RV10-Archive.digest.vol-ff
November 03, 2009 - November 09, 2009
> http://forums.matronics.com/viewtopic.php?p=270845#270845
Subject: | Certified WAAS GPS |
Stein,
No need to be sorry. I am sooooooo use to bad news when
it comes to avionics. J It seems like Garmin would offer a certified
option / plug in for a few thousand as an upgrade path for these units
but I guess they will end up with the cash anyway. I read some place
that Garmin has sold over 130,000 430/430W's. That looks like close to a
billion dollars to me. The one consolation as I have mentioned before is
that I will want a premium Comm in the ship anyway and that's what you
get with the 430W. Same rational I used for buying the G900X. Hay, it
comes with two 16W comms! I wasn't really considering a discontinued
unit in a new panel anyway.
Robin
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of SteinAir,
Inc.
Sent: Tuesday, November 03, 2009 4:25 PM
Subject: RE: RV10-List: Certified WAAS GPS
Hi Robin,
You are correct...and there are a couple alternatives out there, but
their price points make the GNS boxes the less expensive way to go.
Someone mentioned the 480's and indeed they are WAAS certified, but due
to supply & demand, they often times bring more on the used market than
a new 430W costs! So, the quick/dirty answer is that the GNS box is
still the best way to go from a money perspective.
Sorry I don't have any better news!
Stein
The information transmitted is intended only for the person or entity to
which it is addressed and may contain confidential and/or privileged
material. Any review, retransmission, dissemination or other use of, or
taking of any action in reliance upon, this information by persons or
entities other than the intended recipient is prohibited. If you receive
this in error, please contact the sender and delete the material from
any computer.
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of Robin Marks
Sent: Tuesday, November 03, 2009 5:22 PM
Subject: RV10-List: Certified WAAS GPS
I am considering the G3X for my 8A project. Much like other
vendors the G3X includes a VFR WAAS GPS. Sounds like all the accuracy
with none of the certification. For one to fly legal WAAS IFR GPS
approaches I believe the unit need to be driven off a certified WAAS GPS
as far as I understand. Other than the 430W & 530W what are my other
options for certified a WAAS GPS feed?
Robin
h
ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics
Subject: | Re: Door strut attach fitting |
I posted my issue a few days ago and got some responses to check the basics, didn't
address my problem. Here is what played out for me.
I had the door brackets installed within 1/4" of the edge of the window cut out.
I had the canopy bracket installed as far inboard as I could get it. Using the
spacer dimensions in the plans did not work for me. I made mine 7.7". My compressed
struts measured 7.82". When I installed the first strut the door wouldn't
close all the way.
How I fixed mine: I measured the length of the compressed strut and made a new
spacer the same length plus a tenth of an inch for good measure. I filled in and
glassed over my initial holes from the door brackets and reinstalled the door
brackets at the far edge by the window. Then with the door closed, and the
spacer attached to the door I marked out new holes on the canopy bracket. Drilled
the new holes, trimmed the 'ears' off with the original holes in it...beautiful.
Took me 20 minutes to do the second door this way. Don't have pics, but
is fairly straight forward. Call me at 225-802-4827 if I can offer any more info
about how or why I did it this way.
Eric Kallio
Finishing canopy and door fiberglass
http://forums.matronics.com/viewtopic.php?p=270861#270861
Subject: | Re: First successful test of windscreen antenna |
Linn Walters wrote:
> Dj missed it.
> Linn
It is not the first time... *grin*
-Dj
Subject: | Re: Certified WAAS GPS |
I'm liking my 480 more and more...Even though they look
similar, the functions aren't very similar to the 430/53
0 units so I may have a new learning curve on the n
ext project..oops....I mean if I have a next project.
Rick Sked
N246RS
Sent via BlackBerry by AT&T
Date: Tue, 3 Nov 2009 19:57:06
This is a multi-part message in MIME format.
From: | Linn Walters <pitts_pilot(at)bellsouth.net> |
While we're on the strut attach fitting ..... I cut a slot towards the
mounting hole on the end next to the strut attach holes. I plan on
floxing over the three screws, and ground flats on either side of the
head to prevent them turning when putting the nuts on. This way I can
remove the cabin top strut fitting if I ever need to.
Linn
Subject: | Way Off Topic: New PIC |
Congrats Tim, that's awesome.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Tuesday, November 03, 2009 12:50 PM
Subject: RV10-List: Way Off Topic: New PIC
Sorry that this is way off topic but I'm kind of excited because now
N104CD has an official co-pilot....ME! Yes, the little lady now not
only wears the pants in the house but in the cockpit too, since she's
now a pilot!
Tim O. - N104CD's F.O.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From: | Don McDonald <building_partner(at)yahoo.com> |
Subject: | Re: Way Off Topic: New PIC |
That's great Tim.....- I was able to listen to all the other comments bec
ause I got home late after flying to another airport and being picked up fo
r a golf outing.... that being said... here's what I heard at the airport b
ack when I was a REAL newbee and still building..... There's 3 categories o
f wives/girl friends;- the first hates airplanes, will never fly with you
, and tells you so (daily); the second, early on, make you believe that the
y like it, and even go for a few flights.- Then when the hook is set, the
y let you know what they really think.... same as the first category;- Th
en there's the last category, which fortunately for you and me, is what we
have.- They want to go almost every time, and will fight- for their fav
orite seat.
Now you will have to even fight for the left seat!!!!!!!!!!!!!!!!!!!
Luckily for me, at least for the present, Kim just wants to learn enough to
get it on the ground if something happens to me.
Congrats again.
Don & Kim McDonald
Date: Tuesday, November 3, 2009, 12:50 PM
Sorry that this is way off topic but I'm kind of excited because now N104CD
has an official co-pilot....ME!- Yes, the little lady now not only wears
the pants in the house but in the cockpit too, since she's now a pilot!
le, List Admin.
=0A=0A=0A
From: | "John Dunne" <acs(at)acspropeller.com.au> |
Fantastic achievement!!
There's nothing quite like that milestone of PIC.
John 40315
Sent: Wednesday, 4 November 2009 6:50 AM
now a pilot!
Subject: | Re: Big Iron Envy |
We have installed both the MaxDim and MaxPulse in our planes. Both work great
and were easy to install. I must add my two cents here. LoPresti, RMD, Knot2U,
xevision, the leaders in the HID market, and others are pulsing the HIDs.
So yes it can be done it seems. The question may be - how does it effect the
long term life of the HID bulbs? LoPresti puts it like this -
http://speedmods.com/PowerPulse.htm look at the Urban Myths, and you can compare the systems here - http://maxpulsemaxdim.com/comparisons.htm . However, only one system is STC'd and has the warmup delay that seems to be so important. That is the MaxPulse unit. We cannot say if this is important or not. Everyone seems to have a different take on it. But if the HIDs have a 5000 hour life and pulsing them reduces that life by 10% you are going to be in the pilot seat for many, many hours. Your HIDs could very well outlive you. It would seem that being seen is far more important than anything? Safety anyone?
Yes, that little brown spot in the picture is a bear.
http://forums.matronics.com/viewtopic.php?p=270909#270909
Subject: | Re: Elevator travel vs. stick grip clearance |
Here is a link to a short slide show of the build. I will post some better pictures
soon.
http://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=100395192
http://forums.matronics.com/viewtopic.php?p=270911#270911
> now a pilot!
so did she do the flight training in the 10?
http://forums.matronics.com/viewtopic.php?p=270914#270914
Mary and I send hearty congratulations to Andrea! Way to go!
David and Mary Maib
"Twenty years from now you will be more disappointed by the things
you didn't do than by the ones you did do. So throw off the bowlines.
Sail away from the safe harbor. Catch the trade winds in your sails.
Explore. Dream. Discover."
-Mark Twain
now a pilot!
Subject: | Re: Voyager Lifetime chart subscription |
From: | "johngoodman" <johngoodman(at)earthlink.net> |
I'd be careful about lifetime offers. I once had a car battery from JC Pennys that
was guaranteed for life. Then they went bankrupt.
#40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel
delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=270929#270929
Subject: | Re: Seat belts and windows |
Bill,
For the seat belts, Section 49. For the rear windows, Section 45, page 45-18 Steps
1 & 2. Basically it just says use the same procedure that you used for the
door windows.
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings
http://forums.matronics.com/viewtopic.php?p=270942#270942
From: | "Jeffery J. Morgan" <jmorgan(at)compnetconcepts.com> |
For the price though, if you get more than 2 years, it is less than
buying it for two years. They have been around for a while and growing,
so should be a safe bet.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman
Sent: Wednesday, November 04, 2009 7:57 AM
Subject: RV10-List: Re: Voyager Lifetime chart subscription
Pennys that was guaranteed for life. Then they went bankrupt.
Panel delivery soon.
N711JG reserved
Tim Olson wrote:
> From looking at their Beta release that I'm checking out,
> their Data manager supports both Voyager and the AV8OR GPS,
> so apparently somehow they built a relationship with those
> guys too. So it does seem that they're growing. They also
> I think just released a total solution where you buy the
> tablet pre-loaded and it was some pretty darn good price
> like just over $1000 or something.
> Tim Olson - RV-10 N104CD
I went with the tablet with the internal hard drive. I loaded the beta last night
and checked the hard drive usage. It is over 38g. I have been planning on
upgrading the the 32g SSD (which is the only option available) but now I am
going to have to figure how they are handling this. And I have added nothing.
This is not good [Crying or Very sad]
Will have to check to see where all the memory is going. Looks like it downloaded
all the approach plates, sectionals and IFR maps for the US but I don't think
it should have chewed up 38g. for the data + the tablet
PC OS.
Tim, do you have any idea how much just your data is consuming?
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=270973#270973
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |
Gary, SSD's have been well over 32GB for more than a year. I use a 60GB SSD
that I bought a year ago to transfer files between my office and home. It is
interchangeable with any laptop that is less than a couple years old.
Michael
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=636&name=Solid-State-Disks
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman
Sent: Wednesday, November 04, 2009 11:36 AM
PC OS.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
> Michael
If I only had that option. They are using the 1.8" PATA ZIF drive and they are
only available in 16 and 32g that are compatible.
The tablet they are selling appears to be one of the first of the new Net Books
that is also a tablet.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=270999#270999
Tim Olson wrote:
> Gary,
> I'm not sure how yours got so full. I download all charts except only 2
> of the High Altitude IFR charts, and I have lots of space left. I
> wonder if you have a duplication of your chart storage or something.
> Maybe during loading the beta you copied the charts and duplicated them?
> I'll load the beta on my tablet tonight and see what I have for free
> space, but you should have plenty left on even a 32GB drive. Mine is
> a 32, and I think I have a lot of other stuff there too.
I figure that is what is going on but right now time at home is at a premium.
Heading to California this Sat in the -10 and trying to make sure everything
is in order. Will be the first real long trip with good potential of IFR (rain)
at my destination.
> If you get too lost, I can email you what you'd need to do to do a
> complete removal and re-install, and you could see what it does. But
> first I'll upgrade mine and let you know how it comes out.
> I have it on my work laptop and I didn't see any real increase
> in space after loading it....so I'm guessing you have something
> copied or filling up extra space, like maybe a duplicate chart
> repository.
Thanks, I will let you know if I can't find it and need help.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=271008#271008
OK, I just verified space for you.
I have about 6.5GB free on a 32GB drive, with a full install,
including every Approach Plate, Every Sectional, Every
TAC, every WAC, Every Low Altitude Enroute, and 2 of
the 12 High Altitude enroutes. So most of the charts
available and actually far more than I'll ever use. I could
easily trim space by deleting the High Enroutes, and many
of the WAC's and Sectionals from Alaska until I go there.
After upgrading to the latest version of Beta that just came
out this week, I actually got .1GB MORE space left than before.
On that same tablet, I also have installed:
Microsoft Word and Excel from Office 2003
Microsoft Streets and Trips 2009
A large motorola program for using your phone as
a broadband modem.
Some network utilities and VPN Client for
doing work things.
A virtual drive program
Vi for windows editor
Lots of MS power Toys
AVG antivirus
Adobe reader
Winamp
Zone alarm pro
So there are plenty of things for me to use it as a work
computer while I'm out.
So, if you're overflowing a 32GB drive, you've got
something else going on, but it isn't Voyager that's
doing it.
orchidman wrote:
> Tim Olson wrote:
>> Gary,
at my destination.
>> repository.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
From: | Sheldon Olesen <saolesen(at)sirentel.net> |
Subject: | Oil filter apology |
On Aug 11, I made a post about my crushed Kelly oil filter and
included pictures. I want to set the record straight. The failed
filter was the wrong filter for the engine. I am both sorry for and
embarrassed by my mistake. The difference between the correct filter
(48108-1) and the incorrect filter(48110) is an internal oil bypass
valve in the correct filter. I was unaware until about a week ago
that there was any substantive difference between the two filters
other than the 108 had female threads and the 110 had male
threading. I'll explain how all of this happened.
I was at home and going to do an Aircraft Spruce order and remembered
that I needed more oil filters. I didn't remember the filter number
so I looked it up in the A/C Spruce catalog where the IO-540 was
listed under the 110 filter. When I got the 110's it was obvious
that one filter(110) was male and the other filter (108) female.
That wasn't a big problem because the male adapter for the ECI angled
filter adapter came off with the 108 filter. I figured there was no
sense of messing around with the male adapter if it comes off easily--
just use the filter with the male threading built in. So I put the
110 filter on and flew with no indications that there were any
problems until I took it off and found the filter media crushed
inside the metal shell. This was around OSH time so I asked Kelly
what might be the problem. The very short answer from them was the
engine. I also asked the Mattituck guy what might be the problem.
His answer was the filter. I emailed the Light Plane Maintenance
editor and asked the same question and his answer was the filter. I
also had emails from people on the RV-10 list telling me to check the
engine and hoses which I did. Nothing seemed amiss with the engine,
hoses, or oil pressure. Since I could find nothing wrong with the
engine and I ordered new Champion filters and put a new Champ 110
on. I checked it regularly and it wasn't looking distressed at all.
There were no signs of crushing. I thought my problems were over.
While all of this was going on Kim Santerre of LPM wanted pictures of
my crushed filter and I sent them. He was doing an article in LPM on
defective filters and my problem fit right in. The article appeared
last month in LPM with my filter pictures prominently on the cover.
Kelly was not happy about the coverage and started discussions with
LPM. While digging deeper to address Kelly's concerns, Santerre
contacted Mattituck and found out that my model engine ships with the
ECI angle adapter and should have a 108 filter because the adapter
has no bypass valve. Santerre thought that I must have the straight
adapter with the integral oil bypass valve since I was using the 110
filter. That's when I found out about the real difference between a
108 and a 110. It was very embarrassing to tell him that I had an
angled adapter and I should have been using the 108 filter. A
clarification is to appear in the next issue of LPM. Kim Santerre
has been very gracious during all of this fiasco.
Apparently I'm not the only owner who has been confused about the the
108 and 110 filters. Mattituck has a warning that they now ship with
the ECI adapter equipped engines. My engine was shipped in July,
2007 and the warning came out in Oct 2007. See the attachment. I
think that ECI has a poor adapter design since it is possible to
remove the male threading with no difficulty. A fixed male thread
design would make it impossible to use the wrong filter. I still
think that the Champion filter is superior to the Kelly since it
survived in a situation where the Kelly failed although I'm sure the
Kelly will work just fine in the proper installation.
Sheldon Olesen
N475PV 119 hrs.
Subject: | Re: Oil filter apology |
Wow Sheldon, thanks for the update on the situation. It's actually
comforting to know that it was something so simple yet so confusing,
and not some other wild engine problem.
For the builders out there, make sure you read ALL of the line
in his post....don't just skim in. The 48110 filter is indeed
the right filter for many of us. And, for people who have
the adapter from ECI like Sheldon does, the 48108 is the right
one. So don't just skim the post without coming away with the
full understanding, or you may inadvertently get the wrong
filter.
Sheldon, do you know if ECI is basically the ONLY adapter that
we have to worry about this with? I know in my case I just
have the standard straight adapter, and I need to use the
48110 male thread filter. But I'm curious....does the B&C
or any other filter adapter bring potential issues for other
builders? Up until now, I basically thought the 48110 was
the "only" filter for our engines. Especially when you
see this page:
http://www.aircraftspruce.com/pdf/2010Individual/Cat10304.pdf
The 48108 doesn't even list a 540 model...but as you found,
that's not the same if you run the ECI adapter.
Thanks for the post...I know a few TMX engine buyers, so
I'm sure it'll be something they'll want to know.
Sheldon Olesen wrote:
> On Aug 11, I made a post about my crushed Kelly oil filter and included
> pictures. I want to set the record straight. The failed filter was the
> wrong filter for the engine. I am both sorry for and embarrassed by my
> mistake. The difference between the correct filter(48108-1) and the
> incorrect filter(48110) is an internal oil bypass valve in the correct
> filter. I was unaware until about a week ago that there was any
> substantive difference between the two filters other than the 108 had
> female threads and the 110 had male threading. I'll explain how all of
> this happened.
> that I needed more oil filters. I didn't remember the filter number so
> I looked it up in the A/C Spruce catalog where the IO-540 was listed
> under the 110 filter. When I got the 110's it was obvious that one
> filter(110) was male and the other filter (108) female. That wasn't a
> big problem because the male adapter for the ECI angled filter adapter
> came off with the 108 filter. I figured there was no sense of messing
> around with the male adapter if it comes off easily--just use the filter
> with the male threading built in. So I put the 110 filter on and flew
> with no indications that there were any problems until I took it off and
> found the filter media crushed inside the metal shell. This was around
> OSH time so I asked Kelly what might be the problem. The very short
> answer from them was the engine. I also asked the Mattituck guy what
> might be the problem. His answer was the filter. I emailed the Light
> Plane Maintenance editor and asked the same question and his answer was
> the filter. I also had emails from people on the RV-10 list telling me
> to check the engine and hoses which I did. Nothing seemed amiss with
> the engine, hoses, or oil pressure. Since I could find nothing wrong
> with the engine and I ordered new Champion filters and put a new Champ
> 110 on. I checked it regularly and it wasn't looking distressed at
> all. There were no signs of crushing. I thought my problems were over.
> While all of this was going on Kim Santerre of LPM wanted pictures of my
> ECI angle adapter and should have a 108 filter because the adapter has
> no bypass valve. Santerre thought that I must have the straight adapter
> with the integral oil bypass valve since I was using the 110 filter.
> That's when I found out about the real difference between a 108 and a
> 110. It was very embarrassing to tell him that I had an angled adapter
> and I should have been using the 108 filter. A clarification is to
> appear in the next issue of LPM. Kim Santerre has been very gracious
> the ECI adapter equipped engines. My engine was shipped in July, 2007
> and the warning came out in Oct 2007. See the attachment. I think
> that ECI has a poor adapter design since it is possible to remove the
> male threading with no difficulty. A fixed male thread design would
> make it impossible to use the wrong filter. I still think that the
> Champion filter is superior to the Kelly since it survived in a
> situation where the Kelly failed although I'm sure the Kelly will work
> Sheldon Olesen
> N475PV 119 hrs.
Dear Listers,
Just a quick reminder that November is the annual List Fund Raiser. The Matronics
Lists are 100% member supported and all of the operational costs are provided
for my your Contributions during this time of the year.
Your personal Contribution makes a difference and keeps all of the Matronics Email
Lists and Forums completely ad-free.
Please make your Contribution today to keep these services up and running!
Thank you in advance!
Matronics Email List and Forum Administrator
I can give you another reference point. Our stock 182 always used the 48110 and
the Cessna oil filter adaptor, until the last overhaul, when the adaptor was
replaced with the latest version, and the filter changed to a 48108. At least,
the shop put a sticker on the firewall, warning "Use only filters with an internal
relief valve".
So there are other adaptors that need the 48108 filter.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=271148#271148
> doing it.
I have a file dated 10/22/09 which is the last 28 day chart cycle update that is
18G in size. Looks like my last chart cycle update messed up. I have emailed
Seattle support and see what they say. I am not touching anything until I
coordinate it with them in case they need it for debugging.
After deleting that file, then my total usage looks like it will be in line with
yours.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=271161#271161
Richard is at the aopa convention.
>> doing it.
> update that is 18G in size. Looks like my last chart cycle update
> messed up. I have emailed Seattle support and see what they say. I
> am not touching anything until I coordinate it with them in case
> in line with yours.
> Thanks
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
From: | "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> |
The B&C angled adapter also uses the 48108. Their's actually has the filter number
engraved and the adapter.
----- Original Message -----
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
Sent: Wed Nov 04 21:46:49 2009
Subject: Re: RV10-List: Oil filter apology
filter.
see this page:
> this happened.
> Sheldon Olesen
> N475PV 119 hrs.
Subject: | Insurance-- hour threshold for decrease |
Does anyone know what the hour threshold is to get a substantial cost
decrease in their insurance policy?
I would probably have around 130 on renewal in Dec.
Sheldon Olesen
N475PV 119 hrs
Subject: | Re: Insurance-- hour threshold for decrease |
Not so much hours as it is the IFR rating...that will save you a bunch...he cost
of the rating will repay you in two years. My premium for 150k 160 hours is
3K a year. 1600 if I was IFR
------Original Message------
Sender: owner-rv10-list-server(at)matronics.com
ReplyTo: Rv
Sent: Nov 5, 2009 7:53 AM
Subject: RV10-List: Insurance-- hour threshold for decrease
Sheldon Olesen
N475PV 119 hrs
I think a normal break is about 1000; however an instrument rating and/or
commercial license should improve it some.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sheldon Olesen
Sent: Thursday, November 05, 2009 8:54 AM
Sheldon Olesen
N475PV 119 hrs
Tim Olson wrote:
> This winter/spring I'm going to keep my eyes open for a nice used RV-7A or 9A,
> Tim Olson
What's this "A" stuff [Mr. Green]
All real pilots know that for one and two place airplanes that little round thingie
goes in back, not up front. [Mr. Green]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=271244#271244
From: | Jeff Carpenter <jeff(at)westcottpress.com> |
Subject: | Re: AMSAFE seat belts |
I've got a couple of questions David:
How much weight are we adding with the inertia reel belts as opposed
to the standard?
The hard points you show in you installation pictures are much more
elaborate than what Vans provides for the stock belts. Is there a
reason the inertia belts require more support, or do you feel the Vans
hard points aren't enough for either approach?
Jeff Carpenter
40304
Finishing the inside of the cabin top... and making provisions for the
belts
On Nov 3, 2009, at 9:46 AM, David McNeill wrote:
> www.inertialbelts.com is on line again. The belts are shown in my
> Glastar as the belts were not installed in my 10 at that time. Rene
> has good pictures of the final finish. I will enclose one of his here.
From: | Patrick Pulis <rv10free2fly(at)yahoo.com.au> |
Subject: | Wayne Edgerton Could you please email me off line |
G'day Wayne, if you're out there (or if anyone knows Wayne's email) could y
ou please email me off line.=0A=0AKind regards=0A=0APatrick Pulis=0AAdelaid
e, South Australia=0A=0A=0A=0A=0A________________________________=0AFrom: T
im Olson =0ATo: rv10-list(at)matronics.com=0ASent: Fri, 6 Nove
mber, 2009 3:10:54 AM=0ASubject: Re: RV10-List: Re: Way Off Topic: New PIC
gain all,=0A=0AI just wanted to say "thanks" on behalf of Andrea.- I've s
ent=0Aher all of your comments and both of us appreciate it.- Many=0Aof t
he comments are right on...it's usually one thing to get=0Aa girl who is to
lerant of flying or building, but a whole other=0Athing when they're willin
g to help build, and actually follow=0Athrough with learning how to fly the
mselves.- Hopefully=0Ahaving more women in aviation will also keep boosti
ng the=0Aoverall participation by people in general, because the best=0Athi
ng we can do for longevity of the hobby and many more=0Aaspects of plane ow
nership is to add more new pilots to the=0Aworld.=0A=0AThanks again for all
the on and off list replies.- I've not=0Aanswered much on them myself, j
ust forwarded them off to her=0Ato bring a smile here and there.=0A=0ATo an
swer cjay's question, she finished in that leased Cherokee=0Athat I got thi
s summer.- So for this season, that plane=0Asaw two women get their certi
ficates, and now that we're=0Adone with it, we're still keeping it for a bi
t for them to=0Akeep current, and there's a local guy who's going to use it
=0Ato start his training too. So it's great to see people getting=0Ainto it
.- The Cherokee is a real dog compared to an RV, but=0Ait's making a grea
t trainer, and at $32/hr dry, I can't=0Abeat the price.- I figure $125/hr
to fly my RV-10 if I be=0Arealistic.=0A=0AThis winter/spring I'm going to
keep my eyes open for a=0Anice used RV-7A or 9A, if I can pick one up at a
real bargain,=0Aand have that for them to build time in.- Even with Andre
a=0Ahaving a private pilot certificate, adding her on to=0Athe RV-10 policy
will significantly increase the insurance=0Arate, and, truthfully, it's an
expensive enough plane that=0AI'm not going to turn a new pilot loose with
it. So a=0Anice little RV-7/9A would be something they could build=0Amore
hours in.- Plus, it never hurts to have another plane=0Ato have around to
play with.- I love flying side-by-sides. :)=0A=0ATim Olson - RV-10 N104C
"cjay" =0A> =0A> =0A> Tim Olson wrote:=0A>> Sorry that
this is way off topic but I'm kind of excited because now- N104CD has an
official co-pilot....ME!- Yes, the little lady now not- only wears the
pants in the house but in the cockpit too, since she's- now a pilot!=0A>
> Tim O. - N104CD's F.O.=0A> =0A> =0A> so did she do the flight training in
the 10?=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http
===========0A=0A=0A ______________________________
____________________________________________________=0AGet more done like n
ever before with Yahoo!7 Mail.=0ALearn more: http://au.overview.mail.yahoo.
com/
Subject: | AMSAFE seat belts |
I think the overall concern is that the factory hardpoints are just not e
nough. I believe, as David said, AMSafe was concerned that additional rein
forcement would up the safety margin. I know I feel a lot better after put
ting a couple of intersecting layers of S glass over the hardpoints.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m
atronics.com] On Behalf Of Jeff Carpenter
Sent: Thursday, November 05, 2009 4:20 PM
Subject: Re: RV10-List: AMSAFE seat belts
How much weight are we adding with the inertia reel belts as opposed to the
standard?
The hard points you show in you installation pictures are much more elabora
te than what Vans provides for the stock belts. Is there a reason the iner
tia belts require more support, or do you feel the Vans hard points aren't
Jeff Carpenter
40304
Finishing the inside of the cabin top... and making provisions for the belt
s
www.inertialbelts.com<http://www.inertialbelts.com> is on line again. The b
elts are shown in my Glastar as the belts were not installed in my 10 at th
at time. Rene has good pictures of the final finish. I will enclose one of
his here.
rsbooks.com>
m>
Subject: | Integrated rudder trim method |
From: | "MikeInIrving" <mike.strube(at)gmail.com> |
I've researched the threads and Tim's site. There's plenty of pictures and instructions
for the piano hinge style of rudder trim tab.
But is there a "go-by" for the integrated style? I know either will work just fine,
I happen to like the look of the integrated trim tab.
Mike Strube
#41000
Mike Strube
Irving, Tx
mike.strube at gmail.com
http://forums.matronics.com/viewtopic.php?p=271295#271295
Below is my reply to Jeff. I do believe that if you use the standard
hardpoints and regular belts that you should at least use a CS stainless
washer under the screw. This will spread the load on the glass and make a
pull though more difficult.
don't know for sure but the total weight of four AMSAFE belts IIRC is less
than 10 pounds. Incrementally I would say an additional 2-4 pounds over the
standard belts. You add 4 3'x3'x1/2'' aluminum blocks and four rollers Check
with Rene as he probably weighed the alternatives.
The existing hardpoints were deemed inadequate (for the AMSAFE application)
by both AMSAFE and consultant (PhD, ME Caltech) who lives nearby. The vans
hardpoints are setup for a single #5 counter sunk screw. This is installed
without CS washer that would be required to spread the load. My ME
consultant friend tells me that the normal use of the regular belts will
cause micro fractures and may fail (pull through) if and when a crash
occurs. AMSAFE commented that they would sell me the belts if I "beefed up"
the existing hardpoints. Since the roller have screws for attaching the
brackets I needed a means to attach the bracket Since I did not want 16
protruding though the lid I used the aluminum blocks (2024T3 or 7075) .
These were tapped for 4 external screws to hold the pad that holds the
roller. Each external screw has a .75" CS stainless washer and thereby
spreading the load on the lid. In addition since the shoulder straps are on
inertial reels there is no constant shear load on the single screw in the
lid. The hardpoints areas were strengthened by additional E-glass and
S-glass tapes. The calculations of the ME ,while informal, indicated that
relative strengths could compared by comparing the surface areas of the
fasteners. Hope this helps.
standard?
elaborate than what Vans provides for the stock belts. Is there a reason
the inertia belts require more support, or do you feel the Vans hard points
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder
(Michael Sausen)
Sent: Thursday, November 05, 2009 7:01 PM
Subject: RE: RV10-List: AMSAFE seat belts
enough. I believe, as David said, AMSafe was concerned that additional
reinforcement would up the safety margin. I know I feel a lot better after
putting a couple of intersecting layers of S glass over the hardpoints.
Michael
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
standard?
Jeff Carpenter
40304
Finishing the inside of the cabin top... and making provisions for the belts
www.inertialbelts.com is on line again. The belts are shown in my Glastar as
the belts were not installed in my 10 at that time. Rene has good pictures
Max pulse is fine for HID if you run only the fastest pulse rate it offers, 60
pulses per minute each channel 120 pulses per minute both channels. and if you
run them steady on for about 20-30 seconds before you switch to pulsing operation.
The Max pulse only has a ~5 second wamup about 20 seconds too short. The
bulb manufacturers (Philips & Osram) only rate the bulbs for 2000 to 3000 hours
of normal use. I believe Lopresti's hours warranty is based on a hobbs meter
not lights on time. XeVision has a patent pending on automatic bulb warm-up
to substantially improve bulb life with HID pulsing operation.
LED still has a long way to go to compete with HID as a landing light. This is
true in terms of total lumens and reach (distance).
http://forums.matronics.com/viewtopic.php?p=271304#271304
Mike,
How about some crappy photos without instructions? Somewhat self
explanatory.
http://www.painttheweb.com/rv-10/rudderTrim.htm
Looks good & works well.
Robin
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MikeInIrving
Sent: Thursday, November 05, 2009 7:19 PM
Subject: RV10-List: Integrated rudder trim method
and instructions for the piano hinge style of rudder trim tab.
just fine, I happen to like the look of the integrated trim tab.
Mike Strube
#41000
Mike Strube
Irving, Tx
Checked by AVG - www.avg.com
11/05/09 19:52:00
Reposted from another thread here:
The new pulsing Lopresti PowerPulse is the same unit made by http://seatoneng.com/ or http://www.maxpulsemaxdim.com/comparisons.htm is a pretty cool compact form factor, I have to admit, I would use it for Incandescent or Halogen lamps. It is a GREAT product.
However, its built in warm up is NOT suitable for HID IF you are concerned about
ballast and bulb life. Its bulb warm up is not sufficient for HID because the
warm up time is much too short (~5 seconds) and most of the pulsing speeds are
too slow to be OK for HID bulbs.
XeVision was the first (4+ years ago) to offer Pulsing specifically designed for
the requirements of HID, after much discussion with the HID bulb manufacturers
about bulb operating requirements for long life (ARC plasma behavior and electrodes).
We make our own ballasts but these quality HID bulbs are ONLY made
by Philips or Osram (Sylvania).
The unit Lopresti is offering has only a 5 second warm up, OK for incandescent
or LED (not needed), but NOT good for HID.
HID requires the bulb arc plasma reach steady state or very close to it before
pulsing should start if one cares about HID system life. Anything less than 20
seconds of continuous warm up time is too short and will significantly affect
HID bulb life. Slow pulsing is also harmful, 60 ppm (1 Hz) per channel (120 ppm
both channels "wig-wag") is the approximate optimal speed considering both
bulb life and visual effectiveness for HID. Short warm up and / or slow pulsing
allows the plasma to cool off too much in pulsing operation, requiring very
much higher starting voltages to restrike the ARC, thus accelerating erosion of
the electrodes.
Once the HID bulb is warmed up, 20-30 seconds (sufficient) or more, if pulsing
is fast enough, the on pulse is long enough and the off period short enough the
plasma can stay hot enough to again sustain a low voltage arc (~85 VAC) as it
does in steady state without resorting to a high voltage restrike 25+ KV for
each pulse.
The Lopresti unit offers 44 ppm (22 ppm each channel) and 88 ppm (44 ppm each channel),
these are for both channels combined. Only the 120 ppm their fastest
rate (60 ppm each channel) is suitable for HID.
Note: XeVision has a Patent Pending regarding warm-up technology for HID (filed
over 4 years ago). The Patent office has granted our Patent about 1 month ago
and the final paperwork has been submitted for issuance from the US Patent office.
The original XePulse I and the about to be released XePulse II are covered
by this Patent. The XePulse II is about 20% of the size of the original unit
and the new unit includes additional patentable enhancements to insure maximum
HID system life while in pulsing operation.
Philips and Osram (the only quality D1S) bulb makers in the world. both claim a
Tc of either 2500 or 3000 hours. This bulb statistic means that only 63% of the
bulbs will still function (on/off) after that amount of run time in the lab.
Lopresti has used and still uses these 2 brands of D1S HID bulbs and yet still
claims a 5000 hour or 5 year warranty ???? This must be a hobbs meter based
warranty, not a true usage based warranty. Since most users will not use their
HID lights as a large % of total flight time this does not cause them to provide
many free replacement bulbs. And very few users will fly more than a couple
of hundred hours per year.
Without a proper arc chamber warm up Philips and Osram claim the bulb is only good
for about 20,000 starts. That is only 6 hours of continuous pulsing if it
is not in the plasma (steady state) instead of excited Xenon only as during the
initial starting. Depending on how someone operates their pulsing system, pulsing
while "cold" the warmup to steady state can be extended to over 5 minutes
which wears the electrodes at an accelerated rate. Once the arc gap gets large
enough and 105-110 VAC (max steady state bulb voltage) cannot sustain the arc
the bulbs life has ended. When a bulb is new it takes about 85 VAC and 0.4
amp (35 watt) (0.6 amp for 50 watts) to sustain the arc once warmed up. When the
bulb is cold it takes more power to keep the arc going. During this early phase
of bulb operation it can take 2X to 3X the power to the bulb to keep it "lit".
This extended overpowering to 70-90 watts is hard on the bulb this is the
bulb operation phase to be avoided for HID pulsing. Hot restriking after less
than a second of cool down (more than 30 seconds) it takes as much as 25,000
Volts to restart.
Every other company (6) which offers a pulsing system indicates 30 seconds to 1
minute steady on before pulsing should start (flip the switch) for HID.
The HID bulb manufacturers all agree that a close to steady state power to the
arc is mandatory for good bulb life and the higher the pulsing frequency the better
(that works well visibly). Hot restarting takes much more power if the bulb
is allowed to cool for more than 1/2 second. If pulsing only occurs while
the plasma state is well established (after 20-30 secs) then the power required
to re establish the arc is almost the same as to keep it "lit". Its all about
the impedance within the arc and under what conditions is it easiest on the
bulb and ballast to re establish the arc. Its all about adequately warming the
arc chamber up and keeping the off time between pulses short and the on time
of the pulses long.
I guess its their engineers (facts) "opinions" (Philips and Osram) vs Lopresti
sales team opinions. I think I'll stick with them, after all they are the bulb
experts.
The power being put into the bulb/ballast system can easily be monitored with an
amp probe on the cable to the bulb on an oscilloscope to see how the power varies
between operating the bulb these 2 different ways, "cold /cool" pulsing
or "hot" (warmed up) "steady state" pulsing.
One of Lopresti's people told me that their HID warm up was "instantaneous" Those
guys are miracle workers and can defy the laws of Physics.
http://forums.matronics.com/viewtopic.php?p=271305#271305
> is true in terms of total lumens and reach (distance).
I'm curious:
a) how many lumens are typical HID landing lights? The newest Cree emitters
can put out 1000 lumens per emitter, and hooking up more than one of these
emitters into a single unit is pretty easy. I have a 900 lumen 2-emitter
bike headlight (from brlights.com), and it is impressively bright, able to
illuminate most of my backyard.
b) besides lumens, what determines reach? I would have thought it would be
a simple combination of the amount of light energy, and the beam shape (aka,
reflector design). Are there other variables involved? Do certain colour
temperatures tend to illuminate further?
Chris
I'm curious:
a) how many lumens are typical HID landing lights? The newest Cree emitters can put out 1000 lumens per emitter, and hooking up more than one of these emitters into a single unit is pretty easy. I have a 900 lumen 2-emitter bike headlight (from brlights.com (http://brlights.com)), and it is impressively bright, able to illuminate most of my backyard.
b) besides lumens, what determines reach? I would have thought it would be a simple
combination of the amount of light energy, and the beam shape (aka, reflector
design). Are there other variables involved? Do certain colour temperatures
Chris
> [b]
For a good landing light to reach out 1000 ft or more you must be able collimate
(sp) the light. Something that so far cannot be done so well or easily with
LED. With a high output LED you must maintain control of the junction temps. LED's
dont perform all that well with parabolic reflectors.
35 watt (bulb watts) HID at 4200K 3200 lumens, 50 watts HID (bulb watts) ~5500
lumens, 75 watt HID (bulb watts) 8000+ lumens.
http://forums.matronics.com/viewtopic.php?p=271312#271312
Sorry guys, I did not weight the belts. But..my CG is pretty far aft and if
I was building another RV-10 I would reconsider a couple of things in order
to move the CG forward. But I WOULD NOT give up the belts. Examples:
ELT
O2 System (Currently behind the bulkhead)
Battery(1 925 in tray)
Rene' Felker
RV-10 N423CF Flying
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, November 05, 2009 9:30 PM
standard?
_____
(Michael Sausen)
Michael
standard?
Jeff Carpenter
40304
href="http://www.matronics.com/contribution">http://www.matronics.com/chref
"http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navi
gator?RV10-List
One thing that will help the CG is a 680 on the firewall on the lower right
side and tied to a toggle breaker on the essential bus. You will get
automatic trickle charge and additional backup or avionics, but you will
need some isolation from the extra battery to avoid including it in the
start. I put an automotive fuse on the positive lead at the battery terminal
just in case the positive lead might come loose and flail around and ground.
don't want to weld anything in flight.
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: Friday, November 06, 2009 7:27 AM
ELT
Rene' Felker
RV-10 N423CF Flying
801-721-6080
standard?
_____
(Michael Sausen)
Michael
standard?
Jeff Carpenter
40304
gator?RV10-List
Hi Sheldon=2C
If you are interested in the TAA deduction that Tim mentioned=2C here is a
simplified requirement list. It will knock 10% off.
Vern Smith (#324 finishing?)
> From: saolesen(at)sirentel.net
> Date: Thu=2C 5 Nov 2009 09:53:52 -0600
> Sheldon Olesen
> N475PV 119 hrs
Windows 7: Unclutter your desktop.
http://go.microsoft.com/?linkid=9690331&ocid=PID24727::T:WLMTAGL:ON:WL:
en-US:WWL_WIN_evergreen:112009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=
Subject: | Re: AMSAFE seat belts |
Kinda helps blow away that myth that the CG in the -10 is too far
forward and it's "nose heavy", doesn't it. :)
My opinion personally is that the RV-10's nose-heavyness should
not be something people should intentionally try to change,
because in the end they're likely going to find that they
WISHED they had the CG more forward. It used to be that
some people thought they wanted everything up front to be
lighter (i.e. props, and all the accessories) to help "fix"
the nose-heaviness. I think that in reality, the more you
take off the nose, the more CG worry you're going to
end up with, so best to just build the plane not considering
the plane to have any "nose heaviness" to "fix".
If you build it in a normal way, you will naturally be less
nose heavy than the Van's prototypes...because you'll already
have more interior features.
Tim Olson - RV-10 N104CD
Rene Felker wrote:
> Sorry guys, I did not weight the belts. Butmy CG is pretty far aft
> and if I was building another RV-10 I would reconsider a couple of
> things in order to move the CG forward. But I WOULD NOT give up the
> belts. Examples:
> ELT
> O2 System (Currently behind the bulkhead)
> Battery(1 925 in tray)
> Rene' Felker
> RV-10 N423CF Flying
> 801-721-6080
> *From:* owner-rv10-list-server(at)matronics.com
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *David McNeill
> *Sent:* Thursday, November 05, 2009 9:30 PM
> *To:* rv10-list(at)matronics.com
> *Subject:* RE: RV10-List: AMSAFE seat belts
> Below is my reply to Jeff. I do believe that if you use the standard
> hardpoints and regular belts that you should at least use a CS stainless
> washer under the screw. This will spread the load on the glass and make
> a pull though more difficult.
> don't know for sure but the total weight of four AMSAFE belts IIRC is
> less than 10 pounds. Incrementally I would say an additional 2-4 pounds
> over the standard belts. You add 4 3'x3'x1/2'' aluminum blocks and four
> rollers Check with Rene as he probably weighed the alternatives.
> The existing hardpoints were deemed inadequate (for the AMSAFE
> application) by both AMSAFE and consultant (PhD, ME Caltech) who lives
> nearby. The vans hardpoints are setup for a single #5 counter sunk
> screw. This is installed without CS washer that would be required to
> spread the load. My ME consultant friend tells me that the normal use of
> the regular belts will cause micro fractures and may fail (pull through)
> if and when a crash occurs. AMSAFE commented that they would sell me the
> belts if I "beefed up" the existing hardpoints. Since the roller have
> screws for attaching the brackets I needed a means to attach the
> bracket Since I did not want 16 protruding though the lid I used the
> aluminum blocks (2024T3 or 7075) . These were tapped for 4 external
> screws to hold the pad that holds the roller. Each external screw has a
> .75" CS stainless washer and thereby spreading the load on the lid. In
> addition since the shoulder straps are on inertial reels there is no
> constant shear load on the single screw in the lid. The hardpoints areas
> were strengthened by additional E-glass and S-glass tapes. The
> calculations of the ME ,while informal, indicated that relative
> strengths could compared by comparing the surface areas of the
> fasteners. Hope this helps.
> I've got a couple of questions David:
> How much weight are we adding with the inertia reel belts as opposed to
> the standard?
> The hard points you show in you installation pictures are much more
> elaborate than what Vans provides for the stock belts. Is there a
> reason the inertia belts require more support, or do you feel the Vans
> hard points aren't enough for either approach
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *RV Builder
> (Michael Sausen)
> *Sent:* Thursday, November 05, 2009 7:01 PM
> I think the overall concern is that the factory hardpoints are just
> not enough. I believe, as David said, AMSafe was concerned that
> additional reinforcement would up the safety margin. I know I feel a
> lot better after putting a couple of intersecting layers of S glass over
> the hardpoints.
> Michael
> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jeff Carpenter
> *Sent:* Thursday, November 05, 2009 4:20 PM
> *Subject:* Re: RV10-List: AMSAFE seat belts
> the standard?
> hard points aren't enough for either approach?
> Jeff Carpenter
> 40304
> Finishing the inside of the cabin top... and making provisions for the belts
> On Nov 3, 2009, at 9:46 AM, David McNeill wrote:
> www.inertialbelts.com <http://www.inertialbelts.com> is on line again.
> The belts are shown in my Glastar as the belts were not installed in my
> 10 at that time. Rene has good pictures of the final finish. I will
> enclose one of his here.
> *www.aeroelectric.com*
> *www.buildersbooks.com*
> *www.homebuilthelp.com*
> *http://www.matronics.com/contribution*
> *http://www.matronics.com/Navigator?RV10-List*
> *http://forums.matronics.com*
> *href="http://www.aeroelectric.com">www.aeroelectric.com*
> *href="http://www.buildersbooks.com">www.buildersbooks.com*
> *href="http://www.homebuilthelp.com">www.homebuilthelp.com*
> *href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List*
> *href="http://forums.matronics.com">http://forums.matronics.com*
> *www.buildersbooks.com <http://www.buildersbooks.com>*
FWIW, a forward CG is safer than an AFT CG.....
Grumpy
N184JM
>> aft and if I was building another RV-10 I would reconsider a couple
>> of things in order to move the CG forward. But I WOULD NOT give up
>> the belts. Examples:
>> ELT
>> Rene' Felker
>> RV-10 N423CF Flying
>> 801-721-6080
>> *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com
>> standard hardpoints and regular belts that you should at least use
>> a CS stainless washer under the screw. This will spread the load on
>> the glass and make a pull though more difficult.
>> IIRC is less than 10 pounds. Incrementally I would say an
>> additional 2-4 pounds over the standard belts. You add 4
>> 3'x3'x1/2'' aluminum blocks and four rollers Check with Rene as he
>> lives nearby. The vans hardpoints are setup for a single #5 counter
>> sunk screw. This is installed without CS washer that would be
>> required to spread the load. My ME consultant friend tells me that
>> the normal use of the regular belts will cause micro fractures and
>> may fail (pull through) if and when a crash occurs. AMSAFE
>> commented that they would sell me the belts if I "beefed up" the
>> existing hardpoints. Since the roller have screws for attaching the
>> brackets I needed a means to attach the bracket Since I did not
>> want 16 protruding though the lid I used the aluminum blocks
>> (2024T3 or 7075) . These were tapped for 4 external screws to hold
>> the pad that holds the roller. Each external screw has a .75" CS
>> no constant shear load on the single screw in the lid. The
>> hardpoints areas were strengthened by additional E-glass and S-
>> glass tapes. The calculations of the ME ,while informal, indicated
>> that relative strengths could compared by comparing the surface
>> areas of the fasteners. Hope this helps. I've got a couple of
>> questions David:
>> opposed to the standard?
>> Vans hard points aren't enough for either approach
>> ] *On Behalf Of *RV Builder (Michael Sausen)
>> just not enough. I believe, as David said, AMSafe was concerned
>> that additional reinforcement would up the safety margin. I know I
>> feel a lot better after putting a couple of intersecting layers of
>> S glass over the hardpoints.
>> Michael
>> Vans hard points aren't enough for either approach?
>> Jeff Carpenter
>> 40304
>> the belts
>> again. The belts are shown in my Glastar as the belts were not
>> installed in my 10 at that time. Rene has good pictures of the
>> final finish. I will enclose one of his here.
From: | Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> |
Agreed, if you are going to nudge the edges of the envelope. Heavier on
the controls versus lighter, less efficient versus more efficient, etc.
I like to think, "in the envelope is good, out of the envelope grounds
the aircraft". Understanding where you are in the acceptable range
allow you to adjust your technique, e.g. carrying trim or power in the
flare.
Bill "who knows nothing about the '10..... yet" Watson
> Grumpy
> N184JM
>>> ELT
>>> Rene' Felker
>>> RV-10 N423CF Flying
>>> 801-721-6080
>>> McNeill
>>> stainless washer under the screw. This will spread the load on the
>>> IIRC is less than 10 pounds. Incrementally I would say an additional
>>> 2-4 pounds over the standard belts. You add 4 3'x3'x1/2'' aluminum
>>> blocks and four rollers Check with Rene as he probably weighed the
>>> alternatives.
>>> may fail (pull through) if and when a crash occurs. AMSAFE commented
>>> that they would sell me the belts if I "beefed up" the existing
>>> hardpoints. Since the roller have screws for attaching the brackets
>>> I needed a means to attach the bracket Since I did not want 16
>>> protruding though the lid I used the aluminum blocks (2024T3 or
>>> 7075) . These were tapped for 4 external screws to hold the pad that
>>> holds the roller. Each external screw has a .75" CS stainless washer
>>> and thereby spreading the load on the lid. In addition since the
>>> shoulder straps are on inertial reels there is no constant shear
>>> load on the single screw in the lid. The hardpoints areas were
>>> fasteners. Hope this helps. I've got a couple of questions David:
>>> to the standard?
>>> a lot better after putting a couple of intersecting layers of S
>>> Michael
>>> Carpenter
>>> to the standard?
>>> Jeff Carpenter
>>> 40304
>>> the belts
>>> installed in my 10 at that time. Rene has good pictures of the final
Subject: | Re: Voyager Lifetime chart subscription |
Voyager's lifetime subscription offer has prompted me to consider one of their
EFB packages. Does anyone have experience with both their Skypad and the AV8OR
ACE unit? Is there something that I am missing about the AV8OR that makes it
worth nearly another $1000? My panel has dual Cheltons, AF3400EE as a backup efis,
WSI weather and Freeflight WAAS, so I am thinking the AV8OR would not offer
any new functions.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=271415#271415
Subject: | Mainteance for Grass or unimproved strip landings |
Last July I prepared my RV-10 for landing on a grass strip and wanted to sh
are an item I believed to be helpful.
I have 325 hrs on the aircraft and decided to check the nose strut for prop
er adjustment. With a caliper and using one of the previously discussed tec
hniques for lifting-the nose I measured the length of the compression str
ucture (mooney pucks) with the nose loaded and unloaded. It was quite easy
and showed that there was .200 inches of slop. I shimmed out .190 leaving .
010" to install the cap and bolt.
This raised the tip of my prop over 2" providing what is probably the desig
n ground clearance. The plane looks perfectly level.
Its just something to address once in a while and could also be valuable fo
r a hard landing on any surface.
Bill DeRouchey
N939SB, flying with no prop dings
I think you're right on... You'd get little use out of a handheld. If
you had a much more meager panel, then maybe. I know almost nothing
about their hardware, but I suggest getting something that runs it
well and absolutely essential is an SSD. I run an old LE1600, and a
while back I bought one and put an SSD in it for a friend for a total
of about $800 with chargers. I wouldn't go less powerful than that.
I'm actually considering buying another or an LS800 or something for
Andrea to use in place of a handheld for the cherokee. The software
does all you really need, if you couple it to a GPS. Just make sure
your airplane pc has Bluetooth.
> one of their EFB packages. Does anyone have experience with both
> their Skypad and the AV8OR ACE unit? Is there something that I am
> missing about the AV8OR that makes it worth nearly another $1000? My
> panel has dual Cheltons, AF3400EE as a backup efis, WSI weather and
> Freeflight WAAS, so I am thinking the AV8OR would not offer any new
> functions.
> Jim Berry
> 40482
> N15JB
Agreed. I do think the "stock" RV-10 is a bit nose heavy. I ended up
with a CG a bit further aft than optimum because I put in the
Flightline AC air conditioning system and installed an MT propeller.
I think that having the extra weight of the Hartzell up front would
probably help a bit. As it is, I can put four normal size adults in
the airplane but will have to restrict my luggage to around 35 lbs.
About 98% or our flying is just Mary and I, so doesn't really slow us
down, but I am pretty careful about it.
David Maib
40559
Flying
> ELT
> Rene' Felker
> RV-10 N423CF Flying
> 801-721-6080
> questions David:
> more elaborate than what Vans provides for the stock belts. Is
> there a reason the inertia belts require more support, or do you
> feel the Vans hard points aren't enough for either approach
> list-server(at)matronics.com] *On Behalf Of *RV Builder (Michael Sausen)
> Michael
> feel the Vans hard points aren't enough for either approach?
> Jeff Carpenter
> 40304
> the belts
Subject: | Tailcone / Fuse Template |
I managed to chew up my template, so I'm wanting to double check my work
before committing some new holes into my longerons. J
Can I get one of you with the longeron template measure the edge
distance (on the template) for the aft four bolt holes that hold the
tailcone to the fuse?
I've got the hole spacings and distances from the trailing edge of the
longeron, but I need the edge distance because my edge is pretty chewed
Phil
Subject: | Emp Fairing - Inlet |
Earlier this week I had the tail feathers bolted in their final position
and then removed them for storage. While they were on I threw on the
EMP fairing just to get an idea how close it would be and as I expected
I've got quite a bit of work to do on it.
So since I'll be doing major plastic surgery on it, I was thinking about
adding a ram air inlet similar to this one on Tim's site.
http://www.myrv10.com/tips/mods/OverheadVent/index.html
But then the thought crossed my mind.... What about water?
What's the secret to keeping water out of the scat tubing? Rain on the
ramp, in flight, or just flying in wet clouds could pile up some water
pretty quickly.
Phil
Subject: | Please Make A Contribution To Support Your Lists |
Dear Listers,
There is no advertising income to support the Matronics Email Lists and Forums.
The operation is supported 100% by your personal Contributions during the November
Fund
Raiser.
Please make your Contribution today to support the continued operation and upgrade
of these services. You can pick up a really nice gift for making your Contribution
too!
You may use a Credit Card or Paypal at the Matronics Contribution Site here:
or, you can send a personal check to the following address:
Matronics / Matt Dralle
PO Box 347
Livermore, CA 94551-0347
Thank you in advance for your generous support!
Matronics Email List and Forum Administrator
I dunno what Tim used but on the Mooney I used to own that had an inlet in
the roof (later models moved it to the empennage fairing) and used a 1/4 ID
diameter rubber hose that drained via a fitting out the bottom of the
fuselage.
Richard Bibb
972-771-2598
972-835-5979 mobile
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Friday, November 06, 2009 11:35 PM
Subject: RV10-List: Emp Fairing - Inlet
Earlier this week I had the tail feathers bolted in their final position and
then removed them for storage. While they were on I threw on the EMP
fairing just to get an idea how close it would be and as I expected I've got
But then the thought crossed my mind.. What about water?
pretty quickly.
Phil
From: | "Wayne Edgerton" <wayne.e(at)grandecom.net> |
Subject: | Re: Emp Fairing - Inlet |
Phil,
I install a drain tube that runs from the inlet area down to the bottom
of the fuselage where I installed drain fitting of sort that lets the
moisture exit the plane.
If you would want any photos of what I did, let me know.
Wayne Edgerton N602WT
Subject: Emp Fairing - Inlet
position
the
expected
about
on the
water
pretty quickly.
Phil
Subject: | Re: Tailcone / Fuse Template |
The holes in my template got a bit elongated as well but here's what I mea
sured from the end of the template:
3/8", 1 1/8", 1 7/8", 2 5/8"
Steve Weinstock
40230 fuse and engine
-----Original Message-----
Sent: Fri, Nov 6, 2009 11:18 pm
Subject: RV10-List: Tailcone / Fuse Template
I managed to chew up my template, so I=99m wanting to double check
my work before committing some new holes into my longerons. J
Can I get one of you with the longeron template measure the edge distance
(on the template) for the aft four bolt holes that hold the tailcone to
the fuse?
I=99ve got the hole spacings and distances from the trailing edge of
the longeron, but I need the edge distance because my edge is pretty chew
ed .
Phil
-= -- Please Support Your Lists This Month --
-= (And Get Some AWESOME FREE Gifts!)
-= November is the Annual List Fund Raiser. Click on
-= the Contribution link below to find out more about
-= this year's Terrific Free Incentive Gifts provided
-= by:
-= * AeroElectric www.aeroelectric.com
-= * The Builder's Bookstore www.buildersbooks.com
-= * HomebuiltHELP www.homebuilthelp.com
-= List Contribution Web Site:
-= --> http://www.matronics.com/contribution
-= Thank you for your generous support!
-= -Matt Dralle, List Admin.
-= - The RV10-List Email Forum -
-= Use the Matronics List Features Navigator to browse
-= the many List utilities such as List Un/Subscription,
-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
-= Photoshare, and much much more:
-= --> http://www.matronics.com/Navigator?RV10-List
-= - MATRONICS WEB FORUMS -
-= Same great content also available via the Web Forums!
-= --> http://forums.matronics.com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Hey Phil,
It's been a while since we did this, but I think I remember this edge distance
being important -- after the fact. Make sure you get the holes close enough to
the edge so that the nuts will turn; and no more, so that installation works
and you still have structural integrity. We ended up using a nut to get the
distance.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Painting done!
On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p=271570#271570
Hi Lew,
Yeah, I asked a couple of questions around this topic a few weeks ago
and Bob Leffler helped me out with the measurements.
But late last night I built a mock up of the longerons and tested the
hole positions. Unfortunately I couldn't keep the washers off the
fillet curve and moving the hole further to the edge compromised the 2D
edge distance for #12 (AN3) holes. The only way I can really keep the
washers flat on the aluminum is to compromise edge clearance by 1/32 or
2/32 (1/16th).
That's why I am curious to see what the real measurements on the
template are. I'm curious to know if Vans intentionally compromised the
edge distance a bit to get flat washers. It's 1/8" aluminum angle, so I
could see them cheating a bit.
But before I commit holes, I want to be absolutely sure. :)
Another option that came up is to maintain the proper edge distance, but
file the washer down where it intersects the fillet curve. Then prime
the washer where the cadmium plate was removed.
Phil
From: Lew Gallagher [mailto:lewgall(at)charter.net]
Sent: Saturday, November 07, 2009 11:48 AM
Subject: RV10-List: Re: Tailcone / Fuse Template
Hey Phil,
distance being important -- after the fact. Make sure you get the holes
close enough to the edge so that the nuts will turn; and no more, so
that installation works and you still have structural integrity. We
ended up using a nut to get the distance.
Later, - Lew
non-pilot
Painting done!
----- Original Message -----
Sent: Saturday, November 07, 2009 1:05 PM
Subject: RE: RV10-List: Re: Tailcone / Fuse Template
Yup, filed the washers. Later, - Lew
> Hi Lew,
> 2/32 (1/16th).
> Phil
From: | "johngoodman" <johngoodman(at)earthlink.net> |
Grind down the washer.
#40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel
delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=271575#271575
Linn,
I got it about 4 months ago. The one box I still have no is the
Vetterman exhaust. It says 2 of 2 on the box and is 33" x 11" x 18" weighing 30
to 40 lbs. The other box was probably about the same, maybe a little
heavier.
Dave Syvertson
In a message dated 11/7/2009 3:22:03 P.M. Central Standard Time,
pitts_pilot(at)bellsouth.net writes:
--> RV10-List message posted by: Linn Walters
Anyone remember what their FWF kit weighed??? Cost???
Linn
Subject: | Brake Exit Hole Redux |
Hi
After reading the posts of some builders who inadvertently enlarged the hole
in the gear mount, I can sympathize after looking at the plans. They are vey
misleading especially when considering that the hole in the gear mount (at
least mine is) is undersized.
Can anyone tell me where in the plans we are instructed to enlarge this
hole? From what I can see, it should be at least 7/16 to take the AN4
fitting.
Inquiring minds need to know.
Les
#40643 - Not quite out of fibreglass hell, but on a day pass
I'm at the point of assembling doors and want to change to the flush latches/handles.
For those who have installed flush handles, how far can I go with assembly
of doors before I need to alter plans for the alternate mechanism? Can I
proceed as if I were going ahead with supplied parts and change later? I've
seen a couple photos of the flush handles, but not sure how many different types
are available or where to obtain them? Thanks in advance,
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=271631#271631
From: | Dave Saylor <dave.saylor.aircrafters(at)gmail.com> |
If Albert or others from Yuma are on the list, can you drop me a line? I'll
be there for Thanksgiving wondered where to park, fuel, etc.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
Hi Les,
I'm the guilty one for initiating the initial thread. And yes, the
plans are still confusing and I know what I'm doing at this point. J
The hole in the landing gear mount was probably drilled correctly, but
the powder coatings has shrunk the hole. The correct hole size is 7/16"
in the landing gear mount and 5/8" in the bottom skin.
Phil
Sent: Saturday, November 07, 2009 7:26 PM
Subject: RV10-List: Brake Exit Hole Redux
Hi
hole in the gear mount, I can sympathize after looking at the plans.
They are vey misleading especially when considering that the hole in the
gear mount (at least mine is) is undersized.
fitting.
Les
Dave
I installed Steve Deniri's flush handles along with the flush locks. Go to
http://www.iflyrv10.com to see them. They were installed after the doors
were assembled - easily done. They are a very nice touch!
Don't forget to use the billet door blocks.
Cheers
Les
#40643 - Lost in fibreglass hell
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave
Sent: November-07-09 7:44 PM
Subject: RV10-List: doors & latches
latches/handles. For those who have installed flush handles, how far can I
go with assembly of doors before I need to alter plans for the alternate
mechanism? Can I proceed as if I were going ahead with supplied parts and
change later? I've seen a couple photos of the flush handles, but not sure
how many different types are available or where to obtain them? Thanks in
advance,
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
From: | "Lenny Iszak" <lenard(at)rapiddecision.com> |
Linn,
I'd suggest go with Partain. They are set up to transport aircraft parts and they
do it with care, unlike ABF.
ABF delivered my tail kit. It said "high dollar aircraft parts" on the box, with
huge letters. Also two big arrows pointing up and " this side up" next to it.
Guess which side was up in the truck... ABF just doesn't care.
Lenny
http://forums.matronics.com/viewtopic.php?p=271640#271640
It actually depends on what you are getting shipped. If it's just the empennage,
I'd choose the cheapest. Quick build wings and fuselage need a lot of care,
and I'm glad I used Partain.
delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=271694#271694
Subject: | bottom cowling alignment |
I am working on the cowling and have the top lined up precisely. The
bottom cowl alignment has me stumped however. The aft lower section is
flush on the 1001Q as well as the skins along the fusellage on the
bottom and sides. Everything looked great until I took the spacers off
for the side hinge (47 pg 6 step 11) now the bottom cowling forward
section (behind the spinner) is very close (aka the 1/8 space is now
more like 1/32) Thinking I did something wrong I went back and realigned
the bottom, again everything lines up but the bottom area is the same.
Any ideas?
Thanks!
Pascal
Subject: | Re: doors & latches |
I believe you can go all the way before installing the handle and/or
lock. The installation is an add-on to the base install. A very minor
mod to the main hardware assembly involves replacing the stock handle
and button with big button (don't remember the details since it was a
while ago). The billet flush handle and key lock can go in anytime.
I just finished the billet handle and key lock. They look good but I'm
somewhat sorry I didn't stick with the stock setup. Turning the stock
handle into a nice teardrop would remove a lot of the clunkiness.
Adding just the keylock would proved the added security if desired.
But it took a bit more time than I would have liked and I still have to
create some sore of bubble to contain the keylock and handle mechanism.
Both (either) are thicker than the door by a slight amount - a fact not
covered in the plans. And I worry a bit about the ruggedness of the
whole assembly in actual operations.
I don't recall what vintage billet handle and lock that I have but I did
get it over a year ago.
Bill "mounting the canopy - windows in by Christmas" Watson
I proceed as if I were going ahead with supplied parts and change later? I've
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
Subject: | Re: bottom cowling alignment |
Sounds like you have to go back and extract more material from the firewall area
- very slowly and carefully - perhaps on both the top and bottom halves. It
is an exasperating job and must be done slowly and very carefully to keep the
fit at the spinner correct.
Note of caution: My cowling wound up a bit offset to the right - maybe only 1/4
inch offset as you look at it from the pilot seat. This seems like an almost
absurdly small error, but when I went flying (after the engine settled on its
mounts) the #2 cylinder valve cover (front left) hit the cowling during power
changes and at start -up. Solution - I had to put a dent in the valve cover (again
very carefully)n to prevent the terrible vibrations.
OSH '10 or Bust
Q/B Kit - phase 1
http://forums.matronics.com/viewtopic.php?p=271735#271735
From: | "rv10flyer" <wayne.gillispie(at)yahoo.com> |
I ordered complete RV-10 sb kit Aug 24th, 2009. Partain scheduled to p/u one week
earlier than Van's was going to have ready. I called Barbara and she got it
ready early on Oct 9th. Partain then said they had a full load heading east already.
I decided to wait three weeks for "the best" and save $125. That put me
up to Nov 2nd. Partain said he would get me scheduled for the next trip east.
I call Nov 2nd and he is booked up again. Van's had pulled some of my "paid
for" kit parts to ship to someone else(hope they are enjoying them). Still no
reason not to keep the schedule. Van's can ship remaining items at no charge.
I told Van's to ship my kit on the next reliable commercial company with insurance,
I don't care what it cost. They can deliver 1,750 lbs 1,827 nautical miles
via rocket for all I care. I then was scheduled for pickup Fri Nov 6th. Last
week crating guy was out sick. I am nice and try to understand. Maybe they just
have one crating guy and are swamped with higher priority builders than me.
So, once again waiting patiently for pickup from BAX Global. We'll see next
Friday the 13th...that may just be my lucky day. I run a residential hvac business
by myself. I know exactly when I can do a service call one day out or install
a system 5 weeks out. If I am going to run into problems staying on schedule
I will call my customers. It only takes 3 minutes max. That is $3.50 of my
time. By the way my customers only spend $5,000-$12,000 dollars on a system and
would still be a little irratated if I did not call them. They probably would
cancel and get the competition. I spent $40,000+ with Van's, they have a great
product and reputation. But it seems that most people on both big web sites
talk both of these companies up hence the main reason for choosing an RV and
Partain. Both Van's and Partain were always nice and polite they are just not
great at keeping you informed about your "dream". I am sure once I get the kit
delivered to my shop- all will be better. Just venting a little.
Wayne Gillispie
Builder #40983
RV-10 Kit Ordered 8/24/09
Grayson, Kentucky
http://forums.matronics.com/viewtopic.php?p=271743#271743
From: | Michael Kraus <n223rv(at)wolflakeairport.net> |
You think Van's is bad???.... There are guys waiting over a year
(yes, over a year) for parts from Murphy.... Vans has the nicest
people and close to the best service, may not be up to your
expectation, but it is very good as compared to others......
-Mike
On Nov 8, 2009, at 7:55 PM, "rv10flyer"
> p/u one week earlier than Van's was going to have ready. I called
> Barbara and she got it ready early on Oct 9th. Partain then said
> they had a full load heading east already. I decided to wait three
> weeks for "the best" and save $125. That put me up to Nov 2nd.
> Partain said he would get me scheduled for the next trip east. I
> "paid for" kit parts to ship to someone else(hope they are enjoying
> them). Still no reason not to keep the schedule. Van's can ship
> remaining items at no charge. I told Van's to ship my kit on the
> next reliable commercial company with insurance, I don't care what
> it cost. They can deliver 1,750 lbs 1,827 nautical miles via rocket
> Maybe they just have one crating guy and are swamped with higher!
> priority builders than me. So, once again waiting patiently for
> pickup from BAX Global. We'll see next Friday the 13th...that may
> just be my lucky day. I run a residential hvac business by myself. I
> know exactly when I can do a service call one day out or install a
> schedule I will call my customers. It only takes 3 minutes max. That
> is $3.50 of my time. By the way my customers only spend $5,000-
> $12,000 dollars on a system and would still be a little irratated if
> I did not call them. They probably would cancel and get the
> competition. I spent $40,000+ with Van's, they have a great product
> an RV and Partain. Both Van's and Partain were always nice and
> polite they are just not great at keeping you informed about your
> "dream". I am sure once I get the kit delivered to my shop- al!
> Wayne Gillispie
> Builder #40983
> Grayson, Kentucky
Unfortunately you ran into the buzz saw of Vans trying to catch up with
6 months of Quick Build kit backlog that had just had a bunch of
containers arrive at Vans early Sept. Since they had a lot of money tied
up in these assembled components with a lot of frustrated, not so
patient customers that had been waiting 6 months or more from their
order date, it is easy to see why those kits got priority with both Vans
and Partain, who also had a "dry spell" while Vans had zero Quick build
kits going out.
Not that it makes you any happier, and at times Van's communications
could use some improvement, but the month or two delay in shipping will
be a nat's behind in the overall completion of your kit.
Personally, I ordered my QB kit in February, and got delivery via
Partain, missing some items on Oct 1. My build activities were totally
halted for 4 months.
I don't know if you did or did not send Partain a deposit. IIRC he
doesn't schedule you for a delivery slot until he has the deposit.
Other kit companies have gone through bankruptcies, and other horror
stories. So far, Vans seems to be about as good as it gets in the
homebuilder kit arena. Yes, I would like it to be better, but as long as
I can get reasonable support, parts in relatively reasonable time, and
they are still making a profit, I will be mostly happy.
Kelly
40866
week earlier than Van's was going to have ready. I called Barbara and she got
> Wayne Gillispie
> Builder #40983
> Grayson, Kentucky
I have been flying with the iflyrv10.com billet handles for about a
year now. They look nice and are working fine. However, if I was
doing it again, I would probably stay with the stock setup. Like
Bill, I worry a bit about the ruggedness of the assembly over the
long haul. It is a fair amount of work/time to install the billet
handles. Steve Dinieri is great to work with and puts out really nice
products. I am not disappointed with the product or the support. This
is just one of those things that seemed important to me a couple of
years ago, but looking at it from this vantage point, I don't think I
needed it. I do remember that at the time I bought the billet
handles, Steve's setup was the only one that preserved the very
important feature of the latching setup for the handle in the closed
position. That is pretty critical in the RV-10. That is the reason
that the stock handle is replaced with the button. I don't know what
the competing products look like now. I also put in Steve's door
locks and really like them. Very nice setup and easy to install.
David Maib
40559
Flying
minor mod to the main hardware assembly involves replacing the stock
handle and button with big button (don't remember the details since
it was a while ago). The billet flush handle and key lock can go in
anytime.
I'm somewhat sorry I didn't stick with the stock setup. Turning the
stock handle into a nice teardrop would remove a lot of the
clunkiness. Adding just the keylock would proved the added security
if desired. But it took a bit more time than I would have liked and
I still have to create some sore of bubble to contain the keylock and
handle mechanism. Both (either) are thicker than the door by a
slight amount - a fact not covered in the plans. And I worry a bit
about the ruggedness of the whole assembly in actual operations.
did get it over a year ago.
> flush latches/handles. For those who have installed flush handles,
> how far can I go with assembly of doors before I need to alter
> plans for the alternate mechanism? Can I proceed as if I were
> going ahead with supplied parts and change later? I've seen a
> types are available or where to obtain them? Thanks in advance,
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
From: | Roxanne and Mike Lefever <roxianmike(at)msn.com> |
Speaking of venting............here you go..........here's mine
I am consistently surprised as the complaining that goes on in this mailing
list.........complaints about something not done on the QB?...
......like longerons not cut to the exact final spec?.....some rivet missin
g?........some clecos under a floorboard.......give me a break.............
...if you don't want to build an airplane then don't build an airplane (spo
ken by a true QB building part time in year 6 of my QB!).........its our ch
oice........pay the extra for QB or do it yourself....
....and getting on Van's "arss" about timelines?..........please give me br
eak #2.....
most on this list with deposits in=2C or placed within the last 18 months
heard they lost their QB operation and then heard that they were starting a
new QB operation.......I heard by the way that Van's gave back deposits if
requested due to this issue.....thus all should have "managed thy expectat
ions"
Last but not least=2C LEAD TIMES.........give me a break #3........I starte
d going to Oshgosh in 1973..............and guess what.................I ca
n't count the number of designers selling kits that ripped off their "custo
mers" by not delivering against deposits received...Vans is the longest sur
viving kit company in experimental history.......(frankly as a businessman
I am somewhat concerned about new management/ownership that has taken on th
e obligations of a new building and stocking kit inventory in recent years
to provide short lead times in delivery)................Van himself used to
run the business and survive regardless of the economic conditions because
he didn't make financial commitments to inventory/components until they ha
d an order evidenced by deposits (at least he said that and if you toured t
he plant you didn't see much in the way of inventory)
And last but not least..........whine about Tony Partain or his scheduling?
.....call his competition.........oh wait..........he doesn't have any.....
......or at least any that treat your expensive parts like fine china!
So as a reminder=2C aviation businesses struggle to make it in any enviorme
nt. Experimental aircraft related business have even a tougher time......h
istory provides that evidence.....so while Tiger Woods goes to bed tonight
he should be delivering a thank you to Arnold Palmer=2C we should be thankf
ul we have Van's as a designer/supplier..............everything we do has t
o be evaluated on a relative basis rather than absolute/ideals. Buy a kit
from another kit supplier.........please.............then report back!
Geez I feel so much better..........back to sanding!
Mike Lefever
> Subject: RV10-List: Re: shippers
> From: wayne.gillispie(at)yahoo.com
> Date: Sun=2C 8 Nov 2009 16:55:02 -0800
> To: rv10-list(at)matronics.com
> I ordered complete RV-10 sb kit Aug 24th=2C 2009. Partain scheduled to p/
u one week earlier than Van's was going to have ready. I called Barbara and
she got it ready early on Oct 9th. Partain then said they had a full load
heading east already. I decided to wait three weeks for "the best" and save
$125. That put me up to Nov 2nd. Partain said he would get me scheduled fo
r the next trip east. I call Nov 2nd and he is booked up again. Van's had p
ulled some of my "paid for" kit parts to ship to someone else(hope they are
enjoying them). Still no reason not to keep the schedule. Van's can ship r
emaining items at no charge. I told Van's to ship my kit on the next reliab
le commercial company with insurance=2C I don't care what it cost. They can
deliver 1=2C750 lbs 1=2C827 nautical miles via rocket for all I care. I th
en was scheduled for pickup Fri Nov 6th. Last week crating guy was out sick
. I am nice and try to understand. Maybe they just have one crating guy and
> priority builders than me. So=2C once again waiting patiently for pickup
from BAX Global. We'll see next Friday the 13th...that may just be my lucky
day. I run a residential hvac business by myself. I know exactly when I ca
n do a service call one day out or install a system 5 weeks out. If I am go
ing to run into problems staying on schedule I will call my customers. It o
nly takes 3 minutes max. That is $3.50 of my time. By the way my customers
only spend $5=2C000-$12=2C000 dollars on a system and would still be a litt
le irratated if I did not call them. They probably would cancel and get the
competition. I spent $40=2C000+ with Van's=2C they have a great product an
d reputation. But it seems that most people on both big web sites talk both
of these companies up hence the main reason for choosing an RV and Partain
. Both Van's and Partain were always nice and polite they are just not grea
> Wayne Gillispie
> Builder #40983
> Grayson=2C Kentucky
WUVBSCBtZSB0b28hISEhISAgTm93IGxldCdzIGhhdmUgYW5vdGhlciBkcmluayEhISEgIExvbC4u
Li50aGF0J3Mgd2hhdCB0aGV5IHdvdWxkIHNheSB0byBtZSB3aGVuIEkgd2VudCBvZmYgbGlrZSB0
aGF0ISEhISEgIEZ1bm55IHdhdGNoaW4gc29tZWJvZHkgZWxzZSBkbyBpdCEhISENCg0KUmljayBT
a2VkDQpGbHlpbiB0aGUgY3JhcCBvdXR0YSBteSBTVEFOREFSRA0KQlVJTEQga2l0Li4uLjgwIGhv
dXJzIGFuZCBjb3VudGluZw0KTjI0NlJTDQpEbyBub3QgYXJjaGl2ZQ0KU2VudCB2aWEgQmxhY2tC
ZXJyeSBieSBBVCZUDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBSb3hhbm5l
IGFuZCBNaWtlIExlZmV2ZXIgPHJveGlhbm1pa2VAbXNuLmNvbT4NCkRhdGU6IFN1biwgOCBOb3Yg
MjAwOSAyMDoyNDowOSANClRvOiA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBS
RTogUlYxMC1MaXN0OiBSZTogc2hpcHBlcnMNCg0KDQpTcGVha2luZyBvZiB2ZW50aW5nLi4uLi4u
Li4uLi4uaGVyZSB5b3UgZ28uLi4uLi4uLi4uaGVyZSdzIG1pbmUNCg0KIA0KDQpJIGFtIGNvbnNp
c3RlbnRseSBzdXJwcmlzZWQgYXMgdGhlIGNvbXBsYWluaW5nIHRoYXQgZ29lcyBvbiBpbiB0aGlz
IG1haWxpbmcgbGlzdC4uLi4uLi4uLmNvbXBsYWludHMgYWJvdXQgc29tZXRoaW5nIG5vdCBkb25l
IG9uIHRoZSBRQj8uLi4NCg0KIA0KDQouLi4uLi4ubGlrZSBsb25nZXJvbnMgbm90IGN1dCB0byB0
aGUgZXhhY3QgZmluYWwgc3BlYz8uLi4uLnNvbWUgcml2ZXQgbWlzc2luZz8uLi4uLi4uLnNvbWUg
Y2xlY29zIHVuZGVyIGEgZmxvb3Jib2FyZC4uLi4uLi5naXZlIG1lIGEgYnJlYWsuLi4uLi4uLi4u
Li4uLi4uaWYgeW91IGRvbid0IHdhbnQgdG8gYnVpbGQgYW4gYWlycGxhbmUgdGhlbiBkb24ndCBi
dWlsZCBhbiBhaXJwbGFuZSAoc3Bva2VuIGJ5IGEgdHJ1ZSBRQiBidWlsZGluZyBwYXJ0IHRpbWUg
aW4geWVhciA2IG9mIG15IFFCISkuLi4uLi4uLi5pdHMgb3VyIGNob2ljZS4uLi4uLi4ucGF5IHRo
ZSBleHRyYSBmb3IgUUIgb3IgZG8gaXQgeW91cnNlbGYuLi4uDQoNCiANCg0KLi4uLi5hbmQgZ2V0
dGluZyBvbiBWYW4ncyAiYXJzcyIgYWJvdXQgdGltZWxpbmVzPy4uLi4uLi4uLi5wbGVhc2UgZ2l2
ZSBtZSBicmVhayAjMi4uLi4uDQoNCm1vc3Qgb24gdGhpcyBsaXN0IHdpdGggZGVwb3NpdHMgaW4s
ICBvciBwbGFjZWQgd2l0aGluIHRoZSBsYXN0IDE4IG1vbnRocyBoZWFyZCB0aGV5IGxvc3QgdGhl
aXIgUUIgb3BlcmF0aW9uIGFuZCB0aGVuIGhlYXJkIHRoYXQgdGhleSB3ZXJlIHN0YXJ0aW5nIGEg
bmV3IFFCIG9wZXJhdGlvbi4uLi4uLi5JIGhlYXJkIGJ5IHRoZSB3YXkgdGhhdCBWYW4ncyBnYXZl
IGJhY2sgZGVwb3NpdHMgaWYgcmVxdWVzdGVkIGR1ZSB0byB0aGlzIGlzc3VlLi4uLi50aHVzIGFs
bCBzaG91bGQgaGF2ZSAibWFuYWdlZCB0aHkgZXhwZWN0YXRpb25zIg0KDQogDQoNCiANCg0KTGFz
dCBidXQgbm90IGxlYXN0LCBMRUFEIFRJTUVTLi4uLi4uLi4uZ2l2ZSBtZSBhIGJyZWFrICMzLi4u
Li4uLi5JIHN0YXJ0ZWQgZ29pbmcgdG8gT3NoZ29zaCBpbiAxOTczLi4uLi4uLi4uLi4uLi5hbmQg
Z3Vlc3Mgd2hhdC4uLi4uLi4uLi4uLi4uLi4uSSBjYW4ndCBjb3VudCB0aGUgbnVtYmVyIG9mIGRl
c2lnbmVycyBzZWxsaW5nIGtpdHMgdGhhdCByaXBwZWQgb2ZmIHRoZWlyICJjdXN0b21lcnMiIGJ5
IG5vdCBkZWxpdmVyaW5nIGFnYWluc3QgZGVwb3NpdHMgcmVjZWl2ZWQuLi5WYW5zIGlzIHRoZSBs
b25nZXN0IHN1cnZpdmluZyBraXQgY29tcGFueSBpbiBleHBlcmltZW50YWwgaGlzdG9yeS4uLi4u
Li4oZnJhbmtseSBhcyBhIGJ1c2luZXNzbWFuIEkgYW0gc29tZXdoYXQgY29uY2VybmVkIGFib3V0
IG5ldyBtYW5hZ2VtZW50L293bmVyc2hpcCB0aGF0IGhhcyB0YWtlbiBvbiB0aGUgb2JsaWdhdGlv
bnMgb2YgYSBuZXcgYnVpbGRpbmcgYW5kIHN0b2NraW5nIGtpdCBpbnZlbnRvcnkgaW4gcmVjZW50
IHllYXJzIHRvIHByb3ZpZGUgc2hvcnQgbGVhZCB0aW1lcyBpbiBkZWxpdmVyeSkuLi4uLi4uLi4u
Li4uLi4uVmFuIGhpbXNlbGYgdXNlZCB0byBydW4gdGhlIGJ1c2luZXNzIGFuZCBzdXJ2aXZlIHJl
Z2FyZGxlc3Mgb2YgdGhlIGVjb25vbWljIGNvbmRpdGlvbnMgYmVjYXVzZSBoZSBkaWRuJ3QgbWFr
ZSBmaW5hbmNpYWwgY29tbWl0bWVudHMgdG8gaW52ZW50b3J5L2NvbXBvbmVudHMgdW50aWwgdGhl
eSBoYWQgYW4gb3JkZXIgZXZpZGVuY2VkIGJ5IGRlcG9zaXRzIChhdCBsZWFzdCBoZSBzYWlkIHRo
YXQgYW5kIGlmIHlvdSB0b3VyZWQgdGhlIHBsYW50IHlvdSBkaWRuJ3Qgc2VlIG11Y2ggaW4gdGhl
IHdheSBvZiBpbnZlbnRvcnkpDQoNCiANCg0KQW5kIGxhc3QgYnV0IG5vdCBsZWFzdC4uLi4uLi4u
Li53aGluZSBhYm91dCBUb255IFBhcnRhaW4gb3IgaGlzIHNjaGVkdWxpbmc/Li4uLi5jYWxsIGhp
cyBjb21wZXRpdGlvbi4uLi4uLi4uLm9oIHdhaXQuLi4uLi4uLi4uaGUgZG9lc24ndCBoYXZlIGFu
eS4uLi4uLi4uLi4ub3IgYXQgbGVhc3QgYW55IHRoYXQgdHJlYXQgeW91ciBleHBlbnNpdmUgcGFy
dHMgbGlrZSBmaW5lIGNoaW5hIQ0KDQogDQoNCiANCg0KU28gYXMgYSByZW1pbmRlciwgYXZpYXRp
b24gYnVzaW5lc3NlcyBzdHJ1Z2dsZSB0byBtYWtlIGl0IGluIGFueSBlbnZpb3JtZW50LiAgRXhw
ZXJpbWVudGFsIGFpcmNyYWZ0IHJlbGF0ZWQgYnVzaW5lc3MgaGF2ZSBldmVuIGEgdG91Z2hlciB0
aW1lLi4uLi4uaGlzdG9yeSBwcm92aWRlcyB0aGF0IGV2aWRlbmNlLi4uLi5zbyB3aGlsZSBUaWdl
ciBXb29kcyBnb2VzIHRvIGJlZCB0b25pZ2h0IGhlIHNob3VsZCBiZSBkZWxpdmVyaW5nIGEgdGhh
bmsgeW91IHRvIEFybm9sZCBQYWxtZXIsIHdlIHNob3VsZCBiZSB0aGFua2Z1bCB3ZSBoYXZlIFZh
bidzIGFzIGEgZGVzaWduZXIvc3VwcGxpZXIuLi4uLi4uLi4uLi4uLmV2ZXJ5dGhpbmcgd2UgZG8g
aGFzIHRvIGJlIGV2YWx1YXRlZCBvbiBhIHJlbGF0aXZlIGJhc2lzIHJhdGhlciB0aGFuIGFic29s
dXRlL2lkZWFscy4gIEJ1eSBhIGtpdCBmcm9tIGFub3RoZXIga2l0IHN1cHBsaWVyLi4uLi4uLi4u
cGxlYXNlLi4uLi4uLi4uLi4uLnRoZW4gcmVwb3J0IGJhY2shDQoNCiANCg0KR2VleiBJIGZlZWwg
c28gbXVjaCBiZXR0ZXIuLi4uLi4uLi4uYmFjayB0byBzYW5kaW5nIQ0KDQogDQoNCk1pa2UgTGVm
ZXZlcg0KDQoNCiANCj4gU3ViamVjdDogUlYxMC1MaXN0OiBSZTogc2hpcHBlcnMNCj4gRnJvbTog
d2F5bmUuZ2lsbGlzcGllQHlhaG9vLmNvbQ0KPiBEYXRlOiBTdW4sIDggTm92IDIwMDkgMTY6NTU6
MDIgLTA4MDANCj4gVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQo+IA0KPiAtLT4gUlYxMC1M
aXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAicnYxMGZseWVyIiA8d2F5bmUuZ2lsbGlzcGllQHlhaG9v
LmNvbT4NCj4gDQo+IEkgb3JkZXJlZCBjb21wbGV0ZSBSVi0xMCBzYiBraXQgQXVnIDI0dGgsIDIw
MDkuIFBhcnRhaW4gc2NoZWR1bGVkIHRvIHAvdSBvbmUgd2VlayBlYXJsaWVyIHRoYW4gVmFuJ3Mg
d2FzIGdvaW5nIHRvIGhhdmUgcmVhZHkuIEkgY2FsbGVkIEJhcmJhcmEgYW5kIHNoZSBnb3QgaXQg
cmVhZHkgZWFybHkgb24gT2N0IDl0aC4gUGFydGFpbiB0aGVuIHNhaWQgdGhleSBoYWQgYSBmdWxs
IGxvYWQgaGVhZGluZyBlYXN0IGFscmVhZHkuIEkgZGVjaWRlZCB0byB3YWl0IHRocmVlIHdlZWtz
IGZvciAidGhlIGJlc3QiIGFuZCBzYXZlICQxMjUuIFRoYXQgcHV0IG1lIHVwIHRvIE5vdiAybmQu
IFBhcnRhaW4gc2FpZCBoZSB3b3VsZCBnZXQgbWUgc2NoZWR1bGVkIGZvciB0aGUgbmV4dCB0cmlw
IGVhc3QuIEkgY2FsbCBOb3YgMm5kIGFuZCBoZSBpcyBib29rZWQgdXAgYWdhaW4uIFZhbidzIGhh
ZCBwdWxsZWQgc29tZSBvZiBteSAicGFpZCBmb3IiIGtpdCBwYXJ0cyB0byBzaGlwIHRvIHNvbWVv
bmUgZWxzZShob3BlIHRoZXkgYXJlIGVuam95aW5nIHRoZW0pLiBTdGlsbCBubyByZWFzb24gbm90
IHRvIGtlZXAgdGhlIHNjaGVkdWxlLiBWYW4ncyBjYW4gc2hpcCByZW1haW5pbmcgaXRlbXMgYXQg
bm8gY2hhcmdlLiBJIHRvbGQgVmFuJ3MgdG8gc2hpcCBteSBraXQgb24gdGhlIG5leHQgcmVsaWFi
bGUgY29tbWVyY2lhbCBjb21wYW55IHdpdGggaW5zdXJhbmNlLCBJIGRvbid0IGNhcmUgd2hhdCBp
dCBjb3N0LiBUaGV5IGNhbiBkZWxpdmVyIDEsNzUwIGxicyAxLDgyNyBuYXV0aWNhbCBtaWxlcyB2
aWEgcm9ja2V0IGZvciBhbGwgSSBjYXJlLiBJIHRoZW4gd2FzIHNjaGVkdWxlZCBmb3IgcGlja3Vw
IEZyaSBOb3YgNnRoLiBMYXN0IHdlZWsgY3JhdGluZyBndXkgd2FzIG91dCBzaWNrLiBJIGFtIG5p
Y2UgYW5kIHRyeSB0byB1bmRlcnN0YW5kLiBNYXliZSB0aGV5IGp1c3QgaGF2ZSBvbmUgY3JhdGlu
ZyBndXkgYW5kIGFyZSBzd2FtcGVkIHdpdGggaGlnaGVyIQ0KPiBwcmlvcml0eSBidWlsZGVycyB0
aGFuIG1lLiBTbywgb25jZSBhZ2FpbiB3YWl0aW5nIHBhdGllbnRseSBmb3IgcGlja3VwIGZyb20g
QkFYIEdsb2JhbC4gV2UnbGwgc2VlIG5leHQgRnJpZGF5IHRoZSAxM3RoLi4udGhhdCBtYXkganVz
dCBiZSBteSBsdWNreSBkYXkuIEkgcnVuIGEgcmVzaWRlbnRpYWwgaHZhYyBidXNpbmVzcyBieSBt
eXNlbGYuIEkga25vdyBleGFjdGx5IHdoZW4gSSBjYW4gZG8gYSBzZXJ2aWNlIGNhbGwgb25lIGRh
eSBvdXQgb3IgaW5zdGFsbCBhIHN5c3RlbSA1IHdlZWtzIG91dC4gSWYgSSBhbSBnb2luZyB0byBy
dW4gaW50byBwcm9ibGVtcyBzdGF5aW5nIG9uIHNjaGVkdWxlIEkgd2lsbCBjYWxsIG15IGN1c3Rv
bWVycy4gSXQgb25seSB0YWtlcyAzIG1pbnV0ZXMgbWF4LiBUaGF0IGlzICQzLjUwIG9mIG15IHRp
bWUuIEJ5IHRoZSB3YXkgbXkgY3VzdG9tZXJzIG9ubHkgc3BlbmQgJDUsMDAwLSQxMiwwMDAgZG9s
bGFycyBvbiBhIHN5c3RlbSBhbmQgd291bGQgc3RpbGwgYmUgYSBsaXR0bGUgaXJyYXRhdGVkIGlm
IEkgZGlkIG5vdCBjYWxsIHRoZW0uIFRoZXkgcHJvYmFibHkgd291bGQgY2FuY2VsIGFuZCBnZXQg
dGhlIGNvbXBldGl0aW9uLiBJIHNwZW50ICQ0MCwwMDArIHdpdGggVmFuJ3MsIHRoZXkgaGF2ZSBh
IGdyZWF0IHByb2R1Y3QgYW5kIHJlcHV0YXRpb24uIEJ1dCBpdCBzZWVtcyB0aGF0IG1vc3QgcGVv
cGxlIG9uIGJvdGggYmlnIHdlYiBzaXRlcyB0YWxrIGJvdGggb2YgdGhlc2UgY29tcGFuaWVzIHVw
IGhlbmNlIHRoZSBtYWluIHJlYXNvbiBmb3IgY2hvb3NpbmcgYW4gUlYgYW5kIFBhcnRhaW4uIEJv
dGggVmFuJ3MgYW5kIFBhcnRhaW4gd2VyZSBhbHdheXMgbmljZSBhbmQgcG9saXRlIHRoZXkgYXJl
IGp1c3Qgbm90IGdyZWF0IGF0IGtlZXBpbmcgeW91IGluZm9ybWVkIGFib3V0IHlvdXIgImRyZWFt
Ii4gSSBhbSBzdXJlIG9uY2UgSSBnZXQgdGhlIGtpdCBkZWxpdmVyZWQgdG8gbXkgc2hvcC0gYWwh
DQo+IGwgd2lsbCBiZSBiZXR0ZXIuIEp1c3QgdmVudGluZyBhIGxpdHRsZS4NCj4gDQo+IC0tLS0t
LS0tDQo+IFdheW5lIEdpbGxpc3BpZQ0KPiBCdWlsZGVyICM0MDk4Mw0KPiBSVi0xMCBLaXQgT3Jk
ZXJlZCA4LzI0LzA5DQo+IEdyYXlzb24sIEtlbnR1Y2t5DQo+IA0KPiANCj4gDQo+IA0KPiBSZWFk
IHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQo+IA0KPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j
b20vdmlld3RvcGljLnBocD9wPTI3MTc0MyMyNzE3NDMNCj4gDQo+IA0KPiANCj4gDQo+IA0KPiAN
Cj4gDQo9PT09PT09PT09PT0NCj09PT09PT09PT09PQ0KPT09PT09PT09PT09DQo9PT09PT09PT09
PT0NCj4gDQo+IA0KPiANCiAJCSAJICAgCQkgIA0K
Wayne;
Shame you are getting off to a lousy start.
Van's always kept me updated on my SB kits in the form of a sheet with my
delivery date in each and every kit. I received this and was told when it
was ship and the tracking number on time each time.
They have been great with support, contrary to some feedback many have had,
once one gets past the attitude of 1 person they are patient and
"supportive"
My advice is plan ahead, my engine took months to arrive ( BTW more $ alone
than the complete kit combined) - about 2 months behind schedule, I am told
I was lucky, it usually takes longer, my prop from Vans arrived early, about
1 month, it sat idle for a month before getting installed but it was ready
when I was..
Accept delays and plan for them, I expect my avionics will take a couple of
months to arrive and I will wait until the 61st day before I need it to
order them, mostly because my opinion is subject to change as does
technology.
Have confidence that Van's, the builders and your journey building should be
far better moving forward than your past experience.
The group on this list are all great, you will get venting back because most
of us know what the "other side" is like and know we have it good, in time
ou too will see this.
Best of success in your building.
BTW- it's all about timing and you just happened to fall in to the wrong
time to get a QB. This is unusual.
Pascal
Sent: Sunday, November 08, 2009 4:55 PM
> save $125. That put me up to Nov 2nd. Partain said he would get me
> scheduled for the next trip east. I call Nov 2nd and he is booked up
> again. Van's had pulled some of my "paid for" kit parts to ship to someone
> else(hope they are enjoying them). Still no reason not to keep the
> schedule. Van's can ship remaining items at no charge. I told Van's to
> ship my kit on the next reliable commercial company with insurance, I
> Last week crating guy was out sick. I am nice and try to understand. Maybe
> priority builders than me. So, once again waiting patiently for pickup
> lucky day. I run a residential hvac business by myself. I know exactly
> when I can do a service call one day out or install a system 5 weeks out.
> If I am going to run into problems staying on schedule I will call my
> customers. It only takes 3 minutes max. That is $3.50 of my time. By the
> way my customers only spend $5,000-$12,000 dollars on a system and would
> great product and reputation. But it seems that most people on both big
> web sites talk both of these companies up hence the main reason for
> choosing an RV and Partain. Both Van's and Partain were always nice and
> polite they are just not great at keeping you informed about your "dream".
> Wayne Gillispie
> Builder #40983
> Grayson, Kentucky
Thanks for the information guys. I would like the next guy that does a search for
"shipping" like I did to understand what he is getting into and what his options
are. Van's did a great job and my kit was complete and ready to ship Oct
9th one week earlier than originally scheduled. So, I highly recommend Van's.
You just have to make most of the phone calls if you want to know anything. Not
a complaint just information for the next guy. I will let you know how BAX
Global does.
Wayne Gillispie
Builder #40983
Grayson, Kentucky
http://forums.matronics.com/viewtopic.php?p=271781#271781
Subject: | Fund Raiser List of Contributors - Please Make A Contribution |
Today!
Each year at the end of the List Fund Raiser, I post a message acknowledging everyone
that so generously made a Contribution to support the Lists. Its my way
of publicly thanking everyone that took a minute to show their appreciation for
the Lists.
Won't you take a moment and assure that your name is on that List of Contributors
(LOC)? As a number of members have pointed out over the years, the List seems
at least - if not a whole lot more - valuable as a building/flying/recreating/entertainment
tool as your typical magazine subscription!
Please take minute and assure that your name is on this year's LOC! Show others
that you appreciate the Lists. Making a Contribution to support the Lists is
fast and easy using your Credit card or Paypal on the Secure Web Site:
or by dropping a personal check in the mail to:
Matt Dralle / Matronics
PO Box 347
Livermore CA 94551-0347
I would like to thank everyone that has so generously made a Contribution thus
far in this year's List Fund Raiser! Remember that its YOUR support that keeps
these Lists going and improving! Don't forget to include a little comment about
how the Lists have helped you!
Best regards,
From: | Robert Brunkenhoefer <rebrunk42(at)gmail.com> |
it seems to me that poor business practices are bad no matter who it
is . customers who pay a great deal of money for a product deserve to
be treated with courtesy just like we were taught as children. to say
one is not as bad as another misses the point entirely in my opinion.
robert
> -Mike
> Sent from my iPhone
>> to p/u one week earlier than Van's was going to have ready. I
>> called Barbara and she got it ready early on Oct 9th. Partain then
>> said they had a full load heading east already. I decided to wait
>> three weeks for "the best" and save $125. That put me up to Nov
>> ship remaining items at no charge. I told Van's to ship my kit on
>> the next reliable commercial company with insurance, I don't care
>> what it cost. They can deliver 1,750 lbs 1,827 nautical miles via
>> understand. Maybe they just have one crating guy and are swamped
>> with higher!
>> That is $3.50 of my time. By the way my customers only spend $5,000-
>> Wayne Gillispie
>> Builder #40983
>> Grayson, Kentucky
From: | "George, Neal E Capt USAF ACC 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil> |
I must be the only guy in the country who's had no trouble whatsoever with
ABF...
neal
I had some stuff come via ABF - and had to deal with an after the fact
rear gate lift charge. It was fixed but required a few faxes and
conversations.
Partain was great.
Rick and Sandra Lark wrote:
> Linn
> When I ordered my tail kit in May, I priced ABF freight from Aurora to
> Port Huron, Mi where I planned to cross the Can/US border and bring
> the kit home to Ontario. Vans price with Fed Ex freight was 40% of
> what ABF's price was.
> Need less to say, it wasn't a difficult choice.
> I seem to remember the shipping price was well under $400
> Hope you find the same pricing difference
> Rick
> 40956
> Southampton, Not
I too had great service from them.
Gary Specketer
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of George, Neal E
Sent: Monday, November 09, 2009 9:34 AM
Subject: RE: RV10-List: shippers
ABF...
neal
conversations.
Partain was great.
> Linn
> Rick
> 40956
> Southampton, Not
There are at least two of us......
I've had two ABF shipments with no problems. I did pick both shipments up
at their local terminal. On the other hand my Partain shipment didn't go as
anticipated. The fuselage kit arrived in perfect condition and Tony's
driver did a great job. Tony and I just didn't see eye to eye on a customer
service issue. Since I was the customer, I have a rather biased opinion.
I'll probably send my finish kit with ABF when that time comes.
November 03, 2009 - November 09, 2009
RV10-Archive.digest.vol-ff
