFI2qTnIOcTxd8ePiz4c2t4u+N+teJPEF3GIWN5qt60gdi4DRrIzEqE AOSyMGkHB2HFTx1R0fZ0J77tafl/SOWNStDWWltjyK/+NPiLUTqmpan4hnkka4ysC3LfvN4YkgD5 QFwB2xuGBzXFTePtR2LdDUZ3tpPnj3SNxg7Wxz82CCAe/B4PSYYrEyhJSrS6dQnWm5XuYV54vupl Ei3soYsf+Wr/ADD256fX1HFclfalJcLIy3TmRBuxvcgn169s1KrTd7yb+ZDlJ6XOJv8AVr4pIWmJ GzIfJwT3x/IjtkVxL67r2j3SajZXKj5SGRycSLkDacjpwe/8qzqPmXK3uSkz0vTviZd3kR+w3xt9 RjX54C7c45+U+g45x+FVJPiT4/mmjs4ru7dXIRiZ2ZRzgEuWGOvc1xRoU226lr97GqSlq3Y0ZvFP jdAvmXcnlcKG/tADB69Q/FYV38RtYtnkSTVrvzPmGRckjPX14/zz6ONOD+FJ/It0420ZyV38QtUl R/Nu5JExnLXLfNyBxz79KyP+E5u/Rv8Av+/+FdMYaAqbd9LnofhfVNPuZ1j0yLBUFcEnk+uOeevU 16Na38kRMb2SBFcfx5yeze33v89vGrxcZtSep9FRS9muUkfVJHVYpbePywQ2PmIPTrz69v8ACqOr azdG2kkuHiJB2qDE4HJ+7gnr/gaxjBcyV+ps78t2c5L4hukhYwWqCMqAdsbDPQjoen/1q4LxHr9/ a2si3EUbowUAqjgkkEHoeP8AHHNd1GnepFNs4q0uWDktjidN8Ztpl7bvHbjfuAG45IzweB+XPpXq 9t4ik1C3kjBbzWbIHltszjnO5c9sfXv6dWIoWfPJnNha8aiaiiuXv/s1s8ForFCynKcIpyeMKTnO DipdO1nV7S2uBtMcgUKFSIMCByONvv8AoKzUIShZS/4Y1TqKV2v6sd2NV1ue2H+kKsuxcmTy/kOe eMY9Pz/CuS1fX9Ytr+wh/tBCxcbmV0ADYyQDg9eO/rSw8INSVhYmcouNn2NPVdQ1aZNNmXUCEUEN ukA546EJzj2wOvFdZqD6m1ip80GcRjDs+Se5YkjGcjp78daz54RUE117GqhN+0le+gaDNq0klvMW DIHYEg5GMAYxg59vqPSvU1tr66sjbKqE/LtSQOemcH6jLYHHpkA1nWrRU/d2RrTi3Tbn1NW0XUba 1aM2wJ24HzAAe2Aox+uK5G//ALckjgC+SF2/PvlXjHfJXj079Olc8JUnUbbNZL3NGjY060uXt72K eSFpBJ0DD+6PbIxn/Oajs0hCT20t9a5PBHnIccck5/w/Ks51fekop/iXGzSTZV1BtIW0lEmo28ZO Y9wkjLE9+Bx68ZqhaSaCY54n1q3bKjG7GAMY5GKE6vs9ItoH7NO7lqdBo0ej29ubg6pFvJKgrHuK j04HbvUC6j4VlvTFLrjFl+YqIHHJ7jKjPUnjPX2rJOpKpJxiV7qSSOzn1XwitvFHLfzmNiI1bynG CQSCRgY6Y49R61btrrwvqGYrO6ZplGOFfk9c8gDtg8+lckvrEYt8unqaNa7HJ3Oh6c93f3H2thar jy1WNhtJGDk55Az7fpmuU0S/8JRaq9pHq7zXRfcVADL0B9SPbkdutaQnVqRkqcNlrrsQ3FOLbtdn pk1lozwPGIbg3QZcPxjb82Rg455Xvxjvmo4rTR/scbGG4BQgYyARyec9ce3fFcvtJcvQ2Un0RVmu dNW7tVgt5miGzoSrD0J55zyOfT2qU3+niSedNHb7SfkEyr8xjBwQSBkD2z74qIqp0nb/AIcJJtWs VRrVg7SxpYuDjPzHBB4HTrnr/k1y1y2lhLp0sLsLnO0M5II44z/nj60RjUUrOSLWibSM3StS0aS5 t0fRJCMBV3ue/sVPHr9Bmt3X5bOY2cZ0dGVmxl26A5P932qpqSqJyn06Cu3schq+m27oFXSRhfm3 bw3Tp/D68/lXGDwe11JOgtYcsTnMYI5GORkdMY/nW1Ovyxb5mVo5XaTJdD8JXOnXfmXb28tnywiE G3aRnbzu6jg9Oce+K9La6SCAeXYrhAMoz8fpisq9X2s003+YKLSSMaXXpk80iwhEKKMMZQFOMdSe Bnnj/wDVT4tWuJd5ntoBEdrQCJyTzjrjI4PIP+RPJFK/M79NP1JfO3YzdU1lbK0MyMvmY+UFmPPJ 9a5y08R6pqUqOqW504xlWiEUm4uGIY5JI/A56CtYRjyOcr/h8iZc3OoqxqnUbhpIPLtkKgMpBzwD wRx37Hp1/Crkd6dh8+0QkfMobcw9jyev41nKztqUorcG1C+ZyXtoigP3TkADsMEjnkdfwxUU11cS lZfJiLFO+cdcAg5/zzSdo6JisX7vVNQnkuWmuNxnj2TFpGJf5drFySd2WGeR3HU81yEukW6PmWVV R8tw/wDFt2j9AB34zVqraTsJRttoRDRLEHzLe8Ik28gshHsOn+HStRdKtmZJBcoCcDPynn8eRwBk j24q1Wb2QW1szOvdKgtnRo7mNuMiNmU7s+mP85otzZzQRafcGI20cjSrAMFUdwgdtpOAWWOME9SE AJ4GE6kmrq+hGnUh1i403R9Lu9QfR1uHQcQwQq8jnptQA8np/PFctp2v6NrOn297NoU9nNINz280 TRyRsBg5GQSO4OORj1rppRrype2U9E7Wvr627HPKcY1fZtPa9+m5IG08SBhHLtXJVndRgYPPOe2f /rdKjS+iVZBFNl+mFBJxn2A78c+ldMJSe+pnJa+5/wAESfUmkRz5MuGABwWwc+nPuKx/Mmu5oxLE +xeoLNj8fp/XvXXRfLqzmqRbsZ+p3c32ny/szKiMGQ7WyTjqcn2/MVveFvG91bBtNF7HCsMciAMF bzkcgY+fO7B59RjPGMjpfvU+9tdDnkrS9T7W8CeJ/BOieDtSuvFMtrNq120DzahNJI1za2vlzI1v ArSokm9pI5GcI7qIFRGj3uW+XPij41Txf4vvfEtpFJHC04xK7l5JSSWZznlmLEsSTz3OM1rharnT a5eW2nk09f6Z52IvdpO//AOSvvGUN9cTTRh4FclhuIwqDLBfkVUGFB6BFyp2qOAO++Klqnw+0D4Z eFbu0u08Xz6Lba/emZwqpDqVtBe2qLAY1khbyZfMLMxDrNGygDBbvo024yT6L/gfqczlq2eCzeLp dryeafLZsKeRv2gkgD05x+FVbXx/OLpbaCTEbttQu2Qg4GTwfXOB7UvZXI9r5Gbe+ObK7e5W3jIZ 25UHaARnHTgg57DisfUfHn2cR6awWNo8rIphQMrDOQTjOcnBB75pOhJ6PoHtkiPSfG72Gq6bq9os BurOZZlWWLcrshyFdW4YdMjAyAB61+onw91T9hn48WOlxajexeD/AB9LH/pWm3d20Fu7qMHypeIi GLfKCN2Ac9DTpwdOrdq8Xo+vmmPnfQ9ktv8Agnh8J9YZr/w/4wTUICjOn2bxFCEYDC539CAcdGwS cZ5FKn/BNjwnIqRpoV4ZmOGY67A23g7ugGBxuycYHB7Gu6LpS1il9xPMpdfzM2f/AIJ3+H7JYYTp l3lOYhJqkLAE8DaOTyCeMd8j1qH/AId+6X/0C5//AANj/wDiKyqKF9En94+aUdOY/MrQb/T7S5u4 rS2ZBlCVjUNjk85Hbg56/wCHr2nWIvpYpGdxIy/MuAMjp0Hb3r5rFwcZ3k9T6rDS542itDdk8PgS fNJhupOB1x3/AF496zb7Q1G7zGJhw3BwMYB5zjvyecex6muSNRJ6nU1damBJo2yAtLOyb2yNzqq4 /Lp2rzTxXoInsSILoNKV+Uecihz9fxP6etdeHrJVU2tLnJiYTnTcUzxk6LdahYNdWoxPFKGbEgb/ AGe3YDj8672wfXrO0bbtknABBBADE+vf0/P3r2asqM4qL3vY8qgq1K8k9Gv+Adr4TvtUvZY7K5UL CZMli+CD1HIPP09TjvXoNn4de7iuI7jcFdNjAvuDZz1HXPX8q5mqMOZI6OatK3Ma9v4A0W3hnDPM S6EOytgY6YAPfjpmuJ1z4faLJbjUbe4kblSVO0kYbggYyO/P86VPFuDk7Le36BUwkanKnJ6IL7wZ ZrFat/aDfK2CSwGQe/P8uegqPUNKQWixDX5CNoypkQ8A57scdOtcyxblyXgtzaWEcOdxmy94L0fS rbZdy68SyzlignXH5HB/z3xXug1LTVsV3a1mEKduyQEMODngcfr1NcuMrSqVW+W1jrw1DkopXv1G x65o8lvOp1YeS68Ddn06HH059u1cXdppUpRTqExjKnDEg7cepx/nPvWNOpKEm1HU1nS542Zq2V9F aLd2tveSSI+D86jKg8HGOScgc1xCMYbyZYwxSRNxPzc4PAOD+H4fShTvz+ZpyKKjpsR32oMYY5Gt +AD98qc8dRgfXrjGPaqthqdrc3cW5NxcbB8o+9jCjg+gPbr79NFzez0Ypcjn8J2WmmCGPyoOZC5y SeRgfr79OlWGNokxzaDzmUjzAuOO3pkjkjOfpWCq35kt2dXs1ZW6G5OttNFaRCMSZGduACOoJGTx +nb0rdi8PTMhunhYAckoVHGM5HNcsqisk3o/UNL6lCy0l9ZE01nCskStjzA4ZD2PIJyPxIrlIvBk 8WuG2GniPAG2VMBi2BkA49OPwpU63K5Q5umwpKEpK66/1Y7dPD3iWwO6K4u2O3GHm3ZznjBzjHOO 1WoDr8Nn5s8U0kuc9FOOeMbcegrmlOlONlZMtJO1mc3qF7ewXltcva7bjBRmMW0hePlz9f8AHFRx +Ir3zHRU3MeGUtnnk8Dj/PQU1CLjfmCyMyHXL+6nubYxiNhgq+eBlR1GD65/HpXLPr/iOOQWq3TN cgkOWgj2DkDAIXng9M1tGjSk3zeXcb0s9kaGm3GtvfW3n3MCQtHvZ8gN1JxgAfhz6/Sul1SO/lez IkcRK+5efv8AbnPI+g/SspqEakbK+hUVzK0jntel1K3s7iR711UZG7ZgbvfOOQB645OBxXL6T4gL S5udZ/1Q+75ykthdvzDcOnJxjt9KUIqVOTUf1FoprUs6ZfTvcXUkutPJDJllTdkpycgKQBgZwMmt sS3jearzBE64BYMgOeuQQ3PoRxUzUU7NfcXbTcxm1W1s57e3+1K5lcqX34KD2AJ3dOme9XL268kR zQXIlxkfKB8vAPJLA9R79fxocWpK+lxJX1Zm6g0UloZruRFkx1Rydp2kYxwO49hWDoVrarGo2SQo SQFZuRkn73P045+vprCb9m0RyLnTtdkOs3gsii2j4lB8v5iBxjOf7o4z27Vr6TfxXUCsbgvk5Rdw YEg88/Xt+VE1+7Ug3nylkzH5VkRRMcHeO3y/3ec55P48ZqvHdMtwXLxraliv8TZIznB+vY5GMACp S0bTG4vRMllu7chRHuVjgAtkk9R15xjnvj86yrr7HcgwSh0eNxIkoU9ewyR+hB6VVOTjO63FKDl7 pWtLa3tUkjEnGQGAU5UdMkkemPzNaTXsW+JRC2wNs3soYoOB+ZHfn6js3Jzlcnk5VbcoXGolbwWo gYDlt27gYPA9u4x06VsaTp6aikuoMRvLYZPl4A6YJ6j6j6elEpKEbrqR11Na5s1h3IbhFPB2vH37 9DgHjvwfzrn5LLzJWNzexGUZYEnBYcnAyfQk4x6cVMa1loS4p7le4WylYRNcW4QZGDICSOB1yDkY 59M+9c0sNtahRb6pbfIxBXzRxk4PA5GM5xx27V00qsnFx5WYShG6aepakuLKP5xq9vxxt3hgfzbt nn6VSe8smGZNTt9zNjhFIPUjvjsT3reEpyWkGYSVnuYGp31lMWf+04jNkH92gwOAffHB56dfwrzO 4udLa4V21X98CSuFI6e+OlenhZ1HHl5DhxKVrOR1HhzxXp9yWtJr/wCVsqQSQAc4yM84OB+ftXQT anHp8E8cuDC33G8zgZHA545APu3Su2Pu6PdHlTSc9dv6/wCCZfh+00S+lg1PxB4ssrXTI52lFvIY 7ma4ZEMn7yJWIUMVEYVvlLuqsVTc68X4j8T6U97qLaW3k2TyO6I9yssioWO1C4VQxC43OFQO2fkX jHZGfNf+vmc86clHQ4y912KSZC1ypkI52o+1RjgDaMY+n/16ik8Q2cNo1taMzOTvMjJjJx3GM8fM Bk4+mTnW9ktDL2U+qMD+19okAhLIBhSVGVOc7u3bgZ6Z9QCMkXxctEtmzZyfmwPxOM/zpqatZB7G XUozaxcQggW25WYE7XJP16f07/WoX1PU4yJ7eKNWYE5dmZhgj/6/604q7tcJR5dCay8YeKLRQbe8 dJh0aNnXGc578V1tr8U/i5p5aODx9qiCRSWUXcwHP0bBzWjaXUN9Dobf4w/FYJsn8f6mSM/8xG4U g47ZY9uM+w9Kk/4XD8Uf+ig6x/4Np/8A4qspTcnf9BcrPqTw7pDPcefLNIxSFXkMi8M2MYUAcdOC cDjGeme+TVNSgWMW0wDKQpBjI3L0JHHv6flXz9eMakk+lrfofX0la9iabVdaeMP9pPmkBhhBgY7f d9/1615b4i13xfvmEOshYcEnEanbknj7uAfr7VzU6NOMvf2Oid7WjuY9vqHiVoV+16g7nbtVMqCB jrwOfxq4TqHlBI5N5fjLBeQeOT6ZOMVpJUlJuEdCEpOOurMIafqUSTyJeMTJwwU7fwOMZ5P6157J L4gh8+CfUpGVGcA+Y3A6ggZ9CK76EoTb5o6nnYmFSFnHzuYUWt6/Z3TNFqk4JkBBSRhwD6/5zX0t 4ZbVby2a4nuXaRlBbLnuDxj1/wA+9dGLjTjSUrHNg3UnNxb0R1A0p3haK4llI2kFlbAxyMAE/Xv+ XfhbrTo47bUNMd5I5cbVJdfvDlcYbA9Of/r1w0qk58ystLP+tDsxMIU3Ft7mjo8kdxp0AljzOBgq 5zjGAT19j+X4V1v9lQ3kD9BjKZ3IPqMZ4PUfUGuOrOUZvsmz0KfLKC16DtK0q3t5ZApXczAkCRcD IPvx2447V3sdhdJBPmOJQVx8sqZPPbGc4HJ69OOevPVlKTvI6IKKhy30RkC402AiGa7jXIAyJVYg EZ44IOAQB796trptpeoWt75FhJbJDDDA+vHT8P8AGsouUXot/IpqFnqFvBb2U0Q+0eY/lAbNowe/ 17e3U1StLITapJbRpIJmGMNHgEknpuAB4wOM+n0JSleTtbQaUVGL3NK+8PXTxJG0a+Yc9ZFBUHOP UcZAz7ZrPtfDJMkUYngUq+8KpAKLnoQAScZ9ulTGpanpt8wtG6Z6XB4WiRcLPzuxvUjvnnt6/wCF WJvC2nRu5luWVgOXAQHjJPOM/XmuT2nZXNOY2LDw3oBjhvY7iVGAypaTjPOCTg/059M1Lq8+jSad JYahdytYlNrBZynBHOWwvbtn8KzdRyfw7MiXvb7nnst5pmg2N8vg6Hy7vy2dF+1GMSMcnkrx7Anp 61xmjeJLp9bs01jxME1BlPmQSXfzRuc8HazYIPUe5A3DBPWoOpGc5pufkulv8zNtJxSat/Wh7Ysk 32YGTxAgAGVC3IYv6dT/AFosr3RmjlkutdaYjI+R2OMe/IPPYH0/Hz3a14x/A6LbWRn32v8Ag+0V GuGZ9p6skrHryMBeefY5qvbeJvCUUkoVFeRSAB5Mmcc5wSvHf60lGs02tvVCSaa0MWHxt4Xa+uI2 099qkglIgQBzn0PTj8eDmsy98Y+FZluw2mXPB4BAHBwM/fyMZH+RVujWUrprb1GudWuZ1r4p8LG4 t2/su6V1RQWzwOfd+w9vTvWlrHiW0SGH7ArqCwXMu3jOM9OTxTcKkZrnd15FRjN69DlLmfRbuNxf LeT5BUoLgIp6knaq+vf8+tUbbWPBenSRC38Nq0gxtkknk3AHI6mMg9P89Kcfb8rjFpL+upTjs7jY PivoU0kiJo6LbvlY3WV5AQM4yBFyenP681NrPjDT302+kt7KFcghXZpADnnqMfTOO1X9Vq05xcm3 clNWckzzTw9qEEviH+2niSTarCOBg5RAyleCcH+Jj9eucV2OoeIxGpEeiQtnjCySDbjsPmPPuK2x EJSqxTdrK3/BFRjanz331PL9Y8bsLeKKbR4kz23sQBnOe45x0PvxVLwl4nku7SW8W2XY0rD74Jxn rn8u/TvXWsLy4dy5upz+3viFF6O3f+u5V1nXL2bXbS38lBCVcnc68k45xjpyf1rT8OteWrXdrJcA FpnIDMpKAE5HA6ccD09MUpxhGko90n+Y05Oo5dLv8kaVp4g1qe4ltbvTJIrTcQkpViwwTjPABHXg CtT7dfKcRuCUbIyoOeOen4fp0rCpSpQlyxd1Y1jJzXvKxE2oawHZBhgecbuOPqK0obzVS0cQgYZG cgj5+/tSjCnrK4TbuVb6PVN0hWcqC3AB4zzngfqMj8KyJRqSSEmUZbgkjI6dfrTi6bk9BS5rJobJ HLbRzXEtzFsRN7nnO0c4AA78cfSoITcNAkonxGwU/wCrJxuHc5+nPPXtVxaaUrMynZS0IA0k5nt1 3eaj7E+U8jAPHT1x0/hqQ2RUbWuzvwGwTjjH4kc//Wq3LkdrGcm2rlddKmwUKsXOSAhzwTxkYyWG RmsmXSbvzi0djIysfmZAeOOg4/Dv0P1rSFWKbsZTVtGi5NobM8Y/s243NjChlGOo64/H8PbnHl0h xcXCCFwc5Ad8n154wM/0rSnW80YSi79iSbSBBbSSmxcnA+9KpxjIzwSPf9O1Y58LWkzrK1gAck58 44OfXnP4cdutbU8RKKclJGNWClpPU5a+8OWtreEmMRxBRx5nU+w59PX3+uC8elrdTo5EtueAcsxH UdSDmvRhiKlSN4723t1OKpRpxs31ZF9s0G2kcDTMgDgFR79up/8Ariga1pUbgR6QH4wV4yT+H+ea txxEtXMzvSWigUItQndpSdL81i5z+7PQ/wAPAz6flUM+o6ht8mDR2EvXIQ/L+X9avki371TQz5nb SJiSPrZlRRZEyNxhs5PvwRT5Br+jXiy2RQX8E7J8uCuVyM4J5B56j61tH2O3MYS57Wsck6arJF5x AEeST0ySM/p1FdLo8UcljE1y4aUg/wC794njsP8AP1rphy390wq3a1NxNPiTafs2QCOAvHPb2rWn 0ayvJJJI4CsapjK9yTx17e1KT1vczSuNbw8HyrXG1CrNiRRkngDn3/pVT/hFx/z2j/Ss+azsWop9 z7l8M3Wky30Fp5YJeQRmNioVtozznOAecGvaI/BMqFbnyt8ZCFuSwicBiFY4yOAxH4968v2U7I+m VaK0b/pHNXllZWy28csR+0IMYkEmHYDpktj6niuE1K2tWkDPEnmMwCgEnPY4PJx9a5q1OSenc6YT Ulqzzu4kRb82MNshONzSQNkpjbw2flHXp19q3JQ9nbYisQVwOTGOVHQ5P16/Wk435U3a/wB5Km7N oy55NVuxGY9MURAbfnQA9cg+3/2IrzvxZpWpw3X26ZUWFwHbaig7v/1cen4124ZUozUebf8AM4cT KrKFmjgreHULnUJIkDMYvnXLALGVJY9TjBJ9q9v8GaxrnnTxxvIY42I+UJj1xkdR+vSu/E04Tp2f Y83C1Z06mz3PS4dP8VajaTNaSxpIpwCY5WyvJwcj/OOleS2/gvxn5t3LqF3tOVVcwopYc46dD7e3 txx4eeGpuab10OvEQxFTlkl0Orj8JSrp4lt9RniuGfc67IwpYEHKknp/9f610d5ef2XpO2KSWacA b+IsIcHnr2/zxXFXqQnVULJa7ndh4zp0XO/Qd4M1H7XBeS33mqcKAW2jLfNwM53dBjPvW3qFtqVx ZRr/AG8tpGibQqwrlRyM/eA59MVx1p044hprmS7ddDsoKpPDp3szj7XS2tLyaW78S/b5QjKBKvlr 1wCcMScY6Z5/SvRX8ZMlubeO0skIYPlV6kkZPDDGcnoenXrRWkqk4uMeW3QuFGpGFnK7+4z9H1Bk 1OS/k1RpspxBlWjQYIxjG7HOepPHXFZDa9f/APCRxaikkblAQwEeWJBwMdgcdiazahKpN2t7tuxf sppQXNfX10Oqk8UX9y0mP3aICNwQHdjHIJHpivLX+IGr2HijfcTRyccbliUEnufl9vcAH3pUKUZq cHvbf/hisQvZ8r31sevWPjy8nQCaBctg4SY7iccAcAD25/OsvU/Emrtdeb5MnkDLPiSQk89OOxz9 MjvXHCmlNq5u4pRuiSPxNquo6ZKscDgZBy28Z6hTyB6D8ce1c3FaarJdJJNGqbeGZ7hBjI6hWPPY epOCOla0lTp86b1IklKzX5lpb2eCX7KHVcBOGcnjnOQGBbjvz25458G1fX0tvFpkWVEYXON2Hwcj 13EcZHPTH0ruwNOdSrUt2Zx46rCFKk/7yPfLbxbbzeTGjyNujPMJDIAMfdKnk4PXtz6Vr6A+oX8U 621tcNsk2lRlmXAI4IJA6Dnp+JrzZ0nTi+a3Q9ONSLakv+Abdz4b1d/IM6zIxYkKRgY98ZA6Dr34 4qrH4RvzE9zcHbH5mT1/h9jwePY5xXM6sF7qYcyvdHMaRp73Oq3MM24fOfKMMkDlFyA25RKWU5Pd OODjkE98vw7snu5yuoN5bEcYHXJ4IwaqvXVKSVt1/XQmE21qvyM2XwFplvexylSx2cNkfeDA9F5H P8vwreuvCelyTwRLqBE0i7jGApLkDJx9Pf0Nc88S5ONlctS5U+xcl8I+HbWCTzgHuV4kV2zjp0HA xjAP1rDm0TT7dIJvsEUds0XzgoM5DHqCMjk9hjgc9azpVpuLd9yJTbaSM+z8P6BFcD7LotuE4VSs EIAPcglBn6Z9ePXrL3R9Di0m9I06BI0+QnyQNgxkY+UjHPJ7H9NKtetKUbybfqSo9tjxrTfEfgWx FzLNMju7tBBGLfe8sisy7EVRnjb3xjBycDNTX1i11IqtpTQwTBnjWJsHHH8CsTkZwcj8iMV0zjWp 1eaq7J7L08v1ClUi4tpnm3jHSnkjjn8skfKQQoJByePnA28g5HHX1NU7Hw/ZaNo9n9ukjilnJmBa MIdoHJKt2BxwM5z1r0qdSf1dRWt30fZHJL2bxPMlZ26oppa+H7zW7WGTWIPtBbhiFI24yercfXHQ jvzXW2VpYjUTE+sK7bzGCijYvGezc9MfXJ71y1Z1dpQ6fgdFOS3i+p1jaFaqqu12TCCCcR7c9MEH 8sj268Zq9/YejwqS1ywUjABcZJxn+6Pb0/CvPeIlskb7XT6Ectp4bjaCKfV4EmKk/NNGOeOfXqcf lnFWkn8JwiQnVbYgYG77dFnGM5xu+b8PWnGVfZQb+TE3HVXKk+s+DQ3ku4uAxPKS7uvrhs+nr0Jr kJfGPhy38Qm1k06FNJ2Blkkd87v91QcdhjHPqK1pUcRPmUm00nZWMpzSaS79+hvXPjXwM+EjRWhC AYWAtk+nI6Y/U+9c63j/AMHWVtPHZ2Pyj7mLZBz1yTkYGOn5VdPC4uTs20vUylUp6sbJ8SNCRCId PmeRuCwSJQeeeee+e3bPeqN18Tbd7dlg0GbcEyGLoAD/ALKhf/1ZHpW8MBVnvL8zKdeCjqjBf4ga nKWaPwrM3QDJcjGe+F57jt2qhfeNvFM5QW/hcrgDZmOU7enQduM8V208rSacqpwzxsUvhVyl/wAJ V42muZki0m3WVBtO4HC55IwWxnHPTPvWVcaj46lkIltY4pBkERxjjHvn35/D8eungKMXZydzmq5g m7KxnXMvjW6R4nvdqsrDAjCk8YHVf8/rWFbReJ0gvAdQmZRKVZvkDZIyRwOPX29OK7YYSjGHKofN nJPGSlK6l06FaXwvqlzG8894QB/fkJ79fp/hVKbwXqLHzYrpXgPUhm6d+M9gf6V1QjCOllb0OeVZ yd1qLpXhZYLmKZ5HaZTuACg/5+ldP5kzhrcShCpwwZT83p+B4GM+5zzUVaKqy1eiGsTKEfdihBa3 Zlby5lWJcMpUZxnqMH/PHWqT6bfPc5iuZDJjOflxgk8dOue1KNGitWvvJdeu9n9xeHhZ5hvlmcyE LksRj8Pb/wCvQ3hCOSWOWVmfJ+eQvkqMZPt1B5PpVRcIr3Yoyk6kt2YVz8OdJl+1zKWV92UO4Hdx nn8xWJBpsdkt1Ill+5gcK8iDHJOFHr+X9RXTGrzpq36GUoWsbVnbgFpyhLt1XZyOf1+tWmS8YSLb 24RPlwCpGBk/j1PTvSbT3FZ9EMjgu5YzNNAomB7Enb2Xn04o233/AD1X86nR7tle90R7Ro2qaXa6 3HLJKMPsYZKlmKjGFxyOpHHt2r7C8C/ELTo9Q0+GSZmikdAfu7Mfd+br3zn2FcnPNVqaWi2Pep04 SpVIp3epu+M7zTW81Ht42tLlfMB6fdJwVPHQj06gntmvm3VtW8m4C/2cfIGTkzE4PGDyMY5z1HUV z4lSm7+pthvdp6nNReJ9MS9IGmgyOoI3ScH3zj6dK0JPGWlKWV7VQFH94AE4GDz1rz6lGq5bnbCS tsVW8eaIhlERtx1Yp5nAb3zzXA+I/H2mX0E0dukRbYXHBzgcckHpxjFdGHoVeZSdznxFelySjpqe caXr9w1/dywWkDFohvDI+0r0YHJzjv8AWvRfBPi64j1K5ht7e0F3wSYonZumP4mI6j6cnFeriISd KSu9keTQcfbRcoq12evQ+MLlY5bOW5BuAhbaFB9ccDA7HsOhrya/8Syx3+oB1ZopFUrmIbgeT6nB 7cEfWvMw1OSlKPc9HE+zXLN/10Mu71h4NInurmxm89WJV5VHJB568DqfQde5xVCHUI77Tp7vZIpK FBsjUZ68ZH16V1+yd+bmW5lCspJwUX8O5f8ABV20FzdQR2U25towm05HJHB6H065rvri4vPs0ciW 0o4/jZOozznJBz3x+HWuXEQ/2i7fY7cLN/VVyrb/ADMnT9SuJJYrRbdgwAIYMPmB5wRyMd/8a1NU v7qKPz4GRXzzmXOc5HQKfr+Pbisp04qqo3u30NoVJcjctLeYljdXbzLLPIVXGweVOe2PTGRkD/Oa l1CyuJp45bIyZWRtixll3juCcHPQj2JFZNQjUa6M219mpN63/M6BoruJGu7rwhehSpLM1m5JJHGG znnd1Br5+8UeH9TOr6dL4ftLuzgLEP58ksqHBBDAMWK8AjAPTpyOejATiqjUpKUbeX9I48epTh+7 undd/wAT160MFpa/ZrnUpI79irkusxTd8rMOB3xgdcZz3JrsrjSrTyFa41Rym0jEcT9h6s65zj2r grTcJRkob37HowtKPLcv+ENH0DUY5rVzfuVQlZQkKx5yON3mHbxj/OKvt4V8OySER3BJ3LgvOASA R1C8ccd8dMHgVzutWhUkrLXtdhUjHkhG5tSeBtGeV75tO+VMgCN94B5Ay2PfHavl7xLoWlrfedp8 yefvLLFGWcADO4Y2445OPY135biasqrT10scGOpU5UE3Jb/ienW3iC40HTdJ1GzsbZmIxvnR1Uke g98dOM5FdtpHjfxHHIlxarEbLDbkjjwjdMuuRlc8jjuK48Rh4zjJzb1bXl/w53U5qTULaWTO10z4 lDUr2KzuoolVh5YfeV9c84x+JxyRngc91c6hok9qkJ1W2WNgfmF2q5JOCN27IOecE5Ax6E149bD1 aM1CCbW+xu42TtscPH4j0ewumtJdVEkKRlYnDSyBTkOAT0C9eBnH0FaEHizw2l/JG2rKFZDlmt5V CYI+9kAYOT6Hg/i6tGrK0uR3sKCe1jOufGXhxHt388F2zkiPOwYJJBYjPPH48Y5qlqXxJ0izhcWw 1AtsO6Jo0YFjjIG59y9D04HoaSwdaco3Wj7sJPTU5bxH8ZfC1ykkZ0+5a5WIOPM8lPUZOH5HB6+n tXmOp/GXR7mGDyfDbbYCNjSXq5GSWIGATj5unGePbPp4bK6+nvJfK+5yVMTTguWWpJF8a7K1C3MH hSLzwmGIn3buR7cfn2z9S9/aR12+ttQ02PRLSFI0I2yrIdwI6D5hjoP8a6Hk8ptTlVvbyOd42EXo t/8AL9TkfCvjfXYdYlvrPQbdbiWJQzR2jbQcNjJU5J+pPK10eteOfHu/RoLbSpgjutvbMtg/zuc7 Rlxgk4xx6HsCa0qZdCpiY802211fkyo4yEMO27b7eVzyfVfjRflGFzqcZnePzEje0hO9Dkhvun0z 1zXn3iL4ptrdpbQyaizXITyw0UOxEB5IACgdSB0xkHtXq4XLOXlaWi876HlYrNKUbpbtdjlNO8TR 215FdNeSsc7mIOCOOABmvQtN8XHUbuOK3Eyu2SCJDyVXce/Pb88mtcTheeSaWgYfGOnSbevUsX3j g2c81vPFcSKoyx8zGOeT0PcHA46VS0/xbbSxwyRWU0cbKARvx1we6YBA4HX19q444O0OdWszqljX Kbik00/yNp/FeiW8DS3FjP5Sk4LXyqFB5z/qs9a868SfE6SZ1Oh6SsFsRgvcNvaQ5++oATavPQ5J 69BXRhMBKvU55ytBdla/zv8AocWLzF4aCpwXvP8AI9b8B+ILrxH4Q1HUX0Ozt75Y4YVmjeVtjyvD 84RmC5Cq4AbeP3z91Qr0qSaI105upQJI1AMkkZw+R/Dng847HnPpWNLDr29ane7i9/LT/MdfGV1T pNO3Mr6d9Sa4HhqSCV472DeEIAVlDLwPX9KpaHb+Gp9LsZ7qJTdNEpkaRIwS21dxJIzn3/Wu1UWo 6Kx588RUnL3pXO4sPD2lTqQHRUDZKiQA8EqcBSB7fjXQ2+iaNHqdjBZxIyiKRywYMP4T3PtjFZSa baFzS2bNE2VuJzF5SByMqpUAnHpx7evP4VoW1pCrxqURSc5BYcDn8uR+ZqG0yVqcreQBdX10xMuC 8eBgANmJfy7fnmsiS2lWYqys3IwcdB/nitlLb+uwmRtEpVY9pJXChV3cLnPtzyTn171jW2nRI+oh Iw/+k5VmUf3VPOaq7sK1iUafE6TRNGCrDbtPBxkHHr25/nyazpbC3twwX5XJJ2jcRg/ywMGrjLoO Vrq6M6108XurrblSkRt2kIUnlw6qCM9jlvyrpl8LWrGQPE/dmO9sKenGP881UpuLtcLK9uo218Ja dD5zZYS+pk6Y44B5xyR+XtSapZ2dpp1zczTHyoEd8SvwSBnr24z+tZ8znLbUSSR8yxfFWRtWukks BJpiSYB2jftU45ycHOCccda7ZPiP4elgMSXLxIw2iN4WO3PX7pPJ9a6KuFrRcXDUxjiKTb5mYupe MYY0t0sdRW4hJG7dGy4GeR25wTg/nWhb69oD+YI9RQF8Ft8D/Kw6c44x/T8plCrFK0PUtOEn8WhN /bGjhd66nBgAHcUYcgnOeR/9eqVz4ohtiZorq1lDDHfj26nn9KmHtHpKDG4r7Mjnbj4iTozLDZ27 nOeXIz6c9qrf8LH1H/oEwf8AgQK6FRVtX+BDdj069WGOawubaVfMUjEePvgseR6c+/f8a+h/CV/f Q2tlLKrLcFfM+QKzA5HQkg4x2HtXLiOVRpzZ7eDlPnqRW2h6N4m1m1v0WSK9ICNhNpA579OpJGcB cYP5+dTTfbIGvJNzTIpcEOdwJ4HbPykjqc9McVhUXup2NoSfNKMdVY4O+0O4FzbTI83zAgKuSMZy D0/T61y2u6SY7e6xC7TDYSeec9PTI7VnGS5o7FNe41/WxiW1lPLPIk1hNJuG9FUtjoMjnBweRgn1 FPvNCt3jCw2DoGQhsLgkngjP4/rXS58svckrdjDkVSElOLv3DRvDsSTzSSo3mbcKgBII5AA6e3bv 3q34ct/s+uXMAgYqMHaoADZbBA55x657fjWk63NCor6WMFh3TqUuVa3PYrZIotUmMkiQ/uNyxpnD DJyDwQMbu5PesXVtL0ycvLtmlDbXBjEZAK/dycgdQcEV5kJy9omnbTc9CcE6Te+rOZ17+x5dEbNn eGQL0xH8vY8FT3AHX1ql4UTRpNIlM+mzuScKrED8DjH4fXtXU/aKg+WS+I5afI66UovWL7HV+GoL NLlTa6N5ZBIBY4bqT6e31OOtdxdQ38toGs4iE2ZKMSuOTn5uR+QArzMTL98nOVz18NGPsXFKyOa0 95VdI7uIoqE7s3BwAeOckHg47fzrbNzplzA0b3CcqNx3kZIzznOfQ9+vvUVXJNOLvbyNaSi42l+Z a0fUbCLVfJ8wXEGfk3I7sWyBtBOcn5QQef1rS1TxE+m3N1C8Ij3AAYIzhmbbuYjPYY5J5wAMCso0 3Oo3PRtGlV+ypKy0TOev/GFjarNDHp8kkTDaHaMMHyeON2eePTpivK/GGtxrPo80cDsPNcZdNqYO MYxyO+PTHeu3AUXGonJ73/I83HScqbdrJW/M7/TrfzY47mbT40tyigqxc7x142Kecj6n3rrJtYso 13DTFfC4UOzvzkZOOOPY9q4616kuWMtj0aUFGNp6GzZ+N5NMtQi6RbxQkkhSqlQeB2bOcjsQea4W 9+Iuppfq9usm9GUrsgh2FS2ckEEnoMD8+lVhsDKrUldt/eZ4qtSpxWuhXk+KPiItqJu9RMNrJIY9 7wxR7mJXBAVeTwcDnmvJpLy6kvV1G0tUMUgLRyRv8pXjDcNkghf/AB78a9bBZf7KpNRVtFf7vM8X G4+g6UbO+rOxTxZLZ6Hp1tIxaUtiZEUhjyMAluMAADOcnPSt7SfiRHbWJ+xJJnd5eMhNmCRjAGT2 7+vSuWvlVWUW27Jyf5+R1Us5w0ZK15Witl5efmaNn8S7KXUntv7PuEnEO6MrKEXk4znHbcPzPNWr rxVbXCRoNIk3B2JYXTAtknkgA/WuB5fKlNJy/D+u51RzenON4Qeumrsco1xJqEgja1eNZP3ZeNvm jB6nO3H4dP0q3rT6lpNpcXka7iiFsSqCruOATtwT/wDXrqVGDahJX8zjnmFWLco6Efwr0Xxb8Vtc 1OwutRSysLG0M6PZwASFyflB8xmXH3j90f1rPsX1e88LW13eyC5n+wCfjC73Ck4AXHGT7cD61eIo 0qTUKcdravz3Oejj8VX5pSla/RK3/BLuo6DbS6Vq8xtYXuvsylHeJWZABztPUY5xz17815rZ6IzW N20MmyRWchVbhjtX8B0/T6VNCtUcWpyur/oVUiuZS6vr/wAOY09k8AS3mmYAMvyk8AZwcc/jn3/P j/EkSWV7oMkG47pygYEfLgBv6f8A669LDu9WKvun+R59dJQfy/M+kvh7FFPbTORufbggE98AE49i TXsupw6TBZ+G1u7FZFTSddv40Lt80lp4f1W6RuCPuyQo3OPu9MVwUYJ5lTi9r/ozpqvlwspeR+av iURyaho4hRVQ2EcY9WI3oTg/7vtxj3rl1h8sBQoKLkcADgf04r6XC6QszxMd8UWvMsQxrDcJMIw8 eRuXOC4HJGe3f/OK331K2l2eTEI1DkhCw78dTz2qa9Bzlzx+4vC4yNJclRfM0LzVYo7/AFOdZg1o 8m6LziANpC7uOO+fyrPHi7dHJDp+mrPOWISQDbGoPrnv1JI/+vXNDAucY8z5bWOmeYwp83s1zXvq Y919ouHW71e43kH5IIuEzxwAevTr+NYOqM4RkkcMSpJIboxXKqPUKOP+2lelCMYR5YrRHlOcqs+e Tuz6k+GMAj8N6687OsdrNCwjQttk+aMDcF64ycbuBnPBANeueILUx+E3MQwphiyETO4llxz26gYB 5/Svm6ck8ZV00Ul+SZ7uJVqVP0/U6K5sNO0GLQ7XULMytdSrb+Um1iDtyzYLA7VwNxx/EB1Iz6Wv g3TYdjJYRtHjywvlJgErgZ6cce45HpWs5yjy66M54rVrsccdEth4g8QSRQKDHIkSooUInyR5APRe S2T0P4CtX+xbRW8xocrsZQUBwCBz9fbjoOPeb7Pug5dTnb/QdNRZZGt5A8aGQOHcEkckYz9O3t7V Xt9DsriBHuLINzjcd+c4znr9fyH0oU21zC62aJX8Hwyq0ltNJH8xG0s5KKMjnvnnHJ5xVDXPDNtB pk88NxKWBTYxmxtzIucdDnng5+nTNXGo21dISVy7F4T851I1DUG28EvORyQefY5AOSTx09auSeA9 OhkmMV7dq79jOx3EYwe5zwB37+1JT2dkO34GDrXhd7Kyubu01a4S5WNiiuY2Cn7xJyv9e+OpxWFH 4XvHX7SPEE5Z8Mm6CEgZHHRP54z+laKouVPkWpLi27oZF4T1a0uvt8WuZlETQgywR7WUEdQpGMHv 1/Orc1n4ndmC6taEYJObSTqMY48zkk85FJzpvVxfyf8AmFmjnrGXxHdzX9ot9YI0DiFMWsp831P+ t46EcnqPesfxNpPjO60rV4tUubF9N8iQuqRNl1Ct6txz0/D61cXSVRb3XoS+ZxsfHUexL6RFAVeO nQflVmVQ4IIBXOen6fnXtHlPcgMYO4CRsEDBOePzqNxcpgrKpx2IK5/IihpPcaly6jEuLiFseQWT pgTOP8P0NRvqLoGjNoQPukHecHjHST2NS6UW7pm0ar2epSm1BnJdo4/+/U2f/Q6r/b1/54p/3xN/ 8VS9i/5n+BTq/wB0+y5VMMUUl3M1zcPcR7I1QfOGJyOuVKnvg9c8Yr3XwM+qwyOsMZA83IlUAlcK MAE8nHXrXh4xxUU3sfUYNNuSS36/I76/i8SG3VVtoI4IT5aNtw3f5hsBzkZHXoTjPfA0yLxDLAGe /wCWz8zqcKST8vI4BGDjvgZ6VwutF09ddf63OhUXCq+VvY5rVrDxPNcrBFeXG08F4Y924EDjPAzn k9+frXPT+CfEEkZAhuAoBLs00ak8YAPzk46kf730rSVajTSvb+vQyhTnK+5gaT4c15NXjW8EqEKU 2vc5DDjHAyD259xXUz+Gb6dRD5sQ4IOZG4OPQDA6fzoqVqammtrdEa0YScJKXfuV4/h9gB3vIt/K cv8AcJGD9e46+nNZWl+Dl0rW3uWkheQZO3bncc8DCnAP4ccVaxfNCSSeqMXhrVKb63OqljWK4Se9 huNvzbVCBUXuVwDk9uSegqC9vEulEK3LxRhsKkNsgyOoVhgcH0rlvs0kzt5LwalK33I428ttGS1u oby9kALFt00iBQTkDPPGM/hjisK0Syitt9oPNiYEeZDllcDg9Ce+c11RnWkrcqS08l95yShhKT53 Nad3dm9b3GmRxrNJpTtODuZnKqW/hzywxx6cjB6Vqw6zp1297ClrLHPBZm7kKlXzEZY4t3G7gPLG Mf7WeBk1MsLiKkviTfb1LjmOCoqyv32M/UfF/hnwxpd5rF/8yRAPgKzO7E7QADwScjrx1zxVWPxd Fq8WlXFn4YMi3MD3IcFUUKqAgMQOp3hR2zk9BmuiOTYiUrzqJempjPiDDKNqVJt93Zf5nV6D4juZ obWTTJBa2MqjC/ZgnnJ1DK/cEDcO5HPSsnWrK7udc1y3u7y4eS1vrmzTBzvWKV40bHIGVTOB6nHv VXAU8JOM/ibT1fy/zOSeb1cTFxjCyTXUYmhrCU86S4lXZ/Go/XYFOc+/4emF4q0nWIfC8fiuOCFh Frkuj7ZIYSkcYtLaePgru3FnnyzOcgLgDBJvD0oSrRbVl5X66f16mNXG15QkpNO/dJkOm+OtSsRJ aX1jazwgbkkt3mQOxxkZLLsAAPIXtjBBzWLZfE7XfDkd7Da29jdySTNMk9zFLPJbKRny4/Mk8vYP V0dj03c16VLC4aMuaFFfP/gnLUx2LqJKdV/J6fgdZ4a8fa94l0DX9f1G30p2s9WsIXddCsZDDbzQ aiWUKIS2PNhg+YZK46gM2ejg8Y3NvaCOLxJdxLKN/lw/aYVkA4J2kKvGR0A4Ix3xhiPa+0lCOiXR WXREQlzWm7t+epwfiXWLzXIf9Ovb+4dJllRbiQNz5gZiNzEqSF6jrxntWJbT3Nlb2tlahzbwosa7 5UG5FUKB/qT6dc/hxRTcoKTb1/r0M5xU5K6N4add6tZxzCO3jjkjVyDLKxIIHdSufX/61Lpui3Wl 27Wz3kXl7mZT5LM3JJOWZiTg9M54FJ1U7pjjFR+EXQHlh8YNbTT+YDp5dRsjUBmkX+6P9npnHWvV C5G7C7WAwFPtwf8APPWvOxatUST6I9DC2cH6lQ3C27tMqjeH3Z24DbRnOSPQfrVz4lStFpNwsh5Z kBLHOecn6Z6fU1zx1nG5rVsoSV/6sd/+yJbka58RJGyXjs7RckHBz55PUA5yvI6cV5Z4SYQ2kOmO mJI5ngKjIwoLLjHGOQRjFGL15reX5MjBq10kb01wotr6KNskosLcZDEFtuOMZP4d68j0YrJb3pYA NlOCfZvr6AGuSjdqV97nfUesVfoYGvyOswkGFygPXpycda4jxcCf7DbacC9yxXtmOTqMe9ephrKc Hc4MQ04zR9FfC9jsYKxELRYAbI+bOMZx04/z1r0PxrLLbTeE45H6+HfF2cLkEf8ACO6inAXPG2Qc /wCBrloXeaQ9X+TNKr/2OXy/M/PTV4s6x4aVn4+xwjhuPmdieR7t+Ga5xAd7KOFbDe3oCfyP519F hZXhf+up42NVuX+uxfjUONhIJxk/0NLJA7EkfdPRiCfX/wCvXQef11Kg0yOUBrhg5yCFxgN17D/C r37i0iD52gZwAPv+w4ovcG2ypvfm+uF4AIjUccnpx+H86yFtzNd+Q+NwKiQseruylj+W0U27RbRp S1nG3dH1/wDBOznl1XX1Cu1sdPueRnaCQhHbrgZx1O09K921nQNal0N4prq2ezEKzRxR2UzSOqgM qrsYlzwBhUJJ4Ar5SE746srfy7ei3PpcVC1Kn8/zKHh+2127vz41u7C2uLmdQ1qhneMQwgYGBsbD ORknryATgDHotprPiO8tbe+i8OQ+Rcwx3Mfl3yhijqH4V0UA8+p6Y54req1zr3nZabdv61OKnde9 bzMLGvWt/rF0vhm48i4lEwjSeBiu2JFIY7geSrHgdl71dk1i8SMW9zoF9HPJG0wQxoW2IVVjgEkA Mwxkc7hUtXd1JP8AAp6atHLarcz3dncRx2V20jIV2/ZJiWypA5C/Lntzzg1q22p2Nkiefb3CRRqq 4ntJ14IHGXjBPGPU8+9U4NpJfp8iLtPyLKavoNy3ly6paquMgtOvznJ+8M/eyMHPbHTOaw9b1nSZ 7K5tLfVbWSQtGXCTqThXBPB9ACcdhz35XLNNXi9CuaLWh048ReHSR5epW/l7FZULgFxgjcecdQfX pWLq+tWR8X+FLG01FTZvp2oSSIs2IwwkswjNjhiN0mM5I3HBwaqnFt2kns/yIm017rOO0q9Y/CnS bh7ks/8AYluzZPPMKg5J7bvzrpkSGK3hhtyCnkoMdWGc5GOwGKJNX+bFdWXoTSTIsMqSRktkZ2dO o7duCccdu9MiNpteNlUDH3cZzjOeuMYJ9TS12TK30SOD0KCKHU/ETPbqx+1yGNuo4JBHI/2uvvVz xDLFH4a1R0TPl2cw4BwMI4GO/wCP/wCutnrVt5iWidz8+b7bFrOoKOWDjGVI5PHH8qsbgcjj88Z6 4OfpXu3uk/I8iafMyPKxlmA6/l9aPlK8MTxyMdPpTtYnaw1wTt3dR2z3/KoPL43A9OcdM9P1ouO+ hCUQj5sFfpjFM8qD0H5f/Wos3sOzZ+kY8X/D+0CmeSxxv6iWJto74IB4zzg8DArct/jH4DtIRCL+ JFAyNkMjLnHX5U+o696+SnhsVUio8ra/rufZwxmFhvNfmVpPj78Pporm0s9XmmuEOPLWzkx2xywG f89axE+NvhGGG7WGwv5ix3RkLGAGHTALfKOg459qiOW4nlcZJLrq7iqZrhk7xu/TQ8z0j4/af4iv DJ/wjd7b2bA+XJdTMitjJIXaGz0A69SAcda6C9+JzyWjyQ6PIkwjwA15uU4Gevlj/E5PSu6pgHBq EpJ27I4f7S3lCH3sz7Tx/rV0bfUfsNqZdg8vdAHKg46HAqa48W+IblppkATJAHlRdD3I3Z688k0l hKcX1dtNdiPr9Zqystexi3XiHxGwZ/OcEAMCY1GD17gfh9e1fMM/xM8d/wBr6hDqPjC+WNZJIj5U xToxA4TAzXdhcLQk5KVNP8Tmq4zFNq9Rr0NhPix43htHt4fF08lqxPMmWkGcD/WEFh90dG/nmuf1 Hxrfai9pLq2oXlxsU7PMlZ9mT8wG/p90eldkMJSpv93BI5pV6tTWcm/mYGpeIILq2aKGByWYfM4A GQck9ea+kfhnqUI8F6PEyXDXH77akcXAAkbHJwO470Yik/ZJeYU5+9qdudesL1pAulXhuUIVhLJA gZ9oyPlcn07dc113w50GXxR4n8S6Z/ZMZuZvCl5FaQpdfNLcLd2EiLucBVJ2cHPGSeOtcVKMabvJ 7a/drqaOTlGyR0t18BNfl0u5HjW10zTNGlJLS6rfLsYDGB5ibgcYHIOfoK1fD/hHwrGY9PtPij4N +wQqqr9h1y3mbAxgLD8rg9sEfjmvWlmOE/5dQlP0TscioVLvmlY3pb34SadcJpk3xIlV1+UmLwxq ckfYYEkKMvOD09K4r4haxpep+NPEV94Z1Ga40G5lSWKTymhErNFG0p2yKkq/vWkHzAZPPI5Pn4iv PESTlT5YpPdrrboteh0U6fJ1u/Q880YSfZ52kvrkSiZxk3UrAgSEKMbucDj9e9djo2reGrTSde0P xP4bOs6XNdWepW1m+oTWaG4jS5ikMs0QMuPLkh+6OSnX5RuxT5ZXhZP080y9+ly7Frvw60ywutU0 b4FaLaa4FZk/tDWL3WrVwoJC+TcLGeRx949M966C0+J+swWkb6P4T8K6Nq0qBxqnh/w2lrcJkf3Z pJ4sdD/q89OfQnUqy+OrJ+nur8Lv8QS5dombrXj3xz4h0iLRvFHi641K08wyK09vZREFQQDm3hiL YxjDZA5PXBrynWprVL/S4jPGZzFMNgPzKGKf4Y9vpUxjr7qsvm+nfUd+5XaO3ba7AjAy5znGPbP0 OOmfzrEslub2xtL8xqLeaFZfLjBBQOF+XJPOAeuB16V24ekqvNzPRf8ABOXE1XSjGy3LDXerWlvB FHdyC2hVVVSsZOEGMcrk8e/r+NzR9Yb7BcQ3Du95Gz+bF5TZADZCkgBeFI57ZHOc1pXoU4RvBa37 io1p1JWkV9Nv3uvG+g3B0+4jR45k3ShADiNyD1J/PHXpXsz/ALwjdKcgbjzw3Oe/4e/PTFeLjFac U+36s9fCtckvUYyAKpB+TBzlh39u/Wus1/w4vizR4Ct4I4nVZgxAY8qeOfUHPrxxXEp8jjJ9DplD mi4nrv7Lng668O614/WeWKYzWtpsZE2BQPtQ5JJwTnPpz2wRXzdocvka54ktXIVU1e5AJyQmJmJ/ QZ7elVXcZqUktNCKEXCfK9bHh0iafrUk1pqen+f5vO0XU0KsQOuVyQPrnrWvZbNHJSEv9mKIvlyy bthH3SGAG48kc+tdE5KS9m16aExhyvniZuuzCRUKbt205DHpyPp61zfiNV/ssXJY7o5omGD907sZ 9OQ3t/jdGynD1FWd4yaPe/hWrGzimHH+qzggHBYnnnpyBx61ofE6+eO80DEmBD4X15zyQcXEKWY5 A4/15H1rnw6TzSKfn/6Sx1v9zfy/Q+J/EBEeuaAXHzC2t8H3BOePY/57nIuEEMzQAEOrMjHnrn/6 xr3sM9LeX6nk45O0X/WyJwpdPNj+UggHAPB6H/Oe/vUsd6MsJkx6nr2/n3xxXSzztyO41BFIKgnO TgHP5/57VBbW8l7K08zEtxhRngcYwOn501pqFtLl2SMTyjcmLeEFvYnGTz+H61Bp9uZLqCWVCW3i VsDn5nBwT1/g6VM37kvRmtD+NBPuvzPsT4CTJJc+IzvHkG3lb7u4MBEegxwcDrn9cGvorV3j/wCE T1eSOV9iadIHeEFnQhGBAwcb+PbnAyOTXxtLTMMQn3j+SPqcYr0qbv0f5jPC1rHN4d0KFBlvs8UJ Khc8ADhc/lW14XjX/hEvDsu4h2sICASuR+7UY7jn/Gu6bTk/U4HuiW4Fs1wsJmLTnoqc/wCA6AHI 54/Aw3gD+IfDixyLiSyul3Ag8B7b1yCM56ds96lX67K5UrImlEscoRSirIxAATIxjn/IxxWhtaRG hugCN4Izgh/lHBHbgEdCeKmSdroT1Wxw+jxQT6p4uhEOY1u42XIByTBGSo54xz371tQ2mnmJLeew iyHOBJGpCnnpkYzyM9M8fjWt9CVe+qE/sDQ/Mbdolq0OMhBDDhTwDwOB9OuOtfPPizSNJfxjZ7NM j+z/AGTVWCqpB+RrXsOgHz4+prpw822/ee36MiqlZM52w0TTR4F8MTS2WZZLOz3fM2TlEZj1+vH+ OK719Lt5UCRz3SgjAxdyEA8cYYnNXKTeu+rJitNCXT9Gupby9tI/EVwhit4Zhv2OVLtIMHf7Rrxk dTkc1uL4a1KZmkt/FE6wqMgNbwHIx2IA3Ec/X0z1x5k5W5F+KHqtbkFv4I1OGWSWDxOqiaUuxe1X dvIycqSQfzHArI8SeFvEFn4Y1+SfWLWW3itZCcwPG8vyHIGDzxjH1yaqFSMqifK73XXzG4uzsfnt ra+VrN6u8MV2HP8AePXvn1pVCqN6AsR8pzyTyK99fCn5HkT1kx7Arh8cA8jBz/nrUW0KMEnBPIOa e5KH/LJglvl5wQOtRtHhflcE9xkkD/P+FPrYPIiKkkk4x7Zp3yen/jx/xo0BNW1O+Go6WJVP2t2O OAisc9M9jn/69XhNaOY4ora7I3DIWEjOen3gO5zXHyP0O29zLsVMF9eMdNnKuRgOY8ggYwRurro5 ZJOU0tT/AHTJOF3DuPlBx/nrRKKve4I3Nf1fSn8K/DWy0zUrC4vILELc2yXKySwylIN29VJYfdAw QAPmA6Go4rzWJVRB9ljhx8xEchbOPr7nt2qFBW1TWr/Mtu7dizaLrFvFFGmpOkaIEGyOPouMZyDy eOaiury/ht7lmv5yFjLclQTtIOcgDtnP1qbRvqtwu9yeKSR45ZUuphIpA5uJm49CN3r7VwN18NvD 97NNdzXV2J5JGkdVkjABJ3HAZDxknuauE5U23GKJl725taf8OPB1vFE8lvJMMDHnTEYOByQuMdf0 rV8NeF/DUsUV/LpqR3YkaSFw7bokBynRsggFfxpyrVJJ6lKMU0md3NpGgX0zT6nY211dkZaWeNZJ COMks2SxwOpOetRedpunT21laWErMyP5drZ2sspVAVDMUiVivLLyf73fNYqVSb5Wy/cWpYg0LxNd X99daP4W1B7RkR4mntxAwwvzZErKO2OevWmy+EvFV2VTUvBJaIKRme909gc/7Kzsx6Z6entVKPLq 5K/rcm/kRxeA9Y0yNzY6bpVntPzrLP5WwY4JMcbLjnqCetYun3b6drmvW2qXFrDPFFDInlXYaObc mQVYqm75SAeO1VK7T96/ydt0JaSWhZTWtB/s6wlvtZ1P+2Ht0nkh020RxHuUHAMkbqeO+T70+08R +GYxK9+mvXSHhVupLKLJz38l0foMdPT3rojhZvVRVujd2Q6mruyxYW+k3sd5rGneE2ewgdi7N4ku YnlYKZHCQu+ZmVBvYRh9oKltoYE3bDW9I8QRPJpOi20F/FeQWwCSAsyPFdOd8gTJwbccfn61nOm1 Gb5lpukv6/rQIvVHr/hLwr4I1HTZ9T8da/raXkmtXdjbWeii1MUtvDbWMpMhmjMmWe6cAq68L0G3 J63xLrn7O2gJaLdeDLnyreEBY38Q6gkjYGAxijlZCTjoTjp2rl9liJ2VJxS6aXf+Rq501v8A8A8M 8X/tL+ELq6g0/wAJ/A/wvcRwsTHPqukQ3EnBJ3M/ysOxLFu3Jq5pvxW1j44eEtauPEllaR2Ohavp tlp0NhC8EMQubbU2kCKzs20/Y1wCexOBnA0eDlSj7WpWlKS6X937hKqpS5VGy/E4vVNC0qGCRrbS 4x+8Uk7QTwQSQWyD09O/41qL4u8OaVp9nplxrdnbtBbJbEPIiOPLQIVx16qRj2wfbbDTdpJmFeCa ieO6n8a9Fs7O6i0q3a8umkYxm4tkRVxgA5GPlPzMBgnnBxxjtvhv4jt/EGm3GvX1t5UDXZE0cUio QFWMYVtpwSOc7TjOcHFaV03S1YUYqM9Eesnwvoutap4fe28V2elmC5WSWTUZbqVZVyC2z7Navt4J ++ea6q4uNABgj07ULqczJu23FnFD5agsAdwmk/hCk8cEkcgbj5WJpSmm1pyr/N6Ho4eoo+7/ADP7 iONHK7l37QD94ZPGfwPU9z3r1fRYVTSdLVWDILWNdofO07QMEn39zjB615M7WTR6Ub312PqD9nDS LbUNR8dA54srly/HWC0nmTj6/wDoQr85bmeODxJ8QkGMprN2Fx3BmkXt0GO/860ir0/kvzIVvbu6 PIYmeO/ZwAMHOc9CAfWi+k3qqNKBtkU71HJww7fgea6W26isR/y7aY+5lzBI6AYAJJJweQOnPsR7 enWsjWTb3GkXRZsOojbDDBHIYgHpwR+lXTT54+TX5mU7csvQ95+HDr9mEdu37p4oCgPJZgAwA4HP B+npVv4wvawXnie3tmj3ReCyyKGKiMvremRke3G8fQj0rLDW/tS3qOt/ud/Q+IPFBiTVdKYH5fs0 WRzwe/X61TuCZLu62Al/NcA+pDdf8/nXt4bp6P8AM83G/An5/oSxuoKttxGTjHvxj/H86sTWcbsc qRnuGxn05711XtseX5ixaZEpQhj6n5unTP1qSWUwhbaAAyHjjsKNW1cLtsbcRFUithy0rDPPVRy3 0/8ArVb0wK920pUBXn2gey8D+RPXvUVf4UvRmuHf7+n6r8z6h+Bl9/Z1v43EkqgyWDwITu5c42qN vBZz+7HIH7wZOM19E6noOjtpttqUthGNi25MqyeQR86/N5qFTG2OfMypGOCCMj5Kg+XMcRZ7uP8A 6TE+oxvu0qfo/wA2ReDfBXh+28OaBcW2nypdG3RmltppoC79cgq4APQ5x/Cc4JroG8I26Q21lp95 dW8EKeVEgml2qMAYA3dMDpjHTGMYrrlUld81nq/U4YrRMojw5qc93e/Y/EcsKQzBULxLMdpVWx83 BwcjknPccczT+HteiuV1Sz18XF3HC8SfaIEVf3jJu4iUcZQcHtk5PdRcXo42+Y7W0voUr268U6Vb 3V3cXFlJ5cTyFRBLucKuSOD3AwMDk9fay+tapDZoBFbmVgATuJJHoQRjOBngnr9alxTel/68xXlH R7GVpNzq9nc6rfPYwyrcXImKRyYdP3axE8jJ4Xdgn+L61fPiR7Qxi50S4jtyVUOghYZLbQBhskk4 7dwc8HFWevLIFLrImuPFOkhJGmiuI2bkH7NKRjrkbAc+nrxXzz4n1mwGsafdvdhWFjrbZ2GPO4wM m0Pg84z/AEz06KEZN9/+GZFSSashbO/sn8GeGLWG+gaeOytAUWQbgdkYIKg5AzwfTFdqz7FeJSpm yM7cEHA4xj24/UUSb0e2/wBxPTQqJHcDWdX2X6Wv+h2p3tGrHKvOAOTgjPPOOw+vdaNLBBb29i2s JczgFyzuNzITntzjHqT0+lZSavdR7fkXHzOjhtFVN0UgVgdzAN94dD39v1rA8ckw+EvEiBMQi1mw d2BllIOTzkgbfx+lKk71Y+qKveLdz8t9fEa61qrQNmIpH074xn6jINRWwPyrycgtj344/KvpI/Ar 9v0PGqJKci2uWLxliMHA9x/U1CM/MMflxjt0NMzEEYRjwMBcklepoLgkgqM5PGMZ70ANY/NkDCE4 wD7UbE9W/wC+j/8AE09eiHY7W6VYL3TJdoO5pEAHU5Xd/wCy10FpqDCSIsm4K3Q5Ab24I/8A1/pz OzSOwjaUBxhwdx6KSRz0H6V0VtH5xgcqR3y3GRj0H1/nUS2uUeAWzvZePbmzQKI0vpvLIRdwLAgf MOeeMLnGT0ya+kLGZJbdZdh28HPAxnrj8f51dbaL8iIdSUahZQsqzXkaNz9+QKcHtWRcalY3Bv7a 3dpHlidFWBGkyD2GAc/X8PWsOVvWxodJ4P0+31rxj4P0PUTcrpl3eLDcrFbyJK4KuQoZ1weQBxnn 86+27P4U/BMwNHd/D7UbiRduXmv9RhJJ+bJ8m5VR7Y6iufFVp0uX2cor11ZpCMWveTbOF8V/Dj4V Wlna2ug/Dy+h1i+uorO3Y6zqM2xSS07KkszKSkCTOMggFOQQMV6bbar8LPDsLWMXwk0JkwUb7ZY2 07547zROw4B79h61xPE15xSjVu3d6Lp+HmaqCV/c27njPxMn8Ca/4U8XXug+BdB03V7SK0uobiw0 20jmhZb21jO10RcAozZ4Gc9cEivDNDt9btvEV29jqNw+oSaNNFCYlUEHz7QsqhApb5d3X0r0MGpb V22339DGd91+HzOg0vwx8QdcuPsjanJbsNrTs95cfuV6gsCxA4529SMYHIz2mmfCrSbhGudY1W8k tIyoAeUNJcSfISQWQsq9RsGcZHzZyT6t6UdIRTMkpN6sp3PgHwzrWqRRaTNm2UkMmJpmjCgk5LkI QcEn05pz/C3xNqesz6XoHgzULqEQRRRvb6dIVlIG35di4J4HqeOetc+KqcsY87St8iqceaWw+18E fEjSrrw54H8X6PY2EcKTZsda1TTrC5jDSSosmLyZSgWNo5BiNxl8sOAK5XXdF8Hf2teaPrnjzwtY WKOXW6ivrqdvLHzbPN02C6gdicqGGcqA2zNVDFJR/dXl6LT73p+JEqb3k7fM+Yrrx3q/g688ZeFv BGvWV14Yu7mR4dUht5izJIF3RxzXNvBOf+WaNuhjBaPcFC8np/hdqTbjHqN7++j1izjlndgYyFtd TAIY4AzkDOeTyac4JU5Ta1a1/rUIt8yXY7/4h+KNQ0nQ9Zk0fU1Npb6hZrK8EwOXvIbgEZXOOLAc DqAO1fNUWu6rqupLKkMlwQRI0QLMJBxlTg5G7OOOeaeGsqK7/wDAJqL3zGvNT0yPw+r2dwzatcXL JKsi4eKBVUgZBwcsxUnC8IMDlq9g+BOtXKaP4i8PWuGkuNa0y72MSBthtdViySATgNcoOB35orJ+ xnf+tUOnZTTPcpbfV9SeWFrmGO0CGNWWJi4J6DnGcgZJ9zweRXmWofC7RtQ1fUL+91W4Zp55J5UT aoJdtxCBgWxktjknjNcVKpyXcUdE431Ops/gJoUUY83T4nbu73ExwueCVHfGCff2rsY/hzpFhZtb 2iQJbqwkWOOMsqvgHPJ6jA5PPA4rmqZlzPlSv+B0QwWl5P8AU7/xv4I0u8tPhxrt1bGCeTSLOSGS AIn2o28cULb8L8/+rGSeWJY9Sa7nVvC+jWXgjwd4osdOaLUZ5pLWeRpbh0dgpkGFdioO0gZVVzk8 c08RVnKdeN9EvzY6VKCjTkt2zkgSu1HZVRW4PJ7YwR+HQ16L4RdpNAtjM+XDy8jPIWR8Yz6Yx+fW vFqaLU9OK95an2X+ye8Ty/EKRsHbHqUR5Gcf2ZkdP97p/jX5daxj/hYHxH03JydVuDhQxPMzse/A 5x9PbNbU9YS8kvzOf/l7frc8uJCTKSCq78HqR/n/AOvUPl200kEMkoSFpE3SEbliG4ckDrgZ6c10 Xd00J3cddjrryz8LafZwn/hLC7SjYI49PnDuD1ADbccdDn144ycC9t/D50HV7pRqZuVhYQPItuIy QvcCRmwemMA+1FKVZtScElfq/wDIzlyapa6HrnwqkdbOwkQjanlNtbjoVT09GPGeSB9a534r6m7e M/iRBKoW3Hg+zh3D5uX1ezl6+p2H8RjpSwt/7Uk30T/NFYi/1NeqPkfxbEkN/p8xlJV4UbgYCFeM AjntnvyfphhcreX7LnK3DHI7An+mf5V7WHd3Fvs/zPMxa/c/NfkbdhouoaxqGn6Po+mz3eqXlxHZ 2tpbRPLNdTysEijjjQFnd3YKqqCSWAA7V9meEv2NtbNvc/8ACbeNIrLUlPlw22j2ceqLFKkrpLFc 3P2iG3UhFjkRrd7tSJhuKkEVWJxMcPDVXb2W34nBSpOq2uhu6p+yP4fgt5/sfxPmt9Ud0S3i1bRm gtNhPzl7u2muHGxefktm3Hg4xXyj4z8Aa38MtYh0jxt4XntdQuLdby3kN5HLDdQOSBJFKilJFyrI SpO143jYB0dRlh8U8R7ukZdviuvJ6fdYqdFU9bX/AA/Q5oaloX9g6/r0WgAtZ3VtbRO11IWPmJck gYwoBKKTkE/KMFed3OQa5aW8lnFa6Mowhb/XueeOufx/I10OM5U5KU11W3/BKpKMatNpa3XX/gHs /wAKNfuL/UNQtFthHb+bZsWjc5BF1ASDk+gPHvX2dbXOpajYWGntYWvlu8ceZm85SgcbS0BC71Zc ZTcM525x81fNqmqeOqpPqn+CPosTU9pQptpdfzYeF/EksGj6ZapoN47pGAzRLGVBzjn5gcfh7V2U uvwC2srowXflzIJUcWc7Ky4U54XqABkjOfU1U4NSkrrdnImkkZdt4l0a0utQa61CGCGSZWRrhvK3 YRBwHKnHy+nXNa8WuWV5lra7ikwCVCbT7k/Ln+WPTtUyupXasv667D0WrOY12aOXS9SxJjET8I20 k4PP4ZPPWuZNx523kYz2H49Oh/wParjLS5Enu2bcQHl/KMyjPPr7fWquoTCG0hZ0URtPGr8/d+Yd e3YfrV9VbqLo3YhlKThzF1O3IYk5x7D69T614f8AEmNU1LT90u7/AIlGs8sxOCI4OD69PwxjFa0L c+3R/kZy6s0PJUeCfCc0v72NI7NShXIwDHheTjH+PTrXpGveA9CfUpZILVDI0azqY8mNSyq2AOwA znnAOeMYATlJbef5jUdPuOC1LQbSDUja2c5+0xIVwC+9z1X5s5CjJB7jqabD4P1fzJ712EcaoQJT NIZGxkgfNx14xn2+qc19pajt0NLSLLX72KHUh4hlRpflAUKy4VsDdkY9+/T8pPGUniSPwbrkUut+ darBtkV4l3EcKckcnqeT70U+T2i93r+o73ifn1rkT/2nfFVxGYSDk9w36VRtn/dRnZnnIwenT39a +gg/cR5VVWm1Y0nDkbwvI7nrj/OKTk5kUZC4/l/9amZdBHGQIxkqBnnP4/0qNlQYCuCmc4/z+VFw 9SDdIcLtyOgH+yf0o+zn/nif/Hf8KHvox6vY7i7h1GYxxPaRxSRyZJMrcYBBBAHynnn3p8MersQI 0jVBn5nDMM8+4/p69KwfKludlivIdYW6t4/taRrIpwVjGRgDjnPua6uyt70wjzdVlZjjiMRqfTqq jrioly2VkC1Z5/qmgND4tQlLmVZo2drt5clX4x2HQfKBg8Eelel6Vo2nywtvtleTOG34YryfXp9f 8Kc5fu00NLubvhq2tIDfBIVAW4bgoCBjBAz1Oc9/XtxXRTpE11FghcrhsdADkEHA/GsJO8rstaId pU048dfD2S3kIJ1+wiK5BBDTonJ9wx/Os2X4vatBFIW1B94bGAqk546DGfw9z+MqhTrSjzLZfqNT lBe6c2/xC8RX13bXFrLcTSRtI8ZXLMrPkZXA4wu4D0GRVlb74r+IZlh0/QdTmlkYBQlmz5J/4D79 frWyp4PDfvJtR82/n1FzVarsk2P8Pv40tH8Zab4jsLqAT6JO2y4iaPf5UsMhxkDOPLB/AV2lnrek 2fizQrqW732oguEm8o4CoE8zqMD/AJZjjvzRzQnVjUpPmVt1t1F8MbSVmWP+E21Z9V1jUtA1gW1g XXYoInTavyqxR4hhmOST0+bHOMj1Xwx8QfEd1oxsvFfiOG1dtzxtZ6BoyKqKcD9+1oZyxOcsHXGR g5zXRKhzK8m9Ol2l+AKbWhyVn8aPEuiXtxaaF4v1945AVATXL2MAMMZ2xyqikewHcV6ho3iFPFEP jbwV4iut3jzV/D9xq1te38a3ItlsGF9IqOzlo5His5lDDAIZhk5CnGrhoezcoQSdm/P3Vd6vXoWq tnaTev5nx34m0PxLDF4ebwz4fvbq4tYbqGe7gsXkjD/2heyJ2ZQQrqe2OD7nzmH4X/FrWL17298O 3M8vUG6uYYscDosjg+nToK1hVioe9JJmLi2721Op0v4L/EaWWG7vUs7OOL+G5uSzdNv3oUlHAGBn gDP1rsPB2hzaBrVhaaj4q0y8CXZkhsrO6WWSILFc5JDBTjMpJwO7HFROtFwlGF2OKtJNnpvizwL4 g+JfhjxP4W8H6V9u8QSapouoG3F5b27G1tYNZSRi87ouN95EvGT8wwpwa87h/Y3+NGo6Nfatrl/4 e8PaLbbfMg1G/l2KBx5jPbxTR9zy8g+8QMA4rGnjKGHp8lR3lvZJ36f1uXOlOc+ZbEdv+yp8PoND j1fWv2iNLkuQ+JbfQdPGqYxnp5E/nZ4PJhAr0TRvB3wI+GmlzXngnxPrWqeJ723S2ka8WO2trX98 jM7RTwxTRttR1BUyD58HqWWauLrVlyQo2j3k7PftuCpxjq5XfkUZdd0lZE8xyY23MzojEIF7tjoB zjiuV8War5axtbQOYt/LIACMg8fPg4/Dt9KmnGXNG5TkuVo910q8uLnQ9JvQiG5mtIZnDHO/cgY5 wfU/XrTb65keBnQDdtJwCOprwnG1SXqe1G7SZ6f46k02b4Wfs2Nb7Fv18JX5vGBA2uNc1aFSe+Sk Kck9AO1ezaJ4C8TfEz4F/CXwd4J0K41Lx3c+N9RtLeyiGJpkXSbCcAB8DYFMzg5xtTjgZPp4i/tc RJ6LlT19UccHaEPUo3v7KfiXwlBq/wDwtDx/4L8HaxYOq3+iax4ktpdYiU8b00+x+0XEg6YVVycf lbi079njw3p+sadpnxA8S+M7i1eGO1m0fS4dAspzJiSXbdXwubkMm/bh9PUE4wcc15EpKUfdV13e i+XVndF+8rHvf7Pt/o8+j+K9Y8MeGl0rSTJcQpG15LczzIUWAtcSuQkkvJBMMUCEKMRBixP5U/FO 01XQPjZ8Q9L8sxzm5nmG/JKmXbLCw3c4ZHDDqOe9dVFc3Mpfy/kzmk37RNdzyeAkvB5i/vsgNjn5 u/61VumLxtx6bT71uvjTHe8G0zSt7RriMF5SJI3fywSSAB14ycZwfwxTtYuBJpctrG4bKMDgn3/n nHemrOafZmbVo+p6r8GY5LpbSBDgfuwQQRvCjPQ9skHjuK5n4tsieLfiG4zvCaHprBmUDEhlnII6 /wDLJT+FRhrf2pP0/WIq+mDj6r9T5j8ZypLd2Q7xvJC2cZJBV/8A2YfiKorIJbyWR7eVHlLbvN6H jqD+Hc17NFcrim+/5nFiVejLysz9AP2ZdHsfCXgnUPH91ZY8Was82nWFzPbkNZ6egEc8trKXxm4c zW8jCMOqW8kYfZcSIft62v7OG0t7a1H+iCNRBGmSDGR8vJ6/Xv8AXJrycY3VxDb22+4ywyShZHnX jnxHeWstvoVtalWkVZJppFAO3f8ALweAAVJJI646dK4Txx4Ys/iR4IufA1/5EmoSRNLpU0koB0zU SqqhSUsFiilYKkobcpjIYgyQxukUm6VSnVtt/X5FzSknzbbH5m6PpzzfC3xtcRx72ttc0aNhnoHg 1Mn68oOBz+ArzOWZxe+dLGUY7iBgjHynoPTrX0UbNVPn+RxxTU4P+tz6T+A99oen63qUevX0FpG9 p5sZnmSNWfYXTazEfNkJgdeeOa+kbr4maP4efRbOXUB9slhWRVWNn8vDKNzIvzbcnd95eEbnoK+d WGqyzGs3FpPls+m2p7VetTeGpJPa918zW8L+JYbyyu7W3jYJbSfZw7EK0w67tuTtBz90E9+TXvnh i8il8L+HzBJIg+wwAEOpCqY02nBz05POQcenVV42k0+7MafvJaHQ3r5WGRo4zKCcHaMqBwMlu+Mc dOvrz5T4k0PRn1S1iGnq32iCZ3VX2o/zwgAjPQB24/ngCoj7qKbvqzj/APhE9B+1TI9gkUjoRviI BPU85yDn06dj61mS6EmVSC/mWZPmDfaXI6fMNuAOuPYAY5xVuT1b1IdrWK1jZ6rcvc+TrcyWscxi ACxNu2kA7gUzj1wQfx6r4yv7bw3pKanq/iAQWhmSLzDbPl5SGZR8hfA2q3OM8dOM1pCPNUUYLViW ibMrQfF1jr8LxaNqFrebAEfypCgJZTgYZcjo5AOPunsK8j+JviGS4urCebSpvKGlaxHuG0A7o4wS CfTZk4zwRitqUGp2lo1fR+jIk/dutjoRrVofDXh2Nopf3MtluYLksqbC3A9QrYHHT1r6O1zxn4I1 zWdW1Tw1ZjTNFuLma4s9OeZpGsIXYlIPNkCtLsQhPMIUttJwM4qJxtFK2rf9afd9w4t3s9DnIX0W WRblBA5X5Q6su5F9iP1z7CrKXVnFG8AkUxkEMMoQFxjGe/cYHHI69udJt3ZppqjktG1CCDQo5mCe QVaQNj1cnbjP+1j+tUr64uvF+ha3Y6PaObiIRgmbaBy2cZHdgr8f7B9q1WklJy0T/Uag3Tc+iPjj xtolzpdrqP8AaVtHHqL6gioqyLJiLy5txG0kD5igOeeB0ryjTZEa3kRgSAxGfTHevaw75qd99dDz MSrSi12RoQOTujDBec+mR/n+dO3eWQQo2dvTp0/Otutmc3UQnYu4rhSN3bA/z0pAX2hlXLHn5vX/ AD/KndMLjWy5wEUPwc+3H+e1L5b/AN79R/jQ7Cemh6ckZbZk5Xr9PT27fyq0IiqDMYJHAywOBj6+ /wD+quW9juKep2Jju9NnGMPNsO3jllbaMd+QP61tR3NtEfLmu4lk24AeRcj25+vX9KNGkNEd5Npd yoiF6GmxlNsbPvx2+UHHTPT+da1hP5SpssrmXjBYRbV4zgYcr6D/AOv0qHdxt+YKxYtodVtpbt7b Svkml3gvMiEHYoPChu4/X1rRe1145eFbNJSAdrPLI+ehPAUe1Q2tm/uLSltYn8IvqD+M/h7NevEU TxPpm9I42G4JexLjJZiOnoa8KXVI4bqWJLHLK5VgqgE/w8Hn8/r9a2opO6T6EO/qdzp9l8Rr63lu /Dnw+1OcB2dLiy0y5kVdwUclUIIAAwOnPOc86snhX9orxRs05/CmuJblcLDLaPZQL74cRxg+55P4 VMoYOLUq8k2trtfl/wAA0TrNNQVk97HZeDPgb8WvBmqat4j8YaAkHh6DSdRE8o1Gylxm1mCALFK7 EFwoyARz1A5FjxHLbC70Wa4Mgso5blJ3it3mMSSWs8YO1AS3zMvAGOlZurRqVVKg00tO2uv+Ycso wtI5a5j8IXK262sOpfbRgr5Vo9uZNp4OJkUDOQME/St+wvdIu7a5s9Q8K6lOjDjz7iFQxyN2TFPk dGONpwe3cdkqs2rXS/Ezsnsi/YXkehyMtt4I0swgYVp9Rkc44wSJLdhnPU7u/avov9njxTFq3xAu zrLWzaMy2tvc2EEqt+5LSiUMcjO5Xx90cD3rlqtzhJOTej9DWn8aR85atqeteDNd8SeGL3V7uC/t NQmtL60SKJkhuYnKSojmMuQHVh98jP64ljrFyZ5p47jWDBIof5tSutjjqDsMpDDoemORxSj8EZNL VL8vmTpcWysLNdVm1EeGtNXzBjeyDeCCxLZ8vqfQenWumm1PVLKyaUSW8cO+OPZHEzFQSqkg7hkg EdsHAGe9TO8tG3YqyWqQ62m1m0nlu7fxHf2Ykt3t2+wztCssTlSyOF++p2rw+fuj61gw+F9F0+Wa 7tbIrM5LOynZubPVihGev+RSUlH4V8+oNNuzLNvBb/2hKk9vG6CJGUOu7BLSFjkgn+XTmuh02RYl miRo0AO7ZtwHJz2H9cdaUhq1jW0TwPrnjGW/sdB8P6heTbGbyNOsZby4ZCdu4RxDJAPUnA+XAzX0 r4c/4J1ftNfFbT9Mfwx4GurBLh1YDXFS1CI6udxSJ5ZgQVAZXhjYF0wGG4rMq9LD2lVlZLz1+SLV Kc/gR31j+z78HPhlr/h/4afHX9q7w7pvju3tkF5pPh/S9W19okVpE8t7izt3W3nPltmGRfNUBWMe 10Zu3lH7F3hC5u9C8N/DT4gfEPxN9pj8iPUZU0SxvImcIGguYFa4G5iFUS2fzFsc4ryantZSc6UL Rld3dtr9F/mehTqRjFJtaaP1PNdP+I3xM+E99cfGr4Z+Do/Cnh3VpNT0Tw/DqNlBqCaHbvq1xqxt rdr6DyJnhjuLWEytEcxzZKJ5gxzPivx78QPjF4T8beKPG1+NT8QXurw3d5PHBaxLLLJHBZoojt1W FFEEKRhERVCxhcdRXoVY8051N3yRV/nH5f8ADHPGSSST6nkX/CNeKlRZItCuJgzFVWMea7E44CJl hzx05xW34TRrSLW7a5haK+W8k82N+HjPlxqVKkAr90jB+mOK8qqmoXO6E1f3Xc/TL9nFV1H4Q+Kd Te2Ecw8P2zRgEY3JcWUOTx1Khj16k81+Sv7TT38P7QHjXU9Rjjjnklji2rnGLZfsqdeclYEY9s57 dd8PG1SUVro/0OeVt/M+dZNQ06zuTHqGoQQPvO0SyqhYBsdCa1HgVB55KmHAYkE9Bjv6dcVtJSg0 2nboOHLKMrPVHa/YHs7WeZxHgMgTClQi7gMEg5/yee1c1b2shlcqp8oqUJyCOcc5xz2/HislO6Zo 4PS/4HrnwNiWR18wndHGw3BSTuYKuTjgdScn3NeUfEtmuPGPxOhdt0Ta/okQy2TlbS4IGfwJz+Na YTTM63p+qOfEf7nBef6M8M8f2q21xZiMAK8kz4LE8hlUfooxVzWpSLPUWPzLbXEZUdcBhk4/z+Ne gnd0peb/APSkjNRTpVIX3X/trZ+gvwL1HTvEPw++GGhx6kzpb215Z3O1WHkT/bby62ZIxzHPE3p+ 9Hfivo/wxoU/grWU1CPWHk08M2yKS2WVLfOQrFXDh9uSSAvUA4P3a46ztUqRtu3+bOOjF2i1ujgf Gnii01zXdP0y0t4Wvre3UE+S9nHcThcttDR5Ucf3c8Z25Jx5j8Rde1zw1oASGG2tNQllV45Y7ozh EAO5svDHsIITDYbgt0IGW1spf5/ia/Fc8cuPCFj4w8ER6NpDrYavLrFxd306WsCRXLbYfJeV0G+b HmXQCHYkI+aPPmyrXxPHqasW3gFcgYPIP5+9d+Aryre1pT1cbfj/AMMTiKCpxpVIbSvb5G7Fr12i BI7siMnGFOPbtWxZ+KLm2tbmy8uCSKd4pWaa2ikkUx78bZSvmRKQ5DKjBXwpYMUQr38i6HLd73Ok svH0Gn2zPLoGn3F15scglWW/ik4IJUCKZFwdu0nbnDHBBwa7XSPilpdtI+oaBrOraDrrAyyxif7b p93cNLhB5cm2S3hSJiuXa8clAcjPGM8OpKSkuZPppf5NFqTjrse1WPx+8T28GNX0mC8SMuFvrJ2M EqKQpkPyllGeScYyfugiuvh+JUfiW50q80+FX8mOVZYrSeNid+zZw5Q/wEcjPI4PWvLq4R09Yv3f y9TojVco8rLp8X2NusZvYZ4ecMHtpmZQTgZCgg5bgEcdO1TReJNAWaQnWIVhJOxXkCk528ckE8cd O3bpXM4S1e/oXfuM0XVtLnh1OKFhLE0zDhtwIJzjkYPU5GPxr5R/aE8USahrdn4bRh9nsVMsmP8A ntIAcHnDYTbg9fnYdK68DBvEXfT/AIYzqS9xm58FbOPStH+3zlo5b5nnEgmUpLEhMURKdmVxcjnq JBxjGXeNtQfyLUQ3GUXS/EMZKk8/uFyBzx0/IVtNc1ecvX8E0LaEUevMsc3hq1DsxCpF93BIJBxn pnk5/wA8djqFgk0bbgXTKjGQwYjpk456ccfyrhelr+Zqn7qOZ0y0tobjW1eCNws0a8xhsYiQ8HHU /mSfxqC7sbVt8kcRV+5jlZQTg9gcdz2549OX10C+ljkbuZbGG3UTzCxjBVEaR/LiDei524z/AJ70 5NZaC1l0y3lnGn3T7ppLJgszgYwCWBJCjd8oKZ3sGYggBv3ZJNeflc9fDUY1cFJrdN3LD/C/RdQs 1ubPwu8pIHk/2le3NnLMDwFQGIRMcg8LITn0rw/4q/Du18K6PdanB4S1CxuYtkvmBklgILqpLusj gE7uOAckCuzC4iTnGDktelrfc9bni4qk3fmPnA3iFopwvVcnB7/5FaIn81euSTkkHkf416bPLfkR iZkG1vXJ5PGB/n8qeR5RJGcdTg/j7Z4oJEDrg7wAe3bmjzT/ALP/AH8otfqFj0C+s7yKyZ01KZpR 93KqBycZ4X+tW7HThMo+0TzyKQAA8zgHjj8xzx6E1zX0vY7Tq7TRNHQPv09PNI5O1SR6cn+f/wCu tIWFlHGrQW8YAAI2qBuOOMfn6+lZybetyraaFDW1Uf2RI2cpKoIY8gFSMccdO9dOluyhVkYbu/OT gj159uf8al/CgXVG3yRiRBtHIKqBkk+vrj3qOOGTcrsxVT1LHOcY6+vbr7+xrK++upp1RycF6mn3 Hn2l2iajaaj9qt5XGVDxzCRCQGBIyFzgj0yDXoXij48eN9e0WTQLrVtOi0y6Vra4FnbuP3bKVkH7 yWbA2kjtycdOKp0o1XHnT08/R66CU3BNLqW1+MnxL8l4j431CVDkFBpGmqxHXAZbRXHT+92PNcxc eMPGd1qP2z/hJPEccQjLMf7cubYbsjDBYZQABz2A9PaI4egtfZr56/ncp1JyVrsz9Y8Q+ItWAh1i 5ub2JWIDahq9xd/X/Whvzz29az4rvV7+Jbh7mJGkAOI4G3J16kHH6e/Oa3jGKWm3krENtif2ZNcz xTz6jNlGIGEQdR/un098e1W49Mt4kV2aV5GGTunkwF/AgcewH+DvZWSCKRz2k2FndCXfbRGZHkG5 hg/ePVsZ/H2r6d+APh/xJe61qM3hybTYlg8l7lLwMrMhYj91sQnOc5U7Qcrk5AK8+MrwwtCpVqXa S6GuGg6taMIvVn0l4i+HPwz8Z3+oyeKtJkttbu5RJf3umTvE1wzAc7HDQqxwSxVMl2YnLMWO94U/ ZC+CeoywRW/iTxI1ls+VRdWQkUrwMsbYg8/7NcWFxyqUlKFmrdd/nY6auE5JtTPmn4/eI/hh8Mv2 kNI/Zp8Afs4WWvGNdH0261GbxJq8Ot6veanBbT7bN0nGn2cqfakt4zNZXcfmo0jo6MIl6n4l/s7e CfC2tX/wz8NftA6RrXxcttTktF0L+yLq2W7jHz2vkXimW2a6lAjja2LhEmk8qOefCu3ovSnRnFOT mr2VtFo/12u2zkspOVlZJ2R5r4M+C3xr+I72f/CFfCPxDfrcRmSC6Omy21tOoH3hcThIT6D5+ffN fY/gb/gmF+094qsodW8T6ZpnhrQkJa+fVL/zJbGJerkQB4WHB485cdyO3NWxOHoL3569lq/8kaxo 1Kjul9509t+yd+w/8No7DUvi9+2rZaxfEsqw+CxHqCPjP7l2sFvzExHBaR4RzyRX0n8LtM/YEs7C DWPB3wWu7p7ktHA/jSVjLcOH2rJBbj7WPKfaxV/9HyQdwTcM+fXxeKnHnpw9nDa7+J30Wm/XyOml Rop78zOR+MX7Tf7SXw8u9K0jwXd+APC/hiS5dLC58NeGpbzUUsQG8t7iLVfNtQuQFYwgY3ZXdjn8 4PjF8UPjd8Ttb0jT/Ffx18Vala21zeX0Vqb6aSKXa0M0ebWJ2toiI2jOxFZEzgA/Ma9Xh3BYPF5n RU7zleTbl/hl8tN097pEYic4UKkm+WyVvPVfp+Fz5y8IeK9K0PxK94fC0U3iHT9QuZZp76UXLXjy Oobzo7mNoGGyJUKeQFbLgrtbYPYNS/aP8XPrTar/AGHo2PIihNra6bBpcEgifzELxaQtpHI4bB3l Nx2rk/KK7sVhYVq0pzfV6dLfkzhhXlFaepzN5+0B8TdQvpb1tVhS3NuLSO1eziu4I4gNihVvBMwI ChVbcWXYoB4rjz8Q/EiaZf6BFrDLpc9xFPLFsjxJLEMxtkLn5SSQARgknGayjhaMU4xjf5idWcnd sw7nxN4jktrmKbXbs2064ljFzJtmAx8rKDhh/wDrr3z9n7xzfeB5NS8R2Nno2o3EEUcc+n67o+n6 ta3CGWdmjmgvI5EXeqqodAkqjOyRDzXFjqcY0LwjbVXsjqwc26tnLofuR8Gf2t/2frjTrfwp4q+H fg+w1yaAiXTvCttbWhaII1xHElhM2dqiLzCxmwAI3C8qTsax+y9/wTX/AGifGeqX2saRp7fFPXJh p8Y1DX9Wsr2e5mTzjDY2k9ysE8qhy7fZopNjSElgWyfGpzxmEqc9O/zV7r5/mjslCnWi4vb9Twfx d/wQW+BGp6fqA+HXxI8Wad4kkY/ZpNSm06/s7Y5+68Iggkf05uF7186/EP8A4ImftUfDHwDcat4Z e31/wW/m2ulaneWd1pMms3GZC0UAmV7MFcMB/phztJ4xXY8zni6ap1afvJp3j29P8m/QihQjQq81 3Zpr/I+V/iX+zV8dfhvBqMPi74T61a2ttbrc3F3BaG7tIIxj791bCSBSP9+vmjTfs6Wryeco/ebg xcBT75H+etc8b8ra19DsbvJNbHoXwckEd7fmFRjdIMH+6HdcZz04HPOcV4t4yuv7Q8S+P5IBsnl8 X2+2T721beK7jKlW65JUk9se9duCX+31pP8Al/yOLFv/AGWEfM8a+I85+2WIDZYPMCdpAHz9genb /PNRau6SQeKRnkSW5+9gkEHtXco+7T9f/bkZwa19F/6Sz2z4KfEFvC02meHrmUR6deyG9t7h2Yrp 15ESN+3O0pIoRX+XP7qE7gqsG/RXS/iboNxbhtTv4LO+CJI8VzKER1ddyNGzYEiuuGUgk4ZfUV5+ JjKVR2/rVr9CHT5HdbP/AIc8fOo6T4y8f2MyTumn/aWktBEAr3BiieQlS+SAxTOCM7T2PT0vRfih o8ngLUJNU+GHh3WbLVbOSye61XTxeXGnxM+GNrNt3wSHa2JkAcBiAQMVzYqtOnyRu48rjqut1L8N DpweHeI5uXVyvZenL/mZfhuz0vxFo19cx2P2C789fs2nxWaLHFabMl96sQu1uPL24w+7Odwr83v2 gvDTfDyXwD4dmmWeG10t7eOXbs83FxNIzCPJ2A+bnGTyWOTzU5RiObM5Uk78zv8AdGS/4J1Zjh/Y 4JKSs46W9WmfPkeoxNyinPTAP+e9d1Np6ReFtM8T+dIVup5YTGdpCbDgc5zk4btX11SXK4K27t+D f6HzsVdS8jCW9T5dsnTpx/kdz3qf7SHRkYA7h90kVVhGlb6ne2LM9jeyQufveW20OMjjH3SOB2rs YvHmu5t2vLazvDHcvcmSa3EdxM7qoPmXMJSdxhQQpcqDuIX5mJhwT1GtDqLH4xa/bxxQ3U140KSh 9srJdKSrBlwfkkAGB1du9eu6V8ZFvtOu9SvNMjfTY1czXEEvlr8uwEKk4TcwyuVVmPzDivPxGDpq 0k7frfy3+42hUm/davbU0m+IHge506XU9O0cTXyxyTLFLahGYqAxHnFSo4GeGPUAAtxXxrqV1c6n f3V1dqXuriVpG2qTvZjngD69K2wlKVLm59/vIqSUrWPorY2mmPTrPUYhHZQpa/6KiGGcxKqNKNy7 v3hUueRknOKxPFtjqdlp+kSx3ccqT6brL4mjxsV7YtIcgk55LDjjrz1rOySV1v8A5FXbbZ+nnhX9 mz4fah8CPDXxP8U/tY+CIfED+IrHTJPCuhSz6nqllZNaxXcl7cxbYsYWRYxHGZEWQPFPLbSIY6+N 9X8fPbXmuyabos0TWMQuLqK8Yo9tG0kcana+wk5mjGQgJ3bsAAkcc6UHRhKCabWqaV7uTXntp957 WWYGGMxMaNWdlq/uWn3n1r+zP8ALz9ov4d+I/iFpviH+z549fk0yaE2vnqfKtLJwwIdAMibGCeoz XkH7RXgaf4DeLNN8H+JtVge4u9Pj1O3liUhWiaaaH5gc7TmFuASMYx1wOWjU9tOdNRacb/OzSCrl 1RYmpQou/Lfc+T9Z1ey8Yazb6Gl8g8Pxbpbjy5Ar3ZAG0bhgBckfL1JRydoCludub7UPBUscGrEz eFZWCwXuQWtR/CJCO3bdx05x1rulTUo+yW61Xr2/Q0wlX6lUjSrL3JaS+f8Al/wD6g+H/wAQdOvf slhqurC1vH2ra6uN7W9wFbdGl4iFW2FiS0kZG523yiX5mrpfip8NV1zTBo/jnUNT0+2ul/dTW2qt FY6lgM6uh/48piWUPteK1fBTMhJzXDRm6Nbm5dd1fW6/O68tba66oWPwbhOUE9Hs+6/r8D87/ih8 Htf+GF8Irh2uNIkJ8m4MLROADjDxtnHs6l42yQrkg48xtro8IMZxyO45619JSqRrU1Vjsz5irSlT lyyLjMsnzwnn0PelE5UEtny/rzj3/wD1VdjIV+q7TjIyMUbZv+e8n/fP/wBek2HNbRHscksf2OQN jfsbgkE84x+Of5dKjsL60EcIcurBMNuRgPcY9Pyrj3T0OvqdQupCCHeEkfaMswRhnH5D349/pTku JrhTcRWj7mUE7nVd3AOOCe3t2qWuvQZXu7TVNSNpG0CxNHMG+aQuCAD9OO3XNdDHFfPFHnUlCEbd 0MPbscsT+VDso23H3Gsk66lFY3Go3EkLxsy4ZEIbjptA/L3/AArTGlwcq0s0kZO1lkuZHH0IYken GKmzdmo2/rzKWqH6d4Ye5kiXRtBMquvCwQGRhnk9AcVqwfCT4o6yuq3Oh/DjX7q2TzbJGtdGu5AJ I3ZZV/dxclXBUjqGjYEZGKOZK7lL72HJJ7I722+A3xxvPKSH4P8AincVGc6Fejtzy0QA9ufw9e30 79kb9pPVY2ktvhBqwV/umdIoSp+kjKcexrGWIw0PiqpfM1jSqP7LN0/sIftW3KIIfhBcuM5IF/po OOgAzcA9O2DxXbeFv+CbP7XN7aQx3Hwza0bLcT3cL7M5IBMLP2P4fyiWOwi09r+f+Q40Kt78p3lx /wAEyv2j7NVk1Gbw5aA5LC81O4hKDHPPkEcdfxrnZf2BfGds+3xD8e/hfpi8FjdeMooduc8kzJGO 2OorL+0cPtBSfyuaLDVWrvQ6LTP+Cc3gzS7RJtY/bw+DkLM53R23jfw7eS8ndgIupK7DnklRmvVP hd+zH8HPht4iu7q5/bS8F6y1zCLVLTSbeKaVzuVgVFteTs5+UDaE/i68c8uPxKxOFqU/YySa3a0W zv8A0zfDUZUa0Z8yuunyPaj4L/Zl0nU31HxD+0YsILEeWvhHXJIhwRhmS1cHH4H2FeneFfDn7Iuh yz6zofx5fUkZQDaW2k36R55YHEtshQ4PQsOMcV4OHqU8K/aQldWturep6laNStH3oJHz1qPgn9nf xD+014M/aM8J/wBoReKdJvY4rzVBatGt/bLZtp+Z7CbCtNAnkCN4jb5MMhm86SUSR/mPofw4/bK+ At/L8PtC8FyeJ/BWvW994agktYxr+k6pbXgu/NWCYxiXSpZIoZ7lomFndeVH5s0apnP12BrxxNP2 VZrRKOj7Xe6em6+48TEUpUWpQXV/jY/pBh8Mfthj4I+HPGWsaxp3hpYPD1uuvaHpr6fd3en3ECeV NKt7DDlzIIzdkRS7YxOYQ0vliR/mHWdC1/xbe2Os+LLq71zU4B+7v7u9M89v2wDcPlOP7p6DtXkV Y4enWqRp9G9fL9DpvKWj0OQ1jwj8O5LpovFcNjEZY1ae4vLy1Vo8DhC3neZngDCqR7kc14t4l8Hf Arw9Ja3uk+LZSG1CK4W30uzS8jjdSvzsEUMoUqrFmmLHaAoYgCueVOVV3hu/u01NITcHpsYHjXW9 H1i4hljt5dQmgjKxCytrrBVsEjy3GWPy8cE+mcmvhjxkl/rPxOsftXgrVraKaSV0s9U01FWcSWkd okgjleE7Q0MbcsOmQykYPt8LYh5Xm/17HyUYWlfXurXSV3+HkRjYLEUFSpau6PBfGWgf8IF8TfF/ hS5u45pI5kcPaLMIwkqLKoHnhX+USBSfmBwSrOpDNzviLV9O0m2a/m89rNcLkxBduSFzwx7n/PFe 461PEr29J3jPVd7PVHjyhKnJ05brR/I9nf4TX9lpVjf6r4j0uxZ2mS/8+S426HJD5BaK62xfPMUu oWFtam5mUmRJIonikVfL9StrrRJ73SNUSI6pHJsZoJklTAGQ0bxsyTRsGVkkVnVlIZWYMCeaFSE5 TjHobVMPVpQjUmrJhaQmRYvMff3Xqnc8ELjOOn4V7Z4fe3OmJb22jWsF4dMkE1xbRbJL3y55HDzs Sd7BbgxjG3CRoAMgluHHyapW80aYRXq6robPhfwONW1Ky1WO5aGSSNJEkjfbJ5kar8ycZDKyHp0I 4Jr7A8f/AAe+Mnx5/Zp0fUvBXw51zxDdWWqqbOTRvD15dnUip8hnR4VYSDYzF9i43RhQo2mvOVTn qwvooPfa3Tc6FCUeZ9zzHwz8Uf8Agpl+xrpcV9qfhr4l+EPAMUSW9npvjXwxqR0q0tEkLJBbx6tA Y7aPGV3QeU23IDdx+r/7Lf8AwcJaLpd7HJ8ffgnr/hXXjHOh8UfCDWDcQWsR2+XBHoer3KTuX2lZ JzrqjoVtzt2nsjhKFWUqkZcr6OOq/D80UqlRJJq67M/cf4Iftb/sWftcahp1l8PfHnw88b61JLFZ waDJb3HhLxRLI4EskcOnzjT59avmj8wGS2/tiNJYyxZ+kkPxZ/4J8fsi/FrVNet/GegQ6R4tayEH 2fxn4ZFxc2ijarRNqdpGL5HYMXUR2EYAGC4OGPHXpOnJe291vaa2fqbxlde7r5dfkz4Q8T/8EFfD gtdR8TfBrQ9Ti08Q/Z/+KY1ZdahdnzILi5tJmmv4MgH5ZDbAdCoNfgz8Z/8AglL4r8K+MfEOg+DP j54W1vxNa3UurT6TfLeaPfSXF0+1LdHKz6em1o5QxuL+2ZQ0bMiiRN1UKlWhVlVrRupL4o7etv69 DKtBVYKEej2e5+dH7QP7Hv7Ufwvs5df8afBHXU8LWKu1/r+nW66rotqz7Tg6pp7T2RbOQR55I6HG BXgtvY2Goah4gs7/AFJLOxdrUvcsjOsfGOi8nJ468ZyeBXoRnGdKE6b5lrt/iT+RjZxcrrp/7az1 K0+FGowX2kWGjXNprF6kEr266VqFrem4BzuPl2skjjuCMgjg8VV1HTPFmkadB4duUvILSHc6WJLq IS2WJX5sjJOecduTWkVS5k3q/P5/5s5qtScvda0O4/Z20Xxlr3xb0C2it7q6aOK6uLhpXZ47KDyZ IssxDbAGeNB0BZ1XvX6g6N8K5obK1086eF0e1jSGJC64WKNQqLgkHAAx0/hzXyXE1dwxMadN/ZTs u93Y9/JYr2TnLe7/AEK+p+FYfD2oO0DLDFIqRtgqcjjK4GdoIHPHevxO+OXiLUfij8a9asdD06bU kW+Gi6Nb2ySTS3ZWQxosSICZDLIzFVAJO9QK24VhKeJqV6i+GO/m3/kic9q3pxSd7v8AJH0h4Z/4 Jr/tC+KvDfj/AFTRtL8N3Xi/wyXGt+ELHxTp9xrliEDE7reCR41f5JsW7SCdjbyKsRYBT8dahqOq W/h6PwRd2UcEFtO7ZlhYXEcm5twO5scEkdAccV9mpwxGzd4SXRrW2nyaeh87yyprX7SscYtncFnW C4VnxnlWU/8A169l+HH7P/xl+J934ffw14E1ZvDV9fR2H/CQvpd8+lWZeRY2lnuYYXCxxlsuVDFQ D8pPB2nUjTi5T0/V9l5mai27R3PsS/8A+CYX7RWlw67IuueErs2ClpjZ+II3UfKzAPlQ0O4qwUyr GrbSQ2BmvinxR4B+IfgS2t9R8X+EdQsdLnlaC3vZbdmtbmQDJWKcfupTtw3yueDnpWFDF0q8nTs4 zXSWj2v+RrUozhHm3XkclHfRjASdd3B2OSP/AK1dJ4xitPDvifxL4csppX02GdoU81gTLGMY34Ch j77QOBxVuT9tGm1um/ua/wAyVH92531ul+ZxLWVg37yCSSI5yCkmOvscirWly6zouoWOo6ZqcLTw TrOnnxZAKNkep646YzWrs9GZmhY+MPGNhJLPdTxzQEjgomwc/wCxtOOR1PpXZa/8VzrFpYW11pZi 8jTr+2DwShvMeW3aNTtYDaAeT1OCcGsqlCMmpRexSm1dM9s1PV/C7WHh7xAsX2e0l/fSTFXjmtlG 0tIpjwwOEJGM8kEV4lfeP7uLxDc6to8qz2Mcrpax3Vuk0McQLbVWGYMgB3FtpXBLEnnmuGFKfJJT ej0/H/gI9rK6/ssTGpHeKfzvp+R+p37C37dXgH4fat448HeJvDmk+FdB1OHTrnT47Oa9FgL63thb 3sry3lzMYZbry4rhgxEIcSpEIU8qGuZ/4KUeLrX4m/EXwJ488PaHeXXhODw3DpV3dWU6TL5q3Vzc MheOMiAmO6QqzqwOeN21gIhRisXVnCPLGS06/wAt9fVNnoLEuGNnVqdU/wAv8z8otev9NuNSlm0e 2nisMAxR3Fys0kQ6kGRY4wxznkIvpyOaxJNTuRG8TTMY/wC6ehrrjBxST3Qq3s53dtzb8L+PL/wz PaQXBkudCSQM9tHL5bquckRyFW2E/wC6w9u1foT+yN+094SuPEdv8Jfi7qVrB8NNWjkQXWqgeTo9 wqGRTvYkCGVl2FW4WRo5AYx5hfgxuDnJOtQXvL3rdbrXT1CWJhUwf1asv3kLcsvLs/RdT7C+JHwB 02XwfrHif4N+L9M8Y/Cu3guZdQ0yz1a21COzRY5i8ttKC6FkV2cRkud8asyy/cH4y+N/htFbzXfi PwtdRTeHcJ5kEKt59l8gyXQk7k3Kw85TtztLLFvRKvA4hK/Mrczs1taXp5/medjMPLE4b21OK5ob 97Pr+pwdtYzTafc30OmTS2cRAmmVWZYic4DEYAyBxn09q9l8f/ADxN4IljtrjWNLm1AxLN9jTUrc XiBhuUfZ3ZZWJHZVYf7Rr0HXjCcYS6317Wtv9540qDTbj0s/vPCtSs73S7yey1CzkttQjbEsUyFG QnsykAjgjrVHzG/56D8//r1t0TOdq2jR6vZWNqVQyKeAOMnAH07cf1ro7F7KO4R762ke0HBjimCM evRmRwOP9k/48zu79DrWjV9j3nSfGHwV06xVZfg5qF/dBNs32/xWxjkB7bbe0hYf99n+dTR/FP4d PGW0z9n7w2kGwbFudU8RylQAflJXUowcHH8IziuV067b/fWXlFfrzGvNSS0h+J3Hhz486FpOFtf2 cPh1PGOVW7stfuGY4xjdLqp657df0rtpP2r9MXaB+zD8H4nB4ceFrxmHOSfnvXJ9Mng89e+Tw9Rv 3sRP5NL8kWq0V9hHK3f7ZfjDTru0Xwp4A8C6VGjbWOleEbTMffOJfM/M59+tb8X7en7Rlsqf2R42 tkGeFj8H6CwUHj/ltZH8fpSlgaUkvaSlL1k/+AP6zP7KS+Rl6p/wUP8A2qorWaK3+IEMU5Cxqp8N eHoiCeBjZZ+p9RwPavLLD9sL46eHdDsvDemfGuawsrZWBW1uo4ZGd2aSSSRo9jvJJI7yPIxZ3Z2Z iWYmqjl2FUXH2d7u/V7X7vzJeIqX3H6X+13+0JrTyWelftN+M/tKKGYWviXVIgBnGeJFU9hwe9bd x8ef2oNViQQfHj4iXkQOJAPFOruDx1YCbjHXp9at4bC0vioxXql+oo160tIyZbu/jp+0Qmi6bpPi nxFo2o6fDItsG17R9C1283Tp5u55b+3nu7j5SW3ln2BggKhQo5afwTd3NrPrniC+0a2ge4KNdSpD ZW4kYE7Y41RIo8gcIoG7GcV9NnOGyzB5Rh8VhKHvuSTavq+Vt2TdvSyMqMsTWxMoSnZW6vod3Y/A rTNR01Ll/EcUZaNJ4zDaqyygsHGyRXICkc7sMMMMcE46aL4PaVDIrMbmaNlwAzgDnrnCj2P/AOuv hquayXu0lb7z1KeC5v4ktDobP4WaFGGlj01RcFCqu+ZNhzwQrk8e3B611njDTtWt/DUmn+D/AA5Z WzyoTdJY2EEBYlSS/wAyuWweQqgEkjucjzKmKqYicI1ajUb662X3I7YUadFS5YXkefaR4y+I/hK0 eDXpIfEPhOMtAUuz9mvrLYDldzdQMABfnwAcc1yDfGS0l1aS58I2k8FwjYMfmHeD0wQoyAfQDmiO CpzqSq0XaH2o9n5eRPt5RioT36ef/BPfPCXjfxNfeHrDxBcu66i99NFJ8gAcKiYBAAByAPxAPbj1 PRfinq1ldLJPosq31v8AvVaHayrkH5hkhlJBYdO5/F4WtTw05U76JtGlSi60Y1IrWx+on7P3xW/b U+JfhmbQvhj+zvc61peoWwggn8SS/wBnQ3CzqBG0CuPtF6G3qB9mhnzuHYMR85RfsU/tM23iJI/i r4w0y28NpM8Gr7W1O0vUbDDFtJvdGwxUEyLCxMbgKuQ1d+IeGp1nUle7Wy1V0caU9ND0K8+Ef7Kv gu31W68XfEmGW503P22KS+ieZWAzjykPmOePuKCx5FefeJvjH+wr8MdJ0/XPtN9e+c2xVjRLeQAZ Uki98hQMg5+Ysc+4rg+sSk+SK17Wv+C1/A39jKS5nt3eiOH8Qf8ABTz9lXwfeWNn4U8GRahAFBaY xRK6ZU5X/Ro5lc59So6nk8nxHxh/wV5F5bavovgr4H266VMjIIr20a4guOn+sDSQAjOf+WZ7Z61r HA42uvfjyx/vafhqxc+GpO/Nd9o6/jsfk/8AFz4oat8Y/ifrXxM1Tw7Y6PqupCFJrHTFVbaPyII4 V8tAMJlY0JHqzHOTmuN8QQR6ppN1p11PiKSLDMF3bDgkccfxAHk9u9fWYWl7LDUqad+VJX22PDry vWnJK12fXDeI9H8Y6f4y0/V9bgtPDl+5v1mvLi7umm1yWz8tJ5rguYbGW7vLdjN9pkTyjcx4MkI8 yPxr4p+Lrfxn458QeKbbyVS4aCJzbPO1vM0FrBA8luJ1SSG3doi8MDInkxusQVQgUc1ClKNWc5ei +aX+R6WPrQlRpxjK73/BLbpqcNa3TxlF6MCRgZyckn8Pz7V7H4btba+jtmu3IZ45EXAQFSCWHOM4 wpOMgcg46VGOfJTutziwyUqnK29j2zwR4d0PT7H4e6zBqt9B4hZZNVTUdPungn0uWDUr5BJC8RUw zKlvEUZQCp+YYOM/oR41/wCCuP7aH7H6eBodE8XaF4u03Ubea2hs/G+gRO0McUkcazNc6WbG5uJ9 zSAvPPKW2fNk5J8Sio4zFVcLWhaMZW00eze/3bpnp1V9Ww9KtF35l1d+v4H2H8Hf+DmT4eXP9k23 x+/Zu1rTRHaAXmoeEtVs9Ua5uQBkx2V79j+zxkhzhrqVlAB3PnNfcuo/8Fof+CTX7SFj4N8CeP8A VI/Empa1e2unW/hnxV4QEsdrPcOsca3NxqKjSoIwzLvme7EUYJZ3VFZhTybF06t8JPTvdxa9e/y1 8hRxlGUb1NPLf7j6rt/2RP8AgmH+0z4NktPBfwO+GF9oEKRy3beArfSLKa0LqHAmvPDzxkEgjOJS DyQWByWaP+zBoXwZsvDfw9+AGgfE7w58O9MtzFHDYeO7PXLJYvM85re303xfd6haWKyuxZ5rKK0n +8BIuanC1as3LD4/EKMe1SMnd+sYuSfmaVEuVOnFv0tp97PobQLT4s6HZafq/iXwnZ3G37RqNxN4 YnFnc2KxHFra22iX17fxXE7EfPeTa/ZICwK26gYMXxS1zwf8cb/wlp/x01GDUta09dLtray1m5ht NRjkuCzQWNq96n2fVtQJaRGNlJqZRyAWb5QY5lLmjgpvzj+sdFf7k/Ii7VnWjr3/AM+35HyZ42/Y X+HWgeJtK1fwR4m8UeD/ABlpd5qLxaVPNPCtglysRUyOTiSfMUZVls4CgyqttZs/EPxV/YMs/iFf ofij4A8H+OdOnUyatd6hov2LW9WkUExBtZsni1EqCqgKbkKA7bg2AtYxxHs63NFuLStf/NbPXyKc NNdUz5E+If8AwQw+Fut6fDJ8PvHus+FtUW7Nx9iUf2po1uCDlYbeaRbokE/LJNdyEAcr6fmv8RP+ CSv/AAUJ+E9pqmn/AA08S2XijwtfTOktlpOtm2laBBlZLq31ERQZIGNkcszA8DPU+jhM3pu8MYre f2d92t1v0/A5q2Hco/u1r1PgPxf4h/aq+A2r6DZfFT4ZX2jp5clnZW2r+Fn0ldRjRgGKSwRwtdbW AxIrOPcg1+w/7Gv/AATX/bZ+OpsvH3x18c3/AMJ/hQLqN7iC/htm1W4hMkSyRra3Fu72jGNpyBKJ blfJ8wWUyAtXRjcNlkorEzpKc5bK71t1unsupnh62Mg/YwnaK8l+qP0E/aN/YS+Bd18GY/CXwO8Z eIND+NlvFFLH4u1W9jvrbVbhLeBWhvLCaKWNI2lS43TWghbMkUqwARtayfzOeDPgdrv7PHjzxp4u 8flrHWPCWm6gbAXUckD32qTI1jYz6ZMdv2h4J511GO4hygWxMiuflNbZfTw+Ho8kKaTk0m1ezXTd 9Lv9QxcqtWUXOV0vLb7kbP7LOr6r8MP2g/h/8SdJ+MOj6R5utWunX+mRSTXl3qOl3M8UVxaCC3im iOY/uLMU2SRRyDY8aMPor9pr4K6Q37U3jvxNafBfxD441K4hh8Q/8Ip4Z0q+Fg+SYppdRubJjdiO W5glkmjg+zyyi4kZbuBwGPXGqniJSacU46uWmz31/U5+X91Zu+vQ+iv2ZPCv7Q3hWW/1T9oX4jRr 8Fr7RNQFx8KoX0w+Hr2a4QrBanw/ZEWumTi5eLUGmFrbrm1lO55J8Sfnt8XrLQvAvxlk8A+DvG2s ab8Lb67j1bVNLlvb2Wys3nYJOsghWV5m2RxNkxNMYzED5rIGOFKoqlWo1Bcj1S63X2ter2LlF0ow k5e8v6sfdXiX4k+PLRZfiN8Idas/EOq2elxz29/okWotcWPm5N2klzaFZbe4ZlUwRM9u5WVV2lot 5+H/ABx+1t+0doGoaT428Q+P9bn8ZXz3ts/9ty/a5YbI+STb+TcIyQqHjDgoAxVlBbG7d6c6WDxG GXIo82t7aTW2l919/wCG+bqzg5b26dj5u+Jnxx+JXxmm0S5+I2vtqMml/u9PjkWOCCx3Y3GKCBEj Ut5ce5wgZvLXJOBXmGo32nx6kdV1u5RdS3tOz3PzyySgbkZ1IZ5AzdSRjA56isoU4wSjTW2i/rf1 MHO97/ccncWtheRKNI/dk4G+fzVGRweArnBOSM7SOPpWVcWGtWZVmQNE+5FkTfsOOoBKgccce4ro jLW0iNbXRj6q1/DFA0zARltpIPOf6jr+Vd34M8MeH9Y8HeN/Eus6qsV3pD2DxW7ygG8jmnEMqqpw zMqMX+XoFOQRkjPETlSp80Fd3ivvkl+pVOKlKzff8Fcu2Gu3Op+Fp47u8LtFbPDGmFUIOB0GMfJ1 POM5rsfhZ4X8FeNvEPhPwl4h8V2+iWlxDKLq/vWWKKJo4ZJQpeUoql3Xyw2T8zg4Ynac6icKcuVX td2NKNV06ilFn6xfDf4MfAf4TfJqfgiye++zfbF1fxAYbzzoI2ZxcpJMPs8QVcZliSMYUFsEGvh3 4r/tP+F9c+IcutaR4d1KY2timkJ4h0vxLq2l3t6kYI8yBZHmW2gdtziGSOSQ7y0jF2OOSipz5pze u2ya11tbtoeolKq+Zu/4o4iT41eD/EaaaPEGs6xvhXy3HiDw7ofiiQpzkfbZxaXKrz0UEjseKyrm z+EWvIbWGw8KyXTP5kQ0jWNa0WdgRjbLJq6T2a8kH5SAORnHI6Pejtp+K+56/cx2nD08tV9xz7fB DTtYWeTQLDxLIFUnZpFnYeJLeDHH7y80+4TA/wC2APsa5PwlpHiDwv8AEFrDwlrehS6hbBZkbXor KKwnfA+SSHW41gLrvYYlQDKvtLAgmpSUoNP8L3+7dFUpvncmtUehXHhH4r38Pia8g+FNlrFxI5ml 1vw1bm5t9MO7cxibRpfsEYwSu0oVAbgD5SPBxeapp83lIslvLEcNH8wAxxtKNx+BHaso8stFLmt3 3X6/fqdvtVUXuPlb7afeb9j498VeF7PVIvAnivVNEn1SzuNO1f8As++mgW/tbiNori3fy2XfDMjF JIWGxhlSCpwOPE8hQDdnvjPA+lWn7tmtb3dupzwoKnOTWqtpfoXbPWrrSZCunXBNqxSR4J40likc KeWifdG+N7hSVPXPHStf/hOtX/6B+lf+CHTP/jFFn3fybQpYbDyfNKGprWmp3U0UG2BnJUDcWyCC ODyc1oxXt7JJOI4wAGIYljkHAPoBVyS1PBL6zak+yLz0CY2n5edp60sUDQLGEnYjP3Rjr36c+uef y5qRl2Qv5M7lyXGSC0nA4yDyfat3Sba0ns7C5FupnkRWYgkgkj36n/OahqyuwNuBVjXaQSFwpyuf l/n1zj0/Oua8ZTzW/h/UpIJjHPsYh4nKspGe/BHb9fWlGzkl5g7WZ5X4HsPD91qaXPjG1ubnSZV5 aKfBzww3HO4jsVGD057V9s+Ffg/8JrxbfV/D+gWNzbsFO5riSePBGR8sjMM8jgiubMq+KoNeydov sup1YWnRqXUtZI9b07wDoGjvcTaZoWmW7lf+WNskJLZBAJRcY/4DVrxMdMstHmgn8QWtkZi8DyG+ eKaMsCN0TRK5DgZIyMDAByMCvAdadaom25Sv11PR9nGEXZJL7j5o8N/EWLR7jWfEk2ptNr95bf2F dxRwQukmnMEjlKiSMqspiVlWQjG4BsZFbvgyHwHFcz6neTQS6Mt9NEuk6ro/2+SS2/5Z4nMirBMu SRJFEjAqcllLKf0viOhXo5PTr04+7NU18TumotJrolZu9tW7a2PFwcoVMRySe1+nRvX1fbse7+Gv Gvgfw5o0nhnwl4DuptMJdvIlkkmj+clm/wBYz4BJJwOuT179jbeJviZqyxw6F8N0hjAGBIGO0dM4 OAPbHf6V+X1KMeZ1MVVSb1ex9BFuyjTjobVp4J+PuuLytvYKcc7UXb9Cd2O3T07VpD9nj4k6iFbW vHREbMCyQyM3Tr0IGPw4x3rmnj8uw6fJHm82aqjVneUmUJP2ePAum3Elr4k8couorgvFPcpDjJOc 7sFjjPGP8ax7nQ/2TfCtwyax4gt/7bhHAa4mimPUEo67ducdmHWsoZjj8TLkwtLTyW6Zo8NRiueo 1p301OV139oz4Mx6fLZaXrOr3F/FO00KPawKN3ygASRRuGG0ALnHCrk5rxjUv2kVmy2keF7tnZgz JqFw6iQj1ZJE4/2dp4J967sJlGLf+8Wgn82Z1MbSiuWl7z8v8z6I+AH/AAU5+P8A8Cdc0W40XStO ufh9HOJNT8MzyrFFdRbh5jQzxRb7acqComxLztLxyBQK/ro/ZG/bs+Cn7Y3gMajoOrQ6xPZxC3vt A12JIta8ObUEcXzI3m+QofdF5cklozMQVMiOiejVwSp4e8JOdt79ujXpt93mc6q+2k5Sikdb8VP+ CZv7E/7UdpcWj/D7TItdnnluBZG5l0W8vriUbC76hpslsl9IMBwl2EXcVVVkbg/gl+0F/wAG9Np4 XutRtfgr8SZ7LxBagJLo3j6zbeZCwJ3XFpArW+I2yqG2kLELllBLDlw+Jq4NWirwfZJP7/0ZNSl7 SXvPXzeh5P4R/wCCIw03VNG/4WB8Wbu6gAV77TtI0FbcbhyUivZLiQMvOCTAp9hX1lo3/BJz4PL4 nubrxTomjXfhX7OYrbSJo9Rs7uxQSO6GO5sdQhe4b94VZ7mK4ZlSJcgJ8z/tDEV4yXs+RWdne7v6 WtYl0YwlFp3tuujPzF/4K7/s0eDvgBr/AMBNY+HuhWGmeEtU0u906O0sLbyFaaxkhaWWTOHkZkvY FLtljt5Jr4f+Gvxu8I+Dfh74t8K6h4R0t9X1XbDPfXemWV/cvZ4RvKiN3GyxqZEy2zD7WIG4gMPd wqqVssjFzbl3vZ6S7ryPNquMcVK8Vr/kcd8SR4AxpGq+FvBeqWF09vCtzcXdz5lrdTxRKk7wI0Ic F3UTEefIq+bsHABry65utZu7S3iS+lXRoZjItsMLG7tgBivVyMYDdQCR0JFdtN3iudp9v07nPKPv Pl2JbXzLiW0tYYvMuJJBHFHHy0rE4ChRyWJxgfTFfob8KPh1qV78NPI121W2uZ5JL61ZbWzmnhik iVR/ro5BFuGThVVgMfMpJA8fOq6o4eKXxOSsvR67dLHbl8JSqOSWiTufOnwj8Yx+IPCmtSEGPV01 HVLYWkjKWt7dIrR4VcHp5ks90duCP3bjPGTyPxXOr/F7xz4M8By+I7TTDoPh+5vtQvfEN5ctbLD5 t3qfnqYI55z/AKNcxxhFjkY+UqqvQVhgqfs86xS3VlLTu0kduKlGeWYeVrO7X4s+T7Urel7jVHVY HwyWyjcWAOCzNwQuRj1OzAwQGHcWUUOkjSJdMVEuWISKTYC+5njGSwwXwHPGeBxmvdrScbRjseTS hzNyaP3q/ZitvEfiz4e/b/HWpWOp6RJBZf2dCE3zW+6ETyeb8gVgfOiK8kq3moMIkYr6X8UfEX44 +FPh34l1v4HfFPWdM8ZeH7eSfTYrS7luIVa2cmaD7G2+CVyEkh8to2w+CcFeKxywuKp81On7vKrJ 9Gkr/jfqdVH2sN3136a7fgfLPwi/4LV/t5eH4tSsfE/ivQ/FOZdy3Os6JGk0SYGVT7C1sgzk4LIx 69elUfij/wAF2fjx470Dw9JY/D7SdEkd4l1C9vLt9U8tSyiSS1ss2q7sFgIi7n5cs4B3L42HwOFl XckmrW09fPdG1bESjBJ+Z89H/gor+238Mr2y8deAP2mLpNA1SYR2vhO7srG+0K2t3na6lEVtMGjt pGBPm3MEEFw4yPMHAX9ZPhn/AMFpvEuhfCTwb8Yf2nfgXZN8OtcvL2C01/4farHJNvinubeOE6Jq E2+L57SQmd9RIZHjZULZUPF4CjXj7SHuTbstNG/Pz31++5FHES5uRq6tf0P02+BP7e37H/7SJ0qx +Fnxx0W48R3skNrbaHqUj6XqlzcyJv8AIt7S9WKW9ZDlHa2WZAykBzkE/UeoTWASQIEklQHjdhQe fvNyBz1HJ5zg14NXD1aVT2c1Z6+j9H1O1STjzJnkmv8AjDQNIc3EksL3A+UN92NBnpxy/brnOOAM mvEtc+Imq+IJjb6fK7xEbM/MFUZ5Cj0znnA69Aa9PC4VU48zWplKXVHLXekO8Yl1S42AnHzsSSfY df0zXzD8VP8Agnt8Lvi94wuPiN49+DTatqUlkmng3d/facy+WWIkxBe2rSOAwRWkD4VET7iIq9rx Cw+vMl9z+5GDg6mm551b/smaB8JotKl8L/ALTbG40gNJpt9p+j2N1qkDAFgVv4le9d/QtKx6Yrzb xkLvwtZ3mo+KvCF5pVtCEle41HT5LaPJjU5RnAyFBCknHK47VisVTqVYxU+a/W/b+tDWNBKDcdFo fmP8ef2voLaC70j4Xww6nqSSGOW5S5hWKBRy+3LBpHxnG0YHUk7dp/Pq+8feHfEF1Le+K7TVdK1N nZ5ZHmF69zMQox80cAQcEZMjHoOeterSpuzcX73VPe3TX/gHn4hyvZLQtaJ8WL/wTNfXHw41rUre 7ntkgc2N60HmqNrMXeGYEAsrfK4dQG6ZwRi634m+K/xOWLWL/Sry/gtg0X22/vZdQNuWPOHTbtzh R85OQoHIAxuqcYv2k7Jv7/vObmk1yrY09ORIo/K8R+E45SuxStncz2CyKoIYSrEWMgbIJyVIIGCA WzyXjHxB8KtPluLbSvBywXQ+aOOK4Zvs+4Z2glC7BSdo3zEkAE8nAVPmk7U5aen6jXKumpyXhtdQ 8Rahaafo2gMUlkTfdXiSGOFT95mWPJCgHdkEnA6Emu4T4T/EO41XW/7N0m41nRtOCmW5sLM7YopC gjeVY1bDEyxqQS2GcAk5Um51qVKVpy+d9BKEpHrUH7N3xOtvC+teLtX8GTaXZadayagr6vBsLeWG ODEwLKTt4EqqGyOoYZ6nxRrHi62+HTWumeCfDMt3cJPb30y+BvDzXcMG0qpRxZ+Zbuwz+9Taw+Qh g2DXD9eo16idObtF2bTsnpf562R1ww9RL4b3XqfKvi+10aKOxj0jUZ4dVW3K3dvIrBYyVAaPylLF SrHaCVTIXJGTkeaaP4Yv9ev2077SLeRl5e4yABkDgYz0OemOK7qUpwo89Za76djKvyuq1TPqbTfh D4m8EeB/FHhyTXbS6F29rqDCDUY5LdoViMgUiCRg7N5sWSrBk2spAJO35f13SNe0XUPLeACMrwWJ w3qQxC55J6fQ1nQrU68p6WOlKvQjBR66/cUIZ3uEnl+XMRCsuRkk5HGOo4OT0/MVOZMqjugKk7Ww TuXrjgj27GtWknY7oVOeKkok1u0qiQRjBIzkHoc8HPbrXYw+LPE2n39jqkOsTTXcVsLUG6xcoYMn MZSYMjx7jnYVK98VnLXQ6FTi73R1cHxW1G71G3uPEvgfwzqMcQKpANEh0tCQOrNpBs5HPH8Tnuet ejR/HOLWra1tPEmm63Jp8Eg+w6Tb+J5JtIshkDH2PV4NQDjAOAzAdMggc5Sjre9/XX7nv+JMqOuj /r1HHxd8J9TN9q3ibR4L3xBKjCDT38IwWVjbe5m0bULAsRgncbZuv3axtQ8IfCO40e0Ona3aXPii 5kO5dO1u9gt7AHs0WpaXEuOcZ+3MBg5bHNJSnHV/5/5P8ybVYLy+/wD4JSu/gnY3mt6P4d8I+Ljf ahcRb5iLa1u44GPO0DRbrUZX7dY1PtxXTf8ADI3xA/6Ckf8A4SvjH/5UVTqxW+nzX6tP8A9rbdHk +iI0FusUhUPCzQnDAg7Tt4I4IPXPTnNLbzhbu8jjJ42vjjgHtz9APwrZ/E2fPDl1ORftDrCT5anb kgZI7Eds1sLfRNGsjSIhwDtZsdeehOai3Yu1kWUvYXSUKXO4YYrGzcYx1UEA81raRdX9vp8Nv/ZU zlF2qzFFVvT7xz09s0NK2ok2xtzqGqxCPzbNI/McqP3zNg+pBA6/U96w/Ekl6dIu4p7iMl124hQ/ NkgAAsxB6noOgoja6E9jlPDqpcaVZzINuQwA9MMcZ7+n1Ndx4I8V654U/t+TR76SMRRO+wNhH25d NwPH3d3TpjrWmKpxq0nCauhUpyp1OaL1Po74YNrHxlQjSfHIi1McSWcjeXJHx1UDO4YB6f3Tx3r2 gfssalq651vxXkf8tBKzt/Lj0/WvlsRi6WX1XS9laa/HzPap0JV6am5aM7PwZ8Kvh18Jbu71ie/0 TW4o4g0sFxJb/ard0JO+HO5g3qB1wQBnGcOL47fszXHjDxLeXPg++it98kst1em1iaefft/dQmcy SBxukLsVOQAVy3GEsVmebe0qxrS91WUW215KK2/Kx08mGwypwcNXf3tPvZrv+118H9Ex/wAIf4Nk u4VBDCK3aGbf2ALxshHfO7t78ctrH7cPiJozFofgZPsr/Iv2mTyJY2I5OVdtwxk/dArkhkWLrScs XVUb/N/cjR4yhDSknL8F97PKLz9qf4y6mtxHHrFla2cm7YPJkNxEPTzF2E9BweOvFY+haz+0H8Xd Qfwn4cvPEviPV3ie4TTdG057i4WNMFmRIUeUKuRkgcZGTzXp0cnwFG3uc7/vbaeRzyxleS0aivJa /ezzmfwZ8QvEHiC98GzeH/EN/wCKrSeS2udIlivLi9tp42KyRSW5XzUkVwVZCoZWVgRkEV7Z8Pv2 Kv2jPHysfDfwWvyyPsaO/wDJtJx/tCG5dJiM9wjcV11cXh8HTSclDyS1+5amUKVSvLmacvN/5s+u /Dv/AASq+L09zp8Xj7x5oPh+wukAhUtK915mM7Ba3Ysw+CedjsPQnNfSPhL/AIJLeDrJIINY1zxF 4h1yGX9++nLHptlKP4UMM8DydM5aO4YZ7jpXjVM3r1E44Kjfzl/l/wAH5HXHC04q9aXyX9fkfVvg j/gn7+z18PviDpGk6x4I8F6f4tu4N1hovibVXvZb1cDd5VjqVxtl4zgrG+M8DIFfb3w6+H/gXwXp Msnw08IjR7SK/MFxp2g+HDorJMBtMyRzR2iOmCR5ke4EEgE9KlUsbU5amLrP0Wif+f3MJVKMXajD 5n154Y8f3NjqP9najMqyRrG0cpkUTSrgKXliXiPn5iVyvzE/KFzX2T4d+K+ma7pNr4W+J2iprvhy KH7PbNJN5d7paBGRPsl0AzRqpKt5LrLD8h/dgktW6ajpJXi/6uiPiVuvQyvFX7N1l4l0698Q/CHU h4j0CMGWfTHgEeq6amY/9da5bzlXzFUzwGRMht2zBUfHHijwx4ns7Cb/AIRI2Merr8yLqEMrxScE BCY3Vo8nHzgPgA/K3Ss5xnRbSd09vME1L4t1v/X5H4Ff8FUdJ+NHjj4Uaf4e+N3h1tP8G23imyvL C80KFDaLK4mskL3eyaSKIrcSN5cgV3ZYvkztrxb4B+NL6b9nH4VeG/Dmp6nD4XsLC5sLLTnmCRWs iXFxDclY4j5YMs6zyu+1TKZWkZVeRgObFV8RPKOR6JVWvP4b/wCY6VOksbJrW8V+Z80ftY6sw8Jr pT2xjvbvSp9NDKBlGa80ubPbbn7O3HHrjrVj4w/Df4bLJBC/hvS4LRV1LzBY20VsS4s7hrdi8G0n ZMsbDnB2jOQa6svr1IQyxQk1Fuaavo/e0uiK9KEpYm6u7K33Hnmp+BtIsvhay+GfDBTxFHoc227t dPxJdXB02e2zLKihmIN0zgl/vbTyFIr3S18Na1cmbV7nUzKwhMkX+krtbgkMixBVG7gZVV9cYJrh xWIqVNakuaSlLXfR7fr+h1UKdOjeKitUtvmflgvxc1P4M/Ev4oaNZ+FdMuBc6qLJRrMc08UMdobi 2jYBSHYFZSSeT8igDHFfPmvazc694ovrq+dVuJn/ANIeEbVC5DMFUfKqBgWVAONo9K+7w2GhCo8T FtuUY+miR81UqNpU76Jsw/7QnudRe9jiJiL4+QZ2IOFXBOQAAAATgYFegx6nfLbQLbRlZIlLxJKd p3FcgIP4xlQQBnk46it6sOZxTJjKybR+1/7BfimKfwfDoRhCHypbZN8vzl4HM4Cp/D8l3IM8fLbD HAwP0h8MWX9nNK0T5kGw78KpdgADkIoUE4JO1VGSeOa56dnQs/NHoc2to/at+B+IHx7+Ftz8IPjJ 8Q/DOmWLJolzbf2voMUUbDzbW43iKOMEsz+XIslrkkl3tyQOcV8UeLvDPiHwDe+GNN8Z+A7oSFJV m0/U4Lq0bPmTBcn5HQruJHbI5BHFYYT+NJX1dvyMMS7xT/rc2rH4dfED44eJLH4f/B74c39xfmxe 4j0LSy2oyMsCB5pITKBIpJHKbiWZ9iZ3COv6lNU/YU8YfGv4S33wl+INpZ+C/B0NvJpOkLdRQ31x DBBCPsNxa2drOcRJiPbFNPBMgiIeIdCsdXUJ04R96a1tt6Psgw0HLmk1Zd/0O0+DX7G/7C37K/2C 98JfD0+LfHFmxltde8YPDqVxasZI5kaCIRx2du8ckYaOeOBJ1GR5pyc+++Kv2gtV1VXQSpFCAQoz 9zpjA4GMcd/1rk9lKUvbYh69ui66HZFNL3TwzUvifZAyXGq3iM5JG64n2xpnvnIUfie/tW54S/aP +C2la7D4c8S/Eiy07USC/lxWd5eSOqqXPkpaQyGbAHO3OMg8gE051IxjeWtum39eY3CT0SPujwD8 Y/2WrfSm1/Tvix4fhmRC8+peIdQg0uaMbSCdl+YnhXBOcKODjpXbaL8Qfhv8VES++Hfj7RfEOn7N y3GiatZ38bZ7q9tJIjDIIyD2PQ5FeNiVWk/aVYtfL8EdEI2WhqS2EMbGMsqSjjBYg/l+BrIvdDtb khpPLY4HO3p759q4mlvYpK61Ob1rwgNRtlgfbKqcRrJK42dwVPOCDggjkEcc18bfFb9mv4m+Pry0 fX/F8HiLw3FHcRjQfEVqt3ZO7PbGCU+Y5w0SQzJgxsJPtTFgCikdNCooybk3fv2InDTRXPm3xd+w l4W8QaMLXxV+zv8AD+WBQ2INA8J6Xp08hxx/pVtaQy9eNxkBGc8/dPyvF/wTp+FV38NtDufF/wCy lZ6L4oayj/taLSPEviC5uIrnYPO8qKXVLi32b92wbHONu4Zzj06WPxVONlXu/wC9rp6u/wCZyTw9 KT1hb0PNPFP/AAS8+GHibSbfRfCeufE3QJ7mzZRr2vapaXel6e0Wx2jm05bC3klRl8yJGN6hXCvh ghiKeFv+CR/j3wp4e0RvC3j/AMLXNx9nkle8vPDMN1JcTs+6KaGV0EiIYxH+6aR1DF2HBFbVs0vS jTrQtfVuDt8vUzhhEptwfyZ8++Iv+CaH7Z1t4u+wpFaahoc4MV5rOnavaRtLayPDJJE0Ny0L3TKY 0dYpWEfmRjDgfPX1dafsz+OPCvwwsPB2p/DNLjVbG0EUjvolrcTXEwT55meASpuYjPyyPjdgNgZr HF4jD11Qp4abik9d79rO+/rcdKnUU5Or1Pyw8TeP/wBpfxl4jn8JfEP4QawNHSdyYbvSJbOeBSx2 CR5UijOBxhlTcVxxXp3hLxB4qsIdb0zVPhnrl7faskVq090sVr9gt4yysI5XLwZ8ttqZfAAUdiK6 K8cHhP3NKrHlXK7N3ejv+Prc6MH7Ry53Fq19Ut+3/Dnzl428VeDvDnxR8QaBqGix3XhK0u761hWf T7AXPkzSRvHJJ9nJX7SEjVXYSv8AMzKGGMnW0O0+BVjanUdO8Qtb+JLvzo5/tcM9mYYZMk/xNGqe WPLKs7ZDk5HOd50sVTpp0JOUJ2dr3aW/XXW/Q5faUZVH7SKU03r3Z7lB8KfC978P9D8W6bqk0+1W 23Npct5Mi+dJ8pKnLbT8uQfYE4FfIPjzW4/B7/EHQbXwPa6nZ63Zw2lxfS2sd1PpRSVZo5LeWRXl t3Z40BaN4y6Bo2JSRlPZgrJc7dtbfO+zJqTk+Vpnzvb2Fta26SW8dwCygy+fCIiH5yF+Zsj3OCT2 GOdK10HU7yMNBbnyXdQWYqq88ZGSC2Oc4z+tbVJpSbbPUh+5wsZTX+ep6noM134curBLa/LXKYEc uAQSRtKsrZDAgkbSCGBKnOeem1fwV4p+J3ikJ4X8K2sd+bUSG3S6ghNywy0kiid1JbnPlqTgLkDA OOJzjCTqSdlb+vuOzDzjWoqovR+Vv6/E4afwPd6HfSaJ42t73RtTbi2lu7XMEpJCjecqyICHzKol B6bRgk854z8Na14KmjttVkQBgdskcLFHx2ztyrY5KyKjjIOMEE705KclHvqn0ZniOWlBzb0Wh5/J qMgcs0h2sMjK9jzxke9C61LGpCzKVIxg+ldPsr9DhjiY/wA5Uku97E5X8P1pnnf9NBVKOlhSrRPt bTPgq4tre11HWwJFG0GNA24ZJ/iAz1wOuAAOmK858UeErLQdcu9PS7d9zBI3JK+YxAbAX6kjvXmY bHuvVcFGytc8+thvZQUr9TBm0dI0k84Yi6vuYHcVHfvSaPf6cLfy54TLKFXeuzJyBg9gPT613LU5 tEnc1H8W2cAVFtAmBjZLJHGen48de3p71Y0bxXbazqY0wQbGYExhSXX5QWYH5QPug9Pal7N2bFdb G5rcccCWjM/AlAJIByMZ49uDXMaw9reXNzMsqiztkX5i4XzZG57/AN0e3BalTvf7wZzfg1YBYXdq pDIl5LGoLfwgLj/P1rWa4srPWYX4NnMMSqoADDO1geh+65/LnNb1U3FpdiIfFqZGs2Oq/DvxHDqX hvVZgq7bi3uI+Hi5OFbs/QZ7HPTtVjWfjB8TvEiquq+MLuSYEkSJsjkGef8AWIA2PQbq5HhsNi3C vXppyXf+tfmdcK9ajeFOVkd7rEI1HR/CuqahcXF5eT22+WS4neUs42g4OT3OP1rZ8JfCr4g+OhbX ngjwHqF5pouDA9za6fI8KONh2GfAjVlDKx3MOGU4wa5VWp0aUpVGoxTa7Lex0ypynUtBNtpeZ9Ve E/2Gv2ivFcojfw3Bp8GQPtN1epNFk/wn7F9odSPTaMfy9z8Lf8E1/Ed201r4u+LGkWOsRP5k1lZR C8fy+o4aWOYMV/6YHk968ivnOHjdUIub+5ffv+B20sHUf8SSX4s+r/An/BMj4YRf2RrMfhrx74o3 nE1pBYTLbMo6yMTFYyRAZ7SP26nr7vov7Lv7P3gq78ZeD7PwP4f0ia3sjcXNrqPjWYauYhy6zWcL fbzDxkwpcsrkAFSa4fruZYianFqEV2Wnzvuu/Q2dDCwvGXvfi/wPorS9Z8OXml+GtV8JaWbm0M0X n2ngP4cWOlR22Pl3NY6utvFGjY3EwgGQkuSzMWr1WHRfGF3rOuafceElgs9SURaHeeIfGc5t76Uj 7s+hRxJbqAc5WK66DrzWSw9KdSVWd5ybu+3+X3XLdSUIqEfdVuruy/5U3gbS7J9X+IPh/wAKaroL Kuoad4e8O6dpyamSOnleI2vQyDk5gkQ9MN2PAal8Y/2bdJm1jTdT8R674v8ADeuRtPqFleXut6zY C5B3BP7Pu92lQKDyBC8a8fKAMY6Pb0qC3S9P8/8AhjNU5VHdL7zhZP2uIPDegaX4b+GPwoTToNPf NqgFnYafJDnhfscYuPLHTOyVece+Plv9oT9sL9o77BpsHgzV9J0Ya1rlpYSxWWkfbTbGYkbll1J5 4FUMqAIsAYmQgYOCudDH06mLhTcbqTtvr9//AA3qFWg4UXKMtV5dCp4h+IvxG1iwZvFvj/WNQtQo Drd3ihDjqY4oVjhiJJH3FC9BtAxXvvwD/a88dfCD7Jo1882tfDbzgv2G5lX7XZL8oc2UjYwFTDfZ 3byyUIQxGRnPm0sXNVuap8L3X+W+q9fLqdfsouFl0P2o+DP7Q3h7x3oelePfhn4taW2+VhJbzvBd 6dLjPlyp8sltMOeDg4+ZSysrH3Hxn8UpfiDKl/4q0u0m1wFvN1G3hS3uJ8nP77ywElYc/OVDnd8z NgAezPWPJe63X/A8mcbSTtJanll9punXkcsaSK8DqQVcYOCDkEd+MjiviH4g/sD/AAd8T6TJZfD+ K38E3QVhbJo2nQ/2bEzMCxOnx+VGASWciFoCzyMzMSTnkrUvaU+R+tunkEJcslJLX9D8MP2qf2J/ 2jvhfd6lqHxK0CHWfhzY2Go6lbeJ/D3m3NnAsFpPOqXayMJ7Rv3MYZpIlgDSrGk0jHA8Je7t/iN4 a8A2+kbJtS1L7NLItuqvLF5qFXyqkkYYlTlcAgg9K61Tp0qWC5HpGbvfpe17snn9pVqq1m0tD0Tw 1oPii40e0hk0eaJkR4gLuNoiqKSE3I+wfdC8cEYx1FHgPSL/AMNeG9G8O61ZNZyaeH0uKOWRQbm3 t3a3gm8wEoTLDEkhBPJk+mPDr1abdWKevNdenvX/ADR2KnJKDtbQ/DT4q63bN8bPiOmuhn0uXxPe XEpMatJbb7l3LRjKhgN27ZkBsDOKzdWv/DXhC7sP7K0P7TqsthFcR3V9c+csXmhZUb7MYwgZ1Ylk lMyFZeMcEfplGMnRpWejivyR8rOynLvdnMWN3qN9JNHLoq3F88odbkxzPNEACNqqrhCDnoynG0YI ANe7W9p4k1drGa68Dx3dzBayW6wXFlFZIGeJo0lL2zW8ryROyTIGcqXiQOkib0eMTOlRcXOVl69P Lv8AiaUYSq3SVz6S+BGueP8Awbrh03RdTt9K1Oa2M1zfTlVWw2QzRq4EwZQn78byI2fau5QuK/oa 0q3eKMiVVWf5TtV96q3PAJALc57DPoDxVUZYaWCXsr8922+lnov68zptUjU9/ayt6nl/xe/ZH8F/ tQ2mk6L4t8Xf8I5cRCSFNei0mG+e1tpSpffbvNb/AGgKY1dEaeMI28gje+bfwh/4Jn/sZfs+arpX i3xX8YvE/jTxZpolNmdKupvDFneQy+YIpHj0y4muo7mISEkjUkU7UUocYPDL20HKNNKz1u9l8vX/ AIYHBSd29EfXdz+0j8MPhVpup+HPhZ4P0Lw5oUsk0k8VhaQ2r37smxLmWO12s1zgAtLJJMXbli3O fmD4i/tfajdWxFwby9W4ZGEcUK29q0ka+WkjqoVdwXq4Qucs3JY546lfCYZ8s6l5v5v+v6R1U6NS a92NkeG33xq8Wvod/qz6hGyrD5jNJEirEwGGYHIbaCCOWIwM9a+bZfjP4w8XXF09v4muo4IwolSK xeGKTcTgpJKmZOg5jcgBhkDIJ+cnjcW4Talom93t5f1c9aFCDV2trHknijwx4m12O4hg8Xa1cQPI s8cFxq8m21nB6j5iZom3Nut5CwJ2bHjVWWTf8GfBHQ9R1fR7p9O1QeKLYyeTLarudVzuBVoI0ZWG B8zOSAowRjA3o5pFKPM0pWs+z8/n5nNVws3Ny5m1ul/XY+pPCvwj8I/CvxFf/FO6bxbqnjVrNvsB 8Y+Ko9STQpGkil3aaxgS5spwyFEuhN5qxyMm75nMnlPxQ8djxZ4u8Xa0tlci1u5pJo2mlM08xORu cNJIWLZ3MWmkOScs5+YmMzGGNmnGW1tlZaf1/ka4XCyoptvfvueOeD/FXiHwTq02peC9VvdHv3PM 9jLLaSA4yAWjxzyBwc/1765+JP7bfjX4k6Jpfwd/aL8WW/i02zyrFqviK+vLGFFK5lnhuvPg8teA Syc7wqhmZVO+Gr4dV4zxC54dVZMWMhJ0G4WUtD758XeJ/wDgo/ph+EsXgb9pyz12RNMubbxbJqPh nwvbWX9o+TK9rcQ+Rp8Fy1oZvKhljTzLhUXzEVyzKnwn46/4LRft5/CXxPeeAPiF8GvhxD4gsWC3 WdP1oSyjAIKsmpmEggjlV4PBwQa9ehhMuxl4xTpzS1Sem7/mvf5Hj1KuJo+9JJrvb/I9yg/4Lwax pWi2w8Rfsy297rO7bLLZeMWtIc4YnbG+nzsOgwDIevWvS/CP/Bez9m+70xj8Rvgx4507XwxzbaJB peqW+BgD9/Pd2jHnP/LL061nHKJVY81Kovmrfir/AJGlTFQg0pR3PevA/wDwWR/YE8WxR3ninxJq 3hWRslE13w1eyucHHXTI7tRyCPvD+tfcH7PP7eP/AATG+MfjL/hGfFH7WdhodojKWnvdPOlW7AMV kR7rWWs0t2wPlYpKODkDjdhPK8XGaThdeTv+Gj/Aca9OSvB/efpQfiR/wSWuNX0fwT8F/jV4Q+K3 xGv5hHb6JpvxV003cjMcbB/Z8BhIB9X6Z59fV/Gf7MOk6c9jKf2MdSjjnXfHFpXii91aUDqN72cM qp+KDOfWtamHpUoqEqb5vNW/McJy3lJf153aPln4j/BH4R6L9q02/wDhz4p0HxOwxHBqWqIY4hzn MEunxytnPJ8wdOlfGGvfs0fDLVJ7maTwzpF1KWLO8umQlmPHJyhzxjr6V5dWjFu/Lb+vU1jJrWL+ Z8Z+NP8Aglv+x94u1fWfEWufCi0k1m+keWaa31rVLXMj5ZmEUFykYJJJ+5jrXy94v/4Irfs76+91 Lb+L/Ftm7KY4I4tUs5IoBuJUfv7V5GHzY+aQn3716NLM8bRUU0pJbXXT1VvyZy1MLSk3JaMs+Ff+ CX+peBPhnZfDPSPis1zptqZzbyT6SgdhJcPcYcrN237SwHOOgzgfKk3/AATG/ao8KeM9X8T+G/E3 hi58LXdvJY6rpIurwS6/YvzJaThrdEEbkIQfPBikSKeMrLDG67wzOjyy9pTacm3pqrt38ma0YSoS jNa2X49z59+Jn/BNL44azqt9qnh74RahoWhi7kxNd69pd5tgZiUSKw06GSX5VIXc8zl9pZiC2B8Y fFz9m/x18KtD0/ULjwl4ogsod63Wo6p4O1nT4JXJ7S3ESptA24HUHdy2Rj0KWJw9VqNKab7Xs/ul qzor1HXi/bWfp09D5I12bVLaa2ddR37UDgRbx5ZJOc7lGTx7jke9dT4T+Jt/4f1PTr/WLe5uLSKT zEmsLtbS7ikUExvHK0cqqVk2Od0bEhNuRncOurh4VYcstH/W5xYfF1cJ7RUrSi1Zp/n6o/Wu0/bY /Y/+M2ix+H/iX8J9W0G+uZSrtEkeo21ivZ1uEKTbsdQlr6jkZFfIXjnxv8HrjVtW+H8OrDVvhpaX DRaVqEFs9vOlvJtk+UzwIyuhO1g8YG5H2FVbcfMp4TE4aPLJqXLqmvuaa/E68PiKVeLo1JaNbvo/ PyPmPxp4NtNDm0GDwlrP9uWl3mGKe2tAhaVpWEcIiEju0pUplSq/MWVPMVRI31D4C/YN+KmsaND4 n8b6Hcafp7r5y2qhGulXqDLGHLR8A5UjI+ta4zM6ODoQnPSc9o/nfyR5lPDSlWdNvRbsz/F37NVl Z2tzFoL3CXkSn5JGdkbb97eDnA9/0ryL/hQ3ir/p0/76b/4mpw2ZU6lO9ZWfkVWwrUv3T08xmpft DeMGWOGHR7a0nCKHEoLBzjsrHjPoc9uayfEvx0+LHifwroPgvxF4t1K48F2d6NVsdKlvLoafFcqJ UFxHZ+Z9mSQeZMvmrHv+d/m+Zq68Ll1LDvnTu31MsVi1VShC/wAzi9M8UPHqNvLrsu7SNxNxHCqx Fk6kBkAIPoc8HHUcVg6p4h0S5nFvZrO1uzMTLM2WiUkbQD1bCjn7vJPFdqglL3VocifNHXc7vT/D +lrBDNkXAkXKszOVbPIIC7eucYJPQ11mlTnazROLdAwTy4Io0DcDk4BJzWM5OV7/AHFJW2H6jNbx 27SSu89xv2xq7sw3duCcAevT8Kz2hhs7I24UbgPmbuzc555689/0FStvmM8vi1mTRdR1VY4PMV5c 4V9o559D61Je6tq90InOmGKMuPLLK4wSOmSRkY/lXRba5KVtWz1LTrLxDc295B4yQB5Fzbt+6bAH JB8r3I6+przR7VYDOoILK5AUAZx6gfnXNT5eaUYbGzT5VJn0joHhyPVPAPhm6L/P5r5ZiTwGcYA6 ADAPGefevrr4EfF7x/8ADLRLiw8G6no1vBp1xbtdSr4e0s3VzbSyu0iT3Swi5lA3OVYzB0VQiuqK FHg4m1WFWjNXXM/LqexSXs+Wqnulv6H6MeGfjXY/EHTobPxH4lurHVlkBNt9oWZ3JPW3eTIkzz8u Nw7j7pPTauvw+g8N6u+v+OfiXq2l6aD/AGjZG7udFsrGJwAfl1PVNHsbjflRiIzk4wQAa8PA4bER qSjCSi+7V/mlqm/k2duIqUkouS36fmcdbab+yv4b8Q+GvEvgf4NaTqMSIs8eo/2jDa3MiSBXLZsr C9WZ1z957gZKkqzL8x+h/wDhfXgrSYNWj8E/A+K11e52GDVJGtyEbO5gQ6zNNjt8sYIAOAc1VStF NqtOVSSb+Lb5L/gIiEHKKlFKKfbcj1T9p/4yaheQTWEemaPmzFpLbWllNdRT9QXYTytCHOP4Yh1r zK98bePtTsYdF1H4hav/AGajPKumRXPl28ZY5O2OEIFNcdTGVJe6tF/XmbRpwi9Vc5ITQx3yRKsY vpDl3lhDtJjr8wOcj1J71sbJ3/eG5KjGduERFGO2ctxgd+/WuJc017xpfW5Xnnst7ObgzyZyAFMn TrkcgfkK5Dxf4i0LTNGGoeI4oU063njukW6kEeZrZhdRsi5BPlmDzj0CpE7viNXIqgqk60Y0E3PS xNTk5G6jtHqekeE9F+G/jLSj4oX4vaTdaTFALm4InjtI7WPC7pWa4IzGGdV83GzLDk5Bq7JqHwrh S9i8O6ums3Vgu0f2fKtzFI5AYxrOCLRnwRx5nG4dM84yp4mE5U5U3G27/wCCXGVKy5ZXuT+FvjR4 68CXcfiD4WeEJdNvGQiRtR1OK3fc2NwkgtobqG6TjdsaVM7VOQQMfpv8Ef20/C/jrV9P8BfFC2h8 MfE+4htZbRWc/wBm64J8IptJnJMUnnERfZpm3F5YkiknYtt+kyqg6+HqQhNylCz20s76K+ulr7I5 MVLlnFyja+n/AA//AA59ufbEG4g4x78EVYN2pHynAPc5rdQW5hZ9hj3JZlw4DoQwI6gjkfyGK+Rf i5+yR8OfH63mreFo4fD3iuQhhdW1r5trI2VG6W0WSJXwquP3bxEs5Zy2MVx4nCRrwa2ZrSqulNTS Pxo/aU+H/wC0T+ztMNZ8X6FJJ4IUAf234asReWCbjEMXDvl7TLzJEvnLGJH3CMvjdXwpqnx7+I99 4h0rSNE8E3HiC91B47awR9b07TkmkkZVUIgcSMwLBcbACe+BWOFyT265pzSXVu7a+SNcRmcIxlCM W2fF/wAdv2S/iLDJ4w+Kvi7xb4N0zWZbuNpvCia8kurRFzGgxBEJFxg72YyDhX7gCvmrxp8Odbbx Z4jmtFgTT11CWOBTKQUiDlY1Ax02hQAPTAr7rC4ik6MFG9orlTateyWp8xVjPnbfXU9V+Engzxt4 o12HRNM8NPczQSRx/wBpGeGztYy4YItxcTukERYI4UOwLFTjJGa+sof2dvjjZWqXNxJo1vo+5XM3 /CV+HZPJGcbyyXhdgpByAjNgdM8V5WZYnAwrWrTu+yTb9NE/uO/B0sVKP7mOje/T8TzXT/GnwZ8F anff8JR8UNQvtVsnlijOjaQb62nJVoywM9xaYB3kbiqlSAQkqtiv0v8AAf8AwUj/AGfv+ES8O2Ov +NdniO20xI9Qurm11N/tVwmVLosVpjLqglcMVVGkKK0gXcfQwVKsqclKnyRe2q/FdPvZFapTUl+8 5mt9/wCmfJfjr/grn4zvHvrT4cfDu2tYRKfIu9Ru3lLxc43QR7QrY5wJGx0ya9k/ZS/aR+Iv7T1t 47i8d3EUF1pr2vltp++KKVJ/NO1kaRjkGPqB06+/BxH7fDZVVxFCpyyi47ebS33676G+WThVxcKc o3Tvv5K/p+Z9SReBjb6kt4Bu/dSksSTn5GxnOOM9vUiqvxA0T7Lp9kkQ+SBY2y3Ge34Yr86wleVS anJ3dz6WtTa0itLHJW8bXGnJptuuJJUMYCkgEtICNx6j7/t0rpdR/Zy1PQFdvFviW2hRXBC20bSC aPuQ8hj2n6o2OvPSt8bVdOail3/Qzw70fXY5c6P8PdCgJTV/tF0CMRpN5rSEcDJC+WCODjBPX8eX vfG3iqNGsfDxezsM4RIm2uq/3gQcDp2x/KooU6k/frrR7FVHFS0PPb7xaYrx5de1syXBAT97Nvfv xnJ4J5xweKrS65PKjro2k3N7Kc/M6iNBnrneQCOvTOa9RUoQip1Gox/rZGWrl7mrMEaJ8RdWWI3F 9Z2Fpgr5duRK8eTgYLBQCPTB4I65r0fwPbfED4bam154J8VKlzdPBLqMl6ssonEJOzagkSPIDuAP kGHbDLkkw8ww9OcYUoPl6vqxSouUHzvX8D7a8Q/tEeM7a4ttF8P+F9CvdE+wxGLVnv5oZpJdibkk ja1/dur7sOm8FUQhlJKrzHhzwt41+Lq3UbeH9IntxGlld2lqYo7YQ5x5k63DvcXLHczPI+8tnbnC qBeLr0sRGNLDOTne6e1vTW9/PzMadP2Kcqi06rc7z/h2v8C/G3lr8S9B0WGCN2VY/DEdzZb4sdd8 bxKJBz8zxSDrnIOK43xX/wAEev2frm0sE+G/j/V9Mu4lbzpNe0+x1Yz/ANwAwJZmP/aZvMJ64r3s sxeNwdPlxD9ovPf/AMC/zuedicPRry5oe6/66Hw38RP+CRPx50I6xc+HI/D/AIi04KZrcaVqDWlw inA2eTcrGpbPO1Xce/p+ZHxa/Zn/AGmvhZrWuL4u+C/iK1iuYHmlnOkyzQmLeGL+bFvRenXdkDNe 7Sx+Dr2Upckn0lp1vvt+PyPOnhq1K7SuvL/I+Z9LtdRvJZ47eBjKImOzcFIIyxOCewRqk0jWPEWh 3mj6vY3l5aXJl8yC4heSNztPLRupB4I6juK9aNSS2kcqco7Ox9u+H/8AgoR+3Xb6Rc+FbD9tn4tR +GUKxLpafEXXhamIKoCNb/adhXqNpXHB4r3Lwj/wVW/b98M6Pc6VYfH+e6VEVVl1fRNJ1GSNfLLZ El1bu3Y9c1w4rC4bEXlVpq/dJL8jania0Xa9/U9T8D/8Fq/2rvDPlp4xtfD/AIlLOfOudT0hIpMd wq6c1ov0Jz29K/QD9mH/AIKQftQftE3d9N4c/ZrsNZ0GC4MEtzYm80y1gZRG7K11cPcxF1WRHaJN 0u11IjIIz4uNwEcLB1oz93119Ff/ADO+niKdR8ri0/vR+hXir9pXWvBEFzP4m+Ed7bRIMxiS+QG4 xxhC0YTceMAsAc8kV4bZ/wDBT/8AZ81OSSG18KeKpXijNxNLDp9g8UaD7zZN2HKjudnQEniuGdG0 IzvdP+ulzenF1L2svU99039rb9nrUvCd34yvvFpsdMhTzXgvLG5Fzt6DZCkbPMx/hSMOzdQCK2/D /wC0P+zV4ysVvtP+K2gxQBRJ/wATS7TTpF6EZS88px9MA57VjOn7kZyWj28/QIxnK6jrYwfEPwN/ ZO/aGa+vtR8KeCPFd9NEbeS/jt9OvrpU9FuY90seBjBVwR2r46+If/BGf9jzxY1v/Yeha34ZZFZX XRdakPntyAZBfrc4xkcJs4GPeuijj8Xh2kp3XaWv56r5E8kU3ePqfEfjL/gh/wCM9Gs72T4VfHSy u7p5GSK11zSpbaOFCMLuuLeSYswGMkQL06V8AfEr/glX+2P8Jo9Y1GH4f2PiDw7p1sbqfUPDmsg7 0UbmEcM7Q3UrAD7qwMeOM4r18NmmGqy5asXCUrb6r7/+AcU8NJawZk/8E+vhpZeJPGPi74ieJbCS 4Ojxw2eim43EQ3EhLSTK2QrPHFH5QVlIxclwFZFI/cfw9dXdq1vcWd+yXETCSMq5BjYEsCpHIPQg 56181nlRVcxqRauoJRXlom/xbOvBxtRbe7/4Y+Nv2rtKXwL4kn1CFbaGHWrCDVI1hTER81SsmwDa FAnSYFVGxWRlUbVAr4i/4SiX/n7j/IVth0pU1J9bfkjolZWffv8A8MfAvxA8My6Pr1tHfzR75Ygy smeSCR6ew/A10GrfEPxB4j8I+HPBeraVo5sNKLGC5tvDem2t9KCMBbi/ghjublR2WaVwp6V9nhpR r0KdRev6Hz1ZOFScH3OFubS2n/s+VUTzFmBkRsnK5JAORyODx0xW3o/hjRk1ScmISICrIjFisWVD beQM4yQc56cZHJqUnFtIUUmrnuuieANe8RafDqNn9mjsHYqrzSngqdvRQduCP4tvauth+EkenRm5 1HxKm44eRI4RtQDnO9nAxz1xXmVcbCDlCMXJrR9Drp4aU4qTaSG+FvA/h/U57rW7lZpdHBKWEc7m MvHjDSkqAx3nlQNuFwTnPHo1v4Q8N2qtLD4bs3jPP75Wn2jjoshbnpjjv3rkrYys5OEXa3b8dTen h6SipS1bOb8fWscXg65t7Oyjit4pYpBFDCqLneFJAA5+Ut26etfMviISTWM5jUeamHBA5+X5sAj1 x6dBXo5dLmott3af6I5MXFQqpRWljtbTVkvtF0m7MhKCHDEKSSflycD3BFeX6ncPbXNx5ZRMucu/ UYPGPm4/EGroR/eyQS1p6HbfD5RrC3nmzpcGDOVZV2oDtPQDBJwa+nvg/CLXxldabCgit59KluGE WF3NDNCoUgdf9c+Dj/6/nY2X7yrT2Vn/AJ3PTw0f9mhUa1T/AOAfRfwi8R6L4ivJdH8R+MZdP0l5 4xc32lWktxJbRvtuYY3t3eAytBJ5attfaTDvRpPl3fr74Y/Yz/Zn8WW3hrx7OB4qSa1DprCXTWy6 lJtWMySmzMU29fLCGCZ28va0brncK8+pCWHqOdB/Dp8mvxTKi/a4eLa339T6Jufg78OZrNbJPC1s sIGAxQtJ653sd+e+c5ryDxP+zrYzvLc+G7+WBs5CSEyR7fQDIYc98t9K8ephFKLcdGbxrTW7PCvE Hwt8Z+Hz59zpKXNoMDfDHJIe3G1cse/8PbOeM1w32iSMNbiAIVYgDYwKnv8AeAx25wa4JQlSaUlZ nXGcZrRmBNatdz42gR7wTujQ45BPJ+nXGRkjIyav2zxJPHEoChQ3nTAxkA9fvFMnqeP9qsLXdmWt FZDrxzMMQ3l1IV+YP8iIe4IbC578rmvL/G3gzwj498Py+HPGdrb3Vi0omCh5y6yAMoYPEyODhiOC OMjvVU5zo1IVaUrOLumTOMKkZU5LR7nxnrv7Nfj/AOH15Nrv7Pvji+ijBMp0nU2URuQGJ8tjlWYY RU8xAQefM4FcL4j/AGtvjXo/jXVL/wCMt1rOneJJNHXTZZ4l+0nUnt55HidZLhpN+0TzrvErqRtU EBQK+qozw2cw5akUsQlqtlLzXbo+/qjzE6mAqLW9O+/Y9a/Z/wDiHb/GCa6h8XfFi+tdMlcx/Z/t d55isEjDEQQMiHl5M5AUDqw5z9teLXe9t7aV70xwXFkjbzGyhgYwpO4NyODkH9Biu/J6M8JmVeg4 WgkrPTXe/n95WPrxxOGpThvrc+sv2d/20fGvwtNn4T+Jl5c+Ivh1HCpivypOp6UJN5VUZgv2uFdi jy5DvUSkpKViSA/sX4U8U6L408MeHfGXhXURe+FdWtzdadfxBhHdxiR4XK7gCCksUsLqQGSSKSNw royjTM8NGhVdSmvdfTs/8iMPU9pBJrVHTb3Yjc+D7c/560396rHHORjnPPPGf89q8qyehvbsQCWQ MyzJgkFT7gghuR6gkV+W/wC0l/wSE/Za+OEN34i+Dez4afE54SDHp9ukmh6g+QAPsg2C0/dqkYER iUMZZpGlLBBVGpVw83Ok733Xdf1szGtShVjbr37H8/3x8/YC/aG/Zjup1+IvgqW60Nhm18QWEcd3 ptxn5UKzth4d7gqiTJC7gFlQjBr5xuvBlrdF/tEey+xukDqEG4/U8nOfXODivXjio1IqpFnmum43 Ujb8NwSeHrG8tLSO4WZmyGhO4bgMEBSCuSQpztOQF7V9EfDj4yXugW0yXln5kLQCCS4025n0u6GF 5yYw8UwznCiONT0LV5OaYJ4mDcHaTd779Oq6/mepgsT7G1N7W7/kzzHw/wDszfsp+M9Re8uPHeva ZqVxKZDa6xcWdtCNxJ/10MHkIMnAUSZ5r6c0P/gn58Bljgk/sFb+3ZVdbj+075xLnkYMUqqQfXFe Nj+I89wv7qcYwVrJpXv83c7MPlWX1r1E3Lyb2/BHrMP7MH7Nvwv8Oa7408S/DWwl8PaZbGSWJdGF /LPM7pFbwp5odmd5pI0ALxBskNLCuZU+9/2P734J+JvA+i6G/wCztoPheHV4GubTT7eWG6meCT96 jm9ggtZVypLY+8kR3+aCGSuzApZhlsMVnFecnWqezhG75bpN3srLdW23aMq8Vh8VKjgoKPs48zdt d+++xznxd8G/8K68S3mgWaM0MkAu7FrmZS7wMxADMqjkFGXd5cZYYkEaBgo+dPF/i3SYIrs66vkH ygo2ESByW6Ig+cDJ5YgAckmvlVQ+pY+pgpy1jLTz7fhY9uM3Ww8a8dU1qjk5bv4e+BE8Ka18dvi3 pHgLwhq4tZLGbVYb281G8s5vOMd7b6Zp0U93JaHyDtuWjjhf5Qsjnivprxj4G0vxV4E0T40/D34h 3HxG+FmrrJ/ZOs6bpl3ai9EU/wBllY2V+qXMSC4WWPd5TEeRIzqirmvoK+TYx0FjXFKPS+9u/e2n zseTDG0fa+wT/wAj5zutEv7+ZY9B8G21jBLMUU3bG6nVFUlj5aDyXBCs3IUgDnvXGaj8Pdbd3Op6 vNKhUkwwYggD5JLIqAMvbjJ6V4bxsKKSp+83f3n5dl+rPQjS7nJXHgyGyfK6UA7MAZAMuSOmTznj A59ai/s1baORIQUAOWOAvGee/vnp3rJ4irUd5SubpW0SBWuI3WQ3O8gnblc4698kjsPXg1uQ6lCk uZoFY4CknGSP4c57DPA7Fqa8mS0rbG+mr2zwxqCI+oG0EYHoR+VIsl3FdrcxXzNtKNEBGP3ZBB3B uuR1yMHj1quaUHp8iHFbdz2Pwz8fPirpMsIg8UXd5YeZ5rw6jG1wXwMbTLOPNCnHRHU8D8fo3wN+ 1Hq2sXMOk6x4esLfUpG4uZNTaztxwcD96khHYD52Zj0B4FethcyfMqVTX+vPT8TirYdO8oKx9I3P iL4hXMUsMNxpemFt6iZlm1ItnhWAP2URkAfxCRSevFeVeIX8PX2r2PgH4jfHa4m8WalZjZoLa1pt lJqEYYsssenRoskiq8TEOVkG5Dk5GB7M6M8QnFbW1tq7dfRf1c5FNU9ba+f+R8/fEj9k+w8Qi1uI 7DR/EkNuJPs1rrmn2zzW6l+EiNwrRnhuXzEMg4WvhLX/ANkb4beGtW0qeXwJdeHPENtJO8E1vNKg kRt6SKsdwZImiJJx5a47qcEk8EK+Z5Wv9nqc1P8Aleq/4HyZpKhhcZrUjaXdaP8A4PzPOfEH7JXw o1W3ZYNMgFwC7Rs8DRSMzHJaSaIgucnjchAwBjFfLvif9kbxx4W1LWR4YhbU9CNiCJVvbYyJIBKC iK3lSHA8vAER+/j6+zhOJKFWHJi04S+9fetvmvmefWyqpCX7l8y/E52P9gP9r+X4caR8YL74Fa/p nwt1FmTSte1myk0+x1hlOD9lmuQizjPG9SVJBGcgiv6pP2NNYHgn9mD4CeEZ/DdlaPYeEdKFxb2l vHbKty9tFJcswiGx5JJ3llkkwTI7u7FixY6ZniMLjqlHC06nvaysu2yf5oxw1OdNurOOmx6Jbjw5 4M8X3fjjTfEXi+SeVJWOmXvi7U73TlMjFmaO3u3lSHBPy+XtCDCqAvFfL/xpuPhH8RNW8Vaprnw7 0mx8Q3OjX9ve69BbuL6/NysEG2WeHynmXaAAX81lx8hQF90U8JUjXjWckr2VkrJ69tjqVW7UUtT+ bzxnrd9Zab4rsdI1kjQp5Zd1vHKwjuF3nG5QdrZz3rhNC/ax8RaYGS/ecqJNwj2xzI3XLMWIwfov erWWrGRnFvWMnbofX8XVaeCqYT2UIrmjduKWr03PW9K/aw8P6q8cepPAHKhpWwYCp5BId8bjyOAO g+leo+FPj1ZaTJb6p4U8Vahpckhwbiyu5LY9fvCeJkc9OuD05NcNTL8ZhNNWvwPm6WMoV/dWj/ru dnqv7Qf7QN9qcev+FP2tPGlneqf+PW9169voJSGBG2G7leJfc7SGAxxyT6zpn7af7ZWraddaBrnx jluNPubd7aaaPQNFgmMbqVdo5orVZI2wTiRXDKcMrKwBF/WaSpR9rRSnHrtf5KyE6V6rmn7unRI8 78IeINQ+Hcd3FoF0senzTtdzx3FsGDTlVQn5Qrr8qJxwOpHXNe06T8cPFVtLLMbLTpozhlETSREc A85Zsnr2FeLX9+TrS3e/XU2VKLukeTfGTxVqnxc1PQ7zUtLEEdjposEgjke4Zl8+aU4wo2jdMeMd eSDk14v/AMIDbf8AQGuv/Aab/wCIrphXcYRjCdrJLp/mJ0V3PzN1Lxdrmuyx3OqahNNdICFZnVQv rtVVGOmfyrn59QklnnZ1G7yiyksxycjPXOeM9x1Bzxz+h06cKUFCmrJdD5CUpVJOU9Wy/peyWRDP JiEgFuTnPT+teh6Jpd1q2tvY2t/G1zIqyqVmXGNuSMpuwcfTBHas6suS8rbamtJOVorc+pvh0kXh vRr3S7qUSTC4aUty20MqjHzHJ5U1n+INb/4Si8k0OymxpFswOoSIMee2Ri3U4BAPVyOcELwSRXic vPXlVS03/wAj0dVTjT+R0OmanHvgt9uIwdijOBuH44P5AV1TTFQkUTjOckZwB6gcf556Vz1I8srm 8ZK2xheK7Sa58O65HGCbhrWTYCo5fadufxx+lfIj3MjxsWb5TkjJzgEEfj3/AMivVy1+5UXoefjF apF+RmaHdyWtr9ldyYEkcAFvckcH1HasDxahby5V+4ZOobjJH+fzrrUUqt0QpL2drHoHwVlWK81l N2C6xlQQMEASZ/p+dfU3g2VtN8aaA8RZGu1uLI46cxG459eLf8cV42OT+tzt1X/trPWwtvqL02f6 o9+0/TprfUtYuHnRop9jRowIaI5kZtxP3slyQx5GMHoK+wv2dPin4q+GmlCfw84m0ZLuWK+sLhiU mXIfPP3JMPxIM42gHK7lPiVcRKnL23TRNd9LP/M6MPGPK4tn6seAfiboXxC0ddV0S4yF2rdW74Et sxBKq2PYHBBwdp7ggd/DM7q7RR7hnjOcY/p/9eunli0pRej/ACMpR5XYuvCtwu6aJGO77r/Njr6g 8da53U/hx4O8UFhquhbgQcmNURsHrhxytZzoQre67DSad09Sp43/AOCfWn678Mbr4g/Az4pT634h sYpbnXPCd1o/2W5060RC32qGVZ5ftUCAMZW+R4x+8MflLJIn5ZarDrHh6/u9E1iya31G2mMTxyxS O0TdQAoG0ccgjdwfvNnNePisNLD1XB7NXT7/APDM66VXni4y3X5GDdavNI7Rm3kaM/KXuSY0HfGD 14/Hk1xOr+O/DXhyJLrxD4qs7K2kPlq7SRQxsw7B5SMn6GsIU5ylyxi230Ro3GKv/wAMfPXiH9qL 4RaTcTmC9n1WeOXY8dokkm4ZALKzhIGHB6Me1fP/AI3/AGo7HxGs2g6b8NrObRCS6jVxHNDIvUb7 VFCFh2O9sEV7mFyXEtxqVZeztqrfFf8AQ4q+Mppeziue+/b/AIJ8d3OmXVnqFxrnhtlsJXbItrVp PJC8fKRIzsyZ5KtvB6YxwP3e1nxFZan4Zs/Ekd0tnBc2UV5FcvBJhPMgKxjeWTCsygrhsZDDPzcf XUKilWpR3nqvN6Hkum+SaW26OL8H+LI/Gnh/TbjRL1JtOeNra5uGjnHnTI5OI2kVfNVPMCbwqhuo UYAHyS37YHx3/ZC/ab8R618HfFr29ndpp51PRL6H7RpWtokUZVbmAspyAGUTxtHMivII5F3tnXEJ TxU6VVXj7yav6fj+oJzowXLvof05/se/8FFfgv8AtX2un6BFcJ4c+MrQtJN4U1C6R5Lnau93sZsI L1AoZiAiSoI5C0ewCRvv4ThkJJ+bOeK+dq0HRl7usXqn3X9bnrRmpxTTHA9kH4E/Xj86ikhWRS23 5wB04+lZcttUPctW92FtZ9J1TTrXUvDsylLnTNTi822uY22eYpClXj3hAjtG6OUJXdgmvy9/af8A +CWvwY+LFnqni34JeMF8FeOfKLP4f1fyzo+pyhI8i3mGxbZncTNsHkJDEiIiXczgGY3Urw37d/8A J9mZTgmr2v66/gfJHwO/4IjeNpNWu9W/aj+JyeFvDyXkkP8AYfhwS3mtXMaSPC8gW4Ma2LD93Msd 0qtNC3GxxtH6paX+wz+ydo/gj/hAvCXwD0oWkkUqzX+svNq2ozNNEqSZvJ2WSNVczvC8Pkzwrcuq TAhWHrUcJLEr2lROMei6vzZyyqPl5ZJP5L9D+dn9v/8AYM+J/wCxr8SZvOW/h+H16Yv7PuLxkl+x vLEtylndEhds3kskiSYTzo8nEcsNzBB8d/DfxF8btKtda8S+D/B3iZtEsiZNQ1PwvZ3Uljbbf4rh UBtgoC5ZpmI6nHUHlr4WhiIyw1VJvbyf/B9C6VWpSftY3UT6m8afGO18T/BI6L4s8S2+reL475dc aXRrqyu0tbFbcpBHcPZTPCLl5J5yYVRGjFspYZZQH+Ef25/g94Em8Fxaho+sy6RptrYuY7XTBKsh h2brWUTTQMgYIVZ0Mo2twG6U6/D9SeX5bhcPNU1SnKbTu3q7q1v67lQzOnDE4mrUV3NJaeSsfot/ wU++IeufDn4NeAPibPaG61EalHo8dvBeJastzf29zcyyynyZGmSMWEaBAUOZc7u1fht4C/bK+I2l 67pj2/wx8PXWutchrK8Wwur29WRgwHlW91PNZSt82QZbOYggMuHVWHZUyLL62MeOxN3dptaJaLq9 /XVGH9qYmlRWGpWW+vqaOufsi/tr/HrxXrXiK7/Z+8UW13dKb+41Lxq50g3iEcym81qSD7U2BnKu 7HHGeK/pF+CXw90H4DfAT4ZfA+wvzdWHhzTmt5bpmBW8vriR7u/miJjjYwNdTSmEOm5Y9i7mCq7d +Jq0sS+Wn8K7bbWSXR/I5MPCUXzz6n55ftw+IdDXwulnoDmFr7V7TTp5UClXaQuzH3wFO7B56HnO eM+F3iqy8X6BpU0vxCvl8VvDsvNOmj05HFwmQ+1fswJ3bfMChmKq67jkGvzTOcvg8JOrg6d4wqyv a+iaV3p2asfV4LEyjWjTxD1cI2v6u34M9cvrHS7e0a41jVUEKj5pZ/JgVcsBztVQfTnjmvn/AFn4 p+DNK8YSaNYW1jq2l3mnrHFf2PkXsVldPJMj+eVmVokRI4yWjVpV8zKoxrzMkwMsdi405X5Um79N NbX7nXmFWVDDuvBdUtu5t6P4UufEHhfw54iSAwNqFhbah9nEqyeT50Svs3A4bG7aSCQSpwSKy9T8 IalAXDjcWHzY3Akeo6bT+PHr0rF1VCrOHVNr7mW+ayb0OcEE1nIS8JVTlmkxkEjGOh5oh1CWOQhC QoLHIUcnHpg8f1+tdF1JaGfmzYg102TLLdAMeSZZgo2jj5RxkcdMDnbyfXqLXxNZEx+YpJCrvK52 jI564JB4GamVKdua2nQfU9S8F/FfxT4ZdIvDfiCRLMcG0lIlg5YO2I5MqpYg5ZQrcnnmvZ9X+M3h TxbZ6TD47+DGkaubSc3SyzSxvFbXChjHJBFcwTeW6kJiTzNy8sDwFPoYDNKuHaU27La2/wDwxy18 JTq6rr9zODb4jf2LduPBces6RpvmxyfY49fe+WWNHWQxD+0oLlIUbBjK26Q4RyFKsFdcPxZ+0v4/ 1K3vNNHhfSxpssm0rLbGZxGCMBlmLxP06mI+wrulnNOtdSp2f5+q/wArGccEo6c7sfK+r+O7pr+Z 5NHeFnO8rDGqxcg5+WIBI8dl4GOg7Vx+s+NNUvtPu7WzG2d45IllRgrwMwwJAW4Zl6jPcc+lcbjS nNSlqm/wOhxlytN3Z4tpf/BRf9vj4O6r4at/GPinUvEun+HrMaXoEmuTXTPp1pHxEkNzbypcJHGu FjiWfZGoVUChVx/QV+zz4lufF3wU+F/i67s4rW71Tw/puozWtureVbvNbRStHHvZm2KXKjczNhRk k19Q8Ng6eIhisJK6qdN0rJJJdvTufPRqV3KVKsrcvyO48TT5tpcnDgD+LJOOe35/z9/zL/ag1t7G LS7SBSZp7hm/d7iSqqd3v1cce9e7l6TxVFT2v+jOXEycaFSS3/4Y/K34seDp9FEFxojRxTapDNp3 9l3mkJJJJuhG02z+Q7bj5SAA7XRnZo3/AHrlfi2++AnxzsZgt58GfFcLsNyLL4ev0LLzyoMXI69P SumdCjg8RUippKVmrvp5XZriswq5jh8POcdYpp2vrtq/Xccf2b/2hZ40uoPgT4yaDqHXwxqRUg9w fJ9wc12fhr9kD9qLXJo/7G+CPiOK4HIe5sJbI9M/en2AdcjmlPGYSCtUrR+9fkcChVbXLFm9a/s5 /tn6Hdz2Nj8E/HM82fnFt4cvb0HHbzI4nyPo2OldLe+EviXZaNpn/C4fCniPRb21mkhEF5LdaXKV DfKvl3isMfOD9wnDE5wprkqQwU5Rq0HFyv5P8N/yN1Ur29nUvb7hR4+HgvU7+a01LUE0eIp50N5q FtqEbnkgKY4VJAyRujwDnqBxXZaH+0VpEs4nN3CD8qx5dI9xJxjY/wC8IPHRfxrycwyqVf8Ae0oW 72Vl9x6GFxipr2dV39T13SfjJ4Tk1BZLx5reWTG/ltpzjjb1GTzya7n/AIWz4F/6CH8//i6+aqZf i+bb7j01iKTSfMfnJ48+FOmeG/EmtaZbaotjdoUmt7S9IaIJJGkixfaULBZMuUO8CJdpzOR8x4rw j8LPFfjfXf7M02zEY27JbidxFBCrYAcsQxcfMGwgZiBlR3H6daUW6dXdfcfHq904s6Px78NvDfgP TtNSx+JemaxrzHZd2NgpYWoAJyJgzK+GTaVIRwSPkxyKfgy5t4dQj1Bf+PmKS2jCj0kYxscdOCwP Nc85SqQk3GxrD3ZLXqet3Wr3E+pT6TpVzm9mjXe6dLdASC3ueeK3rOwis0htLKMrCg4DYwxHJJzy Tk559682SUYqNt9WdcW5Xf8AXmatnG+9zFgnfk53KDweQRyPX6V6HBch4VuI2wAPukkeh6kcfTPt XLVs0mdMNPMZcSR3MMjtC7M3Bzn0/AGvgbUNbh02a+0uaNzdW8rQnAAAZGIIJznsea78s+KovT9T lxkU+R+omkXw1BLry12sJPmXdk4x17Ht+lb48q6U2t7HuhOBjdjgdwex75Fds/ifcwjsdV8P9Fu9 B8Qy3sLebpMkJCyHPXcvDehAJ5r6A8MXzTeJNGxGv7uZz5suEjjXy3DHeRtQ7S4HIGSBnmvJxVqm IUvL/M9bCtrCzjbr/kfTulalp14ZhDeRTFC0UjRTowDAjIypKn6g4OQcYOa90+Fmp+Tp2qacJYle K5WYCQhSwdBjBAP9w9ePTivnsTFqDUv61OqnpdHqOk61rvhPXo/EHhDWprDUVjkjLIqlWDgDBGPL ccZ+fK5w2Ayqw+sPhF+0t4Nhjitfin411j+1IZDKL/Ub7zdNtjt2klII447ddrMd8yyBRvYzIvyg y7EVFL6q5WUtI6dX0v08tSqkVKHM1qv67n3ro1zp+uafZ6xpOoW91p11Clza3VvMskN1E6ho3jkU lXRgQQwJBGCDjFcn4vvPidZREeB/DllckyLhppyzlQDuVoi0KrzwrCVvUrX0GAw2EljFSzKcqdPr Za37baebs7djjrTrRpuVBJy82Wvhh8Q/j14Z1TQvE9t4W/svxBDcieO7tdV+zyWLI2UPyhyzDAY7 CQDwM4ye5/ac/Zr0f9s3wXqnij4MHS/Cf7WkSSSJpS2sg0nxdLgFBawQ/PHcO24NaJnLNvtI3Zhp 8m2d5bgIKNDCYj2tveSS1W1482zutmluvMihXrSi6jp2a016/LfzP4wfjH4z/aM8F+Ode+HvxS1v V9J8YaVctb3likiWrRsyhlIe1ws0bo6SRyqzpIjo6MyMrH54nnzK91eXP71zlmkcEufx61rhaGHp U4yw0FZrfq/mctWvUqNuo/8AIrtq9nEjLGzPLwMRrkn8uP1qwl5qNy8gs9GmLH+IjG36/meMiun2 UpaydjH2qXwmtHpHjS5fY0sFrbNjcN4yPrjLH04P41+id14W8PeMNC+F8kXhvV7zUY9M0jR3ZBJF pWpCK3t2ndmi2STT7jKsixzpt8pRIyFVZsK1TD4RwxTv7nVb6+7p99vyOrB1JuU7yS09VuunX01P vfwH4Qt/AHw30fSLrQhBfQveXLl4IlaKGW5muIknkREjeSOKWOJ2UKmUYr8pFfjp+0TYWXxI+JN9 4n8I38UsUSi1ZgMRTpGvDRyAktyXXOMHAIYgiuitaFeM4rSzv8zKtWlXcpvq+py66pPpPh+wuVkl sfE1soaCeIvHLFcxkFZI5EHykMgcMGBBxjkV+6v7H3/BXDWvCVzb/Db9qaS41bwhDdzabp3jyKIy X1ukMhRTqcUYLXa7ME3EY8/5PmjuHkLpy+wVSg6cnbV8r7f8BmtPEKNXfRpX8mf0JeFPFPhvxz4f 0jxb4N8QWeq+Fb+Lz7HUtOuY7i2u48ld8cqEq4DKynB4KkdQa6KSa2t086eYRxk7QWbGTzwPUnkA d+wrzXBpuMtGjv5uqNOTSb1XkXVp/wCyow5RkmtxNfqQXQ4tCyiIqVXIuHhYqwZUcVesbz+zpzN4 bsmsZWQxvfPL598wbfuBuiqeWuHdCkCQI6FQ6ORmu/BYHnftai06HNWrW92LLGnaZo6Opv7p/LCn CQxhzkAlQcsqhSQASCSM5AOK9Di8ZvoZePwTpyaSoztu1YSX/Ygi5Kr5TDLrut0g3I+19+M17Ps9 LPY47tO58d/tJfCKx+Mnwz8W+FJdWvdN1W5s3S31nSvtX2/SZwGaC8tvs00Upmt5SJgqtmRPPtx8 tzID/Ib4m/4Jsf8ABR/xx4il8QfEDws2sTLJ9lPiDW/H2jXoaIHCusk9+07xkHIAQnB+7nisqkoU JufLq+ybfpp+uhlNVJaLY+uPhz/wSC/aE002WmePvjX4Z0zw5dReY/8AYNvqmoTwscHBSa2tLcn3 FwR6HFfQXg7/AIJKfAfRZIdQ+IHibxB4o1S2vVlSCSS20jT72HqY7i3QXdwynuUuojjgYpe0xNbR Q5V56v7lp+LIVJL4n9x+i3i7wh4O8ax2Fn438PadrNhbPJItnq+m2l/asz8km2uo5ISV/gLKxQDA PJJdpP8AZfgTw/ceEfCcUGjeEnkMg0vRre30u2iJ9ILBIYhnv8nf04qqlCnUs5q9v622Nk0tUfMf xB/aNtPCfxNsPAsOkReWdEk1jU9XluvKFnbq7wxxqCh893cdN67VDN82CK+P/i98bPjN8TNHew+B tnbnS7kmJ9en1C3WG3DbhlFTzHL/AC5G6PHKsAwOaxzqvhMlwtGtiJO04p6K+rvZaeSTvpvY2wdO ri6k4U1eztv/AJ/cfMcXwh+Nvj6G30b4la3KdEttQivLN/7Ujab5BykhS0WMsu6Ty5EjTyyzb1uQ wVPQfh98CtQ0fXZtS1XWdYtLSC8Ey2SXFk9rqB+RyxkhiSWRBJGrYlWM7o0baCBj81xGe0lhquGw cVaXeLV7/E1r91+nmtfoaeAlKrCtW3XmtLbdPy6+R6x8V/Dt7408H6lo9lLDJNIQyGTY8ZZeMMvR h1GTnGcgEgV8Uy/DDWfAehXHiS38JJpVnYXKI228E4u599vun3DDDzXkji2qgKgAkEje2nC+KSn9 Uva93a2+lvwO3NpU5ZZ7Jr3lNW807aP7j0Lwq/jnwhrPh7VvA/gnUR4bv7CNJpZbtbyPUpWhGx47 WMboFV9rh5ZoV25QtHxj690CDxjrV2174gtbCy09htg02B5Lm4JPO6W4ysYOB/q0RgD0lYVyY6hg XD6y63PVleMYx095O3NLtFLRdZNXVkm30YjEyr1KUYR0jGKlLZPTRLzto3tp5nUQ/DDUvE/2uTRv C15drHyxtLSWYLwcZEYPPXA79s12mn/sZ+ONf8Lf28ktvaXsisY9Nvo5oLnapbIcMgVHJVSqnswL FcVx4XB4qtSlVhbli7O7V7+S3frsu5w1sRSpy5Jav8vX/Lc+XPGnwd8QeGtQl0rxLoskV5CSQk8Y YEBipZW5DKcHDr8pxwa83uNEvLTdtt3WMY+7nj68cD3o9o1+6n0Nk1ZPp0MyWW9gmaRkkUkYL5x6 ZB4x+P0rTsvGWrWbkCVmiXk5wQAD/wDWz+NHs4yV0/uHtuzooPH0UpKXcZzx82DgD8efXqf6VtRa 1o2oeWsxQjJzu+bnsPcc84JrknCcW2i1Yc+maRdu5inVZCSTlh82Tk8Y+lWINA8LrE/2rTvNu89H UGNhg8kggg5PvkelOlVkpJu9iZRb1Whz2oeFPC92ytNpJMBBASGVE3nnGT5bLjJ549Rx1r9Uvg7Y xaP8OvB2kwwhEt9LtbdUGP3WyJVAGOMcdelfQZPOU8VZrS36o8vHxtGL0N7xNKFs7h+pxjnjPHHN fmX8Yvjrpfwt8bQC4+FA8W6jdRGCzsF1trGVSZEDCOPyZftTOTEBHtLDaCFI3Ffs+WUqcuSo4vvv bp/X3nkRh7STi1ffT01/A+TZP+CrXw70a5uoNP8A2bLiwaTAlWz8WRoJcHkHGmKGAI9+ce5rrdD/ AOCnPwJnhgvfFHwx121824MXlWOo2t7MgUrufDQwp0YbQXySvIUFSc62VYhvm9qpN90/zuyYYmhZ xScUeu6J/wAFGP2T4pXbXdD8aWSbQ6pHpVrcE4L8vMlw2NymMmNY1Ksh/eEHFdhon/BSf9lTWZ3s NM/4SS2jACq2pWunWoIGRkvPerz0z1Nc0cpxKXtG4/jf8EX9Zo3tFnZ6X+3x+zjqs7W9j4tuDcFi ojjtY7lgenH2WSXd+GfxFfSXhL43eBtYjin07xNcQyMu4G60XVrRI1HJZ5ZrdIkQZyWLhQM81yV6 Dov95b71f5Xs2/kbwvPWOp82ftH/ALcn7Lmg6HfWHiHxN4Y8X6qIpDbwm2t9eiWQKCiskYdN25gR HI8Qby3BdPvD+e/9oP4s/Cf4mpe3HgHwFPY3CXyFL2Sw0TTUWB1cmL7HptqhJDABZZbmYlc7gWO4 erl1DHQnGT92n15m7vslG9l5t/JdTlxUsNyOK1n5dPU+fYJ72w0/TzbXMsIdGZtjlQRuIHQ89O9J /bOp/wDQYuf+/wC9ew6dOTbcUziVSpFJJs9q+NHj7SfFnjCfWvDU8t5pEsKqPtdukE0ZT5MGONnV BgKwXfJgNgyMQSfPNH1fVJ9Hl0Kz1CRTeyYkiUMBFGpy2T3B44GenXqD31pRnWnKGzb/ABOWLdtT 2Pwj8NtPu0RJNBjvoo1aV0uHdN4C8/MjLIfYBhgkYwTWRqvwovLHfLoc7JdL8xsrmQoMgkqFY4xj gAN6ElhXPVjKPvdOxUX5G1o32e316OyhO26YPvBcGRjjJZh17Yzj0FenKrLC6kkLja2wcHOc/XP1 NeNVbUrt6s9Cmvd0PM/iPqNhFpd1pVtqONWuAvkRRZeVpAUYAquSOg69RnrXf+FdUg07RdE0/Vrm JbxbKIOktyocMEXdld3XgjB70pQk8OlbVu6+4cZQVSTvpY2734gackKtF5kwzhUSAqcdP49o6/y9 q+Ztb8J6Pe61q2sXDyut1dSTiIOFA3sWx8oz9ea0wkalGTb6ojETjUS5Squi6bYBhY2ojcgjdySR 6ZOfasy4SS2nUyjGQCSeQfy/D/Jrs5m3725zpWWh7D8MLwLeyx8tFJDtKnBViOQSCOvy9evPHWm3 093fXatdGWQbMF5ZWO1gemAeOufx/PzZwj9Yk2uh6VKcvYRSehveEvFOqeEr1NRsXBRjsmgkzsuR 15A6Hk4fnBJ6glT9beC/j58N9I06/wBW1rxRDZW9yI8CWK582IruXayWyO/BYc9DjvjNcWOwdTER vRjd7W/U1o14Unao7I5rxB+254GtGlh8L6HqWraisqqp8iO3ikjxy6zyGSbdngBoe55rxjxZ+1v8 UfEIu7ex8LWOm2E0gS3e4El3cRoeqN5jCB8g8kwAc1pg8kjSqQq4mfvJppLv6/5EVswck1Rj83/k fs1/wTcSY/CHUvGHhrxrqkWoNqk9leaZKVfTIZ40hdG+zniVnge1824VopGC+UrIE3N+qGkfFLS4 GjsPG8A0sMdqakZM6fKctjdI3zWjEKCVmxGC6RpNMxr7bifBrH1/7Uw9NQc1FyS6+6tfV7vzODAV XRisPOV10f5I9wbTAEj2gtkYXAyPw9eDVvT9Eu7qcwabZSzXTcCCGFnZ/XCqMnrjpzmviFBqem56 3P3Ph/8A4Kjfsp/CX9oT4cXnxO+NXxI8P+CvjHptvKbLxZrV6kdxqDKrym1vYI83V6ZSHf8AdxSz ea8kyq8ks6zfxn6vpF3ZiG3uNRgluoyHW2jmEm0k88rkZ4yeeQB7V6WXxr0FKnWj7rd4+jvdeie3 qeZiIwcnKDPQYNYs49OZ7XQEVkVcMyFQSwO3OM5yQcH2PpUUOqSKYrXVECEMdtyi5H/AwDjuPmGM ZJwxrukrvc5trHQRG6igN6i+ZZEjZKhyhY5OOnBxk4PIHavQtM+IXjPw5Bbw6L4s1vTrWZRJJFpu rXdkhbOCSsMig/dB5BrOLcZXSKXY9A1Lx94m8RaSdO1Tx1r+o6eyGOa2vtZvLqGYerRSuVbr3Hp+ HJ3UVnG6vbxFIMdmAx6YAHA5/PGOQadaUpyvIcdBW2ai0dqXjaHawbGG3Djq3rnjB5H1GK9s+D37 J/xu+P1zdaD8FPhtrOuTk3E072do5gtgkRkk82eTbBFhPnIdwcDgHFcsqsaMbz2/P/gmkYtvTU/o n/4J8f8ABPn4s/skpPq/xM/aLkhsJ49138P/AAkYtQ0y7uDHCvn3F7dIYo3dDnzbSMyrJbpGzPFu Q/qxZ30umu0mgwCxumjMb3iO32qVGWSNw1wfmRXjlZJIovKhcAExZ5rajhpYmft68bLour85f5fe b+0lTgqadzOUW0WXlbdg5wOntiplvHlcAKABxgcfj/8AXr1uWytY5277m1ahAA7yZOB07+vrWpHC JGHzqikfefOAPXocgdeMn2os0rsOYzda1nwtpNpEYNSkvNUZ5VkhjiCxKAQIyshYl92WzhPlAGck 4DPDXhbxd47l1SXwV8Ob7UbhFEk8Wm2stxcOMjJ8uJS7kEg4AYjPIFcVfE06Su1c1jSvufPPj7Qv EFrrWp6bcQi21S1kaO5srtJIZ7Zh1V1dQVb1Bx1z3rwDX7jXdJSWabRLqWNVZy1shnVVGckmPcFG BnnHf1qaOPw9aKXNZ+YSoyjruvI+RfFn7S/hqwMi2d2JZgDtSIbmzzn5R1x3r5D+M37U/wARNI8O XuseCfBFxq+orIFWziuEjmKkhfMWPBeQBinyxqzfMDjarsM6+Y4SlUVFzXM/nb1NoYarye15br8z gvD73HxO8JaS/wAXvCtlN4ku9txdxwKySWrFnaGMyoVMjRK6Id+5C0QOCAor5KsPC07fEz4z6Z4R 8SpbWPgyJbt9Q+03FrdSLJAZY4QsCsksibHjd3eNDsLhRuCD56pjJ42VaVaXPBJJJ6rl5kktdlrs dsqCoqn7P3ZP87XYeB/2uvE8Iis01m11SADYIdWXybg8fKFkTaWPHLHzevTpn638L/tPeCtWggj8 V6TdaQzj/XKPtFtjGPvookJB65iAGAeM187mnDfJJ1MDo/5ej/wv9Gd+EzK7Ua6+f+f/AAD3fSfE HhjxTp41Twpq9jqVmVDZtp0lUZ5Abacr0PB57V5v4n8AaV4tvJ7vWvDVjNceSkUdzPaI0iokgkRQ x+cgONwAPDfMOa+bw9bE4DEOSvCotOqfp6M9OpClXp6q6evdHpPwz+HHhK61bSPC2oa9F4f0GK2C JJ5bOEWNQqRxRKRubGDglQFVjnjFfqp8OP2Vf2Z59NstVuPiP4gvPFFs/nGzEOnS2N2V2lVcMjOU JzujYEAADcelexlWCqYr/hQqwjUgm04u+9t3Zp6Xvbr6Hn42tUpNUKTcLpa/8Psa3xc8LWU/hJdO h+Ikng/RLaWHdfWklvbKIxImI98m3yiR8iFXGGcEq4+Up4m1vS9C8I6qdU17UtPtLSx3f2yluly6 BEyJgTHKsp4yRsO7PA5Br67C0lWoYTCUsNHSb1253Jx91vTZdL6Xv6+LNtSqVHUe23bfWx8o+E08 D/tEWf2Xwrpv23XraOIarfnTYLK+kmaPyxNctCoRyRGQCWkTjCk4xXaaD8LPh38JfG/gfw54p+H2 seJvHGqMXSez0zzdL0pk2MxMk5jSQKWyZDnAVcpG7IkixvDFOWbzw9VqnKClKSburJcy11burd21 uVRzKf1ROL5ouyT69mjxz9sbwt8FPCF/o3hzwz4btx8RdSJnFpp8YhW0g3jzLqfYAgDElFV1LMxI UYV2X4M1L4cSQW7tFOjMxOEMbBj3IyQR69+fTivls4VHCV6caas3FN9Fq3b71qezgpVJ0W5vr1PP dT8FXluyE5UZO7IBBxySMGuYfS9RsmdiMKrfMCpGfTnH4nt2rzo1ozWp2X6M7jQBAIP9NuXW6JOc n5Bg8YGB6+vfPIr1K0sLG58xIJoLgqMkCXcwVgeSCxUZO7jBwAMZya66NHDz1SvLX5HDWnXjJt/D +hy+seK9H0j7dDd3Ucd0jCFYInCgP3I4A29OnTkccV9s/GTxV8QfAP7Oeuaj8MHtovic1tY6fost 89pHDDdTzQQF5HvGW2XYru26ciIMql8rkH1smgoZjFV1pbX0urnPjf4UXHfU/AC8/bN/4KL6L4Ui +IGq6/rh8D3+oyafHq114MsH0y5uY9rSW8Fy1p5W9QQSkThgGzxnNe56x471L45eAvB/j3xLp8Fl qmoWNwbj7PAM2siTy27mBpA8kIYQ7ioYnDbWLbc19dmdSnQoe2pJau1uj17HlZdUqSxFpO2j/Kx8 q/E34B+KfFOsaj478Sanrk+u65M2pXOqawZJ5tXmkBkM7XEwDStJv3ly5L7t5Jzmvmnxv8N77wNa f2tGxVQqxNgjKk8E5zwTgkj37UsFmccS4056N9r6meJwTpp1KbujzSLxPqUSBfOfGPU1ZXxdcjq5 z0OCeRivX9muh55Kvim+EtvDpVrF9ukO35oEkdmPA2kjjtXI3k1488xm/wBdISzAY5z9OlOMYp67 gmfUH7PUXhPU9A8ZeHfGlhZy2U09tPbtPtjcMglV1Ey4kK/Mh2BwAecZ5rd+I3gH4W6ZpGqnwzDd C5flIrC5M8MV1GhYK3mb22bGkLANnO05ABB8GeIxsM2nRhrSbT12Wivr6/8ADHoxpYZ4P2kvj1/P seM+JbCO10jwmqLh30uKUk8E7tx5Hf8AwrhvKH94f98//Xr16Um4Xv1f5nHotzu7yK+1SKXX76Cd 53Yy3c8hZ5JC+PmLHlmz82ScndnPNWfCiJpd7dfbov3jqBE7fddTk5U9wevB9K64u8tTktZ2PtL4 d+KPC0P2fSZ/KCtuAnvYoTFBuX74Q8O4CghWbaegAY89t8aPGPg7UNR0i08JxWlxp8MGRdxm4DSo zFxHIr7QsiKRHI6DDyK7hiHXG9aEZUYS5tU/wsF9ro+Q73xH4ak8YXXiZJvs+pWwaJLaCD/Ryu0D JkaRpGwSRtPI2A7myava7p3xE8U6Vp91p9xY2lvPFDdohvYsuskYz95flI35xuB+UYBYCvInTiqi nNXS26366nTGcuRwj1KWn/CoWspvL7xlbS3zszzPHayyzEBuoaWMoxPUbW6fewc4ZfaMbR1VfEF8 8A+ZCIIlYnv8kaNkZ7ZNDm27qP3/APA0Gvd0TIEjv7a1Ml9OWgzh1dFDIpOATt44HXrxk+1TPbfM 2RwcbSQc/QZ+n+etQnroh7rUuDTY2jMjMBtBLZIwv+Fcn4l0C7MK3NkVZoy2ePvLyemP8/rQpe+r h0ZL8Pr9o9csFU4l3FGQ98gr7k9a7rWJIbXUrm3cfvVkk4UjGdw2/p/PvWFZJV7eR10X+6vfqc5d 3SeX5MZwMEYJA/EAHn171zep2Kxaha6bPCrIAJZVIPPHAPPYkfrW9G6i2Y1fjVyRbiC1AS3gjC9g oC9vQdD05+tcpH4g1C71rT7OZkW1aZRtCcE7h9cdR0rWlBOTciJTsuVbH7I/8EyviL/wi/xa8Q/D S7l/0HxHY5gxCD/plkJZ4yXyDGhgN7u4JZlhHpX7rKVUAMSM8cjg/wCc96+0wslWwFGX92z+Ta/K xzS0kJoDaz4QV7bwbr8tjozjnSmSO4s4Tz89vFKD9mbnO2IrE3JeNmO6ud+Jln8U/iP8O/GXgm2+ NviWx1m8t3fS72xvIdNGl3ygNDIF02K3BTeiiRSCWQuuRnNeLiMspw9rWoP37XWnW39dLm/t5tKL P50v+GZ9av8AxVq2q/G3xrqeueLxcSJqEdzdS4EysVdJJGYySkNkbty9K990r4H/AA10WwupNI8L afHcorM2+ESMcA9WcE54I5J/w+SxWPqT2dl/W52UqMV70tT0TQ/Cfg2KziurHRoUSX92Ni7SwAzk 9CMFjn07dK/JT4pxeH7HxDcaLpmmy2+qWF1eaffZdfKuPKlaONkHUHYMNnrtB7kUstnOVeopPov1 M8VFKMWlY88tbi4sJ3n02cxEjDRkkxvyDhl6EZXOPXFdTZ+IbK5VLW9ja3uQPLDr80T5JyCT05x2 PU9BXstXdzjvY9t8B/D34g/EvVV8OfD7wFqmva2AriHR9PmvGSE5XzW8kHbGcffY7e5Yda/UH4N/ 8Ec/2kviDLbX3xQ8RaV4G0Esyv8Aa5BqWorhQyOtvaP5W1s4ybhWU5ylc1StefJSXNPsunr2NYQc /JH69/Az/glr+xx8Gbm21fWfBF14+8TI0btceMbgNYDdDtmiGn23lwsgkJaNnZ2XHPbb+iSailjp Fn4esRb2WhWsVvFDp+n2sNrbKII/KjbyIFSPeFyN23cQeSc10YfAe+q+JfNL8F6L+mb86hHlgYdz r9hagLuAI4ye/wCf5VyeoePYsFEm+fHXIGPwr1Y0/Iwb6nF3PxQhM5SKTBZtu0HrXovhc6tqkaX9 0ht7NhlZJMjeOSMDqe3r1qpRUVeQJ9Dt7rxLp2mKILYGW5Bx2Jz6cdO4/Csof294hkJu3aO3P8Az +H+TmvOr17J2NqUG3c6nTdF0vTf3j2aTXIGS8hf168MOfxrFupLuO/luLC4lhOcjyWYfhXhYiUm1 JvU7aa3PQ7L43/Fa20+DQ9T8Sf2z4bgAEOl+IbS31ayjx0K216kkSkdmCZHY1De+IfhR4qaSXxb8 ELW21GWVZZb/AML6tc6ZPKQDkeVOtzZRIflykVtH04IzXO1Cb/eRs+63+ff8yuRJ3Ts/63PMPH3w G/Zz+J6x7tQjt75kID+KPDMckdhCQcxpfWbXNxJJ6OtnADn+Gvgfx/8AsD/Di6Mn/CN3ctlsV1tp bC7kmgZgceY0d2rT4PPy7ojyeBXn4jCRlJyi9e6/Vf16m1OrUpaLVHzRrv7D3xH0F2m8Ma3Z38a/ vFDRy2crtkfKq/vFznu0gHHUV+dt7+yp8d/hNof7V/iDxd8LdVj1HWJ9bvra7tY0vIZ7AQh7Y+bb GWOM4aXCsVYYIKg8FUY+yhKFR6tx+dncdWrGpJPsn+Ksfid/wi2qyQRDSdNms2Tf5kmZP3x9WRmK 8eoUD2yOdjTPGHxH8KCO1XzJbEqqgRrvQJu3YCMCoznsFJya+tqU4VFaR4cJuOiPXvDnx3hFzHd6 xo09nforD7bYSSW86YOVUYYccAffr64+Hv7U3iGGMW1n47t9SGDutNdQJNIT0VZ1aNuoB+9KT6c1 89mWTUsXG1SN7bNfEvn1XqephcdOi17N6dntf9GfVOhftF+D9XC2PxA8F3dmjBUeaGM31qTzuO5A JMZ/h8tjg+vFe2eEb/4VT2N2PhpeQW7Sq3mpoepTWM/Q7i6wPHIvU/exXxdTDZnk8/aYeq3T/mj/ AO3LX8dD3oV6OMXLJe92f6H0v4M/bN0PwNpFt4H8SeGNdurOBTC88o1fVpZt3LB7ibz5JBk8B2AU cKAoArtbj9on4PaZ4Wu7bwotlpPhyRXuTp9ppM0LTOQC2beCEyE9CQEJIHTjA+7w1XBSpp4bGpxl aUouSWq6taarX/hjwalHEqTUqOuqTS6f5Hz54M/bf8FfDi0lstH8Mato+nySNdS21l4cuvL8wgbi wtomUtwF64wmM4Ar6a8L/wDBQ34a+OLOCw8NL9o8SPmLyr2aDTSjAgeY4vmg2qMqSvLkfcVzgHqx KweMqTxMMZGcnrJt3b+8zp0q1HloypWXSyPlUeDvGniTxj4h8XeMPG/hi+8d6rPudbXxhoRFumSI bWCN7hJGVMhRiPLHLMCzmquteD/2vPAd3Frnwq8BX99ZysqXVm+gXNzbXMIOflmhfaucYLIzcEfK ccfB4vC18XmEq+MpNU5vfoktFqk1orH0EasIUOSD1S2fX8jyq/8Ajl4TsbltI/aA+Dmu+BfESP5E moW9hPLp7MHIznygyLj5i0kKkDgniteHwFonjLS18QfDfxLpuv6HOg2y2N1GCwJbPAYpwQeCwOeM cVy43LZ4KbdOoqkOk46p+T7PyY6FdVFqrPs9/wDgnmX/AAglz/btholzbSWE9wSWa4iYCGIK7Fin Gc7SAOASR8wGSPLfH19Y+Ab/AEOG4trq8FyJFtZ7WzYbyiqGYLncilmIBUuByNxOC3o5PlFTNpU6 OGqctZyau37qilfs23o/Kxx4zMFhKkvbQ5oKN13bvZ+Vjrvgv8Htc/aO8R65aeHbOe1t7KOC41jU rmJ3e0jmk2EpBnzbmYRiWURYUMISC6kpu/RD9uXwb4b0b9jv4rX1l4ma71e2t7aW2WOIRBJo7y3D fK7E5QbmAyCSowSSAfoMLk+Ky3PnhsXUjJxcU5R1XvWfl08vI4auNp47CxqUYOKs99PLofyr+MvE 15d+GfCGh3d7Obe21G8uysN+7WrtKLbJggI8uFwISD93crKCAVBP9Hnwa/Y/0Hxp8AvhPqVu82l3 qeG9LW7kgImWeY28T3ZkjYbUbzGkCvkDJJKHq3p8RU06VGhJ25r7fJq/9anBltV06zqR1sjqPE/7 Dfh7xJFY6l4A+IN34Z01ZZHujPHPqENxEiMybInlinQEtuOLgJhmAjwoDfj/APtl/sy+JPCmsC1g 8TWWraLexoZorSwXTJLGSIJz5Ky3EYEmd4cy7mYSAgBQW46ElSpqrUSahb3uunf8v0PVwjoSqzp1 oNqcWtHaz3uj8z734K+I7RrNE1fTBeTzGGOC4vltnDckZecJFyASCH/Xiud1/wCGvjbw3I0WqaRB IVIG60vbO9VsjOA1vI4P4Gveo42hXinF2vtfQ8OrQqU5O627a/kee3UTwy+UbYxzqcFSpDA+4NdF YaL4h16SNrnzmjHIaYt0wOmfXA5+ldM5xjHme5la+h1ravpvhKJ7VZGuLkKR5Ub8Bv8AabsB6DJ/ Ou48X3oHwn8NG8gRdRubhbhPK3KqK6u5wM4JxsUk5PPXqK8+cZKpRls5S/CzubRa5Zp9F/kcv4tk Yad4Z3tkrpNsoxzhQp4rzn7Svo3/AH6/+vXTR/hoym1dH94Xhf8A4ITfsKWv9nw6rZ+J9QntoVgn E2t+VBfFWOXkWKNWBPQhGUYA4659b+LH/BKv9hzSvh9f6PoH7I2kazryGwgt1hvrqwuJi06CQfaL e4haPEaOWbdk+jH5Tx59ia+W5JjMwlNQdKEpprZNbX30Oqhh6VWrCm9pNK76H4Y/ts/8EdPiX8DN L1H4s/BuKS+8BQz/APE00KFZriTQYzjFxDI0k0stmu7BMmZYwu58ruZfxf8AiHoXjHwTp/lzC38+ aZ7eOS3aVsMMf3kGM5yuTzgnFebwpxLS4jyenjE/3i92a/vWWvo07r7uhlj8KsLi50qbvC/uvuuh 554V+FmtXkpk1nTrpICAwwUQjqckP8zDoMqD19jXv1vo8dlGlvsXEIVfL5yMcdT16EdTyMV7lWop O0XcyVOcY88luSOGt5opoMLKCCpDdMemeM/z6HNeM6lqOq2vj3Tree+jn0idpJIo7Yq5VtjfKyr8 ysrHqcZGGrNJPmuujB7qx2Jtbu7w11FstujQggtJ3+cjgDrwOPUkZFPuNOR9xiOAcHGeegz+NZJ2 di32IbaZojh2yM9+46+nfv8AXtWrguPLQfKzdewz6Zptahtoedav4c1CzvI9d0dGjlhcS/KOVOcg hTwegJHStg20l7MbvUCZLll/eMPlweOwxjAAx9B6VNacbRktZbG1BN80XseV+FVddXvFnyHjVwx6 4IKrzXV3+pG51bUby4UeY7kEA/yP410y7IwXxGn4d8E+N/HL6knhLwxdX62qCS5MCZWMEHCliQNz YO1QSxCsQDg43rP9nH4uxRy+KNU8JzWWm2O++nku5IonjjizK58tmD8KpOMelT9ZoUG41Ja9hunO eqWh2PhXxhqfgHW/A3jfSCi63p+o29/AZ4w0ZlhkEsO8ZGU3qNwzyoIzg1/Vr4O8T6V4z8KeGPGO hrIdD1bT7bU7EzALJ5FxGs0e8DIVtjKGGeDn8PrMnnzYOdN/Zlf/AMCX/wBqYStdHWRqrDGfmHOR 1x7U9VYMrYPJ6mumcd10BeR8SftXfCULeW3xT0S2Jt7jbb6ugDERzDAhmIzwHA8tjgAMicFpCa+X fDVl4eeW+XxRqt5ZwJbtcQvY6Yt48rKVGwRvPFt4JOSSPlA44r89q5diMRmry3DJc85WjzNRWuq1 e3/APSjXhTwzqzvaK1sm9vIfoEb3JnlTSri0ikZVdJIdu9yFYOmMgghhn1x2r8vb74J/GD4x/Gv4 oeG/hX8L9e8R69Bq95e3Fto2l3N2bW3kutouJmjVhDDmWP8AfSFUAdctyDVwwWIyrMq+CxdlOC1s 7rdaprdWOedeniqFOtSvaT6qz+a6H6PfBz/ghz+0l4vls7v4z+LtC8DaN5zRXFtHOuu6silAyTRw 2UgsJEJIBRr+ORTuymVK1+rXwY/4I+fsc/C2KxvvF+iaj438SxLDK9x4ju8WS3CHLPDY2wij8pu8 Fy12AONx613RhXxLtBcsO/V/5fn6ExpqOtTft/mfpD4X8PeAfhtoNp4Y8EeHdL0Xw3bFvs+n6RZQ 2ltb7iS2yKJVRMkknCjJzTb/AMd6PZRyE3C8Dqx5P+f6V6VDB06KSgv8xuTbt0PN9Z+M+kW+9WvU Cg9S3Xjr/OvE/FH7S/h3SYLme71qGG1iQvJI8yKsYAzksxwBjPWun3Kabk9BRjKfwq58f+Nf+ChH wf0h4wPHlpclzhfsEhvCuP732cPs6jrj+tfNPiL/AIKUeGLgTQaLpWpXDkjy2KRxxsTjqWfcByOd v5VyzxsIfCrl+zivjl+p5I//AAUB+J1zOknhO0g0q53keZMRcbwcAEZRSp5PzKcgjgjvlap+0X8f viRY3ekat8cvEFlb3G5JImuDf2pJyRuguixZVBJCh4/rXmYjNMVG7pWRcI03pFfedP8ADb9oz9p7 4Xxa4lj8Ubu5vra3tvs1pLPBqlveh2KZhguIvNg8vq4AVfm+VjjI+rPhX/wVj/atsPEkHg/4mfsn ab4ktppIfK1Twdqr6abS3f7r3MF2blRKcE7XltlyCO2a8ihmmHlKpDMqnLZ+7JLyT1XXeyd9X1O+ VKpyRlRptp7/AH29P+Afqd4d/bP+EuuQWn9rz3/h+8kjG+HU7bdtLDDI01uZY1HUElgDnrivf/D3 iTw74rsjf+GPENjqNiDhpbG7inRSegLISAfbOazpV6OLvKjPmX3NeqeprKlUpJcyOlFqm8E9ev3v w7fWrH2GEjpn2ye/vW3JpruZN2Y8aTvAZVyx9ieaH8NzORiMkDjpj19P881nKC0bFzeQjeF7iPJ8 k5Xplf8A61QyaEyhS9sMdRkdOtT7JBzX3PIPib+zz8Gfi7HdD4n/AAs0TWb14Ps/2vUNNgmu4ovS K5KmaHtzG6kcYNfnZ8Sv+COf7LnipJ7rwHaaz4Y1EW7RW6WWqPf2ayZGJZYr8SzyYAPypcxLyPSi NavRf7t6dnqv+B8jKeHpzTa3PzU+LX/BE342aAby7+G3jnQ9ds4YN4jv7W40q7unz9yKFPtUHTu9 wgr8wPjH+xh+1r8IRdSeLP2fPEEVpBB9sub/AE2yTVLO2iA5aa5sDNBF0yQ7A+oruo46jUajVfI/ PZ+j/wA7HHOjUpapXPDvCXjTxT4Z8O/21beJDEyXBgXTsMzFfkO5Y33R8kkH7v3DgmvSrD48xalP FJr+mw/ajgo9qTbyITnlVJ+Zskg7WUc1pUwVN1PbW3Vn2fqupcK8nT9nezTun/kz6e8IftVeNtKE QsvH5nhBQmz1xBNhP7glchxnGMRvjpxX0roP7X+mXEiWnxC8MSWs4z/pOnyCWJsY5KvtZfwL9K+Z zHhmnVvWy98s/wCXo/Tt+R6+FzRxapYpad/8z6Q8PeO/h340Cjw14osp7ptoaBpdk4YruGYpAH6D rjtW9eaXdMzO6ZbAXcWw23kAc/lx0FfF1frGGm6FaLi+vn/X3HtxVOolOLUkczc6XqUal7a7u4Wy TiKeQdc8Fc4P046dq9Ctf2cdO1zwZ4N+IutaHfahp95PM011LFNaf2csM7IPJuJYFjn5hkYyQTvs d0iYK6MD1ZbVqSrNRqOLSvpuzLFzlCK033uXtM1GDQtel1eL4l3Gi6JAiW9hcav4h1GNJXJDC2h2 byrNw4b90pDD5t2QO3+E1l8AvGGt+JvFPjeCy0m9trky654w0CFbqdo8Suss86xTTykFNzlAzMGZ wIxwv1NOFTE88ZvmjovJ+X3/AOZ41ao4uEk7M+b/ABn8bdc8O+KNZ0DwdNa+MPDunypHcRX9hdaZ fxbGb955NxEA5LARtBMo2vGw811kG3nfG3jL9nr4uaFP8Iru513SZVu/P0kana2tiBeF2Ci0lu3R GVy0n7vdnEsnyqWas8NUr5BmP1nBO86bU+V67dkviVr36/mXVoLMKUVUaSlo3/S/r8D1PwH8Qrz9 m7wpf+Fvg98MfFbww3k91PLNpS6nLrxfbtuIRZXHKCMRquI0+RIy43by3xr+0L+13D8ZPDR8BQWW sWOr3MEuyxudCjhs9QXbJktM11JsVGQsFRMGWNlLZ4Xqw2bY/MsfUzCv7NylJym1Jq19W1Gzei2V +liquCwuEw6w8ObRWWm/a79ep+dVzonim50f4eaJq+gX02iWrPf2r/Yo2FvavIftcgaLcfLWVbk5 Y8AE4Uscf08fA74nfD3x/Yaz4K0TUPNnsYIbmW10/Ul2CM7o45I3hKqy5RshHYqdhIG5SfdzZQxE qNSlJWSv31k1+v4HzOAnKFatGTu00vNevqZHx++JHjP4SeCNX1rwt8PYte8KwWk7XS3E6QLZW0UZ dp3l3CU4IK5H3drMXjGWH80v7QHxquviJLeFvh+LPWGmEUSizgmh0+FldnjikljmY790LRTRXCbF jbIk8xDHnhqcPZxjGbs3d9Nltfrra6vsz2H7lJ1bX6enqvTZ7fM+aPBfgL4ieItZ0drTSb0aFHew 3TNeiVLddrZ3At97jI+UMeTX3pfeGPBOj6aL3xHLFa2mOS8km5zkAhEwWc/MOFBPPQjmvJzrFt4i jh8E05appd3t+t+x0ZfQTp1a2I0j0ufLfxA8UeCrCdpNM077KpGVM4SS6nHYqgyIwcHlmPI6ivnT V/F1/qIlhtSYLFxh0RyWcf7bY5+nT617uAw9SNKMsRLml+Hy8l+J5eIqRlUtSjaP9bnKywOyxtKj RwsOHYHHufwrv/ilrlre6houn6VqkV1pFvbfu2gIwjE7SDjvhF49/TFd7jz1qTSulza+eiMF8Elf c7DxB4d1G/tdPe0t2eEWsUKYIyzKoyNo+YDOece/euK/4QrxB/0C5Pyl/wDiawpVqagk5BKNnsf6 mllbT2okku4CsbAAux9T7dDzXmPjfxLYan8X/g38LL97ubTdcbUJ7xLDUbuwlke3tXlgYz20sMgA Ec/G/B3Dg4r6jE5JRzLA18LjafNRcJ8yet0ot2a67BTxTo1qTha/Mt9fwen3lDWfi/8As4aN4sPw 78W/CrVm8bwNeCytNW0WDVL67t7aNzLcJKZbiX7O7IIo5ZnjEjyRjoSV/ET9qj9hP4B634g8b/Gn 4UX+rW/wtcpe634Uh8Pk3nhq6mbmRopphLZ27sRtSS3+UybUzE6KPn8Tw+sqwNGvgaUIUpRWkdFy v4ZWSv7rT6aG9THTxtVOrUu4vtt5JaJa9j4M8S/Bn9nm40IWfgrT9Rj8UJGwS5u7yG4ju9u0ovkK m1GYggnnKtjbkZr8kPHfxe+FyapcTeHY55VXEYjVpJCwUYTBclUCjCBQ7AKiDJILHhpUK6qcrkno v6/4JNespJK+h4zqXxOv7pJP7K0RU/iV53Ziwz1wpGD071wel6xqGs+K9Bv5wq3TX6RtsUIoLlV6 fTjPWu9U1GL1OTmvJaH1KLLznbMJ4569RzggZqJ9FlVDK0THnjJIGM57H6j8K8u66HTy32M06Xcb RJKuH6H8ee2cf/XrWsrJyxG1fmGQcHn156nn0p86asmFtbGzHYbwUEKl8dApwpJ5zkf/AK64EWU1 14gtNG0to5L+6uY7W2UzRoJZZGCIpcsFTllGWIAzzismpSdkbQcYN33HeO/hVrXwrvol8ULbx63f 27X5toZfMeCEyOql2TKHcVbG0n7pzX298Pf2MPA1toWiat41mvpvEc1tBc3MJZIY4JGRWkhYBWZt rFkLh1zjOAauvi5RoQq0ftaa+RNOjzTkn0PouDw/4R+Htro2n6HplvY6Es21lgAWJWZCoeRupYlY 1LsScYyeKp/E6bTv+Fb/ABBMEiO50G/UMoD8/ZpByemRnp179a8iMqk5xnPdtffc6pWjBxXZn5Ga o0M1pYWsM8MbLEMmVOhXrjHP5e9fuD+wL8fPDeh/Cbwr8JvHeuLDr/29B4bjSzcpf2WoSb4wJI94 Z1unu1ffs8sCKM/MpUfpnDdCpi8RicLR1k48yXfletr9otv5HjVZqnFSlte337H6mR4YAEf7uTnc OvBrSWBXZjuzznnsfQGu+VraDSbOitfDum6za3Oka5ZJcaXdI0U8EgyJFbgjtj2PY8jB5rDf9g/4 TXOptq2heI9VtrS6hkM1lmF47cSuG8mJ3TeyoqoNz7jksPmwGb5fOcrli6kK9KfLJdfy6rU7MPW9 k22rrsd74A/Y1+APw6sLiwbTLzV5GaUrNreoyTtCkilTGkcQjgVQGJUiIMpIYMDzX5uWunar8Av2 qNK01fE722kWGsCe2vZ5XaKfS5CzFJDFEzM0kRNuxWMKsjNygBdf0XgRYSpVx1HPLVZPDuMZOMeb TTlTstWnfV9Ltnz2eKrB0KuE9395drp3u/u6dz9Y9W+N/hW3t47wa3ataSAPHIk6MrqeQVIOGGDk YP418kfE3/goF8FfAZv7bW/iNpsWoW6eZJaG8jNwR0G2EHzG69lNfE1HToScJ6NaW6/ce/CLqLmW 3fofAHxG/wCCvPw9tJJE8IWmo6plSySQ2jRxo/Pyt9oaJh/wFWH1r4V8c/8ABU/4xa+kZ8O+GbGw Un959tupboSHHbyhAU6dy+Oa554pp/u0S3CO2r/A+UfE37YX7Q/ip5hqnxBuRprvuNtYqlm0QzyE nhAm7fxOw55BqXS9C8V+NLfSPiD4luNXvvDt0khkvJHa6ukEZaMqxVnZfnG0M4XPUCvMxNfk5ZVJ fE7XfdlU/aVrxTskr22Ej8AXZ1PTbbT7mK4trskxO1xbRyhACxZlMpETbQeJCpzx1r0yP4RTRxx3 q68YLZJI4na9tYgSXH8It55t+ORyy9M4HNePiMxjRnGHs739U97Lpb72vmd9LLp1IuSml/Xqev6X 8Hra0jhNzqV1dTMfvwW4gQ455B3EjnrnvXrvh7wzpmnkLHpUZ9pN0m4dT984Gfp7V4+Jx9SrdJ8q 8v8AM76WCp01du7O0u/BXhbxXc2x13QfNNttaGRZPLMZG7BUKeCNx5/2jXqXgbwb4S8KtKNK0kJP O4M80lzJI78DAYsSwAHbOK8atOTThrb/AIJ3QclDlvp+B9FaNpFrNF50lnbpGV+Qhjljxzgntx3z 1rrrTTtI0m7j1FL4x3sQ3JcRu8bJz1Dqdy+2CD0rzVUq05RdBuMl1vqbqK+113Owsf2tvEvgmdLe 1+IFzfINxe2vbX7crMegkcr5ybTnjzF64xnGPUfCv/BR7QEv003xt8OrxtPUqJb/AESRS7Z6iO0u CucYPWfrx719Fgc4rO0MdG/95b/NdfXT5nDiMFTbvSdn26H2d8Mf2r/2cPiJf2GnRfE2x0PVp1L/ AGfxU/8AZCwqOcPd3WyzyR2E5PpX7Mfs2fstWPxU0fSfHN/r1nP4EuAJbW70y9t7uLUEyeYZoWZG Xg/MCR6V76ft4p4d3T6rZevb0dmeZVhKhdyR+gs3wY/Z18AaHNdaz4L0dbCJR5lxqMCSsce8gP6V 8LfEv4s/sgWt1c2Oj/A611N8spkjlewjbtlWiJYe3yg11/VcPGKV231d3+V7HLD2s7ycrI+YfEfi 79mrXLR7Sy+AmoaRITn7Vp3jC4kk47bLuCVCPwz718665p3ho3U0nhyW6WyJ+RLzyzIg9C0eA312 j6VlOik/cldee/3mqdut2c1Lp5Bf5QTnkH8v8ayrrQbG6UC4tY27jcM5xWE6Cki1N7NHhXxQ/ZK+ AXxl8yb4k/CfQdZ1FrY2iXd/pkEt1BCf4Ybll86DHUFHUjsa/Of4k/8ABCz9jrxiZrjwtb+I/C13 9nZIE0fVzcWxmOdsk0eopcyOB/cjliB9qmi8Th3+7n7vZ6r/AIHyM6lOnU1WjPg/xL/wQh+L3gSe UfDz4ueHfE3hpojLPBren3Wi3kcoztjtfJN5G5PAy8sCk9cda+IPiX+wX+0p8K43Gv8Aw71zTrKK M3Us8EUepWFqm75XlurFpYYBnbw7bvX0rZ4yUanO42v0/wAn/mZeztHlmr+Z8531j8SvA11Zpd2Q l0xWMv8AoYFxEyDguI3yUyRncVjPXGCK9r8FftRappEk1va+Ir6weFQEtpQt3ayhpDuUJcsZEcDH 3JecnBXg1GLwWCzWkuaKv+Pr5P8AM1o4ivg37j0Ppjw3+2HYzy/YfFfhxlVnwt1Zhk3KVzkxykgd BnEp69O1fQPh34yeEfE9nPaeHfGcEUtzCqzW07CF3xlQMNtEhGCMjcPqDXxWNyXH5TN16F5Q7rdL zPeoY+hjYKE3Z9jwn42/CTxbr+ma9P4Q8UvY3t9FFFeM1vFP9oWKXzY/lblHjbdslUq6h3UMA5B5 f4E+Ndc+CV9d65qr6fdXFxYTabdNdWc89vJK8cEqloopIzsE9rJbAgqFzI/zEKD7OQY2GKg8Ny2q N3bvvayXknZHDmWGdOSrqWmmnbc4vxt4sk1gajqnhC8S38exz+bA4tRNHdQujrKjmXf82AE3EM0o nlEh+9vzP2YfEc/jD4wan4A+I/jTXfDepeINPew0c6ZIbK1h1UhFspfJt3jiYKd21Iim+V40zhnr 3MS/q3tq1NXrct+Vv3Wk03ZbcySdnv8AiedG9ZU4v4L2v1Tf6O5vax8StY+AvjLXvAjjUtA1vS7i KCfTtOuDd6RKpTcu2zvIxtjZJA6mKNd6yBgcEGvR7D48aJ8arXw54T+IenWuqalLfBGuZLC5sJo5 cKIViVrlJSuIk3CBnVvKCtAQVx4WJyStToyzGjNNpc6kt5K1/eVrX818z1qWZ0JVY4avB2u01fZ7 aM9SvvhZ4h8H2mleE9LuW0/RrJ0MUc1owkJLq/mq/mmPljkYDsGDKJCFIHPaPocfwT+IWvfFHwnr VzoOp3GntotzfiG1kGoiV45pHW3kgmBYNDFtYoi71ywkViD7+CmsVgqDSu3FfN6PyPwrF5ljsm4m zCVJc3NOScZbNczcG7W2W1u9jyrxLrHi34r+GtW0a1/aQ17xF8N9Tlju5La5vpvPU7FCRTuNpMYA DiBkRNx3NGxUbeM0z4beGfBmjSwz6jKLeNvNlvNQuIxtB2qCzAKirwEHC4+UV87nOYYj2ssvp00l daLe77W/LpsftmRyljcvo42tHlnZ3i1s9n08tO6szwvx38ZtE0aK4s/CUCSQj5f7Rulbyl4PMSHD SHnjIHI6MOD8HePfjBqmr6jdSWcsj3pJWS9ucM2ckkRx/djXJ4AAGMYC17eR5T7KKq1/ja18v7q/ V/IwzHG+2l7On8C/Hz/yOAm0uVNJt/EV/emW5uTkiUlmbGecnJ/hHX161mRvEpVktl39fXPpX0rv 02PJWuolzc+cqiSDAXLcNxk9eK9M8H+BtLufDkF14gt2868l/wBGO5gyLg7SMeuGJJyMYPauTGV5 4agnTfvNq35s2o01UnaWyHeOpZrTXLtrOdo3VIwGjYqSNi9SOfxrhv7b1r/oLXH/AIEP/jV0YQnS g5RV7Izk5KTSP9SsWHiLWiNautThVQRJFaRTB44Qv94r8pb1P4A15Z4q8N6g3jP4dfFWO4Caj4ck 1ETPKpKyQ3UDofLwcBwyoAT0SSTjJAP6jCdOlCSa05ZJ/wDb0XH9Tz5czacd07nx0/xfvPGPjz4x 6l4j+FbXtq9u2nRa5pc5trvWLIAGeCKeAxzo0RijP7uZi42gAOrIPoX4b/HDR/i1oXhTw14k8AeJ 7TRtP0m68OqniG1ihl1TTyI7f7RLuYTJIwtopFeSNGYMxEe4nZ5ubZS8bl0acaitCCSu9VzQa5V1 tHXy0WzZWGr041Wlo5atW83r6u+5+CP7XHgEfA7V/EvjG2smj0ywMkzxBMJ9oQMYVBAOwTPsRQej Oq8kiv50/D/7P3xB1hpJZNBuY41wWM6i2BBI6GYqSec/KDwK/O8LXSg3UesVyv1V/wDgHdVg5TSi tN/vPS0+C/hPwcXHjzx3Y2TLH5qWouA8zKf9liuSeDhQ3BrzP4iar8LZRon/AAr5ZZby0uYpZLxk aNJI+fk2sqsWDEdBj73NbqVWrJSStH8yGlFcrd2fVLWAibMsKqgHQcn2P655zULK0nEaAxE/e6Yx 79f5Yrx3dtnXa+5cttEjlIE9sGGRujO05x144/GteDw5ZEJLb+WJ0JbZJgD3ye2cHpnv14FQ6k73 Ww7XVzTt7Wz1O2lsprVPJkUrIsgGCDwy/wA+nr1rxjXvhfb6Di6XJ04ljE7Kdy+gJbp3+o6ZNXQr eznyd/zIqQvFSj0OP8X+JvEHjHxboL+INQ/tRrNYLOM3isRJBEzTMkgjKswJaQE7gxz94E5r7F0n 9rrWdVmtbPxN4EijdpVWW7jvp41Tc33mh8h2AHVsO546HpXTWwtOvSjC/LbVdtRU67g3zLc+pv7T N7pf2xvCd1caQyhvtFtPaTQ3Ssv3kAlEjLyeSgJxwK8B+KviHw9Y+CPE+m6d4ElsppLN4PMksjCq bxs5PQnnseM15tGk3U92olqrr/gHVUa5XprY+K/C2maZfXOrxaxq9tZ6atjL5s9zuKAbo0BXarHf 8/HHUY6kA/Yn7OXw50jQPiT8Hb/xJr8ur/DRrmW1S4i2WQginMkke24iuA4SK8eOdiTGyL53yjpX 1+S42tgM6wlairOUuVPpdppK3W99tjz6tGNfDzhLtquu6P6LYtPvFOZLGTjrlTx06/5HSmNqNlYl vtjxoOTh3UdvTPuK+lspbMyskcv4i+P3w28CW323xJ4q02xtVHzTXd3FEqjr1ZgP1rx9f+ClXwbu NQuPDPgfX113xBHAZzBpJWRSmQCRKSITyyjG/JzxXHi6tDD03UrSslr3fyRrThKpPlitWeCfED/g oj48k1bUdE8OeGYoWhkkg864uASJFcxn5VHOMHkNXzVqfxN8Q/E7Wf7Y8dtHJqfli3SSEGPywGZk 2ncSDlzznnNfMV+IZ03Crl14Si+ZS66eW3quuzPRp4KMotVtU1a3Ql8R+Cr7xz4a0fwdrfiu8g8P 3l+bf+0/s4vLqEGC6kUGLzoFmBeJYyGkX9385LOoDfBHxb/ZF+I1l8TtV8O/DPw1quueHoVt/sur SaWLCG58yCOVwZGkeBGR3eI/vjnZk7c7RjmvEOExmPhj5QVJSj7+ujnZXaXTW+mun45Ucvr0aEsO pOevu90uiNXwp/wT/wDjtrSs+tzaLo4VsGC8vzcSkdfl+yLLHnkDBkFfQ/hr/gmn4SjmU+L/AIk6 ndxsA3kaVYw2RDYyR5kpn3DOedinHp1r5/F8UU4+5gqbk+70X3bv8DooZPUn71eVl2W/+X5n0t4Q /YY+Afh2Kxk/4VuL7UYnH+lateTzPOc8b4Gdbc9uBEOtfS+m/BbQdK09dO0Xw3p2maZuybeysYoo 8sSTiOJVAySc8dfrXy+NzHG4l82JqNrotor5f8Oz2sPg8NQ92nHXu9znNc/Zv0bUIpGn0aFw53ES RIAxHPTH4+xrzG6+CGk6HIlvLosSOGygMQIyO4JGM4OPpWFLHTvZzdjolRirtfgQy+GbaGIRC0xG Fx8ykk5xnIPB/p/Om9lp1spTzE3EDnHUDjOOn6dvy6nJ1LWdkZOKjqjBvtXsbdZEhwxyegHHtyfp /nmuNvPH11byKbJ4l52qzEjdzjjOAc/r75reFH2kkhX1uypH8RPGozu1Bo4852xrjjPUnHFYuua9 4h1q5aK/1qSKwkhkj3iVQ8MhyBIrSZHRj8pDDPOCBxdXC2pylSV5W0/r/ghCoudRk9DwnxD8PtT1 F4XgvdVYQOVkmutUST7RFIGDBWTeE/h3fKgxnOOtcLH45+HXgvwlqEUPivUdI1J9VeG8msLk3CWd usCBDbyRRmVJ3dmRsMQYztO1W5+kyeMsRhpQnCKai9FHRvov8/meTmKp0aqkpuzktW9fPQzJP2qb bTdH0bwj4A0zULu0ZmXzLy7Fq7lg0ryM7+bK4O5nO7bjIHAAFch4X/bU/aL+G3ie68WfDn4j6p4N 8URBVl1PwpqN3YSuvVd00cglbIB+6cEfWu3BYGeEqOvGVpvVpba9H3Xlsc9XMU17Omvd7s/QzwH/ AMHA/wDwUg0PSbfRfHXxZtfiD4bBTbD4rtVuJFTuFubZoJnYjgM7yH6mvub4Zf8ABwN8J9YMNn8a fghruhXDMi/a9AvrfU4jkjdI6T/ZWiQcnCmZsDvxn0H7GtNtrkl/5L926+WnkY+1vufpD8MP+Cjv 7FHxjlFr4S/aI0GLUAyoLTW5pNGmkduiRpqCw+c2eP3e8c8E19p291b39vb3FtcI9pIoeKWNgUkU jIKsOGHoRWVShUpq8lp33T+f9Mvmvs9CyQpxu5zwSDTvJUYA5B7gVk4X0F13GtACDtJ3dACcd/T/ AD2p4t9m4q3Pt256D0qZUlayHfsdJp3iPV9MhmgFvZXNswClb3TrW5YKP4UeZGeP0OwqeevFaN3e /DDWklXxD8K0gUD5f7B1ae13HpulF6t4H552p5Q7cCuaeGpyVtvxX3f5WLUj56+In7Gv7IvxcnkO saVa/wBp3OZrq91jQjZypt4CLf6bLLeO2ABkJECB26V+a/xc/wCCEPwg+IU11qXww8Q3VjcXl5vi trW4tNWBTH3YLVmi1PrzmWV+c/L687o1KMuaD/y/zX5A432Pyj+M/wDwRl/an+EU13b/AA9uotQc ySJLYR3K281ug/jnjvlgVWIHCxmZ+2ecV+Z/jL4bfH34NldM8f8Awzv7IM7SRyT6fLA8uMBpNrqG lXCgg4xnkEd+ujjKbXssQld/cznlRbfNBWZpeE/2hvE3huIWumeIryGJXy1pdSBUdSCCCrBoV4P3 sbuM9a9TtPj1YanY/Z/FuhC4eVw0M9nKqfeZmMQQqVkBeRpFbMZ3PIDww2YSyilTxKx2BSU106M3 +u1JUvq+Jej69Ue1eGvEXwQ1ueBLbUhbajHJH5dvfssf2hwwJBmcBI8YyCplySRjpXVeP/hdpHjb wZrV3LY2h1CSGS5s5rMECGXkgwuuWVQ4AGD0HNfMZtmGKhj6Eq1JwlHr0ab7/O1j1cHhaP1adOFR TTOw00eA/wBqP4OeGfHvxi0ed/i1oVgNGupLWWGO68QQCTCzQ+bJHvKSeezos0TLI1w+0rJAh828 H/Bj4SXk0eq6JHqEes2qFXgvJrqK8sC6dfLd8hxkgSLuG4Hax5NTUx+Y4TCVaGHqJ06cpU2mrtR+ y9dbW9122aJhQw1WpCdWHvySae131+fX0PbtU+Nh8RW+vfAj4peDNQnvV04SaBrtneOkeqxMFhnW 6ZSoiaMuH2HzVmX92UGEZPKfG/hTWNa8FXvhHVNegutDkt1iml1ezN3Oqor7XSXzVCupP+tKs2Ru 3biWLo5xPLuSFJKcJe8ls1zWurrtLmVu3XU8PH8J4DNMVHGybhVhJXas+bl2vfTVW1XY+IvDPxaj 8Bf8JHoujacl0Y5mEV21xi2QgYLMQOVDDAC5GB975ia+efiJ8cL/AMSTs9xqZ1G6Ukxj7lna5A/1 ca8OeMbjyf7xr3cDla+tPF1Pidv+3dPz/L1PSxuMjy+xo6R/P/gHgE2r6jrE73N/cvI24BcnhAM9 FHA4xnj3ryy5dpZ5G6lmJ+vNfU0EotpHittu7N3SrFbpLjaXZVGWCjKp7nPH61ozeHdQVfMtnVkJ wvJVs/Q8UOolNpoVna5WtbYtexWV2hwXCuvf3GR/Ovpex8TaI8cMCxmJ4lCxxnlRn5QAenTHXFeT mtKrV9n7PZfrodmFnTg5c3U8e8b3Rm8Qalnna+zoMfKAOx7Yri/MH93/AMdH+NelSjanFeSOSfxP U/1KvDtndTKkEExtbJflKcZkIP3QOw46nP09PQ7/AEPSfEQtdBmjQ2DBvMhy6ibaCSDtIPJAxgj2 Ir9ExtSMKEpbaHJTi5LlPjSx0v4Z6F4Kvtd1jWbO30zR7i7+1Xis8UUSxSvGMiTOSQFJwSd7YDHI z438dfBHxLt/iHFc6B8Wrjw/8JdVtfNvNR0nQ2uryyjijYXaPqOTDpMXlbJIrqRGfzHm2spijB9P DKlFU6tWnzxXS9ru19X28lq9jjrc8ZJQfL3fa/8AwT5y/aAvPh58RTeDwz4qi8TaFJZx6bqWtWwi lgvrgIQzfabdVtZJSgV3NuMRtj5Eyor+RP8AaTHxu+G/xO8UfDrxf4ovZBZsRaTRMLaHUrGT5oZd kGI23LjcMttcOhO5TX5RXw8sLnuMoV6fLLmbt/Lre33P101PXlNyw9KpF6NW08v6Z8smyuZydztl uck7c+v+c1PLpUsOkG/e4TG4xpGsis5K7S25M7lXDDDEYJBAOQcdTOfzP0W8Os+o6Fouo3DlmurS KYjGPvordT9fTtW7HawBldN+9eW6dcevY9fzr5qp7spL1PTT2JCq7w0alR/e4JyO3HPb/OKlFwVW WJJiT05OOeMZzxxjHXtWTHfsLiF3/tG1TcR/x8Rg43YB56ctjJGOuMe427lbfUbB1upTPYsnzu2S AuMkgj2/kKzlfdboXkfD+p6o1rr0lzHaNNOyOehYRs7Z529eBjH+19DUh1jxVeFpBAY42JCiMbeT npkk8Yzyc9692MYOMZTfQ43fmaR7d8HviF8QfB/naXqmoyzeHpnMos1Yu9uxIy8bMQAG5LIcDJ3c MTn0b4meN7TW/C2r2f8AZ1yLeQxbLi4lIaNvMVssiBh2+8Xxzjqa56kKcq6nHZtX9TpjUl7FqXY8 N8L6Zpupajfafrdu8umyWwYqpcR5DqcOQQTk4YDplc4OOMn4j6paeHtHng8M20dsYG82IiNRk5Ab IOQ2RwQ2cjAPFdSdWlio8stFZq3c501KnzJdz3zwv/wVq+Oltp/h7w98Q7OTWtDsLGKzZoNVnsr2 6aJFjSWS6xI0rMq5l8wOZHZmLLnFcj8RP+Clnxo8ZaR4o0Twjo2m6LZ6knl/arZJ5b2wjxhvKmZg A7DOZGRmBwUKEZr6CrmDqQlaNm29npr2Vv1Mr9j4km1fWfFNvfX+p6rdXeuMPOaS6meR5HUZYEsS WyORXv37HmpanZ/ErU9SgRklj0wzxOYhtDpcQMp5BBwQCAQc4xXhY2TeHrOTu7HRhm/rFNo/QrTl fU9evruVAJnkd2xwCWYsRzzjk9ef512ZLRyJJENrJhOAMFlyQTnPbg9vlr5m65kr9D6BWR9CpdXU XhTwoyohe81GCFgquQQ00gyRzzsbGRxx9a+xPBHhc+IdAsNUu7r5plLbECgAhmzySd2cE/pXhZq5 Rw75f51+R14ZJz36fqekweBdEskD3I3RjI4DPkHt83A//VXx1+19491L4b6X4JtfCFxLDb3zXi3T QLsfMYgCEMOdoMjEgHnjNdnAuAhmXFGDwmJipRk5Oz1V1CTjddVzJaddmY5zXlQy6tUpuz01Xa6T /A+W/h38do/Dq6gl5pWmXOkyXX2hzq1ld3148ZCKURkmjt0O2NsAqVDMWxjcp6Pwt+0RNefHT4eR eA/tmkeFLm/gtdS00sht7qN2VJCIRlECoTt5ZgcEEY4/oDPOD688Bi6uLppYeFGblzNO8lD3XBJL ltKzT0enmfDYDNYrEU4UpXm5LbTS+vM3vofqdeeLdDtoAwu7dUPbeCTx2A5ry7xB480S5WeEbXXq p29D0654PP16V/K9Ki272P0uTVua589eLtRVo5bixQNEG3FDjgbvvZ64HOSe3tXhfizWtQ0+xnuL y4FjGM75DDudVxuwN2Ru79+h4r3MPF1pKjBXl0SOOtKNNOcn7p8yaV8ax4r1jTtK0fTpriaReZ53 hUcKXZtsTOOiNhd38J9Kbqvx3+G+krPBr/jfT7KWN2R4xI9zN94DHlQIZAME5yvY9cc+1TwNWFdY W15ON3ZaLpq2cn1mjKm6zdo3tr108jwrXf2tPDck0lr4X0DUNTkDMgZlS0iYHADKx3ydfWJT+fHl 9z8fvijqk22zNppeCQfLheacgnO1vPLRnpj/AFY4JHrXuUctpUleq7vsv6uedWzJy0oRt5s57UdZ 8S+NJok8SeJ9TvED+YEuZ3lSLIOSkZIjj5/ugYrrY9Bv9Q8Lad4RttItl8MXOpmQ6hfzW9jG10yq u1r+dkSIBVDFfMVeNzA4476PLRXLTikrWSS/I82tOVT36sm2efQeFmgVptJOb3YUVbi3UsF242lg MjK9D1A+leZauZtML6Vrfh2exklPnc+avmghl3gtyy4JGRkHnmoi5c2kgumrSRRgXTBJDNYXUkCr sDKHGH29c59cnPOOelacd9NF5gkYSRdVwMH8uh/T+VOfv/EtSovlWj0LIk06UMQwRhnkNjbxnPuK 6H4cftH/AB4+D2sM/wAEfjP4j8NQiZZnh0jV7q0hu3GAWliRhHKMYGHVhjgitKEqkL66duj+WzG5 WtyM/Tn4T/8ABcf9uTwBLFY+L4dA8cWJlUy/2ppAguhEMZSKXTjAqsR/HJFKcnkGv1j+Dv8AwXh+ FPiaO3T40fAXxV4UlaQI93p8kGq2cSHAEkjuLaVBk8qsUh6daqaw87aqEv8AyX/Nfj6Fqrd2kj9M /hT+31+xx8aWtIPAv7Qnh5tTmnFtBYarcnSbyaQ4OyO31BYZZevVFYZ4BNfYMciyIskMoMTAYKnI IPcEVlOjUp25lp0a1X3myd1oS5XCgDJzjp+H9KQorMAxGPT6Vm4J9QTa3EeBDgZyBnPHWoBExzgn aBuIzwfSspU3uh31Nq08U+K9N09NDtdfuv8AhHhL576ZJI8lhK/cy2r7oZQe4dGB9DXJeJbHw14s stdtPFPw+0O8n1E7JrpLNrQwQnAaOG3tGis0yP79tJ7g1zVcPCfxRLUr6tH57/HP/gmN+xT8XbjV r63+ETaJcvGsds9jOkU8fd2Z7ZLeBmznG62btycV+UHxU/4IV3tjcXerfAr4xSRSJt+y2HiG0LZb +IyXtqAQCOii1b0JNYwnXw2z5o9uvyf6P7xSjGcfeW58E/FH/gnV+3J8JkuLrUfhBc+J9Dt5Vhgv PCNwl688jnIdLWEfbioAILG2UDuelfMGneO/Fvg7WLzRbbWbzw7q1v5lvf2t8XtGg2DdJGyPiNX4 YfvBknA2ZIFdUlhcwpunWgn5Na/15/iZQ9th5e0oy0PY/hF8edQ8KWS6BFdWVxpjSm4hW6eRDtd+ VjuYlaLczMzYdI0Xa3zV9Iz/ABU8M6pGsmpadd6Fqcwfy9RMEd5BHtPLJcwCSIk/dJ9sNwMV8xj8 lxOFxc8bhHzKV+aD2knuvn2evZnqYfHUK9FUK+jja0uzOf8AFn7SHgvSI7fS/DpPiDWgikm0IW3B wvMkxBReCThQ5ByMDt8TfEn4v+I/G0bWut6z58av82m6XmK1iYAZEh5yev32Zh2AqcoyZ0prE4iH 7zdRe0V5+fZdC8djo8rp0np1a6+S/U+ftXvorqaa01iQx2Yt/MS3CMsYA3szHH3gOOuRXhc7xyFm t4ilsx3RjGNq9ga+yorljbp+p4EnzO5NbRukcYVT+8LAfXIx/n3r1DwD8OfBt9o8N3faxGdcaSQS CZN0KqGIABB4yMdRnJ64rDHYurhKPPThzXavbe2ux04ShDEVfZzly6aX6vTQ7yL4YQadaymDabFl doxZSI+8gFjkHLE4BwMgVz/xH+G2ueAIdLuLvX7G90e8tRqFrc6dKZ4pYGJCYD7NpBBB7j0rmwWO p4mTUU7vvo7+f6ejKxOFlQdpPbbqun+Z5T4Y8L6n4pur6+0RAyW0LXF28zGNYUXALbsHOM/dGTVj TLi1ttStIJN7u1xHk5J6Nxk5+vH+Fek6sZynSW8d/wBDj5ZRipvZ7fqc/rzz6hrurmBdzPcStgdS Ax+vb/JrI/s2+/58pf8Avn/61dEE1FJEymot3P8AU9B8iY3s1wqfLg5PIHPJ5/nV3w/qllrR1N4N VimmhtnSNlYtvkGDtUg4yoHOOxFfe46cXhpQSu3p95z0lqfI3w6+G2n+I9C8R/Cf4ji1dpLq+nis 0keSK7t5WZox5jKhLIzsGbapyEYAE8a3wqTTPEWoeM/hF4809rPxNaTrc2TRfbZofJgkVra4ikvx MjSqUt5WgLSRFlZdjhJs6QdSWFkoyaaippeasn5/c+hFTkday+GSaXy79Dx74x3viO61HxPb+OfH OoalpGj3TWsdtqtjo0OopAcbZYo7GRS8U+xykjwIxWI8KASP5gv2/Ph8PivdtrvgbwZeQ+JNHURW tpe8Xt5Z5dnhKqDiQO7SRxM2T+8C7ndUP5zjPZLMJ4ik1HW7V2+lnq9bWv8APQ7mn9XhGS1tfa1z 8YkkN3HFKSMMmPkQDpx24PfJx61YWNZEkgJB3LgkE8/5zXV6HL1Pv/4cgX3w/wDBlzFFuIsYYHA5 w0ShD1Pqjfn6V1TxSK4SJlAKbTkgH6ZAPp7dvx+Yqyi6tRxd9X+DseklohDalHV3co27HPbGOg/H FQXtlsIaB2kyOBheR3J55x0zj0qE0mh+hAkWpB1CgxzKo5ZiCQMkA88/X9DWRe3M1pkxzOYHYtMg J/dk4+YAj8+nY9zWsLPRIlu25lSaRp9tN9uOnwqjOWaTy1yxzgHdxn/Go7ltPW4LtbI2AcKFO1Tz 06557+2K1jJvZkuy9AsbyMSKDCMYyNigbMcHOSBjn9PpUfi/UN3h++DICH2A7gQf9YuO1Uo/vI2f YenKzz3wgxWPW2V2UssaDecBCu89Dn+8PTqK4DxkLycPZv8AMu7gnnP4dB3Fd0Gvatv+tDCWkUjw 9/h/rFzOzWgj8ktwXYjbk9OBXcaR8ObixiP27UVSXkuAPu4+o9BXXKrG1lqZKL1bIdRs9N0owSWe rpNeBshQd+ORxuAIHUjBqO18Q6v4U1uy1jwzdz22pBRJHIj/ACsCcspToy5GNrZBx0qLc+k1o9Cl JxkpReqPv34GfG7TfGMttpPiG3TTvFGdkasT5F5gAfumY5Vsg/I2c8YLdB9RM0ckV2IyxIlLKeBy OTjv0JHQ183iqPsMRy9N0/K57+HrRq0lNLXqe8xRafcfDb4ZOuoJ/bb66S8IYEQiKYr84zncQ0be gDrnsB91/DnXRYeFdPtwiJEPNO2RwSuZHbBPf1rxM0jzUmkvt/poehQdp/I6i/8AF+lNFsuL+ELj OFbnP4D0x3r5D+Ofgnw18V1s4bnXbqOW03NbPEgbZ5m3eCpODnavcHjqK6OGMfUyLOcPmkaSl7N3 s9ndNP70/kZ5hho43C1MPJ25kfKsv7PlzGoit9ekuVztBNkqYUDAzmbt3wScGtHwx8EdI8J6xb65 qGpibU4XEluJXEMasvDHy8FmIJBHz4GORnGP2/iPxVoZrkVXLcDg3CdSPK5SkmknvZW18ux8hl/C 88LjI16tZNRd0kt7fM9mk1O1tY0NxcXMspBO2BXBbGc4xjI+rdj6V474s/aX+FHg6O7g1TxhpiXE I2PELsXMytxw8MO6Ud+o4x+NfhOHwFWvO1JNt/1r0R9rOtTpR5qkkl+Z8leMP+ChXhKy+1ReHNG1 PUZgzAMFisoCuTjbIwkm6eqDkV8u/wDDSnjL4l+O1m1W5+x6eVl+zATyObGMxSKwDDAkYq7qJGUl Q3GMCvq8syn6nP282ue33fM+fx2YQrx9lTXu9X3PSvhvF4EutEbVT8RYbfSm3LNHdagIPJZwVKOp ZCNwBznAYdARXB/Fy2+Cep6bbz+B4Em8QxzlGuoY3jDxAENuzhXGcAHDYHcCto0cT9Z9tsvLr69w nOh9V5J6vp/XTzPJtA1ePw5N9qS3ikWRTBJEQMMhxkHcCCCBggj1wR1r688AeHfhB8U4rbOpzWOt BBE2n5jikfhiHhVg8hCKgwsXmRoCcxg4NddWEnFypvX8zgp8r0Zn+O/gN4j8IWUutadrsV74ZjYg zEiKSFc9WJJU/wAOPm3HPKDOK6b4U2HiTStE8eaXpPiabS7W/ht4dRkg06CSbFrOl1EpuHX7VZ5l iVi0DRlvLKtuUbDlGblDWCb7Pb+uquU4a8rZe1PwFrWpz3Ou/am1A3Msk11ewSS3Ds5ILvM7ZYli 2SWJOckmuW1vwsms6TFpF6jXFlG7TRwOGZEkYBXdVJwCVVQWAz8oGeKylPlduvUI+8ttNVr5f5ni eq/AqwuJTLoWoNbXZLKLaeNjGTxjBOXQd+Q+cnkCvEvFHgXxf4LiS81zRJotMd/KjvFTdA7ddgkG V3YB+XOfyralN1LprVfkTL3Wk9mclOxa3sRGxN1CX2mQbllVs7UK+i9AfSuY3XUNy95cQbZXPmEK eDwGJwTnvXWmnGxm9JXZ7d8Jfi5ZeCJr9PKMn2uReJSUjgIyNzFQxIGemP4c16zrn7Ry6nFdaMul WV1azDywkdvNK7E8Ar5m1CQcHJGMjpiueop35VT+fT59TopunZuTOR0Hwzfa5fRyrZtDIzeZIzOG 8kewwFX0+XjNfa/7OHxR+Lfwp8XaH4f+HHxc1/SdLM5klhs9ZuoLJ5MEFnt0YROORncpHHTAqYVa tLaWnXt6WKjd7aH9FPgb9pv9pDwxolrqHinXdN17Syi7p7yxhiZMsFC7rcw5zuwrEOSTz2z79o/7 eHh22DJ4z8A6nbsrhd+mK0+1e7SRzpCYwOcgGQ+mScV6tPCU8VDmoPll2exPtuXSSPaPCX7Xv7Nn jH7FFY/FvS7K+uJ/stva6676RPczfNhIYr9YWnY7WI8sNuxkZAr6QjIlVJEYOjcqwwQ3uO2K5K2H rUHapC36+jNVJNe6wxlWZh0GMY/z61A4QghRz0PT/PeudxTK5upFJbK7cr823PTNUhpsTyEFRjnj g1jOlox81tCdNJtzkvApHuB09v8ACvNviF8EvhP8VbC20r4lfDTQvEWlxMZILfXNItL+GFmUqWRL hHVGx/EADwOeBXPPDp6rfp3Qc19z8v8A4q/8EV/2QPFvnXXw/wBN1vwTrO2RjL4f1q4kt7qRjuH2 i3vTOpRSf9VCYBgY9MfnB8Tf+CO37Sfgqee4+Hvi3w94w0HEl1NBfW82k3csg2qIYow88LEhc72a IAk565pxrVYK1XVd+vzM5U0vgPgf4i/sqftF/CyDUrr4lfCLXNJ0SFPtF7dx2ct1aQiRixMt9AHt 17LtEgwAM5r5d1XQ7JJof7MnV4hjdCMYxzhgwOe/Q8H2xy6VVe1lUjrF/wBfIzlFuKTex5V478Pa 9f2txPp9oWAtpYSkRJcBip6ZO5fl59N2egJHhaRtHHHE4IZQFP4Y712RcHG1PuZ+9fU27BoRLaSX DYRGDMQDwu7J/TNem+G7n7DBrcWqWUT6e1y9xBIrhkdZiWVVY8E/UjHU8Vx4yk6lJwTs9Lff/wAE 6sNUVKqpNaa3+4ueDPH2qz315pJ0r7JK7+ZZSNvUSYV1ZCxyrnadwHT5TxzUuvaPrek6bZ6ja6nc XugqHjmgkkT/AEYk5LJGAAoP3mwMnqSeSDC4SnQr1Ene6Tv/AF53M62IqVEk9rs5jwvfSeEo9T1W O7UeFb6GWCW0ZwPtcqgEIinqAWDb8fIMjOcbq3w4trfxZ4k0Lw4XYPPP5jtEpLRKmZHO7sSqN+da csU61ZfPzaTTf5L5ESb5YRfy+Z77Z/AXwu8N74iTUNQRnnmUHzYHUATFM7GVck4yPnGQw6YNS/8A CovDX/Qf1H/wDs//AJJrnr5iqEuSTS+/9Bxpc13c/sS8UfGH4peKn0+bWNF/sbTrsyeXDr18LELt jLxkRjJuN/CgRb2yQCK7Hwj8O/i1q7G7l8WavJCsjkW3h62+xW820Mis8mpeWQDvjxJCJwQsuC3G P2ijhIJxliH7q18rru+vpFN+aPGeJk1+519f8t/vsfXN74dnm0+yuLJBa67bBXtyH3GGTsCwwGB6 MDwwLA8HFcd8R9C1/wAY/wDCuviT4H1EWHiu11OyuZ1Z5DHHLFIYrmKVY8Gb9zLdxBW27hO2GQvv HJzQhW9o9YJ/fF6Pfy/M3abS6O6aP5Qv+CvH7R/xYtv24fjhe+FEgPgqwGm6bE0ljHK9r5djaiUS 7suoNw8uCflO9QOTivymvf2pP2gvEup2sA8bXFwwIS2tWtbaSNcDaoSJ0YDgAcDsK/PGoON6i2u/ k9fyOmNaUopLY8bXWr7W9U1jVNVlV9RvLiS9mZIo41eSRtzkIgCINxJ2qAB2AAq9GVwpLNvOOc/j /n6U0rKy6EH2z8E9c+3eC7W2aULFYzPFKMgEr98H6Ycj1JU16Vca9okUpMOowvKRhBGVbPU4A6nO en+T8oqMo4jEQS053+Op6MZLki/IdJqMLltkYDYOBgHc2eM5/wAnNNGum2JEBcjbggLxke3bvV8t 9yk9LmXd6ubiREmBUc4bHJwPzH+expkssFskkisGidMOHUFQRnkHB/E9OPaqjDl0WwnJPZmPb3Mq SNZpbM0ZICDBOeThcflgdun1jvoRtH2U7ZugwGK5GSRx06EcgdB6cbJOLvfcTvdvsY7rcxgRqu0s SDxnd7H+VY3igX66Jc72/dMVAAxnJIyRyR1HX2FbJpyjp1JlomcHpWtaTYW1+99dRRHz+E3ZcgIg ztHJ7j8DWNqXj3QFVoYLIzyDlW2bB+Zy38uldapSk+ZaGLkkrHE3/inxPcMkOl2qIhI2+VHuPtlj kZ9+KxL2316+RptSvHAZiSXlzt5IHfHY8Ct0oR23MndlSDQklCrHdncx4JyP/wBVdvp+i3Edjbwz 3CkK7lG2EZDZ4JHqRx06fjROatsCNCXT3kWS4mlwApOdx754x39Pyr6Q+FP7Q15oezRfGrtc6LHs WO/ALy2q5GN4GDKg/FgAcbuAOLEUFXpuL3W3qdWHr+xqa7Pc+4/Bur2c/iLw/d2FxHPp011CYpY3 3Ky7xg5GR1GDnv1xX1tFr1pbyTyXOrbLaHERUvuwQgLfTI5xjoa+cxcGo2ktT6Ck05XT6GHq/wAV fDej2NzfTXDNaR/IZHJijjP+0zYAHuf6GvJm/aO8O6lN9k8NNHfzsGGNJtrvVCrY4DSWaSRRn3dk A78ZIwo4WtVfur9F/XlubVK1OiuapK3YzZfH/wAWdZgD2XgmaztCSZLjWdQtrYIg5D+TbeeTxwVY xngZxWR4otfiDaeEPEGs6p4shj1Oytp7pItPsQqzbY8qGM5kzgqD8oUZHSvZo5TLl9pVe3f9Fv8A fY82tme6pK3mfnl8R/hN8ZfGHgi3+INp4o1HW/DsxmebT5byZ2tWhleMlYmbaQfLLfKvG7HfFfFT rcRTPbXMJEiEhlbIIb6HpXvUXTg5UYx5eXp5d1/W54tV1Z2qVJXv1MOaNVZoyMEHj3rqvBh+z69B cEEhYLkKoXOcQORx3H6V0mD2sZYtzIzrKuO/Hb/Oa37cmFywkwTj5kzkcDPHTpz0/pSYLud9pVzo 13tF2oguOrljujccnoASp+72bOckgcV6lpFtYWdsJ5I4mj4ZVl3MsmTw0aqpBHAw2ccZBPfGSaZo mmfSHw5/aA8V+GJoovNOoaergfY9RkCFgOgjuUBlDE5yZfNyPlAXk19H6Zo/wL+MUmnQeFYZfDPj xy4ttPtlWF2LB9oisjMkN5nDny7C4t3JO6YHmuOtFwl7ej8S6dH3f9bb7XRvBqouWf3iaZ45sfgJ qEXw2+JUlvqNtqb3Go6fqOnXAkkCII0KPBMkU9rKBG8hSWONdoGxpyylvUvFHw68I/Fe2i8S/Bzx RourMp33djdTTWV3Ir/Pnz0EjQSYAXE9pKG8w5MZ5rCopOCxEY3T103V/wAGvz8jSK0ceq/E+QPE ngnV9D1ZdL1PSbnTtZbAjtb8W8U93L8qlbV45HhvyGOdttJM6oNzrHkgeY3k95HHNp99bRz2b5WS N1BzzggqeMYAGO9KMmruOzX3r+u+wtLWZ5Lrvws8LayHn0qR9PuS2Ds+eEnJOSuflGCPukAelcbF 8LPs0Elt4islADZXULc+ZH2yWAG4dcZIB4HWuqlXduWW/cxlDtsYup/B2xit5r2cmNWI8mWJjLHO x3buQPlPQgHHAPeuh8DfDywsTK8aFpCRundeuR0Udxnit6k7q1iIRdz6F0vS7HSLSHTvKJkuMMx3 AFiSAuSO3tj+tdR8Iraxv/jFp2jeYWtHaRVdT90c4K9en5nrWE4/uZSkzdPXlifunoGn/EPwx4an Tw3fRyQGzkNhdSBZIbedsiKWRAMqqthnAG0BjzxWyZ/iDr0firS107w9fi1vpILjU723WWVlMENx Hbzxww2y27sl1AyyqLoIrfOkpUlvVoqtKHPQfvpL8br8HZ77XMKtrq2if9aH5ueJ/Eb6VPpsvh7x O1jqFxH9r1+z1K6urh4r3Zax/ZlWVdluqk3UpdI7ZDuiYMYY9h+E/G37YHxq+FmpGP8AZ4+JPiLw 75LxalusNSlt4bqXdJv3Wse2C5ikyHJnictgYypG7bA4+licLip05qUYSs76+9pdWfS7su9tHZou GHrUmrpp2b+Vu59Jfs8/8F5f22/D2t6T4Z+KB8OeMNKuLtUlutT0VLW9UOQqpG+nvbxAZI+ZoZCM nrjFftR8Of8AgtB8L9ZitIfib8JNa0a9km8vzNKu4NSgRSM738z7O6DjoqyHpXnV6+GjUUWuS682 v81+JrTbnF3Puz4fft1/smfEzyk8OfGrSYL5n8v7NrLSaVKznkKq3yxeYeuCm4H1NfVltfWt9bQX tldxz2jgMksbh0cdsMDyD6j86bjpdap9Vqi2mkXFu34UPk44IpGuBkErx1zn+lZuCtYS6WRE7RE5 wORx9PoapXFvEQxAwQeeO3FYzppgnY5XWtBg1O0ntHjIV1KZGAVB/wA9a+BPip+wV8JPiRPqd14k 8DaNe3Vy/mzXjWxtr6Yr90NdwBZ+cY++BisHSUemoSXNa5+YXxc/4JV+Ci99J4C1zVtC1B5WdLe7 Vb2zVcNiJM7JlGSPneWUgDO1uBX4jfGv/gnr+1D8Iry+vtQ8Byaz4bEmTqvh3zL2FV2+Y7vCqi5i RBndJJCq5Bwx4J1ptRbUuvX/ADMmtNj5B060gGpadbXoQW3mp5pkGFKbgCW3EAD616n4o0HwrYaT Pd2NkI7zhoRG7hBkjJAB28g9OnelJzVRR6dQUU+h46JJoWLwuwOScq2Cfy+lal3r+sTWYtzfymJi dy7z8wxg5PX9a1SSfMI52EWZ1Cytpoi0ZJeYJyfLVSzY5HOAe/419WfBrWIPDPgufWtO0aGC5knl LY83LBSgwC7FlyQvIyOOhxzxZhOpChFp7tafP/gF0acKk+WS8/uPRZvixHc7LVtDjTSsEmIOxYtn cMMCqgAnpsPHvUX/AAsTSP8AoAH/AMCf/sa8qtClXkpVE7rzR0/CrI/s78P+I7jw5dtqek/Cy3tn kKW7f2lqMNrO8c08cRlC26XLOpkkQkStE/BODgV0Nv8AHTQtIj1BfGHx70fTLyGNJBaeHDpqzMXe VDFIt013NMUCBiYEhcBgSFr9vVSpV5pt3l+H9fcclCjgsOlGlB1qm1kmoJ+f2pf+Sr1R1mgWHgS8 0NvH3hF49RnaPEGs3N/PqVyiO3zxxXF08kkSkt/qlKqCfugjjrdA1i00uTWtd8RSraeFtKtX1e8V gdo+zwu7TPnnKqHbI9u4GPPxNecKVaLWsYv/AIb7zKvVqVZudXdKyVrJJdEtkj+Hv4qeIrz4v+Pf HvjnxfDt1rxLqN5ql9bmQEBruVpXRSOy+ZgY4AUY6Cvn7R/hD4S0DxdpmtP4g1GKxtp0mjiXY0yu rbl3TKF2gEZJEeTjjB5r53EYV1cLGVBq/Klrttoc0W4z12PDvF/hO80XxNrb6RZOdMhla4WJTue3 t2AkXeBk7QhHzjjGCcdBSjAlCvnKsN2cdff+VcEVJRSnvbUtHq/wu1u+sdRvNKht454LtFd4HHzS mIMwVTnCnaXOTkEgDjOR9GWv2S8hW40eyUQH5g3kgeW5Iz8oHBGe+Mc5ryMXT5aspQ66v8v0OylZ 0r9UNSOdCwkJEbEnAU/Mfy46D8vatFUaCFxccQqp+VsHcSPT9fbr7VzNJo0d9zHc5PyqSyYADKPl HUnjnpj8vatWCZ5T5CqQpBxvIJxxuyePfrng9abV0mC0Qt/d6ZaWq3N9ewwleQ8lyIwFwuMA4z3P +TXn+ofFrwvpJlSK4luZCeHjjb5yeud+PzGa0p0Z1bJLTuTKfJued638cFcPJaafa2sqx5VZmeR5 xkfdI2gcZPP4dRXlt58TPFeoT77nXzLbknbE8SopBJ6qvGeT3P1rvpYWEI2kr+ZjKo3toc7Lq8t5 dG+mmRpWYuVH3T68f56V0Vlr2m2+wS6TE8wP+saZj074xgfhW7g2lGOljOye5uN4utn3j7PsTHOx uo688D/P0pTrGk3tu1pcu6QkgkMnoSRyCSOp4HH51nyNDOk0qwsGED6bqgkwRJ5aP824DhiuARXa xaS8ki78uD8zh92CCcNzyc9f51lOT+0tRpX0TLoS1tt63M8cMQHIcbs9+OuD78dea5bU/EPheOWZ 4bGN5WJ37LcIhJ4I5HH1API/KIxlP4dglpub3gn4u+MvAGvaddeFbe3njEyynT7jfIkpBBHCkNnI 6qQeO44r2i++Lfx58Y6tBq3iJ30rwxJPDFdQ2US2wjiOyNvLM26dWIGd27hiWGOKxr0MPzKVXf8A N+h14fE1opU4ff5dj7+8M/Bv4V4tdXHhaHVJ5FBF7rc0upzjAPSS7aQxsMjITb1GOMGvYBZwWkcd tBCqQKMIka8KMcAAdBnn8q78PSowgpRXz/y7fIicpyk+d3Zxfi2S4uINL0KLKQXjHz3XOWQdE/Ek /gPxrxP9pXxzN8Pfh4bjTNatIGaAWJ0yZU8/Ud5Eb7OpUKmWPyj7wyfu5znVk6/skrp6Nfm/khuK 9lf5nwbY/te+KbHw54f+G/hzw1B/ZiI9tcJiR7qdp53lYRkFVH+t2gbSf4sgnA7bUv2bLvxlYf2t rLQaXr0kYkG668+RfQMI4yrHsQX4BGD2LxVCtLFU6+G6aNPtfqKlVjKhOjOO9n9yPjn4kfC7xb8P 9Wnj1jTnNkxPk3SxjyplyMHIJx24zxnFcr4XLw6lCUwX2SgZ9TG4/rXVCfNG/Xr6nHJNNocEG6Rl wBuKng8DPFWmR2dCGXAGT/DgY6CrEXIBHMEjmARskiQAKSR2z2HQEGuo0bWrrSXQWzq9nIAxtJgr RHOASMYKkleWUg+/WpsupSZ6Np+tadc2yweb5TrlvIuMFGJHVZeOeOjbcbRyxrvdM8T7Ld9MvrYX WmcCazuwCuck8EgFcDocH/HnqU7q23Y0jLqO+J/ia/8AFV/4J1C58U6rfQabZS2VrHqly90+lwEg rBHM+WMOSdqlsIAQoAJBoaR4l1TR5otR0zU5YrkHzElVmSUA4yAc88ZyMcgnNQnLkjzJfId/eumf Ueh/tE6rr+nJ4Z+Itvb6l4daFLeSK+s4ZxMBmQM0MjKrsWKANuCgZJycCuE+LuqeFPD2oeCm8DeI ftOn3630NxYvcSzf2dJbmyWAIZk+0QxOjzKqNI0P7s+Wq7TuxjQTqOK+C1/n3Lc/dutzijdW1+fN QICoyDGRucjqSOO/eul0S4jhcJcTEyIhwHTcSR82OPXJHtmudxXwtaljrnwbomulHMHk3O4MwilK iQk7fmUfKeep4bnr2ra0b4e6gkzRwFJdo2qFYqVBPGAec/TP41pRqNzjCo/K5Li7No8W8ba/eaXq F0pk/fJKyAIcHMZ2DHtnoe9ei/syag2o/GDw+lxGscC27nK53Kcr3HJ4ycduK666aoyJjL30kf0n fDy3ktfD8dnJMZEUdHX+HHQ+o7fjX46/G/8AastvCGueKPCei+J7LUdEV5LeK18P28NvZOylQCwt VhhkR1QR5ZrkIDna+0KcMZkfEudfV6fD83CKdqk0+XlT0Tvf/Fsm9fmerl8aEpVJ1oXsfHPjfx9a 2vho3h1ATanefZrk2vlQR2ttbuguvJBUNPIRLIiMI3t4S0EgZFYA18h6tfXt9ofiDxRqFvvDhbO2 nZ0BedJYWZgAQzbY2xuwF+faPukD3MTkuE4YwEMnw0+erNqVVvV7q19+VvR27b761UlOrTnmFWLU GnCn2b1u13SV1fa/oeZeA5p7r4o+EI5ASz6rbbRux85ddpPrg4JHfGOM1+kv+iWsMq6mR9rYCRso y7T820Bh0PAPr9K+dx0OacdNkeVRbV2cgbtHujBp18pu8ZBbggdeucnkqfpW74R+M3xl+Gt+8vw9 +I2raFPJIr3D6PqVxaNKQQf3nlMBLxzgkggAH0rOjOpQblFv06f8E1c2fYXhf/grx+2n8M9P1CbU PE2meJRuiEcHiLSImeBRw2ySzaCRiQDlpHkyQPx+0vhp/wAHA3g263W3xe/Z+1TT1VV/0jw7qcV7 5r8bv9HuUt/LXgkYlc9vevSo4mlWgvaLlfdbfd0/rQpR5lzH6MfC7/gqv+wn8WJEtdK+O1hpOpmI SG18R29xpXlgjlTPcotuWGeQkrdDjPWvvXw74m8P+KdOtta8Ma/Zajo06h4byyu454JAwyGWSNmU g+x78VtOnKC5t13Wq/4HzIemxvOgbhUGTx/+qs+azVtzgfLjnjjFc7QRe6ZzuoaHa3SOktsrg56g H8a4/UPD1u0bRfZY2iI+60YAAz9PauedKMkNPU+Mvjp+w/8As6fG+6fUviB8K9Nm8TbjINatIRa3 3mBBGjPcQ7XnVFAKxzGSMEA7DX4r/tGf8EYvGU1xqXiL4J/Fc6jGiMYND8TIsEmxUB2x3dtH5U0j vkKHhgRcjMhxmsot0p3mrx/FegOLatHTufjD8Zf2bPjh8BdQaw+LPw21PRgZvJhupYRLZXEgQOVh u4i1vMQCCQkjY6HmvC7rMSh35AxgjtxxXWmpxUou6Zg7owtKtNWv9SmvtKfDwjaD5gQtkHjng5GQ Qe1fZGmaLqsnhLw5p9/JFFqLwfaLmWXagcEhmUhBt+84+bucnnJrizGVJpRavKOv+Xk9Wa4dS5tO pqt4IkupCmmyxRhSY2Sa4DkEbhkGNMAEDdtIyM4OetH/AArjWP8An6tP+/k3/wARXiPEQ+1e/p/m dsqL6W+9I/or0vxJ4a8daVZ3/wAbfjdMtvcql1YpC17dW1vcCRd0NxA0Y+YhfvxuDj5w8jZSl1vw v4Q8carp3hX4K+A5bjxHeX08l3dCG6uba0tZBbKksEhVbtUiIcYmQ/fZtmWVV/b6scNh6D9vVvOd 1ZPS105WS0XLbd73O+VLH4h+wwFFYfC0bSu7KT0spN73lumtLM/Xb4WeENV8H+CvC3ww0TwlJa6D pq/6XqGpNaRPqLgM3nRw2rzbmaTZ8srRELjltuD8/ft4/ECT4afsu/tD+J7oFvtfhVtFaQAkQfb5 ls2b04illcf7p9K8PGYn2uFxFTq1L8dF+h87iYxU37/NfdrZX/Fn8hGg3Oh+N/tGp6MmLyzm8uO7 jyQr8HGOhG1wO/U5BqsPh/8AELXPFU6Xn2ez8G+Yn+nTpkyQKqmQwIGDTOGymOF3ldzICSvnQvQo U3O/vJJ/JHG/eqNLpr95jP4bj0z4rX3ieylWLRIoIbWzDSI7yH7PHEzOVAB6HJ+XLE4AwQOH+Jng fSNNtx4l8NRRxwPMVurRVVVi3cBo16KpJPyj7pIwQCADEYZww1OrbXr6P/gl7xPIbHUv7K1i21G2 zsgmWTGcZHBK9c4IyM5PB75r61tGnuHbUtFO1pgHCy/NDN0AIIwVOAPmHbsT08HHJqMZv+tjqw8k r3LEmtS2jeX4hsns40wfMA3wgjP/AC0A4AwThgM9ap6h4h8NQFJZ9USXd0EeX3DqPuAjn/PeuKMZ Oypm0kkuZPQ4HWfidbKk/wDZGnMzEhQ83BY5GcIM+/JIrkv+Ej8ca8ksNss8UZbAjgAQEkYwGyC3 Xpn8K64UYxjzVHdo53UbdomengrV5TLc3moZYAM5A3EDgAEtx6DPrWpF4M0f5Zp1kmnZMoW6KxIy Dg/MOvYZrR1v5ERbucd498FNJFG+m2qyXIXa2xCpiXLfKw45HcDIGa8dPhHxMjlRYMQvBKk8+9dF GpHls2Q1qVxofiFWLf2bIVIzxjgGoGstWhz5ljMMf7JNbXj3FsQi8urct5iuuOPmUjjj6e1Wo9Yc sEU59KdkO/Y6Cz1e3kK4l8t1bdnJx+ld5beL9djiEMeos9rtzzySPdh830zWcoJ/FqUmbvhexuPF N/LFFex/a1G7bdSNuYdyNoJb8h7kV9B+Hvg3oszRTatfTXDsx+RQIY/U9Du49d3ODxXBia7ovkgt TSFHnV2e/wCl+GvD2gwpBpdlbW8QCqXWNVMo4HzMfmY5zyfT1rG8dpnwhr4gC/LA0qkcnCAtnoe4 /U9MV5jk5Xc3qdkY8tj2/wACePdS8LeILDTriEN4dmeKytZo8iNXAZVikJ4BypKknPzKQCpbZ9KX /irTYY4tVnvFSzZDKzOwxAFALBm6YGevcA+hx7mHvFqkndP8+v8AmTUvVk5xWt3+eh5f4o+Lvg8W Ok6jBrMb2YZmhe3JcXK8k7fLyzZ8psYH8J/D4W+NWtzfFa/0OGzt5WZZfs0E10APM8wKEwqszN90 j7ileFbkgDo+octZYypLrZLvdWMalSShKhbVb+VmeMfBeYeFvi5p1tqksUccl62nXG6BJDE8mY4X jLAFP3xRCykHaxJyBiv0wltZbZC7LviPIkAyCM8H1P0IputThWVGWjkrr/IijFuk5Loc7rmn6Pqt hNYa9ZwzafIu0xXAUqc5+7kjnBODkHng18I/Fv4HQ+B9W0DxJ4Sjkl0ee4cT2+Mm2AAJbJGNpB+o x+JKkYwftr2Wz8+n4MJpSTtufMN/Deadq0sdxC6Ix3oJF2+YhOVYZwGUjHIqYCOZsooLghSAMn/6 9Umnqjns1uSiPB8zcTHn+HggA5A7+vf9a1VkJiSRsBQMSZbHOSfb2HfkGh6AacUsdwB5mN3IwDnv 0xnpzj8O9amlancaYwTar2zEFopSeR1BUqcqRnPHXjIIqWrqzC7TOzttSstXjXyW23fKmGQfPJzj 5DwH7dMHnhachdAGZyoY7PLLKCpx6YzwTgZArGfus1TNNdSYo8knDJtQAgg46gDP6fhTf7W+03EB NqXnCn55MlhnaT79hyPTFZu+40astzD5zSQzFGA48sds4yOuOvv1/PsdN1lWkUsilcAjPAXsAPoQ T+FYTjdWNE9dz0bTryS7dYi2UbA3sCDgE9cc4GOn1/H3TwlcQzzWsUrtsc7AvLE9hxgnqMYGMDd6 V59f3Yu25vBu56nrvwU+D3xCsd3iO1Ju42CG9gha3uouNuI5OACqqMCYSLljiM7efF/AH7PN38Nv jTofiHSvEsd/4QllNrDDcZE8PmFgqPtASUbBhnATJJxGBg1nhcZXV8PU1i+vVP17FVaMLqpB6o/V b4y+OX8Ffsx/ErxLHLNFdDRTYpJCxWaKW6dLMOjA5V0acMCOhQdq/n10zXPh7baba3mmTalqGqxx XV5qGnaBZv8Aa7C2gMnmTTX7xz+XGqBZHkjgREV9rHOSv6PlefPKMsnhsOrVqjb59+WKUUuVbOTd 7N6R1e+3oYbLJVsA8dXqxjQ9pyOLektLuUktZRjePur4nK0nbR2vFPwd8Rf8JX4c1bx3oKeHvDfi PVEtrTQV1KabVhJM9ibeyk3+YbR5I7+Kb9/IZI4IpSw8zykk4j9pvwp4S0HRvD178M/GMd/4F1C6 mtbGwhYTR6QlmzP5YuDI0j7nvXlKPyGdmy3mZHh1KU5qriqsm5TfNeWrabum3vd2/XqcuY5rPMpU oRjalSgoxSVlp1str9F0R5T+z/pENt8TdI8Qfbf+JrZAXcCkLiNwypu+bhmwxIGODz2Ffq34s8Wf COXRbMeIPCNhfeJ5oSyx6eyW0yscgPM0O3knPLb8jOFI5rxa0XWxCtpZavyOOnyxi3I+VF8JR2d+ txBaXHKNsbLOpYjgbly3Axksqg46nvzVjGbu/a0kCmEL58kisNu0jGfXsOnT9ayle0pAmzlPHcVn p3hpDFcP9od1OxjlY4xnao9e2SSec8143kSRBZBlcZK7ePb/AD71EbtXfc66TXs0kYun2aXFyiW8 R88gkbM8/gOK7Twh47+IPw+1gaz4K8U6romtbNhvNJ1CeyuAM8DfCyOOR0yO9ehSqzg3yyOKo+WS 5T75+G3/AAV9/bv+FzRo/wAW/wDhJdMhh+zC08W6bb3+Uzwz3WEu3cAAbjMT1yTk1+h3wp/4OD5Y WsbL45fs+B4fKP2nUfC+qhWaQDAKWlypAUkj5TcZHPJ6Do5qVRe8uV91t93+VvQamno9z9J/hN/w WC/YG+K/9n22ofFybwlrE0PmtbeLNJntUjfgFDc24mt/cM0igj0PFffXhHxb4G+KOmWet/C7x5on iTTLiIzxT6DqlrfgoM5J+zu233DAH1HFYypVIRc2rx7rVfPt8zRK/wAJJf6c8O5J4CHH8JGOe3Xv 0rkr3SLaX5Qg28DAHPcf5/KsmlJE3d7s878SeB9J1nTb7TNT0+OfT7mNre4tbhFkiuIXGGR1OVdW GQVIIPOa/K/9oP8A4JJ/sx/FkahqHh7w9N4R8Ry7pBc+H3WK3aQxhED2TBoBGCA2yBYCxJy+TmsL Toy5qfXp0ZTSmr9T8a/ix/wSD/aU+D2qnVfh5qdt4s8FiffMdMf7JqK26bS7vZTMVdmywWOCWdzt PA4z4N4hNrpOr6p4U8Wx3mi67asiSadqdtLZz223LASJcRoVY7hxgHgHA4rnxidaftKUHt73darp 123Q6CcfdnI8ZvPDmstdz6kNAe8+1O0yz2sokKSbgww0RJ2nAB7dwRUf9l+Kv+hPuv8Av5eUqeJw 3L71RfPdeWp0To1b6Jn9u/hr9hn4J6Bprz+IoL29XznZrSSTybbeWyNiL+8VQTx+9bryTXQfD2Xw Z4S8X6jpvwz8OWbWmYrZZIp28pzlkO6WNZpnO4PlipRcHc6Yr9KhQi5tyfdt9r7/ADf/AAScZnWK xlKOGfu0koqy3aj8PM+tr+S8j7p0Rprl4A8Qac8BAOnp/LpXyl+3t4R0vxP+z18avh9qK28r3fgr VtReGTgtJFBJ5TYznapDEnsSK8utSk8PV5XpZ2+7/M8ms1yWP5GvAfw20T4caVqI1GS0lMk7TMls s0cERb5By7Bn+XyyDtj5yCpzXH+LPGV3qF9cyaankljueTiOSQDAUgLwgAUADqFGMLtxXRgcHOqo e2b5Yb+b7f5maknqjyG+fa5uQCW5LH/np7+5HYn+tclrupRX9jdRSSfu3jKKVYehwRj6ds449K9D HwjKjKNugJ2Vj5uPGVK4OccHIH15z2/+vXsmg/EXxHD4esNN06GNRbqLYSiIu7kEkcHjhWAwFzx1 7V8XXpKrHley1NYT5NUQO/jDWZCdcnuNhG4LMxVc84wnQdfT6YxUUHhvThcTGbUWEh+aRY8Bc9fn 6gnjvj9a524xXLT2LUpKXM2aS+F7j5ZdNMdzAPmAxtYL7Nnbnn/Z/wAOj06WBYHZZsyxko6SqY5I ScAK4bIAPODkj0NZOblvuVbqht5cpZOqPtZiCSAyqQDjH19K3bO4tZYYIJ2f7VIuUjAAG0k9WHzc 46cDvz0pOLtdCXLdplqaXSLXzfNTYxU+WhXccnPXvkAdduPbuKEaWVwkk0cYWPdsbgA/LnPXjv6+ lSlLV7ho+hz99feGtPikaS4WRlXDhUyAc5I+Unk4HPv+NcvDrFlcCRrCzC7Fz5kwA+bOAeDgHjGS fQ1vCM2uaWxLa2Rxz6dq+uzGOG2M6Kdzx20TNtB4/hBxn3NXJfgvq9wiyXGnR26bcnMimRs46Bcj 8yK0liKdKyv8gUJS2Rg618Ir3T491nPI0g52yJjPpjvXASw6votysd3E8cqnKhujD2J4IxWtKtGo r9ROMovU6/SZjceTf2MjR3sbBlMZKskg6MD6V93fBTxxaeKtLnt75tviCzIS5UKCHB+7IuP4TzwO jA9sZ5MdTUqXOt4/kb0XaXL3Pbw6SWzyfKse7aXLLlcAevbGP8iuc8T6Td6hoWsWCsSLizlVcAqp DI3HX/PWvF50kmdKTsrG58PrmeTQPCurXU4ljmSzMu4BlRnSJ8tu4X5mypz2zkMcN6V4ss7B9G1e C6lkjs5l8+QxvGNjblYsN/AxjcQCOcn7zHPu4e7xEIRfxXT9bC5/Zt1EruLX5nzb4qtIL7SLieN5 Hvre3zHdSXJYXCKz7uFVIt5DsmE3/Ke/GfFdN8a6poOpaZez30kiW12l2hzmSI5Odu4EdM4BHXFd +IhKOOw8ZO6ivyvsjF1XOnXq2s5P8/8AI5bw3pereL/Hgv8AwxbR/bTd/aIEluI4Y1cO0qBpHIVA W2gE9TgDJIFfrpqnhm80gMbJxJY5yEGMEc9fQ4AHHGT0A5rwM7rRjiKXI/eV/wBLHVl0ZKnPmWkm ji7rwfpupSbrULbaiSGYSxeb5gGD8u4kcdMgcYPGa4P4i6LdL4c1FLqAZjsrgZYfKSUHQjjdx/LP HNbwzJYvCShU+NW+dmia2GdKo7LR3Pzz13xr4WvLvQPB9zoTaqj28Fq5BaK4trjhf3ThSCijbldv LA8kVh+M/hXqfhUSX2nzG50dMsxZAssILYG5c/MANozhTntjmrot4GsqVSV4zu/8Lvt6P8GYVpRx EFKMbSjpp1Xp3R5xayFIxEz5Y8tk4/n1+h9K1reUl1jkAKY+UE9ew4/H1r1dzitZmgclFgWMBc5U hhx26Dn+XcdKehOSGXehUrkAgA8cY/z/AFpeg7sskxuBI4IUDIPTbgbhk9T2zx6VtWeqTW8MH9oB rmDALgPh0HT5GwdpGMYIIxnjmk1fQa0N61trbUBnTNWWbOGNtKhWZCeoAzhwOfuHOBkgZxVuBmfe DMdn8AHTgc4P4d/6VhJNOzLvcuQqyFCd3nfKSj5G4/UZ56j8c9K6e1Epd2RNzO52rtJIxzgnOD39 B1rGSbZaOw0y+mieByGZ0ALY4UYGQDknHYdM/wAq9f0HxAYbiCJiY5FZBGQBtUkDPDDg4J6AcE89 K5asE9TaDs0e9aPr8siwpBfFolBGFDE7SCTgg4GRx6YPvXY2WuSajqPh+AqUaO6RnIU8n5h949OB 7/TqR50afLWi2b3unqdX/wAFBfEl3/woLwh8PtBhvJ/EvijXILa10/TbaSe51JTGwEcKICzyNcT2 gUAFixAA5qn/AGLpvwSt0+IPiD4faD4S8G2/gTwnp3ifTYdFMdtqN1c3ry6xYxBhJJOIrTzbaPex 3ve4uJn2GSP7DBxhOp70b2ireWt230WnX7jpx1LnwGW4eld1J+0dunvTUV83yO/oj48+NPxj8V+J rn4gWHwx0SGLwRqF1qepW+v+IontNQuJbrUDqEU1uBMCERfscNvvR8rY28qrHKirF8sfG/SrHTNB sNa0DwsdC0GbU4NNjsLpYGIgs7WWO7lbycozSSqSzDLSNEsjFmcseSpnOCzLF1cPhZc3I90naXe1 +if3XVzmxWEpYSjBRnzTa97yemi7pa69emmp8fadHe+I9SvT4csjEbc+bAqyhXABABBLctkrwp6n ivStJ+KXxF8OXMNtqN4ZTGADb6nAxYf7Qc4kU++4fjmplCnO8HuvvPPU5LVH0R4T+P8A4cu4lt/F FtdWDMQomH+kW6n/AH0G8ZyP4T0xmveYvCfh/wAW6Q2t+FL0Xdpt3T3tm63JiYhSQ5XcAQOob3Bx Xn1oujZy2fXp8+xvFqasvuPCfixpD6J4RtXub6C4lkv8rJGNrqNrH5ux+o4/LNfOvnFVByQ2CMk9 yKiKbWqtqdVOyiXPCpjF8skwbAibGOoO1sZ9s4zXatZ/a44XXaUyQUCn5iO/X8v5Vq3ZtnJUS5rn N3mhQqJ2YuU3D3z7cjFY95bWwd4Y4iONw244x6+n/wCqtYu+5k7nP6jaWslpOphKsFb584J+vT8f rTfh9B8RtL1e31/wP4hv9KvIidmo2N1LbTR54PlvGQ3twQK1jWeHTkpf12LgnK1j9Pvhl/wVZ/bl +CKaXYW3x21DxDpthEbdLPxdDba3AqntuvUkkXknGx1I6AjpX3t8Iv8Agv8AalqMmnaV8b/2d9Ju 4beJlu9X8J6pcadPO5J2yGC6+0xHb3CeUD7daiMoVk5Tjyy7rb5rb7rHROcUkpI+7vh7/wAFaf2K /iOdPt77xrqPhnWZwRJb+ItLkWKFuuBdWpmiIPZ22fSvrzwx8Uvht8RNIGt+BfHukazpjsdkumah Bcgbex8tjg/WqlSnHXdd1t/miFJfZdzwz4i+ONVlv7zTrcqljkouBliOOp/p+NfJHxO+GfgX4paP NofxA8O22p2G1xH9pjBe23bSzRSffhJ2pkoVJAxkinKlHRx6ETnJ6PY/nN+P/wADbz4H/FjXfDnh 3WryG1Q/aNOnDfM9q+SobbxlRlWI2glCcLkCvIvt/jr/AKHe9/77f/4uuevSoOd6lNN/15DVatBW jJ2+Z/djq81ve6Jc6p4l1qM2jTNHbLdT3d6ZsBlGyG5SOAliV2lbdsjOC2QRc+AxvdR1S/h0CONd OM4kkm8lnkvSVwAXG1EKEYKAMRjHyngfpNf33ONrRXorvTov+C33POpb3buz6o+IHxM0X4Q6C017 dJJ4j2YVAQdnGAf5V+VOv/tCXHjzxxqfw+1izN5YeIbG8t728eQtLa2ixCJ4wGA+RjcAkbl5jUDG eeCpSi6aoXtzXV/k/wAP0McbiOSlKqtlb8Wkz+dP4lQXHw/8YeMPB91ftdXOm6hcWH2qQyZm8mRo 9w3/ADLkJ0znAHUAV89an4hnFxLOzkSAnaAAQc+3fjH5169FKNGNRqzkky4VFOCmuqucPf8Aii5l TymfcwXGFOAM8E/5HpXI3erGaVVaQctvxu79/wBc/rXmYyScZI0T1ubfi74SeOPDHhvQPGPieXT7 fQ7+3S404Pq9k88kMrGVWW2WQz4w2W+QhdwLEbhWB4IuYLTVZE3rMZI/3YRHfa/QkDbx8pb5uD7j Jr432qqQqezbVm4vps7P/h9jZwaaUj1NPE+hXdpcQRajC00iuCzLgoGGCRjbyVzw2QOw71V0yFba MxWeqRujo3nbWVyqsR93rtY46jkZPrXJySgmnHQvfUXxF8SNM8PQrbxPFJcRKIxHDFEijGSN7hc7 s5z1fnmvmPxF4z1XxFqEkp+Yt8qIg+VR/sr1PU8kk/TFbYeil77CUmz6Y8EafpNx8P8ARrjxMiHU wGJuTOQfLJ/dqTkg4BGeOwGQet/+3vD2lSTPY72bZsOwMQQB6nJ6+npXO4ylOUY/DcLcpxdz4g/t OaS4+yiC3KYcl2ZsZ7nGB2OMdcHsa2bHwP448ViNNH02+msZPmUyfuYfqskhRM/T8eBWknCjG83o hJSk7RR6R4f+A2uapY297rGsx20DKvmQRW5klRiBlJC2BG46Hhh05PWvVNH+DHhLR8P9kN6ynduv P3oOeSNgxGOf9n0rz62Nk7xo6La/9bG8KDXvTO9i8P29pbwxRWoSFTs8uNdioBkkBRjHOewqlc6P azTFVt12EkruKjI9/fBJP+c+e5S5m7nUopWS/wAjOn8FRXuJ/sp2D5WAOQO+P/1e1eYeNfhJot/p 8pe0zJs3GBCMjvleMqeP89K6MPXnGaaexnVpxauj4zOl3XhzXbzTHfdApzGTxuU9D09AR+ddx8Kv ENzpPxX0VIJQsF1FJaSFhwVZdyj8GRK96aVWjJ91+hxxfLJM/TbTvD0N1CL77QoiKh3BOMHGev1U 5/p0rsLK2sbXNtLEjxt8u4knbx09j19K+SnzttM9WKSXmeE/CbUdRTQtHltpN4htI4ZogGw6R4Rh 9QVJHXo3rg+v6xdxavBEI7oLavDMhk6bH/d44HPqRzz24Ir6fDShCvTqydkt/u3ZyTUmpRjHX/gn mWof8I/oNtex+a7XMqSRCady5jD9QDjcR0AB6DjNfK+u6N9llLQ2bXFqODIiEheOMjtwOvNTj8fH EYiE6bslpfb+ka0sLKEGpK990ZusQ/2PqkM+kRiBwiMPKULklQc47cV9LfC79pnX/DQg0nxNEt3o wCod/wB+MDC4B5OBxxggAYAGSa4MZSjWlNS1d2b4aShCMXsz7Y03xF4A+IGlfa9A1dBIyB5IwcPG OMMVByvBC5BIGeDXyr+1Xquo+GvCGiadpGuPDPLegxIHVPNjVSzs2B86Alfl+7lxnpXn4GnUjjqd OSvrr+Zti5JYed+2h8Zfs0eDIvG3jnWNc1bVll17SIhNDp8hO653koXU/dAjJXjIG6RMV9L/ABJ1 H/imNe0iTTZbeU20qbZkRcggg7Vxk9eD3H1r1Mc3UxijLZWt+Z5lGNqPN3PEfFnw/svEYfVoYCmo zIJfOjBy5Pd1P3vw+Yn6YrwPVdD1jw6zLf2xFv8AdEqg7GJHAB7d+uPXFdeDxPNfD1HqtvMxq038 cUTpcowQbfmwAVOTx3OM9Pf8andSzwNGRkseVyAc84+ue3rXo+hz6g8Ujsihv3Y68ndyf1/GrcEs mGyNobJB2gjP046ZPvnrijyAC7R4B4bGPT3yMdeoHHbnvXXWPiGVvk1sm4fdzPkGVTgjJJB3Dn+L J4wCvWk4qSswu0dHa2sD+bc6c/nRKQMHh1BG4ZjyWA65I3KOOehPQ2OorI6mX5FUDr8u4nI644x0 98HuK55RtdPc2UlujsIbi3+RIjIJVYM6SYO3Pc4GehzjsMc8E12dhJJBFELgByF3ALu+XsBjAyf/ AK31rmnHf9DRO9j6D8G674G1DTBb+NNR1Wx1f5mW9t7aO/EucBVdHliZCp3Zk3yZ3KBGCuWmm8Ua J4c1OC6OtQz6fBPGftIeULNuKgbRKoYYLKpyAByeRzXNGnUlUu7P+u363N00obmb+2NP4m+OR+E/ g3wv4Ov9SNpp1zMzWNnJKwkupiqplQwG1LNWBJ6s3pzl2Ph/9ozxV4v8W6v8Zw1pKb6w8T3sGpWV pAbu8WKSytJz5MWWS3gtHVYdyqJBDKwLAs155i8VluS4vGNNUJRjG90pNT/d+4m/7+6Ts0ux9TiK /Ds8swOGhVc8fCFuWN3GF5ObU2lZOzejd9dtjlYdG1JtYsL5YZLy1DCX7ZfxW8fSQyMItm9EO1Mm HJePCEyZLbeP/aE+Ftz8TPDGj6DomqrBe2bXMjOd0tvLJIySOmcKwTceHCg43ZU8Y8vJ6eFhWnic Dd0qcVT68rndylyt720u7av8Pl6rqOk41Pibb/yv/kfn5P8ABvxr4IvhD4g0y4jsS22DU7UO0Bkz 8pD/AClcqpwr7Wxziu8tZPEiWP2TUPsWt6anJhuUAmUf7L4BLdBkBuvWvpE6daPMn81ujh1i9THb R/CN9L/xLdXuNB1cnYbe7G+HfgjaX6qSc8se44rOs7vxr4J1pNa8N6w2maxBIQuq6Ldy20jIRg7T Ey8e4Az0oV3eNSN/Po/UesXeJ3njXWbe8+H3hOyi1dbmZChdfMO+IpGV+dDyCevpz7mvKTcyebs3 ZVec9Dkg4x6dq40nbVa6nbCXuoT/AISMeGLVdRaIMCwiwfcE4+vFVtL+J2patef2eqTJbuCu6HAE ZPRznpjPPqOK6aVKMoubOerK0rHaadrUf9pPpWpap5lvhWWY7d7cZ3Me+c8jnGMZ4Nd23hozGaUS ZlfOSq9OeeOn4VlUvCWiI3Kn/CNaXbLLJqbhrZT/AKtjgMOTyBkn2Az0rntc8Tx28D2tmPJsxkKq HDP24HYEcVz8zrT02R0xSpwvfU8un1C41OV41ACAHagPocH6mr1tapboTD95SPmyBgnnGfxP511x XKrHPKTk9S8iSEuu9dwHPzDnp6f54rZ0bxJ4k8OX0WreGtVntNVhbfBcW07xPGw7h0IYcjqKtTcX dMhXPrHwJ+3V+0h4NtLG3uvHU+oWMOcWutLHfbu2DNIPOI7jEgA9B0r6k8Ff8FOJXMFn8Qfh7C8h fEtxpN4YQF6/LDMH3c56yjt6GrVRS0a+ZV76Hyd8evipB8a/iPqnjC1s5otHeKG1sUmZfMhjRTlX KsVyXZ269GFeM/2P/nzf/s65MRUUqraen+SsDfkf2v8AjDwzAl7JdXd8jXUzxs8dqvlCRvvHdIS0 zruJwhk2bSBtPf0i2+JPhT4HeBGupmiPi+4QC1tE5MEZXKMR/CSCMfX8/wBCVT21S72X9f10OOKV ODfU+H9X8Ra98YPENzqniDUXTRxJvlfd1XqEXPaub8A+FNM8R+PDdaFiSeKSTSbKOBlLNI6pNIsn Uquzy5GYglUG7acgHlxDaqU3Fa3/AOAcGOpyxGHdKn9px+66P57/ANtGAeBv2mPjv4SZWjitfFWo C2LnnyZJ3lhJPGSY3Qk8k8nmvivUtZ3OyxszEHjtn/D/AOt+Neg8Rz0abf8ALH8jail7OGmlkcs9 yGBCkmQjBOTz3z0rovBvh3U/GXirQvC+mjN5dzx26sQdsQb5mdsDO1FyzEDgKa8bG1406M60toq/ yWv6HXTjzzjBdWdP+0n8ULjUfjB4i0zSrYr4d0GK38M6dbXixXDQW9hElsV3leQ0iSPkbT+8/CvH NZlm0/8A4R7WNN1C0hk1DT2uJrS3Zw1kxmmhKSBujOsSzKFyNk0fqa+aoXeHpcy1klf5q7/E3m71 JNdznPMmUKIr+TcP4dikE/UNmq6axqtu24MWI7jNb6PcjUnfX7qdF+3wCSMngyLuH4Zqey1DSIZE lWzCyZ6Y+vrn/Ipcumg7o9E03UtLvkSwluPLT+CV3wIsnJUkAnafXGVyeoPH1t4N+A1tqFlZXmpe JzNpzopH9mBdjAnnErht3/fCmvNxVaWHjblvfZ9DphR9slNPbR/15/me4eGfh74D0zyptA0S182J 9vnuTNIrKB915CzKc84HHB6cAeq2GjXGpg36yyK4O1oiAcHIJ6DnrgnvyM4rxatacpqU3d/1sdlO KhGyRb1HSpbd5NVtLbeQNt9bBQxmUAfNx1cDp6gEdcVmTaWjNBcW8ivayjfEUK4kB4wD3IA/+tWc WrK/p/l+H5FNNEd1o0k8CssIIJAAX+I9cnP17AVlS2MUaMmxZCWADgEhOBng/wBM80k+bRf5DtHR 2J3iuFjaOOIIqDgr0X647/X2+lcn4l/s7RtPudb1u7WCxT5nkmO1QAe/qTnAA69utXDm57R3ZEoX V9j81PGWu2/iDxJqmrWULQ2DErCrHBEa5wTj1yTjtnHbNRfC+1l1f4maJPAgIgdpZSfuhcFR+pFf TpcmHtJ7L9Dzd5qx+tXh+1YW4TYfkAyoz02kjtx2PTsPWuhlm+zzQ27TpHLLuSJGX5nAAyAe/Bzj 68cV8pOzk7HsU4tpRZ5RoHgfW/BkGlrOYijPdASeYSpDXEsio2Puna8eAcYJB4ABrQ8TytL4c8SB GePUYrKWVJEC5j2RFs5+9nMRycdMjkZr3MPOFemnb7P5HNUUqbfdM+Zba9e58i3u7kJfZ4V2BE2O DtY4wT/d464Ga3Fxcn7NcgrIcAEjG3HYgkYH6cV5smr2+49CHwtrcht/CHh/xPrJTU9b/s9pAkP2 tlLwQYKjLqB82RuAIKAZBLADB1/HnwL8Q+EkOpWyC/8AD5QNFqFsC6FG+6WxnZkEdyvPDHNVi8S6 OKcJx91vfz7f8EyoUlLDxkjx+z1XXPDeoW97pl9Jb3CHgo7goevYjB/l9a6L4s/EXUviV4O03TtZ slOs2KzBbqLA8yORRuDKOAchcFccDoetdmEtKvSl1V/yZhiHahUhI4T9nCObw98b/hnY2N4bf+2b Bo7gStxcebHI8aEZAIaRIcAnqF69K/ULxJ4YsNbhuND8T6OmxwYmkLNtYkfwuvzIfY4PQ4rHNJ8m Lhd7r9WPAwjUw8oef6Hk+qfCd9Gjji0mT7TFDEuFO03AQfLuI7g4PIA6dK871LwzBqEVxDf2Scrt dNi5btypAyO/+SK5VUc9U9V+ZE6bg3FrQ+c/Gnwil0+UXOj5D8yfZi5IJHUI5OQT/dbjnr2rxueO 6tLt4JUaKRQEkjPy7SQeQD16A/r6V7+DxX1iPLP41v5+Z59SHJK62JrNpAred8+QVIJxjByPu+p7 9Ku7oi8YAwM547+nHXsB+VdvQxuPuCshTDmNT8pHU/iDyP0qs7TxBizgRYY/d5yfYfU4+vvwAaIu 2mbdFcAPlWXBwfc7v/1dK09J8XX1v5dvqcTXVuqkpJlhIoOMZByG6/U889qJLmVhptHrWhasmq+Z NprB7fnOwkuASAflJ3DqBkjtweK9T06/tkiWdllMoB2kYbnnHyk8E8YPsDjrXHOnaVjZO6udXGj/ AGX7WZ4hbtGWBWRFdkLYHy4DDBboOcEnGBXCeP0a70Se0t3LROy7sgDcoPfoAMdj7dM0oU1zRsU5 aH2Z+yr+0x4H0DQrTQvitqk+m+I7BGt4NaRJHg1OH5dqyeWrNHKMgEsNjYLFgTivo34heM/g5488 Lz3cHxu0w+ehj8maeGOa6hJw4VCfNI4KqVGBukIG48duKyZZ3l0sFN3jJxur7cslL9CKVZ0pc8Vr /SPjrxh8XPg7pcaLo095qUoYo8Wk6WYssF/iklEauvK8AtnA61y9hc3PitZtalhS28PW0ayGKAyT fZAzAAzybV+c4X7pIOVVSTVYnC4bCUI4XC2utEo7L9NfIlTnJtze39b7s838V/FXwtYJF4etIrpr wyFJbzYshMHCuI4ZPk3cNndjOO2S1fC+r6RqdlqF5dWDyy6U7s1rIEMb+XnKF0Uny2IxkAsAe561 goQoRUZvV7le9O7WtjK0yyXVdd8nW7p47VJVeUpg8HkjBI3EE8c84+leqXFn8Pb6WOwg1qeCZ2AS V0LwxLg53hct1wMjPQnHOK1jFNPWxNzy/wAUW9hbNCthqK3CYyWTnbwDgn3z+hHauejO2ZUZvlAG Se+ev+fSuOrHlm0dVJ3ijE8ZKz6Raoqu3+kAkICSflb8utY9jLdEQxW8JjUbRICV3MAO+OT2z9K1 o/w0ZVEue56FongzVfEU9vdW0ghtAcea+4dOy+p/TPpXtf2uz8LWMVok73N3GmCz8kf7x7cYGPau TE1VNqnHpuzWjTtepNadDyrX/FctzNIvm+bNgjjO1PoPyrzK+1KSaVnU73JwWY9PpxV0ocquyak2 zp/Cior3zOfnePaN3bPuenSt10G6RIoz3fAOdme/8qrW7uYstGyKRFnVVbgj5T0PXr/P3qJItrbc YjyAW44/DrSv9wW0Ca2+RlMoycZG1gR0xn0qAxiDDxxjJxnc3HXt0/WncXU0LXV2hVJLgnaDlVB5 T/Pp/jV7/hKIP+mn61DpJibS0sf3R2e3Wtbu7+9Ktplipmn3Zw23oD35OB7V8ZfFbxb4L8K2OseP vH+t29jpCyuzyXD43feYLGg+aRyoOI1VmO04BxX3NPn9rCnFXctLeZzVGuVuT2R+XPxm/wCCjU0u n3fgr4KeGvKtZB5J1O/j+ZR8ylooBnORsZXkPqDHX60f8Eu/ByaV+zNpXxN1mJZPGvibULu6udTv C7XcyCdrVF812bIxCpUALuJAJI2sPalhIUcJUlNXk3FX+92X9amFOp7SUmtrfqfg9/wWBsE8M/ts fEC4u7UxQazYaVqluSvEqfYobZ2Hf/W20vYc/nX5Tm5s5WXMjFSTwFP+NfPqrSjTjG+q0Lpr3EfS Hgf9nbXPEXhoeM/EmqLo2gmOSWLzreSa4dVxiQxKV2o2flJJc4yEIZS1T4GfEbwl8N9Z8VeItc8G XGqeI0gmTT7mK5ijt7eXawIbHBDvtDOrghMqoIevn81qvG0K2DpS5U9G979/w0+Z20W6VSNSS2/p HzTd+GH1p5NXPiG0e8nug92JZ2WVfMOXkO5fmCkksQSec4IyR0Hx4g8NWeu+G7Tw1dQyrBottDcz QyCVZXUuEIcEhiIxGueBhRxXnznVWMw9KEXyWlftolYuKTo1JS3uv1PEoGmZgEJBPGcniumg0jXW TfDCZQcfKjZOT7d812yaWsjG3Y+jPhdq/hLQLG20nxh4dikuHLy3CXdsjbiTtX7wJ4UDH1OOprf+ Jvhn4IN4cOs2ANrrRLSvDZKsUcecFYwuSGzuHOBt9CORzuE/4lN7teli3yvysfIbzLaSK9o8hjPX eBkH0yD831469K+gvhB8TvEfhi7srK01vyNLnmSGZJl3wxhiF3suQcAnJKkHrTr0lWpOE1cuhVdK pzLbqu6P0c0zxBHZ3VvpvjKzGlXjMFSfBezmJII2zdAeQNr4I5Ga+iNGgs0t0W2kG3Jfdnd5vBAx jjGOep618jWUlovh/rT5HrtNq8dn/Vn5lx0tLeRp4plEoGGU9H5IyTj1zz6ke1chfWcekvcagm06 HMQ88QXP2Jv4pUH9w7SWHY5PQ4Gcbu0d76fPp+P5mctHckj0/wA+eG28yMwuu2KZcETdwMjgj5s8 dQepzWwvhJSrKI0Vhggcdev49v5UnJpXRV+55b8RfHngT4V2Il8WajnUJBm30y0Iaa4ODyEJ+QE5 G5iFHHU4B/MT4p/FjXPiLqbXGplbTSI2LWmmQyMY4ByAWLcyOBxu474ABr2crw0pP6zUX+H/ADOT FTS/dxfqeHXmovM3lQAkn5Rg9ee1fan7NPwi1aWY6pfQlJJdszMQDsQHgHJHUnP4Hrjj1MbUjSw8 m+py0YuVRH6IeHTpWrLd2a71vbWXypYmyjqAflYjrhx8yn098464RLHtHlbiP9njpg5POeBn/wDV XxtWpJNpf12Pep01ZORYk0+0v7aWDapYqFYZwSBkj6EHkHse9eCeI9Bv57rVdMV82k1u0cZKKq7m 8xXVu+drrxwOOMV3ZbWk5exjv0+ZniYxUeaW3Wx8Q+L7OfTGFhf2z29/DKV2OPvgZ+ZSOGBI6+4/ FNM8TTxqkOpxvNbABdx5dF4HB53DGOD+FdsoO3K90Y06ivzR2Z3XnW8c7P5ipmMMcnJOc8gdexHf p19PQvCXxT8QeC5Vg0m+jn0vd+9sLnc8E2T8xAzmNjk8rjJ5YOBWeNgp1akKiumdOFa9lDXodfq+ gfCz4uRO/hJk0Txow3tps5UW8rY58orxgDOCg4GMxrmvn3xB4F1PwvJqen+JLBreRbaR083GyYLj lD0dQAeVJ/SnlPPDGU8PVd92n3Vn+K6mWPS+rzklqeGfB/X9Y0jxFpPje3toxeaQi29g80KOhzu3 MVfIYgNgEdMjGDgj9QvBf7SvhPxdZjT/ABZarYa2V2bmO63n5zgMR8uSc4bI461vmlP6xVajuv6s Y4K8aaW19Tp7hNQRmvbRkNhyI4mdsA/7Lfw9emcH1rA1DS9N8Szs3mLZ6scGNZMgHGcjLHnHGDn8 eMnlw0YpqnPRvb/gnTWi5q8d1v8A5r/I8e1rS9TsTKl3YMxBKh4/mDAdTnqOp7np+FfMfiXQIdf8 W2NnJbuS0GAgLD5fnbqR68/zyK6aX7mXPF62Z5lSNvdaOF1/wHqugrI0a+baKd25ch48HjKg9Ofv D0yQOK5FHIBJkCSA5UZ65z+fpXt0K0a8FOPzOKcHGVuhOj4feq47DJzjp0P8P/1/rTGaV3YMd0a/ KdwOFxj0z2J9OnfpW3Uki/eq+bZm81lx83OMADg4HoPT1p6zvE8kcRbcvyZB6H/ZAx70wZraTeMs 4aK5NtLglHUlW4AwQQcjnnp/Lj0/wt8SrjRbmB9csElVZRIJBEjburZ8tgY2zxkEY4PBqZRUopMc W4s95svE+neJprnVodVspLuZ8vbQWsdusYIJwIogqQdB8qqAdwIArM8Z3kMWmLZC5ciQFfLDbVB4 wScjJHzDgr0J78ZxTVT3kac10ciNI+wQS3iW4nVIgzRx/wDLAblUF2QFdu5gB6lwCckCsU22qahD NFZWm7S2wkiSOsUeSPlZi5AAD/McsOh5B5roU+Vabkcpdh8W6dp9rqVpNaRXlzFCXVUjbytwyDuO Ru7cD/aOeK5DWPid4yu7WwU6q9vYwN5ttBbkxrFknBAUgZAJwx+bk8nNXG9OXP8Aa/Inm6Hmura7 f6rqAu7yaSW7YBWeRi5Jx79uOPTpUUF7c2mx1faDgOvJUjrjFcOMd1Fs6sKleRNewaPqwzqNu1vc sOZrdsAkDqeuOuO9Yd74Z1i3tUbTbqO5sIySrKAX6DIY9T0GAcYOcDJOcaOIcfdqbdzSrRv78PuO LeWf7TPHcwBLlSCRyD361aVgZEOOnI/H6daqrZzugp6QsS3aXEiWsdnbNJN53yiM/NnHoP8A9Vdt ong2GBRd68iRnhlhByDjkbmHXr0GO9Q6qp0Ul8TuJ03Oq10N3VfFsdpEI7ZliiUbNw4ZiOAAB0Fe ZX+sXWqtNDAm2NuvqcdcmsaVL7ZVSSXuo3NR8PaJpfw61TUbxpP+EkeaIQKy4Cpu5PPYruGMZzjt XjFsTJIrAEjd+VdMLuLcu/4GGllY9s8B6DPrDX1vawBiQpZmDfJ97gEdM5IH/wBavXH8P6Xo6SRX CKZ1+YADdtIOSCOG6569l7Vzym+ayBpXu9jhLzTobi4zasBb4DHavHtjPI7ce/4VhGMIxWFPucsQ uM84GO/XHr3rRO++xGxY8u3jAEwPnFTubcRt9vmzx+dZd20IZwwLD+JUwcA9Oc84zn8u9UgsYdwy uRAmAmMlmJycdQcf4VU+zQf89I/zf/4mr1FY/rj/AGif27fhd8D/AIcTeHdAv11rx7f/ADy29kxE UWRkebPgrt5PCbjkYIGcj8Vru9+K37T+uN4n8c68bfQAJJrK2VtscceSrC1gZhx8h3zMwBMWze8p jjf9QwmHjgpvFYle8k7LqvP1f4I8etV9tzQpbX1+R5t8dLDwR4U8QeHtI8GeXLEdNC3EkZOJJxPM hyWPzthVVnGxWKFljiVhEn7eWn7TfjD4ZeA/h/8ACT4J+Hr59N0XQrRZ9S0rw7/acVtBaW6z6jc3 V5JLutEUF2eKXTIk+WaVboBTny85zl0aNHDN2nUcmvVJvovPy6HTl+G/d1Zv4U1ftbU/G74//AL4 sfGL4veK/Ffi3xxe6vMoUWNxrWsT3U7W2DIlvC029kjiLsqq7Ko5xxXzt4c+EOn6FqFjq9zZyTSW 852C5w8JmTBAK7dsm04JjbcCMBgQSD8THNlXvC1pq1+mr7HovDypqM5LR7HS/F74laxb6esWqa20 2o3jMB+9IEEf3WdY1wE4+UEAc9Pu18d6hrW9Ba24KWSgFUHTPPJx+npz61NGN1zPqTN3ZxlzO32h lAwSc8HvWjqenR3MgWVGa5gREbbzuOGJyAOoPHHvWz0dyEbngnwvBrusSWUo8mJY2dyw2nAwMAnP XP8Ak16PHoM/hOdp9rTaADtMyqS9r74HVPfqPpXNVqpT9m+paWnMjo7zRL27hE1mRJbkEq2w4bpn HrXD6v4G1a+t0tZbWTOdyqu7ORn1HTk1nCuo+62Nx1PJNT8L6ppN6tpOgCnrvI+Ue4FW4bu30zyI Wbcm9S+MAkBu2e/Fdd1JaErRn67eFvElp8Q/D1trtiIp9OuIyDG6gkE/KylTxkEEEc9OKnfw54h8 PK1x4I8RvZqp3Np9xums89SqA/NDyQcoenGK+Tk/ZVZ05xur6r+up68H7t4Eh8f+KLGPyvEnga+V N3zy6VLHdxsBn5iuVlXBPTa3TNdPo/xc8FTSx295rsNirIUaLU1ls2YYxwJ1TOeMnoRTlQ5l+5fN 5bNfL9UEZKT5Xpf+vQpa98VPhv4BSGGbxfaz6ZN+9ggtJhcTWUmd20iIsShzlW4xgjgYNfOvjr9s jxPe2jaf4CslshsZH1S7SN55FJPKx8pGenJLnngKa68Nl8qslUrqy7dX3+T3Matb2fuW12PhXXfE l3qF9Pquo6jNd6lM+6W4uJWeRycYJLHJ6dSe2K4oy3urXX2ayhZ5G+UKgJ7+3+etfQxiorax5zk3 qz67+CfwBuLy7std8R25EPDKGUkKc8YXv0Jz9K/Svw9pek+GNMZzKkdpgEy52jHA6nvznHXr06V4 GaVnUl7OGx3YWCjHnl1MDxN4itpr201XwxaumsQfL9oU4inhJyY5M8OOM/KOCMjFeo+H9btddto7 mLKXKnE0DYDwsRxkcZB7Ecd68WrS5Ypvf9P+HPRozunE0L9kst00SMylhtOeeecEY/H/AArkfFGu 6UtuJpZVXUEBzucoHxyN2OQeoBAPGfas8HKVPF06kejv8jaolOi03ufE/wAXdcn1Swu5763V9Otw 0xNlbSXEkROMkPtGBgAk7RwBmvm3S9RttRjt5rdyBIodSyDJHGMjseemfavq8RKFde2grd1/n5nk 0705ODZ32p6hNaatpNxBJsBsI+C2Qcs3HOQRyPaugsrnTNSAF04iuW5P9x+BxnPy8/Ucn1rgxl3V bR1YWX7qxoS2M0UiBNySRsD8uQVPVSvfvx+HPSvftI8b2EnhLTLH4mx2Wu+GLp3tntyVbULEAbQ7 BiPMByMNuVxyd7HC1wyvUirOzTumtLP+t12+47GlKNmrp7nlvhz4H6j4l8N6/r3ggpdWNtqktvFZ RKyStCEikR0Vsbsq5+TCtxgAk4HmU2h3VlNPbXNtIkyOUaN0KtG4OMEdQRjoR6+lauu3WqQk7ST/ AKZjCEXTi12O+8E/FbxV4JnW1E5u9F3bntZ2LLg5OUPVO5447kGvqPwp448FfEJY4LW4W31jaN1j MwjkXI58p8fMODyPTJUVrKKlHnW/X/P1QXcX/Wp3ieFbpLcsZRPEM7Qy/vDx0J6f1Oeteea98K7O 6uG1uCyEGqxqQrxquemOV7jn61nSqXdpMzqRjUXNHc8A8W+H7+JWOpRkIGwJkUBU54yR3/3vXvXh fiTwOkjPNFEROR80igYA6/Muf1UZ9fSvQpVJUpXjt1POqU21Z/I81m068sroW88P+sYBHB+VjkAY OM55+o717r4g/Z38W2Ph0eKNHvLXVLKKPN0LIs00OBuYeWwBIAyc7emSQABXq+3hzQtrzHOqNRxl JLRbnz2XXcjGViACrH8B0/PHB7CpFf5CUTI7EtyeASQcj2H0rYy6EsRZRyxPy4BJwUAOOnp7VYjO XLtOgLAqN+ACOAc4B9ev1prYRq6TO9tqCTwXLR3agMjo7gsw7ZwN30xyCeDmvWtG8b3uvXFhpvif UDHHJexK12isPIGURnZQDjAJ+6pICgAc0NX9Sk7aH2ZaeAvhJ4b0O51a/wDETX4LGKVlkd4bV1Zd 5WMOjTMUOQvmbBlcsx+VfjH4kePbTWLuPTdEBj0a1jjiijHBdgCC5AAGWJP4bR2GeyNBUKSnUd5P YUpHn1repDol6kbBHlkAcgjsrDp3znHXGOtclPcKVC+YeOIxtyQOc5A/w/wrnb0SEuxlkswDeY2S Ccgnj6fz/wD11sNY3Mkcc9nKklucHa+DwcD7w5/A59OK5a8FUSRtRm4SuiASsHjjnUxTAkFW6HHo eh/D0p9vczWkrywStHNxypxu/oRXnSi4vlZ6EWpK8TX/ALR07Uo0j13SVlPAM8WFb8gePwI7fSo4 /h7b6ndoNA1uBo1P7yOQnfGuOoHBY8cAgfWpdV0k29Y/kPkUleO/5nQS2OieDont4kEuo7vnZyNz evP8I9vavOdc8VSSzEiRXk6Kq/cTqPpzzzRTi6jvImo1Bcq3PM5tVe6u0gdzJcyuEUbgFXcR+H4d q9b0t9J0W0RooTPqhI3SMNwTkcqP13fhxXbyWSWxxN3ZyPji8nu7ESStmTzRyDxznP8AL3+prznT 1LTR+hbj1zVfYBH0h8M5orLT9auWgZpiY1QZABzuz9e2QRjHFdrcSXd2XkkQyYRRukDAxoN2AD2H P06d64npKTZTepXFpGYnkztQMDjJYkgAEdBnt1xxnrVHyIURoWtYkjPR4wSw+p9sDgkH2NCbvqJ6 bHEXNukM8sGcEkkZ7D1PcdD+dc1dLGszLI5I5I3dx2I+tdMSL22IFtpJHbGR8vOB6/rR/Zx/vP8A k1VuCb6H/9k /9j/4SNcRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNS41ADIwMDk6MDI6MDcgMTk6NTc6NDUATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA BQAAAAEAAALgkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAEAAAkgoABQAAAAEAAALo knwABwAABDYAAALwkoYABwAAAH0AAAcmoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAogoAMABAAAAAEAAAbAowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAAAAEAAAAApAIAAwAA AAEAAAAApAMAAwAAAAEAAAAApAQABQAAAAEAAAekpAUAAwAAAAEAHAAApAYAAwAAAAEAAAAApAgA AwAAAAEAAAAApAkAAwAAAAEAAAAApAoAAwAAAAEAAAAApAwAAwAAAAEAAAAAAAAAAAAAAAoAAABS AAAAHAAAAAoyMDA5OjAyOjA2IDIyOjU2OjM4ADIwMDk6MDI6MDYgMjI6NTY6MzgAAAAABAAAAAEA AAAAAAAACgAAAB4AAAAKAAAAOgAAAApOaWtvbgACAAAASUkqAAgAAAAYAAEABwAEAAAAAAIAAAIA AwACAAAAAAAAAAMAAgAGAAAALgEAAAQAAgAHAAAANAEAAAUAAgANAAAAPAEAAAYAAgAHAAAASgEA AAcAAgAHAAAAUgEAAAgAAgAIAAAAWgEAAAoABQABAAAAYgEAAA8AAgAHAAAAagEAABAABwDuAQAA cgEAABEABAABAAAAwgMAAIAAAgAOAAAAYAMAAIIAAgANAAAAbgMAAIUABQABAAAAfAMAAIYABQAB AAAAhAMAAIgABwAEAAAAAAAAAI8AAgAQAAAAjAMAAJQACAABAAAAAAAAAJUAAgAFAAAAnAMAAJsA AQACAAAAAAAAAJwAAgAUAAAAogMAAJ0AAwABAAAAAAAAAJ4ABwAKAAAAtgMAAAAAAABDT0xPUgBG SU5FICAAAEFVVE8gICAgICAgIAAAQVVUTyAgAABBRi1DICAAACAgICAgICAAUCMAAOgDAABBVVRP ICAAAAUCAAAAAAAAAAD/AQAAGWESMQAAgdEAABNLAADthwAB2w4AAdsOAADtzwAB254AZACDADIA HQAAAAAAAAMwAAAG3AAAAAAjHQAAAAAAAAAAAAAAAEAAMiUAAEoCF40AMgbcAAAGKABQEXMAAAAA AAAAAAAAAAAiIiIiIiIiIiIiIiIiIiIiEREREQFrA6ED7QGGAgIBuAIWAgABAtBgAAEDUgAAAA8A HgAQAAUABQAAAAAAHgAQAAAAAAAAAAAAgwFHAdQCYAMKAgIBLwICAmEAAAwTDPUAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIiQAAPhAAAuAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAgzCa0JpggRARAD4QAAAIIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAgzCa0JpggRAAAAAAAAAAAVShknGZ8VowAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHd3d3cXIhQfFx8QHg4XZAAzACYAAAaaAAAABwA8B3CoE5oAZA8o ZFAeJSMmAdUBfwFoAmgAAAA/AB8AEAG4AhZmZmZmAAAACAAAAAkAAAAKQVVUTyAgICAgICAgIABP RkYgICAgICAgICAAAAAAAAAAAAAAZAAAAGQAAAAgICAgICAgICAgICAgICAAT0ZGIAAAICAgICAg ICAgICAgICAgICAgIAAAAAAAAAAAAAAAAAAHAAMBAwABAAAABgAAABoBBQABAAAAHAQAABsBBQAB AAAAJAQAACgBAwABAAAAAgAAAAECBAABAAAAEzYAAAICBAABAAAA1E4AABMCAwABAAAAAgAAAAAA AAAsAQAAAQAAACwBAAABAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAAAAAAAAAAGQABwEDAAMAAAABAAYAAAEaAAUA AAABAAAIBgEbAAUAAAABAAAIDgEoAAMAAAABAAIAAAIBAAQAAAABAAAIFgICAAQAAAABAAAbPgIT AAMAAAABAAEAAAAAAAABLAAAAAEAAAEsAAAAAQAA/9j/4AAQSkZJRgABAQEASABIAAD//gAMQXBw bGVNYXJrCv/bAIQABwUFBgUFBwYGBggHBwgKEQsKCQkKFA8PDBEYFRkZFxUXFxodJSAaHCMcFxch LCEjJygqKioZHy4xLSkxJSkqKAEHCAgKCQoTCwsTKBsXGygoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAagCg AwEiAAIRAQMRAf/aAAwDAQACEQMRAD8Az9S1OPSZ0hlJJdtoIHT6/lVJ/EbltsULHAyc8Ef5+tZM 881/fteTL5K42xxj+EfXgZ96seWWwwDH0bGa8ipiJOVondCkramgNRu58DcIye45qZUaRissxPGQ CQB+vNUoQqfK5/AcVYjuYtwj8li3TnJ/kK5ZKrLVp2N4qC2LggiQBlUEnuRkj86trDO7QhIwWkwV BPXkjv8AStbw1BFK88d+wtoZUAD9cgHcQMc5yF/DPGSMdRb3HhGF4vtM9tiJfL2tDI5C5JI5bjkn nnr7V00cFKrHmbX3mdSsoO1jz9opnyDtUZ52gVNDoV/d7VitbmYOdqFY2wT16/QH8q9G/wCE58E6 aWFvbCQ9VEcCx/rhf1zXCeP/ABPdePVjsvC16tk0YwLWT928zH+6w4zwOpHYKcsQd45dy6uVzKWK VtEJJ4au7HZHeItv5rYUs27oOhCbjnn0rptO8Aanfae6LJFHHnzEcrIGZum3DKuPcmvGfBfi3WtI 19bK6mm1G2nlW3ubO4ZnkBJ28K3zZXnIx6jHSvpHw/Evhp2C3Usmm3CiSKNuQmcYwT+PHpjPWuil g6VrPdL7zCWIm9jl7T4Y67cRk3D2loVbAUyFiR6/KOn1rXj+EqFQZdWYMfvCOHA/PdXcrqcMyuLV kllVd4QttyPriuUvviIbWV4hZBWUlSGY5B9xgYqnSo0rLk/C5aqVZbMrzfCrw7bp5lxfX4PciVVB /DbWfovg/wAFX9xFAtuZ5SrF1mnYsxHYYIGR9ORk9qzdd8c6helTD5dugXkCXq3c57fSsKLWbnTZ IdYi1ywa68zcbZtzMvBBySuAMccHv+QpUltD8ETao95fidvqmheHNGsNRMGmWYkitpGi8yHcdyoS PmxnOcDqDzXS6tfNoNnv0aG2lRTg26KARwORgjPGK8Q17xs+pQ3S3F1CjSIzubdnJA5YkBiV7Ht2 rqNDv5pdK094Jnn3wR5lY8N8o5J9TUuol8KJs+p0tz8TwtuWjhRZgsZZSeFJLBv5DuetZFz8TdUK NKjBF9I49wH44NY+veArTXPM1KJmjvtmTFG+0TH6ngE+vQnr3NeYT2dnBIytp+oM6nDJI4UgjsQS DWbqSY+Vdz0+T4qX8kUsb3jqT0dflYD/AA7+v4VV1H4iXt7bRwressEcSLl5ACSOrZ4yeo5B4Pc8 153BqNlp8dwh8LQztIpG+4kJMeVYZGHx3z0PKj8UtlklWMWumQK8gG1ApkYk9B061MpuKTuNQT2O jOnLbjMVucdOMZ5qOTSxOPmDAo3IbntkA/mD+Ir6EsfDWjacqrBYxFg2Q8g3sD9WyRXn/i+Xw34b kurWS8/e3N6b+UvJG7xO45QIp3gcKeUxj+I9K9NUqai3sY80mecR6DI+diDj0xip4NDnedFmR0RA ASWHzc9uea24/Efhe53R3ms3ccDEHNrbsJB04BKjHfnn6Gu10rxj8PTJGtnBN5hTkXBYBccYPmPg nvxnr65rCUac1yyehpFyhqtzkvsW+IQW6FFwRgcsw/2j37eg9qbL4fZBuMEijGSfLOK9ebUNGjTM 2mCIcAiSGPI/DOadCfC9/Iqxwae0q8IHgVW5/u5A/StE6UdEjOTnLVs+cNZtzG+xchycc1kxWs9j dQ3SnPlsGI9u9fRut+A9FvxMwSa3ll/jimJC/wC6j7kH4LXmfiT4fajZFpLFo72EsflH7qRF7cEl W9Scr7A9K6YSouSaevnoYtSseV/FmO3XxHaXsIAk1HT4ri4KgDdLlkZsDjJ2ZOO5NezfAfxZaeJ/ DieHtRw97pIxFltpaE9OgHTpjJJxk9q8Q+J7H+1tMt3BS4t9LhSeInmJ2LOVP4OPzrF8J+KL3wfr VtrFi7CWI4ZA5UOp6g+vryCMgcGuVu0rx+RovM+4xoloPmhMtu/9+N+f1zXnvxN8DRhV1+03yMuF vPMnIB5AV9oGPY+vB/vGs/w98bZvEmntqln4XLTwO0LWy3+TtJi+bPlju+AMV3+jeI7rWNEmutT0 JrJm3oLKSTeZFAxzlR15HTGOe9OU5zXv6ocVFP3Tw0aQstq8gj+ROHIG4Anpz74NXdB0fQLo3Q1S eW0PyiAQW7NknO7OFb29OpqbW7G0v4WGja9c6eJXX5GXLhMcjKnDHJ4yBxnqa4++0bWNP0+Oa9iO o3Tkb4ZLdXEESh8tkcHO1ct+ea45SSV4Gyj3Oj1Hw0tranyVQK24m6yGDDBLAh+BxxgqPzrS8Jym +tpLC2niktLJUWOZCoLsWkLjC8EDcvIGO3UGuCm1OdNKfTmEVv50JlEMcXln5iQCMccjH6Vd+GVz aRa7dLH53nIjWrK68A5DEjn/AGP5etZ3bV2DSTPXrYyQAh2D443A/jzXF+NbW3N+biBi7vFvkVc/ u9vUt6D6/wB0+ldnA+xX/hyM1xPilyt1rfAyNHzhfX99WEpOKuvL8zRJM5S8t02OAmTt6k/Wul8F afFdatp0bP5Zh8ufhR8wXkrnr1C/hmuRm1e3VLaO1ilkjljPzzBQyEZHOO3HFekfDm1SQyakyAss QjQY+7kDJH+e3vVzV2kTHZnYeL/HV74W0+SC5spvtMluBDeRBShfZ88gyf4WZflZR0znmvEbS30i 4lS61SW9WOdyXnaZPMc5G5sEEsfmz78+9e6+M9Esl8N29gFwsPmeW2xRjEbt0AA6qD07c184/aWu rdIgMlWZ1Yk5OQB69v8AGvRxEvfa6GcDrpvDmmT3AfStTghh8kSn+05Cu3K5ABVfmJGDjHcCktrD V41t1S2E6XJJVLVlkc49kyV/GuT8SQ3IvrS8IZzNaxu6AAZYfKRg8fw1qImo31rFGtzLDbjbGgEh y7KowqheTyFGACBlc461ytpIs7nw5Lc3c0elrKXzkIrH5kx1Uj2wf88V6RaeDZLiNDe3KvhQqhRu wB6kcV5FBqlz4ee3jhnlvntneZYZ3LBSisy7VBI3ZVQSDxkgE812c3j/AFe73Kk6RAZBAHbvz1rW mlJXIk7HpMWmQ6dB5IuLiTAwFkb5RxxjPb8a5u+1eCEyKULMhxgEHP61xlp4p1LzPMmkM2eMOWBA /AismINDFHGkjlEUIu9snAGOT3q2kLU8y+J8yXXjjU7n7MjiQQnknj9ynpiuJuZEVlAtYxznALc/ rXuGr+C/D2qzPqd7cakLqRV3xQOiJ8oCjBZSegFVj4U8KW9opTQXuSgIM1zdSkyN6EIUGRkdB3FV 9m9iLa2Zh/BvUruxm1OeyZbQuix7ipZRznvnn/CtzxX418Rw63pNkmtyLFdSskyQNtyAVx2GAcn0 q3py2UcCw2Om2liiZGIEIZuf4mJLN07k4rDk8O3GreIdOvI2aSO3lkE745XCjbgd+QB71g5e+acv umS10stjI4klfJHUk9OgHpVbUY0fw5DbMzkfalIUtgoT5mQB6kcfU13Go+ELe1t7KGwnS4vp7uQT xqVK2yxH5kI5OSMH6fnRqfhSWONpJ9SsLSFyQUZxllAcMAu1Qx+bP1AzXLJa/M3S0+Rw1vBbGSxR GIkjgyFBPC5YEY9iTz7VqeDPFqX3iBbaG2eMo6sjO4I2ZVCDgcHkn059smabRIrS1i1qPUILm1gx A7xKclsb2BGOnX3PBGM1Vi8UaVfXy2dhGILidCwnhi2lmALEuSclhk84I7ZrWOsXoZS3PZhMMbfW sa9nBuIWf+6wIz7j/wCvVhrkdVbIwMe9YeqXIAaQMCI43c8+4OP0rkraw+78zWn8R57dLtlu0QLE LZ4IgiElRmVweTz2NeweFmh03wrHcSuEQxedIwHRQM5/KvG7i7W9i1O6TKlru2ibIHRQ2emO+T/P mvUPEV79g8DJBA6xSTxpBFxkEHAK/igat95/12Rn0OfvPG19qer3+nO9zbzNbTqloQnleaUctINo zkg5/Enknjkb3Yt9c+Qu2JJnWMDoFDEDHtxWqusaNY6pNqN1Zy3t1FHtj2NtCkgq2eQW4wOM9+nW rltf2rxebZAkIrBFsLhLe4iUKo+behkIwcAbjnBrWLbik3sPRMY1gJY9MN2vm2y2qkzqrdSzMEGc DPzKD1x1GR1vhbWy3XMuoWtsyziAxFmBgiwTtRsbctyCwO772MEk1cuJGuLZLb+0Zbq4EzNKbpnR 4x13neMcAAbs8Ag44rkrzQLxbK5s5LaQwRyHfdInmRrz8p3Dj179yPWk1diubviLWLKbVLSDTbdI YIbSTdcW6Yeb90cEfQAY9Sc8gikF9KGbaysT1wcCseC1jVrVYJSzxxugJj2nBQj1PQ/z9q11ER/u Eey4qua2wrX3NC2vcYV1P86sRzF+ecZ4rJ8u33Z5Bz2JFW4psghGB/3hk0+cLFu7ukVULkkMdu3v zx/WqyzafNrMenxztvZo0lTZsYZOCQcEHBGM89ulU5pZEnSS4ubeOEI2GaMMxfgqMNwVOGBz04PO MVjWmv2tj4gVppwyiaPy12E4xjrjnOc8fT1qas5JWpvdBGN37yNpJX0yAXcbBkjuFDEgMF+fkkEE bQAScjHGK2fh9q99cRpd3ttBqMTy2lsIrjMohInZQ6Fi3Iyp9tg9Aa5SHxRoHkLFftduk6r9ogt8 QMrjncXkHI+ZhgAYxz2ZtfwXrFvpemzBlWS2klYNKQTEqCV+TgHOc8DofWlUlya+ZcY30NbUZZoP FwTyisMt5ckMoGNxYhsnv8uzjtn3NHj2cDRpnyQTbTAEeu0Y/WqgdbvxHCo1S3eVwYk8gbxGmd2A mAOuOnTocc11XinS4YU0w2zvcfaXkCKVIIwACvT5jkjp6H8Oep8LkvJmsOkfU8t8O3kGkeE4Y9cg uI7afUpJzhQCyqiKcBs9Mntgn6GrI07wrbWq6lbSNZMycyzWzSFN2ME4ztOWAIHqRnGabdf2bb6s bi5u7fZBLmKGeJsTMAG69Auc9SD7CqETwavYX9peajZzXF6YSzJLEJGKEsdxUDcBgfmTXRCrBwk5 bv8ADuYTi1JJHVwasn9nRPbyecgtwqsON2Bj+nSs2WS8uFvofLzKsEitGASc7eBjuTx+dcpouqTu 10IriRISFSPZGW+VWfoc5GeOcd+MVu6VrMlrYXl+JTcNE/7pZ+QnTCkZ4GSTj3rlrprTzRpT7mKI pZYNWSOIySNfReVGgwWOHCgD1ziuw155dW0HRLWKa22/Z0lliml2MRtCgqMZPVuKzTqmtJOdSa1t ZLuUZ3Rw4STAKgMQRnhyM5zgAZ4qrqMcviTWbK8mtmgWzliE8atn5Q28ruxj+IducVpCSu3/AFsi ZrscpOYZpJJDdrG5bLbwQPzqa3hu7dyfKFzCDkiGQBiPbOSOvpWte+Gbd4dlvIInPJZhuORyOT1r Gn0LVrFGeK5W5/3QQ30wK2s23Zk3SSudBatdv5fmTGAKSd8w3ZOeBjHHIP8AnrfFxfSyi4tp7W7f I3FWG/JBI6YxwDge1Y9tZhTIZS+0oAGYnK+pH4/yqJ9PudMunv70RmOdikkEcv7xVOQeQCFOO/5g jIrFTk7tdDWUEjqrC6v768WK+tt5kZFeWZSzqoYHKsTkdx9CaknRYIxJMFtCTgCZwF/MnrWb580d ghsWliChWR87Seh6DpWn4R06O/1eQ3n+kShciSX5mByMHn6VpUfI0n1IjFSRlS+IdMs18+4uzOoO PJtYGUkj1Zzgj6DPIqhNq8mq3AmsllgSRlAhDn5cYB+vIP51d+KGlXOh61He24At5lG58kbHHHJA wARjH0NZfheRCRA4QTSy5yrAjGB3z7VM23C9hx5eaxv3ui3X9kXDR3csUiKNrJMyhQGBO7g5AG7q OMk+tZ2kaH4qNxiS8gtrdACtxIgdm+g46e+PxrRbWrSBRe6hezQ+U2BDvwrOMEqqAZkPI7kDIyQD mqeq6y+taVHNp/nwSNMEheQjbNuITZs6Dsx4Yja3ODms1OaVuncuSi3dFnUfF/h+3kgt2ki1a5t/ m898eXEQASVOMZ642554rP0bxReavqNpp20Pb3hmmYsgeQAu5HU4AAUdMd+vAD/Gl7otitla3Wk2 1y6ITHHHuhCA+6sOMg4HtVDwn4eTxOIbiKW2tBbtsYbS7dSRwW6HJ59jVQSlTcrakSbUrNm1b6as Wo3MEcjSfMr564OO3/fXJ9hXR38Kw2+norK3MjPmPDZwOpPX2+ldbHptlBEFjX5goGAfw7VieLVK GwBUpt8zAIxnhefeorL3GyqbvNHA3F/Ik9y5RpFQNCd8mRiRDgBT0wdx+vp3yotsLF47SJWPy7hE mcfXHFb/AIlSCOw0cNA0t48Nw21cAom8MrsevIDBQQc7jjng82jPLLFFAZVErkcjJAwM8Y7ZzVxj 7i9CJSXMzQSRZBGr2lsY4zgRpEI15POfLxmp7+a3i0K6lj0+3hDsu6FTJtZi2Nx3MTnv1xxU19pW n26MLa/kuLs4bZHbkxxDAznOCe5zn8Kr/wBmPqGmmzaUK3mZLAZ6c9M1lJ35X0uiou115FWyudMW 1EcunXbsSGHl3gQAgEdCh9T370lzqk6xiHT7ueyjQ/JvVZiBySOcDqc9K0P+EanhtwEuEYkcZUr/ AI1gaoslncC2mOXK7lPYj/INa8ib2JctDthEuctGGYjuaBcNG5WKJVPB7gfn36GtFLJeTyx7Cq9w i2ytIylio3EAf5FdijbVmNzKmke8vgZm6HHHYD0/H+dTXtj9p0+4MKhhGu8tgduSB78EcVLpVsNh uHU5zhTkgY+nTrn8qv3Fy1vGzgEnHH1p0or2bb6lTfvadCpp1pDc+HRc+YwCwMqIFAwUyvPXIyO2 KdoWqR2Op3l7JmOPBYgDOMtnFUbS8j03SRbiTghvvc53Ent9arzXK20Ejr0d4xwc9VYn9a58R70o XNKbspWG+OPEv/CX2txbxWLJs+aIzf6wuuDwBnkjcB1zu7c15bbXEtpOskY5U8g8j8a9DnlSdAyZ 8wcg1F/ZFpfsty0MbZ6jA4PfiiEuSTT6kyXMkzm7DxFNbGaU2kDzzOWeeQEtg/wg9QOnGcf06Twd LPetNcyFTb27ZXcPuuc5wewx7fTpSt4RgmJMUssBbrg5z+dXdP0PVLNzCtxayQOuxiYipVe3Tr19 aiqlKL5VqOErPUzb2XTNVvTLdKJJ7h/KjLh8If4VIHIP4dTzXe+B7O1sbOaOK0WPa43OGJZjtBwe SRj0z3z3NZSeF4o7g3HnssrfeKAAe3H+T+ddXoMP2aEW8eNgzjuM9z+dEI8qSFJ8zudHaRW8iCNc oRgbi2T9fmzXPeO4jA2nKHyMS4B7fd9K2Zru3023a5uW2qDgADlj2AHc1xWqXt7rl0lw5SOIl0gS SVY0GBzgtjJ5GT/LpSrL902Ok/fSM25WfS9Jt54yXuJ51mWzRFLSwgneWLDgY6dOn1w7w/ZSkHUb m2t45vuoqDD9sknkfl/+qrNeWomhNxHc+coETsGjlTaoAG0jGBx2z+NbSatYmTy7fUIHVeiSqYsf QuAD+JpUp3spPYdSDWyKer3S48uIESOfn55J7D05puh2p+3yQAbyqEn/AHgVBP55qax0++n1FLsr 5yLlt0L+YoJ4xlcjpn6cVd0CIf2lqDsoJSVgd3bLEn+VFaSlOKRNNWi2y3cWTgcAgj2rgPF+mTnU Le4jjd8RsHC+g6dfdq9SuXVidj/98tmuI8XpHNbSI6s4JGTgfJyPmzwODj6/TNWnZitc13kkkG0E AdSBUU9uZYXjO4A9T6c9quW4G0cCp5gBGeK6pPQhFCKOCC3RBI5CKFAJ9qztSje4UqhfB4xmrf8A E31rPZ3LMu5sb8YzUOo2rDt1IUsFEIWQN75PWmJCrxyRsA21xx/31WxAAYzkA8VnWX/HzN/12x/O sKju4mkNmVPsTFioRFXHGBzVix0hIPMzKZQzZwRgD6VedVEjYUDnsKt7RleB+VK5JEixx9UAXvz0 rShACbolGP4celQRjLKD6VfhUAgYGM9MVSEyaGx89suOnWrzPb6bA88xCInA9T7AetTWYAGAMfJn j61zHjVmLKpJKiDcATwDuHNWldkt2Vyle302uXayTsY7dThE5+UenI5J7n/6wrnbjxXd3awQMkSC 3jCRxxwggjJ5wc8nnJHXHNdLpv8AyD7f3XJ964OAD7enH/LMf+hPWWI2SNcP1ZoLrlqxZLnTIGU9 fKLRNn9R+lTrcaJcgNm7tWPUbVlUfjkGt0QRXFpCJoklARcB1Bxx71weoKsc0oRQoEjY2jHesnRS SLVTmbujo0020m+a11e0ZlOR5paI+2NwH6U54/EdrKlxpn2lkHzSvERIsmTwe+7v64zXL2zMRjJ6 DvVhppbaVZIJHhcAkNGxU/mKz5LMu+h0y+LdcgJS6jhlbuJ4SjD/AL5I/Ws3WNfS+hIktWibIIdJ QwUjvggY/M1u+GZpb62DXcj3DZPMrFz29axvFtvDEW8uGNMq33VA7VUZO9jOpFWP/9n//gAMQXBw bGVNYXJrCv/bAIQAAQEBAQEBAQEBAQICAQICAwICAgICAwMDAgMEBAQEBAQEBAQFBgUEBQYFBAQF BwUGBgYHBwcEBQcIBwcIBgcHBwECAgICAgIDAgIDBwUEBQcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgBkAJY AwEhAAIRAQMRAf/aAAwDAQACEQMRAD8AxLeaMIAwz69wBz+fWrovYxhQ38Jz3wPYiuVu2puk9CVb /wC6FlyQOvT36E/54q2NQkYYD598dv5dQahzXU2jEl/tPbyX5J4yP1xSf2yqA5bI6Hknkf5IrndV b3LiuxC2vdlfjOP6f5/nVOTxGcsvncDgAnOAB+lcVXERirm8KZSm8Rb8hctwcemfr26Vh3njCwtG BuLuOMN8oDvgk98ev/1zXmVsXyr3mdNOk3ZJHFz/ABd0KG8ls3u3aVVxtSMkk9sE9v8AIrKPxC17 UWf+ztLyP+ekznnrz2/n+dfOY3OYUrqG56uHy+UneeiMW+8aeILmGG3u/ElvbeURIUgZQ555HGT6 8e9c8+taTGzSSahcXEvfbnH6/wD6q+er4uvi5J62R61HDUqKvTjr3Ki38lxuGn6MRvPLudxH4d6b Fo3iK7dgE+U9d5wBn2+nHauaUIuSc2dVktGb1h8Pr15I1My8seg5RSeeT9f5GvQdN8JeGtNz9ti8 24yq5kkIGT6AfhVyrWSVPf8AIlttWOxjvtL04eTYaVbhtuBsiBI7dTxmrCvfXrIWyq8DthR0wAPy /OuCbnOXNOV/UfJtqbSeHnNu8mx2k+9tZvvfTP4d6TSBstmOt2tvbvk7QZAze3Q4zWcpR5W77dBX d3Y6mLQftsAlhm8m267iNucnB61mtoHhHTist/cxM2Nx8193HQd/rWHt5JuMFqCdnpuU9T8U+ELN GgsHUkYUeXEfmyPp69681vPFNtIJAltIW64bHv8A/Wq4qo1eRUacm7syovEU9u7+RZqMkcuTn0rO vdV1u4yzMiZBb5I+vHr/APXp8m92aKmk7DLJ5rhvMkkLbCOHGVwOoYdxk9K5TfNbuIo7YFNxHy7j twe9fX55SgsjyuUVZtPX5I8jLpzeZY2F20mreW501rbyS20LNCyy7tzY5B4PHtxnn3rqfCttPJq8 REGxXBDFyc4x+n414GSO2b4V3+2j0sySWX1/8L/I6/xZZmCXTpdrMpjOdhxu5HWuFa01BbmW+s9+ NvlqrNxGccEevPXNejxMks9xL6O35I48m/5FlF+v5s7DRNO8SJp/27U7kS3DSAFIgBhO+B+PSv0l /Z78NtqvwR8a3DHAjjv3HmDB4gXA+uWrt4PcI5rJx25H+aOfP9cBf+8v1PhT4l6s/hnV9QvxprT3 Tzs2xO3PU+3J4rI8MT3GuwR3V7a/Zy43beuB+Jrw8dSticRUctOeSt82enhpP2FLzivyO5trXSEd l8wGYDlS3QDjp26VNeG3ihZrXb5+ODjHc9zx71xwjKUkmtC223Y43Sp9aE8v9ogCAnCANksOcH2r SlitLtpGngfd/st1+vvXd9X/AHjVND5nbsV7bSrEMXFqzHtnp19/wqjr+uX2jLBBY2vyHAYIo3Jy B6ZJ5/Su6nldfEyjFqxhUxFON+aRy9/qWs3SyAtcYOWbqfy6fn9Kgumt5LQrPp9zNdLjazEKvTn1 ya9PD5BKLTlFamFTHwjpT3OakN/Zhlt/DkZbbkNMzPzj+fNY1/qvit43gjSGIDP+qtlBx169e5/O tHw65TbcZSfZf8Ax+v1Z6XOTvrbxvqRMa390XHzDYpHP4AetY1t8OPHWr3CQwaXdzyM2AuxiSx4H Hr74renw5idFSwr1fZmTr2T5nb1PTdE/Y9+PHiFylh8NNVaMMNzHT5sL14JIwPz7V9afCb/gkV+0 z8T9Wh0y40yz0TzbdrmGbV7oQpOA2PLXy1kbeecDaBwefX6TLuCMXVnGWNfs6fV7v7lrocGIzTB0 I3lO77L/AIB6vf8A/BEP47eH1sn8XatpNtbTAsDFcPM0Z5A3BVG3884/Idr4Y/4I1aXBNbt4o+IK /Zdyl/s1oS2OM4Ltgn8K9ivwfl+FleNX2kejtZP7/M8+Wd0tqcGfS/hL/gjr8ALW/wBLttV8Rahd SXNysEYLxRIm4hV3Mqdz/Ovc/GH/AATl/Ze+BnhLxx4tk8AiW/0XSbnUx9rneQq0EUkg6naPuHHG Onrzrh8BgKUE6NJLp3ZyzzPE1Hyw0ue2/sU/sdaMNI8La/8AEH4Q6Mum6xZxa3bagltbSvMk0fmh JDgnnehH41+l3hL4WfDDwPr+oazpunW8OrRqlnKoVf3St8yYUcAEEcgfyrGjCnTpSlKV1fTyWhhV r1J+6ndWPc7O+sbtT9iuY3VeCEYHb+XSrtetTnCpBSpu6OJpp2Y1mVFLOwCjqScAVQl1fTYLpbKa 9jW6PIRnAPTP8quUlFXYi4J4WiEyyqYSMhtwwfxrPuda062MYa4DMwyoQhi30x1rOdWFP4mNK5lX vjLRbCK4luZ9qxf6zOBs4B5/OuBuPj78NrWYwy6yMj7xGMLzgZye/tmuaWOpx6D5WcfeftXfCi2l aOHVfNCjLkEKV6djyetc7qn7ZPwstCsdrfB5CpY7mGExnOcH2rCWZL7MR8jPP7r9vv4b2VwILqxm VD92RcMpAHJwOfXtV7QP2u4fE2oxavHb29l8Pgxlm1GSfMqQRI7yMYSuQgCZMnQZA5PA55ZhVnJU 46Se1uvkUoJXcjyLxb+3xp1tq3iVvA+sQX/hxPJihupYx+7dvNLbRleyjqCOB614P8Gf2wtS8a/H rwdpevalPPowubm4uFWU7UiSGQiRl6bUOGPptrKrjKrUubo9P8i5Rj9k++7L9q/4ceJfC3inx/ae LDYaPo95c2MKSGMxao0e0BwcZ5YkAAjjk18GfEb/AIKFap4w0PVvhb4U0g3HifWmgsbSeKUxtC8s iKQCeDnO3kgAHniuypjZQnGo/dUXZp+RKilr2/Q/OX4ufH7xl4c8Q6Z4Wv8AxezX0MoglWaYsYiB 8wYZ5AIwPp9K4v8A4X54k/6HC0/J/wDGvLxE7T6/L1Jlo7fofmxO88Msq3ETo4JDKykbT0xz/nis +TU7VCAJeQP4iOPr6+n49q9SddXsdMabvoR/25AuAZMsOQfT6/nVaXxHEgADgAAA/OeP881yTxC0 dzeFJszpvFyxr5gm+bqRngHpz7f54riNV+LGi6crtcatDEF4J8xcgdPx64rza+Npp2cjqjS10Rws 3xvsJbuOy02Ke4lYbywyqY9c/jmo7v4mavKZYYBFCRg7zJuPOexGCOn44rw8bmihG0dWd9DBzk/f 0X4mHdeOSY9l94qkOScrEQPwwOf8+tc+2t6XOyz2UF5cSoRtkYlufXnJ9a+drYrE1/ebsj16WHpU 37iIBd6tcXrXAttsrN8u5cnPuPfJrstLt/FeqEwS3hCEYCbtoxjpgD35zmuSs6bvKerR2Rjtcr23 gGLStQil3ST300yo6gE4Unk59On/ANavb7HwQI445Bp5z1ZpmAB6Y5/Ksa2IclCS0/yLjZRsdZba Fplmn+nX8CL02RnkYPt7fyNWRJoSykWdlc3BX5fQD/HvmudSqTu1t3G29bI07O8u5BLHb28NsEbL Fxll/E/54rFl0+3ubl5Lqd53jKsPm+ViM/lj+tDlyt2d35go3uaVjK0MrG6W3jh2EogbnrjPvxmr sfiaxtXt7eNy96ctGka7y457AdvX2pUqFbFVVRoRcpdvzHNqCc6ktEQP44vEt7iUxuYAS2GbgL6Y 69qxk12e5ZdQihj3E5DGPoQehDd/as3RdOUk/Q0jGPVlrUte8RXkPmTX8ht8AFEXb+mOf/rVjw27 NHHLcs5MjYBcMSSexyeO1ZqMYRaSLUY81kgltLVHRopC0mMkKOvt/ntU0lqbph5EBLY4wMAE4p3b aTdvI0astRyaXdSRGNogG+7vYAluOcY/DimN4fu2CQmYiIAYUD7wz/gaULauWpLa6G/oOg2iE25G xc8P2QnHJx+NKNExk7Iyu88kckc9MDnn/PFfX5478O5U/U8HLnbN8d8gltmgSSOG1y6DgBgML6f5 z0+tbPw707WdYuBd3Om+QRvIQZY7QrEk/gK+ZyVf8KWGlfacbfNnpY/3sHWS/lf5M9I8TaNCsGkz 3UqKskcsi7yOgYr391PHvXFH+zLYx26MXXJyQgIzjsMf5xXscVJ/27WUV2/JHDkjvl1Jev5smTWl iYQwWzsuMgY69vTmvqTwH8SNR0v4YXnhDTd0Op3+pyeZuARljKQKgOeu59/4A16PCOEr/wBpRnKP uuL6ejMs/tHL9e6NL4kfAP4j/EH4m+Mr/wAFeBru48NNqM/2GWK3PkvFvOCrHgqfavlTxXJB8O9U m8OeKbySz1WB2ilge2lGxh+ABrTGcN5hOrOpGm3zSb9L9zejjsPCjTjzXaitOuxj6d4o0PUmDWMt xMWGVIUJnp13df8AP4dpYabrGqsv2TR3bjYSWLHHbgV7GTcFYnGzjDlcn2im2ctfOIr3aUfvNmHw F4quHx9jdX5wFiJ4PT+Qr0nw3+z98RPEU0cGn+H76eQ8hYoXYntnC9a/Ssv8MM1k7/UnCK3lU9yP zcrI4HjsVVv7zsfWvgv/AIJx/tB+JbZJ0+H1/FE/IN3GLbrjnE23P1r2rSP+CSnxvvmi+2aXp9px ktdX0DqDj/pmznP4V7y4V4UwMXDH5snNbxowc9eq5rqP6HFPF0IXU6932V3+KVvxPXdA/wCCNXia 5XPiX4haVagqMLaxTTkH3yiD8ia9j0n/AIIyfCmC5tZda+Jl9cwKQZY4NNjhLjuFZpX259dp+lXG vwdgEo4PK515L7VWpypvvyQW3lz7dTCeZ01/Dg36tL8rnr1p/wAEjv2S4dhu7bXbkjqJdRiUN/37 hUj8DXrGjf8ABNv9jPRWjkh+DVrPKqhd11eXcu7HchpNueT271nPiOsnfCYKhR/w0k/xqc/3o5am Y4matFqPp/wWz0Cx/ZH/AGZfBUcuoaV8HfDluiusjO+mQMVVeCAzKTjknrXjXgT4c/BrXNTsfEOm +FtPhtV1T92y28aKixzYXAA44FRSzTE13KVZ3dnZWSV7dErJHmV54mqryqNq66nst14d0CXzNM0H UbO11GeZxB9pgJCDBIJQFS3HbPXFdR8MJrD+2dZ8JapZ20mtafDBObnyQpn37twQHoFIBOP+egrl xOIk6d4tqXW21v8AhxRopqT7f5nYeOPDOjXkMl1dxtnb8wHQ46Ej6mvlz4jeHLHQhFPo+nvctJvY Q7kU5XrjdwfXFc1StKWG9/ZLc0hT10PO9G8YXWl200mueA7y30pJRG15ceWsUPAYNvJ2nKtnAJIw M+lT/tmaJqHir9jX41eNPCbz3Gvw+EtUsbuxjw5ZlhkibcByrICSw9DkdBXn5bhJYjNKWFru1OrJ JO+l3Kyfy3OqK5VBp3f5HtH/AAT58USeNv2IP2UfEF6wbVm8BaLb3+DnZeQWkUFyue5WaORT7qa+ g/H3gT/hLdIvIdKv/sGvMEMV6iZOUIIDY5I6j2zmsKeGpumqdZaLR/LR/kZqTp1Ls/Lj4ufFX4uf AnVm0/xm8lvcGR0tdQs5Chu7dcGN8j5Xxnoe45714pqX7aXxQvo7S5sfikqRRRsPss8YjMqglRlk +8xB745715eLwssvxLpRk3Tlqmuz2N5OEnex9Ifs8ft3vdancaN8TvtVykygWsljbtcP5mVUAqoz yMnjv271674j+N2kz/td+Dfh+sdxBcztHEsc6iGR99q7btk2MABuQRuOAFBbArswk6rwVSUleMXo /mvnoc04vcoftd/tCeFfCXk+FdE8TyxeIlJjvo0Zo12sGABzj5sjJx7etfmZd/tT+IrLy9M/4SiZ reL96hSU/L93jP8AwHJ56seajMZQjOKtql/X4BHY5zWf2qtW1GK5M+uzSucoXEzMWAKYxk9sdeet eN/8Lq/tOWYDULhSyOu5iTtO7cB14yR+FeTzya20LVkcXffES9sovNDHzVOc7+cY+v0ziuQv/i7N cJNIGZbjqxGNpJIOMY9P51m5Naofnc841j4n6tNKHS865G1SemOg9K73TfjV4jtPDnj7X9Y1ifbe aZF4Z0hmPyRQeZFJOi+2yFEPrv6HAxpQmoYiNS13HUmSurLuv8znoPEOk6b4Ra5S7kMk9ugS1k3K xlcENICOirk4/wB4ZHetb9nD436d8JPinpGuahoK6tp7Qy6bf2s0hIls7nC3XuGMW8A/7Z+oyq1H OleGjv8Aj/w5Sb+4+if2x/2qvAvj230Tw58GPC8Xh/w+xfVLqyhjjhWOVjsUbI8KG2oHIUYy/Xqa /NDU/GPimC7sNVi1eWG6RxK8iN82QpIwRjHzAcf4V2YuvDEyjO2rWq7tjbdveOZ8ZeLNeuvEh8X6 jKk15cGOH5l3bSx5b2yf5VV/4TnWfSL/AL9muKq5Takn0tr5aGbXNuz6B8e3un393JPepbKLzM4W ED5c5455U8Hg+nfg1+c/xZv7HSLS/n0DVpF1COUFI8/K6Z5B9xj9a1xtqNCNR9bo78K3Oo42ufDc X7QvxHtPHF74clht5LJCCM7yevIz2PUc46V7ZffF/WLm1RLCzjgn2iOZ7hsBSRyRg/lXz+Kxnsop QerVz26ODVSPPJ6Hneq+O2+VdY8QyyOQDtjGFOTnHH1PX0rzrV/FNjf2c1np+ks0jDIdslmOfzJ5 rxIvEYianN2SsenCjCOkI2NW1n8e3yQfZLHyLbGzCIchRj611OleDfFV6RPqNxO6thtu7txxipqy o03dSu/M1jFRV7nrGieDo9KjQvp6GTu0kgPJ64zx3/Ou6NtbFTE93HCmez4Hp0X8q8yrV9pK7dze OzOl0ux0OOOMmd5FXgCND19yfrXdWVnZsA0YaKHr97cz4+nSuOc227rS5orozLWy1zStYvdQttWA tSgUIw5yTkfTj1rubW01TVoYy0k8kh+8FY4Hvx2qZunKW3Za/iWklq0dNpnhKeJDLebIgTkGUgbf zrThg0mA7W1yNJv4vs8ZbA+g4/X0rKVRSk4xV0O7ehuvpfg2CxuZX1WS5vShMfmNzuA4wo/D3/Ov MWhvS5LXJVOyhjkr+Xv7VUOaTvONkti4/wB4me0stqy3MxZV+YkbsqfXJ9K96+DnhHT9SmvNYttP 8y+ja3hjk2HdGJX+YD0zt/KvpeGOZZvSSWlpfdY4M5/5F1a67fmjz/xFpSLrWu2q2TM4uZRjtwx4 PY1jPpt0sRlaGMKhLMoHQYHb8vyrw5p1cc4N2vO33s76LUcPFvpFfkena/8ACTxN4U0/w/rGqyQy aVfwJIvlkloi6LIucZHKt65BUggVy8Xhpnd0Fsf7xbB49x/KurOcvhlmOnhYyukk7/LUxweM+t0I 14q1219zH2PhS4KtHPEixlsBmPPHTj0/+tWtH4ftrfd5t0Co524yQfqT1/xrxrpO61Opy00FnXTY OPJUngbmOc/TP0rHmv7JVWNSq9vlBJz/APq459OtOMZtaak8smQQItxIGtsgDJPy4zxuB9+SK3vD ng74keKUiTw/4K1G6Ys6q9vYzSK+GwOQpHb17V9/jMqxeZcP5ZSw9NuUb38r3PBwLhDOca6kkkrb nvOgfsX/ALTXil/9E+HN5bxSj/WXJihA/Bm3DP0r23T/ANhL45fCrQtT+Jfi28sI7DTbKczWi3Rd 3WWJ4DjAAyBLnr2oyrg2ph61LE4molJSTstev3G2PzXBKjVpQlzNxa0813OV+HPwv+EPxe1KXT/i P8Vbbw9a6RbiVczwq1x5rsWHz/3cZ4B6+1e6WvgP/gm34KZI9R+J0ms3yHDLBdSOCevIiAFfZ1Mk pYrGTrrBupUdr6O233HzVDPKmDwscNTsrX166u5718Mde/Y01LWIdK+HXwdW/uQQI57i3BBPr+8J P419O2X7F3we+MvxHsvGfjqwvdF06K0t4bW10ZIo0eSJ3fdISj9dwGQvb8a+2yTJq+Cj9fxOHi1F PlpvRN+draeSavtc8bG5xVryVOc2/wAkfo9Y/s+eCdO8Jad4d8GaxcWtnawLBA5dJflUYG7gEn1O a/Nv47f8E74PiFcXqXOjLc3hYsLpIfMEvfJ4zznpXThv7OxbqU8ZSVKd78yvbzVm9PI53i6lKcZK V0z5M8Af8EcNQufHmkvr4u7HQFuklupYFIEkSuNyKJAQhIzg4IHocYr9uPB/7EP7MPgm2tYNK+Fd nM8ShfNvZZrhpCBjLCRimfooHtXXDNa3DtGWDyLERTqNudSCXM1ZJR5mrxS1b5bXb1bsjvljqsop 0pWfVpK/320+Vmet2vwN+DFk4ktfhR4dWQchv7GtCR+JSvTLaztLOJILS2jihUBVSNAqqBwAAOAK 8PF5lmGPt9dxM6ltuaTlb0u9DnnUqVP4knL1bf5ljFFcRAUm4UBewEgDNYusa3aaRafaJn5Y7UGM 7m7DFaUqcqs4wj1M6lSNON2fNHxS+JekXOnX+lyXzIkoltTzzG5R8cD0zn/gNfmBpH7UuneArCLw p4Y0lmnsbtWa8nKl/NTY7OE4AUvyqnsRkmvc+rKh7OEtG1L8jnWJcqTUduZfqj6W+Lvi2y+HnxE1 i51PV7pdQ0a+t7gXEhPkvkidInP3fnjHQdjX1bpF54c+JHxI+DnxX8IeJYv+EJbR7i4gaOdP+JlP MDAkLJnJaPLk90aIqeprPF+zpSinHSVO69WtDSjUd5Oe+qPdPEmrixhvpLq2MlmFaMMF+4+0NhvZ uMH/ABr4p+IV9b6i/h+OWRy0iG5IhJO0bmUBfcEqpHfJrClh4VcPKDeslp92pUas6NRStdHmmmft PfByzs9T+CvxO0i+g0jU44o57iZcwxlgFMmRyowBlhwNn1ryb9pn9oT/AIZj+C37UM/h5T4q0XxL YxnSp7V4/Khvb9I7JpZmHJHlPEWwTg268fMzD5OGY1svxNHAzh71OomvNddfLsexGiqinVvZNXX3 rT/I9R/4IoeNNO8Vf8E/fhxpVvfedq2g654g0nU1Lc2876pdX0ceMkgC3vbcgHHBGBjFfqYuvaQ1 4dPW+jN5u2iPd8xPJ6fhXfHFRnD2038Td/W7/U4Zp88j5U/ab8PeCPi74Qn8Ka3aD7XazGezvZId wtp1GNpz1VujLnnHqBj+Yn4yfCf4kfDDxZf6Pq9uotXGbe4iJ8qdNxwyE9D6jsfWvPr1/rSlCW8N vS+v+Zqk1Bdyf4EfGnx38C/ij4W8b6Lexi/tpzsW8VpLXbIjxSeagZSQUlboykHkHiveP2xfjnof /DYHw88YaP8AFyK7IbRLu4120VdmmMTEZ/LEYOBEu4hQGYFdpywOefDVp0Pb0krxnC9vNNX+9fkZ zs4tPctftn6Ne6R4qtdQ0r4tWnijw1LCJUvobyKa4VpC+5ZWTG8go3O0AAjgHivz8TxDKWaRb+T5 gAQGb5ucfToa1xkoVpRrUvhkk/Ty+ROySRpDW1SGMxoWAJyQc9cenGecYqjD8QYNHdpLqEIUOdxU /Me3B659vWuCcZcrsPmZw/ib43aOFDlizMMggdsn+WOteR6l8cNPO6WJGC5PynnPA6Z61yyjU00L 66HC33xqlJZ7eEgdFwcceh/P1q5p3xvk1Dy7DxEhl0KGNpI4h1jdWLcdueR261naabcN9inFtXHa 78ctYurG1u7qCIKygxhSAEQN5aKAOMDGSMensa2PDfxb0KwvNP1u7hf7TKFiZDJt3SE4z9ByD64F EoyirR9BDPEnxZbVdWvtRhhCSs2Fj5CqgxtA5OeMD1rGi1zxTr3kzW2mzMFwwHlkAZHJPv1prvcL OT2Kl9pvi+9aE3cMvk7SeG5DYOAAO+azf+Ee8Sf88Lr/AL4H+NJyjcPZve39fI+pPi5r/hmWG11/ RGm81E2i3lBz5YPCgj73pnGcCvy9+M/i7w+dQlktfMgZ0JnimOMMBglf9k9Rnp6nrRn0qlKjTpvf dfeerlsHJudu6/U+MPAnh7xD4p8WavrS3LJbTXG4M7YKqTgHJ5/z2r6nm+Glozzy39+03mfOu04C 9euO3B7Yr5PG4mnCdorWy+9H0VNckYRtrYS7+HOgJZyCJkW5UHazEHPTAIrk/DPhGLQNdudQ1S6j mWQ/JFGu7a2Og7ZHJ/H8a4IYmUozUuq0N9W2emtq98RG9paLHAOSz9ugP+fxpYNca4L2Zu5JHQ4I jbb1yR7dv0rGNPfq+/b+v1KjaLS6m/b20lxPFbR2zbSoYvOxyQfUfXPHvXdQ2FrYI11NIoR1+VSQ fyHNclWXLaK3OmN9mXbLWYlkW1jsHEZbKEjAJ6HB9RXc6ZrKWMRM+nmVl3Yw+AuD3GD6Yxx1rmqL ltdmqTehT1+/u7+2uGtkSDaMKc9Ce5x2z/n1q+D/ABDrug6VBHeayn9qnIma1VirLklQN3U44/8A 10RdN0pK3vP7rf1YfJJ6vY6pNVub6dftt7K6E5YO5IH4DiursmihddpDQMoGc/MDxzx07dqzn+7U UtnqbR1TXY6OwFw0sKOqb25UgA4Hp7/WvXfEnwF+JXh3wlpPxB1jQpYfDF95ZgmIwSsgJQuM5UMM EZ9RXpYHA1MXhsRioO0aSu/x2+4561enRlTjN6zdl6nCL4RuYo1uXiQQF9qOzDlgNxX3PI/MV+in 7FPw2/4SOHxfOlt50cF/ppcRopATZdtj0GSnB+terwnK+bp/3ZfocOdSvl1VLy/NHwNr99qMvxT+ IukT2u20g1m6ijZeMASsMMM8H6etbqQWUe+PYBvO0gc9evUYP8ua8apTccxSj/N+p207vDxf91fk eueOvHsmteGPB/h2DRz59tbxq85HzO6R7WIA7HP8687GgeLdV2pZaTeEkZAjtnOf0r6fiLKcwxmb 1KtGi5RtHWztseZkbisBGUpdZfmd1oXwI+LniBo2tPCN2qv0abEY+vJ4/L+te3eHv2F/i54hGb+a 3tIGPOSWYd8cYFcOH4arSs8RLlXbqelUxlGknrdn0B4Y/wCCY630e/WvFE8kgwZFhiVRjuOcn/PS vpPwr/wTV+EWlqj6jp011ISG/wBInc/oMA19Lg8lwVDlap8z7vU8yvmktoaDvj/+xn+x34W0HRvF XjP4kWvgWys7byZYVhjUai4ORjOSznoMKSc15VpH/BR74R+B/CWi+Efg78C9Z12LTrSKyh1PVp4d NhuljUKJCArykkDccxjk9q+/jisvll9OFCnyzg3zN7elrdD4rEzxX1icqj+LW/czIP8Agpj8VL+a Mf8ACmtDtrUnBSLV5ZJBxk43Q8/lz7V3Vt+1pY/FOGTQNfl/seedfLxdQRvA5PbzACvY/fAFeVPE 1YvmouMl2S1IgoS0nJnzT8Zv2UtW8VLLrGg22h3FyQXWC502JI7hTyPnixjPrtP1718Hrd+BPhB4 ll0T4x/stWFzMjkO9rqd9ZSFBna8ZRmSRc9Oo5I7EV91wvnkq8nTpNKslflkk1JeV+vkedj8JOmu eMvd++x+1X7Cvir9hfVNDbUJbbVPDviQzBYrS+Z7iJ4yARtnhjI4OQd+zseea/dHwnovga60qz1P wu0F1pUg3QzxS+ajDpwcnp0rtz/NcyxclOpFQpLRcqstuvW+5x4TD0rtSm3Lt0/zO3jt4Ih+7iUD 2FSZA7V8o25atnpqMYK0UOopFBRQAUUAFUmmjhujHJMoaRN6xk/MQv3m+g3KPbI9apa3SJfRs5nV /FdnBBqkFrIG1CDyvk9fNfy0/NgR+GelfKHjrx9dah4Ni13Ubk2cVrqapb2+5Va7d380gsc7VCAj HHQ5IFe5l1GFH9/W3TWnk1v8k7nBXcqrtHax8B/FLX/EV3qPiJNbultWjmee4hBJaFmt5iqDjP3o yeB29WFfmR4nufE3hy0u4tVigeSG/nsZb1BkyEjIGehX5JNpBLYGDwBRjsTGdenKm9k/uaHCly0Z J+R9JfHb47v8TbSHxjNCFh8SWdteR2/nYjsZoDJp7Y5y5KQKwyD94Eda6/8AYd+KEXhT44fA3wJr 9/NfRi6ddKtwzEWM97bGFmUZ2hCjEsvZlyBnJr5+pjqmIq01fZJenQ7YUlGDstd/8z+iLxfaTv4X 8QQ6ZbK17NAzFW/vbQM+5AUY+gr83oPHaXN3p+h6vcQ2cltdbzfxlWjki8xAfNxkhcPnscqD2rpq ynDB+2pv34SvburLT10NaXLJunNe69PvVv68z5U+P2heCdVfUZLm6SC8gmb7NewuGCoucNgn94p5 Ga/OT9rP4ha14b/Z71b4XaTqSzaReappsiSoC/2uSTzJ2aOQY3RKsUbDI/j6jpXzGaYmni69OvTW 0k7/AKHfRhUpU3GfRPc1/wDgjp+0Pq3wzu/2gfhyLsJpzX+neIreMyMA8rLJbzHaDg5W3twTjOAo zX6yXX7Q+t2njmy16K42ob1ZSq8qBuzj6YOK8+DlFVqafW/3q5zrX3kjbPxT1LWb3UIf7ULaqk7x +Q5LLKmTyOoPBzXCePdE8OfEDw3Jo3ia2EsRiJWT/lpC3OGU9senfpWsanI1Ug9R36H4u/tEeAdY +DRuNT1UwTeG5G/0C9aTajMeisx4RsAcZGea/Lv4wfG7wdbaFp+sXvieB/EcPmLJaW8vmllaQlQp GRnHOenJ+tXXxcafvWtFrR9P6TNY4WVRLk1udL8Pf25fAvi7wquh6pJHo2sRxeQ000LEXSqAAxYA 4Y4BK9eTg84qvc/tJeD4hK1t4z8wrnIjtGyOPU+/fHevGjmrjem7adTolgHFWabZlSftY+GbTyYv 7dnlVXPmbYvvA4ODwPWmH9s74YJJEuoaVPdMCSDKPvjuCp/zxTnmcX8MvuFDAVX8MP61Od8Tftk/ BTV9NmsovBMkR27gYnCgH2OeO9fMniH9pH4dOZmsdMlG187XmBC9OM5/zjFT/aPMrJX+RtHA1t2k jzm7/aR0XbILXTAzjjLFjnrz/n86z9M/aUaDL2mj/amQlmVnY4XjoBxwSPWojWqymm46DlgWo25k bc37Qtpf273d1os8d1nzNiHcAcrwATnGT39z61xrftBT291E66XeyRod21OOe2AB68/1rom63LzN 2XS5msDUs0zXtf2o/FFrMs9p4JllhLKxSRsHqeOeBk4Br2Wz/bs+OMVslvp/w7sUjA2AyHBxgYJ9 +54rkqSi7c9RfI6FgNmctdftV/tH3c8lxa2Gn2wYl8lS3zEn1yRjn24qp/w1H+1B/wBBPTf++P8A 7Gsp1sPfdmiwMH8TP2P+M3xR8F+BPhLptsfDSDxqR5Fuz8rIANu8BucDrjg5r8A/i3431LxZ4nvJ 76/M2tT3G+ZtwwfUnH45r1uI5uWPhhklaKuycpptwnVvu7I9D+HU2oWFptghG84wQn3scY5H8/ev aknvri3iN5cOgySw3fdx90e4P1r4Gvy/WJu99T6VRtFWK0CRSZjuLhVz1l3e/bP+cGrVrbadYIka 3hllGWDAbjnGMc4/z+mDe8YopRTdyKe9Xf5UlszwMTkSthWA9e/b9K2dGuRbqx03SoFdjsL43kdM 8nj8eKJzkouPNZP7vvNIwTep0SSXbFJr8OuWIxkH2yB6de3b8a247ZkMYhPmyqM4A5PHY9B9a4py tqtu50xjpc6yyt5Li3huJ42jBBJHynYfbHSpbmC9hSeeyk8yXGAh4yp9jXM2nJQlsatJaJHaQeGx f26SNYt9paLJBBwW/Cug03wTMrNvRF3fwkDI6dD+fFZSqNPkvoWmorU0x4Jt4JyZr0DnleBj8Pwr s7HRNAtIkaS43Ovyn5icY+nTvTlNzUVYm9m+VbnS2t5p0c6i1iDyZBG1QSSOv1r9kPjLqmm+Mf2L PBCeG5Fu/FU+j+Hop9PtgHnjmt0WN2CD5iDl84/xr6/h+hWq5bj6KV3NJL11PGzRqNXCSk9OdHwF oH7KPx+8d2djHZeA9QGmM/mK1wPKjGeNxD46gDoPSv05/ZH+D3in9l/w/wCMLj4hatpmn3+r3Fks C3GoRbAkSXIckMcZHmjHvx3r3+H+HsTl9SWIxUrXXKorV62OXN8fhXhqlCE7ylb8GjltE/4J7fDr xRrWoeKtf+LIuhf3El2U00Q4fzHLgbiWz97qMdq+pfB//BPj9m6xQBtFuL+5wQr3d3IeT3CqQBX1 +WcJ4WEnWp0LvduX+X/APIxPElRQVOilFJW7s2/h9+yzd/C3xJLqVr8GdM1vSPLKJLb6lE90vzAj EdyiIOM9HFfZen2vw2vNOttP8Y/B/U7EYxtutB+0rH/20tRKo+u6vuKWUq16WJhKdvhk+T5e97r+ 8+eeOraezbSXZnc6R8CvhJrtt9v8O2zRW+4rmBpECt3Gx+AR9K6vT/gV4Ysg6yXc8sZ5AIjBU/UL z+VeFXwmFjWarYdc6euun4fodtPNMTy2lr67nW2Hwy8Kaed0dmzNjB3uefyxXn/xu8c/DD9nP4Ue OvjL41WKLw/oVhJdOjMge8mOEgtoQ5AaaeZ4oI06tJIijk1UPZ8yjCnGN/Lb5vX8Tnq4rEVL+/b0 P4bv23f225LLWNd+P/x/uBd+NNSZz4e8KQyn7No9vz5UESHjIBw8xG5yCeBhR/Ox8Yf+ChX7Q3xT 1i7TSPFUuh6GzHyrTSyIii9gX+8TXkexhia05Nfu4tpLu76tnPUqS0Td2tLnzXJ8dPjdBcC8T4q+ IFmBLKy6ncqQfXIYYOfTHevrX4K/8FNf2pPhhc2sOq+MF8S+H1dTJZ62BK2wdluB+8QnkZJOOuK2 lg6ElZR5X3W5kqkos/rm/wCCfH/BQ74b/tE+FLa20fVWAgWOPUdGu3VrvRJG/iAHMkJOcMODg4ww K1+hXxf+APhj42+G7nRtSt0W42eZp+pRBWe2kIyrKf4kPGV6Efga82hUrZfjoYmk7ShJP7n+TX5n orlxFBwls1Y/FfW9E+KPwQ8R+IfDSWs6a3pUxEluCcToBuWRD/EjrhgfQ4PIOP2U/wCCdv7dHiDQ rP8AsPxhpF9c+F7h2M3lqWazmGFY7Ox4wQPT2r9px2WxzDCUcdhrKliYX/wzWv5/qfI06ssPVnTf xU3Z+a6fgf0Q+Htf0vxToml+INGuRLpd5Cs8LjjKn1HYjoR2IIrar84qU5Uqkqc1rFtP1Wh9DCSn FTWz1CioKCigApMgd6AKFzqlhag+ddIp9Nwry/VLyx1LxlpGsWWrW0f2OJ7a4ZpFDmCUq7AHB4LR LkcZxnPAq4VYUbzm7KzX3kNc+i2Pk/8AaC/aK8KfDnxHLp9rcrPqqRHa8bK8bqw3bXweqsFIB6e2 a/OP4hfH678b2mqeGhqUNvoUVqzW8ZO4NMQELux5J2bgB6tzxUVcySjyqWnqJUHfY+a/GXxmg8Qw 2F7q+vbdXiS3tZXUklo4EWJXx1Y4XBJPPXr1+avjX468P+LLFWj1EiMLIBaQwHFrccSeYCuSyElx tOCCxxXlYnNaFG0pzWnn2OujhKlV8sYnzR4C/aB1rwkbe11rwAmp21mGWxW5m2iEs28sFfg9xgjo e1fW/wCzx+0/4gvv2m/2d7yHwhpthbXPjnRNPmCyRDyYLq/t4JCpAOMJIcHIHHOBXz1LPYyxPIvh ctPvPWllE6dJuVTW36H9JHjv9pT4gaRrNxP4S8D2l9psEUcTrc6ksDGZt258cgonyk9GPzADpn8p fGem/tG6prWuazo114ct47zJHkySP5KeYJVQLsPCkfLk+3Svtq+KoRounTqb26dUmv1PGjh25XlK y0/zPnXXfCnxdv8AUzfeNPH+iQxjdG+X+WINuBwnyjBDHjjlq+NP2mNV0DT/AAToPgePxTaatrya tFc25sGONNtIo7kyIRubIdpYwPQR4FfM1I0Wv3T2d/69djrlPo530sfn9/wTD/a18M/Ez9rnxt4N 0ayurWGPQbuPzrjhbp0mhZDjqCQJePfrX9E+r6zNm1kWQru5ATBJ/GuepSnRxFSjPdW/Ixi+aDaN CDxGtldT3kl0/wBpCkjGQGYgkfTnH59a6vwn48l1OOaz1S7/AHxUbWY98njPesZc172NHyjdY8M+ FfHXh7WPAfjrTra/8PagDG0FwAQyHOcf3WHUV/NT+3h/wTk8a/AvV7/xx8H9LbV/hc7s+xlEk+mM zAhZAfvIM/K3HAAPrWjjTxVKeDnK3WL7Pt89vU9HL6vLU9nN6S/M/Lj/AIRbx2fmktUtwq4cYVWB 74x1/Gnnwb41MBX7VtYAHaHxj1PA/DvwfavlZU6UJNSV7bnu2hrrqZ3/AArPxdcpiTWAJT8u1Nz5 57dOR+FNh+A/iS835uruXuPJt3JGRxz1I/nmumnovcotmUradDpNN/Zp190d4dI1SaZlPDQH5uvJ JH9cc10dt+yX4vnH7vwrdNuwP3kqKckDqCw9fp/KtlTxUpXUVG5m69FaSkbtp+xv4wdyf7EtoF2n /W3C474zjP8Ak89K/Yr/AIJK/wDBJP4a/tP/ABN+Ieg/Gbx5DpiaVo0d7Z6RpUKS3OrxPL5U8okk AWKOAtbgnDMzXUeMBTn2MmVPD5rhK+Nh7WmpJyg20pdk2tbN2vbW3VbnHWx1GEHKCu0fsEf+CFP7 D3hr4C/GrxFcfEW5ufGWkT6tAdSS/tTa6VLbyObaGWJU3LKYfs7MpfOZhtBUrn+Y7W/2UPB2naxf 258USNbJJhTFGg4GfXPHT/6wr7zjCnl2MyilPC4GOHdKrOmuW95Rtze/du8ot6tJKzStoZxzBtP3 LO7+7zFh/Z7+GtkwM2pXDkLnO9eefYdTx+Vb0Pwu+E2mqALKViG3ZaZiT9fWvzJYOnF3aFLF1ZKy RbbQvhfY8R+HbdzxzIpbA5+ufypv2P4Zf9Czpv8A34/+xqnQpJL3TCVWq22z5W/af/axj+NPiqa7 8HWcsOhRqYrMPGQdvQMVPQn+tfLHg7wxqWu6k0j2TtKzB5ZmxwOp47A+lc2a4qM61fEzlq3+HRHs Zbh3SpQpy6K7+ep9Q6T4T1lRCv8Aqk2ll6ADHUfX/PevTLLR7FYY1vpizkDPr6/5/GvjZVE3dLU9 vsgNho1u6/KGzwvPPPUduw5q0NV0uwG63tcsigFlXhjn1P5cY6VlzzndMuzeiOWuUTVrm4CWG2Eu pCgdTjPT8en1xWrZQX1rNb28Ns253IQO4QlcEnjHNOUnKKg5FwVtz0q08LaxdKrB13hdqkgnacdT 69q6e28N/YJ9t/feWSdzEugwuMY/Lt6/SuGVRSbikdCtqjqre78KWY+zyTmYqeCMsDng9v8AOK0P +Ey8NWQVLXTmZgxw3HGP/wBY59qzjQrVJJQW5evoJL8RjGMRwoATjLHrjH0/Srtt8R7QxFZb1lkP JVEA3H69+OPwr0sPkWLqq/Jp5nPPEUabs3d+RVn8TwXZiP2YyyK4dN8nKkd/1IqP/hItZm3LBbAA nshYgnHr7H+VezQyKnTsq8r27aWOOeOcm1BWue/fs4fEbUvh38TrTxH4g8Br4ksHtZbQ6XcbQN77 SsiZUjcpXoezMO+R+v8A4C/Zu+OXjH4xeIvif4Mu7DwD4k0u1TUV0TWBbXdjcRSQqji3EEm2RCr+ aWVgMtwTyK/XuDcjw9bCupUXLQipL3fibfVd7XV/I+SzrEvni5VVf+Xr8j6AufCv7eJjMtrN4b1y zAYg2F5LYF8cfKpWTn2zVrTPg1+0f8QZE0vx78EUuVwWAuNXsbiLdgH5RMyHJ7ZUZIx2r72hk+W4 KTkq8YqP8yd19yb+5Hzkq6qaqX3noPhD9j+wlOpG+8P/APCOX9o3+kxWlzLayRDAYsv2ZwmMHtnv X3r8Ov2cfB3hl9O1K2+MPiK+t40TzrS41G3lhkc8/MXiaVR1GPMB963xeZRwdFww+GhWctHOSel1 o48rj3+1deRjFwc3GZ9KpB4S8OxyNlAAf4mMhXjPv/k06/8AHfhPSUgN5qcaLJnaB8zEgBsbVy2S DwAK+SlSxeJanJbmvNTi+5l2XxU8FX32pbbVQZrd/LuI2VlMLeh3AfmM1k618WNOs9Fvtc0y2aex tLiOK5dcNtRjyQAc+mCcDJA61awFSE7YhqKEq/NFOC3OA8XftA6fpFpcvplzZTMUDRF7pUyD9Twf ryD2r8Rf+ChHhn44/tPj4GnwxAuoeGvDOuT6nqumG/A/tBmtnht5U3EpuichirEDbJIQcgAxUq5b h6MoOsueS062dn+pdONWbuz+Mf8A4KGfsp/ttXvxN17xl8Ufg/q0HhkS+TYTwhJ7SOIk7RvjYqpO P4sH2r8nvFvgrxH4TmtbOfQ7qO8c7vPaIlAu5lIJ6Z4B69DXB9XVGlTVGanFrdd+vzHKLUrSWpW/ soXWFDqZFXkk4J68/XnPpVKXQbmEGPeGzghfQ4yOB+X40lcjlurntX7Nvxd+If7Pfxc8LfFH4eX5 j1OxmUXFuWIi1G2JXzrabHVHUY6Eg7WGGUEf6NX7AHx88KftEfDPw3faTfedp97YJf6XJJgP5eSk 9s47SQyBkK5OMMOiVwY+i3GNZen9fidOGmk3C56x+1d+zhaa1B4e+L2lWeNS0XNprAjjybnTJVZS 59TC7iTPOE80Y5GPLJvhHN4Rn8M6/wCGFtrLTbuFIdUkEZIgu1+USckk+agDntu3Djiv1XhjGe24 WWEqPWlN29Gub/gI8DMKXLmcZLapGz9V/wACx+yvwP1mz8M/DTQNI1HVxNPaswdtmwAOxbgemWJr 6Ptbq3vYI7m1mV4GGVZSCDXxuZ05fWatZK0ZSb+93PSwrtH2b3SRU1K/k09YphAZIi6owXqueAff nA/GrSXCzwCW3YHI+Xdnr71xOHuRnfc3UnzOL+R8u/Er4/8Aiz4eatHpV18OLiXL8TxSBopE5wyt jB6cjqPrXhPib9sr4k6TpU2pWvw1gChsKJboAnnGT1x614eZ53hstxP1eVNvqn0aex7uGyOtiaca qrxSltZX+R4f4l/b4+LSaF9tg8KWNteBlEipcO+wFgvHy4PWuNf9uL4xxCG6uHsWWRQ2wocdj/Ea 8TEcSV6lGM8PTtdtfcejS4cpRm41arbSTPOPGv7dfxgurZhYXWmwShcp+6j44yCTj/8AXXzI37b3 xSl0PW9I8aeHtE1u4vLgSpdTTXUZtY1VVWNVgZQ3Oc54IOORwPLhnGLc3XqPm02toehHI8OoKNOb TvvufKfiv4tPql+2o2PhfTdILxrBINKtHVnwFBZncs0jMVDFmJIOeeufIdW8faw8LPPLcOR8pLOV GTkjj8zXDXxeNxtV1XNR8kdEcvwtGNuXmfd7s8S1LxPqqXbyCJjE/bzPlXJH+PrVWxg8beIL/wCy 6BbPNPM21QoZzn2A/H/PNZYTAYjMcZSwlO86lSSjFLdtuyS82b8lGK0VvJHazfsw/HDU4vtB8IX0 13t3HdaueBznGP8A63SvCdR074keBvEVtdW+oyWWr2Nwk0O0COSCWNgysCMFSGGQfUCvss+4Dzrh zBQx2PoctNtRupRlZvVX5W7Xs7XtewTjyq1WDSemuh7beftYfH7xHZXWm+KvG+szs4A+0Wd1LDIo 9Pl747jFYUfjnX722ns7zWPEtxblgxaeS9dxwF4JJ7j1/iJ71xYXMKsqajUpNtW1tv6nyWNytQnz UGuXtcyItI0u+Dvf6H4huJGjXc8krKHJHOcsMYrjda8NaXYajpM2m6VdWMEUUjmO7uhIzA7sEfMx /j6Z9OOK762L56DjKny+fmefLCzp+85p+S/qxjfBvwv4R8FfG74eeNvDL6TDPc+IXstUWweLzlnn hdNtwqZZTmVTz/jX71WMunqIUvFdQ0QQPjO1s9eegrklVdWpz3u7a/JsULJ6HN+JZ7jw6RPE4kSW LKngkrwCT+PeuG0zxNd3MjLACrDn5OMc/p/+s1E7NXT3NowXU9Y0PWpb1rcXLsQCCSSQVOeMfh71 9B2uljXLSW0vLH7Zp08KiWKSMMroUAKsCOQf8KxTd13RWqaZ8J/tBf8ABMvw+lvrnxI+FPgeC70m K3bUb7S85nt1BUO0KH765YHYOQM49K/K690LwDojyWp8MWEE0TYZXgjBVhwc5HXt+dd9SjSnRjjE rX0l5O36m08RWlqpmbN4k8J2DMYo7CMhc/KYxgdulZs3xL8NW+U/tOyXIwyhlHHbpXJLE4eP2tTL 95Ud5NmDN8afDlu0udehzndhNxx7cDoOea5i/wD2gPCEbf8AIaBYccKST+f0rnljaKdojVKo7Kxy WoftHeEY1Z/7Skdhjcy4HX05579qh0r9sLT/AAbdHWvDfiW8sdTQMI7uzu/IkQMCrAOjAgFSVPPI JBrKWOTsqcb2sX7CafvWOJ179vCyQXm/xBO0s4/e7r45l6gbuu7qcZ9a8C1n9urQIXdoliebkDMx JP8AKut18wxUWmm9W9e73fzE1CPxTSL938c/i7eIk+leBlEcg3KZHxkHv1I7/oa5e8+Jn7QF4zGL SLOBASQGfPX6Z6fUV57r4dP95X+SR1rC1HrBWOKutd/aI1FFM+tWNsrHohypU8EdPp+VUc/Hb/ob LKpeMy1aS5357fqV9UrPXnS+87XSfDOkW6COG0LOQcZUDgAYPbgY/X2r0vR7eexsnuLDTWS3CCRn 2HIzjkjr3NfLYmtUqpxmz6SFNQ17HUwWuvXq2pWQiAnJbP3lIGPc89q3bPSLu1S4nF3mdvmCt90c Zxn0xnmvPlJK0UdMOppF9HjhUXV9H5rKC6BxnI9MH3xUMWo+H41WK0jkmyeVCMc9uQ3PbrVQoYip K0Iuxem/QtQy3b7X03QXIY/xDB57+w9q1ILXxVdSxST20EPlndG5+ZgOnp0r0KOTYmr701ZGcq9K m/eevkdKttrUyKl3rM5OQSseQMenBHv+VTi3twTJKsksnQmVjnI/zxXqUOH6Efid35HLLH9KcfvJ S9r5kVsjQiR3KKu4DJ7f596q6q9vp0iwahcujN86hewyODjgfjjmvpMDkU5RUsPQsl1Z5uIzSnF2 rVteyOB1T4heGdH1R9Lmila6UKGxHnAYBh9eDnv19q0E8eW1y4/szQJ5FI5BQ5J46Yz+H4fj5eKr 18NVlQS1Ta8tDsoU/bxjUjtJX+R6t4NOteJlAg8LeWA5VXmQgcHBX06/hXtmn/DjxrqyweW8Fo2F CeSSpXGOhXv1xzXi1sRXnO9Wo9Oi2PSp0aEN1dnt/hv4aeKfDV7p+vatqzSWqZ8zzC6ksQQCH6gg 4IPr2INfsZ+y9+0L4UHh+PT/AB5rbQ69ptxaW9jeNKHVLdwyKh3HbDEjfedsRxhgWYAZH6HwJxK8 PTrZNJ+8/ehd6ea+658zxLlkazjj6EdI6Ssvuf6HoXi79v8As9OuwNE8KzzWU7kW32eFFw2MEP5T EROOAUyRjBBKMprzfVf27vidaRSNb6TL5bcLJcOEeP8A2SeM+x46D619/HM8O0vaVU2/O/qfHPA1 3duLS72KsP8AwUN1zT76K71/XNOaK4t2hu4xIxmeLgBeMgMATg46cEHg1zGj/wDBR+38G3GqXWky NdC4G5o5HZA2FCq5IzhsgZAAU8cdS3RPMsHh6Vqj0lbs3p5Ix+rVKkvc3SfoN8U/8FePFHlJ/ZOg qkyxCNnaQybyM5ypAB645z6V8l+JP+ClvxI1Z5rm6SEMsgli2hQyFeQQzZxjsBxz7V5VfN8LTpc2 Gu5vpskdNPBVVJe0sl3PCvFP/BS34561fXS6f4jaCe6lZ5bjzmBdmOSXYcDOSScGuT1X9of4zapZ S6n4s+OU0enzp862987BxncB97B+mOoFdHD+VvPqtavmOMVGlT6Pdryv0DF4ihl1OMYUnOb2tsfP WuftN6fpl1HJH4p1rUbhCzb/AD3Cg/RiPc/y61xGkftreKNN1y2m0rVNTsFWZSLi01GWKUcg/wAB UMOPuk4Pp2P0FfM+E8NTWWQwjrU3o5vdeafluefy5lWk6zkqfaK1v6n67/s9ft4+IfFmnNoPxItb Pxt4BmhAmkNvEdVSNiVlV4Auy9VVIYhAku3IEUhHPzJ+3v8A8EoNC+Ifw8vv2mf2CJo7qKW2OqXX hSyuC0F9Gy72fTyCyh8ZP2cjDZYJg4Q/JZjlsMmxcaSlzYWsk4y7X2fy6+V+x2UK7xVF8ytJaNdU 0fyQ6v8AE20sdRv9H8Z+E4U1KCQwTxXWnossbqdpBdQkikEcjj/DCn1D4Y60yy2lxcWTcFkjmMka 4x/DKN3/AI8cAfnxOFSjUdOfRieuh2fjD4L65pfhHUPEfhzVrS+8MWzr9ruoJBuUlolTyyuQ7Fjt wDnLYwOg/ol/4Ix65+1L+zhr8ngb4n/DfxHonhea8TU/Dn9uaXewPbXSp/pMMzSRjyo7iJcbCVwy MAN8xrvpZTiMwwWJrUleMFd7X01076X2FSqxVWLT8j+674eaj4c+I/hHTdVt0SXR9SteY5NrDDjD xyAZGQcqw55BFfH974aj8K6r4l+F3iAjy7MqbOQ8+ZZvk20uD3QqYz7xknrXr8HVnJ1cG/tR284v /Js5M4i4Qp4iP2JJ/J/0iwfiLpmlRm1num/dN5UqB+3TivV/BPxyt9EkT7A8ht2Gdrfd5rln7aVW eGqbJta+Wh6nJGUFOOzPd1+MNnrum3EUtwI53Q7GGPkYcqcexwar/BX432XjHVtV8KancRDVI3Mi 7SRuyTkAHnggj8qyqYdKnJR6bf18jLl91tntPjLw9p/ibSZ/DmryCN51ZbK72Bmglx8pG7gn27jj 0r8Lf2idR+Ivw18R6h4D8fasyIreZC8FqBHdQn7kkbZXcp5GexUg4IIHyHEWVLGYVYmlBucO38t9 fuf5n0nDONhHnwtd+9F3X9eln958f6l44tpbaa3eeciTjcr5HXI9ea8913xaZ7b7N9id0wEBX7y8 +hwDxn86+aw+Dxs6apU6Gnn+p9DXx1CM3NzSZw66hCsbtJbOd3GJmUY7dic1z9/cW82VBhXn/npk jt6e/wCddCyLHVfjaicU86oR0jJv0OdudJtZg2dTVO52jPPPqQMf1rEm8LeGpsNd6tM5zn5Qq59O Dnsa3p8OU4L97UbOKpnTd+WP3kB8K/DxXDyLPI5GBuuCOvXpjrzX1Z+yR8avht+zL8T4/iAPhzZ6 yn2WWza3vpiXh3lGE0EkiyCGVTGAHCElGkTjeSO7D4Ojl9WNfDK046p3s/v6HHVzDEVoum5WT7H7 K6r/AMFgf2d9OaD7D4N1+S0EbiV5VsoWWTA8tY1ErB1JyCxKFQMhW6V/Pb+0T+0B4M+LHxM8Y/EK Cw0/T/7SvJLsWsUiYgDktjPGT6tjk5PevYqZvGODr4V/8vHG93f4Xf779fXucdGNSlzcktX2ufMF /wDGbw3polMup2gUZ4Qgkep4/KuD1P8AaN8MW3msmrrtwclEYj9B+NeDLFYeGqepqqdWb1/E821P 9qPQkZhHqUrZzjYuOfxI96k0Xx7a+O7OXxKlzlY4nRVlGG+9yeP4cgjrXLVxdOqlTin0/MipSlGF 5bH5R/sRfE6+/wCGgfj1qV1qUgEfiKy8RBQxOGhvJjIQC2OjgHjpjoBiv7OdR8U282j6VYWkA/tO SJTNLgYUgYO33P8AWtsdHlxk0tFb9EY4azi00cTp+na3d3jWEME03mxbNrgsCpOSwz0zgDNeyaL8 MRHd25e6it3K5mQLknOTgVyvW99jqdonrmi+FPD2kXOHiMrgYPmEYz16CvY9I18WscX2UKoA2Ar0 4GB/L9KViX7zPbPCviooljdCbDKMSHP3gwAx9M/0r8Vv+Cl3/BO6X4p6Z4l+NH7NTR2fxBXfPqeg 4Ah1Q7SS9vyBHLk5K/dYjIw3XuwVWhKf1XFP91U0l5dn8vyuVTk4SbSP5QdZ+H/7VVrqE9hqf2ay uYXeOWOQFZI2BPBXOQwx/wDWrCPw4+PsslqLrxbBCkjbMLEW6jPA44+vrWVbK8vo1JR1bRLxFZp9 CCT4I/FK42rcfEaUEnlI4SoHrg7uMZHQev0qna/s2+NdUEnn+N7sKucN6nP19Q3fNONPA0npQM3V qy+0SP8Asp3crKt54yuizAl2ywz6kcnp2+tUbP8AZz8NGK4ludTu53jmaMrlVyq4wTxkn3z/ACrV YmMHanRSMneWrk2UNX/Z58EWkEkskErFSACzld+RkcLx1x09q8xuvhf4VhvI47fSl2pKpZizMPTr k4AJJrojiakk9krMn2cVa5+mx0QWumwt5fyrEDkKCxAXI+v/ANesH+xZbiOKSOA+XKgddwGWHHt0 OemK/NZO7PtEkoxT7Fez8K6rreraXoemac9xqt5OlrawoMvLLIQqqB0yzFR+OK9g/wCGSv2gf+iV 6n/36j/+KrWne2plOtCk7SlY8e03S9ckI+weG2CkcGRduCe+T29vr9K7ax8NeOpIdixQRKy88hiM /wD18/z96KWU1sRbmv8AojvdalBWlI6G2+G+rTssl9rbIOMiIHbjvjn2x+Va0Hwm0qOUSXl/cvGC d26TA/z0Fe1hshowa9rqznlmHKnyR+bNmDwn4K0zJMMbP2Mh3sSD6fSsS+8d+FdLY2trZl2TOVit +mOSc4617lHLowSjSh+B5tbMnrzz+SMC7+KNpL8ljosrDPUvgH6n8Dx71jSeP9fZh9l0uCNMcGR9 w7epA9f/ANddkMudR/vHp2R588ycV7q17nPTeK/Fru32i+VFzgxxgd+oz+NWhrNzcz28d3eO6gIf vEk/XpyB29q9HD4ShSa5YK5wVMXWnpKRrpqdvb3elziAGKGdZWyhJYK+SOee3Hbn8vQ9Q1bSPGOq eZZCSNILRgd20bmUFxyT6HH1Fe5hK3LSlSS1u2cM1eadzj7zSdCXWI5r5YfthjjY7kDNgDHTHtXe eH9S8PWl5bWkNygnK5SAhY94x1GfUZ/Kvx/POZ5liY9py/M/QcsbeDo69F+R1tn4w16PxBp8+ntB b6XF9+CWVP3xH0JxwO1fQXhTx7rVpqsWpXOuQi2f7kC28kqoD7gAZ/8ArV4NTldpJXZ7dOipK+78 j6M0rxd4r8avb+H7Kwm1OOVuLeGwKszdiDknjn+te4x6N4d+DMh1nxxdR6J4iW1nt302G4M93dQz K0bxzxRnYoOMjeQQwRhhgDXt5Fk2NxM/7QU3Tpxb16vS1l8jmzPFYbL8N7KprKe0b6v/ACXmfO/i z9omfUWjj8C+GzbJEcfa7q5eRunUKTsH0welfP8Arvjfxzrdw0l7rM8xJw43EKK+6pYSCjGNONrL 5+rfdnw1bFSq1JOq99bdF6f8E46S21ud1kmduRnPP9PfiliOrWsU28+ZMfuqMny+e5x+n/669COG lypSZxyrRi7oguLO7EUkl67Fv4UViAO1ed+IpYbbdDdrtjxhSvTkev5V1UsKmtFe5y1a7eiZ5qXg lWYrviAzhugOCRxXGapq80SPbCRepORyevf2z+A5rX2bjpsYud3qeX65qynKGELLg/OCvUnqQT68 47/rXBT6ikQcTHYcrkoCMe4+oqZU3qmhqVjqPhd8bNd+Ffimy1fTb6R7SSSPzkR2XC7hhl7B1B3Z HPGM1/Sv+yX+2PofgHxr4Wv7u9dfAPiq7kt/E6bx9ks9UuZU+x38CqNsSXjSNFKowv2kRyKAbqQj 66hhKue8L4ihGN6mF1Xfkab/AAat6NnmTqxweYwbfu1dP+3la33p/gfnX/wcNf8ABMzTrbS3/bp+ AehhbG5lR/G1nZKdkjPgR6giLwN2QJcevmH+Nq/jjlvZhIQ6nI+7gYP0z/8AW718lCo69GnVlvbl frHv8rX8z0aitK/c7Pw3488ReHbjTbjRdcnt7q1ukvLdklYeXMhyrrg4BB5B9a/Yj4Rf8F5f+Cj/ AML/AAjJ4CX45NrHhVrdrNrbxBY218UgYbXj8xlWbBXIwXOOa0hOcfdjJpPsctSjTqNSktVsz+6v /gkl+1zofx++EPgHVbW8jXTPE2lJrOnxiQsLO+XcmoWW443NHNHKvyqATBK38Qr9J/2h/AF74k0K 18a+HLIzeKtJik3wRpmS/syMyxKepcFRIg5yVK4+aryTFvL8xpVpPSMrP01jL9TrxdH6xh5Un9pf 8Mfno9to/irT4NWgZy7qSzqGDgjqrA/dIPBBHBBHarGjR3Gmxxr87KnyqHfkjt0X6V+v1+H8BjKk sSpOMpa6Wad9b9D5SnnmIw0Fh6kL8un3aHZ2fiS8tHQmydosFWCzYwfWua8IyXvhzxdfeJLTeJ5L xZoXMrfuo8sZEKjg7mIIPbaeOa45cMU1dwqpq3VdTZcRUmuWcWj9Om+KnhrxX4Gt4k1e3i13au5J WIMbDqwI5rxn4q+ANA/ay+GOreEZ72GH4naQjzaVf4A84jGA2eTG+FV/7pKt3xXyTy+tgaU6tWm7 U5u/Zwl7rt+flY78LjqUsZTlSnpUVvO62+9XXyP5SfjF8WV+EnjvxJ8PfGltf23iTS7k211atCm9 XXr0bA54x1GD3rwy/wD2r9EheSOO2uSOoaV1RTnnPf8AzivhcyzCODxVTDyjrF/8M16n1UMJUnFT T0OH1b9sHQkjb/j1iVj1n1CNR0z1yuPWvLtY/bZ0WwDOb7TWyMKsMzTu2ATnajFgMDk4OBXkvM8Z WfLQpNt+TNvqcIq9SexnQ/tX3/iC3S50XUoG3xrIGhtZJCARkfKqMR1B6ZGKzpv2h/Fd1JNHBPqb 7DsJi0q6UIRngsYgvv7VhUlm89XBr1sv8jT2eDh9pNmYPi18QNQkijtoNZdGPB+VFB5/vSKeo7D9 KkGtfFK9M+dM1GONRu33U8ChsE9AsjH8/wAulTHB46rrOol83+i/USrYOPw/kYdzqnxFuoY7mGBD ZsgdWa9IDZGVxhG7d6wJtL+IOotJGsEUa7MK0tw0gOMk9FGT2+lP+y5NJyreun+ZLxlJJ8kTz/UP CfxFKTST6hpsNsBuKPbXEmMAcArMoPXPI/GvNLzSfEPmvHe60ixqcGOKz289cfOzEdPX0HvT/suh GN3OTf4fkZyxsn8KGaN8JbyOKe7uPGeoSq7eaV8u33IXC8ZMeQPQAjvX2h8JvDEGn/DeexsdSubr U/KkaIXK/vGVzIQ2cfMpbcAcY+TvVYjD0aShOnC12v63OZ1qlTRvQ/M/9k/9mj4x/Cz4x/ErWPHX ht7Xw7c6ZNaJOZkdLuV5o5UdQrZ2hUfOcfeween9nfgiLw3J8IPhz8TddHmWGpadY3Eahs7nkt4p GDnkjBJGD6HNXj3GpjL03dSW68kmPDpwi7not7440i20ddYtQqpI4t1dRlRtUkDP/As1zUnjWd5b W9hcmJh8x4O30/Qn9a4JN2TfU3vpdnoVj4siW5t2kkQrKCcE/QAjP0/lXeWeusJJUtYyxOMNxjv/ AIdRUtpv3QtrdHS6Bq14LaV3lxsONnPADY/kAa7TVLl/s0sUTnZPAGBzyCCR/UVhzJyfzNFDuflf +1p+zBo/xSe+8Q+HbWK08bxr5hKqAmpYHIb0fjAbvnB9R+GXirSRBc6Vbq4RzMYyTjsre/t+X5j1 HNVaMZvdaP7tH/XYwqFaPRYkk3DBw3JOBnP8u/f0rQW3trWLdGqkYGCO3Pb6f1rGbStrYlWS1OS1 RfPSTZ8qnnJbjnkH1z69K8x0yC0t4rpnmQSfaJRyQCPmOOBx6nPvmobbsuomk1ocn4l1DS1/0Zb+ EyMCcbxlV5G7HTntg9j6GvH7prC2uI0jmV/mQKFA655GSAB6de341vC/K9RbI/QvVbBf7BuCQAUt m5PA+4evt09Ov57ejaI8Wn6VDcwYdLZVZWUg+h4P4/56fnz5rX8z7GTXJG259afsAfDeDxr+1j8O YrmxSW00+OfU5Ay5GY4ikZIPpJJGw9wOelf09f8ACtbT/nyi/wC/a/416eDoxqwlKXp+B4GZO+Is 3skfx8T+B7rSH0qO7u0LXM5gz2B2sc89fu9K6b/hHobQQqszOxGMcDB6njvjNfpNLJ6cLuo72OOr mkpXVONiy2l5ZSHPldQAAMc9fx5qOTSIVgLEEgnJDOTx/n+Vd1PC0qSvCJxyxNWrvLQ5dPB8J1KK S3t1WV8/OTu685+oxn/69cF8RdDhsrWWC3tHGogoPtBhIjnU9QjjoepAPvUVIPoTzXXvHD6ToRii tIprdTOw3KqsclR1zwcZyevpW/daasLSC3GFwCFkjU9uh4qY6aIdys/hy6leEmzi8spkrtQjHA9O Tx0+vFUZ/D8sUhZLPjORiMAE/h9TVLTYTY6DT2lx/owWZFypKkZ6jHPNa2iaUjXt6J4wolALAcDB G1ge3Qc13YJfvuVvozGb0sZ/jPw5d3GsaZO2rtawSWgykXzbsPIAQcZJ2gdemSPesSDw5o9oVdIZ ry84UTSSAAfzz+XavyjP3yZxi4RX25H6LkzvgaFtdEfQHgbwZc6pbhrXTc3joNjnHy546fnX6U/s 5fsneIvCmm2PxR+O/iCLRfhqYmSM3MHm3OpbgSq2kAG52wvD4wNwPIJp8PZKs1xc/rCtShZt/ovN /wDBO/H5jSwGGlWnrLaK6t/1+B7N40+L2laTYz6N8EvDjeHvC5QwPfSMG1XUvlKkySjiFT83yJ2b Gew+RNW0abU2uLzU42G5ixZzlnZjyzE8k5PJ9a/Tfq1OMFGEeWC0iuiPzfEY2viKsq1aV5Pf/JeS OXs/DTzzGCVQlgrZTZ1znj8Pz/x1pPB8DE7Y/RenHbnpTp0knY5ZTctUV7zwg8cIFuhCE/MxHI/H 8frxWI3hcQCSS0LNIw2sc5JHXn8uldMlBpQhu9zK7u79Dn9Y02eGEiSGMx7SW3fePbGR2rxfXdCk mWVWtwluSWz13Z6ivewmAjJJJnFWrSijx7XbRUR7XO2MrhTnj34/z/h4DruoRaZcTrGGOPuqxyOM j6nqa8bF0PY4iUEa0ZqpBS7nC3xm1GF2ikVGGNp2n13YGeeCe3cZrzW8vZo2j89w3Hzdio6fl+Pb npWDg23ZGuz5TJulRJUlRcJt8w/NjH+HuPrX6VfsreJLHxX4A1fwNrdy00dvA9nMEZlZ7S4DBQH/ AIGU7wpX7u1OlfacB1lDNauFltWhKPzWv+Z5OdRX1WNbrCSf6fqf1A/sVePIP2v/ANh27+HHxTtY L7xZY2d74N8SW86nyr2S3L27M6qc+VKoDdfmjf8A2q/zpv24/wBni5/Zg/ac+LPwbkikGl6bqLTa ZJOoWS5024RJ7ORlydrNBLEWXPDMRXwc6UsHjsbgJK3JJ2Xo2v1R7TkqtGFWOzV/v1PkgoXKKsfJ 4Ix19PoKsIkttKVZgJMj8Ov+c1XqZn9T3/Bu/wDta3fh3VPHH7O2o6y0Ws2FwnjTwh5jEqCrJFfW 4JcfLn7LKIFADB7tj/Fn/RI8EeJtP8e+DtA8WaTJ/od9bLOg3AtGxGHRipI3KwZWHYqa5JPlxD/r +tbnUrOkrHi/xC/ZV8IeONSl8Q6Frl94f16d/Mu300xGG8cjBaWJ1Kknuy7Se+a8fuP2H/Ffmxtp vx6vRFnLfatJtZPwG3b+dfZ5fxfjcHRhQqR54x0TvZ26LrseXiMoweJk6k42b3syA/sYfFSAObX4 1afKP4Rc+HifzKXA71On7JfxitACvjXw/cMOebC5h3+v/LVsfrXtU+OqTVquGfyaPNrcN4ef8Oo0 /vHH9nP442MuY9O0W5hx96LU5UY+nDw4/WpdJ8H/ABz8Daxb61ZfD++S9t28yOSGa2uIpsZBRhHI X2sOD8ucH1r0I8Q5HmNOVCtUdPmTTUlpZ+aPOlw/jsNWhiMNUUnFp9tv67nwj/wVz/4J2+Fv2mvA Wnftd+GvBV1a/EWw0yM+KNJAlhnu7ZFA82QR43S2+CjsQd0SqdwEQz/L4nwH+HmniRI/BNuJx8pW UMxIHHO8nPrj3r80zP8AeQo1rRvFezk0lduOzv5xt9x99TqzcFFvTsU7X4V/DzS9WsHg8E6YkjQz Ln7LH8xHlEcY+Y89ecYPpXZzfDrQ7i2iWx0OCGVfmCxxqqnn5jwB2z0rx1Ob0bCV7Js61vDGY7dm SJbsEnCRAAgjbjHXjgA+wrz6w0u4uI9ZhlbN3FfzRuY1C5zGQDx6NjII7Eelc9Vc9Nxj1Vgg0pLy M7wXocl/rVwJdyi3QsOOp3dB+Z59vevWv7GR4553blN2Gzxjbg9fzoi7XQnY8r8H2LXvhbSUitka f7OhJXkIAAc5Oc/jnsa7I+E9YuLfEOmXEkyglPJtnYsCFJxtX0Ofx+lb0qNWtG9NXXkgSb1Rwviv 4ZfEXV9D12007wVqD3htH2+ZAYQMhsYMm3HPGeecV6/8Kf2Z/AfibwvqGp/FmaPT/EP2vbBbyNI2 EVFyxMZ2kM2e/bk8ccmJnPDLT4r2t1sOKtbmR6bqfwF+Cum2YWy1GHzGBMm1LggnORtyc9O1fEWu /tQ618EvGPin4caP8D7LxD4f0+cw2F4bidPkV32g7WHOCqkcj5AcAsc8NSVTFQs58jjqtF6Fq3RF 2P8Aa78QeMrW40yf9kXSbkSIYZI5L28Kybh8wILjdkZHbrX7wfsqePNA1D9k7RtP8V6RFB4mTTpd UuNGnk3RWNvA1xKsCFiSMRSAZPJxz0rH95SdPnq8yv2tYqLTZlyT+HPiH8CNC8RfDrUXg0LXGtdc 05ZRuOySJyig5wmQ6lsntngdOAtNJ8ZaDZXVjrkNzDfQxGdpJOY5FVlH7tsEN94dDjg9cVrKnGpS 5mveTenfXX8SlK8lZno/hvV4b3Q4JJrgvNBOu5i3bBGD/nvX0bpeqrnT5FP7pl2E8dRjA5+pry3N 2s/M6Yw5T0nRpDIuqxb+/UdQCAf5V6HZS21zHpDTTFdwkjdgAQo4IOPrWMrqV1/WhWq2PJfHXhi+ +x6lqenwFrSOEyeZt4Kg4z+ByMdq/mm8TfC641fx3qmlXFzcG7W8lEZjbZsYMVyM8DOcDtzg9c16 8LfVpytpp+TOWexi+M9HtfE3ibWdSs9NSydp2f7JZbktkGeFjToqgDH0riodGgmnuYQpPlgFcscA 5P8APJ+tcOGxCrQbfxR0NsVQ9hUt03JD4S0/7IHayhBAOQFxz68+38+lY0XgzRrO0uL2W1jabBYs yA9PT1z249q6U3zWOS/Q861/wxYLpeqXU2lRfaZEdiNgO0EHgZH0zx1FeMWOkJLNYqVCqZF8sP8A wgMMdvpz+P01k2k7PuCv1P0A1Czgt7Afaot8CRfMmBg8cj+f51Y1mXXb/TLHxxLLJML9pJZZWjA2 zNI5cYCjgOWUdOADzmvjKVDnwVSS3v8Akrs+nq1FDF0aT+0n9/8ASP1A/wCCN/g+4134x/Erxjdo SdP0q001WIwAbqZ5TjA6g2Q/76Ff0m/2G/8Af/U16OV0XPDykl9p/ojxcyUnjJ26W/JH8XHijxDo +qW2jSWcs/2yC+SaQS2rqCmCDzjHAJ/L2qo19ok8jbL/AAynDIwZQRz06Y7fl71+tK29v6seFqkO Go2IIc3cW4dcsMYz/wDqH481ftbqyuncLLE8YY7tjgn8f8/0qZWbH6lm0063S4hlADwpIOd+NrYz g46d66K+0nQ9dimSWVfsyoN6OowDyBkH8hx2rColomaRl1PNT4F0W9gv2htnjaMF4ZosgqV46Hge 69K4mbQp2aa2uJpHSPDRs8LJvOeM9O3f269KzaStdDcntYvWehyyOYyqK6rnaQCW7cfj/nNSzaFL PNhJUYgDC8qQfQAjnt+tNK+grshOiXLy+U9vv+bOCoG0e4/P8aqw6Zb2upP51uIVdFKlv+WnJHHr 1rtwLjGsnN2ViJpvczPGp8LQ3Ojy6gYHYQuquCdqqr5K8cKQGBx/IYrU8I6/4IF3p+j6fafaNWmc RQwQW7SEs3HAA57c9OuTX5tn2WYzFZziJYek3GctH09b9j7XKcVShgaSnUSaX69T9CvA1rpXw7js dTvbKG+8WbA9rZPGPIsifutLg/OwyPk6Zr0bXNa8aeN9Qg1/x34gnvr8gpDG5ylumMBI0HCKBjgA dBX2OQ5fDB4WGHS82+7/AK2Pn83xzxde6fuR0j+r+f5FJNDVxJNcTny156cD/wCvWDd2Fteq8T3B W3AzukHUc5/XHH0r35xjquU8TXdlGHw/atMjRW7i1U4VnJ3SHt6V6DpnheIojTqQoA3t+fAz+HP0 rlqe6rmsWc/rGnW91dtZW7GMB8E+31xz06fWr2n+BdNlhMEahHXl3mkOGP4DrmlTvB83UNHqeQ+O /CE0F2I0MfkMvy7H3ZGAcnnivAPEdt5SSQ4BGGGccH/Oa+hy6vJzhGLPPxMI2k2fL3jER232iU43 A5LDkL0/LGa+aNdsLm6k8xVG0tncR1BOT/LHXt2rmzJRrY5uxnhnyU4q1g0jww88kcUmQgBClQB1 AGeO2MfnRrPw3huMCKHEu0p83fjgYPoO2ecCvRw2VyqUXJRJqYpQqeR5jrPgeS0DLlgu7I54zznB 78/nzXrX7OV5d+FfiMkEvmGHUYXtHQHKK20SKccY5jKjPXf7mtcgp/VM/wALKSs+dL79H+ZONtWw NWK/lf4H9GP/AAS++Kx0P4/ftC/D63ONF1A6JrsIbhXeaCfTHKD0xpMTE56y+tfgL/wcpfDqz8Nf tXeAPH1jbKo1vQ7mzu5V6yz293LMM+6297ax44wsSjtXznFEPY8WYpfzX/JM7cul7TLKTfRL8j+b pZVVgd2ACSAvr07dKnkYTMHkOTkkEE9f8mvNNrH0T+y78dNa/Zw+O/ww+Nnh/cb/AMP6ol3JDGQD d2rZjubfLcDzoJJos9VEmRjAI/1DP+CbX7Yvhz4kWWj+FrbVYZ/CHiexj8QeDrpcoJBJH5s9uVJ+ RiuZhHgEMtwG5wK5MTpOE/Vfr/mdFF3TifsrA4cjkB/bpV1V5Pp6VonpoWtUWVj/ADqcRkE4zQm9 SSeMsKtK8m3g8+9aJ9xCOq3UMtvdQK8DqySRsNyupGCCD1BHGK/kX/4KXfseeIf2efjFca94D8OR t8JdfD3mmTtdECwlyPOtW+UsNjMCpJOUeP5mbfjrhH21Cth79OZesf8AgXLg1fU/JK68NeNrrWLW 5e0soIYncoHMsnmBh2wBg8fTn8a0L5/Huj6VqOoS/wBnLFBGWCxwysX2gdPm6n6c8fj46pNN6mja ex3el+HbnUoY7mTxE63DRbiYbZMJuGTgNk4HHX3+tRQfDYWk17Pba3dG4nPnTMyQbXcqBnGzjtxw O+KlKLV7C2PP/E2hSeFrzQre31O6EN1eywyMj7Wy0Ur4+XgDcq8+5q6uiaSLdxJfXpLc4a6dsdcj hvpmsoxSna1wvbWx92/8Ex/Dng7Tv2tfh3Yf2NDJ9rtdSswHXIXbaTSj5Tkf8s+v+Ff1E3vhXSYY TFa6VbovtEg5A+lF+Wck3poVGT6s/Kb9un9mb4seMr/SfG/ws1ll0OGAQ65pEbKv2gLu8pkJ+Xln G4ErzFHg9Qfxy1nSNb8J6i+jeKdHns9THOy4iZGIz1AOMj/aHB7GufEUKcv3tB6tLmXmtL+lkjVq 69Dm7k2cpG25VQcHg8D8vrivm+/8IeHp59Vv00pTPc3ZmkuCjAl8EOuCSrZ+U568Z78ec5S+FaX3 uDelz1X4W+BNDfUI7yeFFtkYOwZxGCB1+cgheAeSMDGe3PmH7W3xwv8A4WfAvxrqnhGGeG8uIH06 OeGQ4WKRSrFgeeVBUfXNa0Kbr4inT+zdX+RLkowcup98/wDBMyfVfHH7B/wNi8QK4vpNEjjCyRsj xJE8sUfDcjMaowI4IZT3r6F8LeC/iZ4e8S2NjqV7JeeC7i5b7UhkJMeVIDEHjrg8Z9ajmjGFWE/i Tlb72XBXjFo9V1D4RxCO+uNBXHmDmMEAqc5Bx0P6H3qtoNh4m0qyFpqFtJ5sEoI+UgsCCCcd/qM9 64akFOPPHv8AodsJc2+57Domr2y35BIBuYVI7bmxj29P5V01jrG6xto3k/epNtI79CMfp+lccm07 ltN6npXhPxKEsbzSb6NJdKFwy3MTEHMbgjj8DnHqBX48+OfhHpfhfx3+0R4ztzG2g6RcXMdhKwyH km/1RBI7NIp/AV6FOsvqdSnfrG33u5y8v723do/NlbiG0sdRvpiqHeWJYYwDwpJ/GuE0nVIry3vZ rm326oWUtGoJDIN3zDHT6d+v18vK4uftqtutrHoZrb93F7mhcarbTRlks5DGMfMIzzj+nHSuQk8Q Wt1JJY2Fo8iRSkzhcYVhjC5z9Dj6V68Vax5G5wniy9uWtL6KKwZfMjcDLDjg9/rXi+l2t9Be6ZF9 lAAuIhuLk9ZF5/z6irl8LXkwt70V5n3t4itgunLHna0zJG7HJ2gjnrx6V9I/s4eEbL4ofDL4j+CZ oWm1jTJlv7TpzDMhVkHPJDxFifWQc14WXxisvhfbn1+en6nqY+coY1S7JWP1z/4JM/DG88BfD34m alq9oItUuvEUkO7B+aCCGIR5OP8AnpJOMdua/XH7R/00T/x6u3B04UKLp9pS/NnFiZqtXnU7s/k7 Ph2yneUbMkc5AGB06+tRP4PiuVk3WsbEEqAyA7s5Oa/SoPlWp47v0OA8aeCQ+hyyR2SJ5U6tuVAM jcO/4Vp3Xw+geeOT+wYtrIqkmEBnBHcgDPaqim5NLd7FK9rI5S7h8KeE/GuieEbyBLDxrqMlqbS1 m3RG6E8yW8ZIbgAvKACeOCexr33xX+zzr2kW/iHVtbQW81hqz+G75I5FIjuxaW16Eb/eguoXU5zy wOCpFehVyfHU8CsfWg1B7X62aTa9HJBzxvb+un+ZxGk6LLpsjRM6/MOA54k4wcY+lRyaFa/a5YLn To2hZcgwsDsOehBPTnt0ryLalerJv+EQ0e8v4ljlRX2ENFgbjjAHJ5HX9a2T8NJS0DW9pJHBkfvi CFDdvoeaajcbfc72T4S6dNbLDJdgPgMS8gbnGOOo9T1rD8Tfs4eE/F2hy2WtwK8TKBAQ+2QNzkhh gjOM8YyK2tCOxN9bnh13+ydpHg/X7G10WJ761mYMZJ5ebYKPmJPTA5PPNfTmm+Gfh34Q04w+Gbfz vEIVUlvQiqoYjB2cZC+/UiuSpOVnTju/y/4JrF3XObvhTSrNJ7i/u41keMFhu6s3Hf26/hXTRQLd 3ckzY2jPyjjHTpx+HFd1CLgrrZI5qknNmhdxWtxDMDcNDCA2SrbhnsPXrU//AAiqXf2VTBJIABIF VDlmOTzjqenqP1rro4fEVJLkpt/Izdkrs7Kw8IaktzbTvok0jgbooY4nOwehx1+tdDc+BfHOsWj/ ANn+HbvaDt4hYYPTrj0NUskzSvK6w8reg/aU4qzmvvRzo+EXjayME9z4duy6n7vkklsde3+cViav 4f8AFFmzxQaLeQyHqXgYbe4/mfzNdEshzWKtLDyt6E/WKF7Kor+p4T4o0rV7Wab7THPvYENuTp07 H6CvmnxijQpJKAAeec4BY8HHt/8AWrbBYStRrN1abikjHENOnpqfKXjWSO8eYRMrIr4fBHynng/z ryLStNkurgx3JHkbsIc8HaxweM98EN6Nz7406ar4q/mZNWpnpGjeGoLORrjYxkYY56L9OPb6d61L zTIWdCYMgHIPvng+3/6uO9e/g8xjhqsqTV1c5KtFTSOL1Pw5HNEzG2YdVx6e+P6egNchoGh22n+M tFvVG1EkLk5wdwQlSOvcDjHrXpU8NTqZlhcTR2c4/mv1Mp1XSw84vs/yZ+ov7Bfj610T9sizsrIb 7u+8DnzBnjEV8wRiOnytcv65ycEYNfCv/Bzld2snjT9nONADqEr69csRjcE8nRY1GfcxsfSvgeMU 48W1H1d//ST1cqlfLIWXT9Wfyph889vrnvVpZm6bcA85yTmvJR0GhbzEFSR8ucdBx1/xr+hT/gjR +3HqXgvXLP8AZp8U+IntY3vBqvgXUS43adqKN50lqGbIAdh50WQB5quvzGVVrHER5qLa3Wv3f8C5 pSlyzTP9Jv8AZy+K7fGT4TeEfGt/arba7PbKuoQKQVS4QlHKgM2EYqWUE5CsA2GBFfQFvPvOM9Ot Y0ZXhbex0yXLNo00bHQdKtqxH0rTqQyUEHoalVwKtaElhX7H868N/aQ+BPhn9oz4SeJfhn4kjQSX Efn6ddsgZrC9QHyZl74ySrAYJR3XIzmumhU9nVhU6J6+nX8AWh/GL8YvCl/8HfHHiLwF42C2HiHT Llra4t5mUFWB6jB+YEfMGGQRgjIxXhnibxRpX9lahAiNcs0RCrDDIwYkHbyvYnA6/wA6wxVJ0cRO ml1081un92pp2Oi8F+INFt9O0+C2sNQn1ORY4/KjsLh3eQjGwAIAT0AH0FfTHxt+E/jD4Lzxxa94 fuLl5IUM0ungSJayEZMchJBVgSATjaSeCelc0Y2jeXXReold3Phfx5NqniG40ebT/Dd6YrW7Nw7y NCnPlSpwd/JzIO3rWedU1yXZZL4flEox/rJolBGBnBDEn/8AVWTjK99EO6L3w0+Ivxg8N+KdI8Vf CpW0jxjbvL/ZuqR3aGS0d45InZV8tuSjsp4PDEEEZFe83fxx/wCCmXiSJP7d/bC163Zwpma0itIV 3YO7y8Rnah6gHn3r5nO8xoYCrFzXM2tle2ja/M9vK8BDF05TnsnY3NO0P9tDXPDmpeJ9b/bi8czf YT9ujsftllskEL7tjK0JMoyBkA8gcjGa/Unwv478GftA+BtOsvG3h+0n1SFltryOSMF4pAMF4z95 VbqpznBIzkGvOwWbxq4ukqceTmTtvq/maYrAxo0pVIPZ2fz/AOCfNnxm/ZQ8O6JZ3mseA/EBRADI bG8O5cccJIPmGMfxBvqK+FZPC81jpP8Awjevw30GviBby1hjZZLVyC8csrYJ2FxGrA56cEDt7OPk owhXpR1urr9V8jzIRi21e2h4V4p/aJ+Cvw6t/G3gPWPGMtzGthKl7PpzReVsDptV3dScSLvB24IB PzZIr5h8H+O7L9uj4xWHgLR9LWb4J6Li/wBZkZCyanMpAits9CuSC/Ygbf4uJwNSvCrUqyg1GKVv VpWX6iqQj7OMU9X+jP30/Yh+Mnww+IfhH4teFfh/eJczeE/F8mkTy2xUw7PsNi+IyOCiymaLgkZR iK+14CJ08mW2cguzK20/KD0/Tisa8/Z1JxqO0k+v3/qaUotw0NG2hlttzo5AK/MrnHX37c1LBdQX u+O4jSTYdrBSHCnrjI6HkVxxxFKbUac1zeRtyTS5mrHK+INLjmmtZLRCsUQJTkgq2STg/wCORVSR riH7XJb5YHbIEbAIZfmIz0Pb0PtRVSbtsawb0TMO/wDHtzoNzPLGXXzBDNJHt5O11Y8H2BU/Wvzr /b6+PelfDv4dwfD3wuLR/GHjHxNbWllaSysgkaQowkfaM7A5UkjJ+XgHFFKP7xRk/d1b9Ixbf4GU 7xqwlFdf+GPjvw/+yd8YfHV4ZtQ+K2nWmgJ5ZNhBo5O7AJOZGmzyMnp3HPavIdKEOleMviD4G1S5 jbxDo161g5VcJcKv8aA9O2Rzjn8PNyXN8Nj3Vo4ai4KCTd3e93Zvb0OzNMJOjy1qtTmb0/U6O6tU jjd2kVQBwc9h6/nXkugacWXVLwQrHJPcySNk9gMLn0+UL+P4V9EpJRZ49rarYr6xYLK9xbgZZSQA TjjPX3B6/wBK8ys9O8vWdHA4c3USs2e+9ecVU7unJvt+gkryV+59la35TWskLyY8tgxJx1GCOM98 +3613f7I3j5vBXxqtJ5XWLTNRt5tOmZ2+U7gJEJ9fnjVc/7Rr5zLJqeBxEF9l3/J/oeznEOWtCfl +p/ST+zndG3+Gsf2KIRm/uprmVkHBV5GYHPrgrXuu2b/AJ+JPz/+tXs0ZtQuut2eQn2Vz+diwGlS 3Trb30bOy5Uo24lunb86+jPA/wCzd8ZfHkNvdeFvh7f3FkygrN5BSN19QzAcY5/Hiv1TCZfWxMee 3LDu9jztd2fVnh7/AIJefGLxfY3Ft4r1DT9It7hd3zSNNLHnvtTjI44z+VffXwm/4J5fCL4dvb6j r5fXNcSNTG9ygEMRAHKx9Dz65r0qdPB4N81P36nfovTuDklex/JB/wAFPvEtpqP7fnxZ17wvMI7f Q9Ts9M02WDgQNZwQqRGVPybZhK3HTqK/az4m2kniTwf+0NrDaUIdLuF8GfEOwnaVzJcpqEV5o7PL HJFG1vMEsbYPDtKpldrMpFfqfFWD9nwLlk5aNUvvbdCf6M46DvTUnvf87P8AQ+Ab6xWXXfBxvFHk rqQUAn74eKVSCO4yR1/qK98tfBel7Uka0hweGYoCD6/5NfiNHlaafdnc31NO18EeEYr1pn0y3LYI c7Bnnnitx9A0O3smgjtEEarvGScZx6Z9DWk1HkemxLb3Ph7Uf2ivDXhXWb/RdXsbncrgp+9gGFPG CHbGQeMg88cV6r8MvHlr8Z9dt/DXhqy1AQAmeW6WW0MNovQuzLISFwSAMd+leHlCxuY4qOEU05Xd +iSWv4I9PGQwyUa1Km4w5Y3v3SV2n5u7X3H07qnh74cQ2sWgN49tXfO24NsftF3K3U/LGCe3AA9K ydI+HXwzklK2em+MrtsDAg8IaxMW6ggbLYjtn8q/Wsv4XyWhB1cxr3nu9VFLyV9/U+brYvHz0wuH fL3f9I9b0H4PwXsVrb6T8CfiRdsW2lx4R1G3HHAJaeNFwcevf1r03RP2c/ind3q/2V+xr40lizgy 3t1pFqjc8HE14rccH7o712T/ANT8D73NGT85X/JnPGnnFXSTjD7v+Ce2aF+yT+0bdLGzfsv6PbQk 5Eeo+LbOMrgcZ8iGf+tezeFv2SP2gFm36n8J/COnoVVFKeL7m6MeMgnaNPTnn+9XLiOMcvw6dPLb JW6Qf56FRyic3zYuu5PyPQJf2R/jjETNpI8LW1xgKBJcXcy4PXOFU9eff2rYt/2X/jlbWpWZ/DbT Y5FvLdIpb1+YGvIrcaVZrSCv5p2/M1WTYSN/el+B4f43/Zt/bTi06aLwtoHgq8vFlDxTXGo3kOVB GVKhCOmcHPBPft8jeKfg/wD8FJdJGoNJ+y34V1cucK1h4xMZHzA5USwnnCgY469a9PL+NqFNNVrX v5rTt1OevkdKprTqteqv+p8z+PvEH7YHhBBN44/YM8aRLEA0k+iz2Oqx8YOBsdWPIznb/CO4r4t8 Y/tD/s+SX01h8U/A2u+E9UmlINvr3he+tVgYk8CQRsmMj727jI56GvscDxDkeO92tGLT06P/AIKP Kr5PmdBc2GqcyWujs/uZ5q3w4/Zi+K4mufh98RNOuLmUMxSw1WGR4znjMZJK+mGXp9a831P9l640 O4n/ALI1v7RDzIgmTacADowyCR1/A1eI4YyrF3xOWNRlbo7r/gGMM2xdJ+wx0Pws1+hwmo+EfEOh 72uLGQxKPmdMMm3oCCvY8/nXNXM6eWzMucZ3HuDkDj8P881+V5jlePyzEuGJp2u9+jXrsz6PC16G Kp81Gd1+XqcnczgswOThQOBgEgDqOe3Fee3RVdQiuEf5gxIAPTg549ea9vh3Ff7ZQpTWjlH80cma UJPD1JR6Jv8AA+zf2ArSTVP2/vC11O4MTfDqeQsOBhL7fz0wS0WOePbivib/AIOWvEMF98f/AIFa DG2ZLbw5dXrLnlRNMiAj/wABz+Qr47jaX/GZVoLbf74noZSrZRRb3/4LP5nDjJAPPTg89alVlB24 +TPfjHr3rxTp6FuN1wueD1BOevQ11vhrxJqnhvWtK8Q6DqU1nrtldR3lld20jRy2s0bB4pI3HKsr KGDA8YBpeQ15H+iH/wAEWf8AgpNN8bvht8OPEms61b29/p8j+GvH+lGB3e5vGERtL22CYKA/NI3y uu2SSPLOoav6wrWSMpHdRuGgkUEFeQQeQQa83DL2c50n0b/4H4WO6TU1GSNyNt6ZRucda+Q/D/7Q niXVP2lta+BuqWlnYw2MK3Kb0keTUoHjkKNG2VEb7lLEHeAsLjGXUjondK66P8Ni4UlOFSXWKufY 8Tk7gc7hSpOwlCOhx1zWqMOVal5GGShPI/lQ8kiEBce3PX2q0Skr6n49f8FUf2QYviX4Ysf2gfA+ iQv4u0RQuvxJCPMvrBVZVmyPvNDkBsg5j5JAiGf5zrjTI0eRWtwGDEYIHJJGcjHbH611Yj95RpVu vwv1W3/ktgaXUqaJ4o074feKvDHinULbzzp+pWt79mL7FuFilWQx55wrbSpOOh9a+lfjh/wUP+EL eENP8e+LLGf7Tq2oNY3VhAsb/Z5mTzGUtIUVkC8g8ZA6A5FfP5tOpRw8asfhTX39DpwdN1arpx3t +R8AfED4/fArUJjqPhW8S3gfDyW897ZRLzluA02VPt057c1l2S+K/FHhn/hOvC3hW4ufC6xLNHqB u7OO2uRuZWVGkmUsBjJIXbyMMSDjgw2a1cXKFCFP3ravp67eZ01MvjSvKrVSXzep5pfeKfE3g61v oPBttYv46t1t2t7X+1Le4Nqbl2ELzeQzKquBKwB+8IyPccXrI/bevzc3T/FDSIJGZnCppBCxg9Fz vwMDv9a+azdZfWxXJml3Uire67K2/wA3qz3MBTq0aP8Ask7wld3a+X6HQ+DPE3/BQnTNO1Dwzpvx I8KXVteFi4u9Ht55Y9y7T5TMC0fy88HqT64r0/8AZzi/bA+GXxQ0zX/FnxBsdT8KrIYdY01LRYvP jIwGSQMB5iZ3Dr0KkDJrzVismw8oOlGfNDVX6eZvPCYmpTqRc17357n65+N/iNBqHh5ZIb1QzqNu 48H2Nfjp+1T8QRa/DD4so2rlZbVIpIYBKQZEEV00oQZHQhQBnq6d6+6pezxFOnK2j1+8+VleLd1q v80fhd4W+Ltppevw+IR8O9I1SJTua1120S9gk4KpujYFDtG0ZIJGM9a+y/hb/wAFHviF8K7K/wBI 8GfB/wADafptypMkWm+HILNnHB5aHY23gjacjrxXJWwkqnNGVeSXZOyv3HGq0+bsfqL/AMEr/wBs D4ifHz4w/FPwB8QrqOPT5NIh1fR7XToBax2himEVyD5WNwIuLfAbpsOODX7szaTdNBvTVp2O7au6 4fPfI614/wDZ+Hp1qsJR5tV8Tu9Uv1udccXWceZO3yRzpae3lmiuoi6lgxYsW3D8T+OKveHtfggu b+wEawvHISyqMbwcYb8v5VosNSpa04JA61Sfu1Hc9w09NI1CxV5lXs7kcbQeSfcAc1i6l4YtbrJs pdrlCdvTsRSv1lsVF8qWh4j4x0id7aWC8tvMZVZI2Vexzx7d6/nP/bygvo/22v2TtD1COV4IdUtb gSSOQsgCXbrgZ6gxEH12j1NdNGP7jGNPajUf/kpbtKdP/FH80frn8NbqJ7Bxn/SWG8DkHaFC5xx6 9K/AD4oeKr3Rv20vie2i3karP4peyuFnchWR5pRkEewIA9VFfC8Dq9XHc+3In+KPV4gdqUfKS/I+ rLzRNc1Cznit5IQhUF9pPyq7BT1J55/ziqY8MX+mDcZgXYmQ7kbIHHQ/561+gR5XGLb/AKsfNLbQ 4zxNaahbWV7exurSxxtMvy54Cn369PxFcrovh2S4u/DmoT3YBaW3kC9+WUkA9ce+K0lrTkl1T/Ic LSnBLue/+N48Wl0pz5W3APPcrjH6flXOeDtC1/XPHmgaL4U08vr0t1C0G1CVjberozewPJ9s18pk lSMamIhN7q/3f8OfQZzTcoUprpdf19x/Yn8MvClj4K8B+HNKkUbba0RBuHLFV5J9yeetdl/bOn/3 R+Q/xr6SjBulG6vp3PDjBtHs/wAL/wBjL4G/CWewuNB+HthNcR9LuWISy5wRuO/PY9vavq+ysLS0 tore2gSOEZVEVAoAHTGOnFfr+Kxk8RZLSC2itEt/6uePrLckEIwmWB5K/Uj/APVVJ3tvPisWuUF2 6sVQkZcDgkD271zK8rpITWm5/Hp+3L/wSI/azsviT8SPjF4U0q38YaFrOtXutv8A2KWN7AbieSZo 2tGw7FdwH7vfnHbpX6R+CfBmoeNf2bPg7pWv6Re26aj8C9X0DWorhniuBrXh+bSZLXIISQSkW9++ WP8Ayz575/ZeIs4yzO+C8N/Z9T3qXNCVN/HG1CbTt/Leno1dMypx5Icr6W/9Jl+tj4Di+BHh3VIr Gb+0dVM0brMmdRmJjdfm3LnoQQMEc1tH4fX6CWGDx3rAdiQnzxEqSQBnMfI/XPPTivwrkUZNJHTf Q5XWPDev6B4l8OaZN8Q9Veyu/MEzMtqXBVfl2HyumRjnPXsM10l98G/FWoPbX1l8W9Wjt1IMsLR2 2HTHQ7Yhjt+GfrVqClF3X4sNN7Hz94b/AGEP2kv2r/i54T8KfCWTUNN8LW013b+IvEUlxLBZ2ISZ QWcIR50pDOVjXJJUZKAhq/qb/Zs/4Jpfs4fs/eDdK0G60CTxP4hRVe91XxFK1493OFAL7JCUQccK FwM+5rhwWFp5RTlXpf7zWcm31hC7SivOVrvyt3PXr4yTwdPDejf6H3bo3gnwfoNultonhfT7S3UY WO2s4Ywv4Koro0treMfu4EH0UCiVSpN805NvzZ5RKFX+7TqEAUUwCmk9aiTQyI8mqE6B8ktxWVxp XuYN5FcpG2zy2Po4ryTxl4C8DeNLO40zx14B0vUrFwQ8V3ZRTKw9wymnCUoPnpTcZImUXsz8wvjn /wAEdf2CfjIZ72f4LWWiawSXS80PfYPE3XcohKqDk55U8ivyv+Kv/BFn4zfD9rjVP2W/2rdTFrE5 K6N4lKX9tsAI2BpFZhkeij6gnNfTZZxTmOAkv3j9f811+Zx4rCUcTD2deCkvxXofmT8TtA/bh/Zy lkg+O/7NsuteGoMBtf8ACLtOqJk5doSXYevJT8K8Msfjz8FfiQ62FnrMVl4hBMX9najF9jukcsTt w2BIwJIwrN3r9SwPEGWcQUVg8xiuaWi7N/o/6TPlq+WYnL5/WsBPmj17r1XVFbWNGhTd5UhC44J5 yMjjP0/z0ry++sJrfUUEvRSCeQODkA+/rXkvh+vlebYarQ96k6kflqtH/mdv9pQxmCrRm7T5Xouu j2Ps7/gmQkuv/tuePb2Nj5Oh+A7G1AyPl+0XN+5Axzkkr17fjX5Pf8HCvica7+3HpmjxyZGleDrC zYbv43ubybp2O2VOfpX5jxZJz4xxV+lz3MuVsooNdUmfgyQzEEngevcU4k5BQgn/AD/OvONR6Nn0 +uevbH8vzrZ0+KW5mEcOdw6n0HfrxQHkfpf/AME2f2sJP2Vv2g9Fv9W1d4Php4h2aJ4hBbCQI7f6 PeEZA3W8h3b+SsTzgffr/TA/4Jw/tM2vjDwy/wAAvHGvxyeNtGtTdaG80i+ZqujhgoxydzW5dIyc L8jw/eIc1xV5Rp11J6XX5afk19x1UZXg49j9UI/JiAxIoH1r5K+Mvw9gPxK8M/Fnw3GP+Es062Do Iioa7SOaLzYiT/ehZwP92nOrTaspLU3pzak7bNWZ9dQalZSIji4jDYyQXGR9asfb9PJ5u4snj74/ xo9tTT+JfeY2lceL6yBX/S489B84q2lxbzD5JUOD2YHFbQqReqYncfPBa3dtPa3EUcttKhSSNwGV 1YYIIPBBGQRX89Xx0/4JaeMbn4+W8fgjxFHYfBXW7yST7Ylut5ceH0YFvLa3Z45JlDny0KMxC4Zy D17sNUoSUqVeVouzXqnt5XV9e9gVrO58R6x+yN+xf8QfG3h34Y+Af+Cl3hjWfiDealb6a+kWOkRf bIvNlELyCL7Z83lsyl1JUqNxzkBT+BP/AAUo+HFn4F8L+J/grBqE16uh+PNSsby+lhMZmnjtbGME KWJQeWyEKDgGRsZyTWfFNPBU8tjPD0JUpxqUtJSUrp823ux7djtyq1TEzVvsyP5/9K+DfiXVtT1d IDdGGAh+H4VDnk5/zyK3pvD/AI38PWS+Fh4z1uDTIlIFlHqEqQoDlmxGp2g5JOMc8/WvCeNjGpGk oq9r7egfUZ8rlJ6Xf+R+qP8AwTi8L6v4VtfH13Hc3bQanqvhxZXuXMhZUi1fbhjzgNJkDpn617H8 SP8AgoTN4V8a+KfBTaNcXGr6Pe3OnzbLGJk8yF2QkOXGQSp5x0NfAZnluIzbP8VSi+WcVFu7a05Y r9T6ShXpZdl9J1E2m7fi2Y5/by8XSWUeuw+AdQ+yzMqo6RRR4G0HOxXLgdcZGK+gvgf8e/F/xW07 wlqWyfThPrNxZGG4JVnjjs7qTcw3ZxuUMAD/AA47ZrgzDIMVlmFeKrTjKN7aXfRnRhsfQxlb2ME7 2udL4I/ayOs+Mdd+FHiTSTbRwXNxb6fqSXjSpcyRuQpKsMx71B2jJ5wO+a+Tf2utSl1jwl4/gSZg 8sUajaRnPnRnHbqgb8/rX2+VU62GwlChXkpNJNPunrb1Wx8vj5wqYqrKmmo32/M/O3wb4f2LJIIT wFXbgAk/Nxgd8j869Tk+H+m6iskzW32W7kjDKsaZ3nYMfKTxuPOR03ZAwMV0ynaTlf5HIopaNWP0 e/4JweHr/wCFX7TPw58QEk2mpWGoadNLk4CND56gjPOWt1A92z61/UKNY3W4UYGCHGDXn1tMRKfd J/mjek7KxWupo5lt7kxjdnDD8ehqeO3tbqSG9K/vWXyyfX6kd+1Yzl7uhsr3PRtJjimsoCuVbyzG Qp6gZHP6Vh3V3fx3MsUkp8tVYgjPA6/yzXPK3K2zaKucld66sdxb/bOYHIUnGQBxnjH1r+en9vQR 65/wUQ/ZqSC8DRWSI/kbiFTbHejPbBJcd+oFdNCf+zY66/5cVP8A0ktfxKa/vR/M/Sz4bSAaSLgq AN4jDd8fL6dq/nJ8U+Hbr4pftj+OPB+nXcdprOoeP761t9TkzjTpHuZisrKGUsqZDbAeSuB1zXxn AzjGeOk+kV913p/XqenxC1yRVvtL8mfpjr/7OHxR/Z98Ia74z1v4yQeKPDltY+fcW76I9vcPJGjO Y4ZDOwAGwrznOUPy7sDzd/Hdje2Q3yFZGUHBIyPYH8/xFfoFegqFKlVo3UZX0fS1v8z51tSb5Vb/ AIY8/wDE2v2smh640UyE/Y5cMWHyAoRkjB6ew7VgeGddtL0eF7eG8jJ3wqu0HJIYLj2//VXNUqqN Ny8pfkVTjFVIOXc968XSSy6e8kbNhpYtwPTmRfX86/Vv9in4L6DosPw/8XXNuJvEGo2sOoOzICYY WxJGBnoNpT68H0r47KryxT7cr/Q+lzZpUEnvf/M/bydQLK2lum/et8qpnhFwMce3FZ22L/nov/fP /wBavslsj5xPTY/UtM7Uy4z0PHWkldIozJLIqopyxPQD39O1fp1tbJHjmfNqFlGXDX0SlW5yw4we QawtUmlt/E3hr5IzBIJ43faCyfKpUA+hwc10UoSUveTV1L/0lg+lmdPKRGkkjEFV5wBzj0+tfmxp 37e37B3xy8eeGfhxpXjs3fxGvLqXStIjufDWsWzR3V3DLbGPzZrZEjLo7p87AHdjqRXo5VlObZnD E1cqpuXsoNz1StFxknu9bq4pe97qV2flhaxyWV3NZNCRdRyPE8bjmN1Ygj5c9xj61KjhGE5tAkBL SHcwHA69cYweD7j6187KdODvOSRSWised/ENNIXxL4B1qXxDpFj/AGddsbpdQ1C3g2ROmMkOwyQS OMHqT2r7G+GniT9jjQUi174u/H3R5ozHHP8AYNPu4whjclUZptwBBI2gqcZBGc8VjHNMNQjJxfNK 7t21/M1jSlLdH3d4U/4KTf8ABPrwVpcWgeHviroemWELyoltG0afMn3+Ezk9evJNbq/8FV/2OrqX yNF+I8N8+1GBtgWXDnahycDDHge/HXivMeN9tU1d2+5q6VRs+g7r9sD4AaXBcT618TNKRYwWxYSv qeQCVJzZLIOCMMM5XjIGa+TPGP8AwVC8IaX4j1DRvBngq51fS45AsGoFnt0uEIyHEciiRfowB4+l a4uf1dRSmm/J/wBfiOjh51W9LJGHaf8ABSjxfqW9tN+EUT+X80ii6kYqnGDkD8Pau60H/goRq+o3 Jtbr4XRF1UO/lakVIB6cOnP4VyLFVW2kbvCRt8R6/of7bHh29m8jWvBV7ZnIAYS+YGz3GUXNepWn 7UXwtnQST3V3CnUlrYtj8EJP6V0RxMnZSiYzw0lrF3O70P4z/C/xHGsmm+M7Mbm2hLlzbvn02zBT +leiw3VvcxrLbTo8RGQyMGBH1Fae0i3bqYuLjo0KzcHB5qnK2M56CgFsZty4bk9fSuS1NEJWQOQ2 fwNSmDtY5bUiBG7OPlA7V5PrOi6bNA8sNsRNnOVOCT+FT7Rw+HYUoqVk0eb61pGk6raz2+pWKE42 HeAd1flb+1h/wTJ/ZT/aD0++uvFHwxtoNfkB/wCJrpQ+zXKk/wAReLaX9cNuHsc1rQxtXD1FyvQy lSSvOmvU/ny+Ov8AwSz/AGt/2cEuvEP7OfxCHjHwRDlx4d11wZ/KAOUjkJAz6D90DjHPSvgD/hbH ia0sfHafEj4Wav4f8beHbUXF9p13EU84HcAYncDcCyn14xgmv2DhLjNOE8Pj4uShGUk92uVN2fVr TR/efL5rlEar9vhGoybV101drr79T9JP+CGNn4j8c+Kfjz8adbkWF9RkttPNsCMmCBC8C9BkIs5G 7A3HJ9h+Cv8AwWY8TxeLP+Cin7Q9xbzeZb2l3p+mLk5CNBp1okqjtgSiT9RX5FmFeri89rYqrrKU eZ+rsz6enThQwdOlDZafcflicISo7Zzg9OlMZCFHrgnjt0pkChcE4A2g11FlBJb24LuVEgJJwRlf 89aV+gGRLfl596MQq5xjjivp21/bG/aSttb8I+KLH40eILXxBoNpFYaTeWepTW01jFGNihZImVsk cM2SzZ5JrOpSp1LOcb2v+JcZyi7xPTW/4KE/tva9c28OoftbfEe4DuF2N401b5snngTjr/j61/bT /wAE6PjF4o8dftT+HbjWPE99d6L4h0EalFb3N5JNGovdLi1BdqsxCjBz0HU1x1adKlKn7OCWpp7S ck05M/Cj9qH4rfFbwn+0D430TTviBrlvbwC1hMaancxorRwQwy4AbGd8UmenzZ9xXnnhz4s/GXV7 k2lh8Q/ENxethlSHULuSQkeg35HQ+vOD1r1s3w8P7TrQoUlZtbJdUmRQqTdKLbd0j9if+CXGr/GC 7+Pnwt1PxtrOueZqeo2NvYabqN3M8k0cV3BdzTGNmO2NYbeTJbHGV9j/AGjyapaROytAmD/sivVz bCLLMPgsHNJVVCTmlbTmk2k7dbGGGq+3nWqRleN7J+i1t8z4+/bH8Tjwj8MG+JWjLcx3ui3EQmFh dTW0kkM0iRY/dcsRIYjyOAX7E1+eui/8FBdc8QQJY63FKt3b42PJqrExP0zgpk/WvzzO8RWo4qn7 N6Sjqkr9T3MPThUoapXTKHinxJ+zV8bPEOh+MvjD4F0ab4jaY3/Ev8U2Di01uwYQyW4xeQ4kkVEl cLFN5kQJB2ZHHwL+25+wDdfHDxncfF/9nzxlpurSX/jm38XX+gajcJZXUBeSzjljgklf7PLGiwGU 7nhIUbEV2A3ZxzieLoLLsfJ8l4OMn9lRbdu9tfkdFCnHD1ZVH1i1p59T5a/a6+F2ieDf2Utc05/B UGma/He2SzqtkkMytvO4NwD06g9s1+CHwj+H9xP8T/DGu31u5+z69Yzea6BgkcVwpHbGCsWM+5+t dub1PY0aFWCTd0r+QsFCpVdVO9rM/oq+OOl6FFqfgFNNsreKza/jIa3VUziGXb0HIHH4V/Kd8dYp rX9sfx9YqoeOXxZeIYxhhKPPkHOFA569O/OeteZWmnxjmHK9PYxf4R6m1ZSeRYVv+d/nI9M1D4m3 On6te6Ha+G9SeGzm8hpYIcRoy4HBzgduOO3FfpF+y/Gda8K+DLu+W5sZZ9WvUYTpsdM2N9hRnpuE f5Pn0Ax4xtSyKEnq3KP5MWQXnmEvKL/NHzp4w8O+I7ST4oJoFpYNrEGoXcsEhnkEgYGK1iIKg7fm uPMx2K+1cv8AFufWZvCV1pHiPUIpNVWW3imlifKvujDFuB3yCcdccV6uEjCtl9Opd80bf+A2X6nn Vub6xJPbml+Z5N4YufBng3w7rHjHxtMf7LtwBHEjYMrgHJJ645HuSMcd+S8N/tjfBzVPElhouqeG 2stLmlEf2kpt8tWYDcSCSB7nuOcCudYbE1lOrS2jt9xm5xhZPqfs74Vt9F8GeLPhz4j8J33neHY7 +wu45WKhlgMkYmUkcfcLc8dR7mv3g0S/+12FhdKpBeIM3PU4B9K5Kru6c3pdf8H9TaDXQ6pCPKmR mJIw568Z/wA/rVvSLgktGJMbScnPY4GK53tqbrRq56T4fuj9naIgnadx/wBnP/1/51l6vdquq4VM YyhHqp+v14/+tWDtqjdX6HkGvs724KrmSO5CFe5DDHA+v+eK/n+/bE06R/8AgpP8IJZbaSEtp4WG Xb8tztgupZChPRlKgMR/CvvW9NuODx8v+nFTT0RUE3WpJfzR/NH6cfDS5H9kcuP9bkY6ZATn1xX8 4emeOPC3hL9u/XfFPi3U54vDdp4wn1C4EUzR+SySTKnzgHG1wrs3TAPrg/J8C03L+0LL7K/Psejx C/dj/i/Q/TXV/wBt/wCGHx18FfEvwZoEsQ1yDw/e6lCvmXUssvllFCqWjAYEmME7sgMAoPJH45fG H4teIfA/hrwja+HLXf4q1t5TGLpmxbrHy+QDknkAckfjX6VOEatGhQqvSMpX72STPm1L4ras0fhR 8TLD4kaO2m6zG0XjGCNkvIFc7JNm0FgeuDkHHucda9h8I2trbeMPDEcYyTqFsA+c4/eKc8984Iz6 dK8mvD2dGrC+ii7eltDWjKTqQvvez+8/QO/VtYuNG0eFQWvNRs7OLOPlMlxGq8HtyTzX9GH7N3hq NL5ZliA06zgjt7cHkhEUDAwB0VQPwr5fIqabq1GuiX37nv5xL+HBdn+Z9j6nqMzNunHyRxNIwHYt j/EGuY/tqH1b9a+oV3seHe3X8v1PtD4k+Ov2kPCWuaqfD2ieCR4NM+zT7zW9antJJhtDYdQhUMDu 6E5AzgV6v8I/GOveP/A1xceLI9KXxTBNPZ366NdtdWW4fNGYpmVd4MTxljj5X3r/AA1+3YvBZVHL KeMwM6rqpx5+aNoK695Rl1alZLurs8OMnqpPW2xe1JAJ7SQxBo7qAuwLHqyMMYA5+Yj0xnPauovB Y6nD4e1C4kZWQreQMi5+bYQc9eCrmvOqOSVOcfNfg7/ghq2tz5D/AGsf+Ci/7K37G/h+XUvjH8Sb aDXWX/RtEtFNxqFw5UlR5EeWRWxgO+xPVhX8gXx8/wCC2Oq+MPih44+IXwh+BuhQPeXujTafd6tY 7DEdD1GfUdIujbwyHF0puGhmlWbbNGQm1Aq14s8+xOUurHBTalJcrafZp/PVL+mdeFouvPm6L8T4 x8ef8FT/ANtH4iT+IZB46sdEtNQ+0ebbaLoNjCqJPdNdFUnmjluEKSt+7fzi6AABuuflTxX+0F+0 X40uJ7nxP8afE12ss87lJtbu/JVrhh9o2Rq4RBKQPMVFG/gsDivjHJN3leT7vX/gHtQoQilHlPPP tviDW9Qjk1u/nurjOwy3M7uxGAFyWOeBjHsKtnR7i1kJW4OByQme/X2J/wAKunNptMupZRSRpWlg rMsYhwGyMg9B+nPH8uma6e20R4Ct1BNu4BXqNuf5dvTpjtVqdSL31MLJ63O+8LeKviB4aurW/wDC fizUdP1KBjJDLZXssDKeedyEHoSCPw9q+vvAn7a3x/8AB9vY2t5Lp2uabBZi0jg1eyEjIAxZWWWN kl3gnILOwwSMEZB1XvtSkr+fX+tyFo9Nz9sv2Vf2q/2c/jrqdtpnj5G+H3iCaaF421S/36YLcxAO 51BhGsJEgZ9s0caLG4Hmu6Yf9o7L4M+APCD41vxJbTy5P2bymRxPtJBAfrnIIxgflXbBwjBXV30a 6mNTmhsx9h4h+DOj/arO+uHJbj7PcJkDrx9K+cfGXjrQLbU71vD8Yi08N8qADcPUVEpPd6IzvJs8 b1P4kxzrJ5s4lVh+7kA27D1GQOvHasu1+I3irQrpNQ8DeN77T5N+5haX8kasVP8AEMjg+jZHbms+ dxL33PYfDH/BRL40+DLuKy8WwafrWnqTuM8YilZQOAssOAvPdo5D0r7o+Hn7fnwQ8YJYWvibVf7B 1edEOLthJasxGSBOo+UDpmVYunStKddaIzlRurwPrux1vS9dsYdS0jUILqwlG6Ke2lWSN19Qykg/ hVC8kikwAcmt3L3bxZhboclqp3QSL2xiuAupo1jC56fpWM3eJVvePONbVJPNX+8eteaagrjcuPkA x0rKTurGlvePH/E+hWV8VTyArg8kLxj+VfE37SP7OXwp8ceCtWk8ceEzPps1u9pdy2EYS4SCQMrj ggupDYKnrnoRXVh8RVo8vLvt637nLUoqUm0Zv7Hv7Jnwi/Zy+Flro/wmt7k6LdyveLcX2fOO/Pyn IBAB4x044r/Oq/bG8aRfEb9qj9ojx1Z3JlsNW8ba1fW0hOd0Et7M8WD6eWVA9hTjUniMbWrVFZ2t btr/AMAKq5acUfMwQruJPU+/H+PalCruK7SCep9f8/rXWc9uoxMOVbbkdgcV1WrOy6e4QghI0Uew IX+hNAzhA+GHA2nHX/P+cVZWQgrlwR35/wAaPUS8jb0u9mguY548CRDuBA5TbyOnSv7xf+CXN1Ba /Hb9jq5aYG4vfhj4TcqxwQ7eEbeJ8fQ/XqOma4MbZcsvM0hrocp+0P8AsM/FXxX+0r8XL2x/Zsu/ EkTeKdTfS9Vl12CxtXs5LuSaNPLkIZiBMcFQfvexz7z8Ef8AglB+0rq99Z3Ot2fhfwHo77Vnk022 +36gFJ24y4jjQ4Aw25yOuOK/SafEmWYHARdHCw9vypOe7bta+uif9WPNlgsRXqv2mIbp3dorT5N7 n7n/ALKH7Fvwg/Zd3a9o8lxrPxGmhMV7r+qyi4u5M4yEfaBEvy/cjVV5Jxk5r7J1TVJQu5SDIenP Qmvgsbj6uPxMq9Z3lJnrU6UacFTirJbHzB+1S76n+zv8YreU8x6DdXYb+60K+cG59CgNfyseHvjP 4x826tpNXj+zgfM3kbsD/dz7frXy+cUqFV0XV6NpO/ex6NGpUpwap9z0PQ/2hlsftqalrMEl0dqr N9l8pScbQAAxHQJnPXnntXVx/tD+I98tvpHiB7Z0UsoW23gqOvMYyBjnOOnNfPVKWGWMhSnJ8j2f Y9OnGtVw7qQV5LdHsU+jfFf4ox/DmTxvoscMuj6i8l9L4gsLy1t7jSnMfmbzcWwV5IiSYxtbLOFY hRkZN7+z7a+OvHui2vhiDwtcXN1eWQltruZd89vH5oujDJs8sJFBGhCyZBLkr93ZJ9hl31OlQl9Z lGaWmydktvuM4YicPZ0ozcGlL727/kfCOl+O9H1hpNBsPEcF3daZ4kuLe4igvIppLPL3agSorFov 9WRhgDw3XmvhXwb+w14a/aB+N3xE+Mmp/tCaBoFxpXjDVTNo91ChuHNpcI7Dc08fLLJHjAPL98cf K4epBcWYuM760Yx6fyp9f6Z1Yu39k0rr/l5J/wDk0jq/C/we/Za8beL4tLm/aG1fSNQ1jUobYSXX gOPyLd5WCgzSvqqhUU7Sz7cgKTivftB+GyfDK80TwJD4otNWittX1F4dV094nhvRDb6kY5UaORwN wjAIDNjLLzjcceL4pZVJSlrGUeqaa1XQWQ1ISxfLGNrJ/ofj94/+KXxA1T4mfEzQtGuLsWT+I57e Dy2lCrGl1cMABxkMRb8npsHPJz7F460/xJe6JqqeJNNu4Zp/EV49p9ptzEZLVIbJIztOAed3zKSO Rg9z9LhoQo0KcVvyR/I8WpdzbtvKX56Hzz+0F8Ota1n4C61NoNlJNPpupRX15BCuWWzKSq8gUHLB WaMk4OB8xxt4/J6y0bX/ABL4m07w54c0i5vtfvriKzsbO0geWe7mkYJHHEigszsxVQoGSTgV6eXc rwza6N3/AD/I4qyfOkf1Y+DvDGq+Bfhp4b+H2vzg61oPhnTdK1V0dnH9oR2iLdbX53bZEIz34Nfv b8I7m917wJ4f8TSygxahY2upod2cpcRLIM+nysvHboa8Cta0Lef6f5nTTdtD2S1EiI7SuCCCuPQd R71Pp9uY7hZQMgnPc5P+c1xys2zpVtGzrtHuo7e5kjkfgk9RgcYPWsXxFqfk6razAjZIgwc8bgff n0/OsbXbRvdJXOX12QnV/EUIiBby47iDHByPmH8xX4A/te2dzcf8FIvhJc/vpEtdGkkZHJEdszWl yvykdWYOMg9qtJ/UcwS/58VPxSNaHvV6Sf8ANH80fon8NDFLpDMsYzvPQcKdqDkfhX8qHxXsZL34 4fF2Z7gtZPe3yhzEQTmeTLZ7k49+v0r53gFpPHtrX3fzZ38RX9ztzfodl+y/BZWnjLxtKhxJH4Xv Q2xOTueAY49Dt49uK5fxBo48dftVfCDwXgyWVva3btG4O0N5c0hPTnIVfb6HivucVUlDD4qr/LCo /wDyVHzlKP7xL+9Ei8KaXB4X/ak+K2myIIrWKCURLGBgfLYknGOnJOffJ9/p/wAK3dndeN/DHlOx Q30fzlDgDdnHHA6Hv6V585OeDc+9KL/8kR0wj/tc/Kf6n6jfB3wvH4q8feGYg6ssVz50scgyBHH8 xYZ6+gIzgjJI7/0bfs72Mq6Gbp4wLc4Vc8Fs/e4/P86nDZVPLsnwVeo7vEL2it0i9F89Hc6cwxUM TjqkIq3s7R+e/wCqPUNcuprhJXBGbmfYBnGFHp/wE4/4DXO/2Q3v+v8AjWkpJM5rX1P1t8TeEfBf xO0GTw3428M2WreHrlI7g299AksbkcqwBHBB6EcjNaXg3wT4U+H+iWnhrwX4ctNL0CEHy7WziWON CeuABzX65PGYyOFeXOtL2PNzcl9Oa1r27ni2tdlnVtCj1BtKP3FhkU7Y8YG0hh+GVxj0Jr8R/wDg sz/wU20f9hr4WWXwr+F1zBP8fdZs9tpFKrP/AGBp8iTRrfHcjRzMJIfLWEnJyXYFVw3nY7Gyo4WM U9b2Xe7v+guW8uXuz+FDxr4y8ZfE3xBrnjv4i+JrnV/Fl/ctdXN3d3ZuDJI7l2ZHbOFJc/L05rlh Ym3mLp90kEAY6jjp2P618PVqOcm22fR4amqcLLQ6SDT4ihUAmQZxn6k9/eugh0uJraQhc4JIB6d8 nH6/5Ncsr7x3N33QyK1jiuIdqEOCDktnPGSePpWpbfY/Mljn+Ysc45O3jHHHGf61tTu/hMalnoeo +CfD3hK5vwuv3jxWbZ/erglT1yR/nqK9kt/B3woVjHH4lnlPTIiX5enfPrW3PUTShC/mc6cVue4f DzwZ8ErgKl3NJJc4HEzAIW/D+XTGPWvY9X8CeBrXT7i48N+HLGe5AyqMwJOR2G498Vz1a1dStL3V 5FJqzcTw5vGGrQ6ZfWFv4eto4lVoCApDRAkkgE9s547V9G/s2ftrfFf4KJ4a8K+LPEmpa58HNPe4 NvonmwmbRnmj2b7KaVGaONHCSmz3rDIUb7jt5q9VN+zTV7p6+j1s/wCuhkpOTal/Xmfphonx3sfG un6LqBvY57q505L1hFdLKksTllDoflZcFSjI6rIjIyuikYqPUPFhZJohel42UEc52A9Ofb/PSun2 l/dM5KzOLHiCRr+NpmVoU+/Hub5++c+nb2r7e8F6t8KPEHheza4gt4byJDG7TY35yT8w68Z6/Sqi 0oti9D5n8ZR2T+INQs9Gliu9LR28oIOAPbI5x6+2a4uPwhcavMkdnG8bsOFyOvYYOD/nvXPursuL tqeieAPHHxw+BmrfafC2o6glkWO60SQiNjggb43BVsHsQe/TqP0Y+GX7b+o6lNb2HxD8MBb/AIU3 FmSsgzgfPGx2tzySrd+FrSFaUXZhOkprm6n2NZ/Ezw3r2myajp2oJIgALx870GcZKkblHuQB3qhJ dx30S3UaYRxkEMCrA9wRwR9K6G7x5onMk+azRxuqZOQOuOtcRdoCzAk7uuO5rNpjlY5m4sY3cFl5 xtFczqOgWl1E8NxArx5yQRVc70sNQVrnlfxZ1+1+G/wo+InjOVVistC8P6hqjYAAVba3kmPsOEr/ ACjNU0PUrm5uJ2x80jMfMkGWzz/I/wA66MKvfqP0/U5a/RMzk8OXrvsZ48njgk89sYH+cVaXwhfk fvC2cdVic4HOeMf5zXdyvsc/Qk/4Qu9Qlv37YyQPs78/59ParHiLRNQh0hpvs8jRmJWdihxHkqeT 0HTFKz7Bc4qLwr4hmCiDRbpsgMCsDnjHHb3rRg8DeLpGVY/Dl6ccjbaSnt16c0wNbT/BHjJZI1Hh q8H+9bOOCceme4r+17/gmfrgtvih+wvfX90kTxeENBs7jJABaDTzZHLdAF2EEdSAM9K8/Hr3INfz GlNn9Z978Rvhlokk1zdeLdNSbzN8p85GYE4GTjJ6Ac9q53U/jx8I4BO03j2xmkWNpPLE+QFU88Ad efTPpWTrQdjo5Wuh4H4h/b6/Zz8Ggx3fiWaacMUKWVsXG4Y7kr69favlT4tf8Fl/2YPhuT/bGt2k MasUIvNWt4pFYHkGJS7jHHbrWXtJN2hEtq0ddD4e+KX/AAWg8D/G3w54r+Gvw20q3vbTVtNudOnu YRcGNY5YyrMZJFQL8rNxtYnOOOTX4YS/HGz0S51aKx2v5hIy1urbMkgKCxOF6jH1OOtefj8PWrKE Xpu3/XyNaFSKi2uj/Q5y2+LzeJtc0XRdK0QQ2803zu8pYlwoPAABAJBAye/4V1nj/wCIvjXQtL1v V/BWs3Fvd2q7WkhYhvLkiCPgjnlZtuMcjJPAr5/G0uXH4ehUs07X8rux7OGqP6rWnBWa/Q+Z/Fn7 WH7SXiXSrzT/ABL8Udbu9PYL+4kvZfLVgoTcVU7SxQAFupzk5JJq5+z18XPEWmeO4b7xXrepz6PH YTQPHHMX+eQrs2xs6qx4YBsjAJ55r2MXQVPBVaeGVpNNLbdq34nnYOq/rdKVXZNfdc/QbwqfB+he LvEmjeFPDtnYXsmuJe3s9tZpFLqTNbiUyykcsx+0t94k5Dc85r8Bf2jtb8X+HPj98Zv7M1m5s7af X72UmMgGU+cxUjH6H2H0r5ThSvVxGd4qpipOcvZrf1jb7kfQZ9ThTwFKNKNlzt/+lX/E+eG8YeP9 YvEtLbWL6YkKHQSSNgevcgV+8H7Ft5qtl8IPhY+reZM8eq6mH4J3K8OpLkhtudvmE5I7e2a93jiE XkvLHdzX5M8rh1P+0HLpyv8AQ/Nz4oeJ/Fmm/Gj4nSeG/tkItvEV9NE1ojgwqbl9jZUHAwOPXivo T4R+MvF3xB8GSah418TXeo6rHq80KtdStIYo/Kt2AGexYsceua9Z0lHCUKnLq4xV/kebUb+sVFfR Sf5n2b4N8F+KY7Wz1bSYlgvlU7HF1AMg9QylhkHdyDjpXSfDP4eeJdC+JXiJvCngzwnomstpNqZd W0rSdKt7wxTyXSMIp02spfy3D7SdwCFh8oJx5uWE0qjs1qlez162/qxFtj3TUPBGt6Lo8kctin2P 5mmcXkEjuW+8zbWJbcQfWv1D/Yw1ePWvgD4TshJ+/sI7jTmTOdi280kUa8nP+rWPGazxFuSEo66u /wA0/LyHDSdnsfWqRhomLE8Ae3B+n4/lWggZ180ZIjIZgew6flz+tcXY6l5m1qEJtJLG52qvmqG4 I5H/AOoVy+uJCyW0w5KScc9Mj/Gpej0fQ1+KJDfGOTUdL1OdCqvbqhJH3sZQ/XtXyL+0NY6LLo8m rtpcI1RjFH5xQbyA23qecc4rlqt+wqr+61+Gx04RP6xTX95fmea/C9lOj+YCeSCeeMjy+f5V+aX7 afwl0yL4J+Cdf061jTVf7duRcTxRKv2jzkyN+ByMwN6da+U4Mmlmah0k5fhGVvxPWzpXhJW1PgP4 EaNdaV4k8WX1yyOh8NX4O1flGWhyT14zgdeCBznivM/hJN/bn/BRPwdYtKCI7e+hJd8ndHpzqT06 7gTj1H41+j49WyvMJf8ATqe/+Ff5HydC6rU1az5om78R44fD/wC2P8X7YKq+dC6ruP8AesoZSD9f KP4j3r6Q8CWsU2seEp0hwQ6Fduc8KM4PfoTnmvPbvl1PXeiv/SDrkksfJf3/ANT9K/2EdM8fa/8A Ef4p6n4v0yG38L2l1Dp2h+WQTcIxYyuxznJXy+MA8tntX9Jfg4weG/BlmwH7542ZFGOwCD9c4rHB 1JSw1GkqjlCOkbvZW1S8r3LxTc8VUk42d/8Agfkc/qviCS5n+XAWCAsFzyHfp/6EfyrmP7dvf73/ AI//APXrttcy5Wfr78B/GOh+P/hF8JPG/hq+uLjw9qOgW8lvNeoiXDr5aY81VZlWT5WDAMQDnBro f+FqaDH8Rrf4a3Gn3keqyWbXsF0YM2rhWIMYkBO18DdggAg4BzxX7Hi8HV+u4ujO0ZUnUclfT3ZO 6T6+Xf1PFldT5WtW3/megSDXXd/snh15bbY7xTLNCBvAPBV2BBJ4B9euBzX8Rn7Xv/BH7/gq9+1D +0P44+Oni34R2bPqt6Zra3g8VaM8dhDklI442u2KqMn5eeXc8ljnwsRhMJjYKdTFqCir2cZu7elt E1p69fU3oRSq805WS/z/AOAfPp/4IM/8FFy4jl+E1hBCoGTLr+mAHrn7snH4Ul9/wQ8/batZm/tX TfCdkwJybvxTZI2Mc5wTznP5/hXzc8Fg6bXNir+kX/kexHE0bt8xo6P/AMER/wBqzVjdLD4s8BGa PyxIkfiuGYxbyVQt5cbEbmBUEjkj1r6l8D/8EAvjXYXdlf8Axv8AjB4V8O+BBiS4uoJ5rq42AglY o2SMFiN2Du4OOD0rWlhMtjarWnJxXS1r+VxTxMF3+4+Vf2/f2EfhL8BfEXg25/Z48eX+teA7ix+x a1d6skYe01KMEmUNGqqYplOVTGVaJwThlA/OdtQ8EeGrp7eLT476SEFWmZiP3n8RC+nXnPp65rza knKpOUIcqbenZdNTP2vPFSa1HXnj+xvIUs7PQba3iH8SIM557nnjA5znNW9J1m0tC147KUJyDg46 DoT/AJ/LFOPuxte9+pk03JNo09K19DdyuLnaS+4bcYAHPbr2rtdN8Y61bX0Tx3zlVyVIflD2/nWm lRWkiuZJJH1D4b1fSfiJpkME0ccPiLyQpY4C3rgng9s42kH8Owrm7/wvPpty6+QyOpwwIIwMdOPx rlTak6T6ben/AABzjs0dT8NvFt/4P1OaztrqC3sLy5h824uYXf7CVbmQGMGTaV3I6gOGVshC6Rlf 0K0nUJ9c06PUbWFFRp3hEUEokSJ4yBIinJLBc8NkhhypIOa6qUm1b5ETu1qzr08P3l8UMakSBRht pw64/TtnpXZ+H/CWo3N5ar5LuXIGQzDIPGOvTn/x2t1Ba3BLse8+EvhFqN063UdiwhDnDEenqvb8 q+gdJ+CN5dCO5NsG3YK4XBAz+VJRurMey1PavDX7O+oa3sgt7aWWJCN29CTHk8fT8uleq6D+wwNR vbjUtZvktVLj93jO/wBSFAwPxrahhOaV56ImVaNNaH094b/Zk8C6BBAGmne6jIKzI2wocY49Kb42 8DaH4Y0dptJ1CUXKknym2vvz1JHB69SD3zzXTUoRhG0d+xze2cnqj5xuNWiuFbe6iUcHg4z689Kx rnY/JwTXJOMoOzQ78zujImdUXrx1wT6Vyt1qkThyinAPBPFRa60LvZHwV/wUb8YWmg/sM/tZ6k10 F2+A9YgypBJ862ki249Tvx+Nf50UXxC8LxMhlglfB5PkAke3J+ldmDbUajWuq/L/AIJxYhXaPQtK +N/g+G2WJtNnDIeNkSDg/Uj+ua1v+F+eH0jUf2HcumcZKxrwM479c4/pXdGcoyTaMGk0jlrv43eG s/N4fuAgyfmdMg49eh57e/41yPij4x+GLjS7qDUNCnNldwEOqyDcyP8AL+B5Jzng1UqrnuiXDqme N+GPito/hzWp9RW41Ga3VfLjjd84QfdLgsQWAwM8DjoOa9eh/ad8LKg36NeFs5bGzJ9eSeBWDUr3 RaSVmy/p/wC0R4a1PULextdFuY5ZXEQZ3XaMnrknjtX9In7DGvahb+Ff2TPFtuFMkdhdRbnK7VNv q+r2iYUryp8oenT0OB5+YNxpxT/mX6mtJLmPub4jeOPE8F0bSz1KaOGe3GEhcqAAdnAHsoHX+VeO 3fiOTToNX1G71Fnljh82Z3nAbLHb/FgseowuSM9q8+pCSqKMVa56aa5eZnzd4t8dPKmjJaLJJcXU rTwxJHI7XKrkHaFHqp/zzX87v7bfiTUdV/ab+It5qMLGVJbO2ZZWQMPKtIItpCHAA2jA+8Bw3zZr 0sPQlSk3J6tfqcVWakvdP0h/ZY0P+yYbq285SjXE7/I5fEfkcA478E4x3FVtR0TR7WWb7deSFWIk KRxbsYGRwWHfPNc2Kk1NOKv2KoP3X6/odh4R8IW+mazZXdrqKPAkP26PfEC8i/uzgnd8p5PbsecG rvizWJL8appun3eyKeVhICnLrsCjk8DGM9/u18vj3GrjaM+XSNr/ACdz28HLlwtWz3b/ACR8+s1l a3j6Xq9qdx+WSQMSxUn5WUn6ZwOmPUYFX4ReAtZ/4WDq9vcyKLSGBfnCti4+dAGXpu4bJ54Vjx6e vCSp4jlm7wmk18v6X4nDyuVOLjo4uz/zP0WgR7H4wXXlw/LLf2IT3LWtpGcEHJGck49+K/F/9tbR 4P8AhZnifWEiEU03izVrRgFAyqC0lU5GP+fhh7gV8Rwk3HPanZw/JRPps91y9J9Jf5mV8O/BWm+B PA7+IPEFjFL4i11QbeKVcG0sFKsz89GYhWUnuUPG2v0x+EfjT/hHPDHgUzrMlrJdX1xb2kyzyGKK SC5EYeRhgM7O3HOzbgjAFepn8Z43Kq+Kb0lVtBeUE43Xq7+uhw5SlRxkKcekNfWTvb5Hj3in4a6B 4h8LfEnxxeapNawpqVpAkUAjT7UJRJqd0CCpYuIPNZcg8qoxjFR/D3TdNj8KaLDYaRDZW5LmSGG6 +0GWTfLiSU7mUSMnlltm1eBgAgivqqlZvA4elZe6orzem54M1bE1Jd2/kfYngnwJYajocut+KNft 9I8MwgiS+unkYuVA4iRSPMI6HBA4IzkYqLSvH37Emn/EiXSdR+MF3FM+jQxrfOIFjE6zzD5kL5K7 WGF3A/Ma5YzqKE3TpuX/AAHcWm7Z7X4q+Heg6ZZ2/iDwp4nj1zwbI/7u8t5WBjbJIEkRYlDx0JI5 HOTX3T/wT+1UP4X8d6QXUS2mt+czfMB5E8ChU7DPmRyn8T9KzrzVShGpDa6+WjQ4/EfonY3P7uTa CcAgZPf+XFWLKYtE+1hvGS3XGCP61xRerR0bpWLMtw0sMIfPyEc5HUdfftnFV9YdX0+WJiqSL+8U qDwF9f1qqih7rXzLg3Zpnm1543RNPtbUjc1uzru/vDPBr57+Pd1/afgKTVvNPlreJGi4GNpbeBxx njH+RjzcQuSjW5v5X+TOzBXeJpJ91+Z5j8MLhk0kq3XDZ/JT+XFcl4/09f8AhTOg3NyIcw5vGNyy BIy0nVmc4GAT8xPb2r5LhK0czpyfdvz2Z62dLmpyXc/M74qx6hNfeLvGGk6daNodj4Smt5Xsr+yl kuLiWcEFIklMm0qJSXK4BiIxuPP5o/sd6bL8QP2/tCupXceTHql+7wlldMqyL093XPbrX6hmzisk x9VbOlJdvs21PlaStiKK/vL9D1H462V1bftw/ECxhAmvpLwW6NISi/NpEiBmwOMKVbnOduOpr6L8 AXmrxeMPDOlX9nbiBSVeRHJYbYzt6n1AH5/SvIunlNN66UU//JTrmk8ylG/2/wBT+gD9kfwiIPC3 h7bCPMuvMvyQuB80mI+e42Kp/H8a/W5odmk6ZbZ4ht44cj2B3H/vrNYZfDkwtGP92/36lYh8+JqS 82eZX04K3LAD9/KxwAAAq8Dv6/yrE2n/AJ6D9P8AGu6UlF6tGLk1oj6t0+x1ab/gnF4tsP2LfiN/ b2tWcWpS+FL6wiMdxEkt5LP9jEco3JPFFM0KBgDuVCQM1/O5+zH/AMFLv2u/gV488XaD8Q9W1PWP D0kstp5PiG6e8nikdBtmiklJmtXjmBWSA/Iyhvl3EMn6xxS8d/auPVek4SlKpzR3cZuTbV12v6NH kULOc+fey/L/AD7HNf8ADXf7RWofCD9pnx54n+NHiSx1zQILK90ODTNaktona41GO1ZZEBBZdkyn 5QDkdRmvy9uf2/v2odeWGXV/i54gm3qzKZtbvmOdxAIBlOBj+R9q+ZxmLqU6NClSejgm9Fvd/wCR 3UXKUuVO235DtO/aZ+L+rQGfVPEuqXMgABLard/NgY/ic/nx2NfQngb9obw/4a1KPT/ip8LNUvrj yop5o7vXb63+SRBIrHa33WRgwboQQe4ryoY2d2pu3yR1ToyXvKR9/wDg/wDbY+F/w2vPCPxF/Z1+ F2peCviZp2pQpqFxc63c3Wm+INNkx9os7iOZjkMwjkRwAA8KnGQrJ6p8Tf24r74weMVsbjxvLc30 90qC0dmLIu8AhlJAQFXBUjcPkYHb8ueidaeIdOM5XabV9tNHqu6dzmnGXNaW/wCh9afDbR9X1vQb /SLvTPhJ4u0G4l2y+FvHcghvVQAYeNniZMnccOHU9eeK8z+Jf7CH7JfiS31G88f/ALDvjTwbPK26 bWfhnra6vYrnALi3zdxovrwnGa3VWnb2bn6qS0b8n0/AcJuD0f8AkfDvif8A4JUfs6eLJ76H4Eft pWNtrIH7nQ/iBoc+m3KN/dkuLcyDJB5PkL0HTFeFeLP+CTH7Yfg+xll0fwXZeL9EQF0vPB+rWmqq VHPEEbi56djF7VhXpU7e77j89U/n5+Zspxn8Wh8S+LPhP44+HmpHSfHnhjUtF1UHi21fT7ixlPPG FlCt+naqFnazwymRY9zrzw4P/wBeuOTnTsqsbdu3rc0nh72nDVHq2htPpsFpPNvDO7bQoyAeuenH SvqHwP4ttvEUf9h+L4DInl4hvwN0kYAwN+B8w9+v1rkbUpuzt2/rzHO1rMl8Q+A5tPkN5p8i3GmM uY5oTlSAcYI9e36V9n/snaQ3jmx1uxtobYavodiimNZ1t3miMjCG4KMzeYyySi3dwqht9lD991au 3D1L3bdu/wDX9bHOuqZ+lHwy+GFr4v0+zu9B0me8ne4MRxEy+TIpAYMG56kEgjowr7q+H37ImvTW pF9aw2UayrPA2zc5BA3q2eME8jpjmvRVFttPYUpqmvePrjwh+zn4R8OI0l5mQHlldvlB9vSu7k8P fDrTLcW8AtxMvKiHBIP0HFdSpK1luccqsm9DpNDuNKsYdun2RXcBuPGfb+tbU2qkYQKBKRuClgDg EAnn0yPzHrWyjJR5UZN3dzldf1KWK3uC+qhEVC7KSBhRnJOOn1rxzxTr0Fs8qC2knuFdUJ6gE7QM +3I//XVQpa33YPbQ+UvEeoeINZOoxx6CLIwyXELSbNiiWJXcodxAztRzt+98p9DXzxbfFTxFpdvM brS1urcKnl7X2yEscEEcjjk84IwPWufEUudXbsXTdnYTXPFfia50+TV4ZI7SIxM6QyzxxlwMnK7h uye3HU/l8l+Mvi946u9y2EggAGPmk3MT3x279a4Kc6FSUoxd7fc/T/gHRUp1IWctLnwz+2zfeIdZ /Yl/af1HWNYlkkHhuVEtywCkM2WJA64C56etfw8apokLFzHlHznG3r/nP8q9GioqL5Vpf9EcFa99 Ti7nTZrdnJB4PJA/x69f0piTzozpg4BBzj/P+c1o4mV7DLnzPLwygjbz747jiuA1JJjYiRmHlvGC mfZvzHQ0WQJnEPs+8MkHkf5/pTVH8QX5hxxwf8/40ijr/CTpFrthNOmUWVWOB6H/AOtX9W37FV7N ZfDf9mHzoFKi01co4Y5i/wCKk1rcGB5OSx6HuD715+YL93H1X6mtL4kfrXo3wssfHUlxrfijxOum 6LGvlW7l0ElwckswBOVGSPXODisrUPhL+z74d0bxJLY37674rNvIln9tMjw+YwOGkRAqOin5ip6g EZ5zXzeKzLEKu6eGjZLeVvvtc9+jg6bgpVd+iPELnwWkHjn4RaX9lgK6Z4PFnaNKf9ZLJqWnW7Fu flzHesw7ks3IHNfyDftt3Er/ALVvxyZZigbXp42/dJEAAQeFTjqPvdW6sMk19Bl1RVU5Xv7sfzZ5 GKjye6trs/VX9kyN5NV1PTplMdzdz3EsDgY8wPblB0+ZT8r9B0U8jiuXtPFPhl7m8t728hZ1bERn 2tvUAHjI6Zyen5VGJjOd+VGUfhep6B4EuIbe/sNZttVtXW6zaC3Ey7hGXViVjGBkYHHoenNa/wAT rq1tbaPUI5nhnhnmaMjAwwV0XJbgDP6jnNfH45ueZUYuNls79dWj6DApRwNVr+tEfL2vePE1q+ik XRlknQFXkQrhsck9hn8hxXtXwI8RXGs62vhdtItf+Eldpfs2qGUqLS3ESzSxr+8EZD+Tjcy7xsjV SN7BvY9jy+xvL4X+D0f4HBTqtt2Wj/Q+otPvWvvibDcMyyH+07QoMqTEEisk2na2VJKMwzg85xg5 P5r/ABh8MaP42/aA8e6Jrt0yaJpuu3OquDHkzRsQrRqDydywR525OD0718Jkrq4bMsVVpxcnClfT zUbfiz6zMlCphaUJ6Jz6/O50k/jD4Iafe+IbT4w/D7xXqPiRZYba1Xwz4h0uO3slVFKwOj2tx565 YnfGyq3IViATX3t4dt7OPTvCdpd+CNW0AR3DE6V4gtPIvoEezv3QSxsqlSysHLALneMDpX03EtBU OGaFNbwsrrq31Z4+TVva5rVbWjTf5HzmLuXx/pfi34c+F7SO9stL8TnxFrmI1MaJHFcW0cLBsZCo MHBJPlE4pfD+gWeh2hsrOGKG0897mOO2iCRrFIqyRKoGRnYwz0GSe9enh8ROvh405w5WlHT5X/I8 rEQVOs3F3vf5anyT+2R8bfFMmr2fw9sLySDRbC1jmuIYyV3llDomOODlWPqW56V+VGu6jcypc3c8 zNeSybt5Y553HH8q+hwVJQpRt1PPrSu7H6W/8E2f2k/F2nePf+FJ67q0134d1W2nNjFKxfyJY0Mj KM/wlEdvYrx1Nf0sfsM61BpHxD+I3h6S5KRalYWmorH0DyWsxhHuRm7HHbOa8XMKXsqlaEdm4y+9 q/4pm1GXNFX6H6yQMiL5ZOBuPr8vT/69LaXixGeDOAVxkHng/wCR2rytLt+Z2LSwiaj+8bBI+bae PQkce/8AOr+rQXAtrkhlKmNlySBu4OP5CnKz0eg4s+edOtG1W+vrc5Uw/PhujdAR6dq8l+O1+Ivh 7LYxQ4zqUDMPQruB/Pn2rz8X/DxHlF/kd+AX+1UdPtI86+G0jnRJpHIBVGLexC+p9x7VV+Lejf8A CS/BnxL4Jh1D7NqM/haUwXBXP2OUiULJgkDCsFbr2r5XhF8uZ05uN0pHrZwvckfjjb+Ar7wL4R8Q WV94xn1O3m05pHkfVY7lZEWaIsWETbYwoLDGcjJzyDXzX/wSz05NT/bJ1HWpSCLfS7iMkqW5lDtn P1iHXtnFfpefuCyLMXDbkfkfKYb/AHmhf+Zfobf7TMsFl+3v4xZifLGvWiH5TwX09EH/AKHnHv71 9GeD7CVvGugS6YoYyTtEsIJyzFW2444+Zv8AIrxr/wDCRSTf/MPH/wBJZ2VH/wAKs7/z/qf07/s5 6UlnoulfZ4ALa2jitIgB95IkCA9P4goP4+9fZt/rsqxhPK3BYycDuTkY/TP+eNMPHlp0432SX3Ef E3J7s8y8S61Z6RY3+saiRHpWn2k15csTgKkKGSVj7YU/lXz5/wANafA//oPQf9/f/rV6mGwlTExc oq6RXK31P2l/Za+HfifwV4m/ap1LUdE03SdC8QeMZdV0PR9MnjeJYI4Irb7WVQARPdG3Wdk7F8Ek 8l/7Yn7P/wAJPFP7P/7SHi5fhho0nxCufAusmHVBpkH2rz0s5ZInEm0HzBIqMrk5BVTngY/XeIMS q2IrVqM2704Rbejk1ShGTd+8k2fOpv2cZdVFfkfxZftBfCHxRL8KLL4j6TBInhCeWPRdQuIZQqrd PGbqCOVAed4t5ZFOCMW0uSCFz+Rum+H9TnlsdOFoy3MaCJ0GQVcfeXt0IwMelfm1elVpzakuit6O 7X5nr0H77jfb/hz60+GFhY+APE2l33iTRtN1IrFPDJo+pRyywTCaCSLdIInRlZPMEiMHUrJGrA8Y r2f9vn4sax4k0j4WeNPAXwy8O6J4gbTls7tvD+nzqL+GDZGhmjmllXcEU/NGEHzcjAGM6cF7Gmn/ AD+Sunc0r1m7KDsfGd98Q/H3jS30efxXeu1/Fbi3KpCkATyyU5SMBcgjBJGcj2r0v4DNrR+LfhbW hBNJax3QNxNhyIVY4Xeecdcc+lOnFQxS5fh1N6XJ7Bt72Z95/tnaZOfjD4Y1eP4w6f4aSTw3aBYL u7mE0zCa5DSJFAjsygbRvPGRjqK43wP8Vvir4QMUngX9uHRIrpWG2O5vdStlXjoTLFGpIIx19eR2 wVZw5oyg5JN7LTd/1sTCMJU0uXXU928V/t1/HXwroEeo/FL4ufDHxnoaeYmNQ1LSdUlwkUk2FVw8 keVhYBvlwzKMjIr6a/Zy+IGsfHXV0tfhhbeG7LWIIo2uZvBXxDPlWplDGMzKrXcEDEowCsqbtp9O NqUrxbhzKKvo4trz9PwuZSjGL5Ys7fWP24vi/wCA00nwr8RfED32l3enWupwaZ450ey1G0u7K6iS e3lS4iaVJUaNhnEWVZXRtroyjzrUPih+w98SJWtPit+yhoFnqrhWfUfA+oT6NKN2Cr/Z4njQ5BGN 0JBBFRSxkFpGVu63j9z2+75kxqSgrwdvyJdP/Z4/YP8AGLQ/8K4+PuueG9SWQsuneMdOS/t2zkbT LbtbSIO27DHA6E81m3X7BXx9064vNY+Emu+APGlgyZig0XxJ9muJBnj9xf8Ak7Gx2E0mcfgM6mGp VZ8/PyX7K8f81+I3WqXd2eGeLfh3+0h8LHur3xv8H/EOh2zk+Y1xpkz2TcYP75Q0L/UN2rZ+Bvxk 8F+G/iJ4N17XLW4tootRtP7TjtJyn2q1WeKSQxkHCyrtEkYfMZkRN6soYHooYadKrGz5k9L7p3K0 upH9k/wUs/Dnh/wvpep/DjwncT3Gr6ZbatObyZHazuJky8EwDMyzIwZZFJJUqMk17GifFjU2US3F vaQNgr5aAbMdjnJ/WvpY4SEb+0mklokuy/rQ8+rNuo7o1x4L1O4jMmveIncZG/DHH64x1rSt/CXh 7SoJb1YmkSIZZs53KOSRjOcAn8q0jKFNfuo/NmTuy1oPiHRdX86LTx5Uccm1GkUL5wA+YAE5yPfF cx451nwnaR20uqa+Y8PLCzoN23crEA46DIUdeeO+DWc003zDT6HAf8LL8BPbPp62omk+yG3ZmcDz c4AYY5HAyNuMZ9gaxNX8fWWpxhrXSwsh8kfe+8Yjlcjpw2DnFNRV+eUtBrmekUfD3x/+LrWuoXVh qM63FxK63EkfmbI1YKFViFILMFwuT24r4m8Q/F62vitvthgtlIOEAIyCGGSc85xXnybrPm5vd6L/ ADOjmjTXIld9Wefar8U2uZ2tnuw7OMKxbLewGT04AFed+INWh1CCaWC4aOUZ5Pc469f8+lcqw6p2 cUKU3J3kz5N/aFudY1z9mL9pXQozDlPBWu3haSRwvlwWNxNKflBy2xXKjbjcqgkBsj+OO4tYHZt0 owCO/BP07mu6hH4kctd3sYF/p9pgs8iqxBPJHQcEgfmM+3vXLz6bCjl0ceSRjgHjpnNdLSWxz31M +TTxsZkJI9MHGce4rzLUNJvbW2a3u4WRWt3eMSYIZQCcr+VRLoNGDbeDtfvIFuhYMlsRkNJ8vHrg 84/Cp7TwosuUkuzu9l+6cd/UVk5JbHoQwVZpOouVPVX3LegWc+neKNLt2hEjCZNqZIDgsPbIr+q/ 9jjw7pes+A/2dreLWo7bUrW31dYkcFEu9mqajfPEueWkVDOQACPkY9ia4MddqCW1/wBGYxjyVOR7 pn6H399JETBI/AbIDEcf0HrWVYXcstwYLHE11LEwjUMDg9CSc4Ax3Pr7ivmcfop3fzPoqOvKfBfx V+J3iHw34qufBus/bBr1p9pkiCuqrNHKw2/vCeV2lVUYBVQMgFTj+bH9qnVF1z9pT436kMJbT+K9 SlACMhw1zIckMA2fXgc54A4r6XAcqpqcLWcU1+h4WJ5uZqW92frD+yDNLp3iS9vriJyq3LtFvJ2q i2pAK4PQHdjPHtXznOnnXiWEujOl0zFyDu+VeR0x+P4DHWqbtO1+36mcF+7bPo/4baZcNLFdTXDL eW0bP5CgbfLK4H5YbJB54rrfFy2eteDJb5rlhHJAXOcbQWIGAuOpLbejdz2r4rMqn/CnTcY7OK/N n0eBgvqNS7+Lmf5Hi3hj4UnxDfW8QZTbueQQsZHG7BOcEnBwMA8V7j4l+A/xG8F2vhi/0vwK6aPq B3xX099EspWPcHynmbj8xiYAqQAfwr6TCWrVakpbQTfz/wCAefCFOjG83rJpfI+jhq+pP4t8A6fd C3EtnEFCWpAUCa5kuDheoAM2ADngLyB0/Kb47eBfjT8Qfi98Wb/wJokjaDb6xq95vhaGKQJbzt55 VXcM5QSx5HB/eKf4gT8Xw5WoxzmvOq7R9lBer93f7j389jfBUlT35/8AP9TI8OeDPCXi2DTBp/ip bfXbe2VLi31G4At7p1hZnPmBgqnfkDLrkkBU7V94/Cax8Q+FvhjoVl4rhRdaszqjyhLiW4YlbPUp IzumIfJyB82RwQvHT0+K7vKeWSt78Vps/i+ZwZHC2ObTv7r/AEPzT8S+O9bt/id4v0rQdM1MSPql 2bhLTUbhDcfvXJOEfpt54OOTX6O+B7VpvB/hSMK4ZtKtiQ7FyGESZ+ZupyOTXuVKPssPh5WWqV2k k9jy6seWc5OO7du27Phn9uT4Y6vp/i7TfiPbW0jeFfEFjHbm5RQIra9t40iaFyDkNiNJOQMiTjO0 4/MO/wDDmtPLcafLZSLexYLROCGYdQVH8QII6Z65r2sNJSowkuy/DRnnVVabPu7/AIJrfCDxFrvx ivPi7d2EkXgnwhY3T3N1IhWO4vrqCS2t7ZGyMyYmecgA4WA7sb1z/Rx+zjqR0H46fD6W6kREvIZr OUv1ClDNjOecGJSOvIFeRmUuarWa6Rt913+p0UFaCb2uftbFKzFox8xQ9Qck98/r0rNuLyaG9wAN zY6d89BXhN7+Z2eRMu+aaTe4Bb5sEdOn9c/nW3eTgWEXmzZYFdxYABQOn+feru77iv2PCLq6m0/x Fqd2J9tuV3HjHUjI/AV45+0HaT23hm184NsmvoZM56H5sD9a8/He7SrO+8X+R6WX+9iqdv5jz3wN J9m8Jandk5xFKc8DoD/nFT+PdRA1bRtHmTMF14eaHafukGR+P/Hj+Rr5Lhb/AH7m9fwsernGsXbu fzlxRXHg+1+MhmluRcQ6V9mXcFMXzTDpwCGHlkH2Peu0/wCCS2lfav2i9R1NnfzGLxBVPyvttbk5 wfTeD9D2r9M4majk+YyS0cf0PlcJriqCf8xyP7YkkyftpfEO5juZInPiHS1WUE5iJtYF4OeO/evq f9mnT7m++N3gi3Ooy3ZE8k7K8hKExRPJjaeByoGOO1ebGEZ5RhlbejFX+R01moZhWdvtH9ZfwitF 0nR9GtfLwFtAW5J+fOAfr3r1vU4ZLdQzkFV7Z4yo6fiacF7qElsfB37ffxP/AOFb/sq/FPUbe78v UtSgTQLU7jl5Lo4kVfcxLKOK/lf/AOFheJf+fq7/AO/j/wCNfXZLU9hg22vibf5ImpUcGkl+Z/a/ /wAEhfEn7MPhvxJrng3wt4h1Wf44Xsuq6e1xNBeJZeIdKgn8+0ukV12QP5PAjYrINkhKjOT+73if S01nwN4j0G6yY7nT7mydQM7lkjePB49GzX6/4hUsdHOq7x9OMXOCcFG3wWko3t1VrP0ueFK7pXf8 v/D/AI3P5Xfhr4H1zxz+yb+0r4Vs106Twy+l6BdS2l7BKZjdC4nS2kt5EI8vZI6iRSp3xyMMjkN+ Cf7SHjm00bWfCXwst/D9pZ+LPDOjrFfara2kccupQSzTPA0hUfvHjw0ZcjcQoBPSvyHMVJzo8z3h B/JJq39dj0F8Ukt3bX5f19x4d4buNR1DU7XVJtQe8iLBPMZiSgwAFYDpX0X8edY1vwp8N/hnreja RJc3KQ3cSRP8ivuXd98jAxg47k5HtXFFSVBq1lzfdozeXKuVpHyp4TuPEvxCuIdUvUjtpGuLnUro xxQQoltkyOXOzYEwDulIGTljycj1f4UfEnRvFPjLwhYXGpavZTx3qwQabYQwDS5JEZtspYlJ5N4y wZ1ypdlAwAKdOEIVowve21/u36/0yqSctF/wD6j/AOCkt34e0O/+FXjLXPBk+sbfD0gjSHUEtSRD Mr/O3lOWX94TxjGTX5B6X+1hBp9xePpvwE8IXFrGuVi1h9TumxxkFobmEHvzj09BU0oRm5rmslJ9 u76v/Il1p04qKXf82dlB8d/C/jLT9VTWPgL4esr6aBfscuh3OowRwSrIrZngu57pLiPYrKYgYS24 netfXf7KeqeN/wBlvQrnx14Gv9O1Hw74o02Wy+02lu5giuAkcsttLbGWIR3FrLLB5iM7CNJ4nR5Y biNpqrKUadaUasneNun37W3/AOGKpfvGqk/Q7vwP+1T4gm+L2vatqukabpcN99vvbAyaab6HTWvb t5J7RpZHLrE6SOY1OY4i7bIx5zk/P/xj+LfjPRvjXqN98M7e1h0y00GbR5Ly1hAjuUu4bhLld2T5 pKXUse9yWVVXaVMUe3w6WDtJKUnd3T9G9F83qKrfljGK+H8u5wnwu/bK13xFqWpaPr/wllvbW60i cWV1FrUlo1jOJVaC5VvJaOVdyNE8ciOHieVVMchiuIvoX4W/HH42RajP9n1NtKEWFjUXbMx2k54X aBxj8q+gr0YYefJzart6v9DKDnVSlayZ+jPw4/4KD/tLeA3it9I+ItxcwKOYbks4cjHHJx619weG /wBpr4dfGjRNStf2iP2V9PTW5YIxaeJxY6fC8s7lQcywtHdIxJfaAM4RWzzgcqliYyjOjLlV9Xrr 2+fqdHLBRk29enmz9zP+CYvxi8Q/EX4I+LPCujaXbvp3gfxXdeEBLC7L5UcMVteQIfOkJBEF5CpG SMFcAAc/c3iX4u+EtAuJ7PX/ABVDbylikkUEplkVlHQBDtB6ZGfrX18Yq0JN3bjF/fFP0PMq/Gzw 3X/2tPg1pzyJDb32qXLHk3U4jXPPbJ4+orhNf/bWs5YZLZbu1tLb7qwWrbnRQBgM2eBjPTFOcovS Tv5LYk+OPEP7YEfh/U/tkWqFrYy5H+2DweenpXmXin9s0ajf3EdvdGWAfPnJYL1xnnGc9qytzayY m+xF4Q+N+tePdUmfRxPdrZhUka2ToGLbTweOh4OOh96+hj4i+JOu6WmkQXX9k2BUhrkESXUg9F6r H9fmPpjrXnY7GU6EXTj8Vtu2htShKXvXP5xvEuqeJvC3/BR741eHbq81BtDt/CrpaveXc0sl4Xn0 2Uy75SdwyZE68bWH09svPFN27uxuGBHQZ+6P8aMLb6pQb35bv5tifvNvqVU8TT+YFWXzGGOADkd+ oqxeeIr6eJUiciTIA+YHk9OP8f61o7N7DV+pz3jI6lqPwO/aR0+Kwa5vm+Gvin5GYr5ynS7neehy QpPy/wAWMetfxdeILmW11OVhhAOu0AAj6Y54x2oi2pOxjUV7WGpqkMkDEt8xHYA8+/HTr/kVStr+ S6k8lThz36c/19Px966E27HO0bMdheXElvZwWckt3K2yKKJDI8jdAFVfmY+gr3DRv2NP2uPGxsdS 8K/sq/EO/gl2R212vhDVPsoVyQGMzQiNRznczADOcinOlUSV1yru9F+J6WAw8eZ4jEfCtk+rPp/w T/wRQ/4KTeM5rW91D4FQ6fps+GEmp+LPD8JiBwMvD9sM4ODkjyiRjpng/Wvh3/g3E/bW1YRT6j4y 8BadbyBd0cmoavLJGDnOAmn+WxHH/LXHPWuacsJR/iVr+UU3+LsvuZ3Sx1BQbk7z/I+tfh9/wa2X 1zcWPiT4jftgG3kikV7iz07wnCuADnEd3LqJ247EwH1xzx9neJf2RdN/ZP8AEfgnwV8ItYGp+ANK 08v/AGpqV/aPcTzTzzzXYKRNGM/6Q6Iwj4EarzlieWrXwmJUoU7x5U3d6uT2UbJaXu+rPIc3OpzJ Nts4/VQr3Kvt2lgPX8s9q8i+I3jK/wDBes+DNX0e8RXj84TI77Vkj3RFkY+hwB7Yz1ANfN14KrUl TktJK3fofQwk4U1Jbo+UP2ltb0n4n/FLUdf8N3QOmWOgJp8TKfmmlLvLKynbnKrIVwccqAM5Nfzc fHyONPjl8Y0vvk1FfFGpKUjj2IGF1KGG0klMYPGTj9a97LKU6WDpQmtVFX/ryPIxk4zrTlHZs/dL 9lfwgmp+GfHnirWLll0+y+2W8MYABmxbiNMMMAAzzJH3ycjnpXm/iLwfqHh/Tbi/uNPmj0kF2jRy JBJNgKEDAcE5LcZACNxXPjZ2lCEXq/z9QoJuDutP8jqvh3PYw6bZXlzFm8uh5JQJnDAuGHyrwCO5 9R617rpvwfu1k0jTNehns9Nuo5GtIM4nIOBn5g2AC2cEAkHAI4r43HTq08RWxVVe7HX7tEfR4OKq 4WFCn8T0fzdz49t9MtfE0djq1n4w1eOPLHyrHRJPs8JVtpjQw3yqWUqULktkrmvdxN8NtXfwzHqG n+LrrX4hb2cJuYbZIFePaiMitOzKSdxJJJJY8jOa+ojVjGn7ODUXs9dbW9N2+55UoN1e6udIdes7 n4oaPa2EzG5jks45RMwKruRWIQBQQNo/iJO4E8ggDhvhbfNZ/Gn4l6VqErSt/wAJxr2iyFDgSLqM CXTsVxjG/QpF5zgtnqc18HlMVHMMRZf8u0/y/Wx9Dml/qVP/ABP9Tgdd8Q6j4I8KfET4beIb66m8 HeKZfs9/fW9o014mq2WI1J2nzX88RpjO4k+Qf48V6N4M02PTPA/h/wAHf2K9jcwvc2lxDcGRnjnb T76KQnzCSuWHmYB24c4wMAepxA5f2U0n7vOm/krfpp6nJk3I8Ukt+V/mrM/Otvhx/wAJB478Ra1Y s09veyXJgiWQsY7gsWG8KN+MBiGBAYn0jda+y/hV4g1Wz8Va14G1CK2Og2U0NvpNws8Xmbikm6Fo s+Yf+Pedw2HC8qzAlAfqa2IjUwtKF9YxX6L7nr80eFU5ld9OZn2x4ftrcQ6l4f8AEvgmy17wPqA8 vVdE1a3Zre6XkFkcYaGUDdsmjKuh+ZWBAIq63+yb+xvbeDrnxRqHwl8WyB9Uig0/QZdYsZLGCNQ8 s6wzy25voYlL26YF1uYT53blzVUauJpLkptcr1V1s7dNt102JcIyV2tiSCLR/suleH/Dfg7TfDvw +02NBY6FpEWIEdVVRLcOf3lzMQFLzSMzuxLMzMSTy+vfFKw+G3xO+BWpR3Cfb7vxbp8KxO6KslsL iIXRcOQHVUcDZySzIACeK5JKcnUUuqlr52b/AKsTtokf0RaVdDcTLMTIVIIUYBI69ap3V6tvcArE FTnawXGCMYH+favMS5rPvY30vdDkuhJMCcKGU5Y9z1P49Pzq9FewwyBbhQ8RXaARx19PTFa6rTsF uh4vrLOfFdzaLho7mMxxIThSxyM5I9/YV5T+0lq41Twp4UkjTaJBESAeQwGTx7Z/OvMzSypTkv5Z fl/wD1MsV8VH1PLfCs2PB2qKi4JjmG0+vz9e+OP51yXxr1gaf4l8OMs+CNMESkdj87E56d/89vle Ff8Ae7+Uv0PRzZ6P1PzJ/aFm+A8nwE+J2reBvijrQ8WG1givPDuuWEb/AGiZZ443NncIuUQby/zu 25UAwK8c/wCCSsNsvxS0nUVz9omv9RkA2NnC2ZQH0xw3r3r7rOK2Jlw3jfrVNRmuZabNcvxL1PAh CnHHYdU3dN39Hc8l/bUMafte+NrstgyeJNMXIJIcCG2GTjH+R74r7z/YU0xNb+Pmk7cSBLNiw3cL mSLPt0DDHPU+9VRf/CPhG1/y6j+hOLt9dxCX8x/VD8PXR5ZYFYYTGAR2TBwPXmvStaCtbypIw2qm 4kDpjkH+VSt2i4an8+v/AAWJ+K1vZ3HwF+Bx1DbqWpTXmv3FvkKJViCQQtjufmuPyJ9q/Gj+xR6f +P8A/wBavoFVdDDYeF7XjfXzk2cteUXUs+n9dj/U+8P+FvC2jOX0Lwzp9nJGxUPbWUUXHHQqoPT0 rrXDvHcJv4ZSBwOOOfrX6Dia1XEOU603OVt223+J5NvdsfzzfsnaTFo+qfHz4ZSJmM6NdWhjIHLW WoRQ9OnG81/LR/wUz0e28C/tPaj4kTTZmtptF1KzNvDHzNJY3c77U9W2zcD1H0r4vMmpVcHbrTa/ GaO29nGXp+R8UeDPGN5YXVpqejzujTRxz+Wysu5cDhl7H6jOfWvo/wAb+PvGPxN8GWmj3HjLU5/D unxtIdDvL+RobQ53F4oy23DEdAM5I98eZVm1HlfR/l1O9KMbOS0PGbmSSP4f6ckDqtvqt1LM6opV jaWrCOJcjqrTCZuO8SnPAq/8Kd1l458CzQpwup2xbAGNpkXP45wOfzNa06n+0wjfZpfp/wAE3hFe zclufpd/wUbsob34afCe/kKFZNN1a3XcoPmN5UDBcjp0JHHrzxX87cmlLFPfOkI5jc4GMABW56Uq LcatVW3f6nnS/r72d54OtQBZ7kyzZBxjk89vT8a+1Pg1r15pNjr3heScR6TqkkXmK0zKsNyiSrbX QwSN0XmyIx4YwXN1EpUTMa0qytUa7r9Tpox/cyVh9xIshknNsYrlGeOdZAN0UgYh0JA6gj261zOq ySLe2rGIEbfmBUENnqOeOpPX9aUbXTv/AF/VgbbStsdD4c8LS6prllYaDoks2pOoit7WwgZnkUKS QiRqTxgtx2z0xX6AaX+yR4h8C6Z/wkvx28Tab4Mi8suulX0q3GsXi5TCpZwlnjLIHKtIUU4wea8L O85pZWqUOV1cRVdqdOOs5Pv5JPdsqjSc9eiPrP4afAX4V/Cbw1Z/HL4t+H7qK/tz9v8AD9rqt3JH LLGyjZc3Vku2OPO4+XBJ5h4DnBIA+RNR/aQn+MH7S3gzw5fajbQ2Y1GKax0tZ1WXHzN5skY+8TtY 9wNp56mvSwssVJ0aWItzx1aS0T6q/W3cynyuTa6H6G/spftD698PPGv7YPgaz3f2U/j9L+d/PVGz PpunwbQM5Zf9F99p3dN/P0hf/tANdgGOZyFOEDSvgH3HbPHNfV0pSlh6N56ckPlaKRwzactfI831 74peIrmS5lgkZbYDcwXsSP8A9eP6V51d/FPxKbWa2hnyGYEuT82PQ5PfP6VcWlp1M32Wxx2q+OtW mhWDUGY26jKhlyM57D19/aqEGvSzxkxy4t8/NGB8w7Zz39c1cXqkS/I7Tw78SPGXhTxBqkuia3NZ JNJuuJbFvLSU8kHauAV+Y4GOM9BX158N/wBr/wCIOlwiLVfsurWiqFK3ibJcD0kjI56/eDdelcGL wlCu3Jq0tNevz7m1Oco6dDwH41eI/BHxE8fp8R/+EfFj4pis5bEvFKJPMgdlcqxKjOGXI49fU14B dWzXMoeE7gxwBg8ZH+efaow8JUaMaUpXS29NWNq+qRoWVtPCwRpuTwQO34E1c3zpOkiH94p+VepJ /H/PFat9EI9d+FPhey+IGt6t4A8RTTroviTQ9R8OXptp1hl8i/ge1l2SMrKjhJmKuVYDqQRxXhkX /Bt9+zjq90brxD8WvGTndvVbO+05EI/2h9gkJ6dmB5PSsvrEaNR3p8za0vfz7W/MzqJK2h754V/4 IKf8E+/h/pcMvjPwnJqbwkE3ms+IdTjbJIGWS3u7eJvoY8fN0r2uD9j3/gln8G7aCP8A4Vl4BluY 2UqU8O2epXKFehE0kE0i9evmD86p47FtOMLQ9NPx3+9kJSlpFHsNh8av2VPh3YrZeCPC0h0teBHp 9gbeIdACF3RqR9Bx6dK5K4/ba8JWOT4a+FsYkHy7rmaAE9+gRzn1OfWvPm5yfNKbb/r+tzaOHqT+ J2POda/bj+J7RTrpVlp9irHBjVHfaOmM5Xvjn26V8beK/wBt/wCP2oT6jbL4zmhgV2L+RHFFwMfK rEMRwT6dAfailQhUb5tX5lzw9OnZ9TzJ/jJ8RfGlkmoax4w1CdlYj97eSlSc8nGcdz2pmheJr7Ur yJrqYsgb5SzEsoz61hWXI3FdztoQjyXUTq9Ru5ZruRlyZP5cE+n0r54+P6SNp/hK4jiaSbcxEcWd zkugC4wck4x+deW7SxSSO3lthnofK/hebR9Z1mUnSLkG/wBXa03Ry7DJIpGQcgYDecBsUg5BOeOP wB+PWkgftEfFizupIYZP+Ep1QKFZnUlbubjdgls4ADcg9SRya+jw85czpvWy0/L9DxKyXIpW1uf1 Efsh/AvXNR+AlhYWOoCymeCNrycr86MytdSIuRyfOaLnPAU+ox02r/AD4kaQ4OneMzqQmIjntNQQ PbzgjkMjZXbjPQZ618lnGKpSxzpSi7pbro32+89jAU5fV48q3bP1V/ZW/wCCZGmwWNt8VfiXoEen eFnuHurO1MBikuYslmkVXJMUWASHOCRkoFTY1fmn+2F8dNB1v9pvxF4iu7BdG8NWKQ6bpFjaxAx2 NjbRQQQhxGnBZImlYuG+d2UNt2ilmGGq0smrUqutSryrXe17nfgKkJY5OmrQgnttfufLd1/wTo+H 3gn4afBL4w/FT9oG4j+Gmr28Wm6bB4e0N7abVJ44Y5d8iNdzMMwmI7/IVMznLO5bHuOn/Dz9kjwv oMFn4EuHudehYzi48Q22sK0oT5vmW2iRM4GBnjoMdq9WlmNNU6cVh9XFO+jev3anJLLpynKaq6a9 O255qPhP4OufGlr4ug+Mvh6OzhuoZlhl0vVoJJERCGDMtowkYsThmxhcDtXlXhP9nSbQfiZ4v8Ya z8dfCP2TUtcttciHm6ssrzRXzzuJFexAG+2nuYeGYZkHUZr5TD05YXE1q86cnzRUdEujTfXsj2cX T+sUI04SV077+p0vxd/ZSuZ/Gl5Knxq8D23gjxdZW2tPp2p6jqEcl1E6GD7VBssXCl1VgGzlXt4G 25UY7GD9nfxNZ6P4NvPG/wAc/A8+szRm6sdQbVZ7f+2rVY7uyiuSJoFDSNgB8Mw3I/zHglZvWp4v DKlShLmai3ppdKz69dPuOfLcLUwuKdWpJctnb52Z89+Kv2Ita0bX/Dnjr4c/GvwebqC5S41SwXxJ aBbyLIciM7hlgfNQHaC6lX+QsYxj6P4M0nw7r0Ws2Npu1udGcsCSBK53FsnuCW5x0Jr28NiaOJpw nBNTUVGd01te2++542Lw1XDyalblk21+p98fCzTPinDo/wDb9x8QotE0XH7q+1W8ihEpwQNqlWdx 7qhHvXtHiy08VXXgfwrpk37SXhZpp7m61yK5mvXUzxymOz2Li2PyrJYSjkD5nccgCu6moJtqDa1b t22/M5tLXPJdU8PfF60sJbvw38RNL1qzT53OmzRXLRjPPyFUc9eynrXwr8WvCVv8QPEPh/WteiVd a0WZri3YbleOZnQl0A6cRDsepp05RXM6fVNPyvp1Jko6n9Fvw81t9d8G+FPEu4FbyxgvlPqJI1Y/ zNa91IlzMqq37wgnqe3H+FeOpe5HskjojskZs93gbN5EiO2VBwcHGfr2NU7nUnSJWZmABJ46gAgj P+e1dC120I0S0Z594iu2W/0nUllIKPvbtkZ9+vT6da8I+PF75vhzQrDzP3kd3OpPPRcgV5ebJ/VZ N9v0Z6mVP/ao3Oa8NTXFv4G1Oe3tfOuhazvHFuCmU7ZSq5xxk4Gfevnr9pfxdHP4p8L27+ZE6WEX mxtwYt8atgj/AIER7181wpG2KlPspafcd+bv3ZLzPy7/AGw9S0c/C3RbiG1sYtbbT4rOVdOsbe2R 408h0eUwj99MRnzJGy7Ny53GvV/+CWmjQfbPCC26FtSbTdVvAOhZiZNoyB0KlOcjrX22e1HPh2pe W6kn9zR4GGjGOYUrLqvzR8gftPf2rqHx7bUNfs2gv5PGUEE0UnDRhDaqBjP6n1zmv12/4JoaXb/8 Lh1qSRcmG0VxwScDf27U7KOVYWF9oRt94sTaWOxD/vfqf0hfC4G4jmvQh2sQoOCc5+Y4/lXV+I76 GZ5IR90uI8f3gMZ59Af89aSvzOxrDyP4/v8Agqz441X4gftp+KYtK0y3ubLwsLfQrW8maXzLMwIH mMQVgMid5R8wKn0IJz8If2t4z/6C0/8A36i/wr6DFJL2VNq7jCK9NFoefWjKVWTSv8z/AF0Ec7Qe nrXJ3/ieTypm0xIWuVd0aG4cxt8oBzyO+ePpX3zV0zz+h+CPwY1t9L/at+Kmm3aBZ9Q1vxPYtGDk RhruW6AGecYgGDX883/BWLT1h8e+F/FaWu4WXj7V9MdwMYW43SAHseYB/OviMbLmqYddk198n/md trQg0+iPyhuDv1OaSD5JxMQARj5Rz36ZHTp/StHX9WnsYtLsLC4eHVb11bepZTFbryTntkqcEYxg V5tv3iT2/pnpJr2Sj1dkfQWt6PpnjPwZ4HuNLZLLUo7aawS2GFilkhkeZ1U9A224icjv5o/HzTQY Lvw/4g0mS/hdLiK4jYhlIKFWBPOOD9fU/WrhpiVr9q/yuXTbs4dUfqd+3JaHVPgF8JL9oA4XU3gd +nl+ZbSc5z/s45yPm5r+f6HwHcf26bqK/cxmNz5T4xhlYAY7Y45+lawly1avMr6s8+a2+Zxtl8LP HMVz/wASb4l3ETs8hjR4Q6wq0qOBnn+EOucZGeMDivvLQbVQvnKpaQCMBxxkhwCcAY5z0p4qcFOn KEbNbs3wqkqM05aHZ3mmQQa/fJNfuyXcUV4CeP3rRIWY88DezAng9fWvtvwB+w1qJ8GL8Zf2jfFE XgX4UqDJbx3ij+2NZGQMWlq2NuSTteTAyuCOQa8bPM7o5LhI1FFyrTajTgt5z2S9FvJ9EXShKbu9 EtyXxD+1n4V+FWkJ4c/ZE8CQ+GrFVaGfxVfRrPrmolXZgzXD/wCqADMAsaoAGCnPf6X+BfwMvvht osP7Q/7V0c8niSSBdT0PRdXlDSox/eR3V5FyR1ykDAEEgsoK7RhkOT1MGque5rL2mMnpfpBvaMF0 UV28i6tR8tofD0PJPil47v8A47anfePPib4rOkfCmG5VIIZA7XWqPkf6uMZJLDOG6KFYmvlXwxDo Xj79q/4GeK9A03+y/D2h3twmm2CJGZHWeJoy9xKMs0mATgEgdBnGS8DiKuNzpSpXVChdP+/UlFp/ 9uwT+ba7Gc4ctPl6s+jPhBqP2/8AaK/busltRssdf0KWNkY7g00FypYjqQRFjt0HU19FXF/JIkds QRICF34xnrkEDr/9avu8O5KhSu/sw/8ASUebJe9sbel61KsckFzEfs7EISwIDL+Fegqls2n20aWU MuxQyCRdp+ucda18xa3PKfH+oNKlrcQbAEPlmIyBmAweQR2zxXP6PqMaN5l1HuwmVGSp49yPx6VU Xa5DWp6GmbuXaumRW6BVbG3OFZQwOTyQQQR7HvXS208UcDqJ0YgY5hAOR74rKcr31NI6HLzMbq9l N1G6ZP3kBwB05U89MdPyq3Y6fcWtxJHDa8ByMueQV69cfy71zOWjfU1S1ROI5Vy8pRJFwBk926Hg HpznvyKZA8EjiS6mU/JuIUMcHOME4645/Ks+bVOxTij0Xwh40h8Iazp+o2aiVMfe28ptK4A9+Mev Jr1/xV8bNe16wgjsr+6t9oyzLcOhYHA5IPQ9ec9eKGua7YnGN0jzDWvG17cWT29zqE7o5BKtKSCc D1JOAAeP8a+YvGnjbWotTtYNGsFfTkfEqSgr5hB6D0Hof5ivo+FuH48Q5jLBzqKKjFvfV9uXu09f Q83M8e8uw3tuW92ltdL1/rc1dG8T6Rq+LaZltbsqP3dxJtXcc9GI2np6jt1rzfxBYeOL74gWt3b2 l3B4ItLh7a5uhZyPaXF1EiM8JnV1CTZmjdQQwKQScdDXNmOT4zhvMJUsdRuteVte7Jd1380dGHxd DMsPGeGn690bfiPWJ1DKCBIFO8Bdp56jIOewNfLM93d3suvRzbFTaQSyEmQKR37EDPPXrXhYRq0k 1sduJbvFrY7LwteQ2nh+1gG1mdyD1yBkg9+nHX1Feu6LHYzoJLYGNyVG0dDgdR3/AFPTpXn4tP2j d+p1UPhXoj0rwrpFrqsN1cXerwQHz5VUSB2IAYgZCjA6VR8d+G/CdhpbeIb3V/tlzptvPLaQxx7Y w6AvvbPJAPQFecd68SrOcaz5Y67Xe3b1O9JOirs/OD4caO0ni74RWUwfzI/FEeo/MQ+9pLmBG3cD H+qPA65GcZryT4t/sfaz4s+LOt+ItI0fz7S98RyXF+GMbu8U1yzSOpx8x2sxwMdeB2r6XDyUa843 6f8AtzPBr39mvX9EfvT8MfDl34P+DGm2UGnyDX7xVVYERmlaaaQKFVE5Ziu1Qq5yVHrX1j8MfgP/ AMKr+Nn7LGq/GvxRYadaazrN5Ld6VfJG63HlwCO0tmkJKiZrq6tpMLn/AFBXcd2a8KjgIYvNauIq fDBv71svTS566r/V8vhTh8TX3eZ+vf7W3ii20r4X+MZNJuIWjXTEhjaPBQrPLFC23H/TN3xj2r+J Xwf46+JuveIfHtwLnwfbanb6xLbSXN/Y373d2AI5A7PAxHAbaPu/cHy4xnfiStCn7OPM9b9vLubZ JDmhUduq/U/Vqz+B/hjx34w+Ht18QrS0utZ0zwZo2nOYEYxic2cMkrxmQF9vmvKV3EnDHPJNe/ad +z78LbjUJLeXwrata2iLEz7BukmYBzn/AHUMZGRz5jeleRgZzkpSvs7L5HbXeyfb/gnW6d+yz8FN UltRceBbMh5VDIY1O7GKzvGn7JvwMufMnTwdaxlhjKqB75/M/WtqtSanZbGcG7PU+IPjR4H/AGct F8f3M3xEvLC2i0DSrHw9pscrqZFhjgV9saJljhpXHTqh9CRxh8Gfst/Hrxr4O8M6VrtpeQado6Wm i27b4ZgBLcy3EapIFYsrEsVxnGW+7zXl4iGYRo1MQqb5E9H5dfkdCr0FU9lzK9l95618Sv2B/wBn rwz8L/HPjGHQnW/03Qr/AFWLbPIB5sFtJKvGeeU6e9fjQs9rYatJd3EWbe2Z5drEfPs5AOe2OD0r 1MC3UoKTW7t+B5OYyvKN/M/On4l/Gj4vftKfEzwd8KfA+tyxXnifXItA0/LS+TbRu6pJNN5Su8cM at5jsqkRxI7Y+WuF+PXx1j/ae8SxfBf4QWLaTB4OsZdM+GZs0FrdeJNHtBI/2fUBkm51KZFa6WQE ySTyTQ4kaWLZ9dhqapLnjslZ+aejv6JXPFqTcnb0t5Hx58Kv2tvjb8HfEFnqejeML2eKBxvsrq4d 42XPzDk/KTgcjnj61/Qx8Ofibonx1+H/AIf+JlhAu/VrIrcALhkmXKuD7hg6HH93iuHMMPHD1YVa aspaPtdar9QozlJOMj9kf2ZvEcGpfAL4YTLdbnj077IygMGiMDNBtYN3xED1I5Bya9Mu9XexuoLm MfIpy/8AtA8V83a94+q/M743SRPf3UUlz50fEU4U5zzkjgfmBn6c1y99fMlpcbZFJXGODk5HUe3B 7d63pTV0mE7bnO+JHM9jZRnCTElkxnnOc/hXgXxrltX0bRru3f55b+4GA3G3y4mHTry59q83N3bA 1LdmejlKX12F/wCtBfB8kMXh+zD9PlU++Tnp0HX9a/O/9uDxY1l8cLrS9NdRLHaWSyDI+c/ZoW2k AjnnPPY181whFSxM3baLf4o9DOX7rufjR8TPiH4x1rwz4w8P6/4btrCxg1SAI620kT3ZQToG6lCM KSSqjJfOTu4/Tz/gl7eXGm+Ofh3HbbQF0q4LsxBBQr82Rg9cngH069/vOJIwhkdaEXooy266HzeC k3jYX7r7rnz3+3pLLc/tH65ew2y/L4zh2MshBDbLQenynK59q/Q//gm5rsq/EvxldXFqIAbFEiLS KwYs0ik+o+6PyGawWuUYRp/Yj+aLxF/rlZL+Y/pn+F5jt/C1rPKxBWJpycEYDcj/APX7GuZ17xJY 6TBf61qVxs0zTraS/upGyNiopmkJPsFb9adFc8+W27SN47an8cfiHV9R+IPjbxf4od1bUdZ1W4u5 M/M2ZXLYz9STn0Ptwn/Cvdc/yxr3MZUj9ZqaX1ZxybcpO/Vn+mB4y/aU+Fvw9+LXgL4OeKr69g8a eI7WSfShHYzzQzbN5ZHeIMI2xG7DfgYViDwa3/GnjvwHa2G9r+3lvgzwqlvIjMpUlCDjgbWHIJBG CMjFfpk8LWhSo1k1y1E2mnfaTi722d1s+ljyL6KR+DmnXP2f9u/xIRsiH/CRXDMkbZTdc6ezYGDg 5aYNkcHPpivxf/4KLLB4n+Gv7Tkm1Jb/AMLfE9b4MFXMQ+3KjDr0EN0c+3fnn8+xatWjfdX/AAqR /wAz0I2dGFu3+R+QmmeH9Q8S+MrPTdJi8x7hlkOFLGNMYkkIAJKqqs5I6KpPrXJ6lAkviLUdUkJa zZzbWxJDBEicqTxwdxz04O3r6+bUjy2l1s1+P/AZ30rNwXz/AEPZvBVrceLNNvfBOnox8QeaL3Q0 DM73FyqFZLSMFuZLiMDYqq8ks1vbQoMymug0rX9K163tLTxHGpuVCC3v4m3MpGMbsfeX69D+VPR+ zmt/8rJr+u5s48sm0fpn+00sOqfsn+Db6Vsm012ylDAfeBinT8jvH86/De4uoIdUghnU4MixA5JD ZOATjv05NXr9YrLz/RHC9Fr3Y3w+ypq0DIhVmcDg57EYxnPp/wDWr6O0rTprj+z7LT7WZr6SVI0t 41d3mZnUCONV+ZyxGFGOTjuaWK5VODbsv8jfC/w5Jn6aaR4E+HX7GraF49+L+lW+tftDm2SfRvDF womg0CQKGQ3aklJJlYByPmRSqjBIIb42+NXxa+IXxu8RSeKfiD4knu7wvuSF2Igth2WOPOAMDHHO B6cV8ZlUHneaTz+sr043hhl2je0qn+Kb2fY6JLkh7OPzP0N/Y/8A2cPDvw60PSf2hvjRoqyX0atd eFtDvEZUZlBxfzLnOxGB2A8blJALYMed8ZfibqHxa1Cbxt46guh8NLO7kNrAd4n8QXKrlCFHIgDY C4+X1O05r6TP8bUw2GhhcP8AxL8kV3qS3b9OvlE54pSqO/wx/M+FPiD4n8T+OdduNc1m2MNl5fk2 dlFbCOKxQMTtUDAwRgZ25yo5IwFt/AOO6T4w+EJg0ZtIHeUrsO/zApIIPTGA2ePTnrW+W4OGX4el hqd/cW/d9W/NvUicpSuz6C+B3jfxHrGv/tKXmqeELe1t7rxKBbXtu0RuL+WFpEcTAIJCkXmHYWOD 552/dOe6udV1SaYvGztHuwZGQgJ1GD+IPfsa+lw7tQp3d/dX5LQ45JN6Lsdxocd8YwJp5Ft0lELh iPkY5IHrkhWP4HpXqst7FaWxt9RvVyknlMRICw5x25xx2yP0rV1Ipbkyi76HmOrLoMnlzx6m8sXm Y2qFUooxg+4PI4weKnsodKeKMCzd3cEHkrtbPbqMY/GspVbeQ40nuehW8gt1VYbSLyMKxZSWwdgJ 5/Hpjjp7m2dVRNxESxlWZkO3hSwAx6kY4AJP0OTWTel2zVRjsznbm7MkhcTOAAAAGIGCSdp9geR/ 9atmLUo4lVgGeYcjnk/h696m+9kFkjOu7mSRwZURNzBnPXjr/Sp4mtxCd6qJP4QGAA47frmkuzKd 1odx4c0+0lt3eVUOcvl2I9+PTvRqFxChWBHygX5uBjGeOPwqm0rkNXexyGpCW7kjtraVVQxl2d3S MADuWYj16e/vXil7rWi3OpraXNz5zAMMRLkZAwSCTg9/1rbCYjEYavDE4WbjUg7pp2t2/wCCZVYU 6kJU6qvGSs0+xl3ACaPrurWFnMbm2tWkKGMPjnYMAc5yUGz3OfSuov8AxFp/g7wr8MvhxYTi9v8A RbBbrxHffu5Fn1fVYLW/uArqWbEccltb7Gb5DbsAqnOf3DNKmY8WcP0crx+CdPF01KpzctozSptw cX/ecotpPp2PjsHHDZRjqmKpVuajNqNr6x960k/SzszH1K5sb9Rdl8QyR5U8HK+uO/bpXhfi+Kys 4tQDybVljKvj70mcHb1HHGSfUCvwbDJxnKLVmfbVX7pn+FGgh0Sx24FursqnvjcQOx5zj9K9y8LM PIt5S+F55XnjOR9K4cX8Ta7s66EvdjbyPQfAWp2UK6r9tXzBJNeJGGGcOzuATx2z19fpXPeMNA8a
September 28, 2009 - October 04, 2009
RV10-Archive.digest.vol-fc
