RV10-Archive.digest.vol-gn
May 24, 2010 - June 09, 2010
        http://www.matronic================
        <     - MATRONICS WEB FORUMS via the Web    -->
      http://forums.matronics.com         - List Contribution Web generous
      nbsp;                        --> http://www.matronics.com/c
Subject: Re: step drills etc
Date: May 24, 2010
Ok, thx Rick. I kind of wondered about those brackets. I probably will just leave them detached from the cover plates until I start rigging, which appears to be a ways down the road. I have to ask another question. At this point (elevators just about complete), I have 300 man hrs into this project. I noticed on Tim O's web site, he had about 170 hrs at this same point..... I must be really slow or????? How much time did other builders have at this stage? I don't want to set a record as the slowest RV10 build, but still want it done correctly. Maybe I'm a little anal retentive?? All opinions appreciated. Rick Lark #40956 ----- Original Message ----- From: <ricksked(at)cox.net> Cc: "Rick and Sandra Lark" Sent: Monday, May 24, 2010 7:16 PM Subject: Re: RV10-List: step drills etc > Rick, > > Don't use rivets at all to attach those brackets, use machine screws and > stopnuts. You will need to rotate the brackets when rigging the trim, just > bolt them up when you have them adjusted. > > I'm not sure what the problem with the step drill except you ARE drilling > an hole first before using the drill right? They don't start holes very > well. > > Rick Sked > N246RS > Annual time!! > ---- Rick and Sandra Lark wrote: >> Hi all >> >> I'm just about done with my elevator construction and while I'm waiting >> for the prosealed trailing edges to set up I went to rivet the trim cable >> attachment brackets to the cover plates. The plans call out for LP4-3 >> rivets. I've bought the Cleveland Tools brackets but I can't figure out >> why solid rivets wouldn't be used here. Can anyone shed some light on >> why I need to use LP4-3's? >> >> Question 2: Can anyone tell me how to properly use a step drill? I've >> been a woodworker for more than 30 years and have never had a hand tool I >> couldn't figure out how to use. I've now bought 2 different sized drills >> thinking the first one was a dud, but can't seem to get the newer one to >> work worth a d**n either. Case in point, when I tried to drill out the >> .060" front elevator spar for the snap bushing, I would have bent the >> spar before I forced it to drill the proper sizes hole. What am I >> missing???? >> >> Regards, Rick >> >> #40956 >> Southampton, Ont >> > ________________________________________________________________________________
Date: May 24, 2010
I stopped trying to track time, oh, around doing the vertical stab. Work goes a lot faster when you don't waste time tracking it. I know of at least one kit that is below ser. no 40050 that is no where near putting the major parts together, much less finishing. Enjoy the build, satisfy your own quality requirements, and it will be done when it is done. Kelly 40866 Fuselage/fuel system On Mon, May 24, 2010 at 7:56 PM, Rick and Sandra Lark wrote: . > > I have to ask another question. At this point (elevators just about > complete), I have 300 man hrs into this project. I noticed on Tim O's web > site, he had about 170 hrs at this same point..... I must be really slow > or????? How much time did other builders have at this stage? > > I don't want to set a record as the slowest RV10 build, but still want it > done correctly. Maybe I'm a little anal retentive?? > > All opinions appreciated. > > Rick Lark > #40956 ________________________________________________________________________________
Date: May 24, 2010
From: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
My experience with the HF strep bits is that they work fine for x holes (x being dependent on the material drilled). Then suddenly, they seem to wear through a very thin, hardened surface on the bit, and become completely non-functioning junk. Having said that, the HF bits are a good value (!!!). I forget the prices but you can get a set of 3 bits for about the 1/3 the cost of 1 quality bit. I'm on my second set having worn 2 bits out but my '10 is close to finished (did I say that?). I have a quality bit which I'm saving for any more firewall SS holes but there's little other steel on the aircraft. I used the HF bits on aluminum and composite and I'm prepared to ruin 1 or 2 more bits if necessary. To use the HF bits, you just have to be ready to chuck them as soon as they don't seem to be cutting. But on sale, they are really cheap and I have room to store them. YMMV. Bill Rick and Sandra Lark wrote: > Hmmm....Yes you're right Carl. Both drills were cheap Harbor Freight > type drills. I don't usually go the cheap route when it comes to > tools. Not sure now why I even tried. I'll look for a "good" drill. Thx > Rick > > ----- Original Message ----- > *From:* Carl Froehlich > *To:* rv10-list(at)matronics.com > *Sent:* Monday, May 24, 2010 8:33 PM > *Subject:* RE: RV10-List: step drills etc > > I would guess you might be using the Harbor Freight type step > drill. They tend to make rough, less than round holes. I bought a > set figuring I could save a few dollars. Big mistake. > > Try a Unibit brand step drill. Smooth hole every time. If your > local Lowes/Home Depot should have them. If not, Cleaveland Tools > does: http://www.cleavelandtoolstore.com/products.asp?dept=21 > > Carl Froehlich > > RV-8A (540 hrs) > > RV-10 (systems install) > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick > and Sandra Lark > *Sent:* Monday, May 24, 2010 7:06 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: step drills etc > > Hi all > > I'm just about done with my elevator construction and while I'm > waiting for the prosealed trailing edges to set up I went to rivet > the trim cable attachment brackets to the cover plates. The plans > call out for LP4-3 rivets. I've bought the Cleveland Tools > brackets but I can't figure out why solid rivets wouldn't be used > here. Can anyone shed some light on why I need to use LP4-3's? > > Question 2: Can anyone tell me how to properly use a step drill? > I've been a woodworker for more than 30 years and have never had a > hand tool I couldn't figure out how to use. I've now bought 2 > different sized drills thinking the first one was a dud, but can't > seem to get the newer one to work worth a d**n either. Case in > point, when I tried to drill out the .060" front elevator spar for > the snap bushing, I would have bent the spar before I forced it to > drill the proper sizes hole. What am I missing???? > > Regards, Rick > > #40956 > > Southampton, Ont > > * * > > * * > > http://www.matronic=================< - MATRONICS WEB FORUMS via > the Web --> http://forums.matronics.com - List Contribution Web > generous nbsp; --> http://www.matronics.com/c > <http://www.matronics.com/contribution> > > * * <http://www.matronics.com/contribution> > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List* > *href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * ________________________________________________________________________________
Date: May 24, 2010
Enjoy the process. My Dad got sick and passed away during my build...during that time all I knew was I couldn't park my car in the garage because of my "project" which was nothing in comparison to my life at the time My total build time is about 2400 hours, or 5 years 4 months and 23 days. Build time is like a fingerprint...no two are the same. Perserverance is the best ribbon they can give you at Osh.... Rick Sent from my iPhone On May 24, 2010, at 7:56 PM, "Rick and Sandra Lark" wrote: > > > > Ok, thx Rick. I kind of wondered about those brackets. I probably > will just leave them detached from the cover plates until I start > rigging, which appears to be a ways down the road. > > I have to ask another question. At this point (elevators just about > complete), I have 300 man hrs into this project. I noticed on Tim > O's web site, he had about 170 hrs at this same point..... I must > be really slow or????? How much time did other builders have at > this stage? > > I don't want to set a record as the slowest RV10 build, but still > want it done correctly. Maybe I'm a little anal retentive?? > > All opinions appreciated. > > Rick Lark > #40956 > > ----- Original Message ----- From: <ricksked(at)cox.net> > To: > Cc: "Rick and Sandra Lark" > Sent: Monday, May 24, 2010 7:16 PM > Subject: Re: RV10-List: step drills etc > > >> Rick, >> >> Don't use rivets at all to attach those brackets, use machine >> screws and stopnuts. You will need to rotate the brackets when >> rigging the trim, just bolt them up when you have them adjusted. >> >> I'm not sure what the problem with the step drill except you ARE >> drilling an hole first before using the drill right? They don't >> start holes very well. >> >> Rick Sked >> N246RS >> Annual time!! >> ---- Rick and Sandra Lark wrote: >>> Hi all >>> >>> I'm just about done with my elevator construction and while I'm >>> waiting for the prosealed trailing edges to set up I went to rivet >>> the trim cable attachment brackets to the cover plates. The plans >>> call out for LP4-3 rivets. I've bought the Cleveland Tools >>> brackets but I can't figure out why solid rivets wouldn't be used >>> here. Can anyone shed some light on why I need to use LP4-3's? >>> >>> Question 2: Can anyone tell me how to properly use a step drill? >>> I've been a woodworker for more than 30 years and have never had a >>> hand tool I couldn't figure out how to use. I've now bought 2 >>> different sized drills thinking the first one was a dud, but can't >>> seem to get the newer one to work worth a d**n either. Case in >>> point, when I tried to drill out the .060" front elevator spar for >>> the snap bushing, I would have bent the spar before I forced it to >>> drill the proper sizes hole. What am I missing???? >>> >>> Regards, Rick >>> >>> #40956 >>> Southampton, Ont >>> > > ________________________________________________________________________________
Date: May 25, 2010
I watched this carefully... http://www.airspacemag.com/multimedia/videos/Go-For-Launch.html .... and I noticed a lot of people standing around with their hands in their pockets. I can relate. Although my project is a one man effort (with critical assistance from my rivet bucker and life partner Alicia), I spend plenty of time standing around admiring the kit, my progress, my lack of progress, thinking about future progress, smoking a cigar, watching the Waco depart, and otherwise scritching my cat. These are the best of times. Now, I have to admit that I have a Maule to fly when the mood strikes, but I increasingly find myself forcing the issue just to maintain some proficiency (or to get from A to B). Fact is, standing around with my hands in my pockets trying to remember what I planned to do is a lot more fun.. sort of. Enjoy the process and remember it's not work. Bill "trying to get comfortable with my progress as a 4th anniversary approaches" Watson Rick and Sandra Lark wrote: > ....snippetysnip > I have to ask another question. At this point (elevators just about > complete), I have 300 man hrs into this project. I noticed on Tim O's > web site, he had about 170 hrs at this same point..... I must be > really slow or????? How much time did other builders have at this > stage? > > I don't want to set a record as the slowest RV10 build, but still want > it done correctly. Maybe I'm a little anal retentive?? > > All opinions appreciated. > > Rick Lark > #40956 > > ________________________________________________________________________________
Subject: step drills etc
Date: May 25, 2010
Rick Everyone builds at different speeds. I suspect I am about the same time hours wise as you. So dont worry about it take your time pay close attention to the details and you will be fine. John G. Cumins 40864 Mounted elevators to horz stab Emp almost complete -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick and Sandra Lark Sent: Monday, May 24, 2010 7:56 PM Subject: Re: RV10-List: step drills etc Ok, thx Rick. I kind of wondered about those brackets. I probably will just leave them detached from the cover plates until I start rigging, which appears to be a ways down the road. I have to ask another question. At this point (elevators just about complete), I have 300 man hrs into this project. I noticed on Tim O's web site, he had about 170 hrs at this same point..... I must be really slow or????? How much time did other builders have at this stage? I don't want to set a record as the slowest RV10 build, but still want it done correctly. Maybe I'm a little anal retentive?? All opinions appreciated. Rick Lark #40956 ----- Original Message ----- From: <ricksked(at)cox.net> Cc: "Rick and Sandra Lark" Sent: Monday, May 24, 2010 7:16 PM Subject: Re: RV10-List: step drills etc > Rick, > > Don't use rivets at all to attach those brackets, use machine screws and > stopnuts. You will need to rotate the brackets when rigging the trim, just > bolt them up when you have them adjusted. > > I'm not sure what the problem with the step drill except you ARE drilling > an hole first before using the drill right? They don't start holes very > well. > > Rick Sked > N246RS > Annual time!! > ---- Rick and Sandra Lark wrote: >> Hi all >> >> I'm just about done with my elevator construction and while I'm waiting >> for the prosealed trailing edges to set up I went to rivet the trim cable >> attachment brackets to the cover plates. The plans call out for LP4-3 >> rivets. I've bought the Cleveland Tools brackets but I can't figure out >> why solid rivets wouldn't be used here. Can anyone shed some light on >> why I need to use LP4-3's? >> >> Question 2: Can anyone tell me how to properly use a step drill? I've >> been a woodworker for more than 30 years and have never had a hand tool I >> couldn't figure out how to use. I've now bought 2 different sized drills >> thinking the first one was a dud, but can't seem to get the newer one to >> work worth a d**n either. Case in point, when I tried to drill out the >> .060" front elevator spar for the snap bushing, I would have bent the >> spar before I forced it to drill the proper sizes hole. What am I >> missing???? >> >> Regards, Rick >> >> #40956 >> Southampton, Ont >> > ________________________________________________________________________________
Date: May 25, 2010
Here here. Approaching 5 years and I am just finishing the wings. Good part is that avionics and after market "stuff" just keeps getting better the longer it takes me. Bad part is that kit, engine and prop prices keep going up the longer it takes me. :) -Sean #40303 http://rv10.stephensville.com On 5/24/10 10:58 PM, Rick wrote: > > Enjoy the process. My Dad got sick and passed away during my > build...during that time all I knew was I couldn't park my car in the > garage because of my "project" which was nothing in comparison to my > life at the time My total build time is about 2400 hours, or 5 years 4 > months and 23 days. Build time is like a fingerprint...no two are the > same. Perserverance is the best ribbon they can give you at Osh.... > > Rick > > Sent from my iPhone > > On May 24, 2010, at 7:56 PM, "Rick and Sandra Lark" > wrote: > >> >> >> Ok, thx Rick. I kind of wondered about those brackets. I probably >> will just leave them detached from the cover plates until I start >> rigging, which appears to be a ways down the road. >> >> I have to ask another question. At this point (elevators just about >> complete), I have 300 man hrs into this project. I noticed on Tim >> O's web site, he had about 170 hrs at this same point..... I must be >> really slow or????? How much time did other builders have at this >> stage? >> >> I don't want to set a record as the slowest RV10 build, but still >> want it done correctly. Maybe I'm a little anal retentive?? >> >> All opinions appreciated. >> >> Rick Lark >> #40956 >> >> ----- Original Message ----- From: <ricksked(at)cox.net> >> To: >> Cc: "Rick and Sandra Lark" >> Sent: Monday, May 24, 2010 7:16 PM >> Subject: Re: RV10-List: step drills etc >> >> >>> Rick, >>> >>> Don't use rivets at all to attach those brackets, use machine screws >>> and stopnuts. You will need to rotate the brackets when rigging the >>> trim, just bolt them up when you have them adjusted. >>> >>> I'm not sure what the problem with the step drill except you ARE >>> drilling an hole first before using the drill right? They don't >>> start holes very well. >>> >>> Rick Sked >>> N246RS >>> Annual time!! >>> ---- Rick and Sandra Lark wrote: >>>> Hi all >>>> >>>> I'm just about done with my elevator construction and while I'm >>>> waiting for the prosealed trailing edges to set up I went to rivet >>>> the trim cable attachment brackets to the cover plates. The plans >>>> call out for LP4-3 rivets. I've bought the Cleveland Tools >>>> brackets but I can't figure out why solid rivets wouldn't be used >>>> here. Can anyone shed some light on why I need to use LP4-3's? >>>> >>>> Question 2: Can anyone tell me how to properly use a step drill? >>>> I've been a woodworker for more than 30 years and have never had a >>>> hand tool I couldn't figure out how to use. I've now bought 2 >>>> different sized drills thinking the first one was a dud, but can't >>>> seem to get the newer one to work worth a d**n either. Case in >>>> point, when I tried to drill out the .060" front elevator spar for >>>> the snap bushing, I would have bent the spar before I forced it to >>>> drill the proper sizes hole. What am I missing???? >>>> >>>> Regards, Rick >>>> >>>> #40956 >>>> Southampton, Ont >>>> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 25, 2010
Subject: Re: TT Hours?
I have just over 310 hours in less than 2 years, most of it from a grass runway. Rob Hickman N402RH RV-10 ________________________________________________________________________________
Date: May 25, 2010
It depends alot on how you track time. I just write start and end time right on the plans as I check off the steps. At the end of the section go back and add the highlighted times up. My time starts when I am actually working with tools/parts in my hand. I don't count ordering, a picture every now and then, lunch/supper breaks, or reading plans before work starts. It also depends on how much you spent on tools up front, shop conditions, your mechanical ability and comfort using tools that can hurt if not used correctly. Like most said...just enjoy the build, hang some pics of finished rv's/trip pics like I did for motivation, fly/hang out with at least one other builder/rv owner for motivation which I do, and save as much $$$ as possible for the next piece but lastly don't forget the family. My wonderful wife of 21 yrs is a really good riveter now...only had to drill out 2 or 3 so far. My 10 & 7 yr olds are good at clecoing and placing rivets for Dad. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Grayson, KY Bldr# 40983 Ord complete kit 8/24/09; DB Sch del 11/20/09 Emp 12/01/09-3/14/10 332 hrs Wings 3/14/10- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=298871#298871 ________________________________________________________________________________
Date: May 25, 2010
Guys Thx for the advise and words of encouragement concerning build times. I really am enjoying building this aircraft. Maybe that's why I'm so slow, I'm savoring it too much ;-) Tim you are one lucky man to have a spouse that mowed the lawn while you built. Having said that I don't think I'd trust my wife with the mower anyway. I will keep working away at it, and as someone said, "it'll be done when it's done". Thx, Rick #40956 Southampton, Ont > > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: May 26, 2010
Subject: Upcoming class: Composites for RV-10s
It's time for another class on Composites for RV-10s. I'm considering July 17 and 18, 2010, but at this point I have some flexibility for later dates as well. If anyone is interested in having their cabin top fitted to their fuselage during the class, free of charge, please let me know ASAP. You'll get enough from the class to be able to dive in to all the composites on the -10. Others who've taken the course say it's very worthwhile. And, once you're done with the class, you'll have as much telephone support as you need once you start getting sticky (we tell you how to minimize that, too!). Time and weather permitting, I'll do my best to give anyone interested a ride in my RV-10. Here's the description: ************************************* This course will provide an overview of the composite parts and techniques used on Van's Aircraft RV-10 kits. We will focus on correct materials and processes, fitting the composite top and doors, cowl, spinner, fairings, and other composite parts. You will receive hands-on training to identify and use all necessary materials. Examples of completed and in-process assemblies will be available to view. *Who:* Harold Bunyi and Dave Saylor. Harold holds a BS in Aeronautical Engineering and built kitplane parts in the Phillipines for many years. He has worked at AirCrafters for 6 years and spends nearly all his time working with composites. I started working with composite kitplanes in 1998. I am an A&P/IA, and I have finished the composite sections of my personal RV-10 project, along with many other composite and aluminum projects. I received my BS in Aeronautics from San Jose State. *When:* Tentatively July 17 & 18 (Saturday & Sunday) 8AM-4PM Saturday 8AM-3PM Sunday *Where:* AirCrafters Watsonville Airport (KWVI) 140 Aviation Way Watsonville, CA 95076 831-722-9141 www.AirCrafters.aero <http://www.aircraftersllc.com/> Class size is limited to 15 builders $350 payable by cash, check or credit card *Please call or email to register, even if you have emailed, expressing interst in the last few days. 50% deposit is required before July 2nd.*Balance due before class starts. The nearest major airport is San Jose International, a one-hour drive to KWVI. Best lodging is the Watsonville Comfort Inn: 831-728-2300. Ask for the Pilot Discount. Aircraft parking is available at the class site. Please call if we can help with logistics. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: May 26, 2010
Subject: Re: Upcoming class: Composites for RV-10s
Dave, I can make those dates, or dates after OSH, most anytime in August. Thanks for pulling this together. Kelly On 5/26/2010 4:30 PM, Dave Saylor wrote: > It's time for another class on Composites for RV-10s. I'm considering > July 17 and 18, 2010, but at this point I have some flexibility for > later dates as well. > > If anyone is interested in having their cabin top fitted to their > fuselage during the class, free of charge, please let me know ASAP. > > You'll get enough from the class to be able to dive in to all the > composites on the -10. Others who've taken the course say it's very > worthwhile. > > And, once you're done with the class, you'll have as much telephone > support as you need once you start getting sticky (we tell you how to > minimize that, too!). > > Time and weather permitting, I'll do my best to give anyone interested > a ride in my RV-10. > > Here's the description: > > ************************************* > > This course will provide an overview of the composite parts and > techniques used on Van's Aircraft RV-10 kits. We will focus on correct > materials and processes, fitting the composite top and doors, cowl, > spinner, fairings, and other composite parts. You will receive > hands-on training to identify and use all necessary materials. > Examples of completed and in-process assemblies will be available to view. > > *Who:* > Harold Bunyi and Dave Saylor. Harold holds a BS in Aeronautical > Engineering and built kitplane parts in the Phillipines for many > years. He has worked at AirCrafters for 6 years and spends nearly all > his time working with composites. > > I started working with composite kitplanes in 1998. I am an A&P/IA, > and I have finished the composite sections of my personal RV-10 > project, along with many other composite and aluminum projects. I > received my BS in Aeronautics from San Jose State. > > *When:* > Tentatively July 17 & 18 (Saturday & Sunday) > 8AM-4PM Saturday > 8AM-3PM Sunday > > *Where:* > AirCrafters > Watsonville Airport (KWVI) > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 > www.AirCrafters.aero <http://www.aircraftersllc.com/> > > Class size is limited to 15 builders > $350 payable by cash, check or credit card > *Please call or email to register, even if you have emailed, > expressing interst in the last few days. 50% deposit is required > before July 2nd.* Balance due before class starts. > > The nearest major airport is San Jose International, a one-hour drive > to KWVI. > Best lodging is the Watsonville Comfort Inn: 831-728-2300. Ask for the > Pilot Discount. Aircraft parking is available at the class site. > Please call if we can help with logistics. > > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > * > > > * ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Date: May 26, 2010
Count me in tentatively.........will talk to the wife.............next step to send a check or what? From: dave.saylor.aircrafters(at)gmail.com Date: Wed=2C 26 May 2010 16:30:11 -0700 Subject: RV10-List: Upcoming class: Composites for RV-10s It's time for another class on Composites for RV-10s. I'm considering July 17 and 18=2C 2010=2C but at this point I have some flexibility for later d ates as well. If anyone is interested in having their cabin top fitted to their fuselage during the class=2C free of charge=2C please let me know ASAP. You'll get enough from the class to be able to dive in to all the composite s on the -10. Others who've taken the course say it's very worthwhile. And=2C once you're done with the class=2C you'll have as much telephone sup port as you need once you start getting sticky (we tell you how to minimize that=2C too!). Time and weather permitting=2C I'll do my best to give anyone interested a ride in my RV-10. Here's the description: ************************************* This course will provide an overview of the composite parts and techniques used on Van's Aircraft RV-10 kits. We will focus on correct materials and p rocesses=2C fitting the composite top and doors=2C cowl=2C spinner=2C fairi ngs=2C and other composite parts. You will receive hands-on training to ide ntify and use all necessary materials. Examples of completed and in-process assemblies will be available to view. Who: Harold Bunyi and Dave Saylor. Harold holds a BS in Aeronautical Engineering and built kitplane parts in the Phillipines for many years. He has worked at AirCrafters for 6 years and spends nearly all his time working with comp osites. I started working with composite kitplanes in 1998. I am an A&P/IA=2C and I have finished the composite sections of my personal RV-10 project=2C along with many other composite and aluminum projects. I received my BS in Aeron autics from San Jose State. When: Tentatively July 17 & 18 (Saturday & Sunday) 8AM-4PM Saturday 8AM-3PM Sunday Where: AirCrafters Watsonville Airport (KWVI) 140 Aviation Way Watsonville=2C CA 95076 831-722-9141 www.AirCrafters.aero Class size is limited to 15 builders $350 payable by cash=2C check or credit card Please call or email to register=2C even if you have emailed=2C expressing interst in the last few days. 50% deposit is required before July 2nd. Bala nce due before class starts. The nearest major airport is San Jose International=2C a one-hour drive to KWVI. Best lodging is the Watsonville Comfort Inn: 831-728-2300. Ask for the Pilo t Discount. Aircraft parking is available at the class site. Please call if we can help with logistics. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville=2C CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: May 26, 2010
my dates are flex too as long as it doesn't run up against OSH..........I n eed to work once in awhile. > Date: Wed=2C 26 May 2010 20:08:24 -0700 > From: kellym(at)aviating.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Upcoming class: Composites for RV-10s > > > Dave=2C I can make those dates=2C or dates after OSH=2C most anytime in > August. Thanks for pulling this together. > Kelly > > > On 5/26/2010 4:30 PM=2C Dave Saylor wrote: > > It's time for another class on Composites for RV-10s. I'm considering > > July 17 and 18=2C 2010=2C but at this point I have some flexibility for > > later dates as well. > > > > If anyone is interested in having their cabin top fitted to their > > fuselage during the class=2C free of charge=2C please let me know ASAP. > > > > You'll get enough from the class to be able to dive in to all the > > composites on the -10. Others who've taken the course say it's very > > worthwhile. > > > > And=2C once you're done with the class=2C you'll have as much telephone > > support as you need once you start getting sticky (we tell you how to > > minimize that=2C too!). > > > > Time and weather permitting=2C I'll do my best to give anyone intereste d > > a ride in my RV-10. > > > > Here's the description: > > > > ************************************* > > > > This course will provide an overview of the composite parts and > > techniques used on Van's Aircraft RV-10 kits. We will focus on correct > > materials and processes=2C fitting the composite top and doors=2C cowl =2C > > spinner=2C fairings=2C and other composite parts. You will receive > > hands-on training to identify and use all necessary materials. > > Examples of completed and in-process assemblies will be available to vi ew. > > > > *Who:* > > Harold Bunyi and Dave Saylor. Harold holds a BS in Aeronautical > > Engineering and built kitplane parts in the Phillipines for many > > years. He has worked at AirCrafters for 6 years and spends nearly all > > his time working with composites. > > > > I started working with composite kitplanes in 1998. I am an A&P/IA=2C > > and I have finished the composite sections of my personal RV-10 > > project=2C along with many other composite and aluminum projects. I > > received my BS in Aeronautics from San Jose State. > > > > *When:* > > Tentatively July 17 & 18 (Saturday & Sunday) > > 8AM-4PM Saturday > > 8AM-3PM Sunday > > > > *Where:* > > AirCrafters > > Watsonville Airport (KWVI) > > 140 Aviation Way > > Watsonville=2C CA 95076 > > 831-722-9141 > > www.AirCrafters.aero <http://www.aircraftersllc.com/> > > > > Class size is limited to 15 builders > > $350 payable by cash=2C check or credit card > > *Please call or email to register=2C even if you have emailed=2C > > expressing interst in the last few days. 50% deposit is required > > before July 2nd.* Balance due before class starts. > > > > The nearest major airport is San Jose International=2C a one-hour drive > > to KWVI. > > Best lodging is the Watsonville Comfort Inn: 831-728-2300. Ask for the > > Pilot Discount. Aircraft parking is available at the class site. > > Please call if we can help with logistics. > > > > > > Dave Saylor > > AirCrafters LLC > > 140 Aviation Way > > Watsonville=2C CA 95076 > > 831-722-9141 Shop > > 831-750-0284 Cell > > * > > > > > > * > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: May 26, 2010
There is a possibility that I'll be working the bay area that week. If so, this could work out pretty well. Phil From: Roxanne and Mike Lefever [mailto:roxianmike(at)msn.com] Sent: Wednesday, May 26, 2010 10:25 PM Subject: RE: RV10-List: Upcoming class: Composites for RV-10s my dates are flex too as long as it doesn't run up against OSH..........I need to work once in awhile. > Date: Wed, 26 May 2010 20:08:24 -0700 > From: kellym(at)aviating.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Upcoming class: Composites for RV-10s > > > Dave, I can make those dates, or dates after OSH, most anytime in > August. Thanks for pulling this together. > Kelly > > > On 5/26/2010 4:30 PM, Dave Saylor wrote: > > It's time for another class on Composites for RV-10s. I'm considering > > July 17 and 18, 2010, but at this point I have some flexibility for > > later dates as well. > > > > If anyone is interested in having their cabin top fitted to their > > fuselage during the class, free of charge, please let me know ASAP. > > > > You'll get enough from the class to be able to dive in to all the > > composites on the -10. Others who've taken the course say it's very > > worthwhile. > > > > And, once you're done with the class, you'll have as much telephone > > support as you need once you start getting sticky (we tell you how to > > minimize that, too!). > > > > Time and weather permitting, I'll do my best to give anyone interested > > a ride in my RV-10. > > > > Here's the description: > > > > ************************************* > > > > This course will provide an overview of the composite parts and > > techniques used on Van's Aircraft RV-10 kits. We will focus on correct > > materials and processes, fitting the composite top and doors, cowl, > > spinner, fairings, and other composite parts. You will receive > > hands-on training to identify and use all necessary materials. > > Examples of completed and in-process assemblies will be available to view. > > > > *Who:* > > Harold Bunyi and Dave Saylor. Harold holds a BS in Aeronautical > > Engineering and built kitplane parts in the Phillipines for many > > years. He has worked at AirCrafters for 6 years and spends nearly all > > his time working with composites. > > > > I started working with composite kitplanes in 1998. I am an A&P/IA, > > and I have finished the composite sections of my personal RV-10 > > project, along with many other composite and aluminum projects. I > > received my BS in Aeronautics from San Jose State. > > > > *When:* > > Tentatively July 17 & 18 (Saturday & Sunday) > > 8AM-4PM Saturday > > 8AM-3PM Sunday > > > > *Where:* > > AirCrafters > > Watsonville Airport (KWVI) > > 140 Aviation Way > > Watsonville, CA 95076 > > 831-722-9141 > > www.AirCrafters.aero <http://www.aircraftersllc.com/> > > > > Class size is limited to 15 builders > > $350 payable by cash, check or credit card > > *Please call or email to register, even if you have emailed, > > expressing interst in the last few days. 50% deposit is required > > before July 2nd.* Balance due before class starts. > > > > The nearest major airport is San Jose International, a one-hour drive > > to KWVI. > > Best lodging is the Watsonville Comfort Inn: 831-728-2300. Ask for the > > Pilot Discount. Aircraft parking is available at the class site. > > Please call if we can help with logistics. > > > > > > Dave Saylor > > AirCrafters LLC > > 140 Aviation Way > > Watsonville, CA 95076 > > 831-722-9141 Shop > > 831-750-0284 Cell > > * > > > > > > * > ====================== &g====== > > > ________________________________________________________________________________
Date: May 27, 2010
490 TT. Four years. Rob Kermanj Sent from my iPad On May 23, 2010, at 7:38 PM, Rick wrote: > 87 and down now for the first annual > > Rick S. > N246RS > > Sent from my iPhone > > On May 23, 2010, at 5:30 PM, Jesse Saint wrote: > >> Speaking of hours, how many hours are people up to? Tim? Scott? Randy? We're at around 850 on N256H. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> Cell: 352-427-0285 >> Fax: 815-377-3694 >> >> On May 23, 2010, at 6:32 PM, John Cox wrote: >> >>> There were a lot fewer than 1000 hours on N220RV and a lot of history that went with the creation of the SB. Just glad no one else found any. John #40600 >>> >>> >>> >>> -- Sent from my Palm Pre >>> >>> On May 23, 2010 12:28 PM, DLM wrote: >>> >>> While giving a biannual to a friend in the 10 this morning, we were stalling the aircraft. At times we got slow enough to get the prestall buffet. When I looked back at the right hoizontal stab and elevator, I could see a lot of movement. Considering that the IO360 RV10 (220RV?) had 1000+ hours of landings and stalls in training, this may be a reason for the cracks forming. We inspect each annual and have found no cracks or even wrinkles. >>> >>> We also found that the aircraft becomes slightly unstable near the stall prior to the buffet and a slight sink rate developes, therefore we plan to use this to avoid the pre stall buffet and subsequent shaking of the tail. >>> >>> Stall occurred at 53 KIAS with half flaps and 2400# >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >> > > > ________________________________________________________________________________
Subject: windows & fiberglass
Date: May 28, 2010
I'm filling the window joint with glass cloth but having problem getting a good feathered edge to the window. Apparently epoxy resin is not the best for a feathered edge, I've tried mixing with cabosil, not good either. Thinking about the blue polyfiber two part mix but don't know about the bond to plex. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299126#299126 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Headliner adhesive
Date: May 28, 2010
All, I recently installed a foam backed fabric headliner in my RV-10 project. I did test pieces using three different spray adhesives: 3M Super 77 DAP High Strength Permatex 27828 Body Shop Carpet & Headliner Spray The Permatex 27828 was by far the best product. It is available at Amazon.com http://www.amazon.com/Permatex-27828-Headliner-Adhesive-16-75-oz/dp/B000HBNU 9K/ref=sr_1_1?ie=UTF8 <http://www.amazon.com/Permatex-27828-Headliner-Adhesive-16-75-oz/dp/B000HBN U9K/ref=sr_1_1?ie=UTF8&s=automotive&qid=1275054862&sr=8-1> &s=automotive&qid=1275054862&sr=8-1 and at auto parts stores such as Advanced Auto. Carl Froehlich RV-8A (540 hrs) RV-10 (systems install) ________________________________________________________________________________
Subject: Re: windows & fiberglass
Date: May 28, 2010
I will be doing this next week too. I am curious what technique and materials have worked best for both fiberglass thickness (paint cracking) and feathering. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299132#299132 ________________________________________________________________________________
Date: May 28, 2010
I've found resin mixed with flox and cabosil to be the best for a feathered edge. Jeff Carpenter 40304 On May 28, 2010, at 6:57 AM, rvdave wrote: > > I'm filling the window joint with glass cloth but having problem > getting a good feathered edge to the window. Apparently epoxy resin > is not the best for a feathered edge, I've tried mixing with > cabosil, not good either. Thinking about the blue polyfiber two > part mix but don't know about the bond to plex. > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299126#299126 > > ________________________________________________________________________________
Date: May 28, 2010
I'm in the process of doing same this weekend. I have taped off the edge and filled in the gap and am ready to cover with light weight tape/cloth. What techniques and tools work well for creating this edge? Bill "finishing up the glass pieces" Watson 40605 Jeff Carpenter wrote: > > I've found resin mixed with flox and cabosil to be the best for a > feathered edge. > > Jeff Carpenter > 40304 > > > On May 28, 2010, at 6:57 AM, rvdave wrote: > >> >> I'm filling the window joint with glass cloth but having problem >> getting a good feathered edge to the window. Apparently epoxy resin >> is not the best for a feathered edge, I've tried mixing with cabosil, >> not good either. Thinking about the blue polyfiber two part mix but >> don't know about the bond to plex. >> >> -------- >> Dave Ford >> RV6 flying >> RV10 building >> Cadillac, MI >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=299126#299126 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 28, 2010
Bill, Jeff, Dave, Pick up some "fine line tape" from the autobody store. It looks like (may very well be, not sure) narrow electrical tape. I think it comes in 1/8" and 1/4" widths. The narrow width makes it really easy to mask in the tight corners. A nice trick is to run the ends of the tape back into the center of the masked area so you know where find them, like a little freeway on-ramp/off-ramp. Use the fine line tape on the plex where you want the overlay to end. The special tape will keep the resin from getting underneath it. Build up one or two layers over the fine line tape with regular electrical tape. That gives you a little dam to run the resin up to. The glass should stop just short of the dam, maybe 1/32" - 1/16". After the resin has cured, bodywork the glass overlay all the way to the tape with SuperFil or something similar. Jeff, I remember you had problems with the feathered edge not adhering to the base. Flox would be fine in a situation like that but here the filled area will be so small that Superfil should work OK. You won't end up with a smooth feathered edge from the plex to the glass. You'll have a little edge as thick as the tape dam. The paint will go another 1/16-1/4" onto the plex and fair in that little edge very nicely. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Fri, May 28, 2010 at 12:01 PM, Bill Mauledriver Watson < MauleDriver(at)nc.rr.com> wrote: > MauleDriver(at)nc.rr.com> > > I'm in the process of doing same this weekend. > > I have taped off the edge and filled in the gap and am ready to cover with > light weight tape/cloth. > > What techniques and tools work well for creating this edge? > > Bill "finishing up the glass pieces" Watson > 40605 > > > Jeff Carpenter wrote: > >> >> I've found resin mixed with flox and cabosil to be the best for a >> feathered edge. >> >> Jeff Carpenter >> 40304 >> >> >> On May 28, 2010, at 6:57 AM, rvdave wrote: >> >>> >>> I'm filling the window joint with glass cloth but having problem getting >>> a good feathered edge to the window. Apparently epoxy resin is not the best >>> for a feathered edge, I've tried mixing with cabosil, not good either. >>> Thinking about the blue polyfiber two part mix but don't know about the >>> bond to plex. >>> >>> -------- >>> Dave Ford >>> RV6 flying >>> RV10 building >>> Cadillac, MI >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=299126#299126 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: May 28, 2010
Perfect! Thanks so much Dave. Bill "now psyched for the job" Watson Dave Saylor wrote: > Bill, Jeff, Dave, > > Pick up some "fine line tape" from the autobody store. It looks like > (may very well be, not sure) narrow electrical tape. I think it comes > in 1/8" and 1/4" widths. The narrow width makes it really easy to > mask in the tight corners. > > A nice trick is to run the ends of the tape back into the center of > the masked area so you know where find them, like a little freeway > on-ramp/off-ramp. > > Use the fine line tape on the plex where you want the overlay to end. > The special tape will keep the resin from getting underneath it. > > Build up one or two layers over the fine line tape with regular > electrical tape. That gives you a little dam to run the resin up to. > The glass should stop just short of the dam, maybe 1/32" - 1/16". > After the resin has cured, bodywork the glass overlay all the way to > the tape with SuperFil or something similar. Jeff, I remember you had > problems with the feathered edge not adhering to the base. Flox would > be fine in a situation like that but here the filled area will be so > small that Superfil should work OK. > > You won't end up with a smooth feathered edge from the plex to the > glass. You'll have a little edge as thick as the tape dam. The paint > will go another 1/16-1/4" onto the plex and fair in that little edge > very nicely. > > Dave Saylor > AirCrafters LLC > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Fri, May 28, 2010 at 12:01 PM, Bill Mauledriver Watson > > wrote: > > > > > I'm in the process of doing same this weekend. > > I have taped off the edge and filled in the gap and am ready to > cover with light weight tape/cloth. > > What techniques and tools work well for creating this edge? > > Bill "finishing up the glass pieces" Watson > 40605 > > > Jeff Carpenter wrote: > > > > > I've found resin mixed with flox and cabosil to be the best > for a feathered edge. > > Jeff Carpenter > 40304 > > > On May 28, 2010, at 6:57 AM, rvdave wrote: > > > > > I'm filling the window joint with glass cloth but having > problem getting a good feathered edge to the window. > Apparently epoxy resin is not the best for a feathered > edge, I've tried mixing with cabosil, not good either. > Thinking about the blue polyfiber two part mix but don't > know about the bond to plex. > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299126#299126 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * ________________________________________________________________________________
Date: May 28, 2010
Thanks Dave for the tips, the issue I've had so far was bringing the resin to electrical tape which looked fine as I laid it in. The problem began as I began to remove the tape, the overflow of resin on the tape in some places began to pull up on the areas of feathering to the point that it looked as if it did not have good adhesion to the plexiglass. I did sand the plex very well but as I pulled the tape I could see the area turn a whitish color indicating a pulling away. My concern is the adhesion down the road and the pulling away/bubbling of the paint. If I hear you right the last 1/16 inch of polyfiber should feather nicely and resolve the concerns of any pulling of resin from the plex? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299226#299226 ________________________________________________________________________________
Subject: iPad and Skycharts Pro - initial impressions
Date: May 29, 2010
This morning, I test flew the Skycharts on my iPad for the first time. I found Skycharts to be a powerful and simple program; perfect for the iPad. The program comes with all the charts (IFR, VFR, TAC) and plates you need. The subscription is $20 per year, a great value. If you have been playing with your iPad inside the house, you may lose you position fix. Once you go outside and have the view of the sky, it finds your position and you are ready to navigate. You do not need Internet connection to navigate. You begin by typing in your waypoints, the course is drawn on the chart and you are ready to navigate. You can toggle between different charts as you fly. What I really like most is the ability to double click on an airport to get a list of IFR plates. No more looking up your plates by state, city or it's name! Another really nice feature for my age is that you can zoom as much as you need to see all the details. This is really useful on the approach plates and the resolution is perfect at all zoom levels. Zooming and panning is lightning fast, no waiting. Since the developer is very responsive to inquires, there are two things I would like added (I need a lot for my $20): It would be nice to have the program nominate the charts I need to cache based on my flight plan. Right now you decide which charts your course crosses and which charts you will need to cache. It would also be nice to have the Approch plates "georeferenced?" so that you have complete situational awareness while using the plates. I highly recommend this app. Rob Kermanj Sent from my iPad ________________________________________________________________________________
Subject: Skypad2 -- Voyager
Date: May 29, 2010
I got my Skypad2 a week or so ago and so far have been impressed........but I have not flown with it. I did run the Voyager software on my PC and hooked it up to x-plane. Pretty good training tool. Voyager's approach plates are geo referenced. Rene' 801-721-6080 ________________________________________________________________________________
Date: May 29, 2010
Subject: Re: iPad and Skycharts Pro - initial impressions
Which version of the iPad are you using? Is the position derived from cell phone G3 network or a true GPS? If GPS, what are its capabilities? Or is there need for external BT GPS with a BT stack on the iPad? On Sat, May 29, 2010 at 5:47 AM, Rob Kermanj wrote: > > This morning, I test flew the Skycharts on my iPad for the first time. I found Skycharts to be a powerful and simple program; perfect for the iPad. > > The program comes with all the charts (IFR, VFR, TAC) and plates you need. The subscription is $20 per year, a great value. > > If you have been playing with your iPad inside the house, you may lose you position fix. Once you go outside and have the view of the sky, it finds your position and you are ready to navigate. You do not need Internet connection to navigate. > > You begin by typing in your waypoints, the course is drawn on the chart and you are ready to navigate. You can toggle between different charts as you fly. > > What I really like most is the ability to double click on an airport to get a list of IFR plates. No more looking up your plates by state, city or it's name! > > Another really nice feature for my age is that you can zoom as much as you need to see all the details. This is really useful on the approach plates and the resolution is perfect at all zoom levels. Zooming and panning is lightning fast, no waiting. > > Since the developer is very responsive to inquires, there are two things I would like added (I need a lot for my $20): > > It would be nice to have the program nominate the charts I need to cache based on my flight plan. Right now you decide which charts your course crosses and which charts you will need to cache. > > It would also be nice to have the Approch plates "georeferenced?" so that you have complete situational awareness while using the plates. > > I highly recommend this app. > > Rob Kermanj > Sent from my iPad > > ________________________________________________________________________________
Date: May 29, 2010
Subject: Re: Skypad2 -- Voyager
Look forward to report from a flight or two. Especially responsiveness for screen updates. I've seen original Skypad, and software is very nice, tablet computer was a bit heavy and fat for use on kneeboard or lap. Hmm, maybe room for it on the tunnel? Kelly On Sat, May 29, 2010 at 6:12 AM, Rene wrote: > > I got my Skypad2 a week or so ago and so far have been impressed........but > I have not flown with it. I did run the Voyager software on my PC and > hooked it up to x-plane. Pretty good training tool. > > Voyager's approach plates are geo referenced. > > Rene' 0 > > ________________________________________________________________________________
Date: May 29, 2010
Dave, If the resin is peeling up with the tape, there could be a few different things going on. Keep in mind that the chemical bond between typical laminating resin and plex is never great. You get a decent mechanical bond by scuffing the plex, as you did. Not to digress, but Weld-On, for example, does a better job bonding chemically to the plex than laminating resin ever does. By reinforcing the resin with the fiberglass layers, you can sort of cantilever a little bridge out over the plex. The glass helps the bridge be stiff enough to ensure that the relatively weak bond to the plex is protected, that the bond to the plex doesn't see a peeling load, and it stays stuck. What may be happening in your case is that the body of resin between the edge of the glass and the tape is too wide. Then the un-reinforced resin could be flexible enough that removing the tape breaks the weak resin bond. If that's the case, then you'll need the glass to be closer to the edge of the tape. Or, you may have some resin still overlapping the tape so when the tape was lifted it pulled on the resin too. You'll need to sand all the way down to the tape to make sure that the only part of the resin touching the tape is the tiny vertical "thickness". By all means make sure that the glass doesn't overlap the tape. One thing you might want to change is the way that you remove the tape. Once you get an inch or so of the tape lifted off the plex, try folding the tail of the tape back around so the sticky side is up, and pull the tail back at 90* to the masked edge--see attached photo. That puts the least amount of peeling stress on the resin/plex bond. Another problem might be that the resin is still a little soft. There's a period before it's fully cured when it's still kind of rubbery and it might pull off the plex. You have to be super careful if you decide to try to warm the resin around plex--the plex starts to deform at relatively low temps (see: my windshield-grr). We use electric blankets almost exclusively now whenever we want to hurry up a curing cycle. Let me know if you think you have something different going on. We'll get it figured out. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Fri, May 28, 2010 at 7:01 PM, rvdave wrote: > > Thanks Dave for the tips, the issue I've had so far was bringing the resin > to electrical tape which looked fine as I laid it in. The problem began as > I began to remove the tape, the overflow of resin on the tape in some places > began to pull up on the areas of feathering to the point that it looked as > if it did not have good adhesion to the plexiglass. I did sand the plex > very well but as I pulled the tape I could see the area turn a whitish color > indicating a pulling away. My concern is the adhesion down the road and the > pulling away/bubbling of the paint. If I hear you right the last 1/16 inch > of polyfiber should feather nicely and resolve the concerns of any pulling > of resin from the plex? > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299226#299226 > > ________________________________________________________________________________
Date: May 29, 2010
I just saw an email update from the folks at foreflight on this. The gps works ok at altitude and doesn't need 3g, but they were unhappy with it's accuracy during climbs and descents, enough so that it sounds like they decided georeferenced approach plates is something they don't want to do right now....for safety. I'm sure with the Bluetooth add-on that it would work ok, but since apple just is too pig headed to allow that option, for non-jailbreakers you'll have to suffer with less accuracy. I love how well ipad works for what it does right...but it has it's flaws too. Tim On May 29, 2010, at 9:15 AM, Kelly McMullen wrote: > > Which version of the iPad are you using? Is the position derived from > cell phone G3 network or a true GPS? If GPS, what are its > capabilities? Or is there need for external BT GPS with a BT stack on > the iPad? > > On Sat, May 29, 2010 at 5:47 AM, Rob Kermanj > wrote: >> >> This morning, I test flew the Skycharts on my iPad for the first >> time. I found Skycharts to be a powerful and simple program; >> perfect for the iPad. >> >> The program comes with all the charts (IFR, VFR, TAC) and plates >> you need. The subscription is $20 per year, a great value. >> >> If you have been playing with your iPad inside the house, you may >> lose you position fix. Once you go outside and have the view of the >> sky, it finds your position and you are ready to navigate. You do >> not need Internet connection to navigate. >> >> You begin by typing in your waypoints, the course is drawn on the >> chart and you are ready to navigate. You can toggle between >> different charts as you fly. >> >> What I really like most is the ability to double click on an >> airport to get a list of IFR plates. No more looking up your plates >> by state, city or it's name! >> >> Another really nice feature for my age is that you can zoom as much >> as you need to see all the details. This is really useful on the >> approach plates and the resolution is perfect at all zoom levels. >> Zooming and panning is lightning fast, no waiting. >> >> Since the developer is very responsive to inquires, there are two >> things I would like added (I need a lot for my $20): >> >> It would be nice to have the program nominate the charts I need to >> cache based on my flight plan. Right now you decide which charts >> your course crosses and which charts you will need to cache. >> >> It would also be nice to have the Approch plates "georeferenced?" >> so that you have complete situational awareness while using the >> plates. >> >> I highly recommend this app. >> >> Rob Kermanj >> Sent from my iPad >> >> >> >> >> > > ________________________________________________________________________________
Date: May 29, 2010
Subject: AirVenture Cup
Is anyone planning on entering the AirVenture Cup in an RV-10 this year? The rules say the crew is limited to two but the organizer tells me they would make an exception, maybe even another class if there are enough 10s. We're thinking of entering this year with three on board. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: May 29, 2010
I flew with my new iPad last weekend for the first time using plates downloaded from www.nacomatic.com using Goodreader for iPad. Played with it at home before taking it in the plane, which I recommend. Easy to bookmark approaches ahead of time for your route. Charts and airfield diagrams (appear to be .pdf copies of the green book pages) are free and you can make a contribution if you want to help them keep the site going. Takes a while to download, so I now download to desktop, connect iPad and transfer. No room on my tunnel and a little big to strap to my knee, so waiting for the RAM iPad holder to appear in mid June, then use some RAM ball joints and connect to the bar going from glare shield to the cabin top. That way it will be facing me at eye level and just to the right of my RAM mounted 396. A little glare in bright sunlight, and have not tried it at night or in the soup yet, but think it's going to work just fine. grumpy N184JM On May 29, 2010, at 9:17 AM, Kelly McMullen wrote: > > Look forward to report from a flight or two. Especially responsiveness > for screen updates. I've seen original Skypad, and software is very > nice, tablet computer was a bit heavy and fat for use on kneeboard or > lap. Hmm, maybe room for it on the tunnel? > Kelly > > On Sat, May 29, 2010 at 6:12 AM, Rene wrote: >> >> I got my Skypad2 a week or so ago and so far have been >> impressed........but >> I have not flown with it. I did run the Voyager software on my PC >> and >> hooked it up to x-plane. Pretty good training tool. >> >> Voyager's approach plates are geo referenced. >> >> Rene' > 0 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Oil Cooler
Date: May 29, 2010
I remember some folks have upgraded oil coolers to one from Alex D what is his contact # and the model # that works in the 10. Gary Specketer ________________________________________________________________________________
Subject: Oil Cooler
Date: May 29, 2010
>From my order. Qty Item # Description Date Shipped Tracking # ---------------------------------------------------------------------------- ----- 2 LOU-12 Louver 12 1 2006X X-SERIES Oil Cooler for 160 hp to 280 hp 1 Glock RV Gust Lock ---------------------------------------------------------------------------- ----- Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Saturday, May 29, 2010 12:54 PM Subject: RV10-List: Oil Cooler I remember some folks have upgraded oil coolers to one from Alex D what is his contact # and the model # that works in the 10. Gary Specketer ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: May 29, 2010
Subject: Oil Cooler
http://www.shop.aviationtechproducts.com/ part # on his site is 2006X. From the web site: Flight testing on the popular RV series of aircraft has shown oil temperatu re drops of 10 -15 degrees F for coolers of the same size in the same locat ion. Not FAA approved. They come in three sizes, Part# 2002X is for Horsepo wer 65 hp to 160 hp Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of gary Sent: Saturday, May 29, 2010 1:54 PM Subject: RV10-List: Oil Cooler I remember some folks have upgraded oil coolers to one from Alex D what is his contact # and the model # that works in the 10. Gary Specketer ________________________________________________________________________________
Date: May 29, 2010
I am using the Wi-Fi 3g. The latest. Apple says the position is arrived any and al three. If using the satellite only, you must have it view the horizon and try different positions to lock the location. I really can't comment on the GPS capabilities since this thing is brand spanking new to me . I will provide updates as i learn more. I am sure that a bluetooth gps will provide faster locks but may also drain the battery quicker. On May 29, 2010, at 10:15 AM, Kelly McMullen wrote: > > Which version of the iPad are you using? Is the position derived from > cell phone G3 network or a true GPS? If GPS, what are its > capabilities? Or is there need for external BT GPS with a BT stack on > the iPad? > > On Sat, May 29, 2010 at 5:47 AM, Rob Kermanj wrote: >> >> This morning, I test flew the Skycharts on my iPad for the first time. I found Skycharts to be a powerful and simple program; perfect for the iPad. >> >> The program comes with all the charts (IFR, VFR, TAC) and plates you need. The subscription is $20 per year, a great value. >> >> If you have been playing with your iPad inside the house, you may lose you position fix. Once you go outside and have the view of the sky, it finds your position and you are ready to navigate. You do not need Internet connection to navigate. >> >> You begin by typing in your waypoints, the course is drawn on the chart and you are ready to navigate. You can toggle between different charts as you fly. >> >> What I really like most is the ability to double click on an airport to get a list of IFR plates. No more looking up your plates by state, city or it's name! >> >> Another really nice feature for my age is that you can zoom as much as you need to see all the details. This is really useful on the approach plates and the resolution is perfect at all zoom levels. Zooming and panning is lightning fast, no waiting. >> >> Since the developer is very responsive to inquires, there are two things I would like added (I need a lot for my $20): >> >> It would be nice to have the program nominate the charts I need to cache based on my flight plan. Right now you decide which charts your course crosses and which charts you will need to cache. >> >> It would also be nice to have the Approch plates "georeferenced?" so that you have complete situational awareness while using the plates. >> >> I highly recommend this app. >> >> Rob Kermanj >> Sent from my iPad >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: May 29, 2010
Hopefully they have made the conclusion using the Wi-Fi 3G model. There are some things to consider for the GPS location to work: 1. The Location Service must be "on". 2. The time must be set to "automatic". It should not be set manually. The setting should also be the same on the desk top being used to sync the iPad. I learned from Airguide Publication folks at Sun/Fun that they will have a bluetooth GPS for their subscription. Not sure if it will have to be hacked to work. I have to admit, obvious from the subject line, that this is my initial report. I did make two approaches to min. and was impressed. However, I am just as happy to be able to have the charts and plates on the screen and navigate the old fashion way, with my panel GPS. After all, we all have at least two GPSs to use for navigation. On May 29, 2010, at 12:32 PM, Tim Olson wrote: > > I just saw an email update from the folks at foreflight on this. The gps works ok at altitude and doesn't need 3g, but they were unhappy with it's accuracy during climbs and descents, enough so that it sounds like they decided georeferenced approach plates is something they don't want to do right now....for safety. I'm sure with the Bluetooth add-on that it would work ok, but since apple just is too pig headed to allow that option, for non-jailbreakers you'll have to suffer with less accuracy. > I love how well ipad works for what it does right...but it has it's flaws too. > Tim > > > > On May 29, 2010, at 9:15 AM, Kelly McMullen wrote: > >> >> Which version of the iPad are you using? Is the position derived from >> cell phone G3 network or a true GPS? If GPS, what are its >> capabilities? Or is there need for external BT GPS with a BT stack on >> the iPad? >> >> On Sat, May 29, 2010 at 5:47 AM, Rob Kermanj wrote: >>> >>> This morning, I test flew the Skycharts on my iPad for the first time. I found Skycharts to be a powerful and simple program; perfect for the iPad. >>> >>> The program comes with all the charts (IFR, VFR, TAC) and plates you need. The subscription is $20 per year, a great value. >>> >>> If you have been playing with your iPad inside the house, you may lose you position fix. Once you go outside and have the view of the sky, it finds your position and you are ready to navigate. You do not need Internet connection to navigate. >>> >>> You begin by typing in your waypoints, the course is drawn on the chart and you are ready to navigate. You can toggle between different charts as you fly. >>> >>> What I really like most is the ability to double click on an airport to get a list of IFR plates. No more looking up your plates by state, city or it's name! >>> >>> Another really nice feature for my age is that you can zoom as much as you need to see all the details. This is really useful on the approach plates and the resolution is perfect at all zoom levels. Zooming and panning is lightning fast, no waiting. >>> >>> Since the developer is very responsive to inquires, there are two things I would like added (I need a lot for my $20): >>> >>> It would be nice to have the program nominate the charts I need to cache based on my flight plan. Right now you decide which charts your course crosses and which charts you will need to cache. >>> >>> It would also be nice to have the Approch plates "georeferenced?" so that you have complete situational awareness while using the plates. >>> >>> I highly recommend this app. >>> >>> Rob Kermanj >>> Sent from my iPad >>> >>> >>> >>> >>> >> >> >> >> > > > > ________________________________________________________________________________
Date: May 30, 2010
dave.saylor.aircrafters(a wrote: > Dave, > > If the resin is peeling up with the tape, there could be a few different things going on. > > What may be happening in your case is that the body of resin between the edge of the glass and the tape is too wide. Then the un-reinforced resin could be flexible enough that removing the tape breaks the weak resin bond. If that's the case, then you'll need the glass to be closer to the edge of the tape. > > Or, you may have some resin still overlapping the tape so when the tape was lifted it pulled on the resin too. You'll need to sand all the way down to the tape to make sure that the only part of the resin touching the tape is the tiny vertical "thickness". By all means make sure that the glass doesn't overlap the tape. > > > > > [/quote] Dave, I think this is probably what is happening, a combination of not enough glass close to the tape, too wide of a resin bridge, and resin left on the tape. So I'll redo & leave a smaller gap, use polyfiber to feather in to the tape, then sand the electrical tape to remove any film that may pull. I'm assuming two layers of glass would be sufficient. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299412#299412 ________________________________________________________________________________
Subject: Re: Oil Cooler
Date: May 31, 2010
Alex is very good to deal with: Aviation Tech Products 2911 N. Mockingbird Ln Midlothian, TX 76065 972-775-1896 aviationtechproducts.com Oil cooler is about $400 - with the discount from deleting it from Vans FWF order it will cost you about $100 - well worth it. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299450#299450 ________________________________________________________________________________
Subject: First formal report on RV 10 explosion
Date: May 31, 2010
Here is a tragedy... though we must note that its a tragedy that could have been FAR worse. The loss of a carefully crafted Experimental, especially a really prized airframe like the RV-10, is tragic, but the fact that everyone escaped unharmed (pretty much) is a blessing. NTSB Identification: ERA10LA256 14 CFR Part 91: General Aviation Accident occurred Friday, May 07, 2010 in Ridgeland, SC Aircraft: SWEZEY T/MOLNAR D VANS RV-10, registration: N110TD Injuries: 2 Serious. This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. On May 7, 2010, about 1511 eastern daylight time, an experimental amateur-built Vans RV-10, N110TD, was destroyed during an explosion after landing at Ridgeland Airport (3J1), Ridgeland, South Carolina. The certificated private pilot and passenger were seriously injured. Visual meteorological conditions prevailed, and no flight plan was filed for the personal flight, which was conducted under the provisions of Title 14 Code of Federal Regulations Part 91. According to the pilot, earlier in the day he fueled the airplane with automotive fuel which contained 10 percent alcohol, flew to Athens/Ben Epps Airport (AHN), Athens, GA, picked up his passenger and then departed from AHN about 1400. The flight was flown at an altitude of 9,500 feet above mean sea level and everything "seemed normal." While the airplane was on short final, "about 200 feet from the runway," he had a "brief whiff" of an odor similar to "a gas smell." Upon landing the passenger asked if they should open the door and the pilot stated "wait [un]til we clear the runway." The airplane back taxied on the runway a short distance and exited the runway on the taxiway adjacent to the ramp area. As the airplane exited the runway an explosion caused the windows and door to be blown out. He stated that it was similar to a "vapor fire" in that there was an intense flash of heat and fire; however, it did not last long. The occupants exited the airplane. The pilot returned to the airplane, utilized the on board hand held fire extinguisher, and extinguished the fire on the floor of the cabin. As he was walking away from the airplane towards his passenger, the airplane "exploded" a second time and was engulfed in flames within moments. The pilot normally "raises the flaps after clearing the runway;" however, could not recall if he had raised the flaps just prior to the first explosion. RV-10 File Photo According to the co-owner of the airplane it had been inspected on January 2, 2010 and the "tunnel" for the fuel line was inspected and free of debris. He stated that normally they use "93 octane auto fuel;" however, they can use 100 LL aviation fuel. He further stated that he had flown the airplane about 2 or 3 weeks prior and did not detect any odors. Examination of the airplane by Federal Aviation Administration (FAA) aviation safety inspectors revealed that the airplane was completely consumed by fire. Only a small portion of the tail section, and the engine area forward of the firewall had not been consumed by fire. The pilot held a private pilot certificate with a rating for airplane single-engine land and a repair man experimental aircraft builder certificate with inspection certificate for the accident airplane. The pilot's most recent FAA third-class medical certificate was issued in April 2009. During a phone interview with the NTSB investigator in charge the pilot reported approximately 300 total hours of flight experience and approximately 135 total hours of flight experience in the accident airplane. He further reported that his logbook was in the airplane at the time of the accident. According to FAA records, the airplane was manufactured and issued a special airworthiness certificate in 2008. The airplane was equipped with a Chevrolet 2006 LS-2 engine and a Vesta 3B78 propeller. The pilot reported to the NTSB that during the accident flight the airplane had just gone over 150 total hours time in service. The 1456 recorded weather at Beaufort Marine Corp Air Station (NBC), Beaufort, South Carolina located 14 nautical miles to the east of the accident location included winds from 140 degrees at 5 knots, visibility 7 miles, few clouds at 6,000 feet above ground level, temperature 32 degrees C, dew point 16 degrees C, and the altimeter setting was 29.98 inches of mercury. ________________________________________________________________________________
Subject: Re: First formal report on RV 10 explosion
Date: May 31, 2010
What an awful scenario! Sincerely hope they recover. Sent from my iPad On May 31, 2010, at 10:17 AM, Miller John wrote: > Here is a tragedy... though we must note that its a tragedy that could have been FAR worse. The loss of a carefully crafted Experimental, especially a really prized airframe like the RV-10, is tragic, but the fact that everyone escaped unharmed (pretty much) is a blessing. > > NTSB Identification: ERA10LA256 > 14 CFR Part 91: General Aviation > Accident occurred Friday, May 07, 2010 in Ridgeland, SC > Aircraft: SWEZEY T/MOLNAR D VANS RV-10, registration: N110TD > Injuries: 2 Serious. > > This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. > > On May 7, 2010, about 1511 eastern daylight time, an experimental amateur-built Vans RV-10, N110TD, was destroyed during an explosion after landing at Ridgeland Airport (3J1), Ridgeland, South Carolina. The certificated private pilot and passenger were seriously injured. Visual meteorological conditions prevailed, and no flight plan was filed for the personal flight, which was conducted under the provisions of Title 14 Code of Federal Regulations Part 91. > > According to the pilot, earlier in the day he fueled the airplane with automotive fuel which contained 10 percent alcohol, flew to Athens/Ben Epps Airport (AHN), Athens, GA, picked up his passenger and then departed from AHN about 1400. The flight was flown at an altitude of 9,500 feet above mean sea level and everything "seemed normal." While the airplane was on short final, "about 200 feet from the runway," he had a "brief whiff" of an odor similar to "a gas smell." Upon landing the passenger asked if they should open the door and the pilot stated "wait [un]til we clear the runway." The airplane back taxied on the runway a short distance and exited the runway on the taxiway adjacent to the ramp area. As the airplane exited the runway an explosion caused the windows and door to be blown out. He stated that it was similar to a "vapor fire" in that there was an intense flash of heat and fire; however, it did not last long. The occupants exited the airplane. The pilot returned to the airplane, utilized the on board hand held fire extinguisher, and extinguished the fire on the floor of the cabin. As he was walking away from the airplane towards his passenger, the airplane "exploded" a second time and was engulfed in flames within moments. The pilot normally "raises the flaps after clearing the runway;" however, could not recall if he had raised the flaps just prior to the first explosion. > > > > RV-10 File Photo > > According to the co-owner of the airplane it had been inspected on January 2, 2010 and the "tunnel" for the fuel line was inspected and free of debris. He stated that normally they use "93 octane auto fuel;" however, they can use 100 LL aviation fuel. He further stated that he had flown the airplane about 2 or 3 weeks prior and did not detect any odors. > > Examination of the airplane by Federal Aviation Administration (FAA) aviation safety inspectors revealed that the airplane was completely consumed by fire. Only a small portion of the tail section, and the engine area forward of the firewall had not been consumed by fire. > > The pilot held a private pilot certificate with a rating for airplane single-engine land and a repair man experimental aircraft builder certificate with inspection certificate for the accident airplane. The pilot's most recent FAA third-class medical certificate was issued in April 2009. During a phone interview with the NTSB investigator in charge the pilot reported approximately 300 total hours of flight experience and approximately 135 total hours of flight experience in the accident airplane. He further reported that his logbook was in the airplane at the time of the accident. > > According to FAA records, the airplane was manufactured and issued a special airworthiness certificate in 2008. The airplane was equipped with a Chevrolet 2006 LS-2 engine and a Vesta 3B78 propeller. The pilot reported to the NTSB that during the accident flight the airplane had just gone over 150 total hours time in service. > > > > The 1456 recorded weather at Beaufort Marine Corp Air Station (NBC), Beaufort, South Carolina located 14 nautical miles to the east of the accident location included winds from 140 degrees at 5 knots, visibility 7 miles, few clouds at 6,000 feet above ground level, temperature 32 degrees C, dew point 16 degrees C, and the altimeter setting was 29.98 inches of mercury. ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: May 31, 2010
>I'm assuming two layers of glass would be sufficient.< Definitely. One layer of 7781 (very common cloth) should be enough. Dave ________________________________________________________________________________
Subject: Nose gear fairing trim for IO-540 only
Date: Jun 01, 2010
Just to satisfy my curiosity, i am wondering about page 48-23, the nose fairing template has a line that says "Trim here for IO-540 left side only". I can't see why the cutout is needed. Does anyone know? Thanks, Jae #40533 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299662#299662 ________________________________________________________________________________
Date: Jun 01, 2010
Prop governor -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jchang10 Sent: Tuesday, June 01, 2010 9:14 PM Subject: RV10-List: Nose gear fairing trim for IO-540 only Just to satisfy my curiosity, i am wondering about page 48-23, the nose fairing template has a line that says "Trim here for IO-540 left side only". I can't see why the cutout is needed. Does anyone know? Thanks, Jae #40533 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299662#299662 ________________________________________________________________________________
Subject: Re: Nose gear fairing trim for IO-540 only
Date: Jun 01, 2010
I thought it was for the vent hanger fairing that is on one side coming down the middle bottom of the cowling. I'm not sure, I don't have my plans in front of me. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299680#299680 ________________________________________________________________________________
Date: Jun 01, 2010
The bracket that holds the bottom fairing in the center (basically the gap between the gear and bottom fusellage) is in that location. Pascal #40720 so close to starting to finish -------------------------------------------------- From: "jchang10" <jc-matronics_rv10(at)jline.com> Sent: Tuesday, June 01, 2010 6:13 PM Subject: RV10-List: Nose gear fairing trim for IO-540 only > > Just to satisfy my curiosity, i am wondering about page 48-23, the nose > fairing template has a line that says "Trim here for IO-540 left side > only". I can't see why the cutout is needed. Does anyone know? > > Thanks, > Jae > #40533 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299662#299662 > > > ________________________________________________________________________________
Date: Jun 01, 2010
oh, yeah, i forgot about that bracket. thanks! Jae On 6/1/2010 8:52 PM, Pascal wrote: > > The bracket that holds the bottom fairing in the center (basically the > gap between the gear and bottom fusellage) is in that location. > Pascal > #40720 > so close to starting to finish > > ________________________________________________________________________________
Date: Jun 02, 2010
Pascal, and group.... Make a new bracket to support the bottom cowl... heav ier material, and wider.... otherwise it WILL break.- I was just installi ng the one I made (of course I made several) and Mark Carey came by to ck o n my progress.... and said his just broke. Texas status:- Kim made it to the Pecan Platation here in Texas about an hour before I did .- About 1,400 miles.... two--4 hour flights seperated by a short ref ueling stop.- No problems... with the exception of the one towering cumul ous, that I thought contained no lightning.... at least until I was skirtin g the edge.... then lighning,.... then I turned to create more distance bet ween it and me... and I succeeded in escaping. Will keep in touch.--- Don --- On Tue, 6/1/10, Jae Chang wrote: From: Jae Chang <jc-matronics_rv10(at)jline.com> Subject: Re: RV10-List: Nose gear fairing trim for IO-540 only Date: Tuesday, June 1, 2010, 9:30 PM oh, yeah, i forgot about that bracket. thanks! Jae On 6/1/2010 8:52 PM, Pascal wrote: > > The bracket that holds the bottom fairing in the center (basically the > gap between the gear and bottom fusellage) is in that location. > Pascal > #40720 > so close to starting to finish > > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Subject: Stein eyeball vents
Date: Jun 02, 2010
Was wondering which eyeball vents from Stein are suited for the flange on the forward NACA vents on either side of the instrument panel. To use his I assume you make a 3 inch square plate to mount on the NACA vent flange and then drill appropriate size hole in plate to mount vent directly to said flange (no SCAT needed). SO should I get the 1.25 or 2 inch eyeballs? Thanks Chris Lucas ________________________________________________________________________________
Subject: Re: Stein eyeball vents
Date: Jun 02, 2010
I had originally purchased the 1 3/4" Stein vents, made the flanges you mentioned. The 1 3/4" vents come with a duct that threads onto the vent and allows the scat tubing to attach to the vent (although the duct would not be used as the vent is mounted directly to the NASA flange). Using the duct is the only means to attach the vent to a flange (unless you can find a thin nut with the very fine threads that match the actual eyeball vent). I had machined the duct or cut off the last bit of the duct to use as a nut and mounted the make shift nut and vent to the flange. We then decided to go with a carbon fiber panel and the above would not fit as the eyeball vent mounts into the carbon panel ( I sold the modified vents) .We purchased the smaller ones. I have not flown the A/C yet , hopefully soon, but I think I would prefer the 1 3/4" if I were to use the Van's panel, but I do believe the smaller ones would be easier to mount as the nut I had to fabricate comes with the smaller ones. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299803#299803 ________________________________________________________________________________
Date: Jun 03, 2010
Why aren't you using the SV-6 vents that Vans sells? They look and work well with no shortcommings as far as I know. Albert Gardner Yuma, AZ ________________________________________________________________________________
Subject: 2010 OSH RV-10 HQ Camping
Date: Jun 03, 2010
It's getting to be that time of year because phone calls and emails have started! Gary and I will again stake out sites for those who are interested in being in the RV-10 HQ area. In past years this has been a group of around 25 RV-10 folks ranging from those just starting the tail kit to those that have been flying for multiple years. Additionally weve traditionally facilitated a couple of large cookouts where those not camping with us can attend typically upwards of 75-100 people including some notable vendors. We will again stake out the sites on the Tuesday before Airventure starts which is 7/20 this year. Payment is required in advance from the first night through the Sunday night at the end of Airventure which winds up being 13 nights. Price this year is $22 per night which comes out to $286. You can either mail me a check (contact me offline for address) or use PayPal. PayPal is much easier all the way around but there's a fee of about $9 that they'll take out so if you use that service you'll need to send $295. Heres how it works if youre interested: Gary, Tim and I (and wives) simply facilitate this for the good of the group. Cost is actual cost of the sites - this is not a profit making venture. Your campsite will be in your name (I will need your EAA number) and will be paid for with a check rather than a credit card. This means if you leave early you will receive a check from EAA when you turn in your site registration on your way out of the campgrounds. I will check with Tim to see if hes willing to once again have info on his website to facilitate people leaving early coordinating with others coming late in the week. Summary, if you want a campsite with the group: - I need $286 from you ($295 if using PayPal) no later than 7/14/2010. - If using PayPal, please send to bcondrey at cox dot net - I will need your EAA number for the registration and your membership must be valid through at least August 2010. - It would be helpful if you'd send me an email with the date you're planning to arrive and leave and the type of camper (Class A, tent, etc) - We'll use our best judgment for the group location based on what's available when we get there but our target will be in the same area that we've been the last few years which is immediately south of Pauls Park in Camp Scholler (around 55th and Lindbergh). - Sites get tagged as required using a little logic based on size of the camper, tent vs. Class A motorhome, whether youve got kids, etc. If you dont like the location you can swap around when you get there. - Well have your car pass, etc. at one of our sites and you simply call when you get close and somebody meet you at the registration gate. Most questions can be answered with the info from last year on Tims website at: www.myrv10.com/osh/Camping_FAQ.html Ill post more info and a reminder in a few weeks when it gets closer. Bob RV-10 N442PM (flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299863#299863 ________________________________________________________________________________
Date: Jun 03, 2010
If Steins go on satisfactorily I'll save $50 for the pair. -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, June 03, 2010 10:23 AM Subject: RE: RV10-List: Re: Stein eyeball vents Why aren't you using the SV-6 vents that Vans sells? They look and work well with no shortcommings as far as I know. Albert Gardner Yuma, AZ ________________________________________________________________________________
Date: Jun 03, 2010
Albert Gardner wrote: > > Why aren't you using the SV-6 vents that Vans sells? They look and work well > with no shortcommings as far as I know. > Well, the $150 price tag might be a considered a shortcoming.!!! I'd need 6. $900 will be used in a lot of other places! Linn > Albert Gardner > Yuma, AZ > > > ________________________________________________________________________________
Subject: Elevator balance weigth arms
Date: Jun 03, 2010
Well I have a slight issue I would like everyone's opinion on. When final drilling the elevator horns where the push rod connects. I made a filler block according to vans instructions, I did have a thought to make it out of steel or even aluminum block but my desire to keep moving got the best of me and I make it out of oak. We as you can imagine the drill bit walked a bit and the holes did not get drilled as straight as humanly possible as stated in the plans. I was able to get the balance arms close not not close enough for me to being level with the horiz stab as I would like. I am about 1/16 or a tad more off. When the left side is flush the right side is up about a 1/16 or a tad more. I know this is close and the elevator aft spars are almost perfect parallel to each other when I run a 4 ft level across the back of then to see how close there in line to each other. So the question is am I being to anal about this or should I g have the left Elevator horn holes welded shut and redrill. Or should I think I am way close enough. I will call vans this morning ro see what they say. I am sure they will say build on. So if you have not gotten to this step do not use wood make the block out of aluminum or steel. John G. Cumins 40864 Emp ________________________________________________________________________________
Date: Jun 03, 2010
Subject: Re: Elevator balance weigth arms
Welcome to the club John. I welded up the offending hole ..... twice .... before I got it right. I made the 'working' block to fill the arm giving much more area to clamp on. I think that I ended up drilling a little dimple to mark the spot and drilling the hole after removing the elevator. Linn John Cumins wrote: > > Well I have a slight issue I would like everyone's opinion on. When > final drilling the elevator horns where the push rod connects. I made > a filler block according to vans instructions, I did have a thought > to make it out of steel or even aluminum block but my desire to keep > moving got the best of me and I make it out of oak. We as you can > imagine the drill bit walked a bit and the holes did not get drilled > as straight as humanly possible as stated in the plans. > > I was able to get the balance arms close not not close enough for me > to being level with the horiz stab as I would like. I am about 1/16 > or a tad more off. When the left side is flush the right side is up > about a 1/16 or a tad more. I know this is close and the elevator aft > spars are almost perfect parallel to each other when I run a 4 ft > level across the back of then to see how close there in line to each > other. > > So the question is am I being to anal about this or should I g have > the left Elevator horn holes welded shut and redrill. Or should I > think I am way close enough. I will call vans this morning ro see > what they say. I am sure they will say build on. > > So if you have not gotten to this step do not use wood make the block > out of aluminum or steel. > > John G. Cumins > > 40864 Emp > > * > > > * ________________________________________________________________________________
Date: Jun 03, 2010
Hi John, Not sure if you NEED to re-drill but I can guaranty you will think about it for the rest of the build and the first flight (even if it doesn't affect it). -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299885#299885 ________________________________________________________________________________
Date: Jun 03, 2010
Linn Thanks for the reply, were you able to get both elevators flush on both sides or are they off just a tad like mine are. Having a hard time not knowing they are not perfect hehehe. John G. Cumins President 2499 B1 Martin Rd Fairfield Ca 94534 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Thursday, June 03, 2010 10:10 AM Subject: Re: RV10-List: Elevator balance weigth arms Welcome to the club John. I welded up the offending hole ..... twice .... before I got it right. I made the 'working' block to fill the arm giving much more area to clamp on. I think that I ended up drilling a little dimple to mark the spot and drilling the hole after removing the elevator. Linn John Cumins wrote: Well I have a slight issue I would like everyone's opinion on. When final drilling the elevator horns where the push rod connects. I made a filler block according to vans instructions, I did have a thought to make it out of steel or even aluminum block but my desire to keep moving got the best of me and I make it out of oak. We as you can imagine the drill bit walked a bit and the holes did not get drilled as straight as humanly possible as stated in the plans. I was able to get the balance arms close not not close enough for me to being level with the horiz stab as I would like. I am about 1/16 or a tad more off. When the left side is flush the right side is up about a 1/16 or a tad more. I know this is close and the elevator aft spars are almost perfect parallel to each other when I run a 4 ft level across the back of then to see how close there in line to each other. So the question is am I being to anal about this or should I g have the left Elevator horn holes welded shut and redrill. Or should I think I am way close enough. I will call vans this morning ro see what they say. I am sure they will say build on. So if you have not gotten to this step do not use wood make the block out of aluminum or steel. John G. Cumins 40864 Emp href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Subject: HID Landing Lights
Date: Jun 03, 2010
I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jun 03, 2010
Albert Thanks for letting everyone know. That's exactly what I am planning on doing. Did you go with the 35w or 50w unit. John G. Cumins 40864 emp -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, June 03, 2010 12:04 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
From: "David Watterson" <davidw(at)dddirectories.com>
Date: Jun 03, 2010
Albert, I looked at Rigid website. The pictures show plugs on the lights. Do they match the Vans wiring harness? David C. Watterson N2733K 557 hours -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cumins Sent: Thursday, June 03, 2010 2:25 PM Subject: RE: RV10-List: HID Landing Lights Albert Thanks for letting everyone know. That's exactly what I am planning on doing. Did you go with the 35w or 50w unit. John G. Cumins 40864 emp -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, June 03, 2010 12:04 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: HID Landing Lights
Date: Jun 03, 2010
My aircraft is the one shown on the website. http://www.planelights.com/index.php?id=661 ----- Original Message ----- From: "Albert Gardner" <ibspud(at)roadrunner.com> Sent: Thursday, June 03, 2010 12:03 PM Subject: RV10-List: HID Landing Lights > > I was very unhappy with the standard wing tip landing lights because they > were not very bright and did not light up the yellow strip in front of the > plane. I bought a pair of HID Lights from Rigid Industries of Arizona, > Mesa, > AZ and they work very, very well. Direct replacement for Vans lamps, and > the > power supply is small and easily mounts to the last rib. Very bright and > lights up the area directly in front. > Tower says I look like an airliner on approach. > Albert Gardner > N991RV > Yuma, AZ > > > ________________________________________________________________________________
Date: Jun 03, 2010
Date: Jun 03, 2010
I'm using the 50W lights in my wingtips too. I'm also using the XeVision wig wag. Works like a champ. I have Archer antennas in the tips, comm 2 on the right, nav 1&2 on the left. The lights and the antennas don't play well together. The antennas pick up a lot of noise from the lights. When I remove a wingtip and separate the components, all is well. I tried all the suggestions that Rigid had: isolated the transformer, grounded the transformer case, shielded the lights, various combinations and other things as well. No luck. The good news is that the lights are so awesome that I can live with the problem. They make the halogens look just plain silly. The navs work within about 5 miles of the station, and if I really need comm2 I can shut the lights off. BTW, don't put any dark colored flammable materials within about 10" of the lamp... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jun 3, 2010 at 12:47 PM, DLM wrote: > > My aircraft is the one shown on the website. > http://www.planelights.com/index.php?id=661 > ----- Original Message ----- From: "Albert Gardner" <ibspud(at)roadrunner.com > > > > To: > Sent: Thursday, June 03, 2010 12:03 PM > > Subject: RV10-List: HID Landing Lights > > >> >> I was very unhappy with the standard wing tip landing lights because they >> were not very bright and did not light up the yellow strip in front of the >> plane. I bought a pair of HID Lights from Rigid Industries of Arizona, >> Mesa, >> AZ and they work very, very well. Direct replacement for Vans lamps, and >> the >> power supply is small and easily mounts to the last rib. Very bright and >> lights up the area directly in front. >> Tower says I look like an airliner on approach. >> Albert Gardner >> N991RV >> Yuma, AZ >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 03, 2010
I didn't use the Van's harness so I don't know. I think on mine I used a 2 wire molex connector. Albert -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Watterson Sent: Thursday, June 03, 2010 12:43 PM Subject: RE: RV10-List: HID Landing Lights Albert, I looked at Rigid website. The pictures show plugs on the lights. Do they match the Vans wiring harness? David C. Watterson N2733K 557 hours ________________________________________________________________________________
Date: Jun 03, 2010
I used the 50W lamps. I'm very happy with the setup. Albert ________________________________________________________________________________
Date: Jun 03, 2010
I will check the VOR reception; I have archer antenna in right wingtip and SL30 and have noticed no problem but i will check with HID lights on. I have had no interference with the Com. ----- Original Message ----- From: Dave Saylor To: rv10-list(at)matronics.com Sent: Thursday, June 03, 2010 2:55 PM Subject: Re: RV10-List: HID Landing Lights I'm using the 50W lights in my wingtips too. I'm also using the XeVision wig wag. Works like a champ. I have Archer antennas in the tips, comm 2 on the right, nav 1&2 on the left. The lights and the antennas don't play well together. The antennas pick up a lot of noise from the lights. When I remove a wingtip and separate the components, all is well. I tried all the suggestions that Rigid had: isolated the transformer, grounded the transformer case, shielded the lights, various combinations and other things as well. No luck. The good news is that the lights are so awesome that I can live with the problem. They make the halogens look just plain silly. The navs work within about 5 miles of the station, and if I really need comm2 I can shut the lights off. BTW, don't put any dark colored flammable materials within about 10" of the lamp... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jun 3, 2010 at 12:47 PM, DLM wrote: My aircraft is the one shown on the website. http://www.planelights.com/index.php?id=661 ----- Original Message ----- From: "Albert Gardner" To: Sent: Thursday, June 03, 2010 12:03 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jun 03, 2010
Since I've gotten older and suffered some high freq hearing loss most rfi doesn't bother me nearly as much. My passengers seem to hear a whine on occasion but I ignore them. I tell them the only time I hear a whine is when they open their mouths. Saw your folks at lunch yesterday. Albert From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Thursday, June 03, 2010 2:55 PM Subject: Re: RV10-List: HID Landing Lights I'm using the 50W lights in my wingtips too. I'm also using the XeVision wig wag. Works like a champ. I have Archer antennas in the tips, comm 2 on the right, nav 1&2 on the left. The lights and the antennas don't play well together. The antennas pick up a lot of noise from the lights. When I remove a wingtip and separate the components, all is well. I tried all the suggestions that Rigid had: isolated the transformer, grounded the transformer case, shielded the lights, various combinations and other things as well. No luck. The good news is that the lights are so awesome that I can live with the problem. They make the halogens look just plain silly. The navs work within about 5 miles of the station, and if I really need comm2 I can shut the lights off. BTW, don't put any dark colored flammable materials within about 10" of the lamp... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jun 3, 2010 at 12:47 PM, DLM wrote: My aircraft is the one shown on the website. http://www.planelights.com/index.php?id=661 ----- Original Message ----- From: "Albert Gardner" <ibspud(at)roadrunner.com> Sent: Thursday, June 03, 2010 12:03 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jun 03, 2010
I had several people contact me directly about my post so I'll copy my reply here. I installed mine like the install pictures on their webpage http://www.planelights.com/index.php?id=661 and it was very simple to do. I did not oval out the mounting plate however but I'm satisfied with the results. If you fly at night I'll bet you cuss the factory setup. I didn't use van's wiring harness so I don't know if the plugs on the landing lights match van's or not. Albert Gardner I did the retrofit on my plane after I had been flying for about a year. You have to remove the wingtip, the new bulbs are a direct replacement for the ones Van's supplies, and then mount the HID power supply somewhere. It is about the size of a thin paperback book and I attached mine to the exterior of the wingtip rib near the spar with some #8 machine screws. I used the landing light wire to power the power supply. Wish I had taken some pictures but it was a very simple job. Unscrewing the wingtip was the biggest part of it. Albert ________________________________________________________________________________
Date: Jun 03, 2010
also mine run much cooler than the halogen. ----- Original Message ----- From: Dave Saylor To: rv10-list(at)matronics.com Sent: Thursday, June 03, 2010 2:55 PM Subject: Re: RV10-List: HID Landing Lights I'm using the 50W lights in my wingtips too. I'm also using the XeVision wig wag. Works like a champ. I have Archer antennas in the tips, comm 2 on the right, nav 1&2 on the left. The lights and the antennas don't play well together. The antennas pick up a lot of noise from the lights. When I remove a wingtip and separate the components, all is well. I tried all the suggestions that Rigid had: isolated the transformer, grounded the transformer case, shielded the lights, various combinations and other things as well. No luck. The good news is that the lights are so awesome that I can live with the problem. They make the halogens look just plain silly. The navs work within about 5 miles of the station, and if I really need comm2 I can shut the lights off. BTW, don't put any dark colored flammable materials within about 10" of the lamp... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jun 3, 2010 at 12:47 PM, DLM wrote: My aircraft is the one shown on the website. http://www.planelights.com/index.php?id=661 ----- Original Message ----- From: "Albert Gardner" To: Sent: Thursday, June 03, 2010 12:03 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jun 03, 2010
Albert, Glad to hear you are happy with the system. All our systems come with wire pigtail adapters that you splice into your stock wiring however you would like. We always suggest solder and shrink wrap although but connectors work just fine. The plugs between the ballast and the bulbs are high voltage plugs and wire, don't cut those, ever! There will be a current surge in any HID system. It doesn't matter if you use a Xevision, lopresti or ours. We recommend using at least 14ga wire out to the wings to be on the safe side. Each 50w light @ 14v will pull about 7a for 10 sec. Once the lights are warm, the power draw will stabilize about 4-4.5a. We have done all we can to shield the circuitry and use shielded HV wire, but 23,000v will cause a little interference. The only way to solve that is a very expensive D1S bulb with the igniter built onto the back of bulb. Xevison makes a very nice system, but you are going to pay quite a bit to get the same light output. With a couple precautions almost all the RFI noise can be eliminated for 1/4 the price. We have sold close to 500 MR16 sets over the last 3 years and only 1 set has ever knocked an autopilot off. If by some fluke you are the second, we will be glad to give you a refund, just as we did for Jesse. I am not on here very often so if you have questions please email me via the link on the website. Thanks Steve(Planelights/Rigid) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299939#299939 ________________________________________________________________________________
Subject: Bulk Wire Order
Date: Jun 03, 2010
Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to work on the airplane, so hopefully we're getting back on track. I'm getting ready to place a bulk wire order and I'm curious what sizes seem to be the ones used most? I'm hoping to standardize on 3-4 sizes and use the next largest size; even if it's not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. Anyone have any recommendations on the sizes they used the most? Phil ________________________________________________________________________________
Subject: Re: Bulk Wire Order
Date: Jun 03, 2010
Here is something from my archives from Stein. Sending the whole message but stick with the wires section only, worry about the BNC after you have the panel figured out. -------------- Stick with the standard M22759/16 Tefzel wire...don't bother with teflon, silver plated, etc...or surplus stuff (you never know what you're getting). Also, if you spend more than a few hours "hunting" for a deal, you've just wasted enough time to buy what you want and what you need brand new. Depending on what you're doing with the plane and panel, buy at least the following initially: 200' AWG22 200' AWG18 150' AWG16 50' AWG20 50' AWG14 25' AWG12 25' AWG10 100' RG-400 Coax a dozen male BNC's, a half dozen female BNC's, a couple hundred PIDG ring terminals, and some heatshrink. Now, depending on if you want colors or not you can split all that up. The above wiring amounts could vary pretty significantly depending on if you're wiring your own panel or not, whether you're going full boat on lighting, radios, IFR/VFR, etc.. I wouldn't waste my time buying whole spools then trying to sell the surplus. Heck, wire is relatively cheap, we're talking about something that costs pennies per foot...you'll only spend a couple/few hundred bucks of wire total. Why waste your time goofing around.......figure out what you need, what colors you want and just buy it. As someone who regularly buys wire in 10,000' - 20,000' spools and keeps over a half million feet of wire "hanging around", I can tell you playing with spools to save a few percent is a waste of time on an item like this, for one airplane. With your Avionics or engine it's a different story because you can save a lot of dough, but in the wiring it's such a cheap item to begin with that it's not worth much effort to save a buck. Just my 2 cents as usual! Cheers, Stein. -------------------- Pascal From: Perry, Phil Sent: Thursday, June 03, 2010 8:12 PM Subject: RV10-List: Bulk Wire Order Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to work on the airplane, so hopefully we're getting back on track. I'm getting ready to place a bulk wire order and I'm curious what sizes seem to be the ones used most? I'm hoping to standardize on 3-4 sizes and use the next largest size; even if it's not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. Anyone have any recommendations on the sizes they used the most? Phil ________________________________________________________________________________
Date: Jun 03, 2010
I had a similar problem on mine. Van's told me to just weld it and drill it again. I did not want to think about that thing failing while flying, so i just bought new elevator horns and replaced them. Wasn't too hard and I felt that it was worth the effort. You can see some pictures I posted here: http://forums.matronics.com/viewtopic.php?t=43969&postdays=0&postorder=asc&start=23 Lenny #40803 White spaghetti everywhere... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=299984#299984 ________________________________________________________________________________
Date: Jun 04, 2010
If you have not tried SteinAir, they are competitive on pricing and offer e xcellent customer service. http://www.steinair.com/store.htm David Clifford RV-10 Builder 65% Done-95% To Go N849RV (reserved) ----- Original Message ----- From: "Phil Perry" <Phil.Perry(at)netapp.com> Sent: Thursday, June 3, 2010 11:12:01 PM GMT -05:00 US/Canada Eastern Subject: RV10-List: Bulk Wire Order Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to wor k on the airplane, so hopefully we=99re getting back on track. I=99m getting ready to place a bulk wire order and I=99m curiou s what sizes seem to be the ones used most? I=99m hoping to standardi ze on 3-4 sizes and use the next largest size; even if it=99s not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. Anyone have any recommendations on the sizes they used the most? Phil == ________________________________________________________________________________
Date: Jun 04, 2010
I personally like to use the correct size for each application to balance weight and safety. Using a wire that's too big for the application only adds weight. I understand the desire to save space, but you can get a wire spool holder that holds 8 spools of wire in a very small space. I have a friend that bought one at Lowes, I think, but I'm not sure. I actually built a wire cart, which would obviously take too much space. Another thing I like to do is use different colors as much as possible. I always use Red for power and Black for ground, of which I use mostly 18AWG, but also use a fair bit of 16AWG and 20AWG. I usually use another color for signal wires that don't actually carry power amperage, and I usually use 22AWG for this. For wires like Master and Starter, I usually use Yellow 18AWG. For Trim Servos I usually use a 3-conductor Shielded wire and a 2-conductor Shielded wire, since the servo(s) need 5 wires. Using different color wires make it much easier to trace a wire through a bundle when (not if) you have to do repairs down the road. I also like to use Stein's auto pilot servo bundle for the auto pilot servos, but I've also done that with the shielded multi-conductor wire plus red and black or with just individual wires of different colors. I also use a decent amount of 14AWG for landing lights (when HID) and for E-Bus and Backup Bus when using Vertical Power. You'll also need some 2AWG for power and starter main wires and 8AWG for Alternator and Bus wires. Or, you could just get white 22, 20, 18, 16, 8 and 2 and make a nightmare for yourself down the road when it comes time to modify or repair. I don't recommend this. The wire bundles might look nicer this way, but they are a pain to deal with. Oh, on the multi-conductor shielded wire, I recommend using no smaller than 22AWG. 24 is a pain to work with and 26 is rediculous, IMHO. The added weight of going to 22 is negligible for the small amount needed. This is all assuming a 12-Volt system. That's my $.02 Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com Cell: 352-427-0285 Fax: 815-377-3694 On Jun 3, 2010, at 11:12 PM, Perry, Phil wrote: > Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to work on the airplane, so hopefully we=92re getting back on track. > > I=92m getting ready to place a bulk wire order and I=92m curious what sizes seem to be the ones used most? I=92m hoping to standardize on 3-4 sizes and use the next largest size; even if it=92s not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. > > Anyone have any recommendations on the sizes they used the most? > > Phil > > > > > > ________________________________________________________________________________
Date: Jun 04, 2010
I went with a very similar list from Stein. But ordered extra 22 and 18, 5 different colors (Red, Green, Black, White, Yellow), 100 feet each. I have some left, but NOT some of each color. I did not wire my own panel, but...there is a lot of wire outside the panel. For example, the wing is a little over 12 feet long, from the wing root to the back of the panel (or strobe power supply) lets say it is 6 feet depending on routing..that makes each run about 19' so far.you will need a maintenance loop (unless you are putting in connectors), let's say 3'. So each run out to the wing tip will be 22 feet. Now since you don't want to come up short, better add a few feet for good measure. So lets just say, for a budget number you will need 30' feet per run out to the wing tips. This may be a little overkill, but you will be surprised at how much wire you end up using. RG-400. I ordered 100 feet and had to get more for the transponder cable because I ran out. Again, it is a long way out to the wing tip...and don't forget those maintenance loops... Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Thursday, June 03, 2010 9:36 PM Subject: Re: RV10-List: Bulk Wire Order Here is something from my archives from Stein. Sending the whole message but stick with the wires section only, worry about the BNC after you have the panel figured out. -------------- Stick with the standard M22759/16 Tefzel wire...don't bother with teflon, silver plated, etc...or surplus stuff (you never know what you're getting). Also, if you spend more than a few hours "hunting" for a deal, you've just wasted enough time to buy what you want and what you need brand new. Depending on what you're doing with the plane and panel, buy at least the following initially: 200' AWG22 200' AWG18 150' AWG16 50' AWG20 50' AWG14 25' AWG12 25' AWG10 100' RG-400 Coax a dozen male BNC's, a half dozen female BNC's, a couple hundred PIDG ring terminals, and some heatshrink. Now, depending on if you want colors or not you can split all that up. The above wiring amounts could vary pretty significantly depending on if you're wiring your own panel or not, whether you're going full boat on lighting, radios, IFR/VFR, etc.. I wouldn't waste my time buying whole spools then trying to sell the surplus. Heck, wire is relatively cheap, we're talking about something that costs pennies per foot...you'll only spend a couple/few hundred bucks of wire total. Why waste your time goofing around.......figure out what you need, what colors you want and just buy it. As someone who regularly buys wire in 10,000' - 20,000' spools and keeps over a half million feet of wire "hanging around", I can tell you playing with spools to save a few percent is a waste of time on an item like this, for one airplane. With your Avionics or engine it's a different story because you can save a lot of dough, but in the wiring it's such a cheap item to begin with that it's not worth much effort to save a buck. Just my 2 cents as usual! Cheers, Stein. -------------------- Pascal From: Perry, <mailto:Phil.Perry(at)netapp.com> Phil Sent: Thursday, June 03, 2010 8:12 PM Subject: RV10-List: Bulk Wire Order Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to work on the airplane, so hopefully we're getting back on track. I'm getting ready to place a bulk wire order and I'm curious what sizes seem to be the ones used most? I'm hoping to standardize on 3-4 sizes and use the next largest size; even if it's not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. Anyone have any recommendations on the sizes they used the most? Phil href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Richard Barnes" <rickbarnes(at)highlanddental.com>
Date: Jun 04, 2010
We also bought the Planelights 50W lights. Although we haven't flown yet, they seem to be much brighter than the stock Van's lights. We bought them last year and when we went to install them, last month, one of the lights didn't work. I called Planelights and they sent me a new light, no questions asked. Great service!!! We had the DAR inspection a few weeks ago, the instruments passed IFR, and the engine started on the first turn. High speed taxi test this weekend and first flight next week. Rick Barnes Mike Howe From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Thursday, June 03, 2010 4:42 PM Subject: Re: RV10-List: HID Landing Lights also mine run much cooler than the halogen. ----- Original Message ----- From: Dave Saylor <mailto:dave.saylor.aircrafters(at)gmail.com> Sent: Thursday, June 03, 2010 2:55 PM Subject: Re: RV10-List: HID Landing Lights I'm using the 50W lights in my wingtips too. I'm also using the XeVision wig wag. Works like a champ. I have Archer antennas in the tips, comm 2 on the right, nav 1&2 on the left. The lights and the antennas don't play well together. The antennas pick up a lot of noise from the lights. When I remove a wingtip and separate the components, all is well. I tried all the suggestions that Rigid had: isolated the transformer, grounded the transformer case, shielded the lights, various combinations and other things as well. No luck. The good news is that the lights are so awesome that I can live with the problem. They make the halogens look just plain silly. The navs work within about 5 miles of the station, and if I really need comm2 I can shut the lights off. BTW, don't put any dark colored flammable materials within about 10" of the lamp... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Jun 3, 2010 at 12:47 PM, DLM wrote: My aircraft is the one shown on the website. http://www.planelights.com/index.php?id=661 ----- Original Message ----- From: "Albert Gardner" <ibspud(at)roadrunner.com> Sent: Thursday, June 03, 2010 12:03 PM Subject: RV10-List: HID Landing Lights I was very unhappy with the standard wing tip landing lights because they were not very bright and did not light up the yellow strip in front of the plane. I bought a pair of HID Lights from Rigid Industries of Arizona, Mesa, AZ and they work very, very well. Direct replacement for Vans lamps, and the power supply is small and easily mounts to the last rib. Very bright and lights up the area directly in front. Tower says I look like an airliner on approach. Albert Gardner N991RV Yuma, AZ ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 04, 2010
While RG-400 looks and sounds sexy, I personally don't see the advantage of using it for nav antennas, and benefit for comm antennas is probably marginal. I can see using it for transponder and GPS antennas. All of the RG-58 in my Mooney is at least 20 yrs old, and radios still work fine. That extra $1.50 a foot sure adds up in a hurry. Opinion over on Aero-electric list recently was minimal difference for normal VHF stuff. I guess that puts it in the primer discussion category. ;-) On 6/4/2010 5:50 AM, Rene Felker wrote: > > RG-400. I ordered 100 feet and had to get more for the transponder > cable because I ran out. Again, it is a long way out to the wing > tip..and dont forget those maintenance loops. > > Rene' Felker > > N423CF > > 801-721-6080 > > * > * ________________________________________________________________________________
Date: Jun 04, 2010
I forgot something.. Crimp tools, pins, connectors...etc. I did not wire my panel, but did need plenty of these. Stein sells a great crimper and all the parts you need to make good connections. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Friday, June 04, 2010 6:50 AM Subject: RE: RV10-List: Bulk Wire Order I went with a very similar list from Stein. But ordered extra 22 and 18, 5 different colors (Red, Green, Black, White, Yellow), 100 feet each. I have some left, but NOT some of each color. I did not wire my own panel, but...there is a lot of wire outside the panel. For example, the wing is a little over 12 feet long, from the wing root to the back of the panel (or strobe power supply) lets say it is 6 feet depending on routing..that makes each run about 19' so far.you will need a maintenance loop (unless you are putting in connectors), let's say 3'. So each run out to the wing tip will be 22 feet. Now since you don't want to come up short, better add a few feet for good measure. So lets just say, for a budget number you will need 30' feet per run out to the wing tips. This may be a little overkill, but you will be surprised at how much wire you end up using. RG-400. I ordered 100 feet and had to get more for the transponder cable because I ran out. Again, it is a long way out to the wing tip...and don't forget those maintenance loops... Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Thursday, June 03, 2010 9:36 PM Subject: Re: RV10-List: Bulk Wire Order Here is something from my archives from Stein. Sending the whole message but stick with the wires section only, worry about the BNC after you have the panel figured out. -------------- Stick with the standard M22759/16 Tefzel wire...don't bother with teflon, silver plated, etc...or surplus stuff (you never know what you're getting). Also, if you spend more than a few hours "hunting" for a deal, you've just wasted enough time to buy what you want and what you need brand new. Depending on what you're doing with the plane and panel, buy at least the following initially: 200' AWG22 200' AWG18 150' AWG16 50' AWG20 50' AWG14 25' AWG12 25' AWG10 100' RG-400 Coax a dozen male BNC's, a half dozen female BNC's, a couple hundred PIDG ring terminals, and some heatshrink. Now, depending on if you want colors or not you can split all that up. The above wiring amounts could vary pretty significantly depending on if you're wiring your own panel or not, whether you're going full boat on lighting, radios, IFR/VFR, etc.. I wouldn't waste my time buying whole spools then trying to sell the surplus. Heck, wire is relatively cheap, we're talking about something that costs pennies per foot...you'll only spend a couple/few hundred bucks of wire total. Why waste your time goofing around.......figure out what you need, what colors you want and just buy it. As someone who regularly buys wire in 10,000' - 20,000' spools and keeps over a half million feet of wire "hanging around", I can tell you playing with spools to save a few percent is a waste of time on an item like this, for one airplane. With your Avionics or engine it's a different story because you can save a lot of dough, but in the wiring it's such a cheap item to begin with that it's not worth much effort to save a buck. Just my 2 cents as usual! Cheers, Stein. -------------------- Pascal From: Perry, <mailto:Phil.Perry(at)netapp.com> Phil Sent: Thursday, June 03, 2010 8:12 PM Subject: RV10-List: Bulk Wire Order Ever since the baby showed up about a month ago, my airplane building time has gone in the drink. But last weekend I fortunately found ~2 hours to work on the airplane, so hopefully we're getting back on track. I'm getting ready to place a bulk wire order and I'm curious what sizes seem to be the ones used most? I'm hoping to standardize on 3-4 sizes and use the next largest size; even if it's not the smallest size capable of the load. This way I can minimize how many spools I need to buy and store in the garage. Anyone have any recommendations on the sizes they used the most? Phil href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 04, 2010
I put in bilateral Duckworks 50w in the leading edge of wings--great light--during day towers think it's a turbo airline arriving. No RF problem. I think in retrospect I would have also put in Vans landing lights in the wing tips --I don't think you can have too much light--I fly off grass and at night any extra light is helpful. Advantage of lights in leading edge is that the wing tip lights get shadowed by the wing itself and don't do as good a job for landing. IMHO larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300011#300011 ________________________________________________________________________________
Date: Jun 04, 2010
I'll jump in here with my 2 cents. I have a set of the Plane Lights HIDs in my tips. Each tip also has Bob Archer ants for VOR only. The ballasts are easy to mount. The power connector to the ballast certainly won't match Vans anything so expect to splice one side of the connector to whatever existing wiring you have. The ballast high tension output wire carries K-Volts and comes with special shielding and connectors. The output pigtail is maybe 12" and includes a hard-to-mount inline black rectangular plastic box. I RTV'ed the external box to the rib. I may go back and add an additional support bracket before flying. I don't recall my lights coming with any directions, but that may have changed since as it's been a while. Be warned that adding a do-it-yourself splice to extend the output side wire length is asking for trouble down the road (don't ask, but thanks for pointing that out Bob). 3 foot long wire extensions are available from the vendor, but you really don't need them if you mount the ballast far enough forward on the outboard rib. The HID bulb assembly is a drop in replacement into the Vans standard lighting mount. The assembly includes integrated bulb, reflector, ceramic mount, ~8" high tension wires and special connectors. The bulb itself is not removable from the rest of the assembly. The lights work as advertised. Bright as heck. I'm not flying and haven't hooked up radios so the jury is out on how well the solution works. Can always pull them out if the HF interferes with other electro-goodies. Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300012#300012 ________________________________________________________________________________
Date: Jun 04, 2010
Please consider either skipping the high-speed taxi, or plan and be prepared that it might very well be your first flight. The plane accelerates very rapidly, and could easily surprise you into getting above lift off speed. IIRC the EAA now advocates against high speed taxi tests due to significant number of mishaps. On 6/4/2010 5:51 AM, Richard Barnes wrote: > > We had the DAR inspection a few weeks ago, High speed taxi test > this weekend and first flight next week. > > Rick Barnes > > Mike Howe > > * > * ________________________________________________________________________________
Date: Jun 04, 2010
Thanks for the insight. I noticed during the transition training the plane wants to fly at very low speeds. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, June 04, 2010 8:04 AM Subject: Re: RV10-List: HID Landing Lights Please consider either skipping the high-speed taxi, or plan and be prepared that it might very well be your first flight. The plane accelerates very rapidly, and could easily surprise you into getting above lift off speed. IIRC the EAA now advocates against high speed taxi tests due to significant number of mishaps. On 6/4/2010 5:51 AM, Richard Barnes wrote: > > We had the DAR inspection a few weeks ago, High speed taxi test > this weekend and first flight next week. > > Rick Barnes > > Mike Howe > > * > * ________________________________________________________________________________
Subject: Spam
Date: Jun 04, 2010
Hey Matt, This is the first time I've gotten this. Is anybody else getting this? Has it happened before? Any way to prevent it? See below: "My name is miss Nina, i'm a free minded, open hearted girl i like to take life as easy as i could, i'm one of the few that still belives in friendship, love, trust and signs, am very much single and was browsing through the forums.matronics.com and came across your contact belive me i like what i see, it will be my sincere pleasure to be your friend if you don't mind, i hope you will not take my request for granted, feel free to email me i will appreciate it if you can send me some pics, i look forward to hear from you soon. Take care. Nina. " (mis_martha(at)yahoo.com) Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300050#300050 ________________________________________________________________________________
Subject: Re: Spam
Date: Jun 04, 2010
Man, I thought I was the ONE she was looking for :( I was feeling so special. I got it too. Sean Strasburg ----- Original Message ----- From: "Lew Gallagher" <lewgall(at)charter.net> Sent: Friday, June 04, 2010 12:07 PM Subject: RV10-List: Spam > > Hey Matt, > > This is the first time I've gotten this. Is anybody else getting this? > Has it happened before? Any way to prevent it? See below: > > "My name is miss Nina, i'm a free minded, open hearted girl i like to take > life as easy as i could, i'm one of the few that still belives in > friendship, love, trust and signs, am very much single and was browsing > through the forums.matronics.com and came across your contact belive me i > like what i see, it will be my sincere pleasure to be your friend if you > don't mind, i hope you will not take my request for granted, feel free to > email me i will appreciate it if you can send me some pics, i look forward > to hear from you soon. > Take care. > > Nina. " (mis_martha(at)yahoo.com) > > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300050#300050 > > > ________________________________________________________________________________
Subject: Re: Spam
Date: Jun 04, 2010
VG9vIGxhdGUuIA0KDQpJIHRvb2sgaGVyIHRvIE9zaGtvc2ggbGFzdCB5ZWFyLiAgOikNCg0KDQoN Ci0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCkZyb206IFNlYW5vIDxzZWFuQGJyYXVuYW5k Y28uY29tPg0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIDxydjEwLWxpc3RAbWF0cm9uaWNz LmNvbT4NClNlbnQ6IEZyaSBKdW4gMDQgMTE6MTQ6MTMgMjAxMA0KU3ViamVjdDogUmU6IFJWMTAt TGlzdDogU3BhbQ0KDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiU2Vhbm8iIDxz ZWFuQGJyYXVuYW5kY28uY29tPg0KDQpNYW4sIEkgdGhvdWdodCBJIHdhcyB0aGUgT05FIHNoZSB3 YXMgbG9va2luZyBmb3IgIDooICBJIHdhcyBmZWVsaW5nIHNvIA0Kc3BlY2lhbC4NCg0KSSBnb3Qg aXQgdG9vLg0KDQoNClNlYW4gU3RyYXNidXJnDQoNCi0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0t LS0gDQpGcm9tOiAiTGV3IEdhbGxhZ2hlciIgPGxld2dhbGxAY2hhcnRlci5uZXQ+DQpUbzogPHJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU2VudDogRnJpZGF5LCBKdW5lIDA0LCAyMDEwIDEyOjA3 IFBNDQpTdWJqZWN0OiBSVjEwLUxpc3Q6IFNwYW0NCg0KDQo+IC0tPiBSVjEwLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6ICJMZXcgR2FsbGFnaGVyIiA8bGV3Z2FsbEBjaGFydGVyLm5ldD4NCj4NCj4g SGV5IE1hdHQsDQo+DQo+IFRoaXMgaXMgdGhlIGZpcnN0IHRpbWUgSSd2ZSBnb3R0ZW4gdGhpcy4g IElzIGFueWJvZHkgZWxzZSBnZXR0aW5nIHRoaXM/IA0KPiBIYXMgaXQgaGFwcGVuZWQgYmVmb3Jl PyAgQW55IHdheSB0byBwcmV2ZW50IGl0PyAgU2VlIGJlbG93Og0KPg0KPiAiTXkgbmFtZSBpcyBt aXNzIE5pbmEsIGknbSBhIGZyZWUgbWluZGVkLCBvcGVuIGhlYXJ0ZWQgZ2lybCBpIGxpa2UgdG8g dGFrZSANCj4gbGlmZSBhcyBlYXN5IGFzIGkgY291bGQsIGknbSBvbmUgb2YgdGhlIGZldyB0aGF0 IHN0aWxsIGJlbGl2ZXMgaW4gDQo+IGZyaWVuZHNoaXAsIGxvdmUsIHRydXN0IGFuZCBzaWducywg YW0gdmVyeSBtdWNoIHNpbmdsZSBhbmQgd2FzIGJyb3dzaW5nIA0KPiB0aHJvdWdoIHRoZSBmb3J1 bXMubWF0cm9uaWNzLmNvbSBhbmQgY2FtZSBhY3Jvc3MgeW91ciBjb250YWN0IGJlbGl2ZSBtZSBp IA0KPiBsaWtlIHdoYXQgaSBzZWUsIGl0IHdpbGwgYmUgbXkgc2luY2VyZSBwbGVhc3VyZSB0byBi ZSB5b3VyIGZyaWVuZCBpZiB5b3UgDQo+IGRvbid0IG1pbmQsIGkgaG9wZSB5b3Ugd2lsbCBub3Qg dGFrZSBteSByZXF1ZXN0IGZvciBncmFudGVkLCBmZWVsIGZyZWUgdG8gDQo+IGVtYWlsIG1lIGkg d2lsbCBhcHByZWNpYXRlIGl0IGlmIHlvdSBjYW4gc2VuZCBtZSBzb21lIHBpY3MsIGkgbG9vayBm b3J3YXJkIA0KPiB0byBoZWFyIGZyb20geW91IHNvb24uDQo+IFRha2UgY2FyZS4NCj4NCj4gTmlu YS4gIiAgICAgIChtaXNfbWFydGhhQHlhaG9vLmNvbSkNCj4NCj4NCj4gTGF0ZXIsIC0gTGV3DQo+ DQo+IC0tLS0tLS0tDQo+IG5vbi1waWxvdA0KPiBjcmF6eSBhYm91dCBidWlsZGluZw0KPiBOT1cg T0ZJQ0lBTExZIEJVSUxERVIgIzQwNTQ5DQo+IEZseSBvZmYgY29tcGxldGVkICENCj4NCj4NCj4N Cj4NCj4gUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KPg0KPiBodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTMwMDA1MCMzMDAwNTANCj4NCj4NCj4NCj4NCj4N Cj4NCj4NCj4NCj4NCj4gDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3Qg RW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdh dG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBV bi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJv d3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09 DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QN Cl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0K Xy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMh DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhh bmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Subject: Spam
Date: Jun 04, 2010
Nina kept telling me all those other guys were 'just friends.' I believed her - till now. Albert Gardner ________________________________________________________________________________
Date: Jun 05, 2010
Bob=2C thanks for getting this together again this year. My wife and I are planning our first trip to Oshkosh this year and will reserve a site in th e RV-10HQ area as instructed below. As this will be our first Oshkosh expe rience=2C I have no idea what the logistics at the field will be other than we plan to get to Oshkosh on Friday or Saturday before the show. How do t he guys get their camping stuff from RV parking to the HQ camping site. Sh uttles=2C carry on your back..??? We are planning on arriving early in hop es of beating the crowd and besides we want to take in the whole positive e xperience=2C so we are staying to the end. Having a premo camp site close to facilities with other RV10'ers will go a long way in making this a pleas ant week. So any helpful hints on what to bring=2C what not to bring=2C et c would be most appreciated. Looking forward to meeting you and the other RV10 families this year. Regards=2C Bill Gipson Conroe=2C Texas 281-814-6006 > Subject: RV10-List: 2010 OSH RV-10 HQ Camping > From: bob.condrey(at)baesystems.com > Date: Thu=2C 3 Jun 2010 08:23:47 -0700 > To: rv10-list(at)matronics.com > > > It's getting to be that time of year because phone calls and emails have started! > > Gary and I will again stake out sites for those who are interested in bei ng in the RV-10 HQ area. In past years this has been a group of around 25 R V-10 folks ranging from those just starting the tail kit to those that have been flying for multiple years. Additionally we=99ve traditionally f acilitated a couple of large cookouts where those not camping with us can a ttend =93 typically upwards of 75-100 people including some notable v endors. > We will again stake out the sites on the Tuesday before Airventure starts which is 7/20 this year. Payment is required in advance from the first nig ht through the Sunday night at the end of Airventure which winds up being 1 3 nights. Price this year is $22 per night which comes out to $286. You can either mail me a check (contact me offline for address) or use PayPal. Pay Pal is much easier all the way around but there's a fee of about $9 that th ey'll take out so if you use that service you'll need to send $295. > > Here=99s how it works if you=99re interested: > Gary=2C Tim and I (and wives) simply facilitate this for the good of the group. Cost is actual cost of the sites - this is not a profit making ventu re. Your campsite will be in your name (I will need your EAA number) and wi ll be paid for with a check rather than a credit card. This means if you le ave early you will receive a check from EAA when you turn in your site regi stration on your way out of the campgrounds. I will check with Tim to see i f he=99s willing to once again have info on his website to facilitate people leaving early coordinating with others coming late in the week. > > Summary=2C if you want a campsite with the group: > - I need $286 from you ($295 if using PayPal) no later than 7/14/2010. > - If using PayPal=2C please send to bcondrey at cox dot net > - I will need your EAA number for the registration and your membership mu st be valid through at least August 2010. > - It would be helpful if you'd send me an email with the date you're plan ning to arrive and leave and the type of camper (Class A=2C tent=2C etc) > - We'll use our best judgment for the group location based on what's avai lable when we get there but our target will be in the same area that we've been the last few years which is immediately south of Paul=99s Park i n Camp Scholler (around 55th and Lindbergh). > - Sites get tagged as required using a little logic based on size of the camper=2C tent vs. Class A motorhome=2C whether you=99ve got kids=2C etc. If you don=99t like the location you can swap around when you ge t there. > - We=99ll have your car pass=2C etc. at one of our sites and you si mply call when you get close and somebody meet you at the registration gate . > Most questions can be answered with the info from last year on Tim =99s website at: www.myrv10.com/osh/Camping_FAQ.html > > I=99ll post more info and a reminder in a few weeks when it gets cl oser. > > Bob > RV-10 N442PM (flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299863#299863 > > > > > > > =========== =========== =========== =========== > > > _________________________________________________________________ The New Busy is not the too busy. Combine all your e-mail accounts with Hot mail. http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4 ________________________________________________________________________________
Subject: 2010 OSH RV-10 HQ Camping
Date: Jun 05, 2010
Bill, The folks that run the RV parking area have a shuttle and are more than happy to drive folks with their camping gear to the RV-10HQ. With that said, I don=99t know when the shuttles start running. If the shuttle isn=99t running, just give somebody a call. All I can share at the moment, is that some folks have been very resourceful in providing transportation between the two areas. This camping guide is a good resource for first timers: http://www.upaero.com/oshkoshairshowcampingguide.pdf The first mass arrivals usually start after lunch on Saturday. Last year=99s cross wind made the arrival a little more entertaining than usual. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Gipson Sent: Saturday, June 05, 2010 10:31 AM Subject: RE: RV10-List: 2010 OSH RV-10 HQ Camping Bob, thanks for getting this together again this year. My wife and I are planning our first trip to Oshkosh this year and will reserve a site in the RV-10HQ area as instructed below. As this will be our first Oshkosh experience, I have no idea what the logistics at the field will be other than we plan to get to Oshkosh on Friday or Saturday before the show. How do the guys get their camping stuff from RV parking to the HQ camping site. Shuttles, carry on your back..??? We are planning on arriving early in hopes of beating the crowd and besides we want to take in the whole positive experience, so we are staying to the end. Having a premo camp site close to facilities with other RV10'ers will go a long way in making this a pleasant week. So any helpful hints on what to bring, what not to bring, etc would be most appreciated. Looking forward to meeting you and the other RV10 families this year. Regards, Bill Gipson Conroe, Texas 281-814-6006 > Subject: RV10-List: 2010 OSH RV-10 HQ Camping > From: bob.condrey(at)baesystems.com > Date: Thu, 3 Jun 2010 08:23:47 -0700 > To: rv10-list(at)matronics.com > > > It's getting to be that time of year because phone calls and emails have started! > > Gary and I will again stake out sites for those who are interested in being in the RV-10 HQ area. In past years this has been a group of around 25 RV-10 folks ranging from those just starting the tail kit to those that have been flying for multiple years. Additionally we=C3=A2=82=AC=84=A2ve traditionally facilitated a couple of large cookouts where those not camping with us can attend =C3=A2=82=AC=9C typically upwards of 75-100 people including some notable vendors. > We will again stake out the sites on the Tuesday before Airventure starts which is 7/20 this year. Payment is required in advance from the first night through the Sunday night at the end of Airventure which winds up being 13 nights. Price this year is $22 per night which comes out to $286. You can either mail me a check (contact me offline for address) or use PayPal. PayPal is much easier all the way around but there's a fee of about $9 that they'll take out so if you use that service you'll need to send $295. > > Here=C3=A2=82=AC=84=A2s how it works if you=C3=A2=82=AC=84=A2re interested: > Gary, Tim and I (and wives) simply facilitate this for the good of the group. Cost is actual cost of the sites - this is not a profit making venture. Your campsite will be in your name (I will need your EAA number) and will be paid for with a check rather than a credit card. This means if you leave early you will receive a check from EAA when you turn in your site registration on your way out of the campgrounds. I will check with Tim to see if he=C3=A2=82=AC=84=A2s willing to once again have info on his website to facilitate people leaving early coordinating with others coming late in the week. > > Summary, if you want a campsite with the group: > - I need $286 from you ($295 if using PayPal) no later than 7/14/2010. > - If using PayPal, please send to bcondrey at cox dot net > - I will need your EAA number for the registration and your membership must be valid through at least August 2010. > - It would be helpful if you'd send me an email with the date you're planning to arrive and leave and the type of camper (Class A, tent, etc) > - We'll use our best judgment for the group location based on what's available when we get there but our target will be in the same area that we've been the last few years which is immediately south of Paul=C3=A2=82=AC=84=A2s Park in Camp Scholler (around 55th and Lindbergh). > - Sites get tagged as required using a little logic based on size of the camper, tent vs. Class A motorhome, whether you=C3=A2=82=AC=84=A2ve got kids, etc. If you don=C3=A2=82=AC=84=A2t like the location you can swap around when you get there. > - We=C3=A2=82=AC=84=A2ll have your car pass, etc. at one of our sites and you simply call when you get close and somebody meet you at the registration gate. > Most questions can be answered with the info from last year on Tim=C3=A2=82=AC=84=A2s website at: www.myrv10.com/osh/Camping_FAQ.html > > I=C3=A2=82=AC=84=A2ll post more info and a reminder in a few weeks when it gets closer. > > Bob > RV-10 N442PM (flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=299863#299863 > > ________________________________________________________________________________
Date: Jun 05, 2010
Subject: RV-10 Rear Seat Foam from Van's
I have an extra set of Vans' rear seat foam for the two seats, including the patterns. Part number is CA SEAT SET REAR 10. The list price is $315. I will take $215 including shipping to the lower 48 states. If you are interested please send me a note to my work e-mail at LJS2(at)pge.com. Thanks L. Jearl Strickland ________________________________________________________________________________
Subject: survey
Date: Jun 05, 2010
What rpm is being used for the magneto check and what limits are considered acceptable? magneto drop? and drop difference? ________________________________________________________________________________
Subject: survey
Date: Jun 05, 2010
1700 RPM 175 Max drop and 50 different Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Saturday, June 05, 2010 2:13 PM Subject: RV10-List: survey What rpm is being used for the magneto check and what limits are considered acceptable? magneto drop? and drop difference? ________________________________________________________________________________
Subject: survey
Date: Jun 05, 2010
Lycoming, the manufacturer of the powerplant most builders select is the best source of said numbers to establish a baseline. The advantage is to determine if timing, wiring, spark or other issues are standing in the way of making adequate horsepower output which could jeopardize safe flight and certainly take-off. Each Builder of the RV-10 establishers their own numbers based on their extensive research before acquiring the coveted DAR or FAA Inspection Signoff. Choice of spark ignition systems, compression, internal components, fuel used and other issues can skew the use of one other builders choice. Personally, I would run the question passed Rhonda on what the Dyno tells her dad with the quality units that they provide. They are solid reference sources for magneto driven powerplants. Choice wisely. John Cox From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Saturday, June 05, 2010 2:19 PM Subject: RE: RV10-List: survey 1700 RPM 175 Max drop and 50 different Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Saturday, June 05, 2010 2:13 PM Subject: RV10-List: survey What rpm is being used for the magneto check and what limits are considered acceptable? magneto drop? and drop difference? http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Comm Antennas
Date: Jun 05, 2010
Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Re: 2010 OSH RV-10 HQ Camping
I will have two trucks there Friday(before Oshkosh starts) night and can dr ive over and shuttle people to the camping area. They shut it down to drivi ng out there on Sunday or Monday but that is when homebuilt headquarters wi ll shuttle people. =0AMy cell is 801-718-1277=0A=0A-Scott Schmidt =0A=0ASe nt from my iPhone=0A=0AOn Jun 5, 2010, at 1:06 PM, "Bob Leffler" wrote:=0A=0ABill,=0A=0A =0A=0AThe folks that run the RV parking area have a shuttle and are more than happy to drive folks with their campi ng gear to the RV-10HQ. With that said, I don=99t know when the shu ttles start running.=0A=0A =0A=0AIf the shuttle isn=99t running, just give somebody a call. All I can share at the moment, is that some folks h ave been very resourceful in providing transportation between the two areas .=0A=0A =0A=0AThis camping guide is a good resource for first timers: http ://www.upaero.com/oshkoshairshowcampingguide.pdf=0A=0A =0A=0AThe first mass arrivals usually start after lunch on Saturday. Last year=99s cross wind made the arrival a little more entertaining than usual.=0A=0A =0A=0Ab ob=0A=0A =0A=0AFrom: owner-rv10-list-server(at)matronics.com [mailto:owner-rv1 0-list-server(at)matronics.com] On Behalf Of Bill Gipson=0ASent: Saturday, Jun e 05, 2010 10:31 AM=0ATo: rv10-list(at)matronics.com=0ASubject: RE: RV10-List: 2010 OSH RV-10 HQ Camping=0A=0A =0A=0ABob, thanks for getting this togethe r again this year. My wife and I are planning our first trip to Oshkosh th is year and will reserve a site in the RV-10HQ area as instructed below. A s this will be our first Oshkosh experience, I have no idea what the logist ics at the field will be other than we plan to get to Oshkosh on Friday or Saturday before the show. How do the guys get their camping stuff from RV parking to the HQ camping site. Shuttles, carry on your back..??? We are planning on arriving early in hopes of beating the crowd and besides we wan t to take in the whole positive experience, so we are staying to the end. Having a premo camp site close to facilities with other RV10'ers will go a long way in making this a pleasant week. So any helpful hints on what to b ring, what not to bring, etc would be most appreciated. =0A =0ALooking for ward to meeting you and the other RV10 families this year.=0A =0ARegards, =0A =0ABill Gipson=0AConroe, Texas=0A281-814-6006=0A =0A> Subject: RV10-Lis t: 2010 OSH RV-10 HQ Camping=0A> From: bob.condrey(at)baesystems.com=0A> Date: =0A> It's getting to be that time of year because phone calls and emails ha ve started! =0A> =0A> Gary and I will again stake out sites for those who a re interested in being in the RV-10 HQ area. In past years this has been a group of around 25 RV-10 folks ranging from those just starting the tail ki t to those that have been flying for multiple years. Additionally we=C3=A2 =82=AC=84=A2ve traditionally facilitated a couple of large cookouts w here those not camping with us can attend =C3=A2=82=AC=9C typicall y upwards of 75-100 people including some notable vendors.=0A> We will agai n stake out the sites on the Tuesday before Airventure starts which is 7/20 this year. Payment is required in advance from the first night through the Sunday night at the end of Airventure which winds up being 13 nights. Pric e this year is $22 per night which comes out to $286. You can either mail m e a check (contact me offline for address) or use PayPal. PayPal is much ea sier all the way around but there's a fee of about $9 that they'll take out so if you use that service you'll need to send $295. =0A> =0A> Here=C3=A2 =82=AC=84=A2s how it works if you=C3=A2=82=AC=84=A2re intereste d:=0A> Gary, Tim and I (and wives) simply facilitate this for the good of t he group. Cost is actual cost of the sites - this is not a profit making ve nture. Your campsite will be in your name (I will need your EAA number) and will be paid for with a check rather than a credit card. This means if you leave early you will receive a check from EAA when you turn in your site r egistration on your way out of the campgrounds. I will check with Tim to se e if he=C3=A2=82=AC=84=A2s willing to once again have info on his web site to facilitate people leaving early coordinating with others coming lat e in the week. =0A> =0A> Summary, if you want a campsite with the group: =0A> - I need $286 from you ($295 if using PayPal) no later than 7/14/2010. =0A> - If using PayPal, please send to bcondrey at cox dot net =0A> - I wil l need your EAA number for the registration and your membership must be val id through at least August 2010.=0A> - It would be helpful if you'd send me an email with the date you're planning to arrive and leave and the type of camper (Class A, tent, etc) =0A> - We'll use our best judgment for the gro up location based on what's available when we get there but our target will be in the same area that we've been the last few years which is immediatel y south of Paul=C3=A2=82=AC=84=A2s Park in Camp Scholler (around 55th and Lindbergh).=0A> - Sites get tagged as required using a little logic ba sed on size of the camper, tent vs. Class A motorhome, whether you=C3=A2 =82=AC=84=A2ve got kids, etc. If you don=C3=A2=82=AC=84=A2t like t he location you can swap around when you get there. =0A> - We=C3=A2=82 =AC=84=A2ll have your car pass, etc. at one of our sites and you simply call when you get close and somebody meet you at the registration gate.=0A> Most questions can be answered with the info from last year on Tim=C3=A2 =82=AC=84=A2s website at: www.myrv10.com/osh/Camping_FAQ.html =0A> =0A> I=C3=A2=82=AC=84=A2ll post more info and a reminder in a few wee ks when it gets closer. =0A> =0A> Bob =0A> RV-10 N442PM (flying)=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.matronic -======================== ============0A=0A ________________________________________________________________________________
Date: Jun 05, 2010
Subject: Re: Comm Antennas
Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: > Hi > > I am planning on installing two Comant CI-122 antennas tomorrow. My plan is > to fab doublers and install the antennas / doublers just aft and inboard of > the fuse steps. My reason for this is I have inspection panels in that area > for the steps so it seems like a good choice. I am not keen on installing > anything where access is a problem. > > Can anyone thing of reasons to not do what I plan? Are there better options > for these antennas? > > Cheers > > Les > #40643 > > > * > > * > > ________________________________________________________________________________
Date: Jun 05, 2010
Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 05, 2010
This is exactly the place where Deems installed his CI-122's. Flip through the folder: http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html Perhaps he can give a report. Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Saturday, June 05, 2010 11:00 PM Subject: RE: RV10-List: Comm Antennas Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jun 06, 2010
I believe if you look carefully, Deems put his antennas under the back seat , not inside of the step mount. That allows more separation. I believe the number generally recommended is 4 ft between antennas, but that is hard to achieve and you probably can get away with a bit less. I can tell you that belly mounted antennas are not going to have stellar performance when on th e ground. Whether it is difficulty talking to ground control or a nearby remote outlet for picking up a clearance, there is a benefit from having on e antenna more elevated than possible on the belly. I have one on belly and one on top of fuselage on my Mooney. Not even airborne at altitude does the belly mounted antenna give better reception than the top mounted, and on th e ground the belly mounted does lose reception depending on position on the airport. I think where Les is proposing would be good for one antenna, but I wouldn' t want it too close to the steps, and I still don't think it would be desirable to have both there. On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil wrote: > This is exactly the place where Deems installed his CI-122=92s. > > > Flip through the folder: > > http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html > > > Perhaps he can give a report. > > > Phil > > > *From:* Les Kearney [mailto:kearney(at)shaw.ca] > *Sent:* Saturday, June 05, 2010 11:00 PM > > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Comm Antennas > > > Kelley > > > Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. > > > Cheers > > > Les > > > ------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly McMullen > *Sent:* June-05-10 7:59 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Comm Antennas > > Les, > That might be a good location for one antenna. Putting two antennas withi n > about 2 ft of each other is not good. > I'd consider either mounting one near an access panel on underside of win g > or far enough back in the tail cone to have more than 3 ft separation > between antennas. Alternatives include a Bob Archer wingtip Com antenna, an > antenna on the top of the fuselage. The more separation you can get, the > better. Of course you also need to consider separation from your ELT ante nna > and from GPS antenna. > > On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: > > Hi > > > I am planning on installing two Comant CI-122 antennas tomorrow. My plan is > to fab doublers and install the antennas / doublers just aft and inboard of > the fuse steps. My reason for this is I have inspection panels in that ar ea > for the steps so it seems like a good choice. I am not keen on installing > anything where access is a problem. > > > Can anyone thing of reasons to not do what I plan? Are there better optio ns > for these antennas? > > > Cheers > > > Les > > #40643 > > > * * > > * * > > *get="_blank">http://www.matronics.com/Navigator?RV10-List* > > *tp://forums.matronics.com* > > *_blank">http://www.matronics.com/contribution* > > * * > > > * * > > * * > > *href="http://www.matronics.com/Navigator?RV10-List">http://www.matroni cs.com/Navigator?RV10-List* > > *href="http://forums.matronics.com">http://forums.matronics.com* > > *href="http://www.matronics.com/contribution">http://www.matronics.com/ c* > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== > =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Jun 06, 2010
I agree with Kelly, I installed one comm on the bottom under the rear seats and I have one going on the top. I've had numerous occasions in the citation when ground or clearance won't hear me on the bottom antenna and when I switch over to the number two, which is on the top, they have me 5 by 5. After I taxi out to the runway I can switch back to the bottom and speak to tower. The bottom is also better when airborne. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300200#300200 ________________________________________________________________________________
Date: Jun 06, 2010
Yeah, that's true Kelly. Deems are a little further forward and that gives a little bit of extra space between them. I'd still be interested in knowing how it's working out though. From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Sunday, June 06, 2010 7:26 AM Subject: Re: RV10-List: Comm Antennas I believe if you look carefully, Deems put his antennas under the back seat, not inside of the step mount. That allows more separation. I believe the number generally recommended is 4 ft between antennas, but that is hard to achieve and you probably can get away with a bit less. I can tell you that belly mounted antennas are not going to have stellar performance when on the ground. Whether it is difficulty talking to ground control or a nearby remote outlet for picking up a clearance, there is a benefit from having one antenna more elevated than possible on the belly. I have one on belly and one on top of fuselage on my Mooney. Not even airborne at altitude does the belly mounted antenna give better reception than the top mounted, and on the ground the belly mounted does lose reception depending on position on the airport. I think where Les is proposing would be good for one antenna, but I wouldn't want it too close to the steps, and I still don't think it would be desirable to have both there. On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil wrote: This is exactly the place where Deems installed his CI-122's. Flip through the folder: http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html Perhaps he can give a report. Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Saturday, June 05, 2010 11:00 PM Subject: RE: RV10-List: Comm Antennas Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 06, 2010
I've not experienced any problems with ground operations. once caveat however, I have not had occasion to contact a remote facility while on the ground. Deems On 6/6/2010 6:51 AM, Perry, Phil wrote: > > Yeah, that's true Kelly. Deems are a little further forward and that > gives a little bit of extra space between them. > > I'd still be interested in knowing how it's working out though. > > *From:* Kelly McMullen [mailto:apilot2(at)gmail.com] > *Sent:* Sunday, June 06, 2010 7:26 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Comm Antennas > > I believe if you look carefully, Deems put his antennas under the back > seat, not inside of the step mount. That allows more separation. I > believe the number generally recommended is 4 ft between antennas, but > that is hard to achieve and you probably can get away with a bit less. > I can tell you that belly mounted antennas are not going to have > stellar performance when on the ground. Whether it is difficulty > talking to ground control or a nearby remote outlet for picking up a > clearance, there is a benefit from having one antenna more elevated > than possible on the belly. I have one on belly and one on top of > fuselage on my Mooney. Not even airborne at altitude does the belly > mounted antenna give better reception than the top mounted, and on the > ground the belly mounted does lose reception depending on position on > the airport. > > I think where Les is proposing would be good for one antenna, but I > wouldn't want it too close to the steps, and I still don't think it > would be desirable to have both there. > > On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil > wrote: > > This is exactly the place where Deems installed his CI-122's. > > Flip through the folder: > > http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html > > Perhaps he can give a report. > > Phil > > *From:* Les Kearney [mailto:kearney(at)shaw.ca ] > *Sent:* Saturday, June 05, 2010 11:00 PM > > > *To:* rv10-list(at)matronics.com > > *Subject:* RE: RV10-List: Comm Antennas > > Kelley > > Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. > > Cheers > > Les > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] *On Behalf Of *Kelly > McMullen > *Sent:* June-05-10 7:59 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Comm Antennas > > Les, > That might be a good location for one antenna. Putting two antennas > within about 2 ft of each other is not good. > I'd consider either mounting one near an access panel on underside of > wing or far enough back in the tail cone to have more than 3 ft > separation between antennas. Alternatives include a Bob Archer > wingtip Com antenna, an antenna on the top of the fuselage. The more > separation you can get, the better. Of course you also need to > consider separation from your ELT antenna and from GPS antenna. > > On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney > wrote: > > Hi > > I am planning on installing two Comant CI-122 antennas tomorrow. My > plan is to fab doublers and install the antennas / doublers just aft > and inboard of the fuse steps. My reason for this is I have inspection > panels in that area for the steps so it seems like a good choice. I am > not keen on installing anything where access is a problem. > > Can anyone thing of reasons to not do what I plan? Are there better > options for these antennas? > > Cheers > > Les > > #40643 > > * * > * * > *get="_blank">http://www.matronics.com/Navigator?RV10-List* > *tp://forums.matronics.com <http://forums.matronics.com>* > *_blank">http://www.matronics.com/contribution* > * * > > * * > * * > *href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List* > *href="http://forums.matronics.com">http://forums.matronics.com* > *href="http://www.matronics.com/contribution">http://www.matronics.com/c* > * * > * * > *http://www.matronics.com/Navigator?RV10-List* > *http://forums.matronics.com* > *http://www.matronics.com/contribution* > * * > * * > * * > *get="_blank">http://www.matronics.com/Navigator?RV10-List* > * * > *tp://forums.matronics.com* > *_blank">http://www.matronics.com/contribution* > * * > > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Jun 06, 2010
SSd2ZSBnb3QgbWluZSBsb2NhdGVkIHdoZXIgRGVlbXMgaGFzIGhpcyBhbmQgaGF2ZW4ndCBoYWQg YW4gaXNzdWUgaW4gb3ZlciAyIHllYXJzIG9mIGZseWluZyB0aGF0IHdheS4NCkJvYg0KDQpfX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZl ckBtYXRyb25pY3MuY29tIDxvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+DQpU bzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20gPHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU2Vu dDogU3VuIEp1biAwNiAwNjo1MTowOCAyMDEwDQpTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBDb21t IEFudGVubmFzDQoNClllYWgsIHRoYXTigJlzIHRydWUgS2VsbHkuICBEZWVtcyBhcmUgYSBsaXR0 bGUgZnVydGhlciBmb3J3YXJkIGFuZCB0aGF0IGdpdmVzIGEgbGl0dGxlIGJpdCBvZiBleHRyYSBz cGFjZSBiZXR3ZWVuIHRoZW0uDQoNCknigJlkIHN0aWxsIGJlIGludGVyZXN0ZWQgaW4ga25vd2lu ZyBob3cgaXTigJlzIHdvcmtpbmcgb3V0IHRob3VnaC4NCg0KDQoNCkZyb206IEtlbGx5IE1jTXVs bGVuIFttYWlsdG86YXBpbG90MkBnbWFpbC5jb21dDQpTZW50OiBTdW5kYXksIEp1bmUgMDYsIDIw MTAgNzoyNiBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYx MC1MaXN0OiBDb21tIEFudGVubmFzDQoNCkkgYmVsaWV2ZSBpZiB5b3UgbG9vayBjYXJlZnVsbHks IERlZW1zIHB1dCBoaXMgYW50ZW5uYXMgdW5kZXIgdGhlIGJhY2sgc2VhdCwgbm90IGluc2lkZSBv ZiB0aGUgc3RlcCBtb3VudC4gVGhhdCBhbGxvd3MgbW9yZSBzZXBhcmF0aW9uLiBJIGJlbGlldmUg dGhlIG51bWJlciBnZW5lcmFsbHkgcmVjb21tZW5kZWQgaXMgNCBmdCBiZXR3ZWVuIGFudGVubmFz LCBidXQgdGhhdCBpcyBoYXJkIHRvIGFjaGlldmUgYW5kIHlvdSBwcm9iYWJseSBjYW4gZ2V0IGF3 YXkgd2l0aCBhIGJpdCBsZXNzLiBJIGNhbiB0ZWxsIHlvdSB0aGF0IGJlbGx5IG1vdW50ZWQgYW50 ZW5uYXMgYXJlIG5vdCBnb2luZyB0byBoYXZlIHN0ZWxsYXIgcGVyZm9ybWFuY2Ugd2hlbiBvbiB0 aGUgZ3JvdW5kLiBXaGV0aGVyIGl0IGlzIGRpZmZpY3VsdHkgdGFsa2luZyB0byBncm91bmQgY29u dHJvbCBvciBhIG5lYXJieSByZW1vdGUgb3V0bGV0IGZvciBwaWNraW5nIHVwIGEgY2xlYXJhbmNl LCB0aGVyZSBpcyBhIGJlbmVmaXQgZnJvbSBoYXZpbmcgb25lIGFudGVubmEgbW9yZSBlbGV2YXRl ZCB0aGFuIHBvc3NpYmxlIG9uIHRoZSBiZWxseS4gIEkgaGF2ZSBvbmUgb24gYmVsbHkgYW5kIG9u ZSBvbiB0b3Agb2YgZnVzZWxhZ2Ugb24gbXkgTW9vbmV5LiBOb3QgZXZlbiBhaXJib3JuZSBhdCBh bHRpdHVkZSBkb2VzIHRoZSBiZWxseSBtb3VudGVkIGFudGVubmEgZ2l2ZSBiZXR0ZXIgcmVjZXB0 aW9uIHRoYW4gdGhlIHRvcCBtb3VudGVkLCBhbmQgb24gdGhlIGdyb3VuZCB0aGUgYmVsbHkgbW91 bnRlZCBkb2VzIGxvc2UgcmVjZXB0aW9uIGRlcGVuZGluZyBvbiBwb3NpdGlvbiBvbiB0aGUgYWly cG9ydC4NCg0KSSB0aGluayB3aGVyZSBMZXMgaXMgcHJvcG9zaW5nIHdvdWxkIGJlIGdvb2QgZm9y IG9uZSBhbnRlbm5hLCBidXQgSSB3b3VsZG4ndCB3YW50IGl0IHRvbyBjbG9zZSB0byB0aGUgc3Rl cHMsIGFuZCBJIHN0aWxsIGRvbid0IHRoaW5rIGl0IHdvdWxkIGJlIGRlc2lyYWJsZSB0byBoYXZl IGJvdGggdGhlcmUuDQpPbiBTYXQsIEp1biA1LCAyMDEwIGF0IDk6MjUgUE0sIFBlcnJ5LCBQaGls IDxQaGlsLlBlcnJ5QG5ldGFwcC5jb208bWFpbHRvOlBoaWwuUGVycnlAbmV0YXBwLmNvbT4+IHdy b3RlOg0KVGhpcyBpcyBleGFjdGx5IHRoZSBwbGFjZSB3aGVyZSBEZWVtcyBpbnN0YWxsZWQgaGlz IENJLTEyMuKAmXMuDQoNCkZsaXAgdGhyb3VnaCB0aGUgZm9sZGVyOg0KaHR0cDovL3d3dy5kZWVt c3J2MTAuY29tL2FsYnVtL1NlYyUyMDMzJTIwQmFnZ2FnZSUyMEFyZWEvaW5kZXguaHRtbA0KDQpQ ZXJoYXBzIGhlIGNhbiBnaXZlIGEgcmVwb3J0Lg0KDQpQaGlsDQoNCg0KDQpGcm9tOiBMZXMgS2Vh cm5leSBbbWFpbHRvOmtlYXJuZXlAc2hhdy5jYTxtYWlsdG86a2Vhcm5leUBzaGF3LmNhPl0NClNl bnQ6IFNhdHVyZGF5LCBKdW5lIDA1LCAyMDEwIDExOjAwIFBNDQoNClRvOiBydjEwLWxpc3RAbWF0 cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBSRTog UlYxMC1MaXN0OiBDb21tIEFudGVubmFzDQoNCktlbGxleQ0KDQpJcyAzIGZ0IHRoZSBtYWdpYyBu dW1iZXI/IElmIHNvLCBJIG1pZ2h0IGJlIG9rYXkuIEknbGwgbWVhc3VyZSB0b21vcnJvdy4NCg0K Q2hlZXJzDQoNCkxlcw0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KRnJvbTog b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+ XSBPbiBCZWhhbGYgT2YgS2VsbHkgTWNNdWxsZW4NClNlbnQ6IEp1bmUtMDUtMTAgNzo1OSBQTQ0K VG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNv bT4NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IENvbW0gQW50ZW5uYXMNCkxlcywNClRoYXQgbWln aHQgYmUgYSBnb29kIGxvY2F0aW9uIGZvciBvbmUgYW50ZW5uYS4gUHV0dGluZyB0d28gYW50ZW5u YXMgd2l0aGluIGFib3V0IDIgZnQgb2YgZWFjaCBvdGhlciBpcyBub3QgZ29vZC4NCkknZCBjb25z aWRlciBlaXRoZXIgbW91bnRpbmcgb25lIG5lYXIgYW4gYWNjZXNzIHBhbmVsIG9uIHVuZGVyc2lk ZSBvZiB3aW5nIG9yIGZhciBlbm91Z2ggYmFjayBpbiB0aGUgdGFpbCBjb25lIHRvIGhhdmUgbW9y ZSB0aGFuIDMgZnQgc2VwYXJhdGlvbiBiZXR3ZWVuIGFudGVubmFzLiAgQWx0ZXJuYXRpdmVzIGlu Y2x1ZGUgYSBCb2IgQXJjaGVyIHdpbmd0aXAgQ29tIGFudGVubmEsIGFuIGFudGVubmEgb24gdGhl IHRvcCBvZiB0aGUgZnVzZWxhZ2UuIFRoZSBtb3JlIHNlcGFyYXRpb24geW91IGNhbiBnZXQsIHRo ZSBiZXR0ZXIuIE9mIGNvdXJzZSB5b3UgYWxzbyBuZWVkIHRvIGNvbnNpZGVyIHNlcGFyYXRpb24g ZnJvbSB5b3VyIEVMVCBhbnRlbm5hIGFuZCBmcm9tIEdQUyBhbnRlbm5hLg0KT24gU2F0LCBKdW4g NSwgMjAxMCBhdCA1OjA0IFBNLCBMZXMgS2Vhcm5leSA8a2Vhcm5leUBzaGF3LmNhPG1haWx0bzpr ZWFybmV5QHNoYXcuY2E+PiB3cm90ZToNCkhpDQoNCkkgYW0gcGxhbm5pbmcgb24gaW5zdGFsbGlu ZyB0d28gQ29tYW50IENJLTEyMiBhbnRlbm5hcyB0b21vcnJvdy4gTXkgcGxhbiBpcyB0byBmYWIg ZG91YmxlcnMgYW5kIGluc3RhbGwgdGhlIGFudGVubmFzIC8gZG91YmxlcnMganVzdCBhZnQgYW5k IGluYm9hcmQgb2YgdGhlIGZ1c2Ugc3RlcHMuIE15IHJlYXNvbiBmb3IgdGhpcyBpcyBJIGhhdmUg aW5zcGVjdGlvbiBwYW5lbHMgaW4gdGhhdCBhcmVhIGZvciB0aGUgc3RlcHMgc28gaXQgc2VlbXMg bGlrZSBhIGdvb2QgY2hvaWNlLiBJIGFtIG5vdCBrZWVuIG9uIGluc3RhbGxpbmcgYW55dGhpbmcg d2hlcmUgYWNjZXNzIGlzIGEgcHJvYmxlbS4NCg0KQ2FuIGFueW9uZSB0aGluZyBvZiByZWFzb25z IHRvIG5vdCBkbyB3aGF0IEkgcGxhbj8gQXJlIHRoZXJlIGJldHRlciBvcHRpb25zIGZvciB0aGVz ZSBhbnRlbm5hcz8NCg0KQ2hlZXJzDQoNCkxlcw0KIzQwNjQzDQoNCg0KDQoNCg0KDQpnZXQ9Il9i bGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KdHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbTxodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20+DQoNCl9i bGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0KDQoNCg0K DQoNCmhyZWY9Imh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0Ij5o dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpocmVmPSJodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20iPmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpo cmVmPSJodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vYw0KDQoNCg0KDQoNCmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/UlYxMC1MaXN0DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCg0KDQoNCg0KDQoNCmdldD0iX2JsYW5rIj5o dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQoNCg0KdHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KDQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP1JWMTAtTGlzdA0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAg ICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCl8tPSBVc2UgdGhlIE1hdHJvbmlj cyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCl8tPSB0aGUgbWFueSBMaXN0IHV0 aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KXy09IEFyY2hpdmUgU2VhcmNo ICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09IFBob3Rvc2hhcmUsIGFu ZCBtdWNoIG11Y2ggbW9yZToNCl8tPQ0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFi bGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09DQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQpfLT0NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09DQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlv biBXZWIgU2l0ZSAtDQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0K Xy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWlu Lg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCg0K ________________________________________________________________________________
Date: Jun 06, 2010
I had mine in the same position, and had a problem communicating with towers on the lower end of the frequency spectrum (118.1 --118.3). So I moved one of the antennas up to the top and left the other on the bottom. Have not seen any problems since. For ref: Home field, KOGD (Ogden Utah) Tower 118, never had a problem Problems encountered: Boise (KBOI) Tower 118.1 Salt Lake City (KSLC) Tower 118.3 Problems encounter during ground operations all the times except once, they could not hear me one time after I was initially handed off..at least that is what they said Just my experience. I noticed a .12673 Knot decrease in cruise speed with the antenna change..just kidding of course. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA) Sent: Sunday, June 06, 2010 8:23 AM Subject: Re: RV10-List: Comm Antennas I've got mine located wher Deems has his and haven't had an issue in over 2 years of flying that way. Bob _____ From: owner-rv10-list-server(at)matronics.com Sent: Sun Jun 06 06:51:08 2010 Subject: RE: RV10-List: Comm Antennas Yeah, that=99s true Kelly. Deems are a little further forward and that gives a little bit of extra space between them. I=99d still be interested in knowing how it=99s working out though. From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Sunday, June 06, 2010 7:26 AM Subject: Re: RV10-List: Comm Antennas I believe if you look carefully, Deems put his antennas under the back seat, not inside of the step mount. That allows more separation. I believe the number generally recommended is 4 ft between antennas, but that is hard to achieve and you probably can get away with a bit less. I can tell you that belly mounted antennas are not going to have stellar performance when on the ground. Whether it is difficulty talking to ground control or a nearby remote outlet for picking up a clearance, there is a benefit from having one antenna more elevated than possible on the belly. I have one on belly and one on top of fuselage on my Mooney. Not even airborne at altitude does the belly mounted antenna give better reception than the top mounted, and on the ground the belly mounted does lose reception depending on position on the airport. I think where Les is proposing would be good for one antenna, but I wouldn't want it too close to the steps, and I still don't think it would be desirable to have both there. On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil wrote: This is exactly the place where Deems installed his CI-122=99s. Flip through the folder: http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html Perhaps he can give a report. Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Saturday, June 05, 2010 11:00 PM Subject: RE: RV10-List: Comm Antennas Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ~=EF=BD=DE=83g(=D3=8D=D3=87qzn ________________________________________________________________________________
Date: Jun 06, 2010
Agree with Kelly on this. Even Cirrus with their all composite airframes have one antenna on the top and the other on the belly. Certainly if one wants to follow function over form and there is no concern for remote ground reception, dual belly antennas will be fine. On Sat, Jun 5, 2010 at 9:59 PM, Kelly McMullen wrote: > Les, > That might be a good location for one antenna. Putting two antennas within > about 2 ft of each other is not good. > I'd consider either mounting one near an access panel on underside of wing > or far enough back in the tail cone to have more than 3 ft separation > between antennas. Alternatives include a Bob Archer wingtip Com antenna, an > antenna on the top of the fuselage. The more separation you can get, the > better. Of course you also need to consider separation from your ELT antenna > and from GPS antenna. > -- William http://nerv10.com/wcurtis/90Electrical/antenna.html ________________________________________________________________________________
Date: Jun 06, 2010
No problems here either. Maybe metal whips are less prone to issues due to size/design? Tim On Jun 6, 2010, at 9:14 AM, Deems Davis wrote: > I've not experienced any problems with ground operations. once > caveat however, I have not had occasion to contact a remote facility > while on the ground. > > Deems > > On 6/6/2010 6:51 AM, Perry, Phil wrote: >> >> Yeah, that=99s true Kelly. Deems are a little further forward and t >> hat gives a little bit of extra space between them. >> >> I=99d still be interested in knowing how it=99s working out though. >> >> >> >> From: Kelly McMullen [mailto:apilot2(at)gmail.com] >> Sent: Sunday, June 06, 2010 7:26 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Comm Antennas >> >> I believe if you look carefully, Deems put his antennas under the >> back seat, not inside of the step mount. That allows more >> separation. I believe the number generally recommended is 4 ft >> between antennas, but that is hard to achieve and you probably can >> get away with a bit less. I can tell you that belly mounted >> antennas are not going to have stellar performance when on the >> ground. Whether it is difficulty talking to ground control or a >> nearby remote outlet for picking up a clearance, there is a benefit >> from having one antenna more elevated than possible on the belly. >> I have one on belly and one on top of fuselage on my Mooney. Not >> even airborne at altitude does the belly mounted antenna give >> better reception than the top mounted, and on the ground the belly >> mounted does lose reception depending on position on the airport. >> >> I think where Les is proposing would be good for one antenna, but I >> wouldn't want it too close to the steps, and I still don't think it >> would be desirable to have both there. >> >> On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil >> wrote: >> This is exactly the place where Deems installed his CI-122=99s. >> >> Flip through the folder: >> http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html >> >> Perhaps he can give a report. >> >> Phil >> >> >> >> From: Les Kearney [mailto:kearney(at)shaw.ca] >> Sent: Saturday, June 05, 2010 11:00 PM >> >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Comm Antennas >> >> Kelley >> >> Is 3 ft the magic number? If so, I might be okay. I'll measure >> tomorrow. >> >> Cheers >> >> Les >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list- >> server(at)matronics.com] On Behalf Of Kelly McMullen >> Sent: June-05-10 7:59 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Comm Antennas >> >> Les, >> That might be a good location for one antenna. Putting two antennas >> within about 2 ft of each other is not good. >> I'd consider either mounting one near an access panel on underside >> of wing or far enough back in the tail cone to have more than 3 ft >> separation between antennas. Alternatives include a Bob Archer >> wingtip Com antenna, an antenna on the top of the fuselage. The >> more separation you can get, the better. Of course you also need to >> consider separation from your ELT antenna and from GPS antenna. >> >> On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: >> Hi >> >> I am planning on installing two Comant CI-122 antennas tomorrow. My >> plan is to fab doublers and install the antennas / doublers just >> aft and inboard of the fuse steps. My reason for this is I have >> inspection panels in that area for the steps so it seems like a >> good choice. I am not keen on installing anything where access is a >> problem. >> >> Can anyone thing of reasons to not do what I plan? Are there better >> options for these antennas? >> >> Cheers >> >> Les >> #40643 >> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> http://www.matronics.com/Navigator?RV10-List >> http://forums.matronics.com >> http://www.matronics.com/contribution >> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> >> >> >> http://www.matronics.com/Navigator?RV10-List >> http://forums.matronics.com >> http://www.matronics.com/contribution >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >> > > ________________________________________________________________________________
Subject: static port
Date: Jun 06, 2010
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
We had long ago installed flush static ports, before hearing how they end up being less accurate than those with a slight outward bump. I don't feel like crawling back in the tailcone and replacing the existing ports. Any opinions on the efficacy of gluing a washer or other small metal disk on top of the flush port, with an appropriately-sized hole leading into the port itself? TDT Tim Dawson-Townsend RV-10 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 06, 2010
Same exact problem I had on my 8A. I drilled a 1/16=94 hole in the center of a couple of 1/8=94 AN470 rivets. After drilling the hole I used a Dremmel tool to cut off the rivet shank, then sanded flush. I used JB Weld to epoxy the rivet heads to the flush static ports, putting a shaved down toothpick in the hole to both hold it in place while the epoxy cured and to keep the hole clear. Photos attached. After 200 hrs still working perfectly. For the RV-10 I=92m using a couple of 3/16=94 AN470 rivets with a 1/16=94 hole drilled through the head and the rivet shank. I=92ll just epoxy the whole rivet in, then glue on the =BC=94 static line over the rivet shank. Carl Froehlich RV-8A (540 hrs) RV-10 (systems install) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Sunday, June 06, 2010 12:42 PM Subject: RV10-List: static port We had long ago installed flush static ports, before hearing how they end up being less accurate than those with a slight outward bump. I don=92t feel like crawling back in the tailcone and replacing the existing ports. Any opinions on the efficacy of gluing a washer or other small metal disk on top of the flush port, with an appropriately-sized hole leading into the port itself? TDT Tim Dawson-Townsend RV-10 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jun 06, 2010
does the transponder antenna need to be considered and what about ads-b tr ansceiver antenna? nav and gps are receive only but do they need to be con sidered?I am not a fan of the archer ant for an ifr ship,in my experince they are quirky(I think thats a word). -----Original Message----- From: Tim Olson <Tim(at)MyRV10.com> Sent: Sun, Jun 6, 2010 8:26 am Subject: Re: RV10-List: Comm Antennas No problems here either. Maybe metal whips are less prone to issues due to size/design? Tim On Jun 6, 2010, at 9:14 AM, Deems Davis wrote: I've not experienced any problems with ground operations. once caveat howe ver, I have not had occasion to contact a remote facility while on the gro und. Deems On 6/6/2010 6:51 AM, Perry, Phil wrote: Yeah, that=99s true Kelly. Deems are a little further forward and that gives a little bit of extra space between them. I=99d still be interested in knowing how it=99s working out th ough. From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Sunday, June 06, 2010 7:26 AM Subject: Re: RV10-List: Comm Antennas I believe if you look carefully, Deems put his antennas under the back sea t, not inside of the step mount. That allows more separation. I believe th e number generally recommended is 4 ft between antennas, but that is hard to achieve and you probably can get away with a bit less. I can tell you that belly mounted antennas are not going to have stellar performance whe n on the ground. Whether it is difficulty talking to ground control or a nearby remote outlet for picking up a clearance, there is a benefit from having one antenna more elevated than possible on the belly. I have one on belly and one on top of fuselage on my Mooney. Not even airborne at al titude does the belly mounted antenna give better reception than the top mounted, and on the ground the belly mounted does lose reception dependin g on position on the airport. I think where Les is proposing would be good for one antenna, but I wouldn 't want it too close to the steps, and I still don't think it would be des irable to have both there. On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil wrote: This is exactly the place where Deems installed his CI-122=99s. Flip through the folder: http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html Perhaps he can give a report. Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Saturday, June 05, 2010 11:00 PM Subject: RE: RV10-List: Comm Antennas Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation bet ween antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT ante nna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboa rd of the fuse steps. My reason for this is I have inspection panels in th at area for the steps so it seems like a good choice. I am not keen on ins talling anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better option s for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/con tribution ======================== =========== -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== ======================== =========== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== ======================== =========== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ======================== =========== ________________________________________________________________________________
Subject: Re: static port
Date: Jun 06, 2010
Kevin Horton had some great info about fixing static port errors. I believe it was in one of his articles in Kitplanes. David Maib 40559 On Jun 6, 2010, at 12:42 PM, Dawson-Townsend,Timothy wrote: We had long ago installed flush static ports, before hearing how they end up being less accurate than those with a slight outward bump. I don=92t feel like crawling back in the tailcone and replacing the existing ports. Any opinions on the efficacy of gluing a washer or other small metal disk on top of the flush port, with an appropriately-sized hole leading into the port itself? TDT Tim Dawson-Townsend RV-10 40025 tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jun 06, 2010
Short answer, Yes GPS needs to be on top. Cat whiskers can go on the top of the vertical or on the bottom of the tail, since you aren=99t using the archer (I=99m not a fan either). While Commant states that they should point forward, there are many RVs with them pointing aft underneath the empennage. I would also suggest reading the install manual for your ads-b equipment. NavWork is pretty up front, for an example, here=99s an excerpt: I haven=99t put in either of these yet, but I=99m thinking the transponder will go in the tunnel near the firewall and the ADS-B will be back by the battery someplace. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds(at)aol.com Sent: Sunday, June 06, 2010 2:47 PM Subject: Re: RV10-List: Comm Antennas does the transponder antenna need to be considered and what about ads-b transceiver antenna? nav and gps are receive only but do they need to be considered?I am not a fan of the archer ant for an ifr ship,in my experince they are quirky(I think thats a word). -----Original Message----- From: Tim Olson <Tim(at)MyRV10.com> Sent: Sun, Jun 6, 2010 8:26 am Subject: Re: RV10-List: Comm Antennas No problems here either. Maybe metal whips are less prone to issues due to size/design? Tim On Jun 6, 2010, at 9:14 AM, Deems Davis wrote: I've not experienced any problems with ground operations. once caveat however, I have not had occasion to contact a remote facility while on the ground. Deems On 6/6/2010 6:51 AM, Perry, Phil wrote: Yeah, that=99s true Kelly. Deems are a little further forward and that gives a little bit of extra space between them. I=99d still be interested in knowing how it=99s working out though. From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Sunday, June 06, 2010 7:26 AM Subject: Re: RV10-List: Comm Antennas I believe if you look carefully, Deems put his antennas under the back seat, not inside of the step mount. That allows more separation. I believe the number generally recommended is 4 ft between antennas, but that is hard to achieve and you probably can get away with a bit less. I can tell you that belly mounted antennas are not going to have stellar performance when on the ground. Whether it is difficulty talking to ground control or a nearby remote outlet for picking up a clearance, there is a benefit from having one antenna more elevated than possible on the belly. I have one on belly and one on top of fuselage on my Mooney. Not even airborne at altitude does the belly mounted antenna give better reception than the top mounted, and on the ground the belly mounted does lose reception depending on position on the airport. I think where Les is proposing would be good for one antenna, but I wouldn't want it too close to the steps, and I still don't think it would be desirable to have both there. On Sat, Jun 5, 2010 at 9:25 PM, Perry, Phil wrote: This is exactly the place where Deems installed his CI-122=99s. Flip through the folder: http://www.deemsrv10.com/album/Sec%2033%20Baggage%20Area/index.html Perhaps he can give a report. Phil From: Les Kearney [mailto:kearney(at)shaw.ca] Sent: Saturday, June 05, 2010 11:00 PM Subject: RE: RV10-List: Comm Antennas Kelley Is 3 ft the magic number? If so, I might be okay. I'll measure tomorrow. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: June-05-10 7:59 PM Subject: Re: RV10-List: Comm Antennas Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: Hi I am planning on installing two Comant CI-122 antennas tomorrow. My plan is to fab doublers and install the antennas / doublers just aft and inboard of the fuse steps. My reason for this is I have inspection panels in that area for the steps so it seems like a good choice. I am not keen on installing anything where access is a problem. Can anyone thing of reasons to not do what I plan? Are there better options for these antennas? Cheers Les #40643 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com <http://forums.matronics.com/> _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com ">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution rget=_blank>http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 06, 2010
The shuttles were running Friday at 1pm when we got there last year. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300258#300258 ________________________________________________________________________________
Date: Jun 06, 2010
My com antennas are where Deems and most others have reported, below rear seat floors with good performance. Transponder is on belly centerline about 10 inches aft of firewall. In the past few months I have been getting an occasional report of intermittent response, seems to be when the radar sight is on the nose at relatively close range, most sites report normal ops after a few minutes of outage at most. VOR is Archer in wing tip, works fine. I have a back up GPS and XM antennas mounted on the firewall under the top cowling, they both work fine. Dick Sipp N110DV 285 hours From: pilotdds(at)aol.com Sent: Sunday, June 06, 2010 2:46 PM Subject: Re: RV10-List: Comm Antennas does the transponder antenna need to be considered and what about ads-b transceiver antenna? nav and gps are receive only but do they need to be considered?I am not a fan of the archer ant for an ifr ship,in my experince they are quirky(I think thats a word). ________________________________________________________________________________
Date: Jun 06, 2010
Hi Thanks for all the info on comm antennas. Checking out my planned placement, I realise that anyone accessing the baggage area coold accidently interfere with the antenna (luggage on ground etc). Not wanting to pull my floor pans or to install anything where it is inaccessible, I have decided to put one antenna in the tunnel just aft of the seats and off center (so it doesn't interfere with the control tubes). The other will go on the centerline in the empennage about 4' aft of the first. In retrospect and given the comments from Kelly et al, I like the idea of having one antenna completely clear of wings, gear and steps. I really would like to avoid an antenna on top (other than the GPS puck. Cheers Les #40643 ________________________________________________________________________________
Subject: Kiwi RV-10 #2
Date: Jun 07, 2010
My empennage kit just arrived! New Zealand has its second RV10 underway. Let the journey begin. Tony From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Monday, 7 June 2010 3:13 a.m. Subject: Re: RV10-List: Comm Antennas Agree with Kelly on this. Even Cirrus with their all composite airframes have one antenna on the top and the other on the belly. Certainly if one wants to follow function over form and there is no concern for remote ground reception, dual belly antennas will be fine. On Sat, Jun 5, 2010 at 9:59 PM, Kelly McMullen wrote: Les, That might be a good location for one antenna. Putting two antennas within about 2 ft of each other is not good. I'd consider either mounting one near an access panel on underside of wing or far enough back in the tail cone to have more than 3 ft separation between antennas. Alternatives include a Bob Archer wingtip Com antenna, an antenna on the top of the fuselage. The more separation you can get, the better. Of course you also need to consider separation from your ELT antenna and from GPS antenna. -- William http://nerv10.com/wcurtis/90Electrical/antenna.html ________________________________________________________________________________
Date: Jun 06, 2010
Subject: Re: Kiwi RV-10 #2
Builder number? Kelly 40866 On Sun, Jun 6, 2010 at 7:53 PM, Tony Woods wrote: > My empennage kit just arrived! > > > New Zealand has its second RV10 underway. Let the journey begin. > > > Tony ________________________________________________________________________________
Date: Jun 07, 2010
Builder 40583. And yep - I think this kit has sat in a garage for several years... Now it is scattered all over the lounge :-) Tony -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, 7 June 2010 3:00 p.m. Subject: Re: RV10-List: Kiwi RV-10 #2 Builder number? Kelly 40866 On Sun, Jun 6, 2010 at 7:53 PM, Tony Woods wrote: > My empennage kit just arrived! > > > New Zealand has its second RV10 underway. Let the journey begin. > > > Tony ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Jun 07, 2010
With the antenna mounted that far aft you might want to verify that the tail hits the ground before the antenna. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300307#300307 ________________________________________________________________________________
Subject: Re: Great Lakes RV Gathering
Date: Jun 07, 2010
All, just a reminder that this coming Saturday June 12 we will be hosting the Great Lakes RV Gathering @ KSBM. Thanks to everyone who has replied so far, if you plan to attend please let us know so we can have enough lunch for everyone. We will kick it off at 10, lunch around 12. All RVer's, all stages welcome. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300308#300308 ________________________________________________________________________________
Date: Jun 07, 2010
From: Richard Martin <martinaerodrome(at)gmail.com>
consider one Dorne & Margolen (DM) antenna on the belly with a diplexer inside of the airplane. The DM antenna will increase your range substantially and the diplexer will eliminate the need for 2 antennae. I noticed that after I installed the DM antenna (removed the comants) my range increased by at least 50 percent. good luck. Dick Martin RV8 N233m the fast one On Sat, Jun 5, 2010 at 8:59 PM, Kelly McMullen wrote: > Les, > That might be a good location for one antenna. Putting two antennas within > about 2 ft of each other is not good. > I'd consider either mounting one near an access panel on underside of wing > or far enough back in the tail cone to have more than 3 ft separation > between antennas. Alternatives include a Bob Archer wingtip Com antenna, an > antenna on the top of the fuselage. The more separation you can get, the > better. Of course you also need to consider separation from your ELT antenna > and from GPS antenna. > > On Sat, Jun 5, 2010 at 5:04 PM, Les Kearney wrote: > >> Hi >> >> I am planning on installing two Comant CI-122 antennas tomorrow. My plan >> is to fab doublers and install the antennas / doublers just aft and inboard >> of the fuse steps. My reason for this is I have inspection panels in that >> area for the steps so it seems like a good choice. I am not keen on >> installing anything where access is a problem. >> >> Can anyone thing of reasons to not do what I plan? Are there better >> options for these antennas? >> >> Cheers >> >> Les >> #40643 >> >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
From: "David Watterson" <davidw(at)dddirectories.com>
Subject: survey
Date: Jun 07, 2010
1800 rpm...1620-1640, 20 drop difference From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Saturday, June 05, 2010 3:13 PM Subject: RV10-List: survey What rpm is being used for the magneto check and what limits are considered acceptable? magneto drop? and drop difference? ________________________________________________________________________________
Date: Jun 07, 2010
Subject: Re: survey
I was getting similar drops as David indicated when doing Mag checks @ 1800. I now do them @ 2000 RPM and see a drop of only 100 RPM. Deems Davis N519PJ www.deemsrv10.com On 6/7/2010 6:36 AM, David Watterson wrote: > > 1800 rpm.....1620-1640, 20 drop difference > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *DLM > *Sent:* Saturday, June 05, 2010 3:13 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: survey > > What rpm is being used for the magneto check and what limits are > considered acceptable? magneto drop? and drop difference? > > * * > * * > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ________________________________________________________________________________
Subject: ADS-B: Transfering cost to the owner.
Date: Jun 07, 2010
I'm not sure if any of you saw this, but I found it on the EAA's site this morning. It's worth reading. Full Article...... http://www.eaa.org/news/2010/2010-06-03_ads-b.asp ---Snip---Snip--- EAA has long favored a satellite-based tracking system, provided that it would benefit aircraft operators as well as the national airspace system. Unfortunately, FAA has only mandated what's called ADS-B (out), which sends tracking information to the air traffic system. EAA has long held that the benefit to pilots would be from systems that allow us to receive traffic, weather, and safety information in the cockpit (ADS-B in). Without that element, the new mandate directly serves only FAA air traffic control. "What this new rule does is shift the cost of aircraft tracking from the government's mammoth ground-based radar systems to the cockpit and the individual pilot," said Doug Macnair, EAA's vice president of government relations. "It makes sense to migrate to new satellite-based technology based on ADS-B, which would replace existing transponders and encoders. But if the aircraft owner has to pay for it, pilots should also receive substantial safety and operational benefits." ---Snip---Snip--- ________________________________________________________________________________
Subject: Re: Comm Antennas
Date: Jun 07, 2010
I don't think the last suggestion will work. The usual passive splitter (diplexer?) will allow half the transmitter power to go directly into the second com radio--not good. Also these matched splitters may or may not handle thepower. If you put an active switch for the diplexer then you won't be able to hear on both radios simultaneously. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300363#300363 ________________________________________________________________________________
Subject: Re: EGT probes
Date: Jun 07, 2010
Just as a baseline: We had the original GEM (slow) probes in a 182 and after 1500+ hours no probes had yet failed. However, I think "fast" probes are thinner and will give less service life than "slow" probes. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300365#300365 ________________________________________________________________________________
Subject: Re: ADS-B: Transfering cost to the owner.
Date: Jun 07, 2010
SSBkb24ndCByZWFsbHkgY2FyZSB3aGF0IG1ldGhvZCBpcyB1c2VkIGZvciBuYXZpZ2F0aW9uLiAg QWxsIGZvcm1zIGhhdmUgdGhlaXIgb3duIHNob3J0Y29taW5ncy4gDQoNCkJ1dCB0aGUgaWRlYSBv ZiBBRFMtQiAoaW4pIG5vdCBiZWluZyBpbmNsdWRlZCBpbiB0aGUgbWFuZGF0ZSB3aGF0J3MgY29u Y2VybmluZy4gIFRoaXMgbWVhbnMgd2UgY291bGQgaW5zdGFsbCAoaW4pIGRldmljZXMgaW4gdGhl IGFpcmNyYWZ0IGJ1dCB0aGUgZ292ZXJubWVudCBoYXMgbm8gcmVxdWlyZW1lbnQgdG8gYnJvYWRj YXN0IHN1Y2ggaW5mb3JtYXRpb24uIA0KDQpUaGV5IG5lZWQgdG8gbWFuZGF0ZSB0aGUgYnJvYWRj YXN0IG9mIGFsbCBBRFMtQiBkYXRhLCBvdGhlcndpc2UgaXRzIG1vbmV5IHdlJ3JlIHNwZW5kaW5n IGZvciBubyBiZW5lZml0LiBUaGV5J3JlIHRyeWluZyB0byBrZWVwIHRoZWlyIHNlbGYgb2ZmIHRo ZSBob29rIGJ5IGNyZWF0aXZlbHkgd29ya2luZyBhcm91bmQgbWFuZGF0ZXMuIA0KDQpQaGlsDQoN Ci0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCkZyb206IFRpbSBPbHNvbiA8VGltQG15cnYx MC5jb20+DQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20gPHJ2MTAtbGlzdEBtYXRyb25pY3Mu Y29tPg0KU2VudDogTW9uIEp1biAwNyAxMDowMzoyMyAyMDEwDQpTdWJqZWN0OiBSZTogUlYxMC1M aXN0OiBBRFMtQjogVHJhbnNmZXJpbmcgY29zdCB0byB0aGUgb3duZXIuDQoNCi0tPiBSVjEwLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFRpbSBPbHNvbiA8VGltQG15cnYxMC5jb20+DQoNCkkgdGhp bmsgdGhhdCBwZW9wbGUgYXJlIGEgbGl0dGxlIG1vcmUgd29ya2VkIHVwIHRoYW4gdGhleQ0Kc2hv dWxkIGJlLiAgRmlyc3QsIGEgY29tbW9uIGNvbXBsYWludCBpcyB0aGF0IHRoZXkgc3RpbGwNCm5l ZWQgYSB0cmFuc3BvbmRlci4gIEkgZG9uJ3QgdGhpbmsgeW91J2Qgd2FudCB0byBvcGVyYXRlDQpT T0xFTFkgb24gR1BTIGJhc2VkIHBvc2l0aW9uaW5nLiAgR1BTIGlzbid0IDEwMCUgcmVsaWFibGUs DQp3aGljaCBpcyBhbHNvIHdoeSBhdCBsZWFzdCBhIGNlcnRhaW4gbnVtYmVyIG9mIFZPUidzIHNo b3VsZA0KYWx3YXlzIGJlIGtlcHQgb3BlcmF0aW9uYWwuICBBbHNvLCBkdWUgdG8gc29tZSBvZiB0 aGUNCnNvbGFyIGFjdGl2aXR5IGFuZCBjaGFuZ2VzIHdlJ3JlIGV4cGVyaWVuY2luZyBhbmQgZXhw ZWN0ZWQNCnRvIGV4cGVyaWVuY2UgaW4gdGhlIG5leHQgMC0yMCB5ZWFycywgSSBkb24ndCBrbm93 IHRoYXQNCndlJ2Qgd2FudCB0byByZWx5IG9uIEdQUyBhcyBhIHNvbGUgbWVhbnMsIGV2ZW4gZnJv bSB0aGF0DQpwZXJzcGVjdGl2ZS4gIFNvIGlmIHRoZXkgd2FudCBpdCB0byBiZSBhIG5ldyBTT0xF IG1lYW5zIG9mDQpwb3NpdGlvbiBpZGVudGlmaWNhdGlvbiwgdGhleSBzaG91bGQgZGV2ZWxvcCBp dCBvbiBhDQptdWNoIG1vcmUgZm9vbHByb29mIGJhc2UgdGVjaG5vbG9neSB0aGFuIEdQUy4gIEdp dmVuIHRoYXQsDQpJIHRoaW5rIGl0J3MgcmVhc29uYWJsZSB0byBoYXZlIGEgVHJhbnNwb25kZXIg cmVxdWlyZWQNCmZvciBjZXJ0YWluIGNvbnRyb2xsZWQgYWlyc3BhY2UsIGFuZCBhbHNvIGhhdmUg QURTLUINCnJlcXVpcmVkLg0KDQpBcyBmYXIgYXMgQURTLUIgIklOIiBiZWluZyBtYW5kYXRlZCwg SSdtIHJlYWxseSBub3QNCmludGVyZXN0ZWQgaW4gYW55dGhpbmcgYmVpbmcgbWFuZGF0ZWQgdG8g YmUgdXNlZCBmb3INCklOLiAgV2h5IHdvdWxkIHlvdT8gIERvbid0IG1hbmRhdGUgdGhhdCBzb21l b25lIEhBUw0KdG8gaGF2ZSBhIE1GRCBvciBQRkQgY2FwYWJsZSBvZiBkaXNwbGF5aW5nIHRoZSBp bmZvLg0KVGhlIGJlbmVmaXRzIGFscmVhZHkgZXhpc3QgZm9yIHRob3NlIHdobyBlcXVpcCwgdG8g aGF2ZQ0KdGhlIGRhdGEuICBJIG1lYW4sIGlmIHRoZXkgZ2l2ZSB5b3UgdHJhZmZpYyBmb3IgZnJl ZQ0KYWZ0ZXIgaGFyZHdhcmUgcHVyY2hhc2UsIHlvdSdkIGJlIGNyYXp5IG5vdCB0byB1c2UgaXQs DQp1bmxlc3MgeW91IG93biBhY3RpdmUgdHJhZmZpYy4uLmluIHdoaWNoIGNhc2Ugd2h5DQpzaG91 bGQgYW55b25lIG1hbmRhdGUgIklOIiBmb3IgeW91PyAgV2VhdGhlcj8gIFdlbGwsDQpJIHBlcnNv bmFsbHkgZG9uJ3QgZm9yc2VlIGdvaW5nIHRvIEZJUy1CIHdlYXRoZXIuICBUaGUNCmNvdmVyYWdl IHNpbXBseSB3aWxsIE5FVkVSIGJlIGFzIGdvb2QgYXMgV1NJIHdlYXRoZXINCmlzIGdpdmluZyBt ZSBub3cuICBJIHdhbnQgY292ZXJhZ2Ugb24gdGhlIGdyb3VuZCwNCkJFRk9SRSBJIGRlcGFydCwg ZnJvbSBhbnkgYWlycG9ydCwgb3IgZXZlbiAoYW5kDQplc3BlY2lhbGx5KSwgaWYgSSBmb3Igc29t ZSByZWFzb24gYW0gc2N1ZCBydW5uaW5nDQpzb21ld2hlcmUgKGFuZCBieSB0aGF0IEknbSBub3Qg dGFsa2luZyB0aGUgbmFzdHkNCnZpeiBzY3VkIHJ1bm5pbmcuLi5idXQgYSBtb3JlIHJlYXNvbmFi bGUgYW1vdW50IG9mDQp2aXopLg0KDQpUaGV5J3JlIHJpZ2h0IHRoYXQgdGhpcyBkb2VzIHNoaWZ0 IHNvbWUgb2YgdGhlIGNvc3RzDQp0byB0aGUgZW5kIHVzZXIsIGluc3RlYWQgb2YgdGhlIEZBQSwg YnV0LCBpbiB0aGUgZW5kLA0KYWxsIHVzZXJzIHdobyBwYXJ0aWNpcGF0ZSB3aWxsIGJlIGFibGUg dG8gYmVuZWZpdCBpZg0KaW4gbm8gb3RoZXIgd2F5IHRoYW4gdHJhZmZpYyBhbGVydHMsIGFzIGxv bmcgYXMgdGhleQ0KZ2V0IHNvbWUgbWluaW1hbCBlcXVpcG1lbnQuICBJIHRoaW5rIHRoZXkncmUg YWxzbw0KdXNpbmcgdGhlIEZVRCBhbmQgc29tZSB1bnJlYXNvbmFibHkgaW5mbGF0ZWQgY29zdHMN CmFzIHBhcnQgb2YgdGhlaXIgaW5mb3JtYXRpb24gd2FyIGFnYWluc3QgYW55dGhpbmcgdGhhdA0K aW5jcmVhc2VzIG91ciBjb3N0cy4gIEZvciBpbnN0YW5jZSwgdGhleSBrZWVwIHF1b3RpbmcNCiQ4 LDAwMCBmb3IgYSBjb3N0IHBlciBwbGFuZS4gIFRoYXQgbWF5IGJlIHRydWUgZm9yDQpzb21lIHN5 c3RlbXMsIGJ1dCBqdXN0IGFzIHRoZWlyIEFEUy1CIGlzbid0IDEwMCUgb25saW5lDQppbiB0aGUg VS5TLiByaWdodCBub3csIHRoZXJlIGFyZSBzeXN0ZW1zIHRoYXQgYXJlIHNwb29sZWQNCnVwIHJl YWR5IHRvIGJlIGRlcGxveWVkIGZvciBmYXIgbGVzcyBjb3N0IHRoYW4gdGhhdC4NClNvbWUgZm9y ICQyNDAwLTI2MDAsIGZvciBpbnN0YW5jZS4gIFRoZXkgYWxzbyB3YW50IHRvDQptYWtlIGl0IHNv dW5kIGxpa2UgeW91IHNob3VsZCB3YWl0Li4uLmJ1dCB3YWl0aW5nDQp1bm5lY2Vzc2FyaWx5IGlz IG9ubHkgZ29pbmcgdG8gbWVhbiB0aGF0IHRoZSBzeXN0ZW0NCmFzIGEgd2hvbGUgaGFzIGRlbGF5 ZWQgYmVuZWZpdC4gIEl0J3MgdHJ1ZSB0aGF0IHdhaXRpbmcNCndpbGwgcHJvYmFibHkgZ2l2ZSB5 b3UgbW9yZSBvcHRpb25zLCBidXQgaWYgeW91J3JlDQpmbHlpbmcgdG9kYXkgYW5kIGNvdWxkIGJl bmVmaXQsIGl0IHdvdWxkIHNlZW0gdGhhdA0Kd2FpdGluZyBpcyBvbmx5IGdvaW5nIHRvIGRlbGF5 IHNvbWUgYmVuZWZpdCBmb3IgWU9VLCB0b28uDQoNCklmIHRoZXJlIGlzIHNvbWV0aGluZyB0byBi aXRjaCBhYm91dCB3aXRoIHRoZSBkaXJlY3Rpb24NCnRob3VnaCwgaXQncyBhIGNvdXBsZSBvZiB0 aGluZ3MuLi4uDQoNCkZpcnN0LCB0aGV5IGRpZG4ndCBuZWVkIHRvIGN1dCBvZmYgVUFUIGFzIGxl Z2FsIG9wdGlvbg0KYWJvdmUgMTgsMDAwJy4gIFNvIG5vdywgb3VyIFJWLTEwIGZseWluZyB3aXRo IEFEUy1CDQphbmQgb25seSBVQVQsIHdvdWxkIGJlIGxpbWl0ZWQgdG8gMTgsMDAwJyBhZnRlciB0 aGUgZGVhZGxpbmUuDQpUbyBtZSwgdGhpcyBkb2Vzbid0IGFmZmVjdCBtZSBhdCBhbGwsIGJlY2F1 c2UgSSBmaW5kIG5vDQpiZW5lZml0IGluIG91ciBSVi0xMCB0byBnb2luZyB0aGF0IGhpZ2guICBC dXQgdG8gc29tZQ0KdHVyYm9jaGFyZ2VkIGZsaWVycyBpdCB3aWxsIGFmZmVjdCB0aGVtLiBUaGV5 J2xsDQpuZWVkIDEwOTBFUyB0byBnbyB0aGVyZS4NCg0KTmV4dCwgdGhleSBzaG91bGRuJ3QgaGF2 ZSB0byBoYXZlIGFueSB1bHRyYSBzcGVjaWFsDQpyZXF1aXJlbWVudCBmb3IgdGhlIEdQUyBzaWRl IG9mIHRoaW5ncy4gIFdlJ3JlIG5vdCB0YWxraW5nDQphYm91dCBzb21ldGhpbmcgdGhhdCBuZWVk cyBiZXR0ZXIgdGhhbiAxMDAnIGFjY3VyYWN5DQpoZXJlLiAgSWYgeW91J3JlIHNlcGFyYXRpbmcg dHJhZmZpYywgMTAwJyBhY2N1cmFjeSBzaG91bGQNCmJlIHBsZW50eSwgaW4gYm90aCBhbHRpdHVk ZSBhbmQgbGF0ZXJhbGx5LiAgVG8gbWUsIGl0DQpzZWVtcyB0aGF0IGNlcnRhaW4gbGFyZ2UgYXZp b25pY3MgbWFudWZhY3R1cmVycyBwcm9iYWJseQ0KbG9iYmllZCBhIGJpdCB0byBnZXQgdGhlIEZB QSB0byB3cml0ZSB0aGUgcnVsZSBzbyB0aGF0DQppdCB3b3VsZCBlbnN1cmUgdGhhdCB0aGV5IGNv dWxkIGtlZXAgc2VsbGluZyBUSEVJUiBzeXN0ZW1zLg0KSW4gdGhlIGVuZCwgSSB0aGluayB3ZSds bCBmaW5kIHRob3VnaCB0aGF0IGlmIHRoZXkNCmRvbid0IHByaWNlIHRoZWlyIHN5c3RlbSByaWdo dCwgaXQgd29uJ3Qgc2VsbC4uLmFuZA0KdGhleSdsbCBwcm9iYWJseSBoYXZlIG1vcmUgY29tcGV0 aXRpb24gaW4gdGhlIEFEUy1CDQphcmVuYSB0aGFuIHRoZXkgZGlkIGluIHRoZSBUcmFuc3BvbmRl ciBjYXRlZ29yeS4NCg0KT25lIG90aGVyIHRoaW5nLi4uSSBzZWUgcGVvcGxlIHRhbGsgYWJvdXQg aG93IHRoZSB0cmFmZmljDQphbmQgd2VhdGhlciB3b24ndCBiZSBGUkVFIGluIHRoZSBmdXR1cmUu Li5vciBtaWdodCBub3QgYmUuDQpXZWxsLCBnaXZlbiB0aGUgd2F5IHRoZSBjb21tdW5pY2F0aW9u cyBwcm90b2NvbHMgYXJlDQp3cml0dGVuIGFuZCBob3cgaXQgc3RhcnRlZCB0byBiZSBpbXBsZW1l bnRlZCwgSSBkb24ndA0KdGhpbmsgd2UnbGwgc2VlIGFueSB3YXkgZm9yIHRoZW0gdG8gTk9UIG1h a2UgdHJhZmZpYw0KYSBmcmVlIHNlcnZpY2UuICBQcm9iYWJseSBub3Qgd2VhdGhlciwgZWl0aGVy LiAgVGhlIHRoaW5nDQppcywgdGhleSdkIGhhdmUgdG8gaW1wbGVtZW50IHNvbWUgc29ydCBvZiBj b2RlIGJhc2VkDQp0ZWNobm9sb2d5IHRoYXQgcHJldmVudHMgdW5hdXRob3JpemVkIHVzZXJzIGZy b20gdXNpbmcgaXQuDQpUaGF0IGlzbid0IGluIHRoZXJlIHJpZ2h0IG5vdywgYW5kIGl0J3MgYWxy ZWFkeSBiZWluZw0KZGVwbG95ZWQuICBUaGV5IGNlcnRhaW5seSBhcmVuJ3QgbGlrZWx5IHRvIGJl IHRoaXMgZmFyDQppbnRvIHRoZSBnYW1lIGFuZCB0aGVuIGRvIGEgbWFzc2l2ZSByZXdyaXRlLiBB RFMtQiBpcw0KYWN0dWFsbHkgbWFueSB5ZWFycyBvbGQgYWxyZWFkeS4uLi5hbmQgbWFraW5nIGEg Y2hhbmdlDQpvZiB0aGF0IG1hZ25pdHVkZSB3b3VsZCBzZXQgZXZlcnlvbmUgYmFjayB0byB6ZXJv Lg0KU28gSSBleHBlY3QgdHJhZmZpYyB3aWxsIGJlIGZyZWUgZm9yZXZlci4uLmFuZCBsaWtlbHkN CmEgY2VydGFpbiBhbW91bnQgb2Ygd2VhdGhlciBpbmZvIHRvby4gIFRoZXkgZGFtbiB3ZWxsDQpi ZXR0ZXIga2VlcCBURlIgaW5mbyBmcmVlLCBiZWNhdXNlIHRoYXQgc2hvdWxkDQpiZSBmcmVlIGZv ciBpbi1jb2NrcGl0IGZvciBhbnlvbmUgaW4gdGhpcyBkYXkgYW5kIGFnZS4NCg0KU28gSSB3YXRj aCB0aGVzZSBzaWxseSBuZXdzIHBvc3RzIGFuZCBncnVtYmxpbmdzDQphbmQgZ2V0IGEgbGF1Z2gg b3V0IG9mIHRoZW0uICBMb3RzIG9mIHBlb3BsZSBibG93aW5nDQpob3QgYWlyIGFuZCBtYWtpbmcg bm9pc2UgYWJvdXQgc29tZXRoaW5nIHRoYXQgaXNuJ3QgdGhhdA0KYmlnIG9mIGFuIGlzc3VlLi4u Li5lc3BlY2lhbGx5IG5vdCBmb3Igc29tZW9uZSBidWlsZGluZw0KYW4gUlYtMTAsIGFzIG91ciBw bGFuZXMgd2VyZSBkZXNpZ25lZCB0byBmbHkgaW4gd2F5cw0KdGhhdCB1c2UgdGhlIEFpcnNwYWNl IHN5c3RlbS4uLi5ub3QgZ28gbG93IGFuZCBzbG93DQpvdmVyIHRoZSB0cmVlcyBvbiBhIGJlYXV0 aWZ1bCBzdW5ueSBhZnRlcm5vb24uDQpUaG9zZSBwZW9wbGUgd29uJ3QgbmVlZCB0byBlcXVpcCB3 aXRoIGVpdGhlciB0ZWNobm9sb2d5DQpub3csIG9yIGluIHRoZSBmdXR1cmUuLi4uYnV0IHdlIHdv dWxkIHN0aWxsIGJlbmVmaXQNCmlmIHRoZXkgZGlkLg0KDQpUaW0gT2xzb24gLSBSVi0xMCBOMTA0 Q0QNCmRvIG5vdCBhcmNoaXZlDQoNCg0KUGVycnksIFBoaWwgd3JvdGU6DQo+IEnigJltIG5vdCBz dXJlIGlmIGFueSBvZiB5b3Ugc2F3IHRoaXMsIGJ1dCBJIGZvdW5kIGl0IG9uIHRoZSBFQUHigJlz IHNpdGUgDQo+IHRoaXMgbW9ybmluZy4gIEl04oCZcyB3b3J0aCByZWFkaW5nLg0KPiANCj4gRnVs bCBBcnRpY2xl4oCm4oCmDQo+IA0KPiBodHRwOi8vd3d3LmVhYS5vcmcvbmV3cy8yMDEwLzIwMTAt MDYtMDNfYWRzLWIuYXNwDQo+IA0KPiAgDQo+IA0KPiAgDQo+IA0KPiAtLS1TbmlwLS0tU25pcC0t LQ0KPiANCj4gRUFBIGhhcyBsb25nIGZhdm9yZWQgYSBzYXRlbGxpdGUtYmFzZWQgdHJhY2tpbmcg c3lzdGVtLCBwcm92aWRlZCB0aGF0IGl0IA0KPiB3b3VsZCBiZW5lZml0IGFpcmNyYWZ0IG9wZXJh dG9ycyBhcyB3ZWxsIGFzIHRoZSBuYXRpb25hbCBhaXJzcGFjZSANCj4gc3lzdGVtLiBfVW5mb3J0 dW5hdGVseSwgRkFBIGhhcyBvbmx5IG1hbmRhdGVkIHdoYXTigJlzIGNhbGxlZCBBRFMtQiAob3V0 KSwgDQo+IHdoaWNoIHNlbmRzIHRyYWNraW5nIGluZm9ybWF0aW9uIHRvIHRoZSBhaXIgdHJhZmZp YyBzeXN0ZW0uXw0KPiANCj4gX0VBQSBoYXMgbG9uZyBoZWxkIHRoYXQgdGhlIGJlbmVmaXQgdG8g cGlsb3RzIHdvdWxkIGJlIGZyb20gc3lzdGVtcyB0aGF0IA0KPiBhbGxvdyB1cyB0byByZWNlaXZl IHRyYWZmaWMsIHdlYXRoZXIsIGFuZCBzYWZldHkgaW5mb3JtYXRpb24gaW4gdGhlIA0KPiBjb2Nr cGl0IChBRFMtQiBpbikuXyBXaXRob3V0IHRoYXQgZWxlbWVudCwgdGhlIG5ldyBtYW5kYXRlIGRp cmVjdGx5IA0KPiBzZXJ2ZXMgb25seSBGQUEgYWlyIHRyYWZmaWMgY29udHJvbC4NCj4gDQo+ICov X+KAnFdoYXQgdGhpcyBuZXcgcnVsZSBkb2VzIGlzIHNoaWZ0IHRoZSBjb3N0IG9mIGFpcmNyYWZ0 IHRyYWNraW5nIGZyb20gDQo+IHRoZSBnb3Zlcm5tZW504oCZcyBtYW1tb3RoIGdyb3VuZC1iYXNl ZCByYWRhciBzeXN0ZW1zIHRvIHRoZSBjb2NrcGl0IGFuZCANCj4gdGhlIGluZGl2aWR1YWwgcGls b3Qs4oCdXy8qIHNhaWQgRG91ZyBNYWNuYWlyLCBFQUHigJlzIHZpY2UgcHJlc2lkZW50IG9mIA0K PiBnb3Zlcm5tZW50IHJlbGF0aW9ucy4g4oCcSXQgbWFrZXMgc2Vuc2UgdG8gbWlncmF0ZSB0byBu ZXcgc2F0ZWxsaXRlLWJhc2VkIA0KPiB0ZWNobm9sb2d5IGJhc2VkIG9uIEFEUy1CLCB3aGljaCB3 b3VsZCByZXBsYWNlIGV4aXN0aW5nIHRyYW5zcG9uZGVycyBhbmQgDQo+IGVuY29kZXJzLiBCdXQg aWYgdGhlIGFpcmNyYWZ0IG93bmVyIGhhcyB0byBwYXkgZm9yIGl0LCBwaWxvdHMgc2hvdWxkIA0K PiBhbHNvIHJlY2VpdmUgc3Vic3RhbnRpYWwgc2FmZXR5IGFuZCBvcGVyYXRpb25hbCBiZW5lZml0 cy7igJ0NCj4gDQo+IC0tLVNuaXAtLS1TbmlwLS0tDQo+IA0KPiAgDQo+IA0KPiAgDQo+IA0KPiAq DQo+IA0KPiANCj4gKg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3Qg RW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdh dG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBV bi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJv d3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09 DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QN Cl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0K Xy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMh DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhh bmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg= ________________________________________________________________________________
Subject: RV-10 losses against the finite pool of insured's
Date: Jun 07, 2010
A few of us were Hangar talking on a soggy dark day a little while ago about what is now the 4 total loss of a finished RV-10s against the fleet of over 300 successful ones. Now owners are beginning to pay increasing premiums to cover those losses. It is some Real Money charges passed back onto the remaining pool with a dwindling number of companies wanting to insure us. After the resent loss of an Alternate Engine RV-10 in Georgia, it was mentioned that 50% of those losses were these (an alarming percentage of the Alternate RV-10 Fleet) and a question raised at what might be a short list of some of the various conditions to look for. There is seldom a simple answer and always lots of discussion which can be a good thing or frustrating. I don't think it's the Alternate Engine choice. As an EAA Tech Advisor, occasionally I am asked about Vans coiled aluminum lines, B nuts, ferrules and the like. Also I am asked as to the merits and costs of Bonaco pre-fabricated products. Attached herewith is an excellent post on hydraulic lines, It just as easily could have been "Fuel" lines on one of our RV-10s. (Note: The PDF attachment is 290K for our bandwidth restricted brethren). Too often, the builders of Experimental Built/Amateur maintained aircraft are yet to get up to speed on the latest fabrication techniques, effective flushing of an installed system and proper torqueing of B nuts. Much is the result of poor preparation and brutal torqueing forces by operators. Kinks, chafes, constrictions , FOD and distorted mating surfaces came to light. Quality Control and a second set of eyes can certain not hurt. I doubt we will ever hear that such a boring subject actually contributed to the loss of the most recent RV-10. Hopefully a few builders out there may find value in a road traveled by an earlier builder with fabricated lines. The pictures drive home what we are looking for in a successful Tech inspection. Some value may be applied to future RV-10 operations. Just fanning the fumes of controversy before packing up for the pilgrimage to OSH. Our prayers remain which those who travel before us and contribute to the pool of our aviation experiences. <> John Cox ________________________________________________________________________________
Subject: Brother's keepers
Date: Jun 07, 2010
In light of John's post about some losses and insurance rates, I have decided to express some thoughts that I have been having for a while. I just got involved in this community right about the time of the tragic accident of a builder who crashed and died in his RV-10. What seemed odd to me as a new member of the fraternity was all of the retrospective thoughts by those who knew the guy well about red flags that they had seen during his building and flying process. Apparently the guy was popular and well liked and people didn't step forward when they saw things that concerned them. I thought about that again when I recently read about a guy who launched his first flight (successfully) without a functioning generator. I can see how any of us, myself included, can get all wrapped up in the first flight hoopla, that we take a chance on something that we wouldn't have otherwise done. None of us are wiser than any other. The lowliest student pilot can catch something that the most experienced ATP can miss. It doesn't do any good however, if nobody speaks up out of fear of offending someone. Every crash is not only tragic, but it costs each and every one of us dearly out of our own pocketbooks either directly or indirectly. Immediately or down the road we are each eventually going to pay for every accident. As a community, we need to hunker down and police ourselves. We need to comment forcefully on red flags, unwise practices, and the like, and foster more vigilance and commitment to building and flying in the safest manner possible. Friends don't let friends push the envelope. I need and request everyone's help to keep from doing something stupid. The safety of the RV-10 community is in our hands until things deteriorate to the point that unwanted hands step in with onerous regulation and/or prohibitive cost. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300389#300389 ________________________________________________________________________________
Date: Jun 07, 2010
Subject: Re: Brother's keepers
Negative Ghost Rider.....Lots of us stepped in, i.e. Horse, water, shown water, refused to drink. Lots of people attempted to guide Dan, even to the point of not telling him any more info that may allegedly use to allow him to skirt the processes. ---- woxofswa wrote: > > In light of John's post about some losses and insurance rates, I have decided to express some thoughts that I have been having for a while. > > I just got involved in this community right about the time of the tragic accident of a builder who crashed and died in his RV-10. What seemed odd to me as a new member of the fraternity was all of the retrospective thoughts by those who knew the guy well about red flags that they had seen during his building and flying process. Apparently the guy was popular and well liked and people didn't step forward when they saw things that concerned them. > > I thought about that again when I recently read about a guy who launched his first flight (successfully) without a functioning generator. I can see how any of us, myself included, can get all wrapped up in the first flight hoopla, that we take a chance on something that we wouldn't have otherwise done. > > None of us are wiser than any other. The lowliest student pilot can catch something that the most experienced ATP can miss. It doesn't do any good however, if nobody speaks up out of fear of offending someone. > > Every crash is not only tragic, but it costs each and every one of us dearly out of our own pocketbooks either directly or indirectly. Immediately or down the road we are each eventually going to pay for every accident. > > As a community, we need to hunker down and police ourselves. We need to comment forcefully on red flags, unwise practices, and the like, and foster more vigilance and commitment to building and flying in the safest manner possible. > > Friends don't let friends push the envelope. I need and request everyone's help to keep from doing something stupid. The safety of the RV-10 community is in our hands until things deteriorate to the point that unwanted hands step in with onerous regulation and/or prohibitive cost. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in progress > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300389#300389 > > > > > > > > > > ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Jun 07, 2010
I'll confirm Rick's statement. Bob ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Mon Jun 07 14:02:30 2010 Subject: Re: RV10-List: Brother's keepers Negative Ghost Rider.....Lots of us stepped in, i.e. Horse, water, shown water, refused to drink. Lots of people attempted to guide Dan, even to the point of not telling him any more info that may allegedly use to allow him to skirt the processes. ---- woxofswa wrote: > > In light of John's post about some losses and insurance rates, I have decided to express some thoughts that I have been having for a while. > > I just got involved in this community right about the time of the tragic accident of a builder who crashed and died in his RV-10. What seemed odd to me as a new member of the fraternity was all of the retrospective thoughts by those who knew the guy well about red flags that they had seen during his building and flying process. Apparently the guy was popular and well liked and people didn't step forward when they saw things that concerned them. > > I thought about that again when I recently read about a guy who launched his first flight (successfully) without a functioning generator. I can see how any of us, myself included, can get all wrapped up in the first flight hoopla, that we take a chance on something that we wouldn't have otherwise done. > > None of us are wiser than any other. The lowliest student pilot can catch something that the most experienced ATP can miss. It doesn't do any good however, if nobody speaks up out of fear of offending someone. > > Every crash is not only tragic, but it costs each and every one of us dearly out of our own pocketbooks either directly or indirectly. Immediately or down the road we are each eventually going to pay for every accident. > > As a community, we need to hunker down and police ourselves. We need to comment forcefully on red flags, unwise practices, and the like, and foster more vigilance and commitment to building and flying in the safest manner possible. > > Friends don't let friends push the envelope. I need and request everyone's help to keep from doing something stupid. The safety of the RV-10 community is in our hands until things deteriorate to the point that unwanted hands step in with onerous regulation and/or prohibitive cost. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in progress > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300389#300389 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 07, 2010
John=2C Nice article. i've made a hard copy to keep in the basement to refer for to rque values. I'm replacing the few aluminum lines I've already installed wi th SS as I believe they are much better. I'm really "anal" about torquing a nd then marking every nut and bolt installed. However=2C one brake line tha t I had previously installed didn't even have a flare on it. How the heck d id that happen??? Must have been those dang elves that work on my plane a t night forgot to put a flare on. I'm gonna have words with them! Thanks ag ain. Dan Subject: RV10-List: RV-10 losses against the finite pool of insured's Date: Mon=2C 7 Jun 2010 11:38:04 -0700 From: johnwcox(at)pacificnw.com RV-10 losses against the finite pool of insured's A few of us were Hangar talking on a soggy dark day a little while ago abou t what is now the 4 total loss of a finished RV-10s against the fleet of ov er 300 successful ones. Now owners are beginning to pay increasing premium s to cover those losses. It is some Real Money charges passed back onto th e remaining pool with a dwindling number of companies wanting to insure us. After the resent loss of an Alternate Engine RV-10 in Georgia=2C it was m entioned that 50% of those losses were these (an alarming percentage of the Alternate RV-10 Fleet) and a question raised at what might be a short list of some of the various conditions to look for. There is seldom a simple a nswer and always lots of discussion which can be a good thing or frustratin g. I don't think it=92s the Alternate Engine choice. As an EAA Tech Advisor=2C occasionally I am asked about Vans coiled alumin um lines=2C B nuts=2C ferrules and the like. Also I am asked as to the me rits and costs of Bonaco pre-fabricated products. Attached herewith is an excellent post on hydraulic lines=2C It just as easily could have been "Fue l" lines on one of our RV-10s. (Note: The PDF attachment is 290K for our b andwidth restricted brethren). Too often=2C the builders of Experimental Bu ilt/Amateur maintained aircraft are yet to get up to speed on the latest fa brication techniques=2C effective flushing of an installed system and prope r torqueing of B nuts. Much is the result of poor preparation and brutal t orqueing forces by operators. Kinks=2C chafes=2C constrictions =2C FOD and distorted mating surfaces came to light. Quality Control and a second set of eyes can certain not hurt. I doubt we will ever hear that such a boring subject actually contributed t o the loss of the most recent RV-10. Hopefully a few builders out there ma y find value in a road traveled by an earlier builder with fabricated lines . The pictures drive home what we are looking for in a successful Tech ins pection. Some value may be applied to future RV-10 operations. Just fanning the fumes of controversy before packing up for the pilgrimage to OSH. Our prayers remain which those who travel before us and contribute to the pool of our aviation experiences. <> John Cox _________________________________________________________________ The New Busy is not the too busy. Combine all your e-mail accounts with Hot mail. http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=P ID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4 ________________________________________________________________________________
Date: Jun 07, 2010
>>Negative Ghost Rider -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300407#300407 ________________________________________________________________________________
Subject: Finish Kit Surpise
Date: Jun 08, 2010
My finish kit arrived yesterday. I was surprised by the gray primer on the cowl. I guess that's something new Van's is doing these days. bob Description: http://www.kitlog.com/photos/project_260/full/FP07062010A0002L.jpg ________________________________________________________________________________
Date: Jun 08, 2010
Looks like a nice get coat. Shucks we can't make comments about your pink plane. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Tuesday, June 08, 2010 4:55 AM Subject: RV10-List: Finish Kit Surpise My finish kit arrived yesterday. I was surprised by the gray primer on the cowl. I guess that's something new Van's is doing these days. bob Description: http://www.kitlog.com/photos/project_260/full/FP07062010A0002L.jpg ________________________________________________________________________________
Subject: ADS-B out
Date: Jun 08, 2010
Hopefully someone will save us with a uncertified (i.e. less expensive) ADS-B unit. Don't forget those AOPA cost estimates are probably for factory certified aircraft, so they have to count at least $1000 for installation, maybe more, depending on antenna locations, etc. Plus STC costs need to be absorbed somewhere. TDT Tim Dawson-Townsend Aurora Flight Sciences tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Jun 08, 2010
Not sure if this is the same, but the more modern composite plane manufacturers are spraying a coat of primer into the mold before the layup/cloth or pre-preg is laid in. This is not a gel-coat (gel coat is polyester based and won't stick to a pure epoxy matrix), but is instead a primer layer. Having it be the first layer in the mold layup does many things: 1) pre-primes the part for the builder J, 2) pre-fills the pinholes in a way that won't allow them to reappear later J J, 3) provides a sure bond between the primer and epoxy matrix since the epoxy cures to it. If this is what Van's is doing now - great! John Melchert From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Tuesday, June 08, 2010 7:42 AM Subject: RE: RV10-List: Finish Kit Surpise Looks like a nice get coat. Shucks we can't make comments about your pink plane. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Tuesday, June 08, 2010 4:55 AM Subject: RV10-List: Finish Kit Surpise My finish kit arrived yesterday. I was surprised by the gray primer on the cowl. I guess that's something new Van's is doing these days. bob Description: http://www.kitlog.com/photos/project_260/full/FP07062010A0002L.jpg ________________________________________________________________________________
Date: Jun 08, 2010
In retrospect I should have found a way to press my message forward without reference to the past. I didn't mean any disrespect or to resurrect painful memories. For that I apologize. I now more fully understand the herculean efforts that the community has made in the past to help members. The community of builders is one of the greatest assets and motivators to this avocation. Let's keep it up. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300542#300542 ________________________________________________________________________________
Subject: wtb IO540 starter ring gear & support
Date: Jun 08, 2010
Looking to buy a starter ring gear assembly for my IO540C4B5, maybe someone who has installed A/C on an rv10 that still has the original single belt assembly. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300546#300546 ________________________________________________________________________________
Subject: When to run wires/static port etc
Date: Jun 08, 2010
About to attach the tail cone to the fuselage. What wiring and other work should I do before I attach, any? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300555#300555 ________________________________________________________________________________
Subject: Re: Finish Kit Surpise
Date: Jun 08, 2010
I wonder if Vans has changed vendors for the cowl. I am generally pleased with the kit, but I thought the QC on the cowl was lacking. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300556#300556 ________________________________________________________________________________
Date: Jun 08, 2010
Subject: Re: wtb IO540 starter ring gear & support
Dave, I know a guy who has one. He said $350. Tom tom.on.the.road(at)juno.com 970-420-1798 > > Looking to buy a starter ring gear assembly for my IO540C4B5, maybe > someone who has installed A/C on an rv10 that still has the original > single belt assembly. > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300546#300546 > > > > > > > > > > > ____________________________________________________________ Health Plans From $50/mo. Compare Low-Cost Health Plans Online. Blue Cross, Aetna and more. http://thirdpartyoffers.juno.com/TGL3141/4c0e8c9fcde012758east06vuc ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jun 08, 2010
I have a dual belt ring I'd like to sell if anyone needs it! -Mike Kraus Sent from my iPhone On Jun 8, 2010, at 1:17 PM, "rvdave" wrote: > > Looking to buy a starter ring gear assembly for my IO540C4B5, maybe > someone who has installed A/C on an rv10 that still has the original > single belt assembly. > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300546#300546 > > ________________________________________________________________________________
Subject: Misc topics... First flight, Insurance, Rudder lock
Date: Jun 08, 2010
Group... First things first. We made the first flight of N277CK, kit # 40761 over the Memorial Day weekend. Flys great. (There are some pictures at dougandlinda.smugmug.com in the rv10-all folder. Look to the end if interested.) Burning fuel most every night. Following the general path of AC90-89B test flights. For a reference point for John's earlier post, my insurance quote went up around $1,000 for $175k hull from Dec to June. I'm about a 1000 hour instrument rated SEL with around 500 hours in a RV7A. Most important question... Any recommendations for a good rudder lock for the -10. I used the spring loaded rod that fits on the rudder pedals for the -7A. Unfortunately, I also now have a 3 inch hole covered with duct tape in the rudder surface of the 7A where this lock failed to hold and the rudder stops broke after the rudder flopped around in the wind. Thanks, Doug -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300570#300570 ________________________________________________________________________________
Date: Jun 08, 2010
Item #2 is not necessarily true=2C you just might not be able to see the pi nholes and larger void=2C but that doesn't mean they aren't there. The Nomex=2C honey comb sandwich material in the cowl certainly can allow f or huge voids where the edge of the honeycomb is keeping the first layer of glass against the mold=2C but the area in the middle of the cell structure allows the glass to come off the mold=2C thus the alligator scale like ski n. From: pilotmelch(at)omnav.com Subject: RE: RV10-List: Finish Kit Surpise Date: Tue=2C 8 Jun 2010 10:48:50 -0500 Not sure if this is the same=2C but the more modern composite plane manufac turers are spraying a coat of primer into the mold before the layup/cloth o r pre-preg is laid in. This is not a gel-coat (gel coat is polyester based and won=92t stick to a pure epoxy matrix)=2C but is instead a primer layer . Having it be the first layer in the mold layup does many things: 1) pre -primes the part for the builder J=2C 2) pre-fills the pinholes in a way th at won=92t allow them to reappear later J J=2C 3) provides a sure bond betw een the primer and epoxy matrix since the epoxy cures to it. If this is what Van=92s is doing now ' great! John Melchert From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of gary Sent: Tuesday=2C June 08=2C 2010 7:42 AM Subject: RE: RV10-List: Finish Kit Surpise Looks like a nice get coat. Shucks we can=92t make comments about your pin k plane. Gary Specketer From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Bob Leffler Sent: Tuesday=2C June 08=2C 2010 4:55 AM Subject: RV10-List: Finish Kit Surpise My finish kit arrived yesterday. I was surprised by the gray primer on t he cowl. I guess that=92s something new Van=92s is doing these days. bob /9j/4AAQSkZJRgABAQAAAQABAAD//gA8Q1JFQVRPUjogZ2QtanBlZyB2MS4wICh1c2luZyBJSkcg SlBFRyB2NjIpLCBxdWFsaXR5ID0gMTAwCv/bAEMAAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAf/bAEMBAQEBAQEBAQEBAQEBAQEB AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAf/AABEIAg0B iQMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQD BQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygp KjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJma oqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/ xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQID EQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RF RkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqy s7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/ APwPhh/z/n9Tj2ArYg7/AI/0rHhm/wA/5/UZ9wa0IZv8/wCf1GfcGvy89g6CH/pv+OP1zj/PX2rl /G2sf2Do1xcef9m9B9s/s38e31/HjtXk/jD4tar4P+0Qf2Vpv2jjH/E4AHv7j8s5rw7xt8YJ/Elh b3s9j/x6/wDH5pN3ef8AEsvv1/CvRwuX4vFNN7Kz1vd28m/Pf13RjiMTf59Onl20vp6v7+p0f9qL VbO6t7HVfDn9p25/59Lz/PtXQa98TtV8YXWj6rpQtba40rWP9D+yXmf+JX/1HP8APOMV4f8ADfwp pXxC17z/AD/7E1C6vP8AQ7Tr/wBR3169PT0rqPEng/VvDd/ceR/ZupG1vP8Aj78PXh03VLHnr/Yf NejiMNhFitr2Wna9unbWy8r+enmYl4vpa3k+mvz6q/r2MeG88R6DNbarY31zbaxa3mqXv2u04/4m g6egPv2xX2R8Pf2hNDvNLt7HxVP9m8QWv/H4Psf/ABLL/wDn7Y9+tfM9neWGvaDczwfZv7Q0v/j8 yP8Aj/8A/wBX+TXj95eT2es3H2cfZh9j1T/t/wA+3+faud4ZZq7Yzptf0Vr6ad3f7zz8NibPz7db r7ten9a/sBoPjHQ9eu9QsdKvvtNxpf8Ax+Z9/T+f09M1Xm+IXhyC08+DVtNuen2y7+2Z+wD3/wA/ 4V+a+j/E7XPDY1C+gvrkXGqWml2Vnd5/6AX9Pp/jWPDqVx8SNZ1CD+1bbTdQurz/AI9P+YZf9/T0 x9Pwrzf7DS1ey1enT7j0FmWMSSs9PM/RjxJ+0J4A8K6ZqE8+q21zrNpZ/bbO0/5//wBPwHT3rw/w rN+0Z8Vbq41XStV/4RPw/dWf+h3d3ZfX/PXjuTxXzveWeq6B4tt9c8VeHP8AhJLi1s/9N0r/AJBv P+e9fTHw3/aunvLq20P/AIVzc22n2vbSbz/jw498Y6/rxQsP/siWDabTSadtbb6dew8Nifrd/ri1 6fLb8F/TR0H/AAp/9oXwqP7VsfHNz4k73v8Apv8Anp9R719c/CvWNc1LQfI8R/av7Ytbz7Fe4s/8 n+vrXg3ir9rr4c+G7XT/AOyvtPiTULqz+2/ZNJzmw/7Dn8s+1c/oP7V095f/APE1sfDfhu3uv+XO 7vNZGpjv9P6/05sRhsVitP7M23fpy3en4bW+63SlhE1vfzvvp8uq+8+8IO/4/wBK0IO/4/0rh/BP jDSvGFhb3Fjfabc9P+PS8/8ArD8s16BB3/H+lcFraWt5djf0LEPn8fh+X/6/vVsQd/x/pVeDv+P9 K0IYf8/5/U49gK1+rW6r8f8AM5yxB3/H+lbEHf8AH+lZ8MP+f8/qcewFbEMP+f8AP6nHsBXWlsl6 I6DQhh/z/n9Tj2ArQhh/z/n9Tj2AqvB3/H+laEHf8f6V0fVuy/D/AO1Oc0IO/wCP9K0IO/4/0rPg 7/j/AErYg7/j/Sug5zQg7/j/AErQg7/j/Ss/z/b9P/r1Yhm/z/n9Rn3BroA0KPP9v0/+vWf5/t+n /wBejzv+m/8An/vigCxNN/k/5/IZ9STVeab/ACf8/kM+pJqv5/t+n/16r+f7fp/9egAmm/yf8/kM +pJrPmm/yf8AP5DPqSaJpv8AJ/z+Qz6kms/z/b9P/r1zgWJpv8n/AD+Qz6kmseab/J/z+Qz6kmrE 03+T/n8hn1JNY803+T/n8hn1JNB0Feab/J/z+Qz6kmufvJu/0/8ArAj+Rz/WtCab/J/z+Qz6kmuf vJh5Xb+f14/yR9SK5wMe8m7/AE/+sCP5HP8AWuP1ObyfxH689f8AP6ZroLybv9P/AKwI/kc/1rj9 Tm8n8R+vPX/P6ZrzMVsvT9Uegcved/8AgNc/ed/+A11E03+T/n8hn1JNc/ND/k/5/I49QRWR6Bz8 /b8P61jzQ/5P+fyOPUEV0E/b8P61X+x+3/j1dB0HLzWZh/1/+f5Dv1FY953/AOA12F5D2+n/ANYk /wAhj+tef+JNeHhuK3vp7D7Tb/bP59//AK3v0xW+H2+X/wAiBoaRoM95f8f8e9qP6f5/xPSvYNN0 fv8A57HnP59fT61x/hXxVoepQ288F/b3X2rHbP8Aj7fp617Bps1hNFxP+PTp/n3/AFpnJ9Yfn93/ ANr5r7yxZ6b1/LP+fz4/E9a7Czs/J/oOOeP5fpjPNV7Oz/z+eefz/Q4rqIbP/P8APn+R/D2rnulu y7ruv6/4dfeWNNh9Px/+ufz6fUeldR9j9v8Ax6q9nCfN7/y+nP8AkH6A11FeX9Z8/wCv/ATzz8R9 Hm/tKK3/ANBubb/ny9+c9P8APuOlV/iFqWq+CdLuJ4LG5udQurP/AEO0/L+gH9MivtDQdH0Pw3c2 9vqtibb7LkZ/zzj+VfO/7eHhXXPEfgPR/FXg6f7ONLvPsesfZAR/xK/b3+lfpCybVaW8+34HjrMf +YRdNE1H06/r6HyPo/hb4c3l15/j/wAR/wBpeKLr/j8+13g03TPz59/88V6BqXw9+B/2Az30Gm21 v/z9/wBsH8sdM+mf/wBXwNeTeKoZbj+1b7Urng4N37Z9f849awIJ5/KuP39z9nuv+nzp65Pt6/p0 rqWWxVv+FS3kr+WnxenTsdPt29LN9LfpufSHjDwp8MtHsNQ8R+B/iN/ZuoWvNnaXd516f04yOPoM 14/r3ja+1KXw/PffaTcf8eWs3Vpef8f+CP8AidfgOvb615/eWc+sf8eNj/o9t/5P/wCT/iMHFc/e Qz2X7if7T/nj39eOPxx16MNhle2ja0e1+n56PovwtzO/X8T2iz1+30e/t9V0rXLnU9Puv+XTVrP3 64Pp+ZNWP7Ysf7Q+3X89z9nuuc2nP2Dp7nGf/wBVfP8ADqV9DFbwCf7Tb/bPtv2S79/8Pw79sV0F nqXnfZ554MZHtjjPX/P50vqq7r8f8zm+rry/D/5E9Y8SQ3w+0QQT/abe1/4/LQ9evP6/168Vz8Op T6Pf6fPYwf6Ra8n/AD16fTrR4b1e+m1m4/6ih/5e/TGf8/y5FGsQ+TLcT8f6L/x5/X/Iz7fjiqaT TXRq3yGfU+g/GD/hMPDlxpPiOx/tL7JZ5vLS75+346f8TzH5/nXU/Df4e65421n9xBbab4f0s/bb v7Xef2bql/pfHHP+eB+Pz/8ADDxJqvgO/wBQvr/7N/Z+veG9U0W8tLuy/tL7fpeu/wBga9x1/L3r 6A0ebxjeWHkeAPDltdW91eape/ZLzxJ/ZvXWsfX/AJFz/Pr4jy7C4XXCN3a130fdfPov+GWGw1mu n6v8vx9Oy+0PB0PwI8ExeR9h0T+0eLK8+yWZ1L7f/wDq+nFe03nhX4SfEiwuNKn0nRNSt/sfP2Sz /wCJnycjH9K/Ma8+Evx+1iK3nvtDNt/z5/ZLP1/yPTvXceCYf2ovhl9o8R6Vff8ACSaPpdn9t1jw nq1mPX/oB/pkf/Wrzv7Ple/9q9b2uvu1kvTb5HoJYvRaP7nppv17fh5H1h4P8H33wf8AGWjeFfP+ 0+H9UvP+KP1a8/8ATLrv/Qv+IuvGa+z7P/VH6D+Yr5o+D/xm0L4zWFvY654c/sTxBa/8Tr7Jd3n9 paZf9v7a0PXOfT0+ma+mIO/4/wBK8rEL/aVby1Xotfvf4jNCDv8Aj/StiDv+P9Kz4O/4/wBKvw/6 4fU/zqgNmDv+P9K2IYf8/wCf1OPYCseDv+P9K2IO/wCP9K6ANCDv+P8AStCDv+P9Kz4O/wCP9KsQ d/x/pXQBsQd/x/pWhWPB3/H+laHn+36f/XroOcsQd/x/pVjz/b9P/r1n0Qd/x/pQBoef7fp/9eia b/J/z+Qz6kms/wA/2/T/AOvRNN/k/wCfyGfUk0AHn+36f/Xqv5/t+n/16KrzTf5P+fyGfUk1zgE0 3+T/AJ/IZ9STVeab97+P8v6/oelE03+T/n8hn1JNZ803+T/n8hn1JNc50BNN/k/5/IZ9STWPNN/k /wCfyGfUk1Ymm/yf8/kM+pJrHmm/yf8AP5DPqSaAK803+T/n8hn1JNc/eTd/p/8AWBH8jn+tWLyb v9P/AKwI/kc/1rn5pv8AJ/z+Qz6kmubEbfL/AOSOlbr1X5mfeTd/p/8AWBH8jn+tcveTed+H+I/n WxeTd/p/9YEfyOf61z803+T/AJ/IZ9STXAetHZei/Ix5+34f1rHmh/yf8/kceoIrYn7fh/Ws+ft+ H9aDpK/ke/6//WqvP2/D+tE15P7duP1Hfof0x+FY815/n+XH8x+PvXQt11Ar3nf/AIDXn/jbXtK8 K6DqOua5/wAg+1/4/B1+3nJ/r/jk9+ovLz/P5Y4/LP4jNfI/7VGv+T4I0/Sv+XjVNY//AF8/55rv wuGWKxe9krfNWXz7P7tG0NatLu0eTf8ACeQal4X8UeKvI+zaha6x9t8N2lpeD/QNL138Px//AFV1 Og/GDx/4b+EuoarB4j1L+0BrGl/Yru7/AOJl27/l9fevB9ehGm/D7T4P+XjVNY9On9hf5+n6Y9H1 jQb+b4aeD7Gxg+0/2p4kz/1//T/DpmvU+q4Nbt3Xpv6X/A9ZYVNJ8q2XT0/u+S+5H2z8N/i18RtS 8LaPPez6bc6hql59i+13dn/Xn8f84+4Jptcs4rf9xpv2jv8A6Z+nbt+H06V8T/B7w3ff2z4P8OX1 j9muNMu/9M+n+Qf/AK3f74vIT5vf+f15/wAgfQivicy0xbs+/wB3KrfkeLiMNhHjLPXp67Xvo1/X TRGP/wAJtqmm/wBn+fpX+kXV4bKyH2z8P89MY6enoH2zXP8Any/8nR/jXm80X9peLfC9jgf8/vp/ n3r7J/4Q+4/59z+X/wBavmMTj8XRqKOlrdLPqv0/q1zn9lhKL5dXe3fy62ffXyu+x+Q3jzUp9ei1 jyJ/9ItbP7b6fhz/AErw+z8YX32WfStVnNzp91/oV5aXfTv9P6Gugh1jzvG9xY/8u93Z/wBi+5Ou /wCfz968n1KH7HLcQf8ALxad+eP88D/PP9JHzOFSvF2V9Nev2Tf1LwH4A8SRGC+0O203P/QJ9h7e uP8AH1rwDxt+yvPNFb/8Ibrmm/Z7Wz+xfZNW/wCJbj8f89O2a+iLO886wt+/HPTP+R/9avoj4G6b 4c1iXT7HXIBc3GqXn+iXfrn+n9M554rm+rry/D/5E6vq+LxWuDV0t7abWb0/rVo+J/h78KtV+D/g PUL3xx4ctsG8+22R+x/2l/n/AD0FfFHjaGDxt4j1jVbHQ7bTbe1/5dLT/wCv07V/TvrHwf0rWPDe s+G9V+zf2Pqn+hHofUdOvf8AyK/E/wCKnwNvvhv4t/4VzBYnnWPsVnd/9B4HP9u611/6Fzn/ADgc 31Z4TFfW9bdrv17/ADW3e/fm+sfWny9Vo+91bt8tLPZeh+c95o8Fn+/ng6jB/wA4/r6VX/10vkTw f8ev4duvofp+Fewa/oMGseKNZ/4+bbR7XWB9su/+gfpf9tf2B/bX+etcP4q0Gfwfr1xoV9PbZ/6C 1nz9vx7dvw79K6ViE2lpr6f/ACQHL6bLPZ39v58H2r7Lef8AHp9s/L9OnH0r6X8E+DvFXxIl1Cfw 54V+06da2ebzP+eM4zXzhDCby/4JNv3/APre/wCP6mv2B/Z18beFYfBun2PhXwd4t/s+1/0G81b+ x/7S+36p6e/H9a83MsT9Vu/R/Kytrp5af8BhhsN/X/D/ADWj767I+Pof2dfHEXijUPDn+k/2xa+G /wDhJ7Mf8wz+y+/+T9DR4V1H4xeCbD7doc9tc6P9s+xfZNWsxqP/ABNP7G/t70OfcV+xFnZwTXX2 7yf9I+x/Yhd9sf8A6uOf60f8IT4Vm/5gdt/x+fbfw/sX+we+OOfb9K8RZzdpW302ls7LsdP1d+f4 /wDyJ+f3hX9qn403n2ef7D4K1K3/AOvT+f8A0L/P0FfoB8MfFWueKrC3n8VeB/8AhGtY+yf8fdpe /wBpaZf8/wDMD1zJHHr9DX5seNvh74q+FfxG1CfSoLkaPc3mqXuj9/8AiV/ma+4PgPqUGvWtvfaH P/Ylv9i/4qTwp/zDO3/E60PPH6e9YZjQwsrPCXbum1fzV+n4aHPhr6Xv03/7dOg8H/B8eD/GWof2 VB/xT41j+2vDZ/6AP9u/8h3Rf+xd/T19/qCGH/P+f1OPYCq8MP8An/P6nHsBWxB3/H+lca2V97b/ AJm5Yg7/AI/0rQhh/wA/5/U49gKrwd/x/pWhB3/H+lMDQhh/z/n9Tj2ArYg7/j/SseDv+P8AStCD v+P9K6fq78/x/wDkQNiDv+P9KsQd/wAf6Vn1Y8/2/T/69IDQg7/j/SrFZ9WPP9v0/wDr10AWPP8A b9P/AK9Hn+36f/Xqv53H/Tv+nT6f5NHn+36f/XoAsf8ALL/P92q9Hn+36f8A16r+f7fp/wDXrnAs ef7fp/8AXqvVfz/b9P8A69V/P9v0/wDr0AWJpv8AJ/z+Qz6kms+ab/J/z+Qz6kmiab/J/wA/kM+p JrPmm/yf8/kM+pJrnOgrzTf5P+fyGfUk1z803+T/AJ/IZ9STViab/J/z+Qz6kmseab/J/wA/kM+p JoArzTf5P+fyGfUk1z95N3+n/wBYEfyOf61oXnf/AIDXP3k3f6f/AFgR/I5/rXPZ9v6/pr7zouu6 /r/h195n3k3f6f8A1gR/I5/rWPNN/k/5/IZ9STVift+H9az5+34f1rzz0DPn7fh/Ws+ft+H9a0J+ 34f1rHvO/wDwGow19b326+p0Feft+H9a5+ft+H9a2Jpv8n/P5DPqSax5+34f1rrA5+87/wDAa+F/ 2opp7zxH4X0rJ+z2ub3/APV6Y/H0r7ovO/8AwGvj/wCI83iPxJ4jt9c0ODTdS8P+F7z/AI+/sfX2 /X/PWvay1/7U3f8ArmX6fgC0afY8O8YaPfan/wAK/wBD0qD7T9m4vPsn/QU/z/kdvpmHwr/aWl+H 9KuPtNtceFzxacf8hT6//Xrj/wCx/Ef9vW+uT31zbaxpfH+iAf6B/nkfT8q7jw3DqsMtx+/z/wBf fOp/2mO/9PcdqWJxP9dv1/Dtfz7/AKwvL8P/AJI+r/2Y9Hnm8W3E8+f+JXZ6p9su/wDPv719g6l5 EMtxPPP/AKP0/X/CvB/2XdNvodL8Uarff8fF1efYvUe2f/r17R4w03+2NG1iD/n1s/8APJz9O2OO nNfFZhZ4teb/AAcYnAWPhXCPEnxGtvEc89tbeF9L/wBC+1/5Ocn+eetfo/8A2z4b/wCett+v+Ffl R8B/B/jHxVqlvYWOug2/2zSrL/jz/P8ADsevvX6Y/wDDONx/0ONz+X/16yx2S4R123d6Lu+z6X1e 3zPEq4n3t7aen6r+vvf8z0OpQf2p9ug/0k/bO36/5/DrxWP4whn1jVbjVbGx+zC5P/Hp9s9uO/T+ n66EMP8An/P6nHsBWxND58Q/In+fT/Dv61+4ns4fLcG9+1r/AC3/AK7+evn+j6lfWefPguc9+n4f X6EDrX0B4P1ieHw5p99pU/2XUNB8SfbbK7/T378ivH/Jn/0i3/n/AI/ln9a6DQden0a1uIILe2ur e6x/x99fx7fjTWjT7NG+T/VMsxUlfdPzV7aaaLXqftxoPiSx8YeF9I8RwfZv+JpafbLP/P8AX154 r4v+PHhWDWJdH8YzwD+0NL/4kt5d/r7+mTmu4/ZR8Vf2x8PtQ8OTzk3Hhe8+n/Er10/29j2664fp 9a9A8YaPBqUWoaVP/wAe2q2ZHfP8/wCf1Fd+Yr61g9tkr20va1vV9vl1PzrFf8JmcvrzNuz2V321 6t69L67n436x8AYLzVNHsdDnOm2/9j6pZeJLu7sz/p+l65rX9vdv8+9fnv8AGD4V658N/EdxY6rP balp/wDzB7v/ADx6fmOnFfthef8AEturiCf/AEa4tePr/nPb0r4X/aR8SeHLweIPDhgGpahqmj6V /pf/ACEjYapoX+f618Xl2Ixf1u1nZO2uz2Vnrut773sexXd3fu7/AH3Z+f8ApsM82YP9G+z9f8jn /PqOv60fs9+D/GPwx8Jaffefbal4f17+y7280m0/5Cdhz6c9+/8AM4z+Z/hvw3PN9nvp+NP/AOPL rkcH1/kPbtX64fCv4qeDr3w54X0r+3LY6ha6Rpdje2l3j8+n8z6gY4rpznXDLror9ez1+Q8Pv8/1 ifUFn2/4FXQQd/x/pXD6Dr9jqX2gWM9tc/Zfz9u/5+/69zZzQT/Z5+n+f85z7+uK+SNzlvHngOx8 e6XbQ/8AHtqFr/x53f8AM57d84rQ+Hvw9sfCv2m+/wCfr/Tfsn/QA1Tn+3emf+Kd/wD1fTuIO/4/ 0rYg7/j/AEroA0IO/wCP9K2IO/4/0rHhm/z/AJ/UZ9wasXmp2Oj2txfX1wLbT7X07/mD/nua6Frt qc50EHf8f6VoQd/x/pXk83xIsfN/0Gxufx4/z/TnsK9g+Hum678Q4tQn0qxtvs+l/wDH5/pgP0/X 24xzXT/Z2K87eTb7efn/AFZgWIYf8/5/U49gK0IZv8/5/UZ9waz5iIbq4gnz9otuO2f1/wA9ParE Hf8AH+lIDYg7/j/Sis+Gb/P+f1GfcGrHn+36f/XoA0IO/wCP9KPP9v0/+vWf5/t+n/16Ptnv/wCO 0AaHn+36f/Xo8/2/T/69Z/2z3/8AHaPP9v0/+vXOBoef7fp/9eq/n+36f/XrPmm/yf8AP5DPqSar zXnk+/5f0oSb2TfpqBsef7fp/wDXrPmm/wAn/P5DPqSax7zXoIf9f9px6f5/mPy4qxZzT3lr9ut7 e5+z/wDP5xx09ff/ADmmsPjtN/6+S/QCxNN/k/5/IZ9STWPNN/k/5/IZ9STRNN/k/wCfyGfUk1z+ p6xBptrcTzz/AJ9/8gnpXMdBYmmghi/f3H2X6evH9f8A69Y8OsWPm/uIPtPH/H3d8fQ9u/1/Xnze 816+1Kbz/wDl34PH4/h/kH1rQ02b0/H/AOuPz6fQetelhsN/X9Wduv8AWuH1h+f4/wDyR6xpt553 SC29/wDQ/r9f/rnHrXoFno2iaxF5F9pVtc9/+PP0/T3/AJ15fo/+P/s1e0eG/wDXf99fyrp+qrsv 6/7e8l9x531jv/W3970/A8H+JHgn/hFZtPvrL7Tc6Pqn/Hn9rH/Hh3/sXP0/lnnrXk8/b8P61+iG veFLHxh4S1HSh/x8fY/ttn1/5CnY4P8An171+c9558Mvkf1H6Z/H8fzr5PEYazv1utfT7v6/H6PL cT9awnS/Xq/+Dvp37mfP2/D+tZ8/b8P61Yn7fh/Ws+ft+H9aErHqpdl9xnz9vw/rWPed/wDgNbE0 3+T/AJ/IZ9STWPNN/k/5/IZ9STTs+39f00BzGsXn2KI/8vNxdf8AHnac/wCf888nn5G1jxJ/wjdz qPg6CfTba3/4mllrHt/1Gsf5H4V9gXvkfjz09P8APT8K+f8Axh8N7CzsNQvtD0q2udY1TWPt15d3 XH2DS+mfrzXoYX7Py/8AbTXDbP0/U8/8N6xYw2lxPfarc/aNUvPsWj2gs+b/ALd8fTvXsGjzWEMX 7iD7Ncf8+n2Pnp/nGf8A9fj82m2MM3h+x/5eLW8N7/onbOef8OeucV7BZ94Ppx+WO30B/HijFfa+ f/txz4np6fqj9EPgbpv2L4c299j/AJCt59t/+t+n+c10PjDWP7N8OawetxdWf2Kzx9P/ANfPNJ4V s/7H8G+H7H/qD6X+X/1vzx0rh/J/t74jadpV9MLnT9L/ANN//Vn/ADnrmvkcP/tWLd+nS3p+O36a ln2R+yt4PvtN0a3nn/0a4uv9N+1/Yjxx0/z159efubydc/5+LX8hXhPwf8NwWdro/Azqn9qfY/8A TP8Ajw0vrzz/AJ+lfQ//AAjl9/0FdO/z+NexRty6+W/q/wDgfgfN1fjfz/Nn8kEHf8f6VsQ/vosc 569v05/+vnnmufs5vOiwOv8Ak/079/brrw/64fU/zr9WPqViV0ivkn6dvRFC8h8i6gn8j/R+OM/5 Pv8A481X/wBTdGDvdD0+vb6fXuOtdBeQ/uv+njI/z/PIz69M1jzf8u84/wCXTt+H5/8A16DBYbVO 6et+v+Z9UfspeJP7H+I0+hz/APHv4o0fVLLnn/iaaF/xPs/n/bma+4NeP7r/AK9b3/PPuR37fnX5 TeFNen8N69o+uQT/AOkaXrGlXvHPtjpX6w+dDqVr58E/2m31Sy+22V369P5V6OHtfyv8re6fIcR4 b/a1jO2n3L/gfLdn5T/tmaP4xh8R+H/+Ecvv7N0jxR/x+fY/+gp6npjpx17GvSP2dfAXw5+Hul+f 4x8OW3iTxBqln/pl3q4OpH3z7e+M/lXpHxx8jUr/AML6HPBbfaNLvNU8T/8AXhk/2D9eP+J5XP6b o8E01vPb3H+kfY/+PT2x/nuOePevNw2GtjG3t52/ry/Xoc+Hb+o3vrbf/wABPlf42fsr32pfEvX/ ABV8JJ9N03wvr39l3ln4Tu7z/iWaDqh/6AfX2/p615Ro/wCyX8TZtU/4qP8As3+z9Uvf+JwLS8zq fHXt9Oua/TfR7PyYrjz57b7R/wA+nt29s/hx7V1A0cTRCfz/AK//AF/6ZrreFwj3Sfq7/oH1heV+ n6faPl/4Y/Df/hXl/wCffarqWpXHNlnn+zP7Lznjr/8Aqr6Hh8SaVB/y3/8AJPqOnbI/z+a/2b50 vnzz2xA/L8j+f6n1PQaPoPnXXW2x3Ofw5/T0zXl4jJMH03f5/wBP77dDoWJxemqtp1W2n96/Reeh n2fjDw5D0vvXr39vz7V0Fn4q0Ob/AJfh9OvPv/nrVibTf3og8i268/6H3J659e3Ppxjiuo0bTdJh /wBfBbfaP+vL/J9P070lw7hWk+/l6f8AB/p6P615/j/9scveeKrGzi88fabn/Iz7cj0x/KvF/GEP jH4hTW8EEFzpun/bP9DtMen6/wA819Uf8Ifoc/7/AOw232jm9/0T8O//ANb+VH9j5uvP8i5ubjj8 ef1xznn6V1YfJMJhd7vbz7ba69F9zD6z5/j/APbHi+j+Fb7R/s8Gq32m3Nx9j/5ex/Zv88D/AD27 egaOPFXhvz77Q4NTtsWf+mfZMc8f/WxzXUQ6PB4kluINVg+y6ha/8ef+e/Ufnx7Gjwz6bFcQef8A 9OX6+n6flXpfV211tbz2/wDAQOe/4Ty+gluft1hi4/5fP5/5/l2rYs/HmlS/683Nt/nn/PH6c7MN nBeRf6RBbfTp/j+efTvitiz8K6VNnz9K03/wDz0/zjPoPy83+xMHe9nffZbgc/D480P/AJ73Nsf+ vL+uf5f/AK78PirSrz7R5F8bnGSOP8/j2rqYvBOhzHz/AOyrb8v8/l+lbFn4D8Kj9/8A2V9pPvx1 /wA9v5c1zf2Iv65f8zoPL5vG3hyGXyJ762+0d7TP/wCv/JODVj/hMNK8rPn8f5/TtnpnjpXqEPgP wrD/AMy5pv8AL9OB7/lXQQ+FfDkP+o0PROf+nP1/Ttx6/pQuHNn71tHq/wA0B4fN4w0qH/luT9ef 8f8AHtVeHxIbz/jx0rUrnt/x5/y6H65/Ovoj+wbGH/UWNsP+3P2x+PH9BRNZ+TF+/wD8+o/wz7Cu n/VzB9b/ANfIDweH/hKrz/UaHdW3/X31/wA9/QcfjoTeA/GN5j7dfW2m2/B/4/B+H/1/b9fUPI9/ 1/8ArVy+pXnk9ef8/l059cZxxXThssweF0dney7/AKbdn+Ke/P8AWfP8f/tjHs/h54cs5bf+1dc/ tIY/5dP5DufevabObSv7GuLHSvs39j2ln/xOD9T6f179+K8es4Z9Y/0fj0/Ue4/D07VoaPpviPQb q4gOq/adPuv+XT/P6dq6Hhm1tuu3/wBr5L7kc9fp8v1PN9en/seXUPPx9ntfwx+X64556968H1jX ptYuftH/AC7j/jz/APrf5/SvcPiD4J8VeJJbjyL62/5/fsnTA/A9f849PH5vh74rspf3+lXPX8s/ 4fTp07ivisTkuMw2LurO+tt1rZfrvv8AI9COIdlq9l+S/vGPZ9v+BV2Onf60fX+lct/Zt9Zy+RPY 3P2i14JNn7fn36+3X10Ibzyff8/6/wCetUsNjNLrTTo9tPPzRznqFneeT/Q888/z/XOeK7Cz16eE /uP6D/Pv/wDW48Xs5p5j5/bn0+g69efwHqSa6jTZvT8f/rj8+n0HrXWk+qd+unXT/P8AEVl2X3f1 2X3H0BoPirVYYv3F9c/r06Y/yD/Ws/UvhX4O8VG4n/0rQ9Yuv9N+12nr/nnNc/o/+P8A7NXrGgzf 8e/65/Dv+XX2PrXk4nCtrZ272dtfv9e/6Vhr4Tv/AFta3/B2R8T+PPh7rngO/NjqsH+j3XNlq1mM aZf+vv0x379K83r9QPiFZ+FdY8B6hY65Pm4uv+QP9k/5Cf8Aamc9Py/qDX5L/E6b4m/CvS7fxH4q +GWpf8I/dXn2L+17TWP7S0wcdOvbp/kV5zy3GYnXCbf5b7/jsfR4fMl5ej+Wn66r9UaE/b8P61jz 9vw/rXzvN+05of8A0Lmt5z/z+e3Hb09uf1GfN+0t4V6f2HrefT/PbHX3xSw+FxnVfh+f3r7t9Eg+ s+f4f8BH0Bed/wDgNcP42m8jQbj9+Lb+XcDpgce3PPSvH9S/ad8Dwxfv7HxJ362fX/6/5/SvB/FX xU8Haxf6dqsF942+z3X9qfbLvVuvT/mBdevT/wCvXTh8NjF39baf8Nr9349KxGE01V3brb9O57B4 P1KC9v8AxBPPBc/6LeaXZWd3/wAxP+fvjr+le0eG9HuLy/0eD/j5+1Xml2Q9/wAPT9PpzXy/P8Qv A+m2mn6Hf/2lbYs/tv8Aodn/AMeH9u8fX+QzXrHwT8eeB4fEfh/VdVnuf7P0vV/+Psf8v+B/XNc2 Y4bFpPz7fLf5df6Z9aXZfj/l6H68TEQxW8H/AD6jH59fp1/n7msf4b+G4de8eeIJ4P8Aj4tbzTLL /wCv79Pf0HSuH0L4weAfGGof2VoeuW1zcdfsl2Tpv2/t65P+enNfQH7NNmdS8UeKZ+3/AAkn9Dz7 9vz6V83l+GaxbWvn06p/f836WObE9f6/lP0A+Hvg6403S7f7dqt1/pVn9is/9D68fhj/AOtivUf+ Ec1T/oK2n6f41Xhs9KvPs9j54ttQtf8Al76cf5+v+Gh/Y3iT/oLW35n/ABr0fqq7r8f8zwz+ObTZ p/N/n1/rj2/wrsIO/wCP9K5ez/c48j/D/Hpx/X26iz7z/Tn8sd/oT+PNfqZ9bhtn6fqaHM0Pufx6 f1/M5Hc1z/k/vbiDpnPt/wDq5/n3611Fn/y8fv8A36fQcj8u/vWPeQmGXz/w/l3HpjPHt7UBienp +qEs/wDVH6D+Yr9Kfgzrx174X+H58/6Rpdn/AGLe+/8AYX+enHWvzPh/czTwfT056/X6/wAzzX2h +zHr3kxeKPDk/wD1CtaszjtzoOu/+4PtSw97edvnf3T5zO8N9bwistd/u+T6fhp0ueX/ABa8Sed8 VfFE8A/0fQbPwvonH6cnP06VsfD3/iZXVzPP/wAfH0HPXpwfx/pXi41P/hJNZ+IGq9f7U8Yap9jz /wBAvQv19e559K9x+G8M/qfT+ufrj/JFdJ52EVsGl2XX0R6fZ/6Za3EHH9oWuevY9MfXj/H314bz Nh9h/wCXj65/zwD6/nUGj2f/ABPrjHf1z/Mf1/KtDUtM8m/t/II6/n29P16c104ff5/rE5cQtNF0 /Rleaz/49/8AH8+P5c1Ys4Z5vr0+np0/L8/St/yfOi8/tj/9Wce3T06V1PhuzgmiwIOP/r4z/n8q Qzn7PR768l/1H+cdyPrx2rqIfDf2OXM/P04/l/nr2rqIYfJ/ceR/n9OR659MVsTQwXlr1/0jv9Of p36/4CgCvpv7np+GP69PUY/DpxXUQ2dvNF58+La4tefbnPXH6d/xrn9N/c/v4IMdP5+nP+TXUczQ +5/Hp/X8zkdzXQdB5v4khEM1vfWM/wDpHp+f+eO341nxATS+ef8Aj3/U8D/Pp+tdRqVmPKz/AID9 R0/z6848NncCLMH+f/19ffP4jnA0LP08j1PX655/z2PtXYabZ+d04/z+fXj0z15rHs7Of/PH1/l6 dPyruNOi8mL8eh9jnn/P/wBfoA0NNs/O/wCWH5ev9MH/ACa7Cz0eD+fP0/8Ar8+1UNNh9f8Aj4J/ z9Mcfl2rr7P18/1HT654/wA9h70Cuu6/r/h195z/APY8Pr/Oj+zfJ469sfTv39On6cYrY87yZfz9 e/T8OnXjrzVfz/b9P/r10Bdd1/X/AA6+8rzWfkxY/n/9f6c465+tcveQ9vp/9Yk/yGP610E83/Tf 1wcflxj69vXFZ975EMWPfn9e3+e/HNYWfZ/1/wAOvvC67r+v+HX3nH3cP/PAfX/9X55H/wBauXm0 yeb7R+fXt/n3zx9BXYTdhBP7Zz/I4/DisebyPK/1/XPTtg8+nX2H4GkF13X9f8OvvOfi02eH/UT9 vX8D6evb6YFdBpv2/n09/Tnp/n0qv+6/ztrY0280qGW4M/8AT6c+vXn8voBdd1/X/Dr7wvIf+Pee f/Pc9f0/EE0uLH/niav3lnBeRf6DObnp6f1/r6561nzabPZxXAmGf/rf068fmcnFG+/9f1ZfccGv 1zrb/gX/AMjh7yGxmluB5Pf09OmMfif05FZ/9mwf8sIPp7/5989foTfvPPB8gwdQfXn8v8eaggM8 J/1B9/8AP9evfqaLLsv6/wCGX3G/1heX4f8AyR2Fn4VsYbDmxtvy/wA/z5xVf/hFYPN/5BVt/Trj /wCt9PetjR9d/wBA8ieD/SLUD+Xvj/OfwsTaxP5X7gY59uufp2qvqv8AXu+Xn5L7kH1heX9f9vea +8z4fCuleV58Fja/aLX/AD+PX3/DNegedpUOlfuPCum/aPsf8/8AEn9D1rl9HvJ/K/fwfX1/yO3/ AOvOxeax9jtbieeDNuOv/wBf/PH6UfVF/SiP+0r6ct7/ANdgh02xs4vP+w6bbahk/wDLn+mf849q seMLLwr48+HPiDQ77/id6PdWf2K8tLuzx/xKu38vWuXtNYnvdL1Ceef7Nj9OnGcY9fbHU9KxtB/c +F/EHnz/AOkfbNL+xjpxj/OeOSB60YjDYSOFvFWe+is9Plrfr3/BebXeMumvL8Wv0tf/AIc/nI+M /wAPZ/hj8RvFHg6f/j30u8/0O7/5/wDS/wDmAjP+eRnvXi803+T/AJ/IZ9STX3//AMFCNB/s34l+ H9c/5d9e8N47c/2F29O/Pf8AU1+eE03+T/n8hn1JNfOWXZf1/wAMvuPqY7L0X5HP+JIRNa55x0/z 3/LPt78v519qf/CP2P8Ao3+ij7FZ9v05/l/SrGsTfvRx/o/1+nt+nr2rH0399dW/n/X16HoDnt/n mmM9I+IXnw+N/EEE/wBmFxbXv2L/AEQf9AIf2Dx+vHv06GvWPhhqWlTaDb2MH2n+2NL1jVL28P5/ 549Pbn5vhm866uJ+n16/y9x+pr6I+GFn5NhcTwZ/0r/QvT8Mfgf68V5OKv8AVFe/W9/PlLw+uLXa 69Ov/APWLO8vob+3nsp7q21C1u/9D+yZz6Z/+t2/Gv6IP2CfDeqw+EtP1XXIPtOsapZ/bbzpn8Ov 4/Tnivw/8B/BTx/r1/p89jY21t9lvNLvf9L7cfX8zX9CHwN8H+I/Dfhy3+w67pv+i2f/ACCbsY1O /wBU/wCgLx69/wAfTn5PMrXVrbrb0jY6fq7e/wCf/wBsfVEM9jrEtx/zDdYtbz0/Dt1/DtU/k+JP +fi2/wDA4V8UeA/j/rln4y1D4c/HCC28N+MP7Y/4k/iH/mGH/qC65n15/wDrAV9c+dff8/2mf+Bd Ynhn8j0Pkcfh+f8A+r71dBps/SDH0/kOf8feuPhm8r/P+eevatCHUoIZLf8Af2/5f/X/AK9evv8A qB9gegf8tf8AP96rF5Z+dFnv6/5P4dvYdaz4Zp5ov3B6fp/np17e5rYhzNa2+fT/AD/PH9e9B6Bz 00I8q37/AGXOf8+nX159TXoPg7xV/wAITqlxqv8Ay73XhvVbL/yin+wj1/6GP+w+OtcNCfJmuD1x /X8KwPFV5/ovh+xHS68SaX7/APEr/wCQ9nr6+o5oPMxWy9P1RsaFps+m6Vb2M/8Ax8f2x1z/AD49 D0//AFV9YfDf/wAmfsfv/wDq6/hXg/hub+0rXUJx/wAfF1efbf5fz9cV9IfDez8mW46/8ef6fy// AFGug+bxG/z/AMzuNNm8m6t76f8A5e/Y5+vX6dPyrYm87U5fP/5d+nHT3P8Anj26Vn6bF59rceR3 vfXoen8uv/166mH9ybeD/n1/wPr1/GunD7/P9YnnCWWfKHn/ANOvfP49O2Peu40GHyYsjn/Oefx9 /X61x8PnzS+f+eOP0/zn14rsNH1LyYvIn4t/8+vbPp6+nXcDsIf9b/qO/wDL+WT165rqIYfOiA+n /wCvv/8AWrz+CaeaXj0/w7+3X2rqLOGf/p5x6fng/j+vfrV/VvN/h/mL6wvL8P8A5ILyz+xy/wCv 7cZz6f5x/PrXQaPPB+v+evfv/k5NYs/+Pf8Ace2f/wBf44wfeuo8K6PY3t1b/bpzbdfy6e3A7jGe T61Ae3Xl/X/b3mvvPP8AxH+5+0fZ/wDP8uvb1xxiuHm+0ZHk/h69Pb+vbNe4fEjR7GzutP8AsJ/0 e6s/yOPfjp/OvF7OGf7Vcfh6/wCP/wBb9chgdBo8M/lW/v0+mP1P68dcV6BZ2c82Prgf4f5+nvWP o9n6/wCfp+vP616BZw9vr/8AXOf5jH9KDoCHR5/J/DjHf/8AV6d+ldBZ6PPDFnn+vv8A5x+XNaGm Q+d+B/T2/wA/riugs7Pyf6Djnj+X6YzzQHsF3/r7vJfcc/8A2bPDEf8AHp6/T3x+HrVf7Hfw/aP+ ff8Azjr+vr+JruPJg8r/AD6fXHv/APW5rPlm/wCeH0zn+X8uPyroF7BeX9f9u+S+483mhn69v/r/ AOPtj06HOPeQ/wDTD1/rjJ/lz9DXcXnf/gNZ80P+T/n8jj1BFafWF5fd/wDa+S+45fq395ffL/Py X3HDjTZ5v+WH/wBY+nfOc1Xn0ef8OOf8/XHP9a7jyPf9f/rVXx/0w/X/AOtXN9afZ/h/kdXsF5f1 /wBu+S+48/8A7Hh9f50fZIf+ff8An/8AFV2F5D2+n/1iT/IY/rWfND/k/wCfyOPUEVAewXl/X/bv kvuOfhhEMv7iD9fp7/4d+laN5NPNF1/x/Mcf4+/afyevn/5657/55OetEMP738f5f1/Q9aBnLzQz 9e3/ANf/AB9senQ5r+VN6foP8K7C803rOf8AP+e5x7Gs/wAj3/X/AOtRuBz/ANj9v/HqJpvK/wA/ z9unatCWb/nh9M5/l/Lj8qz/ALH53HT9fw/HPXPt3xXYsPs16r+uYWJxGui7Lze3l106dr+WfPeT y/8ALf8Az/n0/Kia8vpovIn+03P5fj7HPOOnf6VsfY/3XXj9fp+Xf9cVnzQ/vfx/n/X9B1rM4DHv Ly+Olmw8j/l84/l0H6/0zWxo95PDYeR/z9c8D/PPuf8A9de8h/6b+nP5cY/rRpp86X0/l9P/ANY9 qyxXT1/RHQfm/wD8FJtHP2D4X6qP+Pf7Z4osu/8A1AP8/h6V+Q95DcQy/wCI/rj69R+ff+iD9rr9 mPx/+0t4N0/w58Mp9M/4TDwbeHxPZ6Rq15/Zv9vaZ/Yv9gnRc/p+vNfg/wDEL4b+OPh7qlx4c8ce HNS8JeKdL4vNJ1az/s33J6dM/wBRXzh7WG/3T7/wseH6xD50X6/jk89s/mK4aKGfzf38/P8Anr14 65/L6eg3kvn/AGj0z65/zn68fXNcvD+5lxxjr3/Tn/62OeKCSeys5/8AR/s9x/x65/4+/wD6/r36 V+rP7N/wT8KzeF/D99rk9zqWsXQ+3Xtpaf8A1vf1PfnpX5cWf+tP1H8hX6P/ALJXxy0PwHr32H4j C5udP0uz+xaPd2ln/aX2D6j09fXHXmvLzj619UVrX8vlfytt8/kdeG3fr+h+uHw38E2Om6pp8HNt cXV4P+Xz/jw0v9fQ/l3r7o0fWf8AhGjqH9larc/6V/x+Xd3Z/T/5R/rnGa+L/h98Zvgf4kv9P1yx 8f8Ahu2+y/8AP3rH9m6oc8f8zB/P39a+uNN+KnwyvIv+R/8ACVz/ANxjReR9fqenevicRh8Zo3s2 vW357fd+fT9Z8/6/8BPL/wBpb4e33xC8N/8ACU6HY/234w0vP9sXdp/yE/7L9/T/AAr8+P7T8Y/8 /wBrf/fVfqxr37Qnw58CaXcX194x8N22n3X/AE+/2lzn/AA/h714d/w1H8KfW3/8E5rajU9jFRab 2tb5eXp66HKqeDqvmflo/l3+S3fXvr/P/B3/AB/pXH6x4c+2XX26D/ReuP8A6/r/AJzXYQ/v/wBx n/P6dj/icVoQ/wDPDH+efb/POR2r9MPeNHwrNP8AYLeCef7Tcdfz/wAPX1rt7OYTReR+P8+x9c45 9/evP9Nh+xy8f8e/P0988Dj/APVXcWc3nfh/gf50Hfh9vl/8iV73yPtXn4/z9O3+cZ6nz/xVDPea zo8EEH/HrZ6pe3v/AKYfbPTnHf64r2D7GLz7RB9Pp6nH9P5dK5fQrPzvG/iD/p18N6XZf+D3Wj/n Ptn3rnOfMcN9Wwis1d/q07/8A7j4eabPNDqHX/RbP/Q+/wCH+RmvpDwrD5EVx6fY+f5Z4/D3rx7w HF5N1cf9eY/T6e/vX0DoNn5Nhb9/Xr/nP6/hXoHxB2Ggw9z+R/8A1frn3rsP7N/e+fP2/wAf1z+d Y+nReTF+PQ+xzz/n/wCv6BpsJmi+zzg/aPfnt3/z+FdAHLmz8mX/AOsOnqP6Yz7+tdBptn7/AFx/ n6jn3PvWhNpvk/Z+/t/9fn6en4CtDTbO483/AB5/x/yR6cdBzafXOlvwtY0NNs/f64/z9Rz7n3rq P3EMtv8A57cnGOasabZ+TFjH+kY6+/4YH/689KsfY/3v+o4/Xr/nj9d1AzqNS037ZFbzwd/8n+X6 c1seG9H8m6gnnHb3/wAn0/yaPDX/AB6+RP8A48Y/H8Af/r1YvZ/+WEH+e2T/APW9+OtBvZdl939d l9xz/wAQooLy6/cf8e9r/oQ9v5/rz/KvH7OH/Sv8nn6Hoe3XivaNYiE1rcHn3/l6+3+T18vhi8i6 59O35f5xx9MUHAdhptn7/XH+fqOfc+9dxZ2f+fzzz+f6HFc/o8P/AB75P15/w/xr0Czs/O/oOeOf 5/rnPNB0GhpsPp+P/wBc/n0+o9K6CGHz5T+QP8uv+Hf0o02z8mLr37/5PIroIbP/AD/Pn+R/D2oA 5+8h7fT/AOsSf5DH9ax5of3v4/z/AK/oOtdhNZwZ79uf0Hbqf0x+NZE1nj1+0fqc8/p/Wg6DjryH t9P/AKxJ/kMf1rP8j3/X/wCtXcT6P5OfP/4+O3v2/wAjv6dax5rOfzePfOPUf59utBznLzQ/5P8A n8jj1BFHk/uv846fXPTv+ma2Psft/wCPUeT5X4+/+euPfp+YBz95D2+n/wBYk/yGP61nzQ/5P+fy OPUEV1E0P+T/AJ/I49QRWfND/k/5/I49QRQBy/2P2/8AHqPI9/1/+tXQfY/b/wAeo8j3/X/61AGP 5PnRfl6duv49enPtXP3kP/PD/j3/AK/rjj9D7c9hD/rfIyDx+Q/U/n/+om03zszj/j3/AM4BH6f/ AF810HOcPDpvnf6/n346Z/XHSrE9nB5vv/X3/wAj6dq6iaH/ACf8/kceoIrn7yE+b3/n9ef8gfQi g6Dn5v3Xv0/X8v6Vjz9vw/rXQT9vw/rXP3k3f6f/AFgR/I5/rQBj3kw8rt/P68f5I+pFWdB/1x+h /nWdPnzf3+MY7Y64/wA/04rQ02b7H6fj1/z+vt1A4MRv8/1kc57R8N9Y8n4q6fb551TSNU/p/TPP 9MV1H7VH7KPgf9q74fXOh6rBbaJ8QNLs/wDij/Fn2P8A4men6r/0BdcPOPDvoeP618/eA9Y/4vd4 X68Wn2Lt/wBAX/P8vev0Z0e8nh5x34P+ePb9ec18k/8AZMZrqpaat76f8Dyskehhfs/L/wBtP4V/ jZ8JfEfwx8ZeIPCviOxudE8QeFtYGjaxa8/0614vDZz/AOkTz9LX6fX/AD/kV/Th/wAFhv2dYNS0 vw/+0Z4c0r/SLU/8IX8SPsmP9P8A+gFrXHP/AFK/0r+bfWNNn0268j/l369enp9Oxr1E77HoGfo/ 766tz29+ufy9sfyr2DTdYn026/cQf8fX48/y4H1615voMP8ApVxP/wAu9qfp/Lj17/hXQed+887H 8uuP5YrkxXT0/VAfTHhWYzfaJ57G5/HP5eucGvSLOaymlt4P7Kufc/Y/z/r3rx/4SzX3l2/nwXOp ZvP6/hx3+pr7Y0aeDyv39vbW0/8Ahzn+hH6cV4uK3Xr+iAr6D4D0qH+z76+64N7+f+eh/OvafIsf 7x/KuW02byf3E/8Ax7gj/PT19v0roPKh9P0P+Fcdl2X9f8MvuOOr8T/rqz4Hgvf+e/55/mf8+g9K 2IIOhg/l+H+GDn1471z/AJHv+v8A9atCDv8Aj/SvsT7Q6D/lr/n+9XQaZ/F/n1rj4Zv3X4fy/p+p 6V0EM3+f8/qM+4NBzncWc373z+hA/wA+nv8AzFcPo955OqeOJ8f8fXiTS7E+39h/nnPrXYWc3+i/ 5PH1PQd+nFeT+FbyebS/PnI/4mnjDxRe++eR1P8AnnOKDbMcT/wkr1/SPk/zPrD4bw+dLbjP+ev+ f84+oIbPybS3/wA+/f8AM8/0rwf4P6b51/b8/wCfXOf/AK/4mvoi8/4+vI/59fy5544r0D4k2NNh 9Px/+ufz6fUeldhZw9vr/wDXOf5jH9K5/TYR5XP9f/rf5+ldRDD/AJ/z+px7AV0AbFnefuv3/f8A Q5/Gugs/I6+RbdOn45/T+Yrn4bP917f5/M/jx7VsQw/9fP8An/D8uw5rrw279f0PNxG8fl/6UjuI fPmi/wA+vXGMj/69Hk/vf856/XHXv+mKx9M/i/z611FnD2+v/wBc5/mMf0qDpWy9EWLP9z07/wBP Tpjvn9McVsQw/wCf8/qcewFV4Yf8/wCf1OPYCtCzhPm9/wCX05/yD9AaDpM/UofOsLjke30//UOO v515/DZ/6fx+PH+ff+XtXuENn9ssNYgz/wAetl9t6fl6+g4ry+Gz/wBK9x7fiP8A9X+HAebiN4/L /wBKR1Gm2fk9Of8AP5dOPXHXivQNHs/J/wBf/nv9M8/n+nH6Z/F/n1r1jTdHPlW84+zf6V06d+3/ AOqg6Y7L0X5Gxptn53Tj/P59ePTPXmugFn5MX/1j19T/AFzn29asaPD53+og/wA/5P4d897E/wC+ i87/AD9R9f5elAzj5of3v4/z/r+g61Xs7P8A0rz/APn0/wDr/oenf/DoBZzy/wDLDp6f59/89izh nhl/fn/I6/X/APV60Ac/eQwTS3HH4dPp26dvf1qv9j87jp+v4fjnrn274rqP7O/df5/Ppjp+nbFV 4bOeGa4E/Fva+3/1vb6d6APN9S03yZeMfn6fT/P0rHmh/wAn/P5HHqCK7C8/0y6uPp09OPrnn+X5 1n+R7/r/APWoA5eaH/J/z+Rx6gis+aH/ACf8/kceoIrqJof8n/P5HHqCKrzQ/wCT/n8jj1BFB0HP +R7/AK//AFqz5+34f1rqJocRfv8A/PPb/OPrWfDZieX/AD/+r6+oz0oObEbfL/5I5+GzE8v+f/1f X1GeldB/z7QfTkfjjr/nrmrH2PyeOv6fh+GOufbtiq80P+T/AJ/I49QRQMx7yHt9P/rEn+Qx/WuX vO//AAGuwvP33Xt/X1657f1zzXP3kPb6f/WJP8hj+tAHH3kPb6f/AFiT/IY/rXL3kPb6f/WJP8hj +tdRed/+A1z8/b8P60AcvN+99un6fn/WrHnfuv8AOOn0z07frmib9179P1/L+lV/+Xa5/wCBfyFY Yjf5/rI5zH8KXnk/G7wv/wBful/r369Pb/Cv1A031/z2POfDf49fT61+V+jw+d8WvC8/P/MK9/8A 6/J+vPUdK/Sizm/6Yf6P/wBeZHP/AITfv7E+lfJZj/vX3/8ApMT0ML9n5f8Atp1HxC8B6H8Wvhx4 w+HHiP8A5A/jLw3qmi3gI/48B/0Gj26n/wDX3/iX+Kngm+8H+LfGHgfVYPsuseF/Emp+GLz/AKcN U0L6Hp+H65r+3jTbz2+uP8/U8+49q/mf/wCCvXwfvvhj+0Rp/wAaYIP+KH+N1p/xOLu0/wCXDx5o X/Id/wDcH+HBoy2/u3v8zpw+/wA/1ifkfo9nPD9oguDi4tfw/wA//qNdBDZ/5/nz/I/h7VYhhg+1 f9O913/H9eepA/wrqJrPybXT4OB9qvPw/L8v8iuw3PpD4S6bYab4cF95/wDpF1/y6HP+gfr/APq9 uh9o0e8/feRP9Og/T/69eH+G4fsXh0wfT37nPf6/55rqNI1L979huP8Aj4P/AB53eeP16f55rwsV uvX9EYYjf5/rI+kNNmEP7ifv9OnB4Hbj/JrY8n/p4/SvP9C1Lzv3E/8Ax8fT8/8AI9Ca6D/Tf84r kEfI/ke/6/8A1qPI9/1/+tWh+6/ztqvN+69+n6/l/SvuD7Asw/6kfQ/yrXtJv+e5+n/6/wAsH/69 Y8M3+f8AP6jPuDWhB3/H+lAHQTXn2S11C4z/AMetn6dP6npXD+CYfO0vwvAP+Pj7GL3/AMH2tf8A 1/b2qx4qm8nwlrF9j/mD/Yuf89B/hxxmtjwfZ+T/AGPBj/j00fS7L3/5AufX/P4cc55eY/7rb1uv +3l/n+J9wfB+HybW4n6f57/lz6+/FewQjzrrPPT2/wDrf055rzf4ew+Ro3v/AJI6f5/r6hpsJ83n +n/1/wDP1r0D5s7DTYfT8f8A65/Pp9R6V2FnD2+v/wBc5/mMf0rn9M/i/wA+tegaPZ/ufPn+vU/p /wDXroAsabZnzc/4j9T0/wA+vOxDD/n/AD+px7AVYz0MEHt/LkAfgPyqx5Hv+v8A9auvDbv1/Q5s Rt8v0kGm2Z83P+I/U9P8+vPUWcPb6/8A1zn+Yx/SsfTYf3tv/wDq4/z6dPeuwhh/z/n9Tj2AqAw+ 3y/SIeR7/r/9arEMPnyn8gf5df8ADv6UVoWcPb6//XOf5jH9KDpNnQf+P+4g/wCXe6s/z68cZ5Ht z19DXl3k+TL+Xr36/h16ce1e06FZ/wDE5t5/+Pb04/D8h7/hXm95DBDdXAH8/wDPbjPrirw279f0 ObEbfL9JE+mnzpfT+X0//WPaveNHm86w0/8A6dM9/Tv7evb0rxfR/wDH/wBmr2jw35H2D/PX/wDV 92oGdhZw+RYXH/T1/n2+n65HY1KGCztPIg9f8n+vTp7V2Fnps8Nhb9f9K/yB/noax9Ys/O+z/wDP vyfr/n1H4elAGeYfJsLbP/L17+34f5+lZ80P+T/n8jj1BFWIZvO+lrj8CM/lj8KseT50X5enbr+P Xpz7UAV5v3NrjObj0+v8uvQ1y97P/wAsPrn+o/z9R2rQmmnm6nH6f5/lVfyPf9f/AK1AHLzQ+V/n +fv071n+R7/r/wDWrsJof8n/AD+Rx6giseaH/J/z+Rx6gig6Dn5oYPK+n4dfXHH64rPmh83/AD/P 26d66j7H7f8Aj1V5rP8Az/Ln+Z/D2oA4+aETfuPT8eef5/5xxViGHyv8/wCeOvetCG06T/p/L/6w x9D3qx9j9v8Ax6g5zn5of3v4/wA/6/oOtY80P+T/AJ/I49QRXYTWf+f5c/zP4e1c/eQ9vp/9Yk/y GP60HQc/P2/D+tc/ed/+A11E0P8Ak/5/I49QRXP3kPb6f/WJP8hj+tBznD3nf/gNY95D2+n/ANYk /wAhj+tdReQ9vp/9Yk/yGP61x8/b8P60AcveQnze/wDP68/5A+hFV4Yf3X4fz/p+o61ozf62f6/0 NZ08x8q4n6Y/DP8Ah29awxG/z/WQGP4J/wBM+JdvnH+i2Z+n9T7+n9f0Ig8iH/p2uOp+1/2Lpv8A 6f8A6ZHPGOO1fm/8MZvP+KFvB0+1WeqdfXr7flz6+lfpfptl/wAt7G3ufs5/5e7Oz/4RvTPx13xB 0/XkZ+nyOc/70vVfkj0ct+F+rOh02bGf+PbnP/L5z/n9c18Df8FSvg/B8YP2PPiBcQQf8Tj4c/2X 8QdH/wC4F/yHf/LcOuf4dDX3zD+5/wCW4/8ACk1nUv1/Pt9e1V9e0bSvG3hfxR4V1X7Nc6fr2j6p ousWn/UL13Rf7BHvXnYXE/7Z5beXS/T5vby7Lq+qvu/w/wAz+C/wf4k86L+yp/8Aj4tT/of+R/jg 17Bo+pT6lf6fB5H/AB7f5/Lp/hXh/wAYPBOq/B/4teOPA99n+0PB3jHVNF9f+QFrXf3/ACrqNB8S T/6PqtjP/wATC1/zkf549u/0mIw90nvdLX/g7fp+pht3fv19P8/xPtjTYb6bS/I/49rf/P8AQ1sW cNxNL/gP64+nQfl25fw38bPhjLYW8+ueI7bTdRuuNYtPses/5A/L1x0xoHx58MppfPsfH+i/Z/8A r94/n9eMnvXjfVX2f9f9vea+85cRv8/1kewaDqXnf8fH/Hxa8DtznP8Ak9T1+voH9r/9N6+Z4fG3 g6CW3ng8Y+G+R/0GNG/X/J/Guh/4Wd4V/wChi8Nf+DnRq5fqr/vfh/XVfecxjTQ/5P8An8jj1BFV 62PI9/1/+tVeGD/lgfbt/MD8SR+vWvrT7ggh/wBSPof5VND/AK4fU/zpfI9/1/8ArVoeR7/r/wDW oA4/4hf8ilqEEH/L1eaXZce/Pp+XWvSPDcP/ABObg/8APr/oX6dsemP/AK3Feb+NofO/4RfSuP8A SvGGl2V59f8A9WK9Y8Ew+drNx/1+fge/p7/hSw+3y/SJ4WY7P0/Q+6PAdmRa+RyR9j69Py9fr3P1 r0izhPm9/wCX05/yD9Aa5f4ew+da3HkZ9f6/5/oea7izh7fX/wCuc/zGP6V0niHYabCJvs+O/wCf H+f59q7+zPkxW4/z1/z2/A1yGg2U97345PJ/z7/413FnD2+v/wBc5/mMf0roA2If332f/wDX/wB8 /TB/pmtDyPf9f/rUQw/5/wA/qcewFWJ4v+W+fqfyH/1+Paug5sRt8v8A5IsWcP8A0w9P6Zwf58/U 12EMP+f8/qcewFcvZ9v+BV2FnD2+v/1zn+Yx/SrxPT1/RBh9vl+kSv5Hv+v/ANaug02H/ph9cf4/ n1P41XrY0z+L/PrUHSWIYYYrq38//j36f6J2x1P+elcfr8NvDrNx/wA+91/puPp6f56E/Suvm/1x +o/nWRr1mPL0+fkY/wBCHbjP4DHXPTFXht36/oc2I2+X6Mx9BhPm/X8//rc/j2969w0GCCb7PB2/ X+mPf/69eT6DD511+ZH4+ua+gPCuj+df2+f+Pf2PI65x/U/5EBh/9x87fqj2CGGCGK3g+z/6Ra2f F3+nf9M8da5fWIT9luMn/P6/y5/WvSIbP/Rbibjr+PT09P8APNcPeTfvbiDyMf8A6/6EH04FdAzz /wDszyZfyx/9b9M4/CugEPkWFx/y7fZcf/X/AP1/XFaEMPnyn8gf5df8O/pWhNZ+da3EH9P/AK3A 45/rXOdB5f8AY/3vXn9Pp+ff175qvP2/D+tdReab53H+R/8AWx+HoMVXmh8r/P8AP36d6DnOXmh8 3/P8/bp3rP8AI9/1/wDrV1E0Pm/5/n7dO9V4bP8Ae+/+fyH48+9Oz7P+v+HX3gc/ND/k/wCfyOPU EVnzWf8An+XP8z+HtXUTQ+V/n+fv071X8j3/AF/+tSA5+az/AM/y5/mfw9qz/I9/1/8ArV2E0P7r 8P5f0/U9ax5of8n/AD+Rx6gig6Dl7zuILf8AL9f/ANkiufmh/wAn/P5HHqCK7C8s/J/qOeef5/rn vXP3kPb6f/WJP8hj+tAHLz9vw/rXP3kJ83v/AD+vP+QPoRXUT9vw/rXP3kPb6f8A1iT/ACGP60Ac Pqf8P+fSuH1I+TL6/wAvp/8AqHtXoGpQ+v4f/WP5dfqfSuH1KH1/D/6x/Lr9T6UHOcv5sPr+p/xr H1P9zYXH/Xn3/D8unf8AWtC8h8n8f8R/Kse8m861+v4e/wCWfbv1zWGI3+f6yA5f4M/vvirb/wDT rZ6p+P8AnkdemR1wK/ViHTfO+z308B4H/H34hvP/AHB9Txj/AOtxX5X/AANH/F3/AD/P/wCXPVBn 9e/6/wA6/XjR9N86bz4IAe51bVv+Qnf/AORn/E18jnP+9L1X5I9rLcNf5/1fr38ixZ/vv9RPcj1/ 0P8As38vy/8A1Uanpv2yLz4J/s0//Lnd3f8Annp9fetibTf+e8/2nA/+t6/4fpiuHn1PVdBuvP8A PubnR/8Al8tP+QbqWPw79u4+ma8Q9L6t5f1/4Efx/wD/AAWA8Bz+Ff2udY1z7D9mt/iN4b8L+KB/ 2FP+QDroPI7aHx2NflvFrF9pkVx9hn/4+v19ueuM/wCTX9HH/BdTTdD8SaD8BvH9jfW1z/pnjzRf 7X+x/wDEzv8A/kAf8SXH6/T2r+aeaafp2/8Ar/4++PTqcfbZc08K7u/r/hX6/j5niV/97Xq7/cbE PiXxH5X+vx6f1yP6UQ+NvEdn/wAt+e3+h+/GPz9qx/P9v0/+vWfNN/k/5/IZ9STXVZdvw9P8l9yO Y7iH4neI4Mf8e11/192f+P8AT3qf/hZ+t/8APton/gnNcB+6/wA7ar+f7fp/9el9VX8q+70/u+n4 Aftx5Hv+v/1qr+T/ANMP8/8AfdbM9nPD1/kPXH19fWq00M/Xt/8AX/x9senQ54D7/wCq4vz+/wD4 HmvvM+iGb/P+f1GfcGrFV5+34f1oKs+z/r/h195x+vTed4o+H8H/AFGPtpx0/wCJEOg98dP8mvYP hvD52oW/XHHY4x+FeP3k1vefEHwvb/8APro/ii9/PRMj/OfX8PePhjD/AKV2x2GT/wDr/l+Nb4fb 5fpE+ZzHZ+h+gHwxs/8AQPP/AOnPg/p6fUH8Bmuoh8/zf859vbOM1j+A/wDQ9BuJ/wDpz/yOf8/m a6HTv9aPr/SunDdL+X/tp4h6PoR8m1uPI/4+Lr2/z/kn8ew0yHzvwP6e3+f1xXH6bD6fj/8AXP59 PqPSu4s+3/Aq6ANiH/l2/wCB1Y8n91/nHT656d/0zRDD+6/D+f8AT9R1rQhs/wDP8+f5H8PagAhh /wA/5/U49gK6izhHldv5/Tn/ACR9Sa5+Dv8Aj/St+z/1R+g/mK6Dmw+3y/8AkTZg7/j/AErQhm/d f6/jPf0/p+Y9Oaz4O/4/0qxFNb+b5H+fX9OfYVznSWJpv8n/AD+Qz6kmq+pZm0v/AK9b39fxx9fT 2roPDcOh69L/AK+5ube1vOfsvUD37H6fTvXpGo+CdDhmuP7KsfElzb3XP+en9O4roOv+ysbi8JdR afdxa35etrK/bU8v8E6bfT6pb+RB9p65Gev6/wBfWvpjTIZ9HluPPgz/AJ/X+p6H18302bQ9Bl8g QXOnXP8AX/I5rqbzxVY+V/yFba6zZj/RLuzGm8jrn3/P19qLruv6/wCHX3nKssxuG/3pOyVlZO9r K23Xz8z0eDUvJtbiD19uOe+Ofc9f5VX8r7Z+HPT17fj16+3sOHs/EljNL5Hn232i14/0T/kGdPQd P85rr9N1LyZRBP6fXj19hnn/ADig57Ps/u/ruvvLMNn/ANMP0/I/0Ofx7CtCGz872/P+v+etdBDZ /bO/fP8An+g/KiGz8n3/AC/r/nrXQbnLz6PB+PHP+fpjn+lcfeQwQ/6j/Dr79R6fTr7+wTWZni/z /wDr+nqfSuP1LTfJl4x+fp9P8/Sg5zz/APsz/a/z+dENn+99/wDP5D8efeu4h03919P1H4+nXuKr zabP/I/0Hf8AP09677Lsvu/rsvuA4+bTfOluM/8A1/Xp/TjHHpWfDpnnZ6j+XP4fTj8OvFewf8I3 51r55g/z/nn/APUKz4fDn/TD8/yJ/l39vWo+reX9f+BHOeTzWf733/z+Y/Hj2rn5ofK/z/P36d69 YvNHzLnyP8gn/Hr2rh5rP/j4gJ/P/P14/XtXGdB5/eQ9vp/9Yk/yGP61z953/wCA12F5D2+n/wBY k/yGP61y93/y3/4FXOdBx95D2+n/ANYk/wAhj+tcved/+A12F5D2+n/1iT/IY/rXD3nf/gNAHPXn +qH0P8zXEalMfN4/p/8AX/z9a6+8/wBUPof5muJu/wDW3P1H8hQc5y2sTwfZfI/5eO/59+/T+dcv qU3k2v1s8+3+ex6f4bGvTdh+Y/8A1/pj2rj9el/0C4n/AOnMn+h4P+etYYjf5/rICx+zqPtnxV/7 c+e3Gcj+uff2r9qLOz/def8A8vF1/wAvfQc+/t2/CvxX/ZLh+2fFC35/6Bef8/T245zmv3A1KaDT Yuf+PjGf8+n5e9fD5z/vi9F+aPosl3/r+ZnL6lqUGnRXH264Ntb8WX515/qU0F5EZ7cW1zB/093n +Hr17/jWvrHnia4ggntv7QH/AB+XfXTNB0vt/T6cV5BrGmwTRW88H2m2H/E0/sf7X/y//wDUa1wf 9C5156/yrxj08VsvT9Ufjf8A8Fn9Hg174QfDaex/0m4tfip/ofXP/E90XX+uf+wGD2/lX84+v+D/ AOzf3E8H+kcfbO2f6n9cfpX9EH/BVDxhrmg6X8H/ABFn/iYaD4w1S9s7vP8A1Bf+JF/xI/rz7/Ti v55/EnjD7bdXE88/2m4urz9en9c+pzX1uXX+q/ONvujt8/xPFxW69f0Rj6PoNjBoGoTz/wDLrrH2 Lv7/AE/r/KufvLOw/wBf5H6dfT/Pt25rYs9YmvLD7DBB9puLq9+2g/4/pXvHgn9nvXPElrb3+uTj RLe6/wCXT/mJ59zz349f6+k8T9U31Xn+Ftt9lfysjkSvsfK81nB5v+o+v1/ln26Hp6Uv9jXH/PA/ +Af/ANev0W8K/s3+DtHv7ee++063cWv/AILP8/r/AF9y/wCEU8N/9C5on/gnNcNXMlzbf1ddvT72 n2Ov6s+7/D/M9f8AscEQH/6v05/Lp1NV5tM870H8+fw+vH4dOKsfbPOi4g+vf/6+ex9+maPO/wCm /wDn/vis/rS7L8f8j9Z/tHBPS6106+X+S+4x5tN/dfv4M8e3T+efr3rHm02Dyvpk/gef8niu487y Yvy9O/X8evTn3rHmigmi/cfl/n1/+v1qyfrOCfS9/T/LyR8/3tn5PxGuMcfZfB4x7/5/xyRivoj4 Yw/8e36c/l/9bPvntXz/AOd/xW/xA4/49tH0uyx/np6V9MfCuH91b/p2/Hv2/Tpmu/D7fL9In5xn VnivK6+526H3Bo83k6DbwH/l69v8/jz79enYaPD6/wCfrj8Tn6n0rh9N/wCPDT4Pwxj8fT8f5DtX oGkf8sP8+ldJ84d/p3+qH0/rXc2cPb6//XOf5jH9K46z/wBUfoP5iuxs+3/Aq6ANiz7f8CroIf3v t1/T8/61z9n+56d/6enTHfP6Y4rsLPt/wKgCv9j8njr+n4fhjrn27YrQ02Gfzf59f659v8asT/6r j/j4z7fh/k8/pVizmgh/1/8Ah19uo9fp09+g5zP8Sal/YWl+f1uLr/QbO09NU+v6/wD1sV1Gg3l9 o+l28E9jbXP2r/j8u7v+nvj3rxfWNSg8VeN7bSoP+PfQf+Pwf9RQf5/CvYNN8+8+z+f14/l/nPTj rQdCxW1n6a//AGx3Gjw32m6Xb6VocH9m2/8Az6aTz69h9a838Sal8aby6+z6F8Mrb7OP+XvVvGB1 L/yh/wDCSeEf8n0r2DTYf3Vt5H2bHr/np+v8q7izm/1H6/8A1/14H0rD6u/P8f8A5E9pcZ5ssGsE opW0vb3l0b9b9T4vvLP9qH/SPI0rr/y6f2P159vEg9frV/w3pv7VF5dW9jqvgfwl/Z91/wAfmrat ef2bqf8A5b4/+t+NfpF4J02DU7+386x+0gH/AD+n413/AI38KwaBf6hDBD9mt+Ovr0PX+tP+zVe/ M/nL0/yR5r4hzV/FmW+j66aabf1Z+R8b+FfhjPoN1cX19qv/ABMNUx9s+13n/HgeDz/9c/Suw1jT dV0HX7exuJ/tFvdf8eft2/l9efyrQ1iGCWW4/c/59P6cdK5e817zvtFj/wAvOl3n+h/Xpj/Oeua2 WiS7HP8AWb6t6vV9un970/A948Kzedc29jOeB+vH4n/DpmvWNY8N3Gm2vn+R+f8A+rp/nrXzv4V1 iCaK3vvtH2a4454/yPxI4r7A17Up9Y8L+H9U+w/8etn9ix14/lxx6/qa6Dn9uu39ff5r7zx+eGCG Ln1/x7e/Q+tY95CPK7fy+vP+SfqBXUCaCb/Uf8fH+cfTI6DOO3Pav9j9v/Hq9D0Oc4/R4f8ASv8A I/zzjjt9DXcWfhuC8urf/l29P5dfyz/Lqa5+GLyLrn07fl/nHH0xXrHhuGCaX8f8+3Tn0Oa6DnND R/BP2yLyPI/+sPzPX+XNbGpfDeezi/1HT8/6/wAuv4V9AfD3QtKvJbf9/wDzwffuP519+2fwn8Ia x4at5ShuZjZcPnjOMlSMZHfGc57dDjjxGI+qu2urS++3Zelu+nVm2Hw99b/Prr56/wCX6fgzr3g+ ezluB/n/ADxz749K8I1iz8m6uMH/AA9v8O/8q/Uj42eA4NHutQ8iC2/6c/b098/z478V+b/jaz8m 6uOMn3/r/n0z2NaJ3SfdXKPB9Th8n8T+nPX/AD+ua5a7/wBVc/QfzFdjqX+un/z2Fcfed/8AgNeO egcPqf8AD/n0rh9T/h/z6V6BrH+uH+e1ef3nf/gNAHL3f/Lf/gVcPqc3k/iP156/5/TNdhqc3k/i P156/wCf0zXAaxN53/1+c45//Xnp+lBznDa9MJ/p/h7/AOeuO3Hn/jC88nS7g/8ATn3/AK9sfjmu w1ib91b/AOf8jn6+nIryfxhN50XkdO3t6e3/AOsk1hiN/n+sgPWP2P4Z/wDhYNvP/wAfP+maX+J/ tr3/AM5+vP7MXl4JorjyJ7W2uB/x+asf+XDv+X8/X1/G79le9g03XtYvp/8Aj3tf7L/0v6dvr07Z 9a/VGz8SaVqUVvB/x89f7H8PH/l//wCo3rnb9D9Olfn+c/74vRfmj6XJb/VnvflXr8K/UNSmgmht /wBxc/2f9s/4k/h7/mJ69qn/AEGtc7fyPavP9Sm8+W48/wCzal9qvPsV5/1H9U4/4kuh/wDUu+3/ ANauw1O8gm+0f8TX/j6/0LWPENp/y/5/5guhjHfP515vqV5D/wBe3+h/Yvslpj/QNL4/4kmh9/8A hIuuO9eetWl3aPQxWy9P1R+A/wDwWq1LyYvgv/pHN1/wlB/6/wD/AJAHH+cZr+e+88+8l+wwfarm 4uvXr/n/ACa/aj/gsN8QoPFXxk8D+DoP+ZN8N/bbz7H/ANBXXv8AD+w+3qPofzv/AGafDelal8Qf t+qz232fS9G/0O0u8f6fqn6f1PPevtcL/suETb3tovO3r6/1Y8XE7r1/RHh/hWb+wdU0+fj7Ra3n +h3h6c/gPXP5e1fph4D8VWPirQbe+g4uOt5/04arn/6/+e3yP8Zfh7/wh/ii5EEH/En17/TbPj/j w/z/AJ6VY+Evjb/hFdZt/Pn/AOJdqn+haweuP8/X9cmubMMO8U7ry2vto9v+G/QMNa7v3/T/ADsf eE15BZxXF9fT21tb2uPtf2v19uSPrXm//C9/hj/0Mlr+f/168H+M3irVvEn9oeFYJ7nTdPtc/Y/S /wD/AK/bjn06V8Uf8Irqn/PgfyFRRwyUdfx6fg/06dblVcT72/T+uq6/11f7n1Y87935OP5dc/yz RVeHz/N/zn29s4zUn0ZYh8+aHyP+fX+X6Z5weRx9KrzTfvf9fzjt6/0/MenNWIYf8/5/U49gKJv3 vt0/T8/60EfWl2X4/wCR83Qzf8Vb44/6etY0yx/+t+HXNfZPwxh8mK3B/wA+54/XPvXxfoP+meI/ EE/X/isNU/8A1dMj09a+6Ph7CPKt/X/Pr0P4fjXr4fb5fpE+dzL/AHn5r8on1RpH/LD/AD6V6ho/ +P8A7NXl+hf4f0r1jR/8f/Zq6TzDuLOEeV2/n9Of8kfUmuoh/de/X9fy/pWPps3p+P8A9cfn0+g9 a6CDv+P9K6ANCGb/AD/n9Rn3BroNNm9Px/8Arj8+n0HrXPwd/wAf6V1Gmw+n4/8A1z+fT6j0oA0L yfzfs/0/z7f/AFu9Z+saxBo+jahfT/8AHvpVn9s9vT9R/ngVPN/rj9R/OvGPjBrE80Ph/wAKwf8A Hxr159uvMf8AQL0L/PuOeRmug8//AJjPL8Nl/wAD8DoPg/ps81rqHirVf+PjVLw88f8A1h+H5mvp jTbOCGK2/wA//q6n8e9eb+D9NghsdP0qD/j3tbPP+e/6f417hptn5MVuPx//AFf49849a5z0DQ0y HyfxH6+3+f0xXUWcM/m2/J469een86yLP/j6P1H8xXb6bDPyf8+vOP65/wAegPq3l+H/ANqeoeAx 5N/p/kD/AEj7Zj/6/T6/jX2h8cvh7rmp+BPB/j6CEXMGqaN9jvbu06gaFkZ/Tgn0Ppx8X+Ff9Dur fp16ce/+fy781+lHhvx4Ne+C1x4IngtrmA3gvbMjGbDqccDOByRk9+Kv60+z/APqq/l/D/7XyX3H 5L6lCPN/f9/bGP65/KvF/ElnPD/p0H/Lr6+nOMflxx/Kvojx5pv9m6rqH/Tpd9M+gPH+P+FeL69B PNFcf15/X9ag6LLsv6/4ZfcZ/gnXvtguIP8Al4+2f6YT2/T25J/Sv1B+Fc+h+KvhLc2N99m/tjQb w/Yvtd5+dfjvo15Po/iO4g/5+vXnp69P89a+/wD4P6z/AGxFPYz/AGbzxZ/6H/n8PXvQc1l2X9f8 MvuNCbTf7Nv54Of+PzH4YP8AjwasXkPn58g9/wBM/n/nqOlV9S8/zbiCfnt39eP5/l2rP+2dfPH4 fn1JP17+vHeujY5/q68vw/8AkSveefDL5/8An+fv6dPzroNH17Evn57fyH4Z9P8APHL6lqX+i3Ge cevf/I/lXL2epeTz/k//AF8/j6nNdn1i39f/AGpy/VV3X4/5n2B4b+IX9mywTwT/AOcZzx+OOffm vtD4e/tCTWlhb6VcT2ptxZ5vDdjkZyOOOD+Pcjua/J/Tde65/D+XP6DmuwsvFU8MuftH/wBbp/T2 rmxOH+ta9E7+m3n6W7Bhr63vt19T6Y+MPjyDWPtBgn6Wec+vp/T9a/PfxheeddXH8/T8+PrXrHiT xJPeWtx+/wD88/XHH+ex+f8AXrzzpbj/AOv/AJz26V0/8w1v+H2Os8/1P+H/AD6Vx8/b8P612E37 326fp+f9a4+7/wCW/wDwKvDOg4jUf9afr/SuG1P+H/PpXcan/D/n0rz/AFKb1/D/AOsPy6/Q+tAH H6lN6/h/9Yfl1+h9a8/vJoPNweeff8D168fX6nNdxqU0HT/Pp3/pj/DzfUpv3tx/+rj/AD69Peug Dz/Wf+Xn/r8P/sleL+JJsS2//Px/xNPtnuPT/J+le0axN/pXn+n064//AFfnXz/r83nXWodfs91x 684/H9Peuc5z6w/ZX0H+0v7Y6faNUx2/z2/Wvvj/AIVvpV5a+RBD9m/tWz+2/wCiZ51Q57cfn+Vf I/7Itn5OqaP/ANfnp0/z/wDr5Ar9IPsfk/2eM/8AHr4k1Syx09+P8ivgM5/3xei/NH0eWf7mvVfk jwj/AIVvYTfv4J9S/wBKs/7as/8AicaznnA13Re5/Xv69Eh8BaVpsX7m+1L7P9j+2/6Xef2lnS/x 9+3b8q9ohs7ezk0/t9l8SapZe/8AxPf89+PTFY8Nn50Wj2Fx/wA/nijwxej0/wA+3Q+vAHnJ2afZ 3PVP5F/+Cunwx8R+D/2krjxjff6Ro/xG0fS73R/poWi/2DrvP+fwr4w+DOgzw6DqGt/8vF1rH+h5 /wCoFx1/nX9N/wDwU4/Z0/4X9+znqF9pUH2nxx4Ds/8AhYHhv/p/Ohf8SHXdF/p0/wAa/nf8FQwa D4X0fSpoP9ItbM/bckf8hT9fU/l7CvrMNiPrWES0ult5WXz7a/keT/zFO+2u+1vd/U9o8SaDpXxg +HP/AD7avjn/AKcNU4H49+nrX533lpfaDqlxY30H2a40u8+xXn+fbr/9bp9seCPFX9g+I/Ingubb RtUP+mfa+fsHt/Xjn2ODjl/2ivARhmt/GOlQf9OWsY/H/iddc/r+FPDbP0/U5T5/vPEn9vQ6NpM/ /IQtbP7FZ3ef+YXnn+fNJ/Zo/wCgrrf5j/CuQ0HyP7Z/tWf/AI99Bs/tvb8enGf8fz9A/wCEp8Hf 88rf/wAAjXWB+qEMP7r8P5/0/UdaPKm9P0H+FbEP7326/p+f9asQWf73n/Sfy+v656Yrzz6A5+GH 97+P8v6/oetJL5EP2gf8vHT8vTjp+PFdT/yy/wA/3a5/UvPhtdQ/68/ft/Lr6fkKAPlfwT+/urif p9q1jVL3/wCv/PPbp0r9APAcP7q3/wD1f557dj7V8L/DGz87+z5/p/6evb8P0HpX6AeD4T5Vv+vT r2/X616+H2+X6RPCxW69f0R9AaDCPK+n5f8A1+Pw7e9esaPD6/5+uPxOfqfSvL9Bh7n8j/8Aq/XP vXrGmw+n4/8A1z+fT6j0rpPMO4s+3/Aq2IO/4/0rn4fP4/D8v/1/erQsvP8Aw46+v+ev410AdBZ/ vpc/yIxj8vwrqIf3Xv1/X8v6Vz+m+f8A88PqPwB/+t34rqIZp/8Anh/+r6Y9evHpn1oAJ+34f1r5 ns7z/hMPihrF9/zD9LvP7Fs/X/iRHH+emfxr2j4heJP+Eb8Oaxrn/HtcWtn/AKH/ANhQnP4/X8h1 rx/4J6P5Nhbz3A/0i66Dv/XrXQc2H213t132ifYHhWz/AHVv6/y9PU/59uPaNNhHlc/1/wDrf5+l ef8AhuH917f5z9fpx+R49Hs/9UfoP5ig9E0YP+Pm3/D+YruLObyfx/xP8q5CH/WwfX+grp7Obv8A X/64x/M5/pQB6RoM3/Hv+ufw7/l19j619QeA9fghtbiCf/P8j29/Svj/AE2aeHmDNz+n07/4V7B4 U1ieGX/X9Dj/AD/Xkdu+KAOf+J1n52q3M8H/AB73WRn/APX/AJGPz+b9Yh8mK4/X0weM/wCT+GBX 1R4wm+2Rf0Hr/Tj0PXt6/OHiqE+b/n/9f0z1/GgD5e17/Q78z/8APrecc+34dz6GvqD4J6//AGZd 6PP9u+0j/jyvOOevP5c/5xn538VWfnfaP6/X+vT169a2fh7r3lX9vAM/6VZ/5P8Akn6Zq8NbW9t+ voc593+JJoPt9x/09H9eT+v4c/QVy/2z3/8AHar3mpf2lo2nz9/f2P8AnPJ5Nc/9s9//AB2oAsal edYCfUf54+uOPXmuPF55Mv8A9cdPQ/1zn29KsXl5539Tzxz/AD/XPasfz/b9P/r10HOdRZ3n+fzz x+f6DNbH9sfuun+H8/Tv6dq4ezmPm9/5/Tj/ACB9CasTXn+f5cfzH4+9AHUXmpedF/8AW4/X/wCt Xn+pTev4f/WH5dfofWtDzvN/D2/z0z7dfy5+b9zLnjHTv+vH/wBbHHFB0HP/APLL/P8Adrl7v/lv /wACrqJ+34f1rmLv/W3P1H8hXngcNqf8P+fSvPtR/wBUfp/WvQdX/wCW/wDn1rz7Uf8AVH6f1roA 8/1H/VH6f1rze8hgml/1H+fb8vx9eor0HU/4f8+lefTXnky/9PH+e/6jPT61zgeYeMP3P7iCc/af +XzjH0zxz+X9K8n8YQ/2bFp9l5GPtV5pf+l+2OOvT/Ir1D9/qes3BngFz9ls9U/X1ryfxh583iPR 7Gf7T/16dOM59fX6YrnxX2vn/wC3Afox+y7pv2OXw/Pj/l80vH+eDj/63Sv0Q1KHyYtY/wCnTxJp d7/n/P618H/s02Zml8PwQ9sEf/qA/wA/TivvjWJv9E8QT/8AP1eaXznp+A9v88Zr4LMv96+a/KJ9 Jlv+5r/t3/0mJz+sQ+T/AGwOP9F8YaXe/r6D+n8xXP3kPky3H/Tp8SNL6+3/ANbt+fStjWJv3viD H/HxdeJPC/8Ant6/hz7msfWJvOutQ8gZN1480v8A+v8Aj2z1+nfkOw8n8YWfnaNcWEH+jf6Z49sv UdOvTPXr+NfyL+MLOeHxH4gzB/zGNU/48+emt/pz0/zj+vDWP33P/Lvdax48vf8AytaB/Tj/AAr8 F/iR8MtD03xv4w0qfSrbz7XxHqll6/8AMa/L06+te3l2y9P0OPE/1/5Kfl/eabP1/D+WP89s17Bo OsWPjDwlceHNV/5CGl2f2K8tLvP+n6WOMen+c9cV9EXnw+8KwxXH/EqtsZ/n+ufxx6V4/wCNfDeh +FdB8QeI7Gx/s3UbTR9U+x3Xp6j8P85xXdHdeq/M4z8v5oZ7O18U28GP9K1j+xbPjk/r6+//ANbX /wCEbsPQ/wDfK0TWfnX+j2H/AGFNavPz6fX8uvQdKs/2zD/z2/Q/4160dl6L8jzz9mPJ8mX8vXv1 /Dr049q2PO/49/xz/wDX/TI/EURQ9fP+uMfz/nz+dWfJ8mW3M4/Mc+/4/oO9eQfUGd5s3r+o/wAa x9em8nw5rE8+P+QPqh6+4xzx26V2HkmaL/j3/wD1+3r+GPfiuX8ef6H4I8YT9P8AiT6oOv8Anrzx +tAHz/8ACWH/AJA2P+fPjn/P45/CvvDwfCfKt/16de36/Wvif4Vw/wDIP/689Lz/APXB/wA9R6Gv unwf/qrf6j+Yr18Pt8v0ieFit16/oj2/Qf3P2b2/Tp+eOfpnv39Y02H/AI993+f1/UH1Bry/R/8A H/2avUNM/i/z610nIdhB3/H+laEHf8f6Vnwd/wAf6VoWfb/gVdBznUaZ/F/n1roIZv3X4fy/p+p6 Vz+mfxf59a2Jv3Xv0/X8v6UHQfN/x41jzpfD3hW3/wCYpdi9vcZ/5BZ5/p+vSvWPhjpvk2tvjHPv +n9O469q+b/El5/wlXxf1D/n30H/AIktn/k/rzxX2B4Js/Jit+/9P89s0AfQOgwn7LxnH5/5/n+Y rr4O/wCP9K4/R/8AUn/Peuohm/z/AJ/UZ9wa6ANiGbyPs/v/ACyf6e+a6Czm7/X/AOuMfzOf6Vx/ nfuv846fTPTt+ua6CGb/AD/n9Rn3BoA7DTrz/lv/AJ/D/wDV6mu503UvJ/f9P89v698CvJrO8/z+ eePz/QZroLO8/wA/nnj8/wBBmgD0C81LzpenHpzj/P0z369vL/EkP/Hxj68fp/8AWA/PrWx9s9// AB2sfWD50X6/r/nt36UHOeD+JLP0/wA9u345P69RXD6bN/Zv7/HGl6x/6ff6+vrjmvWNehPlXHX9 P8j+Y69q8v8AJzqF/BP/AMe+qWf2LHT/AImn9f59/SucD6o0HUvtmjeR/Xnp/h+HtRNefuvb/P5n 8OPauH+FesHUtBt/Pn/0j7H9ivP859xznj610E/+t8jIHH5j9D+X/wCvoAsTTf5P+fyGfUk1kTf6 k/Qfyqeft+H9az5vPmx9fXGc59e/06flV4ndev6IMN0+X/tpYs+3/Aq0Jpv8n/P5DPqSayLP/Wn6 j+Qq/P2/D+tQBX8791/nHT6Z6dv1zWPeTd/p/wDWBH8jn+taE/b8P61jzTf5P+fyGfUk0AZ803+T /n8hn1JNc/d/8t/+BVsT9vw/rWPed/8AgNc4HD6n/D/n0rzbUf8AVH6f1r0nUpvX8P8A6w/Lr9D6 159qP+qP0/rXQB5xqcPnfgP156/5/TNeX6xP5P2if+Wc4/8A1GvWLz9zLn+ZGMfl+FeL+KpjN9o/ zjPtx/n8a5wOf8KefDL4gvv+Xj7H9i/Acfr2zXg+pXn/AAknxG04wf8AHtdXml6L1z1Of89/qa9A 1PWJ9NsNQnt5/wBPz6/hXj/hu8/s3xRo9/8A8fP9l3n20cfl/QD/APXXPivtfP8A9uDDdL+V7/8A bu5+yHwHs4NH1TRxBm2xZaoPx/sXv7H06d/p9geJJoIZbe3zza/2Xx/iP85/Hj43+Bt5/bGvaP54 /wCJgbMXv0/L+fP619IeNvEkEOs6hifj7Zz6H+wvr69+/f2HxWZf7181+UT6TLf9zX/bv/pMTPvN S866t/8Ap68Yf/WP6emD0xXL/wBvQTS6Px/x9eMNU1r6/wBhfngf57Vw83iTyZdHn8//AI9bTVNa /wAOfT/9VeX6l4wg021t/wB/i40vwfql77f2prv4fUelch0/Wl2X4/5HQeJPG32LS7Cf/j2t7Tw3 4o1q8u8An/ie61/X+tfkP4kvf7Y17xDqtxxcapeapen8/T9c19YfGD4hQTWGsaHpV99puP8AiV6L /omONL0LRcfoNc1wZ9cc18nzQ/5P+fyOPUEV6eGaTd31/Q8o4+8h7fT/AOsSf5DH9a+V/wBpbUv7 G+H1xBDP/wAhS8+w9vY+v49/yr7AvYP+W/1z/U/5+g7V+e/7ZmvQWcXh/SvPHT7defp9O3r6e9dO G1t/X8wHwfDeeddeIL/j/RbP+xbM/wCf8n15rn8Tf8/H8v8AGtiz/f6XbwH/AI+NUvDfdD9P8g/r 0rsf+EJ1X/nhbfkf8a9w88/beGz/AOe+bm4/H0//AF/1GaJofJ/5Yfz9j7j8Oa1/sdx6j8v/AK1L DZz/APLeC5/PnH5Z/Pp9K+Ys+z/q3+a+9H0BXsvI/Hjr6f56/jXn/wAWofJ+HPjD/rzz0+n+eOxr 1CGzn83yPI46Y+nX8/zzXl/xms54fhz4g9MaX/6euf8AD/JrvA83+GMXky2569uf8n/GvtDwrD/q P1/+vn8cgfnXyP8AD2Hyboj14/DOO/t/kEV9ceHf+Xf/AIF/SvXw+3y/SJ5WK3Xr+iPeNH/1J/z3 r0jTP4v8+teb6P8A4/8As1ekaZ/F/n1rpOQ6iDv+P9K2LPt/wKsezm7/AF/+uMfzOf6Vs2f+tP1H 8hXQc508P7r36/r+X9Kr6xrEGm6XqGqz4+z6XZ6pe45P0/z79Ogo8791/nHT6Z6dv1zXj/xs17+z fh9qMH/Lxql7pei+n4f5JoA5f4Y+G57yS41zrqGqXn2287+nT/8AV/SvsDw3Z+TFb4g/H+f/AOvp ivk/4M6lPZ6Xp8F9/pI6f0/+t29PQV9saFNBNFb+RPj+f+c8/jjjrQdP1h93/X/b3mvvOw0z+L/P rXUQd/x/pWPDDB17/wD1v8PbPr0GdDyPf9f/AK1AixNN+6/D+f8AT9R0rQs5vO/D/A/zrn7yGfys nnj2/AdOnH0+ozWxZwzw/wCvg/8Arfl6/Xn1BroMNfrnW3/At/kdBDN/n/P6jPuDXQQzf5/z+oz7 g1w/nfvf856/THXt+uK2IZv8/wCf1GfcGg3Og8/2/T/69WeZofc/j0/r+ZyO5rGg7/j/AErYhm/d fh/L+n6npQc5w+sQ/wDHxg/Tn6+v+NeH+JP3MtvP/wA+v+f8MDqSK941j99jPfP44/z79O9eP+JL Pzv+WA+z9u+e2M/pXOB0Hw9vPsev6xpX/LvdXn2206D/AJDvr6j+lesal5Hmjrn/AD6fhn9a+Z9B 1L7Hr3h++n4uPsn9i3v59uh/z9K+iL399Fbz/p/h/np0rrw3X1/Q5xIf9cPqf50t53/4DVaH/XD6 n+dLNN/k/wCfyGfUk1B0Ybp8v/bRIf8AXD6n+dWZpv3X4fz/AKfqOlY8M3738f5/1/QdKszf6k/Q fyoArTTf5P8An8hn1JNZ803+T/n8hn1JNWJpv8n/AD+Qz6kmseft+H9aAK8/b8P61nXn+qH0P8zV mft+H9az7zv/AMBrnA4/U/4f8+lef6n/AA/59K9A1OHyfxP6c9f8/rmvP9T/AIf8+ldAHm+veRDF b/8APx/y+cemPz/M14v4kmghsPP/AOXi5vP9L9ff/wDV6HrXrGsf64f57V4t4qmHlf5//V9M9fxo A8Y17P8Ao/8Az72tn/bV51/IGuP8K2dvNf3H2+H7T9qvP7Fsx1/4mn6//rH0Fdhr3kfYPP8APP8A xNB9i9P+JWfoP09OtWPhjo1vNa2+q33/AB8f2x/of+R9fXnt2rDEb/P9ZHOt1bufWHwx+Kmq+Cde 8Qa5BY3PiO4tf+JJZ/2TZ/r255/zya7DxJ8VPGOsS6hP/wAIrrYuPsf/AC92f9mk56568f8A68dq 83+DUHnX+sT/AGf7Nb3V5ql99k/7jX4enr07Z5r6gm037ZFcf6P/AKRdax9iPtyM8den8ya+BzL/ AHr5r8on1mFw9sHfbZpettNP01vtZHzNrGsfEbUpdZgg8OfZrf7Hpei/6Xef8wv/AOucYr8sP+Gw PH/xU/aM1D4V+HIbbTfB+g+JNT/4STxDaXf9p6nr2l+Bf+JFz/0L+On1FfsR8VNe/wCEJ+GnxA8c T/8AMB0fx540/wDBFouNC59Mfz49/wCf/wD4J7+FftkvxA8f31v9puLr/iS2d36/8x7Xe2fX6fpX Rhkvqf1vR9HHz+evp2t1682J3Xr+iP0Yng87/n1/LH54HT/9Vc/eQ+fL5H2f7L19/wDP5fTvjsLy GCY/v/Yj/wDV9T9P6c/ND+6/D+X9P1PWuQg5+8h7fT/6xJ/kMf1r8d/2uryfxJ8RtYsbH/j30v8A 0P8Az/Pjjmv2Q1Ka3s7C4vj/AMe9rZ/6Z7f5/wD1dMV+F/xO16DWNeuZ7j/j417WNUvevODkcfy/ rXu5duvX9TLE7r1/RB4D0HQ7zRtQvtVt9Suf7MvNLsv9EvP7N/5Dvb/6/vj2r6R/sL4c/wDPEf8A g6/+tXzt/wAI35Gs/wBhmDW7m30vR9LvdY/L9euB1z71Z/4SS3/6E3U//AzWv8KyrVHWlzK/37dt /T71cg/ff+x/85/+yqv/AGPP53X/APVuzn/Pbmu4s4f+Pj+n54/lyfYe9E0Jz3+0f5/T+WePfey7 L+v+GX3DX1y6vtfXbY4f+x4Jov38/f8AL/8AWOePrxXk/wAZtH87wRqEHT/TNLz0/wCg0fp26emP Y19ETeRDj6eucYz69vp1/KvF/jNNB/wiXkZ4utY0rjj+fPue3c+9M39T5/8ABMI+1XGf+fzrjP8A hj8K+sPDv/Lv/wAC/pXyv4JxNdXH5/09PwxivqDw7/y7/wDAv6V34fb5fpE5z3DR5v3Vv/nn1z2P 6D9K9Iss+UPP/p175/Hp2x715fo/+P8A7NXpFn++6dv6+nXPfP6Z4rpOc6Czm7/X/wCuMfzOf6V2 Fn++ix/IHOfz/GvP4O/4/wBK7DTZ/Ki/zn/PP8/w6AOgmm/e/j/L+v6HpXzP8ftS+16p4X0OD/sN Xn6f0r6I8/2/T/69fJHja8/tj4q3EB/499L/ALKsv/19vrz9RigD2/wHD/otv6/X9fT/AOt6mvpD Qv8AD+leL+D7M+Vb/wD68+nGOK9w0ez/AHXoO/Of849+vpXQef7Bd/6+7yX3HoGm6lfQn/X5/wAj p647/wA+ldRFrH7n9/AP8/1z+A/OuPhh/wCm/rn9Of6Y/GtCgF9cVu3y/wCHO4s9esYZbeeexubn /p0/z+f55zViXXvtl158/wDx89c+v9f8+9cfDD+6/D+f9P1HWtDyPf8AX/61B0L65p+v69fXqdhB eQS/8t/8/wCfX8q6DTZ/9K/5+fb8OOn8v5V5/B3/AB/pWhDD/wBN/XP6c/0x+NAHqEPkeb/qOn6k /wCHf+VaHkweb/qOfp749PX9K83hE/H7/wDH9T+Hb3PpWhDNff8AP9c4/wA4/wAOnFAHUXkMH+vn g9Oce/1/Dj0rzfxIPOiuOLW2t7rAGPf1P6e/eti88/H/AB/dx/8AW/8Ar/5xw+vQ/wCi3H+f5d/0 PWucDxfX5oIvtFxYzm5uNLvNL1r2/D09Ovft0r6X028+26Nbzn/nzP8AMf5/ya+YLyz8mW4/599U /wBC9vwz/n+nsHwr1j+0vDmnwT/8fFrZ/YunJ/x45OOf6dBznoFV5pv8n/P5DPqSaJ+34f1qvNN/ k/5/IZ9STQdBX8797/nPX6Y69v1xWhNN/k/5/IZ9STWPDN/n/P6jPuDViab/ACf8/kM+pJrnAJpv 8n/P5DPqSax5pv8AJ/z+Qz6kmrE03+T/AJ/IZ9STWf5/t+n/ANeugAmm/wAn/P5DPqSax5pv3X4f z/p+o6VYvO//AAGq837mLHOevb9ef/r554rnOg5bUf8AVH6f1rzjWP8AUj/PevQNSmHlcf1/+t/n 6V5vrA8mL9P1/wA9+3Wug5zyfWJvT/P0z+Ax+HrXh/iSXzpfIg/5ef598/y/w617RrxMP2ifue// AOrn8MYrwbWJh5txPzx/x5/TP4/0965wPIPG032yW3sYP+XX/QrP6dO59vwr1jwfo8Fnpdv9u/0a 30uz+3fQdx09+Mfh7+Xw+RN/aE88Fz9o/wCPKy6DPr/L64NekTalPDYC+yP7PtbM6L/1/wCqf2KO Pp+mK5wPpj4MzH7VcX2P9Hurz7Z/x5+3HX37dfwr6AhvP+QfPn/oJ61n8+/65+vvXzv8GYZ4dLuP Pz9o+x/XPPToR9fzr3jyf9FuTx/otn9i6Z6/5+nPpmvisy/3r5r8on0eF/3N27/5nxf/AMFDvFQ8 K/sg/EnyLj7Nca9o2l+GLTjr/butf8T38f8AhHP7c/yOPh/9kvwf/wAI38B/B/7j/iYa8dU8T3nb /kO9v/Cc/sP/ADzXrH/BWjxt/Y/w58EfDmxg+06h488YfYrPOemhaLx2/wCo4McV1/hXw3/wivhf w/of/LxoOj6Xovpn+wtG5HTH16V0YX/c36nPit16/ohZ4Z/+nb9Pf/PGM9q5+aC4MVv/AJ/+t7dP 04ruJrOeH9x+I9Bxntn/AOvWRN/qT9B/KoIPnX45axP4V+HPjDVf+Pb/AIk/2Ky9+nPr/n3r8ONe m87xbcdRb6Do+l2X/cU4wOR0/wA9K/YD9szWP7N8EeHtD/6D3iQ3v/cL0LPP8+3H61+MEM095Lc3 3W417xIb38O/69h69q97Ltb9n/8AJIyxOjT7P9EfQ/hv4nf8Ir/bHjHVbH+0tYuvDf8AwjH2S74z /wASb8vp74615B/wvn4gemif+CfRf8KTx5qXk+HNH0qD/r9veMH/ADwT+PFeP+f7fp/9eppYbCtP W2uvTs+3r/4FfyWFXEK6Wmi0v/w6/r73/WRR5Iml8+efOP8AIH4e3bPaj7H08g/j+XQAfTt6c9qT yfOl/wBf1/XH9PT07+lZnYL5P73/ADnr9cde/wCmK8P+OUPk+F9P7/8AFSaX+nP+eO/WvoDyf3X+ cdPrnp3/AEzXh/x4hg/4RfR++fEmlgj2/wA/z4rBbr1X5gfO3gmYebxj+f8ALH9a+sfDnf8Az/dr 5X8If8u/4/8As1fUWg/6q2/z6V70dl6L8jnPXtH/AMf/AGavQLOYeV2/l9OP8k/UGvN9H/x/9mr0 Cz7f8CpnOdBDN/n/AD+oz7g11FnN534f4H+dcPDN+9/H+f8AX9B0rqbOHP8A18Z+nP49cfhXQBrz Tf5P+fyGfUk18b+D7z+2PFusar/z86xql6P1+n5cdK+kPGGsT6b4b8QXwn4tdH1T8sf5/p2r53+E tn/kf4Z+nb146VzgfaHhWLyYrfJz9Px/D/P5+waZ/F/n1ryfw1D5MVvn6npz9O3f616vp3+qH0/r XQB2MM3+f8/qM+4NaEM//Lc+3f8AmR+IJ/TrXP8An+36f/Xqx9s8nnr+n4/hjpj37ZroA6CGb/P+ f1GfcGtDz/b9P/r1y8M3+f8AP6jPuDWh5/t+n/165wOghm/z/n9Rn3BrYhm/z/n9Rn3Brl4Zv3v4 /wA/6/oOlbEM3+f8/qM+4NAHQQzf5/z+oz7g1oQ3n+f58fyH4+9c/DN/n/P6jPuDViGb/P8An9Rn 3BoOc2Jpv8n/AD+Qz6kmuf1iITWtweff+Xr7f5PXYhm83/P+eOvas/Uof3Vx/wDq5/z69PegDxDU oYPsGoQ/9vv2vv8A/r/p7VP8JdS8nWfEGlTj/l8+2/8Ag9x+ftx/jVfxJiEXEEHP2rr2756/Uf5F cf4J1KCz8eaeP+gpZ/Yr3+h7evP+cgH1BNN/k/5/IZ9STVfz/b9P/r1Ym/cy54x07/rx/wDWxxxV fz/b9P8A69AFeft+H9asef7fp/8AXrPvJu/0/wDrAj+Rz/Wq/nfuv846fTPTt+uaALE03+T/AJ/I Z9STVfyPf9f/AK1FHneb+Ht/npn26/kAV5of8n/P5HHqCKx7zv8A8BrXvP8AVD6H+ZrmLyacRfv/ AMP/AK3f+fTp2oOg5fUph5XH9f8A63+fpXn+vTdh+Y//AF/pj2ruNSm9fw/+sPy6/Q+tef8AiSaD 7L/1EOM/57/579eg5zxfxJN/x8Y+nH6f/WI/LrXg/iWb979n6dfTt6fTB/ya9w16YebcdP1/yP5D p2rx+y8ibxHp/n/8e4vPzP5nP/1+K5wOH8SQ/wBg6XcCf/j4+2/beh6df8//AFq4+HxVfXkun6Vf f6Vo+l3n20Wlp/0Fddz6H/69dx42mgvPEdxPP/x72tn9iznr/Pn/AA+mPB4dSnm17UP+Pb7P9s9e vt3HB9658T1+f/twH6kfCWbSrPw5cT30/wBmuLr+zPsf5e2efqK9ogvLG8/cWP2k2/8AbH2Lngen 069ffpXD/BOGD/hHNR86f/R/sel/56/09OK+gJoLGGL9xP8A6R/x5d/br+Xpj8a+CzL/AHr5r8on 1uX/AO6P1X5RPzH/AGqPgzofxC+Jfwn8Y659puR4E/4Si9s9J/6iuu/1/wCJGOPwo8meaIQT9ex5 zj6f/W9vr7f8WtS0rUvFuoWNjP8Aaf7Ls/ttld9vp9TxXjE37mXP+jenp/P/ADivQwu79f0Z5uJ3 Xr+iOfm/cy+RP/x8Z9vrx9P888Vn3kP7r/p4yP8AP88jPr0zXUTxf8t8/U/kP/r8e1Y95D5P/LD1 47//AK81BB+Q/wC3V4q/4n/2Hj/iQ+G+PfVNd9c5r877PTRNrOj6VB/zC7Pnr0z6e4/Hp3r6Y/ai 8Sf8Jh8UNYg8/wD5CnjDn/sFaF64ry/wTo895f8AiDxJBB9p5/0P7J349z0r38N/suFu3u9uutv+ H/qxlit16/ojwfWJp5rq449c9fX/AOtn/wDVWP5U3p+g/wAK+2Phj+yL8Rviddefq2lXOiafdf6b efa7P/iZ/wBl/wDuvj3Hf1r6Z/4d7+G/+hjP/g3P/wAzdeilovdtt09P+B+HkeYfrP537r/OOn0z 07frmq8MPkygfT/9fb/69E155Muf5/8A1/pzjrn61Y+2ecbfH9P/ANeOn4V8+fUFiaHyv8/z9+ne vD/j/wD8i34f/wCww3/pn16vaIZv8/5/UZ9wa8H/AGg5/J0Hw+PTWdU/H/iS6/z6j8/58cEd16r8 wPB/BMPr/n/PP+cGvpjQv+WP4/8AstfN/gn/AJd4CfwB/LPP+fXpX0RoM3/Hv+ufw7/l19j619Lh vhX+FflE8c9g0f8Ax/8AZq7iGb/P+f1GfcGvP9Hm9f8AP1x+Ix9R6V3EM3+f8/qM+4NdRznQQzT+ b9fx6emef0zXQWc0/Ttn/Pt+X4kc1x8M3+f8/qM+4NdBZzd/r/8AXGP5nP8ASugDz/4tXn2PwbqH /Pxdf2XZH06/n/Xg/hx/wrg8mK3H1H8/8M//AK6PjZeY0bR7Ef8AL1rGf8+nX6n2rY+G8Pk2tv8A rz+A/WucD6o8Nzev+enXH4ZH0wa9Xs/9UfoP5ivKPDcPr/np1x+GT9MCvULPt/wKugDoIZv3X4fy /p+p6VX8797/AJz1+mOvb9cVXhm/z/n9Rn3Bo8/2/T/69AGxB3/H+laEM3+f8/qM+4Nc/DN/n/P6 jPuDViGb/P8An9Rn3BoA6CGb/P8An9Rn3BrYhm/z/n9Rn3Brl/P9v0/+vWxZzd/r/wDXGP5nP9KA Oohm/wA/5/UZ9wasQzeb/n/PHXtXLwzf5/z+oz7g1sQzf5/z+oz7g0AdBDN5X+f889e1F5N50XQ/ nnP/ANeseGb/AD/n9Rn3Bo8/2/T/AOvQB5h4qhPm/wCf/wBf0z1/GvLteh/4RXxH4fn+0fabi1vN Lvfz/wD18+3PavYPEkHndxz7f544zXzf481ITX9vP/x8/wCh8+n+c496DnPuCaczRW8//P1Z/wCc f/X/APrVn+f7fp/9esjwrqUGseEtPn5/0Wz/APr9v/rntU/7r/O2g6Amm/yf8/kM+pJo8791/nHT 6Z6dv1zVfz/b9P8A69V/P9v0/wDr0AWPP9v0/wDr1saP9nmu4IJ/+Pc+w/z9f5cVy803+T/n8hn1 JNH2zyf9Rxx/ken+QOlBznUa95FnqFx5H2b7Pz0Az09vTnH5euPN9SvPO68f5/Prz6ZzjmtiaYTR eefr+P8Anj/Oa5eabzv3HHc+np+Pf/Gg6Dn9SvPb6Z/r+h49h7V5vqU3/Hxt/wA/p+hHoRXqGrzQ Qxef5Ft1/wD14/x45x1rx/Xpuw/Mf/r/AEx7UHOeX+JJv+PjH04/T/6xH5da4bTbOD7XcGe3+1XH 2MfY/WwGP6/y9ea6nWJv+PjA+nH19f8ACvN5tYgOjahfQfaf7Q/4/dH+yWZ65+n+HWgD5/8AHuvf Y9UxBP8A6RdXmqfbfTuenf8AlXn/AID8+81nz/I/cXV59is7s988ev8AnmtDxXo99qX2i48i5/4/ Mf8AHn+Q4/CvR9B0f+wZvB+hf8vH/Ia/8op+v/1s471z4ppXu7b76fzBZ9v6/po/Tn4Vw+ToNxBz /ovX9M/T9RzmvQNY1L+x9G1C+6f2Xo+qXo4/Hv8Ar09q4f4bjyPDlx0/4/Pf/oCgjjnHfH+RR8T7 zyfCWoQZ/wBI1S80vRf/AAfa17/59e+PgcRrjNNfef5W/M+sw6tg9rbflr/wT53hh8nxJ4ggn/0n 7L4b/T/iQfy/rWPNDz5/+k/Z/wDP9enb161Ys7z7br3jjP8Az56pj/wdfXP4/l05seT+6/zjp9c9 O/6Zrpwu79f0ZmY8Om/8e/Hpz/8ArH4/z71w3xIvLfw34X8Qa5P/AMwHR9Uvc9u3Xv8A5Fes3mpa Vo9hcX19PbW1va8/a+//ANfJ68c15PrOu/DnxVpeoaV8QP7b/se6z/xKdJ/4lv28/wDUc1zPX2/n zXo4ZXt+H4nH9Ytpt5W/+1Pwf8E/CXxj8WvFuoX2laUfs9qf9M8Q3f8AyDLDn/iff/WHNftR4P8A 2D/hz4J/Zut/ib4V+za54o/tj/isPsl5/wAeOl67/wAgLRc9v+QHrnavQPG83wy1jQtP0P4SaVon hzT7Wz/5BNp/yE/xPb24+mK9g/Zd02D4hfD740fAH7d/wjfiDxl4D1TWvDd3/wA//ijwL/b3jzQf +5i41zwv2/5D/avrcLh7pfW7dLO2+33+Z5l/rW70v/Xnu/6b1+X/AAH4qsfhva6x4c0qx/tq38UX nhe9vLPVv+QZ/ZehcDRT/wCDz1rZ/wCFg6F/0I2if+BdeXalpv8AYOn/ANh/8e3ij/l8u7vjrxg9 /wCX5V5h/Yet/wDQV07/AMHBr3klZWSt0/C35L7kcx9XxTdfP+mc/wA/5c/lVjzoJpR0Gf8AP19e uf8AHPhhPm3H/wCv/Dvznt9KsQwz9e3/ANf/AB9sevUY/KD7A0PO/wCWH47f1xj/AD9O9fP/AO0J Ncf2X4XguP8Aj3/tjVOvvouvn/6/59MiveLP9z9o/cZ/6++mD+uT/nqa8I/aD/5Bfhj/ALC+qf8A pmassLu/X9Gc5494H/5dq+kNC/w/pXzd4P8Avj619E6P/qT/AJ719Zh9vl+kTxz1DTZv+Pfd/n9P 0A9Sa7iGb/P+f1GfcGuH0eb1/wA/XH4jH1HpXUQzf5/z+oz7g10nOdRZ9v8AgVbHn+36f/Xrl7O8 /wA/nnj8/wBBmtDz/b9P/r0AeH/GC8+2ap4Xsc8D+1L3r/nv+uR9PWPAcHk2tt+XbHt09h+H5V4f 8QpvtnjzT4Oc2tl26fXue/p+le7+CYfJit/y4x+P/wCroORQB9E6D+5/+tx1/l0/x716DD/qR9D/ ACrzbQZux/M//r/THtXcQzf5/wA/qM+4NdAHQQzf5/z+oz7g0TTfvfx/l/X9D0rPhm/dfh/L+n6n pR5/t+n/ANegDYhm/wA/5/UZ9wasef7fp/8AXrH8/wBv0/8Ar1Yhm/z/AJ/UZ9waANiGb/P+f1Gf cGtizm7/AF/+uMfzOf6Vz8M3+f8AP6jPuDViGb97+P8AP+v6DpXQB2EM3+f8/qM+4NaEM3+f8/qM +4NcvDN/n/P6jPuDWh5/t+n/ANeucDoIZv8AP+f1GfcGiab/ACf8/kM+pJrH8/2/T/69WJpv8n/P 5DPqSaAOf14edFcdf06dfy/zjtXzf4kszNdW8B5HHHf/AAHX1r6Q1L/Uz/57ivnfxL+5us/8vH2z 6+nbt/8AX5oA9o+CesfbPDlxYz/8fFqf/r5zx+H5d69I8/2/T/69fO/wT1iez1TUNKuJ/sw6f5/X +te4TXnky3EHv7//AKvp7/oAWLybv9P/AKwI/kc/1rP8/wBv0/8Ar1Xmm83/AD/P36dqz/P9v0/+ vQBofbPf/wAdomm/yf8AP5DPqSaz4O/4/wBKKACa8/z/AC4/mPx96x5pv8n/AD+Qz6kmtCaH/J/z +Rx6gis+ft+H9aAOevP9UPof5mvMNY/w/wDZa9AvNY0r7VcWM8/2a4tbz7Ef9D6Y4P8Aj0/Tii88 NwXkogg1XRPtPpeaxo2m/j/xUHv/AJ6U/rDXf+v+3jnPmfxJZwTRXFvOP9HuQf8ARfXp+teH6P48 1zTYrjwrPqupfZvC97/Ylnd/8xP+yv8AmBdefb86+wNf0Hwro/2efXPFWif6VwLS0/4mWT2/rivL 9Y8N/BabXp9csf8AhP7nWNV0j7F9ku9H0bTdMv8A/wAuTj09fxrmxL3afdpr/t7VAesfsx+G9D+J 3ijWND8Rj/j68N/8fdpZ/wBm/wDMa/4kWf8AH19q/SDwT+w18D9Y/s/VZ9DudS1C1/5e9W1j/kH5 68Z/rj+Vfnf+yL/xTfje4gg+zWx1T/l0+2f8TOw0vQvb/Pt7fvR8Pby3823/AOnr8P5f565r8d40 xObLFWWaWXS10lotLa9vXttc/SOEsswmLwl8Yu1trvVdflr/AMOzxf8A4Y/8D2Vp5GkwXOm/9et5 /n9eOv0Pj/xC/YgvvElhb2+leI7i2FrrGl61/pdn/wAf59D+ucdq/TiGH/P+f1OPYCrGP+mH6/8A 1q+RwuIzbC/8zXmeja+52/F3fTrtd/W4nLcEkkrWt2Vraa+fb8T+c/xV+w38cPhvF4w8VGyt/Emj 3VnpdlnSbz/iZ9dA/wCYH9fTtXzveTWOj/aINVn/ALNuLXP2y0u+nX6/05/n/VBqWm295a3FjP8A 6R9q/P15z35x16etfJ/xa/ZL+GXxOhuJ9c8OWttqF1/zFrSz/wA/5Htivtsszu3++a6L57fm/l5n yeKyXW+D7rf5f1+J/LvrHiS+8Yap/as8Fz/Y+l8eG9J5x7a1/Qevr6eb69Z394biDyLnvx9k/wA/ X8ueK/djxV+wT4q8K6frFj8MvEeiW1vqn/H59r8N6N/aZ9f7D1z/AIRv/hJ/D3XjBr53/wCFG/tC /De1/car4k/se1vP+QTaXnPXHv8Al7fiftstzLBve3lqtH69dHufN5jlmL2Wneyuum66fgflf4D+ EvxG8bS+IZ/Cs1tbah4X0f8AtoWl3/bOm6nr3/E6/sH/AIkf/g87da9w+G+peOdH1nw/PY6rqVt4 o0vWNLvftekf8hQ6p+XI7dPbFfrB+zfrHgDUrrxxB8XPiN4k8Naxa+G9LvfDf/Cb3ms/2ZqGqDWv +J7ouh/8I/8A8i//AMU5nHr7Cvi/9q7xVfeK5f8AhFPhzpWiaJ4PubP/AI/NJ0fR9N8Ta9/2HNcH /FT/APFWd+fX8PrMNi0+qfz3XTzt8vTpb5vE4WS1V18n5Pp8lq+2vQ+B/jx4qsbz4oeOLjw5qv8A aVxqfiTVL281b/kJdda/5Amhn/6/X8K8O8rVPb/vkf416DpvgOey1m4gngubm4tf9N+yEfj04/z0 xzXQebD/ANAP/wAnT/hXqfWfP+v/AAExnuvT9WfQH/Xef/RyP5/5/A+vSrH2yD/r56ZHGfy+v9fw z4dNn8238+f6/wCmeg/LHX35rQhhn69v/r/4+2PXqMfmZ9aV+YYfcfh1/r+Ryexrwf4/Q/8AEm8L z9/7Z1Qf+UUD+f8AnFfSEEX/AC3z9CfxH/1+fevn/wCP1n/xTmj/APHzj+2Dke39i/8A6/T9OHHd eq/MDwfwh/y7/j/7NX0Ro/8Aj/7NXzx4P/1Vv9R/MV7/AKR/yw/z6V9LhvhX+FflE8c9Q02b0/H/ AOuPz6fQetdRDN+6/D+X9P1PSuP02b/j33f5/T9APUmugg7/AI/0rqOc6CGb/P8An9Rn3BrQhm/e /j/P+v6DpWPDN/n/AD+oz7g1Y87yYvy9O/X8evTn3oA8H1ib+0viDrE//PqNL6fhzx6+4r6Z8K/c tvoa+VtMm+2eLfEE/wD1GdU6gf5Ht/hX1D4V+5bfQ0HQe76PMfK8j+fb29uP/rdK6iGb91+H8v6f qelcPpsw8rn+v/1/8/Wughm/z/n9Rn3BroOc6jzv3X+cdPpnp2/XNHn+36f/AF6x5pv8n/P5DPqS aIZv8/5/UZ9waAOghm/z/n9Rn3BrQhm/z/n9Rn3Brn4Zv8/5/UZ9wa0IZv8AP+f1GfcGg6DYhm/z /n9Rn3BqxDN/n/P6jPuDWP5373/Oev0x17fritCGb/P+f1GfcGgDqIZv8/5/UZ9wa0IZv8/5/UZ9 wa5+Gb/P+f1GfcGtCGbyYgfp/wDq7f8A16DnNjz/AG/T/wCvR5/t+n/16z/P9v0/+vViDv8Aj/Sg DPvJu/0/+sCP5HP9a+f/ABhD50twYP8APHHH+e/XIr6I1LyIf3/H/wBfpxjp+NeH+MB51179P6/T 0P8A9egDj/Ad5/Y3je3864+0XH/L5d/Qf/X7fj3r6w1KbF15/r/n8enT3718PaZefY/F1vNj/l8/ xPqK+wZtS8610+fr/ofT8/wz+VBz4bpfy/8AbTYmm/yf8/kM+pJrHmm/yf8AP5DPqSarzXnne35/ 0qv5/t+n/wBeg6DQhm/z/n9Rn3Bo8/2/T/69V/38PqOfqQQf8+vT2omm83/P8/fp2oArzTf5P+fy GfUk0nnfurnz89Ppxz/h+vrS+d5v4e3+emfbr+Xj/wAWvFX9j6f/AGHBP/pF0P8ATP8AsF/n9M/l 60Aefal4w+2a94ogsf8ARra7vf7as7v66LoGg/n/AMSI/TtmtHw1rFv4k+0aVqs/2a4urPP9q2nP +RjPX2+leX+G7OfUpriC3H+kapefYv8Aj8/+v/n9B9Uab8Dfhz4Pzfar8VNN8W3F1/x+f8IneaNp v2A+v/FQf8VPz1H/ABR/g7Brzl/tPa6WvyfX+v8AgvEb/P8A+SPJtY8Bf2P9o+w/ZtSuP+fvVu/4 Z/riuIh03VfN1D+1P9G+y2f+h/6GP9PH5/8AFP59f/119MS6x4HhuvI0rStb1vT7X/Qvsl34k/s3 U+uOn/CN/p79K8n8V6xbzapqHkeHP+ES08f8ef8AxONZ1LU7/oP+J53/APr9OlGI0Xot+uzEa/7P fhuCH4oW+uW99c3NxdaPqn+h3Y4/zxz+fSv3S+G+pfbPDmnz/wDLxa9sfr+vr7+tfi9+z3DfWfjf TzcQW3+ldLv00v8AsXX+n6eme/Ffsh4Dh/se/wDs5/499UtP9D6n8OP889K/JeLcR/taVtls+u2y 339X27P9R4T/ANzh6P8AJH2Bo/76wt5/X/Pv0/L3xVjyfK/H3/z1x79Pzz/AY86wuIJ/+XX8R9fr 9K6CaHyv8/z9+nevkj3zl7yH/X/p/wDW/Tk/Ws+b99FnnPTt+vH/ANfPHNa83+uP1H86oQ/6q4g6 /wA+v4jr/wDqr0AOXms/O9vy/pXL6loNjeRfv4Lbv7f5PX+prupv+Pv/AD7Vm3kPb6f/AFiT/IY/ rXq4ZvTV/wBX/wAl9yFZPdL7j5v8YfBPwbr32j7dodtc3B/6c+nH647enpmvlfx5+yXod5FcT6HP c6bce+On4cd/8ewr9GJof8n/AD+Rx6giuX1KH1/D/wCsfy6/U+lejhsyxmFaTvvtfbX8dOq/E8vE ZZg8VpZdtrfd07aH85/xs/ZL8caZf6jfQf2nc3Fqf+QtpP5+47fjXx//AMKN+IH/AEHbj/wm9Xr+ pjUtHsdS1TUYL6C2/wCPPg+//wBfH/6ia5f/AIVf4c/58dN/IV9BRz/GUY8r8mvvT/Tu/XqfPVeG sJzaa9Fu+qf5+e9kfzz+T5v4e/8Anpn26/kQw/veftPt9fT/ADkenHFaGYPNuP8Al56+n4nJ/wA9 K0IYfOjP7j7N+OPx/wDrfzrqPNK/k5/cY+zfav8AOe/X6e/bNeH/AB+h/wCKW0//ALDH4f8AIF1/ 8fxH1r6Amh/dfh/L+n6nrXh/x4s/+KSt+n/H59ee/HP5+1OO69V+Zzny/wCFf+XfyfbOP0z/AF/D Fe4aP/j/AOzV4f4X7fj/AEr2jR/8f/Zq+mjsvRfkeVit16/oj0izmHldv5fTj/JP1BrYhm/z/n9R n3Brl4Zv3X4fy/p+p6VoQzf5/wA/qM+4NdJyHUQzT9O3/wBf/H3x69BnQmvP3P8AqP8ADj9f6/jX Pwzf5/z+oz7g0TTYiuOnt379un+fqKAPJ/Cs2dZ1C46fatY1T3/HpgY/+uc19QeG/uW3+exr5P8A BM3nS+f1+1Xnbt+Hr+dfVHhub/j3z9Of1/8Ark/l0oOg9o02YeVz/X/6/wDn610EM3+f8/qM+4Nc PZzd/r/9cY/mc/0roLObv9f/AK4x/M5/pXQc50Hnfuv846fTPTt+uasQzf5/z+oz7g1j+d+6/wA4 6fTPTt+uar+f7fp/9egDqIZv8/5/UZ9wa0IZv8/5/UZ9wa5eGb/P+f1GfcGtCGb/AD/n9Rn3BoA6 CGb/AD/n9Rn3BrQhvP8AP8+P5D8feufhm/z/AJ/UZ9wasQzf5/z+oz7g0AdhDN/n/P6jPuDWhDN/ n/P6jPuDXLw3n+f58fyH4+9aEN5/n+fH8h+PvQB1Hn+36f8A16r+f7fp/wDXrH8/2/T/AOvR5/t+ n/16ANCa8872/P8ApXk/jab0/wA/54/zkV3E03+T/n8hn1JNef8AiryPsv2jvwM9Mev5fT0PNAHk +vQ/Y7/Rp54Ps1x+f/1+mfrjpX1Bo955+g6f/wAe1z/nOP8A65zXyP4w1L7ZqFv5H/UL6f8A66+g PAd752jW/OP9D7/07HB6cc0HOegTTf5P+fyGfUk1Xmm/yf8AP5DPqSar1Y87j/p3/Tp9P8mg6CxD N58R/MD+XX/Hv60ed5/b7P3x/Ttj/I7VnzTeV/n+ft07VYhm/wA/5/UZ9waADUtYg0HS9Q1Wf/j3 tfT/AKCnfj1J+nNfD+va9faxf6hfX032m4uv8+4x9a9w+MHiT/j38OQT82n+m3n/AGFPT3P4f8x8 V872dnP4kv8AyIDkn/j8z/y4egx9f1HPFedicVbW9rW8v+B26dvl1YbDX876fp5af166HhqHVdY1 TT9KsbG5ube1/wCPz7IOf88n6+xxXceJB4j021t4LGfUtMt+gu/sf9pfrk8jH16Zr74/Zj0zwBD4 Ot9K1Wx/4mH/AAkn/IX/AM8Y/rX6AXnwf0OaX+1dKsbf7R/x+/ZLuz/4ln0HH8/6V+bR4sxSxmZ4 NOzbslfba1lr+H4H0q4bX1NYt21fbponbT9OvmfzzeFbz4geG9Zt9V1XQrnW/D91/oV5d6Tef5/z 6HmvvnxV4b8OXlhp/wBhntv9Ks83l3djB+vf/DjpzX6kaD8N/hJ4kiGla54A0TTdY4+2c/2b7n+h 6d+9fP8Ar3wN8OHVNY0qx0v/AJfNU/0T8uf517eFzvFu31vbRJr5dvKx5mJy7CYVJNau2i3Tdu97 6p99vM/P/wCHsM+m/EvwhBY/Zv7PutY1T7Z9k/7AvtnA/wAjFfsRo8M83hzT76D/AI+NLvD/AE68 dv5/Q1+f8vgOx8N+MtAggguba4tbzAF31/Pj355/Tn9MPh7Z/bNB8ifr9jP+evX/APUenH5vxrif +FbK8XspatXaV7RWtvN6/qff8JYZ4XB9LNdbvW6t6+VuvnoekeCdYn+1W88H/L16f4e2P549a9Yu /wDlv/wKvn/R5v7N1S3sP+nz/P8A+r6fWvoCabzorc9vsfv/AJHfpXi4fVX7r/I9vE2+tRttrt/2 6cvN/wAu/wCNZ8//AB83H4/zNaE3+tt/x/8AQqz7ybyb+39R19OP8+3869vDYm+n4dP6v87/AIYm PeYhl/1HA7j6Y/8A1Y6c/Wq803+T/n8hn1JNaGp/w/59K5+ab/J/z+Qz6kmvWWytt0Az7zv/AMBr j9Y/w/8AZa7C87T/AF5/PPf6n8ua5fUoOs+fr/M8f4e1dAHl8P8AyGbj8P8A0GtjyPf9f/rVj6bN /wATPUPI6fbPf2/D/E+ma6f7ZP8A89rn81/woA/mo8mCGU+f+X2P2/r+NE03k8+R/pH+fTsMZ/Hj GOD/AD/pn9f/AGWtj9x5VvjH2bHP075x/nHSvsD83CL9zF5H+fr+X4HtivF/jl/png24/wCfe1vP x4+mfy+hr3DzoM2/kQf4+vH17HP9K8n+MFn/AMUHrGOn6/5P04Hpjhx3XqvzOc+L/Df+u/76/lXt Gj/6k/5714v4c7/5/u16xo/+P/s1fS4b4V/hX5RPHPQIZv8AP+f1GfcGtCufg7/j/StDz/b9P/r1 1HOdRDN+6/D+X9P1PSq95N+6uMY/X/J/kfwqvDN/n/P6jPuDReTf6BcZ/wA+2R/LHqPSgDy/wV/y 7f8AX4P/AGavpjQZux/M/wD6/wBMe1fM/giH/j3IP+fp/wDX/wAK+iNH/wBSf896MN0+X/tp0HrF nMPK7fy+nH+SfqDWxDN/n/P6jPuDXH2c3f6//XGP5nP9K6CGY57/AGj/AD+n8s8+/Qc50H2z9104 /X6/l2/TFEM3+f8AP6jPuDWP5/t+n/16sQzf5/z+oz7g0AdRDN/x7/5+vA/X8vStCGb91+H8v6fq elc/B3/H+laEHf8AH+lAGxDN+9/H+f8AX9B0qxDN/n/P6jPuDXP+d5X4+3+euPfp+djz/b9P/r0A dhDN/n/P6jPuDWh5/t+n/wBeuXhm/wA/5/UZ9wasQ3n+f58fyH4+9AHUfbPf/wAdqxB3/H+lc/DN /n/P6jPuDViG8M8X+f8A9f19TnpQBYvJu/0/+sCP5HP9a8+8Vf8AHrc/UfzrqZpv8n/P5DPqSa4/ Xv3sVzbg/wCc+2ev4fSgDxe7024+y3F8e+PT8f8A9fWvYPhveedpdvB/T/Pp/KvJ9S1K4/su4t/9 GHX/AB9QefU/412HwrvP9Ft8/wA/8gnI9z9eaDnPoD/ll/n+7Veab/J/z+Qz6kms/wC2f8u/65/H P+T74qv5/t+n/wBeg9AsfbPf/wAdqxqWsQaDpeoa7P8A8e9rZjjuT15/+t2rH/5bf9O3/wBb8+n+ cVx/jCH/AISS/ttD+3fZtP0vR/7avP1/sLof+w53571zmOH+JX097X743PB5v7V8VazcQQf6T9q/ 068uyP8Ajw/L/Pt1r6g+Ffwr0qbQf3H2n/j8/wBMu/8An/6/5/8A1c+X2dnBo9h5Fif+3vj/ADn8 PSvsj9nv/TfBtv55P/H5qnPvz+oJ/Xn1r8d4+zvGZVhV9Tbd2vwtfun5L01PvuG8twmLxeqb0Wnr a/Xbz6Mx/CvwZg+Huqahrnh2+1L7fdH/AEy0u7w/6f8AzH+fXp+lH7PfxUg8VaNb+HL7/kIWvFn+ f/IF/Hj+lfO95ZwS2p/5+Bj6Y9P8+vSvD/BPiS+8K+KLieCcfaNLvP8ATB/0D+n/ABOv8nj1Hb8c y3M8Zi83/tdtW0bXfRLbT8fLbr+kfVcGsH9T1Vtb2W6136u//Dn7IXmj2Opf66D/ALfP68f1ry/W LzXPCuqazpWh3tt9n1Q/bftd3Z/2lqnT/oOfn0x7V6B4D8VWPjbw5p+qwf8AHx/y+f8AYUH9PU+v euX+LWmwf2Xb6rB/o1xa3n2H3/znjr/9f9ry7E/W8IsXhWr2XNfs7a9P6SPy7OsNbGK2tvXy0frb zXl1Pi/x5DB/wmWj30EFz9oN5/pgyO3+fbp6V9ofDGb/AIldv+v0/l169x+HPyP4kvBef2PY32lf abi11jSxZ3f09e/1z757V9X/AAs/5BkH0/8AZRXxPHev9l9fh/8Abbn1vDSsorprv6Rtf5HoN5DB NrNvOebi1+v0Hv1zz717RZw/6Lb/AKd/y/znt3rw+aYHxR5H6n8fw+n19a9w02b/AEC2z+HP8hj3 6H+Qry8J8P8A26vzPRxWy9P1Rz+pWfv9M/1/Qcex965/WIfI+zz/AK9f8n/PSu41geTFbnHr65z+ P6fn7Vy+pfvrD/r16D1/P17nH0zXu4ff5/rEyM+8h86LJ6/5H9O3f264/nfvf856/THXt+uK0OJr Xvn/AD9PT2x9K5/91/nbXpYbE/d/X/A69tbbBWm/1x+o/nXIalD/AMfG3/P6/qT6AV1F53/4DWBe TfuvI7/4f/q/yBXpYbr6fqB49ZzH+2dQgPTHP4d/X8fWu3/s2b/p2/8AAzRv/ia4izh/4qO49Bed /T6/5I6e47ius5z+Z/yfI/fwf6Sf+vP+Q/yc9T3rQ8nyfs/7gdsfn9cjj9MmizhHm3H7jn8+fbr/ AJ9a6D7HbzZz9p/D/wCv9fTvx3r6g/Pzn4ftE37jt36HPvXH/E7TfO8B+IPP72ff+v5c/wAwa9Qm s54v3Bwf9N9Pp/Ouf8YWX9peEvEEHkf6Ra6Pqv8ApZ+v+c+v5U47r1X5gfnRoP8Arj9D/OvXtO/1 Q+n9a8w02E+bz/T/AOv/AJ+ten6d/qh9P619Lhfgj/hX5RPCxW69f0R0Nn++6dv6+nXPfP6Z4rYg 7/j/AErPs4e31/8ArnP8xj+lbH+t/wA4xj8/X36/l1EFiDv+P9KNT/49rn8P5Gq8Hf8AH+lF5++/ cc4P+ePx+nsM0GEd16r8zz7wTN50Vv8Anxj8f/19Dya+gdH/ANSf896+b/BX/Ht/2+H+TV9EabN+ 6t/3/wCX/wCod/y9qML9n5f+2nTiNo/L/wBJR6BZzDyu38vpx/kn6g1sQzf5/wA/qM+4NcvDN/n/ AD+oz7g1sQzf5/z+oz7g10HKdB5/t+n/ANetCDv+P9K5+Gb/AD/n9Rn3BrYhm/z/AJ/UZ9wa5zoN iGb91+H8v6fqelaFY8M37r8P5f0/U9KsQzf5/wA/qM+4NBzmxViDv+P9Kz4Zv8/5/UZ9waIZv8/5 /UZ9wa6ANiGb/P8An9Rn3BrQ8/2/T/69c/DN/n/P6jPuDVjz/b9P/r1zgbEN5/n+fH8h+PvViGb/ AD/n9Rn3Brn/AD/b9P8A69WIZv8AP+f1GfcGugDYmm/yf8/kM+pJrl9S/fRXHX1/z7evHvjHFaE0 37r8P5/0/UdKx7ybv9P/AKwI/kc/1rnA8X1L/j6uIOnX/I4/Ht6YrqPhvN/nd+JP/wBf8PesfUvI +1TwdO/r34//AF+laHg//iW61qEH/Lv9s+n09uMfWg5z3Dzv3txgc/4fn/XPSjzv3v8AnPX6Y69v 1xVf7ZB52Pwz/wDW9c8/1qvPeQeb7/19/wDJ+veg6cPv8/1ibHnYP7j/AEkf564H+cV4/wCKv9M8 W6x+/wD9G0rR/C464/6D/wBDXpE155Nr53/T59Of5/h/+uvJ/FUIvPiD4X8j/RrfxRo/2O85/wCY poWtf29oX/p91z/OBXJmbawum9vx9068Mv8AbYrpzRX4s7DUrP7HF5HH2f7GR374z0zjsK+sP2af 9M8OeR/0+ap+Xc+/v2H0r5n8YWc8NqMf5zjpx+nvn1r1j9nXx74c8K6NrF94j1zTdE0+1/028u9W vP7N0zj+X+ea/DePo4zG8P2hHmlfRJNyvola2vZ/nofp2RuOExS5mktG9bdtLvp99u5933n+qH0P 8zXwx4k1ifTfiNrHkXH2a4urzP6dx2/z9a8/+M3/AAVi/ZJ+FcVxY2PjG5+JGsD/AJhPw9s/7S56 /wDIc/5FjHb8ee1ef2fxOsfjNoPh/wCKmlWNzomn+PNG0vxPZ6Tdj/jw7jH8847c+lfn/CeR8RYR LF5xlVk7WuraaWaVr6rbT/g/bV8zyjF2wmDactPN3Vnr13uv1XT9gP2RfiRPNLcaVewC2+1f6FeW nP8AoGqH/P8Anv8AWGv6lB4k1C4sYP8ASdPtc2XTPpx/+v8A/V+a/wCxz4x/tjVP+fbV7X/QtYOP +oL/AMhr/wDX1/l98/D3w3qviS60+x0qcf2hql59hs/9L/s3Oqc9hnpX6Rw29c0wb0tZpX22TS9L aX36n5xxErYxYtbKy6q+3T0v53vZnj3irTf7Nv7eC+/5dbz0/r+Xt9BX0B8MYYJovI88/j+nHH/6 q4f4keFdcs9e/srVYLm21C14u/tdn7fl3/CvQPhvDcQ3VzBOf9I7/wCR7fSvE4uT2s9Fpda/Z/4P 4n0mRtOKemq6bfC9vyOwmh/4rLtj05P/ANf/AA69ufYLO9+xy+R/y7/X649/p+XpXg95NnxRcT+f /wAvnp9fUfrz+dewed+6t/8An556/wD6uvp+debhv90j/wBu/qelicN/n6fjb8fXz6nWIfOi/wBH 9B1/z7d+vUVy0376wuYP89fywa7C3/48Lb8f61y/kz+bce/9Ppj+dejHZeiOA52H/j0/z71kzfuZ c8Y6d/14/wDrY44rsNN03zoriDn/AA69x+v654qveaPmXv8A5/Pn8epPSn9Z8/x/+2Og4e8/cxW/ e3//AF/yz+Irl7zv/wABr1i803916e/H/wBbr/T61y95pvT8s/5/Pn8D0rpw2Zfj1/X9Pn2sR9VX dfj/AJnzv5PkeI7g+2Px9OPU+3Fdf519/wA/A/L/AOtUGvQwWevW/X9Pz/w9enAzWh51l/z7/qa9 P+0v734h9VXdfj/mfzX2cM/lZHHHt+IPHTn6fQYroIYf3P8Ar+3+fy7+vSs/yZoZeMH7L09f8+nP 09tiCfyeD/x8f5/ya/RD8yLEPn+V5/n/AOkc/l7+/p78570TaZ9ssLixP+jfarP7F+vf/P4Us008 I8j/ACf5f4frSQzf6Vb/APLyenT9M+nr78cUAfm9eaPfaDr2oaXff8fFrefX+f0/L8K7nR4f3Vv/ AJ59Mdz+h/Wvq/x78K9K8bf8TWDNt4gtf+Xvv2PP+PX8OK8Ym+G/irR5fIn0q5ubfH/H5a/X3/Xv Xq4bE/Lp/X4de2t9H5WJ3Xr+iOf/AOPOXyPw7dP5Hn096sVYFnPD/r4Lm2uO/wBR+XPf+eM1Y+xT 5+0fh156df8APavSuu6/r/h195yFfyPf9f8A61HMMPuPw6/1/I5PY11H9jz3ktvPB/y9YPPJP+f8 etaF54PvobXz/I/pn/J/H65pgfP/AIP/AHPt/ph68dfTOPT+fTt7hps37q3/AP1c/wCfTp714vps P2O/1CA/8/n+fYY716hpsw8rn+v/ANf/AD9aWH2+X6RLxW69f0R6BDN+6/D+X9P1PStiG8/z/Pj+ Q/H3rh4bz917f5/I/hz71sQzf5/z+oz7g10nIdxDef5/nx/Ifj71oQ3n+f58fyH4+9efw3n+f58f yH4+9aEN5/n+fH8h+PvQB6BDef5/nx/Ifj71Y8/2/T/69cvZ3n+fzzx+f6DNWPtnnc+fjPf0/D39 c8ZzQB2EM3+f8/qM+4NWPP8Ab9P/AK9cvDef5/nx/Ifj71oQ3n+f58fyH4+9AGx5/t+n/wBeia8/ z/Lj+Y/H3rP8/wBv0/8Ar0QzQdO//wBb/D3z69RgA2PP9v0/+vWhDMPKuP8A9f8Ah24x2+tcv5/t +n/16sQ3n+f58fyH4+9dAHUQzDyrj/8AX/h24x2+tY803+T/AJ/IZ9STRDef5/nx/Ifj71n6l+5l /cf8e4/P0/8ArfoM9a5wOHvIZ7zWdP8AsMH2nUftn+h2n4enp/8AW4qvo808Os6hPfc3N1efbbz/ APX06j0HTrViHUr7R9et76xuP+Jha9v0+vv3596PJEOs6hz3/l/n9aAPSJ5vO+zz/wCf8nHt74qx 5s3r+o/xrP8AO/dW8/XH4/8A6+P5dulWIfPml6f5A9fbr2oHh9/n+sSx5MAiuPtE/wDLpxj/AOt/ nHD6lefbPFuj+R/zAbP7aM/9BT/P612F3+5l8gf6Lb/9On+f649ea8/0GaC917WL7H/H1eap/wCU L/iQ/Xnt1/SvMzL/AHX5L84npZbhv9tvvqvzXnbX7vJ9PWPFV4dS8Lif1/p9OnP+ea/nX/b28Sa5 P8brjQ/7V1L+x9L8N+F/sek/bP8AiWe/+c/Wv3p1LUv+JFqFj79ce/sfw/P6V/O9+2Zef2l+0R4w EH+k/ZbPwvZ56f8AMF0D/PPftXzWQcqxF6llFSV+a1krxb38j3OIHJYWKi3ddr36WvY+V/O838Pb /PTPt1/L+oj9lezx+zd8F/8Ap7+G+l/X/mP/ANen+Nfz/wDw3/Zd+P3xgltv+EA+Ffi3W9PusZ1b +x/7O0z/AMHnP/1+K/pg+Hnw31X4S/CD4P8AgDxHB/ZniDwv8N9L0XWLQ3h1L/iad/5DvXm8Z5lg sVjMrwWBzVLrJR12aVnbTy16dDp4DwuNjivrk721+JNJaLvdbfNn1h+x/D5Pi3WIJ7j7N9r6/wDg l9u3PtzwTX6ceD9Y1Xwrf6fP/wAvFre+2P8AI9znp6V+W/7Lv2iHWfEE/wDy8Wt5pf8An9f5elfq BZ6lBqVrp+qwQC2uP+Xy0H49PTp/9avjMsfLm+a67W+bTjf56M+hzrVy9f1ifZ/xg+Jv/C2dKuJ5 /A/hvTbi1xe2erWlmf8AhJhjjjW+g/DGTXgHgn/j/gnn/wCXuzJ7fTOcf5559e40eaCHQf8AXn7R 9kzjnn/9dZ/gjTfJit76cdfr+H+J449KXFVfF4u2KSWyVrX7JafJfJo68keEwmFV3r5762d9WtdX /Vjn/FWg31nqn24f8e90P88Z646fjya9Yhh8mXT4P+fWz9eR9P8APX9OH+J3iTSodF8j/l4+2dfp /j+Qrl7Pxtqs32eexsbm5/0P/nzGff8AXv75+niYXC4v6qr2V310fTe/Vb+SXU9r/el0u1by9Oz6 f8M9fp+H/VQfT+orIm/c39x/Tjr6/l79s18/zfE7xHef6iD7Nbn+nb/PPb0zx954x8VTSifz/wDS Lv8A59Pw+p/z610LLcY7Xk1e3TuNfVMLbVOWivt2/wCC9NPmfSEOsQWd/cQfz4/AD6d8duKz9S8Y aVD/AK++tj6Hv/8Aqz/gMV8nzTeMdS1D9/Pc8dc/nn/PT35qxN4Q1y8l/fz9/wCZz7f5/KuhZGtG 2ul/wv8An+KBYjBaO1no+vl5+aPeNZ+JHhyGI/6d+Ht3zx29OteT6l8YLDyrj7DB9e/+P+FY/wDw rfzv3/279evfPv8AXjr75pbPwHYw2tx58A+0d/8AP+PXr711YbLcIrO6urdOunX1W5zf2i+i/wDS v8zy7xt48v5pbe+g+zcevrz/AJ+tcd/wm+t/8/x/WvYNe8E2P2W4ggg/PHP1HT+f9a4j+zYf+eH8 /wDGvcWX4Sy0v52eu3+X9XZzrFYzqk/v7+nyPxPhmn8n6f578fzFEMPnfv8Akf6Z9R1H4ev+cVXh hgmlt/Ig9eOnoO3r/wDW9K0POnmlHp/L/PbPpnNfZn5yWIP33/Lf/R8/8vg5/wA/5NEP77Pk+36/ TGc//roh5m8+fraf8un659s/lz7cWP8Alr5EHGcfz/T9c+tc4GhDP5MVvPP69v1/z6HOK6Cz/wBV 58//AC9Z9P8A6w/L8zVCz/fRefP9m/r6ZOfTr/8Aqq/5P7rMHH88/pzz/kdegLJ7osQ6bpU3/H9B bXNv6/8A1v8AP44qv/wh/hW8ixcaHpvP/Tn/AGbz+I4//XzWxZw+TFcTif0/w/Ie/wCtWYZvOlx/ yw/P8en5fzp3ff8ArT/JfcR9VXdfj/mc9/wrHwrD+/txqWnc/wDHpaXh9vpz9aLz4Y+Ta4/ty5uf tXa7svqM4PXjt3/n3EP2j/R/Tjr/AJ9Ov49q0IZoIR+4n5/59Lv8+ueOn/1jXZHE4vTRW077fJHK sNg1bV3X9dz8t/FWj/2D431iw/59bzP9fr6e/eugs+3/AAKun+Nmm/Y/iXcT/wDHzb6pZ6Xe9f6g e3+OecZFnpvnWvnwYz7/AI57f5/DNe1hvhV97K/3RPPxPT1/RFiHz+Pw/L/9f3q0IZv8/wCf1Gfc Gq80PnRZ885/z/iOnPpWfDNPDN5H05/n3x/h7Cuk5DY87yZfz9e/T8OnXjrzViG88n3/AD/r/nrW fRQB1Fnef5/PPH5/oM1oQzf5/wA/qM+4NcfDN5X+f889e1bFnMPK7fy+nH+SfqDQB1EM3/Tf0ycf nxj6dvTNWP7T/wBn/P5Vy8N5/n+fH8h+PvViG8gz378fqe/U/pj8KAOwh1Pvj8Pz4/r0+vatCG8/ z/Pj+Q/H3rz/AM7yf+W/X/PvnP8AStCzvPJ/oeeef5/rnPFAHYef7fp/9eq8M3+f8/qM+4Nc/wD2 n/s/5/KrEN5/n+fH8h+PvQB3FnMPK7fy+nH+SfqDRP2/D+tc/DN/n/P6jPuDWhNN50RP1/8A1d// AK1AGf8AY/Ourf8Af/8AHr/pv+l5H/E0A6/Q+vp3r0DxjDYxahb30FjbW39qf8fn2T+v/wCvv3rz +zh+2X+n28//ACB7W80u9vPX/wCvzg/hiun8balBqWqafPB/0GNU+2fZOvf6c/0zQBszWfnWlvP9 n9P8/wAzn8evFV7O8+x3Xn+R9p5x/k9h68cA45rX0fUp4Yrf/n3/AF9/w5/+t6LqP2GGXzoD9m/6 dOnT/wCvz/nNA8Pv8/1icxr2vfZItRnngzbWtn9tvM/y/wA/zwa828KzfY8wXH/Lro/tn/P/ANbH Oa0PHl5B9hEEH2Y3GqXml2QyeufX/P4Vy9nef6V/25/XP4c46fh0rx84/wAv/bf8me5ljs4t9Gmb GsXn/Hxj8sf1H+exr0j9mP8AZ7+EmsePNQ8car4H8N6l4ouv9NvNW1az/tL/AImmeP8AkYMe/p6e 1ePXk3nXU/qeO317f575r7K/ZRm866uPW1vOP/1fmfevzPjRuPD2aSi3G1tYu1vdXVbdT6vLEsXm 6i1eyV9LrZX/AK7W8z7fs9Hg02O3ggsbW2t7Xtafp+XTP/1xXyf8eJrGz1638+D/AEj7H75Hp/8A W6/yr7wms4Joh+Xr6cc+/bsBkV8H/tOwwQ6/o/nwf6R9j5z7f57fr3/FeC8U5ZvHmberWrb7bddP NH6hiMKoYNcqUdN0rLp+G3+fQsfsx6l52qeMPP8A+XUaX/j+X0zn88/ox4blm+wW/P8An8/88+9f mv8Aslwz3l14w/5dvsv/AOrr+f8AIc1+oHhrwrrkOg299BB9p0//AJ+7T3/yfT15r9HyzXN8z1vo l+C/Xc+Bzj4v+3l+cT6I8E3n9saN5HP+lfkfp/P9O9eT/H7xXrngPwRo/wDwjmq3Om3H/CSdbSz/ AOP/AEr/AD7/AI4qx8PPEljpsX2Gcf8AEw+2Ysv0+n4+nt35f9pC8gvPBtvfTz/abi1vMWfP9B79 P5YAr63DYe+L95XVrtNfPb/hn59uSOy9EfN03xa8VePIvEP2+++03Gg+G/ttnZ2nP/E0/wDrf/X+ v0z4DvNcvNG0+xvvtNtiz+xc/j2+nTHHSvl/4G6D5N1rE/8Az6/6F/8Ar6fT16nqa+6PBOj/AGzW RB/2C8/X0/8Ar+nsK5sx+qLF22022V126aO3/DHqxxOL+qrCJ9ndfK2unl+Z0Fn4V+2e9v7n6fX0 roL3wfYwWtvP5Gbjr15z+f5V6BDpvk/8sMH88dvf+h/qXn7m1/8Ar/h/9b+ted9Z/q3/ANqaK+l9 XZLueT/2bbw3Vvz0J/P1/n179q2fsdv6n8v/AK1T6l/y7/aPf/7LOP0/DHerE37n7Pj3/H+WMY9u n553fd/1/wAMvuOgx5of8n/P5HHqCK5aE+TNcHrj+v4V2M3/AC8/8Arj7z9zdcT9OnpjOe/tyfp+ FHoBz+pQ+d9og/LHof1z/n1rj/7Ch9P1P+Negan/AA/59K5fM3/Pv/L/AAr0AP53zNB9qsJ9Dvrb UtH1T/jy/wA/54x+GhDN50v+v/0f7Z9c/wCePTOPcV5P4J8N+I9B8R6fpV9BcWv9g2fii9vMn/qC j6dvX65rl/BP7RWh6xrPiDwr4xsdN03WLXWfsX9rWlmf7Mvx/T1FfomYYXF5XZYvXVXSXe1np6+v mz8zy/E4PNE/qjs1vd2dtL7/AC01ett9vpCA+TLcTzn0PT8//rcVoT/63j/j3x7/AIf5PH6Vx+ja lBeS3AsZ+n/LoM8dvz9cDp65ruPsY8q3/wCPm5uM/wBOR6+p/PiuP5NX7/15mmwQw/Y/89OuOM/k P/1VsQy+dL+/z/ouOeD9aJvI8r/OPf3xnFJZ/uf3H/kp6c59fz6c89aANGG8nm7Efn/Mn8Mf4UGb 97b/AL/7NcHH+md8/wA+w9e3rVea8/dcf8e/SzOf5/Xp69aLP08j1PX655/z2PtQB1EM0Hnf8vP/ AF6cdR+n6fh1rYhggmFv59j3P/H3wf1/yKx7Sb/nufp/+v8ALB/+vWh5Pkf6j/P8if8A9Z70AfK/ 7RXg++vNU0fxHYwYt/sf2K8+yflz/wDX5H514/o8PnReR59zbfnz6j8x2/PPX9GIRBeWtzY33+k2 +P8Al77f54PTnmufm+D/AIA1KLyP7K+zXP8A06Y4P4/1xXq4bE/K2n9f8P21ve/lYnDfO/8AXb9O +lrW+L/7B0qGXyPP/D6f/q7d/wA6x9S0f7F/17/iMcdv85/mPsib4A6VqUv+g6rc2x/5c7S7sx29 PXp7Vy+p/AHxX9l+wW/9m6l0+x/6b/Zv49/p3r0sNicJpd3fr9+/9aeTvz/VX3f4f5nyfDD/AJ/z +px7AVoeT5MX5+nfp+PTrz14r1Cb4S+P7OXyJ/CupHnvZ9v859uPz5fUtB1XTv3F/pdzbf8Abn3/ AM/T8q6frXZ/j/8AbHLZ9n939d195y8NnP5X2j/l3+nToP19O/6Uf6r/ADnOfy9Pbp+fUQzQQ/8A LD/R/wCvf07/AJVnzQ+b/n+ft070rruv6/4dfeb2fb+v6a+8z6PI9/1/+tVg2c8X/LDr6/59v899 ibQZ4ori+8i5+zWv9PTsPX/6+KZznL+TP5v+fX659/8A6/NX/O8mLyO2P/1Zx7dPXrWjZ2f/AB8f p/8AXP5fqM1X1Kzgh8j9/wD6Rj6fr9PX2oAPP9v0/wDr1oQ+fDn6+ucYx6d/r1/Os/yfI/1H+f5E /wD6z3qxD5/H4fl/+v71AHUQzf8AHv8A5+vA/X8vSrHnfuv846fTPTt+ua5+Dv8Aj/Sugs/337jj J/zz+H09xig6D0DwfDYzWGofbjbfZz/z9/l68fgPx9PN/O+2eI7gQfZrbT/smqXtn9k/z/8Aqx1F egaPpsH2X7DewZz0+1/XnP8An+ddh4J8E2OpaN59vB/xMPtmqWX+I/X/AOt684HDzTT6bLb/APPu en+f1/yKJpvO/wBR/wAfPAJ/liveLz4Y6rNpeoQX2h6keMWf+h/if884+leD+KtHvtH/ANfBc23f 7X+Oe3Wldd1/X/Dr7ysNhtPJ9en6evfXz18f8bTD7Vo9vn/oKXv0756Y5/tz1+lZGm/6y4+v/sxq fUoZ9SutQvvIP2e1/suyP/YU9+n8vfvVizs7iGK3z/y9c+/b1z/kenTxMx1xW/fr/dR7eF0T9P1N CGHybX3us+/bn6fpX2h+xzo9v9v1++nn/wBI/wCJX/onf/I/zxXxfeTeRnyB3/TP5/56HrX2x+xP DPNdeMJ5+f8ATNK7cYx2/wA8fgK/JfE7FfVeE8zwl3duNvna6Tuuj2/Vs+u4Sw183XXrrby9f677 H6EeT5Mv5evfr+HXpx7V8P8A7UZgm17w/AJ/7N+12f8Ay9/j/wDrr7gmhn69v/r/AOPtj06HP5// ALY37668P/8ATrZ6p9fp/n8ulfiXAOIvxDlafZX+9atN76f8Oj9SznTCr0X5o7D9lfQdV0HWfEHn f8e+qf2X9ku7Tj7fyfr/AJ/Kv0Y8H+MPEem6DqGlWN9cnT7r/j7tPzz39unv0r8v/wBiHWNVvJdZ sfP+029rrGl/Y8jv/n+VfohoOpwQxXEA/wCfz659D359fbp61+7ZLyvNsz+qeV7235l+S26JH5Zn Hx/9vL84liGYfarecg/6V1//AFf4+/Ssf4na9/aVrb2M4/0e1swOD/THP8/wruNNs4J4bicf8vP+ A/8A1n6V5/8AEKz/ANF+3QQf9fn/AOv3H5mvpF/viv21+45I3aXXRFj4S6PBNo3n6VOdS+1awR9r tP8A9X1x+vevtDwfp32PWbfz/wDj4urLS8f48f4j+dfO/wAATBZ+CNPEEH2X7Vd6pe9h1/z7n3r6 Qhm+x32jz9f+XL+v4c9vrxXyeZYn/a0ku/y28vlq99raM97DYd/VL3d0r+fbz7evkke0TQ/5P+fy OPUEVj6lMPK4/r/9b/P0qxNN50RP1/8A1d//AK1Z95D2+n/1iT/IY/rXIdGG6+n6nD6x/wA9z+P/ AOr8zwfajyf3X+cdPrnp3/TNWNS/fRXFv6cZ/wA/0549arWf+qP0H8xXoFkE/b8P61w+pTf8e5/M fyyM/rn+tdzN/qT9B/KuO1jyIYrj/n5/z+AP9PevQAx7z99Fn+ZOc/l+FY/ke/6//WrZm/1J+g/l WdXQdB+X/wCxn4V8HeKpfjz4x+NJuf8AhD/Bvwr8UWVnefY/+Jn/AMJR460X+wdCGOoONc/PQK/n n+OXg+Dwr488cXGh3H+k69/xOhj/AKjvHvn8f5V/Qx4k8SaH4D+BniDSvDl9c/aPHmsaXrXiXSf+ oXoX9vjQvr/yHNc9fTHav5v/AI/TeI7z403Oh2Njc3Vxqn9l2Vnd56f19D/+rNfuWK+p4uze6tvZ 3tbvfT8PuPwBXjjLq8UtdNFovLse0fs6/FqfTdLuPDnjH/Rbi21n7F9ru+PsGfxz2/Adzmvvjw3r 32z9xPP/ANed3/8AX7ZPf8e+D+T+vWVjDL5+lXum/aLX+y/tmr/bP7N/t7VNC/5guh/5/SvoD4Jf FS++1f8ACOa5P9m+y/6bZ3fp6f5J6celfN5lhuy0/DtfS/TTpoe1luZfWdG/J33b+eu+z/R6fohP N5OPIgH/AG9+3b1/zzmiGH975/2j/SP+fT+fPB9+/b8fF9e+MGh6Dpfnz2NzqWofYz9j/wCgX/8A X+nv61+K/wAYP2tPjhqXxL1jXPCvirUtN8P6Xd/2LZ2lp/yDMenp+n6152Hw31votvTv56aX/wA0 dOIxP1Tvv/l5em+jP6KJjBD/AK//AI+B/n+v5dsUQXn+i28EH/L1+Hpke3Pp/Wv519B/au/aM8Ye MvC/g7Stc1K68UaprGl6LZ2n2z/mKa72/nn1r+iCz/Z7+Jum2GnwQeONTutY+x6X9s/6Bn9qevv/ AJ7UYnDfVO23+Xn6ddQWK+tde35dvlvpudhDeed/r+fy+v6D8BWhZ/vZbfz4Tbfp2PHPTr7+px28 v/4V78adH/5jlz7f8Sf+0/y/L/8AXnmxZ6P8Y/8AX2M/hvUvsv8Az92edS6/5/Ic1xAsRsl6L+uU 9w/132fz4P8ARvf8/wAu9bFnxFmAf6Ra3nP+ffvXh9nqXxi06UC+8AabqXpd2l4O/wCf+feug03x 5rllFbwar4A8SW3P/Lp/xMiO3v8A1NBoewQ/ueM/6R7+nT/6369K6Czm/e+f0IH+fT3/AJivL7Px tpV5Fb/uNS03j/mLWf8AZuPbn2/z6dxD4k0qa1t5xfabbdR+f59u358133Xdf1b/ADX3oDqJv3P+ vn5tf+PM9v8APbHbk1XmhgvP9IngtrnHv3B6/wD6xzxXPzeKtDvLryINc037R1x9s64z19fz/Cuo hmg6d/8A63+Hvn16jDCy7L+v+GX3HD6x8N/A+pS+ffeHNN/0qz/0P7JZ/wBm8fj/AJ47VzE3wB8A Xn2j7D/aWnc8/wCmAjt68/z4PUV7PeHzvs8HkW3+evX6dR0qvDjyvPn9PTPT/PPTr16U7vv/AFp/ kvuFZdl939dl9x8z6x+zH/y30LxH+N3Zf4/0P4d65bWPgn8RrOG3/cabqXf7XpN59f8AOT1/Q/aV lNP5Vv8A9PXH/wCr/PfnpU/nfugRxb2v0H8u55+mK0WJxitorK33fcZrC4PTV38u/lqfmvrHw98V aCPtF9oepYuv+Xs/h09B/wDWrj5tBvppf+njjP2v69Oc9+n8uRX6oQ/v/wBxn/P6dj/icVj6loPh zWIvI1Wx03Uueftdn9OO34D2o+teS/8AJv8AIw/s3+7+B+Y9nps/m/6f9p/0XP2O0/z7fnxxgVYl h/e2/kQf6P27fX/OTj6V98al8JfBt59n8jSrnTcdfsl56f5/+v0rh9Y+CdvN9oFjqtt9oP8Az92f P+fzPbNdKzF6K35r9bL8g/s3+7+B8b+T5X4+/wDnrj36fmWU3kykwfT/AB/z+mensGvfBPx/Z/aJ 4ILbUrc3n/LpeZ/wwfr+tc/D8MfGMMvkHQ7n6Djvj+uP88dH1mPdfh5f3vNfecln2f3f13X3nP2d 59s163nvr4Wtva/6b+PX6e/Jr74+D/2Ga1/4SOexz9qvP+JPaXnp/wBBrkAdf8K+f/AfwH1XWNUt 7/xH/wAS3T7Xn7JjOp35/L+VfaENlBZWFvYwQW1tp9qP+PT/AJ8OnTv+h+nc+dicT87/ANd/1763 tb08Nhu/mrfd/W3a3c6i71iCebyPItrb7L9O/wD9f9Sa4fxJZ6VNa/6dBbXP/X3Z/wCT+eP6jQhh /wCW3/Lxa/y/P/P0xXP+I/30XnwHj7H/AJ/n9ORXl3fd/f8A12X3HqWXb+v6SPg/xj4asdS8R+IL HQrG2023tdY+23tpaf8AYF/yfb+fDzeG9VvL77DBAP8ARcfbfbj/APXX0BZw+Tf+KJ/+Xj+2PsX+ effP51jzab+98j689O/v6/qf0894iXW9/O//AMkb/V15fh/8ifO8NnBFLcQf8fOev+T64x6cfSv0 h/Yu0fydG8UX/kf8fWsfQf8AIF6en+fy+DvEmg/2NdW88H/Hvdf4+vTsfTNfpx+x/pv2P4c/bun9 p3mqXvT8OP8APQivy7xO14eV+sl+qPreE/8Afct+X5RPpiaz6+f+ePwOf/rj1r8x/wBtj/Q9U8P/ APXnnt05PX9M1+qE3kTY+npjOc+vb6dPyr8p/wBvb9zr3h/yOPsuj+2fx9fx4OB61+OeHGGf+ta3 dvw0Xbb7vuP0niO39kLa+vrurefY6D/gn75E2qaxP2/tjS89Pp/LtX3Rps3k6zrFjP8A8uusamLP r+GPb+eOvc/B/wDwT9inm/tDrn/hJNL/AE5/T9DnFffE2mwHVNQ7D7Z34/z+lftuSf8AI4zRddLr 5Qv+t/mfkeb7r1j+cD1jR/8AUn/Peuf8Yab52l/Z/wDP1/x59s9qr6bqM8MvkT9P0P09T/nrXYTX kH2DUfPsT/x55z/T/OPfvX1w8Jt93/pJj/BmEabo2n2E/Tv/AJB6/hX1Bdwj+y7eeD/l15/X2/Pj 8a+V/B+pQWeqW9jB1+28D/J4/OvuCHR54dLt7G+/5erPS73/AD+uf6dT81mS/wBpvbqrv5RPbwz0 evT/ANu/4Y0LObzrC3ng/n6H88/l1qvP2/D+tbGj2f8AoFvB/wA+v+ff1698+tV7yz8mXPb1/wAn 8O/sOtchZw95+569/wCnr0x2/rjms+zx5X+o/r1x9Pw+vvWxeQnze/8AP68/5A+hFY8MM8MtxB6Z /n+v4Y9eK9PDbv1/QCvP2/D+tcvqcPnfgP156/5/TNdBP2/D+tY953/4DXaBy8Mx+y+R+Hb2/wA/ iKKz5ofO+0D/AJeM/l268fn1rO+2X3t+X/1q6APwI03xtY69a/2Vqs1tc84+1+2fb9cZr2DQdY/Z C+D/AIX+KHjHxH4V034o/EDXfDel6L4P/wCEh0f/AI8NV13/AJDui6Hof/u0kdTX57wzTw2vn+f/ AKR9e3t/9fP8qrzf2VPpesT65Y6lreodbPF7/Zo/n9M8++K/V8Nidf60/T8O9vP8rxOF10Wrsrfh /wADb16M/If4wal45vPEdzPqtlbaJb2t59is7S0/5cPQD+vHt3qv8N/iprmm6pp/n33+kWt4M3nt 7/qB0/Q19MftFWeq69oOoT+HNKtre35/ti0+yfh/bXbHv9K+B9Ns9Vhv7eef/Rv9M9eP58dPy+ld OHxCxemnbXZ666Pu7b6/KzPDxGH+p4uL2Wml0lf/AC2sfuRo+paV4w8G6fqv/Hxo+qaP/plpjjr/ AJP+PU/j/wDHj4Y+KvgzqlvBYz3OpeBtUvPtuj6tn8tF1z/qY+cYr7I+APxI8nS7jw5Yz/abf/j8 /sm7/T9MdfT619UTeD/DnxC8OXFjqsFtqWj6ofsV5pOrDGPf/JyfzFc3+6eqX9en9bLbpxL+tL0W 7fp52/4fY/P/AP4Js+A/Efjb9sj4PwarpNz/AGfoP9qeNBd3dn/x/wD9haLnQs+n/FR/2H9Oe2a/ sIs/3GPP/D9fT1/H36V+I/8AwTf+A/iv4bftGfEDxV4jn/tvwvoPw3/4RjwHqxs/7Nxpeu61yNc9 fEX/ABIx/Ov3I/0e8P8AkHj+fT9a8PMcQsUuvd28rJbeS2Wy+86sKn9Uemt/mH9mQXn9efXof8/X 3rHvPDelTS/v7G1+0f8AP3ade/6fTp9K6CHz4c/X1zjGPTv9ev51oWc0E3+v/X/PUdAe9eYdpy8P huCD/UT9/wDl7/T3/wA9++hDoMHW+0rv/wAff/6u/bpWxNZ/Y5e/+e49O34/psQzf5/z+oz7g0Ac v/whPhy8/wCWFt6898e5+mar3nwf8OXn2jz7G2P/AG5+/wDL/PQV3H2OCaXv9o47/n/nv07VoRfb rPH783Nvn+f1+n8jTu+/9af5L7jP6t/V/wD7Y+f7z9mnwdNL58FhbfaPy/Lr/n9K4+Cd9psw/wCJ 5rf9n/8ATpeDUvsHHPT/ACOlfTEOpQf8t/8ARuv/AOs/Ufy9a14LyCbp/M+mfp6eldaxOM07afdp 5eX4vuaHzRN8GfFUP2e+0nxV9pt8f6H/AKHo2evbH/6+O9Y83ww+I0MVwft2m3P/AG5/2b/9f8c9 ee1fVHkz2cvn2P8Ao3/Tpn/iWX//AOr29PXrYh1ixvP3E8H2a/8A+fT88Z/n9KPrPn/X/gIHxv8A 2P8AEbTf3E/hy1uf+vS8+n0+np69az/O8Y+b/p3hXUrb/r0vP7S9f0z649+1fbE0Pm/5/n7dO9Y9 5DBn/UfU98dv6dvXmhYi7Svu7bf/AGoH5X/FT9sD4SfB/Xv+EV8Yz3Om+IP+P3+yf+gf1P8A+ofl mtDQf2uv2ete0+31Wf4jeG9Et7r/AKC15/Zv+en4D3ya/F//AIKHQ+HPHn7VXxgn/wCEqttNuNL1 jS9E+yXY/wCPD+wtF/sHj2+oH86/P6z8Hzw+LfB2hwa5put/29rGl2Vn9kvP+JZYdP8AkOdccfjj rX0Sy7/Y1r8+2zflbZPX5HlLMVdK1tV/Kv1P7OYZoLyKCex/0m3urP8A0O7zk/T9OP8AJomhM3+v /wCPjqPavjb4G+JPFWm6No+larq3+j8c2l7/AGl9g/pxz+B+gr66hvP3R/4mtsbjp/pdn/k/5PPc eSe4tUn3SL/k+T+5z+mPb07Z9/Wq80Ih5/0b/Ss/TH/1unf8a0IfIvf3/wDx88A+2R7/AMuOfaq/ nT/6if8A0X/P+ev4HvXBd939/wDXZfcOy7L+v+GX3GhZ583/AF/9euPp+H1966CzmE32fz84/wAf rz/nrzXH/uPK/wBR/pH079M9P8niug0ybyf+nnp6Y46ZI9v84zSAsalZ+dD59v8Aaf8A6/5/56dK x7yHz4v9Rz/P8c5/z9a7iH99FmCC2uc/8+n19Px78Vj6lo5/0if7D9m59O/f+VB0Hyv4q03+xvFF xB/y76rZ/wCh9eRz26/n+Brl7yGCG66f8fXTueP84GOtesfHKeCG10e+/wCYha2f+h/qeM+vb+fa vJ4dSg1K18//AJ+rM/57j/PrXjYn/el6/oj0Dl/Emj/2lo3n+QftFrefl+o/M8/jX6kfAfSINH+E vheDpcXWji9/P/J5/Lmvzu02H+2LXUIPI/4+rP8Az6D+vt6/qF4Ks/7N8BeH4P8An1sz+uOv4fX/ AA+J4+wyxeUXvp19NPw0t8/u+k4b/wCRvG2ykvS1l+BW1K8nmuvIgzj+f+eP1+lfnP8AtdXmhzeI 9Og1z7Tj7Hnt+P8Anrmv0gmmg876f57c/wAzX5r/ALRXgO++JHxk8P8Ahyx4t/8Aj9vPfS+n6eme tfjfh5mWEwfEE31inq7bpL7rW8z9A4rw3/CTG173Xrq12/r03Poj9ifwTBDpdvf+G7C5tre6/wCJ 19ru/wDiZfh0/wAOSeete4a9PPZ6zf8A7/j7Z6dfX/H+Qr0j4P8AhWDwH4N0+xgg+zXF1Zmys7Tj /kGfy/U4+tcfr3huf/hI7iD/ALfTn3/zn2ya/ZuFovESlm3vJ5zKSa1ukpaenTsnbXy/I8xa0wr7 LX7n076NX/HrX0Gb7ZdXA/59bP8Az2/Hrzz2zXtHhXQb/wAbWHiDQ9KgtrnWPsf23/TLw6bjp6dv w+nOa8n02zg037R58/8ApF1/x+du2f8AOffPTNdx4D1jXdB+0T+FdVubbxhc/wDHn9k/5Cf8v+Kh x1r7XD4b/bPJ6W6b/Py/zWg8NiUsJ0utr7/r5bfdbU5+HQb7w3481DSr6D7NqGl3n2K9tPx6fr+N fp94im0ua58Pz6ZB9mguvAvga+x9jH3To5256D7uBj881+VOseKtcvdZ/wCEj8VT/adYur3/AInF 30/4mn+HTp3619ceCfiPfax/wj8E/wDx8aDo/wDYvT/mF/21/P8A4nnU9Rx2rxc6WFwmEzNyVtrN p3vorLs9nZbnpYVPFtNN3SemnK9YvVdbNKz16230+kLOHyR5H+f69xk0XkPb6f8A1iT/ACGP61j2 esQXn2fyOcfT29fT2/xrqLOaCaUwTnFvddvoen8+3b0r4DDYm7Xd2336f8Nt8u/qrRJdjzfUrP3+ mf6/oOPY+9cvNZzw/aP+fcZ/P8M+v8+lfSEXw9vtYPk6XB9puO9p/n6D0/rXD+JPAmuaDLnVNKud OHXN1Z8f/q4OetfWYbDYzl5rPlsteV26PdK3X8L278f1vB831O/vXvvro1r6bfgr9T5/vIe30/8A rEn+Qx/WseabEVx09u/ft0/z9RXpF5pvfyP8++fwwPpXIalpvk/5/wA8eh/r1f1nz/r/AMBOzY4a ab91PB/y7/8AH77df0/XH1rPxD/z8fz/AMa2LyzPm/r68/r/APW46d8b7Hceo/L/AOtXR9Z8/wCv /AQP5QPDepQXkVv53+P+fXj/AAB7DUv31hc+R/8Ar/x75+vtx4/4bmuPK8jr1/xH9ff8q9PzPDYf 6dBc232r/D/Pr+dfrh+a4jePy/8ASkeEaxCYftEE5tjb3X+hdu/+cflX5r/FTwrfeFdeuIOmn3WP sd3/AJ/x9T6Gv1R1jTYJrv8Acf8AHse/fnnp+H+TxXz98VPAc+vaDcQQQ/8AEw0v/TbP+X/1uPSo wul/T9TlzDDvFW20tf5Jb9tVq/8Ahj4f8B+JL7R9Ut/s/wDx8fbOf6cf4V94aD4kvtBOn6rpU9z/ AGfqn+m/ZOB7/wD6+Qfyr8//ADoNNv8AyfI/6/Lv+XT6Z+n419IfCvXp9Z0HUNDuJ/8ASLX/AE20 /wA+nX16fhXp2vpa/kfOK6fp+nc/Yj4J/E6CG10/XNK1X7NqFr/x+WnOfy5/XIPFffGg/H/4czS6 fBqvjHw34b1C6xnSdW1j+zcj3z+H88civ55/CvjC/wDDeqQfYZ7n0vP09P8AJr0Dxt4Pg+NnhK40 O+nNtrH2z7b4b1bn/QNUHXn06df515uJy1b6W/C2/p1/A9qOYr6pFXTd0r6XeqV+/Zfcf0saPr1j rFrbX1jfW2pafdf8vdpefp+n/wCsV0Hkwf6Pme26/r/9bv6n16V+Z/7E/wADb74e/AHwPpWq65qX /CQXX9qa1rH2TWP+YprutdPb27Dt1FfXE3hTxVD+/sfGOpdf+Xvj/PoMH+teLiMNhenT5L5r1W3e 3fTsWqT7pH0hDjyvIn9PXHX/ADz16dOlV/I9/wBf/rV4vZzeP4Ysf25ptz3/AOPPkepPufw69q2I dY+I8PP9laJc/wDb3/nIP+H1oWG0Vlp0/rmI+s/1b/7U9Yh/de/X9fy/pWh9s9//AB2vJ/8AhMPE cP8Ax/eFbn/t0u8+/wDn8vatH/hO/J/4/tD1u24/58/p/n29KPq3l/X/AIEaHq/7iaL6fT/P/wCr t2r/AGPyf9Rxz/k+v+Qetebw+PND80eeLm268fY+nQj/AD6cVsw+PNDml/carbfT07/gOv8AjwKP q3l/X/gQHbw3k8P+v/zn8Px9CelE3kalEYJ+3S74x/8Arx+lc/D4k0mb/l+trjr/AMvn+JPTH6UT axpXlef9utuox/pnXH4/r1z1rks9rO/ax0Gh/bF9oJ/07/iZaf8A8/f/AD4dfX/PfrWhNrNjeWtx PBP/AKP+f9c8H39/Suf/ALeg8vHn235n1/yP/rc15P42vP7B0HxB4q0O+ttNuNL0fVNavLT/AJhl /wCn/wBf26DmulRba0dm10Zzn8m/7V1n4c1L45/tEeJJ/FX/ABMLXx5ql7Z2uP8Aj/1PXda+v5f5 FfN/wN03+0viXo899/pNva/2pem0vPzPqP8AD8ax/jBLfeJPG/ijxVBP/aVvqms6prX9Pf8APviv aP2VtAn13xvbz+R/x62el2Xf/oNfl/8Aq6V9JiG8Lg11dl5u7S6em3lsup4EVfGrS6v8vP8AH8T9 4PhLN/yI8HH+laP9i6flj/P4c19EedPCbcT/APHv6j+mB+v9K+X/AAHDPDqnheH/AJ9fc+p/zxkV 9oWWsX/lf2H9h03/AImll/pl3eWf9o6n/wDX6dh6V8yfTLZeiOw0Dz4tLt/IP+kXX+m3nPf9P1PH T3rYng/5Yef/AJ9uPz/D6Vj2cv8Ax8wEe/8AU9P6++KsTTeV/n+ft07UDNCGbyftPnj/AEj/ACP8 5/8A16EN55P2jv8Ap+Oe/Tpj3rn/ANxCPPng+0/59fxGe/bgVoWc0Ew8ieDj1/DPTP8A9b+oB0Gm 3nk/6if7N/y+9fbvx/n0xmuoOpc/v5/tP6en4f574ry/7ZBDKPI56f5/zyfbpVj7Z+9/1/H69f8A PP6bqDoPF/jxeQXn7gz/APLn7+34/UfU1832epTWdrb+RPn7L/n8v1/mPQPidr3neI7iD+mfUjH8 +2BxXj8P+hXWoQf8u911/T/P8+a+exX+9L1/RHoH0h8K/wDiZap/072vHXp/n39OK/TCz1L/AIkO nwf9Of8Ah/nGfpX5b/A2aea/1Cfr9l/suy/z39x147cHH3xPr3k2tv8Av/8Al04/Xv8Anz2/Kvy7 xGzxYbB/UYtczsrX2vZevVb/AI9fuOEsLr9c3tbo+6/4ZdfS52Opax9j/f8Av/n2H4etZ3w38Ewe JPFGoeJJ4ORxeXeP/wBf6f8A1683h1KfxJf2+lWXe8Pf9O3FfcHg/wAKwaDoNvYwf8fH/L4Of5D9 eD1r844I4deLxinZq+t/mnv87u/5H1XFeZL6mkrN2X4pJN2+/wCfRnUeG9HgvLrz54Mc+nfH4dPz Ncv4q0e3h/ti+/0b/nyHH+f0/pXvPgnwrNNpdxff6KLe1/4/P9MOfx/z1r5m+J3iuCHVLixg5t/t n9Pf+f8A+sf0vlmF5YpLaKSXRaJbJbfjt30PwzMW/rcXfX/hjy/WJvJ+0QQH/j1s+34d/wDD/wDX j2c3nWtvPBP/AKRa/l+nPT0yP6WIf332jz/f3/Lp159PbtXn8OvT6bdXE4/49+Px9/T16/pXpp2a fZp/cdGH2+X6RPUNY8eWOveAxB8RrG2ubi1/0Kz8Q2l5nxzYaXz11wf8jB4d/wCpW8We/Pg2rHwx 8YaHey6P9h8Vabrlxa3v2K8u/wDkG6nf6WD/AMxzQz/n8a8X8VQ2Hirw3cQWM/2Yf8/dp/zAdV/y PUfh3+V5rPxH8Mde8P65ff8AHx/a+l/bbS0H1+nXrXoZlDB5rg+XFRadrJW32S0Ste2v4WOnC4r6 pi9HdX07bLz8rfrqfuho+sT6bdGeCfH+fw745OP8PYNM1/Q9StfPsb77Ncf8vtpdn8/w6fSvkf4P +PPDvxU8G6fqulfabbWLU/YtYtLvrYap/bXf8R1PXHWu4vLO+0eXz577+n1PTr/np1/IMxyX6rJO Ku73SWvW6Wi+/wDyPrMNilivO/fTb8d/v9bp/q18Eb+D+ybzXb0p5MNnptm1yx5N8gAdlGQerKO4 +b3FcX8U/ileyzXGiD+ztSsDdgHNoScDA5JJJ57kZ4OT1z8E6P8AELxHpsNxYwarc/Z7Tg2n2wfT Pr+J9asf8LCgvMfbp83Gcf8A6vyP4flXsYjjrF4XKFg1lOqiouVtX57aJdV31em3m4bhzDPN5YyU rrmTjG1uW0UrXbd3dNqSt8VraXfrGpaxpV5KfPsbb/P/ANf06dq8/wBS/sqbpBxn36f5P+Tmufl8 SQz/APLf1/M/z/8A1fWsebWP+Xj7R+Y/kB+Hf618V/bjxTXRqzt8lZa2/wAz6b+zP739feaE0Nj5 Vx9o/wA8/wA/5e3WuX8mH/nv+p/+KqvealB0/H+WP89s1j/2x/nH/wBjXpxzxKyemi6+aT6/1oNZ Z5t+nr6v/hz+PfQZbGb/AI8ePtX5/h/U11HnTw2tx58//Hr+PA9e/wD9evnfw3qU9nqlv9e//wBb px/TFesaleH7LqH+PH5emfbj2r99w17O/b9f8rH5pibfWVa1r9P67/idPeTQXn/Lf/R7rH58enQf 41gQ+RPdW+l32qm20+6vBZC7/wCgf/nP/wBfvXL6ZqX/ACx88XPH+eB/nv0yK0Lz/TP1x/kZ6f56 c9a0afYxPH/26vhL4H+A/iPT4NK8VeEvjZp+qaPpd7rHiz4e2es6bplhqnX+xf7c4/4SDJPsOPav h/wT420uHWtOvrLVfs1va3n+maTd2f8AZvU/9Bz9PX9a+4PGFp9stbixvoPtOn3X+hXlpd2ecf8A 1/8APNfnf438E/2DqlzPYwf2bc/bP+PQZ/szUO34g8evua9BYnZJ+W//ANsfM4nC/VsXfdWX42s3 20aX+Z98XkPhX+0Le+0Ke5ttH1T/AE3R7S74/wA/1zX0R4D1LSp/Eej2NjPci3tbzN5/n/PPT0r8 /wD4D+NjqWl3Hhy+/wBJuNLH22ztP+oV7/8A1x1r7w+GOjwTS/brHBt+/Udvfp3965sQ/wDZFd9N b+pz4bDd9db67b/1+nRP9YfhL43n8Ny6foc99bDw/qn/AB53fH+gD6en6V9nww6rNF+4/s25/wD1 5+v14796/KfwT4kxFb2N9P8Az/8Ar+n4D1r7Q+D/AI2N79n8K6rb21zqFqP+JPdm8Om/b/8AqCjp 365/D38jR+aPeSskuyse4Xn9q2cv/Hj1/wCfS8z+Wfx79eK0LLWJ8/v4Lnnp/wDXH554+nWrF5Zz +Wf9C1rt/wAel5+f+c9fzrj5pvskoHn6l9n7fa7P/Oe/4d8154HpEOsQZ/19z3/5c/8APt2/+toR axYz8efbd/09cCvP7PWPJ/1F9x/0+WfJ/wAe/wCddhZ6kZv+gbc/57f5+nU0AdD/AKDef8+1wPx6 4/PGB7f41ZtB0qXP/Epth9bL6VAYTN/zCra5xz/x+f4f5yOfWjyYP+gVc8/8+n0+nr+vNOO69V+Z 55nzeD/Dn/Pjz/nt1PX8vTgn8l/+Cq3iSx+GPwg8HweHL7UtM1jxR4w/5dLz/mF6Fov5c/8AEj/y ef1wvLy3s/8Alvrdt3/6CX0/znvX81//AAWY+JE+pfEv4b+B/PuRb+F/CGqa19ku/wDoKa7rXQ/+ CPv79K9PCL/atVpyoxxOJf1RW3XT5/11+T3Pzfh/ai+MWjfZ4LH4m+NtNt7UHn/hJNZPH44Hv713 GjftpfH6bS/EGlT/ABN8W3Oj3XhvVLLWLS71j+0tMv8AS+v5D9a+H7y8/wA/ljj8s/iM1sabeeTo PiCefrdf2Xov8/8A5R88e9e3Zdl9yOVYjG2S1tZb9vPU9g8HWdj4ktfFF9Pqv9m/2Xo/23v/AKf1 9v5ehr6g/Zv8VeDvh7LceMdc1b7Lp/2z7FefZLP/AD3PP/1jX536DPYw6oJ5zc3NuLPVcWnt7/8A 1vy4rQ03xLPDF58F9c/Z/tn/AIH/ANOnJ+vWsHrvr6/15IeFxP1V2te7t6apX+Wlu2mp/TB8K/GG leJLXwv4q0mf7To91efbbPHH2/8A4nQ79ef681+iGg6bPDaf6d/o2oap/wAfn/Th/T39/rX5r/s0 6ZY2fg34TQYx9l0fwvz3/tT8e/8AKv1AvLzyZfP/ANJxnpadfXgD8q+XPp07pPurmf5Pky248/3/ AM//AK+1F7N5GZ557b7P+vf+X+eOKsXkxnz/AMfNt2+ntz3/ADrP8nyfIH2j/SP8/wD6vxzjigDQ nvP3X/Tv6k9e/Ht60TTQTRf6+2/D6Ejt049f1FZ/ndp/a9/lz1/PHuTXP3nnw/v4P9G6H6D2Pv8A /rrnOg6G8vJ5v9R6e35/0xz6dKSzvLjNx/06+3GP8/pXPwzdr6f0zx9COR+IrYmhg8oz/wDLv7dO c8f5/D1oA+J/GOsfbPEc99/y7/bPTrz/AJwPz9ufmvDPd/uP19f88/kK0PG1n5OqahBjP1/Pgc9P p3rhvh5NPr2vXAn/AOPfS7z06H/9XX614+Iuld6WXXyTZ6KV2l3dj7B+D/n2f2aCf/l1/wCPz/p/ /wA/zxX0BqXiTzrr7DBP/pHpkH2/z/8Aqr5/8NTQabHqE/4fh/nHPua7D4e6lBNrP26+n79fb/Pb 8/f+Z+K39b4hzPFvZWSvdr7OqW23brbza/WcjX1TKEur6bXvb89Ne5+iHwB8B+TF/wAJHqvf/jyI 9fX+Zx/Q19gabDByf8+vOP64/wAPm/wf8VPA8Ol6fYwX32a3tbPtZemfYA5z+Rr6I0Hxh4OvLW3n sdc037R9j9f6fgOlfpvBP9kYTCJvM0m7O2mj0+dr6W6rvol8pnWGxrxaevK91rs2uibs7O7Ow1LU v7B0bUL7n7P9jwOv/wBf17/n6/nfrGsf2lqlxP8A9Pn+cdf8O3pX0R8ZvidpUOjf8I5Yz/abjVP+ Py7tLzucH1+pA/Pmvk/TZoJpf9fxj/Pp6dPz9v1PDYlfU9LNdJL+nv8A8Otj4fMsN/ta8t/uW/XT 1b9D0iH99FjnPXt+nP8A9fPPNeT+JNO8m6/6d7r/ACT+fUe3OOK9Igmghi49f8O/v1965fxvjyf3 HX/Oenb9M570YbEryfX7v6vou+mzOn6t/sf9dttv6XS54P4P8Sf2b4tuLH/l3uv9CvLW8x/Zl+f8 /wD1+TXrHj3w3Yjw5cWM1hptzo+vf6dZ6taf8hOw1T/Ec8V87+TfQ+PLixsYPtNxdf6afsn19vb+ leg+D/i1D5Q0PxHB/aWj3X9qWXH+f0x19q9uyt9btp21/padfl5nmYbrfst/XT/gH1/+wfDY+FfE fjDw54jvtN+z6pZ6prX2S7z/AKBqn9tZ/wAOx/Cvvjxh4CsdS+0T+HL62uTz/on2wd/r/nP51+N/ iSz/AH1vrnhzxHqVtcaX/wAgjVtJvP8AiZ+/9ue/8untVjTfjx8RvO0/Sv7cudb6WP2u7s+2MnH/ ANb+eDXiYvCqX+2YRXT1aev4emm3Y9zC4nCYR/7XvureulvL8rH6IalZwaDL9hvoP+Jhzzd/yH8x 646CvL7yYzS+R5/2b+nTntz/APq4zmvkbUvjl4y1LXreCf7N/wAfn+h8HH9Oh7f5HMa9+0tqvhXV Lexn/s3Ure6/4/fsd5/x4Y5/wHQ9+T1ry3lixaaklayvdK/TvbTZr5Hp/wBprpNeWvpb8196PuCG aeb/AJfvs3+mY/D+Xv0/OsfxJ4qg0eW5Njqtzren/wDT3Z/2bqf1/wA+lfG+m/tLaHN9ngn/ALS+ 0XV5/pl39jzplgfbqfz9c8k12HjD4haVo8s/kX2ieLdPP/MW8PXg/p/OvnsTw5lCvrZ9UtNXb8PR a/NHtYbMsW7JK+yTvft09Onqe4TfEjyYvP8Ax9D6dOOTXP8A/C2Yf+fe4/8AAI18z/8AC7PB00X7 +DUrbqf+PL/H/J/Gp/8Aha3wy/57XP8A4B189UybBqStJbK+vmu/lp9y2evpxxWM7qzt1Xdeb6L7 vuPwI8VeCfO/4nmh/wDHza/8flpxx/ntms/Ur3ydLuO/06/l/T6kV1lnr9wIseUnb+I/0Arznxlq TXdvcSiJIWyD8hz39cD+lf0Mfkxkw3n/AC3g/wCPk/j1+nPf2ruNN1KC8it58fTjPH4f5/KvKNMk N79mM3P0+mf8/nWrotzKmpSWoP7mbO5eewx1zQB0XiWHzorjH1HTj69u31r5H+LXhufUtGuL6xgP 9oaX/pv2P/qF5/z696+ubuQ+V0/z3/P/ABryzxVGLKbzYTgjjHTuO4+td+H2+X6RPJxWuEjfz/8A bT4R+GOu/wDCN+I7eef/AI9/tn/H33sOuOenX9cjPAr9kPhv9h/su3vrKf8AcapZ/bbL7J7fjz1/ /X3/ACX8VaDZQ+KNS0K2Bgs7mIajb7Rk2cv92MZAce5K+mK+2P2NPFep6to2veEtQZbi00SQXGk3 DZEtk/8AsLggj/gQ/PmubMf/AG5/oefl2z/r7KP0I0z9zN5/P2g/X6cf/qr2/wAN699sit/3/wBl 1C1/487v9efoevf0rwPT7l5LdIiBth4X+vp1rrdPvZoLi3kQjJGfYV4J7x+qHwx+Klj4q0v7Dq32 m28QaV/yGLT7H/x/9v7a/Afyzmu41j+ypovtEE/b/l7s+Pp37AfX9D+d3hzxLqumS6Z4ksZzb38O NpXkdCevH8v8K/SDwxqR1XT7XUbi2g/020xJbgEoM+jcE/8AfI+vag48T/X/AJKcRZ3lj/x4z3Ft z29P8Mfr+lbHk28I/wCXa6+v9Px46/jwaseMdIsLKfzYYQD15+mev/1q5COWK6T7GtrBCTj9+i7p PyOBn8aDQ7eKbSof9fBx/wBOn4d+D7f/AK6sfY5rz/UT3Om2+f8An8/4mY4/L04P4+p5DT7KK3m+ SW7PT/l5Ydcf7Pr/AF9a7CGC48v/AI/rjg46j37/AIUHniQ6b9jNx5F9c/8Ab3/xMvx5x/h/Ov45 /wDgpZ8Q/wDhNv2tPixP5/2m30HWNL8M2fX/AJgWi/2Dzntn61/YF4l1PUtG0+S6jnt7l4bPUyou bRGH5h/6V/Bv8WPEV/4m8e+MfEeoFTf674s1TUL1l5Bl/troCQCR747dK9XLt16mOY/+2v8AQ81m /fS44x17/rz/APWxzzXQCH/iQ6fBBBzqusHjj298defxJrn69c0lILDRdJv/ALNDPPZ6X9ojLrjL 4JwcZx068mvbPNOb03wec3E88H2m4tcfbLT/AJ8fTjB/T1HXv7B4P8HWPjDwvb2M99oltqP/AAkn 2L7J9j1n/wDpg5H14ryyy1+5/sNX8qP7Rq2o/aLq4yd5c54Ax+uRX1j+zxHfX0Hhe1u9UuptN/4S jVNX/s5seT9sGi/f3ZJx+H60pbP0f5HVhviX+JfnE/cr9mP4e6rN8PtH1z7PbDRrW80uy+13d5/z FP6f5xmvugeRDL5+T+Pf0/zz7+lfHv7OXiy91rSvCnhyaC3hsPCd54n2rGCTq/8AxOj/AMhMHAl/ 4CRX2ZeSHyp+B/n/AD/nFfIy3fq/zPpY7L0X5GdP/ref+PjHt+P+Rz+tVZpoIeZ4PtP2XBvO34jv 1/8Ar+lV1/dziQdfsYH5/wCelTiMTxDf39vb/PeuYZam8ib2t/8An0+vbtj2/n6Y803nWtv04s89 vQ/yz/I1oeevlf6pfzP936fh/wDXqmLdIuBk8fTj0/Sug6CnNZ+bjz4M/wCff/Jx9ar5nh+z/n3I 9e39fz71t3ltFwcdv5f/AKvwqnJ+7ilI/wCWPC+49/yrnBaNPsfJPxU16fwTr2sarBY6bcz3Vn9t svtdn/nr6/5PPfDfR59H8OW8+q/8hDVMa1eemPy4/wDre1cz8W5Dr3xT0fRb0brMXl38o5P/ABLc eT145zz6ds111xezSYycZz/PP9a+c4jzD6rhGkr3Tj130Vvyv0PZy3DfWcZHZWs/WzS1+9X/AKt6 h/aRmtf8+3r/AJ61X0G8n/tW4g8/r/j/AFwfrWBYSF4ue3+f6j8qWzc2Wt20sPBIzivwLFYdPCuT 3k29d+nW7126+jR+kLESSS10S72/PyPfrPX9Vs/+W91/Lj1/T1/+v6BpvjzVYYvIgvv9Iz/ofr9e 3868pmkOy3k7/Ys/0r2j9lTxbq3h746eFtUsfsk1z9o123/4mFsl6NmpaLmb/WFTkfw/0o4Syf8A tTN1hFKyv3sujV9r/wDA+/lzLMsThcIsWrN9b2b6d12/DQ5zUvGGqzXf+nT/AOkf8vnb+ef/ANdQ WXjaeGXz/P64GPbn/OMYqf4w2ltpnijW7mxiFuk2sarugU5Tj369/QfjXj8N7MBnI6e/fn/P+RX7 8sP9VSwl+i1u3qkuvz3Wv4nwWJxH1trFu1+1mt7NfmfSNl48nm0v/Xj7R09vX65zz/kEaF542nms Lf8A0j/j67AY/wA89sV87abezfZT04IH6/5/rmtjTb6YWFoM/wCovDt568454/yaWF/3x+gvrD+p 3s/607/8HzvqbN54qns/+Eg1aDjULqz+xWd32/H6entzmvmez8VX2my3H/Lzb2t3/wAen1/xJ9+P WvUvHUhhtcx8Zz+GPw/D/GvC9QQJf3eP+W1lluOnJHH+ev45+3wyWitp2/8AAj5vEu1rdv8A25H1 l4P+IX9pXVvPBB/o/wBj+xXg7X/5Z9/ofeuom1ifUtUHkWP2a3z3s/f+vP4/lXzz8O7rY1vKIk3f U9SM56V9hx3j6XFY3PkWd28+n/Z2+02yN8mOuQc5Ga6fqq7r8f8AM8z61isU1dpbbtPy8+q+Xmx0 PhWx1KLT/t19/Yh+2Y+19rDj36df89vCPG3wxvtN1TF9pVzc/aj9usru0/5f/r+Bz1/Lt9QxajPq KW9tcYL5x54J39+3T9f510vwm8Wf2B4+1me60LRPEsQx/o3iK0GoRnOf4mKn9P8AGuf6rhcS1o09 GrK21n/S6eZ1KWJ6SX3+nn5L7j8+YfB080pt4P8AP14/X+tdhplnPo3+vg+1c/6Z9s/D0+vPrzxX 6P8AjX/hGPiR470LT/Evh6Vo/F0eqW1vPYahZ2V14cT+xiM6PMmitsP+8or5o+MfwotfhT4q1Dw/ ba3da3B5on8+5tYrKTfx/DBLKP1r4XjfJ8RTwixeFmo26NpdvS/ro9T63hjMXRxawmKvO9tUr78r 876NJL8UfM+salY3kX7ixtra49uv+H5dOa8+864/5723+fxr07xPpdtbW/mRZDHjp9D6+9cL5Ke/ 51+PezxX86+/08/6t6H6hSjhuW/K0nbZem/yv8z/2Q= ________________________________________________________________________________
Subject: Re: Finish Kit Surpise
Date: Jun 08, 2010
Robin: Actually my cabin is done; I thought the QC on the cowl was worse. The cabin area issues were cosmetic; the cowl issues structural. The foam/glass reinforcement was placed too far aft. I had to remove some, and then reinforce what was left. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300578#300578 ________________________________________________________________________________
Date: Jun 08, 2010
Subject: Re: HID Landing Lights (high speed taxi)
Marcus Cooper wrote: > > Just to pile on, I find myself at rotation speed about the time I get to > full throttle (trying to be a slightly gentle on the engine), Until the engine is fully broken in (oil usage stabilizes) .... abuse it a little ....... full power for the most part ..... the rings will seat faster. Keep a good eye on the cylinder temps .... if they're running cool, lean. If you don't have a CHT probe for each cylinder, I think you should forget the leaning. IMHO, of course. > it's amazing > how fast this thing gets airborne! I also have had the experience of a high > speed taxi turn into the first flight in one of my previous projects. It > turned out great but I can assure you it's an eye opener! > You don't really learn much after one high speed taxi ..... put the pedal to the metal and go fly. Again, IMHO. Linn > Marcus ________________________________________________________________________________
Subject: Misc topics... First flight, Insurance, Rudder lock
Date: Jun 08, 2010
If you like simple and cheap but effective this might work. After strapping back the stick I install this restraint. I used it on my 9A also. On the 9A I started out with the clip installed that others have pics of (holding the rudder pulled completely to the side) but liked this better. Albert Gardner N991RV Yuma, AZ -----Original Message----- Most important question... Any recommendations for a good rudder lock for the -10. I used the spring loaded rod that fits on the rudder pedals for the -7A. Unfortunately, I also now have a 3 inch hole covered with duct tape in the rudder surface of the 7A where this lock failed to hold and the rudder stops broke after the rudder flopped around in the wind. Thanks,Doug ________________________________________________________________________________
Subject: Re: When to run wires/static port etc
Date: Jun 08, 2010
Not a bad idea to install the static ports and tubing now. It is good to do an empty conduit run (Vans sells some pretty good light weight stuff) to the end of the tail cone where your tail strobe and position lights will come out. But you have to know which side to run it up. Antenna wires (VOR and COM) might need to be installed too. Not a big deal to install later. You will have to crawl up there for something later so do not get too concerned about everything now. -------- OSH '10 or Bust Q/B - phase 1 / painting Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300591#300591 ________________________________________________________________________________
Subject: Wing Walk Material
Date: Jun 08, 2010
With new paint on the beast, I have been looking at wing walk materials to protect the paint. ACS has lots of options. There was one long ago comment that was negative on the clear stuff. The old standard 3M black tape seems to be preferred material. I think that the high visibility of the black stuff might be better for keeping guests off of the fuel tank area. Thoughts ? -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300593#300593 ________________________________________________________________________________
Subject: Re: Wing Walk Material
Date: Jun 08, 2010
We just put our 3M from ACS on painted wings without the recommended additional glue and it has a few bubbles forming. I have not tried to get them out yet but would try the glue if I had it to do over . Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300600#300600 ________________________________________________________________________________
Date: Jun 08, 2010
I would use the special glue. I put some of the ACS wing walk material on an RV-7 wing a few years ago. The edges started pealing up. I didn't try the special glue at the time, but definitely would in the future. ~Nick Helsper On Tue, Jun 8, 2010 at 5:57 PM, Ron B. wrote: > > We just put our 3M from ACS on painted wings without the recommended > additional glue and it has a few bubbles forming. I have not tried to get > them out yet but would try the glue if I had it to do over . > Ron > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300600#300600 > > ________________________________________________________________________________
Date: Jun 08, 2010
Mike, The clear stuff we used works great. We added an outline to define the step area but many passengers don=92t seem to be able to color within the lines. Also of note dirty wet shoes do show on the clear wing walk. It is easy to wipe off but if it were black you eliminate one more thing to spiff up. If I were to do it again I would have painted the skid the same color as my outline (steel blue-ish). Robin [image: http://painttheweb.com/painttheweb/rv-10/Images/Paint/Wing%20Walk.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Tuesday, June 08, 2010 3:20 PM Subject: RV10-List: Wing Walk Material With new paint on the beast, I have been looking at wing walk materials to protect the paint. ACS has lots of options. There was one long ago comment that was negative on the clear stuff. The old standard 3M black tape seems to be preferred material. I think that the high visibility of the black stuff might be better for keeping guests off of the fuel tank area. Thought s ? -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300593#300593 ________________________________________________________________________________
Subject: Re: cabin top paint
Date: Jun 08, 2010
I painted cabin top using paint from a local auto paint supplier. Came out nice. A bit glossier than I wanted, but it was what they recommended and looks nice. Had them color-match the leather and it is near perfect. Dwight Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300611#300611 ________________________________________________________________________________
Subject: performance
Date: Jun 08, 2010
Any real life performance specs for your 10. The only reference i have is a 5200MSL @80F and 2800 pounds and flaps 15. ground roll was 2500 feet as measured by the tower. I plan to operate into a 6000MSL airport at 2400 pounds and temp of 15C, winds are forecast to be <5kts. For these conditions a Piper Dakota (O540@250HP) at 2400# is expected to have a ground roll of about 1400 feet and about 2500 to clear a 50' obstacle. The runway has a bump in it at the 1500 foot postion from the end of 24. total runway lengh is 4800 feet. I have been into this aiport one other time in the Glastar in winter; weight was 1900# and O360A4M (180HP) with fixed pitch prop. we landed 6 and had 3300 feet to operate before the bump. Departure was from 6 and not a problem. ________________________________________________________________________________
Subject: Re: Misc topics... First flight, Insurance, Rudder lock
Date: Jun 08, 2010
No pics, but I have come up with a rudder lock system very similar to Alberts and it works quite well. I thought about building one of the locking systems out of PVC pipe that goes around the whole vert. stab and rudder, but really did not want to carry that around in the airplane. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300626#300626 ________________________________________________________________________________
Subject: Preserving fiberglass
Date: Jun 08, 2010
I am finishing the wheel pants and fairings, then the cowling is last before the move to the hanger. I am not painting the plane until after the fly-off period (a choice made due to lack of paint shops in the area and an extensive back log, nothing else) The plane will also live in a hanger. At the risk of inciting something similar to primer wars, what have people in a similar situation done to preserve the fiberglass from any wear due to UV effect or the elements? Will my personal choice in aircraft primer suffice until paint, or should I go as far as gel coating? As with much of the build this falls under personal preference but want to feel out the group to see what others before me have done. Thanks. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300627#300627 ________________________________________________________________________________
Subject: Re: Preserving fiberglass
Date: Jun 08, 2010
get a primer that has UV protection. That's all you need to do, when you're ready to paint clean the parts, sand it down and if needed reprime lightly than paint. By priming you'll also take care of the pin holes now versus later when you're flying. -------------------------------------------------- From: "Eric_Kallio" <scout019(at)msn.com> Sent: Tuesday, June 08, 2010 6:04 PM Subject: RV10-List: Preserving fiberglass > > I am finishing the wheel pants and fairings, then the cowling is last > before the move to the hanger. I am not painting the plane until after the > fly-off period (a choice made due to lack of paint shops in the area and > an extensive back log, nothing else) The plane will also live in a hanger. > At the risk of inciting something similar to primer wars, what have people > in a similar situation done to preserve the fiberglass from any wear due > to UV effect or the elements? Will my personal choice in aircraft primer > suffice until paint, or should I go as far as gel coating? As with much of > the build this falls under personal preference but want to feel out the > group to see what others before me have done. Thanks. > > Eric Kallio > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300627#300627 > > > ________________________________________________________________________________
Date: Jun 08, 2010
Bob Leffler wrote: > > Linn, > > > > Give Geoff Combs a call. I don't know if you have his overhead or not, > Gonna roll my own .... getting ready to lay up the glass. > > but he's got some other items in the works that you may be interested > in. One will save you some painting. > Is he the one doing the plastic interior? Does he have a web site??? Linn > > > Bob > > > > > ________________________________________________________________________________
Date: Jun 08, 2010
The UV protection in a primer protects the paint, not the fiberglass. You need a primer that obstructs all light. ~Nick Helsper On Tue, Jun 8, 2010 at 8:43 PM, Pascal wrote: > > get a primer that has UV protection. That's all you need to do, when you're > ready to paint clean the parts, sand it down and if needed reprime lightly > than paint. By priming you'll also take care of the pin holes now versus > later when you're flying. > > -------------------------------------------------- > From: "Eric_Kallio" <scout019(at)msn.com> > Sent: Tuesday, June 08, 2010 6:04 PM > To: > Subject: RV10-List: Preserving fiberglass > >> >> I am finishing the wheel pants and fairings, then the cowling is last >> before the move to the hanger. I am not painting the plane until after the >> fly-off period (a choice made due to lack of paint shops in the area and an >> extensive back log, nothing else) The plane will also live in a hanger. At >> the risk of inciting something similar to primer wars, what have people in a >> similar situation done to preserve the fiberglass from any wear due to UV >> effect or the elements? Will my personal choice in aircraft primer suffice >> until paint, or should I go as far as gel coating? As with much of the build >> this falls under personal preference but want to feel out the group to see >> what others before me have done. Thanks. >> >> Eric Kallio >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=300627#300627 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jun 08, 2010
I had planned on the UV Smooth prime as a filler/primer unless better suggestions were presented, but I left the name out of my original post until I had a chance to get some flame proof underwear on. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300643#300643 ________________________________________________________________________________
Date: Jun 08, 2010
Only when the plane losses its lid and it lays upside down sitting in the s un Date: Tue=2C 8 Jun 2010 20:54:31 -0500 Subject: Re: RV10-List: Preserving fiberglass From: nickhelsper(at)gmail.com The UV protection in a primer protects the paint=2C not the fiberglass. Yo u need a primer that obstructs all light. ~Nick Helsper On Tue=2C Jun 8=2C 2010 at 8:43 PM=2C Pascal wrot e: get a primer that has UV protection. That's all you need to do=2C when you' re ready to paint clean the parts=2C sand it down and if needed reprime lig htly than paint. By priming you'll also take care of the pin holes now vers us later when you're flying. -------------------------------------------------- From: "Eric_Kallio" <scout019(at)msn.com> Sent: Tuesday=2C June 08=2C 2010 6:04 PM Subject: RV10-List: Preserving fiberglass I am finishing the wheel pants and fairings=2C then the cowling is last bef ore the move to the hanger. I am not painting the plane until after the fly -off period (a choice made due to lack of paint shops in the area and an ex tensive back log=2C nothing else) The plane will also live in a hanger. At the risk of inciting something similar to primer wars=2C what have people i n a similar situation done to preserve the fiberglass from any wear due to UV effect or the elements? Will my personal choice in aircraft primer suffi ce until paint=2C or should I go as far as gel coating? As with much of the build this falls under personal preference but want to feel out the group to see what others before me have done. Thanks. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300627#300627 -= Use the Matronics List Features Navigator to browse s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navig ator?RV10-List ronics.com/" target="_blank">http://forums.matronics.com Matt Dralle=2C List Admin. ==== ________________________________________________________________________________
Subject: Re: wtb IO540 starter ring gear & support
Date: Jun 08, 2010
Would be interested in finding out the part number he has, if it's the right one, I would like it. I'm waiting for my parts manual to arrive to be sure of the number I need. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=300650#300650 ________________________________________________________________________________
Date: Jun 08, 2010
Ummm. WHAT??? Eric just prime with a primer with UV protection like Dupont prime and sand. It will last plenty long until you paint. Rick N246RS Sent from my iPhone On Jun 8, 2010, at 6:54 PM, Helsper wrote: > The UV protection in a primer protects the paint, not the > fiberglass. You need a primer that obstructs all light. > > ~Nick Helsper > > On Tue, Jun 8, 2010 at 8:43 PM, Pascal > wrote: > > get a primer that has UV protection. That's all you need to do, when > you're ready to paint clean the parts, sand it down and if needed > reprime lightly than paint. By priming you'll also take care of the > pin holes now versus later when you're flying. > > -------------------------------------------------- > From: "Eric_Kallio" <scout019(at)msn.com> > Sent: Tuesday, June 08, 2010 6:04 PM > To: > Subject: RV10-List: Preserving fiberglass > > > I am finishing the wheel pants and fairings, then the cowling is > last before the move to the hanger. I am not painting the plane > until after the fly-off period (a choice made due to lack of paint > shops in the area and an extensive back log, nothing else) The plane > will also live in a hanger. At the risk of inciting something > similar to primer wars, what have people in a similar situation done > to preserve the fiberglass from any wear due to UV effect or the > elements? Will my personal choice in aircraft primer suffice until > paint, or should I go as far as gel coating? As with much of the > build this falls under personal preference but want to feel out the > group to see what others before me have done. Thanks. > > Eric Kallio > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=300627#300627 > > -= Use the Matronics List Features Navigator to browse > s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ronics.com/" target="_blank">http://forums.matronics.com > Matt Dralle, List Admin. > ==== > >
May 24, 2010 - June 09, 2010
RV10-Archive.digest.vol-gn
