RV10-Archive.digest.vol-fw
January 13, 2010 - January 16, 2010
Finally got out to the Eci page-
http://www.eci.aero/pages/tech.aspx#breakin
Sent: Tuesday, January 12, 2010 12:30 PM
Subject: | Re: IO 540 motor oil? |
I spoke to Lycoming's Bart, He then spoke to the tech department. He
said that the Cortec VC1-326 could be added to a 20w-50 mineral engine
oil in a 1 to 10 ratio. I will be using a syringe to fill the two
cylinders that lost the oil whan I removed the lower plugs.
> Subject: RV10-List: Re: IO 540 motor oil?
> From: Mikeabel(at)Pacbell.net
> Date: Tue, 12 Jan 2010 11:03:16 -0800
> To: rv10-list(at)matronics.com
> Per Ricksked if the engine is new you MUST use straight Mineral Oil
per Lycoming's specs until "the oil consumption stabilizes". Get it from
your local FBO, Spruce, or Chief Aircraft. Be sure to drain all of the
preservative oil from the engine first.
> OSH '10 or Bust
> Q/B - testing phase 1
> http://forums.matronics.com/viewtopic.php?p=281189#281189
Jake those look just fine. You will find you will get the cut and finish
next to the fine line skills will come back fast. Kind of like coloring
book skills as a kid. What helps me get a nice straight edge is I use a 12
in disk sander that is mounted on my shop smith. With the table 90 degrees
to the sanding disk I get a nice clean straight and square edge on material
I am trying to make.
Check Harbor Freight for a cheap table top 8-10 in disc sander there worth
every penny.
John G. Cumins
40864 Emp in primer mode
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JHearnsberger
Sent: Wednesday, January 13, 2010 6:21 AM
Subject: RV10-List: rear spar caps
I clamped, marked, and cut the rear spar caps outside of my line using a
band saw.
My cuts had a couple of gradual waves in them. I worked them out with an air
belt sander and file by clamping the two pieces back to back to try to get
them even.
It is not that big of a deal other than I would like to get as much insight
as possible while starting out. The cut is not perfect, but will it be ok?
Please see attached images.
Also, my air belt sander uses 60 to 120 grit belts. Is this fine enough for
deburring aluminum?
http://forums.matronics.com/viewtopic.php?p=281268#281268
http://forums.matronics.com//files/img_0107_114.jpg
http://forums.matronics.com//files/img_0108_237.jpg
http://forums.matronics.com//files/img_0109_150.jpg
From: | "Brian Steeves" <Brian.Steeves(at)Parkenna.com> |
Vans is way behind on the wing kits. I ordered a slow build end of August and
just received a phone call today that it should ship next week.
http://forums.matronics.com/viewtopic.php?p=281305#281305
Subject: | Cabin Cover Question |
On 43-7 requires the bending the top portion of the F-1042 bulkhead side
channel. My question is how difficult to take the cabin cover off after
making this bend? I'm not ready to put the cabin cover on for good yet.
There is a reference on 43-10 that states the cover is on for good. It
appears to me that it would be darn impossible to take the cover off once
the bulkhead is bent to conform to the cabin cover. I'm just looking for
conformation or denial of my suspicion.
Subject: | Re: Cabin Cover Question |
It's not bad. I've done it a thousand times lately. You just have to
set one side in and pulltje other side around the vended channel. Go
for it!
> side channel. My question is how difficult to take the cabin cover
> off after making this bend? I=99m not ready to put the cabin
cover o
> n for good yet. There is a reference on 43-10 that states the cov
> er is on for good. It appears to me that it would be darn impossib
> le to take the cover off once the bulkhead is bent to conform to the
> cabin cover. I=99m just looking for conformation or denial of
my sus
> picion.
> Thanks,
> Bob
From: | Jeff Carpenter <jeff(at)westcottpress.com> |
not difficult Bob. The side of the cover flexes enough to pull it out
past the bend before you lift it up.
Jeff Carpenter
40304
> off after making this bend? I=92m not ready to put the cabin cover
> on for good yet. There is a reference on 43-10 that states the
> cover is on for good. It appears to me that it would be darn
> impossible to take the cover off once the bulkhead is bent to
> conform to the cabin cover. I=92m just looking for conformation or
> Thanks,
> Bob
Thanks Sean!
How=99s the overhead console coming along?
bob
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
Sent: Wednesday, January 13, 2010 3:12 PM
Subject: Re: RV10-List: Cabin Cover Question
It's not bad. I've done it a thousand times lately. You just have to set
one side in and pulltje other side around the vended channel. Go for
it!
after making this bend? I=99m not ready to put the cabin cover
on for good yet. There is a reference on 43-10 that states the cover
is on for good. It appears to me that it would be darn impossible to
take the cover off once the bulkhead is bent to conform to the cabin
cover. I=99m just looking for conformation or denial of my
suspicion.
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic
ontribution
Great! It fit really well and it's glued on for good. I have been
taking the canopy off and on for the door fitting. It was really hard
for me to figure out the steps of the canopy. I was afraid to mount the
canopy with clecos and fit the doors so I have been bolting and clecoing
the entire canopy for the doors. I then have to take it back off and
sand and fill so I can paint the interior. I am 90 percent sure right
now that I will be painting the canopy instead of using a headliner. I
could do either one with the overhead console. It has been easy to
blend because the lip is so thin. I am doing some stuff with the
aluminum inserts for lighting and I will be taking some pics soon. I
had to work today so I am in BOI and away from my baby. Call me if you
have any questions.
801-580-3737
----- Original Message -----
Sent: Wednesday, January 13, 2010 1:35 PM
Subject: RE: RV10-List: Cabin Cover Question
Thanks Sean!
bob
for it!
side channel. My question is how difficult to take the cabin cover off
suspicion.
s.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://foru
ms.matronics.comhref="http://www.matronics.com/contribution">http://www
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht
Subject: | Re: rear spar caps |
From: | "JHearnsberger" <jakehearnsberger(at)gmail.com> |
Thank you.
http://forums.matronics.com/viewtopic.php?p=281328#281328
From: | "Albert Gardner" <ibspud(at)roadrunner.com> |
Early on in building I was advised to get a roll of the 3" wide adhesive
backed sand paper usually sold in auto supply houses. You can stick it to
most anything, a socket for small radis, a section of PVC pipe for larger, a
form you cut from wood for the windshield lower fairing, or a short section
of 2x4. Most useful to me was 80 and 220. A long roll was about $33 as I
recall and I used about half a roll in building. Also you might look at a
vixen file.
Albert Gardner
N991RV
Yuma, AZ
Wow, thanks for that info Brian. I think I will order my slow build wings
this week.
Rick
From: "Brian Steeves" <Brian.Steeves(at)Parkenna.com>
Sent: Wednesday, January 13, 2010 1:45 PM
Subject: RV10-List: Re: Wing Kit
> and just received a phone call today that it should ship next week.
What type of scotchbrite wheel? Is it the rolec pad? I am looking for something
to attach to my die grinder. Also, what grit?
Sent from my iPhone.
http://forums.matronics.com/viewtopic.php?p=281348#281348
3M SCOTCH-BRITE DEBURRING WHEEL from Aircraft Spruce
> for something to attach to my die grinder. Also, what grit?
I think I'll take the plunge on the FWF kit before the prices go up at
the end of the month. Are there any items to leave out of the Vans
order (other than the hoses) and source somewhere else? Also, what's
the weight penalty and additional install time for the Throttle
Quadrant?
Jeff Carpenter
40304
... seeing the light at the end of the fiberglass tunnel
Jeff;
Vans now has quality hoses in their kits. I was quite surprised to see
firesleeves on the fluid hoses.
You will need to order the fuel line hose that goes to the fuel injector,
that is not part of the kit.
I ordered mine from Aircraft hoses. they knew what hose I needed.
Pascal
Sent: Wednesday, January 13, 2010 3:49 PM
Subject: RV10-List: FWF Kit
> the end of the month. Are there any items to leave out of the Vans order
> (other than the hoses) and source somewhere else? Also, what's the
> weight penalty and additional install time for the Throttle Quadrant?
> Jeff Carpenter
> 40304
I think I would prefer to use it in a bench grinder. Does anyone have any recommendations
for a good bench grinder to use with the scotchbrite wheel?
Jake
http://forums.matronics.com/viewtopic.php?p=281359#281359
Ooooh, price increases. (I've been waffling on when to order my tail kit,
this might push me over the edge.)
Any word on what the new prices might look like (how much they will go up)?
Chris
On Wed, Jan 13, 2010 at 3:49 PM, Jeff Carpenter wrote:
> I think I'll take the plunge on the FWF kit before the prices go up at the
> end of the month. Are there any items to leave out of the Vans order (other
> than the hoses) and source somewhere else? Also, what's the weight penalty
> Jeff Carpenter
> 40304
They are on the website by now but usually 3 to 5 percent
Done buying for now, next time I get the repeat offender price!!
Rick Sked
N246RS
Flying
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Colohan
Sent: Wednesday, January 13, 2010 4:45 PM
Subject: Re: RV10-List: FWF Kit
Chris
Jeff Carpenter
40304
le, List Admin.
Subject: | Uneven tire wear and brake pad separation |
I've been watching the tire wear, and after 110 hrs, the left( pilot)
side tire is showing extreme wear on the outside of the tire, the Right
is also showing wear on the outside, but not as extreme.
What have others experienced?
So today, I pulled the wheels off and reversed the tires and tubes to
try and get some more wear out of the tires. When pulling the left tire
off the axel, the brake lining for the inboard brake pad dropped to the
floor! It appears that the shoulder that is supposed to hold the rivet
liner to the pad let go, and the rivet heads were "floating" inside of
the countersunk area. Fortunately there is minimal brake wear, and
therefore little movement in the brake when activated. But, if the brake
wear had been greater, there's a possibility that the pad/liner would
have moved and jammed it self against the brake disc. If this had
happened on landing and braking, I wouldn't have wanted to be along for
that ride. Checking with the locals this is a problem that one person
has seen when the rivets holding the liners are set too tight. since
these were the parts that came with the kit from Cleveland, I would
expect that they should have some quality control in their mfg to
eliminate/minimize this. Upon inspection and comparison with the
inboard rivets to the outboard .liner rivets, it appears that they are
'deeper' into the countersunk area , and possibly the shoulder of the
brake material that holds them was thinner and possibly weaker. Anyway
replacement pads on on there way. Something to keep in mind when you do
your conditionals or change tires.
Deems Davis
N519PJ
www.deemsrv10.com
Subject: | oil adapter spacer |
For those who have installed the B&C angled oil adapter, what size
spacer did you need if any?
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
From: | Don McDonald <building_partner(at)yahoo.com> |
Subject: | Re: Uneven tire wear and brake pad separation |
Deems, You did better than I did.... I switched mine at 90 hours... and the
pilot side was worse than the other side.- At the same time I installed
air stop tubes.- Guess It's getting time to get an order together for tir
es.- Brakes looked good.
Which pads did you order?
Any word on the Alaska trip you hinted about?
Weather here in the SAC area has been terrible... at least for flying.- J
ust enough overcast/fog to keep you on the ground.- Going up tomorrow tho
ugh.
Don McDonald
--- On Wed, 1/13/10, Deems Davis wrote:
Subject: RV10-List: Uneven tire wear and brake pad separation
Date: Wednesday, January 13, 2010, 5:14 PM
I've been watching the tire wear, and after 110 hrs, the left( pilot) side
tire is showing extreme wear on the outside of the tire, the Right is also
So today, I pulled the wheels off and reversed the tires and tubes to try a
nd get some more wear out of the tires. When pulling the left tire off the
axel, the brake lining for the inboard brake pad dropped to the floor! It a
ppears that the shoulder that is supposed to hold the rivet liner to the pa
d let go, and the rivet heads were "floating" inside of the countersunk are
a. Fortunately there is minimal brake wear, and therefore little movement i
n the brake when activated. But, if the brake wear had been greater, there'
s a possibility that the pad/liner would have moved and jammed it self agai
nst the brake disc. If this had happened on landing and braking, I wouldn't
have wanted to be along for that ride. Checking with the locals this is a
problem that one person has seen when the rivets holding the liners are set
too tight. since these were the parts that came with the kit from Clevelan
d, I would expect- that they should have some quality control in
their mfg to eliminate/minimize this. Upon inspection and comparison- wi
th the inboard rivets to the outboard .liner rivets, it appears that- the
y are 'deeper' into the countersunk area , and possibly the- shoulder of
the brake material that holds them- was thinner and possibly weaker. Anyw
ay replacement pads on on there way. Something to keep in mind when you do
Deems Davis
N519PJ
www.deemsrv10.com
le, List Admin.
=0A=0A=0A
Subject: | Re: First Flight |
From: | "rv10flyer" <wayne.gillispie(at)yahoo.com> |
Congratulations Jay! Can hardly wait to be where you are. I am 75 hrs into my slow
build. It is going to be the same for me...all 172 time except for some flights
with a friend in his -9A.
Wayne Gillispie
A&P 5/93', PP 10/08'
Grayson, KY
Bldr# 40983
Ordered complete kit 8/24/09
DB Schenker delivered 11/20/09
Starting empennage 11/24/09
http://forums.matronics.com/viewtopic.php?p=281369#281369
Subject: | Re: oil adapter spacer |
Dave, I was a real newbie when I ran into this issue.... and I didn't know
the matronics board existed...- Anyway, I made my own adaptor which attat
ched to the engine, and a second, stock, adaptor went on next.- It looked
to me that the mount needed to be both spaced-rearward and offset.- It
appears to have worked.... engine performing beautifully, with all the rig
ht pressures, for over 100 hours.
Don McDonald
--- On Wed, 1/13/10, Dave Leikam wrote:
Subject: RV10-List: oil adapter spacer
Date: Wednesday, January 13, 2010, 5:42 PM
For those who have installed the B&C angled oil adapter, what size spacer d
id you need if any?
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
=0A=0A=0A
Same for me Deems.....I called Van's and Ken Scott said you and I need to lose
weight....actually my landings are so sweet that I still have the little nibs
on the tire after almost 80 hours :)
Rick
Sent via BlackBerry by AT&T
Date: Wed, 13 Jan 2010 18:14:13
Deems Davis
N519PJ
www.deemsrv10.com
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)cox.net
Sent: Wednesday, January 13, 2010 6:05 PM
Subject: Re: RV10-List: Uneven tire wear and brake pad separation
lose weight....actually my landings are so sweet that I still have the
little nibs on the tire after almost 80 hours :)
Rick
Deems Davis
N519PJ
www.deemsrv10.com
Rick
It is not that you need to loose weight cause if that was the issue the wear
would be in the inside on the outside. Outside wear is very common on
spring steel gear give it time and it might get better as the gear gets more
wear and tare on it. Either that Vans needs to correct the axel angle on
the gear leg it self.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Rick
Deems Davis
N519PJ
www.deemsrv10.com
Dave you will need the adapter=85here is a link to B & C and I think you
need
the .75 or =BE=94=85I really can=92t remember=85I need to go and measure
if someone
else doesn=92t pipe in.
http://www.bandc.biz/oil-filter-adapter.aspx
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Leikam
Sent: Wednesday, January 13, 2010 5:42 PM
spacer
Dave Leikam
RV-10 #40496
N89DA
Muskego, WI
Not my issue!!!! Ken Scott or aka...the ego deflator..told me that...not
really...just thought it was funny that both Deems and I had tire wear on
the left more than the right...you still coming in on the 20th?
Rick
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins
Sent: Wednesday, January 13, 2010 6:20 PM
Subject: RE: RV10-List: Uneven tire wear and brake pad separation
Rick
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Rick
Deems Davis
N519PJ
www.deemsrv10.com
air stop tubes came with the kit.
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Wednesday, January 13, 2010 6:52 PM
pilot side was worse than the other side. At the same time I installed air
stop tubes. Guess It's getting time to get an order together for tires.
Brakes looked good.
Weather here in the SAC area has been terrible... at least for flying. Just
enough overcast/fog to keep you on the ground. Going up tomorrow though.
Don McDonald
<http://us.mc537.mail.yahoo.com/mc/compose?to=deemsdavis@cox.net> >
and get some more wear out of the tires. When pulling the left tire off the
appears that the shoulder that is supposed to hold the rivet liner to the
pad let go, and the rivet heads were "floating" inside of the countersunk
area. Fortunately there is minimal brake wear, and therefore little movement
in the brake when activated. But, if the brake wear had been greater,
there's a possibility that the pad/liner would have moved and jammed it self
against the brake disc. If this had happened on landing and braking, I
wouldn't have wanted to be along for that ride. Checking with the locals
this is a problem that one person has seen when the rivets holding the
liners are set too tight. since these were the parts that came with the kit
from Cleveland, I would expect that they should have some quality control
in their mfg to eliminate/minimize this. Upon inspection and comparison
with the inboard rivets to the outboard .liner rivets, it appears that they
are 'deeper' into the countersunk area , and possibly the shoulder of the
replacement pads on on there way. Something to keep in mind when you do your
Deems atronics.com/Navigator?RV10-List"
target=_blank>http://www.matronics.com/= - MATRONICS cs.com/"
; -Matt Dralle, List Admin=========
One of the easier ways to use a large Scotchbrite wheel is to mount it in a
drill press, and just run the pieces over it. Leaves both hands free to
manipulate/control the piece being deburred. Easier to install and remove
than in a bench grinder. For large/ long pieces, like skins, a small
scotchbrite wheel in a die grinder or hand drill works fine.
On Wed, Jan 13, 2010 at 5:35 PM, JHearnsberger
> recommendations for a good bench grinder to use with the scotchbrite wheel?
> Thanks,
> Jake
I forgot to mention, generally you will get smoother results if the piece is
parallel to the rotating wheel, not the axis it is rotating about. That is
why the wheel on horizontal axis with shaft vertical works well with long
pieces held horizontal.
>> Thanks,
>> Jake
What a great tip! Thank you.
I found the 7a wheels here http://solutions.3m.com/wps/portal/3M/en_US/Manufacturing/Industry/Product-Catalog/Online-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQGLE0_nid=8ZFZHRFX71beH55CPWS904gl
I am hoping I can find it locally somewhere.
http://forums.matronics.com/viewtopic.php?p=281387#281387
Most of the tool kit suppliers include a large wheel as part of their
kits and sell separately. They aren't cheap, but one should do you for
the entire build process.
On Wed, Jan 13, 2010 at 9:14 PM, JHearnsberger
They are around 50$ I am 99 percent done with the aluminum parts and
I'm on number three??? I know other builders that just used one or two
Though the scotch-brite wheel is very useful, I ultimately found that
skins and long parts that were difficult to get to the wheel were
easily deburred with a large vixen file run a few times along an edge
at different angles. It's also pretty easy to overwork a part with
Jeff Carpenter
40304
Yearning for the good old days of metal work... when fiberglass was
far off in the future
>> - The RV10-List --> &n=======================
After 750 hours our tires still wear on the outside. The tires sit fairly straight
when on the ground, but most of the wear comes from the little squeek when
the tires go from 0-60kts at touchdown. When flying, the outside of the tire
is lower than the inside. The more landings you do, the more your tires will
wear. We just got about 150+ hours on the outside and just rotated them to
the inside. The nose tire was just replaced. How have people been seeing the
wear on the nose? It should be much less than the mains, or course, unless you
get a bad shimmy, but I don't remember if we have changed that before or not.
I'd have to go back and check through the logs.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 13, 2010, at 9:19 PM, John Cumins wrote:
> Rick
> John G. Cumins
> President
> 2499 B1 Martin Rd
> Fairfield Ca 94533
> 707-425-7100
> 707-425-7576 Fax
> From: owner-rv10-list-server(at)matronics.com
> Rick
> From: Deems Davis <deemsdavis(at)cox.net>
> To:
> Deems Davis
> N519PJ
> www.deemsrv10.com
I'm using one of these el cheapo $40 ones - works fine, price is right,
and it comes with a polishing wheel.
<http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43533>
Replacement wheel kits are cheap $6:
<http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43758>
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
From: | Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> |
The vixen file seems to be the ideal tool for dressing the edges of
tail/wing skins. I had no idea what it was or how to use it but I
described what I found out in a post - search the archives for 'Vixen'
and look for my post (I can't find the supporting pics). A very useful
tool and very basic technique for skin deburring. Very productive.
I found that the scotchbrite wheel in a floor mounted bench grinder to
be by far the tool I use the most. Still do. I'm on my second wheel at
3+ years of a 4 year QB. The drill press thing sounds good - never
thought about the axis thing but I wouldn't want to have to mount and
de-mount it all the time. On the bench grinder, I first had a coarse
and fine wheel - found just the coarse is fine. Mounted a regular
grinding wheel in the other for the little bits of steel work we do.
The little SB wheel in the die grinder is very handy when needed too.
Have worn one out, on number 2. I used Avery's 3700 but I think I got
it from Cleaveland:
http://www.averytools.com/pc-351-43-scotch-brite-cutting---polishing--wheel--kit.aspx
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |
Too bad Deems is flying, maybe he could come up with a way to pre-accelerate
the tires to landing speed for smoother landings with less tire wear. Heh.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Thursday, January 14, 2010 8:25 AM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
> Rick
> John G. Cumins
> President
> 2499 B1 Martin Rd
> Fairfield Ca 94533
> 707-425-7100
> 707-425-7576 Fax
> Rick
> To:
> Deems Davis
> N519PJ
> www.deemsrv10.com
Subject: | Re: rear spar caps- must read |
Bill is right on... Jeff using the file is fine, but finish EVERYTHIG off w
ith the grinder held scotchbrite wheel or the small scotchbrite wheels show
n below.- I forgot where I got mine, and hadn't got around to ordering mo
re, so I've been making due with the little nubs that I've got left.- Ord
er the "kit", you won't be sorry.- Best and easiest way to deburr everyth
ing.
Don McDonad
--- On Thu, 1/14/10, Bill Mauledriver Watson wrote:
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: RV10-List: Re: rear spar caps
Date: Thursday, January 14, 2010, 7:00 AM
.com>
> Though the scotch-brite wheel is very useful, I ultimately found that ski
ns and long parts that were difficult to get to the wheel were easily debur
red with a large vixen file run a few times along- an edge at different a
ngles.
The vixen file seems to be the ideal- tool for dressing the edges of tail
/wing skins.- I had no idea what it was or how to use it but I described
what I found out in a post - search the archives for 'Vixen' and look for m
y post (I can't find the supporting pics).- A very useful tool and very b
asic technique for skin deburring.- Very productive.
I found that the scotchbrite wheel in a floor mounted bench grinder to be b
y far the tool I use the most.- Still do.- I'm on my second wheel at 3+
years of a 4 year QB.- The drill press thing sounds good - never thought
about the axis thing but I wouldn't want to have to mount and de-mount-
it all the time.- On the bench grinder, I first had a coarse and fine whe
el - found just the coarse is fine.- Mounted a regular grinding wheel in
The little SB wheel in the die grinder is very handy when needed too.- Ha
ve worn one out, on number 2.- I- used Avery's 3700 but I think I got i
t from Cleaveland:
--kit.aspx
le, List Admin.
=0A=0A=0A
Thanks all for the feedback re tires. It appears that uneven outside
wear is the 'norm'. I wonder if we're all landing left wheel 1st? Or if
Van's has a slight error in the gear weldment? I reject Rick's
hypothesis regarding 'unequal weight distribution' :-) . I've got em
flipped and will watch closer for the next period. I've also had a
couple of positive recommendations for retreads for future replacements.
I haven't worked on Alaska, my hangar neighbor from AK just returned, so
I'll have to ping him.
I don't want to make everyone green, but it's 70 deg and CAVU here in
PHX. 8-)
Deems Davis
N519PJ
www.deemsrv10.com
> and the pilot side was worse than the other side. At the same time I
> installed air stop tubes. Guess It's getting time to get an order
> together for tires. Brakes looked good.
> flying. Just enough overcast/fog to keep you on the ground. Going up
> tomorrow though.
> Don McDonald
> <http://us.mc537.mail.yahoo.com/mc/compose?to=deemsdavis@cox.net>>
> pilot) side tire is showing extreme wear on the outside of the
> tire, the Right is also showing wear on the outside, but not as
> extreme.
> to try and get some more wear out of the tires. When pulling the
> left tire off the axel, the brake lining for the inboard brake pad
> dropped to the floor! It appears that the shoulder that is
> supposed to hold the rivet liner to the pad let go, and the rivet
> heads were "floating" inside of the countersunk area. Fortunately
> there is minimal brake wear, and therefore little movement in the
> jammed it self against the brake disc. If this had happened on
> landing and braking, I wouldn't have wanted to be along for that
> since these were the parts that came with the kit from Cleveland,
> I would expect that they should have some quality control in
> comparison with the inboard rivets to the outboard .liner rivets,
> it appears that they are 'deeper' into the countersunk area , and
> possibly the shoulder of the brake material that holds them was
> thinner and possibly weaker. Anyway replacement pads on on there
> way. Something to keep in mind when you do your conditionals or
> change tires.
> cs.com/" ; -Matt Dralle, List Admin=========
I rotate inner to outer one annual condition inspection, then exchange
left & right next annual and repeat inner to outer at the next one.
Turn nose wheel around each annual.
Works ok to keep all wear about equal.
Remember on inner to outer, be careful and dust up the tube well and
partially inflate it to keep from pinching the tube (learned that one
the hard way.....)
grumpy
> if Van's has a slight error in the gear weldment? I reject Rick's
> em flipped and will watch closer for the next period. I've also had
> a couple of positive recommendations for retreads for future
> replacements.
> returned, so I'll have to ping him.
> in PHX. 8-)
> Deems Davis
> N519PJ
> www.deemsrv10.com
>> I installed air stop tubes. Guess It's getting time to get an
>> order together for tires. Brakes looked good.
>> up tomorrow though.
>> Don McDonald
>> extreme.
>> change tires.
>> TOOL GUIDE
>> DRILL PRESS: A tall
>> upright machine useful for suddenly snatching flat
>> metal bar stock out of your hands so that it smacks
>> you in the chest and
>> flings your beer across the room, denting the
>> freshly-painted project
>> which you had carefully set in the corner where
>> nothing could get to it.
>> WIRE WHEEL: Cleans paint off bolts and then throws
>> them somewhere under
>> the workbench with the speed of light. Also removes
>> fingerprints and
>> hard-earned calluses from fingers in about the time
>> it takes you to ay,
>> 'Oh sh --'
>> SKILL SAW: A portable cutting tool used to make
>> studs too short.
>> PLIERS: Used to round off bolt heads. Sometimes
>> used in the creation of
>> blood-blisters.
>> BELT SANDER: An electric sanding tool commonly used
>> to convert minor
>> touch-up jobs into major refinishing jobs.
>> HACKSAW: One of a family of cutting tools built on
>> the Ouija board
>> principle. It transforms human energy into a
>> crooked, unpredictable
>> motion, and the more you attempt to influence its
>> course, the more
>> dismal your future becomes.
>> VISE-GRIPS: Generally used after pliers to
>> completely round off bolt
>> heads. If nothing else is available, they can also
>> be used to transfer
>> intense welding heat to the palm of your hand.
>> OXYACETYLENE TORCH: Used almost entirely for
>> lighting various flammable
>> objects in your shop on fire. Also handy for
>> igniting the grease inside
>> the wheel hub out of which you want to remove a
>> bearing race.
>> TABLE SAW: A large stationary power tool commonly
>> used to launch wood
>> projectiles for testing wall integrity.
>> HYDRAULIC FLOOR JACK: Used for lowering an
>> automobile to the ground
>> after you have installed your new brake shoes,
>> trapping the jack handle
>> firmly under the bumper.
>> BAND SAW: A large stationary power saw primarily
>> used by most shops to
>> cut good aluminum sheet into smaller pieces that
>> more easily fit into
>> the trash can after you cut on the inside of the
>> line instead of the
>> outside edge.
>> TWO-TON ENGINE HOIST: A tool for testing the
>> maximum tensile strength of
>> everything you forgot to disconnect.
>> PHILLIPS SCREWDRIVER: Normally used to stab the
>> vacuum seals under lids
>> or for opening old-style paper-and-tin oil cans and
>> splashing oil on
>> your shirt; but can also be used, as the name
>> implies, to strip out
>> phillips screw heads.
>> STRAIGHT SCREWDRIVER: A tool for opening paint
>> cans. Sometimes used to
>> convert common slotted screws into non-removable
>> screws and butchering
>> your palms.
>> PRY BAR: A tool used to crumple the metal
>> surrounding that clip or
>> bracket you needed to remove in order to replace a
>> 50 cent part.
>> HOSE CUTTER: A tool used to make hoses too
>> short.
>> HAMMER: Originally employed as a weapon of war, the
>> hammer nowadays is
>> used as a kind of divining rod to locate the most
>> expensive parts
>> adjacent the object we are trying to hit.
>> UTILITY KNIFE: Used to open and slice through the
>> contents of cardboard
>> cartons delivered to your front door; works
>> particularly well on
>> contents such as seats, vinyl records, liquids in
>> plastic bottles,
>> collector magazines, refund checks, and rubber or
>> plastic parts.
>> Especially useful for slicing work clothes, but
>> only while in use.
>> SON OF A BITCH TOOL: Any handy tool that you grab
>> and throw across the
>> garage while yelling 'Son of a bitch' at the top of
>> your lungs. It is
>> also, most often, the next tool that you will
>> need.
>> Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign
>> up now.
>> up now.
>> "If you are afraid to speak against tyranny,
>> then you are already a slave." -- author
>> John "Birdman" Bryant (1943-2009)
>> Hotmail: Free, trusted and rich email service. Get it now.
>> Checked by AVG - www.avg.com
>> 01/12/10 19:35:00
On Jan 14, 2010, at 9:12, Don McDonald
> EVERYTHIG off with the grinder held scotchbrite wheel or the small
> scotchbrite wheels shown below. I forgot where I got mine, and
> hadn't got around to ordering more, so I've been making due with the
> little nubs that I've got left. Order the "kit", you won't be
> sorry. Best and easiest way to deburr everything.
> Don McDonad
> that skins and long parts that were difficult to get to the wheel
> were easily deburred with a large vixen file run a few times along
> an edge at different angles.
> 'Vixen' and look for my post (I can't find the supporting pics). A
> very useful tool and very basic technique for skin deburring. Very
> productive.
> to be by far the tool I use the most. Still do. I'm on my second
> wheel at 3+ years of a 4 year QB. The drill press thing sounds good
> - never thought about the axis thing but I wouldn't want to have to
> mount and de-mount it all the time. On the bench grinder, I first
> had a coarse and fine wheel - found just the coarse is fine.
> Mounted a regular grinding wheel in the other for the little bits of
> steel work we do.
> too. Have worn one out, on number 2. I used Avery's 3700 but I
> think I got it from Cleaveland:
> http://www.averytools.com/pc-351-43-scotch-brite-cutting-http://www.matronics.com/Navigator?RV10-List
> " target=_blank>http://www.marums.matronics.com/" ; -
Pascal,
To satisfy my curiosity, do the fluid hoses in the FWF kit have external fire sleeves
like the 1st pic or integral firesleeves like the 124-6J hose in the 2nd
pic?
Thanks!
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings
http://forums.matronics.com/viewtopic.php?p=281496#281496
http://forums.matronics.com//files/hosefs1_114.jpg
http://forums.matronics.com//files/hose124_6j_110.jpg
Which way does the wind blow at your home airport? e.g., do you do more landings
with a crosswind from the left, than from the right? Also, where is your hangar
with respect to the usual runway? Are you making mostly left turns?
As others have noted, wear on the outside of the tires is due to the spring gear
leg,which hangs low prior to touchdown. See the same thing with spring gear
Cessnas.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=281509#281509
first picture
Sent: Thursday, January 14, 2010 10:10 AM
Subject: RV10-List: Re: FWF Kit
> Pascal,
> fire sleeves like the 1st pic or integral firesleeves like the 124-6J hose
> in the 2nd pic?
> Thanks!
> Todd Stovall
> 728TT (reserved)
From: | "Dick & Vicki Sipp" <rsipp(at)earthlink.net> |
Another good technique for edge dressing is called "draw filling" wherein a
standard fine file is turned 90 degrees or perpendicular to the work and
dragged lightly alone the work edge. Like others have said the edge still
needs to be "polished" with a de-burring wheel of some kind.
Dick Sipp
N110DV 210 hours
Rick
Yep I sure am will arrive about noon so I have the 20 and 21 afternoons
free. Shoot me a e-mail off list and we can get together on of those
afternoons.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick
Sent: Wednesday, January 13, 2010 6:36 PM
Rick
Rick
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Rick
Deems Davis
N519PJ
www.deemsrv10.com
Subject: | 1" Scotchbrite Wheels |
I found this on someone's website recently.=C2- Looks like a great deal.
=C2- I'm not sure if it's the exact composition as the product from Avery
, etc., but the price is incredible.
http://www.surplussales.com/Tools-Accessories/T-Aabrasives.html
Sean Blair
COS
Subject: | Re: 1" Scotchbrite Wheels |
Ooooh. Great price. But some bad reviews in a Google search for this
vendor. But they have been around for quite some time...
I took a risk and ordered a package. I'll let you know if it turns out
poorly.
Chris
On Thu, Jan 14, 2010 at 1:55 PM, wrote:
> I found this on someone's website recently. Looks like a great deal. I'm
> not sure if it's the exact composition as the product from Avery, etc., but
> Sean Blair
> COS
Heck of a deal. Looks just like the smallest ones from Avery.
> Sean Blair
> COS
Subject: | Door safety latch |
Van's has issued a service bulletin for their new door safety latch, which I installed
2 weeks ago. They have started shipping parts kits to those flying and
those who have purchased finish kits. See attached link or go to Van's website.
The latch works very nicely and can also be used to pull the door inward while
closing the door handle.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=281560#281560
http://forums.matronics.com//files/sb10_1_4_236.pdf
Subject: | Re: Door safety latch |
Any pictures or install drawings you can share?
http://forums.matronics.com/viewtopic.php?p=281563#281563
Subject: | Door SB just posted |
Safety Latch for the Door SB was just posted...
http://www.vansaircraft.com/pdf/sb10-1-4.pdf
I looked to see if details of the changes were online, but couldn't find
them. I guess who ever receives there kit in the mail first will need to
update us all.
Jim,
Can you post a picture of the new latch?
bob
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry
Sent: Thursday, January 14, 2010 8:10 PM
Subject: RV10-List: Door safety latch
installed 2 weeks ago. They have started shipping parts kits to those flying
and those who have purchased finish kits. See attached link or go to Van's
website.
while closing the door handle.
Jim Berry
40482
N15JB
Anybody have the section 45A?
Sent: Thursday, January 14, 2010 6:10 PM
website.
Jim Berry
40482
N15JB
If we actually think about it.... if the gear were perfectly straight, we w
ould simply wear out the center of the tire.... and then we're done.- The
way it is now, we wear out mostly a part of the tire that would never get
used, and then we get to turn them around and it's a brand new part of the
tire again.- What the hell are we bitching about!
Don McDonald
--- On Thu, 1/14/10, Bob Turner wrote:
Subject: RV10-List: Re: Uneven tire wear and brake pad separation
Date: Thursday, January 14, 2010, 11:08 AM
dings with a crosswind from the left, than from the right? Also, where is y
our hangar with respect to the usual runway? Are you making mostly left tur
ns?
gear leg,which hangs low prior to touchdown. See the same thing with sprin
g gear Cessnas.
Bob Turner
RV-10 QB
le, List Admin.
=0A=0A=0A
It looks very much like the Staniforth latch in the archives. I will take some
pictures when I am out at the hangar tomorrow. My drawings are also at the hangar
right now. With a little care, there should be no problem installing in a
finished and painted door.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=281570#281570
Subject: | Flap motor rod travel |
I am trying to set up my flap position sensor (ray allen) but the wings are
not on yet. Can someone tell me how far the rod travels out of the motor
assembly? Does it start fully retracted (reflex position) and then move "X"
inches out of the motor assembly which would be full flaps? I need to know
"X". Does this make sense?
Chris
#40072
Subject: | Re: door handle & mechanism |
Hey Don,
Where did you find these CNC machined handles?
Sent: Saturday, January 09, 2010 10:54 PM
Subject: Re: RV10-List: door handle & mechanism
Spring for the cnc machined handles.... they work perfectly, are
a direct Vans replacement, and they look WAY better.
Don McDonald
--- On Sat, 1/9/10, Roxanne and Mike Lefever
wrote:
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Subject: RV10-List: door handle & mechanism
Date: Saturday, January 9, 2010, 8:57 PM
I can't be the first to declare the Van's door handle and
mechanism a total RPITA.......although not an engineer..........even I
could design a mousetrap better than this. After sanding the powder
coat off of the shaft handle, the spring is still too small to move on
the shaft and make the mechanism work. I thought bringing in my
Saturday night consulting engineer Jack (Daniels) would help but we
finally gave up tonight. Maybe a bigger hammer tomorrow will bring
success.
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Subject: | door handle & mechanism |
Sean
If these are the ones you want :
http://davidnellis.myphotoalbum.com/view_photo.php?set_albumName=album18
<http://davidnellis.myphotoalbum.com/view_photo.php?set_albumName=album18&id
=dsc00655> &id=dsc00655 contact David Nellis at : davidnellis691(at)comcast.net
I have a set and they are very nice. I also used Steve Deniri's billed
handles on the outside for a nice flush fit.
Cheers
Les
#40643
_____
Sent: January-14-10 8:04 PM
Hey Don,
From: Don McDonald <mailto:building_partner(at)yahoo.com>
Spring for the cnc machined handles.... they work perfectly, are a direct
Don McDonald
I can't be the first to declare the Van's door handle and mechanism a total
RPITA.......although not an engineer..........even I could design a
mousetrap better than this. After sanding the powder coat off of the shaft
handle, the spring is still too small to move on the shaft and make the
mechanism work. I thought bringing in my Saturday night consulting engineer
Jack (Daniels) would help but we finally gave up tonight. Maybe a bigger
hammer tomorrow will bring success.
Cool thanks
On Jan 14, 2010, at 20:30, "Les Kearney" wrote:
> Sean
> If these are the ones you want : http://davidnellis.myphotoalbum.com/view_photo.php?set_albumName=album18&id=dsc00655
> billed handles on the outside for a nice flush fit.
> Cheers
> Les
> #40643
> Hey Don,
> From: Don McDonald
> Don McDonald
> a total RPITA.......although not an engineer..........even I could
> design a mousetrap better than this. After sanding the powder coat
> success.
> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
> href="http://forums.matronics.com">http://forums.matronics.com
> www.matronics.com/c
Subject: | electric aileron trim |
Hey Guys
I'm getting ready to order my slow build wing kit and am wondering if
most builders have also bought the aileron trim kit from Vans. I intend
to install a Tru Tak autopilot and probably the Safety trim system that
Bob Newman sells. Not sure if using the autopilot etc makes any
difference with regards to the aileron trim system (I think not).
As I have already fabricated a rudder trim tab system very similar to
Brian Steeves, I'm wondering if the aileron system could also be
fabricated in house, as opposed to buying the Vans kit?
All opinions welcome. Thx.
Rick
#40956
Southampton, Ont
From: | "Ron McGann" <ronrvbuilder(at)bigpond.com> |
Time of Compliance: Before further flight
So now we are grounded for an issue that we have known about for more than 2
years.
Will be interesting to see how long it takes to get the parts to us in the
deeeeep south.
A real pisser - in the middle of our peak flying season no less.
Ron
VH-XRM, not flying in Oz.
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler
Sent: Friday, 15 January 2010 12:17 PM
Subject: RV10-List: Door SB just posted
update us all.
Ron,
Unless the Aussie FAA sees things differently than our FAA, there is no s
uch thing as "grounded" or "mandatory" in the experimental world as the pil
ot and the FAA/NTSB are really the only two authorities here that can groun
d an aircraft here. As you said, people have been flying for years before
Van's acknowledged the problem with this SB. Use good judgment and go fly.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m
atronics.com] On Behalf Of Ron McGann
Sent: Thursday, January 14, 2010 11:45 PM
Subject: RE: RV10-List: Door SB just posted
2 years.
deeeeep south.
Ron
Safety Latch for the Door SB was just posted.......
I looked to see if details of the changes were online, but couldn't find th
em. I guess who ever receives there kit in the mail first will need to up
date us all.
Subject: | Re: electric aileron trim |
jrlark wrote:
> As I have already fabricated a rudder trim tab system very similar to Brian
Steeves, I'm wondering if the aileron system could also be fabricated in house,
In my opinion, you need both. Vans aileron trim works and unless you want to spend
a bunch of time designing and making your own, Vans is simple to build and
install.
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=281590#281590
I installed the Van's aileron trim and am glad I did. Fuel imbalance
and passenger loading makes a noticeable need for trim. If you feel
like fabricating your own system, I say go for it!
$.02 worth.
David Maib
40559
Flying
On Jan 15, 2010, at 12:42 AM, Rick Lark wrote:
Hey Guys
intend to install a Tru Tak autopilot and probably the Safety trim
system that Bob Newman sells. Not sure if using the autopilot etc
makes any difference with regards to the aileron trim system (I think
not).
Rick
#40956
Southampton, Ont
Subject: | Re: Flap motor rod travel |
If there isn't a 'plans-called-for' position, or you're doing it differently; I
would suggest waiting till the wings are on and you can use the actual...before
mounting anything.
I recall measuring the throw for my 6A and it was at least 5 inches of throw IIRC.
I found that only useful for general planning purposes and didn't drill any
mounting holes until stuff was there to use.
I relocated the flap drive on my 6A from the center to the side (the way the 8 is designed) using an idea that I took from Mel Jordan (http://bmnellis.com/BuilderIdeas/flap_mod.htm). Mel visited my project while it was under construction.
>From: Chris <toaster73(at)embarqmail.com>
>Sent: Jan 14, 2010 8:43 PM
>Subject: RV10-List: Flap motor rod travel
>Thanks
>Chris
>#40072
vans can't ground anybody; unless its in your government's regulations.
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron McGann
Sent: Thursday, January 14, 2010 10:45 PM
years.
deeeeep south.
Ron
_____
update us all.
From: | Linn Walters <pitts_pilot(at)bellsouth.net> |
fwiw. I'm using model airplane servos to turn hinge mounted on the
trailing edge of rudder and one aileron. You need a PWM signal to
operate the servos, but that's easy for me.
Linn
spend a bunch of time designing and making your own, Vans is simple to build
and install.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
I question the need for both aileron trim and autopilot. The autopilot
should be able to handle the minor imbalances. While a trim tab could
reduce loads on the autopilot, it seems like unneeded extra
complexity. I'd be interested in hearing from flying -10s whether they
have and actually use both systems. I could see one or the other, but
both would appear to be overkill.
spend a bunch of time designing and making your own, Vans is simple to build and
install.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
Damn
You mean I'm grounded until I get this done!
Except for the panel, wiring, and wing installation I was ready to go flying
today....
Cheers
Les
#40643
_____
Sent: January-14-10 10:45 PM
years.
deeeeep south.
Ron
_____
update us all.
I'd be interested in 'real life' info too. I had a discussion with a
friend with extensive autopilot experience, and his comment was that if
the aircraft was out of trim, the autopilot 'flew funny'. I'm guessing
it's because the autopilots he was flying behind had rate gyros, not
solid state ones so prevalent now. Since I was already going to install
the model airplane servos and designed the PWM module, adding the
aileron trim was real easy. I've never had actrive trim on anything
I've flown, so this is new ground for me.
Linn
> autopilot should be able to handle the minor imbalances. While a trim
> tab could reduce loads on the autopilot, it seems like unneeded extra
> they have and actually use both systems. I could see one or the
> other, but both would appear to be overkill.
>>> similar to Brian Steeves, I'm wondering if the aileron system
>>> could also be fabricated in house, as opposed to buying the Vans
>>> kit?
>> you want to spend a bunch of time designing and making your own,
>> Vans is simple to build and install.
>> -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying)
If you want to save time on the controller, for a cost, Eric at Perihelion Designs
has a nice little unit called the EGPNMSC.
http://www.periheliondesign.com/moreproducts.htm
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Friday, January 15, 2010 9:24 AM
Subject: Re: RV10-List: Re: electric aileron trim
Linn
>>> kit?
From: | "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> |
Kelley;
I put both in mine. Most of the time you will set the aileron trim at
one position and never move it. Depending on who's flying with you (I
tend to have the same left wheel wear problem Deems has), you may need
to adjust it. Also, I had to have my autopilot serviced and did a
couple long cross country trips. Having the aileron trim helps decrease
your workload and cut down some of the heading drift. My vote is that
it is worth the installation.
Dr Fred.
and install.
>> Gary Blankenbiller
>> RV10 - # 40674
>> (N2GB Flying)
From: | "johngoodman" <johngoodman(at)earthlink.net> |
[quote="toaster73(at)embarqmail.c"]I am trying to set up my flap position sensor
(ray allen) but the wings are not on yet. Can someone tell me how far the rod
travels out of the motor assembly? Does it start fully retracted (reflex position)
and then move X inches out of the motor assembly which would be full
flaps? I need to know X. Does this make sense?
Chris
#40072
> [b]
Chris,
I am also using the Ray Allen position sensor (the VP200 needs it), so I removed
and sold the Van's unit. The limited travel of the RA means you will have to
position the rod very close to axis. I calculated about an inch, which is very
close to the nearest lightening hole at the axis. I put a unique little spacer
I found at Ace Hardware in the hole. It has a threaded hole in it. I mounted
the RA with double-sided tape and ran the motor full throw. No matter what you
do, it will pull the RA off the tape, one way or the other.
There is another RV-10 in the hangar with me and I tried to figure it out on theirs,
with limited success. I have decided that I will leave the RA loose for
now, and once the flaps are on, find the right place. I suspect I will need to
offset the mounting point a little more towards the axis. A task for another
day.
#40572 QB. Engine on, wing attach coming soon. Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=281625#281625
Subject: | Re: Door SB just posted |
So first flight at noon Les? ;-p
On Fri, Jan 15, 2010 at 8:21 AM, Les Kearney wrote:
> Damn
> today....
> Cheers
> Les
> #40643
> years.
> deeeeep south.
> A real pisser in the middle of our peak flying season no less.
> Ron
> I looked to see if details of the changes were online, but couldnt find
> update us all.
> Bob
> href="http://www.matronics.com/contribution">http://www.matronics.com/c
I have both and use both. I would highly recommend having both unless you
fly almost 100% of the time on the autopilot. Fuel in-balance, fat pilot ,
pattern work, hood work ........ I use the trim every flight.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Friday, January 15, 2010 8:11 AM
Brian Steeves, I'm wondering if the aileron system could also be fabricated
to spend a bunch of time designing and making your own, Vans is simple to
build and install.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
You can question the need if you wish. :)
I'll tell you what...the RV-10's tanks are so looooong that they
give a pretty hefty imbalance. Sure, with the AP on you
won't notice it too much, but even just hand flying it around
town, that plane can get very wing-heavy. I would never want
to be without the ability to compensate it. Now, depending
on your loading and everything else, you may only use it on
30-60% of your flights, but when you need it, you'll really
want it. It's easier to build into the wing when the wing is
still on the bench and before you paint the access covers, so
I'd say in my recommendation I'd consider it standard equipment
and just do it. But, if someone really likes to suffer, because
suffering makes them feel more like a man, then skip it for
now and just let that nagging voice in the back of your head
keep talking to you as you fly your 200th hour wishing you'd
have put it in.
and install.
>> Gary Blankenbiller
>> RV10 - # 40674
>> (N2GB Flying)
I talked to Vans this morning about the SB. They referred me to the SB that
they say is being mailed this week. I asked if there was a PDF and they
indicated not. Perhaps someone on this list , upon receipt of the SB, could
send it to the list in PDF form.
From: | "Geoff Combs" <g.combs(at)aerosportmodeling.com> |
Take Tim's advice. It is easy to install and worth every penny. I only have
44 hrs on my Rv-10 and the first 32 were without auto pilot working
Correctly. I was glad I had aileron trim.
Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson
Sent: Friday, January 15, 2010 10:31 AM
I'll tell you what...the RV-10's tanks are so looooong that they give a
pretty hefty imbalance. Sure, with the AP on you won't notice it too much,
but even just hand flying it around town, that plane can get very
wing-heavy. I would never want to be without the ability to compensate it.
Now, depending on your loading and everything else, you may only use it on
30-60% of your flights, but when you need it, you'll really want it. It's
easier to build into the wing when the wing is still on the bench and before
you paint the access covers, so I'd say in my recommendation I'd consider it
standard equipment and just do it. But, if someone really likes to suffer,
because suffering makes them feel more like a man, then skip it for now and
just let that nagging voice in the back of your head keep talking to you as
you fly your 200th hour wishing you'd have put it in.
>>> to Brian Steeves, I'm wondering if the aileron system could also be
>> want to spend a bunch of time designing and making your own, Vans is
>> Gary Blankenbiller
>> RV10 - # 40674
>> (N2GB Flying)
I believe you need the aileron trim with an autopilot. I have a TruTrak but
you need to trim the aircraft before engaging the autopilot for two reasons.
When you disengage the aqutopilot an out-of-trim condition will cause abrupt
aircraft movement especially in pitch. Second, again especially in pitch,
the autopilot may "slip" if the out-of-trim condition is too strong. That
built-in slippage is what let's you overpower a runaway autopilot.
Albert Gardner
N991RV
Yuma, AZ
Sent: Friday, January 15, 2010 8:24 AM
Linn
>>> kit?
David,
If you're looking for the verbage of the SB, it's right here.
If you're looking for the plans revisions, I haven't seen those yet...
Phil
Sent: Friday, January 15, 2010 9:15 AM
Subject: RV10-List: 10 SB
that they say is being mailed this week. I asked if there was a PDF and
they indicated not. Perhaps someone on this list , upon receipt of the
SB, could send it to the list in PDF form.
Albert, good points. The aileron trims a "go" from my perspective. A
friend with a T210 Cessna has an Stec55X that will squawk at him if the
trim is out too much (PITA), so I think it's a good idea.
(by the way Albert, nice design on your spring biased rudder trim)
Now my next question, are the Vans deluxe locking fuel caps worth the work
to install? When this aircraft is completed, it may be tied down outside for
a year or so. The catalogue description says they certainly are not a drop
in replacement. That's ok to me as long as the modification is reasonable.
Most of the archive messages seem to indicate they are worth the time and
expense. Again all opinions are welcome.
You guys have no idea how much easier it is to make these decisions with
input from this forum (especially since I'm stuck on the far north tundra of
southern Ontario). Thx again
Rick
Sent: Friday, January 15, 2010 11:00 AM
Subject: RE: RV10-List: Re: electric aileron trim
> but
> reasons.
> abrupt
> Albert Gardner
> N991RV
> Yuma, AZ
> Linn
>>>> kit?
>>> Read this topic online here:
Don't leave home with out it!
Deems Davis
N519PJ
www.deemsrv10.com
I think everyone is looking for the diagrams/picture of what the fix is.
Michael
atronics.com] On Behalf Of Perry, Phil
Sent: Friday, January 15, 2010 10:04 AM
Subject: RE: RV10-List: 10 SB
David,
Phil
they say is being mailed this week. I asked if there was a PDF and they in
dicated not. Perhaps someone on this list , upon receipt of the SB, could s
From: | "George, Neal E Capt USAF ACC 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil> |
...and it works very well.
neal
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder
(Michael Sausen)
Sent: Friday, January 15, 2010 9:40 AM
Designs has a nice little unit called the EGPNMSC.
Michael
Linn
>>> kit?
I received a positive response to this email to Scott Risan this AM.
"I believe you would eliminate a lot of calls to technical support by
publishing the plans changes in PDF form. It would seem that Section 45A
will be common knowledge in about two weeks; why not publish as a PDF and
eliminate the calls to technical support looking for information. Also the
time of compliance is not very realistic; perhaps it should indicate
different times for flying and not flying aircraft, given that flying
aircraft have already been operating safely via other methods. In my case I
am the only pilot; I have lengthened Van's supplied pins to ensure complete
engagement of the metal door frames. My checklist calls for a manual feel of
the pins when engaged (twice) before takeoff."
_____
(Michael Sausen)
Sent: Friday, January 15, 2010 10:16 AM
Michael
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
David,
Phil
http://i47.tinypic.com/2gxpkdw.jpg
http://i49.tinypic.com/16hvx1t.jpg
I wouldn't think that posting SB on a website wouldn't stand-up in court
as official notification. Meaning the clock hasn't started for
compliance.
But once you get a physical copy of the SB in the mail, with the revised
plans, with the appropriate materials; that's a different story.
The smart ones are probably those who aren't replying to the thread. J
Cause they still don't know about the SB yet......
Sent: Friday, January 15, 2010 12:35 PM
and eliminate the calls to technical support looking for information.
Also the time of compliance is not very realistic; perhaps it should
indicate different times for flying and not flying aircraft, given that
flying aircraft have already been operating safely via other methods. In
my case I am the only pilot; I have lengthened Van's supplied pins to
ensure complete engagement of the metal door frames. My checklist calls
for a manual feel of the pins when engaged (twice) before takeoff."
(Michael Sausen)
Michael
David,
Phil
Hmmm
What was the response....
Inquiring minds need to know.
..Les
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM
Sent: January-15-10 11:35 AM
_____
(Michael Sausen)
Michael
David,
Phil
Attached are photos of the new door safety latch, which I think are self explanatory.
It is my understanding that everyone with a finish kit will have their
parts and drawings by the end of next week. The only thing I would consider changing
is to increase the angle between the legs of the springs that you will
fabricate. My personal preference would be for a stronger spring loading of the
latch. I don't have a way to scan the large format drawings, but will try to
photograph them and get them posted later today.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=281668#281668
http://forums.matronics.com//files/img_0441_836.jpg
http://forums.matronics.com//files/img_0440_915.jpg
http://forums.matronics.com//files/img_0439_172.jpg
http://forums.matronics.com//files/img_0438_137.jpg
And the response was?
Sent: Friday, January 15, 2010 10:34 AM
(Michael Sausen)
Michael
David,
Phil
Subject: | Photo's are in... Plans too.... |
Photo's are below and the plans are attached....
Phil
Thanks Jim,
NO pressure there was there?
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=281674#281674
David,
It appears that Scott took your advice. They were just posted on
vansairforce.net
http://www.vansairforce.net/delete_eventually/Section45A.pdf
bob
Sent: Friday, January 15, 2010 1:35 PM
_____
(Michael Sausen)
Michael
David,
Phil
The time of compliance is determined by the builder. SBs in the USA for
experimental aircraft are advisory only ; even certified aircraft are
required to comply with SBs only if used commercially. Neither Vans nor the
FAA have authority to require compliance prior to further flight. These are
not ADs; ADs apply to certified aircraft.
_____
Sent: Friday, January 15, 2010 11:56 AM
I wouldn't think that posting SB on a website wouldn't stand-up in court as
official notification. Meaning the clock hasn't started for compliance.
_____
(Michael Sausen)
Michael
David,
Phil
When you are inside of the plane and want to open the door, how do you open the
latch? Do you grab the edge of it. What am I missing here? Oh ya and you are
on fire!
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=281682#281682
There is a major disagreement between EAA and FAA. FAA says ADs apply to al
l
aircraft/components they are issued for. If AD comes out on a Lycoming IO54
crankshaft, piston pin plugs, etc. it does apply to any aircraft that has
the exact engine called out, whether experimental or not, according to FAA.
Of course EAA disputes that, but we know FAA writes, interprets, enforces
and is judge jury and executioner. NTSB is a rubber stamp for the most part
Not disagreeing with your comments about Service Bulletins, just pointing
out that there are many opinions on applicability of ADs.
he
re
> *From:* owner-rv10-list-server(at)matronics.com [mailto:
> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Perry, Phil
> *Sent:* Friday, January 15, 2010 11:56 AM
> *To:* rv10-list(at)matronics.com
> *Subject:* RE: RV10-List: 10 SB
> I wouldn=92t think that posting SB on a website wouldn=92t stand-up in c
ourt
> as official notification. Meaning the clock hasn=92t started for complia
nce.
> plans, with the appropriate materials; that=92s a different story.
> The smart ones are probably those who aren=92t replying to the thread. J
> Cause they still don=92t know about the SB yet=85=85
> *From:* DLM [mailto:dlm46007(at)cox.net]
> *Sent:* Friday, January 15, 2010 12:35 PM
e
I
te
of
> owner-rv10-list-server(at)matronics.com] *On Behalf Of *RV Builder (Michael
> Sausen)
> *Sent:* Friday, January 15, 2010 10:16 AM
> Michael
> *Sent:* Friday, January 15, 2010 10:04 AM
> David,
> If you=92re looking for the verbage of the SB, it=92s right here.
> If you=92re looking for the plans revisions, I haven=92t seen those yet
=85
> Phil
> [image: http://i47.tinypic.com/2gxpkdw.jpg]
> [image: http://i49.tinypic.com/16hvx1t.jpg]
> *Sent:* Friday, January 15, 2010 9:15 AM
> *Subject:* RV10-List: 10 SB
at
ld
> *http://www.matronics.com/Navigator?RV10-List*
> *http://forums.matronics.com*
> *http://www.matronics.com/contribution*
Subject: | Re: Photo's are in... Plans too.... |
Just thinking out loud [Question]
With a hole that big on the outside of the door, I wonder how much water you can
get inside the door after sitting in a good rain or flying in rain.
We work so hard at sealing the doors and now we put a big slot in it with a clear
path from outside to inside. [Shocked]
Let the examination begin [Mr. Green]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=281685#281685
I was already thinking about that too. Maybe wrapping a piece of weather stripping
around the inside would help without adding too much resistance. The spring
looks a bit wimpy though and any resistance might stop it. Pure speculation
here of course. :)
Michael
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of orchidman
Sent: Friday, January 15, 2010 2:36 PM
Subject: RV10-List: Re: Photo's are in... Plans too....
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)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: | Jae Chang <jc-matronics_rv10(at)jline.com> |
I'm not too worried. An inventive -10 builder is going to come up with a
mechanism to tie the safety latch to the existing door handle. Until
then, i think a zip tie would look more aesthetically pleasing.
Jae
First order for Skyview parts in.
spring looks a bit wimpy though and any resistance might stop it. Pure speculation
here of course. :)
> Michael
> To: rv10-list(at)matronics.com
can get inside the door after sitting in a good rain or flying in rain.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
agreed: if the data plate still indicates a certified Lycoming as mine does.
Certified parts to remain certified must comply with ADs.
_____
Sent: Friday, January 15, 2010 1:30 PM
Subject: Re: RV10-List: 10 SB
There is a major disagreement between EAA and FAA. FAA says ADs apply to all
aircraft/components they are issued for. If AD comes out on a Lycoming IO540
and is judge jury and executioner. NTSB is a rubber stamp for the most part.
_____
_____
(Michael Sausen)
Michael
David,
Phil
Well, I was aware of that rather nifty item. I'd need two
(aileron/rudder trim) so that's $100 + shipping + servos ($28).
I used a Stamp Computer (http://tinyurl.com/yjrv4kg) $54, and the two
servos $28 + shipping and wrote the program (simple basic language). I
have 10 more I/O ports left to do whatever strikes my fancy. I could
use some of the ports to control dimmers, or discrete flap settings or
Linn
> Michael
> Linn
>>>> kit?
I find it rather ludicrous to build an efficient airplane only to hang
the handle and a speed brake on the outside of the door. IMHO, it's a
poor solution at best.
Linn
changing is to increase the angle between the legs of the springs that you will
the latch. I don't have a way to scan the large format drawings, but will try
to photograph them and get them posted later today.
> Jim Berry
> 40482
> N15JB
My spy inside Van's just send me the revision for the SB come out yesterday
,will looking more efficient then the parachute of the outside lever of the
previews SB=0AAny way I thinks I will adop this one=0AHugo --- =0A=0A=0AOn
Fri, 1/15/10, Linn Walters wrote:=0A=0A> From:
Linn Walters =0A> Subject: Re: RV10-List: Re: D
oor safety latch=0A> To: rv10-list(at)matronics.com=0A> Date: Friday, January
tts_pilot(at)bellsouth.net>=0A> =0A> I find it rather ludicrous to build an ef
ficient airplane=0A> only to hang the handle and a speed brake on the outsi
de of=0A> the door.- IMHO, it's a poor solution at best.=0A> Linn=0A> =0A
erry(at)qwest.net>=0A> > =0A> > Attached are photos of the new door safety lat
ch,=0A> which I think are self explanatory. It is my understanding=0A> that
everyone with a finish kit will have their parts and=0A> drawings by the e
nd of next week. The only thing I would=0A> consider changing is to increas
e the angle between the legs=0A> of the springs that you will fabricate. My
personal=0A> preference would be for a stronger spring loading of the=0A>
latch. I don't have a way to scan the large format drawings,=0A> but will t
ry to photograph them and get them posted later=0A> today.=0A> > =0A> > Jim
Berry=0A> > 40482=0A> > N15JB=0A> > =0A> > =0A> > =0A> > =0A> > Read this
topic online here:=0A> > =0A> > http://forums.matronics.com/viewtopic.php?p
=281668#281668=0A> > =0A> > =0A> > =0A> > =0A> > Attachments: =0A> > http
://forums.matronics.com//files/img_0441_836.jpg=0A> > http://forums.matroni
cs.com//files/img_0440_915.jpg=0A> > http://forums.matronics.com//files/img
_0439_172.jpg=0A> > http://forums.matronics.com//files/img_0438_137.jpg=0A>
=========================0A
- - - - - - - -=0A> - - - - - - - -Matt=0A> D
===============0A> =0A> =0A> =0A>
From: | Scott Schmidt <scottmschmidt(at)yahoo.com> |
(I posted this at VAF, I also am not very impressed)
I am going to have to think about this SB before installing.
It would have been nice to talk with the whole community of RV-10
builders before launching this SB. I do not feel it is necessary and is
just an extra device that if not installed properly will not function
correctly I would suspect. If you drive to root cause on the door issue
it comes down to people not installing the warning lights, and not
properly completing their pre-flight.
I don't want to offend anyone that has had their door come off but I
have heard many stories about the doors that have come off, especially
the one that hit the horizontal stabilizer and there were many other
factors involved with that incident. Most of them will admit that the
door was never fully closed before taking off. All of them should have
been prevented through proper preflight and checklists.
If the current system is installed correctly, the indicator lights
installed, it is very unlikely and almost impossible to have a problem.
The only way for the door to open is if you squeezed the interlock on
the handle and opened the door. I know there are many RV-10's flying
around with no indicator lights on the doors and I don't understand
why. They work so great. On my doors if the pin moves 1/8" away from
fully closed the lights come on.
My preflight includes the following:
-Confirm door handle has locked into place
-Check all four corners for any obvious gap
-Check door ajar light
-Before takeoff, check all warning lights (includes the door ajar light)
If the proximity sensors are installed correctly it is IMPOSSIBLE not
to have each of the four pins in their proper spot. If one is caught
outside the cabin (which has happened to me when passengers try to shut
the door before I get there) the light is on and there is an obvious
gap.
Another concern I read about is the handle not locking into place. If
yours does not, take it apart and fix it. Once mine snaps into place it
will not rotate and is very safe.
I may find that this is a great addition after I have played with
someones door that has this new addition but I won't be adding this to
my experimental plane anytime soon. I worry about emergencies and
having someone on the outside who is trying to get me and my family out
try to understand that you have to lift the little handle, push the
button and rotate the handle.
I agree that the door can be improved but this is a very poor band-aid.
I don't want to get flamed here, I just want new builders to understand
that the doors are not unsafe and if installed correctly with the
warning lights and properly locking handles they are safe. New builders
have this perception that the doors need a 100% redesign, and I don't
want anyone to be scared off.
Scott Schmidt
Sent: Fri, January 15, 2010 3:01:38 PM
Subject: Re: RV10-List: Re: Door safety latch
I find it rather ludicrous to build an efficient airplane only to hang the handle
and a speed brake on the outside of the door. IMHO, it's a poor solution at
best.
Linn
> Jim Berry
> 40482
> N15JB
Fortunately the "mandatory " nature of this does not apply nor does the
compliance timeframe. undoubtedly there will be builders who will offer the
obligatory "yes sir three bags full" but this should be considered for each
particular situation and aircraft. After all, the beauty of this is that the
builder is the manufacturer. You did specify that you or your organization
was the manufacturer on the airworthiness forms.
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt
Sent: Friday, January 15, 2010 3:31 PM
It would have been nice to talk with the whole community of RV-10 builders
before launching this SB. I do not feel it is necessary and is just an extra
device that if not installed properly will not function correctly I would
suspect. If you drive to root cause on the door issue it comes down to
people not installing the warning lights, and not properly completing their
pre-flight.
I don't want to offend anyone that has had their door come off but I have
heard many stories about the doors that have come off, especially the one
that hit the horizontal stabilizer and there were many other factors
involved with that incident. Most of them will admit that the door was never
fully closed before taking off. All of them should have been prevented
installed, it is very unlikely and almost impossible to have a problem. The
only way for the door to open is if you squeezed the interlock on the handle
and opened the door. I know there are many RV-10's flying around with no
indicator lights on the doors and I don't understand why. They work so
great. On my doors if the pin moves 1/8" away from fully closed the lights
come on.
If the proximity sensors are installed correctly it is IMPOSSIBLE not to
have each of the four pins in their proper spot. If one is caught outside
the cabin (which has happened to me when passengers try to shut the door
before I get there) the light is on and there is an obvious gap.
Another concern I read about is the handle not locking into place. If yours
does not, take it apart and fix it. Once mine snaps into place it will not
I may find that this is a great addition after I have played with someones
door that has this new addition but I won't be adding this to my
experimental plane anytime soon. I worry about emergencies and having
someone on the outside who is trying to get me and my family out try to
understand that you have to lift the little handle, push the button and
rotate the handle.
I agree that the door can be improved but this is a very poor band-aid. I
don't want to get flamed here, I just want new builders to understand that
the doors are not unsafe and if installed correctly with the warning lights
and properly locking handles they are safe. New builders have this
perception that the doors need a 100% redesign, and I don't want anyone to
be scared off.
Scott Schmidt
_____
handle and a speed brake on the outside of the door. IMHO, it's a poor
solution at best.
Linn
explanatory. It is my understanding that everyone with a finish kit will
have their parts and drawings by the end of next week. The only thing I
would consider changing is to increase the angle between the legs of the
springs that you will fabricate. My personal preference would be for a
stronger spring loading of the latch. I don't have a way to scan the large
format drawings, but will try to photograph them and get them posted later
today.
> Jim Berry
> 40482
> N15JB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I'm with Scott on this one. I spent a lot of time on my latchs so that the
pins go thru an after market Metal block and then at least 1/2" thru the fr
ame on both sides of the doors.
The doors would have to REALLY flex before these rods would pull out. Besi
des=2C that is one "fuggly" looking exterior latch! :-)
Date: Fri=2C 15 Jan 2010 14:30:38 -0800
(I posted this at VAF=2C I also am not very impressed)
it comes down to people not installing the warning lights=2C and not
have heard many stories about the doors that have come off=2C especially
If the current system is installed correctly=2C the indicator lights
installed=2C it is very unlikely and almost impossible to have a problem.
-Before takeoff=2C check all warning lights (includes the door ajar light)
gap.
yours does not=2C take it apart and fix it. Once mine snaps into place it
try to understand that you have to lift the little handle=2C push the
I don't want to get flamed here=2C I just want new builders to understand
have this perception that the doors need a 100% redesign=2C and I don't
want anyone to be scared off. Scott Schmidtscottmschmidt(at)yahoo.com
Sent: Fri=2C January 15=2C 2010 3:01:38 PM
latch
handle and a speed brake on the outside of the door. IMHO=2C it's a poor s
olution at best.
Linn
Jim Berry wrote:
> Attached are photos of the new door safety latch=2C which I think are sel
f explanatory. It is my understanding that everyone with a finish kit will
have their parts and drawings by the end of next week. The only thing I wou
ld consider changing is to increase the angle between the legs of the sprin
gs that you will fabricate. My personal preference would be for a stronger
have a way to scan the large format drawings=2C but will try to photograph
> Jim Berry
> 40482
> N15JB
Hotmail: Trusted email with Microsoft=92s powerful SPAM protection.
All valid points, except that aileron trim is no where near as important
as elevator trim. The examples you cite are all for elevator trim. I've
heard the message from Tim and others that aileron trim is worthwhile.
Some autopilots have aileron trim function built in. My Mooney has a
knob on the turn coordinator that I just dial what gives a no turn,
wings level position, and that is a crude Brittain wing leveler from the
'60s.
> Albert Gardner
> N991RV
> Yuma, AZ
> Linn
>>>> kit?
Scott;
I have to admit I've been thinking about this SB as well. I was actually
waiting for Tim to chime in and was quite glad to see your response.
Thanks for taking time to give that feedback.
Pascal
Sent: Friday, January 15, 2010 2:30 PM
around with no indicator lights on the doors and I don't understand why.
They work so great. On my doors if the pin moves 1/8" away from fully
gap.
my experimental plane anytime soon. I worry about emergencies and having
rotate the handle.
Scott Schmidt
Linn
self explanatory. It is my understanding that everyone with a finish kit
will have their parts and drawings by the end of next week. The only
thing I would consider changing is to increase the angle between the
legs of the springs that you will fabricate. My personal preference
would be for a stronger spring loading of the latch. I don't have a way
to scan the large format drawings, but will try to photograph them and
> Jim Berry
> 40482
> N15JB
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
Beings I dont have an outside passenger door handle anyway..............
guess I will not have an outside safety latch on the passenger door eith
er.
Let's get creative with the looks of the outside latch...............thi
nk I will make it look like the arm on a Vegas slot machine. Every time
you pull it down to get in you are taking a gamble OR by getting in and
flyng the RV10 you have hit the Jackpot of all 4 place planes!
Dean
805HL "400 Hours with a goal of 500 by 2011"
Weight Loss Program
Best Weight Loss Program - Click Here!
http://thirdpartyoffers.juno.com/TGL2131/c?cp=0OGubPYCYkWM3fYO_vCwuQAA
Jz0315TiJGQRTntSFamdGWtMAAYAAAAAAAAAAAAAAAAAAADNAAAAAAAAAAAAAAAAAAAEUgAA
AAA
My engine is experimental, simply because I have Eci cylinders. Eci
cylinders have a revised FAA AD on them which leads me to believe
regardless of if it's certified or not I think one is still required to
make the changes per the AD.
P
Sent: Friday, January 15, 2010 1:31 PM
does. Certified parts to remain certified must comply with ADs.
McMullen
all aircraft/components they are issued for. If AD comes out on a
Lycoming IO540 crankshaft, piston pin plugs, etc. it does apply to any
aircraft that has the exact engine called out, whether experimental or
not, according to FAA. Of course EAA disputes that, but we know FAA
writes, interprets, enforces and is judge jury and executioner. NTSB is
a rubber stamp for the most part. Not disagreeing with your comments
about Service Bulletins, just pointing out that there are many opinions
for experimental aircraft are advisory only ; even certified aircraft
are required to comply with SBs only if used commercially. Neither Vans
nor the FAA have authority to require compliance prior to further
flight. These are not ADs; ADs apply to certified aircraft.
court as official notification. Meaning the clock hasn't started for
compliance.
revised plans, with the appropriate materials; that's a different story.
J Cause they still don't know about the SB yet..
(Michael Sausen)
is.
Michael
David,
Phil
http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht
I fully agree with Scott and his post. I would add to the reasons the
doors may be opening is poor construction and/or amending the door pin m
easurements to make the pins not protrude out so far and scratch the pai
nt when shut accidently. Look at some of the GAPS in these doors on som
e finished planes and the way the door seal is attached.
These planes are not aerobatic either. Doors made per the plans and flo
wn per the specs will not accidently come open during flight. I am sure
LIABILITY is driving this SB and I am also sure the RV community will e
ngineer a much better fix (if needed) than what is proposed.
My 2 cents to a senseless issue.
DEAN
Weight Loss Program
http://thirdpartyoffers.juno.com/TGL2131/c?cp=CCww_HTcogGrPjRtmf4FEQAA
AAA
The beauty of being experimental is that we can each decide whether we want to
install the safety latch; although your insurance company might disagree if you
had a door opening incident.
Deems idea of a grab strap would be very easy to incorporate. Since the latch kit
includes an aluminum sheet on both sides of the fiberglass, it would make a
good hard point to mount a handle.
When the door handle is opened, the latch allows the bottom of the door to open
approximately 1/2 to 3/4 inch.
Someone commented that the latch cannot be opened from the inside. Not true, just
lift the latch.
The exterior latch is 1/8 inch thick, and requires very little force to open. It
could probably be smallified top to bottom without compromising strength or
function.
Someone with CNC capabilities could make a much more attractive version of the
latch.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=281733#281733
There is no way I'm putting that piece of Frankenstein crap on my aircraft.
Jeeez.WTF is Van's thinking except putting this out to cover their ass. I
think a bungee cord between the two door handles inside would work much
better. Sorry but I'll check the lights, check the doors and continue on. So
far my policy and procedures have worked fine and have proven that too!!
Sent: Friday, January 15, 2010 2:53 PM
Subject: RE: RV10-List: Re: Door safety latch
_____
pre-flight.
come on.
rotate the handle.
be scared off.
Scott Schmidt
_____
solution at best.
Linn
today.
> Jim Berry
> 40482
> N15JB
<http://forums.matronics.com/files/img_0441_836.jpg>
<http://forums.matronics.com/files/img_0440_915.jpg>
<http://forums.matronics.com/files/img_0439_172.jpg>
what does the data plate on your engine say?
_____
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, January 15, 2010 5:24 PM
cylinders have a revised FAA AD on them which leads me to believe regardless
of if it's certified or not I think one is still required to make the
changes per the AD.
P
_____
_____
_____
(Michael Sausen)
Michael
David,
Phil
From: | Jeff Carpenter <jeff(at)westcottpress.com> |
Anyone thinking of integrating the interior aspect of the latch with
the fore/aft movement of the door pin and omit the exterior aspect of
the latch all together?
Jeff Carpenter
40304
Suddenly happy my doors aren't quite finished yet
> kit will have their parts and drawings by the end of next week. The
> only thing I would consider changing is to increase the angle
> between the legs of the springs that you will fabricate. My personal
> preference would be for a stronger spring loading of the latch. I
> Jim Berry
> 40482
> N15JB
It does not matter. The AD is against the ECI cylinders installed on an
aircraft. Just as Lycoming has no say in the AD, nor does Cessna or Piper.
> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Pascal
> *Sent:* Friday, January 15, 2010 5:24 PM
> *Subject:* Re: RV10-List: 10 SB
ess
> changes per the AD.
> P
> *From:* DLM
> *Sent:* Friday, January 15, 2010 1:31 PM
> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly McMullen
> *Sent:* Friday, January 15, 2010 1:30 PM
> all aircraft/components they are issued for. If AD comes out on a Lycomin
g
> IO540 crankshaft, piston pin plugs, etc. it does apply to any aircraft th
at
> has the exact engine called out, whether experimental or not, according t
o
> FAA. Of course EAA disputes that, but we know FAA writes, interprets,
> enforces and is judge jury and executioner. NTSB is a rubber stamp for th
e
> most part. Not disagreeing with your comments about Service Bulletins, ju
st
> pointing out that there are many opinions on applicability of ADs.
the
are
>> court as official notification. Meaning the clock hasn=92t started for
>> compliance.
J
d
he
e I
ete
l of
>> Sausen)
>> Michael
>> David,
=85
>> Phil
they
uld
From: | Don McDonald <building_partner(at)yahoo.com> |
Subject: | Re: Door safety latch |
Rick, I totally agree with you....=C2- although my Van's idiot lights are
not functioning.=C2- Van's sent out a number of micro switches which wer
e ass backwards.=C2- I tried everything to get them to work, then just ga
ve up on them.=C2- Then Van's sends out a bulletin saying if you received
a specific=C2-part numbered micro switch, let them know and they'd send
=C2-out the correct ones.=C2- Well, in the meantime, my pre-takeoff pro
cedure was, and is, to personally verify that each door is totally closed,
and locked.... pretty simple... I do it EVERYTIME.=C2- After a very short
time, it's a total habit.=C2- That coupled with the fact that I threw aw
ay the Van's=C2-plastic/nylon receivers and replaced them with the billet
ed replacements, leaves me=C2-feeling very confident with my RV10 doors.
My 4cents worth....
Don McDonald=C2-=C2-
Date: Friday, January 15, 2010, 4:46 PM
There is no way I=99m putting that piece of Frankenstein crap on my a
ircraft. =C2-JeeezWTF is Van=99s thinking except putting t
his out to cover their ass. I think a bungee cord between the two door hand
les inside would work much better. Sorry but I=99ll check the lights,
check the doors and continue on. So far my policy and procedures have work
=C2-
=C2-
Fortunately the "mandatory " nature of this does not apply nor does the com
pliance timeframe. undoubtedly there will be builders who will offer the ob
ligatory "yes sir three bags full" but this should be considered for each p
articular situation and aircraft. After all, the beauty of this=C2-is tha
t the builder is the manufacturer. You did specify that you or your organiz
ation was the manufacturer on the airworthiness forms.
=C2-
a device that if not installed properly will not function correctly I would
suspect. If you drive to root cause on the door issue it comes down to peo
ple not installing the warning lights, and not properly completing their pr
e-flight.
I don't want to offend anyone that has had their door come off but I have h
eard many stories about the doors that have come off, especially the one th
at hit the horizontal stabilizer and there were many other factors involved
with that incident. Most of them will admit that the door was never fully
closed before taking off. All of them should have been prevented through pr
If the current system is installed correctly, the indicator lights installe
d, it is very unlikely and almost impossible to have a problem. The only wa
y for the door to open is if you squeezed the interlock on the handle and o
pened the door. I know there are many RV-10's flying around with no indicat
or lights on the doors and I don't understand why. They work so great. On m
y doors if the pin moves 1/8" away from fully closed the lights come on.
If the proximity sensors are installed correctly it is IMPOSSIBLE not to ha
ve each of the four pins in their proper spot. If one is caught outside the
cabin (which has happened to me when passengers try to shut the door befor
door that has this new addition but I won't be adding this to my experiment
al plane anytime soon. I worry about emergencies and having someone on the
outside who is trying to get me and my family out try to understand that yo
u have to lift the little handle, push the button and rotate the handle.
I agree that the door can be improved but this is a very poor band-aid. I d
on't want to get flamed here, I just want new builders to understand that t
and properly locking handles they are safe. New builders have this percepti
on that the doors need a 100% redesign, and I don't want anyone to be scare
d off.
=C2-
Scott Schmidt
=C2-
=C2-
handle and a speed brake on the outside of the door.=C2- IMHO, it's a poo
r solution at best.
Linn
explanatory. It is my understanding that everyone with a finish kit will ha
ve their parts and drawings by the end of next week. The only thing I would
consider changing is to increase the angle between the legs of the springs
that you will fabricate. My personal preference would be for a stronger sp
ring loading of the latch. I don't have a way to scan the large format draw
ings, but will try to photograph them and get them posted later today.
> Jim Berry
> 40482
> N15JB
> http://www.matronics.com/Navigator?RV10-List Web href="http://forums.ma
tronics.com">http://forums.matronics.com -Matt href="http://www.matronics
.com/contribution">http://www.matronics.com/c==========
=0A=0A=0A
depends on whether there is an identification on the ECI cylinders. I would
tend to consider engine ADs more seriously but the identification is key and
who is going to identify the parts except the person holding a repairman
certificate or an A&P/IA? If there is no ID, the parts cannot be determined
as certified.
Sent: Friday, January 15, 2010 7:14 PM
_____
changes per the AD.
P
_____
_____
_____
(Michael Sausen)
Michael
David,
Phil
The big ECI on the valve cover is a big clue. I wouldn't be surprised to se
e
a part number on them as well.
> would tend to consider engine ADs more seriously but the identification i
s
> key and who is going to identify the parts except the person holding a
> repairman certificate or an A&P/IA? If there is no ID, the parts cannot b
e
> determined as certified.
> *Sent:* Friday, January 15, 2010 7:14 PM
less
>> changes per the AD.
>> P
>> *From:* DLM
ng
hat
to
he
ust
r
the
are
n
>>> compliance.
d
J
A
nd
the
se I
lete
el of
l
>>> Sausen)
>>> Michael
>>> David,
=85
>>> Phil
they
ould
Haven't any of you folks thought about hitting the "Post Reply" button instead
of "Quote?" We don't need to see the same stuff over and over again. Sorry for
the rant....
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=281757#281757
Subject: | doors, trim, questions |
Great timing. Finished my 4th flight today and then find a "grounding SB". I have
the aftermarket billets, the pins go way past the fiberglass, the doors "lock"
nicely, and my warning light system works (they don't go out until the latches
click and they are the "push to test" type). So I will continue to fly
until our community comes to a more settled opinion. In terms of the aileron
trim: 4 flights is not a lot of experience but on today's flight I flew the right
tank down fairly low (to make it easier to recalibrate the floats) and I
had to use the trim to get the wings to stay level hands off. Now a few questions:
My elevator trim works well (both equally neutral and both sides stay that
way at cruise speeds) although my elevator horns are up about 1/4 to 1/2 inch
on each side at 145K, -3 flaps, and level flight. (Looks like Tim's picture
on his site). So I think all that is good, but when the trim is neutral the EFIS
trim indicator is way off the neutral (centered indication). I've gone thru
the set up procedure twice with the same results. Any advice on how to "square
up" the indicator? Even the aileron trim indicator is off a bit but I really
have not looked at it with even weighting (fuel and front passengers). One
last question: Have about 7 hours on the engine (Mattituck with 9:1 pistons,
LightSpeed on the top) and have been anal about the break-in: only 20 minutes
of ground time and always 70-75% except for the 4 landings. OAT between 0 and
30F, CHT's never above 365 and oil temps at 170 on climb out and low 160's at
high cruise. And I am not burning any oil!! And it still looks as clear as
when I first put it in. Should I just shut up or am I missing something? Jay
Rowe
Subject: | Re: doors, trim, questions |
Newbie here... but still have ideas.... I would put a blockage of some sort
prior to your scat for the oil cooler... get that oil temp up to 180 to 19
0 range.- Insure that it's burning off any moisture/condensate.- I made
a butterfly valve for the rear of the plenum on mine, and it works great.
- Open all the way, I see numbers like yours, in the low 160's.- but a
little pull on the butterfly valve, 180 to 190.- Other than that, keep fl
ying.- Where are you located?
Don McDonald
Sacramento area
110 hours and counting.
--- On Fri, 1/15/10, jfrjr(at)roadrunner.com wrote:
From: jfrjr(at)roadrunner.com <jfrjr(at)roadrunner.com>
Subject: RV10-List: doors, trim, questions
Date: Friday, January 15, 2010, 7:14 PM
Great timing.- Finished my 4th flight today and then find a "grounding SB
". I have the aftermarket billets, the pins go way past the fiberglass, the
doors "lock" nicely, and my warning light system works (they don't go out
until the latches click and they are the "push to test" type).- So I will
continue to fly until our community comes to a more settled opinion.- In
terms of the aileron trim:- 4 flights is not a lot of experience but on
today's flight I flew the right tank down fairly low (to make it easier to
recalibrate the floats) and I had to use the trim to get the wings to stay
level hands off. Now a few questions:- My elevator trim works well (both
equally neutral and both sides stay that way at cruise speeds) although my
elevator horns are up about 1/4 to 1/2 inch on each side at 145K, -3 flaps,
and level flight. (Looks like Tim's picture on his site). So I think all t
hat is good, but when the trim is neutral the EFIS trim indicator is way
off the neutral (centered !
indication).- I've gone thru the set up procedure twice with the same res
ults.- Any advice on how to "square up" the indicator? Even the aileron t
rim indicator is off a bit but I really have not looked at it with even wei
ghting (fuel and front passengers).- One last question: Have about 7 hour
s on the engine (Mattituck with 9:1 pistons, LightSpeed on the top) and hav
e been anal about the break-in:- only 20 minutes of ground time and alway
s 70-75% except for the 4 landings. OAT between 0 and 30F, CHT's never abov
e 365 and oil temps at 170 on climb out and low 160's at high cruise.- An
d I am not burning any oil!!- And it still looks as clear as when I first
put it in.- Should I just shut up or am I missing something?---Jay
Rowe
le, List Admin.
=0A=0A=0A
From: | "Ron McGann" <ronrvbuilder(at)bigpond.com> |
I would be really interested in hearing from anyone with a background in
insurance. Yes we are the builder, and only airworthiness bodies may be
able to ground aircraft. But if you intentionally fail to comply with an
instruction from the kit supplier and a door departs in flight, what are the
chances of a successful claim??
Ron
_____
Sent: Saturday, 16 January 2010 9:53 AM
_____
pre-flight.
come on.
rotate the handle.
be scared off.
Scott Schmidt
_____
solution at best.
Linn
today.
> Jim Berry
> 40482
> N15JB
> <http://www.matronics.com/Navigator?RV10-List>
You may be broken in, but I would go to at least 15-20 hours doing
what you are doing before deciding to change anything, Perhaps even
25.
On Fri, Jan 15, 2010 at 8:14 PM, wrote:
One last question: Have about 7 hours on the engine (Mattituck with
9:1 pistons, LightSpeed on the top) and have been anal about the
break-in: only 20 minutes of ground time and always 70-75% except for
the 4 landings. OAT between 0 and 30F, CHT's never above 365 and oil
temps at 170 on climb out and low 160's at high cruise. And I am not
burning any oil!! And it still looks as clear as when I first put it
in. Should I just shut up or am I missing something? Jay Rowe
From: | "Wayne Edgerton" <wayne.e(at)grandecom.net> |
Subject: | Re: Door safety latchRe: Door safety latch |
I totally agree with Scott's post. I feel very comfortable with the
doors being closed for similar reasons that Scott posted. I also feel
the door closed lights are a must install. I think I've posted this
before, but because of the various door coming open issues I never let a
passenger close the door. If I have a passenger I stay outside the
airplane until that person is strapped in and then I close their door
from the outside and double checked that it's locked in place.
Wayne Edgerton N602WT
sean(at)stephensville.com wrote:
> Mailing list only members enjoy the quoted portion. Each his own.
But not 10 million copies of the SB from Vans. [Laughing]
Gary Blankenbiller
RV10 - # 40674
(N2GB Flying)
http://forums.matronics.com/viewtopic.php?p=281793#281793
I for one am disappointed with this design. When I first saw the
description I was hoping the hook was operated by the door handle, and
had motion 90 degrees from what the pictures show. That would have
been a major improvement. Unfortunately, this isn't any better than
the solution I saw at Copperstate of installing a second handle inside
and out, that operated a bottom of door latch.
I'm not clear from the pictures, is the tab on the outside always
straight out, recessed when latched? or what? I sure hope one of our
fine CNC parts suppliers can engineer a better solution. Most of the
ideas that put another arm on the door handle to operate some sort of
bottom latch seem promising, perhaps difficult to make work cleanly.
> Gary Blankenbiller
> RV10 - # 40674
> (N2GB Flying)
NEVER LET THE PASSENGER CLOSE THE DOOR. I owned a Cardinal RG for 29 years
and I let the passenger close the door once. They managed to keep pushing
until they sheared the pin in the handle. result : a grounded aircraft until
I disassembled the door and was able to close and return to base to order a
part from Cessna. If you have a facade in the aircraft that covers the pins
then install the lights. I don't and I manually feel the pins twice (before
taxi and before takeoff). I made that decision after calling another member
of the list whom I asked how did the door come off. His reply was : which
time? He then related that he lost a door without the lights and then again
with the lights. In contrast to the current administration, I want to keep a
little freedom to be responsible for my own actions. Responsibility
ultimately rests with the nut on the stick.
Subject: | Fresh Meat: New Door Idea |
I woke up with this idea this morning and thought I'd throw some fresh
meat into the lion den and see if I can't start a really big cat fight.
I hope I do. J
The idea is to use a 12v Solenoid Operated Dead Bolt lock. It would be
installed in mid-fuse decks. The bolt will point up and ultimately
penetrate into the base of the door. The bolt operates when 12v is
applied to the solenoid.
With a very tiny bit of wiring logic, the 12v can be routed through a
micro-switch. That switch is used to detect when the interior (or
exterior) handle has rotated X degrees (from fully open) toward the
closed position. I'll use 20 degrees for example.
- Get in and pull the doors down.
- Rotate the door handle to close the main door pins.
- From 0 degrees to 20 degrees the bolt is retracted.
- At 20 degrees the bolt engages to secure the bottom of the
door (before the main pins have even started through the Nylon or
Aluminum blocks).
- The bolt stays engaged until the handle is rotated back and
the switch opens at 20 degrees.
=A7 By having the bolt engage before the pins enter the door frame, it
protects against those who are concerned with bumping the handle
accidently.
A couple of fail-safe modes and emergency points.
- Should you need rescued from someone on the ground, it can be
operated with the regular exterior door latch. They just twist the door
latch and the micro-switch disengages the b
- Should you have a 12v power failure, the bolt will retract
when the power is lost.
- Should you have an accident that rips the wire from the
solenoid, the bolt will retract.
I can't think of a failure mode that would cause a problem assuming you
use a bolt that extends with 12v and retracts with 0v - not the
opposite.
One of my concerns were damaging the door by extending the bolt without
having the door in the correct position. Meaning the bolt would miss
it's hole and it would push up and damage the bottom of the door.
After a little research, I found this lock has a safety circuit in it.
The force of the bolt deployment is really low and if the bolt can't
extend into a recess, the 12v is removed. Saving the switch and any
damage that could occur. Keep in mind it's designed to deploy into a
female recess and then the bolt is designed to operate in shear. The
bolt isn't designed to punch holes in wooden door frames - or our RV-10
doors.
Okay, now that I've shaken this fresh chicken in front of ALL the lions,
have at it. I've got a Houston RV builders group lunch to go to.... J
http://tinyurl.com/ybktr2s
Kelly,
The tab on the outside moves up and down in the slot, but does not retract at any
time. The slot can be made smaller in both dimensions than as shown in Van's
pictures. Mine is just big enough to get the job done.
If you want a prettier safety latch, look at the rear door latch on the new Diamond
DA40.
Guys, the SB threads have been great. I have not seen such rancor since primer
wars.
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p=281813#281813
How about VANS redesigning the door too make the doorsafer tobegin
with. If more doors fall off with this added latch (hypotheticaly),
what's next more SBs andmore "add-on" hardware? Anyone should be able
to lock a door! Time to redesign it!
Sent from my iPod
On Jan 16, 2010, at 1:24 PM, "Jim Berry" wrote:
> Kelly,
> retract at any time. The slot can be made smaller in both dimensions
> than as shown in Van's pictures. Mine is just big enough to get the
> job done.
> the new Diamond DA40.
> since primer wars.
> Jim Berry
> 40482
> N15JB
Luis;
No offense but the doors are built by the builder themselves. Many have
already made their own mods to hinges, the doors themselves, etc to the
doors and with proper planning (confirm passengers know how to close the
door) there really isn't an issue with the doors. The problem is the plastic
that Vans gives as hinges are simply not the right solution, the doors
naturally have an issue with the rear not closing correctly as the door is
pulled from the front more than the rear.
When you get to this point you'll know that the hinges are the first thing
that Vans should have modified.
Pascal
Sent: Saturday, January 16, 2010 10:47 AM
Subject: Re: RV10-List: Re: 10 SB
> How about VANS redesigning the door too make the doorsafer tobegin with.
> If more doors fall off with this added latch (hypotheticaly), what's next
> more SBs andmore "add-on" hardware? Anyone should be able to lock a
> Sent from my iPod
>> Kelly,
>> than as shown in Van's pictures. Mine is just big enough to get the job
>> done.
>> new Diamond DA40.
>> primer wars.
>> Jim Berry
>> 40482
>> N15JB
I suggest that all RV-10 builders and flyers with serial numbers write Van's at
info(at)vansaircraft.com
I have done the same and have asked Van's to retract the Service Bulletin and offer
the latch as an additional and optional latch just as the indicator lights
were offered.
I want to summarize what I have heard here.
Issues with the door will arise if:
-Poor door construction causing a bow during flight (Construction error) (Fix:
Re-build door or add Van's center latch)
-Pins are not inserted far enough into the aluminum frame (Construction error)
(Fix: Re-build pins to extend into aluminum frame)
-Door handle interlock is not engaged (Construction error and/or pilot error) (Fix:
Ensure handles are locked before flight, possible rebuild of interlock)
-Door pins were locked outside of cabin (Pilot error)(Fix: Add door check to checklist)
I am fine with Van's offering this as an optional kit but when they say on the
service bulletin that it is mandatory, I have a problem.
This is 100% different from the previous SB where we added stiffeners to the vertical
stabilizer and empenage.
I want everyone to fly safe and keep our insurance as low as possible, I don't
see this as the solution though.
We need to take personal responsibility to build to the highest quality and use
our checklists thoroughly.
Any system that is put into place (such as our checklists) is never fixed with
more protection devices, system only work and are improved through training and
discipline.
This solution is like adding a fixed gear to the bottom of a retractable landing
gear aircraft. It will be there just in case you don't put the gear down.
The warnings lights and center latch should be optional as 100% safe flight can
be accomplished with the stock system. I do feel there are may pilots flying
safely without even the lights because of their training and checklist discipline.
The experimental category will always have construction issues and must
accept personal responsibility for that and not burden the whole fleet with the
quality shortcomings of the few.
I want everyone to fly safe, have fun and explore this world with their planes
and I appreciate Van's offering a system that solves a problem that a few of RV-10's
have with the doors bowing as a total replacement of the door is very expensive.
Again, please write Van's and ask for the removal of this SB and make it optional.
Scott Schmidt
Sent: Sat, January 16, 2010 11:24:03 AM
Subject: RV10-List: Re: 10 SB
Kelly,
DA40.
wars.
Jim Berry
40482
N15JB
You mean you don't want a belt, suspenders, elasticized waist and special
Velcro adhesive? I measured my pins this morning and the OD of the pins
range from .436 to .438; theoretically they should be .4375. In 225 hours
they may have worn 15/10000 of an inch; I probably will replace them at
engine overhaul. Otherwise after door closure, I just touch each of them
twice before each departure.
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Luis Rodriguez
Sent: Saturday, January 16, 2010 11:48 AM
How about VANS redesigning the door too make the doorsafer tobegin with. If
more doors fall off with this added latch (hypotheticaly), what's next more
SBs andmore "add-on" hardware? Anyone should be able to lock a door! Time
to redesign it!
Sent from my iPod
> Kelly,
> job done.
> since primer wars.
> Jim Berry
> 40482
> N15JB
once again Scott I agree with your suggestion. Thinking through the
letter and it will go out today, this isn't a solution it's a bandaid.
With the negative feedback seen it is obvious most of us have no
intention of doing this mod so why force me as a builder to "have to".
Sent: Saturday, January 16, 2010 11:31 AM
Van's at info(at)vansaircraft.com
Bulletin and offer the latch as an additional and optional latch just as
the indicator lights were offered.
(Fix: Re-build door or add Van's center latch)
error) (Fix: Re-build pins to extend into aluminum frame)
error) (Fix: Ensure handles are locked before flight, possible rebuild
of interlock)
check to checklist)
on the service bulletin that it is mandatory, I have a problem.
the vertical stabilizer and empenage.
don't see this as the solution though.
and use our checklists thoroughly.
fixed with more protection devices, system only work and are improved
through training and discipline.
landing gear aircraft. It will be there just in case you don't put the
gear down.
flight can be accomplished with the stock system. I do feel there are
may pilots flying safely without even the lights because of their
training and checklist discipline. The experimental category will
always have construction issues and must accept personal responsibility
for that and not burden the whole fleet with the quality shortcomings of
the few.
planes and I appreciate Van's offering a system that solves a problem
that a few of RV-10's have with the doors bowing as a total replacement
optional.
Scott Schmidt
Subject: | Door Latch Ideas |
Here is a couple of ideas for all the engineers out there that want to change the
latch. After sitting in Scotts' airplane I came to the conclusion it wasn't
needed but I personally think this is way better than the S.B. or B.S?
I know there are tons of versions of this idea it's just to keep everyone thinking
of a better solution if it's going to be mandatory.
http://www.youtube.com/watch?v=pqOtd-lEQfU
Cust. #40936
RV-10 SB Fuselage
N801VR reserved
http://forums.matronics.com/viewtopic.php?p=281828#281828
Thanks for publishing the 45A PDF. I have no problem with offering this as
an option but some builders may think that they must do this before further
flight. As I have suggested in the past, the fixed length of your pins is
too short. The pins may not fully (full circumference) engage the metal door
frames, depending on where the latch mechanism is located in the latch box.
The pins should be lengthened by 1/2 inch and the user should cut and bevel
as required to fully engage the pins when closing. It seems to me that the
heart of the closing problem is the inattention of the PIC complicated by
the interior facade to make this airplane into a Cirrus/Columbia look alike.
This mod along with the lights seem to be a belt, suspenders, elasticized
waist band and special Velcro adhesive. I realize there must be some
litigation concerns but ultimate responsibility is the Manufacturer (not
Vans) and the PIC. There have been no fatalities and only one significant
airframe damage due to a departing door (which may have had structural
damage earlier), therefore, I believe, a less strident approach is
necessary.
_____
Sent: Friday, January 15, 2010 8:27 AM
Subject: 10 SB
I believe you would eliminate a lot of calls to technical support by
publishing the plans changes in PDF form. It would seem that Section 45A
will be common knowledge in about two weeks; why not publish as a PDF and
eliminate the calls to technical support looking for information. Also the
time of compliance is not very realistic; perhaps it should indicate
different times for flying and not flying aircraft, given that flying
aircraft have already been operating safely via other methods. In my case I
am the only pilot; I have lengthened Van's supplied pins to ensure complete
engagement of the metal door frames. My checklist calls for a manual feel of
the pins when engaged (twice) before takeoff.
From: | "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com> |
Scott,
I'm just now catching up on this but agree with all points below and have a
lready sent an email to Van's. I would also add (and did in my email) that
many builders have also added door pin guides (IFLYRV10.com) which have co
nical receivers for the pins to address the potential issue of misalignment
when the door is initially closed. Further, these increase the surface ar
ea that the pins contact which prevents the wallowing out of the hole in th
e door frame that some have experienced. Even with these guides installed
though, the pins should extend through the actual door frame.
My point was also that the SB is fine, just don't make it mandatory.
N442PM (flying with no door latching issues)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m
Sent: Saturday, January 16, 2010 12:31 PM
nd offer the latch as an additional and optional latch just as the indicato
r) (Fix: Ensure handles are locked before flight, possible rebuild of inter
lock)
o checklist)
ith more protection devices, system only work and are improved through trai
nding gear aircraft. It will be there just in case you don't put the gear d
own.
can be accomplished with the stock system. I do feel there are may pilots
flying safely without even the lights because of their training and checkl
ist discipline. The experimental category will always have construction is
sues and must accept personal responsibility for that and not burden the wh
ole fleet with the quality shortcomings of the few.
nes and I appreciate Van's offering a system that solves a problem that a f
ew of RV-10's have with the doors bowing as a total replacement of the door
is very expensive.
tional.
Scott Schmidt
From: | "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> |
Interesting idea and similar to something else I was thinking about. The
biggest problem would be a rather strong electromagnet in the vicinity of
a whole bunch of sensitive avionics.
michael
atronics.com] On Behalf Of Perry, Phil
Sent: Saturday, January 16, 2010 10:40 AM
Subject: RV10-List: Fresh Meat: New Door Idea
I woke up with this idea this morning and thought I'd throw some fresh meat
into the lion den and see if I can't start a really big cat fight. I hope
I do. :)
The idea is to use a 12v Solenoid Operated Dead Bolt lock. It would be in
stalled in mid-fuse decks. The bolt will point up and ultimately penetrate
into the base of the door. The bolt operates when 12v is applied to the s
olenoid.
With a very tiny bit of wiring logic, the 12v can be routed through a micr
o-switch. That switch is used to detect when the interior (or exterior) ha
ndle has rotated X degrees (from fully open) toward the closed position.
- At 20 degrees the bolt engages to secure the bottom of the door
(before the main pins have even started through the Nylon or Aluminum block
s).
- The bolt stays engaged until the handle is rotated back and the
=A7 By having the bolt engage before the pins enter the door frame, it pro
tects against those who are concerned with bumping the handle accidently.
- Should you need rescued from someone on the ground, it can be op
erated with the regular exterior door latch. They just twist the door latc
- Should you have a 12v power failure, the bolt will retract when
the power is lost.
- Should you have an accident that rips the wire from the solenoid
I can't think of a failure mode that would cause a problem assuming you use
a bolt that extends with 12v and retracts with 0v - not the opposite.
One of my concerns were damaging the door by extending the bolt without hav
ing the door in the correct position. Meaning the bolt would miss it's hol
After a little research, I found this lock has a safety circuit in it. The
force of the bolt deployment is really low and if the bolt can't extend i
nto a recess, the 12v is removed. Saving the switch and any damage that co
uld occur. Keep in mind it's designed to deploy into a female recess and t
hen the bolt is designed to operate in shear. The bolt isn't designed to p
unch holes in wooden door frames - or our RV-10 doors.
Okay, now that I've shaken this fresh chicken in front of ALL the lions, ha
ve at it. I've got a Houston RV builders group lunch to go to.... :)
Subject: | Re: Fresh Meat: New Door Idea |
What about getting out after an incident and power is not available, like fire?
http://forums.matronics.com/viewtopic.php?p=281835#281835
From: | "Paul Grimstad" <Grimsonco(at)comcast.net> |
Subject: | Quick Build Wing Kit |
Complete quick build wing kit For Sale. Delivery options available.
Inventory complete without stall warning system.
Includes wing storage cart on casters.
Paul Grimstad,
Portland, Or.
503-849-2123
No power = A retracted bolt.
Anytime power is removed (Electrical System Failure, Broken Wire, Popped
Fuse, Damaged Switch, etc...) the bolt will retract and allow you to
operate the door normally.
BTW: Michael, that's a good thought on the electromagnetic aspect.
Definitely something to think about.
Phil
-----Original Message-----
Sent: Saturday, January 16, 2010 2:53 PM
Subject: RV10-List: Re: Fresh Meat: New Door Idea
like fire?
Maybe just shielding the solenoid with Mu Metal: http://www.aircraftspruce.com/catalog/inpages/magneticcompassshield.php? This is used in a variety of applications like test equipment where you need to contain electromagnetic fields from sensitive circuitry. Most EFIS systems use remote magnetometers so the real issue would be an old school compass. The vertical card variety are more sensitive than the fluid filled variety.
N442PM (flying)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil
Sent: Saturday, January 16, 2010 3:53 PM
Subject: RE: RV10-List: Re: Fresh Meat: New Door Idea
Phil
like fire?
So your saying that when the power is removed the bolt/pin retracts? If so what
about an in flight power failure and the aft door pin happens to be out of place?
I know what if, what if, but that is what we are trying to protect ourselves
from.
http://forums.matronics.com/viewtopic.php?p=281848#281848
Well, you'd probably lose your door. :)
By the time we get to compounding what-if's, I'd take any of those bets.
Especially when they're both remote possibilities.
I'm not an odds maker or statistician, but I'd bet those are some pretty
long odds. My wife has a PhD minor is statistics, maybe we can ask
her... :)
Phil
Sent: Saturday, January 16, 2010 5:17 PM
so what about an in flight power failure and the aft door pin happens to
be out of place? I know what if, what if, but that is what we are trying
to protect ourselves from.
One question, anyone have any dimensions on the lock?-
One variation, I wonder if installing it along the bottom of the door would
solve door bulge issues in addition to the extra security in keeping the d
oor closed.
Date: Saturday, January 16, 2010, 6:17 PM
what about an in flight power failure and the aft door pin happens to be ou
t of place? I know what if, what if, but that is what we are trying to prot
ect ourselves from.
le, List Admin.
From: | "Billy & Tami Britton" <william(at)gbta.net> |
Subject: | Wing skin question |
Page 16-2 step 5. Wing skin joint detail. I kinda understand what it's
asking me to do but does anybody have any pics of exactly what it wants.
How is the best way to accomplish this job?
Thanks in advance,
From: | John Gonzalez <indigoonlatigo(at)msn.com> |
Subject: | Re: SB 10, VERY IMPORTANT! |
I said this a long time ago. Perhaps this is a known=2C but until the build
ing instructions explicitly say to notch out both side of the door gear box
=2C there is no way to make the pin length long enough to get the travel di
stance which is necessary for safe door latching. The pictures I shared ear
lier in the day showed my pins 1/4"-1/2" PAST THE EXTRA 1/8" ALUMINUM PLATE
WHICH IS SECURED TO THE DOOR FRAME. Subtract the thichness of this plate a
nd the pin would be almost 3/4" past the aluminum door frame. Also=2C BY HA
VING THE PIN TRAVEL SO LARGE=2C THERE IS NO WAY THE INTERIOR DOOR HANDLE CO
ULD BE IN THE CLOSED POSITION AND THE DOOR NOT COMPLETELY OUT OF WACK IF TH
E PINS WERE NOT IN THEIR RECEIVERS.
The plastic guide blocks are only guides and they are plastic so they don't
damage the points on the pins. They were never intended for structural use
Please study the photos which show how to increase the travel of the pins.
Not everyone has done this and for those that have=2C sorry to bore you.
Also=2C if one builds the cabin top return so that it sits flush with the i
nterior of the door=2C there is no guessing that the door is closed. If you
look down and only see the Van's door seals=2C how do you know????
No 4' X 8' plywood needed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 13, 2010 - January 16, 2010
RV10-Archive.digest.vol-fw
