RV10-Archive.digest.vol-ha
October 04, 2010 - Present
      http://forums.matronics.com/viewtopic.php?p=314705#314705
Subject: Re: winter flying
Date: Oct 04, 2010
I have Eric's device in my plane. I live in NH. It really helps in the winter. Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ivankris Sent: Monday, October 04, 2010 6:49 PM Subject: RV10-List: Re: winter flying Give Eric Faires of Nonstop Aviation a call 256-710-6120 here is a link to his website for a 4" valve that fits in the plenum to the oil cooler. http://www.nonstopaviation.com/rv10-parts-c-1337.html -------- Ivan K. www.ivankristensen.com Builder # 40838 Flying (60 hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314693#314693 CyberDefender has scanned this email for potential threats. Version 2.0 / Build 4.03.29.01 Get free PC security at www.cyberdefender.com ________________________________________________________________________________
Date: Oct 04, 2010
Subject: Re: TMXIO-540 and GAMI injectors
Obviously #3 and #5 are your outliers. The question is why. I'd see what GAMI has to say on the data. Somehow, either the injector on 5 isn't what it says it is, or the cylinder is getting significantly more air some how. Is the engine rough when you get all the way to #3 peaking? On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler wrote: > > Kelly, > My flow divider went out to Mattituck and was cleaned and sent back and I > was told it was all set. I flew the plane with the GAMIs cylinder 5 with > the > J(richest injector) and cylinder 3 with the A (leanest injector). > My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 at > 11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and > cylinder 6 at 11.4. > As you can see this is similar to what I had before the fuel divider was > serviced. Any thoughts on what is going on? > Alan > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Mekler > Sent: Saturday, August 28, 2010 5:35 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: TMXIO-540 and GAMI injectors > > > Kelly, > I see your point. I'll stay on the ground this weekend. > Alan > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Saturday, August 28, 2010 5:20 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TMXIO-540 and GAMI injectors > > > Alan, > Let me politely, but violently disagree with your A&P. Something is > blocking > flow in your flow divider. You have proved that. What you and your A&P can > NOT assure is that whatever is blocking the flow won't move and completely > stop the flow. You cannot be assured of stable fuel flow. That is why you > should NOT fly it until it is fixed. I'm sure Mattituck will make it right, > pronto. > Kelly > A&P/IA > EAA Tech Counselor > > On Sat, Aug 28, 2010 at 2:05 PM, Alan Mekler > wrote: > > > > Tim, > > I was not the builder of my plane. My A&P also an AI has done all the > > trouble shooting. EGT spread is less than 50 degrees when flying 100 > degrees > > rich of peak.(that's how I have been flying it) At full throttle > > cylinder > #1 > > runs hotter than cylinder #5. My mechanic called Mattituck because > > they > are > > the Precision Service center closest to us and Mattituck has been > > trouble shooting the problem with us. The engine only has 100 hours > > and is still under warranty. There is no engine roughness unless I try > > flying lean of peak. > > My A&P saw no problem with flying the airplane. I'll know more on > > Monday when we hear from Mattituck but it is most likely we will send > > the unit in for service. > > Alan > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at www.cyberdefender.com > > ________________________________________________________________________________
Subject: TMXIO-540 and GAMI injectors
Date: Oct 04, 2010
Kelly, Everything pointed to the fuel flow divider and this was sent out and serviced but despite trying to get cylinder 3 to run leaner and cylinder 5 to run richer the GAMIs have failed. The only other thought I had was that maybe the EGT probes were swapped on cylinder 3 and 5??? Alan _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, October 04, 2010 8:58 PM Subject: Re: RV10-List: TMXIO-540 and GAMI injectors Obviously #3 and #5 are your outliers. The question is why. I'd see what GAMI has to say on the data. Somehow, either the injector on 5 isn't what it says it is, or the cylinder is getting significantly more air some how. Is the engine rough when you get all the way to #3 peaking? On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler wrote: Kelly, My flow divider went out to Mattituck and was cleaned and sent back and I was told it was all set. I flew the plane with the GAMIs cylinder 5 with the J(richest injector) and cylinder 3 with the A (leanest injector). My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 at 11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and cylinder 6 at 11.4. As you can see this is similar to what I had before the fuel divider was serviced. Any thoughts on what is going on? Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Mekler Sent: Saturday, August 28, 2010 5:35 PM Subject: RE: RV10-List: TMXIO-540 and GAMI injectors Kelly, I see your point. I'll stay on the ground this weekend. Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, August 28, 2010 5:20 PM Subject: Re: RV10-List: TMXIO-540 and GAMI injectors Alan, Let me politely, but violently disagree with your A&P. Something is blocking flow in your flow divider. You have proved that. What you and your A&P can NOT assure is that whatever is blocking the flow won't move and completely stop the flow. You cannot be assured of stable fuel flow. That is why you should NOT fly it until it is fixed. I'm sure Mattituck will make it right, pronto. Kelly A&P/IA EAA Tech Counselor On Sat, Aug 28, 2010 at 2:05 PM, Alan Mekler wrote: > > Tim, > I was not the builder of my plane. My A&P also an AI has done all the > trouble shooting. EGT spread is less than 50 degrees when flying 100 degrees > rich of peak.(that's how I have been flying it) At full throttle > cylinder #1 > runs hotter than cylinder #5. My mechanic called Mattituck because > they are > the Precision Service center closest to us and Mattituck has been > trouble shooting the problem with us. The engine only has 100 hours > and is still under warranty. There is no engine roughness unless I try > flying lean of peak. > My A&P saw no problem with flying the airplane. I'll know more on > Monday when we hear from Mattituck but it is most likely we will send > the unit in for service. > Alan CyberDefender has scanned this email for potential threats. Version 2.0 / Build 4.03.29.01 Get free PC security at www.cyberdefender.com ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== CyberDefender has scanned this email for potential threats. Version 2.0 / Build 4.03.29.01 Get free PC security at http://www.cyberdefender.com <http://www.cyberdefender.com> ________________________________________________________________________________
Subject: Nosewheel Mod
Date: Oct 04, 2010
Hi Ages ago I seem to remember seeing a nose wheel mod that kept a tow bar from penetrating the nose wheel pant. Rather it had a washed and elongated bolt that kept the tow bar outside of the wheel pant and prevented damage due to improper insertion. Does anyone have a link to this - I can't seem to find it in the archives. Manny thanks Les #40643 ________________________________________________________________________________
Subject: Door Operation
Date: Oct 04, 2010
Hi I have been meaning to post this question for months but kept forgetting. Here goes - when I unlatch one of my doors, the strut pushes the door open on its own. The other door needs to be opened a couple of inches before the strut opens it the rest of the way. What is the "proper" way for the door to open - unlatch and it goes up by itself or unlatch and push open before the strut takes over. Inquiring minds need to know Les #40643 ________________________________________________________________________________
Subject: Re: Nosewheel Mod
Date: Oct 04, 2010
It's there, and I just converted mine over this past weekend. Use a 3/8 x 2 1/2 inch long box head bolt with a body style big washer on it to stop the tow bar ears from going too far towards the pants. You also have to use about a 1/2 inch long sleeve between the bold head and the aluminum trianglular block that holds the front of the wheel pant support. I found a 1 inch long solid bronze insert and cut it in two pieces. You might look at your threads closely. Mine were fine (24) threads and one had started to strip, so based on long time A&P comments, I drilled out and used heli coil inserts so I could use coarse (16) threads. He said aluminum should use coarse threads, not fine. I'll try to take a picture tomorrow. grumpy On Oct 4, 2010, at 8:14 PM, Les Kearney wrote: > Hi > > Ages ago I seem to remember seeing a nose wheel mod that kept a tow > bar from penetrating the nose wheel pant. Rather it had a washed and > elongated bolt that kept the tow bar outside of the wheel pant and > prevented damage due to improper insertion. > > Does anyone have a link to this - I can't seem to find it in the > archives. > > Manny thanks > > Les > #40643 > > ________________________________________________________________________________
Date: Oct 04, 2010
Grazi ..Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John Sent: October-04-10 7:53 PM Subject: Re: RV10-List: Nosewheel Mod It's there, and I just converted mine over this past weekend. Use a 3/8 x 2 1/2 inch long box head bolt with a body style big washer on it to stop the tow bar ears from going too far towards the pants. You also have to use about a 1/2 inch long sleeve between the bold head and the aluminum trianglular block that holds the front of the wheel pant support. I found a 1 inch long solid bronze insert and cut it in two pieces. You might look at your threads closely. Mine were fine (24) threads and one had started to strip, so based on long time A&P comments, I drilled out and used heli coil inserts so I could use coarse (16) threads. He said aluminum should use coarse threads, not fine. I'll try to take a picture tomorrow. grumpy On Oct 4, 2010, at 8:14 PM, Les Kearney wrote: Hi Ages ago I seem to remember seeing a nose wheel mod that kept a tow bar from penetrating the nose wheel pant. Rather it had a washed and elongated bolt that kept the tow bar outside of the wheel pant and prevented damage due to improper insertion. Does anyone have a link to this - I can't seem to find it in the archives. Manny thanks Les #40643 href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Oct 04, 2010
Certainly a possibility, since they are adjacent cylinders. Does the engine behave like it has a lot of imbalance between cylinders or no? I'd certainly try swapping those two probes. It will tell you if they are reading correctly or are swapped. Something is swapped, because your results are the reverse of what you would expect with those nozzles. Other option, if easier, would be to swap injector nozzles between those two cylinders. It will either get a lot better or a lot worse. On 10/4/2010 9:16 PM, Alan Mekler wrote: > > Kelly, > > Everything pointed to the fuel flow divider and this was sent out and > serviced but despite trying to get cylinder 3 to run leaner and > cylinder 5 to run richer the GAMIs have failed. The only other thought > I had was that maybe the EGT probes were swapped on cylinder 3 and 5??? > > Alan > > ------------------------------------------------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly > McMullen > *Sent:* Monday, October 04, 2010 8:58 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: TMXIO-540 and GAMI injectors > > Obviously #3 and #5 are your outliers. The question is why. I'd see > what GAMI has to say on the data. Somehow, either the injector on 5 > isn't what it says it is, or the cylinder is getting significantly > more air some how. Is the engine rough when you get all the way to #3 > peaking? > > On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler > wrote: > > > > > Kelly, > My flow divider went out to Mattituck and was cleaned and sent back and I > was told it was all set. I flew the plane with the GAMIs cylinder 5 > with the > J(richest injector) and cylinder 3 with the A (leanest injector). > My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 at > 11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and > cylinder 6 at 11.4. > As you can see this is similar to what I had before the fuel divider was > serviced. Any thoughts on what is going on? > Alan > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Alan Mekler > Sent: Saturday, August 28, 2010 5:35 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: TMXIO-540 and GAMI injectors > > > > > Kelly, > I see your point. I'll stay on the ground this weekend. > Alan > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Kelly McMullen > Sent: Saturday, August 28, 2010 5:20 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TMXIO-540 and GAMI injectors > > > > > Alan, > Let me politely, but violently disagree with your A&P. Something is > blocking > flow in your flow divider. You have proved that. What you and your A&P can > NOT assure is that whatever is blocking the flow won't move and completely > stop the flow. You cannot be assured of stable fuel flow. That is why you > should NOT fly it until it is fixed. I'm sure Mattituck will make it > right, > pronto. > Kelly > A&P/IA > EAA Tech Counselor > > On Sat, Aug 28, 2010 at 2:05 PM, Alan Mekler > wrote: > > > > > > Tim, > > I was not the builder of my plane. My A&P also an AI has done all the > > trouble shooting. EGT spread is less than 50 degrees when flying 100 > degrees > > rich of peak.(that's how I have been flying it) At full throttle > > cylinder > #1 > > runs hotter than cylinder #5. My mechanic called Mattituck because > > they > are > > the Precision Service center closest to us and Mattituck has been > > trouble shooting the problem with us. The engine only has 100 hours > > and is still under warranty. There is no engine roughness unless I try > > flying lean of peak. > > My A&P saw no problem with flying the airplane. I'll know more on > > Monday when we hear from Mattituck but it is most likely we will send > > the unit in for service. > > Alan > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at www.cyberdefender.com > <http://www.cyberdefender.com> > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at http://www.cyberdefender.com > <http://www.cyberdefender.com> > * > > > * ________________________________________________________________________________
Subject: Re: Door Operation
Date: Oct 04, 2010
I think it also depends a lot on the weight of the door after interior finishing and the age of the struts. Early before the interior, the struts were just about right assisting the opening. Now after interior and 300 hours they need "help" opening the door and just barely keep it open. Others on the list have said Van has a higher pressure "HD" version which I will probably try. Dick Sipp N110DV ________________________________________________________________________________
Date: Oct 05, 2010
Subject: Enderes screwdriver redux - the perfect screwdriver
Previously I posted this: *Match: * */#4/* *Message: * */#28437/* *Date: * */Aug 28, 2010/* *From: * */Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>/* *Subject: * /*Tool question - anyone familiar with Enderes tools? <http://www.matronics.com/searching/getmsg_script.cgi?INDEX=78557902?KEYS=enderes?LISTNAME=RV10?HITNUMBER=4?SERIAL=22105026768?SHOWBUTTONS=NO>*/ * I have this one long shaft phillips head screwdriver that keeps falling into my hands. It seems to be a #1 phillips but actually works better than both my #1 and #2 Craftsman drivers. Probably inherited it from my Dad's shop. It's rusty and looks like hell so I'm never drawn to it... until I'm struggling with some screw. I always end up with this one in my hand and the problem is solved. I've looked Enderes up on the Web and see they forge tools and blah blah. Any tool knowledgeable people out there know anything about Enderes? I think I want to try some more. * So I've gone to the company web site with the intent of buying a few shorter models than the 10" one I have. Their pricing makes it clear that the best way to get one or two is to find an old school hardware store that carries them. I found one 2 miles down the road but they only had regular Enderes drivers in stock, no Phillips. Then a Google search turned up this little gem of a story from the year 2000 on an old school Web site called "Everything2". I was amazed! http://everything2.com/index.pl?node=the+perfect+screwdriver&lastnode_id=1797151&searchy=search This is the exact screwdriver I've been lusting after! I will be a very happy camper if I can get a set of Enderes Phillips drivers in the shorter sizes. Maybe I'll just pay the $30 including $10 of shipping for a set of 3 from the factory. With all the screws on our planes, it's nice to have the 'perfect screwdriver' even if there is no such thing. But I'm telling you, this one works MUCH better than my Craftsman drivers. Bill "enjoying the paint" Watson ________________________________________________________________________________
Date: Oct 05, 2010
Subject: My first question, WD-415 related
So there you go, my first question and that kit has not even arrived! I checked the archives and found references for the aftermarket WD-415 replacement to be found from Clevelandtools and http://www.rivethead-aero.com/. Later is no longer online and on the Clevelandtools shop I could not fin it. Any help for locating it please? Many thanks Werner Glastar #5794 HB-YKP RV-10 #41122 on order ________________________________________________________________________________
Date: Oct 05, 2010
Kelly, Thanks for the advice. I'll keep you posted. Here is an excel spread sheet of that last flight. Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, October 04, 2010 10:27 PM Subject: Re: RV10-List: TMXIO-540 and GAMI injectors Certainly a possibility, since they are adjacent cylinders. Does the engine behave like it has a lot of imbalance between cylinders or no? I'd certainly try swapping those two probes. It will tell you if they are reading correctly or are swapped. Something is swapped, because your results are the reverse of what you would expect with those nozzles. Other option, if easier, would be to swap injector nozzles between those two cylinders. It will either get a lot better or a lot worse. On 10/4/2010 9:16 PM, Alan Mekler wrote: > > Kelly, > > Everything pointed to the fuel flow divider and this was sent out and > serviced but despite trying to get cylinder 3 to run leaner and > cylinder 5 to run richer the GAMIs have failed. The only other thought > I had was that maybe the EGT probes were swapped on cylinder 3 and 5??? > > Alan > > ---------------------------------------------------------------------- > -- > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly > McMullen > *Sent:* Monday, October 04, 2010 8:58 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: TMXIO-540 and GAMI injectors > > Obviously #3 and #5 are your outliers. The question is why. I'd see > what GAMI has to say on the data. Somehow, either the injector on 5 > isn't what it says it is, or the cylinder is getting significantly > more air some how. Is the engine rough when you get all the way to #3 > peaking? > > On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler > wrote: > > > > > Kelly, > My flow divider went out to Mattituck and was cleaned and sent back > and I was told it was all set. I flew the plane with the GAMIs > cylinder 5 with the J(richest injector) and cylinder 3 with the A > (leanest injector). > My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 > at > 11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and > cylinder 6 at 11.4. > As you can see this is similar to what I had before the fuel divider > was serviced. Any thoughts on what is going on? > Alan > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Alan > Mekler > Sent: Saturday, August 28, 2010 5:35 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: TMXIO-540 and GAMI injectors > > > > > Kelly, > I see your point. I'll stay on the ground this weekend. > Alan > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Kelly > McMullen > Sent: Saturday, August 28, 2010 5:20 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TMXIO-540 and GAMI injectors > > > > > Alan, > Let me politely, but violently disagree with your A&P. Something is > blocking flow in your flow divider. You have proved that. What you and > your A&P can NOT assure is that whatever is blocking the flow won't > move and completely stop the flow. You cannot be assured of stable > fuel flow. That is why you should NOT fly it until it is fixed. I'm > sure Mattituck will make it right, pronto. > Kelly > A&P/IA > EAA Tech Counselor > > On Sat, Aug 28, 2010 at 2:05 PM, Alan Mekler > wrote: > > --> > > > > > Tim, > > I was not the builder of my plane. My A&P also an AI has done all > > the trouble shooting. EGT spread is less than 50 degrees when flying > > 100 > degrees > > rich of peak.(that's how I have been flying it) At full throttle > > cylinder > #1 > > runs hotter than cylinder #5. My mechanic called Mattituck because > > they > are > > the Precision Service center closest to us and Mattituck has been > > trouble shooting the problem with us. The engine only has 100 hours > > and is still under warranty. There is no engine roughness unless I > > try flying lean of peak. > > My A&P saw no problem with flying the airplane. I'll know more on > > Monday when we hear from Mattituck but it is most likely we will > > send the unit in for service. > > Alan > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at www.cyberdefender.com > <http://www.cyberdefender.com> > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at http://www.cyberdefender.com > <http://www.cyberdefender.com> > * > > > * CyberDefender has scanned this email for potential threats. Version 2.0 / Build 4.03.29.01 Get free PC security at www.cyberdefender.com ________________________________________________________________________________
Subject: Re: California coast via RV10? - Follow-up
Date: Oct 05, 2010
I fly over the hill to do business in SF frequently. I like Marin's Gnoss field that I flew out of for many years. The gas is cheaper at the self service in Petaluma just north of Gnoss, but Gnoss is closer to SF. Hertz (and I believe Enterprise) will pick you up to get your rental car at Gnoss. I always use Hertz. Oakland used to be great (Kaiser Air) but now VERY expensive. Gnoss has lots of tie downs. Parking is cheap $6 and is quite safe plus they have a night security guard. Be sure to park facing west. The hotels in Marin are cheaper ($100/night) and quieter than in SF. I like the Marriott Courtyard -Larkspur and the Extended Stay America San Rafael. If you book direct both have a 6:00PM free cancel policy - good if you are flying. Things to do in Marin or on the way to SF - Muir Woods, Sausalito, Whale watching at Pt. Reyes (1.5 hr drive to the point), and Ferry ride into SF from Larkspur. I would just fly down to Monterey rather than back-track unless you put down and stay at Reid-Hillview in San Jose -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314759#314759 ________________________________________________________________________________
Subject: Re: Enderes screwdriver redux - the perfect screwdriver
Date: Oct 05, 2010
The biggest problem is the head of the Phillips driver - rolling out of the screw head and buggering the screw. A few years ago my former plane partner showed me something called the "X" head screwdriver. They are hard to find, but I located some at Snap-on at OSH a few years back. (just driver tips) They have 2 or 3 tiny but distinctive ridges or cuts on the side of the tip that seem to really grip the Phillips head channels. I did a few hundred screws yesterday - doing my annual and buggered only 2 screws. -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314760#314760 ________________________________________________________________________________
Date: Oct 05, 2010
Tim, For #1 & #2, I would say Watsonville. KWVI. It is in the middle of Monterey Bay. On the north side of the bay is Santa Cruz with its beaches and boardwalk and on the south side, Monterey/Carmel. >From WVI, San Francisco is about 80 mi. You can take the coast road (Hwy 1) for some great ocean views or up the SF bay (101 or 280) or up one and back the other. One last item, if you were to have any maintenance issues, Dave at Air Crafters is located on WVI. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314761#314761 ________________________________________________________________________________
Date: Oct 05, 2010
Hey Les, Here's the link to my previous post : http://forums.matronics.com/viewtopic.php?t=71126&highlight=studs The hangar guys still love it, paint still looks good! Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314764#314764 ________________________________________________________________________________
Date: Oct 05, 2010
Oh yeah, I didn't make it clear in the original post -- the washer backing the head is just less than the diameter of the hole in the fiberglass so that no metal touches the glass. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314765#314765 ________________________________________________________________________________
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Date: Oct 05, 2010
Subject: Re: My first question, WD-415 related
Try iflyrv10.com Bob ----- Original Message ----- From: Werner Schneider [mailto:glastar(at)gmx.net] Sent: Monday, October 04, 2010 11:13 PM Subject: RV10-List: My first question, WD-415 related So there you go, my first question and that kit has not even arrived! I checked the archives and found references for the aftermarket WD-415 replacement to be found from Clevelandtools and http://www.rivethead-aero.com/. Later is no longer online and on the Clevelandtools shop I could not fin it. Any help for locating it please? Many thanks Werner Glastar #5794 HB-YKP RV-10 #41122 on order ________________________________________________________________________________
Date: Oct 05, 2010
The brackets that came in my kit had a good solid weld joint but need to be attached with #6 screws instead of pop rivets. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Grayson, KY Bldr# 40983 Ord complete kit 8/24/09; DB Sch del 11/20/09 Emp 12/01/09-3/14/10 332 hrs Wings 3/14/10-9/18/10 360 hrs Fuselage 9/21/10- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314768#314768 ________________________________________________________________________________
Subject: Re: Just wishing you RV-10 builders a Merry Christmas
Date: Oct 05, 2010
to do my top cover/doors for Christmas. Looking forward to that about like the fuel tanks. But then once finished with the tanks...it was not so bad. I hope I can say that about the fg work. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Grayson, KY Bldr# 40983 Ord complete kit 8/24/09; DB Sch del 11/20/09 Emp 12/01/09-3/14/10 332 hrs Wings 3/14/10-9/18/10 360 hrs Fuselage 9/21/10- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314770#314770 ________________________________________________________________________________
Date: Oct 05, 2010
Subject: 1st answered 2nd question about rudder trim
Thanks a lot Bob, exactly what I did need. Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? Cheers Werner On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: > --> RV10-List message posted by: "Condrey, Bob (US SSA)" > > Try iflyrv10.com > > Bob ________________________________________________________________________________
Date: Oct 05, 2010
Thanks, Lew. Les, mine look just like Lew's except my big washer is a shiny one. grumpy On Oct 5, 2010, at 6:46 AM, Lew Gallagher wrote: > > Hey Les, > > Here's the link to my previous post : http://forums.matronics.com/viewtopic.php?t=71126&highlight=studs > > The hangar guys still love it, paint still looks good! > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=314764#314764 > > ________________________________________________________________________________
Date: Oct 05, 2010
Try Iflyrv10.com David Maib 40559 flying On Oct 5, 2010, at 1:13 AM, Werner Schneider wrote: > > So there you go, > > my first question and that kit has not even arrived! > > I checked the archives and found references for the aftermarket WD-415 replacement to be found from Clevelandtools and http://www.rivethead-aero.com/. Later is no longer online and on the Clevelandtools shop I could not fin it. > > Any help for locating it please? > > Many thanks > > Werner > > Glastar #5794 HB-YKP > RV-10 #41122 on order > > > > ________________________________________________________________________________
Date: Oct 05, 2010
Yep, that's it. Rolling out of the head is the problem and it's what this driver tends not to do. Even at an angle. I don't know if this driver has that feature but I'm going to check. If the "x" thing is the trick, I'll have to get some for my little powered drivers. As mentioned before, Costco has one at $20 which seems to be 50% of what it costs everywhere else. Nice unit. I just ordered 3 drivers and they are on their way.....one small step for this project, one giant leap for my tool box. And I'm happy. Enderes was reselling a 15 in 1 ratcheting driver that I'd like to get but it seems to be out of stock in all channels. Will keep an eye out for it. Bill On 10/5/2010 7:26 AM, AirMike wrote: > --> RV10-List message posted by: "AirMike" > > The biggest problem is the head of the Phillips driver - rolling out of the screw head and buggering the screw. > > A few years ago my former plane partner showed me something called the "X" head screwdriver. They are hard to find, but I located some at Snap-on at OSH a few years back. (just driver tips) They have 2 or 3 tiny but distinctive ridges or cuts on the side of the tip that seem to really grip the Phillips head channels. I did a few hundred screws yesterday - doing my annual and buggered only 2 screws. > > ________________________________________________________________________________
Date: Oct 05, 2010
I found bosch brand driver tips work good too, they have the ridges too. At my Lowes. Chris Lucas #40072 prepping for paint ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Tuesday, October 5, 2010 7:26:14 AM Subject: RV10-List: Re: Enderes screwdriver redux - the perfect screwdriver The biggest problem is the head of the Phillips driver - rolling out of the screw head and buggering the screw. A few years ago my former plane partner showed me something called the "X" head screwdriver. They are hard to find, but I located some at Snap-on at OSH a few years back. (just driver tips) They have 2 or 3 tiny but distinctive ridges or cuts on the side of the tip that seem to really grip the Phillips head channels. I did a few hundred screws yesterday - doing my annual and buggered only 2 screws. -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314760#314760 ________________________________________________________________________________
Date: Oct 05, 2010
On Mon, Oct 4, 2010 at 8:20 PM, Tim Olson wrote: > > Hey all, > > Thanks for the great replies to my question about flying the > West Coast. My trip is coming up quick now, and the info you > all gave was valuable. Andrea called today and found out that > Whale Watching is good right now. The hard part is that some > locations only do weekends, and some do weekdays, so we're > trying to pray for good weather and hope all the plans work > out accordingly. > > I do have a follow-up couple of questions.... > > 1) When doing our touring around San Francisco, which > airport do you locals recommend I park at...a place that's > handy enough that I can get a rental car, and nice > enough that fuel isn't gouging and the plane will be safe? > I am _far_ from an expert on this, but... SJC (at Atlantic Aviation) is probably the most expensive, but also probably the easiest to get a rental car and "safest". They are used to serving the folks in jets, so you get high service at high prices. They can also put your plane in a hangar for a fee. PAO is nice and centrally located, but I think fuel prices are not cheap. I'd guess that RHV is probably the cheapest option in the area, don't know about rental cars there. Other choices I know less about: SQL, OAK, HWD. > 2) How about if I spend a day or three between San Francisco > and Monterey....where should I land for Monterey, or should > I just use one airport and drive to both places? > I've been to Monterey airport, and it is pretty nice. Not the cheapest option for fuel 'tho. > > FWIW: Monterey is the most accessible for Whale Watching from > a logistical perspective as far as who's open on what days, > and they've been seeing them lately. Wish I could see the > Orcas but I think that would require perhaps going to > the Seattle area and I'm not sure that's going to work > for sure on this trip. > > 3) I got good tips for where to stay if we go back by > San Diego and have to stay there, but what place to the > north of L.A. would be good and GA friendly if we need > something? > > Other than the "where to stay" questions, it all seems to > be looking pretty good. I don't make hotel plans in advance, > since an RV-10 can easily take you to a whole different > location in a short time if you can't find something. > We're just doing the usual "winging it"...going to land, > get a car, use the ipad or iphone to locate a hotel, > and then start touring around. > > Oh, and if we do try to go Kayaking or something in > the Monterey area, I'm guessing that 5/4mm wetsuits > isn't quite good enough, eh? If not, we'll maybe > just leave them at home. It's been too many cheeseburgers > since I've tried my 7mm suit. :) > I went kayaking recently in the Elkhorn Slough. It seems that all of the rental companies around there will rent you full jackets, skirts, etc. as a part of the package. So no need to bring a wetsuit. (I went with www.montereybaykayaks.com.) Chris ________________________________________________________________________________
Date: Oct 05, 2010
Subject: Re: 1st answered 2nd question about rudder trim
Mine works very well. Would not fly without it. Putting one in my 8A now. http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx Robin Sent from my iPad On Oct 5, 2010, at 5:41 AM, Werner Schneider wrote: > > Thanks a lot Bob, exactly what I did need. > > Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? > > Cheers Werner > > On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >> --> RV10-List message posted by: "Condrey, Bob (US SSA)" >> >> Try iflyrv10.com >> >> Bob > > ________________________________________________________________________________
Date: Oct 05, 2010
Thanks a lot Robin, any idea how much deflection you use normally? Cheers Werner On 05.10.2010 17:49, Robin Marks wrote: > --> RV10-List message posted by: Robin Marks > > Mine works very well. Would not fly without it. Putting one in my 8A now. > > http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx > > Robin > > Sent from my iPad > > On Oct 5, 2010, at 5:41 AM, Werner Schneider wrote: > >> --> RV10-List message posted by: Werner Schneider >> >> Thanks a lot Bob, exactly what I did need. >> >> Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? >> >> Cheers Werner >> >> On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >>> --> RV10-List message posted by: "Condrey, Bob (US SSA)" >>> >>> Try iflyrv10.com >>> >>> Bob >> >> >> >> > > ________________________________________________________________________________
Date: Oct 05, 2010
Another option, if you don't like the fixed wedge method or don't want to go the servo route, is a spring bias system: http://www.mlblueskunk.com/Rudder_Trim_System.html -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314805#314805 ________________________________________________________________________________
Date: Oct 05, 2010
Yes... not much and sometimes it requires a little "reverse" deflection. It all depends on how your plane is rigged (ultimately) and then of course fuel / passenger loading and X Wind. I rarely (if ever) see it deflected more than 30% of its maximum travel. BTW while I consider all other cockpit trim indicators an absolute safety requirement but having a rudder trim indicator is not a requirement because you can easily overpower the rudder trim with foot action and you have a built in indicator with the slip ball. Your call. The only reason I bring it up is my painter shorted out my Ray Allen position indicator (thanks!) and after about 160 hours of additional flight time I have not really missed the Rudder Trim indication. Again your call. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: Tuesday, October 05, 2010 9:08 AM Subject: Re: RV10-List: 1st answered 2nd question about rudder trim Thanks a lot Robin, any idea how much deflection you use normally? Cheers Werner On 05.10.2010 17:49, Robin Marks wrote: > --> RV10-List message posted by: Robin Marks > > Mine works very well. Would not fly without it. Putting one in my 8A now. > > http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx > > Robin > > Sent from my iPad > > On Oct 5, 2010, at 5:41 AM, Werner Schneider wrote: > >> --> RV10-List message posted by: Werner Schneider >> >> Thanks a lot Bob, exactly what I did need. >> >> Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? >> >> Cheers Werner >> >> On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >>> --> RV10-List message posted by: "Condrey, Bob (US SSA)" >>> >>> Try iflyrv10.com >>> >>> Bob >> >> >> >> > > ________________________________________________________________________________
Date: Oct 05, 2010
I'm based at Livermore (KLVK). Tie downs are inexpensive; self serve fuel average ($4.50 or so); you need to call Enterprise in advance for a car. Several hotels/motels within a mile. Wx usually is vfr, and if not there's a good ILS and an LPV gps approach. You'll want a car but I recommend taking BART to see San Francisco. KMRY is a bit pricey, but convenient, and both FBO's have rental cars. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314809#314809 ________________________________________________________________________________
Date: Oct 05, 2010
Robin, first time I actually went out to your site.- Nice job, GREAT writ e-up...-and I'm flattered that you used one of the shots as the backgroun d that I took of your plane while we were touring Hearst Castle, Morrow Bay , and Pismo with both our 10's.- Now that was fun!- Flying back to Cali f in the next few days for a visit.- Hope to see you soon on a visit to P ecan. Don McDonald --- On Tue, 10/5/10, Robin Marks wrote: From: Robin Marks <robin(at)PaintTheWeb.com> Subject: Re: RV10-List: 1st answered 2nd question about rudder trim Date: Tuesday, October 5, 2010, 8:49 AM Mine works very well. Would not fly without it. Putting one in my 8A now. http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx Robin Sent from my iPad On Oct 5, 2010, at 5:41 AM, Werner Schneider wrote: > > Thanks a lot Bob, exactly what I did need. > > Now looking at rudder trim, anybody has the internal (system) trim and ca n tell how good it works? > > Cheers Werner > > On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >> -->- RV10-List message posted by: "Condrey, Bob (US SSA)"<bob.condrey@ baesystems.com> >> >> Try iflyrv10.com >> >> Bob > > le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Oct 05, 2010
In Canada (where I'm originally from) Robertson screws have pretty much dominated over Phillips. IMHO, they are superior in every way. I've always wondered why they are so hard to find in the US... Chris On Tue, Oct 5, 2010 at 4:26 AM, AirMike wrote: > > The biggest problem is the head of the Phillips driver - rolling out of the > screw head and buggering the screw. > > A few years ago my former plane partner showed me something called the "X" > head screwdriver. They are hard to find, but I located some at Snap-on at > OSH a few years back. (just driver tips) They have 2 or 3 tiny but > distinctive ridges or cuts on the side of the tip that seem to really grip > the Phillips head channels. I did a few hundred screws yesterday - doing my > annual and buggered only 2 screws. > > -------- > OSH '10 or Bust > Q/B - finally done > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=314760#314760 > > ________________________________________________________________________________
Date: Oct 05, 2010
Bob I plan to go with the Bias spring system by http://www.mlblueskunk.com/Rudder_Trim_System.html I like the design and I do not have to cut into my rudder. John G. Cumins 40864 Emp complete Wings s/b started -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: Tuesday, October 05, 2010 5:41 AM Subject: RV10-List: 1st answered 2nd question about rudder trim Thanks a lot Bob, exactly what I did need. Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? Cheers Werner On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: > --> RV10-List message posted by: "Condrey, Bob (US SSA)" > > Try iflyrv10.com > > Bob ________________________________________________________________________________
Date: Oct 05, 2010
My plan is to attach a hinge to the TE of the rudder and one aileron, driven by model airplane servo's. I don't like the big wedge cutout ..... this is for trim, not flying the airplane!!! One advantage I have is that I can program a single-chip (almost) computer to control the servo. Linn On 10/5/2010 2:54 PM, John Cumins wrote: > --> RV10-List message posted by: "John Cumins" > > Bob > > I plan to go with the Bias spring system by > http://www.mlblueskunk.com/Rudder_Trim_System.html I like the design and I > do not have to cut into my rudder. > > John G. Cumins > 40864 Emp complete Wings s/b started > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider > Sent: Tuesday, October 05, 2010 5:41 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: 1st answered 2nd question about rudder trim > > --> RV10-List message posted by: Werner Schneider > > Thanks a lot Bob, exactly what I did need. > > Now looking at rudder trim, anybody has the internal (system) trim and > can tell how good it works? > > Cheers Werner > > On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >> --> RV10-List message posted by: "Condrey, Bob (US > SSA)" >> Try iflyrv10.com >> >> Bob > > ________________________________________________________________________________
Date: Oct 05, 2010
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Chris: Couple of years ago I got this book for my Dad (former machinist). I found it quite interesting. It tells about the history of the screws and the different heads. If I remember correctly, the reason the US has the Phillips drive type head and not the Robertson's is because of Henry Ford. Even then, they knew the square drive worked better, but Phillips had a cheaper screw, and therefore Henry Ford went with it. This book is worth the $10. Get one for some one for xmas and pass it around. Dr Fred One Good Turn: A Natural History of the Screwdriver and the Screw [Paperback] Witold Rybczynski <http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_1> <http://www.amazon.com/One-Good-Turn-Natural-Screwdriver/dp/0684867303/ref=sr_1_2?s=books&ie=UTF8&qid=1286317043&sr=1-2#> *Witold Rybczynski* (Author) ** Visit Amazon's Witold Rybczynski Page <http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_pop_1> Find all the books, read about the author, and more. See search results <http://www.amazon.com/s/ref=ntt_athr_dp_sr_pop_1?_encoding=UTF8&sort=relevancerank&search-alias=books&field-author=Witold%20Rybczynski> for this author Are you an author? Learn about Author Central <http://authorcentral.amazon.com/gp/landing/ref=ntt_atc_dp_pel_1> (Author) ________________________________________________________________________________
Date: Oct 05, 2010
Just one more reason to use the CS screw with the internal hex head for the forward most 3-4 places on each side of the tunnel cover. Removing/inserting those with an Allen wrench beats Phillips head there anytime. ----- Original Message ----- From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com> Sent: Tuesday, October 05, 2010 3:22 PM Subject: Re: RV10-List: Re: Enderes screwdriver redux - the perfect screwdriver Chris: Couple of years ago I got this book for my Dad (former machinist). I found it quite interesting. It tells about the history of the screws and the different heads. If I remember correctly, the reason the US has the Phillips drive type head and not the Robertson's is because of Henry Ford. Even then, they knew the square drive worked better, but Phillips had a cheaper screw, and therefore Henry Ford went with it. This book is worth the $10. Get one for some one for xmas and pass it around. Dr Fred One Good Turn: A Natural History of the Screwdriver and the Screw [Paperback] Witold Rybczynski <http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_1> <http://www.amazon.com/One-Good-Turn-Natural-Screwdriver/dp/0684867303/ref=sr_1_2?s=books&ie=UTF8&qid=1286317043&sr=1-2#> *Witold Rybczynski* (Author) ** Visit Amazon's Witold Rybczynski Page <http://www.amazon.com/Witold-Rybczynski/e/B000AQ1U8A/ref=ntt_athr_dp_pel_pop_1> Find all the books, read about the author, and more. See search results <http://www.amazon.com/s/ref=ntt_athr_dp_sr_pop_1?_encoding=UTF8&sort=relevancerank&search-alias=books&field-author=Witold%20Rybczynski> for this author Are you an author? Learn about Author Central <http://authorcentral.amazon.com/gp/landing/ref=ntt_atc_dp_pel_1> (Author) ________________________________________________________________________________
Date: Oct 05, 2010
Kelly, Tested the EGT probes with a heat gun. All are reading correctly. Spoke to GAMI. They can't figure out what's going on but will try an even richer injector for 5 and an even leaner injector for 3. To be continued. Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, October 04, 2010 10:27 PM Subject: Re: RV10-List: TMXIO-540 and GAMI injectors Certainly a possibility, since they are adjacent cylinders. Does the engine behave like it has a lot of imbalance between cylinders or no? I'd certainly try swapping those two probes. It will tell you if they are reading correctly or are swapped. Something is swapped, because your results are the reverse of what you would expect with those nozzles. Other option, if easier, would be to swap injector nozzles between those two cylinders. It will either get a lot better or a lot worse. On 10/4/2010 9:16 PM, Alan Mekler wrote: > > Kelly, > > Everything pointed to the fuel flow divider and this was sent out and > serviced but despite trying to get cylinder 3 to run leaner and > cylinder 5 to run richer the GAMIs have failed. The only other thought > I had was that maybe the EGT probes were swapped on cylinder 3 and 5??? > > Alan > > ---------------------------------------------------------------------- > -- > > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly > McMullen > *Sent:* Monday, October 04, 2010 8:58 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: TMXIO-540 and GAMI injectors > > Obviously #3 and #5 are your outliers. The question is why. I'd see > what GAMI has to say on the data. Somehow, either the injector on 5 > isn't what it says it is, or the cylinder is getting significantly > more air some how. Is the engine rough when you get all the way to #3 > peaking? > > On Mon, Oct 4, 2010 at 8:42 PM, Alan Mekler > wrote: > > > > > Kelly, > My flow divider went out to Mattituck and was cleaned and sent back > and I was told it was all set. I flew the plane with the GAMIs > cylinder 5 with the J(richest injector) and cylinder 3 with the A > (leanest injector). > My results are as follows. Cylinder 1 peaked at 11.4 gal cylinder 2 > at > 11.4 cylinder 3 at 10.5 cylinder 4 at 11.1 cylinder 5 at 12.2 and > cylinder 6 at 11.4. > As you can see this is similar to what I had before the fuel divider > was serviced. Any thoughts on what is going on? > Alan > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Alan > Mekler > Sent: Saturday, August 28, 2010 5:35 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: TMXIO-540 and GAMI injectors > > > > > Kelly, > I see your point. I'll stay on the ground this weekend. > Alan > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Kelly > McMullen > Sent: Saturday, August 28, 2010 5:20 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TMXIO-540 and GAMI injectors > > > > > Alan, > Let me politely, but violently disagree with your A&P. Something is > blocking flow in your flow divider. You have proved that. What you and > your A&P can NOT assure is that whatever is blocking the flow won't > move and completely stop the flow. You cannot be assured of stable > fuel flow. That is why you should NOT fly it until it is fixed. I'm > sure Mattituck will make it right, pronto. > Kelly > A&P/IA > EAA Tech Counselor > > On Sat, Aug 28, 2010 at 2:05 PM, Alan Mekler > wrote: > > --> > > > > > Tim, > > I was not the builder of my plane. My A&P also an AI has done all > > the trouble shooting. EGT spread is less than 50 degrees when flying > > 100 > degrees > > rich of peak.(that's how I have been flying it) At full throttle > > cylinder > #1 > > runs hotter than cylinder #5. My mechanic called Mattituck because > > they > are > > the Precision Service center closest to us and Mattituck has been > > trouble shooting the problem with us. The engine only has 100 hours > > and is still under warranty. There is no engine roughness unless I > > try flying lean of peak. > > My A&P saw no problem with flying the airplane. I'll know more on > > Monday when we hear from Mattituck but it is most likely we will > > send the unit in for service. > > Alan > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at www.cyberdefender.com > <http://www.cyberdefender.com> > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > > > CyberDefender has scanned this email for potential threats. > Version 2.0 / Build 4.03.29.01 > Get free PC security at http://www.cyberdefender.com > <http://www.cyberdefender.com> > * > > > * CyberDefender has scanned this email for potential threats. Version 2.0 / Build 4.03.29.01 Get free PC security at www.cyberdefender.com ________________________________________________________________________________
Date: Oct 05, 2010
I'm trying to go with Don Orrick's solution as documented here on Tim Olsen's site: http://www.myrv10.com/tips/mods/RudderTrim/DonOrrick.html Don's has a very fine flying '10 with many fine features I'd love to copy. When I saw it at Oshkosh several years ago I couldn't figure out what the vernier knob was for but later saw this on Tim's site. I fly a Maule right now and it has a similar setup in the sense that it simply applies a spring to the right rudder pedal control using one of these to control the spring: http://www.aircraftspruce.com/catalog/appages/thandledashctrl.php The assumption here is that only right trim is required. Works fine on the Maule and is about as simple as it gets. Don uses a pulley to turn 180 degrees at the firewall. I mocked it up with the T-handle control above and looks like the cable can make the turn with out the pulley. So I've installed a bracket and cable and will try to size and fit a spring to see if I can make it work. If not, the Skunk works control horn approach looks good too. Bill Watson On 10/5/2010 8:41 AM, Werner Schneider wrote: > > Now looking at rudder trim, anybody has the internal (system) trim and > can tell how good it works? > > ________________________________________________________________________________
Date: Oct 05, 2010
Yes this photo is on my phone, iPad and website. I occasionally get comments about flying over all that water but you and I know we were on the shoreline shooting west. Robin [image: Flying N110EE.JPG] *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Don McDonald *Sent:* Tuesday, October 05, 2010 10:48 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: 1st answered 2nd question about rudder trim Robin, first time I actually went out to your site. Nice job, GREAT write-up... and I'm flattered that you used one of the shots as the background that I took of your plane while we were touring Hearst Castle, Morrow Bay, and Pismo with both our 10's. Now that was fun! Flying back to Calif in the next few days for a visit. Hope to see you soon on a visit to Pecan. Don McDonald --- On *Tue, 10/5/10, Robin Marks * wrote: From: Robin Marks <robin(at)PaintTheWeb.com> Subject: Re: RV10-List: 1st answered 2nd question about rudder trim Date: Tuesday, October 5, 2010, 8:49 AM http://us.mc537.mail.yahoo.com/mc/compose?to=robin@painttheweb.com> > Mine works very well. Would not fly without it. Putting one in my 8A now. http://painttheweb.com/painttheweb/rv-10/RudderTrim.aspx Robin Sent from my iPad On Oct 5, 2010, at 5:41 AM, Werner Schneider http://us.mc537.mail.yahoo.com/mc/compose?to=glastar@gmx.net>> wrote: > > > Thanks a lot Bob, exactly what I did need. > > Now looking at rudder trim, anybody has the internal (system) trim and can tell how good it works? > > Cheers Werner > > On 05.10.2010 13:56, Condrey, Bob (US SSA) wrote: >> --> RV10-List message posted by: "Condrey, Bob (US SSA)"< bob.condrey@baesystems.com<http://us.mc537.mail.yahoo.com/mc/compose?to=bob.condrey@baesystems.com> > >> >> Try iflyrv10.com >> >> Bob > > sp; --> httphttp://forums.matronics.com/" target=_blank>http://forums.matronics.com <http://www.matronics.com/Navigator?RV10-List> * * * * * * ________________________________________________________________________________
Date: Oct 05, 2010
I looked at AS&S and Vans for the SCREW 3/8-24X 2 1/2 and came up empty. Any leads where to get the screws would be appreciated. Thx Pascal -------------------------------------------------- From: "Miller John" <gengrumpy(at)aol.com> Sent: Tuesday, October 05, 2010 5:48 AM Subject: Re: RV10-List: Re: Nosewheel Mod > > Thanks, Lew. > > Les, mine look just like Lew's except my big washer is a shiny one. > > grumpy > > On Oct 5, 2010, at 6:46 AM, Lew Gallagher wrote: > >> >> Hey Les, >> >> Here's the link to my previous post : >> http://forums.matronics.com/viewtopic.php?t=71126&highlight=studs >> >> The hangar guys still love it, paint still looks good! >> >> Later, - Lew >> >> -------- >> non-pilot >> crazy about building >> NOW OFICIALLY BUILDER #40549 >> Fly off completed ! >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=314764#314764 >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 05, 2010
www.mcmaster.com ----- Original Message ----- From: "Pascal" <rv10builder(at)verizon.net> Sent: Tuesday, October 05, 2010 7:39 PM Subject: Re: RV10-List: Re: Nosewheel Mod > > I looked at AS&S and Vans for the SCREW 3/8-24X 2 1/2 and came up empty. > Any leads where to get the screws would be appreciated. > Thx > Pascal > > > -------------------------------------------------- > From: "Miller John" <gengrumpy(at)aol.com> > Sent: Tuesday, October 05, 2010 5:48 AM > To: > Subject: Re: RV10-List: Re: Nosewheel Mod > >> >> Thanks, Lew. >> >> Les, mine look just like Lew's except my big washer is a shiny one. >> >> grumpy >> >> On Oct 5, 2010, at 6:46 AM, Lew Gallagher wrote: >> >>> >>> Hey Les, >>> >>> Here's the link to my previous post : >>> http://forums.matronics.com/viewtopic.php?t=71126&highlight=studs >>> >>> The hangar guys still love it, paint still looks good! >>> >>> Later, - Lew >>> >>> -------- >>> non-pilot >>> crazy about building >>> NOW OFICIALLY BUILDER #40549 >>> Fly off completed ! >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=314764#314764 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Oct 06, 2010
Another tip for getting out tough screws. Put a little valve lapping compound on the tip of the screwdriver. This has saved me countless times. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314901#314901 ________________________________________________________________________________
Date: Oct 06, 2010
Hey Pascal, I found mine at a local nut and bolt house -- let me know if you want me to send you a couple. Later, - Lew ----- Original Message ----- From: "Pascal" <rv10builder(at)verizon.net> Sent: Tuesday, October 05, 2010 10:39 PM Subject: Re: RV10-List: Re: Nosewheel Mod > > I looked at AS&S and Vans for the SCREW 3/8-24X 2 1/2 and came up empty. > Any leads where to get the screws would be appreciated. > Thx > Pascal ________________________________________________________________________________
Date: Oct 06, 2010
Subject: 406mhz ELT Prices
I just went out to look at ELTs and I was shocked by the price of the 406mhz variants. I know this is the "aviation market", but geesh. The US has no 406mhz "requirement", correct? I believe Mexico has extended the 406mhz requirement until Dec. 31, 2011. I know the whole concept of spending a few more dollars for piece of mind, but man. $700-1800+ for an ELT? I'm not sure I'd ever fly outside the U.S. at this point, but who knows, maybe I'll cross the 406mhz path when/if I get to that point and just go 121.5 until then? Maybe at that point the initial markup for a new product will evaporate? Have others just bitten the bullet and gone 406? Seems you could almost add a 406 EPIRB to the 121.5 ELT and get piece of mind cheaper than getting a 406 ELT. -Sean #40303 ________________________________________________________________________________
Date: Oct 06, 2010
Subject: Re: 406mhz ELT Prices
Here ya go... http://www.aircraftspruce.com/catalog/avpages/elt406.php On 10/6/10 4:43 PM, davidsoutpost(at)comcast.net wrote: > Tim, > Any pricing on this ELT? I can't seem to find it anywhere on their > website. > > David Clifford > > RV-10 Builder > 65% Done-95% To Go > N849RV (reserved) > > ----- Original Message ----- > From: "Tim Olson" <Tim(at)myrv10.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, October 6, 2010 5:23:45 PM > Subject: Re: RV10-List: 406mhz ELT Prices > > > Don't SKIP on installing an ELT, but don't do a 121.5. > These guys are cheaper for the functionality: > > http://www.ackavionics.com/406%20Page.html > > It's been a looooooong process getting it all TSO'd in > the US, but if you can spare a few months, I'd wait and > just do this one. I have one on order right now, and > they have them in stock...they just need the TSO paperwork > complete. Once it's done, it should be about the most > affordable unit out there with all the good capabilities. > > Then also, get yourself a PLB or SPOT as a handheld. > You'll find easy ways to talk yourself into the utility > of having something you can hand-carry while you're > over water, mountains, or anything else. It could > be a very handy device. There are many brands...I have > the one here in my write-up: > > http://www.myrv10.com/N104CD/flights/20071111/index.html > > Nothing too special but it has a nice neoprene > sleeve and all. If you get a nice 406 ELT, just get > a good working cheap PLB. Don't waste the time > and money on a 121sp; -Matt Dralle, > Li-================================== > > > * > > > * ________________________________________________________________________________
Date: Oct 06, 2010
I've got this one on order too - and it's been a verrrrrry long approval process. This was the lowest price one out there but I have no doubt it will go up once it is available. And people like Tim and I are HOPING that we get the original price.... whatever it was. Maybe Tim remembers that price but maybe it's best left unstated. Bill "ready to shoot some more paint" Watson On 10/6/2010 5:43 PM, davidsoutpost(at)comcast.net wrote: > Tim, > Any pricing on this ELT? I can't seem to find it anywhere on their > website. > > David Clifford > > RV-10 Builder > 65% Done-95% To Go > N849RV (reserved) > > ----- Original Message ----- > From: "Tim Olson" <Tim(at)myrv10.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, October 6, 2010 5:23:45 PM > Subject: Re: RV10-List: 406mhz ELT Prices > > > Don't SKIP on installing an ELT, but don't do a 121.5. > These guys are cheaper for the functionality: > > http://www.ackavionics.com/406%20Page.html > > It's been a looooooong process getting it all TSO'd in > the US, but if you can spare a few months, I'd wait and > just do this one. I have one on order right now, and > they have them in stock...they just need the TSO paperwork > complete. Once it's done, it should be about the most > affordable unit out there with all the good capabilities. ________________________________________________________________________________
Date: Oct 06, 2010
It's been a long time since I looked but I think it was under $600, like $55 0-595 Ish. On Oct 6, 2010, at 4:43 PM, davidsoutpost(at)comcast.net wrote: > Tim, > Any pricing on this ELT? I can't seem to find it anywhere on their websit e. > > David Clifford > > RV-10 Builder > 65% Done-95% To Go > N849RV (reserved) > > ----- Original Message ----- > From: "Tim Olson" <Tim(at)myrv10.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, October 6, 2010 5:23:45 PM > Subject: Re: RV10-List: 406mhz ELT Prices > > > Don't SKIP on installing an ELT, but don't do a 121.5. > These guys are cheaper for the functionality: > > http://www.ackavionics.com/406%20Page.html > > It's been a looooooong process getting it all TSO'd in > the US, but if you can spare a few months, I'd wait and > just do this one. I have one on order right now, and > they have them in stock...they just need the TSO paperwork > complete. Once it's done, it should be about the most > affordable unit out there with all the good capabilities. > > Then also, get yourself a PLB or SPOT as a handheld. > You'll find easy ways to talk yourself into the utility > of having something you can hand-carry while you're > over water, mountains, or anything else. It could > be a very handy device. There are many brands...I have > the one here in my write-up: > > http://www.myrv10.com/N104CD/flights/20071111/index.html > > Nothing too special but it has a nice neoprene > sleeve and all. If you get a nice 406 ELT, just get > a good working cheap PLB. Don't waste the time > and money on a 121sp; -Matt Dralle, Li-======= ========================== = > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 06, 2010
link says : Undergoing certification testing, ACK is not accepting orders for the E-04 until ELT certification process is complete. so how does one pre-order one of these things than? -------------------------------------------------- From: "Sean Stephens" <sean(at)stephensville.com> Sent: Wednesday, October 06, 2010 3:00 PM Subject: Re: RV10-List: 406mhz ELT Prices > > Here ya go... > > http://www.aircraftspruce.com/catalog/avpages/elt406.php > > On 10/6/10 4:43 PM, davidsoutpost(at)comcast.net wrote: >> Tim, >> Any pricing on this ELT? I can't seem to find it anywhere on their >> website. >> >> David Clifford >> >> RV-10 Builder >> 65% Done-95% To Go >> N849RV (reserved) >> >> ----- Original Message ----- >> From: "Tim Olson" <Tim(at)myrv10.com> >> To: rv10-list(at)matronics.com >> Sent: Wednesday, October 6, 2010 5:23:45 PM >> Subject: Re: RV10-List: 406mhz ELT Prices >> >> >> Don't SKIP on installing an ELT, but don't do a 121.5. >> These guys are cheaper for the functionality: >> >> http://www.ackavionics.com/406%20Page.html >> >> It's been a looooooong process getting it all TSO'd in >> the US, but if you can spare a few months, I'd wait and >> just do this one. I have one on order right now, and >> they have them in stock...they just need the TSO paperwork >> complete. Once it's done, it should be about the most >> affordable unit out there with all the good capabilities. >> >> Then also, get yourself a PLB or SPOT as a handheld. >> You'll find easy ways to talk yourself into the utility >> of having something you can hand-carry while you're >> over water, mountains, or anything else. It could >> be a very handy device. There are many brands...I have >> the one here in my write-up: >> >> http://www.myrv10.com/N104CD/flights/20071111/index.html >> >> Nothing too special but it has a nice neoprene >> sleeve and all. If you get a nice 406 ELT, just get >> a good working cheap PLB. Don't waste the time >> and money on a 121sp; -Matt Dralle, >> Li-================================== >> >> >> >> * >> >> >> * > > > ________________________________________________________________________________
Date: Oct 06, 2010
Some vendors were preordering for a period. I got mine from Dallas Avionics. Tim On Oct 6, 2010, at 6:10 PM, "Pascal" wrote: > > link says : > Undergoing certification testing, ACK is not accepting orders for the E-04 until ELT certification process is complete. > > > so how does one pre-order one of these things than? > > -------------------------------------------------- > From: "Sean Stephens" <sean(at)stephensville.com> > Sent: Wednesday, October 06, 2010 3:00 PM > To: > Subject: Re: RV10-List: 406mhz ELT Prices > >> >> Here ya go... >> >> http://www.aircraftspruce.com/catalog/avpages/elt406.php >> >> On 10/6/10 4:43 PM, davidsoutpost(at)comcast.net wrote: >>> Tim, >>> Any pricing on this ELT? I can't seem to find it anywhere on their website. >>> >>> David Clifford >>> >>> RV-10 Builder >>> 65% Done-95% To Go >>> N849RV (reserved) >>> >>> ----- Original Message ----- >>> From: "Tim Olson" <Tim(at)myrv10.com> >>> To: rv10-list(at)matronics.com >>> Sent: Wednesday, October 6, 2010 5:23:45 PM >>> Subject: Re: RV10-List: 406mhz ELT Prices >>> >>> >>> Don't SKIP on installing an ELT, but don't do a 121.5. >>> These guys are cheaper for the functionality: >>> >>> http://www.ackavionics.com/406%20Page.html >>> >>> It's been a looooooong process getting it all TSO'd in >>> the US, but if you can spare a few months, I'd wait and >>> just do this one. I have one on order right now, and >>> they have them in stock...they just need the TSO paperwork >>> complete. Once it's done, it should be about the most >>> affordable unit out there with all the good capabilities. >>> >>> Then also, get yourself a PLB or SPOT as a handheld. >>> You'll find easy ways to talk yourself into the utility >>> of having something you can hand-carry while you're >>> over water, mountains, or anything else. It could >>> be a very handy device. There are many brands...I have >>> the one here in my write-up: >>> >>> http://www.myrv10.com/N104CD/flights/20071111/index.html >>> >>> Nothing too special but it has a nice neoprene >>> sleeve and all. If you get a nice 406 ELT, just get >>> a good working cheap PLB. Don't waste the time >>> and money on a 121sp; -Matt Dralle, Li-================================== >>> >>> >>> >>> * >>> >>> >>> * >> >> >> > > > ________________________________________________________________________________
Date: Oct 06, 2010
I think a PLB plus a useless but needed to be legal 121.5 ELT is a good compromise, except that it doesn't cover going to Canada or Mexico or, I guess, the Bahamas. I haven't seen Ack's price list for replacement batteries, but I have seen some others. Some of these Li replacement batteries that I have seen have a price that will make you cry. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=314993#314993 ________________________________________________________________________________
Date: Oct 06, 2010
Now Ben, if you loose your engine, How long does it take to push that littl e button to get a signal out? If you slam into a mountain that's a whole di fferent thing. -The 406 elt gave me a whole- lot warmer feeling while flying over the mountains this summer, (with just one engine), knowing I could just press t he button and someone would know that I needed help and where I was. I hope . -I agree, I will get a spot or PLB for Christmas or before next summer bi g adventures. The point is you don't have to wait for the crash to activate it. -Just my stupid opion. Patrick Thyssen 237hrs, off to ABQ for the weekend ballon fest --- On Wed, 10/6/10, n801bh(at)netzero.com wrote: From: n801bh(at)netzero.com <n801bh(at)netzero.com> Subject: Re: RV10-List: 406mhz ELT Prices Date: Wednesday, October 6, 2010, 6:20 PM Personally I would hold off till they perfect the whole concept... As we al l know there have been several high profile plane crashes in Alaska this su mmer. To the best of my knowledge all of those aircraft were fitted with th e 'new' latest and greatest 406 units. Not one worked as advertised and hel ped in saving anyone. My money is on the PLB's and SPOTs. IMHO.=0Ado not ar chive Ben Haas N801BH www.haaspowerair.com ---------- Original Message ---------- From: Sean Stephens <sean(at)stephensville.com> Subject: RV10-List: 406mhz ELT Prices Date: Wed, 06 Oct 2010 16:09:22 -0500 -I just went out to look at ELTs and I was shocked by the price of the 406mhz variants. -I know this is the "aviation market", but geesh. -The US has no 406mhz "requirement", correct? -I believe Mexico has extended the 406mhz requirement until Dec. 31, 2011. -I know the whole concept of spending a few more dollars for piece of mind, but man. $700-1800+ for an ELT? I'm not sure I'd ever fly outside the U.S. at this point, but who knows, maybe I'll cross the 406mhz path when/if I get to that point and just go 121.5 until then? -Maybe at that point the initial markup for a new product will evaporate? Have others just bitten the bullet and gone 406? -Seems you could almost add a 406 EPIRB to the 121.5 ELT and get piece of mind cheaper than getting a====================== ========================; --------- MATRONICS WEB FORUMS ========= ==============;-------- List Cont ribution Web Site sp;------------------ -----&nb=================== ====== =0A=0A ____________________________________________________________ Mortgage Rates Hit 3.25% If you owe under $729k you probably qualify for Obama's Refi Program SeeRefinanceRates.com=0A=0A ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: Ballast?
Date: Oct 07, 2010
What have folks used for ballast to do max gross weight and other c.g. test ing during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) smaller flight ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Oct 06, 2010
Subject: Re: Ballast?
We keep a bunch of 50# bags of water softener salt in the shop. We use it for ballast and for weighting down wing skins, etc. Plus I have a water softener at home... Salt is pretty cheap, about $5/bag. The plastic bags are more durable than the paper sacks. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Wed, Oct 6, 2010 at 8:44 PM, Dawson-Townsend,Timothy < tdawson-townsend(at)aurora.aero> wrote: > What have folks used for ballast to do max gross weight and other c.g. > testing during their Phase I period? > > > TDT > > > Tim Dawson-Townsend > > RV-10 N52KS > > APRS KB1URG > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > [image: smaller flight] > > ________________________________________________________________________________
Date: Oct 06, 2010
I bought 75# of lead shot at Cabellas and put it in a plastic bag to keep the lead dust away from inside the plane, but I found that I only needed 50# - I keep it in a plastic bucket shock corded to the rear of the baggage area. That way it is easy to remove when I need to load baggage -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315004#315004 ________________________________________________________________________________
Subject: 406mhz ELT alternative.
Date: Oct 07, 2010
We've had the 406 here in New Zealand for a couple of years now. In many cases / places, even once you push the alarm, you can still be waiting for a satellite to come over & pick it up. ( a bit like RAIM outages, I think.) I have the mandatory 406mhz ELT, but the Artex model currently has an AD as there have been a number G switch failures. So we now have 6 month compulsory testing. (urgh -more expense!) I also have a couple of the very compact & neat McMurdo fastfinds for personal use. The neoprene cover means it floats. Lovely & small, & I simply put it around my neck if flying over water. But our main device for safety is the Spidertracks. Although it costs a bit on every flight, we have the comfort of knowing that the plane is tracked globally, and that the emergency services are alerted pretty much instantly we press the alarm. Not only that but we also get global text messaging with it via bluetooth! My wife loves it because she can track the plane via the web any time (or I can, if she's flying.) www.spidertracks.com Neil ZK-RVT Now flying again after the 2 wettest months in memory. ________________________________________________________________________________
Date: Oct 07, 2010
I'm not at that point, but my plan is to 5 gal water jugs @ 40/lbs a piece when full. About as cheap as it gets and I can quickly configure different weights. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315010#315010 ________________________________________________________________________________
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com>
Date: Oct 07, 2010
When you use something as ballast, you should assume you'll spill it. In that context, water or dirt or sand=good. salt=not so much Bob Brown Independence,OR RV-10 - wiring/FWF -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tsts4 Sent: Thursday, October 07, 2010 4:32 AM Subject: RV10-List: Re: Ballast? I'm not at that point, but my plan is to 5 gal water jugs @ 40/lbs a piece when full. About as cheap as it gets and I can quickly configure different weights. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315010#315010 ________________________________________________________________________________
Subject: Ballast?
Date: Oct 07, 2010
Whatever you choose, you will need a lot.. I used 80# sand bags. I placed them in garbage bags to prevent spills. When I was done..the sand went into my kids sand box. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy Sent: Wednesday, October 06, 2010 9:44 PM Subject: RV10-List: Ballast? What have folks used for ballast to do max gross weight and other c.g. testing during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) smaller flight ________________________________________________________________________________
Date: Oct 07, 2010
40# water softener salt bags work great, especially if you have a use for them afterward. David Clifford RV-10 Builder 65% Done-95% To Go N849RV (reserved) ----- Original Message ----- From: "tsts4" <tsts4(at)verizon.net> Sent: Thursday, October 7, 2010 7:32:20 AM Subject: RV10-List: Re: Ballast? I'm not at that point, but my plan is to 5 gal water jugs @ 40/lbs a piece when full. About as cheap as it gets and I can quickly configure different weights. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315010#315010 ________________________________________________________________________________
Date: Oct 07, 2010
Put the lead shot in a PVC Pipe segment sized for the desired weight and glue on caps. Easy to manage and doesn't spill. Jim C N312F - Flying On Thu, Oct 7, 2010 at 12:19 AM, AirMike wrote: > > I bought 75# of lead shot at Cabellas and put it in a plastic bag to keep > the lead dust away from inside the plane, but I found that I only needed 50# > - I keep it in a plastic bucket shock corded to the rear of the baggage > area. That way it is easy to remove when I need to load baggage > > -------- > OSH '10 or Bust > Q/B - finally done > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=315004#315004 > > ________________________________________________________________________________
Date: Oct 07, 2010
I bought 150 lbs of shot from a local sporting goods store and used that. It's easily moved around and can be secured. Jim Combs - N312F On Wed, Oct 6, 2010 at 11:44 PM, Dawson-Townsend,Timothy < tdawson-townsend(at)aurora.aero> wrote: > What have folks used for ballast to do max gross weight and other c.g. > testing during their Phase I period? > > > TDT > > > Tim Dawson-Townsend > > RV-10 N52KS > > APRS KB1URG > > tdt(at)aurora.aero > > 617-500-4812 (office) > > 617-905-4800 (mobile) > > [image: smaller flight] > > ________________________________________________________________________________
Subject: Ballast?
Date: Oct 07, 2010
I think might have answered the wrong question. I thought he was looking for what he used for Max GW testing. Need a lot more than 150lbs for that. So my new answer is..I pack a survival kit with water in it. Weights about 20 lbs and is all the ballast I need to day to day flying... Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Sent: Thursday, October 07, 2010 10:28 AM Subject: Re: RV10-List: Ballast? I bought 150 lbs of shot from a local sporting goods store and used that. It's easily moved around and can be secured. Jim Combs - N312F On Wed, Oct 6, 2010 at 11:44 PM, Dawson-Townsend,Timothy wrote: What have folks used for ballast to do max gross weight and other c.g. testing during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) Error! Filename not specified. ________________________________________________________________________________
Date: Oct 07, 2010
WHY NOT JUST USE THOSE GOLD BARS YOU GOT BARRIED IN THE BACK YARD. -----Original Message----- From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> Sent: Wed, Oct 6, 2010 10:44 pm Subject: RV10-List: Ballast? What have folks used for ballast to do max gross weight and other c.g. tes ting during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Oct 07, 2010
why do all this testing at all? If one builds to the plans and uses the hardware provided, why so much testing? A unique design "homebuilt" would require complete testing. An RV kit built to Vans plans and rigged to Vans plans should perform very closely with the numbers as provided by the kit manufacturer. At least as closely as Cessna did with their marketing driven operating handbooks in times past.. ----- Original Message ----- From: fixitauto(at)aol.com To: rv10-list(at)matronics.com Sent: Thursday, October 07, 2010 10:22 AM Subject: Re: RV10-List: Ballast? WHY NOT JUST USE THOSE GOLD BARS YOU GOT BARRIED IN THE BACK YARD. -----Original Message----- From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> To: rv10-list(at)matronics.com Sent: Wed, Oct 6, 2010 10:44 pm Subject: RV10-List: Ballast? What have folks used for ballast to do max gross weight and other c.g. testing during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Oct 07, 2010
Hmmm. Color me ignorant but I thought due diligence dictated that you are supposed to test the aircraft in a variety of weight/CG configurations in actual flight to verify performance. The only way to effectively do that in phase one is with ballast. Regardless of any one else's opinion, I still plan to explore multiple configs because I want to know what the no kidding flight characteristics are before I plop pax and bags in the plane. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315045#315045 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Oct 07, 2010
I do it because I want to understand how my plane flies at all ends of the s pectrum. Knowledge is king...... Sent from my iPhone On Oct 7, 2010, at 2:20 PM, "DLM" wrote: > why do all this testing at all? If one builds to the plans and uses the ha rdware provided, why so much testing? A unique design "homebuilt" would requ ire complete testing. An RV kit built to Vans plans and rigged to Vans plans should perform very closely with the numbers as provided by the kit manufac turer. At least as closely as Cessna did with their marketing driven operati ng handbooks in times past.. > ----- Original Message ----- > From: fixitauto(at)aol.com > To: rv10-list(at)matronics.com > Sent: Thursday, October 07, 2010 10:22 AM > Subject: Re: RV10-List: Ballast? > > WHY NOT JUST USE THOSE GOLD BARS YOU GOT BARRIED IN THE BACK YARD. > > > > -----Original Message----- > From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> > To: rv10-list(at)matronics.com > Sent: Wed, Oct 6, 2010 10:44 pm > Subject: RV10-List: Ballast? > > What have folks used for ballast to do max gross weight and other c.g. tes ting during their Phase I period? > > TDT > > > Tim Dawson-Townsend > RV-10 N52KS > APRS KB1URG > tdt(at)aurora.aero > 617-500-4812 (office) > 617-905-4800 (mobile) > > ________________________________________________________________________________
Subject: Ballast?
Date: Oct 07, 2010
By definition, we test to verify everything was built to spec. I.e. you can=99t know you built it to spec unless you test. Besides, do you really want to find out how it behaves at gross with your family as the ballast? John Melchert ________________________________________________________________________________
Subject: Re: Ballast-really needed for test flight and beyond?
Date: Oct 07, 2010
40 hours for someone like me that has an experimental engine- (so there goes the Vans spec) 25 for a certified engine and prop- not experimental like many have bought from Vans . I need something to do for those 40 hours so why not use that time to do what the flight test period is designed for.. Ballast is probably one of many things we'll need during the test period, a camera is another and lastly, confidence building as we verify everything works right. I'm with those that bringing your family along, without having a plane fully tested, is a big mistake. Read Tim's commentary on someone who chose to take shortcuts along the way and really did not use the flight test period correctly- we can learn from others mistakes, not doing so will leave one vulnerable to do the same thing. Leave the ballast out or not completing different CG test flights, you aren't doing a full test of the plane. Finding out how a aft CG plane feels like with people on board is not the time to discover it. Cessna had a certified plane- all built the same with the same engine and weights. we are all "one offs" some have barrett, some have Lycoming, some have a Chevette some even a corvette engine, my engine is a Aztec engine cleaned up, in all these cases (except for the chevette engine which I doubt would even move a glider) we need to know the take off and landing settings, we need to assure our gizmos we added for doors and such actually work etc.. we are literally testing our version of the Vans plans.. If the FAA didn't think so our repairmans cert could work on any RV-10. From: DLM Sent: Thursday, October 07, 2010 11:20 AM Subject: Re: RV10-List: Ballast? why do all this testing at all? If one builds to the plans and uses the hardware provided, why so much testing? A unique design "homebuilt" would require complete testing. An RV kit built to Vans plans and rigged to Vans plans should perform very closely with the numbers as provided by the kit manufacturer. At least as closely as Cessna did with their marketing driven operating handbooks in times past.. ----- Original Message ----- From: fixitauto(at)aol.com To: rv10-list(at)matronics.com Sent: Thursday, October 07, 2010 10:22 AM Subject: Re: RV10-List: Ballast? WHY NOT JUST USE THOSE GOLD BARS YOU GOT BARRIED IN THE BACK YARD. -----Original Message----- From: Dawson-Townsend,Timothy <tdawson-townsend(at)aurora.aero> To: rv10-list(at)matronics.com Sent: Wed, Oct 6, 2010 10:44 pm Subject: RV10-List: Ballast? What have folks used for ballast to do max gross weight and other c.g. testing during their Phase I period? TDT Tim Dawson-Townsend RV-10 N52KS APRS KB1URG tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Oct 07, 2010
Subject: why test
Date: Oct 08, 2010
I used my in-laws :-} -------- Frank Dombroski RV-10 N10WD Flying RV-8 N84FD Finished and sold :-{ N40 Sky Manor Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315091#315091 ________________________________________________________________________________
Date: Oct 08, 2010
Subject: How much paint for a whole '10?
I've started painting using a HVLP 3M/Accuspray gun and Axis turbine to shoot an Imron Elite Polyurethane single stage. It's going well so far. The ailerons and flaps are painted. For those of you that have painted, how many gallons did you use (or would use if painting the entire aircraft in 1 color)? If I were to do it all in one color, I'd roughly estimate 3.5 to 4 gallons at the rate I'm going. Seems like a lot. Lohle's estimate was 2 gallons of white but that is a different system. The Imron tech sheet recoomends 1.8 to 2.2 mils. Unfortunately there's no where to measure my paint thickness on the ailerons and flaps. I know I shot a an access panel at 3.0 mils but I was trying to go extra heavy on it as a test. So I know I'm doing less that 3.0 mils but probably more than 2.2 on the rest of the job so far. Bill "I am curious " Watson ________________________________________________________________________________
Subject: Re: How much paint for a whole '10?
Date: Oct 09, 2010
Hey Bill, I THINK it was 5 gal. of white, one of blue, and a quart of red. I'm not positive, cuz I kept running out and sending Wes back to the paint store for more! I was shocked at how much more surface there is on a plane than a car -- not anal enough to do the math, just started shooting. I typically shoot three light coats of final with 20-30 min. between coats. That eliminates runs, fills rivet heads, etc. I don't have a clue as to mils. By the way, I've not had any problems with the paint (acrylic enamel) except for one item. I made the false assumption that the steps that came primed from Van's would have been professionally primed, so I did not strip them and do my process that I did on everything else (self etch primer, epoxy primer, final coat). Now, six months later, my paint has chunked off at the joint of the step and the down leg, because their primer did not bond sufficiently to the steel. So I would recommend taking those down to metal and bring them back up. My process of grinding a shallow in both plexi and glass around all windows and glassing in a half inch of fiberglass over the joint has resulted in a joint that is still as perfect as it was the day I painted it. No cracks after a hot summer. I'm very pleased with that. I'd love to see pictures as you paint -- either post, private email, or maybe I can get doped up enough to make the flight up to visit with Wes. Later, - Lew ________________________________________________________________________________
Date: Oct 09, 2010
I'm using Stewarts system. So far very clean and smooth without major work, I have done one test piece (leg pants) and think I have enough paint on it that it's white and shiny. They told me 2 gallons and truthfully, the paint goes on very thin, 4 coats last being the thickest (1.75 on the fluid nozzle of my AOM K1) so I can see that being a possibility. I mentioned to their excellent support that I thought I needed thicker . They send a sample of what each layer should look like and they told me I would be wasting paint if I applied more than that. In other words, I did it right and it will probably be 2-2.5 gallons for me of all white, but for you the paint may need to be thicker and hence need more. My paint is water based so I add another 25% to the mix, hence it going on so thin. I'll give a paint report in the future for anyone who is a looking for an easy and home safe paint option. Pascal -------------------------------------------------- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Friday, October 08, 2010 8:45 PM Subject: RV10-List: How much paint for a whole '10? > > I've started painting using a HVLP 3M/Accuspray gun and Axis turbine to > shoot an Imron Elite Polyurethane single stage. It's going well so far. > The ailerons and flaps are painted. > > For those of you that have painted, how many gallons did you use (or would > use if painting the entire aircraft in 1 color)? > > If I were to do it all in one color, I'd roughly estimate 3.5 to 4 gallons > at the rate I'm going. Seems like a lot. Lohle's estimate was 2 gallons > of white but that is a different system. > > The Imron tech sheet recoomends 1.8 to 2.2 mils. Unfortunately there's > no where to measure my paint thickness on the ailerons and flaps. I know > I shot a an access panel at 3.0 mils but I was trying to go extra heavy on > it as a test. So I know I'm doing less that 3.0 mils but probably more > than 2.2 on the rest of the job so far. > > Bill "I am curious " Watson > > > ________________________________________________________________________________
Subject: Making the move
Date: Oct 09, 2010
Today was the big day. Time to move the project to the hanger. Weather was perfect and with 5 good friends and a trailer the event passed without a hitch. Even managed to get the wings in place for fitting of the wingroot fairing. back out there tomorrow to finish the wing installation and getting the tail feathers in place. The end is near. Still a little work to do on the doors, but after some vacation and working on other tasks, I am ready to get back at them. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315215#315215 Attachments: http://forums.matronics.com//files/in_the_hanger_with_the_wings_hung_895.jpg http://forums.matronics.com//files/on_the_trailer_900.jpg ________________________________________________________________________________
Date: Oct 09, 2010
Thanks for that - especially the tip about the step. I've been documenting the paint on my Kitlog site under "Painting A-Z" with pics. http://www.mykitlog.com/users/index.php?user=MauleDriver&project=224 You are more than welcome to flight up and visit. Love to see the plane. I think you know I'm at 8NC8 and I'm working here just about every day.... and the weather is beautiful. Bill "prepping the wings" Watson 919-824-4179 On 10/9/2010 8:43 AM, Lew Gallagher wrote: > > Hey Bill, > > I THINK it was 5 gal. of white, one of blue, and a quart of red. I'm > not positive, cuz I kept running out and sending Wes back to the paint > store for more! I was shocked at how much more surface there is on a > plane than a car -- not anal enough to do the math, just started > shooting. I typically shoot three light coats of final with 20-30 > min. between coats. That eliminates runs, fills rivet heads, etc. I > don't have a clue as to mils. > > By the way, I've not had any problems with the paint (acrylic enamel) > except for one item. I made the false assumption that the steps that > came primed from Van's would have been professionally primed, so I did > not strip them and do my process that I did on everything else (self > etch primer, epoxy primer, final coat). Now, six months later, my > paint has chunked off at the joint of the step and the down leg, > because their primer did not bond sufficiently to the steel. So I > would recommend taking those down to metal and bring them back up. > > My process of grinding a shallow in both plexi and glass around all > windows and glassing in a half inch of fiberglass over the joint has > resulted in a joint that is still as perfect as it was the day I > painted it. No cracks after a hot summer. I'm very pleased with that. > > I'd love to see pictures as you paint -- either post, private email, > or maybe I can get doped up enough to make the flight up to visit with > Wes. > > Later, - Lew > ________________________________________________________________________________
Date: Oct 09, 2010
Seems like all the systems are or can be done differently. This Imron Elite single stage, if applied per the tech sheets, goes on with a cross coat. That's 1 wet coat in one direction immediately (5 secs to a couple of mins) followed by a slightly drier coat in the other. It's not meant to be thinned. It's not meant to be sanded or otherwise touched. No clear coat. Using this Accuspray/Citation/ bottom feed pressure cup combination from AC Spruce http://www.aircraftspruce.com/catalog/topages/cite4.php I have a fixed sort of setup. Using the fluid nozzle supplied (1.1) and a fixed air supply (I can only restrict but run it full out), it performs in a pre-determined way. Using the Imron per spec gives a certain paint delivery and minimal overspray. The only real variables are spray pattern and the speed I move the gun. I've played with fluid nozzle size and thinning some of the high fill primer I used. In the end, I'm using the 1.1 and adding 5% thinner per the tech sheet. Looks good so far with a slight amount of orange peel comparable to what I see on many new cars. Will definitely will go thru more paint than I expected but it seems right. Definitely a toxic, not home safe product. With fresh air respirator and ventilated booth, it's fine. Thanks for the feedback. Bill Watson On 10/9/2010 10:20 AM, Pascal wrote: > > I'm using Stewarts system. So far very clean and smooth without major > work, I have done one test piece (leg pants) and think I have enough > paint on it that it's white and shiny. > They told me 2 gallons and truthfully, the paint goes on very thin, 4 > coats last being the thickest (1.75 on the fluid nozzle of my AOM K1) > so I can see that being a possibility. I mentioned to their excellent > support that I thought I needed thicker . They send a sample of what > each layer should look like and they told me I would be wasting paint > if I applied more than that. In other words, I did it right and it > will probably be 2-2.5 gallons for me of all white, but for you the > paint may need to be thicker and hence need more. > My paint is water based so I add another 25% to the mix, hence it > going on so thin. > I'll give a paint report in the future for anyone who is a looking for > an easy and home safe paint option. > Pascal > ________________________________________________________________________________
Date: Oct 10, 2010
Subject: It's 10/10/10 for RV10s...
Which means absolutely nothing but I wanted to be first... and perhaps last. Happy 10/10/10 Bill "seeing the beginning of flight" Watson ________________________________________________________________________________
Subject: Reinforcing Door Holes
Date: Oct 10, 2010
Hi In a week or so my doors will go for painting. Before this happens I'd like too reinforce the screw holes that attach the doors to the hinges. It has been suggested that I use countersunk washers (which I will) held in place with thinned epoxy. I am not sure if this is over kill, but to protect the paint from chipping and the washers from discolouring, I was thinking of putting a layer of thin glass cloth over the washers first. Has anyone done anything like that? Am I being a touch to anal? Inquiring minds need to know. Les #40643 ________________________________________________________________________________
Date: Oct 10, 2010
Subject: Re: Reinforcing Door Holes
I'm not there yet, but as a general rule if I use the Tinnerman washers, I paint where the washer goes and then paint the screw and washer separately. Wait until the paint is thoroughly hardened before driving the screws tight. Linn On 10/10/2010 6:41 PM, Les Kearney wrote: > > Hi > > In a week or so my doors will go for painting. Before this happens I'd > like too reinforce the screw holes that attach the doors to the > hinges. It has been suggested that I use countersunk washers (which I > will) held in place with thinned epoxy. > > I am not sure if this is over kill, but to protect the paint from > chipping and the washers from discolouring, I was thinking of putting > a layer of thin glass cloth over the washers first. > > Has anyone done anything like that? Am I being a touch to anal? > > Inquiring minds need to know. > > Les > #40643 > > * > > > * ________________________________________________________________________________
Date: Oct 10, 2010
Reinforcing Door HolesThinking the hinge on the door side shouldn't be coming off for any reason, I recall I used epoxy and flox to attach the hinge to the door, so the 4 screws are basically holding it in place but technically the strength is in the epoxy holding the hinge and door and the screws are reinforcing the bond. I'm having a hard time thinking how the screws will fit the countersunk with glass over them. Also why don't you just epoxy the washer on after spraying a self etching primer on the washers?, paint them and there should be no reason that they would chip. I have found, since we are using the same primer, that the DTM wash primer has worked better for me with pieces than the 988 has however. Pascal From: Les Kearney Sent: Sunday, October 10, 2010 3:41 PM Subject: RV10-List: Reinforcing Door Holes Hi In a week or so my doors will go for painting. Before this happens I'd like too reinforce the screw holes that attach the doors to the hinges. It has been suggested that I use countersunk washers (which I will) held in place with thinned epoxy. I am not sure if this is over kill, but to protect the paint from chipping and the washers from discolouring, I was thinking of putting a layer of thin glass cloth over the washers first. Has anyone done anything like that? Am I being a touch to anal? Inquiring minds need to know. Les #40643 ________________________________________________________________________________
Subject: reinforcing door hinges
Date: Oct 11, 2010
Timely question of reinforcing the door hinges, as that is what I'm doing right now. I feel the standard attachment method is flawed, at least for me. The reason is, I have always taxied airplanes with the door ajar for extra ventilation, especially here in Las Vegas. When I tried to open the door while taxing the Vans RV10 during a demonstration ride many years ago, I was chastised for it because the demo pilot warned me the doors are "weak link". A forward hinged door, like on a Cessna, will take the prop-blast in stride, and the blast will try to move the door in the direction it wants to go. A top hinged door when hit with a prop-blast or gust of wind, will try to open the door, as the in-flight RV10 door failures would indicate.(none of unlatched doors tried to slam shut, that I've heard of). I have a secure strap attachment nutplate, reinforced with an aluminum plate, glassed inside the door halves, to allow me a nylon strap to hang onto while the door is partially open, during taxi.The hinges are being reinforced with an aluminum plate on the outside of the doors, thru which the countersunk screws will pass. The plate is approximately the same size as the indentations (pockets) in the inside of the door, where the hinges mounts. The inside plate, also the same size as the tapered down portion of the pocket, has nutplates mounted for the screws. The hinge is embedded in epoxy/cabosil, that was set with mold release, so the hinge can slide in and out of this channel, for removal. The inside plate is then covered with carbon fiber, up the sides of the hinge pockets,and epoxied on. The remaining depth of the pockets are then filled with micro, so the pockets are now flush with the doors. The result is a significantly stronger hinge attachment, that should survive my desire to abuse my doors while taxing. Who knows, it may be strong enough to survive an in-flight opening? Chris Hukill ________________________________________________________________________________
Subject: Oct 14th help - mid california
Date: Oct 11, 2010
Wondering if any builders out there around Modesto within 2 hours need help with a build or want distractions from a fellow builder. I have a work trip flying out to Modesto on the 13th and leaving on the 15th so I have the afternoon/evening on the 13th and all day on the 14th. If not does anyone know a good hotel to stay at? I may go to Yosemite. I don't want to stay in MOD if I can help it. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315346#315346 ________________________________________________________________________________
Date: Oct 11, 2010
Subject: Re: Oct 14th help - mid california
It's supposed to be really nice here on the coast for the rest of the week. It's the opposite direction from Yosemite, though. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Mon, Oct 11, 2010 at 9:29 AM, Strasnuts wrote: > > Wondering if any builders out there around Modesto within 2 hours need help with a build or want distractions from a fellow builder. I have a work trip flying out to Modesto on the 13th and leaving on the 15th so I have the afternoon/evening on the 13th and all day on the 14th. If not does anyone know a good hotel to stay at? I may go to Yosemite. I don't want to stay in MOD if I can help it. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=315346#315346 > > ________________________________________________________________________________
Date: Oct 11, 2010
Subject: Re: reinforcing door hinges
Chris, any pictures available? Thanks Werner On 11.10.2010 17:44, Chris Hukill wrote: > > Timely question of reinforcing the door hinges, as that is what I'm > doing right now. I feel the standard attachment method is flawed, at > least for me. The reason is, I have always taxied airplanes with the > door ajar for extra ventilation, especially here in Las Vegas. When I > tried to open the door while taxing the Vans RV10 during a demonstration > ride many years ago, I was chastised for it because the demo pilot > warned me the doors are "weak link". A forward hinged door, like on a > Cessna, will take the prop-blast in stride, and the blast will try to > move the door in the direction it wants to go. A top hinged door when > hit with a prop-blast or gust of wind, will try to open the door, as the > in-flight RV10 door failures would indicate.(none of unlatched doors > tried to slam shut, that I've heard of). I have a secure strap > attachment nutplate, reinforced with an aluminum plate, glassed inside > the door halves, to allow me a nylon strap to hang onto while the door > is partially open, during taxi.The hinges are being reinforced with an > aluminum plate on the outside of the doors, thru which the countersunk > screws will pass. The plate is approximately the same size as the > indentations (pockets) in the inside of the door, where the hinges > mounts. The inside plate, also the same size as the tapered down portion > of the pocket, has nutplates mounted for the screws. The hinge is > embedded in epoxy/cabosil, that was set with mold release, so the hinge > can slide in and out of this channel, for removal. The inside plate is > then covered with carbon fiber, up the sides of the hinge pockets,and > epoxied on. The remaining depth of the pockets are then filled with > micro, so the pockets are now flush with the doors. The result is a > significantly stronger hinge attachment, that should survive my desire > to abuse my doors while taxing. Who knows, it may be strong enough to > survive an in-flight opening? > Chris Hukill > > * > > > * ________________________________________________________________________________
Subject: Cabin Door Gas Struts
Date: Oct 12, 2010
I need to replace my door struts; anyone have a source and a p/n for better one's than Van's. Thanks Barry Barry Marz 18735 Baseleg AVE. FT. Myers, Fl 33917 239-567-2271 blalmarz(at)embarqmail.com ________________________________________________________________________________
Date: Oct 12, 2010
Subject: Re: Cabin Door Gas Struts
I did a pretty thorough search about a year ago for Van's stronger struts. I ended up just getting theirs. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Oct 12, 2010 at 5:48 AM, Barry Marz wrote: > I need to replace my door struts; anyone have a source and a p/n for better > one's than Van's. Thanks Barry > > Barry Marz > 18735 Baseleg AVE. > FT. Myers, Fl 33917 > 239-567-2271 > blalmarz(at)embarqmail.com > > ________________________________________________________________________________
Date: Oct 12, 2010
I haven't researched the exact dimensions but noticed McMaster Carr has a few pages of them. http://www.mcmaster.com/#gas-shocks/=98rz96 -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315422#315422 ________________________________________________________________________________
Subject: gas strut
Date: Oct 12, 2010
Has anyone tried the 9416K15 or 4175T5 from McMaster? This seems to be the most comparable to the original struts supplied by Vans. ________________________________________________________________________________
Subject: Re: gas strut
Date: Oct 13, 2010
You do know that they can easily be re-filled / re-pressurised. We have a local fire extinguisher company where they simply put one in a bottle & pressurise the bottle overnight. Pick up your re-vitalized strut the next day. Cheap, quick & easy. Or else V expensive, slow & V enjoyable if you bring them to New Zealand! My RV-10 ones haven't need to be done, but we have had car struts done. Neil On 13/10/2010, at 7:50 AM, DLM wrote: > Has anyone tried the 9416K15 or 4175T5 from McMaster? This seems to be the most comparable to the original struts supplied by Vans. > > > > ________________________________________________________________________________
Date: Oct 12, 2010
Vans also sells a heavy duty strut. C-1016 HD 600N HEAVY DOOR STRUT $109.00 bob -------- Bob Leffler N410BL - Finish RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315458#315458 ________________________________________________________________________________
Date: Oct 12, 2010
Vans does resell a heavier duty strut than the default one in the finish kit. C-1016 HD 600N HEAVY DOOR STRUT $109.00 bob -------- Bob Leffler N410BL - Finish RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315459#315459 ________________________________________________________________________________
Date: Oct 12, 2010
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Have you guys seen this? http://www.vansairforce.com/community/showthread.php?t=60434 Maybe something here can help you out. Carlos in AZ On 10/12/2010 12:30 PM, rleffler wrote: > --> RV10-List message posted by: "rleffler" > > Vans also sells a heavy duty strut. > > C-1016 HD 600N HEAVY DOOR STRUT $109.00 > > bob > > -------- > Bob Leffler > N410BL - Finish > RV-10 #40684 > http://mykitlog.com/rleffler > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=315458#315458 > > -- Carlos Hernandez<carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Oct 13, 2010
These rock! Drop in replacement for wimpy Vans stock struts. Stabilus, Lift-O-Mat part number 2218LP. ~$80 each (plus shipping). Not in stock. Special order from Germany - 4 to 6 weeks delivery. JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014 Phone 513-769-9611 www.JWFtechnologies.com Regards, Jay [quote="Barry"]I need to replace my door struts; anyone have a source and a p/n for better one's than Van's. Thanks Barry > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315565#315565 ________________________________________________________________________________
Date: Oct 13, 2010
What is the pressure required to close the strut? too much would seem to snap the door open and too little would seem to be insufficient to hold it open. The "drop in" dimensions may work but a pressure range would seem to be needed. I was thinking of using the McMaster Carr strut but want to get the pressure right. ----- Original Message ----- From: "jayb" <jaybrinkmeyer(at)yahoo.com> Sent: Wednesday, October 13, 2010 8:54 AM Subject: RV10-List: Re: Cabin Door Gas Struts > > These rock! Drop in replacement for wimpy Vans stock struts. > > Stabilus, Lift-O-Mat part number 2218LP. ~$80 each (plus shipping). > > Not in stock. Special order from Germany - 4 to 6 weeks delivery. > > JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014 > Phone 513-769-9611 > > www.JWFtechnologies.com > > > Regards, > Jay > > [quote="Barry"]I need to replace my door struts; anyone have a source and > a p/n for better one's than Van's. Thanks Barry > >> [b] > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=315565#315565 > > > ________________________________________________________________________________
Date: Oct 13, 2010
We at www.airward.com have developed a door hinge reinforcing kit similar to what you described. Take a look. Dave Ward ________________________________________________________________________________
Date: Oct 14, 2010
Subject: travel tools
About to take the plane form ME to CA and want to put together a tool kit for the trip. I recall a while back there was some discussions about what tools to carry in the plane but I can't find those posts via the matronics search engine. Can anyone help? Thanks, Jay Rowe #40301--154 hours. ________________________________________________________________________________
Date: Oct 14, 2010
Subject: fuel valve with position both
I might open Pandoras box here but it's not about primer so lets try: On my high wing Glastar I have a left/both/right fuel valve and it is used most of the time in the both mode, except when on the ground (crossfeed risk) or on low fuel situations. Now on low wing airplanes I see the left/right only, what is the reason for it (I guess there must be a technical reason behind that)? ok I get my firesuite out before I get the flames Werner ________________________________________________________________________________
Date: Oct 14, 2010
Subject: Re: fuel valve with position both
No flames. Actually, it's a good question. On the high wing, the valve is always under positive fuel pressure (in any attitude but inverted .... ;-) ) due to the head .... 5' maybe? On the low wing, it would be possible to unport one tank feed ..... and suck air. Linn On 10/14/2010 4:32 PM, Werner Schneider wrote: > > I might open Pandoras box here but it's not about primer so lets try: > > On my high wing Glastar I have a left/both/right fuel valve and it is > used most of the time in the both mode, except when on the ground > (crossfeed risk) or on low fuel situations. > > Now on low wing airplanes I see the left/right only, what is the > reason for it (I guess there must be a technical reason behind that)? > > ok I get my firesuite out before I get the flames > > Werner > > ________________________________________________________________________________
Date: Oct 14, 2010
IM not sure why, but I miss that option.=0A=0A=0A=0A=0A____________________ ____________=0AFrom: Werner Schneider <glastar(at)gmx.net>=0ATo: rv10-list@mat ronics.com=0ASent: Thu, October 14, 2010 1:32:34 PM=0ASubject: RV10-List: f chneider =0A=0AI might open Pandoras box here but it's not about primer so lets try:=0A=0AOn my high wing Glastar I have a left/both/ right fuel valve and it is used most =0Aof the time in the both mode, excep t when on the ground (crossfeed risk) or on =0Alow fuel situations.=0A=0ANo w on low wing airplanes I see the left/right only, what is the reason for i t =0A(I guess there must be a technical reason behind that)?=0A=0Aok I get - - - - - - - - - - - - - - -Matt Dralle, List ========0A=0A=0A ________________________________________________________________________________
Date: Oct 14, 2010
Subject: Painting screws and small parts - what to stick them in - foam?
I remember seeing someone use foam or some other material to stick screws into for painting. I have some blue foam that looks like it will spray debris all over the place. Has anyone used formed successfully? What kind did you use. Bill "fume breathing.... not" Watson ________________________________________________________________________________
Date: Oct 14, 2010
Subject: Re: Painting screws and small parts - what to stick them in
- foam? I use a piece of cardboard to hold PK screws (like wood screws) and a piece of Masonite with the holes in it .... like pegboard. Some foams aren't compatible with paint so test before you try and spray screws. Linn On 10/14/2010 6:28 PM, Bill Watson wrote: > > I remember seeing someone use foam or some other material to stick > screws into for painting. I have some blue foam that looks like it > will spray debris all over the place. > > Has anyone used formed successfully? What kind did you use. > > Bill "fume breathing.... not" Watson > > ________________________________________________________________________________
- foam?
Date: Oct 14, 2010
Green foam used for floral arrangments. Rick Sent from my iPhone On Oct 14, 2010, at 3:28 PM, Bill Watson wrote: > > I remember seeing someone use foam or some other material to stick > screws into for painting. I have some blue foam that looks like it > will spray debris all over the place. > > Has anyone used formed successfully? What kind did you use. > > Bill "fume breathing.... not" Watson > > ________________________________________________________________________________
Date: Oct 14, 2010
- foam? Poke some holes into a cardboard box with an awl and press the screws into the holes. Aircraft Spruce boxes seem to work particularly well... Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Oct 14, 2010 at 3:28 PM, Bill Watson wrote: > > I remember seeing someone use foam or some other material to stick screws > into for painting. I have some blue foam that looks like it will spray > debris all over the place. > > Has anyone used formed successfully? What kind did you use. > > Bill "fume breathing.... not" Watson > > ________________________________________________________________________________
Subject: Re: travel tools
Date: Oct 14, 2010
2- locking plyers - lg & small 2 - phillips screw drivers - long & short handle 1. shorty mini phillips 1 -file 1 std screwdriver 1 - reaching magnet 1- lithium ion drill 1 - set drill bits 1 - assort of extra screws & nylocks 1 - set of ratcheting wrenches 3/8 7/16 etc 1 - 1/4 " driver set -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315788#315788 ________________________________________________________________________________
Date: Oct 15, 2010
in - foam? Thanks all. So many solutions, so dull a mind. I'm sure I have a few ACS boxes lying around. Bill On 10/14/2010 7:33 PM, Dave Saylor wrote: > --> RV10-List message posted by: Dave Saylor > > Poke some holes into a cardboard box with an awl and press the screws > into the holes. Aircraft Spruce boxes seem to work particularly well... > > Dave Saylor > ________________________________________________________________________________
Date: Oct 15, 2010
Thanks Linn, I agree, on a high wing the fuel pressure is higher, but on a low wing you still pressurize the tanks as well so you should be fine? Unporting would only be possible on a very low fuel level or uncoordinated flight I plan to add low fuel warnings as well (have them in my Star as we have a SB concerning the same problem). Will see if we get deeper into that "why". Cheers Werner Glastar HB-YKP flying RV-10 #41122 waiting for shipping On 14.10.2010 22:45, Linn Walters wrote: > > No flames. Actually, it's a good question. > On the high wing, the valve is always under positive fuel pressure (in > any attitude but inverted .... ;-) ) due to the head .... 5' maybe? > On the low wing, it would be possible to unport one tank feed ..... and > suck air. > Linn > > On 10/14/2010 4:32 PM, Werner Schneider wrote: >> >> I might open Pandoras box here but it's not about primer so lets try: >> >> On my high wing Glastar I have a left/both/right fuel valve and it is >> used most of the time in the both mode, except when on the ground >> (crossfeed risk) or on low fuel situations. >> >> Now on low wing airplanes I see the left/right only, what is the >> reason for it (I guess there must be a technical reason behind that)? >> >> ok I get my firesuite out before I get the flames >> >> Werner >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 15, 2010
On 10/15/2010 7:31 AM, Werner Schneider wrote: > > Thanks Linn, > > I agree, on a high wing the fuel pressure is higher, but on a low wing > you still pressurize the tanks as well so you should be fine? > Unporting would only be possible on a very low fuel level or > uncoordinated flight > I plan to add low fuel warnings as well (have them in my Star as we > have a SB concerning the same problem). > > Will see if we get deeper into that "why". Well, you already did!! I'm not sure how much 'usable fuel' you will get ...... the valve is mounted at the top of the tunnel ..... run that station out to the wing tank and see how much fuel you leave in the tank. Better to just take a pass on the 'both' valve. Linn > > Cheers Werner > > Glastar HB-YKP flying > RV-10 #41122 waiting for shipping > > > On 14.10.2010 22:45, Linn Walters wrote: >> >> >> No flames. Actually, it's a good question. >> On the high wing, the valve is always under positive fuel pressure (in >> any attitude but inverted .... ;-) ) due to the head .... 5' maybe? >> On the low wing, it would be possible to unport one tank feed ..... and >> suck air. >> Linn >> >> On 10/14/2010 4:32 PM, Werner Schneider wrote: >>> >>> I might open Pandoras box here but it's not about primer so lets try: >>> >>> On my high wing Glastar I have a left/both/right fuel valve and it is >>> used most of the time in the both mode, except when on the ground >>> (crossfeed risk) or on low fuel situations. >>> >>> Now on low wing airplanes I see the left/right only, what is the >>> reason for it (I guess there must be a technical reason behind that)? >>> >>> ok I get my firesuite out before I get the flames >>> >>> Werner >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
in - foam?
Date: Oct 15, 2010
Hey Bill, I fooled around with spraying a bunch of screw heads, but here's what I ended up doing. Spraying the heads tends to fill up the slot and painting the heads after installed with a small paint brush really doesn't take that much time, doesn't fill the slot, doesn't "weld" the screw to the body, doesn't use much paint, have overspray, etc. The countersunk parts that receive the screws that got painted without screws in them, caused tears in the paint when screws were tightened in them, so I quickly learned to drill out the paint before seating screws in them. One of my wife's make up "paint" brushes works great -- Later, - Lew "No, Honey, I haven't seen it" Gallagher ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Friday, October 15, 2010 7:23 AM Subject: Re: RV10-List: Painting screws and small parts - what to stick them in - foam? > > Thanks all. So many solutions, so dull a mind. I'm sure I have a few > ACS boxes lying around. > > Bill ________________________________________________________________________________
Date: Oct 15, 2010
Hello Linn, no, my valve will be on the bottom of the tunnel (Andair Valve with extension) and I have still the head pressure of the tank vents. As I have still time until I'm there I will do a bit of geometry to see where I end. Thanks Werner Glastar HB-YKP flying RV-10 #41122 waiting for shipping On 15.10.2010 13:44, Linn Walters wrote: > > On 10/15/2010 7:31 AM, Werner Schneider wrote: >> >> Thanks Linn, >> >> I agree, on a high wing the fuel pressure is higher, but on a low wing >> you still pressurize the tanks as well so you should be fine? >> Unporting would only be possible on a very low fuel level or >> uncoordinated flight >> I plan to add low fuel warnings as well (have them in my Star as we >> have a SB concerning the same problem). >> >> Will see if we get deeper into that "why". > Well, you already did!! > I'm not sure how much 'usable fuel' you will get ...... the valve is > mounted at the top of the tunnel ..... run that station out to the wing > tank and see how much fuel you leave in the tank. Better to just take a > pass on the 'both' valve. > Linn > >> >> Cheers Werner >> >> Glastar HB-YKP flying >> RV-10 #41122 waiting for shipping >> >> >> On 14.10.2010 22:45, Linn Walters wrote: >>> >>> >>> No flames. Actually, it's a good question. >>> On the high wing, the valve is always under positive fuel pressure (in >>> any attitude but inverted .... ;-) ) due to the head .... 5' maybe? >>> On the low wing, it would be possible to unport one tank feed ..... and >>> suck air. >>> Linn >>> >>> On 10/14/2010 4:32 PM, Werner Schneider wrote: >>>> >>>> I might open Pandoras box here but it's not about primer so lets try: >>>> >>>> On my high wing Glastar I have a left/both/right fuel valve and it is >>>> used most of the time in the both mode, except when on the ground >>>> (crossfeed risk) or on low fuel situations. >>>> >>>> Now on low wing airplanes I see the left/right only, what is the >>>> reason for it (I guess there must be a technical reason behind that)? >>>> >>>> ok I get my firesuite out before I get the flames >>>> >>>> Werner >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: California Trip - Catalina Island
Date: Oct 15, 2010
(source AOPA) Catalina Island Conservancy officials know a good thing when they see it, and have extended a previous two-day offer to waive the $20 Catalina Isla nd landing fee for AOPA members during AOPA Aviation Summit. Now, the fee is waived for four days, Nov. 11 through 14, to cover the entire Summit. Response to the original offer was strong, so Conservancy officials decide d to extend the offer. Just show your AOPA membership card once you land on the island, and the fee is waived. Not only that, but you get 20 perce nt off the Wildlands Express shuttle service, normally a $17 charge. Should you happen to buy $10 worth of food at the airport=99s DC-3 Gifts and Grill shop, you=99ll get a free Killer Cookie, so the goo d news just keeps rolling in. For those making the trip to Catalina more frequently, such as California pilots, there is an additional option. Join the new Catalina Aero Club fo r $150 per year, and you=99ll have unlimited free landing privileges . =9CI am thrilled to see the pilots who make Catalina one of their mo st popular destinations want to redefine their commitment to the protectio n and recreation of the Island through their membership in the new Catalin a Aero Club,=9D said Conservancy President Ann Muscat. Other benefits to club members include one annual Freewheeler bike pass an d 50 percent off Conservancy campground fees. Current Conservancy members who would like to upgrade to the Aero Club can do so and extend their membership for $115. Those who are current Leaders hip Circle members can now enjoy unlimited free landings at Airport in the Sky.=94Alton K. Marsh Jeff Darnall Jacksonville, FL 904-234-8718 __i__ *-----o--o--(_)--o--o-----* ________________________________________________________________________________
Date: Oct 15, 2010
I have some experience on this topic. During phase 1 testing on my 10 i ran a tank dry over airport and had an engine failure. Was unable to get other tank on line due to air in system. Dead stick landing. no issues. discovered that the vans fuel valve which was left, right and aux was allowing the good tank to still draw air due to being slighty out of the detent position. lousy detent on vans valves. replaced valve with andair. no further issues. not a fan of cheap valves on low wing airplanes. you cannot use a valve with both on low wing. Kevin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315817#315817 ________________________________________________________________________________
Date: Oct 15, 2010
Werner, The head pressure from your Glastar tanks is many times the pressure from the fuel vent. If it weren't, high-wings on "Both" would be running out of gas all the time. Head pressure tries to push fuel back into the empty tank, against vent pressure. That works in a high-wing because you have a couple feet of rise. In a low-wing airplane there isn't enough pressure difference between an empty tank and a partially-full tank to favor the fuller tank. The pump pulls from the path of least resistance, which is the air in the empty tank. Lots of people have tried a "Both"position in RVs and other low wings. It doesn't work out. You'll build a safer plane if you stick with Left-Right-Off. I didn't have much low-wing time before my 10 and while it is something else to do, switching back and forth isn't that big a deal. Plus it really keeps you cognizant of your fuel situation. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Fri, Oct 15, 2010 at 5:36 AM, Werner Schneider wrote: > > Hello Linn, > > no, my valve will be on the bottom of the tunnel (Andair Valve with > extension) and I have still the head pressure of the tank vents. > > As I have still time until I'm there I will do a bit of geometry to see > where I end. > > Thanks > > Werner > > Glastar HB-YKP flying > RV-10 #41122 waiting for shipping > > On 15.10.2010 13:44, Linn Walters wrote: >> >> >> On 10/15/2010 7:31 AM, Werner Schneider wrote: >>> >>> >>> Thanks Linn, >>> >>> I agree, on a high wing the fuel pressure is higher, but on a low wing >>> you still pressurize the tanks as well so you should be fine? >>> Unporting would only be possible on a very low fuel level or >>> uncoordinated flight >>> I plan to add low fuel warnings as well (have them in my Star as we >>> have a SB concerning the same problem). >>> >>> Will see if we get deeper into that "why". >> >> Well, you already did!! >> I'm not sure how much 'usable fuel' you will get ...... the valve is >> mounted at the top of the tunnel ..... run that station out to the wing >> tank and see how much fuel you leave in the tank. Better to just take a >> pass on the 'both' valve. >> Linn >> >>> >>> Cheers Werner >>> >>> Glastar HB-YKP flying >>> RV-10 #41122 waiting for shipping >>> >>> >>> On 14.10.2010 22:45, Linn Walters wrote: >>>> >>>> >>>> >>>> No flames. Actually, it's a good question. >>>> On the high wing, the valve is always under positive fuel pressure (in >>>> any attitude but inverted .... ;-) ) due to the head .... 5' maybe? >>>> On the low wing, it would be possible to unport one tank feed ..... and >>>> suck air. >>>> Linn >>>> >>>> On 10/14/2010 4:32 PM, Werner Schneider wrote: >>>>> >>>>> >>>>> I might open Pandoras box here but it's not about primer so lets try: >>>>> >>>>> On my high wing Glastar I have a left/both/right fuel valve and it is >>>>> used most of the time in the both mode, except when on the ground >>>>> (crossfeed risk) or on low fuel situations. >>>>> >>>>> Now on low wing airplanes I see the left/right only, what is the >>>>> reason for it (I guess there must be a technical reason behind that)? >>>>> >>>>> ok I get my firesuite out before I get the flames >>>>> >>>>> Werner >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > ________________________________________________________________________________
- foam?
Date: Oct 15, 2010
One thing I noticed with test samples is that paint dust will accumulate on the boxes. I do "will call" at ACS so no idea what their boxes are like but I have found that using packing tape over the box holes eliminates any future dust issues. Pascal -------------------------------------------------- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Friday, October 15, 2010 4:23 AM Subject: Re: RV10-List: Painting screws and small parts - what to stick them in - foam? > > Thanks all. So many solutions, so dull a mind. I'm sure I have a few > ACS boxes lying around. > > Bill > > On 10/14/2010 7:33 PM, Dave Saylor wrote: >> --> RV10-List message posted by: Dave >> Saylor >> >> Poke some holes into a cardboard box with an awl and press the screws >> into the holes. Aircraft Spruce boxes seem to work particularly well... >> >> Dave Saylor >> > > > ________________________________________________________________________________
Date: Oct 15, 2010
I did see that over the last couple days...and I can report that someone in t he media somewhere needs to update one minor detail in their facts.....the l anding fee now being charges is $25, not $20. I had no idea until I got the re myself a few days ago. Someone in the pattern landed and didn't even kno w there was a fee (clueless I guess...) but they told him too over unicom th at it was $25. Not sure when it changed but I was surprised when all the em ail news things i started receiving still said $20. Anyway, the place is awesome to land at!!! Clouds all below you and just an island in them popping up to land on! I thought I'd have nooooo problem, with 675+ on the RV-10, but with a combin ation of plenty of traffic in the pattern (visible with ads-b!!!), lots of h eat, and the perception, I didn't descend fast enough or had a slightly tigh t pattern and had to slip off a couple hundred extra feet on final. Other than that, it was a breeze. The takeoff was cool as all heck, too! I t just drops off the cliff below you. Sedona, in comparison, was much less complicated, with all the better surrou nding terrain reference. Beautiful area there too. Almost done with the trip now....heading towards home in a couple hours. The write-up may take a week or two but we got some great photos! Tim On Oct 15, 2010, at 5:51 AM, darnpilot(at)aol.com wrote: > (source AOPA) > > Catalina Island Conservancy officials know a good thing when they see it, a nd have extended a previous two-day offer to waive the $20 Catalina Island l anding fee for AOPA members during AOPA Aviation Summit. Now, the fee is wai ved for four days, Nov. 11 through 14, to cover the entire Summit. > Response to the original offer was strong, so Conservancy officials decide d to extend the offer. Just show your AOPA membership card once you land on t he island, and the fee is waived. Not only that, but you get 20 percent off t he Wildlands Express shuttle service, normally a $17 charge. > Should you happen to buy $10 worth of food at the airport=99s DC-3 G ifts and Grill shop, you=99ll get a free Killer Cookie, so the good ne ws just keeps rolling in. > For those making the trip to Catalina more frequently, such as California p ilots, there is an additional option. Join the new Catalina Aero Club for $1 50 per year, and you=99ll have unlimited free landing privileges. > =9CI am thrilled to see the pilots who make Catalina one of their mo st popular destinations want to redefine their commitment to the protection a nd recreation of the Island through their membership in the new Catalina Aer o Club,=9D said Conservancy President Ann Muscat. > Other benefits to club members include one annual Freewheeler bike pass an d 50 percent off Conservancy campground fees. > Current Conservancy members who would like to upgrade to the Aero Club can do so and extend their membership for $115. Those who are current Leadershi p Circle members can now enjoy unlimited free landings at Airport in the Sky .=94Alton K. Marsh > > > Jeff Darnall > Jacksonville, FL > 904-234-8718 > __i__ > *-----o--o--(_)--o--o-----* > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Oct 15, 2010
Also, a side "benefit" to the low wing's limitation against "both" position is that it reinforces better fuel management practices....and allows you to always know the remaining fuel. Anybody notice that the rv-10's with presumably nearly 100% equipage of fuel computers and flow meters, has basically never had an off-airport landing (that we know of) due to poor fuel planning? Let's keep it that way....we have the tools, if we use them. Tim On Oct 15, 2010, at 4:31 AM, Werner Schneider wrote: > > Thanks Linn, > > I agree, on a high wing the fuel pressure is higher, but on a low wing you still pressurize the tanks as well so you should be fine? Unporting would only be possible on a very low fuel level or uncoordinated flight > I plan to add low fuel warnings as well (have them in my Star as we have a SB concerning the same problem). > > Will see if we get deeper into that "why". > > Cheers Werner > > Glastar HB-YKP flying > RV-10 #41122 waiting for shipping > > > On 14.10.2010 22:45, Linn Walters wrote: >> >> No flames. Actually, it's a good question. >> On the high wing, the valve is always under positive fuel pressure (in >> any attitude but inverted .... ;-) ) due to the head .... 5' maybe? >> On the low wing, it would be possible to unport one tank feed ..... and >> suck air. >> Linn >> >> On 10/14/2010 4:32 PM, Werner Schneider wrote: >>> >>> I might open Pandoras box here but it's not about primer so lets try: >>> >>> On my high wing Glastar I have a left/both/right fuel valve and it is >>> used most of the time in the both mode, except when on the ground >>> (crossfeed risk) or on low fuel situations. >>> >>> Now on low wing airplanes I see the left/right only, what is the >>> reason for it (I guess there must be a technical reason behind that)? >>> >>> ok I get my firesuite out before I get the flames >>> >>> Werner >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 15, 2010
It is possible to have a "both" fuel system, but in low wing planes as others have said it's difficult because the fuel is at/near/below the engine. While at rest gravity would naturally keep the tank levels balanced, in the air it's a different story. It's not just about the tanks being pressurized/vented, but for a "both" selection they need to be pressurized equally. You'll notice that in most high wing airplanes with a both selection, the vents of the two tanks are tied together...in a low wing plane if you didn't have the two tank vents tied together, then one tank will likely have a slightly higher pressure than the other...which mean fuel will be routed from that particular tank and possibly run empty before sucking gas out of the other tank; and you could have an engine sucking air with one wing tank being completely full. It could also cause fuel from one tank to be routed to the other and then overboard. Even though the tanks are vented and "pressurized", it's likely not enough to cause sufficient fuel flow to the engine without and electric or fuel driven pump (which you can get by without on many high wing planes). Remember, we're as much "sucking" the fuel from the tanks as we are pushing when the level of the tanks is below the engine. Anyway, There are ways to do it but none as simple as just doing it the way Van's says. There have been various people who've re-invented the wheel on van's fuel system, but out of the 7000+ flying RV's, the standard way of doing it has been proven as reliable and functional. My 2 cents as usual! Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, October 15, 2010 10:46 AM Subject: Re: RV10-List: fuel valve with position both Also, a side "benefit" to the low wing's limitation against "both" position is that it reinforces better fuel management practices....and allows you to always know the remaining fuel. Anybody notice that the rv-10's with presumably nearly 100% equipage of fuel computers and flow meters, has basically never had an off-airport landing (that we know of) due to poor fuel planning? Let's keep it that way....we have the tools, if we use them. Tim On Oct 15, 2010, at 4:31 AM, Werner Schneider wrote: > > Thanks Linn, > > I agree, on a high wing the fuel pressure is higher, but on a low wing you still pressurize the tanks as well so you should be fine? Unporting would only be possible on a very low fuel level or uncoordinated flight > I plan to add low fuel warnings as well (have them in my Star as we have a SB concerning the same problem). > > Will see if we get deeper into that "why". > > Cheers Werner > > Glastar HB-YKP flying > RV-10 #41122 waiting for shipping > > > On 14.10.2010 22:45, Linn Walters wrote: >> >> No flames. Actually, it's a good question. >> On the high wing, the valve is always under positive fuel pressure (in >> any attitude but inverted .... ;-) ) due to the head .... 5' maybe? >> On the low wing, it would be possible to unport one tank feed ..... and >> suck air. >> Linn >> >> On 10/14/2010 4:32 PM, Werner Schneider wrote: >>> >>> I might open Pandoras box here but it's not about primer so lets try: >>> >>> On my high wing Glastar I have a left/both/right fuel valve and it is >>> used most of the time in the both mode, except when on the ground >>> (crossfeed risk) or on low fuel situations. >>> >>> Now on low wing airplanes I see the left/right only, what is the >>> reason for it (I guess there must be a technical reason behind that)? >>> >>> ok I get my firesuite out before I get the flames >>> >>> Werner >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Oct 15, 2010
One other point. I dont have it with me but believe the manual on the air flow performance fuel pump has a specific warning on introducing air into the system could cause an air lock. Kevin Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315860#315860 ________________________________________________________________________________
Date: Oct 15, 2010
This can be simply explained with an analogy. Picture yourself with two glasses of beer above your head, with a tube coming out the bottom of both running to a Y and a single tube then running into your mouth. Once you start sucking a little, you'd get some beer, and wouldn't need to suck much more after that (or at all). Essentially both glasses are gravity feeding the single tube, and until they both run empty you'll get a constant flow of beer. Now do the same thing, but put the glasses down to your knees. Nothing is automatically filling the single tube after the Y. In fact, gravity will attempt to equalize the amount in each glass so their levels remain the same, but gravity can't fill the tube running up to your mouth higher than the top level in the glasses down at your knees. You must suck, and continue to do so to get beer. The further from your mouth, the harder you'll need to suck. If you get ahead of gravity's ability to even the glasses, and you empty one of them ahead of the other, your required sucking will suck air (likely a mix of mostly air and some beer). Either way, your required constant flow of beer has been interrupted and that's bad. John Melchert N316PT RV-10 (building, QB fuse) Eden Prairie, MN ________________________________________________________________________________
Date: Oct 15, 2010
I've not played with the combination of beer and hoses since college -- but in my experience, when you run beer through a funnel and tube, you can get all sorts of vapor lock problems with excessive foaming, no matter if you use gravity or suck it uphill. Perhaps you can avoid these problems by only using fuel that doesn't contain alcohol? :-) Chris On Fri, Oct 15, 2010 at 11:04 AM, John Melchert wrote: > > This can be simply explained with an analogy. > > Picture yourself with two glasses of beer above your head, with a tube > coming out the bottom of both running to a Y and a single tube then running > into your mouth. Once you start sucking a little, you'd get some beer, and > wouldn't need to suck much more after that (or at all). Essentially both > glasses are gravity feeding the single tube, and until they both run empty > you'll get a constant flow of beer. > > Now do the same thing, but put the glasses down to your knees. Nothing is > automatically filling the single tube after the Y. In fact, gravity will > attempt to equalize the amount in each glass so their levels remain the > same, but gravity can't fill the tube running up to your mouth higher than > the top level in the glasses down at your knees. You must suck, and > continue to do so to get beer. The further from your mouth, the harder > you'll need to suck. If you get ahead of gravity's ability to even the > glasses, and you empty one of them ahead of the other, your required > sucking > will suck air (likely a mix of mostly air and some beer). Either way, your > required constant flow of beer has been interrupted and that's bad. > > John Melchert > N316PT RV-10 (building, QB fuse) > Eden Prairie, MN > > ________________________________________________________________________________
Date: Oct 15, 2010
Many thanks for the many and valuable comments. A both position would work, if each tank would have a single fuel pump before the fuel valve in the cases described, this would grant a fuel flow secured after unporting and switching valve. I agree left right demands a constant fuel management (which puts more load in difficult situation) but makes a bigger awareness of fuel remaining. A lot of fuel (or beer) for thoughts and good technical arguments. Thanks again to the group for filling that gap of my missing knowledge. I probably will go the Andair fuel pump way as it looks to be the better technology with much less connections then the ES Airflow one. br Werner Glastar HB-YKP flying RV-10 #41122 waiting for shipping On 15.10.2010 18:24, Stein Bruch wrote: > --> RV10-List message posted by: "Stein Bruch" > > It is possible to have a "both" fuel system, but in low wing planes as > others have said it's difficult because the fuel is at/near/below the > engine. While at rest gravity would naturally keep the tank levels > balanced, in the air it's a different story. It's not just about the tanks > being pressurized/vented, but for a "both" selection they need to be > pressurized equally. You'll notice that in most high wing airplanes with a > both selection, the vents of the two tanks are tied together...in a low wing > plane if you didn't have the two tank vents tied together, then one tank > will likely have a slightly higher pressure than the other...which mean fuel > will be routed from that particular tank and possibly run empty before > sucking gas out of the other tank; and you could have an engine sucking air > with one wing tank being completely full. It could also cause fuel from one > tank to be routed to the other and then overboard. Even though the tanks > are vented and "pressurized", it's likely not enough to cause sufficient > fuel flow to the engine without and electric or fuel driven pump (which you > can get by without on many high wing planes). Remember, we're as much > "sucking" the fuel from the tanks as we are pushing when the level of the > tanks is below the engine. > > Anyway, There are ways to do it but none as simple as just doing it the way > Van's says. There have been various people who've re-invented the wheel on > van's fuel system, but out of the 7000+ flying RV's, the standard way of > doing it has been proven as reliable and functional. > > My 2 cents as usual! > > Cheers, > > Stein > ________________________________________________________________________________
Date: Oct 15, 2010
On 10/15/2010 4:55 PM, Werner Schneider wrote: > > Many thanks for the many and valuable comments. You're welcome. It's why we're here. > A both position would work, if each tank would have a single fuel pump > before the fuel valve in the cases described, this would grant a fuel > flow secured after unporting and switching valve. I see what you mean. Having a pump (actually two) in the wing root at the lowest point would solve the problem that didn't exist before the 'both' position was selected. However, now we've added two pumps (weight), wire (weight) and switches (more weight) to solve a problem that really shouldn't exist. > > I agree left right demands a constant fuel management (which puts more > load in difficult situation) but makes a bigger awareness of fuel > remaining. As I see it, switching tanks every 15 minutes to 1/2 hour is a whole lot safer than turning on the pumps. However, if you'll forget to switch tanks ...... maybe the switches will end up in the same category. From experience, I can tell you that running a tank dry on takeoff (doing T&Gs) in the pattern will get your attention. That was when I was a baby pilot. Another educational experience. > > A lot of fuel (or beer) for thoughts and good technical arguments. I noticed that there are a lot of beer experts on this list. :-D > Thanks again to the group for filling that gap of my missing knowledge. If we really did. > I probably will go the Andair fuel pump way as it looks to be the > better technology with much less connections then the ES Airflow one. Not sure what that means. :-P Best of luck. Linn > > br > > Werner > > Glastar HB-YKP flying > RV-10 #41122 waiting for shipping > > On 15.10.2010 18:24, Stein Bruch wrote: >> --> RV10-List message posted by: "Stein Bruch" >> >> It is possible to have a "both" fuel system, but in low wing planes as >> others have said it's difficult because the fuel is at/near/below the >> engine. While at rest gravity would naturally keep the tank levels >> balanced, in the air it's a different story. It's not just about the >> tanks >> being pressurized/vented, but for a "both" selection they need to be >> pressurized equally. You'll notice that in most high wing airplanes >> with a >> both selection, the vents of the two tanks are tied together...in a >> low wing >> plane if you didn't have the two tank vents tied together, then one tank >> will likely have a slightly higher pressure than the other...which >> mean fuel >> will be routed from that particular tank and possibly run empty before >> sucking gas out of the other tank; and you could have an engine >> sucking air >> with one wing tank being completely full. It could also cause fuel >> from one >> tank to be routed to the other and then overboard. Even though the >> tanks >> are vented and "pressurized", it's likely not enough to cause sufficient >> fuel flow to the engine without and electric or fuel driven pump >> (which you >> can get by without on many high wing planes). Remember, we're as much >> "sucking" the fuel from the tanks as we are pushing when the level of >> the >> tanks is below the engine. >> >> Anyway, There are ways to do it but none as simple as just doing it >> the way >> Van's says. There have been various people who've re-invented the >> wheel on >> van's fuel system, but out of the 7000+ flying RV's, the standard way of >> doing it has been proven as reliable and functional. >> >> My 2 cents as usual! >> >> Cheers, >> >> Stein >> > > ________________________________________________________________________________
Subject: Re: Totally Off Topic - quadrotor
Date: Oct 16, 2010
Ron, I've been playing with those a while back, when you had to hack out gyro's from a gyroscopic mouse... You'll find some excellent information on the rcuniverse.com forums. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315964#315964 ________________________________________________________________________________
Subject: Screws in Fiberglass
Date: Oct 16, 2010
I need to mount a few things to the fiberglass top using screws (lights, seatbelt holder, etc). What's the best way to do this? Thanks! Wayne N767W ________________________________________________________________________________
Date: Oct 16, 2010
Subject: Re: Screws in Fiberglass
I have no idea what the best way is. ;-) What I do is embed a nut in milled fiber with the screw inserted. coat the screw threads with petroleum jelly so you can get the screw out!!! I do not like PK screws as they loosen up and if you insert/remove them enough the hole will get bigger. Linn On 10/16/2010 4:05 PM, Wayne Williams wrote: > --> RV10-List message posted by: "Wayne Williams" > > I need to mount a few things to the fiberglass top using screws (lights, > seatbelt holder, etc). What's the best way to do this? Thanks! > > Wayne > N767W > > ________________________________________________________________________________
Date: Oct 16, 2010
I've been using Nutserts pretty successfully. They work in aluminum too but only recommended there instead of a sheet metal screw (e.g. gear leg fairings into fuselage) http://www.aircraftspruce.com/catalog/hapages/nutserts.php the AAT916 expendable nutsert tool works fine for the number you'll need to do: http://www.aircraftspruce.com/catalog/topages/nutserttools.php I haven't used them in an operational aircraft yet Bill "wondering why everyone isn't using PreKote" Watson On 10/16/2010 4:05 PM, Wayne Williams wrote: > --> RV10-List message posted by: "Wayne Williams" > > I need to mount a few things to the fiberglass top using screws (lights, > seatbelt holder, etc). What's the best way to do this? Thanks! > > Wayne > N767W > > ________________________________________________________________________________
Date: Oct 16, 2010
Hey Wayne, It's not slick, but works. For the seat belt and headphone holder, I used these T nuts from Lowes or Home Depot: http://www.lowes.com/SearchCatalogDisplay?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=t+nut Drilled for the screw insert first, drilled tiny holes for the "ears" that keep it from turning, then glassed them in. Cover with headliner and you can't tell they're there. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=315977#315977 ________________________________________________________________________________
Date: Oct 17, 2010
Rivnuts worked well for me on the cabin top. http://www.aircraftspruce.com/catalog/hapages/rivnuts.php cheers, Ron VH-XRM flying in Oz ----- Original Message ----- From: "Wayne Williams" <rwayne(at)gamewood.net> Sent: Sunday, October 17, 2010 7:05 AM Subject: RV10-List: Screws in Fiberglass > > I need to mount a few things to the fiberglass top using screws (lights, > seatbelt holder, etc). What's the best way to do this? Thanks! > > Wayne > N767W > > > > > ________________________________________________________________________________
Subject: screws in fiberglass
Date: Oct 16, 2010
I held my custom overhead console with eight to ten SS screws that went int o SS threaded inserts which I epoxied into the cabin top. If you have acces s to a sandblaster to etch the insert surface even better. Here is only a link for showing what I am referring to: http://www.woodcra ft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Oct 17, 2010
Subject: Re: screws in fiberglass
There are lots of inserts you can use to put threads into a cored structure. If you look around (or call me), you can get specialty inserts made just for bonding into panels. For example, here's a link: http://www.gen-aircraft-hardware.com/viewImage.asp?item=NAS1832-3-3&folder=basic T-nuts and other inserts work almost as well for a few screws here and there. They take a little more fiddling to get them into the core and secure, but they cost pennies as opposed to dollars for the inserts above. Make sure the inserts are securely attached to the core and to the skin, and test how well they attached by giving the insert a good tug. Keep in mind that inserts are for non-structural applications like consoles, lights, belt and headset racks, etc. Anything that takes a load like shoulder belts, cargo tie downs, etc., need a much stronger, tested, engineered solution. My overhead light console is attached with five very small sheet-metal screws. It comes off very infrequently so I'm not too worried about wearing out the holes. I could always push a little epoxy into the hole if it stripped. FWIW, I tried to get Vans to sell my overhead console, but they were worried about the tiny holes in the inner skin of the cabin top. So keep in mind that Vans isn't going to be happy about hearing that you put holes in the cabin top. Personally, I'm not worried about what I did to mine. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sat, Oct 16, 2010 at 4:43 PM, John Gonzalez wrote: > I held my custom overhead console with eight to ten SS screws that went into > SS threaded inserts which I epoxied into the cabin top. If you have access > to a sandblaster to etch the insert surface even better. > > Here is only a link for showing what I am referring to: > http://www.woodcraft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx > > ________________________________________________________________________________
Subject: Re: Copperstate RV10 Nest 2010
Date: Oct 18, 2010
Couldn't pull off all three days, but the nest should be set up around mid-day on Friday for a place to crash and relax. Lunch will be noonish on Saturday. Hope to see lots of new and old friends. Myron 602 421 2868 -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316169#316169 ________________________________________________________________________________
Date: Oct 18, 2010
Subject: Re: A&P
Be certain to download and study the Copperstate notam. There will be temporary tower, and at least one frequency has changed from last year. On 10/18/2010 8:54 AM, Don McDonald wrote: > My congrats also Jesse.... hey, I could e some work done... how's your > schedule? (--; > Kelly, should be flying in there in the next day or so.... getting out > of Chino is the current issue... overcast and low clouds. I guess > getting that IFR classification might be worthwhile. > Don McDonald > ________________________________________________________________________________
Date: Oct 18, 2010
Dave, Can you send me picures of how you attached your overhead console? What does yours weigh? I just glassed mine in, but may want to reinforce with screws. Thanks Ross ----- Original Message ----- From: "Dave Saylor" <dave.saylor.aircrafters(at)gmail.com> Sent: Sunday, October 17, 2010 5:08 PM Subject: Re: RV10-List: screws in fiberglass > > > There are lots of inserts you can use to put threads into a cored > structure. If you look around (or call me), you can get specialty > inserts made just for bonding into panels. For example, here's a > link: > > http://www.gen-aircraft-hardware.com/viewImage.asp?item=NAS1832-3-3&folder=basic > > T-nuts and other inserts work almost as well for a few screws here and > there. They take a little more fiddling to get them into the core and > secure, but they cost pennies as opposed to dollars for the inserts > above. Make sure the inserts are securely attached to the core and to > the skin, and test how well they attached by giving the insert a good > tug. > > Keep in mind that inserts are for non-structural applications like > consoles, lights, belt and headset racks, etc. Anything that takes a > load like shoulder belts, cargo tie downs, etc., need a much stronger, > tested, engineered solution. > > My overhead light console is attached with five very small sheet-metal > screws. It comes off very infrequently so I'm not too worried about > wearing out the holes. I could always push a little epoxy into the > hole if it stripped. > > FWIW, I tried to get Vans to sell my overhead console, but they were > worried about the tiny holes in the inner skin of the cabin top. So > keep in mind that Vans isn't going to be happy about hearing that you > put holes in the cabin top. Personally, I'm not worried about what I > did to mine. > > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > On Sat, Oct 16, 2010 at 4:43 PM, John Gonzalez > wrote: >> I held my custom overhead console with eight to ten SS screws that went >> into >> SS threaded inserts which I epoxied into the cabin top. If you have >> access >> to a sandblaster to etch the insert surface even better. >> >> Here is only a link for showing what I am referring to: >> http://www.woodcraft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx >> >> >> >> > > -------------------------------------------------------------------------------- Checked by AVG - www.avg.com 13:33:00 ________________________________________________________________________________
Date: Oct 18, 2010
Ross, Our console is basically a small pod that closes out the upper strut attachment and gives you some room for lights, switches, etc. Here's a picture: http://www.aircraftersllc.com/products.htm It's custom made for the 10 so it fits really well. I think it weighs 2 or 3 ounces. If you glassed yours to the cabin I wouldn't worry about adding any screws. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Mon, Oct 18, 2010 at 10:19 AM, Ross Wendell <rwendell@hydro-splash.com> wrote: > > Dave, > > Can you send me picures of how you attached your overhead console? What > does yours weigh? I just glassed mine in, but may want to reinforce with > screws. > > > Thanks > > Ross > ----- Original Message ----- From: "Dave Saylor" > > To: > Sent: Sunday, October 17, 2010 5:08 PM > Subject: Re: RV10-List: screws in fiberglass > > >> >> >> There are lots of inserts you can use to put threads into a cored >> structure. If you look around (or call me), you can get specialty >> inserts made just for bonding into panels. For example, here's a >> link: >> >> >> http://www.gen-aircraft-hardware.com/viewImage.asp?item=NAS1832-3-3&folder=basic >> >> T-nuts and other inserts work almost as well for a few screws here and >> there. They take a little more fiddling to get them into the core and >> secure, but they cost pennies as opposed to dollars for the inserts >> above. Make sure the inserts are securely attached to the core and to >> the skin, and test how well they attached by giving the insert a good >> tug. >> >> Keep in mind that inserts are for non-structural applications like >> consoles, lights, belt and headset racks, etc. Anything that takes a >> load like shoulder belts, cargo tie downs, etc., need a much stronger, >> tested, engineered solution. >> >> My overhead light console is attached with five very small sheet-metal >> screws. It comes off very infrequently so I'm not too worried about >> wearing out the holes. I could always push a little epoxy into the >> hole if it stripped. >> >> FWIW, I tried to get Vans to sell my overhead console, but they were >> worried about the tiny holes in the inner skin of the cabin top. So >> keep in mind that Vans isn't going to be happy about hearing that you >> put holes in the cabin top. Personally, I'm not worried about what I >> did to mine. >> >> >> Dave Saylor >> AirCrafters >> 140 Aviation Way >> Watsonville, CA 95076 >> 831-722-9141 Shop >> 831-750-0284 Cell >> >> >> >> On Sat, Oct 16, 2010 at 4:43 PM, John Gonzalez >> wrote: >>> >>> I held my custom overhead console with eight to ten SS screws that went >>> into >>> SS threaded inserts which I epoxied into the cabin top. If you have >>> access >>> to a sandblaster to etch the insert surface even better. >>> >>> Here is only a link for showing what I am referring to: >>> >>> http://www.woodcraft.com/Product/2001048/1708/38-24-Brass-Threaded-Inserts-(10).aspx >>> >>> >>> >>> >> >> >> >> >> > > > -------------------------------------------------------------------------------- > > > Checked by AVG - www.avg.com > 13:33:00 > > ________________________________________________________________________________
Subject: RV-10 breaks record
Date: Oct 18, 2010
John is local to me. He is a great and driven person who has helped me with my RV-10 when I first got started. http://www.ocregister.com/articles/rost-271399-says-airplane.html Pascal ________________________________________________________________________________
Date: Oct 18, 2010
Thanks everyone for the great ideas. I'm surprised of so many different ideas. Wayne ________________________________________________________________________________
Subject: Successful Windscreen installation with Weld-On 10
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Oct 19, 2010
Hello, after having read so much about the Weld-On 10 stories and the crazing etc I took the step last weekend and installed the windshield with the help of two friends. I guess the result is very satisfying no crazing. I put a write up and photos on my website which describes what I did. I just wanted to share my experience. It was quite easy to do. And I hope that crazing will now develop in the future. Cheers Michael -------- RV-10 builder (interior,avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316296#316296 Attachments: http://forums.matronics.com//files/img_1035_580.jpg ________________________________________________________________________________
Subject: Re: Successful Windscreen installation with Weld-On 10
Date: Oct 19, 2010
Congratulations on the good installation and the fine "write-up". I think that you have established the protocol for window installation. If others can replicate your success it would be awesome. I had crazing at two locations with the suggested Vans technique. Fortunately they have not "run" in the one year that the plane has been flying. Thanks for sharing your experience in the finest Matronics tradition. -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316330#316330 ________________________________________________________________________________
Date: Oct 19, 2010
I think that window installation with Weldon without crazing is the norm and has been done for several years. Good write up. Sent from my iPhone On Oct 19, 2010, at 10:42 AM, "AirMike" wrote: > > Congratulations on the good installation and the fine "write-up". I think that you have established the protocol for window installation. If others can replicate your success it would be awesome. I had crazing at two locations with the suggested Vans technique. Fortunately they have not "run" in the one year that the plane has been flying. Thanks for sharing your experience in the finest Matronics tradition. > > -------- > OSH '10 or Bust > Q/B - finally done > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316330#316330 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 19, 2010
Whats the link to the write up. John G. Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kevin Belue Sent: Tuesday, October 19, 2010 11:46 AM Subject: Re: RV10-List: Re: Successful Windscreen installation with Weld-On 10 I think that window installation with Weldon without crazing is the norm and has been done for several years. Good write up. Sent from my iPhone On Oct 19, 2010, at 10:42 AM, "AirMike" wrote: > > Congratulations on the good installation and the fine "write-up". I think that you have established the protocol for window installation. If others can replicate your success it would be awesome. I had crazing at two locations with the suggested Vans technique. Fortunately they have not "run" in the one year that the plane has been flying. Thanks for sharing your experience in the finest Matronics tradition. > > -------- > OSH '10 or Bust > Q/B - finally done > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316330#316330 > > > > > > > > > > ________________________________________________________________________________
Subject: gas strut
Date: Oct 19, 2010
So, after all the e-mails about replacement door struts, has anyone found one that replaces Van's heavy duty one? Where do you buy, what is the part #, and what is the price? Lots of possibilities were listed but no definite conclusions from someone who has actually done it and it worked as advertised. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Tuesday, October 12, 2010 2:51 PM Subject: RV10-List: gas strut Has anyone tried the 9416K15 or 4175T5 from McMaster? This seems to be the most comparable to the original struts supplied by Vans. ________________________________________________________________________________
Date: Oct 19, 2010
Here: http://www.wellenzohn.net/HB-YNN/Construction_Blog/Eintrage/2010/10/19_Gluei ng_the_windshield.html Sent from my iPhone On Oct 19, 2010, at 2:08 PM, "John Cumins" wrote: > > Whats the link to the write up. > > John G. Cumins > 40864 Wings > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kevin Belue > Sent: Tuesday, October 19, 2010 11:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Successful Windscreen installation with Weld-O n > 10 > > > I think that window installation with Weldon without crazing is the norm a nd > has been done for several years. Good write up. > > Sent from my iPhone > > On Oct 19, 2010, at 10:42 AM, "AirMike" wrote: > >> >> Congratulations on the good installation and the fine "write-up". I think > that you have established the protocol for window installation. If others > can replicate your success it would be awesome. I had crazing at two > locations with the suggested Vans technique. Fortunately they have not "ru n" > in the one year that the plane has been flying. Thanks for sharing your > experience in the finest Matronics tradition. >> >> -------- >> OSH '10 or Bust >> Q/B - finally done >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=316330#316330 >> >> >> >> >> >> >> >> >> >> > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Oct 19, 2010
Subject: Tough Rivets on Fuse Forward Side Skin
Working on wrapping up the dreaded Section 29 and have come across two areas where I am unable to get the skin rivets bucked. The attached pictures show the two areas. One is in the bottom right corner where the F-1041 meets F-1042 and the other is behind the F-1001J where the forward longeron attaches. What have others done in these two spots? Anyone have a special bucking bar recommendation or maybe the use of pop rivets in these areas? Thanks, -Sean #40303 ________________________________________________________________________________
Date: Oct 19, 2010
My tungsten bar fit in those places without an issue. I know that wasn't the answer you were looking for. Bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, October 19, 2010 4:44 PM Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin Working on wrapping up the dreaded Section 29 and have come across two areas where I am unable to get the skin rivets bucked. The attached pictures show the two areas. One is in the bottom right corner where the F-1041 meets F-1042 and the other is behind the F-1001J where the forward longeron attaches. What have others done in these two spots? Anyone have a special bucking bar recommendation or maybe the use of pop rivets in these areas? Thanks, -Sean #40303 ________________________________________________________________________________
Subject: Re: Tough Rivets on Fuse Forward Side Skin
Date: Oct 19, 2010
I used 1/2" and/or 3/4" steel bar material in areas like this.... resulting in very sore fingers for a few days afterwards. Jeff Carpenter 40304 On Oct 19, 2010, at 1:44 PM, Sean Stephens wrote: > Working on wrapping up the dreaded Section 29 and have come across > two areas where I am unable to get the skin rivets bucked. The > attached pictures show the two areas. One is in the bottom right > corner where the F-1041 meets F-1042 and the other is behind the > F-1001J where the forward longeron attaches. > > What have others done in these two spots? Anyone have a special > bucking bar recommendation or maybe the use of pop rivets in these > areas? > > Thanks, > > -Sean #40303 > > > ________________________________________________________________________________
Date: Oct 19, 2010
Is that the modified emp bar you are referring to? Unfortunately an RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and never returned it. Cannot remember his name or if he is even still around. -Sean #40303 On 10/19/10 4:14 PM, Bob Leffler wrote: > --> RV10-List message posted by: "Bob Leffler" > > My tungsten bar fit in those places without an issue. I know that wasn't > the answer you were looking for. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, October 19, 2010 4:44 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin > > Working on wrapping up the dreaded Section 29 and have come across two > areas where I am unable to get the skin rivets bucked. The attached > pictures show the two areas. One is in the bottom right corner where the > F-1041 meets F-1042 and the other is behind the F-1001J where the forward > longeron attaches. > > What have others done in these two spots? Anyone have a special bucking bar > recommendation or maybe the use of pop rivets in these areas? > > Thanks, > > -Sean #40303 > > ________________________________________________________________________________
Date: Oct 19, 2010
Nope, my tungsten bar is relatively thin, but unmodified. I also have some thinner steel bars, but don't recall using them there. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, October 19, 2010 5:38 PM Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin Is that the modified emp bar you are referring to? Unfortunately an RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and never returned it. Cannot remember his name or if he is even still around. -Sean #40303 On 10/19/10 4:14 PM, Bob Leffler wrote: > --> RV10-List message posted by: "Bob Leffler" > > My tungsten bar fit in those places without an issue. I know that > wasn't the answer you were looking for. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean > Stephens > Sent: Tuesday, October 19, 2010 4:44 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin > > Working on wrapping up the dreaded Section 29 and have come across > two areas where I am unable to get the skin rivets bucked. The > attached pictures show the two areas. One is in the bottom right > corner where the > F-1041 meets F-1042 and the other is behind the F-1001J where the > forward longeron attaches. > > What have others done in these two spots? Anyone have a special > bucking bar recommendation or maybe the use of pop rivets in these areas? > > Thanks, > > -Sean #40303 > > ________________________________________________________________________________
Date: Oct 19, 2010
Bob; You just had to rub that in!!, but actually it's the perfect answer. The bar is small and tough, but it's expensive too. It does work very well for a person just starting who could benefit from it throughout the build. Sean; I used thin plates (1/2 in or so) initially and grinded down one of my bucking bars to fit after not being able to take the abuse of the riveting on the plates. You'll have many more small areas that will need tight riveting. Consider cherry rivets or pop rivets- which BTW I rarely did until the RV-12 came out and I figured the whole plane is pop rivets so it can't be that bad. Pascal -------------------------------------------------- From: "Bob Leffler" <rv(at)thelefflers.com> Sent: Tuesday, October 19, 2010 2:14 PM Subject: RE: RV10-List: Tough Rivets on Fuse Forward Side Skin > > My tungsten bar fit in those places without an issue. I know that wasn't > the answer you were looking for. > > Bob > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, October 19, 2010 4:44 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin > > Working on wrapping up the dreaded Section 29 and have come across two > areas where I am unable to get the skin rivets bucked. The attached > pictures show the two areas. One is in the bottom right corner where the > F-1041 meets F-1042 and the other is behind the F-1001J where the forward > longeron attaches. > > What have others done in these two spots? Anyone have a special bucking > bar > recommendation or maybe the use of pop rivets in these areas? > > Thanks, > > -Sean #40303 > > > ________________________________________________________________________________
Date: Oct 19, 2010
Did you purchase the bar or make it? If you bought it, do you have a reference link? Thanks, -Sean #40303 On 10/19/10 5:20 PM, Bob Leffler wrote: > --> RV10-List message posted by: "Bob Leffler" > > Nope, my tungsten bar is relatively thin, but unmodified. I also have some > thinner steel bars, but don't recall using them there. > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, October 19, 2010 5:38 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin > > --> RV10-List message posted by: Sean Stephens > > Is that the modified emp bar you are referring to? Unfortunately an > RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and > never returned it. Cannot remember his name or if he is even still around. > > -Sean #40303 > > On 10/19/10 4:14 PM, Bob Leffler wrote: >> --> RV10-List message posted by: "Bob Leffler" >> >> My tungsten bar fit in those places without an issue. I know that >> wasn't the answer you were looking for. >> >> Bob >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean >> Stephens >> Sent: Tuesday, October 19, 2010 4:44 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >> >> Working on wrapping up the dreaded Section 29 and have come across >> two areas where I am unable to get the skin rivets bucked. The >> attached pictures show the two areas. One is in the bottom right >> corner where the >> F-1041 meets F-1042 and the other is behind the F-1001J where the >> forward longeron attaches. >> >> What have others done in these two spots? Anyone have a special >> bucking bar recommendation or maybe the use of pop rivets in these areas? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 19, 2010
From: Carlos Hernandez <carlosh(at)structuralaz.com>
Here's a less expensive tungsten choice....http://www.tungsten-bucking-bar.com/prices.html Carlos in AZ On 10/19/2010 3:31 PM, Pascal wrote: > > Bob; > You just had to rub that in!!, but actually it's the perfect answer. > The bar is small and tough, but it's expensive too. It does work very > well for a person just starting who could benefit from it throughout > the build. > > Sean; > I used thin plates (1/2 in or so) initially and grinded down one of > my bucking bars to fit after not being able to take the abuse of the > riveting on the plates. > > You'll have many more small areas that will need tight riveting. > Consider cherry rivets or pop rivets- which BTW I rarely did until the > RV-12 came out and I figured the whole plane is pop rivets so it can't > be that bad. > > Pascal > > -------------------------------------------------- > From: "Bob Leffler" <rv(at)thelefflers.com> > Sent: Tuesday, October 19, 2010 2:14 PM > To: > Subject: RE: RV10-List: Tough Rivets on Fuse Forward Side Skin > >> >> My tungsten bar fit in those places without an issue. I know that >> wasn't >> the answer you were looking for. >> >> Bob >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens >> Sent: Tuesday, October 19, 2010 4:44 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >> >> Working on wrapping up the dreaded Section 29 and have come across two >> areas where I am unable to get the skin rivets bucked. The attached >> pictures show the two areas. One is in the bottom right corner where >> the >> F-1041 meets F-1042 and the other is behind the F-1001J where the >> forward >> longeron attaches. >> >> What have others done in these two spots? Anyone have a special >> bucking bar >> recommendation or maybe the use of pop rivets in these areas? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> >> >> >> > > -- Carlos Hernandez<carlosh@sec-engr.com> Structural Engineers Company 2963 W. Elliot Rd. - Suite 3 Chandler, AZ 85224 Phone: 480.968.8600 Fax: 480.968.8608 www.sec-engr.com CONFIDENTIALITY NOTICE The information in this email may be confidential and/or privileged. This email is intended to be reviewed by only the individual or organization named above. If you are not the intended recipient or an authorized representative of the intended recipient, you are hereby notified that any review, dissemination or copyingof this email and its attachments, if any, or the information contained herein is prohibited. If you havereceived this email in error, please immediately notify the sender by return email and delete this email from your system. ________________________________________________________________________________
Date: Oct 19, 2010
You can get them from Mike Lauritsen at Cleaveland Tools Dave ------Original Message------ From: Sean Stephens Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin Sent: Oct 19, 2010 6:38 PM Did you purchase the bar or make it? If you bought it, do you have a reference link? Thanks, -Sean #40303 On 10/19/10 5:20 PM, Bob Leffler wrote: > --> RV10-List message posted by: "Bob Leffler" > > Nope, my tungsten bar is relatively thin, but unmodified. I also have some > thinner steel bars, but don't recall using them there. > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, October 19, 2010 5:38 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin > > --> RV10-List message posted by: Sean Stephens > > Is that the modified emp bar you are referring to? Unfortunately an > RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and > never returned it. Cannot remember his name or if he is even still around. > > -Sean #40303 > > On 10/19/10 4:14 PM, Bob Leffler wrote: >> --> RV10-List message posted by: "Bob Leffler" >> >> My tungsten bar fit in those places without an issue. I know that >> wasn't the answer you were looking for. >> >> Bob >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean >> Stephens >> Sent: Tuesday, October 19, 2010 4:44 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >> >> Working on wrapping up the dreaded Section 29 and have come across >> two areas where I am unable to get the skin rivets bucked. The >> attached pictures show the two areas. One is in the bottom right >> corner where the >> F-1041 meets F-1042 and the other is behind the F-1001J where the >> forward longeron attaches. >> >> What have others done in these two spots? Anyone have a special >> bucking bar recommendation or maybe the use of pop rivets in these areas? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 19, 2010
Stein sells a tungsten bar. Make sure you're sitting down when you see the price. On Oct 19, 2010, at 3:38 PM, Sean Stephens wrote: > > > Did you purchase the bar or make it? If you bought it, do you have > a reference link? > > Thanks, > > -Sean #40303 > > On 10/19/10 5:20 PM, Bob Leffler wrote: >> --> RV10-List message posted by: "Bob Leffler" >> >> Nope, my tungsten bar is relatively thin, but unmodified. I also >> have some >> thinner steel bars, but don't recall using them there. >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean >> Stephens >> Sent: Tuesday, October 19, 2010 5:38 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin >> >> --> RV10-List message posted by: Sean Stephens> > >> >> Is that the modified emp bar you are referring to? Unfortunately >> an >> RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago >> and >> never returned it. Cannot remember his name or if he is even still >> around. >> >> -Sean #40303 >> >> On 10/19/10 4:14 PM, Bob Leffler wrote: >>> --> RV10-List message posted by: "Bob Leffler" >>> >>> My tungsten bar fit in those places without an issue. I know that >>> wasn't the answer you were looking for. >>> >>> Bob >>> >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean >>> Stephens >>> Sent: Tuesday, October 19, 2010 4:44 PM >>> To: rv10-list(at)matronics.com >>> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >>> >>> Working on wrapping up the dreaded Section 29 and have come >>> across >>> two areas where I am unable to get the skin rivets bucked. The >>> attached pictures show the two areas. One is in the bottom right >>> corner where the >>> F-1041 meets F-1042 and the other is behind the F-1001J where the >>> forward longeron attaches. >>> >>> What have others done in these two spots? Anyone have a special >>> bucking bar recommendation or maybe the use of pop rivets in these >>> areas? >>> >>> Thanks, >>> >>> -Sean #40303 >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: gas strut
Date: Oct 19, 2010
I bought the ones made in Europe. When I open up they go up and stay up just fine. That's how I like them to work. Ordered from stateside. Don't remember who. But mc masters sounds right. It's windy here in kcrp but the doors are not effected. Fwiw Robert Brunkenhoefer Sent from my Apple iPad On Oct 19, 2010, at 2:49 PM, gary wrote: > So, after all the e-mails about replacement door struts, has anyone found one that replaces Van=99s heavy duty one? Where do you buy, what is the part #, and what is the price? Lots of possibilities were listed but no definite conclusions from someone who has actually done it and it worked as advertised. > > Gary Specketer > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM > Sent: Tuesday, October 12, 2010 2:51 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: gas strut > > Has anyone tried the 9416K15 or 4175T5 from McMaster? This seems to be the most comparable to the original struts supplied by Vans. > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > ________________________________________________________________________________
Date: Oct 19, 2010
Subject: Re: fuel valve with position both
Here is my solution to the "hard to feel detent" on the Vans fuel selector. I made two stops using tubing and countersunk screws. Now the fuel is easily positioned from one fuel tank to the other even in the dark. Jim Combs - N312F ________________________________________________________________________________
Subject: aileron trim
Date: Oct 19, 2010
Anyone have experience using and/or retrofitting the Vans aileron (spring) trim system? ________________________________________________________________________________
Date: Oct 19, 2010
I picked up a tungsten bar from ebay, sold by the fine folks at www.tungsten.com. Works great. It is edging out my Cleaveland Main Squeeze as my "favourite tool". Chris On Tue, Oct 19, 2010 at 3:58 PM, Jeff Carpenter wrote: > > Stein sells a tungsten bar. Make sure you're sitting down when you see the > price. > > > On Oct 19, 2010, at 3:38 PM, Sean Stephens wrote: > >> >> Did you purchase the bar or make it? If you bought it, do you have a >> reference link? >> >> Thanks, >> >> -Sean #40303 >> >> On 10/19/10 5:20 PM, Bob Leffler wrote: >> >>> --> RV10-List message posted by: "Bob Leffler" >>> >>> Nope, my tungsten bar is relatively thin, but unmodified. I also have >>> some >>> thinner steel bars, but don't recall using them there. >>> >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens >>> Sent: Tuesday, October 19, 2010 5:38 PM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: Tough Rivets on Fuse Forward Side Skin >>> >>> --> RV10-List message posted by: Sean Stephens >>> >>> Is that the modified emp bar you are referring to? Unfortunately an >>> RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago and >>> never returned it. Cannot remember his name or if he is even still >>> around. >>> >>> -Sean #40303 >>> >>> On 10/19/10 4:14 PM, Bob Leffler wrote: >>> >>>> --> RV10-List message posted by: "Bob Leffler" >>>> >>>> My tungsten bar fit in those places without an issue. I know that >>>> wasn't the answer you were looking for. >>>> >>>> Bob >>>> >>>> >>>> -----Original Message----- >>>> From: owner-rv10-list-server(at)matronics.com >>>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean >>>> Stephens >>>> Sent: Tuesday, October 19, 2010 4:44 PM >>>> To: rv10-list(at)matronics.com >>>> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >>>> >>>> Working on wrapping up the dreaded Section 29 and have come across >>>> two areas where I am unable to get the skin rivets bucked. The >>>> attached pictures show the two areas. One is in the bottom right >>>> corner where the >>>> F-1041 meets F-1042 and the other is behind the F-1001J where the >>>> forward longeron attaches. >>>> >>>> What have others done in these two spots? Anyone have a special >>>> bucking bar recommendation or maybe the use of pop rivets in these >>>> areas? >>>> >>>> Thanks, >>>> >>>> -Sean #40303 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 19, 2010
Sean: Here's what I did for that situation: http://deemsrv10.com/album/Sec%2029%20Fuse%20Side%20Skins/slides/DSC02624.html I used a cutoff wheel on a die grinder to make the cut, BTW ,I think I know where your emp bar is, it found its way into my hangar, send me your address and I'll send it to you. Deems On 10/19/2010 2:38 PM, Sean Stephens wrote: > > Is that the modified emp bar you are referring to? Unfortunately an > RV-10 builder in Prescott, AZ "borrowed" my emp bar a few years ago > and never returned it. Cannot remember his name or if he is even > still around. > > -Sean #40303 > > On 10/19/10 4:14 PM, Bob Leffler wrote: >> --> RV10-List message posted by: "Bob Leffler" >> >> My tungsten bar fit in those places without an issue. I know that >> wasn't >> the answer you were looking for. >> >> Bob >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens >> Sent: Tuesday, October 19, 2010 4:44 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Tough Rivets on Fuse Forward Side Skin >> >> Working on wrapping up the dreaded Section 29 and have come across >> two >> areas where I am unable to get the skin rivets bucked. The attached >> pictures show the two areas. One is in the bottom right corner where >> the >> F-1041 meets F-1042 and the other is behind the F-1001J where the >> forward >> longeron attaches. >> >> What have others done in these two spots? Anyone have a special >> bucking bar >> recommendation or maybe the use of pop rivets in these areas? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Oct 19, 2010
If the fuel line ruptures up in the engine area, how do you turn the fuel off? Try to feel between the detents? As many do not know, starting about 2 and a half years ago, Vans began sending a different fuel valve arrangement out with kits. There is now a spring loaded, lift-to-turn, handle with positive detents. IMHO it also looks a whole lot nicer than the old handle. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316402#316402 ________________________________________________________________________________
Date: Oct 19, 2010
That's what I was thinking. Clearly some people had some problems where they were trying to apply a lot of pressure to the glass to get it to conform to the somewhat irregular glass top. I used the aluminum fingers method but kept it all light and didn't try flex the plexi at all. The Weldon does adhere a lot better than just epoxy or something and seems definitely worth using. The urethane stuff that I think Geoff used sounds good too. On 10/19/2010 2:46 PM, Kevin Belue wrote: > --> RV10-List message posted by: Kevin Belue > > I think that window installation with Weldon without crazing is the norm and has been done for several years. Good write up. > ________________________________________________________________________________
Date: Oct 19, 2010
In June I got a quote for a 600N gas strut from Bansbach/EasyLift, for $45 each, the quote was for 4 struts. It has practically the same dimensions as the Stabilus struts that come with the kit, and has increased end damping. Attached an image of each with dimensions. I never ended up ordering them though, so can't tell if they will work or not. It's made in Germany also, and lead time is 8 weeks. Their website: http://www.bansbach.de/com/gasfedern/konfigurator.html Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316428#316428 Attachments: http://forums.matronics.com//files/easylift_523.jpg http://forums.matronics.com//files/vans_gas_spring_137.jpg ________________________________________________________________________________
Subject: Re: RV-10 breaks record
Date: Oct 19, 2010
... and the last comment on that article: "Didn't John Denver fly in an experimental plane?" :) haaa Lenny [quote="rv10builder(at)verizon.ne"]John is local to me. He is a great and driven person who has helped me with my RV-10 when I first got started. http://www.ocregister.com/articles/rost-271399-says-airplane.html (http://www.ocregister.com/articles/rost-271399-says-airplane.html) Pascal > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316434#316434 ________________________________________________________________________________
Date: Oct 20, 2010
Jim, how do you turn off the fuel in an emergency? Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Sent: Tuesday, October 19, 2010 7:47 PM Subject: Re: RV10-List: Re: fuel valve with position both Here is my solution to the "hard to feel detent" on the Vans fuel selector. I made two stops using tubing and countersunk screws. Now the fuel is easily positioned from one fuel tank to the other even in the dark. Jim Combs - N312F ________________________________________________________________________________
Subject: Are the e-glass strips for the included in the kit?
Date: Oct 20, 2010
Hi, probably a funny question, but I found three rolls of various width of e-glass in my workshop, but as per the plans there are 10 different widths mentioned. I can't remember if the glass came with the kit. Cheers Michael -------- RV-10 builder (interior,avionics, wiring) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316458#316458 ________________________________________________________________________________
Subject: Re: Are the e-glass strips for the included in the kit?
Date: Oct 20, 2010
I don't recall the e-glass being included. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316469#316469 ________________________________________________________________________________
Date: Oct 20, 2010
The only fiberglass provided was the pieces for the door. bob -------- Bob Leffler N410BL - Finish RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316488#316488 ________________________________________________________________________________
Date: Oct 20, 2010
Gotta love this plane... , I managed to get through some holes in the Chino CA weather and make it to Stellar Airpark, just ouside of Phoenix.- Then left this morning and managed nonstop to Pecan Plantation SSW of Ft Worth. - 749nm, 862sm, in 4.6 hours using 47.5 gallons of fuel... done without t he normal favoring winds.- Wife, Kim is driving a car, and is not real ha ppy with me at this point!- She'll arrive tomorrow afternoon... pretty ti red I'm sure. Don McDonald - Thanks Pascal for the transportation, and Jeff, thanks for the hangar, and send me you address information. - I guess if you do the math that works out to a little over 187mph average. - Better that the guy in the article, and he had more miles to spread his climbout over. --- On Tue, 10/19/10, Lenny Iszak wrote: From: Lenny Iszak <lenard(at)rapiddecision.com> Subject: RV10-List: Re: RV-10 breaks record Date: Tuesday, October 19, 2010, 10:50 PM ... and the last comment on that article: "Didn't John Denver fly in an experimental plane?" :) haaa Lenny [quote="rv10builder(at)verizon.ne"]John is local to me. He is a great and driven person who- has helped me with my RV-10 when I first got started. http://www.ocregister.com/articles/rost-271399-says-airplane.html (http://w ww.ocregister.com/articles/rost-271399-says-airplane.html) - Pascal --- > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316434#316434 le, List Admin. =0A=0A=0A ________________________________________________________________________________
Date: Oct 20, 2010
You planned this trip without spending this weekend at CopperState Fly-In???? Sacrilege! On Wed, Oct 20, 2010 at 2:59 PM, Don McDonald wrote: > Gotta love this plane... , I managed to get through some holes in the Chino > CA weather and make it to Stellar Airpark, just ouside of Phoenix. Then > left this morning and managed nonstop to Pecan Plantation SSW of Ft Worth. > 749nm, 862sm, in 4.6 hours using 47.5 gallons of fuel... done without the > normal favoring winds. Wife, Kim is driving a car, and is not real happy > with me at this point! She'll arrive tomorrow afternoon... pretty tired I'm > sure. > Don McDonald > > ________________________________________________________________________________
Date: Oct 20, 2010
The middle position blocks both fuel lines. Jim C On Tue, Oct 19, 2010 at 9:26 PM, Bob Turner wrote: > > If the fuel line ruptures up in the engine area, how do you turn the fuel > off? Try to feel between the detents? > > As many do not know, starting about 2 and a half years ago, Vans began > sending a different fuel valve arrangement out with kits. There is now a > spring loaded, lift-to-turn, handle with positive detents. IMHO it also > looks a whole lot nicer than the old handle. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316402#316402 > > ________________________________________________________________________________
Date: Oct 20, 2010
The center position cuts off the fuel but there is no detent. Is the new valve a drop in replacement or does it require re-plumbing? Jim C On Tue, Oct 19, 2010 at 9:26 PM, Bob Turner wrote: > > If the fuel line ruptures up in the engine area, how do you turn the fuel > off? Try to feel between the detents? > > As many do not know, starting about 2 and a half years ago, Vans began > sending a different fuel valve arrangement out with kits. There is now a > spring loaded, lift-to-turn, handle with positive detents. IMHO it also > looks a whole lot nicer than the old handle. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316402#316402 > > ________________________________________________________________________________
Date: Oct 20, 2010
what kind of weather at Chino? Sounds like the lack of favorable winds might be due to being relaltive low altitude for the CA AZ part of the trip. What percent power was used for the Stellar FTW portion of the trip? LOP? ----- Original Message ----- From: Don McDonald To: rv10-list(at)matronics.com Sent: Wednesday, October 20, 2010 2:59 PM Subject: Re: RV10-List: Re: RV-10 breaks record Gotta love this plane... , I managed to get through some holes in the Chino CA weather and make it to Stellar Airpark, just ouside of Phoenix. Then left this morning and managed nonstop to Pecan Plantation SSW of Ft Worth. 749nm, 862sm, in 4.6 hours using 47.5 gallons of fuel... done without the normal favoring winds. Wife, Kim is driving a car, and is not real happy with me at this point! She'll arrive tomorrow afternoon... pretty tired I'm sure. Don McDonald Thanks Pascal for the transportation, and Jeff, thanks for the hangar, and send me you address information. I guess if you do the math that works out to a little over 187mph average. Better that the guy in the article, and he had more miles to spread his climbout over. --- On Tue, 10/19/10, Lenny Iszak wrote: From: Lenny Iszak <lenard(at)rapiddecision.com> Subject: RV10-List: Re: RV-10 breaks record To: rv10-list(at)matronics.com Date: Tuesday, October 19, 2010, 10:50 PM ... and the last comment on that article: "Didn't John Denver fly in an experimental plane?" :) haaa Lenny [quote="rv10builder(at)verizon.ne"]John is local to me. He is a great and driven person who has helped me with my RV-10 when I first got started. http://www.ocregister.com/articles/rost-271399-says-airplane.html (http://www.ocregister.com/articles/rost-271399-says-airplane.html) Pascal > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316434#316434http://www.mat ronics.com/Navigator?RV10-Lis --> http://forums.matronbsp; - List Contribution Web Site -http://www===================== = ________________________________________________________________________________
Subject: Trutrak auto trim
Date: Oct 20, 2010
Ordered today and wired the harness this afternoon. Two hours were required to make male Dsub 9 pin for AP side, 25 pin female Dsub for the auto trim box and a 9 pin female dsub for the servo attach. TT indicates that a special connector is available if the unit ever needs to be removed for service. The aircraft could continue flying with existing manual trim. ________________________________________________________________________________
Date: Oct 20, 2010
see below --- On Wed, 10/20/10, DLM wrote: From: DLM <dlm46007(at)cox.net> Subject: Re: RV10-List: Re: RV-10 breaks record Date: Wednesday, October 20, 2010, 5:06 PM what kind of weather at Chino?--- Total overcast/mist/rain.- Pascal said that the day I left that night they had numerous thunderstorms and no holes the next day... just a vfr pilot at this time.- Sounds like the la ck of favorable winds might be due to being relaltive low altitude for the CA AZ part of the trip.- Chino to Stellar was at 9.500'.- Weather was f ine, flight was fine... just getting through the cloud layers at Chino was the problem.- -What percent power was used for the Stellar FTW portion of the trip? LOP?- I flew the first part of this leg at 9500', then the r emainder at 11,500 due to clouds.- I usually fly at 2,000 to 2100 rpm, 20 to 21mp, and lop... it seems to depend on altitude, wind direction, and- temperature.... I just try to get everything set at a combination that keep everything happy.- Not so lop that the engine sputters, not too close to peak where the cht's climb.- Sometimes, like today, it even means backin g down the mp a bit.- If you ck the pics, wind at Sweetwater was 060 at 6kt, not favorable at all .- The shot of the panel shows 2,080 rpm, alt 11,400, and mp pulled back about 1" worth.- Sending the AFS efis back to upgrade this winter... then I'll have the oat, and tach working... then I'll actually have tas and win d info. Don't know what percent power I was running at... but Kelley will figure it out for us. Kelley, sorry for not getting over to Chandler... had some sailing friends that live right by Stellar...and-I took them up for a short ride... sorry Pascal... one of these days!- Stellar is-really nice.. fuel $4.18, and $5 per night tiedown. Don McDonald ----- Original Message ----- From: Don McDonald Sent: Wednesday, October 20, 2010 2:59 PM Subject: Re: RV10-List: Re: RV-10 breaks record Gotta love this plane... , I managed to get through some holes in the Chino CA weather and make it to Stellar Airpark, just ouside of Phoenix.- Then left this morning and managed nonstop to Pecan Plantation SSW of Ft Worth. - 749nm, 862sm, in 4.6 hours using 47.5 gallons of fuel... done without t he normal favoring winds.- Wife, Kim is driving a car, and is not real ha ppy with me at this point!- She'll arrive tomorrow afternoon... pretty ti red I'm sure. Don McDonald - Thanks Pascal for the transportation, and Jeff, thanks for the hangar, and send me you address information. - I guess if you do the math that works out to a little over 187mph average. - Better that the guy in the article, and he had more miles to spread his climbout over. --- On Tue, 10/19/10, Lenny Iszak wrote: From: Lenny Iszak <lenard(at)rapiddecision.com> Subject: RV10-List: Re: RV-10 breaks record Date: Tuesday, October 19, 2010, 10:50 PM ... and the last comment on that article: "Didn't John Denver fly in an experimental plane?" :) haaa Lenny [quote="rv10builder(at)verizon.ne"]John is local to me. He is a great and driven person who- has helped me with my RV-10 when I first got started. http://www.ocregister.com/articles/rost-271399-says-airplane.html (http://w ww.ocregister.com/articles/rost-271399-says-airplane.html) - Pascal --- > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316434#316434 http://www.matr onics.com/Navigator?RV10-Lis-----> http://forums.matronbsp; - - - ---- List Contribution Web Site - http://www======= =============== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A ________________________________________________________________________________
Date: Oct 20, 2010
The new valve requires re-plumbing. It's the same valve but as I recall the shaft has been slightly modified (thinner?). It sits lower (to give more room for the hot air ducting), and connects to the handle with a long shaft. The valve is rotated 180 degrees, eliminating the "cross over" in the fuel lines. The penetration out of the center tunnel is now handled by an AN fitting, instead of bending the tubing and a rubber grommet. I was unfortunate to get an "in between" kit; some parts were for the old set up, some for the new. Vans asked which one I wanted, I said the new set up, and they sent the needed parts. I did have to re-engineer some of the now-wrong holes; in particular, mounting the valve lower. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316528#316528 ________________________________________________________________________________
Date: Oct 20, 2010
Yes=2C works great. Simple. From: dlm34077(at)cox.net Subject: RV10-List: aileron trim Date: Tue=2C 19 Oct 2010 16:48:08 -0700 Anyone have experience using and/or retrofitting the Vans aileron (spring) trim system? ________________________________________________________________________________
Subject: Rudder Pedal Mounting
Date: Oct 21, 2010
Hi I was wondering what the list consensus is regarding using the forward or after rudder pedal mounting holes. What are people using and are you happy with the location. For those who answer this query, it would also be useful to know your height to see if there is a correlation. Inquiring minds need to know. Les #40643 ________________________________________________________________________________
Subject: Re: Rudder Pedal Mounting
Date: Oct 21, 2010
Disclaimer: my -10 is not yet flying. I am 5'6" and put the pedals in the aft position. I've sat in the seat, with the foam in place, and I'm glad I didn't put them forward. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316628#316628 ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: Vinyl stripes?
Date: Oct 22, 2010
Anyone out there use vinyl instead of paint for stripes or other swooshes o n your aircraft paint scheme? TDT ________________________________________________________________________________
Date: Oct 21, 2010
I put mine aft. I am 5-10. I have flown Scotts plane and his is in the forwa rd position. I can use either location it just seemed more centered on the t rack for me in the aft position. Sent from my iPhone On Oct 21, 2010, at 18:48, "Les Kearney" wrote: > Hi > > I was wondering what the list consensus is regarding using the forward or a fter rudder pedal mounting holes. > > What are people using and are you happy with the location. For those who a nswer this query, it would also be useful to know your height to see if ther e is a correlation. > > Inquiring minds need to know > > Les > #40643 > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: Vinyl stripes?
Date: Oct 21, 2010
I talked to the guys that do it at OSH a couple of years ago. I had a C182 with Vinyl stripes and they held up well and did not discolor, so I had a good experience with the Vinyl. I looked long and hard at the vinyl schemes before deciding to just do a 3 color paint job on my plane. Reasons - 1) It was not particularly cheap about $2000 over a base white paint job. 2) It is definitely not as permanent as paint even if it does hold up well 3)The price for a second or third color from a good paint shop is about the same 4)The shaded letters that you can get from a professional paint job looks a lot better than vinyl letters - mine done by Kracon in Lincoln CA are awesome. -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316631#316631 ________________________________________________________________________________
Date: Oct 21, 2010
This plane was painted all one color and then they added the vinyl. I thought it looked kind of fun. (there are better photos of the plane out there). [image: img] There is or was a company in our town that printed photo grade images on exterior premium auto vinyl for surprisingly cheap including perforated vinyl for windows. Something like $10.00 square foot. The cost was in the install on a car (wrapping around corners, lights etc=85). But on large fla t surfaces it seems pretty easy to apply. I think they float it on a mild soapy water to position and then let dry. Really great for female nose art on military paint schemes. Also WAY cheaper than the vinyl bars & stars I have seen which I had quoted at something like $300 per sticker. Great also because you can dimension it to your exact needs. And you can change it out when you want a new woman (teehee). Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Thursday, October 21, 2010 6:42 PM Subject: RV10-List: Re: Vinyl stripes? I talked to the guys that do it at OSH a couple of years ago. I had a C182 with Vinyl stripes and they held up well and did not discolor, so I had a good experience with the Vinyl. I looked long and hard at the vinyl schemes before deciding to just do a 3 color paint job on my plane. Reasons - 1) It was not particularly cheap about $2000 over a base white paint job. 2) It is definitely not as permanent as paint even if it does hold up well 3)The price for a second o r third color from a good paint shop is about the same 4)The shaded letters that you can get from a professional paint job looks a lot better than viny l letters - mine done by Kracon in Lincoln CA are awesome. -------- OSH '10 or Bust Q/B - finally done Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316631#316631 ________________________________________________________________________________
Date: Oct 21, 2010
I have a 1/4" silver tape stripe dividing the large white and yellow sections on my plane. It was something I hadn't planned on and ended up getting from the auto parts store at the last minute. The dark dividing line between the yellow and white made a huge difference in how well each stands out. It's held up perfectly for 3+years, except for one small section on the cowl that gets a lot of hand contact and direct air flow from the the slipstream. I've had to replace that piece a few times. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Oct 21, 2010 at 6:24 PM, Dawson-Townsend,Timothy wrote: > Anyone out there use vinyl instead of paint for stripes or other swooshes on > your aircraft paint scheme? > > TDT > > ________________________________________________________________________________
Date: Oct 22, 2010
6' 2" and forward for me. Just a tip as you get to this section. See this thread. http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf Phil On Thu, Oct 21, 2010 at 8:23 PM, Bob Turner wrote: > > Disclaimer: my -10 is not yet flying. > I am 5'6" and put the pedals in the aft position. I've sat in the seat, > with the foam in place, and I'm glad I didn't put them forward. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316628#316628 > > ________________________________________________________________________________
Date: Oct 22, 2010
I also put mine forward.- I'm 6'.... I added rudder pedal extensions for my wife... at 5' 1", it wouldn't have mattered whether they were mounted fo reward or aft, she would have needed extensions anyway. Don McDonald --- On Fri, 10/22/10, Phillip Perry wrote: From: Phillip Perry <philperry9(at)gmail.com> Subject: Re: RV10-List: Re: Rudder Pedal Mounting Date: Friday, October 22, 2010, 7:28 AM 6' 2" and forward for me. Just a tip as you get to this section.- See this thread. http://www.vansairforce.com/community/showthread.php?t=57070&highlight= kerf Phil On Thu, Oct 21, 2010 at 8:23 PM, Bob Turner wrote: Disclaimer: my -10 is not yet flying. I am 5'6" and put the pedals in the aft position. I've sat in the seat, wit h the foam in place, and I'm glad I didn't put them forward. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316628#316628 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution =0A=0A=0A ________________________________________________________________________________
Date: Oct 22, 2010
Ditto...it's a height dependent decision. I am 6'1" and going Forward was the way to go for me for sure. I needed extensions on the pedals for my wife, who's 5'2". I would look at who your primary pilots are and adjust it accordingly. Not sure where the break-point is, but I've had people who were 5'6"-5'7" do fine in the plane. Certainly by 5'9-10" you should be able to go forward. The side benefit of forward pedal position is it allows your seat to also be a little forward, giving you a little C.G. boost to the forward position, giving you a slightly increased margin for carrying baggage. I would not want to have to sit 2" further aft in my plane, because I pile in the baggage pretty good. I need all the margin I can get. In fact, I would actually recommend before you close up the area under the panel, fit a seat and rails, and mount the pedals, and try it for yourself. If you can reach the pedals in the forward position, I'd recommend going for it. If not, then move the pedals aft. At 6'1", I have PLENTY of room and can move my seat back quite a bit, so taller people will do well in this plane. Also, at 6'1", I have my seat moved back a good 2-4" I think from forward position...so I have some good margin to move it forward if I need. But in general, I'd recommend to look at your own height, and that of the primary pilots, and then make your decision...favoring the forward position when possible, to allow you to keep your C.G. as forward as possible. THIS PLANE IS NOT NOSE HEAVY when you travel. In fact, on our trips, the C.G. moves aft so far that on rotation, you have to make very sure to not be as aggressive on the rotation, because it is much more sensitive...and on roll-out, I can hold the nose up even down to 10-15mph sometimes. You don't want to build a plane to be less noseheavy if possible. Remember that the RV-10 is an X/C plane....it's built to carry baggage. If you want to carry ballast (I don't need to), to help with the flare when empty, then great...but don't build it with the idea of trying to move the C.G. aft...that would be a mistake. Tim On 10/22/2010 9:49 AM, Don McDonald wrote: > I also put mine forward. I'm 6'.... I added rudder pedal extensions for > my wife... at 5' 1", it wouldn't have mattered whether they were mounted > foreward or aft, she would have needed extensions anyway. > Don McDonald > > --- On *Fri, 10/22/10, Phillip Perry //* wrote: > > > From: Phillip Perry <philperry9(at)gmail.com> > Subject: Re: RV10-List: Re: Rudder Pedal Mounting > To: rv10-list(at)matronics.com > Date: Friday, October 22, 2010, 7:28 AM > > 6' 2" and forward for me. > > Just a tip as you get to this section. See this thread. > http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf > <http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf> > > Phil > > > On Thu, Oct 21, 2010 at 8:23 PM, Bob Turner <http://us.mc537.mail.yahoo.com/mc/compose?to=bobturner@alum.rpi.edu>> > wrote: > > <http://us.mc537.mail.yahoo.com/mc/compose?to=bobturner@alum.rpi.edu>> > > Disclaimer: my -10 is not yet flying. > I am 5'6" and put the pedals in the aft position. I've sat in > the seat, with the foam in place, and I'm glad I didn't put them > forward. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316628#316628 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List > et=_blank>http://forums.matronics.com > llow target=_blank>http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Oct 22, 2010
I am 5"9" and used the aft position. I fly with the seat in the third detent (2" to 3" inches back?). I am with Tim, set the pedals for the primary pilot. Also, you can made minor adjustments with the length of the interconnect between the rudder cables and the pedals...... Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, October 22, 2010 9:20 AM Subject: Re: RV10-List: Re: Rudder Pedal Mounting Ditto...it's a height dependent decision. I am 6'1" and going Forward was the way to go for me for sure. I needed extensions on the pedals for my wife, who's 5'2". I would look at who your primary pilots are and adjust it accordingly. Not sure where the break-point is, but I've had people who were 5'6"-5'7" do fine in the plane. Certainly by 5'9-10" you should be able to go forward. The side benefit of forward pedal position is it allows your seat to also be a little forward, giving you a little C.G. boost to the forward position, giving you a slightly increased margin for carrying baggage. I would not want to have to sit 2" further aft in my plane, because I pile in the baggage pretty good. I need all the margin I can get. In fact, I would actually recommend before you close up the area under the panel, fit a seat and rails, and mount the pedals, and try it for yourself. If you can reach the pedals in the forward position, I'd recommend going for it. If not, then move the pedals aft. At 6'1", I have PLENTY of room and can move my seat back quite a bit, so taller people will do well in this plane. Also, at 6'1", I have my seat moved back a good 2-4" I think from forward position...so I have some good margin to move it forward if I need. But in general, I'd recommend to look at your own height, and that of the primary pilots, and then make your decision...favoring the forward position when possible, to allow you to keep your C.G. as forward as possible. THIS PLANE IS NOT NOSE HEAVY when you travel. In fact, on our trips, the C.G. moves aft so far that on rotation, you have to make very sure to not be as aggressive on the rotation, because it is much more sensitive...and on roll-out, I can hold the nose up even down to 10-15mph sometimes. You don't want to build a plane to be less noseheavy if possible. Remember that the RV-10 is an X/C plane....it's built to carry baggage. If you want to carry ballast (I don't need to), to help with the flare when empty, then great...but don't build it with the idea of trying to move the C.G. aft...that would be a mistake. Tim On 10/22/2010 9:49 AM, Don McDonald wrote: > I also put mine forward. I'm 6'.... I added rudder pedal extensions for > my wife... at 5' 1", it wouldn't have mattered whether they were mounted > foreward or aft, she would have needed extensions anyway. > Don McDonald > > --- On *Fri, 10/22/10, Phillip Perry //* wrote: > > > From: Phillip Perry <philperry9(at)gmail.com> > Subject: Re: RV10-List: Re: Rudder Pedal Mounting > To: rv10-list(at)matronics.com > Date: Friday, October 22, 2010, 7:28 AM > > 6' 2" and forward for me. > > Just a tip as you get to this section. See this thread. > http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf > <http://www.vansairforce.com/community/showthread.php?t=57070&highlight=kerf > > > Phil > > > On Thu, Oct 21, 2010 at 8:23 PM, Bob Turner <http://us.mc537.mail.yahoo.com/mc/compose?to=bobturner@alum.rpi.edu>> > wrote: > > <http://us.mc537.mail.yahoo.com/mc/compose?to=bobturner@alum.rpi.edu>> > > Disclaimer: my -10 is not yet flying. > I am 5'6" and put the pedals in the aft position. I've sat in > the seat, with the foam in place, and I'm glad I didn't put them > forward. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=316628#316628 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List > et=_blank>http://forums.matronics.com > llow target=_blank>http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Oct 22, 2010
Subject: In-flight deer strike.
Hi Guys, I've always worried about bird strikes especially when flying during the spring/fall bird migrations up here in Canada but hitting a deer while in the air seemed like long odds. http://perry.casson.ca/photos/index.php?album=RV-10/Deer_Strike/ Anyway, we are all fine and no major damage to the plane. Perry Casson RV-10 C-FMHP ________________________________________________________________________________
Date: Oct 22, 2010
Subject: Re: In-flight deer strike.
You need to build a deer stencil and put a silhouette on your door. Seriously! On Oct 22, 2010 12:40 PM, "Perry Casson" wrote: > Hi Guys, > > > I've always worried about bird strikes especially when flying during the > spring/fall bird migrations up here in Canada but hitting a deer while in > the air seemed like long odds. > > > http://perry.casson.ca/photos/index.php?album=RV-10/Deer_Strike/ > > > Anyway, we are all fine and no major damage to the plane. > > > Perry Casson > > RV-10 C-FMHP > ________________________________________________________________________________
Date: Oct 22, 2010
I almost hit a deer right after takeoff in a citation. Glad you are ok. Sent from my iPhone On Oct 22, 2010, at 11:30, Perry Casson wrote: > Hi Guys, > > > > I=99ve always worried about bird strikes especially when flying duri ng the spring/fall bird migrations up here in Canada but hitting a deer whil e in the air seemed like long odds. > > > > http://perry.casson.ca/photos/index.php?album=RV-10/Deer_Strike/ > > > > Anyway, we are all fine and no major damage to the plane. > > > > Perry Casson > > RV-10 C-FMHP ________________________________________________________________________________
Date: Oct 22, 2010
I hope you at least have the venison in the freezer, offsetting to a small extent the cost of repairs! -------- Andy Turner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=316703#316703 ________________________________________________________________________________
Subject: Overhead light panel, lit!
Date: Oct 22, 2010
I purchased these 12Volt=2C 150 lumin LEDs because they are low profile=2C high output=2C low heat=2C low current and very long lasting. I purchased these on the web at: Sailorsams.com. They work great for this application. 10'X25' Mobile Mini storage container deliverred next Friday. Plane is comi ng out of the basement and the container will be a mini hanger for a month or two. All that is left is to do is final sensor hookups on the engine=2C exhaust=2C and attach the fuel and oil lines. Then off to paint!!! JOhn Gonzalez #40409=2C 2300 hours with QB wings and fuse. Of course it sti ll needs to have its' wings back on and they won't fit in the storage conta iner. /9j/4XYXRXhpZgAATU0AKgAAAAgADAEPAAIAAAASAAAAngEQAAIAAAAKAAAAsAESAAMAAAABAAEA AAESAAMAAAABAAEAAAEaAAUAAAABAAAAugEbAAUAAAABAAAAwgEoAAMAAAABAAIAAAExAAIAAAAQ AAAAygEyAAIAAAAUAAAA2gE8AAIAAAAQAAAA7gITAAMAAAABAAIAAIdpAAQAAAABAAAA/gAAYxZO SUtPTiBDT1JQT1JBVElPTgBOSUtPTiBENjAAASwAAAABAAABLAAAAAEAAFF1aWNrVGltZSA3LjYu NAAyMDEwOjEwOjIyIDE0OjAwOjU0AE1hYyBPUyBYIDEwLjQuOQAAJYKaAAUAAAABAAACwIKdAAUA AAABAAACyIgiAAMAAAABAAMAAIgnAAMAAAABAGQAAJAAAAcAAAAEMDIyMJADAAIAAAAUAAAC0JAE AAIAAAAUAAAC5JEBAAcAAAAEAQIDAJECAAUAAAABAAAC+JIEAAoAAAABAAADAJIFAAUAAAABAAAD CJIHAAMAAAABAAUAAJIIAAMAAAABAAAAAJIJAAMAAAABAB8AAJIKAAUAAAABAAADEJJ8AAcAAF/K AAADGJKGAAcAAAAsAABi4pKQAAIAAAADNDAAAJKRAAIAAAADNDAAAJKSAAIAAAADNDAAAKAAAAcA AAAEMDEwMKABAAMAAAABAAEAAKACAAMAAAABDyAAAKADAAMAAAABCiAAAKIXAAMAAAABAAIAAKMA AAcAAAABAwAAAKMBAAcAAAABAQAAAKQBAAMAAAABAAAAAKQCAAMAAAABAAAAAKQDAAMAAAABAAAA AKQEAAUAAAABAABjDqQFAAMAAAABAJ0AAKQGAAMAAAABAAAAAKQIAAMAAAABAAAAAKQJAAMAAAAB AAAAAKQKAAMAAAABAAAAAKQMAAMAAAABAAAAAAAAAAAAAAAKAAACWAAAASIAAAAKMjAxMDoxMDoy MCAxMjowMDoyNgAyMDEwOjEwOjIwIDEyOjAwOjI2AAAAAAQAAAAB////9AAAAAYAAAAmAAAACgAA BBoAAAAKTmlrb24AAhAAAE1NACoAAAAIADcAAQAHAAAABDAyMTAAAgADAAAAAgAAAGQAAwACAAAA BgAAAqIABAACAAAACAAAAqoABQACAAAADQAAArIABgACAAAABwAAAsIABwACAAAABwAAAsoACAAC AAAADQAAAtIACQACAAAAFAAAAuIACwAIAAAAAgAAAAAADAAFAAAABAAAAvYADQAHAAAABAABBgAA DgAHAAAABMYBDAAAEQAEAAAAAQAAC74AEgAHAAAABAABBgAAEwADAAAAAgAAAGQAFgADAAAABAAA AxYAFwAHAAAABAABBgAAGwADAAAABwAAAx4AHQACAAAACAAAAy4AHgADAAAAAQABAAAAHwAHAAAA CAAAAzYAIgADAAAAAQAAAAAAJAAHAAAABP4gAQAAJQAHAAAADgAAAz4AgQACAAAACQAAA04AgwAB AAAAAQIAAAAAhAAFAAAABAAAA1oAhwABAAAAAQcAAAAAiAAHAAAABAAAAAAAiQADAAAAAQAAAAAA igADAAAAAQACAAAAiwAHAAAABFQBDAAAjQACAAAACQAAA3oAkAACAAAADAAAA4YAkQAHAAAEjQAA A5IAkgAIAAAAAQAAAAAAlQACAAAABQAACCIAlwAHAAACPAAACCoAmAAHAAAAIAAACmYAmgAFAAAA AgAACoYAnQADAAAAAQAAAAAAngADAAAACgAACpYAogAEAAAAAQAydGEAowABAAAAAQAAAAAApwAE AAAAAQAABZIAqAAHAAAAFQAACqoAqQACAAAAEAAACsIAqgACAAAAEAAACtIAqwACAAAAEAAACuIA sAAHAAAAEAAACvIAsQADAAAAAQAAAAAAtgAHAAAACAAACwIAuAAHAAAArAAACwoAuwAHAAAABgAA C7YAAAAAQ09MT1IAAABGSU5FICAgAEFVVE8gICAgICAgIAAAAABBVVRPICAAAE1BTlVBTAAATk9S TUFMICAgICAgAAAAAE9wdGlvbmFsLFRUTCAgICAgICAAAAAB7QAAAQAAAAEtAAABAAAAAQAAAAEA AAABAAAAAQAAAAAADyAKIAAAD0AKOA9ACjgAAAAAAAA0Nzg5MjE1ADAxMDACAAAAPAEMAAAAPAEM AAAAAAAAAEFVVE8gICAgAAAAAAAABBoAAAAKAAAEGgAAAAoAAAAcAAAACgAAABwAAAAKTU9ERTNh ICAAAAAAU1BFRURMSUdIVCAAMDIxMU+sDquD8kp3P6Lk5U9bmlL9kFyA43pcgdNrgrMn3tgVlVhe pzJnFe4AS/oV//cQfSxXVs+LisxRGSRI/te1SMXFUE5A42WETjFF6uWv8oBNXbBGHzuaPCNJsWJT h/+CSPB4HnWhaeUbcBI0FV8G8EsYQNiB664Eb3lbsi03CkjLJQCP40MtZmWRj53sDyFVjb3U0K+b pXwIqfzMXeceqDhVgAoh80TTwMExKAG/IP4+7WMSckvMwZrZYXtVlxWfM4UoAIujU/SN8bi0rW80 Q1cd/5m5+8mTabo0mFKOgMZR8fy6xxJdinUafNJ+WwP2PP1QsOvvrigMBbgp3cgOqIGhDaqScMxg XZR0ysqOFmlvPHKJkTWWsG0EZHFdyDU2+3u9lWHD7PqH7y4OqQ0L+5HBzbshZWQvlPfKssC5gCaL RWjP82OSBQKx7Gv7L3YBH90wx26vS0Rr3WUaGhMvwPxhqUYOB/OMQXbrzewudoBtDHG3XmqbLcBz TlipcElvwqWBrh7Du+RQFwpMzY+W4G0dcIYfGzqcQT0cF/Nz1s1VwVBL52eKgalVzcLRP2RQxm09 ll7LlwzlWOSyCRdniHEFX4+zIz/EGXHAKpXvdMnhnXCG31VagxSYdKMTx74HZTU4HAfX5rXIoZYZ vuJzlFBNdRxwfSfpzR2YGOMBowwZMcwezBp1JO6hK2tRT9agrf2QZn/belyhzbqmiWbJ2ClTvF+j swIUaWXc+mfb3Cp5rSBW29pyBlULJHID1+6J5cXoavfjKHA5MWzqrj12gE1dsEBwePA2EUm0YuP1 gQe9bAgCR1Ei9Bhh/E/7XwboV61VKCjXuLzrQRx8hQlrKIUlCC6XQzJk2ZGMyksPFmDtvdAmv5u6 HMGp1ELz5x6YVVWYHufzQtSpwRy6m78m4Y/sQDIhb/DNhtlY9KeWKoglhShqN6FTeHnxrKrrb1al 2XeaInvOJPxhCfQik0U+SvWTuPqHU2K0sQM8mzsbRrFdTYD2r6vqbDEphBLn807oxeVI7t8D04a4 zlMqKm33gLHliH1h+1pAm/6DmKk5wcEPjE5JsS8fDHEWyO9O5fsGajo2Q9mTl9tHDzFnFc7xX/PQ /Vvg+DKfLyR6/r2w16BRRahQBhq4HgBWqn1Mpd+al9daHWSwL+UHavPK6lMX/xSCTjx+/r2m+3RV X605GSSJKgchnFMjasucg9tBGBhy47PDKK+VthbMpdNP+ewVkVtFjBfk+EnTpM4OvZG0Ldm35nEc BEbAgpTLYz1MnScBKYgjBTyvxpUBuzcqa++2wA2dcCPJVVB88MoejByToq11NTh+B3XiNMmhri7t 58YwzP8Adj4fauygbgSScqDOaFcOyG//2fKkuFhMCgxP1qCt/ZBmf9t6XIHplIKzJ97B8ihYbNGd AhRpAdz6W//mEH0tIFbPi4rMURLacwHUHkHvy+1I8OMShDkxbOq7Z/aAXYmwRg/umjwxk7RiQ1z+ uKUoeD5WniL0GHP82uptBvAMvkA2ftiqrPF5RFKjNw4ohSUILpdDMmTZkQAAAE9GRiAAAAAAMDIx MKqqqqKquqqrquqqqqq6qqqqqqqiiqqquqqqqioqaqqqjrqqqqqqquiqqqqqqqqquqKKqqqKuqqq rqqquqqqqqqqqqrqqoqqqqi6qqqqqioqurquqqqqqqqquqrq6qqqaqqqqgqqq6oqqqqqqqqqqqqq qqirqqqiqoqqqqqq6qqqqqqqqqqqqqiqqqqqqqqqqqqqquqqqq6qo+uqrqquqqqqqqq4qiuq6rqO qqqqirqqqqqoqqqqqqqqq2uqqKqqqqqqqquqqriqrqqqquqqrCqiqqqqCuqqiqqraqqrgqiquqqq qqqqqqqo6uqq+rqqqqrKuqqqu6rqqqiqqiqqKsqqqqaquqqqqqqqqqoIKuqqqqqqiqq6rqplyG5X g/KldNBMCwtO+7O+/bRmf9t7XIHol4JZJJzdc5V8Wu8xnRA+Bc/6ff4LEDAttlbSibzOKhmVcovV ikrBhKkKtqFTwHgz6GAZrfSCT11wRh86mj0hSLRjU4b+uEb1pj6XkiL09GEP2hBeBvEdjEA3b+uq rPF5RFKjNw4oiidELJFDMmb2k4vIQg8WYO290Ca/m7ocwanUQvPnHphZV7EcoPNC1qjBH7i2vybQ ve1gFg9Kyo2R2GQzQ5YuCM+FzQ7FolJEiPFUqgduNkGNHPAHX/o3/WEI9CO+R/Nq9bW4/qxTYrFz IDyE0UpAvlIJgPigt+VoPD2AEuX+HejG5Uju1wOYJfRQzIuLznsgLXgJzNXxUHarw77omQn08j8w MjAyc+ZkV5KxznyFJmAva+OOoqmMM38lelyB6ZSCswAAAl0AAABkAAACXQAAAGQAAAAAAAAAAAAA AAAAAAAAAAAAADAxMDIBLgQEgQEAKhsAAAAAAAAAAAAAAE5PUk1BTCAgICAgICAgIABBVVRPICAg ICAgICAgICAAICAgICAgICAgICAgICAgADAxMDAAAAAAAAAAAAAAAAAH2goUCzsRADAxMDAAAABk AK8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwMTAw/wAA AAAHAQMAAwAAAAEABgAAARoABQAAAAEAAAwaARsABQAAAAEAAAwiASgAAwAAAAEAAgAAAgEABAAA AAEAAAwqAgIABAAAAAEAAFOVAhMAAwAAAAEAAgAAAAAAAAAAAAABLAAAAAEAAAEsAAAAAf/Y/9sA hAAHCgsMCwkODAwMEA8OERUkFxUUFBUsHyEaJDQtNjUzLTIxOUBSRTk9TT0xMkdhSE1VV1xdXDdF ZWxkWWtSWlxYAQcQEBUTFSoXFypYOzI7WFhYWFhYWFhYWFhYWFhYWFhYWFhYWFhYWFhYWFhYWFhY WFhYWFhYWFhYWFhYWFhYWFj/wAARCAF3AjoDASEAAhEBAxEB/8QBogAAAQUBAQEBAQEAAAAAAAAA AAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHB FVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2 d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna 4eLj5OXm5+jp6vHy8/T19vf4+foBAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKCxEAAgECBAQD BAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRom JygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaX mJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6 /9oADAMBAAIRAxEAPwDwjIpN2elcZ69w59KcQcUBqGMUv0pFBzRn1oAM03NMQn40fjmgQnPpS496 YChfU0YApXHYKD70ALijrSGLuxTcn0p2C4YJ6HFGfqaBC4/CjB9aQxwUHk5zTce1AWF7Uc0DHU0g etACfjTfwpkijr6U6gYhpeABSGGaTOKAHbh0xQST2osFw59aTHbNABj3p2AB2oCwnFLQAwkelHuB TJuWora4nOIomb6CtBNIv3x/o7jPqMVaRi5I3rLw80j5uZhGvbAyTXSQeGraN8ukkq57nHFaqJzu fY6aHT7W2+aOKIcdNuMVPK0G0EruOO3H86sxPJvEMMQvUZC3zLjJ6Zzxya44571hLc7YbDadxUGw vFKOKkoTGOtH0piGdqWqJD8KbQIX60vegAp3NACBR3NO4qS7C8YozzjNIY3mm8464pi1DpjrilyM cGmSH4U7GMZNIoTAzScDtQAvH1oyaBic073pANopiD1o5PFACbcDrin4pXHYTA+tO/CgYueeTRni kMbkU76CgQ3Bz6U4KfzphYTb70m0UrhYcPYUpHPNBQzj1ozTJEyfSl5oAXFJwKQx3HagGgLjSc0D Hc4+tMm4HjII5qaOGaX/AFcTv9FJqrEXNmLRtQkZR5BUEA5Y4AHvWvB4cmZ/30yBe5TmtFEwc0dO vhqzWIqWkeTP3s4wK0rXRrSEhQh55yTn9a1SRzOTZvJF5JAR9q9gaI8iYktnJ7fyqiCyxQ5+Ucdc ikTzCwYEDH6UCAk/KGGR3PvUmyILncpOO9AzhPFFsk1k0oTLRnIYDqP/ANVeQ5LgE5JAxmsJHXTG Y560ZHSszp2F54peaRQn40mKZIopKBCj9aXNADetIBTEOJPfNL+dIYn86PxNIYAj8aXn0oGN5p2D QAuPek46CkMB9KXIPWgApQR2oHcQ+9JjnNAhuDRj1pisPpOKRQAilHsKAFJNNxzzQDG08fU0yROa MGkMdgd6OnpSKAUuQDQAZ9KTJPQCgBRmm49TQAvFBxzQAuRTc07CbEzntVhIJpOEjdvouadiGzbt tGu7hC+FjA/vnk/hW4nhtmBJuBj2Xv8AnWvKc7mSR+HkGN8zOc9AMV0UWj2UUa5tN5HUsTV8pi5t lxbC04It41wf7lbUVuFhAXCqBtAXAx+FaGNyZflVgOeMHnrQroxJJ5HXvQIeT5jbTtHf60cws2cO P0oAh6uCx/WrkioqDcF49s0ARsVP+rUYx37UFtiNlSOenIoAZEkb8HIJpdqrlNwHqSooGYOpATxN CVLLjBNeHyR+XIyEnCkjNYyOqnuREUYrA7bC49RijHWgBMUn4UAFJ7UyRKMnOaZIc5oFADsGk/Kl cqwuPlpAo7ZoAdg0lAC5Pam4PrSATGOtOyKYbCH2peelABg0YpDsLijvQMM/jSc0AMJx1pd2RVEX FHuKd2qSxO3WjjsKAHZ9qQHqKAEz6UZ7YNArjutIaRQoH1o4FMQbh6c0EkngUWFcTazZIBPritWH TL2blID+PH86tIzcu5pQ6DfSNhgkYHUseBV+Tw7JHwbmPI6jB4q+UwczSt9AiVQ0kxfPOV/HjjNa 0ejaegx9mZyehZzg/wCFWomTm2Xrawto3EscEWOoLLn+ldEYlY4QqF9QPb/9dXYyvccscatyqkEY PGalKRLkgDaegFMkaI1Cncu3A9+RTNocZUlcdM0AS+VkKRkccjFRBDkfP90cigCYKhznnP51EhGf kA54xQBMPMKHCng46VG+4scfdH55oAd5YB3Hpj8ajJAGCCR7UAA2pgHOKQAuMbsfWgBAjKdpIx3I HNSkKq7WGT9KAKs23aR5YJ9DnivG9chaO8Em0gOOMjis5bG8NznOcU3d61ynphupD2xmmIX8P1pn NBIAetKABTFYSjvwKBDetOHSmA/PFNx7/pSKDP50vOKBAcA80z9KAYueKTPFAC9fU0uOKQxR9Caf xnnikUNyPWkzQAneimSJyeKfjA5oGkJt/CjjtQAmB7UcDtQAHPpSUxC803vQIXOKXnAPrRYLjlDM QFGSTwBWxBpl1Pzs2L/eYHH6U0iHKxsDw9dOocSQhT7mr1v4bZmJkmDKO6itVE53UOnHh7T1Ujy2 Zh3L4H86WLSbWN8fZVHcFgTmtLIw5mdNFCIogiqi8dV4pscB6tL14NUZll4YguGOeeorPaCDawGC NvPFAEwMKxgR5OBgjNSKMhNkar74/n+VMAcTB+GTJ+maesbAhpOhHTp3pAK6jt+lIuYxuIIpgWPN +X7vBGcUiAthlwMdiaQCNuAHOM9xxS7YtpAY/iaAELKMEbT256flSI2eq/TAoAGck8BQtRkAjJPf PtQAvBPXipV2oeVOAKAGh4ipx19CKQqFUbW/pQAw5GVOR3wOamcgLnAOex70AUct/CuCOmTXF69F JcWfPHlcgY4+vWky1ueWDkUYA6CuI9caRilz7UANyKM0yRv40e1MQD/IpT9KBCd6XFABS5oAM+gp M/WkMXaO+aX2oHYQgd6OMUgEzz0pd1Owri5OOKMEjrikVuNIA75ozx0pkgDS8Z5oGJml5oAaSRxS YpiF4ozigVxc09Y5GxtUnPTjrTsJs0ItOvJ+Uhfb6kYH61sJ4fujje6J3weTWiRzuaNKLw4WZcyu QRkfLiuqsfD1tCxaVWlIGeSMHvjHetOUwc2bQsUQg26Rx98BRj9KurCqoUdsq3b/AOtVmQxIIl+Q ckn14FWyixjbtHHp2oEKC5xxjPfFBBBGUB9TnpQAwrvfp9e1ShVGflPp16UABVc/MM44x1qQGNQV KqwP94UAVlAbJBAGe3rUyBwwCjIPJANAEQWR3LMDjpxU7DIGSOBz2zQBAxIyAOBzgc01Z1fphiO5 oAdywyMcfmKYQ4BwQM9eaAHqM/eA9OKQxqcnG72J4pgR7k3gKg9gDipAwZhtUgfXmkBN5bD735VE wAb5iwGelAAuxeQcDFSEKQPX+lAD9q5BwvSovvcEZANAEibQPn/QVAWAJ2UANO4ENjJPTbzWTdR+ ZGxkAIbsaBnjeoWptbpk6KTlM9cVln8643uerF6DSeuOaUg9cYzUljOvU0uB0zTEMxz0pfoaZIox QSKA0Ez70UxCc0uTQIf79qSpNBPoc0uKBCZPQCkIJ60xCjHHFP60ikIfTOKZn60CbHcY4HNJjNMA 6UoxSGB9eKaWp2E2HzMcAVfWwvHj8xbeQrkgkDv/AJNVYycjfs/D15OhlmxBEOSW5OPpXUR+HLUH 5fMmJ6EnA/StVE5nPsbEGgWcLENbqT33MTittbREIRBGq4/gG3+VaWMW2y0YI1HIZiPUgfpSArld qAkdflpkFpkG3hCWz2zxSAOG6kEds4NAD0RUwTk5HTOKUpHuxzk9fSgBAipu3cemRUZGTxQBMNoX pu9xSPI2SM9TyO1AD1zgk9W9aQqvrnNAhCq5JJwe3PWmSxgDcOfegZBuUN8qgAj0pRukbsq+uaAE VJVJUvtXnqaEyz8Nnn86YEx28ZABqvuU7QFHHtSAlEnHCE+vFPEZz82Q360ABRkUjJPcjbn9aqrs UMoGT70AMaQIuEyff0+lV95ZgSenXmgB/mtuALjp2zV2N16nJ+nagY0hWJJO0Z9KUJtXeDuHqKBD th7ntnPYUgGOSwyeaABj83TB71GRg4xz0+tACfMT95enQ/yqlNEwbcWwD1xxigZ5zr0BKrOMnsSR nNcKTXLJano03oITx1pv5mszoYmR6UnpVEBjNH40CG4HenY9sUxWFFGBSGHSl3N6mmIbmjOetIYd OgpwPrSGISMcGkJNMLi807r15pDDApCKB2AU4AuwVFJJ7AZJpk3N6PQ9RkQP5OwN03Hn8q1E8NTk fNMue+0ZGK2UTjc0bi+GYIyvmzSMcZ+XAz7VZGiWKHDwOc+pOavlRk5s6m0tkihjiiiEaLyCBzn6 1MbIs+4ngHJz/KrMrl5VWLCKc4FSqeADx9BQIbJExIUEL260q2+1huYkDr2oAewBx0IHfNJGMjhf b60wFdnDrwT61KqDO5h17E4pAOKAj7wA9qYqgA56fTmgBM5U5GAR60gyq/MgP1FAEQZnBG4gVJ8/ AAyDx1oAk2gAc8/ypTGvVs/nQIYdpHJY8/gam+TaNpxxyRQMgYsuQM9OuKiXeCOBjuSMCgCQISQS w9itQupVi24ZPbFAEWcnJAJ+tWXIBxnJ+lAEW0F+BxT1Xb8pOT6igBoKBud3PrUMjjy/lJJz2FAG ZIdox/F1K45rMeaReOCBQA9JQf4uP1FXxcBCQCST3zQM0oyWXdng+1TZDN8zBaAHqD1yR7imM/JX t6UCAEqTlR9aRmO44C4HcGgBXXByxOD2qk5Zl2lSQO4FAzJuoTNbSIQxXGMeprxKaMxzNGSPlOKx kdVPexD+lFYHcJ9KPSgkSimAgNO7UAhR14pPcUAKM+lJg+tAWE+g/OkyTxQK4nXvTqYhwHFJ+Gak sUfWlAyMgUCNKOwvJeUt2x6niujt9BPyPdzbVPVYxuP59K1UTnc+x0ttoNuF8zymdSMDJroLTSre 2+4qI/UHGTWySORybN4qpGwlzuPc9KsBAijkjj6YqjMbwAFUZyaly2ASMY6c0AR7C3OT9KYB5bcn gdvWgB2BuJAAJ9RSNkdFGfUA0ATbWwGJHPbPNMYjBGdo7jNAEaKueKeTtOB1HemIcr9cggilJbKg DIHPJpDHbQRw2PrRhOhY5+lADOTyCcDj1pS7ISQCB3FADAcncDj2FMLN/CDt+lAhHVnTKkKelHKr y2R9KADgqDQZFBOwc9z0oGAm2kgJuI/Kkw8hBPU+9ADSrAj+HHSkdlBx1b1JoAeHQAhQeeuKXez4 4A78igBjDnIOPWlGNxw2TQAjbRzndjqOlY1zPhxHwox971oAplSB0PpURVT16GmIqtENxbOGoEhV xvP09KQzWWZm+XOB6VqRoD1ZeOvPWgZPIM/Krd+fb2pAjZ4AINAhz7gNuQO1OWIYLMeB0waAK74O cD8T1pVfCZwCfpQBTk81hnemB144zXlviG0eO6WY4zIBnnv2/wAmolsbQdmcYTzSda5T0xST+FID 6mgQc9M0nfrQAhI9aBz2Jpk3Fwe4p3SkMTjFM4phoPP1phAx70AxR6UufegBM+1TRRPM4RFyfSix NzsbbQDI2JJm56YWu/sdLt7OIrGg3dC7DLHn9K6VGxwOdzUe1RhjeQOMkU9IY05SIZHGfX3rQxLC xu5BboavtCjY/gA7AcCkA9YlB+91HGeKmYDngD0BoAi3KFJPSq/TB9uhNAFmLLZVhwT1zSbV35Jx joAaAEYZJAG7125pjn5cbelAEr7iOCeBVPad3zMP5mgBjlVwPTrnvSrIpfGDnPrQBYLrn5QCTxnt TsYAPPrgigBcfKB6ds0oUsPkzz60ARBgpxil5zkgbfWgBjtzgcc89qjU5bZuOT2xQIa8jFiG2/L2 yAKruzKVO8EZPGc0DGPcxr8qso9cmolvIQrEshx6kUAI11bsQBKg9eRU6SQ8ZmQe26gBXlRgctnv wamiIK7gDz6DrQAu32H4daQgjoME8EN2oAbn5gcnjtUjbAgGM96AIxhhwQoNZ1zHvjKyBTnkY6j3 oAxlkMR2SEFCMA46VcbaAGHIJ4oAUJljk7QOWJ4CisyW8tyfLtwJG3bSx6fh60AaSI0U7xNnejYw fUGteMquUYE88gGkMsjJPcLnoe1SvlThAQe7UxEQRupbGO4NMKrtXncfSgBI8hslMcGlAkfrgfQ0 AMaIKdwYr24auX1eAXVo8YLs2M5NJlI8aZWVirDkUmDXGz1VqhDim8fSmA3FGKZNheKTmgBOOpJp ePQ0yRx44owfUUhhznI4oxSK1FAxRSKF49OK9H8OQRtbmRgo5JJ7ntWkdznqbHo0ToVKoqhcdcVM oJVmLZJ5wK6TzxoIPCrz6dasKW8wcjGaYFvDZB6f0p5Ucc8UhDioB5wc8e4qRtuAc0DK746Y5/nS xkjsTmgBoDtyMD155FOKqo5bH070ANVwrA7eeuc1IzhV7Z9qAM1ndu+CO1Yr3rJMUVQdvVie9AFj zC77iACccip9wXp17ZHWgCxEcjomfYVpoQMqc7sYoAQKvOTnjvSg+WRh+vHWgCoX5wB+lVri8t4E Ikk2EDI3GgDj7jxBaoDsYuw6ECsOXxRMf9RHsBx945IP1oEc9NrV5LnMhGe4rOe9uZOGmYj0zQIr GaUjHmMfxqDcxpAPUnsSKmWeROjfnzTAkW4kCnDnj9KtpqF2MYnfj1JoGakGvXkTZYh8diK3Y/Eg Yp50JwBzg0Bc6yz12zlXAkAzyVetX7Sj8ody+3IoGPWTdt27Of4TSOhPDMBnn0FAFCaBQMMA7kY4 IrlXu47af5kOAMjae/PBoA5m91Ca7fBO2MHhB0FJZq4vIVZScsOMUAd+7L9rk5ONx6da3IXVRwg5 HU0kMumUKFIUZPfFJ98ZPXtTEIf7o/TFIoK8bDn2oAkLP2TA9aj53AkmgCGWNgAxORn/ADxVFlYA 4UnnI9qBnj2sWxtrxm5w5Jx6fjXPkjknmuWS1PSg9Bu4U09O9SXcBn/JoxTELilwO1Idhwx6c0uK RQEDNO/OgLEeT9KMDuaA9R46ZGOKac46Uhhj1Fd94emBikhYnarA8VrHc56mx6nEjPGdq7R33HJq VCseVJz6811HnDg2P4eM9ulThyecdOuRQA9gx68Z6A1LlipXLfiaQBtXPzPTcbDjJPFAAuCnIHvm mO56L09e1ADlU/KWI9+tOLISCSPyoAkYRk8Fj+Qqi7vtIUj8T0oA566lKZwcsfu46CqEEYJ55J6+ 9MDTUeg+tXIwcge1AiN5it2qJggLl8/oK0YWbJ3DHqTnFIY+RljG4nk9/wCtcxea1ZwA5kLOBwBy M0AcJd+ILqXKxNsQ+nU1yMkkkxLOxf1PpQIr0UCA4/GkoAUUY9KQBk96Q9elMQq8d6k7UDGHPHFO /MUAOHHJq5Dd3EB3Rysp7YNAHVQeIZlk/wBIXfx1HFdpYahZ3PO8Z/uucUFGhcNGQMMXA6dK81vW L3rIOMY4oAuz6PLBZRXU8kaebyic5YevTH602yjT7fbYDna24lTjgUAdbCoaZiRkk4x+FdKigKFA yfftQMkCO67dvHY46/SmbVHfGfagQ8DYcDn8aX/WAYUBh+lADfLb1wfrURRumeBzxk0ATIoIHXPb moXDN8u0DtnpQByev2CS2TM7MGQ7gAPz6142VUEgE4B7jmsJndSGUh61idYvI7UcUAAGaTpQIOlO xnGQaAFHGOwpd3sPzNIq5EeuetL24xVECc5pwHvQFhxHtXR6FJ5eoDJJQg8A9T2ojuKa0PYoXeVC zOcAcVoxBSwYnPr612nkjn4bGKULltw4/WgCTc20DoaegLck8/WkAg4OCe3ApoZOhB+lADmKY45+ tKGYEMT+lADnYEDnk9qrkKDkydOwHX8aBimTGcKAO1ZUzMMBefWgRm+T5spLSqXJ6HirPkOiZKmg AGMgdafLcLbRg4yzH5QeP8imIz4mEa/PyW53d8+tV7nWIbVcffbHRaQzz2/1q6vCRu2p02jt/jXO YLc5oJGY96djvQA0/hRzQAUo6UAPGe1L83vSAaQfemDIFMA/SnDGMnOaBByDTwOnegBWUmnKMnpz 79qALoRAm6VwBnini9gRspGTz0HAHtQM049dkjIWOI5PH3v/AK1YgvDJcuzko7HOc0DNyS5mlIMr s+BgZOcVvabt+2R/OQyxsTj3HApDOptGGWI7k1vZJAV2HX/PWmBPsUkY4AGcY/8Ar0KcHDAGgCZg v938qbnI7jtQAMRnCtxjrSDy+CCQfrQBAHLcBevQ4okibaNzheOBmgZRnSKRCHOVAxtJ4NeFXsH2 e8kG3bEWJQdselZS2Oim9TO6UVzHpCd6OMdBQINpwCabnjvTJFycUmCOc4pi3A49aTI/yaBBTutI skCegpNuKm5dheR3/KrdvJ5M6SZxtPaglo9zsGje2SXs2Mc9B71qsP3mAgrvPGY7D9T/ACqQuxQc YpiF2lh196byqkAnPvSAcnJJyCacW8vHp+VAELFicgChmJTqM+lADRjBBK/icGoyyqD8oJ+tMBjG RcHGM96qO+N8jrkIpfnjOBmkM8ee58zIY/PnOfWr+n6ldwXKx+c7RleFY5H61IHo8F2swXfEAccl ax5pI0Mk0rBjnAJ7D0FMDkrzVHf5IRtH97ua5sjKk4/HNMkrFc9Kiwe9AiXKYwVJPrmmMCOxFADP 1ooAbjI4/OlHPWgBadzSAkwCOajPXnj8KYEec8VLjj/CgQgzu4P50HI7c0DJlwCSaeZBGC38XagR kvI0rlmJJPet7Sba2mu1+2SmOAAlsDJOATj8cY/Ggo1b2O0a4ZrSJoof4VZskfU1G0ELxrHImV43 OvBP0pAYG6W1fa43xdjXYaLMrTyt1ynB/EUxnqdvBiMBgB61pFdiYGCfQ0AHygAAndUu5UHYt0xQ BH8reoJqVSFBDMM9u9AEb7C/XdnnmmsRjaMY/rQA11ChTuIB54qBwsrgKv1y3WgCVh5fy7FDjGGB 6V5p4ltg0fmLjMfB/r/KpZotzzEZI6UvPc1yHq6jTyc9aXtQIaRjoaX/ADmmIdyPb1qPPNAmBPtT sH0FJjQ7gUZH0pFClueBTuvt9aViri8nr+tOC465pXKseu6FcO9rCo7cHHt/+quycOoyMevNd62P GluSFyyhT0z680hXHPFUZiBiF424x3o3ht33fwpAOyDwCuahO4tg/wA+KAAhmwC/A9aeoTcQXLcZ znFMADKpK4JHbJ600YUgeXz7nFAEMzttBRQAOlYzl/sVxk87G/lSGeKSfePrVqCTE0ZbqGwfpQSe lK2yP9ydxIx0rlbq2uHf94Wx+lIZium04IPH6VUYgEY4pkkZJFRE+ooER/TkVKEY9qBkbgqcGowf SgCT5cAkkH2H/wBeme4PNAEo570/GO1AEgFV5OvSgCvg0vNAh4bnJqcMAOOh9aAGlucdqrTsTjrw O9AFdG2nOAfrW9DdxiPaU2sTwewFBRpo8eF3Nhf4mAyf/wBdTPcJK5ES7Il+6p5P4+p96QzPd02k tjZ6nv8AT1rMguWt7pXQYVWB20wPerO482NXDDleRjGK1QQ3LPn0AoAtMFUD5QAKiCZyVHagBxch Rwc/X9ajzuY5zQArKnbn8Kd5Y+8DigBH24O3Le2Ogqsp5OBg470AKVdshiR2rNurWB4mVh5hI9el Azwi6gNvcvGQcA8E1X449feuKW560HoITTCfSkjRjeOc0u2qMxOO5o3KPWgWghOaTn2pku5IBnvT gKg2sPAGelIeuKkoTnH+FOU80wPRPDDZaRWbGzkde4r0cytjCcZ7/wD16647Hl1PiJlT5Axbp2Pe kY5+7nd7GtTnHJ9MD1NOlZeiqOcdABmgCFQxIIwB9OlOKsFAbJH15pAPCIVGWycdzSkIq/KqkZ6Z 5oAj3ktkxlvpTgrSADOPUGgCrNE4UhTj8jXFarLdJbMYmwScPn0Ix3/zzQB5rCDKSrdVPNOnCxDk ZJPApDIY3uUAAlkCD+6x/lUbXE5bInkyP9o0ySD7RMD8zlh71ZSZZCdw+Y+9AiQDJ56Um0EUANAA 7fpUgY9ORQIYyFuSaQKB1/lQMNo496TZ8wOKAHgKDxSb8dRkfSgB29fSopME8Y5oAgA5xTyAASKB DDnHWpADjpxQAgA47ioJBxxQBVpwpjLccr/KnJXoAK1JXERJlbzHPO3PX3P+FIZkPK8jhienTHQf Sug06wN1MJHQpCOvHBoA7R71YpkwWWNeCR2FdpZXiTR+aHAPfikM0Mh2JX5u2MVaXITJ559aYDQu 47ieKmKRjnv7GgCMIzMFB4PFPdTzuOMcUANjIL8fyoDnkKBzQA9UDnDHI9jVNypz8pOOMZoA8m8S WwVxcjI3HGM1wWR1zXNJano03oISfSm8moNtQwRS4oCwu1R+FGBRcLIPwpePT9aRQv407GByaRSD 1oJpDEUkU4e4zQCOn0e5SKUrg73x0P1/xr12JCFUFzyMn2rqhsebVWpbA34XOT1A9adDtVm64rY5 SSRsn5QSO3NM2AjLHGOwoAe5OzqAT6UgA7nNADNy4bA69uwpykdSDkHrQA9mYkBQR/wKoWjfB+fm gCtJubkvgZxz3rn9UKi3ndDnKEnigDxiOZ4pDJg4b9avxSRrGTKgkZjnnIZfp2pAJGWc7VYAe9V2 VCCGBDeueKCSjIozhf1prAKAehznFAGipBUElh+FLnA6E/hQAhckYxj8KQc+poAnYjH3QMDtmq4/ SgQKSVxSb+w9KBjC2OOv1pnJ6UCDtSbh3z+dADlPGMU84xkj8jQBDnaSF6HjpmpOSo3Ngj1NAx+3 ccAE5pfL2nDdKAK7Q5J2mrlg8dreRy3FotzEp+aJiQGH1HSgDu9U0SxOkrqlos1vvOfJkZTwe6jO cAdyeTjivNBG7t0JJoKOos7CBNrztvP90dB9a6hp90bKFwAO3GKQHJysxPzHt0q3p929vMASApPe gR7BZ3PnQhkHXgYHerYLuRuBIpjLAAGCWOPalweNv4cYoAXzCq5KnJ9DUG4Mx4z7UATkKIxlRkUb SwJ4UY6daAFBCry/P161VygPH5mgDnNVgFzaSoiqxI46HmvDiNpZSMYNYSO2nuHApvv/AErA7hoP 1pSPemRuGOeaM0DFGMUnNIYp+9il4FACZ9qTd6Ciwrjsn6Ud+SBQUTxEpIrZxtIORXu1tOJExgKu OMVvA4qpqRtEDnb+mcU9mLAiMce/aug4RyxuMEnApJA4X7+VzQARpGQcknHeggZYLigB43A8hRxn p1p7n5AqqCfpQBCIiRnO3HPWmneR8zZ/GgBuEPyucjrxXKa4VWxmMQ4xjOetAHijzyNCkDNlIySo x0zjPP4UkbjO1jj3pCLjEjPCsPUCoz0wM5oEQM2OT17VVJJOT1oA1o8eWPapcjPWgBMhjjNN4X7w oAZuBPAp3AoArZI4pvU0AP2nGe1KB70CG8004oAaAPWpQccDmgB/mE+1KuC4B78UDNi3KqhBwSPa rDxLINyg5NIZmvEY2+bFNHWmIcGP1/Cp9/NAF1HJOT1NbFurOXVT/ATjPYcn+VJlI5iUnzCCe/eo e9BJ2Wk3uyQIxIU8HmvTkQFRhie/SmUKAT/H16deKsfcTk78+goAdjeOD196PlQ8nH0FACbiTwM1 MSwABzkjgUAQqFLfMOPSiTYOijk8DrQBTkUlDgbeMZrxbW7IWtyzgkq5zUS2NoOzOZNJ9a5D1Q6d hSdT/QUCYDPrgUvb/wCtQAmeOKUg56CgNRuOaXbTJsHNFIoTHrUmOKARIMDoa9g0aVZ7SMt95Rg5 GCD7fpWsNznqrQ6o8fKACRU4RsHauSOTniuo80lIIBBfGO1QLgDk5H04oAcuB90Yx3xUyKw3ADA9 z0NACMDxnaMfrSCJpO4H0pAD99zOwPbdQmwD5sHPY0wK8yKV/dnp1NctqKGeFrX5UJH3sUAeO3ll NbORIhHoex/GsvHNIRvvpepWtul01tIIHUMJANykHpyOKjRo5QEZDG5PXnFAGVOsiSskqsrqcFWG CKI0LdqBF08LgGlA75oAtRpwSTx6VG59elAFbK5x1pzE4xkD69aAK9JnFAh+T9aXd64oACQR90Z9 aioAb9aUGgAJpN2DQBcE+AAOxz6VrJK55Tp3HpQMmYrIPm61QZcGgCWKIsfepniIPFACrkcGugsi cyYG7923Htg0mUjk5GyxPqahzQSSxuUkDA9PSvZdNuRPbxjcQcDORTGjolIPyjk+uMU1mZup4FAy VQAhJI3epprgHGFHT1oAcpdE4Yrk4wKgLEthifyoAsDaBzyKjAJPynAHHSgBxiBx5hAArjPEUEMt gw2O8icptHFIpHjWCpwwP5UyuI9lCdfTNNPuaBBkAU3d6CqsQ2O5pNp9RQLUCcdqUfSgY4e1JipL FAp2D1PSi47DwB35rufDsjmV4Y85JBA/PNVHczqL3T1GNuy4LdMntVgszL97H0rtPJHqoYcsSBUL DLfIDigRZG84xwPypxkJGMcHpSAQIWAOaftBBGSCPQ0wIlWMnJzxSylSQF7UAVJAU6bcYzyeK8ym 1Bri8YbsrngDtSAum4UpskCsD2YZrm7jT7OU742MXPIHIpAWdMuJNLulaO9nEStuKRvt3EdOoI/M V2V54qkfm2heGTkmQsHbOOCCw498AZ6DFMDy+/aG6u2mRZFBxw7hj+YAH4YqmBgcdPpQSREYPPJp VHOKALu5QuFOarFyeOOB6UAVWOeM/jUXtjNAh2RnjgUuOASOvegBBS/hQAhxTaAGnpSDntQMWkoE JznFaEJZUyp5z0oGSNkGrkCmUgdKAOgiiVF4pJIxjIxWRtYzmUZqYkQWrtuG5/lA9vWrIME+xzUZ NUQJmu08P3DLN5RbgnigaPUVkfhcBcfmas/LIBx0HY0DFK5OQePpT0Ybv6mgBGdiMAZxTNo/iORQ AuMj5QPxphWQjgqPpQA8lchmY5H92qd15UiFMA/WgZ4JqlsbS9dFOVPINZeCe9cr3PSg20Nx2JxS /L71Jp6h9BSkjt1pDF5IFJg+v60ihcY4ORTec9aYgzgcZpeaADcPWnA5PSkO48scdOa3dJlaC/jY jh/loWjCV2j2mLbsAUknv7VoBecDJHfmu88YeREDjGfpSDepwBn680CJiGABzSNH8u5+M9KQEJ4O MnGKkQpknPTsaAGvjOBio2DJwFAzTEczrVw0Fi5CnkYB5714/byHz1J7nrSBnQ3JJcN2xxWaZCMk 5z/OpKIQznldwJOeDioG3nsSKokiI9MVGTjjtQIibn2pyjC8cmgBryE5GKr59elAhlAPHWgBfxoG fpQA40m6gAyfwpOKADGKkAJYAZz7UAPZef8AWA/nUXy9CSfTAoAZ0P8AjTw5HQkfSgZe+9GDke9W o2AAA4pDNmOcqoB5FTmRSM8fhUWNUUiQDuYjHpWVPLvIz0HaqM2VePWmmqJG5rVsJAk4JznsRQB7 Va4kiU45x3PFX1U5OEIA7Uyh2Tt56/WpfvLggAEdMUgFMKhcnHuDUDAtjYMAD6UASKNuAcZ9uajL HI9PSgBxEa5fHOOAKqtGWAwOvU55oGcDr9gWtvMQ7nj56DOK8uHbgH61hI7afYXaPbNJ361gdlhA BSgjOMimIM80mT/tUCuJk4yeaUE07CuIcnvSgZxSHqPwO4pwFSWkOBxVmBxHKr4ztOQBwaRZ7dYS eZbxsP4lBJP0rXj+8dzGvQR4b3LTGNQAFye/vTd5YAKuBn7xpkkgDOvUn1pCFwMsTQA9dgPuPeo3 ZMjaAaAEGR83B/GklkwMKp+tAHmviRyURMkZ5x/n8a8/UAEdKRJtuwe3UjOQeTnjFZGGZ8dqRRqR gADipflbINSykU3iVRnqT+dZMg+YjPSqRLIVX1/SptwUYA/GmSVXxngioiR3FADR9KWgQvSkoAOa X6gUALx6UlAC5IGATipRI23B24/3RmgCIsc5B/LimEnjJNAByaKALCNtBHBz+lW/Q4NAyyspAxjI 96mR02k5xjtSGU5HLnk1XPWmIZ36UUARlsUqSYkU9MGgD3XTGV7JDnk8Y3dcVtBmyGQY70Fku5+h 5qQEkAHG36ZoEI+V+WnguV/2frQAhJYc8H2FQHygM8cUAG4sfkAx9KkKbSASQfVT0oAw7uNZA6eW zhhjlsV4feW7Wty0TjHcY9Kykjpg7Mo4646U3HvxXOd40gDvQMDNURoKD7GjLegoC7DoafmkUg5p TUli07r60hi/hT+f8mkWj1fRJ91nCAvzLkcZ9a7WNFxuJJ6duldy2PGluywzRjoBn61MA7gBQTgd xVGRGFZVYbgCaEj4yWyT2oAcSq8Z/KkUjslMB5ZsHavSqr7mGMc0CPKPERxdhWOdox9K4/HNICzG 4A2npV/y1wDHkrSGh+aXoM9Kkoz5XIy35VjliSaohjN3bOKQt+dMRGT1pKBCZoyfWmAZpc4HSkAn UUvNADuaQ0wF4o9s0gEpPxoATJpwYgjsRQBJwTn+dWo+etAx+Tx3pDwehzQAwt69qaWwen50AJ8z cgH8KhbIoERHHWkBNAHs+hfPa7mBbHeu1AwBgAfWgsn2kszEA4OSR0FQnaDkEZpgOXzCRjbj3pxD 9yAvfFIACoTy/T15qEhS2EXr7UASMJRg79q9wKQvGDuDE85PegZA+zcxCY/3hivLvEdqzxC5VeUO GIqWUtzz0DI6ml289c/jXKeqlcTApOnagLBSUhj6U++PyoAXnNNNIYvSnA+lA0FPyOM1Ja0Oy0C4 KStEOd3TjpXrwRUGSduK7IbHlVV7xIZEz8qZJ71bDu6Ag8nrnoK0OYhEJY7fMBPtT2RYjjOT7UAN O3qFqcyIFwF5oArgMc8H8OaYzyR8gkY/CgDxXXWL6hIfcdvaubLY5oJGZzVuGd4z8pIoA0VuI3x5 i9T1WnymPyyyyZGeneoLOekcsT/jVU/WrIDgetRnBoEHFJg0wF5HUUo/SgBOtOA4oAk+X0ooEJSk UANIxTaBiUgoAWkNAC9hxVlWPQdTSAlUDJpT2x1oGRE4ph6UAIGx7fhUZPPB4oEMz7U/HNMD2jw4 M2hAGSD17V27JnIbPvzSLG/u0PChqiO4vhBx3zxQBYHnDgsoH4GlKgdWHrxQBErgHCgH3qRA6k4w B70AMmOT8zZwPSokaJsbUA7ZoAGHmAZOPb0rFvYI3jdXAbIxkjOaQzw25iEFw8foentVXiuVnqRe gh9aOvpUliHkU3j0P50xEgHvS49KksMcZoIHrQFgzjj1oBzwBQFx+7AIoDZPT8hSsXc2NLkMd/Cc Zyw4Pevb4ZCzMWO3phSPaumB59Xc2UdNuAvXvUWxiORx9a3OINgVuTg/WoSV7cn3oAuLJtXhTn1F QqzHgfpSATlfm3Ee1VSCxzI5J9qYHlfiKNVuiVP3gCeK4s4GQeT7UhEWQKd2oEP4HVv0pxIIwHOK YiLEe3lmz9P/AK9QEKehP5UAJj/apD+FADMfT86Tk0AGKcKBDuPTmm0wHZxSigBaSkAh5p2DQMTF NIzQIQCo80DFBqZSB3xSAlByetPzxxQMZz19KZj8KYhhFQ/hSAPxp6jnpQB7boEbi0yudoPPausK YHOKCxyjvjNS5KjGMUxCBS2TmnbYwMjk+uaQxACfuhc+9ScscPjB64NADFMSnqCwqMyjB2pye9AD GQsN7EgY6A4qi8kIPG9iRjFAzyXxBCTcfaBEVB4JA4rj8g1zSPQpvQOPalIweePaszoG8Uzj0qiH YlzikNSWGfpR3piFx7UtIoXGKAMVJVi1C3lyKwxkGvcrEo0ETt8pIweepreDOOqtjfjJwQvToKeQ Q2SeMd66TzwIHGSSacPLC9CW+tIBAC/8WP6U/BTktj8KAKjHd/F+fSl3xrGTx2xxTA4DxFbtJGJ1 RiFGG7gf5P8AOvLMHNIRF3pwoELg5o/ECmITpyGphPYk/nSAjOPemmgBMe1IKYEgOKfkUANoNMQc U6gBBzR0oAMiikAvPrQfpTGNzUByKQF22tp7pxHDGWPsOlbV9pNxZQpK3zqR82B900hmCpAOalBO OBQAzJJxSNmmIacY6VEaADNXbSPzJ1HOBzSA9y0u3aOzRt5XcM9SMVvfLj5ck+mM0FkwHGQufbih RnqBj1pgOUY+bj8RTjx/AD+FIAG4DAUY7iogm4jc34UARlIlYMFy3T60zaxGVOzPTvigB3ljq8me 2B0qOLClgFJ+vSgDG1W0WayeJ2X5hkZ9a8DZCrshxkHFZSOqmIQaUCsDusGOKYRzSuFh5/zijn0o AADSjvQCDNKM4pFC4x1NLxSKHqe45r1PRLoTRBJACQx49uwrWG5hVV43PQI3K4AWrLEEAk4B9q6j yh+1dhJx7VANxIH6AUwFwV5J59KjZdx+/QIf8uMdsVAME4Ck+mKAOd1e2eSzk2rkKM8V4q2Vcj+l AEeOM4pDzQIZkilz70CD/gVMJ9SaAG/hR+VAAfwpuRQAUtAhevXrSAelAC803NMBc0UAO6UlACg0 vOaAFVGdgqgsT6V2Wn+H3lw90Si/3R1NIZ6Xa2sNrHsijVQKvMiOjI4BUjBB70ijyDWNGaycyxAt Cf8Ax2uUDEUCJMjH/wBamHHvTERNz2qM0AArpNIhZ5sjqSAKTGj3eJfJiRemB6Yq1G65IYEe5/8A 1UFD8B2xuP4GlMaD+L8zQBF8nGSTUgPzcA/n2oAjbLY9aaEXPzDJ96AI8EH5MVLud8ZYDHrzQBY+ TBLNuxxVN2AOIwevFAFSS1MoLsxB9q8d8QWQt7vzI8+U3QHnBqJbG0Hqcjmm5rmPRuOzzS4/zikM WkzQMTg9aM+lABzTgCOtIauLj1pQQD0pFC7mJ7V2Hh2YLqCxk8P+HIqo6MieqZ6+C0mNrdOM4q4q LxuJ/rXceMPd0/hGfWmq7YyFH5UgDHz7iRjvxUoRAM5oAhzGQRj5vYU0HaBx9OKYEEhaTcjDhu2K 8L1a1NrduhHQ8fTtQIwsj1pp4oJG5GaAfYGgBCwz0phI7UAJk0UAH5UYpgLiloEAPNLQA7FNI96A ExTtpHNABilxigA/Cl6UhnR6LdRW91+8UENwD6V7AjKygqeDSKLBPFNJ7UwHbVdCrjII5zXj2vaU dOnDx8wSfd9j6UgOUBp3WmSIelQ85oAsRxl2BA4zj2r1Tw9ZMr+cMrt6HFSykejZU8Mcke1AAI4B pjJ9mM89abhR1oAYQvRe3epR16Dp1oAjdCMcnBPaodnYEk59aAJVU7ThVX8etQgf7f4UAKXVR93J 9ajy7Y+XH1HSgBkmT99jj0NcTr1sk1syopLqMqTSKR5B0JHpSdsmuVnqIP0FNz70hkvbJFJjtSKA AA8inZAHSkPYM80pOTwMUrDuJg880mPU0wsPAHFXraZoJklTkqc0irKx77bSK9rHsHJAzntV0KgG 4nP413nhsAcdE+tTbmwPlHI696BCiIhdx5HvRnHG360AAyT9w49aa25sAAAUxAIgQc5/CuH8QacZ rfzhgsn3selIDxuQYcqRioMc9aBB9adTEMpcCgBuKKAF/A0oHvTEO/KmnNACZp4+lAxxHFKB70CH haGFIZHTsCkMTimmgCImu60XV2idYJjlSeCaAPVUKsuVIIPepducGgZYVdvasfWY0udPkgbGcZUn sRQB4F3xjml74xQSI+NoA/GowOaYHT6XaSTzBApOTXtlpatBGsZIAA6ehqS+hoBMAAFfwpoiOcg8 etMCVo2AHINNBjTAeRVZjgA96AFZtpAVQc+oqAq46EAUANO4EDdnHpTg+B0JPrimAYLc8gU0xqDk jr2pAKQxUEDA7U/aRHy6DPNAFQIpO9mBx61E/lsCFIyRzigZ4brFr9lv3XIw3zDbkf0FYOAK5Xue lDVASB60zcKSLbRJgnnFHOcZqS7CnHQ807A6YpDG/jTx6ZpFIXApQBSKsBFSKecUiz2DRbvzbGNO rr8v4D1rsI0QDLkZFd62PDnpJlo4xgA/jTRGx471RkNYgYGenXmnBhkcAYoAHYlgE4+lG1m749aA EKhR99gabhShGNw7g0AeJa5p32eclAfLblD/AEri6CRCKBn3piFpDQAlL9aAF9sUlMQ760tABS/h QA4dKkAOKAJD0qI0hkZxTfxpDEo/CgCRFDHpQ7IpwCKAPR/DupBz9mlfJA+U57V6aGA9qBleW4C9 Otc7OXlOTwKllo8eu0MV5Kvox4pg5FUZibd2ODWha2plcAA5pgey6RYrbxhycN610xIDZzwOgzmp LGsxJ4GaertgjHNMQi4PU04ogYMACaBCOxIwEHH6UnzY5oGRhVDHLAmpc8YU598UAMKfMCzE59KQ sF+4pNAD13kHontVMrk43frQBCUUnjOfXPSqbq0Pz53DvQM808TLveOfA5ypIPWuD29+1c8tz0IK 6DbjqPzpcD0FZ3N7DzSY5qSx2OtJj3pDsOpCRSKFyT7UEeppiELD60uT6EUWFc9G8NTbXcMQF4OD 3r0qM5Uux5PQV1x2PLqL3i8HZxtRcAe1Ixbdz+lanONTGTlanLjZ8o/OkBVCu2COKXa4yC3WgA2r jk5NBCKCCckigRSvLWO6gaJkOCMdOleIappstnKQw47EdxQBzZJHGacOf4sUyRx9jTD9aAG04fjQ AUYOaAHYxRjNMQhpRQBMFp34UhjTSUhjCKZimAoFWkTn2pAU5peSqcL/ADqnigC7ZytBdRuvZq98 gnMkCn1FIpAVBbrT2QAZqDQ8j1eMjUpfcg/pWZsI4Jx6VoYsuWtu8p6HFem6ZYLGm4jDUDR2ITkc Gpwh7Ln9KBiruU5KGnhSc8dfWgACAEHH45pWOOq0ASICVyEwPU03YVYluvr1oAhfaCNpDN9KDE5w N23PrQBEFwcM+8+gp4LZ+QYb6UAIy5+ZpOlMJCL1/EUAVHGSCoIz2JoU7kxxxQBweqWf2tHdAAUX IrzAg7sYrmmelSelhpznimcVkdTJPrSHA6UhiZxTc0yLhye3HvTwSO4oGhmPU/hT8YHTj3oFYUfl +FOFSaI2tMnFtdo5GVB5r3C1kQgy4GCBgV0wZ59Za3NIPu/hx71GGGTzW5wjmCgZ5NKCfSgQ0s4b G6mkAdSSaBkhkAA4zTd4PYD8KBEnmbVBVMGsu9tFvoysmBn9KAPEtU0yS0lK9cng9jXMEFeooEOz mimIKXtQAoFOz70xCjmg+goAbTwPWgB56UmakoeOmQOKafyqhDCAO9GG7VIy1HGM8tzUksVykbOq kpjnA6CgDCALHABJPSp/LCh/Mbayj7pHJoGRDdJgKuMd6900rL2iFj2/pSKRshVDc1cKjbzUFHBa hbB71jgfdH8q582TyTeXjA6Eg1ZDO703TREAXBx/Ku1jRF5C7R9KYB8oztBPpTA7Zx5ZAoAcjndj HNDIXOS2KBCuFQbQ24imI2QBg/lxQMl804IGc4qHbuBLMRn0NADy4T7g/Gm7jj5sD6UARq6g/KOf Wl3NkgZFAB5Y43Y/OmsAExsJ/GgCgHHG4Ec45ocIVypO4UDMCQsjuoztYd+9eR3iGO5kVhzmsZbH ZSepRzx9O1N59a5zuuJ830ox6nNMiz6i8UtBQ7ge/wCNJg9qkoXHoKTHrQFh+fekJA6UiyQPn2r1 7w/cmW0d36r8p564raGjOSrqrna7i4UZwuOnepWVY1+Ugn3rqPLE+aQd6cFOeWNAho2E8kipJCny 7Rk0ARjcwwKmJCr7+9AFUgt1xj0qQRjHJI+tAGdcWkM6MsmCD+leS6ppDxMWjy6A9aAOOeMoSpGP rURUdqZIo5p23HemApptABxSUCHD3pxbFIYwnPWkLegxQA8NijIpiEJFTKDjP8qQzSthlxzz3rsn i/4lkxYcbKQzy+KRopQ6HaQeD6VaaHc5kZg+7nPrQMlx8vy4AHavYtCG6yXtwP5Uho6goB1xikfA TipLOdeAvcuwG7gfyrRs7YJlmT5jVEm6UYDjA9eaZhCCMkn1piI0VlboSPrUxYt7UCDYo6sfrUZY 9Axx1xQMdkKOc/hT03PxuwKAEKbM/OPxqMEEjJyPWgCYsuBtAAxjOajwpPzPn6UAOJA6LigK2BkA /jQBGSM9OlIDz1/OgBzqpXa3OfSs+RAqllFAGfKvnRZ3cj8q861qGPyllK7ZCcH3qXsbQdmcQfem 1ynpElPIzUGo3HrR24FMQv4gU0n3pCDpxSknHSgYh+opoFUSSrx2yK7jw9cFZ3h7NhsfSnHcma92 x6kp3HJzt9RVwFR0BY12njljMgToOTSJ1wzcd8UhD22BSM5pnA6YFAEi5Ayefao+S/OCPSgCUx88 jGahIz3BoANg6k8elIYo2UqUGDx7UAcXqGgCQM0Qx6Ken515rc6dNbuwZCuOzd6AMZhg4IINQHOa ZIZP1o60xCYp6rQAp46CojSGRnNLQAuKSgCQHFTqRj0oA1I52yBngV1qyLc2jwZGXWkM8ymiaGRk YYINPhfa2G+7/KmBceNlwezcg+te1aGNtihPcD+VSxo2ZZEQEswAHc1hJfrcy7IFLIOr44/CkWdN Bgc7cHuSKuBEcnJ/WqJDbEDggkim7G/hxj0oAawIIBbFQOoY7t9ABtcjg9fenAsARtX+tAEYViT2 9qkOMcdaAEwZOgY/hTxuG3oPxoAYQSfmPHsKsAKfmCkigBm3LdD+Jp7hl+UCgBhBHTvTApC80AIy lRxUQYAkHg0AVZ41KZCn3wa5W9thLCyvwp6DtmkykzyiaIxSshB4Peodq+tcTPYSurifWjP40iri ZOen50/8aAQwj2zSY9KYrDjx3pKBh9KOlAh3XvWzp0whuI5MkENzz2NMGro9ttXa4C4A2KK1VKIO eT3rtPEJQGdjjAGKm8tVGW/KgQwhSOBTlPBwvTvQMYXdj0GKQjoelAhCfXmnJtPWgCN9hOM4qPYy cqeBQMmLv07GopbZLhMOqEdwaBHGX3h+FiTEQPY9K4e70SWEbtrD1yMigDm3tJkJypIHpzVPaRTJ FxjrTCaADPoaUigBmKMZoANvNO20AJjilx780ASKcHrWtBcFOQaANVxbXi/vDh8feFVV0G4m5tiJ F9elIouwaXNC32e9R4gfuPtyAa7iS5FnCkNvG07hQFCjP50hmOLC+vpVe9Zo4s/6ta9EtbaOGEJD DsUcDimBpCLPBJzQIFBwvNAiXyX9gPSoihAIJwBQMjwuDxkioDgnhcetAC7T2P51A55BPWgCQjYg YEEntUCtzgLhqAJRvHJOB9aOAcseKAJvlHOCR9aeuD7UABODx0poJH3ulADsg9QaaysACP5UAMUj uQCe1KQp5A6e1AFB0kyTtyKy7iJWUBsigZ5nriYlDjIyOciuQ3H2rkktT1IS90AB60cVBuOzk8Um CO9IYh6UmfSmRcTBPfilwoHJpit3Eyo6Um4+lFguOBPrUynnikWj2LQJzLaLlst0OD0rsoxntkV2 rY8eSsy3hgRk4pjhieaZkIGINOJdjkdBQBIqmmtycEnA6UASKFY9cH0pwGc4IH1oGV9mOwp2Tj5c ACgQgyx+nNGxj0YigBQFBBbBx606QwspG0HPagZiy6dFNyIgPccVlzaHbuTlV5PG4c/nTEc3N4X8 wnyGKn65rGfwtfDOzDgd8GgRlSaBqKZzbkj1B61nnTL1c5t5OOfumgLFAxyA/Mh/Kjy2P8J/KgBR E56IfyqdbadiMROf+A0gsa8Wi6jLwtnMf+AGtmLwjq80RkFrsA/56MFP5GlcqxJF4UuiAZ7mCHnB BJJrfi8M2UafPPNK2ey7R+tMRu22lWsMqvDbKQO8nzc10ISTJHbrgDA/KgZN5TKAcAH1IzVfyj1L fXAoEWk8rkkZNThi/A4FAEuxV6tnNP8Au/cHWgYxmYD5jz7VBvU9RQBGWGTgVDjPOcUARuo7c+tP QDpsyaAGEHoM4pPJAwxbH0oAa21Tksfyp6+SykE5IoAQIn8JOPyqwvyjAGaAIGO09Me1G3IyTigB wRh1ORUqlRwWoAYyqSMDFVX8xfujdz0FACLL5i4K4PpUU8ZdOmRQBxuo2AmiKqdx9B2rzFrCZWKl BkHH3hWTVzrhJIywcmlzXMehcM0mTQIbx60ZFUSGR60nHvQK6HAZ6ZNJkUBdC7h6HNKMHqaAud14 buNt08AP+tAFeyJLsURLziumOx59TcmMjFe3pTwFwMnmrMBN3p+dOJbg9PcUCELN05HvSqgIJJzQ BCWVelPX5gT3/nQMQknjNOC7hw3AoER5bOOn1qVQCfvUAPdY1I71HweQoGaBjwxwcYFAyxwwzQIV 44sD5OfWkUsv3WOD1wTQMmSa5jGVIIPGGUGrX9oSggyQQMQMEletACfa4yB/oNs2O2zOalS4t1Vs abB83UbaAHC6AYH7DDkdDtGRV0ahIDnyIB/wGgCu+o3LHAkRR6ACseea4nUB5GkHpmgCPYSoLdBx z2pvlRn72fzoAQJGBwcipQ7KcKvFAhzOXHUCmER4PVjQMj3Z4VaXawAJOKBE29cAqCaeZDtHHWgZ XD5PJzQZFU4IzQBHgHn+tMz8uMnNACg7v4DRuOCBx+NAEbRMV+9im4ZBjNAEkZSTggH603agbheM 0ASNG45C4HpQXJA+XGPSgBp5HApvmsCQCT7UAKjlj1/CpWAboP05oAaqlQWGSBxSbwwxjBFAFcqQ eh69aMt6cUAZ1yhOe3tXNtb5YnB6+1IpHjfOKb36VyHrMXPqaQYx1FArhvHpUZJPaqsQ2HIpecUy dRB7U7liWPXvQIUKfWnBSOcfjU3NeU1LGRobqJ0fawYc5r6AhVdiNzyM/WtYnLVRfRS3GCBU4CIM GtjiGF+eBinFmP3e1ADkVm685ocqoKgHHpQBXwpPIp24gYXOKBkQyT0xUpVu7dOlAAoyOWH40p45 BH50AOC9OmKlViuQAD70AJgseRxSsAo6kfSgCEk4wOakXIP3eaAGEsTg1K4CqM0CFVlxwOfWn7gD 60DGhizcnFOKqevX60AJwCfYdqiMi4yFINADQN33jx7UhVR/TJoAj3fNwKmPAz1oERhQepwKcCBl c0ARhSDuzwKfkZ9aBio3UbOfrUbN6n8KAFD/ACnj2qPazfeAAoAcoXGMU8fIfu5oAXOfUUxowynB IoAjVWVcbicetOOzILNQBJ5KM3HH0p5hZSCDuFAEZLkcZ/OkUDPOaAJODxmqpUZ++KAFMYJ4FMZX TmgCVJQVwTSMM9voaAAbgOaYWIbkgj0oAHiV1J7Y6Vgm2jzwP1pFHz7k9hRyTXMelqwxzyaMAc0B YWg/WkMTNFMm9x2fQU7HvSLE7UvWkWWEQ4LY6dzXs+kzmezifdlgNv0xWkXqc9RaHaxg8ZO2p9ql sk5roPOJWK4BC5xUBVn6DFAC7McZNKAh46mgQp2jnHSmb8kUDHZKD3NQEFjgkUALtA7ikJUdP0oA cp5yBgelGTnIoAsDhT29Ki3Er0zQBOpAUMcZ+lR7Szcng0AHlqhJY4Paock5/ioESYCjPU9xUZyW BHQ0DJsY+bPNNLqOep9KAHg8cgjPaoiS2BjAoATbtJy3XpUfyluTxQIl+XGAOlMCsTgcUAPG1cfx GmjdnKge/HSgY+Rc8luvpTV6DbyB60AGM/MWpWVeTjPpQAmzJ5PFMGATzn60ANHB6dKGYtx0oAaF YnHWlA29zQAu4H1BqQ4GT1oGREsBwKUSsR1xQA7dxjODSfdB5zQAgK/Q9KidAO+aAIV3L3PWrAkI yGOaAI3aLIO4ZqMygHluKAEmnUDcpP0rO+1bnG1G+p4pFWJmuGAyc89gM1AMkZyPzoKsfPJ9hRXI ekFJg0xB9aKBDcetOAP4UxWF5A6mikWOGPrTx6dqkpExZnOWYs3qea77w3KTJJCWxj5lpx3JqL3T 1WB2lAyMAVo42gZNdh5A4sAvH60K7D+HigCN+T1xT8AdRzigCBiN2QKcGKn7poAacvyeKl2Iozmg CI7GzjJFComeM0ASAYHpj1pAvOc0ADNleT07Uqn5eAOPU0ANLktjOKOhJJoEIzAjvmlRgOcYxQMb 5gL/ADCnhAfm59uaAIWA9TU0e3aRjmgBpJzgU7y2bqxAoAh2jPLVKoTBGc0AAA6g0GM4yzYWgCMO ij7pY1aBZuWGAaAI12qSSST6Uu49BxQA3AznOfpTDvftgUAG0AfM3NQ8g/dzQArM205UCoFIYj/G gYOQhPaoo7kbtqHJ9cZpDsXN2AAw/Sm78HOcigBBIOcgimGWMP1HvQBWeYbgAcj2pN0o5VB+NA7E bPIFyV59Kx5LmdvucccikUkWIMEhpndT9eDU5djIQoDAdDnFA7EW1Gx+6wfXNNIkXdyoweCaBkQn YkB2+btgcVWOp20UpUjc/qB3qb2KUb7FW41yJeA2GHYDoa5ZtWyxOH5P96o5kbKmzgMnGabWZuAO KM8dKBXDkUvbpQAnQ0tABn2peelAwx3zS89BQA8HqM1vaVcmC9RieG+U0luW9rHvETBUVUPXvWmA oTlstXYeMJuUE/Ln60u58nC0ASrGSMntzSDA9aAGHZ97FGWZuhoAMAcsTmmMUB4JIoAkVU25BP0q IgdQcD60AN2k49KZg5x2oAmHIJ7Ckz6UAMKsTnoakbGMFt1ADl6ZxxTt45AFAEGwE5oIz/CaAGg5 PJ6VL1Pyk4oAjw4PSpCz7ducUANAB4ZuBQ5XHy9aAIE8zeNuB61ecY+8c0ARBl7LmlIJHJHPagBA AOMfjSFWPUnAoAEYIeBSHduznigYM6KOBk1A0jMvCmkMjEUz4Odo71N5SR/efn3oAqS3FmhO6TJA 9DQLtBjy4zg+vFBVmQPLcyLkBE9M85ojEmMyzL74FAAZYVU5dj9RmoC9vnO3G7qdtIqwdsNcfKfT gihpooozumY9xk0AZH9q24ID5LDgVUl1a2U5Uhj6YrNyRuoNmNcasDJuQnb6CoTrLhMBFz7is+c6 VSKq6m5IDHH0qq9+5P3m9vao5jRU9RhvpCOpU+tY7ysWJLc+oqXK5rGHKQlh1Jyai3VBZmk804fd zn8K3OJbjcZ+lBpgJgCj86BAcDvzS/SgA6/hTgDnigELjJ5pR0qTUXtipUznOcUirHvGnzbrOBwQ zOBXTrG/G44FdiPGe5Zwq9B+Jp2WIP8AhTJG4PdutP4HzZ5oERZB42nmmbSvrQMkbJHWmR8k8DFA DZCAeOlOX5upx7UAKyjnD01VGeWBoAkJPRcHHtUalg2fegCVm4PPNChe/wDKgBRjkVG0bdQDQAES Y9AaYvXk0ASMB90VHh0GVxQA8swHOKYqBvvHHpQBKqBOCarMSGyqZoAcu7HOADVgIvGTQAvLMdoH FM2nPzUAKX2jGKgLEHn8qBlbzOeBzTys0gBAApDJRCifM75P1pTKE4RSxoAj/eFiZHVV7KKy5L20 RmQyb2HUYzQUlfYkWVGTPllV6gEVFI0TDJcjPakVYoO9vGuXlJ9s1ltqsEPyiFiPUVLdjVRbGf21 EMkIAOuM1iXOtvICqJtUdDWbmbqm7nOyXk8h5lOPaoTcSs2Wdj9TXM22d6gkMkkLtu7+1Rc9M4rM 2SFAHc01mXHrQMi3/lURl5qrENkfmZ6moCxNVYybEzTM1ZkyDkdqd/KtDAfnPXNNBwOgqS79Q60v bpQMQAUpoAaB3qT0waAQ8AbemTSdeoxUGgD2HNSjjGTzQUj1Dw3PuQIRkp09hXpYcMOpxXbHY8ef xMkBycCrathdvQ1RiMCev50bVGec0AMLZ6Ur5ZcA0AKsZxjrSEqpzigBpy4/+tUXzA5zQA8Kx5zT Sp6cUAIFYNUu4qOOaAFA3DJ4pTgY2ng0ANUEHin5IHU80AKuSPanbRyR29aAIuQc7SfpTi2RyCKA DaSOvFM8tV53HPvQAEjNKWJGFGKAG7S2M8VIeDigBd5AxjrTWIA5NAyPflTwT71RblzuYCkMha4S N1RVLMe+OKZIt482ftAROygUFepa2oi5Zi7fzqISyuxJVUWgZDLNbwjdLJgVmS6naRjcAoz0Pc1L ZaTZytzrbSEqgO3sawHvZjna3B6jFc0pnowpdyg0jlidx+maY7lgAST9a527naopEPBGc07Ax15H SpLE3KDyBUBbNOwmxN9Rlzkc81djNsjMh6ZqHd65qjO40nI703PtTIE5/GgE0ANJ70maohkYHvRj PerMbCUlMQoPrTs9cUh3DNJmkO472z+VGccc/SgY7cO1NyaVhti59qeGOe+KLDudx4bn2XhQkYIz XrNtvkBLkAA8Y9K6I7HBU3NdVApRnPAzWhykpVs8nFJ8gJGcmgYEgZwBmlRWbigBGXYMbjVdcZ5o EWD6KuAPeoiAeN3NAxAF6EmlKgEYGRQBJk7eFqNAzZGDQBJ5fAHem4A7k4oAmyMcVHtz1BoAUADG DzTGznrmgCRWGOaQ/MMCgAG4DGaazf3qAGjBx60FsDgc+tAEe7HU5NNeQKM0DKktyCnUk+wzTY3M i8Kw9iKRViz95SGbYPrTNiLhgNzetAEDqx5MgT6CoJLiGBOX3MfU0ijlZteCkqiruB4NYsmtStkY /HtXO5nfGlcwpb2eXhmyKol89ck1zOTZ6EYKJGWGOtN3dfT3qTW4m6kLAUyLkRbJ5phPpVEXG5wa Tf7UxDSTioT1oJYvHoaTjFACZwcCmbh3qrEXG7qMnFUZ3CjA9aBjMijPtVmVxRTvyqS0B49KTNIY dqbxmmIUYz0p4A70BoJ+WKTjOaBi+9OzSGXbSYwzLIpwQa96s3zAhB+VgCDW8DjqrZm4HXoAKnVj u4IOK2OElZi/tUahOvcUAPyT0HT1pE385OKAGkAnk08lQOBzQBXG45B4p+3aeTQBFgFueKm3AdDQ AgJJ4pF3nocYoAMsGyTU+/aM96AGsxbkCoWZwOTigBqtjINT7lwOMGgCTIYcAcUwfKOaAGlhjrzT Cyn7xoAgMqDOKqiZicqCaCijLJIv40bWIBlkOPRakuxcjeIJiONgB3ao5LmKNSZJgooC2pltqFsG 3Bw341hzeIdjEQpnHcms3JI6Y03JnN3Gr3c7E7goPpWK0shOWkJPrmuVzbPTjTSK7MS2SRk9aaX6 5OazNthpORTM57c0AN5o5PU0yRD6UzcM0xBnnvTS1ICMnNMJ96oi43NNzx0pkXGnNIMmrMxSMcYI owO1IAG3vzSnvQPQTOO9N5/yKYrjMUdKsxFycc0Z/OkO4nJ9qAOKYtwBAxmjvQAcZxSfSgTAZxRn HGKB7BTwTjnoaB3JVOMDiva9KkEunwKhO8DBIqo7mdTY7SMKoBYjPpVonPCriug84kCkgc04MiA4 xzQAbwxzgZFRSbmoEPSMAckmlcjpjBoGRDcBuOCKYTzknmgROFjVctzVU9eF4oGKpfnAOKeC2O/N AD1UE8jNPdVPT+dADASODyKjc9KAE4HGRTHkC/e5oGRbztz0HuartKT0PFIdivvcg4BP0qSPzG4a MgDuTQUNYDd2x3NVStwpwsqkE8cUDVgm/dqHmbPNZMmqQxodoGR71LdjRK+xzM2tzO2AQq1zlxcG VyxY4PauOUrnqQpqOpT8zsaRnJPAxWJ1jSWxyajwT1pgOGKafUUEjSeaTfjtQFxhc9qiJPHNWZtj DSe/FMkYW96M5p2IuApvSgAx35oPUdqYhTSfjQA00ntTIE7dqXHvTELgdqOf8mkMYf0pMc4xVGY7 iloKE7000CY7A60DOaAsGKbjBFFxND8E0080DBRk+9S0mVFDh14Fd34duikxiJOCMjHamtxTV4s9 TtG3kljk1sCbb0FdZ5BYHK5PFMWME89KAHsoT7o5qPk9aBCMQvU5pqtznHSgYjHceKf5eeSaAEJC 9OcU1XB6jI7CgBwfK4xzSDBGT2oAj34+6cCgzKpBIzjtQMrNMXJwMVFhm5JxSGZzTRK+1WZpBVhD LIwLYpF2EnVCfmZuOw6Vmf2hbwkoEJNK5SVyhNriRg7U4Bqg+vOUyqZzxzWbmdCpNmMdYmDEGNev PNL/AGxLgYGMe9Zc51exKVxqlxOCOlZjSAxncvzHjNZuVzaNPlKm3NK7L1UY4FZHSQlhTd9OxNw3 Z603fTsK4wtSg96ZFyIsaYTVEibqZnJzTJuGTTe9Ahfak/GmIKTNAhpPbtRmmTcXtnFJg0xDsGm4 HrSKH4FN+lIYlO59BTFY/9kAQVNDSUkAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAAAAABAAAAAQAHAQMAAwAAAAEABgAAARoABQAAAAEAAGNwARsABQAAAAEAAGN4ASgAAwAA AAEAAgAAAgEABAAAAAEAAGOAAgIABAAAAAEAABKPAhMAAwAAAAEAAQAAAAAAAAEsAAAAAQAAASwA AAABAAD/2P/gABBKRklGAAEBAQBIAEgAAP/+AAxBcHBsZU1hcmsK/9sAhAAHBQUGBQUHBgYGCAcH CAoRCwoJCQoUDw8MERgVGRkXFRcXGh0lIBocIxwXFyEsISMnKCoqKhkfLjEtKTElKSooAQcICAoJ ChMLCxMoGxcbKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCj/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsBAAMBAQEBAQEBAQEAAAAAAAABAgME BQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAk M2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqD hIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGh scEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCABqAKADASIAAhEBAxEB/9oADAMBAAIRAxEAPwDw gEdDz3o5xnGBS4zx096MYwpJ/CuM9iwDJ6mjaDyOacCAMkDOeppMkngdu1IdhvXgLyeMUoBAJzig 4PbLen/1q19O8Ka7qiK1npdzIjAFSV2BgQSCN2MjAPI9vUZdm9hNpbmQPTnFO47qOOhNddafDDxB dAM5tbVt23ZNKd314BH610Fp8Io0Xdd6jJIMDiGPZhu45zuHvx+tV7OTM3Wgup5kFBHXtk8U3A/h PNe1wfDHw9AgSW2luMHLTvMwbnoMA4x+H9K24fC+kwIJYNMtIpPuo8cADDK+ox+P1qlSfVmbxMei Pn+3s7m8cx2tvNO3dYkLEenQfhWtbeDvEN1H5iaXcKASP3pEZBGM8MQe9e3x2MEcS7NodRwVXlQO 54PJHergcRlCXdwxyGkbrz39/wAPX2q1SXUzeJl0R43a/DDWpzGZJrWGM43ksxKeo+7gnrxnt1re tPhLabW+2anM67hhoowg2985zz/nBr0UyvGMFl7Fc5x06jp6AVCDHKSqsCxYgqeufUY/xqlTijN1 pvqc7ZfD7w9alJBYxTSrwBPIzhhggll5UnB9sdsVZ8QaNp9z4bvrG1tEt1MTNDFAqqu8DK8AZ5ZQ f51ublZc7c568H5h6D04of5Qq8ZDZyVBB9sen4VVkZ8zvds+a9pJyBxQfTgACt/xhpy6fr90qgeV KxlTaMD5jyAMADnOBjpisE4zkY/rXI9HY9RWcU0M256cgml5YsaCcn0wKMAdBjJ70xWDnceehrQ0 nRdQ12cwWFu8zKNzsOFUepJ/yaoLubOBn3rsvhpd/Z9f8lmULcR9D3dTkfpn8qIpN2YTbjFtGxpn wkmkaL+0L376H91brySc7cMeCM4J4HHeuu0z4aeHrFcvZfbWXJMlyxbd/s4+7364zxXRwn5kJPl4 wAdnJ69DVpnKKvzY4Gck/L9a6VCK6HnSqzluzMt/DmlWPmG2sILViuHEcYXfjselXTAsUZRgBFnd gjA9sdP8DSi424ZT83PC9MD1FYPiPW4rGyieWR7eOSYRs6g5UkZH6A9PTjPFUZmzHNBu25UZzuQZ wB6DH+NWtqbM7ACBgKCB/niuN/t3TbHTYruOdGgkH7qQ8ceoHXPoP8K5XXfijfOn2fSYPIHe4lwz N9F6D8c0AeqTTRRKS7oQuCufc5z1/nWXN4r0OGTa2r2YwclvNTg+nf8AP34zXgl/qF9qE2+9upbl u3mOTj6en4VWXB5x3oFc+gf+Ev0Jm84arZYX+ETLz3xgmrtpfWl3ExtJ4p1YEHyXDj6DB4r5wbKM Ppx71LDJJHMJImaORTwynBBoC59D6jK0UcpiiIZePp9OBz1rm7q8XTz9oluxb5BI8zPJ4+6OueR0 6Zz2rhfD3jbWrS7itVu2vZJWwI7hwFyT1aRmXb9ScD2qYajb6lqEcmoWiQC+nVUkEm54sDaVGMDk kHJHbg8NQM9YsJpLm3D4C5AXgHCjuf0/WpGG/wCQnPfgghfU96i0y1aOyRJEKyMSWGBk98dsDP8A KrxhQhixGAMqBxuPGRnrj/CgDz74l6L9r0sXkaJ5tr+8wC24IfvA849G79OOpryQjGScDFfSVzaR 3MTQyRrJG6lGVm6oQQR7DrnmvnvWdLbSdRnsXBzE2AxX7ynkH8RisKq6ndh5XTiZwIXHHfrTv93t SnHGTyR3FBIUkcnjuKyOkUe+fx4rS0K+XT9XsruQlI45l3leu3I3Y4PbP51mDIyD+OM05CoOP4vx NTtqXurH0nFLK0QLHaM7ixAwPTH1+tSSMgjwuMA5JILEexxkdcn/ACaxfB+o/wBoaFZXXHmeWFZ1 +UlhwT2xyDW7GvBZlDKScA8Y/H8fWu5a6njNWdiIAHy0DmNd3QtgdsnPGPy7V598UHlhtbUTzMsE twodHXJJCMA270GWHH9BXpK4YDlgc5+UZPsMZrzHx5d6fqmoS6VOrutrGsrtH8jI5PbPB+Ur1Hc4 oEefXOq3stvFE1wsiQ/KqGJeB2AOMn9Krxk3KM5Izuwdp71ek0+xisZIh9olmJASYELGq85BUgkk nHIYAY6HORRjiSLCc7R97/69BLF8tSB1Ppgfzpu6GNiVJc+hHFNmuFZyVGM8dO1R7sZwTgjmgB0s gfaGGMHrTkjO7auTuJAA5qFvn6UDep3rxtoETx2d1Feqvm/Z97AO7EgLz1bHJH0B+lbFvZT6xdJD dXG2FHAZ1YtJOeny5HA44z0z3xiq1vci8ZFlZdvQtjBB9B7VsK9vpc8V3A6kRkMAT94jtSbKR6D4 M8ZjUTLp1yAlwnzIwOfMQcbeTzj9evrXWoVflmY9ztxxXzzaahJp99Fd27nfC+9Se+K98029+32U F0qn5kDblGeDgA8fz96YIuGNZCNy5GOccFfQ4HX8q8v+K+hSb7fVIYWzGDDOAp+UZypPpgkjtyRX p5BB4V/LJywH5dPz/Os7XrCPV9LvLBzkTLtDKA2Dxg88cED07UpK6saU5ckkz5zIO4fN39OKNuT+ HOTUtzBLa3MlvMoWSNyjDPAINRfeG4E8e9cZ6ujAAAYxxT1wB0Az+FMzk89aco/yKTKR6x8KdQ82 yuLPzCPs8u5V3dFYdvxBz+FeioNgJ3kED5scdsYzz6+teKfDPUFtPESwYJFzGyjacYZRuB/Qj8a9 tDB1yx+fO3BG7HGPfH/1q6qbvE83ERtUfmI5AwdzNJj1yR6Y5NeEeJbp4/EmomQFiJ2Qq3GVHAB/ ACvd2SQplWPt156deteKfErTjZa+1wF/dXKBg4BALDg/j/jWhzGWbtFs8wo5AGNu0/j09PwrDmkl G7epG7nkYz70hfPIOPfvUbsHY55564osK4zkng9qcq+pA/CkHB4HFOGeueRTEBU4684prKQe9P8A mB5HSnIoZgrOqAkAs2cL7nFABbSbHOOT04qxLKxxk5AHfmvSNJ+G2j/2W5nuHu57iPKXEZ+VM8go O/brnPtmuA1zRbrQNQewvEO5RuRwCFkU9GH8vqCO1IZlySbuAccV714Fw/hXTXlJ+WHbg5ycE4xx XhNtaS3t0lvAu55G2gAdc19H6PZLY6da2YVB5UKjavAB78fifzoGiyPuk5YNkY9B+n9aCoRAxclm HXqF9Mcj07HvU4jGN2AFz8pPH+etQOqlQ2ACTjnr+f8An/EGeM/E7Rls9Vjv412pdghlAP3h9fbH 5d64kDKnk4x0Jr37xjoi67ok9miAvhpIcqM71GR9M9OBzk14CQUZg6bWzgg8EGueorO56FCd42fQ dt556e5pwORu649Kbhev4cUp4GcDHrmsTsLem3j2N/b3cShXgkWRSc9Qc19F2M0VxaxTr8ysoYNu zuB6Y/zivmkMcj5jgd/SvaPhlqjXegxwGT5rZmXO7JAJyPf1Ax6VtRdnY48XG8VLsdsTjBYBs9Rj GPYdf8isTxb4ei8UaXJakQxzp81vI3Ijb65zg/5HFbyoAo+5nqDnOPr1o2jaVwcYyAO/19q6Dzj5 k1HTrrSLyWzvoHgmQ4Kt/OqmMkivorxB4S0vxFCY72HEijEdxEAGT+WR9a8v1n4Xa1pzSPYxjUIB yGhGXA917HvTE0cOFJHPSnxjGeMCp7mwu7Ij7XbSwZ7OhXP0zVZsn7vT0piJpCSOKjZGWJppA2wH GcdT6UgEnueOlbWlsb+yuNJiiIluVGxkRmOQwYZAye3akB0fwt8RXKXFxpMq74vLM0AJz5ZyMjHo c5/D3q18RtMuruexuwnmuUcNgdsrtA/En86TwV4d1jRdVF/qGmzIDC4VVUEyuSAOn3T7Nj1+nplp pU16I7i/tUjlA3JEW5jGR1/2uBnt9etT1L6HGeAfBY0xl1i/jX7SwzGr4Pl5HUg9+vHbivRdxyR5 uVPXAyMD6f1pkloy4YjBXvnkfiKrssgweCAOSFpgWG2yR7hIHOMDPp9fx9ajyBhW2845B/p/+umg mTBXqOpI/XI/rUjIFH38ehI/WgCrdZJCuzL7KcY/D/61eBeK7E2mt3eWJErmVMcfeJJ47c5GK+g5 INy/MAUPQkcH/CvMfidoH+jpfqpDRH5+5KnHp7/zNZ1FeJ0YeSjOz6nl+89vwppfnP8AM9aM5BI6 ij5hzjA+lYWO5tsXueMk/jXd/CvU5LLWpLdmIiuk252kguMkfpvrhFXJwRxV/Sr2TTtQtruPJaKR X4OM4PI/GmnZpiceeLR9NhSw3H5u5PH+f0oKNjj5T3J/h9qbYzC4t43QgI4GCDnI7Y/+vVgjKH3O Tnua6jyiu24/Mwzu5BzninCQSAZAHb1/xp2MA8kjufp2zSAqAP3gC9cYzigBJIo5MqyJIDwcjg/h UDaZpcoBm0fSpGUYJfTLdj9CSmSf1q1tDY+bAB4B7e9IUJXI5P3hg9fXIzQBAmmaOgIXRNIBI5I0 y2Vh9CEFOlCzHLje24kb+Dzzx04qQIwB5JBOc44JoZSq7gACThsdB/n+lACbiVC9RnABHtRHLIgI U5B7ep/lUhTqVAAI6Z4H9P0qvNcJCXDsAAdpLsFAPYZJoAWRnZsE47nPJzTCquM7jyMc8H86SRl5 DNgAZYRgk47e/bsKxtR8RafYSfNdwRuAco7sT/47/h3pNpblqLlsbW1c5L5YHoQQT+I96RzhA28+ YO/Xj6Vxd78QtNijYRfaZnzgoBjH4+nbpWBefEIyoY/sIKjjMsxz+OABWbqwXU3jhasuh6i02Fw7 rgjGc/zB/nWZqkVpd2c1o8ikMhXA569uK8um+IWoCNUH2dQo4Kx55HTOeO1Y1/4w1S8Vk+1ypGw+ ZI3KqfwqfbLoaLCSW7OZ4J54+nenZA6E4oh5fnnmnYG/GOMVm2dC2uNVgDnmlDjPU0nahRxnv60A mz6B+HOojUPDloWILonlnDZxt+UfjgA/jXYkAsQcDPQMea+YNO1jU7CPy7PUbu2TrthnZBnHXANX j4o18gsdc1LcMYP2uTP861VTQ5JUG5Npn0e2cBhx/dB9PXHNM5A3DJUHtzz64/KvnT/hKNf3H/ie al0P/L3J/jUi+JteCHGt6j/4Fyf40e1XYSwz7n0OOc5Gccnsf1oecK3JUZHPzYOP8ivnT/hJ9e2A /wBt6jknn/S5Of1qM+JNcYZbWdQJ9TdP7+9P2qD6s+59FNqEKkY3uwHRRk1Vm1IKCEUA8k7uD0zz 6fjXzy3iPW1Zius6gDu6i6f/ABqNfEGsuWLavfsT1zcuc/rS9qNYbXc9nv8Ax5ploxMt41xID/qr dQRz659Mdj+Fc5qXxNkkbdYWCRsCdskpLE5HoMfqTXmDzSszEyOT6ljSNLJ5kY8xsED+I1k5zezO uNKlBaq50994p1W+GLi9kK7t20EKM/h9KxnuyP4uPavS9B0rTp7DTGmsLWRniUuXhUljnvkc1J4y 0bS7a11EwabaQlIXKmOBV2nZnIwOKPYt6tgsXFPljGx5S92T3PPvULTsagY/OR2waG+4v4/0qOU1 dRscXz6D6U3OR3I9aZk/NTu5FVYz57n/2f/+AAxBcHBsZU1hcmsK/9sAhAABAQEBAQEBAQEBAgIB AgIDAgICAgIDAwMCAwQEBAQEBAQEBAUGBQQFBgUEBAUHBQYGBgcHBwQFBwgHBwgGBwcHAQICAgIC AgMCAgMHBQQFBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH Bwf/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsBAAMBAQEBAQEBAQEAAAAAAAABAgME BQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAk M2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqD hIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGh scEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlq c3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/wAARCAGRAlgDASEAAhEBAxEB/9oADAMBAAIRAxEAPwD+ MCWeFz5jL+6X+I8BeP8A64GfYetRDVbeZfIgOZBnKqOmQowT+nJPp718sqcpK/RH6jKrCLs93sQ/ aJmR9ts7Sg5beq8gDsfzJParscepNbiVoUUNhAHCjpznIAwPzpy5I/E9Qj7Sfwx087Do9OlEQ+0D aTl8MQM44wCfTpjr1qWNYd+4Ahy+0/Nwx5/wB79PWocua/LsaRhy259xzF4yytEV2nBI4yfbg4oe 4uozIDMUHJ2qnMZHUA9uvr/OpST0NG2vIPMgjeBDK3mMFzvzg5HUZ9jjn1FQSXcLuzkOshU7cAYJ Hbpx3P5d6ajJu7JdSCTirkEkisI41n2gjrwdvtnsce3FVQpBCLOqso+Y8YPXjr19uK0WnQyfvO7d hZpI1/dxfvCx5YAPuYHnn/PTvTh59wcw27owI3EkEnAzyMdsfTH409leT+Qn7ztBX8/+D1Gf2fKz BfP2nbkgBR+H17c9M+4q4ml27rtnmYsF5YfNtGPQfgPalKs0vdiVDDJu85aMb9jsrYuph43ZyrFt 3HJyM+/4HPrT2nZvKCbwAOEJ4xwR34+nGPxpXlPWTL5YU/dpqzGzEL5u9ELsw+6QAAc8A9O2P8Ks pZqm+YKgiLgAs3AGcZ+Xt3+g6kipbcdO41FSfoI/lzFys++Q9CuMr9c9OnXPTB71Yk1CPS4oyUQM VOc8tyBySPxx1HUcg4qeWUmoWNOaEYupfb+vvKA1OV28uO1Z9uBuBADf7QGOoA/WoZFuLhz5Eawj b8zbxknBJ7ccD9M1pyRhq3fyOf2kqytGNuzehOsggt91zfNLcBj8wXIXj19jzgcc5oVvMlMkkTrl SRxndkcHoMdRk84zStu7W7IrmslFScn1YscNwrKYJwAx3BhGcZ5XOSOvX179xVmG3a8UR3l0xA7F doYDnIP8XA9uOR0pOSXvKOq8ylCT93m91+QtxY28TKY0dwPugrjocZzkYP0+vGaZbwsvlhIJN+45 C4JYg46Z6dPzPtUqblH3mW6cYStFEsss+4+TEPKx94v3AJ5OeuD+XvipI1n8qQOgCN03bh82B0yO nIyT9e2am0Ut9S05N2S0Jbh7hy8dzMBKG254XBHGAR057nHY1QksY4WVo7lWO05VFPy+4B/E4xkc g04Pl0S0YpxU/ieqIhHDHD5nnBiOWC7QGBz0AILdP51SFy0kkcaxs8QwrEAdOv8AEM9OnpjNapN3 b0MJNRaUVdv0/wCGLVmsgjkkMpDKp44b5eSen3e30JzVqNJJJXBXaVwhIG49ugJ7ZHT1xUyau2aQ UtEyKeJpJDE0oYMMA78D9P8AOAe9XvKS2VJJNpO3KqFznrg56Z5P8+9S27KKRcYq7k3f8Rq3Yffv nGXHHzAHGCPXj8T+hqJ5DAio8qxqchduCykYH59QPXB96Si07WBzTSd9v1HRala29uiRo7shHzL2 6Y+YewAAPXGe2KluNWnuYnW3sDjC4LOAVCnA6c5wR+POOaTotvmnKwKukuWnG+m4iXF82D5gSEEn 92oyM5GM47EkdRyajeN8tI9197acqhbHqQT34I/rTSinaKB88l78iNIJVOHvCIh2wMH8h7cfn9bl vpXnRSTvtMajcWkbDHpjGR9O/v05olUsrpWFCim1d39RGjg8o7zmZyFPyEnr8uCR7H69OlNi8tpV gWFtvm7WCqNzE9AM9T6Dnr7UtWmNqMWmLI1vEfLZQQG3L84ztODuxk44wO3rk4rPkvbHMyxK7KCA hLBsd88gZ5wOnr0rSEJy1T0Mp1aUFqtf63GO08TPGLAeaTuA8v5uoxwQBx6D3HNegeF/hJ8WvHKS X3hL4d6xqOnI5V7iw0y5nhiK7Sd0kSlVA3rkk8blrohSctrtnBVxcaaabUUe3aN+wr+0vrk8aP8A Dm+srZyima+2xwqzbiuWGeDhhn/Zbiv0t+Ef/BFuLXPAVn4g+JPxlRfElzvNvo3hqzF0SVAba1zM 6neQeEW3YHY7B9uN3fSwc3b2miPGxGa00n7B8z/A+z/g5/wSL/Z78OSTQeK/AOsa5chA/wBuuJS9 vCjAne0W1VAI3EFsY2gHkjH6F/Dz9nf4T/BO2fT/AAr4H0CBNohhupoYbWGPGVzhFjZ3YMDuMhyY 1Ytt+96EKFOmvdWvfqeJVxdau/3ktOy2H+NF+EGqXFxYW1r/AKS8QWS9WaG1ghzLkFZ2R3B5kbKx BwoGAVXI/k9/bk+FGkWn7Unia18IWuuQ3uvadZ6xoNtc6ZAv9p3jLFHPbx4my674rpYpE86SeVI4 /LzLvHPjEvZ6rY7cubjXVna/9f1+p8FzxyM8y3c27ABynzDsOccAYGPw+lZzRojSHzADtHK8fzIP 8q8WL0tFaH184pu8nr3LqpBLJulwpxtzgKTjJwAOBz6n/Cp1FsFDJlZGUgKCeg7ZwBnjtjPpxWbc tlsbRUEuZ7jrSFIZUMudg6Yzgn8T9B+R96WS1lkkmuJyPKXByQcEdsH8OnqKXPaXMUqT5FFevyGO 8UBZxNzzuRVGV4x7Y79Onf0qmUkeWSP5Mnkbl4IGOmAOMf5FaR7sxn2jt+H9f1qV4pQpWAiMrkFm UHPvznPfGOOQDU6yjIeSMeUQOjYLAdO2M8Z/OrkuzMoSta6KbIZZFVl24+8GYDnjgAj37+lS7eH8 pnWEkFgCdpPJAPOPqfoe+Kq+ljNrW+zJII/IDurF3Py4VhnnPPfp1x29aMyPFIi4SAnLASbjnsM8 Z69h0pXvdsrl5bJf13LLrMJUDNkqNoIP3RjG3jpjnPHvnmnbH/vr/wB/G/wqHJKxqoSdytb6IjiN nuGV5D0H93Pr26frWjFa2sO1UgB28EvjknPPHXv/AIjionVlL3VoOFCEbSerf/DluC0txE0j3Oza Bt2tk/n/AJ9aJbmZEQPcqIwcBAwVgwzjJHT8++axfvP3kdPwR92X4lO4mKM6IVkJj/eGA/I2cH06 5IByep7VVSW5MjSRKqLwSzEYU9iAOvHp354xWkYxtd/8ExnOfNaK+fTzIHe8hiNxPqDPIuD5a7SF zjqM4HX1PPbBq1bFWUM16it5bbY5IyWUc5AJ+UdOOecgfS2ly3jH+u5EHLmtOevpdX7f1oRpKrNg Q7icsMEjePxzn/63tUsUNxeToIIwD/F82QcDv2P8yTmk7RTcmNJzajFEstqkcJklmja43nKqc4wc dOfXHXr1yCDVRbWyARZIgXUnkITuGcjKg+mPY49qSnJr3SnSipLns+/qTBrYRJFHMUUctg/e6cDj Oec5x6elKgVVWSNHeQNndnG3nB9ce3v6gg0ndb6eZSSltrbZehPLc3ICl0wCcLuUDd689x1GB/QV FFKRcSYUBSCCQNy85HTr+vOKXLFR0Lcm5JtFmSFPJEjEGXdvbB+ZuMfMcfTseTnvVOYQxkZch0bC gSA4YE919uSeOQaIuT0HKMVqOaSMSM7KpHDoSrcg57Y59OnOKru+2O5Xa7Pu3kMxCqeQeMdehzns apJ9zNtW0X9eYs0t5dB4Y32qAdzrlfUZOOSfrnoBzmooNJu/LeZ5AXYbd8uWx19+vHHTOMc5qlOF ONuv4kOlUrSTvZK+nT1saq2M8MYjmlLx47RZUNycDqScEc5x83tmq4sUhKefMxI+bYp79SSQOO46 /pWftN+VG3srJcz267FqI24Rnjtw0hI4J4H9e39OatNN54XAX7OMKWxnb7ckgn9TjFZuLveT1NYz ilaKsmWmmgDmPcxdlHljaCEJwOcD/J2471myXaoWEcgWYHG/DZA6EE5z+nc9uaUYt7oc6ii20ywk dvL8m55psEgDO7OTkKF46ZHfvjqKrT3IkLSW8JGDsT5udvUAdcD6/h0ppSb97REtwStG7bK8Vhfy QNFuC5+fIJyoHXJHpnJ4Oc1pHSruWNmlKxxqNpPU8YGSM4XqO59OhpyqQT0FClUa956fkU306QBS 0zZ+6QMDPtz198/SoI7GK1KI6hpTyc/MMdsgjA45JGeMYqo1bppaClh7NSk7mvF0ZI7HGxSWI4A5 Bzgjp0/Lp1qM2l2ximkWRCw+XkAlcckHIPPI5+mTWXMo3u7m3LKSSjGxXnt44pCZJk8zoUdsc4we vTH16DseKrtdQRo0a/PtzlQSyknuTxjPHPParXNOzSM3y0209WMS4jMmBZuU6KS4HqR2GDz/AJya enmO6JHbJuOOTkZx7Z57j9Ktq2spfcRFuaVofeONtG7K7kM4JyqRlQg6nPHHbv3wKkOn2KMWeTeM ZLdxxnGGx+nbFS6k9olRo095f1/wxdaKyVlMaFlzlQuAwGR3wPT8OuOaS3uo2d4OkWSzbwQpI+g7 jI7dOfWs7Skm2bNwg4qPUilvB5oRwRG+D/rCcDGOFX0ycZ5GB6VSgVJ5Ft3uSrv8qFztUMTgbmJA X6nIHWtYwaV9znqVY81m7FmVTaXdyk9uSyStCMyIF3LkEAg7TyexYfUEVRhmSWVEj3hySCQMjB69 PxrRU5WuYuvC9tf68jtPDnw7+IPjKO6n8I+CdV1OC2khguXsdOnuBbPKH8sSOinaXEcm0EjPlnGd vH054d/4J/8A7W/jHTdN1q2+Fc0GkXQLxS3+oWNsyDcwO+J5FmVhsOVMZbvt5Gd6WHqVbOETgxGZ UMOnGc/l1/zPvX4N/wDBGHxV4lGm3vxP+K1pp2m5Ml7b6cpaSBd0aIVkkBBDNKqjEZO44Ckc19Hr /wAEb/gno/jC+nXxZ4jn8Jw3rG0N15LxNa5wvmPHbRPKWLRhXURKxI6bsD06eXwWk5a+R89WzqtJ t0opLz1Z+gvw1/Ye+EvgCW1+IvhbS4bbWHaUWt4LKFrhpQqq26RdjBgrAsVXDvkkNlzX0I+meK7X wPfWs13aR5UBZxdKPK2fNINoAy7c7lwNzPzjAz3RhCFlCNrHkTrVKjcqr5n5nZeFZ7LU9Emt9TnS Z1LbUkhWSOyDuWdPLZQACCN2DgDj1o1Kz8JWqWF1ouiWst78xjKzs/mOdqqAgwQVychsn5dwOGUC 9mZal3RdR8YyxXt3dWYk05xbOspubdiQkqB3G6Vdr/dADAjAccZLBGFt4l1G4sLyGK3skjWG2ZlU C5OMr5rKdgG7BcBuNzMvBJKvqV08zqrj4Y6dDA51TR9NntGEQeU+QGgztEmwKJTB+8wqt54UBAGL A5b+a3/gsp8B/C+m+EfB3xf8O6ZFa6tbavPpd5DFFchZ0lRW89Sh+zjyjbpD8qruEgLDcoNc9f3q UmdeDk414a9T8Fb/AFKbxAx1G9Jl1ElpLmZlZmuZGYlndix3MSxy3Ge+WYk5ItrkSvcCbMaNlS3B Ldun0PfoDxxXz94wvFn3fLOoozj5Pt/X/BJVlt0CiacmYnJVR97OcknHt7nkVI080ioIoScfKdqN 14yMkcEn+eM8ik463loi1O14w1fUsfab7ascUR2YG3OMAdePXqR16ce1VmF27OSY1z1x91cnGc5q YqC16subqy02SIVg+U+W+HIPTI3duME89s8cmljtmMwkkVSkigZBLEDIOfbkcA84yPQ1pzbmHLe2 owxKPuogCjgEYI7dcjJ5AH1FMSJzMquifMfm9VAPOMcE9TyRzjtTv5icOiSLymRUYvDtttjBeN+Q M85+pJ6456cYqO7mjdFjljRQ/J2nGAehIXPHfjsaS3TQ5P3Wmv6/MoSwMzeajAqRkgygFfYj6/55 q3befFGtxuz2yAMA5BOM8dxn8uM1bacbMiMZRk5L/MkjeNpcMd2Tj5VGDgZx6Djvj61b2W//AD7/ APj8f+FYzk4u17G0UpX6lN2DAS3DOJnG5d2AN3QcdAD/AExT0M8nlxsYUUcl5EY/Nz7c55Oef0o0 t/kCvzaLV9WO3ROS0t4GfkYDEA8jrgY59M9Pxpnn24McSW4yCfmKnJyADx7HJx+FK0rbWQ3KG97s Rr6582bAQOzKABkgjv3z0HvxkVIXuXRz5RLHqwDJt6dhg9yOvQjjNHLCNhqVSV9P69SSO3lWJY4l 25O8D5VHGTzgZBwT3zyMdaQ6YkSiaVRtB+XIwGHY7Scg+vU4461PtLPTdlKk5K8lohqC3WYqkYYM RwoByeOMDj19cVbS4kCmGNR5mOjuQFPb7wGP6evNKS5viZUWov3UIIYTKRFKGTAGFdeT0PYn1PTp xQDZTGbNwERRlcjPBAySRjAwp/TApe/0Wxf7u3vS3/r+tS1KllEmY4906jksqxlhjquDkkYPIz0H qazZdriQhtsmCrIEbjGQDg4wMfp60R5uoT5be7pb8/T8ilHD5MErmT5wQY2QkY44JPU9iMH144pI XuZtreUC7MMKD949fQ/iffNbe67tnPaUbRXYfHHPgPcXLHcfMdTg5PI6e3PXHX3zV54Ipg/lygty dw6PnIH9fwGOuKiUtbxVkaQg+S0ndkJgREYxksWbBw5BJxk4HpycHng59atWkdv5kiyIfMJwcrg5 784OO/fA/GlKTadjSEIqav8A1/kOV7aCVT5bM6HcuGZs59M8Y/Xn6VPcX5lTKwqZCw6EDbu46MBx xnPPAzwaz5XKSk2ac8YQcErv+uvf1MyR7piFWUQRHOQjb89s54BPTp6571XKmF3nhn3NkHdIMEde MY79ccjp1zWy5Vol8zllzPWT26dPvsXrWebyysTIigDZy7BzwSBxzxg8jj9C65dppH+0EyW6tjJR Y/M5z0zwD16cdam0Yyut+/8AwDRSlKFnttb/AIJBHDNiTybTylDEkksXYDOOORn0Pbntmrf2ZryN JAwwoJcnjafxH0A+tKUknzXuxwg37trLohYbOCKNSgZmOWzvIJzxg5OD26DPOT0xViS7QnZHwygK oOWweB0J44xjjjqKh3m7s1SjSjZL5k0bJ5Zmiutm1QB5eQSSTnn15I64PrjFWPNW6TC3sapjYRJ8 xOc+g+YA5H4j2FQ09+Xb7zSMkly82/crPewK23yW8pSELpk7iCQemck9c5AyM47VnmYCU+XbN5TE 4JyzN1xxwOSR9D7VcYtLVkTqXaaje39f0jQMt1Ja7RhXxholUKD8oweeTzuJ5P8AjRNlKwBupXUD JYMwweBjk9sY9fWhOMfhWopRnUS53Zf1p+ZYFnapb74CkiYG7D9yD6fMcYPtwD9WR2sZKG2dUjV8 soB4XPUbhz378nHFHPJ35vuDkgmlDf7y3c+RD5/mKAQOjEcHHPUnJJ/Pp24gXUGjmZoJEVtpDs24 59iR6gmlGDmtdgnVVN+7uU31GKQHy2ZZc/N6MeCegOTnB/Cq0pMisZIQVO1ssCWIzyfpk8j14reN Nx33OariIy21Xmem+Bvg/wDFX4mq8nw88Aaxq8UZIkbTtPmnhgI2l/MkUFVxkE7iBgj2r7c0T/gl 1+0rq2qeHbC3fQILTUrOOa7u7nU5lTSGaMTNFcr5JkMqAru8hJh/dZua6aWErVVeMdO55eJzXD4e fLKV32Wpf0b/AIJZfHvE1x4k1rRNPtYJWyqzT3EhRfMy4CoF3EIGUFhw/JUqRX2N8E/+CSvwmu9L utX+NHxB1uS3MbMX0qLybZJFjdjG0gguGc7goCqA3QYIbdH2wy5/FVl9x5NbPOb3aEPmz6Oh/wCC Zv7Hsd0+gr4b1a+urIeQsOqeIZ2WNPNctGXg8sDEm4b12A+Ydqncrn3v4M/sK/BPwHeya54G+E2l T3YKrFcyI2pPbbUeMhIrjzGjd1Ub22r5qtuJbGa7oYWhG0uU8mtjsXPmhKpo+2h9jaZ4Gj0C2uY5 rW1j0Q7UR7WyS2W3B3MUaAFu4U7kBGeQOijrtasvD2q6vftfsiandTLtAs/KDbECptKgbCAPlZCF w3IbMbJ0KyOJ76HTLaeHtJto57nSrK7CIGTYFjcMq7AHLviIbZCdzxquFPLfLWJqHh3xvDZahrdj plxc7JjFdi2nSSW3DeYpjUOBETtRpMh9pXkcBiFew30uTajrlnPp2nQaDbG0u2s1mvAJCrxyFRlG WNVjiPJLDc2DkFmYYFTwnoE9zqiW+pwvczkieWzdW8y6jzvL/IzM0bBTgkjPUAYJD16i06HSSeH/ AA1ouoy2VpeTxxx5uIc3pIk4GxpBIHTqCNmPlHHzE88/fxaaJ4TbWNxJCjl2uleZ4iy4fCofLVV2 5AUAkDOM8AJAr6Gt4n1iK10zSNN/tWeO6U/uP3v/AB7OCnzGVFVi2Qh3AMDgHdzUFv4X1bWNJS2s /E008yosUau2xo2QOFWNn3FgvysOBxgcdaNgZBd+H7OM2qWZ0y7vItkk99eT3OJJEkQKpVZAgGxE GwHaoOMA7ifzl/4KE6Z4e+Lnwg+JHgOXxHeQXVpbNMVktpI7Hfb+ZcJA5WON1USqAWBHMiAxBA7j KcbQZ0UpXqRfY/kThgvIJGsrh/KuI2aORDwVx1BHTt+YB70y4spknZY45TOcAkjHOCSMlsY/HH51 83KSVRqx+hUoudCMr32sKlgzMPOiCuBwVAOQBkEkYGCCOepGetSxQxOiIrfvAxwrNyCPcdeg+nFZ ynfbY2jC2jWpMVaJjOk4lXbgsAQM84GcDB6+1RRReZIZIQqOezd1IOSO4AAzkkVN7Xf4FcrbUVr5 kMyxoTE5wCGUhWyM42nufzx05pkkcYCMgfYoVSWUcEr1zt4BwcfQmrTenb8SJRjt1X3EMDeWTLtH yqSpZSQ30HQ/UehonjkKAJv3NgkEkjBwOv444HU5q/tXZk9Y2/r5kMlxvUW3LSsQ5kJwwA7Z754P +9+OYnuMwBUiYv0Lq3BGOh4wcc+/J64FaKOxi5rXTy/4Iedd3CRD7PjCgbsgYUdhxyeQDnJPFX2M rM7KoWJsAnduA6AkkDHUenrwc0pKK6ji5y+yL5W8gybkkJynBxzgliD25zjHT8am+zy/8/8AD/34 b/Coc4rR/mX7N/0itFAbm38yNVj7/wCsRTkZ+6vpz7VUGnsrxCa6UvgMDvJKjHXA59OOOh70KSTa SuEqbkk72Xa5YS2topjwc4wCeeeu7A44547fpVpP3ayABAh2nBP54BHTkYyO4/GZSlLcuEYx2/r+ uwiz28Sq0KCTIwxUcHqcEtwOO3rz1FMmuZ0QRW8YWPIOGKn2ySORnsO/BqVDX32U5u14L5kDy6gF MaysE2DgMfwB+oJ4Pr9KswR27xYLyO2cAbgN3XBwD+Hr1POKqTSXuIUYu/7xiMkbExAqZQoKCJMl 8dAOevfpz16VXiuo55tzxOW3bWO8DJySc88jkHnAyOeBRFNp9LBNxTWl0+3l8ydnYIwS3QoSMKN2 QOOBzzzzjnn6VBsab9zJGxRTnBbIJwOg9eB0/lQtNbjkuf3Wi7Gt75cR84NH9wrIM4AGO44xk/jU IjtxkyEEqAv7vY4A4x/+v1GO1RdXfIrF8rSSqO/5lizJwJjGTFG3JkZT2yeeh6ZI7g9qfLNahJJF j2y5PEZChl7gjrgcHJOOaVm5Oz/yL5oqCb/4JSE0IJ+zxuHwRxJkYx6Dpzz+nNQvdCQkPIqRbSWU And7ZyeOhOCOlaKDer1Zk6iSstE/mPaezmjjPkBmOfMIPzZyfXPvzjrilgSF4yTKyE/PyvPULnOO ADxjv+NFpRWuo04TemmhfUiKMmRFLYypTGFGO7Yw39cH8Yo5ZGPntGhkILAk+xJPpx7d8EVnZO7u aXasrJ/1/XkSvtyJbq8DyK/8ACqRk9xk8nPJPqMHNNeKwZfPYFrz+6V2jBBPLZwPTGP5Cnea+FWQ uWDd5u7/AK/q+ololrJdnzMKMEKEVhu6DBzgfj6c8dKsNMiSI8x2wq2/944QNjsCME8gd+AcDrSk pN230HFxUb7a69v+AV2vYgrmWSMK2c4TB4yRg4J5PH0zU89xFNIDnAIK5VlG7j0YkjPqfrjIxRyN Wdh+0T0T+4EDW7KGh2sxBO/ODgg/QHt04/Gq22SWVll2BAd+7PK4Hp+Qxn2460JrWVwfNZRaL0i3 0qSW5myCAGEcowSMAHAz2HvwTVdLe3ScxzzhGPC7cHByOvfPr6cHGDSUvswQ5Rt71WXzJxJpqDy8 vJIANrCMqQfQg/5xx3qmb9ctGqbm52M2A3Hrjk9OhPA704wnJvm0JlWpRS5Nfw/pkX228mEy8hjy QY87z755x7+n1qSCw1S8cSW9lcSlmWJMRFsscAAY47YA/StlTjHRHJUxDerPZfh5+zj8fvirczW3 w++EviHUmjQ72ttPmEan5gAZGVV7Ebc9mPQGvSn/AGGP2pI7yw0+8+Fl4gnQSBpLy3WOIbmQrK7S BYjuRhh2HADDK4J6IYStJXjA8+pmmGhJxlU9d/0Pqf4U/wDBK346eKtKeXxELDTNUntpmEd5Fezi zjYRNBKv2YgB3JaMby0Y86MnDEFfofSP+CQnw7tPD1zqfij41yXerR37LFHZ2NxGlzHGrCSNUeAE srFG80svy7x5Zyprsp5e9HJ2Z5dbOr3VON13f+R638If+CXf7O2heMLbUvF2l+IvE3h6GQg2cMkk dtM3VFd4VWbdtDZRWRu+V6j9FdM/YW+APhvWXt/B37OunprMSqW32QnMBkt43ZVeXIjZGnTL7/lb cHCkMg7KeFo0pJ2u+7PKr5hicRFpz5V2Wn3ns3hb4J+GfD3lwyWl5Z211axxGGS4aNbN8/vGzldx U+apKJIoUtgMSQPTrb4Yw+E7i906y1W5TQL3ZNKxVJhuAYoomdFYKq4U4GCyswyDmumxwXsc/ovw r8K6vrMqRyT3WowMb5oHysN4qDYFfbIuB5a5JQBiSxUbiGFzU/DtrcJdaPZT2U+rAp9qN1DGJwI0 MQjdFUK6EvnBBO4nJLMxZsE3uVrLwbcvpFzc2vh+1i8SQlbf7PIFh8tthXcokcMCd5YMBjO3kgYq xZW3ivRRdvoUU0eqKYfKEd2gVgT8yqSAzjdnC4OQSSeKL6WBbts6G30nWL61tZbi0DRhzLcLawb7 mV2VyzqVJDIgDsRxngk4C45zW/BEGnQTWdxeiaGaRLlEifaVMTPsy6/fIClByy4kLYZxwMSZu6Pc eGobiNDoMfmXIMBiaeREkcxrtAkPzE7ySVxjBYcZBF6x1zTLDTdesrKBTp9lHGqQrcrKzuWICLuC +ap8xgVAyAqja23k6WH5nLmGXxLcXN06NGw3tBbLbKDggZG+NAOuMK23O44wWOdOx0XVtBtrK8jd k1ZhwJ4Vwn3Qf3nXgLkkcDjk7jQ+wJ2M/XkbW7iO503Vo47pnEzQbpJJBGTkLvCnfg7OcZ46AEit eW8ksdFkulfTGuRIIliRYgsjbOGMbszgFSx3FiAzggqVXABzWvafq+vWum/ZPD0cEKBpQ0EbZWMt gs3lqQxIDudu7hSASQRVvSH1y2ubiLTJZ7HVFt41ltnkZkJDICRhAh+XH7tiCAn3jjCq97D0SbN6 80eCe0srqS+kgilInMdk7eYjB1jJCsf3pZVZgAF+Zmzxtrx74k+D/AV34H1HTtYsrqLUruSMNfFd 8dxBmXJlZpQYhGVUsEiZcoABuC0p7FU99z+Of9rDwEfhZ8dPEvhuLSZdP0W6xqVnYAK6W9vKzlNg XGRjce3LEcYr5+/diFytsvGCSwGT0yckgA5wvHU4OTzXzGKhyVZJPRs/RMsqe1wkG1dpdSZri1lj EEgZXVdq5b5Qc5AGTxznJJIJ744LvtkEJCEqrrhQWAZMlc8qow/PY9eM9K4+ST0/r/hz0+eHxfL/ AC+RTeV7eNZ9yYOQgIK4HdcjC9+f94fhTUrKCpnLSM/yqsbE8cnkehxkDPTHQitIrRysY1J2ko3/ AKf9bkd1cb5l8hMEBSWkRlZQOe3sc564AGaz44riYvHPIEV2OCyY2j6+/HPHQepraHLGOurOao6k 5+7pG/b8ywbW9Z0+0Ts0YUBcptZhjgZwTjGfYY96nZo4ZFlUNjIYBduBxkHGMZ5I9h27UuaLso6B 7OUU3U1/ApFYRFI8oKg9Mk49OevbA/WnNLBGskaR5mYElHzleO2AM9wBj1654095mfuR3WpAkp3R iX58NllVyMDHTK9Bxj6MDit+KSOLnGFOCVKk5HQ5YgEZGQOvJ+tTUVrWKoybu2v6/r+ugt4T5kkF vDmNQo3EkNxnGcgEcjPbJHboKOLn+83/AH2P8amKjbUuo583uuyLAlhhU7og+dr+UAByB8p3H5sc 8jIzu9qgju4A0Ihj3EABSTlhnOQMkgcknOOvPBGBPLKSbuNzjFpNf1/XqXJp98cf75IUPTGTlSRn OeMZH5+xrKupo0dASZtjMNoUHB3dyfvAnJ6nP5UU10S+YVJLlbbv5FmK6tYwJpbfMhxnac8DGOTn k9yP15FVorp0WVVlYg8MFAwTj2HYnrn06Zp8j1vqhOolbl0ZNLNM0EeLUJGBgO4A3c+wGfqT3x16 xRwSzLdNJOGkC/OWJYgE5PI/r+AzT0itNR+9Nq+mmzJrW3O9gFZWVmPykjj06Z5Pf+hrRW1t2Xy5 7lVCtyAwAYjoOeB1xyR6ZFRObv7quzWFNcvvuy/r7iwbPybeC68mPy3+ePlcgggfMM5X15GRwcd6 ryErNGXeMDglstwyjr/9btx61knzPqaW5I6JJaC3TksYYI3eRVYYII+v4/XnAx6GqqJL5PmCRBtc lMsoY8ZzjOR90Hvjg9etxVo2erFJ3emi/MpvMiGQXkuFIVgVAUkkdznI+9+GPepPO88Ri0hIiXBb 923Od3IB4HGcZ4xWltOboYXtLlXxen+Xl3Jri0uPKjcEbWAK7c/LgkZPA7DOOMDB61STSI57lBIw xn7yLwvIOeAMevT1PSiNVRTcRyoSqO0/6/AlOnwW+5VYbR907txz9DjH9MkUkMEkhUxu3mEhQAgA KkDPI5z68evuKOe/vMfslFqMSeBI0jkjmnRIsdYl5c5PGe38u9RSTQxKYw7JtGNgDDc3+70JH4fS kk29FoPSKV3r5f11IYQyBg675WXAIfBXuOSM9+nsfSpfNAPNsqtnnAO49+5wOfw6GrerepCvFLT5 lY3Fy8kbxlyyrgd/lHHHPB6/r2wKlTYXEjhjn5x85AH+76nHHTrTaUdtyVeT1vYld4Jdyom47Rk5 JOePXnPt757VP9rt0yrRAcbUKELtK9PqePzOeahwk9C1Vpx1S/r1JvtcdyirHlQScsitgDJxx1PX 2yevTNb2k+Hdf1e3mm0vSLy7nIbYtratISVUuQQoJ+6sj5xyIXP8DEEaTvYipiopczdkdXpvwa+N Gq2ZvtK+HOuT2oJzLBp05xz3IXBG4dP7wIr7Q+Fv/BLv4/8AxF0qDVL9IdHtZApLX7wLjcV2hVkm jllwVkV2jjZFKj5jzt7aOCqSd0rLuzyMVm1GmrKXM+yPfdS/4I0ePPDF+1h4i+MelyNx8tjpd1Mz newAUyGPgqN3ODhsbcgivf8AwZ/wSB+Ful3GjL4+8YeJdTjvJiFGn6b9jAjMhjjZQ6yGQNuRw6Pt Ideeorthlqvec9PI8irntRrlpU0n3bv/AJH2pff8E3P2T/Amj2WueEPgYPEP2KBrSG5u76S7nEUo aUzzxboo5yJZvJDyRM6hAFJVUA+n/hl+zzHY6WfCOieBLS3ijSRp2RVL/ZmbDQPuLB13IrD2ZWy3 Cr206FKn70Y7Hk18XiK2k6jZ33/CpfEeiWuhxeD3021htI57aS3ksYsSu7byJQ6mOb5fMQEg4Dbl 5VGHgXir4KfELxBcafJ/wnOsQ6pBcpJ9tXV0truOLfKwgSdoXZoeZnwoidcDZ8zLKm3dmClsrHuG o/DjRrHw8H8S6tZXN/Ipnhu4Y5pZIgxwgbcEibapjXqT+7XPQM1c+FvCGnT2l5ZT3t5LJsgS6xZx ONzsGMkkWGaQbflYlDgjkKBuF3sDvs3oQP4k8GeEb/8A4R+28ITC0gshBFFaXM+YVlIkDmRAskx3 lcsZXDfMFypGOi8N6rrGpavJoWn6VqEVhGJjPdahDcTwwEAgAROquW5XIjeTIZGcbQxB0uwvZ6M6 2+t5I4bS2ttXW5iYrOY543VI9hLbwzkryXkwFz14+ZgKo6NrWouyJql5HdaaJGcpJcmOOGNsbhv3 AqDt2kA9gA3zAU7C1PXYk8PT2FgbiygCrEIFeYrstk+YSZkTLSqXL7R8xypUY5zw1pplhouoXt/o d2J3VpC1xBAIwo8tztIR/wB3nBXaDwCeM/LSQtTZ0nxLZwW2qstj9nS2VD5kqBw0zKTtwQsiksFP HAC5YkgCq1jY+IfE94mo2ccf3Npt4JZEQoiu4ZxIwQKvIBY55xxQu42raInbRruNtVuruXOrwkNs uCzRxIqBSweMZU8bw2cKFUHduyOauU0B72C7ubq6Dr8qXNtIEjgLgsMEIheTJxluvlkLkYFAbo9A ebR9F0zSb/Vku4/scgntHltN0lzKu1gEZmKgKfnwVyA3IICKvOa3rd14hjaaWOO3nmvVkZJoY7OM quFVWCrGvTpt5A39AORdxNWMu0TWrXU59Sle3cSYeHK8RpnJhG8ALgdGDAgIQDksBKlnr/iEwSXO pJHYx4iLytGo27sYPmeXuU59cYDcqo4OoPTY07fw7o5sJ9Ts9UtY72eZYncqSdg7KpHl/MM5VjyR 16iuZl8MiPSZrrTpbj7RtUXEixEW5HmYIIGNpb5OG67gQVJVaWzHrY1pJNV8ORyIW2WUqGKWU2s6 75I1yysAzK+7AIDE4+9hBVXS9Tju57abTYUtp44yCnmfJOxXDZd2JI5B28rtDc/dDCEXPEFlounQ HV5kgjlIEkb3YSaC8bcpYLGFwoKvGSGPRXG7tXjxm8MX32kvPbTzpsbao8u1MjY4lE6+UsXmFMsz CJHZtowMKmXFs/B//grH8PfDeqad4L8eeAfCNtaQ6aJo768ithDPqiSSK8akeazOIt/yyMiF/Ok+ 8qKV/Dxdzw7obYLPgNxjOCMjb74xgjkAnNfPZjFRrc19z7nIKkp4V0+q/wCHKEmmeX5zXVwGjf5m 4IJODg+oycY/A9KiW0iiidmLxxgcYwQ4OPcHqpwvYg1xRqN7bfqe1Kgk7yevV+RbghsJAIJLkBEU nhCQSfTK8ZznJz1HpTmlgRJIEk3Dp1XAI68nJPQfU89hUPnbs0X+7UL31/r+v6uUpAOdqFpjgB5A M9c44z7EnIOcr9Wyed5hiBQsW2tyDgjg9Tjr3OPTtWitpcxfNdtfj1I0e5+XzIwpPzLvYhsg5PzA gg5xk46/jVRhK4kwjSEZ+8Cvy55O4nPYHGAeo7VpHlT0MZ8+l1r2/wA/8yw0tvLAy4KsTygBKDH0 59856EDFQSSLcJuM4zgI20hCcZxj5eT33c8jnrVJSW6Ik4vZ7r+tQit3ZIjGDvUmQsqdMDqWx19A eOT072MvDJsLq3JG5gw3cn5vUkA+n4Um1J2ZUYyirr/gDwW8x5QP3YDHOSAvXGQ2QTxnHrTPtcn/ AD0f/vhf/ianliy+acdn/XzuD2tnCrZn8xwpyC5AB9OTknkc9ufTNTj7OjfZ4rdQyqXBcoqsAcgb geD3yD2GKluct3ZBywjold97/wBWK86apeqJU2xiP92AuFKjGMkHj2yM42+9OXT1jjYzOVY5XCkM c4A5z9fw7DIo54QShDcPZTnJzqOy8v8AId9iaQkY2k5JfcNoAzycemAfamw2EkRIEzLJtyFUkL7Z 79M/kPUUe06blKjtLb+vyHtBbQ8vtcqOkkvCk85wMHp/9fkYq0HtIiAk6LIcMgCAAjr1POfp67s9 al88lt+hUfZwdm1f72PiW1Kh5VJEkZGxTwCDkZHcZ7e468VX82xjCxxW6KSoZj98sR9e2CeOOpOS QKlc7bV9CpezspNa9yv9qvZ7p2iWbyDgqWkAwcj7vHXOO3YHpkVJHHLO4Ny5baBhGY4OSeOc85JO PrnHFaPkgtNzOPPJ3ktL9f62HNsi8y2EybpAM5UYBOSDvYd8+voT04SC3hjghKk/ayeN7YUAZ65O CScYI+uetK7t6lKMb3b1X5/1+oW8UqxtPE+cEknkNjIyA3OCQBg47elLB/o++UOFCELnG4ocYA+n 8/TgUn711YaShaV/P+u5Nd6k1zsZk3OeSGHytzxgryeo9eee5qK4vDGg2Aqr5HAA254PTnHJ7dci iNKySuEqt+aVv6/r5lFbi8LjaVjUA5yzOEbrxkZPfP44NWv9Ka3jhkxJuO4DzN+0dWG1c46ZOeen YmtJKC2Moe0fxbdr/wBX1K5EbMUk6o3I4O3nHIGfTGMe3pVv90iqpjPkjO4SZAyOo4xjkZPHt2qX zaJFxcFdsp+fGGCpvViM/L/CMnggDknIPB9KU3sQiSAWDMHUHDM2VJHYA+vPvjHHStPZyl1sYzrw h0uMGm666o8ek3BB27dsDnfu6Dgc59O44r1PSv2f/jnr1tY3Wn/CnxBLbXQAhnOmXHlsMjkMVwB0 +bpjJzxx0wouVuRXZ5tbGRp39rJL52Pp/wCFf/BOb9qH4la6nhuy8CJbS3S5jvNTuoEgLLtLqWV2 dCFydwA+6FI2yZH6J2H/AARMtPC9o+t+Ofinq1/bEvFJY6LptrA1vIScBp5Zpspt2g5hRgXA2jGa 66eBcre0dl+J5WIzlRusOuZ93e3/AAT6n+D/APwTw/Zf0a90a/0v4Z6pqkUaxWV1PqjTBHuvLZXf 9/mI5YhvlQIQAP3bivtXQ/gDrfwz8dtr3hjS1uNK+2OVmmPm/aosjzI5HmlkQSo4QkpudjOWZsbW PoU6NOkuWnE8StiquIfNWlfyO+sfhbdjWD/amrW6aWjrJcRmJjHJLk5AG47ih4J2OOSBnPPq1xo/ 9i28un393Hbw3AVithbWyRECMqxBQD+EtuKHkjGMtWz1ObW97FKLQvB032XTZrNp7d1khgN/dPA0 m5SAQ0TpIh2tuwJM5BOTji74e0nwno1vqkXh68trzSIhiSCG4mlks3dV2rJHIdqKypuU9GUltzMD kemgt9WVIJNc14JbRPaGKEESkK6BiJWYOyybQ2VZCCoxgAAd672MazZfYtUgukSNmCxxectvPHb4 4ZQG8sswcHZubG7hzhtowVrnO3/h/wARa9dX15ZXbQxQoywLHlWmIP3gCMjDBnCnGMgclqbcfCrR J9BmuLjx3qlnfE/OivKko2Z2kSIFcYZmGdoOBwoLkAfoCb6Hn+neEZLmC2tNX1G9v2imkmup76ZY jIjsD8yoFZF2kZdnyxZiCCMV6B4Si8FeHfsSy6UI9dC+Us0U8hluZBsy/lGXcNy99oDMxA2hTTvo GrZjnWJ/E+v3FvpFv9ohb5BbhLdRJtygcOQrImZF+UnA2r2T5ez1Se8TS9CtNIjuNlmy3NsdxgW0 md1dj12kKSw64DdD97K0THuc/rjRPOFnkkvndUluZjZkra8PuTBLfL5gSNWJVi0gBAALLozaf4au tMNspsrdp0YSrcCMyIF2pvjjMjNkndxggNkgkDgC3UxJtP8ADfhrR7OHTokNum+eNpRKPMDcLu/g J43KwGPmAzjin6VrUHhTU577T7V0twrTXcc0gjxIJEycgh1HzDkbW4diSRin0C12R2vii08Q28Uf 21YJLqcBY5hsaaIRbozG5ChRjavJzyOq5Av3Wl+NNIlK6bdW5mDo0MU5ZV2nDFcSZjVMYbncSTHg NlsLyDYowt4khin1bWvGtlMZVWA20X2hIJHKszgvlcYIGPfcCABhtK1sYFtra8u7yynhVgYk+37V VnOR8qMkpOFHDbtvzE9c0gt2MsXMzPaFwXknQxmJCTIrbhuDK2dzZAI3HHOAN3I17ZZrS1m1if5w qlvIRvLneJ8MJFcKVbBwMliRzhQOabegt2Zc+j+K7g3ep3DC2s492EuHAd8Y+UYI3nJJDdDkf3hW 9p1pcm30VrxZwUd3WKZZAjFggDrsGWJ2gEDtHndyMGgFWXwZfapc2VlftHayxv5c15HYyhLZnZeH WNZZs5JTBLZAHyhgarweGBZWapq+q3s0emgIoFuTsiYlyfnKGMYbeCVwSR8vOStNh6s07jUnmv5t XiuJV07YMxHZO8O8kbeBksMAnYoxyMBeKuDwnJcwT+JLCwX7MArRxoHAjkbG1VPR/lwxHBzuyAAN xsHU5bVprYPBN4pnfECiOKONQqwBsyY2sMldrnuoywI4DZ4200bQ4rPVIorOS70d/wBxMsMcLSKq qw5HzOic5DHaPlOdxFJjWtz4f/aq+FmkfFbwn4lstP8ADlrCL2NorB2sHHmTYDD57d4SuAVcxwqq bXVdm04r+Urxj4a1XwH4x8SeDdTiYatpF7LZ3UBWQNDLGSHQ7gjHa2VJ6HbxwRnxs1ppxjM+s4ax Eo1J0u5ywnE0bRgYKnHKjKLtPQDPHY57e4qpO8D/AGwzqquF4EnBXAzhRnAJwP6da8VJp6H10pRc by2/r+vuKrrbLLttwuGCFDuBbPoORj8u3ABqnIFfygsmyQbRuWQKMfdPb3/mfetouV7s5pqLTSdl 0HpHclCuWJU7FA+Xb83QZ6c56dCM981TuI76FhFlgGU+btDYKjJUjceRnHbueKuMoN2ZnOFXl5kP jR3EIlyxG5jwfmPoByPToBkH2qGGOW4ZSI28wAA7QSTngZ4wM9gO/tiquldmbjJ2Xf8A4BsxWiON qtG8gB3PhSqdSeTncOVPOM7iPeqZSCNVMsTsRw/7vaB6Ac857ngjis1JybsayiopNq/ov1HJvDRk RBkOGZ8FiB15+YgZOMjHFVprg7VjZtrtlsK3ykAcD17D6D9dEk2ZSk4rXQeZi6y7929flO3AwcAA ZOcc8Z74HSqf73/nlL/3/X/CnaK3/ITlOWq1+aX5mokWNkWCXD4RQdqhuO3TsAehHfnGVa3QNMEk /eKcr8oweR3GcDqc5I4ycg1i5O+puoLZf0y3FLsBFxH8oyGKj5TwBx6k479/rVRZp2cCBcMBsAUZ zgDqvToBz3wSec0klrfYqUnpbf8Ar7yd7gAh5pYo0J4LICxI6EYHGcdfXk96z3vLaJGNpKcsAMLu OTgkckcjrxzz+FVCDey0M51Un7z16f0imltczxtJKgQjbguV46ccnryPr+GK1hp5bY5H7x+AIwoL knp6dzwAPbANVOaWkf8AgCpUm05S0+65PHbSF3NxvYsuPnXdwQcnnnrx+nY00XUPmM4sjGFbJwwB bnPb65/AdcGsviej0N7ezSvHXuTyanqVzuhtYdtuSSqMBtPGBwByeevvgdaozWnlzSW1zcr56jAR xgsccjDHAPPGMk4wKcFGHux1ZNRzmuabtHzM6ORp5J/3ZBYgN5YJ3HPOA3c4B6/4DRjt3e3wElwG 2lpAAqDIyepA5zxnvjuK0naOlzOmpT1t/l/X9XJXiu5AWmk/dEngx4UMOoHT9MnAx7VFDBGlxJMX fg5ADFeOq7+vH3c89O+ahSSVoo05G/em/wBCR3to5EERwxz2IYDGAMkYwB7e2elZ9w9jFMhjIGAp YkDIPQjjkd+4JH5VcIzf3GdSdJLyuQPPv8wiIsr4JIXJU985ORjqcZ7Hua0NNsNV8RailhpNndXm ozuwSC3RpZZiASQIxliev68c1tGnLpqctTEQV29P6/rc+pfD/wCwr+1V4s07U9Wg+FV5ZaXZCFpG 1a5s9NaZZVkePyFupFe5G2N8+UHCnaGILLn3X4S/8Eq/2pvig066xplnoFgrARS6ldwuLhyN2AIn ITCrIxLsv+rJAOGK9kMFUk0nGy7njVs2owTanzPsv6t+J92/D3/gkT8MdH0nS9O+KvjC/vvEgJnd NLgNmLmOVYCm2e581HhCuXjc20bEiUEsNoT6k+F//BLL4HeE2F3efCTUdYnlljNo+qyvqAWF1UKs FuG8ogkFg0ibvu7WGNrd1PCU4WctTyMRmWIqXUXyp/f959n+Fv2T/h94K8yXwfoGi6LfxSzvcGy8 NQAO0WTIqGH+HGWfau3G3oVBHpNx+zf4HSUTSgam8kounlml8o+ZFkIyFmwEaRTyG+8JCCcKK6ox jFWS0PNnUnOV5O77s9Ft9O8GaDYWcEfhfM6NuAZ4QkE2eqkgyHsQxYEYwc7cnUv5dbfUp5rPwsWs J0hl2pa5eFXwA++JdyKwOC2RxjkjBF+ZG2hv3nhzVnYR6NoCtPNGivIqIkcQ2Nk/OmZGIJPQspUb eBkc1qEOt6ei266u7QXB2PJczefJ5ro6lUDnaNxOdiEHLFsE5Yr1DQ6V4tW8H+HpNOtpoJr8OssD mDZcIxHOPlw+GweWzxhQdxrn9K0Kxn82LyXa5H8XkSiEk/KAU3ZXLADZuIOSCxwRR0uJvQ9NtfDd loVlfpqV8ot54FaDDXDKJWQbgwdGc7gWA6D5W+YD5mwr3S/Cc9xqksd7cXGpiVw0fkpELg5AeQzS kMSzZbYYs/dBUYICAtnTRpOkxou+6naKO5khktZFZudqNuPAHJAb5dwUd/lqppunT+Rava6PAS9u /nGZEZAzDaOoADANuB3ZG7IwwxTvcWyKFvFf2tzbSQxq0TqUXZLKpTByTEOQSVxk5PMh+XIU1jap b+KNOuTEJkUzApBcSlJ4lSQEMzhQxBXDcHByoZSpGKOo76Eujp9gsJdG1XxBZG6heGWeVLlYY7pn BACwuWVh1BCkr8uSqAcMuPFmgWd+Ym0OzvJvsr2ayzzNucHO0AfKynAwxLuCMjC4UUrFHN6B408H xQastz4FeTW1jJgVoNzzqVbYIwpU+X904xuPyY2qzGt9fGgZ57eC0lXzGKi4VoZfLUlVI+6PmIDZ G8ZypyOrVuwa0sWdY8MW8179q026t7zSWSSF2dRDGgdQgYohIBAIYDJAbB2qM1yOn+B9W8N3t19t 8S7oRfLLbwlFlTcAwWM7X2IqruGXLYWPcCPmBXmNdkeh+CfDWl6fcaj9u1OCbS7m383/AEgFGEvm AMqjmWKQfN/yydWy2EYlWXN18NaTXdhpsmn/AGKynkiWcB2LR7mciNzu+6x45Y5c4ZgAQt7iempk eRNbX0kmpeH76ysWV1+0JZm3DSOnmHLKFBUhxnkLtZR0IBhS18WyahZW+k6C03hYFFbzEeMkIPNZ isnAwuWDbhgMDyBktvULK25nXnhq41XUdQhECwadPucLYbZF82I5MkgVWWNERjnapOC2OrGuUubr wxGsNhLqpl1C3jaR3nxFFOMBiqqN+XU7sfd3KoAG7Ck6j6HWeG/ipo9noUV3faTaJdqT5TGAmaZR u3hiSRsO5RluDtQZwuRuweKLPxe0i2Vm8dtKPLhjuLlpZVAALln2LhMZY8EDOcnBpLcGtLjp9An0 i1g1KyneG+85Q0PmwTwyKf4dods4I3EsxBAAK85PNN4g1G0uLSRpGeKOMvAwTKrk8lVTI527Rk8E dtvDeovJm5FqupW0U17PDFc7cKyMGy6hjIytlchcRg5IBOeTxgM1TxFfXG83No4jxIU/cjJDn5SS VD8YBG7cTnr1pAbOkWdxfR28ctqsfmKBCpjb962W/hBCxk52gAHkKAOSao3tzLZwzwPJc2RGYkUM ThMMDuU5+blFODzjH0fUXocpHBNNqGoy6vqEL2LN5plJMSq2HdtkcQIUZ3YGwLyPu5xTdY1Pwf4o vPtOpC2W4ESNF5FrIXdhtDysE8sNkqpUbwF7jk4T3KR4rr2rTanAPCWmeHVhNvBcSvegJbDZj7zz 3IQRoikjBkC7mJHzbTX82X/BQrwTp3h74gaXrlqkdhLeAgxQ6ckMF8qsfNnaTJcv5jLkMhXLnYVA 2152YxU6EvI9vJJypY2m07X0+8/OK63yTTPNKhj3Mdh/hxnptOMdDzxkbRxVVLOwSRhOrsmzeoDM uccEZ25AAyT6gDn0+dUpJWgrH306cW+aq7jjIgtRBDaKskbZ+/ISM9WOflyfl569MVUCX26FkaKJ CRtbYgDSDpyfbk44Gce9XGyvzO7/AK7ESUnb2dkl+H3/APDFdptnnbbx/taOR8iuGxjJwcDA7dgA oPpUN2ySztcTZlbgKxYZOMAdBgcD/Oa0jFpppWOeUlKLV7/56jBeDZw/zY24QBeezMSf8On1qMzS s6hY8SkdduDxwcYIHb17Zq1BLVmbqOSstf69RFN7M7rJN5agkeZv4Qc5yACSPZc96jSGdXljS68y FeQQCAQMdAxBxg9gDj6VfuLRR0MWqrak528i0lvM6xxW4kYt9/cwPJx6DgZI59QKY6Myu5j+bOWb H3/XHY4H9QKXMkNQfr/X9WJ4re0ijjDQ7UycKcAjgEFiAcjufbnvxLssv79r/wB/G/8AiKmc53/y /wCHRrCnTtay+f8AwzJEfdtd2zHv2iXACn1JyMHjH9317VIxjSK2ktiJ7mRxGyjgNycqwzznAOR6 4zg8Yta26fkbc2mu/TzKZlup2CXQTbuDEcAkZGRnofTPX5cfXRE0Ub+XlXjAAdslc9Tkk5655Ckg 8U5JWtEUHJy5p7/1/VzOubHcWMiLuVugIcOoznBzjOSPz+lTxC1W3R1hxz8xfIGMYI44JOD09Bzw aHJuKUXoChGM25LV/wBblYPCzST+au5cEF+P8QOgz/8ArrTSW38uEOzPdYONoztwfTJ2+nA4yKJK Wmg4ShrroxJpZ3gnjW32ylvlMhYnkZIyBjrt5OD83AzxWcq3rwrFJcFWjyV8tsAHgZ49ge46jj1I ezitdfyHUjVk1bRfj/X9ela3t5I5GlWdxOTkfPjaOnAzxwcD8RnOK2Vs4ZfMYRfv2LO4Z9o+pzzj qeCDyScYqpz1uiKVJWalr136lYXSWaSRspYhcAhtoBPUc9TgkdcdfWqLaq0akKn71lHyBOFJIKhc Ht7Ac59aqNJz1vuZ1cSqSUbbf16mlp6arqNxb2VlpUs108u1FSJnZjnG0L3zkDt1Ga9x0H9mL9o3 xq80uh/BnxNJbRRLM0iaFdrGikqqlpWQImSygEty745zW0MNKTvFNnHWzGnCPLUko377nrWl/wDB OX9q/V7bSdQ/4Vw1tbTzmOUXt9ZI0CZRTI0STNMY8SZL7ADtdVLOhA/Q3wH/AMEP7uy0/RLv4m/F i5a9vbGSefStA0Uy3Gk3UTMfJuzcOkaq6j5XVy2cb0TKg99LBzatPRHi4nNqfNej7z/A9P0H/gl/ +za66H4ePhnXdQ8RzwDbe3+sG1iu13SkOIEii27s7FfzSrG3RVDOz7v1m+AX7IfwC+D3w81Dwz8O fhtZeHfFE1nLCPETRC9ureVsjzC00i/ayGwQrTKBsBXhSH76eHhSSstTxcRja2Ik1N+72X9XPeLr 4c+FNakXVtfY6hNLDsMSykqwBGFDH5i/yf6xSBlssdrMKmuv+Ed8ENHrNrpfkXEij7OgIl+ztEx6 SOQ6SFkjbeMuQxO7OQd1fY43qZln421HxBe+HbqLS4zqkTJGkkcBj3kEKgUrhgSvyFt5Y84IyRXp us2MwtfNtdPkWfcIJIby+aOSO4VCFkLJMGXbufBPyLjJP3jRboO+pwaeEpdXudQivbvybUy5+zQy Fo7lmbOE4ztwR8zEkkZZq9JfT9G0Xwy0chud0Y8iZ7bzIkALjdmQHyuFVUZOTlye3Le1iU9TGj0e DRvs1tolvHcxO6wyTy3CzpMmd4PkeuFjfC5VSQDgkgdk2i3HhxpmntoAJYZjBFKyyNgjGGjc5RnG 7aA29TgjH3iugHNveyFWtTtt4FmIN48MiIzMyL90KWKBlYjCFgGckdcdH/Z8kdotrfGSWaJWLM7k KqqxH7mNtm5Szh125BJJIABahu2gWMzV4dVXVJNL1HUsER5DJGkccbOxJCBSdq+4OMEr8oAUVX0y bSraO4mvUAlTZItoBNGoUM6x+WVDKu9Y9xGd2DhvmLKPaw1vcjvNU0q9u5raKyaX7TGsu+WIowlX G9Y9krSRIWDZDFSqgbcAgVWGiQRXEJklkubYzlkUttlX7pQOruTvLbiCAeRlGO7JXqD3OsN9d6Zd E2sRglYm5xG4kZYwWdV3KWx+6CkuVJUjnGCKqQ3Ouq2+706f+yirK8tvEGzI23CujL0ycHOBuXjP ODSxO5Wvoteg1KC0k0aGOxQh44bvT0RgxwrNiRyGXKjgjbkEYwSKueJtDe9Iu5LWbTr+JSEez/fB XIY7wx/u5X724gjIYgcGg7nn+reGNPSG6uJ/G95BcLGIbSExtCypuVnMiqVGeXKvsJILgBC28t8J ab4b0+4ivoZrRtQgt5J5XaaNiuxWZjGpw6/u8hlywYFgSchA+gavYtXF3paag4s7KBIZ4/LfyI5Z Zdg3FlwjruA35C5wdx+Y/Nnm9MS20rxKbHVdQ+3WxK3D3CyeSky7DIsbAjfl1dcPjI3NnCqCHshr XQ6a91W+S1j0jw+7PprzidCZnit90YcjLHB3EbVDnYw4GOc1VvtD1LUYH1DVPFD3MZkMkZmWVhCW VWBEmCXyXfHsoYg0umo9nocvceHGsb61W+klvYpZmmH78LGh7E8DazBFBBGcBG3Z4HY+G73S4pRp eg6XJHP5fliSS5Dl9hXLA7QwIPOO+49mAB0Bu7NS41tpdS01YPD12nntsluY/MtQ4diFCnjBDKeQ CoIxtPfltc8MXF7f3CWLyKsim4hM8k1xJChaQ43xtGmDtZcFFJw3QkGjpcR5bqOtpHqEVqDbw6ar yGWKKR0kUGKVXQuI2J4VcBjuB3BScnd43c+LNIsXe1v7tLSF1Miys/ySZfadzSMVbAVgABwcYwaR e9rjbj4m6RfyTiy1GM6bcvkX8UkDGdyMRtIU3KGV2Z5FJDZVhncARs+EPFMyI0MN9cM+1ZX8jayq CrEs7bsk8oOSSBvA5GKV9Asuh7zqNzptoug2dt4nnS8KGSS3kEcaq25kxvY4kB2EneAMYT5stt7D QbqUPKbXWvJsTH5ssbpFIZcho8FXG0OclQexzhhxh6E6sjuL/TLjUU1K3sZYrRVWNXTKxM6AqhAK fMwAYdSchjuzTrKPT7m9j0uC8iRZJUnCy2yq0ifPuBcsjjByoXgHqBkUdAtqNkkwzLHPaJYkrvVU kt/s5C4Ub2JEgDHc2Au4YySRuqDSvDMs1odQl1S2MkkjYEksYkSPgKXhUM6jkYbBGSOTxRqtw8ki pNoFlqUzWV7qSXEG/YV86EeaWZ2By7pGF3kZ5IBVn3YxWa94Em1SC1toDbiZ0knawWBWUhgCpVjw RGAUG3OWXGM0PQN2cF45tNM/sa1k0i3hkWSVrlmSBpRb7lQMxUxxjB24EQfBCNuXYyE/mH+2x8EI /iX8FtRtrS71GfxvaxzahI0lks0DqgZYgzRhmtCBLOAQD8x3sQpG7GtDmhKPdHVhqrpVoTX2Wmfz DXkrwXTQXJUSxSCOUbSRkHuefz7kBu+aa1xdKpV1Vc8nCAq2Oc4z6ZOPQ9MV8vKnyu0j9Kp1nOHN Dql0KBaWWSMmRmJGQofaOB1GcgcADPU4BqJ4Gjlkbe+4nJKsrErwep4zzz15GPaqTS0SM5RlL3m/ y/JiSAEysMMm7Clk4wBnA28EAdeehwDxUm2KNkY2qPPjJVww/A4K4IyAeT2+tNt97E2Vnpck+0XC oJmtnEO7a3L4PBxuwRg4GeD24qm7McIzgSjDKdoBOccZJ3dCByeBQlZ3WopPW0lb/g+pbEch2rI5 eYHkKRuBODz1yfXJ4I5waQLcNjLHIGP3anO3JJzzk9f5jtRddiuVrW/r/wAAsIu2PeUADAqDu6Z4 HIGTxkdMc59MRTSx3FugaYB8uAuwKrj+HnGWIJb9ADzgCbvdK5LStZ6f1/XmS3CorxSFnAc4Z3BX PqVGSdoOee+PbFL5Nr/0Ek/76k/+JpXdtrjajd3lYzWtZX3rAQ+9zuOMAnnOOhIJA6DqPrSx2xSN ZWfLBypRhkMfwPvgjp2Gc1TkrcvUnkd+a+nQiubmMbcO74ALbsjBzyCOuAe57D14E9u+xo3jgkYb GGw7l6ZwckfQdOPTmhxtDXQSmnU0TbX9fItx3GpywmFWVIySN6plgTjIGeuBgY5wCe5rONqyJITK WAUkM2PmPHGD3wfTI6/RR5Y6QRU/aTSc3t0RbiggD/vFKNkMVHAJwSO/1x7n3FWgPKcPCh2FS2G6 qTkYH0Ax0478gVDbe+xrGKja25bSRkGYyQrsoA3FsDqSBtwe3p/e74pBd2io/wBocbgygICQpGCO QOoz2xk8jPIqFBt6blyrQjH3tvU6Dwx4K8W+OLyK18HeHpLt4wvmSKFWKFWdVV5ZHIjjUMwBd2Vc YJxgmvf9K/Ym/ai1nT/D+q2Hwyu10/VEUWk73FqFEjMy7SPNLpIuMmNlWQblbZh0LdtHCVKiuo3P IxWaUaDtKdvT0P00/Zq/4JDeDpWm1H9pfx+6XsMyPHomgv5iTJGWE6Syj55QRtbMJViquEDsyhf0 zsP+CY37OHg3WtGHg74D2V/bskc7tr1rPKfKG08rcMMkgqzHllxncuCB7NHCU6f8RXf4HymLzKvi JN03yx6d/mz6k8K/s2/DrwLdHxPofg6zfXY/LggjmtY40YKoHkmUZLIkZWONg5ClW6DAHfah8IRq Wqm3s7230nQZLhJ4rS3EhuEJVUlHmsxOwuqhoxDsGBsyM112Ubcq0PN5nK7k7swrX9nSXSby4lvP FlyukMdpS3ijuVnRdzmRGaeNt687gqOgCEndtG3s9D8MeGvD801vDHPfhoMsznbHNGuSeI8KAWzJ 5eDtYk5BFPdg20jr9CtPDR86ez0SNNXlhBW42QlwAC2xUO1c9CXbHGcg55s6lo2pXet61qD3ltBp 9tK0Nn9oJieQIUwyKij7OcMrEEDG4LkhWNF9SLaFmCw1PQ5NMljfyNFaFQXO396Gw2zBO4DODuxw XJHXnb1TTNBk1OzvHsrc2iETwtEXmPmFR8khd9uNyNKiOhwRnAJo31DZGpf3VjpEs9zqGjy24iDO ltbyRscggfuoEj2KM5UbcENuA6jHE3OtXeowzNe6H9miA/ds8LKcYVXVvuj5WBA3LlQdv3uCIGi1 pulXVvqJvmEbFWZ0jMoUw7R1GwhmAB3bsrypwck1u674T0/VTDBp8pghmeMTSCFY0LhuGUoDLIAR uAfe3zHYCAWI97gnoy/ZeH9L8NZiN1N8jBI3vjuj+UbCPlAKgDYMZ3DAxxitC71aOCaCN9NjPmBo ldTIxZS7fN8zMOWyMoqZB6cmkBUv76G+1W1lvShvYkdo5bdmCygDAJWUZ3OUDAFRycnGSax7+KW5 1FJNcuHWGBPMhjlhd4jGpPTyQG5ZiuEGFyx4AoQMzltLfVLaDU5xH/Z6h4zlpFZG+8PM3DIz0Xkk FOVHe54n8OSzPJeC9H72FXmaWFi7yOFkVhI8iIBJ1yiA/JnJGSz6htqFnp1k2k6fezQmRvLZpAVR sqxYCR23ZXLKVKgAAKvJLirGlad4WsJrk6LpNu88iiNVjLlIE24Ztu7I3EFj75+X59pQtWY17430 y2up1kurZBcKTLG7iNZV3jPyYKcGPOBkAgZwQQN7UPFUdykcWiyiOOZESYSuTHuIKc72PHzOAScr 97eM4BYdranPnVvEUr2MltGzzZKRrezKiMiso3mJ4yxRQsnyru3twgJ+U9hZ+JtQ1iCW7vbeQ3Df NcMIWbLAZOeH6lcCVsDAfamRigeljFi8KWt888t1qrx20sfmSK0bFUVe20bWB5BGxmHRckNmuHaH wvpUt09lHJc3RA3STyJJBFhmC7Y3TOcMvOcqN7c9AxJtanRSeOPDmgCaK3082qyMS/kRtMzCT5nj 3x8CM7mBIG5j937xAi1+5udfEB0awWa3dHjZZY5EcuCdzrhR2KMVyBls7Tkkmz1Hurs4a20GWS6u bVpoI7aIiYT7pk+0EF1wuFYqMFcblX5jtK4AJ9H1iw1630uOR9WsYkSGOGWDMUb+XtCrvWMck71+ 8QeC/UsxTGjktTtZLJrW51WRWhUpG4jlbMIXB2uxXAYELg56FRk5NWb3VtHMNm8KwGcM8ZnKgvly SNzZ3OxxJncWyCemCAbgu6KepprdsA1pqEhEixoFAkKTFQrAZDYBJw3PBJXHaqd1qHinTrK+m1HU BY2cEXltJHFhFkUBjukchQdgb5uSNzcHGA2I+SNR8aDTp9Ui0a4El2zO7XzoJEkBIDiNXzzg49Wy Qco2a8m1m1nvftAk3Sqqs7tESXmOwfMj7MAHZgHoMDJ+7TS1uyZO+h49cNq3hd5rnRIrk2z3G6Wx dtkbAgK7qxHysFBTeFPHBBHT0vw98Rb/AOx30R1SW3vYbZsx3JUCMsBHwjOoYFHADKHOAykBQSIk rM0hJWsz1n4Wv/at89zeaspgERuZYUjaQzBQGbKjbnaCZCWKriNjzgA/Ql1418NyXk9jpPl3unoQ I5I18pWBGMYQiMAAqDjkkcnuRDdzvvDc+o6sYUudPtTpsOAzEKu88uB9/wBF2liDjI3HgVp6x4k0 /SP+JfZRSPdTwmRXkCZgGd8ewSAsnzbWGCco3GQ+afkSzn7Cx/tCGF7gq1rkCJUXb5koJJCkAjjP TIOOvOMaVxFZaMiSWk8kkhZUeESozP0yf4lwDgZJz04x0H2BbmLpVnLd3KpYeD7gRpsmmnhhmaMQ hSGfLEgElGwSMbg3IxitDxTeXVnNNH/ZssdzOQAr7tvlHcUO0Bdp+8ShQdfu5LU9W7Bpa9zkx8Pb edL3U21d40LMGczHYhO9XhYFB8zqOxA2nj0Hk/i3wz4A/s3XtP1Lxbuurk/JY20cRijUsJSE8zzA IwVTA3lmICfNkgS1c0g2fyU/tj/CVvg78b9e0v8A0eXTdQkOqWVxBjZNDIVIjddx2Sp91xxwUO1c 5Py1LbywvaiCSVZ2UPwnIOOPX3AH+yc+lfL4pcmIknsfo2Vy9rgaclo1+ZUaJfP3QlpeGweNzfQA ntnv0B54FJDD55PnShYyWI2RjBbDbc5YehAPbG7FY3aV7a9v6/yOtxd/J9e+3n+pLHBJGrWz3LRr vGV53Iw7ZzjjHQ/xE5HAIryQIxPm7I2jBCqWwNu5cAZ7fNjg++MU09dEJx93V/8AAIfIVpH2u5lD nacDqCOjA5yMg8A8j0qFrcHBMgBbA27CQ3rye3f3zjsatPujFwu9H/X+XmOtwVKZZmC8kPHHznr1 OBgfQ5x16i7JJOgM3nH5xubf5bKx6tkZIzznGOOwGaUrN6r8xx5lF2f5EMcsT+TtEcYwGLOflPIH AUEggE9s4yevFTS20UnO2Rxgqflb5ccgZOBn8OMcnnFDcosaUZKzXyX6jI4WijTyLAMzLuUtgMTk LwAPm+n49+ZPK1f/AKBzf9+G/wDiaHKD1lMlqrHSnT0/rsjOuogSUurlXcqNu1xgHPcsT0yfUfnx QXyYwgWN5do4OS5IGDjDccEe49RWkW7aaIxmrT973n5dfl/mT6esZ3mOGMADJdwMjcMdD0xyc44x nIrQWIJnykUJgbeuVOTjkdyeambtJq5rSS5U0i1GPJmifJcOMNtxlsHg8j8cc9jg4FV/MxG7DasZ 2jOCSR6Zzgc8n1PI4zWa1dzZpxW/z+QhmjSXDXEkkwZSokDbmXBxxnpjGBz27dPXPgd8HfH3x08e aT4Q8CeD73V3V4pL2OwkSExwGRA0kk8gaKEfNgSSDAJXg4wdqdGdRpJas4sRiqVCDcpaLq9z9NfC 3/BIPx1HI03xS+IVvbGOXzJLbQ0e5kaA7v3vmOqrknHKq65GCcnav1v8Kf8Agnh8AvCHii/s9E+H uq+OLm1eRpfthsroBGEe39ysKxkK23PLYLndtXcB7VHAQgk6ju+3T/gnyWKzmrVk40lyrv1/4B+k Xgv4Na1YWWn6drn9laH8NbXfDBpGgWT2W23MhmSbyVuZY45mVlR/9UnRkjXcFT6D8I+AfCFxdXtv p2haxe+HrOH7QXubq0xawrlYyRlHGZvNBaNMqHCkYJY9sU4rTY8ib55HoGkavpOnPcWGk+HksJSP L/cQoTMgP3TIclmyG5U4JOQV2kH0Pwfc6zNrkuqTC5ZYomuLVUgLmzt/mcsxRQuOBzjavmFgAw4u SvqzNaaGnqNxqU7siwhtOLmN3kk+dn3LuIjPU7QuMYU5AyfmrKvNG1Hy9R1zXL9mjlaNQ1lEjtuL 5Xkg7VwGG4BSS23GNwpdA6lhrvS5LUWNqsrxwxmL7VdrCZHdQisy7YgwjGCqIc5wSCFwtdDZaXbx 2FpcOkt1NLK0cG1CzzFuWBC4yMMflB5L4B60thvV2OJtY2tNaTRdAhS2aS4ZI7gweVI0xKhgsjD5 Dn5WUOB0BPG6kn07+z5Z7iexWSSSNRImSJ5lBAYZJbuWx5ndRxkhafkBs6todwNFiC3dyuil1+0W dtDIqRNy2WcExq2UfnHQE88itT+xdFsrHT0gAi1MRyNJcLeSsQ4yVdwVCq+AfkDHBQEcnBXQLXZy n9t6VDqdtNYWsV9DAixW/wBq8zB4Y5kAK/N7g4AX7xIrF0TVLi1B1JkWO0iHkvjB3F84zk9TsOOn QZPTLtYHqbOsXn2po5LO1nFt9h3yN9llJkd3JXGNysTGuDwo+RgM7eb1tZa3YSWL2cknkTIS0SRb kjULkswP3wFc/MV5wdrcZo6WF1F1QJM8+n6mWNz5x8wBEKhQT0G0YPGByDk8AcVs6RdWVlNNHbw+ Vp6wCbyJjKCycgKTGd2OA672Izt7UAT2+vC0k2aPptnZq+d0k1uhjzgNuYEBcnkdOuTgEnOZqWpy 69eWPC3MjOpla1tkjK4z22j5tg5ZsFfoOUHkLNY2Vtvb7SyWGDGyRSiIXkQx5gZt38XHy4Y9sVgx aVrMdyl1psDvFITBHHgLLvO1G8tQuM7ywK4JI+U8ZBafcOpDq2owTy3dtPdwwWhwjRwwrGIkUHaV UkjPA3KGA5HfmmaPocFxqbz6NqqtCsamRnJt4YtiIN2+VwfN5LYGMFGZSAOBKyFvsVdUg8IHUrq9 jiglECb3u4xHPCu8Z2ZQMjucMBzjIDHaASuNq2ozTXN7p2i/YzDYzBHVG8twCQHRQdvzk7eJFIBz 3bkHY6W/1O9s1gmiiztJVmnvG3uoGyNimBgAoTt25AA4ORnkdPi17UWbWL20N7ysq209wsUQhByx G4K68gqXAA3HjkDIu4GTqWsXdhFdaTqF9eiCOMi0FrcSRTBOH+fypQrrtLtlUznHzBRsrb0a78MT agtqba8McsjQlgEkaWQ7UJ2g4fLEggNjkEnnANhvUta5d6VpVtFfW9s74eJZGgTY0G9WXCjHBC4z xubduOc1i3OqeIPEV/NbLK0dsqqvlXB8uW6jUs3lCba5TGGzkbQwLHkYo8wVtkQ3Gt69Lp9paKCN NWeQBbT94rE/ICQHyrtsY7SARnpU2mvHe6lPbz3cl1PO88k0pgDNINvUb8EHDEkHJXryeKEtAfY2 NY8RaJBZ2pngiis4rmK0w0ojjDy5CYBdfL3ABCFJXPcExiiC91i7guzp0I8i0bErJEFLhiDKqIyj zCoVCzY/5ZrubbzSYIfe+JLy4jj8vRJYbGbeCbn928kA+bcJQxQbhuYL5R2cfNJ1Hzx8VdD1jxV4 VudP8La/El/lJT5kzFJwmWMeE2ld2QQ23I2Y3HLbVYr0Pmjwh4qt9cvb3TvFGnCz8YwiWzntdkAL ose1Ci7/AJ3z3BJcYcPIXIXVv9L+xXJgk/exxvhCyMPLbBYgBwMpl25OCSytgklTa2MmtdDFvhC8 AMsIW3f92QdpyG2OqKu1sYIyDySCCcDNcTq/gwa1bhba0SMrECsluG/1xD45BwD8yqcbR8vQ5JKY LuamnnxV4Jlu9P8AFuoKJLgmKNhdG38xXyhke2jAcja6txzkjdH1z9BeAZU0/T47lofPLxbVEJ3I nmIGQkgMSQMoy/wlwpK9KhWN3dpXR9Tabfx6FZ2c2nIRfCBLuWYTFbWRZFSLyj52Mll2qxVTgKQQ VG5b1q9nqeqXWoXtnHNeXly3+kqJBFMrurYX92JBjoRH8zBtu3nJqJDWpbttK0XQkv7l99stzFEI rYlTKwPPmK37wocx+ZkFOpC5UkHm4NQ0ddStp7nTIrgO0kFkb6yWb+0QXVQiDyyrMoZSAxB24XcM 4Y8wRu6l4w0nTbOLTdA0S/8At7xpKZDI00ZjcbtzAqAOJI/3YHHQ4PXiRb32us0Ul48MyI5WSRlR F3SIB5YB2oBuDELzjJ6Gmu7DyLGq2rWuix2mp6krWCsNoh3MC+5gSGO9iSQVDDaflySMAHxu+svB N3Hc6RrukmC7RnjjNwlyFgg5KsWt0J3+7RSbiTkr1Ce12Umm7H5G/wDBVL4JeDfE3w/0P4i+CVhn Twva+U620Jka7WQk3EjM0EbLt8yJVV2Zisa5YiPFfzuSSzP5csbZi2YUM6gqBxngbRyPQHp6gnwc whFVYyfU+zyGrN4edKPR+X5/kMjkI8lZQpjJ2CPnnJ6c9yeSMeo75prlZI3Kui4VmQxMrZ5K4POA cY4GPlIrz9tUj3nZqzev9fkVzLGkzeVaYTBO52ORkdSQR0xnGMA+maY13GqKU/1m7rHGACB93r7f oSeoq1Fu2t/yIc4wv7tvxdyvJfW6MoFvuUknYY2MbAntjGM4C4x7ip/tUziZrSBhKqqQyLhQOnTB JOTwQRznnJFV7Pbnen9fiYe2u37OOve39afL8SuhnYIZLhElc7QIihJGRtzgdOSPXIGcVcnOnREt dXs+8Afu/LUbQoGRg9eQc+mMn71DTvanH7wi1y81adl5WIk1GwY/6JBK8bKSrBAQcZLccE9Mk+gI q3b3M0joqWTOxXaVwSX6feJ7kDOc4A2+tTKm4/xJJGkMRGetKDa/P+v63Gz3LMqoqhGyTy6nhuQS QMD9OGPPTFbdP/z8xf8Af9P8aahps38mEqqb3S9Wi/KsJmLGQHcVLyOGO1vm2n5eQOnuPTpVJ7yY QiASL9nIUFjuIBx0ALdsjjAz+FRFOVuZFyfI3yv+u5DEHl8uOG4YnjcvB3dM7QDk5Oc4B9c4Jq1O +9SsFrtYjdvkZfmAGDgADPQnHOSCM8VTte23clOVn1/T+uxADfSiKVyI0QggYyMnH5ZwDn29K9A+ Gvwr8V/FbxDbeGfCdkbrVCsk0zkKI4IlJBkd+ABkgAA5OQBnOK1px55xhTWt7HNXqulRnWquySva 3p/wx/Qj+zR/wTZ0DTNA0m71TwVBe+KoxFM17rumtKJjISVcRyRtCibkUJvU9cbsZav1J+Hnwg8P /C7T9L00aPp1hZSIHmXT7a2tJ76QkIJHncv8mdo8vycAozfKWbP0VKhClFRjufBYjF1cTUlOo9Ox 7tFJoeljWLAadbCOWZnbl1DIrAKu0/NtRMbAwDADAIwVrReS9jikk0MRWFpYzxIn2WD5JyoG0PMx O5j5SHJ3BtmcAJgbWObzZr6b8MLvW9urMLqTRERDdNKkkiwll/5Zsu1SAq8vtUAqemFz6ZoGheHd GspbHTpb37aHML2pTfG+3c7CRWBKkZI2rxwxbqSR66COhF94cLrbS6ZaSlAqzs0cruAAdrfMQozy Su4D2A4W7p+oQXAiW2tlgjJlibbIHNzCCmUCAgxg/wB7gksSOhIm2odLiancaipaK3guVkaTZCGk SJyHVd4ztYDggHLZ+Zd2fmB5zUtQ1N10uzgAt1M+64kJUxBQy5CYzsIbqWO3LDIxyT0Gt7lOPwze 6q8ksOoQNYsx8tTIFmuQMBtkQ3sDn5ixGCTgDPy1t+F7nTPD8FxDqM97cRNG3n/NGyKu0jJWRdu8 5cEjbtyACSTT30QbMLLVvIke6+zYMs6AAzukk4I27QEBlZecLg8BsYJAIht49Q8QajcQ6VIsNgrK TtnkkJOVSTI4I5BcKSoycDnml1DoZuo6LrN4JLZi67ADKAibS6+27cNoBAP8WD7irl1qGmQ2Eltq mspHc+SfLlOwohjSTI8vauVdgq/dO0MQA5BJBHnsK+HbFormw003Eomji2SSia3LmOQ5ZAiqTt8x 1+ZsDgg81ynjnxpb6U76UZY7q0eJGP2VZVRDG6k/fAIJMmSqs3JZj6UX6FJdTmbPxzrq6vau11Jc PO8av9oDsEBEe1Rv++vlOrAr0D5JGMj09/GesyJeWJ0+WK9Vtr3E5UrO5/dyHPAUAksWKlsjrnFL yHZHb6fYOmmWt7c6hG94ZGeKN9k+EKgjfjJQcSHHU53AAYNapZdJuXleCZ7m6ATyFnQK75+T5B8j DOFwxYDGccAU9yPMoRXE9vNdRIjxwAKJEnC/ut/EnO4LgMEGWxztBGOA3XLGxhiWLQ52n1Gby5Jj liJiUyyjazAghgT8w4JBAG2gPMz0S71Gyk0m/kH2xlZkZpWV4Qo2op3PtKKOAFjJGAu5Riqqahb6 Oz2dvLGJVcxiKR1WS5wJHdkZ1CrhY1UkluXUgfMQADjBfWNzNqeLp43WN5rtLpSpwNwYAYwcAsAS wJx1XIAwtV1fwrpvhU6hrUllY6zFClxZ3Ucy7IlOZJMtIxkQlQcqGK5ZcgNty5dmEb9D5i8Q/taf BTwroqanrnjm01DSlvXV2ubnZEZkVUwxQ/I/JICyPwoyo4Y+Eap/wUS/ZT8IamNb8H/EQDVBJCWj jhcIZUAVGSUsu0/Nku6Lgr1HUK9g0tds8e1D/gqj+zvPdSyLd6wbqUMkS226MK7jJy0ieWF4Uld4 A3KSTtcVlwf8Fb/gTYaJcvFNrg1GEtsjewjmE0ZYlljJAVWw7AEsgAjBUg7cDldCUoq92a1x/wAF dvgDq8kOu6lLqs94ZZLZNOS0SOazt1C4lLsIofmBCqd7OfLYOEATzPUtZ/4Kwfs06GltcQaHeu13 G9tMtpdWV7JGqrEwKtBePKVMbIT5gClvMUYMTqByGpQ3H2H/AAUd+A+s6adTtPFV3ZWF1Fc+a2op aq7SDaUAVSWSIkr8xLKGYIMlRn23wD+3N+yjd6REg+L2nf2/HvIZ7aKPyZQyoBGJSyPF8xILBzvQ HAGNw2Umt7n0V4V+IXwt8eXWn2vhnx5b6yby6RbfyrmY4/5ZxqSVGX+bGclC6FmGCK7HW7LS9Pt5 7bxDr8t3bmQQfajdR+eN7B5VHlloyzB9wADE5Yc5w78hO+5Q0i0v9UtSbT7M9jbiMwJqDRW7O7hi FXzG+bZySBwD8pGW57LUrnW9PtYBdWBa/K7i5vbfzHj5D7GEm4bgWCgLzkY3HaSmCMHRNJuJYtSj 8SxoiFw1s8L3O4RneuIigUEAqQcjkbsbcEnn/F/hTQIRHcRxRyagsQjheNmgUfOdsiLE4kn3Kv32 U/6zngIaGNdz4c+Lfw4nvvN1WSOB2DPFBdQrM7yeWB8piYtK8eVEatIoBO75htkK85o3xE1TS7T+ wviZpE8eoRw/a4LhH/dsikfNIhxuyCV6+YDnO/gUldMGrpnd6LZw3nhubx5eLbxaLIn2lb+9dUto 4VEm6SR2I2AGNsqAWGCSUZa+Qfix/wAFDfCHw/x4T+A9pBq2tq5ivfE19autuoKlSbSE4LyITnzJ AF3ITskVgaG76IUdNWbv7PPieL4s+DP2hfin4s8Raxd3tvrOkrbLfRSSWyiaO6aWKGUhktC7NLKI I9gbytzAmJQPsH4feI9N1HR57l7+6l8TlG8m3iYubhi287zhmZmBcFcJym4k7sHODfNJPudErWVu x9aeHJ/iCdGnsbnUTBa71kks5QhY4boyklSTk8bcHgZ5YV6H4c8LXOiLd6u+luuiJbtJNLPBIFLb 0CHcdpG7eoyGH3hwDxWr0Rgt9jjNStNKkk1O51GfUdTvOiSW6qkFrFknCnYzzMcFCxY/L83PLG7d 2GmaVpY8rSmMt2isVuU2uBuzgM4xn5FbKk53bTk5APIHd6mdcpN4higsrQHTbPY6A+YCTjc6BtkY y5Ixk4JJH3QMiS08KXcJE9vdrMHgLXHnXjRyGQMc7UUKAGU8Alj1xnkFvsCdjKttN8KeGJ5ptT1a ee5cw+VO17IZvkUKojKrH8owMZXcvlx7cEcv8Ta3p2jG1gvNXkurnajgFlmezjP7yNcrgg4OcMT8 yuASAaL9B6tXPl74kaZdfELQ9e8Mazr1n/wjF1ZXemTiGWBGjjukeCVCLvy40jZZDvDbhsJHBJYf x6fGj4bWXwy+KPifwNDfNNLZXLEFbZFUxkIyOuDtYNuYhQAFAXnOQvl5jB+z510PoshqJYj2TXxH ml1stvOhnkLyFgxdYcHBA6BiOc5zxgnB54pm3bbxRqhMG0yMzSbVU59h1+XLDI4JHGMjwVsnsvvP tZX5rJXf3f1+BlrJMoWOVgIoxuMeWO4cAjqQCeM9OVGKoGWPzN0hC4JIGOD+XTseD6gcmuiK/lOK btbm/wCGLRlWNJEWJiXYPhmGIueByODg8n+61U1kjeNIYFLscZDKpG4gHv0Jx168e+A4xb1InNWS trrYZJ5Uocuzglw21VDBVJPPOM9fyznkU0qPmhCMzK+CBw2AQuNpPXkjBI5wauL6GU1fVav+v6sa rjUAyiXyoIQqxsgjRueOMevU8kdxkcUqoQzSTXCzPIem3cEIyANowB1xx2Ix3rNOCXuLfrc2cKrl 77SS6W/r7iGC24HmWz5UsxBCrt6889eRk57gjPNWNy/7P/fuL/4qnKTb0f5/oJU1FK8fvt+rQyXS pbh5JbqZQgkVAj8EjjPBPHbr7+lQt9lCiDfnaOv3hgHBzjHfjp/KoU3L3YLY1dOMHz1Hqy9Asdyg aO2kVGZmGRw7evToBwcfmBxUs8bIX82ABgSR8quc8AAseR2xjOc4HQCs/tcrep0aez5ktH3/AMv6 sQJPISkKskSkAZZT8vQH7i5HIAz/APXr9Kv+CW2n2GrfHbVzrkMz2C2ce9EO0zxhyzgMc8AqrbSr dATwpruwUYrERueNnMpvAzS27f1of0/+A/HGpa/c/ZPDdmYfDsBijLzXWSdibAAinso2mYRgKFX5 tzYPpkUXhu88Ui9urJpL8iQQrPcRookQusbeYCFBVShHOOByo4P0ezPg27o6fxHLrlpq99YWqosE srzlUuPJhjnVZEcySylcSZJDLvJkxtPzFQJ7Hwvq2o2JjkuZLh5Yw8zwzXDSKgydpVyRjA57dCMk nImiXoj0fwppM+jaNaxXc0lrG4kklBkcyT7d3ltEoKq4Xdn7xONxI+Uk9dosOk2Us9nMIZdReQea bhhbmD5G2hJCV5XnIyqthCCeAF1bF2NqEaPa3Mx1yC2MKKkqiFbUvNtAQR+dh/NGHy656BuM4YZG n67pNjqPmTyCSzRsxm4Uhzk4K/us7TycY44/MtcfkbV/ruktJLJaQ2pt0wyvGHLk4IRdpBba5XP3 duWK5XOK4XUZtU1Xyw8DyXcwMKt5T7ZVJ2rx/DjaV2nocjsqhIdjelt9Ts4NTtk1BfJMIjyYTLmQ N85RkdUCBVYgAAAZXLYDNi6bpXhe4a3uG1GeS4SNVMAmYo43ffjG3axYAEZztGRggtgQdDe1TVYr Ce307TNIebUGkjmsGnCuUPZPnLr5atuyOmQpPHFc9fa54mh1AW1/fIrWB8opK0aAMCMgKDgYOcqM nOeOCA0gfY6DUNU1E6I0NnAsyok7SM0luzkdZGCI7YONpxkgbcZDV8walq1payTWeq6m/wBqWMCK dPuRTM25R5ZUsoOGwoOcsrfLySkM+C/H/wAQNd1r4jXGi+DtWu4vDOmq8BWxkZXurkAh2JLHARiF 4yBtYg5YV7H4X1O9uLPSLS41C7Z3t180zPMGk3sAqqzSEfdlBIAjyWYHOSTaStdkSb5rI9f0+9ju kkOiJZOZmWB1EKIWkVGYttcM8YjAYO6y5PB2AnFa3hy3TTprabW/PkluVkKzDUBGhV8lRsZd+Cys wZshyFAxtOY5bFKS0R9A6NfHR5rU2EwmlkYTtE+4tbRk7QJGwMKAATz0bJI5NdDf6roqzCa9WIXL zBm2neB1yqFS2FO1sZB+6D0Jwag9ixqOteHxHfXhQkG2bDlYy9uPk2gfMQnPAYnc23opJz5/qPif UpdNmWLUWisN6KIruYp5hc/KSABhcLHnkkn7pAJKtdxHzn4//ax+F/7P2n6mPGPj/RRqiW7nyxKt 848wurDMKuiuxUurM2MJgFm2V+Sfxw/4LR+Bru91OL4ZfDuSaWaKE/bJSYlWdCPNZVADmNssQPMJ OQW+YKQm9QbUVrufnX8Qv+CoH7RfjK81CbRL6HStPu1EctvbZIDgAK8cnEqOMsSQ/wDEelfHvir4 8/Fvxpcx3niXx3ql1eRoYo3kuWyic7s9j154yRxnFIzc29EeX3fiTXdRuLm5vdWlmmlbczSSNuYk 59TVIXLRoRI8mSwJXd9O/H8qCNyvdHz1SdZmV1bKFs5456+o9uuT60yK3dpcfaGJJ+UMeA3THzdB 0wRUrbQRsQRyI8kdza/v1UfvArMO+c7d3XjsPTis99SkXbGokEiDKLt2Dk9x1ORn86fqGh0en6oL rT7yN/KSWKMMiSll+0EyLlFKdWIJYligCo3zbtoMlpLPHEbkyNH0XC8hccjDHJBHyjj/AOsUM3dK +I/jXw9cwajp/iK6juopDNG63EuUlbjcqqchsADd1+UelfT/AIN/4KA/tQ+Gbezsv+Fm3t6rSGZo 9Sdbjg7Q5PnBiDhFGR2B65NNFKclp0Pvb4X/APBZLxdHcWVp8TvCTSQbmWO70uT5xGEYEyA5DKSf uqqdTyelfo34O/4KbfBr4wXml6fD4tTSbnyRp8R1kmB5CEcBmKbtismVwScBSMbflDT11NYyjL1P sG08eLrGjpf36R3OiXiRnTLjT72OSGMyvh5RvmUqAFCFdu0cPtyqseqv/EXg6W3ku77xIFukuB50 UoaaE+aigNhidyDGCAfuk4U/Nl7lO6VjFNh4Ql0q68QaPFLHMGEkqNpkEaxbuRKGMoCr8wztCgBg cHBI/OX9pz4i63p3g6bUNE1KaKdpYryzkgWS3TTLqSWFJGWCQbMYAQlMqyxR8/LtEvqxtWsmflF8 a/2lPjP8XNLi8N6/4hY+E0dRJY6ckdtbXsidbl4o/ld3LbzkYycgKQK+e/DWhR6wmp+bqflXECFr aERO3nvvQFMgYQ7WdtxOCExjmmr2bM3q7H7AfsQpBcfsb/He4/tS0knPjPTY1tjewpOpgstUVpkg kUylUVkRpA8apuRXVzIpX7X+CviDxBaNplnb2UCaisx/0lnlaV2bACkF/LP3ATlTuBAY44Ex1k/U 2aaSv2PrzQm8Xvqmk6bq6XD2xlEUcwUm3ycANvXG5QdgKqDncB3JqbXLzXLa/jXU4ktIJSq23+iE KqllwRkAkggggDOCMD5gBp1IvY7dtW0dI9OvZNNnItcK15FHGzXPK4ljzAoQYUFASCMqQQSTWXpu my6z9oiKWyxOkcELzrGzLvccoXlBUglOfZ8jCthJdQ8hlxa3Ok6jeWP2qKGVJYzC0trcW8oC7yep aLLjD7TzztVlHFV2haa8N1qPipbt43WD7PJNJGNob5QN4AVCOCuVONpyM4BdsenUHfQ0mtbn7JZT KEkgkjuSzK4PGSqneuQWHDg8gjBwayvFfhzwzc2FjHpNzBPctObj7M6+WsgcKAnmfLJlSu0AEjDO cjkUBqkefat4A1W0aC5mnh0zTWWET+RZwSFIpGUl1EsJLtsjR1z5i7jwArNX863/AAVN+CmqeHP7 G+J80kVze25gsby9a43STQNG3kEIQS6jdxJ+7CL5aFclQObE0+elJM9DL6/ssTTmu5+NMGrKv+l2 8Z+0BiUxI28Fh19AR69RnPB5qKK51VpluI4iJVDZy456nOB0PGQPUE96+c9nGLbm/I/QPbzqKPso +d7/ANfdsVZkvcGV1WNyu1u5kGR3IIByOo55z2qCGyuMmECUsXVcBDknOOQcZJx+JFXGUEtPxMZU 6spJP7l/XzJJLG1gCNlncENzt6gZ/gJyOeDkZ549LBQGQyzMGk24K7xnk88AgEjHPI5weuaTnKWv 9fiNUYwunv8A12YRFIUaFc7WYFCRliR068jrnHXtVjBDo4Q91VSN2D3xkFR2Ge2e9S3rq9zRLouh dh+yvArMpE7sNpTILHJGDgnJOOgxyHB7GprS4tld4ITjeNmV3HB4OemRjACkep7Zzm1LVGsXC8Wt 3/X/AA5JDZTbWlnjVdx3I7hVOSecsq7mz2Uf/rm+xP8A891/74n/AMKhzi+l/wCvM0VGfR2+/wDQ 5uTZbiaCWZS+/d3O499uT9ffnHalhntEMkqRtIcqSCMcAknI6A9zjIzj3re0pK60uc3NThJRerX9 bl+2uYws8ZUQbQNpx8znJ+UHtwTnpjgZzg1XRzNayyNdIDuwG3OGIOMMdnGR656AcHBqOWzbtc0c 1JJXtpt2t17jYN7uYfNmcNjLEMMDP3sLnG3k7ecd+1fYf7DHjS/8N/tGeF421G3tLHULa9iufOub e3jlKW80qRhpht3l0CpEPmkkaMBXfardWGajiIyemp5+YxlPA1ILXR7/AKH9gPwLttW1zQvC2qLo a6f4INu0cOo+YHku5xM7KNxJMSr8+PLVUZ0kc7mD49a1a007wpO2r2OoxXk9y7ILyF3aR0bcCSCF KZjDIUKgFdwO7gj6a5+dtW0XQ1bjV9evRpb2kTxQxDcq3MRjE8LqojJxh2J5O4M2RLlQpClq8Wsa mlyftt3EyyuYfMmidVUFskAjJ2KCfmIBOccjFMnc7nRFvNUtjp1zqSJaMN6mORnUSDoAqkEnDOAd uCSfmwcjZ0LRLoXNyLKAG7Vgk0IQXDKo3eYygAEkA7hydoBzkBsJhruXrltFudlzcnczHyVMUkRR GRmJO0DcwYeu0kg4BxxppqHguOAwiyInlkOZPMjPl4RgSHkIzkybtpbHHrhlWo7HIrcxW0IntYFb T1kUKGJZmh3BSu/jjnhV6fN1xiu0j1y1RNPhS4nu7uS3LRoloVMczn+ArLt25XALbQDIxIB6j00G tTyfUNN1rVJJJC3+hY3JJHKW24ODu4yp5xk9MnBzivQbzydBv7rVVu3XVNok2xJbKF3ZyNqPIQcS H5eMEDPfAIzZPFmkzvbXE1q8qqQbiN5t3mlVC/MS4Zu5wAuMnA5yevm1iw1G7Waz0yyitYv9WkkJ upAAuS7GYHPLZyVAwwA2kBQWGfPPiy9lnFxo0+rzWcgk2TWrq3lTyIG5EUSkBtq7S2PvZ+Ycbfh3 4yeNRoN/qfhXw7cNJqlwFW5uZwN2mxgHcVIBDOTwpB9GzwKel7DTsrnm/gHw3aWQsGu7MPGqt5i7 tjqzcfMQCeDtGeMh8DnOPoS00yVpo4rZoGtoH3naArfMEMjJnlgHKlQc9HyAcmrMEd9p+nRO63SX BZIVVZiFjJVlGW3KSoTOGOCoXAOQMk1ynx38R6vZaXo/wj8OahMviK4uo7nVbq1mkEujaeJYg7oV YBJJCNoU5BUsBkMjGJP3WXFe8j17RtdvLjWoJ0vJLi3WNW/0yIQxkeWpwNzIxB2hQwILbVOM7RXr 99rkDWckN1MgniVWmuLiSOZ5WRCynzGUIkQVVVSuAqknOTgqwz8xfj9/wU1+CvwdS9sTqg1/X5Ql xPbCZXjdgMgedE2wgh9g2AlQCrrlCa/FL9oD/gpv8U/i1fapbeFrmXQtAAAgEVwFIQEAbWCh5GOc MScEEnYgXIPIUpKO25+beveMdW8Qyvdazfy3LscxtI7N5RZtzFFBxz36j8hXOSTRxjzFmjmAYZKM QT3xzg+x6dKRk23uNEsTBJSvzgBQGPC9s+/5cevFNdvKXJJYHnYF6Z54yOD9PT60CI3ePzZJGLIG 5wV7n8PU9qnisJJojLa2krBSGdlQ7AT09Tzg8cdD6UWECQEgGaE5JHztkADt0Xp+FB053ykcbKxH GWypGf8APrU9QHRWzoQJLxBHkIxMyfKMcZ4/oaguoHaUyjUoWhOeWJP64C1RI6zRrMNK8TI5HDKS oH0H/wBatKOWz+z/AGNbhRM5DHcCH6cj0H1x2+tJodyhNHdEW8CzlmDb23KvTPBBPJPfpxmtTz1i dpL1FeNlVNqxL/CcABlHJPT9e1FmhlxIUtEWee4ClgSwzwmDkKB0AGckDOfeqkN3GzS6hdsTEGKK jrlpH6qqk+4znpTA9u8C/Hb4xfCdYNR8GeL7yMnNxJE1wRCpfKAshbDEF8gZOTuYqccfq78Df+Cp Wu3tzYWnxg8ErcwWiIseq2EC+fF5aJGnyHmbaY4vl4UZOQAWJFpsaxqdJH6+x/tQ/CD4r6VFJol/ LqPiJrURrcPbWkB8snJDiOJht53FFVuYziVgQV/Pb/goXruveBPhpbxaisVrZa7fW0C2wshBPGIj IG2EOwEayRygDeGk8uORh02tbFyZ4v8AsOfsk/Cz9oCbxD4r+LfxRg8N/CXwvYJrWv3Jvlt5LiGS UQC3gYQ3DJKzYCsLefBwBHIzqp8w1jRvg/ovxD1+3+DenanN4U80GwXXmt5pyoiUStIY0RXQSB9j bVJQKWVW3Cpu+Zx6WHy2SZ9l/ALRr3S/2R9DuLey0qLw3q3ijUp7K7sYwJ7s3AsTJFO4OHWISKUG c/vHBJBGP0g+Euk61aabpE97BahodtrFagW/7tCiBZGAJG8naHLKSpA+XIIVR6tGktHZo+itQhvb 8RWd9OIL5vktbFbjciSNJgEAIwO75cFSq4KndjIL4rS2TfdT61bXtxDbyQOn25oFcENGyRsmVkDb iepV0J91FrQhq4+003w/Pc2SxWghgjiKxzsyhVGMgHvIQFjUHgfLgDPWvazXlld3S6deSQrt2Kqp GDGwYIWDSFih3ZbcCpBJAIGQH5CRt3ujXGrWonv9bt4XhjVGZJ3nBY7ArM+1gy8kdcKVYHHAalB4 Y0G/tEjvLhXkjMZeWKSNQVUEsvlv8vXuzA5UfKR0S0BnLTeH7R/LGnNLfXscfmpbNeIm90BLDhVA TCnaMuzE4C5NdtpjWa2Mdp9htYy8Lz/umaUW6yRogV2kMKxlJfmLDdnGcMqZYfQpapnA+INPvLi2 jXVfFUlvp5KxrEsIkZYyZFcq3yAEHaQMfNuYbuOfmr9qf4Y/DHxB8CPF2i67oiX9vqmnlLaXUBcP AZ4UJtmIidTGyOQuVkEqI+VKbnDKSvFpl021NOPRn8XviUW1p4l8S6V/YFrp72sxglt9MuLr7NEE bayqbtpZnBIByXI6kbhjHJzRs4faWJ6IpflsE8nA7YP04HfNfJ1FyVZJv8D9Ow8nVwtOcVuu/wDT GTRbh5cDRrDkPJtXABO7AycnBHfsCeuM0CCVEZRceWrIW2kpgn3JIwDggY7heuanmVrNXLcJ6yjL +uo4ER5SRSyFchDGPl4HIHbtzxkDkVC8sbEfuG3LxyAAV4OAG479u2G7UJNu6YNqMbOLb/r+rfIl EMTpDLHMokKlxH8/ysDx0Tv1x7HkdKabZbhSWULGmeFUnJIzg4HAPJ6nhTjkUXcdxcqlp3/q2wiq 9sFV9sagFhK5jLMMgbexzwO5PBIGDzaDmWVB5kUavLwVTOTyGKl8/d55ycdjxmm9ubUlOz5bpf1v 218yOLUHtRNHEHN84wzAldyleQegwecnngDGATUP2u+/581/7/J/jSdNXvJ/cUq7taMb/gUbtjMz XIddgJVvMMjMcAHnnOD065xir8c7bN/neXNtOeChA+VW5OQBnIOD3ORg8XJLlWm39bGcG+d62v8A f95mTRxmRA135jHG7cS23BGc89e/f65rREFqF8+eUF2B+7HtUNu6dAo7kYzgHJ7iiUpWVlb+v6/q 4Rpwu+aV1/XX+vyNWOxe7gYxKsi7MLsyoTB67V6c4XLDuB3Fa2gzTab4j8PX8JAube6jk+aJdhIc MNowQMgjBUEj7+c8DOnP94l2ZrXpXoTa2a/r+v1P7D/g74hXxVNpemPcSaX4XhxDF5cxkWGAMxjV SVDbAONwXPUkAmvr6xt/Duk3EzvFIIQnlwT+QIgwO1C5XO0EoDlQcAtjAr7KOqTR+Vzum4s9WvtV tpNJ02fS/spmtmW2WSJt6XOW3B4w2N21edpIIyDwWwuXZQ69r1tKt3EqGTe6qsZbywdo8peDt4UL gYztA5ABpIlroayaW+k3lrd2aSK80jbomlQukTcrs2rGpIIfdnaDkAdGxDLbSvcW1xKyIGlX7Qsh 2vEoIGdozySrZAL456UdRdDtNU0mwax3289m8pjDrLBEyA43LuDMuVG7YvzqCSAS33s85cXVnaW1 usUbeZ80lzPcOfN83ccmIEDaAFAyv8RYj+Ag1Y9jprbULGLT5b698CSSWTKR593Ew3b2YoxKhc5G cdRjJ7jbh6hrJOo2x00SwKxVBJl4533A7m67ETB5G7K+YAGIBajrYCxHt8MiL7Vc3BhZPLm+zzfu 5S+T5bFmTKDcvmEE8MflJUbq2p634beXTdMtL8jTRIsk9xFbYWNthYIPmQORhwq8Ebm5J6LVsfTU wbPVvA2mXUuqvPqVxcxQpFJnVDHYyRbm5a3Qr5km5V+8hKkEjCHFJP4r1Wa01NYdSCwXKF2ity7P cAZYbwmBuUjOZF4ILDGAaF1uD0sz5s8az6tbahpVvo2oyxiF3RUu/LXc6BXkbaWBCgsQoySxHXqq /LUk3wG07xZe/wDCY/Fuy0/xg96zTpql7EUhdmPySSZXy9pUcFgy4wQCBSlJRdyrc0Uj6D0v4a3G o6Vp+v8AhDVrTVPDkjMbWeC6t7pLgYGT8h2uGBH3CxLDOB2qJHeTXQ0mKOUalcSiKVQjjfLLJl+A hzkyN0VeMcnKrVRkpbGbi47ou+JviZ4b+EnhW88T6zCZb2VDZWdjDOitqs7ZUqFID7BghmycfOME ttr5w8NeLNRudR1j4l6w1o/iTVLp7q7gjs2hgl3gD7PCmcJBGgKK2Q43E7iwUrMndpIIrTmOP+Jf 7bPw8+Eej+VHdD/hIhmQaRbXDfaUXYhO9lJ2pluRgYDEgNt+X8ZP2n/+Cjfxx+OlzNot1qj6V4JU eXDZWErDzEHyqLuYbWuMD3VQQMKM5LYpS5VZbn523eoanrN6LvW7+Se5lyGmklJIByMKd2cY428D npiq8mm2iBbZbwTREliSob1zhhwv6fhSMdxttAsbbYm3Qt82S+4L1PU8c/j+FOmhRUKKxU8q3yEj 279ev6UAZ251ISMqVI53jGMegxj1qc20i+TuumWNhj51yGJ6nJOD+GeDQAgnkCMuwecDyRGrAj8T ge2B3qw0iXAhmZGjcrh0VFQFvXgcZyPXn2IFJhuaAQsXWJo8EZ5kRSQfbP44xVkQSJGr5GG4Ci4X HHXIDH6Un3EZF3Yjbt85FDZOJJUznueuetR2yXVlGI7eeLz93zKGyW6EYAGeuPyqhMilukMm27md JMYVkhLKo7ZYEcdeAD/StCzltoLGQpbF7kHKyJMpUr3yNvLcjvigLFW5S6juI5HQs0qCYsrEk+x6 Y/pW3C0AgMjSn7cJQDG4yASMDkdAMjv3oA29Zgmv/s0FzemW7ESriSUyE7MLEgzwAFVQAeB06AZz dNspLd4Ir23RXXMdvt/j6kAAccnjn2zQ0B7No/h7RtGd9Y8fa0bLRY4HkyVcs8hUFUiQn978zKSF J2q+4jJBHNz/ALQvgjw7NJF4K8LTzzKVcy3Eq+XJLwGLqMqw3BmXGeHC5IQZNehokt2dfp/7a/xO 023RfD3g/Q1ZW3gLaTFycKFBaNo/u7cAg5UEgHaABy3xe/aX/aC+LGg+D9e8aQR6jYaZKYY4IEnK wox+XO6R8ElW+bGPmOfvciVi3LpY7P4X+O9N1yzli0DVTDeoAt5YzM0ckDfxCRD94Ag4blc988D6 R+HXiTSbC+vNY8Tv5mi2ULyTqjBJb3aCRHESDsZyuM44G4+1D2dhx+JJ7H6nfBiKx8Ofs6fBbRrS wuWlUP8AaluI4irEzzqpiTBMii3W2ViVDeYjHGAGP6ReEr+4vYIkudTktb+BfMAjRd2xyv7ko5TA XcwO3A+XAXaoaiCtc1nq2exaLDBZaqv2yBm1hEf91dISrtgn+OIIFJG0A9MbmIHLdAdEsLfQZtQs Y7i3TzVSUHUFkUsCWII2ggYBAByGKudw2laa8ydje8Kaxe2txEYnkitY2V/Ph3jdIOcKF+XK84GM Zx2p2o3cUs89raaZZys0QaJpFXMZDghiN20EbW+8pB3tkEEGjqLoPsIku9Tkl1PRTdiTEk0Foslu UyQSERcKFLccLtBK4AFZGsXmnStqdjF5lvar80UJBJmbIwqjbuUj0Zzx1c4+YC5Bd3mhZi1i30Vo 42jWJQFaIhQxwQUiKHIjAL4BLZJB5NcnBLrmss1jLCkcE86RK8kUBkZG2jp8o2qVYjJByzBiflKh S0Rd8SeF/B9lbRy+K/GCXGqmEb7SCIkORGx2tEhQKyZU7/MAyrKy+vn+sP4MEd4Bax3EFvbSW0dx bW8u6/8AMjljCBdqEq+1FG/DjLOoaQEFbq5Suj+UD/gpN8G/FPhL47av8WtY0J7bwrrMsFtIsVjH YiG6SIxoEhVEBMkduzs4Tl/NL/MwB/PO7mE8sl7EqCF2LoqYX32jaF2gDAwAuAN2BmvmswpuOJb6 f0z9AyKtGpgIxT1Xn0Wn3/mMzc4d4UGFL/uwm7YQMfdK9RksPTDHr1r3TbYoYmhlBJbKyLk54X1+ bBBGfZfTjiSV1Znsyk0pc6/y/r/huoW180b+WlyhVEbGYxkF8Z3bhhTgjJGehXPNNSOTUbmUS3iK 0gZ0SYqiuVBJOeAgxkcEeg5quVQbly6/0zHmc4qKlp+HYqGZOgjd0KsF/egrk4zgtgDPPGSelNe5 ut7pDAkbAbQyvnf0yAwyO5II7MfXFaKMftP5W/r8zOUp/wDLuOve/wDT/Aln025W43XqtA7hSqux LFegIJABBI4PqM+1JbG0g+0PPNI0mw/6onBJzkhgRxycjnIJHGRh8za5YohQSlzSeuum5UNzBDJ5 EcHdvN3y7geo5CqMHnB6896X7Ra/8+0P/fLf/E1XLJ6p/wBfeZ+1pr3XFfe/0RE85TKOmC21gTIC eQSenAPT0rWgjNyTEUdmPIIVVIGAFbkHAxn5eB0OelRPRXR0U7zlaxr2tlbzR2zC1OA2GIQM7c5y OecAhjyAM8kYpLnSrm3+9AI5Cd6gqw46BsHOR8pP1JNcntGpWlI7/ZJwTjHoP8uUyRyTXTSQLtUx HccA52jaeowp6AgjPIwM2bIxSQBV5b92ZGI+7gkBi4PuOMjJbGOOHzaXirf1/XqKVNbTd73/AK+X 4H9OX/BK74jwfGjwNq+gTiRdU8PPbrdAvK896MTLE25lITYdpP7zGUUskmVVf2GuNWFx4TtrrQtJ ja3e8kFvM8c6xtIzSMipI24x7UbI/eHIC8sUJP2OGm50IS8kfleYUlSxlWHRN/5mjpnhvxXrNrG8 t2LcW8Qllcyj9wuSoG2MkyABgSBk5PCkVc0LXdW8NX+qGa5uJm2MY3S4mhYgPycKCz53nI4GeSBk g9HkjgFs7m91bVb4SXaQWznfxMWATO75QzfOTjAUtyxABrTufDFojxXwjnnikxc+XHIEnYKrF3KK x2Lv+VSXBx0Bzwg3M3Ub+4kWKc6jJFpjBlkaUcylckDYW55AXpjCrgcYrtl8mfSILGz1RBpTgStC ZRiRgZFw8e85IAUAsqngHaM5JsPc5abXBYXb2ekzTQyNlbd9+WKuG2gFQhOVJBJ6hh0yAeda68RW GrjUmkRU8zzHR1ZVmTfjocBUJLKMHuRwaEBY8R3MFzqflWk//EtJVirSCWS3AGGBChBnJ/iVWO1S wXJAbd6hpt1occd5qljIioGggEsUjxqzIhaT58IfuDHDY2k4XoapIGrnMS+LBDAbe2a0O0SR+atu wkLfw7m3FjgAjHIyBkDti6h/wmEVpbT3NkIdIlZC1zbOHiXbhdzIm7ccE54yCW9GALdR3POm8TXO mSeLfGV9C9zBoljdauBcyEQ3EVjbz3zIUwDh9nKjGdzA4JGP5Rtb+MNx4hutY0HxPcb724vJrmK+ kY5dpHZjvJ5YksTuJ7nvzWUtW/IcnaPqL8Iviv8AEX4TfGbwBe+FfGGp6Zp11PPFeiyu5YluDtUx Bo1YI+1mJCsD1Yc8V/RR8MP2rvFWuaJoth4n8Pw6srXLtKqQoJSpC4RRj+HafmbzMhhkgg5lK/vL QIO8VF6nJePvEGh2vj3xF4413U7e20uD/R7Gz1C1BtdIiSBPMd0bczuzTPnMeMEckMQn5ffHf9tr X7pNV8PfDcR20NwDFdaisCCSIA7/ANxkfuCWYklSGyDuUEAm1tdkzahsfnJqd7rHiO71DVPEAa/1 Fg0ktzeXTSTTSEk7vnYtKcnJUAg5JIPNcRe6UsUt1bSgCZB5bBpCCrHpgE89ABkDHPHTNGDd9TlL 7R7i1OUuUkUnPlEFVI4I6AjHfsDx61Np18dNnW6u7KGfDb5Le4Vyjj0Gx1O3024/CgRbuNT0/UTN NbeH9OTLfdt2uQcdcjMucj05rlJfI86V8vG4OWBIKqevTtz9aLh6jhcBMMXRwPvHaBtPXndwPzqK 5CCMnygsm734Pb5hxzn/AMdouBXuIJiy3lqV81VQyKv3SCNwOR7ds+vpxbhbeBc26b5DncAA4U9x j+RxnpQBJHak5ZXAIPAd8Ek/7J/LOK07eKdJFLA7QfmIHH5nrUAdA8r3duIDNLlMmL96cAn0AJx/ 9fpxXLS3lqbsrqtxdYSJwmShG9UbaNuRgFgAT1AJOCeDa1E0YYu4J52igvBHCCHXJ3PnjI6DP0OB W44gmUW94ys5IVXyVJ9FxkjIP44zn0oAiEcjXc8qX0kG4hY4iGTzEHG3qfQdz+eKt3aTR/vkCTSP kqAnLYJVSy4wTzn8PwoQM3tMtfs06XupFku9rKSY2BR8YfOBxjG0dP4s9eOk/t23toL3XryRmsYQ xUMmQ03PABxvOBuyW5Az2xTEfMnirxhqnirUXl1C4dkA2pGHOyBCciNB2HQk9SeTk8na8G+FDreo 2cchZbRpUR28snapOCeO4GTjvg/SmrJGq1P3k+Ol5+wpp/7Pnw5+CX7O3wHjTxrZafo954l+Juoa veG91q+m023l1SxWykSNI0gv3uIY5VOx442UJJ+7nPyJ8OtGsfDmrz63aWNtc6l5TRQWNxZpPCmR s8yRHBTPJ2oVP3S2FwKxjKTWpTUef3Twb4x/BXTnS28UfDhH034jQzT3d/Ilyypd5HMSKcrEwK4A UBT5rq3AUnzDQPjZqDWL6F4zsRZeI7aVBNctE6xTkkACVAuI2I3NyNpycbeFrRO2rKSbbSP6pv2S tMk8d+Hvhnq+n28Fxp2k+HdPe7WGZJWjluYIjw8iuI8Ha5cqVBfavO2v1A0Pwjp22yvL/UreG7kA SaOKAqvlrlnbBwsgO0Fh5xJLMAAQSWtFqU37xoanZr/aSJa3NrLoaSMkeY3Q4YfLkF2SLaQxUbyM kH51LEbtjqOk3l5EmkxnT4bYEo7SzOFy3JGW4JwW7DJOckjDF5F/VPHVsP8AiUaS4fT1kVvNjZ1G 4RqjFOWGWwSxA+YhWP8AdFCz0W11uF5bWB4bqOLzIVwEjxyu5u2AQMAZyWAHOAUM1odS8O6faWVl NqU/20KRL5EpUPIFcKY5djH0GCF42KT1Iwnn8KnUrtLeRFQFWguLpzJu3NuPmMVwzYPXaOF78GgN 9Rt3rEt7djSNBmdrR/8AR0gEx2SSsQrgIQpYkhcqR8xBIFVdfsNDsZLO6mu7u4tghuBax3PlLA5b buBETJ91VIcYBCqATtxT6CW5y+t6pp/jKfTdG0PwjYxNbTbpJd0v2icEBI1mJTLgEID0BZzjGTWv p82t+Eba20iXwzpN3qE1o1vbxNFtW2E2R5jsmxs7ZG2tIWwrfdxiptpYvS+p+UH/AAUh+FPg74kf B59JGtQN4pgja6inJliWzkk8pxLIsRQTZWR0YMhPOSMwjd/JSLe+jk1K3t5IpY7eU28kyuDE/wB4 ZV8j5T82MDlSK8fMoxVpyPreHas/epQf9WGx2t9JKpnugLb7ybmfAG48ttJI6EnGcEY70twlswcr uYjbsXK/IwAzg7cY6nB5wRzwa8nmXN7isfTOnNRvUle/9JdfL/hhLJ44SY5bX/RyNmwttYnJIO7H ykMFPAyemeeYb0WJyYomiJbZgEsQucjOAM8nrjnnpjkXNz3TugfK6dmrP8l6f8MVoJIYbhJUzIrN /qpASV98DjrkAHOTjIq0N8jeYZHAzukUxKFj7ZOegzngBc846VbTvzNGUWuVRT+dr/L+tvxK9zNH Z2giMzuW+baJAEDYwMgAg/dOOf7vriq9uJ2BlR38lV2BpM4x83AyOOQWAB4welUvgbkjOX8VRg2/ yFhuruSIRw4jITI+fBJznHUccnH5n1pPN1b/AJ7N/wCBH/2VDVGLakr/ACC+Jkk4aLyZtTfYoC5d wt02C0ZQLtJY9Mjj5Tntgn7p6iMXlvkzsqpJxu2g4UjGcZ7nnjrj6AVhaclc61KnGVvn8yzLqab4 0VN0oKu+4gGQ47ZPJ49OScng1egnmu/K3xsiDa73EqyOkYy2MqqseSAAMEnB6ColT5Ypt/1+Bqq3 NK0V/Xf+vuJvMubmSK2RxJCPuCVmwVzuwCAODjJOAcfjU8Gk7ni+0T7bcZVWQu8eQcFPlGVJww7D nHA5rJzUNl/kdKpOpu9NvOx+tn/BMPxXeaZ4i8d+DrNwuoXotv7OiSeH7Q5kYpMNrAyOpCRRnZsx 5oUthih/p98J2es3PgjRL5xcjVxbh4Z5hJkJKSsjNJg/LskVCpOwiTBAbIb6zLZc+Eg29f8Agn5n n9N0szrRSsnb8i9oXirxRp9w9lcxW3lQyny7iGZY1tfmUbvmQMykBmGCCCM4GXatW00258Qm81GR o3uw7F2kuEXBI3ELuwz7dr5fJ4x/CMnv2Z4m6sjPe0ittSm8mC3uZyhCSbyQI0ZWJXJB3Day4K9M kDLZqbVfFMiyX02oXlpDp87R+bb2xK/KEAiVJHVssAu1nx821jn5qT1Y11Jo9Uju3tXmNsI9hIVT C+M8sBnADYyQeMBQB05RrnVdjXXh6+tjbyKgR5JYgxZl5XdKV3AYZWXlRjH8WaBpWMDRotWlvLzU 49fnstRtTtkdSPNWNhtkKLnLIE3cICQBkbcbg19FuNU1J7vW/FflQuuQJ5S0qIOvzIpBC/MCcLwC cDOA+ouhv+HT4Oltrx0v7tJLCZ5be9inaG5i2H5NqeaVUhm3g8Esu3cSQ1UNM8RWn2PV/DsXhh72 /dfJhi8xWmlZxtLHMe47DszGG5JyBhThbhtuR2Or2NrqSW1t4Ot0LQ7pXuX+RIpI9r+WXDDzQuGX nqBwSBXGfEXxf4pv7LT9V0exhitorj7ZaTHdshmbfGGIIEbMVD7VQMSpZSCNy0W1H9k+Y9QvfEcv wU+Og1bVbme9j8M64qS3NzIzCL+yrp2ZS3BTDOcKvtkggV/Ib4xtQdVukWM+crcEscsOMMpHXp74 zjsDUL4mE9ki7o3iXVdMl0N5oWbXLO6gubNism8K4VQ3GCRsk3qc9Fz0xn+jP4fa54UtPAelap4W uhqGtTm3Nv51jFcfY5SgJ3mQyKyYkVGi2bsKCTuXynTSu0xR6M+G/jT8M/jZ41vrhbu1nTQlklvI 0tZpEDxMMYYfKjBAZP7u4FuFLBK+J/F/gG98JSy6bfW86Xg2kwmNDIYmViSHVsEAhgWxt4X1zTTW xlO7bbPJtXlsLa2m8lX+0CTJOPnA+UAYBHTOd2TnjjjNcmL+ScweResxVNqtIF2Kf7oJIx1z0POT mqsZ30MB9QvC0kssRZtpxuUKuc/QY/SsO5aC4bz0LxzqORuxk+oJ7cdeen0osFx1jbajqcrRQwZk 25YqQd4H9fQ5FbMvh/UYbdrhkCxhQG+fdtIOMDBI59Qf8admF0cXdXW13WWMZJAUsoyR3Gcn/GrV rI5eI3fyRE4LL8xxnqAxGfxI/wAUBYuX0eCVlivLgzsoyklpGq89QCJmzwF6+p9MmpEzWcqtbSyN aMcN5UgOzp25B/AijQNTrLeCN41eFjIrYJycZ/nzVuPajCIxENj5gO//AHz1/Ed6nyHqbkcauUla EMMAbcHBxgc9D+XX8c1554o/0i6dUtj5aj+4F8v16nOc5PX169ae7EzkY7e4Csw3NDnG9kI2/Q/n 61OjXsW5UL+Vtzg7SCvIzz0Pp+dArmjb6rLM1u91GX2L5aZHLDdnjPbJ7Dua7Kzv9NtkkewjcGSM LKJHQrlTyqfdZQfm6FsjH4AFe6v0hW1jtpIWikO5kOT5ZO4DlgMAg4yc4x69OZ8WateS6C2lRMyW kjR7hubbK2/g4YYXAdhkdvqcsa3PEopgszzMgbc5bHIyM19ZfDL49+HtB1wah408EQ3GjAKZLLSl jszOy7QnyIqpgKgBIw7Md3LZJU7taGkLN6n1F4W+IHhvxHqF3r1rJaTzX2HhgkMwCl50djDDArLH IsbN8silUjD4XeFr0m3+MPgbwt4FXS/CdhLcfFjUs/2nqdwq/ZdItRJGLe0sieI2+UNLeH947MkS CONJXvMmpNpLb9DaHJZtrVfmcLreuxvLpVvbxyXOo3aL5FtGgaWZ8bioHAO3OC52qOOcYNfMHxh8 S6BEDNZxQSeNIYVguruzlZoLYSow+zLKoXzHOZHYsDgxnZtbcTo0nowjKUH7RbrY/Sz/AIJMftK6 hp2reMPhLr90TayT/wBrW08qyOtsnypLjZlkXbtyEAOwNjhSK/p08NavdSW6B9Wtjb3AMlrO0Fuo uowxaKSN5WVgGCtndxkKfnYrupdgV7XPTfC1h4bM0ke3+0pxEsjNchisbMfmACSAoN5UZUliD25A 6LxDqNukiSw6XBbXVxDGUht1WEiRAE81VTCfN8xDKpOSw/2iO4kupzp0K406yaWxjxaI7BpYvk2I 28OjbgAS4BHBAIBGD0FlteuNLu7aW0haK2l3RSOXDN1DLG27qq4UhsHJU8dgxoytJa1vzcf2m7qC 2Jdyo+EJ6suQWwQrYCn7vJxkVLcW+i2d0k+lzHMEqMpELoN+BnbtOUB45yc4HAycAuhbHhQ3AuNW ivooYZJWLCUoAxKs7KZAepYZClgOc9Til8Qy6TBBqttpHn3kkiyeXDFaxLFFbhWIbeGkYkEbiSAQ F4IPKoOhwel3t3f3s0rwXEc7LI0ssqFzO4TYxaUsrIu1m3Akryu5SDUY0vxHrMd7b6tfTwwRqwjn neQJMpzkRCQjaAxYk9OuBmn1GtjgvFnww+HVraTL4ki/tS9CSCSxncP5PzbVypKMNxOOBuHykHtX 8ff7enwWHwn/AGhfEl7p4c+HtYnm1G3LSFxCzSEyIpKRtJjcH+5kCQbs8E8GPjzUW0e1klRwxkVL ZnyYktosbM8PzBR5bbAwZejHDqST75HI4OAMJLc5Q+TcBgygAAYUBdxGBjHAwDnn5yPUD5blk5a6 n6S5R5fddn/XXe362Mt2jkJjhG2bDHezggc4zwvv75JGM4rFM0TyQ+ZOy7TuCrIRyAOoyuM8nrkZ Ye9dVNP1+X/DnnV3F7u3z/XT8y0bWG4LfZoCw4DL5ihdwA3cDgjPAI7EHrRc2bQ/LcOiKpKgkHKk YOFyBg4PTqOc1Sm78r1ZDpLlc1on31/4YRX06LJurovL0CoJAcZ9SMAYyBg9hxVeTVrN0K2hc4Cq zMCxIOOMYHXrjPY8+jVOpN3asiJVqNNKKk3L5lSaVyG254GP35YbBgcja5GeiHJ6EDbkVQ8yb/nr B+ZrVJJWf4WsczlUvol/29e/5s62DTGmYzzShkwSCw++RxjHOWP14PJ4AxLbQxRgKkYXzOC7tuA9 /TOBnB68njGK5HUv7q2R6kKPK+fdv7tTStbSzleWGZisgAI3EEOCRkHOODnPuR2BzV+/8pZPJgUB gmCqjHHIOGzwvOODyCP7pzztyc0nsdUVCMG0Z0MstsyieAJb7dyyRB9rkHqSSMkBivAx0xnJJW1u o4yPmZDuLb2xt285xjlfTI57DGOacU7uP9eQ4VORpS0a+71Psb9jLX5NJ/aI+HliLki21WY6ResW ACLOv+tbzXRT5cmyQjeB8hwRuzX9iPh/xTbeH9NXTIb+HUL6Axwq91MXigeH92xkSTbHyQBh9y8k AsucfQZPJvDyi+jPhuKacVjozj9qKL2j3OueLNSk1G61SXyDbrAG+zCFo2KbS3lxliEDMec4xhjg kCuklsV8P2d1p995u2TbJBKxVmZSjkYDAZz+75xx34yK9jyPlNGznLS8t/tUk0Y1C9skm/0BZo2b zApUknYRjjAJXkcDPOa9JsIrRbUPrK6bJbXMYeJZY0mkmVAQFTcu6LgAEHacleDgUPYe7OG1HUEm 1S9tNN0maKcRmGJ32rHCE3csoi3SMo3KGZs4TGegqDR4Nct9PvPLuFtYreeJDFbKwe6lJHQMuDjB OACVyTgDmh7aBddS1d3Ed9qGmiVZPPmiKPMbswsJ/PbJkEsOCDGAMYHXcGbpW2vgbw7dSG71e/it wrYf7TLLIVZlLrIVXOcFMEfMFBOUY8Ur6A93Yn1OTSfDktm8GgWkyi2MazvN5yShXUiXaQhQrtUf dAbDE7skHmIvENu02pS3Hgi83vGr291bwNF5bvucOzbGkcMMAAsB8ynnqCwepoxafres2bxz6ksV pJDtWIyszq21m+eN0Urg7sbxgMwK7toryTxf4X1r7BbWel6xF5ZUwwxG3K+WzHbhndfLU4B+djtX zFJIwdrA/J79s74tfHPwT8LfEcPgktDeyXUmk+IWaBZpDbXkE9ufvhjCGLMrMQDvkBDAmv59fBw1 TxfqF1omqEjUbO5y7SoN8fODuB5BBBBz9DxxWTfKnJlSTlyxW50/jzw7pPgrSb/V9TZZEZUto082 NGmLj5mYHnCqCxIX0yPmzXn3g/x78cdChL+DvF3iHSvDt6ZLxbTSNSnh8iNiSV8mMqH3fewoyckl RzSheSTFUtCXKi7rvxs+MF1dpFH8ZNenu4lCM51m7LrycgrI4ZDnOVKqfbvXn1z8bvi/DeGbUfF9 5dykMh/tBvtAIK7D/rc87Rt+gA7VrZdTOT87o6DR/jBBqsdrba5a+SY8qJI1VkHI6qR8o6klfU4U ck99qEGp2cMVpBqSyRXDrcpFb3yyptKgo5ETMgOOeSCMHOOKRkzMbS2n82O4M0cm8rKQzMS3qpL8 gnPcH035xWTe6dArhZEuN+3IJh5QZ4BIY88dgOceuAXEie3vX0zeYrdnccZe3BJB4OQVJ7Hk88/l o3M19qaPJFf3CBiQTnaQOoAGF7f0p30Fyq5zE3hdonluJFWRs7su7M4688jLflyc9K0I9LsJoxFL C0dyuMlLUHHUfNlwMZwD+fXip9SvIYNJs5DIkVvllAR03jcp7Edup49Rg0zTvD0FsZ4Z4mjhc53S SHcG+6AMDB69fegDbsYLSzt54YBDMillXzQWCMRkdCST9ccY4qt/b1ttittRtBHGWyGjLKsucZII Bxwe44H0GUItLrOjSJHD80T7jzKwdNuMDDKARnngrjpya4vxObZrqe3gCtbuiyboyXG765IH5U9Q bOf06AzkxzuscQySzAknPpz15z26fhW5NplgmnzX6KxKsC3mL5ZVTkL0bk557cYxk8UxbmA0d29r 9rQqRkKoHmDgnqCeM5wP8irsG+3t0lAZYJCHbkFS4BA+XHUbj36Z+lILFprWMo9y0isfMy0YXkE9 dzDp3I5OcHOKytes40ilazkMqKBIqBsdACB9RjH1FUkC3seMRwupJdeBxz/h1FX7ZpEmLIzK/OCp OcYPH64xTLOu8P8AirxB4au9Q1PQbuGG/ukMUrG3TYUJyyhQCI8/dJQKdpZPusyn6X8BTX3izQ9R 1ldRWw02xkVtUuL9G8mzdx9/epPnA8BehYuNoJY1DVi/iscZ41+L0enW9/4d8Cu4ikPkz+IJwV1L UogrqVQbj9kgk8xiYl6ggZxuU+W+G86pbXWito7XN3ckCxCZZ7WQkEsB3LAAE9wo9MU1aOrB3loj 91P2QfgfbfsyfDeT4m+MradPidq8KLaW2URrO3l2+Wsu7JVpC0e1WGcHgMzBV+xf2cf2ufD+l+KZ vCWt+K1srNpJbiBLqORC8R3MnKB1eJtiAq4ZE84MAV87bmnbU0uublP2cg8W6VbaVbRS3VlBC8Bu EjjS43FG3RqyRsjKpbeZWXciAEZG5UWs7SbaW+uYJNJgaW684AeYceWzoBwS4Q4Kk5yMkKcHlRoh vQ9IvdSudJia0vVmimnhALQSyIrbtxTdu3FgFxlCFPQHBJNN0/wvJfz3Ut9qTLbzTs4jlgjhDjG9 crvATcCSBnkdM4wWu4maWp+FtHsmIsbuYC4jOXjWQLkDD9DuzyQTnuDjGM1RZ3uoawLBPltpJfOc +e8+1VZm+ZyQZCBuyVkVTkEY60rh5C6jZanqFu0t7dIyRfKZXuHwoLDAfKjOSfvEE8kHgABnhe6d 7u0n0yRXng3t9nEHnEoCdwZZEKsoBGRgqASe5yDJp/EBibU7fw/aQgbFgeaNCpnXHzDIxlflClTx ghQCQTVnT9PttcnCa7ePbQK6wW9rZptV8uu8F0QlioJfgYz6ZwX5i20OL1p9HsNTudGjt5WsLDzc JHFiSZCx483YBk/LjKAsDgDkCvwh/wCCrHwNj8bfDC++Jvh1ZYtU8PxTJPDbJNOot45YAfOZiIig LyPHIjzODuQKBIMYV4c1OSfU7MFVdKvConsz+a0XKyQw7bpFuY2BMe0ly2ec5Un05JGAB36sbUJG KC0inYlwqkRsWB+8O4PuAD6nvXy7p+876W7/ANbH6Uq96acXdtLZeWq9f6vczPtdx5UttHBgl1IG 9t8jAHaCD2AJXPGQRznrBFFcyFikUifICyqpJwfmz15AIz/31Wy5YJ3f9f5I5H7Sbso2/H+myyp2 tHukJjR1/dswfPAGMpgjpjH0xnFSQabZ3AzcF2XLEEbE+UZyeep4zx0Kkd+Ic5R1jv8A103NI0Y1 PdqP+vXb+rFn+z7KwgElmvODltm8ISozklPlxu+oypGaYkcUe4Idq/xlBjJIPTdjHHp3B9cVHPOa 5pb/AIfdqaqjSpWhDZf1voMWMTKrTWSm3VSQd3QE7eoADDp74OaT7Npn/PnH+v8A8VVc0lpGRDp0 5WdSnqX7aO5jlVtiKrjOF5VUORj157AkcZzkYrTtra5FsJZ2ZYwxKsxwTkjK5zkklQewPJzWFSUX qjsowmlZ7a7bf1+IRvGrSIkoO1FdsFhhiQOACc5IHHHpkYFSyXU86RTCMMR8q7iu0FRj+HAxwCTx zz3Oc3G7vI1U9LR1Rl291LBc7/Lj2gkqQpkUYUjJ42tzz06jHfnSFx58kk0sbKhX7yuFJbA5xsJC 5AOMDA6HNXJJNNPp/WhFNvWLWl+nb1/y3Pd/gH4s0TwN8XPhX441S4jttP0TX7DWZZdQhmuYJvsk wuGR0QB2WQR7NucAthmUElf6qfgDrfiPxlpt7rln4hRbXTY4opppJm81ygMaoiFdxATdgfImECk7 iqn2sll7tSMt9D5HiuH7yjUitLWPsTQl1PRCstjewiY/6YGeMo1uSSyhtvyxnpgA8F156hc7VdN8 68tLm61WT+1ZJE3NJMzCfcD3CbCQwJLGQgBgCMhq9zqfHbJ2PZYpNLs/DrXyXa/2lDbo/wAsaAqE QKcqcd9q5DYwQdhySOU/4SbUvEGp6UbG3ne6iCqJZArLLgcozso3gBGwXY4Ck8EFibsVtLkNjpUv h3VJpAY7u7dNm2RXT7EWID+bvBOcMyYzj+Jm+UrV3XZp7/xM1pZ2kEUCxDzXJuGdlCHeN2zc24bj lhxgfMFFHUe+pT1LS9PWzLavdg6if9FktobqEBx5j4A2IC+HjyWy5O0EnkVjyLpNpa6fAjNNOkyt MixArGWXG071GcbTxgjkkYxlgL2R1Hh59BjS2nsmlSMxo4jsdPEsiFSiGRnlxtYvIq4U9ThSeKbe eI9VuL6fTrGC4S4Abc9xDCjqzHawlfqAQAwD8jJ+X5txW7C2lzlbqz8eW2nMmm6lb4acNL9mmzjG 1BlgfLAwWwRlsqc8EGvP/Ev/AAl2p3dvFFrqXOkrIls5ee3SQiPCjy/NYNnhdpJHy9lAaq03Ej4r /a+h8P6D8Ovi3cwf2e+lTaHfT+Ul0s4WV4ZXVGieQlnBAXcqBUCR5O45r+TTwb8SofDnxDvtfvrf On3itHdhRuMjcN5nzHbuZ1yc8fOegrKcb3RXPblZ7R4X1TwL4nsPEXiT4v29zrPh26uUn0OxtNbF vNpce7B3wtGBMwzsIZGWRVfGBtkGZZ6vi8uYPCK/bdIMqkSXNpGknJ2hJsFguSQBl9hyO44pe6rI yqPnd76nLeIvCuh32s3EHi5Lix1FCzJNHbwyg4+9sZZUV03krvjkOeflryLxD4fh0yFIotajupnH mGFAQIDyNhZlAYjjgAr0+Y80eZnsc7YeG0vEkmUNbXUcMryF3V42I5UZA/d5HygkuC+0fKDx6J4A 1Ga60aWOTUkhaEARFxK2euVG3IHYcihlWTiehi5trV4w2qxTlgfmU3S45wOpXngn/OKjXxLpUMsE clojBGy0zM5LN+LHIySTyOvtQ0QmZf2ua5uQ8F4kSO5KRKtxlVBzjLEjuOemTXQaM+ng3rX32q4Z 1ZY2ilSILuYEMwMTFxgHgEYJBzjqK3VBqVb+RISyQTbAQcfMknKnIGGIznGOM+/as2fUZLT7LdGZ kZ5I4yrpEUAweQhHfH+elF9bB01LM+rL50FxffZzbrIuXijUbjkfewMFepxkfrznSa813b+SjLCG nL+YELb/AOILhVOSSOMnHIzxmjcDCutSs7hjBLAFuF4LIpQ9evy8gj8elZIuZUQjy8xjorB2D88H v7jqM9aQXuEU8MUUbQjHXzV3j73ODtIPGCBz3zzTn1YSIUS624yFVYUA2+nBA9eMcZNNPsJk1neW twmHjke+bnLMuCfoU4znqPStW4SzltBODJbbl2uVRNz9QRtyMjkY46ZOKOgHO/aoNB1C5j8uO4ha NkJmR0CkrjdsUn5gSOuR7VsaZf63q/h6WzjncLBIEjEKJHEY2O4rIwwB83ILddzdCQCAuyLX9m2d v5QeaN5niAljgkWVsjBUllOzpxw2R3GaS38OyWphmu4ZZbKVJFVVk2N5hjcxvuKuCFYqWUAblG0M pbcotSnGyuznPEPw+jdoZ9JvUkaUZ8tVcFfqCBjv6/h0rhZPD+qaTcBdQsJAobDAqe2CR9fY+1V0 0KTuf0L/ALOf7BX/AAT3/wCClfgz4eeB/wBl7xJ47+HP7YsegOmreFtWs38QaR4o1m3g/wCYdcrH bx2NvcbTcvLeXytD+8gjt7grHJL+IPxl8O+Pvhbr+u/AXWPGM2o6D4f1q9ENvbvdrYtOXET3MEM6 pgTpDC4fYCyGLPIwJi1szSUbarYi+E/wE8XfFTW4tPsmjs9NA3Xl5dv5cdtGAWy2epO3CqOWYgDk 1+yXwE+Fvwb/AGbLA6lbQw6z4+fCHVrq2ydPKgsrW4Zcop3bWkOwsNoxjc1KTu7CirE37RvxBlvG SbRGvI7KWNY2WYZLOEG5mCj5QSCdoztHl4Y45+Atb8T61NqtpryTo2r2xUwXCDa6hW+UttxlwQOS CSRnPAqFsKb97Q/ZT9iD9quy8S29povjaNJXjdYVS4bJjkVc7ME4ZGGCuQclCp6c/uvb+OWh8M6S dK0m2htIkaVIUS3BZAd0bA+UrsF8xsSMWPUDbsOLjtY0+JJlXTrq+8RXVxcX0jpfOQ4xGhjSMngD DBVXAGOv8IGK9DsdOa0hv4dS12M4iZoV3OvmyBSqKpjLAnLBjxglcblBLVTAqXVxqMN0t/bWKFgh LRwCZ1AQZKgys755xgFgSMjjNbiePLHRLSGJmukeRyyxrZKUKMNry+bIWKuSqg4RvudRjFLfQelz gzqVnqd1di5aWaNsGOEOdyLyAXKgZZdwIOMEk8dQeobSdFt9Cs9UVTFdoygBJGBdcnLAHgtjgHIx jjBwS9hdBkFpeTwMuhwSW+lh1kSS4nQbGA2xsoUbmxtOSu4k8nkCtfRNPvrHRtRu7i/eDWHYQzyq IyHgkU7QI5AGbPfaWyB2yuU9rAnrc88v7fQLbUtSuLu+Et467oomgJPGFCkDeDg8hiVBC464x85/ tEeEtG8beHtV8P6jpX23Tb+1NkiiKQxrCyNGzubdt+wswDBCxJbGNwUGZq6sa09JXP4pviP4LT4d fE3xp4TvdLERhuJ4xE8omDI77kKthtm5DGcZLLuwzA5A4SO3hA3eXmKMhT8+4yYJOOnHHpnp6Zr5 XE88a0rn6Xl3sp4Sm7DJ1tnkWFFQDBDDJULjHDHIBGeMg5xjAyMVUuL2USFXnjWIsFbIHIYnkkAn dx168VnGLlZS3/r+tzqnNRvKNktv6/4C1HtFJdq4smX5SzRovzMFxuBwB8w2k9QOCc+lR+TKStuF mdWXzFABZ0UBsDJIBBzk4Hqfc1dJWe/9f1/wxnyycuZbPt/X9fMdGltGiLM6GTcHDKQwTgEggjn7 3f1PXGasPKGmIjaeNFcR7Q4c8nG3jA5AAJ7lenPEvmd29vMtKEbRT10vb+v+GH3IiRMRygzEgSGW RSOOvK88Zx2JGfbFPEf/AD3s/wDvqX/4qlHmavr8l/mKo4qVvd+b/wAiWRJXnWJI9iNu2BeQEPzd cggdOTj17EVogRxok125xyEj3IyuoLryQxAYkA+p57EZUmrJLc0je75lZf15kLSacrvDDLv3LtQu p3Ln+IEZAOBjvwTgAjNV2vrK3S2MsbjJ2OSi54yTgk5PPBOOMkUKFSVlsxOrSp3e6/r+vuQi3kDQ ExR7ptxC5UONgwSCd2SOo+XsDVr7bdNcHKlHQk7yNuwKegBJyRkYHtz1odNfbev9dBxrN/BHT+tb 3LUtpPE1qt3amN5VVk83cAynJBAOOOPUf99Cv6b/APgl98XdOP7P+j6Bq8+pav4lg1WWz8l23rGy kfZocmQsyANGvAVwjbYwuwF/Tyma9s0npZngcS0v9kjOXSS/I/WeLRLG71OeTW9dhRyNgtoZ1Yyx DAIVkcgFiQ3zAL1Ocgqe21CDwpaafoYn8TWDLGjRxpqM0iyAxeaFVlkJUMAANqArhUDZIzX0N7Hw erdkjBfVbzVtXlm0ixZYI4DEN6oXILESHeip5g3F8bhwvByF46fTYfFH2Oe5S0sZvuSO80kaLK4A yHjnCk7SxG4KfmBwWHzUaE9bHO382taprUawi1sboxpFIY5XKluSzKQF4z06DLEc43HfuvBLQaLY yNrzPMtubgj7YuMOFkI2BjjsDgYwgODngbsPqUJYNCt7OxkbR5rq2Co0xa7lRJWOdrt84+VQWC7e dxGR8207tuukJLHd6t4XntNCndJUkkR4AyAlnWEtwV2lwpXk7jk/MaOlxb6FfXLzTJbiBNGwlpHB JJGY5iJLYqvygNmPEhIGQpbcWyobpWZDbeK7G5t9bt4JF/dtKyzFJWYhi5ODnC4ViN+7IGeeCDQZ Z1vxB4i8SxwWlxYfZrfzS7m3tERGUHJLeUqg7VQnJABzn+ImsOXwzFr9lH4avrz/AIlsCG6Se0u5 UjHmtGJPkaM8hlAJAyWQEbhswaWEfm9/wUH0qz+G3wR+K39g6pK0osbi2vAbdXV2mVU8oyFFdWUE 8NnDJwBkk/yY638YF1j4HeGPgdd+D9Njm0XxVqfiSw1+EOl639o21jb3VrcnJSaEHTbSSHhTEzXP 3xN8g0KVrJnL+HfEA1IwaZd3ix3eBHG0rbVY9FHp/jXqVzaaj4VisrvUtDuLa4mbFrqVvdNEkihc lhuUlicj5g4UAkYPafIyfcy4tbRormW7v57q0JYpbvIqFzjCsX2PuOCcgquegYE8cbJcJO1sJFib yn3ukqlUKgnO7aVOCOrA5wOCMUCucHrGvzXoj0uwY/2UrBsAbfPcD7x9epAHYdsk16H8HprlJtUW 21CWCNoyrGNuWBwGABZc5yMjIyB6Ch7ldGj1sq0ETNPdRm4D5XfjaW3c565PPB3cfpT8ac8Dyt5Y uXyAE8tiFxjAznBPsAePekSYU9h5D2zTNJskb+EFAidd3AOeCO3QVoXR063tgyatI8R4URncFDZ9 89Pb3ptgZURgvEBhm3LHl9xZslcj1H0qh4jIisYXM6MyzgK3UFcNzwPUD8O3oWFoctc6zdXKfZnT EbkFgCF3Ht7deenf3rNH2qAOvmsuSQY2fuMjp6j8OKLdQJY7S9kkAEGXxn5uPx6Z/wD11qD7dCJf NVkOM/MOD2OR+Z/OgCsWdk/eqjMOB8zjaMDt06YH4VkXEEI37HIYYPzNjbjv7ZpMXqQWiXnmr/pj lDyNpD5OML1I/OutN1DYwx6bfTrMJAJJBGoJgI7Zzgn1/wAmgEaA1XSQQllpULvtOx54xIScdCrK R/wLHB9Kixb3t5p8WoeWEeRYG/ef6s8YJXPGMjsB1HY09OxalbY+jPhb4K8OodYsvEWlRzeVKPJZ 5xG21T82IvMy3Y7sf3gDwceseJvhxoPiPfLpV0kciKyTxsCckDlTzxgY6d8D1qL66D3Vz5y1nwlf aVdnZbbkTkSqMh1JyoXjbkknBA7jmoTFBJEm6EkqTyRu5HUEHII49untWiZGzue8/Cv9oD47fAPR td0b4PfGfxL4Z0DWvLk1K08M+KL/AEyPUGiGFNxDZTIHKh2G6RTwzAHk55rxH4si+I/ibU/HnjhL jUfGF9cPfXup6jd3F/canM7hmeeWeRnkbry2Se5OQQupXM2rHQ+HPEgsTFa6ZsjSILJDsj28jhju YFlyGIZQQDxxkA17tpWpS31mqLGhRYlGxS2N53dcks2PMOGYk4yM8YqZu2prTV9za+Pkl7F4H8C6 3GVaOaxUTO9uipbNG0sZVDgh/kMT7+Dvcjqua+Frm8uNQknu4yscR5GFQA5wPlRQFxnoAMAdOOkw 2Jq/Edb8NvFj+DPEsOqJdOsLo0DsHfcQcOBtUjcFZVYA5GcdOo/pn/ZN/aA1j4xeFLOyfxBaRa5b WkS381y8Z84O27zgIk3LtUoZPvbWDOSM8UnrcdN3jys+75v7fEy3U+rR3DLGZGRo7iVRInOW2BlL HD/MNy4zuIJwEij8d6ktsr2jR3ZVBGktr5UZQkksCBkA8jO3OR0Kg1d0aHps2p3Ol2WlLqsktprb KzzGQSSC5Yu67Y0KqqqygAhgSSvGBhVh1LRbvUDbS6fcRzPKrsJY4pCGT5g67HQByCCAVPXnnIYC 6C8ytpugW+ivc3U8MCSyNvfzGgEgicZDKrNl2O0cAcg4yu6kuNZtxcpDcq0iFlYLIiHyuSxOQTvP zFST1GeOuDd6gdXY63vsTcW8dnHZP/oxUmMzxKw7FnyQck7SuPl+XaSSOJGkWmvav9nlljtLEuxa STzCI4852qQGY9cbv54GRAyzrXg3w/o7Xen6nNNCzNFvkdZMRktjK5w5UgsCCpDFSMZAx5df6NoM pntIdKaadlaWZraaVpJgivkmYO5ZTh1IynBYjjJC82Um0rH82P8AwVX/AGevFdp4o0T45/2HpFrY 30U/9pTWMNys9wNxMc1wR+5+7mEeW2QUZWAOCfxgkj+0wJI6yZ+VEJRc45PXseODz0HPNfOZlD2e I511PvuHqqrYP2O9iFZItsUBkEbrhTISy5xyGOcenAz0PqKc0dq8sZjZ5gNu3aoZgOeAM8kY6eoy cVwe+tfxPdXsno9X2/4cJFSaSSG3tUWSZ9wlmlJ2LzycA8HOenPPTpWY0kschkM6M5H71DLvzwMA gc5B478gYxVRts3d+hlVuveSSXr8y0Iru8RTJbCJkcqoOIwST2BIbIJ7dA3tTZ7e1jm2bBFPhQUV XJUjkkAcA/L29Pei7UuWDvb+tx8sZR56qtf718l37Msi6cCOPy2dEwAzQ8HGAoG0Ajjkc9C3c1P9 tk/590/79Tf41Ps49X9z/wAyvau+kfvX+VjKkN5NM9xIx80OzhmIOQeOjjnOc8+vbOaI1vHaNopI +QPmjjJ3cEY4yp+XrkZ49q1bprdbf16GCjVk/de/z+7qSysfk8+DKkhgSMgnjkEccnOTyOBjjNNj hQxvMkHlzq4YlWyWKj2OQByT9MdgaV7LRlOKfxLVf0vUiaSRC623BPPmYAJwf4SR75x15BNaMcUu IjJHK5zxiXZj0BGPvA9ByOcZHFKbSXn95VNSk/L7v6/y+42NH02+nMn2YSNKFDbIlJIUfN0XnGec 9OhPXB/Zb/gl94q066ufGXgS6hEd/DNHqVuzzwgW4meO2aTYzAkxuUkOEckKo27NxG+XVUsYrf1o cOe0HLK536Nfnsf0ReD/AArbadax3Gt2s81g2YPPmR4Ftk/eorORnMiOULAnC5KbckbN7SoRLJbP pMIjtYZFnW4uIPMeBP8AlmEyRkDqAMbupxtzX1fxI/Npe62eiaRrV09zd/2THJPNCOPtAitSYm2o oO5sfcwAg7HqQKl1y98URy6cYpJrO3Z40WSKaQKhL7gWQcoQDuCcMQu7bk4pCOf13Q5tbnh1nU7w iSMhJZNzMJGw2dzEcPnb0ZiPmyc1b1OOO50pbC1TZbxyPJDcPNgohVcJkbSfmXlmyQR8uASCdhG3 pt3BGluBbNNqSxJHKhcTiIBIyGD/ADEbssrRhlC7dvUkCjejbJqOoWuiXbaS/lEySRoiSM4JkKKU G35jgYJ4U4LCkNFaO38UXOotMJGSylYNI0sCbp0Mm/PyMoYgjdt3KpKg7lwMXdZuNemtjb3GuWVr KWE7WqG6CzMCyqu3yyCzDBGWxjAYjJFPysCsaeleFzq+mNc6neXa/MfKkCMd7YBRXyQoBCttGcjn 5scjyr4h6Bq/gm2lhhvI5POyk0YWZGWRAQ5zMm0sGxuAzg56dCXWxKPza/bS02Hxh8E/F3gXwhaX +oePb2ylWPTZ5UY28cYQ/e2IJGb5tuMY2quCcZ/kE8ZeFtU8P6reW15YSwXKMRNBIrJJCw67lbnF DeopLQ4zy8kboyeAQef8mu50TxRruliKK6Q3mkEKpinBLLGP4Y5MEpxxgfL6g4oaIPf/AAjo/wAM vGul3r2viVdP8RRQO9vpV4NpuJRswkcpIjYEEkbmViY2GzJXPkXxWs9W8La9rHgrWdNew8R2VzLa 6pC8LQPHIrYMbREL5RByGjwMFcY6iklqFjyixt45pisys2FIGO7YO3r2zj8K9z8GaI2lWwfykYjJ yQfmJxnHbA7H+YPCe4PSJsie+u5Z2CeWocKrNuwwBGOBzxx0/pWhFaXV1NbRmzaYMuxhmTcxyQMD 5vUH8B0zQQek3ulRaFZPHeQsLmSJMJIWYxIemDgtwCOemK8o1HRLSZ5J7VlMarl3lkOEXPryep7d eaSG9ibTo1s/3UF2PsshEmFkXoByQO57YPPQVha3PNcz7rPTrlIlU7pJA5PPPpjHXr2p3Ynscy4I VfMVRkjktjPuWXg/l3qxBPDCIJDu80Nu2K2QfQkcE89sUCNc6vb3Tlr1VwCzBI0CKXOOQuAFJAGc egpDNaSrbl7ecMrfvMujZHbbxwR9aAIbuS2FuDBqTmRid0cq/cAPGWGenoPrXOo8jSKvlgKSRkgE HPHJ/wD1UDM9GAaVhJtKnAUHBz+ea1YN/mTHBK8e6jn03c+nNAiJ2jMkjI43JydjHb/LFRm7TClx nGPnXIK9eBgnP5dqYj3LSfHdrbwalqcl6g1lXtpYC/zpMjh1uFdRlRxIuVwo5cdyK928M/Eezs7W 21SwhaeCVFeZFt8eXM3zFMsxL4Xac4IxtJwcis2jVOx6RqniGHx5pUFlPujEbGZYxMzRKzYVmC5A DYVQeOij0r551jQDocskUH7+3Z2AYD5cnJOTyevPA+ppxfQT7nPLp8l3cQ28BXzl2liAyY9ABz6d 8e1elL4Vvzpn29rbn7qv2IIwSAM5x2zz+NU2kKKbItN8+xu/Lu4WEedqF/qOOle3eD7qRH8qZcJv 2qFIOf4TyDnoODz+ZpSRrTfTqez/ALUFxap8Hvg7BaXlu27RGjdmYF0kW+uWaMgRjDCN4WwWc453 4O1fzmlnt0kYFDvPcEkN+pH/AOusqduV27v8xV3Ln17L8ist3v48wAA8AAf/AFuOf5V97/sL/HK9 8D/E7w5Y6hqCx2Mcvy9mkiJwYxlipbcVYfKc4IOB1vdXFTdpI/qa0fU5PFVnJFp2k291agy3KXNv dqIbtlJOVcBhhVHTfnBXIJYbvQ5U0axuftttCTaQyNCUZvNMRBGdxtnCMd3Tb3VuuNxo3vbU53Ut WOpxyC002FIodpRZFyfvNknJ3HlwAfmwFUZ4zXd2Vpfw6PPrscs0rbBFIUYv5IcEoZJZFwW7bVHS Mk4IJNdCTmPE2nwxapNFLq0rpCm2QvB5ZJAAGwguGGOQQeccHBydXw1dW9rpsZfw7FO88qpby3U7 KzcYaRArEABmx8/B2kYG1loB9iLUfEeoapctbw2sMcyJ5EavcKgUZGRCu4bQcHHygkAjHWtGy0eV mddUbyZzsdCsoBjcoN+5TGASCcYyB8vBOAaAMfVo2nlOmfZptRnMv2rej4VImOzBGScZ2HndyTgj PzQz6d4murS70m20n7Gk0saCO0+YSSKcBgERlIUblG11yXBBHIKY1Z7s+Yv2pf2aIPif8H/G3hfX 9bs7LUrrTmnXULuX7PHA+5JIyElR1YFofKU/NyoG8krX8QWs6EfDOveIfDLTC6isbqa3E8TB1k8q UxMwZSVwWXAKsylgCCynJ8nNI+5GR9Tw3V/fTp62K95BHbGNIyrwlFc/PvESnqu4kAlSedo5ORnG RUPnom2BJZFYuAB5hYkE915Xrk545IwOa8BXl/X9f5n2ztHR6fP+r/kZCLGyiM25OHGflb5iOFJz 0GCOnZmxV4JdmRYGcJCoLBQcsBnHG4+uB7Bc+taycftamUVO3u6d9/6uRzy2KPiVsY/v9QNoyenQ kk9Bnn0qmNVtmcfvw8kbfu3DqM5GfTczZ4zn8emKjTnJXa0MqtelTly31b/r7v8AgEcmoz5lktbe L7RJhAVCv0ycktk5PHIPQ478V/tniD/nlH/3wP8ACtFTorSo3f1OaVbESd6UVb+mau8QiR7hHZh8 xXJygYjPHAXIDDGMNnvkEOgvRc7N16hwvHzthVyuQCFJBwe/OOfTOTjdc1rnT7VQfJzWb899f0/r YckbhDcMw8kqRncu4kEA4CjIHzADt2zUJu22PLuxG77MRI2BHkbtrEgj7xGPcck5ospP8CnJwX49 /wCv+GJU+0gyearZQM+1IxkEE8tkbfv4Hf05O0VZa/NokDJ5zYbkFDgchsE56Hg4B9G6ipcYysl/ X9feXGc4czd/u/r/AC7GhHHcPkzREPhd58sAochjwcYOD0GMng8HNfYP7HvjW48A/tA/C3xJe2kc 0r6nZWTvHN5c8ccjxwgQzOHCHYwAODgIOMJtJh6sKdem13DHYapXwVdS09177/16n9Znwp8Uv428 MwRo1xHYRubu5kuHkY3FwWJ3hY2Xdx86k9NoyXbkfQukan4F0o3+nRrPJNDtlSV4EZy/zKwdyQzo MBSw2HL7wg6D7JJ2Pyabu7F+68VavrLn7dC7WLKkwnWeKPARHyrDlC2C2Puty3BZqn1Lwz4p1iOb WdQv7qURQxu0l1IpeISfvAn33wCG3AswySPl5zTWxMkk9DhNGa2vJ0TU9OJjiRmb7PJIrTY/vbt6 jI6ME644r1Dwte6A13fumnAWMVv5OJI3kLSbUwUkG0K3y5yWAAJwD0pai3ZrX3ia0udQ09dIm26d Gyk/aSdodWAXDDzckAAfMWxyRjgDDkt9ZaWW9FrE9s8vnRkyr88auy5KD5gWJyVfBIXJHQgWgeR1 2rXHiq1MWn6Q2nyWkxjBNvMJEtx8+3ib5lAILbVOCWwD8208n/wjGta/f3N3q11HNYRkIXiZQ0wV lVsEZDM2S25ic569BT03B9kZviDRLvSrmCymvruznAaLZcO8RTDPEVwqDdwmxiGAJbnGCD57rOtP pNrc22p3pMcS5eVpQszr8w2lS2Qx3beARkHIJOSLXcPJH5A/GD9prTfE3xl8TaD4dtnS+jumjN6x m+0TpkB0m3ArlXSRkYgNg5bcrIU8v+LnwZ+Cfx+H274k+HZI9dm2l/EFg3l6iuQCGbexE3YfvBIc NlTgq1Zt6j3PyR+Kn/BPz4ieH9Ylu/hVqcHiDw+RviO5LW8jOW+R4HblhsPzISDgHgtivrj9mz47 /Fb4cfDjSf2T/jn+w98N/H/ws1C/i0611LxNoFhpPiLQ47m6WWf7F4mh8t7Rn3Y+03huo4FBwFiD oavdIlWjI/bP4hf8Exf+CGdv8GdA/aDvvHV7pvivWYrRF+E/gf4ueFmvtAv71ysMU2oaxc3McttA +yK5vSyBYy1w0UIRoR+En/BSzw9+zX8QNP8Aht4j/Z48FaH4PuNDjPha/wDD0/jbWPFfijUoLISW UV5e6gmnQ6MbaNLBDClvdTygX6qjtaJbQWSXxaFSUeV33/rX/gH5peHvAlro5ku9Wt3mwowqOiFW PIJBB4x2689RW7qjPvaGEFVC4BbAVcgZxgk8c4x/9aq6nO3czlRorzNjK7gqoYDAbOCSO/AJIGSO B0Fen+D9Oupit0wCxBiHDHBTPJ56Z7/0qWCLfiPUbAalKJGdoBG4HKJt4+U5PAGdoI9Ce/I8w1e1
October 04, 2010 - Present
RV10-Archive.digest.vol-ha
