RV10-Archive.digest.vol-fy
January 18, 2010 - January 27, 2010
      > RV-10 #40333
      > N540XP (reserved)
      > http://forums.matronics.com/viewtopic.php?p=282180#282180
Subject: Left exhaust hanger
Date: Jan 18, 2010
Using Vans metal tubing with rubber hose stock and dual clamps, I found that with time the clamps will allow the hose to slide down from the initial position. The exhaust stack made contact with the fiberglass lower cowl. A beading tool allowed a quick ridge to be formed on the metal tube stock to capture the hose and clamp. Looks like it will be a longer term fix. Some of you might find the similar change over time. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, January 18, 2010 12:20 PM Subject: Re: RV10-List: Left exhaust hanger I am assuming you are using the stock Vetterman.... that being said, I tossed the original brackets aside, and built my own out of stainless. (I know several of you out there, just said, "of course he did").... It seemed to me that to be properly positioned the bracket needed to be bent, and the original bracket had lot's of mounting holes in it, which would have made it even weaker. The attached pics should help. Just zoom in on the first one to the actual bracket. I made a couple of extra if you're interested. 100+ hours and no problems whatsoever. Don McDonald --- On Mon, 1/18/10, Jae Chang wrote: From: Jae Chang <jc-matronics_rv10(at)jline.com> Subject: RV10-List: Left exhaust hanger To: rv10-list(at)matronics.com Date: Monday, January 18, 2010, 9:08 AM http://us.mc537.mail.yahoo.com/mc/compose?to=jc-matronics_rv10@jline.c o m> > http://picasaweb.google.com/lh/photo/A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1 s RgCI7088GZlYCc2AE&feat=directlink I am looking to get some ideas of doing the left exhaust hangar mount. Does anyone have any photos of what they did? It seems a bit rube goldberg as there is a lot of interference points: the air cooler, the heat scat, tubes, etc. Any--> http://www.mat==================== <http://forums.matronics.com/> ________________________________________________________________________________
Subject: Re: 10 SB
Date: Jan 19, 2010
I just received my kit of parts for the Door latch SB courtesy of John Cox - thanks John!! The latch mod is certainly a very agricultural piece of design. I am with Scott and the growing chorus to write to Vans and recommend a review of the 'mandatory' nature of this SB. I'll watch with interest for the more elegant solutions I'm sure the more enterprising builders will propose. And I'll continue flying in the meantime. Cheers Ron VH-XRM, flying in Oz _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Sunday, 17 January 2010 6:31 AM Subject: Re: RV10-List: Re: 10 SB I suggest that all RV-10 builders and flyers with serial numbers write Van's at info(at)vansaircraft.com I have done the same and have asked Van's to retract the Service Bulletin and offer the latch as an additional and optional latch just as the indicator lights were offered. I want to summarize what I have heard here. Issues with the door will arise if: -Poor door construction causing a bow during flight (Construction error) (Fix: Re-build door or add Van's center latch) -Pins are not inserted far enough into the aluminum frame (Construction error) (Fix: Re-build pins to extend into aluminum frame) -Door handle interlock is not engaged (Construction error and/or pilot error) (Fix: Ensure handles are locked before flight, possible rebuild of interlock) -Door pins were locked outside of cabin (Pilot error)(Fix: Add door check to checklist) I am fine with Van's offering this as an optional kit but when they say on the service bulletin that it is mandatory, I have a problem. This is 100% different from the previous SB where we added stiffeners to the vertical stabilizer and empenage. I want everyone to fly safe and keep our insurance as low as possible, I don't see this as the solution though. We need to take personal responsibility to build to the highest quality and use our checklists thoroughly. Any system that is put into place (such as our checklists) is never fixed with more protection devices, system only work and are improved through training and discipline. This solution is like adding a fixed gear to the bottom of a retractable landing gear aircraft. It will be there just in case you don't put the gear down. The warnings lights and center latch should be optional as 100% safe flight can be accomplished with the stock system. I do feel there are may pilots flying safely without even the lights because of their training and checklist discipline. The experimental category will always have construction issues and must accept personal responsibility for that and not burden the whole fleet with the quality shortcomings of the few. I want everyone to fly safe, have fun and explore this world with their planes and I appreciate Van's offering a system that solves a problem that a few of RV-10's have with the doors bowing as a total replacement of the door is very expensive. Again, please write Van's and ask for the removal of this SB and make it optional. Scott Schmidt scottmschmidt(at)yahoo.com _____ From: Jim Berry <jimberry(at)qwest.net> Sent: Sat, January 16, 2010 11:24:03 AM Subject: RV10-List: Re: 10 SB ________________________________________________________________________________
Date: Jan 18, 2010
Subject: Re: Left exhaust hanger
John, I roughed mine up with very coarse sand paper and it has not slipped in 650 hours. -Scott Sent from my iPhone On Jan 18, 2010, at 10:17 PM, "John Cox" wrote: Using Vans metal tubing with rubber hose stock and dual clamps, I found that with time the clamps will allow the hose to slide down from the initial position. The exhaust stack made contact with the fiberglass lower cowl. A beading tool allowed a quick ridge to be formed on the metal tube stock to capture the hose and clamp. Looks like it will be a longer term fix. Some of you might find the similar change over time. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, January 18, 2010 12:20 PM Subject: Re: RV10-List: Left exhaust hanger I am assuming you are using the stock Vetterman.... that being said, I tossed the original brackets aside, and built my own out of stainless. (I know several of you out there, just said, "of course he did").... It seemed to me that to be properly positioned the bracket needed to be bent, and the original bracket had lot's of mounting holes in it, which would have made it even weaker. The attached pics should help. Just zoom in on the first one to the actual bracket. I made a couple of extra if you're interested. 100+ hours and no problems whatsoever. Don McDonald --- On Mon, 1/18/10, Jae Chang wrote: From: Jae Chang <jc-matronics_rv10(at)jline.com> Subject: RV10-List: Left exhaust hanger Date: Monday, January 18, 2010, 9:08 AM http://picasaweb.google.com/lh/photo/A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink I am looking to get some ideas of doing the left exhaust hangar mount. Does anyone have any photos of what they did? It seems a bit rube goldberg as there is a lot of interference points: the air cooler, the heat scat, tubes, etc. Any--> http://www.mat==================== ________________________________________________________________________________
Date: Jan 19, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: doors & insulation
Interesting. Someone else had mentioned using 1120A311 which I purchased. I have the older green top and find that most of the edges are 1/4" or better. The only section that is consistently less than 1/4" is the bottom sill. I'm guessing that the newer pink top is a bit thinner and more consistent in edge thickness if you had to build them up. I've been trying to figure out how to grind much of my edges down to 3/16" to fit the A311. So, I think I'm going to get 30' of the A411. Given the added thickness of the headliner abric that will be underneath it, I think that will be easier to work with. Thanks Bill Geoff Combs wrote: > This is what I used Danny. I used the 1/4" edge. I built all my edges > up with fiberglass to put some strength back in the door frame area > and it made the > edge trim fit much better. It was a ton of work as Michael said but > good results. > > 11 1120A411 > <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=859151940559946&tab=find&FastTrack=False&WRCntxt=OrdHist> > 50 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" > Bulb Width > > > Geoff > ________________________________________________________________________________
Date: Jan 19, 2010
Subject: Re: Wing Plans Page 23-5 Step 3
just cut it in half, the dimensions of the whole thing are on the next page or so. you do not have to be very exact as yhere is plenty of play when you put it all together On Mon, Jan 18, 2010 at 11:44 PM, Kelly McMullen wrote: > > I have the correct tube identified, but don't see where it says to cut in > half or any other dimension. > > > John Kirkland wrote: > >> >> I'm at the same spot, cut it exactly in half. >> >> -------- >> RV-10 #40333 >> N540XP (reserved) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=282180#282180 >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 19, 2010
Don, Do you remember where you found those red rubber washers that you used to isolate the upper cable end from the bracket? Are they heat resistant or anything special? Thank you, Roger ----- Original Message ----- From: Don McDonald<mailto:building_partner(at)yahoo.com> To: rv10-list(at)matronics.com Sent: Monday, January 18, 2010 12:20 PM Subject: Re: RV10-List: Left exhaust hanger I am assuming you are using the stock Vetterman.... that being said, I tossed the original brackets aside, and built my own out of stainless. (I know several of you out there, just said, "of course he did").... It seemed to me that to be properly positioned the bracket needed to be bent, and the original bracket had lot's of mounting holes in it, which would have made it even weaker. The attached pics should help. Just zoom in on the first one to the actual bracket. I made a couple of extra if you're interested. 100+ hours and no problems whatsoever. Don McDonald --- On Mon, 1/18/10, Jae Chang wrote: From: Jae Chang <jc-matronics_rv10(at)jline.com> Subject: RV10-List: Left exhaust hanger To: rv10-list(at)matronics.com Date: Monday, January 18, 2010, 9:08 AM http://us.mc537.mail.yahoo.com/mc/compose?to =jc-matronics_rv10(at)jline.com>> http://picasaweb.google.com/lh/photo/A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1 sRgCI7088GZlYCc2AE&feat=directlink<http://picasaweb.google.com/lh/photo /A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink > I am looking to get some ideas of doing the left exhaust hangar mount. Does anyone have any photos of what they did? It seems a bit rube goldberg as there is a lot of interference points: the air cooler, the heat scat, tubes, etc. Any--> http://www.mat==================== <http://www.matronics.com/Navigator?RV10-List> ________________________________________________________________________________
Subject: Conduit abrasion
Date: Jan 19, 2010
This morning I shot a quick video describing some of my questions regarding abrasion protection of conduit. http://www.youtube.com/watch?v=saRUrF2vtMI In 1990, we used text and thought it was great. In 2000, it was the cherry on top if you could send digital photos. Now it's 2010 and video is where we are. On a side note, what's 2020? Phil ________________________________________________________________________________
Date: Jan 19, 2010
Hey Bill, I don't know if the pink canopy is any better in the edges, they are very inconsistent but then again I am using an aftermarket seal. I have been building the "gutter" up with thin strips of fiberglass until it is flat on the outside. When it got close I filled it flat with epoxy and milled glass. You have to use something like glass strips because it has to be structural, you end up trimming so much down on the other side. I was lost for a while and finally started seeing the light at the end of the tunnel when taking off the door a million times and touching up each spot that looked too close or filling anything with a gap too wide. I'm sure a lot of people are much faster at this. I know if I had to do another RV-10 I would do the same seal and it would go a lot faster knowing what I know now. ----- Original Message ----- From: "Bill Mauledriver Watson" <MauleDriver(at)nc.rr.com> Sent: Tuesday, January 19, 2010 3:32 AM Subject: Re: RV10-List: Re: doors & insulation > > > Interesting. Someone else had mentioned using 1120A311 which I purchased. > I have the older green top and find that most of the edges are 1/4" or > better. The only section that is consistently less than 1/4" is the > bottom sill. > > I'm guessing that the newer pink top is a bit thinner and more consistent > in edge thickness if you had to build them up. I've been trying to figure > out how to grind much of my edges down to 3/16" to fit the A311. > > So, I think I'm going to get 30' of the A411. Given the added thickness > of the headliner abric that will be underneath it, I think that will be > easier to work with. > > Thanks > Bill > > Geoff Combs wrote: >> This is what I used Danny. I used the 1/4" edge. I built all my edges up >> with fiberglass to put some strength back in the door frame area and it >> made the >> edge trim fit much better. It was a ton of work as Michael said but good >> results. >> 11 1120A411 >> <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=859151940559946&tab=find&FastTrack=False&WRCntxt=OrdHist> >> 50 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" Bulb >> Width >> >> Geoff >> > > > ________________________________________________________________________________
Subject: Re: Conduit abrasion
Date: Jan 19, 2010
Here are some pics of mine. I did a similar setup but used two on each side instead of three. I cut my holes close tolerance under the seats and wrapped caterpillar grommets around them. The exiting holes are so tight they can't move. I stuffed two lines in one hole wrapped again with the grommet. Maybe I will abrasion tape around the step where they contact the conduit like you stated. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282254#282254 Attachments: http://forums.matronics.com//files/dsc05540_151.jpg http://forums.matronics.com//files/dsc05541_923.jpg ________________________________________________________________________________
Date: Jan 19, 2010
All during my build I wandered through my brothers shop and confiscated eve rything that I thought that I might be able to use during my build.- Amon g those were several sections of rubber left over from military/govt projec ts from the past.- Then I just make the washers out of that.- I can sen d you some if you'd like.... got lots.... sent some to Pascal last week. Don McDonald --- On Tue, 1/19/10, Roger Standley wrote: From: Roger Standley <taildragon(at)msn.com> Subject: Re: RV10-List: Left exhaust hanger Date: Tuesday, January 19, 2010, 5:42 AM Don, - Do you remember where you found those red rubber washers that you used to i solate the upper cable end from the bracket? Are they heat resistant or any thing special? - Thank you, - Roger - ----- Original Message ----- From: Don McDonald Sent: Monday, January 18, 2010 12:20 PM Subject: Re: RV10-List: Left exhaust hanger I am assuming you are using the stock Vetterman....- that being said, I t ossed the original brackets aside, and built my own out of stainless.- (I know several of you out there, just said, "of course he did").... It seeme d to me that to be properly positioned the bracket needed to be bent, and t he original bracket had lot's of mounting holes in it, which would have mad e it even weaker.- The attached pics should help.- Just zoom in on the first one to the actual bracket.- I made a couple of extra if you're inte rested.- 100+ hours and no problems whatsoever.- Don McDonald --- On Mon, 1/18/10, Jae Chang wrote: From: Jae Chang <jc-matronics_rv10(at)jline.com> Subject: RV10-List: Left exhaust hanger Date: Monday, January 18, 2010, 9:08 AM http://picasaweb.google.com/lh/photo/A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1sR gCI7088GZlYCc2AE&feat=directlink I am looking to get some ideas of doing the left exhaust hangar mount. Does anyone have any photos of what they did? It seems a bit rube goldberg as t here is a lot of interference points: the air cooler, the heat scat, tubes, etc. Any--> http://www.mat================ ==== =0A=0A=0A ________________________________________________________________________________
Subject: 2020 was Conduit abrasion
Date: Jan 19, 2010
Phil, I cannot begin to tell you what we will be doing in 2020 but I know in 2011 we will start filming in 3D as 2010 CES was all about 3D TV's and CES 2011 is already slated for HEAVY 3D video cameras. I suspect in just a few years we will all have OLED tablets or "scrolls" as computers. If you have not seen OLED displays check this out: http://www.youtube.com/watch?v=nbTO5VM6s- Small OLED's started showing up in buttons where the small face of the button is a OLED display showing the status of the button "On" with green background, "off" with red background. Now the buttons have animations and small video loops and one can easily imagine a series of buttons on the panel that when you select for example a Landing Procedure all the appropriate buttons turn a specific color or display or give flashing visual warnings when they are not selected for that specific phase of flight and one button is dedicated to a check list etc... Another really cool item I saw at CES 2010 was a Microsoft Table Top called Surface Touch with full touch to control capabilities. Check it out: http://www.youtube.com/watch?v=kr1O917o4jI So for 2020 I expect the entire panel to be one large OLED multi touch display where I can reconfigure my panel any way I wish at home and then load the new configuration into the display by just resting my phone on the surface. When I choose the IFR procedure a large 3D IFR plate is geo referenced on the displayed along with any/all relevant information. Now if I could only get it to perform a perfect hot start. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Tuesday, January 19, 2010 8:37 AM Subject: RV10-List: Conduit abrasion This morning I shot a quick video describing some of my questions regarding abrasion protection of conduit. http://www.youtube.com/watch?v=saRUrF2vtMI In 1990, we used text and thought it was great. In 2000, it was the cherry on top if you could send digital photos. Now it's 2010 and video is where we are. On a side note, what's 2020? Phil Checked by AVG - www.avg.com 01/18/10 16:56:00 ________________________________________________________________________________
Subject: Re: 2020 was Conduit abrasion
Date: Jan 19, 2010
Robin, Your youtube link is invalid. Thanks. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282265#282265 ________________________________________________________________________________
Date: Jan 19, 2010
Thanks Robin. I think this new setup might work well. Just mocked up now and not final fitted yet. Robin used a clamp around the mount against the firewall, which i had not considered. It actually looks like the better spot for a clamp. There is much more clearance you can easily see in the pics. It is a tight fit for the clamp but you can see the wedge used to give a bit of room. before: http://picasaweb.google.com/lh/photo/A9mT9HXyj7yKkkz3NrP4kQ?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink after: http://picasaweb.google.com/lh/photo/-ictyfdhx9QfrQrIAIFkvQ?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink The right side is much easier. The left side is more crowded because the 2 4 6 cylinders push the exhaust further aft. However, too far aft, then the oil cooler starts interfering. The sweet spot is definitely smaller on the left side. Jae 40533 Robin Marks wrote: > Same as the right for us. > > Robin > > ________________________________________________________________________________
Date: Jan 19, 2010
http://www.youtube.com/watch?v=nbTO5VM6s-4 How about this... Thanks, Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Tuesday, January 19, 2010 9:55 AM Subject: RV10-List: Re: 2020 was Conduit abrasion Robin, Your youtube link is invalid. Thanks. Jim Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282265#282265 Checked by AVG - www.avg.com 01/19/10 07:34:00 ________________________________________________________________________________
Date: Jan 19, 2010
dangit I just ordered two of my G3X screens! -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282274#282274 ________________________________________________________________________________
Date: Jan 19, 2010
http://cbs5.com/technology/lpd.television.imaging.2.1427833.html Here's another one for large screens called LPD. They use lasers at about 10% of the power of lcd and plasma screens. ________________________________________________________________________________
Subject: Rack on door handle
Date: Jan 19, 2010
Anyone know if you end up using the middle piece of rack gear that the plans tell you to "trim and save". I would like to use it for something else. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282308#282308 ________________________________________________________________________________
Date: Jan 19, 2010
Hey Sean, I'm planning to add the tape to the conduit and not to the step... As tight as those steps are, I can only imagine how hard it will be to pull the step and tape through the mount. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Tuesday, January 19, 2010 11:21 AM Subject: RV10-List: Re: Conduit abrasion Here are some pics of mine. I did a similar setup but used two on each side instead of three. I cut my holes close tolerance under the seats and wrapped caterpillar grommets around them. The exiting holes are so tight they can't move. I stuffed two lines in one hole wrapped again with the grommet. Maybe I will abrasion tape around the step where they contact the conduit like you stated. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282254#282254 Attachments: http://forums.matronics.com//files/dsc05540_151.jpg http://forums.matronics.com//files/dsc05541_923.jpg ________________________________________________________________________________
Date: Jan 19, 2010
Good point. That would kind of take away the reason to make the plate to make the step removable. ----- Original Message ----- From: "Perry, Phil" <Phil.Perry(at)netapp.com> Sent: Tuesday, January 19, 2010 2:08 PM Subject: RE: RV10-List: Re: Conduit abrasion Hey Sean, I'm planning to add the tape to the conduit and not to the step... As tight as those steps are, I can only imagine how hard it will be to pull the step and tape through the mount. Phil -----Original Message----- From: Strasnuts [mailto:sean(at)braunandco.com] Sent: Tuesday, January 19, 2010 11:21 AM Subject: RV10-List: Re: Conduit abrasion Here are some pics of mine. I did a similar setup but used two on each side instead of three. I cut my holes close tolerance under the seats and wrapped caterpillar grommets around them. The exiting holes are so tight they can't move. I stuffed two lines in one hole wrapped again with the grommet. Maybe I will abrasion tape around the step where they contact the conduit like you stated. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282254#282254 Attachments: http://forums.matronics.com//files/dsc05540_151.jpg http://forums.matronics.com//files/dsc05541_923.jpg ________________________________________________________________________________
Subject: Re: Rack on door handle
Date: Jan 19, 2010
How soon do you need it? I have both of mine ( I think) since I used Hendricks locks. Ill mail them to you Rick Sked ------Original Message------ From: Strasnuts Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Sent: Jan 19, 2010 12:58 PM Subject: RV10-List: Rack on door handle Anyone know if you end up using the middle piece of rack gear that the plans tell you to "trim and save". I would like to use it for something else. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282308#282308 Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Jan 19, 2010
Just about finished with the construction and haven't come across a call out for their use. I would say no. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282326#282326 ________________________________________________________________________________
Date: Jan 19, 2010
Thanks Ron. ----- Original Message ----- From: "Ron B." <cfxoa(at)klis.com> Sent: Tuesday, January 19, 2010 4:05 PM Subject: RV10-List: Re: Rack on door handle > > Just about finished with the construction and haven't come across a call > out for their use. I would say no. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282326#282326 > > > ________________________________________________________________________________
Date: Jan 19, 2010
I have some vague memory of using it as a guide for some aspect of the door assembly, but its use isn't permanent. On Jan 19, 2010, at 12:58 PM, Strasnuts wrote: > > Anyone know if you end up using the middle piece of rack gear that > the plans tell you to "trim and save". I would like to use it for > something else. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282308#282308 > > ________________________________________________________________________________
Date: Jan 19, 2010
Page 45-13 , step 4. Operate the latch mechanism so as to cause the rack trimmings to extend Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282331#282331 ________________________________________________________________________________
Date: Jan 19, 2010
Yes the plans have you use the cutoff shorter pieces to mark the doors where to hog out fiberglass. It pretty much requires the shorter pieces to be able to install the mechanism and the plans have you install the mechanism to figure out how much material to remove from the door to be able to install the door handle with the full length pieces. If doing it again though I would seriously consider cutting them a bit longer to have more travel for the door pins like was mentioned in the last couple days. -Ben Westfall ________________________________________________________________________________
Date: Jan 19, 2010
I finally found it in the plans. I read right over it a couple of times. Sorry I should have taken more time before I asked. Rick, I still need the extra for my third pin. Thanks everyone. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282334#282334 ________________________________________________________________________________
Date: Jan 19, 2010
I think I would just order a few more and then make them as long as you need for the travel aspect of it. I am going with the 3rd party door handle and locks. Vans are way to crude of a design and not the quality I want. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Westfall Sent: Tuesday, January 19, 2010 3:50 PM Subject: RE: RV10-List: Rack on door handle Yes the plans have you use the cutoff shorter pieces to mark the doors where to hog out fiberglass. It pretty much requires the shorter pieces to be able to install the mechanism and the plans have you install the mechanism to figure out how much material to remove from the door to be able to install the door handle with the full length pieces. If doing it again though I would seriously consider cutting them a bit longer to have more travel for the door pins like was mentioned in the last couple days. -Ben Westfall ________________________________________________________________________________
Subject: From Van's on the door SB
Date: Jan 19, 2010
FYI. I was hoping for a better understanding on this issue....... Begin forwarded message: > From: "Gus Funnell" <gusf(at)vansaircraft.com> > Date: January 19, 2010 6:08:59 PM CST > To: rudi.greyling(at)accenture.com, rv10builder(at)verizon.net, ddddsp(at)juno.com > , gengrumpy(at)aol.com, dav1111(at)suddenlink.net, bob(at)thelefflers.com, robertbrunk(at)mac.com > , bob.condrey(at)baesystems.com, scottmschmidt(at)yahoo.com > Subject: Service Bulletin > > Thanks for your email regarding the recent RV-10 SB. > > The point of any SB is to benefit both RV builders/pilots AND Van's > Aircraft with increased safety and reduced costs. Most of the > complaints we get about SBs list only the builder's personal > concerns about difficulty/cost of compliance, or their belief that > there is a "better way". > > We always consider those issues, but we also have to balance them > with broader concerns; to maintain Van's Aircraft as a viable > company, and to protect it against future liability. There will > always be potential for some conflict between these two points of > view, which we hope that our customers will understand. > > As with all Service Bulletins in the certified and experimental > world, it is not mandatory that owner/operators comply with them. > It is up to the owner to comply or not, at their sole discretion. By > issuing this service bulletin, Van's is recommending that it be > complied with. > > Fly Safe, > > Vans ________________________________________________________________________________
Subject: Re: From Van's on the door SB
Date: Jan 19, 2010
We all got the same response. At least they responded, but I was with Scott, Vans response- As with all Service Bulletins in the certified and experimental world, it is not mandatory that owner/operators comply with them. It is up to the owner to comply or not, at their sole discretion. By issuing this service bulletin, Van's is recommending that it be complied with. Would have like to see the compliance as being "optional" since what Vans is giving us really is not the only solution, there are much better ways to do this, as many of us have already mentioned and their SB is not opening that option with their verbiage. Pasca; From: Miller John Sent: Tuesday, January 19, 2010 6:22 PM Subject: RV10-List: From Van's on the door SB FYI. I was hoping for a better understanding on this issue....... Begin forwarded message: From: "Gus Funnell" <gusf(at)vansaircraft.com> Date: January 19, 2010 6:08:59 PM CST To: rudi.greyling(at)accenture.com, rv10builder(at)verizon.net, ddddsp(at)juno.com, gengrumpy(at)aol.com, dav1111(at)suddenlink.net, bob(at)thelefflers.com, robertbrunk(at)mac.com, bob.condrey(at)baesystems.com, scottmschmidt(at)yahoo.com Subject: Service Bulletin Thanks for your email regarding the recent RV-10 SB. The point of any SB is to benefit both RV builders/pilots AND Van's Aircraft with increased safety and reduced costs. Most of the complaints we get about SBs list only the builder's personal concerns about difficulty/cost of compliance, or their belief that there is a "better way". We always consider those issues, but we also have to balance them with broader concerns; to maintain Van's Aircraft as a viable company, and to protect it against future liability. There will always be potential for some conflict between these two points of view, which we hope that our customers will understand. As with all Service Bulletins in the certified and experimental world, it is not mandatory that owner/operators comply with them. It is up to the owner to comply or not, at their sole discretion. By issuing this service bulletin, Van's is recommending that it be complied with. Fly Safe, Vans = ________________________________________________________________________________
Subject: Floating Skybolts
Date: Jan 19, 2010
I just realized the SkyBolts I ordered for the firewall are the floating type. I'm using hinges on the cowl split line. Would the floating type allow the cowling to move away from the firewall creating a bigger gap than what i've been crafting so carefully? Or should I just order the fixed receptacles? Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282374#282374 ________________________________________________________________________________
Date: Jan 19, 2010
Subject: Re: 1" Scotchbrite Wheels
Well, I can now tell you what you get: - I got my package today, after ordering on the 14th. Fast! - A big bag of scotch brite wheels. 49 of them, actually. (One short! Oh well.) - They are of the type GP-5AF. Compare this to Avery's CP-7A. (Nope, don't know how to decode these numbers.) - Avery's are gray, hard, and can take a corner off of a piece of aluminum no problem. These are reddish, slightly squishy, and barely seem to scuff aluminum when you rub it on it. If you run them for a while over a rough edge you might convince yourself that it polished the burr to make it sharper. In short? A great deal, if you need these wheels. I'm not sure what I'm going to do with them. :-) If anyone wants one (or 5) and would like to pick them up from me, you are more than welcome to take them. Chris On Thu, Jan 14, 2010 at 4:37 PM, Chris Colohan wrote: > Ooooh. Great price. But some bad reviews in a Google search for this > vendor. But they have been around for quite some time... > > I took a risk and ordered a package. I'll let you know if it turns out > poorly. > > Chris > > > On Thu, Jan 14, 2010 at 1:55 PM, wrote: > >> I found this on someone's website recently. Looks like a great deal. I'm >> not sure if it's the exact composition as the product from Avery, etc., but >> the price is incredible. >> >> >> >> http://www.surplussales.com/Tools-Accessories/T-Aabrasives.html >> >> >> >> Sean Blair >> >> COS >> >> * >> >> * >> >> > ________________________________________________________________________________
Subject: Re: Floating Skybolts
Date: Jan 19, 2010
Lenny, I did a large oil door similar to Dave Saylor's and used the floating Skybolt fasteners at the firewall. There is no discernible change in the firewall to cowling gap. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282376#282376 ________________________________________________________________________________
Date: Jan 19, 2010
So we now have it from the horses mouth. This is CYA ! Deems Davis N519PJ www.deemsrv10.com On 1/19/2010 7:22 PM, Miller John wrote: > FYI. I was hoping for a better understanding on this issue....... > > Begin forwarded message: > >> *From: *"Gus Funnell" <gusf(at)vansaircraft.com >> > >> *Date: *January 19, 2010 6:08:59 PM CST >> *To: *rudi.greyling(at)accenture.com >> , rv10builder(at)verizon.net >> , ddddsp(at)juno.com >> , gengrumpy(at)aol.com >> , dav1111(at)suddenlink.net >> , bob(at)thelefflers.com >> , robertbrunk(at)mac.com >> , bob.condrey(at)baesystems.com >> , scottmschmidt(at)yahoo.com >> >> *Subject: **Service Bulletin* >> >> Thanks for your email regarding the recent RV-10 SB. >> >> The point of any SB is to benefit both RV builders/pilots AND Van's >> Aircraft with increased safety and reduced costs. Most of the >> complaints we get about SBs list only the builder's personal concerns >> about difficulty/cost of compliance, or their belief that there is a >> "better way". >> >> We always consider those issues, but we also have to balance them >> with broader concerns; to maintain Van's Aircraft as a viable >> company, and to protect it against future liability. There will >> always be potential for some conflict between these two points of >> view, which we hope that our customers will understand. >> >> As with all Service Bulletins in the certified and experimental >> world, it is not mandatory that owner/operators comply with them. It >> is up to the owner to comply or not, at their sole discretion. By >> issuing this service bulletin, Van's is recommending that it be >> complied with. >> >> Fly Safe, >> >> Vans > > > * > > > * ________________________________________________________________________________
Date: Jan 20, 2010
So, did you use the same McMaster seals I'm getting ready to use? 1 1120A411 <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 30 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" Bulb Width And if so, can you help me understand what is 'flat on the outside'? I've heard various things about how the door gutter should be trimmed. Right now, I have them trimmed in a way that these seals work quite well: 2 93745K23 <http://www.mcmaster.com/itm/find.asp?searchstring=93745K23&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, Extra-soft, 1/8" Thk, 3/4"w, 50'l 3 93745K43 <http://www.mcmaster.com/itm/find.asp?searchstring=93745K43&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, Extra-soft, 1/4" Thk, 3/4"w, 50'l But this material simply sticks to the door and compresses very easily with a lot of memory. Same stuff I have on my Maule. Very easy to fit and would look OK if I was painting my door. But it won't work if covering the door with headliner material as I'm planning to do. So my door/gutter joint has a gap of between 1/8" (very narrow) and 3/8" around the edges. And the gutter edge/face itself varies from being almost parallel to the door at the top near the hinges to being perpendicular to the door at the bottom edge. Not very consistent. It looks like I will have to widen the gap along the top and in a few places along the side to accomodate the 3/8" bulb so it doesn't change the exterior fit of the door (which is quite nice now after much filling per Deem's technique). I will also have to thin the edge down in places where it's too fat to take the 1/4" edged grip. In doing all that, I'm guessing that there is some end state that I should be working towards that is not obvious to me yet. I'm wondering if you can help steer me towards that since you were once "lost" but now found, so to speak. Isn't it amazing how much you know AFTER you climb the learning curve and finish one of the thousand tasks on this project.... almost makes you want to start another. Thanks for the reply. Bill Seano wrote: > > Hey Bill, > > I don't know if the pink canopy is any better in the edges, they are > very inconsistent but then again I am using an aftermarket seal. I > have been building the "gutter" up with thin strips of fiberglass > until it is flat on the outside. When it got close I filled it flat > with epoxy and milled glass. You have to use something like glass > strips because it has to be structural, you end up trimming so much > down on the other side. I was lost for a while and finally started > seeing the light at the end of the tunnel when taking off the door a > million times and touching up each spot that looked too close or > filling anything with a gap too wide. I'm sure a lot of people are > much faster at this. I know if I had to do another RV-10 I would do > the same seal and it would go a lot faster knowing what I know now. > > > ----- Original Message ----- From: "Bill Mauledriver Watson" > > To: > Sent: Tuesday, January 19, 2010 3:32 AM > Subject: Re: RV10-List: Re: doors & insulation > > >> >> >> Interesting. Someone else had mentioned using 1120A311 which I >> purchased. I have the older green top and find that most of the edges >> are 1/4" or better. The only section that is consistently less than >> 1/4" is the bottom sill. >> >> I'm guessing that the newer pink top is a bit thinner and more >> consistent in edge thickness if you had to build them up. I've been >> trying to figure out how to grind much of my edges down to 3/16" to >> fit the A311. >> >> So, I think I'm going to get 30' of the A411. Given the added >> thickness of the headliner abric that will be underneath it, I think >> that will be easier to work with. >> >> Thanks >> Bill >> >> Geoff Combs wrote: >>> This is what I used Danny. I used the 1/4" edge. I built all my >>> edges up with fiberglass to put some strength back in the door frame >>> area and it made the >>> edge trim fit much better. It was a ton of work as Michael said but >>> good results. >>> 11 1120A411 >>> <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=859151940559946&tab=find&FastTrack=False&WRCntxt=OrdHist> >>> 50 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" >>> Bulb Width >>> >>> Geoff >>> ________________________________________________________________________________
Date: Jan 20, 2010
Bill, Call me 801-580-3737 ----- Original Message ----- From: "Bill Mauledriver Watson" <MauleDriver(at)nc.rr.com> Sent: Wednesday, January 20, 2010 6:44 AM Subject: Re: RV10-List: Re: doors & insulation > > > So, did you use the same McMaster seals I'm getting ready to use? > 1 1120A411 > <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> > 30 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" Bulb > Width > > And if so, can you help me understand what is 'flat on the outside'? > > I've heard various things about how the door gutter should be trimmed. > Right now, I have them trimmed in a way that these seals work quite well: > 2 93745K23 > <http://www.mcmaster.com/itm/find.asp?searchstring=93745K23&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> > 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, > Extra-soft, 1/8" Thk, 3/4"w, 50'l > 3 93745K43 > <http://www.mcmaster.com/itm/find.asp?searchstring=93745K43&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> > 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, > Extra-soft, 1/4" Thk, 3/4"w, 50'l > > But this material simply sticks to the door and compresses very easily > with a lot of memory. Same stuff I have on my Maule. Very easy to fit > and would look OK if I was painting my door. But it won't work if > covering the door with headliner material as I'm planning to do. > > So my door/gutter joint has a gap of between 1/8" (very narrow) and 3/8" > around the edges. And the gutter edge/face itself varies from being > almost parallel to the door at the top near the hinges to being > perpendicular to the door at the bottom edge. Not very consistent. > > It looks like I will have to widen the gap along the top and in a few > places along the side to accomodate the 3/8" bulb so it doesn't change the > exterior fit of the door (which is quite nice now after much filling per > Deem's technique). I will also have to thin the edge down in places where > it's too fat to take the 1/4" edged grip. > In doing all that, I'm guessing that there is some end state that I should > be working towards that is not obvious to me yet. I'm wondering if you > can help steer me towards that since you were once "lost" but now found, > so to speak. > > Isn't it amazing how much you know AFTER you climb the learning curve and > finish one of the thousand tasks on this project.... almost makes you want > to start another. > > Thanks for the reply. > > Bill > > > Seano wrote: >> >> Hey Bill, >> >> I don't know if the pink canopy is any better in the edges, they are very >> inconsistent but then again I am using an aftermarket seal. I have been >> building the "gutter" up with thin strips of fiberglass until it is flat >> on the outside. When it got close I filled it flat with epoxy and milled >> glass. You have to use something like glass strips because it has to be >> structural, you end up trimming so much down on the other side. I was >> lost for a while and finally started seeing the light at the end of the >> tunnel when taking off the door a million times and touching up each spot >> that looked too close or filling anything with a gap too wide. I'm sure >> a lot of people are much faster at this. I know if I had to do another >> RV-10 I would do the same seal and it would go a lot faster knowing what >> I know now. >> >> >> ----- Original Message ----- From: "Bill Mauledriver Watson" >> >> To: >> Sent: Tuesday, January 19, 2010 3:32 AM >> Subject: Re: RV10-List: Re: doors & insulation >> >> >>> >>> >>> Interesting. Someone else had mentioned using 1120A311 which I >>> purchased. I have the older green top and find that most of the edges >>> are 1/4" or better. The only section that is consistently less than >>> 1/4" is the bottom sill. >>> >>> I'm guessing that the newer pink top is a bit thinner and more >>> consistent in edge thickness if you had to build them up. I've been >>> trying to figure out how to grind much of my edges down to 3/16" to fit >>> the A311. >>> >>> So, I think I'm going to get 30' of the A411. Given the added thickness >>> of the headliner abric that will be underneath it, I think that will be >>> easier to work with. >>> >>> Thanks >>> Bill >>> >>> Geoff Combs wrote: >>>> This is what I used Danny. I used the 1/4" edge. I built all my edges >>>> up with fiberglass to put some strength back in the door frame area and >>>> it made the >>>> edge trim fit much better. It was a ton of work as Michael said but >>>> good results. >>>> 11 1120A411 >>>> <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=859151940559946&tab=find&FastTrack=False&WRCntxt=OrdHist> >>>> 50 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" >>>> Bulb Width >>>> >>>> Geoff >>>> > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 20, 2010
I used the edge grip stuff as most others have. This has the added nicety of trimming the gutter edge and making it look very finished. My process went something like this: - Fit the door - Adjust the door to gutter gap to about 3/8" all the way around using whatever method ( a surform, aka cheese grater, works well for this and the following work) - Build up the gutter edge on whichever side with flox to make it more perpendicular to the door - rough finish, check edge, attack with surform, repeat - once "close" I cut strips of the edging to check rough fit and filled in or removed material as necessary - once that was close I installed the seal all the way and checked fit and adjusted until the door could be closed AND locked without a great deal of force - Once that was complete I removed the seal and proceeded with the finish work of the gutters to make sure everything blended in nicely Wash, rinse, repeat for the other side. I also used the 100 MPH release tape method of creating covers for the door hinges which I then permanently attached by bedding in with flox and using nutplates to attach. Once Abby covered my doors they look very nice. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: Wednesday, January 20, 2010 8:45 AM Subject: Re: RV10-List: Re: doors & insulation So, did you use the same McMaster seals I'm getting ready to use? 1 1120A411 <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 30 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" Bulb Width And if so, can you help me understand what is 'flat on the outside'? I've heard various things about how the door gutter should be trimmed. Right now, I have them trimmed in a way that these seals work quite well: 2 93745K23 <http://www.mcmaster.com/itm/find.asp?searchstring=93745K23&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, Extra-soft, 1/8" Thk, 3/4"w, 50'l 3 93745K43 <http://www.mcmaster.com/itm/find.asp?searchstring=93745K43&sesnextrep=589606556598957&tab=find&FastTrack=False&WRCntxt=OrdHist> 1 Each Oil-and Water-resistant Vinyl/buna-n Foam, Adhesive-back, Extra-soft, 1/4" Thk, 3/4"w, 50'l But this material simply sticks to the door and compresses very easily with a lot of memory. Same stuff I have on my Maule. Very easy to fit and would look OK if I was painting my door. But it won't work if covering the door with headliner material as I'm planning to do. So my door/gutter joint has a gap of between 1/8" (very narrow) and 3/8" around the edges. And the gutter edge/face itself varies from being almost parallel to the door at the top near the hinges to being perpendicular to the door at the bottom edge. Not very consistent. It looks like I will have to widen the gap along the top and in a few places along the side to accomodate the 3/8" bulb so it doesn't change the exterior fit of the door (which is quite nice now after much filling per Deem's technique). I will also have to thin the edge down in places where it's too fat to take the 1/4" edged grip. In doing all that, I'm guessing that there is some end state that I should be working towards that is not obvious to me yet. I'm wondering if you can help steer me towards that since you were once "lost" but now found, so to speak. Isn't it amazing how much you know AFTER you climb the learning curve and finish one of the thousand tasks on this project.... almost makes you want to start another. Thanks for the reply. Bill Seano wrote: > > Hey Bill, > > I don't know if the pink canopy is any better in the edges, they are > very inconsistent but then again I am using an aftermarket seal. I > have been building the "gutter" up with thin strips of fiberglass > until it is flat on the outside. When it got close I filled it flat > with epoxy and milled glass. You have to use something like glass > strips because it has to be structural, you end up trimming so much > down on the other side. I was lost for a while and finally started > seeing the light at the end of the tunnel when taking off the door a > million times and touching up each spot that looked too close or > filling anything with a gap too wide. I'm sure a lot of people are > much faster at this. I know if I had to do another RV-10 I would do > the same seal and it would go a lot faster knowing what I know now. > > > ----- Original Message ----- From: "Bill Mauledriver Watson" > > To: > Sent: Tuesday, January 19, 2010 3:32 AM > Subject: Re: RV10-List: Re: doors & insulation > > >> >> >> Interesting. Someone else had mentioned using 1120A311 which I >> purchased. I have the older green top and find that most of the edges >> are 1/4" or better. The only section that is consistently less than >> 1/4" is the bottom sill. >> >> I'm guessing that the newer pink top is a bit thinner and more >> consistent in edge thickness if you had to build them up. I've been >> trying to figure out how to grind much of my edges down to 3/16" to >> fit the A311. >> >> So, I think I'm going to get 30' of the A411. Given the added >> thickness of the headliner abric that will be underneath it, I think >> that will be easier to work with. >> >> Thanks >> Bill >> >> Geoff Combs wrote: >>> This is what I used Danny. I used the 1/4" edge. I built all my >>> edges up with fiberglass to put some strength back in the door frame >>> area and it made the >>> edge trim fit much better. It was a ton of work as Michael said but >>> good results. >>> 11 1120A411 >>> <http://www.mcmaster.com/itm/find.asp?searchstring=1120A411&sesnextrep=859151940559946&tab=find&FastTrack=False&WRCntxt=OrdHist> >>> 50 Ft. Edge-grip Rubber Seal, Bulb Opposite Grabber, 1/4" Edge, 3/8" >>> Bulb Width >>> >>> Geoff >>> ________________________________________________________________________________
Date: Jan 20, 2010
My understanding is the floating is for giving a larger area to align the bolt initially, once you tighten it down it wont "float". Pascal -------------------------------------------------- From: "Lenny Iszak" <lenard(at)rapiddecision.com> Sent: Tuesday, January 19, 2010 7:16 PM Subject: RV10-List: Floating Skybolts > > I just realized the SkyBolts I ordered for the firewall are the floating > type. > I'm using hinges on the cowl split line. > > Would the floating type allow the cowling to move away from the firewall > creating a bigger gap than what i've been crafting so carefully? Or should > I just order the fixed receptacles? > > > Lenny > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282374#282374 > > > ________________________________________________________________________________
Date: Jan 20, 2010
I have them and they are great. No discernible separation. Makes a nice tight fit and the floaters give you an extra bit of wiggle space to fit the cowl. Happy to have them on the top of the cowl. Note: If you use their suggested spacing, the "kit" leaves you two fastenings short. I had to order two extra pieces and they screwed up the order. The kit is made for RV7/8/9's and the IO-540 has a bigger cowl. The Skybolt people are not the easiest to deal with. Contact me off line if desired. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282476#282476 ________________________________________________________________________________
Date: Jan 20, 2010
I would like to give my kiddos to Van's for coming out with this S/B. Unfortunately, we all live in a CYA world. They recognized the problem and the potential liability and acted. Would any of us rather that some non-builder user sued Van's and won a big (say $30 million) lawsuit, essentially putting them out of business (like what happened to Piper a few years back). I know because I lost about $5000 on my deposit with Piper. Until we get rid of the ambulance or hearse chasing lawyers in this country we are all screwed. We are still (at least for a while) lucky enough to live in a country where we are free to build and modify these amazing experimental planes as we see fit regardless of any S/B. Use the S/B - ignore it - modify it you are free to do as you see fit. Despite all complaints, I will bet that 90% of us will fit the Van's S/B (or some mutation of it) when we show up at OSH this Summer. As we all know Van's philosophy is to build a light - adequately built and well engineered aircraft that flies fast - turns easily - and is a delight to fly. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282481#282481 ________________________________________________________________________________
Date: Jan 20, 2010
I agree Mike. I am continually amazed at the amount of whining that goes on with this list. I think the quality of Van's kit is incredible. Don't like the door latching mechanism? Fine - you are free to change it. It's a HOMEBUILT. That means you, as the manufacturer, are free to do anything you like. I think Van's has done an excellent job with this kit, and has made the changes they felt necessary based on real world flight experience. Many feel the changes are un-necessary (particularly the SB on the empennage bulkhead to prevent the crack found on the prototype), or ugly, as is the case with this one. Every builder is free to evaluate these changes and make their own decisions for incorporation. Ever look at the quality of some of the other kits out there? OK - off the soapbox and preparing for the flames. Jack Phillips #40610 Raleigh, NC Slo-Build Wings - assembling the fuel tanks and eagerly awaiting adventures with Pro-Seal -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Wednesday, January 20, 2010 11:17 AM Subject: RV10-List: Re: From Van's on the door SB I would like to give my kiddos to Van's for coming out with this S/B. Unfortunately, we all live in a CYA world. They recognized the problem and the potential liability and acted. Would any of us rather that some non-builder user sued Van's and won a big (say $30 million) lawsuit, essentially putting them out of business (like what happened to Piper a few years back). I know because I lost about $5000 on my deposit with Piper. Until we get rid of the ambulance or hearse chasing lawyers in this country we are all screwed. We are still (at least for a while) lucky enough to live in a country where we are free to build and modify these amazing experimental planes as we see fit regardless of any S/B. Use the S/B - ignore it - modify it you are free to do as you see fit. Despite all complaints, I will bet that 90% of us will fit the Van's S/B (or some mutation of it) when we show up at OSH this Summer. As we all know Van's philosophy is to build a light - adequately built and well engineered aircraft that flies fast - turns easily - and is a delight to fly. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282481#282481 ________________________________________________________________________________
Date: Jan 20, 2010
Of course this is CYA. But it's nothing like the certified world. A year ago or so I got a letter from Airborn, saying that they had established a service life of 5 years for vacuum pumps. And since they hadn't made any for five years, all Airborn pumps were now unairworthy and had to be removed from service. Of course, this had no authority of law behind it (at least in the US part 91) but was just CYA. Poor guys in part 135, some other countries, however, were out of luck. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282506#282506 ________________________________________________________________________________
Date: Jan 20, 2010
Thanks guys, i'll go for it then. It looks as if they float only about 1/16 fwd/aft, and more sideways. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282520#282520 ________________________________________________________________________________
Date: Jan 20, 2010
Lenny, The floating ones are actually better than the fixed when you are using many of them in a cowl. Temperature changes make the cowl dimensions change slightly. With the floating socket you will have easier engagement and allow for minor changes due to climate. Once the fastener is engaged the pressure keeps them from moving. Rick Sked -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lenny Iszak Sent: Wednesday, January 20, 2010 10:55 AM Subject: RV10-List: Re: Floating Skybolts Thanks guys, i'll go for it then. It looks as if they float only about 1/16 fwd/aft, and more sideways. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282520#282520 ________________________________________________________________________________
Date: Jan 20, 2010
I agree, as I gather most agree, Vans make a wonderful kit, the issue is the solution Vans came up with for the door. I believe there could have been a better option than a hook that should have been considered, like improving the door, better system of locking, etc. I built my door so they close correctly, rear first, my 5 year old (at the time) beta tested it for me and it closes each and everytime without issue or the rear not closing. I am just building a plane, Vans knows planes significantly better than I so why not get their doors to close correctly to start with versus putting out a SB that I think avoids the issue to start with. So my whining is- improve the issue before band aiding it with a hook that brings yet another issue, rain getting into the doors being one. Vans is a good company I think they thought this through, but with Dick flying his own plane one would think he would have found a better solution. Pascal -------------------------------------------------- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Wednesday, January 20, 2010 9:52 AM Subject: RE: RV10-List: Re: From Van's on the door SB > > I agree Mike. I am continually amazed at the amount of whining that goes > on > with this list. I think the quality of Van's kit is incredible. Don't > like > the door latching mechanism? Fine - you are free to change it. It's a > HOMEBUILT. That means you, as the manufacturer, are free to do anything > you > like. > > I think Van's has done an excellent job with this kit, and has made the > changes they felt necessary based on real world flight experience. Many > feel the changes are un-necessary (particularly the SB on the empennage > bulkhead to prevent the crack found on the prototype), or ugly, as is the > case with this one. Every builder is free to evaluate these changes and > make their own decisions for incorporation. Ever look at the quality of > some of the other kits out there? > > OK - off the soapbox and preparing for the flames. > > Jack Phillips > #40610 > Raleigh, NC > Slo-Build Wings - assembling the fuel tanks and eagerly awaiting > adventures with Pro-Seal > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, January 20, 2010 11:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: From Van's on the door SB > > > I would like to give my kiddos to Van's for coming out with this S/B. > Unfortunately, we all live in a CYA world. They recognized the problem and > the potential liability and acted. Would any of us rather that some > non-builder user sued Van's and won a big (say $30 million) lawsuit, > essentially putting them out of business (like what happened to Piper a > few > years back). I know because I lost about $5000 on my deposit with Piper. > Until we get rid of the ambulance or hearse chasing lawyers in this > country > we are all screwed. > > We are still (at least for a while) lucky enough to live in a country > where > we are free to build and modify these amazing experimental planes as we > see > fit regardless of any S/B. Use the S/B - ignore it - modify it you are > free > to do as you see fit. Despite all complaints, I will bet that 90% of us > will > fit the Van's S/B (or some mutation of it) when we show up at OSH this > Summer. > > As we all know Van's philosophy is to build a light - adequately built and > well engineered aircraft that flies fast - turns easily - and is a delight > to fly. > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282481#282481 > > > ________________________________________________________________________________
Date: Jan 20, 2010
This builder is thinking the solution is already out there - the aftermarket blocks combined with the light system seems positive enough and sturdy enough to me. Nothing else need be done in my opinion. I'm guessing that Van may think so too when he has builder/flyer hat on. But there's a business involved... From a CYA perspective, I can see how the blocks and lights may not be enough for a factory supplied solution, even if they'd like to think so. All a litigant would have to do is pull the threads on door latching. So they've put out a very positive, perhaps crude, probably low cost but liability avoiding solution to CYA. And left it up the flexibility of the builder and the rules surrounding homebuilding to chose the right solutions. I'm comfortable and perhaps even impressed. Bill "can't wait for the SB but can't figure out where to store it" Watson Pascal wrote: > > I agree, as I gather most agree, Vans make a wonderful kit, the issue > is the solution Vans came up with for the door. I believe there could > have been a better option than a hook that should have been > considered, like improving the door, better system of locking, etc. > I built my door so they close correctly, rear first, my 5 year old (at > the time) beta tested it for me and it closes each and everytime > without issue or the rear not closing. I am just building a plane, > Vans knows planes significantly better than I so why not get their > doors to close correctly to start with versus putting out a SB that I > think avoids the issue to start with. > So my whining is- improve the issue before band aiding it with a hook > that brings yet another issue, rain getting into the doors being one. > Vans is a good company I think they thought this through, but with > Dick flying his own plane one would think he would have found a better > solution. > Pascal > > ________________________________________________________________________________
Date: Jan 20, 2010
Total agreement here too. It's easy to lose sight of the whole homebuilt concept when building one of these modern kits. Jack Phillips wrote: > > I agree Mike. I am continually amazed at the amount of whining that goes on > with this list. I think the quality of Van's kit is incredible. Don't like > the door latching mechanism? Fine - you are free to change it. It's a > HOMEBUILT. That means you, as the manufacturer, are free to do anything you > like. > > I think Van's has done an excellent job with this kit, and has made the > changes they felt necessary based on real world flight experience. Many > feel the changes are un-necessary (particularly the SB on the empennage > bulkhead to prevent the crack found on the prototype), or ugly, as is the > case with this one. Every builder is free to evaluate these changes and > make their own decisions for incorporation. Ever look at the quality of > some of the other kits out there? > > OK - off the soapbox and preparing for the flames. > > Jack Phillips > #40610 > Raleigh, NC > Slo-Build Wings - assembling the fuel tanks and eagerly awaiting > adventures with Pro-Seal > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, January 20, 2010 11:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: From Van's on the door SB > > > I would like to give my kiddos to Van's for coming out with this S/B. > Unfortunately, we all live in a CYA world. They recognized the problem and > the potential liability and acted. Would any of us rather that some > non-builder user sued Van's and won a big (say $30 million) lawsuit, > essentially putting them out of business (like what happened to Piper a few > years back). I know because I lost about $5000 on my deposit with Piper. > Until we get rid of the ambulance or hearse chasing lawyers in this country > we are all screwed. > > We are still (at least for a while) lucky enough to live in a country where > we are free to build and modify these amazing experimental planes as we see > fit regardless of any S/B. Use the S/B - ignore it - modify it you are free > to do as you see fit. Despite all complaints, I will bet that 90% of us will > fit the Van's S/B (or some mutation of it) when we show up at OSH this > Summer. > > As we all know Van's philosophy is to build a light - adequately built and > well engineered aircraft that flies fast - turns easily - and is a delight > to fly. > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > ________________________________________________________________________________
Date: Jan 20, 2010
I don't really mind the response Van's gave for the SB. I do wish they wouldn't have made it mandatory, but in todays world I think that every company does the CYA dance whenever they can. We should be glad it isn't an AD and that experimentals don't have to comply with AD's. We built these planes ourselves for a reason...so that we could have the freedom to experiment and modify. If Van's wants to cover their butt, so be it. When it comes to a structural fix, like the bulkhead patch, I don't think that we need to question it much...if there is a structural problem, we can just gladly obey and do the fix...because we can't really prove the design as-is is faulty. When it comes to this SB, we all know that doors flying off can be a problem...but it's our job to find a way around that happening to us. Good thing we're free to choose our methods. One plug for the internet age... I really think that the honest "I built it myself" builder, who participates in a list such as this, will be a far "safer" RV-10 pilot. Some of that comes from the care they take in building, some comes from the knowledge of how it's built, but, a LOT OF BENEFIT will come to those who built it themselves and through the learning process decided to take part in a list like this. On a list like this, you get to hear about the good and the bad....like doors flying off. I don't remember the count or know the current count, but I think, if I remember right, that I'm personally aware of about 5 or 6 door-off incidents. That's not a small number for this size fleet, and ESPECIALLY since Van's had it happen to THEM before, they probably understand that it's time to do something about it. So they provided parts, and guidance, to fix their little doormonster. Where it is sad, but not unexpected, is that after it happened to them and a few other people, if Van's had participated more in the online discussions, and taken things to heart, perhaps sooner into the kit sales cycle they could have improved the latch design, and maybe by kit 300 or something, they could have had a better door latch mechanism as standard production. But, we all know that once Van's has finished a kit and started selling all kit sections, they're DONE with it. They don't improve it unless they have a major issue. Not even for a major MINOR issue. Look at the axle extensions that we all used to know about. We heard about many people breaking axle extensions...high rates of failure. But that's minor to them, so they don't even re-issue those parts. They just simply do not go back and revise much unless they personally see many problems with it. I'm not ranting about it...it's just the way they are. They went on and focused on the RV-12 project. There ARE no major improvements coming for any section of the RV-10, I'd be willing to bet. It would be more likely that there would be an RV-13 in the makings (or maybe RV-14 to avoid losing sales to superstitious folk). Maybe the RV-14 will be a new design of a nice 4-seater...who knows. Maybe they'll learn some things from the -10 and it'll have new doors. But I just think it's unrealistic to expect major changes to their RV-10 design....even if it's something they could make much nicer like the door latching. Also, for their fix, they needed to come up with something that could be an easy bolt-in fix for already flying planes. They realize that fixing the entire latching mechanism isn't really very easy on a finished plane....so I'm sure they came up with what they did because it was something that anyone could add, pre or post construction. So, while I think the SB fix is ugly and not what I plan to do, I really can't hold them in poor regard for how they did it or what they did. They really should "cover their asses". It wouldn't make good business sense not to. It would be nice to not see the word "mandatory" there, but in the end, it need not worry us anyway. We can comply as we wish. Tim Miller John wrote: > FYI. I was hoping for a better understanding on this issue....... > > Begin forwarded message: > >> >> Thanks for your email regarding the recent RV-10 SB. >> >> The point of any SB is to benefit both RV builders/pilots AND Van's >> Aircraft with increased safety and reduced costs. Most of the >> complaints we get about SBs list only the builder's personal concerns >> about difficulty/cost of compliance, or their belief that there is a >> "better way". >> >> We always consider those issues, but we also have to balance them with >> broader concerns; to maintain Van's Aircraft as a viable company, and >> to protect it against future liability. There will always be potential >> for some conflict between these two points of view, which we hope that >> our customers will understand. >> >> As with all Service Bulletins in the certified and experimental world, >> it is not mandatory that owner/operators comply with them. It is up >> to the owner to comply or not, at their sole discretion. By issuing >> this service bulletin, Van's is recommending that it be complied with. >> >> Fly Safe, >> >> Vans > > > > * > > > * ________________________________________________________________________________
Date: Jan 20, 2010
The issue is Service Bulletins are not intended to be a redesign of the airplane. They're intended to provide a retrofit solution to a known problem in a current design. Anyone who thinks Vans is going to redesign the doors and write a SB against it will always be disappointed. I stand by Vans on this one. They have a right to recognize a problem and offer a fix for it. Think of the alternative. Phil -----Original Message----- From: Pascal [mailto:rv10builder(at)verizon.net] Sent: Wednesday, January 20, 2010 1:47 PM Subject: Re: RV10-List: Re: From Van's on the door SB I agree, as I gather most agree, Vans make a wonderful kit, the issue is the solution Vans came up with for the door. I believe there could have been a better option than a hook that should have been considered, like improving the door, better system of locking, etc. I built my door so they close correctly, rear first, my 5 year old (at the time) beta tested it for me and it closes each and everytime without issue or the rear not closing. I am just building a plane, Vans knows planes significantly better than I so why not get their doors to close correctly to start with versus putting out a SB that I think avoids the issue to start with. So my whining is- improve the issue before band aiding it with a hook that brings yet another issue, rain getting into the doors being one. Vans is a good company I think they thought this through, but with Dick flying his own plane one would think he would have found a better solution. Pascal -------------------------------------------------- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Wednesday, January 20, 2010 9:52 AM Subject: RE: RV10-List: Re: From Van's on the door SB > > I agree Mike. I am continually amazed at the amount of whining that goes > on > with this list. I think the quality of Van's kit is incredible. Don't > like > the door latching mechanism? Fine - you are free to change it. It's a > HOMEBUILT. That means you, as the manufacturer, are free to do anything > you > like. > > I think Van's has done an excellent job with this kit, and has made the > changes they felt necessary based on real world flight experience. Many > feel the changes are un-necessary (particularly the SB on the empennage > bulkhead to prevent the crack found on the prototype), or ugly, as is the > case with this one. Every builder is free to evaluate these changes and > make their own decisions for incorporation. Ever look at the quality of > some of the other kits out there? > > OK - off the soapbox and preparing for the flames. > > Jack Phillips > #40610 > Raleigh, NC > Slo-Build Wings - assembling the fuel tanks and eagerly awaiting > adventures with Pro-Seal > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, January 20, 2010 11:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: From Van's on the door SB > > > I would like to give my kiddos to Van's for coming out with this S/B. > Unfortunately, we all live in a CYA world. They recognized the problem and > the potential liability and acted. Would any of us rather that some > non-builder user sued Van's and won a big (say $30 million) lawsuit, > essentially putting them out of business (like what happened to Piper a > few > years back). I know because I lost about $5000 on my deposit with Piper. > Until we get rid of the ambulance or hearse chasing lawyers in this > country > we are all screwed. > > We are still (at least for a while) lucky enough to live in a country > where > we are free to build and modify these amazing experimental planes as we > see > fit regardless of any S/B. Use the S/B - ignore it - modify it you are > free > to do as you see fit. Despite all complaints, I will bet that 90% of us > will > fit the Van's S/B (or some mutation of it) when we show up at OSH this > Summer. > > As we all know Van's philosophy is to build a light - adequately built and > well engineered aircraft that flies fast - turns easily - and is a delight > to fly. > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282481#282481 > > > ________________________________________________________________________________
Date: Jan 20, 2010
Jack Phillips...you forgot to say something. Just build the plane better=2C never settle for=2C "Good Enough!" You and your family are going to be in the dam thing. Van's is doing what they need to do in this litigious=2C gr eed driven society. > From: pietflyr(at)bellsouth.net > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: From Van's on the door SB > Date: Wed=2C 20 Jan 2010 12:52:11 -0500 > > > I agree Mike. I am continually amazed at the amount of whining that goes on > with this list. I think the quality of Van's kit is incredible. Don't lik e > the door latching mechanism? Fine - you are free to change it. It's a > HOMEBUILT. That means you=2C as the manufacturer=2C are free to do anythi ng you > like. > > I think Van's has done an excellent job with this kit=2C and has made the > changes they felt necessary based on real world flight experience. Many > feel the changes are un-necessary (particularly the SB on the empennage > bulkhead to prevent the crack found on the prototype)=2C or ugly=2C as is the > case with this one. Every builder is free to evaluate these changes and > make their own decisions for incorporation. Ever look at the quality of > some of the other kits out there? > > OK - off the soapbox and preparing for the flames. > > Jack Phillips > #40610 > Raleigh=2C NC > Slo-Build Wings - assembling the fuel tanks and eagerly awaiting > adventures with Pro-Seal > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday=2C January 20=2C 2010 11:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: From Van's on the door SB > > > I would like to give my kiddos to Van's for coming out with this S/B. > Unfortunately=2C we all live in a CYA world. They recognized the problem and > the potential liability and acted. Would any of us rather that some > non-builder user sued Van's and won a big (say $30 million) lawsuit=2C > essentially putting them out of business (like what happened to Piper a f ew > years back). I know because I lost about $5000 on my deposit with Piper. > Until we get rid of the ambulance or hearse chasing lawyers in this count ry > we are all screwed. > > We are still (at least for a while) lucky enough to live in a country whe re > we are free to build and modify these amazing experimental planes as we s ee > fit regardless of any S/B. Use the S/B - ignore it - modify it you are fr ee > to do as you see fit. Despite all complaints=2C I will bet that 90% of us will > fit the Van's S/B (or some mutation of it) when we show up at OSH this > Summer. > > As we all know Van's philosophy is to build a light - adequately built an d > well engineered aircraft that flies fast - turns easily - and is a deligh t > to fly. > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282481#282481 > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jan 20, 2010
Agreed, John. I don't know what I'll do when I get to the latch installation. I'm still working on the fuel tanks and trying to figure out how to beef up the fuel tanks so when a passenger steps forward of the spar they don't cause leaks around the rivets. Here's a case where this list has given me a heads up on a potential problem, at a point where I might be able to do something about it. I'll probably run my potential solution past Van's, with the understanding that they will almost certainly not approve of it due to legal concerns. I'm considering adding a doubler sheet under the skin as they did in the wingwalk area. But I understand that they have a business to run and that whatever I do as the manufacturer is strictly up to me. Jack Phillips #40610 Raleigh, NC _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Wednesday, January 20, 2010 3:07 PM Subject: RE: RV10-List: Re: From Van's on the door SB Jack Phillips...you forgot to say something. Just build the plane better, never settle for, "Good Enough!" You and your family are going to be in the dam thing. Van's is doing what they need to do in this litigious, greed driven society. > From: pietflyr(at)bellsouth.net > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: From Van's on the door SB > Date: Wed, 20 Jan 2010 12:52:11 -0500 > > > I agree Mike. I am continually amazed at the amount of whining that goes on > with this list. I think the quality of Van's kit is incredible. Don't like > the door latching mechanism? Fine - you are free to change it. It's a > HOMEBUILT. That means you, as the manufacturer, are free to do anything you > like. > > I think Van's has done an excellent job with this kit, and has made the > changes they felt necessary based on real world flight experience. Many > feel the changes are un-necessary (particularly the SB on the empennage > bulkhead to prevent the crack found on the prototype), or ugly, as is the > case with this one. Every builder is free to evaluate these changes and > make their own decisions for incorporation. Ever look at the quality of > some of the other kits out there? > > OK - off the soapbox and preparing for the flames. > > Jack Phillips > #40610 > Raleigh, NC > Slo-Build Wings - assembling the fuel tanks and eagerly awaiting > adventures with Pro-Seal > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike > Sent: Wednesday, January 20, 2010 11:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: From Van's on the door SB > > > I would like to give my kiddos to Van's for coming out with this S/B. > Unfortunately, we all live in a CYA world. They recognized the problem and > the potential liability and acted. Would any of us rather that some > non-builder user sued Van's and won a big (say $30 million) lawsuit, > essentially putting them out of business (like what happened to Piper a few > years back). I know because I lost about $5000 on my deposit with Piper. > Until we get rid of the ambulance or hearse chasing lawyers in this country > we are all screwed. > > We are still (at least for a while) lucky enough to live in a country where > we are free to build and modify these amazing experimental planes as we see > fit regardless of any S/B. Use the S/B - ignore it - modify it you are free > to do as you see fit. Despite all complaints, I will bet that 90% of us will > fit the Van's S/B (or some mutation of it) when we show up at OSH this > Summer. > > As we all know Van's philosophy is to build a light - adequately built and > well engineered aircraft that flies fast - turns easily - and is a delight > to fly. > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282481#282481 > > > > > > > > > > &============= > > > ________________________________________________________________________________
Subject: Quick Build Wing Kit FOR SALE
Date: Jan 20, 2010
Complete quick build wing kit For Sale. Delivery options available. Inventory complete without stall warning system. Includes wing storage cart on casters. Paul Grimstad, Portland, Or. 503-849-2123 ________________________________________________________________________________
Date: Jan 20, 2010
I agree Jack, quit complaining and get out there and fly the plane! It is always easy to complain when you are not flying and you have time building and absorbing all the comments from a site like this. You can really work yourself up. At our company we preach "GO TO GEMBA", which means "go to the actual place" before you start complaining and coming up with solutions, go to where the problem is and use it, learn it and get to know everything you can about it. Then you can really identify the issues, the root cause and test proposed countermeasures and possible solutions. I have spent my last two weeks praying to the weather gods and I have not had the answer I am looking for. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________ From: Jack Phillips <pietflyr(at)bellsouth.net> Sent: Wed, January 20, 2010 10:52:11 AM Subject: RE: RV10-List: Re: From Van's on the door SB I agree Mike. I am continually amazed at the amount of whining that goes on with this list. I think the quality of Van's kit is incredible. Don't like the door latching mechanism? Fine - you are free to change it. It's a HOMEBUILT. That means you, as the manufacturer, are free to do anything you like. I think Van's has done an excellent job with this kit, and has made the changes they felt necessary based on real world flight experience. Many feel the changes are un-necessary (particularly the SB on the empennage bulkhead to prevent the crack found on the prototype), or ugly, as is the case with this one. Every builder is free to evaluate these changes and make their own decisions for incorporation. Ever look at the quality of some of the other kits out there? OK - off the soapbox and preparing for the flames. Jack Phillips #40610 Raleigh, NC Slo-Build Wings - assembling the fuel tanks and eagerly awaiting adventures with Pro-Seal -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Wednesday, January 20, 2010 11:17 AM Subject: RV10-List: Re: From Van's on the door SB I would like to give my kiddos to Van's for coming out with this S/B. Unfortunately, we all live in a CYA world. They recognized the problem and the potential liability and acted. Would any of us rather that some non-builder user sued Van's and won a big (say $30 million) lawsuit, essentially putting them out of business (like what happened to Piper a few years back). I know because I lost about $5000 on my deposit with Piper. Until we get rid of the ambulance or hearse chasing lawyers in this country we are all screwed. We are still (at least for a while) lucky enough to live in a country where we are free to build and modify these amazing experimental planes as we see fit regardless of any S/B. Use the S/B - ignore it - modify it you are free to do as you see fit. Despite all complaints, I will bet that 90% of us will fit the Van's S/B (or some mutation of it) when we show up at OSH this Summer. As we all know Van's philosophy is to build a light - adequately built and well engineered aircraft that flies fast - turns easily - and is a delight to fly. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282481#282481 ________________________________________________________________________________
Date: Jan 20, 2010
The problem is not the builder but the purchased (second owner) aircraft. We have one here that was purchased by a businessman who according to my sources has already lost the same door twice. No record on any FAA database have I found. In addition his aircraft was annualed and the shop left the nose wheel flopping side to side by 20 degrees. I talked to the second shop who was asked to fix the nose wheel and pointed them to the MATCO axle solution. The problem is not we builders who own and fly but the hired guns and other sellers that build an aircraft to Vans specifications and sell it. Since we either do not have deep pockets or are adequately liability proof, the litigant will try and sue Vans. For me, I already have an adequate solution to the door and will not implement the SB. Now for space to store another box. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: Wednesday, January 20, 2010 1:46 PM Subject: Re: RV10-List: Re: From Van's on the door SB --> This builder is thinking the solution is already out there - the aftermarket blocks combined with the light system seems positive enough and sturdy enough to me. Nothing else need be done in my opinion. I'm guessing that Van may think so too when he has builder/flyer hat on. But there's a business involved... From a CYA perspective, I can see how the blocks and lights may not be enough for a factory supplied solution, even if they'd like to think so. All a litigant would have to do is pull the threads on door latching. So they've put out a very positive, perhaps crude, probably low cost but liability avoiding solution to CYA. And left it up the flexibility of the builder and the rules surrounding homebuilding to chose the right solutions. I'm comfortable and perhaps even impressed. Bill "can't wait for the SB but can't figure out where to store it" Watson Pascal wrote: > > I agree, as I gather most agree, Vans make a wonderful kit, the issue > is the solution Vans came up with for the door. I believe there could > have been a better option than a hook that should have been > considered, like improving the door, better system of locking, etc. > I built my door so they close correctly, rear first, my 5 year old (at > the time) beta tested it for me and it closes each and everytime > without issue or the rear not closing. I am just building a plane, > Vans knows planes significantly better than I so why not get their > doors to close correctly to start with versus putting out a SB that I > think avoids the issue to start with. > So my whining is- improve the issue before band aiding it with a hook > that brings yet another issue, rain getting into the doors being one. > Vans is a good company I think they thought this through, but with > Dick flying his own plane one would think he would have found a better > solution. > Pascal > > ________________________________________________________________________________
Date: Jan 20, 2010
Subject: Re: From Van's on the door SB
Well that opens a whole other problem area. If you don't implement the S B, and the aircraft is sold to someone else who then looses the door, you a re also potentially liable. Call the aircraft Bob's Toy in the paperwork i f you want, the insurance company won't care when they are looking for a wa y to offset the costs. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of DLM Sent: Wednesday, January 20, 2010 5:21 PM Subject: RE: RV10-List: Re: From Van's on the door SB The problem is not the builder but the purchased (second owner) aircraft. W e have one here that was purchased by a businessman who according to my sou rces has already lost the same door twice. No record on any FAA database ha ve I found. In addition his aircraft was annualed and the shop left the nos e wheel flopping side to side by 20 degrees. I talked to the second shop wh o was asked to fix the nose wheel and pointed them to the MATCO axle soluti on. The problem is not we builders who own and fly but the hired guns and o ther sellers that build an aircraft to Vans specifications and sell it. Sin ce we either do not have deep pockets or are adequately liability proof, th e litigant will try and sue Vans. For me, I already have an adequate soluti on to the door and will not implement the SB. Now for space to store anothe r box. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Bill Mauledriver Watson Sent: Wednesday, January 20, 2010 1:46 PM Subject: Re: RV10-List: Re: From Van's on the door SB --> This builder is thinking the solution is already out there - the aftermarke t blocks combined with the light system seems positive enough and sturdy en ough to me. Nothing else need be done in my opinion. I'm guessing that Va n may think so too when he has builder/flyer hat on. But there's a business involved... From a CYA perspective, I can see how the blocks and lights may not be eno ugh for a factory supplied solution, even if they'd like to think so. All a litigant would have to do is pull the threads on door latching. So they' ve put out a very positive, perhaps crude, probably low cost but liability avoiding solution to CYA. And left it up the flexibility of the builder an d the rules surrounding homebuilding to chose the right solutions. I'm comfortable and perhaps even impressed. Bill "can't wait for the SB but can't figure out where to store it" Watson Pascal wrote: > > I agree, as I gather most agree, Vans make a wonderful kit, the issue > is the solution Vans came up with for the door. I believe there could > have been a better option than a hook that should have been > considered, like improving the door, better system of locking, etc. > I built my door so they close correctly, rear first, my 5 year old (at > the time) beta tested it for me and it closes each and everytime > without issue or the rear not closing. I am just building a plane, > Vans knows planes significantly better than I so why not get their > doors to close correctly to start with versus putting out a SB that I > think avoids the issue to start with. > So my whining is- improve the issue before band aiding it with a hook > that brings yet another issue, rain getting into the doors being one. > Vans is a good company I think they thought this through, but with > Dick flying his own plane one would think he would have found a better > solution. > Pascal > > more: http://www.matronics.com/Navigator?RV10-List content also available via the Web Forums! http://forums.matronics.com you for your generous support! --> http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 20, 2010
I'm not sure I understand or agree with the statement/s, about the original builder's liability increasing in the event of an accident after resale. If that's true, then any modification other than paint scheme carries the same potential. I'm not a lawyer, but I'm not aware of any successful lawsuit on an experimental builder following an accident, by either an insurance company or a plaintif. Maybe I'm just ignorant ( OK let the comments rain!). Deems Davis N519PJ www.deemsrv10.com On 1/20/2010 3:38 PM, RV Builder (Michael Sausen) wrote: > > Well that opens a whole other problem area. If you don't implement > the SB, and the aircraft is sold to someone else who then looses the > door, you are also potentially liable. Call the aircraft Bob's Toy in > the paperwork if you want, the insurance company won't care when they > are looking for a way to offset the costs. > > Michael > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *DLM > *Sent:* Wednesday, January 20, 2010 5:21 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Re: From Van's on the door SB > > The problem is not the builder but the purchased (second owner) > aircraft. We have one here that was purchased by a businessman who > according to my sources has already lost the same door twice. No > record on any FAA database have I found. In addition his aircraft was > annualed and the shop left the nose wheel flopping side to side by 20 > degrees. I talked to the second shop who was asked to fix the nose > wheel and pointed them to the MATCO axle solution. The problem is not > we builders who own and fly but the hired guns and other sellers that > build an aircraft to Vans specifications and sell it. Since we either > do not have deep pockets or are adequately liability proof, the > litigant will try and sue Vans. For me, I already have an adequate > solution to the door and will not implement the SB. Now for space to > store another box. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill > Mauledriver Watson > > Sent: Wednesday, January 20, 2010 1:46 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: From Van's on the door SB > > --> > > This builder is thinking the solution is already out there - the > aftermarket blocks combined with the light system seems positive > enough and sturdy enough to me. Nothing else need be done in my > opinion. I'm guessing that Van may think so too when he has > builder/flyer hat on. > > But there's a business involved... > > >From a CYA perspective, I can see how the blocks and lights may not be > enough for a factory supplied solution, even if they'd like to think > so. All a litigant would have to do is pull the threads on door > latching. So they've put out a very positive, perhaps crude, probably > low cost but liability avoiding solution to CYA. And left it up the > flexibility of the builder and the rules surrounding homebuilding to > chose the right solutions. > > I'm comfortable and perhaps even impressed. > > Bill "can't wait for the SB but can't figure out where to store it" > Watson > > Pascal wrote: > > > > I agree, as I gather most agree, Vans make a wonderful kit, the issue > > is the solution Vans came up with for the door. I believe there could > > have been a better option than a hook that should have been > > considered, like improving the door, better system of locking, etc. > > I built my door so they close correctly, rear first, my 5 year old (at > > the time) beta tested it for me and it closes each and everytime > > without issue or the rear not closing. I am just building a plane, > > Vans knows planes significantly better than I so why not get their > > doors to close correctly to start with versus putting out a SB that I > > think avoids the issue to start with. > > So my whining is- improve the issue before band aiding it with a hook > > that brings yet another issue, rain getting into the doors being one. > > Vans is a good company I think they thought this through, but with > > Dick flying his own plane one would think he would have found a better > > solution. > > Pascal > > > > > > > more: > > http://www.matronics.com/Navigator?RV10-List > > > content also available via the Web Forums! > http://forums.matronics.com > > > you for your generous support! > --> http://www.matronics.com/contribution > > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Date: Jan 20, 2010
Paul are you giving up on your -10? Jack Phillips #40610 Raleigh, NC _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Paul Grimstad Sent: Wednesday, January 20, 2010 4:35 PM Subject: RV10-List: Quick Build Wing Kit FOR SALE Complete quick build wing kit For Sale. Delivery options available. Inventory complete without stall warning system. Includes wing storage cart on casters. Paul Grimstad, Portland, Or. 503-849-2123 ________________________________________________________________________________
Date: Jan 20, 2010
If you want to improve on Van's seal method, add a coat of CS3204 A-2(PR 1422 A-2) over the original B-2 sealant, before you install the back baffle. It is a brushing compound intended to cover rivet heads and fill any gaps in the B-2. Then put a coat of CS3600 (PR1005L) sloshing compound over that. Every Mooney wet wing tank is sealed that way. A belt and suspenders approach. On Wed, Jan 20, 2010 at 2:09 PM, Jack Phillips wrote: > Agreed, John. I dont know what Ill do when I get to the latch > installation. Im still working on the fuel tanks and trying to figure out > how to beef up the fuel tanks so when a passenger steps forward of the spar > they dont cause leaks around the rivets. Heres a case where this list has > given me a heads up on a potential problem, at a point where I might be able > to do something about it. Ill probably run my potential solution past > Vans, with the understanding that they will almost certainly not approve of > it due to legal concerns. Im considering adding a doubler sheet under the > skin as they did in the wingwalk area. > > > But I understand that they have a business to run and that whatever I do as > the manufacturer is strictly up to me. > > > Jack Phillips > > #40610 > > Raleigh, NC > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez > Sent: Wednesday, January 20, 2010 3:07 PM > To: RV 10 group > Subject: RE: RV10-List: Re: From Van's on the door SB > > > Jack Phillips...you forgotto say something. Just build the plane better, > never settle for, "Good Enough!" You and your family are going to be in the > dam thing.Van's is doing what they need to do in this litigious, greed > driven society. > > >> From: pietflyr(at)bellsouth.net >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Re: From Van's on the door SB >> Date: Wed, 20 Jan 2010 12:52:11 -0500 >> >> >> I agree Mike. I am continually amazed at the amount of whining that goes >> on >> with this list. I think the quality of Van's kit is incredible. Don't like >> the door latching mechanism? Fine - you are free to change it. It's a >> HOMEBUILT. That means you, as the manufacturer, are free to do anything >> you >> like. >> >> I think Van's has done an excellent job with this kit, and has made the >> changes they felt necessary based on real world flight experience. Many >> feel the changes are un-necessary (particularly the SB on the empennage >> bulkhead to prevent the crack found on the prototype), or ugly, as is the >> case with this one. Every builder is free to evaluate these changes and >> make their own decisions for incorporation. Ever look at the quality of >> some of the other kits out there? >> >> OK - off the soapbox and preparing for the flames. >> >> Jack Phillips >> #40610 >> Raleigh, NC >> Slo-Build Wings - assembling the fuel tanks and eagerly awaiting >> adventures with Pro-Seal >> >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike >> Sent: Wednesday, January 20, 2010 11:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Re: From Van's on the door SB >> >> >> I would like to give my kiddos to Van's for coming out with this S/B. >> Unfortunately, we all live in a CYA world. They recognized the problem and >> the potential liability and acted. Would any of us rather that some >> non-builder user sued Van's and won a big (say $30 million) lawsuit, >> essentially putting them out of business (like what happened to Piper a >> few >> years back). I know because I lost about $5000 on my deposit with Piper. >> Until we get rid of the ambulance or hearse chasing lawyers in this >> country >> we are all screwed. >> >> We are still (at least for a while) lucky enough to live in a country >> where >> we are free to build and modify these amazing experimental planes as we >> see >> fit regardless of any S/B. Use the S/B - ignore it - modify it you are >> free >> to do as you see fit. Despite all complaints, I will bet that 90% of us >> will >> fit the Van's S/B (or some mutation of it) when we show up at OSH this >> Summer. >> >> As we all know Van's philosophy is to build a light - adequately built and >> well engineered aircraft that flies fast - turns easily - and is a delight >> to fly. >> >> -------- >> OSH '10 or Bust >> Q/B - testing phase 1 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=282481#282481 >> >> >> >> >> >> >> >> >> >> > &============= >> >> >> > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jan 20, 2010
Thanks, Kelly. Where can I find that CS3204 A-2? Jack Phillips #40610 Raleigh, NC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 20, 2010 7:23 PM Subject: Re: RV10-List: Re: From Van's on the door SB If you want to improve on Van's seal method, add a coat of CS3204 A-2(PR 1422 A-2) over the original B-2 sealant, before you install the back baffle. It is a brushing compound intended to cover rivet heads and fill any gaps in the B-2. Then put a coat of CS3600 (PR1005L) sloshing compound over that. Every Mooney wet wing tank is sealed that way. A belt and suspenders approach. On Wed, Jan 20, 2010 at 2:09 PM, Jack Phillips wrote: > Agreed, John. I dont know what Ill do when I get to the latch > installation. Im still working on the fuel tanks and trying to figure out > how to beef up the fuel tanks so when a passenger steps forward of the spar > they dont cause leaks around the rivets. Heres a case where this list has > given me a heads up on a potential problem, at a point where I might be able > to do something about it. Ill probably run my potential solution past > Vans, with the understanding that they will almost certainly not approve of > it due to legal concerns. Im considering adding a doubler sheet under the > skin as they did in the wingwalk area. > > > But I understand that they have a business to run and that whatever I do as > the manufacturer is strictly up to me. > > > Jack Phillips > > #40610 > > Raleigh, NC > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez > Sent: Wednesday, January 20, 2010 3:07 PM > To: RV 10 group > Subject: RE: RV10-List: Re: From Van's on the door SB > > > Jack Phillips...you forgotto say something. Just build the plane better, > never settle for, "Good Enough!" You and your family are going to be in the > dam thing.Van's is doing what they need to do in this litigious, greed > driven society. > > >> From: pietflyr(at)bellsouth.net >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Re: From Van's on the door SB >> Date: Wed, 20 Jan 2010 12:52:11 -0500 >> >> >> I agree Mike. I am continually amazed at the amount of whining that goes >> on >> with this list. I think the quality of Van's kit is incredible. Don't like >> the door latching mechanism? Fine - you are free to change it. It's a >> HOMEBUILT. That means you, as the manufacturer, are free to do anything >> you >> like. >> >> I think Van's has done an excellent job with this kit, and has made the >> changes they felt necessary based on real world flight experience. Many >> feel the changes are un-necessary (particularly the SB on the empennage >> bulkhead to prevent the crack found on the prototype), or ugly, as is the >> case with this one. Every builder is free to evaluate these changes and >> make their own decisions for incorporation. Ever look at the quality of >> some of the other kits out there? >> >> OK - off the soapbox and preparing for the flames. >> >> Jack Phillips >> #40610 >> Raleigh, NC >> Slo-Build Wings - assembling the fuel tanks and eagerly awaiting >> adventures with Pro-Seal >> >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike >> Sent: Wednesday, January 20, 2010 11:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Re: From Van's on the door SB >> >> >> I would like to give my kiddos to Van's for coming out with this S/B. >> Unfortunately, we all live in a CYA world. They recognized the problem and >> the potential liability and acted. Would any of us rather that some >> non-builder user sued Van's and won a big (say $30 million) lawsuit, >> essentially putting them out of business (like what happened to Piper a >> few >> years back). I know because I lost about $5000 on my deposit with Piper. >> Until we get rid of the ambulance or hearse chasing lawyers in this >> country >> we are all screwed. >> >> We are still (at least for a while) lucky enough to live in a country >> where >> we are free to build and modify these amazing experimental planes as we >> see >> fit regardless of any S/B. Use the S/B - ignore it - modify it you are >> free >> to do as you see fit. Despite all complaints, I will bet that 90% of us >> will >> fit the Van's S/B (or some mutation of it) when we show up at OSH this >> Summer. >> >> As we all know Van's philosophy is to build a light - adequately built and >> well engineered aircraft that flies fast - turns easily - and is a delight >> to fly. >> >> -------- >> OSH '10 or Bust >> Q/B - testing phase 1 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=282481#282481 >> >> >> >> >> >> >> >> >> >> > &============= >> >> >> > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jan 20, 2010
Sealpak is one vendor. I don't recall if Sacramento Sky Ranch or Spruce had it. Be prepared for hazmat fee, as it contains enough Toluene to have flash point around 90. On Wed, Jan 20, 2010 at 6:55 PM, Jack Phillips wrote: > > Thanks, Kelly. Where can I find that CS3204 A-2? > > Jack Phillips > #40610 > Raleigh, NC > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Wednesday, January 20, 2010 7:23 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: From Van's on the door SB > > > If you want to improve on Van's seal method, add a coat of CS3204 > A-2(PR 1422 A-2) over the original B-2 sealant, before you install the > back baffle. It is a brushing compound intended to cover rivet heads > and fill any gaps in the B-2. Then put a coat of CS3600 (PR1005L) > sloshing compound over that. Every Mooney wet wing tank is sealed that > way. A belt and suspenders approach. > > On Wed, Jan 20, 2010 at 2:09 PM, Jack Phillips > wrote: >> Agreed, John. I dont know what Ill do when I get to the latch >> installation. Im still working on the fuel tanks and trying to figure > out >> how to beef up the fuel tanks so when a passenger steps forward of the > spar >> they dont cause leaks around the rivets. Heres a case where this list > has >> given me a heads up on a potential problem, at a point where I might be > able >> to do something about it. Ill probably run my potential solution past >> Vans, with the understanding that they will almost certainly not approve > of >> it due to legal concerns. Im considering adding a doubler sheet under > the >> skin as they did in the wingwalk area. >> >> >> >> But I understand that they have a business to run and that whatever I do > as >> the manufacturer is strictly up to me. >> >> >> >> Jack Phillips >> >> #40610 >> >> Raleigh, NC >> >> >> >> ________________________________ >> >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez >> Sent: Wednesday, January 20, 2010 3:07 PM >> To: RV 10 group >> Subject: RE: RV10-List: Re: From Van's on the door SB >> >> >> >> Jack Phillips...you forgotto say something. Just build the plane better, >> never settle for, "Good Enough!" You and your family are going to be in > the >> dam thing.Van's is doing what they need to do in this litigious, greed >> driven society. >> >> >> >>> From: pietflyr(at)bellsouth.net >>> To: rv10-list(at)matronics.com >>> Subject: RE: RV10-List: Re: From Van's on the door SB >>> Date: Wed, 20 Jan 2010 12:52:11 -0500 >>> >>> >>> I agree Mike. I am continually amazed at the amount of whining that goes >>> on >>> with this list. I think the quality of Van's kit is incredible. Don't > like >>> the door latching mechanism? Fine - you are free to change it. It's a >>> HOMEBUILT. That means you, as the manufacturer, are free to do anything >>> you >>> like. >>> >>> I think Van's has done an excellent job with this kit, and has made the >>> changes they felt necessary based on real world flight experience. Many >>> feel the changes are un-necessary (particularly the SB on the empennage >>> bulkhead to prevent the crack found on the prototype), or ugly, as is the >>> case with this one. Every builder is free to evaluate these changes and >>> make their own decisions for incorporation. Ever look at the quality of >>> some of the other kits out there? >>> >>> OK - off the soapbox and preparing for the flames. >>> >>> Jack Phillips >>> #40610 >>> Raleigh, NC >>> Slo-Build Wings - assembling the fuel tanks and eagerly awaiting >>> adventures with Pro-Seal >>> >>> >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike >>> Sent: Wednesday, January 20, 2010 11:17 AM >>> To: rv10-list(at)matronics.com >>> Subject: RV10-List: Re: From Van's on the door SB >>> >>> >>> I would like to give my kiddos to Van's for coming out with this S/B. >>> Unfortunately, we all live in a CYA world. They recognized the problem > and >>> the potential liability and acted. Would any of us rather that some >>> non-builder user sued Van's and won a big (say $30 million) lawsuit, >>> essentially putting them out of business (like what happened to Piper a >>> few >>> years back). I know because I lost about $5000 on my deposit with Piper. >>> Until we get rid of the ambulance or hearse chasing lawyers in this >>> country >>> we are all screwed. >>> >>> We are still (at least for a while) lucky enough to live in a country >>> where >>> we are free to build and modify these amazing experimental planes as we >>> see >>> fit regardless of any S/B. Use the S/B - ignore it - modify it you are >>> free >>> to do as you see fit. Despite all complaints, I will bet that 90% of us >>> will >>> fit the Van's S/B (or some mutation of it) when we show up at OSH this >>> Summer. >>> >>> As we all know Van's philosophy is to build a light - adequately built > and >>> well engineered aircraft that flies fast - turns easily - and is a > delight >>> to fly. >>> >>> -------- >>> OSH '10 or Bust >>> Q/B - testing phase 1 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=282481#282481 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> &============= >>> >>> >>> >> >> >> >> >> >> http://www.matronics.com/Navigator?RV10-List >> >> http://forums.matronics.com >> >> http://www.matronics.com/contribution >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 20, 2010
I'd suggest that if you sell your aircraft, hand the new owner the parts and the SB for the door. Now it's his choice. Lawyers may still come after you, but at least you have a plausible defense. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282631#282631 ________________________________________________________________________________
Date: Jan 21, 2010
Subject: Wing Wiring and Conduit
Hi all, I am working on my wing ribs, and realize I have to start thinking about what all will need wiring in the wing. Without knowing exactly what will be out there, I want to leave as much room for wiring as reasonable and was wondering what other people have done at this point. I see the conduit that Vans sells, and it mentions that it has been used for wing wiring. Has anyone done this? Is this the blue ribbed conduit shown in the recent conduit abrasion thread? The plans call for enlarging the wiring hole to 5/8" (0.625") for the grommet, but the conduit is 0.810" according to Van's. Is this too much of an enlargement of the hole? The plans say that enlarging to 5/8" will create a notch in the angle on the inboard rib, I don't want that any larger than necessary. Also, if installing AOA, do the lines get run through the wiring run? I would like to finalize at least the pitot line. Looks like the bottom skins shouldn't be put on until all of these details are worked out. Thanks . . . Kent Ogden #40710 Wings ________________________________________________________________________________
Subject: Door Departure in flight pics
Date: Jan 21, 2010
Does anyone have the pics of the RV-10 that had some previous damage from a hard landing and then later a door departure in flight with damage to the horizontal stabilizer? I thought I had saved those pics but can't find them now. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jan 21, 2010
Subject: Re: Wing Wiring and Conduit
I installed vans conduit, enlarged the holes to 3/4" and pulled it through the ribs. I have 5 wire pull stings running through it now so I na pull the wires when needed. On Thu, Jan 21, 2010 at 11:05 AM, Kent Ogden wrote: > Hi all, > > I am working on my wing ribs, and realize I have to start thinking about > what all will need wiring in the wing. Without knowing exactly what will be > out there, I want to leave as much room for wiring as reasonable and was > wondering what other people have done at this point. I see the conduit that > Vans sells, and it mentions that it has been used for wing wiring. Has > anyone done this? Is this the blue ribbed conduit shown in the recent > conduit abrasion thread? The plans call for enlarging the wiring hole to > 5/8" (0.625") for the grommet, but the conduit is 0.810" according to > Van's. Is this too much of an enlargement of the hole? The plans say that > enlarging to 5/8" will create a notch in the angle on the inboard rib, I > don't want that any larger than necessary. > > Also, if installing AOA, do the lines get run through the wiring run? I > would like to finalize at least the pitot line. Looks like the bottom skins > shouldn't be put on until all of these details are worked out. > > Thanks . . . > > Kent Ogden > #40710 Wings > > ________________________________________________________________________________
Date: Jan 21, 2010
The Vans conduit will fit nicely in a 3/4" hole, which, as I recall, is the hole size Vans does not want you to exceed. Jeff Carpenter 40304 On Jan 21, 2010, at 8:05 AM, Kent Ogden wrote: > Hi all, > > I am working on my wing ribs, and realize I have to start thinking > about what all will need wiring in the wing. Without knowing > exactly what will be out there, I want to leave as much room for > wiring as reasonable and was wondering what other people have done > at this point. I see the conduit that Vans sells, and it mentions > that it has been used for wing wiring. Has anyone done this? Is > this the blue ribbed conduit shown in the recent conduit abrasion > thread? The plans call for enlarging the wiring hole to > 5/8" (0.625") for the grommet, but the conduit is 0.810" according > to Van's. Is this too much of an enlargement of the hole? The > plans say that enlarging to 5/8" will create a notch in the angle on > the inboard rib, I don't want that any larger than necessary. > > Also, if installing AOA, do the lines get run through the wiring > run? I would like to finalize at least the pitot line. Looks like > the bottom skins shouldn't be put on until all of these details are > worked out. > > Thanks . . . > > Kent Ogden > #40710 Wings > > ________________________________________________________________________________
Date: Jan 21, 2010
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Kent Ogden wrote: Kent; Few things to think about; AOA. I ran my plastic tubing lines thru the same conduit. Plastic one worked well. As mentioned, Make sure you have an extra pull string. Other things to think about: Wingtip lighting (position /strobe/led/whelen) Will your pitot tube have a heating element for ice? Will need power and indicator lights. VOR /marker beacon antennae? Some people put theirs in the wingtip. Temp probe? I put mine in an accessible area inboard of the innermost inspection plate. Do you want a landing light (like duckworks) or go with the wing tip landing lights? Start getting a spread sheet of what you want in the wings before you rivet up the lower skin. Dr Fred 515FW ________________________________________________________________________________
Subject: For fixer-uppers
Date: Jan 21, 2010
http://www.avweb.com/avwebflash/news/MiracleA320WreckageToBeAuctionedOff_201873-1.html#gallery -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282786#282786 ________________________________________________________________________________
Subject: door SB
Date: Jan 21, 2010
Just got the kit today and will not install. I lengthened the pins and may put the aluminum blocks to replace the nylon guides.I feel the pins twice before each departure. Once after doors are shut at the hangar and once before takeoff. I always shut both doors. ________________________________________________________________________________
Date: Jan 21, 2010
Subject: Re: door SB
Maybe it would send a message if those of us that don't have the finish kit tell them to delete the SB parts from our order and credit us. On Thu, Jan 21, 2010 at 3:36 PM, DLM wrote: > Just got the kit today and will not install. I lengthened the pins and may > put the aluminum blocks to replace the nylon guides.I feel the pins twice > before each departure. Once after doors are shut at the hangar and once > before takeoff. I always shut both doors. > > ________________________________________________________________________________
Subject: Garmin G3X EIS & Auto Pilot
Date: Jan 22, 2010
As a heads up on the 20th Garmin announced the EIS component of the G3X including sensors would be available in February. They further announced an integrated Autopilot interface when mated to the TruTrak GX (not on TruTrak's website that I can find). As Garmin says: TruTrak GX Pilot autopilot has been designed to integrate seamlessly with the G3X, will enjoy advanced autopilot features that can be operated right from the PFD. Using controls and status indications derived from Garmin's certified GFC 700, the G3X autopilot interface implements sophisticated flight control modes including altitude preselect and capture, heading hold, GPS navigation with turn anticipation, and coupled VNAV descents. When used in conjunction with a GNS 430W or 530W, the G3X can also fly coupled holding patterns, procedure turns, and WAAS approaches. Cool! More basic info: The basic G3X system is available at a starting street price of $9,995 and includes a GDU 370 glass display, GSU 73 ADAHRS and engine interface unit, GMU 44 magnetometer and GTP 59 air temperature probe. The G3X engine sensor kits for Lycoming, Continental, Rotax and Jabiru engines are sold separately. A software update that adds EIS and autopilot features is expected to be available for free from www.garmin.com in February 2010. Someone on the list was concerned that Garmin may not offer their ADS-b package for the G3X. Garmin stated in their press release Wednesday: "Regardless of the type of aircraft a customer operates, they should never have to sacrifice features or services that enhance situational awareness, improve safety of flight" Ok, marketing 101 but as I always thought why would they turn down $9,000 by not making the new ADS-b available on the G3X? Robin BTW, I guess I feel compelled to say I have no ties to Garmin other than my G900x, 396, Nuvi 200 & 205, Golf GPS and a Garmin T-Shirt I occasionally use when changing my Aeroshell. ________________________________________________________________________________
Date: Jan 22, 2010
Kent, I used Vans conduit through 3/4" holes like the others have mentioned. For the AoA, I enlarged the tooling hole near the pitot line hole for the second plastic tube. John -------- #40572 QB. Engine on, wing attach coming soon. Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282861#282861 ________________________________________________________________________________
Subject: Re: Garmin G3X EIS & Auto Pilot
Date: Jan 22, 2010
Thanks Robin, I've been too busy on the doors to keep up with the latest. I feel pretty good about my recent purchase. Sent from my iPhone On Jan 22, 2010, at 2:14, "Robin Marks" wrote: > As a heads up on the 20th Garmin announced the EIS component of the > G3X including sensors would be available in February. They further > announced an integrated Autopilot interface when mated to the > TruTrak GX (not on TruTrak=99s website that I can find). As Garmin say > s: > > > TruTrak GX Pilot autopilot has been designed to integrate seamlessly > with the G3X, will enjoy advanced autopilot features that can be > operated right from the PFD. Using controls and status indications > derived from Garmin=99s certified GFC 700, the G3X autopilot interface > implements sophisticated flight control modes including altitude pr > eselect and capture, heading hold, GPS navigation with turn anticipa > tion, and coupled VNAV descents. When used in conjunction with a GNS > 430W or 530W, the G3X can also fly coupled holding patterns, proced > ure turns, and WAAS approaches. > > > Cool! > > > More basic info: > > The basic G3X system is available at a starting street price of > $9,995 and includes a GDU 370 glass display, GSU 73 ADAHRS and > engine interface unit, GMU 44 magnetometer and GTP 59 air > temperature probe. The G3X engine sensor kits for Lycoming, > Continental, Rotax and Jabiru engines are sold separately. A > software update that adds EIS and autopilot features is expected to > be available for free from www.garmin.com in February 2010. > > > Someone on the list was concerned that Garmin may not offer their > ADS-b package for the G3X. Garmin stated in their press release > Wednesday: > > > =9CRegardless of the type of aircraft a customer operates, they should > never have to sacrifice features or services that enhance situation > al awareness, improve safety of flight=9D > > > Ok, marketing 101 but as I always thought why would they turn down > $9,000 by not making the new ADS-b available on the G3X? > > > Robin > > > BTW, I guess I feel compelled to say I have no ties to Garmin other > than my G900x, 396, Nuvi 200 & 205, Golf GPS and a Garmin T-Shirt I > occasionally use when changing my Aeroshell. > > ________________________________________________________________________________
Subject: Windscreen install before panel?
Date: Jan 22, 2010
Thoughts on whether or not to install the windscreen before panel? I can't think of any particular reason why not other than the cabin will get warmer due to reduced circulation while crawling around. Cheers, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282907#282907 ________________________________________________________________________________
Subject: Re: Windscreen install before panel?
Date: Jan 22, 2010
Jay, I installed my windscreen before the panel, and would do it that way again. I would suggest installing any defrost fans you may want before doing the windscreen. I also painted the lower 2-3" of the inside of the windscreen to hide the fiberglass fairing you will create on the outside. That area is very difficult to work in once the windscreen is in place. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282919#282919 ________________________________________________________________________________
Date: Jan 22, 2010
I did all my panel, subpanel, and wiring work with the top forward fuselage on a work bench. Made it much easier than crawling around the fuselage. http://kochman.net/N819K/wp-content/uploads/2009/10/img_0624.jpg That's what I'd recommend, if you haven't riveted that part on yet. If you have, it probably doesn't matter whether the windscreen is done before or after. -Rob On Fri, Jan 22, 2010 at 9:53 AM, jayb wrote: > > Thoughts on whether or not to install the windscreen before panel? I can't > think of any particular reason why not other than the cabin will get warmer > due to reduced circulation while crawling around. > > Cheers, > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282907#282907 > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Jan 22, 2010
if you mean the actual front of the panel, installing the components. no problem if you mean setting up the wiring and layout I would get all that backend stuff done first, get all the wires positioned than close out the upper fusellage and install the windscreen. This will help with where to position your fans in relation to the avionics but more importantly it will allow you to get easy access to move/route wires around if they don't fit in a certain place. Pascal -------------------------------------------------- From: "jayb" <jaybrinkmeyer(at)yahoo.com> Sent: Friday, January 22, 2010 9:53 AM Subject: RV10-List: Windscreen install before panel? > > Thoughts on whether or not to install the windscreen before panel? I can't > think of any particular reason why not other than the cabin will get > warmer due to reduced circulation while crawling around. > > Cheers, > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282907#282907 > > > ________________________________________________________________________________
Date: Jan 22, 2010
To clarify... The forward fuse is riveted on and the engine is hung. The fans are in place. Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=282950#282950 ________________________________________________________________________________
Date: Jan 22, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I did most of my panel work with the forward fuselage section upside down on the bench. I would wait as long as possible before riveting that whole section in place. The engine can go on, landing gear, the top fitted - you just can't final attach the top. Then I riveted it in place and continued to finish the panel. I attached the top, fitted the doors, glued the windows... everything short of the windsheild. I'm still tinkering around inside and trying to hold off on the windsheild until the last possible moment. I find everything easier to do with the windsheild off. It's been cut and fitted but it is in storage until I have to put it on. Bill jayb wrote: > > Thoughts on whether or not to install the windscreen before panel? I can't think of any particular reason why not other than the cabin will get warmer due to reduced circulation while crawling around. > > Cheers, > Jay > > ________________________________________________________________________________
Date: Jan 22, 2010
makes no difference than, however do not install the avionics until after the windscreen.. between fitting the plexi and resin you don't want to worry about it going near the avionics. This is what I am doing not what I did.I don't have the upper fusellage riveted yet so doing all my wiring was easy enough. Have fun.. Pascal -------------------------------------------------- From: "jayb" <jaybrinkmeyer(at)yahoo.com> Sent: Friday, January 22, 2010 12:30 PM Subject: RV10-List: Re: Windscreen install before panel? > > To clarify... The forward fuse is riveted on and the engine is hung. The > fans are in place. > > Jay > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=282950#282950 > > > ________________________________________________________________________________
Subject: New product introduction: TCW Technologies
Date: Jan 22, 2010
Fellow RV builders, TCW Technologies, is pleased to introduce our newest product, Integrated Back-up Battery System (IBBS). IBBS is a complete back-up battery solution for powering critical electronics such as EFIS, GPS, Autopilots and Engine monitors. The IBBS product combines a rechargeable ni-mh battery, a smart charger circuit and the transfer switch in a single enclosure that is easy to install and only 1/2 the weight of a comparable lead acid battery. The IBBS provides about 1 hour of back-up endurance for typical EFIS and GPS systems; additionally, it includes surge suppression and allows systems to operational before and during engine cranking. The IBBS system is very easy to install and eliminates other field installed components such as transfer contactors and diodes. The IBBS product has been tested by Garmin for use with their G3x series of products. For all the details please visit our web site: www.tcwtech.com Thanks, Bob Newman TCW Technologies, LLC. rv-10 40176 ________________________________________________________________________________
Date: Jan 22, 2010
My two pennies: for me, the last two items that get riveted on are the forward upper fuselage and the cabin top. Almost all the wiring will be done prior to attaching the forward upper fuselage. Before you are ready to attach the windshield, fit the windshield and then use a sharpie to mark the outside edge on the fuselage top. Paint the forward fuselage top with a flat black paint .... look for 'textured' black in rattle can. Linn Pascal wrote: > > if you mean the actual front of the panel, installing the components. no > problem if you mean setting up the wiring and layout I would get all > that backend stuff done first, get all the wires positioned than close > out the upper fusellage and install the windscreen. This will help with > where to position your fans in relation to the avionics but more > importantly it will allow you to get easy access to move/route wires > around if they don't fit in a certain place. > Pascal > > -------------------------------------------------- > From: "jayb" <jaybrinkmeyer(at)yahoo.com> > Sent: Friday, January 22, 2010 9:53 AM > To: > Subject: RV10-List: Windscreen install before panel? > >> >> Thoughts on whether or not to install the windscreen before panel? I >> can't think of any particular reason why not other than the cabin will >> get warmer due to reduced circulation while crawling around. >> >> Cheers, >> Jay >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=282907#282907 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: Wheels, chocks and fiberglass
Date: Jan 22, 2010
Just a note to the list, for whatever it's worth. Found my nose wheel flat today at the hangar (not sure why yet). I use the small, aluminum chocks with litening holes you can get from Srpuce and other supply houses. As the tire slowly deflated, the wheel pants settled down onto the chock. The top of the chock did a good job crushing the bottom of the front part of the nose fairing as the chock is wider than the tire. Now I have to do fiberglass repair and cut the chocks down so that they are no wider than the tire itself. You might check your chocks out to avoid similar headache in the future.....and remember this when you are parked on a transient ramp somewhere (I take my chocks with me). grumpy N184JM ________________________________________________________________________________
Subject: Re: Wheels, chocks and fiberglass
Date: Jan 23, 2010
Great tip Grumpy....not normally a concern for folks used to retracts Once you get pants you need to worry bout "PANTS ON THE GROUND" lol..... ------Original Message------ From: Miller John Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Sent: Jan 22, 2010 7:09 PM Subject: RV10-List: Wheels, chocks and fiberglass Just a note to the list, for whatever it's worth. Found my nose wheel flat today at the hangar (not sure why yet). I use the small, aluminum chocks with litening holes you can get from Srpuce and other supply houses. As the tire slowly deflated, the wheel pants settled down onto the chock. The top of the chock did a good job crushing the bottom of the front part of the nose fairing as the chock is wider than the tire. Now I have to do fiberglass repair and cut the chocks down so that they are no wider than the tire itself. You might check your chocks out to avoid similar headache in the future.....and remember this when you are parked on a transient ramp somewhere (I take my chocks with me). grumpy N184JM Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Jan 22, 2010
I am putting windscreen on first. I don't see any difference if you already riveted on the forward fuse top. Two more cents - I used rattle can, spray on, truck bed liner from the local auto parts store to paint the forward fuse top. Textured, flat black and very tough. Scuff and prime first. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: "Linn Walters" <pitts_pilot(at)bellsouth.net> Sent: Friday, January 22, 2010 5:15 PM Subject: Re: RV10-List: Windscreen install before panel? > > My two pennies: for me, the last two items that get riveted on are the > forward upper fuselage and the cabin top. Almost all the wiring will be > done prior to attaching the forward upper fuselage. Before you are ready > to attach the windshield, fit the windshield and then use a sharpie to > mark the outside edge on the fuselage top. Paint the forward fuselage top > with a flat black paint .... look for 'textured' black in rattle can. > Linn > > Pascal wrote: >> >> if you mean the actual front of the panel, installing the components. no >> problem if you mean setting up the wiring and layout I would get all that >> backend stuff done first, get all the wires positioned than close out the >> upper fusellage and install the windscreen. This will help with where to >> position your fans in relation to the avionics but more importantly it >> will allow you to get easy access to move/route wires around if they >> don't fit in a certain place. >> Pascal >> >> -------------------------------------------------- >> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >> Sent: Friday, January 22, 2010 9:53 AM >> To: >> Subject: RV10-List: Windscreen install before panel? >> >>> >>> Thoughts on whether or not to install the windscreen before panel? I >>> can't think of any particular reason why not other than the cabin will >>> get warmer due to reduced circulation while crawling around. >>> >>> Cheers, >>> Jay >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 23, 2010
Oh please Grumpy, can we get a picture? "Looking like a fool with your pants on the ground" Too FF ricksked(at)cox.net wrote: > > Great tip Grumpy....not normally a concern for folks used to retracts > Once you get pants you need to worry bout "PANTS ON THE GROUND" lol..... > ------Original Message------ > From: Miller John > Sender: owner-rv10-list-server(at)matronics.com > To: rv10-list(at)matronics.com > ReplyTo: rv10-list(at)matronics.com > Sent: Jan 22, 2010 7:09 PM > Subject: RV10-List: Wheels, chocks and fiberglass > > > Just a note to the list, for whatever it's worth. > > Found my nose wheel flat today at the hangar (not sure why yet). > > I use the small, aluminum chocks with litening holes you can get from > Srpuce and other supply houses. > > As the tire slowly deflated, the wheel pants settled down onto the > chock. > > The top of the chock did a good job crushing the bottom of the front > part of the nose fairing as the chock is wider than the tire. > > Now I have to do fiberglass repair and cut the chocks down so that > they are no wider than the tire itself. > > You might check your chocks out to avoid similar headache in the > future.....and remember this when you are parked on a transient ramp > somewhere (I take my chocks with me). > > grumpy > > ________________________________________________________________________________
Subject: Re: Door SB
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jan 22, 2010
Now that I installed the flush door handles in rear part of the door and the unlock button is in the front I'd need a third hand to release the door latch in the middle of the door. I guess I really have to rethink if my setup is still feasible with the new SB. Not happy with the entire door locking mechanism Michael -------- RV-10 builder (avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283045#283045 ________________________________________________________________________________
Date: Jan 23, 2010
Michael, I have been flying with the same door handle setup you have. I don't have the SB kit yet, but I imagine the sequence to open the door will be to push the forward unlock button and rotate the flush handle to open. (two handed operation) At that point, the SB latch will still be holding the door in the closed position, but the pins will be retracted. Then you will release the SB latch and pull the door open. Shouldn't be a three handed job. I am curious if it looks like the SB latch is going to interfere with any of the internal flush handle mechanism? David Maib 40559 Flying On Jan 23, 2010, at 2:36 AM, Michael Wellenzohn wrote: Now that I installed the flush door handles in rear part of the door and the unlock button is in the front I'd need a third hand to release the door latch in the middle of the door. I guess I really have to rethink if my setup is still feasible with the new SB. Not happy with the entire door locking mechanism Michael -------- RV-10 builder (avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283045#283045 ________________________________________________________________________________
Subject: Another flying 10
Date: Jan 23, 2010
At approximately 1:30pm Thursday N569JC lifted off at KLVJ=2C Pearland=2CTX and flew straight and fast. The Nafsinger/Cram built 10 was completed in a little over 3 yrs with most all of the work done by my build partner and f riend Nick Nafsinger. She was a QB but with many mods all designed by Nick. IO-540 by Lyc Thunderbolt=2C Dual AFS 4500's=2C sl-30=2C 327=2C 430W=2C an d Dynon D-6 backup. overhead panel w/dropdown screen in back and all aircra ft lighting switches. The electric cowl flaps work flawlessly. Doors have 3 point locking system operated by the one handle. I could go on and on but I will spare everyone. Great airplane=2C I will miss the building process b ut not the $$$ part. John Cram was: 40569 now: N569JC- flying 1.9 hrs http://picasaweb.google.com/N569JC/20100121N569JC# ________________________________________________________________________________
Date: Jan 23, 2010
Subject: Re: Another flying 10
Another 10 added to our family.- Congrats and welcome aboard!- You are so right about missing the building process.... but I keep tinkering anyway ... seems there's always one more little mod to do. Well off to the airport to find an excuse to go somewhere. We're considering a move to Texas... Granbury... not too far away. Don McDonald --- On Sat, 1/23/10, John Cram wrote: From: John Cram <johncram(at)msn.com> Subject: RV10-List: Another flying 10 Date: Saturday, January 23, 2010, 8:53 AM At approximately 1:30pm Thursday N569JC lifted off at KLVJ, Pearland,TX and flew straight and fast. The Nafsinger/Cram built 10 was completed in a lit tle over 3 yrs with most all of the work done by my build partner and frien d Nick Nafsinger. She was a QB but with many mods all designed by Nick. IO- 540 by Lyc Thunderbolt, Dual AFS 4500's, sl-30, 327, 430W, and Dynon D-6 ba ckup. overhead panel w/dropdown screen in back and all aircraft lighting sw itches. The electric cowl flaps work flawlessly. Doors have 3 point locking system operated by the one handle. I could go on and on but I will spare e veryone. Great airplane, I will miss the building process but not the $$$ p art. - John Cram was: 40569 now: N569JC- flying 1.9 hrs - http://picasaweb.google.com/N569JC/20100121N569JC# =0A=0A=0A ________________________________________________________________________________
Date: Jan 23, 2010
UHV0dGluZyBwYW50cyBvbiBpcyBvdmVyIHJhdGVkIQ0KDQpHcmVhdCB0aXAgdGhvdWdoLiA6KQ0K DQotLS0tLSBPcmlnaW5hbCBNZXNzYWdlIC0tLS0tDQpGcm9tOiBCaWxsIE1hdWxlZHJpdmVyIFdh dHNvbiA8TWF1bGVEcml2ZXJAbmMucnIuY29tPg0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29t IDxydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClNlbnQ6IEZyaSBKYW4gMjIgMjE6MTU6NDIgMjAx MA0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogV2hlZWxzLCBjaG9ja3MgYW5kIGZpYmVyZ2xhc3MN Cg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogQmlsbCBNYXVsZWRyaXZlciBXYXRz b24gPE1hdWxlRHJpdmVyQG5jLnJyLmNvbT4NCg0KT2ggcGxlYXNlIEdydW1weSwgY2FuIHdlIGdl dCBhIHBpY3R1cmU/DQoNCiJMb29raW5nIGxpa2UgYSBmb29sIHdpdGggeW91ciBwYW50cyBvbiB0 aGUgZ3JvdW5kIg0KDQpUb28gRkYNCg0Kcmlja3NrZWRAY294Lm5ldCB3cm90ZToNCj4gLS0+IFJW MTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogcmlja3NrZWRAY294Lm5ldA0KPg0KPiBHcmVhdCB0 aXAgR3J1bXB5Li4uLm5vdCBub3JtYWxseSBhIGNvbmNlcm4gZm9yIGZvbGtzIHVzZWQgdG8gcmV0 cmFjdHMgDQo+IE9uY2UgeW91IGdldCBwYW50cyB5b3UgbmVlZCB0byB3b3JyeSBib3V0ICJQQU5U UyBPTiBUSEUgR1JPVU5EIiBsb2wuLi4uLg0KPiAtLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0t DQo+IEZyb206IE1pbGxlciBKb2huDQo+IFNlbmRlcjogb3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tDQo+IFRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiBSZXBseVRvOiBy djEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiBTZW50OiBKYW4gMjIsIDIwMTAgNzowOSBQTQ0KPiBT dWJqZWN0OiBSVjEwLUxpc3Q6IFdoZWVscywgY2hvY2tzIGFuZCBmaWJlcmdsYXNzDQo+DQo+IC0t PiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IE1pbGxlciBKb2huIDxnZW5ncnVtcHlAYW9s LmNvbT4NCj4NCj4gSnVzdCBhIG5vdGUgdG8gdGhlIGxpc3QsIGZvciB3aGF0ZXZlciBpdCdzIHdv cnRoLg0KPg0KPiBGb3VuZCBteSBub3NlIHdoZWVsIGZsYXQgdG9kYXkgYXQgdGhlIGhhbmdhciAo bm90IHN1cmUgd2h5IHlldCkuDQo+DQo+IEkgdXNlIHRoZSBzbWFsbCwgYWx1bWludW0gY2hvY2tz IHdpdGggbGl0ZW5pbmcgaG9sZXMgeW91IGNhbiBnZXQgZnJvbSAgDQo+IFNycHVjZSBhbmQgb3Ro ZXIgc3VwcGx5IGhvdXNlcy4NCj4NCj4gQXMgdGhlIHRpcmUgc2xvd2x5IGRlZmxhdGVkLCB0aGUg d2hlZWwgcGFudHMgc2V0dGxlZCBkb3duIG9udG8gdGhlICANCj4gY2hvY2suDQo+DQo+IFRoZSB0 b3Agb2YgdGhlIGNob2NrIGRpZCBhIGdvb2Qgam9iIGNydXNoaW5nIHRoZSBib3R0b20gb2YgdGhl IGZyb250ICANCj4gcGFydCBvZiB0aGUgbm9zZSBmYWlyaW5nIGFzIHRoZSBjaG9jayBpcyB3aWRl ciB0aGFuIHRoZSB0aXJlLg0KPg0KPiBOb3cgSSBoYXZlIHRvIGRvIGZpYmVyZ2xhc3MgcmVwYWly IGFuZCBjdXQgdGhlIGNob2NrcyBkb3duIHNvIHRoYXQgIA0KPiB0aGV5IGFyZSBubyB3aWRlciB0 aGFuIHRoZSB0aXJlIGl0c2VsZi4NCj4NCj4gWW91IG1pZ2h0IGNoZWNrIHlvdXIgY2hvY2tzIG91 dCB0byBhdm9pZCBzaW1pbGFyIGhlYWRhY2hlIGluIHRoZSAgDQo+IGZ1dHVyZS4uLi4uYW5kIHJl bWVtYmVyIHRoaXMgd2hlbiB5b3UgYXJlIHBhcmtlZCBvbiBhIHRyYW5zaWVudCByYW1wICANCj4g c29tZXdoZXJlIChJIHRha2UgbXkgY2hvY2tzIHdpdGggbWUpLg0KPg0KPiBncnVtcHkNCj4NCj4g ICANCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVt IC0NCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0 aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwg RkFRLA0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+ IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdy ZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0g ICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAg ICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQo ________________________________________________________________________________
Date: Jan 23, 2010
I had a main flat once and found that I couldn't jack the plane until I took the pant off but couldn't get the pant off because the lowest screws were Phillips and resting almost on the ground. Had to locate a wing jack to change the tire. After that I used short hex head screws in those locations so I could remove them. Albert Gardner N991RV Yuma, AZ > ------Original Message------ > Subject: RV10-List: Wheels, chocks and fiberglass > Just a note to the list, for whatever it's worth. > Found my nose wheel flat today at the hangar (not sure why yet). > I use the small, aluminum chocks with litening holes you can get from > Srpuce and other supply houses. > As the tire slowly deflated, the wheel pants settled down onto the > chock. > The top of the chock did a good job crushing the bottom of the front > part of the nose fairing as the chock is wider than the tire. > Now I have to do fiberglass repair and cut the chocks down so that > they are no wider than the tire itself. > You might check your chocks out to avoid similar headache in the > future.....and remember this when you are parked on a transient ramp > somewhere (I take my chocks with me). > grumpy ________________________________________________________________________________
Date: Jan 23, 2010
David, You are correct. Opening the door is a 2 step sequence, but it does not require 3 hands. Rotating the handle allows the bottom of the door to move outward 1/2 to 3/4 of an inch. Lift the new latch about 3/4 inch to open the door fully. The new latch also makes a convenient pull point to bring the door completely in for closing. I had been thinking of adding a strap of some type, as others have done, but probably will not now. I don't know how this will work out with other door handle systems, but the upper surface of the latch is 1/2 inch below the aft door pin rod and 11 1/2 inches aft of the stock door handle shaft. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283104#283104 ________________________________________________________________________________
Date: Jan 23, 2010
Perry, Phil wrote: > Putting pants on is over rated! Pervert!!! This is as family list!!! .... all in good fun Linn > > Great tip though. :) > > ----- Original Message ----- > From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com> > To: rv10-list(at)matronics.com > Sent: Fri Jan 22 21:15:42 2010 > Subject: Re: RV10-List: Wheels, chocks and fiberglass > > > > Oh please Grumpy, can we get a picture? > > "Looking like a fool with your pants on the ground" > > Too FF > > ricksked(at)cox.net wrote: > > > > Great tip Grumpy....not normally a concern for folks used to retracts > > Once you get pants you need to worry bout "PANTS ON THE GROUND" lol..... > > ------Original Message------ > > From: Miller John > > Sender: owner-rv10-list-server(at)matronics.com > > To: rv10-list(at)matronics.com > > ReplyTo: rv10-list(at)matronics.com > > Sent: Jan 22, 2010 7:09 PM > > Subject: RV10-List: Wheels, chocks and fiberglass > > > > > > Just a note to the list, for whatever it's worth. > > > > Found my nose wheel flat today at the hangar (not sure why yet). > > > > I use the small, aluminum chocks with litening holes you can get from > > Srpuce and other supply houses. > > > > As the tire slowly deflated, the wheel pants settled down onto the > > chock. > > > > The top of the chock did a good job crushing the bottom of the front > > part of the nose fairing as the chock is wider than the tire. > > > > Now I have to do fiberglass repair and cut the chocks down so that > > they are no wider than the tire itself. > > > > You might check your chocks out to avoid similar headache in the > > future.....and remember this when you are parked on a transient ramp > > somewhere (I take my chocks with me). > > > > grumpy > > > > > > > > > > > ~,gM4Gqz.'8E]t.+-fZ+`axr^jzZ(j|n)b'!j'+ry'C > { > ,x(ZP!jrrj|-&j',r5hum > 'ojj+E]t.+-08IaT1 > jgrz{Zi^&lZ+ky+k&j',r+k&j',rhB{ky.+jY^.+-i0fr((nbxm-&j',rr&*''k{w/tml ________________________________________________________________________________
Date: Jan 23, 2010
Would there be any issues with completing the tasks listed below prior to riveting the forward upper fuselage in place Fit the upper cabin top brace Install the engine Fit the upper and lower cowls Install the cowl baffles Fit the windscreen Larry Rosen Starting building after a year away Linn Walters wrote: > > My two pennies: for me, the last two items that get riveted on are > the forward upper fuselage and the cabin top. Almost all the wiring > will be done prior to attaching the forward upper fuselage. Before > you are ready to attach the windshield, fit the windshield and then > use a sharpie to mark the outside edge on the fuselage top. Paint the > forward fuselage top with a flat black paint .... look for 'textured' > black in rattle can. > Linn > > Pascal wrote: >> >> if you mean the actual front of the panel, installing the components. >> no problem if you mean setting up the wiring and layout I would get >> all that backend stuff done first, get all the wires positioned than >> close out the upper fusellage and install the windscreen. This will >> help with where to position your fans in relation to the avionics but >> more importantly it will allow you to get easy access to move/route >> wires around if they don't fit in a certain place. >> Pascal >> >> -------------------------------------------------- >> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >> Sent: Friday, January 22, 2010 9:53 AM >> To: >> Subject: RV10-List: Windscreen install before panel? >> >>> >>> Thoughts on whether or not to install the windscreen before panel? I >>> can't think of any particular reason why not other than the cabin >>> will get warmer due to reduced circulation while crawling around. >>> >>> Cheers, >>> Jay >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 23, 2010
no issues. I did everything except the windscreen. I'll rivet the upper fusellage than do the windscreen as it makes little sense for me to move the windscreen, fit it and wait to final install until I finally get around to riveting the front- which will be months. Pascal -------------------------------------------------- From: "Larry Rosen" <N205EN(at)gmail.com> Sent: Saturday, January 23, 2010 2:30 PM Subject: Re: RV10-List: Windscreen install before panel? > > Would there be any issues with completing the tasks listed below prior to > riveting the forward upper fuselage in place > Fit the upper cabin top brace > Install the engine > Fit the upper and lower cowls > Install the cowl baffles > Fit the windscreen > > Larry Rosen > Starting building after a year away > > > Linn Walters wrote: >> >> My two pennies: for me, the last two items that get riveted on are the >> forward upper fuselage and the cabin top. Almost all the wiring will be >> done prior to attaching the forward upper fuselage. Before you are ready >> to attach the windshield, fit the windshield and then use a sharpie to >> mark the outside edge on the fuselage top. Paint the forward fuselage >> top with a flat black paint .... look for 'textured' black in rattle can. >> Linn >> >> Pascal wrote: >>> >>> if you mean the actual front of the panel, installing the components. no >>> problem if you mean setting up the wiring and layout I would get all >>> that backend stuff done first, get all the wires positioned than close >>> out the upper fusellage and install the windscreen. This will help with >>> where to position your fans in relation to the avionics but more >>> importantly it will allow you to get easy access to move/route wires >>> around if they don't fit in a certain place. >>> Pascal >>> >>> -------------------------------------------------- >>> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >>> Sent: Friday, January 22, 2010 9:53 AM >>> To: >>> Subject: RV10-List: Windscreen install before panel? >>> >>>> >>>> Thoughts on whether or not to install the windscreen before panel? I >>>> can't think of any particular reason why not other than the cabin will >>>> get warmer due to reduced circulation while crawling around. >>>> >>>> Cheers, >>>> Jay >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 23, 2010
The only thing you can do is the mounting the engine. You can fit the brace and drill it but you will have to take it back off. The cowls can't be done until the fwd top fuse is in place because of the hinges. Also, you can't do the baffling because the cowls can't be installed until the hinges. I hope I'm right but that is the way I had to do it. Sent from my iPhone On Jan 23, 2010, at 15:30, Larry Rosen t wrote: > > Would there be any issues with completing the tasks listed below > prior to riveting the forward upper fuselage in place > Fit the upper cabin top brace > Install the engine > Fit the upper and lower cowls > Install the cowl baffles > Fit the windscreen > > Larry Rosen > Starting building after a year away > > > Linn Walters wrote: >> > >> >> My two pennies: for me, the last two items that get riveted on are >> the forward upper fuselage and the cabin top. Almost all the >> wiring will be done prior to attaching the forward upper fuselage. >> Before you are ready to attach the windshield, fit the windshield >> and then use a sharpie to mark the outside edge on the fuselage >> top. Paint the forward fuselage top with a flat black paint .... >> look for 'textured' black in rattle can. >> Linn >> >> Pascal wrote: >>> >>> if you mean the actual front of the panel, installing the >>> components. no problem if you mean setting up the wiring and >>> layout I would get all that backend stuff done first, get all the >>> wires positioned than close out the upper fusellage and install >>> the windscreen. This will help with where to position your fans in >>> relation to the avionics but more importantly it will allow you to >>> get easy access to move/route wires around if they don't fit in a >>> certain place. >>> Pascal >>> >>> -------------------------------------------------- >>> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >>> Sent: Friday, January 22, 2010 9:53 AM >>> To: >>> Subject: RV10-List: Windscreen install before panel? >>> >>>> >>>> Thoughts on whether or not to install the windscreen before >>>> panel? I can't think of any particular reason why not other than >>>> the cabin will get warmer due to reduced circulation while >>>> crawling around. >>>> >>>> Cheers, >>>> Jay >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 23, 2010
Larry, All of the items on your list can be accomplished before riveting the forward top fuselage in place. Just cleco the top skin and proceed with the other steps. Obviously you will have to remove the cabin top brace after drilling for the hardware at the upper end, then reinstall it after the forward skin is riveted in place. There is no problem clecoing the cowl hinges and fitting the cowling, baffles, etc. without the top skin being riveted. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283146#283146 ________________________________________________________________________________
Date: Jan 23, 2010
Man do I feel like a ri-tard. I guess I can finish my baffling. Thanks Jim. I never thought of using clecos. I'm serious. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283149#283149 ________________________________________________________________________________
Date: Jan 23, 2010
I guess I have 4 pennies in here now!! I'll bolt on the engine mount so I can mount stuff on the firewall prior to riveting on the forward upper fuselage. I think I'll put it on the gear just before mounting the engine. My proposed schedule would be: 1) fit the cabin top brace 2) complete the wiring ..... My panel will be connectorized for easy removal and the wirng to the fuselage will either be coiled up with the forward upper fuselage, or attached after it's riveted on. 3) prepare the inside of the cabin top ..... in process now .... getting ready to lay up the overhead console. Might include painting on inside. 4) install all the interior trim panels and seats. 5) river forward upper fuselage. 6) install cabin top. 7) get on the gear. 8) hang engine. 9) baffling .... make plenum. 10) attach cowl 11) install windows and windscreen. 12) final assembly of wings and tail feathers. 13) final paint ..... wings & tail feathers will be painted after they're assembled. If there's a quagmire in the making .... someone let me know!!! Linn Larry Rosen wrote: > > Would there be any issues with completing the tasks listed below prior > to riveting the forward upper fuselage in place > Fit the upper cabin top brace > Install the engine > Fit the upper and lower cowls > Install the cowl baffles > Fit the windscreen > > Larry Rosen > Starting building after a year away > > > Linn Walters wrote: >> >> My two pennies: for me, the last two items that get riveted on are >> the forward upper fuselage and the cabin top. Almost all the wiring >> will be done prior to attaching the forward upper fuselage. Before >> you are ready to attach the windshield, fit the windshield and then >> use a sharpie to mark the outside edge on the fuselage top. Paint the >> forward fuselage top with a flat black paint .... look for 'textured' >> black in rattle can. >> Linn >> >> Pascal wrote: >>> >>> if you mean the actual front of the panel, installing the components. >>> no problem if you mean setting up the wiring and layout I would get >>> all that backend stuff done first, get all the wires positioned than >>> close out the upper fusellage and install the windscreen. This will >>> help with where to position your fans in relation to the avionics but >>> more importantly it will allow you to get easy access to move/route >>> wires around if they don't fit in a certain place. >>> Pascal >>> >>> -------------------------------------------------- >>> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >>> Sent: Friday, January 22, 2010 9:53 AM >>> To: >>> Subject: RV10-List: Windscreen install before panel? >>> >>>> >>>> Thoughts on whether or not to install the windscreen before panel? I >>>> can't think of any particular reason why not other than the cabin >>>> will get warmer due to reduced circulation while crawling around. >>>> >>>> Cheers, >>>> Jay >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Subject: top engine case bolts
Date: Jan 23, 2010
I was attaching the front and aft baffle brackets to the top of the engine case. These bolts are 7/16 diameter coarse thread. The question I have is one=2C why are they undersize for the hole which the y fill=2C second=2C why are they coarse thread=2C lastly=2C what is the tor que value. I have the lycoming torque value pages that were put on this for um=2C but I couldn't find the specification for these bolts. Regular value for a 7/16 is 50 LB/Ft. I snapped the first bolt I tried to t ighten. I am believing that these bolts are very special and must be design ed for expansion. Anyone have the answers and another source or will I need to call Lycoming to order another bolt and get the torque value from them. Thanks=2C JOhn ________________________________________________________________________________
Date: Jan 23, 2010
Congrats John! Finally an airplane with a James cowl like mine! Did you have any temp issues? Did you actually need the cowl flaps? I'm just hoping that normal 260hp engine will not produce heat problems when using the James cowl unlike those fire breathing dragons others have used. So pleeeaaase give me some numbers. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283168#283168 ________________________________________________________________________________
Date: Jan 23, 2010
Subject: Re: top engine case bolts
Looks like the parts manual calls for LW25 in varying lengths for all the parting line bolts, which is 1/4" bolt X20 pitch thread. The manual calls for 75 INCH pounds. Not sure where you are finding 7/16 diameter bolts other than for the alternator mounting. You can get engine bolts from most parts suppliers. On Sat, Jan 23, 2010 at 8:02 PM, John Gonzalez wrote: > I was attaching the front and aft baffle brackets to the top of the engine > case. These bolts are 7/16 diameter coarse thread. > > The question I have is one, why are they undersize for the hole which they > fill, second, why are they coarse thread, lastly, what is the torque value. > I have thelycoming torque value pages that were puton this forum, but I > couldn't findthe specification for these bolts. > > Regular value for a 7/16 is 50 LB/Ft. I snapped the first bolt I tried to > tighten. I am believing that these bolts are very special and mustbe > designed for expansion. > > Anyone have the answers and another source or will Ineedtocall Lycoming > to order another boltand get the torque value from them. > > Thanks, > > JOhn > > ________________________________________________________________________________
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Date: Jan 24, 2010
Ya know. I think he is assuming the head size of the bolt, 7/16" is the bolt size. A 1/4" bolt has a socket/wrench size of 7/16..... No wonder i t broke at 50 ft lbs. Ben Haas N801BH www.haaspowerair.com ---------- Original Message ---------- From: Kelly McMullen <apilot2(at)gmail.com> Subject: Re: RV10-List: top engine case bolts Date: Sat, 23 Jan 2010 20:59:13 -0700 Looks like the parts manual calls for LW25 in varying lengths for all the parting line bolts, which is 1/4" bolt X20 pitch thread. The manual calls for 75 INCH pounds. Not sure where you are finding 7/16 diameter bolts other than for the alternator mounting. You can get engine bolts from most parts suppliers. On Sat, Jan 23, 2010 at 8:02 PM, John Gonzalez wrote: > I was attaching the front and aft baffle brackets to the top of the en gine > case. These bolts are 7/16 diameter coarse thread. > > The question I have is one, why are they undersize for the hole which they > fill, second, why are they coarse thread, lastly, what is the torque v alue. > I have the lycoming torque value pages that were put on this forum, bu t I > couldn't find the specification for these bolts. > > Regular value for a 7/16 is 50 LB/Ft. I snapped the first bolt I tried to > tighten. I am believing that these bolts are very special and must be > designed for expansion. > > Anyone have the answers and another source or will I need to call Lyco ming > to order another bolt and get the torque value from them. > > Thanks, > > JOhn > > ======================== =========== ======================== =========== ======================== =========== ======================== =========== ____________________________________________________________ Home Improvement Projects Click here to find experienced pros to help with your home improvement p roject. http://thirdpartyoffers.netzero.net/TGL2241/c?cp=wxGXoqqqRn9It2bQAO2Qr AAAJ1E315TiJGQRTntSFamdGWtMAAYAAAAAAAAAAAAAAAAAAADNAAAAAAAAAAAAAAAAAAASh AAAAAA ________________________________________________________________________________
Date: Jan 23, 2010
Larry, I don't foresee any quagmires, but I do have a few questions and suggestions. I am not sure if your list is just the stuff that needs to be done, or a proposed work sequence. 1. If by interior trim panels you mean the sheet metal, there is really not much point in putting it in yet. It looks kind of cool to see it in, but it is going to need to come back out for final inspection. Even if you are compulsive about planning your fuselage wiring & plumbing, I can almost guarantee there will be something that needs to be changed. 2. There is no need to rivet the forward fuselage before you final install the cabin top. You can slide the forward fuselage on and off with the cabin top in place. I would put off riveting the forward fuselage as long as possible, which means everything on your list except the windscreen and wings. 3. Make absolutely sure you have made any/all modifications to your subpanel before you rivet the forward fuselage. Having to cut access for long avionics or mount components on the subpanel after it is installed is an absolute pita. 4. I don't see doors. You are going to love doing those. 5. Baffling will have to come after fitting the cowl. I am not sure about the plenum since I don't have one. 6. There are a few rivets in the upper firewall to forward fuselage ribs that are very difficult to access with the engine in place. You will want 2 sets of very small, but highly trained hands to help with this step. Have fun. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283172#283172 ________________________________________________________________________________
Date: Jan 23, 2010
Larry posed the question .... the list is mine! Jim Berry wrote: > > Larry, > > I don't foresee any quagmires, but I do have a few questions and > suggestions. I am not sure if your list is just the stuff that needs > to be done, or a proposed work sequence. Both. > > 1. If by interior trim panels you mean the sheet metal, there is > really not much point in putting it in yet. It looks kind of cool to > see it in, but it is going to need to come back out for final > inspection. Even if you are compulsive about planning your fuselage > wiring & plumbing, I can almost guarantee there will be something > that needs to be changed. I ran sufficient conduit so adding wires shouldn't be a problem. I also have a wire run down the center console without conduit so those covers might pose a problem. > > 2. There is no need to rivet the forward fuselage before you final > install the cabin top. You can slide the forward fuselage on and off > with the cabin top in place. I would put off riveting the forward > fuselage as long as possible, which means everything on your list > except the windscreen and wings. Good point. The cabin top and the forward upper fuse are my final 'close out' items since I really don't want them in the way. > > 3. Make absolutely sure you have made any/all modifications to your > subpanel before you rivet the forward fuselage. Having to cut access > for long avionics or mount components on the subpanel after it is > installed is an absolute pita. I'm there now. My transponder is the only deep item. such a shame to do so much work stiffening the hole for a couple of inches. > > 4. I don't see doors. You are going to love doing those. My doors are hung .... going through the process to add the McMaster-Carr seals. Lots of grinding/filling on the door jambs. > > 5. Baffling will have to come after fitting the cowl. I am not sure > about the plenum since I don't have one. I think you're right. Good call. > > 6. There are a few rivets in the upper firewall to forward fuselage > ribs that are very difficult to access with the engine in place. You > will want 2 sets of very small, but highly trained hands to help with > this step. Only the engine mount will be installed prior to attachment of the upper fuselage. I have stuff to mount on the engine side of the firewall so need clearance and maintenance room. > > Have fun. Fun??? Well, I am enjoying the journey. This is far more complex than building my Pitts ...... but the fun will come in the flying. My brain keeps the tune 'I'm a traveling man, made a lot of stop, all over the world ...... I want to see a lot more of my country before I croak!!! Thanks for the guidance!!! Linn > > Jim Berry 40482 N15JB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283172#283172 > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 23, 2010
I was about to make that admission=2C what was I thinking From: n801bh(at)netzero.com Date: Sun=2C 24 Jan 2010 04:22:43 +0000 Subject: Re: RV10-List: top engine case bolts Ya know. I think he is assuming the head size of the bolt=2C 7/16" is the b olt size. A 1/4" bolt has a socket/wrench size of 7/16..... No wonder it br oke at 50 ft lbs. Ben Haas N801BH www.haaspowerair.com ---------- Original Message ---------- From: Kelly McMullen <apilot2(at)gmail.com> Subject: Re: RV10-List: top engine case bolts Date: Sat=2C 23 Jan 2010 20:59:13 -0700 Looks like the parts manual calls for LW25 in varying lengths for all the parting line bolts=2C which is 1/4" bolt X20 pitch thread. The manual calls for 75 INCH pounds. Not sure where you are finding 7/16 diameter bolts other than for the alternator mounting. You can get engine bolts from most parts suppliers. On Sat=2C Jan 23=2C 2010 at 8:02 PM=2C John Gonzalez wrote: > I was attaching the front and aft baffle brackets to the top of the engin e > case. These bolts are 7/16 diameter coarse thread. > > The question I have is one=2C why are they undersize for the hole which t hey > fill=2C second=2C why are they coarse thread=2C lastly=2C what is the tor que value. > I have the lycoming torque value pages that were put on this forum=2C but I > couldn't find the specification for these bolts. > > Regular value for a 7/16 is 50 LB/Ft. I snapped the first bolt I tried to > tighten. I am believing that these bolts are very special and must be > designed for expansion. > > Anyone have the answers and another source or will I need to call Lycomin g > to order another bolt and get the torque value from them. > > Thanks=2C > > JOhn > > ____________________________________________________________ Home Improvement Projects Click here to find experienced pros to help with your home improvement proj ect. ________________________________________________________________________________
Date: Jan 23, 2010
Linn; All looks like what I did/am doing. I might suggest you do the cowl before the baffles, I noticed that it was easier to fit/adjust the baffles to the correct cowl mating than it would be to make the cowls line up and fit around the baffles. I had a heck of a time with my cowls they were warped and took loads of work just to align so I am glad I did my cowls before the baffles. I really would hold off on riveting the upper forward fusellage until after step #10. The engine can be mounted without concern of the piece being riveted on, I have had it this way for months . Pascal -------------------------------------------------- From: "Linn Walters" <pitts_pilot(at)bellsouth.net> Sent: Saturday, January 23, 2010 4:24 PM Subject: Re: RV10-List: Windscreen install before panel? > > I guess I have 4 pennies in here now!! > I'll bolt on the engine mount so I can mount stuff on the firewall prior > to riveting on the forward upper fuselage. I think I'll put it on the gear > just before mounting the engine. My proposed schedule would be: > 1) fit the cabin top brace > 2) complete the wiring ..... My panel will be connectorized for easy > removal and the wirng to the fuselage will either be coiled up with the > forward upper fuselage, or attached after it's riveted on. > 3) prepare the inside of the cabin top ..... in process now .... getting > ready to lay up the overhead console. Might include painting on inside. > 4) install all the interior trim panels and seats. > 5) river forward upper fuselage. > 6) install cabin top. > 7) get on the gear. > 8) hang engine. > 9) baffling .... make plenum. > 10) attach cowl > 11) install windows and windscreen. > 12) final assembly of wings and tail feathers. > 13) final paint ..... wings & tail feathers will be painted after they're > assembled. > > If there's a quagmire in the making .... someone let me know!!! > Linn > > > Larry Rosen wrote: >> >> Would there be any issues with completing the tasks listed below prior to >> riveting the forward upper fuselage in place >> Fit the upper cabin top brace >> Install the engine >> Fit the upper and lower cowls >> Install the cowl baffles >> Fit the windscreen >> >> Larry Rosen >> Starting building after a year away >> >> >> Linn Walters wrote: >>> >>> >>> My two pennies: for me, the last two items that get riveted on are the >>> forward upper fuselage and the cabin top. Almost all the wiring will be >>> done prior to attaching the forward upper fuselage. Before you are >>> ready to attach the windshield, fit the windshield and then use a >>> sharpie to mark the outside edge on the fuselage top. Paint the forward >>> fuselage top with a flat black paint .... look for 'textured' black in >>> rattle can. >>> Linn >>> >>> Pascal wrote: >>>> >>>> if you mean the actual front of the panel, installing the components. >>>> no problem if you mean setting up the wiring and layout I would get all >>>> that backend stuff done first, get all the wires positioned than close >>>> out the upper fusellage and install the windscreen. This will help with >>>> where to position your fans in relation to the avionics but more >>>> importantly it will allow you to get easy access to move/route wires >>>> around if they don't fit in a certain place. >>>> Pascal >>>> >>>> -------------------------------------------------- >>>> From: "jayb" <jaybrinkmeyer(at)yahoo.com> >>>> Sent: Friday, January 22, 2010 9:53 AM >>>> To: >>>> Subject: RV10-List: Windscreen install before panel? >>>> >>>>> >>>>> Thoughts on whether or not to install the windscreen before panel? I >>>>> can't think of any particular reason why not other than the cabin will >>>>> get warmer due to reduced circulation while crawling around. >>>>> >>>>> Cheers, >>>>> Jay >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=282907#282907 >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 24, 2010
Subject: wiring
Since I'm deep into wiring, there's some things I do to make life easier. I thought I'd share them. Wiring up my intercom I used some 4 wire shielded for each position. Stripping the insulation off the braided ground is tough. My 'hint' is to use a razor blade just pressed on the insulation .... don't 'saw' .... and bend the wire to break the insulation all the way around. Keeps the braid intact. The next 'hint' is to use an insulator from a full-size alligator clip to capture the insulation and pull it off. You might have to flex the insulation to break it loose from the braid. There's also a nice EAA video on dealing with shielded wire. Linn ________________________________________________________________________________
Date: Jan 24, 2010
Subject: Flat Front Tyre
I recently took off with a fully inflated front tyre and minutes later landed on a dead flat one and ground the spat on the tarmac but thankfully no more drastic damage. Though I had come from a grass strip, at the postmortem I found no thorn but a tube tear near the valve stem. I am wondering whether the valve stem clipped the nose fork and caused the problem. I had fitted the new axle mod a month earlier and did not have the valve cap on. Interested in Grumpy's and any other experience. Geoff Bryant VH-XVR 170+ hrs and 12+ months to date Adelaide South Australia > > ________________________________________________________________________________
Subject: Re: wiring
Date: Jan 24, 2010
Thanks for sharing the information Linn. I have a few months but plan on doing it all myself. -------- Wayne Gillispie A&P 5/93', PP 10/08' Grayson, KY Bldr# 40983 Ordered complete kit 8/24/09 DB Schenker delivered 11/20/09 Starting empennage 11/24/09 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283210#283210 ________________________________________________________________________________
Subject: Windshield install
Date: Jan 24, 2010
I want to post my experience with installing my front window yesterday afternoon. I had no problems at all using weld-on. The window turned out as good as I would have hoped. I started by getting the window to fit very well to the flange and did the usual due diligence in tapping off the inside edge and prepping the mating surfaces. Then mixed the weld-on and while my son held, scooped it into a squeeze bag. Cut a 1/4 inch opening off the end of the bag and ran a 1/4 inch bead of glue onto the flange right at the aft edge. Do not over apply the glue. We set the window in place and gently pushed till the weld-on flowed across the flange. Then we ran straps across the window connected to the wing spar to hold everything in place. I put blocks of foam and two rolled up leather gloves under the straps at specific points to ensure a tight fit but not along the glue joints. No crazing anywhere. I believe crazing comes from too much pressure at a point while the glue cures. It really makes some heat as it does. Using a squeeze bag to apply the product is also the way to go without question. It almost eliminates the strings and puts on a very uniform bead. After squeezing the bead, placing the window, adjusting the straps and checking the fit, I could still easily have squeezed more free flowing weld-on from that bag. Plenty of time to work with this way. Also, by putting the bead of glue at the aft or outer edge of the flange, cleanup on the inside was minimal. Remove the inside tape after about 30 minutes. I have one minor crack in all my windows from using fingers to hold in a back window during gluing. I would recommend weld-on and try to minimize any point pressure to the glue joints for good results. Just thought you might like to know. Dave Leikam RV-10 #40496 N89DA Muskego, WI ________________________________________________________________________________
Date: Jan 24, 2010
>> 6. There are a few rivets in the upper firewall to forward fuselage >> ribs that are very difficult to access with the engine in place. You >> will want 2 sets of very small, but highly trained hands to help with >> this step. I forgot about those rivets - really perverse. >> >> Have fun. > Fun??? Well, I am enjoying the journey. This is far more complex > than building my Pitts ...... but the fun will come in the flying. My > brain keeps the tune 'I'm a traveling man, made a lot of stop, all > over the world ...... I want to see a lot more of my country before I > croak!!! Went to see "Up in the Air" last night (Clooney). A moving little movie human connections and such, but the great aerial shots scattered throughout had me longing for some flight... and not the airline style of slumming around. It's ironic that we've done less flying during the last 3 years of rolling our own, than we did in the previous 20. It's been some of the most interesting aviation play ever but sure am missing the clouds, and the places, and the people at those places. It's hard to buck up for a 400 mile slog in the Maule when dreaming of '10! But flying is flying - need a vacation. Bill "flying the '10 in 10" Watson ________________________________________________________________________________
Date: Jan 24, 2010
Linn, Sorry for the misattribution on your list. You are right about the Pitts being much simpler. I did a plans built Pitts S1S about 30 years ago. While building all those ribs and stitching was repetitious, it was a stone simple airplane. Also, access was great. There wasn't anything that you couldn't get both hands on. The -10 wont be nearly as much fun, but my wife is looking forward to something she can enjoy flying. She did one take off and landing in the Pitts, and said never again. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283236#283236 ________________________________________________________________________________
Date: Jan 24, 2010
Subject: Re: wiring
Thanks for that. I've managed to avoid working with the multi-conductor shielded stuff so far but know there's some ahead. I just finished mounting my front seat headphone jacks. Though my panel is a DIY effort, I used FastStack for a custom wiring harness including the jacks for the PS audio unit. I had them wire both regular jacks and Bose power jacks for the front seat. The problem was where to mount them all. Didn't want to put it on the panel so ended up installing them on the sidewalls just ahead of the seats. Came up with a little bracket that should work with or without my Flightline interior. Just posted here: http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=0&log'458&row=1 Bill "does the wiring ever end" Watson Linn Walters wrote: > > Since I'm deep into wiring, there's some things I do to make life > easier. I thought I'd share them. Wiring up my intercom I used some 4 > wire shielded for each position. Stripping the insulation off the > braided ground is tough. My 'hint' is to use a razor blade just pressed > on the insulation .... don't 'saw' .... and bend the wire to break the > insulation all the way around. Keeps the braid intact. > > The next 'hint' is to use an insulator from a full-size alligator clip > to capture the insulation and pull it off. You might have to flex the > insulation to break it loose from the braid. > > There's also a nice EAA video on dealing with shielded wire. > > Linn ________________________________________________________________________________
Date: Jan 24, 2010
Subject: Re: wiring
I already had the pilot/co-pilot jacks mounted and wired .... and changed my mind. I have a PS 3000 intercom going in ..... and decided that hanging the headsets on my overhead console .... would drape the headset wires across the cabin and I didn't want that. So, the headset jacks will be mounted in the center console covers between the seat backs to keep the cord yanking down to a minimum.. Goof plugs will fill the old jack holes in the panel. I wish I had looked closer and taken more pictures of flying 10s ..... but Sun-n-Fun is on the horizon. I'm constantly amazed at the neat ideas that builders come up with. I received my door latch SB kit yesterday. So sad that all the time and expense of making up the SB kit just for CYA. The quality of the kit is excellent .... the reason sucks. Linn Bill Mauledriver Watson wrote: > > > Thanks for that. I've managed to avoid working with the multi-conductor > shielded stuff so far but know there's some ahead. > > I just finished mounting my front seat headphone jacks. Though my panel > is a DIY effort, I used FastStack for a custom wiring harness including > the jacks for the PS audio unit. I had them wire both regular jacks and > Bose power jacks for the front seat. The problem was where to mount > them all. Didn't want to put it on the panel so ended up installing > them on the sidewalls just ahead of the seats. Came up with a little > bracket that should work with or without my Flightline interior. Just > posted here: > http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=0&log'458&row=1 > > > Bill "does the wiring ever end" Watson > > Linn Walters wrote: >> >> Since I'm deep into wiring, there's some things I do to make life >> easier. I thought I'd share them. Wiring up my intercom I used some 4 >> wire shielded for each position. Stripping the insulation off the >> braided ground is tough. My 'hint' is to use a razor blade just pressed >> on the insulation .... don't 'saw' .... and bend the wire to break the >> insulation all the way around. Keeps the braid intact. >> >> The next 'hint' is to use an insulator from a full-size alligator clip >> to capture the insulation and pull it off. You might have to flex the >> insulation to break it loose from the braid. >> >> There's also a nice EAA video on dealing with shielded wire. >> >> Linn > > > > > > > ________________________________________________________________________________
Date: Jan 24, 2010
Subject: Re: wiring
One other tidbit .... if you plan ahead real good (sometimes I did) you can use short pieces of heat shrink in place of lacing cord or ty-raps. Makes pulling bundles easier. Just make the shrinking part the last thing!!! Linn ________________________________________________________________________________
Subject: Re: Flat Front Tyre
Date: Jan 24, 2010
Appears my flat was from the valve core. I had aired it up 2 days prior before flying, so it was a fairly slow leak (appeared fine 1 hr later after flying). Had trouble getting the chuck to depress the valve core to allow air into the tube, so my suspicion is the valve core got out of whack. Replaced valve core and so far it is holding pressure. Had trouble again getting the valve core depressed enough to allow air in. Appears to me that the valve core recesses too far into the nose tube (90 degree valve stem). Gonna call Desser on Monday and ask about different valve core. Going to look at all my pants during annual next month, and maybe shave a little off the bottom of each one so that bottom of the pants are slightly above the wheel rim. grumpy N184JM On Jan 24, 2010, at 3:55 AM, Geoff Bryant wrote: > > I recently took off with a fully inflated front tyre and minutes > later landed on a dead flat one and ground the spat on the tarmac > but thankfully no more drastic damage. Though I had come from a > grass strip, at the postmortem I found no thorn but a tube tear > near the valve stem. I am wondering whether the valve stem clipped > the nose fork and caused the problem. I had fitted the new axle mod > a month earlier and did not have the valve cap on. Interested in > Grumpy's and any other experience. > Geoff Bryant VH-XVR 170+ hrs and 12+ months to date Adelaide South > Australia > > ________________________________________________________________________________
Subject: Re: Windshield install
Date: Jan 24, 2010
Hi Dave, What was your shop temperature during the installation? Jeff Carpenter 40304 On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: > I want to post my experience with installing my front window > yesterday afternoon. I had no problems at all using weld-on. The > window turned out as good as I would have hoped. I started by > getting the window to fit very well to the flange and did the usual > due diligence in tapping off the inside edge and prepping the mating > surfaces. Then mixed the weld-on and while my son held, scooped it > into a squeeze bag. Cut a 1/4 inch opening off the end of the bag > and ran a 1/4 inch bead of glue onto the flange right at the aft > edge. Do not over apply the glue. We set the window in place and > gently pushed till the weld-on flowed across the flange. Then we > ran straps across the window connected to the wing spar to hold > everything in place. I put blocks of foam and two rolled up leather > gloves under the straps at specific points to ensure a tight fit but > not along the glue joints. No crazing anywhere. I believe crazing > comes from too much pressure at a point while the glue cures. It > really makes some heat as it does. Using a squeeze bag to apply the > product is also the way to go without question. It almost > eliminates the strings and puts on a very uniform bead. After > squeezing the bead, placing the window, adjusting the straps and > checking the fit, I could still easily have squeezed more free > flowing weld-on from that bag. Plenty of time to work with this > way. Also, by putting the bead of glue at the aft or outer edge of > the flange, cleanup on the inside was minimal. Remove the inside > tape after about 30 minutes. I have one minor crack in all my > windows from using fingers to hold in a back window during gluing. > I would recommend weld-on and try to minimize any point pressure to > the glue joints for good results. Just thought you might like to > know. > > > Dave Leikam > RV-10 #40496 > N89DA > Muskego, WI > > ________________________________________________________________________________
Subject: Log book recommendations
Date: Jan 24, 2010
Does anyone have recommendations for airframe and engine log books; either paper or software versions? I am also down to the last page in my pilots log; any suggestions there? Thanks. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283294#283294 ________________________________________________________________________________
Date: Jan 24, 2010
68. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, January 24, 2010 3:46 PM Subject: Re: RV10-List: Windshield install Hi Dave, What was your shop temperature during the installation? Jeff Carpenter 40304 On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: I want to post my experience with installing my front window yesterday afternoon. I had no problems at all using weld-on. The window turned out as good as I would have hoped. I started by getting the window to fit very well to the flange and did the usual due diligence in tapping off the inside edge and prepping the mating surfaces. Then mixed the weld-on and while my son held, scooped it into a squeeze bag. Cut a 1/4 inch opening off the end of the bag and ran a 1/4 inch bead of glue onto the flange right at the aft edge. Do not over apply the glue. We set the window in place and gently pushed till the weld-on flowed across the flange. Then we ran straps across the window connected to the wing spar to hold everything in place. I put blocks of foam and two rolled up leather gloves under the straps at specific points to ensure a tight fit but not along the glue joints. No crazing anywhere. I believe crazing comes from too much pressure at a point while the glue cures. It really makes some heat as it does. Using a squeeze bag to apply the product is also the way to go without question. It almost eliminates the strings and puts on a very uniform bead. After squeezing the bead, placing the window, adjusting the straps and checking the fit, I could still easily have squeezed more free flowing weld-on from that bag. Plenty of time to work with this way. Also, by putting the bead of glue at the aft or outer edge of the flange, cleanup on the inside was minimal. Remove the inside tape after about 30 minutes. I have one minor crack in all my windows from using fingers to hold in a back window during gluing. I would recommend weld-on and try to minimize any point pressure to the glue joints for good results. Just thought you might like to know. Dave Leikam RV-10 #40496 N89DA Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Subject: Re: Log book recommendations
Date: Jan 24, 2010
For pilot's log I use the nice one from Sporty's (not even sure if they still sell it). I also transcribe it onto an Excel spreadsheet - makes it easier every year, at insurance renewal, to add up total, in type, night, last year, last 90 days, etc. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283306#283306 ________________________________________________________________________________
Date: Jan 24, 2010
Congratulations John from a fellow TX RV'er. Maybe in another decade my 10 will be flying. If you are in our part of the state stop by sometime (0TX1 - Pecan Plantation). -------- Dave Moore RV-6 flying RV-10 QB - FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283317#283317 ________________________________________________________________________________
Date: Jan 24, 2010
at 98 the Weld-on 10 doesn't work so well Sent from my iPhone On Jan 24, 2010, at 5:22 PM, "Dave Leikam" wrote: > 68. > > Dave Leikam > RV-10 #40496 > N89DA > Muskego, WI > ----- Original Message ----- > From: Jeff Carpenter > To: rv10-list(at)matronics.com > Sent: Sunday, January 24, 2010 3:46 PM > Subject: Re: RV10-List: Windshield install > > Hi Dave, > > What was your shop temperature during the installation? > > Jeff Carpenter > 40304 > > > On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: > >> I want to post my experience with installing my front window >> yesterday afternoon. I had no problems at all using weld-on. The >> window turned out as good as I would have hoped. I started by >> getting the window to fit very well to the flange and did the usual >> due diligence in tapping off the inside edge and prepping the >> mating surfaces. Then mixed the weld-on and while my son held, >> scooped it into a squeeze bag. Cut a 1/4 inch opening off the end >> of the bag and ran a 1/4 inch bead of glue onto the flange right at >> the aft edge. Do not over apply the glue. We set the window in >> place and gently pushed till the weld-on flowed across the flange. >> Then we ran straps across the window connected to the wing spar to >> hold everything in place. I put blocks of foam and two rolled up >> leather gloves under the straps at specific points to ensure a >> tight fit but not along the glue joints. No crazing anywhere. I >> believe crazing comes from too much pressure at a point while the >> glue cures. It really makes some heat as it does. Using a squeeze >> bag to apply the product is also the way to go without question. >> It almost eliminates the strings and puts on a very uniform bead. >> After squeezing the bead, placing the window, adjusting the straps >> and checking the fit, I could still easily have squeezed more free >> flowing weld-on from that bag. Plenty of time to work with this >> way. Also, by putting the bead of glue at the aft or outer edge of >> the flange, cleanup on the inside was minimal. Remove the inside >> tape after about 30 minutes. I have one minor crack in all my >> windows from using fingers to hold in a back window during gluing. >> I would recommend weld-on and try to minimize any point pressure to >> the glue joints for good results. Just thought you might like to >> know. >> >> >> Dave Leikam >> RV-10 #40496 >> N89DA >> Muskego, WI >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Subject: more about the door SB
Date: Jan 24, 2010
I saw this on the door SB thread on VAF tonight. I don't recall seeing it cross posted to this venue (sorry if it already was) so I thought I'd cross post it here for those that might not read the VAF forums. http://www.vansairforce.com/community/showthread.php?t=53151 What caught my interest though was post #19 on page 2 by John Trollinger http://www.vansairforce.com/community/showthread.php?t=53151 <http://www.vansairforce.com/community/showthread.php?t=53151&page=2> &page=2 http://rv10.trollingers.com/vans_images/Drawing1.jpg I don't recall anyone mentioning his approach on the matronics list of a way to operate the SB latch without the exterior protrusion using the stock Van's door mechanism. It seems pretty clever. One would have to cut a big enough access hole in the door to make enough room to attach the piece. Riveting might be a bit too permanent if you had to remove the door rods but I think the idea has some legs to it. I wonder if it would flex the tube up rather than lift the latch? -Ben Westfall ________________________________________________________________________________
Date: Jan 25, 2010
Subject: Re: Wing Wiring and Conduit
Thanks for the replies. I decided to go ahead and order all of the accessories I will put in the wings (lights, servos, AOA etc.) so there will be no surprises down the road. It's surprising how much extra you can spend on accessories :). I have been mulling the Safeair tip tanks as well, but at this point the budget won't bear it. Also, after reading all the great trip reports and thinking about the reality of sitting in the plane for that long, I don't think I will really need them. Kent #40710 Wings >>> "Fred Williams, M.D." 1/21/2010 1:11 PM >>> Kent Ogden wrote: Kent; Few things to think about; AOA. I ran my plastic tubing lines thru the same conduit. Plastic one worked well. As mentioned, Make sure you have an extra pull string. Other things to think about: Wingtip lighting (position /strobe/led/whelen) Will your pitot tube have a heating element for ice? Will need power and indicator lights. VOR /marker beacon antennae? Some people put theirs in the wingtip. Temp probe? I put mine in an accessible area inboard of the innermost inspection plate. Do you want a landing light (like duckworks) or go with the wing tip landing lights? Start getting a spread sheet of what you want in the wings before you rivet up the lower skin. Dr Fred 515FW ________________________________________________________________________________
Date: Jan 25, 2010
I don't know if that makes sense. The market of available items keeps changing. I don't plan to rivet the bottom skin on until I am just about ready to mount the wings to the fuselage. Pitot selection depends on EFIS selection, as does AOA. Servos depend on autopilot selection..True track and Dyon are supposed to physically interchange, but not electronically. I don't think the market is mature on LED lights, nor HID lights. Given that from the wings completion to wing mounting is at least 6 months or more work, I want at least 1 more OSH to go by before I finalize any of that. Kelly 40866 Wings about complete, except for wiring and accessories. On Mon, Jan 25, 2010 at 8:30 AM, Kent Ogden wrote: > Thanks for the replies. I decided to go ahead and order all of the > accessories I will put in the wings (lights, servos, AOA etc.) so there will > be no surprises down the road. It's surprising how much extra you can spend > on accessories :). I have been mulling the Safeair tip tanks as well, but > at this point the budget won't bear it. Also, after reading all the great > trip reports and thinking about the reality of sitting in the plane for that > long, I don't think I will really need them. > > Kent > #40710 Wings > >>>> "Fred Williams, M.D." 1/21/2010 1:11 PM >>> > > > Kent Ogden wrote: > Kent; > > Few things to think about; > > AOA. I ran my plastic tubing lines thru the same conduit. Plastic one > worked well. As mentioned, Make sure you have an extra pull string. > > Other things to think about: > Wingtip lighting (position /strobe/led/whelen) > Will your pitot tube have a heating element for ice? Will need power > and indicator lights. > VOR /marker beacon antennae? Some people put theirs in the wingtip. > Temp probe? I put mine in an accessible area inboard of the innermost > inspection plate. > Do you want a landing light (like duckworks) or go with the wing tip > landing lights? > > Start getting a spread sheet of what you want in the wings before you > rivet up the lower skin. > > > Dr Fred > 515FW > > ________________________________________________________________________________
Subject: Wing Wiring and Conduit
Date: Jan 25, 2010
My view on the tip tanks=85=85 Wife and kids don=92t fly legs more than 2.5hr legs=85 Weight. I have my airplane at 2800 and with people in the back seats I hit the limit. 60 gallons at reasonable fuel burn rates (12.2 rich of peak, 10.5 lean of peak (or better)), always provides for at least 4 hours of flight time=85.. So for me it does not really work out to be a good deal. Just think of how many flights you will have where you will need the fuel=85=85=85=85. Rene 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kent Ogden Sent: Monday, January 25, 2010 8:31 AM Subject: Re: RV10-List: Wing Wiring and Conduit Thanks for the replies. I decided to go ahead and order all of the accessories I will put in the wings (lights, servos, AOA etc.) so there will be no surprises down the road. It's surprising how much extra you can spend on accessories :). I have been mulling the Safeair tip tanks as well, but at this point the budget won't bear it. Also, after reading all the great trip reports and thinking about the reality of sitting in the plane for that long, I don't think I will really need them. Kent #40710 Wings >>> "Fred Williams, M.D." 1/21/2010 1:11 PM >>> Kent Ogden wrote: Kent; Few things to think about; AOA. I ran my plastic tubing lines thru the same conduit. Plastic one worked well. As mentioned, Make sure you have an extra pull string. Other things to think about: Wingtip lighting (position /strobe/led/whelen) Will your pitot tube have a heating element for ice? Will need power and indicator lights. VOR /marker beacon antennae? Some people put theirs in the wingtip. Temp probe? I put mine in an accessible area inboard of the innermost inspection plate. Do you want a landing light (like duckworks) or go with the wing tip landing lights? Start getting a spread sheet of what you want in the wings before you rivet up the lower skin. Dr Fred 515FW =B7~=89=B2, _____ g'=D3=D3 ________________________________________________________________________________
Date: Jan 25, 2010
My point in posting is just that I think the product gets more negative publicity than it should. Plan to install on a cooler day, and keep the product refrigerated until just prior to mixing. Using a squeeze bag makes a huge difference in application time as well. I bet it took me little more than 60-90 seconds once mixed to get the product in the bag and apply the bead to the flange including the time to reposition a step ladder from one side of the fuse to the other and I'm no artist! I did experimented with other products (3M Scotch Weld 2216 easily pops apart after 5 days curing) and in the end, I really feel confident with the strength of the bond using weld-on. That's all I have to say about that. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, January 24, 2010 9:57 PM Subject: Re: RV10-List: Windshield install at 98 the Weld-on 10 doesn't work so well Sent from my iPhone On Jan 24, 2010, at 5:22 PM, "Dave Leikam" wrote: 68. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, January 24, 2010 3:46 PM Subject: Re: RV10-List: Windshield install Hi Dave, What was your shop temperature during the installation? Jeff Carpenter 40304 On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: I want to post my experience with installing my front window yesterday afternoon. I had no problems at all using weld-on. The window turned out as good as I would have hoped. I started by getting the window to fit very well to the flange and did the usual due diligence in tapping off the inside edge and prepping the mating surfaces. Then mixed the weld-on and while my son held, scooped it into a squeeze bag. Cut a 1/4 inch opening off the end of the bag and ran a 1/4 inch bead of glue onto the flange right at the aft edge. Do not over apply the glue. We set the window in place and gently pushed till the weld-on flowed across the flange. Then we ran straps across the window connected to the wing spar to hold everything in place. I put blocks of foam and two rolled up leather gloves under the straps at specific points to ensure a tight fit but not along the glue joints. No crazing anywhere. I believe crazing comes from too much pressure at a point while the glue cures. It really makes some heat as it does. Using a squeeze bag to apply the product is also the way to go without question. It almost eliminates the strings and puts on a very uniform bead. After squeezing the bead, placing the window, adjusting the straps and checking the fit, I could still easily have squeezed more free flowing weld-on from that bag. Plenty of time to work with this way. Also, by putting the bead of glue at the aft or outer edge of the flange, cleanup on the inside was minimal. Remove the inside tape after about 30 minutes. I have one minor crack in all my windows from using fingers to hold in a back window during gluing. I would recommend weld-on and try to minimize any point pressure to the glue joints for good results. Just thought you might like to know. Dave Leikam RV-10 #40496 N89DA Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jan 25, 2010
Jim, I'm glad you asked, I've been meaning to post this. This is about the third or fourth version. We've been using it for about a year now without any changes. I use a spreadsheet, then print it on card stock. I can go back and enter the data pretty easily, although it's not as foolproof as I imagined. I keep several blank pages in the flight manual (binder), and use it as both a flight log and maintenance logbook. I've worked with a lot of different logbooks and I like this one best. It puts a lot of information all in one place. My engine came with a logbook but I keep all the engine and airframe entries on the cards. When the pages get full, I file them away so I have a permanent record outside the plane. The card stock holds up pretty well. I can stick the transponder sign-offs, etc, right on the page. While I'm sort of on the subject, I keep track of time with an old-fashioined Hobbs meter running off of engine oil pressure. I had a customer who absolutely had to have a Hobbs meter in his plane, because he swore he'd need to refer to it regularly--he was right. I hate waiting for all the glass to boot up before I can just jot down the airframe time, then just turn it all off. The Hobbs is just really convenient, if a bit out of place. My two cents, Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sun, Jan 24, 2010 at 5:19 PM, Jim Berry wrote: > > Does anyone have recommendations for airframe and engine log books; either > paper or software versions? I am also down to the last page in my pilots > log; any suggestions there? Thanks. > > Jim Berry > 40482 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283294#283294 > > ________________________________________________________________________________
Date: Jan 25, 2010
Subject: Re: Windscreen install before panel?
Haha, guilty as charged. I have those shows scheduled on the DVR. Just goes to show you the power of television. My next build after the -10 is going to be to a 450 Hemi powered, lifted, monster truck rock crawler thing with FOOSE wheels! ;) I did pick up a can of the bedliner. After just 1 day of drying, it didn't seem exceptionally durable per se. Also, with just 1 coat, I didn't necessarily see the powder coat illusion. Will keep testing it. Jay 40533 RV Builder (Michael Sausen) wrote: > > Sounds like you are a fan of the Powerblock. ;-) > > > ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jan 25, 2010
I am just a bit surprised that you are vocally recommending a product that did put a small crack in 1 of 5 windows..... I built 1 RV-10 with Weld on, and I personally will not use the product again. Especially after talking with the windscreen manufacturer in Ohio and 'wishes Vans didn't recommend weld on.'. I have used SikaFlex with great success and I don't need to worry about point loading as you do with Weld On. Sure Weld On works if you happen to have parts that fit perfectly and if you do everything exactly right, but if one of the windows doesn't fit just right and you need to pull it in place, Weld On is way less forgiving. YMMV, That's just my experience. -Mike Kraus RV-4 Flying RV-10 wiring Sent from my iPhone On Jan 25, 2010, at 9:16 AM, "Dave Leikam" wrote: > My point in posting is just that I think the product gets more > negative publicity than it should. Plan to install on a cooler day, > and keep the product refrigerated until just prior to mixing. Using > a squeeze bag makes a huge difference in application time as well. > I bet it took me little more than 60-90 seconds once mixed to get > the product in the bag and apply the bead to the flange including > the time to reposition a step ladder from one side of the fuse to > the other and I'm no artist! I did experimented with other > products (3M Scotch Weld 2216 easily pops apart after 5 days curing) > and in the end, I really feel confident with the strength of the > bond using weld-on. That's all I have to say about that. > > Dave Leikam > RV-10 #40496 > N89DA > Muskego, WI > > > ----- Original Message ----- > From: Jeff Carpenter > To: rv10-list(at)matronics.com > Sent: Sunday, January 24, 2010 9:57 PM > Subject: Re: RV10-List: Windshield install > > at 98 the Weld-on 10 doesn't work so well > > Sent from my iPhone > > On Jan 24, 2010, at 5:22 PM, "Dave Leikam" > wrote: > >> 68. >> >> Dave Leikam >> RV-10 #40496 >> N89DA >> Muskego, WI >> ----- Original Message ----- >> From: Jeff Carpenter >> To: rv10-list(at)matronics.com >> Sent: Sunday, January 24, 2010 3:46 PM >> Subject: Re: RV10-List: Windshield install >> >> Hi Dave, >> >> What was your shop temperature during the installation? >> >> Jeff Carpenter >> 40304 >> >> >> On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: >> >>> I want to post my experience with installing my front window >>> yesterday afternoon. I had no problems at all using weld-on. >>> The window turned out as good as I would have hoped. I started by >>> getting the window to fit very well to the flange and did the >>> usual due diligence in tapping off the inside edge and prepping >>> the mating surfaces. Then mixed the weld-on and while my son >>> held, scooped it into a squeeze bag. Cut a 1/4 inch opening off >>> the end of the bag and ran a 1/4 inch bead of glue onto the flange >>> right at the aft edge. Do not over apply the glue. We set the >>> window in place and gently pushed till the weld-on flowed across >>> the flange. Then we ran straps across the window connected to the >>> wing spar to hold everything in place. I put blocks of foam and >>> two rolled up leather gloves under the straps at specific points >>> to ensure a tight fit but not along the glue joints. No crazing >>> anywhere. I believe crazing comes from too much pressure at a >>> point while the glue cures. It really makes some heat as it >>> does. Using a squeeze bag to apply the product is also the way to >>> go without question. It almost eliminates the strings and puts on >>> a very uniform bead. After squeezing the bead, placing the window, >>> adjusting the straps and checking the fit, I could still easily >>> have squeezed more free flowing weld-on from that bag. Plenty of >>> time to work with this way. Also, by putting the bead of glue at >>> the aft or outer edge of the flange, cleanup on the inside was >>> minimal. Remove the inside tape after about 30 minutes. I have >>> one minor crack in all my windows from using fingers to hold in a >>> back window during gluing. I would recommend weld-on and try to >>> minimize any point pressure to the glue joints for good results. >>> Just thought you might like to know. >>> >>> >>> Dave Leikam >>> RV-10 #40496 >>> N89DA >>> Muskego, WI >>> >>> >>> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >>> href="http://forums.matronics.com">http://forums.matronics.com >>> href="http://www.matronics.com/contribution">http://www.matronics.com/c >>> >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http:// > www.matronics.com/c > > ________________________________________________________________________________
Subject: Another wing build question--wing walk doublers
Date: Jan 25, 2010
On page 16-2 step 3. The second part of this step has us dimple the aft most screw hole for a #8 flush head screw. Easy enough. Next it asks us to machine countersink the rest of the screw holes for a #8 flush head screw dimple. Do we countersink the skin- or- the wing walk doublers underneath of the skin and just dimple the skin? Next question is the last part of the step. We are asked to machine countersink all the rivet holes that correspond to the W-1027A and W-1027B wing walk doublers for the head of an AN426AD3 rivet. Again, do we countersink the skin or just countersink the doublers and dimple the skin? Thanks in advance, Bill RV-10 wings ________________________________________________________________________________
Subject: Re: Another wing build question--wing walk doublers
Date: Jan 25, 2010
Countersink the skin and doubler, nothing gets dimpled. Use a piece of scrap with a #8 dimple as a test piece to judge how much to countersink. The test dimple needs to fit in the countersink, just like the fairing will when you have the wings mounted. Otherwise, the fairing that covers the gap between wing and fuselage will sit high. -------- RV-10 #40333 N540XP (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283401#283401 ________________________________________________________________________________
Date: Jan 25, 2010
Thanks Dave! I have had no issues with Weld-on, windows fit fine and I'll probably go this route for the windscreen so your feedback is appreciated. Pascal From: Dave Leikam Sent: Monday, January 25, 2010 6:16 AM Subject: Re: RV10-List: Windshield install My point in posting is just that I think the product gets more negative publicity than it should. Plan to install on a cooler day, and keep the product refrigerated until just prior to mixing. Using a squeeze bag makes a huge difference in application time as well. I bet it took me little more than 60-90 seconds once mixed to get the product in the bag and apply the bead to the flange including the time to reposition a step ladder from one side of the fuse to the other and I'm no artist! I did experimented with other products (3M Scotch Weld 2216 easily pops apart after 5 days curing) and in the end, I really feel confident with the strength of the bond using weld-on. That's all I have to say about that. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, January 24, 2010 9:57 PM Subject: Re: RV10-List: Windshield install at 98 the Weld-on 10 doesn't work so well Sent from my iPhone On Jan 24, 2010, at 5:22 PM, "Dave Leikam" wrote: 68. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, January 24, 2010 3:46 PM Subject: Re: RV10-List: Windshield install Hi Dave, What was your shop temperature during the installation? Jeff Carpenter 40304 On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: I want to post my experience with installing my front window yesterday afternoon. I had no problems at all using weld-on. The window turned out as good as I would have hoped. I started by getting the window to fit very well to the flange and did the usual due diligence in tapping off the inside edge and prepping the mating surfaces. Then mixed the weld-on and while my son held, scooped it into a squeeze bag. Cut a 1/4 inch opening off the end of the bag and ran a 1/4 inch bead of glue onto the flange right at the aft edge. Do not over apply the glue. We set the window in place and gently pushed till the weld-on flowed across the flange. Then we ran straps across the window connected to the wing spar to hold everything in place. I put blocks of foam and two rolled up leather gloves under the straps at specific points to ensure a tight fit but not along the glue joints. No crazing anywhere. I believe crazing comes from too much pressure at a point while the glue cures. It really makes some heat as it does. Using a squeeze bag to apply the product is also the way to go without question. It almost eliminates the strings and puts on a very uniform bead. After squeezing the bead, placing the window, adjusting the straps and checking the fit, I could still easily have squeezed more free flowing weld-on from that bag. Plenty of time to work with this way. Also, by putting the bead of glue at the aft or outer edge of the flange, cleanup on the inside was minimal. Remove the inside tape after about 30 minutes. I have one minor crack in all my windows from using fingers to hold in a back window during gluing. I would recommend weld-on and try to minimize any point pressure to the glue joints for good results. Just thought you might like to know. Dave Leikam RV-10 #40496 N89DA Muskego, WI href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jan 25, 2010
Bill, Just countersink the skin. The doublers should be in place. If the countersink bit has to cut any of the doubler to get the proper depth, it will. As you know, with a countersink, the bottom of the wing skin will be flush, so there is no need to dimple or countersink the doubler directly. Same procedure for both operations. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton Sent: Monday, January 25, 2010 2:05 PM Subject: RV10-List: Another wing build question--wing walk doublers On page 16-2 step 3. The second part of this step has us dimple the aft most screw hole for a #8 flush head screw. Easy enough. Next it asks us to machine countersink the rest of the screw holes for a #8 flush head screw dimple. Do we countersink the skin- or- the wing walk doublers underneath of the skin and just dimple the skin? Next question is the last part of the step. We are asked to machine countersink all the rivet holes that correspond to the W-1027A and W-1027B wing walk doublers for the head of an AN426AD3 rivet. Again, do we countersink the skin or just countersink the doublers and dimple the skin? Thanks in advance, Bill RV-10 wings ________________________________________________________________________________
Subject: All dressed up
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Jan 25, 2010
Finally after 3 months since my first flight I got my gear legs and wheel pants painted and installed. I thought I would share these photos and help inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my AFS 4500 SV's. More photos available at http://combsfamily.phanpare.com Geoff -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283424#283424 Attachments: http://forums.matronics.com//files/img_0337_283.jpg http://forums.matronics.com//files/img_0325_153.jpg ________________________________________________________________________________
Date: Jan 25, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I feel the same way. It does form a very strong bond based on some test pieces I bashed around. Seems like all the alternatives may be a bit easier to work with. The strenght of the alternatives may or may not be all there but it may not be needed. Clearly there are some challenges and warnings with Weld-on's use. This list seems to have identified them along with work arounds and that makes a big difference. Thanks all! So, I used the tongues and clecos for the 4 windows, takes 15mins or less to do the job, removed everything in about an hour - no cracks, nice bonds, only spread some mess around on one of them when I didn't use the bag. Plan to do the windsheild and expect no problems. Bill > Thanks Dave! I have had no issues with Weld-on, windows fit fine and > I'll probably go this route for the windscreen so your feedback is > appreciated. > > Pascal > *From:* Dave Leikam > *Sent:* Monday, January 25, 2010 6:16 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Windshield install > > My point in posting is just that I think the product gets more > negative publicity than it should. Plan to install on a cooler day, > and keep the product refrigerated until just prior to mixing. Using a > squeeze bag makes a huge difference in application time as well. I > bet it took me little more than 60-90 seconds once mixed to get the > product in the bag and apply the bead to the flange including the time > to reposition a step ladder from one side of the fuse to the other and > I'm no artist! I did experimented with other products (3M Scotch > Weld 2216 easily pops apart after 5 days curing) and in the end, I > really feel confident with the strength of the bond using weld-on. > That's all I have to say about that. > > Dave Leikam > RV-10 #40496 > N89DA > Muskego, WI > > > > ----- Original Message ----- > *From:* Jeff Carpenter > *To:* rv10-list(at)matronics.com > *Sent:* Sunday, January 24, 2010 9:57 PM > *Subject:* Re: RV10-List: Windshield install > > at 98 the Weld-on 10 doesn't work so well > > Sent from my iPhone > > On Jan 24, 2010, at 5:22 PM, "Dave Leikam" > wrote: > >> 68. >> >> Dave Leikam >> RV-10 #40496 >> N89DA >> Muskego, WI >> >> ----- Original Message ----- >> *From:* Jeff Carpenter >> *To:* rv10-list(at)matronics.com >> *Sent:* Sunday, January 24, 2010 3:46 PM >> *Subject:* Re: RV10-List: Windshield install >> >> Hi Dave, >> >> What was your shop temperature during the installation? >> >> Jeff Carpenter >> 40304 >> >> >> On Jan 24, 2010, at 8:18 AM, Dave Leikam wrote: >> >>> I want to post my experience with installing my front window >>> yesterday afternoon. I had no problems at all using >>> weld-on. The window turned out as good as I would have >>> hoped. I started by getting the window to fit very well to >>> the flange and did the usual due diligence in tapping off >>> the inside edge and prepping the mating surfaces. Then >>> mixed the weld-on and while my son held, scooped it into a >>> squeeze bag. Cut a 1/4 inch opening off the end of the bag >>> and ran a 1/4 inch bead of glue onto the flange right at the >>> aft edge. Do not over apply the glue. We set the window in >>> place and gently pushed till the weld-on flowed across the >>> flange. Then we ran straps across the window connected to >>> the wing spar to hold everything in place. I put blocks of >>> foam and two rolled up leather gloves under the straps at >>> specific points to ensure a tight fit but not along the glue >>> joints. No crazing anywhere. I believe crazing comes from >>> too much pressure at a point while the glue cures. It >>> really makes some heat as it does. Using a squeeze bag to >>> apply the product is also the way to go without question. >>> It almost eliminates the strings and puts on a very uniform >>> bead. After squeezing the bead, placing the window, >>> adjusting the straps and checking the fit, I could still >>> easily have squeezed more free flowing weld-on from that >>> bag. Plenty of time to work with this way. Also, by >>> putting the bead of glue at the aft or outer edge of the >>> flange, cleanup on the inside was minimal. Remove the >>> inside tape after about 30 minutes. I have one minor crack >>> in all my windows from using fingers to hold in a back >>> window during gluing. I would recommend weld-on and try to >>> minimize any point pressure to the glue joints for good >>> results. Just thought you might like to know. >>> >>> >>> Dave Leikam >>> RV-10 #40496 >>> N89DA >>> Muskego, WI >> ________________________________________________________________________________
Subject: Re: All dressed up
Date: Jan 25, 2010
absolutely beautiful On Jan 25, 2010, at 1:21 PM, aerosport1 wrote: > > > > Finally after 3 months since my first flight I got my gear legs and > wheel pants painted and installed. I thought I would share these > photos and help > inspire everyone still banging rivets or working on the fiberglass > that it is worth every hour. Also included a picture of my panel > with my > AFS 4500 SV's. > > More photos available at http://combsfamily.phanpare.com > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying > 40033 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283424#283424 > > > Attachments: > > http://forums.matronics.com//files/img_0337_283.jpg > http://forums.matronics.com//files/img_0325_153.jpg > > ________________________________________________________________________________
Date: Jan 25, 2010
I used an entire can on my forward fuse. As many coats as I could get on until the can was empty. The stuff I used dried very fast so I sprayed all the coats in a short time. I also primed first with self etching primer. In testing, I found without the primer, the coating did not stick as well. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: "Jae Chang" <jc-matronics_rv10(at)jline.com> Sent: Monday, January 25, 2010 12:12 PM Subject: Re: Fake powder coat - Re: RV10-List: Windscreen install before panel? > > Haha, guilty as charged. I have those shows scheduled on the DVR. Just > goes to show you the power of television. My next build after the -10 is > going to be to a 450 Hemi powered, lifted, monster truck rock crawler > thing with FOOSE wheels! ;) > > I did pick up a can of the bedliner. After just 1 day of drying, it didn't > seem exceptionally durable per se. Also, with just 1 coat, I didn't > necessarily see the powder coat illusion. Will keep testing it. > > Jay > 40533 > > RV Builder (Michael Sausen) wrote: >> >> >> Sounds like you are a fan of the Powerblock. ;-) >> >> > > > ________________________________________________________________________________
Date: Jan 25, 2010
Beautiful job and great design. Do Not Arhcive > Subject: RV10-List: All dressed up > From: g.combs(at)aerosportmodeling.com > Date: Mon=2C 25 Jan 2010 13:21:43 -0800 > To: rv10-list(at)matronics.com > com> > > Finally after 3 months since my first flight I got my gear legs and wheel pants painted and installed. I thought I would share these photos and help > inspire everyone still banging rivets or working on the fiberglass that i t is worth every hour. Also included a picture of my panel with my > AFS 4500 SV's. > > More photos available at http://combsfamily.phanpare.com > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying > 40033 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283424#283424 > > > > > Attachments: > > http://forums.matronics.com//files/img_0337_283.jpg > http://forums.matronics.com//files/img_0325_153.jpg > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jan 26, 2010
Geoff, VERY NICE! Jim Combs (N312F) On Mon, Jan 25, 2010 at 4:21 PM, aerosport1 wrote: > g.combs(at)aerosportmodeling.com> > > Finally after 3 months since my first flight I got my gear legs and wheel > pants painted and installed. I thought I would share these photos and help > inspire everyone still banging rivets or working on the fiberglass that it > is worth every hour. Also included a picture of my panel with my > AFS 4500 SV's. > > More photos available at http://combsfamily.phanpare.com > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying > 40033 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283424#283424 > > > Attachments: > > http://forums.matronics.com//files/img_0337_283.jpg > http://forums.matronics.com//files/img_0325_153.jpg > > ________________________________________________________________________________
Date: Jan 26, 2010
Definitely inspired here - Really nice! Bill "finishing up a morning session in the shop" Watson aerosport1 wrote: > > Finally after 3 months since my first flight I got my gear legs and wheel pants painted and installed. I thought I would share these photos and help > inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my > AFS 4500 SV's. > > More photos available at http://combsfamily.phanpare.com > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying > 40033 > > > ________________________________________________________________________________
Date: Jan 26, 2010
So all the skin to doubler holes for the AN426 rivets get countersunk right through the skin also? This won't remove too much of the skin to let the rivet work properly? Bill -------------------------------------------------- From: "John Kirkland" <jskirkland(at)webpipe.net> Sent: Monday, January 25, 2010 1:19 PM Subject: RV10-List: Re: Another wing build question--wing walk doublers > > Countersink the skin and doubler, nothing gets dimpled. Use a piece of > scrap with a #8 dimple as a test piece to judge how much to countersink. > The test dimple needs to fit in the countersink, just like the fairing > will when you have the wings mounted. Otherwise, the fairing that covers > the gap between wing and fuselage will sit high. > > -------- > RV-10 #40333 > N540XP (reserved) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283401#283401 > > > > Checked by AVG - www.avg.com > 01:36:00 > ________________________________________________________________________________
Date: Jan 26, 2010
Correct...... There is nothing unique with countersinking these rivets as opposed to any that you've done previously. You do want to test the setting of your countersink cage on a piece of scrap first. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton Sent: Tuesday, January 26, 2010 12:19 PM Subject: Re: RV10-List: Re: Another wing build question--wing walk doublers So all the skin to doubler holes for the AN426 rivets get countersunk right through the skin also? This won't remove too much of the skin to let the rivet work properly? Bill -------------------------------------------------- From: "John Kirkland" <jskirkland(at)webpipe.net> Sent: Monday, January 25, 2010 1:19 PM Subject: RV10-List: Re: Another wing build question--wing walk doublers > > Countersink the skin and doubler, nothing gets dimpled. Use a piece of > scrap with a #8 dimple as a test piece to judge how much to countersink. > The test dimple needs to fit in the countersink, just like the fairing > will when you have the wings mounted. Otherwise, the fairing that covers > the gap between wing and fuselage will sit high. > > -------- > RV-10 #40333 > N540XP (reserved) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283401#283401 > > > > Checked by AVG - www.avg.com > 01:36:00 > ________________________________________________________________________________
Date: Jan 26, 2010
All I can say about your 10 is "NICE JOB".- All I can say about my plane is "it flies".--What I was told was that at altitude they'll look ident ical! Great job Geoff! - Don McDonald- --- On Mon, 1/25/10, aerosport1 wrote: From: aerosport1 <g.combs(at)aerosportmodeling.com> Subject: RV10-List: All dressed up Date: Monday, January 25, 2010, 1:21 PM m> Finally after 3 months since my first flight I got my gear legs and wheel p ants painted and installed. I thought I would share these photos and help inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my AFS 4500 SV's. More photos available at http://combsfamily.phanpare.com Geoff -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283424#283424 Attachments: http://forums.matronics.com//files/img_0337_283.jpg http://forums.matronics.com//files/img_0325_153.jpg le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Jan 26, 2010
When you countersink the skin it will take a little off the doubler but it will leave plenty on the skin for the rivet. Steve Stella 40654 Wings N521RV reserved -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton Sent: Tuesday, January 26, 2010 12:19 PM Subject: Re: RV10-List: Re: Another wing build question--wing walk doublers So all the skin to doubler holes for the AN426 rivets get countersunk right through the skin also? This won't remove too much of the skin to let the rivet work properly? Bill -------------------------------------------------- From: "John Kirkland" <jskirkland(at)webpipe.net> Sent: Monday, January 25, 2010 1:19 PM Subject: RV10-List: Re: Another wing build question--wing walk doublers > > Countersink the skin and doubler, nothing gets dimpled. Use a piece of > scrap with a #8 dimple as a test piece to judge how much to countersink. > The test dimple needs to fit in the countersink, just like the fairing > will when you have the wings mounted. Otherwise, the fairing that covers > the gap between wing and fuselage will sit high. > > -------- > RV-10 #40333 > N540XP (reserved) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=283401#283401 > > > > Checked by AVG - www.avg.com > 01:36:00 > ________________________________________________________________________________
Date: Jan 26, 2010
Subject: Help identify Lycoming hardware
http://picasaweb.google.com/lh/photo/wGhe7fWJwye94wS1XjFPNA?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink http://picasaweb.google.com/jchang10/DropBox?authkey=Gv1sRgCI7088GZlYCc2AE#5431122204574256322 Does anyone know what the intended purpose for this locknut is? It came with the lycoming engine in one of the hardware bags. It came in a count of 8. As far as i can tell, it is an Aluminum locknut. Never seen one of these before. Any ideas what its intended usage is for? Jae 40533 ________________________________________________________________________________
Date: Jan 26, 2010
Don Don't think you did not do a nice job on yours. Yours is as nice as a lot of them out there you should be very proud how it turned out. Just my 2 cents. John G. Cumins President JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Tuesday, January 26, 2010 10:25 AM Subject: Re: RV10-List: All dressed up All I can say about your 10 is "NICE JOB". All I can say about my plane is "it flies". What I was told was that at altitude they'll look identical! Great job Geoff! Don McDonald --- On Mon, 1/25/10, aerosport1 wrote: From: aerosport1 <g.combs(at)aerosportmodeling.com> Subject: RV10-List: All dressed up Date: Monday, January 25, 2010, 1:21 PM <http://us.mc537.mail.yahoo.com/mc/compose?to=g.combs@aerosportmodeling.com> > Finally after 3 months since my first flight I got my gear legs and wheel pants painted and installed. I thought I would share these photos and help inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my AFS 4500 SV's. More photos available at http://combsfamily.phanpare.com <http://combsfamily.phanpare.com/> Geoff -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283424#283424 Attachments: http://forums.matronics.com//files/img_0337_283.jpg <http://forums.matronics.com/files/img_0337_283.jpg> http://forums.matronics.com//files/======================= <http://forums.matronics.com/files/img_0325_153.jpg> ________________________________________________________________________________
Date: Jan 26, 2010
Thanks to all that replied. Also sorry for the "simple" question. I just wanted to be sure I was doing the right thing and not destroying the wing skins. Bill -------------------------------------------------- From: "Steve Stella" <Sstella(at)incisaledge.com> Sent: Tuesday, January 26, 2010 12:31 PM Subject: RE: RV10-List: Re: Another wing build question--wing walk doublers > > When you countersink the skin it will take a little off the doubler but it > will leave plenty on the skin for the rivet. > > Steve Stella > 40654 Wings > N521RV reserved > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami > Britton > Sent: Tuesday, January 26, 2010 12:19 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Another wing build question--wing walk > doublers > > > So all the skin to doubler holes for the AN426 rivets get countersunk > right > through the skin also? This won't remove too much of the skin to let the > rivet work properly? > > Bill > > -------------------------------------------------- > From: "John Kirkland" <jskirkland(at)webpipe.net> > Sent: Monday, January 25, 2010 1:19 PM > To: > Subject: RV10-List: Re: Another wing build question--wing walk doublers > >> >> Countersink the skin and doubler, nothing gets dimpled. Use a piece of >> scrap with a #8 dimple as a test piece to judge how much to countersink. >> The test dimple needs to fit in the countersink, just like the fairing >> will when you have the wings mounted. Otherwise, the fairing that covers >> the gap between wing and fuselage will sit high. >> >> -------- >> RV-10 #40333 >> N540XP (reserved) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=283401#283401 >> >> >> >> >> >> >> >> >> >> > > >> >> Checked by AVG - www.avg.com >> 01:36:00 >> > > > > Checked by AVG - www.avg.com > 01:46:00 > ________________________________________________________________________________
Date: Jan 26, 2010
Subject: Fuel Check Valve & Gascolator
I purchased an Andair fuel check valve (non return valve)and gascolator wit h my finishing kit, however I am yet to decide where to position both items .=0A=0AMy initial thought is to-install the check valve after (down strea m) the Floscan fuel flow transducer in the tunnel?=0A=0ACould anyone please tell me where the ideal placement for the check valve would be?=0A=0AFor t hose of you out there that have-installed a gascolator (I have the Andair version), could you please indicate where you positioned the gascolator on the firewall and the location of the drain line.=0A=0AAny pictures for eit her the fuel check valve or gascolator installations would be very much app reciated please.=0A=0AMany thanks in anticipation.-=0A=0AKind regards=0A =0APatrick Pulis=0A#40299-- (VH-XPP reserved)=0AAdelaide, South Austral ia-=0A=0A=0A _______________________________________________________ ___________________________=0ASee what's on at the movies in your area. Fin d out now: http://au.movies.yahoo.com/session-times/ ________________________________________________________________________________
Date: Jan 26, 2010
Ta da! Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis Sent: Tuesday, January 26, 2010 2:41 PM Subject: RV10-List: Fuel Check Valve & Gascolator I purchased an Andair fuel check valve (non return valve)and gascolator with my finishing kit, however I am yet to decide where to position both items. My initial thought is to install the check valve after (down stream) the Floscan fuel flow transducer in the tunnel? Could anyone please tell me where the ideal placement for the check valve would be? For those of you out there that have installed a gascolator (I have the Andair version), could you please indicate where you positioned the gascolator on the firewall and the location of the drain line. Any pictures for either the fuel check valve or gascolator installations would be very much appreciated please. Many thanks in anticipation. Kind regards Patrick Pulis #40299 (VH-XPP reserved) Adelaide, South Australia ________________________________ See what's on at the movies in your area. Find out now <http://au.rd.yahoo.com/movies/mailtagline/*http:/au.movies.yahoo.com/se ssion-times/> . ________________________________________________________________________________
Subject: Advanced Flight Systems AOA Pro Version
Date: Jan 27, 2010
Anybody else with a Pro version AOA have problems with the dimmer function? All else works O.K but can only see a faint display. Appreciate any suggestions or clues on this particular problem. John 40315 E-mail message checked by Spyware Doctor (7.0.0.514) Database version: 6.14220 http://www.pctools.com/en/spyware-doctor-antivirus/ ________________________________________________________________________________
Subject: Re: Advanced Flight Systems AOA Pro Version
Date: Jan 26, 2010
If it is always dim no matter what you do , the backlighting is bad. It'll have to go back. Ask me how I know? -Mike Kraus Sent from my iPhone On Jan 26, 2010, at 6:13 PM, "John Dunne" wrote: > Anybody else with a Pro version AOA have problems with the dimmer > function? > > All else works O.K but can only see a faint display. > > Appreciate any suggestions or clues on this particular problem. > > John 40315 > > > E-mail message checked by Spyware Doctor (7.0.0.514) > Database version: 6.14220 > http://www.pctools.com/spyware-doctor-antivirus/ > > ________________________________________________________________________________
Subject: AC Weight and Balance App
Date: Jan 26, 2010
Well, I got an Android phone right before Christmas and since it is an open architecture I decided to try and hack out a weight and balance app for the phone. After a lot of learning...I got it done. If you have the appropriate hardware, let me know what you think. It can be found in the Android market, under Applications, Tools. The name is AC Weight and Balance. If you sort by date, it will be at the top..for a little while at least. The main screen allows you to put in the front seat weight, rear seat weight, baggage weight and fuel weight. Show chart...shows chart Settings button leads you to the settings for both the graph and AC AC1 . AC4 - lets you create settings for 4 aircraft. If you hit the menu button, you will get two choices.Home and Empty CG Calc The Empty CG Calc gives you the ability to calc an empty CG based on wheel weights. If you hit the save button, it becomes the empty weight for that aircraft. I am not a software engineer..but I have stayed in a Holiday Inn before. Your mileage may vary. J Rene' N423CF -- Flying 801-721-6080 ________________________________________________________________________________
Date: Jan 26, 2010
Thanks John.... of course I'm proud.=C2- In some areas I am just REALLY p roud, and then in some others, just content. Don --- On Tue, 1/26/10, John Cumins wrote: From: John Cumins <jcumins(at)jcis.net> Subject: RE: RV10-List: All dressed up Date: Tuesday, January 26, 2010, 11:23 AM Don =C2- Don=99t think you did not do a nice job on yours.=C2- Yours is as n ice as a lot of them out there you should be very proud how it turned out. =C2- Just my 2 cents. =C2- John G. Cumins President =C2- JC'S Interactive Systems 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax =C2- Your Total Technology Solution Provider From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Don McDonald Sent: Tuesday, January 26, 2010 10:25 AM Subject: Re: RV10-List: All dressed up =C2- All I can say about your 10 is "NICE JOB".=C2- All I can say about my pla ne is "it flies".=C2-=C2-What I was told was that at altitude they'll l ook identical! Great job Geoff! =C2- Don McDonald=C2- --- On Mon, 1/25/10, aerosport1 wrote: From: aerosport1 <g.combs(at)aerosportmodeling.com> Subject: RV10-List: All dressed up Date: Monday, January 25, 2010, 1:21 PM m> Finally after 3 months since my first flight I got my gear legs and wheel p ants painted and installed. I thought I would share these photos and help inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my AFS 4500 SV's. More photos available at http://combsfamily.phanpare.com Geoff -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283424#283424 Attachments: http://forums.matronics.com//files/img_0337_283.jpg http://forums.matronics.com//files/============= =========== Navigator to much much href="http://www .matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10 -List Web href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =========== =C2- =0A=0A=0A ________________________________________________________________________________
Date: Jan 26, 2010
Geoff, I was particularly fascinated by this shot in your album. Because the leg fairings are not on you can visualize what the -10 would look like as a retract, or just in flight, straight & level at 12,500', maybe a little XM music in the background. Beautiful work on the 9GW. Looks better than certified to me. Robin http://combsfamily.phanfare.com/3161550_4830915#imageID=84783324 ________________________________________________________________________________
Subject: Re: Help identify Lycoming hardware
Date: Jan 26, 2010
I have twelve. I thought maybe for the exhaust but have not got that far yet. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: "Jae Chang" <jc-matronics_rv(at)jline.com> Sent: Tuesday, January 26, 2010 12:51 PM Subject: RV10-List: Help identify Lycoming hardware > > http://picasaweb.google.com/lh/photo/wGhe7fWJwye94wS1XjFPNA?authkey=Gv1sRgCI7088GZlYCc2AE&feat=directlink > http://picasaweb.google.com/jchang10/DropBox?authkey=Gv1sRgCI7088GZlYCc2AE#5431122204574256322 > > Does anyone know what the intended purpose for this locknut is? It came > with the lycoming engine in one of the hardware bags. It came in a count > of 8. As far as i can tell, it is an Aluminum locknut. Never seen one of > these before. > > Any ideas what its intended usage is for? > > Jae > 40533 > > > ________________________________________________________________________________
Date: Jan 26, 2010
Subject: Re: ceramic coating on exhaust
I ceramic coated the outside only on my exhaust and my heaters also crank o ut the heat when barely opened. =0AI have 650 hours on mine and it is hold ing up great. It does lose that original shine but has not cracked or peal ed. =0A=0APeople have mentioned that if you do have problems you cannot we ld it but I will cross that road if it happens. So far I have been very ha ppy. =0A=0AScott Schmidt=0Ascottmschmidt(at)yahoo.com=0A=0A=0A=0A=0A=0A_____ ___________________________=0AFrom: Robin Marks <robin1(at)mrmoisture.com>=0AT o: rv10-list(at)matronics.com=0ASent: Tue, January 26, 2010 10:39:09 PM=0ASubj ect: RE: RV10-List: ceramic coating on exhaust=0A=0A =0AChris,=0A Let=0Ame explain what I know and extract backwards.=0AI=0Ahave:=0A=C2=B7 Forsling double ceramic coated exhaust system.=0A=C2=B7 We ll documented heat issues (hot engine)=0A=C2=B7 S/S fire wall mount ed heater valves=0A=C2=B7 Dual Heat Muffs (one cut down by 25% to p roperly fit the exhaust=0Atube)=0A=C2=B7 Generally direct heating d uct paths=0A =0AUnlike=0Amost of the -10 fleet I am unable to get enough he at into my cabin. Tim and=0Aothers have noted that at HALF heat setting you can bake Brownies. Ok, ok maybe=0Anot that hot but comfortable enough to f ly in Wisconsin for gosh sakes. In my=0Aship with FULL heat and OAT =99s at about 30F I am uncomfortable with a=0AT-Shirt, long-sleeved shirt a nd a vest or beanie. For any length of flight I=0Ahave to bring gloves and a few times was shivering a bit. I do have a little=0Aleak in my cabin whe re the overhead console wraps around the door support=0Abracket but that is not the problem. I have a pretty tight seal overall. Not=0Anearly enough h eat is coming out of the heating system. I have checked=0Aconnections and t he function of the heater valves; all good. The only thing I can=0Aput my f inger on is that the double ceramic coating is doing what it=99s=0Aad vertised to do; send the heat out the bottom of the tube. I have seen a=0Ad emonstration of a hot Harley shut down and 15 seconds later you can grab th e=0Aexhaust. Don=99t try that with your car exhaust.=0AI=0Ahave also heard that some owners have been experiencing the coatings chipping=0Aor co ming off the surface of the pipes. Mine look good externally so far (120=0A hours) but who knows what they look like inside and who knows what it will look=0Alike or perform like at 820 hours. =0AI=0Areally didn=99t give the coating a second thought when ordering the pipes.=0AUpgrade, more powe r, =9CSURE, I=99ll Take Two!=9D The coatings may=0Anot be the problem but I am hard pressed to see what else it could be. Throw in =0Athe potential to degrade and I would be just as happy to save the $ and use=0Awhat has been on every other plane I have ever own or flown. Standard exhaust=0Atubing. =0A =0AA=0Anote of personal privilege. I know people can read into the written word many=0Adifferent things. I hate for some to tak e away that I am always complaining about=0Aeverything. Blah, blah James Co wl (and all it=99s ramifications), blah,=0Ablah Garmin, blah, blah LO P and my famous %#@*&$! Painter The whole=0Aprocess was a learning experience for me. Most issues are cleaned with just heat=0Aissues remaini ng. LOP flight has given me a path to rest my engine while I=0Afigure thing s out. I love the plane, love it=99s systems, I use it a=0Alot for w ork & pleasure and surprisingly have stopped dreaming of what I=0Awant next (ok, except for the 8A due to fly in 2010. Teehee). =0A =0ARobin =0A =0A =0AFrom:owner-rv10-list-server(at)matronics.com=0A[mailto:owner-rv10-l ist-server(at)matronics.com] On Behalf Of Chris=0AJohnston=0ASent: Tuesday, Ja nuary 26, 2010 6:49 PM=0ATo: rv10-list(at)matronics.com=0ASubject: Re: RV10-Li st: ceramic coating on exhaust=0A =0ANot to hijack, but why would you not c eramic coat the=0Aexhaust again? That became a standard issue item for me when I built=0Acars, and I expected to do the same for the airplane. What gives?=0A =0Acj=0A =0A =0AOn Jan 26, 2010, at 5:37 PM, Robin Marks wrote: =0A=0A=0ANo=0Amuffler. The exhaust is a Forsling exhaust with megaphone typ e collector area.=0ALooks great, sounds great. Mine happen to be ceramic co ated inside and out=0Awhich I would not do again.=0ABetter=0Aview of exhaus t. Photo attached.=0AThe=0Aheat muff is a standard heat muff cut down (slig htly) to fit a flat area of the=0Aexhaust on co-pilot side. Pilots side unt ouched as you can see from the photo.=0AIf=0Ayou want a muffler I think oth ers are using the Vetterman system. I have seen a=0Afew and they are beauti ful units too. Others can surely comment better than me=0Aon those systems. =0A =0AOf=0Anote as nice as these photos are, I am REALLY happy to be past this=0Astage and burning 100LL and not fingertips.=0A =0ARobin=0A =0A =0AFrom: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-s erver(at)matronics.com] On Behalf Of Marcus Cooper=0ASent: Tuesday, January 26 ,=0A2010 4:48 PM=0ATo: rv10-list(at)matronics.com=0ASubject: RE: RV10-List:=0A Fuel Check Valve & Gascolator=0A =0ARobin,=0A Real nice installation FWF! What muffler and=0Aheat muff are you using?=0A =0AMarcus=0A40286=0A =0ADo ====================== ________________________________________________________________________________
Subject: ceramic coating on exhaust
Date: Jan 27, 2010
U2NvdHQsIGNhbiB5b3UgdmVudHVyZSB0byBndWVzcyB3aGF04oCZcyB3cm9uZyB3aXRoIG15IHNl dHVwPw0KDQpCVFcgc29ycnkgSSBkaWRu4oCZdCBjYWxsIHdoaWxlIGF0IFN1bmRhbmNlLiBJdCBn b3QgYSBsaXR0bGUgY3JhenkuDQoNCiANCg0KUm9iaW4NCg0KIA0KDQpGcm9tOiBvd25lci1ydjEw LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBTY290dCBTY2htaWR0DQpTZW50OiBUdWVzZGF5 LCBKYW51YXJ5IDI2LCAyMDEwIDEwOjExIFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20N ClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IGNlcmFtaWMgY29hdGluZyBvbiBleGhhdXN0DQoNCiAN Cg0KSSBjZXJhbWljIGNvYXRlZCB0aGUgb3V0c2lkZSBvbmx5IG9uIG15IGV4aGF1c3QgYW5kIG15 IGhlYXRlcnMgYWxzbyBjcmFuayBvdXQgdGhlIGhlYXQgd2hlbiBiYXJlbHkgb3BlbmVkLiAgDQpJ IGhhdmUgNjUwIGhvdXJzIG9uIG1pbmUgYW5kIGl0IGlzIGhvbGRpbmcgdXAgZ3JlYXQuICBJdCBk b2VzIGxvc2UgdGhhdCBvcmlnaW5hbCBzaGluZSBidXQgaGFzIG5vdCBjcmFja2VkIG9yIHBlYWxl ZC4gIA0KDQpQZW9wbGUgaGF2ZSBtZW50aW9uZWQgdGhhdCBpZiB5b3UgZG8gaGF2ZSBwcm9ibGVt cyB5b3UgY2Fubm90IHdlbGQgaXQgYnV0IEkgd2lsbCBjcm9zcyB0aGF0IHJvYWQgaWYgaXQgaGFw cGVucy4gIFNvIGZhciBJIGhhdmUgYmVlbiB2ZXJ5IGhhcHB5LiAgIA0KDQogDQoNClNjb3R0IFNj aG1pZHQNCnNjb3R0bXNjaG1pZHRAeWFob28uY29tDQoNCiANCg0KIA0KDQpfX19fX19fX19fX19f X19fX19fX19fX19fX19fX19fXw0KDQpGcm9tOiBSb2JpbiBNYXJrcyA8cm9iaW4xQG1ybW9pc3R1 cmUuY29tPg0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTZW50OiBUdWUsIEphbnVhcnkg MjYsIDIwMTAgMTA6Mzk6MDkgUE0NClN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IGNlcmFtaWMgY29h dGluZyBvbiBleGhhdXN0DQoNCkNocmlzLA0KDQogICAgICAgICAgICBMZXQgbWUgZXhwbGFpbiB3 aGF0IEkga25vdyBhbmQgZXh0cmFjdCBiYWNrd2FyZHMuDQoNCkkgaGF2ZToNCg0KwrcgICAgICAg ICBGb3JzbGluZyBkb3VibGUgY2VyYW1pYyBjb2F0ZWQgZXhoYXVzdCBzeXN0ZW0uDQoNCsK3ICAg ICAgICAgV2VsbCBkb2N1bWVudGVkIGhlYXQgaXNzdWVzIChob3QgZW5naW5lKQ0KDQrCtyAgICAg ICAgIFMvUyBmaXJlIHdhbGwgbW91bnRlZCBoZWF0ZXIgdmFsdmVzDQoNCsK3ICAgICAgICAgRHVh bCBIZWF0IE11ZmZzIChvbmUgY3V0IGRvd24gYnkgMjUlIHRvIHByb3Blcmx5IGZpdCB0aGUgZXho YXVzdCB0dWJlKQ0KDQrCtyAgICAgICAgIEdlbmVyYWxseSBkaXJlY3QgaGVhdGluZyBkdWN0IHBh dGhzDQoNCiANCg0KVW5saWtlIG1vc3Qgb2YgdGhlIC0xMCBmbGVldCBJIGFtIHVuYWJsZSB0byBn ZXQgZW5vdWdoIGhlYXQgaW50byBteSBjYWJpbi4gVGltIGFuZCBvdGhlcnMgaGF2ZSBub3RlZCB0 aGF0IGF0IEhBTEYgaGVhdCBzZXR0aW5nIHlvdSBjYW4gYmFrZSBCcm93bmllcy4gT2ssIG9rIG1h eWJlIG5vdCB0aGF0IGhvdCBidXQgY29tZm9ydGFibGUgZW5vdWdoIHRvIGZseSBpbiBXaXNjb25z aW4gZm9yIGdvc2ggc2FrZXMuIEluIG15IHNoaXAgd2l0aCBGVUxMIGhlYXQgYW5kIE9BVOKAmXMg YXQgYWJvdXQgMzBGIEkgYW0gdW5jb21mb3J0YWJsZSB3aXRoIGEgVC1TaGlydCwgbG9uZy1zbGVl dmVkIHNoaXJ0IGFuZCBhIHZlc3Qgb3IgYmVhbmllLiBGb3IgYW55IGxlbmd0aCBvZiBmbGlnaHQg SSBoYXZlIHRvIGJyaW5nIGdsb3ZlcyBhbmQgYSBmZXcgdGltZXMgd2FzIHNoaXZlcmluZyBhIGJp dC4gIEkgZG8gaGF2ZSBhIGxpdHRsZSBsZWFrIGluIG15IGNhYmluIHdoZXJlIHRoZSBvdmVyaGVh ZCBjb25zb2xlIHdyYXBzIGFyb3VuZCB0aGUgZG9vciBzdXBwb3J0IGJyYWNrZXQgYnV0IHRoYXQg aXMgbm90IHRoZSBwcm9ibGVtLiBJIGhhdmUgYSBwcmV0dHkgdGlnaHQgc2VhbCBvdmVyYWxsLiBO b3QgbmVhcmx5IGVub3VnaCBoZWF0IGlzIGNvbWluZyBvdXQgb2YgdGhlIGhlYXRpbmcgc3lzdGVt LiBJIGhhdmUgY2hlY2tlZCBjb25uZWN0aW9ucyBhbmQgdGhlIGZ1bmN0aW9uIG9mIHRoZSBoZWF0 ZXIgdmFsdmVzOyBhbGwgZ29vZC4gVGhlIG9ubHkgdGhpbmcgSSBjYW4gcHV0IG15IGZpbmdlciBv biBpcyB0aGF0IHRoZSBkb3VibGUgY2VyYW1pYyBjb2F0aW5nIGlzIGRvaW5nIHdoYXQgaXTigJlz IGFkdmVydGlzZWQgdG8gZG87IHNlbmQgdGhlIGhlYXQgb3V0IHRoZSBib3R0b20gb2YgdGhlIHR1 YmUuIEkgaGF2ZSBzZWVuIGEgZGVtb25zdHJhdGlvbiBvZiBhIGhvdCBIYXJsZXkgc2h1dCBkb3du IGFuZCAxNSBzZWNvbmRzIGxhdGVyIHlvdSBjYW4gZ3JhYiB0aGUgZXhoYXVzdC4gRG9u4oCZdCB0 cnkgdGhhdCB3aXRoIHlvdXIgY2FyIGV4aGF1c3QuDQoNCkkgaGF2ZSBhbHNvIGhlYXJkIHRoYXQg c29tZSBvd25lcnMgaGF2ZSBiZWVuIGV4cGVyaWVuY2luZyB0aGUgY29hdGluZ3MgY2hpcHBpbmcg b3IgY29taW5nIG9mZiB0aGUgc3VyZmFjZSBvZiB0aGUgcGlwZXMuIE1pbmUgbG9vayBnb29kIGV4 dGVybmFsbHkgc28gZmFyICgxMjAgaG91cnMpIGJ1dCB3aG8ga25vd3Mgd2hhdCB0aGV5IGxvb2sg bGlrZSBpbnNpZGUgYW5kIHdobyBrbm93cyB3aGF0IGl0IHdpbGwgbG9vayBsaWtlIG9yIHBlcmZv cm0gbGlrZSBhdCA4MjAgaG91cnMuIA0KDQpJIHJlYWxseSBkaWRu4oCZdCBnaXZlIHRoZSBjb2F0 aW5nIGEgc2Vjb25kIHRob3VnaHQgd2hlbiBvcmRlcmluZyB0aGUgcGlwZXMuIFVwZ3JhZGUsIG1v cmUgcG93ZXIsIOKAnFNVUkUsIEnigJlsbCBUYWtlIFR3byHigJ0gVGhlIGNvYXRpbmdzIG1heSBu b3QgYmUgdGhlIHByb2JsZW0gYnV0IEkgYW0gaGFyZCBwcmVzc2VkIHRvIHNlZSB3aGF0IGVsc2Ug aXQgY291bGQgYmUuIFRocm93IGluIHRoZSBwb3RlbnRpYWwgdG8gZGVncmFkZSBhbmQgSSB3b3Vs ZCBiZSBqdXN0IGFzIGhhcHB5IHRvIHNhdmUgdGhlICQgYW5kIHVzZSB3aGF0IGhhcyBiZWVuIG9u IGV2ZXJ5IG90aGVyIHBsYW5lIEkgaGF2ZSBldmVyIG93biBvciBmbG93bi4gU3RhbmRhcmQgZXho YXVzdCB0dWJpbmcuIA0KDQogDQoNCkEgbm90ZSBvZiBwZXJzb25hbCBwcml2aWxlZ2UuIEkga25v dyBwZW9wbGUgY2FuIHJlYWQgaW50byB0aGUgd3JpdHRlbiB3b3JkIG1hbnkgZGlmZmVyZW50IHRo aW5ncy4gSSBoYXRlIGZvciBzb21lIHRvIHRha2UgYXdheSB0aGF0IEkgYW0gYWx3YXlzIGNvbXBs YWluaW5nIGFib3V0IGV2ZXJ5dGhpbmcuIEJsYWgsIGJsYWggSmFtZXMgQ293bCAoYW5kIGFsbCBp dOKAmXMgcmFtaWZpY2F0aW9ucyksIGJsYWgsIGJsYWggR2FybWluLCBibGFoLCBibGFoIExPUCBh bmQgbXkgZmFtb3VzICUjQComJCEgUGFpbnRlcuKApiBUaGUgd2hvbGUgcHJvY2VzcyB3YXMgYSBs ZWFybmluZyBleHBlcmllbmNlIGZvciBtZS4gTW9zdCBpc3N1ZXMgYXJlIGNsZWFuZWQgd2l0aCBq dXN0IGhlYXQgaXNzdWVzIHJlbWFpbmluZy4gTE9QIGZsaWdodCBoYXMgZ2l2ZW4gbWUgYSBwYXRo IHRvIHJlc3QgbXkgZW5naW5lIHdoaWxlIEkgZmlndXJlIHRoaW5ncyBvdXQuICBJIGxvdmUgdGhl IHBsYW5lLCBsb3ZlIGl04oCZcyBzeXN0ZW1zLCBJIHVzZSBpdCBhIGxvdCBmb3Igd29yayAmIHBs ZWFzdXJlIGFuZCBzdXJwcmlzaW5nbHkgaGF2ZSBzdG9wcGVkIGRyZWFtaW5nIG9mIHdoYXQgSSB3 YW50IG5leHTigKYgKG9rLCBleGNlcHQgZm9yIHRoZSA4QSBkdWUgdG8gZmx5IGluIDIwMTAuIFRl ZWhlZSkuIA0KDQogDQoNClJvYmluDQoNCiANCg0KIA0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJv bmljcy5jb21dIE9uIEJlaGFsZiBPZiBDaHJpcyBKb2huc3Rvbg0KU2VudDogVHVlc2RheSwgSmFu dWFyeSAyNiwgMjAxMCA2OjQ5IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1Ympl Y3Q6IFJlOiBSVjEwLUxpc3Q6IGNlcmFtaWMgY29hdGluZyBvbiBleGhhdXN0DQoNCiANCg0KTm90 IHRvIGhpamFjaywgYnV0IHdoeSB3b3VsZCB5b3Ugbm90IGNlcmFtaWMgY29hdCB0aGUgZXhoYXVz dCBhZ2Fpbj8gIFRoYXQgYmVjYW1lIGEgc3RhbmRhcmQgaXNzdWUgaXRlbSBmb3IgbWUgd2hlbiBJ IGJ1aWx0IGNhcnMsIGFuZCBJIGV4cGVjdGVkIHRvIGRvIHRoZSBzYW1lIGZvciB0aGUgYWlycGxh bmUuICBXaGF0IGdpdmVzPw0KDQogDQoNCmNqDQoNCiANCg0KIA0KDQpPbiBKYW4gMjYsIDIwMTAs IGF0IDU6MzcgUE0sIFJvYmluIE1hcmtzIHdyb3RlOg0KDQogDQoNCk5vIG11ZmZsZXIuIFRoZSBl eGhhdXN0IGlzIGEgRm9yc2xpbmcgZXhoYXVzdCB3aXRoIG1lZ2FwaG9uZSB0eXBlIGNvbGxlY3Rv ciBhcmVhLiBMb29rcyBncmVhdCwgc291bmRzIGdyZWF0LiBNaW5lIGhhcHBlbiB0byBiZSBjZXJh bWljIGNvYXRlZCBpbnNpZGUgYW5kIG91dCB3aGljaCBJIHdvdWxkIG5vdCBkbyBhZ2Fpbi4NCg0K QmV0dGVyIHZpZXcgb2YgZXhoYXVzdC4gUGhvdG8gYXR0YWNoZWQuDQoNClRoZSBoZWF0IG11ZmYg aXMgYSBzdGFuZGFyZCBoZWF0IG11ZmYgY3V0IGRvd24gKHNsaWdodGx5KSB0byBmaXQgYSBmbGF0 IGFyZWEgb2YgdGhlIGV4aGF1c3Qgb24gY28tcGlsb3Qgc2lkZS4gUGlsb3RzIHNpZGUgdW50b3Vj aGVkIGFzIHlvdSBjYW4gc2VlIGZyb20gdGhlIHBob3RvLg0KDQpJZiB5b3Ugd2FudCBhIG11ZmZs ZXIgSSB0aGluayBvdGhlcnMgYXJlIHVzaW5nIHRoZSBWZXR0ZXJtYW4gc3lzdGVtLiBJIGhhdmUg c2VlbiBhIGZldyBhbmQgdGhleSBhcmUgYmVhdXRpZnVsIHVuaXRzIHRvby4gT3RoZXJzIGNhbiBz dXJlbHkgY29tbWVudCBiZXR0ZXIgdGhhbiBtZSBvbiB0aG9zZSBzeXN0ZW1zLg0KDQogDQoNCk9m IG5vdGXigKYgYXMgbmljZSBhcyB0aGVzZSBwaG90b3MgYXJlLCBJIGFtIFJFQUxMWSBoYXBweSB0 byBiZSBwYXN0IHRoaXMgc3RhZ2UgYW5kIGJ1cm5pbmcgMTAwTEwgYW5kIG5vdCBmaW5nZXJ0aXBz Lg0KDQogDQoNClJvYmluDQoNCiANCg0KIA0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b21dIE9uIEJlaGFsZiBPZiBNYXJjdXMgQ29vcGVyDQpTZW50OiBUdWVzZGF5LCBKYW51YXJ5IDI2 LCAyMDEwIDQ6NDggUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6 IFJWMTAtTGlzdDogRnVlbCBDaGVjayBWYWx2ZSAmIEdhc2NvbGF0b3INCg0KIA0KDQpSb2JpbiwN Cg0KICAgUmVhbCBuaWNlIGluc3RhbGxhdGlvbiBGV0YhICBXaGF0IG11ZmZsZXIgYW5kIGhlYXQg bXVmZiBhcmUgeW91IHVzaW5nPw0KDQogDQoNCk1hcmN1cw0KDQo0MDI4Ng0KDQogDQoNCkRvIG5v dCBhcmNoaXZlDQoNCiAgDQpodHRwOi8vZm89PT09PSA8aHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tPiANCiAgPGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbT4gDQoNCiANCg0KIA0KIA0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0 aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJj aGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhv dG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5t YXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAg ICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBh bHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3Qg Q29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3Vz IHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUs IExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCiANCg= ________________________________________________________________________________
Date: Jan 27, 2010
James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not > have ceramic coating on my exhaust. Just another data point. > > > Gary Specketer > ________________________________________________________________________________
Date: Jan 27, 2010
Mine has been working perfectly for more than a year. Nice and bright in daylight, and the dim button works as advertised at night. My only complaint is that I have not figured out how to lower the volume on the voice alerts from the AOA. It's way too loud for me. David Maib 40559 flying On Jan 26, 2010, at 6:13 PM, John Dunne wrote: Anybody else with a Pro version AOA have problems with the dimmer function? All else works O.K but can only see a faint display. Appreciate any suggestions or clues on this particular problem. John 40315 E-mail message checked by Spyware Doctor (7.0.0.514) Database version: 6.14220 http://www.pctools.com/spyware-doctor-antivirus/ ________________________________________________________________________________
Date: Jan 27, 2010
I have a modified Van's cowl and regular baffling. I bought this engine used and it had the cold air induction. I have not done any scientific or side by side tests to tell if I get more power. I know they get more power on the dyno at Barrett than a standard set up. Fuel economy is a direct function of power produced. At full power I suspect I burn more because of the increased horsepower, but at cruse it should be the same. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 9:15 AM Subject: Re: RV10-List: ceramic coating on exhaust James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall.- I get plenty of cabin heat.- I do not > have ceramic coating on my exhaust.- Just another data point. > > > Gary Specketer > ________________________________________________________________________________
Date: Jan 27, 2010
When it yells "angle, angle, push, push", my wife says that it is obscene. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Maib Sent: Wednesday, January 27, 2010 9:33 AM Subject: Re: RV10-List: Advanced Flight Systems AOA Pro Version Mine has been working perfectly for more than a year. Nice and bright in daylight, and the dim button works as advertised at night. My only complaint is that I have not figured out how to lower the volume on the voice alerts from the AOA. It's way too loud for me. David Maib 40559 flying On Jan 26, 2010, at 6:13 PM, John Dunne wrote: Anybody else with a Pro version AOA have problems with the dimmer function? All else works O.K but can only see a faint display. Appreciate any suggestions or clues on this particular problem. John 40315 E-mail message checked by Spyware Doctor (7.0.0.514) Database version: 6.14220 http://www.pctools.com/spyware-doctor-antivirus/ <http://www.pctools.com/en/spyware-doctor-antivirus/> style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?RV10-List blue; text-decoration: underline; ">http://forums.matronics.com style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 27, 2010
The cold air system adds 15-20 additional hp to the engine, so a stock compression 540 with cold air should run in the 275-280 range. Gary is correct regarding fuel burn. Fuel burn should increase to 26 gallons/hour at full power. With 9:1 compression, we see around 290-290 hp and up to around 300 hp with 10:1 compression. These are verified hp numbers based on years of testing 540s with various compression/sump set ups. We don't encourage RV-10 drivers to go 10:1, due to reliability and TBO issues. It might interest you to know that Red Bull pilots run 10:1 max in their race engines. Rhonda Barrett-Bewley Barrett Precision Engines, Inc. 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Wednesday, January 27, 2010 8:36 AM Subject: RE: RV10-List: ceramic coating on exhaust I have a modified Van's cowl and regular baffling. I bought this engine used and it had the cold air induction. I have not done any scientific or side by side tests to tell if I get more power. I know they get more power on the dyno at Barrett than a standard set up. Fuel economy is a direct function of power produced. At full power I suspect I burn more because of the increased horsepower, but at cruse it should be the same. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 9:15 AM Subject: Re: RV10-List: ceramic coating on exhaust James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not > have ceramic coating on my exhaust. Just another data point. > > > Gary Specketer > ________________________________________________________________________________
Date: Jan 27, 2010
Kelly, You may want to take a look at Rod Bower's site (http://www.ramairforhomebuilts.com/) . Not only does he have a nice ram/alternate air solution, he also has a bottom scoop that will fit on a standard cowl. He now has products for both horizontal and vertical sumps. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 9:15 AM Subject: Re: RV10-List: ceramic coating on exhaust James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not > have ceramic coating on my exhaust. Just another data point. > > > Gary Specketer > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jan 27, 2010
Vetterman is now making an exhaust that will work with the Cold Air setup and it's basically the same price as the Forsling. However where the Forsling is "tuned" (equal length pipes) the Vetterman is not. Again, well known theoretical and proven performance increase from equal length pies. I went with the Vetterman because I was concerned about the heat output of the Forsling for cabin heat but that sounds like it's not really an issue as long as you don't ceramic coat or at least mask the muff area off. I also went with the James cowl, but again, it was before Gary and others with the experience in fiberglass had paved the way for modifying the original. I have also heard that once you ceramic coat you cannot weld a pipe. Something about it getting into the pores of the SS and how it blocks heat transfer during the welding process can cause a porous and weak weld. Of course the real advantage to ceramic coating is that it should keep the heat contained in the pipe which increases exhaust velocity and scavenging but I don't think it really helps much with our old big block engines and in some cases it seems it can hurt. If I was to do it today I would: - Barrett Cold Air - Stock cowl - Baffles - Uncoated Forsling exhaust My $0.002 Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 8:15 AM Subject: Re: RV10-List: ceramic coating on exhaust James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not > have ceramic coating on my exhaust. Just another data point. > > > Gary Specketer > ________________________________________________________________________________
Date: Jan 27, 2010
Thanks Rhonda. Answers my questions. Seems if we are to believe the stories of 100LL demise, anything over stock compression might have issues. Rhonda Bewley wrote: > > The cold air system adds 15-20 additional hp to the engine, so a stock compression 540 with cold air should run in the 275-280 range. Gary is correct regarding fuel burn. Fuel burn should increase to 26 gallons/hour at full power. > > With 9:1 compression, we see around 290-290 hp and up to around 300 hp with 10:1 compression. These are verified hp numbers based on years of testing 540s with various compression/sump set ups. We don't encourage RV-10 drivers to go 10:1, due to reliability and TBO issues. It might interest you to know that Red Bull pilots run 10:1 max in their race engines. > > Rhonda Barrett-Bewley > Barrett Precision Engines, Inc. > 2870-B N. Sheridan Rd. > Tulsa, OK 74115 > (918) 835-1089 phone > (918) 835-1754 fax > www.barrettprecisionengines.com > ________________________________________________________________________________
Date: Jan 27, 2010
If you believe . . . . :D Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 9:17 AM Subject: Re: RV10-List: ceramic coating on exhaust Thanks Rhonda. Answers my questions. Seems if we are to believe the stories of 100LL demise, anything over stock compression might have issues. Rhonda Bewley wrote: > > The cold air system adds 15-20 additional hp to the engine, so a stock compression 540 with cold air should run in the 275-280 range. Gary is correct regarding fuel burn. Fuel burn should increase to 26 gallons/hour at full power. > > With 9:1 compression, we see around 290-290 hp and up to around 300 hp with 10:1 compression. These are verified hp numbers based on years of testing 540s with various compression/sump set ups. We don't encourage RV-10 drivers to go 10:1, due to reliability and TBO issues. It might interest you to know that Red Bull pilots run 10:1 max in their race engines. > > Rhonda Barrett-Bewley > Barrett Precision Engines, Inc. > 2870-B N. Sheridan Rd. > Tulsa, OK 74115 > (918) 835-1089 phone > (918) 835-1754 fax > www.barrettprecisionengines.com > ________________________________________________________________________________
Date: Jan 27, 2010
We have been coating the exterior of intake pipes and exhaust for this year's RB engines we are building. One of the biggest problems with ceramic coating is the quality of the application. We would never do the inside of intake pipes because if it did chip off, it would go directly to the valves. Not a good situation. The guy I'm using to do my coating said that you have to grind off the coating to reweld. We asked, because we do have to reweld intake pipes on the cold air occasionally. You can always wrap your exhaust to try and get the same effect on the scavenging. Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Wednesday, January 27, 2010 9:17 AM Subject: RE: RV10-List: ceramic coating on exhaust Vetterman is now making an exhaust that will work with the Cold Air setup and it's basically the same price as the Forsling. However where the Forsling is "tuned" (equal length pipes) the Vetterman is not. Again, well known theoretical and proven performance increase from equal length pies. I went with the Vetterman because I was concerned about the heat output of the Forsling for cabin heat but that sounds like it's not really an issue as long as you don't ceramic coat or at least mask the muff area off. I also went with the James cowl, but again, it was before Gary and others with the experience in fiberglass had paved the way for modifying the original. I have also heard that once you ceramic coat you cannot weld a pipe. Something about it getting into the pores of the SS and how it blocks heat transfer during the welding process can cause a porous and weak weld. Of course the real advantage to ceramic coating is that it should keep the heat contained in the pipe which increases exhaust velocity and scavenging but I don't think it really helps much with our old big block engines and in some cases it seems it can hurt. If I was to do it today I would: - Barrett Cold Air - Stock cowl - Baffles - Uncoated Forsling exhaust My $0.002 Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, January 27, 2010 8:15 AM Subject: Re: RV10-List: ceramic coating on exhaust James cowl or Vans? Is there a real difference in power or economy with the cold air induction and/or Forsling exhaust? I understand the theoretical for the cold air induction, and if the exhaust is better tuned, etc. Just wondering if the final result is more speed, more climb and/or better fuel economy, so I can sugar coat the $$ expenditure. On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > I have the same setup as Robin, Barrett cold air induction, Forsling > exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not > have ceramic coating on my exhaust. Just another data point. > > > Gary Specketer > ________________________________________________________________________________
Subject: Re: AC Weight and Balance App
Date: Jan 27, 2010
neat, wished someone would do this for iPhone. lbb -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283654#283654 ________________________________________________________________________________
Date: Jan 27, 2010
IMO, the power increase from Cold Air is very real (so is the fuel consumption @ WOT). Any performance increases from the James cowl & plenum are unrecognizable Tuned Forsling exhaust ceramic coated inside and out is less rediated heat in the lower cowl and better scavenging. I took one of my heat muffs off and only have heat supplied to 1/2 of the cabin. The coolest OAT's I've flown in were 0 degs C. And we had no problem keeping the cabin cozy, even had to reduce the valve somewhat. Deems Davis N519PJ www.deemsrv10.com On 1/27/2010 7:15 AM, Kelly McMullen wrote: > --> RV10-List message posted by: Kelly McMullen > > James cowl or Vans? > Is there a real difference in power or economy with the cold air > induction and/or Forsling exhaust? I understand the theoretical for > the cold air induction, and if the exhaust is better tuned, etc. Just > wondering if the final result is more speed, more climb and/or better > fuel economy, so I can sugar coat the $$ expenditure. > > On Wed, Jan 27, 2010 at 6:45 AM, gary wrote: > >> I have the same setup as Robin, Barrett cold air induction, Forsling >> exhaust, and oil cooler on firewall. I get plenty of cabin heat. I do not >> have ceramic coating on my exhaust. Just another data point. >> >> >> >> Gary Specketer >> >> > > > ________________________________________________________________________________
Subject: OT - I want one - Apple iPad
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Jan 27, 2010
Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=283666#283666 ________________________________________________________________________________
Date: Jan 27, 2010
Subject: Re: OT - I want one - Apple iPad
On 01/27/2010 02:54 PM, jkreidler wrote: > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creation-event/?sort=newest&refresh=30> has some pics and details of the presentation. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Jan 27, 2010
Once the apps get written for this product I can see some real use in the c ockpit. So far I've been underwhelmed by what's out there. This may be diff erent. Gonna hold out until April until the better unit is released. Go to www.apple.com and watch the movie about it. pretty cool. Dan > Date: Wed=2C 27 Jan 2010 15:05:46 -0500 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: OT - I want one - Apple iPad > From: deej(at)deej.net > > > On 01/27/2010 02:54 PM=2C jkreidler wrote: t.com> > > > > Looks like Apple just released the iPad... Starts at $499=2C 1.5 lbs =2C 1/2" thick. > > > <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creat ion-event/?sort=newest&refresh=30> > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > =========== =========== =========== =========== > > > _________________________________________________________________ Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. ________________________________________________________________________________
Date: Jan 27, 2010
perfect size for a electronic flight bag... approach plates will look great on it On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill wrote: > > On 01/27/2010 02:54 PM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" > thick. > > > < > http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creation-event/?sort=newest&refresh=30 > > > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > > ________________________________________________________________________________
Date: Jan 28, 2010
Looks beautiful. But is there a GPS in it or not? What's a 'Digital compass' and 'Assisted GPS (Wi-Fi + 3G model)'?? (per their Tech Spec) EMNTK Cheers, Ron VH-XRM, flying in Oz _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday, 28 January 2010 7:41 AM Subject: RE: RV10-List: OT - I want one - Apple iPad Once the apps get written for this product I can see some real use in the cockpit. So far I've been underwhelmed by what's out there. This may be different. Gonna hold out until April until the better unit is released. Go to www.apple.com and watch the movie about it. pretty cool. Dan > Date: Wed, 27 Jan 2010 15:05:46 -0500 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: OT - I want one - Apple iPad > From: deej(at)deej.net > > > On 01/27/2010 02:54 PM, jkreidler wrote: > > > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. > > > <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creation -event/?sort=newest&refresh=30> > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman > > > _____ Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign ________________________________________________________________________________
Date: Jan 27, 2010
Me, too. This is a huge winner to me. I always thought if only the iphone and itouch screens coud be bigger, then you could actually so much more with it, like actually use your whole hand for touch interaction, see an entire news web page, chart, etc. etc. They rewrote those basic apps to take advantage of the entire screen real estate, instead of hacking it. Yeah, just like with the iphone, it'll be a matter of time before apps will be available for any purpose. jae 40533 Danny Riggs wrote: > Once the apps get written for this product I can see some real use in > the cockpit. So far I've been underwhelmed by what's out there. This > may be different. Gonna hold out until April until the better unit is > released. Go to www.apple.com and watch the movie about it. pretty > cool. Dan > * > * ________________________________________________________________________________
Date: Jan 27, 2010
perfect for ForeFlight On Jan 27, 2010, at 1:04 PM, John Trollinger wrote: > perfect size for a electronic flight bag... approach plates will > look great on it > > On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill wrote: > > On 01/27/2010 02:54 PM, jkreidler wrote: > > > > > > Looks like Apple just released the iPad... Starts at $499, 1.5 > lbs, 1/2" thick. > > > <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creation-event/?sort=newest&refresh=30 > > > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/ > sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Jan 27, 2010
Garmin just passed out barf bags to their aviation employees....... I can't wait for a USB connected XM & GPS antenna combo... Bye-bye 696's.... Approach plates, weather, music, movies, GPS, manuals, charts, etc.... We might be getting close to the holy grail.... From: John Trollinger [mailto:john(at)trollingers.com] Sent: Wednesday, January 27, 2010 3:04 PM Subject: Re: RV10-List: OT - I want one - Apple iPad perfect size for a electronic flight bag... approach plates will look great on it On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill wrote: On 01/27/2010 02:54 PM, jkreidler wrote: > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-crea tion-event/?sort=newest&refresh=30> has some pics and details of the presentation. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 27, 2010
Digital compass = magnetometer probably enhanced with GPS info AGPS=GPS that uses wifi or cellular to acquire a faster location lock Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Ron McGann Sent: Wednesday, January 27, 2010 3:08 PM Subject: RE: RV10-List: OT - I want one - Apple iPad Looks beautiful. But is there a GPS in it or not? What's a 'Digital compa ss' and 'Assisted GPS (Wi-Fi + 3G model)'?? (per their Tech Spec) EMNTK Cheers, Ron VH-XRM, flying in Oz ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Danny Riggs Sent: Thursday, 28 January 2010 7:41 AM Subject: RE: RV10-List: OT - I want one - Apple iPad Once the apps get written for this product I can see some real use in the c ockpit. So far I've been underwhelmed by what's out there. This may be diff erent. Gonna hold out until April until the better unit is released. Go to www.apple.com and watch the movie about it. pretty cool. Dan > Date: Wed, 27 Jan 2010 15:05:46 -0500 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: OT - I want one - Apple iPad > From: deej(at)deej.net > > > On 01/27/2010 02:54 PM, jkreidler wrote: t.com> > > > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2 " thick. > > > <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creat ion-event/?sort=newest&refresh=30> > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Grumman > > ________________________________ Your E-mail and More On-the-Go. Get Windows Live Hotmail target="_new">Si gn up now. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jan 27, 2010
The iPad does have BT so who needs a cable. Just because a BT device has b atteries, it doesn't mean you can't hardwire it to power. ;-) Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Perry, Phil Sent: Wednesday, January 27, 2010 3:34 PM Subject: RE: RV10-List: OT - I want one - Apple iPad Garmin just passed out barf bags to their aviation employees....... I can't wait for a USB connected XM & GPS antenna combo... Bye-bye 696's.... Approach plates, weather, music, movies, GPS, manuals, charts, etc.... We might be getting close to the holy grail.... From: John Trollinger [mailto:john(at)trollingers.com] Sent: Wednesday, January 27, 2010 3:04 PM Subject: Re: RV10-List: OT - I want one - Apple iPad perfect size for a electronic flight bag... approach plates will look great on it On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill > wrote: .net>> On 01/27/2010 02:54 PM, jkreidler wrote: com> > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creatio n-event/?sort=newest&refresh=30> has some pics and details of the presentation. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jan 27, 2010
I really like the way you think.................... From: RV Builder (Michael Sausen) [mailto:rvbuilder(at)sausen.net] Sent: Wednesday, January 27, 2010 3:57 PM Subject: RE: RV10-List: OT - I want one - Apple iPad The iPad does have BT so who needs a cable. Just because a BT device has batteries, it doesn't mean you can't hardwire it to power. ;-) Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Wednesday, January 27, 2010 3:34 PM Subject: RE: RV10-List: OT - I want one - Apple iPad Garmin just passed out barf bags to their aviation employees....... I can't wait for a USB connected XM & GPS antenna combo... Bye-bye 696's.... Approach plates, weather, music, movies, GPS, manuals, charts, etc.... We might be getting close to the holy grail.... From: John Trollinger [mailto:john(at)trollingers.com] Sent: Wednesday, January 27, 2010 3:04 PM Subject: Re: RV10-List: OT - I want one - Apple iPad perfect size for a electronic flight bag... approach plates will look great on it On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill wrote: On 01/27/2010 02:54 PM, jkreidler wrote: > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-crea tion-event/?sort=newest&refresh=30> has some pics and details of the presentation. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ; - The RV10-List Email Forum -http://www.matronics.=============== < Same great content also available via the Web Forums! href="http://forums.matronics.com">http://forums.matronics.comhttp://www.matronics . com/con ________________________________________________________________________________
Date: Jan 27, 2010
I'm not sure you need XM if you use ForeFlight On Jan 27, 2010, at 1:33 PM, Perry, Phil wrote: > Garmin just passed out barf bags to their aviation employees=85=85. > > I can=92t wait for a USB connected XM & GPS antenna combo=85 > > Bye-bye 696=92s=85. > > Approach plates, weather, music, movies, GPS, manuals, charts, > etc=85. We might be getting close to the holy grail=85. > > > From: John Trollinger [mailto:john(at)trollingers.com] > Sent: Wednesday, January 27, 2010 3:04 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: OT - I want one - Apple iPad > > perfect size for a electronic flight bag... approach plates will > look great on it > > On Wed, Jan 27, 2010 at 3:05 PM, Dj Merrill wrote: > > On 01/27/2010 02:54 PM, jkreidler wrote: > > > > > Looks like Apple just released the iPad... Starts at $499, 1.5 > lbs, 1/2" thick. > > > <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creati on-event/?sort=newest&refresh=30 > > > > has some pics and details of the presentation. > > -Dj > > -- > Dj Merrill - N1JOV > Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/ > sportsman/ > Grumman Yankee Driver N9870L - http://deej.net/yankee/ > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jan 27, 2010
Yep, or just go to Apple's site. The really nice deal is the 250MB of AT&T 3G for 14.99 a month or unlimited for $29. This looks to be the making of a nice little flight bag addition. Although the name absolutely sucks, anyone else see the MadTV skit a couple years back for the iPad. LMAO. http://www.youtube.com/watch?v=lsjU0K8QPhs Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Wednesday, January 27, 2010 2:06 PM Subject: Re: RV10-List: OT - I want one - Apple iPad On 01/27/2010 02:54 PM, jkreidler wrote: > > Looks like Apple just released the iPad... Starts at $499, 1.5 lbs, 1/2" thick. <http://i.engadget.com/2010/01/27/live-from-the-apple-tablet-latest-creation-event/?sort=newest&refresh=30> has some pics and details of the presentation. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Date: Jan 27, 2010
My son-in-law says the high end model coming out in April will have wifi=2C blue tooth and gps. Dan From: ronrvbuilder(at)bigpond.com Subject: RE: RV10-List: OT - I want one - Apple iPad Date: Thu=2C 28 Jan 2010 08:07:49 +1100 Looks beautiful. But is there a GPS in it or not? What=92s a =91Digital compass=92 and =91Assisted GPS (Wi-Fi + 3G model)=92?? (per their Tech Spec) EMNTK Cheers=2C Ron VH-XRM=2C flying in Oz From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday=2C 28 January 2010 7:41 AM Subject: RE: RV10-List: OT - I want one - Apple iPad Once the apps get written for this product I can see some real use in the cockpit. So far I've been underwhelm ed by what's out there. This may be different. Gonna hold out until April unti l the better unit is released. Go to www.apple.com and watch the movie about it. pretty cool. Dan > Date: Wed=2C 27 Jan 2010 15:05:46 -0500 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: OT - I want one - Apple iPad > From: deej(at)deej.net > > > On 01/27/2010 02:54 PM=2C jkreidler wrote:
January 18, 2010 - January 27, 2010
RV10-Archive.digest.vol-fy
