RV10-Archive.digest.vol-ia
January 30, 2011 - February 24, 2011
      of spares for down the road.  I paid $9 or so for mine, and I cracked
      one on install.  So I used a spare right away.  Once the bearings
      start to go....years down the road...it will be nice to just have
      a couple on hand to swap in so that all the holes line up.
      Not as critical for the square fans because they're pretty standard,
      but for a blower like this, you may want to not have to search for
      a match.
      (See David's post below)
      On 1/30/2011 3:33 PM, davidsoutpost(at)comcast.net wrote:
      I just finished this area up last week. I used two of these
      http://www.surpluscenter.com/item.asp?item=16-1358&catname=electric for
      the defrosters and one for avionics cooling. I figure there is no need
      to add heat to the defrosters as they will scavenge enough from the
      avionics and the tunnel. 23 cfm each and they blow pretty good and are
      quiet,,,not that that will matter when the engine is running and
      headsets are on.
      David Clifford
      RV-10 Builder
      N849RV (reserved)
Date: Jan 30, 2011
Subject: Duckwork HID lights
Again with my Wig/Wag HID=92s I get noticed 7 miles out on approach in the day time. Dual flashing HID=92s may be one of the best safety vs. cost items on your build. Seeing is avoiding. Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick Lark *Sent:* Sunday, January 30, 2011 7:03 PM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: Duckwork HID lights Sam, I've only bought and are about to install one Duckworks light, for the left wing. Having said that I don't like night flying and avoid it when possible, so I don't expect to use it a lot. Also you can always install another after the aircraft is flying if you plan accordingly. I do know on e will be much brighter than the 2 lights in my Cessna Cardinal. Rick #40956 Southampton, Ont --- On *Sun, 1/30/11, ospreysammy * wrote: From: ospreysammy <helosammy(at)gmail.com> Subject: RV10-List: Duckwork HID lights Received: Sunday, January 30, 2011, 12:58 PM http://ca.mc1207.mail.yahoo.com/mc/compose?to=helosa mmy(at)gmail.com> > I am currently at the point of finishing up the outboard leading edges and I plan on using the Duckworks HID landing light system. This has led me to tw o questions; first since they are so bright, is one in each wing needed or would one in the left only work? I am thinking only using one would reduce weight, complexity, electrical load but would add asymmetry. Second questio n is, do I need to wait to rivet the outboard rib until the light kit is done ? I looked through Tim's outstanding writeup of his installation (thank you Tim) and it seems it may be easier to do the light kit with that outboard rib removable. Any insight from experience would be appreciated. Thanks in advance. -------- Sam Clark Builder # 40972 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=328966#328966 --> http://www.matronics.com/Navigator?RV10-List great content also available via the Web nbsp; -Matt matronics.com/contribution" target=_blank> http://www.matronics.com/contri============== = * * * * ===========* ===========* ===========* ===========* * * ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: AHRS Mount angle
Date: Jan 31, 2011
The non-Sport versions of GRT have a separate AHRS and magnetometer to consider. The AHRS must be very close in roll and yaw alignment. While you want it to be close in pitch as well, however there is a pitch offset adjustment in 1 degree increments. If you need to make minor adjustments after your mount is fabricated, shims can be used. Van's sells an AHRS mount that goes behind the baggage bulkhead that guarantees alignment and has attach holes prepunched for several different AHRS units. The magnetometer also needs to be in alignment, especially with the yaw axis. Typical locations for that are either high in the tailcone or outboard in a wingtip. There's an alignment procedure for the magnetometer that can take out some of the effects from nearby ferrous materials but keep in mind that battery contactors, autopilot servos and trim servos are all little electromagnets that will potentially cause problems. When I installed my magnetometer I found that the level of the longerons was unacceptable because of the battery contactor. I wound up putting it on a small shelf attached to the top J-channels. The center J-channel gives a nice longitudinal reference for alignment. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329076#329076 ________________________________________________________________________________
Date: Jan 31, 2011
Since my install was in 2005 I established the plate on two angles across the longeron and then ran a fish line from the aft center of the tail cone to the front center of the tail cone. See before and after pictures ----- Original Message ----- From: "bcondrey" <bob.condrey(at)baesystems.com> Sent: Monday, January 31, 2011 8:50 AM Subject: RV10-List: Re: AHRS Mount angle > > The non-Sport versions of GRT have a separate AHRS and magnetometer to > consider. The AHRS must be very close in roll and yaw alignment. While > you want it to be close in pitch as well, however there is a pitch offset > adjustment in 1 degree increments. If you need to make minor adjustments > after your mount is fabricated, shims can be used. Van's sells an AHRS > mount that goes behind the baggage bulkhead that guarantees alignment and > has attach holes prepunched for several different AHRS units. > > The magnetometer also needs to be in alignment, especially with the yaw > axis. Typical locations for that are either high in the tailcone or > outboard in a wingtip. There's an alignment procedure for the > magnetometer that can take out some of the effects from nearby ferrous > materials but keep in mind that battery contactors, autopilot servos and > trim servos are all little electromagnets that will potentially cause > problems. When I installed my magnetometer I found that the level of the > longerons was unacceptable because of the battery contactor. I wound up > putting it on a small shelf attached to the top J-channels. The center > J-channel gives a nice longitudinal reference for alignment. > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329076#329076 > > > ________________________________________________________________________________
Subject: AHRS and magnatometer
Date: Jan 31, 2011
one more picture. ________________________________________________________________________________
Subject: Tank attach zees
Date: Jan 31, 2011
On page 18-4 step 1 we are instructed to rivet the nutplates to the fuel tank attach zees (T-1012's). Do we need to final drill the bolt holes to a certain size or are they the correct size already? My holes have paint in them from priming so at the least, I need to run a bit through them to get the paint out. Can someone with unprimed Zee's tell me what size the hole is? Sorry if this should be common knowledge but I wanted to make sure. Thanks in advance, Bill ________________________________________________________________________________
Date: Jan 31, 2011
Subject: AFS fuel flow system display changes
First, I'll preface by saying that I really like the equipment that these folks have for our planes and their customer service is top-notch - and I am an outsider not related to the company other than as a customer. Not bashing anyone here - just trying to get an understanding of who this change impacts and how it impacts them. My configuration started as a 3400EM - I have since upgraded to 3400sSP configuration (new processor and screen in addition to six-pack display) to have a set of backup instruments. The upgrade also included a Beta software release to fix a couple of last minute bugs in my system. Here's the scoop: I have 19 gallons per side for main tanks and 9 gallons per side for tip tanks for a total capacity of 56 gallons, with them all filled, the system reports 56 gallons available. Previously, the "Fuel Used" display only showed that fuel that has flowed through the flow-meter. If I only fill the mains, the system shows 38 gallons available and zero used. As I ran the engine for my flight, the "Fuel Used" display would increase from Zero by showing only fuel flowed through the flow meter. Now, the "Fuel Used" display shows the fuel that has flowed through the flow-meter plus the unfilled tanks. If I only fill the mains, the system shows 38 gallons available and 18 gallons used. As I ran the engine for my flight, the "Fuel Used" display would increase from 18 while adding the fuel that has subsequently flowed through the flow-meter. Somewhere during the flight, if I look at the "Fuel Used" display, I note that what is reported is getting close to what I just put in.....18 gallons early. Good safety margin - but not what I was expecting. I have queried the folks at AFS about this - they respond that the change was made in the interest of safety and to reduce confusion. Yes, I could simply not look at the "Fuel Used" display and only look at the "Fuel Available" display and cross check that with my fuel guages and time calculations for flight endurance planning purposes. I also asked for an optional flowed-only mode or to allow the user the choice of calculation methods (they still have the old code and it simply would be a system setting). I know that I am not the only one having trouble with this change - AFS indicated that they have received multiple indications of concern. Anyone else out there think this is an "odd change"? How are you (planning to) accomodating this? I am planning to try ignoring the "Fuel Used" display and see how that works....with a plan B of having multiple configurations (with and without tip-tanks) that I can upluad when Iplan to fuel the tiptanks. I don't expect them to change it back - but they may provide options if enough folks ask for it. Or, am I being overly picky about something that shouldn't matter - in the big picture? Your opinions please, Ralph Capen ________________________________________________________________________________
Subject: Re: defroster/defog
Date: Jan 31, 2011
DQpZb3UgbmVlZCB0byB0aGluayBhYm91dCB3aGVyZSB5b3UgbW91bnQgdGhlIGZhbnMgYXMgc29t ZSBhdmlvbmljcyB3aWxsIGJ1bXAgaW50byB0aGUgYmFjayBoYWxmIGJ1bGtoZWFkIHdoaWNoIHdp bGwgcHJlY2x1ZGUgbW91bnRpbmcgdGhlIGZhbiBpbiB0aGF0IGFyZWEgQUZURVIgeW91IGhhdmUg Y3V0IGEgbGFyZ2UgaG9sZSBpbiB0aGUgZGFzaGJvYXJkLiBGb3IgaW5zdGFuY2U6IE1vdW50aW5n IGEgR2FybmltIDQzMFcgb3IgYSBTTC00MCBpbiB0aGUgbWlkZGxlIHN0YWNrIHdpbGwgY2F1c2Ug dGhlbSB0byBydW4gb3V0IG9mIHJvb20gb24gdGhlaXIgYmFja3NpZGUgbmVjZXNzaXRhdGluZyBh IGN1dC1vdXQgaW4gdGhlIGJhY2sgaGFsZiBidWxraGVhZCBhbmQgcHJlbWF0dXJpbHkgaGl0dGlu ZyBhbnkgZmFucyBtb3VudGVkIGluIHRoYXQgYXJlYS4gIERvbid0IGFzayBob3cgSSBrbm93LiAN Cg0KRGF0ZTogTW9uLCAzMSBKYW4gMjAxMSAxMTo1Njo1NSAtMDgwMA0KU3ViamVjdDogUmU6IFJW MTAtTGlzdDogUmU6IGRlZnJvc3Rlci9kZWZvZw0KRnJvbTogcnYxMHJvYkBnbWFpbC5jb20NClRv OiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KDQpJIHRoaW5rIG15IGNlcnRpZmllZCBhdmlvbmlj cyBmYW4gY29udmVydHMgbW9zdCBvZiBpdHMgcG93ZXIgaW50byBub2lzZS4gIEkgYWN0dWFsbHkg cHVsbGVkIHRoZSBmdXNlIG9uIGl0IGFuZCB3b24ndCByZXBsYWNlIHVudGlsIHJpZ2h0IGJlZm9y ZSBmaXJzdCBmbGlnaHQ7IG90aGVyd2lzZSwgaXQncyByZWFsbHkgYW5ub3lpbmcgd2hlbiBJIGhh dmUgdGhlIG1hc3RlciBzd2l0Y2ggb24uDQoNCiANCi1Sb2INCg0KDQpPbiBTdW4sIEphbiAzMCwg MjAxMSBhdCA5OjA5IFBNLCBMZW5ueSBJc3phayA8bGVuYXJkQHJhcGlkZGVjaXNpb24uY29tPiB3 cm90ZToNCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIkxlbm55IElzemFrIiA8 bGVuYXJkQHJhcGlkZGVjaXNpb24uY29tPg0KDQoNClJvYmluLA0KDQpPbmUgb2YgdGhlbSB0aGVy ZSBuZWVkcyBpdHMgb3duIGFsdGVybmF0b3IgOikNCg0KQnkgdGhlIHdheSwgaSBoYXZlIGEgY2Vy dGlmaWVkIGF2aW9uaWNzIGZhbiBhbmQgaXQgcHVzaGVzIGhhbGYgdGhlIENGTXMgYXQgdHdpY2Ug dGhlIGFtcCBkcmF3IG9mIGEgY29tcHV0ZXIgZmFuLi4uIFRoZXNlIHRoaW5ncyBhcmUgYW1hemlu Zy4NCg0KTGVubnkNCg0KDQpbcXVvdGU9InJvYmluKGF0KVBhaW50VGhlV2ViLmNvbSJdVGhvc2Ug ZmFucyBhcmUgMjMgQ0ZNIG1heC4gVGhhdCBpcyBub3QgYSBzaWduaWZpY2FudCBhbW91bnQgb2Yg YWlyLg0KSSB0aGluayBlYWNoIG9mIG15IDgwIG9yIDkyIGNtIGZhbnMgd2VyZSBhYm92ZSAxMDAg Q0ZNLg0K77+9DQpIZXJl77+9cyBhbiA4MCBtbSBmYW4gd2l0aCA4NCBDRk0NCmh0dHA6Ly93d3cu bmV3ZWdnLmNvbS9Qcm9kdWN0L1Byb2R1Y3QuYXNweD9JdGVtPU44MkUxNjgxMTk5OTYxMiZjbV9y ZT1jb21wdXRlcl9mYW4tXy0xMS05OTktNjEyLV8tUHJvZHVjdCAoaHR0cDovL3d3dy5uZXdlZ2cu Y29tL1Byb2R1Y3QvUHJvZHVjdC5hc3B4P0l0ZW09TjgyRTE2ODExOTk5NjEyJmNtX3JlPWNvbXB1 dGVyX2Zhbi1fLTExLTk5OS02MTItXy1Qcm9kdWN0KQ0KDQrvv70NCkhlcmUgaXMgYSA5MiBtbSB3 aXRoIDkwIENGTQ0KaHR0cDovL3d3dy5uZXdlZ2cuY29tL1Byb2R1Y3QvUHJvZHVjdC5hc3B4P0l0 ZW09TjgyRTE2ODM1MjEzMDA5JmNtX3JlPWNvbXB1dGVyX2Zhbi1fLTM1LTIxMy0wMDktXy1Qcm9k dWN0IChodHRwOi8vd3d3Lm5ld2VnZy5jb20vUHJvZHVjdC9Qcm9kdWN0LmFzcHg/SXRlbT1OODJF MTY4MzUyMTMwMDkmY21fcmU9Y29tcHV0ZXJfZmFuLV8tMzUtMjEzLTAwOS1fLVByb2R1Y3QpDQoN Cu+/vQ0KSGVjayBoZXJlIGlzIGEgMTIwIG1tIHdpdGggMjQwIENGTS4gWUlLRVMhDQpodHRwOi8v d3d3Lm5ld2VnZy5jb20vUHJvZHVjdC9Qcm9kdWN0LmFzcHg/SXRlbT1OODJFMTY4MzUyMTMwMDEm Y21fcmU9Y29tcHV0ZXJfZmFuLV8tMzUtMjEzLTAwMS1fLVByb2R1Y3QgKGh0dHA6Ly93d3cubmV3 ZWdnLmNvbS9Qcm9kdWN0L1Byb2R1Y3QuYXNweD9JdGVtPU44MkUxNjgzNTIxMzAwMSZjbV9yZT1j b21wdXRlcl9mYW4tXy0zNS0yMTMtMDAxLV8tUHJvZHVjdCkNCg0K77+9DQogRGlzY2xhaW1lcjog UGxlYXNlIGRvIHlvdXIgb3duIHJlc2VhcmNoIGFzIEkgaGF2ZSBub3QgcmVhZCB0aGUgcHJvZHVj dCBkZXRhaWxzIGluIGRlcHRoIG9uIGFueSBvZiB0aGVzZSB1bml0cy4NCu+/vQ0KUm9iaW4NCkRv IE5vdCBBcmNoaXZlDQrvv70NCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNz LmNvbSAob3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tKSBbbWFpbHRvOm93bmVy LXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSAob3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tKV0gT24gQmVoYWxmIE9mIFRpbSBPbHNvbg0KDQogU2VudDogU3VuZGF5LCBK YW51YXJ5IDMwLCAyMDExIDc6MTMgUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSAocnYx MC1saXN0QG1hdHJvbmljcy5jb20pDQpTdWJqZWN0OiBSZTogZGVmcm9zdGVyL2RlZm9nDQoNCg0K DQog77+9DQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBUaW0gT2xzb24NCg0KRm9y IHRob3NlIHdobyBjb3VsZG4ndCB2aWV3IERhdmlkJ3MgcG9zdCwgSSd2ZSBjbGlwcGVkIG91dCB0 aGUgdGV4dA0KIGJlbG93IHNvIHlvdSBjYW4gc2VlIGl0Lu+/vSBMb29rcyBsaWtlIGEgZ3JlYXQg d2F5IHRvIGdvIGlmIHlvdSBjYW4NCmZpbmQgYSBnb29kIG1vdW50aW5nIGZvciBpdC7vv70gQXQg JDYsIHRoZSBwcmljZSBpc24ndCBiYWQgYXQgYWxsLg0KDQpNeSBhZHZpY2UgaXMgdGhhdCB3aGVu IHlvdSBkbyBmaW5kIGEgZmFuIHlvdSBsaWtlLCBidXkgYSBjb3VwbGUNCm9mIHNwYXJlcyBmb3Ig ZG93biB0aGUgcm9hZC7vv70gSSBwYWlkICQ5IG9yIHNvIGZvciBtaW5lLCBhbmQgSSBjcmFja2Vk DQogb25lIG9uIGluc3RhbGwu77+9IFNvIEkgdXNlZCBhIHNwYXJlIHJpZ2h0IGF3YXku77+9IE9u Y2UgdGhlIGJlYXJpbmdzDQpzdGFydCB0byBnby4uLi55ZWFycyBkb3duIHRoZSByb2FkLi4uaXQg d2lsbCBiZSBuaWNlIHRvIGp1c3QgaGF2ZQ0KDQphIGNvdXBsZSBvbiBoYW5kIHRvIHN3YXAgaW4g c28gdGhhdCBhbGwgdGhlIGhvbGVzIGxpbmUgdXAuDQpOb3QgYXMgY3JpdGljYWwgZm9yIHRoZSBz cXVhcmUgZmFucyBiZWNhdXNlIHRoZXkncmUgcHJldHR5IHN0YW5kYXJkLA0KIGJ1dCBmb3IgYSBi bG93ZXIgbGlrZSB0aGlzLCB5b3UgbWF5IHdhbnQgdG8gbm90IGhhdmUgdG8gc2VhcmNoIGZvcg0K YSBtYXRjaC4NCg0KDQpUaW0NCg0KKFNlZSBEYXZpZCdzIHBvc3QgYmVsb3cpDQoNCg0KT24gMS8z MC8yMDExIDM6MzMgUE0sIGRhdmlkc291dHBvc3RAY29tY2FzdC5uZXQgKGRhdmlkc291dHBvc3RA Y29tY2FzdC5uZXQpIHdyb3RlOg0KDQogPg0KDQo+DQo+IEkganVzdCBmaW5pc2hlZCB0aGlzIGFy ZWEgdXAgbGFzdCB3ZWVrLiBJIHVzZWQgdHdvIG9mIHRoZXNlDQo+DQoNCmh0dHA6Ly93d3cuc3Vy cGx1c2NlbnRlci5jb20vaXRlbS5hc3A/aXRlbT0xNi0xMzU4JmNhdG5hbWU9ZWxlY3RyaWMgKGh0 dHA6Ly93d3cuc3VycGx1c2NlbnRlci5jb20vaXRlbS5hc3A/aXRlbT0xNi0xMzU4JmNhdG5hbWU9 ZWxlY3RyaWMpIGZvcg0KDQogdGhlIGRlZnJvc3RlcnMgYW5kIG9uZSBmb3IgYXZpb25pY3MgY29v bGluZy4gSSBmaWd1cmUgdGhlcmUgaXMgbm8gbmVlZA0KdG8gYWRkIGhlYXQgdG8gdGhlIGRlZnJv c3RlcnMgYXMgdGhleSB3aWxsIHNjYXZlbmdlIGVub3VnaCBmcm9tIHRoZQ0KYXZpb25pY3MgYW5k IHRoZSB0dW5uZWwuIDIzIGNmbSBlYWNoIGFuZCB0aGV5IGJsb3cgcHJldHR5IGdvb2QgYW5kIGFy ZQ0KcXVpZXQsLCxub3QgdGhhdCB0aGF0IHdpbGwgbWF0dGVyIHdoZW4gdGhlIGVuZ2luZSBpcyBy dW5uaW5nIGFuZA0KDQogaGVhZHNldHMgYXJlIG9uLg0KDQpEYXZpZCBDbGlmZm9yZA0KUlYtMTAg QnVpbGRlcg0KTjg0OVJWIChyZXNlcnZlZE5hdmlnYXRvciB0byBicm93c2UNCiBpY3MuY29tL05h dmlnYXRvcj9SVjEwLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYx MC1MaXN0DQoNCiB0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbSI+aHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tDQog77+977+977+977+977+977+977+977+977+977+977+977+977+9IC1NYXR0 IERyYWxsZSwgTGlzdCBBZG1pbi4NCg0KID09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0K DQpObyB2aXJ1cyBmb3VuZCBpbiB0aGlzIG1lc3NhZ2UuDQpDaGVja2VkIGJ5IEFWRyAtIHd3dy5h dmcuY29tIChodHRwOi8vd3d3LmF2Zy5jb20pDQoNClZlcnNpb246IDEwLjAuMTIwDQoNCj4gW2Jd DQoNCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTMyOTA1MSMzMjkwNTENCg0KdGllcyBzdWNo IGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQo6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0 b3I/UlYxMC1MaXN0IiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05h dmlnYXRvcj9SVjEwLUxpc3QNCg0KIGhyZWY9Imh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8i IHRhcmdldD0iX2JsYW5rIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KICAgICAgICAg ICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCg0KPT09PT0NCg0KDQoNCg0KDQoN Ci0tIA0KUm9iIEtvY2htYW4NClJWLTEwICJGaW5pc2hpbmciIEtpdA0KV29vZGludmlsbGUsIFdB IChuZWFyIFNlYXR0bGUpDQpodHRwOi8va29jaG1hbi5uZXQvTjgxOUsNCg0KDQoNCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUg TWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55 IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2 ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9z aGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNv IGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9y dW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1 cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExp c3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlv bg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KIAkJIAkgICAJCSAg ________________________________________________________________________________
Subject: Re: Tank attach zees
Date: Jan 31, 2011
If I had a memory I'd be dangerous. While building I have charts to check sizing. I do believe a K-1000-3 is for an AN 3 bolt. An an 3 bolt requires a #12 bit , going by memory. The Avery tool catalog had this information listed in it on page 57 a few years back. I think it is also in the red book from Van's. I can find out for sure if no one helps out, I'll have to go to the hangar. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329113#329113 ________________________________________________________________________________
Date: Jan 31, 2011
Date: Feb 01, 2011
Subject: Re: defroster/defog Pictures
David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: davidsoutpost(at)comcast.net Sent: Monday, January 31, 2011 5:46:03 PM Subject: Re: RV10-List: Re: defroster/defog Here a a few pics of my defroster and avionics cooling fans. Like I stated before, these things put out plenty of air. I also wanted my stack located in the center of the panel, hence the modifications to the center rib and inner panel. I made up some dimensional boxes out of cardboard to represent the avionics with the harness connections included and taped them together to be sure I had adequate clearance. David Clifford RV-10 Builder Howell, MI ________________________________________________________________________________
Subject: Re: Duckwork HID lights
Date: Jan 31, 2011
I have 2, although not wig-wags. I installed them after completing the leading edges with no problems. As long as they are off of the airplane I had no issues at all with access. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329146#329146 ________________________________________________________________________________
Date: Jan 31, 2011
Bill, as is said, timing is everything.- I just happened to prime my tank Zee's today.- - So there is a little epoxy primer in the holes, however it is not real hard yet.- Having said that, I was able to finger twirl a #13 drill bit but n ot a #12, as it seemed to catch some aluminum. - So since a #13 is .185", I expect the holes are .002 or .003" shy of a #12 hole.- I'd drill them if it were me. - Hope this helps. - Rick #40956 Southampton, Ont --- On Mon, 1/31/11, Billy & Tami Britton wrote: From: Billy & Tami Britton <william(at)gbta.net> Subject: RV10-List: Tank attach zees Received: Monday, January 31, 2011, 7:37 PM On page 18-4 step 1 we are instructed to rivet the nutplates to the fuel ta nk attach zees (T-1012's).- Do we need to final drill the bolt holes to a certain size or are they the correct size already? My holes have paint in them from priming so at the least, I need to run a b it through them to get the paint out.- Can someone with unprimed Zee's te ll me what size the hole is?- - Sorry if this should be common knowledge but I wanted to make sure. - Thanks in advance, Bill =0A=0A ________________________________________________________________________________
Date: Jan 31, 2011
Sam, as Robin states, you can't beat the HID's for recognition distance/bri ghtness. - I'm a little concerned about wig-waging the HID's so I am going to use the wing tip halogen lights as wig/wags.- If they don't perform as I hope, I can always change my lighting configuration. - I expect this aircraft will evolve as I fly it and I will need something to mess around with when I'm not flying anyway.- As everyone knows, that's the beauty of an experimental...... - Rick #40956 Southampton, Ont --- On Tue, 2/1/11, Eric_Kallio wrote: From: Eric_Kallio <scout019(at)msn.com> Subject: RV10-List: Re: Duckwork HID lights Received: Tuesday, February 1, 2011, 2:39 AM I have 2, although not wig-wags. I installed them after completing the lead ing edges with no problems. As long as they are off of the airplane I had n o issues at all with access. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329146#329146 le, List Admin. =0A=0A ________________________________________________________________________________
Date: Feb 01, 2011
Thanks all for the insight and advice. I went ahead and ordered two, I can't argue with the safety of being seen. I have crossed paths with quite a few light civil aircraft and some were closer than I would like before they were seen. Thanks again. -------- Sam Clark Builder # 40972 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329252#329252 ________________________________________________________________________________
Date: Feb 01, 2011
While we're talking about Duckworks lights, I know Tim suggests using the 35W D1S bulbs. Vans only has the 50w HID's on their website catalog. Are they the D1S style also or do we need to order directly from Duckworks? Bill -------------------------------------------------- From: "ospreysammy" <helosammy(at)gmail.com> Sent: Tuesday, February 01, 2011 7:49 PM Subject: RV10-List: Re: Duckwork HID lights > > Thanks all for the insight and advice. I went ahead and ordered two, I > can't argue with the safety of being seen. I have crossed paths with quite > a few light civil aircraft and some were closer than I would like before > they were seen. Thanks again. > > -------- > Sam Clark > Builder # 40972 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329252#329252 > > > ________________________________________________________________________________
Date: Feb 01, 2011
Thanks for the replies, looks like there is somewhat of a consensus to align with the same plane as the door sill so I will shim under the twin ahrs box as required. My mount is already a done deal I just wanted to make sure I should just go ahead and shim it level to the sill. -Chris #40072 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Monday, January 31, 2011 11:52 AM Subject: Re: RV10-List: Re: AHRS Mount angle Since my install was in 2005 I established the plate on two angles across the longeron and then ran a fish line from the aft center of the tail cone to the front center of the tail cone. See before and after pictures ----- Original Message ----- From: "bcondrey" <bob.condrey(at)baesystems.com> Sent: Monday, January 31, 2011 8:50 AM Subject: RV10-List: Re: AHRS Mount angle > --> > > The non-Sport versions of GRT have a separate AHRS and magnetometer to > consider. The AHRS must be very close in roll and yaw alignment. > While you want it to be close in pitch as well, however there is a > pitch offset adjustment in 1 degree increments. If you need to make > minor adjustments after your mount is fabricated, shims can be used. > Van's sells an AHRS mount that goes behind the baggage bulkhead that > guarantees alignment and has attach holes prepunched for several different AHRS units. > > The magnetometer also needs to be in alignment, especially with the > yaw axis. Typical locations for that are either high in the tailcone > or outboard in a wingtip. There's an alignment procedure for the > magnetometer that can take out some of the effects from nearby ferrous > materials but keep in mind that battery contactors, autopilot servos > and trim servos are all little electromagnets that will potentially > cause problems. When I installed my magnetometer I found that the > level of the longerons was unacceptable because of the battery > contactor. I wound up putting it on a small shelf attached to the top > J-channels. The center J-channel gives a nice longitudinal reference for alignment. > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329076#329076 > > > ________________________________________________________________________________
Subject: Pirep on Lord 7545A/E urethane adhesive
Date: Feb 02, 2011
For those that used the Lord 7545A/E urethane adhesive in lieu of Weld-On or other products, would you still recommend it? If so, how many 50ml paks are required for the windscreen and all the windows? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329328#329328 ________________________________________________________________________________
Subject: Front Seat Adjustment handles
Date: Feb 02, 2011
Anyone installed their seat adjustment T handles inboard and the seat back adjustment handles outboard which is opposite of Van's recommended locations? Just curious if doing so would cause any problems or is it a wash (ie doesn't hurt but really doesn't help either) so just stick to the plans? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329333#329333 ________________________________________________________________________________
Subject: Re: Front Seat Adjustment handles
Date: Feb 02, 2011
What's most important--bring the front/back seat adjustment forward on an extension--more like on autos. Very big difference and ease with moving seat. Someone had plans and actually sold these. Don't remember who. VERY nice--you'll wish you had a different arrangement than Vans designed. A few bruises on hand and scratched watch convinced me. larry -------- Larry and Gayle N104LG Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329336#329336 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Feb 02, 2011
I believe I was the first one to use this adhesive and I would use it again. I have 185hrs on my 10 now and everything is great. I did some test prior to using and I found the bond to be better than weld-on. The great thing about This is you can clean it up off the windows with PPG DT-870 reducer. This will not harm the acrylic or craze as the Weld-on can. This is a urethane Adhesive and is not as hard as weld-on so it will not crack as easy. We use this Lord adhesives for many other applications here as well with great results. I would get the 215ML if you can and get 4 to 5. The 50 ML will not Go far. You need about a 3/8" bead minimum al the way around the window frame. Go to album below there are some pictures http://combsfamily.phanfare.com/3161550_4534177#imageID=74040224 <http://combsfamily.phanfare.com/3161550_4534177%23imageID=74040224> Geoff Geoff Combs President 614-834-5227p 614-834-5230f www.aerosportmodeling.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tsts4 Sent: Wednesday, February 02, 2011 3:05 PM Subject: RV10-List: Pirep on Lord 7545A/E urethane adhesive For those that used the Lord 7545A/E urethane adhesive in lieu of Weld-On or other products, would you still recommend it? If so, how many 50ml paks are required for the windscreen and all the windows? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329328#329328 ________________________________________________________________________________
Subject: Re: Pirep on Lord 7545A/E urethane adhesive
Date: Feb 02, 2011
Thanks Geoff! -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329347#329347 ________________________________________________________________________________
Subject: RV-10 Door Handle covers
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Feb 02, 2011
Aerosport Products has completed and will be shipping the new Door handle covers designed for the stock Van's door handles. These handles and cover plates can be installed in minutes and dress up the not so nice looking interior door handle. The cover plate covers the gear box area. They will be available in 2 colors a Light tan and a Med Grey. These handles are made from ABS plastic and can be painted to match your interior colors. They will be available online at www.aerosportproducts.com On 2-7-11 Cost will be $95.00 per set. And $65.00 for just the door handle covers. Geoff -------- Geoff Combs RV-10 QB N829GW Flying 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329349#329349 Attachments: http://forums.matronics.com//files/doorhandleparts_493.jpg http://forums.matronics.com//files/doorhandle_175.jpg ________________________________________________________________________________
Date: Feb 02, 2011
Steve Dinieri still sells the forward seat adjustment handles on http://iflyrv10.com. I think Greg Hale invented those, and the plans or on his site at http://www.nwacaptain.com/seat_lever.html Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329372#329372 ________________________________________________________________________________
Subject: Re: RV-10 Door Handle covers
Date: Feb 02, 2011
aerosport1 wrote: > They will be available online at www.aerosportproducts.com On 2-7-11 Geoff underestimated his webmaster.... :D The RV-10 Door Handle Kits can be ordered online at: http://aerosportproducts.com/handles.htm bob -------- Bob Leffler N410BL - FWF RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329379#329379 ________________________________________________________________________________
Subject: Fuel quantity calibration problem
Date: Feb 02, 2011
I am trying to calibrate the fuel quantity levels on the GRT EIS 6000. I have the standard Vans floats in the tank. Before O call GRT in the morning I wanted to see if anyone else has had this issue... During calibration, following the sheet from GRT, I got AuxSF/Auxoff setting of 52/151 for the left tank and 79/225 for the right. These numbers seem a little higher than others have posted, but there may be more resistance in my circuit. During calibration of the tanks I had noticeable movement in the values on the EIS and on the EFIS. However, with the tanks full and the settings entered into the calibration menu, my tanks both read 2 gallons on the EIS. I have rechecked my numbers as well as my settings. I am set to integers and have actually had to set the sensors to reverse sensing because they were counting down when adding fuel. Any thoughts, or similar experiences out there? Eric Kallio 3 days until DAR...if I can get my fuel level calibrated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329394#329394 ________________________________________________________________________________
Subject: countersinking baffle holes
Date: Feb 03, 2011
On page 18-4 step 6 we countersink the tank skins to attach the tank baffles to. It tells us to leave every 10th hole uncountersunk for alignment issues (these holes are countersunk and riveted later, after proseal has cured). I guess I just don't understand why it's asking us to do this. Everything is final drilled and should line up perfectly. Is it just because of the added mess of the proseal??? Is this necessary to do or has anyone just countersunk all of them at once. Seems to me that countersinking and riveting after the proseal has cured is a sure way to try to make the tank leak. Thanks Bill ________________________________________________________________________________
Subject: Re: countersinking baffle holes
Date: Feb 03, 2011
A dimple or machine countersunk hole is enlarged to the point that your baffle will not seat properly. The seal is made with a nice layer/bead that pushes up in front of baffle bend line as you install it. I am sure some sealing takes place around the rivets too, but your main seal needs to be that inside corner. I just followed the plans, using almost 1 qt per tank. Just before baffles are installed I thinned sealant with toluene/toluol max 15% by wt then went over all joints and rivet shop heads. Then tested tanks to 1 psi with electronic manometer.(Water can be used too). -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 41 Fwd top fuse skin/panel Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329437#329437 ________________________________________________________________________________
Subject: Re: Fuel quantity calibration problem
Date: Feb 03, 2011
Check to ensure you have a good ground with star lockwasher under terminal at one of the six sender attachment screws. I'll be installing EIS this summer so keep us posted. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 41 Fwd top fuse skin/panel Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329438#329438 ________________________________________________________________________________
Date: Feb 03, 2011
Your right tank readings are a bit higher than mine but if they work they w ork. =0AI did my EIS twice before I got it and even after I did the math I had to adjust =0Athe right tank numbers to get it to read-the correct amo unt.-the numbers quit =0Aclimbing at 24 and25 gals so I used that as my f ull reading. I have the Cheltons =0Aand have yet to get them working right. One tank will read full and the other =0Aempty after calibration. Double c heck your math and see if you missed =0Asomething.-=0A=0A=0A=0A=0A_______ _________________________=0AFrom: Eric_Kallio <scout019(at)msn.com>=0ATo: rv10 -list(at)matronics.com=0ASent: Wed, February 2, 2011 6:25:55 PM=0ASubject: RV1 0-List: Fuel quantity calibration problem=0A=0A--> RV10-List message posted by: "Eric_Kallio" =0A=0AI am trying to calibrate the fue l quantity levels on the GRT EIS 6000. I have =0Athe standard Vans floats i n the tank. Before O call GRT in the morning I wanted =0Ato see if anyone e lse has had this issue...=0A=0ADuring calibration, following the sheet from GRT, I got AuxSF/Auxoff setting of =0A52/151 for the left tank and 79/225 for the right. These numbers seem a little =0Ahigher than others have poste d, but there may be more resistance in my circuit. =0ADuring calibration of the tanks I had noticeable movement in the values on the =0AEIS and on the EFIS. However, with the tanks full and the settings entered into =0Athe ca libration menu, my tanks both read 2 gallons on the EIS. I have rechecked =0Amy numbers as well as my settings. I am set to integers and have actuall y had to =0Aset the sensors to reverse sensing because they were counting d own when adding =0Afuel. =0A=0A=0AAny thoughts, or similar experiences out there?=0A=0AEric Kallio=0A3 days until DAR...if I can get my fuel level cal ibrated.=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matr - - - - - - - - - - - - - - - -Matt Dralle, L =========0A=0A=0A ________________________________________________________________________________
Subject: Nose gear slop
Date: Feb 03, 2011
After 238 hours I found that I have about a 1/2" of vertical slop in my nose gear. How difficult is it to add the spacers? Any good ideas on how to do this? Sheldon Olesen N475PV ________________________________________________________________________________
Subject: Re: Nose gear slop
Date: Feb 03, 2011
I just added another spacer to N256H. I had added one or two in the past and just added another. It is very easy, but you will need some help. You need to get the nose in the air so you can remove the cap that the spacer goes under so you don't have to remove the heater box controls. Then just add the spacer(s) as needed and compress the rubber donuts enough to get the bolt back in place and then put the bolt in and you're done. Very easy to do with a second set of hands. I compressed the donuts by jacking up slightly on the tail, but you can also do so by either adding weight to the nose or possibly a rachet strap between a hard point on the engine and the nose gear leg. Just FYI for those out there who are getting up in hours. I have now also tightened up the swivel on the nose fork at least 3 times on N256H. I am hoping the shimmy goes down now that I've added another spacer and tightened the swivel, but I'm sure it will. Basically, both of these items are not just one-time adjustments for once the parts take on a "permanent set", so keep your eyes on them and adjust as necessary. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 3, 2011, at 10:55 AM, Sheldon Olesen wrote: > > > After 238 hours I found that I have about a 1/2" of vertical slop in my nose gear. How difficult is it to add the spacers? Any good ideas on how to do this? > > Sheldon Olesen > N475PV > > > > > ________________________________________________________________________________
Date: Feb 03, 2011
On 2/3/2011 11:24 AM, Jesse Saint wrote: > --> RV10-List message posted by: Jesse Saint > > snip > Just FYI for those out there who are getting up in hours. I have now also tightened up the swivel on the nose fork at least 3 times on N256H. I am hoping the shimmy goes down now that I've added another spacer and tightened the swivel, but I'm sure it will. Basically, both of these items are not just one-time adjustments for once the parts take on a "permanent set", so keep your eyes on them and adjust as necessary. You can also add belleville washers and cup two at a time to increase the drag. Linn > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Feb 3, 2011, at 10:55 AM, Sheldon Olesen wrote: > >> --> RV10-List message posted by: Sheldon Olesen >> >> >> After 238 hours I found that I have about a 1/2" of vertical slop in my nose gear. How difficult is it to add the spacers? Any good ideas on how to do this? >> >> Sheldon Olesen >> N475PV >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 03, 2011
I think I've probably tightened the nosewheel swivel nut 3 times or so...and the last time I was in the low to mid 30's lb-ft of torque. Recently I had the nosewheel off the ground and found that it was still snug. You're very right that it'll take a few times to get this snugged up...but at least there is light at the end of the tunnel that it'll turn into an annual thing to check. The first 150 hours or so I think you'll want to check it at least 3 times in that period though. Tim Olson - RV-10 N104CD On 2/3/2011 10:24 AM, Jesse Saint wrote: > --> RV10-List message posted by: Jesse > Saint > > I just added another spacer to N256H. I had added one or two in the > past and just added another. It is very easy, but you will need some > help. You need to get the nose in the air so you can remove the cap > that the spacer goes under so you don't have to remove the heater box > controls. Then just add the spacer(s) as needed and compress the > rubber donuts enough to get the bolt back in place and then put the > bolt in and you're done. Very easy to do with a second set of hands. > I compressed the donuts by jacking up slightly on the tail, but you > can also do so by either adding weight to the nose or possibly a > rachet strap between a hard point on the engine and the nose gear > leg. > > Just FYI for those out there who are getting up in hours. I have now > also tightened up the swivel on the nose fork at least 3 times on > N256H. I am hoping the shimmy goes down now that I've added another > spacer and tightened the swivel, but I'm sure it will. Basically, > both of these items are not just one-time adjustments for once the > parts take on a "permanent set", so keep your eyes on them and adjust > as necessary. > > Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: > 352-427-0285 F: 815-377-3694 > > On Feb 3, 2011, at 10:55 AM, Sheldon Olesen wrote: > >> --> RV10-List message posted by: Sheldon >> Olesen >> >> >> After 238 hours I found that I have about a 1/2" of vertical slop >> in my nose gear. How difficult is it to add the spacers? Any good >> ideas on how to do this? >> >> Sheldon Olesen N475PV >> >> ________________________________________________________________________________
Subject: Rivet Squeezer for sale
Date: Feb 03, 2011
I have a Chicago Pnuematic Rivet Sqeezer for sale. I has a 1 yoke that is included. See photo http://s767.photobucket.com/albums/xx317/Jdaniel343/?action=view¤t=IMG_6408.jpg Asking $300 obo. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329469#329469 ________________________________________________________________________________
Date: Feb 03, 2011
Thanks Wayne. That answered my question. Bill -------------------------------------------------- From: "rv10flyer" <wayne.gillispie(at)yahoo.com> Sent: Thursday, February 03, 2011 7:44 AM Subject: RV10-List: Re: countersinking baffle holes > > A dimple or machine countersunk hole is enlarged to the point that your > baffle will not seat properly. The seal is made with a nice layer/bead > that pushes up in front of baffle bend line as you install it. I am sure > some sealing takes place around the rivets too, but your main seal needs > to be that inside corner. I just followed the plans, using almost 1 qt per > tank. Just before baffles are installed I thinned sealant with > toluene/toluol max 15% by wt then went over all joints and rivet shop > heads. Then tested tanks to 1 psi with electronic manometer.(Water can be > used too). > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 > Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 41 Fwd top fuse skin/panel > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329437#329437 > > > ________________________________________________________________________________
Subject: electronic ignition
Date: Feb 03, 2011
Can anyone give me some advice on a good electronic ignition system for my RV10? I will be going to Sun n Fun this year and want to check into this....Thanks -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329487#329487 ________________________________________________________________________________
Subject: Re: electronic ignition
Date: Feb 03, 2011
Lets see, some of the usual suspects include: Light Speed Engineerings Plasma III: http://www.lightspeedengineering.com/ Unison LASAR: http://www.unisonindustries.com/ourproducts/lasarelectronicignition.html EFii: http://www.flyefii.com/ G3i: http://www.g3ignition.com/ EMAG (suppose to be real close to releasing a P-Mag for the 6-cyl Lycs): www.emagair.com -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329489#329489 ________________________________________________________________________________
Date: Feb 03, 2011
The Lightspeed Plasma that Van's sells seems to be the most common. Emag has been promising a 6 cyl version for a long time. G3 modification to standard mags seems to be the other most viable alternative. Probably one or two others, but not that many options. On 2/3/2011 1:21 PM, greghale wrote: > --> RV10-List message posted by: "greghale" > > Can anyone give me some advice on a good electronic ignition system for my RV10? I will be going to Sun n Fun this year and want to check into this....Thanks > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329487#329487 > > ________________________________________________________________________________
From: "carl.froehlich(at)verizon.net" <carl.froehlich(at)verizon.net>
Date: Feb 03, 2011
SSBnb3QgYSBub3RlIGZyb20gZU1hZyB0aGF0IHRoZXkgd2lsbCBoYXZlIHRoZSA2IGN5bGluZGVy IHBNYWcgYXQgU3VuJkZ1bi4gIEkgcHV0IGFuIG9yZGVyIGluIGZvciB0d28uCgpBcyBhIGZvcm1l ciBkdWFsIExpZ2h0c3BlZWQgb3duZXIsIEknbGwgbmV2ZXIgYWdhaW4gcHV0IHRob3NlIG9uIGFu eSBlbmdpbmUuICBJIG5vdyBoYXZlIDMwMCB0cm91YmxlIGZyZWUgaG91cnMgb24gbXkgOEEgZHVh bCBwTWFnIHNldCB1cC4KCkNhcmwKClNlbnQgZnJvbSBteSBtb2JpbGUgcGhvbmUuwqDCoCBQbGVh c2UgcmVhZCBwYXN0IHRoZSB0eXBvcy4KCi0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tCkZyb206 IFJvYmluIE1hcmtzIDxSb2JpbkBQYWludFRoZVdlYi5jb20+ClRvOiBydjEwLWxpc3RAbWF0cm9u aWNzLmNvbQpTZW50OiBUaHUsIEZlYiAzLCAyMDExIDIwOjM2OjQxIEdNVCswMDowMApTdWJqZWN0 OiBSRTogUlYxMC1MaXN0OiBlbGVjdHJvbmljIGlnbml0aW9uCgotLT4gUlYxMC1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiBSb2JpbiBNYXJrcyA8Um9iaW5AcGFpbnR0aGV3ZWIuY29tPgoKSSBrZWVw IHdhaXRpbmcgZm9yIHRoZSA2IGN5bGluZGVyIFAtTWFnLgpBdCB0aGlzIHJhdGUgSSB3aWxsIGJl IGFibGUgdG8gbW91bnQgb25lIGluIG15IFJWLTE4LgoKUm9iaW4KRG8gTm90IEFyY2hpdmUKCgot LS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20KW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21d IE9uIEJlaGFsZiBPZiBncmVnaGFsZQpTZW50OiBUaHVyc2RheSwgRmVicnVhcnkgMDMsIDIwMTEg MTI6MjIgUE0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tClN1YmplY3Q6IFJWMTAtTGlzdDog ZWxlY3Ryb25pYyBpZ25pdGlvbgoKLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogImdy ZWdoYWxlIiA8Z2hhbGU1MjI0QGFvbC5jb20+CgpDYW4gYW55b25lIGdpdmUgbWUgc29tZSBhZHZp Y2Ugb24gYSBnb29kIGVsZWN0cm9uaWMgaWduaXRpb24gc3lzdGVtIGZvciBteQpSVjEwPyAgSSB3 aWxsIGJlIGdvaW5nIHRvIFN1biBuIEZ1biB0aGlzIHllYXIgYW5kIHdhbnQgdG8gY2hlY2sgaW50 bwp0aGlzLi4uLlRoYW5rcwoKLS0tLS0tLS0KR3JlZyBIYWxlIHJ2MTAgLS0gTjIxMEtICnd3dy5u d2FjYXB0YWluLmNvbQoKCgoKUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOgoKaHR0cDovL2Zv cnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0zMjk0ODcjMzI5NDg3CgoKCgoKCgoK Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sCl8tPSBBcmNo aXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwKXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToKXy09Cl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgICAg LSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFp bGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24g V2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0g ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8t PSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09CgoK ________________________________________________________________________________
Date: Feb 03, 2011
I have the light speed and only have 38 hrs on it, but so far so good.=0A =0A=0A=0A=0A________________________________=0AFrom: greghale <ghale5224@ao l.com>=0ATo: rv10-list(at)matronics.com=0ASent: Thu, February 3, 2011 1:21:42 PM=0ASubject: RV10-List: electronic ignition=0A=0A--> RV10-List message pos ted by: "greghale" =0A=0ACan anyone give me some advice on a good electronic ignition system for my =0ARV10?- I will be going to Sun n Fun this year and want to check into =0Athis....Thanks=0A=0A-------- =0AGreg Hale rv10 -- N210KH=0Awww.nwacaptain.com=0A=0A=0A=0A=0ARead this to pic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=329487# ======================0A=0A=0A ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Feb 03, 2011
VGhpcyBpcyBvbmUgb2YgdGhvc2UgcHJpbWVyIHR5cGUgZGlzY3Vzc2lvbnMuICBGb3IgZXZlcnkg cGVyc29uIHRoYXQgc2F5cyB0aGF0IGhlIG5ldmVyIGhhZCBhIHByb2JsZW0sIHRoZXJlIGFyZSAx MCBwZW9wbGUgbGluZWQgdXAgdGhhdCBoYXZlLiAgOikNCg0KTWljaGFlbA0KDQpGcm9tOiBvd25l ci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBjYXJsLmZyb2VobGljaEB2ZXJpem9u Lm5ldA0KU2VudDogVGh1cnNkYXksIEZlYnJ1YXJ5IDAzLCAyMDExIDM6MTggUE0NClRvOiBydjEw LWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogZWxlY3Ryb25pYyBp Z25pdGlvbg0KDQpJIGdvdCBhIG5vdGUgZnJvbSBlTWFnIHRoYXQgdGhleSB3aWxsIGhhdmUgdGhl IDYgY3lsaW5kZXIgcE1hZyBhdCBTdW4mRnVuLiAgSSBwdXQgYW4gb3JkZXIgaW4gZm9yIHR3by4N Cg0KQXMgYSBmb3JtZXIgZHVhbCBMaWdodHNwZWVkIG93bmVyLCBJJ2xsIG5ldmVyIGFnYWluIHB1 dCB0aG9zZSBvbiBhbnkgZW5naW5lLiAgSSBub3cgaGF2ZSAzMDAgdHJvdWJsZSBmcmVlIGhvdXJz IG9uIG15IDhBIGR1YWwgcE1hZyBzZXQgdXAuDQoNCkNhcmwNCg0KU2VudCBmcm9tIG15IG1vYmls ZSBwaG9uZS4gICBQbGVhc2UgcmVhZCBwYXN0IHRoZSB0eXBvcy4NCg0KDQotLS0tLU9yaWdpbmFs IG1lc3NhZ2UtLS0tLQ0KRnJvbTogUm9iaW4gTWFya3MgPFJvYmluQFBhaW50VGhlV2ViLmNvbT4N ClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU2VudDogVGh1LCBGZWIgMywgMjAxMSAyMDoz Njo0MSBHTVQrMDA6MDANClN1YmplY3Q6IFJFOiBSVjEwLUxpc3Q6IGVsZWN0cm9uaWMgaWduaXRp b24NCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFJvYmluIE1hcmtzDQoNCkkga2Vl cCB3YWl0aW5nIGZvciB0aGUgNiBjeWxpbmRlciBQLU1hZy4NCkF0IHRoaXMgcmF0ZSBJIHdpbGwg YmUgYWJsZSB0byBtb3VudCBvbmUgaW4gbXkgUlYtMTguDQoNClJvYmluDQpEbyBOb3QgQXJjaGl2 ZQ0KDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb20NClttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tXSBPbiBCZWhhbGYgT2YgZ3JlZ2hhbGUNClNlbnQ6IFRodXJzZGF5LCBGZWJydWFy eSAwMywgMjAxMSAxMjoyMiBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0 OiBSVjEwLUxpc3Q6IGVsZWN0cm9uaWMgaWduaXRpb24NCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogImdyZWdoYWxlIg0KDQpDYW4gYW55b25lIGdpdmUgbWUgc29tZSBhZHZpY2Ug b24gYSBnb29kIGVsZWN0cm9uaWMgaWduaXRpb24gc3lzdGVtIGZvciBteQ0KUlYxMD8gSSB3aWxs IGJlIGdvaW5nIHRvIFN1biBuIEZ1biB0aGlzIHllYXIgYW5kIHdhbnQgdG8gY2hlY2sgaW50bw0K dGhpcy4uLi5UaGFua3MNCg0KLS0tLS0tLS0NCkdyZWcgSGFsZSBydjEwIC0tIE4yMTBLSA0Kd3d3 Lm53YWNhcHRhaW4uY29tDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0K aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0zMjk0ODcjMzI5NDg3 DQoNCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0g LQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dz ZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRp b24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBG QVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0gLS0+IGh0 dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpfLT0NCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQpf LT0gLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28g YXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09IC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBT aXRlIC0NCl8tPSBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPSAtTWF0 dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24NCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09DQoNCinmn6J7bDdyaE00043CrWnHnOqiut6Byq4nTlddDQrLhO6Z i+KAkWraqCcsListFeatujXigato2pssetieJiM3MTU1MDE72KXYnsucDQrLlO+/ve+/vSticCty eSfIgyDload7ICx4KFpQPi3Imuantmtrait5a3ltw4wmatqoJyxyNeKBq2gVddC4be+/jO+/vSfL nG/Nqmraq0VddC4rLU0TICQRTkVDEknKp+mtqlsoau+/ve+/veW6uHlo6ayq3r5t36Jm4rKHKG3f ombisoco77+977+9Qntr1rnkoap5Mueoryouei7Lqe+/vW0NCuKistCdKdqG26kwwqbisoco77+9 77+94q6rYnhtw4wmatqoJyxycu+/ve62qifbvSdre++/ve+/veG2qQ0K ________________________________________________________________________________
Date: Feb 03, 2011
SSB0aG91Z2h0cyBvbiB0aGUgZyAzIHN5c3RlbQoKU2VudCB2aWEgRFJPSUQgb24gVmVyaXpvbiBX aXJlbGVzcwoKLS0tLS1PcmlnaW5hbCBtZXNzYWdlLS0tLS0KRnJvbTogVGltIE9sc29uIDxUaW1A bXlydjEwLmNvbT4KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tClNlbnQ6IFRodSwgRmViIDMs IDIwMTEgMjE6NTY6NTkgR01UKzAwOjAwClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IGVsZWN0cm9u aWMgaWduaXRpb24KCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFRpbSBPbHNvbiA8 VGltQG15cnYxMC5jb20+CgpJdCdzIGludGVyZXN0aW5nIHRoYXQgeW91IG9yZGVyZWQgMiBvZiBz b21ldGhpbmcgdGhhdCBpc24ndApldmVuIGF2YWlsYWJsZSB5ZXQsIGVzcGVjaWFsbHkgZ2l2ZW4g eW91ciBMaWdodHNwZWVkIGV4cGVyaWVuY2UuCkkgd291bGQgbmV2ZXIgb3JkZXIgMiBvZiBhbnl0 aGluZywgZ2l2ZW4gdGhhdCBMaWdodHNwZWVkIHdvcmtzCmdyZWF0IHdpdGggb25seSAxLiAgQnV0 LCBJIGhhZCB0aG91Z2h0IEknZCBnZXQgZU1hZ3MvcE1hZ3MKd2F5IGJhY2sgaW4gMjAwNC0yMDA1 LCBhbmQgdGhleSB3ZXJlIHByb21pc2luZyB0aGVtIHNob3J0bHkKYmFjayB0aGVuLiAgSXQgY291 bGQgYmUgYSBnb29kIHRoaW5nIHRoYXQgdGhleSB3YWl0ZWQKdGhpcyBsb25nLCBidXQgdGhlbiBh Z2Fpbiwgd2hhdCBraW5kcyBvZiBwcm9ibGVtcyB3ZXJlCnRoZXJlIHRoYXQgY2F1c2VkIHRoaXMg bG9uZyBvZiBhIGRlbGF5PyAgVGhleSBjZXJ0YWlubHkKaGF2ZSBoYWQgdGhlIHBlbnQgdXAgZGVt YW5kIGZvciBtYW55IHllYXJzLi4uc28gaXQgaXNuJ3QKbGFjayBvZiBpbnRlcmVzdC4gIEkgd2Fz IHJlYWxseSBpbnRlcmVzdGVkIGluIHRoZW0sCmJ1dCB0aGV5IHRvbyBoYXZlIGhhZCBpc3N1ZXMu CgoKVGltIE9sc29uIC0gUlYtMTAgTjEwNENECmRvIG5vdCBhcmNoaXZlCgoKT24gMi8zLzIwMTEg MzoxNyBQTSwgY2FybC5mcm9laGxpY2hAdmVyaXpvbi5uZXQgd3JvdGU6Cj4gSSBnb3QgYSBub3Rl IGZyb20gZU1hZyB0aGF0IHRoZXkgd2lsbCBoYXZlIHRoZSA2IGN5bGluZGVyIHBNYWcgYXQKPiBT dW4mRnVuLiBJIHB1dCBhbiBvcmRlciBpbiBmb3IgdHdvLgo+Cj4gQXMgYSBmb3JtZXIgZHVhbCBM aWdodHNwZWVkIG93bmVyLCBJJ2xsIG5ldmVyIGFnYWluIHB1dCB0aG9zZSBvbiBhbnkKPiBlbmdp bmUuIEkgbm93IGhhdmUgMzAwIHRyb3VibGUgZnJlZSBob3VycyBvbiBteSA4QSBkdWFsIHBNYWcg c2V0IHVwLgo+Cj4gQ2FybAo+Cj4gU2VudCBmcm9tIG15IG1vYmlsZSBwaG9uZS4gUGxlYXNlIHJl YWQgcGFzdCB0aGUgdHlwb3MuCj4KPgo+IC0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tCj4KPiAg ICAgKkZyb206ICpSb2JpbiBNYXJrcyA8Um9iaW5AUGFpbnRUaGVXZWIuY29tPioKPiAgICAgVG86 ICpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSoKPiAgICAgU2VudDogKlRodSwgRmViIDMsIDIwMTEg MjA6MzY6NDEgR01UKzAwOjAwKgo+ICAgICBTdWJqZWN0OiAqUkU6IFJWMTAtTGlzdDogZWxlY3Ry b25pYyBpZ25pdGlvbgo+Cj4gICAgIC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFJv YmluIE1hcmtzCj4KPiAgICAgSSBrZWVwIHdhaXRpbmcgZm9yIHRoZSA2IGN5bGluZGVyIFAtTWFn Lgo+ICAgICBBdCB0aGlzIHJhdGUgSSB3aWxsIGJlIGFibGUgdG8gbW91bnQgb25lIGluIG15IFJW LTE4Lgo+Cj4gICAgIFJvYmluCj4gICAgIERvIE5vdCBBcmNoaXZlCj4KPgo+ICAgICAtLS0tLU9y aWdpbmFsIE1lc3NhZ2UtLS0tLQo+ICAgICBGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20KPiAgICAgW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb21dIE9uIEJlaGFsZiBPZiBncmVnaGFsZQo+ICAgICBTZW50OiBUaHVyc2RheSwgRmVicnVh cnkgMDMsIDIwMTEgMTI6MjIgUE0KPiAgICAgVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tCj4g ICAgIFN1YmplY3Q6IFJWMTAtTGlzdDogZWxlY3Ryb25pYyBpZ25pdGlvbgo+Cj4gICAgIC0tPiBS VjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJncmVnaGFsZSIKPgo+ICAgICBDYW4gYW55b25l IGdpdmUgbWUgc29tZSBhZHZpY2Ugb24gYSBnb29kIGVsZWN0cm9uaWMgaWduaXRpb24gc3lzdGVt Cj4gICAgIGZvciBteQo+ICAgICBSVjEwPyBJIHdpbGwgYmUgZ29pbmcgdG8gU3VuIG4gRnVuIHRo aXMgeWVhciBhbmQgd2FudCB0byBjaGVjayBpbnRvCj4gICAgIHRoaXMuLi4uVGhhbmtzCj4KPiAg ICAgLS0tLS0tLS0KPiAgICAgR3JlZyBIYWxlIHJ2MTAgLS0gTjIxMEtICj4gICAgIHd3dy5ud2Fj YXB0YWluLmNvbQo+Cj4KPgo+Cj4gICAgIFJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToKPgo+ ICAgICBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTMyOTQ4NyMz Mjk0ODcKPgo+Cj4KPgo+Cj4KPgo+Cj4KPgo+IO+/ve+/ve+/vX7vv73vv70s77+9A2fvv73vv73v v71NNO+/vUfvv71x77+977+977+9eu+/ve+/ve+/ve+/vS7vv70n77+977+977+977+977+977+9 77+977+977+977+977+977+977+977+977+977+9AThFXXQuKy0SZu+/ve+/vVor77+9YO+/ve+/ vWF4xq3vv73vv73vv71y77+977+977+9Xmrbq3rvv71a77+9KBrvv73vv73vv73vv73vv73Hthfv v71qfO+/ve+/ve+/vW7vv70pYu+/vSfvv73vv73vv70hau+/ve+/ve+/vSfvv70r77+977+977+9 77+92Kjvv73vv71yGO+/vXkn77+977+977+9Q++/vQo+IOWhp3sKPiDvv73vv73vv73vv70seCha 77+9UBDvv73vv70hau+/ve+/ve+/vdmuchnvv71yGe+/ve+/vWoa77+9fAjvv73vv73vv73vv70M Jmrvv73vv70nLHLvv73vv70177+94oGraO+/vRV10Ljvv73vv70bbe+/ve+/ve+/ve+/vQo+IO+/ ve+/ve+/vSfvv73vv70c77+9b++/vWrvv71q77+9K0VddC4rLe+/ve+/ve+/ve+/ve+/ve+/ve+/ ve+/ve+/ve+/ve+/ve+/ve+/ve+/ve+/ve+/vTAE77+9OO+/vQJJYQEU77+9VDEKPiBqZ++/ve+/ ve+/vXLvv73vv716e1rvv73vv70a77+977+977+9ae+/vV7vv70m77+977+977+9bFor77+9awHv v71577+977+9f++/ve+/vSvvv71rJmrvv73vv70nLHLvv73vv73vv73vv71/77+977+9K++/vWsm au+/ve+/vScscu+/ve+/vWjvv73vv73vv73vv73vv73vv73vv73vv73vv73vv73vv73vv73vv73v v73vv73vv73vv71C77+9e2vvv73vv73vv73vv73vv73vv71577+977+977+977+977+9yovvv73v v73vv73vv73vv73vv70e77+977+977+977+9Lu+/ve+/vSvvv70D77+977+977+9alleListAdmi 77+9Bu+/ve+/ve+/vWnvv73vv70w77+9Zu+/ve+/ve+/ve+/vXLvv70o77+977+9KO+/ve+/ve+/ vW7vv71i77+9eG3vv73vv73vv73vv70MJmrvv73vv70nLHLvv73vv71y77+977+9Ju+/vSon77+9 77+977+977+977+977+977+977+977+977+977+977+977+977+977+977+977+977+9J++/ve+/ vWt777+977+9dy/vv710bWw9CgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3Qg RW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0 b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4v U3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3Nl LCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QKXy09Cl8t PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09Cl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQpfLT0gU2FtZSBn cmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEKXy09Cl8tPSAg IC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09Cl8tPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cl8tPSAgICAgICAgICAg ICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIg Z2VuZXJvdXMgc3VwcG9ydCEKXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQg RHJhbGxlLCBMaXN0IEFkbWluLgpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2Nv bnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Date: Feb 03, 2011
ICBTZWVtcyBvZGQgdGhhdCB0aGV5IHdvdWxkIGJlIGhvbGRpbmcgb3V0IGZvciBjZXJ0aWZpY2F0 aW9uIGJlZm9yZSByZWxlYXNpbmcgdGhlIGV4cGVyaW1lbnRhbCB2ZXJzaW9uLiAgVGhleSBjb3Vs ZCBiZSBnYXRoZXJpbmcgZGF0YSBmcm9tIHVuaXRzIGluIHRoZSBmaWVsZCB0byBzdXBwb3J0IHRo ZWlyIGNlcnRpZmljYXRpb24gcHJvY2Vzcy4gIEFsdGhvdWdoIEnigJl2ZSBhbHNvIGJlZW4gaGVh cmluZyBhYm91dCBob3cgdGhleSB3ZXJlIHdvcmtpbmcgdG93YXJkcyBjZXJ0aWZpY2F0aW9uIGZv ciBhcyBsb25nIGFzIEnigJl2ZSBiZWVuIGhlYXJpbmcgYWJvdXQgdGhlIDZjeWwgdmVyc2lvbi4g IFRoZXkgYXJlIGNlcnRhaW5seSBub3Qgd2l0aG91dCB0aGVpciBwcm9ibGVtcyBpZiB5b3UgZG8g YSBsaXR0bGUgZHVlIGRpbGlnZW5jZSwgTWFyYyBaZWl0bGluIGhhcyB3cm90ZSB1cCBoaXMgZXhw ZXJpZW5jZXMgaW4gdGhlIHBhc3QuICBOb3QgdGhhdCBhbnkgb2YgdGhlbSBhcmUgcGVyZmVjdC4N Cg0KTWljaGFlbA0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20g W21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBP ZiBSb2JpbiBNYXJrcw0KU2VudDogVGh1cnNkYXksIEZlYnJ1YXJ5IDAzLCAyMDExIDQ6MTIgUE0N ClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogZWxl Y3Ryb25pYyBpZ25pdGlvbg0KDQpJIHdhcyBvbiB0aGUgcGhvbmUgd2l0aCBFLU1hZyB0aGlzIG1v cm5pbmcgYW5kIHRvIHRoZWlyIGNyZWRpdCBlYWNoIHRpbWUgSSBoYXZlIGFza2VkIHRoZW0gd2hl biB0aGUgNiBjeWxpbmRlciB2ZXJzaW9uIHdvdWxkIGJlIHJlbGVhc2VkIHRoZXkgbmV2ZXIgcHJv bWlzZWQgYSBkYXRlIHNvIGFzIHRvIG5vdCBkaXNhcHBvaW50LiBUaGF0IGJlaW5nIHNhaWQgdGhl IDYgY3lsaW5kZXIgdmVyc2lvbiBhdCBTTkYgMjAxMSB3aWxsIGJlIGEgc2FtcGxlIHRvIGhvbGQs IGZlZWwsIHJldmlldyBidXQgbm90IGJlIGF2YWlsYWJsZSBmb3Igc2FsZS4gVGhlIHJlYXNvbiB0 aGV5IGFyZSB0YWtpbmcgc28gbG9uZyBhcyB0aGV5IGFyZSBzaG9vdGluZyBmb3IgY2VydGlmaWNh dGlvbiBvbiB0aGUgNiBjeWxpbmRlciB2ZXJzaW9uIHdoaWNoIGdpdmVzIG1lIGEgbXVjaCB3YXJt ZXIgZnV6enkgZmVlbGluZy4gSGUgZGlkIHNheSB0aGV5IHdvdWxkIG1vc3QgbGlrZWx5IGJlIHJl bGVhc2luZyB0aGUgZXhwZXJpbWVudGFsIHZlcnNpb24gcHJpb3IgdG8gY2VydGlmaWNhdGlvbiBi dXQgSSBzdXNwZWN0IHRoZSBkaWZmZXJlbmNlcyBpZiBhbnkgd2lsbCBiZSBtaW5vci4NCkkgaGF2 ZSBhIDQgY3lsaW5kZXIgdmVyc2lvbiBvbiBteSAyMDAgSHAgSU8tMzYwIHRoYXQgaGFkIGJlZW4g cGlja2xlZCBmb3IgMTAgeWVhcnMgYmVmb3JlIGZpcnN0IHN0YXJ0LiBTdGFydGVkIG9uIHRoZSBz ZWNvbmQgYmxhZGUuDQpJIGhhdmUgYmVlbiBvbiB0aGUgNiBjeWxpbmRlciDigJxsaXN04oCdIGZv ciB3ZWxsIG92ZXIgMiB5ZWFycy4NCg0KUm9iaW4NCg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNl cnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb20+IFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0 bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20+XSBPbiBCZWhhbGYgT2YgY2Fy bC5mcm9laGxpY2hAdmVyaXpvbi5uZXQ8bWFpbHRvOmNhcmwuZnJvZWhsaWNoQHZlcml6b24ubmV0 Pg0KU2VudDogVGh1cnNkYXksIEZlYnJ1YXJ5IDAzLCAyMDExIDE6MTggUE0NClRvOiBydjEwLWxp c3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0 OiBSRTogUlYxMC1MaXN0OiBlbGVjdHJvbmljIGlnbml0aW9uDQoNCkkgZ290IGEgbm90ZSBmcm9t IGVNYWcgdGhhdCB0aGV5IHdpbGwgaGF2ZSB0aGUgNiBjeWxpbmRlciBwTWFnIGF0IFN1biZGdW4u ICBJIHB1dCBhbiBvcmRlciBpbiBmb3IgdHdvLg0KDQpBcyBhIGZvcm1lciBkdWFsIExpZ2h0c3Bl ZWQgb3duZXIsIEknbGwgbmV2ZXIgYWdhaW4gcHV0IHRob3NlIG9uIGFueSBlbmdpbmUuICBJIG5v dyBoYXZlIDMwMCB0cm91YmxlIGZyZWUgaG91cnMgb24gbXkgOEEgZHVhbCBwTWFnIHNldCB1cC4N Cg0KQ2FybA0KDQpTZW50IGZyb20gbXkgbW9iaWxlIHBob25lLiAgIFBsZWFzZSByZWFkIHBhc3Qg dGhlIHR5cG9zLg0KDQoNCi0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tDQpGcm9tOiBSb2JpbiBN YXJrcyA8Um9iaW5AUGFpbnRUaGVXZWIuY29tPg0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29t PG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClNlbnQ6IFRodSwgRmViIDMsIDIwMTEg MjA6MzY6NDEgR01UKzAwOjAwDQpTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBlbGVjdHJvbmljIGln bml0aW9uDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBSb2JpbiBNYXJrcw0KDQpJ IGtlZXAgd2FpdGluZyBmb3IgdGhlIDYgY3lsaW5kZXIgUC1NYWcuDQpBdCB0aGlzIHJhdGUgSSB3 aWxsIGJlIGFibGUgdG8gbW91bnQgb25lIGluIG15IFJWLTE4Lg0KDQpSb2Jpbg0KRG8gTm90IEFy Y2hpdmUNCg0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0tLQ0KRnJvbTogb3duZXItcnYxMC1s aXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20+DQpbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNv bTxtYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPl0gT24gQmVoYWxm IE9mIGdyZWdoYWxlDQpTZW50OiBUaHVyc2RheSwgRmVicnVhcnkgMDMsIDIwMTEgMTI6MjIgUE0N ClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5j b20+DQpTdWJqZWN0OiBSVjEwLUxpc3Q6IGVsZWN0cm9uaWMgaWduaXRpb24NCg0KLS0+IFJWMTAt TGlzdCBtZXNzYWdlIHBvc3RlZCBieTogImdyZWdoYWxlIg0KDQpDYW4gYW55b25lIGdpdmUgbWUg c29tZSBhZHZpY2Ugb24gYSBnb29kIGVsZWN0cm9uaWMgaWduaXRpb24gc3lzdGVtIGZvciBteQ0K UlYxMD8gSSB3aWxsIGJlIGdvaW5nIHRvIFN1biBuIEZ1biB0aGlzIHllYXIgYW5kIHdhbnQgdG8g Y2hlY2sgaW50bw0KdGhpcy4uLi5UaGFua3MNCg0KLS0tLS0tLS0NCkdyZWcgSGFsZSBydjEwIC0t IE4yMTBLSA0Kd3d3Lm53YWNhcHRhaW4uY29tDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY289PT09PT09PT09DQo9IC0tPiA8 aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0zMjk0ODcjMzI5NDg3 PiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy49PT09PT09PT09PT09PT09PT0NCi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0 aW9uPGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbT49PT09PT09PT09PT0NCn4sDQpfX19fX19f X19fX19fX19fX19fX19fX19fX19fX19fXw0KZ9OTDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAg ICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2UgdGhlIE1hdHJv bmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRoZSBtYW55IExp c3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPSBBcmNoaXZl IFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0KXy09IFBob3Rv c2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09 ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBTYW1lIGdyZWF0 IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0NCg0KXy09 ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09 ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0gIFRoYW5r IHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Date: Feb 03, 2011
The Pmag would be my choice. I am in no hurry since my Lightspeed/mag setup is working great, but I will probably change to dual Pmags at some point. David Maib 40559 flying On Feb 3, 2011, at 3:21 PM, greghale wrote: > > Can anyone give me some advice on a good electronic ignition system > for my RV10? I will be going to Sun n Fun this year and want to > check into this....Thanks > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329487#329487 > > ________________________________________________________________________________
Date: Feb 04, 2011
I have 1 Electroair and 1 mag and I am very happy with the setup. I can run LOP smoothly and it starts good. The Electroair is the old Jeff Rose setup they compare in the EAA CAFE report. I used the Electroair because Lightspeed did not have a mounting bracket for the crank pickup to fit my engine. The guys at Electroair are good to work with and they are going for a certified model also. Blue Skys Barry ________________________________________________________________________________
Date: Feb 04, 2011
I had the experience as Jesse, 300 hours added an addition washer to the top of the nose gear. Not a difficult task. Dick Sipp ________________________________________________________________________________
Date: Feb 04, 2011
Subject: number of seats
I did a search on the FAA aircraft registry for "model = RV-10" and looked at the number of seats. Most were listed as 4, four were listed as 5 (which I know has been discussed here), but I was surprised to see that there were nine listed with 2 seats. What's the reason for doing this? Lower liability premiums? I suppose it could also just be bad data--I did notice one has 10 seats and three are "light sport". -Rob -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: Re: number of seats
Date: Feb 04, 2011
Mine was listed as 2 seats with the faa,but 4 with avemco,just bad data tha t I have not yet corrected-Jim -----Original Message----- From: Rob Kochman <rv10rob(at)gmail.com> Sent: Fri, Feb 4, 2011 8:09 am Subject: RV10-List: number of seats I did a search on the FAA aircraft registry for "model = RV-10" and looke d at the number of seats. Most were listed as 4, four were listed as 5 (wh ich I know has been discussed here), but I was surprised to see that there were nine listed with 2 seats. What's the reason for doing this? Lower li ability premiums? I suppose it could also just be bad data--I did notice o ne has 10 seats and three are "light sport". -Rob -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 04, 2011
I have tried a couple times. Same numbers and no indications. Can anyone out there smart on this system give me a call. There must be something obvious I have overlooked. 225-802-4827. GRT appears to be snowed in today. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329598#329598 ________________________________________________________________________________
Date: Feb 04, 2011
Subject: Crow Harnesses
Anyone using the Crow seatbelts in their -10? When I ordered mine, I didn't specify and dimensions--I just said I needed a complete set for the RV-10, since I understand they've done a few. Having now installed mine, the shoulder straps seem to be too short between the latch and the "Y". See the attached pictures. The "Y" is right on top of the headrest. I could move that back a few inches, but then the shoulder pads would be in the wrong place. Something doesn't seem right here--any ideas? -Rob -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Feb 04, 2011
Finally got in touch with GRT. After a bit with Carlos, it looks like the settings are working now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329656#329656 ________________________________________________________________________________
Date: Feb 04, 2011
Subject: Re: Crow Harnesses
Rob, I agree that the pads could be a little more forward. In the first picture it looks like you're leaning forward a little to put tension on the harness. Either that or you have a serious shoulder/back problem!!! If it was me, I'd move the 'Y' forward a little and then take the slack out by pulling on the adjustment for the shoulder belts. The shoulder harness should be adjusted so that in your 'cruise' seat position with the harness just a little slack from snug (yeah, go ahead and measure that!) you can reach all the stuff on the panel that you need to ..... without having to twist the upper torso very much. The only problem moving the 'Y' forward is that it causes the shoulder belts to rub the side of the neck. This is a problem I have in my Pitts, and the solution was the shoulder pads for car shoulder belts. Nice and soft on the neck now. But you'd hate to just cover up the pads you paid so dearly for. Linn On 2/4/2011 2:25 PM, Rob Kochman wrote: > Anyone using the Crow seatbelts in their -10? When I ordered mine, I > didn't specify and dimensions--I just said I needed a complete set for > the RV-10, since I understand they've done a few. Having now > installed mine, the shoulder straps seem to be too short between the > latch and the "Y". See the attached pictures. The "Y" is right on > top of the headrest. I could move that back a few inches, but then > the shoulder pads would be in the wrong place. Something doesn't seem > right here--any ideas? > -Rob > > -- > Rob Kochman > RV-10 "Finishing" Kit > Woodinville, WA (near Seattle) > http://kochman.net/N819K ________________________________________________________________________________
Subject: Experience with paint - off RV10 topic
Date: Feb 04, 2011
I am getting ready to paint my current aircraft. Does anyone have experience with PPG or Dupont (Imron) paint? Unfortunately, my RV10 in not ready to paint - and probably will not be for some time. Thank you in advance for any comments. Dick Gurley Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329675#329675 ________________________________________________________________________________
Date: Feb 04, 2011
Subject: Re: Experience with paint - off RV10 topic
I know this is far more info than you asked for ...... but hopefully others might benefit. Two things make a great paint job .... preparation and ..... practice. Practice on your current airplane and you'll be way ahead when you get to the -10. The best job would be a strip and paint ..... sand and paint leaves a lot of extra weight on the airframe. Work on filling dings and deep scratches ..... the smallest imperfection shows up in the paint. Choose your base color ..... I like white ..... even if you're going to paint over almost all of it. It'll give even color presentation everywhere. Use 3M Fineline masking tape .... green for straight lines, blue for curves. Use paint masking paper. Newspaper doesn't hack it. The paint job is not the place to save money. Get a good paint gun. Yup, I've used HF paint guns, but you get what you pay for, and a quality tool will not let you down. Mix the paint, reducer and catalyst. I like to reduce the paint a little more than recommended. Not a lot. A little. Use the proper reducer for the temperature you'll spray in. Wait 30 minutes. They call this 'induction time'. I don't know why it matters whether the induction time occurs in the spray gun pot or on the airplane .... but it does. Use a tack cloth everywhere!!!! Change the cloth often. They're cheap and really help a nice paint job. Spray a tack coat .... really, really, light. Wait about 30 minutes. Spray a light cross coat. Wait 30 minutes. Spray a second cross coat. Look carefully at your paint job for Throw away that paint left in the spray gun. Resist the urge to spray it on the plane. All it adds is weight .... and sags. Clean up the equipment and go home. Did you notice the 'Wait 30 minutes'???? I found that if you scrimp on the 30 minutes, the possibility of runs and sags goes way up. A professional painter may not do this, but I'm not a pro painter and don't play one on TV. No matter how many times I stayed at a Holiday Inn ..... I still needed that time. Best of luck .... and post the pictures when you get done. Linn On 2/4/2011 8:24 PM, rngurley wrote: > --> RV10-List message posted by: "rngurley" > > I am getting ready to paint my current aircraft. Does anyone have experience with PPG or Dupont (Imron) paint? Unfortunately, my RV10 in not ready to paint - and probably will not be for some time. Thank you in advance for any comments. > > Dick Gurley > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329675#329675 > > ________________________________________________________________________________
Date: Feb 04, 2011
And, don't forget, Imron is pretty toxic. Wear personal protection equipment. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329689#329689 ________________________________________________________________________________
Date: Feb 04, 2011
I got mine certified with four seats (You have to install seat belts and rear seat backs in four position) but installed no rear seat cushions. Reason - to keep my plane light. The rear belts and cushions weigh a lot. I have removed the left (pilot side) rear seat back and belt assembly. I have left installed the back right seat back and belts assembly but still no cushion. I figure that if I need to carry a third person - they can sit on pillows. My current empty weight 1617# with the tow bar which I always carry. I figure it is mandatory equipment - try moving the plane without it..... -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329690#329690 ________________________________________________________________________________
Subject: Potential BIG trouble with GPS...keep those nav radios!
Date: Feb 05, 2011
Check out this article....especially the effects on certified (i read that as "sensitive" GPS's) http://www.gpsworld.com/gnss-system/news/data-shows-disastrous-gps-jamming-fcc-approved-broadcaster-11029?utm_source=GPS&utm_medium=email&utm_campaign=Navigate_01_31_2011&utm_content=data-shows-disastrous-gps-jamming-fcc-approved-broadcaster-11029 Tim ________________________________________________________________________________
Date: Feb 05, 2011
It will take more than 30 minutes to finish the first coat on an airplane. you should be able to return to where you started and continue spraying. --- On Fri, 2/4/11, Linn Walters wrote: From: Linn Walters <pitts_pilot(at)bellsouth.net> Subject: Re: RV10-List: Experience with paint - off RV10 topic Date: Friday, February 4, 2011, 7:55 PM I know this is far more info than you asked for ...... but hopefully others might benefit. Two things make a great paint job .... preparation and ..... practice.- P ractice on your current airplane and you'll be way ahead when you get to th e -10. The best job would be a strip and paint ..... sand and paint leaves a lot o f extra weight on the airframe. Work on filling dings and deep scratches ..... the smallest imperfection sh ows up in the paint. Choose your base color ..... I like white ..... even if you're going to pai nt over almost all of it.- It'll give even color presentation everywhere. Use 3M Fineline masking tape .... green for straight lines, blue for curves .- Use paint masking paper.- Newspaper doesn't hack it.- The paint jo b is not the place to save money. Get a good paint gun.- Yup, I've used HF paint guns, but you get what you pay for, and a quality tool will not let you down. Mix the paint, reducer and catalyst.- I like to reduce the paint a little more than recommended.- Not a lot.- A little.- Use the proper reduce r for the temperature you'll spray in.- Wait 30 minutes.- They call thi s 'induction time'.- I don't know why it matters whether the induction ti me occurs in the spray gun pot or on the airplane .... but it does. Use a tack cloth everywhere!!!!- Change the cloth often.- They're cheap and really help a nice paint job. Spray a tack coat .... really, really, light.- Wait about 30 minutes. Spray a light cross coat.- Wait 30 minutes. Spray a second cross coat. Look carefully at your paint job for- - Throw away that paint left in t he spray gun.- Resist the urge to spray it on the plane.- All it adds i s weight .... and sags.- Clean up the equipment and go home. Did you notice the 'Wait 30 minutes'????- I found that if you scrimp on t he 30 minutes, the possibility of runs and sags goes way up.- A professio nal painter may not do this, but I'm not a pro painter and don't play one o n TV.- No matter how many times I stayed at a Holiday Inn ..... I still n eeded that time. Best of luck .... and post the pictures when you get done. Linn On 2/4/2011 8:24 PM, rngurley wrote: > -->- RV10-List message posted by: "rngurley" > > I am getting ready to paint my current aircraft.- Does anyone have expe rience with PPG or Dupont (Imron) paint?- Unfortunately, my RV10 in not r eady to paint - and probably will not be for some time.- Thank you in adv ance for any comments. > > Dick Gurley > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329675#329675 > > > > > > > > > > > le, List Admin. ________________________________________________________________________________
Date: Feb 05, 2011
Good point Jerry!!! I don't paint everything at once. Wings and tail feathers off so I can turn them or hang them to get both sides etc. Fuselage by itself etc. I've never had the room to paint an airplane assembled. I don't mind taking the time since removing sags and runs is a lot more time consuming. Also, remember that I'm not a pro ...... Trim paint applied same way, with masking paper and plastic sheet to protect other areas from overspray. Successive coats start in the same place, so the oldest paint may be 1 hour (or more) 'old'. Urethanes have a long pot life if mixed correctly and have the correct reducer, so the spraying time isn't a factor. I use the 'break' for some liquid for me and mix more paint. Oh yeah, as someone said .... use a real good paint face mask with both a cloth and carbon filter. I don't care for the fresh air hoods/masks because I always seem to catch the hose on something. It would, of course, be better. Linn On 2/5/2011 2:07 PM, Jerry Stark wrote: > It will take more than 30 minutes to finish the first coat on an > airplane. you should be able to return to where you started and > continue spraying. > > --- On *Fri, 2/4/11, Linn Walters //* wrote: > > > From: Linn Walters <pitts_pilot(at)bellsouth.net> > Subject: Re: RV10-List: Experience with paint - off RV10 topic > To: rv10-list(at)matronics.com > Date: Friday, February 4, 2011, 7:55 PM > > > > > I know this is far more info than you asked for ...... but > hopefully others might benefit. > Two things make a great paint job .... preparation and ..... > practice. Practice on your current airplane and you'll be way > ahead when you get to the -10. > The best job would be a strip and paint ..... sand and paint > leaves a lot of extra weight on the airframe. > Work on filling dings and deep scratches ..... the smallest > imperfection shows up in the paint. > > Choose your base color ..... I like white ..... even if you're > going to paint over almost all of it. It'll give even color > presentation everywhere. > Use 3M Fineline masking tape .... green for straight lines, blue > for curves. Use paint masking paper. Newspaper doesn't hack it. > The paint job is not the place to save money. > > Get a good paint gun. Yup, I've used HF paint guns, but you get > what you pay for, and a quality tool will not let you down. > > Mix the paint, reducer and catalyst. I like to reduce the paint a > little more than recommended. Not a lot. A little. Use the > proper reducer for the temperature you'll spray in. Wait 30 > minutes. They call this 'induction time'. I don't know why it > matters whether the induction time occurs in the spray gun pot or > on the airplane .... but it does. > > Use a tack cloth everywhere!!!! Change the cloth often. They're > cheap and really help a nice paint job. > Spray a tack coat .... really, really, light. Wait about 30 minutes. > Spray a light cross coat. Wait 30 minutes. > Spray a second cross coat. > Look carefully at your paint job for Throw away that paint left > in the spray gun. Resist the urge to spray it on the plane. All > it adds is weight .... and sags. Clean up the equipment and go home. > > Did you notice the 'Wait 30 minutes'???? I found that if you > scrimp on the 30 minutes, the possibility of runs and sags goes > way up. A professional painter may not do this, but I'm not a pro > painter and don't play one on TV. No matter how many times I > stayed at a Holiday Inn ..... I still needed that time. > Best of luck .... and post the pictures when you get done. > Linn > > > On 2/4/2011 8:24 PM, rngurley wrote: > > --> RV10-List message posted by: "rngurley" > > > > > I am getting ready to paint my current aircraft. Does anyone > have experience with PPG or Dupont (Imron) paint? Unfortunately, > my RV10 in not ready to paint - and probably will not be for some > time. Thank you in advance for any comments. > > > > Dick Gurley > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=329675#329675 > > > > > > > > > > > > > > > &cs.com/Navigator?RV10-List" > target="_blank">http://www.matronics.com/Navi - > MATRONICS WEB href="http://forums.matronics.com" > target="_blank">http://forums.matrobsp; - List > Contribution Web Site -http://w====================== > > > * > > > * ________________________________________________________________________________
Date: Feb 05, 2011
I'm half way through painting my '10. Cold temperatures brought me to a halt. I figure I'll be back up and running in about 3 weeks. I've documented some of it on my log here: http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=5986 This being a first attempt, I certainly don't know what I'm talking about. Just learning, making observations and projections based on one incomplete experience. I'm using a Dupont Imron Elite - that seems to be the current Imron product line. Imron is a big brand with a lot of history. Seems to be a very high quality line of paint. Things said about previous iterations of Imron dont necessarily apply so be cautious of all Web advice. I've gone with a single stage paint rather than a base coat/clear coat - both have advantages. There are detailed manufacturers data sheets for all products. They are on the Web and your local paint supplier will have them. I suggest reading them and treating them as gospel before listening to any other advice. It's in the manufacturers best interest to have their products perform well and to be used optimally. The only notable exception I found surrounds regulations around VOCs (the poison stuff your going to spray all over the place). A little reading between the lines can help get slightly better results, i.e. don't be afraid to thin stuff a bit more than spec'd. Urethane paints are highly toxic. Hang around a paint distributor for a few hours and you'll start to see some of the effects. The toxicity apparently caught some of the old hands by surprise. Ventilation is good, fresh air to breath mandatory in my opinion. I like my fresh air system so much I often use it when sanding fiberglass. Pay attention to data sheets - things like 30 min induction time is mandatory for some paints (e.g. epoxies), not for others. Temperature ranges seem to be important - keeping the aircraft AND the paint within the range eliminates a lot of problems.. If they say spray one light coat, wait, they spray full coat - do it for best results. If they say spray two full coats as a cross coat, do that. Having a paint supplier that is local and accessible is more important than the brand of paint in my opinion. Unless you go with one of the folks that specialize in serving homebuilders. Loehle has documented a lot of good stuff even though I'm not using his system. He has a good pin hole filler product. The good news is that the modern paints are tough and look great. But you really don't want to get any on something you don't want it on - it won't come off easily. Your neighbors will not like any overspray. I wonder what refinishing is like for an aircraft painted with Imron - cant imagine that it strips... does it? Paint guns - A pro-grade HVLP setup seem optimal. By pro grade I mean $$$$ with clean high pressure air to the gun and pressure reduction done in the head. Watching the local pros use there equipment with Imron is entirely different than what I'm doing. I have a high quality HVLP gun with a combination low pressure turbine and fresh air system from Aircraft spruce. Everything you need for about $1,000. I can get good results but not as easily or as productively as the pros around the corner from me. An old style high pressure system will work with this paint too by most accounts (I don't really know). The old pros will swear by it (because it's what they know). You'll waste a lot more paint. The stuff can get very expensive, especially in the fancy colors. You'll throw off a lot more toxic, sticky stuff. Practice practice, and I don't necessarily mean just with the gun. Prep, mixing, everything benefits from practice. Like every job on a first home build, by the time you finish it, you probably have become competent in it. Unlike other jobs (riveting), your early mistakes can be hard to hide. Practice on something else first can be a good thing. Everyone will tell you that it's 90% prep and 10% paint - it's a lie. It's 99% prep for a top notch job. Anyway, I swore I'd never paint. I'm doing it anyway. I'm loving it. Bill On 2/4/2011 8:24 PM, rngurley wrote: > --> RV10-List message posted by: "rngurley" > > I am getting ready to paint my current aircraft. Does anyone have experience with PPG or Dupont (Imron) paint? Unfortunately, my RV10 in not ready to paint - and probably will not be for some time. Thank you in advance for any comments. > > Dick Gurley > ________________________________________________________________________________
Date: Feb 05, 2011
Hey Dick, >From the replies you've received and your response, I think you'll do just fine -- just don't blow yourself up trying to heat your paint both with open flame in cool weather!! Your original query was about Imron vs. PPG. When Imron first came out many years ago, it was the rage cuz it was so tough. Then urethane base/clear came out, and for some reason the car painters (around here at least) never used Imron again. I started painting after Imron was no longer in vogue, and I used PPG with great results for years. Then my supplier got tired of PPG's high expense and now only deals in Dupont -- so Dupont is what I've been using lately. As I'm writing this, I'm waiting the 30 minutes between the second and third blue stripe coat -- Wes trashed his nosewheel pants in a hard landing, so I'm finishing up a new one. I'll include a couple pics of these steps. I've taken pictures of the process from patching the fiberglass (he landed with a low air nosewheel in a trial fit and the tire caught just enough of the back of the glass to break it out) to present -- so if anyone is interested I can send or post all of them. This is Dupont's Centari Acrylic Enamel with gloss hardener added. I like it (or urethane enalmel) better than base/clear for the plane due to the weight of clear, and the ease of touching up the one step paints. One more comment: As you can see, I also paint in pieces in my backyard shop, and I still use lots of newspaper for these small pieces, covering windows, etc. But for covering the fuse and wings for doing stripe work, I agree that plastic or roll paper is the way to go. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329774#329774 Attachments: http://forums.matronics.com//files/bluestripe_medium_116.jpg http://forums.matronics.com//files/stripestaped_medium_798.jpg http://forums.matronics.com//files/white_medium_131.jpg http://forums.matronics.com//files/holesfilled_medium_182.jpg ________________________________________________________________________________
Subject: OMG, u there.
Date: Feb 05, 2011
how have you been doing? I saw this Acai Berry stuff that is really amazing . I have been feeling fantastic ever since i have been taking it. finally d iscovered a way to lose weight that works and is really good for you! check out this article about it if you want to learn more about it and buy some http://health.com/health . You can get from that page for really cheap. I s howed it to a few buddies already and they were thanking me earlier saying they lost 6lbs in under a week so I figured I would fill you in also =3B-) The stuff is crazy. A lot of great info on that site but lemme know if you have any questions about it. ________________________________________________________________________________
Date: Feb 05, 2011
Thank you to all! This has been a great help. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Saturday, February 05, 2011 4:57 PM Subject: RV10-List: Re: Experience with paint - off RV10 topic Hey Dick, >From the replies you've received and your response, I think you'll do just fine -- just don't blow yourself up trying to heat your paint both with open flame in cool weather!! Your original query was about Imron vs. PPG. When Imron first came out many years ago, it was the rage cuz it was so tough. Then urethane base/clear came out, and for some reason the car painters (around here at least) never used Imron again. I started painting after Imron was no longer in vogue, and I used PPG with great results for years. Then my supplier got tired of PPG's high expense and now only deals in Dupont -- so Dupont is what I've been using lately. As I'm writing this, I'm waiting the 30 minutes between the second and third blue stripe coat -- Wes trashed his nosewheel pants in a hard landing, so I'm finishing up a new one. I'll include a couple pics of these steps. I've taken pictures of the process from patching the fiberglass (he landed with a low air nosewheel in a trial fit and the tire caught just enough of the back of the glass to break it out) to present -- so if anyone is interested I can send or post all of them. This is Dupont's Centari Acrylic Enamel with gloss hardener added. I like it (or urethane enalmel) better than base/clear for the plane due to the weight of clear, and the ease of touching up the one step paints. One more comment: As you can see, I also paint in pieces in my backyard shop, and I still use lots of newspaper for these small pieces, covering windows, etc. But for covering the fuse and wings for doing stripe work, I agree that plastic or roll paper is the way to go. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=329774#329774 Attachments: http://forums.matronics.com//files/bluestripe_medium_116.jpg http://forums.matronics.com//files/stripestaped_medium_798.jpg http://forums.matronics.com//files/white_medium_131.jpg http://forums.matronics.com//files/holesfilled_medium_182.jpg ________________________________________________________________________________
Subject: Winter and wheel pants
Date: Feb 05, 2011
Last year I left my wheel pants on for the entire winter. Unfortunately, ice chunks formed in the space behind the tires. The rotation of the tires hurled the chunks around inside the wheel pants and caused the paint to crack and chip from the inside. Last spring I repainted all 3 pants. I didn't want to repeat the painting but I wanted to keep the main gear strut fairings in place so I came up with this solution. The fiberglass was laid up over the wheel pant using duct tape for the separation medium. Each hole on the wheel pant was marked with a sharpie to keep the alignment of the strut correct. I used 4 layers of bidirectional cloth. The layup is in 2 pieces. They were done simultaneously. The aft piece was laid up first. I used 2 pieces of duct placed adhesive side to adhesive side to separate the two pieces. The duct tape was placed on the forward edge of the aft layup and the forward layup was done over the duct tape. After the glass was laid up I ran a nail through each black sharpie mark trying to keep the nail hole centered on the screw hole. I then drilled to the correct size and added nut plates. I'm not going to paint these--the sun is too low to damage them and they are not outside for long. I flew the setup today and noticed no adverse effects. It has been so long since I flew without wheel pants and gear fairings I don't know exactly how much the airspeed is affected and what the difference between the two setups would be. I read somewhere that most of the drag comes from the gear struts so I'm sure it helps some, but how much I can't quantify. Sheldon Olesen N475PV 238 hours ________________________________________________________________________________
Subject: Re: Landing gear shake
Date: Feb 06, 2011
I have posted on this topic before. Mine does the exact same at the same speeds as does many other RV-10's. Sometimes balancing the tire fixes/helps, sometimes different tires, pressur es, ect. I have tried most with no success. I have talked with Van about it and he in dicated that his personal plane even did it. I have also heard that when peo ple installed the wheel pants it started. It all comes down to a poor gear d esign. A round gear leg is not the optimal design for a landing gear but is t he cheapest shape from a manufacturing point of view. It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes . It is the system hitting a natural frequency. Van said people have put a block of wood on the backside of other RV models t o stop it. I spent a considerable amount of time re-drilling my gear legs to get the ex act toe-in on both sides and it did not change one thing. I have tried two d ifferent sets of tires, pressures from 25-60 psi all with no luck. My next p lan, when I get to it, is to install the wheel pant spacers from PlaneAround .com and start stiffening the wheel pant to the gear. Then I will start find ing a good way change the moment of inertia of the gear leg, stiffening it i n the front to back direction. I've been told by Vans not to worry about it. Just think of it as a massage w ith every landing. I will find a way to eliminate it though. Let me know if you find anything out. Thanks, Scott On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but n othing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly m oving forward and back. > Are others noticing this shaking? Is there a fix or a way to minimize the s haking that anyone has discovered? > > Thank you, > > Roger Standley > N291RV > 165 hours > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 06, 2011
Thanks, Linn... I sometimes do slouch quite a bit, which is probably what you're seeing. I did some adusting, per your recommendaton, and I think it'll work. Now I just need to figure out what seat position I want to fly it in. -Rob On Fri, Feb 4, 2011 at 3:12 PM, Linn Walters wrote: > > Rob, I agree that the pads could be a little more forward. In the first > picture it looks like you're leaning forward a little to put tension on the > harness. Either that or you have a serious shoulder/back problem!!! > If it was me, I'd move the 'Y' forward a little and then take the slack out > by pulling on the adjustment for the shoulder belts. The shoulder harness > should be adjusted so that in your 'cruise' seat position with the harness > just a little slack from snug (yeah, go ahead and measure that!) you can > reach all the stuff on the panel that you need to ..... without having to > twist the upper torso very much. The only problem moving the 'Y' forward is > that it causes the shoulder belts to rub the side of the neck. This is a > problem I have in my Pitts, and the solution was the shoulder pads for car > shoulder belts. Nice and soft on the neck now. But you'd hate to just > cover up the pads you paid so dearly for. > Linn > > > On 2/4/2011 2:25 PM, Rob Kochman wrote: > >> Anyone using the Crow seatbelts in their -10? When I ordered mine, I >> didn't specify and dimensions--I just said I needed a complete set for the >> RV-10, since I understand they've done a few. Having now installed mine, >> the shoulder straps seem to be too short between the latch and the "Y". See >> the attached pictures. The "Y" is right on top of the headrest. I could >> move that back a few inches, but then the shoulder pads would be in the >> wrong place. Something doesn't seem right here--any ideas? >> -Rob >> >> -- >> Rob Kochman >> RV-10 "Finishing" Kit >> Woodinville, WA (near Seattle) >> http://kochman.net/N819K >> > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Feb 07, 2011
I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > I have posted on this topic before. > Mine does the exact same at the same speeds as does many other RV-10's. > Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect. > I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view. > It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency. > Van said people have put a block of wood on the backside of other RV models to stop it. > > I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction. > I've been told by Vans not to worry about it. Just think of it as a massage with every landing. > I will find a way to eliminate it though. > > Let me know if you find anything out. > Thanks, Scott > > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > >> >> Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back. >> Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered? >> >> Thank you, >> >> Roger Standley >> N291RV >> 165 hours >> >> >> ======================== >> ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List >> ======================== >> ums.matronics.com">http://forums.matronics.com >> ======================== >> http://www.matronics.com/contribution">http://www.matronics.com/contributi on >> ======================== >> > > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Subject: Landing gear shake
Date: Feb 07, 2011
I mounted a camera on the bottom of my RV-10 to find out what was shaking and what was not. The main gear has a shake at 34 kts and started When I put my wheel pants on. I have balanced and changed air pressures with no real success. The nose gear would shimmy at 15kts if Tension was loose. The camera shows the wheel pants get into an oscillating motion. It is an up down motion. And as Scott I believe it is from the Poor gear design. I have no noticeable shake on grass. My shake seems to be worse with more load in the airplane. That being said I can break hard quick thru it and without much shake. Geoff Geoff Combs President 614-834-5227p 614-834-5230f www.aerosportmodeling.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Monday, February 07, 2011 10:59 AM Subject: Re: RV10-List: Landing gear shake I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: I have posted on this topic before. Mine does the exact same at the same speeds as does many other RV-10's. Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect. I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view. It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency. Van said people have put a block of wood on the backside of other RV models to stop it. I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com <http://PlaneAround.com/> and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction. I've been told by Vans not to worry about it. Just think of it as a massage with every landing. I will find a way to eliminate it though. Let me know if you find anything out. Thanks, Scott On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back. Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered? Thank you, Roger Standley N291RV 165 hours ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/ Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contribution ========= href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ________________________________________________________________________________
Date: Feb 07, 2011
I did exactly the same thing as Geoff and got exactly the same results. David Maib 40559 340 hours On Feb 7, 2011, at 11:34 AM, Geoff Combs wrote: > I mounted a camera on the bottom of my RV-10 to find out what was shaking and what was not. The main gear has a shake at 34 kts and started > When I put my wheel pants on. I have balanced and changed air pressures with no real success. The nose gear would shimmy at 15kts if > Tension was loose. The camera shows the wheel pants get into an oscillating motion. It is an up down motion. And as Scott I believe it is from the > Poor gear design. I have no noticeable shake on grass. My shake seems to be worse with more load in the airplane. That being said I can break hard > quick thru it and without much shake. > > Geoff > > Geoff Combs > President > 614-834-5227p > 614-834-5230f > www.aerosportmodeling.com > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Monday, February 07, 2011 10:59 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Landing gear shake > > I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > > > I have posted on this topic before. > Mine does the exact same at the same speeds as does many other RV-10's. > Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect. > I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view. > It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency. > Van said people have put a block of wood on the backside of other RV models to stop it. > > I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction. > I've been told by Vans not to worry about it. Just think of it as a massage with every landing. > I will find a way to eliminate it though. > > Let me know if you find anything out. > Thanks, Scott > > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > >> >> Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back. >> Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered? >> >> Thank you, >> >> Roger Standley >> N291RV >> 165 hours >> >> >> ========= >> ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> ========= >> ums.matronics.com">http://forums.matronics.com >> ========= >> http://www.matronics.com/contribution">http://www.matronics.com/contribution >> ========= >> > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > ________________________________________________________________________________
Date: Feb 07, 2011
Jesse, I really like what you tried and have thought about it. I never had a shake until around 100 - 150 hours. If the front gear settles down slightly it changes the toe-in. If it is still possible can you measure the distance between the prop and the ground? Where did you purchase the spacer? Scott Schmidt ________________________________ From: Jesse Saint <jesse(at)saintaviation.com> Sent: Mon, February 7, 2011 8:59:26 AM Subject: Re: RV10-List: Landing gear shake I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: I have posted on this topic before. >Mine does the exact same at the same speeds as does many other RV-10's. >Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, >ect. >I have tried most with no success. I have talked with Van about it and he >indicated that his personal plane even did it. I have also heard that when >people installed the wheel pants it started. It all comes down to a poor gear >design. A round gear leg is not the optimal design for a landing gear but is the >cheapest shape from a manufacturing point of view. >It is not the caliper either. Even if I slow down with no braking it occurs. I >can replicate it on the ground with one wheel jacked up and use my buffer to get >the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the >system hitting a natural frequency. >Van said people have put a block of wood on the backside of other RV models to >stop it. > > >I spent a considerable amount of time re-drilling my gear legs to get the exact >toe-in on both sides and it did not change one thing. I have tried two different >sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I >get to it, is to install the wheel pant spacers from PlaneAround.com and start >stiffening the wheel pant to the gear. Then I will start finding a good way >change the moment of inertia of the gear leg, stiffening it in the front to back >direction. >I've been told by Vans not to worry about it. Just think of it as a massage with >every landing. >I will find a way to eliminate it though. > > >Let me know if you find anything out. >Thanks, Scott > >On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > >>Today I was able to have a guy observe the gear up close as I was landing. >>I have been feeling a shake during roll out below 30 mph. Sometimes not too >>much but sometimes significant. Applying brakes seems to make it worse but >>nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are >>smooth. He said that the left main was shaking and it looked to be rapidly >>moving forward and back. >> >> >>Are others noticing this shaking? Is there a fix or a way to minimize the >>shaking that anyone has discovered? >> >>Thank you, >> >>Roger Standley >>N291RV >>165 hours >> >> ========== >>ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List========= >> ums.matronics.com">http://forums.matronics.com >>========= >>http://www.matronics.com/contribution">http://www.matronics.com/contribution========= >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution n ________________________________________________________________________________
Date: Feb 07, 2011
One more question, how did you know you needed to add a spacer during the conditional inspection? Is there something you are looking at? Scott Schmidt ________________________________ From: Jesse Saint <jesse(at)saintaviation.com> Sent: Mon, February 7, 2011 8:59:26 AM Subject: Re: RV10-List: Landing gear shake I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: I have posted on this topic before. >Mine does the exact same at the same speeds as does many other RV-10's. >Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, >ect. >I have tried most with no success. I have talked with Van about it and he >indicated that his personal plane even did it. I have also heard that when >people installed the wheel pants it started. It all comes down to a poor gear >design. A round gear leg is not the optimal design for a landing gear but is the >cheapest shape from a manufacturing point of view. >It is not the caliper either. Even if I slow down with no braking it occurs. I >can replicate it on the ground with one wheel jacked up and use my buffer to get >the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the >system hitting a natural frequency. >Van said people have put a block of wood on the backside of other RV models to >stop it. > > >I spent a considerable amount of time re-drilling my gear legs to get the exact >toe-in on both sides and it did not change one thing. I have tried two different >sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I >get to it, is to install the wheel pant spacers from PlaneAround.com and start >stiffening the wheel pant to the gear. Then I will start finding a good way >change the moment of inertia of the gear leg, stiffening it in the front to back >direction. >I've been told by Vans not to worry about it. Just think of it as a massage with >every landing. >I will find a way to eliminate it though. > > >Let me know if you find anything out. >Thanks, Scott > >On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > >>Today I was able to have a guy observe the gear up close as I was landing. >>I have been feeling a shake during roll out below 30 mph. Sometimes not too >>much but sometimes significant. Applying brakes seems to make it worse but >>nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are >>smooth. He said that the left main was shaking and it looked to be rapidly >>moving forward and back. >> >> >>Are others noticing this shaking? Is there a fix or a way to minimize the >>shaking that anyone has discovered? >> >>Thank you, >> >>Roger Standley >>N291RV >>165 hours >> >> ========== >>ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List========= >> ums.matronics.com">http://forums.matronics.com >>========= >>http://www.matronics.com/contribution">http://www.matronics.com/contribution========= >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution n ________________________________________________________________________________
Date: Feb 07, 2011
Jesse, I am also interested in how to tell you need an additional spacer. My condition inspection starts at the end of this month..I have 150 tack hours on the airplane. Scott, there were two spacers provide in the kit..now if I can just find the second one.. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Monday, February 07, 2011 10:17 AM Subject: Re: RV10-List: Landing gear shake Jesse, I really like what you tried and have thought about it. I never had a shake until around 100 - 150 hours. If the front gear settles down slightly it changes the toe-in. If it is still possible can you measure the distance between the prop and the ground? Where did you purchase the spacer? Scott Schmidt _____ From: Jesse Saint <jesse(at)saintaviation.com> Sent: Mon, February 7, 2011 8:59:26 AM Subject: Re: RV10-List: Landing gear shake I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: I have posted on this topic before. Mine does the exact same at the same speeds as does many other RV-10's. Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect. I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view. It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency. Van said people have put a block of wood on the backside of other RV models to stop it. I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com <http://PlaneAround.com/> and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction. I've been told by Vans not to worry about it. Just think of it as a massage with every landing. I will find a way to eliminate it though. Let me know if you find anything out. Thanks, Scott On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back. Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered? Thank you, Roger Standley N291RV 165 hours ========= ref="http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/ Navigator?RV10-List> ">http://www.matronics.com/Navigator?RV10-List========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3Ehttp:/www.matronics.com/contribu tion> ">http://www.matronics.com/contribution========= href="http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/ Navigator?RV10-Listhref=%22http://forums.matronics.com/%22%3Ehttp://forums.m atronics.com> ">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics. com/">http://forums.matronics.com href="http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3Ehttp:/www.matronics.com/contribu tion> ">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 07, 2011
The spacer came from Van's. It's part # U-1002 on page 46-07. I had someone hold the tail down and then I lifted up on the nose gear to see if it was tight. It moved, so I knew it needed another spacer. You can also tell if the bolt holding the cap on can move freely when you loosen the nut. The distance from the prop to the ground depends on how the engine hangs on the engine mounts and other things, but I'll measure it...7.5". Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 7, 2011, at 12:16 PM, Scott Schmidt wrote: > Jesse, I really like what you tried and have thought about it. I never had a shake until around 100 - 150 hours. If the front gear settles down slightly it changes the toe-in. > If it is still possible can you measure the distance between the prop and the ground? > Where did you purchase the spacer? > > Scott Schmidt > > > > From: Jesse Saint <jesse(at)saintaviation.com> > To: rv10-list(at)matronics.com > Sent: Mon, February 7, 2011 8:59:26 AM > Subject: Re: RV10-List: Landing gear shake > > I just did a condition inspection on N256H. Before the condition it had a fair bit of shimmy in the 25-30 mph range after landing. I added another spacer on the nose gear shock strut and tightened the nose gear pivot nut one flat. Most of the shimmy went away. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > >> I have posted on this topic before. >> Mine does the exact same at the same speeds as does many other RV-10's. >> Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, ect. >> I have tried most with no success. I have talked with Van about it and he indicated that his personal plane even did it. I have also heard that when people installed the wheel pants it started. It all comes down to a poor gear design. A round gear leg is not the optimal design for a landing gear but is the cheapest shape from a manufacturing point of view. >> It is not the caliper either. Even if I slow down with no braking it occurs. I can replicate it on the ground with one wheel jacked up and use my buffer to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the system hitting a natural frequency. >> Van said people have put a block of wood on the backside of other RV models to stop it. >> >> I spent a considerable amount of time re-drilling my gear legs to get the exact toe-in on both sides and it did not change one thing. I have tried two different sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I get to it, is to install the wheel pant spacers from PlaneAround.com and start stiffening the wheel pant to the gear. Then I will start finding a good way change the moment of inertia of the gear leg, stiffening it in the front to back direction. >> I've been told by Vans not to worry about it. Just think of it as a massage with every landing. >> I will find a way to eliminate it though. >> >> Let me know if you find anything out. >> Thanks, Scott >> >> On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: >> >>> >>> Today I was able to have a guy observe the gear up close as I was landing. I have been feeling a shake during roll out below 30 mph. Sometimes not too much but sometimes significant. Applying brakes seems to make it worse but nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are smooth. He said that the left main was shaking and it looked to be rapidly moving forward and back. >>> Are others noticing this shaking? Is there a fix or a way to minimize the shaking that anyone has discovered? >>> >>> Thank you, >>> >>> Roger Standley >>> N291RV >>> 165 hours >>> >>> >>> ========= >>> ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List========= >>> ums.matronics.com">http://forums.matronics.com >>> ========= >>> http://www.matronics.com/contribution">http://www.matronics.com/contributi on========= >>> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forum s.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >> > > > > > > > > ________________________________________________________________________________
Subject: Fuel tank dimple dies
Date: Feb 07, 2011
I'm ready to dimple the fuel tanks. I have the tank dimple dies. My question is do I dimple both the holes in the skins and interior parts with the tank dies or just the interior parts with the tank dies? Doesn't seem like the skins would need the "oversized" dimple but they may have to be the same as the interior parts. Bill ________________________________________________________________________________
Subject: Re: Fuel tank dimple dies
Date: Feb 07, 2011
I used them on both. To be honest it didn't even occur to me not to. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330008#330008 ________________________________________________________________________________
Date: Feb 07, 2011
Good enough. Thanks again for the help. Bill -------------------------------------------------- From: "tsts4" <tsts4(at)verizon.net> Sent: Monday, February 07, 2011 12:34 PM Subject: RV10-List: Re: Fuel tank dimple dies > > I used them on both. To be honest it didn't even occur to me not to. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330008#330008 > > > > > > > > > > ________________________________________________________________________________
From: "carl.froehlich(at)verizon.net" <carl.froehlich(at)verizon.net>
Date: Feb 07, 2011
RGltcGxlIGJvdGggd2l0aCB0aGUgdGFuayBkaWVzLiAgWW91IGVuZCB1cCB3aXRoIGp1c3QgYSBs aXR0bGUgbW9yZSBwcm9zZWFsIHVuZGVyIHRoZSByaXZldCBoZWFkLgoKQ2FybAoKU2VudCBmcm9t IG15IG1vYmlsZSBwaG9uZS7CoMKgIFBsZWFzZSByZWFkIHBhc3QgdGhlIHR5cG9zLgoKLS0tLS1P cmlnaW5hbCBtZXNzYWdlLS0tLS0KRnJvbTogQmlsbHkgJiBUYW1pIEJyaXR0b24gPHdpbGxpYW1A Z2J0YS5uZXQ+ClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQpTZW50OiBNb24sIEZlYiA3LCAy MDExIDE3OjU3OjIwIEdNVCswMDowMApTdWJqZWN0OiBSVjEwLUxpc3Q6IEZ1ZWwgdGFuayBkaW1w bGUgZGllcwoKSSdtIHJlYWR5IHRvIGRpbXBsZSB0aGUgZnVlbCB0YW5rcy4gIEkgaGF2ZSB0aGUg dGFuayBkaW1wbGUgZGllcy4gIE15IHF1ZXN0aW9uIGlzIGRvIEkgZGltcGxlIGJvdGggdGhlIGhv bGVzIGluIHRoZSBza2lucyBhbmQgaW50ZXJpb3IgcGFydHMgd2l0aCB0aGUgdGFuayBkaWVzIG9y IGp1c3QgdGhlIGludGVyaW9yIHBhcnRzIHdpdGggdGhlICB0YW5rIGRpZXM/ICBEb2Vzbid0IHNl ZW0gbGlrZSB0aGUgc2tpbnMgd291bGQgbmVlZCB0aGUgIm92ZXJzaXplZCIgZGltcGxlIGJ1dCB0 aGV5IG1heSBoYXZlIHRvIGJlIHRoZSBzYW1lIGFzIHRoZSBpbnRlcmlvciBwYXJ0cy4KCkJpbGwK Cg= ________________________________________________________________________________
Date: Feb 07, 2011
Has anyone tried counter balancing the wheel pants with some weight up front, just like your control surfaces have? I don't remember where I heard that suggestion, but might make sense to change the harmonic frequency of the wheel pants. Kellyt On Mon, Feb 7, 2011 at 9:34 AM, Geoff Combs wrote: > I mounted a camera on the bottom of my RV-10 to find out what was shaking > and what was not. The main gear has a shake at 34 kts and started > > When I put my wheel pants on. I have balanced and changed air pressures with > no real success. The nose gear would shimmy at 15kts if > > Tension was loose. The camera shows the wheel pants get into an oscillating > motion. It is an up down motion. And as Scott I believe it is from the > > Poor gear design. I have no noticeable shake on grass. My shake seems to be > worse with more load in the airplane. That being said I can break hard > > quick thru it and without much shake. > > > Geoff > > > Geoff Combs > > President > > 614-834-5227p > 614-834-5230f > > www.aerosportmodeling.com > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Monday, February 07, 2011 10:59 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Landing gear shake > > > I just did a condition inspection on N256H. Before the condition it had a > fair bit of shimmy in the 25-30 mph range after landing. I added another > spacer on the nose gear shock strut and tightened the nose gear pivot nut > one flat. Most of the shimmy went away. > > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > > I have posted on this topic before. > > Mine does the exact same at the same speeds as does many other RV-10's. > > Sometimes balancing the tire fixes/helps, sometimes different tires, > pressures, ect. > > I have tried most with no success. I have talked with Van about it and he > indicated that his personal plane even did it. I have also heard that when > people installed the wheel pants it started. It all comes down to a poor > gear design. A round gear leg is not the optimal design for a landing gear > but is the cheapest shape from a manufacturing point of view. > > It is not the caliper either. Even if I slow down with no braking it occurs. > I can replicate it on the ground with one wheel jacked up and use my buffer > to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. > It is the system hitting a natural frequency. > > Van said people have put a block of wood on the backside of other RV models > to stop it. > > > I spent a considerable amount of time re-drilling my gear legs to get the > exact toe-in on both sides and it did not change one thing. I have tried two > different sets of tires, pressures from 25-60 psi all with no luck. My next > plan, when I get to it, is to install the wheel pant spacers from > PlaneAround.com and start stiffening the wheel pant to the gear. Then I will > start finding a good way change the moment of inertia of the gear leg, > stiffening it in the front to back direction. > > I've been told by Vans not to worry about it. Just think of it as a massage > with every landing. > > I will find a way to eliminate it though. > > > Let me know if you find anything out. > > Thanks, Scott > > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > Today I was able to have a guy observe the gear up close as I was landing. > Ihave beenfeeling a shake during roll out below 30 mph. Sometimes not too > much but sometimes significant. Applying brakes seems to make it worse but > nothingwill make it stop until slowing below 20 mph. Speeds above 30 mph > are smooth. He said that the left main was shaking andit looked to be > rapidly moving forward and back. > > Are others noticing this shaking? Is there a fix or a way to minimize the > shaking that anyone has discovered? > > > Thank you, > > > Roger Standley > > N291RV > > 165 hours > > > ========= > > ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > ========= > > ums.matronics.com">http://forums.matronics.com > > ========= > > http://www.matronics.com/contribution">http://www.matronics.com/contribution > > ========= > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > href="http://forums.matronics.com/">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ________________________________________________________________________________
Date: Feb 07, 2011
Tim Olson and a few others. Tim has the writeup on his website. -----Original Message----- From: Kelly McMullen Sent: Monday, February 07, 2011 12:17 PM Subject: Re: RV10-List: Landing gear shake Has anyone tried counter balancing the wheel pants with some weight up front, just like your control surfaces have? I don't remember where I heard that suggestion, but might make sense to change the harmonic frequency of the wheel pants. Kellyt On Mon, Feb 7, 2011 at 9:34 AM, Geoff Combs wrote: > I mounted a camera on the bottom of my RV-10 to find out what was shaking > and what was not. The main gear has a shake at 34 kts and started > > When I put my wheel pants on. I have balanced and changed air pressures > with > no real success. The nose gear would shimmy at 15kts if > > Tension was loose. The camera shows the wheel pants get into an > oscillating > motion. It is an up down motion. And as Scott I believe it is from the > > Poor gear design. I have no noticeable shake on grass. My shake seems to > be > worse with more load in the airplane. That being said I can break hard > > quick thru it and without much shake. > > > Geoff > > > Geoff Combs > > President > > 614-834-5227p > 614-834-5230f > > www.aerosportmodeling.com > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Monday, February 07, 2011 10:59 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Landing gear shake > > > I just did a condition inspection on N256H. Before the condition it had a > fair bit of shimmy in the 25-30 mph range after landing. I added another > spacer on the nose gear shock strut and tightened the nose gear pivot nut > one flat. Most of the shimmy went away. > > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > > I have posted on this topic before. > > Mine does the exact same at the same speeds as does many other RV-10's. > > Sometimes balancing the tire fixes/helps, sometimes different tires, > pressures, ect. > > I have tried most with no success. I have talked with Van about it and he > indicated that his personal plane even did it. I have also heard that when > people installed the wheel pants it started. It all comes down to a poor > gear design. A round gear leg is not the optimal design for a landing gear > but is the cheapest shape from a manufacturing point of view. > > It is not the caliper either. Even if I slow down with no braking it > occurs. > I can replicate it on the ground with one wheel jacked up and use my > buffer > to get the wheel up to 50 mph and when it slows to around 25 mph, it > shakes. > It is the system hitting a natural frequency. > > Van said people have put a block of wood on the backside of other RV > models > to stop it. > > > I spent a considerable amount of time re-drilling my gear legs to get the > exact toe-in on both sides and it did not change one thing. I have tried > two > different sets of tires, pressures from 25-60 psi all with no luck. My > next > plan, when I get to it, is to install the wheel pant spacers from > PlaneAround.com and start stiffening the wheel pant to the gear. Then I > will > start finding a good way change the moment of inertia of the gear leg, > stiffening it in the front to back direction. > > I've been told by Vans not to worry about it. Just think of it as a > massage > with every landing. > > I will find a way to eliminate it though. > > > Let me know if you find anything out. > > Thanks, Scott > > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > Today I was able to have a guy observe the gear up close as I was landing. > I have been feeling a shake during roll out below 30 mph. Sometimes not > too > much but sometimes significant. Applying brakes seems to make it worse but > nothing will make it stop until slowing below 20 mph. Speeds above 30 mph > are smooth. He said that the left main was shaking and it looked to be > rapidly moving forward and back. > > Are others noticing this shaking? Is there a fix or a way to minimize the > shaking that anyone has discovered? > > > Thank you, > > > Roger Standley > > N291RV > > 165 hours > > > ========= > > ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > ========= > > ums.matronics.com">http://forums.matronics.com > > ========= > > http://www.matronics.com/contribution">http://www.matronics.com/contribution > > ========= > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > href="http://forums.matronics.com/">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ________________________________________________________________________________
Date: Feb 07, 2011
Yep. lot's of us have done it.... but it seems we all end up with some amou nt of =0A"shake".- Mine disappeared totally.... for quite a while after i nstalling =0AGoodyear FCIII's.- I have a small amount now, but acceptable .--Always try to =0Aavoid braking as long as possible.=0ADon- =0A=0A =0A=0A=0A________________________________=0AFrom: Kelly McMullen <apilot2@g mail.com>=0ATo: rv10-list(at)matronics.com=0ASent: Mon, February 7, 2011 2:17: 06 PM=0ASubject: Re: RV10-List: Landing gear shake=0A=0A--> RV10-List messa ge posted by: Kelly McMullen =0A=0AHas anyone tried coun ter balancing the wheel pants with some weight up=0Afront, just like your c ontrol surfaces have? I don't remember where I=0Aheard that suggestion, but might make sense to change the harmonic=0Afrequency of the wheel pants.=0A Kellyt=0A=0AOn Mon, Feb 7, 2011 at 9:34 AM, Geoff Combs=0A<g.combs@aerospor tmodeling.com> wrote:=0A> I mounted a camera on the bottom of my RV-10 to f ind out what was shaking=0A> and what was not. The main gear has a shake at 34 kts and started=0A>=0A> When I put my wheel pants on. I have balanced a nd changed air pressures with=0A> no real success. The nose gear would shim my at 15kts if=0A>=0A> Tension was loose. The camera shows the wheel pants get into an oscillating=0A> motion. It is an up down motion. And as Scott I believe it is from the=0A>=0A> Poor gear design. I have no noticeable shak e on grass. My shake seems to be=0A> worse with more load in the airplane. That being said I can break hard=0A>=0A> quick thru it and without much sha ke.=0A>=0A>=0A>=0A> Geoff=0A>=0A>=0A>=0A> Geoff Combs=0A>=0A> President=0A> =0A> 614-834-5227p=0A> 614-834-5230f=0A>=0A> www.aerosportmodeling.com=0A> =0A>=0A>=0A> ________________________________=0A>=0A> From: owner-rv10-list -server(at)matronics.com=0A> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint=0A> Sent: Monday, February 07, 2011 10:59 AM=0A> To: rv10-list(at)matronics.com=0A> Subject: Re: RV10-List: Landing gear shake=0A> =0A>=0A>=0A> I just did a condition inspection on N256H. -Before the cond ition it had a=0A> fair bit of shimmy in the 25-30 mph range after landing. -I added another=0A> spacer on the nose gear shock strut and tightened t he nose gear pivot nut=0A> one flat. -Most of the shimmy went away.=0A> =0A>=0A>=0A> Jesse Saint=0A> Saint Aviation, Inc.=0A> jesse(at)saintaviation.c om=0A> C: 352-427-0285=0A> F: 815-377-3694=0A>=0A>=0A>=0A> On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote:=0A>=0A> I have posted on this topic before .=0A>=0A> Mine does the exact same at the same speeds as does many other RV -10's.=0A>=0A> Sometimes balancing the tire fixes/helps, sometimes differen t tires,=0A> pressures, ect.=0A>=0A> I have tried most with no success. I h ave talked with Van about it and he=0A> indicated that his personal plane e ven did it. I have also heard that when=0A> people installed the wheel pant s it started. It all comes down to a poor=0A> gear design. A round gear leg is not the optimal design for a landing gear=0A> but is the cheapest shape from a manufacturing point of view.=0A>=0A> It is not the caliper either. Even if I slow down with no braking it occurs.=0A> I can replicate it on th e ground with one wheel jacked up and use my buffer=0A> to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes.=0A> It is the sys tem hitting a natural frequency.=0A>=0A> Van said people have put a block o f wood on the backside of other RV models=0A> to stop it.=0A>=0A>=0A>=0A> I spent a considerable amount of time re-drilling my gear legs to get the=0A > exact toe-in on both sides and it did not change one thing. I have tried two=0A> different sets of tires, pressures from 25-60 psi all with no luck. My next=0A> plan, when I get to it, is to install the wheel pant spacers f rom=0A> PlaneAround.com and start stiffening the wheel pant to the gear. Th en I will=0A> start finding a good way change the moment of inertia of the gear leg,=0A> stiffening it in the front to back direction.=0A>=0A> I've be en told by Vans not to worry about it. Just think of it as a massage=0A> wi th every landing.=0A>=0A> I will find a way to eliminate it though.=0A>=0A> =0A>=0A> Let me know if you find anything out.=0A>=0A> Thanks, Scott=0A>=0A > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: =0A>=0A> Today I was able to have a guy observe the gear up close as I was landing.=0A> I-have been-feeling a shake during roll out below 30 mph. Sometimes not too=0A> much but sometimes significant. Applying brakes seems to make it worse but=0A> nothing-will make it stop until slowing below 2 0 mph. Speeds above 30 mph=0A> are smooth. He said that the left main was s haking and-it looked to be=0A> rapidly moving forward and back.=0A>=0A> A re others noticing this shaking? Is there a fix or a way to minimize the=0A > shaking that anyone has discovered?=0A>=0A>=0A>=0A> Thank you,=0A>=0A>=0A >=0A> Roger Standley=0A>=0A> N291RV=0A>=0A> 165 hours=0A>=0A>=0A>=0A>=0A> =0A> ===========0A>=0A>ref="http://www.matronics.com/ Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List=0A>t=0A> =0A> ===========0A>=0A> ums.matronics.com">http://forum s.matronics.com=0A>=0A> ===========0A>=0A> http://www.m atronics.com/contribution">http://www.matronics.com/contribution=0A>=0A> ===========0A>=0A>=0A>=0A>=0A>=0A>=0A>=0A>href="http: //www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator ?RV10-List=0A>t=0A>=0A> href="http://forums.matronics.com/">http://forums .matronics.com=0A>=0A>href="http://www.matronics.com/contribution">http:/ /www.matronics.com/contribution=0A>n=0A>=0A>=0A>=0A>=0A>=0A>href="http:// www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?R V10-List=0A>t=0A> href="http://forums.matronics.com">http://forums.matron ics.com=0A> href="http://www.matronics.com/contribution">http://www.matro =========================0A =0A=0A ________________________________________________________________________________
Subject: No longer a project
Date: Feb 07, 2011
DAR stopped by yesterday afternoon. He had already inspected it apart and wanted it all together. He took a look at it, watched me run it and taxi it around the airfield. Satisfied, and after 45 minutes of paperwork he handed me the airworthiness certificate. I guess it is no longer a project. Now it is an airplane. It was too late in the day to fly, sun was going down. Weather today was absolute garbage. Maybe first flight next Saturday, just waiting on weather. Already starting to get the grin and haven't even flown it yet. Eric N518RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330043#330043 ________________________________________________________________________________
Date: Feb 07, 2011
Subject: Re: No longer a project
Congrats on the airworthiness, Your DAR seems a bit anal. Hope your first f light =0Ais flawless.=0A=0A151BJ 38.6 hrs=0A=0A=0A=0A=0A___________________ _____________=0AFrom: Eric_Kallio <scout019(at)msn.com>=0ATo: rv10-list@matron ics.com=0ASent: Mon, February 7, 2011 2:46:16 PM=0ASubject: RV10-List: No l 19(at)msn.com>=0A=0ADAR stopped by yesterday afternoon. He had already inspect ed it apart and wanted =0Ait all together. He took a look at it, watched me run it and taxi it around the =0Aairfield. Satisfied, and after 45 minutes of paperwork he handed me the =0Aairworthiness certificate. I guess it is no longer a project. Now it is an =0Aairplane. It was too late in the day t o fly, sun was going down. Weather today =0Awas absolute garbage. Maybe fir st flight next Saturday, just waiting on weather. =0AAlready starting to ge t the grin and haven't even flown it yet.=0A=0AEric=0AN518RV=0A=0A=0A=0A=0A Read this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php =0A=0A=0A ________________________________________________________________________________
Date: Feb 07, 2011
"I guess it is no longer a project"? Who have you been talking to? It'll always be a project!!! CONGRATS! Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 7, 2011, at 4:46 PM, Eric_Kallio wrote: > > DAR stopped by yesterday afternoon. He had already inspected it apart and wanted it all together. He took a look at it, watched me run it and taxi it around the airfield. Satisfied, and after 45 minutes of paperwork he handed me the airworthiness certificate. I guess it is no longer a project. Now it is an airplane. It was too late in the day to fly, sun was going down. Weather today was absolute garbage. Maybe first flight next Saturday, just waiting on weather. Already starting to get the grin and haven't even flown it yet. > > Eric > N518RV > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330043#330043 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 07, 2011
Yes, I did that as well with no change. Scott Schmidt ________________________________ From: Kelly McMullen <apilot2(at)gmail.com> Sent: Mon, February 7, 2011 1:17:06 PM Subject: Re: RV10-List: Landing gear shake Has anyone tried counter balancing the wheel pants with some weight up front, just like your control surfaces have? I don't remember where I heard that suggestion, but might make sense to change the harmonic frequency of the wheel pants. Kellyt On Mon, Feb 7, 2011 at 9:34 AM, Geoff Combs wrote: > I mounted a camera on the bottom of my RV-10 to find out what was shaking > and what was not. The main gear has a shake at 34 kts and started > > When I put my wheel pants on. I have balanced and changed air pressures with > no real success. The nose gear would shimmy at 15kts if > > Tension was loose. The camera shows the wheel pants get into an oscillating > motion. It is an up down motion. And as Scott I believe it is from the > > Poor gear design. I have no noticeable shake on grass. My shake seems to be > worse with more load in the airplane. That being said I can break hard > > quick thru it and without much shake. > > > Geoff > > > Geoff Combs > > President > > 614-834-5227p > 614-834-5230f > > www.aerosportmodeling.com > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint > Sent: Monday, February 07, 2011 10:59 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Landing gear shake > > > I just did a condition inspection on N256H. Before the condition it had a > fair bit of shimmy in the 25-30 mph range after landing. I added another > spacer on the nose gear shock strut and tightened the nose gear pivot nut > one flat. Most of the shimmy went away. > > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > > I have posted on this topic before. > > Mine does the exact same at the same speeds as does many other RV-10's. > > Sometimes balancing the tire fixes/helps, sometimes different tires, > pressures, ect. > > I have tried most with no success. I have talked with Van about it and he > indicated that his personal plane even did it. I have also heard that when > people installed the wheel pants it started. It all comes down to a poor > gear design. A round gear leg is not the optimal design for a landing gear > but is the cheapest shape from a manufacturing point of view. > > It is not the caliper either. Even if I slow down with no braking it occurs. > I can replicate it on the ground with one wheel jacked up and use my buffer > to get the wheel up to 50 mph and when it slows to around 25 mph, it shakes. > It is the system hitting a natural frequency. > > Van said people have put a block of wood on the backside of other RV models > to stop it. > > > I spent a considerable amount of time re-drilling my gear legs to get the > exact toe-in on both sides and it did not change one thing. I have tried two > different sets of tires, pressures from 25-60 psi all with no luck. My next > plan, when I get to it, is to install the wheel pant spacers from > PlaneAround.com and start stiffening the wheel pant to the gear. Then I will > start finding a good way change the moment of inertia of the gear leg, > stiffening it in the front to back direction. > > I've been told by Vans not to worry about it. Just think of it as a massage > with every landing. > > I will find a way to eliminate it though. > > > Let me know if you find anything out. > > Thanks, Scott > > On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: > > Today I was able to have a guy observe the gear up close as I was landing. > I have been feeling a shake during roll out below 30 mph. Sometimes not too > much but sometimes significant. Applying brakes seems to make it worse but > nothing will make it stop until slowing below 20 mph. Speeds above 30 mph > are smooth. He said that the left main was shaking and it looked to be > rapidly moving forward and back. > > Are others noticing this shaking? Is there a fix or a way to minimize the > shaking that anyone has discovered? > > > Thank you, > > > Roger Standley > > N291RV > > 165 hours > > > ========= > >ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >t > > ========= > > ums.matronics.com">http://forums.matronics.com > > ========= > > http://www.matronics.com/contribution">http://www.matronics.com/contribution > > ========= > > >href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >t > > href="http://forums.matronics.com/">http://forums.matronics.com > >href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >n > > >href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >t > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ________________________________________________________________________________
Date: Feb 07, 2011
Mine measured at 8 11/32". Don't know if there is any slop in the rubber discs yet. Interesting it is over one 1" taller. Scott Schmidt ________________________________ From: Jesse Saint <jesse(at)saintaviation.com> Sent: Mon, February 7, 2011 10:47:58 AM Subject: Re: RV10-List: Landing gear shake The spacer came from Van's. It's part # U-1002 on page 46-07. I had someone hold the tail down and then I lifted up on the nose gear to see if it was tight. It moved, so I knew it needed another spacer. You can also tell if the bolt holding the cap on can move freely when you loosen the nut. The distance from the prop to the ground depends on how the engine hangs on the engine mounts and other things, but I'll measure it...7.5". Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 7, 2011, at 12:16 PM, Scott Schmidt wrote: Jesse, I really like what you tried and have thought about it. I never had a shake until around 100 - 150 hours. If the front gear settles down slightly it changes the toe-in. >If it is still possible can you measure the distance between the prop and the >ground? >Where did you purchase the spacer? > > Scott Schmidt > > ________________________________ From: Jesse Saint <jesse(at)saintaviation.com> >To: rv10-list(at)matronics.com >Sent: Mon, February 7, 2011 8:59:26 AM >Subject: Re: RV10-List: Landing gear shake > >I just did a condition inspection on N256H. Before the condition it had a fair >bit of shimmy in the 25-30 mph range after landing. I added another spacer on >the nose gear shock strut and tightened the nose gear pivot nut one flat. Most >of the shimmy went away. > > >Jesse Saint >Saint Aviation, Inc. >jesse(at)saintaviation.com >C: 352-427-0285 >F: 815-377-3694 > >On Feb 6, 2011, at 2:09 AM, Scott Schmidt wrote: > >I have posted on this topic before. >>Mine does the exact same at the same speeds as does many other RV-10's. >>Sometimes balancing the tire fixes/helps, sometimes different tires, pressures, >>ect. >>I have tried most with no success. I have talked with Van about it and he >>indicated that his personal plane even did it. I have also heard that when >>people installed the wheel pants it started. It all comes down to a poor gear >>design. A round gear leg is not the optimal design for a landing gear but is the >>cheapest shape from a manufacturing point of view. >>It is not the caliper either. Even if I slow down with no braking it occurs. I >>can replicate it on the ground with one wheel jacked up and use my buffer to get >>the wheel up to 50 mph and when it slows to around 25 mph, it shakes. It is the >>system hitting a natural frequency. >>Van said people have put a block of wood on the backside of other RV models to >>stop it. >> >> >>I spent a considerable amount of time re-drilling my gear legs to get the exact >>toe-in on both sides and it did not change one thing. I have tried two different >>sets of tires, pressures from 25-60 psi all with no luck. My next plan, when I >>get to it, is to install the wheel pant spacers from PlaneAround.com and start >>stiffening the wheel pant to the gear. Then I will start finding a good way >>change the moment of inertia of the gear leg, stiffening it in the front to back >>direction. >>I've been told by Vans not to worry about it. Just think of it as a massage with >>every landing. >>I will find a way to eliminate it though. >> >> >>Let me know if you find anything out. >>Thanks, Scott >> >>On Jan 23, 2011, at 6:40 PM, "Roger Standley" wrote: >> >> >> >>>Today I was able to have a guy observe the gear up close as I was landing. >>>I have been feeling a shake during roll out below 30 mph. Sometimes not too much >>>but sometimes significant. Applying brakes seems to make it worse but >>>nothing will make it stop until slowing below 20 mph. Speeds above 30 mph are >>>smooth. He said that the left main was shaking and it looked to be rapidly >>>moving forward and back. >>> >>>Are others noticing this shaking? Is there a fix or a way to minimize the >>>shaking that anyone has discovered? >>> >>>Thank you, >>> >>>Roger Standley >>>N291RV >>>165 hours >>> >>> ========== >>>ref="http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/Navigator?RV10-List========= >>> ums.matronics.com">http://forums.matronics.com/ >>>========= >>>http://www.matronics.com/contribution%22%3Ehttp://www.matronics.com/contribution========= >>> >>> >>> > >href="http://www.matronics.com/Navigator?RV10-List%22%3Ehttp://www.matronics.com/Navigator?RV10-Listhref=%22http://forums.matronics.com/%22%3Ehttp://forums.matronics.com >href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >n > > > >href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com/">http://forums.matronics.com >href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >n > > ________________________________________________________________________________
Date: Feb 07, 2011
Jesse, it only really continues to be a project because we want it to!- - =0ACongrats Eric, and welcome to the family.=0ADon McDonald=0A=0A=0A=0A =0A________________________________=0AFrom: Jesse Saint <jesse@saintaviatio n.com>=0ATo: rv10-list(at)matronics.com=0ASent: Mon, February 7, 2011 4:19:52 PM=0ASubject: Re: RV10-List: No longer a project=0A=0A--> RV10-List message posted by: Jesse Saint =0A=0A"I guess it is no lo nger a project"?- Who have you been talking to?- It'll =0Aalways be a p roject!!!- CONGRATS!=0A=0AJesse Saint=0ASaint Aviation, Inc.=0Ajesse@sain taviation.com=0AC: 352-427-0285=0AF: 815-377-3694=0A=0AOn Feb 7, 2011, at 4 llio" =0A> =0A> DAR stopped by yesterday afternoon. He ha d already inspected it apart and =0A>wanted it all together. He took a look at it, watched me run it and taxi it =0A>around the airfield. Satisfied, a nd after 45 minutes of paperwork he handed me =0A>the airworthiness certifi cate. I guess it is no longer a project. Now it is an =0A>airplane. It was too late in the day to fly, sun was going down. Weather today =0A>was absol ute garbage. Maybe first flight next Saturday, just waiting on weather. =0A >Already starting to get the grin and haven't even flown it yet.=0A> =0A> E ric=0A> N518RV=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A > http://forums.matronics.com/viewtopic.php?p=330043#330043=0A> =0A> =0A> ====0A=0A=0A ________________________________________________________________________________
Date: Feb 07, 2011
We balanced all three wheel pants before flying (photos attached). Somewhat typical for RV's as long as you don't want to make the lightest RV you can. It sure hurts to add weight without adding function. That being said I also had a worse than average nose wheel shimmy for some time. I tried balancing the wheels and adjusting the castle nut on the nose gear many times to try & reduce the shimmy. I was able to narrow the speed range but not eliminate it all together. Then we lifted the nose and felt some significant movement of the nose gear. After further investigation we found a loose busing as detailed in this extremely exciting video staring my hand: http://www.youtube.com/watch?v=EmT38rDenwA Once I replaced the bushing (with a custom bushing) the shimmy was completely eliminated and I have not thought about shimmy in the ~200 landing since the correction. I think the shimmy was gone because we had already optimized the other components (castle nut, balanced wheels, balanced wheel pants etc...) Robin ________________________________________________________________________________
Subject: Re: Crow Harnesses
Date: Feb 07, 2011
Rob; Attached is the US Transportation AC21-34, a take on the GA safety belt restraint systems. Conrad B. -------- Conrad Booze Sr. Engineer P. O. Box 7028 Warner Robins, GA. 31095 (478)-335-4264 conradbooze(at)cox.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330057#330057 Attachments: http://forums.matronics.com//files/aircraft_seat_belts__ac21_341_176.pdf ________________________________________________________________________________
Date: Feb 07, 2011
The option I used. www.inertialbelts.com I could supply some installed pictures if needed. Contact me offlist. ----- Original Message ----- From: "conradb" <conradbooze(at)cox.net> Sent: Monday, February 07, 2011 4:38 PM Subject: RV10-List: Re: Crow Harnesses > > Rob; > > Attached is the US Transportation AC21-34, a take on the GA safety belt > restraint systems. > > > Conrad B. > > -------- > Conrad Booze > Sr. Engineer > P. O. Box 7028 > Warner Robins, GA. 31095 > (478)-335-4264 > conradbooze(at)cox.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330057#330057 > > > Attachments: > > http://forums.matronics.com//files/aircraft_seat_belts__ac21_341_176.pdf > > > ________________________________________________________________________________
Date: Feb 07, 2011
Thanks, guys... I'm having second thoughts with my "good enough" assessment from the other day. The belts feel fine, but it seems like the geometry is off, with the shoulder straps essentially coming from the top-center of the headrest. I think I'm going to call and have them re-make the front seat shoulder straps. There's also *way* too much extra strap (around 3 feet) when I have them adjusted, so something is clearly not right. Maybe when I said "RV-10" they assumed all RVs are the same? Not really sure what's going on, but this is something that needs to be done right. DAR inspection in 13 days. Not exactly what I want to be messing with now... -Rob On Mon, Feb 7, 2011 at 5:34 PM, DLM wrote: > > The option I used. > > www.inertialbelts.com > > I could supply some installed pictures if needed. Contact me offlist. > > ----- Original Message ----- From: "conradb" <conradbooze(at)cox.net> > To: > Sent: Monday, February 07, 2011 4:38 PM > Subject: RV10-List: Re: Crow Harnesses > > >> >> Rob; >> >> Attached is the US Transportation AC21-34, a take on the GA safety belt >> restraint systems. >> >> >> Conrad B. >> >> -------- >> Conrad Booze >> Sr. Engineer >> P. O. Box 7028 >> Warner Robins, GA. 31095 >> (478)-335-4264 >> conradbooze(at)cox.net >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=330057#330057 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/aircraft_seat_belts__ac21_341_176.pdf >> >> >> >> >> >> >> >> > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Date: Feb 07, 2011
Subject: Re: Landing gear shake
Robin, that's one nice hand..... Do you use palmolive or or something similar? Very impressive. :) I'm at that phase of the project right now and getting ready to put it up on the gear on the 26th when I have some help coming to town. It doesn't look like yours were worn it looks like that's the factory fit. Mine are new and have equal play. ________________________________________________________________________________
Subject: Van's stuffin advertisements in shipments
Date: Feb 07, 2011
I received the back order items off my FWF kit order today. I was surprised to find in the box with the Vetterman exhaust, an advertisement for G3i Ignitions and Flight Data Systems. I just thought it atypical of Van's pushing a specific product other than their own. Bob ________________________________________________________________________________
Date: Feb 07, 2011
Subject: Re: Van's stuffin advertisements in shipments
Yeah, I had that in my exhaust kit as well. I think it is Vetterman putting those in there, not Vans. On Mon, Feb 7, 2011 at 7:41 PM, Bob Leffler wrote: > I received the back order items off my FWF kit order today. I was surprised > to find in the box with the Vetterman exhaust, an advertisement for G3i > Ignitions and Flight Data Systems. I just thought it atypical of Vans > pushing a specific product other than their own. > > > Bob > > ________________________________________________________________________________
Date: Feb 07, 2011
Let us know what they say. Ordering the same harnesses is near the top of my todo list. Jae 40533 On 2/7/2011 6:01 PM, Rob Kochman wrote: > Thanks, guys... I'm having second thoughts with my "good enough" > assessment from the other day. The belts feel fine, but it seems like > the geometry is off, with the shoulder straps essentially coming from > the top-center of the headrest. I think I'm going to call and have > them re-make the front seat shoulder straps. There's also *way* too > much extra strap (around 3 feet) when I have them adjusted, so > something is clearly not right. Maybe when I said "RV-10" they > assumed all RVs are the same? Not really sure what's going on, but > this is something that needs to be done right. > DAR inspection in 13 days. Not exactly what I want to be messing with > now... > -Rob > ________________________________________________________________________________
Date: Feb 08, 2011
Subject: Re: : RV10-List:Exhaust
Exactly, BTW, you have the blow out gaskets from Van's and in the Vettermans box there is another set of these Gaskets, so one set to much (at least in my kit). Werner On 08.02.2011 04:06, Kelly McMullen wrote: > --> RV10-List message posted by: Kelly McMullen > > Yeah, I had that in my exhaust kit as well. I think it is Vetterman > putting those in there, not Vans. > > On Mon, Feb 7, 2011 at 7:41 PM, Bob Leffler wrote: >> I received the back order items off my FWF kit order today. I was surprised >> to find in the box with the Vetterman exhaust, an advertisement for G3i >> Ignitions and Flight Data Systems. I just thought it atypical of Vans >> pushing a specific product other than their own. >> >> >> >> Bob >> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 08, 2011
Subject: Door Pin - Bullets
Does anyone know of a site that shows the installation and proper adjustment procedures for the folks who install the aluminum blocks and bullet shaped pins? I'm guessing you simply cut the taper off the pins, then tap, then put the bullet on (with lok-tite). But am I missing anything else? Is it really that simple? Thanks, Phil ________________________________________________________________________________
Subject: Re: Door Pin - Bullets
Date: Feb 08, 2011
Has anyone examined the pin system for longevity. It seems that its two pieces of aluminum threaded together that if they loosen and separate, one has no door. ----- Original Message ----- From: Phillip Perry To: rv10-list(at)matronics.com Sent: Tuesday, February 08, 2011 7:00 AM Subject: RV10-List: Door Pin - Bullets Does anyone know of a site that shows the installation and proper adjustment procedures for the folks who install the aluminum blocks and bullet shaped pins? I'm guessing you simply cut the taper off the pins, then tap, then put the bullet on (with lok-tite). But am I missing anything else? Is it really that simple? Thanks, Phil ________________________________________________________________________________
From: "Masys, Daniel R" <dan.masys(at)vanderbilt.edu>
Date: Feb 08, 2011
Subject: Three-peat offender: 7A, 10 and now 12
Since building RV's is like eating potato chips (you can't stop at one), I am pleased to confirm that once you have a fine high performance RV-10 you can still have fun building an RV-12 Light Sport. We had a little RV family reunion in Nashville of all 3 planes my wife and I built. She made an online photo show at: http://www.photoshow.com/watch/rn2dF6mM?language=enu .com/watch/rn2dF6mM?language=enu?source=em_ps_show_recipient> And the first flight of the RV-12 is at: http://www.photoshow.com/watch/yF2vr9Cn?language=enu .com/watch/yF2vr9Cn?language=enu?source=em_ps_show_recipient> -Dan Masys RV-10 455 hrs RV-12 4 hrs ;-) ________________________________________________________________________________
Date: Feb 08, 2011
Pretty much that simple. You thread the inside of the rods as part of the standard Van's install (page 45, step 1) for marking the hole location in the door jamb. After the hole marking step you simply cut off the taper and install the threaded tips. The aluminum blocks simply replace the stock Delrin pieces. Unlike the Delrin pieces you can match drill from the aluminum blocks for the mount holes. Alignment for the door latch sensors is identical to stock except that the magnets are integral to the tips (I think all of the sources now do this). Just adjust the reed switches so that they only trigger when the latch is completely shut. Bob On Tue, Feb 8, 2011 at 8:00 AM, Phillip Perry wrote: > Does anyone know of a site that shows the installation and proper > adjustment procedures for the folks who install the aluminum blocks and > bullet shaped pins? > > I'm guessing you simply cut the taper off the pins, then tap, then put the > bullet on (with lok-tite). > > But am I missing anything else? Is it really that simple? > > Thanks, > Phil > > * > > * > > ________________________________________________________________________________
Date: Feb 08, 2011
The aftermarket pins from IFLYRV10.com are stainless with steel threaded rods and installed with locktite. Bob On Tue, Feb 8, 2011 at 8:28 AM, DLM wrote: > Has anyone examined the pin system for longevity. It seems that its two > pieces of aluminum threaded together that if they loosen and separate, one > has no door. > > ----- Original Message ----- > *From:* Phillip Perry > *To:* rv10-list(at)matronics.com > *Sent:* Tuesday, February 08, 2011 7:00 AM > *Subject:* RV10-List: Door Pin - Bullets > > Does anyone know of a site that shows the installation and proper > adjustment procedures for the folks who install the aluminum blocks and > bullet shaped pins? > > I'm guessing you simply cut the taper off the pins, then tap, then put the > bullet on (with lok-tite). > > But am I missing anything else? Is it really that simple? > > Thanks, > Phil > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Feb 08, 2011
I can confirm that. My first kit was a 9A, now flying a '10 (512 hrs) and helped a friend build a '12 in my garage. Started the RV-12 in mid-July and finished up at Christmas. It's quick to build and cost ME nothing for all the fun. Albert Gardner Yuma, AZ N991RV Subject: RV10-List: Three-peat offender: 7A, 10 and now 12 Since building RV's is like eating potato chips (you can't stop at one), I am pleased to confirm that once you have a fine high performance RV-10 you can still have fun building an RV-12 Light Sport. -Dan Masys RV-10 455 hrs RV-12 4 hrs ;-) ________________________________________________________________________________
Date: Feb 08, 2011
> It seems that its two pieces of aluminum threaded together that if they loosen and separate, one has no door. I think it'd be difficult for a pin to thread all the way out without noticing. That said, it's not too difficult to build it such that even without the pins, the rod engages with the aluminum block. -Rob On Tue, Feb 8, 2011 at 6:28 AM, DLM wrote: > Has anyone examined the pin system for longevity. It seems that its two > pieces of aluminum threaded together that if they loosen and separate, one > has no door. > > ----- Original Message ----- > *From:* Phillip Perry > *To:* rv10-list(at)matronics.com > *Sent:* Tuesday, February 08, 2011 7:00 AM > *Subject:* RV10-List: Door Pin - Bullets > > Does anyone know of a site that shows the installation and proper > adjustment procedures for the folks who install the aluminum blocks and > bullet shaped pins? > > I'm guessing you simply cut the taper off the pins, then tap, then put the > bullet on (with lok-tite). > > But am I missing anything else? Is it really that simple? > > Thanks, > Phil > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle)
Date: Feb 09, 2011
It is a pretty simple add-on and provides a lot of security. I have been flying for over as year with no noticeable wear or trouble. I consider these pins virtually a mandatory option. I had to ream out one or two of my aluminum receivers as the install angle is very critical and they were mounted very slightly off dead center. The advantage is that they bring the door and door pins into alignment and provide a super secure lock. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330284#330284 ________________________________________________________________________________
Date: Feb 09, 2011
Well done. Hope to see the new beast - maybe OSH ! Be sure to post some pics here and on the Vans first flights sheets. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330287#330287 ________________________________________________________________________________
Date: Feb 09, 2011
Mike, I couldn't have said it better myself.- Well over 200 hours, and th ey =0Astill look band new.... Although I still ck each door on every single flight, =0Aand will continue doing that forever, I have much more confiden ce in these vs. =0Athe stk Van's install.- Also consider doing (at least) this mandatory.=0ADon McDonald=0A=0A=0A=0A________________________________ =0AFrom: AirMike <Mikeabel(at)Pacbell.net>=0ATo: rv10-list(at)matronics.com=0ASen t: Wed, February 9, 2011 10:36:13 AM=0ASubject: RV10-List: Re: Door Pin - B t>=0A=0AIt is a pretty simple add-on and provides a lot of security. I have been flying =0Afor over as year with no noticeable wear or trouble. I cons ider these pins =0Avirtually a mandatory option. I had to ream out one or t wo of my aluminum =0Areceivers as the install angle is very critical and th ey were mounted very =0Aslightly off dead center. The advantage is that the y bring the door and door =0Apins into alignment and provide a super secure lock.=0A=0A--------=0ASee you OSH '11 =0AQ/B - flying 1 yr+=0A=0A=0A=0A=0A Read this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic.php =0A=0A=0A =0A______________________________________________________________ ______________________=0ANever miss an email again!=0AYahoo! Toolbar alerts features/mail/ ________________________________________________________________________________
Date: Feb 09, 2011
[Mr. Green] I am green with envy. Congo Rats Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330341#330341 ________________________________________________________________________________
Subject: Paint Shop
Date: Feb 09, 2011
We were scheduled with a paint shop that finishes out the fiberglass and un fortunately the shop has closed due to the owner passing away. Does anyone know of any reputable paint shops that finish out the fiberglass as part o f the paint job? We are in the southeast (TN) but would be willing to fly the plane to another state for the right paint shop. Thanks=2C Vicki ________________________________________________________________________________
Date: Feb 09, 2011
Subject: Re: Paint Shop
Hi Vicki, sorry to hear about the death of the paint shop owner.- I had m y RV 9A painted a year ago at Lancaster Aero Refinishers at Smoketown Airpo rt near Lancaster, PA- Lou owns the shop and Dave does the painting.- T heir number is 717 394-5805.- The work is top notch and I did not do any prep work on the fiberglass pieces prior to dropping off the plane.- A pi cture is attached.-I was completely thrilled with the paint job.- It's been about 1 year 1 month and the job-still looks great.- - Smoketown Airport is not around the corner, but the price, workmanship and 3 week turn around time all exceeded my expectations. - Best of Luck - Steve Koziol 267 614-8251 N424JK 117 Hours --- On Wed, 2/9/11, Vicki Jones wrote: From: Vicki Jones <vickiajones(at)hotmail.com> Subject: RV10-List: Paint Shop Date: Wednesday, February 9, 2011, 8:15 PM We were scheduled with a paint shop that finishes out the fiberglass and un fortunately the shop has closed due to the owner passing away.- Does anyo ne know of any reputable paint shops that finish out the fiberglass as part of the paint job?- We are in the southeast (TN) but would be willing to fly the plane to another state for the right paint shop. - Thanks, Vicki =0A=0A=0A =0A______________________________________________________________ ______________________=0ANever miss an email again!=0AYahoo! Toolbar alerts features/mail/ ________________________________________________________________________________
Date: Feb 09, 2011
Hi Vicki - Sorry to hear about the death of the paint shop owner.- I had my RV 9A pa inted a year ago at Lancaster Aero Refinishers at Smoketown Airport near La ncaster, PA- Lou owns the shop and Dave does the painting.- Their numbe r is 717 394-5805.- The work is top notch and I did not do any prep work on the fiberglass pieces prior to dropping off the plane.--I was comple tely thrilled with the paint job.- It's been about 1 year 1 month and the job-still looks great.- - Smoketown Airport is not around the corner, but the price, workmanship and 3 week turn around time all exceeded my expectations. - Best of Luck - Steve Koziol 267 614-8251 N424JK 117 Hours --- On Wed, 2/9/11, Vicki Jones wrote: From: Vicki Jones <vickiajones(at)hotmail.com> Subject: Paint Shop Date: Wednesday, February 9, 2011, 8:15 PM We were scheduled with a paint shop that finishes out the fiberglass and un fortunately the shop has closed due to the owner passing away.- Does anyo ne know of any reputable paint shops that finish out the fiberglass as part of the paint job?- We are in the southeast (TN) but would be willing to fly the plane to another state for the right paint shop. - Thanks, Vicki ___________________________________________________________________________ _________ Never miss an email again! Yahoo! Toolbar alertsfeatures/mail/ =0A=0A=0A ________________________________________________________________________________
Subject: Paint Shop
Date: Feb 09, 2011
Very nice paint scheme and color selection...swwwweeeeeetttttt! Date: Wed=2C 9 Feb 2011 18:18:04 -0800 From: biovail2001(at)yahoo.com Subject: Re: RV10-List: Paint Shop Hi Vicki=2C sorry to hear about the death of the paint shop owner. I had m y RV 9A painted a year ago at Lancaster Aero Refinishers at Smoketown Airpo rt near Lancaster=2C PA Lou owns the shop and Dave does the painting. The ir number is 717 394-5805. The work is top notch and I did not do any prep work on the fiberglass pieces prior to dropping off the plane. A picture is attached. I was completely thrilled with the paint job. It's been about 1 year 1 month and the job still looks great. Smoketown Airport is not around the corner=2C but the price=2C workmanship and 3 week turn around time all exceeded my expectations. Best of Luck Steve Koziol 267 614-8251 N424JK 117 Hours --- On Wed=2C 2/9/11=2C Vicki Jones wrote: From: Vicki Jones <vickiajones(at)hotmail.com> Subject: RV10-List: Paint Shop Date: Wednesday=2C February 9=2C 2011=2C 8:15 PM We were scheduled with a paint shop that finishes out the fiberglass and un fortunately the shop has closed due to the owner passing away. Does anyone know of any reputable paint shops that finish out the fiberglass as part o f the paint job? We are in the southeast (TN) but would be willing to fly the plane to another state for the right paint shop. Thanks=2C Vicki =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution Get more visitors on archmarketing.yahoo.com/arp/sponsoredsearch_v2.php?o =US2140&cmp=Yahoo&ctv=Q107Tagline&s=Y&s2=EM&b=50">Yahoo! Search Marketing. ________________________________________________________________________________
Date: Feb 10, 2011
Loehle is in Wartrace, TN. Not sure how close they are to you, but I know they do the finish work on the fiberglass. http://www.loehle.com/ On 2/9/11 7:15 PM, Vicki Jones wrote: > We were scheduled with a paint shop that finishes out the fiberglass > and unfortunately the shop has closed due to the owner passing away. > Does anyone know of any reputable paint shops that finish out the > fiberglass as part of the paint job? We are in the southeast (TN) but > would be willing to fly the plane to another state for the right paint > shop. > > Thanks, > Vicki > * > > > * ________________________________________________________________________________
Date: Feb 10, 2011
From: Vicki Jones <vickiajones(at)hotmail.com> Subject: Paint Shop We were scheduled with a paint shop that finishes out the fiberglass and un fortunately the shop has closed due to the owner passing away. Does anyone know of any reputable paint shops that finish out the fiberglass as part o f the paint job? We are in the southeast (TN) but would be willing to fly the plane to another state for the right paint shop. Thanks=2C Vicki _____________________________________________________________________ Hello Vicki, GLO Custom Painting Grady O'Neil Just north of Fort Worth, TX He usually only paints RV's. He painted mine in 2007 and quite a few other RV10's. He has a new web site which only shows four RV10's but he's done many more than that. Grady is a really nice guy whose easy to work with and does really good work. http://www.glocustom.com/ http://www.glocustom.com/custom-paint/6 Wayne Edgerton N602WT ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Re: electronic ignition
From: Richard Martin <martinaerodrome(at)gmail.com>
I have 2000 plus hours on my RV8 with Lightspeed ignition. No problems, great performance. I have found that NIPON Denso spark plugs number X27GPRU with adapter bushings available from Light speed seem to perform the best. (note, I have dual electronic ignitions, NO Magnetos). I use a small standby battery that will provide 4 hours of operation in the unlikely event of total electircal system failure. Dick Martin RV8 N233M the fast one Post note: Sheilded wire is unneccessary. I use high grade Indy race wire. On Thu, Feb 3, 2011 at 2:21 PM, greghale wrote: > > Can anyone give me some advice on a good electronic ignition system for my > RV10? I will be going to Sun n Fun this year and want to check into > this....Thanks > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329487#329487 > > ________________________________________________________________________________
Date: Feb 10, 2011
I will add a post note to my previous reply, To my knowledge, the Lightspeed is the only full CAPACITANCE DISCHARGE ignition versus the inductive systems of most of the others. Dick Martin RV8 N233M the fast one On Thu, Feb 3, 2011 at 2:38 PM, tsts4 wrote: > > Let=92s see, some of the usual suspects include: > > Light Speed Engineering=92s Plasma III: > http://www.lightspeedengineering.com/ > > Unison LASAR: > http://www.unisonindustries.com/ourproducts/lasarelectronicignition.html > > EFii: http://www.flyefii.com/ > > G3i: http://www.g3ignition.com/ > > EMAG (suppose to be real close to releasing a P-Mag for the 6-cyl Lycs): > www.emagair.com > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329489#329489 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Feb 10, 2011
Subject: Re: Fuel quantity calibration problem
I experienced the same problem years ago when I built my RV8. I converted to Capacitant sensors in the fuel tanks. Easy installation, superior accuarcy and no problems. Dick Martin RV8 N233M the fast one On Wed, Feb 2, 2011 at 7:25 PM, Eric_Kallio wrote: > > I am trying to calibrate the fuel quantity levels on the GRT EIS 6000. I > have the standard Vans floats in the tank. Before O call GRT in the morning > I wanted to see if anyone else has had this issue... > > During calibration, following the sheet from GRT, I got AuxSF/Auxoff > setting of 52/151 for the left tank and 79/225 for the right. These numbers > seem a little higher than others have posted, but there may be more > resistance in my circuit. During calibration of the tanks I had noticeable > movement in the values on the EIS and on the EFIS. However, with the tanks > full and the settings entered into the calibration menu, my tanks both read > 2 gallons on the EIS. I have rechecked my numbers as well as my settings. I > am set to integers and have actually had to set the sensors to reverse > sensing because they were counting down when adding fuel. > > Any thoughts, or similar experiences out there? > > Eric Kallio > 3 days until DAR...if I can get my fuel level calibrated. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=329394#329394 > > ________________________________________________________________________________
Date: Feb 10, 2011
Check with Flying Colors of Texas (http://flyingcolorsoftexas.com/index.html) in Gainsville, Tx. They do body work and excellent paint. My RV10 just got out of the paint shop and looks fabulous. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330490#330490 ________________________________________________________________________________
Subject: Exhaust Pipe Temps
Date: Feb 10, 2011
Has anyone measured the temperature of the exhaust PIPES either as they exit the bottom cowl, or closer to the tips? Not the egt, but the pipes themselves. Thanks, Don McDonald -------- Don A. McDonald 40636 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330555#330555 ________________________________________________________________________________
Subject: Seat belt countersink
Date: Feb 10, 2011
It has been a long time since I have seen any emails about this=2C but wasn 't there a countersink being sent around for countersinking the screws that go into the cabin top for the front seat belts? Anyone have it? John ________________________________________________________________________________
Subject: Re: Seat belt countersink
Date: Feb 11, 2011
Hey John, Yes, the traveling countersink is in residence and ready to roll. If others are ready (i.e. have your canopy -- you can go ahead and countersink the hard spots before you have the seatbelts), send me your addresses off line and I'll start another mailing loop. Don't forget, I also have the helicoil kit for re-threading the nosewheel fork for the tow studs. Later, - Lew ----- Original Message ----- From: John Gonzalez To: RV 10 group Sent: Friday, February 11, 2011 12:45 AM Subject: RV10-List: Seat belt countersink It has been a long time since I have seen any emails about this, but wasn't there a countersink being sent around for countersinking the screws that go into the cabin top for the front seat belts? Anyone have it? John ________________________________________________________________________________
Date: Feb 11, 2011
Subject: Re: Exhaust Pipe Temps
I had my exhaust pipes ceramic coated inside and out. This resulted in a dramatic reduction in radiated heaat. Dick Martin RV8 N233M the fast one On Thu, Feb 10, 2011 at 11:13 PM, partner14 wrote: > > Has anyone measured the temperature of the exhaust PIPES either as they > exit the bottom cowl, or closer to the tips? Not the egt, but the pipes > themselves. > Thanks, Don McDonald > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330555#330555 > > ________________________________________________________________________________
Date: Feb 11, 2011
The downside to such coatings is that once coated they can never be weld repaired. Just one of the trade-offs we have to weigh and make our choices. On 2/11/2011 7:51 AM, Richard Martin wrote: > I had my exhaust pipes ceramic coated inside and out. This resulted > in a dramatic reduction in radiated heaat. > Dick Martin > RV8 N233M > the fast one > > On Thu, Feb 10, 2011 at 11:13 PM, partner14 > > wrote: > > > > > Has anyone measured the temperature of the exhaust PIPES either as > they exit the bottom cowl, or closer to the tips? Not the egt, > but the pipes themselves. > Thanks, Don McDonald > > -------- > Don A. McDonald > 40636 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330555#330555 > > > ption, > www.matronics.com/Navigator?RV10-List" > target="_blank">http://www.matronics.com/Navigator?RV10-List > ronics.com/" target="_blank">http://forums.matronics.com > Matt Dralle, List Admin. > ==== > > > * > > > * ________________________________________________________________________________
Date: Feb 11, 2011
In response to the questions about the helicoil kit for the tow studs: The socket head bolts (allen screws) are fine. Others had posted here that the steel studs eventually stripped the aluminum threads in the fork; either with difficulty threading the studs in, normal wear from installing/uninstalling the pants, or in our case from destroying the pants on the runway! At any rate, it is a five minute fix to drill out the aluminum threads, tap with the oversize tap and install the stainless threads so that you don't have to worry about loosing a stud or pants somewhere with no access to the kit. We paid $50 for the kit -- I'd "rent" it out with the required coils for $5 plus shipping. Your nose fork and pants don't change, it just allows for the steel threads on the studs to contact stainless threads in the fork instead of the aluminum threads. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330592#330592 ________________________________________________________________________________
Date: Feb 11, 2011
Subject: OT - Cirrus crash - perhaps having an open door fly off is
not the worst design consequence http://www.liveleak.com/view?i=589_1297368527 (warning, obviously this dated video depicts a pilot's death, but not graphically) ________________________________________________________________________________
Subject: Re: OT - Cirrus crash - perhaps having an open door fly off
is n
Date: Feb 11, 2011
Awful and tragic situation, but a good warning to all RV10 pilots. Check and double check those door pins carefully as they are surely the weakest and poorest designed component of the RV10. A careful visual double check by the pilot must be a basic part of the preflight procedure. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330693#330693 ________________________________________________________________________________
off is n
Date: Feb 11, 2011
I never look for the pins; I do feel each end twice before committing aviation. Fortunately the door departs the aircraft in the RV10, usually at rotation. This allows the door to sail over the tail. Having had a door in an Arrow open after takeoff, control was not a problem. The right seat passenger had a more difficult time cleaning himself. ----- Original Message ----- From: "AirMike" <Mikeabel(at)Pacbell.net> Sent: Friday, February 11, 2011 7:39 PM Subject: RV10-List: Re: OT - Cirrus crash - perhaps having an open door fly off is n > > Awful and tragic situation, but a good warning to all RV10 pilots. Check > and double check those door pins carefully as they are surely the weakest > and poorest designed component of the RV10. A careful visual double check > by the pilot must be a basic part of the preflight procedure. > > -------- > See you OSH '11 > Q/B - flying 1 yr+ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330693#330693 > > > ________________________________________________________________________________
Date: Feb 12, 2011
off is n The following statement was made in this thread about the RV10: "those door pins carefully as they are surely the weakest and poorest designe d component of the RV10." This can be onew OPINION but it factually is NOT TRUE. I would be willi ng to bet a large sum that ALL the incidents with the RV10 doors were ei ther Pilot error OR Builder error. I will leave it at that.................just wanted new RV10 builders re ading these post not to freak out and wonder what they must do different in the building process. DEAN 805HL 500 hours ____________________________________________________________ $65/Hr Job - 25 Openings Part-Time job ($20-$65/hr). Requirements: Home Internet Access http://thirdpartyoffers.juno.com/TGL3131/4d562150dfc0034bb5cst01vuc ________________________________________________________________________________
Subject: Re: Potential BIG trouble with GPS...keep those nav radios!
Date: Feb 11, 2011
I think that problem, if it exists, will get nipped in the bud pretty quick. There is one user who won't tolerate known GPS interference, and who is highly influential: the military. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330725#330725 ________________________________________________________________________________
Date: Feb 12, 2011
Subject: Re: Door design
Hmm, There have been only 3 significant modifications from the factory. Only one of those areas modified was due to problems on more than one aircraft, and actually consisted of two modifications to the same area. (warning lights and extra latch) Your statement is a very broad brush allegation, with a small element of truth...yes, all aircraft accidents are due to pilot error as well. They shouldn't have challenged nature by attempting to fly in a man made machine. The fact that there have been at least a dozen door incidents is no coincidence, and very unlikely that there was significant builder error in that many aircraft. The fact that the door latching isn't that positive, requires significant care by the pilot to ensure adequate engagement is all evidence of poor design. No aircraft system should require extra special attention on every flight like the factory door design does. It is better that new builders be aware of the potential safety issue and the options available to reduce the risk than to tell them "just build it" like some would do. Better to spend a bit extra time and perhaps money on the doors than to have the airframe damaged, have to spend a whole lot more time fixing it, assuming losing a door doesn't precipitate a more serious accident. With awareness builders can make informed choices and ensure they don't suffer the same problems of those that led the way. Kelly 40866 doors, etc. EAA Tech Counselor On Fri, Feb 11, 2011 at 10:56 PM, ddddsp1(at)juno.com wrote: > > This can be onew OPINION but it factually is NOT TRUE. I would be willing > to bet a large sum that ALL the incidents with the RV10 doors were either > Pilot error OR Builder error. > > I will leave it at that.................just wanted new RV10 builders > reading these post not to freak out and wonder what they must do different > in the building process. > > DEAN > > 805HL 500 hours > > ________________________________________________________________________________
Date: Feb 12, 2011
One other observation. When the door is closed and latched, the full circumference of the rear pin should be in contact with the metal of the door frame or the metal door guide (after market). This may not be the case depending on the accuracy of your location of the door latching mechanism within the recessed box. In our case , it was not; hence we made new pins by buying another appropriately typed and sized tube and slotting and drilling one end and then installing the overly long pins. we retracted the pins and test fit; then cut and beveled so that the retracted pin would just fit inside the door frame. After several fittings, we were satisfied with the fit. The retracted pins just fit inside the door frame and the extended (closed) pins make full circumference contact with the complete hole in the metal frame. Then after the doors are closed, before engine start, I feel all four pin ends; before committing to flight they are felt again. I do not use the light system because one builder who lost two doors, lost one of them after installing the light system. I have suggested to Vans that the pins should be supplied overly long by 1/2 inch and fitted by builder, but have seen no change. ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Saturday, February 12, 2011 5:47 AM Subject: Re: RV10-List: Re: Door design > > Hmm, > There have been only 3 significant modifications from the factory. > Only one of those areas modified was due to problems on more than one > aircraft, and actually consisted of two modifications to the same > area. (warning lights and extra latch) > Your statement is a very broad brush allegation, with a small element > of truth...yes, all aircraft accidents are due to pilot error as well. > They shouldn't have challenged nature by attempting to fly in a man > made machine. > > The fact that there have been at least a dozen door incidents is no > coincidence, and very unlikely that there was significant builder > error in that many aircraft. The fact that the door latching isn't > that positive, requires significant care by the pilot to ensure > adequate engagement is all evidence of poor design. No aircraft system > should require extra special attention on every flight like the > factory door design does. > It is better that new builders be aware of the potential safety issue > and the options available to reduce the risk than to tell them "just > build it" like some would do. Better to spend a bit extra time and > perhaps money on the doors than to have the airframe damaged, have to > spend a whole lot more time fixing it, assuming losing a door doesn't > precipitate a more serious accident. With awareness builders can make > informed choices and ensure they don't suffer the same problems of > those that led the way. > > Kelly > 40866 > doors, etc. > EAA Tech Counselor > > On Fri, Feb 11, 2011 at 10:56 PM, ddddsp1(at)juno.com > wrote: > >> >> This can be onew OPINION but it factually is NOT TRUE. I would be willing >> to bet a large sum that ALL the incidents with the RV10 doors were either >> Pilot error OR Builder error. >> >> I will leave it at that.................just wanted new RV10 builders >> reading these post not to freak out and wonder what they must do >> different >> in the building process. >> >> DEAN >> >> 805HL 500 hours > >> >> > > > ________________________________________________________________________________
is
Date: Feb 12, 2011
Well, it might be a true statement that "ALL the incidents with the RV10 doors were either Pilot error OR Builder error.", but I think the design of the doors and the latching system make it way too easy to make these kinds of mistakes. Aviation design history is full of these kinds of weak designs. They usually get modified/re-engineered at some point. Having built the airplane and now flown it 330 hours, I agree with the statement that the doors and latching system are a real "weak link" on this airplane. I love the airplane, but that's the way I see it. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330752#330752 ________________________________________________________________________________
Subject: Lost doors & door warning-throttle system
Date: Feb 12, 2011
I've been reading the lost door posts and I am dismayed that there is still no definitive solution. I have Van's door fix and have not installed it. After I read the post from the guy who blew the door open during run up with Vans door catch installed it seemed useless. The key to safe doors is to be sure the pins are in the door frame holes and long enough. I never liked Vans magnetic switches for sensing where the pins are so I use micro switches. The micro switches are held in place using a bracket attached to the screws above and below the pin hole in the frame. It is designed so that each microswitch has to be touched for the light to turn off-- that is each microswitch is capable of turning the light on by itself. Any door misalignments with one pin in and one pin out will still trigger the lights and horn. I recently added a throttle position switch to turn on a horn if the throttle is wide open and the door pins are not correctly aligned. The throttle bracket is mounted to a bolt on top of the air cleaner box. The horn can be defeated with a switch and the horn resets itself if the throttle is retarded so the system rearms itself. My big problem is that my Bose headsets are very good at canceling the horn noise. If any of you know how to make a device that can make an obnoxious tone and send to it to the audio panel I would like to hear about it. I borrowed heavily from my Long-EZ's canopy-gear-throttle warning system for the design. It uses the relays and lights that came with the kit and about $40 of Radio Shack parts. I feel if the pins are in the correct position and deep enough through the frame the doors are safe and this system tells you if both conditions are met and gives a final warning before takeoff if they are not met. Sheldon Olesen N475PV 239 hrs ________________________________________________________________________________
Subject: Re: Lost doors & door warning-throttle system
Date: Feb 12, 2011
What do you mean no definitive solution? Sean's latch mechanism is basically an ideal fix and is available as a retrofit... You can't do much better than that for those that want a better system. On Feb 12, 2011, at 10:31 AM, Sheldon Olesen wrote: > > I've been reading the lost door posts and I am dismayed that there is still no definitive solution. I have Van's door fix and have not installed it. After I read the post from the guy who blew the door open during run up with Vans door catch installed it seemed useless. > > The key to safe doors is to be sure the pins are in the door frame holes and long enough. I never liked Vans magnetic switches for sensing where the pins are so I use micro switches. The micro switches are held in place using a bracket attached to the screws above and below the pin hole in the frame. It is designed so that each microswitch has to be touched for the light to turn off-- that is each microswitch is capable of turning the light on by itself. Any door misalignments with one pin in and one pin out will still trigger the lights and horn. I recently added a throttle position switch to turn on a horn if the throttle is wide open and the door pins are not correctly aligned. The throttle bracket is mounted to a bolt on top of the air cleaner box. The horn can be defeated with a switch and the horn resets itself if the throttle is retarded so the system rearms itself. My big problem is that my Bose headsets are very good at canceling the horn noise. If any of you know how to make a device that can make an obnoxious tone and send to it to the audio panel I would like to hear about it. I borrowed heavily from my Long-EZ's canopy-gear-throttle warning system for the design. It uses the relays and lights that came with the kit and about $40 of Radio Shack parts. I feel if the pins are in the correct position and deep enough through the frame the doors are safe and this system tells you if both conditions are met and gives a final warning before takeoff if they are not met. > > Sheldon Olesen > N475PV 239 hrs > > > > ________________________________________________________________________________
Date: Feb 12, 2011
It seems to me that an important part of Sean's upgrade are the longer racks, which give a greater engagement depth. This is such a simple mod that I do not understand why Van's hasn't changed the plans to cut the racks longer and get a longer throw. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330789#330789 ________________________________________________________________________________
Subject: RE: AeroElectric-List: Warning tone
Date: Feb 12, 2011
Sheldon, Here are a couple tone generators. I'm sure that there are more. Then just route to your intercom. http://www.vx-aviation.com/page_2.html#AL-1A_more http://www.gretzaero.com/Toneboard.html bob -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sheldon Olesen Sent: Saturday, February 12, 2011 11:54 AM Subject: AeroElectric-List: Warning tone Hi Bob, I designed a door-throttle warning system for my RV-10 that was heavily influenced by the Long-EZ canopy-throttle-gear warning system. It has a warning horn that goes off if the throttle is wide open and the door pins are not in the correct position. My problem is my Bose headsets are very good at canceling the horn noise. Is there a simple way to make a device to add an obnoxious tone through the audio panel? A couple of inputs to the device would also take care of the stall warning horn. Thanks, Sheldon Olesen ________________________________________________________________________________
Subject: Re: AeroElectric-List: Warning tone
Date: Feb 12, 2011
Even easier - if your current horn is a speaker, and one side of the speaker is grounded, just route a wire from the 'hot' side of the speaker to an unswitched audio panel input. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330792#330792 ________________________________________________________________________________
Subject: Cowl Fasteners
Date: Feb 12, 2011
I was talking to a recently flying RV-10 pilot who just removed his top cowl hinges along the firewall because of some blow back from the hinge opening. Another RV-10 I just saw, the paint is starting to crack around the hinge area. I'm curious if any of the flying RV-10s that installed either the standard hinges or camlocs wished they made a different decision? Thanks, Bob ________________________________________________________________________________
Date: Feb 12, 2011
I like my hinges. I do get some staining if I fly through rain, but got that with cam-locs on other planes too. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Saturday, February 12, 2011 4:34 PM Subject: RV10-List: Cowl Fasteners I was talking to a recently flying RV-10 pilot who just removed his top cowl hinges along the firewall because of some blow back from the hinge opening. Another RV-10 I just saw, the paint is starting to crack around the hinge area. I'm curious if any of the flying RV-10s that installed either the standard hinges or camlocs wished they made a different decision? Thanks, Bob ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Feb 12, 2011
Subject: Re: Cowl Fasteners
I have camlocs everywhere except the aft edge of the lower cowl. I wish I'd put them there, too, more for the ease of operation and not so much the sealing. I think most people end up going to screws for the bottom near the exhaust pipes. I had to because the hinges kept failing. Also, behind the prop you pretty much have to use screws. Everything else I've seen people try--hinges, camlocs, etc--always ends up too loose. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sat, Feb 12, 2011 at 1:33 PM, Bob Leffler wrote: > I was talking to a recently flying RV-10 pilot who just removed his top cowl > hinges along the firewall because of some blow back from the hinge opening. > Another RV-10 I just saw, the paint is starting to crack around the hinge > area. > > > Im curious if any of the flying RV-10s that installed either the standard > hinges or camlocs wished they made a different decision? > > > Thanks, > > > Bob > > ________________________________________________________________________________
Date: Feb 12, 2011
Same here....I get some now in rain and did in my last plane with camloks to o. On Feb 12, 2011, at 4:01 PM, "gary" wrote: > I like my hinges. I do get some staining if I fly through rain, but got t hat with cam-locs on other planes too. > > Gary Specketer > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Bob Leffler > Sent: Saturday, February 12, 2011 4:34 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Cowl Fasteners > > I was talking to a recently flying RV-10 pilot who just removed his top co wl hinges along the firewall because of some blow back from the hinge openin g. Another RV-10 I just saw, the paint is starting to crack around the hing e area. > > I=99m curious if any of the flying RV-10s that installed either the s tandard hinges or camlocs wished they made a different decision? > > Thanks, > > Bob > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 12, 2011
With the retro kit from Sean the racks are not longer. Providing care is taken to optimize the travel, penetration through the metal frame is not a problem. One has to understand the concept and obtain full travel. The center latch in Sean's kit is key to me. If the door is not pulled on properly, the center latch hits the door sill bracket and rotation of the door handle cannot continue. A little tug inward for the center latch to clear the top of the catch bracket. The cam now catches the bracket and then the rotation can continue and the pins will be lined up. So not only does the center cam latch help with pin line up it also is an indicator that the pins are not lined up. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330815#330815 ________________________________________________________________________________
Date: Feb 12, 2011
Everywhere on the 10 where you have rivets in fiberglass, you should consider laying a layer of glass or glass tape as these will work their way through the paint in a hundred hours or so. The blinds holding the top on and the solids holding the cowl hinges come to mind... How do I know? I did this on every spot on the Glastar but one. I missed the 4 solids holding the oil door on. A hundred hours later the heads of the rivets could be seen emerging through the paint. ----- Original Message ----- From: Bob Leffler To: rv10-list(at)matronics.com Sent: Saturday, February 12, 2011 2:33 PM Subject: RV10-List: Cowl Fasteners I was talking to a recently flying RV-10 pilot who just removed his top cowl hinges along the firewall because of some blow back from the hinge opening. Another RV-10 I just saw, the paint is starting to crack around the hinge area. I'm curious if any of the flying RV-10s that installed either the standard hinges or camlocs wished they made a different decision? Thanks, Bob ________________________________________________________________________________
Subject: EIS Tach
Date: Feb 12, 2011
Been through the archives and the Yahoo group. On the GRT EIS 6000 and the tach from the Lightspeed III I have the wire run from pin 6 on the Lightspeed input connector to the GRT EIS pin 12. The tach P/R is set to 3 and the sensitivity to "H". Still have no tach indications. So, after reading the data in the previously cited sources has anyone had any luck in pulling the resistor in the EIS in getting any indications on the tach? Anything else worked for you? Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330832#330832 ________________________________________________________________________________
Subject: oil pressure adjustment
Date: Feb 12, 2011
Hey Guys, My oil pressure has been running a tad bit high. I wanted to adjust the pressure down. Does anyone know which way (CW CCW) the adjustment screw should be turned to lower the pressure? I could guess, but if I'm wrong, I have to pull the cowling off again. Don't want to chip the new paint. Thanks, Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330849#330849 ________________________________________________________________________________
Date: Feb 12, 2011
I used the SkyBolt camlocs on the RV10. They are great for fiberglass. They adjust in or out to compensate for various thickness. I used these on the RV8. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330851#330851 ________________________________________________________________________________
Date: Feb 12, 2011
Subject: Re: oil pressure adjustment
I would recommend leaving it alone. Slightly high won't hurt anything. It likely will come down as soon as warm weather returns. On 2/12/2011 9:29 PM, greghale wrote: > --> RV10-List message posted by: "greghale" > > Hey Guys, > My oil pressure has been running a tad bit high. I wanted to adjust the pressure down. Does anyone know which way (CW CCW) the adjustment screw should be turned to lower the pressure? I could guess, but if I'm wrong, I have to pull the cowling off again. Don't want to chip the new paint. > > Thanks, > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330849#330849 > > ________________________________________________________________________________
Date: Feb 13, 2011
RV10-List: Re: Cowl Fasteners I like my camlocks but would avoid placing them on the underside of the cowl. Just too much shaking, oil, exhaust going on down there. Unless you keep extras in the plane and in your hangar ($$) you will find yourself missing one (or more) at some point. Just about the exact time you need to fly some place. Often involves pulling everything off to replace. I prefer Tinnerman washers & S/S screws. The best $0.05 solution Ask me how I know=85 Robin 4 RV=92s & counting=85 Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *greghale *Sent:* Saturday, February 12, 2011 8:37 PM *To:* rv10-list(at)matronics.com *Subject:* RV10-List: Re: Cowl Fasteners I used the SkyBolt camlocs on the RV10. They are great for fiberglass. They adjust in or out to compensate for various thickness. I used these on the RV8. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330851#330851 ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: EIS Tach
Date: Feb 13, 2011
I went around the tree a dozen times with Klaus on this exact issue back when I had Lightspeed ignitions (2001 - 2009) . Klaus never responded other than "your wiring is wrong". The problem was solved after talking with the good folks at Grand Rapids. They can walk you through the simple mod to get the Lightspeed pulse to work. Carl Froehlich RV-8A (620 hrs - now with dual pMags and very happy) RV-10 (gear fiberglass - pressing to move to the paint booth this spring) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Eric_Kallio Sent: Saturday, February 12, 2011 9:26 PM Subject: RV10-List: EIS Tach Been through the archives and the Yahoo group. On the GRT EIS 6000 and the tach from the Lightspeed III I have the wire run from pin 6 on the Lightspeed input connector to the GRT EIS pin 12. The tach P/R is set to 3 and the sensitivity to "H". Still have no tach indications. So, after reading the data in the previously cited sources has anyone had any luck in pulling the resistor in the EIS in getting any indications on the tach? Anything else worked for you? Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330832#330832 ________________________________________________________________________________
Date: Feb 13, 2011
My oil pressure has been running around 95psi since new. This is during the first start of the day. After the engine has run for awhile, it will go down to 85 psi which is OK for me. I just want to lower it some. The AFS engine monitor becomes a nuisance until the pressure drops below 95 which is where I have the top limit set. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330876#330876 ________________________________________________________________________________
Date: Feb 13, 2011
New 172s if I recall correctly have their redline for IO-360 set at 100 psi, and the pickoff is in a location that would give closer to 115 psi in the old pickoff location. I'd say it would be a lot easier to just reset your AFS limit to 100. Many planes will go over red line on first takeoff of the day in cool/cold weather. Nothing to be concerned about unless you start losing oil outside the engine. IMHO this falls under don't fix what isn't broke. Kelly A&P/IA On 2/13/2011 8:30 AM, greghale wrote: > --> RV10-List message posted by: "greghale" > > My oil pressure has been running around 95psi since new. This is during the first start of the day. After the engine has run for awhile, it will go down to 85 psi which is OK for me. I just want to lower it some. The AFS engine monitor becomes a nuisance until the pressure drops below 95 which is where I have the top limit set. > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330876#330876 > > ________________________________________________________________________________
Date: Feb 13, 2011
Hey Greg, We had the same issue. As I remember, it is not a screw adjustment. The way we adjusted the oil pressure on the IO 540 was to cut the safety wire and unscrew the cap on the oil pressure gizmo on the copilot side of the engine -- that reveals a steel ball and a pressure spring. On the opposite end of the spring from the ball are a couple of washers used as spacers to increase/decrease the tension on the spring -- which regulates the oil pressure. We took one washer out, and all is well. At first, it doesn't look like there are spacers down in there, but they are. Sorry about the lack of technical jargon -- I can take a picture of it later this PM if needed. Later, - Lew ----- Original Message ----- From: "greghale" <ghale5224(at)aol.com> Sent: Sunday, February 13, 2011 10:30 AM Subject: RV10-List: Re: oil pressure adjustment > > My oil pressure has been running around 95psi since new. This is during > the first start of the day. After the engine has run for awhile, it will > go down to 85 psi which is OK for me. I just want to lower it some. The > AFS engine monitor becomes a nuisance until the pressure drops below 95 > which is where I have the top limit set. > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330876#330876 > > > ________________________________________________________________________________
Date: Feb 13, 2011
One more thought on high oil pressure. I heard of an oil cooler being blown out due to too high oil pressure on another plane. I don't know how high that would have to be, to be of concern, but I never would have thought of that at all. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330896#330896 ________________________________________________________________________________
Date: Feb 13, 2011
off is n I was never aware of this accident before but the NTSB report seems telling: http://bit.ly/h7jB05 Preliminary review of recorded air traffic control tower radio communications revealed that the pilot was cleared to take off on runway 07L. About 34 seconds later, the pilot transmitted to the tower controller, "I need to return to close the door." You can actually see the pilot side door opening at impact. http://bit.ly/dK2yrC A strong lesson indeed. Bill On 2/13/2011 4:30 PM, Marcus Cooper wrote: > --> RV10-List message posted by: "Marcus Cooper" > > A very tragic situation to say the least. However, I think the point was > not that the doors are a poor design (although I agree they are having been > a victim of the door latch mechanism), but rather to focus on what your > priorities are if the door departs. Simply said fly the airplane first, > worry about the door later. I don't know the details of the Cirrus accident > but have not heard that the crash was due to structural damage making the > airplane unflyable. Distraction is a constant enemy but especially when > something that odd happens. The RV-10 flies just fine with the door missing > so don't let it become something worse than it needs to be. > > Marcus > ________________________________________________________________________________
Subject: Re: EIS Tach
Date: Feb 13, 2011
Went ahead and ran it from the mag with the 27k resistor and put the pulses back on 1.5. Ran it with no issues. Eric Kallio Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330950#330950 ________________________________________________________________________________
Subject: Another first
Date: Feb 13, 2011
Finally, it is my turn!!!!!! After getting the tach wired in to the mag N518RV made it maiden flight. Put 2 hours on it today and it felt great. The controls were very responsive and the aerosport power engine ran like a champ. Can't wait until the break in period is over and I can really explore the flight characteristics. Tomorrow I will work off some of the minor squaks and try to put a couple more hours on it. Only 28 more to go. Eric Kallio N518RV Flying... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330951#330951 ________________________________________________________________________________
Date: Feb 13, 2011
Thanks everyone for the replies. I did find what I wanted on google. I adjusted the pressure by turning the adjustment screw out CCW 1 turn. Pressure now on takeoff 85 instead of the 95 I saw earlier. Alls well and the airplane is flying great. The 14 inches of Oklahoma snow finally melted and the temperature outside was 60 degrees. -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330953#330953 ________________________________________________________________________________
Date: Feb 13, 2011
Please excuse my question, because my plane isn't flying yet so I just don't have this experience, but my engine has a vernatherm, which is a required replacement at overhaul and is supposed to vary the oil flow into the oil cooler, based on the temperature of the oil. When I hear about an oil cooler being "blown" because of high oil pressure, when the oil is cold, how can that happen if there is a temperature compensated valve in the engine limiting the flow to the oil cooler? Thanks. Steve Weinstock 40230, finishing kit In a message dated 2/13/2011 11:54:55 A.M. Central Standard Time, Tim(at)MyRV10.com writes: --> RV10-List message posted by: Tim Olson Probably when it's cold out: http://www.reiffpreheat.com/Oil%20cooler%20heater.htm An oil cooler should be able to handle normal situations fine...and if you were talking high pressure because of no preheat, then you're talking an extreme situation that wouldn't be fixed by changing the setting a little lower. I did run into one RV-10 pilot at one time who didn't calibrate his oil pressure on the EIS, and never set the proper scale factor and offset to make it read properly. It read high, so he just adjusted the engine. Scary....once you set the proper scale factor and offset, you'd probably find he reduced it way too low. So FIRST, verify the reading is all calibrated and set right, then decide what to do. But, you're not going to save an oil cooler from blowout due to routine normal oil pressure extremes, unless it's a bad cooler. Tim Olson - RV-10 N104CD do not archive On 2/13/2011 10:58 AM, Lew Gallagher wrote: > --> RV10-List message posted by: "Lew Gallagher" > > One more thought on high oil pressure. I heard of an oil cooler being blown out due to too high oil pressure on another plane. I don't know how high that would have to be, to be of concern, but I never would have thought of that at all. > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330896#330896 > > ________________________________________________________________________________
Date: Feb 13, 2011
Answer to the last question is, I think, that the vernatherm never closes completely, so the oil cooler sees full pressure even with low flow rates thru it. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330967#330967 ________________________________________________________________________________
Date: Feb 13, 2011
Subject: Re: Another first
Congratulations!! On 2/13/2011 7:24 PM, Eric_Kallio wrote: > --> RV10-List message posted by: "Eric_Kallio" > > Finally, it is my turn!!!!!! After getting the tach wired in to the mag N518RV made it maiden flight. Put 2 hours on it today and it felt great. The controls were very responsive and the aerosport power engine ran like a champ. Can't wait until the break in period is over and I can really explore the flight characteristics. Tomorrow I will work off some of the minor squaks and try to put a couple more hours on it. Only 28 more to go. > > Eric Kallio > N518RV Flying... > ________________________________________________________________________________
Date: Feb 13, 2011
Well done Eric.=0A=0AWishing you safe and smooth skies.=0A=0ARegards=0A=0AP atrick Pulis=0A=0A=0A=0A=0A________________________________=0AFrom: Eric_Ka llio =0ATo: rv10-list(at)matronics.com=0ASent: Mon, 14 Febru ary, 2011 10:54:28 AM=0ASubject: RV10-List: Another first=0A=0A--> RV10-Lis t message posted by: "Eric_Kallio" =0A=0AFinally, it is m y turn!!!!!! After getting the tach wired in to the mag N518RV =0Amade it m aiden flight. Put 2 hours on it today and it felt great. The controls =0Awe re very responsive and the aerosport power engine ran like a champ. Can't w ait =0Auntil the break in period is over and I can really explore the fligh t =0Acharacteristics. Tomorrow I will work off some of the minor squaks and try to =0Aput a couple more hours on it. Only 28 more to go.=0A=0AEric Kal lio=0AN518RV Flying...=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp ://forums.matronics.com/viewtopic.php?p=330951#330951=0A=0A=0A=0A=0A=0A ===============0A=0A=0A ________________________________________________________________________________
Date: Feb 13, 2011
The vernatherm is wide open when cold, allowing oil to bypass the cooler. It needs to fully close shutting off the bypass when the oil reaches 180 degrees, forcing the oil through the cooler. IOW your thinking about how it operates is backwards. On Sun, Feb 13, 2011 at 7:07 PM, Bob Turner wrote: > > Answer to the last question is, I think, that the vernatherm never closes completely, so the oil cooler sees full pressure even with low flow rates thru it. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=330967#330967 > > ________________________________________________________________________________
Date: Feb 13, 2011
Yup, 30 hours. Don't know what drove that decision and didn't push it. I also have a test flight area that averages nearly 95 miles on each side. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=330978#330978 ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: Picture of remote engine heat switch
Date: Feb 14, 2011
Got my remote engine heat switch set up, as seen in this photo. All the parts are in an old plastic tool box I had around. On the left is the circuit board of the Velleman remote switch kit. It use s a photocell pointed at the cheap pre-paid TracFone next to it. When I ca ll the cell twice within one minute and the photocell detects the phone scr een lighting up when those calls arrive, it trips the relay supplying power to the Reiff pre-heater. Power comes in on the green extension cord, which I tapped into for phone c harger power, detector circuit power, and then to feed the relay. Power to the pre-heater continues out the green cord to the right. Works well at home - now to take it to the hangar! TDT Tim Dawson-Townsend RV-10 N52KS (http://aprs.fi/?call=n52ks) tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) DQoNCg0KVGltIERhd3Nvbi1Ub3duc2VuZA0KNjE3LTQxNy04MzQxDQo2MTctOTA1LTQ4MDANCjYx Ny01MDAtNDgxMg= ________________________________________________________________________________
Date: Feb 14, 2011
Congratulations Eric! How are your temps? I'm very curious to know cause i got the same James cowl setup. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331015#331015 ________________________________________________________________________________
Date: Feb 14, 2011
Thanks for the info, Kelly. I tend to think backwards anyway! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331044#331044 ________________________________________________________________________________
Date: Feb 14, 2011
Eric, Did you get any indication why you got the 30 hour fly off? I am just beginning my project and am still learning the ins and outs of the process. Do you have a certified engine and prop? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331069#331069 ________________________________________________________________________________
Date: Feb 14, 2011
As for what drove the 30 hour fly-off I have no idea. I didn't press the issue. I have an Aerosport Power IO-540 with a new Hartzell prop. The only comment I got was even though the engine is a clone of a certified engine it was made to higher tolerances than the Lycoming factory and the IO-540 and the prop are a certified combination. Can't offer more than that. Temps: I have 5.0 on the engine right now and have done nothing other than fly around on the engine break in. First flight at 3000 PA and 54 degrees OAT my CHTs ranged from 390 to 420. Today by the end of the flight at the same altitude and 10 degrees warmer outside my CHTs were down to 378 to 414. Of course cylinders 5 and 6 are the hottest cylinders. My oil temps were steady at 192 degrees and 78 PSI. I have the oil cooler attached to the aft engine baffle as opposed to the firewall and scat tubing. The Sam James cowl is certainly not airtight as I have it installed. Now that it seems my temps are coming down after break-in I figure I have about 3 or 4 more hours before beginning to really seal up the plenum to control cooling. I am waiting for my superstar ground and flight support guy to put together and post the pics and video. When I have the link I will post it. I was so fortunate that when he filmed the first landing it was pretty. Not the same story today. Fortunately no one was watching today. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331091#331091 ________________________________________________________________________________
Date: Feb 15, 2011
Subject: Re: Crow Harnesses
Before I call Crow, what about the other systems (Hooker and the standard Van's ones)? Where is the "Y" in relation to the headrest and mount on the canopy? Halfway between? Closer to the seat? What do people prefer? -Rob On Mon, Feb 7, 2011 at 7:13 PM, Jae Chang wrote: > > Let us know what they say. Ordering the same harnesses is near the top of > my todo list. > > Jae > 40533 > > > On 2/7/2011 6:01 PM, Rob Kochman wrote: > >> Thanks, guys... I'm having second thoughts with my "good enough" >> assessment from the other day. The belts feel fine, but it seems like the >> geometry is off, with the shoulder straps essentially coming from the >> top-center of the headrest. I think I'm going to call and have them re-make >> the front seat shoulder straps. There's also *way* too much extra strap >> (around 3 feet) when I have them adjusted, so something is clearly not >> right. Maybe when I said "RV-10" they assumed all RVs are the same? Not >> really sure what's going on, but this is something that needs to be done >> right. >> DAR inspection in 13 days. Not exactly what I want to be messing with >> now... >> -Rob >> >> > > -- Rob Kochman RV-10 "Finishing" Kit Woodinville, WA (near Seattle) http://kochman.net/N819K ________________________________________________________________________________
Subject: parameters
Date: Feb 15, 2011
I was wondering if anyone has ran across a list of parameters for the RV-10 with the standard IO-540 engine. I want to setup my EFIS parameters tomorrow for all the speeds, temps, rpms, etc. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331192#331192 ________________________________________________________________________________
Subject: Re: Door Pin - Bullets
Date: Feb 15, 2011
I finally got around to respond to this. From selling pins and guides and setting up a bunch of doors and talking to customers I have learned a lot about the doors. Two of my customers had pushrod tubes from Vans that were extruded with oversized I.D.s which would not hold the 5/16-24 thread. It is important to make sure the threads engage well enough to hold the pins in place. Loc-tite is great after finishing the pin installation. I sell both styles of pins, angled and bullet. My pins are hollow with long 5/16-24 set screws and allow the builder to epoxy vans' magnets inside the pins. They work great that way and don't need further adjustment for the proximity switches. They also work good because they are not open at the end to catch on anything . Mechanical micro switches work with these too of course. I do believe Vans had the good idea of having an angle on the end to pull the pins to the guides. If you think about it, the angled pins have 7/16 of error to pull the door into the guides where the bullet pins have only 7/32. I try to talk my customers that have the 180 handles to use the stainless angled pins and Delrin guides. They really work well together. I only sell the aluminum guides with bullet pins because the stainless angled pins will catch on the aluminum where the bullet pins slide through easier. The only time I suggest the angled pins is on 180 kits when the length of penetration into the the cabin structure is sufficient. 90 degrees only gives you about 1 inch of pin extension. Vans' setup is about 110 degrees and give the pins about 1-1/4 of extension. 180 gives the pins 2 inches of travel or with the planearound latch it gives you 30-60 degrees of the cam pulling in the door and the rest to pin extension (1-1/4 to 1-5/8 inches of travel). Some things to think about - anyone starting out with the door should NOT cut the Vans' rack gears per the instructions. You should cut them in half leaving five inches for the upper and lower pieces. Even if you don't want the extra travel, it is there if you ever want it. Cutting them short per Vans' instructions limits the travel of the handle from the blind rivet in the gear rack or the end of the gear rack hitting the Vans' gearbox. If you don't want the full 180 degrees you could drill the rack gear and push a roll pin in it to stop the rotation if you desired. The gear racks are EXPENSIVE and add 80 bucks to the retro fit 180 just because plans tell you to cut them short. I encourage any questions about the door, door pins, door guides, latches etc. even if your not interested in anything I sell. I truly want builders to have the info for their project no matter what they are doing. The doors are the achilles heel of the RV-10. I'm not saying they don't work, they just require attention. The plane is absolutely awesome overall, this is just the weakest link. 801-580-3737 -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331194#331194 ________________________________________________________________________________
Date: Feb 16, 2011
I have 2000 plus hours on my RV8 with the Skybolt cam lock fasteners and a Sam James Cowl.and ;plenum. There is nothing better. Cowl can be removed and reinstalled in 2 to 3 minutes. Nothing comes loose and no ratteling. I never hesitate to remove and check engine etc. because of the ease of removing and reinstalling. Dick Martin RV8 N233M the fast one On Sat, Feb 12, 2011 at 3:33 PM, Bob Leffler wrote: > I was talking to a recently flying RV-10 pilot who just removed his top > cowl hinges along the firewall because of some blow back from the hinge > opening. Another RV-10 I just saw, the paint is starting to crack around > the hinge area. > > > I=92m curious if any of the flying RV-10s that installed either the stand ard > hinges or camlocs wished they made a different decision? > > > Thanks, > > > Bob > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: Re: parameters
Date: Feb 16, 2011
Engine-Check out the Lycoming operators manual Airspeeds- Check out the speeds provided by Vans in the Finish kit. To get you started on Engine. Tachometer Normal operating range. Green Arc 500/2700 rpm Red Line (Max Continuous Power) 2700 rpm Oil Temperature Green Arc Normal range 75 to 220 deg F Red line Max 245 deg F Oil Pressure Normal range 55 to 90psi Start and warm up 115psi Minimum (idle) 25 psi Max 95 psi Fuel Pressure Normal range 14 to 45 psi Minimum 14 psi Maximum 45 psi Cylinder Head Temperature Maximum Cruise 435 Deg F Maximum engine life 400 F and below Pascal -----Original Message----- From: Strasnuts Sent: Tuesday, February 15, 2011 8:20 PM Subject: RV10-List: parameters I was wondering if anyone has ran across a list of parameters for the RV-10 with the standard IO-540 engine. I want to setup my EFIS parameters tomorrow for all the speeds, temps, rpms, etc. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331192#331192 ________________________________________________________________________________
Date: Feb 16, 2011
Here's a spreadsheet with settings from my AFS engine monitor. It's a little hard to read at first but you'll get the idea. These aren't the strict limits set by Lycoming. I've massaged them a bit after living with the plane for a while. For example, if you set the RPM limit at 2700, you'll get a nuisance warning at 2710 so I bumped that up a bit. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Feb 15, 2011 at 8:20 PM, Strasnuts wrote: > > I was wondering if anyone has ran across a list of parameters for the RV- 10 with the standard IO-540 engine. =C2-I want to setup my EFIS parameter s tomorrow for all the speeds, temps, rpms, etc. > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331192#331192 > > =========== =========== RUMS - =========== ite - - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== > > ________________________________________________________________________________
Date: Feb 16, 2011
Subject: Tailcone crack found per SB 08-6-1
I found a crack in my tailcone as described by the SB during this year's annual. I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. I've only done stalls a couple times, i.e., Phase 1 and BFRs. However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. I'll post another picture with the doublers installed and the total time to complete the repair. Fly safe, Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Subject: Re: Tailcone crack found per SB 08-6-1
Date: Feb 16, 2011
Dave,thanks for a well documented and useful post,my understanding is you d id not do the service bulletin,If that is the case I have an extra set of t he doublers I will send you-Jim -----Original Message----- From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com> Sent: Wed, Feb 16, 2011 11:15 am Subject: RV10-List: Tailcone crack found per SB 08-6-1 I found a crack in my tailcone as described by the SB during this year's an nual. I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. 've only done stalls a couple times, i.e., Phase 1 and BFRs. owever, the first time I landed with a significantly aft CG it wasn't retty. I banged the tail tie-down hard enough to bend the "open oop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. I've been checking it visually at every annual and whenever I have the anels off at the elevator bellcrank. At some point during the previous inspections I saw what looked like a inor wave in the bulkhead and a fine line where there is now efinitely a crack. When I first saw it, I crawled into the tailcone nd was able to feel the area with my fingernail. After first oticing the "fine line", I watched it very closely at every nspection. I never noted any change over the next two inspections. his year it looked more pronounced so I looked even closer. I've een working as an IA for 20+ years and I've seen a lot of cracks. ven with my hand on it and solid boroscope inspections, I could not onvince myself that the mark was a crack. We finally confirmed it by hining a bright light from the front of the bulkhead and looking in rom behind with a boroscope. After disassembly I centerpunched the utboard rivet at the top of the bulkhead and the crack really jumped ut. Before that, even with the top plate removed and having complete ccess to the bulkhead, it was hard to definitively call it a crack. The repair is pretty straight-forward. The only comment I would make s to completely remove F-1010A in Step 9. It's only three more rivet eads and it makes working in the area a lot easier since you can rive the tails out of F-1010A on the bench instead of with it ttached to the bulkhead. In the future I plan to treat any warping or marks on the bulkhead as easons to add the doublers. The damage seems to have happened lowly, not suddenly, so the 25 hour inspections seem adequate to atch the problem. You can see the area through the elevator ellcrank covers with a bright light, so the inspection shouldn't add ore than few minutes to a preflight. Last week we inspected another -10 for a customer and there were efinitely no cracks, lines, warping, etc. It just looked completely ifferent. I'll post another picture with the doublers installed and the total ime to complete the repair. Fly safe, Dave Saylor irCrafters 40 Aviation Way atsonville, CA 95076 31-722-9141 Shop 31-750-0284 Cell ________________________________________________________________________________
Date: Feb 16, 2011
Excellent, Dave! I'm sure I speak for everyone on this in thanking you for your detailed presentation of this problem. Jack Phillips #40610 - building ailerons today Raleigh, NC -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Wednesday, February 16, 2011 1:19 PM Subject: RV10-List: Tailcone crack found per SB 08-6-1 I found a crack in my tailcone as described by the SB during this year's annual. I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. I've only done stalls a couple times, i.e., Phase 1 and BFRs. However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. I'll post another picture with the doublers installed and the total time to complete the repair. Fly safe, Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: Feb 16, 2011
Dave I to have a extra set of doublers if you need them. Just shoot me a e-mail and I will get them in the mail to you Wings rear spar scuffing and primering once the rain stops John G. Cumins President 2499 B1 Martin Rd Fairfield Ca 94534 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Wednesday, February 16, 2011 10:19 AM Subject: RV10-List: Tailcone crack found per SB 08-6-1 I found a crack in my tailcone as described by the SB during this year's annual. I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. I've only done stalls a couple times, i.e., Phase 1 and BFRs. However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. I'll post another picture with the doublers installed and the total time to complete the repair. Fly safe, Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Date: Feb 16, 2011
Thanks guys, I have the set that went out with the SB. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Wed, Feb 16, 2011 at 12:42 PM, John Cumins wrote: > > Dave > > I to have a extra set of doublers if you need them. Just shoot me a e-mail and I will get them in the mail to you > > Wings rear spar scuffing and primering once the rain stops > > John G. Cumins > President > > > 2499 B1 Martin Rd > Fairfield Ca 94534 > 707-425-7100 > 707-425-7576 Fax > > Your Total Technology Solution Provider > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Wednesday, February 16, 2011 10:19 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tailcone crack found per SB 08-6-1 > > I found a crack in my tailcone as described by the SB during this year's annual. > > I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. > I've only done stalls a couple times, i.e., Phase 1 and BFRs. > However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. > > I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. > > At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. > This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. > Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. > > The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. > > In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. > > Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. > > I'll post another picture with the doublers installed and the total time to complete the repair. > > Fly safe, > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > ________________________________________________________________________________
Date: Feb 16, 2011
Well, I guess that proves that the S.B. was a valid one and should be done. I know lots of people were doubtful, but now that there is another case it's clear that it's a good idea to do. It was a 1 day job to do the whole thing, so in the big scheme of things it wasn't too bad. Tim On 2/16/2011 12:19 PM, Dave Saylor wrote: > I found a crack in my tailcone as described by the SB during this year's annual. > > I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. > I've only done stalls a couple times, i.e., Phase 1 and BFRs. > However, the first time I landed with a significantly aft CG it wasn't > pretty. I banged the tail tie-down hard enough to bend the "open > loop" eye bolt and grind half an inch off the rudder cap. That was in > December 2008. I think that event may have led to the crack. > > I've been checking it visually at every annual and whenever I have the > panels off at the elevator bellcrank. > > At some point during the previous inspections I saw what looked like a > minor wave in the bulkhead and a fine line where there is now > definitely a crack. When I first saw it, I crawled into the tailcone > and was able to feel the area with my fingernail. After first > noticing the "fine line", I watched it very closely at every > inspection. I never noted any change over the next two inspections. > This year it looked more pronounced so I looked even closer. I've > been working as an IA for 20+ years and I've seen a lot of cracks. > Even with my hand on it and solid boroscope inspections, I could not > convince myself that the mark was a crack. We finally confirmed it by > shining a bright light from the front of the bulkhead and looking in > from behind with a boroscope. After disassembly I centerpunched the > outboard rivet at the top of the bulkhead and the crack really jumped > out. Before that, even with the top plate removed and having complete > access to the bulkhead, it was hard to definitively call it a crack. > > The repair is pretty straight-forward. The only comment I would make > is to completely remove F-1010A in Step 9. It's only three more rivet > heads and it makes working in the area a lot easier since you can > drive the tails out of F-1010A on the bench instead of with it > attached to the bulkhead. > > In the future I plan to treat any warping or marks on the bulkhead as > reasons to add the doublers. The damage seems to have happened > slowly, not suddenly, so the 25 hour inspections seem adequate to > catch the problem. You can see the area through the elevator > bellcrank covers with a bright light, so the inspection shouldn't add > more than few minutes to a preflight. > > Last week we inspected another -10 for a customer and there were > definitely no cracks, lines, warping, etc. It just looked completely > different. > > I'll post another picture with the doublers installed and the total > time to complete the repair. > > Fly safe, > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell ________________________________________________________________________________
Date: Feb 16, 2011
Has anyone found cracks without a tail strike or heavy turbulence? At this point we seem to have two instances of crack. Are there others? ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Wednesday, February 16, 2011 12:27 PM Subject: RE: RV10-List: Tailcone crack found per SB 08-6-1 > > Excellent, Dave! I'm sure I speak for everyone on this in thanking you > for > your detailed presentation of this problem. > > Jack Phillips > #40610 - building ailerons today > Raleigh, NC > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Wednesday, February 16, 2011 1:19 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tailcone crack found per SB 08-6-1 > > I found a crack in my tailcone as described by the SB during this year's > annual. > > I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. > I've only done stalls a couple times, i.e., Phase 1 and BFRs. > However, the first time I landed with a significantly aft CG it wasn't > pretty. I banged the tail tie-down hard enough to bend the "open > loop" eye bolt and grind half an inch off the rudder cap. That was in > December 2008. I think that event may have led to the crack. > > I've been checking it visually at every annual and whenever I have the > panels off at the elevator bellcrank. > > At some point during the previous inspections I saw what looked like a > minor wave in the bulkhead and a fine line where there is now > definitely a crack. When I first saw it, I crawled into the tailcone > and was able to feel the area with my fingernail. After first > noticing the "fine line", I watched it very closely at every > inspection. I never noted any change over the next two inspections. > This year it looked more pronounced so I looked even closer. I've > been working as an IA for 20+ years and I've seen a lot of cracks. > Even with my hand on it and solid boroscope inspections, I could not > convince myself that the mark was a crack. We finally confirmed it by > shining a bright light from the front of the bulkhead and looking in > from behind with a boroscope. After disassembly I centerpunched the > outboard rivet at the top of the bulkhead and the crack really jumped > out. Before that, even with the top plate removed and having complete > access to the bulkhead, it was hard to definitively call it a crack. > > The repair is pretty straight-forward. The only comment I would make > is to completely remove F-1010A in Step 9. It's only three more rivet > heads and it makes working in the area a lot easier since you can > drive the tails out of F-1010A on the bench instead of with it > attached to the bulkhead. > > In the future I plan to treat any warping or marks on the bulkhead as > reasons to add the doublers. The damage seems to have happened > slowly, not suddenly, so the 25 hour inspections seem adequate to > catch the problem. You can see the area through the elevator > bellcrank covers with a bright light, so the inspection shouldn't add > more than few minutes to a preflight. > > Last week we inspected another -10 for a customer and there were > definitely no cracks, lines, warping, etc. It just looked completely > different. > > I'll post another picture with the doublers installed and the total > time to complete the repair. > > Fly safe, > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > > ________________________________________________________________________________
Date: Feb 16, 2011
Dave Not a problem. Have fun. Saratoga annual starts tonight so no RV building for a while. John G. Cumins President 2499 B1 Martin Rd Fairfield Ca 94534 707-425-7100 707-425-7576 Fax Your Total Technology Solution Provider -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Wednesday, February 16, 2011 1:04 PM Subject: Re: RV10-List: Tailcone crack found per SB 08-6-1 --> Thanks guys, I have the set that went out with the SB. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Wed, Feb 16, 2011 at 12:42 PM, John Cumins wrote: > > Dave > > I to have a extra set of doublers if you need them. Just shoot me a > e-mail and I will get them in the mail to you > > Wings rear spar scuffing and primering once the rain stops > > John G. Cumins > President > > > 2499 B1 Martin Rd > Fairfield Ca 94534 > 707-425-7100 > 707-425-7576 Fax > > Your Total Technology Solution Provider > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor > Sent: Wednesday, February 16, 2011 10:19 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Tailcone crack found per SB 08-6-1 > > I found a crack in my tailcone as described by the SB during this year's annual. > > I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. > I've only done stalls a couple times, i.e., Phase 1 and BFRs. > However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. > > I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. > > At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. > This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. > Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. > > The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. > > In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. > > Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. > > I'll post another picture with the doublers installed and the total time to complete the repair. > > Fly safe, > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > > ________________________________________________________________________________
Date: Feb 16, 2011
I purchased my RV-10 a year ago. It was built in 2008-2009. The builder is no longer alive. How can I tell if the sb was complied with? What should I be looking for. Nothing in the logs that I can find. Alan N668g Sent from my iPhone On Feb 16, 2011, at 11:19 AM, Dave Saylor wrote: > I found a crack in my tailcone as described by the SB during this year's annual. > > I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. > I've only done stalls a couple times, i.e., Phase 1 and BFRs. > However, the first time I landed with a significantly aft CG it wasn't > pretty. I banged the tail tie-down hard enough to bend the "open > loop" eye bolt and grind half an inch off the rudder cap. That was in > December 2008. I think that event may have led to the crack. > > I've been checking it visually at every annual and whenever I have the > panels off at the elevator bellcrank. > > At some point during the previous inspections I saw what looked like a > minor wave in the bulkhead and a fine line where there is now > definitely a crack. When I first saw it, I crawled into the tailcone > and was able to feel the area with my fingernail. After first > noticing the "fine line", I watched it very closely at every > inspection. I never noted any change over the next two inspections. > This year it looked more pronounced so I looked even closer. I've > been working as an IA for 20+ years and I've seen a lot of cracks. > Even with my hand on it and solid boroscope inspections, I could not > convince myself that the mark was a crack. We finally confirmed it by > shining a bright light from the front of the bulkhead and looking in > from behind with a boroscope. After disassembly I centerpunched the > outboard rivet at the top of the bulkhead and the crack really jumped > out. Before that, even with the top plate removed and having complete > access to the bulkhead, it was hard to definitively call it a crack. > > The repair is pretty straight-forward. The only comment I would make > is to completely remove F-1010A in Step 9. It's only three more rivet > heads and it makes working in the area a lot easier since you can > drive the tails out of F-1010A on the bench instead of with it > attached to the bulkhead. > > In the future I plan to treat any warping or marks on the bulkhead as > reasons to add the doublers. The damage seems to have happened > slowly, not suddenly, so the 25 hour inspections seem adequate to > catch the problem. You can see the area through the elevator > bellcrank covers with a bright light, so the inspection shouldn't add > more than few minutes to a preflight. > > Last week we inspected another -10 for a customer and there were > definitely no cracks, lines, warping, etc. It just looked completely > different. > > I'll post another picture with the doublers installed and the total > time to complete the repair. > > Fly safe, > > Dave Saylor > AirCrafters > 140 Aviation Way > Watsonville, CA 95076 > 831-722-9141 Shop > 831-750-0284 Cell > <4 Crack after centerpunching rivet for drilling.jpg> > <1 Bright backlight viewed with boroscope--with frontlight.jpg> > <2 Bright backlight viewed with boroscope--no frontlight.jpg> > <3 Ready for repair.jpg> > <5 F-1010A removed to punch out rivet tails.jpg> > <6 Stop drilled--note crack ends above F-1010A, not visible from fwd side.jpg> ________________________________________________________________________________
Date: Feb 16, 2011
> How can I > tell if the sb was complied with? What should I be looking for. Have a look at http://www.vansaircraft.com/pdf/sb08-6-1.pdf. That is the specific bulletin - it details the change and how to spot it. FYI - for any service bulletins related to vans aircraft, you can find them here -> http://www.vansaircraft.com/public/notices.htm. -ron ________________________________________________________________________________
Date: Feb 16, 2011
There should be a logbook endorsement,if not your mechanic can inspect it f rom the pictures and instructions on Vans website.The inspection is easy th e fix is somewhat more involved,it took me a couple weekends but I work slo w-Jim -----Original Message----- From: Alan Mekler MD <amekler(at)metrocast.net> Sent: Wed, Feb 16, 2011 3:10 pm Subject: Re: RV10-List: Tailcone crack found per SB 08-6-1 I purchased my RV-10 a year ago. It was built in 2008-2009. The builder is no onger alive. How can I ell if the sb was complied with? What should I be looking for. othing in the logs that I can find. lan 668g Sent from my iPhone On Feb 16, 2011, at 11:19 AM, Dave Saylor rote: > I found a crack in my tailcone as described by the SB during this year's nnual. I've got 775 hours on the Hobbs. It's been flying for 3 1/2 years. I've only done stalls a couple times, i.e., Phase 1 and BFRs. However, the first time I landed with a significantly aft CG it wasn't pretty. I banged the tail tie-down hard enough to bend the "open loop" eye bolt and grind half an inch off the rudder cap. That was in December 2008. I think that event may have led to the crack. I've been checking it visually at every annual and whenever I have the panels off at the elevator bellcrank. At some point during the previous inspections I saw what looked like a minor wave in the bulkhead and a fine line where there is now definitely a crack. When I first saw it, I crawled into the tailcone and was able to feel the area with my fingernail. After first noticing the "fine line", I watched it very closely at every inspection. I never noted any change over the next two inspections. This year it looked more pronounced so I looked even closer. I've been working as an IA for 20+ years and I've seen a lot of cracks. Even with my hand on it and solid boroscope inspections, I could not convince myself that the mark was a crack. We finally confirmed it by shining a bright light from the front of the bulkhead and looking in from behind with a boroscope. After disassembly I centerpunched the outboard rivet at the top of the bulkhead and the crack really jumped out. Before that, even with the top plate removed and having complete access to the bulkhead, it was hard to definitively call it a crack. The repair is pretty straight-forward. The only comment I would make is to completely remove F-1010A in Step 9. It's only three more rivet heads and it makes working in the area a lot easier since you can drive the tails out of F-1010A on the bench instead of with it attached to the bulkhead. In the future I plan to treat any warping or marks on the bulkhead as reasons to add the doublers. The damage seems to have happened slowly, not suddenly, so the 25 hour inspections seem adequate to catch the problem. You can see the area through the elevator bellcrank covers with a bright light, so the inspection shouldn't add more than few minutes to a preflight. Last week we inspected another -10 for a customer and there were definitely no cracks, lines, warping, etc. It just looked completely different. I'll post another picture with the doublers installed and the total time to complete the repair. Fly safe, Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell <4 Crack after centerpunching rivet for drilling.jpg> <1 Bright backlight viewed with boroscope--with frontlight.jpg> <2 Bright backlight viewed with boroscope--no frontlight.jpg> <3 Ready for repair.jpg> <5 F-1010A removed to punch out rivet tails.jpg> <6 Stop drilled--note crack ends above F-1010A, not visible from fwd side. jpg> -======================== -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Feb 17, 2011
> There should be a logbook endorsement,.... Only if was installed after receiving his airworthiness certificate. Since it was built in 2008, like with my project, it could have been installed during the build so there wouldn't be a logbook entry in that case. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331323#331323 ________________________________________________________________________________
Date: Feb 17, 2011
Probably a good suggestion to all of us that are not yet completed....put mention of SBs complied with in the initial logbook entry, as a point of reference for any subsequent owner, or heaven forbid, any accident investigation. Much as I dislike it, whether for certified or homebuilt, logbooks are there to protect our backsides, and to make our lives easier when we need to verify something that our brains have blotted out. On 2/17/2011 5:29 AM, tsts4 wrote: > --> RV10-List message posted by: "tsts4" > > >> There should be a logbook endorsement,.... > > Only if was installed after receiving his airworthiness certificate. Since it was built in 2008, like with my project, it could have been installed during the build so there wouldn't be a logbook entry in that case. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331323#331323 > > ________________________________________________________________________________
Subject: Aircraft Video
Date: Feb 18, 2011
I'm looking for a camera installation for my RV-10. I've used a hand-held video camera but really would like a camera mounted on the VS and a recorder in the cockpit. Shooting from inside the cabin shows up the prop in straight ahead shot so I'm thinking raising the camera would help. I've seen video on Utube that was taken from the VS. Anyone have experience or sources? Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Aircraft Video
Date: Feb 18, 2011
GoPro cameras are great for that type of thing. They also have tons of different mounts for them. Most "stunt videos" you see on YouTube are probably GoPro cameras. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 18, 2011, at 11:49 AM, Albert Gardner wrote: > > I'm looking for a camera installation for my RV-10. I've used a hand-held > video camera but really would like a camera mounted on the VS and a recorder > in the cockpit. Shooting from inside the cabin shows up the prop in straight > ahead shot so I'm thinking raising the camera would help. I've seen video on > Utube that was taken from the VS. Anyone have experience or sources? > Albert Gardner > N991RV > Yuma, AZ > > > > > > ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Feb 18, 2011
I like the Contour series.... The Contour GPS has a built in GPS so it shows the ground track in Google maps along with the video..... Small package, very well built... Sent from my iPhone On Feb 18, 2011, at 12:10 PM, Jesse Saint wrote: > > GoPro cameras are great for that type of thing. They also have tons of different mounts for them. Most "stunt videos" you see on YouTube are probably GoPro cameras. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Feb 18, 2011, at 11:49 AM, Albert Gardner wrote: > >> >> I'm looking for a camera installation for my RV-10. I've used a hand-held >> video camera but really would like a camera mounted on the VS and a recorder >> in the cockpit. Shooting from inside the cabin shows up the prop in straight >> ahead shot so I'm thinking raising the camera would help. I've seen video on >> Utube that was taken from the VS. Anyone have experience or sources? >> Albert Gardner >> N991RV >> Yuma, AZ >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Feb 18, 2011
Albert, I have placed a 3 camera (can add a 4th) video recording system in my 8A. One on the VS, one on the belly pointing aft and one in the cockpit to film both Pilot & squirming Passenger. The cameras are all 520 Line or greater bullet cameras with the choice of different lenses (~$100 each on eBay). The end result is a good looking image from multiple angles. The down side is the video is not HD. I was unable to find a small, reasonably priced *remote* DVR that recorded HD video so I decided to go with standard def and supplement it with something like GoProHD http://gopro.com or the ContourHD camera http://contour.com/ internally mounted. See Note at the end of this email. I have a feeling that 5 years for now there will be many different choices but unfortunately your plane will be painted & flying for some time by then. Below are a couple of photos of the install. You can see in one photo the shot from the tail on the display screen. I can switch which camera is being recorded with the knob to the left of the display. I think this system will work out nicely but is not the ideal hardware for the task. I did see some cool stuff out there but it was many thousands of dollars so I decided to go low-def for now. FYI I always carry two additional cameras. One is an HD Video camera called the Sony Bloggie<http://www.sonystyle.com/webapp/wcs/stores/servlet/CategoryDisplay? catalogId=10551&storeId=10151&langId=-1&categoryId=8198552921644696 004&XID=O:sony%20bloggie:dg_bloggie_gglsrch:Blo_Blo_nopromo#/model8gbCont ent>MHS-TS20 . It is a pretty amazing HD unit for the price with a 3=94 screen. I paid $120.00 for the camera. Takes pretty good still photos too. Occasionally I mount it with a suction RAM mount. This is a video taken wit h the prior version of the Bloggie called the Webbie. *Note: you should watch this in 1080p mode*. This was a test video in low light conditions. I was learning the focal length of the camera. http://www.youtube.com/watch?v=4aJt4_Chswo&hd=1 Here is a New Years flight video. Suggest you view full screen & 720p. Agai n taken with the older Webbie: http://www.youtube.com/watch?v=VR2i9EQRZ50&h d=1 I have to say the videos from the Contour & GoProHD are much better than the Sony Bloggie for action video. Also my 14 Mp camera with 1080P video does a surprisingly good job of HD video. Sorry no examples. Good luck, Robin Note: I believe the best HD video recording system will probably be a PC with an HD video card. Record to a HD or SSHD then transfer content to thumb drive or transfer via wireless / Bluetooth. There are several cards on the market that accept independent video 4 inputs. This may also be the cheapest way t o film multiple HD videos. Unfortunately at this time the cards insert into =93tower=94 style computers. Not something I wanted to add to the airplane. The early adopters curse=85. DVR on top with removable memory card. Rotary camera selector. [image: DVR 001(2).jpg] View point shows full flaps plus cockpit, prop etc=85 [image: DVR 001(3).jpg] Rear facing belly camera. Should look good with the smoke on! [image: Belly cam, naca scoops 002.jpg] Tail camera [image: Tail camera 007.jpg] Dash Cam. Yes=85 Chrome Roll Bars J [image: Dash cam, windscreen 001.jpg] Can=92t show you all these photos w/o showing the panel J [image: New cam 006.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Friday, February 18, 2011 8:50 AM Subject: RV10-List: Aircraft Video I'm looking for a camera installation for my RV-10. I've used a hand-held video camera but really would like a camera mounted on the VS and a recorde r in the cockpit. Shooting from inside the cabin shows up the prop in straigh t ahead shot so I'm thinking raising the camera would help. I've seen video o n Utube that was taken from the VS. Anyone have experience or sources? Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Baggage floor angles
Date: Feb 18, 2011
I had a big scare with those 1023B's. I was rooting around my parts drawers and found the virgin parts still covered in vinyl. I searched the part number which led me to this thread. I panicked thinking I hadn't installed them and they are covered by other panels so they can't be seen. Fortunately I found pix in my log showing them installed. Van's must have sent me extra copies of the parts. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331433#331433 ________________________________________________________________________________
Date: Feb 18, 2011
That is better than Bonanzacrafters non-existent quality control. I was working on the pieces that attach the wing root fairings, and found the nut plates for the bottom fairing were installed without the screw holes getting any dimpling. Guess I will need to drill out those rivets, dimple and re-rivet the nutplates back on. Then I went to do the forward tank support brackets, that attach with a couple AN3-5A bolts into the fuselage side. Natcherly, the nutplates were installed, but the bolt holes never finish drilled, so had to drill them carefully to not burr the nut plates, and will have to live with no de-burr of the inner side of the holes. Just sloppy work. Oh, and if the brackets ever had a part label, it was long gone, so had to identify by shape, size and hole locations. Little things that make building so educational and recreational. ;-) On Fri, Feb 18, 2011 at 11:23 AM, woxofswa wrote: > > I had a big scare with those 1023B's. > I was rooting around my parts drawers and found the virgin parts still covered in vinyl. I searched the part number which led me to this thread. I panicked thinking I hadn't installed them and they are covered by other panels so they can't be seen. Fortunately I found pix in my log showing them installed. Van's must have sent me extra copies of the parts. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331433#331433 > > ________________________________________________________________________________
Date: Feb 18, 2011
Kinda glad I did not have the money for the qb now. I have heard of many things that had to be taken apart and redone by other builders too. I spent 9 weeks/205 hours getting to the qb stage. Glad you have the patience to deal with it. Working on the cabin top now. Take care. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 43 Cabin Cover Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331472#331472 ________________________________________________________________________________
Subject: Re: Exhaust Pipe Temps
Date: Feb 19, 2011
Hey Don, I never saw a reply on your question re exhaust pipe temp, so today I aimed an infrared sensor at the exhaust pipes just as they clear the cowling. 250 F and it's 65 outside. He had just landed and I took it as he stopped after taxi with the engine still running. The numbers bounced around a bit (wind?) but 250 seemed about average. I'm curious what you'll do with this number? If it's about protecting the fiberglass from heat, I've thought of using the same type of heat shield that is on motorcycle headers -- a strap clamp around the pipe that holds a metal shield off with an air gap in between. But if the adhesive reflective tape works just as well, that may do the trick. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331546#331546 ________________________________________________________________________________
Subject: Fwd: q.com
Date: Feb 19, 2011
Matt, can you help Dave? Begin forwarded message: > From: "DLM" <dlm34077(at)q.com> > Date: February 19, 2011 5:09:37 PM CST > To: "Miller John" > Subject: Re: q.com > > convey to the matronics list, if possible, that q.com is a valid domain. also that dlm34077(at)q.com is a valid FROM address as well as a valid TO address. I still receive the list messages; I just can not reply; I receive a message rejection from the list. > ----- Original Message ----- > From: Miller John > To: DLM > Sent: Saturday, February 19, 2011 4:00 PM > Subject: Re: q.com > > What do you need me to do?? > > On Feb 19, 2011, at 4:33 PM, DLM wrote: > >> the list has implemented something that treats my dlm34077(at)q.com as spam. the q.com domain is valid for Qwest DSL. Since I can not send to them perhaps you could pass this message to a person there. > > ________________________________________________________________________________
Date: Feb 19, 2011
I mounted the POV 1.5 camera on my rv10's tail. The tail height aims the camera over the top of the cabin. The prop strobe effect is at the bottom of the video frame. The cord to the camera contains the video and power. The system comes complete with a hand held DVR that has a screen on it so you can test or aim it. The DVR has AA batteries that also supply power to the camera. The video is recorded on a 4 or 8 GB SD card in the DVR. The camera also comes with editing software. Amazon has a complete system at http://www.amazon.com/VIO-POV-1-5-Video-System/dp/B001TALUFY The camera installation shown on my web site is an older camera that did not work very well. I adapted the camera installation to mount the smaller POV camera. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331593#331593 ________________________________________________________________________________
Date: Feb 20, 2011
Subject:
test message ________________________________________________________________________________
Date: Feb 20, 2011
Subject: Re: : RV10-List:
5X5 On Sun, Feb 20, 2011 at 2:52 AM, wrote: > > test message > > ________________________________________________________________________________
Subject: Re: Cowl Fasteners
Date: Feb 20, 2011
I have Skybolt Camlocks on the back of the upper cowl. I use the hinge/skewer system to join the upper and lower cowls and plain old #10 SS Screws and nutplates on the back of the lower cowl. It all seems to work well and seems to be holding up fine. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331686#331686 ________________________________________________________________________________
Subject: Dremel tool - recommendation - and anecdote
Date: Feb 20, 2011
About 3-4 years ago I bought the Dremel Cordless 10.8V lithium-ion batter powered tool. It has proved to be an invaluable tool in building the RV10 and in doing routine work and maintenance. Anyway - the charger was dropped or went south and I needed a new charging stand. The fine folks at Dremel Service in Palm Springs CA agreed to sell me a new charger for $28. I called and they said that it was ok to come by and pick it up. I did and was surprised to meet Mrs Dremel herself. She and son Rob Dremel run the place and have a great little mini-museum on site showing the history of this gem of a tool system. A very cool piece of Americana. The family sold out to Emerson Electric years ago and it is now owned by Bosch, but they keep the family connection. Dremel has a new 12V Lithium-Ion powered tool which might be even better than my 10.8V system. The Lithium-Ion stuff is light and the batteries have great hang time. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331687#331687 ________________________________________________________________________________
Date: Feb 21, 2011
Subject: Re: flaps
I finally got around to fixing my flaps. I found it was in the Show planes flap positioning system. Apparently my jack screw rod end bearing- could turn enough to wear on the micro switches. I took off the system from the j ack screw and flaps work just fine so I called and sent the position system back to show planes and they went through it and replaced the micro switch es and sent some counter sunk washers to put in and that seems to have fixe d the problems. --- On Tue, 1/11/11, Robert Brunkenhoefer wrote: From: Robert Brunkenhoefer <robertbrunk(at)me.com> Subject: Re: RV10-List: flaps Date: Tuesday, January 11, 2011, 9:56 PM I have flaps that do not go all the way up after reaching 1st flap position whwe they have been down while in flight and on the ground. 350+hrs.- Robert BrunkenhoeferSent from my Apple iPad On Jan 11, 2011, at 6:48 PM, DLM wrote: =0A=0AMine have 370 hours with no problem; I do not use =0Athe flap positio ning system.=0A=0A ----- Original Message ----- =0A From: =0A Patrick =0A Thyssen =0A To: rv10-list(at)matronics.com =0A Sent: Tuesday, January 1 1, 2011 5:28 =0A PM=0A Subject: RV10-List: flaps=0A =0A =0A =0A =0A There are two of us that are around 300 hrs and now the =0A flaps have been not wanting to come all the way up. If you give them a =0A little- help by pushing up on them or by takin g off where there is =0A air pressure on them, they come up. My budd y has looked in his tunnel =0A and does not see anything wrong. Wond ering if anybody else has had this =0A problem. I'll- be taking- mine apart in another week or so to =0A find out what is going on, wondering, if this is a know problem with the =0A flap motor or the gears. They come up to around the half way or first =0A flap setting with n o problem and then stop, and going down there is no =0A problem just coming up. Patrick Thyssen N15PT 281-655-9363 =0A href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c =0A=0A=0A =0A ________________________________________________________________________________
Subject: rudder pedal extensions
Date: Feb 21, 2011
Tim, We made these out of =BC inch Aluminum. They are pretty heavy. Lightened them up with holes. They extend about 4 inches. My wife couldn=92t keep het feet on the floor and move the pedals so we welded an extension on. No interference with the brakes. Working on a few modifications to allow easier mounting and better cosmetics but they work. Alan _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, January 02, 2011 9:13 AM Subject: Re: RV10-List: rudder pedal extensions http://www.myrv10.com/N104CD/upgrades/20090503/index.html These are really crude and could be refined well with some effort. I painted them and have left them in almost all the time for I guess 1.5 years now. They don't interfere with the brakes but that's because I built them in such a way that they wouldn't. They basically only touch the pedal surface...not anything else. I still have to pull them and drill some lightening holes some day, and maybe fill some gaps with wood putty for cosmetics. Tim On Jan 2, 2011, at 7:41 AM, "Alan Mekler" wrote: Does anyone make a rudder pedal extension? My wife is only 5 feet tall and can=92t reach the pedals. I tried making a 4inch extension but it interfered with the brakes. Alan N668G ________________________________________________________________________________
Subject: Re: rudder pedal extensions
Date: Feb 21, 2011
Hi Alan, That basically looks like what I did but I did it in wood. I haven't yet li ghtened them but i think done right they could be made fairly light. Would b e interesting to use carbon fiber but actually i think being a little heavie r is probably a good thing to some extent...at least on the bottom half belo w the bar. Mine remove with two bolts in only a minute or so. No interfere nce with anything. I've left them on for a year or more now. I plan to sp iffy them up a bit soon, and lighten them a little and maybe add anti-skid t ape to the bottom lip. They do make it work ok for the wife...so I'm happy. Tim On Feb 21, 2011, at 9:08 AM, "Alan Mekler" wrote: > Tim, > We made these out of =C2=BC inch Aluminum. They are pretty heavy. Lightene d them up with holes. They extend about 4 inches. My wife couldn=99t k eep het feet on the floor and move the pedals so we welded an extension on. N o interference with the brakes. Working on a few modifications to allow easi er mounting and better cosmetics but they work. > > Alan > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Sunday, January 02, 2011 9:13 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: rudder pedal extensions > > > http://www.myrv10.com/N104CD/upgrades/20090503/index.html > > These are really crude and could be refined well with some effort. I pain ted them and have left them in almost all the time for I guess 1.5 years now . They don't interfere with the brakes but that's because I built them in s uch a way that they wouldn't. They basically only touch the pedal surface... not anything else. > I still have to pull them and drill some lightening holes some day, and ma ybe fill some gaps with wood putty for cosmetics. > Tim > > > On Jan 2, 2011, at 7:41 AM, "Alan Mekler" wrote: > >> Does anyone make a rudder pedal extension? My wife is only 5 feet tall an d can=99t reach the pedals. I tried making a 4inch extension but it in terfered with the brakes. >> Alan >> N668G >> >> >> > > ________________________________________________________________________________
Date: Feb 21, 2011
Yes keeping the wife happy is important. Now I have to get her a seat cushion. Alan Sent from my iPhone On Feb 21, 2011, at 10:37 AM, Tim Olson wrote: > Hi Alan, > That basically looks like what I did but I did it in wood. I haven't yet l ightened them but i think done right they could be made fairly light. Would be interesting to use carbon fiber but actually i think being a little heav ier is probably a good thing to some extent...at least on the bottom half be low the bar. Mine remove with two bolts in only a minute or so. No interfe rence with anything. I've left them on for a year or more now. I plan to s piffy them up a bit soon, and lighten them a little and maybe add anti-skid t ape to the bottom lip. They do make it work ok for the wife...so I'm happy. > Tim > > > > On Feb 21, 2011, at 9:08 AM, "Alan Mekler" wrote: > >> Tim, >> We made these out of =C2=BC inch Aluminum. They are pretty heavy. Lighten ed them up with holes. They extend about 4 inches. My wife couldn=99t k eep het feet on the floor and move the pedals so we welded an extension on. N o interference with the brakes. Working on a few modifications to allow easi er mounting and better cosmetics but they work. >> >> Alan >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server @matronics.com] On Behalf Of Tim Olson >> Sent: Sunday, January 02, 2011 9:13 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: rudder pedal extensions >> >> >> http://www.myrv10.com/N104CD/upgrades/20090503/index.html >> >> These are really crude and could be refined well with some effort. I pai nted them and have left them in almost all the time for I guess 1.5 years no w. They don't interfere with the brakes but that's because I built them in s uch a way that they wouldn't. They basically only touch the pedal surface... not anything else. >> I still have to pull them and drill some lightening holes some day, and m aybe fill some gaps with wood putty for cosmetics. >> Tim >> >> >> On Jan 2, 2011, at 7:41 AM, "Alan Mekler" wrote: >> >>> Does anyone make a rudder pedal extension? My wife is only 5 feet tall a nd can=99t reach the pedals. I tried making a 4inch extension but it i nterfered with the brakes. >>> Alan >>> N668G >>> >>> >>> >> >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 22, 2011
DOES ANYONE HAVE A (POH) GENERIC GUIDE OR FORMAT FOR THE RV 10?=0A=0A=0A=0A ________________________________=0AFrom: Alan Mekler MD <amekler@metrocast. net>=0ATo: "rv10-list(at)matronics.com" =0ASent: Mon, February 21, 2011 1:44:08 PM=0ASubject: Re: RV10-List: rudder pedal extens ions=0A=0A=0AYes keeping the wife happy is important.=0ANow I have to get h er a seat cushion.=0A=0AAlan=0A=0ASent from my iPhone=0A=0AOn Feb 21, 2011, at 10:37 AM, Tim Olson wrote:=0A=0A=0AHi Alan, =0A>That b asically looks like what I did but I did it in wood. I haven't yet =0A>lig htened them but i think done right they could be made fairly light. Would be =0A>interesting to use carbon fiber but actually i think being a little heavier is =0A>probably a good thing to some extent...at least on the botto m half below the =0A>bar. Mine remove with two bolts in only a minute or s o. No interference with =0A>anything. I've left them on for a year or mor e now. I plan to spiffy them up =0A>a bit soon, and lighten them a little and maybe add anti-skid tape to the bottom =0A>lip. They do make it work ok for the wife...so I'm happy.=0A>Tim=0A>=0A>=0A>=0A>=0A>On Feb 21, 2011, at 9:08 AM, "Alan Mekler" wrote:=0A>=0A>=0A> =0A>>T im,=0A>>We made these out of =C2=BC inch Aluminum. They are pretty heavy. L ightened them up =0A>>with holes. They extend about 4 inches. My wife could n=99t keep het feet on the =0A>>floor and move the pedals so we welde d an extension on. No interference with the =0A>>brakes. Working on a few m odifications to allow easier mounting and better =0A>>cosmetics but they wo rk.=0A>> =0A>>Alan=0A>> =0A>>=0A________________________________=0A =0A>>Fr om:owner-rv10-list-server(at)matronics.com =0A>>[mailto:owner-rv10-list-server @matronics.com] On Behalf Of Tim Olson=0A>>Sent: Sunday, January 02, 2011 9 :13 AM=0A>>To: rv10-list(at)matronics.com=0A>>Subject: Re: RV10-List: rudder p edal extensions=0A>> =0A>>=0A>>http://www.myrv10.com/N104CD/upgrades/200905 03/index.html=0A>> =0A>>These are really crude and could be refined well wi th some effort. I painted =0A>>them and have left them in almost all the t ime for I guess 1.5 years now. They =0A>>don't interfere with the brakes b ut that's because I built them in such a way =0A>>that they wouldn't. They basically only touch the pedal surface...not anything =0A>>else.=0A>>I stil l have to pull them and drill some lightening holes some day, and maybe =0A >>fill some gaps with wood putty for cosmetics.=0A>>Tim=0A>>=0A>>On Jan 2, 2011, at 7:41 AM, "Alan Mekler" wrote:=0A>>Does any one make a rudder pedal extension? My wife is only 5 feet tall and can =99t =0A>>reach the pedals. I tried making a 4inch extension but it inte rfered with the =0A>>brakes.=0A>>>Alan=0A>>>N668G=0A>>> =0A>>> =0A>>> =0A=0A ============ ======================= =0Are f="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List================== ==================0A ums.matronics.com">h ttp://forums.matronics.com =0A=============== ==================== =0Ahttp://www. matronics.com/contribution">http://www.matronics.com/contribution=== ====================== =0A=0A =0A=0A ________________________________________________________________________________
Subject: Re: Dremel tool - recommendation - and anecdote
Date: Feb 22, 2011
I have the same one. I too have used it a bunch on the build, at work and around the house. Good for rivet shaving. It runs between 5-35,000 rpm. Last long enough for most small jobs. Charges back up quick. No cords to cut into like I did with my old one. But it still will cut into fingers if you desire some excitement. The 6" deburring wheel does a good job on fingers too as most of you know. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 43 Cabin Cover Read this topic online here: http://forums.matronics.com/viewtopic.php?p=331807#331807 ________________________________________________________________________________
Date: Feb 22, 2011
http://www.vansairforce.net/POH/N423CF_RV10.pdf Not my creationcreated by others, modified by me. I can get you an MS word version if you would like. My e-mail is.. Rene (at) Felker (dot) com Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Traville Houston Sent: Tuesday, February 22, 2011 4:23 AM Subject: Re: RV10-List: rudder pedal extensions DOES ANYONE HAVE A (POH) GENERIC GUIDE OR FORMAT FOR THE RV 10? _____ From: Alan Mekler MD <amekler(at)metrocast.net> Sent: Mon, February 21, 2011 1:44:08 PM Subject: Re: RV10-List: rudder pedal extensions Yes keeping the wife happy is important. Now I have to get her a seat cushion. Alan Sent from my iPhone On Feb 21, 2011, at 10:37 AM, Tim Olson wrote: Hi Alan, That basically looks like what I did but I did it in wood. I haven't yet lightened them but i think done right they could be made fairly light. Would be interesting to use carbon fiber but actually i think being a little heavier is probably a good thing to some extent...at least on the bottom half below the bar. Mine remove with two bolts in only a minute or so. No interference with anything. I've left them on for a year or more now. I plan to spiffy them up a bit soon, and lighten them a little and maybe add anti-skid tape to the bottom lip. They do make it work ok for the wife...so I'm happy. Tim On Feb 21, 2011, at 9:08 AM, "Alan Mekler" wrote: Tim, We made these out of =C2=BC inch Aluminum. They are pretty heavy. Lightened them up with holes. They extend about 4 inches. My wife couldn=99t keep het feet on the floor and move the pedals so we welded an extension on. No interference with the brakes. Working on a few modifications to allow easier mounting and better cosmetics but they work. Alan _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, January 02, 2011 9:13 AM Subject: Re: RV10-List: rudder pedal extensions http://www.myrv10.com/N104CD/upgrades/20090503/index.html These are really crude and could be refined well with some effort. I painted them and have left them in almost all the time for I guess 1.5 years now. They don't interfere with the brakes but that's because I built them in such a way that they wouldn't. They basically only touch the pedal surface...not anything else. I still have to pull them and drill some lightening holes some day, and maybe fill some gaps with wood putty for cosmetics. Tim On Jan 2, 2011, at 7:41 AM, "Alan Mekler" wrote: Does anyone make a rudder pedal extension? My wife is only 5 feet tall and can=99t reach the pedals. I tried making a 4inch extension but it interfered with the brakes. Alan N668G ========= ref="http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List%22%3ehttp://www.matronics.c om/Navigator?RV10-List> ">http://www.matronics.com/Navigator?RV10-List========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3ehttp:/www.matronics.com/contr ibution====================== ===> ">http://www.matronics.com/contribution============ ====================== http://www.matronics.com/con=============== ________________________________________________________________________________
Date: Feb 22, 2011
I still only have plug in models but love the new cut off wheel chuck and the new durable cutting wheels. > --> RV10-List message posted by: "rv10flyer" > > I have the same one. I too have used it a bunch on the build, at work and around the house. Good for rivet shaving. It runs between 5-35,000 rpm. Last long enough for most small jobs. Charges back up quick. No cords to cut into like I did with my old one. But it still will cut into fingers if you desire some excitement. The 6" deburring wheel does a good job on fingers too as most of you know. > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 > Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 43 Cabin Cover ________________________________________________________________________________
Date: Feb 22, 2011
Please be careful with the rudder pedal extensions. Last year the aerobatic community lost Vicky Cruise in an accident in the World Aerobatic Championships. The cause of the accident was attributed to the rudder pedal extensions that were attached to a borrowed airplane. They apparently came loose and jammed the rudder hard over, and she did not recover. I know that everyone installing rudder pedal extensions are going to make sure that there will be no interference ..... I'm only offering this as a reminder. Linn On 2/21/2011 10:37 AM, Tim Olson wrote: > Hi Alan, > That basically looks like what I did but I did it in wood. I haven't > yet lightened them but i think done right they could be made fairly > light. Would be interesting to use carbon fiber but actually i think > being a little heavier is probably a good thing to some extent...at > least on the bottom half below the bar. Mine remove with two bolts in > only a minute or so. No interference with anything. I've left them > on for a year or more now. I plan to spiffy them up a bit soon, and > lighten them a little and maybe add anti-skid tape to the bottom lip. > They do make it work ok for the wife...so I'm happy. > Tim > > > On Feb 21, 2011, at 9:08 AM, "Alan Mekler" > wrote: > >> Tim, >> >> We made these out of =C2=BC inch Aluminum. They are pretty heavy. >> Lightened them up with holes. They extend about 4 inches. My wife >> couldn=99t keep het feet on the floor and move the pedals so we welded >> an extension on. No interference with the brakes. Working on a few >> modifications to allow easier mounting and better cosmetics but they >> work. >> >> Alan >> >> ---------------------------------------------------------------------- -- >> >> *From:*owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson >> *Sent:* Sunday, January 02, 2011 9:13 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: RV10-List: rudder pedal extensions >> >> >> http://www.myrv10.com/N104CD/upgrades/20090503/index.html >> >> These are really crude and could be refined well with some effort. I >> painted them and have left them in almost all the time for I guess >> 1.5 years now. They don't interfere with the brakes but that's >> because I built them in such a way that they wouldn't. They basically >> only touch the pedal surface...not anything else. >> >> I still have to pull them and drill some lightening holes some day, >> and maybe fill some gaps with wood putty for cosmetics. >> >> Tim >> >> >> On Jan 2, 2011, at 7:41 AM, "Alan Mekler" > > wrote: >> >>> Does anyone make a rudder pedal extension? My wife is only 5 feet >>> tall and can=99t reach the pedals. I tried making a 4inch exten sion >>> but it interfered with the brakes. >>> >>> Alan >>> >>> N668G >>> >>> * * >>> * * >>> * * >> > * > =========== =========== =========== =========== > > * ________________________________________________________________________________
Subject: Re: Tailcone crack found per SB 08-6-1
Date: Feb 22, 2011
What I learned from this is you can strike the tail on landing. I did not think you could. I have landed with very high nose attitude before practicing short field approaches, but probably not with an aft CG. Great post, thanks. -Scott Sent from my iPad On Feb 16, 2011, at 4:19 PM, Ron Walker wrote: > >> How can I >> tell if the sb was complied with? What should I be looking for. > > Have a look at http://www.vansaircraft.com/pdf/sb08-6-1.pdf. That is the > specific bulletin - it details the change and how to spot it. > > FYI - for any service bulletins related to vans aircraft, you can find > them here -> http://www.vansaircraft.com/public/notices.htm. > > -ron > > > > > ________________________________________________________________________________
Date: Feb 22, 2011
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Governor control cable bracket
Date: Feb 22, 2011
I'm trying to figure out what to do for a governor bracket. I'm using a PCU5000 governor and James plenum. I purchased the bracket from Van's but it is clocked wrong (ether pointed at the cylinder or pointed straight down). How did others do this? Carl ________________________________________________________________________________
Date: Feb 22, 2011
Subject: Re: Governor control cable bracket
I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich wrote: > Im trying to figure out what to do for a governor bracket. Im using a > PCU5000 governor and James plenum. I purchased the bracket from Vans but > it is clocked wrong (ether pointed at the cylinder or pointed straight > down). > > > How did others do this? > > > Carl > > ________________________________________________________________________________
Date: Feb 22, 2011
Wayne, which wheel/bit are you using for rivet shaving? I have the equivalent corded model, with the long flex cable installed which makes it real nice for doing stuff like fiberglass and plexi trimming with cutoff wheel. On Tue, Feb 22, 2011 at 6:48 AM, rv10flyer wrote: > > I have the same one. I too have used it a bunch on the build, at work and around the house. Good for rivet shaving. It runs between 5-35,000 rpm. Last long enough for most small jobs. Charges back up quick. No cords to cut into like I did with my old one. But it still will cut into fingers if you desire some excitement. The 6" deburring wheel does a good job on fingers too as most of you know. > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 > Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 43 Cabin Cover > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=331807#331807 > > ________________________________________________________________________________
Date: Feb 22, 2011
Here's a link to a set of pictures that should be self explanatory: http://deemsrv10.com/album/Sec%20FF2%20Baffling%20and%20Plenum/slides/DSC04852.html Here's a link to some write ups that accompany the pics: http://deemsrv10.com/FF2logindex.html Deems On 2/22/2011 5:46 PM, Kelly McMullen wrote: > --> RV10-List message posted by: Kelly McMullen > > I think that is the exact combination Deems has on his tricked out Ten. > > On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich > wrote: >> Im trying to figure out what to do for a governor bracket. Im using a >> PCU5000 governor and James plenum. I purchased the bracket from Vans but >> it is clocked wrong (ether pointed at the cylinder or pointed straight >> down). >> >> >> >> How did others do this? >> >> >> >> Carl >> >> >> >> >> >> >> > > -- Deems Davis ________________________________________________________________________________
Date: Feb 22, 2011
Subject: Arizona vacation
Hi all - My wife and I are presently on vacation in Arizona, and will be in the Tucs on area Friday Feb 25 - Monday Feb 28th, and then in the Scotsdale area fro m Tue Mar 1 - Thur Mar 3. - If any RV10 builders have a couple of hours to show off their -10, please e mail me as I'd love to have a look and-a talk. - Regards, - Rick #40956 - Wings in progress Southampton, Ont -=0A=0A ________________________________________________________________________________
Subject: Re: Arizona vacation
Date: Feb 22, 2011
I am at FFZ; send a phone number to dlm34077at q.com ----- Original Message ----- From: Rick Lark To: RV10-list Sent: Tuesday, February 22, 2011 6:31 PM Subject: RV10-List: Arizona vacation Hi all My wife and I are presently on vacation in Arizona, and will be in the Tucson area Friday Feb 25 - Monday Feb 28th, and then in the Scotsdale area from Tue Mar 1 - Thur Mar 3. If any RV10 builders have a couple of hours to show off their -10, please email me as I'd love to have a look and a talk. Regards, Rick #40956 - Wings in progress Southampton, Ont ________________________________________________________________________________
Date: Feb 23, 2011
Hey dlm, are you in witness relocation program?- Never see a real name, j ust =0Adlm.=0A=0A=0A=0A=0A________________________________=0AFrom: DLM <dlm 34077(at)q.com>=0ATo: rv10-list(at)matronics.com=0ASent: Tue, February 22, 2011 9 :50:04 PM=0ASubject: Re: RV10-List: Arizona vacation=0A=0A=0AI am at FFZ; s end a phone number to dlm34077at q.com=0A----- Original Message ----- =0A>F rom: Rick Lark =0A>To: RV10-list =0A>Sent: Tuesday, February 22, 2011 6:31 PM=0A>Subject: RV10-List: Arizona vacation=0A>=0A>=0A>Hi all=0A>=0A>My wife and I are presently on vacation in Arizona, and will be in the Tucson =0A> area Friday Feb 25 - Monday Feb 28th, and then in the Scotsdale area from T ue =0A>Mar 1 - Thur Mar 3.=0A>=0A>If any RV10 builders have a couple of hou rs to show off their -10, please email =0A>me as I'd love to have a look an d-a talk.=0A>=0A>Regards,=0A>=0A>Rick=0A>#40956 - Wings in progress=0A>So uthampton, Ont=0A> =0A>=0A> =0A>href="http://www.matronics.com/Navigator ?RV10-List">http://www.matronics.com/Navigator?RV10-List=0A> href="http:/ /forums.matronics.com">http://forums.matronics.com =0A>href="http://www.m ======= =0A=0A=0A=0A ________________________________________________________________________________
Date: Feb 23, 2011
I was put in the witness protection program for building too many aircraft. ----- Original Message ----- From: Don McDonald To: rv10-list(at)matronics.com Sent: Wednesday, February 23, 2011 7:39 AM Subject: Re: RV10-List: Arizona vacation Hey dlm, are you in witness relocation program? Never see a real name, just dlm. ------------------------------------------------------------------------- ----- From: DLM <dlm34077(at)q.com> To: rv10-list(at)matronics.com Sent: Tue, February 22, 2011 9:50:04 PM Subject: Re: RV10-List: Arizona vacation I am at FFZ; send a phone number to dlm34077at q.com ----- Original Message ----- From: Rick Lark To: RV10-list Sent: Tuesday, February 22, 2011 6:31 PM Subject: RV10-List: Arizona vacation Hi all My wife and I are presently on vacation in Arizona, and will be in the Tucson area Friday Feb 25 - Monday Feb 28th, and then in the Scotsdale area from Tue Mar 1 - Thur Mar 3. If any RV10 builders have a couple of hours to show off their -10, please email me as I'd love to have a look and a talk. Regards, Rick #40956 - Wings in progress Southampton, Ont href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c or?RV10-List" rel=nofollow target=_blank>http://www.matronics.com/Navigtronics.com/" rel=nofollow target=_blank>http://forums.matronics.com ________________________________________________________________________________
Date: Feb 23, 2011
Thanks Deems - perfect. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Tuesday, February 22, 2011 8:15 PM Subject: Re: RV10-List: Governor control cable bracket Here's a link to a set of pictures that should be self explanatory: http://deemsrv10.com/album/Sec%20FF2%20Baffling%20and%20Plenum/slides/DSC048 52.html Here's a link to some write ups that accompany the pics: http://deemsrv10.com/FF2logindex.html Deems On 2/22/2011 5:46 PM, Kelly McMullen wrote: I think that is the exact combination Deems has on his tricked out Ten. On Tue, Feb 22, 2011 at 5:10 PM, Carl Froehlich wrote: I'm trying to figure out what to do for a governor bracket. I'm using a PCU5000 governor and James plenum. I purchased the bracket from Van's but it is clocked wrong (ether pointed at the cylinder or pointed straight down). How did others do this? Carl -- Deems Davis ________________________________________________________________________________
Subject: Wheel bolt info
Date: Feb 23, 2011
I'd appreciate it if one of the builders who has not yet put their wheels together would give me the AN bolt numbers off both main and nose wheels. Van's doesn't have it, nor does Cleveland have it in any of their manuals and won't answer the request. I need to stock some extras. Thanks - grumpy ________________________________________________________________________________
Subject: extra tanks
Date: Feb 23, 2011
For anyone who has added two additional tanks to the RV10 wings, please advise the approximate time/cost to do so. I am already aware of the engineering issues. thanks. I am considering buying tank parts from Van's and installing additional tanks outboard and interconnected with the existing tank system. ________________________________________________________________________________
Date: Feb 23, 2011
Subject: Re: Wheel bolt info
Well, the best I can give you is parts breakout in the Spruce catalog, pg 232, 5:00X5 Cleveland has either AN4-31A for most, or AN4-22A for the rest. For 6:00X6 it is most likely AN5-35A On 2/23/2011 8:00 PM, Miller John wrote: > --> RV10-List message posted by: Miller John > > I'd appreciate it if one of the builders who has not yet put their wheels together would give me the AN bolt numbers off both main and nose wheels. > > Van's doesn't have it, nor does Cleveland have it in any of their manuals and won't answer the request. > > I need to stock some extras. > > Thanks - grumpy > > ________________________________________________________________________________
January 30, 2011 - February 24, 2011
RV10-Archive.digest.vol-ia
