RV10-Archive.digest.vol-gf
February 26, 2010 - March 06, 2010
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m
atronics.com] On Behalf Of Kelly McMullen Sent: Friday, February 26, 2010 6:57 AM
Subject: Re: vibration in mains on roll out
I wish I understood why using the heaviest tire out there reduces the vibration problem. Not to argue with results, just don't grasp the physics. On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald wrote: > > Greg, sorry for the abbreviation.... Goodyear Flight Custom III's... make sure you get 15X6.00X6.-- It is so nice to not have the vibration > > --- On Thu, 2/25/10, greghale wrote: > > From: greghale <ghale5224(at)aol.com> > Subject: RV10-List: Re: vibration in mains on roll out > To: rv10-list(at)matronics.com > Date: Thursday, February 25, 2010, 4:05 PM > > > DON, > > I have not been able to find the Goodyear FC3 tires.- Where did you pur chase them?- Also is the- MICHELIN AIRSTOP TUBE what you used available from Aircraft Spruce? > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Feb 26, 2010
I'd like to see some 'standard' for describing the antics of the landing gear. I refer to shimmy as the action of the nosewheel and tailwheels when they act like a crippled shopping cart. That being a side-to side castering. Cure is to tighten the spindle nut on the nosegear or changing the angle of the tailwheel spindle. As for the mains ... 'walking' would be the fore/aft movement as the airplane rolls .... caused by many things. Caster (the way the wheel center line points), brake rotor wobble (changing drag on the rotor) and loose wheel bearings will cause this. There may be others that I haven't come across. The other antic is hop. Out of balance or out of round is the typical cause. Since we perceive all of the antics as an airframe vibration, the only way to really tell is to get a pair of eyeballs to watch as you land to see what's really going on. I've heard of (but never seen) putting a hardwood fairing behind the main gear to stiffen it to remove the 'walking'. I'd also really like to see more discussion on gear issues from those that have been there. Linn Don McDonald wrote: > Rick is at least partially correct... what I think may have happenned > was through lots of, ok and not so ok landings, the balance in the tires > simply got worse and worse. That imbalance feeds back through the gear > legs, then at some point, they are unable to remain stable, and begin to > shimmy. What I do know, is that it sure feels wonderful to be shimmy > free.... and I promise to make all my landings in the future, > perfect! (--; > Don McDonald > ________________________________________________________________________________
Date: Feb 26, 2010
Linn, I have seen that done on a Harmon Rocket. That is what made me think of the carbon fiber as long as it fits underneath the stock leg fairings. It is nice to see everyones ideas/comments on here. Don, I like the "rough landings, leading to out of round/balance condition, then leading to the vibration". I just wish the tapered rod gear legs were not so sensitive, because my 172 landings are not perfect(I wish I could say they were). I actually had more fun, had a better view and landings seemed a little easier with my friends RV-9A. Have not done one in the -10. Just the demo ride last year at snf with Joe Blank. -------- Wayne Gillispie A&P 5/93, PPC 10/08 Grayson, KY 40983 Ord complete kit 8/24/09 DB Schenker del 11/20/09 Started emp 12/01/09 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288375#288375 ________________________________________________________________________________
Date: Feb 26, 2010
One thing I want to point out is if I allow the aircraft to roll out until taxi speed then apply the brakes there isn't any wheel hop/vibration/shimmy or cocoa bop.. I HAVEN'T ruled out brake chatter/grab except it does not occur stopping from slow speeds...Now my theory is that when applying the brakes "hard" to make the requested turn off causes the gear legs to move aft increasing the toe out and causing the wheel to seek "it's" true track. The energy stored in the gear leg overcomes the tire and in effect the swinging steel ball pendulum starts to occur. I'm not so sure you will realize enough stiffness with a composite or wood backing. Redesigning the gear into a flat shape rather than the cylindrical that currently is in use may be the answer. Anyone get similar results off grass? Grass would allow the tire to slide rather than trying to get back in line with the track of the aircraft. Just brainstorming... ------Original Message------ From: rv10flyer Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Sent: Feb 26, 2010 1:40 PM Subject: RV10-List: Re: vibration in mains on roll out Linn, I have seen that done on a Harmon Rocket. That is what made me think of the carbon fiber as long as it fits underneath the stock leg fairings. It is nice to see everyones ideas/comments on here. Don, I like the "rough landings, leading to out of round/balance condition, then leading to the vibration". I just wish the tapered rod gear legs were not so sensitive, because my 172 landings are not perfect(I wish I could say they were). I actually had more fun, had a better view and landings seemed a little easier with my friends RV-9A. Have not done one in the -10. Just the demo ride last year at snf with Joe Blank. -------- Wayne Gillispie A&P 5/93, PPC 10/08 Grayson, KY 40983 Ord complete kit 8/24/09 DB Schenker del 11/20/09 Started emp 12/01/09 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288375#288375 Sent via BlackBerry by AT&T ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Feb 26, 2010
Are you two standing there playing with your Blackberry's? :D No, I have no understanding, as I haven't experienced it. Kelly mentioned the physics of why something heavy would dampen it and that's what I addressed. I believe my comment in that context was accurate. HA! :P Michael - having crackberry envy -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)cox.net Sent: Friday, February 26, 2010 1:56 PM Subject: Re: RV10-List: Re: vibration in mains on roll out Is that some sort of an attempt to quantify your understanding of the problem? ..Mine came on progressively so I am leaning towards the tire as the main cause, Don is here now and he swears that was the fix for him..if it were a gear specific issue I would think it would have been there from the beginning right? Sent via BlackBerry by AT&T -----Original Message----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> Date: Fri, 26 Feb 2010 13:21:57 Subject: RE: RV10-List: Re: vibration in mains on roll out More mass and different materials to absorb the vibrations and convert it to something else like heat. Same principals used in deadening sound. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, February 26, 2010 6:57 AM Subject: Re: RV10-List: Re: vibration in mains on roll out I wish I understood why using the heaviest tire out there reduces the vibration problem. Not to argue with results, just don't grasp the physics. On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald wrote: > > Greg, sorry for the abbreviation.... Goodyear Flight Custom III's... make sure you get 15X6.00X6. It is so nice to not have the vibration > > --- On Thu, 2/25/10, greghale wrote: > > From: greghale <ghale5224(at)aol.com> > Subject: RV10-List: Re: vibration in mains on roll out > To: rv10-list(at)matronics.com > Date: Thursday, February 25, 2010, 4:05 PM > > > DON, > > I have not been able to find the Goodyear FC3 tires. Where did you purchase them? Also is the MICHELIN AIRSTOP TUBE what you used available from Aircraft Spruce? > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com ________________________________________________________________________________
Date: Feb 26, 2010
I have to think if the step gets to the point that many want to have an access panel to resolve it that the gear may be the same issue. Specifically, the bolt tends to become looser each time someone kicks off the step or the gear absorbs the perfect landings causing it to slowly get more loose. Don has a resolution to his by replacing the tires and balancing them, that may be the solution but there may be others, I am watching this issue closely as there are far more complains about the gear than there are about the doors flying off, yet Vans has never heard of this issue before anyone calls them on it. BTW- Scott at Vans support has been straight up with me, he's told me he knows of issues, has always given a suggestion and never told me I was the first to tell him about it, never seems to even cross his mind.. I would encourage some to give Vans a call and see if they have any suggestions, maybe enough calls and they may pursue a solution. -------------------------------------------------- From: <ricksked(at)cox.net> Sent: Friday, February 26, 2010 11:55 AM Subject: Re: RV10-List: Re: vibration in mains on roll out > > Is that some sort of an attempt to quantify your understanding of the > problem? ..Mine came on progressively so I am leaning towards the tire as > the main cause, Don is here now and he swears that was the fix for him..if > it were a gear specific issue I would think it would have been there from > the beginning right? > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > Date: Fri, 26 Feb 2010 13:21:57 > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: vibration in mains on roll out > > > > More mass and different materials to absorb the vibrations and convert it > to something else like heat. Same principals used in deadening sound. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Friday, February 26, 2010 6:57 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: vibration in mains on roll out > > > I wish I understood why using the heaviest tire out there reduces the > vibration problem. Not to argue with results, just don't grasp the > physics. > > On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald > wrote: >> >> Greg, sorry for the abbreviation.... Goodyear Flight Custom III's... make >> sure you get 15X6.00X6. It is so nice to not have the vibration >> >> --- On Thu, 2/25/10, greghale wrote: >> >> From: greghale <ghale5224(at)aol.com> >> Subject: RV10-List: Re: vibration in mains on roll out >> To: rv10-list(at)matronics.com >> Date: Thursday, February 25, 2010, 4:05 PM >> >> >> DON, >> >> I have not been able to find the Goodyear FC3 tires. Where did you >> purchase them? Also is the MICHELIN AIRSTOP TUBE what you used >> available from Aircraft Spruce? >> >> Greg... >> >> -------- >> Greg Hale rv10 -- N210KH >> www.nwacaptain.com > > > ________________________________________________________________________________
Date: Feb 26, 2010
Nope....this one is just due to round gear legs. No big deal. Far more an annoyance (minor) than a big deal. Start by balancing everything and most people will be pretty ok. Some may have variations of issues that make it less ok. But it's not an overwhelming problem. Tim On Feb 26, 2010, at 5:34 PM, "Pascal" wrote: > > I have to think if the step gets to the point that many want to have > an access panel to resolve it that the gear may be the same issue. > Specifically, the bolt tends to become looser each time someone > kicks off the step or the gear absorbs the perfect landings causing > it to slowly get more loose. > Don has a resolution to his by replacing the tires and balancing > them, that may be the solution but there may be others, I am > watching this issue closely as there are far more complains about > the gear than there are about the doors flying off, yet Vans has > never heard of this issue before anyone calls them on it. BTW- Scott > at Vans support has been straight up with me, he's told me he knows > of issues, has always given a suggestion and never told me I was the > first to tell him about it, never seems to even cross his mind.. I > would encourage some to give Vans a call and see if they have any > suggestions, maybe enough calls and they may pursue a solution. > > -------------------------------------------------- > From: <ricksked(at)cox.net> > Sent: Friday, February 26, 2010 11:55 AM > To: > Subject: Re: RV10-List: Re: vibration in mains on roll out > >> >> Is that some sort of an attempt to quantify your understanding of >> the problem? ..Mine came on progressively so I am leaning towards >> the tire as the main cause, Don is here now and he swears that was >> the fix for him..if it were a gear specific issue I would think it >> would have been there from the beginning right? >> Sent via BlackBerry by AT&T >> >> -----Original Message----- >> From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> >> Date: Fri, 26 Feb 2010 13:21:57 >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Re: vibration in mains on roll out >> >> > >> >> More mass and different materials to absorb the vibrations and >> convert it to something else like heat. Same principals used in >> deadening sound. >> >> Michael >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- >> server(at)matronics.com] On Behalf Of Kelly McMullen >> Sent: Friday, February 26, 2010 6:57 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Re: vibration in mains on roll out >> >> >> I wish I understood why using the heaviest tire out there reduces the >> vibration problem. Not to argue with results, just don't grasp the >> physics. >> >> On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald >> wrote: >>> >>> Greg, sorry for the abbreviation.... Goodyear Flight Custom >>> III's... make sure you get 15X6.00X6. It is so nice to not have >>> the vibration >>> >>> --- On Thu, 2/25/10, greghale wrote: >>> >>> From: greghale <ghale5224(at)aol.com> >>> Subject: RV10-List: Re: vibration in mains on roll out >>> To: rv10-list(at)matronics.com >>> Date: Thursday, February 25, 2010, 4:05 PM >>> >>> >>> DON, >>> >>> I have not been able to find the Goodyear FC3 tires. Where did >>> you purchase them? Also is the MICHELIN AIRSTOP TUBE what you >>> used available from Aircraft Spruce? >>> >>> Greg... >>> >>> -------- >>> Greg Hale rv10 -- N210KH >>> www.nwacaptain.com >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 26, 2010
An engineering look at the problem (I got this off the web). My comments below the math: http://en.wikipedia.org/wiki/Fundamental_frequency Consider a beam, fixed at one end and having a mass attached to the other, this would be a single degree of freedom (SDoF) oscillator. Once set into motion it will oscillate at its natural frequency. For a single degree of freedom oscillator, a system in which the motion can be described by a single coordinate, the natural frequency depends on two system properties; mass and stiffness. The radian frequency, =CF=89n, can be found using the following equation: Where: k = stiffness of the beam m = mass of weight =CF=89n = radian frequency (radians per second) The stiffness, k, of a body is a measure of the resistance offered by an elastic body to deformation (bending, stretching or compression). where P is a steady force applied on the body =CE=B4 is the displacement produced by the force (for instance, the deflection of a beam, or the change in length of a stretched spring) =46rom the radian frequency, the natural frequency, fn, can be found by simply dividing =CF=89n by 2=CF. Without first finding the radian frequency, the natural frequency can be found directly using: Where: fn = natural frequency in hertz (cycles/second) k = stiffness of the beam (Newtons/Meter or N/m) m = mass of weight (kg) while doing the modal analysis of structures and mechnical equipments, the frequency of 1st mode is called fundamental frequency. ================= My thoughts: The landing gear may have a natural frequency around the 40 mph or so speed some have experienced. At that speed, without much energy required to excite the harmonic or resonance response, it doesn't take much to cause a noticeable vibration (out of alignment, out of balance, surface condition, gear loading due to gross weight, etc). The wheel rpm at the offending speed could give us a clue as to the natural frequency. That is frequency = velocity/tire circumference. Then work the rest of the formulas backwards to determine theoretical mass and maybe even do some stiffness measurements on the gear leg. Might get close, might not but the goal here is to get a look at what it would take to move the natural frequency around until it is no longer excited during the takeoff or landing phase while on the ground. Adding more weight, like a heavier tire, could conceivably lower the natural frequency to the point where the natural damping of the steel gear leg is such that at a lower speed the rotating wheel can no longer excite the harmonic mode. Same goes for stiffening the gear leg with carbon or wood: it may raise the frequency and damping factor such that the mode again cannot be excited at the new condition. Classic spring mass damper solution of sorts. Perfect alignment, perfect balance, perfectly smooth landings and runways would probably not excite the harmonic on roll-out. But we all know these conditions don't last very long. So the answer is probably some combination of straight gear (aligned), better damping (carbon stiffener or other mod on to the gear leg to either raise the natural frequency, damping or both), and balanced wheels and tires. Sorry for all the formulas but it helped me think it out out, Tom #40950 waiting for long build wings. Crestview, FL On Feb 26, 2010, at 5:34 PM, Pascal wrote: > > I have to think if the step gets to the point that many want to have an access panel to resolve it that the gear may be the same issue. Specifically, the bolt tends to become looser each time someone kicks off the step or the gear absorbs the perfect landings causing it to slowly get more loose. > Don has a resolution to his by replacing the tires and balancing them, that may be the solution but there may be others, I am watching this issue closely as there are far more complains about the gear than there are about the doors flying off, yet Vans has never heard of this issue before anyone calls them on it. BTW- Scott at Vans support has been straight up with me, he's told me he knows of issues, has always given a suggestion and never told me I was the first to tell him about it, never seems to even cross his mind.. I would encourage some to give Vans a call and see if they have any suggestions, maybe enough calls and they may pursue a solution. > > -------------------------------------------------- > From: <ricksked(at)cox.net> > Sent: Friday, February 26, 2010 11:55 AM > To: > Subject: Re: RV10-List: Re: vibration in mains on roll out ________________________________________________________________________________
Date: Feb 27, 2010
I agree...not much going on to do damage up high around the gear mount but you can't help but wonder, the vibration is wonderful from an adult toy stand point, I want to relax and have a cigarette after each landing. :)...Tim do you still have this issue and just living with it? Sent via BlackBerry by AT&T -----Original Message----- From: Tim Olson <Tim(at)MyRV10.com> Date: Fri, 26 Feb 2010 18:07:49 Subject: Re: RV10-List: Re: vibration in mains on roll out Nope....this one is just due to round gear legs. No big deal. Far more an annoyance (minor) than a big deal. Start by balancing everything and most people will be pretty ok. Some may have variations of issues that make it less ok. But it's not an overwhelming problem. Tim On Feb 26, 2010, at 5:34 PM, "Pascal" wrote: > > I have to think if the step gets to the point that many want to have > an access panel to resolve it that the gear may be the same issue. > Specifically, the bolt tends to become looser each time someone > kicks off the step or the gear absorbs the perfect landings causing > it to slowly get more loose. > Don has a resolution to his by replacing the tires and balancing > them, that may be the solution but there may be others, I am > watching this issue closely as there are far more complains about > the gear than there are about the doors flying off, yet Vans has > never heard of this issue before anyone calls them on it. BTW- Scott > at Vans support has been straight up with me, he's told me he knows > of issues, has always given a suggestion and never told me I was the > first to tell him about it, never seems to even cross his mind.. I > would encourage some to give Vans a call and see if they have any > suggestions, maybe enough calls and they may pursue a solution. > > -------------------------------------------------- > From: <ricksked(at)cox.net> > Sent: Friday, February 26, 2010 11:55 AM > To: > Subject: Re: RV10-List: Re: vibration in mains on roll out > >> >> Is that some sort of an attempt to quantify your understanding of >> the problem? ..Mine came on progressively so I am leaning towards >> the tire as the main cause, Don is here now and he swears that was >> the fix for him..if it were a gear specific issue I would think it >> would have been there from the beginning right? >> Sent via BlackBerry by AT&T >> >> -----Original Message----- >> From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> >> Date: Fri, 26 Feb 2010 13:21:57 >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Re: vibration in mains on roll out >> >> > >> >> More mass and different materials to absorb the vibrations and >> convert it to something else like heat. Same principals used in >> deadening sound. >> >> Michael >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- >> server(at)matronics.com] On Behalf Of Kelly McMullen >> Sent: Friday, February 26, 2010 6:57 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Re: vibration in mains on roll out >> >> >> I wish I understood why using the heaviest tire out there reduces the >> vibration problem. Not to argue with results, just don't grasp the >> physics. >> >> On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald >> wrote: >>> >>> Greg, sorry for the abbreviation.... Goodyear Flight Custom >>> III's... make sure you get 15X6.00X6. It is so nice to not have >>> the vibration >>> >>> --- On Thu, 2/25/10, greghale wrote: >>> >>> From: greghale <ghale5224(at)aol.com> >>> Subject: RV10-List: Re: vibration in mains on roll out >>> To: rv10-list(at)matronics.com >>> Date: Thursday, February 25, 2010, 4:05 PM >>> >>> >>> DON, >>> >>> I have not been able to find the Goodyear FC3 tires. Where did >>> you purchase them? Also is the MICHELIN AIRSTOP TUBE what you >>> used available from Aircraft Spruce? >>> >>> Greg... >>> >>> -------- >>> Greg Hale rv10 -- N210KH >>> www.nwacaptain.com >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 27, 2010
Ok...you win obviously an engineer quantifying his findings....I remember all that stuff " heh yeah right" just never figured I'd use it in real life...knew I should have paid better attention!!! Good show old man.... But you're like 20 years old right? How bout substituting numerical values to gear leg, mass and resonance and other stuff like that, not being anything other than becoming hungry for more knowledge Sent via BlackBerry by AT&T -----Original Message----- From: Tom Koelzer <40950(at)rv10.net> Date: Fri, 26 Feb 2010 18:42:14 Subject: RV10-List: Re: vibration in mains on roll out ________________________________________________________________________________
Date: Feb 26, 2010
I only wish I was 20 yrs. Aero engr, class of 76, A&M. I'm only getting ready to do wings but if I get to the gear later and we are still having issues with vibration, I know I'll work the problem. Maybe there are others out there with gear interested in doing some measurements. I know there are some young engr bucks out there with brains that work better than mine to do the math. And probably have access to some really cool simulation applications on which to do the analysis. Tom #40950 Gig 'em. On Feb 26, 2010, at 7:09 PM, ricksked(at)cox.net wrote: > > Ok...you win obviously an engineer quantifying his findings....I remember all that stuff " heh yeah right" just never figured I'd use it in real life...knew I should have paid better attention!!! Good show old man.... But you're like 20 years old right? How bout substituting numerical values to gear leg, mass and resonance and other stuff like that, not being anything other than becoming hungry for more knowledge > Sent via BlackBerry by AT&T > > -----Original Message----- > From: Tom Koelzer <40950(at)rv10.net> > Date: Fri, 26 Feb 2010 18:42:14 > To: > Subject: RV10-List: Re: vibration in mains on roll out > > > > > > > ________________________________________________________________________________
Date: Feb 27, 2010
Tom, I will measure you do the math...let me know what you need and maybe we can provide a definitive answer to this problem...we don't need no stinkin computer models...they get confused predicting weather! ------Original Message------ From: Tom Koelzer Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Sent: Feb 26, 2010 5:44 PM Subject: Re: RV10-List: Re: vibration in mains on roll out I only wish I was 20 yrs. Aero engr, class of 76, A&M. I'm only getting ready to do wings but if I get to the gear later and we are still having issues with vibration, I know I'll work the problem. Maybe there are others out there with gear interested in doing some measurements. I know there are some young engr bucks out there with brains that work better than mine to do the math. And probably have access to some really cool simulation applications on which to do the analysis. Tom #40950 Gig 'em. On Feb 26, 2010, at 7:09 PM, ricksked(at)cox.net wrote: > > Ok...you win obviously an engineer quantifying his findings....I remember all that stuff " heh yeah right" just never figured I'd use it in real life...knew I should have paid better attention!!! Good show old man.... But you're like 20 years old right? How bout substituting numerical values to gear leg, mass and resonance and other stuff like that, not being anything other than becoming hungry for more knowledge > Sent via BlackBerry by AT&T > > -----Original Message----- > From: Tom Koelzer <40950(at)rv10.net> > Date: Fri, 26 Feb 2010 18:42:14 > To: > Subject: RV10-List: Re: vibration in mains on roll out > > > > > > > Sent via BlackBerry by AT&T ________________________________________________________________________________
Date: Feb 26, 2010
That's exactly what it is...a resonance issue. That's why we all see it at the same speed to whatever degree it happens. On mine, I can get a walking of the gear at high speed taxi. Some days it's not there, but if you set off the right vibration it'll trigger. Then you tap the brakes and it's gone. On landing, after balancing my tires, it's usually pretty good or nonexistant. But, before I balanced the tires, or after they start to wear from things like flat spots (caused by harsh braking or patchy ice) it can get easier to set off. If you get anything that causes any up-down or fore-aft motion, it'll trigger the resonance and it happens only for maybe 5kts worth of speed range. Some days it doesn't happen at all. Others, it'll give a good shake. But, it all does get better with everything balanced. With tapered rod gear like that, it's definitely going to happen to some people. The stiffening of the gear may improve it with carbon fiber, wood, or whatever, but, it may also just change it so that it happens at some other resonant frequency or speed. With things balanced I haven't found it to be any sort of major problem. If maybe you have oddly toe'd or formed gear legs, or tires, it may be different for you. Scott had bigger problems with his Goodyear tires than his retreads....but then again, each tire has a different shape/weight. I just figure that with the gear legs our babies were born with, it's going to be a fact of life to some degree. We could try all sorts of things, and maybe be successful. But, for mine, with things balanced, it's just not worth doing much to. Before I balanced the tires, it bugged me a bit sometimes though. I do think that axle nut tension is a factor too. Try a little tighter or looser and it may change a bit. Remember, there are a couple hundred RV-10's flying. Probably a majority have at least felt a little of what this issue is, but there are only a small handful of people who really feel it's a big problem for them. Our planes aren't all identical, so it's up to the builders to deal with their own specific issues, and if they share their experiences then maybe others with the issues can improve theirs too. But, there are also a large share of RV-10's for which this isn't a big issue at all. Considering there isn't much that can be done BEFORE you find if you have a problem, other than a change in gear leg design, just build the plane, fly it, balance everything as best you can, and if you decide you need more, share your ideas and see if it helps. But it's nothing to worry about if you aren't already flying. Tim Olson - RV-10 N104CD Tom Koelzer wrote: > An engineering look at the problem (I got this off the web). My comments below the math: > > http://en.wikipedia.org/wiki/Fundamental_frequency > > Consider a beam, fixed at one end and having a mass attached to the other, this would be a single degree of freedom (SDoF) oscillator. Once set into motion it will oscillate at its natural frequency. For a single degree of freedom oscillator, a system in which the motion can be described by a single coordinate, the natural frequency depends on two system properties; mass and stiffness. The radian frequency, ?n, can be found using the following equation: > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > > > Where: > k = stiffness of the beam > m = mass of weight > ?n = radian frequency (radians per second) > > The stiffness, k, of a body is a measure of the resistance offered by an elastic body to deformation (bending, stretching or compression). > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > > > where > P is a steady force applied on the body > ? is the displacement produced by the force (for instance, the deflection of a beam, or the change in length of a stretched spring) > > From the radian frequency, the natural frequency, fn, can be found by simply dividing ?n by 2?. Without first finding the radian frequency, the natural frequency can be found directly using: > > > ------------------------------------------------------------------------ > > > ------------------------------------------------------------------------ > > > Where: > fn = natural frequency in hertz (cycles/second) > k = stiffness of the beam (Newtons/Meter or N/m) > m = mass of weight (kg) while doing the modal analysis of structures and mechnical equipments, the frequency of 1st mode is called fundamental frequency. > > ================= > > My thoughts: The landing gear may have a natural frequency around the 40 mph or so speed some have experienced. At that speed, without much energy required to excite the harmonic or resonance response, it doesn't take much to cause a noticeable vibration (out of alignment, out of balance, surface condition, gear loading due to gross weight, etc). The wheel rpm at the offending speed could give us a clue as to the natural frequency. That is frequency = velocity/tire circumference. Then work the rest of the formulas backwards to determine theoretical mass and maybe even do some stiffness measurements on the gear leg. Might get close, might not but the goal here is to get a look at what it would take to move the natural frequency around until it is no longer excited during the takeoff or landing phase while on the ground. > > Adding more weight, like a heavier tire, could conceivably lower the natural frequency to the point where the natural damping of the steel gear leg is such that at a lower speed the rotating wheel can no longer excite the harmonic mode. Same goes for stiffening the gear leg with carbon or wood: it may raise the frequency and damping factor such that the mode again cannot be excited at the new condition. Classic spring mass damper solution of sorts. > > Perfect alignment, perfect balance, perfectly smooth landings and runways would probably not excite the harmonic on roll-out. But we all know these conditions don't last very long. So the answer is probably some combination of straight gear (aligned), better damping (carbon stiffener or other mod on to the gear leg to either raise the natural frequency, damping or both), and balanced wheels and tires. > > Sorry for all the formulas but it helped me think it out out, > > Tom > > #40950 waiting for long build wings. > Crestview, FL > > > > On Feb 26, 2010, at 5:34 PM, Pascal wrote: > >> >> I have to think if the step gets to the point that many want to have an access panel to resolve it that the gear may be the same issue. Specifically, the bolt tends to become looser each time someone kicks off the step or the gear absorbs the perfect landings causing it to slowly get more loose. >> Don has a resolution to his by replacing the tires and balancing them, that may be the solution but there may be others, I am watching this issue closely as there are far more complains about the gear than there are about the doors flying off, yet Vans has never heard of this issue before anyone calls them on it. BTW- Scott at Vans support has been straight up with me, he's told me he knows of issues, has always given a suggestion and never told me I was the first to tell him about it, never seems to even cross his mind.. I would encourage some to give Vans a call and see if they have any suggestions, maybe enough calls and they may pursue a solution. >> >> -------------------------------------------------- >> From: <ricksked(at)cox.net> >> Sent: Friday, February 26, 2010 11:55 AM >> To: >> Subject: Re: RV10-List: Re: vibration in mains on roll out > ________________________________________________________________________________
Subject: Reinforcing screw holes on wheel pants
Date: Feb 26, 2010
Okay, After being severely repremanded about glassing in the nose wheel mounting bracket, I have finished mounting my pants per the plans. Now I am concerned that the screw holes are somewhat enlarged due to countersinking and will fail over time. Is there a preferred way to reinforce screw holes in fiberglass. Inquiring mindfs need to know. Les #40643 ________________________________________________________________________________
Subject: Re: Reinforcing screw holes on wheel pants
Date: Feb 26, 2010
If I recall correctly you should have some flox between the screw holes and bracket.. so there should be plenty of strength, you can use a countersunk washer, forget the screw size, but they sell them for all sizes. Good thing about fiberglass is you can just flow the hole in the inside again throw a few layers of glass on top and start over in a year or two if there is a problem. From: Les Kearney Sent: Friday, February 26, 2010 8:26 PM Subject: RV10-List: Reinforcing screw holes on wheel pants Okay, After being severely repremanded about glassing in the nose wheel mounting bracket, I have finished mounting my pants per the plans. Now I am concerned that the screw holes are somewhat enlarged due to countersinking and will fail over time. Is there a preferred way to reinforce screw holes in fiberglass. Inquiring mindfs need to know. Les #40643 ________________________________________________________________________________
Date: Feb 26, 2010
These are great discussions. And thanks, Tim, you have a great insight for what really matter. Flying is what matters, safe flying. This is an nuisance that I find particularly interesting because of my background (aero engr and flight test) and does not threaten safety of the vehicle. But a nuisance none the less. So generally speaking, I think there may be a resonance mode with the gear that causes problems for some and not for others. The catalyst is what excites the mode and how to dampen it. If not excited, nothing happens (all guys know this). I'm interested in a solution, long term. This is not like doors flying off the airplane. This is like explaining to my mother why my airplane shakes when I land when she rides with me. It's just that simple. No problem, maybe only an embarrassment. I'd like to contribute to a solution for those who see this problem more than others and are interested in doing something about it. Van's might have an idea or two as well (other than wood glued to the landing gear). I'll ask later if we get to that point. I'll talk to Neal and see what we can come up with regard to cheap instrumentation. I have other ideas to pursue. If there is little interest, that's ok. I believe in supply and demand as the driver to all solutions. If I see this when I finally get to the gear and flying, then I'll tackle the problem again. Tom aka Cowboy On Feb 26, 2010, at 10:07 PM, Tim Olson wrote: > > That's exactly what it is...a resonance issue. That's why we > all see it at the same speed to whatever degree it happens. > On mine, I can get a walking of the gear at high speed > taxi. Some days it's not there, but if you set off the > right vibration it'll trigger. Then you tap the brakes and > it's gone. On landing, after balancing my tires, it's usually > pretty good or nonexistant. But, before I balanced the tires, > or after they start to wear from things like flat spots (caused > by harsh braking or patchy ice) it can get easier to set off. > If you get anything that causes any up-down or fore-aft > motion, it'll trigger the resonance and it happens only for > maybe 5kts worth of speed range. Some days it doesn't happen > at all. Others, it'll give a good shake. But, it all does > get better with everything balanced. With tapered rod > gear like that, it's definitely going to happen to some people. > The stiffening of the gear may improve it with carbon fiber, > wood, or whatever, but, it may also just change it so that it > happens at some other resonant frequency or speed. With > things balanced I haven't found it to be any sort of major > problem. If maybe you have oddly toe'd or formed gear legs, > or tires, it may be different for you. Scott had bigger > problems with his Goodyear tires than his retreads....but > then again, each tire has a different shape/weight. I just > figure that with the gear legs our babies were born with, it's > going to be a fact of life to some degree. We could try > all sorts of things, and maybe be successful. But, for mine, > with things balanced, it's just not worth doing much to. > Before I balanced the tires, it bugged me a bit sometimes > though. I do think that axle nut tension is a factor too. > Try a little tighter or looser and it may change a bit. > > Remember, there are a couple hundred RV-10's flying. Probably > a majority have at least felt a little of what this issue > is, but there are only a small handful of people who really > feel it's a big problem for them. Our planes aren't all > identical, so it's up to the builders to deal with their own > specific issues, and if they share their experiences then maybe > others with the issues can improve theirs too. But, there > are also a large share of RV-10's for which this isn't a big > issue at all. Considering there isn't much that can be done > BEFORE you find if you have a problem, other than a change in > gear leg design, just build the plane, fly it, balance > everything as best you can, and if you decide you need more, > share your ideas and see if it helps. But it's nothing to > worry about if you aren't already flying. > > Tim Olson - RV-10 N104CD > ________________________________________________________________________________
Date: Feb 27, 2010
Les use stainless countersink washers on the glass, brush thinned epoxy on the fiberglass before using the washers, this will reinforce the hole, the washer will distribute the load. Sent via BlackBerry by AT&T -----Original Message----- From: "Les Kearney" <kearney(at)shaw.ca> Date: Fri, 26 Feb 2010 21:26:58 Subject: RV10-List: Reinforcing screw holes on wheel pants This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Feb 26, 2010
I am anxious to see how mine will do. Awhile back I redrilled my left gear leg so both wheels were pointed in 1.10 degrees. I only used 1.10 because the right gear was set there from construction when lining up the factory holes. I moved the left gear to match since it was toed out and the right was toed in. I called Van's to make sure the bolt I used would be structurally ok. We'll see! ----- Original Message ----- From: "Tom Koelzer" <40950(at)rv10.net> Sent: Friday, February 26, 2010 9:49 PM Subject: Re: RV10-List: Re: vibration in mains on roll out These are great discussions. And thanks, Tim, you have a great insight for what really matter. Flying is what matters, safe flying. This is an nuisance that I find particularly interesting because of my background (aero engr and flight test) and does not threaten safety of the vehicle. But a nuisance none the less. So generally speaking, I think there may be a resonance mode with the gear that causes problems for some and not for others. The catalyst is what excites the mode and how to dampen it. If not excited, nothing happens (all guys know this). I'm interested in a solution, long term. This is not like doors flying off the airplane. This is like explaining to my mother why my airplane shakes when I land when she rides with me. It's just that simple. No problem, maybe only an embarrassment. I'd like to contribute to a solution for those who see this problem more than others and are interested in doing something about it. Van's might have an idea or two as well (other than wood glued to the landing gear). I'll ask later if we get to that point. I'll talk to Neal and see what we can come up with regard to cheap instrumentation. I have other ideas to pursue. If there is little interest, that's ok. I believe in supply and demand as the driver to all solutions. If I see this when I finally get to the gear and flying, then I'll tackle the problem again. Tom aka Cowboy On Feb 26, 2010, at 10:07 PM, Tim Olson wrote: > > That's exactly what it is...a resonance issue. That's why we > all see it at the same speed to whatever degree it happens. > On mine, I can get a walking of the gear at high speed > taxi. Some days it's not there, but if you set off the > right vibration it'll trigger. Then you tap the brakes and > it's gone. On landing, after balancing my tires, it's usually > pretty good or nonexistant. But, before I balanced the tires, > or after they start to wear from things like flat spots (caused > by harsh braking or patchy ice) it can get easier to set off. > If you get anything that causes any up-down or fore-aft > motion, it'll trigger the resonance and it happens only for > maybe 5kts worth of speed range. Some days it doesn't happen > at all. Others, it'll give a good shake. But, it all does > get better with everything balanced. With tapered rod > gear like that, it's definitely going to happen to some people. > The stiffening of the gear may improve it with carbon fiber, > wood, or whatever, but, it may also just change it so that it > happens at some other resonant frequency or speed. With > things balanced I haven't found it to be any sort of major > problem. If maybe you have oddly toe'd or formed gear legs, > or tires, it may be different for you. Scott had bigger > problems with his Goodyear tires than his retreads....but > then again, each tire has a different shape/weight. I just > figure that with the gear legs our babies were born with, it's > going to be a fact of life to some degree. We could try > all sorts of things, and maybe be successful. But, for mine, > with things balanced, it's just not worth doing much to. > Before I balanced the tires, it bugged me a bit sometimes > though. I do think that axle nut tension is a factor too. > Try a little tighter or looser and it may change a bit. > > Remember, there are a couple hundred RV-10's flying. Probably > a majority have at least felt a little of what this issue > is, but there are only a small handful of people who really > feel it's a big problem for them. Our planes aren't all > identical, so it's up to the builders to deal with their own > specific issues, and if they share their experiences then maybe > others with the issues can improve theirs too. But, there > are also a large share of RV-10's for which this isn't a big > issue at all. Considering there isn't much that can be done > BEFORE you find if you have a problem, other than a change in > gear leg design, just build the plane, fly it, balance > everything as best you can, and if you decide you need more, > share your ideas and see if it helps. But it's nothing to > worry about if you aren't already flying. > > Tim Olson - RV-10 N104CD > ________________________________________________________________________________
Date: Feb 27, 2010
Subject: Storage Help needed in VA or DC area
Sorry yo blast to entire list but I need help. I'm moving my RV-10 project from Texas to Virginina. It is loaded on an 18 foot flatbed trailer in crates (overall lenght 22'). I was going to store it in a garage in Lynchburg VA temporarily until I found permananent space in N VA - my ultimate destination. Probl4em is when I got to the garage in Lyncburg the door isn't wide enough (Need 97" and it is just at 96") for the trailer to back into. I don't want to unload the crates as I will still need a place for the trailer and I don't plan on it being here that long anyway. Anyone got any storage space in VA/MD area that can hold aloaded trailer for a month or so? Richard Bibb 972-835-5979 cell rbibb AT tomet.net ________________________________________________________________________________
Subject: RV12
Date: Feb 27, 2010
Having completed the 10 in 2008 and flown it about 250 hours, I am considering building my third aircraft. It will probably be an RV12. Does anyone know of a set of PDF plans like we have for the 10? I would build it E-AB but would like to preview the plans prior to a decision. N48007 Glastar 2003 530TT sold N46007 RV10 2008 250TT RV12? COM, CFII, A&P ________________________________________________________________________________
Subject: Re: PEM nuts
Date: Feb 27, 2010
Jim, You've got my interest, but I need to get a little more info. What I'm seeing is a nut that you can rivet. You mentioned a squeezer, but I assume you can buck these things as well. Cost less than nutplates. John -------- #40572 QB. Engine on, wing attach coming soon. Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288489#288489 ________________________________________________________________________________
Date: Feb 27, 2010
John, the nuts are round and have a serration all the way around so that wh en you squeeze it into place , it digs into the receiving metal and is fair ly permanent.- I probably should just send out some of these to everyone on the list.- I'm sure almost all would find several suitable uses for th em.- Much faster and-cheaper, Don McDonald - -- On Sat, 2/27/10, johngoodman wrote: From: johngoodman <johngoodman(at)earthlink.net> Subject: RV10-List: Re: PEM nuts Date: Saturday, February 27, 2010, 7:49 AM Jim, You've got my interest, but I need to get a little more info. What I'm seei ng is a nut that you can rivet. You mentioned a squeezer, but I assume you can buck these things as well. Cost less than nutplates. John -------- #40572 QB. Engine on, wing attach coming soon. Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288489#288489 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Subject: Chandler Hangar
Date: Feb 27, 2010
We have had a change in plans, and are going to fly into Chandler AZ on Monday the 1st of March...(for 1 or 2 nights)... anyone have room in a hangar, or know of someone who does. We are certainly willing to pay.... it's just that the 10 doesn't like to get cold at night. Thanks, Don McDonald -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288502#288502 ________________________________________________________________________________
Date: Feb 27, 2010
I use PEM nuts for all my electronics mounting. I like them better than rivnuts because the PEM nuts mount from the back of the aluminum leaving the front side flat, unlike the rivnuts that have that 'washer' on the surface. Linn Don McDonald wrote: > John, the nuts are round and have a serration all the way around so that > when you squeeze it into place , it digs into the receiving metal and is > fairly permanent. I probably should just send out some of these to > everyone on the list. I'm sure almost all would find several suitable > uses for them. Much faster and cheaper, > Don McDonald > > -- On *Sat, 2/27/10, johngoodman //* wrote: > > > From: johngoodman <johngoodman(at)earthlink.net> > Subject: RV10-List: Re: PEM nuts > To: rv10-list(at)matronics.com > Date: Saturday, February 27, 2010, 7:49 AM > > <http://us.mc537.mail.yahoo.com/mc/compose?to=johngoodman@earthlink.net>> > > Jim, > You've got my interest, but I need to get a little more info. What > I'm seeing is a nut that you can rivet. You mentioned a squeezer, > but I assume you can buck these things as well. Cost less than > nutplates. > John > > -------- > #40572 QB. Engine on, wing attach coming soon. Panel delivery soon. > N711JG reserved > > > > > Read this topic online here: > > http://forums.matronics.com/visp; --> > <http://forums.matronics.com/viewtopic.php?p=288489#288489> > <http://www.matronics.com/Navigator?RV10-List>http://foru > - List Contribution We -Matt Dralle, > Listm/contribution" > target=_blank>http://www.matronics.com/contribution > <http://forums.matronics.com/> > > > > > * > > > * ________________________________________________________________________________
Date: Feb 27, 2010
John, Don has already covered it well, but to answer your question more specifically there are no rivets involved in mounting PEM nuts. A rivet squeezer works well for setting them when the hole is close enough to an edge. In spite of Don's admonition otherwise, they can also be installed with a hammer and a hardwood block when the hole is too far from an edge to reach with your squeezer. Once a PEM nut is set, it takes a minimum of 200# of force to push it back out. So while not a secure as a riveted anchor nut, plenty strong enough for many applications, easier to install and cheaper. Try 'em and you will like 'em. Jim Berry 40482 N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288520#288520 ________________________________________________________________________________
Date: Feb 27, 2010
Subject: Re: Chandler Hangar
Cold at night???? The forecast low for all of this week is in the high 40s, nothing colder than 45. :-P Expect 70 or so for day time. partner14 wrote: > > We have had a change in plans, and are going to fly into Chandler AZ on Monday the 1st of March...(for 1 or 2 nights)... anyone have room in a hangar, or know of someone who does. We are certainly willing to pay.... it's just that the 10 doesn't like to get cold at night. > Thanks, Don McDonald > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288502#288502 > > > ________________________________________________________________________________
Date: Feb 27, 2010
For what its worth, I totally eliminated my shimmy by re-balancing my tires (original 130 hrs ago). The surprising part for me was how much lead weight it took to get them balanced. I was most suspect of the balance until I did 2 test flights following the re-balancing...... grumpy N184JM On Feb 26, 2010, at 2:19 PM, Don McDonald wrote: > Rick is at least partially correct... what I think may have > happenned was through lots of, ok and not so ok landings, the > balance in the tires simply got worse and worse. That imbalance > feeds back through the gear legs, then at some point, they are > unable to remain stable, and begin to shimmy. What I do know, is > that it sure feels wonderful to be shimmy free.... and I promise to > make all my landings in the future, perfect! (--; > Don McDonald > > --- On Fri, 2/26/10, ricksked(at)cox.net wrote: > > From: ricksked(at)cox.net <ricksked(at)cox.net> > Subject: Re: RV10-List: Re: vibration in mains on roll out > To: rv10-list(at)matronics.com > Date: Friday, February 26, 2010, 11:55 AM > > > Is that some sort of an attempt to quantify your understanding of > the problem? ..Mine came on progressively so I am leaning towards > the tire as the main cause, Don is here now and he swears that was > the fix for him..if it were a gear specific issue I would think it > would have been there from the beginning right? > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > Date: Fri, 26 Feb 2010 13:21:57 > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: vibration in mains on roll out > > > > > More mass and different materials to absorb the vibrations and > convert it to something else like heat. Same principals used in > deadening sound. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Kelly McMullen > Sent: Friday, February 26, 2010 6:57 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: vibration in mains on roll out > > > I wish I understood why using the heaviest tire out there reduces the > vibration problem. Not to argue with results, just don't grasp the > physics. > > On Thu, Feb 25, 2010 at 10:30 PM, Don McDonald > wrote: > > > > Greg, sorry for the abbreviation.... Goodyear Flight Custom > III's... make sure you get 15X6.00X6. It is so nice to not have > the vibration > > > > --- On Thu, 2/25/10, greghale wrote: > > > > From: greghale <ghale5224(at)aol.com> > > Subject: RV10-List: Re: vibration in mains on roll out > > To: rv10-list(at)matronics.com > > Date: Thursday, February 25, 2010, 4:05 PM > > > > > > DON, > > > > I have not been able to find the Goodyear FC3 tires. Where did > you purchase them? Also is the MICHELIN AIRSTOP TUBE what you used > available from Aircraft Spruce? > > > > Greg... > > > > -------- > > Greg Hale rv10 -- N210KH > > www.ef="http://www.matronics.com/Navigator?RV10-List" sp;--> > http://f= - List Contributionsp; > &bsp;--> > > ________________________________________________________________________________
Subject: I heard your email
Date: Feb 28, 2010
www.DriveSafe.ly read it to me. I will get back to you soon. Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Feb 28, 2010
Rick Well after putting my wheel pants for the nth time, one of the screws pulled through before I could get some countersunk washers. The nice thing about fiberglass, perhaps the only thing, is you can alsways repair a proplem to "like new". What did you use to thin the epoxy (I haven't tried that yet)? I was wondering if you made the washers "flush" with the surface of the pants? Did you recess them, build up the material around them with something like Superfil or just leave them proud of the wheel pant to be painted? Inquiring mind need to know Les #40643 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)cox.net Sent: February-26-10 9:45 PM Subject: Re: RV10-List: Reinforcing screw holes on wheel pants Les use stainless countersink washers on the glass, brush thinned epoxy on the fiberglass before using the washers, this will reinforce the hole, the washer will distribute the load. Sent via BlackBerry by AT&T _____ From: "Les Kearney" <kearney(at)shaw.ca> Date: Fri, 26 Feb 2010 21:26:58 -0700 Subject: RV10-List: Reinforcing screw holes on wheel pants Okay, After = being severely repremanded about glassing in the nose wheel mounting bracket, I have = finished mounting my pants per the plans. Now I am concerned that the screw holes = are somewhat enlarged due to countersinking and will fail over time. Is = there a preferred way to reinforce screw holes in = fiberglass. Inquiring mindfs need to know. Les #40643 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =B7~=89=B2,=03g'=D3=D3 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Feb 28, 2010
I use stainless steel tinnermans with stainless steel flush screws on all fiberglass (spinner, empennage fairing, pants, etc.). The fiberglass is countersunk enough for the tinnermans to be flush. The tinnermans go on top of the final paint. I like the look. You end up with the screw spreading the clamping force over a much larger area than the screw head and on non-counter sunk fiberglass. Carl Froehlich RV-8A (525 hrs) RV-10 (systems install) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney Sent: Sunday, February 28, 2010 10:54 AM Subject: RE: RV10-List: Reinforcing screw holes on wheel pants Rick Well after putting my wheel pants for the nth time, one of the screws pulled through before I could get some countersunk washers. The nice thing about fiberglass, perhaps the only thing, is you can alsways repair a proplem to "like new". What did you use to thin the epoxy (I haven't tried that yet)? I was wondering if you made the washers "flush" with the surface of the pants? Did you recess them, build up the material around them with something like Superfil or just leave them proud of the wheel pant to be painted? Inquiring mind need to know Les #40643 _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)cox.net Sent: February-26-10 9:45 PM Subject: Re: RV10-List: Reinforcing screw holes on wheel pants Les use stainless countersink washers on the glass, brush thinned epoxy on the fiberglass before using the washers, this will reinforce the hole, the washer will distribute the load. Sent via BlackBerry by AT&T _____ From: "Les Kearney" <kearney(at)shaw.ca> Date: Fri, 26 Feb 2010 21:26:58 -0700 Subject: RV10-List: Reinforcing screw holes on wheel pants Okay, After = being severely repremanded about glassing in the nose wheel mounting bracket, I have = finished mounting my pants per the plans. Now I am concerned that the screw holes = are somewhat enlarged due to countersinking and will fail over time. Is = there a preferred way to reinforce screw holes in = fiberglass. Inquiring mindfs need to know. Les #40643 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matr onics .com/Navigator?RV10-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D href='3D"http://forums.matronics.com"'>http://forums.matronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D href='3D"http://www.matronics.com/contribution"'>http://www.matronics.c om/co ntribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D =B7~=89=B2, _____ g'=D3=D3 ________________________________________________________________________________
Date: Feb 28, 2010
I shoved some pieces of GRP that I had cut off of the doors (window) under the screw holes (epoxy/flox glue) and they are tight and tough. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288612#288612 Attachments: http://forums.matronics.com//files/p1041194_130.jpg ________________________________________________________________________________
Subject: RE: RV12
Date: Feb 28, 2010
From: "Masys, Daniel R" <dan.masys(at)vanderbilt.edu>
>John Cox writes: Will forward you what I have from the TEEN FLIGHT project (RV-12) we are building at Van's. The plans start out as 11"x17" base sheets just like the RV-10 and Kinko's/FEDEX were nice enough to convert to PDF. We have four of the twelve Instructors with RV-12 experience. Your experience pulling pop-rivets on the Rv-10 floor make you a natural to tackle the 12. I can also report how many Rotax sit on the shelves which tend to be going out like Hotcakes at an EAA breakfast. Get ready to be working with gentle hands on the 0.020" skins. Lauren Paine has an article appearing soon on the build project sponsored by the Center for Airway Sciences. John Cox -40600 ------------- I can second John's "gentle hands" comment with those 0.020 skins on control surfaces of the -12. Having built a -7A and a -10 I started handling the skins on the -12 like the prior two planes and promptly got a couple of fingerprint depressions in the trailing edges of the rudder. When they say 'light' in light sport, they mean it! Also, be very careful about hole alignment, especially when building up the HS box spar. The differences of the hole alignments are so subtle it is very easy to get the thing assembled upside down (especially since it's airfoil is symmetrical). Ask me how I know. ;-) Other than that, the only two things to be aware of building the -12 after you have built a -10 is how shockingly fast the assembly goes (e.g., set 300 rivets and close out a wing top and bottom in a few hours) and how Van's has fallen way behind their projected delivery dates for the kits. Waited 5 weeks beyond the original projected ship date for the wing kit, and 6 weeks (14 weeks total wait) for the fuselage kit. Plan early and order those kits long before you need them or you'll have lots of time just sitting around waiting for the next kit to arrive. -Dan Masys RV-10 N104LD flying RV-12 N122LD fuselage ________________________________________________________________________________
Subject: Water ballast tank
Date: Feb 28, 2010
Folks, I'm about to start riveting the VS and want to put my mind to rest about W&B issues before doing so. My concern is trying to optimize the W&B so that the use of ballast, if at all required, is as easy (and light) as possible. I anticipate running into a rear CG problem with 4 passengers and baggage. I'm assuming some moderate soundproofing and interior (circa 20lbs) and the MT 3-blade prop, which both move CG rearwards. My "solution" is to move the battery forwards to the firewall. This avoids having a rear CG problem in all practical circumstances, reduces cable weight and voltage drop during starting, but increases the issue with the inadequate elevator trim when flying solo or dual. To solve that, I proposed putting a water ballast tank near the tail, instead of using the traditional shot bags used by Van's in the demonstrator. This minimizes the weight required, and would allow dumping and refilling the ballast anywhere, anytime. Vans have helped me in so much as confirming the following: 1. If loaded with a CG at front limit of 15% (ie. solo, no ballast), the plane can be landed OK with half flaps or a touch of power in the flare. 2. A comfortable CG location for landing is around 18% or rearward. 3. Structurally, putting a water ballast tank in the tail is "probably OK". The VS appeared to be the preferred location rather than the rear fuselage. The space between the lower and middle inspar ribs is the perfect volume. 4. Nothing disastrous will happen with the CG at 32%. So now I'm considering 2 options: Option 1: Move the battery forwards, add the water ballast tank (or use a lot of ballast in the baggage bay). No problem ever with the rear CG, but ballast is a must if flying solo, to keep behind 15%. Option 2: Leave the battery where it is. Accept CG back to 32%. Never need to use ballast. I would appreciate any feedback from those who are flying regularly near gross with passengers or who have the experience from flight testing. Does the plane really fly OK with a CG location slightly rear of limits? Also, if anyone can help me find the summary weight and balance table of all the finished -10's I would be grateful. The rvproject link mentioned in some messages on the forum doesn't seem to work when I try. Fly safe! Gordon Anderson Switzerland VS primed (DuPont 825R/XB383 ;-) ) ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Re: Water ballast tank
Why would you want to build in a tank? If you are full you won't need ballast for sure. If you are solo, a collapsible 5 gal jug should be plenty, that could easily be carried into FBO and filled, as opposed to needing a hose or a container to get water to plane. Jug could be easily secured in baggage. I'll let the flying folks comment on W&B, but I sure wouldn't be adding complexity to your build at this stage, and not in the VS. Better to worry about what primer to use, or not. ;-))) On Sun, Feb 28, 2010 at 1:44 PM, Gordon Anderson wrote: > Folks, > > > Im about to start riveting the VS and want to put my mind to rest about W&B > issues before doing so. My concern is trying to optimize the W&B so that the > use of ballast, if at all required, is as easy (and light) as possible. > > > I anticipate running into a rear CG problem with 4 passengers and baggage. > I'm assuming some moderate soundproofing and interior (circa 20lbs) and the > MT 3-blade prop, which both move CG rearwards. My "solution" is to move the > battery forwards to the firewall. This avoids having a rear CG problem in > all practical circumstances, reduces cable weight and voltage drop during > starting, but increases the issue with the inadequate elevator trim when > flying solo or dual. To solve that, I proposed putting a water ballast > tank near the tail, instead of using the traditional shot bags used by Van's > in the demonstrator. This minimizes the weight required, and would allow > dumping and refilling the ballast anywhere, anytime. > > > Vans have helped me in so much as confirming the following: > > > 1. If loaded with a CG at front limit of 15% (ie. solo, no ballast), the > plane can be landed OK with half flaps or a touch of power in the flare. > > > 2. A comfortable CG location for landing is around 18% or rearward. > > > 3. Structurally, putting a water ballast tank in the tail is "probably OK". > The VS appeared to be the preferred location rather than the rear fuselage. > The space between the lower and middle inspar ribs is the perfect volume. > > > 4. Nothing disastrous will happen with the CG at 32%. > > > So now I'm considering 2 options: > > > Option 1: Move the battery forwards, add the water ballast tank (or use a > lot of ballast in the baggage bay). No problem ever with the rear CG, but > ballast is a must if flying solo, to keep behind 15%. > > > Option 2: Leave the battery where it is. Accept CG back to 32%. Never need > to use ballast. > > > I would appreciate any feedback from those who are flying regularly near > gross with passengers or who have the experience from flight testing. Does > the plane really fly OK with a CG location slightly rear of limits? > > > Also, if anyone can help me find the summary weight and balance table of all > the finished -10's I would be grateful. The rvproject link mentioned in some > messages on the forum doesn't seem to work when I try. > > > Fly safe! > > Gordon Anderson > > Switzerland > > VS primed (DuPont 825R/XB383 ;-) ) > > ________________________________________________________________________________
Date: Feb 28, 2010
Have you accounted for the 25 pound tool and spares box that is carried with each experimental. Unless you carry all the service manuals (or the tools) how are you going to maintain/fix the aircraft away from home base. Many FBOs won't touch them with out manufacturers continued airworthiness documents (insurance reasons). One must be prepared to maintain it and have a few spare parts available in the tool box; i,e, serviceable spark plug, master contactor, starter relay, spare cowl pin material, etc _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Gordon Anderson Sent: Sunday, February 28, 2010 1:45 PM Subject: RV10-List: Water ballast tank Folks, I'm about to start riveting the VS and want to put my mind to rest about W&B issues before doing so. My concern is trying to optimize the W&B so that the use of ballast, if at all required, is as easy (and light) as possible. I anticipate running into a rear CG problem with 4 passengers and baggage. I'm assuming some moderate soundproofing and interior (circa 20lbs) and the MT 3-blade prop, which both move CG rearwards. My "solution" is to move the battery forwards to the firewall. This avoids having a rear CG problem in all practical circumstances, reduces cable weight and voltage drop during starting, but increases the issue with the inadequate elevator trim when flying solo or dual. To solve that, I proposed putting a water ballast tank near the tail, instead of using the traditional shot bags used by Van's in the demonstrator. This minimizes the weight required, and would allow dumping and refilling the ballast anywhere, anytime. Vans have helped me in so much as confirming the following: 1. If loaded with a CG at front limit of 15% (ie. solo, no ballast), the plane can be landed OK with half flaps or a touch of power in the flare. 2. A comfortable CG location for landing is around 18% or rearward. 3. Structurally, putting a water ballast tank in the tail is "probably OK". The VS appeared to be the preferred location rather than the rear fuselage. The space between the lower and middle inspar ribs is the perfect volume. 4. Nothing disastrous will happen with the CG at 32%. So now I'm considering 2 options: Option 1: Move the battery forwards, add the water ballast tank (or use a lot of ballast in the baggage bay). No problem ever with the rear CG, but ballast is a must if flying solo, to keep behind 15%. Option 2: Leave the battery where it is. Accept CG back to 32%. Never need to use ballast. I would appreciate any feedback from those who are flying regularly near gross with passengers or who have the experience from flight testing. Does the plane really fly OK with a CG location slightly rear of limits? Also, if anyone can help me find the summary weight and balance table of all the finished -10's I would be grateful. The rvproject link mentioned in some messages on the forum doesn't seem to work when I try. Fly safe! Gordon Anderson Switzerland VS primed (DuPont 825R/XB383 ;-) ) ________________________________________________________________________________
Date: Feb 28, 2010
Have you considered what happens if the water in your VS tank freezes? Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288647#288647 ________________________________________________________________________________
Date: Feb 28, 2010
Definitely way too early to worry about it...and I don't think the VS is a good spot for ballast. Sounds like you're way overthinking things. Time to find a flying 10 and go for a ride. Tim On Feb 28, 2010, at 3:20 PM, Kelly McMullen wrote: > > Why would you want to build in a tank? If you are full you won't need > ballast for sure. If you are solo, a collapsible 5 gal jug should be > plenty, that could easily be carried into FBO and filled, as opposed > to needing a hose or a container to get water to plane. Jug could be > easily secured in baggage. I'll let the flying folks comment on W&B, > but I sure wouldn't be adding complexity to your build at this stage, > and not in the VS. Better to worry about what primer to use, or not. > ;-))) > > On Sun, Feb 28, 2010 at 1:44 PM, Gordon Anderson > wrote: >> Folks, >> >> >> >> Im about to start riveting the VS and want to put my mind to rest >> about W&B >> issues before doing so. My concern is trying to optimize the W&B so >> that the >> use of ballast, if at all required, is as easy (and light) as >> possible. >> >> >> >> I anticipate running into a rear CG problem with 4 passengers and >> baggage. >> I'm assuming some moderate soundproofing and interior (circa >> 20lbs) and the >> MT 3-blade prop, which both move CG rearwards. My "solution" is to >> move the >> battery forwards to the firewall. This avoids having a rear CG >> problem in >> all practical circumstances, reduces cable weight and voltage drop >> during >> starting, but increases the issue with the inadequate elevator trim >> when >> flying solo or dual. To solve that, I proposed putting a water >> ballast >> tank near the tail, instead of using the traditional shot bags used >> by Van's >> in the demonstrator. This minimizes the weight required, and would >> allow >> dumping and refilling the ballast anywhere, anytime. >> >> >> >> Vans have helped me in so much as confirming the following: >> >> >> >> 1. If loaded with a CG at front limit of 15% (ie. solo, no >> ballast), the >> plane can be landed OK with half flaps or a touch of power in the >> flare. >> >> >> >> 2. A comfortable CG location for landing is around 18% or rearward. >> >> >> >> 3. Structurally, putting a water ballast tank in the tail is >> "probably OK". >> The VS appeared to be the preferred location rather than the rear >> fuselage. >> The space between the lower and middle inspar ribs is the perfect >> volume. >> >> >> >> 4. Nothing disastrous will happen with the CG at 32%. >> >> >> >> >> >> So now I'm considering 2 options: >> >> >> >> Option 1: Move the battery forwards, add the water ballast tank (or >> use a >> lot of ballast in the baggage bay). No problem ever with the rear >> CG, but >> ballast is a must if flying solo, to keep behind 15%. >> >> >> >> Option 2: Leave the battery where it is. Accept CG back to 32%. >> Never need >> to use ballast. >> >> >> >> I would appreciate any feedback from those who are flying regularly >> near >> gross with passengers or who have the experience from flight >> testing. Does >> the plane really fly OK with a CG location slightly rear of limits? >> >> >> >> Also, if anyone can help me find the summary weight and balance >> table of all >> the finished -10's I would be grateful. The rvproject link >> mentioned in some >> messages on the forum doesn't seem to work when I try. >> >> >> >> Fly safe! >> >> Gordon Anderson >> >> Switzerland >> >> VS primed (DuPont 825R/XB383 ;-) ) >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 28, 2010
I have an AFT CG (empty) and will be ADDING a battery to the fire wall in order to provide more backup power and move the CG forward. I also tested the airplane with the CG outside the aft CG limit and did not find any problems. I loaded the airplane up to gross weight (2800) for me, using nominal (for me) pilot and Co-pilot weights, loaded some weight in the baggage compartment and then filled up the back seats. Until I got to 2785 (if I remember right). That put the CG outside the envelope and became worse as fuel burned off. I tested the airplane in that config, again no handling problems. I did get a better break in the stalls, but that is normal as the CG moves aft. I also did my service ceiling testing in that config. (20,100). I also flew the Vans Demonstrator for my transition training... I am with Tim, you are way early in the process to be thinking about a permanent mod. I think you are taking the right step first by asking the flyers... In my early days on the list, the concern was about the forward CG...so I made some decisions during my build to move the CG aft..ELT location...O2 location..Strobe Power supply...bigger battery. things I would do a little different if I built another RV-10. I like the way the airplane handles with the CG in the aft 25% of the envelope, BUT I think it handles great on the very front of the forward CG (Vans Demo). Everything you add (except oil) when flying is aft of the forward CG limit. And, you can always add temp ballast to the baggage compartment if you want to move the CG back. Just my opinion... So...for this annual (my second one), I am putting a 680 on the firewall along with an additional contactor, mounting box, etc I will be adding 17 lbs or so. I am also putting in the Safety Trim system and an avionics cooling fan (for DVD player...quits during summer after running for 2 hours or more). Along with a little more interior work, I am hoping I will move the CG forward a little. As long as the 680 works well for the next year, I will then replace the 925 I have in back with a 680. If all of that does not move my CG forward enough, I will move the ELT up next. A little extra weight in the tail can really move the CG Aft... Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Gordon Anderson Sent: Sunday, February 28, 2010 1:45 PM Subject: RV10-List: Water ballast tank Folks, I'm about to start riveting the VS and want to put my mind to rest about W&B issues before doing so. My concern is trying to optimize the W&B so that the use of ballast, if at all required, is as easy (and light) as possible. I anticipate running into a rear CG problem with 4 passengers and baggage. I'm assuming some moderate soundproofing and interior (circa 20lbs) and the MT 3-blade prop, which both move CG rearwards. My "solution" is to move the battery forwards to the firewall. This avoids having a rear CG problem in all practical circumstances, reduces cable weight and voltage drop during starting, but increases the issue with the inadequate elevator trim when flying solo or dual. To solve that, I proposed putting a water ballast tank near the tail, instead of using the traditional shot bags used by Van's in the demonstrator. This minimizes the weight required, and would allow dumping and refilling the ballast anywhere, anytime. Vans have helped me in so much as confirming the following: 1. If loaded with a CG at front limit of 15% (ie. solo, no ballast), the plane can be landed OK with half flaps or a touch of power in the flare. 2. A comfortable CG location for landing is around 18% or rearward. 3. Structurally, putting a water ballast tank in the tail is "probably OK". The VS appeared to be the preferred location rather than the rear fuselage. The space between the lower and middle inspar ribs is the perfect volume. 4. Nothing disastrous will happen with the CG at 32%. So now I'm considering 2 options: Option 1: Move the battery forwards, add the water ballast tank (or use a lot of ballast in the baggage bay). No problem ever with the rear CG, but ballast is a must if flying solo, to keep behind 15%. Option 2: Leave the battery where it is. Accept CG back to 32%. Never need to use ballast. I would appreciate any feedback from those who are flying regularly near gross with passengers or who have the experience from flight testing. Does the plane really fly OK with a CG location slightly rear of limits? Also, if anyone can help me find the summary weight and balance table of all the finished -10's I would be grateful. The rvproject link mentioned in some messages on the forum doesn't seem to work when I try. Fly safe! Gordon Anderson Switzerland VS primed (DuPont 825R/XB383 ;-) ) ________________________________________________________________________________
Subject: does any one have a flight profile i can use on fltplan.com?
Date: Feb 28, 2010
Does anyone have a flight profile for the Rv-10 that I can use on fltplan.com? Thanks, Alan ________________________________________________________________________________
Subject: Re: OT & Cross Post - reflections on the transition from analog
Date: Feb 28, 2010
I don't see where you draw the conclusion that gps is more capable and reliable. It is true the scenario revealed a flaw in the receive equipment when the ILS transmitter system had malfunctioned, and it is true that digital systems can achieve better error control, but two points - first ILS systems are extremely reliable and very few accidents can be accredited to ILS error when the equipment is maintained and operating correctly. Second, gps can malfunction too, one example is gps signals are very susceptible to interference signals. This happens much more than the kind of example shown in the ILS incident. cjay MauleDriver(at)nc.rr.com wrote: > > Anyway, this had me reflecting on how much more capable and reliable > digital based navigation (GPS) might be compared to analog based > systems. In the above example, everything in the aircraft worked as > designed. Procedures were for the most part, followed and executed. > The automated navigation systems of the aircraft were prepared to fly it > into the ground. The collective brain of the 3 pilots (NZ designation) > was the only thing that saved a crash. Is a WAAS based overlay of the > approach susceptible to a similiar sort of failure? > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288684#288684 ________________________________________________________________________________
analog
Date: Feb 28, 2010
At least GPS has RAIM and will let you know when it is not reccieving good info. ----- Original Message ----- From: "cjay" <cgfinney(at)yahoo.com> Sent: Sunday, February 28, 2010 8:13 PM Subject: RV10-List: Re: OT & Cross Post - reflections on the transition from analog > > I don't see where you draw the conclusion that gps is more capable and > reliable. It is true the scenario revealed a flaw in the receive > equipment when the ILS transmitter system had malfunctioned, and it is > true that digital systems can achieve better error control, but two > points - first ILS systems are extremely reliable and very few accidents > can be accredited to ILS error when the equipment is maintained and > operating correctly. Second, gps can malfunction too, one example is gps > signals are very susceptible to interference signals. This happens much > more than the kind of example shown in the ILS incident. > > cjay > > > MauleDriver(at)nc.rr.com wrote: >> >> Anyway, this had me reflecting on how much more capable and reliable >> digital based navigation (GPS) might be compared to analog based >> systems. In the above example, everything in the aircraft worked as >> designed. Procedures were for the most part, followed and executed. >> The automated navigation systems of the aircraft were prepared to fly it >> into the ground. The collective brain of the 3 pilots (NZ designation) >> was the only thing that saved a crash. Is a WAAS based overlay of the >> approach susceptible to a similiar sort of failure? >> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288684#288684 > > > ________________________________________________________________________________
Subject: Ideas for external power access panel
Date: Feb 28, 2010
I'm at the point in my tail cone where I need to build in some support structure for my external power receptacle, and I can't decide where to put it. Either it'll be facing forwards in the lower-left corner of the baggage bulkhead and externally accessible through the baggage door (a la Tim Olson's), or facing downwards on the bottom of the tail cone to the left of the battery and accessible through some sort of hinged, latched panel on the bottom of the plane. I know some people have installed theirs in the latter configuration (e.g. http://showplanes.com/images/curProject_002/DSC09797_800.jpg ), but I haven't been able to find any good images of how they managed the access door and latch. Can anyone comment on this? I like the idea of being able to access the external power receptacle without having to go through the baggage door in case the baggage compartment was filled with stuff or it was raining or something like that. But I'm not wed to the idea. Any advice would be appreciated. Thanks, -Mouser RV-10 #40988 (tail cone) http://mouser.org/projects/rv-10/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288687#288687 ________________________________________________________________________________
Date: Feb 28, 2010
analog
Every ILS has a monitor for localizer and glideslope, and if they aren't functioning properly there will be a notam that the monitor is out of service and the component is unmonitored. If you lose RAIM on GPS you have no backup other than VHF equipment, assuming you aren't trying to use GPS as sole source of nav. On Sun, Feb 28, 2010 at 8:17 PM, Seano wrote: > > At least GPS has RAIM and will let you know when it is not reccieving good > info. > > ----- Original Message ----- From: "cjay" <cgfinney(at)yahoo.com> > To: > Sent: Sunday, February 28, 2010 8:13 PM > Subject: RV10-List: Re: OT & Cross Post - reflections on the transition from > analog > > >> >> I don't see where you draw the conclusion that gps is more capable and >> reliable. It is true the scenario revealed a flaw in the receive equipment >> when the ILS transmitter system had malfunctioned, and it is true that >> digital systems can achieve better error control, but two points - first ILS >> systems are extremely reliable and very few accidents can be accredited to >> ILS error when the equipment is maintained and operating correctly. Second, >> gps can malfunction too, one example is gps signals are very susceptible to >> interference signals. This happens much more than the kind of example shown >> in the ILS incident. >> >> cjay >> >> >> MauleDriver(at)nc.rr.com wrote: >>> >>> Anyway, this had me reflecting on how much more capable and reliable >>> digital based navigation (GPS) might be compared to analog based >>> systems. In the above example, everything in the aircraft worked as >>> designed. Procedures were for the most part, followed and executed. >>> The automated navigation systems of the aircraft were prepared to fly it >>> into the ground. The collective brain of the 3 pilots (NZ designation) >>> was the only thing that saved a crash. Is a WAAS based overlay of the >>> approach susceptible to a similiar sort of failure? >>> >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=288684#288684 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 28, 2010
Subject: Re: Ideas for external power access panel
mouser wrote: > > I'm at the point in my tail cone where I need to build in some > support structure for my external power receptacle, and I can't > decide where to put it. Either it'll be facing forwards in the > lower-left corner of the baggage bulkhead and externally accessible > through the baggage door (a la Tim Olson's), This is where mine will go. > or facing downwards on > the bottom of the tail cone to the left of the battery and accessible > through some sort of hinged, latched panel on the bottom of the > plane. I'm not fond of this approach. > > I know some people have installed theirs in the latter configuration > (e.g. http://showplanes.com/images/curProject_002/DSC09797_800.jpg ), > but I haven't been able to find any good images of how they managed > the access door and latch. Can anyone comment on this? A door similar to the oil door/latch??? > > I like the idea of being able to access the external power receptacle > without having to go through the baggage door in case the baggage > compartment was filled with stuff or it was raining or something like > that. But I'm not wed to the idea. Worst case scenario ..... it's raining and the baggage compartment is full. If it's in the baggage compartment, you stand under the FBO umbrella, move stuff that's in the way and plug in shore power. If it's on the belly you're on your hands and knees in the water trying to look up into the receptacle to get the plug in. And cussing yourself for putting it there. Just a thought. Linn > > Any advice would be appreciated. > > Thanks, -Mouser > > RV-10 #40988 (tail cone) http://mouser.org/projects/rv-10/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288687#288687 > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 01, 2010
I placed mine behind the baggage bulkhead panel and have a removable cover to gain access. I fabricated a small cover out of fiberglass that I molded to the corrugated bulkhead panel. I will either hinge it at the top with a latch or just use velcro to hold it in place. I want the bulkhead sealed up as best as I can to prevent air leaks into the cabin. I thought about putting it in an area with an outside door, but elected to put it inside just because. David Clifford RV-10 In Progress Empennage Done Engine Overhauled & Pickled Closing up The Wings ----- Original Message ----- From: "mouser" <mouser(at)mouser.org> Sent: Sunday, February 28, 2010 10:36:26 PM GMT -05:00 US/Canada Eastern Subject: RV10-List: Ideas for external power access panel I'm at the point in my tail cone where I need to build in some support structure for my external power receptacle, and I can't decide where to put it. Either it'll be facing forwards in the lower-left corner of the baggage bulkhead and externally accessible through the baggage door (a la Tim Olson's), or facing downwards on the bottom of the tail cone to the left of the battery and accessible through some sort of hinged, latched panel on the bottom of the plane. I know some people have installed theirs in the latter configuration (e.g. http://showplanes.com/images/curProject_002/DSC09797_800.jpg ), but I haven't been able to find any good images of how they managed the access door and latch. Can anyone comment on this? I like the idea of being able to access the external power receptacle without having to go through the baggage door in case the baggage compartment was filled with stuff or it was raining or something like that. But I'm not wed to the idea. Any advice would be appreciated. Thanks, -Mouser RV-10 #40988 (tail cone) http://mouser.org/projects/rv-10/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288687#288687 ________________________________________________________________________________
Date: Mar 01, 2010
I've always put them on the bottom of the tailcone facing down. I use a Piper Style jack (Spruce sells them, but I'd have to look up the part #). You just drill a big hole in the bottom, put in a doubler plate and two bolt holes and it connects to the positive side of the battery or the battery side of the master solenoid. The receptacle itself has a spring-loaded, hinged door. It sticks out a little bit from the bottom skin, but it should already be fairly dirty air back there because of the air coming out of the cowl and exhaust and the gear legs. I then get one of the piper plugs and put a 6" piece of cable on it with a crimp on the end (I cut off the ring part of the ring terminal). I carry that with me, so if I need to jump it or charge it, I just hook the red to the crimp and the black to the ear of the plug and I'm good to go. You don't really even have to look to get the plug in. If you decide to do this, it can easily be done later, although it doesn't hurt to do it now. YMMV, but I really like this approach, because I don't have to take anything out of the baggage area to get at it and it's very easy to hook up a trickle charger in the hangar without leaving a door open to let dirt and dust and critters into the plane. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Feb 28, 2010, at 10:36 PM, mouser wrote: > > I'm at the point in my tail cone where I need to build in some support structure for my external power receptacle, and I can't decide where to put it. Either it'll be facing forwards in the lower-left corner of the baggage bulkhead and externally accessible through the baggage door (a la Tim Olson's), or facing downwards on the bottom of the tail cone to the left of the battery and accessible through some sort of hinged, latched panel on the bottom of the plane. > > I know some people have installed theirs in the latter configuration (e.g. http://showplanes.com/images/curProject_002/DSC09797_800.jpg ), but I haven't been able to find any good images of how they managed the access door and latch. Can anyone comment on this? > > I like the idea of being able to access the external power receptacle without having to go through the baggage door in case the baggage compartment was filled with stuff or it was raining or something like that. But I'm not wed to the idea. > > Any advice would be appreciated. > > Thanks, > -Mouser > > RV-10 #40988 (tail cone) > http://mouser.org/projects/rv-10/ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=288687#288687 > > > > > > > > > > ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Mar 01, 2010
I bought a used 3prong receptacle and put it on the outside facing down as in option 2. I have use it twice and a helping person connected my 3 prong adapter to the outlet and hooked it to his car battery for an easy start. He then closed the hinged door and fastened it shut , returning to me my screwdriver . I would not chang the location . It seems best to me. Robert Sent from my iPhone Robert E. Brunkenhoefer Brunkenhoefer Law Firm, P.C. 606 N. Carancahua Street Suite 1200 Corpus Christi, Texas 78476 Phone: 361-888-8808 Facsimile: 361-888-6753 robert(at)brunklaw.com On Feb 28, 2010, at 9:57 PM, Linn Walters wrote: > > > > mouser wrote: >> I'm at the point in my tail cone where I need to build in some >> support structure for my external power receptacle, and I can't >> decide where to put it. Either it'll be facing forwards in the >> lower-left corner of the baggage bulkhead and externally accessible >> through the baggage door (a la Tim Olson's), > This is where mine will go. >> or facing downwards on >> the bottom of the tail cone to the left of the battery and accessible >> through some sort of hinged, latched panel on the bottom of the >> plane. > I'm not fond of this approach. >> I know some people have installed theirs in the latter configuration >> (e.g. http://showplanes.com/images/curProject_002/DSC09797_800.jpg ), >> but I haven't been able to find any good images of how they managed >> the access door and latch. Can anyone comment on this? > A door similar to the oil door/latch??? >> I like the idea of being able to access the external power receptacle >> without having to go through the baggage door in case the baggage >> compartment was filled with stuff or it was raining or something like >> that. But I'm not wed to the idea. > Worst case scenario ..... it's raining and the baggage compartment > is full. > If it's in the baggage compartment, you stand under the FBO > umbrella, move stuff that's in the way and plug in shore power. > If it's on the belly you're on your hands and knees in the water > trying to look up into the receptacle to get the plug in. And > cussing yourself for putting it there. > Just a thought. > Linn >> Any advice would be appreciated. >> Thanks, -Mouser >> RV-10 #40988 (tail cone) http://mouser.org/projects/rv-10/ >> Read this topic online here: >> http://forums.matronics.com/viewtopic.php?p=288687#288687 > > ________________________________________________________________________________
Date: Mar 01, 2010
I mounted an AN2552-3A power receptacle ($69 from Spruce) on the belly on the starboard side of the battery. Door on bottom. Sorry for the out of focus photo of the door, someday I'll take a better one. John -------- #40572 QB. Engine on, wing attach coming soon. Panel delivery soon. N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=288724#288724 Attachments: http://forums.matronics.com//files/dscn1471_829.jpg http://forums.matronics.com//files/dscn1473_103.jpg ________________________________________________________________________________
Date: Mar 01, 2010
Subject: Orlando area hangar recommendations
Hi All, I've got to leave my RV-10 down in Orlando, Fl area from Mar 13-21st. Anyone have recommendations for a friendly/secure hangar somewhere in that area? Thanks, Perry Casson C-FMHP Regina, Canada ________________________________________________________________________________
Subject: Re: Orlando area hangar recommendations
Date: Mar 01, 2010
You can leave it at x-35, but you'll need to leave the keys so we can keep it "warmed up" for you. Actually, you can call the airport manager & leave it in the county hangar very cheap if they have space. Phone number is on airnav or aopa. We're about 90 minutes drive from Orlando. I don't have any hangar experience closer to Orlando. Jesse Saint Saint Aviation jesse(at)saintaviation.com 352-427-0285 Sent from my iPhone On Mar 1, 2010, at 8:38 PM, Perry Casson wrote: > Hi All, > > > Ive got to leave my RV-10 down in Orlando, Fl area from Mar 13-21st > . Anyone have recommendations for a friendly/secure hangar somewher > e in that area? > > > Thanks, > > > Perry Casson C-FMHP > > Regina, Canada ________________________________________________________________________________
Date: Mar 03, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: Doing the windscreen - any last minutes tips?
Jim, just wanted to say Thanks for the detail on the jacking. I never would have tried the C-clamp thing on my own but it works great. Engine hoist on the engine mount (engine on), an oak 1.5x1.5 c-clamped to each spar, a camera tripod doing nothing back at the tail. The first pant is going on fine - might try the 2 ply supports but not having any problems there yet. I just got a laser line thingy - very cool. $30 at Sears for a 1 line device with detachable magnetic mount. Couldn't imagine exactly how to use it despite all the mentions of it's use on this list. Fool around with it for 10 minutes and it starts to seem indispensible. The centerline of the aircraft thing is a piece of cake. Bill "starting to enjoy an otherwise uncomfortable set of tasks" Watson 40605 Durham NC Jim Berry wrote: > > Bill, > > The bottle jack and short 2x4 go under the spar stubs, and are used to tweak the fuselage level side-to-side. The longer 2x4s are clamped to the aft sides of the spar stubs to help maintain the level position. It needs to be long enough to reach from the top of the spar to the floor. I used 2 C clamps per side. I jacked the spars just enough to get the main tires about 1/4" off the ground, then raised the low side a little more to bring the fuselage level. The C clamped 2x4s did a good job of maintaining that position, and showed no tendency to walk. Once you have it leveled side-to-side it is easy to tweak the engine hoist and/or tail support to get level fore and aft. > > The other thing that really helped in getting the wheel pants in position was to make 2 L-shaped jigs to hold the wheel pant level fore and aft. Basically just 2 plywood supports with one leg on the floor and the other leg perpendicular to the floor. After you establish the fore and aft level line on each wheel pant(use a laser level) you can measure the height from that line to the ground. Drill a #40 hole in the nose and tail of each pant on the level line. Drill a hole in each jig the same distance from the floor, and pin each jig to the pant with a finishing nail. You now have a way to hold the pant level and at the correct height. By moving the jigs around you have a stable way to position the pant relative to the tire and mounting bracket. Have fun. > > Jim Berry > 40482 > N15JB > > > ________________________________________________________________________________
Date: Mar 03, 2010
Bill, I am glad to hear it is working for you. Your first laser level is just the foot in the door. I started with a single line level, then a dual line, and now a 5 line level. They are kind of like hammers; more is better. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289068#289068 ________________________________________________________________________________
Subject: rudder question
From: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Date: Mar 03, 2010
I will find out when I start clecoing the skin on. But, is the second rib/stiffener supposed to be longer than the bottom rib? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289085#289085 Attachments: http://forums.matronics.com//files/img_0260_138.jpg ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Tachometer Pulses Per Minute
Date: Mar 03, 2010
Are all IO-540 engines set for 3 ppm if you are pulling the tach signal from the p-lead? And are all IO-360 engines at 2 ppm? Thanks -Mike Sent from my iPhone ________________________________________________________________________________
Subject: Re: rudder question
Date: Mar 03, 2010
I am going to guess that it is longer. As I recall that back seam has an aluminum fillet that is pro-sealed in between the skins. The lower frame accepts the fiberglass lower tail piece. I would suggest at this point that you place #6 nutplates on the tailpiece attach holes. You WILL have to remove this piece for maintainence - the screws are much easier to remove than a spinning pop rivet. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289097#289097 ________________________________________________________________________________
Subject: Balancing control surfaces - after painting
Date: Mar 03, 2010
My unpainted control surfaces seem quite well balanced, but as I look at the paint thing, I would appreciate any comments about what needed to be done after painting to re balance. I know if the controls are not balanced after painting that it can change the Vne dramatically and can put you at risk for flutter. -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289098#289098 ________________________________________________________________________________
Date: Mar 03, 2010
IIRC, it is..... If you look at the skin, you'll see how the rivet lines merge toward the aft-edge. The second rib from the bottom is angled down so they meet at the lower-aft edge of the rudder. Phil -----Original Message----- From: JHearnsberger [mailto:jakehearnsberger(at)gmail.com] Sent: Wednesday, March 03, 2010 2:19 PM Subject: RV10-List: rudder question I will find out when I start clecoing the skin on. But, is the second rib/stiffener supposed to be longer than the bottom rib? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289085#289085 Attachments: http://forums.matronics.com//files/img_0260_138.jpg ________________________________________________________________________________
Date: Mar 03, 2010
From: Aaron Gleixner <aarongleixner(at)sbcglobal.net>
Subject: Re: RV10 Transition Training
Joe,=0A=0AI am starting my search for transition training in the RV-10.- Shooting for a mid to late May first flight.- I was looking at the RVator , and noticed you will have the plane at Sun and Fun.- I am staying in Wi nter Haven nearby for Sat and Sun of Sun and Fun-and for the week followi ng on vacation with plenty of free time.- Any chance you are staying in t he FL area the week after sun and fun and available for transition training ?=0A=0AAaron- =0A=0A=0A=0A=0A________________________________=0AFrom: zac krv8 =0ATo: rv10-list(at)matronics.com=0ASent: Mon, Febru ary 8, 2010 11:57:44 AM=0ASubject: RV10-List: RV10 Transition Training=0A llow RV10 builders.....=0A=0A- - - If you are in need of RV10 Transit ion Training on the East Coast, I can help you out.- I use Van's Aircraft N220RV that is based at St Mary's airport (2W6) in Maryland.- For more i nformation, check out my website at- http://www.zackair.com/.=0A=0AThanks =0AJoe Czachorowski=0A=0A--------=0ARV8 #80125 =0ARV10 # 40512=0A=0A=0A=0A =0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic. == ________________________________________________________________________________
Date: Mar 03, 2010
Does this picture help? http://deemsrv10.com/album/Sec%207%20Rudder/slides/DSC00762.html Deems Davis N519PJ www.deemsrv10.com On 3/3/2010 1:19 PM, JHearnsberger wrote: > --> RV10-List message posted by: "JHearnsberger" > > I will find out when I start clecoing the skin on. But, is the second rib/stiffener supposed to be longer than the bottom rib? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289085#289085 > > > Attachments: > > http://forums.matronics.com//files/img_0260_138.jpg > > > ________________________________________________________________________________
Date: Mar 03, 2010
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Jake; That looks right from the picture. I don't remember specifically, but I think some of the fiberglass may fill in that little space. compare it to the plan pics again. Dr Fred 515Fw. JHearnsberger wrote: > > I will find out when I start clecoing the skin on. But, is the second rib/stiffener supposed to be longer than the bottom rib? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289085#289085 > > > Attachments: > > http://forums.matronics.com//files/img_0260_138.jpg > > > ________________________________________________________________________________
Date: Mar 03, 2010
Subject: Re: OT - EAAs Sport Aviation magazine facelift
On 3/3/2010 4:53 PM, Bill Mauledriver Watson wrote: > I still look forward to Kitplanes with one big > reservation - the 'survey' issues where they do the lists - lists of > plans built aircraft, lists of kits, lists of engines. A waste of > paper... just filler. On the other side of that coin, those are some of my favorite issues. I like to go through and look at all the various designs, specs, etc, and drool a bit... :-) -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Subject: Re: Tachometer Pulses Per Minute
Date: Mar 03, 2010
For 4 cycle engines: 6 cylinder engines will have 3 mag firings per revolution. 4 cylinder engines will have 2 mag firings per revolution. Is that what you asked? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289158#289158 ________________________________________________________________________________
Subject: OT - EAAs Sport Aviation magazine facelift
Date: Mar 04, 2010
I totally agree with Michael. Those three issues are almost content free in my opinion. They should maintain these lists on their web site. Or do like some other industries and produce an annual buyer's guide to give to new subscribers. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen) Sent: Thursday, March 04, 2010 9:21 AM Subject: RE: RV10-List: OT - EAAs Sport Aviation magazine facelift I don't mind them too much but I wish they were addendum's or maybe just online. I feel like I lose a month of content every time one of the "list" issues comes out and I believe they are up to three a year now. Marc tends to watch these high activity lists so hopefully he sees some of the feedback. Michael ________________________________________________________________________________
Subject: Good deal on Unibits at Napa
Date: Mar 04, 2010
Just thought I would throw this out there if anybody is building their too l kit and needs unibits. Napa has a sale on part # VG 3018008 which contai ns Unibit #1 (1/8 - 1/2) and unibit # 4 (3/16 - 7/8) and 7 turbomax drill bits all for $45.00. I think I paid almost that for the #3 that came with my tool kit. I just got mine today and it comes in a nice case also. The sale is good till the end of March but I believe it is a closeout . I st ill marvel how easy unibits make holes in sheet metal compared to regular drill bits. Jeff Nichols #40648 Working on the fuselage ________________________________________________________________________________
Date: Mar 04, 2010
I am having trouble getting the bottom rib to lay flush against the skin. I clamped the rib to a straight edge when drilling the two pieces of the rib together. But, the flange on the spar is a good bit higher than the rib. I have tried using fluting pliers and other bending tools to get the two flanges even with each other. This would be on the right side. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289224#289224 ________________________________________________________________________________
Date: Mar 04, 2010
Jake, Check that your R-1010A Sheer Clip is oriented correctly. (That is short flange pointed up - not down). If any of the sheer clips are pointed down, it will cause the associated rib/skin holes to be misaligned. Phil -----Original Message----- From: JHearnsberger [mailto:jakehearnsberger(at)gmail.com] Sent: Thursday, March 04, 2010 11:18 AM Subject: RV10-List: Re: rudder question I am having trouble getting the bottom rib to lay flush against the skin. I clamped the rib to a straight edge when drilling the two pieces of the rib together. But, the flange on the spar is a good bit higher than the rib. I have tried using fluting pliers and other bending tools to get the two flanges even with each other. This would be on the right side. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289224#289224 ________________________________________________________________________________
Subject: Re: Good deal on Unibits at Napa
Date: Mar 04, 2010
$12 at Harbor freight. Worked fine for me the whole time, a mechanic once brought his professional unibit over and he couldn't tell the difference other than that he "felt" it might be a little faster to make holes but in the end he conceded that the HF works. I say spend the money on drill bits however, there is a difference there. From: nicholscatoauto(at)aol.com Sent: Thursday, March 04, 2010 8:28 AM Subject: RV10-List: Good deal on Unibits at Napa Just thought I would throw this out there if anybody is building their tool kit and needs unibits. Napa has a sale on part # VG 3018008 which contains Unibit #1 (1/8 - 1/2) and unibit # 4 (3/16 - 7/8) and 7 turbomax drill bits all for $45.00. I think I paid almost that for the #3 that came with my tool kit. I just got mine today and it comes in a nice case also. The sale is good till the end of March but I believe it is a closeout . I still marvel how easy unibits make holes in sheet metal compared to regular drill bits. Jeff Nichols #40648 Working on the fuselage ________________________________________________________________________________
Date: Mar 04, 2010
I went both routes and found the following with one of the the HF unibits. After repeated use in several different materials, I notice that suddenly, it stopped cutting. It appeared (to my untrained eye) that the bit had a very hard but thin surface. It cut as well as the higher priced unibit up to that point. Then, once it wore through the thin hard coating, it became worthless. Can anyone validate such an observation? Of course I simply grabbed one of the other unibits that came in the same $12 package and I still had the high priced bit in reserve. Whatever the difference, the HF bits seem like a good deal. They'll work until they don't, then you can replace them, twice, for the price of the high dollar bits. Bill "still cutting holes" Watson Pascal wrote: > $12 at Harbor freight. Worked fine for me the whole time, a mechanic > once brought his professional unibit over and he couldn't tell the > difference other than that he "felt" it might be a little faster to > make holes but in the end he conceded that the HF works. > I say spend the money on drill bits however, there is a difference there. > > > *From:* nicholscatoauto(at)aol.com > *Sent:* Thursday, March 04, 2010 8:28 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Good deal on Unibits at Napa > > Just thought I would throw this out there if anybody is building their > tool kit and needs unibits. Napa has a sale on part # VG 3018008 which > contains Unibit #1 (1/8 - 1/2) and unibit # 4 (3/16 - 7/8) and 7 > turbomax drill bits all for $45.00. I think I paid almost that for the > #3 that came with my tool kit. I just got mine today and it comes in a > nice case also. The sale is good till the end of March but I believe > it is a closeout . I still marvel how easy unibits make holes in > sheet metal compared to regular drill bits. > > Jeff Nichols > #40648 > Working on the fuselage > ________________________________________________________________________________
Subject: Van's FWF hoses - life limits - replacement
Date: Mar 04, 2010
I was wondering if the Vans supplied hoses on the FWF kit are the newer Teflon hose or the old rubber style. From what I understand the: Rubber lined hoses need to be replaced every 5 years Teflon lined hoses never need replacement I sent an e-mail to Vans asking them about this, and Ken Scott replied that the hoses are Teflon but did state anything about life limits. Any intelligent comments appreciated............ -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289265#289265 ________________________________________________________________________________
Date: Mar 04, 2010
On their web site, NAPA wants 74.99 for this set. Bill From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Thursday, March 04, 2010 1:31 PM Subject: Re: RV10-List: Good deal on Unibits at Napa $12 at Harbor freight. Worked fine for me the whole time, a mechanic once brought his professional unibit over and he couldn't tell the difference other than that he "felt" it might be a little faster to make holes but in the end he conceded that the HF works. I say spend the money on drill bits however, there is a difference there. From: nicholscatoauto(at)aol.com Sent: Thursday, March 04, 2010 8:28 AM Subject: RV10-List: Good deal on Unibits at Napa Just thought I would throw this out there if anybody is building their tool kit and needs unibits. Napa has a sale on part # VG 3018008 which contains Unibit #1 (1/8 - 1/2) and unibit # 4 (3/16 - 7/8) and 7 turbomax drill bits all for $45.00. I think I paid almost that for the #3 that came with my tool kit. I just got mine today and it comes in a nice case also. The sale is good till the end of March but I believe it is a closeout . I still marvel how easy unibits make holes in sheet metal compared to regular drill bits. Jeff Nichols #40648 Working on the fuselage href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 04, 2010
Subject: Re: Van's FWF hoses - life limits - replacement
AirMike wrote: > > I was wondering if the Vans supplied hoses on the FWF kit are the newer Teflon hose or the old rubber style. From what I understand the: > > Rubber lined hoses need to be replaced every 5 years > instead of 'need to be' say 'recommended'. Kinda like TBO. The rub ber hoses have lasted over 30 years ..... as long as you don't move them. They do get brittle. > Teflon lined hoses never need replacement > Never say 'never', but the lifespan is a lot longer than the rubber hoses. Teflon hoses will also take a set with age. They may not get brittle ..... but I don't think there's any empirical data. Linn > I sent an e-mail to Vans asking them about this, and Ken Scott replied that the hoses are Teflon but did state anything about life limits. > Any intelligent comments appreciated............ > > -------- > OSH '10 or Bust > Q/B - testing phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289265#289265 > > > ________________________________________________________________________________
Date: Mar 04, 2010
Teflon hose is IRAN - "Inspect and replace as needed". I am still searchin g for ""Lifetime hoses,belts, seals and universal joints". I have conclude d their life limit is known when they fail in flight. YMMV. John Cox From: AirMike Sent: Thu 3/4/2010 3:43 PM Subject: RV10-List: Van's FWF hoses - life limits - replacement I was wondering if the Vans supplied hoses on the FWF kit are the newer Tef lon hose or the old rubber style. From what I understand the: Rubber lined hoses need to be replaced every 5 years Teflon lined hoses never need replacement I sent an e-mail to Vans asking them about this, and Ken Scott replied that the hoses are Teflon but did state anything about life limits. Any intelligent comments appreciated............ -------- OSH '10 or Bust Q/B - testing phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289265#289265 ________________________________________________________________________________
Date: Mar 04, 2010
I put teflon hoses with integral firesleeve on my Mooney 8 years ago. They are still fine. No deterioration noted., All you need from Vans is the part number of the hose they supply and you can tell what it is. >From the web store: "The fuel supply hoses have integral fireshields." Only teflon hoses are available with integral fireshield, so those are okay. I'd want to know about the oil hoses as well. On Thu, Mar 4, 2010 at 5:10 PM, Linn Walters wrote: > > Never say 'never', but the lifespan is a lot longer than the rubber hoses. > Teflon hoses will also take a set with age. They may not get brittle ..... > but I don't think there's any empirical data. > Linn > >> I sent an e-mail to Vans asking them about this, and Ken Scott replied >> that the hoses are Teflon but did state anything about life limits. >> Any intelligent comments appreciated............ >> >> -------- >> OSH '10 or Bust Q/B - testing phase 1 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=289265#289265 >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 04, 2010
It is in their tool and equipment sale catalog. I think you may have to ca ll or stop by a store to get the special. I called to order mine. -----Original Message----- From: William Greenley <wgreenley(at)gmail.com> Sent: Thu, Mar 4, 2010 5:39 pm Subject: RE: RV10-List: Good deal on Unibits at Napa On their web site, NAPA wants 74.99 for this set. Bill From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Pascal Sent: Thursday, March 04, 2010 1:31 PM Subject: Re: RV10-List: Good deal on Unibits at Napa $12 at Harbor freight. Worked fine for me the whole time, a mechanic once brought his professional unibit over and he couldn't tell the difference other than that he "felt" it might be a little faster to make holes but in the end he conceded that the HF works. I say spend the money on drill bits however, there is a difference there. From: nicholscatoauto(at)aol.com Sent: Thursday, March 04, 2010 8:28 AM Subject: RV10-List: Good deal on Unibits at Napa Just thought I would throw this out there if anybody is building their too l kit and needs unibits. Napa has a sale on part # VG 3018008 which contai ns Unibit #1 (1/8 - 1/2) and unibit # 4 (3/16 - 7/8) and 7 turbomax drill bits all for $45.00. I think I paid almost that for the #3 that came with my tool kit. I just got mine today and it comes in a nice case also. The sale is good till the end of March but I believe it is a closeout . I st ill marvel how easy unibits make holes in sheet metal compared to regular drill bits. Jeff Nichols #40648 Working on the fuselage href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ======================== =========== -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Date: Mar 04, 2010
Aaron, 220RV will be flown to SNF by pilots from Vans. While there, the RV10 will only be used for demo rides, not transition training. Sorry. It should be back in Maryland a few days after SNF concludes. I can help you out after that, but at St Marys airport only. Joe [quote="aarongleixner(at)sbcgloba"]Joe, I am starting my search for transition training in the RV-10. Shooting for a mid to late May first flight. I was looking at the RVator, and noticed you will have the plane at Sun and Fun. I am staying in Winter Haven nearby for Sat and Sun of Sun and Fun and for the week following on vacation with plenty of free time. Any chance you are staying in the FL area the week after sun and fun and available for transition training? Aaron From: zackrv8 Sent: Mon, February 8, 2010 11:57:44 AM Subject: RV10 Transition Training Fellow RV10 builders..... If you are in need of RV10 Transition Training on the East Coast, I can help you out. I use Van's Aircraft N220RV that is based at St Mary's airport (2W6) in Maryland. For more information, check out my website at http://www.zackair.com/. Thanks Joe Czachorowski -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=285378#285378 > [b] -------- RV8 #80125 RV10 # 40512 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289293#289293 ________________________________________________________________________________
Subject: fuel dipstick
Date: Mar 05, 2010
Has any one made a calibrated fuel dipstick? Alan ________________________________________________________________________________
Subject: Re: fuel dipstick
Date: Mar 05, 2010
I made one and use it every time I fly. I check it against the numbers on my fueal flow guage. Robert Sent from my iPhone Robert E. Brunkenhoefer Brunkenhoefer Law Firm, P.C. 606 N. Carancahua Street Suite 1200 Corpus Christi, Texas 78476 Phone: 361-888-8808 Facsimile: 361-888-6753 robert(at)brunklaw.com On Mar 5, 2010, at 4:31 AM, Alan Mekler wrote: > Has any one made a calibrated fuel dipstick? > > > Alan > > ________________________________________________________________________________
Date: Mar 05, 2010
Robert, Do you mind sharing what you used? Alan Sent from my iPod On Mar 5, 2010, at 10:08 AM, Robert Brunkenhoefer wrote: > I made one and use it every time I fly. I check it against the > numbers on my fueal flow guage. Robert > > Sent from my iPhone > > Robert E. Brunkenhoefer > Brunkenhoefer Law Firm, P.C. > 606 N. Carancahua Street > Suite 1200 > Corpus Christi, Texas 78476 > Phone: 361-888-8808 > Facsimile: 361-888-6753 > robert(at)brunklaw.com > > On Mar 5, 2010, at 4:31 AM, Alan Mekler wrote: > >> Has any one made a calibrated fuel dipstick? >> >> >> >> Alan >> >> >> >> >> >> > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Mar 05, 2010
VGhlIEF1Z3VzdCAyMDA1IGlzc3VlIG9mIFNwb3J0IEF2aWF0aW9uIGhhZCBhIGdvb2QgYXJ0aWNs ZSBvbiBob3cgdG8gbWFrZSBvbmUuDQoNCk1pY2hhZWwNCg0KRnJvbTogb3duZXItcnYxMC1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tXSBPbiBCZWhhbGYgT2YgQWxhbg0KU2VudDogRnJpZGF5LCBNYXJjaCAwNSwgMjAx MCAxMDozNyBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYx MC1MaXN0OiBmdWVsIGRpcHN0aWNrDQoNClJvYmVydCwNCkRvIHlvdSBtaW5kIHNoYXJpbmcgd2hh dCB5b3UgdXNlZD8NCkFsYW4NCg0KU2VudCBmcm9tIG15IGlQb2QNCg0KT24gTWFyIDUsIDIwMTAs IGF0IDEwOjA4IEFNLCBSb2JlcnQgQnJ1bmtlbmhvZWZlciA8cm9iZXJ0YnJ1bmtAbWFjLmNvbTxt YWlsdG86cm9iZXJ0YnJ1bmtAbWFjLmNvbT4+IHdyb3RlOg0KSSBtYWRlIG9uZSBhbmQgdXNlIGl0 IGV2ZXJ5IHRpbWUgSSBmbHkuIEkgY2hlY2sgaXQgYWdhaW5zdCB0aGUgbnVtYmVycyBvbiBteSBm dWVhbCBmbG93IGd1YWdlLiBSb2JlcnQNCg0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpSb2JlcnQg RS4gQnJ1bmtlbmhvZWZlcg0KQnJ1bmtlbmhvZWZlciBMYXcgRmlybSwgUC5DLg0KNjA2IE4uIENh cmFuY2FodWEgU3RyZWV0DQpTdWl0ZSAxMjAwDQpDb3JwdXMgQ2hyaXN0aSwgVGV4YXMgNzg0NzYN ClBob25lOiAzNjEtODg4LTg4MDgNCkZhY3NpbWlsZTogMzYxLTg4OC02NzUzDQpyb2JlcnRAYnJ1 bmtsYXcuY29tPG1haWx0bzpyb2JlcnRAYnJ1bmtsYXcuY29tPg0KDQpPbiBNYXIgNSwgMjAxMCwg YXQgNDozMSBBTSwgQWxhbiBNZWtsZXIgPGFtZWtsZXJAbWV0cm9jYXN0Lm5ldDxtYWlsdG86YW1l a2xlckBtZXRyb2Nhc3QubmV0Pj4gd3JvdGU6DQpIYXMgYW55IG9uZSBtYWRlICBhIGNhbGlicmF0 ZWQgZnVlbCBkaXBzdGljaz8NCg0KQWxhbg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRo ZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0K Xy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBT YW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpf LT0NCg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpf LT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Date: Mar 05, 2010
fuelhawk markd with a sharpie at 5 gallon increments. fuelhawk from pilot shop. On Mar 5, 2010, at 10:37 AM, Alan wrote: > Robert, > Do you mind sharing what you used? > Alan > > Sent from my iPod > > On Mar 5, 2010, at 10:08 AM, Robert Brunkenhoefer > wrote: > >> I made one and use it every time I fly. I check it against the >> numbers on my fueal flow guage. Robert >> >> Sent from my iPhone >> >> Robert E. Brunkenhoefer >> Brunkenhoefer Law Firm, P.C. >> 606 N. Carancahua Street >> Suite 1200 >> Corpus Christi, Texas 78476 >> Phone: 361-888-8808 >> Facsimile: 361-888-6753 >> robert(at)brunklaw.com >> >> On Mar 5, 2010, at 4:31 AM, Alan Mekler >> wrote: >> >>> Has any one made a calibrated fuel dipstick? >>> >>> >>> >>> Alan >>> >>> >>> >>> >>> >>> > > ________________________________________________________________________________
Date: Mar 05, 2010
great reference! question I have is how did those who calibrated the fuel do it one gallon at a time? 60x 1 gallon jugs, every 5 gallons would probably be fine upto 25 gallons per side.. thanks! Pascal From: RV Builder (Michael Sausen) Sent: Friday, March 05, 2010 11:13 AM Subject: RE: RV10-List: fuel dipstick The August 2005 issue of Sport Aviation had a good article on how to make one. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Sent: Friday, March 05, 2010 10:37 AM Subject: Re: RV10-List: fuel dipstick Robert, Do you mind sharing what you used? Alan Sent from my iPod On Mar 5, 2010, at 10:08 AM, Robert Brunkenhoefer wrote: I made one and use it every time I fly. I check it against the numbers on my fueal flow guage. Robert Sent from my iPhone Robert E. Brunkenhoefer Brunkenhoefer Law Firm, P.C. 606 N. Carancahua Street Suite 1200 Corpus Christi, Texas 78476 Phone: 361-888-8808 Facsimile: 361-888-6753 robert(at)brunklaw.com On Mar 5, 2010, at 4:31 AM, Alan Mekler wrote: Has any one made a calibrated fuel dipstick? Alan =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 - List Contribution Web =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 =C2 ======================= ~=B2=03 ________________________________________________________________________________
Date: Mar 05, 2010
I can't see how a dip stick is beneficial. I've tried it won't measure any fuel less than 15 gallons per side. The AFS 3500 fuel totalizer is accurate to .5 gallon. During flight test bothe tanks showed fuel burned at 29.5 as the engine sputtered. You can't ask for much better than that. FWIW though I Still flight plan at 15 gph fuel burn and pick a must land point if the EFIS craps out. Can't totally give up on the basics Rick On Mar 5, 2010, at 3:38 PM, "Pascal" wrote: > great reference! > question I have is how did those who calibrated the fuel do it one > gallon at a time? 60x 1 gallon jugs, every 5 gallons would probably > be fine upto 25 gallons per side.. > thanks! > Pascal > > From: RV Builder (Michael Sausen) > Sent: Friday, March 05, 2010 11:13 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: fuel dipstick > > The August 2005 issue of Sport Aviation had a good article on how to > make one. > > > Michael > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- > server(at)matronics.com] On Behalf Of Alan > Sent: Friday, March 05, 2010 10:37 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: fuel dipstick > > > Robert, > > Do you mind sharing what you used? > > Alan > > > Sent from my iPod > > > On Mar 5, 2010, at 10:08 AM, Robert Brunkenhoefer > wrote: > > I made one and use it every time I fly. I check it against the > numbers on my fueal flow guage. Robert > > Sent from my iPhone > > > Robert E. Brunkenhoefer > > Brunkenhoefer Law Firm, P.C. > > 606 N. Carancahua Street > > Suite 1200 > > Corpus Christi, Texas 78476 > > Phone: 361-888-8808 > > Facsimile: 361-888-6753 > > robert(at)brunklaw.com > > > On Mar 5, 2010, at 4:31 AM, Alan Mekler wrote: > > Has any one made a calibrated fuel dipstick? > > > Alan > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > =C2~=C2=B2=03 > > ________________________________________________________________________________
Date: Mar 05, 2010
what i did was pour 5 gallons in and mark . when i got to 25 gallons i poured 1 gallon at a time and marked the full mark at full tanks top of filler and the measured number of gallons total. my measurement of the last 10 gallons before empty is done by sliding the dip stick straight down to the bottom until it touches always holding the stick against the back side of the filler hole. . i get consistent and accurate measurements that way. between marks i estimate the gallons and check it against the fuel monitor and the float gauge i have installed which gauges each tank separately. it is a 2 tank EI instrument.. i am confident in this system. the float gauge only 30 gallons until at/or below 15 gallons or so. but at these levels to empty i found it to be right on. i tested it by draining the tanks 5 gallons at a time then 1 gallon for the last 5 gallons for each tank. robert. On Mar 5, 2010, at 5:38 PM, Pascal wrote: > great reference! > question I have is how did those who calibrated the fuel do it one > gallon at a time? 60x 1 gallon jugs, every 5 gallons would probably > be fine upto 25 gallons per side.. > thanks! > Pascal > > From: RV Builder (Michael Sausen) > Sent: Friday, March 05, 2010 11:13 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: fuel dipstick > > The August 2005 issue of Sport Aviation had a good article on how to > make one. > > Michael > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Alan > Sent: Friday, March 05, 2010 10:37 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: fuel dipstick > > Robert, > Do you mind sharing what you used? > Alan > > Sent from my iPod > > On Mar 5, 2010, at 10:08 AM, Robert Brunkenhoefer > wrote: > > I made one and use it every time I fly. I check it against the > numbers on my fueal flow guage. Robert > > Sent from my iPhone > > Robert E. Brunkenhoefer > Brunkenhoefer Law Firm, P.C. > 606 N. Carancahua Street > Suite 1200 > Corpus Christi, Texas 78476 > Phone: 361-888-8808 > Facsimile: 361-888-6753 > robert(at)brunklaw.com > > On Mar 5, 2010, at 4:31 AM, Alan Mekler wrote: > > Has any one made a calibrated fuel dipstick? > > Alan > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > ~=B2=03 > > ________________________________________________________________________________
Subject: sealing trailing edge
Date: Mar 06, 2010
Can I use any of these products or do I need to order something special? I am ready to seal up the rudder. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289401#289401 Attachments: http://forums.matronics.com//files/img_0283_281.jpg http://forums.matronics.com//files/img_0282_493.jpg http://forums.matronics.com//files/img_0281_189.jpg ________________________________________________________________________________
Date: Mar 06, 2010
Subject: Re: sealing trailing edge
The pictures are of Permetex gasket products, used in engine assembly. They're not made to seal up the rudder. What you need is called 'proseal' and is found here: http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1267916071-182-15&browse=misc&product=proseal. Same stuff used for the fuel tanks. Linn JHearnsberger wrote: > > Can I use any of these products or do I need to order something special? I am ready to seal up the rudder. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289401#289401 > > > Attachments: > > http://forums.matronics.com//files/img_0283_281.jpg > http://forums.matronics.com//files/img_0282_493.jpg > http://forums.matronics.com//files/img_0281_189.jpg > > > ________________________________________________________________________________
Date: Mar 06, 2010
I would recommend that you buy a 3 oz kit of the Flame Master tank sealant from Vans for this. It is what they recommend and it will give you some experience using it before you get to your tanks. The sealant will hold the edge of the rudder straight as an arrow and I don't know if what you are looking at would work as well. It is also used building the wings on the trailing edges of the aileron's and flaps. David Clifford RV-10 In Progress Empennage Done Engine Overhauled & Pickled Closing up The Wings ----- Original Message ----- From: "JHearnsberger" <jakehearnsberger(at)gmail.com> Sent: Saturday, March 6, 2010 5:46:19 PM GMT -05:00 US/Canada Eastern Subject: RV10-List: sealing trailing edge Can I use any of these products or do I need to order something special? I am ready to seal up the rudder. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289401#289401 Attachments: http://forums.matronics.com//files/img_0283_281.jpg http://forums.matronics.com//files/img_0282_493.jpg http://forums.matronics.com//files/img_0281_189.jpg ________________________________________________________________________________
Date: Mar 06, 2010
OK, thanks. I was hoping I would not have to wait before finishing up the rudder. I wanted to take advantage of this beautiful Saturday while I can. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289406#289406 ________________________________________________________________________________
Date: Mar 06, 2010
Get 2 or 3 of the 1 oz kits. One for rudder, one for trim tabs and one for horizontal stab, if I recall correctly. You don't need more than 1 oz at a time until you get to fuel tanks. On Sat, Mar 6, 2010 at 4:03 PM, wrote: > I would recommend that you buy a 3 oz kit of the Flame Master tank sealant > from Vans for this. It is what they recommend and it will give you some > experience using it before you get to your tanks. The sealant will hold the > edge of the rudder straight as an arrow and I don't know if what you are > looking at would work as well. It is also used building the wings on the > trailing edges of the aileron's and flaps. > > David Clifford > > RV-10 In Progress > Empennage Done > Engine Overhauled & Pickled > Closing up The Wings > > ----- Original Message ----- > From: "JHearnsberger" <jakehearnsberger(at)gmail.com> > To: rv10-list(at)matronics.com > Sent: Saturday, March 6, 2010 5:46:19 PM GMT -05:00 US/Canada Eastern > Subject: RV10-List: sealing trailing edge > > > > Can I use any of these products or do I need to order something special? I > am ready to seal up the rudder. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289401#289401 > > > Attachments: > > http://forums.matronics.com//files/img_0283_281.jpg > http://forums.matronics.com//files/img_0282_493.jpg > > ________________________________________________________________________________
Date: Mar 06, 2010
Get use to waiting for product, it's part of the build process. You will never know what you need until you need it. But it's all fun anyway> Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289411#289411 ________________________________________________________________________________
Date: Mar 06, 2010
You can probably get a pt of CS3204 B2 from Sacramento Sky Ranch faster than from Vans, and less money. http://tinyurl.com/yas9een On Sat, Mar 6, 2010 at 4:58 PM, Ron B. wrote: > > Get use to waiting for product, it's part of the build process. You will never know what you need until you need it. But it's all fun anyway> > Ron > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289411#289411 > > ________________________________________________________________________________
Date: Mar 06, 2010
SSBkaWRuJ3QgdXNlIGFueXRoaW5nIHRvIGhvbGQgdGhlIHJ1ZGRlciBURSB0b2dldGhlciB3aGls ZSByaXZldGluZy4gSW5zdGVhZCwgSSBjbGVjb2VkIGV2ZXJ5IG90aGVyIGhvbGUgZG93biB0byBh IHBpZWNlIG9mIGhlYXZ5IGFuZ2xlIGlyb24gKHRvIGtlZXAgaXQgcGVyZmVjdGx5IHN0cmFpZ2h0 KSBhbmQgYmFjayByaXZldGVkIGJldHdlZW4gdGhlIGNsZWNvcy4gIFRoaXMgZm9ybWVkIGEgc3Ry YWlnaHQgVEUsIHRoZW4gSSBjb3VsZCBiYWNrIHJpdmV0IHRoZSBob2xlcyB0aGF0IG9yaWdpbmFs bHkgaGVsZCBjbGVjb3MuIA0KDQpDaGVja2luZyB0aGUgVEUgd2l0aCBhIHN0cmFpZ2h0IGVkZ2Ug c2hvd3MgbGVzcyB0aGFuIGEgMS8xNiIgZGV2aWF0aW9uIGZyb20gcGVyZmVjdGx5IHN0cmFpZ2h0 LiBJJ2xsIGJldCBpdHMgY2xvc2VyIHRvIDEvMzIiLiANCg0KUGhpbA0KDQotLS0tLSBPcmlnaW5h bCBNZXNzYWdlIC0tLS0tDQpGcm9tOiBKSGVhcm5zYmVyZ2VyIDxqYWtlaGVhcm5zYmVyZ2VyQGdt YWlsLmNvbT4NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSA8cnYxMC1saXN0QG1hdHJvbmlj cy5jb20+DQpTZW50OiBTYXQgTWFyIDA2IDE0OjQ2OjE5IDIwMTANClN1YmplY3Q6IFJWMTAtTGlz dDogc2VhbGluZyB0cmFpbGluZyBlZGdlDQoNCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQg Ynk6ICJKSGVhcm5zYmVyZ2VyIiA8amFrZWhlYXJuc2JlcmdlckBnbWFpbC5jb20+DQoNCkNhbiBJ IHVzZSBhbnkgb2YgdGhlc2UgcHJvZHVjdHMgb3IgZG8gSSBuZWVkIHRvIG9yZGVyIHNvbWV0aGlu ZyBzcGVjaWFsPyAgSSBhbSByZWFkeSB0byBzZWFsIHVwIHRoZSBydWRkZXIuDQoNCg0KDQoNClJl YWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t L3ZpZXd0b3BpYy5waHA/cD0yODk0MDEjMjg5NDAxDQoNCg0KDQoNCkF0dGFjaG1lbnRzOiANCg0K aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tLy9maWxlcy9pbWdfMDI4M18yODEuanBnDQpodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20vL2ZpbGVzL2ltZ18wMjgyXzQ5My5qcGcNCmh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbS8vZmlsZXMvaW1nXzAyODFfMTg5LmpwZw0KDQoNCg0KDQpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0gVXNlIHRo ZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0gdGhlIG1h bnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPSBBcmNo aXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8tPSBQaG90 b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KXy09DQpfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAg ICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFs c28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0gTGlzdCBD b250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMg c3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwg TGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PQ0KDQoNCg0K ________________________________________________________________________________
Date: Mar 06, 2010
But what did you use for primer? ;-)) On Sat, Mar 6, 2010 at 7:49 PM, Perry, Phil wrote: > I didn't use anything to hold the rudder TE together while riveting. > Instead, I clecoed every other hole down to a piece of heavy angle iron (to > keep it perfectly straight) and back riveted between the clecos. This > formed a straight TE, then I could back rivet the holes that originally held > clecos. > > Checking the TE with a straight edge shows less than a 1/16" deviation from > perfectly straight. I'll bet its closer to 1/32". > > Phil ________________________________________________________________________________
Subject: starter wire routing
Date: Mar 06, 2010
I'm not liking the way the #2 AWG wire bends at the starter end when routing it from the FW on top of the oil sump. The way it is now, I'd think the ring terminal would snap as it doesn't have any strain relief. Does anyone have any photos of their routing to share? Maybe I should look for a 90 degree ring terminal instead of the straight one I'm using now. Thanks in advance for replies. Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289444#289444 ________________________________________________________________________________
Date: Mar 06, 2010
go to home depot or lowes and get PL-2000 works for this. It was really easy to use using a caulk gun and cost like $3.96. no need to wait for something like this. AS far as the comments about the flamemaster (proseal) talk sealant, the stuff smells and is really sticky, use a ziplock or something else to squeeze it, I didn't< I used Q-tips and less than a can to do all the tanks. No leaks from using only what is needed. Practice is good advice but I might suggest doing it before doing the tanks not way before and along the way, although it can't hurt. Oh and if it gets on any of your clothes don't waste time trying to clean up with MEK again really smelly and toxic to the skin. Another reason to avoid using tank sealant for anything but the tanks. Best of success with the trailing edge- use a L bracket clecoed to keep it straight as an arrow. Check out the archives, everything I mentioned for doing the trainling edges was covered by Les Kearney a couple of years ago. -------------------------------------------------- From: "JHearnsberger" <jakehearnsberger(at)gmail.com> Sent: Saturday, March 06, 2010 3:32 PM Subject: RV10-List: Re: sealing trailing edge > > > OK, thanks. I was hoping I would not have to wait before finishing up the > rudder. I wanted to take advantage of this beautiful Saturday while I > can. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=289406#289406 > > > ________________________________________________________________________________
Date: Mar 06, 2010
Same as Phil, I did not use anything to hold the rudder TE. Rolled the edges with Cleaveland edge forming tool before and back riveted on flat iron. Came out straight. On Mar 6, 2010, at 8:49 PM, Perry, Phil wrote: > I didn't use anything to hold the rudder TE together while riveting. Instead, I clecoed every other hole down to a piece of heavy angle iron (to keep it perfectly straight) and back riveted between the clecos. This formed a straight TE, then I could back rivet the holes that originally held clecos. > > Checking the TE with a straight edge shows less than a 1/16" deviation from perfectly straight. I'll bet its closer to 1/32". > > Phil ________________________________________________________________________________
Date: Mar 06, 2010
Hey Jake, A search for "PL-2000" turned up nothing ... probably meant PL-200 ? Party on. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Avionics in, engine started! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=289453#289453 ________________________________________________________________________________
Subject: Overhead switch panel finalized
Date: Mar 06, 2010
The little stuff takes as long as the big stuff. /9j/4R3BRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNi40ADIwMTA6MDM6MDYgMjA6MzQ6MzcATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA BQAAAAEAAALgkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAEAAAkgoABQAAAAEAAALo knwABwAABDYAAALwkoYABwAAAH0AAAcmoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAogoAMABAAAAAEAAAeYowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAAAAEAAAAApAIAAwAA AAEAAAAApAMAAwAAAAEAAAAApAQABQAAAAEAAAekpAUAAwAAAAEAHAAApAYAAwAAAAEAAAAApAgA AwAAAAEAAAAApAkAAwAAAAEAAAAApAoAAwAAAAEAAAAApAwAAwAAAAEAAAAAAAAAAAAAAAoAAABH AAAAHAAAAAowMDAwOjAwOjAwIDAwOjAwOjAwADAwMDA6MDA6MDAgMDA6MDA6MDAAAAAAAgAAAAEA AAAAAAAACgAAAB4AAAAKAAAAOgAAAApOaWtvbgACAAAASUkqAAgAAAAYAAEABwAEAAAAAAIAAAIA AwACAAAAAAAAAAMAAgAGAAAALgEAAAQAAgAHAAAANAEAAAUAAgANAAAAPAEAAAYAAgAHAAAASgEA AAcAAgAHAAAAUgEAAAgAAgAIAAAAWgEAAAoABQABAAAAYgEAAA8AAgAHAAAAagEAABAABwDuAQAA cgEAABEABAABAAAAwgMAAIAAAgAOAAAAYAMAAIIAAgANAAAAbgMAAIUABQABAAAAfAMAAIYABQAB AAAAhAMAAIgABwAEAAAAAAAAAI8AAgAQAAAAjAMAAJQACAABAAAAAAAAAJUAAgAFAAAAnAMAAJsA AQACAAAAAAAAAJwAAgAUAAAAogMAAJ0AAwABAAAAAAAAAJ4ABwAKAAAAtgMAAAAAAABDT0xPUgBO T1JNQUwAAEFVVE8gICAgICAgIAAAQVVUTyAgAABBRi1DICAAACAgICAgICAAUCMAAOgDAABBVVRP ICAAAAUCAAAAAAAAAAAAAQAAGWESMQAAgdEAABReAADhFgABwiwAAcIsAADhGQACI1oAZACDADIA HQAAAAAAAAAAAAAAAAAAAAAcFgAAAAAAAAAAAAAAAACAWQoAAEgDGuwAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAiIiIiIiIiIiIiIiIiIiIiEREREQFrA6ED7QGGAgIB3gH0AgABAuBgAAEDUgAAAA8A HgAQAAUABQAAAAAAHgAQAAAAAAAAAAAAgwFHAdQCYAMKAgIBLwICAmEAAAwTDPUAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIiQAAPyAAArAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAmIBHgAAAAAAAAAAAAAD8gEAAAABHgEvAZsCPAJiAk4AAAAAAhcCvQWgBVcFSgTO AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHd3d3dEGUQpRCkQHg4XWgBZBEYBAB0bAAAAHgY8BwzlIhsAZBYt AAAeJiEsAdUBfwFnA7cAAABTAAwABwHeAfRmZmZmAAAACAAAAAkAAAAKQVVUTyAgICAgICAgIABP RkYgICAgICAgICAAAAAAAAAAAAAAZAAAAGQAAAAgICAgICAgICAgICAgICAAT0ZGIAAAICAgICAg ICAgICAgICAgICAgIAAAAAAAAAAAAAAAAAAHAAMBAwABAAAABgAAABoBBQABAAAAHAQAABsBBQAB AAAAJAQAACgBAwABAAAAAgAAAAECBAABAAAAEzYAAAICBAABAAAA/z8AABMCAwABAAAAAgAAAAAA AAAsAQAAAQAAACwBAAABAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAAAAAAAAAAGQABwEDAAMAAAABAAYAAAEaAAUA AAABAAAIBgEbAAUAAAABAAAIDgEoAAMAAAABAAIAAAIBAAQAAAABAAAIFgICAAQAAAABAAAVowIT AAMAAAABAAEAAAAAAAABLAAAAAEAAAEsAAAAAQAA/9j/4AAQSkZJRgABAQEASABIAAD//gAMQXBw bGVNYXJrCv/bAIQABwUFBgUFBwYGBggHBwgKEQsKCQkKFA8PDBEYFRkZFxUXFxodJSAaHCMcFxch LCEjJygqKioZHy4xLSkxJSkqKAEHCAgKCQoTCwsTKBsXGygoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAeACg AwEiAAIRAQMRAf/aAAwDAQACEQMRAD8A8VwAcdMe1SeWzDowHpViOEEEcZPNOePzSEH3f4j7en41 5/MegoENvF5jB+Sv8I/rSTuMlFJK5NTzyeSoVDnPeq0UJkY4HPbNC7jemiFt7Yyt/eHSrpKr8oA9 MYoUCJAFwuPegfe5647YqW7lqNkJwxx1JPajA4/KnbODgc0/aMYweO3Sgdhm3Knv70hXALc+gyak C7uBkjP5UgjLHpwelIdiMLvxjoOME4prgb9v3uR0GeasbBxg59B3FNKMRkrj3x1ouFiDYw4Azz1w efenKm/37e3WrEMHmMcj5Rkn6f0qeO2+VfmAK8DPI9etJyBRGR25UZ25fbkL6etTKE3EHIXuGFOE WCcH5RyTnoPoKZPcCMYGN44wcbfw/PvUasuyQ64xGo3J/geKzbi43nAIpHlaR8uxwMkfrUMnDEgd ulaRjYylK5Ewz1+n0qJ1HcVYKgAMeAD61CQTjI49q1Ri0XUXAzx+P6fzp7EQg88nqaFUE5I2hcj/ AOvVeVjM+0jj8fWs9zbZEaq0zt/Fx3q6qCFVyM5HPNOgh8tGIx06jjFOYZBC+3Gcihu41GxFtzkd 8Z4FOAU4wx6+nSnBeAQOMc/5NABC4xjuMUihwXB7DA9OlSi34OWVcdDmo2cQhS3EmT8vGMY+vvSJ cblYOcA/U5/zg0tR6D0VSxCNuOM9eamwDH8u4gnqQT1rir69kGoSyRuUKsVHPStfTfEJcrDckAng sen/AOutJUpJXRjGvFuzN0xgtjsBnA6n/P8AhUiWgQHO3OCPToOnStG2txNEJeCDyGHI/nzzxTZW OCSG2jDjg4POduf89a5+Y6uUpHCr8oI5JAP8I6880/ABKhQcYyQB+np2qacxQ/KUBH9xW56/j69q zZJ2lGCOmc5Xjp2oWonoLcXJHmKg44GRzx9KpuScAjJzjOCe3+fyqUoQB97kc4qFgUIUHOOAR6Vq lYyepHgAY7jjFNJ3HAAYZzwKd5eQctt44460ojCq2SCSe3AqiCNowDx75OKiZcnJB5qcgdTjb/Pm mBeMAE+1UiWiaSUKuxeg6YFS2sW1ctz3oWAF1Yk9MkcVYhYwzRTgKzRNuVZEWSNj/tqRgj61m3oa JdxvIyRjJHXH86asZI64GMZpyRRqHCb9pbOC2dueoGOMdeKkPLEAAjoeOpqSytK0a5weI1yWzx3q GLUbU7hHMkrleFBz9ar+JHmjt4raNSPNOWJPUdf8fyrmVEtrIrjG5Dmt4U1KN2zCpUlF6LQ6vzGL fvGJJ5Jz0ptxemxtJJlI8zG2PHXcR1/Drz6Uy2Y3CI6jduAK5559KSytBrniCK0Cg21tmSX0OMZ9 Op2rx9aiTjBOUtlqVFSm1GG70Rt+HfD9rDpaG6t45Z513uJFBKg9Bz06fnn0rP1jwXEo86wmEOSA IZW4J9FPXP1zXfEQ3EkJlhhiMEDR+bFEqswyWy7dW7DJPAHA65801qXUNd1UtbyARRKGhQE/KpGc 8d+5/wABXkYWtVq15SjOy3d9vQ93E4alToxpunzPZW39b/iWNJ8R3fh9H03VbR2QDMLMPmiPqD3X qOPX6Y2W1R7y3Dxyo0RJxt5AP17VlXmq2NpptrZ3g/tF5QHlkJyqeoB9QPTpUI0Sa3EV/o1wVWU5 S3nwC+CemeD07/nXoe0i/eqLlv16P/I8x0pwbjB81unVf5mu67wNxdXbj58n6fhxUeN5IB+Vjjpn P5VnxayuXTUYprS5XglgcEk59Pqe3bGa0Yp4rz5o2RuMqQAeR/OtXFoxUkxuPNDHcoy2OQfb9OP1 qMxkfJgMSSMjj9c1cCHBKj3AweB61Xk4xwQSOcmlcbK7r8wHAIAAOaiJA6ruOSeelWUjZgCUwPrW rp+gvKqyyNsjIyD1ZgfQdquKb2MpNLcx7e2lmZVjQuW6AD9a6HTPCfmr5s8+wd0j6/iT0/D860or aG1QrCgQHqe7fU06C5a0l3jlDww9RW3s3bUw9rqcMsskY/ewTRrnGCu4Hp/dz+tON5bqNnnpvzwu 8A59xWxeSNbnytpWReGBBBX/AOvVFkinG2WKORf7rrmu6WXxesWYQxU7aoquZ1VpNkrMcYWPqT/n n8Ky4NcubIiK7iR1YclPvDHUMuevHTjjnnrW1FpVuciHz7cs2QIJSBn/AHelS3vh64lUyrOksq/M rSJtdT6gpjHP1rH6lUWlrlvELe9jC1O4+1JHLGwZGyQwPX2Pvj+VZnlCff8ALkngH0Oev5VqHRr6 xMp+yO0RAO1WDL+PAP6f4GaNNpDBNoxgDbtP41lKLp6NGqqe0VrkTH+zdOaXC/INic8liP6dfw96 6nwJo5s9Ka6kUrLdkMM5HyDO388k/QiuWFs2s6za6aGKorfOR27sep6DOPfivT7gSaYZbWayeCW3 cQi3Qxtk4GApViuOcdeMHOMGvEzOrJU1Tj11fp0PaymnH2rqy6aL9Tn/ABNfW72txo63SQ3EkSyO Dnc67gNgwpAPVjkrwuMndisbSbLdIBENqxrxWvq2lw3M13e2pBdT/pAYEHIHqfbB/L1pdJtvJst7 YDP8x+lY0JRjRUYfP1PqMLh+as6smm/yXRfqzC1OzEmoQQSxIybd/wB0dzz/AC/Sql1Y3D6xFI87 uFQEKg2kKM4RRn0H61vaRD9t1K4vnBKKflyMcdB+mB+NWLawGo6zcbV8uOBTHkDPIzn9c/pXapta eVgrYClX1kt3cztOd9dma3v7OIQKuVXHKDqMH8QP6UyfwsdOnW6srhvIDYkjzyc8fQ/5xWja2QuL idwqyRxyLh855XjcP896ffXUdy6+SsqxdhK4JJxgngDAznAPIBwSeaISkp2p6R6o+ezDBQw9ud8z ez6/gUmUncqrkk/hSSRrCryy8hFLMMcADnoOowKsqhCMw4C9cHrWXc3jw3tvJ8rKjAlWGQT7jvxX TFczPIm+VFi2ZLu0ju4dxRsEZHQdCD+tdZpzF7CPJyyfKR6en6YrktEEVmb7S2dmjglzE8g2l4mG VOPcc/8AAq6jQ5PMiZSc9Dj6cH+lfRSpxeGTitv+GZ4CqS9s+YtOuetV5E3dq0HUZ6VLpscBvl+1 ANGUYKmB98g7TyQDg44/n0rz7XZ1XscpJLJM7STsZHdtzl8ksT1J9aWO1jkIzEoyflAGKdFFuI4+ nNdLo2mLEFuZB+8PKKP4fQn3/wA/T2KtSNKF2cVOMpysiG18Nwxwh3aQTMM8EYT296xdSg8uYwxX CuRw5wV59K29b1YwE2tuxEh4dx1Ue3v/ACrmpJBEpkY9vWs8LGpNc83o9kXWlGLtHdEEk09mjEEu dpwMg54z0qnaWd/PMbq/hMMbANloyCwA4NdP4f0JruRb+9B8vrFGe/uR6fz/AJ9pp1mNXv1t0Xdb wMGm4yGYHKrn2Iyfw96wxeIp001a6N6FKdVq2jOD8OeDta0WW71K80e4ZLkhYZYV85sElmykeSoP y9R27dK14rm2nkeFJ43ljOHjDDch9COo/GvRfE+tPpVrFp+nbZNRuPliQDO0d3Pbj3/kDXMaV8M7 C8tgt/IWmbnACtGvoMMOT7/5PzLyn66nXnPlb267H0SzNYO1GEea2/T+mc9c28U0bRum5G6j8c1B LGgjIRADjAB6V37fBbUWxJYatGzFcFZi8YX6KNy/pXPal8O/GGlom/T5rlclS0UYmZ/f92fl/EVg 8mxVLSnNS+dvz/zO6jxBSStrH5XX4HM2sSaZaYTDt1wo5LdutFmn9jaRMMBbiUYXccEE+nv/AIUM t4N/mWRAU4AV/mP4EAD86wNSQ2UqyIk9s0rlwrDjceuGUkZPPGa1jhcXD+JBrz3R7GHzvDVpKHMr vzt+DNaeNLPR4rZXKyyOGcgdACCefyBHpWeuPMBKkjHQGrHm3U1tH9rmaVyOrHGB/nFQbNpJOa1i uWNmeVnFRTxFl0RLK4aP93EUUdcnNYN+PMMijquMfXGa2XZvLYY5BrNdMz7sffHPuR/9bFbUtLnh VdbDIyZ7/S7r7guoGtZJHbO548EYHshiUfSuu02M20wjz8p7+oI/xFcLJvhspZUiVm065judxPIT dggfUun/AHzXoCqN6kc7l+97A/8A16+ly+PtqMoHz2Ml7OomXpHjj6sB/OqVzesykJEe/wAzV0a+ G9KsQ8mqazCgX7sVsRNI3JByc7R0Pf061m3Op6Va28kdnC8m4glpnHUZ5HH+fyrynGXXQ77obp+h +S/mXG1lAyFTnn8hWyHUdB3xz1qsJ8KDn5j0GOM+3txT1lBABPbH0qalSVV3kOEVBWQPZWcu5pLW Pc3OdgyaptoemyyBjag4bIyxxn6Zq08pPAFPUhRkn8aqNScVo2S4xb2IJPOuT9nsVc5YI0o4AJzx n6An8Diu60myt/Dukrxyq/ixqloOmozi6kWPbGCqOoI3DOdxzzzx2HAHGc1Fq2pfbJiEOIU4Uf1r iqS+s1FCOkUejTX1am5y+JkUI33cl3Kd88v33Ix9APQD0/rzXUaMQXHJHrz2xXIRzYIwa3tJuSHU 55OBXq0+x5krvVnqViipCu3njrirNYtrrdlaad9pvriO2iRcl5GAH/1z7VxuvfF6CPdDodsZjyPt NwCF+qr1P44+lUqFSpJqKM3UjFas7bXdJ0O/t2l1q3tTEgAM8xCFBngb+COT696+ffGEGk2l5Imh SyXlntBMk6YKnvgYGfrgfpk9ba6B4u8cyrd3sjx2x+ZZ7olVwcf6tAOhGDwADjrXY6T8ONA0fbLf btTuAQd0/EYPPRB16jglq64KFBOMpXfZbGHNKUlKKtbqfLWoS3umXRvS8l1p0jBZFIGYvQ8dP8g9 QavLLkYDBlYblYHgg17T8TvBenwQm8tII47S7PlS2irhVYjqoHAHB+h6e3gtvBLptxd6PMxMlsfM hc/xRnof1/X2rzMbhoqKrU1o9/Jnp4bFTnNwqO73v3NBQQxBzzVByBOoI6Ejk1bV/MVXHJB6VWvV CMsnYnNeZDex3T2uVHiWW5u4GBYT2rhVH8ThTs/8e2n8K6zQLkXeh6fMrZPlKrE9SVG0/qK5SeZr W6tbqM8q+AT+n6gVteFXWDTLuyaRX+xXEigAjJUHIOPc5r6HJ52quL6o8DM4Ximu5qzxzs5JcBTy O5qo1sGHzAyN/tHNaMcjXEYLRFMHgHuPXNQXdxaWSb7q4jgXtuYDP09a6ZZbKU5SlJKNznWNSiop XZuI/QEdeT1GKkMoC8Zz/KoI03LkgA46VNFFvbJHPsK8FI9W4qkkA98+laujWT31yANyoPvFWxwQ cr+Ofy9c1RELO6RRjLMflAHFdWpi0DTPlAM7D5Rjq3rXPXqNe5HdnVh6afvy2RH4h1RbWEadbthy v7xlP3R6fj/L61iW0xbAbknvVcrJNI0kpLO5yWPc1ait2bBAIxXRRpqnGyMq1X2krskXKucj8c1o 2s5LKFcjB+gFLHpzyqGC8tyRVqGwkRgAuDgdR1rsiupzMk1LSbbxBaKkjCO6iB8qX+jDuK6Dw34U 0HQikzRfbbtSD58wBCtwcqvQYIyDyR61hsr2wGcdMHPpVyzv1UZYnA759/8A69dqqNx5b6GDgr81 jtp9V3ABT1yPY1Um1FY1ZnfHBzz1Hp+tc4+o+YcrnGOgqhPqLu/3jjOCai0YhqzV1uZNb02W2/hY AKCOQ3VTXz547sjaS2erBCGtpPJuP9xvX6HP/fVewHUQHxkY6rnvz0rivFVsur2t/bBF/wBIiIVc cB8ZB/76AP4VvTSrU50e6/EzqXpSjVXRnnkBCyPHnvTph5lsePuHFZ2n3Blt7WVjksu1j6kHH+Fa CkOZU7MuRXyzVmfQJqSM253TwmMEbxypPqKqi0j1SQSw3cdheIv7xJiVU7R1VgCc4HTHJ5zzipZG 2tx160yVEcbpUU4711RbjscUkpbl/wC23sNt5N1rskoB+7bJhiPeRgCD+BqiZrdHLxWqySHgy3A8 1m9zu4z7gCoDLGi4jjH41BJM7d8D2raVWpU+KTZhGnCHwo9dtLgbSAM/jWhE6om5jgYyc+lYtj98 /wCe1acv/Ho3/XI/yrNuw1qdNodusaNqFz8vHyhv4V/xptzOb+cyP90cKp7CrC/8gVv9yqMPT8q5 cL78pTe53Yl8kY01sWIY49wHGP6d6uokaqGUcdee9UYPvD6H+Rq4n+qX6V6KPPNOwvkgeNzhsHJD DINbGoanbXarNDCsZHDBe9crH91a0U/1DVrGRLK2pXiuAc4A4rMW++YhWAwMfWn3/T8ayl/15/z2 q+ZiNkai5BwRg81DLdA5BPP9aqJ3/wBykm+/Sc2JED3REoOQD1x3NUJJS7Elec5Jzn+f0qR/+PiP /dH9agHQ/Q/+hGtsHJqvH5/kRiV+5fy/M8rWJbW5v7VT8kF9Iij/AGc8fyrRix5qZPXiqFz/AMhT V/8Ar+b+Zq5F/rIvwrxcQrVJW7s9Sg7wi/JFC6gaHE2Mxs7JkDow7flVK5c7UJOBnmtjUP8AkF/9 vrf+g1i3n+p/4FVx2RlPRsiJJOP0pJVVOM9qd/y1qO5/i+gqzI//2f/+AAxBcHBsZU1hcmsK/9sA hAABAQEBAQEBAQEBAgIBAgIDAgICAgIDAwMCAwQEBAQEBAQEBAUGBQQFBgUEBAUHBQYGBgcHBwQF BwgHBwgGBwcHAQICAgICAgMCAgMHBQQFBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcHBwcHBwcHBwcHBwcHBwf/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsBAAMBAQEB AQEBAQEAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJx FDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNk ZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJ ytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEG EkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpT VFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAHCAlgDASEAAhEBAxEB /9oADAMBAAIRAxEAPwD+QePS40QCNSYyMZ6ZHT64HPWtfyYo7URJ1IJ+bj5eQDzwO3618jKTZ9VC mkrJdDIjIklEW/aAwGTgbvxrpERTChJOQMA/5/z+tKXaw6SlrchhEjytIMBg3yjBwT0x65zj+VVt R1a688xmEeZjA4PTHsOn/wBeiKjKSS3LlJwjp1EuL0iBJU/1+cbSv3Sce/tSWYke2l37Vcnbn8T+ eaVvcYruUly9h1vqeoQowEm6AYJ3k9vr/nrVXWtTkvJbax0k/PJgyHsvPOfenGmnK99OoOpNU+Rb vY7vwzp0mi+VB5O4yIWJI7dT+mf1ro9QaeANI865+UBCvUEHnp+H41zVGpVL9z0KcfZ0VHsbNtBG tpYXi7VkYAFl5IbPP5YHP1FYuvapJ54W4JYqCpI7jPP5/T0rKKUpq+6N6kuWn5M8m1z7TLLFHbSk Ss5JJGccc/59jVeBmtzcwyTFp8Z+p9vX/wDXXerezWmp5EpfvJOT0WhmqV1ATQwxkT4I5OOueB+f +e/T6HCmxre6AKk5Dn+9yaufuxs9yKMb1FLpsdR4d0IwX11M6ARnopUDNepWlmLJo7lk/dsvce4B GOnpXDXndqx6+FpKMU30bLum2FvcXbX3mFIACGyOCcflznr/AIVduZhdu03lq0PIVlA5PPPv659K 5pNOS8kdaSUU97mdFF9ltZ1u9rfOTGOgUHke/Hqfwxms8j+z4GUSsd4LLhs7QOoHfGDWi1bXcznf Rl+0kSaNGaDhcKMAcZGPTjn/AD6Y4V0MirFwSMPgjGTwDxRGOrTYp2tF21LemwxhbtX+bjOGx35z z9f50+eSQpJHawKwTHJGG57jOPX/ADino3d7EpWgrblCKzPmmWRQX4IXkD6deK0VMdzeCXyDtRRn 2/H/AD1pybvfsUopJJjpbqCeZZI2w23JXGBz26Y64qe1SJI5IIgTIwx0IKnP8uP1qJXjGz6FJR5r lG9gXTrOZduSPlO5eD0GfY9sVBZTXBDKFBbGDxgEEAn8simvejcmzjKyRGbi8gmKqR9nBJwMsAQv zH3qvqAZE87AdpI1lB9QD0x68/XiqUUpXFra3Y2ZZEj0y1hhiIkKOwGMck5Az371mJCZdPs572Ld Mu5SSo6Z6Z+n1rOKdt9b/wCZcle11pY1r2S602S4fTIlEYAeE/NkFcHbn8/zNZq3NhqNzYXVyGUl W8xuMo/zEccf5H5kU7c636/cEmr8ltCxp9q1tfX02kzCa4Ks6KcnHOCPc4zz71V0MfZrVUuoyLky PIY26ghhkZ7de3X+dN8yk+rt91twXuyj211IigOvq0iAxxt5mGTAPXGMnntzxVS+T+1NVRI7XCx4 a4Q5AZd2SB7+30qkkpRd9kZtaNW3ZJYw6Yj37y/PDk/uiBlCvAOO3f8AlVWxuItcRrGRQrRMSpIx gc4yc+gxReWsu1mHuJKK6lmDRo0tpjLOkTOS5APVRnBGfXiiRVins0t8/ZB8pxgFsnOe+D1H/wCu hz5nboL2dlfqaFz9m0QRnrG6hZI8AlM4zx064PrVeO4WzWaa2tQ1pIdrDuCuT0GPXOP8ahXmr9y2 0nZdCok2pC61BrnEcElqYtpIAGW+v0/AGq0NgSscNwoMZkLZXHQ/MMkewP8A+urtGPwmbUn8RYsd It7ie7lhnMcYiVoy38ecDA9q3tJgSKxluk3GZl2kYx8ynjjoQQRzSqTbTRrTjbbzLlhDLf6lFLdQ LJacn5QdoHA9Pqa7/QbOxslurSGKOS7lAypTKrx149B7+npXNVl9lPSyNqMftvcv3Ok38Ol4lth9 rmjBjbHKjJH8s1HaTwabZiyvY2e+t13DgYf6+2fXFZXUo+6+v4bG9mnfodBapaW13aMZjtNmXkiU Z2kZIwM8cHoKqXGh6JfRx6jKWIEf2mNcEEvjoe49enQdu+Sc4SuluPlVtToYdPtWtbSWyhRVERLP twGJ6gfT61o/2K1lYXs95fhlDKFhQjKccHj8Pz/PNzjopK7ZoovRo8zhmEd7NLcRv9lOMcZJVRgH t3rY1PTYYZ9L1q0jaKGOD7SCw69VH+P+Fb3aaXRoyUbp6k+o6la6np8dxLH5aoAr4wdwJHJ/KuY1 6Kz0SCW4guQxcoUwv3c8kDP068dc0Ur6QRFRqzl2PNn1RbtHVCS+WY8jnvjj3A/nXCXi4ZzG+5wu W79eMfh/T3r0qEeW6sebXtJFQahMlhHp8aqcRnc5UZOM+/v6+9Y7W8t/H5AtwLcMoDYwCP6/r3ro glG8uqdzjd5+7a/QpX2m/Y/KDv8AuxhSoxyAP19v/rVmm2jmkYJHy3RRjJAx/nGK1UrpSsYTglLl RKJ/IG0KNwUKuDnLH0/I1nX1o9xcxsqjZGuTtHBPPT9eKcdGZ1PeioruZ/2BzctKrFo0xuYjg8ZP +FXP9G/55L/30P8A4mtea+xiqc7to3bNVWDyZPlyMN659B/hmsqWBmkNt8wEfzLz1x/kZ+ormV7t s7JRdkkWBo2+BnEvzbSQgPPOev4n2q1ZxSKrW8rYYEY3HHH17HNEptqzFCm4yt0LNwEVfMj3FUz2 /i4/z+FRySWV8YWgVfMA2uSOueB9AefxzUpy+JmjceblfUq3NkLfy3ZRt378YHfAGAP89KvwQSXE DoB8v3hjjv0z/npQ3dXHGnaVkVtXns9Mh+x2yBtRmBCAEHb+H0rT8E+E10s217fndHKu5s9UOepp Oo40W+stvkXClGpiFyrSH5nssMumxIrxLuYAxjaOueoPTsTn29aS8hsL+zS4urYIFbbnqcYOD+lc HNPmvc9blg4cttDye6t9bsrySwiuHNgcyICOQMjp7YBxWUby7t2+z3se52wd2cEAKcgH8R+mPSu2 PJJXS1aPLlKpBtSelyjqEkIuyyr5iOp4OPlPPQD8PzrGur6FLuFNv7zBIxgAA/8A68VvFN69Tnqt Run3LC22WSTywC2SGGOuenSuq0W1F+k0EIIkC7h3OR6dfp+VFRtR5uxVKK5lDuep6HYTzTCyvUAm 8sEdmyAcnjp2578fh2cMFk9hPaXE+y5KkYB6MD0/zzXl1ZO+nke1TilDXqUraxjh0drV2xcqTg5H I565+tZE128Vvb25DqpOPvZPUcn0x+HaiFpt+oSTSTi+hFBDeai1wszqSq7juO7IHHHHXj9TWVbP MvmO7krnb1+5zyAT2IHfNbLlbcUjKXN7t+p1cEsccKJEVJVdxLdsfX8OaznmzI3mxHrg46Y654+h /Ooiur3NJa2SQ+8jhWGWSyBEjAKDxyMY6fnzVqEwSwMqRnHAbI+bORk5+uT/ADpXbS8hJK9unQoS 2cZkdoMFVPy9OvGeBz1qe7tDbohjBKOgY4J59fTpn1/xq+a6VxKFr6lO1tIVmk3KSQPU4PU8j1wB yP6VozWt1EUuIBk7vmI6DPTABw3QcUnK794cIqMW4kkJt2kZr+IPE7LklQPyP0A/I1UM1vLqotre Iok20RbQMbgfu/jipSaTXRItuOjt1LEdxaQx3Et9AVQZUoqjhiOOep/OqtrNpr3dvbyw/Kifw9Su Aeh9OT6cUrT1cWJuCa5kS35+1wwR2Uw+8sCEdWPH9T9ePylS9uZrFoIolYxPIJwSAUO5Qcd+Mf8A 6qGk4pvSz/r8R/at3M59TiM13HBmSMDdGCPlDbRu+oqzBp0AgAnZUMyCZQB9w7S3Pt/n3qnemr97 aEq1R2MTQBJpbx6tYuWlLAx7uQcHcSfbIwQc1evmuL7V7CWBRHPMd8jAEAFskkemAD69acmnVc32 sKKfs1CL1G6pNqLTz2sEAPlNkP2I+6Rx+B+h4qXTHjvYNQhnRYruVkVSCMqST6H6ce3tSdlG6eoJ uU3F+ZnWGiRacby5e4ElzE7OUOMNgENwOnJz7c+tZ1hqNpEJkW1cyyl/NZeoIxjH4E/lWl/aXa02 MWo0uXS/9WILm6mZ7e6Uh9sQiRRz07gDqetU3ttTCu8jtuB385+8VJ/w/wAauPJbYl80rpC6Z9sv nmvLm8aQbRv3cbgeT1B5GO/rWylqWjt7m0umEKuTt3ZyR1GD9amTina2g6aco36lq9upEls7mW28 zzRgxjuTnA49Dj9O9Vrm2m0yxtDFKRJKdzAAn8c/T2qVZKOt0/0NG23J22/Wxs6olnpVjavuY3A+ SNlyMR446fh+VdLG097Hp2n21vsLQLIW25Db+Tj8McfjWE23FS6a/gbRSUuSO9vzOs0jQLez0eeM zBcwNGHPBZgRnH5+wrVk8/S2SGOCPcbdXaQnOSRzyfw7VzykpOXS51KKikdLZ3c2r6RZBlYTzqsc boPu7STgdAOMHkVWs9Pi0nWr2e4iFxZkGAORncVB55/n7daxT5U6adn0fzNGlaLLWgP9p1XUp4Yc JtaBHYfMQRjOPoTS2Onm5mguJJ9iJAYREVxuYkg/ng84qeblbuuwoq5aguvsT29ha2++JZPJYDIE RA5I9/8APbFTf23aWGuPZ3Fq7PMjTFiCQhH3cntwB2pckpX5Xra5d0tlojm7wB3hvIrdVnuSVjix yVH4ZyckZrLv7ufV7U2l9OIUB8sDgF1B46dhgj8Pz2i02pdjOXl1MWfU7e105bFV+V4XbcwPB6ZJ /wA+teWXeo3DpJFebmhBY7mHQ8YH5fyrooQfvX3OLEVLRstjAkFzGsTW7YhCby4I5JOPrx/SsK7u oYLkTTYWMqSe4z0BPQk4IPTv1rvhZ6rc86b5VdoxbyVZp8WmRvG9s9MY4/Dg4/8Ar5qzPdzBbeG3 42sH34PT159+ecd62a25jDmtdxJpFiu45Z523NxyDncB1x2+vTt+ONEubyWeMDyiAqLxznPQcURv y2sTLSzKzpGkjSD5mQ9Mc9P0/lUU1xcTtMIUxIVAwAQpP19OlWt02ZyVrpFW3a4FtcQPxIx44wW6 /wCRVb7Jd/8APN/zH+NaRko3MG5aWL7zy2zK7DK5PUHBI/ryfz96W3uw94k0q4Ow43E4YdexHqel YpaNm3NZqMu5ppf2Y3PtADHlfTv+tZl0TPdwSRviEkgYyO1JRs+ZmlSUZRVmPsI7jfLasAbdjgZ6 n37/AM+la0ukxpCqwPi5GVAHBPI7e/8AntSlLldl13HCDcVJ7mrBaxyqkd/xcAYGT8rHaMdf88Hm szWLpPDmmxXF1Nh1/wBWueXwQAMfSoT5pKC6m87U4uq90tTO8CeGbvU1uPFmrIWR3xGg42+/PT6V 7FBLbXcQCRlYwp3LwcD68DtSxMrzai9I6fcXgoONFOe8tfvFjtobSFYLJmM0km9fTAz1z2xmp9WV 7mwnt2hWO6iUyEPjDnjAx3Gc9+9crlqm97nY7KDS7HBv4guNTsA0LBbhYzGBgcjGM9Bkdfz9K82M N9JcGa8nIZG5POAcdvyz+dd1KMYXueZiJSquLT0NOKa3srooJPnHOWJ5Tg+nJANaF7DbXt0d0WMA HIPTP/6x/nNP3lJSQk4ShyPuS2N5CksFtbWzEeYsfPG3Pfpz3r1AadBaoogiEc/TKgHJPOCV9vp0 rKrzRdu52YZKcW7bHaWqS28BvVy7LHjjHzZyMY+hrH1LUrW0d45ISLtgX+borAYyeM1x2cpNR3O+ T5I3K2qyz2tvFq32hiX2sUIJ2g9c/nn8ahlu7bbam4b9yQSrBsBjzzgHPHStIq6Ulp0MpOzaltoz UttPtpYsQbluJULHJGAB6du3v09qwbpSljJZwSE3AcNuJzn15P4fn1pxfM3d63RM/dVy/wDbcPaL bRYmRAXGeMkZzj/9farVvM93cTxfZfmKmRicHPP+fzpcttW9h8+qQty7R28M6MQB1Vs/Keh9+w49 KuWNvBGzzo/zY+dQDlgcYI9ep9OlJ83K7FWfMkyLVoo44PtVo48tiF5659Pzz+tTWl4LaKLLLI55 XnIPfnPT34/rQ480V3uNe7Nt7WK6bgpn2FH8zbtA9ff05NTJdpbm78xP9E8xQ6k/dyP1HB9PypPX S40+XVIYb0W0a3ckO+IMONudyDv9eMfjUMtoLu0bUrV/Lki+aOMA5wCcEH2yPXrzSV1q9noJe9eN vNE+nxedp7y3MhKsoYIwzuIwR1/+v1qaztreB4bieIrKEkcKwOD0yBz2GO4zmk24c1i+VNKUlqZu vwafsSS1+WNZFYsBnbuPUY6EGs+Uypb3MsDs6NIRI6A/Op3EHpz29KuDbiuYymrSbRTssTxq8TlW j2sFAzuHIOCe/HSuwt44Ly9hi87ddDavIPzfLx9D2/Gid1vuh0knbzMoxnQ7i6heDzFtmWNlU5Vs 9VH0OfStrT5YtXszdtGsEkVz5chBHyjB6Y/p9azldr2l9+nqaU5a8ttO5y8/iK51F5preILPBGyl V53EEYOPqB2rDtdQTU7e6niiMflMknAx8+T/AIit40+VXvtp95zyqtvlfX9C5o10kunyXFyWa/E5 QoVH70HBIOevQ/lW14qvrS3vH+yWY+VXh2p/Gw6kDqcgj8RU8rVWy21K5kqXM99/mcnZpbafOxVn WRIxGdxIw2QAR0/vHnFalzDeC/tWJMkkrBgCTyehBHp0/wAiresuaS1aIje1o9LfiVpbi0R7qyaP ZEk/LqCN3GQMgdM9s+laERkZmhEbJEYxIpweowehxzxyT3pW5dZev5DjK+hcFoClnm4YtEC8fmD7 xKgrjPc5+vFXJ441tDNen54tkWGznod2QfTp74rK/bT/AIJokle/Y0dS8HXk8rx4aVW8t4eOAW+X HPTnJANenaFoM62kLFFANuIEkPByOSoJ61jVqp00rnTRpWk2bMWky6hY6dbSIICsm2M4z5hI5znp kg/hXNeLNAvpPJ0+wtJhakM7SnOXcuFUAnjaAP51hTmudKWyuzWcXyvlLmh3k1r9i0u9vvJEEQk+ mQOM9M8+v6VYsLqW5jvLq2kYFVdipz8zMeSBn8aUkldpaf5gndJdUS6NqV5axw6fZSKJzJkuwI8x 9pwOucDgV193cWWiXs2rXEG54U8zy1zgkAgD3+Y+386znG8rL7VyotNWtoinpUGqkyzfYSbnylvJ Ix1If5hn04PI/wAa57U57m61z7EVaKV3/eu2M+m31H4U48vM6l7qwSTUVpuZmorL5f2uK+KywSGC PcMBUAxuA49Ce/UVwElzc3OoqAx8mJepbG8HPzHP6e5roppWuuiOardWSZmaxruy0tLZosMAULEn AUdz6Z6/4159d31xeOjwEfZI5gWBA+bHGevv7da7aELK7ZwV5ttpGbc6gdTkfy222UZwUTOMgfz/ AMaeba3e1muZY2Zj8kQIOOmc9PXGcV0W5bJHNzc7cnqv8inFBaQWbXM6jdwhJA4Ax69B3/CoJBaz urQOArHbuxnAHf8AAH9KpOV32Ibg0l1HQqSuQhMCIyc4O4nnoM5571iqbgzgiIjP3UAJ/l7VS8yJ p2SRWitruWaJm2rbpyxzk5yAeahW6iE08hOIgwUEgjP4+1Xvsc8rw+LuZ94X/tL7Sx7ZAA+UZ4BP r0z+NTfbpf76fkKtxul/kZcyjKV1uzROxSDexZRu2O/br9ar32mwzT6f9nI27gJMDoCTz+VYp8p0 OHMmuun5l280FIr23ySIAoc5JGe2PT9a110xZb6O3CYjKghgSP8A63XH5VEp3SNadFRfK11OrOh5 tII4I1DqxzgHkc+vbNWzDZ2tyIPKVyFBG05/P8hXO5t6R31PQUFBXaM69NusMxmXYUAkY4G5APmH 5ivJbeyvfiHr636ZXQ7VwAp6E8D6Diumg+VSrS+ytPV7HDiU6sqdCP2nf5I90jinjszYwOBAGP7s g9e3PFdJb2LPbzxwwZkK8qVI4PPXjtnua4pNLbqenGL2fRE8kWlWNlaeZP8A6U77ZE5IUA8AHtx/ OvIvH2q3sE8SaZ+8XOzdkDHHzDJ/EflVYdOdVKW2pljJuFKXs9zhbG+86F7GQZmx8ozjYSTwT6E4 /Krs+mG7QFlK2juFILfn7jPP5d67n+7ldnmL99BJ9CCez09ZJZwWKgcrnJIxg1v6L5Uif6O6tGF5 3n5ufr9B27iiTbjrsVBRjNpHeeHvDlnPFLqjqcRurlFx1ycYz06elep28MFwttbQ2ymYkuWce/AA 7cGvPrzblbsevh4KMFZbkl9c28CSRwwqLls/KQMcYz9B16en5cf4kklDR5iHmtHljjOQen5gd/f6 1FOLTia1HLkfKtrGDpHnTGS0u2zBGc4PXGeh/P8ASr402S5v44J1zFnzEAHAA5PX369OtdDfLJ8u 36nPZzpq5payGUD7FMfPIBTH5ZB/z36ViLuix58bGdl+6QxKnjP19OueR71NOzim9wqXcmugza/m JNEPm3FZCq8muhspri1bAj3gjaWGcjgD+n8vxJpbX+YRlJMj1A2s0zRWbEs21yONoPp/n+lTQxxt E32eTDfKSOMjjnHHPOAKLvl1Rdk5trchn0yS7Z45T+4BJb5sYbjHXGO30qpp9qI7qaNyWU5MS5xz z0x6e9NP3WkDjyyTkzorfTvtcbowkSUgtGDwDjnr0/Hv+FSx2HmxT3F8VEIUY5xuK98e2PxrJ1Er 2NEtr6orm4gAuBEubUnYhxn6ZPTHHT/61R21y0kKRxZIEZLAgY+XAC8nuD7UrXV3uF/e0IINTiha 2sLwKqmVni6nnC4FX9SvLjVg7mFVuFYodq4D7+p6cdBjjuKNpqV9BxnzRcYo5yzWe5srvTZXG10b eT95C3zLjPJ6Y9c1aihjgs4bK3cGXBjHYN1GCPeqbWqXqQldXb6WLmlaDbDSNQvrK7HnxSqBAeuG yWA9geP/AK9Ys9zdW9nY6lDF/wATB5zEEXqo45A9+n5elCftJNS72+QNezguXtc3dJne2vLeTWEX y5J2Yg53SE5wTnv05NJ9llTTta1FCfkkO5S/HorY+oqWvestnZfiWkuVt7q5x9nDNbSC8i+WOcGR DjPIABB6d81pSRW8gu4RZ+QGKbgqnDsB83X1yD+Fau6ldP8A4JzRho0/l8zS0uPRdPnZ7uXbaLJK VVRzvAUDgeuP84qG9/srypLkLjyhEU3/AHmVhyQPrxz61HNU579Do9yMOVFWRtKdLxzE/wBvMK7U ZAMktwDkYzjvg44695ru4/tG90+C7tTBMuBM6kDagC/ruJ/H8Kave76X+7Qybi4tJbtDdW0jTkUr prlmmm8zLkfLj5fp6/lWvo9rNrl/oul6fNGqvH5auW6Mx5BJ4GOvpxSlUfLzT6XLUUpuMLf0zLuo byO+gt5YP9JjlJVSeAgBG768EV1Wp6Db3mmRNLOhvFVZ5lAHzeaSQPQnAPv1qJS5HFrW5cYufMme g24fTtKtpXtwLlQCm/orOAqZ7YHzHPv+NatprFlbWEVoyKL+AKoOcYdyxZsjgYAyD75+nHKLaun1 /r8Dri7WMGO61kWiyLKGmEyT2pJyD84C4787sV63aeJpb7RotLvJY49QVlgk2q2cJ5j8e53Ht6Vn WgnyyXTW3kXTlq79jjbWys573UTJpzTXEe64kB4UIpBAJA4AH8q3bXQtOsZ7i5e43CW0MKoBx5j7 Np49+KVSck+XcaS6qxgaJpZbfLqjgSxw+bFtAzGQACSfc5P8veGaG8vIr+W2lE6B1jZ2O7y0J3HI 9e/5elVeLk122ZKjaPmdRonih7XT7O+mtJAs/wDo7vjIKKxA3e33ccjp7YEXiDVNBgn1XVGUNqXl bYCuD7sf1NZKnKM7Re+n4jlKDjqfPuu+JIru4tApP+kjbsVTxzyfUdMfhVC/lle4nUtst1jB2qTk Dg8/UnOfzr1IU7JXPOnJOTPP7x7maL7G8jGZmZxv6kHp+VYtwxgt7iFBlsDOSRt5/PjIP4V2R2UL Hn1JPcZZRrpdjLcNGTPcZGwjJRMZBHrxg5q1FeeVYXAvYxt2gIDkFQTjJ/DJrTWV2+5CvBct9lqU 2Ed+RaY3I4AABAwCOp/T680RQ2kUBtCq7klK8t79jjv+Pp9R3tbsSuV+9bQy766kg2FFKwKOmRgs c/QkdKQzHT5o3bHm7ACfYjsPWrSuku5m5WcnbawTXeYULxBQXIC465IPTv61S1Gyt1giiDgRoNzY bHJ5GPTk/rQrxsTOzT06GOkMUA8+QkxcNu9gPrz6VJ/amnf3pP8Ax2tLOWtjjc4xdpHS3dut8gVO AD8wYZK8f/rq3o2jyWUks0p3EseCd21c8H179cVz3tFpnpxp3nzrX9ToLwme2gmjiDBc78gZYDgV n2Fwt5Nbho/nDZPyFegyOOe49ayV+V+VzeUmppJ7npCIZEDyZCMuBg8sCOP8ce3tXLCxawvAl7IP MZS6sThSc4x161zxfLzK39I6Zq9vxPLvFNxfarrsnhzTJDvm4mYdETsufw6V3llpz+HLNbCxtiWU YcAZ3Hp19Sa7J2jShSvZvVnn0VzVZ1X0fKv1O0h027m0wSTkrchtowxAxxnPthT+NbWt69qFvHbQ WUY8qJVRhtYEDDd/qffP8uJpTly9Een71ODcf67nD3s9vLaidpANSidmcFvvj1/X6da8z1u9fUpF WFMxA7tw6hvQ4PfH69a7KC197S39I8/EyfLo733MsxRx3SkRt5jLuBK8ls546elJC99cvIjkmFQJ Rx1H/wCsn8zXQ7SV5fI5feiuWB2Fvb6fcS2080R3SDAUYAI56+uBkVv+EvCsV7qdxvn8mEDhWPGA Se/Tp+lYVKkoRk9ztp0ozlBpdT1hrK5s7K60y0iVnYfOyE8qQBu/nk1nyXDWErCUyZAyDkjnGOoP tXArSvzdf+Aeivd5b7FpDDLDcXh2tcAHAZjuGcdSTzkKTn3rn2vLnU4Zrp7ImeKPYG67sDP4Y/lm nBa3b2FJ3VjFmdrC/hdYhiX/AFgUnG7nPc5//VXQSX8su6S0KrMcxgg52ep5zx1/l2raUeZpsyg7 OUG+piwC6gcyT7iYBuG7ndj375962LuV5o7K4mTEbHeduBuA6j0HT8fWh8vMrMUbuLUl/Vy5Z2gu ELecPIY5UNjJ579c+tQyTTWcs9uHDEY5znuDj8/1pX5nylWUEmnuM06xL3E07WuGkXOAcZ/X68/1 rdntrfTJrK6gh8wsAJI3J+Xkn+n657Upyd+VDjC0VJorIk01zdC3+ZGOVA3Hj1IP4f5NUTaTXDPG JAk6t1LDB9cHsf8APeiNovUbjN6F6aWZIbS3lZgRwGB69D+IHA/CoCl1e+ZFNOChLFBnBwADjA6n r+dK0YrmZW9ooRUmW0+1Qw7ZRkhMY4Hykk0/TDdSLfGYFW2Awk9HwpDYHfrx9OvFJpWd/wCv61Bc 3N6iXunw2d3YQXTq4dQ0hAztLDg/Xp/jS6e/2ae8AX5twYtnv0xxx+X50NuUU5aL/gityT/rsZkm k3eoa49zFc/K37xsfcA+9g+/bPvW1d29neWs11p6Hzw7lYiOVGODxxyzfpTlP4VHZJXJjF3d33sM ZJrSCeSNds7MvyqQSQoIJH44Gfer0Wn2wewkhgMnlWxuNx4wzEccdcHI9OKi7s2aqP8AN/WpU1e2 ls7fT5L6Asz4kjYnlgSCBn6fyqu8epW908Zt2+xkJK3XDDA+Qg9SCxP4elOLjy76dPvJfuytbsX5 0t2aO3aNVV0KIDnqzduO2Dxz2rITU5I5XWYR5jYhRgkNuZlPTqecChJyWrf/AA4c3K7GbL5Ql1Rz Bvh3kxsR90nHAz7kY/Kq986SWNq89t/pSsEJB47HH0zx+NbWk2nf+rGTa1Vv6ubcEMdzqltcSRlr hSsjHjEoBXgc89MfhVXUdThvdUuzHGDIE8nHHyAuuDxw3Q/nWXK5PfZGjcYxd+ruRP4e1C3tpp5o yrONv/Ac9R+nPqTXUeEvDl9py2d4XKsEkkHmHGxkG4455xwP096KlSPs5L+th06TUoy7FrU7W0kv 7e5aTM5t28s4PzycJg9s8fqfXFaFtZTWLi3vofLnEsbwLjPnbclSfb8D3rFy91XRvGPW1jqpdZie DVjrMRHEccaImNxIwr8fj+nIptvpp1WESC4jS7N0kMig5bYVYDAPUnPI/SsdIK720/I00k0nuWtN Nsnii6sII3ksbaIpuY58wpkqMHoNwx/wEVZtb6Sx1qyvpl3zi3Nx5S4KtIRnn1/Tp71Eo3vr9n7i lsmtrm7az3BibUFOdQuJEguwgAIjIGQAOvQnH69arS61caFJqdk9o9xLJJHcRCNMsem1Qex5HHH3 aydPnbjfXT8LFOTik+hDLcSR2YnuFCQwptdD95iScKM9h6+prdttf8O2WlyWOwJdXS58teiMCAGP I4+VjTlGTso9/kNNc3vM4PW/FcGmaONLtf3kss6Qg4GxgrDLDt36/SvIfEfjWS3tLlLVF85YxFGp 54+YE+nPOa7KFC797qcGIrqMW7XtocJDMruNRuC4ZmYJyR8oHUfjmrVv9pvLu8n85hA8avnphOc/ n0+nWvQateX9aHn8zbVnvqbLyQSRRziPLI5RiF9Rn8uPpwK8zvH+0X3lICsSE7yTzgckn17/AJU6 O7uTW0St1OtW502Vvs+5UuzD8pJ3ZPHTr+fH1qjIYpLYwqBLIZFLtt6A9frgCiPMnZ/eEnF3t/TM rTI7i3uTFbMv2maUiNm6fKevX2/SqtxMn2ia3KNvHKgkncSOp/H61tvJtIwV1G3mVTbXN0Ybdx5j CTcePvLx/wDWrUv7WO3nmuHIZwgwBzjGCM89cYFJ2TSW/wDX5igt5S3RWw14gvplHngsIlx7A857 dP8APTF1BWiiIJ3YjO4HJznHPJ9/0zWkHqkzOd1G76mI/wBpvYYztIQtgkdcY/z/AJ4qD+yk/vzf +PV0qooaROGVOVR8z0O7swn7m3nBEpkxu9T2z78/yrt7K3S2lDTMd5UBlK9u2QOnQ15tS6Vke3Rs 1d9CWWCJolUghQc4wMdR07elWtLtbSC4kkkUBmxIR1zx7/0rFylZnRCKcjUnuzD9lNshLbuVPC8d h+n5CuK1rWZIE1EalEBduwFuvGS3P3c9OlTTpttW3/4I61S0W0jM8NeF1gdNfvpv+Ji05Ldwc846 e/r+dewedZXEclrbL+9dfMLMMbOSDyT2xn1PFViJ881bZfkhYWiqNLlfXX79y9q04g0ldMlkzcLG BvCkHkcA/jn64P1ryzV9Q1G3jms4mLyNtGc5bbyeTWVCKlut3f5F15SitDgdZvLi6kt5WiKDdsIy OTxkcepGKY8iJpscyOEtz8ucEZcHp09PWvRtZJHlSmuebloY9teRzW6RtCxK5ZH455/+t0966aKx NsUu1H+ksgZVVuDnGRj8B1x1qp6O3cKT5lJmrollc6tqUZitilmCHAJBAIzuFeoRQulxbyxJi7IP yjneAOR15JHH4+xrkru1k36no4aMnFyktGdHaaxcW1zfXttHksh3K5xsYHHA9sdOlc5q2oJfC5iZ cFGD/Kpwc88kcdj+RrljC001udkpe6ovqQpphnjSf7btklwWVXPyqB836ZP41LaS/Yrpv7NkMgUF cEAqQcDB98ZGeelaN8ycbGfLyO/Ur3zQki2nhHm+YrZ98jPPtn/Gt2wvrTSZJTa6fG4mhKvkEeWe drA9PwpNTlFRvoFo812tjNOoW08c6OCyNlGCDJz6/n/nvVtYlNpGkiMdg+Vcc4P+f88078mgWU/e SI2i2RTNFIFl/gQeg6+vbvimQ2xkhnlvCd6ru6ckfTr/AJ+tVeyv1Jcb+69iZ7lmEAWMlowPnHQn OR+P410dnG89xb6k7DaX27GPLNg/oazmkvmVG97dCg080eq3NxbusasnlGI87c8D+n5e1WojGi3E M0Y88OwcrkbSM8/y6Z/wTVtepatqR3s/2oaakVj8zj5zjAXt9MY75qlcQQ2kbozZmB3ArjMf97r6 cHmhXSUb3/4cV9eYdDdXsEt9FPGDYtCuAqnjPPTH1p2nW7NbsY5QZvmaPJ+4Acnk+xx1ola2nUE2 2vmP1gQSsP3IE2wZbspz09+OO/51zVtY6iVuBbtghhu3AAMdzYwPQ/561VOS5VfYco8024/0zqf7 MlcKbW5CSyyJvAOeQRn69Bmta3tN0/2SyP75vnyx6tnJ28jIH9KybVry+fyKjFp6GXNbG7VrS3f/ AE+KYQnewGRjA6nBGSOn5VQt4bzT5RcSTO0SMQpIPIOCe3TIbp71SknFrr/VhOLumti5PePeXMVp G+5UdhEoyR1BwD7KT3x1p17Ppsc76faXrSl7UYfBHlyqcMenTH8hUxVmklpv/X4l30bvqVrwiSS9 XeqlXCwSHH8a5bH44P4/SqCy2+k3zKYcxJsaIuDl1BJY+/zZ9Ohq0m48qRnK27RRfUILgTT3kax2 s0fnrxxuJGMevJBNauu2mnW/2aXT8NDMsH2gFgQkqojP9Bv6dOlNKUJJLYnmjOEu/wChWsLqW3kg RVx5cLBSMYwS27P5g9PwqzpFrBBby3t1ZiF5GUlnALO5VOBnthz+IpSTSlZ7/iVFJ/F0PT31IQ2l 68zB0/1KII/mZGbcuG9Rn17Hsa5mY6vFaadEIBNKr75HPACYDFPbrz+Fc8Yq+r/qx0S3906nRPCT 32mBwVLzXDRJKxBCPgMRk8Dr68+9P0vQVvNUi0rW7/deTzGO2mZgNwwqoAenGT3qZVE+ay1X5F8m id9CW002ZtQub1BFJYwxDDscrIVBXIz9VNaOmRRazrzT2mnmJVdrmXeRtVVLFGzgZzgfrUytaTT0 SsNdE+4y61DRbC8+1TQ+WFbDLGQS0uTj8+T+NRWOoTatq2oHTdPC2UUzwu5G5zGFGVUYzn0xnAPF TyySbk9A5teVb3Jb17rwrrDzRQyK6TJNFEVzuQ4ViSehyuOfXFb1rqQaLQNS12dbaRZvtM/G0xhs qoO7H90t+IqZxVlNO7a/QpXTaeyMXxrZpaya3Osxkgkm3BVzjaQGUeud23P0rxfxZrlhe29i+nxF LlIljllU/wAWCTnv04/GujDKVTlktupz4iUY3Xz/ABOSkvrqe2spJLobIgxiwxJAIGDjv2/Ksq+0 03cccsb4RgVIY45wCDz/AMC+lehF8jWh5tT31Z7hLbXKwmMWihbeMHG3BPRen4f4VtSzswiMlssa KEzwPmj2KMAf5ySacrWWv9MmPMnqRrfR+feybilvK0a269lUDBOR15wfxrkb6O3HlxRliyndIVX5 nTqeR6/5604Rkm0TUs4pN7f5kSLCbqe4FuxkdQYwc/KT0HH8vT8aIEmi1B9NMo3ElBxjaWIBJx6A k960bUk0+xhZq3qQyyRWOpRwjcYo3LK/f5SQRx05J5FPnms55YpreJftTxjGf4juwTz2HJxTd7p7 BeKvEWC2ntTLNuPnvIYwy8j5sdKi1KAKYCrMInQpuYduMk9eSc9fUCi8ecT+HXocx/aE0WmrbWUm bl3ZUYtz6Z55/wD1VVgEVsh+2zEg53AZI9vx+n6Vulyr3Vq2ckveknLZI1THb+WBZKWlf5inYEev T0qHyr//AJ9E/wC+v/sqj3X8ZfNy6RV18jurdbY3Bu5DwuNq4GGHA49/Wte6kt5GhkSIk7dxYcEH HTr0zXJLmbWp6S5VA6PShaahFDbxhEHBUngHHPJ/ADr39qgcQWF6kshHlpjcoycdiMcY6cdKwd+f kbOr3eVTsUXvoHkNx5WZEy5jYYyoAJOe56/kK4+C2fxvrqasISNLtyVi2g5J7Z7YyR74raC5G6r6 L8/6ZzVE6zjSS3d36I9Ys7CKGcR7gYkUu+cfKQOPr1z/APqqRGitrGW6d4irTfKq53EAgfiPX3Nc zd2diSWiOSm1OTVBqkt1+7nRgoC87xjqO/tXAardxyXJggaQtIqlXHJGDz/LP4/SuqlG0rLY469S 6Uu/4HE2yJPqiCeeQ2aMW5bBDDPt9Olb8sDXp1CM7PsYJJA/v9D9Pu5rsk0mro4Kfvxab3f4Do7K CK3uIoQoGBs3cqM9ck/y966nw7aXFtHcG7t0nbYuPmBCtjgH09c+3vWVRqzu7N9TelC000tDvrXT pLazaW1h8tmQOFxyATkkY+o/Sul02OOWKxubiLbfg71Z+hT5eSeNvOenp2rhqyumz1aas7JaEL6e Gju4ZIz5pPmjPSRQecH8M/jWXrn2XSn0y/tVDBwMoxGSCQSDjPtjr7VEZOUlFdSqisnPsRW01jqU tyWcwPFHvC8fdweuOnb8CfSs22tVitxqMbFbaU+Yx6gEc++Px/wrW8knF/8ADmWmkv67Bc3xRBdx jeVkJAbnauMjn/8AXwana8tbiznBiMc6HzOP7p5I/rj3qlGyuSpRs4/O5b0eyULcrEm4HPOBkE8l sn06Z4/lUSNI0kkckjfL+6UgghAP6Y5/Ck2nJ6DtyxSexYgso2tklW5xOjZ4GC+fTP4fmas4nijk W5RjGTtLsMfKe2aTd3r0KUbI0zAkUgtYmDSHAR8fePcfr+tVXunubxbMoBbnBHUDcCB64PT/AD0q d9R25Sa4vFsphcSRhmZsEMoyRzkgc4GO+PxqrPp6R3f9o/bckqHZSwwyv2J9cf4U4vl1te4rXuk9 jQN1wJLRCs6klgRgFP8AOelUnsrrU3kk84GEgquTzjG7cT9F/wAKm/JeTRUtVZLc2b+JtPs7GSWE ZljaOFgc5C7hk8YPYfhUKxWQ0yYWSEo8m/pyoGcheckZHXnpmpu7Jxel/wAi2jCtpIotStLKQCR3 Q7peeWOcgew44+tdKNDlCywtt+2ZZ9xJAACk7hj04/Gqk+Rq/XUUdbpFFBII7u0tZwbiF32SMODn Cgr/AN8n8D71VvHktJLK1imLTHpJkhoxlww4PGTk+nNHut7bibajf5HRWttYanZ/LMsWooEW535X dsG4Mpz6RgH/AHutUbm7eeRbRJkZMblDbRkYLBD75JzjuazWr16GkrJKzMu80m5nmaawJEsU+6Ij JA35Ug8egI96IdJitp5YZ0KR7zuYtgtk5YLn2z0/+vWnOntuZuN5XfQopot1MWit5dtgXiEbuRvD /LhR9R6en1q7q9vc3yWGls6PqVrviBjYAn5RhT9AeSe+cU3KLab3Wv4E8skpXe/+dyCZZ7prKyMY jsrZDDvdABuEarwcc8hfyrTj8OQ3U62NxqAeRpcXCoQCV2jkdOQeOPWlzqCVi1G+qBLPTob+bSLV W86XzECsPmjOQ2QOeuD6V099pWoatHpcN5bMiRiOF5FXjzQXy34jaP8AgIrJyaalLf8Az/4Y0ir3 itjqfEVjoMGkXWmvehb61EcUYj+9JIzBQAPQHPPsOtQy6R4htL6+uAsa6fE0iPCGBy2AAQfQkAZ+ tYQkrWq6b2/A2s3K8NjZiaPT/wC0rGG5aOGK8ku2EjZMDsGTZn+98qtj0ce9MFzpF8bRYrV/Ltop 5FmUMP8ASCEZIgQcHIDE81F5LWP9f1cv3fh3NeyntToUNs1mCVhERGMKQdyg598ZJ6c+1Uxptre2 2sWct0otZIC0U8bEByqfJECD0zhfz6Ur8srPv+qHyppIyLbwpbw6FDdam6Prc1yHmjYjOzKBSCen 8Z4x0966C502KwnzojESQxi5lbhd8wfaqkHHG0k/RfxpurzScbe7r+ehPJyrbUzn8VP4je8m1BAU IQpIcbtrN8uM992Sfc/lX1i+0vUdVyuZUgtPNljX5cpGCFb1zkjH1pKm4ySi9v8AgCclJXe7PL/+ EwE96Le43CzEQMMUmMvkDLN689q4eCaz1DWb6yu4/KDF5NpwAxHIHPQk8Yx0xXoU6bpp26K559Wq pcqfexT1Cyt7PFrtxLlEjXqpGACee2WHpmsfV4r9Ly3S0UiV3JAZhtDdGPoMfNj6V0QabvLb/gHL KPKvc8h93a6qt1GySbluCFkk6gkkZBI7ccD3qfXZpxq1qI72NhEogPo3csfYbs9fTNNckmra6MmX NHmu92v8xmpPBdXMVrbRMbfy9m5RnJIx6dcg1mapD9kgguo4g0pRY48/xY7DI/H6ZqqfSLFL7Ukt DCYXck9nCWcuYVkJUnC4XOOM9uPbpxTJWj/tBBFua63Bm25PbJxn6AZ+tapK2nYwlffzNa2i0/U4 JGCFfKiaBecEyYyT19Wz+VJb2cKRWcjFdygjjAyM8fkD07YqOaWzNeWL5WUL25/sy6Ko7NC2GwAe cg/5z7VkzX13rCxM0YS0z5YG37xyMnn0FaqNrTfQ5ptqTpkBsWEix2kA8pm5YjlRnBIH1FVdQ07f 5cbQHyS24EdSeg/TH4VSldpmcqellsWrWCO3tUaM5beY5JT/AAjAOAPpyfrU223/AOfk/wDfH/16 l+Q03FWOyjtri3cwT4KsuR833SOgHp1PHH1p0bGG8FrNGyoVOC3G0AYJHOOdv61ytp7bHfdxSS11 NgSSi2AiXG1uuTuXoOfWrckTagPNmyufn8zI5I/L2rLRep0R5ndGd4njeSa102wdWu5gA8idNre4 PB5I/rXSeFhD4eaEfZBJZ7tsh/jBGA3T/JpvWjyp7/0hwS9q6i2Wn+Zulraa+vJZJwlqXCqxZflB IPXuPr2+lYOp6cbS7tpZJ0a2VvLTOT6HIx+dYRbTt/WxpUSa5l6nGanrFtardXCyBZWYFdwBAU9R 6nnPTPSvL7qTULu2lvYL9XR3IEIA3LjnI9M5NehRjZXkux5mJk5PlpvzJ4laJZrfId22yA/d3cjI Hbp+db8stlc20UX3Lh0znd029ckfhnv+laSTvdGMeWCalv3/AK9TX07RTdRWYWVUkcts3AbZMeo/ E/lXeaLpdvppkup23RS8sgJKtjkge/P+elc9aejilr0PQoUtVM6+21CERGxtxtYqzZxyi44Iz2yP 0riW1m6cmzaMr5Jxv2jBBGfw7/TnGK54Qu3zep1VJ2S030LktxLsivI7ljCp4QZJXOflz6cD8Dg1 n3FjOTOHZgYsODj7uCCcZ6H2q42jo0ROMn5s2Ht1i1K6ktCps5IFDEjlXxjGemOe/rTdN1Kzis5d Fv4mGn3A85yg6DBGBjB69exx9KlqUo2W+/3FfC9dVr+JnkWtgba3MW9/m2DP3lB4zzwRT7mQjUZJ JYkEDEMBwQgIGBz/AC9/yvVu/cl2tZdDQvrlLe105tPibMi7tyEqQckHJHXvx/8AWptzZJdKHWUR oRtIBxvHGfx6k49uKSbi1LrqHxXS2LF3HcRxrFBa7rMgFXwCcDAOcfp7itmxuL1bP7G0izRzEvgq CQey8c5IH/16mSjy+f6lJNT7IrXgFqC8TiRs7k5xtJ/h6Acc4/LmlFq9wzsu3hN7Z3DDc8deuf19 qS0tIq19OpPayicpcTeW0kREMTsuQ+SeTnuMn8h3pBYxRwPDeSFpl4IXnLDOB1+vbuPah3T0/r+r l2TV7heLdTC0ktJFBZyhjz8xyckN+ORjg/pVpbSP7JZ29qUEawuk2TzJghRjntnFQ3Zf18iUtSWT 7TbadaNdRAqjMCpOeMBjg+hBq/YR21/a3M0ClEmyqLj7uPlzn6E5+lRa8eaO3/BNOtrdDGkhsbTU EhZ1F7HIrHYg4+6Sf1AwD6/Wu0trO1VhbyXTBbjCnIJI3OoK+3Q8+1OpKTSYQW6T2MCSOyW6me4b YhiJOOOMgj15wTVSwuI725itfs43xq4SRjgSDA3E8ZBBJ/P3p++0/wAxe6nYZolrJc6pHeyBjmcZ TbwB0we3Rjn6fSr93o1nfalqf2pV3BZHQKcBScOGHfoDx6023F3XRDtzRV1oW7SRrGyaC2VZJWgQ RFDxMd4w3AI43H9awbrUfto0yGa3YOzOY3lOGGeVGOuCF4/3qmK97nTFKStZr+rjbe4vIfN0xIl8 yB2lhOPuycKAeecnA+mKg8OaXKmpzfu1n1GMvJN23bvkz/48cewq5WjGVnvYFeTjfSx0cWlWdzZR xzby8squgU4KIzSgsR2yVJ+gB57Ufstrpl5aHzzFZuSyyn75JYEDp1IAyPftWd2/dexdkkpNnf6n Z2UcGnXQKJ4ieJd/QmSSR2/EBVYA+4FbGp65Bpvh57fULhDeRIkzIo3EKQY06HOdrMTjuR6CuZ3q KK6/p0/yN01DmfSxyVxpNlex3niO3us3895cSyA8LHGrBxx6jAHY8/WrlxA7TW811LMFmlDSwknG RGu0Nz+P+TVubaV+l/wISVteupttqD3+n2mnafZqxmvJLhyctK8gw3zHnJ2qo/GrNu/2C2urSztG WOS1+0ozcpuOFwCDksQcZH90+2crNJx5tb/gaKSvzJGXPMttHp8V6jNeybZLhEOdw+YNwOgBfFaL 6MmtwWek6XcNa2kdvAysSATs8tlAHBy28E/nxT2tJ6xBJNOK0ZD4bvbrQ4TJ4hVZtUvQ4t45TgLg jYSc8fIxOBwcj0rd1HVpdZuNTTTwPs0eZVlIx54VwqnB/AY/2aU6cVPnT93oC0hyvfY8bv8AVrTM NpDcJGEK7c8jy05UkcE/eYY9uK5PUddttN157uN2aBHA80qTuHIAbjjsT6V2QpuUuVLp+pxVZqKO U1m4eDVINSsP3lgqE5YZJU/NwO/OK02eG4vJvEuo24O9xI0YA+QMwLD1HyjGc966mnyxcXq1Y47+ /JPZO5j6hqkQnkW7t90k8wYAAYiiRA6g+mSex6AH619Qkiu7tJpFIyjCCJeNvXdz9CAOe5z2qoxa a9PImclK62dxmmzST28VvM2VaYDO75hnAxnPqT+f55MtjHZXhe5kDQs8gjPuucfn2HfINWvdk0t/ 6/yIqO8E2tixHc3tnbSOdog3BEGRuyxHpyeNx/E/SlhhF5BBMCW2v5YLHpnJzj2/Xj6ivdj70TNN z9xmRqVxe2LW8WnQ48r9yHlX7xwM9PrikhWKGaGe5BaR4jvfPJYsCwH/AI9+vrVpWjo9WTK/O+xB HefYry4Em0ofnKA/KpJxnPqN3v8Adp2rajc3MUraVaERZ8tMsfmUdSOePqMcCnyJzUnsQ6loSjHc om18sy3LTGScnZjKnaB1PJwOucdeKvbbUIXhkIuFV3AC9WxgAAd+R29fehyb6Akra79zPnie2e3l lBLyBozHxkdyfTNV5L24uI5Sy/vPLxEq8bSc46+gxn3p2vZmbk43iyskEptpllbdtfaFU53npgc+ w/Wq/wBjl/6Bkn/jv+NaRv8AZ0Mm4r4k2em/NItveSyYeNmyvXOMDt6VKji6ubeWdSCpLE4yc84x 6dST7VwpaaLbQ9SDvbszooltL6zkijAF8jlo9rD5jtHqf/14FMMkNrZ3JnBRUXop5JHQfXr2HpWG rut2dPRyt0MbQbB1uLnUriZhLKQykrnC/wCGT+ldzppCygLNm3DElm/i3Y49Mf8A2VOo7vbQmkmk rkt7BE2ptCxYRt5hZhyF2/MPr0FeW6rcahqKyGOfbDuZlJOMD5sHBPfOPwoo2clKXQnEN8ritDk/ Et5cT6baxQtGTEc9vn6bhj+tYuhyQ3LiWSU7SFRggx5Y4BYfn+tehFJU5dzzpu+I956GzqENiIJd PlZhKj/u2JwUwACD+PH403Q7KIywrKpa4RWQgDO7B9uOeueKWqgUox9p5Hsuj+Grki2VmEarueBS BubJ4A5/zmtbSvtlqt3bXWySBTuhkDDIHY4I6YGMVwTnCfMr+jPVhBw5W+pauLM2y393FPtmjUFg ASMMoBH5449qwoXs9T1K3gt02wHi4eQfxgkBs/jgj/Coi3ZtdFr59UU1eSjcrXTJam9svIMrRs5j MSgh8HGPrkj8vbFOhn1WOSCTavleUyvuIDbsZwQfb8sCqsmrv+tCE5PSKKtrqthc2sEbqP7QkeNZ lVSOOQQR+A5/OtPW7b+zb2S2slUIGEKysowVIB3jPt6ehqtYy5Zbf5BzKULx3VvkVJIb1HW7YlyA SkhXlW4yD6AdM/hTEnk1m/WxuYtsu3zJSO6DHQ45PX8qaS+LsDv8LW5v2kRgyivuskJRFcc5J5we vv1FNmBW2ulaBjEZAFyQMErxx6Vne87o0slFmrHPe6gtsYDH9mxkgEZB7D3ORnGafbRyLa32pCSN WtJwyPtBXOcAn17VL5Y+73Y1d6leNoNRS7S6KmUuHyv3QpBO0fjT7EI0LNN8qv8AKhfPGMkH68Af hT6WBItXej21pp++0yZw29lOSjAg8qR6FT+ffNRyW4V7c/aF+0SSGR4w2QAozu9BnbjB7mjn5v6/ r0G42ZYh0g3htPJuQyyStInPzBjyG9uCefp3657xXjW62P2cm3VyqTf3DlWJP6/rSWr7NBNNao6a P7DcWaWaAygtuByccoNw5HHTB9jWW9pNi4sLGOSO3QJFvz8odgmNpx9c1mm9VN6bly12NbRdHTc1 xfQCW7djCQByUG0HPJwx6f8A666BtPM7hIS0bQXAXJXgjBbGPrtHtk1Laur7L8i1H3U76mArzara 3l/cQiOCKN48YH7xg6ttb2OAM57mmyRW8b3OoWMKNBHII42C84Z1YHPX5s88elUtPdT0WhOnxG/J PbaHafZIogZEkiO5Tna5cFj78gDtwa5R4rnU9Q1G8uJRERcSsiHowO8/dB7bwf8AgNKF1ecgk3oh kdldx2suoRz8wqUjjUHCSA8cemV6ds+2Kv3Gj3Fu1neS4WeSOSOLK5+UPJGm0cbeQBz2UHnvbcU2 uoWbWhz6b7i/TSoJXN5cHETgna2Sy/KR1YNHkfSvST4XFlNpKWshggnz9pmJJkBCqGJAPQbcjj+I 1FSfJZW3/wCHt+BUE5IsxaPcNe20mizJJbRuY4S+F3IrN1Htgge4PPrqajpGlanbXlnewGCWO3Wd QXy1ozIzxkH/AGiqDHQE1hKo4tSS1W6+f9I2UUlZrRlK501jawvdPFLdrcRRo643TBnQEjrwA5JP QBelMl/s27lCPaGUT23mzBjhgfNOMD/dZcD60KTsnH/hhWSVuot2sNlptnHlJmDSN5KL0Hygkntk kEY9j71c8P2N7rWo3E2oXwltZZrf7QGwFJzmQjn5UKhcHsG9hSbtT52tegJvSP8AXY6eCfT/AAnd pHoaQy6kkiT7nywLuCNoAHTcef8AdAyKq6RKdZtbzT5cFdKdZJJWT5o4lCEbgBg7pVYY9Dx6VknL WvLf+rfmaW95QS0MaKyvoG1W3ht4Tq0sLrbK5BbYxEiKOeNysGJ9jwa0NZ1SysXsY9UgRbmPdK53 ZRyu3dGCPRdi+hKVbV53i9f0/wCHE7K/MZOqatas8erS2rFreQXqW0j8rGCiIvcBffvz1rjNf8V2 9raxSQzDyVXDFOVPylgucZ4Y89elXTpyk4pvRGVSagmeRao1o8Vv5V6puIzGpdOQVZs4HU+3Wra3 2maRcra6za+Zbxzqzr9792pBPvy0gGfUDFeiudxSStLoea5RU3Le/wCpi302+CGKW18qZ52Kqeka ALgH3BJ9O1Nmhtpop4ll2SxJ5kgfsCMKv1OMY554rRXil11Ikm7v/gHOyW51DZqdxlUyIhGccsqj JP1wT/j1rRe5+1uJra18xw3lBgOHUEgnt1xnnPFaO+ltloZJXXM1dsmWyijmmV9gjjb5nU/KHXg9 8fLtJ+tXmu7K8sYZb7YHiklnWQDAbdtVBgnovP8AjWbu2mv6urFWt7r0X+RQtXjjlY3h3+aN8MfG IMhecDv82OOuWrIXVZ5kkhmiaL5hHboq/wCtbdsyc4IAG4/hWije7e39XIcrK9hNSa6v7tIpZF8s yiPYoxk9M/iSp54qGe4jSNoJxvuUd4UKLgAN2PPufzx3rSMdEl0MZP3pS6mdbadHftPFeTNGcnYe D0II5/iGT07kj0rdaxMaOv2lRHEY0QJj94eS2DgdzjPb8aU6icuWwQpr4lv+hhXoumdoFjUzKB5j A/Io3gn5s8nBH51LA4KS21m3zB8M4A4wQTgnp0znHT60+i1FrGeq1Zl/aftLsgk3XI3FGCg4UlVx 6kkZHbp+FZ8bzIJ2ZdqY8pBj23Nj1+v1q4pbdTGb5mmOaOSaOCSByIgFj2gcljnB9+/4kil/sy9/ 6af98H/CrtH7QRi38J6ULSBIVELAROpYbmxgk5P0PAB/H61oyW0f2ZjEdjgYOBgNkZ7fXnpXA5vq ejFR1v0H6TYXsszzykRlepHQKCD/ACOCfYVhpa3+oa1dlWMkEIEjMHzucEDJ7dRj8DSjKKlK+yRT i7QV92egWklla24SPHmKc5YEYXjOBjv/AJzWVql5CgVLaM+UzKxxj5SOv4Z4/XvWCUnL3jdtKOhl zXd1CslzeSlWaU5fuzfT05I79K47xBEjLHPbbhZh1MuSRgNgdB9f5H0rop6S0Wmxy1m7We55/qTT x3MUSQhrLk788jgnJJ+v6102iWZt4Wt41SSYjBLDlVOCfpjBz9DXY2lD8zhpRcqjcumhcuLO1aWE lvmICHcQCGVSQD7k/rjpXoVroMY1EaxBGkdqwBCqOGJ649x/IVzVJ6cvkdtKClJtb6M7e4vrlo7b T4YzHexBJIXA4ZctkflgY/2frXMXCsrK4vMMwAcHBx0yuD1OAc544/LljFbWO2V95PQs6KiThbNp zJbuW3rgEsD/AIHOPy+lPT4zYyyWuwJYl2U7id2wsMDJ5xnv/kVq+aKFy3UXfQl0qW70rz7eBd8Q Jm2twyAE9Dx2J6H0qhcxGzeFtQkaKeXjJIBjzgDA+hx7in7rldbsLe6r7IuRaLYxXMc6yIwKNLEq YBYjIAIPUd8ds1seZDeWbxTxsTkpGg68Nheo7E9M96Upyk15DhGMVKKKj3Qki061gm+9A5mV1Jy5 OCMng8DPXir1hLafZblprYJbiNisoO593TGOuORn6ik1JLR21+/UtW2sMmePTZLeESG5tEBaRwpY LuAPB/OrFzcFraK5ncKrkKsYAPB+6fXv+H60b8rSBO10PsbYqsnlusUQJzESMr3GPTrzx3rTt9Nt 445rYT/MQWwx+WXjPPXPIPXmolNt+6vMdOMLPm+SLdvoFzBEt4ZI1Em5mj3ffP3cYPYA4FZ+laBb x3d9DqVxthdjHExIbMoUkH64JHf9MUOpdScdx+z1jzHS32hX65e7uQllFb4iBAImIUcDrnPU896T TtIea5mmmtgFgiWR1yf3meCF3dT97j6+lQqia93b/M0cHdX2J7ZES4kWWJXWK33okQIZAqhjnsdo ycfWo95bUk05UAZ2wSThdgxk5/DGfwqHfd7A2rWe5Us9ONo0ELOwgDNGJM/dZXKE/kQeO1dDb3ln YPb2chSaEBXfBxvcHIY9z/DTm3JWiNJKxdv7FZLgajpUjNbsI5HG7nzJCcJ16fL+ZqvpjyrazRTK WnmkliIJyYQ2GJH4cfjWS1hsUn22M6O3jgs5Va5YRhRI0bkgMGYEvwBzlAO459Knv7eKeRNLtQYr DcJmdTyHyojBzywG3H4nvWzeqb23+YtOVp9SvcreXV5ObeZFhh8maZs580tubHqAGC5yO35ZBju9 Ut7PUrVEa7Ynzpg3BQnkEeuMD/gI4oSirL7/AJomV+Z/gdnapHBpN/JcczOJEWDZgiV5EQtuIzjE Yxj+8e5qG0S7+3RTvltMt4WU+dkFVOGO3PHzMT39D3rK+jv029S7NWGjRLKWXS/shIvI4zGHJ2je sm4MMdPlfPPq31rrW8L6tf2msXem3IO10xIW2t5S/fbafuqS2zoPu+9KdVXi5rT/AIJpGNleOhpW cNvovh4i+VF1m6lhs4vMJ+f74eUDoSGUH6ms/wARahZ21+NMe2ilvo7eIXl75nEzuUdoeR/Bt2g+ jjBxWKbcm4ve/Tov+D+RT5Yx2GPZ/bZNS12zeL7Q9gVjtFbizO1QTnsQiuT7tnjms7+3TEl8ItFA u5poo1kZtplgVUZ8dsZZufRB6c2o86te1rL1JlaOtjmZIrKOwfUXumjjlHlO8hO9yrRhwgHPIJA/ QY5HW+GURjqk97E9uFnFvDCWAGI8RjJ9AiE9vunrnFVOUlF6eX9ehMNJKwWHiTRNKm1q3MYk1AO1 tgMWaMbwnBHcMykHPeuhaC10zXNUuNNBj0K6ggeVpSeWaLCBx6rknGevfvWTjOMmpbPb5WsWnF7P Vf8ABMe/1XT5b21vLCGRb23jNtbb3yzlIljHHspPJ9D+Pm+oTQXEcsd9e4ht44pxKxI+Zo3DBc8s dwz3zxWtKMrLm1f9f5kVZN7bHMrqep6y1+JpAbZFEewZ3yjDzYzgZ5iTNcdqTRWMc/n7fsZBhXcw BbcCWcAnPcjnpn1xXdTSvyROCpNfFI51dJi1W9M+lPt0xdyoGcbmfAVSxHGd2MDHHPpTpNPebxGp hYzQzS7FUtuDoGzk9uo5OfTpXTz3fvbpa+pycl1dbN6en9Ml1LffSXl5pki/aFmKBA2QNwYsSeck DP5dafcXFsDB58zHUJCSwQcbljJUkjsHYflSV7LTUrRXlJ3T/wCGM25kvpo4RJGsdkp2sY1GCM7f Tknr6jn3qxAs8MGrQWpMaQjCyMcHG0HGRxuOD+VPS3L0v+pKu5Xfb9H/AJE0lurW0Nk6KJ5USOOI YO9iFOQR2yckdR60GRFhaUwqbSKLb5gYEzYYs2Oemc5PYDOR1EpvqDsttWRWen+Vf399qEDQTQMI ViY7ju2cggnoM547jH159Irs3Md/Ixa1QbFYgAZIOOB3Jz2/U5rSLvftayM5J8qt3bZQS1u574ta looXVVMjMVLDco3HsMkgZ7da6exGk26pFktOC86LgAscbgrdMfMB/hV1JPaJnSik3KZcigjubcCV djhf3kjHIlOWOcDsc8+lc/PaPbsbZpS9xIqom0n90MFnYdeSSwx349BWak7tGkkrXWhPHZyXJks9 7m2hcrIdpDFsHcD0JOR+GazDMsDx2ttGojkOXXb6gfp/kVcW37v9XIl7q5ikY4dOmhMVwGhz5hxg Mw4x149u3I+tVLlWmuJ790ZbZcsFQ/ezyBgexwfY1otXdmMkkuVMy5FnKRqH2iXDFV6gA/hknH6j 3pv2aT/npc/katytpY5p8197Hq0sTTQMUkAkf7hT7oJ3HAz/AC9q1reeKK2S1vTt/vZHUluuT2Of 1z9eBu8eVLW57EPdlrs9Bdd1yCy0xLawH+mzZVJVXICkbecj6evWr2kwDS4LJoYd075E5Vuc5zu9 +cD8Kz5WoWb3f5Gy9+enRWN66023eaGO8n8tGUlOQckfMPwPA/GuJuDBezTPHEUgtoihVMgOQe/v xkfTilTbav0Q6iStB9Tl9S8RRyXgslTEEA46nfkKPz9v/wBY43UNQWWN7sCQxMfLeMY+XHGcemcn B/WuylTtZt/0zzq1ZTuJb3MEEUlrfp8wj3ZGM5Y8D9P510GheS0VqTayOGOx1VcEADj8D+PXitJc yUmhUnGUkup28GmWsNk8M1iJPM+dWPJjZc4H65/+tXU+GZLi2CpLaBoR868ZyCMZwe+a4pvmi7yP Rpx5JR0NHxTqzyLZPo+nt9pLYeUpjDYxgE9uo98da5fVWfW5bhLphBGAJGXdyWAIAz36Y9eRUU4c iUnq/wCrF1G3eKWnQheOWTS7JbV2iuy7B9nXHQ559v5fWkuDJdRtdksquiKZTwOeM45zyD/+qrur 9L6/cReSWj7f8EmGqSWeqSwSMpuki2wjI/eIRtzg+2Pz9qv28j63pbahrWjPsVSkbN1DL057kbf8 9aUo8tpp2ta34lc/M3CS01v8v6RTmjngkS4uvkja3wGwSF4OQCB/nPtWleQ6zKEnadTHEyMQh5Ge R178fpRaDs5LQfvWdv6/r9Bmm6pLb3OrXFxAplRSqQ7cghwofjsDxj/OJtINxZ39yBZiSzJcHeM7 A4OOB34B/Ck4NKSb/rv+Jab7dy1FuIuraEqH3kxrjAYEKB07dP8AIroNRsxp1zFHPYhpEtxKoRso VAIP481DeqSZcU+Vs5qOH7VHBNHIwupnLlwc7QFJ24PXABGfz9a7V4IkSCV5dga3jbI+baTuPJ7d Bz798Up9EKKV27mpoBkv41udXR3CIxErZ2gfMPlxx1/Xrip5ksYrQy+VJOsbkxKuB5jgHd97GMMc fh71i3aVo7G6ScVc6qysLK5srHTGuI5b50dIhNLzHvxtB56g4I98VSn16LS7nU1maNSgNjNaMpL2 7KDlwB3PY1lH33b8PnuW7RSkjzhvEGk3Oo308CPCW84wAc+ZwMow7DG78z+HPXnifTrMvDI+2SX5 o5C2fL3A5HPONxUDBFdcYVH7rWpyzqQSUuh21lfrK6XmoTeZalo5CqMvzJOgBIXsf3ePWrWv6bYP b6g2mAGy0x8PMDhirDKoR/suGHPXGazV4zSitP6/zNdGrvcpPqU0FpZ3saF45GRUwoQxEbgBt743 Kf8AgJ71v6fZajfS2cmlyQebPMEmaQdYUT539uASDjsaTUYp823+QouUtlqUr5ZrnzpGASYzxtbr JyJk/eEDjqCwA6/xL1qIx6vdO4jtmeFSDKFOG8x9yqM9wCCT+HPNNKL6/wBf8OOSl2HolhDBqcMV w7POIX3njAP7wL15+XbwK2vDmlm21G2zqETGK5jBt23eXM4j4x6p8oz06nvUzlyxfMvu9ECV2rPY 1Do8Wo3WqSo5kFtHD88iqI3dWGdoPBAxx/vk+laOnWl9rGm2f9sOIrdBHuMSjMoEextvQYUxls4G M56g1m5Ra5rbfqjdLVNbM2NS0RbV9POhzGeC8WLEsilRFIBtckYHXy8Y7gZ6YNdTqipbWhuNUjLJ fvHGrRgAo7gGUNj+E7wAB0FYOTnyq2rNEkm10OU8TW8N3NDfajdFZrSKWJomXmBJGkaORckZPzA9 z83auc1G0uJNOWzvyiyFQ5PKmQKyFASM/MyMOvZfetYSXutdNP6+9ESb1sLdabHJFf60sDRWVsps 5EjJH2pYl3F+D87FiEyD0OMekV8A2lNq9xahr+z8+xETMFErZSP04VUbH/ASfctO9rPXZgo23/qx qapo+kSJp1vFChvpAbmOIqQGWMqCACOpMpPpwPx6S8XR30ua0u1IngWe7lfd1ZxDlWx/d8uRBn+6 fXFZucrx/ryKShd37W0OctdG0dNIkggtQmjI0E0M0gO9yZB5hkzng7Sef7vfHCX8eoT6HqK3/k/2 f/aUkgdHz5gZnkbdk/8ALMPyOgCgdjQm5S996p6ddexFrLyOMv8AxNYi2ufENpbG3tXilCxSElwG VwzoByByuf8AazjoK818Q39hqN9pKbx5MMMUUYCkRy/uyGfJ9NoPOQOO1dtGM1LmfT9DmrTjZoTR bm3m0+G8W7ML2yBbdVyPNK7EYkjGSRMRjnOWrltXS5udS1C0EyXEhuPsxI53cbmY54Axz78/j0U1 77v06nLUu4K2zJLmwm0PRLW7t5ysssrQk4ypYON5/A9D/tdOKz5LqZ4Ls2IKXMc3lDdgHDPvJHfH GcfTpVxtL3n31Mpe4lHy0Kb6U6W8siTARDzBBGuT50hRQ5I5yAx/HHan6HDe3EmoJ9lEkbo4lYLn arjPHsFIOPceuKtyjKMm9DNRlGcUtfw/ruT2tw39mrFdREsbtpHywHmEngD2/h/L61WtlmiuptPu Y99wZXRkXGGfZ1GCM4OF7/ebvxU2S5kvULaRdvUrS38d009rExeeNntQ8bZOAucgn8z/ALw9aqm3 jt9KtIbuWRLiJNzgE5bcSRgfQ8gdiT61qouNklqRJqTctlYxodUu9Sea5ZmFrHuZpJG+aTjcT7kj 5fw605FmsrVDcEyjeZo4t4xgKeMDrycHsOK1aUHyowi5T/eN6al2Jo7m1h3u0l5NLsC7eBtG4cd8 s5OM54BPaphprx+YZIwoLGRCGBkIw3HqAFVST6H6Zyk3G6ZrZTewy2N8bxjJJ++GZPKUBQ2VO5eT zyVGMDgHjniK8luGMPlbd5ODIg4JCqeDjsCf/rHil7vMkP3+XUdpbXlvOI7gM9sHMsgySW5J7YO3 5Mk+mPerEsUNzIkESZhd/MYd9pOQBk8cnr369sUaKb7AruHJLc5+ceXbzoQA6Hy124IDE449uW9O nvUcltI0RlmOdkaoyKMFs/QdOR6d62Wmr6mDSei2K/k3B+0bnUJywIPB4AGCevOfwA9Rip5Nz/z3 H5CrtzGL5o7pHq8du76YLWI7du4oOTuGPX8Dnj0NSJpNq2iCXU7tjdrGCSxOFHVR+ePyrz5SaV7d T1FG6fM9Lf0zmtD0S71ecahKW+zxSDy0Y/L5eSOOx616hJpdhCWlnkkzGCY0TuQCeeuQcfrxSry9 7kiti6ELQ5pdTA1a1MqmS3mZmcbmEufk5469OOfesS4voYrKSCICJvLI39dxPQZHfnp65+lCvKK8 hTahzM8x1O+MHltaSFr7nduTlmI4xnOByRj2qtpVjNq10Zp3bzymXTG3BHsMDJOMetdq92Lk1r+h 5bfPVST0/r/hzoktoSgS5wZnjMW1sZTB4P8AKvQND0yS18u8WzdZzIsbMGGN/wB3Pt0HesaslZ62 udtCnd8256ButNLuf3+DE8Y37gBtJBIOc8elZEt29szfY3DwTQbUJxgjjqOx6j/9dcSTkm5df0PR IFm+22n2SOd18oh3R0IbJGTjPpj/ADzUF7Bus4JkQG7ZAJEB4JGcMCevU9R39sVaaUrES20MqfSt QWCdogyJKQW3DBXrnHXI68+9V0ka5AW6TZbLGG3rlcgZ4I7ZyOfatfcesd/zM7SUknszbs7ezaR5 xA66glvtxtJDMMkfTgZ4Petm1utUutGn065kUWW4hg+Bt3D5WGMED8fWspq/x9P6RrBdYbamVrdp PNZ21whYWyjYV3DKMNynr0U46+nNFlZavZzw3UkiBFZHKM4IfALZIPUcE9uDj2ppxULPzJ5JRlde RqpCJ7qa8gkRYmiZ2d8EPs42qM+65B7U+2DWkc8st3shnk8tGDcfIRuIx0yDx9D61Gnw2NX8VzOv La7nsp7m1uSk8Uf2dvLPzSRk4yM8YHrj0z77iQXN/YTPcZ+2xW7MqL1KliB0PQhQf6US5bLuhJSu 3fRkTQXOn2+lXFpcRx3AlEqhgP3SMCrIRnnO78x61v213ZajJb2V7I8aSEq/ygAgDuMepBB7/hUS u480dWr/AOZUHaSjJ6f5mp/atjpemyaeLgmGESNGEUFpHMgATHsMkn2J9K3fnj0mxlmgRLuyjjjj KdLl/kG5znkuzljn+7WUlb3npd/f3/M3Uls+hpWN/ZNJHq0lglxqovEeWMN5amIbSDuBJXjeox3w e1cVr95aX2p6nrfm+U8ryMI1HmyQMBtjDeoP+J+qhGalrrpZLy7/ADFOzjqvM8J8TavPqN5FJZ2q y2toB5xtwFZWJ+fdnHZWYD69a+N/iR8UZp2fR9LuWeONyTIfvqEJVV3ewPb+gr6HLsPzzSetvwPl s3xTpU3b7X/AL3w6+NGr6Peac9xd72gkSQLKxKybTkA85Cjrj2r7K0z4u6Rq91BEY1az1J0a8Z8k mWFZNxPrl/0A5pZhgbVOamtP8tV+RWVZkpU/Z1nrp/keq+Fnk1OJ4Xhc2kV3G6z5G3Y+cegHzsM/ TP009MvtO1GG1WZRHfR3JspQrb/k5ZXx3AGR+vbB8WcXzPyPoofCm9LnZywSTvZz3EP+jQxwxtKB 8gYcjc2QASH2KvsfQ51NC1u3tV13TL0oJ7iU28bqQDITmbzBzwvzIoJ5O0gZxzzSTceVPbX8djoi +Vq5SsdAW6e2NtbvPqodGcEHAVA1uxHqwVMk+itmt618MWr3Ulhdw+VHLEDp82w83DMU5xzjPBOC OBxRKpJ6X/r+rjUFu1oWNI8LXapZ215dSJaXUQk8gAByJG+Un3CvwMjlMV3+jz31z4d1Ce4tILCX TrKULbyrua4ZYVidcrzg+XGT13ea3UjjCpKEr27/AJ3RvGNtOphW9xarOlpcoZL1NTSSMxBfLdjD BHhW/uhVJJB6sepzVPxRfJqn2fUTPEJYyhmghzslcyvEHQDJAAYYByT5ffuRi1Nf1v1BtOD/AEOb S+g8U3smq6pK2+zlmiii5UzhC+xmwcNhfLHcZjOD2GXrekahHb3Glx3xN4GDNM21jiVkdBgnIKRN yecH6VtD3ZRi1ovy3/r0MtZKTj1N4C5itlezu1a3hlgt3tFG4m4kBEgI6nOxjkjjBPGak1nR/Kmt vDEVuWBn33M0QLI7yZJjBwB0VePcfU5KXLK2q6/cv1uU7yjuJf6ONSufDbPHJHq8KW0NqFLBbgiY HccnI3LtBx+fGKn0y0ubS01O7vZYHtnIaZOrSO0L7lJPYFgQOOU9eKTlaKW1tn8wslK5y15O6aDc SRhjKJpIWQt+6uFBOxh/dySOOe/TrXmsmseZZxadDeulm0X2pEQHbEXDlkAA7qynOc5A6YxXVSin fZtO/wCn5HPUk1Z36HKXpkkult3DxaT9lRGCru3IFY7QcY2lnA7ckc+tJGto9MGnS2cDalKqW8Wf lEZIKJjHHGUJPqCMV3e8vh8v+Ccj+JqW9jKZY4Hm0mA42xbYnKjYkZZWD5HIfKxg9MYb3rV0i+sr bVLq0mVYdOWIM0jR4bCqVYcZzwrYA/vfWid5RdjO/K15aGJc3f8Aa+ow6ZpwmbTIklkBUHEO5sjB wP4nAyc9BSy2jsLq7uGGch4yB8pLIQqjjAOCc/Tr6WlyWT3/AM2S7T5pJaL/ACLC6rJZ6hALyBAC 7wQRg8OGfaSOMEbeQO+AK1kih0pLy1t7/wAqCSBrd44iCM7BlySOP9X26fjUS91cvQF72+jX6nGX 9teTzLPboRBbBd/T7sa/eAPv3/2vYVXZ0E07zTzCWMtv3Bi7viNn+90BY47Z5OeK2XwpRWqMnzdd jLnnjsgs1lbnKSy7xnON3zEj+9n5AMflTb2+utYgiLgxrCNssrOCZQABk8nAC/KOnJ45raMbNTl5 nO5O7ppD9Rhigh8uaON7Y2oEG1yCkm7gn14UjHH3ickYFK+m2ggjuBcslzH5cWxTzuABIYD/AGsD pnjPeoUpON9ynGN2noy86fZZL2dUEtuPNUTYwhxycDIxyFycDHyjAyajvZTcyQltzyqELRrjCjCq cYJychlAweCM9ahau9y2mocuyIp4pJLm1uLWAvKRyI2wFGX38eg5GeTx3xT9NBsHc3MSid38wvyu ASzbWIH3QMcdTjJIzmqfw2W5KTvdrT9SKS6F7JEsJddyrJI+Dl1AOcE9hnGByDnI55rxRujNKJNs SMSzE5DAZ28EZ4JYH6D3pr3UT9p2e5SUyvLHFcEpEAfOyNzHnB+Uk4JBAPTrx2zNcHzjLPIB9jky +FA+UBAiAYBJ79yMjB61dkndf0yUt0/60MJniubJztbAPlE8jzCMqMdegXHHofwy/sEH/Pu//j1b RSWknb7jiqK7Vro90fVvIRjLAjuj44HzYyP4e/0+lcrqSXviG/l0mGIrZq293UjoSOBj065PvXnU 4KL529j15PnSiuuh6Tp7R2cP9l2UX7hY1XgZ5Pf27D6mqVvcfY3ufnWQSoEtx8xG04HIOMEBax1v Lme507JLtojnTfXrwT29wfMvlkLNIjHBQEY6nnkivPb7U7B4yLlvLKsVUZPLZyCT1wCDXVRgk/dO KvLlinUZnQtDqutR3Sw7LYtkEEbQcdOef/110NnM73DyxWuGkfc5CnG9PmGM/Q/n+Ws46cr6IxpW lqurL4sY9YWO5+xsLuIkpj+Ig56dOc/54r0K0gutM00RBpDOHVypJ+8TjBz06fhXNW6Qvc7qMbXn H+vU6HVbeLULG1lZcOU3OUOMkDG36gnp2q7ZQWd5YxrO0fnxxM0QaPadwB4GOvf/ACK5m2oq/Q7P tNs5m5trWHTBHI//ABNnl3llYHy0UEHIz+Hr3oks7m2ttON0RtbG1oQCGRcZ3dORx+NaKV9zO29t kU765utQgfUILzy0R2QxnjA7AgeoP6GtOz/sq5jN+8DtAGEMibcZ2jGeTjrt9Oh96bTjG0d9gVnp IhuRPJqObm1NveO4EJjUZdAOvsTkd8fNWSmmaldXIVrjbA6q2TncMAk5z0yD+FEeWK76B70muU13 OpYeKf8AeX4i/dqxySc7Rnr1H8veuauHGs6mVsojHPawiIg/d3hic+wwevtVQtrJPRdCal7W6tnY vdTTWmmxQ2gCTNIRsOI4zkBsn6KfzPrVNLS+vIL3SFsVYS7RBMGbEGCzMT6DGRWaStq+v66lu7uk v6sXIIhp8Qma4VxGJLWfaPmmJK7cHHQnAyOc5Oa29Hgt7uCDUdOWT7SUV515x5ZKqSSOu0twPc1L b1kti420TIdWt9PDmYXAWcysDuOVUKxK7QfYfTOantpoodOOsSKCrIUlByGYrgnggHsCfp60ndwV gVubQwru6XT9Qtk1CAiQtNuRsJuwx2lcHkjBHqcfWro1+e+vxBFeBUklBWOZztiULhTzgE9BxjoT jrVcl0nuiVOz5b63Ne61W2sNZ1nSbeZZNPYkiTjyWESuE+YnIyeB/vdKwjqMVq82oXFi8d1LIiGI yARrGgbLHPHzLjp3DUoQfxaapf166DlJWs1s2eK/FPxg+mabqGr2GkfYJI5I32KwKTuigKzAEDlW HH1Ffm1K4uXaVny7sWbOT1/Wvpspp8tKU27t2V/Q+OzyftMRGnaySv8Af/wxQMkkOcMdo4HHWu08 L+NL3QL2K4hlPlKSQhyceuAeO9epUpxqQa7nh0qjo1FJdGfavw9+N1rfWepWdxdeXF9lhjlikYD7 QBKoO3PQ7GOegGSe1e66RqtpJaXd/oksiGb/AEiGNUb7u0IwJJ6MrIox/ebnpXymKwzoVJXWj+7o fc4HFwxVKEr6pP5bnrXhrxLc3Udh4U1GyEUdzdRwSytIQqy+eQrlc84WRQW7EE8A8eseFZ9A07xc dUj0ezl8O6ZNLIxnDPhREyI7jGSFkIxyPXIwK8erGcOaMJXve1vPRHt0pKai5rVWNnw+uua1JdNo 2nzRXj3UiQAYUpam3Yvy/AJyxYZz8/B5xXRaZpdxqNtZ3ViFXVLV4I1aYb1nclRMByAqhmicdyN3 tnknaDvJ3a/r/M6YJz0N3UdYgUhbWMz6xJKNGtpFiMhu5LiQwR42HjZ5ruoA4ZhngGsnT4bKWxvr 3Vmfz2dvtUZ+VokBkCkbf4S8kZJJ6Ko57xaUVfrsvzNrrn8v1OWvdK1K+8S6Hbx27Wvhpoo2toYt rPLBjfLKSuOWKupbrwO2KoaXYadNq+iacyr/AGPeSwWKSjgfvJDGH5xkgsh2gclTxzXRe6su2vrq YKLvrpr+BV8NSW+geJzo93p4l0HS7i6gMspH70eR5QAcg8AMgHfLk54FXbB7ye6tr+8s4YHit2uJ HYnYzyPISDz3EpAHt0Hcnbmcr7paet/8wjdWi1qjoHuJZfENrcAQW9tcMIGvJFASMNKZPtDbjtB2 NLk7sKCecYI5qCy1HRfDtpMu5IrSeOKN1cKySNbzSxsFIOVVlLfKM7dq8E5qYuN0t/6Y763RBfXX 9n3MVjHNH9n0p44mNxIMyxRgsyJ/ES3ltuf1b1Iry281OCKWOa2uIU0yfTo/mVstK7bXYqA2d+JM kY46Y5rWlG/Tp+PQipIwdQ10TQRROHl08Th54nAZ0cojnjBIXdvOz16HrngZru6g8QW0UcIkm3rN BgnncmQrccKDtH4fl30qdm76bnnVpXaZbeDWo1hhlUtBFIsU+Vw0pO3CgDoAygYHUevaqdOYaneT 6m4hhZYoGi2qzRjcmehGD054B39atSjH4epEudv3tBEt7a9tTfQM7ThPJXy1/d26oDhieACzK7c8 4GcUmjJNHCINTKm5GZFlcg/JE3Cqq5+8Q69P4uRjmhv3ddGv6/EEvfUls/zK0UkltZXE12p+3zQS JHtU4ZGmZkYc9TjuQAFz0wabNo15osk1+l55mmrCLlPOflxu8tSRxhgCTg++RzV80UuV9dmQk5JS T1QS3enXejLLMwNzkLahFyQckFsj1YgAeie4AwLpI3eKWe0eNZ0dzzuMX7thGgI4JLFSe/p2pxuv xM56tNeRGP7XghvJXINuz7GAUfNGnGSM/KMsn1yfSqsUt5dQ3VtOA95IwhAVslztQhuTjB5JI/LF a8sXrH+u5nefwsZa217MzyzyqLhDI0quDsBAbrgHjcGPrnHY1Tgv5nt40uNLjQmd5yyb902/GA3b YuwkDH8Ume2C6krdiWmkrre9yAz2M8RulQbYlaXNw3zFSUjGDjlgzDtyAfTixBBeyWamaFxKMMXC gNkncME8jgqn45HIFN6Jc39egR969tmaFnpl7aWi381zG1qSY1yGCggh2bCgkrljk+x9qigcSpOi qzztKZVmc5Kr5WcAf3dzt6HO3pzmbp3kirSVlJmnd6jFprT2sELS5TyyCfkXIBxkE5YcZB5GysDN xt1WBMmdsbnlTBRQpzt+bAJAUdSM+ucURWnM+oqjulGK2LUXmsTGSfs2EiXKjcFTr9AQvHQ84IzV PU1laSFobfy7COTfkZI6rndkdAc8Zz1FOO9yZaQ0WpHJul85JWcNIp8onH3UycjAB65x68DHAFQ2 M4kIFxuWyhAREIYmRsAYA6nJxluwOa0a0sjOTcXd9f8AhyOZ7C8EEPlYiLbgQuASvUk9PxHc0/8A s/S/9n/vuqvOKSTISpybZvXNxfeH2u7yW1U3E6/KrfMRluP15rf8NW8gsDcuctOzKWj+UjOPz9fw FccuVU+dPsvuOyjzc/K1sjqTpo0yCxlMztK2XYsP4QRxntkdulZWu26C4ju9PTaUIUKzHAJJ69uz VjGV5XezOma91+R5fd3JtbieYXDtJIWVlAOQwJHGMcfT3NclBaRXtuUnG6NpTLk/eBA6dffFd8Fy rmS7Hl1I87s9jqBo5lgjhskVLgYmB7MFBI+bHHA5H0rqtIt3uIbMy/uZ3fcWUHHIcDr6+v0rOcrx ff8AA6KMEnZLc9D0XSPssbLegP55YxFVA+Ucc9wePTtUi2k0l9DdNOGiVi0xfo42kjA4J4HUevNc TmnKTij0FH3UMgEjJdsJVRWuAE2YO1uM4x+Bz7VcvbSPULeDy7g/umJLM+0lwMkg9sDgg+1KTUba bDdnGyOat9Pjt5ZNT1SYSXM8ZjEatgo3csOmOMfQ5FXbq8lmsbC2u2SOCDMaCNR95jgk+mCRzWj1 auttiUnFNPczhokIvGtmuXkmuFId2P3dvO/8w35060sGmnu5JLlzp83EduCMMMnt1/8ArVXPdO69 A5Oq+YlwbzU7u5tJQchAYi2RtKZXqeMnHSojf3k1tcw72ba5LsFwTGcI3IxnkBfY0oxjpHtb+vwC 8m33ZsWtukFkUF663IiSRRnls9BuPTHBz25p89mot4zCVW7Z1F0yZJbA3AcZOAQqn6HtUt63kupa jtf+v6RNqFs8wSKw/d6fFOVRT993Zcnjg4yCcZ71ainvVL/6R5cMkAUp0IOCTwRk52kEe/frSsuW zWv6jcXdy6FCCSW+uNNj06yDqbuNZnZf3ZLZ5xzxncOc9s11NvGI9Rg0u3uHQi28xkBIDbXIZD2b cCuDxwOPeZ7cu4R7kut6jpnhiGTUrnToJbvUI5DGoYlrFhIoDjIPUZGOCRzmvPNf8RLqsdxfklZX jRzEY/lRRGFIAGDnluMfxLVUoXtNt22JrVIp8q0/4Jj3Vqb24nW8u99vGV2FA2d4O9wpxj5cgZzy TxnrU9y91cSo0EQW4nkcwhmwqPhwnJPG3Iz356c1u3FWutF/TOZXve92bPhPVtN10TNelfJhL7I5 w2C7N94kkfLgHiu0t4tP1HUdNOsXaQaRJHOZ/lLuhKEpgAHBPp1AxWFVOE5JLb87f8MdVJqcE/vP h79obU7Kw0OLSrUTC6vrpm2SNkRoD831G4EelfFQEjSARg7iduPpX1eWq2GTfVv/AC/Q+HziV8bJ rpZfr+o1wW3EEMR2HX/PFVzEHTcnXP5mvST6HlSTe+5fsdRnspYZIZcOD2/zzX0X4P8AjPPFZJp2 sTNgIIYpYwMxx5BxjjpjOTnjiuPGYVV4LTVHVgcY8NN32e/+Z9W+HfG0+qTzrY3xuSsxmS5jbc8S iPcM5685OK+o9J1O7e/t9G1KGOPT1lWC5kU/JIqBC6sw6EsC2FB5HfrXyWMpKHu7Na/8D/I+7wVf 2kVNO8b2PpXSLyw1/S9I1PS45Y5NOUx6g/DPvkEkgLY6sSuwYHcDoVroNdkudPtdHnSxeHw9KGiZ YG5guIVImiDABgWiSOUthgN554rwmpylyy37fivwPoLpx5or+ti14J0ldem1O+vNQi/4RzTri1Nv 5fyTJNdDbEyH7wCiTeDjKsowVbGeTuptP0u4uAJmNrd3MMEttMC5d4zHF5XUkKS7YA4wgGD0o05n BLVW+/cUtKcZf12MjVbO7vNHW9muLiKWDT5oLHypCHWDEMbfdAHJLvtGACW471A+l6DeYnvIpDPY zRQ2+AFEL+WWY7Vydw/dsoK9HU8ZzWic0vdX9f02Q0r8s9LjdZ8nVrh5dKsylpHHawiE4aVrg3EK YdlxuztaUkDDbjgZIqO50ib7Bo2k2sKi82LakyFmZj5DRRvIoxtAZycfN2PNCklZa36ia1dlp0+8 sXl5NqEGlaVeRKlksEogaRvlVnVnAbjhjuALEAAKfm5rkte1drVmnlLG9t5E1B1dWCOjMUWLGCMF fLIA6Djqc1VOKul/WpMm0rnnlyLfVbu10m5udkU6CCeeXP7iRGXeTt6jcpzgfxDGc15lLeXMdxeN ZQKwgY+TCR/yxdUkRSoI+bG3J9Uz7D0KMWvdl0OGrJL3lqxl3fXV4Tc26Reezu94FbmFfkRWPPUm VuccYHQ1OIo7TUfNghntoo7vdZzOCHA3KUL4PBICv17e/G3K7WS/rQxXvatFLXdRnsJJHs7vz7uK eMxwmPKS5BUNjPJ4Unj+HrzVq3hnuNKTTtTAN/5W8Tg5YnGWx6lNgAwegBPUClpFJ21uK8pTlG2h yhkvtL1H7IsYjtBCssofBDkxgbQvqQxGMkjd0BqzBd6lNd2mpy6RG8E80VpG0hJDMSp+duTvJKZ7 YPPGc6unH4lLdGSlNSty3sXb6JdRtbu/SUw/ZdQeG2+0L8pgO5AxI4wqBSQOnzHnoI7nSFu7+7sl maFILM3M8O4glw5DR/Ng9SgIA5ycZ4FSpcvnyluPPGzdr/1+hx+nQSLb7rmXFyqYt/lI3hCCV4zy d4bJzwMHsavXGpvJttbePzbsxKs0vBUHbuYKACS25sHPqARkVtyqT9DDmcYpN6mMkzlZoS3mZgKp vwFdSwPYAgZOB/exnkZNTyahJOI7mMC3u7e4Dx3KfuWRgUkEgCn5WGexJyBg4IxTSTvf5epmm1G/ Ww/SrjUHuDazzhd6B45WyVjVShChgBzgHOemGrLnskSRZxeiZJI1nyu5PMbLDGeSoxycsQDx9ZTS lJIfvSjr/X9XNCexbdKlxEFjiAdPKLAEFsgLjoyncMjuD3Fa2pSXF9dBpHDvE7rfF0KiOQkZU7F+ UBioUYIGUBFF02pPoUvd36lG4t3iVlmkLliVwpYLFH93HscBM7fUfSoLe60m5gg1By0TyRlUjfOc 8jPGRyGcnOANvH8OVZyjeC+QtFPll/wDPtJk0+5SCKRpbdP3rMRsPzbdx4Py4IKkMM/dwTxV+8vr dp7aZWErlml+UYDkjcMrwepJ2jnnH8JrSV73SM1PRxK8NxJGxuJI4mDQsDubOZdpxgDBLZwR7rkj g1VkWCT/AEV74pCAXHIJD4znJOTx1ORyTn2FHqkS7u3MyjbTSTXU9y7xNbvvCSs2WPIbaMH1C5I/ 2uflOU1W5MksY8kpBlQkeMZCjLMR1HHfPJLHvzoo+/cxc1KL/rQr2scbwXFzcApEGfzFUhcZ6KvH A+Zcc9h25qvu0T/pv/3/AF/xqvfk3ZojmjFe8zv0tn1vW7qW0mEmkiUi2Yr8zLuYgke/JxyM12Da W0el73kJEI2qEPXA5/mK86b5YqL/AKZ6lOOjk9blP7c81jOJLnKbizRk8qM8HJ6YPNcrdawgt5vP lCzK+7LEgOgJI4wQOB+QOaqEbtrzHUk0tex55dXMMN7dATSOHUvFkj5PXB+vrnofrVqHTbpvJkwF kA3j+Hdn1B+n+Fdm0VdHnpc7tHodIbGGOdpZIHiKsUUZJ689M9gP1rttK09YAJsMV252oCN3Tao9 iT+lc1SUnFXO2hF8zZ1Emo2KahbQXE7ACHARc5UsSD+R69uO1TtGqxwJbkJJuKlJBn5W4xycH6e/ 5clmrN/1udikm33H6xb2WlxyWM1vGqySh2MB5RwDwM8gEEn2rCv0v7ed2tkExcgCJfmYAjO7Pf1/ A+tVF81rvR7BJcqvHoOthH58EMaoZDIGmIALgMrAH04P6Y9Ky2tJLd2N5dxxWbZEzKudyjJ59GJH b1HrVJ23Jaehp71W4vG0reJQgWSVx85U8gjPf+f8orDLeU90ViiQNAm7gxMM846Hkg9c8kdjRZ8r 11K8uhoXFwdShht2hWG12ESkL87Hd94cZUkenXApLiEeHBJfQrEyrcLaDo/nyM4AX2B5OenHJ9Zt tC+jH0510Mm4eRtRwLTCzOypE5wYpDxwRxtxxj3BxV21E2ix6lNAQ+nFGlnkZstC4zlQfojfielV o0ot/wBf8EnXm5l0MuW41G8vLeK4nCqH82KELly7bI/mOMk4BPt+POk9tNEunJdoEjml/wBfuwUV MYzzkNk9emB71XLGNlHclczu+lzqdAMMSag1vFK1q8ls5aDP7ollVGHrt3s2enHJwaqXuotpl1dt rN2i3BknAaAkgsRujHPO0MgX8frWPLzSd1r/AFv+Bq7Qhd7Hm8+rX+u3kk15bmeUxvL5qjYoBKJj B6ABgOe5NNKCCKV205Fvwss7QEkbWUBhjs2cqAP/ANddaXLaEWcnNztzlHUrQX4FzeXM9wpvHj+z iRUxsaQ5Yryfu4+uM+mKmurI7bmKO5LXUaG5wjNhdrAMwwOSS0ePYe9P4eW+xF24t9vzLWmXWnfY dFjaxmnuEdd8e8RgOzMWQ5HI2qn6eua9atPDGvzWunpf3XkXTSfazbL/AKyPMY3SFjn5D8pA6fOP wwrS5Hefd2X6s2w95K0dO5+Xv7QPiSDVPiDfafZXhmi0+P7AHLEhnBJkbP1Jz7g188yTbVeVM8/I v9a+vwNPkw1OLXRfjqfCZlVVTF1ZJ/af+X6IppJIASM1oQ7JYyWOGGfmrta3OFSutQeIPuBHPPOf 51XQyxZ5OO+KW+4Sjb3kek+DPiLrXhG5kmspAyMCHjfkNwR+HWvu/wCFXxy0bXY9Rh1rzmmugqS5 mwqO2GaTkdflbnnlx2GK8TM8G5Rdenvp+Z7+S5g6dSOHqP3eh+mvwV1w6emo+IbaJ02XFrbz2rKZ PNP2fzEfyDkSEpaXJ5x877RngV9RadqWkWT+DWvb9Y7bUdZeOEPGWjMM88Co0ikYXERiVmAIyjDn ofg8TGXtpaH6VhZKVKz2Wv4nkaXyHxnZ2WmQxLoqSR6fJHCQC0MQlgVAmVAfzpGTOD/qwSOoGs9l oWoalqtvp1wqLYWemapDczYVLoJPi4jIwDJIJZoWwNxK27FSwyaXMo6v1/QtcrVr9XY86t7HU/Et +dBtUSCGWyXTrxA7YRWtURljXJO6WRZm+XkBWweKyPEsccun39/osBF/IfIumlBVQ480xy46rlI0 Xp1UE8VcdHFPbS/z/wCG/EwlG6cvuMyz8iOPRZtLtkWKOZWWWaYFXKBArYfBA3uzYbIxwAoytdvq VlcaRa6prWqSI8Edr5cUkIZvNe3Cs4yArLt4wcfx56HNOT963X/gijqn2PK9W1KW+06K2kvIY7Yl AQsexohJOVEj5wQONwOMkYwcHI8pXW47+2uZPEMs0kUeZg8f35VhbdEOcEAIVYE4HDDGRXVShdXj vfqc1Sb67HLadrvk3l9eXm6ab7RGkCEHbFiRXkJ28kbcg9M8dcEVk26apqj6rrEyvFcIr2ysy7Np wUj3AcZHky4+7wuO1d1uS8reRxuXPaK3NJtPSL7Tp0Vr/o05RElRstI8ZSPjd93fJIWIOMFU7AE6 unu8x8O2UssQS9kt5p5iSR5gMhOzC7Fw3k5yeN/puqXJP3nvv+H/AABpNb7HIWMltJqlnHBp7I32 cGBl3Fru5LBUU/3flJPbJGcc8Nu9XtpNTnluJ83MUUex7baGLFh5ke3jtu+cDBGRgZ2nTkbZjzWK k1reK8qzanvj2CXcHyDuRpAuc/eIZu+crgVZhWaxtLnQReJK1pcuQdygjaI4zudeCOH2g5PPH3qp uLjotAWktWNnML6rNpjXcqTp5kMjqgBLtMVh2AfM5KkHORng9eawdTvgt/c77dGkIOJXDAyFTgFQ cELjqu0lhtB64CincUmrC6tYw3LSPbxXKmBYBkById/mABnPRztPTn5Tx8uaoWYsrO90i8t3LXAP mOCPlwHbbKp4I42YycggddwrZN8vL1MXBc/OmQwTrE9pssDJITJBKrEur7FKq654UDcpJXPfpxU1 0EV57IhBG0Ee0sgVi5AB3AYHAAPB5bOSeMS730/qwly7tadzG+13Vslza2rt5RhaWR9538IFCDac H5Tg9M78DHQ6f2qzt7CMyxLE6KXIVCqsrbdsYXHykbQwPPIYcdqcXbR9bkxl36f8OVrZ717eMzwM umsERQ4TJkTzFByMMiAvn0JRCQcGmWHlWqzXTxt9mb90JJSuCd4Y89/ug7cHI3EdjSsl7o7XakLN FJLZRJLcFZmaW4nAAMaoQgVFAAOSZGBJODvByNhJV443eRim+x3osaE7WkXIG1Ty2Mq4OckHpjgG 47ENp6XMSS1tVuIZnUmxKhjtyd8YJAycHlj93gYK8k4yEtBKv2KRArPJlAFOApkYlnbqvTcOMYyD 2q73SRny23/rYjl/f3MFrZlEmUBEJCsVHlkkNyD1xnjuT14p8ou7iN44MGRTuIypXbtBblchzheO TjeeOx0itE77fqQ7ybsNbTo7a082abBCmJyFGVG4Anjn7xOccgYINOnt45fKmmm3iUbst0VMkZGe cHr0H3gME9BN7g1y9fM17DSZrqyuYR5rR3A37c5+fkZI7AeoyBls8AZrf8ILd/8APH/yOP8A4mkp 2voP2SqJXje3mdHpGj3llpTJpxIulZSo3cHjJPp2/XpzXS2c6jTmluLkC4Ljzdozjnk47+uPc1wV JKUm+t/wO2mnBJNnPXc1zZW0M1lyJC6NGxH3WypOPX+p/Lg9TukijSKNWLMhzG3YngYNa0km20Y1 5NLVmTp1hp8bKZJmMhQ+VlepJycemM/pXc6Vay3cU+9llZIgBwegYADjGMgH8q1qyd7/AHf16meH hra/qdDbaYNU8+62uCj7EA6kj2Oc8d/TFeiQsrpZyLZbVt9uyQfdyOD8p78jNcNR3tG56VKCV31Z mx6fZsbvVWuN1yI8Y4OEJJOMc5JAP5ViWtpdfa2lmKtNuHy5yw3bWAHcHjj37c0KSV7+g5RSsonT alcRnTBLOPNm3t5zhMhgGHC+44/zzXGtLdXGpW0VlZtDqjIIiQuUCx5PQE9ee/rRCLd23p28v0FO VuU00sLmGyXU/taG4jk85kGVLxhlyvHY8jHv36Vejv7yK2ureaKKNFZpApi5AYhRjPPHA/AfWj3W r9n95Sun6mFfwak86XkMIZbkK8QjXhdq7WIxjIOCcc+lVoLOaYi+nG4gggY+7nPLcD5uhx6c/S1J KOmr8yeVttM2b5/7TCXEch+2JG26TbwjKdi5PUkjJ7gAVV0bSpZr2W41EPstohIqTuAkpcEMAccF evA54/Cebki1fVf13+ZSXv2jsXdQtrUajewPMJwqGPJBGx2Ktxt4BCllOPToKp3Ut/pb3FtbCIW0 yiNN3zZQA8lD0JWRMHnnjr0ItSVpPpp+YnaK5l3JLG4S7vreW9WSO+3QyxKow86kHkqfQhTz0Cn1 rt5rOK5TN3GskV6jRxRlBmYfu0JPQqdz8HI5z6cqbaty/L8zSnZpp/cc6mtW/gnw3Conc6oyvaxx GMYVgCvy9sEyLjrgAV5xqev3OqwTRX0S+dJIggJc7jCY3T5h3wQefVgO1bUafNKVZnPXqKMfYrVL cmFxLolpa3ovTLqLSSR+RuGI4ZMqyYzyFk8wnPcH61jXt8+rS6qZWnjnRd+/BIJwSVHqMgkAD8q1 STk6i/rU53J8vsn/AMNozSiijlMbpZMtzFskEZO5ABG5bcM4H8B9unYVuRXWmJPcm7vVWW6kVwgK iPy1BkZMkk53RRqvGMZ5qJ3e2pceVbvQht0aTxBaavbeY9q28lW/ikJYlgBjhnVgPQcV6n8TPFdj 8FvhL4h12e1RddltzbxB2wbi4m3hmX/Z3tv68iLJ68YVIyq1KOHj9ppfjqaKao0K9dvSKb/A/EO5 uJbuW5u7hi9zMxO8kkkscsT+f6mvqv8AZX/Zml+PHiDU77WZZoPAulqi3E8a4NxM/KxL74yxx0Ar 6HP81jkeT4jMEtYK0V3k2oxX3v7j5jhbJHxFn2GyybajNtza6RinJ/fay82fq1Y/shfA+y0KTRI/ BsTwMDG08jbpTz13Hvk+3Svhj4yfsAa/oUd5q/wxvDe2Ckt9hlIEiZ5wp79OhNfkvDfiBi6GYyjn FTnpVXq/5H5eXkft3FXhrl+NyqH9iUlTr0l7qX212l59n330Pzw1zw9r/hbUZ9L17S57W8Q/NHOh QnHHB7/WsUlGUKRh/XtX7lSq069ONajJSjLVNdUfzrWo1sNWnhsRBxnB2ae6YkkZZvkGF6D8v8av 6Zq93psscsUjxyA5yp5PHera5o2ZkvckpLY/YT9jz9qDwtqU+heEvFaqvja4aXT4tRYksUb7MsBH GAY1W457h29hX7EW0V9448NXn+gIq6TeWUUbAIFNtdF4lBx85CnLZ54TGcgV+aZxhpYPGNS0juvS 9v1P1vIsXDH4KPLrK1n62PNtQ8PDwFqEvhrUtOnj13SpDbXdt57iKRIys6sJUIOXaQqec7h0zXOS aRexaZ4dvdTU31vpupxG/gjbatyJ1lEySBT8geOBCrYynzkk454lPmlzPr19UehNW0tojBivG02w sY7O6urZUvk1SaSVgMTRZjCyOCCGATOGx8p9CM4en+J9I1DQryDVpd199mby5mwiRyqVWGSRc52+ U+AT3OCRtcm1GT95LVPX7+hk5xVl0PFp/FzyWx06zgP225nErMCfKSR2lXcBkdYo1O5u6HB4FdHr fxO1URpqFvZWzRXcsMDRRJu8rYEtnJBYgb2DHnbnep4Oc9XsHKSTfV/p/kcntmlJI8r1B5bHRrm7 n08uzTuEx8i/u4wwUjoBHEznqcb1y2Tk5OqXi6tbpY3unJtuQGWJd48xVZtqr12lizDp97r8uMdd OO076IxnNJOLRQktcr4fu/NeC7JEpAPCIWaJmbH3lVmJwMn5ec5NXVtJdSe203T38u6uLiTz3Z2C tKJsRIRjH8IkyDyJl7jA1c1pJ7GTSWxjRzWVlrOmQw5jgumZEuyGDOuNvmE4IX51VTkY+Q525yLt lpcCCWSRxJqJefyXbO0bVG09flAj+8Rjg49TSba17r/MmKjey6FfTVVru5sra4MdnBLK73ALBt2w jDZOeQyJuAC4DDGGxVvURZTWVtci4tIbi5uI4dpwzStFHhneNCpHmHe2FxgyLgdAB3cla/8AWv4B GKSKgCzrAbNFt1uYprqF5CTmLKqzMWXjCrHHuH+ye5zxd3bS3Ws3SrayxmRYLqWGfavmJhH3AqMB SFOMjjcBgE4rWDs2/L+vuZjUbmkr27f8H1Lt3BNp7RvcW8ck00byRwgsRbKpBBJyT9DjOJOf9pt/ arqNppsiy/6aJCse5Fy24JgMRgdQw7Dpx3qr2tJO/wDkS7u8W/6/4Beutl5aSraWjW0DCCXErMzR RkymEsG+Y8S5UjG4FTgnkcNMtnJMBcRzFYrdIpInjcC2C/IGYEDGcbmxkHcuOc0qd9VHcKqTSb2N S0t7KezmuLMRQMkDTIslu+XAZAMjH3TgHqc7cfxZqzfNFc6fpsFzdGDUiHO948KyJFwzFRk8jaG5 5zlhtNGvNd6vX8hfZ7KxJoemyaStrdQFbidZY1BYBomlV92cAd0RB8wIwWGBnnGRZJ3mmkKi0kuM Hyzk43huCDsU5GPYD73NOM+ZyfmRKPLCK/EimlWXZYNIwCqFkdEJC55IfOfm3FQRtx85Hao4LLUZ LOKMSxS+cMKkWSdwKg9VznawbdyMIQDuBAvRLUj3nJpF22sbrVbbU7suyh5QpJdSMocAqiksMh8A 4xyTwQ2MTUbe5uW+zW0mLeMllLDJaMEckk8ZC/dz6dM5qoNXt2JlF8qvuyeyuIhAkUy74IwwLb8t Jhcnjj5cEjrwEA4zyxfN3FFkKeZGD8gbjcpIA9STnJwMcj61yvm1JbtFKJXXF7IYNJhPkRRvHJMq 5LttUlV6lcKRk+g4xgirbzwm5vYVjAcnbIpAG7aOCDkA4PoQeVH8RIdn31sTdWTt1LtrA+pIkU21 LNbdtqqWbO7GCccjGXYjnlADjcMPg0pIy6Xh8yCQ7yisWHl9UAzwd3IwOpb0Bwr8qaQ0ufW//DHV XGo29rG6xR7Co2FYwCZO20kdRuK4AxgE++cf+1Zf+gV/5DWpjCVruVjX2/JpFm35b2fkWcTKxYYD 7scDr1weBk/jzWRcrJawrE4xLt+eNSByfmLc8468GuWMlLXudDVo/I56VJnNvJHdESHkIx4Hp+Fc ZqkkuppbxqyCQAuW6ltvGBntnP44rqpJb9jgq81km9zcsra2vo5y0ZVy4UMcr2AOOfr69+ld5psF naLi2YhDsjkDnG8g9e3IyKzqtv3XsdGHS+PqdrawSWdvdRvIyll2hhyEfOT8xHOQTzilnlaCFVee SWCODa2FI3OwJJXH48//AK642m3ddTvXNbUpWlyu97coIoo4/LVXUDON3J9c5656ge9VriRriS21 Eqy3KEFiowZDjhumMcDH14q+Vtu5L1tYNVvbiC/W6hvVEksiSPbh+VORnI6AEZOfzHaqukXX9k6m uuJpqz6k7K/k5IUZAwgJ4HIb/vqrteFlpfQV9e9tS5czy3U17crDhrqRg6EjKOMHauOmF47c4qGG 8ubw6q8tgrX0SAPdBgQULICx3EdVOehHX1FZ8ml7/wDDDcpLdFLTHMzyASeaLe1OSoIWIrnbt9Bl v6jrVmC4sLrT4YpSYzu+YEshJOQS3HGQ3A5+4D2q2mm7Ia6Nkur27Wl/NZWlzIkZkB28bmYLuaQd uVByM/hUOrXUwSyhJY3HNsyOx2nKuzM/cdevsfUZlLmUW9+oSbjexUtkSFHulgctMytuJPlo8oYf KPb3PcgVo6ta6fcpaXsDwRwRfPIrnBAKrGzqucsRgccY2k03KSkmgSummdD4X0VdSvdaubRbc6XZ 2pjKqzCcxSERkqc4bauW49B3xU2oXFl4at7y4t8PqcYjhslllCqPNLux5+6UbZ6YJHrUNylPkv0W /T0+/wDA0SUKfPbU8a1i91PXW057qCJZVSKKNgx2LuCoHy3UsQrEjGMZ6Vh2GoWz3tjb6oHcozIL kD++oCrn+IByDg9zz0JruhFKFo7paHmVJ/vOafVr7/8AgEU9k51Ka6ilY3ILBY8Z8tl3LtHOCMNu zjp9c1cGsWsVslncygzFZGllOCrqD8rA5yWY8EehGKppy5bdP6/EiM+Ryc3o/wAzTfU4LR2muUjh iVkj4I6n5lBA6jCLn3PJ55s6mmnxaamq20ccslzLJBYkgloDGAZGwcHH71sHocDrWdpJxs9H/X5F pxd09/6X5m74a0u2vdbn/s++dLWKNYYxcDLMDuKuFUjj7zY+vpXyd+2P8Vp/G3jPTvBNjdq+k6Mv lssZyguWHzjPcIMJ6DDV0ZfSVbMYTa+BN/O1v1/A5M2rexyyUb61GkvRav8AI+S9O0651e/s9O0y EyXk8yWdtGnLSsxCgY9yfzIr+kT4H/CSw+DXwt8M+BraNTqcMX2jUpUIzNdyfNI2QTwDhAeeFFfI +KmYeywGDy6L1qTc36QVvzl+B9v4N5bz43H5tJaQjGmvWb5n9yivvPVnVT5aFgM4zwcD64/+t1qK VMpvQ574GRz6/p+lfiSex+/2PKPiT8Gfh18TtLew8X+H4JpCpCzqirNFnuG6/wCH41+U/wAaP2Df F3hU3Ws/D24bU9HUl/sxx58a/wBf881+mcEcZTyupHLsxk3h5P3W/sP/ACPyrxA4FhnlF5llsVHF wWqWiqJdH/e7P5HwPqOmapod3Np2r2UtvdxttaGZCrA+4NVwwYtwQTx83T3r96jONSKqU3dPVeZ/ Nk41KVSVKrFxlF2aejTXRlm1uL7S7mG7sZXS4Q+YkkZKsjAjBBHOeK/U39l/9uDWYb/SvDXxB1Y+ WkcFnBN5xhE6pKHDTPn5mBLEkjnJBzkbfGzvL443De0irzhqv1R73D+ZSy/FKnJ+5N2/4P8AmfsD 8Uvi14Mu/FUPivSfE9zqG+4sptOmc+dNOVWN5Hnlz80imGVGJZsOAGLHdt+dtX+Jl1pzWkVtc5zb Ro0iSqiyXUaxxJzwQo3SfMcNld3I5HwNGhOSUZRt/wAA/R8RXjKTdPX/AIJybeObpNDvrC8tJ7mb 7IS0wlhd1bz/ANxuB24LOJyZMZOecha8ql8RWjaxeXs/zFm8q3tN55/ePKsUvO07QH5LN/AOcYr0 qVHl5mn307HFOspNJ/8ADkV5Pe6u0l1o0Jj1iG3hKQxl0WaIRRyls4zliXzjH3GHOedSR/kF8kMV rZCBvPwCC/mAANGjfN8zxMAR23kMRWzUY2+7/Iw1lqkaWsWmiGO50S133lkTPM0ckoEag7XeMOdo A2L5e5Rk7FGegbFvLi31G7umiKYnuI2lkjIDhdzhQAPuhs5PAI83I5Yipi52XNsVLlV1bUzLOKyu WvLiLU3S38mXyG8seZEAxGArMAq5LEt22A88ETWJkK2N+YAShuLUK+/NsrPGBPIduACYCoTcCoHO MgHR33atYz2aTRPNpOp6hrc888QaC3t1t44TIpEBIDHEfbDJLLu55I6bsnNSC7sIbqNN3nrLIsIk XekSEIskkmcnjBBx82EPPAAE4u0U+n/DkNO+u5HqFoGt9JvtUul+zmOeQh1fbfDZtC8ZGQy44Ixu TpjIL/Qo1u7nTtPC3N6VinigLv5m1Yz5axozYYkssgYHPJAO2mm0tvL/AIIcvVsx737Gvna3cr5c HlNbPG8StHBHtKRgA4yWL7SPWJfSrEj2mpeIdU1C3kkNp9mYRSEFvKRs7VjUkEnnBXrhmzjpWiuo uXSzRGl+VrqUm0p715ViRYtKihO55ZTJu6gnBADqzDAyU+RecHNWpbkXd6ZYXjWEqk+yNEVJtsCs EGxU3oNuMnhmQueSQqbu99EHLZWfXqYE39pK+n38c0kssrCOF3BP7tI02tjAY7DHGFB4+78o6VZe 2t7Z457VNlwYt9vM7B1ZQiby3OXJctgnp93nAYVovh6kWvddmUmSLSHuJo53EjQeUXARmlZsAhiR ll4YEZyMjggnJHb2EUeqyzShr9x8/GY3QkgqAc4wef8AgA74FF5Nppf1/WgmlFtP1Gpd3EUWkvbW rK3lSG4fzWKEbxtDHg/NgEcYxtIPHFWey08SEajKFeFnlkkVsee0imQkYPU4AGMHcxzyCaa5oy82 JxUlZ7GVazpdSrdNKRaO4lkkZMKjHZj2yGbJPQBCCMUPKmmpE1misBgMCmBAWwFC8jnGxB67345z Wmr917GN7Lm6mnbzBIkktb7zEaYAF5GZoAU+7yucfM3HQnngYNY+9RKk0aFkZCAQhAjjJXDAk7iR jJ7ZPHQYILe2gpSeibv2KN1Oz28wsiPNMfmbThNivlSD/D0ywzwAUJ5pzQXEk0suOxCKdrFUztBU n72OR1JG1jxg410SXMYtN3tsX9LFxBLLbkSZeTdKGXO3b0ZmH+0RnudpJGTXQ2WkQiWPUdqJGgLh DFkANjAyBkhTu+U9guTnFTKXLeXcuK5oqLsPkEG4QWq4GVkMaZckYIxu6seQMdOc4+WvXfBX7Pnx P+JcsF1BpT2tjwj3l3ujRuRlgOrcAcAcenarhH7czKpOzUIdT7p+Hv7HHgfw2IbvxPjUdWB3YYlY VI/2TndjjJP5V7L/AMKC+Gf/AEKum/8Aftf/AImrvJ9SfZpfE9T8Q7ue2WJLu1nz5a+XuJOcHA3Y 9+ax9V1OOMwO/DNHgSA4wGAJznt/j7Yrhim2lLc651FZ320OXvNT+zubMhkBGGlTnkLkcjoOvT1r HtmhuLyGxdJDIQ7sVUAx5wQM9Ow/M+tdcI2XMvU5JT5pcrT7Hp2j6fb3cdsiyq7swXrhlbaSxHc9 D+H413FrYpp7xQMu2dELOiDqW9znI4riqtt8lj0qKSSZsT3VxYzx290wOm3EW+RVwSXVsAD+7x25 HNVI5pXvXgt7tv7PCGaIqoJ6nCnHHIyOa50lZdv1OhX6iTaZNLLHdxzL5caqoADKvb734kfkagk1 hkultriHbcqxGVJA2kKCp9R/8TV2U7KIleO6Jp1TxTPEIwkUy7V3MF2nb6k89hyfaqVtb3aajMl+ ZIduycSIAMgYIxgdfmGO1NPlXK+n4lJaprqNuwRYwQx4N1DLJOxBwzsxYkMe+CeO/WodOtpZFlgm Kr51ltlicKA4K8EA8gAhQfZjVXUYtk2u0ug6102KH7ZFBmG3uIUiwJAC4xjaD74yPcH0rSa3sTcz QTWzt8vlqdx3KqqMZ/vNzwfb8Kjmk3cpJJbFDUdUsvtun3k995kzwbbjIyGx5ZiOR0ydy+pH1qrp 8F5qpuWnnRAiKrNGpd13bupxxuUBcDgccjvSVlzOP9X/AMrCetTlXUm1GXbrGs6ZY30L6THKixSL IViby/NcjBAOf3ik8/LhvQ1U0HxR4PMcyvMiTokkl5HcbWWFBKcKjZ+ZmEobkjlTjpTXM4Pk30v9 xPtIQl78ursX9Q8f+FXmupdMltRbBYkjhWTLFdix4YDGV4JI6jYAc155q91eau135F0H012mdEZM m4lYMGBbgDAiwB/eq6NKUGpVVr/X+f4GNWtGppSf3HORXNv5+r+dAJI4meDbJKGaNGdS5AGTu2qw 56bqrXlrpkM93dafpywlLsK9vJIyrEokzgZPy5J45PCHtXbFNaJ6aHDNwcE7aot/vmtbaaLy2u7y SUCOEMXiiCpg5PHzZKgdcx9uKr2cUZtvsV2fLuYJ0GON8rclBjuRuAxk8jNK+l49P+G/4ISu5arT /PU6GZLbUJIbOx0l1WQxLKpffJJIVRVI4zguGI9iPTnQuVl+0WMNvAi2VvbRW0DAYacYEn5vzgn0 A9KzbkrRk/62NVbVwVr6f18zY8SeMLH4Y+B28cHTQ2pLbCG2Mygbp5k+RevzbS7EDrhXPYivyZup bm8ubu/ndnvrmU5LHJZ2OWJ/PH416eT03+9rye7SXy1f5/geLn81KVGivsq79X/wx+gX/BPT4NDx n8Srz4j6ralvD3hkKbfIyst/Ju8v67ArSfULX7cSBipL4DEbRnqD9etfh/iVjvrXE06Cd1RhGHzf vv8A9KS+R/QXhZl7wXCVKs1Z15zqP0T5F+Eb/MqvAowcnO7oR147/n+opMhMBF6A88HJ98/Wvgr3 P0nl2bIRCGJlfJ57dz61E1ossZVgcYLHuT3qlJrUiceqR8+fFv8AZ1+GfxTs3h8S6LEmpso8u8gX ZKrHoQR1P1/XpX5Q/GX9iL4g+AftWq+Es6x4eXLYiGZoV56r/Fj19xxX6zwNxpLBuGVZpP8AcvSE n9nyb7fkfjniHwHHNKc85yiNsTFe9FfbS7f3l+Ox8bJJPpF3LZavYyZjEiNDICjRuVKqemeGwcd8 YqFVjmcXFrJ5bq2R2I9MGv2+6a54u8Wfz0m0/ZVFaSb36eX+Z9QfC/8AaY1/wnHa6H4tMl5pUUm+ Kff+9i5zgn+NcknnPXnivu/wD8RYPF/hOx1LTtet7m8Nv9jeJ1yWZ0+cmMZwdvy542sE9GNfK5nl 6w8nWpx9xv7r7/10PtMnzR4mKw9eX7xL7/8AgnomqasdUXTrXyjIohWCK6Q+SIIpA0oxuI3/AL1W RhwN03TGMZd4ttp5fRYfMgkFkTua13zbVdY5GY52xuuATuBIE4wM4YeQk7KO57sveTb6EdhcahYX l9JCsBnt7OCO0wVk+2YMUkbkcAjG3I+YYRuTuxT55p76a5uFmgFrhY/mZyTCY8JjaMkfPIOCfunk 5Aq1ZSvrsTdpW/rqX72wifTb64n1+3N7K0VnFASkchd2ADgOMlV2HLfMOu72m1jTpDeQ2lpqkMsD y2qW6wOcXLlMKrEkbRnceePnPJ4pRqXashuO7T/rsMjjvrrQFZ41S7EMi2jyJj7RtMkxHHXPmIxT JJDKeR00muBd3LQWYKaa0Q8qNVOX2qS5yR84DBjnJbCnPbCa+5E262Oe1mJrS5g8tle8toQhuYox +9QM8HmtjGAxwQxHdzxnFbEVhpGqahZmS+htiyRzPGqBR9pd7pEUOhGwdlGQNsgz1UhSvZSSv/Wg 018MtDl2ttPgjisrS7eRJIlV5JFEawJmIuyuWILH5McA/MOoJqGOeWzs75/s8JVuLW4MbhlEaCNg TkqOCBgHKlQc4Fb/ABLVWv8A1/mYu0ZadB1jZWGoPqDaldl7acSNCgZ3jjkV2b5eO3IUklRkZIAY 1bkMVnLHDcMPvriERAmREwjqkg8tAQE5ICncUAUfNSk5N8qXp+oWiveImiktLu0sZZgsazRTNcxx ruFq7EHoRn5RnbgZPm5IYmo4rS3uYItYV5luUQwRSlGKW5CfIShDAfOpYYPWQ5yBuMtppf1uPS9u pU1CYyz3l01vIs1vgWtsrb0bggDYp2ptI2sAPmxkgbTnnVVvKS6ictK03k+UsZUqqhdu8vgKGDFQ e2CSBkE3Db+vIym3daGjLbxSRXMVjMpWQzMJQscbybWQ42ADa22Rfu8ghgOEJGRO0MdhNqL3Bkgn UMpLSboQEAjG7OW+7HwM4BU54Iq1+Ipr3bsivvssdnbFr2Q380ameNiF4+fbs2n5j+7DA9cOvGAC allbrcXNzab5GvMCKBWUSK77yoYZ27suMbuMbmyCBimno21YzdlZX/rcXUbC6V0m0q2826CLIVGG MoLRpGI1B5y4JxtYnYScgMxyIjdopuLq7dWc+axP3Ub7xLZOSflTqO4bIxWqSlFNLUyd7pE0sMU9 08kLFN8RRYk4LtlEcvnA3AADAA+62BnNMup/MuL6S3JWKNhsadACyKRgKOdpOTwOm3vnmt3Zky0v ZkclpHdXMcAg2PMCz8/eBIHBAJbIO3IzwO4roLLQ1EQM8e2ZVyvynEnOwkncd+WLfN6Kpxg8S5NW FCKbbNqGUWrRC1tgGOW37RtIbAwD3yGY9+RkZ7ereC/g1478ZSx3Fyv2TTpFAaadSoIXO3YhG49e xGcDPvcKfM9dWTXqxoxsuh+iXwI+Anwr0K3laXR0u/EqMJDc3vztLxgFE6JgYGBk9eeefrH+y4YV 8uKFUhGBgDoOg/Kt6kGrXOehUU4uXXqMaDphccjI6/mP8+1O8tP7y/8AfuX/AAqJJKxrKS0bP5op ryUfaUuI82pYFUXjaXxkEHsWB49iKwvNhV0jB3WqgxyKRkjPHf3z+lZQjYUn1a/4Yp2tmZbqWDzX EjyloVYDkfwjI6Hp+FdnY+Hlnu47q3YK6oA5Qk7s8c45ODkfnRUny6mtKnzWu9T06w0f+wGe4jj8 zbOG8tV3FQDt4PbP41o/aBc3R8llEKESKHG94lGev4lcZrz5vmbkelCPJHlRUsJ9Iv7uby9VhcNG 0iSSsAibBjO4dQScEeua29GTTvEuvPoHh/VrW41WOGS5lSKVAQsaGVx2HyhX79jjrUyVSCvKLslf 0RUJ0pPkU1d+Zy+f7R/c2F8kmnSMFldcAIQQWC568KRj3HrVq7MI+zPuBMhjQMyj92vI+bHfCH0+ 9mqWlklvuTdb7mxLGYdPmuI4oApKqm0ADaTs3FV6HjqP71MSK5mma9izGJYi0m/L/Z2jyAOcDBC5 HXIOBg1PTX+v62NbWtoVrK5t086zG64j2syCNRkvgMyucdflAx79fWsI7E22qTXUziaRViEhQgpG APlVQM9eQOvWqu9XFb/5haMlZkdzHDctaotuUt53KjlS24IGVcd+NpzyMg9eazbuC+trq/uJrxFj LnzfKclo28vKEHHswwOfkJ704vZP+n/SId+m2hHbWudb0fz5IzYuChjWNt/mM5O3JPzcIfwzz3Nj VNZ03RdPkuJ9Tkgt0ieV08vYHaNPkRs9clpMAjsccmqcZTcUle/5iuqcZTctj8vPiV8Xda8R6tKu mXkkGnIcqE+Q7yu1jkfTH/668qi8S6/EJVXVrgK4w2JT8+PXHXv+dfaYXCUqVGMHHW2p+c4vG1q+ InUU3a7sSWXiDWdPmjngvnEoIbO4+49fQ19o/CX4kx6vpdpHNZJJdW11bxCIcZ3yMSx9eg5/2cE1 hmOGUqPNDRo6spxUqWI5JO6f/Dnq2wPPeWFpaRS3DwSTErkGKZvMByT127gx9dg96bq9sXuLuG+D Swti5J/ilbOz8VO04PYZ9efCTfMkmfTyScW0tE7aE51WC2e3ij2ROg8y4WZiGCsu0r9Aoc/XnoKi gm87VvMgZWupFKMCufL3hCGz1JJQDOeqn+9SUWm79hSmpKMV3J55b3TIVvL27aSS4ILq6H9xAoRl UYyecZBzwM1vWVhdXVmlnHPI0rhYrdoukCAkxLn+I+WNo6dB3qZcsfetp/kaU1KUnFPX/PX8z5V/ aW8eSa1rFv4QtiFstFLQy7P+W13vO/kHDBOQCODk184WttNetaRW8Je4dxBAqg5ZyR0Hc5PH1Fe/ goKhg4OXq/nqfM46csRjZqGrk7L5Oy+/9T+kz4C/DGy+AvwI0DQL9BBeW8bX+tTHjN5KqmQMcclQ FjA7iP3rxzX/ANqy70XxRHpC/D68k0dn/wBccCSVc/eWPPpk4PNfzng8rrcX5tmWOjU5U5ykm+t2 3FfKNvkf1Tis2wnBmV5dgakHLlhCFo22SSct+/3n13oGpW2v6Jo2uacu6xvLeO5iOCpKOoI7ZB5H WtD7MRtYL1yPTnOf618hUTpVJ0p7ptP1V0fc01GpSjUWqaTXowEEjvGqoN2flxz7cVz/AMRvGHgz 4V6Laaj408Q21gkpG37Q4XcTjAAOMn9OarD0a+LxVLB4WDnUm7JLdnLialHB4arisRNRpwV227Jf M/Mr4j/tX3GveOreDwreqPDsUip569JOnI/CvtnwH4+0bxBo1qxvI3lKruyQecDr1+n0r73POHZZ bluE5Y+/b3vXsfC5BxLSzjMMZCMlyRlaPmu69Tyz4vfs0/Cb4twu+o6fFZ62y/ur60UI+SOMgfeH B49z1r8rfi7+yF8SvhYbm9sLVtV8NhiyXNqhLqvbco5z9PyFfV8EcYypcmTZtL3XpCb6f3X+jPhP ELgWOLVTPslh+8V3UgvtL+ZL+buuu++/ytcOsbeTcxEMDgg8FT0PX8a1ND8Qa14WvF1Lw/qMkFwu cNGxGc5GDg88E1+vuEakOWavFn4XCpOnNTg7TifcHwp/aY0jVzdaL41jjtby6CwC8KkRQo7Ricqo +4WRFGBgYjQfwivre2ubDWtXmXQnkvtMIknjujCJDNG20l8gHcXjRHwQfmDjrivkcbg5YSs/5Xs/ lsfd5ZmEMbRTfx9V+p1LRre32m2Fs/k6vLJDFaneskUMPl+aAwB+ZwVQEHp5u084WmTfaX+0re2+ 7MXkRSSkhgqMhkdjxudUMjgKVyecDivO6rues+t1dFSRNFt9TuJZdPRLPzYVtUM3mSSkpuJwpQ7U kmVsHHJGDlSTz91eTtDaW8KXMXk3JlW6W3Ym6k3xxsqBj9wbCwPUKGyMBiNIJ3u+xnJxWiPTPCb/ ANiWVrPIu9pZH/fwz4ZYWkZtwO04ZlRuoyAz9CSKxdU0p7XSrK2BjYrbL5abS8jths8KwCkiN8I3 YnI6GslJc/k/+CN/Arb/APDDbDUb+W1F7d3Ed3eTtFLM14GLCNXEnmYCkjGX4G7O0heWFQRavp1z q12ZNLlijjj89HA6JEqMAVlCgkE5BBBLepyapKV3KOnb8Bc23MQ21qupDTY4dPMfkxGSaaWF1QSG 4xwiksq+X5S52Yysfc4rPsdHWSxOo38sBkmuVVkVg8hhkMrCQYABwu8Bs7gzKVzyBrzWT01Rm1d3 ehb1LQZ7kxSsFnmktmtpJ5Y0X5mkVpCiAYAyigADouQpCqSt1cSNcWduqtKscKLHv2h2kwrZG4Hk Hq24g7OCR1hvmStuVy8t7dSS508Wl4lwxhjS4ZbZfKLtIUBOGPKhmBZ2yrLypHAZica+e1tlH2S4 kSNFSB2EY8xjkFiMhjkk9flOBt6mhPmaa1/4ArJJyvqU7qzjthLHIEGovbIJEkjMRhQAKUUrjewV VztYtu3seWOa/niWG4aSNm1R4N8jeQAUkYE/J68kJgAZJYE7euiu/ev/AMMZJ8smyG5e6gsbzSll j8hBkyOxfYD5gbcxG7LJtwvGdwyOFFUpbWwv9KuAA62DRmJjuDSsOXVlQgqPlBBwO7844p3cXzLu S1zOz3sRamge5tIVjhdpS32eOPgxRopihJLZZsKFIy3dicnIqCznGlxRfaDuggkyRyNoB3MrYJJ5 LD1BY4IPIu7lGy3/AKRLbTemxSt9ZRGZvJBMrI0okJ+RurEKcrkH5eRjaTwDkHPurGabZbywxpIA GkJCsiM54xgYAwxfA6euCKu3K/eehi/fT5VoSSWk8b20cDbNSdUZvLbduVgrKpYE7SM4PTDZB5rY g8MX2pefNDAxO4p5bcxxrtA3burOS7DGPlCjtTc4xXNIShKXupbmla6Xb6axUyb0Rgk7eXxI+Moj ElsHJJK9x1IwRXZ+D/hx4p8eans0HSnax+TzLkhkjjI45I4OeSAPQ9zV0lKpO/cipKFGnbc+3vAv wJ8KeDBHe30SX+tAEmadAyxdeI1OQuASM9cAV61JKIl2Kg3Z2jHfsPb8q9KjBx0PEqVnOpzN7lax 1y80nUbe/tpNssRBUA8MM8/nmvrbwz4hsPFWlRX1vnzwAJUIAwf89/8A61XUp9S8LVcaji3ua00R yVB6nrn8MnP0qD7NL/z0T/v5WLjFOzWvod979fyP5oNTnjFvNJLwssamNQACApJH14I/D1riSiwr eXEsO5i5MeDhQDg8n17fWuKC93fQubtPU6G2gGpSQz20RgkHlqzvyrO2ME4HYg8da9BtkGmxWwuH Kssm8mIcyIGB/LJHNYVm9IXv+R10El7/AEOzs9Zll/tW2EOSZVSOWRdrowBBVe7DGcj/AGfavN/i DezSSab4X8PwSpd3aszunLSFyAq4H+0cZ9x9KwoU714pvTr6JXNsVNww7cN9l89D0r9j/wAO/B3T /iZ4fs/i1oGs+INH+1iK+tLO9SwswinMqNdO6kAhSh2nqevevWP29fCP7HOv/Ey91H9lr4TeI/DH hk28U6m11uLWIlkKgsWKzyujZwCgYlDx7UYjF47+1KUacoKlZ80Wt+ybtZP5lU8FgHk70ftr/Evi vpa2uy1Wzv3R+avhxPE3gnxdpM+nap9t0q4lQR7i+2UOdpBXqrBuvHBr7UFsNP02PUFiYX0gEZ+Q sJJGwRg/w4ywJPHbrXTj3CThUgrcys0cuWxnCnUo1JXUXo+6exlXkAsC4vb/AHM4RI4Y0JO5nwMg dcrwc+gNa9jNcXH2drMqYnIzkd+ABwRjJbbjv9TXE/h5rWR6MW4u3U07d/LW7lgRcSjzYCedmXKq enI+YNj075rIt7WH+2LKOfdM8QdGYlQp2MGXHvwQBwMN+NSrq762/QvR2uVLmLTbS9LSTok2F2sV 3CSQqyuDn7qqVVRx1friluLhHW3srm1MdgImlhZIyfMkDcHAxklS/PTB9MVaUpJO5Puq9te5uX9r FMIdQOm7NQcQmNlffGkiARZ4GMlgTgHruBzuzXw7+0r8RNP060/4RjQdR82WUI7nbhkDKpKE4zuB JJB9unNdmW0pVsVTjulv8jzc6rww+BqO+stF8z8/nG4EEk5AOaB8pYBvX+Vfbo/Oh+7BHp6V03hX xDceGdZtL+3Y/Kw3AnAIz3x781nUgpwlB9S6c3TnGpHdO599aB4hbU3sLqwucxXQSScBdxO+M72G eDk7uPRsY9dpr3zYPtVxZFYtrR3Adt2FJYo2QDgjhTz1BPrXysocknFbr/hj7elV9pTTWqZXu4bt 4byW73S396y2wmO0spMbgx+pyzZJ9BjvmujSGazvPKKol5HchricYEgXGxnIXtvkOGPoAD0pNrRf 10KjFq76/wBM07e1Gq6Paao0DySQynzbbA+dFJVgTgZwrcjP93pnNQ3niO5+H3gXxX4vvrhUllsm XTbR2GfOLwxxiPBwSV2SH0WJ/WsnBVGqPd2+97/caufsIyrLZR5vuT0+8/MfVrqfUL24mmlMlw8r vIx6vI5LOT78190fsB/CBPiF8ZrXxPf23m+FvCyJqLiRMpPeE4t0xjB/eKXweqxEV1cVY1Zbw3j8 TF2aptLycvdj+LObg3APNOLcuw0tV7SMpelP35f+k/if02fB7wz8Lvibf/Dz4d/E29Sx8PP4lE+q 37ErugZrUJvx/ChjkbHT94a5n/gql4R/Yl+GXx28c/Af4DeE5rvxTpniTQpNI8Zx3RnsrayuNMle 6syYiqTE3RhcTCN8Kso3oFIk/G+B6ioZPWlTqctVVpNrvT5bv9F8z9046pyrZvQw8qPNTdG6lbaf PFRj21Tk+7svM8C8A6Je6Z4P8PaZqUYXUYbOISoAPkfALKMdgSRx2FdHNAkLFWj+cnj8f8+npX51 i68a+Nr1YPSUpNejdz9TwlCWGwGHoTd3GEU/VRSZN4g1nwv8N/Bmr+P/ABZqcVvp1kob9+4GCSf1 44xX82n7W/7R19+0B8RbnXELx+HLbMGn2xbhIwfvkdmbgn8u1fpXhLk88ZmuIzyrH3KKcI+cpJXa 9F+Z+SeNGdU8HkVDI6Uv3leSlJdoQf6yt9zPmDT9c1HTHVre5YKGzgk19E/D/wCPuu6J5Nql60Zz gZY4Oa/bc2ymjmFFxlE/n/h7iDE5Lio1KctD72+APjDxt8SfF9pPd3Ei6VAvzDsTj3/z+dfordWa iExXEaupXYQyjkY5z+fSv5+4rpUMHmccJh9OSKv6n9P8K4nE5hlKxuJ3m20vLofGfxn/AGQ/hp8U Rc6jYQJpXiZhlbm2QKkjYwNyjg5Iz364r8r/AIq/sy/E34Q3kr6zpr3OgZ+TUbNfMQJnO5lHIwvJ HIHrX6JwRxiq0YZPmkvf2hN9f7rffsflviFwI4Opn+TU9N6kEtu84pdP5l8+58+um4K7/I5GAePn PuO3BFevfD745ePPhtELLTNSZtM3PiJv4S6qpIbqflQKFbK9ePmOf07EYeniqTpVFdH47hMXUwlZ V6b9UfoP8PPjp4a+JF0D/aZg1B2kA+0sPNtAwjEY4VVbBLFiAoxEx/jAHr89+dQlsbO+vnudLt13 XEvAeKfYXIckAKqghGkzg7CfRa+Mr0JYas6U17y6+XQ/QsJi6eLoRrwej3X53Owv9FZZk1LS5OYn Hm7mLiOZ1lOBk8lD16AErk5AJ5a4ktrf7JZ391H/AGPCw82RvMeS7lBjiVCq/UHcxzh5Mkl1Bxg7 pd0dcko37f1/kXIms76TSoLi6EmlLbNL5Kq4YLNvZCjNkthYwjl1zmXYOm6lntRpupLMiK6GJb/c 7F5vM2ZKqAeQWc5Uj5jhgCDkjTvy/wBdyNHqaNrJp1vDBew3F6dTltsRzxkF4sqVjCEuDnarqfRM lSSAKwzCiXF3NN9oa4cvEhjPmS+YwD46YUIQ2FAA4VRnFVBuzbtcidtEjs7z7TJLJc2NvH9tijkM 0SKjDPz45I+dAg5J5+TAIDADlkQ6pJb2sKql6bbD25UloojIFVkGScZKYI/28nAG2VqtWU1bdfMk /tC8uGukwWtLZEkgYx+WGKQIFYjgHccgkY6HhsGlWLydRlfVEkE8lwfJCDcUVfLVznqp2SNn5SVy fTJVuWOmr/q4rt6vREOo20VpYiZrUfamll2t5mNjocKpVMh1KFgoxneQ2SFwV/s29ktjeS2s0tuI iEQsQkW1gVPVVYiQrIw6gHd0Jqr6a6Ca1sjAlea4luA3mxRK6GG3Rdz+a0SIE3ZJUnaAx7KnqQRU +2G9ie7up0aRyCJWAVWMbBhJ8v8Aqoxgn1OAxbCkGklZJbbfqZ7vUrywR3zXF1fRbEll8985KySq qny92ck/Nyp6ZYHOc1lXtrJHDayshSNdsqQhVPnBWXOSRuYswABJA4bBOedE9DN9/wCtygsN7Y37 SiMo83CuDtaQEbsjcMBTgHp0bHsUiUw39w+oQSTl5M3CFWTA3MCW3cKxIZjxnhjjkA6enW34Eapp y6PYdGxZpdpja5nVxtRuZCWDqwBQbvvR4BC9jx0Mp0m6uzMTYkabbRjfKYzmR1UFsHjKhjuAPOAB yaL8vvMnfSKv/Wp3sei6fYNBdtbCUpkiEKTGmOQBnlscEtkdOnSprO11zXLi00jTdPaS4d9rWsMO S6789B1/hDEjHUdaiKdWSfRFVHGjF628z6T+Hn7NDyPDrXjyZ8vJ5jWKPkj5t2JGAA9sD889fqzT 7HSvD2nwaZpFnFDZRfKkcShQvftnuRzXt0cPy7vU+bxWI9rJ2egyefcrdMgdAc/yx/kGsa4eQkkr kjoM9TXbCDtc4ee+pmzhHJOPmyMc11nw/wDFw8JarBNcs32CUBJkUYyTwDz0pzh7uxcZSjNNdD7A hurS9tILy3YSQSKCDuycH/D+lHlw/wBxv/H/APCuaS7L7z1VNySlE/m0tbZNajkuJiFs4iVVZFJZ 8Z/oR+Zps3hyW6mgi8v7KjFElIO7bGCBuA6EEZPHp+XgRqezlyyei/E9aVJVUm18y1ZaMtrch7VG a0eRWSZQdsuOemMAc4z7+1dLfvFJLc3CW+bOMGNT02gHpjrgHnI65FRJuc1Js1ivZw5baDNOmaW9 S6Q+XubII5yRuCnHtk8+9Sz6Ro+oXcV5dyg3cMJVJx3kyM7T0OcDtxmpi3TndGkowqU+WWz/ADPU vHmkeA4/CNndeB9bnt/EEMLGOCOFGiZtuDG3XJzznsRn1rz74T6vd6V4htbjx9pUd7aT25SSG3Z4 XtXWR9vPIlYqy/NxjAHbNc8OerSqOek03bt6s6240q0Yw1g7X8vQ0PHOl+Hr3xxceIdE8PxW9teS EWtkXGYZVEYdzgDBO09OrF6dPeSrPDfeS0hf94U3HGwNvyVPsuKpOUqdNTldpW/4Jmoxg5uC0bv/ AF8inDJJdXVraXY8i1kk8wB1wfOO/ZuI9CrDHt27PNi9rcm1tERJTucBThEZm2BcA/3zvIHdfSjm UW4rYEr6vfYsS3qy3CaTaWrm+Plyu6sVYs3G0dcAfLj0J56VhDUImP2h45ik25pQCT5akDoyjDMQ RyCD8tNJv4dwcle5uWdnLqCQXkkkTvHazYtpI8G2cr8rMOOrKcZySYwOlUDdz2sEYeEiOaEpEpQb kDB1VgAeFIJyuSV9h1Vrtw2/zu/zCz376lXxVrGq6X4PaeXBZInnhUw7yI0j3MdwwCoDLJg5Py57 Yr8Y/GWu3XiHxBqWoXkjNMZDjcfTj+n6V7+QQi5Vai6WR8txRVk/Y0n5v9DlyByCOeelPSKSQ7UU kYx0r6a9tz5OMJTdoq7Ce1uYAS6EdzkdqpsZOnBNNNPVClFwbjLRo+qfgF4sDre6BOiNcxxPcoZH YNJGi5IU9AVxnkfdDd+a+lrWRltZIX1DbazO5wFDAMUdsZxuJBbbj7v8TY2ivnMdT5MRNW31R9Xl lXnwkFta6/r8B9mk6vK87yyXKqs1tFIuWZmkDkKBwTtGMkcZx6VrQXN6WludQmAuHjPy3DKxB85h gYyHO5AScHoeMVxSSeqXoehFuLSvvud74es4LS4vTdXZMiXCNMYnBZkAQPhe+5j78EA5r5B/ak+I a614ntPBtncxvp2kFyfKUgPcy7cg55JRAiexDAeprAQdbHRlbSKb/C36kZlVVHAuN9ZSS/G/6Hyx bAhzMOZQNqf7Tk9f1J/Kv6P/ANj34LS/Bv4EeFba9tjH4o1xBrGpZUbkMgBhiJH9yLaSp6M718l4 sY9YfJMPgU9a1RX/AMME5P8A8m5T7nwZy76xnuKzCWqo0rf9vVJWX4Rl959LuJkYoG56kr9cf5/C sFfDmiSasdauLJZdTUDbNIN7KQAM+mcYGevvX4TRxmIoUp0qFRxjPdL+ux/R9TL8LiatOvWpqUob P+vvPZfh7ox8S+I9J0GP/j9vLhLWJC2MvIQo+nJArf8AEvg1dK1DUh8rrbbmkKjOCuc14FatOlie Xo1ud7SlDlW61P52v20fjzq/xY8Sa74E0zU3j8C6VdNBGEJ2312hw7nHVE+ZQO5JPOBX5kX1rcWc 7wzL8wxyD1Ff2DwVl9PKcjw+BirS5VKXnKSTl923yP4v8Q8yqZvxDiMdzXgm4R8owbS+UtZfMjjR 2AAQnt9a6Xwxodxr2uWGlQo255Bux1C55/z64r6mtUVKlOpLaKbPiMLh6mKxFLDwWs2kvmz+hr9l n4TjRPDltO9tsnm2sTjGB17+n9a9C+Kfxd+G3w71OHSPEfia1tb10/cwySKrvjuBnOO31r+Vsb9b z3iOvSwkHOTbdl2R/Z+FWEyHh+g8ZNU6cIxV27K+i/M+FV/aXn1/4hwRWsnlaCJCqHgM4yOfp35r 7S03XtI8SaaTL5csci4kR8FWHXkEYxXt57ks8rjhvZ7qKu/M8PIM8pZzDEtapTaX+Hp958l/F/8A Yx+HvxMa51bwpOuk+IQgAaD5oJWChQGXoOB1Hp1Ffl58TvgT8RPhPera69oEjaaoP+mRLvhkGTzk fdzwOfwr9G4L4v8Ar0Y5TmcrVoq0ZP7S7P8AvL8T8k8QOB/qE557lEL0Za1IL7DvrJL+Xuum+x5R EJ7KaG60+4aC8UkjY5BBHoR0OMce9fWHwk/an1jwmbfRfFsbNAiSwi/Qb3/esN5mQ58wBS4+XB9s 8193j8GsbScV8a2f6H5rlmYSwNZS+xLfyPvjwP8AEzwx4m8+bwfqENxbiE3Dzi4ljbaqumzDHcGw CB8oHzAkEgGu20XUBNo8ul28iLpuPM87ykDKIzJuPmMMhdu0HYQrea4ycqF+OqwlRbjPRq1/VH6D Sq060Izg04vr5GfpenTxXFzqn2hbu5aNYluC/l+Ug3blEf3cneh2kAAA4wh4dqV+8VzYA2fl20cY lkuHQAxbFJw+W3HqFBO0ZUEdCQ/ikr6f1oD92LsP0s3d7HaT3ly6XAgLuxJkKsRJNhSrMWKklAAM fKPw1k0u9+0Lbabb7baa4cRLEN21MttWNiSSFLBFO4/cA6LkuXLFvT5CWuiKdndXSJILO3VYJIVh t4wwzFG4VTsBPLeYGHJ5I24PUzG3EhtpINwugnkExovyMrbCBjb8rK5YZJwVfO0kEzpGz/rzHpLQ LBUmsrSOKWUWTWxEzRYQAYWH+AFsEuMjrwOO1Lf3ILR2/k4WKB43jDcXBJUmRicnJMaKvIAUqeqi pS95obenuoyNRglvnSW4uMXRKOPLJUxlT1yORnj7pIAI6Z4iS8TT7ciCd108EieNGJWRWZQfm4DE klQWJI42kHJNtRkkktiU5RbbMjUtVuLP+0NNilKysyCRtj5vJMKCqlQdo2naevBOSeBUFzZm5t7q 7sLaJZm2qLInPmFggIAUlWPHAGBhiMqMVSvGz6XMm9ZI5mFrN5LqZk/eAI7CBlRMurBVjzyTyB1O Bz2aluLp4boy3sZe4QOhiBx5jeUCAGwQVACkgHnLBduM1ra7/Ixd1ZdSquptfxanNcZju5LPMbFi GaUSICMtzjap4+X7q8jusEd5e3F+mkRvcWcjJIHWIkiNckAFgCAWXJPBOAeMnNpJXT2X/AFzc2y1 Z0el+HrezlhtdRvEedsSFYW3hjgH72PmGBjgY9Otb51SSR1t4LcGyZ/lUDcPu5Byc85BP1I96hr2 s720/r/IuNqcVHqeu+CPgj4z8cXEOoaiGsNCZNnmzx4Z0OG+ROpHbJ4Oc+x+yvBXw08H+ALVYtF0 9BelAkty4Bll9RnHA4JwOK9vBYay5mrf13PnswxiqNwg9DqbmbglcBc9OwHXnPSsuUquQmMnBH6Z 69a9RRS0sePKomU2MjqxAJyRwq9BwfSqE4wchm4PJwOf/r00rXEnqZtwEUsQATt4Hfvj+X6Vizk5 zsyM7hkdADxjj1zSfdlX3sz2P4VfEJdOuF0DVZibN2/dO7H5W9Oe1fQ//CU6J/z9R/8Afxv8a5m+ V2OyjVXJyuN7H89tlaXV9HcyTFIUAWRbqRvowyOmckA9O4qq97q+oSoLgKjRAoSgXLbQWyQ38PzH 8MdxXy1oSk2+n9WPq1zJJLqdIsUtzZWl096LfUpYleRCSwKD720Ad/wqVr22S2tnghB0xWCyTKrB iRlV3Z59P++h71lbZL/h/wCmb6bSen9XKUmlR3d6kTXLReQSZrdyWAG0c4HVsvkKPTFaMukXNlZ2 cVq4m08llyGz8qA9R1BAJJ6fdFae1jLlja39MydKUW3B3XbsUZtStLFhbMsh2MAd0eWViwIx7ck5 PGPwFXSqWVxFcWU4FyFAYbt6gOSfvLxkZAyeBmplBxSb6lqpGb03Lojtri3TS1keW5bzTORtBC7c 5DehYc98NVmS7s7qOSQzN9sdSAHOTGy7Rtx/F8px7ZPpUWeyRtFrlHSXbnWZZDCBcGdJJJMiTdgY 3IT0yXP8uvSZf7OuU89lhDsxR3IYlCshwSf4ePlGPl6juaSUkk0/66DTUrmDpmjh9ZF5bxTwJGzQ zOMOzb0UBiucBRx9Dk/TVtLVbO00yeBkkGHmYKMjygpAIVuckMTnHGVPHFOU/svsiUra3KENpp19 NJeG523DRRzBSGdpZlZhtPPAXPUnsCOtdJbW8i2w1GGGOeUeYyo7ACRGby5G2r8zMGZcL935uABg mZt8rTLgrLueX+OTLN4P1u0a+3zC2lme35A+Rf3gYLnGdw4zggd6/HFdOnvdYk0+Jf37zbQW/h5P J/z2r6TI2owrO3Y+R4hpyrYrDUoby0Xq2ketRfDu0tY0JPnS7cgt71gXdr9mZoRCqY+UjAFdsMRK tNp6eXke9i+HqeS4eEoe9zaOXn/WxmvafaU8o4IJ2gnkKf8AA1wt3bm2nlhwcDoe/wBK7qEtXE+M zalapCv/ADLX1X/A/I1PDOsX3h3WtN1vT323NtKHB6gjoQfUEZB9jX6LWE0mt6bYR2qxxWEkP+jk ZY3PyMxbDZ5xg/L1B2+ufOzWK5oVPl9x0ZLOTjVpLyf9fcjdtmlvtWt5tQgh+yW2yBygOcIkcDFD 3LhWYnnO44GM1eSCS+kL2lruJuJFfY2d5Y7cADlzklu3JPHr48rp6PSx76XNZta3/wAjqvGvizRv ht4Y1vXr6BmvLmGeWOFlUxrNn/RypHrI+/Iz9306flFql5cavq19qd7O819NIZZpG5LysdzH9a9H KKbtVrProvl/SPJzqcXUp0Iv4dfm/wDJI+nf2Ovg/wD8Ln+PHhjQLy1MvhTSj/aurnZuVooSp8tu CMSSGOL/AIHmv6VbuWe4J3sMDkdMA9cV+KeLWOVbO8LgU9KNPmf+Kb/yivvP6E8F8t9hw/iswmta 9Wy8401yr/yZyM0wqoJyRzk4H3vQf59aRYR8zqp4OOOxPP8AnPvX5ZzM/Z4rojUsre4e7jFtI4u8 go6/eB5P1HOK5H9rj4vy/AH4KsI77PxH8SrJa2JkYM1um3M1zhuT5atkZGC5jUn5hVYDBrNM7y/L LX9pUXN/gj70vwizzM5xX9nZTjMw2cIO3+J6L8Wj89P2hv2Q/DHwn+DXwtu9P0q81HxBq3w10n4m a7qkNpPMdMtdVsbS9g3+WrCGONr+ytTJIVV5pkywMoFflf4N0ex1bXYory1SVl28OnBUk8f+Oniv 6T4ZzDG4vKMTjcRL3nOqo26RjOUEl8kvxP5uzTLsrrcU5XgMPSvTlCk5X+05Q523566n2L4C+F3h G/13R4Ljw5FLYJJ590qgKzW8QMsuOuD5aP7+1WvD/wAOvAWjfGDwfb3kcdmNS85YmbiOQwspIzwA cNn8PavOr5jmE6WJjCbk/ZydvRN/fofuGP4Q4dweR0MbHBwhKFajaSVmnKajr5a2/E/TP4h/Gr4e /BH4ZjVoNWhur9MwW9rZsryXDgY2qB6nv0ABPrX84/xZ+JeufE7xnrvi3xBldUupi2znFug+6gB6 ADC+vygnkk153hVktWE8ZneLhyzm+SKe9r3b++y+8/KPGvOFGhgsjoP3f4kmtrpWivzdvRnL6L4u 1PRpUZJi8YOSD1/OvrPwD8dvEs1lJaaRcutxxF1+6WHBH5E5r9Dz3J8PjKXtZrRbn5XwtxFjctr/ AFei/i29T9X/AIMaTrCeBrC91mR2vJVEzseoJ5/DvXWeJ/7Cl0yaHxBFBJpsi4aK4UMrkgjIz7Hr wa/nrEVHLNKssLo1N8tt1rof07ShbL6SxWt4rmvs9Ndz4Q+Kv7Evg/xrBLrnwxvF0vUH3Oto5Btp CT0GfuenXAAyc1+aPxE+FPxE+FV8+n+NvDs0MRbCXBUmKUdRtftkcgHBxzjFftvB/FcM1gstx8rY mHX+dLr690fz7xzwVLKKks2yyF8LN3cV9hv/ANtfTscvoF/r2ls974av54WzudY2OHxkDcvQ8Z6g 8E19deCf2r797HT/AA94809mECyJDeRFyR5mNxdc5bJWPjPPPIHFfVZhgI4uPPCyqL8fJ/ofHZZm c8BLlnrSl+Hmv1PcrH9pnwAqWmi6VJMJ0IdriUERGQBMfKww33W+bjkDtzXoum+LNM1SO3u3uDPb KDdOIbhcy5ZdgYN8u0s4UkjjDcHdivDnga2HSdRK7+Z9LRzTDYptUXt8rnT6Fq1xbG2W7WVrlB5m 6NwN8hd0BTAGAAVXBx90MDk8ehLb2HEdhNGY0lmlLmQ7UJyAiO2TyEwByMMue5rhqrlei0PQoy5o q+6/pkSzR3litzLbbgZ8CMjIZQpA6rt+XzGcnPbg5UUtxaLcCxELeUSqxxiJ8tGhMgZFx0+6zYyw G45IrN6O/qavXUmE9lFaQWccrtZwjCuMNtZju3NknoI4gSCQpXAyQCcu2tFe5u7+2hZ7c5hjYq48 tpCE3EcHILYDEZyQOM8JJq7aKsrpbiyWHkauGF6Qke0LGFYl3baCGPQYIZVABHXIwayW+aDSka48 y9j2lEMZdmYbiDgn5OQvUcAgEc0072aWhEla9zn7+4EdxJcSLNNqKWnmwFGBRNsjZJODhgMHgjO7 ttps2NsIsI1+zm2zunUgldpK4xyGOXIYnOBgcZItLTb/AD/pmO0u/wDTMEwJDJ9pEqMiOXhjViSp TyxgAk5yWYc9lfLHs66iI/05XMspjd5xBI6ieQBRtAADFgDt+XnIOM9W11lO69P6+ZFrI6Gy8NTT W959vVVUAqkUgyGJxkDORzgAnnpn0rqLW4l02Ga0gjGXYiWQLt80DBAJ+oyBnqc9hiWlUfLfQaXs /fe56F4A+D3ijx6VvrNRFp4bLXUrEYbd820jlsZzjsetfZ3gb4GeDfBEcVzJbC+1RFH76dAQrf7K dF9uvWvcwWB/5eVVp0XzPn8wx6cnTpP1f6I9Yl2hNiqBgcDp/wDW71iSkh343DPAI6f5/wAK9lRt 7qPCnPzKE2d4lXhwSB/9Y9qqOVCgYOOnbkfjxV20supnzbXKbKOWcnaeuev6/wCfyqm81sI5mkj3 SDGwemSeTnnrUN2aXQad7MwJnfIDHPJCgZwf84rOmt3mRpB9zIBb9Mik10NX3W5nyeVBtbdg9VP5 Y98ZqP8AtCT/AJ7D9f8A4qolGL3RMmna7PzeGtImnymZVtrtg2Y5FG0Fs89CCOuPTGamsoDc3K3B f9zLgOplCK6/McknAA2nI9uvpXxjXKnJo+7i+ZeiL8YezuLe8W38wRr5YjEZDGMrvTGDnGOoHpno eciHULyd7cWto0ekmV2ZXi+VR2BIJ5HynJHbNEUnd3/4fUtt3UVv+hfnsYlmEs181xCUwVgUF2G4 hXDZwOCVbOcHtXpFvcWdtaeRDfhZdzi5lhjBiZ1UDyywOMEuMAf3fQVlVUpRVlZG9NKLkm9Tn70R JBqxsbZZI2kMKIGQuyLtClsgLggMcZJAUevHLx6fcwWlxHNdE3ig+VsOWeT5/lbp0284GACOckVp TnZWlrt+WuhnUp8zvto9SJZW0jUZI3cEymMGORwpYYBYkDk4AIOOmTWlY3cYWS2+2RC6wJDvG0Iz Y4GfT8SAK0lFTXMuv6GUZuDUJGykVlezt5GqBJkRlDIxB8xsg8njbyDk85LegpEVY4JLe7hzYhlS MLhdzlXIZhnGA+Cc/e6DFYu7umrM3VpO8WTCeRE1aWPeZI22lQ2MKwfLgAc/6s8ZBOO27Na1jZyW Wn4knjAiiUSXEiqv2hVR0IjjPJ4Usw4zuHpUS2V1b+v+CWtdWagDWFkBHHCIZEnVnZj/AKPtJcRr nksAu1vTGQQRxi3utC10xbJ5YI3EJtoYrc4QuSC4VgN2CkxdvUYx2xnZSlp3+Rpeyd9rHl3iDWn1 ppr42Jhhmj2TgwYRWZk81hH1ICgYUnO1gD1zXwLqvg7TtB8Q6pfRSIZJJgERTlYjxvAPf5sj6Cvc y+pKhzU1rzf1+Rz4XLI5nj44qbtCgnN/lFf+BW+5m1YyG63wPznhc9R/n09q4Xxjbt5guNw80fLL t7n1P869FLlqwl3PXxsnicvxFKT1j7y+W/4HHRDaJgRwRkEDofxrl9VtjmO6IOGZl3E5yRg5z+Pt XoUn77PzfOIr6tSfZszYbbDKQQSe36f5+lfd3hCK4i8JeDoEmd41tY3YsudhkXZgZPK8Lx7kduOf MbOEPX9Dkyjm9rUcey/M7WW7CSsqN+4l2SFQQvybWQgr6Y3Nke3Tv6dZaNqaWeo3TaZFts2e5jli VcwKGjV3I5BBMqFcZ9T048Kq+WK97Vn1FC8puK6HyD+1X4yuW1rSfCv25XitrcXMkEalfs8spd4o 2zkkiN0Y8n/WY6jA+VbENFFJM4+dRx6sx/8Ar8/hX0GAp+zwUPPX7z5rG1Pa5hVb1UX+Wn6H9Bf/ AATh+Cv/AArv4KN461SzK+I/FMouwZE+dLGMlYBng4dt8uOhBjNffzRGVsDsTwRjj0r+UOMsf/aH FOZYlO6VRxXpD3F/6Sf2dwPlv9m8JZXhbWfsoyfrP33+MmVWiWVAQvzdRmnJbBVz6rkBfpn+Y/Wv nObSx9fFeR654Q0HStK0y+8a+J7hLfQdNt3vLueUgIkaAuTk1/OF+2h+3TcftC+Lr/RLzw7HbeHd J1K4i0aWJwZordiquJSBzu8qElVbAKty3ylfufCrInnnEeJzeUmo4NJR7Oc1JNP0j+aPy3xe4lhk eR0csUOaWLunr8MY2fN99kefal8dfjr4/wBM0XSNc+Jery+Ej4dtPBzmK4dY7jQbT7KkNlIEA863 h+w2myJgwDWsLY3IpGppfhfRrDxHrF94ftZodAe6Z7CG6UNOsGT5fm4JUPtxuAJG4nk1+24lYfAY aWFwsVGLcrrrzOTb692/mfAcE5Zjs3zSGb4+LtTUORtWXKoJRt/26lqfVfwygurdtV1G2UgQ2c4k YgZEc0bW7+v/AD3XnPpjnGYPHnw60/4geF7K2aTy9SjZ5LaY/wDLNy5UjgdCqjj6e1fNYetKhi1W Wtvy7H9PYrKKeb8MVstq7VElfs1qn8mkzwfwn8C/Elvqk51edVihuYlUckTxMHMjg9tu1Vx38zjo a+ZP2uPD2maD8dPEdj4esTHpw07R5mVCrKss2m2k0vKgdXkY4IyM4JJyT9pkmKhiMwqunpFQ/VH8 1eKXD9bJeCsHDFvmrPE2vu7ck1vvra584x2V1INot3J9lJIr7m/ZK+DuoeLvEenI9sSzyrLISudo /hB+mSfxNdXFGPhgMlxFZy1sz8m4GyatmXEOFpyg+VO+2h+oP7TXxt8N/s8+BtG03TIUu9dcCKC1 LBBI4A3EkA/Kvrg9RX5q67+1Pf8AxQu9Pi1DFhBCBm3ikOyRs889+uMY/Cvy3gzhaeMy1Z9Xfvyl Nxj5d/vv9x+tcd8Z0sszN8O0Y292PNO+13flt5pL7z7A+GXxz0ptOtLa9lGI1GRngjvkZ/lX0LoE vhz4vaZeQa1oMN3oD7oSlzECsgzyVPUdB6flXg5rl2JyrEzxtOXK4v3Xs7tn0GX5nhM1wtPDWU1K Lut1a2t/vPmjxl+wt4f07ULnxH8L5xEhXzZdMuDlGKgnCN2Bz0wewC1+fnxm+Hp8Ma7bWGqaDPp2 oyyGMyFCqO3U4OMNjI6evav1XhPiqOdU1SxErYiK1X81uq/VH41xfwn/AGNKVfBwbw8np15G+j8u z+R4nqfhjVtJ8x7m2PlHH75VyvbH6Z/Ormg+MvEPhmRJ9OvnEe7BXdwy4xyD2wTX3MoQqw5ZLRn5 2nUw1TnpuzR9P+BvjzaXctha6+X89wyyuWG3BUgY64IwpGOfzr698F69p08R+z6huj2Tyx8LuARg CAxLYG0Njsd2eQq4+Zx2DlRk/wCV6r8T7HLMfHFRV3aS3O6bWYryLRkt7aNbUpGsgVSTI2FZo8Ft uMcKBtLFx/eFakWoTfekCLZ2+bec55HzkOEdVwx+ZzxkcBeSuK8iUe570JqXTUo2s2xTbRWoWzkj jdpcLnI8sMoCnhTuCAnqRk9QClzeTxNLPaSOLGBUEhJKqYzgbcrgHBMa9OCwHJNGsp6vRjexmm8a Ky8y6dbaZ8vcMgBZQdpXaQCUIbAHXqx9qpm8W2guzK6/aSQiOXCBHJWTPJyFxv59dpPXJaWr9fw/ 4YTb6laCTzLrUILlU37Uh8lCBEkhO5kGDlgTvGQe55I4OEskc15dK8Yk8tsRlMYlwRxhRggkEe2D 26Xbd9DJvZo2jo0yBleyCySuvzHOIwVdzsCk7iSScEkggjpWpEul6Y6pp0CNcAMu51BXdxkgDnk5 J6cJjIFHvTagmOygueRV1LWHH2W4vJfLD4Uuf4ySfujPGM46dQOatiN5XjEQO8nbvYk55yOvTPX8 /wAf0fg3hWGOl9dx0f3Udl/M/wDJeXU+F4q4heCg8HhJfvJbv+Vf5n3r+zVrcdz4KuNJMu6SzunX pk4fDevqcV9CSSEAN5g3A4+v1/n+NdOcUFQzPEU4qy5np66/qePl9Z1cFSm3d2/JlCR23CMsGBPY Dv0+n5/1qlJHnDElVx068dP6V5lrnS5t6lORQA428c9PWqUpVEIBUsBkjPJ65/w/Ch27Be7SsYlz IzOSeF7/AF/D/GqPkSzELtYA5Y8/j+XIrNpbM282MFnxgLk4JZs8DHAFYF5M5dlVjtyMYOD6Dj+l D0VluVGV9jn54srjjPTK45OBn/P+FUvsz/3n/Ss7LqQ5K+p+aWp6dNcz3U9pbkhgkipJIT5gjzkc HjJPJPcdq0Ir6C8spUntZ3kWVt21sByyBWCkn5ccDjoMmvkrc0Ur6o+0jLlbTLsmrsFMcrPL5a+U THuDRl02khuv8RHvkdhWrp3iqyvImt47CSa4uSyRhOMklVxzgYGcgjsxBNZOi2rrY64VbOzV2XY5 NVivNRjkWR4o0UKxUMQXizKuPlCZ2ZIAOe1Uxa3MTTahYaiYLY5O3blWkBDK6qccEHaB0JC+9Ze5 q0rp20NU5vTms0yUXl1DZ2h1W0f91JvVJAwaVcOXJwMHk7sf7SnpWfc69cpa3UcccJ23uFKM7nyg itubj1ZQcZ64HNUqacrdPImdSyascN4r1hrRLe5sVQWsUquoIO+4Vsl9vBAUZxjOfmUHIBxzOLy7 FolldvNeDy2Q7dqRBmYrHvJ/iJ4HXIGeld0I8tJNr1f9fcedOTlWcY/I7LTkvbHTJ/EN7rrLMYV2 wQqzbiSxZZCRkYYAFgSFBQjPzEeMH9qPStI8TanoOrabLHYxTeW8kWHWMxkqRn7xBIPIPcnNVh8L 9cc4xVrfjYzxeMWXeylU15nr6f0z6E8HfErwb4mtPtvhzxLaS6hOqx3NuGLFVUgKAG5ZiMArwOSc 46dvDqltd2ay3F9nUJIWJt1BzHDl4mR2xwxV/MAIzjGDjGeGth6tOUozi01p+G56lHFUq0FOnK8W NnZItJluvNeS2mkkitclis3kGFJkY9DId4+YgDg9elZl7die3Esdw8UEjTMHW3VkVchAgAYE5AAJ JGMe3MJN/wBf12NZPRM8s8ZX+p6Za6yLCJJLtA2yYMfmREzu27cAggEnvnB7V8a38zSI32os0jD5 izcsx5Jz9a9fBU48vMvI7MBXVKliYS+1p+f+ZnabqHlTRtznBGfQcV6Zp/g1PG2i/E/U1ukjk0Hw 7HrgU/8ALxjULGyMaZOc4vTJgdRE1ehiE6cVNdLfmc2BrrEOVGfVSX3xZ8/3gWK2uZQfmXPUdOcA f1r0Hx58PpvD/gn4SBtsmp6vYy6xKiKd8KTTywW6MPVltWlXj7sqnvWyqKEqafV2+6LZ8jmcfaUp RX2Vf5uSX+Z5bp+mh7hbcRnz8lfqR2/nX3h4a0zTdP07QYLdiTawRo8cyhWMiiMvhvQkgjrgE8ZB rnzGbUY28zmyamr1JeiNm7iu5YUVJBkH7PJOIthtYmkcsSBztIYDnJO8jtXYavruj/Dvwl4g8SXr fadUtA623yna0e4oRkjALEoU4+7xXjTj7RRpx6ux9BCSpe0rS2ir287H5RarqF74h8QXuo38zS3k srSyyMc7nY5P4AnAHoBXuHwC+EN98Zvi/wCBfhfYxv8AZrm5E2ozIObe1jHmTv6DbGrEepwO9e/m mLhlmWYjFy+GjTlP/wABi2eLw/l0s2zLD4Nb1qsIf+BSSb+Suz+qCz0ay0mxsNI0m1EGlWsEdtaw JnZBCihI0HfAUADr0p0sJXJJ4Pviv4slVlVqSqTd5Sbb9W7s/vKnShSpxpwVlFJL0SsRrGd7BQN2 PTnBz/hXT+GdAl1q6js4hwziMZ45Jxn8uaxr1VSpSqPobRjsfF//AAUw+N2u2Oh6L+yN8Hke48Ya hDHfa+1qoxbwqvmKjn+AKu2ViSMAx9QSK/nSi+EfiG/1yw0kBWuLmfy0ZSSCi8tL67Ao3FsdOa/o 3wlwtLI+DqeKxGlXEuVeXflfwf8AkkUfyp4pvG8Vcbwy3Bq8KLjQj2521zfjJJ+h96aZ4c0zQ9L0 zQdPhAsLOIQw7u4PJY/7TNlj7sTir4twoGYwVI28cA81VSrOtUlUk9ZNv73dn9GYHLcPl+Ho4OhG 0acYwXpFJL8Ee/eCxq8Xg7UrlWVNEDrYlQq5aWVllLE9cAWy8jgZXv17LykSG0jTr9niJ5GSxQEj 6ZJOPeuOmk5TP0PBwjHAwjHq/wAbIjQARMucDjHPoPf6fifwr82fEiXOq/Fv4v32qhZFi1uXT4mO G3C3JhGM5/hjXmvocofJDEy2ail98l/kflfihh4YrE5BhZwTg61STTStaNKa/OSPZPg/4O8O6z4k a01W3jFkthfTgbF5ljtZpIl5HeREH419R+DPi18Nf2cNOkub62kPizUbCa8tYo4mIba0sKpv+6GL xfgCMkV4Oe4PHZ3RqZdhpay5b3fS+oVcLlWQZHSzSVKMOWVk1FLVpq2i6s/Kz4tav8Vfi1rOq/ED xBbGayhVm8iBi4sYB7dcAEkk/wC0eB08BVnQhgwBHviv1XKaOFwuApYTB/BTXL81v9+5/HHFNDNZ ZxUxubR5amI/eLW65W2lb0tb5H2J+y14Z1zxtq0lpIX/ALFEiRCQ527jy3PsPp1r9dtY8f8Aw0+C Gj6DpXiHW47OOVhBbIRl5W4yQo7ep6c1+RcdRr5jnlPKMvhzSetl3t+mp+ucB04ZZw083zGfLHXV 9I30+/Sxy/iX476VealZaZ4YuRPZlkM1wjgjBIOB/n6V6lPpPgD4leH4rTxbptrd2zIAfNVSynPB Unpg8gV86sux2TrDYmm3CstXbo+x7X9pYPNJYihUtKjt5NdT5T+Jn7HOoWlu2pfDy8F7phQySabd cnGeAjYOeD05JP8AdFfB3ir9n6+m1S+s7CyksNXijMhtZ0OxyODtPTr6ce5r9j4Z4jpZxRVGr7te Ks1381+p+RcUcLyyuq69Bc1CXwv+W/2X+jPm/WfDuq6BeNa6tYvBcKSOMgHsQD7/ANTxXonw18Ze LNM1vTtN02KW5vLmaKKIEbmzuGAPctg88cD0r6fEU4VaUozeh8VQlVw2IjKmtb7H6raHpsY08297 eJHqM4ZpCJDI1smcOFHIIyc8ckYIwMEWtkaWBkdC4iXzPLQsN7PgB2brtXcCBngk18POTk5W7n6T BWjdjHUSyt5FqRI+0giRVhVHAwuep6gtnoUxjg0y4urK2uUhglVofKd5IWZlGW+ZUwScn5ACf9ha hO+iL21sZdxe6rdw3WIcYkE/kLIm8kk4Vmx3IXjG7J4BJ559PNu9yztm2l8yWR4xjacsNgY9FGM4 HQADIJONIqKTcf6ZnJyb1J9NsL3UL1oID5khkE/YgY3bcnoM7wM4GCOMYFdvpPhbTNFnWS4y0yOd y44OM5Ofc5A4HUnHeoqTtenBasdKCb5prQjvJpTeTN5mIzJuxu3EHGduSTwpY/ifeoYrOC6jhkWF kiCggq2N4XKjaD1xnHOPX2r3eH8pnmmYUsLC6Td5Psur/T1PHzvMYZfg6mJb1tou7e39djH8f6XD /ZdjdQALJGzKwUZwDnr2xxj8PSt3Q919pcFwAgGwBWPzYyMdfX/6wr+j8LQo4eNGlS0hGKSXpp+R +JYutUq03WqO8m3f566n0x+zfqEdn4h1bQ1cGOeHeobu6nn9D/8ArxX2d5WA+R247dOn9K/OOJqb hm1WV/iSf4W/Q+iyWXNgIprZv8xhCKokJOCcCs+UAhs5HHPpjnH+TXzrWh62+5Qu2C70UjcCfcD3 9/X9awJX3DjqeuQSPX/OamSethx7sgNttLNMBk4wOhH+cD9KWO2aVN7/ACQA/OOxrNrVLqU5JblG +uQ37m1TEAPJzjcOOc/56mucaKGQFSMgHuORzwD0ok7OyNUrJ6lCeI/NuJAK4z6E59Rx9Pes/wCy v/z3/RalRC8dmz8YfDH7QfgHVpmi/tAWF2/y7bwMiEHJYFjxznv19q9Y0/U9L1S2kj0fUIZoZSZA kU+/aT984Q8lvm4PXOa+br4OrRdpLQ+kwuOoYqKSav22ZpxpDaQiRYnaUGYugbaJVZdpGOoP8YPT rjtVwRFjBK94FuY/3JZMjY5OPlA44xknHQfWuKWlr6/1/wAE9OMlsn2NfaZZrm8tGkeWWUBjnc8j kqScYGcFeOehzU2lvqE7Q3E17DHbwR+dOfJQs6FWIAO7K4ABzg84HU84uMeV3W3bQ3i5XVnoZ1/4 huNVmubW4jkTTCiKfMYIQWHlsyAnBG5AvGM4z1yF5TzJ5xP9kDoBgTqJD8/IYoz91DIxz6qM44ro pUrKy+ZhVq330uRTWdneWFq97ayBxGHTMh2o4GwNwckEr0PHz8Cuo0LTtFjaF7G6C29qlsY1jH75 lyFf5UG1WOGYMWOAyjdggB1JVFFxexNJU/acz3OJ+KPxv8LeDPDh02202M+IZ1eJC0KOYMqqmZlZ tsjqp+WM/KWQhuGJr89fE3wz8S6XqWm6XNp5i1DUNNttentVLM1hZXSCa081iOA9u8M6knBjmiOc sRXqZPRlhqUqtZ6y/JX/AFZ4Gf11jMRGlSX8PT1b/wCAjzOLzraf7dYTyQQxHCyRuVbPQnIx9K95 8EftJ+O/DDhdekGo6WwCbZcLMF/2XHJOAev5162JwtLF0+Wa16Pz/wAjxsHjauCqKcH7vVd/+Cfd fw2+Jnhj4lWjf2Nqx+0xhXlsZztkiaRmR5D1yCWAwo6dOcZ29Q1Ka2mmhts+e73IkY7FUgJgqMkH cV8044OXVR2FfJ1cPKhWdKatY+6oYmniKCrUtb/1b1R5N4u1Gf8AsXXpbVmt7zyZ38vzBgxozOUB 6nL4PzdSFHpXzX4ghjkt7XVLQq1lOodSpzg9MccDBr18FH9235mVLEOFSdLyT/HX80c5p72ySyRT RkbwRu/unt6etaD6pLa2940N0UjktmtZAD95SyswOO3yr+NdNROTcZLR2O6nOhDDwq0vdlFST8+q /M53w/p1nq14dX1veng60kVpQpw125ztjX3Yjr2zmu28W+O9Y1/xKvjnW+b/AMiO20i3BylnDAiw 26DP8MUaqq/7o96tw56i/upr5vf7kvxPjq+ItFvq2pfKN1H722/uL/w+8H3ks1jq14gPnsypv5II AbkY/iJIB9T7V9Apb6YtxPNqNzJ5UcTKu4H94yFd+4KeVZWcg/7IrgxU+eo+XpoduAounQTm7Xd/ wudibS41R2WygdobTy5rjyZSVeMqi4xyXbc0hwTjcRjoK+eP2mfFEmnfZfAGnXh/s1SLm4ijYgGQ jMQcHHzDJJU8jqetY4KKnioQttd/dt+Z05jUdPBVH0laP+f5M+UNOsRaQzX0xXai7xnGGPRR+Jx+ Ga/dT/gmB8Gjp/g3xN8edfs1TVtdY6ZpoK4K2kO3z5VyMASShU4Ix5Djo1fPeKGP+p8J4pJ2lVca S+bUpf8AksWfYeE2AeJ4qwcZRvGjCdZ+qThH8Z/gfquIcSDcMqSDwTnj8aZqtosEk0USHymPGVA9 xx2FfypGXvpdD+vI2sZWzGI2Xk/3T1z16f0rV8QfFLw18B/hl4t+LHiKeBWtLcw6VBPKkYvL91Ii jy3RQTvcjO1FZsECtfqdXMqtHLaF+atOMF/29JJv5K7+Ry47GU8vwVfHVXaFOMpP0irn5haj8Lvi afgb8Yf2p9c8P376HPfwSeLPFt0iCG+uNSVJtL8PWknKyy+TNDdTpCzeWs6LL5aJtk+PND8PWunW EfijU4AfF18HLgY8uytjtKxoOdvIPzdcfU5/pu8cLg50aKSiuWlFf3YxW3/bvKvVs/B+EMG8x4mo Ympq489eo9NJNuyfnzyvZ9kaUblo8ADfnjnJGDkdef8A9VTQWxmlC4Jb2yT/AD4+lcCdmz92op1K kVbdn1f4R8LXMvhOCLa+yZjJ8xOC3K5A5B4OM/8A186mq6V9knIWE7QduQAQBjgentjivOpV71Jx v1P0aOGUaEIrojM+w3G6KOFfmZsLk4GSenP8vavzSvXa+1jUL4riW4uZbmXGeZJHLsTnOeWNfR5b K8auumn6/wCZ+Y8cYZTr4GTXvR57fPlv+R9B/CLRpbq41K8jIX7La+aegJDyRwcfjMDjivUfGXw1 8P8Ai/Sm03xCpEwBmtriMDfCZGMuB6g7icHufqKmjWdHGyqxeyOrMMro5jwxHAYiN4y+++6fqtzy m+8BSfDP4KfFW8t9UlaafSxa3DpvUPFcyra7DjAIPnZIOBkL7V8J2/wQ1O5kGNUGG6gqeK+nweZr CYR1Kkb88pP00R+CcYeH+I4gzrDYLA11H2FCnF82t7zqWenoz9FvhbpGk/Brw2NX8RxLZeHNN0s3 u925mdwpjY4GSWMqkAcknGK+IvH/AMYz8X/Hmqa7IsgsIUEGnQyY/cR9GOBxuJAJ98jOMV4XDeAq 4zP8TnVX4Yqyf96Wrt6J2+Z4niiocMZJhOEoP95JRk7f8+4rS/rJfgx+j69rWiXEc9hNIFU/N1wf z69D6Zr9FvgrJrPiObw/a3hlQy+XI8O4/KeDk/gT1969firC4alQ+t297X8FufmvCuKxNav9SUny 6fnsfpRbWqw20UYP7lU4OfT1/wA+prlPFfgHQPFsbrq2noZMMvnIu2RR0yGAyeMAelfj2HxNfB4m OKws+WcXdM/bq+Go4nDSwuIjzQkrNM+CfjN+yVrFzbz6h4Yt49UtQMtbuAsy+y9c/wD1sk18eeB/ C0Pwu8T397eeHpXl8prfy5lKvabjh2UdTkZUHOMMT0OK/Y8ozyGeZfOEJKNb7Uf1Xk/wPyDNOH55 NmVKq481Bv3ZefZ+aPtfSNQ07XbCK90xUWykgddwIzuUbFHHzD5VAAPcZFVZbmEXtvLco/2BCFHm ZCybSODjnB6cY4XjjGfOakpOEt0ek0kklsyawa8gmht4EbydqIj5A3FWP3u5ORx0yfbNZy2UaGC7 uEXzYZGiLgEluNvzL0Kj5RwBn0GBk0Tduomrq3Qn0XddRwxi3b7RI5MxZtoz8vlHI5JVVVvcvnnv 2mk+D9OithDOpCsrShEYKXX7pIYHgDGOPb61nWqOnp1ZdOHtLNv+v+HJru1h0p5I7KFUheHz/MTC uC2RjHUDqR9ccZrnrq+lki+zmONZJDv3rknYQq4PPv8AX9adGHNJSYV5KCtHY4PSvHXhG98cxfD2 21HzvEYtnnmSM4WMrg7GOOpGTjqMfSvYLWJAI5URdxIQnbw2ScdPQ1+6cA5XTo5fPHNfvJycX5RS Tt873/4Y/HOMczliMcsFB+5TS+bd7v5bfJlHWdOa90fULZgTuhMgHA3FfmA98nA9O+a43wJcySWr aaYc7WyBnGCcnjPXn+lfoyirU301X6/qfHqV8NNN6p3Pc/hneLoHjbw9dM4RBP5ZOMAh8qQeOnP+ Ffoif3i8EnoceoxxXwPGlHkxtGqlvG33P/gnv8P1L0asL7O/3r/gFd4k2P5gHl59h68+vWsG6k3u YkQgc55GSO+a+KZ9DtoZv2dtxIG3HXgckdOtQvHHAG8vlwD6H8Kh9blLoysLeWclsHaMEkkDAwP0 71Qu5HbdGrny1bAAAXcD1H8qXwoqLTexnTQ7VcgHk5PAA6nBx+X5VRysUbALgY+YHtjH+NS07loy pm3EjvjJBOAf8+tV9zf8+6f990te9hOTWijf5H5Q69+zdoN2si6h4Wia4I+WS3OCeD+Y4FeZaj+z XZae0M+h6tqGm3TZ2tG5wSOOoxwDX0GZZO6E0ktH80eThMT7SPPF/wCZQXwp8ePCWZdH8UW2qWLL taK7UfMMepAJIxnr+dbT/Fbxvo1s0fjH4ZXSo65ae0bzUlIAXO0gbRgc/N6nivlcZkt23D3Wvmv+ AfRYXOqtFclf3l+P/BNjQ/jr4Fikt4Dqk1mCxV4rpHQQ5HA3EHpgr1wAfbNdq3j3waNQuZIfFFlD OMeZGbxATnPyuQcjqG7ntgEYrxKmXV6c23G9+2p79HNMLUgmp2t306FZvEumEOq3VsZGV440SeMj cyjkkn7wwvJz9R0Or/Y2oyi4aEK6bGIcHKmQ/dIOeQMdOckgetRpQjeZtBPFStT6GofAkpkcSX3n WPmhZIk+ZWUNsIGO/JfOSAP7xGD1Gp6Z4asdL1C/N48Onx25WOa5yxnQlkjClcEIDErDaVzkAZBA PBUxE6rSpLr+Z6NHCxpRftHf9D5r+NfwJ1rxv4suvFPh6ytvskFsiywRlVkec+Y+FRRht24YkHBC jJyDXzTJZ/EPwR4d1a1+zXFtJ4mkksr25ktwJJljKNJFHI43qMSKHCkBg6o24FhXvYHEUa+Hp0Zy vJWTv9/z2PksywuIwmMrV4R92XM1bs/d+XxNFu40X4XeMvEvgDwha3cPhvwdYW0Meu69e+fN5146 gzSskUbSCCMhQESOWT5pHG8OqJ4ne+FtTOgXHjn7C/8Awjf2wWFqxKgl3DtGrKOhZY5DnofLfB4N elTnKNozfz85N6fJHlVqVOd6lFW307RjZX+bOf0zUNb8LanbanpN28GuIwaN4yQY8f09q+7fhj+0 BpHi8ReHPFJjsfFRMcEdwFPlXPUYOej79pOfUc8GufMcN9Ype1pr3o/ijtyfHfVqvsKr9yX4M7zx JpStcfYvIUSzICFA3H95kgnbyRypA5zXy7o8cek61q/gDW5Numzs11pMzg4IJOV/H+YPeuXAy5qc 4Ldq6+R7cvZ08xoSrO1Ntwb8mtH99jG1e0a3kks7RD5gPMn90Cucjs31+9ktxdmPRbVR9quTnAA6 gHuTzjGc/nXVB/aluv6SN81qxp03Ci/dlZL5atno3m2N5Z2EOnwqthFmO3t2I+UEfMzAdWIG4k8g Y9qn0PSYvE2uafLd2xi0C2zjbj963yg/MOo+XA69M8ZNZXnSjKUnqr/ezwlCNarCCWjt9y/pHsVj a3c05ayhHlReeluEfnejbFCk8EfMwJPc+mBXqOnaRYRI1+YiyTy/uDOGdAH3E7gMYCkKuB2br0ry 6ja2erPcpU+aXvL07eR6PpGqWnw80HxT4g1CwH2OC3iZpJldovJjLsylON37xIkB45Y/h+QPjbxD feJfEWpazdP+9nmaYgMflJ6Lz6DArryempVq1du+y/zPO4gq8tKjh15v9P8AM7n4eeA9Y+JHijwL 8NNDHma3q17CrKc4QyMFQMeyqCCT2DHPSv61PCHgrRfh34Q8MeC9AUJoOlWEVhargDesa7TI3X53 IaRj3Zie9fkPjRmGuXZXF789Rr7ox/8Abj9w8EsCo0sxzSa1/d0k/ROc/wAZR+46RCFAYnkgdfr9 Pr+tWp1W5RJCP3gUBsL0+vavwd6NM/oSjNNcpjm2kkkjjVclmA464/n6CvwQ/wCCl37UFv8AErxt onws8DasX8C+GlaBzG37u+vSV86fj7ykqFQ/MDGiupHmsK/TvCvKf7S4qpYqcb08NGU/+3pLkj+c n8j8t8Yc4/s3hKphKcrTxMowXey96X4JL5npus/8FCf2gv2nP2Uv2Xf2E/EVhpVp8C/hzrepeLpJ bG1cXWtXd3LdSxz3cjuyr9lS9uLO3SJYlCznzBIwRk4S+mE1xhSFjX5VVScIgGFX2AAwB6V+vZ5y wxVPDw2gr/fovwSOHwowjWT4rOJrWvK1+9ryk/TmlZeUUUYWG4E9GJ7AZz+nrXdeEtEbU9Rt444v mL7Qc9fQjpXiVHyJtn7LlFH2uMprzPvXwzpSWUEEflZisog20rnMnRBjHPzHkZ6A1HJZW1w3mSQj c2eV7/X17/nXz0Z6819dbn6Uoqx5x49tY/Dvg3xR4kjuBElnZvIsmCCJThIuncyMqgjGM1+WlhBv m3Dq3pxjNfU5PObw9ST7/ofm3GUYzzHB0luk397S/Q+pfg7BNbjUykbeVLFHCxwcY82KQA8j/nmT +FfQPiC1jNvoc0cUhDaZYyyEqflk+zReYvBPR9w5x24HStadpVK0u1j0alNwwOHptaWf6f5nA/E5 7KP4PfELTbw4kuo7CJBsON0d/a3G0+mVhbPtmvkDQM3N1CNmBkAcf4V3VJN4WC7X/Gx8lDDxjn7q pazUI/KLk1/6UfT/AMRvAs/jn4cXWjiRUvRDbCAv91niVAEbkZBCHn1IOCcV81/A/wCFekW/i6+j 8deDVl0q1guku4GZk3MIJQnzJliBJsJ2EMQuAyHDDfKcZ7DBxhCVpc6bXdNo+f474OoZzxG8XiMO pxlQlFNq/LKMZW/Fq3mcP8M9POoTxDxXpBs5IH8wmUALO2Tt2kDkDqQeuOetfqf+z/odk6ya2ZQ7 rhB6KSN3PTBwcke4rHjPMYVqTVB3ilbTzer/ACR+BcK8HZxlMlicywkqa5m22tOyX5n1qL6I/ulP yBevcdv/AK/QUtxfw+YAg/2dzDIHA7++M4r8qdXljofokoWTtuSpPEVwoxK3PDE+/FeEfHrwd4Ov PBGvarqOlodc8kx2UkajzJbhuI1AH3yWIz3xmvXyLEYiOZ4f6o7TlJL1V9b+R5WawoywNb6wrxjF vXvbS3nex8v+GNE/sPSodLuSTuQGZugkLZZtoH3ugAzg/JjjJzGyTxSKskZNrCAjbRks4+UYA+U4 3fe/AEk4r9Mqz9rWnOKsnsfnq5uWPPvpf5DntLi4vHvrO08szOHjgH/LIb95VRnK88DkkAevJuaZ 4duIZbh9UtkW8lC5Khu+CQB2+9ySOuKwlNRTSepUIOTStodqNN0+2E/2eIhVYKqqoGQeAOfZQOvc 9c1ZgMMMjPbtmJCySAnCEAtgA+gx/h1rid5p8x0vljpFaHOXUgu/tXkkfPzuOcsvzHC8Drx7D6dP Ff2jpfF3gH4Gw/EXwywMF1q7aLJcR4Z7E+WXZ2/ulvlVcjqD3xX0GV4b2+IhTfm38k3+NjwM2xTw 2HnOG+y+fU/L/wCD/jC78MfFHwx4mluidt6PPeRiTIrna5Zj165/DNfuDZusnkzBwUaMspxxyCS3 HA6/r7cfuHBtTmwuJw99pKX3q36H4vnUH9YhUte8X+D/AOCbf9ny/uZmYmIg9OByMY4ryLSrI6L4 vvtP2swk3BF9TyR+n8vxr7uorRu+6fy/qx4tKSnSqRW9vyPZEs3t1trlmKyptwABwR0PHbvj6V+h fhbUIdV8O6PqKLkSwK2OpJwAenvmvjONqadLDVV0bX3q/wCh7HDc7Tqxb3V/uf8AwQvhIZDgZj7d s1QNoQ5JOR/Q+30Oe9fnT1Z9Y79StLFhXHAI4+Y9Rn/PSqS28XzRyAeXkMcAZbnt7fzpNDTfUp3V wrqFWIrGuOnrj2rLkjVsMeflwB057Une+ha0V09yBoIthLj5s4AHBbjj6df0/Kibdi6syZDfd4PP P8j/AFqLdh3styA6eHbfOxCA5HYr19ad9ksf+fl/++k/wqnFN3sFk+jfzsfJ1vZXtlHayzMATENv CuUQnvzhSeABz/OraxWWomSJ7LcFLKRJg7QDjbzwMYHT35r9Sr01LV+Z8bSnyXtojmrrwhpV5Ltm hjSELh9y7CBuPf06+vQetedavo3hGa6uLGzkuIYgMGVyHjeTOML0baB1/wB3NebVwFCtJRStff8A r7vxPSoV6sm0tUu5xer/AAr8Gaza3lmbS0u0B4eSNYnk5Bzg4P8A+r8a8E8UfsqaBqHNhpk1qWJI eFtwCjjJz7n9R615GLyV8rnSX3fmdUMRG/LJWfn5njGufsratZrIdC1dpFQ4SOeJlZ+M7sjjB/Xr XNw6d+0H8NlupNDvL1rSMAsIn8+LAPo2cDp0x29a+WxWBbTp14XR6WHxVXDTVbDzs/637nb6D+2F 8QNEdIPG/hCG5jYBS8PmWskadwByDmva9G/bC+EUkdnHfWd9ZwggyQzWizIMKAPuHocdRyO2MV8x iciqRlzYOWnZ7/efX4LiahNKOYQs+6V0/wDI9x8MfG34b+JzH/wjXjfS31eR0k/0tik4QYDghwOp wcDGNzYx1rd1TwRoniyxWz1/To9R+d7lbqaQKsbM7ArHs9V2EE9SBkevjeyr4GqpSTjNbbfh6nvc 2FzCk1TkqkHpZfqfPXxL/Zq0fULTx7rul3IfU75hf6fZQhEjSR7j5+VABXytwRcLywP8Iz8j6v4c 8beGvEPgyzmjM4sJFvdO0p1E8EF1JIqkGJw0TPJ5UJf5WDLsVgQuK+jy/GRxNO09GtF/4DZv77nx +aZfPA1eenrF2b9eZvl/I4fUdX0PVbPxzrXiTRriXx5qckTaQ9pMsNrpiiUAxtAyMZI/JyiKroYv LjxvUkDC1D4f3seq6D4a8MXQ1fXb+3gleOxgnaSCeZgogIZAXkLMiqY96tvTazbsV6kXye6/h/JJ HiTiqi5o/F1822/yPaPhT8YHsmbwx4vAuNMitWt4dRkOWtWIIHmH+JV3cN1BxXsPjbwRp3iCG1mv polxu+y3MShWVsFkxj72WbluvU47V5taDwuIVWGz1X6o93DVVj8E6VT4lpf8meP6z8P/ABdMIlfV ka3dQDJHGVMi8HJ6HJ5/U9BVtPh/NcWdno0Uyw2I3FwgJMzjnJJ9QDz6ZPrWkq9K14LzZnOji61o 15aJWXp1+ZYsPBKJLCby/c2CoIBBGuCqhXLe5G5ctjqM16Zotr9ihC2tmfMMKGMumFjQ5RmwpIwC MY5yDuznmuatUdRW2R1YSj7GV73f4HRWekyyWVxCZzGv2WSKOUOB5cTRQjLYxnI3HIOSXUc9T6Tp Wlz3Nn/aktysUNrMBCSfnvDJgKpWTJzl9+QMbUYnPU8VaUVH+v68z06MJc1nL/gf1sfP37RfjC50 vQE8IeefPv1WS5i3k7Io5C6nB7OdhU9wp9a+H9Kto728ae5UmyhBnuCM/dBA25HTcxCg+rCvZy2K hhPaR63f6I+dzSXtswUG7pWX3b/mz9hP+CWfwZm1vxR4s+PWu2H+h2AOn6Q8i/K93KpErLkYzHC2 CP8Ap4jI6V+4D73Hzfdwxz1z39T6+tfzB4oY9Y3i/EU4u8aMYU18lzP8ZNfI/qzwwwDwHB+ElONp V3Oq/wDt52j/AOSqJXLPjClQAcKeTjrzjn1q3aMFkWOVuvU+9fnktnY/S6UuXU+ff2tfHOofDX9n P4neNNAv4odXgt4LdPMmhSVo7iVYH8gPLG8km6RARHvdI2mlCkRNj+bjwX8C/E3xAgn8Wa5dm2t7 xzLDuX55FJzuwOAOePbmv37wtnhsn4axWbTSlVq1eRLraKVl+LfzPxbj7JMdxvxrg+H8PJwo0KLq Tk1ouaVrru27JfPsfX3gzwVpfgPQotD0rc8hbM1xKPmckngH+EDnA98+1bEwCqMMc5LEjPTjHB5/ E161bETxeIniKm8nf08j9ayrKMPkWU4XKcN8FKKWu7fVvzb1KtqjzzLCpGWwGPXjp/n2r6l+EHh9 JbmTUnjAjiBC7R/FzzXJjZctKVux9hwzSUq8ptbI+pNsVvplrbgj7RO/2hww5CciP36Fj/wIVQYL hyBuBHJIwcdfT1/nXhuKslE+6j1Plj9rTxeumeF/DngSykxe6hK2oXm0n/j2iJjhUnoytKJmK9QY UJHSvh7R7VpLmMAd8V9jl8PZZfBd9fvPy3O5vF8ROK2hyxX5/mz9APhB4KZvDryyL8924VOCcDp+ Rya9H1Lw/ewM6zxEMONvOABjAz7Y/WvHhinHE1H0vY++qYWE6EacuiPn749weT8PUtw2C2rW24BR 8w8q6PXrjOCQe59q+XPCtmDd242gHIBOPevelVU8MpR7M+GeDdPPYxkux9x3QWDTr5NrbBKGGQTn 55O/fjpXJhZRa65deaxddMuRvznaDCw79+mK4KPNH2Guh9Pi6calOspef5Hz1pdrBLcxp5YA3jcM DpkAfWve/GHiH4m+EfCEV18Kwhmhmj+3RQW6u8sTKwU/LhmwyqACTgyEAAuQbjh6eLxUMNX+CV0/ 69T5jibCKfC2KdKCc48rXqpL9Ln0P8A/GmseNvhxa6j4s+0L4yN9dLNG9qIovsix2pgZHLl3cyNc h1MahVWIh3LsE9mKbW3MAAehxjb/ADH+RXxOd4Sng8ZPD4e/Krbn4ziqM8PiJUpLs++6T+8W41O2 061kv7ydY7aFS7yOw2xqoJJLHoMA18n+IviJJ4+1A6jtmXQIMHToyTGZPm/1xXg5YYI9FHqa9jhD CSliKuNa0guVf4paP7o3+bR8fxNXUaMMMnrN3fpHX87fichKoawubTzRIV3Rh92RGpHQAdThgAMn HfqTUdvZ3U9oVkTyofMVwWkw7A7jgDsOjE+w9BX3V1GNz46zZ2egi2s7qS0jVVaU5WRyrEnGWI7D g/Tr71t3NxazNasGWW7VHyIR13d8+mDjnjpXDUvKpdnTBRjC2xjvqE0sHlRxEBWYcjlgDgDOOpxW HfzuI3Bcqu0t5QXlzubj6nOD9BXVRpXlZmFWo4ps8l8d+NTpsKaXp7f8TExr5hQcRDPAGeuete1f CrQLD43/AAT+PnwV1FVOq6hoja7pCMST9utMOduOckBR34xxX02XR9ji8K3s5pP0l7v5M+YzGXt8 NXp9lp8j+f66Se0vmgljKTxOVKkYKsDjn3Br92v2f/EH/Cc/C3wRqykyXptxbzsBuw8Z24/T8Mfj X6jwZJwzKtR/mg/vTR+UcQL9xTqdnb71/wAA+gdR0vy2t4C2Ci5chv4sdOfxryPxtZ/2RrOk6zEu HchZSBwdpwecdeRmv0usoy9pCGyX5HzuDfvKMnumj0hTb39uXRjlUzkYwBjOM/56V9UfBfWje+EB Ytkz2spiGR0Q8rj8P88183xXS9pk/P1jJP8AT9TvyGfJmLg3umv1PT2DFjhRz6j+nvThp8kieao+ Untxnn2r8rfZn3SfToVpbJgjbU+cZPT8aybi1YyMXYFvYdvQc/hSV72HotCmYVXAjHznt/nnpiqz QorN8oMxJAIzwOPfn65pSjdgn1uVv7PeXfNL8noS3P5f561DI6W7OIuXydzYXGR3z39RStbQOZvq NsvD+ueJrmGz0uxmuLiRgipHGeue5A445/Wus/4Ub8Sv+hTuPzotLorj54x0PhzTopdQtle9VRAu GGTy5IY8568bc/hxzVq9ntrVjZaewAkVCxkcEKcqW5wfmyP5DkCv1Xls3TPi4t3aW6f+RwfjXxJb WpbSLOMfaNq/am805VeCFHTDcnOOnIFeVQvpawyearoT1IJIx6fh6HuainKk03OOr2/4J6+Gg4U2 77/kV5BbvFMkarwMbmfLcdOT04z+VaFrf3tsFUXciR5YqN+cc4xg9M9B/KhU3du+h0zUZrllqdTZ +KVEMlhdaVbSQ4VHdkwxVcZOeec9T680y8t/Bt/ZurWkkM5JVduGA5DYJ6f/AKq5qmDo4h80omPL VoxbpO67M5DWvhL4Q162t47e5tLkSKqkSRq5JJPGSMjHf3zXkes/saeFdcadk0kKyDBls3KjIGMY PHAweR7V5Nfhr23NVpSSS+8qljo35akbXPINZ/Yet0LJpmv3MOGyJZ7fKYPQAqecdM/pWWfht8df hw9vp3gPxJPdfuxLttrkzeWMkLuVxgEjHAyO2cg4+Nx2WVJSdGrT5op9tT28LiZ4b9/hqvLL8/0N CH4iftPaOVfVfDIv1jYIZWsCXDLkhdydxnOPcHHStSy/aH0fcIvGvw3mt72RgWmgySo5+ZS+CM7z yMnkHJ4r5+pllO7+qVOWS6P8j3qedVkksxoc0X9pf1Z/I5nXdL+AnifRY7bwdqy2etPfRzM2pjYy xqki+WjEfKuZNx55IHoK4jUPhx4r+H/iTVLr4Zap58lvp/2j+0YZ48RhYBLK6Ov3WSbLwsMOkqRM uHVSOqlUrpezxUbS1bttZWtY48Rh8PJ+3y6d46WXW9ndvyPNr28tpfCnhvwEfDNrBCsyTajqcMI+ 1XqxNcSrH5rKzI5+1sr7SEkVLMOm63DH274f63Y6ZN46hj1qO6+GGiC3i89lnldwQsbXsKtAjLbN c+SipIEkjF5bo2drut14OpTkvmvW+hjhKsKVeElotE+1ktX9+p63qNjBaw6cTIz6WUSSK7VDsdHR 5EYDAyWU7wTjhD68c5cpHbwqrkgGCQfvvuDez7MFSSBl1XGfvD3rx/ebt/XofRXi7yTv+qKNvaIW P2aNzcRToX5AXyhtC4buNzDqP4SOrVvJogt1AecmNYRCjEsW+7GBgf3hjaufT8aqTsrSepEY6X6H S6ZY3V0qW9wGWFfK2AoilthUsdnRgCqtnOcgHjBA6O5OkWdpYWV/KYbJrW4YzCPGUtkEnXsSxC5G Plw2CRXJUvKSil1v6nbT0i6kmfmz8T/FN/488Wa74quizG5mby8jAWFAEiAA4UbQAB2/CsjQPDuo avP4f8J6ZE8msazdRjyoU3OyswWJVA5LMSSF75T1r6a8cNhVzaKK19Er/ofJ06VTFY18q96fw+bm 7Jf+Tfgf1i/BH4V6b8Fvhf4K+GlgE3aZaqLuRTkT3r5e4fPdfMYqp7Rog7V6UZBIOW+bcQpA6+vs PpX8SZljJ5jmWKzCe9Wcp/8AgUm/1P7mwGEhgcFh8DT+GlCMF/26kv0HlG2F+CfTrQuEZl5w3XB6 en+fpXDe+h6Klcp6to2j+ItLvdH1zT4rvTZlAmt50DI69/0+nSvy3+MvguXw7428VWllp0UGmpeT /Y47eHy4lgLkRiNRwq7Qu0dgBX3HBOLnDEVsLKb5GuZRvpfRN272se1lGEo1vrNVQXtLRV7a8qbd vS/Q8JltzGWDAbwRlsn07jH04x+PWsW8AAdAw4UMB0yf6da/VKeruc+JpSg2mh3hdBc3hCnMm7y1 Gc5J4Ax2/wDrV+gXw+8MpZabpelSAR+cVad23YUckkgA9ASe9cuZtrlh3f5H1XDdHkw8qr3Z3NyX uLmaRciMnCZGdqgcDr2Ax07VWitWmnjgTiSRhGu47QucDqfwP415Ku5JdD6V6RPyx+MPi0eP/iP4 h8QQTF9MMv2axJXH+iwgRQ8f3iihm9WZieTS+ANBm1XVbGCCMmRpFVfqTX207UsIo/yr8kfmGXw+ uZ5Os9VKbfyufrN8K/D1tZz2yNtFrp9s9wd4PzyIu5V445bjGf0ro1trPVDcPqCj5ydoCAknqfT/ ACa+ZpW9knJ6yk/6/E/RZvV+Vj8+P2p9Qt4te0bwjayZmt4zd3arICFd+I0YdVZVBbnqJge9eWfC /wANS6vrmnRBSU8xSwwT3/8A117P8HAXv0bPmKcPrGdzmvs6fd/wT7F8Q+HLqOx+y2cLNOzBiR/C AP55J49fevJPEFlcaZ4f8RzvEFItTExxg/vCseMH13Y/LuawwlZVPZxfQ9fFUeWnUa6nh2gQbr+H ngsMZ9MjH9OlfY3hyaeyLvbSMsuQNwXptOMqeuevHsK6Yt/XKdvM8/F0k8rqU5bP/M9T8FzJPeXY WBIyI0BjjUBQSSeAOAMjpjiui+NXwK+KMHwo/wCGgdL8fWVh8LLfxAvhe2NvcRG51fVFjE01skRO 5BHE8Ds7KAwu4NhOWC+Fi4wxPE8KFanzRau/RRX+Z/P/ABfNYJ46rTnaa5Yw9XG/5Js+cfiF4iHj aSbwTpCSJ4XtJ/KvJWl3C9nibDRFuN8aMAHOPmYbQMKa5bTzBcvJB9mBkCALuO0dd355Br7DDYKl l9F4WkrWbk/+3nt8o2Xqj8gxuMnjq6qz3skvktfk5XZIunrmCGAlYy/JQD5ckZIHA49frWufLgVb S3tvMdI2XDgY3jBB5wMYx+oqptvRHPGPK2/Iybe5H7qOJV4BO9jxnkjOPqP89L1le3EVikyxo080 zpI+1gEPTCnv1AAH86HFOwX67kZ1lbWMRylTNIMsrL/Ecr24Hb161wXiHVDaaPqd8Dlo4GCkjG4j oFPuT168cV6ODoqVRXRxYqo1TfkfEel61d3uq6g19KftjvvkJ798gZ6jBFfYn7Mfj6fwV8V/BOsP MVs475Ip8MQDBMfLfdweMMT74617GJapvnj9lpr5HzuHk6tKcJbtNf18z4s/bs+CE/wc/ag+JXhe ytmGjXV1/a2nvghXt7n98uD6AsR17V9Lf8E//GC2uh+MPA5KyX8Ui3dtu/gVuJCB9QPz/P8ASMgq rD8QUpQek729JRbX6H51nVOM8JPm+y0/xsfoS8DOz75CZN393qT0+v6VxXj7S1vdBuZBGDcwYfBP fGCf6V+r04NzstWz4+jJQrw6K/5lDwlqUOoaBaR3DYkVdsmAScrwDx+A/OvoP4J30sOtalpkh/cX EIMSquMMh549xjn2715ecUPa5JXg1qov8Nf0NcBN0c3hd/at9+h9QhFQhl5POcLgnHt9Kc7lULKc DuoxyevH+f51+MyWvc/R4tJMotHLcrtVOD0bOc5GDz61WNlgqJgQAQT3I9Dge9FraIpalOSxZ5XU J8g9R2/w4P0qBhb25yFLSBjk46etSiN9DnNXvtkLTSktCASwUcL0PPqeleU6Drup+PvGY0TSopY9 KhlVZplGHbpkZP3QOp+lOKu7IJPkg31P6BNZ8D+EvBf7JXg7XPCFhYDxlcxHzLi1cCUoq45544AB B7k9eK+G/wDhJfiH/wA95f8Av5X0cKco4eiqSS93Xz1fkckG1FH45rNp7XEUNjeTwxlNjpOgYnrk LjIPTBPHXqM1z/iDV9O0syw25D6r95WZshWzyWAGMeg+h6V9jVta0Wk2fOUIc81G3r2seD33n/aU i8neZHJck5wTySTz64/Wnzyw28qhFKyE5bOQSo+YDp/npWfJ71ke5zaFaK/dX4UPE2W+YYCkn07Y GOeeprZNtPMiIkecEEncRgehHUAdeK3VNyjp0JjJXZYiuEii3GUm5bG3y1B9Oh9MY/D8KLhjMi+X dD5TlVI29/w78/hUK9lBFPRuTKEayQLHIisMZwynkdiQffsAO1dnos2rLGk019JHZ54R2OZc8dvx /IVNaTjG3XoKFONR++jvF8eT+Z5N3Ygx48n5FADIBjGPYYxzW9Do/h/xLaSXtnYGMogWR9u3B+o4 wOee5Jrknh4VWuZa3uZTdSlzTpvQiufhTb3Uxt9Ldl3kuxyWA47ZJHc49a818b/s72Gp20r3unRS FEETSI4VwOQM57DJ9Pyrya3DNLFRnOmrSWzW5tHNp0oRp1b8v4Hxj4y/ZHjmmeHw7qk0E3/TaDco 78becYz6HpXz/qP7Mnxl8LyXC6HqDOrBvNEFy0fmAY4K5+bJPTBr57G5NisJFylHmS37/cddGvCp JeylZvzsecale/Ebw7aRaR4s0OWbTbd5GiEkIQoZNqsd6jnOxM5z90CrUN54b8UrqTxWT2CNLJcL axqDBbMx+7uck7ApYL1PAzXizp8rutDrjNy92e9vwseteBPFw067k0m+1OC+0DdxHCFL2bOmUZGG BjLyh1HTJHGK9rvNOs7e5kukhBhlTZHKk25HfdzjYcN/CQB6HnIyPExlL2U1K2/5n0OBrKtRs3dr 8v8AgbFCwsI7a/kt4HlQSbQhjdW84ZjKxkHKkBV3HjqeB8taUlrc7xBauVVdkUbPGhAY5wB1JLEA g8bgSTjGK5m/I74xlunuaGmS6kkMcv2UATBSsk5YKBlwFODlCcs3HPKnoQa5j49+NrTRPh+kdsuz VdcMsfllVCwx4jaZ4x6/KIw4GCHPOR8sUqftMTSjF9fw3/Qdet7LB1nLs/x0/U+CNDgN9cpY3RYW jhpZWUAmKNAWYgH0Cnjvx61+pn/BMT4MX3xG+KWtfFy805pNL0KSNtNhEZIe/YMlmFYnIESi4lBU na1vDkfMDWPHuYrKuFsxxLlZ+zcU/Oo1D8Nzv8OcD/a3E2WUpxuo1HN/4aSc198mkfoZ8af2qR8P dQ1HR/CHhC6167tJjDe3CMIbSGUYLxiRuWYZAO1SAeCc8V6V+z/8ao/jboGrXVxoE2ma5ps6wXtp MQ3LDcrow/hOHX1yjV/N+O4RrYHhqnn1SquZ8rcOqjKyWvfVXXT1P6XwPEtDGZ1WyijSlaF1z9HJ XbXe2j16/ce8TSrgsFAIHBOcqP8APOa8R8T/ALQ/ws8JatNo2s626PbSGO9uo7WWS1sZAASs86gx xNz0Yg8ivnMuyvGZpVdHBx5pJX3S9Em+reiW7eiPocTjMPg4KeInyp/0/kur6Hsa6tp00os4r+Jr naGMfmqWww4O3rjjrXC+OPAmkeM7cfbYFFyAVSb+IYHA9+35/msDiK2XYqGISaa6bXTPZyvMFgcT Gq9YvSXp/wAA+L/H/wACrrRoZ7y2UtADkMq4yPwycCvkvx54b1bwzqp0G6tjFeNHFKUyB+7lRZI2 9cMjqw46Gv2jI8zo5ioOMrt3dvS17/efQZosPXp+1w00+unmdn8HPBdxda/DJdwERRsZCOen+c19 4WUMkNrPMN6Fv3MQ6YT+LGOnQDpzk+la5pU5sSorZI+jyil7LBU13EW3JyY1AA7Z5P4dDXlnxq8V Dwf8O/EF9EcaleKNJtsjIDzq4kfBIIAiWXDDlX8vsa5sHBVMVSgu6OrMKvscHWq9VF/lofmPHal5 MZ5719gfAHwspupNXmjG2FcqCOrY4/pX0uZVOXDT130+/Q+O4cw/+0Tq9kfoXouny2XheS8mOxr4 gggAFsHOOR2xngdz60/Tv7OtLy41i+mWHSNPt/tdy8nCoqJuLN1GM8sfQGvKpUVz4eDXS/43/I+r qTtGcvU/HPxr4kvPHnjbxF4qu1YG+u3ljRjkxR5xHGD6IgVPotfXX7PHhJIYJtau0IJIjiO3J7Z/ Ppx69q780l7PCuK62R4eRwdSvWxEurf4n6e6Z8OvCsPhfSm8REJq118xfBRtxbke4BP0wARXw1+1 f4U0vwPokdjDIrXmoXCRxjBU+Wm2Zz0wdpEI9P3gxVfUKdGlRqQl72nMvXU9T20p88ZLR3t99j4r 8K6Q9/qdska/OZAAMfe5/wDr19gQaVNpskjTcRMxEeT1U8nrjueuOeKn2yhjIX7MyxWGdbAzpx6n Y+CoJI7rVHJIDJEBnrwHzzXHfGzx/qGuabpfwZ0zUpn0yG8m1m7iVwYNLaVIo5ZFXH/HzKlvCik5 KpHn0B4qFOVbib2sErQXM/TlWnzdl8z+ZfEKfsa+MpVnu4pL+9ZW+5XfyZ5Bp9tp+mQxWMEJjeHC QqqkLGu3hgOuccc+ucetOAvC955csrSKuXKgYVRkHPoWyePavrm5SvJ9T8g0jZR2H2ttJPcpdPI2 zG0orlRn5toIHXBPfr+NWrq3ntLgw3d3FES6ohIJwpGCDnPTnP06+kSauo2HBPlbudHa2KwNC9wq mPysBY2Xgg9T2z93jPGKzLyFbfTmtrdR5TEpFsYkRjk5LDqee3oKyg+eoaTVoXOLvNSRJEkdc7Cd gIG0DpnBPU57+lcN4xuHbTYbdoDmVgAMg8BcnPrng88DP0r3sJFq8r2PFxs7qx8aa/avoutrK2dr uGz6mvYPCl6rGykR8qwIOOOMZHv16V3Ylc1JPujxME+StOD7n1x/wUe8OJ8TP2ef2Zv2mLUJLqYs X8Ka08ceCZ7cfIzfUZH4ivzT/ZU8bnwj8afCz3Ehjsr5/sEylsBhJwufX5gPSvrsrxPLUy3GeVO/ /br5H/6Sz4zOKL5MVR7X/wAz9vVk8mU+Y52A5B28c96WW0S5s7+zwfMlQq5YdMjj/Gv3SmuWab7n 5opPSTZ5J8P0e1vdR0u62llfI3ff+9ggAfT/APXXvPgi4l0jxP4duIpAkRuBHISpzschcHuOv+Pr U4qlzYXEUnrdS/J7nVVl7PHRqx2Ti/yPtF7ZjO8aZJBxuAPNR/Y2QK0gIHoSRggfnX4RNKEnF73P 0yL5rW6jpBLGFMZTb15HToO/Xisi4kdF3Ng/7PTHTn/62Kys9ytVoY0jTy/IrYGMnDYJHvzVORGd to5IH0DY/wA/rR5hZq3mVHgR0bzkBjwcLyc89Ofxrc8G6Pp2muJ9LiijlnmXzCoAxkjg46jpWkN0 zKbvufq/ZfFH4ZWv7P48FaxoN7cfEexhdUtY5GMDhuVKMPXnpjAGOTXyz/wmtt/0Se6/8CpP/ia+ ioTouhCNSN5LR/8AA8rGMY2Vmz8nPin8Ffid8HNJi1Lxd4WuIYZrgWyXKPDKk7gblVHjckjCnJA6 V8WzLqD3jTXIaO5ZjLIXBXpkjGe/sCOcV7mGx1HG0/rOGlzQeifmvX7jz8Php4ecoVlaX6GP513L K0cGcdMBtxUDPJ545wDznr7ZnJS4D/bLwiRRlAE37s5+929fzr0qdlBOeifTvqW7ybUdyuXFvLGl tCpDIVbJ5K+noBxnB6YBq5bXZlzBNMSfu5AwOc8dMHHr3zXTKp7RcsVaPYiEeR3TuzbtZYX81Um4 RF+XaPU4GRwehJx3ont5QmQd0QUMQFwX9T/Tt+NZ8l1zJG2qZq2VollbxTahC5lU4WLPCj1OOM9v x6c1fWSS7umEkfy5yuRjy+mcD2GRjpzXL8Um3sv6uaSfLaMTuPDvhmbWbuNSHFtkAt8xxnGDjseD x3x9ce76fZ2dhZnTI4QLYHALcHAJGW2jOcj69q0jDk1av/Xc4sRUWkF0Lsl1ZW8Im+0SIV2qiYz0 6HgdTk9fSqC/Z9UF39qnRsjlRIMEEdOfYMf8k162DlRs+jfc8evOUtE7pGWnh9b2aOK2lRbxgc7j jygM/eY8YGDz15x1rndY8D+HBZNb3LhrrL4kDYaUjC5Cr0Xk4/A9648Xho1cTNON6dtfXSy9f8jt w85UsO8Q3rsv1PMNW+E2h6q88NuT5WAqCRFKZzk4BOPUc+1cI/7L+ganpmuW8nh+2OUdGNuoR2OM 5OPwP/66+QzTIVKnKpT1/M9nAY+M6nJPezPkbXf2Q9PSMSaFe3liSmCJV8xW5weRggdsVheG/A3j z4YvLp15drqHg2WUF0V/3kG0MA8QboOclQe31B+QzDK68ISpSjf9GethK8aNWNaEtP06nbeS00dt LaXYS2YoVmwPm2sFLDBzuAAOOmW/CnW1xA9rPLLbziUSBUMo8ry2jVVdlYHlgrYzk43Z9DXyM04N rqmfWwlzOMk9Gro9D0GbT3uEu9dkEv76PzzESQRkjCrtIjIIIAxgh1PAHH58/GjxS/jHxxfR28x/ sWxd7SyRnDCGNWZm7DgFjyOu38a3yqnz4tza0itP69DmzyryYKNOD+J6/L/gnDW1vJBokiRoP7R1 SQQRZIHl2yNgtyOjOqjIPSJwetf1U/sZfDuX9m34P+DvCv2ZYNfutNurjWN8KmSC71G0MEoIx8sk ELRRd8SQs68tmvzfxnx3JkuHwEXrVqt2/u042+7maZ+neC+XqeY4rG1I6U6Khfzqy5t+j5Y2uj6L +Oep/sn+Bv2Zv2YdD8K/C20174xa3rF7H46MupzwDTrt0CWisgSQx2KTP9qkkymYrdrdH+ZpLf51 +GPg3SfD934v8UaPox0+31yW3njsiCDaokZbYd33isksqqxwWQISASRXyXFmOoUuG1ho1L+25FFd bR5ZN+l1o/M+14Uw2Nln1etNWjF1HKy0d5SUE/OzV/R/Lo/GXjzwz4ITw6/ibVBbR6pqcek2Zk5E tzIkkiKT/CCIn+Y4GcAnJAr5g+Eeix6Z4h+Jf7OviV4Nd8CNZNr9ndyN5rSWt/cTLLbXTc75N6ys rk7mQ8g43v8AFZZRrUcqxVVxcbqNanNdJUZ8tr9L8703uos+1x1WFTMMPSi1JJyp1IvtUhzJ/wDk iXo2Gs/DTwp8Y/jDrXiSxF1p2k6BG2m3+qaPfy202s6pti/clo8h47KJFU5PMk5Qj90cx2nxc8R2 Xw58UfE/w7r9jf8AgW0097bwvZajMqXOvS2siQ/aHn3NlrmSK4SFAoJ3wHA3FR7ao/2jSw2X4+HN GiqNLnilzqdb3km/tKnTTjZ7OK2OR1/qdSvicNL3qntKnK3py00o3Xbmk07pddrn1ikn22zgSa32 tJGheJgGIYjO3jr6ema/MD9o3xTonin4kLdeHhn7NBDZTTKeLmSAuoZR/dEflxj1EQPOangahU/t erUg/chF3fTVq332v8j9ByaE6vtH9m0V820/0Z7Z8LNGnh0NdQukIvLgKDgckDnjt3/SvcEjMcgh XAEabOvTqD3x1z6cY9q+vxEuavOXS5+oYamoUoQXRC3CKkQbopIAOPbBxnrn39vSvgP9pzxC+qeJ tL8NwE/YtMhLvwMtcThXc5HUBFiXB6MretduUx5sWp9kzzs+f+wThHrb87ngmjaS13dQxxrudiAA PWv0m+E/gyWLT9C0G1gY3d06lsDls9umeB/SvQzV83s6MXrJnFktFUqEqnc+h/Fd8LzULXRrFs6d Yp9nhIyAzAkyHnsWyPw4614b+0x4mPgb4LyaNbzGPXPEU4txtkCutqo3THHdCMIwH/Parw69rjJy WqWnyVkdONk6eCl3t+Z+avhbR5tT1K2t4BmV32j0Ga/V74UeDobc6LozQ7re2iFxP8qsD3APseAe +AayzNupXoUO7Msop+ywcp9z6z8c6Pcatd+DdK3+UkMIafafujClzkem0/Wvyf8A2o/HCeMfivqt rAxOl6X/AKBCu5iPMUnzWIPQ7vkz3WJa9OrT5atST68q+5W/U0g06cEvP8WWvgL4Rm1vXLd8YVSO Quce+B6ckj2r7707wB4W8R2zapqUW6KaR4bVUO3yljLRj8TtJB9Mc14qpqvj5qWyX9fmjrm3CmrH zT4/16z+Glvqdn4eK3XiG9uJbTTIJGGD5RIklfBz5UWSWPf5VBy4r560SGNLSXzbl7jW7mTzryaR cPLIxG9mx68AAYAGAOMV6uU4aVGFfEy3qOyf92On4u/3I/j3xMzCOL4rxVGntCT/APAklH8EvxJ5 WSaSaScKHBYwgDoFGA3P0B9+K5g3Et151paXQEjTYfYuTJg457AYA/T1r3IKyvLofnVST+87i3mm iSBblArEDDRAcvnt78n8qqX8Yvbq2mSUAtKUw5JPDKCeBzwa5l8bka68tj1yHR/D+ipbS3G+5eRN hUg4Bxgkj8u9cX4xuYDbi2S2WKJItoCKBjOflHYE9O/1rKhz1KqkyqtowaWp5fcIttErTKo3H5SV OQCc5Gep4H+TXl3iyV7q8s0k3AiJpGQ4+TJwB+QHc96+lwytSk+589ivjUWeA+O9Fmurf7UzAyIo bA6r169Tjr+tZngnVkktZYGlImQEA4wQc46Hr19q7Je9h7roePrTxjX8yP1q+BekQ/tFfsTftVfs 9hDc+ItMtU8Y6BEQCRJAB5wQc4+4Dn1av5yo7q80TWLW8RmW7tZ1kXnkMjZ/mK9zASbymg+sJzj+ Kmv/AEtnhZvBfXai/m1+9H7neEfjU3iPwl4d1u2slIntonJZ85YDnt6g8Vp3PxB8R3LyOsiRKuMM i9fXr+B/Gv3vDYj2uFpTgvijF6+aPztZfTTfO9nb8Tk9G1nUbPxzZS/ajvmk3Ox5yzg8HHuR/nFf S0q3h8i7SQmRZAxzjPHzDr/ngV00Jt1K8Zat2/FHDmy5KsHHsfdXhvV5dV0DSb9QrPJCpYju2MMe 59a15pY4/wB5M4JyM8nj/OBX4fjaUqeMrQlupP8AM/QcPU56FOa3cV+Rzt1flsiNj5XP1Pb9ax2c EttB3DjIPHP+f85rkdzfZXZEHcsAzHaSCcHHGOmP89atpZ+YB5RYvgYbGMfl/nmolojaFmrdSK+0 83MJkztccMo6t+VZEV8dHiu1RcpJtwDnjHQ+nf8ASnTk1JeRFSN+h9K/AH4/aNpGvx+HPHk8aaRc yD/iZbC72nOBnrgAZOQGPBwOc191/wDC3P2cv+ivL/36uv8A5Hr1aOLlTgo2Xzjc4JqcZNctz8Av 2g/2kPEXxp+IV/4vvb+RNML+Rp8Dfet4woDOdxP7yVt0sjZxuYKNqRoB47d6jpHlwG8WMyBcbWww Ug4G7jGSQevqc46V93lOApZbl1DBxSfKkm333b76u54mJrTxWKlidm3+C2Ri6xofhC/t0fTNGXd1 dy208jkjZ3wByc4y1Zp+Ful3dul3AbmKFkGZEIcA9QAxHcdvfpXq1KFN6vR+Rz0sRXp+7F333TOT vPhjfxKr2l6ryEhPJkjwUJ3KBlSRjIxwSKz5/h7r9lAZ0tEkKAsTDJkKoJBxnGBwc5HGDnpXNUw8 6ac4u6/Gx30cZSnJxqe6zKsdB1qC1glutOmikusTlTG3AOFAUE8ehA7j3rat1fSXBlkfzQCEUkkc 5GeOp/PpXLPmXu7XPQhKNnNO9i5Z3d3JGkrSFudzEgcgHoPfgk49a7nw5pkuoyOsNmTKvMkpPyDJ OTk5z6fh+NUpRuosyk4tOb/4c9o0tLrSkjtYZNjRncWDZXI7gjkngCl1XV7SK5huvtMbSEASKNwV euBjpwAePU+vNdkOWul71meRVqSg+bd7mFK11qd0zOoC/dRFIKgjg9cDqR/nmsl7wWyXSzPHHGhO +VuAg7kfU8fpSqRlRj72tkc8H7R3SPKrjx9fLdzx2kkq6aW27BwZAMn8yc+mMii38c6isPlzxxu7 Mz/McEcdPf8A/UaxpznFWv5/PQ9n6vCrTUZbrqben+Mku3haeNokHB24YbR7f1zzz61794N8Q+G7 jT78wagQ5jJ2bcF87g3Y/wCRWlSeH+ryjJWemv8AXQjD4WcMRGzurP8AI5q4tFmieaEwPCWJCkqT jrjnp0J/zivmT4rJ4Wu3ubJYInkZG3NG2wR45JZs8YwQB+Heor5VSxd1Kzj5dDj+uVMOuVXVvuPl 7RNNPhjVLoLN53h+YgTWlyS4ILBvkKkEH5VBwR061sy+Hre41H7PZRuElwy3kab9oYrvXG45bCtk Hk/Nxk1+R8XcP1MorxxVF3pTvfykv80fecNZrDMaP1SppUht5p9vR2ND4gamPhr8NfFfiP7XDb6i HXTLCOEcXF00YcN03FoVm3bzgcHGTmvzU03SLzWtSs9Nt2Bu7uVYEkkcIoLEAszHAUZPLHjGc14G T/w6+Ifp9yv/AMA9LPbzr4fCQeumnm3b/I+2/wBib4T2vxu/aX0SW5sd/gLwvB/aM0bxsEkhtNgj SRdxH76d4FkQNyLiUgYBr+jS7MrNM8sgdmYnLHP4k9+/+ea/nvxdx/1jiHD4FPSjSTf+Kb5n+Cif 0f4UYFYbh2vi7a1qsrf4aaUI/ipGbcWdtcSbpLeNpM43BFJ5/wD1VbEI6Kg2jnnv/k4/KvyuVWcl FTk3ZaXe3l6H6XCEINuEbN6uySMDxV4Q8NeNtGn8P+K9Gg1HR5CrSW1zGHQsOhx2IyeR6kd653Sv hr4d8GeHtZ0T4fWcWi3F1C4juoIVdo7jyykUz+Zu80oSpCtkcEYANdlHMsVTw31BzboOSk4X0e35 2X3J7oyqYShOq8SoL2trc3Vb29bXf4nA6r8KLm28BeGfhP4VldfDUswg168lbzbi7sSrvdfO7bmn upMI74+VZpmG1gtc/wCE/hxpj/FHxrq2q+CLe30nRDp2m+FiIVWKOIQtdzywoDtDefeyKX253R8E EGvfpZ1J4XF+zq8tSanN9LznVhGy/wANPmtbbmkjzpZclXoNxvCLjFeUVCTu/WdtO6TPcdQhjn0f xPDH5i3Q0bUZLby2O8TraTmDbtBORKEx7gCvzG8CfCnxH4u8WQWVlpc08zSl/LSJnZgoLs21eeFU k46AZ7GvpOB60KOExsn8V4/dZ2/G5+mcM0ozwtSpN6Rndt9kup9u6b4fOmQWwEO1YEBQHjJxx+vv 0BqQ2cscLny8nIHQn+f+fyr2FLmu+599FWRWzI7CJjuAcEIcDv0yRnngfiK+Vf2h/h9aW2n2Pii3 kD38t5JFdMxVXcuDIh2jg42y5IHHyj0p4bHvD5thsLFaTvf0s7fifPZti7Y2hgLX9pGTfyWn5M8r +E/hCXUNesWmgP2ZG3k4PIGSf5V+nXw/0v7JpeveJ3IVolW0tSRhlkfcdy9+FU/QkV72Imp46Fto pv8AX9Duw9P2eGUDovCvh62u9SjXyAynvweM45J9Pevzc/a78Zr40+LF1o2nzh9C0OFdOg2yblaV fmnYcDad52Ef9Mh6V15b/BdR7t/kcuYpzh7NGd8BvB5vNXXVZo/9Ht/mI7E9gR3/AP1V+sPwR8Nr NBNqV0j7GIncgcBRlY0Oecs2W4OMRn+8DWFOKxGcQX8qNpL6vgLLexo/GDxlF4G8CeMfGU4T7ZHb tDaq4zudiqRjAIJBdo1bH8LE9K/DqO3n1HUW8w77qSQuzFizMSc8k9Sa9bFOKk2ZUo7I/Q/4OeH2 8LeBdS8RGHbdlRb22c/66UFQVI4BChj+Oa+hdVv7L4f+BJNY12ZYNN0XSGv7qRh8sTIhc5xz1IB6 8eteNgVKpNyj1v8Ai7L8jbGVoUKUqs37sU2/RLU/Lbwf4vtPiZDP8RZ7oNf3TLbwoo3C0t0AxAnP Jyfmfjc7u2MbQOolUkzzwq8cAcBsMOcADqRnHOa+p9m6bVHZR937rf8AD/efwfm2IqYvMsTi6j96 pOU29/ifMvwf3HKavPK0kcCEMd2WO5i0S8Z5Ix2z69as6TZxLcSTZ3CUhsg/6vCkZPuSP6+1bNWg 7Hjpc07PU6pIbqW7h0yOFWkZdyupC++PYduK3dJ8KmS4a61IH5A7LHHJjcRnv+A7Vxzagv8AgHWo Xf8AVzob2/a4DlgiMkZIG4jPPf8AyP0rzHWmdoZZFQNJkBAG55OCMH0xSw9oy/rYmu/dOQ1QSSyM rTjy4k2uWPzDjgZ+vpXl/iZtuqXSFwcKkeCeRwDgemM/Svo6Ef8AZ3bueBif4tmcHq9v9ptpYXkw OQQWA3E8Dp+OBXg1mraN4haBm2RSEfMBjnP/ANb9BXXR1pyjY8nFRtUpzb6n6uf8E3PiTp3w8/aj +HM+szonhrXml8O6n5hAj8i8QxgnPT59nHGCfoR+WX7ePwTn+Af7V3xp+GptTFY2mtXEtnuGAbaZ jJEV7H5WAz7GvXyefPl+Lo9Y1IT+Uoyi/wAYo8nOYJVoVO8T179lXxANV+H1xo0krGfT7rAHJOxv mH4Zzx719Mk8kR53E8HPoeK/aeH6rrZRhpP+W3/gLaPh8SrVai6X/MtXEaBNPv1RjJG+PQqcjp29 MV9YaesGoaTFeSsUt5VDbiMdQScg/pXv4Z2rtNbo8POYWp0przR9I/CvV0bwkun2zApaytGGB/hb 5hXZTSb+ZSxz+P6/j7V+QcQ03RzbEw7yv9+p9dk9T2uXUJt9LfdoQSx7wDngEDAY4PrUZgZNwZsL u4zwc8/n3rwmz1Wrq6JQIkYFGyDnJJGBnrVu2nePeAxIJ49R29O9Jxuh02otO5FcHEu/aQ2QcckH 9OPp/Wufu7VHJn/hbkDdknP/ANekrLU2nZq55n4hs5fLhdAuAeMjAyfXrn8u/vXKfZ7z+7F/3yf/ AIitFW5DmnFN3PnCzFzc28mqSWaK5wYs8HGRnBOcduec7uDxVVrs3UF1aWpJlYkKdm5Fzwen1x+G cdj+wWlKSV7Pr/Vj46FRR5rapf8AALumWtrpUwkkvGecgq8TBY84655OF6cev410b6vrU6Ja3E4X ToWaWMQyEl2JI+8cknhR2AC/iKcFKcXJPR7fLRhTqTUKjdkpK34pmPc67e2MkC3lwis2SBuy2ASc 5Gec+n972NdNYWRvYJLqzmGxm2SMxPzjj7pPXvx29+21RJxXI9Ov5GVC0W5Xvf8ArT7jXjSTTod3 yPcMWiYuRx9Mnpx39adJpmiagf32mQPMhy+F3Zzn5s4Hp29fesIw5neovR9kaSryh7tKTX+Z1vg7 4SJ478QW+m6Rp6q8q5DxvmK1iOcu2RhQPbJJIA5OK+tov2WNB0rSI7fw94keB2HlvJcwgiZgBk/L z1PHoOMnJz8jn2c0cpxdLD01zXV5eSvp83qfQYHB1sbhZTqStrp5nlXiH4C+OrZbmLRrjTrq0U4D RSMrMSRnhh65HGeAfWvJtY+HPjnTVjtb3whd+RISWlgj3hyMnqP8966cDxBlmKSSnySfSWhwYrKs bRk5cnNHy1PPdXc6NLAdUsmgijXLLKpUnJBIII/T3NeKeJPFr6jL9ngGLNTkDG3eTzk9O3T6Cvcp 1nNpp8y77nNh6PNJyelvlqctJcRPlYrZSVxwM49zz9MfhUySW0jGKRVUqrcvzzx+H0rZuMpXta33 HpWa0TLgikiVnjmXIYndnrgd/TPp9M4xXZeDLyW1luVFwQrqd7Z5YYY9Px9O9c2NUVh5ON9kdWFb +sw5l5fgfOPjv4n3ulLd2tpfyx4coVSTHCk8YB6cD16V8o6z8SfE0kwVr1pEDFgsgye5+vfHeuOe KnQmp03rp6HHiKNOpeLidF4O8e32qarFZyaaXuZCB+6woX65/n9fWvpzwPpHiG51CaWJoo7dggZV 3DdnkDgD0OT7855rox+Ho8QZPWw2Kjbmuk+zWzXo/wADgweKnk2ZUsVSldrp5PRp+tzJ/an8HWek /C+e51fS2fzr2KbTLqOVci8Yp5rSID93yYpE3ADnysjmvzpgkTw14d1HxHOjrcXO7S9OYBgGYqGu XUlSjhImEboSD/pkbDODX4vDL8TlkKmBxXx83Ts0n+Vz9Kq4vDYzG0cfQT5VFN+qvb8bH7r/APBN 7wJp/gn4Ap49jiA1TxhdtceayLuFpZPLbIu4cjNyL9iO6iHP3BX6DrNu3SqcwgduuRxg8f5wfSv5 E46ryxXFmZ1pdKjh/wCAJQX/AKSf13whQhhOGcsow29lGfzn77/GQY5PyfvNxJxyAT79TUg2jcSD kELxjA6da+SZ9Krbk2DgLnkEdjj0/oPypxi8xSuFAPzc44qL21NEyN48hi5GR79OOlYtztBO1QAi YB4+v1rWm9SG7KzZlMSWBIwxxxjPGffiqOjy23h69vLzTrRYXmgkheRYkc7ZUaKQDeMLlGIDDkE5 GCM19DlGYywFSX8srX+Wx62UZusudWlUjzUqnxJP77fI0ZX0m9jgt7eZAVyvzjbk8EcnqeccDoKr TeH4pYk4HTJAwcdOPrX22HxVGtBToT5l26r1R+m4HNMFmFNToVE/LqvkcXeadb2TSBcmcEEgcKcg 5yBnuB2zxXxX8X5dS13xneabOjpb2MptEt2OQHQ7JDwMfMysw74wD0rXKpU8Tns6rd/ZQ09dn+dj wr08ZxFXnF39lBR9G3dnq3wu8IHTNN/tGePE8mI1Bzkjj29zX0Te3Nzpljp2g25O0L5knQ7nYAZ4 45Cn/PX2J1HKtOSfkfR8qUYxOl0zxFF4a0PVdYucCVLZljJbGHbCLjHPUg8c8cV+SninQNQPi3Wb a7nF1qBvJVlnB3edIGO5gwHzZOTmvUy/ErlWG6pOX3u36HBU5Z1XDro/zPtL4UeE10bQLC1ZGWa5 YNJjkhR9M9ucc5r9StD06w8O6LBpNqsQjijXznVhh5Aoycke3HHTFdGSuM8ViMVJ67L53/yLxcXK NOmttz8zP21fiNDrV9oXgnTJs2MZN5NhThyNyJyexJlyOn7uOvkb4eeGf7V1u3jWMklhu+Y8Y7// AK60xldOFSqttR0oNOMWfqX4a8Ls114a0DyQLLToU1O6AH3p3A8pGHTKgZ9wuO9fNX7dl3reqfB/ Vvh3oWoi31zXmVJZA7hktUZWdDjqJP8AVkHjBNbZNS5a1HmV9Y3/AO3Vr+Nz5zi9Vq3D+Z0cPPlq TozhFvo5pxT+V0fFXw38EL8PPBXhrw5E4nayWQzTh8CSR28xzjGdoZsD2Ar0KS8861ml8xQoAV2P PJPO0djjjP8A9avfxS5sTOT7n8T43D/UsRLB3vyWjf8AwRSb/A52RH+2zBJgsYTywc55bnv36133 hTS9HnnlW61N0slZQzJHn5SeSo7n/PtWNdtQfKjjgk6mux699p+EUGuWtutxOLcYUmVTuHUDofcH 8OtejaX4a8O+L7m7tfCd1JJ5cZmk37VESgZ6/wCe/vXlzdSKTndnoRVGT5IPX/gHg2p3Nqks728C kEklm784/r27/jXnGoXI2QsIgFjbGWH32HPTqM5P+cV2UIu7u9jkqqNrvY5GZRdzzJMRI0LAAY4Y csDjBz6A98V4pqd15+u64CwBWZidx449OPQfrX01Ff7K35nzmKl+/wByhdQ5DDy8njbuP3ev614D 8QbM2V5BeR53LyffnPH6/wCTWuG+O3c8/Gx/dOVrWPVPAPie8gTRtX06dob62mSeGRWxseNg6kfQ gH6ivsD/AILP6Na/EH/hmj9qzSrc+X4z8KQw6k6L8ovrYKrhiP4uSOf7p5PWvRye8cRi6X81J/fG cX+TZ5+bJVMNRrL0++x+ZP7KXiT+zvHN/okspFtf2xCgtxvU5Bx9M1+lOlaTfagUt7S3eWdx/Afu 8f559/ev2LhCtzZTy/yzkvlo/wBT4HMbQrSlLayf/B/A9O07wVeafp+pX2s2+BBGZljk4ZuT0Hp3 r0nw3qEd3oWmwu7fZzGMIUzzg19phqMo1Y1pvdNW9LN3/wAj5rM8TTrYVRpLaT19Ue3/AAiuGa81 nTVQIrxLID0wVJGceuDXua2ikYkYA4BIxnca/LONaXss5k1tKMX+h9Xw3PnyuK7N/n/wQZREgTPU YI44HQ1Xkj3qcjjkgYwSfSvjpPW6R9HGKloZY8xXKjJXORgYGenX8qndgoBfg4LdepFNszt72rFk mVQ+WwSAQRnk8evbpXH6v4k0qyk8m6uxuPPy8kc/y5rGUo003J6HVCHMlGKPIPEXxAjRZYLW03DH DMAQxx1NcH/wnmof8+MP/ftv8a4ZY+nd9jpjhVb3jx2CCWO2c3UnmTk7liLnEbHgkgjjGMdMDb+N bktzDDbraSBmfaG+7hh8o5+UcjOQBn/EfvDclG9/n/XyPzq3NFQh8v8AMoxalps06wxWYMEMeC0n ysuPUnrxn8M84JrRu7y1eKBdLiRiwZ5GLYAxztAJyBn259K15ajkpXt0Jj8E4fMit9L0691CB5Iz Nqbs/lCNdyQphsEjqcbueOciuts7I6cbS3ZpRI0XR8KqMTnlSeBz35IPA71VZycYwt5/16mNJypJ 1JbbL8fyLlmv2ue5c2zSTxAoCUKbckc44xzjPToa9J8MeHNY17XbXw7pFpJPqt420JEgwF7u2eAA AxJ7AH1GOStiVhac61XSCV2/JL/hzehRlXrRpR3b0+Z+kngPwPpPwv0+Cz0eIreGSO4ubpSRLcTx gBShGDGFOSoHK5zknJM2rT3Ny8jGFRu+Y4DADnBUd8YGMAdBX4fjMXUx+Lq4qf2m36LovkkkfolG jTw1GFKPRIrvPPJJZRMANyjCIiqAzHAH59T/APqGUVSBHnLmNVx5jH7qjGe5JPTr+NYRi7tNdTRy tY+O/jF8S/CXiJL3SbS3iuoYpPnlWJfn2/KCCR0PX/Ir5cvvCnw/vIXa7shHNI25URtjD72D8p4H P45+lfsuQZNiMFgIKp8TSk9ddfLyPjcfmmEqV2qXTS9jHm+FmkXAt5bC/eJS2STg/T+f06dawZfh NqAknSwuIpVTLqSdpfHHRs9zjP4mvVnhqvvNbGdLF03yre5y194Q8SW6OZtLmaBMszKu5WOOoPf8 q80bxWdL1NreVXiunzHg5y2R3PYYPT2rjxUZQoTT00OzC1oSxELS1ufF/ivULy+1LVCWYobiRSTx 0JP4fSuUs/D1/rWqW1jp8BLSkA56J6knnGPWvKo8+JqQprd2JxElBTm+h9f/AA7+EunaTBaRxhpL 1wXnfChn6dD6ZPQen5/Y3hDwnawxquxVcjacDGQO2eoP/wBavqp06VGkqUPhX9fnf5nzScq9R1pL VnMeN/A158cvGun/AAg02NmjRUjbauVgkdlcsx7hQEGOeSQevHyz8Yv+CbX7XPg9oYr34H6pqXgX TFeG01bRoVuEv2ZzI8ohV2keTLrGdqfdhjHO3cfwTijNcNh85nCrUSbbs3tpolf0P2rhDKo4rBQn i4t03o7bpOzbt1Pev2bfjq3wJ8H+Gvgh8YfDepaM+n/aU006np89nMsM08l06tFMqtw87t04Dj1F fevhL45fCbxWI49H8cWTMVDiFpgsmf8AdPIH4d/Wv5e414YzOOa4vNMNSdSjVk5px1tzO726J31P 654dpYaWS4OGBxCqKnFU7XtJciS96O60aPZtPubO9iD2tyjpuBLI4cAc9SOv/wBY10EdtgENnywu SeMjp/n6V+Y1eaEnGSsz2knFa7kYgw7nbg4xjB4//UcUjfKAETIB5z19OD25/nWd7sE7LczLpmkP lAg9j0yPU8fXv1rJuFwwWDJjXkD09T+ddNPouhnOW5lz88RnLngZJ6Y461nSq38GRnj/AD/OuuHm Yt9yhKgVTjI45Y9un+fxqksksAMcbsq85VWxz/kda7KNSdN80JNPyCFapRk50puLXVOzMm7aZ0mf IZ8Zy+Tk578gnHfkd+nFclp/gjwrqVxYya7eyPqqRxxz3UxG67dVA8xyBjcxGT0GScAV7+S4/wCp 1pS6y0u/62v+R7vDOb08DmE3i5+5UVm3rre6b/H7z6Ju9K8MTLYXHhXTo4LOO1tYFt455J8zxxRR zXGX5AllEkwTLBN+wHaik8ddabNa3Rkw2/oA3UkH349a+wUpJua+F6rqfqWEqwr4anL2qm7K8lpd 21dltd9DyP4reLYbTRZPCtvIra/LbtfBIZBvhiR4o1kkXGdjGaQA8Zdc/wAJFfLvgPwpe69r1vBJ buV3ZJ6jAGScn0Feth5KOHq15aOyt6Wv+bZjTUKlWbg72dn8unyuffPg7QfKkbUGiCwRKsMQ4JAG ASB6jI+ozXpFxq1zHY3ge5cweW2SWPA6c5PH+FcFOrVpx/dPV2282a1d230PzA8dahbeMNWHi+0J EOoKWjVkUOIkkaJCwUnaSsYfk8hgf4q9k+BHhOP7a2oXzolohBZmUthOpyOOOg9t2cHGK9KtUccM qc/T8bE0Jc8FVXVX+8+6NL1NrF5LNxtvJSZrkMvzCV+dhPfYNsYPonTmvzl+Ofiy58X/ABO1tI5Q dO0yQabCCQUcoB5rDHP+sZx/wGvo8jmq2J5bfCn97/4c+T4tlyZTKP8APJL5b/ocBFHJNpkcUUu4 FvmCg/Nyf6DPtVdbO4cSW5t2L8FuCEB5PJ74PPX0OK9StL99N+bP40zpuWa4tv8Anl+bMi702YXE xWRTGMs7BuHbnPXGBnjNXtIlCusiSkowI+Vd53DoAcfpUzalA8iK1NtYkcz3TqHuXk81iAv3f/rY 9+lZyS6pYtfyWFzNFJI207HKBhnABCnJHOefSsFKLT5/xNm9nE3dKudQ+yxweWGK/Lu38txyT6n+ vWsm9tT5M26AD5z8wYHaBkD+fU4/pRSfLNpMU+ZwOMlCpMSqng7SCcqTkA5A7cD8K+fdRldPFWuQ HlxOVxnOeM5Hr1r6agr4Ns+ZxbXt7LqaMjO0YOT5fAwMfMePy9Ov/wBfzjxrp73mmv8AuwZQPmIx 8mPr0OR+v0pUXaafmZ4mPPSlG3Q4/wCHF7GY7vT5ZNrIePVvYfmc1+m/xItR8cv+CXXinQER5/Ev w18S/wBpWxYgslhcglseigswH+5nrXqZd7ubQi/tKcf/AAKErfikeViE6mV+j/LQ/Eb4QTpofxH8 G65fA/Yob+HzucZjLBWGfcHrX9Hen2uhac1ufD1rEIGRG3YycEZzn8RzX6zwG4zp4qlLo4v701+h +W8SSkq1GK2af3pli50z+0ZLqK6Qq0yFRkZB3A/lXnPgKO4tLG4s2bfPa3MkSpnAVR6d+56+hr9J s3yrs/zX/APm5WlhJrzX6ntfge7vrTxZp9yAVicmB+BwGBA6fhX0y4VR82Cc5Hygf/r7ivzLj+lb G4erbeNvuZ9jwlPmwtaHaX5r/gCMUMQB55wMn5vU5PWqph8s4iIxk/Udf/r81+eNn2Mf7pTv7vT7 SOTz51XAAOT+fv8A5615nq/jq2gDR6ZC0ki8biABj2/KsZ1YwWptGi5yv0PLNT8WaxOzM13iMg7Q DkZ6H69Dx9elcPf6h5kpYsTLnkddrY4HtXkV6s6r947KUIxVn1Kuq6FfHSPt39qpG/lcRsMlmPTO efWvO/sOt/8AQQg/74H+FdVPBUuROf6GLxOr0LflaObb/R932453yZypwM9D0yR0HrjtVSO2Zbgg SFixZlJXcGIOc/L2B6ZPGM1+9xTdnJWXY/MlzJON9y1LpkCpHFaqjq43yyHhmIGSF9+x6n86t22h yzRmQx+VICUjxyX78kdAAQeh/CtYyUYudTo/0SKqNW5I3vsdTbLYaDbwxW8yNeyD5p9pyMc8jjjg cc/X02rK4TUZbVZYmZ4yWecpjzmypBIPTkjA61lzubdRdfMc7u1JLRf0/vZ1uiaLq+u3lpZabp4u LmV/3KJj5t3PP49/bPSv0e+G/wAM9N+HGnLNKiy+KLmFftNwrFwo/wCeUQxwuQuScbiuT0AHxPGm Z+ywiwEH79V6/wCFf5v8Ln0fD+CfP9amtI7eb/4C/PyO2mvAzKwZgFBTcw+8R6evHH49qqkl5C4Y NtJPPGAT6fjX5hdptM+utfUokZ/ewyEtkRswHbHGMcDoeRXxP+0D8VJprpvC/hW5YWbN5d9dR5/f ZOGiTnlcZBPfJH1+o4Wyz+0c2p+0TdOn7787PRfN/kzx85xn1PAzlH45e6vmt/kfH0d5cNe3q+as kZByBtPzgA4J7465P9arQ3Zlkm36c0s+35HBXhjkA5PB6dPXFfuTjb3ovp/TPzeEYtNJl1r6ZXYL Ji2gYKwzgupxkkA8+30pUvmtbcPZzsxTCsWIAVOg6fQg03aerHFSptcr2OY1zx7PbWwtbM/vJM7i HOORjr1GOf06V4HDqL3mvWsjxwyRvKGZZY1JA45/Pt64qJ0oOnJTjpa2uv8AW5rCrONeOvVfmdn4 e+AafFzxxeaBo3g2NIZHLzXa5SO1TgGRsZz1OAOpxX6DW3/BPH4R2empHoF/eWt88apJcb9/mEcb iG/PAHU18JnObwyvE0Y4Smue15eSey+Z9LhMBPG0Kvtqj5b2XyZr2v7EWqaCsbaN4hiuoI1CqZY9 jvjpyMjJFed+PvhZ4r+Fvhq+8R67pe3TIpNgeNwTksFRFPcsSBjHr2BNRS4owteMp4hOMl06EvJK 9BrkfMj6y/YD/Z1vhM/xC8S22df1CUzOXTG1WYthR/Dnp3wMj0Nf0M/D7w2LOK1jhjPGApA5z04r +ZuJsY8bmVapurs/orh7BrBZXRpW6K56V8Q/hN8LvG/hV/Avjf4f6RqmhOXlura8sYnWaRwFfccZ bIVQee1fmH8VP+CMH7AHxHN1qFt8Ih4c1MqfKfw3ez6dFC394wwMqyH/AH85/CvHoYvE4WTdCpZd nrF+qZ7VO9NqtSk4T6Si2mvmv+GPwo/bp/YEX9iC18J3fwP/AGqPEE/iXWLiR9O0DXI4pBFYRb1l nzGirGnm7IYy28yFZef3Tmvg3R/2mf2xfAbRQ67ouneI9OTmTyxi4lUdyygqvXsvavs8R4U4TinJ aWbVsN7OtUV709H5O3W+7/M82p4v5plmZSwOJca1Om7OUlaT8uZaaPq0ereG/wDgpDo9rPbWvxT+ Fmt6K5O2a6ggM9tDgdcr87degWvqjwV+1v8As++PvJh8O/Euw+2zjbHbXTfZ53PPAifDDkenp61+ F8S+F/EGRSlUoU/b0V1iveX+KO/3aH6hw/4hcP8AEEY041vZV39idlf/AAvZ/J38ke1WeqaZqFvL dafexTJxkxyBhj6qTn/JqvNy+dxOFGTjt6fnivgFCdOTjUjZrufZykraEEjBQzhjz3BPA9f0FZUs S8/vMAZbtn8v6fWtoaGLdtGUZxkE9Vx27dPrjt/9as1xkGRmAXnA/E8966obIxlK+5lzAD5HzjGB /n8sCsiVcsyLGNg4BH1+tdlMzur3Q9DNYyBreZkmCkF42Kn0PNK/iXxCjLGL92iA+UMobBPQZPOf c9c16+Dx2Iw94wno1s9jrwmaY3Ayvhariu3T7tjz+CxtrXULvU5bJZbm4ZhPJMBJJKjFSV3Ek4Gx cLnAwAOlexeEfFXwx8GaJ4ju71rPT2ubTybi71KNSthCskUzOkj4WF2MQQOGz5bSpjEnHvYDG1K8 nh6k9Zuy9bWS8ulvwPs8j4gw9DBzp4+q4pz53O/mpSu90nbXpZtPQ6PTfE3hDxRaQal4X8TWF3pM y7rd7a7jZXXPJQ5y3JPI+teYfGnx5omg+E/+EX1HXPKn1m7g0xhCyNLDbTOq3MmGPASAyAPg4coe /Hu0sLi8PjI0KtNp+nbVn3Msbg8VgvrOGqqUJLRxaad9tUfOsvhS/wBR1x0MJYFhsVI9qgcfdxxj 0A4/Svs34eeBpdIsLJ7i2G23IubmOWNsFU5KMOD85xFj1b2rSpNVJUqcTpcVCmxmo6pf+EtO1fxZ qLBpbWCW6Kyf8t5uDGhzjO6RkTPbd+NfByeFnEYuhft9skZpHdxuErOdxLbuef8AHuc19DkEpUY1 K3d/5HzXEWGpYzDqjUdtb/cn/mUJomtba0tzIDHg72Hcgn5RgdP/AK3vUH2qQC8eVtkONkYJ5DHu c+1e87VG5Pdu5/EeZzU8xxUoPRzm0/K7KEuFh3tcHL7VUhTtk6bjn6549+taEJdGV3mHD/dUc9++ Onapm7RPOSaaLdy7GK4WGZgr4ACr90Z55+ua0tAtLe9sJn8xQ4IHzZwzDrg98/1/Guee2hvZOWqN 61TTdKe1jdPv8M+TlsZIAz0Gc4/H0rE8QulxDMECgr86JyD054HXp2/M44ilzOogn8NkeehC2xWi BuP9Zn+6frjoPX37d/lTxW11pvxH1e22cSOsi47Aj/62K+swiTwr1PlcwVqydup0kcoCfKclhjjH fHT2461W1O1jkiuY9u7MZU8HAz6cfXj61m1ZikrxPnbT5ZdI8WKhkxHI53dK/XP9ge4sfFPiz4kf BrX5o20bxr4VvtL2yNhZJ4lMkAxjBz8+Onau6FT2WOw1a+04P/yZX/C55cbywVek91f/ADPwE+Js V/4S8ZeI/B8u6KXTL+azfsS8Tsn8xX9BP7Mniu4+IHwa8A+ItitcPaR285DAnMf7s5J6dP8A9XSv 1jgaapZtisM39h/fGS/zPzDiiDVChUXSTT+a/wCAfRjp5l0SzbEjVTxySQDx/n0H4+aaLp8Vl458 T2bggSILmMbSd2Qf8P0r9WUXZ6dY/wCX6nx9Oa9jUT7X/FHpmnOI5Le5Fs+xGV0PAyQf5Yr6Da7t TapLM4UFN+C34/j618L4kUV9XwlePdq/qrn0/Bk1KpiaXdJ/izltZ8baRpaFRKHKr9xeRnBH8/8A 69ed3XxB1HV1eKxTZgH7vXHfp06fyr8ZrYjk92O5+l0aEnrI5qea7nBlnvCX3And6DjjH8qelg93 FuijY4Xd6HIPP4f571xx5p1LN7nZNKMU2zJh8Nm91ALd3XlWpfcyqM/L6cfh+NdbcfDK/sZJL7SN Hka0eRYYJJ0KF2bjjd29T2xyRzW6pQu7K7OV1GpXkzkPEPgvWdPJtLuNzd5y8YVsYI6jjnrXJ/8A CI33/PjL/wB+5P8ACuiMZcq5tznbim7nlVhbNHP5MqyKMlFIHGMZYk+mD14xWl9iuUnkMN3+4Qcp u3euAT9Mcf1r9vjzOKfb56H57KcY2drp/p/VzItUuzd/6DamS4IA5OF6ngewxnHWu0sXvIzFBMpk m+ZpGKttyMkhf0yTnvVz1UYJb/kv89PkWqkVTqVHutPn/Wp0dvaIoDppaCWUeYQfmIOM5J+gz+Gc Vd0q2vprhFt4GeF3CrGEJYsfuj+8TntznP41Mp077bGEIyk0o63/AKR+kvwd+FbeANIl1vxDID4o mALRj5/sA4PlDA2lzgbmyQMEDjJb1R2kheN5JzvJ+cdcjr1BGecD8a/D8+zD+0c0q4mL929o/wCF aL79z9Jy/DPC4WFKW61fr1KV2kkaq5cMAFGApOBjpx+HtzVd5A4XBxlACMqAWJ7c8Y9evT1rzVbq 7nW2rWPiv9ov45XWj+f8PfAt8g1Ro9mpXSPn7N6woRkbzzuIPyjjrnHxXcS3t1DbpqRMqkMWOfmP Qj6ZzX7VwdliwmWfWqitOr7z6NL7K9La/M/P8/xjq4r2MXpDRevX8dPkZSssEZW0xHAZNjAtuLc4 5I4zj+Va9pDfZW4zGkW1lZS3IODgnH+evOTX1c53uv6tpojxbR5btf1/Vi3NO6rD9piSPgM1yF+V wBxgHr/9f8+Uv9as7ENsvoonJOGl+9wD1HqfTn+dFNcmst3/AJmT1jdeR85+IPEFxfTPNHCVgjH7 rZn526bj/ePB/Ou9+C/w68UfFDxlZaNounM8vyNc3Eo/dWSE/fckenQZyf1pY3FU8LhauIqP3Yq/ 9ev6mmGoSrYmnThq20fun8OfhL4b+G2ly6JonE8hV7y425e7kHc46D0UcAYr2C2sJoVnjz8jfLna vyj29+P51+F4nF1MZiJ4qpvJv/gfgfpVKhGlH2UfhRr/AGFkhCuWxkHcTnoeOvuP1r4m8Vm4/aI+ Mml+D9LZpfh7oFwGcqSY7+9HDyHsyxgtGnXneQcNXkZjiPq+EqVV0PVyzD/WMdRovXW79Eftl8Dv h3aeH9J061gtQsaIqgADjjFfefhGyjsIhdmPHlr8o7bj09z61+OYifPUc277n7RTgoUVFdjRuJGk kkZyCckk8jJ/ya8B+Ovxk8MfBvwF4i8deKZXGiabD5jwwyKs97K3EdvCW48yQ/IOCFG5yNqNjoyj AVM1zLD5fRV5VJJffuc+Y4yll2Ar4yq7Rpxb+5afefx5fHn4g/Er47fE7xN8UPG7eZqeoTZWCBma HTbdRthtYM8iKKMBFzknaSSWYk+PR2N2r/vLZxnB2len5/T2696/sXD4NYHC08Jy2UIpeWh/NU8d HGVpV1K7k23fzOw0PwSPEMii7s42sQQzmaFWUt7Bhg8D/PSuk1z9mb4Na/pwXVPAWntctn/SREEk U+oIwFz6ACsK2W4TGQtXppt7P/gi+u16FReyk1Y8jP7Mem6G+Phr8TfEXh8Q/wCqt4NQaW3L4OSY 3OzHX+E/4dNY6f8AtgeD7YtpfxD0XxDbq52x6rbtDKy9h5iEKMdc7P8A6/5nxL4MZFn1OValTUaj vqvdlf1tZ/NXP0Dh7xcz/I5Rw9ebq0l0nrp5Pdfe15Gx/wAND/GzwsWXx38CLua0ULuutFuEnDcD dw+wgZJwACf5V0mkftd/CK8Mdrr1ze6JfOD8urWM1uqcdPMdVQn2BNfzlxJ4OZ/kk5ywkfawXTaX +T+R+9ZB4qcPZ0o068/YVH/N8L/7e6fOx7TofxH8D+KbIXGgeK9PureQhlaK5Qhj7fn/AJ61uSPG 8e6KQY7FT0+h/L8q/Ma2BxWCqOliqThJdGmvzP0KFelXgqlCalFrRp3RTkQFTIV4yTznrnHXt+Xe qTxBUDuMMD35xjp0/D/IqoU9bMiUrbleVSVO3vxk/r+nt3rNlhzvTGUHy8ZGM+p78110479jHnfc hNsiszNEOBnGOntnv06/TjmvGfjr8NNV+JHw61PwtourrZtNMs8reXkSKgYhcfUlh7qp6jFezk+K pYLM8Ni68eaNOSbXozizVVsZlWKy6hPllVi4p9m1Y+DJ/g7pnwT8Y6xomga5JPqel3UtkuqWskkX 2vy3KGWMqQQj7Sy852kd6uanqV5qcz3mp3stzdufmlmkZ2c445PJ6j86/YZ4ueYKOLqK3Mk/RPWx 99w3kVDhnLIZZhZPlSV9Xq7av57n0B4D/aq8c/Dd9Ku00jT9QurCWOW1ku7dJSDGwZN6yK6TL8oB R1KkcMCCc++eFP8AgoJbgXVp4g8OSqbkqZmRhIZNvOdzEtnOTnr16mvFllDjUeIw8tddH5n29LPa CnGGLi72Sum2tH26Pu1vpfRI3vGHx0i+Lun2mhaBo5ttD3i5upZ/9bcbB8keAcbM/Nz1Kqe1cBfs YIi8jqCQcZU5Ofb8cV6uBouhQ5Zb31PL4xzFYHKMZjU/gpya9WrL8bHmV/JNLKhlYC2jBCt90bu2 B17dfcVjzX0zbN9vmM7djE48wDgZ445r0YpaI/iio25vuEs00ToohVthBV9y4UsOo4+orqYYHZSH AdhtEmQSWJGB79u/T8MVnUaUf6+4qnre6LdxpyxPIUxsRQM/3tx+bb0/X396qeG18y7kge52ujHy 4CRwD0yO/A4B61g3eEn1NGrTV+p1l7BbGKXNwftNsDLjGdoAAwMd/wCVedzXSTymWFXEUuHUycLn scen4d6eHj1ZNaXLexgPdLFJcCKTMskZ3FjnaufyNfPvxmsBBrOha9DGwWdDbseB8w6D3r6jB6Yd o+XzG3Nfs0RaGH8pSJQV+8WIxjPbn/PSt57RJCFbngpnGCR359P8RWcpLmbKhFOC6nzN8QLD+ydY FxHI2Vl5O085PvjPevrH4BeO7rwP8Qvhd41hcBLHUbaaRzgAR7gknrxsLD0xW2I96lCot/6Z51GH 77EUu6PnH/gqP8NIfh1+2H8SG0+AR6FrRi12yCfdaO4QMSP+BBq+nv8Agmp4un1f4f8AizwjLcMD pd2JkGeRHLycD6g1+pcLVVDieFtqil/5NHmX6H5xxNS5sum/5ZJ/jb9T9QNKaGS+zChdgmHxg5GQ Mf5//Xk65Fbw+MdJvrl/KhntXtlVTnzHXn5uPfFfuFOD5ZPrp+aPzyOrnFveL/BXOjhiWa2iEUbS AfMuPlBI4P4YzWb4lutVmexEc+IzCEbBOFwcH+n5+1fG+JVC/Dqqx3hOOvrdH0HAdZvOJ0ns4P8A Bo5WGzu5tizgluoGDjnp0z3FdNbaLOgJjwg28naM89R/MV/PTpym1I/YOdJW6mtbaOiBW3guRnJG fXjn6frWraWNxcB4YgQ5OPlGOMc8mtuXayM3U3uT2XhPVZLyWW3g+4wZtwYE4weD9a/Ui9Np8Wvh x4E8C2fw0j0zxRpWmoLu8A+ecxqCWUckZY9euBjjPHpYKMYVWpQvzRa+ba1/Q8+vO8lLseA+IvAk 9raR6h46tI452t9luVUKflJAMnqQceo4Neb/APCO+GP+f2H/AL5X/wCJracFCTU73/q1/MlRc0pW PyviuL6zhuUvLB2uGJAIUsqAn1JxwD39uOMU/Qp00W9FmQXR0LsxwA78kAHrwTjv/Ufs1F8ys16f qfntRJxai9H+Fj02NtJ0AxzWwabWLgEruXCw4bk9Rg/e9cCpn/06CY3MSxELujKvtdsgElj16YGD 68daXNzt1mvJfia1FyqNCO61/r+uha0nTY5Qk8tztkChNpBz24Bzx6k193fBL4Svo1vb+M/Eiu1/ JzZWYiO62DD5ZGH99scA/dHPJb5fl+J8yeBylqLtOr7q9PtP7tPmj2clwirYtSeqhr8+n46n0Mk8 13fma8SRpCDiPdzkD36DA647e1V5yyeQ4AI3BD82Rzj8fWvx63vXPu7vl1KFwyGR4Em3kksVIxzj jjtjnk185/Hn41WfgDSJdD0V0n8UXMQQMfmFiCM7jjo5wcD3zxkZ9nI8unmWYUsLHZu8n2it/wDL 1ZwZji1hMLKrJ67Lzk9F/mfnFiWYveSRTMzAlmYZMrHG4lic8nnP+NMgs57jzM3WeNpRVAOc9vw5 /H6V+/RSjTUU9ErWX6fI/MZPmk5N3fX+vmL9ltBNNmQiSIZ2HAA7nPvjP+RmmWUlp5sccUUkkbsQ 5Y5HLcj8j+NNOMZOy3/r8BN1JRknt/TM/wAU3ts2ZsKXKfdJ2r6hQOOOPpxXgOv3o1MOG2jafnCt 0Hcgjufr3rRX5U2tO/8AX9XMnJxS7m38Kfhl4m+KviS00Dw3YsSQfPupVJis4ieXb39O5K4Ht+43 wm+EXhf4WeHLTw/4dhPnDa11duAZbmXjLMT2xwAOBnFfAcbZm48mWwlv70v0X9eR9Rw7g03LFVF5 L9X+h9AJbmKZn8stjBLMclv8R6n/ABrfRYp18uN+duQrAcnsDge5r85erTex9mo2TTevQ+ef2gvi Tc+FtAtPBnhq9J8ZazmFCuSbS3PEkxxyD/Ch9cnPy8+9fsi/AyDwpounyS22LtwGkJU7s8Hkmvle KMTyYeNCL31foj6zhTCe0xc8S9o6I/XPwXoIt4rdUjyeAOCDXuD7bSBLfoqj5vc1+aSbbbZ+lW2S OT1bVorOCaVnRepJdgqKAMlmY4CqAMknAABPGK/mQ/by/amPx3+ITeGfCWqB/hXoMksFhcRFtmr3 LZEl4wbBKkLsiBAKxjOA0j5/XvCHKfrGcVc1qRvGirL/ABP/ACR+aeJuafVcpp5dB+9Wd3/hj/m7 fcfDVnp11ezQW9vbGSSZgkaAcyMcYAAHXJ4GM5r9Uv2XP2Dhrl3Z+M/jZaeVoiIZodKU5Mpx8vmn nA3EEp37+lfvubY6GEoKP2pq3our/wAj8Ty7CSq1OfaMdf8Agf1sfo9qX7H3wG8T2MMcng2COQFI y1ujRGMbR82VwAOSADz8ua4LxZ/wS7+H+rW1wPC/ja4tIxEzxRuokXdnCqSeeSPyOa+Ww+MxFJ2p zul0e3yPcq4WnOTlazR8z+KP+CSPxz0KG4vvDd/YarbBiERWMcrnA6g9ASeueo6V8s+NP2Kv2mPh 65bX/hDqwhDInm29sZ4yT0CmPJJxz06Gvo8Lm9FJKunB/evX/hzxq+Fqxlz7pnz3qHh/V9JuriHW NKnt9QT93smgeMrjIOAwGPyrl9T8I6PqsEh1PSLa6umOMzWyPx0PUZ79a65rC4tNzipJ/PcIzlSs 4Ox41qP7MXwd1me5vm8JJZ3oG77Rp7tbyJ/wJSCM5J4rDh/Z28R+HUI8E/F7XdP6+XDdzC6RxgcF pQz47cHv+fxufeHuQ53RaqUFd9bf00fW5HxznuRTj9WxD5V0vdP5bfgQfZv2nfDkiR/2joeuWgyQ JY3tpNg6ZO5gTx1wPxqj/wAL78e6EXi8afCG9jCEq0mnzJcRnnqMkEjHovpX4Tn/AIJVsM5Tyybt 2eq/zP2zIvF/DY3lpZnS5X1lH/I2bD9pv4VXLiLVb26026UDcuo2csezPB+ZlwenbrXoOmfE3wBr wDaT4w0+dSSflnX5uvrX5VmHB+eZZJqvh20uq1R+l4TiDKswhGeFxMXfpfX7tzrbW5sbohra8iky OqyBgOevHpV8IgYpxjPfB/z9f6V8/OjOErTVn5noOd/eR84/En4QLrTzanorZvCSzIPXj8PX+lfH mu+GtU0eVobuJlYE4JXB75P8/wDGv1PJMdTx2Bhyv3opJr0P1PLsZDN8AsTT/iQVprrddfmchcLv hkhZc/KScevP5dqzvDGlTanq1vBGMIG/eEjhefTp+de7DSMrihTdfGUacd21/mffHhDRV0rR4twx I4DEjIwMcD26frVPWLpTNFb+a6jJRgpyOeo569cU6UfdTfW7PnPFjH+w4crU4u3takYL0XvP/wBJ KUljaSrBACP9Y3uFwOvTmueu9KO+3uIf3kjEDGNuAD+gGcY70+fufzDKKtdbkT6fKTJgbXVw7IME EdB+P5dfetyO7cwq7W+26G3JYAZ/Aen9PSs5tSSuVH3dBJJ4UkQwvumYDkZA3+noOOcdPxrDMb2+ r+bu2yEDL49scHv/APXqYKyldCcm5bG3fm6jYwwxsd4LSYbGcgk/lXN6o7LLFArHytu7joD6fT8/ pWlF8z5rE1HJxehxiH7Q0xMycgKduMjHr0z2rlviNpZ1XwRetDn7TZulxk9Mcg8+nP8AOvpcE3yN HzmNSlJnnHhNZZIgQNi4CgBhx6H26V2Qjf5D5YcpjPYAE+o59+tc9T+I2TTTdM8W+K+lh7NLjbiT kNg/5x+lQ/Du8+3aPb292chMKw6jr6e/TPWup+9hV6nHH3cwcb7o9u/4KU+HdW8bfBX9mL4/3bLN Lc6fNoF7Mi9Gt2ITcfXAPX2r57/4JseMF0b4z6r4YuZyLPVtOddmfvyxkMP0LflX3fDlZxzXKa8u vs//AJD9D4LiamngsbBLZN/c7/ofvJDBIk7fZQIYjwSTwOOB/n0/PH8d6e4tdGvRMo+y3ac4GMMM Ek/jX9JU4rVeT/I/JaU25rXe/wCKOqia6aC4wyfKq4+ULkYHT8+tdx4B8CRfEGY2sl1HDHb4M80p 4VTg5Az2znGeuK+c48w/1jhXExUbtcr/APJonqcI4j2Wf013Ul+H+aOk8ceBNE07V00vwTI13YQx KZ5CMlpO+e3TB445Ndb8O/gR4x8aal9li0C4lMeHMSQsxwMZ3Drjn9fev5zqUIqo4J3Ssr/mfscq 6Ubvc/UL4cf8EkvHOoap4X13xsPsfh29Pnm3EwSR0wG25x+7yO/OPzr0b4j/ALB3wH+EepXtz4i1 tI97fudPgkLC2UDOCxOWJ75/rXoUMvU4SqzdlZP5a/i3ocyrTqS0dkeI+L/D37Pfh34dSXOj6Wx8 ZR3qBppB9+Lp8g9B973J9BTdU/al8MDQ9G0nUvDdjpF/Z2pWG/iRke/IXOZQDzn0JxkgjOABVKpQ oVoO17rX79GvRJG06TcObf8A4c/OT4u/tDXvj/WbOPUJrdrG3VlBhQJ5nQAlR9M+5PNeS/8ACc6T 7fkP8K5sVN1azl/kSqsoJJHw5HFd3lwYkJESqeCxAY8k9O5xnr6V1Nj4aRJ7fVJGJto8iKPaMuzA DcSfugEnkdcV+zupKENFq38j4LR1Uukdf6+ZYlhe58zy08y6LhWMjgBBn1zwP8ccda7WGzt1InuY lX5uAGy5xzkZ7+/b8qyk7by26DhJzd2ro+rfgb8J7PW5P+E98U2SjR4nL6baur7p3GNsjZH3Ac4H UkE8ADf9cJci8m85YY0sA5WXkjJbIwpzz09T6nrX5DxTj/ruYypfYpe6vX7X46fI+9yrC/V8JB21 lq/0/AkWK2aVxFcqpwduCcE4+bPTHp+H41Q+y/Z2cvdAhipKEHPQkYz3wOvv2r5u97WPUV7a7s8S +L/xS074baFHJEqzeILoN9lhbGUJOPMYDkKM8Z6ngdyPzO13U9U1me61TUJ3+1ys0kjzEF5mI5z+ vp+GBX6rwLlzp4WpmM96j5Y/4U9X85fkfFcS4yMqtPCLXl1fq9vuX5mFNNfgFmkPklfnVsYGBjHT 9M1JEW8yJ0YSLuCgsRwcdQO+Mdfav0Hm6df0PmXGKWn4Gpcwy2dufNQESKGcHGSvv+Xp6exrCvLi 2sYk33gRQcBlOCM88L+gxVuLckl1Xy/q5NOfKr7/ANI8H8RXC3d/Kr6gxkIIjTOd2OmT26fyrV+H Xw41f4j+K7bw54diMs8ihrmVmIS1TIDOxGeO/vXPXrwwWFqV6z0im/u/z09S6dKWKrxp0lqz9qfh H8LvD3wt8NW/hnQYF+1thru6YDzLiTpuPt6DtXu1lE6hQXQ5IJBPHQ//AFjX4bj8XUxuJq4qq9ZN v/JfJH6PhMPGhSjShskjsJmUSbFbjYMY5UcDqfbNcj4z8c6J4E02617Xr4JHGh8uMY8yVuyoCRkn pXHCLd0juqNLU+fPgR4I1v4u/EC/+JPiiA+ZPKPKhwSsCD7ka5/ugDkd8+uT+4/wy8IxadaWUfk4 wBn5f68V+acSYn2+MlFPRaI/UOGsI8NgYX3ev3n1x4f00WkMdyy4GMIPfsaNXuRGkmG5UZJ9K+Vt zOx9L3bPxf8A+CjP7VTaJpmofAnwLqy/2/qFsF8Q3ED82Fk+D9lV8YV5gB5mORGwTP7xgPxl8FeA 9e+JHiXSvC3hrTXmvpGVEOCqQ56s7Y+VQDyc9B61/WnAGV0sj4Vw9Wv7s6vvy+e34WP5v43x8s34 kqwpPmjT9yK81v8Ajc/Y79mr9k3wl8Mkt/EHicJf+MNhRZnXdHZMenlA5GePv9eTX3lpcTwwrFah hE67XJI4GcHj3NcGMx8sfiZVZP3dl5LoLD4eOGpqnFa9fU9u8NpH/pqyKdgi3RIPULjp/LrXsvhd bu40KSQQ7JGkjkYsnNvEGKnJ7MSTjv8Aka0pJJcy8ypO7sz33wzpU5j8yV5GlLQs4J4dFzhSe2OP cmvo3RbN2upGu7OG5LRrNFbYDfZ1ORlieBkYwOtaVp2hq9/wOaSu7mnqnwG+B/jK1mtPFvwn0S+S 5JLLNp0LliepJK5z059vavjb4kf8Ec/2J/iJ9rubDwhe6DeycRtol88KROM8+Wdy9+mOwrx447FY Oo50J2/rqtmZ1MLSqa2s+5+fHxC/4N+rqCK+n+FHxvhYAs0Frrdg26QZyFaWBgAeT8201+bnxO/4 JJ/tp/C/7XcTfCt9b09Af9L0O4jvAADgYiBEvI/2DjvX0mA4opzap4xcvmtvmt18r/I86tgq1JOS 1XkfmZ8SfBnxC8HavLoXifwhqmj6hyrQanYT2soA7bJVVh0z+Oa8Zl0acYWSBvMBOSQcntz/AJ71 9D7Wni17WlNOHRp79zahBQjGzMG98H6dqhFvd6TFcyN1BiUnHfHpUFv+yp8M9SBvvEfhqOEMQ3k2 rGNiTjkkfhnHrXJVyXBY6/1inot31Oh5vicCk6NR8z21/H9Dh9Q/ZE05nZfBvj/WtKYEmKMXTsgP HUE5x0HPv61zV18Fv2ovDHHhL4pQ6hCpysN4ijPPQn/P+HxWc+FmW5nzOlTi77Jqz/8AAkfX5T4n ZrgHGFeo3Ff9vL/P7mcfr/jX9r/4a6d9t8WfDaz1C0XJM9oxwFAPOBk9j26ivmfVP2yNbvvE+jy+ OPBNnH4bS8C31jHGwnaLOHO5iMlQSdvGcbdyk7h+aw8N6WQ5i6s+eMdfdez+fW1z9My7xjx2DhHE YGMPaOylZuzi904+l+9mdD4utLPRddntbSZZLZ1SaIqDxHIA6c9wVKsD6MDXq3wq8IRtNbkp98ef M55O1T90/jgfjXi14um3Du7H9gcN1oYyCzHpyKS/7eR9QTBYIZZCdqIpAG76ce35dq4OSMybyyGM b8MxHB9Tz3J4P1qpJWj5H4/4v4797l+XJ9JzfztFflIZcF5hD5KOoOSG388Yxz2qli4gjjYMTjJC jJ4GAPT6/rzWNlY/F1ZFcfv1kVQwccbmPfHOeOmMflUFxJHCm95Ss7Yc/N74/D2pcrbsxP8AmHzx +ZYmZpE+0R5C7uMKT+p7VzV7LeI1vdoMyIwAwOhwf5DnGewq4W6ol8x1dldyS28FpKuJiAQGIbHf g++R+dYur2kjJj7s+1sk859OnAP1qYO0glaUGzzW7VxPOnlhWGcsRwR3P5468/nWlpcUV/HqujMB +/s5IxlscgAjp9DX0uD+Cx85jdJ7HgnhQNFcT2Up+cSmI9QeCc/l/jXqEcIXzEUAE8NkfeI45x17 /nWNZe+0mPDq9O6Z5944043ej3ZkQMc8cc9OvHbOP64rwX4b3Js73VdNdDu3ZBYdAcemPy/wrpo+ 9h5R7HFXvHG0597n6QeMdEk+K3/BMj4r6EYfO1TwT4hj1i2xkmOCYZfgcjq/Xr36V+L37Mfiv/hC vjx8NNddiIY9Tjil5xlJDsP/AKFX02UVeSll9f8Akk1/4DUb/Jo+Rz6j7SOLpP7UZL70z+pmKIXm wZ2xN+8HGdvfr+NZ3iREutA1izcElULJlT0X5h0/Kv6sw65pKS/r0PwqnKScG97l3SH+16daTsd6 zwocBsYOMck9f8a+3v2DvgnB8ePjQvwrk1WOztp7OS5nnkbIWOIru46H74xyO30PlcVpPhbGWV/d X33X6nRkFV0s8wzX8zW/e6P2r+Hf7D3wX07WvFHhDTxFe6zpyfabi8MihIo1bGSemSc5P4AcV1fh P4p/s3/AH4mfENrfUbJdNj0tbYwIquLiUDJbzPXcWyBjovTGK/AlhI0U038Mopvzun99vuuftSvJ vmPlv40/8FQL/WZNI0Xw/LFFp9l8sb7c52tlT15PAGPfmvyx+I37RPivxJqOoanrniWa5ubmczPL K2SoJzheeB/n3rmxFe8fZw+Ffpf/ADN4JR2PBdb+OV7cXCrJeEpFxk9G6HJ/z2+lef3vjK88TLfT arM32YAhDuJI44I/LHf/AA81tKSTNXUk42i9GeAa9Z3ayMk1/iFip4JO3PuO1YX9lx/9Bdv++pP8 Kls5Za7kGj6fc6h/yEi0FnGgluHCjKrwOpICkhT3z/XZ+0SX9yYrKQn5dkKMeEjA6Y7dv/r9a/aH Juoqd9Fr82fFWjGF11/Jf1+BtafoF1MsUj/fMhYxnODn6fhk+9fSHwi+FKeMdQOpahbFfCunyATl WK+e/BMYYcjqpYg5ClRwWFeZnWMhl+XVsTf3kvd/xPRfc/yO3LMPLEYinScdG9fRf8A+14lMsD2W njyrRRsiKIEVU+6MADCjbwBx1wKWQCVX09FPlkKMgYx0wBxxz155x361+HtyldyestX3P0SK1S7G pb27QKIwgUKpfJGcfLwcH6jnpzXLePfFS+GPD+oeIX0ue9uYo9kVtApeSdiAFBxnAHJLHpyeehuh B169Ohe3NJK72Wu/oOrPkpSrNXsr2/yPy18XnXvFWsXniTxO10t9NLkJIjARLnGxR0UDdgD8+Sa8 4vrGO5umtVkYEsXySADztGW/qK/f8vp0aGFp4bCyVoxS08kl/wAF+Z+WYupUq4mdSrF3bvqi7DYW um25s5GWRmClfmweeARnt6e1RSaXbWkwMM7KQCANu8dPU+npn+VehFw5Lp9r/wCRyuVR1GrfEY7T SSwyKZmcldo3AjJBAxn057V5R4i11I71ba5nUzlOxyFOePqev+TXRF3Sts/zFVvFuLWpyXgr4fa7 8Tdeh8O+Gth1SWQlgrPiJONzsf4VHUn1x1NftD8GvhB4f+EHhi00LS0WbVHUPfXxXD3UmMknPIUE 8L2Hua+D40zD2dOnl8J3cvelZ9Fsvm/yPocgwznKeKlGyWkf1Z7xaZYKTHjJ9+hx1NdRaBSqtgbh kjB6Zr82dro+zppNbHJfEn4p6X8PtOkkn23GqsgENqh+Zm6ZbH3R0r4rtW8VfHPx3Z/2nIzwCQMQ ufLi5ztUHjC9M45P0rsxNP8As7JKuYVVrP3Yen2pL8F948K3js2pYKG0XeX6I/bX4AfCy08N6XYW 0dqBtQDO3n/P51+hfhPRQhtU2hUHU4zgetfhGNqOpVlJ9WfuOEpqnRjFHqN/cxQwpHCMRqNoA/rX wr+15+0rpPwG8A3upwOs3i+7DW+k2nDCWYYy7g/8s0B3N1ydq/xZr0+F8recZ5g8C17spLm/wrV/ gjgz3HrK8nxWNe8Yu3nJ6L8T+enwP8MviF8e/F19rF1PLNPc3JudS1S6JYF3bexJP3mJycepFfsB 8KPhH4T+GGg29poOlqb35TcXRUeZM2MMzN1x14r+nOIcZGnGnlVB6RSvbyWi+SP54y2hKcqmNrLW T0/V/M+htCsBPcSu4+bYREucLGT0z6j/AOvXoenW7wx2lpNIm+STc8kWDsGM8/59+9fOUo3R6bum e7eHdPjjuBcvcnItwwjUffbOAox7dT7V7f4e0e9RLPT7iXfPeut4wY7VhAxsEh9BywXrzXowVlov 6/r8DGWr1Po7w01pq+o3fh8IXcW4KyR8EpHgfKewywyepJFfRPhjTI4IbTdCIomBHlk5Z8cbm79a jGSsuVMxhuz0qyhWMtAoAmRf7vTPPHvzWl9nuUltkg2LaqSXLZLH6fU968GpJcz5v67F8ra900T3 5pBXMdBxPjL4a/Dv4iWMml+PvAuka1prEFoNU06C6QkdDtlVhxX5t/Gj/gjV+xL8Wo7q50fwTc+E tccfJc+G7owwo2c5+yyB4fbAVeD14GOnDYzE4OftMPUafbo/Vbfqc9XDU53cdH5H5R/Fn/gg78V/ AMmoax8HfFmneLNMVWeO2uFFhqPU4UK5aF8LwW81Nx6IK/KH4nfAD4l/CXW7rQfiR4F1LStbDcW9 9ZSwlgOdyFgFkX0ZSR6Gv0vIs/w2PgsPVahV6ro/OL6+m6Pmsfh8RCpzTWnR9DxmTw5LA/n+RtY5 yu0HBHXsMVlappMqnbE3J446evoPavqKcffbijzJVHFpsqW8Nurm3mbzYgAZFZcqTjpz/Ovi349f se+DPi7dXOsR2n9n62WGJ7cKqtk8lhnH40s1yqjnGW1MPJe+k7Pqn0t5M1weMlhcWqt9Lq66M8Ms v2c/Hvin41XHw48NaA9zqkU1x5drG6hEt7SB5pCJJSqrDFBA77nYARx5J4r2Xwzpk2gaL9rk06R7 ieRFCKDu8tmCISDyBlix9F5r+QsZD2eMlQlo4Np+qP8AV7hnkpZDTjF805U6c7L+SSfI+2vLKyNS fXdDu9fTwhc3yHWXtRdiAPhhHuKqxHXGVOPpXN6ta3+lSu9wBLb43Agtzxxn/PX61kpfvXRmrXV0 fz14m4lY3iWtKjK6oqNN+TS5n805Mo2t4hWIOBI+CAVUcY7f0/HNXIxBPCzwuVLksEYjIGMZOfpz UVFZ6o/P1JS1IvsnnK3lRjzyC20gYDD1B7VkT2sl/LE9wFDowX14GDkfqO3Ws4yd2302Bpu6M4iO 1QsZt0LKQuDkrjP/ANbketV9VuIZLOTT4m2zuOrZBIH+f09qpp3TE3ZNJmlbq8UMdtNt8tAu9yTn PP5c/wCFNvBNdboXXMhYjJ7qByc845PrWcH72pbu4Hleu2Y8xJCxEcUmT1y5OeCf8MflVLTpTZax p92kw2l9rlvQ9/y/P1r6XATvGyR81mEWpScf6seY3lg+k+MvEFmgChZ2cMvVc9P1r0Sx8+dY43yc rncw5bHGcAAH19OtLEpKcrCoJ2INe0zNreO77o2TA5wCSD2PTp+dfGli50nx1JGW4lOzJJw2T/8A qrXCNzp1FtocePXJVpS8z9Yv2M75PENj8efgzfNusfFXhO5iVWbhpY1YqQCMZw36V/Oze2934U8W XFuwaO9sL8r8wOVeKT/EV7eWz/2BJP4akvxUGfP5xTtiZp9V+lj+rb4S60nij4e+EPEaz+aLnTre dhnO5igODnrz1+lelRlbhp7SaBSrxnJYdFPGPpX9bZXP2mCw+I/mjF/ekz+eK0eWvOD+y3+ZzHg6 9b+xZdLuJlHkStHyMlSrEY/rXtPwm+Iur/DTxhZeLPDuozW+q/Z5bR5YSU3RyDDD3Bxn8K2zLDfW MoxVCS05Zflf80GEm8Pm1GoulRf+lHosv7W3xStG1iDS/H15a/b4jbXKwzsBMg3YDYPYE/TJ9TXg WteOLxILkXeuPNK7AuxcsX7nnJOP8K/lzEVqvO4N2Sbfz2/Q/eI9zynW/iHqDxCG1QsqnknPB5HB Fcel5rt9IJ7u8PkgA7O/qBXFKeljWK0K9zNBauZ7u7G9jkhj0B6E5/z+dcvrXxC0m3tZIo7slhzh Tnp059aycralxje9jxbWviZqdzD5en2smMELkEtjJxnPPua5D/hNfF3/ADyk/L/69PmS0tcz91aM +o7qQMG0nTY3c7908hRVRWz0AGeOwxnPbvW3p1oIblPLtkVlCqhYAkjvzzgnHQf/AF6/Z6KVubu3 6Hws5RbUU9El8+n/AAfme6fDvwVd+N9ag0uCR4bdcNdTxnaI14wF4PzHkAdjk8AGv0E0rQ9JsNPh 0zw9AkOn24WGOMNnbwDkZYlmYhizE9SSTyK/OuNswdSvTwNN6QXNL1e33LX5n2WQ4XkoSxFvi0+S 3+9/kaFtpDvcri5AIIkYkD5z6j1AH8ulWCz7HeaRdgAyN3zAflnv+WQK+Dbbirs+iSinoTGBpYrc 3cTNO6EL83XHb27/AOc1aS3t4I98ihXLAMuR8rd8jtQlytW1KVpJ3Zk3en6ZdTxRXFnEWbDFWjUg HnqeccYrltQ+HfgO9FxPe+HLKSNuAxtwC4XPOQBgZyPU969DD4rE0J89Cq4ejOOrQoVFy1IKS80c JefAP4a3MRux4YhSST52ZCRu9O/v+lcde/sz/Du+MkrTT2+wfdSTluuevf2r6DC8S5th3yurzL+9 qeVVybL6l37Oz8jybWv2Q9IcO1l4lmjEvzRxvGCFB45x6AeteLa7+w/rs0jXmkeKbMyciNXhKt35 JOcd+favosPxtVjZVaC+R5Ffh6L/AIc7+p9Q/Bn4A6P8I/DzWVsBP4gnVXv78r+8nf8Auj0Udh+P U17zZ6RKS2+Ji244ODyT/Tg18lmONqZhjauMlvJ6eS6L5Hu4LDQw1GGHWy/r8zpIdLljjSPaSepx wR+vpXlHxQ+J0Xg62k07S40l8SsAscKniAY6tg/pSyzAVMyxlPCw67vsluzbGYpYTDyqvdbLu+h8 M6xH4i1bWpLvWNQabWbx2IzlmQcfN7DnAHrX6gfspfBQaTY22o3dpi7lAJJXle4GfX+def4mZhCn Up5ZQdoUoqP4a/pc93w/wM6znj62rk73P188D+GI7S3hVYsHaOg5BHvX0Rp9obOFWYYcjPrgV+G1 J80j9kjZKx578T/iFoXgHwzrPifxBfLBpVpC00zk9FA6AdyTgADkkgV+BOsaL45/a2+KV98R/GMU tp4GWUQaXaSscrbKxKooPAycszfxMSRxiv17www0MFDGcQVY6xSp0/8AFLd/JWPzLxExc6qwuT03 pK85/wCFaL73f7j698K6fonhW2g0XQ9LEFnAfLRI0AEhwOT69K9x8Os1xbXC3UQCyIEG44VGJ+Un HXAzxx1r7NOdWtzz1k3qfCcy5LRVkjo/DM17IY4lTbbLuW4LfxnccEY7Yr1XR7NbjUEWOE+TK4LE kcegA7Dr+ddkIxWkdv6uZJya5me0aDDdw3ELQQE3EhIiKDdhemTjpx+NfT3hLTxBDaR7POknuQqy N8zBUPOewzzxXbHrf1MpPyPo7wLbmMrdW0YSRLho33Y/doDk8D1PP5V9A+HrH7PevHIuY9pkBI+8 Scn6V5+Nkkpd7Ep6o7iJFVd+zDnk565NS14Td2dEFZCUUigooAK5zxV4P8KeOdEvvDfjLw5Y6poN yhjntL+2jnilU9irgimm01JbomcI1IuE1dM/KT45f8EcP2fPiDHfX/wu1O98Kau/zrabnvdPZ8kn KSv5ybuB8su1eyGvwq/aN/4J1ftEfAi21HU/E3gGafwfAxxrOmMt1ZlRj53aLLwLlsDzljyeADX6 Jw7xQpSWEzKXvOyjPv5S6J+ez9d/lcyyudFe0o3cfxR+cus6Tf6ZI4EAD5wo2YHOP6VV0vRtTjcX upbYosERqTguPp71+i05Td1S3aPC/dqSlW1Sd/8AgHmfja+0q3u7nWF2W9+Ekt/MiykskUiNHIpK kEqyO6MOjKxB4Jr8v/jt8XvjT8OpNR1PStCs73w28mIroQuDBwANwHXpxyO9flXG3BGAxCqZvhYW rX5qluvd2/F+p/RvAXjrxfw9gKWVT5K9GlFQp861UV8Kclq1G9l5H5tRfHP4iW/jy/8AiGusMfEl ypV5SoKrGOiAfwqBwB/+uv0r/Z8/aJ034saYfDviPZF4ljQIwY8Tj+8B6njOPWvx/O8BCOH+tUNJ QS+5GOUcR4vMs1xH9pS5pYmc5t/35Pmf/A7Hs2r6PLpUjSQnNoeg78j/APVWNBrZYlo4R5iDDbuT nOcA/T+leImsRTVRPXqe1OLw9Vw6dDbguG8hhINsjHczNnkDHHUVnXbwsQzkgbc8j5mGc5/z1rnV 1sbdEmYpEYdZE4cnIB7L6/X/AArB1JJri6iKod6khNmehOBn/wCvVwdpXZnO9rI6bS5j5EbKgLn5 ckjJ45P8q0NsoDzxW4V1UKXABJ9fbnGO/XisnZTtc1W1zy7XJWiuGRUJjJwxPA6+v6456+9c5cfu Qsc7LvyQVUknvjGQD/8Ar9697ASsrM8HHpO5yviRj/wkmnXRYDzrdfMBGSGXgj1/CuzsfLMG9eCR hh1wOmB6c+nvWuKiud9Ec+EfuaDNREl5byQgAKiZCjvknkY9ent/L4o8dWv9m+Kbe6CMqNLuB5wo JH+JrbB25pLujjzX3qaqNbNH3x+yF4yj8K/HP4Y61cTgWU18LW45O0xyr5ZB/E+31r84/wBvf4fx fDP9rT4y+HbeIJYf2vJdwBRgFJsSAj2yx/yK9jKuV4XEw6xlB/epJ/kjxs3Xv05Psfsp/wAE+/GK +JP2bfDUBkElzYtJZOzsSVKMQP8Ax3H519t22FuZEhCthTk9dxA//VX9V8K1PbcPYCp/07jf5afo fzpm0PZ5pi4W2nL83Y4PS0hh1nxDFJCuBOJAgz0cA/5/lXT3Uqwtby/dY427BgYPvjn/AOt9K+ll FSjVpy63OGrJLEKp6P8AI8J1P+0/7avI8kW6yNtwOgJOPp26f0pJZrWBWS9kGG5YMc5/E+tfyRmM OTHYil/LOS+5s/oOjaVKnJLdJ/ejnL7xpomnp5cb+YcgEDHGPT3/APrcVwGr+N9U1F2XSrNltyeC Rz/TPUfpXA7J6vU3t3KEPhjxHq4ae7vnQPjIOTj29vTt1qWx+HlnbbmunaRt2QWJwfy/CspXkyov qzcvPD2nwbzHEAcDdgEY9x/nvWZ/ZVh6H8m/wqox5kZyunoe2WGg6jayRyzadNG0jblQRvzz0PHX pgDOMDJrvPDfgzXvEviDT9E0PRJJdWmbaAVY7VwdxJP3QBya/Wama4OjRlUdVWS79t7a/cfIYTLq 8qns5xd/6+R+gPhLwRpXhLQ7XQNCaJn4N1cSgAu55dzzgjpgDIAxzySfQY4X08B9QSNGMTSBVXbk biDtx8pOdykDIBXGQARX43jcTUxeIq4qrvNt/wCS+S0P0HDwp0KcaNPaKsUTrMlyjyiPYRtVYlXa Spy3HHT5gOPy64lN7eyLLcumFAyDtHyEkjJ656ED1x7VzqLNdm+xLDqixxTMFPnKw2sQMoW7jPf/ AOvWZd6m/wBpnhuIsMvyNjkc9Px9RWiitEhJ33LA1CeFlkaI/aZCckgYPcAj61cS5adGWeZUnU5Y MPlbHtjj6CtYRTsZzdldkL3QVgoJIUjBB9O4+p/lWdeS+V5YfacglyueT1Gef0rSMdb3IlJct2Yb SNKImUlixKt68YIHoB7VIBGdzeWDGRgg9e3P/wBf3rdXt5nM9XoadnCz+UwOQAdyjnkd/fNbsRSL O8EqeMY68/55p3voaQXKtTyX4m/E+Dw5A2l6Kyy6oWAldTkW4P6buOlfKs+p2hgudb1QeZMxMhZh uZye3uTwB7kCv0bh/DLLMsrZjXXvNc2v8qWn3ny2aV3jMVDC0ndJ2/7ee/3f5nqf7P8A8M9R8deJ j4l1a1yhf5UIyq44VQPRR39cmv28+FngeLTbS0CwYwBzjFfzlxXmMsfmNWrJ7tn73wrgFg8vpQt0 R9h+GdJihjSSRf3ScAe/atjV9UjtoHlZgI1U/WvkLc0krH1baS16H5cftB6tL8YPEkGhXV0R4E02 4DtbKeNQuVPVznlE5AXoWJPYVh2MVtDBbwQRBbZFKhVGBjnFfu2VUPqWU4XAJfCuZ/4pat/LY/EM 7xX17NcRintflX+GOi/V/M3rK2RFSYY2A5BL8n1rtrWTzNNnsYwV2fvOufMYDGM+gyfzr16d01Js 8aW1jr9EuoHsraW4k2SiMhuwLnpx1Neq+C7V1by5pBcTsxCSA9CeScdgOa76VtEloZ23uz6E0R4L C403SrRitzDkGcHPmOeoJ9OSBX0x4QimiNvZeV5N5HJ5gfOFKt7+pJ/Wu6mkoa7Ixk7M+ovD2m3F m/kKAskcsTSrH1fIByT6V7zpk6Twi4RWC8j5lxnBxnnryK8fH2lqiYt9TYyFBJ6etHavJOhPoJQa CgooAKKACmsqOrJIgZCMEMMgigTSasz8V/8Agp1+x3+ypofwL8e/HC20Kw8MfEnT4kn082DiCDWZ 9wX7MbMHy2Zw7NvjRXBAZmKhgf4v/GHxE1uS7mWC3aBUyuHbPqMgf4AV+p8LZljp5ZJ125csrRb7 JLRvrbvv0PmMVgcP9c9nT23av1f/AAx4ghvPEms2kF9qJQSzBZJ5CSkSk4LHB7dcetbnj/w/4Ca5 m8M6bN/aehiPypZHXiVjxkfj/nivoqFWdfEyozjzRkndvq+x3KjSpYZ1U7STSS8ur+R+RX7R/wCz NeeCbm68V+EYDN4YfMkkagk22T/KvjjQvE154Z1az1jSrl4r2GRZFKsRyMHB9uMfia/G+IsolluP q4SS9yWsf8L/AMtj1sHir8lanL3otfJo/a34HfFzSvjH4MhuVlQaxGnl3cJwWjfjkD0JJo8Q6XPo 12b2zGBuDEEn68fl1r8npQlhcXVwtRddP0P16dWOMwFDG01uk/w1RZ0zWHuCATuwu85PT2759frW 9IUmRi5I4yQeDtxnuPSs6sXGo2mEJKcbsoAn5VVNqByd2cAgDv8ATpVN/LngnbySqliwYE/LgDqS epzj/GpSld6ld9Sjp2UuPJT5mEeSOmB+XHeungETPuLMfm2kZxk5JHB9OPzqZqzuhxWljhvGEUqB d0YCnlSuSw7dh25NebS3Ybc0rr5SEEFTncMD/DtXq4NqyseVjorm1OT1y583+z51jwUc9eQd2Dx7 5HYmu/0j7NLAsgB6gk85Pc57AZ/XB9q78WrST8jzcI047mvdQoIpxAmGKkAk5PfIHf1x/Tv8c/GS 08qRZ1B3burMeOc/4U8FdVUjPM43wzb6Hpvwcv3a107WrFCbywlhu9w4IKOGHPb/APXV3/grdpEG sfGX4ffFPS7cLp3ifw5a3SOFwJHQYY57nBH6V6+UySnjaL35U/ukl/7ceNmkObDYeoux6j/wSq8V rc+GPHfgidx/ot6l2g5BxIuPw5U5PvX7D2TafF+9kjYhcgKvbJ/T0/Ov6j4Cqqpwvg32Ul902fzz xHGNPPMVGW3Nf74pnG6vFYW/iiOSyDqt3ZYbcerqTz9cH+vbmWQ+XZWwmuE3g4fLD5fpz/nJr7SP NzS5l/VkeLi3D2kXTvayseD/ABIvfFX9szWugWJ8kxq/nk9yBnp/X29K87tvCPiLUJFk1adggzkE k9/T8vyr+UuJKaoZ5jqUVtUl+Lv+p+85XW9rluGn3hH8kdbb/D/TrWND5Ad85OTz0wOv4046NZ2w VI4UWM/IT90gfU/WvAa0O++mhoKibSqtwAq8kc/j68dar3UWbZo2cBgcAD/P6UmWnZ3MCfy5A8WQ XZeAf/r4zxVD+zW/55R/kv8AjU6R0bKvHqfs9pVvp8Vw01zpEJ1Y2pZYjgtbqy5jfthuRtGBjKnB 6VoxnSNHtb3yLZJNVnCiWdlBklJO4kYGcZOc5ycdea4rtWtt/VzuiopXS1G+frE+oW97NA4dpcRI qLEY8DIO0YXnLHAwBhRmq17qep/6YdXllubw4toXmlLGOJc4C+gyRgDgfnUSd7LojSKitVvYzZ9Q 1CWNJfJjxIq7cnPTcu7v33AdvQVZe8Zvs6LKqqFSIIpJ37c4JA68k9eTVxT1G2raErkyXTs87LNy 0vruB4B7E/yFMTYJyZBlQQFHQdSScnqcZ/yKpepHe25ueTEYoZ41dmYfe9G9c/56AUs372ZESFgk nUv1J6cn/PU1ouqb6k76LoVbiZQv7s/OrAuCB8x4H4dKwLzyZndFYeUGGOTye/8An0renu7GM5Xt oRoqjgsQmcgZz9DirdrFI7STHBHAA7g88Vo7WZmrye+h1MK+UfkTGOh7c+5rwz4i/FNNNibQvDcg Oo4Inuc8RDGCF9+OtevkWXPMsfGk/gXvS9F/nsc2PxUcLhZS6vRev9angSxPfx/aZbwPOZMk/wDP Qn1z9fSvS/GHwM1/Rtf+HnhrWLuFtc1DTINZu9OhO+XSopyWthc44SV4dkwj+8qzJuw2QPquO8zh leTLDw0dV8q6aRV38tEvmeXwrgZY/NYuW0Xf5v8A4Y/UP4DfCu10HS7KKK2CIFXp3/Kv0F8J6CI4 oAF+Qd/8/jX8q42s6taU273Z/SmEpqnRjGO1j1CSZbeFVUgRqO9fI3x2+JTWkMnhvSrjF/KP3ro3 +qTvz0B7fnXfw7gvr2a0qdrxj7z9Fr+OxwZ9jPqOV1qkXq1Zer0/4J8cWzqp85wSudoPq3X8etWQ xEoZ1bDE/KPSv2daH4pPdnRuX8mJYE/fbQUwPlHPNdbpsjIggll2yov3u2Sff6H8q66T0Whk9Wdx pCQyXUUxKSgKDtPQn6Yr2HSJ3eWMhBE5U+YIzgL06fnXdRau9DN6HtnhuW2uILVfKDPG6lWzkkkH JPrX1J4R1qKfS9PtdQyYZJPJV3OGBGBn6YWvRhF6pM55tO6Z9Y+FrieWa7nmRvs8qD5t2XkVRjPt 0FexafJd3Nvp5hXcgi2v82Nv+NeRjFFO/QlXeh0cEEkKyeZKZCecEDC+wp8InCH7SVMmTjYCAB+N eQ3F3aR0RjKLS6dSSipNAooAKKAPMPif8aPhX8GNHbXfih460/RrDYzxi7nUS3AXGRFCMySnkcIp 61+IX7R//BayOytdR0T9nzwW0VwGMS63rKq7jnG6K1UlQehBdnGDylfV8OcM1s5n7ev7tBdesvJf q/uPFzPNY4V+wo61H9y/4Pkfg98dv2kfjD+0Prba98TvHF5qeoDKRi4mIhtk6lYolwkQ7lUUDP51 8keJPBmn6/Zv5gVboD7wxnkDt35r9kw+WYWlhFg6MLQS0t0/r8T5D65OFaNaTbd7s+YPE9pL4Zmn 06OIqMcy4OZe47fjgelcVbPibMrYwu3PTI4HTt0//VXmUaKo1eWT+Hf5H0k66rUk4PQ19OsbPWZb jQ7+JLiyuQySo4yGU9c/hX5H/tf/ALM198F/FL65olnK/gq/ffFIqnbbsf4Ceg+lfLcY4Knjculi oa1MPbXvCTs/udvxN8JN0cRDmfu1Lr5rX8jyD4BfFG++FPjWy1MyEaRMfJvEzwyHvjpxnvX7Oi/s vGOhW2r6cA0M8QdPmzwR146/nx+Ffztn9F0cVSxiWj0fqj9d4VxPt8HVwMnrHVej/wCCeN4m0a9l hmOUB2qc9B1/yK62xv0nh3bxGCdoDZzjHHPQckf5HHFWSklNHp0m4NwfQ2ZJLZrdXdj5RBKgH72B 1BP+eTQo82IbTmMnhcdx1JH5VyNtb7HWmnp3MK6uIrNlughKsQud2NxHH5fn+NdLbxW0gjuSCs4U naW7nqOOvPp9Kc21FMKepjatayySyTqcfu/lQnPzHjpn/OfxrxC+mgS/lj2gw78bQRxyOf6f0rvw Ls7Lsedj4pRuc/rwTzF8pMx8HcT0C/Xqf/rV1/hu6jW1G7a27lu+09wPQ9/xr1MQrxpyfVfkeThr KrNLZM3728eIuqHLDHOP84r5x+K1gklheysQ747k8c/lUYVtVosMaubDzRV/Z+1VIdP1a1Zm4DRk fXp7jpmvp3/gobo8Hi39i/8AZc+IFmN99pMk2jXbAglAMhenQEr3/rXrZV7uaYmD605/pL9Dxce+ bKsNbo2fJX/BMrxfHoPxu1XQrhj5Wp6awA3Y+eM5GPfDGv6BpLziKFSUU4OSOT2+uRzX9LeGdVVO HOT+SpNffZ/qfz/xhT5c8nJ/aUX+Fv0OZ8SIlvdaLdwuWnjnMbITwyuP/rVdms4FtvOZixkYggHo OvPf/wDVX6TD4ku6/wAz5Wq7xg2aNjbWt7Yq88Kh1OzOM5x7HpxXF6lYwQXU2xMKCQOQQTn0I9Qa /l3jWl7DibHw7yv96TP3Lhup7XJMHP8AuJfdoY80lvEm5AWyCQD78Dr16VzV7BFIskh+44O0+hx1 r5N6aI921tiNYwigI+0DAI2n/Pp79ax3ilhuF3Mpk3hgG6fh65pXtoGq1EvLC2nvPPtw27gvtHGf /wBf86X+zz/ck/z+FddDL8ZiY+0oUZSXdJnPVxuFoy5KtVRfm0fq3b6zZw2VyZ5Ej1Pyy8ixQ7hJ gn/W88YxgLzkkdMZO1aeZNax3kkcZjnJlghRFVYJHHQsx528EL1yM5JHHz7d25HvL3YtWGEX8MDS JC8lzFE7XEjSB/LLMR5mc579SepXjmqV8jafpFm0qzJdL1EiD96W+9luqnnpxx9ealoik76FxbaK G2tATKXih+YHpL1xtPoMYPpg1BHFEz27gOtsqexY/TBHX3P4U03d3E0XorbZDDHGCF3bnJHMfu34 Z7fzpHjjXEoG4hiokPKnHqP89qtau6En0JYrpxFwxaPO8qTjkNjP17U5b9FY7FIZlKk+3citItt3 JkrI5+5uyE8uBizORwR0Ge/Tk/4fSstZkRsSAggnIHT8Py5rojdvQ5pWUtC1CzP5Mcf3xyFyPUY/ z710sMbyDEhxjktnGcY5PpVS7Dgkmkx95dtGgSOI7f4v8/19q5q78G6DqTsbjQYcEknaME84PPX2 5/8Ar1vhMXicJU9phqji/IValQrQ5KsE12O48JeAPAHgHSL744eK/C8c/hvQL1IdM0yZQYvEWtMj SWtmQ3yyRJhbi5GGxEqoV/fqa6r4LeC/EHjDxBq/xD8b3ct94v1e7kv7+7l+9JLI244z0AGAB0AA Ar5Ti7N8TjJKGIquThGyv56v9D6vhHLqUa0q9ONl6f10P068E+GY7W3hRY8LgZHc/wCPWvoLTbNL WBIzjgZJ/pX5hUbctD9TjdLQ8v8Aip8QLLwho91OZFFww2QpnlmPtX5x61qlxrN7c6nqEzNNI5dj knPpj0HTiv0jgvBKGGq42a1lovRf8E/O+NMZz1aOAi9vefr0/C5kwTrv5OCOCfX/AB9K2IZI2kWf OAvA54J619wmfByV2bkcmfs5PKNkdef8/wCNbtq2GkdpCQz4KHPyr0AB/Wumm7NKxg1e6Z3ei3Vv C0a7GXBG1gSM7T0/SvQ9M1Vbq3mw+Gdh1b5lx16f54r0aDik+5nNXdke3+Fb+OLUIpII9tqFBbBI Cnnj8q+mfBmoQT634VfW4POsFTCxxHGxccMffpmvTp7NLT+kctQ+ovAEt/pfiK5D3U8unPGWUNgp Dubhc/SvrfQUijjKxS7lPzkehNeXmqtt2VxUbtJt6nQZpK8E7AooAKKAPAPjr+078Gf2c9HXVfib 4sit7p8eRp1via8uAc8rCDkLwfnbavGM54r8T/2i/wDgsp4r1mO/0L4A+FDoumFdn9saksc18+e8 cQJhi+p8w45BU19jw5wvVzOUMXily0L/ADl/wDwczzaNDmw9B+91fb08/wAj8UPiJ8Z/iN8UtVud X8c+LL/VNYmwWuL+4eWTaM8bmJwBnAA49BXjF/LGkUUt0zNIBtA3YGT+Pp/Kv1+hSo0KcKFGHLGP ReR8pUnKXvSlqzj57oSPKttH+5Z8E5PGeuPWq96jwENHI7BlAIGTnPuf88n6V30Vyu99P6/4Y46z 15UjsvBv7LnxN/aRn/4R74ZfDTU9X1IssZltLZjHCx6eZMcRp0P3mGQDjpWZ8f8A/gl/+0j+zamk X3xV8NeRpN4MC6tpfPiibI+R2XhW5I7jI9xn5zMs0y+WawwNKqvayXvW2T6Xfd9unU9LL6lejg5z cXaL0fT+uhwPhb4W+HfClqb+aBJtTOI1Mh+7kckDP19Kzfi98LfDXxY+Huo+BdWgSSO6VhG5xiB8 cEe4PtXesBRnQxFGrqqseV/PQ5Z46vOpRlf4Hc/mB+Nvwf8AEnwT8e6v4N8Q25WSGTME2DiaPJ2k H6dfSvpL9lf45XOmtB4J1+b/AETzAlsXbqOy/hX8x8RZZOCxOCqL36ba+aP2HhrMVRxdDERfu1LJ /M+3PEOnpcTRNCheCU5ynBJ5xg8+35V59FNJa3b2FzyUJK54XjP/ANf9a+Lw0lUopX1R+hYuPsq/ Mtmd9ZTWTJbyPcZkIJI5OQR04+v61Ya5jLG3AAXAx7n361zuMr6mqfuqxgX0uU8kSjZkAFj938Qf X60/QNWa4LW/ymbfsK5xhcADpnrk/wCeKqSXI7rYnmtOzOg1DDStCGxvAQk5+XqDzXiHiuxW1uZ0 RMIMDdjqevT171vgptTSOTHxjKlJrY4TUg8li0WMSFcliBnIz/h1Fb/hSVlWLOWj2HLZ/H9f5V7l ezpRv3Z4dG/tpKJ1DOu9tyny8YwMtg15t8Q7TztLuYOxXd15Hcc9v65rCjpVib4j3qMk/M8I+D91 NZa9q+mFsK43BO5OcD/GvuXxkP8AhNv2KPjf4EuUMt7o95Drlim0nyoyf3hBx0yCe+cj8fVwslDN 6bWnMmvvi1+Z4tRe0yjb4Wz8qf2UPE7eE/2gPhvqQOEe/W2c5P3ZMp/Miv6jvMEiW0gbdu4yTgfo Bx2/yK/obwqxCeXY2g3pGcX98f8A7U/CuOIcuZUKvRw/KTMPxXYxx6bcXZXLJKsqnumDk8dutTWN 2ksbrsJtWXfycEY569h9K/W4K7jp0/X/AIJ8PWk3RXqzd0kw3Qu/LbI3BcA8cD9O9c1rSTGRo0Qk gDJbHP8Ah0r+b/EekqXFGIlbSUYv8Lfofs3Bs3UyCgm9nJfizmJogjZMWMd8jk8/n2/z0xpfOYSK +ScY644/w/wr4OMZSaildvsfTt8qvJ6ANOmZPLI2h+QSAc8Z7/Sq5shFGZGBZue+T36c9ev4Yr9N 4W8PsTj5RxebJwpaNR6y669kfF51xZSwvNh8BaU+r6ItIk8sY27Y0AJBIxuGOOPw/Gotlx/z8r/3 7P8AjX7bQyrC4KjHD4akowS0Vv8AI/NcRisTiarq1al2+7P0amvGhXzTBaEPI7IqRhjJuJ+/s+8e nQhR0GOc9DDAgjmZhGXuYkVlk27kYcnBUYQYUZwOcYr+Lkktj+lb6OxZupJYn0yF7BRp0EZLwwu3 POSWYfNww68YOcVRj1Wxk8tL63eeJPmWJpPkBcDLtg8npx79jV3XUpXa00CdlMqPNcDymjIijIbE SY4B6ep59fXrVmxhllvJDM3luV+VVGPnH3efTn/Gqj0ZLd9GXrySOJA0M3+khcSszE7x0CjI6cdq je6RoyjuocEbSoIAU9T7kk/pirTjqmhJPcddXJ8wqrKP3YJAG4jsB7E1j6nd2bTsRKcgbdwXH4fn xW0EnqiJy5Vrqc/dyyM+x3ZsL2U8DqM+hOB+VIj4KNGMytjDYJ2jnJ69Oelap9mc2rdmdBYxTs8Z DcbhyB06ZroZGe0iMkkoz1788dfWpeuqN4RskV7BFuYpZJhyeDjrjnFek+CfC1z4q1q00O1miiaX PmXVw5SGxgQF5riZ8ErFFGryOQCdqNgE4FNtQg5N6JFcrcuVIw9f1Sz+OHxC0TTPCkbr8G/Cyvp3 hpJIysl/ubdc6hOCSTNcyjzCMgIgijAAjAr9Cfhh4Lh020tY0gwAoHT/AD61+W5ziJVqzb3ev330 +W3yP1LhzCewwkW1q9T6u0GwW3SN2QBwuOOgNW/EGvWuk2VzdTyBY0UszMcAAZrwacJVaijHdux9 NOShBzb0SufmR8UvGV7428QS3plb+zIJNsKA8MPXPvxXGySW5t1kSRtwBAJ6Aciv3DKsKsFg6OGW nKtfXr+LZ+IZri3jcbVxN/ienpsvwMq3Zts0kbr5anJLGty2nE0JeeL94GDAr3r0bK255klzdC4b kK0JAJXAPyn7rf4VtQX0hihZmwCOueeO2K0jJpky0jrub2m6oq3Ef3iBg7STx616Hpt2kUlsXkfZ KWMQC9fy6ivQoRUtnsc85KOsj6D8L3f2y2ubZUCxyKEUO2Gz/ER+XSvdvBGprCLW2nvB58WVAIGS hOBn869iHwxe366nNPdn3T8N9XyUtbhVfTQfnkX+IJzz6YLf56V9JeEI7YSXmt2l1I5umUbJGJWJ B0Cjt6152YRaUrbOyZmr8y11Wp6WR+VNr507wooA+e/jd+1N8C/2etPmuvid49tLXURH5kelwOJ7 6cc42wJlgDggO21cjlhX4P8A7R3/AAWU8e+MDqfhv4H6WPDWgNmMalLsm1G4QjGVJBjgzk/dDMMA hxX2nDXDFTMJxxmMi1RWy/m/4H5ng5pmapxlRw8ter7eS8/PofjN4x+J/ivxjql/rfifXri81WVz JPdXk7yySse7M5JJ/GuDn1nzo2MVyS23JUEYNfr9Gl7OEaUFZLRWXQ+RnUikpHKzapdytJ5WQAPl 5+/+faq5hmdVlnctEx+7nJJ/yfSuhLokjOTck5PY+5f2av8AgnD+03+0xPHqvhrwcNJ8Fkjfq+uM 9tC4JHMSbTJNxzkLtP8AeBxX7z/s9/8ABF34CfD23s9Y+NF/L4w8UiMA27r5GnQv3KwglpO4+diO c4zgj834l4ydL2mX5VL3tpT7d1H8nL7u57GXZRUxUo4iuuWC/E/V/wAHeAPh38K9Gg0TwL4TsdJ0 iLhYLG2SNePXaMn6msr4ufDzwl8XPh14g8E+MNJgu9M1G2aAJOitsdh8rLnoQea/OKVWssRDFSbc uZO/zuz6mVGh9Xlh4x921j+Mn9tD9kXxj+zJ8QdS0vU7N5fBkkm6w1JUOyRWyQmTzkZA+or40stJ s7uOSS3VllVSc4wM9ck96/oDLsXTx+Ap14PdbH5viKU6GIlTktnY/O/9vb4DL8WvA83inSLAN4x0 qMuHRRmeMfeB/D/PNfzy2Oo3fh3WYblP3d5bS8gg5ypwcg1+TeIOW+wzKGMS92vH/wAmj7r/AAsz 7vh3GKph/Zp+9Tf4bo/ar4V+Kk8b/D7RNYglR7lYxl+nzDg8dB6f/X6VfFFkJbRtVgUNcKd0gC9f zOOx9q/BKKdDF1aHZtH7pVf1jBUcRHW6T+djk/DupTPLNGJVGxs7eCVA5OMdP65r0C2SO4SSF8bG +bc7Akc9MdvTv0/CrrxsyKEuaCd9SDUIIVtmjwRL/ERk7RxnI7nrWBpe201TEIGwHCZzg84z+o54 rKKcoNX1HJ+8mjvLy3lA8xSu18IWPP1475BHFcD4usY5oi0ce85JHqrcH0+nrRQny1EPERvCSep5 JeRq1o7TY+6Sxyc5wOOfzznvUfh+ULLiQnfnAxkkc4B/z7etfRy97D3T2aPmoe5XSfVHoHlmFX3S KB0UjAzx7/X9Pz43xPb77O82R/u3UAD06g47fpXPTa9on0OiovcstT5D0m//AOEe8dQzMcfP8wx1 zwf8+1fpZ+z9dab4nvPiF4R1JS0Ou+GLu0jRT96VVLKO7dj/AJ4r1FaOPw1STsrx/wDSkeLTbeBx NHqnc/C1DdeDPHaO5ZLvTNTBwOCrRSg/0r+sPwfqkeu+CfCGuRSb1uLOGbIHA3KCcfhnmv3bwqqc uJzHDyfSD+5yX6n4tx7TSeDqv++v/SWdPq6fb4Z0aTKGJsDA9/8AD9BXLeG5pp7K189htC4OMDGO P51+3RtaPl/kfncleg0uj/r8vM6vTJ2026wm0bwScen+f61Bq0ttKVeSVS5HQdK/EfETJcZmXEuH p4Gk5SnTXpo2tWfpnBuY4fB5DUniaiUYzl+mxyjr50ZYHeo6bT1Hp7dfYYxSnTZk8mWCIeWTlg38 XHvX1HC/AWEytRxONSqV/wAIvyPBzziuvmDdDD+7S8t38x0NooZfM2lc9CMAevJ+lYM9/BHfTeRC J5gOFjUu2ev0r9E9ykm10sfK04ym2+nf+v8AIgbTtXvstNCsMTLgM43ED/dXj8PeoP8AhFZv+gnH /wCAjVi68m7tW+f/AATeP1e3vvX5/ofpAL3RhKnn3H+vEcczrbupRF28KWB2r09+pOc817OZNP1u eEgfvZGMbyD5NoPPA+8cADAx61/EtoprW5/SyUmrf1cuXtynlTiSRo552IIZyqBAMhQAOudpPtxX LWJWW6jSbaqjaEAYgkt3P656dqmSu0bR0VnudaRFbRapc5EiKFSKXYPn5zkbugz9KtWtx5VpG8nP y5fdjcSeAoPoAcgetaJ6mdlZstTXljHZ3ByuFIXk+/r2x3/GoFU3M4aYMkC4YI/BkAGFB9u9Pd8q Em1uUr26ht3X7Hcbo2jO4lR+7A69Mn2965ougLRkEyNgnP8ADj8PSumPnsY1JdCT7RHNKUL4dkGd vLH1FblsrMXXyNsSjYm4jGBz+P6da002M4pvXobKSssZh3L5BxkZI246j9KW+uVnljjC/uAOdo54 7GotubpbNk8c0SS+YpC2/wDtY47Y/nXovxKur7wX4ZtPg3o7yj4k+KLaC58VyoQraJo7lZLfTcfe SW4IS4uFYgqogiKBg+fOzWt7HCNLeWny6/hoduAoyxGKjSsfQHwO+Glvo2nWUa2wHyg9Pb/P5196 eGtHS3iiAj6AYGK/K8XVc5yl3P2LCUvZ0oxR30s0dpbkluMd6+Hvjt8ThfzSeGdOmBiQn7QVY8/7 HB/OvW4XwSxeZwm17sPefy2/E8riXG/U8sqKL96fur56P8D5gnvc/uum4ZwDj8azY5GME8JQg7/l 46nPb86/Xob+p+QT8yosixQOCAHBBY5Az/k9K0ob5lnSaNCICMZPIY4/+tWmjitDLq3c0BJE8G/z Au4gEAe/ar+m3IV8rKTszgN35HrVxS5r3E+azTOqs5GurkXkzBZcEkbh1Bweles6PJ9oGlu8qPc5 2xKSF2L17j2Jr08P7S0kvtP79Uc01HRW2PUdD1BDeG3ckyocAgnrnnFfQ3hu5hlMUcDoLo8uW7DJ P+fwr1KTTVu+nz2OeUex9SfDTx7dQGGw8pFjeXAwevTI9gSK+zvDPiqOVNskaK6uVEaHgjt0/Os8 XRVSCkjNNRfqe36fex6haxXMYwGHSrlfKTi4zcX0OyLvG58ufHj9sz9nT9nBDB8T/iJbQa6Ymli0 m0Bub2UAcfuo8lM9AXKj3r8BP2nP+C1fxV8Yy6h4e+BOlp4X8KzK0SX06JNqUqdC+45SHjsgLL2f oR9xwxwnVzCccXjo2o7pfzf8D8/Tf57Nc4jTTw+FfvbN/omfjP4l8feIvFepX+v674gmu9RuWMkl xcztJJO3dmZuT26nnNcYdQv1AdBulwWG48Y+lfsFKhCjBQjHRbJf1sfHzquekmU7i5vZIC8k4Zn+ ZlHY44FW9F0LU9Vks7PSLOa41WZ/LSCGJ5JJHI4VUUEsfYClUagnOcklFXb6Jd/zHCPu6I/W/wDZ 2/4I+ftHfF+30vXfH0MXhDwvM6M39ppvvpYepZbZT8mRwBIVbPVcdf3q+A//AATB/ZO+BUOkX8Xg ZNe8X22121bXdty7Sj+JIiBFEM9AqA8DJJ5r8n4l4uqYuUsFlkrUuslvLyXZfn6H0WWZTzx9vilp 0Xf1PvtHtNMtRBb28cMQO2KNAFB+gFZeqa6LaC3aNwGJyQwOeK+Ip0XUmm+p9JzKKUVokRyX39pJ qFtC0aGNQxfIJbjPArkNG8TNqGrS29xZn+zY1/dySHrIeOP8a66dD93UXWNvxIcr9Dw/9pX4KeG/ j98PPEfg3xNp8E8jArC7AFoX/hcHqMV/IZ+0z8DPEP7MnjPWvDPieEtYK2bGdVIS6U8DB9fb8a/R uDcdGNOeCm9tVftvp+J8vn2DlOUK8Fq9GfIRiKxm3vrbzEnUmVSM7A38OPpX87H7ff7Px+EnxKn8 SaXZFPC2sEzx7UISOQ8sue2TzXo8eYP65w5HEJe9Qmn8paP8WjDh+v7HM3Tb92on96Mz9kL4upp0 8vgC7x5bsZbcseCD94Zzwelff2rpEouo3INrLH90Y5PI6/0r+VM1pewzRyS+KzP6HyKr9byZRe8N Pu2PER5+m6k4lBA8z5fVh7fn0+tekaLJG6iSFsKV3gZ6Y555xknHt9KjELRNGtBtNrtc24IyQfOj +VmG/IJwvb+Y/OuS1LCzTiBlXJDJ8pA7cj0HIHrXPG/M0dNTa63OvsryFtMZJbg71BLZ5IbaD0Of ase+tBPpc37lwwBZ5Onfg+nephpP5lSXNCyvseI6giwTObpyyOcqyjH0C89OP61iadKkOokq+Tu3 gZ6jgDOTx9PWvo6XvYd9rHzFVcmLi33/ADPSkuHdY4mQttAIyRjkHgjtjn8hUOsxLLZyJGh+783B Gcn/AAz+Fc20lY6nbldj4a+IsB0/xPDdKP3W/nPH6fpX2T+zj4uOifEbwHqLSYg+0pC+CAGSUMmO eCMsPevTqu0KdV9LP7rM8Kl8eKguqPz/AP2mfBzeG/jd8SdNjiXyDqc0sYUAYVzuGPQc8V+7/wCx 14lufF/7O3gGeSTFzb2v2WbI5BiJTn+VftXhpV9nxHi6XSVOX4Siz8l49g/qNColrGbX3p/5H1LB 5pjWAREsTgnHY9M96+b9Q+Idv4cudQ0O205pLuOeSMMeFwTn8vav3yNSnCN59H97s/8AI/OMLhXi ueC0Stc5Cy8e+J9X17Tpb+7MdqsoDrHkDafcd+fbpX1VY6Xp5t5Z55AB95Sx56nv+f51iqlKrW9r yrmsl8rs6MfQ+rRp0KTfL27v072MeXVtJsklitwZpy33YhnHU1C11r14qx21oIYOCHlOGGT6ev41 o5X0jvv/AMOccKKWtX7hz6baeYH1K6eeTqRjC+pyBVqPdYLM0CoIcg/KBk59c/hz6e1YPbX+vQcp OXup6EE1ySrPICQT825h8v0/Oqf2iz/2f++j/jWT30ZFuXSS/I+25YH1m2huLK8VIAvlYdGTknLM cnlyche4xkfdOE1S5jsbSCIzW8l6i7XEeWMYXgbeyjGBg/Wv4rUXy3ex/TkW7cvUzP7Wn1BiAxC7 0IPL7eMAZHHHfGOTzyK1Psipdw3Ud3umUE5IOSen8qNPibKb5XbuWxNLeRS70ZosBVBX7oU8D+Zy a0/tcYVYGuWa5LCMKqjlPXPXPPGKuK3vuHr/AF6Dbqz8lUlSbdhhGseBy+Dknt3NF9ercRvb/aC0 oADsqnB/2AT0H+elaRvqn3FKWt30MW3kuDibCxo7ZZWHAXn0zVJlBTzDcb2Lddp3Ann8vauqKstW cdSetkXLWORJ/tCr+4JCAHjd6n/PvW7HKF2qzfLk4yf6fh+NTfdGsI2Wpp3tyAsTEBVILBTkkfWq 9qAYJL2WQkMSvy4A4H+f0os02m9DTSyaZ6F4LvdL8FeHNQ+MXiPT47uy066Wz0HTbhPMTXdaKeZF EyHAMEAK3E+TyPLjKkSnHSfBPwJq+v6vf+NPFUz3fiTUrl768uZeXmlkYuxJ9yegAx26cfI8RYlX 9mn8Kt9+v+R9bwvhOevKtJXX+Z+mngvw6lpbw+XGM4Hbrn15r261ijtYVI4GOeBzX59Ud3c/S4Ky t0PDPjJ8SYvDekz2trMP7RkUiJSfug5yfwr877jVZbm5uLhzuklkJeQ5yfXrX6bwhgfq+AeKmveq PT0X9M/M+Mcd7bHRwcdqau/V/wDAM+OS23SI7Hf1yen86ZcXpkZBG21TuIJ6mvsY2UlY+MfwtmZI 3yOkbA4PTGC3+etTjUgdkAlIhQ/NxwKt+62o6IhLa5ul/wB4sY2FcKQpP0zmrUuoQxssEaArn5iM celawS3a0IldO1upv6UGvLuNnl2qAV29OP69K9L0spFPHHLKPM4AKtxxXdR3RjJa6HtGmLtmt7iQ 7DjAI6lj0/z7V7b8PZVfU5Gu5sKkb4Jx8w2/1r1cLCXNGK2bMKrtBs9z8DXFvc3Vve3d2I5JCW2u cKiA8D8a+x/D+swadMk097G6rEBwR1YetdjpSnD1OZS20KvxX/bh+Av7PPgldd8Z+PLQ6hkoml2k gmupWH92NSWwM8noPWv59/2i/wDgtF8dPii/iLwn8KdvhzwjOslus0cYa+mjYYz5n/LI/wC7yPWv T4f4Uhia0sXmEGknov1f+R5GaZm6KeHoS957vt/wT8gdU8Ua/wCINVuNQ1TUbi61aQ5mmuJWdmPc sWzn161WvLYOY5HkWSXJ3cfQ4HOP/wBf0r9ShCMIckFa2x8jK7ab3ZYeXesG2FAsabcjn36dq2/C fg7xX4x1ux0Hw1pd1f6pdShLe0tYWllmY8YVVBbjuewByazrVYUYSnOXLFK7b6K3U1jG0U7eR+zf 7M//AARk+Mvj2XTdX+NtyvhXwk7LJJZo0c2pSpzlcDdFCx45JcjuoPFfv/8AAH9h79m/9nG3t4/A HgGA6+pMkuq32bi6lc9/MkyQPRVwBzgDJr8f4n4pqZlJ4PAtxoLfo5Wvq/Lsvm9dvpMsypK2IxUd ei/Vn1uLhBlI2UkDIA4rKudRgwublRnIZepBHavjKdOTltdn0EpaWRyms61eQW0F3Z2pdk5jUr94 98Z/nXIQ+Jo9V1Fm1V5LaD7KMiSMA7m6/Tt+derQw65HOOslfQwlO1rnLajqWnzzPb6HqzRasXFt skB+df72D147+9d1pVtaaNp9vDeXZubgPucFRvLde35101lUjTjTcfefXyQ4NXvfQxL/AFG3tbjU JJw6pgSEgn50JwQK/nw/4K46fomr614JjSZrj7PC90sW3BRm6A+3t7D617WQucMZBxejsvxX+Zhi VCpSmpdE39yZ+Jdnol/fG4u7hliiXgswyBnqfT/9XtXzl+2L8BvDnxr+DXiPQtOn87WrOA3dozLl vMQE8H8McetfrOMwbxmXYnBP/l7CS+dtPxPz3C4hUMXTrJ/DJf8AB/A/lLsrzU/Avi63naJ4NQ0+ 7CypjByjYIP5V+0/hPXYvFng/SNWgk3rNCsoIXPb2/P0/Wv474louDpTa1Tsz+jeDqym69C+6TX9 fccX4ouLa5uwVQrKDvJAPOOD9KTw5qQSSUMwCEEHPU+2Px/GvNkueimz2r8ld2PTxcrNp+Cu6YhV JC4x0APtxXP6hatNujkfYNqgMR936ZrhgrPc7ZJM3L0WdhPZ2cbhoXQbm4yx9evPcVf+zM0MyGbc hzxjgAdMYHt+ealuzRUXGzT6HhPiOx2XTOFA8tiFweGOCePwHpXnmoCOO7S4iBjYqE5zjnqxz1r6 HAT5oOL7fmj5rMIONfmX9ancaTcSLbqs3I2YBAxzjvzXRbp7q1dSVMuxsKTk8Akcep/wrOVuZdjS Dbik+39dD5F+NGmrCkVyedrn/gP1z/n+u38Ntaljg0i9VyJbaSOVWyDkq2Rxj1A/KvQn72GTXmeP FWxtSD6os/tpWNjB8UdN8UpGxh1jTILvzMYVmwNxHr29a+uf2Bfj78PNB8E3vw88Ta3HaXYvWltx M20Mj4PBPfPXmv0/gPH0MLxHh61epyxnBq77yirfifm3GGEqYnLqkaMeZxkpW9L3/M/VTTtb0fU4 vP0e4juIsZBRgcD8/wAOuOK+LZNPsNd8WeJ/tN4UuRMziNF3MwHH+frX9HVLewjrpda9NmfmOXKp RjXfLqkvzOv0v4Y3mopHLBC8MaNzLLxwvPT06fnXvFh4WQ20a6jfvcMFA8sMQqnHB9//AK1RCHLK /TbzMsVi/aWTWq/zNSCC1sYfKh0+NCAR06/U/wCetRzSxxuW2EsV4G0Ljp/n8K0nZWUVZHnqfNLn 6lK5vbPyFWSGNSOCz8D16nj0r598e/tI/CP4ewzJ4i8YQC6XJMELh3AHYKK58TiMNgqLxOMqKnTj q5Sf5dztweCr42oqWGhzM+G/iL/wUl0e1+0W3gDwx9oYApFPdEooPrtHOK8R/wCHkfxQ/wChc0v8 pK/Msw8UcLh8TKlluD9rTX2ptpv0Xb11PucPwVSdJSxdVub7dPI/pbhvTbIUF7EsIBwdpkMvAUFQ c/TOBjOKr3NjPHGt1Cu9WZGYBsFhnG3B7n5jxzjn3r+e3spH6zCTvdKxZs9QsoheS2V28dowIjLE jJwd5HX3A69fY1fkvrl7iwhnnK2/3jIQASuCQBxx7n6Um1yrzNGrs1LNYcOpknVNoeZjyZeeigcj 735Cta2gkt7qK4kjcxD/AFQ4HzEYAAGenWtE07JGbsrEV1cy2rn5GdgjJFgEkseAcdc/4iqM91La ebC0DCYJuwMEIx6j69q3gr3sjKq4mFaXFw4DFD5obB35woPcD/P86vG4zbu0U3zxOFb5QS3PX6Vs m1F26GCabbNm1upypZ13yNwoxgAc0kt2VlKMDvU4AHABI7ep/wAKy5tb/wDDHTFWRo3E8lxYxidi jscZyOFHtXX+FPDV74juLTSrG7it7TY81xdzMFitLaNS800hzwqRqWOMk7cAEkCrc+WM5t7K7FZ3 UY9zTgeT4zeNNGOk2MkHw18PwnTfD1pLnIi3FpbqQEDE07lpnIAGXCjha/SL4a+D4tOt7YLEAQoB H0r8xzfE+0ru71b/ADP1Th3C+xwsZNb6n1DpFisEallxgccY44rF8deM9M8IaBqGralcrFbW8Zdm JxjA/qa8KhSlXrxpRWrdj6KrUjRpTqS2SbPyU8S/F6bxrrWo6zqu5LeSTbAgzhY/4QP5n8ayYb+N jhZOG5zgZ9f61+3YKjHD4SlQh9lJf1+J+I4+tLFYyriX9pt/j+hdtLklRvUNzzkdB9a1EiWYBjbZ UAlTkc+px6V2Q5XNXOBv3WZWoTIDLcLHtTIUjBweazp/sKQCVVG/d+8bPpj9a2krpyXchXTsi1pd 3E0rXCEENkKMnjH1rbsTJczvdOy/ZsbuTyen+NON3sJ6M9B09bWGA3dyU89uE9D2wPTtXoGj/YLZ Le6uV3r3LE4BPT/PNehho03Nc+um3mY1OZr3TpodfkuLYrZOA0Tffz178Zr1Pwj4uitpvt11gzDC KjcBlyN39RXo0KqUryen6mM4NppHt/hjXQkn9qaombFm3RRDIDL2H589O9eM/teeI/j5beAbe6+E mo/Z9PjDPcrArG4AbsPToea9vA16ca9KdVe7dX8ldf8AB+RwYqNSNOTpfFbQ/ny1vU/FGs63dXHi ae5l1RSxklu5GLbu/wB7nr2965zTobtJppblsIDwQOW/+t/hX6tR5FCLpL3Wv6+R8HOU+eSnvf7y 1mSZZJRMfMVs5OeR/X/A11Xhfw7qviW8ttJ0ezuL3UJn8qK3tomkklc9AqjJJ/8Ar1U5qlCUpytF LV7fMbdtLavT/I/YH9lL/gkB8Vviy2meI/jBeS+GPBrzCT7Eqq17cIBnvlIgTgdCSAeFODX9HH7P 37IH7PP7N2lWdj8MvAVpHq6LibUZ1867uZMfeeV8sTycDOADgAV+P8T8Q1cfN4TCSaorf+95v9F8 3rt9NlmXKPLiK616L9WfTaagYBO9zHjB+T0qrqmtx2qwRSXCCWVgFPavjo0Oaatr/wABHvc2ljkJ dQy95HPCUManypA3EjH0rg5J7++0Sa9vHKXMVxjMLdAD3P06/X8a9ehBR1euqt89zGTYeINburXT YI47zdq9rGZo4/8AnqCDnIHpmuF0e6mNu03iAGTXZVa5klLjYsXRUwOB9PrXZRpqNP3VZt/hv+bM pXbsy1rmq6fc32kaxp+mh72DaZJY++OSDj6Y/Guj0nWtQfUJbqSfDMWaSNlGUBHA/SqlQXskpu7s 16f1oCm72SMPUPES397bQrcqssjFCoIwijkEk/h+tfm3+3T8ItP+L/hnV7nTWiHiuyicb1IO9EGc D6/5616eVR9ji6UmtmvzObGKU8PUjHdpr8D+b0LdaTPqumXoZWRijxyDB3A4/wAisJYbCF3FxEzQ OpEhXp2OOe2DX7LTmlCnJPT/ADPzHlk5Sir/APBP5of+CjnwCj+GPxkn8TaTEyeGtdH2uEbMBJf4 lH55rH/ZI+JF2baXwbeXJaOB8whuytnj2/D1r+XuP8tjh8zzDDpe6pucfSXvL8GfuvBGYNPB1m/i XK/lp+aPqvxZYhLtJlYLG57Y5/zjj6fhXn9ldpBcM5kLozfMP5AfiBX51h26lBdz9Exi9ninfuex 6Rfq9tBJbgnIyUYMc8cEnuK3LkC5t3lK5+XcewAJ5/Lj9K4Z6Svc7YaxXZnFrqbf2piZztjUqpIw enU88V6RpcsAtXjwctzknr065+lFZOysx03ds838bWkjSMqRffG4HcMZz+fv+NeM6rGZLQmVg8ik O6jPOOvTnnJ+lexlklZJHiZmndO5t6NerJA8XBwu7J4VueOenp/9fmtzz3RjbRN8/AZF5PPbg89Q OfWtpK10zmjO6vc8O+Leni70a52n96D8vJ/yOP5V498NNVhEMlncPtdSa7qacsM0ujPLrPkx0W3u j6f/AGlvDc/jv9nX4a/EOxhVp9DeTTb3aMssYOFJ9OOa/NiKTyxvW4KlehU8g/XtXsUG3h6Ml/Kv w0/Q+fxUOXEVIeZ7P4H/AGh/if8AD2IQaF4xuVszgGF5S6kenPSvrn4J/t2aToeuvN8QtEEiSqFa 6iUEg+p7jv8AnX6Twxx5i8sdPBZo3Uw1995R813sfJ5rw/SxVGq8IlGpJfJs/T7wF+0B8L/iRYRy eF/E8Dzt8wgeVQw47j1H+e1evy6zp9nZx3c11HFaHkSFwqk855/Sv3jCYjDZjRhisDVVSEtmtfv9 D8lxWHxOFrPD14NSX4/hqfOnxI/aq+EPw/iZtR8W281+md0FuwdicZxkZ46V8J/EL/gpbMyvZ+Af DfQELcXR6H2X09q+V4j40yvIOaiv3uIX2IvRf4mvy3Ppsm4WxWO5a+KvCm+nVnwr49/aj+NfxGnn XUvFVxHbycCCzLIv0wOTWT4J/Z8+OfxauYG0HwVqVwkrbvtV0jRxn/a3vj0Pr0r8HzziXM89r+1x 9VtfZgvhXov1P0rCYLB5bSVGhC35s+x/CH/BOJrC3i1b40fFvTNGsMgvb2sgkm6Z27mwMnpwD0rv /wDhhj9ln/o4C6/76h/+JrwHzX9+ah5Pc9GGGxtWPPCFl5rX8z9xUubi2dU2IzE7UlllwsO4M23a D/Dx2xlgOorXF9DJJp1r9n8y5UbmKAsCeh9hgZJPqcV5MZXfvLS57UVbc6UWt7cxi7tYFfYWCKuC Yxngc4HHU8dwKRLeQRkzlGYxsEi3ZLtgnJxwOmT0HAFW9FqhX10G6N9q1Frlprryyg2q4GEC4GQS e5HIHpzXUG3ntbc3H24DcjPEVByF7Hjpx/SnBys5L+v61HPR6mVeu8EUSSXsklwVLAyfKCSM845z j+lZhvlNiyiZvObG8od545+vpXVTbV9Tlqcs27EBeW7gaQStHbg4yy43ADPUdzWhFp89x5bhtm4B /Lx8zZOefXpmnN9UOCSYRanLbrdnyG3geXHgZDN9fz/LNdMAgtIZrpGEm0bti9CR3Pepi1Nt/wBa m0/dty7tmfeRT/ZJFjBSAyAgsSzc4A6f55r0zXVm0DRbb4QaO5bxZq0cc3ie4CqH0+0yrwacpOWV mIWacHbz5SFSYya4M0rOhhJu9ubT5bu/9dTsy6j9YxVOml1/r8D7G+Cnw3g0XTrKNYAuFHOOvavu HwvpSRxxsVK44GR1/CvyzF1eeo2z9jwtNU6SjbY7e8vYdOtWdiBtHfjFfld+018W7nxpqVx4U0a6 X+xYH2zyA/LLKO3uFx+ea9vhXBvEY/2zWkE38+h4XFWN+rZY6afvVNPl1/A+HJ7m7t7qSzLsWg59 V9v8/Su2tNVugLYtICfLC4wRnvn+X51+m05O2u5+XNK9z1Dw9qUd+pi4EY+8/OGI7CupkUu5aM4j K8EtjPp9R/hXXH3kmjnldO3QxdYnlkVbWMDydv7xuMk+v0+lYkkMUcUFq/39+4hc4JPTNdEldK2x itzbtkjk8uyi2CJSWdx/Eef0rqVmwttjYVxhlBwMfh36VS00SEktzZs/tUlwbh33WoAKo38Pbiuk s5rl7eaOXOWI2ZPXj8q3pNq/N1uRK2iOihmjs7KO3iB84yDdwfx/z711+kXkMjSX11INkRxHb92P bP4/1rupON1CWiRD2ufR1n4kvbLQdGOt2jfaJJFkCugXCfwgZ7EY/wD1V9BaDqGl6ja2IvLEm9vy sK2pX5TGeM89Ovt1r26cozjro7J7eW34nFOy1T7nwP8Ata/8E/D4mTUvHfwk05hqCMz31uMLGuF3 EfXGDjrz0r8NZdB8Qt4hk8OS6bML2KUwNAEJd5AcEADOfqPavv8AhrMPa0KmGxMv4ezenu9vlsz4 zNsN7OvGdLaX5n6dfswf8Eu/jN8a4rbxJ41P/CPeBpZvLLSjNzKvcqvRBzxuJOQRtr+jv9nH9jP4 Afs2aPHY+C/B9s+tFUFxqlygluZumf3jZIHsK+X4nz2WPqPDYR2pxf8A4Fbv5dl8z0cpy60VXrr0 TPtQazZROsNuvl2YwOF6D2xSXF7YaZEk7SsZmJbdnjHpXwnsql1HrLc+i8jGl8Tafqdpc2xuPJlz hOeSc1x1xPbXG22u7g3TW6s0pVseX6d+uK7aFGdO6t53M5tWtfQ5HVfF0eu2cf2S/MCxRl4w4/12 0ev1rmj4svU0a3urFluImTF2V+6D/wDq4r04YdQgqclpfcxctdRtt4h0rXH0x9N8037QukvXdGg6 ls/T9arXKxxy/Z0IjQRDzCG3GYAk7fb0raMHH3W72/pf5i1uJDPeLOIrRWhiCb5C4G3tgA9jjH+T RDroke6Z5diM3Mg7YHr2FNxU3oUlFJtnmmt+KreC9k0mzCusls5N1j5UOMk5H8v8K8qPhfRNWsn8 T3WrXAuTDIh+b5HYdAFPr6/SuiCkmlGVnfX8H/w5E2pPQ/nu/aU8ATeHfibrWrT2zJb3Tl8AYAJ7 f59a+b71rWC1ilSBhOQQvPp3Nfq2W1ViMBTq33S/Dc/NcfTlRzCrT6c34Hwz/wAFAfgrb/Fr9nvU tXggDeJNFUXdvtGWKqDkD8BX82vwV8Vy+CviPo17L8ttJN9mnB/hDHGfwP8AOvx3xUwLWPp10v41 L8Ytr8rH6BwNi+Smot/w6n4P+mfrl4gNvqmlJdWzLIowQSuffqOB1Iz7n0rxa6h8l5RHGwjR2YqQ c8+47dOPfpX4NgtIyg902fuWZayhVj9pHonhbUJBaMJdoAXdwOc4/wDrj9fSvQYp2ubfdLJ8uc4A wCef5c8e9Y1kozNsPLmpxucXqU0f2mUxRZbdhCV7jPc812umSxyRiMjeB8g9M9c1nNaFQa55FTxV YfbNKZpWCYGE3A459O/bpXz/AHNu4luUkZSgYgZz8wwccdOv+fTvy6VnY83M4PlUjBsL6aF3g2fO uVYeufrn6fhXURajGilppwJgOCOQ3TsT16dvX6V6lSHvNHjUZtRTOe8SJ/aGlXrRIDvUhx17Edc+ 2f8AJr4xtbmbw74lkinylu0m0jPWunCpuE4M4ce7VKdRrY/R39njxx4Y1mz1z4T+NJVHhPxDbmEv LgrBO3CsN33c5xnPYV8I/tF/sy+PPgN4mvob2yefwpJIZLHUIgWikiYnaCR0OOtehg581B03vB/g 9fzueZmMbVvaJaSPl5yyhTj5h1zWvFYQSR7opwCFzgnrXTc4ERabqmqaNdLcaXfy29yP+WkMjIR6 dCK9oh+MHxc8W6ZD4bm8V6jcqf3cMETOzMfbHJr1cDnmaZZRqUcFiZU4TWqT0/4D9DkrYLC16kat emnKOzZ1vgr9kX9oD4jzx3UfhO4trJzu+16m5hXHqA3zHgntX1f4a/YJ+G/hhF1H4v8AxVRpowGk sdM2jAxkqWOSe/YV5E6spt1ZS06yfX07nVRpVcRJQw0dO/Q9r0u+/Zj+EdsW+HfwqhvNYjBC3mog SMxHfL5POex7HjtXNeKv2l/G2o2gW21qPT7RyUFpYR7F2f73X0HTtXn1MVyyaw61/me//APdwmV0 6P7yq7tdWfM2teN9R1S4lubieWVjzunlLYPPNc3/AMJPfesX5mublnLVy1+Z1e1UNEf04aNpTanZ zLdWr7CwCLCFWNM4OQckkZGMkknaecHFX9S17E0ej2tywMeI2ZVCeYcdOnQcdO+a1iuVaLU4E1sQ fbJw3z3RQx5KhD1XJOBjqeOT7nmtSd7nFnped+q38KlztwLKDocAdyOp9/eqbbSTRSSvoagtZnuW s7OBV0+JtgfGABzkg9zjqepJqLUdVjgvpbQbWhEageUvO7ORj2yP8acHeNu5VlJbnN6j9qgbyRcg vMBje+GycHAJz3wD+VQQm5hmuYywPmMFI6bQMY57/wD1q3V7nLLXQ7Ozh/0O0tZjlOWxkDdzn/Dn 2qW51C4VR9h3q0YOXHcngYPYYP6UTupWHSd02uhTiMjXFuYiWvmXhBjapxgt06/lV+CbWdPnmiuJ l8liF4+7jqevfnrRC8dUtDS6k1GW51ml6nB4ZspPGd5AtxdpJ5Wj2s2W+03Y5RivRo4uJGHGSEXn Jr2v4C/De7nuJPEGthptXu5XubmaTJeSR23MxPuST1718nxFivsJ7afq/wBD6/hnCqpWdZrY/THw Z4fS2t4YQOg/OvZrZUtbfdnAxnkdRj2r4Gck2rH6TFcsVc+Mf2nfjavhPSf+Ee0m4H9t3qsg2tzD HyCxxznPA+vtX5f2OoyI85nLTTKzMUck7cnqSep5r9L4XwywuA9q1rU1+S2/zPzHivFLE5isOnpT Vvm9X+iKgvotl7JNEMPwQCPwH6VoW07m4tIxGvzuqHdxjvx/k9q+kTW9tz5e1tLndRS/YjOznYh+ 5t7D15/Our0PUk1NntJIypUYRTydvc11U3rZGM9UdTcWUMVpNJAmbkfLuI4J/pj/AD2rh7eGSWV9 6fc+YnOM+v4/4V2RjfljEwbs2y1asqvNLPnylyTg8+/Pf/69b2mRWF2Le4idltSSPmYjJ5/wApJc zST1J11fQ7G3ubaMoHlxArDeB1A9eK6K61XSbSa0nt7wtb54Gentmu2mo25nLsZtO50Gn6lBrN5J HAVS2UgqCvQ49eP8+tdn4XsX1SW7CTRG2tiZCWON5GMAY7/4H1ruprnmmlo729P+GM5aJo9YtL2P VYJ9R1W8mkniIt4EY/JFgDHH1xXsmj6jrBMRn1A/ao1V4J1YZTA46e/5161OUm5TUr31b7drHHJ2 0aPUfDPiTxLJpGsWf2yZ7DzFacs3M7kAEZzk8celN+Ef7NHwttvirq3jm78F251q8h3W+VUrEw5J +pJ/l+PUqtTkfK2rrW3Vdfva/A5atKnVac18Luj7f0r4gtpOlTeHY4IkghYoAFAww7DH+FdPp3jq KeRbGFJHmkcJkcknv9B79K5J4WFnNPfU1Td79EWD40mWV7VZFU20mJNw4OcnH5Vfm8YXV1pU93JC JSZgkUCnlgOpNYywsFaX9a6j5nbyMWfxPb6ktvNHAsTwvmTacHA/hB/z+NUrfVInv9YsrWRUsbpT JPM8mJE46fj/AEraNBxXe3+ZEm1do4GPWrGTT7m2hT/iVQsYkPcg9we4qvptzcWqx2Ntxp5ZQBu4 bJ6n8K7OVLVaojSzuSNrD6dqF5LplqpeEfZm8vpjrz+lQ2882sIkk7i1+z/NgNkvnrmpainaC1HH Ru6MXxB4/gt7eOwhuV8hHMlw5+8Qo6fQkfrXi998S7jX2ubKznEelHcoZP7/AG5prlpq61f+e5b7 2CPXbVbO0BINmzrACX4yOCT3/P0rmL7W47jVNT8JWt7mwDiaOWMfIpGMgc4A4qeZcrd/Lz1TX6Ao vdI+HP2vvAOoeKvCh1jT9LXdZuQZQOZjxk/1r8j5JZ3LLdJtdfkIwODn/I96/QeFcT7bBzoP7Mvz /wCDc+F4moKnjKdWK+Ja/I5XXbOO903UNJmjzb3KNDImBjawxnHb61/IZ+058OLn4S/G7xj4dEbR 20V609rk4zGx3DHrivnvErD+2yvDYnd05uPykv8AOJ6XCNa2Jq0V1V/mmfeXwM8aReL/AAZYLK4+ 0+SFcNyWIwDgd/8A9f4WvEZZLvkYjUlmHTAHAzk57H9K/mJ0vZ4+pBn9C0631jK6NZ9Ny9od7E4j cN5YQZI644JwPfP+eteqWF0Hs0eNFySPLXPvj8P8+tc+JioysdODkpQWhl6w2xGO0GbJJyOB0x/+ vmk8OXquC5ceYByFOckck5x/j/ji4/u7ml7VUkdvrEMdzpzt1lWMMqdQw9OvXrXzbqm+O+lVomCj 53XGeT7kV0YF8srNnPmK/dXOQvQbfUg0igE4APbOB6e2fpk0u9cKVB8sdiRk89eevOf89ffnq+b0 Pm18LG2kwiMiiY+XIMjOeM+nfP8AhXg/xY8FSow1OziyANzYyenvV0JqNW3c58ZDnw77o4XwV4xf TpYNPvy28MAj9Cpz1z2Pvmv1F+EX7SdlqekW3gT4raHBr3g4oUDXADyxLgDGSeQMnHfpW8pvC13V Xwvf0OSlBYzD+xfxR2Ox8c/sGfszfE0W+q+Btcu9C1G9h+1C2C7lVWxzt6Y59a+fj/wTG0d7q4tb X442asnLpNCquo/3d2fQ9utddOtTrpSw1WMk+jep51fB4rDyalTaOs8MfsF/s3eDrsXHxL+Ksupw RAvJDaOEHHQHbyOff8q9rT4m/sz/AAVgWx+D3wptmvRFhb65hDNkDALFhuJ68VNWdKk74iak1tFb X8+5WGy2tWSqVtu3Q8Q8c/tMeKtfvJZLnWXi09oyotrNdiox6cj735d+nFfOOoeKdUv3u52nkdnP zO8h6Z9ep7frXn1alSu+eo/RdD3acYYeHs6e/kcje+IZI2drq9IcLhlU9QAO4Nc/c61FPtaODdLu +Ykkj2x9BThSvqlY56uJirp6sz7jVbuSMw+ZsT0XnPp06/mO1Z3nXH/Pdv8Avhv/AIquiNNJWSX3 nDKtOTv+X/DH9WFhLbaTZaVHcXb3E/l5jjWRtruSArHBGB1xnt781j6pp1ra35e5O2NpUYxxuOF6 NyCST79z0x0qHdxXkzRW1TNpPsEs/my3KrZx9fKQgvkEqoz6d/qTjpVq8vWmvElLu7mBRIY1xkAc L0GAPT8TR0v0NL2WhZTUtQUR2z3TiydSMFsbR6n0GfzrJhEU8l1e3k5CrhYyOA5JOBjr61cLyaVy ZPlWhDNLsvP7Tnha42oVjG0gM69x7f57Cr8a20dtDMG3aiXLsDxtY8foP51tFWi31MFzSdkdLYWn +nR3joriOLc5QkhPQf8A161bvbfGS3RzHCp/eNtxubqQPpUpXla/c0dknZGfDafZNUjhtDuiYYZz 0GffrVmxQanfG0nuQljHumnmPKxIuSxz24I49aUpezg5Seiv+GpUbzku52Pw/wDD918R/E1rqsls 66BZqINMtznEcWRl/wDeY5Yn3r9S/hx4Sj060tlWIBtuOmMf5/wr80zjEOtXkrn6nw/hFRwsW1q9 T6V0y0W2hUkAAd+Pr/KvPviv8RtL8B+HNQ1bUJlUIpCqTgsxHAHv0/KvIwlCWJxVOjDeTSPexNeG GoTxE9ops/FD4heK9a8Xa3qni27uPMLy7o1znywDwo9AOlZ2lrObdrqIBmlwXZuoB/H61+zUKcaN NU47RSS9LH4nWrPEVp1pbybb/MS0hihuWmmmDzNkBCM5NX4LGe/1AG3mKLC293PBAPAA/D0q0n7q W7M7rWR1ysswlaWQsA3AJHzY459utbOizTQ3UVz5hLt1JH3V7D/PpXSt0zJyWvmevRPJNbtOArmV cA+hP9a5u/ClhbrGgQ8NzyOM/wA674y9xprVfqclryTKMEEDiRVJECMFZ+7k57d8Z/l6VrLbiG1i CMqwx/MvOMnjtV06d1KSd/8AJMJOzsJ9juJTLcrJm2Pqfvfh07V0enaH9tRZHAAaQCMZ+8OOaIwb VuoXO50/Rbq3ma1hZVYnBbsgH4/59a9C0S4NpHc6Vb2oJcgCRepPU/nXfQkk05ea+ZlLU76wEEtz /ZLOcF1Kx7sbm6kk/r+Fdboc2pzXOoWGmbvtSAndI2RGoPOM16kJSTSjrfT7rnNK1tVoek+HfGWu Wl1bae6/uGyqPjAZgCC36V7vpXi94tc0yximLCJRLM4kwexI65Hf8q9ClUc4p/1/XUyklfQ7qXxh b3cd88ESqWbzBAT8y5xkk9v/AK1bsHjWwa7sW0LVViuvKAuGABMXPI9M+1WktrL5+ZlutEdDpuuC e2u7czq0fm+b5kh+eQ9ec9f/AK1XofE0drFbarBA/wBgy0alm6tzyBVOMXonozLWPxEllrEmo+Wf Mjito2MkhB5AIPT/ABrBnvbOHUbi8jYXMCoRGWYjzif04/pTslFK1o/iKzd+5zg1PWIIIPNSOG3d mTyickL1z78VtnVY41D6bOJH4Qg9sc/T1qXJtXtZLoWoroWn1dtMsLkwyJ50hEkhBBHbPP5/pXk8 nj+W4u7ttPYlNpiUEffYnk/59KLqEddHuCVkzy7xz4viSV1i0yeS9H3yo+WdhyQfpj9K8i0u5uJ7 bWIrnU1t/OfzEt0yHJwBtH5/41zVJrnUab11vfpo/wDhzaKtG/U7Pw54j/4RzSrSS9UShp1SZJD9 wZOSOeCRnt3rrPE2taJ4kvJdR0O5jtdLWLO8DaHl6lf0A/GiKThZ/HpZ/n9yBxfOprU861vUIvFn geeBtUWO8jdoVhx8rgrgNjpnnNfih8R/C0nhnxRrVncPwshaPByOSa+u4SxD+tToX0lG/wA07f8A BPluKcO3hYVUvhl+aPP418yUCaMszDooPpX4R/8ABXT4Q29nqfhb4n6RanZIps7yRV+Xd2OR+Nev xrhfrHDGNfWLjJfKSv8Ahc8bhqr7PNaVtmmvvR8Vfsf+IoJG1rw1ezBZIsXMAJPQ/eA/HFfUXjdv sOoeavBmOODngdeOg6fzr+ScbGUc1a6Nf8E/pHK5qpkUbbxf62Ob0y7R7jAQgk7E546Yz9c+lev6 RIq+UrzqEzg55557dh0HHqK5cWrbHZgpXi7Iv63DatEszIBGPmxzyevX+H8PfriuX0NltL9VUnyp FyRyMZ4wf8iuWKfsmjpmrVEz121Rbi2CqQJdu45XCgf5x35r578YwGK/mdwA8mdyDocnj6/r/Wrw bftddyMbd0XfocBrgl8u1k2kHhSSQOOT0rCM8i/LIMqeg9enpz39TX0sbOK9D5dtJyvoiEPLGyEk YQZYLxjH19wPTpXQN5OsaY9u8Sl8bSGx+v6dvWonHVS6ig7y5e58w+OPhvdadeXF3piF7U/MxUZ2 9/wrkdA8Ua5oEscLsxjXlVPBU9P5fzrug1Xpa7nkTVTCYhyjsfXXw8/a58YeE72ymtdYKTQKiIlw BKoVOi89uo/Gum8c/Hu6+IviO88Talf20N86gMLb5Q4XpwO9eTLL1RrOtDqrH0Ec49vhvYVbb313 +88+uvHMDiUNqY81jkvvOGzjt9a46bxJbzndlpWHA25xz0PH09xxmuqFKTbbVjirYqmlaMvuM2fX JpgEhtQGX+IjJP51Qa5v7tghdvmXAxnGPz+v5VvGnGPxas8+pXnN2jsOi01mJMm7OckHq3fn2q2m lF1MrryF6KSAP6dvp9atyitEzONNy6DRahQuVGzBye49h+ZpPItPWT/vr/61ZuT6GqpQt7zsf09W dmsCJK0yzNGSQJGAUN25HGB2Pt17VAtvbaze3F3dSiJCdo4OZMDqATnA4xk1U4tSs9zJWNG3Nu1t L9lilSTzNysT/DjGSR0yMY+uKt2zwwect6G8t4ti7AfmJ6dOtCi3pc1Ure8Ma2khaQq7PJ1y6/dH sD3+vpUYsxdzwQ4G1ctJhud2D+tdEI2XmY1ZXWjOjtrR0JgST/Ro4/vdXd+4Gfx6cVoxaJHI32gr tKE5HV+n86qa5oq+hEWoybfka1vJFazQqzbISSFTbgHHA3H/AA9au3siR2snmx/KzfLtwMk9v60K 0lzW2Km2uVLdmYQsZijjBWLqzdS2R0qK5tpNWv7fwHosbHeyNqcy9cZyIT/Nh649K8zNK0KWFbT1 /T/gnpZbhpV8XThvrqfol8GPh3Bo1hZqsO1cDgL0xxmvtfw/pQghi2jGB0Ffl2KqOpVbbP2HC01T ppeRv6vrNtpNhPcTShY4wSzHjHevx9+Pfxen+JGvXVrYTn+wLOVo4mLHbM/Rnx3HYe1fQ8KYT2uK liJL4Vp6s+d4uxnssBDDRetR/gtX+h89ojqI7Ry0licNnGN2evNaFipDTyyyn7Ki+Wie/b64r9Eb t7r/AKsfmsYp6m3YWkPmr5gzKAOBzjJ6Z6/5NdQLdFTy7lNsRHzYPLE//qqo2er3CXuqzAaeIQrg EMVIGemP8a1LFELFVUkg+vBP+RXRBWSRlK1j1rwxNO1tiZN0wGFQDP0P86i1HQS928iEeUeHJPTP bmu1RbUU3r1OZtJtoS306O3to7cIXUsWGf4j2q7NaQzskUw3H1xkL7f5/pXXyRUOT8TJu7uLNZ7m gsotwBPJ6gen9K7GHSpbWOB2+WPgAnjkGoqcyS5XsNPudpYKqeYZchSpBfHX8/5122iGzh8x4c4C 4BIPp1rrw9vdW6Jn1ZJYMs14ZWdldn4lB9P8/pW7BcSaZdPIk7NIx2KOQWJ9a7ac5Jqal1MLWurH d6fd23kaZ/aV+RMrMgUdEHByc+/v3Fb8+o2Wh6pcvFFMZZY18uUk598fif8A9denBq0W5Wfl3t/w DnlF82mx0+m69PpupyTpG9wJIxI0cWSUjHHPPTJHPv71veHNT02W+tNQbUTE1xKfkXkpjoD78/mR zXTBKUkm7Nfr/wAOZSbWsPQ7DS2v7y+a7s7yXdHc7Co+7sI5478E/wCc17vpuo2sWmQWurxGSxtJ 98ijgsp7+3JoTcrq+mv9fgZS1W+pnya34Ye4nuNGuGVZS6+QeTtxxx+Z/CvPZNb3W9wTchJI8rao eMDqT9f896u6UVC6f9X/ADBRau3uRQ+KDFEt3duLjjkZzjtj+dTWniH7LBqHlKAmRI65+bocYpSi nK9tf+AO8rPQ4TV9d1G+uom05xHaqhWVXk+9zzXHXGt6hDPBDpLpuimGW4yVPUfl3rCUmk2lotr+ n/ANbW1e5gXHihP7SktzCwG9i8wOdoP/ANevOPEfiC0tY4mitj9ojkHmSsMMVz/h+VYVp07Sv0vo +/8AwCqcH1PRzc6Vq8uhxxyRrqHl+YIHbIbI4yO/Wual1SKxMNnf2MZMNwziFDlX6/8A1zmlUUX7 /Rrfqrq9i1GWzM5rFrmNEtXMVpNcAsAeYtx6f/q7fWviX9of4dw2Es2s2cyyqJmTDDjbnrXp5DXl hs1oVE/dvy/KV/x2POzqh9YyyvTW6V/mj43vdTksZVshs+1ucEhRwpzXzZ+158GdB+Ln7Ofjjw/H IZNct4GvICeSZEG7g/hX6xmlD63l9fDNXU4yjb1TX4H57lM1RxcKjlax/JX8OfEuo/D7x3FcR/JK srW06kY6HBBz6V+omoyjxN4V0vX4lDKIxJ8pzng54/EV/Gud0/Z4ijV2d7M/ozhus6mFxOGvpbmR yFi4UiaSMFeBtB9f5f59a9B0Odrh7cg4cnHOflIzz78fzrzMSrK72PYwclflO0dPMdoSNrc4DE4P 0H8+D1/CvPrkTLqkaqQgTqC33snv+Yrkpu6aO+tc9Z0XUZYoZJHOVyQACMjp0/zjmvPPH8JhWS8W PcQeSxPBPTAwNp/nSw7tW06hX97DtHjV+zS2dxuYDYQ+APu+30/z0rnFk+UluMHI4HHtx+NfS09a asfJydptWKbXMpMsQ/unAP6c9qu6ZqCwuFK4fcMHPXt+VOSTi0iIv3joX+yShkuI1IZT93nJPc4+ o/wrz7Xvh1pWsTNPaALIP4vf8z/nms6c3B8yKq0Y1oqMtzybUPhnqVrcyeT80XVTjn9arQeGNRhl Cz2pTPA4OB7fjmu5VoyW55EsNOErWOk03wrcNtDW7bSOcg89PX3rsLLwrveFduFPcnjGOhPbFZSq 6NlwoTasi8/h6K3lYNIuF7AjPTJz+GfrTEj0+yUHeDIF9uvUDms3OTSSOmNGMXeRnyXlnHEx285J bbjgdPT9awrrWwEWMPtQjI46H1PvmqUGwlOMVaJz15rsaW5zcYcYAHXPXjn0/wAaw/8AhIn/AOex /wC+TXRGGhyTqq+p/VNpYs47bynuiSWZpDtJB7kdfbH0xW7ZyefM7G2RYSgVQV+d1HXk8Ac/jmpt HdvYadtEtDQAW4hhs0kWOEknZktnpjJPHPHB/SiSP947CMu68ZLHGR/P/IprRrzBt8rXUGic7JZz nBwIyx7HOf5VoWFoi+aIwQ5GWbk7M89evAroW2hhdN3OjsYHeNZVQlFOVLnGOcFvc8VuxQMqMIsq xwWI5Lc88n+fShLm0+4q3Kr7XGzwvaEMYwY8Bhnnb7fyrNkVrxSHfJXhVyQT7/THas+bmi6cUWop SUjN1DVW0WzCiIPqjyeXZIGOZH/v/RRyfU4r6R/Z/wDhe8Sx6jexM99MfMldxlnY9Tnv3r5LiLEq P7qPRWPseF8JzzdZo/SzwhoUdrbQIFA4HYDnj/P416oJFtIC2cKq55718G25M/SIK0Ufnr+1X8an RJfAfh+cm8lUm7aPrDF6exP8q+ELdrK6+y22WCqeVGBnnPOO2a/UeHMJHDZdBy0lPVn5XxPjPrWZ yhF3jDReq3/EtzxeYMKpEe7aBnGB9a1Gjt4NPPkwFpT1xn5j6j8xXu6KMm90j55XVkbmiWsthCLi VAblsM4x2x/+ut6RIpJ4SxzKxweR8o9q1pr3UmTUs22vkX547dlhjK7m3Y4/DIpIbd4nIjQlVbPO DuPrW6SUrsxu2rHe+EpvJuDJcsw3DAx0FelTad5kSLjMJ+f8+a7oy5nB/I55KyaD+x5XaOSRQETO 3px16/Wli0tAJZWGI+cEV0tKWvTUhdEadjo37xLzZlgOA3HNbVzDLOEhbKqCcDPSk78iXcqL1ZoJ ZMUSNgctjPH3OOx7VsRWV5GyGM7Vxjnv6/5zWsPdtbcTe50lnbG2t0YufNQkDHIPtWrapbs0Fzfh i5fIwvXHbHpgV10WrpS0WhlLVaM5q6hv5J70x3O2MSF1UnlF4x9DnNde3iqw15dAhkVzdwY85geH UE8Zx3xj8a78PNvmU+trff8A5GNRNpcp0eka9dvr18LC+ay0WWPyrjABOQDtGe3U9x1ru9JGlzR2 cGnTtHa2zbpHYDcxJ6/j/UV3JuabT0V7X7aO7f4fI5pJrQ9qi1HT9Mt7SS0cjJ6k8sTxn3/+vXRL riWrTW8sbMDHucOemR3/AMPerjJJqMX/AEyHomzn7jW7Ozvor2xniSdVG9MdfX9K5pNV01tQa7uT GUdmXyz/AAbiOc/564pKMdFpa/8ASDV3XkcnPPb2F7dw2k8rB3KquDgFuSfwH5YNN1qze0TTtYhm kbTpI2MpDfM2MZJx0Hp+FS+aOnM9O3a9vw/UHNcyZh33jfTbu3S9tbVQbaNEaLkeYPf3Pv6fWuB8 Qa5eg3q2c0avMEkCqfujpgHHPXr/ACrGpyxjzU16a+q/PUuCd2pFDS727UahGWQSxkTeWxBMknXg +nrVbWbyXXFufOt4ba7ucAO3SPaccdM+tc87uPI4K7v+v6s2VuZyR5hfeI/7HupIZJWe5iYK86H7 wH8ua6TTrvU7nSrvxBA4ECghHlbJJP1rl52nyp3e7XR2N0vdRJpvjeHSbG4WcFyU3ls5CnHSvEPG WrRapoGpR6gR58yvLE8hyit0AH0/z1rbC1r4igovXmX5r9SK1KMqU4y2a/Q/POS0OmJcRSyma+lc s8xIJIz0HsKbJbQ39ldadPL+4mhaN93GQwIP+eRX7zRnNwpupvpf5n4/XcFiJKm7pPT/AIB/H/8A tQ+Bpfhl8f8AxzoBjKxJqDzxcYyjncCPSvs/4E339tfDJrRmDMgdenXv6+9fyJxph3hsXiaSX8Ot JfJSaP6G4Lrc84/36X6JmNHc7b2S1bOUPGRtH68Hsfxr0zwlMIJZyzZlJXnHTIHPHvnn86+bxSvT uz6LCytWbO88xpp/MKs3owxhc+n0yP8AJzXA6mq2t81y7kksRywBJ+vb/PtXBSWruepXvy3Z23hy /a4khthgoRk9x9Rj+f61L4ztoLrTplYZZUIBBz0Pb8KhNwrpod1OjI+d4ZFlivoAMMEbcO4GBjH+ cc1xqXJibDxkjOTkjqPfGO9fT0f4aR8jXdpuxX89W3LwrYz1HQ8dPxqMy5CnzSAeRwPXpWltXYzb 7mlDeoWV9xZhnhTkkZ68f5/KpUvpCp5wgGAM+nAHX3x3qGi1JJKwSXUuBLvO7gA9unp+GcfWo3vC wQCLLg5zjOO5qeW1g55X16jX1ORUchQMDrjrnHtnpnjrz7VmXeqOqF2lIHLNg8HPI9+h9aahZkSq aHJX2uqAwa5xxt4PGPw9sfkK5u51yFEZYyWYnI6Yzjk4NdKh0SOOrVWtzHl1a8lBaJSufXuM/wAv SsSaS4c5knYgnpk5H5Vqklsc8pykVGhg25ZiW65bnr/9f/8AXUPlRf3k/wC/Y/xqk5djPll0P6x7 B9yRy+Uik437uefQY/8A14PQV21qkkqq/SRjtJBHyr6D3z1IHrWHLBXsjem21Zmn9nHlnYQWZuD/ AHR7Z6/59aozMmCWG454yNuTnj6f1q6e+gptpIFtVDRyysDnsT1/+tk1qWMc0ilgSVc4yRgAfh27 f/rrpV+XVGDvdHaWMCkgzy7W+6qL29gPx6V1En2AxparIvm7R8zYzj6Coab0S0RtHlUbye5lX9gI V2mRmjPU8YX/AArm5XGnmS9mcR28YYtu/hUD+f8AjWNSXs06jLUea0O5e+F3hO58eeJF8Q30DC2U 7bWNhwidjj1PU/Wv1O+HnhOOwtLdRGAQO3BX/PevzXOMR7StLU/VMhwqoYSGmr1+8+ibGFbeIfLw B7V4l8bvipD4E8P3MsGJNUcFIIsgZb1Oew7152X4Z4vGUqEVe719Op7GYYpYPBVsRL7Kf39D8rr6 abW7651HUH3Xdw2+dscuT/QfpVaTQ0sX3WcYyfu8Ake39Pzr9kjTUIRjFaLY/Ep1ZVJuc3rJtscl ndQyQrKuXP3RxyT39q3orOEJGj48/f8AMfUj0qlHmeoc2l11N1EOAXX5RwTjrUsFks0plkQ7Tzxn mtomUnudBBpMsv70A7x8qL1yOtb8FhCJEWSNgQMHaOv+f89a0SUtxXSWq0Op07S5J3j8leSwGO5A /nXvej6C1zYxQyqBIOWxn681vS3aRnK3Lcuz+G18pZXVi5+UDjj0q7a+FPNcpPEohCc57V6aTktd bnK272JbfQkkuBDEvcKoXPT9KTV9HayvTDtJc43FecZ60TjflRUXq2mbVh4dd1Qi2JnYjLV1dt4U kQlZNrqOFHvWsYaK+wN9jQHhaZdsW35mOQf7nPP+feq19prW00Cxx5SMd/4iR/n9a6KcfeTIb0bZ xF2V0+8a5lQBJflkT24P4f4Vm6pc6bpXlLpsJ2lcdBnP/wBauiMoq0nun+tzKzZCmqmFIHwY7SRs yr/fb/69d94eJuVSeW5eCNpAQvUuM+v+e9dMZOTtF27enX9bGbXKrs9Qg8RR2U2nw3CSStlmQHnH cHntWLrXjjULkuGu2EkkoV2AwcA10e05Y2T1/wCB/wAFmVuaXM9i5ca3ZzSSQTRkRIq7SDy56nPf FYdxq97dXTNbwYhVuiHJPoT61MpRT2/4b/ggo+7fobEt1qGhMb9AZkKBcEDBY+n5iuB1HxTrltpu rSxkBATGMvnAPOB+P9KKtZrVK7V3f+vQUIprmZyTa/psOk2fn27GY/vJ9h/1g7H8PSsO51+/aOK8 ghRI5nIjBGSq8kfjiuN1IqCS1e/kv6bNVHXUn03ULZG8z7TulBJmkXJx9f5fgK5zXrv7XYTTQXP7 6zcNESeWXPT/AD61k25RlGMtX/w/5miVuh51rN9cWupabI9xGv2t42dX9OvP5/rXWaV4jW+vL3wz JMkWlBt/mFuWOO3+PtXEpWlJWV3p6XuzpSMnxfLJbWbGy2fYlO1sHsM49q+btX8SX+peH722Ntut 0kIVyfuLz0/Enn8KiNV4fFU3a6T/ACd/zLlTVSjNeX5nz/PdRxO8JhGAx3MVz/j7/wCNVbqaC4eG 2g5BIKsQee/Xiv6PpyVVU0l0R+Gyg6dSV31Z/Ol/wVl8Cnw/8Z9D8WR24WDUbQbio4Z19fX/AOvX ln7HPi6e3HiPTWCvHJBhFfH7s/3lyOent+VfzD4n4VUs4zOFrJyUv/ArS/U/deAK7awEn2a/Bo7/ AMS2qWmr3Atx8u/PXrznHX+VaXhl5o5FcP8AKM5z17AZ/P8Ap3r89bUsLGT3sj7lrkxcoro/1PUo 9S/cosKkAZDbcjcBz3/zzXM+Jo1lZL0MeegIwAO3HU9B/nivOp+5Oz/4J6VWSlTZq+CMC5WaS4Ii Cjrwc8+uPT/9Vega2IhYuFQbdhJYMcnPTPpn/Pepqv8AfX2Lpa0dWfNEkK2+p6gI2G2QHC49icn+ Xboa8xleVpG2qphGcnunI9P/AK9fR4Z81O/9bHyuMVq23f8AMpuVLMpYgDqcj6dP89KljbzJU3L8 /wB4dDu9MDjiujfU5L3d+hejg2OpKn055x7e/Ge9TlQW+U4GRkEYA6ZyPap20sUrP3USSRL5ZaSU YJwCQPpzxj36Vg3urW9mivuGT8vr3/Xt6URTlohzlye8zkbvxEGYxxA8MWC5Axgdq5+5uby6XAY/ yOce1bxio6s4Z1XJtXKEsMg+ZskE/U498Ae1IkaAsijGSSVI/oPw4q7tmVtdSFyVMgCYTsSM9BVI hBk87ep/+v8AhSDoUJpGZfLRhyvPbOP/ANdUvLb+6P8Avta0WxlKR/WHp/kyxwt5W2NW/dxoQWVR zkn37nr1GcCu5hl3MOSLplAjUHJA7nn25zWSV0mbQaV1c2Le2gtreSXbKfmKiRjnjpj+p/xqVIJI 0WV0xGRgDGMn2HryauL5r67kya0I3CNIwBZ5QOAoztJOa6vSLZ5E82YBnB+VSTjj/PNay0jqTG/N sdPCJYAzyQl2PAI7H9MfTHb879vp4njnaHapyDknlj0x+GOnv3pRaWqLkrq3UbJbNA5t7hsIQct1 Gcev5jHtXlV0k/jfxBa+F9OXNjC6/anHAkbg7foO/vj0rzc3r+ywz13/AEPQyrDuvi6dNrS5+jXw h+H9tpVpaqLdVkG3Bx04HWvsfQtPWCJWC4AHUgDNflmJm5zbbP2HC0+SnGNhPFfiWz8PaVdX15cb YI0JPp0r8uPiF4w1Dxz4kutSllZrXlbeM5+RM9eO5r6zhDB3q1Ma1fl0Xq/+AfKcZ43koUsDF6z1 fov+Ccf/AGeqKARkk9Sx+nGPr1q3a6WjFHlc7gfl3Hj/APXX6BFNaXPzhtbm0ulC4mEsygKhwgUc knOOtTr4WuLmQC2U98kgnd9fSritbrcLt2sa0ejrbOsEuNwGN2OB681qLYxxrtjGCxx9zOfx/wA9 K0jG5lLRs9E8OaBELeS7nkG3b8g68e9WpdPa6Mf2S3CxhuCV5b1IrRR95yY5PRHa6N4fma5SOOE+ chU8jP8ASvZ/s0FnLFYwOPtDgF+eM8fy5rqpL3tDOXw6HcXPhyGwjs57oGVGwT5fOPrjrXoll4GG o2aX1rbEwsoGduD/AJ5r0aOsWm9Uc89GzY8N/B68nvZbqS12QRpvLFep9BxXK+Kfh+sF358rMm75 V+XqaufkTBvoUbfw95EMNszMQG3MwHb/ABra0XSYUvZxcScc7OvWtoLSw3ubF/ZR20EciT5YZDoB ljXnmt3FoE3iErGvBBHO78f8mtUklqRe7seMavJDC7oOZid+GPAHpn/P6VwMmrW8+oXnmbWbCrH1 IQg//qqZWe40nbRl2aedr8RXO3yQA67ecen9P8muti1VG+yRM7RsikA5GFA6fT/PeuinJxbto/8A gmc9rXNs6zO8MEouiLqMY3Ejke2e/wDKqf8Aac+ppJGJAEAAaQjBB55H/wCv0rZzbtZav87W/Ayc Xe5oJfTQJdsWDqkYQEdTW5pV1NFF58AJlAXceCNvt+dTzNTv1s/mU/hd2bd5exTwK0tw5s1B3HH8 X+c15nrbpBo95dW0he3EuApOc/Wid5X97v8AcSnZbHHxavaabqkUmzzLCeHyn3LlYm9M+1U9WaGL TxuutpRyq4HJDdevr/npXK5RUZcu6/LS33WNOW7VlqNudV0q3is9F0gokbL5tzJLzlvT9RXl+v6m +n6uLC4njltJ2WaYQ9VB6CuStLljeCXKrLz1X/Bf3HRCPkct4p1iG81G5tL4r9mVN1uE+9uwCMn8 P51iaRqKX1/p9pFMzXTpgswwVGOnPAPvXHWf72S0T2t6PT89Tohzcux3Wmtq14J7HVI4206QyRqX bhGx1z/n9a8CNwbOy1GKS2VtNheWLLOFEsnJG31A9f8A69XJSajOUNrq/lv+V/mUmm2umn3niXmx zjzzENhzmM/X/wDVUE8zpPJCYlCqDtKjnnnt371/ReTSjXwWErLrCL/BH4hmNN0sfiKc+k2vxPyO /wCCu3hGPVfhl4N8X29ofPsrvypJe4Dfzxx+lfjx+y54l/sfx8ljI7CK5iKDjow5HA/KvwXxYo/8 K+Ikvt0oS+5W/Q/WOAqvJDCN9J2+/wD4c+2fH8DC73xk5fBIyVGPfP8AKub0mZ4mRpSgXbu24xjH oO3T61+P0Pewa9D9QxfuY6Vt7no1tP5axy7iYuuF65PbNVr9Z3U4c+QBjJ6g+/qOP1rlVufVHbeL gSeHZI1nlSZwZxwF4+Ufh716XIiXNkQwwCM8joAM8en5dunesq1+d9jShZ02mz5q1kCLXLiNGKoH 6A8EcAH/AD7V51d4t7iZQMksQflH1z/k19HhFekl6Hy+Nsq7v5lDOTt2lju5/wD1c+v86vWvzOjM gxgqM5yD/n+lbtnGnZ3L0S+Y5iACtnryNoH6fzrTlEcaEsqhuAwAGe3PTocDjmod76FxetzhfEOr tBthifnHGPTjHSuB3Neyb5RuPTBHfg/1rogrLQ460nKVrFkQLGyjy/mx06AewpjomMOP3YG4AcZF F3uRylZpAEeNIwC3B3fnx2qnMAWO5fmxgAcEnPaqJvrZlCSUjcrhvLJBx3P+cVSmIGFk+7nAJ65/ H3P86pENtGfJsYPhSMdRjkjIqruj/uyf9+k/wqvUze5/Vdokc6wQqWIJ+dgCBwxGSWPPcccnGTXf aUyQrPdF9942Ei3DG1SeSfrjp/k53fQ0V022z1250CZIbISzD7JFACo65ZsEseuPT8q4m5u2lnxG e+EAUge56U6L100FV0aNKyIMSfZl8xM/OTxvPPJFdHZyCO4hAcvHk4VR8oPXHufatrfeCbjZG8Hl ZJFW2PlL6nkmp47WWaSExzEFRkrGenr07/Xils9NRtuXSxy/j3xFLZ2sWh2KKdanOyLaQSg9TXu/ wG+GIsoLe5ni/fSfPI7DJznPP618bxFilzcqe2h9rwthE5OvJH6L+FtIjtoYE27eAAAK9AuLlLC2 LyABAuT0FfDNPmaR+iw92Nz4M+NnxAl8T376BYTn7DE2ZNpJ8xgeR+H9K8Ug0plDuOemV4yT9a/X Mjwf1PLqUGvefvP1f/A0Px7iDHPGZnVmndR91fL/AIJoQ6c0pKpbZbHJHYf5zXR6H4alv5WKwbbO M73bAyQP89K9lLU8NXTLUlrIs8hEijJ+TCjCj/8AVXQW9kltbxQLMXnbl2A6cfp/9atIpq7HJvfo bEWkwCIM9uGiPG/HUnuP8+lW18MvfNbw2MeBuBc7eF6Dn9K1in9kybex1N74XfS9QsrWC/3wOm5l J6+wrQk0qeQQ21kAsijq3Qf5Faxj3Wwrva50Vvetpk720cn+kkKNwPLn8Pauu0+GK51eG6uJT9pI AVdxPP0zXRBczSEe6eH9YisYbm2kVZFK4G8E4PHT86+m/wBn2/0zxDqcvh7VJkjjH3C3QsegGa7K a5L21M5a2TP0Z0z4W+FE00WsYXew5Ix81eP/ABO+AugXOjXclnOq3EaFkyB1HNckq1RuzF7O1tT8 7rmxOm3lzBM3+r3Iwx97Geaq2UtpMhmmIEg3FNoxz7169NcyUjN36lbTdQit2ubh2jecnAZsEDp0 FeR+L7rzbi4ETAk/NgDgetXJPluxK587azdmeS4jjyZSScj/AD7V53HfLbxzKy/6U8oCAngYxjr/ AC/xrGyupb2K1Sep0iX6iMQIzmXPzMSevpn8f5VVe9u1uZ7e4mY7eSB/Cv16V0e0aX6+YkurZsRa 5BDGkAcyMMgZ7ZJrT0fxCLl5LGC2yiAl3wc5HTNaXguW++xg1e8maaa+qqY2kURoA3JyW7D6/wCN dDc+KXsrGGWNwCxDnHOB2FPna999EJdmVbrxlbvpEVk1z++eX5VXqc9K4qHUnv530s3BSHeWbdnC nj/69Z1J3jGz3VvvKSad7ks9xpFvObVrwNZopkYd92enT1H6VhatqtneW8l3bjHlHMceMlh2J6+l c9RJRabV/wCtzWKd0zi9VMDR215P8srgNwcAH0wPbt/OuP1+SaW2eK0aNL5lByDlmGePpivPlB8z klvr5I6YvRaHKBZUgSa6DmdFCySOSeepA/z/ACrGGsRX2rI4mWKNBsjlB27D/n/PWs5SbV1u2vLX r+KNoK92jcXzvGOhX1npOtNHqEVwRhG/An8a8M1WC+8N6u3hzV5RcwIx2zb92xs5yT+JpVnWdNVX K8NmvX/hiqesnT6ow7XS31DTVexb7skg3KAQeazZI1tLgbsk9MnjOfw9c1+88KYt1OH8LGO6glf0 bR+TcR4P2OY4iq/tT0XyPjv/AIKAeE5PF37LXjww2LPcWircZ2cjbzwccV/Ll8MNSOleP/Dd0rHi 5VG988Yr8w8U6Sli6FRfaotfdKX+Z9bwTU5aMf7tRP8AI/ULxvC1zaWt6SQChwwyCMAe/v8A56V5 pplzJczwKY8qMdFGMfnX4bg4qWGd+h+x5iuXF3XWx6TYOwMUYYAPk4btnnJ/TiuovbRXt44iSJHU ngHJHI5H4d//ANfJO6nfqdNOScHqcjaxeTfeYqMr5G5umenftn8K9usk36a0jPtRkwCFPy8evp/h WVfeKZph7+9Fnzh4u09oNa8+OQly2QwPB+v6/n+NeS6zJFBrFxB5mXOOD06Djj8K9/BScqR85mKU KzZREjKyLuwwyOnfPoeuKuIAisWypzzj07D+fBrr7HAjUtJEWQxkZK9/U8dcdqg1efYsgJIj4LYX IHU8Z+tKy5i72geMardPcXTRrI2Ae38X4/5zV60VkQ4XGATk5PbHH+fWuh9Dg1cnqNncBiWIBwCO cnpjv04NVriUARlSRGCPU+h70rdAb3sVXPmM6Fck/dHXH4dPwHpUKwNLIgG5toB7ADt/kd6epO+l xjWMrbgZCq/eHzeoP+NR/ZolyJDk465zj8f1ovfYTVtypLNahQQvzZbk4+Xgj8u9UvtMf/PVf++V /wAKuMW1qZuceh/TzpWpYhla4l/fM2GVc4X/AGR6n1P/ANavQ9J1WAr5ML7pCQiBSTn1quVi5tT0 Gx125FjNDLckF2ALMMkL6D35I+lZytG0E0iN5jN3Bznnpyf0pwjyt2Bybszp7F5I7aRbsoLjHywx EB+neulg2pZQyXnyIOgXnHfk+v8ASla/QtKy87GzDue0aRWZ48bQqjbuz+tZ+t6wvh7S5L6UoiIM cdc+gH+etTUmqcJTb2KjFzml3MT4SeEtQ8Ya6fEmqxNl3xGh52KOg5/U96/Uf4f+G47CCBDENoUf w4H0P+e1fl+b1/a1pH6vkeG9hhoq3Q9+s2jtYFzjIzXgHxi+Ictray6PpUuL11KswP8Aq1PX8cVj kuD+u5jSpNaXu/Ranfm+M+o5dWrX1tp6vRHyCZ2a4WYx4IOBK55f19xWxKm5rWHLAP8ANvXP51+x pWSSPxabu233OmsY4LW3nnQMY/uj/PftW5bXd1Lp72+Qluy4VV6n05rRLsJy0sU7K1RXjeUAtIMD vt966S/srPRoIoYVZryYAyMf4QcdvWtIwb2Mm+56h/Y6T6XpcCqI7ZFDM56nArTml0iK3XTrKYeS v+sfuxFbKL7Aym8NvqkkM4QRsiBI2HPA/wA/yqrBaPbSzTxs5cAhA+ee/wDnNaJvdbE+ZVgkna9j uPswF0XALNkgDv8ATn/PNewadHp8E1tdyxhp8cMORW8EvkPsa6ztBqENyJGMGdzIOAP8/wBa9J8N arJpkhvtPcpL5odCGwQa6KTs2zN6n3L4c+O2oQ6Tp0b3v+logD5PJNdJqHxVn1ayZ5rvOVPy5610 KnCSbSIm2nufIvxCusXd1qlsp2tyR/8AWryYeIpEst21TIScg4IH0rSNoxs+hCetit/b1v5bYiHm rk/8C/z715d4g1NxHLKB87Z4zyBmqekA2aSPEb69j8owBgbmSTqw+7/nmuMuBbxPcRSjE3UPnIOf 61ildprp+Y3zLYhuNfgtoFjLDfCQVP8AEe4/mK5G21S/1C+1C5S4CY+Unk8Y/wDr8fWtXLkty7v/ ACFFbtm3d3UNqLdrWR2m8vdID26D/H8q3dP1KfSLOW3Uhr6dQ3ygZUEc/wCfaiMuWV90l/X4kyst GT6ddxzSiSd8x7Sv+6fX3rMGvK0DWpZnu2crs9ADx+gpuS5Lye5FvfLMhW7mtriBhHdKmXBJwuOw 9aX7TK8wuZGH2aJwZG34Lnr/AFrOTd3yrTT8v8ik3syPUYYr1pbmNttrkKMHJ5PHH8qeJIobHybQ b3RdshLdcfrjpWTim3L10LUtTk9eiRBZzvKY2Yb1DHjivM7yLVNRuI/sc+JpZfJJcY29/wAK4K/O p2j/AFodNOV4nL31/qNhqQtb68K6db5EkwOVkfpj8+9ctqenz/ZJLuFwbeVx5Y3HcepztFYVXKSd 3qr/APB/E6Yyilc3FW68JWgitHxPLFu37uV4OOh9cZry258QaQmqxTa9Mxs3fdLkZ8049fr/AJFZ 1JuCjQlK0d/v6/cb04e0Tkt7C6Z4ks/I1GGxUpZiUmIjg4P19c/pWHNPPLM00RySTyO/+cdfpX7v wVy/6vYeUdveXyUmj8m4rk3nNSHZL53RznxasYvEvwY+Ifh+dVYSaVNuB/ibafT3r+Md459J8UP1 Wa2vSPTaVf8ATpXxnidSd8DUfVVF/wCkv9T2uD5v2VWPZpn6w3k6at4H0q73HayozAYJIK9f07V5 TpfN1JbythUc4YknseAP89/x/n/BJ+zqR7Nn7ZmT5p0Zd0j1Wyk80xtkZHyq2AAAB+WeldFcw3Ep W4iIAEfI5OFz6nvx/KuObXNr6HTTfuNX1Me5tmNwr8LG3CsfXH9cV654dBubGOCQbmKDOOuM/T36 /wCArKs/dTNqOkpeZ4r8SbCO31qFsFSTkAckjjv/AJzivE/HfhjUNNis/FsKF9PmbY5xwMdP/wBV e1l8rUo36ngZnTvVlJPbU5SCXzI0lVx05xyT0I4z6VpR/vEPm5HVQc8euf0Fel6HlRbt5Fix/wBb GABtzgc/555qpr4lMEqoDtxkemO+M/X/ADxSStJXG/gZ4q0zjUiGYEZwduc10itJHk7Rtznj/E/1 reSV0cMXuVJ5AxcBDvPY9CfwqjcF32h/lULtHPTHGP50K4O72GluQo4OQckZx29f1+ldPpVks2GO X4xg8HHUn27+1TLRahG7kXdU0zyYUkXdzwRg4Hvz+P5Vx0lmqsiBW38kkHgdv8acZIVSMk9Ss+mA kc4ckAsew9qf/Y8f/P6PzFPmXYhUm+h/RdpUvmeXiQhR8zE8bE6n6c49TXd6VdWsE+bNi0pJOd2Q o7nPuf8ACt7tO1jLTtqdhBcfbYx5sjuc8kjaHzzgD+f/AOqug0tr0mARxMSpydi52jgHk9KFa2o4 v3tDsbQk3jmwlCTkfvHcbmHqB7849q7ETxrZs9xcKUJACnoAO/es27bGi2fYZDqTJF57N+4AOxcb Rx3P+fWvL5Zbj4j+LotOsUI0S2k+Yq2Q7j9DjH515Wb4n2WG5U9/0PUyihLEYyEWrpan6KfCfwdb 6dbWscdvgAD/AD7V9gaNAlvFGSowowVr8wxFXnk3c/XcNDkpJIwvH/juz8NaTPO84Dj5QM9SenHp mvhrXLyXVNU/tW5nleeYghU5zg5wfavt+DsHywq42a391fr+h8Xxnjb+ywEX/ef5L9TQgFnOBbyx sJSNykYJPTr6dOa6GNvJgKybRGGCjHJH+frX3Om58F7vxF62FlNYyQCZmk8zJJHA/wA/5xV++ezj t4beFyZyAW25BA/z/OtES72Ymn3aJMjhRtjA2LnqRW7YxnWdTjJkDF24XHb/APVXRBx2uZPsdp4k 1/Zt0yCUrFGqhiO3FU9BVzbyF23Bju3H/H8TWsnfVCb9462z3oRLExaHG3DYGF71Pe+VcvJJZXJy gyiA8H/GkpXs4/8AADU5Y6ulwvlTnaynDNtx+Rrr9O12N4IfJdliVMJn1Hetrvp1EmixFrLssqpc k7sAljgKRiux0rxSlulvF5wZUOSR/FWqqKNkxK71Z2Fr41n+1pdRS4XjgMenSvVrHxwZUR0l+X0B 6/rW9Kokrkyd2Zesa7c6g0u6QNbMMYPavHdTupbKRo2l/dHkf5961nOzTj2M4c13fucld6vO2As2 1cnIzn/PauY1TXJ3Uo8wMZz3yKcanMrfmNp330PKde1KG2dZhOGnxgAnpj3rkptetpJXE0m1I1Bb 2P1pqKScWyZLqcJqt/Csk13HIpVMEZ5wOf8AP41oQapbWcdxcm4CggELnqf8k/lSj8Ts/wCrMpL3 bGzb6jbySm4llXzpYgVXcPlwP8/lTYrq4gnN9cSsI2U4bPTHP4f/AF/atHdNK+/9fqS9VqaHh7UY r7BM2FDMUjz1Ixz+tOs1tftNzqLXSiTeyqB/D7/n/Kok21Fx20JWjYtpNOs+olnLlUJPzcDk/nUU BF5pRzITcCXLBCcHv/8AXrLnb9dR936CT6nLHcxJavstoWywPO5v84rHstXlk/thJ5iZJWLBlPQg VnKbuknp/wAP+pcVd3K11e3d0Psd7IHuNgaFixwm3+fSvMNcGvxzW5hmQTSOWQK3H14/zzXFiKlW XvxWvX+vmjppcsXsc3qjXvhi8gtfFQWWyldZB3wTk/1JqlHr+m2uszairloFcLHbE5DL2wazqPli vaaSWj9NzaK5vfWzI/EOszLcJZpHumkfeTk/KpGQOOgAx+VeYava2q6fbQ3Vus+pS3m1FPJQ54B9 u9c1dxqSbltZv/I3g+WKs7f5ENjeSzahc2N5ZRwrGgOxBjp3/r+NXriXzGX7OrbFOAoHSv3HgGrz 8PwS05ZSVvmflHFsLZ1J94xJ7S2Oo2mrWLJhLq2lhIYDncrDJ/Gv46fjloR8L/Gbx9onCmDVJwMH /aJArwvEmPPg8JUXScl96X+R6XCUrTrLvY+/PAd2L/4Y6XvUGRbdPnxnBX0FedF5o7t8keV5m0HP +eOK/njCLlq4iHmz9ux0ubD4WXeK/I9X0JBPHGpf92wxtzyT0OP69O1dowMUJG0BSemOuOK4az95 3O3Dv93cyLiZXcM0g3rhlwTknJ/zmvSPCd0fJR2I2E4AzwfQd/TvWFVL2abWhvRa9o9Dz/4wxzJN a3EUOSGO4Ffv9z39hXsHgLwDpnxJ+CWq6XNChvo2l2dCVPbGenT9Pxr0sJK1CMl0Z5WP1xbi+q/Q /ObVNKvvCmu3/hzVYylzE5Vcn7+Dxyeo6+tSi4yy4xyM88Egc8mvaXvK99D5+zi3F77Fm3mZZ0k2 kL1znI4x3q5qoN1bt5JCjGenPoPp1/znFG8khp6NHhOoE2Nx5rnD7u/bOPT8/wATWxDqT30ayhMF RyDnBIx/9euiSVlI4YStJxIi0igygZAyMY56/wD1/wBKFjaUK7qAScYJ6/zpX8ytbkotctGcqHOM kdf8/jXXaPOI3jQtldueDgN0/Xt/+qolqiofGvM1Ne1aMQSQ4BwA5GBz0GD9P8+teXT6lcFScnJO 4n1/z/nvRCOmoVZe9oVHv5dplmbjt65+h61H/bP+wf8Avgf/ABVacpj7z1Suf0LySOmnyhHIBnKn BxkDdgV1eiySfZ4zvOSxzz1weK2Zy3fPY9e8MIrXS7lB/dP1FdveSyRRzrFIyrzwpI/iPpWEW3Oz 7HRF2Wh1ekKohjYKA3lA5x3+ar8YDwWO4A535zznAGKiL/UuekdP61M3xTJImg6mUkYEQNjBIxwa m/Z8jjFnEwQbiRzgf36+V4glLkevb9T6jhdL6w9D9QvBKJsHyjjaBx0r2GIlbfAOBvYcfSvz+p8T /rsfpq/ho+PfjtLK2qWkTSMY8E7Sxx970rzDS2YWbkE58k/zr9X4a0yujbz/ADZ+UcTtvOK932/J G5p/EF8w4Ij4I7V1SE/2PEc8mMEn1Oa+hv7h890K+nEiyyDzxzVIO4nuMOep7/WrXxWJbdie2JZ7 gMcjf3/Gu++H3/IdufZRj26VrHqZy+JDNdJ/tWbn+Nv5iu50bi3AHTyv6CtG3yxIW8vQ3QSJYwCc GI5HrxVG0ZlkuipIO4dPrQm7FoxNSA+zy8fxH+tS2JP2ADPG7+taR6ev+ZK6mrOAIGwO/wDUUKTt PPWTB9x81K7u9f6sEdjr9PY/2fC2Tu29a9S0NmEAwxH4+wrppt89iOhqMzC3OGP3c9e+a4jxRykh PJwP6VtJv8v0Fb3WedagSJJMHGEbp9DXF6gxWxlYEggNgjtwaV3eWvYrojyfVAC1wxGW9T9K5OD5 /tm/n5HPPPOBWsG23f8ArRmPf+uxzGsADQ7rA7A1yYd3kVXYlcoME54LVld+7r0RpHZnU2Lv/azt vO4KwBz04NdLcu58P26liV89+Cf9quiLb9pfz/QzXxWHsTDauYTsPlZyvHP4VV0N3aW0VnJXIOCe /FZtv2a16P8A9tFH4kv66HbIzK/iDaxGFXGD0z1rO8IM3lX3zHh+OenXpTbfPFX7lS6kVqA82vbx nDcZ5xwK42Iki4YnJ81uT/vVxTbs3fr+rDqxt47iaNg5DBODnkcVxokkkgvnkkZnUKFLEkryenpW dRvv/Wh0x2PNfifNLcJYm4laQgR43sWx931rJdVFmkgUeYZiC2OTjpzXNjW3Vd32/I6qeiSXc71Q DoeqTkfvwkeH/iHI79a8c0Z2fxvbxuxKC5cgE5A49KyxDdoebX5l0dpnY+NQE+IWnKgwpgJIHAJx mrciJ5Fn8o5j5461+18C6ZRUS/5+P8kflnF3/Iyh/hX6mHGzLfW4ViAWwcHqMGv5I/2vlUftK/FB QAFGsSjH41weILby2in/AM/P/bWdXCLftZ69F+Z9V/B5mX4Y2W1iP3ZPB9zXJ34HmwnHJK5P51/O uH/3rEf4mfuOI/3HCf4UeneG2JlXJNdxK77JfnPPXnrwv+NcWI+NHoYX+DE5K6ZmntAzEgx5OT1O etet+E1AdQAMb8fhWGJ/hJeT/Uuj/Fn8v1OX+MxIgiAOBx/SvZ/2TpZDaa/EZG8oKflycc4zxXbR 0wUGu8f0OLHf738j5S/a8t7eHx7DLDAiSMnzMqgE/vO5FfNdk7NErFiWyOSa9zD60Ff+tT5yt/Gn /XQ3E+aR1blQXwD/AMCrobf/AI8kbuYzk+vFOb95L1FD42fPni4D7WeOuc+/y0nhBQzXYYAj5hz/ AMCFdX/Lg4Y/xfmdHqXyy3CrwAHwB2wawA7kHLH+M9fcCohsXU2NCBm2TtuO7awznt8tdLYE7Rz/ AAqfxwab6mcfjRj627nzWLEtubkn2rlwB9mQ45IOff5sVUSqm7+Zk64NslsBwPJkPHr61ye9/wC8 fzok2tjeOiVj/9k /9j/4SEcRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNi40ADIwMTA6MDM6MDYgMjA6MzQ6NTYATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEAMgAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA BQAAAAEAAALgkgcAAwAAAAEABQAAkggAAwAAAAEAAAAAkgkAAwAAAAEAEAAAkgoABQAAAAEAAALo knwABwAABDYAAALwkoYABwAAAH0AAAcmoAAABwAAAAQwMTAwoAEAAwAAAAEAAQAAoAIABAAAAAEA AAogoAMABAAAAAEAAAeYowAABwAAAAEDAAAAowEABwAAAAEBAAAApAEAAwAAAAEAAAAApAIAAwAA AAEAAAAApAMAAwAAAAEAAAAApAQABQAAAAEAAAekpAUAAwAAAAEAHAAApAYAAwAAAAEAAAAApAgA AwAAAAEAAAAApAkAAwAAAAEAAAAApAoAAwAAAAEAAAAApAwAAwAAAAEAAAAAAAAAAAAAAAoAAAAq AAAAHAAAAAowMDAwOjAwOjAwIDAwOjAwOjAwADAwMDA6MDA6MDAgMDA6MDA6MDAAAAAAAgAAAAEA AAAAAAAACgAAAB4AAAAKAAAAOgAAAApOaWtvbgACAAAASUkqAAgAAAAYAAEABwAEAAAAAAIAAAIA AwACAAAAAAAAAAMAAgAGAAAALgEAAAQAAgAHAAAANAEAAAUAAgANAAAAPAEAAAYAAgAHAAAASgEA AAcAAgAHAAAAUgEAAAgAAgAIAAAAWgEAAAoABQABAAAAYgEAAA8AAgAHAAAAagEAABAABwDuAQAA cgEAABEABAABAAAAwgMAAIAAAgAOAAAAYAMAAIIAAgANAAAAbgMAAIUABQABAAAAfAMAAIYABQAB AAAAhAMAAIgABwAEAAAAAAAAAI8AAgAQAAAAjAMAAJQACAABAAAAAAAAAJUAAgAFAAAAnAMAAJsA AQACAAAAAAAAAJwAAgAUAAAAogMAAJ0AAwABAAAAAAAAAJ4ABwAKAAAAtgMAAAAAAABDT0xPUgBO T1JNQUwAAEFVVE8gICAgICAgIAAAQVVUTyAgAABBRi1DICAAACAgICAgICAAUCMAAOgDAABBVVRP ICAAAAUCAAAAAAAAAAD/AQAAGWESMQAAgdEAAArfAAGlvQADS3oAA0t6AAGlpgADjgAAZACDADIA HQAAAAAAAAAAAAAAAAAAAAAgFQAAAAAAAAAAAAAAAABAOhMAAEgCGdoAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAiIiIiIiIiIiIiIiIiIiIiEREREQFrA6ED7QGGAgIB1gHjAgABAtBgAAEDUgAAAA8A HgAQAAUABQAAAAAAHgAQAAAAAAAAAAAAgwFHAdQCYAMKAgIBLwICAmEAAAwTDPUAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiIiQAAP0AABGAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAABOQBrQAAAAAAAAAAAAAD9AEAAAABrQH5AyMEkQTjBOQAAAAAAtUDeAXKCBcIkwhd AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAHd3d3c7IDsnOycQHg4XWgBXBmcAAAAfAAAAEQwyDTXKIR8AZBsq AAAYJRwnAdUBfwFcAzUAAABVAB8ADwHWAeNmZmZmAAAACAAAAAkAAAAKQVVUTyAgICAgICAgIABP RkYgICAgICAgICAAAAAAAAAAAAAAZAAAAGQAAAAgICAgICAgICAgICAgICAAT0ZGIAAAICAgICAg ICAgICAgICAgICAgIAAAAAAAAAAAAAAAAAAHAAMBAwABAAAABgAAABoBBQABAAAAHAQAABsBBQAB AAAAJAQAACgBAwABAAAAAgAAAAECBAABAAAAEzYAAAICBAABAAAAjUkAABMCAwABAAAAAgAAAAAA AAAsAQAAAQAAACwBAAABAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAAAAAAAAAAAGQABwEDAAMAAAABAAYAAAEaAAUA AAABAAAIBgEbAAUAAAABAAAIDgEoAAMAAAABAAIAAAIBAAQAAAABAAAIFgICAAQAAAABAAAY/gIT AAMAAAABAAEAAAAAAAABLAAAAAEAAAEsAAAAAQAA/9j/4AAQSkZJRgABAQEASABIAAD//gAMQXBw bGVNYXJrCv/bAIQABwUFBgUFBwYGBggHBwgKEQsKCQkKFA8PDBEYFRkZFxUXFxodJSAaHCMcFxch LCEjJygqKioZHy4xLSkxJSkqKAEHCAgKCQoTCwsTKBsXGygoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoLAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUS ITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElK U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4 ubrCw8TFxsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3 AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5 OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgAeACg AwEiAAIRAQMRAf/aAAwDAQACEQMRAD8A8xjWXgEDnnuMe1WFi2n5vmP1xirCoDg8LnpmnLAZMckq TXjuR66RWySxwpxnOP8ACpsfZogWGWJ5OcgHp/LipkiCuegVOtVLhjcTDaOOlLcewy1tzNKCegwT itIkAbV4AznjpSQxi3jGVAI5OTz70oHzHIPPPP8AOk3caVhV2nkjrwcmlA5J7D1pVX8hxinleDgA e9IdiMqFXJ29OmKRVJzleR3H8vpUvk73CAgjn8adsJ3Fe3Ge340rjsVSuS27G3nByeD9fypEi4BA yx4Ax1qyY2c8MSSOuOMev51KEMCsDksxxg96LhYjiKxEnapYEhVHT6/1p6oJDwg59AQCcd/89qkE J8tFChs9s9fp2HWmyyfZlVFP7w8dMfy781JVhtxN5CtGigMerHt9P1rPkAZfMzlsgn/P4U8uXyD0 POCMH6fXmmn52B5BOB1xnmrSsQ9SuPmz1+g5qNyqgKo/lkVLkn7oPbn0ppiwTzk9DVkECxALkAe/ SoJQQM7elWmU8rzk9umKjlQquOSB0yKpMlo1I06enSplGAevPbp/+qmrtxt2ggnOTzTi4Cs+ThRn 2J/zx+dYs1RXu5NkIRcZweR6+9MtLbaDKRwOnNIkX2qc9OPX+daBUDaDwfY9KeysC11ICQxwM7jy eO1KqjOc8+vrTiDjIXHPY4pyADIViScnA+lIofEm8ldwx04pZZ4YItzD8eCMDqaiunWL5AuZFGG6 jaf8ev8A9esnWrgRaXcMzgu+I1HJ3E9R+QJ/CnGN2JuyNiy1CzvAGglWTPBJPT6+1XfILD5QSMcE Hr/kVxNz4S1/Q41vINs/y/vEtySV9iO4+n/16B48uIrURrDiXcCcn5eO/wDP86cYxq60ZcyCUpUt K0eVneeUiDzMBnYuACMDp2/T8aqrHIzsScg89OvrwKqaBqza3aB5EfzF+8QMDA9v0/CtNpY13oqt I2cFlHB9Dz161m04uzNE1JXRFLP5cbBRuZsAnbk/z+lZ58wsCyDP3+Ry35e/86sMRxJIByBgZ9uO efWoZlwDs+bnJVl7/wCf5VS0JZA+3PAGf4SR8x/D/GoZcsrKOVxyTjp1qw6GQRqx2jGBzjAqJUyx cdcDAYjn2/z/AEq1oQ9SJEYnBHHX5fpntSsGUjlWO3qDmpFypOV3KG5Azzjr/PjimlWU72yMgYLZ +bAoEVyOG4569CMj6Uxk3buMEdqnEWTkDjj6frRcPDbKJGb5uo4zk/1+lUtXZEPRXZfwwGVGOOB6 8VDdP8qxqfmzzz1qUg4HG33JpIoGWUu4JBHykDIrNGhNBAIkA2ZJ59KVgeu3IAwvXNSPHBcWzKGf zmyQ6ucphflAGcEEk5z/APWpygK24jCZGc445qWXYhYKpztyTyV7n8P8aqSavYW9wYTdQtcg7Amf 4s98dPoat3LNb2tzIEy8cbMAxwCQN358Y/KvM57M5Mm95HbLF/U9TW1Kmp7sifOouUVdLc7cl3Ys SSxJOew/GnaZbtq3ieyszJiOzX7VKGZlwwxtzxzglT34Jqlpdz5lhHc3GYz5ZMkhzg7c8/kP1rqP hvYyS6feazOGD6hN8nII2LkDHcclhz/dFcmOq/V8POXXZer/AOBc3wUPb14R6b/d/wAE6QRmJHNx NFtjLBplBWMqCfmG7kDAzzXl/iu0TXr17+1iiihIxH5akO6j+NhgZJ/MDArvfF9xeJaLpul273F5 cjewR1HlxqRktnsTwOx59MVzWm2QnQfumtIkVnkVjvMYBIPPfkHB715WXxlTX1laX29P62PpJ0aW Lk8NPWyv8/yOaur3WPD2nw2YltZ4JU3pLEQxUdCD79uR1zycVp6Hqcv2Rpr26iaAnYGLfMzd+Ovp 781tP4a03ULX7TaXISVVJkZ+FOOTkH0z1Fctd6MLyT7VZwJYbV2syqTHuxjJHO3P6fWvchXhNWkt ersePisoxOHbnT96Pb+v68zq7S8t7qPzLeRZBjBC9V6ildc7mUZA4KgDn1riI7+80crZrbw2xbrc ZLhz6g5x3FdxYMs9ohS5E5xgv2b3FXKHKuZbM8uM+Z8r3W4rw7ecAHHC7uQf/wBearvhcbjkrgA9 BV8qGO1VUBjzhjkcjHWqlxljknPOQMfX/wCvWZbICWVeARgdOWHI5/pTI4DMqkZAGMseMc5q0tvl yHBjVSMDHOcf/WqG4nluB9mtcLt+8x5WP29z3x+fUZ2pwlUlyxWplUnGEeaRBcXCxOlvAhllcZCr 2H95j2Xj/AGqr2rBi8khkkPG4jAX2A/z7nit3S9Jnu5PJtgcA7pJXPJPqT+H6cYArpY/CVi3kxvK 8e377/3/APD/AD9a9mMKWEj72s/yPKlOpiHppE5EStGAOd2c54BHuc/jU6TD5uQM+g4xx3qKXwWs YIsr2e1IIIVX+UnPfrnvVeTT9esSSYre/RRwVJikY/qPX0rgqZfVjsrnXTxtN7svSOhG948cc4PO QO+PwrNudbTT4FubiN/LJCAgDcSR6cH1/Ko5NTjVyl9DcWLA4JnjJTn0ZcgfpVq50i11u1jaO93m POx0IdDk5wQMjqP8a5HDkdpnVz86bgRTarDq9hMtnMsvyEbFyCpxjnPOOK5qK3mRwvlyhsHY4AKr xzu9QenXsRg5qzd+HL+wkEtgrq5B8xrWQsuCc4CnnA44JIPrVmyvHY/Z7pNk6tt34Kq5GexGQfw/ LpWyior3dUSqs2uSWhFqkZttNjsbZGkluXEUcS5LnnsB1z0/GvYdK0yPSdMtbCIqRbxKhZU2h2A5 bHYk5J9zXnHh+wGpeOLWKVUEenRfaGjZj97grjHcMyHB4+U9e/pjaemyRIj5KySiVhCBH0xgDbj+ 6MnkkZzkkmvls7rRbjRva2v3/wCS/M97KqbSlUtvp93/AAfyOYvdd8QabNqmm3/h/wC32GpSgWtz bBWeIDaFUk5wpOCQ2Blnx1zUMdimpfatHNzbpeW8UU1xGnytM/mKFUKQOQCGITIJ6EAhW6mFLtC3 2lgQw3YBB2sc5UEAZA7EjJ/Dnn9U8M6Nrd413LFIt0CokeN2QyLt6HsQRwSOeMZ4rPD5hHSFSNlF bx/Dr/TOp0KtJudGV23s+27W39IzZdLhu0tZoyr21vE8zxIRuCgkYIJxuJRsnjrj+GltdRuo4082 2Wb7ZIdkYwuF6Zz17jr2FXrq68R295dW9lJaNpGohUuUKkOMMz+YSCCzbnbHPOQCO9MttR026abS 7L7Rda+kphil8lomaDGPmUrhX5wMNglsZ5yfRhKM4pxd9LvyO+lmfJ7teLWtr9/MzotDs7r7QzTw NmQny3jHlHHJ49PoeOKpR+HYrSRr7TJJktY5hFNF8xjYsTt2sR04zg4OFJNaGnYmubiCa2mtp7A4 itJYzvdiRhnzgL157jCj3q9FfzQxmKBkdShBlGctuBDHPHUEjvkfXFdUHUjLluY5jSwVWj7bZvZ2 3M9iykDODn7xP9PWnx2+MSSMfZeePepECI27BPzevGPp3qO8m8uJmznapY4PXArfVuyPlnZK7Oa8 Ua81mRa27/v2HzEHlB2/E/p+IrpdD02O+ukskH2eKJckD2PIGepye/uTk1xus6bBd69Zzu5ht9Q2 pujGdjqApX6k7TnGBv8Aau7sWexv45kGedwHr2YfiP619JgKP7qThufP4yr+8Skdlb2UVnEIoYwi D07+/vSTkAH0qw0yyIrRnKsMgjuKpz5IrhcW3dnUpJLQ3Lz4Za9armGO3ugw5WGXG3p/e2+lcJrN vdWMxsbiCSCRcb0kXBHcV9A+LPEKeHNJku8K87HZBGc4Zj647AAnt0xkZrwaSaWWWSWaSRpJCWcs SSSecnPWvZw06lVNy2PNmo03oYipJ0wGHTb1H5VAugafez5FkIZslhNbkxsD65FdCtklzKiLCHdj hQg5Ofpzmu1t/Advb2iD7VIk5GZCQGQewHBwPXNXiJUoJe16l03Kd+ToeYP4Z1S3TNlqrSIvJjuV EmfYt1/Ws6TUdb05m/tDSjLDn/XWvzfhtPJ5rrdSgkM7JBKksathWBK7vfmsHWNSvLCIQJGzM/Hz LnGfeueeW0amysbQxdWC+K5n6NfW/iDxZp8GnrKs+WMssQ8t2OMIjcgsm/bvHJ2gkdK9su/BOp2F sJbTU4LwJFuZNQXyWJzksZYxgKB0Hl/U1zXwf8IRyX7a7c2sUcqL5aFF4BPLN+WB+Jrovi7rV6mk f2RpN1Ha3t4wZ3fPyRA9AR0yRjkEEbh3r5rF5dTrVvY8qlbT/PXfQ9ihjqtOCne19TjG8R2TOyXI ktCCfmlX5Mf3t65UA9txB9qepgdPOtzGyzfPvjwQ/AAbI68Ac+1cGLvxLp5C32lfbYfu+ban5j7k L1H4Ck0660NrmWWK/uLK5nlMjKzmLBznDfwnBzwSeteNXyB078ra9dV/X3nr0c4jPfU6u4t54oXF qVaR5A3719qgZGRwDgY46e/XJrnvENwr2Z0qW5WC8kj8yQxq4Z03BdqkAhc8n5j0UjqRWssuoRor RzR3qFcgyrtZv+BIMY/4D+NVb2S3ulH22yuIHAwJYo/MDH6qC2Bj+ICsKOFq0ailUjdLqtf+Db5H oxxVCquRysnv6f8ABK3g2eLT7ozSwiW3UZ8vAO19ytuAPfKKfqAatvlcnp3xTLKyaztV3Jtd/mJH 8qc+eDnivdu2rMwzd0/axUOwkI3kfKQCRyOuBUF9tPmfLlSh69OhzVmC4liUCNlGDn7inP1zUN5H vXBcZYbWI7Zpw0meJP4DmxZ/2hb3GjucvJhoCTgCQfcPUDnJUk8DcT2rpdBvf7Z0aKVDm5jO2T/r ov5DkYPturm5w3lrMoIkj6g9fcVbW5a11aK/idhba0D5hBI/0pfvDJ5JbcG44zKB/DXuZdW9nU5X szxMdS548y6Ho+j3AltPLz9zlc/3T/n+VTy/PwKwdGaWCQCUeWpOQCeoPX9ea6N48ex9K6cbS5Kl 1sznw07xt2Dxp4jbxJqzyJ/x6QAx243NyueXwcYJ+nTA7VgqoIHJHpiti68J67aAPNp0m0nP7sq+ M89FzU+jeHZ73UFjuIJI4UwzmRGUkZ6fU/4+lehCpRp09JKyOVxqTlqtWbPgvQ/KH9q3KncwxAp9 O7f0H4+1HjLXTCn9m274kkGZmDfdX+7+P8vrXTl0hRUQKqqMKoGAAOwrlb7wrb3UjzLdzeY5LMZA GyT9MV49OvTqYj2tbboehKnKFLkpnDyz+QjMT9BW74T0V1U6zdx7pW4tYTx14Dfjng9hz6VJ/wAI cWvomnuVltYzllAIZj2H0ruNIsmuL0O6FYoPugjGWI6/kcfia6sfj4qly0nv/VjHCYWUql6nQ1LM QeH9GeadgqoheR8AbieSR7k9vU4ryDVZJdc1We8JczXDjagAOB0VRgDPAA967bx7rJmlTRbZm4wZ gufmPVU9+oPfnHpSeHdCTTwLidQ10w4A6R+w9/U/5OGBpxw1H21T4pben/BNsRUlVq8kNluYEHgf VII/NBSWVwCUD4I9ueM/jWbqnhppONV0vco4DyxZA9g3b8DXrVuMnv8A41q2sROBjI9K3jiZPSST RlKkr3TPmm88KLaM02l6jcae2ciPcXiPtj/HNVHv9b023MmoWAv4VPM9p1A7kj/6wHFfTN/4L0LV lzc2EYfnEkX7tgT346n65rl9S+FzwITpNyJFXkRTcMeP7w4JPuBUunhK+klysaq4iivddzxXT9Zs dXUfZJx5mMmFxtkH4d/wzU8qiQEHP4VqeLPAVuHeS7ifS9TT5kmQbS5BPOB97/eHp1rlrS+vrW7/ ALM1qIpcqSEuOgf0B/ln868vFYCdD3lrHuelhsbGtpJWZoqoRSDzn1qKYs8WTyy8c1Mz5yrDDDsa iGQxBJIavN2Z6G6Mm5TEwcfcmHOOzDr+YwfzqkLR7m1vtMVik6gXVkynBEiZYAEAsSQXUKCMsy56 CtW4BAkiPUfOpJ9M/wBMj8qpXUj2sltfwO0ckLg70OCvoQR0wcH8K7Iys1JHDKN04s6/RL5dZ0iz 1FRgugLgDgHkOPoCD+VdGsvmRhict0Oa4bwlJFZ6zqWkxxrHaXQGo2aKp2qjYDoCeSFb5M99jV17 LcMDDEdsmcHdgcDv6DI5r6yolicF7RbrX/P/ADPmKbdDFezez0/yPVZLyNwDtJB445/Oq7TqwZmw AD3PNZQuyy7nIyAT8wzz/nNMkuiwVOinrj+VfKHvl15A/OeKrSy7R2qHzvl649s1Fv3NzxzVRQmy 1bL5jjIz7Zxn2H+T69q6In+y9OdkCecQSoI2hnP06DPpVDRrYswds7V5xn+L88HA9gQSwqHVb/7R deWh/dxnA9z3NYfxatuiOlfu6d+rMXStHaC5kvbx1muZHLZHQE9T9TXQwjmqCPk5q9CwyK9WU5VJ c0jgUVFWRq2qgsBit21iwoJ4rGscEir2qa3Z6DYi4uyx3HCIi5Zz6eg/GrUXK0YrVkSklqzUJCgk nAHUmuS1zx5bWZaDTFW7nHBkP+qX8uW/Dj3rltS8Q6t4om+zRxukDfdtYASW7/Njlv5cdK6DQ/AK oFm1Rvm/54IePxP58D86744alQXPiHr2OR1p1Xy0lp3OYGlal4wui1wXuZTgecwwIh26cAdeB154 rK8VfC+SGyMN3NvEgxDcQj/Vv+P8u4/T3CKGOCMRwxrHGvRUUAD8BUd5ape2s1tIAVkQryM4PY/h 1qHjeaVuVcvYtYdqOktT5CspbuO5n0q/+W/suN5P+sTsf1HPoRVwSGVDjhh2966H4keGprdBq1tG U1DSifNT+/ECdy9OwyevQn2rko7tJPLuI/8AUzqCOPX+teLmGE+r1bR+F6o9XBYr29PXdaMmuhvV ZkJ3KcnA6VSIWa2eE9MEYznFaAYbijAFGXis4kwTtH68da4qb0sdc11Ki6gbSHTNW2EzaPcGO4IU sxt3+VvYBSeB3Mx9K9PhvHtLqC7hK743EiE4I3A5H1zj9K8quUjS8lgkKi3vozG5YEhSR97A6kcM PdRVnT/G8FjpSaNqS3Fte2g8hpAoKjY2AOOQcDHSvqcoxUIKVOo7J9/6/qx81meHlOUZwWp7Lb3q YJTaAOAev0qyt0gdee2SSO9Ytl/x7t+H8jV5uv5V4DPUuaP2kYKd+4FWbOPzmGBk5wMjIJ7diPU4 PUAis1f9cf8AeNbejfdH/XZf/QXqaknGDaLprmqJM2b24XTNPEaN+9cbVOcn3Nc6rY56/StTxH1t vx/pWTH0/OlhVanfuXiJNzsWo5AB1qzDMARzWeOi1Yi+9/n1rtizlZt2l4Nw2kn3rolhttStGtrp Fmiccqf5g9vrXH2Pf8K63TPuj/d/wrZN2M5D9H0Gw0SHZaxZc53TPgyNnsT6cDj2rSooqJSlJ3k7 suMVFWQU3eN2KdUI/wBaf896SQpOxxvjrS1crfxqCHHlzAjjPY/iOPwFfNl5p58P6tfaKxIiB+02 Wf4omJyAfYgj3INfU/jD/kBzf76fzr5q8f8A/I56f/2CP/Z5a7MT+8wN5bxehzYZuGMaXValJZS8 O4csnOai1FhIqzL1Iwfr2pbf/j3f8f5VFP8A8eY/3hXza0kfQPWJmXeLuMIX2kco390+tU2m0+ch NbtZRPGu1J4HClwMBQcgggD2zjAzgACx2/Cs3XP9Yv412xdnZHFPVXZ//9n//gAMQXBwbGVNYXJr Cv/bAIQAAQEBAQEBAQEBAQICAQICAwICAgICAwMDAgMEBAQEBAQEBAQFBgUEBQYFBAQFBwUGBgYH BwcEBQcIBwcIBgcHBwECAgICAgIDAgIDBwUEBQcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcHBwcHBwcHBwcHBwcHBwcHBwcH/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQAD AQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNR YQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldY WVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TF xsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEE BSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZH SElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0 tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgBwgJYAwEhAAIR AQMRAf/aAAwDAQACEQMRAD8A/nHh1mCLUYYJ1BKsQpJGOvPTj8a7S+vTPHCtnGAIcg4A+brnJ6du ntX5tOPLOLP0inLmj2KVm1xtKJFtz8pDL09/zA6+v5SlrowyzSTYtskhSdvtn9f51N4p2ZettRkE jFERZBHCQxUkgcD8foMfj3psNndXd3FCVAtRuxx25wCfw5PpSTSvdbC1k7Iu2+mahc6hLbADyt4I YDr6gY/H0ruLXSLyKVhKqkEAbiOAQB+XJFROUdkawi7XK94bDSL+O9vNuCpLcDBxg/p/Wrt41pf6 CuoxCPaJMADlvX8B279aybb5ZL0LTtonqYPh+4E2qXN7c2xdAMIz84POee/J7VjXmsDT7q4lgJih duo+656fz/zxWnLebhp6Gb01S1N/wjp0um3E3iG15nuRkAkjGev1OQeleh3egLrUQvYznUCyls8n PXnPH9OKwnNKrz/L5HTTirKJo+J7qPUNP2xskN2kbIyHjO3jrxyRn8s187TWVp5EZtWJPmhVDHIG D147dfUVWGlo0RXTk7rc5jV3lJZpDhd3GPofxFaEOjH7Kuq2rh5T95WJIznpXenywVvQ47OTbvqj 2nw1pSzRWN1NARKqeY6NxwQTwMfj/SvR7LSo73VIZI5xGI1DTDGByO35gdj0rz60/ea3Wp3Qimlc 6W8CanG0ttANgIRHUgZbpn+fPvWPqEUF0lpp895mVATJPg847EEf5/lzxajbuv6satSS1diGKecX e2JDsJUFu7AHAI+uB9KZfRX0V5DOkQS3bhgzDcw74/KrVuZak2bT8hNLWKL7ZF5BSNtzZZD17dRU lxp5u3SacSmINlEHRh1wR+FVez1M2uYge6KQvZwrslGeAOCOn8vT1qe8mdIlt7bLMAFdCTkc9P69 qFBXV/UfmizCjokRkXEZHzLtwR9T7ggVNeWcGqg2lsxRNvAboTn5v/1VLbi7taFJc3ukY0uHTprm KWQPIowXHBG7g4H5/lUj6faII7yCYLHvCkBeWBHOB2z/AJ6UnO7vbQdle3US10ywNvcXO9XBDIqb gMD3qGzSGNrxrzTcIu9AQuMtzjnkDuR9Km7aetmXbVWHSXUMFultJblLeR8+T/FsHIyT0Bz261lW WhQ3cLTFPKSSYrGQMsWU9AeQBz9PSnF8l5dybXF8PSnSLOdrSUSs5+ynzfnCcHcfQEdKdpttfDWr nyWP9nJD5gRhy7ADjGMc5PFElHnm2NK9oooXR1sy/wBoXdvCsW7BjYY2ldpHGOOo5q3qVjoF9drq dy770eOLyw4HVQenOM7f59aE+SSdPXp5CavdNGdezagtyZ9FsRLH5Sp5nl8Q9ONxx7c+tc7qE0bX saTyf8TMqTGApKjceOTwPp7+1XGKdpbvquwuW2rWhZl8O29rBbw3N2kl8Rvk8vG0Ek4HGD0wO/fs cU6w06fS0vPttuqsmxQ0PVnxwAPT5vx59Kt1FOPLbrp5hyNWa1OjYQW8XntEvnfL5jIp5JOQB3PT P4GpYLWzk1Wy1YxSHCbl3oQfMY7ScYwB83X0FYNy5W/l/XoU4nTW9nLBc6hehZJjKSkcSHg4A5yB 0HOKreHdOurfVbwTacPKukLhQSdqr0J9Tx09frUOzUkv6sWoarQ9lkgNofIawm+zSW6xxKzBfLBU /Mw+mfwFc5qnhO+utJum06wku7uZVG48iOIONxAH3ckgYHJzWNOS5lfqbyi2tDzzT47vQ3tNKvoJ ZypZvs8X8A4I4zzy2Px+lWba1vZbqe31G3cXbq0scQ+7H0OCoHJx29a2krKUk/P/ADZzcrty22NH SbW7+2vcRweeIAZJOcHceAoPU8dfy7VuxX6/aLDUrvS3iWMt8nl7RHHggsD6kjjuQM8VlJac0WXG 8Vdrc9U06bRL1n0x7Yxq8AMYK7ERDnjceSe5H19Kd4l1fRtE0uDRNHGyyji8qSQLjbIcliW4JJz+ VYayaja/U6fcim7angDa3baxp95m8EVskrSFlHzTYHBPcDpxXHamkFy4NjIjgwhWCgbnyRwPyNd1 OMoO1tjgm76o5G7sobZUleAq75JUEfIAvPTnPT+VVND8uOPVXtUZ7x08veUyEzk84479P8K6W3KD v/Wpi42krEtnY/Y57mZphLqUnVHxtVdpPJ9cnp7Viq92l1b2GoQmKRnx8h+VlXbyfxz9a0XK20vu 9ES+axo3sxs7pjZSeZFsDHYB8rsOB7nHOPWuav1guhJFv3ajjcqKuMZPOfXAHtTg1pJr1B21u9x0 tkt/b6Y0uVkMRVyg9CBwe3196mmtIA1lptlJIJGdDIhPU4wOAM8+vvSveytdIhRsl3INXmMn2mMM wkBWJdhAGPY+mM8/rXN3V3ps1mYHjAlVMbdo5PqScZGea1pRatboZ1GoppI4my0s3LG5GBF6MmA3 Oc9s8Z/LjtXTxWEKCJVIKyDLscZLdePpXVUnuc0afM+YbfRWKXVoqyksgAOW79f0z1+lTxfZL+6v biKBRaRKAhYZOcYx16ntXO5O2v8AWpsvNaFa3it/sMs8oYXoYhcjhVyMZ9z/AJ4rAknQRrFBE4jA wzl8b/wz1zx/kVcObmfkTPl26lJZI9PjimhtS7OrJ8oyEPTv+P5D6VH/AGnc/wDPF/8Av2P8K09m 5+82jPmUej+Rz7Xl9fTW+owoRGGb5sH2GOnXH8x+HY2N9eW6hpG3OACwzwvc569Bnt6CrqRXKok0 nLWXToar6+ZbtWV1LMvQAgICQckDpxkVZa5kvbZ7e3H7tjggZODx6/19a5nHltc6VPmTszSsvDBu 0tLZpmKqBk7uQeMk46/X2rs7OTT9Mhu7KJwXLbd57A8D1z/9esqlTm0Xqb04pas2Y5LWwZhbyeZC qKfMYjkkcgemcCtWx1f+0IrsvtVYjuRskeZz0Az7Z5rmnFtOW39f8E1UktDzfWNIsdcmke+uXEI+ 4qMeckHJ/wA9+vFN0tYNPsr233AW0RJTktjt0J/T2+tdN26ahbREctpcyZv/AG/TL+FY9MdFf7sw BOM844rmbmG01/VrXSLYE2EPNwx4JxgjJ/X8fas6bkpa9Nf8i/jVj2G4/s2xSCOytZSI0J8wHhVP A9sc8fj7VvaRdHSre21K1g3T3BPD/wAK4HQ8A5x+tc0+ZxaluzojpK9jynxVrNzqN1fMsxjXeSu3 jao6g+/bivJ7RL2BGv55GaTfhUI4UE8Y9P8APHNdtGKjDlaOKpzOT02ImgnknuPtTB4d20Z4x3yO 34+1d74etGzB5EXnRBiHCkH8v/r81rO1rE042kj6D8OadHZR2t7K2yE4Vt+OTnkdP849M10Gn6bb Q3Gq3LuGsrk4ikyAe/4gZJ56dzXk1J/FY9CMU0l2Mq5lubO2gtW+UeaQrKcbD/eI+tYpigl0y/nn vi8qH5R/ezk9fXvxVQ3utW3v8yHruzQ0+SWxlt4pIi0oh3Kv90fTPPOPfFW54ppGMyMTKBhjIThc gk4z/nFN8qlzPW4N6ctiw0rfYJLeZkVdoVWK43DPXOPelt7tpCtoyszLypHQjHTn/PIpW0bXqTpo upTBit72OWa32Sq2QOhOc9T0Pep7i0Cb7pZQqzEABvX24/r7elVe1m3dDto0i5FcQRQxrIiNk8ox P+e3bpUM0cUUiiLYoKgIEBwAPX07dalN7N6FJaXM97RjdpdWGbhYss8jcKueTn8M0qWC39ml9ISI oNzeYDw5PH/18j06027JNfd/XcVrt2LWnaHE6SKk+xGxIMsBycdf1/OseWa/ha+tTcD7MswlLbgC GOQMdz1/SknGTd9y+Vq1jJnmmn1GbznxMQVDNuIUKDgjPqa6C3myLSO6vAiROVTYvLk8n6cAde57 VUuVJR/rYFq9WW5LD+wb1EuLdWjMcl4kGRjZv6n0zj+VXtP1Oe8huL+a2S2uIHGUVc+YWB2fhWUk 5rmvp+fQuPuvlseeXGr65e2+oXsQHmKVWWMcqAOvHsoXt+NYt011caZYauy7JXl3YIxuABwSDyOp HHYdfTphCMErd7fgZM9K0/W5HttTtbEvFbS20cQVoxkuwUs3TjAJPbmuDitrp0uLlYgsa42BzlvL XOTg+uc/h6VnTXJzc3kVO9l5G9b6Zcahpd/cLbKrCULH5Qyx3dAB+v4H8c2Xzrt0h05pmjVCrlxn fIpzyegx6dsU7p79OoNOyVjZsYRPbx6reXQRMm3+7wHIPOPbgd85NdBE8Ef2Zbm6Y2bFI7gtgZTA IUenQc9M1lNu6Vti30Z0F0mryTaRqWmMRp6Su6pGoUIrHozcZ7A/h0rt5rm1gt7QRx7r+fazMQPk jyXL9+vAHt9a55crso/M3i0k3b0MLxBrKXAaPTrtjeNKC3mMcyEttAUHAAwD/XrUOk+J9Y0z7VLZ 6wyWRKpJGuQpJYD5T9UHI6D3NDhGUPh1/rUhz9/mIfs0spttUtpkBknkj3hzJLK24ZP05H8q6CK+ iSJ9MjmP2iR5ZGlEZLNsHr27j6Cm3r+fyLiktTLhntRIYtLVSxYxny3D7DwWdiPTBY57nHbFd3pW l6bd+H5bQ6lPNPPL9nt/MX55ZSFHAPQ/yB9azlJr3rBC0mR+ItVi0+003SnjdjHcrERsySQn3d4/ l/tZr5/+IPjnVLorY2ylLZZ2NyT2Pp78H171rQp8807+ZGIqcqtHc4k3Vtb6XDAbOYeZGHCgk7s4 56/j/StjTYbnT7bzXtX+1Idqbuo6beveuyUdLN7s4U7yTZF4htpmsp5YYQH2/M5/5Yt/EoxwTjHP QVx+k3MuhRMu0rOzOQjNmRgFJLOT+g9/SqhaVPk8/wCv8wktUyymuXN9ZtdS2aJco20sPlB55b8C TjrjIqneRQhEvbuRZ2kuAXZTnaxGcAdgP8eOlUlyysnrsS3zIetg15p0kNlaAavCzSYR8qSwwhOR 155yc81iiz8iyL3bR7ydh28swOQxJP6Y9TVQl0euonHZvY6G1t7eOzS0sLecTeWZ5Z5WysUagnGO O/1rCt7m3tdSjkErgTIPnbI2fUn2P86lJyUu4aWVjI13VPsbpptvYoAWLyzKwJU54xnqf061yZsI vOTUA/E+MrKSFCjtjrkn8ea7afuU+abvf8Dlm+abTWiNi1GmS3j2YtjuwQZFGAfw4z0H061DPa+Z GkUEhWXYVQLu+Qg5B+vU9f51EpyvaRUYaXRmxWMM9hcSIu3YAFzJnJ4ByTgnPBqSG2k+zKsDlMt8 oY4LHpkknjjn8aFJbP0DladmYl2slmytKzv5zEhQcgAnnIxg4xn8RRGNNVXhl3ifbnnA4POOD9P1 q7yteJlKKejMK4u5FiS22bUGdqDGD0OSe3T9e1UftLf8+6/99f8A1q1UdNDKKeup1+lwfZdFiils 8xlxtGORnkepB4H+NJd26WUMr3Vu2yTJ6EnP+fw47cVm2+Z2fU05PdvbYuaXZWzyKRbBXzlTk8A8 YIxz69+1d/oul6fbeS20AnJAPr+PNZ1JOzR0Uoq12dMtr9juJCYR0Pl4YYHYkc/5ya5KZrd7vfsP kDlskHc2R6+38jWMHfU1lo0rGxLIr2cKwn5ST8y8kdj064PH61QvLB3tJ7W0icXUaglhnDd+x46Y /LmlzcskvMH8OhzcSX9pazQ3JJkkGSx6qfTnOMZHT2p1nYrBYTt5omLMBtLfNnHT1/x/npJx1sup HK9L9CBdLvdItYdXhsv3zTlEQ8+aWJA46H1z9a9Z8GeB1k0qa7ugUmnJllJGCGz3H58Y6GorVFGD mn1t9xvThrZnoF5oWmy6U1laXbK0Y5HH7zAwc+vIz+deNapq/i3T706JEge3hUtDKvXnAHP4H8jX PQ5Kl41FZ7mlS8NY9Tmv7QBS5trtN0qK0ZKHJkfOefWsm60q+utNjkjukiJOzG44GD05/wA8e1dc LQd5eRyyu78rJbCC2RooNSkH2syLjB/iZsZODwP8a9k0fQ00ma1SzKhpeZNwyAv1/wA8Zqa0mlyr Z3LoxTd+p6pdWzafbxQTQGWwgQ3APqf/ANR/+tXP2kr6xHKzM0EUakxxZAYt6/T29689apybOtx1 aZjR6tLHbLdXKGRIyFKuOWzxu5znp6d66UxaatiftSpGoTz+nLNgYHP1HWtJJw95fgQrXaZiLIxv xqS4E0KbQVPUngDr+lJBLdyRLGtz+/Zs7PRh09P5/wBauy0b6Ctpc626g+ypLFNKZFZVBDHJ39Py P/16r6ffiC3m821AIBO7nqT2559cf/WqVeUQ+GVmihq98ZTEPLDXe7eevzLjgcVHbCbWPPnMJ8qN ACCfujr/AIU4xSjzX22E3e5pGMSRme5hkAdf3bEYD45HTt+Wc/WrKWMkbPdXsuEl/wBWikZUH/P4 fhUtpb/Iqye+g60t7SxiurO3wyDPLEjOf5nP16VFbvZndZgMII5gvJG0jHPX6mp3bb9RxskkR6zN bzGT7DCxAYK6Akgd/wCX8qyZLae6e1lW3RTCwebqPMyB1/HJ70LS0mU3roF9pw1G7SRrxY44yFMm 0cMSAQQcd8+1aeo6a2n6tb6RKFe3YbxPGwKsSM4yD74z70+bRRa1sDjvIxtLv9V1CaXU763b7OC8 SySDISNHBwvYj/GujNlBrGpXl9AVWFrcTIrOcEhCDnnHUVE7RlpslYI+9Gz3PPtOhumJubWMCORi jryNuB1bPVev5e9dH9lv765EtzYeY0k2UK8gDaC2F9MEc+9aSai207MlJ25Ui9Z6vDpcT2Njpazy ySKHu5Sf3RXPyqAPp/XvWYby7ku44NPjhRwh+0yXIDGVU3Y249Tg49h6Vny6uUnvrp+Rbd0kuhJZ W+t6y13dw3JhnjhVTGoxuHAzs7cHr9KkttUbSdDsdLeF5AI3C7Au8sxPPtjnn+dNqL/dx3TFrZtr cqW2oLBfRacYN1nGqyKn3grDO4n3wTXoXijSI71rPVdNgjQSGAGMplnbCqVUEjAxnJ61ErwcXfR/ mXH3oMgTUTKt9piM6qqbZEOdoiV8kLj+JtoX6ZrQvNT0pbPUpb9Xt3gaMQKgOX4xyw5K/MFx3waz 5Zc65epd01d7GTZ2VhdC1utTuVliG/zYotylDgkDPVs8gfU/hlWFnPe6PHplxD5EjXguAFVjM8ZB 2oFP3VyepHoa15nZ3W1v1I5UbtgdW05rFGQJHEjuIo3BdASHLuR07fr2ratI9CvdPWxuNXljmvJh 5dvyJWVs5IPUKeBj3PrWdve54q6NIdIz2O08O+A5rPRoLnS7NIBM7+dGq7mAP9/v6DHH5Vzd7FpO naXJLdzTHxHDKY4nEpVY1IG9lUHIwcgEe+Kyc+Z2Wrb1NXDkiubY8muda1TUo0STUf3Nu5kQs53K TyT6knP6Vy91pdrqUHm27r+74Z5GO1zyCzep5ziu6mo01eKOCbckLLa62HtjbuAixlo2c5aXHU89 B7e1bwm1MfY9X1BFba5aIPjDuc53nPzYxn8RTlyWXK9diYr7jKlby4LubUIHk+0XJeZ92F3EbmAH YA/54rkrm7eW4tr23hQyeUXjd1wu05U5P44xx0q4Pd/Zf+X/AABPS6EURQYtr+9WPTi4YIkeX5xk fp0PTioNNubGz1CS3ukPkAyMgyCEJXgn37fX61XvSi+Tb+rmfwpGcX1TTnae2SRmZPMTMeC3Lcn2 HTg/jWhDE17dGfUY4jbIrMJApODwWPvzkZ+uOuKuSSbnHqC0vHoPjvNPlliQ3EjyN+7aJ0wruW4y T1AHPp1+tYHia3mQzw2T+c87KVQkbAc8c+nPP0+lFG6qcslZEVHzRduh59qdpPqd9BcW5yys2WyQ qsBjgegOPc/nV5NNnv43trq6zMvLyA8cgDg+nIP04rtnJRjHyRzRi3dnYQ6cltZ3MhliMcZwhXO4 H+vYfjUGlWxhubiV4FW7kjdws4AWMHgEc46HOc1yc/uux0pLS/QhFjHtmEko8ptoVsYAA6njpn1+ uOaw7m3lksWlidUQlmVVUlmXHGc5wKqMve20Iaexnw2UlysMaOfQE5+Y8c856k/yqncWEUkYSV1B y0a4AB3dT/QfiOlawfvWsZS1v2OP1a0T7OSkxNxsAXCElj2GP8/pXJ/Y9T/55yf9+/8A61d0JLl1 RwVopS0PpCa1nlWCKJAFVuWxyfwz6cYrQtLK3uIWguEzctgBdvHLHoPXn9K8t7abnqKKeiRTm0ue Ge3zFmGEkAru5zkA/TpXarp8cElvKVBVYwNx9SMk47dPXvUTd7f15msIkmrjz7EzbwpicAnI5Hyj Az65Pp3pE0q0khEVxGWll3YfOdvy9MnNZqbjFWeqLSu22c/JLZaIDZkNvX96E2k46EA/kKr3F5eQ yWraed01wD5vy8rxz/L/ACK1S5neXX/hzPS2m6HxrDc28sfLXJBV4zkt1H5c59evanaXbxnDXkP7 8MEMYY8Hjk+nQf0pPS7LSu12NnQxH4i1Q6hcYi0aCby7dX4ErAgMwB684HPoK9Vu9Jl+1201reYt 95aXJwCDhuB0Of6Vz1GotRfb8TeHvLmZXguUayvRFuaeRmjjf2OQTnkDoP1+teM6hr89/p09nblI b6EG2aQgcnJz16Hr3/xoo07ybfl9xnVlbY81tQbSR8xNcXTo7ZyTsPzEfqOnqa1dNe8/d29+peF8 SbYs7lLZGfc/WvSaTi5P5HNrstj0Pw54RsdX1eS53N5cCrKyLn5tpyB9Ocf/AKq+g9PsrZ57Hy7B dscbSMzkbSTnAHX1/T8/OxNSWi7I7aEVv3LQuJbi9dLd/wDRkQ+bktzxz9eleSX39pPOt0d0atJ5 YKcD5jn+QOPrWVFRTuxz1erOhudL+2yWzxBPJDCEDjDemefc/hRrggvbkaZBhpGcRNIMhVYcdq0i 3KUddv6+8Vm1ZlO4gltGWMhWGPk2/wATD39OD1xU9tZ7ULyuuT8zMAeSB2wPTmnf3bol72Ni7uZr GxdbW7Epd1yc5K9c89uOO5qS3ju4pRElv5kZUE9SEyc5zS5Y2u/uBu8kkXnjtrS78pgv2gJuVyeB xz+X+FZAnFq8gEbSQOxACcYyec+vSiN5K43fQ6F9QVF+zrCHt1HmEjnYFHKgenGP6VnXV1c3t1Dd s3l24wFjI6knjH4Y49+tQoO/vMej0KhljhvYbZuH8xA7c8EnPUEdqtatpvmpdT3AC2yOihV+UDPf 69z34ob5ZR8/8wtoV4jDa3pjZ2ZWjGMc7QAc8DqSCQf/AK1Z0EN/ca/9l84tZcuYgo2xpnJY9Ofb 6Gmlu2uhWrNGXTISLX7PEJhKRvUNlY+uN3AzgDJqeNfOn0y0v1MdtFHwI1JKnGdp9zhee1JSVttd QSs9zTsdOuriCwsrOyIt/LlcK8nGTkc9uDn8h+PPJBqBgkXTrdUaOTy8Mxycjkk+2Tx0qIuLum9L 6/NjcbpXNre1vasZpNzwY81Y1yH54UfzJrAurqWxvJIUllkcxY2oABGSAdvtnbz/AJw4x5rrfcJN xRFdQazZx6sscBgDjzGt2/1hZs7sk9Oo9Kp3EN9PPA0ThkRhFIsa/NtJwoUkcjrk1ouTqJprQ6ez s7hbTV2WREuHUv5cZ5kB5Vcg9eFJ9hzT/Dvhy41kpqGvxCG2RHlWPPKL8xGB/urjr71jzxipSb16 GnLzWXTqdtZ6Ro2k3tvqkxM1vM7RxxRALGgz/GTgtk4PHbH4cvLcDULqfTbS5O/IRmizhNuOVPHU nr6dDWavKV7bItpRSiuo+fTtUgRbK4WEaVgyCdgQ7kAAbmz93JJx9anl0Of+1rG3m1COSJ4xKZZT 8rxljsYrzgZB9Ome9UnCOzbJtJ6bLQ0LSK0u9cW4leG3sY2lnN2ImPmRooHypyVYtgc+pNZt54i1 P7Xcx2ECzyzyLEZoYwPLU5O1W9SSM+wPTApWU3aTsrfL0C7ivd3bOg8DaGllKsHiHcz3Ecsl24m+ /HjAUnHIywHHXjtW14G8OaO+uNrMW6a3YSxLI7hTbAA7ME/ewvUZ47dKidXl9olt/X+RtTivd7o7 abV5PCGiXmo3GqsdQkKKLWP5hKyqTGpx9zO1SR35z1rxTxZ4h0+80i31GSBJNVDF5pCVDbn4K4HB AAAI9j+KowblzRVr6BVmoxcX2uccukaZNYRapaLGxkBkmxLnZ82BkD7vHauYaCGe3lj08K21mHnM CCwP8RHbPPGO9dkZyfxHE0rtozrKw1vULEX9zcxm8AKxCNj+6QNwCv8AFwOg65FXb23dfDenpqGr 7bmGfzWjRSZE2g4x0ABO0Y9c+mKtSg5JKOqZlru2Rfb5tQ0ywtYYXuboPvlJbILEjO7tgE89efap JbU22nMHdYHRSxjJyQo6YHfGO/f9DSKUb632C9ziVs7q4tU+WNr1W3TM4K+UjHkKOpOcH+RqTV4b jTJIoVtUVG2szFCW2klicds8Dp/9fdyjzciZmrr3upsQ6vJDLexapOryKm2KV/4V53KB9Sfxq6m6 0jiQxYlP3GP3l3D7xPYfMfl/xNYSi0/d0v8A5bFp3icRrV61zsnsv3UgZovl+Ubuc4x3x3965W3u tQ3tNczSSJ8qI+Cdikc9/wAP8iu+nBKCXU5akuaVkXZLK8ee4ijZRbCNQWxknjJI9hjGe/rRBH9o XyVnzbQFVeZE+bnk7UPYD8+aUpdFqUoqO6I9JsZ2uYYba9PkzSFN8mASueuOR6847e1dZZpFczyT u6w2qhkZHJO4BcZ454x/9YcVjU+K9iorozJuAZIprcgNbMTs34HA6bieAvHTvj1rIF7bypcyXUit Jgx+VAWAVQPX6DPGeADmnGLault/VxS5b2ZcFtBBZSXAyITjgL8wPfjk4x/KuQmhmRxduAFx8qsp y2O4BHcZrWD0d0RPRHOXl1IGAB8ydjhueMjOSPyx155qp5t3/wA8FrqhZR1ZwzetuVfj+h9Fbmin EZg3yEkYx9AMc98fgcVV060H2qdpARKzFgmeY8Hj+R+leYnaN11PSjB202OlsUhtXayuIvMZ+V6c Hkg4Ofy96nlma8t5I8bZFySvGQuD78ZB/Ss3q3K5td20OP1GK5TLHcbZRv8Alz2IOMemMce9RT+L rkwRTxxYjkAVeeTgjIHTPTFaqkp2sRzOOnUikttRmulmnhJmkTGcDdtIx+eTz9K6HTtCbTBHb+Xu uBh1yST6k4/Xr+HalUmorkv/AEioxfOaltoUttnUlVVu5TkKwwGHv/PI/XNcxrzXU0Fnp+lwg6xq U3zbOTCgyGbn6H/69RFqc79L6+iLcOWFup6HZ29pBo2kaKbN0tomZd5/jY45Bxz6k11g0yO91Cws BcFbAIxeUthWJ6c9+hH+RWMm7t77v/gGyjdW2PPPHerLY6NNLo0wadWIRV+XbtGMDn9foa8F069u wJbfUVXz3USO6YwDweM5z06/nXZho3puezOOrzKqrbG3DdWMt2tvYzFcoVlkJIwT27+3Y96tnw/c F7Q2lz/xMHm2EgnCr8vXsPxrZNxspInkUrpM+ltE8LXfh+y+y2DrcXlzF5YMZyWzyT7DPQ/1zVie OXRG2zxsWRFTc/QOcA8c15k5KpLmT3O+3LFa6INT1PZpMC2F3CL/AM3OT/exzj2BP6fjXPz6beyW tveSz7oWQRgIOHm7Y98579qIcsdWtWxSV29Snp39oyeXYtHI9xvKruBA3EkAfrj/APVWvc+Hb6wv Z0vNsIhjYso5xLgnr1BP9T6CtG1B2b36C5Xa5H5E4srCaNWaVkbg8nI6j8iOP8nat57CC1kVok84 KwBY5w5HQeh5zn3pO7VosnXYxdP09ZWtkuSWUZCuzDDnkHkf5612DXsf9nXcFuQpkxG2zqF4Hfn/ ACKKjbatsOCtuUpbaDS/7OivAZLdlAkK4O1Rg4JPUZwKtLbJIlxNCQI+SFc/Ngd/19KnmduboNWt ZvYbqtvBbmDypdxkQ7VXJ3N6fXp+VVCpiS3Fywd8iRU3fMu0DPA9x0/xp3T12YNJSbTERobhbG4t 7dPtLZEiSAnbz1Pv04q/efZptNuIJ76Uxr+83KpxIw4wMdMn8QKluV11f/B/X9ClazucjK9za3Pl xoShBjhi/wCWjlgQM9No55/Ct2wsr82893Eds86hWVzwCCMkfr+fSnNrlTezFFSbujci05w/2KF9 943LkqAsRYn5R0zxn86x7uwF07R2t0VkR2Wb+8CuGOPUk/0561nzR5r2NXFbIWFbvS4oVuGJQAkF y+cjYRz7j+dP08ac1rqN1qE8hhWLagThvMbkZ/xpO6TcVuJK1lMgh1CFrdpIlETStGWgcZYrja5w Oc9+fXNU9jOZ73TI5Jmime5undtg8vIjBC/eIGVx+XflqDi3zdWJrmW3oQW9zqd9e3WrmF7jSbUR mYgjbJuHyrjPPYkfTnOKvXt+9zp2jiSNIL22t0aRQeq5ZjnHJJ3Lz0wT9avkirKL0Wlv6+QXfLbv qU9JsZNRMzxyyCMxP5plTCxjBACAfXGfb1Nd8lvdaBDo0ltJHdLOBMd+F3Lh1AwOVQHOfWs6qXw9 S6ateSNHxXZ3Fvc6OJEklQRZEjFo1TcMn5R1zgAA4PX1rn9MuLKa4tY9NsHtrhZWcy3AJWcKVzjH UHnnOQCKiMZOF1sW171mbeqPZXTS/wBpkNYusphjA4n3Yx8o4wWwo+pPrS6Z5Gl6sluliGjEMMDN KhQRSqTuUluSoJOAMHIqfes7CuuYtC20xLy8mOpkvEphvNsaxxBnJCxISCSxAZjgcYArI8I6dpl3 a2tlo7LL9oZ7nazAtaknaF59mP4EmlKTcXzLQppKStuegazpsLi+nudSS5lljhhCxxlBGFOfkx1w Tjjriq1hby6Xp+lWNoPNCuUAkygkkYcjd0AyeTgcc1KfNFRSsXZp8z7HDX+vwpe3Gh3eoQsZJnlj WVuFkJADL2wcA57Dp6V5Guu6fpGpa9FNaRTWDowScISo34XMY6AcjHsa6qNOVpKOl9UcdWaum9TY sbKHQdLuj5f+lSrIqjA8pXO0cjuVUEA+pFZNtq1jbzzWMAkfUUt4YpJZSAqP3+U9eeMCtP4l5fMh OKsmYDRrp3lw2l20skchM85bEaO5JYYJxjBx0PT3rT1Wwg1m3lkaSGOVMPHJ5hZWJIGNo5Yjdn8K 0b95T28jPRxcUYci3KzfYNNZ4riElMxqASMBtxxwSSTnnqDVe6lvIL8wS20c5CopndywhyMAcY3H 2/xq0o3teza3Jab2Ne40i7+zXItIJGuZMKJZDnCE9VXOeeRz/d/PkNN0e4iv9QSedptQlwN0rsdo ByM9vbAJHOOMUqc4qLXX9AlF80WWNSmS8tvNVFFzCxWKORT+8kXqx9ev644rEu9X1a5tk09HxOX3 b0TL4YBSOuMDtjoSOa2hT5knLoZyk1fzMX7He3JNgsA+x7m+dlLbDxk5/DnGQfetFYY7TdDZSloF QxEGPjkfw7sAEZwDz/LO03b3Ysyim35l6a3aL557abz3jBA3HlgR949l6E/TrzSW94GuLpmiMUAb c/lx481CP73Ge4GOwxXPLmfvX1NrWsZ+oPazQT3tkjBd6D5U25zwABnIXgg9OhPeqrm4u4lvp7lb eNUG8spwvbaAOo4/HjFXbq1dmcnul2INRls7n7FameWSbALrnbx0DEegGfxJrnr20R72SS0cxRqH ZfMc8rnk46+uOvarg2o2a0Jlrqnqa8F6Ld4/Jf8AdhGaRQpyzHpk+/T14qHUp01SP7QpYmIBplXI 5OSq5GcDJP8AnNCilNTJcrnLadYLa4kVt5Yu5UkfIOv0xx784/HV+0D+6P8AvpP8K2lJcz/r9DGE Wlax7Xp8srXNvqAiAUDfyOFyPw749qr30c0t/JfwurSyAl/4s5+YjuO/SvPSjGWuuljvS906FoWQ LdCNSjKPMAxxjr/+r9Kjn003txJdwAx+aFDqQQFAH6cjP41Kklr8inG9kc9c3LwPJZXqgxMwhiCr nJbORkDqePXgGt5/DS2+kaas8cJEDHbux8w645/z/VuXIk1om7oFFvXsatlZZ1iEtKDC6hMfeCY9 cdfX3re1OG006N9S8ktOx8hCOQpOQM/qfr+uE5PmSN0rJnOXdzLa2j3N4zMwUA53bE+8SSemOB68 1zGit/Z91qGu3bssl2m2CNl5SFeFC9xnk/5BrVR92fKtXojOVm1c9L0m1urifRdWvGC2ZuNzRMei 9z9Tx9c+1UfEGv8A229uI5YPJ0sTfKQCMpyO3+eay0c/Rfiaydo2fU8Z1qd7xZNL02YSIDvZsjAX J/8ArGuQaIPHEqTIzIdsoAHPOf8AgXXmvQp/D59TjlFuTtsXrC0XTS81xAREzb0KqM7sfjjt2r07 wjYXV3YvNdwZinbcMjHlhQB39eP09DSqydnIqmrS5WetaZd3dlLpM7tsaMedFJnqgB6gd/f/APVW de6rd6s6xvCkkjYdSOhweig+vJzxXnqKc7nW5e7YZLb6LB5LSQh2WN5XV1y0srAKRj0HPH0qS3vQ baKZbkLbqpMEfH3gApIHtzz7elV7zV5dNF/XzB+TJbCbUBHeN915CQkhIByByyjHXNZ9vqt1fasL VnZ5ufPkkGQJDwck5zjpSUI3clK9iXKWifU2EeK38y3N424hizomNuDkj3z04/WqcUsEkaWzQOtt lthxy/JJJ9Bj3+lWnfW1iX3ZpSws9parDKwRXKoFXkDtnH1PJx1rQtLaG3eKR2yVGTGT1H4d/rUu Wlkgsm7snklF9FHdF0jCtwoXHydPzx+uao3t5cRSW39nwmZCMSNnHQ/4ClGN2ova+5bd9TREdtbN aXc8AJUBVB+8hPJ46dx1rJuGmmvGlh3fZldVLbdxf1HOe2OBTXvPXoO3L7ps3NpHPHDHHsS4LkxN 0KDHQ+o4Hr6Cq2otcQGOKKUCzSPdI6ryQOSeenOABUXTtGSLStflIrCFdVWzfTkYQudryEZcnPQ+ mcfrV1baa2aAXcyok6kRIxOf3bAZPUckjt69aV7XTV2CjdXWxkX13JpaRzXVyXvZXcjBYJF757nb kD6+9dBplnaatZwo1x5d4CrT5/dgopBO08E52kH6Y78qS5Yc62/QcLOTi2VbmRbi5hUXsTIi7iTw XznPHchSKy7Xwzd3Vwt1CkjxE4Y9Fk2YIIPfAJ5zz9RSi4wTT/rqS/eZDf6fG1tNFfFV1FlVtoU/ uskkE4z1wPU9qmhsE8Ox6hqsuq7LlEjEyKrN5zyAABRyCVzuGO/PHNW5vlWl77fgNJvUqW9hcw6Z JHp67Le5cKVfI8hUzycEbj8x/wDrYqzYPpM0HkG1nuL6SIiRnByh2oA4xjrxgcEAA9aUm3eUP6/q wly9Uejahp+r6q6XGhRxHRoYFa5dRjyERlQB9vHLtwO+FrTTS/DcFq81jqUsmpwSKqoVJCoh+ZQB ng4JHbC9cmsb2SSW+/kdMY6tt27HG6jrPim71eLWDZCXSLe+WSEyJhDLsBG5f9nr7bRnvSDXNTW4 Xzr+M2YEvleRGuSHJUHJyThMkEY+bntVqEbKz6fiZOUne/8ASL11cQ6zqVs2maN5VnDawxQLDKS0 YC7d4OD82VYgn+mKfeXt/Lf28t4ot0hhI8gh5CJMFASxwCTuDE1LTveTu0UtX2uyzpmnazqtrDCE S10uWVJkyn7542dVJJOTnG45wOCPWtd/DMq2K6noennTr6UrBGsuDmJd5Zyf4Bx+JGealySdm9Ov n6Fcsnq91sdjYWkuiqNWlu/tOr/YkLKXBS3XBAUBvu9c8c9+vNeL+JrnU5mv7nTbiVkt3dg6Aqkx IzsHPOM4yR2+lTT5ZTTktAr3jDQ4ZYdL1S2MOvMY5JY/OEyoCBhkwN3TCA9B1ZvY1R1o6UYtStdL u5JLa1mSBMAfvjngnj7owB/+qu+Mp3UeX3V/mcTUXFuT1Ca1nnitjDcNcys+VjHyooUZYj2ypHv+ FcmGe+1M6wlz5dtE6r5QUbTJ3Oeh/iI46ECqg42b+X3kyvexeu7y1kkme109XaWXyTIuSHZTtPPG Ap5z+PtWpa2qW99csGRJoA2Z2wEQ/MWHzfQfKB2pO6jq+gWbY641GyWwXUrlbaG4FtHDG6IMTlS2 WVRyA2QTnJP41mQ3Ullp8ulxPFNej/SVkCDdvO1UXpj5VXPPQMeKSi2lF39fJaE7PRGXa397JPY+ aLmPVbgs0zSyFcoFyiqo55wO2cexBrDtbZDemwjupmleLDu0oH2YjOCT0J5zgf3e+K3hBRuklb+t CZapOW5U1XVRe/Y7LTLdDPgqrKTuH8O72bjj0NZ62MmmxW2oX9wRL5e2NcfJwTk56ADGcnOOO1dM U4xjGW/5HPJuT5r6I1bY6e2nSm6cpK7tFBIJACq4OcDrnHQfXPXFR3NpcCyJ89BbllfDFtzLxkE9 gODx3HXtWM2+e3TuaRSsu5Nb+ZJayWcup+TatE48xVBaSLbkgMOFLAFfrn3qjdraakkENvA6wWzF 5IixyFYHG5jx0A4B6k96mNou8dlfcppcupz9r9lM9mlyzFyCQWBONmNi7QO+OnH55NXJZmMUKzaa k7tIWkDc7WDHACgkDsc9Bmrs7q+iMkrKy1M0WM0ztNHZhZ5HCtJkhVXIKrj3GDx3xnpVTT1mUTam 1rDCI5PJUudzyZx6D3PHbkVSaadpCty20L0tvZWU9rZRtunkk3M54wWwRn2wPw5rn59Nubxr+1t7 pY4I9pZAuPOIJ5JzwOOOvSqg3zc0yJxWqRkXiWltAJWkJuGyoVRgAj04569enWsHzv8AZk/SulJd fyOSo2rJI+ntAhV9GuJWuf37k4iySFx04HPc5rVNiINLE0PNxvw5fPGOc/Xkd+9eW2nJrzPVjqnb crtNKt5aI/8Aq1cK6kAfKeRn+WO1b88r2thDIsapvl2YY5J5/IZJ/T0rOdpOKvoWtdzMtreBrwXE lnunDhhuXIye+PoR279K6S5tJTbXKMnmZQOgO7Iz0pVJWlHstitUtSp4d8NXEV2ZfPPlgHPQYJ64 +nPT09q6zVZtH06K8a9fMSrujiwW3noPx79O9ZTk5TtTWppBJRbb7nnfieKbVBaeF7MFA5WaRypB SMYbr15I/T3rtrC20u40u3FzNA+pNCqRJtBAYKcgZ6AcA889e1aPSmlHdu7+ehKXvSJ/E9zNBpNh ZiVY7mIp5gyAzuTuJI+pGBXiWu65qUxKZj8hVeLfI2PmJ6479enpVYeEJXuhVnvbocFpxkgtpmmY NbMxhWTLYeQEbceo/wAOtU7TSZ8XtzeMGnIMiIoAUHGAD+Xua9GMkuZnLZto9R0LTzqNsY9VsGe8 ldY1wOADjAP4/wA69X060nsprOA2bm3I2bGcfMy8nkdegriru3uJ6anXBbOx1c9pbAwyRGIwBSpi Y/6oHt9cf/qrF8Qz2Wm6bDErRnUoZSUCYY7AODnsMHP5+tckOaTUdTZ2SbuYUWoNex6ml9Bv1Hyg UeMDCnpx9T/npSala/YtMs9Qjs22T4iTa+SCPvHAzgA8fXrWqbTUb6P/ACM3d+8RtNqxubu5tSVt I8OxYfdJ+UAD/AVds0uWvBObcCAN5wZeSexY/ln8qa5UnYS11aFvCqStqCswt2IjJXnkdse+f6Vo xTR/2eqTQxFXxtUfwj/Pak17t+otFqzZsIrHyItT0+5DXJkJaN2PCAYz+nSqvyGGWOT78joEJB3N 1J/InFTzO97aladOoy3KQW5t7ksuwfuyFblsAYPrjPWrNjBc2aLY22XlOZm4zg8gD6ZI49vrVSvZ qQW6oJrc21urzL5l2vDxoOE65z6Y4P4j0qxZrLb2Fm6TfNK5UKFyY16knHqOKmTui0mmaN19n1Aa fe6plQYvKBC7BGFIPQcDkjJ9z1ou9ON9p8BRtwbg+WTyuDnoMnjHH86zcrWu9upXLq7FTQ9MuLeS eGNlRSwkU78MeCCpx0Hr9PQV0etWsdysd6Xh3fKkar8xiAHp6ZxUykm20y4r3LNHP3zW1ufs1wEu PM2FSFJMIAJOfqMnH5mop7OSbX4SkPlIEjIhALFxyw56dQM9ehHenFyW/ZkuN9EdFc+G7TVdWniu EQI6M0YAZVjLJgNn6/r69Kq3DzWdmtlbMs58qOKMwyFQxB/eEHoOSy5AGdo9qly5rR6L+mU1a7Rz Ie91O/sbW5so47meAELGGZ8A7iGboBtOe2QR+MVxb32p2qrqMrokUnmKSUxIU3BRjp94r9Aea192 NnvYm7kdNpOmi80qBmk2wtOS0DHMu0kktzk4YKxyezCuoj0iXWLeY2Ua/aJMzOYIWzFuQfIxB4AZ m7jOBn0rKT97VmsIp27kGg65rNhpeq6elklvqpMUMduMrFLEnmODgn5/nkJJ56jPXjEnluRotvpu m2whvPMb7ZOZWXhlCqpPHcs2O4OeBUxglNu+7+9f8OG6styomj6jpNneWepXUs1pbHy55llCopIC sFbOSxLYwecDmnzade+I7meazEENoPKHlxZTys7VVNzYzlMMeOAeOuTqpRj7y+EztJ+717nfxmDQ nh8L6EVlkkiVJnQYxu2MSXzlY0K44xnc3TJqhYvH4r0bUU1CR21JZzYQyQRhDu+88nI6YwATxnHp g4NO3td9b6v8De32VtqTaZb22kmXUru7uf7Ttv8ARUPmbVLSgrvJPJ2bcggd6fZ6tPa+eLq7/eKp NvKGBicuOHkyfmOAFx6luOtOSvrFf1/THF8uiZxWr+JLu8ubq9s/n0eULI6AfNI6xDe3YKoYgY7Y 4BxXlurvq8NpLfWer/adOgWOZo40JzK+BsjQ9twHzHrtzXTShDRT8vkzkqtyvY5iSXWZPD1rBF+9 EU4RliUGSPc24hnPHBQA9vxrVjt1Phy1stNuC9+0zGSC4G5YMMG8xsHaMAnkk5wTzXS+WOi2vd91 1+450rvV9Blpbvqkcs1nYPbXcKTRFmk271CuSFGcY6kgZJz2ziqs95a2Vnd29pArscSG5R1dZMBc YA6nPBIOM/L3qfebtvb8h6vVK1x+mzzafb2ltFIZppd+xxjMcxzlcjqQB056fhVjTrQvaS2V+jxS R+Yty8zKSzcsxAPTuMngfjSm0m31vf8Ar5iRLGkj/wBm2i6TEXcGaeZ5A0dvaseCR/Bwox1LbuRj BFXTLSObXk1ZraS1tBE8iS5BEyAYJVeQOw9iT6GndpStLvp69PUGr2ONltb2TW5Lu2Sa4kC4UzOQ sKZyzHnoQMA+i9hXN3l1ZWtwLSzVpF2YZjjNxKG253juCTwMjjOa7acU7cqW33HNNpO9zTCyOkUE dmfLmKsZHyGiHVhu9MKOc+tat9YXsy2K7xLp8Q8t02OSGwCCqHknjOPwOB0Jyivil/wGJRTRrbtF ElvIdNaJ1bfL5USbdoU7gBx6HIx278ZyLmCDVE+yRlob252vKHyqrCAccHhM4I29Tu6HvypyTvLY 1svRmdFFM1xa29hDs0kN5bZK5kz3OeADjOCeAfxrM1mO8iuYpYJETTGKx71wS5DKSuVyDyRnv8w6 VrFapS10/EmXwqwrww/YZNXWNHmJKNkdWIIwBnb/AArx25PPFUYJTbQx31xbyBHAjMccnLHaBwRz zknjvzzQm5aX8tQlpuinb6pHcedHJDL9nSVYohwMtgjOMduBnk8n2qbUInspXW1uQ1lKpMQjTLbu x3dB69Dj07HRLllZ7eRkm2rmXqNriT7ZJN+/zHkuN284AOe4A6cY9e/ENsLi5nu5bUhokU+YehJP AAzwBkVenKTp63Me8i0ySbzL1XcopMYixy3Ynvyce/GPSqPm2P8Az4z/APfMv+NbL2kkuRK3yOaX KnrFv0PpK3sjp8Ans3zHJ9wDkDPTv24Pp79qkijvb++SxllIRclznqOMcHoeBxXl3UtX0PTWti7e 6RBLe+RFcEyYQODz82Afbgc/nWpLo17P5X2ty8Rj3rtPQjp/L+RrLnSS5kaJLWyNDRNNuorXUbia YB8naCcbF6fU54P/AOqtuz02e8gupXmAlIG0BiS/bjvzj8j71m5RXM0jSKbsiS0sXt55LV2KwBMt I5XBOOxH07+vU1n3I01IbybUZEa2EJ8tXOSwUZx9SePxx3qebm+FalW01Oe8K6XeNbXGq6i37+Ul gjL0HIUA98ALXYmzh0ybUZoYESGCFB85+bLDB98n/HpzWlRq7jH0/r7xRVlc4HX9XbVLrUrq4iaN kuAqqp/1iqOoI4HUZJC9K8S1mZZVuIpVRZHGY1LZIy3JOO46V1UItWimYVZXehqabApt0tt8QFqR wyYBJUEEdiORVnTtN1LUDPb+ai3TTCEeYeB19/atb8qk29NzNJ3SPZfDFhDpERe73yyytlYx8xyQ BkY9M/oPpXVa1qd8+lG6giAntX8ooc/MVAyTj/aPr2964qvvVIyezOuN4xatqcrFcSzlo7xsTTEE 7V24Vh0Jxjvgc556c0kdkLuFIoolEeGXkFumByeBk5460P3dU7IbXY0ngjjkXz4ZI3is/LfoA5ye Qf07d6q2c97DBNatGothEEZ5uPLDsu8g8fMc5yPQc56y7ta/h/XUV7aIbD9p1aW9QSmOxUkxxjI3 qM8k9CT+VOtZ5Iri508NhGhMbS4+6x54x0Pb0q7Jpx7Cu0zXsrD7HEkJcSB8soYcMTznkHHpzWib JLqwhvdQlCSofL8tRgBR0HTB59exzUSmr3j329Q5U00y9awW7PAssyxwRMfOZVHyqTkc85JbAqlP FLLIL+3kVod5VZOBnbjJzjrQneV2rDsmrFqWGe6hso44wSHDBUUlpMHnrzjjrzViTzBKtiDtuFcM 8anczdcgHknPpz1NS+hVpaNDJYp1R5AmS6y7gBkscgZx7fzoNxPbx4ud0RYDYqrkY2lSfY+3rTtd aFNyT2Nk2LXGjAX0/wC8A4dgvpt4AHTPt3qCO7utNRLGwcPMqjCoCNobjHsSCST1+lZqzfL0L1Tu nqy94c8M2cNuLo3TxTyu8ieYxJIA2ru77Sdx4rVlYWMNxcy28Ulp8pUIpyxJ2nJ9AMZ9M0nKUpNp FqLikUJ9LsDBbXF6saahOFkWJSQ0aE4OfXjP5/Q1raMbS3l1C+u7bhAsZQ5UqDyw3YwDxjODx05p SlJ6dgUUpJ/Mw9UvbjXL2xbYU09IG81tm2Ndm9skE5ICnIPoO3NU4tHnklmn88t5AeRVVWG8hGYh U67Rnj655OKaSguXclxlN32NKXRL63gt7uSRkmn/AHMssUZLECPdt4yVA3dgcbTz1rkobAXXirS9 CuVK6SZFZbiXKiQgsW45wBtJ574x2ppp3fb9AlBK2nY9tvItEtBqGpzwJcv5ATylURxW8rpjGT97 aPTuD0yDUkVs2llNVgu5U0rYsdwEQrHcOo3MgUkEsx3kdANxJzWDbcLtf1/Wp0pWd10OKvbicGG8 1mwgiX7G13unO6RQpwsKhDkliFwPfgdji3lvCbWL7dqH2Oa7kimmdlJSFJZCoG1en3Y+OCQ4PQit oqzXVf1sc823fm0KV3ajUrmNPDGo7rcSGUwtGw3lerZI2qF6k4x8zAc1c8OrE1+tqt3LNutpHvJV TKs6uzskbE4UKFHzdgAOnAb5eS1teooq8lrobWleJYdDv/EOn2umLMZrYKJY0LGNWBJJlPO/KnG0 Z546iuisNLh0mOXXY45hEkcVutsI2bzJ5ArN8zYBGGXJznkDoM1k4uK331NYtPTtc2JllaATa3bF No+15lt1Du+793tU9sfNkj2AOK8j8YardWd83hTT7eOSABbiaYqwdizEBW4z8u45wOSvHu6UeaXK pWS1Jq+7F92ZF2+nXVpdabfxytZWqiNZUkYCYgfOu1RxuCoepwAeleS61NdX1+Ct9EiySANbRb1j K4HyqoOeAcHPOTx0JPZQT3fQ4qi0Vjs5r1Bb6dpV1aPHdyYKoFwm1ch8KeDgOST1+vQ8vqrhbXSt IgmkWJZWvJGcfPdbSSST6AkEDPJ9sU4J3s15/mDSaMm5vLv+z7U6hamL7SzOodsNsyNzcfxHcc9+ K3LOXR7OLSLixgMenfLDKCA0cQw5YYyCegbPTcW9s1KPurk1jr/X5kXX2iG8b7Ddwy2SsIUuJJwo XYlqvbcOir8xBA9T7CrBTT0sZFvI2+ySgC4Bk3LFtIxI7HJcuV6D+FgOhNDuuWSSux2+zI5ZLp5t UlWHUlSwltsjbuYJIAQqk9xjkjPVQPrmavq0+gwtaXesrPIUKxx/MTGjPuOBgcDJxjj5uK3hCMpK Kjrpr+ZnKTSbM3+0Lli2qJcSruYLKC2UK8AAk4GSFJIGR931ptpp9tF5bKZpxEHKO6K79S2VUYy3 b8RxxXQ0ox/N+hzWctTqZLizintVuJDK0aDZjBIJAOcDAOBnjIzgEnBNX4ddErKsKQQ3Kyh1kcgm 4dgUyTjlTk/Lnuo9DXHKMpe90t+Gp0JWlZrUvTRWV1A0Fwkcl8Vy8rsIyzYYZCg4IG3he/1zXPXC 7ZNSvLpYoo3jKwmaMHK4IHGc5J68cA/jUK8rxvr0X9bja0uXJYVfTV+x3oLt++bykBzwSwzxwBjj /Zb0yeWY3GliaT7MkizykKACWHKqSepB5B6dscYNXB3Tvo7ineykkZ9yk0jN5+1LbdwkQGNx3Y6Z Bbtz6kdzVV/LW4hijgw0G9FmLZZlAIPA7kkHpzkdMVstLWehm195SjT5Iks5xLKyhl3IPlPQgfNh cHjJ9ueuJPtF15W2Qh7pjh1cLtCjJAz0HQfjjniqevkyLtLQpLc3N7bMhB8gsr7ZFGCcZJA9Oh6/ zNV3maE3iRxxhUVXT5RkADJ7+v0/pVqKVzN62aM8Ca5DXUluqSsm5VyASBjJzxjP59R2qDdJ/wA8 v/Jgf41p7OMt+n9dmZuKlZtn0RbwSQGC3tFHkqNi+/Uc/j/KtKUuGklEeGQBWJ5L+/4cD25ry3q0 mz0Vpr1LOm28d1cy6hkvCBtJTqv6+v8AOpQbi1sJIoI3KD5pMHoGPAHHt+WT2qH7zSfSxpqldEtx NLl7hGzDtVSpONnbnpmrtpdrpUs08W5p8B4wdzAcfxegPTPvUqOlh3Sd0aU0n9tT+bE37xjG7oe6 85GeeST37Y9K5bWtOM2r/wBlBCYUK3M4YD92F+4p7DPX6YpU3yNR7XLd3qejCewvtGs4orcR3gkC ybh95MDB6emfz61xviGx8wx35vFMAYSSlicFgcKDn0OfXp+NSmoys0VOzTdzybxVqphtLj7PG5Mz MkbjjeAuCM+meeOnP4cFYaTb3SPf2cL5RSkoLbiHJw5BOe/THvXo0lONNs4p+9L0IprS5jvbmxeb bbshHmgjDYxwcn0z7H0zXt3hHwvLfKk3m+VZM6t5j4bLgZwPrwB+fFOvLlhvp/Wg6S13PRdChmsR c2Ny8ZG8mF26ocknPOTgA81BqUun6NDbXu9ZyZJA8IPyM2Tg59x+leddOpp1/DQ7H8N30M1hbW2n 2Ehk8/V5rgNFFuCo0ePu9M8Yx34AqlqGnX9uLl9RY26zSq6LG+WXaADwMkZxj349a0Ulza/JENa6 PYpQ6xJG2pWbwlkkO5ZDztBK/IP6gccV03iO1srm9tLqOLGnlk/dMfunbjLKPcE8dBj8S3JJPo/z 0GlzqxWvdJRLa3WC8zvxJsjO1snt2PQHJ4/lViz02502xjh1GJUnuZsuwIxt/hwev3c/maOe8bta v8R8u5urBFKpPyrAnzqVbr/CMnGegz/njM06NRcTxXkfmWakbJCWBZsHP1A45pJ2T/rUGndG/aIr 2usxQWARpThCxwFOOpHX6nv+NZ8Nvtju7AyhmAZ1VIiF2gcnvjPH51K0cupTjyqLaNbQl1S78q4U gW8biKcJ1VOTyQDzg8j1IFXY7qUy3N7FbNC6kosjIdwYfMACfbuexNJq91FlLm5bssRxRw2sF43m u5iYJCi9idwbqQRyeueWrce2sZEgnvp0AIWIttBCR/eJ56nH0B644GYbs72KUE0tTmFt7tLyOc4a MsDC0mclTgDAPHXcT/Wu8stMtY9j3xCXV1KGlmCDESADbtx3K/jQ5JK8fuLhG797oPvLO40W6gZb hWsjEbjciBgIiWCqB0yeOv65qG6B1Hw7aWcrFL6VdwZflCwplmXk8Eljz2556is7/C/n/X9dS9Vd PsV1sjqEkl5qBDSFGEbRgMMcBVVecnk4PPUdM1WLzyPq9zKpMckhxEWwFI4XB6MSccDJ4PoaL207 BaxkSJeRW62OsKskUonmCeaFDuy/KoCgbgAQPrgdOK3/AAnb30NxHHqRKGT95KqDaWiDo+w7jlSd q9s5Xp1qp25W0Sk20y1b2d/qN/a/2YyrDHd5L7i0SOMggHoSEVhgdO/TNbUttpl/M8SaUN7OwE54 yCVZAM/dAIUnGeo6VHNy/B8zSKvujeu/D/gq+0TVRqGsX0V2rpJDaoAUYRx7gxYclizOSTwAQBls 5898Yareae/hfw9I6y22mo+oTXbSKAzSMoETBeSQAAcgbRu7nFTG75U1qr2e/wDWth1LQV4vex52 the3mp2ptNRtpZri5aQyFcpG+4up6MdoHA5A+UnOcmrFtPc6lcaadXtxHpaTqonihBExLErKQeMj buC8jIySMV0PkfvLfszlje77M3NC0SK71N9MmnkjmSEpNI8nDQu7EquCSx24znuOTg12OiaRpeme HNTe/jibSHWWCNCNqyiX5inHzZKxsu0dpCe+KzqTa91G0IpNMt6bbWSaxc6TocKQWvmNHdyH/l6z 8ojQNwoUBiRnqD2rWEPhmey11m8RXUM0VtHtikZYlknZFjfyQCeAof5+uAo64Ah3u+ZXfX59vl+p ooqz7Hlep+IL1dKmnu78/aZ3uFjuZpgfkXdhI1GSdzEAN/dX6AcIJ/E2v+TqcNmGnMDTz2+QFGAy ozt1x0YDPT061vThBLmlov6/I45ycnyplHQ/E17Z6TFC1okkeWup96ny0UOuAP7+SQuCew9qi0bS m1CVLm/MIYLLc29qkW3esnIdycBFBJweORjjPO91T55p7/gZNubjFqxD4peOafQbA2jLqC2gtrsT bcTPlw20J/BgoOcltvpgVgwx3UDWscd4Y7SFZrQ3ARQzBXwSD0AHzdM8Ioz6UrcsYvZf8EUtzYmt dO1CbUJYLqNBb+UsPmqSFOMFVGeWLfMTjOE5PetS30+2GgraJpMDy211DHLKshRp4wCxKrn1B+bG AMZGcGp9pKyV2reX9dQWrbSOIvNYv49U1G0tYYyJopI12qrQxx+YWVdxxk9sZLHAHGaz7jT5r3T9 VsLma1i0/wA0SPM+0mSTOzKLuAYnLIvoPwrVL2dn6foZyfMtB8esW+kM+nu4PmvJMoMQClGOzIY/ dP8AFkZxzjrmuM8RWsR1ORGjDWo+aO7UMCQuOqsowT6ccsAQCK6aCalzS66+phUd1ymhNb/ZrD7J burT7VKrEAXXr1PfknJ7YA65xXtFmt7M3rWqMg5Ckg/xZIIGdzlhu24xjn0NObTik3b/ACFGLaVy fT7q1g06H7XbSLfNOPM89CW+6FAxxgsMADkAKc10MelvbI0s3lCDdmFQjAozFvmDHG7k8YHrWE24 tq/XSxpq9EZFvBY20rItwnmFBGsj5XBZeFQ5+YjI3HPUnuKi1GzjvLtNsrGbkfvdwYgfMX38AcEj jPI6gDBUZPmba1/r8A0Ssi5ounX+i6lIbK+SMiLJZztVYie+7bhyMHkdOmelRLe2l/eQqVUKEMfz bowN5xglucAHJJOO/Wh6ydSKtoF7e69jKltN1tdWtpNGIEmKbiyBMLz3wSwGB9e1VpbWOG2mj81Q rxxzHblpJQSFVAcfLxnHt9a0Tvp9/wDwf1M7arsUEd4baYQW0fmqBt8tuIcNuOSBgnHOe/AGM062 t38ye/NrtWKMSAAhiuPlOcHGdx5/LHrV7J3ZPVK2hmTtGsgvPKd2kYv5DhldB14XGRwN2PpUn9nr NDLcxhRsTzTFsdN+7GcHuP4cnHX25tScf6+4lq/myi0k8Nn+8eNrqQ+WsOP4OeOvAB4J9eOpxWd5 F3/0CYf++pK2jJJauxm247H0fHZXhlt4lkURhV2gdWxk/iSBjv1q7crPayywyofsbllLZ9e3Pp/S vJ91uy3O9balvQ8xXDWa7VhkZV7YXjOfQdq2Z557W9ZXjAtGLIEGSdw4B6f5/Gs5Jyb5n/X9I0T9 1X+Zjb0Nvc2moh1dpGCqD6D+pP6itSw01JbOWNm2X32cY+YYAyOPT/J9aG0ou+qv/wAOVFRbHwM1 lpklyxCmNdxkfgsQeOv6ZwOKzNEW8EVzfajKjT3D+bISDlskbR7cY9etCatJrvoO7vudFcq7aV5k jr9pV87YyB5efur9ec/j3ryrxjJmSSzlu3hsxDGzu5wCWB3FQOvI/OnRtz27GdXRHjniaZLmws4Q 0hSBcQFickDHUenP6Vt6NaSx6ekTXA3yof3ewgIuAc57fNjqf8a9Lany+bMN5OS2NPRfDH9rRXFr uZtTE8RGXzgHIYc8/wB38q98sZm0zS0008qzkK6DIWRV4x6dvzrkxElO0fP8NDeirJtmTqkbWrEX d4xuAcS/wg7if/ZQTx+dXo7K0vdPuLURpIBAphLkYGW4x0z/ABE/Q+tY81knEvrb+rmeLaO7tLYz MZtQjl3RvnbtVQd3fgc8dO3rV6fTL24iXUZp1kWKLbGcksxJIJ5OTyuM8fTqaLpP3vl/wSrKUbL1 M63n0y4gsr7+zWSZZhEEwArFTnccnPvuPp7VrzGa3gme4eINdMAJXIyqDjA4x1yAfqaJXUrSf3CV uV2QwRajeT3F2UhWS1s1Pyk8BMIOpzlslvbBIxxjTtp5X0e2uorY3FvGxaR7kjmR1bBCjJIUA9Pb 1pStvF/Mra7RDpsUyTqxuVls4l84RBcYc8nI6nr6D0qyUmsZre6ltvNv55ZPKhf5QkY4O7B44BPX n8KTaei0fn97FZ8qfY39N1CSSGO7SP5A5iUbfvNnPQfz+gresZbXUraGx06ELErk3TSADcRt+VV6 4HQcc1Di1ez06m0W5JX+Q8fb9JhmNuiRxgF5vNdVxuIKgcEDJHXrgelXdSvbKzjhnimJgOG8gqSq sVOc8kenXru6Utb92aL3U09EjM1fU9Oj0S3la9+yXaxDzNwyCS3CL0yMZJ5GTjpXJajfwSWiwzag vlvhnwRlhu+nXA56YAz1Ipx22/yInOPc6ax8QR6lZLFa7JFDCKGbGSwx+7HHIOd3X24wMm9qMEo0 +3nh1h5Fl3zWkSdNoO1o+M4wCD9Tyck1m0+b3tfLt/WpalzK6diyNXezjitQzR2ysFkZzlnZG2gs G+6MseD6c1ZiSZZYjaWTXJurlbaRUYlUd1DFQRwzAN90ZAPXFGl9C0+ZPqZlxczC4llbAMczxfeK lcDywwB7jDDHYsODVREutQLw20bRwuUitpfLBU4VmZtxJOSSgA6c+mBVJKxLu9i9FYWuoC1aynDx WkJjNwckxJGW3MnYktn5jn5jj0rvEs4LfR7mS8mSa38zd/ogQyyyMqFfMc87V7gE5OQOpJzlaNl1 LglvuXtPsdSs9XXQ9OuyltcQgwogztGDy2ASD8+fqRnrW5PoVnp+iPts54tciDvbyXSsAyFPvN0B GEMhyRtICgDJNRN7OPW39I15XZN9Di9Qe90zw9Jf28LQma2TypJWXFxnChSD0U4ZeOhDDpmuZ8Q6 dd/8S+ytGjvL24Id2jTaLIkyGZckKGUKVO9+Aex25rWFtG97vyWhlO/K0cPqN5GlvDHZWj28LXEd qUaTYYYw4hLu2cqo8xiSck5frwK7vU9IScWvhzT4DLYxTLplhOrMwnYrhSFPQurAbcfLhs4703s2 9fzsZRSs0iTTrG2TxPfyQyGWOxHkSQPtyxwFcA9yHfj6MTUOl6Lpdt58EettFYQPHI32kbEF2fu7 dwOEXjgHrj6VPNveN/I0jDqn1Z6nctC1/YQSaxY3FiqNb7uivE+8yPlRk8soHG7AwMcY8R8SatZJ qN9DHdqXi2RcgMsP3W8tVBySfcgkEHipppy0jcdaSUDhdRhGsrp9xEyRBWElvBdIojYhCCADwArA nn+9+WPf6hPp7alfQSwzT3F0Q8u5lV2zhODwApVj1IwwGc8Drgrx5O33b/5/kcLeqaM/UfN8gIXR NLEkNpPGH3S3TcMQGP3F3RtnjID9iRm/YPNc36T6bLDPqGAHtZQxzt+YFl53RphW64ye+Kuytrt+ RL1lZFT+yNUvfE1td63rvm3rHaIrZiG3SIzDJORjA+bOOMnqeM5NSsDLqNnYWsscs7pbhgrFCRLg gNnqfmO7vwcHpTsmrQWiS+YnZb63ZoNo11cf6Vo100jRSv8AabeBwVeEcnBOWxyO44OADnAq3mra 9eCRsRjTmRWZ135zKWUDIHzNwD3z3qVyTfN1QawXu6mDDqmnrDc6fNbs04XyosxqoibIyTjnIAAB HQHJ56Uv+JZdx3MFmqx3gcS28BYMyuWORhjkBQzHPTqPYbxU07yd0ZN3VjmjbLJcSf2XbObfY6Ga WQoIFPysMc5OPlwOgY9+KqGKzSfVbG4m8wfujHtlPzFRghcYAy2Tn0PFdaclfq1+DOZpddjppbGS 5jkjsrONbDzULMkhaR1ZsOQowFbAKjkYHoeRjWGjaRdXTW6TS27xXpMMrsf3SldxG7jcykBcAHJb jIGa5/aTtpq9/wDhkb8qdrs2bS3uIVslsblri/jkKsdoZQ6AlTuYZZhu3Aj7u3ODkCp7iaSaO4a8 huZJoSqRRpwhVsOvJA2KNxY/3sZAHNZOykpLR/l/kW7JaEbw3NzZxhtPEtzCAqLHCfugBMIPlH3m xknJzzk1Fa2mqWQ+0XVqJXaNUuIs4AVR32njkEMCeSSBtwad4uPK5f8AA/pkpX1KWozXuoQTWwtv O+VZ7nzPMwMrgZPdRlcAg8cdMgtntWkuRYmLI8pMo27eQpDYXf27nI6Y5PNVZJe6/P8AL8CJIxbm zS7ivLuEI1uWDYR0QSsCGLHGSSeuBjOOvStLcdQuruGa7CTRRqWkjBMjRgnKr90fMcryfccA1d+u 7X/AErXZREOoyXYNqIJdOY7jAjDC7DtTjPYA5zweetc/EJIo47eKEqJJC1yVLEsApGS5Gc4AP6jm tIa6L5/16kO5IsUkjWcNvGsrCQkKXJ35H8RzggDJHbkfSnQrKNNEDJIlu9wR8kchSVSx2qSTxj68 4PGOaN+nUmy1ZBLp7mQWZIS6bK8/KIwcFSWAPBHIPHbr0Kf8IrqP/QUh/wDAn/7GtHJLRq5i99vz Pc4IzHcyLZIAoTepJOAduAOpyM9sd63baxvbnQ5LrU0DT7woCqeBzyR+XXFeY+VR5m9dD0Iq929i pHaqvkPFuwQN/J5Bz90kn2H58VtvYXVxFFP5wNxIQQr447nr/wDX7e1ZylqrmnI2uVEUejrd3hkn Yx3AA2M+CN2evt6ce9NthdHXYre2R9sbfNkja6kEbeOvY0rxleL00KSaaaK96+qX2vXNg2PscKrJ OFGQuDhQT+ZA6Zro5H0m3tUjCbocESFk5ZxyD04wDz9cfVSjZQ5PX/IaV7yZwr3l1dXrqkhWBphI AxJB42g+nGG44rgtduLW9sRbzgxZYqrbQXlI54x9P19a6aS5XeK2/Exlyq92eeTWIvmk1WNh5kQw 6GTaoAIzuB69enfiu802ze8i8p7kCdthVcfOyseBkdOuPxHNdc5+7bexlBNvQ7fSNPTTNSguNLtJ G4JmGSRxxn8zXqut6wbPRJLPT9NcaoseIyqALAvGWPTJ5rz6q55xbdv+AdkLKMvdOFvLh9ShtYdb 2hUiUyhMM0zA8ZPqcg9f5VUuUiZNNn8z/SLYt50avgbs4UHHGSDjHuRTi+S1tv6/4BHqLNbwm6zN dpCohk2bDnYx52n8RjA9at+HbrxBr1xpMelnybdsxSvLkFgA2GGc45JOPcYoklJXlsvv6ji25cl9 TS1uyke61S6lmiWaBY/lTIAAXnGM9c+pqjaw6XeWKO92RchZHZd4IclvlHrz0+h9KSb5U0tv8i2t ZJ2LYsdR0i41u3lVvPmEcshc5AxgBBjjj2+vHWnaZZWttBqEv2oLEzCIR5JIODgkdBxn35xSbTi2 le4ktUmdF4futDgvhb6lKy3YWSOONc5xgfM3sQMD/Iqi4DahE5uGH7tllkIwTksW247kjHp2z6T7 3NqtC9LI6zQ7qJNMSJZwZSUeZY48sgUOCuPUnqemeMVuaHFPC1/fXUTLqLlWtoQNpKkHaQOxwp+Y +vHWs5L40ax1t5HNXF7aXtvDO8pkWNi90Gy7qoYqoTcTuOFHr/rPbFQtdxpaf2lftM8M9vOIrYjJ XrGC2eOcDk98/Smk1vv0IbR5ffzW9patc66yyQoARGJn3BAATtbouSQoJGTzx1rwvxL49bw/o11f 6iXtrB2d1jdcK6PkkIx5OQAMnnk+lehQp+1dktNLI4atT2UXJ7LW58u+G/2tfE2k67qENveOmhXE gaOJhnZhsqDnoBk9P/1foB8Lf2g/C1/Y6Dq984a7sZTLcRhwzXm4sZGGc4RQEAAA5JPOeO3NMpdG KqU93a/raxx5bmixDcXstvQ9S0rxFp01tBbQTpLBewCcEDDSSFdwDN6ZZjjjOfxHo6C3aS5TTNTk jvLIGc+VG0e+Nh99XJAUkkJwcnk+leDOLikpI92FTmXb+rm8sME91pVtJaRIkESxukLhhKw3kgds kbmZs4JKjuDXVeHIbW90rWdJayjg1E3TRqSQxuXwzsu6TogTbucEDaFGaylNqK7nTC3N/XYoweGL bU59z6fuMjNHdlhsitxhpgqqcFvlYgKOAMKMEVcXw5b3zWcFpBJ/aaakC0KIxEkYby43cAZRARuI yBjg9eRuSVxqDVrHZWdnqmhyWF14VvbVtYtdQWC5u7x2HktnDABdx+UoDkg4HJ9n+P7jT9H1LTpb jVn1TU7aJIjHcBjDCAgLkLuIACZwGOFxj0Iz0lO8Vq769vT7zWVoxfbQ8pnvotZtLCSSOO4hkjhV 2SUC3s1V2KQgZ4YI2VQDrKCAM5HG/wDE00PV9Unv7ma2vGhhiiaZVbzxtTLoSRuPK5GAP3bE4AIO 0WmrNf59Dmlq+ZbG7qem2dnqS2Mt7bvdQzR2M8EagvCiIrnd6uzSkkZHTOB31Ht9O8PXBt9K3LLJ Ey2cpkWRbeaZvmkQggIVibaX9d2MnoczdktgUVZtGhYaTqcenaVq4i8vTI5IYp71olj+1yECVgCf mKkI3A6GTknBy+61rT4ry51W/wBVX9/OBJA6Bn3hwTLJlcYZgcKAuAmOhNJ73X9f8MaX5VqcFcah JBYNaQ3El7qEUbtGGTAgTcXwuM7mAO4/7x64zXnerXTz6fei8lMVg26WKXycSRzOSRhAMuzO7Nnk 8Z9ztTVpJpf0zjqze34mJomiX2s6Tez6jNsgtU8pYmCB0DMGaR+udxVuBk5+b0zpr4YtXt7qxub/ AM3RrbY0SAKDJIweSNfMYHJBLbUQHfjJ6AVtKqoyaitv6/UwjC9m3uVbq+aw1mBF8LRQsgkV0u7n dFbtyN5JJJIZgSeM7QpOMCn3OhRLqk14dRa61JkZZPssbF7hUzkAjCrGNvmEk/dB6EAFcyi7J3bX y7+g733K76ddvJJq0VmLVjFFbWkW3HzOY1aNsn5Wwz5Y4JLMCeDnO0250/VYJdS1vSzcsxW7jlt2 CxQqWLNvIw3IYfMDzzuOAtNSckpReq+4XwySa8zAtfFK6FLqs2lvFbWjgQWcgiZmkUsMhFbapBKr u3HGBlueQ6wsHMISLUpzrUUyzsN5klLhkVRwONo6joO2PmrVx5Ltq7b1+W5F3JJdihezaPozatb3 FzI9wfLRvNtcGJQwZsYyCx2bCODh8demAlnLLd6ja2tiY7cOYZ7jePmAYHLMB8oUkLgZLHvwa6KS kotz0Tsc8mnolqOvZYoZ5raZjIicQxSAK1woGFXZj5QCzsck5J7d4717ewt55LqGe2YXCOw2dV4T gnJBGWIznoSFPZtydktGNJErSWkss88MywmVtkMe8K7Qj7vzdGY8FhjkoRkdahSNdPEElvBJ9ma5 ZnuJXJ3DCsGLbQFPzFs9cEDAIzWWt2tP8ytk2QSW2o/6I+noYoykm15J2cKrAgyKD03BtgA7H8tj UbOa0htY9Wl8lVKvJ5gIlnYAblypY443AjHGM/eGIbg5K2sirS1fSxrWS2l/cXt6S0drGGWDE7Hz UG6V8KckNg5z04yOWAGFq1/Hr0UMf2WVIwiypvmJMzoSEL4UnO1WwDtC7gTjiiEZOe6svIh25WVW mupZ5tSuRcSRyrGIzCrNsVSGzjPJBJc+pHPTi5JNfG0lW3jT7bs3farhCx2j7z7gc4AYgLngDkno b5Vovy3Fqld6s5uDTXsLU21yiTyvJuh2udpyfnY4A7d+5PoMUy/jZ4rw2kp+2xMYJAIgFY4HzKQM sNu45Pv+Gq3v0bIlovP8ye5n1HR7G004I7SMu+Qo4XzHbaBk8bVXrnAJXByMg1ntetJazG6tFkhD r5e3IEYOOSB1yOoyOBx04IxVrrf+tzO8r2sCC6VfJt4okKoxjQN88zkjPGcrnj8sZzkCz9hW9t3S 5kjWMbY0SNNnmuBgn5c4wCepxnPJ5NUpW13C3MtFZEdvbW2mzXupSMs0rKFGVLEnpn1Yj5eOnbsa d/bv/TuP/AEf4VqoTn7yMJPXa/yO+aeS4vVitYmMC5VSoIyBxn+f+RXqOnR3raXOscsnnykbty4C jHQeh4+vrXlVUlCLk9T0qd+hi6jpWoxWzNZzbbtcZPPToaZCdl0beUO+oqqlcgheOCc/ln60lZrT +kaKLi12NK3uFi1CGVpNyspflTtR8nCngHrg/TFbL32l6Fp93fzXKlo1Zkx3OcYOPXt9faspqWkU ty4yWrb2MnQZJ7eKCWS3El/f5ecFgfLJwyjk5wBt9+tO8QTadpz3VxdTq+oxIpjh67W554/iGR75 Ap71NP66A7KF30PItcvbrSdKtzbR/wClThdzO5JXcwz06HHHt6YxXnGp6g86LZMwZipCGM7jESdw JY8A4PTH869CnHdrVt/kcdSUm7LYZDooljKmeRYlj2uFJ/fFTuI68fh7dK9z8D6PENlptZjKBIrM pGxFyByRkckYGeTTxE/3bRdKHvLqdx51h9j8uCMJqSxuAoByy5B64PQL19TUEV958s7z3BjklCRx MEO0cEHPpjb0J7+9efZvVq51aK34lJrRPskscajfE5aNnPRCBy3ctnkCsq48P3UEIl2tHyJmz1fC se5PfFaKSTtITi3qtv6/yFtre4ecK9uZNVM6oo8ssqLwWB5ySew9Bnua0CrNBa3UCpbww/M/zZG/ JOAF+8B7E4x1pNq92xRTu3Y13s7C/S+gNwrwuAZpmTLNxlQFHJ/2vyxXLtZWcFr9tvbyVIEm8sIk XG4/MpGM8DH5n8yEpLSK1KslZnXWsdrdwSXF2kj2YBVC+0M8jBtrEZOcbSfYnv3gea1t9MjnSxEl qWdpWxgQEnEZORyfvADP9ajVuyZTSSvbUeLa3vfsUeGWaA7p8D5pQw3bhznhVHPU+lbkaRXJGqT2 jFLONt1sVOV7g4IyT86jA7kdqL6WX9X2+4SUfvM21nvMSw205t51AcRBSrDdzvYk5bJYjAxwD161 o+ItfnS0t4G1AS/u0R5C2HMYOz5m7cN2Paly801dalczUXroY0viBYLa20GyWJ0VYkLISHkORj8M AE/7tZmqaibQ6tpUi5jMaTEE7N+0hQgcnnOcBRnkNjgk1UY66vfUznNKOx59JqE2kreRS6b50Drv Mc8oKIzsSBvwcBcMeepHfFfBP7TnirU3ttM8LzOWjmaK5dcklFjQqoXsFG4Dp29q9rLKfPjYOT8/ u/zPKzJtYSpGMd7L79D4onil/wBZErAjoD2zn/P0rW0Px3rfh+4U2l66uo2j+7t79eOwr7KdONaD hLU+OU6mEqc0HZM++fgr+1DZWA0uyumhjuUmgVRIm4MwO3n0JzkngYXHrX2XpHirT9b1V9Sk1FZ5 ZBKksE7q8a/vThVVfvJ5caqFyMnknAxXw2YYKWFrOTjve39dz7jAY6OJpLleqt/Wx9HeC/iNb3Vn rdhrtjPLd3qSQSzRxbEiUkl9jqCyjzcKRwT8wzgmvbLLRfDum+I/C/kyJqCJb2epXVz9r8qONpEk JiwwJUDajNlTgOFJJLhfEqR9nJx6O+u/Q9+i4zjF9UTa143ljtdQTQbR1j+2NbLuIbcixrubcynA kk3E4GcZByDgO0DX4f8ASvE+h3mzSbhnj1ByuLiSNdoeQPyqO7Zj4yUVQ2SWC1g6bjD3uv8ASNed c2nQm1/xBda4bC20GxG+WE3txgpFHAipFEjbjwFLyNjBLMZWz14xL2Wx8QppGk2F9b2sGqJJBclY 2ea3tU2AO5OAsbYOEGCcEkheA1dJOT1/r/IU/eutjiUv7aPTbTSIInjjU3bswi8uQuHRAEOMPlhl 34AxsBPAFTUvC122kaBL4ssXjbTlmnFrEWkKQH7kTHJUvtYGQ54LDkZVRumovmvrf/NGXKpaW00N HTYL3UX1q7sdceDV0aYwRQWhkkZipyXk+5HtVoz143JjBDY3XubC50jTtJn0qK3SCE7nBd55JmQK EllwT8u9ZPbCqoyN1RLWStpb+vuRcUuW7Rdur3VYEsJl1WSKe2ea/wDshj/coFSNAqK3yhv3eGOC 3yDP3RnzppbW8nNr4gnuILMLCkkaW6BlmCMTjcPlGDkk5GSBzjFOKbSa6ee5NS+zZ5XNe+IRPOun ZF5C2WCrgsZVXJO/gqF2rncem7I7VmuI5Li2ukQ3dhAGS5hErL/pW98ZYZ3nLxg46DgY6jqjBK9t /v6aHBJybtL+u5oW1teR/wCj63aNFJgRSsDuHnAHrn5uC45PO0EDGV28bKZ9U1/TI9KmuI7WJ/Pu UGSGmQ7lUZzvJ3EbRuyGC9DiqirSlfVb/gwbasludLfWI1Mx2ULxi9t1USXVw4i+zRMS4Yx9WLjL lmHLegGK87TTr+ztH0+XUZBcXcxW4KSeVJCpIEalgpI3Ng4HPyknK4zcJRa5WrkSV3zOX9fedVJo Os2yTQy6zFGHNtJBG0T4cbsBeTgjCKNxOCGU+mNe5hs7661u4tbZUma33TlZ38uZtrLIAjYCIQXY MwztTAHz5WOaG8NF1+dvxvcErXUnc5XUksp7LwqILJbTVvKVp5NvmeYpc4AAxsyQpGTkDGeCM85c au8c13/ZUkq6wu61Ty8KsZQgOzD5cAAdSGJbpgj5dqalL4lfe/pczlazcUYUqfZVIe036b5uBO0n zypsw7cE4znlc5wQM8mtyIXVrbl723EVng5kiTKQKwdkDocfN2GckjCjOGWumSvbr5f18jniru7R Su5BbRLf3ssM9pNZJZShFO1ZmDAEBzwQ67stkFgWIwSq2xe6be6ZPBBuYu5Ywy/MxUbjwnVFQbcZ Ockk5Oa53zaSWytv0NlaN49TmrmyE8yxX0Zt7QqxupGQqEUMQgB+9gldp2jkpzwM1d0+C1W+sdQO nQyQwbxHa3fmkJuA3MVC842L97A5zznBqTly2i/mS136mrqMcNxd2FvHAfJliGIrWcb2mX+ErKPl XcrEZxwp2lsVDdySWqxSa06xXly6zKJSpysY2qxJyGCoG4PHzH15zSu1bWX4+ZTempXjtNG1PT9S ls9RiWKZg0QuAVHUkBWXiRsL8x+XOwDPINR22qy2d5Naz3okLxCLesAAcbSoJBCkKDz2yFJGR1qz lF3i9P8AgCl3RJqN3aRTGa0mMt3JE7fMxwTkMWCgnAPynaoAAI6cCqAluWintpdrWcwAEir87twQ kfBOcgfdGcD0yKcVZKUlr5EN6toYFsYbxRdXsykReXCYCxLlhgh3HzKOp4XPPfINZOialcwHfBfb rOKQx20XOHkIX5QWJG3G0lueh4/vaKN1K8fQzbeiG3zXEV1HeXQ3NOzsgdSyuuB91juLHcc9Dzt5 5GZdKhkitmuJdP3yQxkiKWU5VTgghByckDrg8j6VUrcvuvy/zsTa72uykmiwTiyvDeZuJFkkCsy/ J1+XIOPvEZAAz07VrpJBPGsVxdRIyqAWUAk7f7o6YyD29M9K0ivaW93b+v0Im0l6mlpNi0s0dvZw FpXdZIW2sv8ACck5Pf8ALpjFdf8A2F4g/wCfdf8Avpf/AIqsa01zLm/MIw5lobGixG1DBlRY2OQ+ MnaD+Pfn8vWtyLV57K18i5ZWgyzoFH7w56ZGe+7+VcMo8zt/XzO2MuXZGo+spbadPE1ift2/chcc AdM/XHrXMrJPqU9nf3jgRRE8KMGU9RyO3r16VMadm31/4FjbmutEWl02+1LX7i2edItLmjleQIOF 5XA7DcT6561y994dubnUrvw1bXLm0hxNITknP8Kkdh1PTt3q6coxlZrRK9/QTi0tHuejtYaRbRxX EkkpuY4l8uGI/LnjJbHXGMYx1rzvWAlperNbgTWUbhj5vylpDjfz1PVjj3qYe9LVaDqaLQ8z8S30 l093fR2/mPEFjmYk4iLH+HP4Ln+WawtI0ZbOS31SWUiV08ySLHVjwgBz3zyeOneu+PuQ5U9zkdm7 nVGyikmt7ixuCVt3JMKgDzCdvOTj06e9e4aK9zYy6RZ3recxV4pWwqj+EljjsP8AJrnrvmilLc6K Wkr9DXSC3g12WSGMrHJlNzJuAXoO2RnA7ZqxqNhpOn3zTSMraUtqWCD5VeVvvZAJJwffnB6VyuTs l5f1/mdDjdfM5iDTJYtHuX+0s9usgBVWAKOx4LNn7oIHvx1NUryUXsV3c3115bRnEcIILeWAAowT gev6d6u9tVHX+tSfs8tzfstVjubc3OnwpHdTSGENK6t5THhcbu5xx09OnFYkkDs9xZ3E5GoKNkkq sGDfeLMvQFuQeT17eiSs2uw3r6EcGmWemWbKdRMd3JkmMvukcKOAQPzOB/jUGrR6pcNZadHsnhur hZ2GSPIYAhc46fd7eh6VSkpSvJW3/Alq2iNqwSWDStSt4rpgkDo0lxJhlMeSG2jOOGDL16Z9cCxZ 6Ul+5trnV3XR5VMssOSryquSqjk5Y5A/4F6Cp5rNycf6/wCAUoqSScieVLqK3uv7JsvKuyXBUn70 UbYHU5J6DgfU967K1lmSC6vXw2shADbCNtsSLtbc3O0E/QHnsOKh6rz/AELjde7b+v6ZTvbW8hFt 4w1NILaAo8q2fmRySXqqFQ8gcYOe2OGAJJrxDW9WluTcWcVmslwzqgmKuVhXcFVfx3HGOuSeQK2o xUpaPRaX9H/SMqzcXay1MZPNQQiWQyXqqIpJAQAXLE4BHGAu30A3HPTi74f1zTprieXUoWN1bSGL csLFGuOdxDHhu6jjqPrnolG6ajp/kzBPVJo1PENqyW7lvL8u5twAqt8nmRkiTOCS55ZR3wRk88fl N+0D4gN74/1WIPH5FliyjWEARjZw5GODlu4/u16WSwUq9+y/yWpx5hUVKnzdnf8Ar70fLV9q0kt4 0scnQbfTH14+tUDdR3O7zVUOc9OhJz1r7KMeVKx8hWrxrylGWzb+8VGnspFljlPl9QQeuPevpD4R /HzU/BlxDY6lKz6M8qGcqcykKQRgtnHQDIHAJwDXPjcLHF0HDr09RYHEzwWJSlt19D9JvAHx00zx JpcF2dZ+0mQTxtbKyxSxhkUxjav3gpdiF+XIABJBIP0ufifrmi6TbXU9rm4ZCsV67ABo0jChQg+b aqsBlhgcN3AHwGJwfJUdN+67/wBbn3+GxSnBVIu6t/XzPOfHf7Tfg/QdP0HR/Dl7KNdtJ2a4kcg+ amyJQML/AHOTnJYknJGcL4Zo37Sv9p6hp1g9zcyeGFfatqh3bWwCVC/xA7Q7biB0H02o5ZWlSdSc Vf8AqxFXMqSqqnF6/wBXPrv4Q/Ei61u38Q3s+pM0DXEUEUl8wHlxPG+MhPmaNeBgc+mSrGvoXTZJ 47iWSy+zs1zp8st2ssUi3EKAlVSKMDAcrIJOSQoYHJYEV5daHJUlHoepRm5wjK+pp6glxLHpf9nX 0JYQy2lqXiLtIIsS7/mPd8L833sN25GLf391e6jq2nrqMa2fkSSzI84Z0iRS/lk7Tnc4O7nrx8zY U5pK12ttf6+ZtrH5nW+G4V1XRNTliLxyK+95IITHHOHlIZA20ADL4JJJy20dwNS/sray1GTTfDaR SXhYmWIqzJEpxtJYnGQCuWHyjGPm5FTzNNpl6cqseW6zevaX0PhrxHdLNaSR4t7hEBa3tmeQyOFz /rDt2c7vlZunBHnWoa9aWOv3188dxPpq2sn2SC58rcG2IoaQg4zlk3DPyD5QGYFhvTV00la+3+Zy 1ZWtps9TljJLr/ip5IYQtqLeSQh4CgDGJt7MP4lQAlcqcCMYA5FXU0ZrDR7u0SWFtPfy3meBtkuY 0f5C33uJZQGwccjrgFt5PltDyRzKHMnL1Nye3kifT7fVL6ORprpvt4aRTNPPmTOXky8jEMPmYE7i M55J49LmS01C8jgsEYJE9lYSmXY63DyhBIwGGwCSwZsKMhQQihQo2kpK+j6f15DlZWb3/r9TL1fU rSS71m3uQ99h4vKRAczyHcGZ3XAdfmVlwQDtUgANVQ+E9Mb7NFL9qmtPNSOeKWFwS8qeYD8w2jbh yQBhVVSeGJrVc1O1tF/wP6+4xcYyNC2+xwT/AGaK+uY47M7pGnc5aOQssIBAzINrIwOOVBPXGM6G +064v7aS8s4mU7VCsgX7QqpgnAJZFY7flxy2/wCb71Tyyu29P6v+CC6SSZkXeoavpmqTjUr0S6ms gnto5FXysHcgMZIEmRvYhc4wpypPyihfWWl3chh0/Tr0SxlvJZCMRpuVULkgjLFS5DcEswBHNdFO PK+eO1jGTvdPcqixu9Ns7c3p3K86yQXBkJCFztYhV4PVOdwAAY9AdqXVvfm9jy0xCgRqJZkCYVY8 L8vIzuJzkcvIA2B81SlFu/TX+vUFBrRjoNCayNzePqIXUFlHlI4+SGVBlRFlsuSWxgYKgf7WQvh6 xWyvJLia48i8g4VlVFT7453kEZLAsCers5I+XNRKSlGTvv8AkUk4yTK9kmo6lp7Xuq6sJruMeUY4 ipDKWPlhjIACy4X1yWB4b5at3UkS+dbmy8y+kJtwRuDPKdioiHaAVVCjFsDJ3Z5PE6J8sdF+gar3 rblEi4e+vkklDafcF0l8vCqmQeSVXIHyklV4bcRg8Yv3FzcS2ep30Fik2nWhidzeOiB2LKQqpMfm bA+6m4hd+RjlSy5lJOxmuZJ6XMKWyKQ6XZtZhL0R5jKyFnkmPUKMYHABCgHkgEk/KMK8t4opY3eQ XAOfOaRQiOhbHlhgcljgjPXrjrWy06ktaXT+RejRhcMEkU2tswmk8yLdgKmGQA4BIK9w2eBnGKp3 MsEtrb3FrHvyHcvI77skZ6dBnjkdkI9qN3d/1oS22tVuNuJpzDLYTQoXZSy2odtr4DFX2rknj5vn 4zvwKp2GlebbrFe3AW4KyMFkUhZfuKyqADyC2eG6E5yeK1TSVr/13M37zQ+G0hmL/ZZWkvYVEW2Q AnC7QR8oPzEKPTnjPJI19Cs4GuFaG3jS5RR9oin2sXABOCc9AdoP19BwpN8ra0DRbG2NH86P7Nbr 5cBkXZCww2M4YnAAAJGevPTjoGIlrqtqMxpDcws0RMkLcyKfvFV4HJxg5PJztzgEm1HR3728yeVS lzPboRveTRSzeTOoXyXh3SsHDgdditwOmeB3GMnGMf7W/wDz9D/wHP8AhVwpJR2JlOadqbPT7mS5 uIJ7gsywqMyJkkrk5/Hvn1osdStxHbatIHM3mBWDEncB657Db09q86zt7ve33ndE19SvpNSu1uLa IbiBEydFI9+nocj3/GtCwn+zQxJd2Km6V8H+7twBxx6Ej8zWVuWOr1NU7Sd1oR6nrcFhaz3FpYET xSAnJGWD5ACjPPzYJPTjt1p/he1Ph60iknDSavdsZbhjg8HkL19x+dFmovXV/pr/AJFKzkn2ILqc aet/Asytf3cPlxPk7YAGYSEYI3H0+uPp5Tqer3CaV9olvh9ot8KGyC0rljlie5xj9a1pJSeu91/k Z1O3b/M88M2rave3NjJiOw3KZCrOA5+U57lidx59c11ehJbamk8t0P8ASIYtqxkYA2kbck8c/wCe ma7Ki5Fpra34nPBO70PY/DPh1LSS9uLm3EMjsfs4jbHmMACT155brz36d960tbhrq8up/njSJ1XL DCSZXJHrweuOfU1wTd5OzO2Mfdi0jQsJHDrLd3WQIt5RcFnY5IGMHueR3xWDrPhqS8lijnv9tmoa edt/CuHxjpznJ7+9QpKMr2uaON0tR6XIc3tjaqiaZMUd0QfvZAnQAjPG5hxj168CspdGs3n0+CMF 5bw8RmXdsUjJO0ei7j6ZIxVJyitNyH726sTadpUdrNd3vmBnnlZ4EkYEQAF1yAc5I6fXgVktay/Z 7rULydknjY7SWxJMGPIXpgZIHJHA59Krmu7ryX6EtNWVyfTrOeS5bWtQBkjSNk89s4RlQKRnOWLM GbCjjK/Ub0F7p8V/JJvVfN2wRwYJZZGGSQeQW6KM5A7dsqWsu9tNO5aVtWTz2W3TLbSrlCmnWkTS YQqDKw+f5sDu3TvzzmmWQjtoWmlkiEUQDZX5t4LJleQNpIy3G7ooPfE3unb1+bG0XdBs5vEF9Hd6 i6x2emuvlxspCsjqyqTyB947gM9QfoOrsLtYtR1tLy9thY5AEkbKqkoWDBSM/KWVFGGyxHXkUpWj eO9l/wAEuD5UptqzPDfFOr3Gu+JdS1aznW20qSZntoFlDptIAVVByTgbTgdOck81yd7cpFLd2s1w GuMbi6keVb7SVBYk/M/zsAQDjccV104pRSS1t/w/9dziqPmbl3ZtBEvpDbWs2LCZ/sscQcKwK7Uy 5AAUBv3hJPCjqeKxdNkvVnt9OitliumuTIk0qrLuDkMWVScLhFycjnIHPSrWsWnp/wADcl2TTTPU NWt9E8OeCNc8V6vZs8OmWt3O93ddblkUttRD8wAIIGPvFgR2r8DfFGtXesahqurXrg3NzPLdMqgK qliTwBx95jxj/CvX4eTnOvUeysl5bv8AyPHz18qoUo9bt/hY/Wb9lv8A4Jn+EvEvw+8J/EX4z315 JqWrW4vodHt5DCtvbyDMPmtgMXZSrkDgBgOtbn7Qn/BLHS7qzfXPgfe/Zb9UJOmXUhdHwOgPUE/5 FflNfxdxNDiupTqQX1CE5U7JatJte0v8r27H63Q8JsDV4XhGLax84xnzt6KTV3C3ZbPr1Pxx8d/D bx78J9bbQvHXhu5srpWZNssfySY4JRuhH8vauCYR3Em6Bth64yf61+94LGYfHYenjMLNTpzSaa6p n4Lj8BicFiKmX42DhXpu1n/Wvk+x03hjxnrfhXUbfUNOuWS6R1cHPy8DHI6H8q+mJv2svEWr2As9 VL71XyWaJyDIhUAjPoWAJH+yO+TWOLy2liZxq295Dwma1MHTlRe36/8ABPnDX/iBqmr3s9zZ3DpG Sx25Y7QTkgknkA/nmoPDPjrWNBnM0d24l3hnYEgk4Ix9OtdbwtP2Ps7dDzFja3t/ap9T7m+D/wAZ D/bOn21xcFtGVVjaCJdoLBNkeWJ6DcDjPVcnFfr58I/HMevE3N5F5NxfOum6PtaY/Z5oo1WZ2EeG k2LswgYYcqc4AA+FzjCOhUul/wAF/wDDH6PkuNWIpps+k/D66faaNBcs09pLfwGJJLSKMvYw2zyp gM7bo3PzjdjneVBDbcU/EXgaC18KWHiSOEjTDI1vHOFkkR5VYM3nqSuQBJEBjapPqcGvn1PllaXf 8vy11R9HKCtcms/Glj4a1/U44WnlMcD3CxOLdl3oXV1L42khWZuBt8zb90gbeI8ZeMNJ/tG0Fnos 1jLbTxxX6bWWaViVdUGCTgMjF9y5xwoz8wFTad+6IlOPLZ73PLLrxXo0GpTxRRzXfnMPtF3KzBJp HVZwY+g2MSpLkj5GBIw61xyQ6XMNSto43juZ7dryR5CXWLMhH3lPykCItsIydyHaQxrrhzxi212O Go4y0Rp6eNljpV7LHOs6boojGrGW4K+XGrBDwPMlaTG5mO1GPGUNYF7pem6TaxXt+iXU0akxTX5/ hSPJxgANl12r2BmJq1v5vsS42Wr7M2za2ur39pqL+Rd3VwqSWsBkMhtyHOXdmK7mKmTDOAMrnAHT Luott5Lb6fcRsdQJTCxZYbWYxkMwKIAJVcEcEhT1BANbWeyX5f8ABE1d3T3OtummtrXWoLq9t7cQ Wpd5SY1nuxvOxUMYYg4VFxzwxDHJLjlhqyrFNp+mag5s0ZYpvLP7uNpF2qOvzZAYDJI+UHBKkVMP fWqb/r9Ak7WscZ4j02eTWFu0+1JcyuIpL4OfIvJYyC+SSQshLou4Dksc8hRVwPqFlHea3qBV3MjR RQFTkZKjC8fukUgMcAZzjgKM9C96MYrf+t/NbHO21eTMu5carZ29o1r5ur2x3hiSI97BWIwCcjhR t4OB0zmppYLqGyCWMhGpRFVciVlMpVcDBJIKKSgXOeVZcg5I0k1Fcs9v0MkubVIgeXWFmubGbllB BMrgRxovAjOG8tVQvMSVx2L9M1x8N39tdIIobiaKdFaVow8bcLtWQgAoGUkgFs5zgKcDCjHRyi/6 /qxT3sdelhIIZDNcrcXsEqzx+Yku8SbWLLukB+VWK5YgBtjDcCErh9YjF1cwwzXEiOzMwWLYkabW OXdmcq2Gwx24GCM8Aipg1KTstV/w5U7W16nTXOlXEFnb6kusMZr6583zikg8rbGHyWwCpw5Jfbnc M9c1naZaxWk9zc3VzJM4lYJLdEqYuDvK4Bxyy4G70yDwQc143hGzf4a2Ja6N6GbBqemwzGTU9kSp H8rMFDMCc5BUg5LbSxypxtHA5OiFVUuYZLyS4u5JYw8twCX2KOu7cFBZdgXIzwBx0qmpLWSvtZkt qSuykxntL7VbiOzllGPlkkhcbCcNw7Z6nbyBz7jpiadc/ari5jbzRAvz/dIR9hBQZwQCSV5yMggD 0qrR5ZS0exDtdLua7Sxh0keKFrkuAqBg6yEcb2Xb8p4bOQeox1JMbWI1RY5bwolkm7bJJKIvK28M wAB4ydoHXIJx0y7pWk9xO17Iop9n1OKG4vLpNsSZtmWcbiqlgQzHBw7NnAIxnCjkZ1ILy3iaW+ih eZ3XyYnQnytwXBABGCfmztGSAw555pp6xvtp/mLRe82QnTL6eFNQhB+0FmjnQPgy5Z0YYCnGQuSO eqgjBOd2x0W5jknhtNNhkvLgeZODIgChMAlvXcFGOPQ9Fq+dKLbdrGSu5WjudcdOso1t7zUrtrzV Y0U+dBICIgmSRx8qNxwQCOc5yprjtW1CecPFpiKtlKnESyYAyvI/vMDk/wC9kj1rKjecuZ6JeRdV qCstzjNYudJ0y21XU9X1OK1tof3s80hIVcDIdmYgHHy459O+DXm//C2/hh/0VCw/77T/AOLr3qOF xFWHNTp3X9dkeLiMRQhO1SVmfV2m3C6iGmNkyQtgOzY2uQoIP0z+h7VVltr7UdMu4r8pEsbM8ewg 71BwoPfJ/wAfw+Xtyy1ex9HZyirIvWNheXGZpIPKES5RVPLL1z2x0rRupftmn3EVjBLLqrqI9uFA iwcM2cehH86iTvKy6b/qWk0mrGBZ30ut6nYaLbWKpHaJ5s8hPMzYYLk57cH/AIHXaPpoS3n1aa8k F1KVUYkxhTnccDkcAcUS92yTu3+pcVfX+tDlvEksd7J9us38tkwhUfMu1hkjPQfke5+ngl88cqXC RY+y7hncCwLEfdGD/wDq7+ldGGv16HPWd5PsXdPk82K4kVULqSgOcjnowGevHXpz2r0fRbS7ub1S qKJQUibnjj5cnHpk/lnOBWlT3b6/1oTT1setpcWxj0u3S5SOzCuyFiVLE/Jwo+YjknjrgcYq8NNe 6eyskBeKTCEOx35zkcLk849D0rgdlvvc70naxU1G2RJW0m3XbdxRbVDcKdvIbn0HGCOorAgaaG4d 9Sg220bFo5pPuSMOvtwCendutC1Tvv0E371l6FO6tL2X7HNDcJDMIsklcksrHBCnseSSffjmratY I1qmnSF7hYnX7XIApJz8wUsMjOTyOOg4qn7yVunXyJ2upP0IrMiOWWS7nSG1BEMcYkkZhhS+eV6c 9euTnsK1EP8Abc8bapN5UQUHyQrAR4GBx1JwMe2OM9QpfzLWxSlfQr3F7dwzT6FF5M8E9mtzcINu 23yyhFQYzv8AlkJ6BQDnBNYlupv7ebzmQahC7QWXy7pGlCqQ7Ee5O5uuRjPFUlFLmd77/wCf4aib 5nYta7bXTzyW91KzW0JSN3jfat3MXYOcj5WQYAHUHnBFbVpolrNoV/frqBjlZEktbKKEy+YBNtcN IzKsYIjc8bichcYLEO6jBO2l/wA/8g5bt3Nvwi93rL6hBo1wkcjqXWOZX8yR4nQFfmACqokYEtj7 uQemPPPH18LODUNK0bdJZysUmnkLNuVjvLEg5GTuJyTkNjgc0QXNXUHvpf8A4AVGlSUkcLpUmixW H2y8gkea4Uy25mX7yvHhiuThArjIOP4jwMc4NvPJc3dtcz3avbSR70ZQpk80OxLnPPBfIOBhj+Nd bvzu/wAjllJK1upvfbbPTLWJin/HszSoSpZrjcfkBCk7hnB2jbkE54IFOtb/AE+/1CwdkEd5HMr2 wlQiQDapy+SdoA25ycdcDkVKjN3mttRJp2TPKf22vHumeGPhj4Y+HehSn7frbpJOsjZaK3iIfknp udk98h89sfA37Mvwjm+Ofx6+G3w68gyaTc34u9TxwEsLf95Lk/w7lQqPdhXowxH9k8NY3M5aOMKt T/wGLt+RxUcP/anFGCwCV0504v0clf8ABn9Zz2sVuywwQBbdIwiIgAVFA4AA6ADAwB2xVQxHe0p6 Z6ZyQeMda/jBTcvebu2f2IkraI8r+Jvwb+Hvxc0qbQ/HXhy2vYGUrveNQ6ZzyG5PHb0JyOa/Ev8A aO/4JieJ/C8moeKPgretqGkrmQ6ZKQJoR1IQ/wAXGOD2ySa/WfDjjypw/io5ZmMm8JN9f+XbfVeX c/MfELgWlxFhHjsClHGU1o/50vsv9H09Ln5Wa/o2t+HL+50XxJo81rqcXyyQ3EbJIp+h5/HvmuUm EkEihj8nXAI+XtX9V4etTq041aUuaMldNapp9UfylmFGrSqSp1oONSDtJPRpogDiNcA4b07E1saN ay6hcRKEJ8xwuOepHp1rduy5jzYLmkkfYvwY+Guqambe/SLGlJJiaTYzLb8qHdmA+bhZCF6kxkZG a/Y74KeGXs47VtQmvbWWydJlnUrvkm8wZQLnJkIYhwWwDxkCJg3wufV41KjjFXsfpfDuFlToJy66 n2tpcVzPoMmsW0j3U5tZLRB9nKvvmLedhQu7cHLKHAXdwMbSBXnFz4xvLe/1XQo2eLBkivdRmXzW TYTGIVRhsiD5VPNGXy25SrBc/KKMZNprbz/rr1Pq5SlG1uv9XPL216002S+0lYRaebPvOoxljNti Ct8n8KkvKTvBJZjCob5VxDaSz65rl9Bp02fEAlkmndLV5CyIMDgDLyl2xIM8HsAAtdcYvd9vTQ5J Su0l/TNfXdJe78W3d7rF251VmvzHp0aCGKO8MkTOCgyq+Xs8shiMeV95Qu5uQTTdSsnu08PS3Nv5 ERVUK7HnLptlLnlRHgnkA/KSF4XdThOLiovp/VyHFKV4PW/9Idaxv4etluNVjEsK26lo5DKs8jEh N3y8sdxCZ6ZORkMM6N55ukadeWen2BuNZNrLaXEkxMmfmbeAPuhCg29edkuSA+A7Jy0/q36E7X5t zldPhureztdRsEkimYKZLBdhSLzI3XLk/efy2RyeNm5iOiA2ra0lkvZNFcpdWdopUja8Zec8kEHh wsa5xwW8xBghgRUrXbe6/Hz/ABM1zXsJZ+G01X7dYyXsLXMgSe/S2JdWA3v8w4cZETE5H3SwOVY1 Ru4PsNivh2PTP7NtTNDd7bhFKMVbzCQy7WZnkDhnyue424ApT5tumvqTKKive6lXWru3v/DVjY3F z5LWc/2n7GcmS5dgmWYrlkUy78KGygHTL85k8huI8zXTC0nR4Yl3MzwlnVSDHwQxXaDkDO085XA2 gnyrTVN/5mU7y1Xl+BNK+nQ6bLPeaewFxdEx+SyZmiIlU/KmG27kUEqf+WbDIwAtG602HSrwx2sF 1Ekrf2fDHIPk3h48qNm4B0LpKSQSPUkUnN2ab0/ESS0bVhNU0yN/t15FbtLI8cglkaGVgkcSq86j nHybUQEFlCgtngVzEdx4guFiki0w4ifzbjmWNollLtvIBPHOFJOOT1wuFGKknzuzG/ddonTwLp+7 S9d0+yQxJO24NbI5vY1ZnQMkmQ4bejlGxkOmeGYVhxMkk0uo22nRsi3UsUFyylRIPkI25G2MHAIX acGR+vSlHn96+jWhLa6bG5rukwatbahf2e+W7SGOT7O0zRuEj+Vo2JxsVXwoRjyVGAOlcwdYtBfX CWhmFtH5jhowDDI+1iv3goY4AySpO4MechaIXnBJrb+t+oppJ3ZUgt7lLeOLEQZJWlj81UDncdrH G1shVLHHOdrZ3KoAuDT9MvbQSvYgR7onhgiUApH94AEZ/wCepBZ+evUg1pNtNSiyUtLNG5qyabJb 281rHLFBCVkFq83mDl2Zm+ZWJK5VSTkquPlySTws0A1Oxmil1CDyRIfL2K0sl1lQAG3AfKCuQAf4 sE5UAFNuybWqfyB2fwjZRF59oZIGW3My26qgEZYY2lCScEAgt8vtjO2si6aK9sdQ08WO1VxGQysC ODlsgHYqhuQc578qMdFNa6PsYyab9TpNKtre80uDT7iFU1CVJBl1JSLBQY55c5xhcBs5wOBUmk+H FvEaMTnzRGDG0kO5lkUqoQZyQm1R2yeR6GpjKS5ubv8AgEr6XOusbWOy09klRpZC29pM4QbS4UgE DILAjGOmO5yK+t6hLZLbXrqwEkbYmd8u0mSVznOcqQSOcdOxrNWqz5Vt0GkoRu9/+CYt5rthebvK ikG7IYshZnKqdxPTrjGR1GeOa8y8beM/D/gHw1d674i1MWljHF+6R2BlnYg/JEMhmJBPA9OeOa9L B4acpxpJauxw4mvGEJVJvRL8D4/1KLxt8e9RttT8XJLpnw3jZWs9IjYrJeKDxJKePbk9iABjmtH/ AIZ5+Gf/AEBZv/An/wCvX6hgMohTwlOMk9umn9X3PzHG5hUxGJnUjsfpfa2jrCmm+c0VsigbkP32 ORtJOMDA+tRafdW9zC8E0gV2l5DDAVVHb8h+dfidnK7SP2ROz12NO2u2g1M3Nm2+1Ep+UHlBggEA dsflVh9X0zTo9ZjsrorfRo8sBZf+Pl2KgJkkd8ZHNZuEnpFepd7Qbv3HeGtFlSBrm8lKy3MbGUqC DyMk5xx0GM+3WqzyvI93aRF48KIxGed4ySc4OecbefenJqUnbZBytQT6nmGrau8FtPK9tuUTmbAJ +VB1zjJOAP1Arh7COO8mMhjxpfmq6gKerDJ9+5ruox5Yt3/4c5patXR3+naPGsIKqodgvlADIzkg kHv0A6k/yr1Twjotvp+l3Mc4P295dgaM5I+X5uvA/wA4rGrUfK13OilFc3lY6WXR4ry6bVxKixxR PsjAxgYGSAcnhQvXnj0rntPW8W8/tbzSZmP7su+7YG5AAGRgAjOOePXNcyaaafQ3d7o1tbntbc25 +zK8/k7k2I37xztY845Axknk8HmuT0lbrWJLXT7F/wDiSxzrAHlByxU7nZh2BAJAzzxinFS5XN9P 6QN3lyxR0cB1LQtQls0toJCodfNf59gkA28DgclgO/Tp1Ofqs2oyrMyypIICQViwHlaQAKOMgY2j sM4OBSVpSTuDvZoxNPsrlby3ubm2RpoZAFUx8sQV3MTxwcgDI/hwR0rWv4DrMTT24dbiKMiVyQxZ gSoTj1UBvm9c9+bbUpa9BKN4vzLnhzThZ2GqNqz/AGfzXaJ3ugd0KKg5XALZyGBIXBIAAOKqy28V xYSmynEIaIlJJFTdiRi58w8MDtY5xlvlAyBk1Epe++2hXKlp5GdFfXTzXC3t8XO3fJ5pCq0cZUIg UfOGPGQORu+teh6XPpNxZWrNK0Nhb2YureMMxeZNpjByo+UFwzAHHDMvzYLU6itrFaBTd5NGT471 Cw8Hab4k/siKG8v7p4VWfLARO0aGWLy+Rg4Ubs4IBJXnj58itptWu4Lazu1voJiZLgbpFEcqI8Sg jAUYRc8KVAx6Zrow7XK6rv8A5WX+ZjX+NQXT9f8AgHP6hqVzfaoZ7+wZbCKHyILcFQhO1CWUdycM Rweo3A4yd211LTbaS7t7RVKxJypZVjdVKvISp5KjIQY2nJHY1vKEtk76Xfr/AFc579di5pOtpdS3 lsNPuDNaRfapJUhISPChFbPHyFmjUMdoOcD0rY8N6fqy3lhKI4JkglfzxLIgVXff+8LDuDkY543E /KMGJ+4mpDi+Zqx+W37UnjR/HXxh8QixuUk0jS2/sSyMRDRsIiyswYH5wz+Y27PPymv0y/4JEfB6 SDTfiT8ctSsyJbp18O6UzDpHHsmuWU+58hcj+64rz/EbGf2Z4fYiknaVRU6f/gUk5f8Akqkep4b4 P+0eN44l6xpOc/uTivxlE/ZmaIvhcEJ9fTB9Dmo2gjXIZcqOcfn+P/66/kpS0sj+q1C2xDJEpjCp kr/eA/lVUaOkrhFwS53HA4+n0rSNRwVyKlO6ueV/GX9iv4NfHbwpfSePPDsSamsTvDqNuoSeJiPv ZGM88++Ocjr/ACo/tLfAX/hS3xB1rwvoWr/2po8DsY51wXjUk4V8AAkcDOBzngV+++CvGOPxlfEc P4x81GCvCT+zr8N+z6H4F4y8KYKODp8QYSHLXuozS+2u9u679j5ceYp8p6A4wR0xWjo+qSaZeW93 E2QrKzLnqBziv6Qkk4tdz+bItxqKSP3n/Y28c/Cjxx8OIdIN1NF4hsbue+mVEX99wWRCNwICt5G0 5CjYzfeIr7osvEFvp2iwzaXDAthDMTJGpDo7SKkYIYDerABlZ1LEs5dCCqsfyzMIVYYyrSq7qT+5 vQ/Ystq0Z4GlVp9Yo888YfFOy0HSBJe65d6cLK6cGOK4CTQuU2LEQDldsiksckKGHHzfP8Qah+05 a3OoxaZpuuxx6SlyC5muXMs+1meRpZm/eMxZnYyHL5UBWGMHbA4GdeMp8l4+S1bMcZjqdKUYuVr+ Z7t8OPi7pGvwadayarHcR3NvtiN5PjyHLq0jKWcbs5dy5J2l85yAw9xh8T2sa6dJHq1vDFDcQXAu 0uZGZmSNizTEPulkdm8wEHktnsorDEUXTqOnKPnb9DejVU4KafzMt3S+0++axgmw5R5rq4t1RpIi zB34b5UJKgjhjheo3br+rwW9paz6WIZntQJUuJ4m81ZApj2KZz9xVZJgBuKgyrtbhvMzjtyW2+4u 903b+u5J4hikuXutQbUprvSJr5MtOsbl3nZVi83JYkgs0mCTl0xwMka0t7PHJd6dp6S24hn8qecm J/OIwhOQTuO1/MDA7MqBggkhbpRWxNmm3HqUGkFlqEumSXEGblg1peROd67UxlkQAbPNYMTjLlm3 ADbUlxoWo6jJdnR9MuRe2svl27vIFeRpfv5fjBOVLZwNpU42qcuyi99P6uNq+nVHIX1hcPLL5pEc l3BNLciYylnRnIVztOUK9FDFyoVgoJGasXGpyWFlaNZwlN0f2nN4hLo/y8hByF2+YAAwHMfP386N XaXQwvyu8t0ck+larqFxd6/5wtb5oWiUxSDEEa5VeSW2r5aE5GPvAGrOl6extp4LiZ4dOhiWa6li ALZLIcqGBUjqOOoOD/sdMpJQ93dW+dtEYRTctXuXdN0O5N5d3dhaxt9lkWKUvOUinZJNsYcSZHAY TbwR84YYUFaSGSaWa81Fo54riRJIoWZQsdwSPPLnYpwwJVMRY54HGMc0nGTb/D+v67mrVla3W5gw waoG0u5hea40WQlmVyNzIHDgvjKxocJhNo2jqQSc6EpAktY5LryrKUG8WLfxMqzl0Lsu0+WxYJtX +EEk5BId02rbdvMm7jv/AEjPk8uL7TaCz3LqCrGstvCuHSMNujVx8oA3FieAVAAGNwNi+e0s7KSx azk2QmOePcVZZUfcp+VAwJbcjHzOoyBilaUpLv179hOy3RSmkmvrkXuq3TeTJFCbtZ7g+aJCQd8r MoHzK7fNk45Bznhmp6xIn22GyeJLyeF4IHjCeZMNqgb0C7imFkwuR94A5AYG+VWjFPQUnZXSt+f/ AA5mW9vcacJ5pBA0pVT9ljJZZMFwA5GdiZYZAxkAgYIzUGqqk95NcoYPMilEcSiMtvzsVWIQAFAM AEj5gzfKSatNc2j3/q5nZtK+5I2oRyTQX9xZpHqDs6oTN5yzZUvxgfNjcATyOOfvYOYlretLHcS3 ccciwKBIiJtVc9F6nHzZ4wSeevNWm7a63I12M3UIbu7l828055lWMNExKlZ1UZZi7EkZJJ4JB6Dt WlDbTzLaXNppc32YN8qO3luSAuH+RiNhZk29CckcNmtErKNpaEXve5f03TbZ2USApGiHyY4sMQmQ A208E/K3qDtz7nsrezt0MVreW8olfGyZJCCwb727I6gunU8dAOuJqz5dtwiub0RT1O4tNMKM8aSK CwEBY7X2nKOwQLu54VMnv3PPJzx/NuCMYJFyIHJb5gFw2ACMcDv79a1w8ZbvqZVp8vyPnv4k/HbR /h95Xh3RrNNU8czMywabakMImPCrNtyR67Ac+pAxXkug/DfXfFutWvjr4t6h9u8RZLWum7QbTTgM EDYOGb8McZ5PT9E4byhyl9ZqK/XXz2Xq/wAj4XP8zcm8JRenV/10X5ntTWnlqUA/e5wOhyPbrgdO 2aZ9muf+eJ/z/wABr9JhQpte/v8A15Hx/wC76n1PdssNrq091O0UEhUWqx5wc8k8Z9D+ApkR07Wp ZGksGXSXG6CblWbbjOSOhOAPw9q/mOzSvF7fi9P+Cfuqs9/mWdGIs728+ywtLCGKMcfdXBIHA5xx zXCoF1vxilvFITbRw/aFCsBh2Y7V6HO0Yzj3+guCam5dlcpttRR7M5e01gWl/d/8SxCTBgZZuAT6 H/P4Vxmtzqftk8N8Yr3KKjEfefnPHpk4GcfTrWEErppaf8E0m2ly3PK/EAuojZwBI28x9mc8HJzy G+9wDWnpVhqUrW9tCAYWlwQFG1QpG9uvToOPX2rtXLyX6HPvN2/pHrmkWUMn9nZtd7QsuQzBskEc 8kYGcn/GvQ2D2lxeyKsSW/mRxxNnBKkbnYZ7479PSuCo7u19jupRUVoZUEljFetbRzLO0jTM5cbd yNgbecDBIYYOOmfYULi8jbULPUW2xv8AclQtlckBdo7k7Q3TsPakubTQHZLcqX95f2TXFrc2qSQy hwpJOVRyMb8AYXlRjAyM0ul6hpmlaDceGY7R5p5WV5bzzXdoz0kALYHzEhSNpz06Zy7JxSg9/wBP 8xKXvXK97qM/lyLqFkTakqtxHGM4dQVHAbJwwVc4PY4GeKlxcXD6m9skmLU3CtDaBB821WCBgMcB SAPUZbNCS9V/W/y1C94liC7sA91aBJUXztzM4LPxyiE55468kenSp9csfseoQ2djeXC2zNHNhTt8 4eXuLDjGPkA+gAwTRZ8yvrf/AIBTXutp6hq7RTT2cQiAaYDzxLJ8kAWOMuQBkgks438HG09Cafpy WVtqFmjI62ZV9pYgl2CBVbplflJfAzw0Z4Ocv3lHQaSvcu3Mdjptte3aXKvqTyGe1LRxzOuW3Sl4 8MGY87txXGMnavJ7XULXS/CdpDqOp31pc6kyW6eaTtWeLcHKKARgsIZAT8hKt2yTSvJ7bt2/pFKK ipdUj5k8RaxfeJNTmmvNRnmuLm4z9nfy41RiQi+SAqqqBFiGSSMBsdMDz/UrW40e7t54bVLe2DRY lWTckkZZuGRQSu5ZHLbiM8ZPAB9GkoRj7Llt+p59R3bmia6kmWOX7HZy7rtZWgaaPCCFXCsEDAnl lCAgjgMDwTmbS1shK99BZx3EssJUqy7Y49oYb3IPJBDNtxyASPWrd1GTRm9WjXS8DJKNRuJYo7qA SbwMOwMhPlnPXkEoB1CZ5yCed8c+Lbbwf8PPHWsKDbajbIkUEbr8ss7FYkVFyOm4sx54VifWojTd SSgurX5pfgJuybW9n95+QdzItykQsd8l5PMsKoDlmeQ7QB3JP8zX9d3wO+Hen/s9fs7eA/B15b7L vR9MiF+iIC819O3mTKP7zNNKyD/gI6DNfB+NmIqTwGUZRS+KtWbS/wAKUV+NQ/RvCOjRo4nNcyX8 OnTjr/ivKX/pB4cf2q/EGnfEObwpr/w/EGkR5keSC486a3izgPIAAoXrkgnp3HNfay7bq3S4iO6F 1Dg44wRkcfSvxfinhirw1PC81TnjVje/ZrdfjofsnDXEWG4io1alGDi6crNPez2fzE8goU3DgZ7A f5zW/oWjtc3gZUbeTt5PbIzXyNWpyU5SPpPZ3PCP26f2itD/AGd/g5dWdvdxt471YtbabaBxvK4I aRl6hV4OemRjvX8sut6vd6/ql7quq3jTahdSNNNI5yXLZJPP1r998GcplhcjrZvUj71eb5f8ENL/ ADlf7j8G8VsxjWx9DKU9Ka5pLzlsvkvzPOfEHw70jXXaS0AguhkblGA5Ht+XrXims+Ddc8NTH7ZZ M1uDxKoJQ1/QmXZkqiWGrv3+nmfz9muTyot4vDxvTb1XY3fB+q6/oE0XifwrqpttXs5FcKoyWAIw cHhhnHBB7V9gW/7d3jB7WW28Q6WPtzW0NtI9ucArGDhlDE7SWbeRyMquc4GKzDKaWPnGrtNaeqFg M4qZZTcGuaEtvI+a/F3xt8WeKbq+mjvnhtpZWlZQ2CWY5Offgc9eD35rmNGk1GeRZjPvYc4Y5Udh xz36Z9q7aWFo4alyxR5tbG18dX55v0R9GeH/ABld6JJZvO8n2mPdEQXOF3AcqoxgcZxxyoPpj9Df hJ8QZdW/szUzorSxpGLdHMgMiS7Rj5EUjJycjkc5JLMK+ZzbCrk9pF26H2OT4pzvSkr2/A+yY/E2 s6nZR6NBpMdvb+esF3MSImlljOUUNJnC7mdC4BIVi2HJAqbVNaWdHvLtSbWC+traeCxdTLdJtZyJ B83lFgiqsjFdoAzliBXy0Y20Tv8A1/wx9Q5Oz0sbuh22mamoiivmOjWvni4gkjU/u04AWMrueaRy mG+4PMXav7o1gQapd6Hp8F/BeNbsIJQY3jiLNsDL1kDeXg8ZI2jkkEjks23FLX/Mlvlin0M7SIrT Vlm1Lw/fX0NvBC1tp5B2vsU7JJI1mChUYu33xuYfNgbhXUSW3iSOLU9G03WpF2CR7qNXDyDzAuC7 M4Vd29FUnnMmCTuJVvk2nHVbmdpbwe/9fkczfaSY3h1JjJBHNiWWWdci4RLiePacHarFggAILsGL bduC+Xa3ccE001ztileO1DywStH9qlBMUsp3/MCdq5IBBAbbg/KdYtcrsrtGElytJmnBBYWSyRy3 DR37yuFd5DEJIyp2sIyARuyp2tkBR8w+YEpD5FmZrhpbMwxQj5pbaIIJtrElYpPnkbIK5GA7quG+ 5klKT91f1/SBK+vb+vkRanHJBp0xitQpZRHbs8hVpMl9qAAFt5L/ALxmGAidcHJSGPSrm/0947qR 5NNjie1UpJmCPa0uwsuVwFZFMbdQhGzhqzb2cX6/l/maNNvVmNc+Xe6naveyn7NDZNvumeRoZVUK xVVQZkDsuG4PJYhlBVlw5DLeSzSS7hAyRxsscar5eGVVQnILgp++GVAAyOMA1cI2v/w33mUm5PQ0 JiLyV7iFoI7i5VExGdnkwuERFUgEJtB+YEZUgktx81SIy295f3sYG53iCF2IUlFDl+dx3lJExz/C CQScBxsk00J26GJpcmmNpK3D3yR6s7FFupVLZUCVirPxgFQThRvXAw1Z1tFb215aXUUUMYkzseOV 0kDszqGUDlsAs3fnHzZIzreeunkZ3Vk0W7zS4LS3tbdJIIbvfE7AASSjMZZfmf7wVSC2cdug4rlt NtrzSRJc3F8U1d4j5gJKgQ7cruY9CyFVAXgFS2SWWri7x13/AEIkmnd/0x8uoWDPbXY0/wD0lCsM PnuGYjdhtqduM4BxnA54rQ1SzuDc28l9dsLSONJJykmGwCoZty/IzkBQTzglcng1VuWzevYhvqYc l5czwRB3dojKhjhZUw6HaeHXI2sNo6Y5au5s7KSC4VYbWSO4QNKwMxOwsyuxIyFGSCqjHYnjccU0 o6N6ak3d7dTsLW30jSfsdyyia4kXCyRjYU3sCSG7nbxxt4xnoAeV1TV724t5rfR4UWGRpIpmAJZ1 3FsuQPmJyoJ6bR0GABhTg61Tmnov6sjSbVJKMd/1MXVrgRre3mp3sNtbxo7yyM/EahOx4AQYPQiv iDx18bvFvxK1u4+GXwIs5JEK+Xc6qGZQIxkFw2MxR8jLn5jj5Rzz9VkeWSxtaCUbxVvm+3+fkfMZ 1mKwdBrm957eXd/5HbfDf4G6Z4Ega+lb7b4unGbzUZ1+7nqsQP3Fz1P3j3r1WfT/ALP5u3PlId3m cAce/wCX6fh+34TLFhaMaUVd9X3f9bH5hPE+2qOT6nLXTC5Dx2QYBtwaTBz/AC4ByBxz6+lZX9kX n/PU/k1dapz+wtB+2VNuKf42PsVGiVUIgJO1nG5PkUBQoPTufTsTVzRLS7fzLLUrYZUgKmNixscE ds9Pw5Ffym3aLbevQ/eIa2sUr5jpNtdXSxyCWZAkUYPytKSwz7AAfTrVHwf4ZhSCG7SbY6Aq43YZ sHB3E9SffjAFPmUacpGjheSRsXcnmiW9lmWKGNDGNsmGVsDdtJA9GX0HQetcBqBiu5pkkOHB8zhl wo4JOVGM4Hc/lmrpXWtr2InucPc+XM8aoDIFZliHB8slvvED/ZOM4z1r0XRdOvo1tYIyxgAdXLMV O4tySB1HbuOnFdE3or7mdNSckz2axtYtNguN0e+T5i+T8xRSdo9sDgfWrV/PDHGmoQ2qeXOSqRM3 /HsWAUBuTnIbPbpjHQV5zu2d6tFWXQyLuG5iwltbIro58yTIYADA2pg44O7nvnrgYq0t3phlgjkg CgKBs8sHcDkcY7984OcGm27Kwla99kUb+0S71CXUdI0oeX8zSI2WCgAbmyRluWByBj5fUEitp0D6 nYxefeKNPaSKGS3XCvOFk3uEXAKYAIz8oyRnpmi9knLW1hqKUnbZmVfuz311ZJBHs8yWSFt5YghY 9qqA3zHduPTnGemDV69sHkvbfVbrc2r+ZFLIHV2UOqlWJBznhhIeccA8AVUZONmibXb0NKe2s1LS agryu8krSMNhIaRwh/A5xnqFBxnjFXULi0gudHt9R1SKOBM28iSBg7xokhTplgSyg7h8oV+T0qE2 9o+hb8mW9AsptYmWW/EUdm9zCJHYru8tpPl3kn5A5UYJ2gfJz0rEms9Rn/4Se7kmkuorUypujEgE sabPMdCoOETy8sxwAMH3qrpN26fntYdnypvZmxL8Xfhzo+jy6rcapFdW77rexeSII8hZ1d3dQR5e eUO07hsBDAhc+Kax8VNB8ZzRaPZ6+j2shCtPats8iIx5mIQElBghMhRtGCBwcb0aFZy55R0RjXxF OypKWrOSksLq3utNktAEtzHcXMQaYLsVNiYBYAyZKHaTntjcWBqjqMDBprOG9wcurTScqzxu+90G T8igFMNnKsTxmu1O9m9/+H/yOOfYvReILezsoorIs7iHIeaUF0TIMcaDGck72OMZzlu2a+lWNpqg 1GxeXy9OkmDuwG0liRHI6BBnGwKvA/hGB0otKLk2iZPm91E0Vv8A2Pd6hcSsiWcUixpIQXeORgI4 9uCRIVUAd8FeehA+WP2zfF9hajwx4F0q6YtBa/arxcYHmS/6sYzliqB8H0kDc5JrqwEXLHUY203+ 5f5tHPipunhakuq/4f8AQ5f/AIJ9fCNPi7+1R8N9PurJpNE0Av4n1MFdylbYhoFb2adrdSCR941/ Z58ErT4PanqdvYfF5Zf7KTVba6doxkmFZEEuBn5iI2kIBPJwa/F/FjNaUePsko1X+7w/s5S8ueo2 /wDyVRZ+yeG2W148DZjWw8U6lZz5b7NRhGL/AB5vmeQ/8FKPFXwu1r4g+JPhL+yv4A0G1+HUmqxn S9XsIZW1HVJrvTU+0mZpt0sdnHLuRS2xQ0kuEIALcXo+j/2bpGlaYZi5ht4oGc5+dlQAn15wa+Y8 T8xw9fE0KGHnzLmqTXlCTSgvuifVeGuDxVHBVa+Mjao404y21mk3PbTRu2mnY07ezSWVct8mRyOm f89vaj4pfEnwR+z58Nb74m+OtQSLTINwVdw3zEDIVASNzscAD3r8qpYbEZljcNlmFjepWkoR9Wz9 HxGKpYHC1sXiJWhBOTfZJXf5H82ujtfftP8AjTxt+0B8WnlvG1q/mGh2M88hh0+yViEWNCcBRwqj +6meS1dnd/Cb4Wx29hFB4TU3SeZ9okaXAlJwEAHYKBn3Le1f1JXxtfKqscowEuSjhoxpRSSt7kVF v5yTbPh8g4SyvOMlo5vm1BTxGK5qsnLV2qNygvSMHGKXkeD+OPhPBpU0upaBbFbIfMUyTt5z/X2r oPgH8P8ASfG3iyPSNWihlUFQbacDMmeeAev/ANb6GvVxWaVHktXGwb54R1t0fc+TzXg2jl2dUYUI fuJvZ6r09D7j+M3/AASq8Ba74Hm8TfDLUG0TxiYt5tj81tdtwduDjb0AByOSSSeBX4CfFj4UeK/h d4q1Hwp4207yNYgbDMjb0kGTgqfQ4yM4OMetdXhh4gPiilVy3MNMTSvaX88Fpf1Wz7n5X4o8CQ4f 5M2yz/dqj96P8kn2/uv8PQ8ilgltZNyjOCPx5ycivp34f6t4KvtKuZLt4ofETBIo4DGUXYEb5gwP JBC8cliw54NfqmM9p7JSp/P0PyjLXSVdxrbPb1PcvBHwX1vxTdrePpV0bdWMhiaINhmIUAkYBAPz c43YPPWv0O+FXwrh8L2Oi6nFqebwkytGjgJbOM8SAfdLIq5Gdo8sjnb83yGbY6Eo+xTTWx97lOBd JOrLd6nQ+Jvil4V02XTILTVmlGlNN5Q814t8jBpFj253Bg2wkgr/AKpCcsS1cfYfFf8A4SeWzzrK WlrJdPMLWONNk3zJiR3UBiWC4BALBYSSOleVTwsnD2klt/V/xPUliFzKmme9eEfFMGp6Lf3sy3E9 1GEaSYhI2nMav+7gjHRdxESFmbghtwyK6Z9bj1O61L7JokdxrZDzTOylZLaLe0QRBjG04kcHgEhd 27OF5JQcajUdEjojOPL6/mZawTPb22mJIL60eb/UyyqvlD74do13bgxzvVmUHygCRuAFDUEsrPxH bPNqM99aPKqXQW4eOO4Zi6eW0rbthbDrvKqhLgKuAAairvlf49DGe179hYLPWLxrFL+488tEyzmS 43oPMjKhIiwGPlcHBGMjj7xrf1C6ttF1i2m0qFPLV3jtg0CtFFcEOASjrtYLg7VyMfLt+YAjbS6j HaxFpRTbMm80PUb2ynkiSafVZraSE3RILRHCNjds+8SeBg/dVyAOs9hbWj2+tC+tpZbKCOJIZWhz 5SHAK+YxUnacIHVsgnsW5xbS1T2/zWncfLZrTcpzGS18NxWlvcTJfw3CPaK7L5iyeZy02CQPlZHV SQDhRxylWFsYJLSdoCqamsEdv5QhADjeHaMKRs5Z5NoJdhnBOzOU9r23GlzadkZslvJqeqRvf30N lIWSR7eBSEtI4xJgk5GG/ekkcZZEPG3Ay5Htory9t2SCI8ujzxqCF3xY4LBgNxVtvzYBY7CScGuq Xb7yGtbtluO9gtNQv4LeJJoGhDJHHFJHHDE0j7BJwSp3RMoLEnbGBkkgijsdbi6mlLTTXW82qzTv HuZdqiRlY5EbKrxjhWyp5OzDV8Or/wA/62Ik72RX/sa8s1uNP02JYjLeyXJIlZpF3QkBCD8p24wh CjDyctyMctb3BSVNTttsCY+ztumEgkYfJjdjbuZskKCwViFBJHFqSmm/T+kKXNFasNR8S6c82lWr zxJqcYLRR7zEcbxzIFHKlVwM5J9TuIEEl+b9ry4mbCqXLBFKeSpLMBGBxwwHGeMZzzy1CSs3/X9M htPqV9OtNTa8S8ub2Mv5XnHZ82xwijKFcnzA3y5x365war2emTXNvO8kkv2PzC8okf8AeyRsEccj 7xPynbknPooBrZNateRlLrY6jT/DcCN9tupwlpIzWsKyxN5kSIynIOCAAMgnOCSBz37BzHaldJ09 2ktodkpuWnD7wvHPHL7y/wAoJAwMYJ4zqtzkqaVkv00NKceROb3/AEOIe5u3eOGbUXaVZHVnEQBl yQwUAc84AyM9SOMccR4x8daH4D0uTW/FeofY7UMdqqAGkYFhsjUnLsQMjOOAc16ODw/tZxp046v9 TgxdeNKEqk5bdT4kN38Vf2sdcu7LQY5NI+FkUwS7vG3eW5XB2nB/fS9CIx8q/KT0BP2n4F+GHhj4 eeH4fDnhXThFaYElxcOA1xfSAYMkj9SfQcKAcAAV+5cI5NDD0FiJdNI+vWX6Lyufjuf5tPE4lwtp +XZf5+Z2uqWthYafGZXzu+ZFX7zE5xtGeeD1ryy5sLzU5YhPE0Fn1VOmR6k8cck+vtX388Mm4xfa 7PCo1vZwdaXV+6u/mOfTbeBUtooS7HptOMj7x55pP7O/6h7/APfyvKxeIwuGqclStGD7M6MNDEVY OcIN69EfRQu4khs7RQWl8k+YMbRgbjkHHOBjnJ6mrmsPD5dtd2krPOx+cHjcQNu447DgelfyQ/dk r7O5/RSs1ocX5/8AatzHbpKRbWTurGY/6x3Pt6cLj3rpIP7LtII5I1aN/v7E5EzH5RkDkADJ6HoK uSajyd/1BNPVnG3d8LRdQtkkyAgRFbHQdMZ5zz6n8MV51qWqXNwYofOCXBfdMrLxnI4+h7cc47V0 UopttrYwk2tibR9N1NtXt5Zc7PJ2qELdWAJyMdSeg9z7GvpTwVYvFafaL7i6jtyuXCgggjB6jJwc jkfdH1pYmaSXL/W5rQT9pbobUjzR2N2loszPjbuZMNscYIIx1OTz1wTzVc6VEiTkTu8JAkZm5REw CATkZORnB9B1rgb1bOy17XGXV2+kRGeS3JgUFQeoDFcg8ceme/JFZ+oad57QaleM5u2VUeQj7zkj gB++AORgAHnrVRVrSXoKST9027ZdM0lP3CSpEJ0t5FGAWAO5ixHbqNo9Sc9ay5tOkvLW8htrcSXL S+ZJKT1VzuGw85JxgdwGIHejmvdsp7qK2Jr2zgNjI2nGCOYxvF12+WuPxUdVwB6EHqcSXOnW2lRG KTUy4gEKR7FUKVC4YgEk/M/lgKeSSAees8z+8fLG90zlbifULSy0yeJnKlSDIGLRN5hj2pnHJQjg DHP0GKd/a+de6dgxT2Mt68dxMWWNURQp4XHADEDk8D161tG3Mrbf1bTzM2nLTsdJqDR6fGt/b3sV vZxxzyvsjZpMJG77cg4VSu4kkZ27jngivw3+PX7SnizWvGPiDTvBmvXFh4b2talLKeZEmR8NKnJ3 NGT8u1sAqoyOTXt5BhKeKxM5VVeMVfXvfT8jwuI8dUweFgqErSk7fKx8y3HjDxTqNulte63dPblw dhmbaOfr6j+VdV4H+I2veDdYtL23vJPs6tiRN2dy9GAz7Z/OvtZYWi6TpRikmfB08bXhXhXnNtr8 j9X/AAl4yXxt4Zh8RWd4zafJcfaJmZ9zQoHZ0AHUtvBUcnopZgEUV3EuqWGpFIIcfZFjDxR7kDpG +MbyMBmAYv8A8DzgcmvhKlFwqyhazi395+jUqqqU41IPSSTM24sZrqS3kZFae9ljt7SaNUXZEoLg Z25JyQdwGCQMBs89D9kgupJ47CeSNYlaGKSN1VEzvdUAGTIXyqZPdg2D0Kk9E/67fmHeR6DZafpl +LbxHqvnQTWyCW5kntyUK53q5wDjBdmAB2gBQSAOfxP+KHjI+OPG2ta03ywXEzOisf8AVwjCxJkn +GJEX8DXo5JCUsRUm1pBJff/AMMjgzKS9nTpL7b/AFS/Js/eb/gjX8G20v4Q/E/47ajbBdR8Qakm l6czAg/YrU/OynurzOQR6249K/XV0dCrJgse/r+P4V/I/iTj/r/HWbzvdQmqa/7hwjF/imf1j4f4 RYXhLLKfLbmhzv8A7iNz/wDbvuIVt4hMZPsyecBndjBHUcfl/StO2gUuiuDjOcjOcV8RWq1KnvVJ OT83f8z7SNKnSTVOKS7JWNSbTvsyG5iG4kZ4z+Oc9a/mz/4KA/F/xD+0V4x1vwfFe3MPw58M6jNp 9r5YcJcXKHZcyP8Aw/fUxJnkBHI+9X6T4SYSnX4jea1Un9VjeKf88vdX4czXmkfnniJXnLJJZZTk 19YvFtdIpXl9+ifqV/hP4v0PVfDFloegxNCLCNLZoOQUCDAAJPOMD8/avSJY2bbxjOAcrjdz9fb8 K/UMbQqUcdWjWd5Ntt9763/E+24br0cZlOFq4dWhyJR8kla3ytYmFhFdW0sU5Ur0bjr6fpXj+t+F ZND1JdZ0iaS3nVi0U8LsskBzwQV9+3f09OjLa8YTlQq6wno09v6ZvnuXxxWE5or3o6r5HtWi/wDB Qn4l+DvC934K+KmmrqVwkDjS9XgARpGC4QXCjC9cksuAeMIuCT+eXjbUX+Jer32t+JZhdXV2xklZ hnZ6BfQD+lejw3wphuGMficwwD9yq04f3FvKP3/gfgHG2Y1s0o0sqxcPhvz6aSe0Wvlr6nz74o+E 14qT3ug7pY1PMbct0/hPc14jLaXenXTQXUMkFyjcBgQQc/n1HUV+v5fmFPG09X763R/PeaZTUyzE 2abpy2f6ep9f/B39qvWfAKpp3jXTm1fw1t2mN3YFtzqz+Yy8vuA2ZJLKpbbtYhh6D8Q/21vEXjC9 uIPC8DW1o7Efu8KXyACQq8BcruCEtt3Ec5Yt5tTIoVMZKtf929beZ6kOIJUcHHDyi3VWl+66P+vU 840+98W6/p899rdy3lpmVjMzFVkPQ59NuAB6/nXIn4kar4XvvLtNRlDmIRBuNwXBABHIztO32HHt XbHD0qjlSitEcdTF16MYYmo/eZ9dfBz486tqOn29hJLIfskb73XcC4c+W46ZZgGLByQBtAGTjP6Y 6J4kl8S6M1nLqptofPCgSXGxwixOYxLO3zzM4LExLx84AJLMG+SzbCRw1W2+p9dleMeJoKfVo7TT fEGrq+oXdlKvnIpSOZ4E8uVVRAgYgfw5KxDgAks5IJzhxR6trt4tomnG30ssHQyY3SPtAyVAwqsV Yq275hyVG4CvNpxteTZ6U5NpQSNeyutPN9NpsXMqriMpbSNHKUieRgc4yNis3YrgYAyKsNaQNJo0 gNusNrKs1yUgby54WaQlo3cndLwoU7cKE3YycMOyf+QkuZbjLKaYXtxdX2oBnkH+kR7GeaEoFDDD 5OdsQQx8NI5dcYYhm6k1mkV9KJS2nJMxS2MTykEK55CYWMhwMAnOSDxg1nHV2Ssuhe0btlSwl1C3 sZb23fzbwubkKsBdCAi7Dk8cMzYJByRJ2IDZxgQ3U1vfX3mWvmElgkqG3ZFUNIcj7rZdFPfyzgAN Ra13HfoRJtJNlA6fbfZLif7P/pEoZPLjfLRgh5BhiduDxjqSR1+UNWbFLLdQ3eoNpDy6TNKfLErp GPNf5gvmMdwRVJyoGMBRwfvWpaOTfWxnJbWRBdLb2+kT2LXUyRT2mI7hF3KDHg72ZmORktjjseSD WBBZtJqCarqd3OpjSNFcIYgCCzv5g4zJ9wjGMFuCu1qqDSTdtX+pm76JPYzZxdGaY3kxZ2QiNrco ZGcksUTOXbMW1hkAgBs8nJr6UZ59Dj0aASCzjYfZkkmAcMrsSxYtlF3bQSSo2nkDknRWtptdEPmT bY6FbE6ebW81F/7QkiRYiRlXyxcqSMlNyoxPBJ+XA5IEr2ltLLp0V7+4/fJGXVGcRQMxB+4CgIJ+ 7ljgfd6mndxTt02FokrkGm7NQv7i8jgVVGIo4mZyHYBskk5Lc5IHTJbgjivVdH8JS2kxbVY3wGGV kGyNCGZixABAG4Dgnqwxx0VWTpx13f6bipU/azv0W/6G3qOp2WmWlxaSCOaNWl/dgg8/Jw2QAq8E 4X/ax1ryXUNTmefU7eIkosm6OQK+MYQtxnA3YUZIOexFLC0m229h4qrGyS6HkPxK+KHhP4a+H01L WiTqDArDaiQiW+PJPB+6oONzYA+pIB+VfB/wn8fftK63Z/EP4pvLYfDcsfsUEe5GvYgxPlwA/cjz w0xyWPTPJH6TwrlE8TVUn169o9X+iPz3ifM1SpujB67v16f5/cfotp2j6BpGnWmleHNAttN0W1Qw 2mn24KxwIAfXknOcsTkkk96zNX1C30hvIMXnXLfNHAgHGRxnngHj61+4YalCjThTgtIpI/L2nXqu bdru712Ry8VpPO8mo6rcHz9mEQDgHPZc5GfSoblnxIJSghxgfJgqPT/PPSuvE4ung8LUxFeVlFa/ 5foiIU54vExpUersv6/FsxRZ3WpMyRx7IyDuOTjpjJ79uOe1J/wiU3/Pyn/fbf8AxVfg+a4+vmOM niZvfZdl0R+l4PCwweHjQpW03831Z6zd2dzNIhspTHOkUflswHA5OOOT0A6j0zWrd/adUvoXgRfs htJZZG3kD9yocgHPzZ2sfTP1xX5c7OKfU/S4rVrocf4atpFgQXzFpQyyXDK33s88Yxn+vPNbHiXU 5GmngsY40eO3hghUY+RkHyscg5JzuPrjHQcaySlUt0RN7QseaavdGRzKYnSYoIg2OT8u4sR171QZ ZGng1BIFKyBY8kHCAMx5Jb7xPPXsK6IpqKa66GT1baPZfC2nhjbzi28yMSoECFmOEbO5j6AY7e/X FerJBa3VtbS2Mo+2iV44kZgPK27TnqeDj2z+PHDVfvO/Q7qMfd13Z4r4x8beK28T2Hw98IRpNqQn ke7uXziRiu1t0jAbVAIYkHHA655/Rm3/AGGdCH7MC/FO8/bq8Mad8R7eFDZeFo10OdL6RWzsW8l1 aKRMbsvi3Lg8CNiAaubwuGw0alWDnKeqS7a2+8I/WK0pOltFpdeujeidkt3080fkr45+KHxY+Hvj xB44sdPvtAdki+1WizyQIgGzzF807wzIuQXALY4OMV9JaWbfXrRNZR9+k/6xZU3Eq2Fck44AyOev Qfg61KnCFKtRleLXXoxU51KlScKytJP8CX+1L27to7crItvblVMkqbQ43EEjdhivzDP94HjqK2Va Ka3m0jzJ1cRgq8a+WYQF2L83X+HaMHtnHaudqy/M2TB7G3TR7eBLbZqHmHZHgNsUKULn5jgj5QF/ 2myRtIbEjsmsdOfVbjUQ10rN577VdmjiZQVTchVTwcZP3pAcYHCTV79ypR1000LZ8nw7Zzfb7Riw gayjEpFxGdwEYdY+FzjKnIIONzBuTVybRNLmt7TTxcok9vOJLmQoMRcJJHJIyfKwBLDy8A5fOFBJ LbnfmSHGKbs3qfLP7XXj7T/BPw21K5S6ikutRBaKBiRJDjdkdgSoEa4AAAfPGAD+A9wZbqV3bcZZ XMhbnuTn368fnX2nDFLlwtSq1u7fd/wT4LiyspYqlQX2Vd/MktreRj5KsoJA2qTz/n/CnSpcW8my aIqeuBjpkd/pX0yZ8o4tK7Wh9Ffs7fE5/DHiSLw5fzqukXsiRmRhuMRyDtA77sbSO+a/UMXDSGS3 ULFZi3W3eSQhWZXURkM6AuwKSLGw6sq7VXkZ+TzqjGnilNfaV/nt/XqfbZBiHVwbhJ6wdvkNtLHb qcXBN/cwOtm0si7QFKkOVH3V2wyZGRy4bI6HrtDsJxJp+npFBIk7BZLkxlw68hmCEDjofurnocCv Gk/ds30/I9uO/c87/aO8Yy+EfgbqkdzfNFreosNJitVbn7NJ5kjOdowV8uHoSDunAH3SB+PcFrf6 pdW2nWFuZNTvJktYI1UlpHkYKAB65IFe9kqjDB1q8tm27+SR4uYKVXH0aUNXayXm9vxsf26fAr4Q 2/wQ+CXwy+E1qij+xNJgtbjy8BJLwjfdSDBP3p3mbr/FmvSvshyxCfNxwBzj/OK/grNMe8wzXG49 v+LVnP8A8Ck3+p/cOVYWODwWHwa2pQjBf9uxS/QiS3J3FFBRR1Axz/Xr/nNL9nYohBOTwox/X8K4 uY9aUU4ux5F8fPjPF8Dfg/408cXEka64LM2Gi28g3Ca9mysZ2FgWWNfMmYA52QyEdK/Kv45eF/gr rfwm8BfC34KeNdN1r4o6novh25h06w8+8nvbu8he91e4uL0YtbUWjQ7JzcyLIgnUbQsNw8X694Z5 Zi1Uo4+nF+xnWfO+lqNJuN32cqkl5uPdH5ZxtjKcaFXCr+IoLl/7fqJStftFHyR8GfBGr+G7HUL3 XLJ4rqZi2yVCCgJLlcY7BkH1Fe3um3duGccZPUAjjn3/AMfpX6ZmtWNfMKs4PS6X3I/R+F8sqZZk eDwdZWnGCv62u/xGre2tvOPOul3n5cNjI9B1GMgf5727i2a8WWKSMGMg7gcDI6d/wrgcJQam1Y9+ dHnTXQ4vVPgLfeO7DUDaWvmW0abyyJxGT0H+fevj7xL8J/GXgG/kivdPmfSQT8yr8yjnHv8Al0xX 22U5lTxFOWEqv3raetj8w434EnWoxzTDapP3klql3XewWSW5ggKShrZ9reYOgBAyf6/h9K+7PhJ+ zD8N/i94WSLxXo0dysw2pcwkLNE2Rgqw5B6/mcYrxOJc4xuRYVY7CS5ZqW/T0fkz8/hwZh5Yr6tj Iqrh5x0fk+vk0fDn7S/7AXi/4K2es+LvCesDV/AELfvFl2pdWwOfvL0bGMkjH31Ayc4/PK0ju9Lm F7YphhuLxSfd46gg1+l8JcS4binKY46kuWa92ce0rJu3k90fgHGnDWI4Xzn6pKXNSfvU5d43dk/N bee59BXXx20/VPCtvoKaKLS/XLzNnKSOQAAg/gUbQQPvEsSTxWf8OfhlrnxHv2ngspGt9wKtGpfJ JwvAzxkZ3dPlPXGK9hR+oUZ1Kkr6/wDDHkObzXE0qFONtNV6bn6nfCj9nSzsdMhu7fK3EMhQ3Ji3 RxoJGALJ1aQsIyB2EeQMkGvomDxX4J+HOnLOL9IpbQLYo8gVm+WdHKFF+TnaofIbtkcZPxOLr1cd W5IpvX1PvcPRpYKineySPBPEf7T+lafq99FYask1rGVYGBXVboKu3owyFbhyMAjJBPJz1fgT4p3X iu+U6dFMbVIUnmLXHzOqgdAMLgfIMDPTk5znqqZdKhh/aVF0/E5I5jTrYl0qcru/Q+j7Cw1a3giW /uYmjgF1d3CpgNcTK0hYITuUA7cdSQCATlSK666t31O3uTfGU3EMLXLBCmQfm4YMD8xCypxn5nyT 8uB402udSS+89eCdnH8SrJLLa3l01zf+fqfkJJFNLIVcsBvf5c5J3tgYyCRxyeKqaRHbWkvmXsTy SyxGQRQM5ZcZaPYBkcOCX+6ApGcJky5NSSSBpPW+hen08LfQaTjal3HHJHASFdgZc5ZcHKkYILYB 3ZB2lS3N+Jb9H1WyuGhS6MSRRrLGuZFcIfL3fLgZBfJIICjHAIIIe+015/1+ATajH0Ny+fSNQtLW SWK+k1mSSGeYGdER33dUC87lQkDeSAGJxy1cXfWlqdMiT7VJHrEnmw+XgFUSSRVM2QOgAwMbcfNy AQQRumtF/wAAiSgk2uxz1/a3Fhbxpb6iqSwQJbicyuixossTN0wZFUDAGG3hiMAE1HazXsgilgWR 7PzGdJrbERkKykqzDd3bJDHPcd8VaXMr7GUnL4dyvE9lqF9vnt44dLLPIpaQKlvGifMNw2ktjcgJ 5c5AUkZqrdnSLq71y+0+GPy7aOS4jjhU7RGGKhZGw28/czzng4zTXNe99NPzJbve+5lxLavb6nAI MySshgw5cPCQAXDsVUbdqL90jD4HY1c8N2F1rN0sWnyym8QuhkFwFijXcdyEkbUG5mzgkjaOQDz0 LlUZSlsvLujK/vKKWrPafD2h2+lwW26KF77PmI56QEHdlSeHOeckg88gYxSarrt5fwXV3f7VkZy5 C4HptAIyMHaCOexrhu6lTnlfy9DssqVPlXzPMdSvLKK6uhLfytI43ysFUqcfKFUMRtXhc467iT15 +cPi98dtA+HFo9vDH9t8VTRj7HZhiBHyMSS4+cqecKSC3GOBX0WWYKeIrRp206+n/DHzuZYyOGoz q31X4vp+P4HnPwx/Z01/xhqsPxQ+PkjXGoTnzbLQrgtkLj5HuVH3EGRthB6j5xjKn7mW0mBhK8Rq oVF2gLGB2AwAg9ABjGOMV+85DgY4TDRfLZyS+S6I/HM1xFTEV5ym7/1d3MDU9efzm0rSTHNejCvN t+S3z1yf4jnp2FZcGmixe5muAZrx2DtI5ywJ/Ijkcd6+wpw5U1J6L8/+AeLWl7KnyU95b+nQ9n+H 37P/AI4+JNne6np9sLfTEiO2e4LBbiUD5Yo+M9gN3QV5FqfgnV9H1e40vWrNotQhJjeJhgRkf/q6 98V+c8WZ2sY54DCzvGm/f830Xotb+Z9dw/l0qFKOOrwtKa9306v5/kasGgmIIm35f4l2n349/wD6 /FWv7Dg/59P0evguVPc+kd+5du5FvIJFiVogYN3yptI2Yy2RjnP1PQ89aitCt3O2lS2u+waFZEuA xGQ+QykAnpjPUde2a/O1ZR321P0ZO79TkJo4YtWvdKsQd42pGSjEE7SVAHUkHIzj+HrjmtcTpLAY dqNdsfIAKhsHBwMg57jg8cHOeo2d5ct/JmLej7Hk2sSK2qR/ZYHZVMTzMTgSbUCgKAcAAgdR0HQm tHQLe4uZLpb5yIVMkhTaApkO1cnkeh/DjnNdPLFU7voYxleXKu578umrbPp8UAMLMVeVU6KpdSQM nOMZz/Loa1tLlTTYnVCFVJG8pwXZpXdlA5+6B83pnkc15u8brqelZxlp0Ow/Zb+BVn4/+KPifTfE ht0Weea+tHuH2wyL83yyf7rNvxzkxJnIOG9w8SeMfEfh6fW/gxq91qOrS6Jp82rWlraajPPpOjaR FMTdXpjaRYo32gbY1DKzSbeZNkb44mpOtiIYemtoxfkrLX5q2h3YSlSpYfnqO1+b7zzv9s74KfCq 58CfD+5+F/iH+1PEOu7mmtIYNqw52ukjKGPllV8wsAxwCM9K8j0XRLTS/C+neF4bgyxxWYhknDlF kwD/ABHjD7SDjAPI5yaqjXqTwkYzVnzN/JaL7zKvTjDE1HF6WS/C/wCousE3qRaZBcTC0W5AaO3Z vKMMYL7m2kZYkjtn5SNvQmOztkhsxaXivcRSZTeh8vepkKrjcCxDZLLjHCA8iqTaijPXmu9f+Aa+ pzpaRvYhLWSd4cHZn/R5cglBwu47lQFiDznpxmna3Nta6fc2f2YPBHJ88UShnLviRcvnawIDdRj5 j6cRd2uh6J3KtjYC3kW31CJxNcxBLx7gqGtvMcqQFJAKnCNgt22ng5OzY3dlYaXqmnf2J5mnxkXE D7gJIjGsnQlxvDM+9+BghWxniq96Sai9P6/4I46ayPxF/bX8YP46+LNv4P8AD0afZLciGNgADPkk K7HOMYPsB35rxyy+EemWMZW6L3N8VBGTgHjkKO/PSvuKGIeBy3DUofFJXfzOPhrg+HFeZZhj8ZNq jQkopfzSte1+ytr6o5y40/R7aXbDYrGVbJIByp9j0/ziub8R6XaLp08iZ+1RncnHVe/6fyrtw9Wo 6keZ3ucnEuWYKOXYj6vTUHSaat62Z5wY33xMq4PykMc5B5Oc/rX6t/ADx7P43+Hssep20D31uott Qu97iULGAI2HbdIGOWUFsRZBAVgc87pKeHhV6xf5/wDBsfHcPVpQxU6XSS/L/gNn0fBsj1a3uLbU JDYWqKsfm22F2ljlSoJbAlllAJIzjnkqF6PRobBtQiudRu4ZGW7d7h95cxGRnZQ/X5vlDFsEnaMK eVr5KXWUVZn2UUuax+Zf7Z3jaPV/iK/hux3xR2kMErwkgqXniikLcDgbRAACSRhhnsPRf+CZXwfP xg/bC+HaXNp5nh7woH8VaizYKqbYr9mBHQ5uXgGO4z6V2cQYr+yOBswxidnHD1Gv8UotR/8AJmjD hmh/afG2DouN17aGnlGXNL8Is/r5lii80u3QYH+NVmgjWTgEp1PNfwOmz+16Mug6C0KySxFTkjcu Dx/n/CrkVjE1rdRFRvGQM+nBH86mVR9PI64yT1P58f8AgpR+3Tbx+J/FX7Ovhnwrpl/pemyQrc6p dFpJbe8AbzlgAwqOgfy9zBsEP8ucEfmx8Fv2pbf4Z/Evw740j8JP9ktbe5huIILli04lRoip3EBk KMwZG+U7jkEYA/svgTgmpguDaEHXaniKftGmtIyqQTSXZLr53P5h4k8RMJS43UqmEU6OHrRi7PWU ac/e+b6dD9B/AXxP0n44+D73xzpenLaX0N/LbXtmHBMO4l4ju43bk5JwBkFRnGa3m097yKeO1wHX O0HBPpn8BzXgYnCywGNq4Ks7unJq/ddH800f1Vkua0eIMmwmeYeHLGvDmSve3Rrto1Yv+DPgreeK NW09WV2jkfaroQQSCM55yMDPr1FfW/iP9my6t9J0yTQrSWS4t5DHfMzACMtjy1AznOVkz/8AWrPM seo1KVPTl6v10PoMFSi6PPN25n/wPzPqPwR8FdE8NfD/AEh49Tjn8UX13JHcaesRH2ZI0TZI7E7f mMkmBg4CMSea8j+IXwS0PxPDJFc2aEY2ghckDJ6Doe5x7mvPpYmVDEe2py0Z20JQxUJ0K1Pls5Kz 1vFNpP8A7etdeTR+d3xE/ZIvtGuLjUvD6H7OTukhVeO/P14H5+9ePeBvHvj/AOBniRhp0zpbBiZb SdTsfOcED+HseOp6+tfWVvquf4CphMTqpLXun39T4TN+HfqkJSwq0TvFdr7r07Gl8cvjnrXxRm0/ SY4Tb+HUiV5IwT++m7s3qBk9q+MvF/wd8O+Ms2+nobbWWB/ewLhT6Bl9On6nvXXw3CfC2HpUaWqV 3P8AvX3/AOAfzDxrlks5xuIoYyNpLSD6q2z+/dHy94/+AfxQ+HtmdT1Lw/LceGwx/wCJhbpvjAGf vEcr688YI9a0vhV8afGHwilk+x20N9o84UzWlwPlOMEcjnHONpyCCRjDGv1KhisDn2A56E7xfbeM l0fmfieIwWY8OZly4iFpRV/KUX1X9aM9m8b/ALcPxF8T2kGmaNI9ppgijiaN3OWK528joASeevzE k8147c/E3xd4icz6jq8jo2ARvwWxk9uPvEn65PU5qsFk+GwkVpeXfzOfG55isXJpO0ex6L8M/CF9 4u1WSeaZ105AzN5hJDAepIyB6n0HrX67fBX4eWPhzT9PhOnAXAjh8wSSMc9QOvzBSVDZOAAo4PWv Jz/E2tSg9j3OHMK7OvUV3I+kJbGKOZbmae0yh842zLIrLJkCVmYEoyh9wHDH923J4AXVrS6i1DUy 1xNHbLI0gmSWTE7RBEZgrA/NsCKoIPIPy/KcfJaTd2uh9klp7pLny1ggk8iRt6xC42gLIMDcV3YL qoJOWG7jGCo21Y066lhS5wFextJpreUq5WOfcjrGSVO5iThwCdw28jrUtbJsLWd0Ytylp9tezhea WKWZYwi/IhJUqrdBwAC3bay5B7GtLFY20CWcLmKBTskkBjk2s7bV8xySMElT3yXGMZ5d7afgRpeT 7EGoNf8A2e/ayQM8DSdED/vdoKncPlIOMkZxhPy5nxTC9tiW0vo0S5WGGZAdzBQh34PLbmJ2kL1L HgKKIuKsmjObdnYmgCTWl5pSW/mlf3X2hlRi5Q/65GwAAFIxuPp8pxxyE9/Lo08r+UwVo2gs42bC lQw2yYXocYGCAQxbORknSMb2i9yJu6i0V9Rso7aazby3aze3RHCMA0L5O4/MCR1bCggMQfXNZiaW 1i7Q2/2hJJXxFHMsTbVZQoALjZzj5cghc8YxkXGXNHla3M7Pm2Or0vw1c+IrxG1S4W4b+OZisgCq WCKuSdwXG0bieA3ua9R0/TLbwvBLFbuTGYl+eUsfOC4AVQvA2lS/zAfeU9sVnWne1GOxrRhvWl8j Bl1a1uLC1TSn+aSbcXkZsFgWXgcEdSOeOD61zN/fXlyjvfSObjdghmfaSOT3yS3449cnNbUKLUlf 4jGvVtF22PlT4u/GceHtSh8B+AbD+1PiPdP9mtre1j8028j9yvO5xkkLn5cZbgc6Xwh/Z0fwPrS+ OvijLDrPxJkxOsbOJ4NIkbGck5WWZP73Krj5QcZr9V4SyjmnGVVdOZ+nRfN6n5nxJmLbcaXwxf3v r9yPp6aWa43XE0pMzuXkdmzuxz8xI989a5bUNSutZH9n6TL5dsCFlljz8/Yhfbg5NfrmHpxgk0tf 6/I+AqVU5SnPp+LLGnWyWEYtbCNWnxhlOSc+gz3/AKkV9v8AwT/ZhutZNt4o+INsY9JcLJDp7KVk ujwQZP7q/wCzyT7d/M4jzyGSZbL2b/ez92P6v5L8bG+S5bLNcwUan8OLvJ+XRfPb7z9ALXSrSwgi sbO2jhto0CJHGoCoo4wB26dvavKfiJ8DdD+KcsamaGz8SgbILuYERyHqElwOnYNjI47V+IYfFShW dSo21K6l536/fqfqtWjGVHkWnLt/kd18Jv2LvDXgaS31jxk6an4hVg6qRi3t2HPyr/GR/eP5CvpH /hVngz/oXrL/AL9JXHiatSdVtu3zOyhhacKa5ldvfqfzZeXraJfukbGOBTbxxg/MzcbiemBg/qOO ajmWe304Xxla3vAV3224OGOMgKo6ZLZx2x+J+YXLZH0Sva/zNNbmLWJ4ro2sdu0UbSMPLBcMpYgn B4wSfXPSrUENvFcx+Wqx2iI3mySEF53U5BXnuCTkfTkc1ElKL5U9Pz7Gloys7GTf+GNIube4n2TQ ahKqR2wIBWTKqSSQcjdycY7jnnNYsGj6rpVpp0ka5kklnO88iRIz0YdVIwVzxuOMDseiNW8OSp0f 6MxnRtLmpnYf2o91FLHe3bQ37xo8b/KqxqqqCBuPzdM9PQ57i5p3iO3sJXsI/nuPIBZ0H+rBYDce 5APTHqCOKx9kmmoq/mXGraSUjurHX9S0y8gm0iQxzxnc0veMyMFYHBGQQOM8Dg5440dR1F7y6N81 uZ7iYjzzGsYkZQNxG4gkcK+Bz1HvjmcEpKT1O+NRuFuguralbam7QxfNOtrK8bPtdLZXACgEgjcA CCeoIzjIFZFvb2zaXbwQRvH8zBojGu+BY1TbgL8qKzbj1YgYGMjlWdlfyBvm1tuSQWT2FzpN5Zz/ AHI1mlknTIkMgO+MRgMw2/Ovr39BTr9Z99xexR2+GiZo0UKd67pflVSRt5wu7kqAp74oUr3Y0mo2 RyifaZ/+Ega90/c6y290kvAW2d5Ad3Q/N8pRgQMhzgAndWtFpLWxv57KSb+2YtjWzb32RzMrYLgc EnK8AjhGQ+1tWXKnf/LQhW3LWdVvrVP7fto3spbUwJMY0UzRMil8FSA7s7DeRjJ3844p0E2kaNdR 21xaC9t5Yw93HGXBeb96pQyBWKKhXzTlfmULyQQWlK3ur/hjTpd/cfiZ8Y9GvLr4/eM/FEsf7hce S6xbFYyICQq54AG5ep4IPTms+K6kkl86Fl80NuGeecDt+XBr626q0qKX2YRX4f8ABPteEMNWyvI1 Vmre3rTqL0vyr71H8TyjxTaSC/M6wlUmXzBgcDnnGPxrBh019UvotNXJnMUhwBwVVSTn8O/tXo4e Vowk+n+R8nxfThGWYUoqynsvV3R5xHZSF3UQ5YZxj+LBr7T/AGVLa4S28cQJdtC8kdqwbKkRj96C 2w8tgDjHrxziurM5J4Kolrt+aPyfKIf7dTfr+TPtufTr+Kx0+41GEJAYVknieVE2p87PtXnc7MWI x0GTkjOe3vtX0jQvB2r+KNaslt7GxsWM6ttzPI67kRgQNqsEK8jcodQD97d8bN8ySg93b72fbxfI pSl0V/uPwf13xHqHjXxv4h8VanL5l1d3Mt5cOdxHLHpntlgB6DHpX9L3/BE/4Jf8I18FvHfxv1Wz K6t4q1Q2OnvInTTrLKFkb0kuJJVI9bYegrw/GnGrL/D/ABGHi7OrKlSX/gSm/wAIHseD+FljOLae Lkv4catR/dyL8ah+0ZtVHTAH3u2Bnt+gqsYnRwq5xnPAr+KFK+5/WdNlxYwskcuMBSFz9TmvGv2p /i7pv7PHwL+IHxQvMPqCwpY6PbEgm71CbctvEoON33DIwHO2NsV35PgKmbZxgcrprWtUhD0UpK7+ Su2ZZlj4ZblmKx1TanCUvuV/xP5tYf8AgnF8WPGPiyyn+KviM2vjnUEfXfE9mXDTaBFN+8iivHbO y7lyXaH/AJZJjcS5KK7xJ+wDovgtodT0n4t2VrqdvOJLd7y1823Lp8w3+biNwWAG0q4bO3B6H+7f 9Y6VH2eFwtFulFWVuy0VvVJNep/KGA4PoY2nXx2YVn9ZqSbVtouWrbXX3m18jhfgNpviT4FfGyP4 Y+KtWhvNJ8TWslrBPbH9090h3wt6k7iygnk+YOwr7Wht5ZbwoBk5wWzg9emPTn19a+L4oVOWZvG0 9I1oRl81eL/9JR/TvhK61HheWTV5qVTB1pU7rZqSVSL/APJz75+Bfg+fQdEGu3AKXbMDCem0ghs/ XIHIrwf4sfGzXbPxpfW/hvXWhtLBjbko+RNICN+RzkblxznpnrjPy+CoLHY2Sq+9FL/hv68j9ppx jTgklqerfDL9rfw7qLWeieNNOe1vSwi+3QHzI2Jz94cFex4BHUZ9fsFGtL5Ibi3k820ddyEEgkEZ B9uCP0qMZg54WqoPZ6pnNOLjJzjs/wAH/kYd/wCF7G8hcrGu0gjp+mP8/rX44ftZX2jan8VbnStA hQDS7RNPneMgiaYO8khyO67kjI7GM98k+hkMn9akktOX9UTiWsRR5ZbpnzZZaKZ3FvsYlmOAAcE4 5PT/APXV7UvBPifwbLb60bEi1Yb1aSMlOepOOQMdx3PHWvqpyp1f3E3rJNI/L+KODaONlHMoR0g/ eS3t387bs+gfh/8AFvw3qGlSeDvE+nR2YlYRs05V7a4UdAcjG4kDg98Y6ceHfGX9hf4feJPCGr+O /CGux6JqwUyRQEhrS8wuQqAcqzbQoOcZYk8DFfM5dmuP4NziyTqUK8lddHfqu0on47xpwlh8zwrw uIajOnFuFTtpp6xfVH5A+L/A+u+CdUaw8Q6XJDJnG4oQsnPVW6Hg5Htin2E0G+KS0UspBDB2zj6e me3pX9DUK1OvTjVpSvFq6Z/KdehVw9aVGrG0ovVH3x+zl8SfA1oq6Jrsz293NKAySEGJwNp3sxBP 8Lgnk4wFGc5/SHRPEMl6upay9tAlncyR3Vw7RR4jYKypHAASVAAyFLOfvli2MD47N6E4YiTqbPb+ vkfe5JiKNTCwVN6x3XY9q0LX9Ku4bV71IE1+UiCPzbgyEAuzKH3LhRtSVh8w7nIGa6RbiWbVFtxe qrR6dxsyrB8DLAbfmBKbRx1IDEjca+dnHllZ9NvvPpIOMknHrb7ydTHNFcw3UnlXe3ciSOxdwCuX 5/hVGcBUIY53AgDFQLc2NjFbQwwujM0U8VuuUkjIDKZMoRsOSpHIZVx3JrPry7r+tSr7trUxpVn1 C+tIzDEt9EpKuhX5NxZiNxBAThfmySQcg8AU/UrOyjNvcNAsk63OZIhLvMjr91HCDEjKwJ4GTlMD aCTSlbRMl7NtGbdGzsopRNZiWKSNZJImbBdgTGVJyNpwFPykZ3HHADVhXTnTz9phgibUhGlxHaY3 LalN2A23L8bHJBIzmJs5QGjd2l5/IzkrXVtv1MG6tL+wF/pBuSyeckkQjQRvN5m0gO4OQGViegCg EEcEVlXscME7EQJgpLOh3AyBnhfcQSG5yVO0klT8nJAxomun9f1qZOzSuNKpGt7b2FlKklwVULPJ HtiABYbkCkBRuA4CklSoK/MB0mj+G/7UW7vpIrn7E0qyRRht6XQA2EMrk4DOFG0/d2nIHNVKXIpT dm1t/wAAmMfaNRO5vi9qyrY2O2ND9m86IDLhQzb3cMBggFMDn5wCOpGfresx3tvbCUP5ESIOTtKD ORlgeBnLEHPoeKwowbnGUtfM6Ks1CLhbQ5K58u0hnmurtorZHVsllHAGM84x1bB9GPvXw78Tfjzr vjPXB8MfgVDNfa1cuYDexZJx/F5RPCqO8p4AHHY19ZkWX/W8RzSj7sfxfRfM+TzrMVhKDUH70tF/ mfR/wP8AgvofwV0qS9+1LqHxUv4ydR1hwT9lVvmaC3JJIUkfNJwznrxgD1mQxQxi8mmVYwdzMTgf Tp1zxxzmv3fKcv8AqlHl+29Zf15H5JmGIeInaL91fn1f6HJXr3ethVdTHpG4BF6NKTtGT7Hg4/8A rV0mj6Le6lf2ukaFZGW8mIhijhQs7seAOP8AIr35ONCnKtN+6k9fTdnj1b1akKNLy+bP0l+Bn7Md h4TWy8TeNoIbnxSNrwWxAaOy4zz2Z+evQZ46Zr7B+yxr+8xwMcD+n+NfhHEOayzjMZ1k3yLSK8l1 9Wz9UyXL45Zgo05fxJayfn/kv8yCSPe7bl4AwGx71SkjwxHYcjvk/wCT1rxmk9Ueuez+CPHkci2u g6/KAqjZaXRJ6dlcnt6N+FeqfbNI/wCgza/9/wBf8abjCVuboXCuqa5ZX8tLn8tVlqEkN9qVuFcy jKGV8FJSW+U7unIyenQfhVHVIbGfUbJ57YqTcrhcllkcsBv74xlVxjoOvavkIpqSkuqPpVK8V6mn c2kdy+qy6RqMccsbmOWRyRhA5QA4IIJAHBZuvXNV4rW1vbeK6lvCbcIVCYACBejbyxUls5IAHAHJ yMTGTStbVfrsacluum52jX1tEZRqzGRREvkOqF1iALZAwTgBnHI69an05fthhNrG6SxsrrbLIy+V GzuS6Bc5Zizg8D6dzm4yd5LY6N3Z7k8OmaU1s97e2PlSzqkUCSllZdxXyy7OPlP3zx3yAOeMyXwX aXGq2rafKYbzZ5Qj5kNzK7qFIbac4ViWUDIJGSp4NQrThtqhVaMaiTtZ/wBf8AxZtK8R6HcXl5Bm VFtk8udtsZG5VAQKAPmwGG7gkk0mjeJbiFtQivlYTRx7ICSUjRmdQVO7qfmz1AAHcit7QrR5luc6 dSi7S2NIeLIobKSK0njhmLPG74CgockhVYfLlVfjB6nk5xXYtfva3lwtjNLHDIu5/NZsnB/e5UYy CQw4PUEHHNYVKbjudFOqpbGXdvFb3FheLDczWUQiHlxIctIsbb3UYG1QGkOf7vPQ1Ygu7z7BPO3m KZzJ+6R0PlQSO5YNghlcIpYAEYyMEcYzsmrGier5SK3FpaWU7Wk84nL8ec67EeR+VJI2/KHY7tpx uXk5rc1O0fz7a5ggSC981bv5VcNPAc/Lk8fdG3BA+8ByeKaW3M99PyK0tZEotYNIudLkn1ZJUjc+ dHKcmUKABHz9wldgOMDG3ZzyvIfETWNPzevHqAMi2FtazHAR7hPKYO42DYi7hGSW5+ZnHJAKilzr Qc2lFts/Hr4z+IYNR8b+Iri0AFt9sljT5QuVQ7EYjPGQuSOcZrzG1vN5BUc8k46E4BHSvrsJB+wj d9D9EzHFQw1PCYCmrqFOEdOjUVd/fe52fju08MP8K/hnfWAZ/GbX+rW+pIqnAt0No1q3PQ5kuFz0 OwccEnQ+CnhnTbTwz8Y/jDrqwyaRpGkSaFpAkOPt2s36PDHHHkfN5URupyRnb5CcHeM3CUo4aqlu 5OK/7elyr8/uR8LxROMq9pb8sW/Pljf9F954Xrfgx/D2ieF9UnAS71FZZo4jGQBAGCI3I5DMHwRx gHvnH2D+zxpM3h/w/rmpX2mIZL7ykjdwQyeXu4XGeC7qp4zkJ9a6cfW58JKzs27L5P8A4B+cZbhn Txl/5Y3+bX/BPqm6tVfTZJrjTJJ7tbdyLQnHCsIw7dWIAAYKduc4zjDV86/tgeNr7w98KLDw7M7m 81fIErbkZY0IfAC8bj+7RuORgnGa8LBQdXF0YN/a/LX8T28fU9ng601/K/x0Py58NeHL/VvsmmaZ aSTatqV1DY2kUYO6R3cIoXHUsxIx9K/vU+Bvwms/gj8Gfhr8JdPSNbbQdHtbBzGPllnVB9ol9i8x kkPu5r8l+kXmPLgcoytP46lSo/8AtyMYr/0uX3H6j4IYBQjj8c1ry04J/wCJynL8FA9HnicZdVJU Hg56f49/ypltbO8hLkcnP1r+WLrlP6Cja1jbm0VkdImlHlyL8uMEDPI/rXxz4p+G/wAUv20f2wPh l8J/gH4Xh8S6B8PXlZmlmRdOt/F7RxhL69Lbke20tZ/P8so7vPYzwCN8lT+k+FWXyxfFkMR0w8Jz v/ekvZw+d53XXS62PjOPsasNw9OMnaM2uZ/3Y+9L/wAli/6Z9o+Bv2UdB+CNnrmu+OLF9d8OW1re X+q6rqDyNNqVxCCZbmTzMs0pcARoWZi8ycmTBP48/HL4kiH4s3Xwsi+DGnnwxfR+db3V7aPLeIXU kyCXfjGB02/L79v6KoydRqMZctk5ed10+7Q/IqU50p1K0J3XupL82fOXhT9jSLWPCXxY+LeoeIra 0tfhxr+iahpNvczbbm/a+a6jFvbgjMnlmISsMgBInOeMH3X9mD9n7xT8dPiR4d8GeGrJZNUvpmI8 91jjijjR5ZZZHbhY440kkdugVCe1ednWIli8TToxeySX/b2r9NWf0D4cVsNheH8wznFXjGM3Oo7d KVKDbXf3dPVWPY/2n/i/4X/Z98DwyQX4Se7vY9E0QKoV5p3OPP2noqLulOeB8ik/MK/J2/0/xBLq L2sA8yEkMZHOSM8/Mex65GayyWlDD0ZV6ukZt8r6vk0/Nn6bSzGjXxFTBwl+9pKLmuzmm0vuX5H0 F+zl8M7/AMW+Kl1bVYydLsW3ysynEhH3QPbdj8zXW/Gz9qLxh4J+Mc1h4Hv1bQNIt/sV1A4zFd3L HdISeo2krF7FGx94Gtq1GnmWZSw7+CEN+zf9I9Kb5aEUluef67+238XvEOhtodnb2FjqMyeXNfWy OJQCMHy8tiMnnnk/jzVv4Q/sz6/8QdLl8S6tK0VnI257l13FiSCxPdiSc4HJ/WtZ0qGSYaU4+9KT XroZwUZ6tWS/M7L4Ufsv+K/EfjjTNEm0poppLuOELOyxJl2Cpl3IVQePmJCgHJbHNfoF4w+FejWM mq+GLmGy1HT4GeyMsKq0NyiDyQ8TOgIUoCVJUYyDgHp5mLzLmxFKvRkmo9PX+vxHKdFVVg2neUXJ u2iV7JN93rouid7aX/Pz4sfso2CC41XwajZYCR7NzyjYGduOq53AewBPORXxfrdj4x8Li00K5lni 06Dcy2M7v5a8AMVByV4C4A4GOANxNfQ0Z4XMaUZVI3S180+67H51xdwn9fwFahh1aVrxt+MfTt9x BP4f8LePNIm0fX9PjuITjdFMoLRnBJIbqOgwc87fSvmPx3+xvquk2Vzqvw9mN3blmf8As9yPPiBO F2H+MYwP17V73D+dSyzEfUcbL93J6Pt5+jP4z4q4flVqzahy16ejXe3Q+QZbS80jVZtH1Kwks7+E H5ZFZGAPQ4P1BB/Edq9m+Hfxw8YeALyKGe4e70pEKrBKzlQCMEqM4z8xGSPXpmv0LE4eljKXs32u mfA0KtbAVVXgrK9pI/R74UfH7RvGv9mCyuUg1hSIHQKifaM7tqyEkqQCikZ+6x4IDEj7Q8N+JLa1 srS8ikiubK6s9kLzIJlWUANtYABGyWclic4b7uSa+Dx2FqYepOlL5M+8wGLhiaUasHo/6ZLo2ttB a3Hnp5l0srxNtLBoxlMEBgchssFUcEbhkBTV+7NwPsDXRH9pbRtSIF1YooEa7u+FY5A/hUAbdvPA 1FbHoqfMrJbfmT/a1EWo75A16h+fa+0BwuNrqMDJIJUYOA20AnFYMV5qtvcW1kWSJmcTzrInzrHj AwobGMlhwedi5zUqzvqJybasZuoFLiR2j1KOW9ZWKsoZflTMQXHIX5MHHfI/u4rN1bUZrl9QkYj+ y/KVrhY5mWR5RGCrBmHzMHfLLxw5PJINVGPvK/8AXYhuTvZkOoX/ANq0WG4hvYYJxbiXy1eQGWRm TdJvPzE5BGTuOMdelR20UmqwnT7eFCJPvyEhQ8gwo24JLEvvA6nr0BILUe+liNb6djvLPwvqN9Pd eI9Ss1SA7isMUQUw48wYbPzOOQo/iA4461q3lvDZQNbX1+409D9ot1VnkEaj5dvzEgMcjKjPOOma wnJTkkndf8A3hBwTnPRv8jktR1krHayWdzKY2jzEjKPmXrz2zkLk9Oa5XWtetdA0+81vXLqC00yF VeaeYgLnA9c46+nOeK9LCUHKUYxV27aeZ52JrqKcm9Frr2sfnf42+Kvjz9pfxWnw0+FNtInh6RyJ ZXLIJEDYMs7f8s4sdF6k8Y7V9w/Cb4OeEvgr4fl0nwyPtPiO6Cf2lrM0Y8+cgcxx4/1cQOdqjBIx uya/auFMnVOKlJXUOveb/RH5Hn2ZvEVZyXol2Xf9Tvr69trC3W4u2KEDj5Tuc9MAL1PTpXOJZXGt stxfqYrVMeVb4zjkjLZ5Ynr7V+k06L0utz49z5I8ye+iPRPBngHW/HWpWGgeHtP867LfNhiFiHUs zfdVRz+uK/Uv4PfAjQPhhZ/aEAuvE0o3T3bqML/sxL/Co6Z6nHNfEcaZwqFBZZh5e9PWXlHt8/y9 T6DhjLvb1njqy92Pw+cu/wAj31YhGSgGST1x7Z/+v+NPCo26JTlsZGFzg/5Ir8oatds/Q07FaRck c5BHXpt6f5/Gs6VMli3JHX0yc8Y/z1ppLYpPVpGRclky4H48D36/56VR+1y+p/77H+NVyb2sF/I/ BW2n1E28MRtnjtJZQzsz7chSBnnO3IDYznr1rtNGiurU3EtyySSINyK5G4NtJBOUGfmYjqeMH6fI 1FGKav8AM+ppyd07FPVFaeG0h0y2k82dyZ0K4SV88lgPmJyJGyAe3HNGiwT6pJYJdvi0t1dTbrho SMDyznbnd82dvP3V6fNWdoqL6v8ApGivz2a0O28QX8MkENoJMw28nnW1sY/lAyfnLRq2chWHUH7o zVfz5I4r8WcSxTG1RCzIC7KhLEk5GSRk7cZOAcjG04+vU35vflJf1oaOoXEVpd3X2m+Rp51IhVFW R4nlwobptGGXI5PIKkMMg1x4gmhuYrG1hU5j8tMSAkgnZI3LBuS6ntxuyegCtdK+xpzcrdtz02cN dRwC4eea4YlLaGKPhonkTaXVsHc2WXb05yQc4rzrUGXT7JtVuNJF7HJuV4CikpDvCkqxOF+YBWYs OPUDFRTunyruXUa5byV7GdL4U0K8tb3WdP1iB7iAeZBdWrTPBKyEDYsmecM2ScDzN/UjbnmNNt9X sLwW0Nkl1OGL3l4EbzDGqK6mUMzbVX5cgY+XuCS9daqe0ThU0a6nHOnKm+aCuux0Fp4o0+C8trKe wjFjFC/LuqAA4zv9W+YBQcjaSM9K0rTU7CYvcWpZZY5oy/nholaNzKjKhI2kkBlbBJAUcjNRKlKG u9y6daEnZ9DYs7ueeINc26rOJhcg3W7EiyrG4OyIgFlJlCkHaWjAIOGDax1C1t45LyG5jadblQYz Flx8m1tpxxHGUUlVbOGAUcVhLfRfrudMXZXOa17Wpri1iudPh8mykl+1OpdfMvJJJI4htPYkB2AZ VB8oADJG3y7xJJcol9e3cUyXMkk9uLiNmdw7lUlRMbUEexgjZJ4AAyM52pL3k7mNWfc/JLx7Zrb+ ItbtoJG+zR3s0YyNp+R2GGHY9OD6iuc0q6ggWe2NquJFAEhPIbIx+eAMV9fTi/q8UtNEz7rC4zDz xUK1aKlGUbf4eZWv8tGLLa6p4n1TRvBWhxB9du3+zochViXJeSQsT8qjLMWJwACTwK9S1/TDfp4b 8A6bLPH8N9GIULFGwl1OYbWnuMDAVpcKFLHKoEH8NEWqUYKXnL9I/m38j894mrLF5hUp0norQf8A 7d+SRwum6Rrvj74lJpeoOkEFlMliyFlMNjDAdm3joBg7jj5izE8tX3V4X0SOw0OwtLeF7m5WR4SV KjYP4XXI27ht25Od20jB5rDMZpKnSjsldng5bTk1Vry3lJ/gev8AhbSYp9asF1ufzFieWXCFUwqI WIGcBgpx3IPQKxbFfll+2P4xsvFfxiu/Duj3RfRdJA0u1AztIjdyzDk85d89uD+PPksefMLxXuxi 3827fk2VncksCo9ZSS+R9H/8EsPhBD8Yf2yPhypss+HfB1vJ4rvW7B7bYtoeepN1JA+PTca/sHu4 0BZYj3ycdv8AP+NfzF4/451+L8JgU9KNCN1/enOUn965T+iPCbCxo8M1K6jb2lWVvSEYw/OMjPkh AynRSc8ngilMW0fKMOeMenrX4ZfQ/U0keF/tI/HbR/2cPg347+LOtSK02n2rJpsDbf8AS7+QFLeP BI3Ded7qDny0kIBIrzf/AINXf+CgWh6b8df2hvgH8TpYBrfjQReK9G1GbHny3Vmhhu4C+N8skkEg uCT/AM+s7sQWJP8AS/gjlawuR5nxNUhdKrTitNeWnaU7f+BfevI/BvGHMJYvF4ThujK0pU5zfr9l fPla+Z/Qp/wUK8U+Ef2jP2TvGfgD4RWMVv48t5rSbyAEDMba7huHwFBJ8xIo542wCVKtxX8of7X3 iXx1+zZe6La/EnwfPN8StFWC9t5xbbUnhmBChi4+aGQBwHwQQNwGK/QqmJwuOxqnSXJGTsvmkvxP mMnwmLwGX+wxcueonKWm7S19Xb8D23wxB4Z/ap+B48U/C5/K8nUYZde0pl2zQXaK0KxiMDLFBJI4 boVkZlLLgn0DwjqGn/BDwnrTWXiNdIt5rGW11XUnuBAosmA86NnyMRsow4zhlypyCQficZi/aZri sJTd50p8jt35Vb776fI/qvgL6pX4MoUKsU4+85qS0cXJzTfk1a99HZrufjD+0J8Iv2g/2sPHcfxt 1vw7Non7N+h3p0zQk1OQWlxc20UpFzOsDjcZ5XXJVgpw0MeSE47vwv4XvvFniCzsLW0eWaeYKoCb mfJxwBjknA/A19hmFbD08HhMHh3dUYWk+827y9dU9Tg8PHisfjc+z3Fv/ecQuVX2pwhaC/8AAGm/ M+w/iz4j0b9kj4ZXQvIEfxvPfx6PaWMQLyXmou/lBFEYbeIhvckAhim1cl1z+dfx58H3fgj4i+IN Eknae3803EUkjA+ZHKd4L/M3OWwfmPOa83J5ThiourvXVRr/ALhuC/8Ab7fI/QY5ph8VjquApO7p whN+k+blXk7Rv80Zvwj8B3XjPxVplhBExDyLuIU8LkdPTnP6V+m3xX8U/wDCnvhzBpelXHl3Um21 tYw2dpA+dwM8YUHn1IrXOJfWcbh8H06/16Hr0oxjSu/U+cvhh+1brPhS8/s/xPby6npMjfJIJczx djgt9/J5yTnr1r9JtD8U+H/GukWWsaCZBYypuWKcEOPXdu5615mY5esLNTp25ZXt5Pt/kYVoSbVW Gy3/AEZDqmgR3cTqYsHOeODxzwa+D/2vNRsrfQvDngJNNspdZe6bVZ70wL9siiUMkcZkYEhHLytt B+ZkUtu2pt2yPE1cPi5U4q8XGSf3bmVeEcVTheTTjJPTrbo/LufB1h4U1XU7kWmlqwupD5aBTzk9 vxwP0rqbG6+IPgPUFs/FljNNaDlQyEH0BU47jnBx1J5xk/SuNHGp4d/xIq8WfkfG/A2ExntMfSpq POrOS3jLo/R7PtufVem/Bb9mT9qbwrNpviKyt5/EsUTKLu1xDqWnyMHVGJ4ZhuUPtbhgijgEV+eP xc/4J6eOPhZLeT2O/X/AhY+VqFrGPtNkmRtE8YGTwyqWGQTuwAq5rLhbjSvgMxqZDnj5Vf8AdyfR 9I3/AJX0Z/PXE3Bv7j63hqVqsFapFfaS0v6r8UfB+s+A/FXga4jv7UFbUYeK4gYlDjOMnqD3IPfF fZf7M3xn1/xFrlp4Bv8ATbhWkgEcc9szAqI8ndIQcLGoZyQOvTPOa/VMzo0cXhHiFa8Vf7j8owLr 5fj1h3rCbtp0uz9P59KkQ28lvcMIcLPcHzFaSU4zndkgc568jPTtSiXS1kgGorJcxs4gt0kxEY0V HVgxU/IGI5wDgxsM9BXwknpdbn3lrK1/6/4cpefp9usmnCaeS5HzOmzHlSEO5wJNqkqSw7YKnk5G bV9La6dd6u09ubiS2jzC5VZF3Mc/IRyxG7ktlRz161DTfSzC8fiWpg399qEtg8t1aSRQtZmKNCiJ 9mLlSCWAYsoVwwBUfcbqSAediDalui+1hL2OHajQRELMXXrg/dbYxPJyPm6MeK5FFXjqZSm20Z9t HPLEtkbl5t8IQrDEzZxIpwqjcertxkjKnJ4Fet6H4Xj0PTrC8lsnlkkAVYYtoMK7g5I65LM7Hfn5 SSTjJpVZckeXvt9wqVNSkpPZGtrmtbmmt7WWa3UYKqxyWGQT1AwxLN2HfBPBPA6vNPOr3rSFY95K HBO0btmQrHnIDYOOgAycZqcLSXNFd2Xip2i2jh9a8QaH4S0O+8ReIdXEGnQR7pA7483n5QM/eY4G FA7e2a/Mr4hfHWX40+MtN8OXd3HpXg1JwfMcsUgjPBnnH8Zweg9cAc19tkeFjH2mNqx+DRett/l+ Z8RnuMlywwkH709/Jf8ABP0u+F/w18D/AAx8MwaL4BjEtjOqXE+pMoE2oF1BDOeCB2CDgeld3qV1 FpYQhM3Dr+5i6s5bPJ9sd6/e8rw0KWFpwh8KSd+99b/iflGIqKpUk2/+GMWDS2nkTUdXlJuSg2ov McOegGe/bPtXsPwu+EPiX4oazHbaRG6aYjA3F5Jny4Fxj2yfRfxNd+ZYqllmDq4qu7WV/wBEkcOH ozx2JhQpbydl5Lv+p+p3w++F/hv4caMumaDaKsjDNxcFR5kzYxliOe/AHAr0SFxho1XCg5Bxzn/9 Vfg+NxVXHYqpi67vKTv/AMA/V8JQhhKFOhSXux0/4PzLvlgsC56jA9vfI/zzUW3cAmwEd8Dj/wCt XA4u51KQ2RVRMjjnjIJH4fnWPcMByevBPHP+fekluVzdjn7lmCMRyewH5fn/AIVmbpv+eMn5/wD1 qaVrppCbPwgFuttZ38c4L2rIJR5oyU25CBO45bPy88dKvWlxqNo2mwxyrDpi7/Pby/nj+XaiYyqq d5GfTBwDjj5SUU4vmWj/ADsfTU5OOqZdh1v7PFJHZ3QluY4gTKc7EyACOpyN5bgAnBz6Vo29tDaw QW+6Sa4aAXrCBwNu3gOWwQoy3PfA+hrCzj01f9eR0KV9XrYh8Pa1dazdiO4XZI0UHkKocO8rhGbf noqjcfug5BAyPmrr4NSMtvcQXNpFbX0Z8yzBnWFbpCr5wc7ickhsDrG2AxwamcLaLobQm2rvd3LV h4TtNQ1S4kkufNZpsskhV1UqxGApVh0yQMgnC9cmrKzQXVxFp0uoOskab5I7fzFwdpiXoTnJiYMc 8AA8ZWsW3K1lt/X/AAToilFXfUuDxhPG8sms3M6GJCiTBThoBuCLGQeGLBVLEEnC/Wo797W5XTot RgNxZ2sAuoiC6QxyNuUkRh8SYdcbiWx6ngVHs1F3S/r+mac6nGzMt4IAtnBazBoHgRYI4txt7GNs edlQDuxsZt+cqqKcdK8ou/H/APYsV7brMgeO8m8wwRrHGXit12qJHZt4/e5YfKGJ4JxxtRp+1TSR y1qipyv1/r/hjMs/Flpdt9outKZ595ZUti0wugqNJIVmOAmzLY4OfLJwu1VrNTxPZmSwvpYbi1nC CGNQWwGUuynBYEMWDYA+YgHoBiu5QcbxvddEcjal7/zudP4a+JvhbxBYxHTdVtrqRWMr3ccoLyOC Vbartn5eVUAdRjtx37a3Pb20en2c1v8A2baxrbtLJtkkd44QtxLwzMUYtuBIHJ3EDPOFXDyg/eVu tuptTxMWrxd13IdXaNNTlv7dppdJtFSESsVj/eRqDMABjYy7AMN90ZAXIOfNta1JLVTp+nyoizTG NFmkM4eVfP5QscP8xdzjG4sB0NZ005SV0aVJp6pn5lfES0i8OfFPXvDmpyLFpWpOb7Tp23hAXO4r 8/zc5BG7Lcgk9zyF9a2+i3D3OooY7eJd8bOuPMfkjA78E8+uK+ws3hafKviS+9qzPcyHFYephE6s 1zUnKMlfaMLyTfk1Y0LSafwJ4cbX76Jf+E08SARQp8oOn6axweTzG820qOh8vcclZK9M1PUYrGyv NZa6ZtUtESJoLgKf9NmJaOAKq/PsG5nDMMcqN3OM61KM2pR2fur0Wn56/M+Dq42pXr1qk1r8b9ZX lb7rL5He/C3wRJ4f0h7rVYd3iG8ufNnuJGAMakh5QxJAyAGdgR3IPUV9LeHj/ZV4lnYyzPKLdSpn y5B8yTYpBUZZtp5PTI9K8nFy9pUnJfLyX9I7sNBUaMIt62/E3fEXi8fDjw3ca5fWcYaytJLiVJgo Zn+X9yHBLJkBAQNvKqcEYNfhNfXF3eazd69ezFpS7SBv7xPII+mc/TNelkNNL29XvZL+vuPKzh89 fDU30d3+H+R/UP8A8ERPgg3hL4B+M/jhqdoyap411X7PYF15Gm2G6NWRvSS4e4Uj/p2Q1+1fGSzj Ldsnrz/n8q/iLxVzH+0+P84qp3UKns1/3CSg/wAYs/rbgbCfUeE8sotWcqam/Wo3P/24qSQhjmQD I54HQ+lMWIAtICAc8cdvz+tfn99LH1qXY/Cb/gug3jXT/h/+z9ZWF7A/gDULrU5LuG3lYz2+o2/2 cILlBwsbQ3GYWIG4rdgZ8tsfzu+B/iF4v+Fvimw8YeA/EEumeILSQS2t1AymSFgdwIyCMqQCDjgg Hg9P7p8HsJg34dYGlG0lU9o52/mc5XTt1Ssrbo/kLxSxuLhxzia7Tg6agoNp7KO6vum232Z++Ghf 8FptD8Y/Db4aeGvij4H12Lx5pmmWFhquq6DqSINfa2YRrcXcjTxMrEKm8MrkhiCxBLN9PeDf2kLv /grBrPxy8SmzvZdV8E/D+13w38aNKdMsJp2jKRxO/wAipPOWALEbSW65HHxVw9jcrynF42hNONNx krb2U42W26Xme7wtxPl2PzbC0sRHllJSi27WV4Pm+Xr2Mv4QeKfh3+xda/D74p+GtU1XWdb1lILv XNK0aKOS0uY5Z/31pfee6n7Tb2a+ZA67Fkmu5IpJEW3SW59a8bDRP2pf2ivC114Tiz8Gfht4asvG eqp9mmnj1/xBdGG20uFY4xm8WPULvS4WjVeXlnQrgEj5rE8NYqhxrQz+LfK6M3UWylUhFQpyfR/G rf8AXu5+kPOeTg2H1Wr7OGIl7JxT1UFOTalta6u+vuyR96fta/sPfE/wd+z7ouNHaw0LRZINP+yt IvlSBHe3uWLdDsvFWBNxIZBCQM4r4e+G3w1034YWM2s6oyrqYQgSkAiNcHkDu5H1xyevNZY6NWk4 4SUGpSSv8/8AM/WfDPM8uxPDFfE0aycY1anM77JKOr7aafI4XwR8G7b49fFB/j944kY6J4FuNVHh nTfLIjSeKHT1glk/6aiW++0hl5V7SFclRivkH9oLRtR8c/E7XtRsbUyW8TC1jfaesSqj9f8Ab3em QBWGCxUp8XPC3tTweGUF/inJTk/V3+5Hp8JV6WZ4rH5xTTXt5t/KKjCC+UY7d7n2j+z/APs+ax8M fh/oXxP8R6TLDHrXnw6PJMhU3iwMFmliP8SI58syAYMiugJaKQL8NftEfEf/AIT/AMZrLpt4JvC9 onl2JjzsfIVnmBB/ibocgFFQ8HNexh4zrZzKrNbLTyutPvV2fbU8XQxNNzw01KKlKF1tenJxn900 4vzTOQ+FXgyXxd4s0+yiXdF5iF2wcRgYLHvwRk9u1fQv7R3xI1Twzqng7wP4K1Ka0/suJby6+zyF MyNxDHJjn5UXzMdCJ/UCuvERhicxp4eorqMW389EdeqpK3VmV4f/AGrvjNrD2+iWq6c9zLthSY2j GRScAtjcQSfxA969q139m3VL/wAP6pr/AIt1p5fHlzbwXQNw3+s81UkTJJ4DROrJtBzlABg1w16d LKnH2N3KW7fRdvmZp04WTXvS2Xpa79FdfejX+AH7Nzrrq6x4o1O3sIraCW6hafdiaSJGdI02g/Mx AVScAlhlhX0F4u8E6d4j0AeGNYtll0cStMEwFcyFFQMWxl9qrhASQu6TbtMjE839qTp4361h5aWc beWn5nPiY0MTUlg6tK8Y2d3s276edut1a7XY+P8AWv2Q/E//AAkGk6j8G9SI8VNLHBZoJEgljmeW MKC8hEbJvZSQ58vbGTJhd1dt8N/jVqx1bVfh78VLA6Z46sdQl0ye3nikhfzEVy0c0cnMbo0c0LBi eUQHDyBBvxHk8c6yqObYX+JS69Xpdxfmt4/d1PyPi7JKdCtKrhfiik5x68jbSl5pNWf4lH4zfswf Dr4sabfXemwx6R4mnALT28Y+z3BJYnzIlGO45QKcIoFfntoPwb8Rfsz6/qLa94USSTUR9nhvUlyg jXLkRSqOAx27lOD8h64Ir1OB+LpZrgpZDj6lq6Xuyf2oro/72nzXofz9xDw3CljoY/Bw9yW6/lk+ vo9PmfX2k6hba1pNzqVvqM09hdQedbkRuoIRiFCjK4ZSzjG3qqj+LiG6826msdN8vyzJseQloi65 DZ9gQCBjOAcnoK+glu1Jdzw61OpQnKjL4otp+q03NDT9WWaMvf2+/UZAJpxk+WGIPmEcDcTkdOgY t14PLLZ3Mt/b3FxazR2ziX7Xbywxn7Pt8tD82CWyyMSWCjMgwPmwElZvmZi0mkWrGIXX2gy3BEX2 pVkDhRImxUJUK64Ufh2PAxzJpPhqeS0js7cFpwPLCo6kNGVDfN3PYkEdyCeaSlZtPYShzW5T0XQP CuneF0TV4QDqcyEO+ACVZAMKc4Xk8gAAsfStfWLmLg2EUaoEaMBVxsf5ic4IKn5Tz15JrmcnUqOT 22OtQjSp8qPNtcvBe3zyTgNIgHzFm2phQVVdxzwAPXGMVx+qapDpljdajqsiR6bBA080srDZGqgl mOeAAoJyQBz74r2MBRbnGK32XzPJxdXlTk9up+Nv7RPx+vPid4mnstOuWTwlbSstnG428cAzSY/i bGQp6DA65z852eo2mp3Wk6JpdkP3lyiPK/352YhSSfzwOgzX6NSoKjTpYaGijv5vqfmGLxPt61bE PXmvbyXT8D+g611uz/sXT4tPVFujCkYiZsCEKMAsfQAcevtWPZazpFnNJPqd2bjVHYrIpBwnPbPT HTHtX7ph6dKhCNNvZLT0Wx+eVIVqkW4p3e77L/g/kfXnwW+BGrfFa7h1K8tXtfCUbKZLroZgBysY xg9PvdADxX6neFfB+h+DNJttA8Paeltp8QwiLgFuOSxPUk9TX5hxpm6xmM+oUX7lPfzl69o7fefY 8M5d7Ck8ZVXvy0Xkv+D+RvPAHOSozz/D/M/nVKSHy26c5xjGQOnYcV8LZp2bPq0+qJI4ZDuVkODz 3/r9fapiFVSI1J4HI4J7/lU8qvsNSW5SuUNrKqsm1iN23POD61zt1Iq+Zzk46n8/6mk42umaRdtj EuWCbpZQQMcc8t19fes37Yn/ADxb8l/wpcndGcm3sfhddaLqNm8cyTiSdcMu19qOA2cDC8e348et FVgu7O/E9yVkYDfbvkhmYDOOMHlec4Pzjrjj5hKFaPPRtp/Vz6O06UuWtp+pNHpy38rmXYiFhut1 jDPlQNp+VuAFIIU4HDYwQDWvo8TWsV2kl3L55xb4U5dhuG0Kv3mBUKOSc8Hr0wmnqrf5nTTbvdMq vbW8Z0zUdLnInuZvsnnmZQsQDhtznOF6YwBhju6kHbeW/JvpWtdSdrgzOZpht/0cIJOoVnOUZ9/G OWznIIaJLRX89fQ2U7e7fQZF/bVg58u/EmmgxRQMkzTbc/Iz7DwwA3ZYnrGMnqK6yaDSrm8ha1u1 8gWKwtesrgHCmQku2MscpkKGGGOMsMtztRa9xW/4Y6KctHGT6mrZEXOmy2Us9vHLPGI2YRx7ZAwB ZQrFy2AGX5csCB68Y+uCHR2A02ZZbi3RoHjORsEiyF94yCwfynbIKh9uFOBurLefLbqby0g2mcDq 92todO2ys90UMA82Rg0CMka+aV2hCSSFCgjOAQCMk+Q6jcWcep6lDZ6KyqivZxqtyUH2lW80y8oS mYoQGXcRl2IKEKq+jQjZSW2h59V3cXbqdRb+EBrNzqMt+htLCWG4aZIVYx+eXSTYMNujJBA3gDI2 BdxbC/Nv7Tnjy2+G+j2elw6HDNrkt5qaWzOzFzJLBaRhn7ARhd69VDTSkE81phFLEYunh116/n+R jjpxwuCq4hrW2nq9vxPyn07xDrfh7UzJp+oS28sTYaWCVk24OcZHXkfpX094A/bH+Jfhm7hGtaid V0tm+aK7YrIB5bRfJImGGUYhu7Z5OQCPtcXl9DFw95Wl0fU+DwOZ4jBTVnePVP8ArQ/Sf4SftFeA vi3ph0/SHW18SoGRLa5eNHmLtGxkYFyDiQSMWHGGVctuIHpmsaZfSwQw2sLP5azyySsiKAgQySbH IAGMcliMnccZJJ+KxOGqYOu6VT7z73DYmnjKMa1PZ/gfK/jf4daB4008DVYJGeJiIpE2r5BjwC+4 kMRlwfXbzzzXj4+Ak12y3OoeKDMiQCWNZVV2GOFTYuMZAJOAW5HHIz6+Gx3sqXsqsbqO3l3OCthq /PN4aq4qorT8/wDh9jB1D4XeMI9YGtXEkGpan5axwrM2IYCVAifYAF+TO4Z4yAcGuh8D/CvUNIuD f+J737ffmaSW1gjJKCVmQvI5/iYjpk5JwB1raeMpey/dLXRLy7v5nNRwNf2ylXl7t23532+SsfUu heH1nuBY3RUbPMQorDbhEkk3M2DuzHggqTwRtzuBr1PQrZrnUTLbIk2n2eFg+0P8rAEsCGGSSdxD feHDHrzXh1ZNJ3/q57as2mfJX7ZfjtYvCdr4Zhl3Xeo38l+77QGECDA3AcIXkkEhUZGFXHoPzl8N eEfEfjrWNA8I+FtNmvNf1S+gsLS3iUs0ss8yW8K+xMkioM8fOtfQZa6eEyx1pu0VeTfkv+Ajw8RR q4vNlTgru3KvNuy/OR/fD8IvhtofwZ+Fnw7+E3h8q+keHNHtNKSVE2faHijAlm2jGGkk8yU/7Tn6 13iqeMfd7cY5r/OTMcXPH5hisdU+KrOc36yk5fqf25hqEcNh6WHhpGEYxXySRL5O7A2nd68dageJ fl3gDsCDyB+PH/6q4kzoOe8VeEPC3jPw9faF4p0O1vtKkSSN4bqJHykqlGAOMrkcEjHHFflX+0N/ wRz/AGdfiHbX3iD4ZTTeFPFsoJWG2w1i8jF/maHaRGiBYwEjCltxJfJzX6DwL4hZzwTjU8NJzw0n 79JvRrq12l2a/K58dxdwdlfFeEdLFwSqr4KiXvR+fVd0/wA9T8Lfjz/wTm/ab+BMt/cnwZPrnhty Amo6IrXBVWdvLR4gC5kYBWKxmTYActwcfrn/AMETfgL4/wDgXb/FX4/eMtIutNv/ABRoF74Es9J1 CKSJrnSbrC3zXEL4JSRliEWRw0DNtIZSf6Q428RclzLw6xOPynExdWu4U1Bv34ycouacd9IqWu22 tz8I4W8Os1wvGtPAZtRl9XpxnJ1FflkuVxjZ7Xba93fysffP7SPxn8U/syfsnf8ACH6noXhGP4Z+ DfEC+NNAvGgf+3Nf1p4ntrKO5keXyp445JWuBbxRowjtsl2MbSP+Rv8AwSj/AOCgOgfCf9snwp4p +Ouhya34N1HVLO4azW5VIrS4ttQh1Ow8iNiiBo76ITpGWCSTupYqdzn2+GM9p8Z8OyzfC0XH2PLF XW8oKEpW7rpf1DiXBVeGs0pZLWr3jX55b6RUuaMH5PXbskf2p/tWftYeDv2zv2YPiL8F9B1SxtdY v57ZrO/UmISpDqUN/aSIJtrfvkt40bgESB8dOP5nv26fC/xq/ZbbR/CMGr2OuQ2lraav9vt2M/2U zw+bHvVcHaQ21oyQ4Rtyknax83F5hRxmLpV8dBR1jG66X0Xpc9vhnAYrKcJiMqwOIk/aqc+W7Sko 2dnb9etz3L9kv42eA/j98ALWDwU0EHjSKx1AeItFD/6TYXP2mylZmXgvG5V/LkwAVUr1RgOW8K/D nwdf61dXltrcGo6Il5MHms5I5H3JKyzJnkbkkV42z0ZSGAIKj8vwlTF4XizPsNiKb5+eOvRRV1B3 /vRs49z+lvD6vh45PSVOS5pQUkvPrp5N69j2b9ovx34j8f6JqX9sWgh0y30GPSbS2QeVYeH9GjQx pBGzk+UhVnAxud3kkk+aRy5/CS8sJNX1aa0061eOzlk2wQw5KRxp/q+B6AYAPscmv0bLHNxnia3x T95+my/L8T2OHVRhiK+WYKV6OFjCmm9XKbvKpJvrJt3k+srvqfpL8D/hZb/DzwuNc1tAmp3MQciT gxRcbeuOW4OPQZ7mvz88fJeal4u8Q6leTtPNLfSsZlG4SYY4xjgDGNoBwAR2FcWW4yGIzLEt7pL7 rtL77XPr5VYyn7CL1ik/vul+R9JfsxfC7+1NYHiO7t8WVqfMXI6twVz+vFb37RnjaW98Sw+E9Nn/ ANAsowbhVP35mwcEdDtULj3LDtROf1nN7WuoLX+vmdKfLaPZfmdh+z78RPiJd6naaA7LeaQq5LXe WeJeBwwJJ9gRye9fWPh/4heEPFOo6loum6vDJqVpL5Myqcrn/ZP8Q4PI9D6V5+Lw8aVefsl7mjf9 1s5sRR19pDe13/XcPGXi7Qvh/pr+IL/UDFdQgy2aQS7biSZRmPyivIIbB3/w4znivyS8Q295rWrX ur3szHVJ5muZLjozSsxctn13HOT3Ar0MsnWhh5xcnyt7dG1p+pyvDU8RCUqtNPmXLdrVrt6H1x8A NK+P+uWF82ieDdV8TeFbCDzLhrCyeeewjQgZ+QFnGCW243bUkflY2K+Z/tO+MJ/H118NvhR4OhZ7 i8vDrGp3rRfLpVjCphfzCwyrO84wo53RqCAGXLy/havHP8FxHhKbWFcpubWylCMrr0k7L1Z/NXiB hIZJ9fweHmpW5UktXF1LNKS6WWqfVGroOh6R4e0zTLGzsGW2tfJiiUOu1VwMAseWJPzsM569zxjX tpHEJLxTL/accgXDkh0baFGeCGU9duPyya+x5m23LW+/zPxyeur3C906W1m0mS+tFe+ucyQytIwZ sllyQDgAMrccZAPQYNMN4Jb5YrDToZrS6RWYifZsYHLOoGcDOBjOc/7vzG/3EW5HtrfuTaN4Wubq +vHt4EdGldpJG+aN3Ygvkthgcggn35zgGvV9Kg+ySxzwupkScmQBiAC3GQRxgZzj26VjXnzLlNaE Le99xr3kdvJB9ptyomWKSW2kcAqpGc7yenIJ9cjOeorzG8vpopbaeKYJIFMgdCB5nRT0HUgDoAev TiooR5t1/kaV5W1RySBHuvOcuz4KKWO7oTyegz8vqeSe3X80v2zPjkJr+P4N+HNTWO1V45NbulfK hidwiO0chchmXn5go/hNfYZDRUsQqkldQV/n0/E+Pz3EOng5RTs5u337/hc/NrWtVjntv7D0xY30 6CeRzeCLbNeFsDcxPOMKNq9ue5Nd18DvC9z4s+Kfw80eC3O2fVrdCWBwAHBzx9K+xoL95BN6t/m9 j4DEzioTlFaRT+aS3+Z+12vWt34Y1K80GAtJe79vUliQPvH8B+nSrnh7wld3Ecd/qX+rZiQh4aX3 xwcZ/PJr9wpYeXtOWd9/wPjsXioxo3hu0rLzP3A/Zd8VweIvhdo9ooRb3TF+wzRrxgJ9w491wfzr 6bihDsGzkenTn6V+HZth/q2ZYmjJbTl919D7/K6yxGAoVb7xX+RP9m+RgFz07daqtaqGJyDjue/X /wCtXluNmem9kk9CGZCG8srgjI5+mfSqc7bMGPhumf8AHHelJaWHdW1MS7dt+WctIT8x7kn/AOtW BMcfO/LEZ2gZxz3xTUbiclZdzjtUumm3YfjHPQGsDzT7/wDfS/40OEpbXMXJvU/l1+GXxj+KfjHT fGfiPw94j0uC00Wwa+1Cy1W6ia71SV2fMWn2dtEjnc21PltzHFndLMikY0dP/bXtbeW1tvHvw9kj dwEIs3jk289WYlQp742ZzXi1cig6klg5uM1v2d+2v9dz2qWf/uoRzCnzQktGt1rbX+vkep6L+038 B9eS9sBrxsdbfad96WjiiARl2l5Qpb+H5VYfdIwc19A6ZcrqG/UdE1WKe1eJMSQSbxEu0jdtZjks MY3Y/nXBWo1cN7mMhZvZ9H9x6VKdDEx9rgZ8yW66r5aMupbsIi5RVDFYLgNHvYHbl2UEt2L8ZwTw Dg0+HL3TXTfvTtbbJOqsqYj2Km3twDwvJZgTjg1yTo6Nx/rY6KdQv2H+nwXCT2rE72wYgoPlooZE JVjlskqc54VvSugsIv7RW8i06eIvFEsKeZhVgIEeE3MPmByeFIOAeBjFclSD1VtDrpSukurKOjSw 6Ul7/osk13DFtt5JZWEk28kymMu21QTtY7QeBszkc8baz6kFvxNqmLiSTymnCqB5MnEYRpAx2glo +FAHzbcqFK1Ti5NuS6L7twnNqKUfM5C2uLiVreWB/Ibe2IJ7kLEr7yrxJI43TpuGRMVU7S2AwAFd GZ9Ljud+p6bJJdQtNHBcOixiFykYE3lkDcu4Mc55BXn72eupS6R3OeE4t+9qjtR8RtD+G3h5/Ess 6JHHbyMWlVtsyspVwi7SwOMsuVIJVweQK/K/4uX15+0obz4m6deWNrJbanpnhHQNHneOC8u5Ltbm RpYAcCa1tVt0E8jvmOfU7fGYpl2dGS4aUcTPGVNoaff/AJK9zizzERq4aOAp/FLX7tvvdj478UfD +/0HUfEGgXunTQR6NM9vqplRg0dyj+W8b+hEmV9z9a86u9HdVjuZIgJZRi2gGen94/59q+2pVFNJ rr+v/APgq1Fwk0/6tp+LL3h7VtY8J6ol7o0w+2W8kcxmYuvkOh3DaVII/AnFfqr8M/22vhnqfhuO z+INzfaXqUUSwkx28jxXkbEI6x+Xuw2GYnfsUhP7xrzM3wFTFxjUoJOS6Pqj2skzKjg3OhiXaL1T 7Nd/U9/srvwt438Pxah4OvYbnS2tg0ksRDKzHLHI3cDgDaSR8gyPvA5a6RP5d0fsrwMo/wBSrqrL tQjcWJIBxGvygAYBDDJ4+anB03KFRarf8D6yMo1VGcHdPUxpNGt7ONZp50kkJnIiVSXg2oozhh8/ YAgdQ3fAqlYaYXT5pFSyWULcO6nGcEq2OmSVY44HzHgnApqSSbKaVkmd1ZWWn28UkZu0WMRqwO5Z XG8KrLGOm9QxYrnBK57HHf6bqGntJZRfaY/tMKL8xTcImAYbn52AYYpknqT3YmuarzOLY42T31Py W/aP8V/b/ihqNhoZDaNp0aaRCrMGVDF8smwZICeYZSuOcBc819j/APBIP4KH4r/thaV4t1Cy3+G/ A+nya9h03I18cW9igPQOskn2hf8Ar2PpV8YYz+yOA8zxt7SWHkl/imuVfO8js4Q9pm3E+X4GUVyQ rp37xi3Vaf8A4Af0N/tLat+0ld6rqngX4EaVeJd2N1Bpdxc2emm7vLvUZ2QRwQLyqHcyRhWUs7yY UYALN/ZR+Ivxe1fWfF/w0+MkYm8Q6RBDcQ6h5EkElyr/ACuJUYDDAleQFHJG0FTn+VcZwXluG8O4 5y0/rlo1W76cspRXLbolGSfe/kz+hMHxLiMTxPVy1W9ivdXduzd/m1b0Ps2Zz8xBHsQM18yeLP2u Pgp4N8Vap4Q1fWtQe50+7Wy1G+tNHvLjTtOnKlpI7i9SM20LRhSZQ8g8rI3YLAV+cZRkmPzurUoY CKbgru8oxW9kk5NXk27RiryfRM+vxeNw2CjGWIk1d2Vk353dk7JLdvRdT6FjvrO5JhivY2mKK7Rh wWEbdG29cHGc1BdMZN3GY+mM84z0/UV53LKErSVmbuS6GdcptXaRlGGCMdQev8z7VkyKi7GAwFIK g8Dgjp+nFdFNu1iLq/mfmh/wWJ+EPjX4k/ArwpZ/D3w1rmq+JtF1lby+hsZ4haW+nLZSee88ODJN N5rWwhKspQGdNkhmUx/yq6jY6t4a1O40jWbGex1e2fybm1uYnilt3XhkeN8MhHQggd6/tHwPx+W1 +CMPl1CpH29OVR1IfaXNNtNrs4ta7dD+U/F7BZlS4onmVam/YTjBU5dNIq6v0d7u3zP0I+BX/BR/ 4o/Cnw3r3hbxRph8WadI8UlhNqepzwz6VIqoCYpVVmKsY0dkyMsm7O52J/ar/glp4q+LX/BTqH44 fA/x7p+nWskulyr4M1mVmjht9QWCe4axxLve4Yqqz/I0YTLM+7egHo8e5NgsDkONzF1LNODhHRe9 zxsr+bMeEOLMXDMMOpU3KNKFSdR7twjCTk7eh8neD/h58fP2dIPFniLwJqOo32h6RBf6auraZYPa /wBkXFzdzQRpeBoh9pyzF1EhDAXMSk+ZbJHH/Sl/wRB/YV/ZfvvhNqfjz4iwmH4n65pcUbNqOoxh oHh1O+j1JILd2IEjqbGOSYrvRbwJGYzLJ5nNRy/A1sRTxtWCpQxahzz7qEZyj90np93RH6BxDnGK wPDmGx+R4pvF4duMox3XNKKltraUVK67N9zx3/gpi/wp8LfGP4h/AcaVK3hOPR4boaxaxBY4r2dH lSYGPjykj+zQDdlQ0D4wWIP5ZfA34WfC/WtVmvPDPiPTdbubaRUkgs7iOUwvt3jzADx0GQQOnPev ns2qVMDSrSpu9JK/N0SS6n7B4RZ9RnldeGPqKGIny1FGW+sbPV7tPdb6mn+2l4rn+HWgaL4GttRa PxZ4pmt9IszGAWia4cLNKq5BIihcsWHIJU4AzXzT4R+Fmv8AjvxVp2i6Tpc1ze3NysMcFvA0ktxI 7AJHHGgLOzMQqooJJIABJr5/hmt7XKpZvJfx5ycf8EbRj+Kl87n6Jk2Ohi8xzPE1J2p0vZp32ilG Unf/ALdcWz9Gvit4Usf2WvCmteGIXt77X9KEdrfm1G6L+03wr26uCBIsLko8ikqxikZGddjH8mor i+1/U57u9ZpdQuJ3mkZhku7HczH3JOc/X0NfQYGhyTr1JO93a/R23t5X29D3MtxqzHC0sbGLj7VK XK94qSTipLo1Fq67n2n4ahHwa+FeqeI3UReIruLyrHPysJXGI2H+7zJjuI/evjKGS6tJlnsriWKX G0NFIysoPBGRyAeh9a0wcvbKtOSupSf3KyPRavNv5fcfYfwe+Fdh4k0a+8X+NNXllaCMeSsxkkLo Ml2LMcIiqDkkg5KjaQSVrL8LfDHjHxNcnwhq0U2nB/3kTbldDjnAYAlTwQR6keorjq4ipCpKcY/u 17unR/1+YlU9+cJxso9b3von/mvkfc3gTT7r4NPo8/w38Z31lrcNoonv7PfbtHI4/eQ4BJkjHCsG G1sH5SuK9o8Taj8Bf2i5Z5P2nvA0WjfEO4WQp8UPB1qIrm4mkLPv1jTY1Md5vmlaeaeEI4SGC3ih RQXr6nhHiSOW+0y7H+/hqr96P8rf2l6Pfr18n+R8d8HT4nprNstgqeYRi4uLfuV6f/Pqo9uZaOE/ sy0vbVfl/wDFP4fWnw++I/i/wlYeMINXhs72a3j1GzuhLFeQxyEZiKko5KnIMbMhGMOwwT5XrAst SNvAty0ZK/vEjZUMcexism/k72O5ScEbdo7V62Jp0qOLnGi7wTdn3XRn8rVqcqcpwlFxd9no0+qd 9U11XQy2ljkbfqtwgtQQLeOOQBQwXcFySSV5Cgeq1paX4VtbuZHuYHWJm+zFyVztU/Mq5+96fhx6 1zylypsxUeeVr6nsEU8EVpJZyRyLfGORVCKBjAyB25x9c4rBFo8Exn83Yz5KGINkN824kZx0XJz7 deK4dW3dbna7WS6f8MLLLGNMu4JVEtrGuI5gNu2MdeO/IK4PBrg79GnlS5GBYphC6uRl+fxOcdBx yDnmuzCxb91b/wBaHFiZK1jjPHNlr1j8K/i3450KSKOXQtFudS2lD98FUQ4z/eYHHTgmv5std1ef Wr6eaVnM0jtJPLI5d53OSWZj3Oa/QckoqnhHPvK33JNfmfnvEdVvERo9Er/eZtrELhhEMhQdrY6t 7f5/rX1n+y062fx2+F1msam9e/LRRA4C7I2br2xjr9a+gwcefGUIPrOP5o+SxkuTB15f3Zfkfsf8 QbC4N/Y+KIW/0xJPLlcHqRyufbqK6/TXtr6wgnMgM/lqYwAPl77civ3xR/frS11+Wh+f1v8Ad6dR dLr/ACPrb9lbxn/wj3xAGiXKrDp2pxrbgE5/fryh9AT8w/EV+rMMKgggcjA69/8AP+fT8g43wqo5 3KqlpUjF/d7r/I+84Tr+0yz2Td3CTX36/qWDE2eFzjsR0/z/AIVXlgyM9iR0JH6fj+tfFuNrM+rT 6oyJyNrbFzzyf8Pyrn7qVCxjU9Mcdj/n1ocb7hzaamLNIqMUTJk7dODkfkRWBqkn2UCJRmdwdxx0 9QP1rWMEkzCU7nET8tkrjr16ZqttPqv5GjkfQxb1bsfgJ4u/ZZ0K9DjVfBSGVuC6od4IOSF7jofu 4Jr5/wDFP7HumSC3bS9RuLWdAQkUwJVBnj7wJPU9xyelfQ43KqtG3u2/I8ehiadaLcJXR84/E/8A ZQ8feH44LjTLSK9gYnDQkeY23OSwPA/Fskdq8o8Oa78Y/g2TdaRdajYQF8OjCQQPt5IBBxkjqVIO O9eHXwsa1GVHEQunp/wx30MTVwmI9thptNf1r3Ppjwh/wUC8TaatnY+MfBlteQhgZp4OJOFxwhwD 0UfM/AH4V9J6D+2p8F/E8lhZXd9d6VMSWU3QIWJ8ADe6gRjhSuS3APXNfMVsjr4eXNhnzw7Pdenc +ww3EGDxUOXFL2VTRKS2fr2+Z9LaJ4w0PxWI9S0XWre7yRta0umf7dlRnIJGSSpYkblGDgmtST7P Y3v9oGGVJRLiRcfPL12yPwVON7YDA5yBle/j+y5nZ/NdfuPZblTSfTe6H3E02rubqOykFzHF5CPH IC3y8Ev1ZVBd85AzkDnbXJ3mreX9q+1LPHKVRIid3lnayyMW3fecFUBGNuC+MYxRTpXnbsROq2rv rc5UTHTZZ5V3T3iRAqZEV03OZSHVHBWMqoDDJb73IHOVsUfxDd2elW43SQXSxRyk4EEKSMU3fK2e IkPKgFiOc4VtqjSXPdaGVOLk+S17nX6v8JZvEeh+IvBuoaNLcXM2nXa2EV1IJBp880arCRgKrENs KjcMsEycYr4Q8Q/sp/FH4ea1osOiOst4lo1xNe2bMYNIl3yxyBmwNxiSNn+UE5faMnAq8tzGjDno 1ZWUtfJaO/zfQzzTLa1TkxNFax0873X4I8VkvrpfDPhvwv4m0GR/B665Nr+r3GxFa8kRIg9ulw8Z ceXEVZlZ5FzPGdgIy/NeINJ8L+JbLxP4y0+GK18T6tqsGk+GdBjYxy2lkq4N1LtiEEhCoqPh4syz 7wm3IH0ceaEnKm9G9fm1f7oo+bqKnVhy1FaSWnyVkvnKVzl/GHwO1zw5qfxA0uygk1HRPCH2ceJt Qs7S7WLTriVkjaG486KN4mjuHNs7OgQzDajOGRn8Vu9KnUxXDW7Lcy8W8BH+rU85P4ck/hXbSrKp FPrpp6q/5HlV8O6UnHprr3s7fi7nVeBfHXjj4U6zJf8AhbU3Qqd1+khLQzAclXUEDp1xz2zzg/qN 8K/j14J+OGmf2VqJj0nxoyF5LaTYBc4UgyLuBVlU44wAAOQuRXm5rg/bRWJpfEt13X/APYybHum/ qdZ6P4X+h6/f6RPFf+bdzlogkzMr224KN6Idx4wRnjPAOMZwRUej6TZWt/PHcSER/KPNeP7gG4ur IflLAKu0ZG07+ozj5pytBpL+r/gfVfFo2X7a3hg899RmgMMi5tZvl/1m9CY3BAI4RlLLnAdSGAVq Xx5qK/DD4eeKfGrXSjWdOtwlvatJKfNlkjCEyD/lqwIXc7/xCM8nLNDTqVadNfaaX36fh+Y2406U 6r+ymz8U5J5Z7i81KdsuWZ2Z+eTn7xPOcE/lX9UH/BFv4OP8Of2YdS+LF3Z7fEPjfWpL+OT+9p9k XtrUH0ImN4/uHSvkvHTHfUuBKmFg7e3q0qfyV6j/APSEfV+D2E9vnyrzXwQqz+b5Ka/9Kl+J+4fj 348a/H8Gfiv4R8GeB7SP4na7qOn6zo3ieJiJtB1K2jS3NwFxmQtEsgKho93myKxKsRXy94A8EHRv EXifxvqKyjXdSjW2AubjzpIraOSV41cqFjV9rojLEiR4hQhAxdm/Bs44yy3FcC0Mpo/7zKnTpSSW yhJSlJvzskv+AfrOUcLYzA8SVcbObdFSc4t76wUFFemsntq/ma/xK+Ifhv4XeEdX8deMbloPDVgY zdzrGzi2SSRIQ74+7GrSZdzhUQM7EKpNfIPhnT9J8N/GPxd8CdUvLHXvhT8SINe8Tw2DnzZbCd5I 5NVimIOWgmkvlYb/AJldyqsV2pD8fkNHFLL8XNRajNSnTmvsVcLFVteydOUkr9ZJq7R9fmE6csRS TavGylF9YVbx+/mS+5p7mF48+Gdr8RP2nbPQvhn4gv8AwxqHhvw6mp+K9c0aYM0tzPC9joVjLDIz RSGGFLq8Mcke0BLZv+W26usi+P3ivwboXxT1658Oz+JPhX8P7CWxv/ESXcKap4i1KwW3OpSR2wWO BYYd90skhk4lspkVeN1e/Vw1LO8JgcuxvLTr0qNL9/ZtylWnajTnbRxVKcZOVnJKDSukkebSnUwd WviKTcqc5yfJdWioR9+Uezc09LpXd9Hc+sdP1KDWtL0/VLEFra5gjuYzyPkddw+nBFUrkEuMA8H5 dvQkf5zXwPI6VSVOW8W19x9AndXEvNRv7ua7nnm3zzZ3ljk/MQSf0618qfGr9lb4G/HiOdfiH4Et LnUZMsL+BPJuY2dt7ssqjO5m+83UjjNe5kOdZjw9j4ZjlVZ06ke2zXZrqn1R5ma5Xgc3wc8BmFFT pS6Pp5rs10sfj58Y/wDgj74hs9Qa5+C3jq2udPmkQNZayfKMQJYsRKob5VBCquGY4yT2r9eP2TPh NF+yd8OPA/hHwZqbp4l0uQajPq0C+XJc6oxDyXA9NrKiIeSEiiByVzX61xv4nLjDhnCZXGg6dbn5 q38r5VaPL1s22/Ky+X51wn4cUeGc8xmPdVVaE4OFOLWqU37yl0ei5fNN38/jD9pz/gqh4s/Zx1r4 2/s0+AdPmk8M3+uWGta3pN1Y2qWmsX9vMuoQSXc4/wBM2q5jzBDJHGwRSeWdj88/8E4f+Cmut/D/ AOMuoaf8cPiL/Z3hTU4dUvTqMyN5Vtqt09jdPJ5aARQRvcaZYvtVUjXy3AB34P7vlWXYrMeCsvnX SdT2FOUVHzin23dz8mzLOMFl3FuLwtCPLT9tOM5Pa6fKn12svI/aGf8A4Ke/si6qPGmn/GrXPCev Wmt291ot7q9tPFcT6Pp06hYrq3RYp5TcWrkzKUhnLruRIDII8flP+2P8AvG/7Bvx+8DfFz4X+Ior fT9UMGpaLrFl5V3o2v6ZcNGyO8tvK8EtrIskZMiTOnz5SUEb6+WxGXVqdWhgcbTboYpVKM4u6bvC 6euzSTs+jSPvcnzHCzdZ06/v0/Z1qclqouMuWcdN01JNrezbW2n6efsn/BjSP+CsX7QV58cfGkMm hH4e6PpDaL4WtdSMi3H2pntZpFQJHI5jn0y433QRFmj1AW5RHtJBX1L8VP2WPF37HniLwwmsR2ul +JdXtri404LdILiIxJCZlRgc5U3CxLICNzo+3G3NeHHJcRgMHQy/Cybo4WnCF7WvJtylJ+spN+S6 vc/RuE+OMtyfM8x4eztuMsRKUtfevGMEku/vU4xXnK6srn5N/G74meKvHOgjwRJoKWltDqC3kkLq WuUmjR41V3UkYIkJIHGVQjpms34J/Bvibxb4pRYdHtMyO0p2KxXOQSeNoGSx6AA5PSu/EVZYPBrD 3u0uVW89fzbP2rhbGQxuTLN9lWnOWr299xivlGMb+hgfFT4kaV8RDZNoMvmaDbvusZYgBBPFIiFW 39GdgolAB+WOWDKqzOK4vwD4Lu/FuuWGn2NuXkkkC7VBOMnpjt9PrU0YVcHhnCvHlcb6Pfy+/wDU 9XJ8xo5rgaeYUJJ05OVn0cYykr387XPr34pa7D8Pvh+PCOjSBbrUIhZyED/lgu1pCMerAD3BPpXi fwV8N6h4g8aaWLG5khXzVZpkYqUUYJOV69OnfisKDbwT5+t/vb/zO+DUYVKzW92/kv8AJHtFl+03 Z3XxJ8S+EpNG87wDpSGzOtRsfNlvEJMqRoBiREXAPQhgeuc133iH47+CPDwmisJZLu5YsieXC/lq wz94kc9umc5HIzmu6eT1ueiob2Tb7X1t6238z8cfidkFPDY6VeXJVpTnGNPVupZ+64u1km97vTfU +Q9UuW1a7e+k8hbxTJdSCRmRN25wwJP3SOp6fhWNqKRm7W8t8PHMmyOGMFsJtyNy4wcljg8ZyT1B r6dRsoxXQ/mHF154qtWxNR+9OTk/WTbf4s6aw8Nxyi41zWUhju4xHMSZduSwAAxnIxkkjjk/Su80 bTAYWuJtQ2wbWQ2qonlp8xKsrdVOPy55rGtNNPS9hU4RT7PqQPZPFfie3mea3aMyqCTkEuARnocq 3I9hiqE8tqlnGqIEWRtkgck7V6tjIyvHv2rGN5SVn/X+Rcla9zlNQvJJbaG0SECILuMpIKIoUnJK nAwfT1rBmvY1jNzDKhjC71LDCnoM5xwScHvjrXrYWndpHm4maSfl+R6p8KoPD3xL0bxv8OtRuQdP 8V6BeaKrOy7RK8bLEeegDbevOea/lL8ceE9U8E+KvEXhjVrV4r3T72ayn3L0kRip69eV4Ffb5FUV TL6kVvGp/wClJL/21nwHEMHHFxqd0vyC1tINDs/t00TNdS8W8J5Y56ZA7+v1r60/Yw+EfxK1L45e A/iBfeEr5PDltLNNc308BjiRWglRdpcDcNzKOB/9b6nJ8LXxeYUFQg5NTi3bok1dvsfH5nVp0sHV U5JOUWl5trSx+3+qaOurWN5p4wXmBQcYwf4Tn1z39zXlvgS5EFzeeH9QH+kIx2KPlII4I7Z6/nX7 lGUuX2rWzt8mfDzSdCdNP4dT22xFxpl3pNxp8hE8M6zqyp9zawZTk98jiv2i+Gfim08a+DNB8SWr AmeEGUDnbIOGU+mCCK+E8RMJ7uFxajs3F/NXX5M9/gzE8tavhXu0pfdo/wAz0AoUTbgflnHSsm8l CgqMbOpPpX5Va5+hp6WexytzPuwDxjgYx27fzrn7mSOFmKt8+T0yfQdKqMenQylJbIxhJDBuZstP 06D5f84rmr0kyTM5y/fIPH+eK2skmvmZ37mBcR7eSB82cHHX6/lVDy1/ur/3x/8AXpWsZuTWiZ81 ra2zXtyLn92pl3F2T7zbTvJGOAc9OnFc/rPhPQdQubRf7MjKsH3TFF+7n7x28eo6V+y1MNCdo1Fp b/hj87oVXTd4StY5zxX8C/Cgit4bBpVvmGcgIULHlVPPBwwJ47j1rxPW/wBna4uxPZSWtpeRlQjM UBfGf72OM+1eBUyONe3JG3M9j2KeaqNlV+8+UfiL+xJ8PtTS5lfws1lfH5s2/Az1JIGCTw2CSR17 18deL/2CdRiLHwlr4knA4t7lAHJOOOPlQD6t+NfM4/KKuGqyjDp0PWoYiNempp6Hz3qXwQ+P3wiv pdQ0i3voRGVPn6dKxRzjptGPM7j7pHXtXTaV+2J+0B4NgfStXmt7qWN1LHUrE+cADnaACFXjj7nu fWvlcbllHEy/excZ91o/+Ce9gc4xmAj7OL5oP7MtV8u39aH0P4J/b48K6kLex8e+EJ9PuAoi+2Wb CRcEnc8mBnJyflWPGDxX134H+LPwI+JLQp4e8ZWxv2JlS2uZAkyELtY+X1RcZGWCg96+YxuBx2B9 9R9pBdVul5o+wy/MMuzNqHN7Oq/svb5M+hLDwzYyTQ3kM4m0/ck2I5Qyu6ncjZ+bJBwQxzzzW2um /ZTPPZxxi8ZNsUcUCiMySMu4CMDG3cxcoAANo4+XB+bqV3UbT+H+tz6SGFjSjzRWv9dTZsjrpvdD ewgthawiS4u53V2nLnhFG3jBPlA9ACnXmul0F9D0LTNW1HVN0Vhdx2odGkJEmFlUFgMghxImF6fJ 7cYzs42p9f8APT+vM1ir6VNEvx0PL/il8Jfhj42tNMs/FFisllYyfaUtY5DDEHmkRbg7UHJk2IGL E8RDJwmK+AviF+wxremWMmp+EtXTVdW+0RwW8ES7fLQiQq3OeZDIpU8DEZznjPu5Xm06KVLEax2v 211b7nzua5NGs5VsMveXTvaySR8jeK/hl8RPAB1fwfdWd3Hozz7NSMSsIrwRyoVBYcOjPGj7T8u6 NSRlRTdS8Y+HvEF94z8d+Nfh9af8JHeaXFpekWNhDJaWaTLZGzE7RRurRyF/L1BmQlHubdkaIxXD hfqYONWKrUZb/drb9EfJT56TdGvDRfonb8Wc/N8L/DusXek+GPDmtSLa22mDVPEVzflCsckbEytA YxvniEWLzZsWUKXiKM0WW83n+Hnimy07R/Flvp80Emo3M0Wl3ELAeV9lEcsx3A5Ro45YpznB2zRP 90g1vDEJvlkrX/W/6IwqYOSalTd7bfKy/wDSmfbvwv8A2idW0u61X4f/ABx0qd2tZRpS6i9viWzm WXDxPCAoDK7OjEcc/dXlj9af2TdXUYksv31r5fmWsgKiL5SpErLjABEittIBJIJ9T89j8MqNV1Iv 3Jeez6/mfT5fiHiKVqi96Oj/AK8yTT7PV3m0W3GmtFcJ5qmWNCVwu8GQoBhclowq7mJ3HHfHzJ+2 b4jk0LwF4T8MmOX+1NXPnyyNMSZLS3YhN+TkkyOCOSPkxniuXCxjPH0ILe9/ktf0N8Y3DAV5NdLf fofnlo3hfXPFmqeG/CfhzTnudd1m+i06zhiB3TzTSJHHGB6kuuP9+v73Pht8OtF+Ffw48CfC7QHV 9I8O6PZaNBMq7RcLbwpEZSOPmcoZG75cnrX4x9IrH2wuT5an8U6tRr/CoxX/AKVI/XfBrASpU8bi 5xt7lOKfq5Tl+cTopdqjHRDn14AH+HP4UkMJxH2A4zgce+a/lp3P3NX6kOoaXY6tZz2GoW8c1nMC ksUi7ldD/eBryvwH8B/hB8JrrUNS+HHw70zR7+6hW2uJ7K1CySQq8kqxl+SE8yR325A3MTjNd+Gz XMMJg6+XYevKNCtbninpK211/XYxq4TD1qtPEVKac4X5W1tfseVQeCfiD8Jfhb8S9R8JImt/HbxN rE+otfMuYBqF/OlpaSOJTn7Fp1qbcGMnJgsWCjc4WvEtP/Z88Laf4n0L9mNPEetf8Kpi8Hz6xq2m /bjv8T3NxexxSm8m5lKv5btLGrqkn2hw4YSHP3WBz+kqeKxmHpxc5TlUUJK/JHD04ww3ZWj7SWl7 NwV1bfw62Xyc6dKrJqKiotrTmc5N1Pv5V5pSdne592GGOFI4YVVIlUKiqMBQBgAAcAAcYFZt9PbW cU91d3CRWqI0sssrqqRqoJLMxwFUAEkkgAdTXwkOerU01lJ/e3/wT3G1GN3okeYfDXxyfiL4N0Xx w+lS2NrqavdWEM6ssr2TyMbSZ1bBRpYPKlKHlPM2nJBJ1bDX9E1uFLrRtWgubdlLK8EqupCsyEjB II3Ky59R7V62JwNTC4rE0I+/GlNwclto2l99nbU5qdWNSFOo9HJJ2e/9K5VuW5bGevB/n/n2rLkf 7wGRjK885A/PrTgtBt2Z+c37UX/BP/4c/H/W9c8cW2q3ek/EC6CmS9VzLHcMkaxoHRuigRgZBzgA DAAA/F/4yfsI/tAfB6ebU28PNrfh9HKpfaWHlZMnCM8XLBmOSFXecAk4r+nfDTxOoTw+H4dz2ShK CUKdTZNJWUZdnbRPZn8/eIPhzWlWr59kkXJybnUp9bt3co9+7j93Y7b/AIJ8fs/X/wAYvjrp+ta9 p0zeDPDN0l3dGTKx3F+GAtoMsOfnHmupBG2Eq2N4r+n341fFT4T+Jv2MPDn7N/j7TNHtvFk3iy4v /Bt7NLbwzG1mlln1Ky3y4O0F0lVmbCoQhKxxKDyce53isT4h5dleAblCl7JSUe7bqTlp/LDfyudH BnD/ALLgeWb1X7OsqsqsXLTmhFOlyPyk27f3rM8o+CHin9jz9m/9rzwvqP7J3x8v0n1PwKuk2cOs RfYZ3u73SL6TU42EbABbe8i0rykJZHljBV5kgWRv0T/aC+Knwa/bM8feEvEn7RfxSu/C8ei6be6Z aX4SNLeCS4R5oJXeVkjaKO5ZFldmjUR8tIixu8f3GZUKtDGKjhG3CcY81+ru1e33/fqcdfMaucVY Z5mFGP1unBwXLZXtG/vNbtp2vrolY/nx/aQ8DftC/sAftNT6J8VrVtc8OX8vkyRXbM32lCfkltpZ AhYjcMKwXOApVTxXzB+2h+2Z4m8TXlv8KPDFjcaT8P5LaKW+lSMRtqiMqv5ZOciNBncuV3HIYbcZ 4Mnyp5zn2AxsmlRUZe0pvpUpO1l3T3f+F9z7nMuO8y4b4Fx+X4F80JtexqL7MK65m9Nmruz6Nrqe pfsj/D+68W/BTSNR0Q+dLNqt4NSQbd1tdK4QK6jlD5C27gN2YY61+xHw68AfDD4J/Bu+8V65qYn+ KN85VbfYwh0DT4wrPM7jHmXM7nyooV3CNEkZsvND5fmZ9ilLNcXQm/e9pPT0do/o/ReZ+58JTqU+ AOG6GWWl7WlQUnp7sORTqvzcmnT7qU79GfnX4q17WPiH4wub2SF/KkcRW8OM+TEGO1eOp5ySOpLH Ar2DxRd3nwX+HVloGiERfE3xSzafpbNhfsabVaa4Y9hEjbs4OHeMEYzjClRVWthsEtrpv/DHV/kf S8UZpDJeHMdjpOzjCXL5ytaK+cml8zzXwlo2leEPD9roOluhlttu+eRcs7KxBk3A5ySXJHuOtTSv LbPMkCxPaZDsicjHPCknHBPJ9h3HH1qd5N9z+G6s5Sk5N3bevz3Kcg0q5tneJ1ndpHAiDZADKvzZ x659TnHatyxSzsIrS8jvvNhnGx5oxwig7e/3ef1X06TK9r2Mo8vNzIj1CCPUoc7pHijVQuxVYNIG VQDkjb0JPt6kjFy21KWO4gnWeRkLqkkbw4J6kHHUNwox6VlNaWS2Lj7snJM3lvZdUne0VYUtoIxu WPOQXIwD3zxkn2Bx2rDFvZ+beRRygKpbI8xSAWO5lcnPOCeR6ilTi43aY5yu9zltTaOOWaNPLUBm UIv+rKYOWJOM5IJPHrXkXxD8SR6X4SvYWuNlzMfskKg/fLjDYB/2Axz24r38upttNrb/AIc8TG1F FMxvhP4mk0m2ihSci5tZI5oxvB2gY5Hfjg+vWvB/+Cl3wX8OaZd+F/2pfD+D4M8UKq31tFGALfWY 1/fAnAxv5bBHrzXrZLNwx1bDdJpteqaf5Nnz2fUVUwVKq947/wBfefkv4K+J8vhz4h+F/GFxp0Nz a2F7FM9tIiuhiDYZQp4+6T+ODX9M2g6laa7pGlavpcsR028topreSE5TynUMu3HGMHp71+18DVly 4vCLR+7Lza1TX5fefkHEUbV6FV7NNL1v/kzobdJ8tMo4jHQ98kY/n+teSeM9Kk0DxDZeJ4EH2eTP mfL1cYDfpzn1NfpEYt0pw8vxX/DnztJQdR07/Emj1/zBe6elxaTBoXjGMnOVJPpj3/Gvtz9jzxm8 N5rXgG9ud1o4F1ZsW+XcBiRRn8Djv8x+nhcXYX65w7WmvihaX3NX/Bs6OHq31XOqKe0rxfzvb8bH 3ZqF3HDkJg85PPfp1NchczlyVAwTxwen+etfhyi1qfrMpWV0zAnkBVkjBJ56df07VSitzLIzn7oO 4n/PSqUehi5aGVqAjaRlh4RegA69+fWueniC7iykA+wzz19P89KrlbbsCb9TBvF2FTu3HoFHQD3P Tn/Gqe4/8+sf/fYqeVPVESdno7HiGr6fcNbvvvLVo2i89QnzHaeg44Gcnn/GqGnLa3rSiYNFMnyA Z2oEXHBPPJ4HpkGv21NuHLJXsfm8VGzadmR6jd2t95lrLd/6esylYyjAodoViWI4A449x6U3UzdW /n2qwxqfOkfPmnds52jOfYHgdW61Sp3kvZ6f0hyurGe8LFDJqtkhJjjJ8yP5tqqCpCnAyeOvoT3r nNX8G+HNV8y6WyQyZ3E7RwSQCxwO5IG3I9q5cTQjVf7xX/M6KGIlTdoOx51qvwv0iHTL7VdRumtY EyqlSHDHJIHtk4APQV86eKf2ZPBfi61kvNS0fTr2ykK7AiKjF2G4ccBmAPfIHtXzmOyKNWTdPVI9 3DZi3D94up8W/EL9gLwrcSXkmgPd2MmXYITvQnnvggD6LXx/4y/Ys+KPh7/SdGEeoW+CV8rcsn4K efbJx0r4/E5biMPdOOiPUhVhOzgzI8OfGL9pT4G3H2Zr6/NnGQGttRR54SMDClwckAdFD4HPAr6/ +Hf/AAUksDKtr8SPBksSkBGuLCQPk4+ZmU7do5+6obsK+KzPh6liW6uF9yfVdH/kfZ5PxVWwqjh8 euen/N1X+f5+p9r+E/2tP2dvE01smm/Em2tZ5o1Bjun+zu3IIXY2GJyAcEDoDXvlq/h7xGIL3Tr2 2vAmNkkcwO0DbgEA5AwB6Zzivi62ExeDn+/puL/A++oYvA4+CeFqKX5pnQ21gq2kUd1JNMvKyCRt wZcHAAxnhjnGe/XjFclrHiuXS5HvtK0SAFmUTbU+d5QibHPOMJ8vrkFhnOBWcIc77DqS9lG7V2Yv iWHQfGenaxpuowXM09zcZLTwouxSAqqvB4BaRwCejIoFeT+K/wBk34beO5hqem2cdpBbxCC3jh+7 5xiYRbsd/mjJxn7vOc4rvwmPr4BaO8ddPVJHm4vLsPmCba97vs9Lv9T5M8SfsS+J7S7urHwzrcF0 ZrsR3czgqlsBsfqc8BCOh5wa8jufhf8AGPwDcx+KptKm+w6Y4treOZA8MzyQtDIrQnKsjxRRwy5H zoUQ5AwPqKGYYTFpWdpPp110R8pXy7GYKTla8d7+mv5h4Yu/ix4Qh8DeDdP0VDc22tWHjZElsUmk tLmy01zHMBICuyWBlkmjKkSNaxFhlDnv/CHxY+L2gya34sj8Gi88DXnie+eWCOExxJK8n2ySGHbx GFS4RhHjG04UruJDq0aFbSUrJ7fN6fkaUa1ek/dp6p6/JK/4n6C2Xg3UNMbxLf3El0moCUhYXuFa BLj7vQELKd0m0Hj+8Ogr8qP27oI0+L3h7T11ITSWvh6xtpkH3LSZDIkqjgfecGXjgLIvuB5WVWeZ xa1Si7Pytv8A13PSzSnJZdKD0bktPnsdX/wTAs/CPiz9sj4Sxa9ES9hJd6ppkLN0vbS3lubdz6hD ACB13BcDqR/X5Z6k06bHysxOBjHA+tfzZ9ICVZ8U4SjUfuxoJx/7enO7/D8D+ifDWphq3DUK+G+1 Kz9YwjH9PxOiyZJGCc7Rhccfjz/nmpY4MYXGM9fy6fSvwPyP0ZPUcI8KWLAA9fbGP1/wpTbo4z5Y 2YwTn/GpvqO+pB9jBABGCOv/AOr8f1FYl9Y2cXn3n2KIalKVjafyh5gjTf8AJvxnbmTdtzjPOK1h Jpuz30FOzjY564QZYEcjJ+g4z/8Ar+lfJ37VniWGw8H+FPA+p/aovDXinWYdI1+/gt5ZI7LSAjz3 iSMisEW4SJbJmbaFS7kfcPLGfouGqTrZ1hIq14y5km7JygnOMbtr4nFRXqebmM1DB1W72tZ76Juz fyTv8ir8QfiRpus/Djw/pnwg8RW82teLZV0bQr/TZE22UTxs1zex7Pui2tkllRgCvmi3Q/60GuF8 F+DfCHh/476bpHw5sVs7Hw34LXStZityDBsmnibSbdsNkSQxwajMVK5C3qP/AMtsn6nCQxGX5Xis PiYtSnGtKrF72TVGlzecazk12+ZwzdOviqU4WaTiovfdOTt6wsfToMLsxc5AB4HfA9vfH5GuI8We LfC3hJ9Ii8Ta9aWDahdCyshdTLH9on2PII03dW2IzfRTXzeFoV8RWVChBym72S1bsm3+CO+tOFOD nUkkl1fnovxK4vYLqKKW2kSWzb5g0bAq3vkf54rIvDHhMk5xkZ4JrtpxlCVtmvvJtc5qKx0/Sojb 6ZaQW8ZO9kgiSNdx6khRgnoM9eB6V8Zft7/sxeLf2ifB3wz1PwBr2nW93oMd6JLG8Zo3vJZzb7iZ BlVG2IlRtJJb3zX2XCGeUsk4nwOb49SnCMpKXV2lCUb672ueBxVkmIz3h3FZTgpKE5qLj2vGSlby vY/n48ceBPij8MtXig8b6Bf6XqcbgRzT7gNwIKbJBkZBUMMHI9q+yP2Jrz4yfHf406P4J1f4ja3P 8PLb/iaeI1utQluC1lEy/uVd2LJ5zssJ2EMFkdh90mv6oz3M8uXDGMz3DOM4wpSlBrvb3V5XlZNH 87ZBl+cYbijC5HiVKE51YxnF/wAv2nrv7t2mj+tBL79lr9pL9nTXf2X/ANp7UvP1bwrY3+rfDS9v po/tEdnDaOsmixTMN7QwsVe2jZjsR47eNokhgQfjF4s/YHi+En7O1j8Xf2kNGn1T4S+MfCPivxD4 Y1zSNUsvt1lq+lWssNlLMJg7mB9Uu7GC5hdo2lTDq7SRhJvzHwnzbNM3r1aeYQa5J06jktOZSSjN rzlKL5u8mz9D4np4Ph2jmWV1qXNSrxqQw63Sbi6iTtt7OTkop7RUfI/Of9lzV/in4A8QJrPwx8TT wtLC13d6e8fm2tyFUFmlhJwSMAlwVbC4zjIP6TeAfi14k+IujeMvEfxj8WWNl4c0mK0uHuGK2tlZ RPL5GWUkks8k0ChixxyBjdz9TxDgqOPx1fHUKLda2kY/aa2dusrL59ro/d+EMMuEOEKGHxGMc6ND 2cry3hCc1eP+FXb7rVbaH0n8LNT+CF7ouseOfDfjDStW07SU8++ubS5jmjslYSFTLtzgHypSueux jzg182weIb74i+KtW+LniCL/AEu/URaJZy4P2DS4yTF16SSkmZgDjL9fmwPByalifrdepiacouMU tdLOTu/wWvqfN+L/ABNhsRgcLlWCqqcZtTk4u65UrxV/NtS+SOok0+6ld5fPP2Y4jZMrgENnHTjg scdPl6VBZQCG4SGJ4EtgHjkTeVIUKTsUdSefvdOOlfScy3t6f5n8+SVnuZYi+xTWZSySH5uFPVt2 cYBwdoIOPXGfetkWMcEJW3gInlkMyrFt5Xli4J424HIpyu2ZpK7stS/bH7BpsLQl3vJQJGLqQHcD JGDwNwyQazb+81D7VeW8UrGSR1kCIfuKd21mOCQQuV9Dj1rGybbe5d2laI60jDXV9awNIqyxCbe0 mZFO4pwVPBOD7g4rPa5FtFLHbzIZoyZZIWI2xkA5yerfLzkn09q0haUtfmZz92N0+5yk0/2owSm2 aO2k3MSyswYAlcAnpnOSPQV84ftEzNptl4U+zTgwSXckhwf7qqFGT9c/hX0uWwVpJdmfPY6d/eXr Y808MazcpFHfwf66Nw/zNuDgY+9jrX3h8P8ATPC37TXww8d/sv8AiKaNbbxRam40KR1yNL16BC0O 0nHEuAnUA8dc1rh6n1bH0MS9lKz9Ho/wbObEwVfL6tJ9rr5H80HjTwNqXw88V+IPCviOxkg17T7q SyvLeUEPBJGSrKR9R/Wv2D/4J1/Fb/hMPAOr/CrUp1Ov6CftNk7sC09k7Z2gdTsPHHYrX6xwnXeF z2FKbsp80H911+KR+R8RUebAe1S1pyT/AEf5n6aQQuxVymZRH8wzjgdOnQ1V8SeH49b0S902VA10 B51uM8K65JH49K/ZaF+ZJ7bfhY+Fc+ScZJf8McL8MfOna80+/iO+EsY1Dfwkn8sf19q9/wBI1e+8 F6zpPiSwBFxbzrMMHAKHG9ffK5H41E6CxWErYSXVST+aZNWo8Li4149GmvzP010bXbfxFpWn6tp0 vmWdxEJo2JzkMKlkXawTPHrx/n/9dfzzUpOlUnTktYtp+q0P1+FVVKcJxejSf3mWYSWwCRz0A5Jx 29O9RO5RPLHL4+bGeB7/AJVNuo07vUybiPaXKn5uhOeTkfrWHcxIf3koGAOACPmxznn61NuhonpY wJofO3zMcYzg5PY9B+FU8J/z0P8A30f8KTRF762ueIR200emD5lAVBCuMsehYbgwyDwTtXHb0rIW K8ttPtipyhbKs4UgFR8uecE+oPHPTOa/aYPW8kfm/RnTLoVvDolvfJpsUr7wDu67gNpzgkZLFcY/ u96xbrTbO2Q6pPbMkrnEYdmO/bndnjHBBzn6CiM3Jtxls7LyG3KNrjobK58QIs7yukW7a7yAYZiF XucYG7BAPaoYbazhnTTYYwPK3l3XnaRgAHtnqT9fpTaaTi5a9Sk3daHzp8Q9ct9R1JNKsr7NhasY mYjiZlJ3Nj0BP+e3n0ltcQtE0V2cAA/K5BB5BAI/z1rSNJKjzxlq/wBT3sPHkhGE1/w7NCz8Tapb PJFIVltcHImjyMdTj+Xeukt7rwVqiufEOjYlO4KYhx0GBxz97OTgZrirYKnXpWnG7CVOVOTqUHZv p3MHU/gt4N8QWtyyTWtxECd8cyKQowTgEg4P6+tfLfj/APYN8Ca1apef8IqIZpMn7RZSFWJyRkjk t19R0xXyuP4d5k50ld+R10MwjbkrKzR8c+Mv+CduswTPJ4R1OVGJIEF2hBJ5xz2GeOv4V4ofgn+0 /wDA+5TU/CdxqEAifzC2n3JaIvtPWL7r8Z5KnGK+NzDK61Kn7PGUrwf9fL1PdwuJqUqqr4Go1Jaq z/q/oepeHv29/wBoX4e3U3h7x54Tiv7q2bbLFdRyW9wrfxCQ4Y59tox6V9I+B/8AgpB8Mdektk8e eEb3TLlgA1xGomij/wC+SXP/AHzziviMTw3yp1cBU0/lf+Z9rguLIyapZlTs9uZfqj6w8P8A7R37 PfiqS2TRfiNpbahcMGWGeVI5Ax5+71z+vAr1XTr+zxdS6RPbtZ3HmMUiuFcIwTggDOBlc47EkdyR 85VwmIoSca8XFvoz6uniqGIgp4ecZJdn+An9qabp0+pXdrbg6jdXyt5cqttD5jiLBPTanHbAOOOv V3dvDDPdrrCW9zvkQHKK4ClmKLt9hzn0XPHfmalB82z6eW39XNYuEotNXRHqXhrwpaxS6pLp1u+s Xy+UzMM/ejCqjNwQpRBn6jr0q+1t4X0yztbTS9JtoLfDXYtPIGxMAIz7cHDngZ6naOeKPb15JRc3 bb7tivZUIt2hr/nv951mnXDWdhZafHD5ssj75HRt+xcFi23+E9APzr5P/aC/ZQ8DfGJILiyu4bLx W8UixXMoLqzYzmTB3Mv31Ocks+cjFbYHGVcFiPaxV73uvIVbD08RGKmtmn9zufldq37Nn7Qv7KPj Xw38WvCqRf2jpF2L2z1CxnJKBQFYyKCCiMrFGAcHDsMjrX68/Aj/AILEfDHVbfT9O+NvhS+0TWhG I5dRtEN3Z7gNu7ZGBNuYj7qxbVyAX718z4l8Ey8QMFh81yeSWMoRceWWnPG91G+yad+W9lq7tH1v A2e4XhutWy7GO1CrJSTW8JPRtrezVttrbO5+u3ws+OPwc+MWlpq/w1+IOmarZ/ull+y3kTtDJIu5 Y5FDHbIRyU+9144r3hLJkU5XkYLcYxnrX8gZjl2NynFzwWY0ZU6sXZxkmn/TP3KniKNanGtQmpQl qmndNEctthgB1Jz9P89aaIfLwUXjPA6cVwGnNdFadljGYjnjrnofeuWuQDG8ryZPRCSM7vw7DHX3 FVEv7OpzlwAylVPzdfTPT/P4VgXaKyTRsgaJlIdeDuB6g+oI4x7V20m0007GL7M8c8U/Cnwf4jgt hHZPpt5aWs9pZXeksLWeyhnnt551hZBiLzXtYd5UAsqlSSCaTwJ8PPDHw10KbQ/DFtIIZrh7y8ur qZ7i61C6kCq01xPIS80hCopZicBVUYCgD6KWc46tgP7PqSTje7lb32rtqLlvy8zcuXZyd3d2tyLC UIYj28VZ2tbp2vbvZJX7aHXP5Sb3OR0x05OP64r5q+Nek6L8Qbvw98JdT0qC8trxk1nWFlUMLfT7 aWNhHwdwa5lCQYP34FvBkFRXVkFSpQzOli4Ss6N6l/OCckvnJKPzt1M8ZCNWjKjON4z91ryej/C5 5TqHiq3+GniWw+EHwt8NNe6hFof2ix0iB2FtYGW4cLLd3DFjBCArYB3MQhWJGIwPoGJ7k2luL11N wFXzSmdpkx823PbPSvbzXDqMMPjK071669pJW2T2k/Obu0v5Uns0Y4Wop89KnG0Kb5U/NbpeSVlf vddChcqJEdldc8fLnqP8/wBK5m7ZHJU8gDYM4GQB14rio3PUpR95I5PV/Buj+NbU6PrmjW19ZyKV aO4hWRSCMHGRxwevvWd4L+AfgX4D6Trd14B8MW+lyalMktwYfvSkZ2KSxztUFsLnAyT3NevHPMdR wU8jp1n7Cs05Qvo7O+3Tz72FVyvLp4qnm1ahF16Skoztqrqz/A/ET9q39sHTPEvxM0+Pwpe6haQa HJPZ22q2t0QZmZisk0YU5VHU49WGAfStjS/EvxU8X6LqmkfFzxJquoeDLnTpbnT9IW9MMM97cG3Z JbtUwzxxBBMsWSPOhhyNoYH+m8kyd8O5NgoVre1cLqytq25NP/DzP5n4flsMV4i8T47C5Wv3FKa9 q5Wdqd+W8eznyW72PbfgV40tvhpH4xkjjH9q32nNp9rMyjEKSNtl9cFlyOBxk4Nfoh/wTy+FHhb4 2H9or4U+N7Yy+Gtc8By2k6gnK/6Za7H3LgqUcIwOeqjn19HJk1ndKo9byX3JbH7/AMYYRYbg3N49 HCC+SnFG5rX/AATw039kP9mXVfDWk+ObnVLrxZ430yfxFO5EQn0qyttRe1tEUA8GVw0jcGTcRgKA DwrxRRTG1aCNoIgIbd1I80r6LjphVGPqPSuriLD0sNjIqmrSkuZ+bba/BJI/larKbUaTk5RirK/Z NjjFGlrC8NmIrZPKmAcFpXPO5iP6e/5Z2nQOsl1LcyRieW5jZ2nYo6s2CBj+EYKnHt7184tI6v8A q5ztrTQg1SKaS7tjA0X30WORskuQ2CTjrxkfgKo397JOoFnMDK6grLGSeBgj8zgcf1qrK6uQ5W5n 1NMR6s9iFgaSe+VAZllYBgoYk7c8Ake34Ve0i2uJluIUmi+6Bs+4YQAJB74IBArOfKomkb6HRzta yRxSmdbYn5SdpLSKM8c8A/X2rzfXmnE9yLhArySKpTIAbbnJJXk5+Xpgcmqw6u9ehGI5VHQ5N7+4 nYKLY5yyKGLBUDNzgnrwPr2+vjPxz0b+3tH0ZYVzPGkzOQOEwV6D655r6rAR5KdSb7fqfM4xupUU f6/rY+R/DeoC0uLiwnPlujFQM9QMnJ/zivpP4ZeIb3SNbsl0658m8eaOe3mjcAwTxtuR1Jzg/KPX 7opYuHxLpuThpc65H5ozv+CqHwg0Dxp4X+Gv7ZngjRzHJ4iMmkeOYYQDHaazAFAkYKMJ5y5YE9eK /KT9nb4oXnwd+LXhjxrbsRZQ3Ihvo0OBLav8si+/HzD3UV9xl2LlH6lmMX71oTf+KLtL8Uz88zfC 831nCPrdf18z+oPRLiDVItO1PSXM+nXUKTRSA5EkbBSpBz3GD+NdwujxQ2lvqci+XLuywX1PT+lf 0JRnCpTdSOzV16M/JZbxVtdvwPEvGNm3hPxdZaxBkWdy25goIGDjeOPrnFeqXCx32mQGHDgg4YAn GQSCOeMitoNe2l/eSf8AmaYyXNCjWl1Vn8j6z/Zn8WPL4fvPB11IRc2bF4AzAl4WJ6H2Y9PcV9U/ Y/3Rmc/Nxxnv/wDX/wAa/D+J8K8HnWKp20cuZektf1P0XIcS8VllGpfZcr+Wn5GROEkJBJB9iM/4 96yT5jN5MYwfUHH8/WvBtf0PZv0Rm3IZeZVGOwz71g3CYWWS44xztDZziknuX9m1zlL+6afMYyI9 vTv+NYuyL/b/AO+f/sqyk3f3RxvbRGbruhs626aSy/b5YpGO9GUO28R8EjgEAn04I561ydvpUsGm NZ38ZkgV/MJEihmxgDp1y3Pfvmv2ajW9zle7/wAz869n7rXU1hPB/YS6VBdg3aXG9BsGCQwVSQMl f4jyeh461iX9lPqEkemTT7gPKweFXjcZAx5AUsWOc8fjW1L2cZcz3bv/AJmdRNyTXZCPa6jpvmaS 9sFdP3qSJkZ4D7yCc84GOOy+1ePeNNSn8N6Ldx2t+f7UuV8pDFjMYPEjt68fKD6njpTqdbauTS/z NcPTVStFPb/I+Y0Mk0rBJWYqmxd3XJI4z79anaMxKmC2VOGx0wBz+Z4/GtFHVdj6Ky/rsSYjdcxO ScbmLbevXHpyQP0qW1WC5aFlUiUZLLz1zkfXt+f41q03Na38iIytdvoXBOYVVow/mDADknC8/l15 /Suks/FeuwKkZujLArbvLYjseAPxOee2KmXKm7LTcmVOnUSU9/xO1t/iHYzW9xb6lpMTXDsN8uMk 8e317Vfbwn4H8Ry3cunuYpnGIiGUc45BB4z/AENefjsJTxsXOqkpL/gGcHWwTTpyvE8c8b/syeH9 a1DUJ7rRbTUrieR282aMByzrk8/xEE9Wzk5NfMfiv9jbwFewfYbvwKkd+eXuVTDZOcjcF4529B7e 1fA5rwxVmqcsK+SXl+qPfwOb4aUpQrRUk++/yPjjxd+w94k8NyXuo+EbE3colPlRBidi4ByARkHo Mkg57V4TFoXxo+Fd8JLKfVdMmSXf+6eVYy46ZA+RueMEHvXyeIwVWKlSx1K/TbQ9SnXdGUamBqOP XR/1c9r8LftmfGjw8LZPEMVnqdpHgF7iBo53YHrvXgd/4f5V7Baft6QTia91rwsYrl5sMLW4ZvIT g5zIADjBXqTzz0xXztfh+nOTdCbSfR9D6LD8UVFFRxVPVdV1+Xc+xfhR+0P4K+LGkR6hot9vCg/a 7e4kVHidSCwwfvY+UBuK9f0LWvtOrNJd3DSEW4j/AHY+RFyT97nPUfiDXy2IwtTDVJ0ZLWJ9jhsV DEUoV6ctJHbaJqMtiZG+0b4R5yztGepBBG0nqcALj37c1z9hLLcam2sa5G8MjEtbWxVsRxcKxznG 4nHH+96nHIoqzl12R281+VdD85v23PjXf2UmoeDbG7QRyRqEMbgsMrh1fuOd/H071+nP/BED9nD9 nfR/2Jv20/2y/wBrT4VaP4p8Gx3Nt4c8P6b4h063uoLy5tUE+2FJ1ZWeS5urSIZUgNDnBwa+g5JY Ph6dSm3Gc2rNaO99D5SeKnV4g5YO3s4v8dPnuek/s9f8EGLT44eA7T4r+BPjJrXgD4rnzH0u805i ILeWRjvkYxbZdqqWjVIHhBHzb+cV6P4h/Yx/4LbfsZ6PPrWkpofxh+EFndrbpDFOkOsxadbxu7TM smxEaQKFwZb+csUwrZNfEcRZNkfF9CWEz7D2nDSGIgvfjba/eN73TutXs/eX6Xk3E9fI6sIOpdTt eD+Ft9v5X6eWj2PJPDP/AAVe8AaP4hbwV+078KPFPwz8eiFLiSz13SLpFCyMoi2o0YnUEEt5kkUS YBwTiv0f8BfFX4b/ABV0WLxB8PvHelazpDSNAJ9Mvop0MqgFo1ZCVYjvtJxmv5o4x8PM64Rqe3qL 22Ek/crQ1i+yla/K7dHo9bNpXP2XJ89wGcQf1aVqkd4P4l0v5rzW3Wx0eouWSOOLqWyc559B/n0r BvAQvkA/KDwfocH+tfBRVrI9tt6owrgbsiP+fNY8+ADuyOCTk8Z5/piummZ3MKZQA/ODwB3x/jWX KqFW8w8A5I45713QbIbS6GNOd/yfmcAjH9P/AK1eYa/4cUyeKdS0e9a18R6lapaC/KLK1qIxIIdi N8pEbSvIEPy7nbI+YivWwNZ0aj0vGVlJd1zKVvK9kc1SLqeTW3k7f8E8k8GfCez8A+Jr3UNMUyC7 sAL/AFK6lMt3qV55jM0s0hGXbbtAPAUKqKAqgD1R42wmAeTtxnk++RXt5hjnmOJWJlu0lborKySX RRVkl0SSDD0VRpqlHZde9+vq9z5d1nxbfx+PW1yyvRIl3p97pOgWLlTHPJDcWaPcgZDENLK+4gke RaxyLyxzem8Z3djrF5op064utO0/SJrybUDhTeXMXlDyYh91yVclm4GWVVzh9v00stpShSgvdah+ Mfddv8VRyu+0Xbsb4ebjfrd/de7/AAVvvPbvh/c6TJrjaXJdI2qLCLmSIHLRxk4Vm9AxVgucZ2Nj ocfM37eXxW1PSfC1j8L/AAPmbxv4kZ9OsreJgWjgxi4mPZAF+TeSNoZ5M/uzXFw5lksfxjgMNXj7 ikpv/BH3m/RxT+85uK8w+ocO43EUn7/K4xt/PL3V87tH4Ca3+zmll8RPDmgatqTXl+u6/wBYSJcQ 21srDy1DHnfLjoRkKQ2McD7KtJ28QTTw3kaR+V/qgg4wPb2wP8iv6kzTHrGxo1qatGELpf4npf8A 7dSfzPnvA3hyWS4LNMbNXlWqRi5PtTjsvSc5r5Ekmi3UEkSqu5Q4XIA4wf8A636nmv2Y/wCCVF63 h34sePjcRRxi78LPEnnbcMTdQDjPcBuTzxn0GDJq0Z5nhmn9o/T+O6cqvCGZwivsR/CcWff37aN3 Jd/CjRGs5MMmu27mH5dpUW84znnBHJz7Y71+Ud8sb201xFblY0lwQ7k5O4dsc9evr1r1eKWv7Qg1 /IvzZ/IuIXLUcexn3aO0TGG9C4w7yKpD5DH5Ao6YwceuKNQggtkuIr5ox/ookbIO5dzZ5fk9SAR7 818vfXltqczWj10Of1KAxaS8nmBo5CRDIuBswB6889vT9aqLqtjNq8NpLbSpZRxBRPGMBPmHHH/A uR3PsKcbtcyW34mMnG6UvL/hzv8AT5VRZhbR4hKbXBlwV29xnP4/UdaxfDelXF14jaw8ooZySbpy qBAOeT1P8PHUnGK527czOh3Sgj2QWei6L5FrL5NzqkbblMsmTyRwB2Ixk/j7V4V4x+z3FxLJEgjw 5BRX4eQ8k5HLcDtzz2rTDpqROIUVGxyaARmNfIQNnLc5wcc/kMce3NcD47l3W2jzLhYwJg8rBSu3 j09ia+nwrXsJvyR81iXbERVtNT4d8eaUul6nPqtqgVCxVgOMg/oM5z/kV1HhjV/Oit5I3IlQbozG RuQrz8uP8nFdVX3qcZNeRy0bU60o/M/SL9m698KfG7RfHn7M/wARpIk8LfEGwawtnlAK6fraLvs5 1znYSRtLDnkDNfzg/FD4YeJ/hR8R/Fnw18S6a9v4j0bUJbG6SRSCHiYjIz2IAIPvXt5HP2mW1KTf vUqj+6auv/Joy+8+b4gpOOMVRLSSufuL/wAE7PiufGXwpuPAGqXvmeJ/DxVYtx+aSxbPlYz12EFP oF9a/TDUglvptrp+3bcH97IpGQM9FOefev6E4XrvFZHh6reqjyP/ALddvysfima0fYZlVhFaKTf/ AIFqvzPL/Gnh8a54avreBFe5UfaIW5BDLnK+2Rz+Arjvhpqt1qNn/Zck6rc2v7og9XXqOnpyK97b 2c7+X9feYTalhXGX2X+Z7n4I8Sf8IR4ys9dEgWFWAnXGcxtw2D9MH8K/RVb+O8hinhlzE6h1bP3g RkH/AD7V+ZeIGE5MZh8Yl8cXF/L/AIf8D6zg+vzYetQ7O/36P8UU9hlfcThM5OSOn+frVW7lihGE Ybh1z34/z+VfnzXQ+yhZs5u6ugpDHliOp9eK56+dplUknrzj+H3rOV9eU1SfU568jdEbIAVuemSf 88VkbV/u/wDjjf4VEfUq7P6mPHf/AAS0/Zc8WR3A8Pafqvhu5kfzDPpGovI4YlyQq3v2iNE+b7qo oGOMZOfh7x1/wRj13TIb1vhz8VLbVIJW8uOy1q2a0eIOQrSNdQeZkqpJwsAzjAxX0mF4ixuFXLio +0j32kv0f4Hz1fKqU7yoPlfbp/mvxPhb4jf8E4v2o/BFxe3V58KGv9OKpKJ9EuIbmMAEnEceVnyM dDAPvcV8FeO/Cfi7wfqM+ga34bvrPUUKSyW91aywPJGzDkJIAeowDjqPavr8uzbAY+XJRq+8t4vR /d/loeJXwdfD61o6fh/TOI1C+/4RnRrzWJmdVYM6wuSVKk4BLHBJyMAcgccdDXyfda3e6xPdXl62 Z3fd7Rg9gPTHp6168KjTbT2Vvv6/I6sDRvecltZGfZDTnRneJ/MbO3Bzg5I5z7fz9qkj8PalNF59 vGVh5cMwIBBbj+f0q6cuZ2end9D05Qk015bEC2C25AZw87AZUc59x7nj8xUdzaXEOzzg8ZJwoXON pJH+fqa6p1IvlhSWi69TnhCSTlLcRFms/vMWVTt2/wB4Dvzx68+/tT0jafd5kAEwfJwfpx/k+lTJ p6NFXu+ZaEkIWPMStuCHqcn9f0/X627WCS4vIYrEs14WG0Kcke4x6npUuNnylRldNNH1p4e8P3um aBpoLmbUUcGR2ORyfmAz7/y9K9I0XQLC3NxLeWju7/LudQMYLAYzVezXNG0b66emh4E6i5qj9TD1 b4a6TfxLcx6OsbMjbinAOTkH868v1n4LaDcWrw32kpcyysFjR4VfPHY4ODxz+NeTm+VYSrBycFZ7 no4DHVoqMOa7PkT4r/sa+CdVikgfwULeQBnNxafKcknnA68nGc+lfmr8T/2G/EzyTnwfrcf2dST5 N0uxm7gZGBzjtX5vjclqYSb9mu+jPqIYmniFy9UfHPiP4GfGD4f3Uk//AAjeoosKl3urEuRtJ5O5 PmxkitP4c/tI/G34Vaikmm+Irq6sY2ImsNULzRvweDuIZcAHHPHHFfOYvBUcTGVLEQSl3tqj0cFj 8XgKkalCbt26P5H3j4P/AOCh3hi5s4bjxn4NuLG9JbfNYTCaFHx94owBGeOgJ4rsNR/br+HGqadI mk6o733lExtMm3JzkKVPTt1HPNfJ1OH8TCpyppx7/wDAPtY8S4KdHm+GbWqf6M/NH4ieItS8deIb nWLuRpYXkJUbgcLknJP55P6V/W78O/C13B8Jf2Fv+CcPguHYNB0az8ffEiOJ848Q6qDerbSlDjNr HPkjJGWjBGVBrqz2n7LBYXDr4YvmfpGLt/5NY8zIW8TjsTiH9ppL/t5/5I/q8+BngCx8GeE9B8P6 bbBLa2gSJFUdMDH4V9i65bJpmn2GmJw2wSSD/aIr47CRfsKlR9f1Z62dVefHU6S7v8EfLXxg/Zl/ Z/8Aj9osvh/4zfB7w94k0V51uXttX0u3uY3mT7kjLIpV2XOVLA4NfhH+0B/wbgfs1TT6n48/ZJ+K 3ir4T/EUW0ywTaZq1zNYvJI+52nV2M/lAZUW8EtvHjAxgU0/Z06lFxjOjO6nTmrwknvo72v5b9Uz 08sznFYOtTcZO62adpL0fX0fomkfg94r+O3/AAUC/Y/8eeIfB/i06Z8Vfh7pV/NCurW9uLS5vLeH McbK8AeO3VioIBSV2/vHOa9u+Gn/AAVg/Z/8cXttoXxC0zVfBvicrBC8WsWjeQ0zk79kq5CRKQf3 kxj47dq/IOK/CLD46lLOODXbS8sPJ6p9eST39Hrpo3dI/c8i43pYlrCZt7s3oppWUtPtL7L81p6H 3t4W+I3gb4g6Xaav4G8Wadq2lTFvKnsLqOVJMfeKlSdw7ZGRWrMVJAbOMH3/ADr8GrYTE4KvPDYq m4VItpxkrNNbpn3V4yipRd09mtjLuT0+brzgdQe5/SsaYMjsJGGzaG4PB4z2rWmTJsyLpSiu+fm5 +m3r/n8K5y6AKM7ZJ6kf5/Ou6kY3s7mL5Syb2IyMYOTjP+c1VltGuLWYqQAvzHcxHBOOP/rV6FOT Uk79S4tXPDtU+D1n4t1jw3Fo+ojStRs7KXRNNuo40zptrcvbLOYS3Eb+Xbqiv/B94DgGvKPEfwb8 bfCGy1vwvoEt7rLi70yz0mDUboCKxt4pw06u6Lu8pYgw3kb3IRc9Gr7vLc5pVaVPA46K5bpuo9ZK 0ubT/wACqerkP6pKFWWIw7fNZ+7sndW1+6OvZHt/w9sbL4faF4h8Rapeo10Fe81LUJsR+dKF+Z2J PyRqqgKucIiqvQV+dvwM+MfwO+Mvx3+PPxu+N3xXsdF8I+G/DGpXmneH7plTUPEFvbEPbabp7NnZ dXcxjiYqCVFxO3KKwr6bgHLcRmeYZvm1GL92MKUf7qnJK6/wQVrdtD4nxCzSjgKWXZdN3c5Snb+Z 01dL/t6bR4LZ6XPCuq6j4gi8vxjqUpu9SGMeRIxyY1Uk4CZ2BckLgL2rn7WBdP1SOViAh+Ug8lgR /wDrNfrKkpyqxivdei/wpWX4I/ZeGMullfD2Cw1RWnyqU/8AFP3pfiz0a3ga6u7a2ZCSzAHOc44z mvt3wFBPoOnw3FlO0F2g2LLGTG4wB0YYPINZ4VuEoO+q1T9D6eNOnUoShUinGWjT1TXoe5ax8W/F 3ijwl/wiXiXWUm0qCUXqSzBfOJRSgXI4bAbjvnGTXnU+nXqwPepdRSJtxBEXGFBIyxx94jb+Ptmv SxuOnjakHVV2ko3/AF/E/kXxEy7BZbxRicJgI2ppQbXZyXM0vLU5l421K38tl8q/JxHIobccE7mX 2Gcn64pIpy1vIt2ZpL2VHD+WhA2jGQck49f5HFcrslc+FvrzNHOarf7UniY/6LL8sTnBYcHjAPyg fTuPWs/QlaR/K1CMyiF2RkbAAZT1wOmSc571typU3I55Pmqq53DWjWsIGH+zNuDDI/eEA5b2GMjt Vrw/batc6/bSx7WtYFUyS4GBHkqcZOOABxjPeuNtNNyZ2Wd0lud7qtzBumura5O6NMvKsXzIemcf j+GQK8e18sY7y9klJdWDLu6JnnI/M9a0opJpxRniNFoch4gu5priKNcr5q4UFRtOU5GQcgkY5rgf HMTPpuhGCQKTNIpTJUAMq7cfkT27V9PgX/s01vofOYq31hPqeK+KtDXUrV7VwrSCIklsHJ45J7fQ Y/GvnLRbyfw5rn9jXDvsDsBu6Hjpxz3/AF966KX7yk1ucdZOFSNQ+jvA3iO90S/tJbS7aO9DpNDJ G/zRSqdyOpByCCB0P8q9b/4KgfCWx+J/gL4X/tzeFLFA+twpoXjVIlwtrq1uu0TNyceaBnJ6nHPN d+QTccdVwz2qQbX+KHvL/wAl5jzs+pOeFhW/ldvv/pn5cfsy/Gmf4I/Gjwp42kkb+wBOLTVIhwJr WQgMcHI+XAce6V/TTBfLrEFrrEtyJbe5VZYnjYcxuAQVx2wR07V+28CYqU8PisFzaRakvRpp/ikf jHFFKNPFU66Ws1Z/L/hwZBbRC5TiCTIVcZ3nI69x9fb6V4Xrdi/gLxvBqSqRZ3wzt4wqtjKj6EH8 896/R1BTpzit1733Ox4GHkpe0g/tJ/etj18iZ4bJrlF8tgBjAyw5PJHQHHWvsz4L66dX8NJpkzEX 1h+6KtyQnJT64Hy59q+R43wyxGSrE21hJNejuv8AI9ThfEexzN0ek01891+TPWZIFkPzOSAQCx6B vb1rJvHghDIkYYgcN1x+dfjL1P0te9oc1cMjFy0nPOcHrn/P6VQnUOQv8K8gY+8T/k1m11OiD6Gd Lbo3yTKWi5+q/Sq32LTv+mv/AHzWLcuhsknu7H9y3TOaOM+1dMrM84hlII+bkE4xXnviDwB4I8Wa fNp3iHwpY3mnO48yG4tkMcmGWT516ON6q2CCMr04rgqP3+dOzXXqaJXTT2P5Qv8AgqDF+zPrvxX/ AOFZfBfw5baXZ6H51lq1xo0caQXeo7x5kKxxgKBAQys2fvmVSPkyfyXuvgrqJFxDpWohs8hGGfMI PGMegJ71+u8OYPFTyTDVsRUcpTTl729m/d/8lsfM4nH08PjKlOMEorRW/H8Tj9Q+HnibQ5J7V9KZ 7lfmMic7RjjP69+1WLnU76xhhs76OQKYwhDKVG7ocHjd2NeniadVKNO2m/r5nbhcXQqRc1LV/ecl piIb1GK/ulDHJJ5Pbntjnsas61fwzXWnxQS7JY980hByp6rtJwQOXyP92iMpqrDW+36m/NFU2nub WlrpVxYwC8IWYkjdjscdvUZH61l2OiW97fzRR3eyIZZtw788fn/Kt6c+d1JN2a1IdKPuKPUtX/h4 WVzAkI3pyqsMHJHXg98j+de6/Df4eW1nNba1eyBLpjlQFztGPvkevYfT6V00Lunzy3e35HJi1KMJ qC1PWbayeO+uLUIJLrjaeg4C5cHpnsPpXQtdvAV0+SUOYwEkUn3TjOefc1iqk6c3Z+djw3FKCXfc 6CPXreHTYTcWe2PzCEYNkEg5wAe33c+5rOl8Z+E4LW8lmmU3zgKrJx9nVSN30ZuRn0qMROOIth5+ 7qd2Bg6dR10r8uy63ON1/Wk1aZo4hshKMiMpBIU5JyT16frXIHw/4a1mCZZbHzp8BThFGM9Tx/nj 6VVfCRxScJRu2c9OvKjV9o7nmXiP4IaLcpI+nT+XBIr+ZH94DnhSD2+Xv3r5O+Kv7JHhHVtPuDfe EbafPMksChJScHnjgf4/Svj8z4dc4v2av+fyPewebRmuWq7P8D8lvjR+z94e8JXV/b6MLm1gYNmG 4UkZHQAkc8ED0r4ivvBuqWU8yBC6q2Dt7/418TXwdTCzdNnsOtTrKM4P/I9J+BehX+rfFvwDot9A 8un/ANoR3F5bSMQk9vAfPliY4OA6RtGD6uK/vb/4JEfBHXvELeKv2j/iEGuPFnia+lvEnlHLRs5I Zc/dUjAUDjaFr4jiuShhYye70+9pv8j7Xg9XqVJPaPvfcrL/ANKZ/Tt8M9AW51GxRox5Ef7yTPZV /wAeB+NdJ4nu2vNWu5P9ogfTt/SvmKcfZ5dD+9J/dFL/ADZpiKntc0lr8Mfzf/AOe4UEngda/NT/ AIKN/tPL8DvhHdaNoF9t8ea+HsdOWNv3kEfAmnHpsVgAezunXBrlqXcbLdnqZdT58QpPZan8sura 7DcWtxHqF3KQyLHbx55kPVOnT5sDGO2OO3mXjP4a+BPGxtdP8aeELO7abc8k0qAySOwB3Er83Y4z nqMCnSc6Ek6crNH0rnd3vqfNeqfseaPpF5c+J/gp461vw3qGJLeIRXE6IS2SDIyMrhVbkJyMgZBH B39J+N//AAUD+BkEN1rcOm/EHwXHPgsY0gvRBGApCNGFEaHj53jlc+1ebnvD3D/F1D2OcUuSva0a 0FaSf97+ZeT+TW59LkvFGYZS+VS56XWEtumz+y/w8j3L4ef8FU/gz4hu/wCw/il4Z1bwh4pjCrNH dWrz23msfuRug3hVHJeVYgR0r748K/E34f8AxGsU1fwR4y03VrCRzGJ7G9jmVmGCVypOSM81/PXF Xh5nnCdX2lWHtcM/hqwV4tPVc38r9d9bXWp+qZVn2W53RVTCTtNbwekl8uq81obt6fm4AwACQev+ Tz+VYd0nzFexwMg/59DXyNPSx6OqMuYtHuAB2Y5weT14Gax7kknYM5PBrsp9ylJpmRv2yK6fe3Bj /wDrrotSvD4kghbUSBdxxbfNY8uF9cfz9u9dim42Z6mDrJySejPy+/4KJfF3Wfhl8Grbwl4at3N9 4lu2tWljILpEmPkwDuzIxAGAQVRwfvCvyi+Cn7PPiKx1qDxh43AjaN0uYrJz80kinKiTttBxkd8Y 71/Svh46GT8EzxF/32LnNryUfc/C115s/LMdw5i+N/E6hSemDy1U5VH3cm5qK85WSfZL0PsG5WTz JPtY8xGfeJGJ3McklueSfrXK6ghYsHJ3sCc4IOSeOnGePyH0r2aKjGzi9D+l6iSjboezfDC1Os6p ZnaQ6YUZ6Fs8DJ69q+34rdLSGOCLPyqBuyAOAOOcfT/IqqUXGbXVfqzpjpSj53LrafaXS2/22zVo GYq8obBix+HfjrU8tzbyGKCyhJdQpVDlV8sHn2yc/XGa0bvLVaH8ZcbYpYvirNK6/wCfso/KHur8 Ecqb/wAn7PbNbrBPIWMbbsjaW5I6YB/rUE9vNFaktdM92jBtoA29Rk+3B/8AHau9rtnybu0zgtQg jvr6J7dVG1T5b8HzgOo6cZx15PPvWvoyhiXiBRzIXkLMf3jc4Ax0HTGfatajvDQ5YxvUukda+nwv qNi0SO9o4w0cYzn1Pt1Htz7V6fY6Fb2YNrb2I2sHZ4zkNIpzyB356/WuCcno7+Z3xjq3Yz7nT761 kuGQmOFownPfJBOc9+K821u0jS2lZ5AITJ5ZBG5W2lfvD0yeD9a1oySktNGTWXu8rOI1g20NwZYk HmqgPlIqlWBHDZ9sdPevOfiDbSt4O0u8dAJvtYGcnOCpx3BPQjj09q+oy1Xo1F5foz5rHWVeLR5Z DFIIGRbgMrIWYEZJx6Z9ePzNeEfEvw+6yxaxZQ42H5ipIyB1J/E1rhm+ez2ObERbp6bkvgbXhfR+ VNLuudpUgnqwA5Br9Xv2Or7w/wDGnwv8TP2OvHcinw38RNOkt9LefpYa/Che1lUtkLu2heBnOPWt MNW+pZnhsTLaE4t/4W7S/wDJWzmxMPrGW1YeV/mv+Bc/mt+L/gDxN8JfiF4w+HXi6ye18Q6NfT2F 3C6lSskTsueRyDjIOMEYr9z/APgnj8Zz8VPgxH4N1K5Mni3wuRZbt2XmtGB8hueu0fJnn7uT1r9h 4QrfUuIHhKm01KHzWq/L8T8g4po8+AjWX2JJ/J6P8bH6FW5Z2SIxuXT5sMowcDPbrzXHfEvSLTXf DckrBU1G33XCiQ7SFONyr6nGD6cV+y4aKdZQezun8z4TDPkrQkld3/MzvhjrNnqunTWZu4zeWqje ZGBLjOBgfTNfQnw78TjQPFtlPeMEsLkfZpScYIzhSfTDY57AmvLzTDxxuW4mhDbllFddVt+NjfDz /s/NIOWnLNP5X1/Bn1jdXgz5MTfJ3bg1gXD5UkOQ3TnoK/nyStKx+wQ0tIxJdzAJt+bqDn71UQro wK8bcDBP3uM+n+cVO+iLTtK5d3K8WAAJurDH3j6fSoMSf8+Q/NP8awlFp9zsUnJJxP7fQSc5GKgb zNsuCA3RT605t2v5HnaXKvnGNZXlwoBzkn+X+fWvz3/4KHftUXH7OPwXu4vCV7GPitr/AJtpoSFl LWSKq/aLwoeSIVkTbkMplkhDDaWqMLhnj8ZQwa+3JJ+jd5P5RuxV6iw9CpXfRfifx56jNreoX739 7M2BI8kzuQWmZjuJbOTk4PJ5yTmmxeJdY057W9+0RfZwcRxq33R165BPA5455r9/pqnThGktFHZL t/wD4TRtN9mbqX321k1aVmDqpMxbLbsDjPPt0PofWrcpsL77NLFJDOnz8SovzDbnnPYADH/163jF Shaa91X+4wlJp+70OO1fwn4Pt7eaZ7MeZJnEkR5XOe4HuTXm0vwot2vNRex1UEybRGjD7gHOD78t zx1Fc0sHCMvaQsvI7qOY1ILkqLmRm6p8PvE+nxfubdpEjXrF069QfxHrWBFput6dKr32nukkhJUF CMHOOevQ5596wdCcU1Jb7HqUcfTqzvGXyO+8C+Hr3xJLcG4lA0+3DeYR0dhj5c9MknJ9setfRsNk 0axyIshsI12pGckse2COgyV/E4o5/Z8sLbf0jLFYnmcl2/M25WceVdmwKIoSLeG4xgg/zJ/AVat7 azQmOVsSSoZcBNzMOwz7kD9aucqdSLknaR5cG1q9jz7xZr02gaUy5zqUwPkgt/qwxGGxz/8ArxXg V+LhLRzNcEyOuWA6EZ6H+fWvPqOrGTlbfZ+R7mWwjySmzFGsahGyJBdybRtAGCUHf3ru/D/xAudJ kMl1aRzJuActwR0GRjpgf1Fd2HqVaWsdbir4elXi+ZWffY9HtPiJoeqOE1C2a3tdmCRt5Oc9u3P+ elct4r8YeFNJs5orbWUmmnClYwQxGOQT+ZFejH2NdxjU0b+48XEUK+Fg+XVfifDvjux0PxfNKb2G KZkQbovJUhQSQBuxkZBP/fXtXzB44/Zg8F6vcf2lpsEtnkbi0XK/7230zj864c14fweOj7y5Z/zL ucOFzbE4STd7xvt/Xodh+x3+xhreu/GuDS2lW6tr/wAuxgmiGGMTyB5n6ZRgqKgI/wCepFf6BH7N 3wv074c+CfD3hjSbRYrC0t44VCrjG1QOPav5g8RKH1LNKeVuV3DV/PVfgfvvBFVVsjq5ha3Povlu fol4at18O+ELnVtoFzckQxZ/u5Of6/kK4S4kM00khPJOfpXzWLXs6WGoLpBP5ybl+VicM/aYjEV3 1lb5Ky/O5x3i/wATaZ4W0PVNb1i+ittLs7eS6ubiZwkcEUal3d2PCqqgkk9AK/z5P2qP+Cxnh39o v9pj4h6rqOhXo+GcF/LpXhi4ifcW06FiiTGPqrS8ykDJG8DtTwGAqY5z5Psq/qz14Y6jl0YSrL+I 7eiXU6HwF8b/AIP/ABLtYE8PeKbO4vQ6kwM4jkiUY42tzkEH616ldwW17cvNbu6vvLAgqCQdoyD6 DHAHHBrmq0atGo4VItNH0NKvCrSVSlLmi+q2LmozahdgaVpro1uRsnDk5dhg/Kfz/E8VlrZapJeC 3lt0SMFEJzncc8oM8cdB6H6VzuKivM1blN6H4N/F/R9fl+KPj5/EMZbXptWn81WGdqGRsKpYblHT BBrpvC/wb8Y6RY2Pi3wl4jv9G8RzBxbT2E80MjRnIcrNGRheSCAc8++K+7qxw88LRwtampwmknFp NNW6p6M+Ty3McwweKrV6VVx5HJ7vTXpY+qPAf7Rv7cvwzexgma28beGw6RvFcwA3HlJ/CkiAFc/8 9JFkJxnvX094O/4KY+AmlTTPjJ4D1nwtrOHaeR7WS4tVZT91Co81+/Plgda/E+LfCLA4yVXGcLVF Crq3Rb0bW/I+no9PPoftPDnH3t6caOcLV/bS/wDSl+q+4+1/BXxl+FfxQtPtvgLxzpupR4jZ0t7u IyQlhuCyJnKMR1UjI5yK7OYsPMaQHcemV6fjX4LjMuxuV4meDzCjKnVjo1JNf8OfpMK0K1ONehJS g1dNO6Zm9W2qAF6HIJ/HntzSY+QxxsD04IIwMe9ZrQuFVw1PNvFfws+HnjnxD4O1/wAfeEYdT/sa 9S9sxJkOhBBO3HuAceq18F+OvhlqugXk4tY2mswxVT5ewgZxgr2P/wBf6V+s8CZpXxFKWX1Z80Ka 9xfyptt/e2fY8H08PfHVqSSqVJRcu7tHlT+5WPHbuwuYwUnsNi5Iw6EYyR0BHP0+prltVtWMIaNC QDuK44KnA5x69K/UKLtJLp/mfXTV04s+pvgf4SazijvLiP8AeKhnm+XkZOF/HP8A6D0r6NlQRlWx gZJHGATn/POO9d9GK99v+rG1WUaNFyltGN/u1HySOBLFubyZo1jQgKNz4CgfgB196yVuWnMtpfO6 XAKiGJGHVW25OMY6nn2HFC0baP4Wx1eWIxlfET3nKUvvbZBrdu8yQLbMXurdNz71G4HkE/kOT2rB guXvYZ4S4WDyzucKQZQW5K5/h4/nQr8q02OF3vq9zmb02081jPZEpGYNwQnqclcgduM8e1dP4etd Hi1Gwa9kk84K2W8wKiknAJGPT+ZzW0+bkcVuYwS9pds9+ufHnw78PaPpNlYeGJ0uIQEecsn758jd x7+9dDB8cvC2qXWk21xo8Flp0sipLcG3eRoUyBztOR0yeO9eU6FTq7vX7z0VWgm4pHI+P9S8L6r4 y1e28H6q1z4cTymhnZGjEhKgvuUnONxYD2xXj2sRPHcFm3SwmINjgLGxPTGPm6CummnF2ejt/wAO Y1mnflfU84v/AD1uLQtGkZBJdiuQd5xkYx0GfTrXE/Es/afAWoz2nmO0IjuN2Cdo3EHA9OTxgcCv qsp5W5Rb3X+Z8xmElGUfU8K0uSS7sELFQyhcEdW4OeO3b3qbWtPe/wBOe1dA6PHlUJOAepx3zwfa ntKy6Myd5Rstj5hVH8Ia85mXbbFuSCMEE+/vX1X4A8X6hoGraP4k0PU/s19aTRXVpcxMA1vcRMHR lHrlef8A69aYyPOr9GjDC2tUoy03+56Hr3/BY/4P+H/ir4K+Cn/BQb4b6bHHpnjG0Gk+NooEBSw8 QW42SF9qjHmbScnrwa/JH9kf43XvwH+MWj+IgGHhy7/4l2pQbiFeJyNr9QPkbDZPbd61+gYDGuNX Ls1v8Uac36x92f8A5NGX3n51m+C9rRxODn5r59PxP35vvi3r98qR6T5UFtIA+5BuZlIB4PuD1H41 yceq3+pTG81LUHuJEPAduCSCDX9BqrdWhotGfB4bCUaDjLlu+5P4J2eEfG0d7fzAaXcfIhYcKpwV OMdjx+NfUeqXYuo45Io2EEeYwwGEk/rzx60sHTvOrTe17r0f/DHlZ1G2IjVT+JfkfWXw78U/8JH4 VsLyRdt2gNtcDOfnTAyPqNprszGz/dXOM4I7Y/yK/A87wv1LNcVhrWSk7ej1X4H6jlOI+s5fh67e 8V960f4lWa3kwx6+/bB6/wCf8azygD4QE9jjHX/DmvLTTR3u62A27KC2ckEnCkkf1/zmod7f88j+ Z/8Aiado9WHNNfCf26ySgN5aDL++QO56/hVQPNd2Yk5iZ1OMj5lPTv8An+tctRNqXZEJbXOX8ZeJ /D/g7wrr/i/xRqENp4b0+1e9vLqdwkUESLuZiT0UKM/jX8W/7XH7QuqftL/FnxV8Tr65mtbW5f8A sjRrIj5rDTICvlRnBYFiWkkcBmHmyyYIUqB9XwPgfb5nWxUl7tONl6z/AMop/eeLn9fkw9Oinu7v 0R8lE2xtTZwXTvcBst1ODggg9uc/1q1p1heRXGnyaqkbNlhDx8rMeOg71+sKKcvRaHyyUmnK+5qa ndSFXtEgljhLCLAXGCGBJP4sfyx605baKG2hRrllgiQNIQMMx4Yj6fLxzVR92Nlv/kLmVnJrczdH uotVdZpYxHYuWDGQjG0Alj68AcE+grYFvYobhIHzbqrjzBkseOM9snI69a2spSUZdiamivHoaWnS T7EtIo5JN6FSSw278HByfYCvVvhd8Mta+LnjvRPBWkw+bqcrlZS65S1gXl5mPYBR7ZOB1IrPGYil gMJVxWId4wi5P0SbKwtKeJxUKFP4pNL8kftxN+x38DrPwhpfhAeFIoxaQC3a5ChJ5pckySMR/EXy T0A6dq+ffFv7A3hLUma58I+K7u1QjyxFP88SHhvl79f5e9fg2A4zzLCV6k6vvwlJtp9LvZH6Pi+H 8JiYRVP3ZWSuuvqfOXiv9ij4vaNOjaULfU7FFYDbKVbgEj5eR/Kvk/4j+HfGXwzke/8AEfhy6t41 QxKzRNsLYI2qw68E/n2r73LeJctzSCjTly1H9l9/JnzWJybFYSp+8jzR7r9T4h17xTqup6rLcyyF YzLlFJLBRjgDPtWVLr15OMoWMIO351yW5xznr/8Aq9K+qjrTjHfobU/3cOS1i1p99BIjGcnzANyc ZH+elJLFGvllmyr/AC/L3xnqPStl7OSk0/e/LyKle0OXbuct4n1xNMt5bm3ZGj2gHuAMAY/zmvgf 4l/EC5vb147K7kjjD53xH5uh9MY/+vWmHpXkuboYYqScGonk9r8UvG2jzuLe9kkg3Av5pLbj65Jz 2x+FfZXw41fxN498MC+ubNLVWLBF3sxlwAc4P8OQQPcH0r1IylGLT2tfU+bx2FpRXtYaNu1kf0Gf 8EtP2bzDPcfEnULcFQ4t7RzHgOf4mQ46f4rX9K3gfQizWNlBH+8Yqij3PFfxpxljf7Y4xx1en8PO 4r0Xur8j+h8nw6yrhXB4d6Pk5n6vV/me9+ObiK2+waHanENrEq/U4H9MfnXmksiRRtKT2/OvMzGS njaqW0Xyr0j7q/I4sug/q0G95a/e7n80P/BxF+1h8R/A37OJ/Zx+Cmk3114s8agp4lvbCNnOlaIP vRHbyGumHl4/55JLn765/gCutOv9Hm+yalZS290pyyzRsjK3pggf5FfXZNgK+EwUa9aDj7X3k2t4 9LfiebnOLhVxXsISv7NWfruyGCS6tHivLGaSKZCrLJHIwZT2ORzn6V714R/bI+PfgRIbKy8WC902 ECOOHUYhN8oxgb+G9skmuzE4DD41ctZarqt0c+CzXF5bLnw70e6eqfy7+Z92/B//AIKPeFNTaDS/ ihoLaTeO/wA2pWmZYG4wN6n5hkk89AB161+ing34ieFfHEEN34K8Yabqtq670FvcIZBxgYHXPXJ9 6+LzLLa+AqNyXNTe0v8AM/QsqzPD5pSvQfLUW8H+a7o8++J3wC8M/EHxHbeKbuI2etv/AK+QDKTl fu7h2PY49Oa9EtPhVolxYaTpEmkQ/ZrRBE0kO4NdAZJGTyB0LflV0sz9lThK15QVl+Sv6CnlsXVq xekajTa693956/caLodtoVvp2m6TBa28JDMscezzDwMHj6Yya8M8TfDnQPFNhdaTrvhe3vrG4ZpV M8YZgCQCob7wGABwf4a8uhVqxqOq5+9ffU9KrCHKqcI6I+YfF/7Dfws1C8m1fwNcaj4d8Q28gkWb T52CwMRlSqnlB7qc4z3rK03TP25PgwVs/BfxIt/GGgRR5js9XUSyDJznLsJXbb6yYHPHSts0y/Ju KMN9VzygnL7NRaSj6P8AR6eR6OUZ3mGTVF9Xqfu3vF6p/Lp6rU6TTP8AgoTf+Err+yvjr8F9V0e9 RhC9zYrviDdGZ1fbtx12qXr6v+Hf7VHwH+J6wL4Z+INn9skOEtbsm2nJ5/5ZyAMeh5x2r8T4m8Ms 2yaLxeXf7Rh+6XvJf3l+qP0zLOKsszOSoc/s638r2fo9n6b+R75HdW11EJ7e5SaBjtDK6leueo46 emay9S0nTtQRo76zR4yDkFRyP8/pXwGBxeLy3FRxGHk4zg/6T8u59ThMZicFXjXw0uWS/H18jzvx D8IvCXiSzh0tbWG2F1cRQzXbni2iZ1VnUHGCoJbJP8Jr8y7bTY5fEz6IWEnkXLxuy8qxjOCQfTIO K/cuFeIXn0J81PlqU0ubs99fI/SMhzepm/MqsbSja9tj7s8I6WmleG7Rli2yXTb/AFyiEooI/wB7 zPwNb00Suqx/8tG68Y5z1/LH6V9zCMlSTb8/vOrijFfVMhzPFJ/DSqW9eVpfiZOn6fKZJ2vJg4iT zFcpjG04GB/nt61lXCSLEt9se4l8xIsRjOUY8EnthsdaSkpPVaH8Ry7sbl5PMtYrllkZfmDcMjdy cjrla56OMLh5EUqAVJWMhmc7gT9OR0/KmtHYzem7Mu/0uRreKeGDbGPkiXGXAGckj09PwqpbxXUd wAGxJkNhiMNgc9+MitOa60MHF810dmJUvxZbriN/JPmshA+XP3hn1HYe9UtVtUeW3jEbGdJTtIYB WVhkE/1rmT5ZO50yTcbMr2tvNa38k0dwERwsed/+t2jIHp3NdNJp96Yre5F27PuJG1eNpB9OvGPy olJKwKNo2OH1q3ls2udxUs/ygEZyCcZyeFHJOfY1yt7pX9s6NrWiBQiS2rqAu4lhtIXB9c4OM9q+ kyaf7xXdz5/NI2Vz5K8PXAjtDbOQJULIR0IPQ/5z3+td3JK4hChd7KmBgcDHU5wck/4+ta1YuNRq 5zU5XSZ4x8SNAbVLWSfykDqSA6rgkY479/8AOK434e64+JNHvEw0bFX3A7iDjO33we9baTw6kvsn O5OGJUrb6H7N/sOQeH/2iPhv8af2C/iBdqdJ8daTLfeF5psbbLxBaIXi2Z/ilRf/ACF6nn+YX4p/ D/xF8LPiB4t+H3iyxktvEWjahNp95C6FSskTFG+8AcZHX0r6TJ6iq5OoX1o1JR/7dn78fx5z5fOq Xs8fNraST/zP1q/ZL+Jh+JHwt061vLndrmjMun3RJBaSMD90578rge5WvrONLWziMkjZOflC45xj 0HP/ANev6CyLEvG5ThKyerik/WPuv8j83xUFSq1IJbN/5nNazfXGp2xn8rc8TKERT1HPbvjrivq7 4c6pea74ahvGhjFxEohkiccs68nvxkc17lFuOLjBvSUbL5HkZzBVMup1Yx+F2b9T6P8Ag1cT2+r3 WnXMIijvUby1zwsiAkD6kBh+AFfRwRkSTJJxkYPBHr7V+R8fYb2Ode2W1SKfzWn6H1HCGIjUyr2a d+STX36/qXoI96bSAV9/btWHcWCo7seE5+U9vr+VfDxuj6+TT1KLW4gwQ+W7jHXjnP4VH5if3U/I /wCNN37GLaWh/bIzsWK7QEORu71VmkIRFRei8A8YH+RXDUk7DitdD+d3/grv+1ve6h4hm/ZU8F36 /wBiW8VveeK5EVgZLglbi3s845VV8mdiARuaMbgUcV+CFrZxXX29XuCpIIgC9WJPOPTGP1r9b4Lw UsHkscQ/irPn+W0f/JUn8z4/O8SquKlTS0irf18zCtYociG2nPLgXDqfv4PTOOmD2963W1yWORLi G0DwQOXx2BOTuHpjIAH04PNfXSitErnlwlFx28yzb6/m1jlvIdzvM8pjx0yc4YZzjHPc8iprK6tp BcT6jOXSWXe6gYJA6Lz9SPxq1Ts/d3/4JNTZtd7fh+Rfksv7RsTeQ2CpaxRuBwVAG7K4UdSefyNY N68oFl9ngc4k2OB91ccHI79f1relFvRbo5p1OVOMtmdjpemXpSKWOOSacyeXFBCCWkY4VMAd8nOB zmv38/ZR+AVv8F/AFvqPiCxjTx9qcSzakxwz2qNytuCOyjliOrE9QBX514h5pLDZRHAJ+/Wl0/lj q/vdkfW8J4P2mKliqm0Fp6v/AIFz6dvZ/Nl3ooyqbUGOFXBHX1qmHU2wAOVWQhVxjA4PTv8A/Xr8 StLlevY/Qk1c5+ec2wuWL/u1DMXbACgdetfkV+1V8ftC8d6tdaFpO250HTpmjV1AKSsPlL/jzj2r 7PgrKKmZZtzxWlJcz7Xei/VnjZ1mFLBYW1T7Tsj4X1Lw54C1G0ja90yNbtsvgZDDHfj+Vcje/BXR Lua3m07UGghaPMbEbhyef0r9weDnRi0v80fEU8fCbeunbqcLqXwb8RRW011p7JNBGfuqcMy/T8vS vPdW8P63o1vPdX+lzJGAdpKHGBj8q5/Zyoy5ai1v8juhiaNVXTtofFvxd8Zi2jltYGZZAMlQ2No/ z/n1+J7q+m1HUGaZSIwpBABI4Ptz/ntxXoYbmgm2tH+pzV53l5nrPwl+GB8e65H9sVhpsDK83JKv 7D8c5r9UfhV8K/7d8R6L4N0K23TX8q2sYiUhYYlI3EKOQQDtHufaubiHGrLMhxmPvqqcvk7WX4nH gqMsyz7CYCC051f79fwR/Xf+zZ8LbD4feDPD3hyxt1SK1t0jbaMbnwNx9+ePoBX6P/C/SorcXet3 C/uLWMkEj+Ij/D+Yr+Msq/2jNPrFT+ZzfpFOX6H9AcQzVLBOjDsor56fqc9q97JfXtxdSfedi556 Zrxz4peP/D3w58GeJ/G3iu+Fv4a0mykvb2XIDFEHCJ6u7FY0HdnUd6rDUJ43G08PH4qkkvvepx0n DDUHUl8MI3+5H8ffxq+OPib4tfEbxH8QdWYNLqV287QM29IIhhY4RkcKiKqj6V49rXgT4R/FK1ay 8V+AdOvZlB3kWwEgJHJDYGetf1fTyzDRwNHLcRTUqcYJRT3slbR/I/JsRVrTrVcYnaUpNv5vsfIn jf8A4JqfBXxclzc+DtYu9C1GTcEiA82NDz2bt9K+GPH3/BLX4+eH7h/+EGubLxDC7t5SWz7JcdiQ 3T8+3Svk8fwfONKpissqc0FvGTtJel9yqWcSdWFGvC9+q/yPhTx/8GPi58Orm403xn8P9Qs5Vdoj JJauULKcHDAFSOvQ+vNUvBWteJfA2oW+r+GdaurDWo8lZoJGRl654HX8a+JxWGcVLD4mFu6aPfwW KcakcRh52cdmu592/D3/AIKC/GjwtDBZ+JrS113T0XGZ0aOY9OSw4z+Hr6V9teA/+CiPwg11oo/E lnf6HfscNJtEkRBxn5lzx19M18XjeHqlLmqYF3XWL/Rn6Ll3FVGvGNHM1yyX20tPmfWPhH44eB/H 0RuPB/j3TdRgI+WMSoJI8DoVJyT7e1dwdSvViS3uLHdFkS+YvQEk9/QZzXhqhyT9nUi4yXRnvubl TVajJTg+q1JzaPKbqSOZRLM4VQcbcAZwcnHf9RXK3mlva7Y5Yv3TSMxcAn2zx7E8f/XrRU3HQ53O 5m6xo+ia5YS6Vqun21zC64P2qBZFKNxgKwxk+o5BNfMXjb9jn4H+KpUgHhhtLvJIiEn0yVogXzgs 0bZRieeDivQwuLq4f3HrHsLRNSpaM8dv/wBm39or4Qsl38Bfjlc3GkAkDTdTk2PFGg+UASb4jkcA KE+vSptN/bd/aA+Fksdl8dPgzLc2QcLJf6fG8JVMf8DjYnGcl178V83xFwNkPFMZYjCJUMT3SVpP +8v1R9Vk/FmMwHLRxjdSn98kvJ9fRnqWif8ABRT4Z+ONW8OeDfDng3Wj4l1a+t7GJJIYSluryBZJ HCucqqbmI9B+I734Z/s+Tmfx1qms6xHY3en6cL6xtb5Ss2tzNdW1qYbbJ2s4Fw9weT+7t5TzivDy DhDF8KUa0cZUjKrVenK9FFXs3p1d/wAD978O+IMFmMsa8EnUdN07xS973pcrdn9mF7yfRXPXbuLU bQ6Pb6fYpJax7LWQmTLRxJE3zjAO5i4QEZAO8ntikeO4EDXMQ/eqduP159hX1aaaSe1rHueJ2JeD 4Nx9958kF/29NX/BMwp4L+S8NvLfDzVJkZiOoOOnrjH/AI9Un2qWBbm3ZwIREAVzhmwf5/4UW5la 2p/Il2ndmelrB++vowkNy4LFnwQBkkkZ5zjPNYUmsSRWtxeSEvBE5CRhNxYYADD0yRnHNUosUm4r TYrapdmU2xclisQcS/MAcnke2Of61nYkE8a6lHumVVKFQG2Z7k9+AKp2tbqYt3k/NnSWSxywzsYV j+YtGBwZDjJOOuPX8aqXs8/nWZujttNoCxgYyPc+3Xr3rnte8up0K3Lc7lNGtrmKzuXZHiAVyxbl mAycD06DHoOprUF9bRm6sobUIVRSmDt2AZz079s1im73kacqXzPKvFUDTEXaSKpJ2y4PzHp+Z69K wLW4bzZQVHmoApKoAAucHG0dc8/hX0GUy5a0XFHhZpG8XfU+Hddik8IfEvxNos8LRWBuXubXGcND Jl1HPIwTj8K9DtZ1urRd33HxtIIwoI3E/pn8a9fGw5azaXX/AIJ4+Fa5Ul0KOr2Aa2diDuZiAhIY Fu39fQV8teKLWfwv4mjvFYpE+GcYxj3JFLDu/NCXUMU2kpX2Z9XfCj4j6x4N1rwr4/8AB+pSW/if Sb62vrO4Q5ZJoWDITjGRkAEdxke1es/8FsPg5ofxBm+Dv7fvwp08J4O+JmmoviGK3UFNN1+ABLmJ 9vRiwPUfw+p59bh6T9vjMHJ/HT5l/ipP/wCRlL7jx+IIKVOhiPVfqv1Py/8A2UPH9r8JPiFp8esX ITRtaC6bcoc43sf3bDPcMcZ9GPpiv10Fw91cNtUlQ+1FXp26cc/ryK/c+A66qZXWoN+9Cf3KSv8A mmfl2bwUcUpv4ZK/3aHqnhD4X63e3NldarF9nsHZWLOAWZTjgKf616r4QuZNL13xB4dktkN3buZF k4Uup+Xp6DAP4195Chz1I4mW8dPlLr+C9D5rE46NXA4jB0trxlfzWj+XyPaLJr20uLTWg3l+S6Tq iNksy4Oce/8AjX2vay2mr2GnazZYezuYUnRhnI3AZBPqDwfpXwfiLg+fD4bHRWzcX89fzPS4JxKj Vr4S+6TXy0f5jhESG3DHA+b1xj/P41UlIyrEZyDk+h49v85r8maP0ZStqYVxDvOCwLe54Wq/2A/3 4/8Avof40N23Ildu5/aVcQlzHI1wQBkmNfX1/D0r47/bd/adsf2Wfgx4g8d5jm8UXMqab4ftJFLJ PeOrMGkA58qNVeR+VyE2ggutclHDvF4ilhKb96clG/a7Sv8AJahWrKhQnXa0im/8vvP42fFXji+8 ceMNe17xVql1fajqNw+palqLtulnmZwxbP8AADknaBgfKAMcDgrrVNMj1SxXTlcxFGV1wRsTP3s+ /P5e1fv+FoU8LRo4eCXLBWXyVl+R+dVqtWrOdSb1lv8ANnRC80rUbFYILURpHy0w6kE8HHfg+tUr K1tFj23O+K0yhl2DOFxkKD69D+NdKjVd3MmFk1FdCbyZWuZXggRlwUCjOVxkk9PQCtAW9pbXESSz Msgw7hh8obqRg/y78VpBqMFOW7InWjLT+uhaj8U2kNyy26F4QTGYMAg8bd5+np7+1WbAXE0drHbR nGN8qscHBIzn9M1UVy3dt1f8/wAiZvn5VFn6pfsMfs5XWsXUHxc8c6ME0y0k36Nby9J5l6TkHspz t9+ewNfrBFNHLK0TtuLJnaOeRgn+Z/Sv5944zJZhntWFOV4UVyL1Wsn9/wCR+p5Bg3hMugp/FP3n 89vwK8iiZzbsBjByAOvI4zWVM9xBcEZB3HOM8ID1/Hivj0/st7o93Tsfnt+2v8ebzwdow+HnhW5C 65fxqL2WPk2tu2Bjg8M4/IZPevyEa+mN9c20sQKNEWK4GchQVyD04P8AKv3rw9yyOFyOWKa9+u+b /t1XUV+b+Z+acV4tV8esOvhp6fN2b/yM211HTpGnS6hk+28mHamS7nPXtgVoNq8smyBCVtUBhkkB 6HGM57d+ntX6Clb3ZOy/r8D5mMX8SZebWnsbeBopi4kHzqowqjPYduK4bxt46/4lw0pCDG0YDeYO E559cYyPypqlGo1dbhKtOMLdj4t1rw54R8V3otdf8PQvbufM84HawHPAPp2B681H8I/2H/Dvx++I kHhPwY15aB5i1xOyF4rO2BOXcnHJA2gdzj0NRm0sLl2ArYyeihFv1a6erFllfFYzHU8NB35n11t3 fyP0sb/glv408A22n2vgTXbS9023Yu/mjypJcZYn0znn619Pf8E8PgQb3xNqXxGv7TdZwuLXTSwJ BVSQHGfUhnz6ba/BuO+NqWZcMSwtKPJOTSkvJa/nY/VeCuGquF4i+tV5cyipST83of0ReDNGWC3t 4gnQD8a+o9RC+HvCOnaOnFzcDzp+3HXn9B/wGvxXKv3WFxNZ7qHKvWbS/K591ntT2uKoUe8r/KKv /keR310qJI5PA/Wv5/f+Cun7Tatc6R+zH4U1AE28kWreLJImJP2gqWtrM4/55I4mcHI3yIOsdfZ+ HOX/AF7iKlVkvdpe98+h5Wf1/q+Vypp61Hb5LV/ofhhFcv53mIp2g8hueOO3Y10OgXUkPiCxniul jGQjZPy4yBmv6WnG8oKLtZ3v2Pzpq8JX6o9b1LX/AAxpUTQf24k08nzSCCJu3bP6/hVKw+Jun6bv t9M3wxvwt1uAKA9R/X8K5mqimude5rdefRnNKhBU+aD/AHmln0XodTa6b4f8RWszX9vBqkckWyRL hFkC8ZOAw/rXgPjf9ij9nT4jW89xqvgKPT53Jxc2K+UU46/LxUY/LsuzSmqeMpXktpL4l13PMo18 ThZOdOdm+nTTyPijx/8A8EpYYdt38K/iH5srn5bPUogVUE/3l+tfn78W/wBij9oX4anUJr/wFLd6 dG5UXVgPNRvcAfN05r87zjhDG5c5V8L+9o918SXmv8j6TB55Tqx9liVyz/Bnyto2n63oeoREQ3ll q8MmScPEy9AOmGB4P+c19t+Cf2oPjd4WMJh8Zyz26KsRgu18xSB0yD9R0PavhMdl+HxklGtHXv1P rcqzTE4BOWHn7u9nqj7w+F37dXw01G1tdM+KskWn6sUDtMkRWKRsYbB5A7YBr6i8O/Hn4FeKruOx 8N/Eywe7LfLDJMvzlucc/jXx+Ky3MMLVmo03OmrtPyP0PB5nlmY0Kc3VUKsrJrbX5nrsmlvKiXEd vHKhBJeE9j0PXmskeH7ecqZJXW7wTslGCRzgf5/+vXHTrU6vwvXszqqUJ0pJSWnkVJ9GhhijFygB DYBA+YN257jg/wCRXM6np9nPby2txaxT27A5hdAQ5HTKtkHjPX/Cri2pcy01M3y9dzyRPgp4A0Xx QnjnQvAun23i1N8f2qK3VWUNkMwCjGSCRkAHkivevD/jrxdoNo1vGxm0x3Vp7S7hS4iKR72VMOC0 a/PnapXlueea1liakqiqTd3a2uunoehlmZY7KcSsVl1WVOa6p2+/uWtW8T+HNbijlfwbBZam7E+b ZTSRwsoxhUibO3GTzuPb0zXD6gLiQbdjxIzbI9vO7gkE/wAufWuap7KU1KnG3lfQ+z4l8Qc24myj D5VjYxShLmlJXvNpWi2um7+ZntYySWJLBPMK425+c/LnFZTWVs8LzXKmWHgtvJ3qwxnp1HFRdaqJ 8AlbR7GO0durueRaBsEbt2V59q5lWinnuvMbNoHwhBwCTzk49G/p+Glr3a3MpNepSumkNwZBchIw ilowQBgAA4HOaduhe5nu5JPLtJFACE8gkn07dMY/vUt1clK71ZvRWxmVSZMy7cFSCQOD+fH/AOqm X9izw3UIwXPRt/3AAu7ntk5GO+Kw+0tDezaZteF57zUIN+zbAkQREB6MCcNnnt2x1rc1DTf3E+ox 3Jyit9rbOGRCx7f17Vi/i5F1ZorygmeXz3dvLI4jkMgJPlsx3Edvp2zmsSxnFhLetvZ3kGdzLzuT 9Tyf0r2cvfLWjbQ8fHcrhKSPFf2ifCX9q+H7D4haTGTqFnhbnaM5hORye+044ryfwrqnn2bReZlG UDLDpx3Gfw/AV9Hi1zJS62/FHz1CVpyR21xJGqABDvxuXOcZIwO/t+leL/EfQV1PTJrpHLSKpAO0 Z46fj/iK46EpRrJnRXipUpI8++FustbXE2kTybpVf5Mt9489Tz3z+tfub+yFY6f+1j+y3+0p+wn4 klR9fubCTxz4DaVd3k6pZgC5giz0Mi7GCjGR5p7celgKiwud4WrL4XNRf+GouR/+lX+R5uMg6+VT e7jr9zt+TP5HfiG+u6L4t1bR9YgltNU026ktWt2JVreWNipBBwQQR+df0wfsS6v4R+LXwF8G/ECI m58Vwx/YNVMxU+TdRnYQAegYFXGcHDD8f17gOs6ecVsFJ6Ti/wDwKDv+Vz8k4sU6eBp1afflfo1/ wD7sNqb2zgjMICxAlgnUc9q848d6FBo2ueHPG8ZPkLL9jvt2QAvABOOvA/8AHa/YlfklDa6f3rX9 D4TBSTqSp/zJr5/8Od1BBJeRrJHdZs92VCgjAHIAJ+tfUXwfvYD4f1nw7J8t/ZSLdQgjBeKThwOf 4X9h/rK8Li7BfWsgxHIvgtJfJ/8ABZ28OYmOGzqgr6SvF/Nafieh3M6o2VbOPTJxz/8Aq5rEmumD kn/Vk8deK/Ardj9fvpYgkdMZU/KRjr15+uah3x/88z+T/wCNJtrRILtdD+y7Ub2DS7G61bVLuODS 7eCS4nllk2rDGoLFmJ4ACjJPoDX8eH7d/wC0TJ+058ZNc1+y1qa68B6czad4ctCHVEtchWn2tjEk zqJWyoYDy0OfLFelwphXUzOWK5XJUY30/mk+Vfg5M8/OZ82HjhlJR53a76JanwwmgJaW4so2G+Vl UZIx1yc544wT+Cisa80W0sb68uIGBDRgZK7gM59B3J/XvX7R7qd5r+mfDNO6tsy9oen4doZd4Ugj lcfKOBnNSXVnfxWt87yF4fuMAPlVsZJ/Dnr6UleU328/uNpVOVa9jmIPt1vCZIUdYMli7Mec84A6 nPX8q7CxljvVRbu0Z3kJzsblm6kn0HUd67Xyym0919xxNx5dP+GIb5Y4kjS3s/KZvnDLwHIPzDkc 4BB/GvqT9lT4M+Ifjd8QdM063gki0KErc6zchciCIMMID2Z8EKPqegNcGb47D5flWJx7fwRbXm9o r77feb5Xh54vMKOHWzkr+i1Z/RhpOi22iaZp2gadZpb2VtAsMcKcLEqjAXp2AqC8ZLeVGSIhzw23 oB6D0Ffy1Kc51JNu7k238z9qXLyK6tYqSP50ayrKFbdgEnqe9fN/7Q/xr0/4EeBNT8Z3zLNqBzFp toet3cODtXHUqOSfYV1ZdhJY7G0MDBe9UkoL5u34bmGLrrD4epiXtFN/cfz+eJPiR4q+IepXniLx Reyf2nd3JleQZ+8SCMjpgDt6AVx63VzZG6n+2G4mJKmXnuBg9OuOe3Wv6nweDhgsLTw1GNoxiopd kkfjGIxP1nETqVN5Nu5astYUTKRbboyCu/BPIycZH+eK3JJ7S72i2hcST48yA5+bHf25/nTnrOKg 77L5dQUrR1Zh3F3b2ltdLcRu0mChVSTtwCfyB6/jzXzP4v8AFdut1ObO4WWBI2R8ctIW9MngDA/y DXp4WCvy7rQ4cXUlayZzvgbSNW8b+ILLRtHs5JtSupkgt4YxueRm7Adhkkk8epr+kn9mb4B6X8D/ AAVaWU1rHL4uvESTVLtE+9JjhFPXYvQD6mvz/wAT8yjRwdLKKbtKo7v/AAr/ADf5H0vA+ClLEVMy mvdjovV/8D8zovj/AOLbrS/C1t4J0hnHinxC5sIxEx3w2pGLiTjleGVARzmQY6V9efs5/DG08EeF ND0W2tVRYIgX2gDMhGT07DgD2FfzBxPUSjQw0OurP3vhunKNPEYifovl/wAOfoJ8PdDS91O0WQf6 NH+9lJ6bV5OfTPA/Gui8Xav/AGje3U6H5M7I/ZR/j1rzo2pZao9Zy/CKsvxk/uOOu3WzTyhH8ZP/ ACR8h/tI/Gq1+Avwh8YfE+4hjn1GyjFto1jIwH9o6pLkW8fPVFw00npHE3rX8a/jS78b694j17xX 4vF1da5f3ct9fXkgLm4nlcu7senLMxx/kfufhRlMqOV181qQ/iSsn5I+Q4tx9L67SwKlrGOq85a/ kcjaysDmQZfrg8ZOR+Y/z3q7FN5j52YjxjP4Z9sdq/Um/e1Pm01yLm2KkkbMNyyE5PGCTjpViw0u 91Ob7HaIXnkbbwPufr2+var6tWOepNRhzN2Ppnwd4cHh7ThHDcH7dID5z5JHfoOgHHXvXYxnyGRo pC8QUFieBzz09aIpQbZ486nO+aS3KME4uZ5nlzsB3nnkduMfhWlcX6yWUKiASSZA/eNncCcHIPtX RGslutfLZmU0lBp7Hkvin4H/AAk+JDSQ+MPAFhcytlVnhiWOQZGc7hgj65r5J+In/BMj4e6vbXN/ 8MvFs2n3p3O1ndZePfjgA9QOnGa+WzrhjB5rJV6CVKt5fDL1Xc9XLsyr4Si4t3gfll8a/wBiX49+ Abm9vrnwhPqGkLlVubE+aMZ6lOoH4f1r5HtdJ1HQ7kpdQS294rcCQGMqwP4c5H618HLK8Zl1eVLG UuW+3Z+jPoqeOo4mKlRnqvvR9E+E/wBrH46+ADaR6X47uJrKICMW98RKhQDHU89vWvuzwJ/wUltL 02lp8QPCLRq22N7uzcOoxkFiDyfXjPJr4zNuFMNiakp4G0Ki1t0Z9zk/F9fDpUMzXtKff7S/zR92 +AvjJ8MPinapd+DvE0TygDMO8CRc9Mo3I9OnrXdXWlySeXJDErhSW+U7Tz19z1r4ibrYOrLDYuNp I+6VOjiqKxODkpRev9f5HMPD8ssVrZlZVOcY+bnPI/l1rMjmuXk82YlvLUI2SVyOMZAxk4x+dayg rOzvfY54uUWotEV3N5s26Qpgq3lEEAhgAMYH481XlulRDJcSNvjGzBOcNkfp2rDlaZspbu5jwu4n +2RndJKjJzyMfy/yabeNJP5hjcLtw8iqBk8ng9vWpluDu9jFvbi08meJXUSFi0iuBuJbkce3p7Vx 2oWk0EMhtrR3ecbg4JCqc8nA/ADp1qtrXMpd0Yn2AQTmFAWjVlbDHhvlLEKe+MdKsi08y9hmYkFZ 1G1m4K4B5HbHT+VEvzM4x15fM9GtIsSDKRmMOu3ac4U9ck9smp7yWO4+0iS2UQs6v5iNymB1x3A7 iuR7s7Xe2urOK0y+n8O6vII7pV03IYRKCVLA56+h5/Guku9TZI5HnIYXSlGLDgoTkcD9D7CqatLm XUzpytGUX0OK1R1sLayjjiVYjhYWK8hcc9Ov1z9a4d5DHqiMNzbGaPr8uT3PTn5s/hXo4NqM4yue bjI3i0jqtFtk1i3vvD95abrS5ieN0PIwQQDn/PWvhFdOn8D+NNY8K3zukcFx+7wcl0PKkZwSK+rr WnQun/TPmYPlrXZ6Ra3CXZXjA4+Ynp/np/k1n38C3EJjkhJjfKc5wT79/WvMbtJ66nffRpnyl4qt ZPCHiqPUbfcLcPlio6jPv+Ffbf7PHxt8Q/CTx78OPjD4NmZPEGiX0N/CocqswTmSBjg/JKhaNhg5 DmujFwcqcKkXrb013RxUVF+2wz2d/wAdDlf+C8n7LugfD/4/+C/2pfhTbA/A74v6Lb+L9JljjxHb 3EsatcQnAAUhmBK9QS2eRXzx/wAEqvjlD4O+K+q/B7XLlv7B8Tqr2a5JVL+IEjHpvTIJ/wBgCv1P JcbCjxBgMfHSFXkl8qsVf7uZn5hxFh/bZVioPeKv/wCAu5/Snp25re8ZrdshSuxRjjAAx3PT9ayN d8PDxF4Y1DRLuRmuLpS0I2fddeVHse341+/QilOPkz8ioVnSnGp5nKfD7U3vfClqkqP/AGlaTmCY EcEjKnPftXvHgbWpfDHiHSri7ljSymdoZ2Ybm+zyDDdeuAdw91FbVsL7bA1sNKN21JfmjB1nhMxV WP2Jp/c7nuOowvb3lxDIc7GIyOjD1H+T1rJni3Rvgjr24PT9K/mOvTdKpOm/str7mfvlOanCM11S ZTSQozRyf3SPoP8APNG6L/nu/wD3yKxfmXddj9g/+CuX7WM3hnwr/wAM4+C9ZWHWNYtftfiWaAv5 lvZD/U2gK8ZuCG8xc58pNpXbMDX8zttc3EGp3EdqrOPKLmZuAzAdRz2PPFfoPA2DdDLXi5x1quT+ S0X5X+Z8nnuIc8bKnF+7FW+fUnn1VdRiEjBvOViAOwHf8zxnnp+VXTrm7hF3etbAwkbQWbJUD09z yR6c19vCUk3B63PBa9+5sRX5urOe3nZk1R3MY+ueOnP8P611nh2O2ns7rw5cToZVfy/MPK7j1Yn8 Mj6VrGzT01T/AC3FUWjSdrpPzNOTT9E0VVtZ5BcOu4vswSD278cnrx2rHura4jurWSwfZbTBtsTL zHn1PvWsZKSdSez6GSozskv+CdH4a8K+I/Eeo6PoFjpcl5rN1OsdnCoBaV3PbHTsea/ok/Zx+DWn fA/4eWvhqGNH8Q3JW51S6VcG4nxzzj7qj5FHHA9Sc/mfiVmKpZfQy2lLWq3J/wCGO1/m/wAD7Hg/ B3xFbGzXwrlXq9/uX5nukszwujBg0p5J64zzWY9zH5SieEvyRuPFfiiT3W5+h6bNaHM6xqltaWNz c3dzHb2EEe+aZzhYowMseenAr+e/9qT413Pxr+IdxeWt9I/g3T5WtNIhJKiRQfmmI/vOQOvbAr9H 8OMsWKzl42orxoq//b89F9y5n9x8nxZjXh8AqEXZ1H+C1f6HzbLeSwiOy+zl13ZJAHqSOf1zVVtN u5sRFM7+cAjCrzzX71UvNXXQ/MY2TcpI0dPfU4A9upRYCfkPGB/9cU7xHPNp4EcRQShMNOSRvPfH +e1FOEYu9/eZM53a5dj5/wDFvinVbTatjeEIVIO3H7wN256kk14kllHfsUljxcFmMmDzKxbhR716 dKlGEOdo83ETc6nKuv3n7qfsG/ssQ/DvSYvix4s0oL4sv0BsYZRltPt2AzweQ7D8hX6jwTeVBNfX E4S0jBdzIcBVUbiSc8DHrX8z8X5ks3zvEYqMrwi+WPpHT8dX8z9p4ewUsty2hhZL3mrv1ev4bHzT 8FtLuPjL8WNe+LN5A/8AYdvKLTRopF4EKkiNvqxLTHv86g9K/XPwboy2VtCgQZxX41nNZ4jNJK+k dPuP1bAUvquUQj1lq/nqfQ+nn+xtCk2OBc3K4O3qEHUfia4m+mlmZIYvmmdgkajHJJ4qZKU3Sox8 lb1f/BPIwyTq1K0ur/Bafofzu/8ABQj9oO1+KHxTj8FeHtS3/Dnwt5thHKhOy+viR9rucYwwLKsS E5+SPIPzmvzruHa8tGFtdAvgMwkUfPzwAK/s/hbL4ZRkGDwMfswXN6tXf52PwbPMZPMM1xGK7ydv RbGe+j6NfQRC80qEXm4g8bPb8Otc3d+AtKuIP9FeWJ2PblQMnOM+4r0q2FpSalBWb/rYyw+Or0rp u67F7wV+z7418fa1JoXgy0+13Ij3nbkBFGMsxPQA8c17T/wz546+G8SR6t4OujIfmuJ1iLBz6AjP +c14NfMMLhMd9RrVVGdrrtr+R6kliMVgI1aUG43s/kM1G0fTLWRvIKPtAwQQyn0wfTkVhrFLJawp Ko3gngn1Ndalf3t+p5vKkrMtQQQSHyIrYov3HyeGOSep5/8A11CDIbm5KbVthxu9G74/OtIwclzr czm7PXVGppNha3flFpMSYOTyMn2/z/OtbybhvMaNspuI452e4/Sud88J2T1N6UkqVnsZUFnNc3U9 jJvkR8kEkMG74Oeg7fjXl/xC/Zu+D3xBsZ18TeBNOnvJckyWyokoHsyjg55rujSwePwzwuNjzevT zT6HPOGIp1ViaD5f1PzI+MP/AATJ0ieSVvht4gmtJyS32K/yygjnCtnpkivz18ffsvfGL4VFpPEX hKSTTVORc2itKhAPU457frX5vmnDtfB4qpiMK/aUbfOPqv1R9Ngs0VSjGOJ0l+B5p4S1CTQ9ahul 1K5067jBCyQyNHID26c+nFfVvhT9uH4w+CjFYXV5Bq+mRcI12u2Rh1+8uc8d8V8TmmSYfNny1o2a 2ktz7TJ8/wAVlCvRfNBvWL29V2Z9gfD7/goX8HvE01rovjeRtG1lzhvOX9wTjtIDgH/PvX2Zouq+ GfGVja6n4Z161vbNv3sbRyq4bjjkZx1r8zx+AxWUYl0qq5oXdmup+n4LHYHPMOq2Hlap1j1X+aMj V9PeFkLWwB3kg/MVIOe46fjWLNFdW4YoVmhP+sB5APTg9PWpSjUheP8AwxnNTpVHCojPjm8kvGId jr8uWOOvJP6frTXE3mWkUZ2OwLyBRkY9P5fka53HkZopXijDuGhgktke2MilwGdl+4OefqOn41fL 20stpGYSwJ2scAKFbv8AoKmSa2BNXaZg3Wj+fBFJYxmJkmG92IITBGcZ5JOQOP8A9Uc+jxbALh92 3Ll8jcHz6fgfxrNN7Irk+4sQJL5T2zTxmMocpjO0Ekg5z+dTXl1OsA8qNSIsou1cs24/NnH86jTn 0X+RabUTl9T8gPBfJBgx5XDH7rDGTj/P611Nq9pqcNuoXeyAAsT8rk84I7cnninK61fQhNczS6nO a5bNNAyNIWEZ3kLnbjg/L7dPTOPavLtUe4E09xBMoHI2OAoJxwzZGeP1rrw7SaucOLTSdi5p2qXX 2xLm0dlPyMvbdjqPTr+fNeR/tR+EszeHfiJpkf7iVFhuCnXDEEE/Q8f5xX19FqVBLbQ+Tq3VZ2/q x5r4dvoZ7aONWCyAKSGAzn0yec4wfpXaPbGSOVI5Adrbzt7H0HGehrzZq0k2z0ou6ueK/FDw213Z /bFRjGRh8568fj1Ncn8I9fLbtFnK+ZD8y5bnHGDjp/k10358I2nqmcd/Z41O+jP240vwdH+3r/wS t+OX7MEmbn4xfCGeXx34LHDSz6RMXe6tozkltkzTZA4CzRDtX8gPhzxNrnw58a6F4n0OYweINJv4 7qB8YZJYnDAHIHHGCD2yDX1OWVZTyjB1U9ablT/8Blzx/wDJZr7j5HN8PFYnEYdr3ZX+6S/yZ/Zt 8CvinB8ZvhX4J+IOlSxnTdSsUlJOAYpCvzow9VbI+or3LQmgXzbYxl1Vt2C3IPUn8+a/qDA4hYzB 0MTHacYy+9XP57rQdGpVoTXwtp/J2OIOk2Oi+PtVS9m2W+tR/aLOEKQElXiQluhz6V6HFCt7bosF oA2zasjD7pGc9fzr3oNym3a3b7v87nLj0o1o1Oa/NFP8D2/S73+1vD2mXUsjPdwD7JOeu5kHDe+V 2n86kaMHdn8+5P1zmv5u4pwjwWfYyhay5m189T9u4fxSxeT4Ste7cEn6rR/ijIupUy2OuMgHt3x+ tZvnf7KfkP8AGvm3G56+j3PCPiR8R/HHxW8d+K/FnifVBe+KdZupb+8n+YCN5OQiKclEVNiKmSEV Qo4UVwFxNHbtbhoMFIsM3TJOPz6D271+3YDDQweEp4WHwxSS9ErH55Xqe2qSqy3ev33Kd3ZSQwJL Df48xgUUA5wucg+n+frSQ2zRqsLSj7NG2ZVbbln2gD6dQRXowXMlp/X9fkYL3Wk/62/U3oruS7vn hSNWlj25cKMg5GTn6gjPFLHa6iNQvo5lKIqAO2QAWBbGMdfu8n3960pezim5ddvQVbSSiun9f8MP t43TUw8l2oMu53yMjcAW/H/61bsNnJKt1NcXm6BF3qQejdAPc4xxRNXaTWlhe0jGXuPsfsF+wb+z 3N4e0uL4yeM0B1S8T/iRRzod1vC2FaUA9GYZAPZf96v0se7G3ekQ8vLDPJ5x1/Cv514zx7zPPsTO PwQ9yPa0dH97uz9XyTDLB5bSpNav3n6vv+CM0sbc5nx5igjHvWTdvNvYDhSScEfdGcHj8RXyytd9 j2el+p+Wv7cfx1+zxT/CTwxqREpQNrM0THIB5WEEH8WH0HevyWs2022SWS5n3SB2BYZBjPc1/QvA GWvL8hpVmrVK37x+j0j+GvzZ+WcT4t4nM5UovSHur5Xu/v0+RJDd+RI0lvJuQttAI7+vPTj/AD6X 1O+8Bjm8uARsGVskE8nqK+65btqW9v0PmW0rLQwY4p0ldrkty/Hl54BGc5/L864zxj41sbZzbASO pJxxwi8Zp0kpOKmRNpptaW/r9DwS61IXVzc26Q4U5dNoyTjoNx9M5xX33+wh+yxJ8Qdfj+Kfjqzc +F9NuBJZwSL8l/OP5op/M49DXBxZmkcnyHE1Iu05Llh6y0/BXZXDuBlmGbUYS1jF8z9Iv9WfvNaq nlpwvl4AVVUDgcD9P5V4P+0P4muZdL0T4U+HpHPiLX223AjzmKyBw444BkOIxyON57V/LVSsqUKk 5PbX7j95w9N1p06a+00vxPtT4DfDW08JeHtL0mCHAhUbyBjfJxuP9B7AV9ueG9L3MigYUDJPoK/N 4N1sTOq+rPu8xmqNCNNdEdRqd1uXYowirgAdq+C/23f2hF+AvwX1a+0e7VfiF4hWbSNCVXxJaoV2 3V4Mcjy0fYjdpJUP8Jr67hPL3mnEeEw9tFJSfotT5PM8T9RyfEVr68vKvWWh/Mk19fagsaOxY8li o6AmqVtciITM6MqcbT/e5/xr+xFzKi3H5H4JUd6qT3NeWXZ5Rnj3Kw3ru/ujgEnPWvSfhx8L9f8A iZ4msPDXh1ZZZpWUyyDOy1TPLN7DsPyrDE4mGDoVMTVlZRi2/wDL5s6qFJ16saUFq3Y/cn4F/BLw z8HPCz2WjxpLqjw/6bcyKDJNyM89hnoK9nbSLPU4MS2EbKDvYsoIZR/DgjFfhONxlXHYmpiq2spa +nZfJH6Nh8NTw9KNGkvdWnqcNrvwG+GHi6C9t9V8KW3lzbQz+WAwOc/KRXz54v8A+CfHgzU43PhP XZrORh0cb0jz059/WvVy3O8bgklGXPDs9TgxuW4fEN6csu6PlPxn+wJ8ZtDR5dHWHUbZWbYkDESu uCdxB+hr5O174YfEDwkzWfiDwhe26CQqZDbtg4PJ3Yx+GeuK+7yzPsJi5cknyTfR/wCZ8vjcvxGG g7q8b7op2cQjiitMBZUctmQYI9q14QDp9yIgUjB6nncTjJFe29Za7vqcSUvZaI5G+txbSSRvM5Lq drx5GQexrLiS7010Uy7X2bn3E8KOp6/SuulRt7yWpy1Ks78svkeb+IPH+oy3kqW9wJUVmjy6jB7V xF1rUGqRPb6vbK1sQVK4yCO5Kn64rLC0nCu51Hvc9RxcqaT3VjyvxF+x/wDBr4yxu8vk6fre7HmQ RBH5Iznsfp3r4v8AjR/wTW8feGY7m/8Ah3qMOsaeCNsUgCXB9uOG+uBXj5zwnHFc2Py1pPfkWl+9 uz8goZ68HUWHxcXy9/ysfjr8TvAPjTwbr93p3izw1d6dOrldtxAUBAyOCcZ/CrXwx+KvxJ+GesQ3 3gzxTdWap1jSUmN89imcf561+MZjhFVnWoYqn1aaa1X+R9zl+Pq0J08Xg6lno0118j9W/gv/AMFJ bO+nttA+MOjiIEBG1K3BZCx4yydR36ZxX6L+E/Efw6+J+lrrXgbxDbXFrKN+YJFO056Mucjp6dq/ Ncwy+vlFVzjeVJ9f0Z+u5XmuFz7DunK0a8en6ryGarolzaZSVSbcMHEmMn8+/wD9euaiu2SOfa28 KCDtPKDB9OgzUe7Wp88NhyUqNT2dTQJWglE5gQ+eoZ2IUsTuHf8AT6VHIzqskMcJYgKHJ4AG3Gc/ jXLNPY1TvrYqeQyCdlUYBB6k4P8AXnHPaqyyq9wxeAeYzuHB53+nP+elQ1a7vqXdJETRRWiXTyjz EBCBl+UqM549hnp9cZqvp93b3LN5s5EZVownTgEYYfTJ/KpV9WmF+hkSaVEZrhbONzvO0BwSSTwO KpaNA9jc3llb3BF+jAJEw4OSefbqfyp3TTizJRtJM6vZDLaSC4gK3SDYG3Y9zx3x715l4osbSby0 dMT+b95PlTIyTn24H8qqhJ8y8iMTC9M4a1v1d3hUSfaYk5Kv8u7J6D0x+v0rv7ewtfiD4B8QeE7p Qbry2aIMTnnnqR2b+dfZ4Nv2S+R8fiXaququfC3hR7jStT1PR76Ai/tZGgkGDn5TgH8eP5ete5Ws SyJIVUBepzgHI+ntz/8ArrgxCcZyR10daatuZ+q2A1LS760lXhuDJwCv49ug/Oviy6jk8F+NYHY4 haQRk57ZwOv1rbB+9GrTerZhi1Zwq9mj9Wf2D/2jk/Zq/aO+H/xVljkm8Hl5NK8SWgUlb7R7xDDd BlwS2wFZ1UD5mhUV+Sv/AAVl/Zx0/wDZ1/bJ+JWn+FED/DTX5h4k8NXcanybmwvAJoyjdCPn7dse 1e7kNaMsFjMG3qpQqL5pwl/7YeHn9FrEQrW0kvxX9I+2f+COHxmXXvDnjn9n3WLvbPZsdZ0nLAN5 DkLOgHX5Xw+P+mhr9zLWC4sppLfSn+ZxjJ9R3z9f881/SnA+IWL4dwzlq6fNB/8Abr0/8laP534k o/Vs7xNNrRvmX/byv+dzH+I+kXVzoen65EhF/pUqXiqvJZDxIAfTHOPbmun0S5u9TEKwXKGOS3Vg yY2kdRjtyOtffUkkoS8vyf8AwT5/F8zw9KovOP6/qdf4H1NrS9vNGlmJE64GTkLIhJHXp3H5V273 DBmV5eRwex/+vX4f4nYP2Gc0sRb+JBfenb/I/U+AMU62TSpXu6c2vv1X5mRc7mBZBkEH2B/z/n1r P2y/3V/77r8zlJJ7n3drnyTYrLpWt3duw3OmYXAYFsgHdk5H0wPzOKsapatfqt7Zyjd5ysVAwI1C 8c5yOuK/dE7qLXVfgfmUXNcrWv8AVyC+lvYU0+8ltkyAEAIPUKF3cd85I/Ot60GnPZnUZYM4cbu2 706+2D+Ndia5LxdktBTTvG2+5sWrwwpPJp8LSTyMRuH93jr9DnH4mq89+sKSyCLy7k5UbjuLcHdk 9f8A9dXBRaV9yK3M21fYp6VJdjybYW6PvTIMmP4uQa+0f2V/gLffGr4ipP4gib/hANKdbq/dBtW4 5+SDP+2VycdFB9RXn8Q47+ysoxOOlLWMXb/E9I/ideTYZY3H0MO1o3r6LV/lY/el0torbT7CwiWO 1iTZDEqgLEi8AAf5xVy5vo4mniiUBCoOBzwcHbn1zjNfy9Ocnebd22/xP2ZJN8ttDPQTSF5ERSwR iFI9wO/Hc18vftKfHSy+DXga/wBdkkDa/ebrfTLbqZJWyd7AfwqBk/gO9dmXYOeY5hhsDS3qSS+T ev3K7McVXjhcNVxMtoJs/n71fWLzXdRvtd1zUZri+u5Hmldz1J+ZifXr/SuQtzBqV3cWTK25/m4H Xpx045Ff1TQjSw9CnTpxsopRXklsvwPxStKVSrKpJ3lq/v8A+HHSFrZpLWS3JKgnjjk5x+A/rXRI 2nJYQwySE3+drgHooB7/AKflXVF7Si9/6/Iwqpy0T9P1OXv9Vgt7JWEeZsBcofvknjPb0FfP/i3x NaPerN5CGUEBlcH7p7H6V1UKOq53qv1OLETdrR0O+/Z2+DWqfHv4gaV4Y0WOZfDlq/m6rfqmFigy PlB/vNyoA6ZzX9Ifg7wpo3gzw7pfhjQbRYdHs4VhhjQY2hRj8Sa/HfE/N/bY2hlNN6U1zS/xS2+5 fmz9B4Jy32OEqY6a1qOy9F/wfyOxvdR0zQdMv9V1KYQ2FtE9xPKxACRopJJP4dK8Q/Z78Nan8SfH WufGLX4WJnm8jTIpFH+jxLwigf7KnJP99ya/Ec8r+xwE295Oy/r7j9YyGj7bHwVtIq/z2/zP1n8H aItna26hcEAV7vaQ/wBm6e24YmlUY+nWvjMJG0eZ9j2s1qc9RQXV/kchq17BHHK1xexwWiI0s88j BUt4kBZ3cnoqqCx+lfy9/tfftA/8NB/F3XfElvHIPBtkF0rw9CSQEsomcq5GBhpWLStxnMmCeAK/ bvB7K1VxuLzOa0guWPq9/wAD8747xXs8Hh8DF6ybk/RaL8bnyYN9lC2ASZCMBRyeucmrn2O0Yb0O ZSd+Gz8oHQCv6Mp03TpJyd7M/IJzvVuj0z4a/DbxJ8UPFFj4b0XTXdmwJJSuUt0z95u2Pav26+Cn wZ8L/CLQodL063WTUpVxcXzKA8z+5/uj0r8v43zWL5MtoS63l/7av1+4+54cwVoyxdRaWtH9T3D7 Od0iwykDbg57gY4rptLAFwu2ZVVkI+bnHHcfWvz2EY8y11ufUNy5W7F+CMta3EEhHmo4IA6BQeSf bmujiAjiaMMzRkAqQM7iD3PatldaJ7Iwbvq+p2FnJGz2V7cwK0rqVEcfVivALenBrQuPD/h/VI45 LjSYpFCbfLliVwzk8kf5712RnH4tn/wzMZRvpujyHx3+xz8BfiGtxHeeEIrS+wZBeWf7tixH8W3o c/yr4/8AF/8AwTD+02skvgDxYUKqfKhvY9wc8hQHHPpzXuYHO8Vg5JTfPFdH09HujycVllOtF+y9 1/gfB/xB/Yc/aG+Hd3c+f4Omv7Ln9/YDzuO+FHK4/pX56fEefxNpGoS6HeabeWIDGJxcwPG0hHGM MBx2/rX3+V5zhcXTapztN/Z6nzdXA1YYhSqqyR5FLZnYw/5aE7iDwTVVYIwq7UyTkBRyRz1/z7V7 Ps4yaa7M3jOUbq2jPYfh78PrqSaDXdalMNoreZFCzENJ37dq9ovtccu5WGOOFFwvy9B7etdlCc8N FNatnz2OrQxFa3SOnr3PIfib8I/hx8VtLudM8d+FrS+tnj2gmFQ6n2frmvy2+NH/AASRsm0i98S/ BTxKI7vb5n9kXr538ghY3PI78GvkuLeHqOb0HjMFC2Kja6Wikut/Psz1uHswnhayoVZ/umm9elld H4y+P/hV47+Ferz6J488MXVhqMbEZmjIWT/dbHI/HpVz4d/E3xh8Lr+013wHrc9lqSOXlVXLR3AB 4DoeD/npX4ljsFzwqYPFwt0ae6P0TL8fKjUp43B1NVqmv6+R+1v7PP7anhH4p21p4e8bTQ6f4r2I CZDiK5YgZ2k989up/GvrHV/CUM+b/RGXfjdtByrg88dj2r8xxFGplGMlh6nwPb0P2PDYmjneAjia TtNb+v8AwehwL3xsG8i8XZdbWUjbg4/xyKdDdhmkijA8oqGkIORkY4/z6VpVo6c8X7rOeEndwe6L piimnjEE+ZB1XcSCP5e9QmBftBjdxjf8jKm3HPOMdO4+lcjve73N1qZd3b3ClLUp5thKq7Tg4yB1 yfT86x5NLMMcMjOu9mK7i2ML97p+NNJLRPcGnv2GLeQQ3RYgvPGBvAbAKjnH6+tY1o1vdavd61Dc qrhWjO04+YHvnrjnHrmoaS0Jum0vM6FkWe3dtzyOBxL12kYH689v/r87q8H2qyvpvMBO4ggdWwBj B7dfxzUwfLIqpblaPJ7uKOzeOVY1JkBVwOpk42DP6103hzUV0HxFBfxKBbthJgT8pDYX1/z17V9d ldTnpKPX+kfH5jDlk+Xpr+p4p8fvBsfh34hW+v2S403VI1YupIXzOnP1GPXNJpIiNvA7NuDH5WAw fc/0pYte9fYuhyuF1sawsjL88zYlznb1CnPBPOOma+Y/jV4YlZZdXhhBBXJYc4YZ5/z+VZYOdq61 8h4uPPRkra7mp8JPFE19o26KYC8t/kfefbaf0P61+iX7f3wysf2wP+CVnwY/aE0K0ST4p/Buc+Cv EghQGSTS1/485GPXAhaLk/xRv0r2cjSp5tKh/wA/IVI/NLnX4wPJzde0y6jWts1f7v8AgH87n7Jf xfuvgV+0B8PfH0c5i0uG9S01IbseZZzEJNu9QAd31Wv7UI5bK8tUu9PlMkFzGskMiFSNjjIAPSv3 3wvxLnQxuBb0jKMv/Ak0/wD0lH4Hx5R9lj8PiV9uNv8AwF//AGyNxRGIlstYiDGSJo5GOCCjAjHt 1zXA+CFuLGK80I7Wm0q5MRRjgtC3KMD/ALpxX7FQS5En8vnp+iPg6828LOKXwtP80d89vFY3A1KD 5IPMGCzZIbr+GDiu9kKTiOaGXIkw4JJxg8n/AA/CvzbxXwvNl+ExiXwycX/28v8ANH2vhriuXF4z Bt/FFSX/AG67P8yhNOkW5m+VQckg4A/P+VQ/2pZ/8/X/AI8tfg7XM9z9fcZPY+QpbdJBcTZcqshL Sru3XDn7wx1568+tFtb3cgnthblVLKiKWOC/3uuOSME/UV+9QjyatW0V/wDgH5kn7sXF+n+fyNUi EWUENwGN1G+4qM7XZj0PrwP1NXo7a6vI9qIBZ8fPjAwW+YgduMj6Culxi43e35kQm/ac3Q2YnXTI J/scZQBhEpycccZ98jP41UstOnvLq6ttRWNQqhV+b7jck9eM88n2p0rObk1oTUeivu9vuPUfB3g+ 98aeIfDvhHwvYmfX72RLWzjUbfmbGWJzwFG5yegAPFf0EfBn4ZaX8JPhto/g7Row92sQa/unHN1O dhkcd/vAADsMV+ZeJeZOGHw+VxlrJ88vRXS+9t/cfZcGYNXrY5rb3V67v9D1a0LrOkZA87bty2Dt GD+vOaY0B8x43cbgu8e3Uk5P1/Svx2SSd0+h9+ru5iXF3GMLGzBdoJYZznP+NfmH+0Z8APjL8T/H t14lSW0ufDEIEOm2XmlTEijPPbLEkk/Qdq+g4UzLB5VnEMbjYtxjFpW6N9fuv955ee4TEYzAvD4e STb1v2XT7z4g8Y/AD4taJbvHP4EmYoWI8lQwbOMZwMnv+VeW3PhLUPD7q+p6BeW9+GVCJIWBznOB x9T/AJNfvmXcQZZmCUsNXi32bs9fJn5dicqxuFvGrSa89/6+ZjyJHLamS5gLzOzblddhUducZ965 CdYkvGWNcR4DFh7nHHPpXvUqseZW69jzuRrnbfwnlfjjV10cEeaJZ5D8mwcKOfw7/wCcV5noHhq/ 8d+M9N8K2cU8t/fyJHbRxxZ3HjGT1A4Jz6Zru56NHC1K9SdoRTb9FdnmSUsRiYUYL3pOyXm7fmf0 S/s3fA7Q/gR8PrLwxp0SyazKftGpXO35p5yATyf4R0A+lfS9qp3YZgQeigjtX8s5tjpZpmWIx1R/ HNtenT7kfumX4b6lhKWEgvhil87a/ifP/wAbNWvPFOraD8INBcyXF7LHcaoV/ghDDy4z6bmXJ9k/ 2q/QT4MeBbTw/o+l6baQ4s7aJY0yOvcn6knNfn3E1e7p4aPq/mff8OUuShWxL32+7/g3PsTw9YKv ll0wgxk+lb2o3bbSzNwBgfSvHgrU0kRWftMQfln/AMFGvj/N4A+HVv8AC3w/fKnirxTFvvmV8Paa UrjKEdQbhwV6YKRuP4q/BIsXjkiuAp56AgAHoPrX9ZeGWVRy7hfDVZxtKteb9G9D8U40xrxWeVqc NY00oL5K7/EkT7C0Qmum+VeAi46jPNdN4C+H3iD4ga7ZaL4dtzNcSOoLdRAgI+Y+navvsbiqeFw0 8TVdoxi2/uPmMLQniK6pRV5Sen39T9wfgt8JtB+Ffhi20/T7cPrDKGuboj5pXxzz6c9PSveETzvs zyxkLyVGMZ7V/PWNxcsdjK2KnvOTfor/AOR+qUaKoUIUYfZX6F9JWETieMbc/KQfyz610FtExS3x Gox8oK9vc1jFRHKUrJM17YBjcyyx4EmIunOfQetd5Z50xLVJuroSoKgqmeefWuula7k+n9f15GDv syeysLgzCaICbCiRmBxtXPQ/WuxkWGKWE2uW02Rl4Y4KuQMn6VdOLimrkSep1OkiI2WpGGNmuZjh UDYQtnj/AD710Vtazxi2aSVoii79pXgsOwq21ZWev9aELm5mraHUwxQ5NxcqC6HAB53Z9q4Dxv8A AL4RfE+wa28cfD/TdQhdCA01sm9SepDAZBz6GiNSVOSnF2a28iKtOE4uNSN0fnL8Xf8AgjX8CvGU c958OtZvfD+pkfKqt59uT15V+QO2Aa/MX4j/APBKv48fCO9udYbRU8Q6DE37qXTQWYL6tF978s19 pkvFU+eOFzGXuvaXX/t7v6nz+Y5fUp0JVMNr5dT591vwxrOmahDZ6rYS2/lALLHPGY5FHpggenp7 1wmrQQzOkUEbbiMk+iDn6V+pQlSrU+aOqezWzVj4GUZKXK/mSC0ka3Zyil4wAWVcZx0B9+n45qvZ wPFI9xNc+UiLuBP8RI4Hp6VzW5JxujaErQk0vI5/4p/CXwJ8ZfCX/CLeMvDNrqNrIDmVoF86IkYy rAZB5z1r8IP2ov8Agmj4n+HN1qniX4SLcan4VjzLJZuP39uvOQvB34H45H4V8txnwwsxw7zLCR/f xWtvtx/+SX47Hs5BmrwdZYetK1OX4P8AyPzEOmaho2oFZ43tbyFsbXBSRGGePUHNfbPwD/bU8V/D O/sdD8bahLqXhBiVaSQl5rYYG3DdWAPr0z7V/P2bZZHMMPKnL41ez8+x+xZFm88sxMaqlenK3MvL ufr/AOGPEfhD4x+EdN8YeHZVls7mPMUm0Ag9fmHUY4964nUtKvdJu40xthblwO/09f8A69fC4SUo Tlg6+8W0fpeLhTq04Y7D6qSTC2uIZlAhYiUHaJGyDjnnrjP+Faf2+3MQhEoL+pOMjPI/Uf54pVYy U7djGnJNepLdFppfszS4gUAbuo54IH6fnXL3NsroZGfdCgYoCfvjOP8AP0rnjdKxt0epmJH5XnxJ DvJVpCM4O7HAJz/L1rjVSZdRaSIHY8m6VDjAAUA4x05x+dO+67mNTppqegW1w88EJyBlBKyk5KsB zkY6YzTbqOd7f5+zFWVe7cdvcVmtGkbauNjxXxDBJa36xmBkjZiMkg7iMcjj0yapT3MNottCSGhX 7yFc5J6ZI7dD6cda+iyyr0Pmswh7zbOq+Iulr8RPg209r82saWd2VBDAx8gY916/T6V87+A9QS4g t1nY7yCFY9A3TkY6c16GOirKWxw4SScI36aHqhhLxssy/dZcLwcgZGevX/6/WvOfGOgrfaTe2bLu bLEq38PYj3/z6V5lKfLUTT6ndNJxaufH/hC8k8M+OLjSHLC3mbYq5wFIOTxz/PtX7wf8EwfFnhbx N46+Kv7JnxBnH/CvPi14ZudBEcnKQ6rCrS2b8nCkgyx5yCWZB3GPboV/qmb4TFyfuxnBv0ulL8Ln i1oe0yyvT/ld/udz+U/9of4Q658Afjb8SfhD4jtXi1bQtWuLFxIMMyI5CNg/3lw341/T/wD8E3Pj uPjP+zV4Ti1Fnn8SeHsaJfZbljAAImJ6/NGY2+pNftXAFb6lxPXwUnpOM4/OLuvwTPxjj3D8+W0c QvsTs/SSa/NI/QrdA8cJvzlTndzyOvGfp/KuN1ia38N+KtA8QWEOba/T7FP5jEq7Kd0ZJ7cZH4Cv 6Apxbi1bp+TuflF+dTi3uvyVzupgsha7xGttLzIvBGT3H+e1VLzxHB4c0WZrdHljtnwMjpv/AKZ/ nXzPHuF+tcKYx2u6cVP/AMBev4Hs8D1/q3EuGXSpeH3q6/Gx4D4h8farrcRgjkZYeWKl85z2rif7 Sv8A+4v/AH0/+NfybPESlK6lZH9IxpxhG2n3noazXKadKILPfGY1WMKVDPkk5yM/NhRnnOD7Vy0+ kX0mmC6vL5mnWYbYVbqoGMeuTwMc1/RkeWcrxdz8cjelGUkvQXw7DrEmqX9rqkC74kW4O3JCjOCF 99p9Oor0/wAFW0000kOoWi7cShEb2U4ABxn+EfXNdE5v2LtpZbfL8zODTlp8vvIPsk+p3ksl1cHb DN/qyMA7ctnpyBnr7UttarDfn5GcL8zM3Gemc+/Wroy928vX9RTbbjvbofsh+w38FJfC+lJ8TfEu mf8AE8v4V/s+NkGYLUjO8dwZODnP3QPU5/Q0EOI2ZcTLw0eOhxtAx/wEZ+tfznxfmP8AaWe4irGX uxfJH0jp+Luz9eybCLB5fQp21a5n6v8Ay0RDJ+7hEsfNyxO7tjGc49uV/WsOe6x5SRtk/wDLRmHA 4Iwa+atpr6HrxeruZD3DS73dR5KnYzY4JPf+tZF7eiQ3DBl2D9PTH5GlFtSbWzCdpRu1cxpp4LmN g6bWJJ6Z2qM5/pXKahpGiaxLJBdaPbyYBzviQ+vr35rpoznCSlTk0/IwqQjJNSSaPKPEXwQ+GuuS fZ9R8NWoR32lo02kr+H17V4L4y/Yw+E+rvINNkntFiUDdE/BJHv+FfW5VxdnWW2Ua3NFPaWp4WOy HLsWrunyyfVaHy74y/4J5rrDN/YPjkQn722eAEYB7n8hXpX7Lf7JEXwV1jV/GHjG+i1DxZM/kWcg TKWsHcr6M3fsK+nx3iBWzHJq2Aq0uSdRW5ltbr8zwsJwnTwmYwxcZ3jHWz79OnQ+7IAPMDOcL6n0 o13XLLwpoWq+IdR/49LaIzY7ueyqPU8Ae5Ffmj7M+3hpqcR+zN4Lv/Emsat8S/EEOdb1OYtHnkRJ wDtz2AAQfQ+tfqz4S0cWkEMSpxgdq/O80rfWcylLoj9Cw1L6plVOn1au/U9bt0+z25XB6c1wvjXx VofhPQNd8UeJb4W/hvS7SS/v5i2NkUYyQPVmOEUerCuvLsLLG47D4OCu5yivvZ41SrGhTrYqe0E5 fcj+Vn41fFTX/jN8TvEnxG8RDN3qN2TDbA5Szt1wIYUBP3UjULxjJBOMmvM7kpDv8iDzLcZJU9Qc dM/561/cWAwsMFgqGCgrKEEvuS2+4/nHE15YnE1sRLVyk3950XgrwZrPjfxDYaLpFoZZ7rA2qMpC M4LMfQc5Nfs/8GPgz4d+FGhWtlp1qr6xNEGublgu5iOoB7CvgOOsy5KNLLKMtZayt2WyPqOGcInO WNqLRaL16v8AQ970+5j85E6RBipOM4BrVSeKCaEJIzFT91jnHrxX5lTg5J26H2E5qLT7mqCryB2I VfRuOT7dvpW5ah22xB22kAsc53fStUuu1yG7SsztbaLzLmxePMdmFBH8RB6E/wCFdAlq0M0KOGNq DvBY847Y/GuiClZ2fl8vMxdro6jLwZnh/wCPZsAKOm7rn9a6q00ktJ9knPloUWQjqRnnP6Yra7ct EQ7WOu0LSYJIyJJniQ52Y+8HB4Yj6V2EBEcbrMwbOYl+XnHr9amztZvQV7s3re0iZ1fyvk2Y56ce lbEEEcWVCZx69qxk7aJilduxahgU7OTjHI96v+UCF3KCB2PNYTk7ha54j8Uv2bvgt8Y7aeDx54Ds rq4dSouljEc6H1WRcEGvyz+M3/BJdIYrjWfgn4mSaRMsNK1UYLj+6k69/wDeH419TkHFOJyqao4i 86LtdX1j5o+dzfIaeKTr4VWmunRn5TfEb9nT4rfB3UZ0+Ingu/04NIVRpo91vMefuyoSjeuAT06V 4rLpMjTZmhMqhtyKPu5x3P8AnpX67hcbh8bhY4nDz5oy6rp5eTPiJU6kKjp1FZrTUvQ6idOj2RWe 6UAgNjIGTxmu7e2VvDsja1Yq0TplPOjAYL1P/wBbNenQqP2fJFX1W/br/wAA5HSjzS9pLo7Pz+yf kV+2l+xL4D+J9pqPijQEh0fx75XmQG3UCK9yCdsoH164J/Kv54/Fnw88T+ANdudB8TaY8F9GxxuU 4lA/iX16fr7V+N8d5FHAY6WYYWNqNXV26Sav8r/mfoXDWOniMHCjXfvR0+SZ7V8KP2jfiV8IrfTN L0LUi+hx3G97CU5SQHO4ZxkZ/wAK/ar4WfFjwj8bfCkep2LIt7GNlzauV3wPjPrz2INfhfEOVuj/ AMKWH019759T9s4Xzh4hf2Riu3u/Lp6mf4k0e80ZZpIc7QxZVH8XP+fzrk9I1i2nuI1uIyiRn5hn lTg9OfWvPiliaPtI72PWqL6vX9nLZ7HbLdRXMTsZl8syAkHO4n+o/wA96oXtsQAyMNu/O3aQCOvT HFcFnHp8jq+JXRQ+zrGFi3l0O4uA5B3ccDn3/wDrVkyWVuIZdr4umPc8P0znH4VOuopK90irpU+y Uwv80rJkleSgBB5x2/8Ar11UIg37yd5DAkFvu+hA9O/51nLTVDp6qzOC8aafdiGRYkSVGOVU8FZP Td0A5z2yDXkTTujTQXsqlguT1+TBAx/nr0zxz6uXzjzHkZhD3nc9M+G+v2l1q1/4dmVXs7+I2u4/ MDIFJXjPcbue+BXzK2hXfhfxhr3hyZMLHcOYjznYTlentx6V9BXlzUVJeR4dCNqs4La/5nqemXEz GFTgHvjvxjJHWte8s7f7PJNGCQU2t8uD7k56/wD1hXju0Xoeglpqfn58YNMfRPEKatao+9JFfA43 A4zyPb+dfSHwp8e6hot94R8caBcNBrmm3cN/azISrLNC6SIwx3BXrz1/CvTxPvUKc/K34Hn0knWr 0HtJfod3/wAF3PhJZeK9b+CP7c3gyxRfC3xI0KF9V8rGINViUrOre+5XBz/dFfKP/BIb43HwF8e7 74batcBfD3iy18mHLgCO9gy8eM8ZZC4P+6or9Q4exzo59leYt/xHSb/7fSjL8Wz8r4rwrr5LjaT3 jFy+cXzfoz+qO+09UVFbDtIG5A+7xhfY1zvifRLXWPB97ZiZ1vI4xLbOoyPOj+Yd8jPTt1r+qaN5 Sp3Xl95+B0ppTg79TN8Mz2+q6Xpd7OrmN48+WT1PcHJ7GrGt6ct1HdadJcbIbgGIKy46jK49wcH8 ajHYaOOy3E4Se04SX3poWXYmWBzbC4hP4KkX/wCAyTf4HiVr4PvLItBdWwV1bDM3JBHU1of8I3/0 0/Rf8K/iCph60Ks6ct4trXydj+tfaU2k3rc/rb8Y/s0/AfxfpxtNf8B6VLfTPDHH+5VQsYUKrYbI UquOeOeOtfNHjv8A4Ju/s5apfxCz064s4kmt1LWlw+2IyYJwAwUt1zkdT7Cu3BcRZtlVp4bEPlvs 9V9zPKxOT4HG6VKaT7rQ+XPEX/BNLQ7GbULnwf46khjkRgsF3GGdV2g98tgZwCSeh5JFeH+If+Ce XxQ0GO2g0TxnZ3c0Mu8oY9hMmeBu3kdB0xxz1r67BeJU04xx+Gv3cep4tXhGEYtYef3/AHnkd1+y L8atGv00uPws1xeSj70LKRvz3LYAHNd7+z3+yj438Y/E6O88c6LJaeE9M23U4nAC37KwKwKB13EH PqP96vfxPG+WSy+tVw0/3nK+WPW9rL/M4MJw7iY4yEa8fcT1fluz9l4FSK5hgsh5EMSBY0RcbcBF C4GOAATirOoTz6eLm2mUm/EzROhHzA8Fvx6+tfiVTmV5yd2z9Ei4v3V0Ode8nXJjP7x0G4nAKZPT 8yB+Fc1f6hIiBZV+XYzjng88N09uKiT1SL6Mq3usM0btCAIxHhl9jtyw+uK5ldQ82VUCblwC4A6j 8enX9KvSTdiVtqyOLVd7bWX/AEcHb05XsMn8qjuJXiY7NrLwQwxlhnnJH6VvD3o3M5SSkr7FCWZ5 FdhGGRVPPTbnp/IflXM3E4X9yoySPMYD8+v4VUVJbdSZuLav6mMWTaz7wZmOcDNMc7zIo6A71B4x 7f8A6q6LJRszC7ZpW21zGjD5cjP0ryz4x+GvEviDXPh54R+xyRaDqaNqYc/8vEccrRKcdQoZGPuc EdK5MXXjh8POpN97etjvwNH22KpUVs5L/M/QL4R+C7XRdLsLeGELDHGqqAOgAr6v0OyCoHKj5RxX 5zRTqVJVH1Z93mU+WCguhp6hdiCAk9ACa/D3/gpT+0W9zPZfAPw5eP8AYw8d/wCI5ICPml4a2tiR zhR+9YerJ6V+o+F2VLMuKaVWavCinN+T2j+J8FxZjPqPD9ZJ2lVagvzf4H5Cak1xbS2yRynYGyxH JGew/wAnrXc+F9Av/EWvWehaBpzzzXmE8raW2MTksTnjrzX9W4qvSw1GeIqvSCd/Q/D8PCpXqRoQ 3k/xP14+CHwY0X4ZaHG7wLJr0qA3E+OR/sqewFfQsyNMgYuQqDbnoCOwr+esxzGrj8dWxtTeT08l 0XyR+qYbB08LhaeGhtFfj1N3S1jEgP8AAo6gZrRtYkS5nnK5lUAsx/SuOF7aPdm0rcy5lsbMAMs6 rjJIyeOFxkD866jT493nW7kBVHLYwAfr+dbcrjLe7IbTW2h3NosKCKOIncUKsWHoc11tpCDAkk0o E8fTeM59Bn6V0QTaSX9bGTfU6a3ljnlZwVWNDt24znIxx711Wm2ZMquHkaUqFCgZ+UdM1rZp66Ea HbWFhIXE7khicgeldVDaW/nDILK2Dz+tZzu07he1kjZgSJp3VcsRxg9BWqqMXyAuz6VzTbvZi31J 9qg5xS5rAtK2olFAzG8QeHNA8V6VeaF4m0a2v9HuEKTW13CsscinggqwIr80/jh/wTF+G3jFb7Wf hPqJ0HW2DMunTZewkY54GAZIR7jeB/dr3MkzzE5PXvD3qT+KPR+a7PzPFzbJ6WYQdSn7tVbPv5M/ Hb4u/s/eOP2b9TkPxK0D7JEWAs5twktb3HVo5R8pI67eGHGQMivjPxX8aoru5u9MtnSe6dgiDjyg OnHrz2r9wwGaYavg1j8PL3JJ276X08tdz4KOV1p4lYSpo00369v67nz7fW/i7x34zs/D+nxtPq9z II4YU528ZPHZQMkn2/PyP9oT9l7w78Q7fUvCXim1ih8R2ibYbuBRuifpjcOoz1FcOI+rZ1hq2W4j WUo39L7Nej2Pr6OFq4G2Ipq1NS5fnu/wsfhF8R/gR4q+FXjltB8VWbizBzBdBMLMnIG0889Ov69u z+GXivXfhx4m0/XPDcjRrE486HJIuF/iDY68dDj6V+D5jlboyxOX4uOqvF/5/dqj6fC4ydGvSxuH lrFp/wCaP2L8K+KdI+JPhi21vT9quVHmRNjdG3dSPqa8o8UeGjp9w08IORy6r3HXPv2/OvyahCrg 8TVwVVaptf5H7HipQx2DpY6g9GlL8CnpOrxmQkyFsgEcn5eMf5711JmSSOVix2sDt56DucfSivDl lczoT5o7ldY5oVglUbrolWwcgkev6VTFrEkBtYoSJSgwxB6ZGc+npXK3uzdLoY08a2F358cgXC7R tIHAz+A44/Gt2zittQC3MMxAMuGHQDjHU9ameq5kvImNk3G43VrOS9WKGNm3K+CTkq3B64OT/wDW rwfxPbG2vkmATezMsmFwJBwfXnPH5104KpH2iRyY6CcGZ9neW8TDUbJTHdrMs6Kq8oVOQQT24HX0 rS+OMEUt/wCEPiLYJts9QgVJhkZjf+6cdxkg/jX08U5UJRl0ufN35a+i3RBoVws6rMkg2oAV4yc+ p9O1adw0k6xpu/0U8bh27Hp+B/8A115T91ts7+h83/G3wn9p0y52nPlpuQk4yM/rjP6dea8V+Dut /ZBcaPdMfMjkLR8Zx26fhivVg+fAadGee17PGwbe6P2W8F+Fz+1//wAE5P2jv2W79mk8Y+Cs+N/C Qdf3giJzcRgHnG4bjj++a/k/8FeLNa+GfjvQPE2mlodZ0fUoryIH5SskThsEdecEH6+9fVZZiHLL MHWjvSlKP/gMueP4SR8fnOHUq2Jw8l7srr5SX/BP7nfhD8QLP4nfDLwR438PyrNpur6ZBfRMDkJv RWIOehGSCPrXsGm6Ve3iS2sShomAZicDafxP0/Kv7FwOJp4rB0MVF6TjGX3pP9T+WZUqkaroRjea bVvR2PJY9C1Pwhq+s+FdQtRGCTqWn4OQY5M7sH2bP51qXE41Gyg1Ge3BThADlcEHHH0Oa9SlKEuZ xej29HqRjqFShiXTqq01Z29df1PorwLY/Dx/Ccup6l4cvNU8WzJKsMNuciKYDCEgA5APzHucEe9M +x3f/RMrz/wHf/4iv5P4jwOAwGfY/D14Nv2kmteknddujP6RyHGrGZLgsTUlrKnG+vVKz/FH9Hwv 7SJIriwtCsjr5KyXLkhiqMC2c8c5I5wD9MVyV1fWawy28F9NORPGdu7ERkQctgHB5wBweM1+Y4ip GKcra9F81ufXwhJu1/Ux9d1eWa4N5qkKrPEVjCqAHmxu3DaO3zjB6/KM85qrBdaJ5Wr6jrUii6lg istPhTLLayBgkly5zktt8wjOfmccZGaiEqb9o6i962nq9hSjL3fZ7X1ObjvXtra9iuGQ6k8e2Qrn 92hIeNt3Y9M9eMioU1OKxtY7OzjDBblSgCgvK4XG4A9cY4Hq3NWrJ3S/rqPoZ0E2oLI9xlxevA8y sowY29PyXGcVjT65c26WjGIm4V2kkdmOXc5zzjrjH5Cs5SldX6bfeWkkjmrrV51vYobqEDyXBkJA zw3T8ATXPS3UpMlu8mEZdgU8hVJ6e3NJJvVlXSsjLknlgjmcS70xge4HH5UaewchY7gCVgDICDyc ZxWsbuXmQ3oMV0RJY/N6AM3HLHuP0H51SicyEyBx5eRjPAGDnH+fStEpJJJkO121sZtxdyLHPk7Q pIbH8R5OP1rmPOlErO784O3I/HFdNNNQV+pzy+NpdCo07gIrRnAYZO0HA/zitWCFUBbBMnrjpVPS JUbt2O/8C+GB4y8TWOkzTi10VI2u9TvnbatjZwqXmlZiCBhFOM8bmUd60fDtw3xe+I2p/EUacbfQ QkWm6BaFcCx0u3BW3QAj5Swy7D+9I3NfNcR11DDxp97v9P8AM+l4coe0x0qr2gvxf9M+4/DOlrbw xoFxxXpsbfZ4Qq8DvXy1BWgexjp+0q2Pmr9pP406Z8Gfhx4g8Y3ZD3kMRjsbfPN1dMCIk+mfmPsp r+W/X/FHiHxpr2qa/r94ZNTu7p7q4lkJ3SO7EnntX9K+CuX+xwGMzWcdZyjFekbt/ifkfiRil7TC YBP4U5P1lp+SJNL0i/1rVodJs45JtUuJAkEQXpz1H+NfrX8A/gtZfDfSf7S1GNJfE9zGDNJjPlAg fIuf1r67jzNPquDjl9KXvVt/KKf66L7z5zhfCe3rvFSjpT29f+Aj6itvLWPzCxLjIwP0qxExyWBP lkAnPAyPSvyFWPupSezN2yCS7pS+1gd3GQMA5rqLZQ4aUYAOMjOS3pW8U37qMn3N2xhlMSNwcPnJ 9K7LTdlu/wBmiCOzEli46ccH9a3px95X1X9IiTubFlBLNkH5Zs/KzcV2em2xZJIWG9wVcZ6EdOv5 fnXTDmtczfY7eytA9wqmNFY/OzKOnHQe9eiacn2OJZVcbCg5x05q1qmuUybS1udLbLL5wCx5iK8S dMGultbNIIxtGRjHNc9WSWiF1uakcKRj5Dg49OtTYAx61xyd3c0STEPNFSWFFABXm3xQ+LngD4Oe HZ/E3j/xDDZWKg+VGzAzXLf3Yox8zn6dOpwK6cHhK+OxNPCYaPNObsl/XRbt9EY4jEUsLRlXrytF H86f7cf7Vj/tbW9n4Pg0P+zvAVhcvPZhm3XFzKRtEkjDhRjOEHHPU1+QviT4S6z4ZkN/Zxme1RiV kGQV/wA5r91w2RRynKaeGptycU+bzbd27evTsfB0c1WJzCVSouVSeny0Ryug32q+ENRTxFply8Wv FWELg5aMMCCfqc4otpdR1O+mu725eW4lcu7scszHJ5Na4OnClUjUjH3mkm/J7L5XPaq1qk6XsnL3 VLmXr1ZxHj34deGfivoF/wCGPGGmIyTIUhuNmHtH7Mp7YPX/AOtX4i/GjwB42/Zs8bHw14p08S6c x32F8vMd1F1BBPGcda+T41y+m6dHOVT29youv91/o/VBgK8oYqWElK8ZpuPqt19w74QftNL8PvGN rfXd4R4fuGWO9gB+UL/ex6jIP0B/D9aodS0fxzottr2gTJNayxiWKRCCGDAnB/MfnX888ZUYLMoZ hh17slZ27r+kftHBeMdbL6mW1HeUHdej/pngeo6df6BqJmVisZ55QgD2x7f0rV03VtzXkl0CV4ZS MMPoPyrwqzVWHOluepBypVZUXsjpI9S2RNKFBcgFYwOi/wD6j60+ITKsqzt8mOMnqPQf57158l0R 6EXKRj3/AJU32mGc4BYqmRzjHU9/X9KydF1SO38rT5JWM4zjeeGUdOe5xU8rcWl/wSHJQmmdsZFu bPzYmEgB3FcHIxnn868o8YaS1/azaguTHEoXAzwcjoPz/Snh58tVSW9xV1zU3Y8Wi3wzi33K9uVH ltg5U4HB68Z469+9ehR30Pi34b+IPBrw77+zUXthk/eQcyLnqCDz+P4V9hRfNTevQ+TrK1RN7XOL 8G3kctmUlbMqAIVIJ3dM89Se34+9emQrHGroMhsbh6H/AAryakUpPudys0jhvGulm8spZnQl2Ugo TwcHHBHsP6+tfnrI58I+PIrjawR5BkgkZUnOOea9LAe/TqU31RwY73JU6nZn7EfsafGK5+DPxW+G /wAV32T+GLqT/hHtfgkIRJ9NusRS7sjBKqwkGepiAr8av+Co/wCzFN+zD+2d8WvA5tjD4bvLt9Y0 eRRlJre4zIpXj7u4sO/SvayCo54HF0LfBKMvvvF/+kxPEz6ly4mnV6Tivw/pH6qf8EYvje3if4Re LPhRqF2W1Tw3deZaqeT9iuCXXvztk80ewKiv2ujuri2tmnnn4JBypxkDvxX9acCYr65wtgW94pwf /bjcfysfy1xLReD4hxlOGnv82naS5v1POvGd1cxT6L4mkDstlKYJ3clh9nlwAfoG2H8asy3F3cD7 NG0bWzLuTZyuCOpPr/8AXr7iEYqzXb8tP8jxcROU1GpN3bW/XT/gH6Gf8EwtZ8HxftB2fgvx/epH balZzmwlbo93HhljJPCho/O57lVHev6Sf+EF+E3/AD82v/fyOv5x8RcPXw/FFecad1UjCSdt9OV/ imfs/Adb6zkMYuWtOUo7dN1+Z8ianeWlta29nMv7+RpA8qylYRGAAu0h8DJHzEjPA9TVeeWUzo04 hWZm88iMYVMuVBY528kYHI+7X4ZUV5cnmvw/4Y/XI30mZF9eQveXNrJcRFrm+Z5yBn7OhVkX7owM MxOAM/KBjms+cos+mwNb/wClzJKCuVIDBWbJI45ZEPT+97Vm7K7fdAlexzEU9nb6ZqFzcTRLeRhS sRXi4XLAsO4xjH1IFEa3g01roxgXYR1s0VQGTcRIWPHbLKP06U+bmk5Lt+Y7csdUZl3dSxQsEmIm eONEbn5B/EP0H5msTxBObeWGNCuJAhiI5ORtDbvyJxTe+j0TGtbJnO6rATeXBnuY2jlk4kDZDgZL HPcda5wK5W4ELqI94V+fvcngZ/Oi97ITW7Q2WIsZ41UiFQoYAD5OtUov3Uy8jzFPOOARirjo1Jky V1Ye11E8sroFB3llGRj6H2PNUr5ljhhRSoUH5znGSewramlIid4xRyt7fDe0SSMW352+uMVTMiu4 dh+8Oce5/lwK6YK61MHfe25BbSJIyMZCHDA7T0I/zj9a27OV5GmLLn5s+uRVP4rlwjoz1HxZG3hT 4Y6J8PrM7fH3jfZfakyt+8sdAR/3UW4HKm5kG49mjTDDgV758LPCMOk6daRpCBtUA8egr4HiCs62 NdPtZfd/wbn3HD9H2OXzxD3m/wAFofS+mW3lRhiAF9Kk1K8S2gkdmAwM81xQWyQpfvKx/PD+3j8f bv4k/EmfwdocpfwroJdFKHK3N0eJX46hcFB/wKvgGKznvbuLy7RnncjMMYLEnttA+v6V/afBWWQy bhnBUKnutQUpestXc/nrinFPM89xVWLuublj8tEvwP1E/Z7+A9r4Qji8Za7CG8RTR/JHJg/Z1PYD sa+xINuU2n03f1+tfk3EeZ/2rm1bEJ+4nyx/wrRffv8AM+3yrB/UcDTpW96136vVmqCr8Ywgyw9/ rWhbJNKDKvGFOAOnFeOrHbK6bTNuzg8gTNcZ87j5D0wf610yLDGsaysRMRnGfTvW6194x20Z1tpE BEHAPBX/AIFmt+0gC7lERaVjuU91X3Fbxs7O2hEtzsLD9+0UuPNnZtuCOAPX613GmxLg2u0Z3Ydg eF+hrsa05v68jNt3sd9p9nbLJAzJlYwWOP4j/hXc21j9pLK4HlAgquOBUyfKrmbSd7nRPZLcwwxm RhGuGBQ4OfSughgChQxJ4HHpXHVnooijGzcu5a6dv/rUlcxulZBRQMKztX1jStA0281jW9RhtNKt 0Mk9xcSKkcSjqWZuAKqEJ1Jxp01eTdklu2+hMpRhFzk7JH5XftFf8FMfDvheC80L4G2cep6l80ba 1dKRawt0/dR5DSnvltq9OGr8SviN8S/HnxS8RN4g8Z+J7vUdcnJJlnkLBV5IVR91V6gKoAHYV+88 H8L08lwv1vFxTxNRa/3V/Kv1a66dD8yz/NpZjX9jTf7qOy7vu/0MTSUiMJMsbZDENHj9a7CK10+8 spLVuYsZVmXnt8pFfXxs5PzPDlzrkkuh85fEX4PX/mXOuaVETbEbmhC/dz1IryGPRr2ziJFsysuR ynQ14WMp/Va/Ktt1/kfU5di1iaHM3rszV074f+J/FFzHJY2bBOGZ2BAA7nn9K6j43/sf+Fvj38I7 7wf4tjP9vWsBbTr1AMwS44OeTtNR9UjmmHr4Wt/DqRav5916WRy4/Mo0KtF0fihJP/gH8kfxs+Dn iX4QeNtd8FeK7RodTs5HQMUO24XJwyk8YPJ7/jX0b+x1+0SvgK8/4V34uuydHmk3WUrsx8o5x5ZP YcZH5elfzRxFllR0sRgqsbVKba+a3P1vhzMo4fGUMZB+7Jfg/wDI/T3xJa2ms2CaxYSCSKRSylQM EY/pXiN1G2kbZ4ATat8uwkfIeo/TNfnmE1pyoVPiWh+nZhCKqRrw2Z0ej6tZkTqQxcr8oPbI6c5r fuLxpIQ8ca7CVKjODwemO9c9SHKwo1FKFkU765llAxGpuBgbQOeRj+XeuH1VbiO7i8hWWVfnLAE4 UnPP16VEeVu4VX1SO80i9N3pKKh2yEkjHB+p4657UydFvraaxRg7FS0iN1LfWsvhl8zZtSgmuqPA vEmnHTr+ab1faVOQVPbPbAHp/wDqoabqMuhaxBqjS7bON1FxGR99H4Yfk2f519Vl9VThFW8j5fHU 3TkzOngj0XxNd2FtIwgeUyxMc5dD8wI/MV6rDcq8a/ulEhBJB788YHp17+lc9f3ZuzNYNuKkYGrO LxJIDJgbcEYOFPfHH6/nXw98bvDqwPHewjbKjZDbThh68f19a68DLlqpdzkx0VKhNvdHunwJ8Uxe IPh9Jo1yMu26Dc7Yw45Xnp6jt1r6+/4LCeELT9pn9iL9mH9sfSVEvjbQLceDPGLKvzCaACNJH/iw +1WGezj0r1uHX7PMcZhJPScJ29YtTX/pLPLzr95gsLWWtk1+X+R+Kv8AwTk+OcvwL/ak8E6hcXvl eHNbf+wNRDH5NlwwEbMB/dlCc9gWr+wqe4lnht7gzIV+8F3cMDyD7V/THhPivbZPisG3d06l/lOK /WLP5s8Q6PsM6p17aVIJ/ON0/wALFfVrgXWnTafNGWhuo3gK4ByCOMZ75x+VcZ4S1qZNHtre6twk 0RezugF2lHT5Sc+4wfxr9bjZRhbdP/hvyPiJe9S5uz/P/hjsvC+v6v4J8U6T4q8O3JN9ptxFeWrh uJNrZKn+R9Qa+pv+G7vjb/zyi/74NfOZ5w7hM4xEMRX3UbfK7fZ9z08n4gxeU0alGjLSTv8Agl5H 7Z/23o93bafDJbMIlfzJIiiIqIWTZk5PTZtPQcDqKyrfXVg02e5uNQM8aqCIxGu6UxvIIlyQSWAa RyMkHb7Aj+Hq0lF3kv8Ag7H9ZqEuR2ehRudX0uHSXtreKFEnhimnh+USOZUuJlTcc5UZjz1O4gdQ KYwuJprFdQQ4hLYVnUZjCqDyWOXKhyc91P4SlJzu9r/kHwpqxxrtp1y88sqyFSzGVgfvneT8uTwv X8h610KXdxFbNEbxo5UkUQOANqxuOR9ec5PQZop+6ko6BKTfxMhvdTspJm0+xnAgUJPK8wBMkuCO PQDIOPbNcZqKDUb9dQa/jRrRAWQHm5I+VyB2PP6Vckmrpabij7vTc5OXUvPjLlRHB5jbUIJKZ3Y7 +4p9jcRzwG4lt2ZiSIypAAkPJ/QCiKuU3pZCPc/vTbPKsd2H/eHJ2txx/Xis6eLzbuVkYoG+cDPI HpxWvKrWMebS66mXOEc7lmAbbll7nHqfWsGfUNqeUzEOrlmDDg/T6DPNaU420Byuc1PeKfPPPnkg 5H8XfFOheQ4dpB5oyVUj7oI7fpXVBNXRhI0bEK8DZQF8jOew/wAmvXfht4d0nWdXuNX1+byPBejW j6vrc/ICW0QyUXGMtISsagc5fIBxWdWUYQlUe0Vf7kaLm+FdTV8C/wBs/FDxv4g+KHiO2Md/qlx5 kVsCCtjbqAkMCYGAqIFXgDJBPUmvuLw7pqwRRRqowAM1+ZVpyxGMnUl3/wCHP0fk+q5fSodkjvAV iiz6elfPHxv8VSWfhy/0mxvDDqN3E8Ecifeh3AgsPcdR74NetllL2uNoxtonf7tTyKs/ZYetWvZp O3q9EfjH4j/ZFmuGurjS/E2TOxZxMuWLHvnvnJ/WvQ/gx+zFpPgfVG8R+Ibpbq+VdsEf8ETc/NX9 DYrjnFYjK5YGNFQlKPK2u22h+TUeHcPTx31qUm7O9n331PrRI4wFEbjpkgdq0Ij8oODnPHvXwyT3 ufRuS1NSJVZAVHydDW1E48xFB2qMcjOBjpwK2hujGSumzWtx5+PMOfmwTn0roY42JXzDzwNvfHNd EXJ3vsY2S1e51KyqV5AG7CgdCh6D8K6XTyyyGRpTuZdrMDyB9K66bskZtaux1elYjZYw5WY8bh6d /wA69C0yBLuylsFYx24YF3P3mxXTHTl/IxnfVHpGiW7tbxxMG8pMqWPVh2r0KwhMTOucgYC471jV ejSDZHRQQ/KgJHBzV/gV503dlxQlFQaBS4oA+MP2iP22/hd8CEv9HgJ1vxxEMHTrOQBLZyMjz5eQ nb5QGb2HWvwo+O/7V3xm/aAvL1vFWpmHwwhL2mk2TtHawDggsoOZHH958n0xX7FwNwp7CMM6zCHv vWnF/ZT+0/N9O3rt+ecS597WUsvwsrRTtJ9/L0/M+XbazurjyrRg/lE5yD90d8+/eujgt3s7RF2q LgLtyQDgZ447V+nS131SPkFraKWvc1dN02e4keYOEnGABzhjXrFh4ae8gtnEGJD2A+VutcvPFKUn pY6Gnamu9z7v+Cn7C3xD+IFnZ6r4shGh+GpMnffRMbmVfmHyW52tjKjlzGCrBl3DGfrnxl/wTU/Z 21bwfLpvhbQJLPxigV4tWuLueb7Q69pYd3khW7mONCCAeeQ35JxFxm55hSo5frSpS95/z9HFeVuv V6rRa/bZRkE4YSrUrO0pr3V27N/1sfl347+CuufCTVdQ8P6t4dFvdRI0aqyDayngOjDhlOOCP8a+ fb43sFrcQLYkoVA+XnuRg/p+tfpuX4mhicLSxFB+5JXTXmkfDYmnKjXnCr8Set/I/Nf9vz9j/QP2 gvhnfa3oemRW3xT0mMywyqo33cYGSjdznsa/kV8UadrHhXX7zTZ7V7bUrKZopUfIeN14OfTmvynx AyqNDG0sxpr3a0df8cd/vVn9599wpj3VwssNJ+9B3X+F/wDBP1O/Yu+No8X6HN4J8Q3YbU7dcruB Py9sH0I/rX13rOkQ3DLpEkYAJLRtu788Dr2JH61/OuYU/qea1IraWq+Z/QmVVlmGR0Zv4orlfyPC dREukX/2NZGjmRspIRke/wCH19q73Sr2F7cSNcI4BO1zjCnOOvPrgVjiYOyktbkYeVpOL2R0keMJ I+DchvnKrt3ZOOPQe1c1qUEk63AEDCNwWBDcqBkYxx71w3s7nbPWNiHQr5NMnhS5GUkXCfMO38z1 45rt7ubYHvLVtsbRbcBR14HXHXr+ZqZJc9+jClK8LdjzLxfpRfT1ubq23TSKCGRs8jufXt+deMXd ybtJ7dI9wLbF4wz44Bz3/wD117OVze1zyMyh71ylf3s8tpot4ADcwOLOXd94J/CCTz0GPw9677Sr tZrPeX3vjBUdB/h1rtxkbVXL5nDhrukvLT7iaQqyYnIw5C8kZ6AA5HX/AOvXhfxa0I3mk3CI251O /OCT0HOfofw/IVGGly1ouwVlz0pX6o+ffgp4hk0HxHqPh64k8uKb5kU4I3Kcj8T/AEr9jf2YLjRv ib4I/aA/ZL8aSM2gfEHw88+hoxGy31y1Rni2qc7WkQkZ7lF/H08NUWFzzD1m7Rco39G+WX4Nnm1I fWMnmrawb/P/ACufypeLdB1r4feN9c8O38b22t6VfyW8mch4pYnIz9crx9K/sr/Y2+Msfxz/AGef hx48luQ+pXFgLTUdpH7u9gBil4JJGWUnnsfpX754U4l0M7xmAk/jp3+cJL9Gz8G8ScMpYPB4tL4Z uP8A4Er/APtp9K2Ih1KISTk+ZCcklucjuM15hqMsmneLJ4bd2NpqSeaSWG3zowAR9Su0++DX9BwV 1JS8rff/AJXPyWm/dmnLpp8jbm+1pamKCblNwCEcH6H/AD2rF83WPRP++f8A61bqEJfEcLbTtc/p fmOqJfySanEqaq5hkhibIKSJtjKBcDDqsocn/fyTnJoya3Z3+l2MUdgscsTN9qkAKsjrK5UkZ6ne 0Y6dMY+XNf57TWlnu+p/aujV0zEuY4EmsbzWbjzb83QlCo2FjgErRbCQTjcBx1zkelXr3VJLm4gu 9SuCsjGT9yqlR8wGwjPc4kB9seoxgoxb39fUq7asSpZGWSa0hZmlzEsEbAgtgBmY8DAypOOOoqay 1SXU5blp3Cqh2IOPmAzgEdjgKM1rBNz1M21yWOd8Qao0dpJfNagXMjEREkYZQ2Ccd8nj8a83t9Sl kvJVJ3RKSCy8hst0Hp0NRN3nyo2p6Ru+hfa4Zk+2XEqC0kcqAOvy4A4/E/lWxFL5Ft5QjByQ8YB+ 4CchiOxx2q09bMye3qY12JTMC5AZom57Z9/0FZKaiwuPLeLzOhY8ccEgZrVW2FFJrYz59Re0iFwV HmSRlTg9ct1/DFYM93LcArOg+TMgB4LZrppaaNHPO2ljJj8/7RCu0ZdSW9B1/wARVhIJnaR5Yz5r cjb2A/z1rXa9txRte3Q6W0tFQGF3bcADgc/me3WvXfHlu+g+GvC/wL0/5dc1V4Nf8WkY3wxj5rGx fuNozOyHkOV7GvIzeuqWBnJvWWn6v8EerldH6xj6NPpe7+Wp9JfDbwzHpthbIIsEKBX0Hp8AijB7 4r4HD680u59tmE9eVFLXdWh06ymuZXAjRSST2r89vGfiefxL4hurxpMwA7IVz91Qf619hw3RU61S vLZK3zZ83m9T2eEhST1k7/Jf8EwAC0AmVxuztI55/wA81fif/RwJVABOc9CPavs0nFnzDkmrly3V VZlkGHznOcZHoKvRsjhVRhwflGehrdWZlK+ljZj86MJGqgqxBI9a24Y443Tj5j8zc+g4rZLa5g31 NS0LF0YgqWbGB3/zx+VdFGA250+/wOtbQtezJfc6G1Tzt38UoxjjjPOc11Niqi4eORiZB94KOc+l dcFrp0MZSSep3tnYPusrxlxGR0HU/wCFeq6bbedJDHtGC25R2xXRJK+isY3vc9L0iJIoJ5pUOFT5 R6ZrpNLtjbQxxMxYliST/DnoK5aknyv+uga3udHAgij2r696krgbu7m8bKKsFFIo88+JXxW8A/CH w9P4n+IPiODT9LQHb5hzJMQM7Y0GWdvYCvxD/aG/4KWeMfH1zq3hT4RytoPhUZRb8nF9eIRgnPSI deFOfev0Dgnhb+1K6zHHQ/2eD91Pack+v91de707nyXEmd/VKbwWFf72W7X2V/mz8w73U9X1O4uZ ri6MtzJIXkeRid+c5JJ6nJq/ZWz3MTjzM5ChgjY9ya/c5PljyrZdj80clzKS17+pe0/Tbm5maNQQ AMHnpjsfyru9J8LXN4olYJ5RAJBHXH/165ZysmdMYt3Z9j/Av9kj4hfFu7ivtL0xLTwwkg87Ubws kK4IDLHgFpXAzwowCMMVzmv2A+EH7KPwv+E8dpeCwXVfE0RDC+vYwUhYbcGGHJSPBUEMdzglsPg4 r8l4x4pk51Mqy+flUkv/AElf+3P5dz7jIMlVSMMZio6LWK7+fp+f5/TlFfmB9ueR/GX4PeGvjJ4W m0PWo/L1GMF7G9QfPbSY4z/eQ4AZO47ggEfgX8X/AIZeLPhd4x1XwtremGK5i5Vvm8q4iP3ZImI+ ZDj81IOCCB+qeH2bpqplNZ6r3oen2l9+vzZ+f8X5fyyWPgtJaS9V1+aPnPx1bWkSW8jSFWK4lk28 HH8I9c8V/OT/AMFTP2Kbm3S5+O/gPS/kCq2s29unC9/NAH15Nfa8UZYsz4dxcIq86S9pH/t34l/4 Dc+dyLMPqWZ0HJ+7N8r+ex+Ivwv8f3nww8e6B4mtpCttHOiXXP3oSQGOM9uv4V++9hrOm+LdB0/V dMuUkjliSeKRevQEfnX8g8VYdxq0cVH0Z/TvBmI9pSxGEk/NHnfjezS/sPtrxk3iYUqyD5sHBPT/ AD6Vweg6gHjEd23yNhgFxxggfj2/OvJTVWgmmerVj7PEOL6nptmwewkhRySMKBkEqSen14H0rSmc GzEcr4jaIruZeQc9M9MmvNkmnqehF+6jzi6hjt7vYisn7zeu45GPr9a7sajeXWmvG0RMgAXjkEEj GffJAonfSTMqT5ZSRNLZx3OmTRmUveoCoTPGeD17dD9a+bvE9nJpZR1jYHIXei988k/QfhXXgJct VXfU58fByh3OLv7i8t1YTRg29woXcoHDgnBOPp1rr/Dd5LOGhZFDY5B6gjrj/P6V9BjEpU6c0+6+ 7/hzw8O/ji+jv951sEYIJaIk5wAScAjv/n3rk/FVlFPDcRyxkxOpDEZyvGB06e31/Pii7TTN3tqf AnjKCfwr4utr6EhZUlDK/TO05z0z27+gr7w+GHxWu9C1jwD8RdCJXU9FvIdRjCAZPlsGYc8Dd8w+ hNeljafMqNWPb/hjz8OknicN0d/8j50/4LO/BnRPBn7SGm/GXwLGp+HfxC0qDxHYSx/cWaRR56cd 1Y4PfINerf8ABFr42JYeKPHvwI1y/IsLyE63piOxP75NsU6jPQlfKYD/AGWr9d4Lx8cLxXgMTf3a tl/4Nhb82j8h46wjxPD2KSWtNxn/AOAyV/wuf0FJLLZzXCqn+jscK+0Ar65x7VwvjWFX0C5vLIH7 bp8v26IqhJO0fMv/AAJSRX9T03zSST30+9WPwKk0pxcv6uV9K1fT54o3e53WksStEV6lSo4yfyrS 87RfV/8Av4v/AMTV3sk7b69TkqNU5OL3+Z/RVZ6nKsscd0yG6X9yt2zFpJHkwJkPAO75WOcNjeMZ BBPIz6jYRC0gk1dpUVmmljIJH+tD+WpOByS754GPxx/n7UTmk4n9pLSTsOtJvKgabULwyzXQ+RlZ isYDOseRnkghj/wIdc1oxafqeopqNojLFfpKt3HLcFQuwS8EAYzu6kYGAO2MVmo2a5N/1Q3JpO5Y n8Q6haahDeyXbPMES5IKgbUYsmCB3xs9OtV3uWsNTnnYZtrhDG2D/qy20kr+eB9cUk5S38/xGuVJ NdTjvEusC6mhtVcNZhZIUcnmMqxJx9cD8aw/DF1Gt/MI402R7zhuVYs21M59PT/Ghq8r2LjJqLTL l42W0vToZcospO/Axuzz+HzEVal1JoJVlYEFi+73Y9qqKabv/XQzlsjObUbq8lhsbRvnaI7mYA85 xn69P19KjXUbOwQm4jLOWxIGIO4jABGPStFaTUmLZcqOTuDumnli/wCPQsWUHoqD/HNVBdvvSXI2 AlMjsOn0/wD1V2QSSscknqx8Em9C0EeJtpTnrwe31rciDRxgSuFYD7uMkHHSrlrdL7yoX0uer/DK DTdNm8QfEjxaiyeE/Dtqt9dQkj/TZycWtqN2AWllwMHghWzWv8KtG1fxTrWsePvFLmbxHq1017dS sM/Mx4VQeiquFA7KoHavj+J8Q0qdBdFf73/wD67higpVauJa2Vl+v6H3HoNgscEYUDGO1di7iKIn sBXzlBLkR6uJlz1bHyn8dfG6wwL4espsXMwzJg/dWvleKUJMdoBJAUEjOfbNfouQ0fY4GEmvibf+ X4HyWdVefFul0ikv1ZsxSLK/mBMMoGcdj6ip5JY3cKQW2jk56nOa9pN3aR5MkraALjc4k35PQZOK 1bXJmiyQGPP5c1vHZIxdr8zOmjcpcKGb5dvBHv8A/rrYhlAj3EZIOAc9P88VskjDWz1Nu1cg+a7d MED/AD3ro7N4wr+YoJOVAPvzmumlFxdyG76HUacn2aJZQMsDkE11OlaeLe4uLhnJuJhvOewrto1J KLh3epjON5xlfY9B02bY6hiZIH5PU7ME/wBa9U0iNoLiMMzAPl+f4OOa0klr3MtOa56Lp2bqCW3l H7osp3A+n+RXa28K7I1ABGM59K4K7toio367l40lcZuthCQqlmICgZJJwBX5wftN/wDBRP4d/CJd V8J/Dzbr3j1UePzYmBsbGQcfPIP9awP8C8cYLCvoOHMir59mEcPDSnGznLsuy83svv6Hl5vmVPLc LKo/jekV59/RH4PfE74vfEz4u6/ca7488S3epXzgGNZnPl2y5+7GgO1B7AV5tZWYkWSSaPBjfIyO g9PftX9GYXDUMHQp4XDwUYRVklskj8gr16mJqzrTd5Pfu7m/BNcX/nTrpyi1dQqnGK2tB0a8O+W3 5MTBSFxlhnn+VFWel0goxjte59K/Cr4EeOvijqceleEPDk1zdFg8pQYihzn5pJGwsanBwWIz0GTg V+wnwQ/YR8FeBRaaz8RpYda19MOtmisLGBvlPIbBuMYI+cKpDEGM8GvzbjHij6hCWXYKX76S1f8A In/7c+nbfsfX8P5O8XP6xVVqUX/4E+y8u7+R95wQQWsMVtawJHbooVI41CqgHQADgCpa/HW23dn6 IkopRirJBRSGFeH/AB3+Bvhv44eE5tG1MLb6/CjHTtRVMvaucZU/3o2wAyH0BGCAR3ZZj6uWY6jj qPxQd/VdV81dHFmGDhj8HVws/tLTyfR/efzhfHDwjr/g74hy/DHxHaGG90399dqcEYx+7KkdVbIY HuK+f/EPha18S2GseGvEVtHN4dvY3guUkxtKMrDBz04Nf07l2Io4unCtD3qdSK+alG/6n4jjKM8L +7mrTjr87n8dv7en7Luqfsz/ABb1PRo4d/gzUJHu9JnU5URlifLJxwVz/nFb/wCxT8crjS9Ub4ae Jb2R4nJk06SRidoON0XXpzuH1I9K/lfjnJXg8Tjcvt/Dk3H/AA7p/wDgLP3/AIKzhOpg8a5aTVpe u35o/TbWbeJsTABraXqc8ZIyD+NeJeIdKbSdR/czr5YJOMg8Hr+NflmDk5QcXrY/VcxpqNbnT3Nf w5qzTW+2SXYQd49/r/nvXoct7Fc6YN8eZflJCrzz3yOnvWFePLPfYMPNyj8jmtR06KZnMyv5RQuO SPQjGOT+n61rardWtvJpU1nMRatEilMHrweeOvb8BWCvPfYb91tmzC0dz50KDDL+8I3HIHTr+PvX m3jnQz9o+0CPEZ3HaW4JA7jp2ooTjGrdF1kp035HhVzZXDxNtmLKr/cdR8pB6e3UY5/hFVPD2oPF qLWsmcq+QTknPTOT/KvrHapg7ro1/kfMJctdw6P9NT2JJBLbqYnAUZQtnqeB19+T/jVOS286GYzT sxPBO0c5GO47EfyrgTaN30Vz4u+OXhtfs011CoWVHJwEA/Xp/kVgfBvxKDZyWEj7nQ4ZTjIweOPe vYd6mDTa1R5qfs8erfaR91ftF6Jb/tF/8E3dQ0yKHzvHnwm1b+0bbIHmPot3k/KBzsjYMvpytfhD +zz8WNQ+B/xq+H/xN0+R1/svUo5LlEPMtsx2Tr+MZfHvivqMpxMqNDAYum9af5wm7fhY+Qz/AAar xxmDa0nGS/8AAk7fmf2uadrNp4t0TR/EOl6ij6Re2sdzHMGyJEcBlP0IIFWDdtN5cMkS+TIPLYFc 7lOB+WD+lf2jh6vtIU60dmk189T+UYtxXvrVffdHxD4u+Mmo+B7jW/AukabG15ZXEkS3Nx82Iicq FHB46Z9uvr5n/wAL28ef89bb/vwP/iq9bnpU24xinq9/U+lhk+FqRVSrq5a6dnr2P647DWrDSxFa 3HlXF7BHukuflKyy4CttK5ztJwuM8bTWlrN/A0Zt9PFvK8ttnMSNiOV02qFOCDt+8ecHnGMg1/nl J8+iWh/U8obtsfb2M9leQxKd9tFcPBCYXyXwdpdlGMA7Aw4z83NM/wCEpm+ytPPEqX0NjHaxK7Z3 yLw5PGeWJOPRR71nrF76rX8B/GtDYt7/AEy/021utSiVtQ8weaYlxgAAhiPYHH1b2Ncj4g1+znii XSwytCNgZm6cEg49Bj0/lRKyTa3CMXz26I5SyZrrN2ylrMSPtO/kDjGfz/Wtpzb2guJIIjHd8khj gEYGCD68k/hQ1dKw3fnI45Q8Kykhoedp3dAfb61fS8tLmWGNYmMcUQaTcT87DGW/HAqkrib3uZ9x FFaXflQynyFXzHfJzhskL9eawdQvfN23MMZdiBGM8rtPTHvW0I6JMzlO2pVkiDwSJcXu0EqFXqRg ZIJqsWjikYGX95gkDGAfTj867YxtFyucMpSlO3QuWiyLE8cgInG1t2eeT0roNPVrieGOJC927CNU UZZ2J4AAHqfrUXvvsdUb8p6x49txHeeFfgRo7L5Wly/2t4nliORcatKg2wEjqtvGQpxkFmY4BWvq rwH4disLK3jWPACgdK/N86ruvjpJPS/5aH6DklH6tlam1rLX79vwPcbCCO3iVQuABXOeMPEVt4f0 i81C4lCxxoWNZ0KXPOFKPVpEcy55VJbLV/I/NbxJrd5r+t3eq3EpInkIXuEXPH5cVWYbPIWIghSc 89z/APW96/VKVFUacKS0UVY+Bq1nXqTrP7TbNMAR7mYlTjkdqtb02gw8uGySa2irb7mTel0yaEGN iJHznkc9ec1tQTfNlF47ewroS6GN1ujpbUNJJG/Bx2z1rdtykjOUGEz09K0jYzequbNqfMLHodvG a6Oz8sP8zAtgKfQe9ddNSZm2dhaSBY0WfiLOTgc+1ehaTdNI67xhXTy9zAZA7fSuyDV9EYvU7rRo IkRonQqD0Pr7+1ej6aryWpZiWKrwe9VsQ9Ez0LR1cQwqPusBj3rt7VFRQozx61wYjeyKik3csd68 d+LXx4+F3wT0ebV/H/ieG2cKWis0Ie5uCBnCRD5j9Tge9PA4HE5lioYPCQ5pyf3eb7JdScXiqODo SxFeVoo/BH9o7/goh8S/jZJL4e8GGfw74Dy8csFtOftF7GTj9/IMcEfwL8vXJNfn1fpNctHcRyYt 9xyxOcfj9a/pDh/IsPkWAhhqCvLeUrayb6+i2XZH4/muZVsxxcqtRu3RdEuhvW9nLFpiXH2sOZJN p4+ZQOea1bJ0SZUaPfj+Prn1z+fSvYlKytNHmwjzJWdmeneEvCGq+I72206y0ya4nuGVLeCGJ3eR yQFVUXLMSTgKBnPHev1c/Z+/4J737y2XiT4uObDT9yyf2PC4a4ul64lkU4gU4XKruchmGY2FfEcW cR08mwvJSaded1CPZfzPyXTu9O59JkeVTzHEJJWpR+J/p6v/AIJ+qHhLwZ4U8CaPb6B4P0G20/SY wAIreMLvIULudvvSOQoy7Escck109fg1WrVr1ZVq0nKcndt7ts/U6VKnQpxpUo2itkFFZmgUUAFA oA/DH/gop4ZuLP4v3Wv2lsHvb6wtgJCOAiKV2/gRn8a/P7T/AAvZ20cereIpHez83cyJ0bHODX9F 8IzlPh/COGjUEk/RH45xN7OlnM1L4W03+J8N/t/fsxeDv2pfgp4p03w/YrB4z01Xu9Jk2DcWUZKZ 9D6e5r+LC8XxH8NvGClka18RaZdFHVhzHJGcMpXjjgg+vPrXwXiflfLisPmCV41YuEn/AHo/5xa+ 4+p4Ix0XSq4am/4cuZLyb/zP3R+EfxB034qfDjRdbtbiNpZ4VjuI1YZilHDKe+c5xXOeK7R4r9kl ftnKnBJ7fy/rX8xQpyw+Lq4dq1nt8z+ka9RYrAUcTDsvxRx9pdy295Pb73jh3YVj1H+8fWvYdGv8 xLItyspyFZSM59P8+9GLg+a72OfCTb07HQGSO+Lv5eFAOAeO3GAa871W4OnyQRupeAuMgtjbyT+B /wAK4qalKTijrrfCmd94f12OQS+Qm98bJMkkjnvU/iC3TUrGdIlDPjIyMfz9vzqNYz1Nk1OlY+X9 Us0iu5JxKShzmFj93GMH61y12gS/N7nCHIx2PYk/Tr+NfU4GTq0JRtuvxWp8vif3eIUk+p3ej6vb 3kTW6cFcDr1z9Pp+vNdbHJBtWFnKx54br1x/9f8AL3rmlFxKjZSPI/iLo6ahbyoqh1lDKdwGDxjv /Mf/AF6+E9EmuPCXjWWznUiFyUAPQ/MPz7+letg3z0Jwfb8jzsY1CrSqLufpl+y9410jTvHsfhLx RNG3grxXYzeFtVR8FPLugUhkYYOdku1vbqOgr8Nvjz8GtV+C3xd8d/DfXmEN3peoy26huS0e4lG/ FcGvXyqpzYOpSvrCafymv84nk5zC2JU+6X9fgf0bf8ExPjnp/wAS/wBm3TPAWq6xbt4v8NTDSGWR 1DzWp+a3cA9Rs/d/WM1+kM3kWRMfmq6hQASnPAyMY/Cv7D4Oxbx3DOXYhu/7tRb84Pka/C5/KOf4 T6nnOMwtrWm7ejd1+DR+eXxo0O31D4xQhbqO1XUI4y00q4QMwwOfYj17/jVT/hUKf9Dzp3/fz/69 fT4mu6dV2g2mk9H5I73i6tGhh4xg5e4tfTQ/qUk8Q3upeHLCKysljdJJoY0BB/ebpZGcoxJXCsB2 ydvPGa6HUJo9Lm0VIQrWDtL5ML/6yCSSIAfMR821guQGPKnB5zX8Ata+6f1LHTVm1aXxsLK5ed2F +Y5WlU48xQdoJ2+2Tgj+9nA6VjTooiF3qVwqIkyM4AGQihWRMHP3jk9OlKpBN2uTGUm3K2nQo3eo WtvjNzKQYgYghC+ZEdrAtj0IP/fNZt9ceVHa30U0ckcbCRxwWZSuWBHsBjt6Dms5pcqLh10MUahZ yRyhQ1vHLOJEUkkiMH5Bj6nP4CpI724uL26g1O5kMccQEeT1Y7QWz3GAfWnromxLdu51VtHaTIZY 3aOEnZBH1O7qSfYZqW1Hkxzo7Ms0hBGQclFBOefUgdKpXtoO6vZmfLdKd9uIz57zbWzyVUL6deDW Lf6lE1q0YkAKsEbA7dAfwFdVNXjdHNVlZ6lE3ckrbSdwIDGQjHHQfyq19pdZV3JuUpuUHqew/wAK 6Ol+hgnrddTVS4WSOMu2ZWHbqvP6f/Xr2P4YyWXhDT/Evxn1mzWW10MLBpFq/wB2/wBZmBFrGBjk R5Mz45UKp71y4mqqNCpV/lTO6lB1XCkt5WR1vwV8JXsrTa9rMjT61fTPd3c7gbppZGLu59yxJr7f 0WzEMaKF7flX5dJ+0xDl0P0urFUcNCiuiOkmmWGMnOMV8R/Hzx0L26Hhy1mPkoQ85X1zwDj8DX0W Q4f2+YQb2j733bHgZjVdHAVZLeXur57/AIHzYyJtUxB8kDdnJ5/z/Or1odrttcsqNuJB5JFfojTT 5j4iLTbj1Nae4JSFQSR1Prz0FWYZcRgnqa0Tb1JSSTRcVMYETA/jWtGzxlQOucdvxrRLUzk0lc6O 2lZYN/SQ/Lx6VtWkrxuu9eTjPpjH+FaLYhu7NiKUHcyEjsCOtdNphDSAP0H3veuuGmxkzsrOUTO2 4/u8Y4745r0PRgGhBfBixnp0HX/69dNO8pWRErLVnoWmzhWhiLFiTwwHJB6V6VpUrQBrbft2rkk9 81ty2dmc8ndOzPRNIdmSDyVDSKoUDNdFc6np2kWs+oatfx29onLyzOERMepPArhqwlOoqcFeT0SW 5Skkrt2SPyy/ar/4KUeHvAyXPg/4IvFqXirc0U+pMm62tCOPl/56N+nFfhN40+IHjX4g+MtS8T+L /EdxqGsXTl5Zrh8/MewHQDsAOAMYr9x4K4aWTYVYrEx/2iotf7q35f8APz9D834izj6/X9jRd6Uf xff/ACOek012nhilm3RYy+0YPr2rtLdtOmijsYIv3IwBkdT+H+ea+35ldu+x8u6cpxWlrG1p2lHz BaLARg5xjqc19t/s5/sdfEP4yzW+px6X9g8Hs5L6xexsIjtYKwhQYa4YHd0IXMZVnU14Ge51hsnw U8XXe2ijfWUnsl+fktT0sDl1fG144aktZfcl1bP2/wDg7+zl8L/gnbI3hbRjNr21kk1W+2S3RUkk orBQsS842oq5Cru3EZr3ev52zDMMTmmLnjMXK85fcl0S8l/wdz9cwGBoZfho4agtFu+rfVsKK4js CigAooAKKAPkb9sL4GD4vfDW+vNFtwPGWmqbi0dQN08a8yQn1yM4/wBrFfgHbpLFa6laT8xRuVKN wynGCdp5/wAmv3Hw3x6r5VUwc3eVKWn+GWq/G5+Scb4X2GZqvb3akU/mtH+n3nMP/Z9jcAfZ98bD MpHUtgk/pX8vH/BYT9knSfAXjO3/AGhPCGmvF4P8QTbb9Io8JbXXTLY6Bv8ACvR46wLx3DdXk1nR kqny2l+Dv8jl4SxKw2bU4yelS8fnuvxPzk/ZR+Jd34I8cTeEzdE6ZfOGij3/AC+cOmMf3hxx6V+r viqyj1LThqMMf74YYg9V5HoeuK/kPiGmqGYUq0dObc/qLhqq8RllXDyfwbHgl/PJDcXMcikW+BJ8 xGTjHO76812Xg7ULdHjhuJeFx5gI5Yds9vrj1rjxEeakzqoT5aurPWbe8hQskAAk4ZeO5579OM1h 69ZQeWk0jKTkK44zn1UD8Pfj3ryIJqSsepP34PyMfQb0pcXqxnZFkbh2Jzg/zr02zla4IeBf3pAX BHJxz/U/4VNXSeoqL92x4r8QvDdskk1zF8lwy5+Q8ZBOMj16V43eW8hhW1W53swOePwbg9/pX0OU 1eZRTe36HiZlDlcmir4ZDeb5KDLr8uSCPy9B07dq9NimNrKkkm4hccKO3f8AlW9aP7xw7HMtkxdZ +x3tg29leQ4fbz8oHJA/P9K/Pf45aMdK1iDWreP92xBPBGTwP6GujL241OR9Tlx65sO5Lo7npHgb xGb3SbW6tW23KFSrhiCrDbg98cg10H/BTH4Yjx/4K+Dv7Xvh6MONdsxoniZYx/x76paKIyz4A++g DZ/2hXq5U1HFVqPWUfxi0/yueZmqjPDUa0fT+vuPyL8MeMPFvgrUxqXhXxBeadqKEETWlw8TEjpk qRnHvX3Z8MP+Cm/7THw+nsRqXiCHXrCJlDQ6nH8xVT0EiYPfqQelfofDfGOb8NS9nhJ81B/FTlrF 97dYvzR8HnPDuW51B/Wqdp7KS3/4PzPdNV/4KVaJ8VdXs7r4o+FJbKWPCiTTnDxoN2emA3vx6Vq/ 8Ni/s+/8/wDqv/fl6/acP4ocKZhRhWzGE6FVJJxSclot01/wGfJT4SzLBqOGwFSMqcVo3uf3B6Rc 2Mut2AhaRNKEErxqki42FwrSdxl9g564UenG/eazaW+pfbVfdawW0LWoUFjbKf4QyqMEvuOfXHPN fyZtGLe2v9fgfsivpFl621W5aSCVLZltvsrhkaRvMkUjapkJzuw4zgjnaOe9aD20lnJcTyX6rZxM J5RKBiRdrAtnnLEkAYz1+lc9nK7t/Vy3LSx5xqF9eWkyada7JXYOqztIAFyvmFAPUBlUDuSaswap pv22yjaMb1RfMVOd24Nn8Bx+dGnUdnvcsTTXHlpcLaAOyeXv2kj646cdPc5q7s8oSXLW5DI8fkK+ GIA6574AP6027K3YnTm8i/pVxfXULTo48ovuKEnKEAkfTP8AStM3uqJHG3l/vyPKxJyMHuPocVUX ZWaKtZ3Zm3N1d2d4s7MiszLHwucZGDzVK+EcM0MEkasSC0h3evPNdtJq3K0cNbV3TMV5WlIhiiKx 4PJ9DwKtwyM0iFgQIhtDMOw6HH0qpO+hVJanXaBa3Ws39hpmlW5m1K9mFrbxD70judqgfUkV7F4t tLXVvF3h/wCEfhuZJvB3hAtDdTxH5NS1hyDdzHBIYIf3KgjK7HHQ18/n9f2OD5U7cz/L+ke/kVD2 +Pp9o6/dsfYHgjQksbW3QIAAAB+lex20axR5/KvhMPrq0fa4yV5cqPOPiX4ztvCvh+8v5ZQHC4QE j5mPQfnX5paprFxq2ozX13OTNLIXbGcHP9K+84YoNUquIfV2+S3PkOIK1nRw0ezk/wAkNSe6FuIl D7ic5GeR61etJSqkscIxyR64yP8ACvq7XVj5lWi7rcvxThpWjPIUHGf51qRZwUkyQTV7IL3u9jWg QSAOZcjp9PWtBQw2qX6YOfU8Y/KtYNoymnZG35yhI8Dkn65rWW5eRlBOQRxx09q2iZvd2Nq3uAkA X1Yc/wCfSurs34UQjJbGM9veuiD0uR1sdnpqKyjk4GWNdlbagFWBN5CjgqB2ruozUZNmNSN1bzPQ 9HuisCSKQJMDYfT6/nXqNhIZIxHcn52Zct9K0fddSWlflPU9MuvsyxlB8vBz6ZrgPjt8G9O+O3w6 1XwPfardWc00ZkhmtpmTEo5UsAfmXJ5U8VjRxEsFi6WMhvFp/cYYmisRQnQTtzKx/MN8Y/gL8Qvg h44uPCvi+08tVk/cXJUmK7j7MjHrx27Z9q8oj0SGHUZrp58IDvYep7cflX9HZfjYZngqWNoP3ZK/ +afpqj8gxVN4avKhJarRmtbwreTiSGPdGQA2RjP+c1698Mfhd4g8eeJLfw54U8MXd/rEh3+TawtK yJuVS7YGEQM6hpGIUZGSKvF4mjhaMsRiJqMIptt6IVGnOrPkpq7eltz9w/2ff2BvBvhC107xL8W7 RNU8UAB10vfmytcFSvmgAfaHABDKxMXzsu18B6/RSKKKCKOCCJUhQBURAAFA4AAHQV/OvEOd1s7x 8q0n+6jdQXZd35vd/d0P1jJcsjl2FipL95Je8/0+X5klFeCewFFABRQAUUAFFAC4UjBGQa/Av9t3 4KS+BvjFea/p8SxeFta3XQSJcCOUnMnA45ILfifavv8Aw6xjoZ3LD3sqsGvmndfhc+J45w3tMshi EtYS/CWn52PizULLSfLmkF1tZDy578YFeB/HP4K+H/2kfgr43+FviW3jeK6t5fsUroMQzBco4z0J Pev3Cvho16VXDT2qRcX6STX6n5Vh68qEqdWD1hJP8T+Ez4jeD/EPwe+J+v8AhS8V7XX9E1BoRJgq cxsdrjIzg8H8QK/Zf4LfEzT/AIq/DrQtbEqrfyw+RexHkrMg2t/n3FfxXxjl86LakvepScX8n/mj +r+C8wjKbhf3asVJfd/wUYniHRru0ml8iM/ZUOHJGQFbp06dP0rB0tDBdyXYbKZDFvXGBg8f5/Cv n6c1Uwya3aPpKkPZV3F6anr+jXCS3C3ZKqCu7DdQeQe3PT29K19Tt7eYbXyzEZw3GM/T8K8mV1Ns 7460rI4G8EOm3saBWy7BdwOQD+h/PPQ16boN4P3Ek04LM/AA5BPTjvnp260q1+VSFQlafKR+MtJi ls7m5jzIw+8u3LLxjj0r5ZvnkttQuI2ZzEFIw65KN1BGOTXflk/eaZyZjC90uphyTPY35aRQsTkE DAwWAyfw6131lqDXVlE9xKBIXAKleoHTv6e3evcxEV7TmXU8eDvBc26J4pY7h3DAKFBGTnIHrz6f 1rwT4uaB/wAJFot8rRZkhJKAE5Ixz/Opw79nVi33FVip0px7nyP8O/E1z4d1eTRriTC78AP3OeQP wr9Sf2ebrwl8WfBfxA/ZY+Jt5HB4a8XRLLo95I+F0vV0U+TJnOFDFiM+/P3a9aM1hcfSrva+vo9H +DZ40m62XTpdYa/18j8M/jd8FfGPwS+Jnif4Y+ONOa18Q6ZdPbsXUqs6A/JIp7qwAIP4dRXlVxoc 0SFpQwmHTjIfvxXtSThJxfQ8Ja6GLFbTTT+SkRacnCgDJJz2rV/sPXP+gdP/AN+//saVyHof6Y2j abqcOlXT3Enk3MdtNEvzKgTDrnG1hvwDIeOeSTwONTRZJpoluRceTZSbUiR1UGfYxXI4z0ycknOe ScV4MleW+h7Sl7ux6J9uktJRDbSoY7iLe28A+QCSVA9OR0H96sHW7yQQ6cZb8y+Sdkiv/FgsRx65 z+nXFZyj0He7u0UINL/tKJ7hJ1jmWc+SrZL4Vg2DknJIAB9hWvq0lpbzi1it4o3CqkrIByRjCjHo GFRy2TbG5PYmttZnjtMGD/QDEY3RuqFRnIPvkfma1pofMEVtG7rf3Ei7I2BLRQDDbvxH51ctddiI /ETwNBFMtlbMdpOH4OcqwOTnqcAfgT3qxdXJl864Eu6aKTlcHBIHH65zVxtZIuT1bMF7l95lkYeY 0vzgfwgYOfxNZk+6+EcwZtzdR0wARzXVDfc5JO8bG02lgNbxRuTEuGfIwSAOeR65/Sr01tGqTW0h BfA2DuCfr7USV3oVTutz1PwPIPhn4M1v4rTKT4gd20PwnE65J1GZD5tyB3WCIk56FmA6ivVPgn4I OmWFvJOCbhzvkdyWMjHqxY8knk5PJr4biXE81dUU9F+v9I+44Xo2hUxL9EfZukWghijG3GBWzeXQ t4GZuAP1rwaKaij16j56p+efxx8dHxJ4gk0ezlJsbMneB0Z+/wCVeCKytFH5gx827nvmv1TKqKw+ BpQa1au/U+AzWt9Yx1Vp7Oy9FoaiTGJlDFtiDp069c1qLFtEK7WwFzkHOO46V6iXMjypaNAhcToT hdzY5PU1uRybj5eTt78d+tGujuaO/Q3IwRGAH/eYyPpx2qwG2bfMYZxn61pF6IyldMsw3GZsbhjg bcdK3IpQ0irk4zjg9/8AOK2W5mjctZBLJt6Ipxmuts7r7OkbBfnHHP410rW1iNDptO1J8P5fCEHg dxXVaXdq+5peCfuk8iuqn3M567Ha2OrKhEeDjjJHQV6RpWtvPciSUksuMD+8B1zXQnFqyMpPS6PW NE1Wf7HPIyN8x+XuAor1jSr6O4tPtci7ZAdq8YyP85rlxMbx5kKLW7POPjX8CfAfx28JXfhvxhpi NK0Z+zXiqPOtJMcMrex7V/Nz+0r+zB8Qv2evFdnoWtQGbw5es50/VY1zFdhT9wn+CQDGVPqCM195 4eZ77DESybES92prC/SSV2vmtfVeZ8dxXlcfczClHyl89me+/s0/sL/EP40QaV4i1UNofw8wrrqF 1DmW/UHkW8RIZsj/AJathPQvgiv3l+GHwf8Ah18HND/sH4e+GYLG3b5ricAvcXjbmbdNM2XkwXba GJCg7VCqABx8dcSf2hif7Kwkv3NJ+8/5pLp6Rf3vXojp4Wyf2NP+0MTH3pfD3S7/AD6eXqel0V+e H2YUUAFFABRQAUUAFLntQADH49a+eP2mPhVp3xP+Gmt2skAOs20LXFnIFBZXUZwPrXp5NjJYDNcL iov4Zq/pez/A8zN8LHHZdiMM+sXb16fifzr6lBBaS3Okz6eTcxSlJlcYO4ZBBzXHSA2cpFqxiOCQ CPlI68/4+9f0/GfNGM4O+z+8/AoXhOVOa62Z/Mz/AMFpP2bBba7o37RXhnT1W0vT9i1lYVxslHKS HHryCf8Aar8t/wBkD4o/8It4nv8AwpqFxjTr795GPSYDDKB7r/6DX83+J2VxpZvjIRjaNVKovnv+ KZ+8cC5g3hcLU6wfJ/l+h+pPiKQ6jpkWpwFjC6gyrggY7bh3I9+nNeGqbq3u4GhDBWZ9525Vc/l6 jH1r8UwKtTnSl0bX3H7NjnzThUjs1dHo2jamZGtsgeTvUOSTknI6fn+FeoRySXrCYKnlnCDjsD6f Uf8A6q4cTHlm/wCtTShLnjp/XmefeILK53XMSQKkoYuW3fXt7+3pWl4T1IgfZ5mZZExywOSQRx+g IpStKlp0DVVex68264shlQ2RtOcZx/Wvlvxhpbw6ndzJEywyEsysMHIXgr/9b0p4KSjVt3KxsU6S kjz7XU+16XDNFu3xDIHOccDJBqlpupTzRLGW5wCAR6DB/kRX1UkpQg/VHzSfLUlE3hrFukB847ie A3fPofzrJvprLWIp44rgLOo6eox/+oVnyuLcrGitfVnwJ8VfCmo6FrEmpwqQhkLhgvGTzjNd18N/ iS99bW6rOYdUh4/dswZWXG1l984OfavSqwVehGp2PHoy9hjJ0ZbSP1BeD4G/8FAfBei/D/46axF4 d/aA06IWugeMVQBNTQABIronAZhwME9uDnp+Xnxz/Ya/aO/Z01K7t/GPga5v/CYJa31zTIGu7K4i 7PvQHZx97dgDpk16eFxHt6CnLde7L5bP5q3zPDx1F4Su4y+Hoz5UsXsre5WWO2RZUO5XCg4I4710 v/CQTf8AP4v/AH5WunTqcm73P9AC98U6jNquqwPI00dqUtY0ZifNGcM2cDkne3Y/XBNb+qa0t7Hp MEBMN5kGSGOUFLRAm08juT8x5HUV4DfNHm8z3m9E7HZXl4Z7q6j027djKHYYJzhQFRfxYVmwM+lf 2hY3SHbGV2yP1DcEDJ69cn/drNxaeoc17pHpGjX9y9kjzWcKrs813YjILDaF7YO5gT9cV53BJqJ1 OTIzO87B2ZvlGMEkc9gAfwxVaLZE31aOrtrjzLlYTIHtHKSsVGVChlBP5A9PWt6TWxDr99qO5pJe UjJ4EcargH/CpttdlJl6DWdPs4EuLZt1zzuyoyMnr+Hr9KxrHUvNvJXaVvLaTLYPX6/hVxXvJJhU l7uxE92l1eXMjx4gQNuIBxnHepbKZNynaVUqvc966qdtOxyO+yOtspUuJLuKDexUAHJ6gdea2tC0 DUvE3iPRdBsAH1S9mEScn5C38bY6KoBYnsFJ7U6jSbl8zePM48r3PQr27sviX4/0rT9AXd8PPDMP 9k6OQBtumBzcXZx1aaUFs85CqfWvtTwdoqWdrAir0ABH+elflmaVvrGMnPo2z9Myyl9WyynFrVq/ 3nrMI8pAR17V4d8ZvHSeG/D9ysMwF/KDHEAecnvXRl9D6xiqNBLdmFeqqNGrXf2U38+n4n5ySrqD tNcScytjc/ck880yJ2SJI3iZjnLYB49P1r9VppwSj0PzeTU7tk9tI7rLGzEggAdz/wDXrfs72NIZ FXBOBnn9K1Uml5EKKlpcelyvlBVBLAiui06WJZlbd8uc+tPmvsUlrc3LdwiyXE2AGJxjtVUzxzkl cgZwOeR6GtVvoZNmmFjit3kU7pRwcfTtVzTrhX2qxwR97I6VolsjM6C1eJ3Q78KAM4966S3VZ/JM N1lS2089Mn/69dEdlZ6ku6OmtEYI9ukw3JyTjp3/AJZrq1AtrWOZLhTGFGBu713U4uyS+ZhKXdHQ 2WrR4t4IgG8xdp5yd3+c16Dp0l8Lu1tlTl/unPXJrr0unbYxXNFO57noImv2/s6K6ZVtlyyn+JeA f5ivV9ClZQkbndZcqnsSf/rVzYhaNdiYSv0O5t9yAo5zjgVzni7wR4R8e6fb6T4y8P22o6bFcR3U cF1EHRZYzuVsH37dCMg5BxXlwq1KNVVqMnGS1TW6OipRp4mhKhWV4vdHSxRRQRRwQRqkKKFVFGAo HAAHYVJWTd9WbpKKUYrRBRQMKKACigAooAKXFAEXmp5jxnhwu76imRXMU6v5LAsOPpVcjtfoZOqt uosvmAo5ICKMsaazwXMLbgDGwK4PftTtopLoQ3upn4X/ALdPwm0rwV45t/F/hy0JstT+a5jRdqxT A44475/SvgS/VbaHyrsYut2V5yAhOSPr/wDXr+lOGsVPG5HhKs/i5bP/ALd0/E/Cc9w/1POcRTSt Fu69Hr/wDwP9of4FaL8evg146+HF5bq9tfWUph6bo5VUlD9c96/g98aaB4i+DfxO1TRL2Fotf0TU miO8EZMbdfcHH5GvgPFHAXp4LHpbqVN/+lL85H2/AWMajXwzezUl+T/Q/av4WeJLHx38PdE8QWrF rfUIFLx9fJlAxImOnDbq831eaaw1R7A8GLPyno/PH09f1r+X8OnHGV6cls/xWjP6QqtTwGGrx7L8 dTQ8P6oxEImCoWXeCRyvbBAHPOK9W0jUYo52Ea5d05VjxnP4Ed+KxxUGql4lYSadkyxrDC8gxGmJ OrgDIcD1HXt+lcMNQGm31uwRlypU5A5ccDNctJc6cH5mlRpTUnoe0aBq8coij2qW8vruOAe+Ow71 598StL86MXKIVU5G5ecZBAPpkf1rOk+StFHRU9+g3Y8DM0MMzW8M+8MCrMRnDEYOf/11wFvObC6m tZVJnRimxuMAjj+fX3NfW0ryw/3HzFa0appM4lBAbJH32PqcHGf8/jWQW/eefHhZFHzYOMDGOn1G efWrV7WIk7Gf4q8OWfijQ5YpMOCpIXGCrY9/pn/61fBfirwzrHgnWDMu+Pa+6MrnA+vpXbg6ifNS l1PNzGk/drx3R6j4K+KcN5NFb6lIILtcKH3AJJ+fQ/Sv1P8A2cv21fiV8P3Hh/U/FcN14VZFVNN1 xDeWrfNjYrn50Ug9842g4OMHOUquBq+0pK/l0a7FRhRzKiqdWyffs/8AJn1z4rtf2WvjJdW0/jL9 kLSdU1W50SXXLrUvC97bK0FrEGaZ5PmjdDGAXdcblXBIxyfE/wDhVv8AwTk/6Nu1T/wdD/49XTDO somrylKD6xs3b7jzavDeOpy5aUZOP927Xf8AU/bOz1mGDbfwXE01jJcuZWg+bJKkA5AHIHvxuJAG efRtIuPDbfaJ7aVotSfaGjbktH8nTkMSTnpk9OKylHRxvqv+AVdu5t6b4he11ea9NkyxwttI3EZG W2k7hwM4wD7Va1nxJHf3Hl29uVjMjEO/BYhVA47cH3rJ2sl1He7ujpm12fVLvSrWLd/Z7IkswBx8 inJyfXd0/OsDVtedPEMq2FrtCzbVH3uTuUnn6gfhU3i5WQ7W3Ohg8RutnE6IgmnLs3QYjz93H15q ydUmle8uxdKis0ZCnJzubOPYA/oKOraGl0REmpR+dcOWDHyy2OcFjxn6Veh1m3gs4YWw0jkyMQcc YwB9c/pWtOzRnVlroST3d5bRqoGbabbI23oQccZz71tLqcV3cwJZt5cKAF8Y44xk+tdCaUV3M1rL TodbpLlI57nBNu0mwYGOgySK9LTULjwV4Fvdet12+N/FAk0fRlBIezsuBeXS4OVJGIUbqCzkZrz8 xrKhgakvK33ndgaLxGKpU7aNq57h8GvBkOjaXZxrBtAUA19e6RbLFGPTpmvy72nPWlJn6jV9yjGC LGr6nHY2kkruAqqetfmx8T/G/wDwlniS/nWbNha5jhGfvHPJx9RX1/DFBVcXOu9or8WfLZ/iPY4J U1vN/gtfzseXx3Mu07z8ikgtk4wf51esTHJctBIcqfvMCOAen8jX3y5t2fEuV1YW6jaH5oT8it8r jvn2qKJZbaNhsJYnhs9uvarvyrVE3vqifT5ws7CdMEr+R/yK1LG7mWYKjru3E4GcCm3azKUrs3zd m6ikUSAKrcqeOmafb3aSPvYDcflA4rVMy3di1b3qgyhwQmCVxnk961EureONQkh3OvG7oSfStoSS SlfVGTu35GjaXEqM3lsN7LgA9+ozW3a3xtrF41k2zvJuAx0AGcitKTTlr5hJ2VkXYNculuA6SLsa PDE8hu3+FX7XU5p2WASkkjdtFdFOTezJlZbncaK81rLbTF8gDIYk5Ir2bw3rUNzqlndXkzIpdY4y 3Hcc120pNx5b21RhN63PftA1VbWTUbsJvBJij2nnJ5yfbpXd6Jqd7bJa280ylWYkjuncD9aucU20 YRb2PULDW4Zbh4yWJXHzetdQpDAEV5Fem4SR2UpX0ForA2CigAooAKKACigA3JkjPI61nXl6YOEg 38fNg8j0q4Q5pWehjUqJJ2OcbUTDeJc6qHQ5Me1Rldp6Vr2Swjzru2cfZJRkf7JHeuqpFxj7vwvR epyqV35jBfNKVsJFZkYHbNjhgPes241Qpc2M6xlYd7RexI65/DNEKSva+mv49PwBzvueCftL+FNG 8f8Aw61nSri3R77buhbH+rccg57dK/n51/QLu01a5tNTaNHty0T85JYHgc8+/wCdfsfh1iJvAVsH J/C7r0eh+Ycd0OTEUMXBfEuV/Lb8Gc5qqf2VZSi2l36o5ACp0Ktxkd+lfytf8Frv2Tr/AOHHjrQv jrpWlsmg62ghvmVOI7gZOfTngflXq8e4ZYnhmpFbwamvk7P8Gzn4NxHsM0in9rR/Pb8T4X/Y3+M0 Xhq01LwDq7f6M8/2q23twpIAcAfhn8TX2x4+soo57TXoo8wPH5bgg4ORnJ4/zzX8gZnR+q5tGona NS/3n9PZPWWJymVN707fcchp995ERkEBJJPByR17du+a7/Qr37XNaSBG5fEsf9wdc/rXDi0leR14 aSXu3O6Mj27GO5kY25YqAV5A5Iz39a828QxRw6gm75lzhVLZUHgDPp/T8K4KL9/3V0O2q01r/XY7 DQr/AGPlhsIVRjOQcn0+hP8Ak119/bCeznSUK0DFn7HGQemP88fhWM/dqXW7NINSp2Z8l+IrWTRL +6tCgSVmyrv069c9zzk/Q9xXE+JoY7a5h1dVG5m8qTHUMMAkY9Rj6cd6+rwU+ak0uq/4J87jFy1P T/gkH9pSPCGDEiQgjg4br7e/+TWXdXvlufLm3My7ssSCDg9emOSe1dVk9bHJKpJJO+hLpetTWTFJ QxtWYK4JGff6+n9RVTxt4a03xbDNFOimOUEpIACTwcAms03TqRmgsqtJwkfE/jP4b6r4ekuUjVns UYncvUfWsXQvGHibRB5MF472yMB5MpJGO4Gencf5FeveniaWv/DHiP2mEq6f8Oex6R8dr+xWWCY3 dkZojDIbaVwHjYbWBGeVYcEdwfYVY/4W1o//AD/3n/fA/wAa5fqTTbSvfqelDNnGKjzuPkmz+vPw VJJ9i1dvMbcNxByePmFe1+DESS5LOoZvKi5Iz/y2jH8qzm7NWPM+1M372WVNQhCyMA91GHwT8446 +vU1sAD+3NSGOAgI9uBWc+hUf4Zt6izQ2ty0JKEQxgFeOPTisrSFEl9d+YA2JFxnnHK1z3d7FQ1W ptXn/IE8Myf8tCZ8t3Pzt3qOIk6TqpJOd0f8zQ27yCPxSG2nVf8APerNz/rB+X4ZFdkP4cTGt8Vv M7yUnEC5+UK2B6c1R07/AI+bZf4TsBHqNy1VTYUN2em2pKwKinC4bgdK7zxQS3xT8JwMcwQ+GdKE KH7sQaLcwUdFyxJOOpJNeHxC39TXr+jPfyBL+0Kfz/I+3vBIAt7UAYG1a9mtiRCmDivzqPxs/QMR 0PKfi1LLF4X1Vo5GVvIflWINfmXcs3mXfzH7y9/c1+g8K/7nVfXm/Q+G4pb9vhV/df5kuSDKoJwZ mGPxNOsWbzJPmP5+4r62LfMfNNbm3dE/YF57n+tbVgM6fNns7AewxWv/AC8a9DOG/wB5yspJnbJ7 Kf8Ax6t/TCS9wSecLQm/axX9bDezXmW4fuz/AI/zNO0/m1Vj97PX8a1Wz+RD2L9uT9jlOec/1q2h J8kE5AYfyrV7/cKW6NK2d/tkp3HIifHPSul0wlo7gsckRLgnt8prag7yV+7/ACMquxVszkKD0y39 a6TwwSbyYk5I2/zrSk2tvImR6pcgLp9mwGGIPI+prslJA04A4HH9a6ot6/11MOqPcPDjuNDDBzuy ec816pCT5MEmfn5579fWu27sct3zHscCIHscIOQSeOvDV2Onkm0Uk815+I+H+vM6aBe7D6UlcZ3L ZBRQAUUAFFABRn7lBMtivL0lPfIrG1UD7RFx1Xn35rel8SOKrs/66sybj95e6iknzIEQgHkA8VH4 c+bSr0NyBLIAD2HFdb/hf+A/kc/VfM1VJWHSFU4GwcD8Kr6mqnS58qP9YT071lHePr+rNJfD8v0O Vmggn0nWVmhR1IjBDKCD+dfgv+1Pa2tt8XtejtraOOMruKogUE464Fff8BSl/a9VX05H+aPguOUv 7Npvrzr8mfKMbu3ie0VmJXyOhP8AtGvkT/grxZ2l/wDsAePJ761jmmhljeF5UV2ibJ5UnJU+4r9C 4p/5FVddOWX/AKSfOcIt/XJvyj+Z/Dx8PneLxpopiYqftGPlOOx9K/bEEzfDa3eYl3+woctyc7ev Nfx7xR/Fwr8/1R/TXDH8PFrpynkmnyP5ZXedu9hjPbLcV3/g2ST+1JW8xt3lDnJ9q8zFa0tT2cN8 a+R6lOS0ku4k4IIz25rzfxWzf2hIMnHyfz/+ua8yHxr+up31uoaNJI1mSzkkqQST7rXsumkmx0zJ zm3JP4dKiv8AFH+uhVLden+Z81/E4A6rCpHy7G4/KvGfFHOkwE9Vuht/2fu9PSvocr+Fni5kldGT EzCytiGOflHWqjk/Zbvn/l3Lfjt6/WvTXwyPLnsv66hcALGdox8rHj1y1aenyynTmBkbAZgOTxya wqN2Y4b39TN1OOOW2i8yMNmGQncAcnnrXxl43hhinuRFEqje/wB1QO9duCbuv66s48wS9nF21POp 5JDFkuSRwDnttNZXmSf89G/M16iPJP/Z /9j/4SCCRXhpZgAATU0AKgAAAAgADQEOAAIAAAALAAAAqgEPAAIAAAAGAAAAtgEQAAIAAAAGAAAA vAESAAMAAAABAAEAAAESAAMAAAABAAEAAAEaAAUAAAABAAAAwgEbAAUAAAABAAAAygEoAAMAAAAB AAIAAAExAAIAAAAQAAAA0gEyAAIAAAAUAAAA4gE8AAIAAAAQAAAA9gITAAMAAAABAAIAAIdpAAQA AAABAAABBgAAB6wgICAgICAgICAgAABOSUtPTgBFNTQwMAABLAAAAAEAAAEsAAAAAQAAUXVpY2tU aW1lIDcuNi40ADIwMTA6MDM6MDYgMjA6MzU6MzEATWFjIE9TIFggMTAuNC45AAAhgpoABQAAAAEA AAKYgp0ABQAAAAEAAAKgiCIAAwAAAAEAAgAAiCcAAwAAAAEANAAAkAAABwAAAAQwMjIwkAMAAgAA ABQAAAKokAQAAgAAABQAAAK8kQEABwAAAAQBAgMAkQIABQAAAAEAAALQkgQACgAAAAEAAALYkgUA
February 26, 2010 - March 06, 2010
RV10-Archive.digest.vol-gf
