RV10-Archive.digest.vol-gl
April 17, 2010 - May 06, 2010
      I've got a good set of tools coming from PlaneTools, but am wondering about
      setting up a work bench. =C2-How big? =C2-I'm going to build the bench
      from
      scratch, so wondering how wide and long would be good, since I can make it
      any dimension then I might as well make it right...
      Tony Woods
      Not started anything yet!!
      MS -
      e -
       =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin.
Date: Apr 17, 2010
Subject: Re: G3X has now has SVT. :)
A Garmin GNS-430/W will flow a flight plan to any device that understand Aviation data on the RS-232 or FLT PLN data on the ARINC interface. This includes any device from a portable up to an advanced EFIS. I have a backu p portable connected to a 430W and any update to the flight plan on the 430 i s reflected on the portable. This is also true for Aspen, AFS, GRT and other EFIS. I would expect no less of a G3X. -- William N40237 - http://wcurtis.nerv10.com/ On Mon, Apr 12, 2010 at 11:18 AM, Perry, Phil wrote : > Check out the attached file=85.. > > > I only wish I could control a full Garmin stack with the G3X push buttons > now. > > > As it currently stands, I believe you have to load an approach in your 43 0 > and then do it again on your G3X. Kind of a pain, but it would be nice i f > they linked up so you only have to load the approach once. > > > But I really like the direction the product is going! > > > Phil > ________________________________________________________________________________
Date: Apr 17, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: Finishing up and Painting
It's starting to become clear that my next major step is composite finishing. I've just 'finished' basic fabrication of the pants, canpopy top, doors and cowling but the next step will be going back and getting these parts to some sort of a final finish status. I guess I need to pick a path through this including a paint system but then just focus on composite finishing until I get it to the point where the aluminum is. Glad I'm building an all metal airplane. Let the mess begin! Bill AirMike wrote: > > I found after finishing the plane and getting it flying that the hours upon hours of finish work on the composite parts were starting to drive me crazy. It was a real grind and dirty work compared to the build. > > If I had one suggestion on painting. Do as much as you can on the composite stuff to bring it to a high standard. Otherwise it is just lipstick on the pig. > > Most of my fellow EAA'ers locally seem to like the DCC Concept system for self painting. I never got even close to perfection on painting my interior parts, so I decided that: considering the toxicity of the acrylic urethane systems that I would farm it out to the pros. Cheap it is not, but spraying is a real art. You gotta respect those in the build community who can do it well. I could not. Currently in the paint shop - Jet Glo now being applied. > > -------- > OSH '10 or Bust > Q/B - phase 1 / painting > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=294424#294424 > > > ________________________________________________________________________________
Subject: Re: Vettermans plans
Date: Apr 17, 2010
That's all you get. Just start pre-installing what you know fits where. And then it's fairly easy to place the remaining items. Some of us have replaced some of the support brackets with heavier metal. The install is rather simple once you get into it Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294590#294590 ________________________________________________________________________________
Subject: Fuel Lines
Date: Apr 18, 2010
Hi I am planning on installing Bonoco Inc steel braided fel lines in lieu of the soft aluminium lines spec'd by Vans. I am wondering if anyone else has done this and if so how the the fuselage passthrough to the wing was handled. It would seem that one otion is to use a bulkhead fitting at the fuselage which would make the connection to the wing vey simnple. Alternatively a single run of fuel line fom the fuel valve to the wing is also an option. Thoughts . comments anyone? Cheers Les #40643 - Systems / Wiring / Finishing ________________________________________________________________________________
Subject: Workbenches
Date: Apr 18, 2010
Tony This link : ( http://www.eaa1000.av.org/technicl/worktabl/worktabl.htm ) will take you the plans for the "official" EAA workbenches (if there is such a thing. I put mine on heavy duty wheels (lockable) so I could move it around easily. They are very strong, dirt cheap to make and entirely functional. I put MDF on the top of mine as it is soft and there are no splinters to worry about. I made two and, on occasion, clamped them together to make a single large surface. If you alter the dimensions of the plans, you can make smaller (or full size if space permits) work benches to hold some of your power tools such as band saw, drill press and grinder. I found a table top belt sander / disk sander to be invaluable. I learned from experience that when making long straight cuts on the band saw, it was better to cut proud of the cut line and then use the sander to take the material down to the cut line. This dimpler: http://www.averytools.com/pc-619-84-drdt-2-hand-dimpling-tool.aspx is absolute gold. It is much faster and easier to dimple using this tool. I can't imagine building without it. When mounting my gear, I placed the whole fuselage (without the tail) on a table. I used an engine crane to lift it. It was the perfect height to allow the gear legs to be installed safely. When you get you kit(s), keep the Styrofoam sheets, or a least some of it, to put under large components during assembly. I also made, using 2X4's and MDF, a large dolly for the fuse once I moved into the "boat" phase. It was 4' wide and about 6' long. It also was on castoring wheels. I am a big fan of MDF as it is perfectly flat, cheap and doesn't splinter. Cheers Les #40643 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rwendell@hydro-splash.com Sent: April-17-10 5:17 AM Subject: Re: RV10-List: Re: Firewall access I went with 4x8 ------Original Message------ From: Tony Woods Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Subject: RE: RV10-List: Re: Firewall access Sent: Apr 17, 2010 3:00 AM Hey all. This sounds like a stupid question, but I'm about to start work on my empennage in a few weeks and am getting my workshop sorted out. I've got a good set of tools coming from PlaneTools, but am wondering about setting up a work bench. How big? I'm going to build the bench from scratch, so wondering how wide and long would be good, since I can make it any dimension then I might as well make it right... Tony Woods Not started anything yet!! Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Apr 18, 2010
I was able to figure it out with a little head scratching and some pics from a build log. I wish I could remember whose so I could give credit, but I forgot. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294646#294646 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Subject: Re: Fuel Lines
Date: Apr 18, 2010
I would recommend using the soft aluminum lines. A lot cheaper and last longer. In fact, you could buy the flaring tools, all fittings, and the aluminum lines cheaper than the flexible lines... One suggestion would be to split the line from the fuel valve to the tanks into 2 lines and use a 90 degree bulkhead fitting as they pass thru the tunnel walls. Then you basically have 2 straight runs vs. 1 complex run. Just my opinion.... I can send Picts if you'd like to see how I did it. -Mike Sent from my iPhone On Apr 18, 2010, at 8:45 AM, "Les Kearney" wrote: > > Hi > > I am planning on installing Bonoco Inc steel braided fel lines in > lieu of the soft aluminium lines spec'd by Vans. I am wondering if > anyone else has done this and if so how the the fuselage passthrough > to the wing was handled. It would seem that one otion is to use a > bulkhead fitting at the fuselage which would make the connection to > the wing vey simnple. Alternatively a single run of fuel line fom > the fuel valve to the wing is also an option. > > Thoughts . comments anyone? > > Cheers > > Les > #40643 - Systems / Wiring / Finishing > > ________________________________________________________________________________
Subject: FWF included items
Date: Apr 18, 2010
When I am looking at Van's website for what is included on the FWF kit=2C i t is different than what I received from them. I seem to be missing a gascolator and a starter solenoid(contactor). Reviewing the paper work that comes with the FWF kit=2C I do not see that e ither of these items are included. I would think that since the FWF kit for the 10 is the most expensive of al l the planes=2C and if these items are included for the other planes=2C as is stated on the web site=2C why not for the 10??? JOhn #409Engine and gear about ready to come off so the plane can be extrac ted from by basement. ________________________________________________________________________________
Date: Apr 18, 2010
I think you are getting into esoterics of fuel line life. Standard aircraft fuel lines when in wings/fuselage and not exposed to engine temps or outside air last a very long time. I replaced one that likely was OEM 40 yrs old last year. Yes, it was hard, no it was not anywhere close to risk of failing, it just connected two aluminum lines together and was a "while you are there might as well" deals. Personally, I'd expect any fuel line inside the fuselage, protected, to last longer than you will own/fly the aircraft. One can go to the braided stainless lines and have very long life, or make them lifetime by getting teflon core hoses. It becomes what your time is worth type of exercise more than what is cheapest or more durable. If your time is worth $10 an hour, you can make and remake a lot of soft lines. If your time is worth $50 an hour, it becomes more of an even trade off. On Sun, Apr 18, 2010 at 6:35 AM, Michael Kraus wrote: > I would recommend using the soft aluminum lines. A lot cheaper and last > longer. In fact, you could buy the flaring tools, all fittings, and the > aluminum lines cheaper than the flexible lines... > One suggestion would be to split the line from the fuel valve to the tanks > into 2 lines and use a 90 degree bulkhead fitting as they pass thru the > tunnel walls. Then you basically have 2 straight runs vs. 1 complex run. > Just my opinion.... I can send Picts if you'd like to see how I did it. > -Mike > > > Sent from my iPhone > On Apr 18, 2010, at 8:45 AM, "Les Kearney" wrote: > > > Hi > > I am planning on installing Bonoco Inc steel braided fel lines in lieu of > the soft aluminium lines spec'd by Vans. I am wondering if anyone else has > done this and if so how the the fuselage passthrough to the wing was > handled. It would seem that one otion is to use a bulkhead fitting at the > fuselage which would make the connection to the wing vey simnple. > Alternatively a single run of fuel line fom the fuel valve to the wing is > also an option. > > Thoughts . comments anyone? > > Cheers > > Les > #40643 - Systems / Wiring / Finishing > > ________________________________________________________________________________
Subject: rivets at bottom, center of fuse/firewall interface
Date: Apr 18, 2010
As I recal=2C the plans called for not riveting the center 8-10 rivets at t he above described location. The center hole is reserved for the bracket wh ich helps support the cowling=2C but why did they leave the other holes not rivetted? The nose gear=2C main gear and engine are coming off so I can remove the fu se from my basement=2C and these rivets can only be placed with the nose ge ar off=2C so is now the time to set these rivets? Thanks=2C John ________________________________________________________________________________
Date: Apr 18, 2010
Subject: Re: FWF included items
Both the starter relay and the master relay are in the electrical kit. Don't know about gascolator, as I am not that far along. You can get starter relay cheaper at Spruce, master a few bucks more than Van's price. Really a question of which is easier for you to get order from. Should be under $50 for both, with shipping. Kelly #40866 On Sun, Apr 18, 2010 at 7:45 AM, John Gonzalez wrote: > When I am looking at Van's website for what is included on the FWF kit, it > is different than what I received from them. > I seem to be missing a gascolator and a starter solenoid(contactor). > Reviewing the paper work that comes with the FWF kit, I do not see that > either of these items are included. > I would think that since the FWF kit for the 10 is the most expensive of all > the planes, and if these items are included for the other planes, as is > stated on the web site, why not for the 10??? > JOhn #409 > Engine and gear about ready to come off so the plane can be extracted from > by basement. > > ________________________________________________________________________________
Subject: Fuel Lines
Date: Apr 18, 2010
Mike Perhaps I am being a bit anal, but I don't like soft AL lines in the cockpit. While I am sure that the are serviceable, I don't don't think they will stay intact during an accident if the cockpit was in any way deformed. My thought is that a braided steel line might be a bit more forgiving. I have seen pix of a light a/c that was consumed by fire and it is a very sobering sight. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: April-18-10 7:35 AM Subject: Re: RV10-List: Fuel Lines I would recommend using the soft aluminum lines. A lot cheaper and last longer. In fact, you could buy the flaring tools, all fittings, and the aluminum lines cheaper than the flexible lines... One suggestion would be to split the line from the fuel valve to the tanks into 2 lines and use a 90 degree bulkhead fitting as they pass thru the tunnel walls. Then you basically have 2 straight runs vs. 1 complex run. Just my opinion.... I can send Picts if you'd like to see how I did it. -Mike Sent from my iPhone On Apr 18, 2010, at 8:45 AM, "Les Kearney" wrote: Hi I am planning on installing Bonoco Inc steel braided fel lines in lieu of the soft aluminium lines spec'd by Vans. I am wondering if anyone else has done this and if so how the the fuselage passthrough to the wing was handled. It would seem that one otion is to use a bulkhead fitting at the fuselage which would make the connection to the wing vey simnple. Alternatively a single run of fuel line fom the fuel valve to the wing is also an option. Thoughts . comments anyone? Cheers Les #40643 - Systems / Wiring / Finishing ________________________________________________________________________________
Date: Apr 18, 2010
Van's just has a generic listing of what's in the FWF on their web site. Last summer I requested a detail list from Vans for the RV-10. Here's what they sent: 1.00 FF-10 IO-540 W/CT10-3 F.WALL FWD.KIT W/3LVR 3.00 CT A-740 BLACK PUSH PULL CABLE BLACK 2.00 DUCT CBT-5/8 COOLING BLAST TUBE 2.00 EA 4" DUCT HOSE CLAMP 4" HOSE CLAMP 1.00 EA CV HOSE 7545 BREATHER HOSE -540 6.00 EA GASKET 77611 BLO-PROOF EXHST GASKT 4.00 EA DYNA VI I(O)-540 VIB.ISO. RV-10 ONLY 1.00 EA OIL COOLER 20006A OIL COOLER I(O)-540 1.00 ES ALTERNATOR DELUXE 60A KIT W/OV PROTECT 1.00 FAB-360/540 FLTRD A/BOX-360 FI320 1.00 FF-1005 BREATHER TUBE 1.00 IE VMP INSTALL KIT FITTINGS/HOSES 1.00 PROP GOV MT P-860-3 I(O)-540 LYCOMING 1.00 VA-102 FUEL PRES. HOSE 15.5 1.00 VA-133 OIL PRESS. HOSE 27.25 1.00 VA-135 OIL COOLER HOSE 16.5 1.00 VA-168 SENDER MOUNT 1.00 VA-186 OIL COOLER BOX ASSY. 1.00 VA-187 4" FLANGED DUCT 1.00 VA-190 OIL COOLER HOSE 27" 1.00 BAF-10-540 BAFFLE KIT IO-540 1.00 PT-035X1/4X4' LO PRES-BRKE RES.TUBE 1.00 SS304-26GAX1/2X9 SCAT CLAMP !!SHARP!! 1.00 VENT SCAT 2X3' RED 2" SCAT 3' LONG 1.00 VENT SCAT 2X6' SCAT TUBE X 6 FT 1.00 VENT SCAT 4X16" 4" DIA. RED SCAT HOSE 1.00 EA DYNA BOLT I(O)-540 MOTOR MOUNT BOLT KIT 1.00 BAG 516 RIVET AN426AD3-3.5 1.00 BAG 517 RIVET AN426AD3-4 1.00 BAG 518 RIVET AN426AD4-4 1.00 BAG 519 RIVET AN426AD4-5 1.00 BAG 520 MISC. AN BOLTS 1.00 BAG 521 MISC. WASHERS 1.00 BAG 522-1 MISC. FITTINGS/CLAMPS 1.00 BAG 523-1 FITTINGS/MISC. 1.00 BAG 524 MISC. CLAMPS 1.00 BAG 525-1 MISC/BEARINGS 1.00 BAG 526-1 CABIN HEAT SHUTTLE HW 1.00 PT-062X1/4X24" HIGH PRESSURE 1.00 VA-182-PC KIT THR/MIX BKT IO VERT 1.00 VA-189 FUEL LINE IO-540 25.5 1.00 CT 10-3 QUADRANT KIT 3 LEVER KIT RV-10 540 1.00 DOC FF-IO-540 TEXT/DWGS RV-10 F.FWD 1.00 EA EXH 10 I(O)-540 I(O)-540 VETTERMAN 1.00 VA-138 FUEL SUPPLY HOSE 14.0 Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Sunday, April 18, 2010 10:45 AM Subject: RV10-List: FWF included items When I am looking at Van's website for what is included on the FWF kit, it is different than what I received from them. I seem to be missing a gascolator and a starter solenoid(contactor). Reviewing the paper work that comes with the FWF kit, I do not see that either of these items are included. I would think that since the FWF kit for the 10 is the most expensive of all the planes, and if these items are included for the other planes, as is stated on the web site, why not for the 10??? JOhn #409 Engine and gear about ready to come off so the plane can be extracted from by basement. ________________________________________________________________________________
Date: Apr 18, 2010
Subject: Re: Workbenches (and other stuff I know now...)
When building that bench, make sure you use 2x4's that are _absolutely_ straight, and even better if they have also seasoned a few years (aka, perfectly dry). I bought the "premium" 2x4's at my local Home Depot, and found that after I assembled my bench (with a 3/4" plywood top) there was a 1/8" to 3/16" warp in the work surface. Not good. So I got some MDF, set it up perfectly flat on top of the bench (using washers as shims), and screwed it down. I'm still working on my tail section, but here are some random things I've learned so far which I'll type up while they are still fresh in my mind: - you can save gobs of money by buying tools used (vansairforce, local EAA chapters, ebay). The problem is that when you are first starting you don't know which cheap tools are a good deal, and which ones are cheap for a reason. You also don't know which tools are "needed", and which ones are more of a gimmick. (For example: what the heck is a "dimpling mallet"? Why is it any better than a $3 rubber mallet from the local hardware store?) On the other hand, some of my used tool buys are in the category of "I'd have never thought to buy this one new" and yet is "OMG completely invaluable" for certain operations. - the two most expensive tools which folks rave about are the pneumatic riveter, and the DTRT. Starting off, I'd save your money. [most controversial sentence in this post...] I have borrowed a friend's pnumatic, and it is amazingly fast. This will help you make mistakes faster. Also, it is quite heavy and bulky, which means you really have to plan out how you hold it and position it when getting into tight corners to avoid mis-squeezing a rivet. When you are first starting, slow and careful is the way to go, since mistakes take so long to fix. I have a normal c-frame, and I am frankly somewhat baffled about the supposed speed advantage of a DTRT. Dimpling with a c-frame and mallet is a fast and pretty simple operation. I've hardly spent any time on it compared to all the other work. Not what I'd optimize, IMHO. - As a beginner, I've found that: (a) squeezing a rivet produces a better result than backriveting which produces a better result than bucking it. (b) it is hard to mess up a squeezed rivet or a backrivet. It is trivial to mess up a bucked rivet. (c) squeezing a 3/32" rivet is easy. squeezing a 1/8" rivet is a feat of strength I am not strong enough to do. Well -- this is true with both the Avery squeezer I borrowed from a friend, and the old-school hand squeezer I bought used. I recently bought a Cleavland Main Squeeze, and this thing is a work of art -- it makes squeezing perfect 1/8" rivets absolutely trivial. I love this tool. (Sadly, it is expensive.) The pneumatic also makes it possible for me to squeeze a 1/8" rivet, but it is really finicky about positioning the ram to get it squeezed right, heavier, and harder to position in awkward places. I find that I end up with a better result using the main squeeze. (I could see how with practice I'd get better with the pneumatic and it would be faster -- but I have time to do things right...) - It is easier to mess up a bucked rivet with too much air pressure than with too little. Always start with too little and dial it up, not the reverse. - For your scotchbrite wheel you can mount it on a grinder or a buffer. I bought a cheap grinder, which works. My friends bought a cheap buffer, which has a longer shaft. I envy them, since they can get their wheel into more tight places. - Deburring the inside of lightening holes is a real pain. Until you get a $30 die grinder from Home Depot and a 1" scotchbrite wheel -- then it becomes easy (and incredibly noisy). - Buy a cheap belt/disc sander. I got a combo 1" belt/5" disc sander from Harbor Freight. It is _way_ better to cut outside a line and sand down than to try and cut a line. - Don't try to debur the edge of a skin just using a die grinder and scotchbrite wheel. You will waste too much time, and burn through grinder wheels like crazy. Easier is to: (a) use a regular file (not a vixen file!) to get rid of the cut marks and make the edge flat. (b) then quickly run the die grinder down the edge. - For smoothing/deburring the cut edge of thicker pieces: start off with a file (not a vixen file!). You will want some jeweler's files for getting inside corners. This will get rid of the cut marks. Then use sandpaper (I find that sanding sponges work well here). Then a quick buffing on the scotchbrite wheel will polish it nice and smooth. You will get much worse results if you go straight to the scotchbrite wheel (as I did the first time I tried this). - I haven't yet found a use for a vixen file. This tool appears to be made for taking off aluminum quickly from rough-cut pieces. Most of the RV-10 that I've encountered so far is pre-cut pieces. My belt/disc sander works better for me for getting edges down to a line. - If you leave the blue plastic on pieces it helps stop you from scratching the nice shiny alclad, and makes it prettier. I hear that if you leave this stuff on too long it becomes a real pain to take off -- but I have not yet had that problem, after 2 months. (Fingers crossed.) - I got a pair of chucking reamers for match drilling the pre-drilled holes (#30 and #40). As a result, I tend not to get burrs on holes. Well, I still go through the motions of deburring, but for the life of me I can't tell the difference in pre- and post-deburring of these holes. Perhaps I'm doing something wrong, or perhaps using this tool means I don't have to deburr. - You can never have enough light in your workshop. If in doubt, put up some more fluorescent strips. - Join a local EAA chapter and visit a few builders, to see what they are doing and get their advice. - Take a SportAir workshop if you can. Working on aluminum which is Not Your Plane lets you make your mistakes on stuff which doesn't matter. - The vertical stabilizer nose-ribs are too long, and you will want to sand 1/8" off their tips to avoid denting the skin. Do this _before_ you assemble it for the first time. (oops) Read Tim Olsen's site, which contains this critical tip and others. - When you go to put your vertical stabilizer skin on for the first test fit, get a friend to help you wrestle it. This is a challenging thing to do by yourself. - When putting that vertical stabilizer skin on, pull out the fiberglass tip fairings which are supposed to match it. You may have to coax the bend of the front of the skin to match the bend at the nose of the fairing -- and easier to do this while the skin is still not attached. (Yup, I never thought of this one...) - If the plans tell you not to dimple/match drill a hole, put tape over it to remind you. You will forget. Even if you circle it in bright red marker to remind yourself. - _Always_ clamp down a part before riveting it, either with the squeezer or the rivet gun. This will save you much grief. - Speaking of which, the Irwin bar clamps (or similar) are absolutely incredibly useful for clamping down random things to your bench while you work on them. A few cleco clamps are also really useful to have. - When inventorying your kit, check the formed parts for cracks. Never thought of checking for this, and a cracked piece later slowed me down while I waited for a replacement in the mail. (Double check part R-1004.) - If you buy a two-part primer, and a "calibrated paint mixing cup", double check that the calibration is accurate. My first batch of primer (and hence the entire inside of my vertical stabilizer) had twice as much reducer than it should have, since the calibrated scale was printed on the wrong part of the cup... - Speaking of which, if you want to hear a whole series of people with very strong (and divergent) opinions on a plane building topic, ask about what primer to use. Then step back, waay back. Also can be a good way of losing your new plane-building friends. You will spend way too long deciding what you want to do, and form your own opinion. By the time you spend a gazillion hours on your chosen technique, you too will either hate it, or feel strongly that your chosen method is the one true way ('cause why else would you have put all that work into it?). Chris On Sun, Apr 18, 2010 at 6:14 AM, Les Kearney wrote: > > Tony > > This link : ( http://www.eaa1000.av.org/technicl/worktabl/worktabl.htm ) > will take you the plans for the "official" EAA workbenches (if there is > such > a thing. I put mine on heavy duty wheels (lockable) so I could move it > around easily. They are very strong, dirt cheap to make and entirely > functional. I put MDF on the top of mine as it is soft and there are no > splinters to worry about. I made two and, on occasion, clamped them > together > to make a single large surface. > > If you alter the dimensions of the plans, you can make smaller (or full > size > if space permits) work benches to hold some of your power tools such as > band > saw, drill press and grinder. > > I found a table top belt sander / disk sander to be invaluable. I learned > from experience that when making long straight cuts on the band saw, it was > better to cut proud of the cut line and then use the sander to take the > material down to the cut line. > > This dimpler: > http://www.averytools.com/pc-619-84-drdt-2-hand-dimpling-tool.aspx is > absolute gold. It is much faster and easier to dimple using this tool. I > can't imagine building without it. > > When mounting my gear, I placed the whole fuselage (without the tail) on a > table. I used an engine crane to lift it. It was the perfect height to > allow > the gear legs to be installed safely. > > When you get you kit(s), keep the Styrofoam sheets, or a least some of it, > to put under large components during assembly. > > I also made, using 2X4's and MDF, a large dolly for the fuse once I moved > into the "boat" phase. It was 4' wide and about 6' long. It also was on > castoring wheels. > > I am a big fan of MDF as it is perfectly flat, cheap and doesn't splinter. > > Cheers > > Les > #40643 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > rwendell@hydro-splash.com > Sent: April-17-10 5:17 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Firewall access > > > I went with 4x8 > ------Original Message------ > From: Tony Woods > Sender: owner-rv10-list-server(at)matronics.com > To: rv10-list(at)matronics.com > ReplyTo: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Firewall access > Sent: Apr 17, 2010 3:00 AM > > > Hey all. > > This sounds like a stupid question, but I'm about to start work on my > empennage in a few weeks and am getting my workshop sorted out. > > I've got a good set of tools coming from PlaneTools, but am wondering about > setting up a work bench. How big? I'm going to build the bench from > scratch, so wondering how wide and long would be good, since I can make it > any dimension then I might as well make it right... > > Tony Woods > Not started anything yet!! > > > Sent from my Verizon Wireless BlackBerry > > ________________________________________________________________________________
Date: Apr 18, 2010
There is no gascolator on the -10. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294689#294689 ________________________________________________________________________________
Subject: Re: rivets at bottom, center of fuse/firewall interface
Date: Apr 18, 2010
John, I cannot think of any reason not to do those rivets now, if you are going to have to remove the engine and nose gear anyway. I wound up using Cherrymax rivets there because I was not willing to pull the engine for 8-10 rivets. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294691#294691 ________________________________________________________________________________
Subject: Re: It was warm yesterday, but that's ridiculous!
Date: Apr 18, 2010
-------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294698#294698 ________________________________________________________________________________
Subject: Fuel Lines
Date: Apr 18, 2010
I've done a complete replacement of brake lines with Bonaco. That's including the tunnel lines and everything. I plan on shooting a video of my routing and sharing my hose length findings for others considering a similar replacement. But it'll be another week or two before I get a chance. I would have shaved a few inches on the tunnel lines and 1 inch on the tunnel -> Landing gear line. The Teflon hoses will probably last longer than the airplane. Their inspection will still be inspected for condition annually. The plan is to do the same thing for the fuel lines. Once I get all the fuel system components placed, I'll measure for the fuel lines and get them ordered from Bonaco. I'm going to firesleeve the tunnel fuel lines while I'm at it. I am also swapping the aluminum 45 degree fitting that penetrates the firewall with a steel version. Once I get there I'll share the hose lengths, etc... Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Sunday, April 18, 2010 10:31 AM Subject: RE: RV10-List: Fuel Lines Mike Perhaps I am being a bit anal, but I don't like soft AL lines in the cockpit. While I am sure that the are serviceable, I don't don't think they will stay intact during an accident if the cockpit was in any way deformed. My thought is that a braided steel line might be a bit more forgiving. I have seen pix of a light a/c that was consumed by fire and it is a very sobering sight. Cheers Les ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: April-18-10 7:35 AM Subject: Re: RV10-List: Fuel Lines I would recommend using the soft aluminum lines. A lot cheaper and last longer. In fact, you could buy the flaring tools, all fittings, and the aluminum lines cheaper than the flexible lines... One suggestion would be to split the line from the fuel valve to the tanks into 2 lines and use a 90 degree bulkhead fitting as they pass thru the tunnel walls. Then you basically have 2 straight runs vs. 1 complex run. Just my opinion.... I can send Picts if you'd like to see how I did it. -Mike Sent from my iPhone On Apr 18, 2010, at 8:45 AM, "Les Kearney" wrote: Hi I am planning on installing Bonoco Inc steel braided fel lines in lieu of the soft aluminium lines spec'd by Vans. I am wondering if anyone else has done this and if so how the the fuselage passthrough to the wing was handled. It would seem that one otion is to use a bulkhead fitting at the fuselage which would make the connection to the wing vey simnple. Alternatively a single run of fuel line fom the fuel valve to the wing is also an option. Thoughts . comments anyone? Cheers Les #40643 - Systems / Wiring / Finishing href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 18, 2010
Subject: Re: Tools
On Sun, Apr 18, 2010 at 9:38 AM, Chris Colohan wrote: > - If you leave the blue plastic on pieces it helps stop you from scratching > the nice shiny alclad, and makes it prettier. I hear that if you leave this > stuff on too long it becomes a real pain to take off -- but I have not yet > had that problem, after 2 months. (Fingers crossed.) If you leave the vinyl on the edges, you won't get a fully smooth, deburred edge. Scotchbrite wheel gives nicer edges than 1" pad in die grinder. Each has its use, and the die grinder is necessary for some things you can't reach with Scotchbrite wheel. > - I got a pair of chucking reamers for match drilling the pre-drilled holes > (#30 and #40). As a result, I tend not to get burrs on holes. Well, I > still go through the motions of deburring, but for the life of me I can't > tell the difference in pre- and post-deburring of these holes. Perhaps I'm > doing something wrong, or perhaps using this tool means I don't have to > deburr. Get #41 reamer. You will get holes that are the right size after dimpling, rather than loose. > - You can never have enough light in your workshop. If in doubt, put up > some more fluorescent strips. > - Join a local EAA chapter and visit a few builders, to see what they are > doing and get their advice. Good advice. Kelly #40866 Tech Counselor ________________________________________________________________________________
Date: Apr 18, 2010
... while I see some sense in the comment below about the pneumatic rivet squeezer, the DRDT-2 Dimpler I found to be a huge improvement over the C-Frame and mallet approach. I used the C-Frame for the first half of the project, then borrowed a fellow builders DRDT-2 for the second half. It's much faster, less prone to mistakes and QUIETER. If I ever start another project, the first thing I will do is buy my own DRDT-2. Jeff Carpenter 40304 On Apr 18, 2010, at 9:38 AM, Chris Colohan wrote: > > > "- the two most expensive tools which folks rave about are the > pneumatic riveter, and the DTRT. Starting off, I'd save your > money. [most controversial sentence in this post...] I have > borrowed a friend's pnumatic, and it is amazingly fast. This will > help you make mistakes faster. Also, it is quite heavy and bulky, > which means you really have to plan out how you hold it and position > it when getting into tight corners to avoid mis-squeezing a rivet. > When you are first starting, slow and careful is the way to go, > since mistakes take so long to fix. I have a normal c-frame, and I > am frankly somewhat baffled about the supposed speed advantage of a > DTRT. Dimpling with a c-frame and mallet is a fast and pretty > simple operation. I've hardly spent any time on it compared to all > the other work. Not what I'd optimize, IMHO." > > > Cheers > > Les > #40643 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > rwendell@hydro-splash.com > Sent: April-17-10 5:17 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Firewall access > > > I went with 4x8 > ------Original Message------ > From: Tony Woods > Sender: owner-rv10-list-server(at)matronics.com > To: rv10-list(at)matronics.com > ReplyTo: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Firewall access > Sent: Apr 17, 2010 3:00 AM > > > Hey all. > > This sounds like a stupid question, but I'm about to start work on my > empennage in a few weeks and am getting my workshop sorted out. > > I've got a good set of tools coming from PlaneTools, but am > wondering about > setting up a work bench. How big? I'm going to build the bench from > scratch, so wondering how wide and long would be good, since I can > make it > any dimension then I might as well make it right... > > Tony Woods > Not started anything yet!! > > > Sent from my Verizon Wireless BlackBerry > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Apr 18, 2010
Not to mention a MUCH smaller chance of whackin your hand with the mallet. (a DRDT-2 convert) Ron ----- Original Message ----- From: Jeff Carpenter To: rv10-list(at)matronics.com Sent: Sunday, April 18, 2010 7:34 PM Subject: Re: RV10-List: Workbenches (and other stuff I know now...) ... while I see some sense in the comment below about the pneumatic rivet squeezer, the DRDT-2 Dimpler I found to be a huge improvement over the C-Frame and mallet approach. I used the C-Frame for the first half of the project, then borrowed a fellow builders DRDT-2 for the second half. It's much faster, less prone to mistakes and QUIETER. If I ever start another project, the first thing I will do is buy my own DRDT-2. Jeff Carpenter 40304 On Apr 18, 2010, at 9:38 AM, Chris Colohan wrote: "- the two most expensive tools which folks rave about are the pneumatic riveter, and the DTRT. Starting off, I'd save your money. [most controversial sentence in this post...] I have borrowed a friend's pnumatic, and it is amazingly fast. This will help you make mistakes faster. Also, it is quite heavy and bulky, which means you really have to plan out how you hold it and position it when getting into tight corners to avoid mis-squeezing a rivet. When you are first starting, slow and careful is the way to go, since mistakes take so long to fix. I have a normal c-frame, and I am frankly somewhat baffled about the supposed speed advantage of a DTRT. Dimpling with a c-frame and mallet is a fast and pretty simple operation. I've hardly spent any time on it compared to all the other work. Not what I'd optimize, IMHO." Cheers Les #40643 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rwendell@hydro-splash.com Sent: April-17-10 5:17 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Re: Firewall access I went with 4x8 ------Original Message------ From: Tony Woods Sender: owner-rv10-list-server(at)matronics.com To: rv10-list(at)matronics.com ReplyTo: rv10-list(at)matronics.com Subject: RE: RV10-List: Re: Firewall access Sent: Apr 17, 2010 3:00 AM Hey all. This sounds like a stupid question, but I'm about to start work on my empennage in a few weeks and am getting my workshop sorted out. I've got a good set of tools coming from PlaneTools, but am wondering about setting up a work bench. How big? I'm going to build the bench from scratch, so wondering how wide and long would be good, since I can make it any dimension then I might as well make it right... Tony Woods Not started anything yet!! Sent from my Verizon Wireless BlackBerry ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution ________________________________________________________________________________
Subject: Workbenches (and other stuff I know now...)
Date: Apr 19, 2010
Guys I am extremely grateful for your wise words and input. Chris your comments and guidance are very, very much appreciated. For a total newbie, it gives huge confidence to know that there is a whole bunch of other people out there who also started out thinking a bucking bar was somewhere they got thrown out of in Anchorage.... Tony Woods Sustainable Energy Services Afghanistan =D8=AE=D8=AF=D9=85=D8=A7=D8 =D8=A7=D9=86=D8=B1=DA=98=DB=8C =D8=A7=D9=81=D8=BA=D8=A7=D9=86=D8=B3=D8=D8=A7=D9=86 www.sesa.af twoods(at)sesa.af int tel +6421576555 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron Walker Sent: Monday, 19 April 2010 12:44 p.m. Subject: Re: RV10-List: Workbenches (and other stuff I know now...) Not to mention a MUCH smaller chance of whackin your hand with the mallet. (a DRDT-2 convert) Ron ----- Original Message ----- From: Jeff Carpenter <mailto:jeff(at)westcottpress.com> Sent: Sunday, April 18, 2010 7:34 PM Subject: Re: RV10-List: Workbenches (and other stuff I know now...) ... while I see some sense in the comment below about the pneumatic rivet squeezer, the DRDT-2 Dimpler I found to be a huge improvement over the C-Frame and mallet approach. I used the C-Frame for the first half of the project, then borrowed a fellow builders DRDT-2 for the second half. It's much faster, less prone to mistakes and QUIETER. If I ever start another project, the first thing I will do is buy my own DRDT-2. Jeff Carpenter 40304 On Apr 18, 2010, at 9:38 AM, Chris Colohan wrote: "- the two most expensive tools which folks rave about are the pneumatic riveter, and the DTRT. Starting off, I'd save your money. [most controversial sentence in this post...] I have borrowed a friend's pnumatic, and it is amazingly fast. This will help you make mistakes faster. Also, it is quite heavy and bulky, which means you really have to plan out how you hold it and position it when getting into tight corners to avoid mis-squeezing a rivet. When you are first starting, slow and careful is the way to go, since mistakes take so long to fix. I have a normal c-frame, and I am frankly somewhat baffled about the supposed speed advantage of a DTRT. Dimpling with a c-frame and mallet is a fast and pretty simple operation. I've hardly spent any time on it compared to all the other work. Not what I'd optimize, IMHO." Cheers Les #40643 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rwendell@hydro-splash.com Sent: April-17-10 5:17 AM Subject: Re: RV10-List: Re: Firewall access I went with 4x8 ------Original Message------ From: Tony Woods Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Subject: RE: RV10-List: Re: Firewall access Sent: Apr 17, 2010 3:00 AM Hey all. This sounds like a stupid question, but I'm about to start work on my empennage in a few weeks and am getting my workshop sorted out. I've got a good set of tools coming from PlaneTools, but am wondering about setting up a work bench. How big? I'm going to build the bench from scratch, so wondering how wide and long would be good, since I can make it any dimension then I might as well make it right... Tony Woods Not started anything yet!! Sent from my Verizon Wireless BlackBerry arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Apr 18, 2010
Go for it now. Also as I recall there were some prior posts about the cowling bracket being too weak (and breaking) so I fabricated a stronger one that I secure with a pop rivet - not the best solution. I would suggest a nut plate to secure the cowling bracket. Lots stronger - super secure - and easily removable. I see no reason not to button those holes up now. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294790#294790 ________________________________________________________________________________
Date: Apr 18, 2010
Hands down go for the Bonaco. I futzed with those darned aluminum lines for hours and then finally ordered the Bonaco. Nice folks - good service - reasonable price. On the pass thru (to the wing) just cut a bushing in half on the band saw and snap it in around the Bonaco line. After hours of frustration, I had my fuel lines installed in something like 45 minutes. I think that they have an OSH special if you are going there. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294791#294791 ________________________________________________________________________________
Date: Apr 19, 2010
I used a combination of the existing aluminum lines, Bonaco lines, and some braided lines I made myself. If I was doing it again, i would use nothing but Bonaco lines for the Brakes, and maybe a few homemade braided along with Bonaco for the fuel lines in the tunnel. As far as a pass through to the wings, try these: http://www.aircraftspruce.com/catalog/hapages/an832.php Here are a couple of shots of my tunnel. The all blue lines are Bonaco and the ones with red are mine. John -------- #40572 QB. Working on Cowling & Panel N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294808#294808 Attachments: http://forums.matronics.com//files/fueltray_581.jpg http://forums.matronics.com//files/fuellines_842.jpg ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 19, 2010
Subject: AHRS Reboots (was Heads up - AFS 4500 potential in flight
reboot issue) SnVzdCB3YW50ZWQgdG8gZm9sbG93IHRoaXMgdXAuICBJIGluc3RhbGxlZCB0aGUgdXBkYXRlIGFu ZCBubyBmdXJ0aGVyIHByb2JsZW1zIGhhdmUgYmVlbiBub3RlZC4NCg0KTWljaGFlbA0KDQpGcm9t OiBNaWNoYWVsIFNhdXNlbiBPbiBCZWhhbGYgT2YgUlYgQnVpbGRlciAoTWljaGFlbCBTYXVzZW4p DQpTZW50OiBUaHVyc2RheSwgQXByaWwgMTUsIDIwMTAgMTI6MzcgUE0NClRvOiBydjEwLWxpc3RA bWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogQUhSUyBSZWJvb3RzICh3YXMg SGVhZHMgdXAgLSBBRlMgNDUwMCBwb3RlbnRpYWwgaW4gZmxpZ2h0IHJlYm9vdCBpc3N1ZSkNCg0K ICBKdXN0IGEgbm90ZSBpbiByZXNwZWN0IHRvIEFGUywgUm9iIHNlbnQgbWUgYSBsaW5rIHRvIGZp cm13YXJlIHdpdGggdGhlIGZpeCBmb3IgdGhpcyBpc3N1ZS4gIEkgaGF2ZW7igJl0IHRlc3RlZCBp dCB5ZXQgYnV0IGF0IGxlYXN0IGl0IGRvZXMgZXhpc3QuDQoNCk1pY2hhZWwNCg0KRnJvbTogb3du ZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgVGltIE9sc29uDQpTZW50OiBXZWRu ZXNkYXksIEFwcmlsIDE0LCAyMDEwIDk6NTggUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNv bQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogQUhSUyBSZWJvb3RzICh3YXMgSGVhZHMgdXAgLSBB RlMgNDUwMCBwb3RlbnRpYWwgaW4gZmxpZ2h0IHJlYm9vdCBpc3N1ZSkNCg0KVHJ1ZSwgYWNjb3Jk aW5nIHRvIHRoZSBuZXcgcnVsZXMsIGFuIGVmaXMgZmFpbHVyZSBpcyBub3cgYW4gaXRlbSByZXF1 aXJpbmcgYSBmaWxlZCByZXBvcnQuLi4uanVzdCBsaWtlIHNvbWUgZW5naW5lL3Byb3Avc3lzdGVt cyBmYWlsdXJlcy4gIEkgdGhpbmsgaXQncyBnb29kIGluIHRoYXQgYmVmb3JlIHRoZXJlIHdhc24n dCBhIHJlYWwgZ29vZCB3YXkgdG8ga25vdyB0aGUgY291bnQgb2YgaXNzdWVzLCBhbiB3aXRoIHRo ZSBwcm9saWZlcmF0aW9uIG9mIFRBQSB0aGV5IG5vdyBhcmUgd2FudGluZyB0byBrbm93IGhvdyBy ZWxpYWJsZSBzeXN0ZW1zIGFyZSBpbiB0aGUgcmVhbCB3b3JsZC4gIFRvbyBtYW55IGNvbXBhbmll cyBxdW90ZSB0aGluZ3MgbGlrZSAiTVRCRiAxMCwwMDAgaHJzIiB3aGVuIHRoZXkgbWF5IG9ubHkg aGF2ZSBhIGZldyBzeXN0ZW1zIG91dCBpbiB0aGUgd29ybGQgd2l0aCByZWFsbHkgbG93IG51bWJl cnMgb2YgaG91cnMuDQpUaW0NCg0KDQpPbiBBcHIgMTQsIDIwMTAsIGF0IDEwOjIxIFBNLCBNaWNo YWVsIEtyYXVzIDxuMjIzcnZAd29sZmxha2VhaXJwb3J0Lm5ldDxtYWlsdG86bjIyM3J2QHdvbGZs YWtlYWlycG9ydC5uZXQ+PiB3cm90ZToNCklzbid0IHRoYXQgbm93IGEgcmVjb3JkYWJsZSBpbmNp ZGVudCB3aXRoIHRoZSBGQUE/Pw0KDQpTZW50IGZyb20gbXkgaVBob25lDQoNCk9uIEFwciAxNCwg MjAxMCwgYXQgOToxNCBQTSwgUGF0cmljayBUaHlzc2VuIDxqdW1wMkBzYmNnbG9iYWwubmV0PG1h aWx0bzpqdW1wMkBzYmNnbG9iYWwubmV0Pj4gd3JvdGU6DQpZb3Ugc2hvdWxkIGhhdmUgaXQgcmln aHQgYXQgcm90YXRpb24gYW5kIGJvdGggYmxhbmsgb3V0LCBUaGFua3MgT1ANClBhdHJpY2sgVGh5 c3Nlbg0KDQotLS0gT24gV2VkLCA0LzE0LzEwLCBNY0dhbm4sIFJvbiA8Um9uLk1jR2FubkBhdXNh d2QuY29tPG1haWx0bzpSb24uTWNHYW5uQGF1c2F3ZC5jb20+PiB3cm90ZToNCg0KRnJvbTogTWNH YW5uLCBSb24gPFJvbi5NY0dhbm5AYXVzYXdkLmNvbTxtYWlsdG86Um9uLk1jR2FubkBhdXNhd2Qu Y29tPj4NClN1YmplY3Q6IFJWMTAtTGlzdDogQUhSUyBSZWJvb3RzICh3YXMgSGVhZHMgdXAgLSBB RlMgNDUwMCBwb3RlbnRpYWwgaW4gZmxpZ2h0IHJlYm9vdCBpc3N1ZSkNClRvOiAicnYxMC1saXN0 QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPiIgPHJ2MTAtbGlz dEBtYXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4+DQpEYXRlOiBX ZWRuZXNkYXksIEFwcmlsIDE0LCAyMDEwLCA1OjEzIFBNDQpUaGVyZSBpcyBub3RoaW5nIG1vcmUg ZGlzY29uY2VydGluZyB0aGFuIGFuIGluZmxpZ2h0IHJlYm9vdCBvZiB5b3VyIEFIUlMuICAgSSBo YXZlIGEgMyBzY3JlZW4gR1JUIHN5c3RlbSB3aXRoIENvbTEgYW50ZW5uYSBvbiB0aGUgYmVsbHkg YW5kIENvbSAyIGJlaGluZCB0aGUgY2FiaW4gdG9wIGFmdCBmdXNlIGludGVyc2VjdGlvbi4gIE15 IEFIUlMgaXMgbG9jYXRlZCBvbiBhIHRyYXkgYWJvdmUgYW5kIGFmdCB0aGUgYmF0dGVyeSBib3gg KOKAmHN0YW5kYXJkIGxvY2F0aW9u4oCZKSwgYnV0IHdpdGhpbiB0d28gZmVldCBvZiB0aGUgY29t MiBhbnRlbm5hLiAgQ29tIDEgaXMgcHJpbWFyeSwgY29tIDIgaXMgYmFja3VwLiAgSSBoYWQgYSBt aW5vciBwcm9ibGVtIHdpdGggdGhlIHBheCBoZWFkc2V0IGphY2tzIHRoYXQgY2F1c2VkIGFuIGlu dGVybWl0dGVudCBvcGVuIG1pYyBwcm9ibGVtLiAgV2hlbiBJIGF0dGVtcHRlZCB0byBjb3JyZWN0 IHRoZSBwcm9ibGVtIGJ5IHNlbGVjdGluZyBjb20gMiwgdGhlIG9wZW4gbWljIHBlcnNpc3RlZCwg Y29tIDIgdHJhbnNtaXR0ZWQg4oCTIHRoZSBjb20gMiBhbnRlbm5hIGJlaW5nIHRvbyBjbG9zZSB0 byB0aGUgQUhSUyBjYXVzZWQgaXQgdG8gcmVib290LiAgSGF2aW5nIHlvdXIgUEZEL01GRCBzY3Jl ZW5zIGdvIGJsYW5rIGF0IDMwMDDigJkgYWludCBwcmV0dHkg4oCTIGJ1dCBhIGdyZWF0IG9wcG9y dHVuaXR5IHRvIHVzZSB0aG9zZSBiYWNrdXBzIChBU0ksIEFMVCkgdGhvdWdodCBhIGdvb2QgaWRl YSBkdXJpbmcgcGFuZWwgZGVzaWduLg0KDQpGaXhlZCB0aGUgb3BlbiBtaWMgcHJvYmxlbSBhbmQg Zm91bmQgYW5kIGZpeGVkIGEgZG9kZ3kgQk5DIGNvbm5lY3RvciBvbiB0aGUgY29tMiBhbnRlbm5h IChSRiBsZWFrKS4gIEJ1dCBvbmx5IHVzZSBjb20gMiBmb3IgcmVjZWl2ZSAodHggc3RpbGwgY2F1 c2VzIHRoZSBBSFJTIHRvIGRyaWZ0KSwgcGVuZGluZyByZWxvY2F0aW9uIG9mIHRoZSBBSFJTIGF3 YXkgZnJvbSB0aGUgYW50ZW5uYSBkdXJpbmcgdGhlIGFubnVhbCAodGhpcyB3ZWVrZW5kISEpDQoN Ckxlc3NvbnMgbGVhcm5lZDoNCg0KIDEuICBwdXQgdGhlIG1hZ25ldG9tZXRlciBpbiB0aGUgd2lu Z3RpcC4NCiAyLiAgZG9u4oCZdCBoYXZlIGFueSB0eCBhbnRlbm5hcyB3aXRoaW4gM+KAmSBvZiB0 aGUgQUhSUw0KIDMuICBkb27igJl0IHJvdXRlIGFueSBBSFJTIChvciBoaWdoIHNlbnNpdGl2aXR5 KSBlbGVjdHJpY2FsIHdpcmluZyBpbiB0aGUgc2FtZSBsb29tIGFzIGEgdHggY2FibGUgKGluY2x1 ZGluZyBSRzQwMCkNCg0KQ2hlZXJzDQpSb24NClZILVhSTSBmbHlpbmcgaW4gT3oNCl9fX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb208bWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4g W21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBP ZiBKaW0gQ29tYnMNClNlbnQ6IFdlZG5lc2RheSwgMTQgQXByaWwgMjAxMCA4OjQ1IFBNDQpUbzog cnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPg0K U3ViamVjdDogUlYxMC1MaXN0OiBIZWFkcyB1cCAtIEFGUyA0NTAwIHBvdGVudGlhbCBpbiBmbGln aHQgcmVib290IGlzc3VlDQoNCkp1c3QgYSBoZWFkcyB1cCBmb3IgQUZTIDQ1MDAgdXNlcnMuDQoN CldlIGhhdmUganVzdCByZWNlbnRseSBpbnN0YWxsZWQgYSA0NTAwIGluIGFkZGl0aW9uIHRvIHRo ZSAzNTAwIGFuZCBoYXZlIGRpc2NvdmVyZWQgYSBwb3RlbnRpYWwgaW4gZmxpZ2h0IHN1cnByaXNl LiAgV2hpbGUgZGlhbGluZyBpbiB0aGUgYWlycG9ydCBpZGVudGlmaWVyIGZvciBHZW9yZ2V0b3du IEt5ICgyN0spIHRoZSA0NTAwIHdpbGwgcmVib290IHdoaWxlIGVudGVyaW5nIHRoZSBhaXJwb3J0 IGlkZW50aWZpZXIgYXQgdGhlIE1BUCAvIERpcmVjdCB0byBtZW51IG9mIHRoZSA0NTAwLiAgSXQg cmVib290cyBvbiB0aGUgdGhpcmQgbGV0dGVyLiAgSSBhbSBub3Qgc3VyZSBpZiBhbnkgb3RoZXIg YWlycG9ydCBpZGVudGlmaWVycyBhcmUgdHJpZ2dlcnMgZm9yIHRoZSByZWJvb3QuDQoNCklmIHlv dSBlbnRlciB0aGUgYWlycG9ydCBpZGVudGlmaWVyIGF0IHRoZSA0MzBXIG9yIG9uIHRoZSAzNTAw IHRoZXJlIGFyZSBubyBpc3N1ZXMuICBTaW5jZSB3ZSBhcmUgdXNpbmcgdGhlIDQzMFcgZm9yIHRo ZSBhcHByb2FjaGVzIGFueXdheSwgdGhlcmUgaXMgYSB3b3JrIGFyb3VuZC4NCg0KSSB0YWxrZWQg dG8gQUZTIGFib3V0IHRoZSBwcm9ibGVtIGFuZCB0aGV5IHNhaWQgaXQgd2FzIGEga25vd24gcHJv YmxlbS4gIFRoZXkgY3VycmVudGx5IGRvbid0IGhhdmUgYSBwbGFubmVkIHNvZnR3YXJlIHJlbGVh c2UgdG8gZml4IGl0LiAgVGhpcyBwcm9ibGVtIGV4aXN0cyB1c2luZyB0aGUgbGF0ZXN0cyBmaXJt d2FyZSBhbmQgbWFwIGRhdGEgcmVsZWFzZS4NCg0KSSBmb3VuZCB0aGlzIHdoaWxlIG9uIHRoZSBn cm91bmQuICBJIHdhcyBnbGFkIEkgd2FzIG5vdCBhaXJib3JuZS4NCg0KVGhhbmtzLCBKaW0gQ29t YnMNCg0KTjMxMkYgLSBGbHlpbmcNCg0KDQoNCg0KDQoNCmh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCg0KDQoNCg0KDQoNCg0KIGhy ZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0Ij5odHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpocmVmPSJodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpocmVmPSJo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vY29udHJpYnV0aW9uDQoNCg0KDQoNCg0KDQoNCiBocmVmPSJodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9SVjEwLUxpc3QNCg0KaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tIj5o dHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0K DQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWls IEZvcnVtIC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9y IHRvIGJyb3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVu L1N1YnNjcmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJy b3dzZSwgQ2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0K DQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYx MC1MaXN0DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBX RUIgRk9SVU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEg dGhlIFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tDQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1 dGlvbiBXZWIgU2l0ZSAtDQoNCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBv cnQhDQoNCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlz dCBBZG1pbi4NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRp b24NCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Apr 19, 2010
Subject: Check Valve For Static System Cabin Venting...
Dear Listers, Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail. Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source? I'm assuming this will meet the requirement? Thanks! PS - Attached are a couple of pictures from Taxi-testing and Magnetometer calibration this weekend. Cool? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log Status: Final Bits/Inspection/Test Flight ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Apr 19, 2010
reboot issue) SSBoYXZlIGhlYXJkIG9mIG90aGVyIHJlYm9vdHMgb24gQUZTNDUwMHMgdGhhdCBhcmVu4oCZdCBq dXN0IGFpcnBvcnQgc2VsZWN0aW9ucy4gIEkgc3VzcGVjdCB0aGF0IHVudGlsIHdlIGhlYXIgZnJv bSB0aGUgZmxlZXQgb2YgdGhvc2UgYWN0dWFsbHkgZmx5aW5nIGJlaGluZCB0aGVtIHRoYXQgd2Ug d29u4oCZdCBrbm93IGZvciBzdXJlIHRoYXQgdGhlIGlzc3VlIGlzIHJlc29sdmVkIChtb3JlIHRo YW4gb25lIGlzc3VlPykuDQoNCkJvYg0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21d IE9uIEJlaGFsZiBPZiBSViBCdWlsZGVyIChNaWNoYWVsIFNhdXNlbikNClNlbnQ6IE1vbmRheSwg QXByaWwgMTksIDIwMTAgMToxOCBQTQ0KVG86ICdydjEwLWxpc3RAbWF0cm9uaWNzLmNvbScNClN1 YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IEFIUlMgUmVib290cyAod2FzIEhlYWRzIHVwIC0gQUZTIDQ1 MDAgcG90ZW50aWFsIGluIGZsaWdodCByZWJvb3QgaXNzdWUpDQoNCkp1c3Qgd2FudGVkIHRvIGZv bGxvdyB0aGlzIHVwLiAgSSBpbnN0YWxsZWQgdGhlIHVwZGF0ZSBhbmQgbm8gZnVydGhlciBwcm9i bGVtcyBoYXZlIGJlZW4gbm90ZWQuDQoNCk1pY2hhZWwNCg0KRnJvbTogTWljaGFlbCBTYXVzZW4g T24gQmVoYWxmIE9mIFJWIEJ1aWxkZXIgKE1pY2hhZWwgU2F1c2VuKQ0KU2VudDogVGh1cnNkYXks IEFwcmlsIDE1LCAyMDEwIDEyOjM3IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1 YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IEFIUlMgUmVib290cyAod2FzIEhlYWRzIHVwIC0gQUZTIDQ1 MDAgcG90ZW50aWFsIGluIGZsaWdodCByZWJvb3QgaXNzdWUpDQoNCiAgSnVzdCBhIG5vdGUgaW4g cmVzcGVjdCB0byBBRlMsIFJvYiBzZW50IG1lIGEgbGluayB0byBmaXJtd2FyZSB3aXRoIHRoZSBm aXggZm9yIHRoaXMgaXNzdWUuICBJIGhhdmVu4oCZdCB0ZXN0ZWQgaXQgeWV0IGJ1dCBhdCBsZWFz dCBpdCBkb2VzIGV4aXN0Lg0KDQpNaWNoYWVsDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNz LmNvbV0gT24gQmVoYWxmIE9mIFRpbSBPbHNvbg0KU2VudDogV2VkbmVzZGF5LCBBcHJpbCAxNCwg MjAxMCA5OjU4IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBS VjEwLUxpc3Q6IEFIUlMgUmVib290cyAod2FzIEhlYWRzIHVwIC0gQUZTIDQ1MDAgcG90ZW50aWFs IGluIGZsaWdodCByZWJvb3QgaXNzdWUpDQoNClRydWUsIGFjY29yZGluZyB0byB0aGUgbmV3IHJ1 bGVzLCBhbiBlZmlzIGZhaWx1cmUgaXMgbm93IGFuIGl0ZW0gcmVxdWlyaW5nIGEgZmlsZWQgcmVw b3J0Li4uLmp1c3QgbGlrZSBzb21lIGVuZ2luZS9wcm9wL3N5c3RlbXMgZmFpbHVyZXMuICBJIHRo aW5rIGl0J3MgZ29vZCBpbiB0aGF0IGJlZm9yZSB0aGVyZSB3YXNuJ3QgYSByZWFsIGdvb2Qgd2F5 IHRvIGtub3cgdGhlIGNvdW50IG9mIGlzc3VlcywgYW4gd2l0aCB0aGUgcHJvbGlmZXJhdGlvbiBv ZiBUQUEgdGhleSBub3cgYXJlIHdhbnRpbmcgdG8ga25vdyBob3cgcmVsaWFibGUgc3lzdGVtcyBh cmUgaW4gdGhlIHJlYWwgd29ybGQuICBUb28gbWFueSBjb21wYW5pZXMgcXVvdGUgdGhpbmdzIGxp a2UgIk1UQkYgMTAsMDAwIGhycyIgd2hlbiB0aGV5IG1heSBvbmx5IGhhdmUgYSBmZXcgc3lzdGVt cyBvdXQgaW4gdGhlIHdvcmxkIHdpdGggcmVhbGx5IGxvdyBudW1iZXJzIG9mIGhvdXJzLg0KVGlt DQoNCg0KT24gQXByIDE0LCAyMDEwLCBhdCAxMDoyMSBQTSwgTWljaGFlbCBLcmF1cyA8bjIyM3J2 QHdvbGZsYWtlYWlycG9ydC5uZXQ8bWFpbHRvOm4yMjNydkB3b2xmbGFrZWFpcnBvcnQubmV0Pj4g d3JvdGU6DQpJc24ndCB0aGF0IG5vdyBhIHJlY29yZGFibGUgaW5jaWRlbnQgd2l0aCB0aGUgRkFB Pz8NCg0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpPbiBBcHIgMTQsIDIwMTAsIGF0IDk6MTQgUE0s IFBhdHJpY2sgVGh5c3NlbiA8anVtcDJAc2JjZ2xvYmFsLm5ldDxtYWlsdG86anVtcDJAc2JjZ2xv YmFsLm5ldD4+IHdyb3RlOg0KWW91IHNob3VsZCBoYXZlIGl0IHJpZ2h0IGF0IHJvdGF0aW9uIGFu ZCBib3RoIGJsYW5rIG91dCwgVGhhbmtzIE9QDQpQYXRyaWNrIFRoeXNzZW4NCg0KLS0tIE9uIFdl ZCwgNC8xNC8xMCwgTWNHYW5uLCBSb24gPFJvbi5NY0dhbm5AYXVzYXdkLmNvbTxtYWlsdG86Um9u Lk1jR2FubkBhdXNhd2QuY29tPj4gd3JvdGU6DQoNCkZyb206IE1jR2FubiwgUm9uIDxSb24uTWNH YW5uQGF1c2F3ZC5jb208bWFpbHRvOlJvbi5NY0dhbm5AYXVzYXdkLmNvbT4+DQpTdWJqZWN0OiBS VjEwLUxpc3Q6IEFIUlMgUmVib290cyAod2FzIEhlYWRzIHVwIC0gQUZTIDQ1MDAgcG90ZW50aWFs IGluIGZsaWdodCByZWJvb3QgaXNzdWUpDQpUbzogInJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPG1h aWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxt YWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+Pg0KRGF0ZTogV2VkbmVzZGF5LCBBcHJpbCAx NCwgMjAxMCwgNToxMyBQTQ0KVGhlcmUgaXMgbm90aGluZyBtb3JlIGRpc2NvbmNlcnRpbmcgdGhh biBhbiBpbmZsaWdodCByZWJvb3Qgb2YgeW91ciBBSFJTLiAgIEkgaGF2ZSBhIDMgc2NyZWVuIEdS VCBzeXN0ZW0gd2l0aCBDb20xIGFudGVubmEgb24gdGhlIGJlbGx5IGFuZCBDb20gMiBiZWhpbmQg dGhlIGNhYmluIHRvcCBhZnQgZnVzZSBpbnRlcnNlY3Rpb24uICBNeSBBSFJTIGlzIGxvY2F0ZWQg b24gYSB0cmF5IGFib3ZlIGFuZCBhZnQgdGhlIGJhdHRlcnkgYm94ICjigJhzdGFuZGFyZCBsb2Nh dGlvbuKAmSksIGJ1dCB3aXRoaW4gdHdvIGZlZXQgb2YgdGhlIGNvbTIgYW50ZW5uYS4gIENvbSAx IGlzIHByaW1hcnksIGNvbSAyIGlzIGJhY2t1cC4gIEkgaGFkIGEgbWlub3IgcHJvYmxlbSB3aXRo IHRoZSBwYXggaGVhZHNldCBqYWNrcyB0aGF0IGNhdXNlZCBhbiBpbnRlcm1pdHRlbnQgb3BlbiBt aWMgcHJvYmxlbS4gIFdoZW4gSSBhdHRlbXB0ZWQgdG8gY29ycmVjdCB0aGUgcHJvYmxlbSBieSBz ZWxlY3RpbmcgY29tIDIsIHRoZSBvcGVuIG1pYyBwZXJzaXN0ZWQsIGNvbSAyIHRyYW5zbWl0dGVk IOKAkyB0aGUgY29tIDIgYW50ZW5uYSBiZWluZyB0b28gY2xvc2UgdG8gdGhlIEFIUlMgY2F1c2Vk IGl0IHRvIHJlYm9vdC4gIEhhdmluZyB5b3VyIFBGRC9NRkQgc2NyZWVucyBnbyBibGFuayBhdCAz MDAw4oCZIGFpbnQgcHJldHR5IOKAkyBidXQgYSBncmVhdCBvcHBvcnR1bml0eSB0byB1c2UgdGhv c2UgYmFja3VwcyAoQVNJLCBBTFQpIHRob3VnaHQgYSBnb29kIGlkZWEgZHVyaW5nIHBhbmVsIGRl c2lnbi4NCg0KRml4ZWQgdGhlIG9wZW4gbWljIHByb2JsZW0gYW5kIGZvdW5kIGFuZCBmaXhlZCBh IGRvZGd5IEJOQyBjb25uZWN0b3Igb24gdGhlIGNvbTIgYW50ZW5uYSAoUkYgbGVhaykuICBCdXQg b25seSB1c2UgY29tIDIgZm9yIHJlY2VpdmUgKHR4IHN0aWxsIGNhdXNlcyB0aGUgQUhSUyB0byBk cmlmdCksIHBlbmRpbmcgcmVsb2NhdGlvbiBvZiB0aGUgQUhSUyBhd2F5IGZyb20gdGhlIGFudGVu bmEgZHVyaW5nIHRoZSBhbm51YWwgKHRoaXMgd2Vla2VuZCEhKQ0KDQpMZXNzb25zIGxlYXJuZWQ6 DQoNCiAxLiAgcHV0IHRoZSBtYWduZXRvbWV0ZXIgaW4gdGhlIHdpbmd0aXAuDQogMi4gIGRvbuKA mXQgaGF2ZSBhbnkgdHggYW50ZW5uYXMgd2l0aGluIDPigJkgb2YgdGhlIEFIUlMNCiAzLiAgZG9u 4oCZdCByb3V0ZSBhbnkgQUhSUyAob3IgaGlnaCBzZW5zaXRpdml0eSkgZWxlY3RyaWNhbCB3aXJp bmcgaW4gdGhlIHNhbWUgbG9vbSBhcyBhIHR4IGNhYmxlIChpbmNsdWRpbmcgUkc0MDApDQoNCkNo ZWVycw0KUm9uDQpWSC1YUk0gZmx5aW5nIGluIE96DQpfX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fXw0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0 bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IFttYWlsdG86b3duZXItcnYx MC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgSmltIENvbWJzDQpTZW50 OiBXZWRuZXNkYXksIDE0IEFwcmlsIDIwMTAgODo0NSBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25p Y3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClN1YmplY3Q6IFJWMTAtTGlz dDogSGVhZHMgdXAgLSBBRlMgNDUwMCBwb3RlbnRpYWwgaW4gZmxpZ2h0IHJlYm9vdCBpc3N1ZQ0K DQpKdXN0IGEgaGVhZHMgdXAgZm9yIEFGUyA0NTAwIHVzZXJzLg0KDQpXZSBoYXZlIGp1c3QgcmVj ZW50bHkgaW5zdGFsbGVkIGEgNDUwMCBpbiBhZGRpdGlvbiB0byB0aGUgMzUwMCBhbmQgaGF2ZSBk aXNjb3ZlcmVkIGEgcG90ZW50aWFsIGluIGZsaWdodCBzdXJwcmlzZS4gIFdoaWxlIGRpYWxpbmcg aW4gdGhlIGFpcnBvcnQgaWRlbnRpZmllciBmb3IgR2VvcmdldG93biBLeSAoMjdLKSB0aGUgNDUw MCB3aWxsIHJlYm9vdCB3aGlsZSBlbnRlcmluZyB0aGUgYWlycG9ydCBpZGVudGlmaWVyIGF0IHRo ZSBNQVAgLyBEaXJlY3QgdG8gbWVudSBvZiB0aGUgNDUwMC4gIEl0IHJlYm9vdHMgb24gdGhlIHRo aXJkIGxldHRlci4gIEkgYW0gbm90IHN1cmUgaWYgYW55IG90aGVyIGFpcnBvcnQgaWRlbnRpZmll cnMgYXJlIHRyaWdnZXJzIGZvciB0aGUgcmVib290Lg0KDQpJZiB5b3UgZW50ZXIgdGhlIGFpcnBv cnQgaWRlbnRpZmllciBhdCB0aGUgNDMwVyBvciBvbiB0aGUgMzUwMCB0aGVyZSBhcmUgbm8gaXNz dWVzLiAgU2luY2Ugd2UgYXJlIHVzaW5nIHRoZSA0MzBXIGZvciB0aGUgYXBwcm9hY2hlcyBhbnl3 YXksIHRoZXJlIGlzIGEgd29yayBhcm91bmQuDQoNCkkgdGFsa2VkIHRvIEFGUyBhYm91dCB0aGUg cHJvYmxlbSBhbmQgdGhleSBzYWlkIGl0IHdhcyBhIGtub3duIHByb2JsZW0uICBUaGV5IGN1cnJl bnRseSBkb24ndCBoYXZlIGEgcGxhbm5lZCBzb2Z0d2FyZSByZWxlYXNlIHRvIGZpeCBpdC4gIFRo aXMgcHJvYmxlbSBleGlzdHMgdXNpbmcgdGhlIGxhdGVzdHMgZmlybXdhcmUgYW5kIG1hcCBkYXRh IHJlbGVhc2UuDQoNCkkgZm91bmQgdGhpcyB3aGlsZSBvbiB0aGUgZ3JvdW5kLiAgSSB3YXMgZ2xh ZCBJIHdhcyBub3QgYWlyYm9ybmUuDQoNClRoYW5rcywgSmltIENvbWJzDQoNCk4zMTJGIC0gRmx5 aW5nDQoNCg0KDQoNCg0KDQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAt TGlzdA0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0KDQoNCg0KDQoNCiBocmVmPSJodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdCI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KaHJlZj0iaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t Ij5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KaHJlZj0iaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL2NvbnRyaWJ1dGlvbiI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KDQoNCg0KDQoNCg0KDQogaHJlZj0iaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRv cj9SVjEwLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0 DQoNCmhyZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQoNCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24i Pmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBV c2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09 IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoN Cl8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwN Cg0KXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8t PSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0K DQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0K DQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAg IC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K fu+/vd6ZyqU00400feKAkXLqp7soOF5FXXQuKy0SZlorZSx62J4xa3hX6p6w1q8GaG4w66G6Zsi4 66KWK2J6y65yListUn/SuRwqbS3IouSeqiENCifstrIGMOChqtGAQGghatmucnLmoa3nobbavw0K MGt4yqbWrwZV14Lisphtw4wmatqoJyxyNeKBq2gVddC477+977+9TjRYQEU5FQ0KSSZ6IN6q16jX p2zailbroqrYnlnmhaJreW1+7pqJJ8ucaG1+7pqJJ8ucb9quKy0g77+97raqJ1nmkorXk+SKi+KA keqousuuK8atOtqWV8uAdmhq3r5t77+M77+9J8ucb9yie2vhtpp/DQowa3jKpsqn2Kjvv73vv73o np/pra/body/2aUNCg= ________________________________________________________________________________
Date: Apr 19, 2010
Just got back from SNF and wading through emails. The soft aluminum lines will bend and stretch during a really bad accident before rupturing .... you won't bend or stretch as much. Flexible hoses won't stretch .... and offer a better opportunity for pulling something loose. Both typres have their advantages ..... flexible lines are great for compound routes where many bends are needed, soft aluminum is lighter, less expensive, easily bent/worked, and as long as it doesn't get repetitive bending forces lasts a long time. Just my 2 pennies. Linn Les Kearney wrote: > Mike > > Perhaps I am being a bit anal, but I don't like soft AL lines in the > cockpit. While I am sure that the are serviceable, I don't don't think > they will stay intact during an accident if the cockpit was in any way > deformed. My thought is that a braided steel line might be a bit more > forgiving. > > I have seen pix of a light a/c that was consumed by fire and it is a > very sobering sight. > > Cheers > > Les > > ------------------------------------------------------------------------ > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Michael Kraus > *Sent:* April-18-10 7:35 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Fuel Lines > > I would recommend using the soft aluminum lines. A lot cheaper and > last longer. In fact, you could buy the flaring tools, all fittings, > and the aluminum lines cheaper than the flexible lines... > > One suggestion would be to split the line from the fuel valve to the > tanks into 2 lines and use a 90 degree bulkhead fitting as they pass > thru the tunnel walls. Then you basically have 2 straight runs vs. 1 > complex run. Just my opinion.... I can send Picts if you'd like to > see how I did it. > > -Mike > > > Sent from my iPhone > > On Apr 18, 2010, at 8:45 AM, "Les Kearney" > wrote: > >> >> Hi >> >> I am planning on installing Bonoco Inc steel braided fel lines in >> lieu of the soft aluminium lines spec'd by Vans. I am wondering if >> anyone else has done this and if so how the the fuselage passthrough >> to the wing was handled. It would seem that one otion is to use a >> bulkhead fitting at the fuselage which would make the connection to >> the wing vey simnple. Alternatively a single run of fuel line fom the >> fuel valve to the wing is also an option. >> >> Thoughts . comments anyone? >> >> Cheers >> >> Les >> #40643 - Systems / Wiring / Finishing >> * >> >> >> * > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * ________________________________________________________________________________
Date: Apr 19, 2010
Subject: Instrumentation Checkout - HDTV Video
Dear Listers, Last week I ran the IO-390 on the RV-8 for about 12 minutes and went though and checked all of the various systems and sensors. I talked though the each of the things as I was checking them in an HD video I edited of the session. Thought some might find it interesting... http://www.youtube.com/MattsRV8?v=-byMWhyTwjA . Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log Status: Final Bits/Inspection/Test Flight ________________________________________________________________________________
Date: Apr 19, 2010
Subject: Cleveland Static Ports and 1/4 ID to 1/4 OD
For those that have the Cleaveland static ports, what have you done to transfer from the 1/4 ID tubing that the ports need to the 1/4 OD tubing that most everything else uses? The Cleaveland installation instructions mention to just slide the 1/4 OD into the 1/4 ID, but that doesn't sound like it would be optimal for a leak free transition. thanks, Sean #40303 ________________________________________________________________________________
Date: Apr 19, 2010
Subject: Re: Check Valve For Static System Cabin Venting...
At 03:53 PM 4/19/2010 Monday, you wrote: >--> RV-List message posted by: Linn Walters > >Matt, cut the tubing, insert a 'T' with a short stub of tubing. Put a plug in the tube of a type that you can pull out easily if needed. >Simple, light, and inexpensive. >Linn >Matt Dralle wrote: >>Dear Listers, >> >>Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail. >> >>Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source? >> >>I'm assuming this will meet the requirement? >> >>Thanks! What a great idea, Linn! Thanks. Here's what I did tonight including a couple of pictures... I added a small "T" Nylon fitting in the 1/4" tube for static air just in front of the instrument panel under the left cockpit rail. I cut a short piece of 1/4" tubing and filled it with black RTV and then put a piece of heat shrink tubing over it to form a handle. The whole thing fits nicely under the cockpit rail and from the pilot's position is just barely visible, yet can be accessed easy. In the event that icing conditions occur, the fitting can be unscrewed and the plug removed for cabin venting. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits/Inspection/Test Flight ________________________________________________________________________________
Date: Apr 19, 2010
Not sure where you are finding this "requirement". #1. There is no IFR certification of OBAM aircraft. #2.You only have to meet the requirements of 91.205, para a, b, c and d. There is no mention of alternate static source in that FAR. You can't fly IFR until you complete Phase I and your operating limitations will state after Phase I that for night VFR you have to meet 91.205 C and for IFR meet 91.205 D. It is up to you, the builder to decide if you need anything else. If your static system is at all like the RV-10, with a port on each side of the tailcone, and you incorporated an uphill section to the top of the tailcone to join the lines from each port, there really is no need for an alternate static source. Mooney used the same design and through the 1960s had no alternate source and no drain. Only after Part 23 was issued did they start incorporating those features. IMHO, just adds complexity and potential for leaks. Perhaps I would think differently if you were based outdoors in Oregon or NJ, but hangared in most parts of the country, you will almost never get any water into the system. Kelly #40866 On Mon, Apr 19, 2010 at 1:50 PM, Matt Dralle wrote: > > Dear Listers, > > Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail. > > Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source? > > I'm assuming this will meet the requirement? > > Thanks! > > PS - Attached are a couple of pictures from Taxi-testing and Magnetometer calibration this weekend. Cool? > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > Status: Final Bits/Inspection/Test Flight > ________________________________________________________________________________
Date: Apr 19, 2010
Matt, Really enjoy your videos. Nice work. Here's an interesting idea for an alternate source: http://www.rv7blog.com/2008/11/09/alternate-static-air-valve. Safeair has an alternate source kit, but it seems it would be pretty easy to do yourself: http://www.safeair1.com/PS_1.htm near bottom of page. -Sean #40303 On 4/19/10 3:50 PM, Matt Dralle wrote: > Dear Listers, > > Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail. > > Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source? > > I'm assuming this will meet the requirement? > > Thanks! > > PS - Attached are a couple of pictures from Taxi-testing and Magnetometer calibration this weekend. Cool? > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > Status: Final Bits/Inspection/Test Flight > ________________________________________________________________________________
Date: Apr 20, 2010
Hello Matt, simple, still unscrewing in icing condition would not be my thing. In 2007 I've posted that once: hopefully attached, what I did (on a Glastar) a Curtis Drain Valve CCA-1550 together with a T and two elbows to fit the static line. And I did an inflight check, error is 4 KIAS to high indication. br Werner ________________________________________________________________________________
Date: Apr 20, 2010
Try one of these miniature air control valves from McMaster-Carr, Clippard, or AMR. John -------- #40572 QB. Working on Cowling & Panel N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=294940#294940 Attachments: http://forums.matronics.com//files/8399kp2s_995.gif http://forums.matronics.com//files/8399kp1s_102.gif http://forums.matronics.com//files/tv_2s_158.jpg ________________________________________________________________________________
Date: Apr 20, 2010
I used 1/4" ID Tygon between the static ports up to a 1/4" tee fitting secured to the mid-point on the bulkhead. From the tee fitting there's 1/4" ID Tygon coming out and transitions to 1/4" OD standard static line along the longeron. The 1/4" OD line is very snug inside the Tygon and I've also got a small hose clamp at the transition point to insure sealing. No issues with leaks in 2 years. Bob RV-10 N442PM -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Monday, April 19, 2010 9:31 PM Subject: RV10-List: Cleveland Static Ports and 1/4 ID to 1/4 OD For those that have the Cleaveland static ports, what have you done to transfer from the 1/4 ID tubing that the ports need to the 1/4 OD tubing that most everything else uses? The Cleaveland installation instructions mention to just slide the 1/4 OD into the 1/4 ID, but that doesn't sound like it would be optimal for a leak free transition. thanks, Sean #40303 ________________________________________________________________________________
Subject: do I need a transponder?
Date: Apr 20, 2010
I am currently planning my IFR panel for my RV10. Does anyone know what the future requirements for ADSB transceivers will be and does it negate the need for a mode C transponder. If that's the case what is the timeframe for not needing a mode C and needing the UAT for the ADSB? Chris Hukill ________________________________________________________________________________
Date: Apr 20, 2010
Subject: Re: Workbenches (and other stuff I know now...)
Chris Colohan wrote: > When building that bench, make sure you use 2x4's that are _absolutely_ > straight, and even better if they have also seasoned a few years (aka, > perfectly dry). > > I bought the "premium" 2x4's at my local Home Depot, and found that > after I assembled my bench (with a 3/4" plywood top) there was a 1/8" to > 3/16" warp in the work surface. Not good. So I got some MDF, set it up > perfectly flat on top of the bench (using washers as shims), and screwed > it down. If you have a tablesaw, a better option is a torsion box top. I make mine out of a 1/2" MDF core, 1/4" MDF bottom and either 1/2 or 3/4" MDF top. By their nature, they pretty much have to come out dead flat. In case you don't know what it is there's an example here: http://thewoodwhisperer.com/episode-18-assembly-table-torsion-box/ Alternately, you can rip some 3/4" plywood into 3 1/2" strips and glue them together to make your own "2x4"s. --Rick ________________________________________________________________________________
Date: Apr 20, 2010
Yes, transponder and encoder have to meet TSO standards. Encoder may not be too difficult through FAR 43 Appendix E, but transponder pretty much will have to have TSO. GPS for IFR has to meet TSO requirements. Altimeter has to meet same requirements as encoder. Most other instruments like airspeed and gyros are at your discretion as the builder. As long as you can fly the assigned clearance accurately with the instruments you install, I believe you are okay. On Tue, Apr 20, 2010 at 10:22 AM, Linn Walters wrote: > > Kelly McMullen wrote: >> >> I appreciate the data point. I think we all know that FAA inspectors are >> not very familiar with OBAM requirements. Has been discussed many times that >> there is no IFR certification of OBAM aircraft. > > I've been researching IFR use of non-TSOd equipment and am just as confused > as when I started out. I believe that even if you are OBAM, you are still > subject to a transponder/altimeter certification every two years. ________________________________________________________________________________
Subject: Re: do I need a transponder?
Date: Apr 20, 2010
Yes, you need it.. No plans to get rid of transponders any time soon.. even when you get your ADS-B equipment, the transponder will be required as a backup... Of course, eventually that will change, but I don't see it being done any time soon (like no sooner than 15-20 years). -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295040#295040 ________________________________________________________________________________
Date: Apr 20, 2010
Subject: TSO'd Instrumentation For IFR?
Dear Listers, I'm working with the local FSDO this week and had my airframe inspection on Monday will get my sign-off this Friday if all goes well. Looking over the requirements for IFR, it appears that I've got everything I need as far as equipment is concerned. I have a Garmin SL-30 for Com/Nav and a Garmin GTX-327 for Mode C transponder. All of the other equipment and functionality is provided by the GRT Horizon HX sytems including the encoder, attitude, airspeed, altitude, compass, etc, etc. I do not have any steam gauges or other flight instruments other than what is provided by GRT through an HX installation. My question is can my RV-8 be approved for IFR flight with this compliment of GRT HX specific instrumentation? Or, would I need to have a TSO'd encoder and/or other TSO'd pieces such as rate-of-turn, slip, sensitive altimeter, artificial horizon, direction gyro, etc? Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits/Inspection/Test Flight ________________________________________________________________________________
Subject: Re: TSO'd Instrumentation For IFR?
Date: Apr 20, 2010
You do NOT need to worry about this for your airframe inspection. You will only get approved for Day VFR and only need to meet Day VFR requirements. There is NO such thing as IFR certification of an OBAM aircraft. You will get operating limitations restricting you to day VFR for Phase one, and then state for night VFR and IFR you have to comply with the requirements of 91.205. You won't find any TSO requirements there. The only requirements for TSO are found in other parts, such as the transponder, which for all practical purposes must be TSO. Your Altimeter and encoder will need to meet the TSO requirements, but you can have a competent avionics shop certify your altimeter, encoder and static system, as well as the required transponder check all in one operation. TSO equimpent, with the exceptions above is only required for Part 135 and similar for hire parts. [quote="Matt Dralle"]Dear Listers, I'm working with the local FSDO this week and had my airframe inspection on Monday will get my sign-off this Friday if all goes well. My question is can my RV-8 be approved for IFR flight with this compliment of GRT HX specific instrumentation? Or, would I need to have a TSO'd encoder and/or other TSO'd pieces such as rate-of-turn, slip, sensitive altimeter, artificial horizon, direction gyro, etc? Matt Dralle RV-8 #82880 N998RV -------- Kelly McMullen A&P/IA, EAA Tech Counselor # 5286 KCHD Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295050#295050 ________________________________________________________________________________
Date: Apr 20, 2010
Matt, Yes, I think you're okay; but with the irony that you won't be able to get home to KLVK in ifr. There are only 2 approaches into KLVK; a GPS approach, which requires an ifr TSO certified gps; and an ILS, which in Livermore's case, also requires an ADF (or you can sub an ifr approved gps). PS What hangar are you in? I'm in 311. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295052#295052 ________________________________________________________________________________
Date: Apr 20, 2010
Matt, Also, it wasn't clear to me: if the GRT goes belly up, do you have any backup instruments? Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295053#295053 ________________________________________________________________________________
Date: Apr 20, 2010
Yes, I've got dual AHRSs, Magnetometers, GPSs, and triple HX displays. I also have a completely redundant and independent power source for the primary HX Display/ARHS/Magnetometer/GPS/SL-30 in case the Vertical Power VP-200 dies. Matt At 08:11 PM 4/20/2010 Tuesday, you wrote: > >Matt, > >Also, it wasn't clear to me: if the GRT goes belly up, do you have any backup instruments? > >Bob > >-------- >Bob Turner >RV-10 QB Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 21, 2010
Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Date: Apr 21, 2010
Matt Dralle wrote: > Yes, I've got dual AHRSs, Magnetometers, GPSs, and triple HX displays. I also have a completely redundant and independent power source for the primary HX Display/ARHS/Magnetometer/GPS/SL-30 in case the Vertical Power VP-200 dies. > > Matt The question asked above is what is your approved GPS? The only ones I know that are regularly installed in experimentals are the 430, 530 and 480. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295070#295070 ________________________________________________________________________________
Date: Apr 21, 2010
Get Clippard switch here: http://clippard.com/store/display_details.asp?sku=TV-2SP Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295093#295093 ________________________________________________________________________________
Date: Apr 21, 2010
You don't need an approved GPS to fly ifr, if you only go where a VOR and/or ILS will take you. However, Matt's home airport (KLVK) represents a problem, as there is no approach you can legally shoot without an approved gps (or, ADF). Matt, one comment: be cautious after grt software updates, as that represents a single point failure of all your attitude info. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295125#295125 ________________________________________________________________________________
Date: Apr 21, 2010
What do people think of this idea: I was thinking of permanently leaving my backup (Dynon D-6 most likely) instruments on alternate (cabin) static pressure, and have no "alternate static" valve on the main instruments (most likely GRT). Yes, they would always slightly disagree with the main instruments. But a static blockage would also be immediately obvious. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295126#295126 ________________________________________________________________________________
Date: Apr 21, 2010
This would work .... but why have instrumentation that 'disagrees'. It's like a dead watch .... accurate time twice a day. How come you're worried about your static ports becoming blocked, but haven't addressed a blocked pitot??? Both are subject to ice/water intrusion ..... but proper plumbing inside the fuse/wing keep that problem down to a minimum. I'd put a simple mod to the static line like Matt did. Linn Bob Turner wrote: > > What do people think of this idea: > I was thinking of permanently leaving my backup (Dynon D-6 most likely) instruments on alternate (cabin) static pressure, and have no "alternate static" valve on the main instruments (most likely GRT). > Yes, they would always slightly disagree with the main instruments. But a static blockage would also be immediately obvious. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295126#295126 > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 21, 2010
I have yet to hear of a mechanism for both static ports to get blocked at the same time. Even with driving rain followed by freezing, only one side would get blocked, Perhaps if you got mud daubers in both sides. Blockage should be obvious before or shortly after lift off, with airspeed being way off. If it makes you feel better, your plan certainly is a way to always have alternate source of info, but might drive you crazy with differences in airspeed and altitude. On Wed, Apr 21, 2010 at 11:34 AM, Bob Turner wrote: > > What do people think of this idea: > I was thinking of permanently leaving my backup (Dynon D-6 most likely) instruments on alternate (cabin) static pressure, and have no "alternate static" valve on the main instruments (most likely GRT). > Yes, they would always slightly disagree with the main instruments. But a static blockage would also be immediately obvious. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295126#295126 > > ________________________________________________________________________________
Subject: tailcone thickness
Date: Apr 21, 2010
on the bottom; I seem to recall the thickness to be .040. Anybody know; if not I can measure tomorrow. ________________________________________________________________________________
Subject: Re: tailcone thickness
Date: Apr 21, 2010
my trusty micrometer says .03 On Apr 21, 2010, at 5:14 PM, DLM wrote: > on the bottom; I seem to recall the thickness to be .040. Anybody > know; if not I can measure tomorrow. > > ________________________________________________________________________________
Date: Apr 21, 2010
VGhlIEYtMTA3OCBpcyAuMDI1LiANCg0KDQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fDQoNCkZyb206IERMTSA8ZGxtNDYwMDdAY294Lm5ldD4gDQpUbzogcnYxMC1saXN0QG1hdHJv bmljcy5jb20gPHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPiANClNlbnQ6IFdlZCBBcHIgMjEgMTc6 MTQ6MDggMjAxMA0KU3ViamVjdDogUlYxMC1MaXN0OiB0YWlsY29uZSB0aGlja25lc3MgDQoNCg0K b24gdGhlIGJvdHRvbTsgSSBzZWVtIHRvIHJlY2FsbCB0aGUgdGhpY2tuZXNzIHRvIGJlIC4wNDAu IEFueWJvZHkga25vdzsgaWYgbm90IEkgY2FuIG1lYXN1cmUgdG9tb3Jyb3cuDQoNCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUg TWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9z aGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNv IGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Apr 21, 2010
I will measure tonight I think it is .032 but possibly .025 John G. Cumins President 2499 B1 Martin Rd Fairfield Ca 94533 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Wednesday, April 21, 2010 5:14 PM Subject: RV10-List: tailcone thickness on the bottom; I seem to recall the thickness to be .040. Anybody know; if not I can measure tomorrow. ________________________________________________________________________________
Subject: Looking for RV-10 Wing Kit
From: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Date: Apr 21, 2010
I am looking for a RV-10 wing kit. Thanks, Jake Hearnsberger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295198#295198 ________________________________________________________________________________
Date: Apr 21, 2010
Subject: Instrumentation Checkout Video (HDTV)...
Dear Listers, I wanted to check out the operation of all the various systems on the RV-8 now that the engine is running. For example, comparing the fuel flow and fuel pressure readings between the FuelChec DX and the GRT EFIS. I also wanted to run the engine up a little and make sure the CHT and EGT's were coming into a normal range and the all of the probes were working. Also, I wanted to see the oil pressure and temps in normal ranges after a bit of running. Finally, I wanted to check the engine RPM with the new TruTach II hand held optic tachometer. On April 13 2010 I hopped in the pilot's seat and fired up the IO-390 and went though some checks. I videoed the procedure and used the intercom to call out the various readings I was observing. If you select the 1080p version of the YouTube video, you can actually read most of the values right off the GRT EFIS displays! Towards the end of the video some music starts to play. This is coming from the Kenwood via the MP3 files on the 64GB thumb drive plugged into the panel via the PS3000 Intercom and is exactly what I'm hearing in the headphones. YouTube Video (Select higher resolutions 480p/760p/1080p for clearer picture): http://www.youtube.com/MattsRV8?v=-byMWhyTwjA PS - Video was edited with Adobe Premiere CS4 on a Windows Vista 64 system. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits / Inspection / Test Flight ________________________________________________________________________________
Date: Apr 22, 2010
Like Phil said .025" -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Grayson, KY Bldr# 40983 Ord complete kit 8/24/09; DB Sch del 11/20/09 Emp 12/01/09-3/14/10 332 hrs Wings 3/14/10- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295271#295271 ________________________________________________________________________________
Date: Apr 22, 2010
Subject: N998RV Signed Off!
HOBBS Meter: 2452 Construction Hours Its official! RV-8 N998RV was officially signed off by the FAA this afternoon, Certificate and Repairman Certificate and the obligatory entry was made in the aircraft's logbook. A special Phase 1 test-flight area was agreed upon and extends from Livermore to Stockton to Merced to Lost Banos and back to Livermore. Next week I go up to Oregon to get my Transition Training from Mike Seager ( http://www.vansaircraft.com/public/trainfly.htm ) and after that, its time to test fly! YAHOO!!! I can't believe its signed off and the test flight is this close! How exciting! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits / Inspection / Test Flight ________________________________________________________________________________
Date: Apr 22, 2010
Congratulations Matt! Bob RV-10 N442PM -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Thursday, April 22, 2010 3:57 PM Subject: RV10-List: N998RV Signed Off! HOBBS Meter: 2452 Construction Hours Its official! RV-8 N998RV was officially signed off by the FAA this afternoon, Certificate and Repairman Certificate and the obligatory entry was made in the aircraft's logbook. A special Phase 1 test-flight area was agreed upon and extends from Livermore to Stockton to Merced to Lost Banos and back to Livermore. Next week I go up to Oregon to get my Transition Training from Mike Seager ( http://www.vansaircraft.com/public/trainfly.htm ) and after that, its time to test fly! YAHOO!!! I can't believe its signed off and the test flight is this close! How exciting! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits / Inspection / Test Flight ________________________________________________________________________________
Date: Apr 22, 2010
Subject: Re: N998RV Signed Off!
On 04/22/2010 04:57 PM, Matt Dralle wrote: > > HOBBS Meter: 2452 Construction Hours > > Its official! RV-8 N998RV was officially signed off by the FAA this afternoon, Awesome, congratulations! -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Grumman Yankee Driver N9870L - http://deej.net/yankee/ ________________________________________________________________________________
Subject: Ram Air
Date: Apr 22, 2010
Here is the Manifold pressures I get at WOT at various altitudes. I have a ram air intake and wondering if someone with a standard Van's cowl can give me their # to compare. 900' 29" Take off roll 2500' 28" 4000' 26" 5000' 25" 6000' 24" 7500' 23" 8500' 23" Manifold was reading 29.53 before startup. ________________________________________________________________________________
Subject: SnF Awards
Date: Apr 22, 2010
It looks like the RV-10 community was well represented in the awards circle at Sun N Fun. It's certainly no surprise that Geoff would win Best Interior. That will be a tougher award to win next year when everyone starts showing up with one of Aerosport Products <http://www.aerosportproducts.com/> interior packages. BEST INTERIOR 2009 GEOFF COMBS RV-10 N829GW CANAL WINCHESTER, OH OUTSTANDING AIRCRAFT 2009 RON TERHAAR & FRANK RV-10 N816RF FITZGERALD ALBANY, OR OUTSTANDING AIRCRAFT 2009 NORMAN & DONNA RV-10 N879SP ST.PETER RIVERVIEW, FL ________________________________________________________________________________
Date: Apr 22, 2010
Congrats Matt Cheers Les Kearney Sent from my iPhone On 2010-04-22, at 2:57 PM, Matt Dralle wrote: > > HOBBS Meter: 2452 Construction Hours > > Its official! RV-8 N998RV was officially signed off by the FAA this > Special Airworthiness Certificate and Repairman Certificate and the > obligatory entry was made in the aircraft's logbook. A special > Phase 1 test-flight area was agreed upon and extends from Livermore > to Stockton to Merced to Lost Banos and back to Livermore. > > Next week I go up to Oregon to get my Transition Training from Mike > Seager ( http://www.vansaircraft.com/public/trainfly.htm ) and after > that, its time to test fly! > > YAHOO!!! I can't believe its signed off and the test flight is this > close! How exciting! > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Final Bits / Inspection / Test Flight > <2010.04.22 - RV-8 - N998RV Signed Off.jpg> > <2010.04.22 - RV-8 - N998RV Phase One Test Area.jpg> ________________________________________________________________________________
Subject: Re: Ram Air
Date: Apr 22, 2010
That's really close to what I have with the standard cowl. Tim On Apr 22, 2010, at 4:22 PM, "gary" wrote: > > Here is the Manifold pressures I get at WOT at various altitudes. I > have a > ram air intake and wondering if someone with a standard Van's cowl > can give > me their # to compare. > > 900' 29" Take off roll > 2500' 28" > 4000' 26" > 5000' 25" > 6000' 24" > 7500' 23" > 8500' 23" > > Manifold was reading 29.53 before startup. > > ________________________________________________________________________________
Subject: Ram Air
Date: Apr 22, 2010
Those numbers are close to what I get from my Saratoga. With this information I can not see the benefit of the additional cost of the new sump and required additional hardware. John Cumins 40864 Finishing emp Wings next -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, April 22, 2010 4:37 PM Subject: Re: RV10-List: Ram Air That's really close to what I have with the standard cowl. Tim On Apr 22, 2010, at 4:22 PM, "gary" wrote: > > Here is the Manifold pressures I get at WOT at various altitudes. I > have a > ram air intake and wondering if someone with a standard Van's cowl > can give > me their # to compare. > > 900' 29" Take off roll > 2500' 28" > 4000' 26" > 5000' 25" > 6000' 24" > 7500' 23" > 8500' 23" > > Manifold was reading 29.53 before startup. > > ________________________________________________________________________________
Date: Apr 22, 2010
Congratulations! I'd bet that a ton of stuff you worked hard on and worried about wasn't even looked at, while other items that seemed minor did get a close look see. Be sure to send a notam to the RV lists when that first flight is to occur. On Thu, Apr 22, 2010 at 1:57 PM, Matt Dralle wrote: > > HOBBS Meter: 2452 Construction Hours > > Its official! RV-8 N998RV was officially signed off by the FAA this afternoon, and Repairman Certificate and the obligatory entry was made in the aircraft's logbook. A special Phase 1 test-flight area was agreed upon and extends from Livermore to Stockton to Merced to Lost Banos and back to Livermore. ________________________________________________________________________________
Subject: cover or paint screws
Date: Apr 22, 2010
Prepping doors after getting seals and pins fit, now wondering whether to cover screws, should I assume never needing to remove door handles and pin blocks, or is there reason to believe I will need to at some point remove the screws? I realize though that the screws do not take and hold paint well and think a smooth door would look better. I don't recall looking that close at other 10s to see what others are doing. Any opinions? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295336#295336 ________________________________________________________________________________
Date: Apr 22, 2010
A sump has little to do with manifold pressure, and everything to do with intake air temperature and even distribution to cylinders. MP is just one small piece of the overall equation. On Thu, Apr 22, 2010 at 4:53 PM, John Cumins wrote: > > Those numbers are close to what I get from my Saratoga. With this > information I can not see the benefit of the additional cost of the new sump > and required additional hardware. > > John Cumins > 40864 Finishing emp Wings next > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Thursday, April 22, 2010 4:37 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Ram Air > > > That's really close to what I have with the standard cowl. > Tim > > > On Apr 22, 2010, at 4:22 PM, "gary" wrote: > >> >> Here is the Manifold pressures I get at WOT at various altitudes. I >> have a >> ram air intake and wondering if someone with a standard Van's cowl >> can give >> me their # to compare. >> >> 900' 29" Take off roll >> 2500' 28" >> 4000' 26" >> 5000' 25" >> 6000' 24" >> 7500' 23" >> 8500' 23" >> >> Manifold was reading 29.53 before startup. >> >> >> >> >> > > ________________________________________________________________________________
Subject: Brake Line Entrance Holes
Date: Apr 22, 2010
Is there any reason why you couldn't/shouldn't enlarge the brake like entrance holes in the forward part of the tunnel cover? It seems to make sense to open that area up a bit and eliminate the opportunity for chafing. Phil ________________________________________________________________________________
Subject: Re: cover or paint screws
Date: Apr 22, 2010
Most are epoxying and painting over the screws. It is not a big deal, but it provides a more finished look. It is a bit iffy that the paint/epoxy hold when/if the doors are removed and the bolts are re torqued. This is a good opportunity to pound my drum to those novices in the build process to take a lot (I mean hundreds) of pictures from every angle of the RV10's that you see when you go to OSH or sun-n-fun. Especially focus on pictures under the cowl on these planes. Looking at these pictures will save you much angst in the build process when you can visually see what others have done. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295348#295348 ________________________________________________________________________________
Date: Apr 22, 2010
Well done and good luck on the phase one. Don't forget the RV grin and a post to the Vans First Flights web site. Hey............. who is going to maintain this site while you are out flying??? -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295349#295349 ________________________________________________________________________________
Subject: Re: Brake Line Entrance Holes
Date: Apr 22, 2010
I did it also. Not a bad idea also to wrap the entry area with silicone tape. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295351#295351 ________________________________________________________________________________
Date: Apr 22, 2010
Congrats, Matt. How far ahead did you schedule with the FSDO? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295362#295362 ________________________________________________________________________________
Date: Apr 22, 2010
At 09:10 PM 4/22/2010 Thursday, you wrote: > >Congrats, Matt. >How far ahead did you schedule with the FSDO? > >-------- >Bob Turner >RV-10 QB I put the paperwork in the mail on Thursday and it was signed off the next Thursday. Really. 7 days. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Final Bits/Inspection/Test Flight ________________________________________________________________________________
Date: Apr 23, 2010
If you're going to cover them up..... make sure those nice round heads of t he countersunk screws are no longer nice and round when installed.... grind the sides into a square.... less likely to spin when/if removal and reinsa lling is necessary. Don McDonald --- On Thu, 4/22/10, AirMike wrote: From: AirMike <Mikeabel(at)Pacbell.net> Subject: RV10-List: Re: cover or paint screws Date: Thursday, April 22, 2010, 7:23 PM Most are epoxying and painting over the screws. It is not a big deal, but i t provides a more finished look. It is a bit iffy that the paint/epoxy hold when/if the doors are removed and the bolts are re torqued. This is a good opportunity to pound my drum to those novices in the build p rocess to take a lot (I mean hundreds) of pictures from every angle of the RV10's that you see when you go to OSH or sun-n-fun. Especially focus on pi ctures under the cowl on these planes. Looking at these pictures will save you much angst in the build process when you can visually see what others h ave done. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295348#295348 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Apr 23, 2010
I'd probably cover the pin blocks, but not the screws holding the latch in place. IMHO there's too much chance of removal on the latch mechanism screws. Also, as was already suggested, you can remove the nuts in a pinch on the pin blocks if you have secured the screws well enough, and possibly squared off the head a little, but you have to remove the door handle with the screws. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Apr 22, 2010, at 9:05 PM, rvdave wrote: > > Prepping doors after getting seals and pins fit, now wondering whether to cover screws, should I assume never needing to remove door handles and pin blocks, or is there reason to believe I will need to at some point remove the screws? I realize though that the screws do not take and hold paint well and think a smooth door would look better. I don't recall looking that close at other 10s to see what others are doing. Any opinions? > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295336#295336 > > > > > > > > > > ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Apr 23, 2010
In Michigan, you have to file 6 months in advance.... Really..... 6 months Sent from my iPhone On Apr 23, 2010, at 2:30 AM, Matt Dralle wrote: > > At 09:10 PM 4/22/2010 Thursday, you wrote: >> >> >> Congrats, Matt. >> How far ahead did you schedule with the FSDO? >> >> -------- >> Bob Turner >> RV-10 QB > > > I put the paperwork in the mail on Thursday and it was signed off > the next Thursday. Really. 7 days. > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Final Bits/Inspection/Test Flight > > ________________________________________________________________________________
Date: Apr 23, 2010
Wow! When I was at the OAK FSDO last September they told me to give them 6 months notice to schedule the inspection. I guess they're not as busy as they thought. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295428#295428 ________________________________________________________________________________
Date: Apr 23, 2010
On 04/23/2010 01:31 PM, Bob Turner wrote: > > Wow! When I was at the OAK FSDO last September they told me to give them 6 months notice to schedule the inspection. I guess they're not as busy as they thought. Matt probably runs their mail server... *wink* -Dj ________________________________________________________________________________
Subject: WTB: RV-10 tail kit
Date: Apr 23, 2010
It's time to start building a family hauler :) I'm looking for an RV-10 tail kit. The closer to Charlotte, NC the better. Looking for one with as little work done as possible, but will consider all options. Let me know what you have.... and we can go from there. email: vitez (at) carolina (dot) rr (dot) com PS. Another option, just to throw it out there, is that I'd be interested in trading my RV-7A (flying, painted, glass panel, ~270TT) for an RV-10 kit that's coming up closer to completion.. If someone's looking to downsize.. well, I'm looking to upsize to fit my recently expanded family.. Thanks! Radomir -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295459#295459 ________________________________________________________________________________
Subject: Re: WTB: RV-10 tail kit
Date: Apr 23, 2010
I have a 95 % complete one. It is very nice. Asking 3700.00. I can send photos Geoff Sent from my iPhone Geoff On Apr 23, 2010, at 5:11 PM, "N777TY" wrote: > > It's time to start building a family hauler :) > > I'm looking for an RV-10 tail kit. The closer to Charlotte, NC the > better. > > Looking for one with as little work done as possible, but will > consider all options. > > > Let me know what you have.... and we can go from there. > > email: vitez (at) carolina (dot) rr (dot) com > > > PS. Another option, just to throw it out there, is that I'd be > interested in trading my RV-7A (flying, painted, glass panel, > ~270TT) for an RV-10 kit that's coming up closer to completion.. > If someone's looking to downsize.. well, I'm looking to upsize to > fit my recently expanded family.. > > > Thanks! > Radomir > > -------- > RV-7A > N777TY > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295459#295459 > > ________________________________________________________________________________
Date: Apr 23, 2010
I have one that is about 60-70% complete (the portions done were completed during the Alexander Technical Center workshop a year ago, so they have been double-checked by an expert). I'm in Johnson City, Tennessee, about 3 hours from Charlotte. As a plus, the pieces are still crated from their trip back from Georgia last summer. Plans have changed, and I'm not going to be able to continue building anytime soon, so I'm going to have to part with the dream for now. -- Chris -----Original Message----- From: "N777TY" <microsmurfer(at)yahoo.com> Sent: Friday, April 23, 2010 5:11pm Subject: RV10-List: WTB: RV-10 tail kit It's time to start building a family hauler :) I'm looking for an RV-10 tail kit. The closer to Charlotte, NC the better. Looking for one with as little work done as possible, but will consider all options. Let me know what you have.... and we can go from there. email: vitez (at) carolina (dot) rr (dot) com PS. Another option, just to throw it out there, is that I'd be interested in trading my RV-7A (flying, painted, glass panel, ~270TT) for an RV-10 kit that's coming up closer to completion.. If someone's looking to downsize.. well, I'm looking to upsize to fit my recently expanded family.. Thanks! Radomir -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295459#295459 ________________________________________________________________________________
Subject: 569JC
Date: Apr 23, 2010
Anyone know the story yet? ________________________________________________________________________________
Subject: 569JC
Date: Apr 23, 2010
Here you go............ See Below Phil Today I got lucky, real lucky. 3 Months ago to the day our RV-10 was signed off from a Kit to an Airplane, today it experienced its first and hopefully last engine failure. With 58 hours on the Hobbs she had until this point been the best 4 place airplane I've ever flown. I had flown some friends from Pearland TX over to Victoria so they could pick up their motor home. A very non-eventful flight, a little bumpy VFR down at 2000 AGL, but an overcast layer prevented any higher. Once there I decided that I would file IFR for the flight back, get on top and enjoy some tailwinds. I left Victoria, climbed to 7000 and enjoyed some much needed sunlight. Houston Center was their normal cheerful self; all in all, life was good. I was cleared down to 4000, as luck would have the Overcast layer had also dropped a few thousand feet so I remained on Top... wow so nice, still don't have to be in the clunk! Center switched me to Approach, we agreed upon the GPS approach back to Pearland, and I was cleared to the IAF. Up until this point everything was absolutely great! I started my decent out of 4, down to 3000 going direct the IAF... At 3400 ft, that's when the adrenalin started pumping. Now I'll be honest, I don't' know if I heard the prop fluctuate or not, but something got my attention. I did a quick engine check and saw that EGT's where high... very very high. I knew immediately I had a problem, but I had no idea just how bad the problem was. Training kicked in and Mixture to rich, boost pump on, tank switch. The EGT's came down, but they didn't stop coming down. When I saw them drop below 200 or so, and I was getting no reaction what-so-ever from the throttle... Well, Houston We Have A Problem. I declared the Emergency... If you ever want to hear a frequency go totally quiet, just use those words. Informed Approach of a total power failure and requested vectors to the nearest airport. Houston Approach was for the most part absolutely wonderful. Without missing a beat they informed me that Brazoria was 7'Oclock and 5 miles. I IMMEDIATELY started the turn and realized that with my now wonderful tailwind turned headwind, there was no way I was going to make it. Let me back up just a bit... All this is happing IMC. I entered the overcast layer at about 3800 FT, bases are reported anywhere between 1000-1500 depending on which ASOS you listen to. Continuing on.... Not going to make Brazoria, I know I have to do something. Glancing at my EFIS Map I see that =BE a mile away is a private strip that Center probably didn't even know existed. I turn directly at that airport (7R9), informed Approach where I was going, then I waited, and waited, and waited.... Not much else I could think to do at the time. Still IMC. Engine Out. I didn't really think I'd be in this situation, ever. =BC mile from the airport, at 1300 ft I break out. Guys & Gals, I haven't been so happy to see a perfectly mowed grass strip in my life! A quick turn away to burn Airspeed and Altitude, slip to final, and down we come. The landing went perfect, it was downwind. I didn't care, the airplane didn't care. The prop finally quit windmilling in the flair, telling me that it really was dead, as if I didn't know. I managed to get us (me and the plane) on the ground, unhurt, out of that situation. Is it all skill, well I'd like to think so... but I know better! I got lucky, very lucky. What went wrong? The short version: a fuel line broke. The long version: During final assembly it came to my attention that people with the Fuel Flow transducer in the "Tunnel" where experiencing FF fluctuation when using the electric pump. The fix? Move the FF Transducer to between the Fuel Injection Servo and the Spider. Well, that's what I did. When I relocated the Transducer I had to fabricate a line between the Servo and the Transducer. The line I fabricated was =BC inch aluminum, that was the flaw. That line broke just outside the fitting. When I made that line I made sure it wasn't under any stress, in a natural position, etc. Apparently that was not enough. Now, I will say this. This was the one component of the airplane I was never quite happy with. It just "didn't look right". I had some other builders take a look, half heartedly hoping they would tell me that aluminum was bad and I should change it, but no one did. So it stayed, and worked fine for 58 hours. I blame no one but myself for what happened. A part of me knew that that line wasn't right, yet I talked myself into believing it was fine. Don't ever short change your gut... most of the time its got good instincts! She's now grounded, awaiting Stainless Tubing so I can make the fuel like the way I originally envisioned. Parts should be here next week, and the adventure will continue. Now comes the part where I'd like to thank the people that helped me stay alive today! First my Father, Kirk. You see, I started flying Ultralights at 14, and it was he who preached at me to practice engine outs. They where 2 strokes, and it wasn't "if" they would quit, it was "when". I never lost an engine flying Ultralights, but I sure practiced. My Flight Instructors. All you guys (and there has been a few..) who would randomly pull power, then say "Now what?" Rob Hickman and the entire crew at Advanced Flight Systems. Without those awesome EFIS's (and I really do mean awesome) I probably would have never known that the airport I landed at was there. It didn't show up on the 430, Approach didn't know, and I was stuck IMC. And the data logging.. wow. I poured over every second of that flight to find out when exactly I converted from ASEL to Glider... Having that data is invaluable. John Cram (build partner) and Rick Carr for selfless gathering their own tools and driving to my rescue. With their help we where able to fabricate a new fuel line ferry the airplane the 22 miles home. The entire group of local airport bums that showed up to offer a helping hand. I only wish I could remember each and everyone's name, but that is not my strong suit. I owe all of you at least a beer! Last but not least... Brazoria County Constables and Sheriff's (no less than 5) who showed up, lights and sirens agoin, to come to my rescue. Thankfully I didn't need it, but it sure is nice to know that help is on the way. In case anyone wants to know how fast this happens. Total time from Me turning on the Fuel Pump to wheels on the ground: 2 Minutes 46 seconds. From: DLM [mailto:dlm46007(at)cox.net] Sent: Friday, April 23, 2010 5:57 PM Subject: RV10-List: 569JC Anyone know the story yet? ________________________________________________________________________________
Subject: GRT XM weather
Date: Apr 23, 2010
Just removed a GRT processor, an XM receiver. XM antenna and harness from my RV10. I am going the ADSB route. Anyone interested in the old equipment , please contact me directly by email. $600. ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 23, 2010
Awesome story! Great job getting down in one piece. Thanks for sharing. Sent from my iPhone On Apr 23, 2010, at 17:10, "Perry, Phil" wrote: > Here you go > > See Below > > > Phil > > > Today I got lucky, real lucky. > > 3 Months ago to the day our RV-10 was signed off from a Kit to an > Airplane, today it experienced its first and hopefully last engine > failure. With 58 hours on the Hobbs she had until this point been > the best 4 place airplane I=99ve ever flown. > > I had flown some friends from Pearland TX over to Victoria so they > could pick up their motor home. A very non-eventful flight, a little > bumpy VFR down at 2000 AGL, but an overcast layer prevented any > higher. Once there I decided that I would file IFR for the flight > back, get on top and enjoy some tailwinds. > > I left Victoria, climbed to 7000 and enjoyed some much needed > sunlight. Houston Center was their normal cheerful self; all in all, > life was good. I was cleared down to 4000, as luck would have the > Overcast layer had also dropped a few thousand feet so I remained on > Top wow so nice, still don=99t have to be in the clunk! Center > switched me to Approach, we agreed upon the GPS approach back to Pea > rland, and I was cleared to the IAF. Up until this point everything > was absolutely great! > > I started my decent out of 4, down to 3000 going direct the IAF At > 3400 ft, that=99s when the adrenalin started pumping. Now I=99 ll be > honest, I don=99t=99 know if I heard the prop fluctuate or not, but > something got my attention. I did a quick engine check and saw that > EGT=99s where high very very high. I knew immediately I had a > problem, but I had no idea just how bad the problem was. Training ki > cked in and Mixture to rich, boost pump on, tank switch. The EGT=99 s c > ame down, but they didn=99t stop coming down. When I saw them drop bel > ow 200 or so, and I was getting no reaction what-so-ever from the th > rottle Well, Houston We Have A Problem. > > I declared the Emergency If you ever want to hear a frequency go to > tally quiet, just use those words. Informed Approach of a total powe > r failure and requested vectors to the nearest airport. Houston Appr > oach was for the most part absolutely wonderful. Without missing a b > eat they informed me that Brazoria was 7=99Oclock and 5 miles. I IMMED > IATELY started the turn and realized that with my now wonderful tail > wind turned headwind, there was no way I was going to make it. > > Let me back up just a bit All this is happing IMC. I entered the ov > ercast layer at about 3800 FT, bases are reported anywhere between 1 > 000-1500 depending on which ASOS you listen to. > > Continuing on. Not going to make Brazoria, I know I have to do some > thing. Glancing at my EFIS Map I see that =C2=BE a mile away is a private > strip that Center probably didn=99t even know existed. I turn directl > y at that airport (7R9), informed Approach where I was going, then I > waited, and waited, and waited. Not much else I could think to do > at the time. Still IMC. Engine Out. I didn=99t really think I=99d be > in this situation, ever. > > =C2=BC mile from the airport, at 1300 ft I break out. Guys & Gals, I have > n=99t been so happy to see a perfectly mowed grass strip in my life! A > quick turn away to burn Airspeed and Altitude, slip to final, and d > own we come. The landing went perfect, it was downwind. I didn=99t car > e, the airplane didn=99t care. The prop finally quit windmilling in th > e flair, telling me that it really was dead, as if I didn=99t know. > > I managed to get us (me and the plane) on the ground, unhurt, out of > that situation. Is it all skill, well I=99d like to think so but I > know better! I got lucky, very lucky. > > > What went wrong? The short version: a fuel line broke. > > The long version: During final assembly it came to my attention that > people with the Fuel Flow transducer in the =9CTunnel=9D where > experiencing FF fluctuation when using the electric pump. The fix? M > ove the FF Transducer to between the Fuel Injection Servo and the Sp > ider. Well, that=99s what I did. When I relocated the Transducer I had > to fabricate a line between the Servo and the Transducer. The line > I fabricated was =C2=BC inch aluminum, that was the flaw. That line broke > just outside the fitting. When I made that line I made sure it wasn > =99t under any stress, in a natural position, etc. Apparently that was > not enough. Now, I will say this. This was the one component of the > airplane I was never quite happy with. It just =9Cdidn=99t look > right=9D. I had some other builders take a look, half heartedly hoping > they would tell me that aluminum was bad and I should change it, bu > t no one did. So it stayed, and worked fine for 58 hours. > > > > I blame no one but myself for what happened. A part of me knew that > that line wasn=99t right, yet I talked myself into believing it was fi > ne. Don=99t ever short change your gut most of the time its got > good instincts! > > She=99s now grounded, awaiting Stainless Tubing so I can make the fuel > like the way I originally envisioned. Parts should be here next wee > k, and the adventure will continue. > > Now comes the part where I=99d like to thank the people that helped me > stay alive today! > > First my Father, Kirk. You see, I started flying Ultralights at 14, > and it was he who preached at me to practice engine outs. They where > 2 strokes, and it wasn=99t =9Cif=9D they would quit, it was > =9Cwhen=9D. I never lost an engine flying Ultralights, but I sure > practiced. > > My Flight Instructors. All you guys (and there has been a few..) who > would randomly pull power, then say =9CNow what?=9D > > Rob Hickman and the entire crew at Advanced Flight Systems. Without > those awesome EFIS=99s (and I really do mean awesome) I probably would > have never known that the airport I landed at was there. It didn=99 t > show up on the 430, Approach didn=99t know, and I was stuck IMC. And t > he data logging.. wow. I poured over every second of that flight to > find out when exactly I converted from ASEL to Glider Having that d > ata is invaluable. > > John Cram (build partner) and Rick Carr for selfless gathering their > own tools and driving to my rescue. With their help we where able to > fabricate a new fuel line ferry the airplane the 22 miles home. > > The entire group of local airport bums that showed up to offer a > helping hand. I only wish I could remember each and everyone=99s name, > but that is not my strong suit. I owe all of you at least a beer! > > Last but not least Brazoria County Constables and Sheriff =99s (no > less than 5) who showed up, lights and sirens agoin, to come to my r > escue. Thankfully I didn=99t need it, but it sure is nice to know that > help is on the way. > > In case anyone wants to know how fast this happens. Total time from > Me turning on the Fuel Pump to wheels on the ground: 2 Minutes 46 > seconds. > > > > > > > From: DLM [mailto:dlm46007(at)cox.net] > Sent: Friday, April 23, 2010 5:57 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: 569JC > > > Anyone know the story yet? > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Apr 23, 2010
Subject: Re: 569JC
Perry, Phil wrote: > Today I got lucky, real lucky. Awesome job Phil! I've had 3 off-field landings ..... two engine related and one was precautionary for fuel ..... which leaked from a hole in a hard line. On all occasions, I was snatched from harm by the thousands of angels on my shoulders. No skill involved! And declaring an emergency (another flight after the fuel leak .... I didn't find it after the 'warning') was the easiest thing I ever did!!! Linn ________________________________________________________________________________
Subject: 569JC
Date: Apr 23, 2010
That was not me!! Mine won't fly any further than I can throw it. :) That was a copy and paste from the VAF posting. I should have made that more clear. Sorry about that, Phil -----Original Message----- From: Linn Walters [mailto:pitts_pilot(at)bellsouth.net] Sent: Friday, April 23, 2010 6:40 PM Subject: Re: RV10-List: 569JC Perry, Phil wrote: > Today I got lucky, real lucky. Awesome job Phil! I've had 3 off-field landings ..... two engine related and one was precautionary for fuel ..... which leaked from a hole in a hard line. On all occasions, I was snatched from harm by the thousands of angels on my shoulders. No skill involved! And declaring an emergency (another flight after the fuel leak .... I didn't find it after the 'warning') was the easiest thing I ever did!!! Linn ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 23, 2010
I take back all that nice stuff I said;) Sent from my iPhone On Apr 23, 2010, at 17:46, "Perry, Phil" wrote: > > That was not me!! Mine won't fly any further than I can throw it. :) > > That was a copy and paste from the VAF posting. I should have made > that > more clear. > > Sorry about that, > Phil > > > -----Original Message----- > From: Linn Walters [mailto:pitts_pilot(at)bellsouth.net] > Sent: Friday, April 23, 2010 6:40 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: 569JC > > > > Perry, Phil wrote: >> Today I got lucky, real lucky. > > Awesome job Phil! > > I've had 3 off-field landings ..... two engine related and one was > precautionary for fuel ..... which leaked from a hole in a hard line. > > On all occasions, I was snatched from harm by the thousands of > angels on > > my shoulders. No skill involved! > > And declaring an emergency (another flight after the fuel leak .... I > didn't find it after the 'warning') was the easiest thing I ever > did!!! > Linn > > ________________________________________________________________________________
Subject: 569JC
Date: Apr 23, 2010
Thanks Sean... At least my dogs still like me. :) -----Original Message----- From: Seano [mailto:sean(at)braunandco.com] Sent: Friday, April 23, 2010 7:01 PM Subject: Re: RV10-List: 569JC I take back all that nice stuff I said;) Sent from my iPhone On Apr 23, 2010, at 17:46, "Perry, Phil" wrote: > > That was not me!! Mine won't fly any further than I can throw it. :) > > That was a copy and paste from the VAF posting. I should have made > that > more clear. > > Sorry about that, > Phil > > > -----Original Message----- > From: Linn Walters [mailto:pitts_pilot(at)bellsouth.net] > Sent: Friday, April 23, 2010 6:40 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: 569JC > > > > Perry, Phil wrote: >> Today I got lucky, real lucky. > > Awesome job Phil! > > I've had 3 off-field landings ..... two engine related and one was > precautionary for fuel ..... which leaked from a hole in a hard line. > > On all occasions, I was snatched from harm by the thousands of > angels on > > my shoulders. No skill involved! > > And declaring an emergency (another flight after the fuel leak .... I > didn't find it after the 'warning') was the easiest thing I ever > did!!! > Linn > > ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 23, 2010
Kind of cool to see the flightaware trip. http://flightaware.com/live/flight/N569JC -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295519#295519 ________________________________________________________________________________
Subject: aerosport overhead console
Date: Apr 23, 2010
Has anyone tried fitting the carbon fiber overhead to the green cabin vs the pink that it was molded for? I don't know if there is any difference between the pink and green? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295520#295520 ________________________________________________________________________________
Date: Apr 24, 2010
I don't have any empirical data, but based upon conversation with Geoff Combs who has a green cabin cover and has seen my pink cabin cover there shouldn't be any difference in fit. The basic differences are in quality of finish. You may have more work filling and sanding with the green version. I would give Geoff a call directly. (614) 834-8659 bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave Sent: Friday, April 23, 2010 11:50 PM Subject: RV10-List: aerosport overhead console Has anyone tried fitting the carbon fiber overhead to the green cabin vs the pink that it was molded for? I don't know if there is any difference between the pink and green? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295520#295520 ________________________________________________________________________________
From: "John MacCallum" <vk2gcn(at)cirruscomms.com.au>
Subject: 569JC
Date: Apr 24, 2010
That=92s just an amazing story! I=92m doing SE CMD right now with about 35 hours in and that scenario I have thought about over and over. What if the big Fan stops when you=92re in IMC? All I can say is well Done and good on the technology that led you to that strip! cheers John MacCallum Builder 41016 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Perry, Phil Sent: Saturday, 24 April 2010 9:11 AM Subject: RE: RV10-List: 569JC Here you go=85=85=85=85 See Below Phil Today I got lucky, real lucky. 3 Months ago to the day our RV-10 was signed off from a Kit to an Airplane, today it experienced its first and hopefully last engine failure. With 58 hours on the Hobbs she had until this point been the best 4 place airplane I=92ve ever flown. I had flown some friends from Pearland TX over to Victoria so they could pick up their motor home. A very non-eventful flight, a little bumpy VFR down at 2000 AGL, but an overcast layer prevented any higher. Once there I decided that I would file IFR for the flight back, get on top and enjoy some tailwinds. I left Victoria, climbed to 7000 and enjoyed some much needed sunlight. Houston Center was their normal cheerful self; all in all, life was good. I was cleared down to 4000, as luck would have the Overcast layer had also dropped a few thousand feet so I remained on Top=85 wow so nice, still don=92t have to be in the clunk! Center switched me to Approach, we agreed upon the GPS approach back to Pearland, and I was cleared to the IAF. Up until this point everything was absolutely great! I started my decent out of 4, down to 3000 going direct the IAF=85 At 3400 ft, that=92s when the adrenalin started pumping. Now I=92ll be honest, I don=92t=92 know if I heard the prop fluctuate or not, but something got my attention. I did a quick engine check and saw that EGT=92s where high=85 very very high. I knew immediately I had a problem, but I had no idea just how bad the problem was. Training kicked in and Mixture to rich, boost pump on, tank switch. The EGT=92s came down, but they didn=92t stop coming down. When I saw them drop below 200 or so, and I was getting no reaction what-so-ever from the throttle=85 Well, Houston We Have A Problem. I declared the Emergency=85 If you ever want to hear a frequency go totally quiet, just use those words. Informed Approach of a total power failure and requested vectors to the nearest airport. Houston Approach was for the most part absolutely wonderful. Without missing a beat they informed me that Brazoria was 7=92Oclock and 5 miles. I IMMEDIATELY started the turn and realized that with my now wonderful tailwind turned headwind, there was no way I was going to make it. Let me back up just a bit=85 All this is happing IMC. I entered the overcast layer at about 3800 FT, bases are reported anywhere between 1000-1500 depending on which ASOS you listen to. Continuing on=85. Not going to make Brazoria, I know I have to do something. Glancing at my EFIS Map I see that =BE a mile away is a private strip that Center probably didn=92t even know existed. I turn directly at that airport (7R9), informed Approach where I was going, then I waited, and waited, and waited=85. Not much else I could think to do at the time. Still IMC. Engine Out. I didn=92t really think I=92d be in this situation, ever. =BC mile from the airport, at 1300 ft I break out. Guys & Gals, I haven=92t been so happy to see a perfectly mowed grass strip in my life! A quick turn away to burn Airspeed and Altitude, slip to final, and down we come. The landing went perfect, it was downwind. I didn=92t care, the airplane didn=92t care. The prop finally quit windmilling in the flair, telling me that it really was dead, as if I didn=92t know. I managed to get us (me and the plane) on the ground, unhurt, out of that situation. Is it all skill, well I=92d like to think so=85 but I know better! I got lucky, very lucky. What went wrong? The short version: a fuel line broke. The long version: During final assembly it came to my attention that people with the Fuel Flow transducer in the =93Tunnel=94 where experiencing FF fluctuation when using the electric pump. The fix? Move the FF Transducer to between the Fuel Injection Servo and the Spider. Well, that=92s what I did. When I relocated the Transducer I had to fabricate a line between the Servo and the Transducer. The line I fabricated was =BC inch aluminum, that was the flaw. That line broke just outside the fitting. When I made that line I made sure it wasn=92t under any stress, in a natural position, etc. Apparently that was not enough. Now, I will say this. This was the one component of the airplane I was never quite happy with. It just =93didn=92t look right=94. I had some other builders take a look, half heartedly hoping they would tell me that aluminum was bad and I should change it, but no one did. So it stayed, and worked fine for 58 hours. https://dl.dropbox.com/u/5834625/RV10/photo%203.jpg I blame no one but myself for what happened. A part of me knew that that line wasn=92t right, yet I talked myself into believing it was fine. Don=92t ever short change your gut=85 most of the time its got good instincts! She=92s now grounded, awaiting Stainless Tubing so I can make the fuel like the way I originally envisioned. Parts should be here next week, and the adventure will continue. Now comes the part where I=92d like to thank the people that helped me stay alive today! First my Father, Kirk. You see, I started flying Ultralights at 14, and it was he who preached at me to practice engine outs. They where 2 strokes, and it wasn=92t =93if=94 they would quit, it was =93when=94. I never lost an engine flying Ultralights, but I sure practiced. My Flight Instructors. All you guys (and there has been a few..) who would randomly pull power, then say =93Now what?=94 Rob Hickman and the entire crew at Advanced Flight Systems. Without those awesome EFIS=92s (and I really do mean awesome) I probably would have never known that the airport I landed at was there. It didn=92t show up on the 430, Approach didn=92t know, and I was stuck IMC. And the data logging.. wow. I poured over every second of that flight to find out when exactly I converted from ASEL to Glider=85 Having that data is invaluable. John Cram (build partner) and Rick Carr for selfless gathering their own tools and driving to my rescue. With their help we where able to fabricate a new fuel line ferry the airplane the 22 miles home. The entire group of local airport bums that showed up to offer a helping hand. I only wish I could remember each and everyone=92s name, but that is not my strong suit. I owe all of you at least a beer! Last but not least=85 Brazoria County Constables and Sheriff=92s (no less than 5) who showed up, lights and sirens agoin, to come to my rescue. Thankfully I didn=92t need it, but it sure is nice to know that help is on the way. In case anyone wants to know how fast this happens. Total time from Me turning on the Fuel Pump to wheels on the ground: 2 Minutes 46 seconds. https://dl.dropbox.com/u/5834625/RV10/EntireFlight.jpg https://dl.dropbox.com/u/5834625/RV10/landing.jpg From: DLM [mailto:dlm46007(at)cox.net] Sent: Friday, April 23, 2010 5:57 PM Subject: RV10-List: 569JC Anyone know the story yet? http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 24, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
Subject: Re: 569JC
Nick, really, really nice job piloting (period). Sitting in the virtual cockpit with you, I'm imagining that it must be nice not having to transition off a vacuum powered anything when you lost power. And the situational awareness of the glass has to be sweet. Would be curious to hear any thoughts of why there wasn't a fire. Bill "fully awake this morning" Watson 40605 ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 24, 2010
Great story. Just last week I was on the phone with the folks who make the red cube transducer and they too told me that putting it in the tunnel like Van's shows on the prints is a bad idea. The other thing they told me and that they were emphatic about was that you must use FLEX line both in and out of the cube. In fact they suggested no hard line anywhere between any mounted components in the fuel system. They said that different masses get different vibration patterns and will crack the hard lines. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295572#295572 ________________________________________________________________________________
Date: Apr 24, 2010
Subject: Re: was 569JC- now vacuum pump behavior with windmilling engine
I realize that the 569JC discussion is over on VAF but I'd like to ask a question I just realized I don't have a clue about... If you lose your engine and the prop is windmilling, does your vacuum pump still generate enough suck to power the gyros? Or does the horizon just slowly fall over? (assuming you have vac powered gyros) Thanks, Bill Bill Mauledriver Watson wrote: > > > Nick, really, really nice job piloting (period). > > Sitting in the virtual cockpit with you, I'm imagining that it must be > nice not having to transition off a vacuum powered anything when you > lost power. And the situational awareness of the glass has to be sweet. > > Would be curious to hear any thoughts of why there wasn't a fire. > > Bill "fully awake this morning" Watson > 40605 > > ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 24, 2010
I believe Vans has their Demo plane setup per the plans and they haven't had issues. I recall asking support about this a while back and they stated all their planes are setup with the aluminum tube and never had an issue. The plane with this issue has his cube in the engine area by the servo to avoid reported fuel pump issue (high GPH readings when on) not the tunnel- he would have known he had a problem if it was in the tunnel the fuel smell would have given that away- lucky there was not fire in the engine area. P -------------------------------------------------- From: "woxofswa" <woxof(at)aol.com> Sent: Saturday, April 24, 2010 2:09 PM Subject: RV10-List: Re: 569JC > > Great story. > > Just last week I was on the phone with the folks who make the red cube > transducer and they too told me that putting it in the tunnel like Van's > shows on the prints is a bad idea. The other thing they told me and that > they were emphatic about was that you must use FLEX line both in and out > of the cube. In fact they suggested no hard line anywhere between any > mounted components in the fuel system. They said that different masses > get different vibration patterns and will crack the hard lines. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295572#295572 > > > ________________________________________________________________________________
Date: Apr 24, 2010
Depends.... but most vacuum pump installations generate enough flow to power the gyros even at idle (look at the vacuum pressure gauge, is it in the green?). so if the engine windmills at 1000 rpm or more, and usually it will (depends on the prop, if there's internal damage, etc), then yes, the gyros will work. If this wasn't true, then a 172 making a long idle power descent thru the clouds might suddenly find the gyros didn't work! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295576#295576 ________________________________________________________________________________
Date: Apr 24, 2010
Subject: Re: Fuel sensor location (was N569JC)
FWIW, I'm in the process of changing the location of my fuel flow sensor. I had it in the stock Van's tunnel location. And as others reported that location yeilds a higher than normal reading when the fuel pump is turned on. However, it also gives me fluctuations in the instantaneous readings. Typically they are +/- .2-.4 gph. But occasionally can vary as much as +/- .8 gph. For purposes of fuel totalizator functions, it doesn't appear to cause much of a problem. As the totals are within .1-.2 gals a fill up. I suppose because the +'s and -'s offset each other. But I've been working on tuning my fuel injection via the restrictors, with the desired goal of getting to +/- .1 _ .3 gph variation between cylinders, and despite all of my best efforts with data logging to capture data, it's just not good enough. So after talking with Don @ Airflow, he stated that the best place for the sensor is between the servo and the dist spider. I've been playing with this for the past couple of days and it looks like I can position the sensor on the corner of the sump under the #1 cyl. Its going to require 2 new integral firesleeved SS/teflon hoses, and the install will be close quarters, but it appears it should work. The FloScan installation instructions call for the sensor to be wrapped in firesleeve, and that makes supporting the sensor and fuel lines a challenge. Deems Davis N519PJ www.deemsrv10.com On 4/24/2010 2:29 PM, Pascal wrote: > > I believe Vans has their Demo plane setup per the plans and they > haven't had issues. I recall asking support about this a while back > and they stated all their planes are setup with the aluminum tube and > never had an issue. > The plane with this issue has his cube in the engine area by the servo > to avoid reported fuel pump issue (high GPH readings when on) not the > tunnel- he would have known he had a problem if it was in the tunnel > the fuel smell would have given that away- lucky there was not fire in > the engine area. > P > > -------------------------------------------------- > From: "woxofswa" <woxof(at)aol.com> > Sent: Saturday, April 24, 2010 2:09 PM > To: > Subject: RV10-List: Re: 569JC > >> >> Great story. >> >> Just last week I was on the phone with the folks who make the red >> cube transducer and they too told me that putting it in the tunnel >> like Van's shows on the prints is a bad idea. The other thing they >> told me and that they were emphatic about was that you must use FLEX >> line both in and out of the cube. In fact they suggested no hard >> line anywhere between any mounted components in the fuel system. >> They said that different masses get different vibration patterns and >> will crack the hard lines. >> >> -------- >> Myron Nelson >> Mesa, AZ >> Emp completed, QB wings completed, legacy build fuse in progress >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=295572#295572 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Fuel sensor location (was N569JC)
Date: Apr 24, 2010
I believe the key is no aluminum hard lines firewall forward; I had Halon lines in aluminum running from the firewall bulkhead fitting to the carb air box and from the bulkhead fitting to the sprayer over the engine on my Glastar. Both lines initially failed due to vibration. After using an intermediate rubber tube to isolate the airframe from engine vibrations and properly securing the sprayer , the problem was solved. However this would not work with fuel lines; stainless or SS Teflon flex lines are imperative. Aluminum hard lines have been used and approved in certified aircraft (airframe) for many years. As a side note hydraulic return lines in my Cardinal RG twice cracked the flare at the electric pump and allowed 5606 to leak. Fortunately the leaks occurred and were observed on the ground. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Saturday, April 24, 2010 3:03 PM Subject: Re: RV10-List: Fuel sensor location (was N569JC) FWIW, I'm in the process of changing the location of my fuel flow sensor. I had it in the stock Van's tunnel location. And as others reported that location yeilds a higher than normal reading when the fuel pump is turned on. However, it also gives me fluctuations in the instantaneous readings. Typically they are +/- .2-.4 gph. But occasionally can vary as much as +/- .8 gph. For purposes of fuel totalizator functions, it doesn't appear to cause much of a problem. As the totals are within .1-.2 gals a fill up. I suppose because the +'s and -'s offset each other. But I've been working on tuning my fuel injection via the restrictors, with the desired goal of getting to +/- .1 _ .3 gph variation between cylinders, and despite all of my best efforts with data logging to capture data, it's just not good enough. So after talking with Don @ Airflow, he stated that the best place for the sensor is between the servo and the dist spider. I've been playing with this for the past couple of days and it looks like I can position the sensor on the corner of the sump under the #1 cyl. Its going to require 2 new integral firesleeved SS/teflon hoses, and the install will be close quarters, but it appears it should work. The FloScan installation instructions call for the sensor to be wrapped in firesleeve, and that makes supporting the sensor and fuel lines a challenge. Deems Davis N519PJ www.deemsrv10.com On 4/24/2010 2:29 PM, Pascal wrote: I believe Vans has their Demo plane setup per the plans and they haven't had issues. I recall asking support about this a while back and they stated all their planes are setup with the aluminum tube and never had an issue. The plane with this issue has his cube in the engine area by the servo to avoid reported fuel pump issue (high GPH readings when on) not the tunnel- he would have known he had a problem if it was in the tunnel the fuel smell would have given that away- lucky there was not fire in the engine area. P -------------------------------------------------- From: "woxofswa" <mailto:woxof(at)aol.com> <woxof(at)aol.com> Sent: Saturday, April 24, 2010 2:09 PM Subject: RV10-List: Re: 569JC Great story. Just last week I was on the phone with the folks who make the red cube transducer and they too told me that putting it in the tunnel like Van's shows on the prints is a bad idea. The other thing they told me and that they were emphatic about was that you must use FLEX line both in and out of the cube. In fact they suggested no hard line anywhere between any mounted components in the fuel system. They said that different masses get different vibration patterns and will crack the hard lines. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295572#295572 ________________________________________________________________________________
Subject: Re: 569JC
Date: Apr 24, 2010
All the more reason for a fire bottle; note the fire handle in the picture. System is plumbed to two sprayers; one over the engine and one aft of the rear cylinder baffles -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Saturday, April 24, 2010 2:30 PM Subject: Re: RV10-List: Re: 569JC I believe Vans has their Demo plane setup per the plans and they haven't had issues. I recall asking support about this a while back and they stated all their planes are setup with the aluminum tube and never had an issue. The plane with this issue has his cube in the engine area by the servo to avoid reported fuel pump issue (high GPH readings when on) not the tunnel- he would have known he had a problem if it was in the tunnel the fuel smell would have given that away- lucky there was not fire in the engine area. P -------------------------------------------------- From: "woxofswa" <woxof(at)aol.com> Sent: Saturday, April 24, 2010 2:09 PM Subject: RV10-List: Re: 569JC > > Great story. > > Just last week I was on the phone with the folks who make the red cube > transducer and they too told me that putting it in the tunnel like > Van's shows on the prints is a bad idea. The other thing they told me > and that they were emphatic about was that you must use FLEX line both > in and out of the cube. In fact they suggested no hard line anywhere > between any mounted components in the fuel system. They said that > different masses get different vibration patterns and will crack the hard lines. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in progress > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295572#295572 > > > ________________________________________________________________________________
Date: Apr 24, 2010
engine That all makes sense. Just couldn't think it through. Thanks! Bob Turner wrote: > > Depends.... > but most vacuum pump installations generate enough flow to power the gyros even at idle (look at the vacuum pressure gauge, is it in the green?). so if the engine windmills at 1000 rpm or more, and usually it will (depends on the prop, if there's internal damage, etc), then yes, the gyros will work. > > If this wasn't true, then a 172 making a long idle power descent thru the clouds might suddenly find the gyros didn't work! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295576#295576 > > > ________________________________________________________________________________
Date: Apr 24, 2010
Subject: N402RH Fuel sensor location
This is how I mounted it in my RV-10 _http://picasaweb.google.com/lh/photo/IpZAMWzeY7fiT9lprJGZqQ?feat=directlink _ (http://picasaweb.google.com/lh/photo/IpZAMWzeY7fiT9lprJGZqQ?feat=directlink) Rob Hickman N402RH ________________________________________________________________________________
Subject: Re: aerosport overhead console
Date: Apr 24, 2010
When I spoke with Geoff last he mentioned the mold was built around the pink cabin and wasn't sure the differences between pink and green covers. You are probably right, the differences are probably minor and can be filled or corrected. Now just deciding whether I want the overhead or go with something else just for pilot/copilot lighting. I'm trying to justify the idea of lighting, air front/back with overhead. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295604#295604 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Apr 25, 2010
That's pretty similar to how I'm mounting mine. As others have said, alumi num hard lines FWF are bad juju, I went with Bonico SS/Teflon hoses w/fires leeve. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of RobHickman(at)aol.com Sent: Saturday, April 24, 2010 9:02 PM Subject: RV10-List: N402RH Fuel sensor location This is how I mounted it in my RV-10 http://picasaweb.google.com/lh/photo/IpZAMWzeY7fiT9lprJGZqQ?feat=directli nk Rob Hickman N402RH ________________________________________________________________________________
Date: Apr 25, 2010
He was running the Advanced Flight Systems EFIS. It is solid state internal gyros with 1 hour of internal battery backup. no vacuum. Plus it records ALL data for the flight. So he was able to go back after he landed and look at what happened and when. The AFS system is really sweet. The map system shows all private use airports as well, the Garmin maps do not. And as you increase the map display range it declutters as needed. Jim C (N312 - Flying) On Sat, Apr 24, 2010 at 5:13 PM, Bill Mauledriver Watson < MauleDriver(at)nc.rr.com> wrote: > MauleDriver(at)nc.rr.com> > > I realize that the 569JC discussion is over on VAF but I'd like to ask a > question I just realized I don't have a clue about... > > If you lose your engine and the prop is windmilling, does your vacuum pump > still generate enough suck to power the gyros? Or does the horizon just > slowly fall over? (assuming you have vac powered gyros) > > Thanks, > Bill > > Bill Mauledriver Watson wrote: > >> MauleDriver(at)nc.rr.com> >> >> Nick, really, really nice job piloting (period). >> >> Sitting in the virtual cockpit with you, I'm imagining that it must be >> nice not having to transition off a vacuum powered anything when you lost >> power. And the situational awareness of the glass has to be sweet. >> >> Would be curious to hear any thoughts of why there wasn't a fire. >> >> Bill "fully awake this morning" Watson >> 40605 >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: RV-10 QB Fuse & Wings For Sale - Ohio
Date: Apr 25, 2010
Hi Lew, I sold the fuse kit, but still have the QB wings. I was out of town for 6 weeks, haven't done anything to sell the wings. Are still interested? Asking $10,000.00. Thank You, Ed Mueller ed(at)muellerartcover.com 440-458-6006 440-864-6097 Cell On Feb 13, 2010, at 3:41 PM, Lew Gallagher wrote: > > Hey Ed, > > Lew Gallagher here. > > First, I'm sorry to see so many RV-10 projects going on the block > lately. For three years now, I've been helping my friend build his > RV-10 and we're almost at engine start and inspection stage. I've > enjoyed this project so much that I've been collecting parts for a > future build of my own. I now have the tail/empenage kit, cowling/ > spinner, rudder pedals, Whelan lights, etc. So I'm always looking > for additional parts at bargain prices. Am I correct in assuming > when you say you have the wings and fuselage, that the tail/ > empenage is not included? > > I just missed a quick build wing kit here in SC for around $10K a > while back. I doubt if you would sell your kits for what I could > pay -- and you are 600 miles away. However, I would like you to > keep me in mind if you don't get serious offers. Have truck and > cash ... will travel! Also, if you get any inquiries from someone > who has already purchased the slow build kits, but wanted yours > instead -- then I would be interested in picking up their slow > build wing and fuse kits. > > Later, - Lew > > > ----- Original Message ----- From: "ehm6006" <ed(at)muellerartcover.com> > To: > Sent: Saturday, February 13, 2010 2:21 PM > Subject: RV10-List: RV-10 QB Fuse & Wings For Sale - Ohio > > >> >> Finances force sale of RV10 Quickbuild wings and fuselage. >> >> $31,000.00. Delivery immediate. >> >> Like NEW from factory. Inventory done, NO work has been done on >> these. These were built in the original factory, not the new one >> that has seen some problems. Were originally shipped by Partain >> Trucking. >> >> Located in Grafton, Ohio (~25 miles southwest of Cleveland). >> >> Save at least $5,000.00. >> >> Vans Price: $36,135.00 + Crating($1,000.00) + Freight. Delivery >> 3-4 months. >> >> >> Ed Mueller >> Grafton, OH >> 440-458-6006 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=286298#286298 >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: N402RH Fuel sensor location
Date: Apr 25, 2010
I wasn't trying to stir a pot with my post. I was just repeating what a component manufacturer told me just days before this incident happened, which really drove it home for me. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295649#295649 ________________________________________________________________________________
Subject: Emailing: IMG_0661, IMG_0652, IMG_0659, IMG_0660
Date: Apr 25, 2010
Attached are some pictures of the disassembled fuel filter after 265 hours. Although I rinsed the tanks about four times (to remove bits of pro seal) before fueling initially, invisible particles of something (looks and feels like lint) must have been left in the system. There was no impedance to fuel flow but small particles were removed. Based on our findings the need to clean the fuel filter (about 1.5 hours to remove, clean, install and test) should be every 500 hours. ________________________________________________________________________________
Subject: Need more horsepower!!
Date: Apr 25, 2010
QWJvdXQgMmhycyBhbmQgMTVtaW4gYWdvLCBvdXIgYWlycGxhbmUgZ290IDcgbGJzIGFuZCAxNW96 IGhlYXZpZXIuICAgIA0KDQpNZWV0IExhbmRvbi4uLi4uLi4gIEhlJ2xsIHJpZGUgaW4gdGhlIGJh Y2sgc2VhdCBmb3Igbm93LCBtb3ZlIGludG8gdGhlIHJpZ2h0IGluIGEgZmV3IHllYXJzLCB0aGVu IHNsaWRlIGludG8gdGhlIGxlZnQgc2VhdCBzb21ldGltZSBsYXRlci4gDQoNCkFsbCBpcyB3ZWxs IHdpdGggTW9tIGFuZCB0aGUgYmFsbGFzdC4gDQoNClBoaWwNCg0KDQoNCg0K ________________________________________________________________________________
Subject: HS doublers SB
Date: Apr 25, 2010
We use an alternate method of compliance; we inspect at the annual or any encounter with heavy or greater turbulence. Attached are the pictures. ________________________________________________________________________________
Date: Apr 25, 2010
I cleaned mine my first two annuals. The first one was very dirty (90 hours), the second one pretty clean. From what I have seen, 500 sounds like a good number. But, since I don't fly that much, I don't think I will ever see that many hours between annuals and plan to clean it every annual. It is my understanding that the lint is from the filters in the fuel truck. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Sunday, April 25, 2010 12:24 PM Subject: RV10-List: Emailing: IMG_0661, IMG_0652, IMG_0659, IMG_0660 Attached are some pictures of the disassembled fuel filter after 265 hours. Although I rinsed the tanks about four times (to remove bits of pro seal) before fueling initially, invisible particles of something (looks and feels like lint) must have been left in the system. There was no impedance to fuel flow but small particles were removed. Based on our findings the need to clean the fuel filter (about 1.5 hours to remove, clean, install and test) should be every 500 hours. ________________________________________________________________________________
Date: Apr 25, 2010
Dave I have the old AA OH console which I promise you was heavier and MUCH more difficult to fit regardless of the type of canopy one has. I personally believe the OH console is one of the best additions to an RV-10 build for COMFORT, lighting & location to hide wires, O2 etc... Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave Sent: Saturday, April 24, 2010 8:32 PM Subject: RV10-List: Re: aerosport overhead console When I spoke with Geoff last he mentioned the mold was built around the pink cabin and wasn't sure the differences between pink and green covers. You are probably right, the differences are probably minor and can be filled or corrected. Now just deciding whether I want the overhead or go with something else just for pilot/copilot lighting. I'm trying to justify the idea of lighting, air front/back with overhead. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295604#295604 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Apr 25, 2010
Dave the only area that might fit a little different would be the step in the canopy right at the rear of the back doors. That being said I Do not think you would have any problems fitting it to the green canopies. Geoff Geoff Combs President Aerosport Modeling & Design 8090 Howe Industrial Parkway Canal Winchester, Ohio 43110 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, April 25, 2010 6:31 PM Subject: RE: RV10-List: Re: aerosport overhead console Dave I have the old AA OH console which I promise you was heavier and MUCH more difficult to fit regardless of the type of canopy one has. I personally believe the OH console is one of the best additions to an RV-10 build for COMFORT, lighting & location to hide wires, O2 etc... Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave Sent: Saturday, April 24, 2010 8:32 PM Subject: RV10-List: Re: aerosport overhead console When I spoke with Geoff last he mentioned the mold was built around the pink cabin and wasn't sure the differences between pink and green covers. You are probably right, the differences are probably minor and can be filled or corrected. Now just deciding whether I want the overhead or go with something else just for pilot/copilot lighting. I'm trying to justify the idea of lighting, air front/back with overhead. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295604#295604 ________________________________________________________________________________
Date: Apr 25, 2010
Way to go Phil! Must have held your mouth right to get a boy on your first try. I had three beautiful daughters. Can't wait to see Landon kicking tires at the airport with the old man. Gi ve our best to Sara. Congrats to both. Bill and Lynell Gipson Conroe=2C TX Subject: RV10-List: Need more horsepower!! Date: Sun=2C 25 Apr 2010 11:31:39 -0700 From: Phil.Perry(at)netapp.com About 2hrs and 15min ago=2C our airplane got 7 lbs and 15oz heavier. Meet Landon....... He'll ride in the back seat for now=2C move into the ri ght in a few years=2C then slide into the left seat sometime later. All is well with Mom and the ballast. Phil _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_2 ________________________________________________________________________________
Subject: Vixen File
Date: Apr 25, 2010
A Vixen file is the ideal tool for making those little spacers Van uses here and there. Since the end needs to be perpendicular to the axis, you clamp the Vizen file down on your drill press table, chuck the piece of tubing in the drill press chuck and lower it down onto the Vixen file. After that end is finished, measure it for length and reverse the piece in the chuck taking off the necessary amout to get the proper length. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Subject: RV-10 Empennage & tail cone for sale
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Apr 25, 2010
I have a Rv-10 empennage and tailcone for Sale. It was alodined and primed. Excellent craftsmanship. I have more photos on request. Asking 3700.00. Open for reasonable offers. Geoff Combs -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295707#295707 Attachments: http://forums.matronics.com//files/tailcone_1_184.jpg ________________________________________________________________________________
Subject: Re: Need more horsepower!!
Date: Apr 25, 2010
Ditto!!! What was that correct mouth position? Rick On Apr 25, 2010, at 5:41 PM, Bill Gipson wrote: > Way to go Phil! Must have held your mouth right to get a boy on > your first try. I had three beautiful daughters. > > Can't wait to see Landon kicking tires at the airport with the old > man. Give our best to Sara. Congrats to both. > > Bill and Lynell Gipson > Conroe, TX > > > Subject: RV10-List: Need more horsepower!! > Date: Sun, 25 Apr 2010 11:31:39 -0700 > From: Phil.Perry(at)netapp.com > To: rv10-list(at)matronics.com > > About 2hrs and 15min ago, our airplane got 7 lbs and 15oz heavier. > > Meet Landon....... He'll ride in the back seat for now, move into > the right in a few years, then slide into the left seat sometime > later. > > All is well with Mom and the ballast. > > Phil > > > Hotmail is redefining busy with tools for the New Busy. Get more > from your inbox. See how. > > ________________________________________________________________________________
Subject: Door Pins and Guides Q and A - taken from emails
Date: Apr 26, 2010
I thought I would share some questions and answers on door pins and guides taken off emails with permission from Rudi. There are pros and cons for the different pins and guides offered. Builders that have dealt with the vans doors understand easier than new builders who haven't seen the mechanics behind Vans' doors. Rudi, I will be shipping your parts on Wednesday. One question. I now have two types of pins and guides to pick from actually three. I have bullet type SS pins that are hollow with a solid tip and I have bullet type pins that have a small magnet on the end. The hollow ones can have the Van's magnet dropped inside and glued. The bullet type pins go with aluminum or Delrin guides. The threaded portion on all my pins are a 5/16-24 set screw that you threadlock in after installing the magnet. If you want the bullet type that has the magnet on the end, it is already glued on. The other pins I have are on a slant and are hollow but have a solid tip, again making it possible to drop a magnet inside. RUDI: What type works better with the standard Vans Sensors and standard Magnets? Bullet type with magnet on front or slanted with magnet on inside? Sean: Both work good. The slanted pins require you use the Van's magnets that come in your kit. In a perfect world I would try to talk everyone into buying the 180 kit with slanted pins and Delrin guides. Van's had a good idea for the pushrods, they just didn't quite capture the whole plan. Slanted pins work really well because they pull the full 7/16 of the material. When you try a bullet type it will only pull half of the bullet or 7/32. Van's pushrods have the problem of being hollow tipped which catches their delrin guides or their original UHMW guides. I have seen builders' doors actually cut into their guides. One door that fell off was because the pilot thought the door was closed because the hollow tip was pressed into the plastic guide and later (in flight) failed and opened the door and there it went. My latch pulls the center of the door and really helps the pins into the guides. If your seal is super tight, your door will flex at the fwd and aft where the pins exit the door and enter the guides. The slanted pins are easier to line up because of the full 7/16 advantage. They only work well with the Delrin guide blocks I make. Since you have the 180 kit I recommend the slanted pins and Delrin guides, up to you. With the slanted pins you have to "clock" the position to pull the door down and in like the vans original pushrod ends. This is done by filing the end of the pushrod until the pins line up to your preference. I know it is kind of weird to have so many options but I am getting a feel to see want everyone wants/likes. RUDI: Why does the slanted pins only work with the Delrin guide block? Sean: The shape of the slant makes it rub and catch on the aluminum as it pulls into the guides. I believe it is because the oval on the slant acts as a small rod and enlarges as it pulls into the guide. Metal on metal. That's why Van's pushrods won't work on aluminum guides. Aluminum gulls on aluminum. RUDI: Why do you recommend the slanted pins with the 180 kit? Sean: Partially answered above, but also because the pins extend so far and engage through the frame of the aircraft. With 90 degree kits and Van's original doors it is hard for some builders to get the pin extended past the Delrin. I like to see the pins through the cabin frame and aluminum structure instead of just the Delrin guide. That is why a lot of builders prefer the bullet type pins and aluminum guides on the 90 degree kits or original equipment. Sean: Hope this helps. Let me know if you have any more questions. If you don't mind I may want to post this Q and A on Matronics or VAF. I like people to know pros and cons to each pin and guide. Thanks Sean Strasburg www.planearound.com -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295738#295738 ________________________________________________________________________________
Date: Apr 26, 2010
One other comment. The pins should be about 1/2 inch longer and cut to size by the builder. Depending on where the latch mechanism is located within the recess, Vans standard pins can be too short and not place the full circumference within the metal door frame when engaged. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Monday, April 26, 2010 6:13 AM Subject: RV10-List: Door Pins and Guides Q and A - taken from emails I thought I would share some questions and answers on door pins and guides taken off emails with permission from Rudi. There are pros and cons for the different pins and guides offered. Builders that have dealt with the vans doors understand easier than new builders who haven't seen the mechanics behind Vans' doors. Rudi, I will be shipping your parts on Wednesday. One question. I now have two types of pins and guides to pick from actually three. I have bullet type SS pins that are hollow with a solid tip and I have bullet type pins that have a small magnet on the end. The hollow ones can have the Van's magnet dropped inside and glued. The bullet type pins go with aluminum or Delrin guides. The threaded portion on all my pins are a 5/16-24 set screw that you threadlock in after installing the magnet. If you want the bullet type that has the magnet on the end, it is already glued on. The other pins I have are on a slant and are hollow but have a solid tip, again making it possible to drop a magnet inside. RUDI: What type works better with the standard Vans Sensors and standard Magnets? Bullet type with magnet on front or slanted with magnet on inside? Sean: Both work good. The slanted pins require you use the Van's magnets that come in your kit. In a perfect world I would try to talk everyone into buying the 180 kit with slanted pins and Delrin guides. Van's had a good idea for the pushrods, they just didn't quite capture the whole plan. Slanted pins work really well because they pull the full 7/16 of the material. When you try a bullet type it will only pull half of the bullet or 7/32. Van's pushrods have the problem of being hollow tipped which catches their delrin guides or their original UHMW guides. I have seen builders' doors actually cut into their guides. One door that fell off was because the pilot thought the door was closed because the hollow tip was pressed into the plastic guide and later (in flight) failed and opened the door and there it went. My latch pulls the center of the door and really helps the pins into the guides. If your seal is super tight, your door will flex at the fwd and aft where t! he pins exit the door and enter the guides. The slanted pins are easier to line up because of the full 7/16 advantage. They only work well with the Delrin guide blocks I make. Since you have the 180 kit I recommend the slanted pins and Delrin guides, up to you. With the slanted pins you have to "clock" the position to pull the door down and in like the vans original pushrod ends. This is done by filing the end of the pushrod until the pins line up to your preference. I know it is kind of weird to have so many options but I am getting a feel to see want everyone wants/likes. RUDI: Why does the slanted pins only work with the Delrin guide block? Sean: The shape of the slant makes it rub and catch on the aluminum as it pulls into the guides. I believe it is because the oval on the slant acts as a small rod and enlarges as it pulls into the guide. Metal on metal. That's why Van's pushrods won't work on aluminum guides. Aluminum gulls on aluminum. RUDI: Why do you recommend the slanted pins with the 180 kit? Sean: Partially answered above, but also because the pins extend so far and engage through the frame of the aircraft. With 90 degree kits and Van's original doors it is hard for some builders to get the pin extended past the Delrin. I like to see the pins through the cabin frame and aluminum structure instead of just the Delrin guide. That is why a lot of builders prefer the bullet type pins and aluminum guides on the 90 degree kits or original equipment. Sean: Hope this helps. Let me know if you have any more questions. If you don't mind I may want to post this Q and A on Matronics or VAF. I like people to know pros and cons to each pin and guide. Thanks Sean Strasburg www.planearound.com -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295738#295738 ________________________________________________________________________________
Date: Apr 26, 2010
Subject: Re: Vixen File
Nice! Wish I knew/thought of that before now. thanks. Albert Gardner wrote: > *A Vixen file is the ideal tool for making those little spacers Van uses here and there. Since the end needs to be perpendicular to the axis, you clamp the Vizen file down on your drill press table, chuck the piece of tubing in the drill press chuck and lower it down onto the Vixen file. After that end is finished, measure it for length and reverse the piece in the chuck taking off the necessary amout to get the proper length. * > *Albert Gardner* > *N991RV* > *Yuma, AZ* > * * > * > > > * ________________________________________________________________________________
Date: Apr 26, 2010
Subject: First Flight for kit 40214
All... - After 6 years of balancing work and plane building, kit 40214 (N4959S) left the ground for the first time yesterday.-It climbed like a champ and we were at 800 feet by the time we hit the end of the runway.-The flight was uneventful with engine-temperatures staying where they should and the pl ane flying true and level. - Many thanks to my good friend Robin Marks for the encouragement to keep at it even when I was trapped at work 7 days a week.- Robin also tied me up with an A&P that could help solve the wiring problems that Accuracy Avionic s created in the panel that they built for the plane.- My OP Technologies EFIS is now talking properly to the engine monitor and the air data comput er.- Most of the function on the OP seem to be operating properly, but th ere are a couple of questions that I will have for the OP group. - I have an appointment with GLO Customs for paint in late June and and will post photos once it is out of the paint shop. - It sure feels good to finally have it in the air!!! - ...Jearl Strickland - ps..Robin, I opened the bottle of 1822 Madeira for Ken, my son and I to cel ebrate.- We need to get together later this week and work on reducing the volume further!=0A=0A=0A ________________________________________________________________________________
Date: Apr 26, 2010
Subject: g;ideslope capture
Slowly, oh so slowly, working my way through the GRT/430W/SL30/TRUTRACK set up menus. I now have everything talking nicely to each other and most everything seems to be working except for one interesting problem. Both the 430 and SL30 capture the localizer well (10-15 miles out), and the 430 captures the glideslope at the usual distance, but the SL-30 only picks up the glideslope when I am very close in (like one mile). Dispite the SL30 capturing the localizer could this still be an antennae problem (mine are Archers in the wing tips)? I could reverse the ants. to see what that does but it would be a lot of work because of the coaxial routing. Any suggestions? Jay Rowe #40301 (flying with 50 hours). ________________________________________________________________________________
Subject: Vixen File
Date: Apr 26, 2010
Me too! > Date: Mon=2C 26 Apr 2010 10:21:34 -0400 > From: MauleDriver(at)nc.rr.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Vixen File > rr.com> > > Nice! Wish I knew/thought of that before now. > > thanks. > > Albert Gardner wrote: > > *A Vixen file is the ideal tool for making those little spacers Van use s here and there. Since the end needs to be perpendicular to the axis=2C yo u clamp the Vizen file down on your drill press table=2C chuck the piece of tubing in the drill press chuck and lower it down onto the Vixen file. Aft er that end is finished=2C measure it for length and reverse the piece in t he chuck taking off the necessary amout to get the proper length. * > > *Albert Gardner* > > *N991RV* > > *Yuma=2C AZ* > > * * > > * > > > > > > * > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
From: "John Erickson" <rv10builder(at)ericksonjc.com>
Date: Apr 26, 2010
Jay, You are using separate antenna for the 430 and the SL-30, correct? (With a splitter for the 430 since it requires separate GS and LOC inputs if I remember correctly?) One fairly easy test would be to swap the coax from the splitter input to the SL-30 and the SL-30 to the splitter (ie using the "other" antenna for the other receiver.) This will tell you if the issue is in the box or downstream. Assuming it's downstream, I'd look at bad coax crimps. The antenna is a fairly simple device and as long as everything is screwed in, I can't really see much going wrong... The crimps on the other hand could easily be creating problems that could easily be more apparent on one frequency band than another... Good Luck, John #40208 Wings (Still) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jfrjr(at)roadrunner.com Sent: Monday, April 26, 2010 8:26 AM Subject: RV10-List: g;ideslope capture Slowly, oh so slowly, working my way through the GRT/430W/SL30/TRUTRACK set up menus. I now have everything talking nicely to each other and most everything seems to be working except for one interesting problem. Both the 430 and SL30 capture the localizer well (10-15 miles out), and the 430 captures the glideslope at the usual distance, but the SL-30 only picks up the glideslope when I am very close in (like one mile). Dispite the SL30 capturing the localizer could this still be an antennae problem (mine are Archers in the wing tips)? I could reverse the ants. to see what that does but it would be a lot of work because of the coaxial routing. Any suggestions? Jay Rowe #40301 (flying with 50 hours). ________________________________________________________________________________
Date: Apr 26, 2010
Jearl, That is terrific news. I sure wish I was in town to witness the big event. I am positive you will have little to work out between now and the end of your Phase 1. It is fantastic to add another flying -10 to the fleet and even better to have one at our airport built & piloted by such a nice and talented person with a wonderful family. I look forward to some loose formation flying and air to air photo sessions and heck maybe even some cross country trips. Clear skies, Robin, Nova & Hannah *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Mr Luther Strickland *Sent:* Monday, April 26, 2010 8:32 AM *To:* rv10-list(at)matronics.com *Subject:* RV10-List: First Flight for kit 40214 All... After 6 years of balancing work and plane building, kit 40214 (N4959S) left the ground for the first time yesterday. It climbed like a champ and we were at 800 feet by the time we hit the end of the runway. The flight was uneventful with engine temperatures staying where they should and the plane flying true and level. Many thanks to my good friend Robin Marks for the encouragement to keep at it even when I was trapped at work 7 days a week. Robin also tied me up with an A&P that could help solve the wiring problems that Accuracy Avionics created in the panel that they built for the plane. My OP Technologies EFIS is now talking properly to the engine monitor and the air data computer. Most of the function on the OP seem to be operating properly, but there are a couple of questions that I will have for the OP group. I have an appointment with GLO Customs for paint in late June and and will post photos once it is out of the paint shop. It sure feels good to finally have it in the air!!! ...Jearl Strickland ps..Robin, I opened the bottle of 1822 Madeira for Ken, my son and I to celebrate. We need to get together later this week and work on reducing the volume further! * * * * * * ________________________________________________________________________________
Subject: Re: g;ideslope capture
Date: Apr 26, 2010
You didn't use any splitter on the SL-30 input, right? It has an internal one. I'd try to get a short length of coax, and a female to female adaptor, to temporarily splice the known good antenna to the SL-30. If the problem persists, then you know it's internal to the SL-30. Maybe a bad internal splitter, or something else. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295762#295762 ________________________________________________________________________________
Date: Apr 26, 2010
That's exactly what I would recommend. Isolate the problem and then narrow it down until you find the cause. Ideally, you would actually switch the antennas, like you said you didn't want to do because of the coax. Another option would be to find someone who has another SL-30 that you could slide into your tray and see if the problem is the radio or the wiring. If you are getting the Loc signal at the same distance on both radios, but the glideslope is not the same, then my thoughts would be something in the radio, which would be solved by swapping radios with someone. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Apr 26, 2010, at 2:11 PM, Bob Turner wrote: > > You didn't use any splitter on the SL-30 input, right? It has an internal one. > I'd try to get a short length of coax, and a female to female adaptor, to temporarily splice the known good antenna to the SL-30. If the problem persists, then you know it's internal to the SL-30. Maybe a bad internal splitter, or something else. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=295762#295762 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 26, 2010
Subject: glide slope capture
Thanks all for the advice--good as always. I'll do the coax switch to isolate the gremlin (SL30 or ant). Crimping doesn't seem to be the problem since the localizer comes in "loud and clear". Jay ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Apr 26, 2010
Subject: Aftermarket Rudder Stops?
Has anyone seen a plastic-type rudder stop alternative? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: Apr 26, 2010
Yep... Oh, you probably want to know where too. :^) http://www.vansairforce.com/community/showthread.php?t=56277 I bought one, but haven't installed it yet. Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Monday, April 26, 2010 4:17 PM Subject: RV10-List: Aftermarket Rudder Stops? Has anyone seen a plastic-type rudder stop alternative? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: Apr 26, 2010
Subject: Re: Door Pins and Guides Q and A - taken from emails
I switched my door pins and blocks to the slanted design using the delrin blocks and they work great. The slanted pin uses a threaded rod that can be removed so you can glue the stock magnets inside of them giving you a clean finish. As for clocking them, it was pretty simple. I would just make a mark and then use the 6" 3M wheel to file down the rod until it was perfect and loctite it. I am using the stock Van's seal which requires more compression than some of the other aftermarket systems. I wanted as much early engagement of the pin as I could possibly get. I'll get some pictures and more video tonight so you can see this system in action. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________ From: DLM <dlm46007(at)cox.net> Sent: Mon, April 26, 2010 8:32:42 AM Subject: RE: RV10-List: Door Pins and Guides Q and A - taken from emails One other comment. The pins should be about 1/2 inch longer and cut to size by the builder. Depending on where the latch mechanism is located within the recess, Vans standard pins can be too short and not place the full circumference within the metal door frame when engaged. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Monday, April 26, 2010 6:13 AM Subject: RV10-List: Door Pins and Guides Q and A - taken from emails I thought I would share some questions and answers on door pins and guides taken off emails with permission from Rudi. There are pros and cons for the different pins and guides offered. Builders that have dealt with the vans doors understand easier than new builders who haven't seen the mechanics behind Vans' doors. Rudi, I will be shipping your parts on Wednesday. One question. I now have two types of pins and guides to pick from actually three. I have bullet type SS pins that are hollow with a solid tip and I have bullet type pins that have a small magnet on the end. The hollow ones can have the Van's magnet dropped inside and glued. The bullet type pins go with aluminum or Delrin guides. The threaded portion on all my pins are a 5/16-24 set screw that you threadlock in after installing the magnet. If you want the bullet type that has the magnet on the end, it is already glued on. The other pins I have are on a slant and are hollow but have a solid tip, again making it possible to drop a magnet inside. RUDI: What type works better with the standard Vans Sensors and standard Magnets? Bullet type with magnet on front or slanted with magnet on inside? Sean: Both work good. The slanted pins require you use the Van's magnets that come in your kit. In a perfect world I would try to talk everyone into buying the 180 kit with slanted pins and Delrin guides. Van's had a good idea for the pushrods, they just didn't quite capture the whole plan. Slanted pins work really well because they pull the full 7/16 of the material. When you try a bullet type it will only pull half of the bullet or 7/32. Van's pushrods have the problem of being hollow tipped which catches their delrin guides or their original UHMW guides. I have seen builders' doors actually cut into their guides. One door that fell off was because the pilot thought the door was closed because the hollow tip was pressed into the plastic guide and later (in flight) failed and opened the door and there it went. My latch pulls the center of the door and really helps the pins into the guides. If your seal is super tight, your door will flex at the fwd and aft where t! he pins exit the door and enter the guides. The slanted pins are easier to line up because of the full 7/16 advantage. They only work well with the Delrin guide blocks I make. Since you have the 180 kit I recommend the slanted pins and Delrin guides, up to you. With the slanted pins you have to "clock" the position to pull the door down and in like the vans original pushrod ends. This is done by filing the end of the pushrod until the pins line up to your preference. I know it is kind of weird to have so many options but I am getting a feel to see want everyone wants/likes. RUDI: Why does the slanted pins only work with the Delrin guide block? Sean: The shape of the slant makes it rub and catch on the aluminum as it pulls into the guides. I believe it is because the oval on the slant acts as a small rod and enlarges as it pulls into the guide. Metal on metal. That's why Van's pushrods won't work on aluminum guides. Aluminum gulls on aluminum. RUDI: Why do you recommend the slanted pins with the 180 kit? Sean: Partially answered above, but also because the pins extend so far and engage through the frame of the aircraft. With 90 degree kits and Van's original doors it is hard for some builders to get the pin extended past the Delrin. I like to see the pins through the cabin frame and aluminum structure instead of just the Delrin guide. That is why a lot of builders prefer the bullet type pins and aluminum guides on the 90 degree kits or original equipment. Sean: Hope this helps. Let me know if you have any more questions. If you don't mind I may want to post this Q and A on Matronics or VAF. I like people to know pros and cons to each pin and guide. Thanks Sean Strasburg www.planearound.com -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=295738#295738 ________________________________________________________________________________
Date: Apr 26, 2010
Subject: Re: Aftermarket Rudder Stops?
Thanks, Bob. Just what I was looking for. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Mon, Apr 26, 2010 at 2:25 PM, Bob Leffler wrote: > Yep=85=85=85 > > > Oh, you probably want to know where too. :^) > > > http://www.vansairforce.com/community/showthread.php?t=56277 > > > I bought one, but haven=92t installed it yet. > > > Bob > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Dave Saylor > *Sent:* Monday, April 26, 2010 4:17 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Aftermarket Rudder Stops? > > > Has anyone seen a plastic-type rudder stop alternative? > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Apr 27, 2010
Subject: Oshkosh Trailer
Hi all, I have a trailer that I was going to rent for the week of Oshkosh but we ended up buying one and plan on bringing it out this year. It is a nice trailer and I can send pictures. It is $1200 for the week. He will set it up for you at Oshkosh. I have rented a trailer the past 5 years and it is a great way to go to Oshkosh. You fly in, your trailer is waiting for you and you can enjoy the campground with all the activities that occur at night. Shoot me an e-mail if you are interested and I can send pictures and the name of the individual. Thanks. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Date: Apr 28, 2010
Subject: OT - I can do that!
Right up until they started painting I was thinking, "I can do that!" http://www.breitbart.tv/florida-one-video-documents-creation-of-new-southwest-jet/ PAINT.... AHHHHHHHHH! Bill ________________________________________________________________________________
Date: Apr 28, 2010
I keep telling you, Bill. I've painted my last aircraft. The RV-10 will go to a professional paint shop, where they've got all the lighting in the paint booth (did you notice the lighting they were using in that video? Lighting is crucial for a good paint job). Give up while there's still time... Jack Phillips #40610 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Mauledriver Watson Sent: Wednesday, April 28, 2010 11:02 AM Subject: RV10-List: OT - I can do that! Right up until they started painting I was thinking, "I can do that!" http://www.breitbart.tv/florida-one-video-documents-creation-of-new-southwes t-jet/ PAINT.... AHHHHHHHHH! Bill ________________________________________________________________________________
Subject: Re: Swivel Overhead LED cabin lights
Date: Apr 29, 2010
Here is my Aerosport overhead. I am installing two Aveoflash Eyebeams that can turn red or white by touch and also has intensity. I made the angled piece by cutting the aluminum and welding a strip in then filling it in with fiberglass. The Eyebeams scratch easy so I had them send me two new coverplates. I will be buying some protective film to cover the new ones like the film on an iphone. I tried them out and they work great. Two of them cover the entire panel and make it possible to have two lights instead of four. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296148#296148 Attachments: http://forums.matronics.com//files/overhead2_999.jpg http://forums.matronics.com//files/overhead1_151.jpg ________________________________________________________________________________
Date: Apr 29, 2010
Subject: For Sale Garmin 296
Seeing the demand for the Garmin 496 I went to the hangar to pull out my gently used Garmin 296 in excellent condition with several accessories. Package includes: =B7 Garmin 296 =B7 Garmin Face Cover =B7 Yolk Mount (plus Bracket) =B7 Suction Style RAM Mount (plus Bracket) =B7 Dash Mount =B7 12V Power Adapter =B7 USB Cable =B7 External GPS Antenna =B7 Fabric Case What it is missing: Attached Antenna (unit was hard mounted in my RV-6A so no need for antenna-Sorry, can=92t locate) Comes with External GPS Antenna Price $625.00 Free US Shipping Extras: =B7 12V Power Adapter =B7 120V AC Charger =B7 Price $25.00 Free US Shipping Robin Robin(at)PaintTheWeb.com 805.801.8550 ________________________________________________________________________________
Date: Apr 29, 2010
I used lights that are in the Cirrus. Their price was $25.00 each. They come with 24volt incandescent lights. I changed the bulbs to Chevy side marker bulbs so they would work on my 12volt system. I am looking into changing the bulbs to LED. The lights matched the vents I am using with the air conditioning. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296178#296178 Attachments: http://forums.matronics.com//files/cirrus_lights_795.jpg ________________________________________________________________________________
Date: Apr 29, 2010
Just a word about your plan. Look at your sun visor and see what kind of ro om you'll have in that area. If your OVH hangs down a lot you will sacrific e with sun visor being low at times. Rosans are pretty big. Patrick Thyssen --- On Thu, 4/29/10, Strasnuts wrote: From: Strasnuts <sean(at)braunandco.com> Subject: RV10-List: Re: Swivel Overhead LED cabin lights Date: Thursday, April 29, 2010, 12:02 PM Here is my Aerosport overhead.- I am installing two Aveoflash Eyebeams th at can turn red or white by touch and also has intensity.- I made the ang led piece by cutting the aluminum and welding a strip in then filling it in with fiberglass.- The Eyebeams scratch easy so I had them send me two ne w coverplates.- I will be buying some protective film to cover the new on es like the film on an iphone.- I tried them out and they work great.- Two of them cover the entire panel and make it possible to have two lights instead of four. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296148#296148 Attachments: http://forums.matronics.com//files/overhead2_999.jpg http://forums.matronics.com//files/overhead1_151.jpg le, List Admin. ________________________________________________________________________________
Date: Apr 29, 2010
Good point. I would think that installing them further back where I installed mine would give more room away from the visors than the commonly mounted red lights fwd on the console. I don't know I will have to look at that. I guess there are pros and cons. Hard to adjust if they are in front of the visors and hard to point to the panel if behind it???? -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296192#296192 ________________________________________________________________________________
Subject: G3 ignition systems
Date: Apr 29, 2010
I receive a newsletter called Central States and it is for Canard airplanes . I was reading a writup about an electronic ignition system www.g3ignition .com I don't claim to know much about any of the systems=2C but what I have read in the writeup and on the web site looks good. I also spoke to the owner o f the company. I like the redundancy in the event the power is lost it reve rts back to the normal rt and lf magnito mode. When I spoke to Rhonda at Barret a while back she was saying that they were not using Lightspeed because of factory support issues. Does anyone have any experience with this system(G3i) Thanks=2C John Gonzalez=2C 409 ________________________________________________________________________________
Date: Apr 29, 2010
There is another good write up by Larry Vetterman on his web site. Look at the bottom of the page (http://www.vettermanexhaust.com/) under the title Results of (3) Exhaust System Tests Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Thursday, April 29, 2010 3:08 PM Subject: RV10-List: G3 ignition systems I receive a newsletter called Central States and it is for Canard airplanes. I was reading a writup about an electronic ignition system www.g3ignition.com I don't claim to know much about any of the systems, but what I have read in the writeup and on the web site looks good. I also spoke to the owner of the company. I like the redundancy in the event the power is lost it reverts back to the normal rt and lf magnito mode. When I spoke to Rhonda at Barret a while back she was saying that they were not using Lightspeed because of factory support issues. Does anyone have any experience with this system(G3i) Thanks, John Gonzalez, 409 ________________________________________________________________________________
Date: Apr 29, 2010
Subject: Rob Hickman's RV-10
Surprised no one has mentioned the big spred given the RV-10 and Rob's airplane in this month's KitPlanes. ________________________________________________________________________________
Subject: Re: G3 ignition systems
Date: Apr 29, 2010
I'm installing it. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: John Gonzalez To: RV 10 group Sent: Thursday, April 29, 2010 2:08 PM Subject: RV10-List: G3 ignition systems I receive a newsletter called Central States and it is for Canard airplanes. I was reading a writup about an electronic ignition system www.g3ignition.com I don't claim to know much about any of the systems, but what I have read in the writeup and on the web site looks good. I also spoke to the owner of the company. I like the redundancy in the event the power is lost it reverts back to the normal rt and lf magnito mode. When I spoke to Rhonda at Barret a while back she was saying that they were not using Lightspeed because of factory support issues. Does anyone have any experience with this system(G3i) Thanks, John Gonzalez, 409 ________________________________________________________________________________
Subject: Van's stock bottom cowl vents
Date: Apr 30, 2010
Has anyone used a different vent system for the bottom cowl? I have seen the added side vents, but has anyone used these for the bottom in place of Van's stock vents. Dave Leikam RV-10 #40496 N89DA (Reserved) Muskego, WI ________________________________________________________________________________
Date: Apr 30, 2010
Subject: Re: Van's stock bottom cowl vents
Yup, Here's what I did, to avoid messing up the paint job on the side of the cowl. http://deemsrv10.com/album/Phase1/slides/DSC07581.html http://deemsrv10.com/album/Phase1/slides/DSC07554.html The next question will be how much did it help w/ heat removal: Andwer: ...not enough. Deems Davis N519PJ www.deemsrv10.com On 4/30/2010 12:35 PM, Dave Leikam wrote: > Has anyone used a different vent system for the bottom cowl? I have > seen the added side vents, but has anyone used these for the bottom in > place of Van's stock vents. > Dave Leikam > RV-10 #40496 > N89DA (Reserved) > Muskego, WI > * > > > * ________________________________________________________________________________
Subject: Rudder trim de nuevo
Date: May 01, 2010
I have always liked the idea of a mechanical and tabless rudder trim rather than a servo/tab. Does anyone have any experience or feedback on the "skunkworks" spring bias rudder trim kit? I have ordered it, but yet to receive it. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296388#296388 ________________________________________________________________________________
Date: May 01, 2010
For another data point I LOVE my servo driven rudder tab operated by my thumb on the infinity grip. Use it all the time to keep the ball centered. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Saturday, May 01, 2010 12:00 PM Subject: RV10-List: Rudder trim de nuevo I have always liked the idea of a mechanical and tabless rudder trim rather than a servo/tab. Does anyone have any experience or feedback on the "skunkworks" spring bias rudder trim kit? I have ordered it, but yet to receive it. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296388#296388 ________________________________________________________________________________
Subject: Re: Rudder trim de nuevo
Date: May 01, 2010
Hey Myron, We put this system in Wes's RV-10. He's limited to 35 miles radius during fly-off, so not much chance to really test the trim at altitude and cruise speed yet, but he says he's played with it a little and it does what it's supposed to. So far, he says the plane flies so balanced that he doesn't really need it yet. I like it for the same reasons you do -- clean rudder, simple mechanics. Also, it takes out the "slack cable" effect. I REALLY would recommend that you install this early in your panel build if you know where it's going -- we added it later and it involves upside down mumbling, but it can be done. We ended up putting it to the right of center just because we didn't plan for it and that's where it fit. Pay attention to the direction you wrap the cables, and which one goes to what pedal so that when you roll the knob to the right, you get right trim, etc. You might want to ask about the springs for the -10. I think they probably sent the stronger ones if you ordered it for the -10, but there is more friction in the cables than you'd think; the trim knob will not move the rudder playing with it on the ground, but apparently holds it where you put it in flight. They do mention stronger springs for the -10. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Nine hours fly off completed and counting! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296411#296411 ________________________________________________________________________________
Date: May 01, 2010
Oh, yeah. You might want to brace the bottom of the lower panel where you mount it -- the tension tends to flex it. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Nine hours fly off completed and counting! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296413#296413 ________________________________________________________________________________
Date: May 01, 2010
Subject: RV Transition Training w/ Mike Seager - Day 1 - Getting There...
The trip to Vernonia Oregon was pleasantly uneventful and rather relaxing, actually. The Flight on Horizon Air was smooth and the plane left Oakland Airport right on time and even arrived at Portland Airport 10 minutes early. I was also pleasantly surprised that the Enterprise rental car establishment at the airport had a brand new 2010 Chevy Camero's in the fleet. I've been wanting to drive one since they came out and quickly exchanged my "luxury car" reservation for the sweet, Silver number seen in the pictures. Its a very nice car. Plenty of power, handles reasonably well although it tends to over-steer in the corners, rides well, and has a "very nice" factory sound system. The system has XM radio support, but Enterprise doesn't maintain a subscription to the service which is a big-old fat bummer in my opinion. FM radio is a jungle; ack. Anyway, back to the trip... It was around 2pm by the the time I got on the road, so my belly was telling me it was time for a refill. I noticed this nice looking place along the highway called Rose's Restaurant and Bakery and it sounded like what I was in the mood for, and it turned out my hunch was right. I ordered a big 'ol greasy BBQ cheese burger that was as big as a mountain and very tasty. They have some awesome looking deserts there too, but I resisted. I don't know why I resisted, mind you... Just as I was leaving, the sun turned to dark gray clouds and then it just started to hail like crazy! It was pretty cool. It was about an hour and a half drive from the Portland Airport out to Vernonia. Along the way, I snapped a couple of pictures of a sweet glider airport by the highway. The green fields with the airplanes in the background was quite a sight. I thought wistfully of the RV-8 trapped in the hangar back at home... Once you turn off the main highway heading towards Vernonia proper, the scenery is quite spectacular. The filtered sun through the various clouds and patches of rain made the trip just that much more enjoyable. Well, that and the purr of the Camero's V8. I'm just saying... I rolled into Vernonia and the Garmin GPS that came with the car took me right up to the front door of the Rockcreek Bed & Breakfast. What a lovely place! The pictures of the interior are the living quarters for the guest. There's just the one bedroom, so I pretty much had the run of the areas shown. The owners live in the back half of the house, but the two areas are divided and so the guest's front half is very private. Patricia Davis, the curator of the Rockcreek B&B was very nice and made sure everything was just right. She promised a big breakfast in the morning with all of my favorite things, so I'm looking forward to that!! :-) If you're coming to Vernonia for your transition training with Mike Seager, you own it to yourself to stay here at the Rock Creek B&B. You won't be sorry. The accommodations are outstanding and the price is very reasonable. Here is their web site: http://www.rockcreekbb.com/ After I got settled in, I drove out to the Vernonia airport and looked around until I found Mike's hanger. I knocked on the door and found him there still and we had a nice conversation and he showed me his Model T restoration project. Very cool! I'll have to get some pictures of it tomorrow. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Date: May 01, 2010
Subject: RV Transition Training w/ Mike Seager - Day 2 - Sessions 1
& 2... As luck would have it, Thursday morning it was raining in Vernonia Oregon. Go figure. After a wonderful breakfast at the Rock Creek B&B, I headed out to the Vernonia airport to meet with Mike Seager at 10am for my first RV transition training lesson. We spent the first hour in the office for some "chalk-talk" all about RVs. Mike went over RV speeds, attitudes (the airplane's, not the pilot's, btw), and other things related to flying an RV safely. It was a very good primer on the RV. By now, it was only raining "a little bit", so we headed out to N477RV, an RV-7, and hopped in. We took off to the West, with a fairly stiff wind. I nice left hand turn and we headed out toward Scappoose. Mike took me though some aircraft handling such as turns and climbs and descents and got me used to the flight controls on the RV. As is typical with most new RV pilots, I was over-controlling some. The air was *really* bumpy and I was really working hard to keep the plane level with all the turbulence. Then Mike showed me how to just let the plane fly itself though those bumps by relaxing my grip and not constantly over-correcting. Wow! That's was a lot easier! We headed over to the Scappoose airport and set up to shoot some landings. There was a "nice", almost 90 degree cross wind there to go with all of the turbulence, so it was quite a work out both as a pilot and on my stomach. I didn't barf, but I sure wanted to... After 6 stop and go landings at Scappoose, we headed back to the Vernonia airport. Mike has been restoring a 1923 Model T Ford and he decided that he was going to take it home for lunch that day. What a sweet car! Friday afternoon he even took me for a ride! Considering they started making Model T's around 1907, it rode surprising well. With the fully enclosed cabin and heater, it must have seemed like a space-ship compared to the horse and buggy that most were still using at the time. The little car has an amazing amount of power. There are a myriad of levers and pedals that must be negotiated to drive the thing. Most peculiar is that fact that the throttle is not a pedal, but rather a lever on the steering column that kind of looks like a turn signal. Mike's also been into Radio Control model airplanes and has a number of them hanging from the ceiling in his hanger. Some of them were simply massive and frankly looked like you could put the family cat or dog on one and take them for a ride of a life time. In the afternoon, I headed back out the Vernonia airport at 3PM for my second lesson. The weather was better, but the report for Scappoose was for even more wind than in the morning. So, we headed out to the McMinville airport South of Vernonia about 15 minutes by RV. http://www.macairclub.com/Welcome.html McMinville is where the Spruce Goose is now stored and there is a large aircraft museum there. The wind was fairly calm at McMinville and so we did about 12 stop and go landings and then headed back the Vernonia airport. BTW, the Vernonia airport has a large hill on the East end of the field and so you have to sort of fly a dog leg around the hill and then straighten out right at the last minute to land on the grass strip. By the end of Friday, I had it down! Mike said, if you can land at Vernonia, you can land anywhere! :-) After the second lesson on Thursday, I headed down to Hillsboro to meet some long time RV-buddies at the Rock Creek Tavern. Don Wentz and Jerry Springer were there and I met a new RV-buddy named Ryan along with his wife and daughter. The Rock Creek Tavern is quite a place with lots of atmosphere and even a live band on a Thursday night. The giant BBQ cheese burger was nothing short of awesome. By the time I got home, I was bushed. The giant, comfortable bed at the Rock Creek B&B felt so good. I didn't wake up until 8 the next morning! - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Date: May 01, 2010
Subject: RV Transition Training w/ Mike Seager - Day 3 - Session 3...
Friday morning I headed back out to the Vernonia airport for lesson number 3. Mike asked me if I'd like to fly the RV-6A this time since it has a constant speed prop similar to what my RV-8 has. The RV-7 we'd flown the day before has a fixed pitch prop. Some constant-speed time sounded like a great idea, so we piled in and took off. I'm really glad that I got some time in the tricycle gear version of the RV as well. I would seem that it would be just like the tail wheel version, but easier. In reality, however, landing and taking off are different propositions and Mike took me though the steps. I'm also glad that I got the training with the constant-speed prop. The angle of decent on final approach is significantly greater with the CS prop and its somewhat disconcerting to be pointing the airplane's nose that far down on final. Its definitely not a flat approach ala a Cessna 172 or even like the Citibrias I've been flying. We flew out towards Scappoose and did some slow flight and climbing turns along with some power off and power on stalls. I was amazed at how far up you have to point the nose on the RV to get it to stall with full power. Way up. I mean WAY up. The stalls were gentle and predictable, but that second stall if you don't get the nose pushed down far enough was a little weird. Other than that, the stall handling and recovery were pretty text-book. We headed over to Scappoose and shot about 8 stop and go landings. Again, kind of a stiff cross wind, but there wasn't too much turbulence so that was good. After that, we headed back to Vernonia and I made a pretty good landing on the grass strip! I didn't get any pictures of the RV-6A we flew today, but attached are some additional pictures of the RV-7 I was flying. - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Date: May 01, 2010
Subject: RV Transition Training w/ Mike Seager - Day 3 - Session 4...
By the time the afternoon session on Friday rolled around, the weather was looking pretty good. Still cloudy, but clouds were fairly high - around 3500ft - and the wind wasn't blowing too bad. We got back in the RV-7 and took off and headed West toward the Astoria airport out on the coast. We shot a number of stop and go landings here and then headed out to the Oregon Coastline proper at about 800 feet. I got some great pictures from plane as we were flying along. It was amazingly beautiful and I commented to Mike that there are very few people that have had the opportunity to experience the beauty of the coastline from that perspective. Spectacular. We shot a full stop landing at the Seaside Airport (56S) and then headed down the coast a bit further to the Nehalem Bay State Airport (3S7) and shot a landing there as well. From there we headed back to Vernonia where I managed to squeak out yet another pretty good landing! All toll across the 2 days and 4 sessions, I flew 6.0 hours with Mike and made 34 takeoffs and landings. I have to say that I feel much more confident now in the RV. I absolutely cannot recommend this experience highly enough to anyone who is getting ready to fly an RV for the first or near the first time. Whether its for an insurance requirement or not, you cannot afford to not take the time to learn the specifics of flying an RV aircraft. Particularly if you only have Cessna or Piper time, but even if you have a fair amount of tail-dragger time in aircraft such as the Citibria like I did. The training is invaluable and frankly a must. I also cannot speak highly enough of Mike Seager. What a pleasure it was flying with him these last two days. His years of experience really shows and his calm, yet firm manner was perfect for the task at hand. If you are about ready to fly your RV, give Mike a call and schedule some time to get checked out. You won't be sorry you did. I told Mike as I was handing him the check for his effort, "You know Mike, this was the best money I've spent on my RV-8 project", and I truly meant that. - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Subject: Cushioned steel loop clamps
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: May 02, 2010
In my TMX- 540 they used cushioned steel loop clamps to hold the fuel lines attached to the valve push rods. I'd like to use the same ones to hold my ignition cables for the LSE in place. Does anyone know where I can get those? The MS numer is MS21333-75. Cheers Michael -------- RV-10 builder (interior,avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296453#296453 ________________________________________________________________________________
Date: May 02, 2010
Subject: Re: Cushioned steel loop clamps
Genuine Aircraft Hardware lists them in their catalog, cushioned and uncushioned in various sizes. http://www.gen-aircraft-hardware.com/ On Sun, May 2, 2010 at 4:37 AM, Michael Wellenzohn wrote: > > In my TMX- 540 they used cushioned steel loop clamps to hold the fuel lines attached to the valve push rods. I'd like to use the same ones to hold my ignition cables for the LSE in place. Does anyone know where I can get those? The MS numer is MS21333-75. > > Cheers > Michael > > -------- > RV-10 builder (interior,avionics, wiring) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=296453#296453 > > ________________________________________________________________________________
Date: May 02, 2010
Adel clamps, cushioned and un-cushioned are available from Aircraft Spruce, Wicks, B&B Aircraft supplies, or from the fly market vendors at SNF and OSH. Jack Phillips #40610 Raleigh, NC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Sunday, May 02, 2010 8:41 AM Subject: Re: RV10-List: Cushioned steel loop clamps Genuine Aircraft Hardware lists them in their catalog, cushioned and uncushioned in various sizes. http://www.gen-aircraft-hardware.com/ On Sun, May 2, 2010 at 4:37 AM, Michael Wellenzohn wrote: > > In my TMX- 540 they used cushioned steel loop clamps to hold the fuel lines attached to the valve push rods. I'd like to use the same ones to hold my ignition cables for the LSE in place. Does anyone know where I can get those? The MS numer is MS21333-75. > > Cheers > Michael > > -------- > RV-10 builder (interior,avionics, wiring) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=296453#296453 > > ________________________________________________________________________________
Date: May 02, 2010
Thanks Kelly that's exactly what I was looking for. Spruce just sells clamps made out of aluminum. Michael -------- RV-10 builder (interior,avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296478#296478 ________________________________________________________________________________
Date: May 02, 2010
Thanks for the info fellers. I will install this thing and report back. It appears simple and cheap. Robin, I can appreciate the ease of the koolie hat. I am trying something different with my stick grips (cutting/modifying the uprights off of a Boeing 737 yoke) and that leaves me PTT, Pitch trim, and A/P disconnect, so no koolie hat for me. BTW, My wife wants to improve the menu for the RV-10 nest at Copperstate, but I told her we still have to have the special krispie treats for you. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296489#296489 ________________________________________________________________________________
Date: May 02, 2010
I'm a big fan of those too. ;-) On Sun, May 2, 2010 at 12:02 PM, woxofswa wrote: > BTW, My wife wants to improve the menu for the RV-10 nest at Copperstate, but I told her we still have to have the special krispie treats for you. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in progress ________________________________________________________________________________
Date: May 02, 2010
Subject: Product Report - iFLYgps700
If you are looking for moving map dispays, i9 found this little gem at Sun n Fun, the iFly GPS 700. It is an inexpensive touch screen driven GPS overlayed on sectional charts. There are NO hard keys anywhere! This is great for VFR pilots, and Nav Data for IFR situational awareness. In addition, it contains all the IFR charts for reference, but the GPS does NOT overlay the approach plates. Total cost is the best part - $499. Data updates are only $69 per YEAR and are done at home on any computer with a USB port as often as needed. Download the latest data (sectionals, approach plates, software) and then plugin to the unit for simple update. This covers all US sectionals, and gives you the current TFR's and Metars. There is NO weather download in air. The data fields can be resized, colored and moved or deleted. Intuitive flight planing and adding waypoints on the fly. Check out the You Tube Video. (turn up the volume, he is too soft for me) http://www.youtube.com/watch?v=_xqFmLRoSiA More GPS info - http://ifly.adventurepilot.com/ For the best search engine for $100 hamburgers - http://adventurepilot.com/ Steve (I am not seling this, just using it) n2715d C-170 RV-10 #40499 building..... Stephen G. Blank, DDS 184 NW Central Park Plaza Port St. Lucie, FL 34986 772-475-5556 cell ________________________________________________________________________________
Subject: MilSPec Fittings
Date: May 02, 2010
Hi I am interested in using MILSPEC fittings for my cowl. I was wondering, however, how difficult is it to remove the grommets after installation. I would like to to be able to remove the cowl hardware prior to painting the cowl. Cheers Les #40643 ________________________________________________________________________________
Date: May 02, 2010
Not sure how you could improve on last year. Yum yum. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Sunday, May 02, 2010 12:02 PM Subject: RV10-List: Re: Rudder trim de nuevo Thanks for the info fellers. I will install this thing and report back. It appears simple and cheap. Robin, I can appreciate the ease of the koolie hat. I am trying something different with my stick grips (cutting/modifying the uprights off of a Boeing 737 yoke) and that leaves me PTT, Pitch trim, and A/P disconnect, so no koolie hat for me. BTW, My wife wants to improve the menu for the RV-10 nest at Copperstate, but I told her we still have to have the special krispie treats for you. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296489#296489 ________________________________________________________________________________
Subject: Re: MilSPec Fittings
Date: May 02, 2010
Don't put the rings on till your ready to have them on for good actually I never did put the retainers on after paint, I just pull them out of the holes Rick On May 2, 2010, at 2:08 PM, "Les Kearney" wrote: > Hi > > I am interested in using MILSPEC fittings for my cowl. I was > wondering, however, how difficult is it to remove the grommets after > installation. I would like to to be able to remove the cowl hardware > prior to painting the cowl. > > Cheers > > Les > #40643 > > ________________________________________________________________________________
Date: May 02, 2010
I did put the retainers on mine so I wouldn't lose the fitting. They are easy to remove with a sharp pointy tool. You can also buy extra retainers cheaply in case you bugger one up. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296549#296549 ________________________________________________________________________________
Date: May 03, 2010
Michael Wellenzohn wrote: > Thanks Kelly that's exactly what I was looking for. > Spruce just sells clamps made out of aluminum. > > Michael Just out of curiosity, why isn't aluminum acceptable? If they look better, then I understand (g) John -------- #40572 QB. Working on Cowling & Panel N711JG reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296575#296575 ________________________________________________________________________________
Date: May 03, 2010
Engine compartment, steel holds a bit longer in case of a fire :) I guess Werner On 03.05.2010 14:40, johngoodman wrote: > --> RV10-List message posted by: "johngoodman" > > > Michael Wellenzohn wrote: >> Thanks Kelly that's exactly what I was looking for. >> Spruce just sells clamps made out of aluminum. >> >> Michael > > > Just out of curiosity, why isn't aluminum acceptable? If they look better, then I understand (g) > John > > -------- > #40572 QB. Working on Cowling& Panel > N711JG reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=296575#296575 > > ________________________________________________________________________________
Subject: WxWorx connector
Date: May 03, 2010
Does anyone know who's the manufacturer of the power plug used on the XM receiver box? See attached picture. I'd like to use aircraft wire to hook it up instead of the wire they supply with the box. Thanks, Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296585#296585 Attachments: http://forums.matronics.com//files/dc_power_supply_4b117b1278d85_173.jpg ________________________________________________________________________________
Subject: Re: WxWorx connector
Date: May 03, 2010
I don't know who makes it, but perhaps you can help me with a problem related to the connector I was about to post. In relationship to the 2-pin connector to the box, which pin is positive and which is negative? I'll spare the details, but I cut above where I marked the wires and haven't a clue which one goes where now that I am trying to wire it in. Ooops. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296592#296592 ________________________________________________________________________________
Date: May 03, 2010
If it's like the one I just sold it is a dc power plug. Looking at the picture the left box is the GRT processor; the right puck is the XM receiver. The connections are the antenna (pink), the data connection to the GRT processor, and the DC power plug. The ultimate power connections of the whole system is the red/black wires out of the Dsub on the GRT processor. This may help. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lenny Iszak Sent: Monday, May 03, 2010 7:36 AM Subject: RV10-List: WxWorx connector --> Does anyone know who's the manufacturer of the power plug used on the XM receiver box? See attached picture. I'd like to use aircraft wire to hook it up instead of the wire they supply with the box. Thanks, Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296585#296585 Attachments: http://forums.matronics.com//files/dc_power_supply_4b117b1278d85_173.jpg ________________________________________________________________________________
Date: May 03, 2010
Subject: antenna problems
Last week I indicated a problem of not receiving glide slope information on my SL-30 but was getting good localizer data, and the 430 was getting both loc and gs from the other ant. Both radios get the VOR stuff normally. I have switched the ant. leads and found that now the 430 isn't getting the gs (but still gets the loc) and the SL-30 gets both nicely. Thus I have an antenna problem but only in the frequency range of the glideslope (I think the gs freq. is much higher than the loc. freq.) So what gives? And more importantly what do I do? The ant. in question is in the port wing tip fastened to the lower aspect of the fiberglass fairing, and grounded to the wing skin (just like the other nicely functioning ant. in the other wing tip). The marker beacon ant. is also in that wing tip but fastened to the upper aspect of the fairing. Is there anyway that the mb ant is interfering? Thanks, Jay Rowe #40301 ________________________________________________________________________________
Date: May 03, 2010
Take your voltmeter and check continuity to the center whether it be male or female; that is the positive wire. The external metal is ground. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric_Kallio Sent: Monday, May 03, 2010 10:05 AM Subject: RV10-List: Re: WxWorx connector I don't know who makes it, but perhaps you can help me with a problem related to the connector I was about to post. In relationship to the 2-pin connector to the box, which pin is positive and which is negative? I'll spare the details, but I cut above where I marked the wires and haven't a clue which one goes where now that I am trying to wire it in. Ooops. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296592#296592 ________________________________________________________________________________
Date: May 03, 2010
My connector has the two pin plug as shown in Lenny's pic, however, the other end terminated in 16 ga. red and black wires with an in-line fuse. When cutting the wire to connect to the lead wires from my panel buss, I cut on the wrong side of my marks and can't tell which pin is the power wire. My WXWorx box is a single black box with a USB to the GRT screen, the antenna, and the power wire I cut. I have no diagrams from the manufacturer showing the pin identification, and I have been unable to contact any manufacturer that can/is willing to help. Looking at the end of the plug Lenny has, with the notch down, which wire is positive is what I need to determine. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296621#296621 ________________________________________________________________________________
Date: May 03, 2010
Subject: Re: antenna problems
Any chance the MB and VOR antenna cables got mixed up? I think MB antenna would sorta work for VOR/loc freqs, but not GS. > On May 3, 2010, at 3:54 PM, wrote: > > >> --> RV10-List message posted by: >> >> Last week I indicated a problem of not receiving glide slope information on my SL-30 but was getting good localizer data, and the 430 was getting both loc and gs from the other ant. Both radios get the VOR stuff normally. I have switched the ant. leads and found that now the 430 isn't getting the gs (but still gets the loc) and the SL-30 gets both nicely. Thus I have an antenna problem but only in the frequency range of the glideslope (I think the gs freq. is much higher than the loc. freq.) So what gives? And more importantly what do I do? The ant. in question is in the port wing tip fastened to the lower aspect of the fiberglass fairing, and grounded to the wing skin (just like the other nicely functioning ant. in the other wing tip). The marker beacon ant. is also in that wing tip but fastened to the upper aspect of the fairing. Is there anyway that the mb ant is interfering? Thanks, Jay Rowe #40301 >> >> >> >> >> > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: May 03, 2010
Jay, Interesting problem. You are correct, Glide Slope is three times higher in frequency than VOR or LOC transmissions. Since antenna are resonate at odd multiples of operation frequencies, VOR/LOC antennas work just fine for Glide Slope. >From your note you point out the both VOR antennas are identical and mounted in similar fashions, one in each wingtip. As such both antennas must work - unless there is some other problem. Your note say both work at VOR frequencies. I wonder however if both work equally well at VOR frequencies. My guess is they don't. I would first look at the most common culprits for such things, the antenna connections or less frequent a bad run of coax (the coax perhaps damaged on installation). The best way to do this is with an antenna analyzer. Most amateur radio operators have one. You might try the local ham radio club. Someone will jump at the chance to help. Here is a standard analyzer that will do anything you need: http://www.mfjenterprises.com/Product.php?productid=MFJ-249B My thinking is the problem is not so bad that you do not receive any VOR signals, but such problems tend to have more of an effect at the higher GS frequency. I would not suspect the MB antenna unless it is very close (a few inches) from the VOR antenna. Come to think about it, make sure your MB and VOR antenna leads are not swapped. A MB antenna will make a poor VOR antenna, but it will work with strong signals. Carl Froehlich RV-10 (systems install) RV-8A (525 hrs) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jfrjr(at)roadrunner.com Sent: Monday, May 03, 2010 3:55 PM Subject: RV10-List: antenna problems Last week I indicated a problem of not receiving glide slope information on my SL-30 but was getting good localizer data, and the 430 was getting both loc and gs from the other ant. Both radios get the VOR stuff normally. I have switched the ant. leads and found that now the 430 isn't getting the gs (but still gets the loc) and the SL-30 gets both nicely. Thus I have an antenna problem but only in the frequency range of the glideslope (I think the gs freq. is much higher than the loc. freq.) So what gives? And more importantly what do I do? The ant. in question is in the port wing tip fastened to the lower aspect of the fiberglass fairing, and grounded to the wing skin (just like the other nicely functioning ant. in the other wing tip). The marker beacon ant. is also in that wing tip but fastened to the upper aspect of the fairing. Is there anyway that the mb ant is interfering? Thanks, Jay Rowe #40301 ________________________________________________________________________________
Subject: OSH headquarters camping
Date: May 03, 2010
It looks like we will be tent camping at RV10 headquarters sunday monday tuesday. There will be four of us (two fathers and sons). Anyone have room for a couple of two man tents for three nights? Also who is keeping the list of campers at RV10 headquarters? ________________________________________________________________________________
Date: May 03, 2010
This is a long shot - is it possible the GS is "shadowed" by the fuselage? The GS transmitting antenna is slightly offset from the runway, while the localizer is off the far end. Easy test: while on the ILS, swing the nose around 5 deg or so, to the right (if the problem antenna is on left side), see if that makes any difference. Otherwise, I'd make sure there are no GS/LOC splitters inadvertently in the line from that antenna. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296644#296644 ________________________________________________________________________________
Subject: Re: Before mounting engine
Date: May 03, 2010
jayb wrote: > Riveting the cowl hinges before attaching the engine mount is a good idea as the mount gets in the way of several hinge rivets. By the time I realized this, the engine was already hung and it got interesting. > > I pulled FW wires after the engine on without problem. One advantage of doing it this way is that everything is known to be accessible after the fact. > > Attached forest of ground tabs to FW before engine on. > > Mounted LSE Electronic Ignition to aft side of FW before engine on. > > Install of air vent control cables after engine on doesn't look like fun as there's little clearance. I didn't have my cabin mounts done at the time, so I'll be the poster child for doing it backwards. > > Ran engine control cables after engine on without problem. Would have been easier beforehand though. > > Jay Jay, Do you have a photo of your firewall that you can share? I haven't installed the mount yet, but am looking to install the forest of tabs and the the fat cables this coming weekend. My concern is that I'll install them someplace where I wish I hadn't after the engine gets mounted. thanks, bob -------- Bob Leffler N410BL - Finish RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296645#296645 ________________________________________________________________________________
Date: May 03, 2010
Thanks for the suggestions. I even talked to bob archer today. The problem, he thinks, is an "unhealthy" connection at the ant. I did not discuss the possibility of switching the mb and nav ants but that may be a possibility since the runs are side by each all the way. That will be very easy to check out. I'll have more info tomorrow. Jay Sent from my iPhone On May 3, 2010, at 8:40 PM, Kelly McMullen wrote: > > Any chance the MB and VOR antenna cables got mixed up? > I think MB antenna would sorta work for VOR/loc freqs, but not GS. > > >> On May 3, 2010, at 3:54 PM, > > wrote: >> >> >>> --> RV10-List message posted by: >>> >>> Last week I indicated a problem of not receiving glide slope >>> information on my SL-30 but was getting good localizer data, and >>> the 430 was getting both loc and gs from the other ant. Both >>> radios get the VOR stuff normally. I have switched the ant. leads >>> and found that now the 430 isn't getting the gs (but still gets >>> the loc) and the SL-30 gets both nicely. Thus I have an antenna >>> problem but only in the frequency range of the glideslope (I think >>> the gs freq. is much higher than the loc. freq.) So what gives? >>> And more importantly what do I do? The ant. in question is in the >>> port wing tip fastened to the lower aspect of the fiberglass >>> fairing, and grounded to the wing skin (just like the other nicely >>> functioning ant. in the other wing tip). The marker beacon ant. >>> is also in that wing tip but fastened to the upper aspect of the >>> fairing. Is there anyway that the mb ant is interfering? Thanks, >>> Jay Rowe #40301 >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 03, 2010
Eric, My wx box is in hangar right now. I'll head out there tomorrow with a Voltmeter and check it out for you. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296652#296652 ________________________________________________________________________________
Date: May 03, 2010
Subject: N998RV Flies - Teaser Shot!
Yahooo!! Mr RV-8 flew today for the first time!! Yahoo! .5 hours at 1pm and 1.0 hours again at 4:30pm! There's a ton more pictures and some sweet videos, but this will have to do for now... More to come! Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Date: May 04, 2010
The connector is made by Conxall. I bought additional connectors at Digikey. They are in the Digikey catalog on page 264-265. Pete _______________________________ Message 3 _____________________________________ Subject: RV10-List: WxWorx connector From: "Lenny Iszak" <lenard(at)rapiddecision.com> Does anyone know who's the manufacturer of the power plug used on the XM receiver box? See attached picture. I'd like to use aircraft wire to hook it up instead of the wire they supply with the box. Thanks, Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296585#296585 Attachments: http://forums.matronics.com//files/dc_power_supply_4b117b1278d85_173.jpg <http://forums.matronics.com/files/dc_power_supply_4b117b1278d85_173.jpg> ________________________________________________________________________________
Date: May 04, 2010
Photo is attached. No warranties as I'm not flying yet. Aft tab access may be less fun than the firewall side. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296703#296703 Attachments: http://forums.matronics.com//files/hpim0768_190.jpg ________________________________________________________________________________
Date: May 04, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
I'm doing this from memory, but I thought I was told that in the GRT setup, the box is powered by the USB connection? Bill Eric_Kallio wrote: > > My connector has the two pin plug as shown in Lenny's pic, however, the other end terminated in 16 ga. red and black wires with an in-line fuse. When cutting the wire to connect to the lead wires from my panel buss, I cut on the wrong side of my marks and can't tell which pin is the power wire. My WXWorx box is a single black box with a USB to the GRT screen, the antenna, and the power wire I cut. I have no diagrams from the manufacturer showing the pin identification, and I have been unable to contact any manufacturer that can/is willing to help. Looking at the end of the plug Lenny has, with the notch down, which wire is positive is what I need to determine. > > Eric Kallio > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=296621#296621 > > > ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: May 04, 2010
I wasn't planning to get things into high gear yet but the plan is to do th ings just like the past few years. I'll post something later in May or ear ly June when I've verified costs and am ready to start collecting money. Most general questions are answered on the FAQs from last year on Tim's web site: http://www.myrv10.com/osh/Camping_FAQ.html We (Gary, Tim and I) haven't coordinated details yet but I expect that we'l l do about what we've done in the past. For those unfamiliar with how it w orks: - Gary and I (and Brenda and Susan) usually arrive Monday (or so) the week prior to OSH and locate an area where we can have a group of adjac ent sites. - The past few years this has been in the area of 55th and Lindber gh in Camp Scholler which is very close to the gates, showers, etc. o Actual location will depend on what's available when we get there. - EAA requires that sites be paid for from when "staked out" until the end of the show. If you leave early unused nights are refunded. - You must have an EAA membership with an expiration date later th an Aug 2010 (Show ends 8/1/10) - People desiring a spot in the "RV-10 HQ" area send payment to me in advance. - We stake out the sites and pay first thing Tuesday morning the w eek before AirVenture starts. o Each person will have a site officially registered and tagged in their name o At that point you have a site at OSH with your name on it - When you arrive at OSH simply call and we'll meet you at the ent rance with your registration package including car pass. - Site size is nominally 20x30 (feet). In accordance with EAA's r ules, we can make the site larger if required for large motorhomes or trail er rigs. - If you rent a camper from Fox Valley RV (or similar) you can pro vide us as POC and we'll get them the location info General notes: There are usually a couple of "announced" large cookouts in the RV-10 HQ ar ea. In addition to those camping in the group, it will be open to RV-10 bu ilders, flyers, enthusiasts, vendors, etc. that feel like showing up. Atte ndance has exceeded 100 every time we've had one... To fund the cookouts we simply put out a collection plate with the intent o f simply covering costs. Because of generosity in the past we've again got a surplus from last year and will use part of that to pay for a common sit e for gathering. We usually can come up with several canopies for shade. If there are picnic tables to be found we'll put some of them in that area also. The area is very close to both the Theater in the Woods and FlyMarket gates and therefore easily accessible to those attending but not camping. Any a fternoon/evening during the show you will find at least a few RV-10 types h anging around the camping area. We get there early and don't mind a little work for the common cause but it seems that every year a couple of situations always come up... - Invariably somebody that didn't sign up for a site will call (or even show up) a few days after we've staked out the sites and want one. S ometimes they'll get lucky and there will be something adjacent or close, s ometimes not. We can only guarantee a site for those that have paid in adv ance and that we've specifically staked out sites for. - Any coordination for cost sharing, splitting a site for the week , sharing a site, etc. is between individuals. Tim has in the past posted a calendar on his website to facilitate this. Let the countdown begin! Bob RV-10 N442PM ________________________________________________________________________________
Date: May 04, 2010
Thanks Pete! Mine is an Ethernet version and it could be powered by the Ethernet line, but the switch i'm using does not support Power over Ethernet, so I need to connect the power wire. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296734#296734 ________________________________________________________________________________
Date: May 04, 2010
Subject: Re: N998RV Flies - Teaser Shot!
Congrats Matt. Looking forward to the videos. -Sean #40303 On 5/3/10 10:22 PM, Matt Dralle wrote: > Yahooo!! > > Mr RV-8 flew today for the first time!! Yahoo! .5 hours at 1pm and 1.0 hours again at 4:30pm! There's a ton more pictures and some sweet videos, but this will have to do for now... More to come! > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Test Flight > ________________________________________________________________________________
Date: May 04, 2010
Subject: Missing glide slope problem solved!!!
Some of you will recall my difficulties in getting the glideslope frequency to my SL-30 although the localizer came in fine, and even the glideslope showed up when I was within a mile of the TDZ. The problem was simple and all "pilot error". Some of you raised the possibility of having the leads switched between the marker beacon and navigation antennas. Even Bob Archer didn't come up with that possibility. But that was the answer. I had mislabeled the coaxial cables. Everything works spot on now. Thanks to all. The suggestions saved me the task of removing/replacing the wing tip fairings. Jay Rowe ________________________________________________________________________________
Subject: FW: firewall pass through
Date: May 04, 2010
RV-6A builder Roger Bocox told me about these. This is what's on my plane. We simply drilled out the hole the grommet was in the plans with a large hole to accommodate the stud. It seal, insulates, and passes the current through in a single step. Here is a link to a couple of different models. Ours is: <http://www.quickcar.net/electric/57700.html> http://www.quickcar.net/electric/57700.html or a different style <http://bluesea.com/category/9/productline/overview/11> http://bluesea.com/category/9/productline/overview/11 Pete ________________________________________________________________________________
Date: May 04, 2010
Eric, Checked my connections. See the attached picture. Jesse, thanks for that idea! Not bad, but now that I found the connector, that will be a better solution. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296768#296768 Attachments: http://forums.matronics.com//files/wxworx_connector_314.jpg ________________________________________________________________________________
Date: May 04, 2010
Thats what I needed! Thanks Lenny! Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296771#296771 ________________________________________________________________________________
Date: May 05, 2010
Subject: EFIS Simulators
G'day all, Anybody know where I can get a GRT EFIS Simulator? Reading the manual only gets you so far and I'm not too keen on shaking down Synthetic and ILS app roaches inside controlled airspace until I have mastered the 'knobology'. Cheers Ron VH-XRM flying in Oz, finishing first annual ________________________________________________________________________________
Subject: Re: EFIS Simulators
Date: May 04, 2010
If you find anything I would like it too. I figure 6-8 months until I am flying. Maybe more, maybe less. No hurry, but when I get there, like you I want to be as familiar as I can with the system. Eric Kallio Fairings, cowling, and wiring. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296782#296782 ________________________________________________________________________________
Date: May 04, 2010
Subject: Alignment of engine mount holes seem off by quite a bit.
Dear RV-10 list readers, I've been building my RV-10 for about a year and a half. It's time to install the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out there knows if this is normally what is expected please let me know. Everything else in this excellent kit has fit very well and it's not my intention to speak poorly of the kit or Vans in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasing the holes out but which ones do I align it with first? Everyone's comments and experiences are welcome. Thank you. Matthew Collier ________________________________________________________________________________
Subject: Re: Alignment of engine mount holes seem off by quite a bit.
Date: May 05, 2010
Hey Matthew, Ours was a very close fit. Three holes perfect, the last hole with minimal persuasion. I think I'd give Van's a call first before chasing the holes and get their opinion about bending the mount to fit the holes. Later, - Lew ----- Original Message ----- From: Matthew Collier To: rv10-list(at)matronics.com Sent: Wednesday, May 05, 2010 1:14 AM Subject: RV10-List: Alignment of engine mount holes seem off by quite a bit. Dear RV-10 list readers, I've been building my RV-10 for about a year and a half. It's time to install the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out there knows if this is normally what is expected please let me know. Everything else in this excellent kit has fit very well and it's not my intention to speak poorly of the kit or Vans in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasing the holes out but which ones do I align it with first? Everyone's comments and experiences are welcome. Thank you. Matthew Collier ________________________________________________________________________________
Date: May 05, 2010
These mounts, actually mounts from most kit vendors, are off by a bit. Because of manufacturing and the welding process, some miss alignment occurs. Install the bolts in the areas that are the most inflexible, the center ones, and then work your way around to get the others in. I have not heard of any folks who were unable to get them in, it just takes holding your mouth just so and persuading it to move over a bit. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matthew Collier Sent: Wednesday, May 05, 2010 1:15 AM Subject: RV10-List: Alignment of engine mount holes seem off by quite a bit. Dear RV-10 list readers, I've been building my RV-10 for about a year and a half. It's time to install the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out there knows if this is normally what is expected please let me know. Everything else in this excellent kit has fit very well and it's not my intention to speak poorly of the kit or Vans in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasing the holes out but which ones do I align it with first? Everyone's comments and experiences are welcome. Thank you. Matthew Collier ________________________________________________________________________________
Date: May 05, 2010
I did not have too much trouble aligning the holes as I remember. It did take a small amount of persuading but not too bad. I just started installing the bolts and everything began to align. I did hear of at least one mount that was replaced by Van's however. Dave Leikam RV-10 #40496 N89DA Muskego, WI ----- Original Message ----- From: Matthew Collier To: rv10-list(at)matronics.com Sent: Wednesday, May 05, 2010 12:14 AM Subject: RV10-List: Alignment of engine mount holes seem off by quite a bit. Dear RV-10 list readers, I've been building my RV-10 for about a year and a half. It's time to install the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out there knows if this is normally what is expected please let me know. Everything else in this excellent kit has fit very well and it's not my intention to speak poorly of the kit or Vans in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasing the holes out but which ones do I align it with first? Everyone's comments and experiences are welcome. Thank you. Matthew Collier ________________________________________________________________________________
Date: May 05, 2010
Apparently this is pretty typical. I was complaining to my A&P friend and h e said that even on the certified planes that this was the usual (mis)fit. I was trying to do the mounting by myself but finally gave up and got some help. That made it somewhat easier. From: lewgall(at)charter.net Subject: Re: RV10-List: Alignment of engine mount holes seem off by quite a bit. Date: Wed=2C 5 May 2010 08:13:09 -0400 Hey Matthew=2C Ours was a very close fit. Three holes perfect=2C the last hole with minimal persuasion. I think I'd give Van's a call first before chasing the holes and get their opinion about bending the mount to fit the holes. Later=2C - Lew ----- Original Message ----- From: Matthew Collier To: rv10-list(at)matronics.com Sent: Wednesday=2C May 05=2C 2010 1:14 AM Subject: RV10-List: Alignment of engine mount holes seem off by quite a bit. Dear RV-10 list readers=2C I've been building my RV-10 for about a year and a half. It's time to install the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out there knows if this is normal ly what is expected please let me know. Everything else in this excellent ki t has fit very well and it's not my intention to speak poorly of the kit or Van s in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasin g the holes out but which ones do I align it with first? Everyone's comments an d experiences are welcome. Thank you. Matthew Collier href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c _________________________________________________________________ The New Busy is not the old busy. Search=2C chat and e-mail from your inbox . http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:O N:WL:en-US:WM_HMP:042010_3 ________________________________________________________________________________
Date: May 05, 2010
Ron, Short answer is that there is no simulator for GRT. There are a couple of other options that might help if you've actually got one of the display uni ts. 1) There is apparently an MS flight sim driver that allows you to plug your GRT in to the PC. I've never used it but on the surface it sounds in teresting. Chatter that I've seen sounds like usability is limited - prett y much display only. 2) GRTs have the ability to record/playback flight info. There are so me that you can download, put on a USB stick and then "playback" on a displ ay. This is really nice because you can flip between screens, etc. but aga in it's only playback and not entirely interactive. If you aren't already a member, I strongly recommend joining the GRT Yahoo group at http://groups.yahoo.com/group/GRT_EFIS/. You will find discussion , files for download, etc. that can be very helpful. Bob RV-10 N442PM (with 3 screen GRT) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of McGann, Ron Sent: Tuesday, May 04, 2010 5:19 PM Subject: RV10-List: EFIS Simulators G'day all, Anybody know where I can get a GRT EFIS Simulator? Reading the manual only gets you so far and I'm not too keen on shaking down Synthetic and ILS app roaches inside controlled airspace until I have mastered the 'knobology'. Cheers Ron VH-XRM flying in Oz, finishing first annual ________________________________________________________________________________
Date: May 05, 2010
It's all about quality control.... if they have the proper jigs, and they w eld in the appropriate steps, it should be within pretty close tolerances. - Van's should make up an acceptance jig to ck the motor mounts prior to shipping.... depends on whether they're doing them, or they out-source them .- If it's out by as much as you say, I'd send it back in the hopes that the next one is better. Don McDonald --- On Wed, 5/5/10, Danny Riggs wrote: From: Danny Riggs <jdriggs49(at)msn.com> Subject: RE: RV10-List: Alignment of engine mount holes seem off by quite a bit. Date: Wednesday, May 5, 2010, 6:21 AM Apparently this is pretty typical. I was complaining to my A&P friend and h e said that even on the certified planes that this was the usual (mis)fit. I was trying to do the mounting by myself but finally gave up and got some help. That made it somewhat easier. From: lewgall(at)charter.net Subject: Re: RV10-List: Alignment of engine mount holes seem off by quite a bit. Date: Wed, 5 May 2010 08:13:09 -0400 Hey Matthew, - Ours was a very close fit.- Three holes perfect, the last hole with minim al persuasion.- I think I'd give Van's a call first before chasing the ho les and get their opinion about bending the mount to fit the holes. - Later, - Lew ----- Original Message ----- From: Matthew Collier Sent: Wednesday, May 05, 2010 1:14 AM Subject: RV10-List: Alignment of engine mount holes seem off by quite a bit . Dear RV-10 list readers, I've been building my RV-10 for about a year and a half. It's time to insta ll the engine mount and I was shocked to find the mounting holes are about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm wondering if this is typical or if my mount was build a little off. If anyone out th ere knows if this is normally what is expected please let me know. Everythi ng else in this excellent kit has fit very well and it's not my intention t o speak poorly of the kit or Vans in any way. It's just surprising to find a mis-alignment so great in an area I would consider to be one of the most important. I'm tempted to try chasing the holes out but which ones do I ali gn it with first? Everyone's comments and experiences are welcome. Thank you. Matthew Collier href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigatwww.matronics.com/contribution">http://www .matronics.com/contribution The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get started. =0A=0A=0A ________________________________________________________________________________
Date: May 05, 2010
Before tightening any nuts, a few of my holes were perfect, but a couple others seemed way off (the pilot hole was barely within the engine mount hole). I then tightened the nuts on the holes that did align. That pulled the mount tight against the firewall, which also made the holes closer. At that point, they were all within 1/8" of center. Note I drilled my first hole without the mount on, then had my wife hold the mount while I drilled the second hole. From there, the mount holds itself :) -Rob On Wed, May 5, 2010 at 7:38 AM, Don McDonald wrote: > It's all about quality control.... if they have the proper jigs, and > they weld in the appropriate steps, it should be within pretty close > tolerances. Van's should make up an acceptance jig to ck the motor mounts > prior to shipping.... depends on whether they're doing them, or they > out-source them. If it's out by as much as you say, I'd send it back in the > hopes that the next one is better. > Don McDonald > > > --- On *Wed, 5/5/10, Danny Riggs * wrote: > > > From: Danny Riggs <jdriggs49(at)msn.com> > Subject: RE: RV10-List: Alignment of engine mount holes seem off by quite a > bit. > To: rv10-list(at)matronics.com > Date: Wednesday, May 5, 2010, 6:21 AM > > Apparently this is pretty typical. I was complaining to my A&P friend and > he said that even on the certified planes that this was the usual (mis)fit. > I was trying to do the mounting by myself but finally gave up and got some > help. That made it somewhat easier. > > ------------------------------ > From: lewgall(at)charter.net > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Alignment of engine mount holes seem off by quite a > bit. > Date: Wed, 5 May 2010 08:13:09 -0400 > > Hey Matthew, > > Ours was a very close fit. Three holes perfect, the last hole with minimal > persuasion. I think I'd give Van's a call first before chasing the holes > and get their opinion about bending the mount to fit the holes. > > Later, - Lew > > ----- Original Message ----- > *From:* Matthew Collier<http://us.mc537.mail.yahoo.com/mc/compose?to=ivdiggs@gmail.com> > *To:* rv10-list@matronics.com<http://us.mc537.mail.yahoo.com/mc/compose?to=rv10-list@matronics.com> > *Sent:* Wednesday, May 05, 2010 1:14 AM > *Subject:* RV10-List: Alignment of engine mount holes seem off by quite a > bit. > > Dear RV-10 list readers, > > I've been building my RV-10 for about a year and a half. It's time to > install the engine mount and I was shocked to find the mounting holes are > about 3/16" to 1/4" off from the pre-drilled holes in the firewall. I'm > wondering if this is typical or if my mount was build a little off. If > anyone out there knows if this is normally what is expected please let me > know. Everything else in this excellent kit has fit very well and it's not > my intention to speak poorly of the kit or Vans in any way. It's just > surprising to find a mis-alignment so great in an area I would consider to > be one of the most important. I'm tempted to try chasing the holes out but > which ones do I align it with first? Everyone's comments and experiences are > welcome. > > Thank you. > > Matthew Collier > > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * http://www.matronics.com/Navigatwww.matronics.com/contribution">http://www.matronics.com/contribution > > * > > > ------------------------------ > The New Busy is not the old busy. Search, chat and e-mail from your inbox. Get > started.<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3> > > * > > get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List > =nofollow>http://forums.matronics.com > blank rel=nofollow>http://www.matronics.com/contribution > * > > > * > > * > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: May 05, 2010
I had the same problem. Per Vans' advice I used a clamp to pull the mount over far enough that the firewall hole was still not centered, but completely within, the engine mount hole. Then I match drilled it. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296852#296852 ________________________________________________________________________________
Date: May 05, 2010
Subject: eBay Avionics
As an FYI for any builder about to make a avionics choice: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160431095390&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_2927wt_1165 Robin ________________________________________________________________________________
Subject: Re: eBay Avionics
Date: May 05, 2010
So I guess they still haven't sold it. This was listed at Sun-n-Fun for $29,995 on a board in Wentworth's booth... I thought it was a good deal... -------- RV-7A N777TY Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296868#296868 ________________________________________________________________________________
Date: May 05, 2010
A bit of Due Diligence is needed here. The system as pictured can't (read can NOT) be made into a G900X system since the GIA-63 boxes are Non-WAAS. You're stuck with a system that you can't load any G900X software on and they are old non WAAS boxes. No SVT terrain, etc.. They are great G-1000 components (for older installations or in Non-WAAS installs), but not a great solution for a G900X. If they were a steal, I'd have bought the same boxes at the same auction they did, as I have a pretty good idea of what stuff is worth. As always, buyer beware and do your homework before buying 2nd hand stuff without knowing EXACTLY what you're getting and exactly what you can do with it. My 2 cents as usual. Not trying to flame anyone, just trying to make sure nobody gets something they didn't bargain for. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, May 05, 2010 2:26 PM Subject: RV10-List: eBay Avionics As an FYI for any builder about to make a avionics choice: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem <http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160431095390& fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_2927wt_1165> &item=160431095390&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_292 7wt_1165 Robin ________________________________________________________________________________
Date: May 05, 2010
Stein; You and I spoke yesterday about our similar financial crunch, many may have forgotten what you did for your customers with those Cheltons when that company left everyone hanging a couple of years ago. It pays to remember you took the hit for them and made sure they were taken care of even if it meant delaying your progress on the RV-6 just as you are doing with this last post. I enjoyed our conversation and your insight, truly you are among the few that provide an excellent customer support experience and anyone who thinks a word of advice from you is flaming will eventually find their decision may leave them going down in flames. Thank you! Pascal From: Stein Bruch Sent: Wednesday, May 05, 2010 2:26 PM Subject: RE: RV10-List: eBay Avionics A bit of Due Diligence is needed here. The system as pictured can't (read can NOT) be made into a G900X system since the GIA-63 boxes are Non-WAAS. You're stuck with a system that you can't load any G900X software on and they are old non WAAS boxes. No SVT terrain, etc.. They are great G-1000 components (for older installations or in Non-WAAS installs), but not a great solution for a G900X. If they were a steal, I'd have bought the same boxes at the same auction they did, as I have a pretty good idea of what stuff is worth. As always, buyer beware and do your homework before buying 2nd hand stuff without knowing EXACTLY what you're getting and exactly what you can do with it. My 2 cents as usual. Not trying to flame anyone, just trying to make sure nobody gets something they didn't bargain for. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, May 05, 2010 2:26 PM Subject: RV10-List: eBay Avionics As an FYI for any builder about to make a avionics choice: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160431095 390&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_2927wt_1165 Robin http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Door/Baggage Locks
Date: May 05, 2010
Hello all, I'm wondering if anyone has solved this problem: I am trying to find three door locks, one for the baggage door and one each for the main doors. Spruce sells a set of two, but I'm not sure if these can be re-keyed. I'd like for all three locks to use the same key if possible. By the way, my ignition will not have a key as it uses the Vertical Power system. Any help would be appreciated. Mike Schipper #40576 - finishing - www.rvten.com ________________________________________________________________________________
Date: May 05, 2010
Subject: Re: Door/Baggage Locks
IFLYRV10.com Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Wed May 05 16:35:11 2010 Subject: RV10-List: Door/Baggage Locks Hello all, I'm wondering if anyone has solved this problem: I am trying to find three door locks, one for the baggage door and one each for the main doors. Spruce sells a set of two, but I'm not sure if these can be re-keyed. I'd like for all three locks to use the same key if possible. By the way, my ignition will not have a key as it uses the Vertical Power system. Any help would be appreciated. Mike Schipper #40576 - finishing - www.rvten.com ________________________________________________________________________________
Date: May 05, 2010
You can get them from iflyrv10.com. If you are more energetic, you may be able to pick them up at home depot or lowes. Your local locksmith should also be able to assist. Most sell hardware. bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Schipper Sent: Wednesday, May 05, 2010 7:35 PM Subject: RV10-List: Door/Baggage Locks Hello all, I'm wondering if anyone has solved this problem: I am trying to find three door locks, one for the baggage door and one each for the main doors. Spruce sells a set of two, but I'm not sure if these can be re-keyed. I'd like for all three locks to use the same key if possible. By the way, my ignition will not have a key as it uses the Vertical Power system. Any help would be appreciated. Mike Schipper #40576 - finishing - www.rvten.com ________________________________________________________________________________
Date: May 05, 2010
Subject: RV-8 N998RV First Flight - Pilot Report And Photos!
Dear Listers, Monday May 2 2010 at 1:15pm, RV-8 #82880 N998RV took to the air for the first time! The first flight was about 30 minutes and all systems worked as expected. The only post-flight adjustments necessary were an increase in the amount of available Up trim, and a decrease in the upper RPM limit on the Hartzell prop. After a smooth takeoff, I climbed out and circled the airport at about three to four thousand feet for a couple of circuits then came around and landed making a nice three-point landing with no bounce. The plane handled excellent and the power from the IO-390 and the Hartzell can only be experienced to be believed! What a great combination! I want to thank Van's for designing such a great aircraft and for producing such an outstanding kit. I would also like to thank all my List friends for their help and assistance during the project. And of course, a special thanks to all of my personal friends that have come over and lent at hand during the construction - I own you guys a ride and a $100 hamburger when I get the Phase 1 time flown off! Probably in the Fall or Winter some time, plan to take it in for painting. I'm planning on a Candy Apply Red with some very understated and elegant golden trim with a nice clear coat. For all those that are still building - keep at it! The end result is 100% worth the time and effort you put into the project. That first flight will be the experience of a lifetime and something you won't soon forget! Attached are some pictures from the first flight and few shots of the engine, panel, and interior. Below, I've listed the system highlights. Build Hours: 2457 Hours Build Time: 23 Months Kit: Van's RV-8 QB Engine: Lycoming IO-390 210hp Ignition: Slick Mags w/ Slick-Start Module Exhaust: Vetterman IO-390 4-into-4 System (Sounds Great!) Prop: Hartzell 72" Constant Speed Governor: PCU5000 Alternator Primary: 60a Plain Power Belt Drive Alternator Secondary: 20a B&C Direct Drive w/ B&C External Regulator Steam Gauges: NONE! Flight Instruments: Triple 6.5" GRT HX / Dual GRT AHRSs / Dual Magnetometers Realtime Weather: XM Module For GRT HX & XM Module For Kenwood DNX-8120 Autopilot: TruTrak Digiflight II VSGV Two Axis w/ Auto Trim Module Fuel Flow: Matronics FuelChec DX GPS: Dual GRT Modules (Garmin engine) Radio: Garmin SL-30 Transponder: Garmin GTX-327 Electrical System: Vertical Power VP-200 Entertainment: Kenwood DNX-8120 with 7" LCD / Psgr 7" Remote LCD XM Radio / DVD / 64GB MP3 / HD AM-FM / XM Weather / Full Bluetooth integration with Blackberry (make and receive calls through headsets) Intercom: PS3000 Stereo Headphones: Bose Aviation Headset X Interior: Classic Aero - All Leather over All Comferfoam Carpet: Custom design - Cut & Sewn by Classic Aero Oxygen System: Mountain High O2D2 w/ Electronic Tank Valve & PSI Seat Belts: Hooker 5-Point Harness Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Test Flight ________________________________________________________________________________
Date: May 05, 2010
If you are using a keyed ignition switch, you can special order from ACS a switch and three door/baggage locks all keyed alike. A little more expensive to special order, but I really like having only one key for everything. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296898#296898 ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Date: May 06, 2010
Where I come from they "that sure is purty!" > Date: Wed=2C 5 May 2010 18:27:08 -0700 > To: rv10-list(at)matronics.com > From: dralle(at)matronics.com > Subject: RV10-List: RV-8 N998RV First Flight - Pilot Report And Photos! > > > Dear Listers=2C > > Monday May 2 2010 at 1:15pm=2C RV-8 #82880 N998RV took to the air for the first time! The first flight was about 30 minutes and all systems worked a s expected. The only post-flight adjustments necessary were an increase in the amount of available Up trim=2C and a decrease in the upper RPM limit on the Hartzell prop. After a smooth takeoff=2C I climbed out and circled the airport at about three to four thousand feet for a couple of circuits then came around and landed making a nice three-point landing with no bounce. T he plane handled excellent and the power from the IO-390 and the Hartzell c an only be experienced to be believed! What a great combination! > > I want to thank Van's for designing such a great aircraft and for produci ng such an outstanding kit. I would also like to thank all my List friends for their help and assistance during the project. And of course=2C a specia l thanks to all of my personal friends that have come over and lent at hand during the construction - I own you guys a ride and a $100 hamburger when I get the Phase 1 time flown off! > > Probably in the Fall or Winter some time=2C plan to take it in for painti ng. I'm planning on a Candy Apply Red with some very understated and elegan t golden trim with a nice clear coat. > > For all those that are still building - keep at it! The end result is 100 % worth the time and effort you put into the project. That first flight wil l be the experience of a lifetime and something you won't soon forget! > > Attached are some pictures from the first flight and few shots of the eng ine=2C panel=2C and interior. Below=2C I've listed the system highlights. > > Build Hours: 2457 Hours > Build Time: 23 Months > Kit: Van's RV-8 QB > Engine: Lycoming IO-390 210hp > Ignition: Slick Mags w/ Slick-Start Module > Exhaust: Vetterman IO-390 4-into-4 System (Sounds Great!) > Prop: Hartzell 72" Constant Speed > Governor: PCU5000 > Alternator Primary: 60a Plain Power Belt Drive > Alternator Secondary: 20a B&C Direct Drive w/ B&C External Regulator > Steam Gauges: NONE! > Flight Instruments: Triple 6.5" GRT HX / Dual GRT AHRSs / Dual Magnetomet ers > Realtime Weather: XM Module For GRT HX & XM Module For Kenwood DNX-8120 > Autopilot: TruTrak Digiflight II VSGV Two Axis w/ Auto Trim Module > Fuel Flow: Matronics FuelChec DX > GPS: Dual GRT Modules (Garmin engine) > Radio: Garmin SL-30 > Transponder: Garmin GTX-327 > Electrical System: Vertical Power VP-200 > Entertainment: Kenwood DNX-8120 with 7" LCD / Psgr 7" Remote LCD > XM Radio / DVD / 64GB MP3 / HD AM-FM / XM Weather / > Full Bluetooth integration with Blackberry (make > and receive calls through headsets) > Intercom: PS3000 Stereo > Headphones: Bose Aviation Headset X > Interior: Classic Aero - All Leather over All Comferfoam > Carpet: Custom design - Cut & Sewn by Classic Aero > Oxygen System: Mountain High O2D2 w/ Electronic Tank Valve & PSI > Seat Belts: Hooker 5-Point Harness > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Test Flight ________________________________________________________________________________
Date: May 06, 2010
Subject: Re: RV-8 N998RV First Flight - Pilot Report And Photos!
And looks like VP-200 should be on the list below as the main bus. :) I am planning on one when I get to the panel. I'd be curious as to your opinions both on the install and first flight of the VP-200. -Sean #40303 On 5/5/10 8:27 PM, Matt Dralle wrote: > Dear Listers, > > Monday May 2 2010 at 1:15pm, RV-8 #82880 N998RV took to the air for the first time! The first flight was about 30 minutes and all systems worked as expected. The only post-flight adjustments necessary were an increase in the amount of available Up trim, and a decrease in the upper RPM limit on the Hartzell prop. After a smooth takeoff, I climbed out and circled the airport at about three to four thousand feet for a couple of circuits then came around and landed making a nice three-point landing with no bounce. The plane handled excellent and the power from the IO-390 and the Hartzell can only be experienced to be believed! What a great combination! > > I want to thank Van's for designing such a great aircraft and for producing such an outstanding kit. I would also like to thank all my List friends for their help and assistance during the project. And of course, a special thanks to all of my personal friends that have come over and lent at hand during the construction - I own you guys a ride and a $100 hamburger when I get the Phase 1 time flown off! > > Probably in the Fall or Winter some time, plan to take it in for painting. I'm planning on a Candy Apply Red with some very understated and elegant golden trim with a nice clear coat. > > For all those that are still building - keep at it! The end result is 100% worth the time and effort you put into the project. That first flight will be the experience of a lifetime and something you won't soon forget! > > Attached are some pictures from the first flight and few shots of the engine, panel, and interior. Below, I've listed the system highlights. > > Build Hours: 2457 Hours > Build Time: 23 Months > Kit: Van's RV-8 QB > Engine: Lycoming IO-390 210hp > Ignition: Slick Mags w/ Slick-Start Module > Exhaust: Vetterman IO-390 4-into-4 System (Sounds Great!) > Prop: Hartzell 72" Constant Speed > Governor: PCU5000 > Alternator Primary: 60a Plain Power Belt Drive > Alternator Secondary: 20a B&C Direct Drive w/ B&C External Regulator > Steam Gauges: NONE! > Flight Instruments: Triple 6.5" GRT HX / Dual GRT AHRSs / Dual Magnetometers > Realtime Weather: XM Module For GRT HX& XM Module For Kenwood DNX-8120 > Autopilot: TruTrak Digiflight II VSGV Two Axis w/ Auto Trim Module > Fuel Flow: Matronics FuelChec DX > GPS: Dual GRT Modules (Garmin engine) > Radio: Garmin SL-30 > Transponder: Garmin GTX-327 > Electrical System: Vertical Power VP-200 > Entertainment: Kenwood DNX-8120 with 7" LCD / Psgr 7" Remote LCD > XM Radio / DVD / 64GB MP3 / HD AM-FM / XM Weather / > Full Bluetooth integration with Blackberry (make > and receive calls through headsets) > Intercom: PS3000 Stereo > Headphones: Bose Aviation Headset X > Interior: Classic Aero - All Leather over All Comferfoam > Carpet: Custom design - Cut& Sewn by Classic Aero > Oxygen System: Mountain High O2D2 w/ Electronic Tank Valve& PSI > Seat Belts: Hooker 5-Point Harness > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Test Flight > ________________________________________________________________________________
Date: May 06, 2010
From: Richard Martin <martinaerodrome(at)gmail.com>
Mike, I own a hardware store with a resident locksmith and a laarge inventory of "Cam Locks" also known as vending machine locks. I would suggest however that you go to a local locksmith to buy them because the lock cams may need adjustment etc to suit your particular installation, also, he will be able to set up all three locks with the same key eliminating the nusiance of careing 3 different keys. If you need more info, call me @ 920 619 6968. Good Luck Dick Martin RV8 N233M the fast one On Wed, May 5, 2010 at 6:35 PM, Michael Schipper wrote: > > > > Hello all, > > I'm wondering if anyone has solved this problem: I am trying to find three > door locks, one for the baggage door and one each for the main doors. Spruce > sells a set of two, but I'm not sure if these can be re-keyed. I'd like for > all three locks to use the same key if possible. > > By the way, my ignition will not have a key as it uses the Vertical Power > system. > > Any help would be appreciated. > > Mike Schipper > #40576 - finishing - www.rvten.com > > ________________________________________________________________________________
Date: May 06, 2010
Thanks to Dick and everyone else who responded. So "Cam Lock" is the official name for these things, huh? Now that I know what they are called I did a search on McMaster-Carr and found a nice selection. They can be ordered with the same key number. http://www.mcmaster.com/#cam-locks/ Regards, Mike Schipper #40576 - finishing - www.rvten.com On May 6, 2010, at 7:45 AM, Richard Martin wrote: > Mike, > I own a hardware store with a resident locksmith and a laarge inventory of "Cam Locks" also known as vending machine locks. I would suggest however that you go to a local locksmith to buy them because the lock cams may need adjustment etc to suit your particular installation, also, he will be able to set up all three locks with the same key eliminating the nusiance of careing 3 different keys. If you need more info, call me @ 920 619 6968. > Good Luck > Dick Martin > RV8 N233M > the fast one ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: May 06, 2010
I got mine from Lowes or Home depot, don't remember which. Just match the numbers on the package for keyed alike. I think I spent less than $20 for all three. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Schipper Sent: Wednesday, May 05, 2010 7:35 PM Subject: RV10-List: Door/Baggage Locks Hello all, I'm wondering if anyone has solved this problem: I am trying to find three door locks, one for the baggage door and one each for the main doors. Spruce sells a set of two, but I'm not sure if these can be re-keyed. I'd like for all three locks to use the same key if possible. By the way, my ignition will not have a key as it uses the Vertical Power system. Any help would be appreciated. Mike Schipper #40576 - finishing - www.rvten.com ________________________________________________________________________________
Date: May 06, 2010
Subject: Re: Vertical Power VP-200
At 05:38 AM 5/6/2010 Thursday, you wrote: > >And looks like VP-200 should be on the list below as the main bus. :) I am planning on one when I get to the panel. I'd be curious as to your opinions both on the install and first flight of the VP-200. > >-Sean #40303 > >On 5/5/10 8:27 PM, Matt Dralle wrote: >> >>Electrical System: Vertical Power VP-200 I would highly recommend the VP-200. Installation is very nice as the big red box has all of the wires for each circuit. You simply program each wire for the type of device and expected load. The device is named accordingly, for example "Strobes", and shows up on the main LCD display. Operationally, each mode of flight, for example "Taxi, Run Up, Takeoff, Cruse, Landing, etc.) is programmed into the VP-200. You specify which devices you want on and off during each mode of flight. The VP-200 can automatically detect each mode of flight and will automatically switch on/off the devices for the given mode of flight as you have preprogrammed them. You can at anytime manually override the automatic setting of a given circuit if necessary. Basically, you turn the VP-200 on, and fly the plane. All of your electrical needs are handled automatically. Factory support has be excellent. I wouldn't build another airplane without a Vertical Power electrical system. Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: Phase 1 Test Flying ________________________________________________________________________________
Date: May 06, 2010
Also be aware that some cam locks are longer than those sold by Van's or ACS, and will not fit within the depth of the baggage door. Jim Berry 40482 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=296941#296941 ________________________________________________________________________________
Date: May 06, 2010
WOW! REALLY NICE Bill "served by the list" Watson ________________________________________________________________________________
Date: May 06, 2010
I agree completely! Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On May 6, 2010, at 12:29 PM, Matt Dralle wrote: > At 05:38 AM 5/6/2010 Thursday, you wrote: >> >> And looks like VP-200 should be on the list below as the main bus. :) I am planning on one when I get to the panel. I'd be curious as to your opinions both on the install and first flight of the VP-200. >> >> -Sean #40303 >> >> On 5/5/10 8:27 PM, Matt Dralle wrote: >>> >>> Electrical System: Vertical Power VP-200 > > > I would highly recommend the VP-200. Installation is very nice as the big red box has all of the wires for each circuit. You simply program each wire for the type of device and expected load. The device is named accordingly, for example "Strobes", and shows up on the main LCD display. > > Operationally, each mode of flight, for example "Taxi, Run Up, Takeoff, Cruse, Landing, etc.) is programmed into the VP-200. You specify which devices you want on and off during each mode of flight. The VP-200 can automatically detect each mode of flight and will automatically switch on/off the devices for the given mode of flight as you have preprogrammed them. You can at anytime manually override the automatic setting of a given circuit if necessary. > > Basically, you turn the VP-200 on, and fly the plane. All of your electrical needs are handled automatically. > > Factory support has be excellent. > > I wouldn't build another airplane without a Vertical Power electrical system. > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Phase 1 Test Flying > <2010.01.07 - RV-8 - Front Baggage Area Complete (1).jpg><2009.08.22 - RV-8 - Primary Alternator Installation & Wiring (12).jpg> ________________________________________________________________________________
Date: May 06, 2010
Did I see that right? 3 EFIS screens, a VP-200, and a single COM radio? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On May 5, 2010, at 9:27 PM, Matt Dralle wrote: > > Dear Listers, > > Monday May 2 2010 at 1:15pm, RV-8 #82880 N998RV took to the air for the first time! The first flight was about 30 minutes and all systems worked as expected. The only post-flight adjustments necessary were an increase in the amount of available Up trim, and a decrease in the upper RPM limit on the Hartzell prop. After a smooth takeoff, I climbed out and circled the airport at about three to four thousand feet for a couple of circuits then came around and landed making a nice three-point landing with no bounce. The plane handled excellent and the power from the IO-390 and the Hartzell can only be experienced to be believed! What a great combination! > > I want to thank Van's for designing such a great aircraft and for producing such an outstanding kit. I would also like to thank all my List friends for their help and assistance during the project. And of course, a special thanks to all of my personal friends that have come over and lent at hand during the construction - I own you guys a ride and a $100 hamburger when I get the Phase 1 time flown off! > > Probably in the Fall or Winter some time, plan to take it in for painting. I'm planning on a Candy Apply Red with some very understated and elegant golden trim with a nice clear coat. > > For all those that are still building - keep at it! The end result is 100% worth the time and effort you put into the project. That first flight will be the experience of a lifetime and something you won't soon forget! > > Attached are some pictures from the first flight and few shots of the engine, panel, and interior. Below, I've listed the system highlights. > > Build Hours: 2457 Hours > Build Time: 23 Months > Kit: Van's RV-8 QB > Engine: Lycoming IO-390 210hp > Ignition: Slick Mags w/ Slick-Start Module > Exhaust: Vetterman IO-390 4-into-4 System (Sounds Great!) > Prop: Hartzell 72" Constant Speed > Governor: PCU5000 > Alternator Primary: 60a Plain Power Belt Drive > Alternator Secondary: 20a B&C Direct Drive w/ B&C External Regulator > Steam Gauges: NONE! > Flight Instruments: Triple 6.5" GRT HX / Dual GRT AHRSs / Dual Magnetometers > Realtime Weather: XM Module For GRT HX & XM Module For Kenwood DNX-8120 > Autopilot: TruTrak Digiflight II VSGV Two Axis w/ Auto Trim Module > Fuel Flow: Matronics FuelChec DX > GPS: Dual GRT Modules (Garmin engine) > Radio: Garmin SL-30 > Transponder: Garmin GTX-327 > Electrical System: Vertical Power VP-200 > Entertainment: Kenwood DNX-8120 with 7" LCD / Psgr 7" Remote LCD > XM Radio / DVD / 64GB MP3 / HD AM-FM / XM Weather / > Full Bluetooth integration with Blackberry (make > and receive calls through headsets) > Intercom: PS3000 Stereo > Headphones: Bose Aviation Headset X > Interior: Classic Aero - All Leather over All Comferfoam > Carpet: Custom design - Cut & Sewn by Classic Aero > Oxygen System: Mountain High O2D2 w/ Electronic Tank Valve & PSI > Seat Belts: Hooker 5-Point Harness > > > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: Test Flight > <2010.05.02 - RV-8 - N998RV Test Flight (1).jpg><2010.05.02 - RV-8 - N998RV Test Flight (2).jpg><2010.05.02 - RV-8 - N998RV Test Flight (3).jpg><2010.05.02 - RV-8 - N998RV Test Flight (4).jpg><2010.05.02 - RV-8 - N998RV Test Flight (5).jpg><2010.05.02 - RV-8 - N998RV Test Flight (6).jpg><2010.05.02 - RV-8 - N998RV Test Flight (7).jpg><2010.05.02 - RV-8 - N998RV Test Flight (8).jpg><2010.05.02 - RV-8 - N998RV Test Flight (9).jpg><2010.05.02 - RV-8 - N998RV Test Flight (10).jpg><2010.05.02 - RV-8 - N998RV Test Flight (11).jpg><2010.05.02 - RV-8 - N998RV Test Flight (12).jpg><2009.11.12 - RV-8 - Engine Baffling Powercoated And Completed (13).jpg><2009.11.12 - RV-8 - Engine Baffling Powercoated And Completed (10).jpg><2009.08.12 - RV-8 - Leather Upholstery Arrives (7).jpg><2009.08.12 - RV-8 - Leather Upholstery Arrives (9).jpg><2010.01.14 - RV-8 - Final Instrument Panel Installation (1).jpg><2010.01.14 - RV-8 - Final Instrument Panel Installation (2).jpg><2010.01.14 - RV-8 - Final Instrument Panel Installation (3).jpg><2010.01.14 - RV-8 - Final Instrument Panel Installation (6).jpg><2010.01.18 - RV-8 - Canopy Frame Installation Complete (5).jpg><2010.01.20 - RV-8 - Sliding Canopy Installation Complete (10).jpg><2010.01.20 - RV-8 - Sliding Canopy Installation Complete (7).jpg><2010.02.27 - RV-8 - Spark Plug & Ignition Harness Installation (18).jpg> ________________________________________________________________________________
Date: May 06, 2010
Real men don't need a radio to fly! An spare EFIS, on the other hand, maybe... Do you see a place for another COM on my panel? :-) Matt At 11:04 AM 5/6/2010 Thursday, you wrote: > >Did I see that right? 3 EFIS screens, a VP-200, and a single COM radio? > >Jesse Saint >Saint Aviation, Inc. >jesse(at)saintaviation.com >Cell: 352-427-0285 >Fax: 815-377-3694 > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: May 06, 2010
Matt, Congratulations on your first flight. The plane looks great and your have done an incredible job of detailing the construction process. I'm sure it will be a great asset for other -8 builders, like myself. Per Jesse's comment, the only thing that you may find desirable in the future is a second COM radio. Not from a reliability standpoint but it terms of situational awareness. I am currently flying a -4 with a very basic VFR panel (496, 1 COM, steam gauges, wing leveler) and the only thing I really feel is missing is another radio. There are so many times that I wish I could be monitoring another frequency (or contacting FSS) while dealing with ATC. Its a constant issue and adding another radio & simple audio panel is at the top of my to do list. Again, great job on the -8. Doug Morrison RV-4 N818WW RV-8 N666NJ (Panel / FWF) Matt Dralle wrote: > > Real men don't need a radio to fly! An spare EFIS, on the other hand, maybe... > > Do you see a place for another COM on my panel? > > :-) > > Matt > > > At 11:04 AM 5/6/2010 Thursday, you wrote: > >> >> Did I see that right? 3 EFIS screens, a VP-200, and a single COM radio? >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> Cell: 352-427-0285 >> Fax: 815-377-3694 >> >> > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > ________________________________________________________________________________
Subject: Gear Leg Fairing Tip
Date: Apr 06, 2010
To my RV-Ten'r Colleagues - I tend to stress about things that are not as complicated as they seem. In this case, how to simplify the alignment of the gear leg fairings? Per Van's plans, you need to create center lines, artificial center lines, Points, A, B, and X. Huh? What? This looks tough. Well it's not if you are willing to spend $30 on something you can leave in your shop and use another day. Here is what I did. 1. Drop a plumb bob from the front and rear of the plane, per plans, and snap a center line. 2. From that center line, use a tape measure to measure out 27" from that center line on both sides at the front and at the rear of the plane. (Note: 27" was a perfect measurement for me!) 3. Snap a chalk line, per plans on both sides. 4. Here's the expensive part - Buy a laser like the one pictured for less than $30 - mine came from Home Depot. 5. Place the Laser at the front of the chalk line. Turn it on- Level the laser per the bubble guides on the laser itself.- and voila!!! A laser mark on the step, and the gear leg fairing IN THE RIGHT PLANE, PERFECTLY VERTICAL, and PERFECTLY PARALLEL to the center line. No plumb-bobbing from the step or fairing required! 6. Stretch the strings - per plans off the bottom of the step where the laser light hits, around the gear leg fairing, where the laser light hits. Hold the string in place with small strips of electrical tape in a cross fashion per pictures attached. 7. Measure up from the floor to both points of light. If the height does not match, adjust the laser left and right of the displaced center line of the chalk line. Keep in mind the step itself is level to the floor, so moving left and right of the chalk line moves the distance to the floor up and down as you move across the leg fairing. It's easy to see if you are parallel to the line, as you can measure to and from the chalk line to the laser line. If none of this makes sense, it will be readily apparent once you set it all up. 8. I got a fabulous/near perfect result, with very little effort in just a couple of minutes. 27" off centerline was exactly what I needed. 9. The attached pictures have a stool at the end of the chalk line in order to show where the light is lined up. All you have to do is put a small object on the chalk line to make it more readily visible when making the initial laser alignment. 10. Note that I drilled holes and cleco'd the fairing onto the wheel pant. I colored a black sharpie dot on the cleco holes prior to laying up the wet glass layers. The black dots make it simple to find the cleco holes through the wet layers. Once the wet layers are on, use a very sharp pick or awl to separate the weave BEFORE you try and put the cleco in, otherwise, the cleco will grab a fiber and pull bubbles into the layup. I placed wax paper down between the pant and between the rear of the fairing. Worked great! 11. I shot the pictures in a darkened shop so the results would be more apparent in the pictures. The laser works fine in a normally lit shop. 12. ..and no, when the police came slowly driving by, I had NOT been shining the laser at airplanes..only the neighbors house a block away! Hope this helps! Pete James ________________________________________________________________________________
Date: May 06, 2010
Well, at least the SL-30 allows you to monitor two frequencies at once. The frequency in the active window has priority, but you can monitor the freq in the standby window at the same time. I use that feature all the time after I land at Ogden. A lot of time only one controller is working and after landing they give you taxi directions and request you monitor ground....all the real action is happening on the tower frequency...... Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doug Morrison Sent: Thursday, May 06, 2010 8:21 PM Subject: Re: RV10-List: RV-8 N998RV First Flight - Pilot Report And Photos! Matt, Congratulations on your first flight. The plane looks great and your have done an incredible job of detailing the construction process. I'm sure it will be a great asset for other -8 builders, like myself. Per Jesse's comment, the only thing that you may find desirable in the future is a second COM radio. Not from a reliability standpoint but it terms of situational awareness. I am currently flying a -4 with a very basic VFR panel (496, 1 COM, steam gauges, wing leveler) and the only thing I really feel is missing is another radio. There are so many times that I wish I could be monitoring another frequency (or contacting FSS) while dealing with ATC. Its a constant issue and adding another radio & simple audio panel is at the top of my to do list. Again, great job on the -8. Doug Morrison RV-4 N818WW RV-8 N666NJ (Panel / FWF) Matt Dralle wrote: > > Real men don't need a radio to fly! An spare EFIS, on the other hand, maybe... > > Do you see a place for another COM on my panel? > > :-) > > Matt > > > At 11:04 AM 5/6/2010 Thursday, you wrote: > >> >> Did I see that right? 3 EFIS screens, a VP-200, and a single COM radio? >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> Cell: 352-427-0285 >> Fax: 815-377-3694 >> >> > > > Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > ________________________________________________________________________________
Date: May 06, 2010
How do you configure the SL-30 to monitor on the standby frequency? Matt At 07:53 PM 5/6/2010 Thursday, you wrote: > >Well, at least the SL-30 allows you to monitor two frequencies at once. The >frequency in the active window has priority, but you can monitor the freq in >the standby window at the same time. I use that feature all the time after >I land at Ogden. A lot of time only one controller is working and after >landing they give you taxi directions and request you monitor ground....all >the real action is happening on the tower frequency...... > >Rene' >801-721-6080 > > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doug Morrison >Sent: Thursday, May 06, 2010 8:21 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: RV-8 N998RV First Flight - Pilot Report And Photos! > > >Matt, > >Congratulations on your first flight. The plane looks great and your >have done an incredible job of detailing the construction process. I'm >sure it will be a great asset for other -8 builders, like myself. > >Per Jesse's comment, the only thing that you may find desirable in the >future is a second COM radio. Not from a reliability standpoint but it >terms of situational awareness. I am currently flying a -4 with a very >basic VFR panel (496, 1 COM, steam gauges, wing leveler) and the only >thing I really feel is missing is another radio. There are so many times >that I wish I could be monitoring another frequency (or contacting FSS) >while dealing with ATC. Its a constant issue and adding another radio & >simple audio panel is at the top of my to do list. > >Again, great job on the -8. > >Doug Morrison >RV-4 N818WW >RV-8 N666NJ (Panel / FWF) > > >Matt Dralle wrote: >> >> Real men don't need a radio to fly! An spare EFIS, on the other hand, >maybe... >> >> Do you see a place for another COM on my panel? >> >> :-) >>
April 17, 2010 - May 06, 2010
RV10-Archive.digest.vol-gl
