RV10-Archive.digest.vol-ic
March 20, 2011 - April 08, 2011
      -----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Leikam Sent: Saturday, March 19, 2011 10:39 PM
Subject: G900X
For those who are flying a G900X panel, How does the system calculate "TTL Time in Service?" I called Garmin and the guy I spoke with told me he would get and answer and call me back, two days ago. It is not from engine start to shut down. David Leikam RV10 40496 N89DA Flying ________________________________________________________________________________
Subject: Re: engine cables
Date: Mar 20, 2011
I ordered RV-7 throttle cable from Van's. The remaining two from ACS per Ivan's information. It took 9 weeks to get them, so order early! They cost twice as much. They appear to be a little better quality with a larger hole needed at cockpit bracket than Van's. Won't install them for another two to three months. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 45 Doors/Transparencies- 1228 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334535#334535 ________________________________________________________________________________
Subject: Doors and Sean Strasburg's kit
Date: Mar 20, 2011
Still working on doors. Yes, adding the windows and latch assy. does change the door fit. I'm sure the McMaster Carr seal will too. The doors seemed pretty stiff until adding more weight, then there is really alot of flexing at the door hinge attachments. Sean makes a good kit, definitely worth the money. I just wish I had one set of instructions to go by instead of going back and forth. The only thing I noticed so far that does not seem right is cutting the latch pins 1 3/4" past the "closed/extended position mark". This does not allow enough of the untapered pin to extend into jambs properly. I think I will leave 2" on the second door today. Then it is on to cutting/building up the cabin cover flange for the seal. How much compression do I really need on that door seal?? I was thinking maybe about 3/16" or half the bulb diameter to keep from putting so much tension on the door. I think I have about 1/16" clearance between flange and door at the top so that will really need some grinding and building up on the bottom side. Any advice is much appreciated! -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 45 Doors/Transparencies- 1228 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334538#334538 ________________________________________________________________________________
Date: Mar 20, 2011
Subject: G900X
Here is the clone site URL: http://airplanelogs.com/ Robin *From:* Robin Marks [mailto:Robin(at)PaintTheWeb.com] *Sent:* Sunday, March 20, 2011 10:27 AM *To:* rv10-list(at)matronics.com *Subject:* RE: RV10-List: G900X Gary & David, Another way to do that is during shutdown (on my system) the MFD is turned off but the PFD stays on. At that point it is just like revision mode. Follow the procedure listed below Engine > System to get your time. I have two other suggestions. Some time ago I mentioned to the RV List a free website called www.CirrusReports.com I record my flight data for every flight on the top MFD SD Card slot. About once every 4-6 flights I swap out the SD card for the backup SD card I carry in my flight bag camera case. Take the SD card to any computer, delete any small files that represent engine starts but not flights (they are obvious due to file size) and then upload the flight data to CR.com. The upload process is fast & easy. I uploaded 6 flights yesterday and it took probably 2 minutes. From there CR.com presents every single engine & flight parameter you can imagine including Geo-referenced map, and charts of every engine item with the option to display any 4 individual items at once so you can see for example Fuel Flow vs. CHT's. Speed vs. RPM. The combinations are enlightening. It also has a spread sheet function to give you Departure/Arrival times, Hobbs time, Flight time etc... In many ways it can substitute for your Log Book as far as accurate flight dates, hours, notes. You can choose to make your flight data public or keep it private. I have decided to make mine available to the public. http://www.cirrusreports.com/flights/N110EE/ Because it has this data it also has a simple export to Google Earth in both 3D view & Cockpit View. Here is a screen capture of the 3D view for a local flight I took back in August. Again this took less than 1 minute to produce: [image: Flight.JPG] Here is a close up (from the other side of the airport) of my departure & arrival on different runways plus the over flight of the airport. It even shows I taxied back to Self Serve Fuel. Very powerful! [image: flight2.JPG] Nice feature! Moving on I have one more suggestion. If you have not installed the latest version of the G900X OS. It has many small changes I have noticed. For example it has Ground Speed now displayed next to True Air Speed so I can eliminate the GS I normally had as an option on the MFD and can use that space for some other parameter like ETA. It has an updated Flight Planning system and displays including different flags that I still have no idea what they mean. It also has some really cool features like anytime you scroll over an airport or roll over one in the Flight Planner it gives you instant weather reporting vs. having to push a couple of additional page buttons and leave the map display to get updated field WX info. Very tidy info. I bring this up because I bet there is a better representation of times in the new OS. I just have not played with it enough to know the differences yet. Also if you want to make a stink about these times with Garmin one day they may just place the times in their own section on the appropriate status page some day as they should have from the start. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of gary Sent: Sunday, March 20, 2011 8:31 AM Subject: RE: RV10-List: G900X This is one of the dumb features on an otherwise great system. To get to time in service, press the red reversion button on the audio panel. Then on the PFD select the engine soft button and then in the lower left corner is the time in service. I think it calculates only flying time derived from ground speed trigger, but am not totally sure about that. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Leikam Sent: Saturday, March 19, 2011 10:39 PM Subject: RV10-List: G900X For those who are flying a G900X panel, How does the system calculate "TTL Time in Service?" I called Garmin and the guy I spoke with told me he would get and answer and call me back, two days ago. It is not from engine start to shut down. David Leikam RV10 40496 N89DA Flying ________________________________________________________________________________
Subject: Re: Doors and Sean Strasburg's kit
Date: Mar 20, 2011
Hey Wayne, Pin extension is totally up to the builder. I recommend 1-1/4+. The way Vans' plans have it you get just over an inch. The reason I suggest 1-3/4 on the 180 kit is to take advantage of the cam and to allow it to pull the door in before the pins come out of the door. Anything over an inch is better than the original design. When I initially built my doors I had my seal squeezed way too much and finally relieved it by making my door reveal 1/4 instead of 3/16. This is still really tight and the door shuts with minimal effort. McMaster seals come in both 3/16 and 1/4 edges so if you are too tight with a 1/4 inch lip you can do what I did and take off a 1/16 and make it 3/16 edge. This makes the reveal bigger, which in my case 1/4. Hope that made sense and I hope this helps. Anyone should call if you have any questions. 801-580-3737 -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334553#334553 ________________________________________________________________________________
Date: Mar 20, 2011
Subject: ribs/skins
Hi all - I have just started to do an initial fit of the fuel tank and leading edge ribs into the skins and found the ribs to be extremely difficult to seat in to the nose of the skins, at least to have the holes line up for the clecoe s.- - I have fluted and straightened the ribs, and still they appear to be far ti ghter than the vertical stab ever was.- Can't imagine throwing tank seala nt into the mix. - Any suggestions or words of advise???? - Rick #40956 Southampton, Ont=0A=0A ________________________________________________________________________________
Subject: Re: ribs/skins
Date: Mar 21, 2011
I was in the same situation as you a couple months ago. These do seem to be the tightest fitting ribs so far in the whole build. The easiest way I found to get them in is to start on the top side leading edges and just start a few clecoes in them. Then flip the skin/ribs over and work them into place adding a few clecoes on this side. Flip back over and add a few more. Do a few at a time on each side all the way to the trailing edge. I sealed my first tank a couple weekends ago and will do the second tank this weekend. They do start to fit a little easier when you get them drilled and dimpled, but still tighter than any other ribs yet. If you have a second or even a third set of hands helping when you seal it's much easier. I had two other guys helping me out when I did my first tank and I cannot even imagine doing it by myself--I know there are guys that have done it solo but extra hands is always better. Good luck, Bill From: Rick Lark Sent: Sunday, March 20, 2011 8:48 PM Subject: RV10-List: ribs/skins Hi all I have just started to do an initial fit of the fuel tank and leading edge ribs into the skins and found the ribs to be extremely difficult to seat into the nose of the skins, at least to have the holes line up for the clecoes. I have fluted and straightened the ribs, and still they appear to be far tighter than the vertical stab ever was. Can't imagine throwing tank sealant into the mix. Any suggestions or words of advise???? Rick #40956 Southampton, Ont ________________________________________________________________________________
From: "carl.froehlich(at)verizon.net" <carl.froehlich(at)verizon.net>
Date: Mar 21, 2011
QW5vdGhlciB0aGluZyB0byBkbyBpcyB0byB0cmltIHRoZSByaWIgbm9zZSBmbGFuZ2UgZWRnZXMu ICBUaGUgZmxhdCBmbGFuZ2VzIG5lZWQgaGVscCB0byBjb25mb3JtIHRvIHRoZSByb3VuZCBub3Nl IHNraW4uCgpTbmlwIG9mZiB0aGUgZmxhbmdlIGNvcm5lciB0aGVuIHNtb290aCB3aXRoIGEgQSBz Y290Y2ggQnJpZ2h0IHdoZWVsIGluIGEgYWlyIGdyaW5kZXIuCgpUb28gbXVjaCBmb3JjZSBmaXQg d2lsbCBkZWZvcm0gdGhlIHNraW4uCgpDYXJsClJWLThBICg2MjUgaG91cnMpClJWLTEwIChnZWFy IGxlZyBmYWlyaW5ncykKClNlbnQgZnJvbSBteSBtb2JpbGUgcGhvbmUuwqDCoCBQbGVhc2UgcmVh ZCBwYXN0IHRoZSB0eXBvcy4KCi0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tCkZyb206IEJpbGx5 ICYgVGFtaSBCcml0dG9uIDx3aWxsaWFtQGdidGEubmV0PgpUbzogcnYxMC1saXN0QG1hdHJvbmlj cy5jb20KU2VudDogTW9uLCBNYXIgMjEsIDIwMTEgMDU6NDg6MzMgR01UKzAwOjAwClN1YmplY3Q6 IFJlOiBSVjEwLUxpc3Q6IHJpYnMvc2tpbnMKCkkgd2FzIGluIHRoZSBzYW1lIHNpdHVhdGlvbiBh cyB5b3UgYSBjb3VwbGUgbW9udGhzIGFnby4gIFRoZXNlIGRvIHNlZW0gdG8gYmUgdGhlIHRpZ2h0 ZXN0IGZpdHRpbmcgcmlicyBzbyBmYXIgaW4gdGhlIHdob2xlIGJ1aWxkLiAgVGhlIGVhc2llc3Qg d2F5IEkgZm91bmQgdG8gZ2V0IHRoZW0gaW4gaXMgdG8gc3RhcnQgb24gdGhlIHRvcCBzaWRlIGxl YWRpbmcgZWRnZXMgYW5kIGp1c3Qgc3RhcnQgYSBmZXcgY2xlY29lcyBpbiB0aGVtLiAgVGhlbiBm bGlwIHRoZSBza2luL3JpYnMgb3ZlciBhbmQgd29yayB0aGVtIGludG8gcGxhY2UgYWRkaW5nIGEg ZmV3IGNsZWNvZXMgb24gdGhpcyBzaWRlLiAgRmxpcCBiYWNrIG92ZXIgYW5kIGFkZCBhIGZldyBt b3JlLiAgRG8gYSBmZXcgYXQgYSB0aW1lIG9uIGVhY2ggc2lkZSBhbGwgdGhlIHdheSB0byB0aGUg dHJhaWxpbmcgZWRnZS4gIEkgc2VhbGVkIG15IGZpcnN0IHRhbmsgYSBjb3VwbGUgd2Vla2VuZHMg YWdvIGFuZCB3aWxsIGRvIHRoZSBzZWNvbmQgdGFuayB0aGlzIHdlZWtlbmQuICBUaGV5IGRvIHN0 YXJ0IHRvIGZpdCBhIGxpdHRsZSBlYXNpZXIgd2hlbiB5b3UgZ2V0IHRoZW0gZHJpbGxlZCBhbmQg ZGltcGxlZCwgYnV0IHN0aWxsIHRpZ2h0ZXIgdGhhbiBhbnkgb3RoZXIgcmlicyB5ZXQuICBJZiB5 b3UgaGF2ZSBhIHNlY29uZCBvciBldmVuIGEgdGhpcmQgc2V0IG9mIGhhbmRzIGhlbHBpbmcgd2hl biB5b3Ugc2VhbCBpdCdzIG11Y2ggZWFzaWVyLiAgSSBoYWQgdHdvIG90aGVyIGd1eXMgaGVscGlu ZyBtZSBvdXQgd2hlbiBJIGRpZCBteSBmaXJzdCB0YW5rIGFuZCBJIGNhbm5vdCBldmVuIGltYWdp bmUgZG9pbmcgaXQgYnkgbXlzZWxmLS1JIGtub3cgdGhlcmUgYXJlIGd1eXMgdGhhdCBoYXZlIGRv bmUgaXQgc29sbyBidXQgZXh0cmEgaGFuZHMgaXMgYWx3YXlzIGJldHRlci4KCkdvb2QgbHVjaywK QmlsbAoKCgoKRnJvbTogUmljayBMYXJrIApTZW50OiBTdW5kYXksIE1hcmNoIDIwLCAyMDExIDg6 NDggUE0KVG86IFJWMTAtbGlzdCAKU3ViamVjdDogUlYxMC1MaXN0OiByaWJzL3NraW5zCgoKICAg ICAgSGkgYWxsCgogICAgICBJIGhhdmUganVzdCBzdGFydGVkIHRvIGRvIGFuIGluaXRpYWwgZml0 IG9mIHRoZSBmdWVsIHRhbmsgYW5kIGxlYWRpbmcgZWRnZSByaWJzIGludG8gdGhlIHNraW5zIGFu ZCBmb3VuZCB0aGUgcmlicyB0byBiZSBleHRyZW1lbHkgZGlmZmljdWx0IHRvIHNlYXQgaW50byB0 aGUgbm9zZSBvZiB0aGUgc2tpbnMsIGF0IGxlYXN0IHRvIGhhdmUgdGhlIGhvbGVzIGxpbmUgdXAg Zm9yIHRoZSBjbGVjb2VzLiAgCgogICAgICBJIGhhdmUgZmx1dGVkIGFuZCBzdHJhaWdodGVuZWQg dGhlIHJpYnMsIGFuZCBzdGlsbCB0aGV5IGFwcGVhciB0byBiZSBmYXIgdGlnaHRlciB0aGFuIHRo ZSB2ZXJ0aWNhbCBzdGFiIGV2ZXIgd2FzLiAgQ2FuJ3QgaW1hZ2luZSB0aHJvd2luZyB0YW5rIHNl YWxhbnQgaW50byB0aGUgbWl4LgoKICAgICAgQW55IHN1Z2dlc3Rpb25zIG9yIHdvcmRzIG9mIGFk dmlzZT8/Pz8KCiAgICAgIFJpY2sKICAgICAgIzQwOTU2CiAgICAgIFNvdXRoYW1wdG9uLCBPbnQg CgoKCgoKCg= ________________________________________________________________________________
Subject: GPS Interference Update
Date: Mar 21, 2011
I saw the following on my morning read file: The Air Force is studying the equipment that a commercial telecommunications company wants to introduce across the United States because of its likely interference with the Global Positioning System signal, Gen. William Shelton, Air Force Space Command boss, told House lawmakers last week. The company, LightSquared of Reston, Va., seeks to erect <http://r.listpilot.net/c/afa/64mkv5p/2lu0z> up to 40,000 towers mostly in US urban centers for a new 4G broadband network. "We believe from what we have seen thus far that virtually every GPS receiver out there would be affected," said Shelton. He continued, "What we're looking for now from the company is actual hardware that they plan to use so that we can collect empirical data as opposed to analytical data." This technical analysis is due for delivery to the Federal Communications Commission-which is mulling whether to grant the company an operating license-"by the June timeframe," said Shelton. He noted that the company shifted its business model from a "largely a space-based effort with terrestrial augmentation," to "a terrestrial-based network with space augmentation." Deputy Defense Secretary Bill Lynn recently wrote FCC Chairman Julius Genachowski "strongly" recommending that the commission defer final action until the analysis is completed. (Lynn letter <http://r.listpilot.net/c/afa/64mkv5p/2lu10> ) Regards, Jerry Folkerts ________________________________________________________________________________
Date: Mar 21, 2011
Thanks for the reply Sean. I ended up cutting other door at 1 1/2" then cutting new angle, then threading. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 45 Doors/Transparencies- 1228 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334583#334583 ________________________________________________________________________________
Subject: O-540
Date: Mar 21, 2011
Question about the engine mount that comes with the finish kit. The engine mount ears on the O-540 can be one of two part numbers: 70456 12A19770 It appears that the difference is the size of the engine mount bolt thru holes in them. The 70456 part is for all O-540 models *except* A1A5 and A1D5, those two use the other part. Will either of these work with the finish kit ? Is it just a matter of using a different size bolt with different engine/cushion/isolator mounts ? Or is this going to be a problem with the actual engine mount provided with the vans finish kit ? Thanks Ron ________________________________________________________________________________
Subject: O-540
Date: Mar 21, 2011
The RV-10 mount requires the small hole mounts. If you are ordering a new engine, then yours will have the small mounts. If you are using a rebuilt engine or a mid-time engine, there is a chance that it could come with the large hole mounts. I think some of the -C4B5 engines on Aztecs used the large mounts. You can pick up the small hole mounts used serviceable (just make sure they are inspected) or new surplus. Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ronald Walker Sent: Monday, March 21, 2011 8:09 AM Subject: RV10-List: O-540 Question about the engine mount that comes with the finish kit. The engine mount ears on the O-540 can be one of two part numbers: 70456 12A19770 It appears that the difference is the size of the engine mount bolt thru holes in them. The 70456 part is for all O-540 models *except* A1A5 and A1D5, those two use the other part. Will either of these work with the finish kit ? Is it just a matter of using a different size bolt with different engine/cushion/isolator mounts ? Or is this going to be a problem with the actual engine mount provided with the vans finish kit ? Thanks Ron ________________________________________________________________________________
Subject: Re: O-540
Date: Mar 21, 2011
No, I tried making the large-hole mounts work- they won't because they have a different dynafocal angle. Use the small hole mounts (70456) and hardware as Van's uses and save time/ money. Sent from my iPhone On Mar 21, 2011, at 8:08 AM, Ronald Walker wrote: > > Question about the engine mount that comes with the finish kit. > > The engine mount ears on the O-540 can be one of two part numbers: > > 70456 > 12A19770 > > It appears that the difference is the size of the engine mount bolt thru > holes in them. The 70456 part is for all O-540 models *except* A1A5 and > A1D5, those two use the other part. > > Will either of these work with the finish kit ? Is it just a matter of > using a different size bolt with different engine/cushion/isolator > mounts ? Or is this going to be a problem with the actual engine mount > provided with the vans finish kit ? > > Thanks > > Ron > > > > > ________________________________________________________________________________
Subject: Re: O-540
Date: Mar 21, 2011
> Use the small hole mounts (70456) Thanks Kevin and Rhonda -- My confusion stemmed from the O-540 parts catalog saying that the A1D5 has the 12A19770 mounts - that's the model number that is stamped on my engine plate. (From an Aztec.) The good news is that the part number that I just read off of the ears is 70456. No action required on my part. Build on. -Ron ________________________________________________________________________________
Subject: finish kit windows released
Date: Mar 21, 2011
Following up to advise that Cee Baileys released the side windows. I don=99t have them, but I know they are like the the windscreen- plug and glue. No cutting required. Same price as Vans. http://www.vansaircrafttires.com/categories/RV%252d10/Airframe-Parts/ My disclaimer remains- I gain nothing as I already have my windows installed but the quality of their products are very good and I believe those behind me can greatly benefit from these options. I should also state that I have gone to Cee Baileys and asked that they expand their inventory of parts for builders, there workmanship truly is first rate. I have requested they think about doing carbon fiber doors- that fit/ require minor adjustments. No idea if they will pursue it, but if they do I would encourage builders to go that route as anything they put out will far exceed anything you=99ll get in the kit and the price will be probably the same if history is any indication. Pascal ________________________________________________________________________________
Date: Mar 21, 2011
Subject: Re: O-540
Aero instock carries nice new machined mounts also. Reasonably priced. http://www.aeroinstock.com/products/APS-70456/6202/47458/product_detail/index.html David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Rhonda Bewley" <Rhonda(at)bpaengines.com> Sent: Monday, March 21, 2011 9:37:45 AM Subject: RE: RV10-List: O-540 The RV-10 mount requires the small hole mounts. If you are ordering a new engine, then yours will have the small mounts. If you are using a rebuilt engine or a mid-time engine, there is a chance that it could come with the large hole mounts. I think some of the -C4B5 engines on Aztecs used the large mounts. You can pick up the small hole mounts used serviceable (just make sure they are inspected) or new surplus. Rhonda -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ronald Walker Sent: Monday, March 21, 2011 8:09 AM Subject: RV10-List: O-540 Question about the engine mount that comes with the finish kit. The engine mount ears on the O-540 can be one of two part numbers: 70456 12A19770 It appears that the difference is the size of the engine mount bolt thru holes in them. The 70456 part is for all O-540 models *except* A1A5 and A1D5, those two use the other part. Will either of these work with the finish kit ? Is it just a matter of using a different size bolt with different engine/cushion/isolator mounts ? Or is this going to be a problem with the actual engine mount provided with the vans finish kit ? Thanks Ron ________________________________________________________________________________
Date: Mar 21, 2011
Subject: WingX 7 for iPad
Well, I was checking updates last night for my iPad2, and ran across WingX 7 Pro being updated to version 5. It has now solidified its place as my favorite in-flight app for the ipad. Foreflight is still my favorite for weather, but, WingX 7 just blew it out of the water for in-flight use. I don't have time for a full write-up but got excited so I posted pics here: http://www.myrv10.com/tips/IFR/WingX/R1/ Note that everything is geo-referenced, and now they even add features like integration with ADS-B for weather, so you can even take and hook it up to NavWorX and get weather in cockpit on your iPad. There are just too many features to list here, so check out the screenshots I took and read through the New Feature List part. I fired it up and it was really zippy on the iPad2, also, so I'm going to give it a good run-through on my next trip. -- Tim Olson - RV-10 N104CD ________________________________________________________________________________
Date: Mar 21, 2011
Tim, To be clear since the HiltonSoftware site is not; you pay $99.00/year for the WingX Pro 7 plus another $75.00 for the Seattle Avionics chart data subscription. And you pay $149 for ForeFlight HD Pro that includes the Seattle Avionics chart data subscription? Does that sound right? Oh... I have a lifetime subscription to Seattle Avionics but for PC Tablets that I have never used. Thanks, Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, March 21, 2011 12:16 PM Subject: RV10-List: WingX 7 for iPad Well, I was checking updates last night for my iPad2, and ran across WingX 7 Pro being updated to version 5. It has now solidified its place as my favorite in-flight app for the ipad. Foreflight is still my favorite for weather, but, WingX 7 just blew it out of the water for in-flight use. I don't have time for a full write-up but got excited so I posted pics here: http://www.myrv10.com/tips/IFR/WingX/R1/ Note that everything is geo-referenced, and now they even add features like integration with ADS-B for weather, so you can even take and hook it up to NavWorX and get weather in cockpit on your iPad. There are just too many features to list here, so check out the screenshots I took and read through the New Feature List part. I fired it up and it was really zippy on the iPad2, also, so I'm going to give it a good run-through on my next trip. -- Tim Olson - RV-10 N104CD ________________________________________________________________________________
Date: Mar 22, 2011
Subject: Re: WingX 7 for iPad
I believe that is right. Foreflight is something like $79/yr for the standard version, and $149 for the HD Pro version that gives the Seattle Avionics Geo-referencing. WingX is $99/yr for their software, plus $75/yr for Seattle Avionics geo-referencing. Also, on WingX, you can optionally buy the fuel pricing from 100LL.com for I think $29. Personally, I paid something like $299 on a special, for the Seattle Avionics data subscription for the "lifetime" benefit again. It's used on a handful of apps (not Foreflight, which ticked me off a bit), so it's semi-portable. I thought at the time the SA data was $99, but now I see it's $75. Now, keep in mind that for both versions, paying that extra $75 ONLY gives you the benefit of geo-referenced approach plates, for the most part...I'm pretty sure that's the case on Foreflight, and I think it's true for WingX too. So, you can still view regular approach plates without paying that extra charge, for someone who wants to try it out without breaking the bank. All it does is put your airplane on the approach plate so you know exactly where you are. Some people will care, some won't. For non-IFR pilots, I wouldn't even bother. The fuel pricing is nicer on WingX. On Foreflight, you get great fuel pricing included but only when you have internet access. On WingX, you download the database and it's on the iPad when you fly. So for me, that's a huge benefit, because I often will reroute in-flight for various reasons and that allows me to quickly pick lower priced fuel stops...and I can easily pay for $29 in ONE fuel stop. In fact, you can save enough if you fly a couple big trips a year that you can pay for the entire APP! When it comes to the apps themselves, Foreflight really kicks butt when it comes to weather, and they were doing great with sectionals and low-enroute charts and things like that. But, WingX really blew them out of the water on the in-flight functionality, especially with this new release. Just the way the main map screen is put together, it makes it very easy to transition from screen to screen. You can load a plan, fly it, and hit buttons like "approach" that will automatically bring up the destination approach plate. So it's very handy. I haven't flown with this latest release, so I'm hoping it's just as straight forward, but it looks like it will be. The terrain enhanced sectionals and stuff are pretty nice, too. To be straightforward, I should tell you that my Foreflight subscription recently turned non-standard. I had just renewed and paid $125/yr, which was the plan for covering 2 iPhones and 1 iPad, when Andrea got her iPhone and we switched to Verizon. So I thought I was all set, at $125/yr. But then a couple days later they released the HD version. I emailed them a little ticked off because I wanted to at least TRY HD for a year, knowing the WingX really looked better in flight (i.e. I would recommend WingX as an in-flight app rather than pay extra for foreflight HD, but I still would recommend Foreflight standard for pre-flight), but I thought, since I, on my own dime, like to try these apps and tell y'all about them, it would be stupid for me not to try the HD version. But, to upgrade my plan, they then wanted something like $250 or some huge number like that, which as you can see is double the $125 I had paid a couple days ago. So, they did a custom upgrade for me so I could use it for a year on one iPhone and iPad and still have Andrea's phone on the account....so I didn't have to pay all the way up to $250 but some price I don't remember, that's in between. If it weren't for the wife's phone, pricing would be simpler. That brings up one other big big difference.... With Foreflight, you can load the software on all your iDevices...but you can only sign in on one iPhone, and one iPad, with the subscription (the standard one). So for me and Andrea, you have to start doing special things/plans, to cover both our phones. She just likes Foreflight for the WX, as it's just so awesome for that. Now that we have an iPad 2, I wanted to put it on both iPads so I could choose which one I used in-flight. Well, I can only have ONE of them signed in at a time. The issue for me is, I have a jailbroken old iPad that works great with my Bluetooth GPS. iOS 4.3 isn't jailbroken yet, so the iPad 2 I'm forced to use the GPS that's built-in, unless I buy the plug-in one. I know others like the plug-in one, but I think it sucks to have one more thing to plug in during flight, especially if you can bang it and damage the port or the device. Bluetooth GPS is really ideal. (The other one that's wi-fi wouldn't be so bad) But I also already own 3 of those bluetooth GPS's, so I want it that way. So this means that on our next trip, I have to figure out which iPad I want to use, and stick with it until I can sign in/out again, and give the other one to the kids for movies. Not a huge deal, but, it just shows that each iPad isn't equal. I'll probably use the iPad 2 on the way down, just to see how the GPS works. If it doesn't work great, I'll get fuel and swap the sign-in. Now, with WingX, as long as the devices are on the same iTunes account, I have WingX Pro 7 on BOTH iPads, and it works simultaneously, without signing in and out. So, if you are planning to play with it on multiple devices, that's a benefit too. You can have a "backup ipad" that way, ready to go. So see, I'm not totally burned, because since WingX is really the best in-flight app right now, and it works on both, it's what I'm probably going to be using anyway. WingX on the iPhone though, is much less useful. I don't even use it, really. Right now, today, I consider it worthless compared to Foreflight. So if you're an iPhone user, stick to only Foreflight. See, that's where it gets so complicated...one app is better on one platform and one on the other....at least with foreflight, you get free usage on an iPad too....so we can have awesome weather planning at the hotel using foreflight. Now, on to your last thing....Yes, as you know, I too have a lifetime Voyager (Seattle Avionics) data subscription at the EFB level. So, personally, I wasn't thrilled to spend all the money on these other apps. But, I'm a geek, so I did. Hopefully it helps others out a bit. Right now, Voyager is fairly useless to me, simply due to the hardware. I use it for planning trips from my PC, but with WingX as far as it is, it's basically not worth me bringing the old LE1600 into the cockpit anymore. The battery life sucks compared to iPad. Using a stylus sucks compared to iPad. The display is less bright than iPad. (See the attached .jpgs...3 is the iPad, 6 is the LE1600 WITH the viewanywhere display) (Note, the ipad has a Brando Anti-Glare protector on it!) The weight of LE1600 is much more than iPad. The charger is many times bulkier and heavier than iPad. The LE1600 sucks as a movie platform, iPad rocks. The list is endless. So, there isn't much place for Voyager right now for me, as long as they aren't on iPad. There is ONE exception. I reviewed the capabilities on this trip to Mexico. WingX is USELESS in Mexico. No charts, no database that includes Mexican airports. Probably not canada either...so Alaska fliers may not like it for flying up through Canada. Foreflight actually has the airports in the database, but no sectional view available, and I think the only map that shows up requires internet access to see the map, and doesn't display the airports in Mexico. So at least Foreflight can plan distances and give you headings and things to save your butt. Voyager, however, has not only the database, but displays airways in canada, and gives you airports and terrain. If I remember right from playing with it a couple weeks ago, it looks like you can use Voyager to fly in Mexico and Canada without too much issue. So, on my mexico trip, I do plan to lug that freakin' tablet along, just hoping not to use it too much. The iPad can load (using goodreader is how I did it) the government provided CH-22 WAC chart that covers mexico though, in .tif form....so, I actually was able to use iPad to view the WAC and that will work just fine...it won't give you any GPS stuff, or put you on the map, but you can at least not carry a paper chart. I have emailed the folks at Seattle Avionics and expressed my displeasure with them not getting an iPad app going fast enough. It sounds like they have been very busy (obviously), getting their DATA into all the other apps that they could. They are really our only hope against Jeppesen, for reasonably priced NavData, so I'm glad that they are so ingrained into all these apps. In the past, they have told me that if/when they do an iPad app, your lifetime subscription will be applicable to that app. That is a big relief. They also told me I should expect to see some really cool news around Sun-N-Fun (i'm hoping it's true), and that I'll see even BIGGER news around OSH. So, perhaps by late summer we'll have something else that will come in and take the place on my iPad of Foreflight and WingX, or at least one of them. Also, regarding voyager, they told me that they just started a NEW PROGRAM for iPad folks, where if you've bought an iPad subscription for any of their partners programs, then they'll discount a year of Voyager subscription 50%, so VFR that's $99 is only $49, for instance, and VFR+IFR that's $199 is only $99, and EFB at $299 is only $149. They're doing this to provide some relief in the interim until they have something else in place to offer. Wow, that went on far longer than I thought it would. Guess I better start actual work work now. :) At any rate, I love these apps, all 3 of them, for various reasons. Ideally they'd all be available in one platform (iPad) and you wouldn't need any other platform. If any of them could do on iPad what Voyager does on PC, I wouldn't even USE a PC for anything flight planning related anymore...I'd only use an iPad. Presently though, I like to PC plan on Voyager, Weather plan (and file) on Foreflight, and then actually fly, with WingX (in the US 50). Sadly, that costs some money, but, with lifetime subscriptions in place, the annual cost could be as low as $75+$129 (Foreflight standard + WingX with fuel, free Voyager with my lifetime). That's pretty cheap compared to the truckload of cash I have to pay Jepp for their NavData on my 2 systems in the plane....and the above software is even easier to keep current. Tim Olson - RV-10 N104CD On 3/21/2011 8:57 PM, Robin Marks wrote: > --> RV10-List message posted by: Robin Marks > > Tim, > To be clear since the HiltonSoftware site is not; you pay > $99.00/year for the WingX Pro 7 plus another $75.00 for the Seattle > Avionics chart data subscription. And you pay $149 for ForeFlight HD Pro > that includes the Seattle Avionics chart data subscription? Does that > sound right? > Oh... I have a lifetime subscription to Seattle Avionics but for > PC Tablets that I have never used. > > Thanks, > Robin > ________________________________________________________________________________
Date: Mar 22, 2011
Subject: Re: Canopy Skirt Buzz...
At 10:25 AM 3/22/2011 Tuesday, you wrote: >Matt, >Did you settle on a material that you preferred for deadening the canopy buzz [on your RV-8]? We are experiencing the same thing but at a very narrow speed range. Before we reinvent the wheel I figured I would ask. > >Thanks, >Robin Hi Robin, Yes, solved mostly. Here the stuff to get: http://cshyde.thomasnet.com/viewitems/tapes-with-psa/uhmw-tape--black-anti-stat-rubber-adhesive?forward=1 This is black UHMW table with a rubber adhesive (good to 150F). I got the .020" stuff. Its not very bendable sideways, so don't try to get the .5" kind and wrap it around the s-curve in the back. It definitely won't stick for very long. Get the 6" wide stuff - Part number <http://cshyde.thomasnet.com/viewitems/tapes-with-psa//item/tapes-with-psa/uhmw-tape--black-anti-stat-rubber-adhesive/anti-stat-uhmw-19-20blk-6-5?>19-20BLK-6-5 (5 yards) or 19-20BLK-6-18 (18 yards) - and lay it flat over the skirt on the inside and then trace the contour. Move it up by about .75" and then trace again. Then cut out the piece which should be a perfect fit around the inside edge of the canopy skirt. I forgot to take any pictures of the process! That's so not like me! :-) I also used the .5" stuff (<http://cshyde.thomasnet.com/viewitems/tapes-with-psa//item/tapes-with-psa/uhmw-tape--black-anti-stat-rubber-adhesive/anti-stat-uhmw-19-20blk-5-5?>19-20BLK-.5-5) for along the straight left and right side of the skirt. Although, I wish I'd used the .75 stuff. Seems to dampen the vibration and also doesn't mark the paint/metal due to its low co-efficient of friction. Its basically the same stuff that Van's sells for the flaps, but much thicker and black. I also like the high-temp rubber adhesive. We'll see how it holds up over the Summer. My only complaint is that I wish they made a .040" thick version. - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 153+ Hours TTSN - Paint Job Is All That's Left To Do... ________________________________________________________________________________
Date: Mar 22, 2011
Subject: Re: RV-8 Insurance...
Here's this year's Insurance Quotes along with the coverage details on my RV-8. Can you guess which one I went with? $1m/$100k Liability $5000-$10000 Medical $0 Deductible $150k Hull Ground/Air 153 Hours, Aircraft 153 Hours in Type, Pilot 450 Hours Total, Pilot 242 Hours TW, Pilot Avemco: $5811 EAA/Falcon: $2975 ($3075 last year included Test & 1st 10 hours) NationAir/Chartis $2888 AOPA/AIG $2475 - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left To Do... ________________________________________________________________________________
Date: Mar 22, 2011
Matt, we are in a similiar position.... I have more hours in the RV10, but less =0Atotal hours.- Did you have a contact with AOPA/AIG?=0AIIRC I'm pa ying a little less than $1,800, but have no hull insurance while =0Amoving. =0AThanks, Don McDonald=0A=0A=0A=0A=0A________________________________=0AFr om: Matt Dralle =0ATo: rv-list(at)matronics.com; rv8-lis t(at)matronics.com; rv7-list(at)matronics.com; =0Arv10-list(at)matronics.com=0ASent: Tue, March 22, 2011 4:56:15 PM=0ASubject: RV10-List: Re: RV-8 Insurance... =0A=0AHere's this year's Insurance Quotes along with the coverage details o n my RV-8.- =0ACan you guess which one I went with?=0A=0A$1m/$100k Liabil ity=0A$5000-$10000 Medical=0A$0 Deductible=0A$150k Hull Ground/Air=0A=0A153 Hours, Aircraft=0A153 Hours in Type, Pilot=0A450 Hours Total, Pilot=0A242 Hours TW, Pilot=0A=0A- - - - Avemco:- - - - - - - - $5811=0A- - - - EAA/Falcon:- - - - - - $2975 ($3075 la st year included Test & 1st 10 =0Ahours)=0A- - - - NationAir/Charti s- - - $2888=0A- - - - AOPA/AIG- - - - - - - - $2475=0A=0A=0A-=0AMatt Dralle=0ARV-8 #82880 N998RV=0Ahttp://www.mattsrv 8.com - Matt's RV-8 Construction Log=0Ahttp://www.youtube.com/MattsRV8 - Ma tt's RV-8 HDTV YouTube Channel=0AStatus: 160+ Hours TTSN - Paint Job Is All ======================0A=0A ________________________________________________________________________________
Date: Mar 22, 2011
The AOPA agent I worked with was Clint Dayhuff clint.dayhuff(at)aopaia.com Very nice guy. Got me a quote back in 1.5 days. Retained over the phone. Matt At 06:30 PM 3/22/2011 Tuesday, you wrote: >Matt, we are in a similiar position.... I have more hours in the RV10, but less total hours. Did you have a contact with AOPA/AIG? >IIRC I'm paying a little less than $1,800, but have no hull insurance while moving. >Thanks, Don McDonald > > >From: Matt Dralle <dralle(at)matronics.com> >To: rv-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com; rv10-list(at)matronics.com >Sent: Tue, March 22, 2011 4:56:15 PM >Subject: RV10-List: Re: RV-8 Insurance... > > >Here's this year's Insurance Quotes along with the coverage details on my RV-8. Can you guess which one I went with? > >$1m/$100k Liability >$5000-$10000 Medical >$0 Deductible >$150k Hull Ground/Air > >153 Hours, Aircraft >153 Hours in Type, Pilot >450 Hours Total, Pilot >242 Hours TW, Pilot > > Avemco: $5811 > EAA/Falcon: $2975 ($3075 last year included Test & 1st 10 hours) > NationAir/Chartis $2888 > AOPA/AIG $2475 > > >- >Matt Dralle >RV-8 #82880 N998RV ><http://www.mattsrv8.com/>http://www.mattsrv8.com - Matt's RV-8 Construction Log ><http://www.youtube.com/MattsRV8>http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel >Status: 160+ Hours TTSN - Paint Job Is All That's Left To Do... > ________________________________________________________________________________
Date: Mar 23, 2011
Subject: Optimal cowl intake and outlet areas for engine cooling air
Hi, Can any of the engineers out there please advise whether there is an optimal ratio of the cowl inlet to outlet areas for engine air cooling? Thanking you all in anticipation, Rodger In Oz where cooling matters ________________________________________________________________________________
Date: Mar 23, 2011
Subject: QB Kit Primer
Hi, Can anyone please advise what chemicals will remove, by accident or design, the Sherwin Williams wash primer that Vans use on the QB kits? Clearly the acids will but what about MEK etc? Thanking you in anticipation, Rodger In Oz the land of sun and salt. ________________________________________________________________________________
Subject: Re: RE: RV7-List: Re: RV-8 Insurance...
Date: Mar 23, 2011
Good Grief, I paid half that on $100,000 RV-7. I have the same amount of hours in type and total. I suggest you contact my agent and ask her for a quote: klehman(at)andreini.com Direct 650-378-4310 No harm in at least asking. Dave Henderson RV-7 N925LW (Lord Willing) -----Original Message----- From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Tuesday, March 22, 2011 5:56 PM rv10-list(at)matronics.com Subject: RV7-List: Re: RV-8 Insurance... --> RV7-List message posted by: Matt Dralle Here's this year's Insurance Quotes along with the coverage details on my RV-8. Can you guess which one I went with? $1m/$100k Liability $5000-$10000 Medical $0 Deductible $150k Hull Ground/Air 153 Hours, Aircraft 153 Hours in Type, Pilot 450 Hours Total, Pilot 242 Hours TW, Pilot Avemco: $5811 EAA/Falcon: $2975 ($3075 last year included Test & 1st 10 hours) NationAir/Chartis $2888 AOPA/AIG $2475 - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left To Do... ________________________________________________________________________________
Date: Mar 23, 2011
For those with quadrants: Per Dave Saylor: I replaced the stock cables with 47" for the prop, 51" for mixture and 72" for the prop. I got the cables from a local cablecraft distributor. Also, ask for the highest temp rating you can get. The green cables from Vans aren't the best. A set of replacement cables should be $200 or less. The vendor is California Push-Pull in Chico, CA. Talk to Frank. http://www.push-pull.com/ 176-VTT-2-51 176-VTT-2-47 176-VTT-2-72 These are for the mixture, throttle and prop respectively. Ask for Frank if you need a live person. He knows what they're going on. The cable tags will say "not for use on aircraft", which usually means they know you're using it on an aircraft ----- Hope this helps! bob -------- Bob Leffler N410BL - FWF RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334767#334767 ________________________________________________________________________________
Date: Mar 23, 2011
I was wondering if vans changed cable lengths before my serial number. I had no issues using the supplied cables with my Aerosport lower console and throttle quadrant. Kit number 40936. Sent from my iPhone On Mar 23, 2011, at 8:42, "rleffler" wrote: > > For those with quadrants: > > Per Dave Saylor: > > I replaced the stock cables with 47" for the prop, 51" for mixture and 72" > for the prop. I got the cables from a local cablecraft distributor. Also, > ask for the highest temp rating you can get. The green cables from Vans > aren't the best. A set of replacement cables should be $200 or less. > > > The vendor is California Push-Pull in Chico, CA. Talk to Frank. > > http://www.push-pull.com/ > > 176-VTT-2-51 > 176-VTT-2-47 > 176-VTT-2-72 > > These are for the mixture, throttle and prop respectively. > > Ask for Frank if you need a live person. He knows what they're going on. > > The cable tags will say "not for use on aircraft", which usually means they know you're using it on an aircraft > > ----- > > Hope this helps! > > bob > > -------- > Bob Leffler > N410BL - FWF > RV-10 #40684 > http://mykitlog.com/rleffler > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334767#334767 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 23, 2011
Subject: Re: Optimal cowl intake and outlet areas for engine cooling
air Considering the work that was done to develop the SamJames cowl and plenum...and how well they work - I think they're a great starting place. -----Original Message----- >From: Rodger Todd <rj_todd(at)yahoo.co.uk> >Sent: Mar 23, 2011 7:42 AM >To: RV10-List(at)matronics.com >Subject: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > > >Hi, > >Can any of the engineers out there please advise whether there is an optimal ratio of the cowl inlet to outlet areas for engine air cooling? > >Thanking you all in anticipation, > >Rodger >In Oz where cooling matters > > > > > ________________________________________________________________________________
Date: Mar 23, 2011
air Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air Ahhhh.. as one of the first -10 James cowl flying owners with lots of negative experiences associated with that cowl & plenum I strongly suggest that is about the worst starting place possible. As usual the factory desig n while not as sexy is functional and proven. I think it=92s been established that the openings on the James cowl are just too small to properly cool the Lycoming 540 engine. There has been some success (I am not totally up to date) by increasing the inlet ring size from 4.5=94 to 6=94 but that is a l ot of work. Imagine taking a new cowl and cutting the inlets back to then manuall y make transitions to new 6=94 inlets. Then modify the Plenum to match. Plan on significant R&D right when you want to be flying your plane. I don=92t even want to go into the James Plenum that is misaligned from the factory as if they had NOOOO idea how wide their cowl inlets would be to mate to the plenum. The plenum doesn=92t even comply with known design principals of smooth but ever increasing volume as the cooling air moves aft. Having owne d 4 RV=92s, 2 with stock cowls & baffles & 2 with plenums & James cowls I fin d the plenums to be a large pain in the ass. Extra weight & complexity. Reduced access with limited definable benefit. Additionally forget about flying LOP out of the box with the James set up. While the stock cowl seems to not be an issue the James owners have a difficult time seeming to straddle a razors edge of LOP vs. poor engine performance even after exhaustive injector balancing and adding an expensiv e (and heavy) turbo rails & fuel injector shrouds. Showplanes is making a valiant effort with a new cowl for the -10 that is great looking. Unfortunately it=92s still a little early to that party as t hey do not have a production unit available for sale. I personally will be removing my James cowl or making additional major modifications to the unit within the next 12 months. If you are building to fly head my warning. Robin Marks RV-4 Sold RV-6A Sold RV-10 220 Hours RV-8A 4 Hours *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Ralph E. Capen *Sent:* Wednesday, March 23, 2011 9:27 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air Considering the work that was done to develop the SamJames cowl and plenum...and how well they work - I think they're a great starting place. -----Original Message----- >From: Rodger Todd <rj_todd(at)yahoo.co.uk> >Sent: Mar 23, 2011 7:42 AM >To: RV10-List(at)matronics.com >Subject: RV10-List: Optimal cowl intake and outlet areas for engine coolin g air > > >Hi, > >Can any of the engineers out there please advise whether there is an optimal ratio of the cowl inlet to outlet areas for engine air cooling? > >Thanking you all in anticipation, > >Rodger >In Oz where cooling matters > > ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 23, 2011
Were your lengths the same as the ones I listed from Dave Saylor? I've got to order mine, but I'm planning on taking some measurements this weekend. I've got the aerosport panel / throttle quadrant too, but my fm-200 is in a non-standard location to accommodate the rod bower ram air mod. Its horizontal, not vertical. It may need a couple extra inches. Bob Sent from my iPhone On Mar 23, 2011, at 11:01 AM, Seano wrote: > > I was wondering if vans changed cable lengths before my serial number. I had no issues using the supplied cables with my Aerosport lower console and throttle quadrant. Kit number 40936. > > Sent from my iPhone > > On Mar 23, 2011, at 8:42, "rleffler" wrote: > >> >> For those with quadrants: >> >> Per Dave Saylor: >> >> I replaced the stock cables with 47" for the prop, 51" for mixture and 72" >> for the prop. I got the cables from a local cablecraft distributor. Also, >> ask for the highest temp rating you can get. The green cables from Vans >> aren't the best. A set of replacement cables should be $200 or less. >> >> >> The vendor is California Push-Pull in Chico, CA. Talk to Frank. >> >> http://www.push-pull.com/ >> >> 176-VTT-2-51 >> 176-VTT-2-47 >> 176-VTT-2-72 >> >> These are for the mixture, throttle and prop respectively. >> >> Ask for Frank if you need a live person. He knows what they're going on. >> >> The cable tags will say "not for use on aircraft", which usually means they know you're using it on an aircraft >> >> ----- >> >> Hope this helps! >> >> bob >> >> -------- >> Bob Leffler >> N410BL - FWF >> RV-10 #40684 >> http://mykitlog.com/rleffler >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=334767#334767 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
air
Date: Mar 23, 2011
Dear Rodger, I has been a few years, but if I recall correctly, then the factor is right around 1.5 (I think?) for the hot expanding air to exhaust properly, when compared to the denser cold air coming in. I agree with Ralph, as Sam James's cowling and plenum systems are very efficient in that respect, by tightly controlling the cooling airflow and not wasting any air molecules for unnecessary drag. Konrad On Mar 23, 2011, at 10:27 AM, Ralph E. Capen wrote: > > > > Considering the work that was done to develop the SamJames cowl and > plenum...and how well they work - I think they're a great starting > place. > > > -----Original Message----- >> From: Rodger Todd <rj_todd(at)yahoo.co.uk> >> Sent: Mar 23, 2011 7:42 AM >> To: RV10-List(at)matronics.com >> Subject: RV10-List: Optimal cowl intake and outlet areas for engine >> cooling air >> >> >> Hi, >> >> Can any of the engineers out there please advise whether there is >> an optimal ratio of the cowl inlet to outlet areas for engine air >> cooling? >> >> Thanking you all in anticipation, >> >> Rodger >> In Oz where cooling matters >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 23, 2011
air I'll take Robin's explanation as an education since my actual experience is with a 6A - my bad as I thought they did the same GT / NASA testing on the -10 cowl. I would really like to see the 'new' RV10 cowl as I am contemplating a four-place..... Thanks, Ralph -----Original Message----- >From: Robin Marks <robin(at)PaintTheWeb.com> >Sent: Mar 23, 2011 1:30 PM >To: rv10-list(at)matronics.com >Subject: RE: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > >Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > >Ahhhh.. as one of the first -10 James cowl flying owners with lots of >negative experiences associated with that cowl & plenum I strongly suggest >that is about the worst starting place possible. As usual the factory design >while not as sexy is functional and proven. I think its been established >that the openings on the James cowl are just too small to properly cool the >Lycoming 540 engine. There has been some success (I am not totally up to >date) by increasing the inlet ring size from 4.5 to 6 but that is a lot of >work. Imagine taking a new cowl and cutting the inlets back to then manually >make transitions to new 6 inlets. Then modify the Plenum to match. Plan on >significant R&D right when you want to be flying your plane. I dont even >want to go into the James Plenum that is misaligned from the factory as if >they had NOOOO idea how wide their cowl inlets would be to mate to the >plenum. The plenum doesnt even comply with known design principals of >smooth but ever increasing volume as the cooling air moves aft. Having owned >4 RVs, 2 with stock cowls & baffles & 2 with plenums & James cowls I find >the plenums to be a large pain in the ass. Extra weight & complexity. >Reduced access with limited definable benefit. > >Additionally forget about flying LOP out of the box with the James set up. >While the stock cowl seems to not be an issue the James owners have a >difficult time seeming to straddle a razors edge of LOP vs. poor engine >performance even after exhaustive injector balancing and adding an expensive >(and heavy) turbo rails & fuel injector shrouds. > >Showplanes is making a valiant effort with a new cowl for the -10 that is >great looking. Unfortunately its still a little early to that party as they >do not have a production unit available for sale. > >I personally will be removing my James cowl or making additional major >modifications to the unit within the next 12 months. If you are building to >fly head my warning. > > >Robin Marks > >RV-4 Sold > >RV-6A Sold > >RV-10 220 Hours > >RV-8A 4 Hours > > >*From:* owner-rv10-list-server(at)matronics.com [mailto: >owner-rv10-list-server(at)matronics.com] *On Behalf Of *Ralph E. Capen >*Sent:* Wednesday, March 23, 2011 9:27 AM >*To:* rv10-list(at)matronics.com >*Subject:* Re: RV10-List: Optimal cowl intake and outlet areas for engine >cooling air > > >Considering the work that was done to develop the SamJames cowl and >plenum...and how well they work - I think they're a great starting place. > > >-----Original Message----- >>From: Rodger Todd <rj_todd(at)yahoo.co.uk> >>Sent: Mar 23, 2011 7:42 AM >>To: RV10-List(at)matronics.com >>Subject: RV10-List: Optimal cowl intake and outlet areas for engine cooling >air >> >> >>Hi, >> >>Can any of the engineers out there please advise whether there is an >optimal ratio of the cowl inlet to outlet areas for engine air cooling? >> >>Thanking you all in anticipation, >> >>Rodger >>In Oz where cooling matters >> >> >> >> >> >> >> >> > > >------------------------------ > >No virus found in this message. >Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 23, 2011
air SW50ZXJlc3Rpbmcgbm90ZS4KCkknbSBqdXN0IGZpbmlzaGluZyB0aGUgcHJldHR5IHdvcmsgb24g YSBTYW0gSmFtZXMgY293bCBhbmQgcGxlbnVtLiAgTXkgZmluZGluZ3MgdG8gZGF0ZToKLSBUaGUg Y293bCBmaXR0aW5nIHdhcyBubyBoYXJkZXIgdGhhbiB0aGUgY293bCBvbiBteSA4QS4KLSBJIG5v dGVkIHRoZSBwcm9ibGVtIHlvdSBoYWQgb24gdGhlIHBsZW51bSBub3QgbGluaW5nIHVwIHdpdGgg dGhlIGNvd2wgaW5sZXQgcmluZ3MuICBQZXJoYXBzIHRoaXMgd2FzIGZpeGVkIGFzIG15IGNvd2wg YW5kIHBsZW51bSBsaW5lZCB1cCB3ZWxsLgotIEkgYWxzbyBub3RlZCB0aGUgY29vbGluZyBpc3N1 ZXMgeW91IHJlcG9ydGVkIGFuZCB3YXMgd29ycmllZC4gIEkgZGlkIHNvbWUgbWVhc3VyZW1lbnQg Y29tcGFyaXNvbnMgYmV0d2VlbiB0aGUgSmFtZXMgQ293bCBhbmQgdGhlIHN0b2NrIFZhbidzIGNv d2wgYW5kIHdoaWxlIHRoZSBpbmxldCBhcmVhcyBhcmUgc2ltaWxpYXIsIHRoZSBKYW1lcyBjb3ds IGV4aGF1c3QgYXJlYSBpcyBtdWNoIGxhcmdlciAoc2FtZSB3aWR0aCBidXQgYWJvdXQgYW4gaW5j aCBsb3dlci4gIEFnYWluIHBlcmhhcHMgdGhpcyB3YXMgYSBjaGFuZ2UgZnJvbSB5b3UgY293bC4K CkknbSBzaXggbW9udGhzIGF3YXkgZnJvbSBmbHlpbmcgc28gbm8gcmVhbCBvcGVyYXRpbmcgZGF0 YSBsaWtlIHlvdXJzLgoKQ2FybAoKClNlbnQgZnJvbSBteSBtb2JpbGUgcGhvbmUuwqDCoCBQbGVh c2UgcmVhZCBwYXN0IHRoZSB0eXBvcy4KCi0tLS0tT3JpZ2luYWwgbWVzc2FnZS0tLS0tCkZyb206 IFJvYmluIE1hcmtzIDxyb2JpbkBQYWludFRoZVdlYi5jb20+ClRvOiBydjEwLWxpc3RAbWF0cm9u aWNzLmNvbQpTZW50OiBXZWQsIE1hciAyMywgMjAxMSAxNzozMDoxMyBHTVQrMDA6MDAKU3ViamVj dDogUkU6IFJWMTAtTGlzdDogT3B0aW1hbCBjb3dsIGludGFrZSBhbmQgb3V0bGV0IGFyZWFzIGZv ciBlbmdpbmUgY29vbGluZyBhaXIKClJlOiBSVjEwLUxpc3Q6IE9wdGltYWwgY293bCBpbnRha2Ug YW5kIG91dGxldCBhcmVhcyBmb3IgZW5naW5lIGNvb2xpbmcgYWlyCgpBaGhoaC4uIGFzIG9uZSBv ZiB0aGUgZmlyc3QgLTEwIEphbWVzIGNvd2wgZmx5aW5nIG93bmVycyB3aXRoIGxvdHMgb2YKbmVn YXRpdmUgZXhwZXJpZW5jZXMgYXNzb2NpYXRlZCB3aXRoIHRoYXQgY293bCAmIHBsZW51bSBJIHN0 cm9uZ2x5IHN1Z2dlc3QKdGhhdCBpcyBhYm91dCB0aGUgd29yc3Qgc3RhcnRpbmcgcGxhY2UgcG9z c2libGUuIEFzIHVzdWFsIHRoZSBmYWN0b3J5IGRlc2lnbgp3aGlsZSBub3QgYXMgc2V4eSBpcyBm dW5jdGlvbmFsIGFuZCBwcm92ZW4uIEkgdGhpbmsgaXTigJlzIGJlZW4gZXN0YWJsaXNoZWQKdGhh dCB0aGUgb3BlbmluZ3Mgb24gdGhlIEphbWVzIGNvd2wgYXJlIGp1c3QgdG9vIHNtYWxsIHRvIHBy b3Blcmx5IGNvb2wgdGhlCkx5Y29taW5nIDU0MCBlbmdpbmUuIFRoZXJlIGhhcyBiZWVuIHNvbWUg c3VjY2VzcyAoSSBhbSBub3QgdG90YWxseSB1cCB0bwpkYXRlKSBieSBpbmNyZWFzaW5nIHRoZSBp bmxldCByaW5nIHNpemUgZnJvbSA0LjXigJ0gdG8gNuKAnSBidXQgdGhhdCBpcyBhIGxvdCBvZgp3 b3JrLiBJbWFnaW5lIHRha2luZyBhIG5ldyBjb3dsIGFuZCBjdXR0aW5nIHRoZSBpbmxldHMgYmFj ayB0byB0aGVuIG1hbnVhbGx5Cm1ha2UgdHJhbnNpdGlvbnMgdG8gbmV3IDbigJ0gaW5sZXRzLiBU aGVuIG1vZGlmeSB0aGUgUGxlbnVtIHRvIG1hdGNoLiBQbGFuIG9uCnNpZ25pZmljYW50IFImRCBy aWdodCB3aGVuIHlvdSB3YW50IHRvIGJlIGZseWluZyB5b3VyIHBsYW5lLiBJIGRvbuKAmXQgZXZl bgp3YW50IHRvIGdvIGludG8gdGhlIEphbWVzIFBsZW51bSB0aGF0IGlzIG1pc2FsaWduZWQgZnJv bSB0aGUgZmFjdG9yeSBhcyBpZgp0aGV5IGhhZCBOT09PTyBpZGVhIGhvdyB3aWRlIHRoZWlyIGNv d2wgaW5sZXRzIHdvdWxkIGJlIHRvIG1hdGUgdG8gdGhlCnBsZW51bS4gVGhlIHBsZW51bSBkb2Vz buKAmXQgZXZlbiBjb21wbHkgd2l0aCBrbm93biBkZXNpZ24gcHJpbmNpcGFscyBvZgpzbW9vdGgg YnV0IGV2ZXIgaW5jcmVhc2luZyB2b2x1bWUgYXMgdGhlIGNvb2xpbmcgYWlyIG1vdmVzIGFmdC4g SGF2aW5nIG93bmVkCjQgUlbigJlzLCAyIHdpdGggc3RvY2sgY293bHMgJiBiYWZmbGVzICYgMiB3 aXRoIHBsZW51bXMgJiBKYW1lcyBjb3dscyBJIGZpbmQKdGhlIHBsZW51bXMgdG8gYmUgYSBsYXJn ZSBwYWluIGluIHRoZSBhc3MuIEV4dHJhIHdlaWdodCAmIGNvbXBsZXhpdHkuClJlZHVjZWQgYWNj ZXNzIHdpdGggbGltaXRlZCBkZWZpbmFibGUgYmVuZWZpdC4KCkFkZGl0aW9uYWxseSBmb3JnZXQg YWJvdXQgZmx5aW5nIExPUCBvdXQgb2YgdGhlIGJveCB3aXRoIHRoZSBKYW1lcyBzZXQgdXAuCldo aWxlIHRoZSBzdG9jayBjb3dsIHNlZW1zIHRvIG5vdCBiZSBhbiBpc3N1ZSB0aGUgSmFtZXMgb3du ZXJzIGhhdmUgYQpkaWZmaWN1bHQgdGltZSBzZWVtaW5nIHRvIHN0cmFkZGxlIGEgcmF6b3JzIGVk Z2Ugb2YgTE9QIHZzLiBwb29yIGVuZ2luZQpwZXJmb3JtYW5jZSBldmVuIGFmdGVyIGV4aGF1c3Rp dmUgaW5qZWN0b3IgYmFsYW5jaW5nIGFuZCBhZGRpbmcgYW4gZXhwZW5zaXZlCihhbmQgaGVhdnkp IHR1cmJvIHJhaWxzICYgZnVlbCBpbmplY3RvciBzaHJvdWRzLgoKU2hvd3BsYW5lcyBpcyBtYWtp bmcgYSB2YWxpYW50IGVmZm9ydCB3aXRoIGEgbmV3IGNvd2wgZm9yIHRoZSAtMTAgdGhhdCBpcwpn cmVhdCBsb29raW5nLiBVbmZvcnR1bmF0ZWx5IGl04oCZcyBzdGlsbCBhIGxpdHRsZSBlYXJseSB0 byB0aGF0IHBhcnR5IGFzIHRoZXkKZG8gbm90IGhhdmUgYSBwcm9kdWN0aW9uIHVuaXQgYXZhaWxh YmxlIGZvciBzYWxlLgoKSSBwZXJzb25hbGx5IHdpbGwgYmUgcmVtb3ZpbmcgbXkgSmFtZXMgY293 bCBvciBtYWtpbmcgYWRkaXRpb25hbCBtYWpvcgptb2RpZmljYXRpb25zIHRvIHRoZSB1bml0IHdp dGhpbiB0aGUgbmV4dCAxMiBtb250aHMuIElmIHlvdSBhcmUgYnVpbGRpbmcgdG8KZmx5IGhlYWQg bXkgd2FybmluZy4KCgoKUm9iaW4gTWFya3MKClJWLTQgICAgICAgICAgICAgICAgU29sZAoKUlYt NkEgICAgICAgICAgICAgU29sZAoKUlYtMTAgICAgICAgICAgICAgIDIyMCBIb3VycwoKUlYtOEEg ICAgICAgICAgICAgNCBIb3VycwoKCgoqRnJvbToqIG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0 cm9uaWNzLmNvbSBbbWFpbHRvOgpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21d ICpPbiBCZWhhbGYgT2YgKlJhbHBoIEUuIENhcGVuCipTZW50OiogV2VkbmVzZGF5LCBNYXJjaCAy MywgMjAxMSA5OjI3IEFNCipUbzoqIHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tCipTdWJqZWN0Oiog UmU6IFJWMTAtTGlzdDogT3B0aW1hbCBjb3dsIGludGFrZSBhbmQgb3V0bGV0IGFyZWFzIGZvciBl bmdpbmUKY29vbGluZyBhaXIKCgoKLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIlJh bHBoIEUuIENhcGVuIiA8cmVjYXBlbkBlYXJ0aGxpbmsubmV0PgoKQ29uc2lkZXJpbmcgdGhlIHdv cmsgdGhhdCB3YXMgZG9uZSB0byBkZXZlbG9wIHRoZSBTYW1KYW1lcyBjb3dsIGFuZApwbGVudW0u Li5hbmQgaG93IHdlbGwgdGhleSB3b3JrIC0gSSB0aGluayB0aGV5J3JlIGEgZ3JlYXQgc3RhcnRp bmcgcGxhY2UuCgoKLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0tLS0KPkZyb206IFJvZGdlciBUb2Rk IDxyal90b2RkQHlhaG9vLmNvLnVrPgo+U2VudDogTWFyIDIzLCAyMDExIDc6NDIgQU0KPlRvOiBS VjEwLUxpc3RAbWF0cm9uaWNzLmNvbQo+U3ViamVjdDogUlYxMC1MaXN0OiBPcHRpbWFsIGNvd2wg aW50YWtlIGFuZCBvdXRsZXQgYXJlYXMgZm9yIGVuZ2luZSBjb29saW5nCmFpcgo+Cj4tLT4gUlYx MC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBSb2RnZXIgVG9kZCA8cmpfdG9kZEB5YWhvby5jby51 az4KPgo+SGksCj4KPkNhbiBhbnkgb2YgdGhlIGVuZ2luZWVycyBvdXQgdGhlcmUgcGxlYXNlIGFk dmlzZSB3aGV0aGVyIHRoZXJlIGlzIGFuCm9wdGltYWwgcmF0aW8gb2YgdGhlIGNvd2wgaW5sZXQg dG8gb3V0bGV0IGFyZWFzIGZvciBlbmdpbmUgYWlyIGNvb2xpbmc/Cj4KPlRoYW5raW5nIHlvdSBh bGwgaW4gYW50aWNpcGF0aW9uLAo+Cj5Sb2RnZXIKPkluIE96IHdoZXJlIGNvb2xpbmcgbWF0dGVy cwo+Cj4KPgo+Cj4KPgo+Cj4KCgoKCgoKLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tCgpO byB2aXJ1cyBmb3VuZCBpbiB0aGlzIG1lc3NhZ2UuCkNoZWNrZWQgYnkgQVZHIC0gd3d3LmF2Zy5j b20KCg= ________________________________________________________________________________
Date: Mar 23, 2011
air As one who drank the Koolaid, I would beg to disagree, IMO the Sam James cowl intake area is WAY UNDERSIZED, I believe this has been substantiated by another -10 builder who did some considerable modifications to increase the size of the intake for the SJ cowl/plenum and saw improved cooling performance. If you think about it, it stands to reason, James uses the same size intake rings for the 6 cyl as he does for the 4 cyl ????? Yet there is considerable more area to cool an more heat generated. The cowls look sexy, but I cannot attribute ANY improvement to speed/performance. However, by way of comparison there is a Reduction in the cooling. Deems N519PJ On 3/23/2011 9:27 AM, Ralph E. Capen wrote: > --> RV10-List message posted by: "Ralph E. Capen" > > Considering the work that was done to develop the SamJames cowl and plenum...and how well they work - I think they're a great starting place. > > > -----Original Message----- >> From: Rodger Todd<rj_todd(at)yahoo.co.uk> >> Sent: Mar 23, 2011 7:42 AM >> To: RV10-List(at)matronics.com >> Subject: RV10-List: Optimal cowl intake and outlet areas for engine cooling air >> >> --> RV10-List message posted by: Rodger Todd >> >> Hi, >> >> Can any of the engineers out there please advise whether there is an optimal ratio of the cowl inlet to outlet areas for engine air cooling? >> >> Thanking you all in anticipation, >> >> Rodger >> In Oz where cooling matters >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 23, 2011
Subject: PS Engineering unveils audio panel + remote com radio
Here's a picture of it: http://www.ps-engineering.com/PAR100EX.shtml PS Engineering announced this new product this week. Cut and pasting from the company's website: Another Revolution in Audio Panels PAR100EX Brings Com Radio to your Finger Tips! PS Engineering takes communications in a new direction - OUT of the cockpit! Reno, Nevada. For over a quarter century, PS Engineering, Inc.R has been known as a premier innovator of intercommunications for crew and passengers. Today, the company is adding a new dimension to their communications vision, a 760-channel, VHF communication radio fully integrated with the audio control panel. The PAR100EX system combines an audio control panel, audiophile stereo intercom with IntelliVoxR, BluetoothR connectivity, and a remote mounted VHF aviation communications transceiver. Never before has there been so much communication capability controlled with such a small footprint. "For years, people have been asking us, "Why doesn't PS Engineering make radios?" explained company founder Mark Scheuer, "because we are so deeply focused exploiting every type of audio technology available, developing a radio would only be a distraction. But now that we have a great core of audio technologies, it is time to invest into radio technology. After all, since 1972 when I received my Amateur Radio license, I have always been fascinated with radio, now it's time to put it into our company's product line." PS Engineering, Inc. is always looking for ways to improve flying and delight their fans, so they partnered with radio expert Microair and integrated an important piece of avionics, with an advanced audio panel system. By working with an established radio manufacturer, PS Engineering's customers will benefit from their individual talents. This system will save cockpit space, weight, provide the most sought after functionality, and save money over the stand-alone independent systems. "Microair is excited about partnering with PS Engineering," said Microair's President, Phil Ainsworth, "We are looking forward to getting into more airplanes with the PAR100EX, and the combination of our expertise will change the way experimental and LSA aircraft avionics panels will be created." The PAR100EX's low price makes it attractive for the Experimental and Light Sport aviation market (the unit will be FCC approved but not hold FAA Approval for airplanes certified under standard airworthiness), and the elimination of one panel mounted radio saves panel space. According to the Senior Design Engineer, Eduardo Lopez-Gil, "Seamless integration between the audio panel and the radio was the primary goal in this integration, for the best user experience possible, with minimal panel space. The KISS principle was practiced all during the development of the audio panel." The right half of the PAR100EX is dedicated to the comm. radio, with an easy to read LCD display that shows the frequencies, which are controlled through a concentric knob. This radio has active and standby frequencies, and a standby frequency monitor mode. The left half has all of the audio panel controls for radio selection, intercom and music volume, intercom mode, and PS Engineering's multiple music mute mode control. The functions of the PAR100EX are electrically independent, including the power supply, so even in fail safe on the audio panel, the VHF radio can still be used. The PAR100EX can be configured as stand alone, as COM 2, or as COM 1. The system can be a primary VHF Com, and the second radio could be a tactical or business radio, ideal for ALE, game management, fish spotters, etc. An integrated BluetoothR system allows the PAR100EX to interface with cellular telephones, giving the aircraft occupants ready access to their telephones. In addition, the BluetoothR will stream music from compatible devices like iPads, and smart phones. The list price of the PAR100EX, including the VHF com radio is $2,595, and deliveries will start in the second quarter of 2011. About Microair Pty Ltd: Microair remains committed to producing cost effective products. We feel that with the technologies available today, the price of modern avionics should come down. We listen to pilots, to understand their needs and situation. This feedback influences our designs for future products. We mean it when we say "designed by pilots for pilots." Microair Avionics Pty Ltd * P.O Box 5532, Bundaberg * West QLD 4670 Australia Phone International +61 7 41553048 *Fax International +61 7 41553049 www.microair.com.au About PS Engineering: Founded in 1985, PS Engineering has become a leading manufacturer of general aviation intercoms and audio control systems. The company's sole corporate focus is excellence in the design and manufacture of avionics systems for General Aviation Aircraft. PS Engineering Inc. R is credited for many innovations in the field, including IntelliVoxR, SoftmuteT, Karaoke ModeT, Split modeT, Swap ModeT, and the IRST(Internal Recording System). With a network of over 600 authorized dealer/installers worldwide, the company is a leader in retrofit avionics as well as a supplier to other major avionics manufacturers for their audio panel requirements. www.ps-engineering.com FOR MORE INFORMATION CONTACT: Gary Picou PS Engineering, Inc. 9800 Martel Road Lenoir City, TN 37772 Phone (865) 988-9800 - FAX (865) 988-6619 E-mail: gpicou@ps-engineering.com ________________________________________________________________________________
Date: Mar 23, 2011
Subject: Re: PS Engineering unveils audio panel + remote com radio
That is a nice way to go in a tight RV8 panel. PAR100EX a 530W :-) and a transponder. Done. Sent from my iPad2. On Mar 23, 2011, at 5:18 PM, Kelly McMullen wrote: > > Here's a picture of it: > > http://www.ps-engineering.com/PAR100EX.shtml > > > PS Engineering announced this new product this week. Cut and pasting from > the company's website: > > Another Revolution in Audio Panels PAR100EX Brings Com Radio to your Finger > Tips! > > PS Engineering takes communications in a new direction - OUT of the cockpit! > > Reno, Nevada. For over a quarter century, PS Engineering, Inc.R has been > known as a premier innovator of intercommunications for crew and passengers. > > Today, the company is adding a new dimension to their communications vision, > a 760-channel, VHF communication radio fully integrated with the audio > control panel. > > The PAR100EX system combines an audio control panel, audiophile stereo > intercom with IntelliVoxR, BluetoothR connectivity, and a remote mounted VHF > aviation communications transceiver. Never before has there been so much > communication capability controlled with such a small footprint. > > "For years, people have been asking us, "Why doesn't PS Engineering make > radios?" explained company founder Mark Scheuer, "because we are so deeply > focused exploiting every type of audio technology available, developing a > radio would only be a distraction. But now that we have a great core of > audio technologies, it is time to invest into radio technology. After all, > since 1972 when I received my Amateur Radio license, I have always been > fascinated with radio, now it's time to put it into our company's product > line." > > PS Engineering, Inc. is always looking for ways to improve flying and > delight their fans, so they partnered with radio expert Microair and > integrated an important piece of avionics, with an advanced audio panel > system. By working with an established radio manufacturer, PS Engineering's > customers will benefit from their individual talents. This system will save > cockpit space, weight, provide the most sought after functionality, and save > money over the stand-alone independent systems. > > "Microair is excited about partnering with PS Engineering," said Microair's > President, Phil Ainsworth, "We are looking forward to getting into more > airplanes with the PAR100EX, and the combination of our expertise will > change the way experimental and LSA aircraft avionics panels will be > created." The PAR100EX's low price makes it attractive for the Experimental > and Light Sport aviation market (the unit will be FCC approved but not hold > FAA Approval for airplanes certified under standard airworthiness), and the > elimination of one panel mounted radio saves panel space. > > According to the Senior Design Engineer, Eduardo Lopez-Gil, "Seamless > integration between the audio panel and the radio was the primary goal in > this integration, for the best user experience possible, with minimal panel > space. The KISS principle was practiced all during the development of the > audio panel." The right half of the PAR100EX is dedicated to the comm. > radio, with an easy to read LCD display that shows the frequencies, which > are controlled through a concentric knob. This radio has active and standby > frequencies, and a standby frequency monitor mode. > > The left half has all of the audio panel controls for radio selection, > intercom and music volume, intercom mode, and PS Engineering's multiple > music mute mode control. The functions of the PAR100EX are electrically > independent, including the power supply, so even in fail safe on the audio > panel, the VHF radio can still be used. > > The PAR100EX can be configured as stand alone, as COM 2, or as COM 1. The > system can be a primary VHF Com, and the second radio could be a tactical or > business radio, ideal for ALE, game management, fish spotters, etc. > > An integrated BluetoothR system allows the PAR100EX to interface with > cellular telephones, giving the aircraft occupants ready access to their > telephones. In addition, the BluetoothR will stream music from compatible > devices like iPads, and smart phones. > > The list price of the PAR100EX, including the VHF com radio is $2,595, and > deliveries will start in the second quarter of 2011. > > About Microair Pty Ltd: Microair remains committed to producing cost > effective products. We feel that with the technologies available today, the > price of modern avionics should come down. We listen to pilots, to > understand their needs and situation. This feedback influences our designs > for future products. We mean it when we say "designed by pilots for pilots." > > Microair Avionics Pty Ltd * P.O Box 5532, Bundaberg * West QLD 4670 > Australia Phone International +61 7 41553048 *Fax International +61 7 > 41553049 www.microair.com.au > > About PS Engineering: Founded in 1985, PS Engineering has become a leading > manufacturer of general aviation intercoms and audio control systems. The > company's sole corporate focus is excellence in the design and manufacture > of avionics systems for General Aviation Aircraft. PS Engineering Inc. R is > credited for many innovations in the field, including IntelliVoxR, > SoftmuteT, Karaoke ModeT, Split modeT, Swap ModeT, and the IRST(Internal > Recording System). With a network of over 600 authorized dealer/installers > worldwide, the company is a leader in retrofit avionics as well as a > supplier to other major avionics manufacturers for their audio panel > requirements. www.ps-engineering.com > > FOR MORE INFORMATION CONTACT: > Gary Picou > PS Engineering, Inc. > 9800 Martel Road > Lenoir City, TN 37772 > Phone (865) 988-9800 - FAX (865) 988-6619 > E-mail: gpicou@ps-engineering.com > > ________________________________________________________________________________
Date: Mar 23, 2011
Just to follow up on the insurance information I posted, I got an email from EAA/Falcon this morning indicating that they had quoted this year's policy based on last year's flight time numbers (basically 0). They re-quoted on my current hours (153 TTSN) and their quote came more into line at $2490.00. I just wanted to set the record straight. Also, the AOPA coverage for $2475 is really with USAIG (United States Aviation Insurance Group), which is not the bailout "AIG" (American International Group). At least I don't think so. Here are their respective web sites: United Status Aviation Insurance Group http://www.usau.com/usau.nsf/doc/index American International Group http://www.aigcorporate.com/index.html FYI - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left To Do... >--> RV-List message posted by: Matt Dralle > >Here's this year's Insurance Quotes along with the coverage details on my RV-8. Can you guess which one I went with? > >$1m/$100k Liability >$5000-$10000 Medical >$0 Deductible >$150k Hull Ground/Air > >153 Hours, Aircraft >153 Hours in Type, Pilot >450 Hours Total, Pilot >242 Hours TW, Pilot > > Avemco: $5811 > EAA/Falcon: $2975 ($3075 last year + Test & 1st 10 hours) > NationAir/Chartis $2888 > AOPA/AIG $2475 ________________________________________________________________________________
Subject: Re: engine cables
Date: Mar 23, 2011
I'll have to look at my part numbers tomorrow and maybe you can cross reference them. It may be easier to route little longer cables than stock ones, mine went in easy and I was able to set all my controls to end even at the top and bottom while hitting the stops. ----- Original Message ----- From: "Bob Leffler" <rv(at)thelefflers.com> Sent: Wednesday, March 23, 2011 11:26 AM Subject: Re: RV10-List: Re: engine cables > > Were your lengths the same as the ones I listed from Dave Saylor? > > I've got to order mine, but I'm planning on taking some measurements this > weekend. > > I've got the aerosport panel / throttle quadrant too, but my fm-200 is in > a non-standard location to accommodate the rod bower ram air mod. Its > horizontal, not vertical. It may need a couple extra inches. > > Bob > > Sent from my iPhone > > On Mar 23, 2011, at 11:01 AM, Seano wrote: > >> >> I was wondering if vans changed cable lengths before my serial number. I >> had no issues using the supplied cables with my Aerosport lower console >> and throttle quadrant. Kit number 40936. >> >> Sent from my iPhone >> >> On Mar 23, 2011, at 8:42, "rleffler" wrote: >> >>> >>> For those with quadrants: >>> >>> Per Dave Saylor: >>> >>> I replaced the stock cables with 47" for the prop, 51" for mixture and >>> 72" >>> for the prop. I got the cables from a local cablecraft distributor. >>> Also, >>> ask for the highest temp rating you can get. The green cables from Vans >>> aren't the best. A set of replacement cables should be $200 or less. >>> >>> >>> The vendor is California Push-Pull in Chico, CA. Talk to Frank. >>> >>> http://www.push-pull.com/ >>> >>> 176-VTT-2-51 >>> 176-VTT-2-47 >>> 176-VTT-2-72 >>> >>> These are for the mixture, throttle and prop respectively. >>> >>> Ask for Frank if you need a live person. He knows what they're going on. >>> >>> The cable tags will say "not for use on aircraft", which usually means >>> they know you're using it on an aircraft >>> >>> ----- >>> >>> Hope this helps! >>> >>> bob >>> >>> -------- >>> Bob Leffler >>> N410BL - FWF >>> RV-10 #40684 >>> http://mykitlog.com/rleffler >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=334767#334767 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 23, 2011
Subject: For those that haven't bought their avionics yet..................
http://garmin.blogs.com/pr/2011/03/garmin-announces-the-future-of-avionics-.html#more ________________________________________________________________________________
Date: Mar 23, 2011
So far the only thing I hate about Garmin is that they roll out new product s too fast making their other new products obsolete way too soon. EEEHHHGGGG! > Date: Wed=2C 23 Mar 2011 20:30:01 -0700 > Subject: RV10-List: For those that haven't bought their avionics yet..... ............. > From: apilot2(at)gmail.com > To: rv10-list(at)matronics.com > > > http://garmin.blogs.com/pr/2011/03/garmin-announces-the-future-of-avionic s-.html#more > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Mar 23, 2011
Subject: Re: For those that haven't bought their avionics yet..................
What a cool looking GPS. Pretty soon we will just buy a touch screen panel from Stein that is then loaded with software and is completely customizable. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________ From: John Gonzalez <indigoonlatigo(at)msn.com> Sent: Wed, March 23, 2011 9:50:27 PM Subject: RE: RV10-List: For those that haven't bought their avionics yet.................. So far the only thing I hate about Garmin is that they roll out new products too fast making their other new products obsolete way too soon. EEEHHHGGGG! > Date: Wed, 23 Mar 2011 20:30:01 -0700 > Subject: RV10-List: For those that haven't bought their avionics >yet.................. > From: apilot2(at)gmail.com > To: rv10-list(at)matronics.com > > > http://garmin.blogs.com/pr/2011/03==================== > _==== > > > ________________________________________________________________________________
Date: Mar 23, 2011
Aero-News Net also reports that Honeywell/King has collaborated with Aspen Avionics and claims they will finally have their WAAS GPS 770 before the end of this year. On Wed, Mar 23, 2011 at 8:50 PM, John Gonzalez wrote: > So far the only thing I hate about Garmin is that they roll out new products > too fast making their othernew products obsolete way too soon. > > EEEHHHGGGG! > >> Date: Wed, 23 Mar 2011 20:30:01 -0700 >> Subject: RV10-List: For those that haven't bought their avionics >> yet.................. >> From: apilot2(at)gmail.com >> To: rv10-list(at)matronics.com >> >> >> http://garmin.blogs.com/pr/2011/03==================== >> _==== >> >> >> > > ________________________________________________________________________________
Date: Mar 24, 2011
air Thanks Konrad, That was the information I was seeking. Incidentally, do you know the source? I too have the Sam James Cowl and plenum, in fact I was the second customer. It is therefore quite disturbing to hear that the intake area is probably too small. Increasing it to 6" will actually increase the airflow by a factor 5 (proportional to the 4th power of the radius). However my understanding is that the system works by having the intake very close to the propeller trailing edge and therefore having relatively high energy air entering the plenum. The expansion area of the plenum causes the air to slow down and hence be more available for efficient cooling whilst the intake provides the pressure that drives the flow. It's not a simple system and hence I was looking for an engineer's opinion. I received an update to the cowl some time ago and now I am getting ready to install it. It appears that the air outlet was too small and Sam sent me a new outlet to replace the original. This part will have to be glassed in and as I am also using a non standard exhaust system which is larger than the Vetterman I wanted to design the replacement outlet so that I only have one amendment to make to the cowl. I was aware of the LOP problem and was lucky enough to be able to see the solution (pressurised injectors) on Deems' aircraft last May. Many thanks to all, Rodger --- On Wed, 23/3/11, Konrad/Conny wrote: > From: Konrad/Conny <klwerner(at)comcast.net> > Subject: Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > To: rv10-list(at)matronics.com > Date: Wednesday, 23 March, 2011, 19:06 > Konrad/Conny > > Dear Rodger, > > I has been a few years, but if I recall correctly, then the > factor is right around 1.5 (I think?) for the hot expanding > air to exhaust properly, when compared to the denser cold > air coming in. > > I agree with Ralph, as Sam James's cowling and plenum > systems are very efficient in that respect, by tightly > controlling the cooling airflow and not wasting any air > molecules for unnecessary drag. > > Konrad > > > On Mar 23, 2011, at 10:27 AM, Ralph E. Capen wrote: > > > > > > Considering the work that was done to develop the > SamJames cowl and plenum...and how well they work - I think > they're a great starting place. > > > > > > -----Original Message----- > >> From: Rodger Todd <rj_todd(at)yahoo.co.uk> > >> Sent: Mar 23, 2011 7:42 AM > >> To: RV10-List(at)matronics.com > >> Subject: RV10-List: Optimal cowl intake and outlet > areas for engine cooling air > >> > > >> > >> Hi, > >> > >> Can any of the engineers out there please advise > whether there is an optimal ratio of the cowl inlet to > outlet areas for engine air cooling? > >> > >> Thanking you all in anticipation, > >> > >> Rodger > >> In Oz where cooling matters > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
air
Date: Mar 24, 2011
Dear Rodger, I don't remember the original source, as it has been years since I last thought about the subject matter. The main thought is to create the proper pressure differential between the "properly sealed" upper and lower cowling chambers to actually - suck- a sufficient amount of cooling air through the cylinders... notice that I didn't say -blow- through ;-) I would actually rig up a measuring system to see what the actual pressure differential is in various cowling-/cylinder locations before I would start hacking on the fiberglass at either intake or exhaust locations. A somewhat pilot adjustable cowl flap sure would be my choice of heat control (i.e. exhaust suction control), depending on climb, cruise, or top speed operation... The Racers at Reno are a mighty fine example of how little air flow one can get away with, if their cooling system is really maximized for proper performance with a minimum of cooling drag. I know Sam James in person, and he sure is one interesting guy to talk to. I am not an engineer by any means, but I do listen to smarter people then I am, so I can learn from them. If I were you, then I would have a long talk with Sam to discuss all options to improve cooling, if need be... Like I said earlier, I personally would experiment with it all first, as to come up with some accurate data to know where the actual problem may lie to begin with. Just my two cents, Konrad On Mar 23, 2011, at 11:21 PM, Rodger Todd wrote: > > Thanks Konrad, > > That was the information I was seeking. Incidentally, do you know > the source? > > I too have the Sam James Cowl and plenum, in fact I was the second > customer. It is therefore quite disturbing to hear that the intake > area is probably too small. Increasing it to 6" will actually > increase the airflow by a factor 5 (proportional to the 4th power of > the radius). However my understanding is that the system works by > having the intake very close to the propeller trailing edge and > therefore having relatively high energy air entering the plenum. > The expansion area of the plenum causes the air to slow down and > hence be more available for efficient cooling whilst the intake > provides the pressure that drives the flow. It's not a simple system > and hence I was looking for an engineer's opinion. > > I received an update to the cowl some time ago and now I am getting > ready to install it. It appears that the air outlet was too small > and Sam sent me a new outlet to replace the original. This part > will have to be glassed in and as I am also using a non standard > exhaust system which is larger than the Vetterman I wanted to design > the replacement outlet so that I only have one amendment to make to > the cowl. > > I was aware of the LOP problem and was lucky enough to be able to > see the solution (pressurised injectors) on Deems' aircraft last May. > > Many thanks to all, > > Rodger > > --- On Wed, 23/3/11, Konrad/Conny wrote: > >> From: Konrad/Conny <klwerner(at)comcast.net> >> Subject: Re: RV10-List: Optimal cowl intake and outlet areas for >> engine cooling air >> To: rv10-list(at)matronics.com >> Date: Wednesday, 23 March, 2011, 19:06 >> Konrad/Conny >> >> Dear Rodger, >> >> I has been a few years, but if I recall correctly, then the >> factor is right around 1.5 (I think?) for the hot expanding >> air to exhaust properly, when compared to the denser cold >> air coming in. >> >> I agree with Ralph, as Sam James's cowling and plenum >> systems are very efficient in that respect, by tightly >> controlling the cooling airflow and not wasting any air >> molecules for unnecessary drag. >> >> Konrad >> >> >> On Mar 23, 2011, at 10:27 AM, Ralph E. Capen wrote: >> >> >>> >>> Considering the work that was done to develop the >> SamJames cowl and plenum...and how well they work - I think >> they're a great starting place. >>> >>> >>> -----Original Message----- >>>> From: Rodger Todd <rj_todd(at)yahoo.co.uk> >>>> Sent: Mar 23, 2011 7:42 AM >>>> To: RV10-List(at)matronics.com >>>> Subject: RV10-List: Optimal cowl intake and outlet >> areas for engine cooling air >>>> >> >>>> >>>> Hi, >>>> >>>> Can any of the engineers out there please advise >> whether there is an optimal ratio of the cowl inlet to >> outlet areas for engine air cooling? >>>> >>>> Thanking you all in anticipation, >>>> >>>> Rodger >>>> In Oz where cooling matters >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> Forum - >> FAQ, >> - MATRONICS WEB FORUMS - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> > > ________________________________________________________________________________
Date: Mar 24, 2011
air Thanks Konrad for your sage advice; I may be able to go to Florida in August and I will try to call on Sam. THanks very much, Rodger PS Do I have stack space for a GTN750? --- On Thu, 24/3/11, Konrad/Conny wrote: > From: Konrad/Conny <klwerner(at)comcast.net> > Subject: Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > To: rv10-list(at)matronics.com > Date: Thursday, 24 March, 2011, 8:11 > Konrad/Conny > > Dear Rodger, > > I don't remember the original source, as it has been years > since I last thought about the subject matter. > > The main thought is to create the proper pressure > differential between the "properly sealed" upper and lower > cowling chambers to actually -suck- a sufficient amount of > cooling air through the cylinders... notice that I didn't > say -blow- through ;-) I would actually rig up a > measuring system to see what the actual pressure > differential is in various cowling-/cylinder locations > before I would start hacking on the fiberglass at either > intake or exhaust locations. A somewhat pilot > adjustable cowl flap sure would be my choice of heat control > (i.e. exhaust suction control), depending on climb, > cruise, or top speed operation... > > The Racers at Reno are a mighty fine example of how little > air flow one can get away with, if their cooling system is > really maximized for proper performance with a minimum of > cooling drag. I know Sam James in person, and he sure > is one interesting guy to talk to. I am not an > engineer by any means, but I do listen to smarter people > then I am, so I can learn from them. If I were you, > then I would have a long talk with Sam to discuss all > options to improve cooling, if need be... Like I said > earlier, I personally would experiment with it all first, as > to come up with some accurate data to know where the actual > problem may lie to begin with. > > Just my two cents, Konrad > > > On Mar 23, 2011, at 11:21 PM, Rodger Todd wrote: > > > > > Thanks Konrad, > > > > That was the information I was seeking. > Incidentally, do you know the source? > > > > I too have the Sam James Cowl and plenum, in fact I > was the second customer. It is therefore quite > disturbing to hear that the intake area is probably too > small. Increasing it to 6" will actually increase the > airflow by a factor 5 (proportional to the 4th power of the > radius). However my understanding is that the system > works by having the intake very close to the propeller > trailing edge and therefore having relatively high energy > air entering the plenum. The expansion area of the > plenum causes the air to slow down and hence be more > available for efficient cooling whilst the intake provides > the pressure that drives the flow. It's not a simple system > and hence I was looking for an engineer's opinion. > > > > I received an update to the cowl some time ago and now > I am getting ready to install it. It appears that the > air outlet was too small and Sam sent me a new outlet to > replace the original. This part will have to be > glassed in and as I am also using a non standard exhaust > system which is larger than the Vetterman I wanted to design > the replacement outlet so that I only have one amendment to > make to the cowl. > > > > I was aware of the LOP problem and was lucky enough to > be able to see the solution (pressurised injectors) on > Deems' aircraft last May. > > > > Many thanks to all, > > > > Rodger > > > > --- On Wed, 23/3/11, Konrad/Conny > wrote: > > > >> From: Konrad/Conny <klwerner(at)comcast.net> > >> Subject: Re: RV10-List: Optimal cowl intake and > outlet areas for engine cooling air > >> To: rv10-list(at)matronics.com > >> Date: Wednesday, 23 March, 2011, 19:06 > >> Konrad/Conny > >> > >> Dear Rodger, > >> > >> I has been a few years, but if I recall correctly, > then the > >> factor is right around 1.5 (I think?) for the hot > expanding > >> air to exhaust properly, when compared to the > denser cold > >> air coming in. > >> > >> I agree with Ralph, as Sam James's cowling and > plenum > >> systems are very efficient in that respect, by > tightly > >> controlling the cooling airflow and not wasting > any air > >> molecules for unnecessary drag. > >> > >> Konrad > >> > >> > >> On Mar 23, 2011, at 10:27 AM, Ralph E. Capen > wrote: > >> > Capen" > >> > >>> > >>> Considering the work that was done to develop > the > >> SamJames cowl and plenum...and how well they work > - I think > >> they're a great starting place. > >>> > >>> > >>> -----Original Message----- > >>>> From: Rodger Todd <rj_todd(at)yahoo.co.uk> > >>>> Sent: Mar 23, 2011 7:42 AM > >>>> To: RV10-List(at)matronics.com > >>>> Subject: RV10-List: Optimal cowl intake > and outlet > >> areas for engine cooling air > >>>> > Todd > >> > >>>> > >>>> Hi, > >>>> > >>>> Can any of the engineers out there please > advise > >> whether there is an optimal ratio of the cowl > inlet to > >> outlet areas for engine air cooling? > >>>> > >>>> Thanking you all in anticipation, > >>>> > >>>> Rodger > >>>> In Oz where cooling matters > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> Forum - > >> FAQ, > >> - MATRONICS WEB FORUMS - > >> List Contribution Web Site - > >> > -Matt > >> Dralle, List Admin. > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 24, 2011
air Yup - I took an earlier post as an educational point - my experience is with my 6A - which I'm happy with. Like I said before they should have done the same level of research and testing on the -10 cowl...... Takin the heat - fessin I'm wrong.... -----Original Message----- >From: Deems Davis <deemsdavis(at)cox.net> >Sent: Mar 23, 2011 4:57 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air > > >As one who drank the Koolaid, I would beg to disagree, IMO the Sam James >cowl intake area is WAY UNDERSIZED, I believe this has been >substantiated by another -10 builder who did some considerable >modifications to increase the size of the intake for the SJ cowl/plenum >and saw improved cooling performance. If you think about it, it stands >to reason, James uses the same size intake rings for the 6 cyl as he >does for the 4 cyl ????? Yet there is considerable more area to cool an >more heat generated. The cowls look sexy, but I cannot attribute ANY >improvement to speed/performance. However, by way of comparison there is >a Reduction in the cooling. > >Deems >N519PJ > >On 3/23/2011 9:27 AM, Ralph E. Capen wrote: >> --> RV10-List message posted by: "Ralph E. Capen" >> >> Considering the work that was done to develop the SamJames cowl and plenum...and how well they work - I think they're a great starting place. >> >> >> -----Original Message----- >>> From: Rodger Todd<rj_todd(at)yahoo.co.uk> >>> Sent: Mar 23, 2011 7:42 AM >>> To: RV10-List(at)matronics.com >>> Subject: RV10-List: Optimal cowl intake and outlet areas for engine cooling air >>> >>> --> RV10-List message posted by: Rodger Todd >>> >>> Hi, >>> >>> Can any of the engineers out there please advise whether there is an optimal ratio of the cowl inlet to outlet areas for engine air cooling? >>> >>> Thanking you all in anticipation, >>> >>> Rodger >>> In Oz where cooling matters >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 24, 2011
Finally - some competition to Garmin - maybe it will get a little bit more reasonable now?! -----Original Message----- >From: Kelly McMullen <apilot2(at)gmail.com> >Sent: Mar 24, 2011 12:26 AM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: For those that haven't bought their avionics yet.................. > > >Aero-News Net also reports that Honeywell/King has collaborated with >Aspen Avionics and claims they will finally have their WAAS GPS 770 >before the end of this year. > >On Wed, Mar 23, 2011 at 8:50 PM, John Gonzalez wrote: >> So far the only thing I hate about Garmin is that they roll out new products >> too fast making their othernew products obsolete way too soon. >> >> EEEHHHGGGG! >> >>> Date: Wed, 23 Mar 2011 20:30:01 -0700 >>> Subject: RV10-List: For those that haven't bought their avionics >>> yet.................. >>> From: apilot2(at)gmail.com >>> To: rv10-list(at)matronics.com >>> >>> >>> http://garmin.blogs.com/pr/2011/03==================== >>> _==== >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 24, 2011
Subject: New Garmin Radios Announced GTN 650 & 750
Garmin announce the successors to the GNS 430W and 530W. <http://garmin.blogs.com/pr/2011/03/garmin-announces-the-future-of-avionics-.html> Larry ________________________________________________________________________________
Date: Mar 24, 2011
air FYI Even though everyone refers to them as the Sam James Cowls, Sam only builds the Plenum, his son Will builds the Cowls, they are as different as night and day to talk to. Will is extremely helpful over the phone. Deems ________________________________________________________________________________
Subject: Re: RV-8 Insurance...
Date: Mar 24, 2011
Matt, You are correct. AIG and USAIG are different companies. We had USAIG for many years on the 182 and they had a nice "plain language" policy that you didn't have to be a lawyer to read. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334912#334912 ________________________________________________________________________________
Date: Mar 24, 2011
Subject: MT Governor oil leak
For those with the MT governor who've adjusted the orientation of the control arm (which I assume is pretty much all of us with the MT), have you noticed any oil leaks in that area? I'm getting a small one on the top and front of that circular part (where there's a seam between the main governor body and the ring that the 6 screws hold down). Anyone seen anything like this? I'm wondering if I damaged a gasket when reorienting the arm. -Rob -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 24, 2011
For better or worse (and I think better) touch screen interface in aircraft, cars, etc are here to stay at least until reliable voice control or maybe direct mind control :-) comes about. Touch screen can be done badly, such as the Bendix/King AV8OR line, and it can be done well such as Garmin and iPad. Anchoring your hand with an intuitive touch screen interface is IMHO quicker and easier for data entry than knobs or buttons. I've flown with my land Nuvi RAM mounted on the panel and iPad and have no issues with entering commands in turbulence. If you look on the Avweb video you will see the Garmin pilot rest three fingers on the bezel while entering commands with his index finger. All operations were faster than if those commands were being entered with knobs. When done this was, data entry is effortless. If you allow you hand to freely float above the screen it will be difficult. The F-18 Super Hornet upgrade and the next generation F-35 fighter has touch screen interfaces. The military usually invests a significant amount of time and money in human factory testing. If touch screen was such a bad thing, no consideration would be given to using it in the "turbulent" environment of a combat cockpit. In 1998 Garmin introduced the GNS-430 with a list price of $10,995. In 2007? Garmin introduced the GNS-430W with a list price of $11,295. In 2011 Garmin introduces the GTN 650 with a list price of $11,495. Is this a new product too fast or too expensive? I guess it is a matter of perspective. For comparison, consider that the Bendix/King KX-155 Nav/Comm transceiver with glidescope has a list price of $5,008. -- William N40237 - http://wcurtis.nerv10.com/ On Thu, Mar 24, 2011 at 12:24 PM, Dave Saylor wrote: > > It seems like touch screen would work a lot better as a kneeboard or > on a console. Rubberbanding a route seems hopeless, about as difficult > as writing legibly in the same position. I haven't flown with an ipad > yet but the GPS in my car is mounted vertically next to the rear view > mirror and even on smooth roads it can be difficult to use, especially > doing stuff like entering text on the "keyboard". > > Also, I like the fact that I have three major brands in my panel. > They work well together, and if something goes TU I don't have all my > eggs in one basket. I guess you can still spread things around with > this new hardware but the intention seems to be a single-brand > solution. ________________________________________________________________________________
Date: Mar 24, 2011
Did I miss something or did they not say that you could still do the input via the knobs if you wanted too? So... if it was very turbulent and you were having issues, couldn't you just revert back to the old method of input? I really like the idea of being able to input airways directly. In the video it shows them selecting a vor and then all of the airways showed up in a list. slick! Shannon On Thu, Mar 24, 2011 at 12:43 PM, William Curtis wrote: > > For better or worse (and I think better) touch screen interface in > aircraft, cars, etc are here to stay at least until reliable voice > control or maybe direct mind control :-) comes about. Touch screen > can be done badly, such as the Bendix/King AV8OR line, and it can be > done well such as Garmin and iPad. > > Anchoring your hand with an intuitive touch screen interface is IMHO > quicker and easier for data entry than knobs or buttons. I've flown > with my land Nuvi RAM mounted on the panel and iPad and have no issues > with entering commands in turbulence. If you look on the Avweb video > you will see the Garmin pilot rest three fingers on the bezel while > entering commands with his index finger. All operations were faster > than if those commands were being entered with knobs. When done this > was, data entry is effortless. If you allow you hand to freely float > above the screen it will be difficult. > > The F-18 Super Hornet upgrade and the next generation F-35 fighter has > touch screen interfaces. The military usually invests a significant > amount of time and money in human factory testing. If touch screen was > such a bad thing, no consideration would be given to using it in the > "turbulent" environment of a combat cockpit. > > In 1998 Garmin introduced the GNS-430 with a list price of $10,995. > In 2007? Garmin introduced the GNS-430W with a list price of $11,295. > In 2011 Garmin introduces the GTN 650 with a list price of $11,495. > > Is this a new product too fast or too expensive? I guess it is a > matter of perspective. For comparison, consider that the Bendix/King > KX-155 Nav/Comm transceiver with glidescope has a list price of > $5,008. > > -- > William > N40237 - http://wcurtis.nerv10.com/ > > On Thu, Mar 24, 2011 at 12:24 PM, Dave Saylor > wrote: > dave.saylor.aircrafters(at)gmail.com> > > > > It seems like touch screen would work a lot better as a kneeboard or > > on a console. Rubberbanding a route seems hopeless, about as difficult > > as writing legibly in the same position. I haven't flown with an ipad > > yet but the GPS in my car is mounted vertically next to the rear view > > mirror and even on smooth roads it can be difficult to use, especially > > doing stuff like entering text on the "keyboard". > > > > Also, I like the fact that I have three major brands in my panel. > > They work well together, and if something goes TU I don't have all my > > eggs in one basket. I guess you can still spread things around with > > this new hardware but the intention seems to be a single-brand > > solution. > > ________________________________________________________________________________
Subject: Optimal cowl intake and outlet areas for engine cooling
air
Date: Mar 24, 2011
Now, Deems - Sam is perfectly reasonable and more than willing to help. As long as you see things his way... ;) Neal -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Thursday, March 24, 2011 9:11 AM Subject: Re: RV10-List: Optimal cowl intake and outlet areas for engine cooling air FYI Even though everyone refers to them as the Sam James Cowls, Sam only builds the Plenum, his son Will builds the Cowls, they are as different as night and day to talk to. Will is extremely helpful over the phone. Deems ________________________________________________________________________________
Date: Mar 24, 2011
> Did I miss something or did they not say that you could still do the input via the knobs if you wanted too? So... if it was very turbulent and you were having issues, couldn't you just revert back to the old method of input? No you didn't miss it. Everybody else did. -------- Mike Sydney, Australia Pitts Model 12 under construction. "Get your facts first, and then you can distort them as much as you please." Mark Twain. Writer. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334980#334980 ________________________________________________________________________________
Subject: Re: WingX 7 for iPad
Date: Mar 24, 2011
Tim, We really appreciate you being on the leading edge to help guide us not-so-geeky folks. I have been looking at ht iPad2 and wondering which one we need for these apps. Do recommend the 16, 32, or 64GB? -------- Dave Moore RV-6 flying RV-10 QB - FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334989#334989 ________________________________________________________________________________
Subject: Re: QB Kit Primer
Date: Mar 24, 2011
Any of the ketones (like MEK) should work. -------- Dave Moore RV-6 flying RV-10 QB - FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=334992#334992 ________________________________________________________________________________
Date: Mar 24, 2011
AIG as an aviation underwriter was sold off of the parent firm. It is now Chartis. AFAIK it always was pretty separate from the divisions that did the evil credit default swaps. On Thu, Mar 24, 2011 at 8:09 AM, Bob Turner wrote: > > Matt, > > You are correct. AIG and USAIG are different companies. > > We had USAIG for many years on the 182 and they had a nice "plain language" policy that you didn't have to be a lawyer to read. > > Bob > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334912#334912 > > ________________________________________________________________________________
Date: Mar 24, 2011
Hi Dave, Personally, I get only the 64Gb version with 3G. This is because only the 3G versions have a built-in gps, and that can be very handy. Mine actually works well that way so often I only use the built-in gps, especially in the car. The 16Gb version would just work for most people if they only want it for one main app, like foreflight or wingX. But, I would never ever go with a 16....always get at least 32Gb. The aviation chart and plates take up quite a bit if space. At 32GB, most people would be ok with a couple good, big, charting apps and some other stuff. 64GB will give you the option for storage for lots of music, or a dozen or more movies for layovers waiting for weather, or for kids entertainment. So I always go big. In fact, I'm a bit disappointed that the iPad2 didn't come with 128GB, because I would have got that one just for movie space for the kids. One other tip....I use Goodreader, and with that, I have almost every manual for every item jn the plane, in .PDF form on the ipad, and also put PDF prints of websites and stuff for vacations on the ipad....and copies of the ASRS form, and insurance policy, Copies of my pilot cert, medical, airworthiness, radio station license, and just about every bit of info anyone could need...all on the ipad with me on my trips. So, it's very handy for all of that stuff too. In fact, on this trip to Mexico, I needed CH-22 WAC. Rather than buy it, I downloaded the zipped .tif from the government, and good reader displays it great....so still paper free....and cash free. You'll never be sorry for going too big....just broke. ;) Tim On Mar 24, 2011, at 10:23 PM, "nukeflyboy" wrote: > > Tim, > > We really appreciate you being on the leading edge to help guide us not-so-geeky folks. I have been looking at ht iPad2 and wondering which one we need for these apps. Do recommend the 16, 32, or 64GB? > > -------- > Dave Moore > RV-6 flying > RV-10 QB - FWF > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334989#334989 > > > > > > > > > ________________________________________________________________________________
Date: Mar 24, 2011
Re: RV10-List: Re: WingX 7 for iPad Regarding WingX 7 for the ipad. I spoke with Seattle Avionics yesterday and they said if you purchase the SA subscription for WingX 7 the same subscription would drive both Beacon & Sky Radar. I took a quick look at both apps and didn=92t see anything special if one already has ForeFlight a nd WingX7 however I claim to be no expert. I do know that the SA data is * included* with the ForeFlight HD Pro app (at a higher subscription rate) an d not usable with any other app. Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson *Sent:* Thursday, March 24, 2011 9:31 PM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: Re: WingX 7 for iPad Hi Dave, Personally, I get only the 64Gb version with 3G. This is because only the 3G versions have a built-in gps, and that can be very handy. Mine actually works well that way so often I only use the built-in gps, especially in the car. The 16Gb version would just work for most people if they only want it for one main app, like foreflight or wingX. But, I would never ever go wit h a 16....always get at least 32Gb. The aviation chart and plates take up quite a bit if space. At 32GB, most people would be ok with a couple good, big, charting apps and some other stuff. 64GB will give you the option for storage for lots of music, or a dozen or more movies for layovers waiting for weather, or for kids entertainment. S o I always go big. In fact, I'm a bit disappointed that the iPad2 didn't com e with 128GB, because I would have got that one just for movie space for the kids. One other tip....I use Goodreader, and with that, I have almost every manua l for every item jn the plane, in .PDF form on the ipad, and also put PDF prints of websites and stuff for vacations on the ipad....and copies of the ASRS form, and insurance policy, Copies of my pilot cert, medical, airworthiness, radio station license, and just about every bit of info anyone could need...all on the ipad with me on my trips. So, it's very handy for all of that stuff too. In fact, on this trip to Mexico, I needed CH-22 WAC. Rather than buy it, I downloaded the zipped .tif from the government, and good reader displays it great....so still paper free....and cash free. You'll never be sorry for going too big....just broke. ;) Tim On Mar 24, 2011, at 10:23 PM, "nukeflyboy" wrote: > > Tim, > > We really appreciate you being on the leading edge to help guide us not-so-geeky folks. I have been looking at ht iPad2 and wondering which on e we need for these apps. Do recommend the 16, 32, or 64GB? > > -------- > Dave Moore > RV-6 flying > RV-10 QB - FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334989#334989 > > ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 25, 2011
That is very true. Wingx currently does it far better in flight, is all. Although, if ALL you care about in-flight is geo-ref approach plates and not moving map, ads-b, and stuff like that, foreflight will be the better choic e in flight. Tim On Mar 25, 2011, at 12:26 AM, Robin Marks wrote: > Regarding WingX 7 for the ipad. I spoke with Seattle Avionics yesterday an d they said if you purchase the SA subscription for WingX 7 the same subscri ption would drive both Beacon & Sky Radar. I took a quick look at both apps a nd didn=99t see anything special if one already has ForeFlight and Win gX7 however I claim to be no expert. I do know that the SA data is included w ith the ForeFlight HD Pro app (at a higher subscription rate) and not usable with any other app. > > > > Robin > > > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Thursday, March 24, 2011 9:31 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: WingX 7 for iPad > > > > > Hi Dave, > > Personally, I get only the 64Gb version with 3G. This is because only the 3G versions have a built-in gps, and that can be very handy. Mine actually works well that way so often I only use the built-in gps, especially in the car. The 16Gb version would just work for most people if they only want it for one main app, like foreflight or wingX. But, I would never ever go wit h a 16....always get at least 32Gb. The aviation chart and plates take up q uite a bit if space. At 32GB, most people would be ok with a couple good, b ig, charting apps and some other stuff. > 64GB will give you the option for storage for lots of music, or a dozen or more movies for layovers waiting for weather, or for kids entertainment. S o I always go big. In fact, I'm a bit disappointed that the iPad2 didn't co me with 128GB, because I would have got that one just for movie space for th e kids. > > One other tip....I use Goodreader, and with that, I have almost every manu al for every item jn the plane, in .PDF form on the ipad, and also put PDF p rints of websites and stuff for vacations on the ipad....and copies of the A SRS form, and insurance policy, > Copies of my pilot cert, medical, airworthiness, radio station license, an d just about every bit of info anyone could need...all on the ipad with me o n my trips. So, it's very handy for all of that stuff too. > > In fact, on this trip to Mexico, I needed CH-22 WAC. Rather than buy it, I downloaded the zipped .tif from the government, and good reader displays it great....so still paper free....and cash free. > > You'll never be sorry for going too big....just broke. ;) > > Tim > > > > On Mar 24, 2011, at 10:23 PM, "nukeflyboy" wrote: > > > > > Tim, > > > > We really appreciate you being on the leading edge to help guide us not- so-geeky folks. I have been looking at ht iPad2 and wondering which one we n eed for these apps. Do recommend the 16, 32, or 64GB? > > > > -------- > > Dave Moore > > RV-6 flying > > RV-10 QB - FWF > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=334989#334989 > > > > > > > > > > > > > > > > > > > > ics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > ttp://forums.matronics.com">http://forums.matronics.com > -Matt Dralle, List Admin. > ======================= > > > > No virus found in this message. > Checked by AVG - www.avg.com > Version: 10.0.120 > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 25, 2011
Acetone works fine as a solvent to remove the QB wash primer. Larry On 3/24/2011 11:30 PM, nukeflyboy wrote: > --> RV10-List message posted by: "nukeflyboy" > > Any of the ketones (like MEK) should work. > > -------- > Dave Moore > RV-6 flying > RV-10 QB - FWF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=334992#334992 > > ________________________________________________________________________________
Date: Mar 25, 2011
Subject: Re: Matco RV-10 Nosewheel Axle replacement write-up - A must
Read Pascal, Thanks for the tip on the new tube. That's the first I'd heard of the "New Easy Valve". Coincidentally, yesterday I was emailing with Bob Leffler who showed me his main tube stem clearance, and also with another RV-10 buddy who had JUST yesterday, installed those tubes. They both sent me pictures, which I have used completely without their permission, to quick get the info out on this link below. http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes This one is worth all you RV-10 guys checking out. It basically summarizes the Nosewheel, Front Axle, Nose tube, Main Tube issues, and gives you links to the places to get the things that will fix all the issues. I also have pictures of some of the various situations, from both my plane, and a couple other RV-10's, so that you can see all the issues fairly close up. So it gives you everything you need to arm yourself with a fix if you're a flying RV-10 builder, and everything you need to prevent the issues completely if you haven't yet ordered those parts from your kit. I sure wish all this stuff had been either known, or available, back in 2005 when I needed it. You newer builders have no idea how much less pain you get to go through.... hell, everyone remembers Randy #006, and his way cool build process....even he just called me regarding axle extensions because he's broke a couple of the Van's standard ones so far. You get all the benefits. Tim On 3/24/2011 3:22 PM, Pascal wrote: > > One of the items that was bothering me about the rear tubes was the > angle the stem comes out of the tire. It made for checking the pressure > rather hard, usually I lost 1-2psi just trying to get the gauge in there > to check it. I discovered yesterday that Desser sells a tube for the > 15-600/6 tires that has a stem with a 75 degree angle on it. I ordered a > couple as it bothers me enough to just put in now versus continuing to > deal with the current stem. > http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html > > > Pascal > ________________________________________________________________________________
Date: Mar 25, 2011
Read
I have tried several times to get my nose wheel stem to fit, but I have to remove the cap and even then it is still a close fit. On Fri, Mar 25, 2011 at 9:43 AM, Tim Olson wrote: > > > Pascal, > > Thanks for the tip on the new tube. That's the first I'd > heard of the "New Easy Valve". Coincidentally, yesterday > I was emailing with Bob Leffler who showed me his main tube > stem clearance, and also with another RV-10 buddy who had > JUST yesterday, installed those tubes. They both sent > me pictures, which I have used completely without their > permission, to quick get the info out on this link below. > > http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes > > This one is worth all you RV-10 guys checking out. It basically > summarizes the Nosewheel, Front Axle, Nose tube, Main Tube > issues, and gives you links to the places to get the things > that will fix all the issues. I also have pictures of > some of the various situations, from both my plane, and a couple > other RV-10's, so that you can see all the issues fairly > close up. > > So it gives you everything you need to arm yourself with a fix > if you're a flying RV-10 builder, and everything you need to > prevent the issues completely if you haven't yet ordered > those parts from your kit. I sure wish all this stuff > had been either known, or available, back in 2005 when > I needed it. You newer builders have no idea how much > less pain you get to go through.... hell, everyone remembers > Randy #006, and his way cool build process....even he just > called me regarding axle extensions because he's broke > a couple of the Van's standard ones so far. You get all > the benefits. > > Tim > > > On 3/24/2011 3:22 PM, Pascal wrote: >> >> >> One of the items that was bothering me about the rear tubes was the >> angle the stem comes out of the tire. It made for checking the pressure >> rather hard, usually I lost 1-2psi just trying to get the gauge in there >> to check it. I discovered yesterday that Desser sells a tube for the >> 15-600/6 tires that has a stem with a 75 degree angle on it. I ordered a >> couple as it bothers me enough to just put in now versus continuing to >> deal with the current stem. >> >> http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html >> >> >> Pascal >> > > ________________________________________________________________________________
Read
Date: Mar 25, 2011
You are so right about all the aftermarket options available in the last year alone. I can tell you there is a lot more in the skunk works I know may be out by Osh. I believe if I can help those behind me with better options so they dont have to suffer the pain we did, I will. Basically everything you're doing very well Tim. As an example, Windscreen and windows is a HUGE option, anyone who doesn't go the Cee Baileys route is really doing yourself a disfavor! The price is the same, all the trimming is done for you when it arrives.. That was about 20 hours and numerous scratches from on-and off fitting that future builders dont need to endure. I push http://www.vansaircrafttires.com/categories/RV%252d10/ for a reason, I make NOTHING on this other than knowing I am sending you to a "one stop shop" place for everything you need for the RV-10. Yes, I was blessed to work with them for the windscreen, but in doing so I saw amazing attention to detail and fair pricing for the work, I believe they could easily charge more and it would be worth it, as the final product is better. The wingtip lens are not even worth comparing, there is no comparison between the Vans one piece and the one you get from Cee Baileys, it arrives fitting or with minor trimming and is far superior quality. As Tim said, newer builders will get better, easier and better options, than anyone before them had available to them. Pascal -----Original Message----- From: Tim Olson Sent: Friday, March 25, 2011 6:43 AM Subject: Re: RV10-List: Matco RV-10 Nosewheel Axle replacement write-up - A must Read Pascal, Thanks for the tip on the new tube. That's the first I'd heard of the "New Easy Valve". Coincidentally, yesterday I was emailing with Bob Leffler who showed me his main tube stem clearance, and also with another RV-10 buddy who had JUST yesterday, installed those tubes. They both sent me pictures, which I have used completely without their permission, to quick get the info out on this link below. http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes This one is worth all you RV-10 guys checking out. It basically summarizes the Nosewheel, Front Axle, Nose tube, Main Tube issues, and gives you links to the places to get the things that will fix all the issues. I also have pictures of some of the various situations, from both my plane, and a couple other RV-10's, so that you can see all the issues fairly close up. So it gives you everything you need to arm yourself with a fix if you're a flying RV-10 builder, and everything you need to prevent the issues completely if you haven't yet ordered those parts from your kit. I sure wish all this stuff had been either known, or available, back in 2005 when I needed it. You newer builders have no idea how much less pain you get to go through.... hell, everyone remembers Randy #006, and his way cool build process....even he just called me regarding axle extensions because he's broke a couple of the Van's standard ones so far. You get all the benefits. Tim On 3/24/2011 3:22 PM, Pascal wrote: > > One of the items that was bothering me about the rear tubes was the > angle the stem comes out of the tire. It made for checking the pressure > rather hard, usually I lost 1-2psi just trying to get the gauge in there > to check it. I discovered yesterday that Desser sells a tube for the > 15-600/6 tires that has a stem with a 75 degree angle on it. I ordered a > couple as it bothers me enough to just put in now versus continuing to > deal with the current stem. > http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html > > > Pascal > ________________________________________________________________________________
Read
Date: Mar 25, 2011
Then you need the new wheel like I do now. Mine is coming today. Tim On Mar 25, 2011, at 11:07 AM, John Trollinger wrote: > > I have tried several times to get my nose wheel stem to fit, but I > have to remove the cap and even then it is still a close fit. > > > > On Fri, Mar 25, 2011 at 9:43 AM, Tim Olson wrote: >> >> >> Pascal, >> >> Thanks for the tip on the new tube. That's the first I'd >> heard of the "New Easy Valve". Coincidentally, yesterday >> I was emailing with Bob Leffler who showed me his main tube >> stem clearance, and also with another RV-10 buddy who had >> JUST yesterday, installed those tubes. They both sent >> me pictures, which I have used completely without their >> permission, to quick get the info out on this link below. >> >> http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes >> >> This one is worth all you RV-10 guys checking out. It basically >> summarizes the Nosewheel, Front Axle, Nose tube, Main Tube >> issues, and gives you links to the places to get the things >> that will fix all the issues. I also have pictures of >> some of the various situations, from both my plane, and a couple >> other RV-10's, so that you can see all the issues fairly >> close up. >> >> So it gives you everything you need to arm yourself with a fix >> if you're a flying RV-10 builder, and everything you need to >> prevent the issues completely if you haven't yet ordered >> those parts from your kit. I sure wish all this stuff >> had been either known, or available, back in 2005 when >> I needed it. You newer builders have no idea how much >> less pain you get to go through.... hell, everyone remembers >> Randy #006, and his way cool build process....even he just >> called me regarding axle extensions because he's broke >> a couple of the Van's standard ones so far. You get all >> the benefits. >> >> Tim >> >> >> >> On 3/24/2011 3:22 PM, Pascal wrote: >>> >>> >>> One of the items that was bothering me about the rear tubes was the >>> angle the stem comes out of the tire. It made for checking the pressure >>> rather hard, usually I lost 1-2psi just trying to get the gauge in there >>> to check it. I discovered yesterday that Desser sells a tube for the >>> 15-600/6 tires that has a stem with a 75 degree angle on it. I ordered a >>> couple as it bothers me enough to just put in now versus continuing to >>> deal with the current stem. >>> >>> http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html >>> >>> >>> Pascal >>> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 26, 2011
Subject: Re: NAV/COM/GS Antenna
>At 02:53 PM 1/26/2011 Wednesday, you wrote: >Gday all, >I bought a Comant CI-121 NAV/COM/GS Antenna (V dipole) to install on my VS but I have discovered that it wont fit. >The diameter of the mounting base is 2.5 inches and that will not fit into the Fibreglass Fairing on top of the VS. >Which V dipoles have other people used on their VS? > >Cheers > >John MacCallum >Builder 41016 > >Rydal NSW Australia Hi John, I realize you posted about this a few months old, but I thought I'd comment on your VOR antenna mounting conundrum. You called out a "CI-121 Nav/COM/GS", but I think you really meant something like a CI-158C which is a Di-pole VOR/GS/Loc antenna. The CI-121 is a fiberglass COM antenna only. Here is the Cheif web page on NAV/GS/Loc antennas: http://www.chiefaircraft.com/airsec/Aircraft/Antennas/ComantIndustries-NAV.html In any case, I mounted a CI-158C in the fin of my RV-8 and it works very nicely there. Here are some pictures of the installation: Finished Installation: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log=67041&row=1 Installation Techniques: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log=66967&row=49 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log=66968&row=48 Best regards, - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left... ________________________________________________________________________________
Date: Mar 26, 2011
Read Today I installed the new nosewheel from Matco and took some photos. Unfortunately, in my state of intense focus I totally overlooked getting a photo of the stem to front fork clearance of the valve stem...but it was definitely over 1/4" of clearance. I updated the write up here: http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes and also copied it to my own section of the site: http://www.myrv10.com/N104CD/upgrades/20110326/index.html While I was working on it, I found out I neglected to link the fullsize pictures so you couldn't zoom in and see them close up....sorry about that...that's what I get for not using my normal page building tool, and just winging it. Anyway, the new nosewheel fit great, has awesome clearance, and is now permanently not an issue anymore. Now my only task is that next time I change the main tires, I'll throw on a pair of leakguard tubes with the "new easy valve" so I have tons of clearance there too. Tim Olson - RV-10 N104CD On 3/25/2011 8:43 AM, Tim Olson wrote: > > > Pascal, > > Thanks for the tip on the new tube. That's the first I'd > heard of the "New Easy Valve". Coincidentally, yesterday > I was emailing with Bob Leffler who showed me his main tube > stem clearance, and also with another RV-10 buddy who had > JUST yesterday, installed those tubes. They both sent > me pictures, which I have used completely without their > permission, to quick get the info out on this link below. > > http://www.myrv10.com/tips/mods/index.html#Better_Tires_and_Tubes > > This one is worth all you RV-10 guys checking out. It basically > summarizes the Nosewheel, Front Axle, Nose tube, Main Tube > issues, and gives you links to the places to get the things > that will fix all the issues. I also have pictures of > some of the various situations, from both my plane, and a couple > other RV-10's, so that you can see all the issues fairly > close up. > > So it gives you everything you need to arm yourself with a fix > if you're a flying RV-10 builder, and everything you need to > prevent the issues completely if you haven't yet ordered > those parts from your kit. I sure wish all this stuff > had been either known, or available, back in 2005 when > I needed it. You newer builders have no idea how much > less pain you get to go through.... hell, everyone remembers > Randy #006, and his way cool build process....even he just > called me regarding axle extensions because he's broke > a couple of the Van's standard ones so far. You get all > the benefits. > > Tim > > > On 3/24/2011 3:22 PM, Pascal wrote: >> >> One of the items that was bothering me about the rear tubes was the >> angle the stem comes out of the tire. It made for checking the pressure >> rather hard, usually I lost 1-2psi just trying to get the gauge in there >> to check it. I discovered yesterday that Desser sells a tube for the >> 15-600/6 tires that has a stem with a 75 degree angle on it. I ordered a >> couple as it bothers me enough to just put in now versus continuing to >> deal with the current stem. >> http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html >> >> >> >> Pascal >> > > ________________________________________________________________________________
Subject: quadrant cable lenghts
Date: Mar 26, 2011
Per Vans the quadrant cable lengths were 49.5" for the throttle and 52.5 for the mixture. Because these were a little tight I special ordered cables 1.5 " longer. that is 51" and 54". The cables received were about 4" longer than the installed cable so we had plenty of extra cable to route. Mine was an early firewall forward kit but something has drastically changed either in the original cables supplied or the way they are measured. I don't know whether they measure the same way as certified cables. also do not use the eyeball firewall carry-thru unless using the double nut version; the eyeball with the small screws and SS clamps are a PITA to remove and install with the engine in place. This operation should have never been needed since cables should last to TBO and changed at overhaul when engine is elsewhere being overhauled. ________________________________________________________________________________
Date: Mar 26, 2011
Subject: Aerosport Products Additions
I recently made a couple of upgrades to the plane, two of them were the door handle covers and baggage door cover from Aerosport. Here are some pictures of the install and final result. I know Geoff will be at Sun n' Fun with many of his cool products you can see on his plane. http://www.vansairforce.com/community/showthread.php?t=70179 Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Subject: Re: quadrant cable lenghts
Date: Mar 26, 2011
I'm one of the ones who couldn't route the cables per plans, too tight. I had a number of emails with Vans, couldn't resolve the source of the problem. But anyway, per Vans (Ken I think), the measurement is: >From the farthest point forward (threaded end) with the control full forward, back to the mounting flange (cockpit end). This only works if the forward ends are standardized. What also matters is the distance forward to the attachment nuts. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335145#335145 ________________________________________________________________________________
From: "John MacCallum" <vk2gcn(at)cirruscomms.com.au>
Date: Mar 27, 2011
Yes thank you Matt, You are right I quoted the wrong model. From memory it is indeed a C-158. I didn't think to Let out the Fibreglass more to get it to fit. Thank you to you and everyone else for your photos. Cheers Cheers John MacCallum -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, 27 March 2011 4:25 AM rv7-list(at)matronics.com Subject: RV10-List: Re: NAV/COM/GS Antenna >At 02:53 PM 1/26/2011 Wednesday, you wrote: >Gday all, >I bought a Comant CI-121 NAV/COM/GS Antenna (V dipole) to install on my VS but I have discovered that it wont fit. >The diameter of the mounting base is 2.5 inches and that will not fit into the Fibreglass Fairing on top of the VS. >Which V dipoles have other people used on their VS? > >Cheers > >John MacCallum >Builder 41016 > >Rydal NSW Australia Hi John, I realize you posted about this a few months old, but I thought I'd comment on your VOR antenna mounting conundrum. You called out a "CI-121 Nav/COM/GS", but I think you really meant something like a CI-158C which is a Di-pole VOR/GS/Loc antenna. The CI-121 is a fiberglass COM antenna only. Here is the Cheif web page on NAV/GS/Loc antennas: http://www.chiefaircraft.com/airsec/Aircraft/Antennas/ComantIndustries-NAV.h tml In any case, I mounted a CI-158C in the fin of my RV-8 and it works very nicely there. Here are some pictures of the installation: Finished Installation: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 67041&row=1 Installation Techniques: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 66967&row=49 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 66968&row=48 Best regards, - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left... ________________________________________________________________________________
Date: Mar 27, 2011
No It's a C-215 but I shall adapt the same technique. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, 27 March 2011 4:25 AM rv7-list(at)matronics.com Subject: RV10-List: Re: NAV/COM/GS Antenna >At 02:53 PM 1/26/2011 Wednesday, you wrote: >Gday all, >I bought a Comant CI-121 NAV/COM/GS Antenna (V dipole) to install on my VS but I have discovered that it wont fit. >The diameter of the mounting base is 2.5 inches and that will not fit into the Fibreglass Fairing on top of the VS. >Which V dipoles have other people used on their VS? > >Cheers > >John MacCallum >Builder 41016 > >Rydal NSW Australia Hi John, I realize you posted about this a few months old, but I thought I'd comment on your VOR antenna mounting conundrum. You called out a "CI-121 Nav/COM/GS", but I think you really meant something like a CI-158C which is a Di-pole VOR/GS/Loc antenna. The CI-121 is a fiberglass COM antenna only. Here is the Cheif web page on NAV/GS/Loc antennas: http://www.chiefaircraft.com/airsec/Aircraft/Antennas/ComantIndustries-NAV.h tml In any case, I mounted a CI-158C in the fin of my RV-8 and it works very nicely there. Here are some pictures of the installation: Finished Installation: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 67041&row=1 Installation Techniques: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 66967&row=49 http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&log 66968&row=48 Best regards, - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 160+ Hours TTSN - Paint Job Is All That's Left... ________________________________________________________________________________
Date: Mar 27, 2011
Subject: RV-10 TAIL KIT
I'm listing this for a friend who has an RV-10 Tail Kit for sale. The eleva tors, vertical stab and rudder are done, the rest is in Van's original box. He's asking $2800=C2- or best offer. He prefers pickup, but could ship. =C2- Contact Ed Athey=C2- (423) 863-4466.=C2- Owner is located in Lim estone, TN. Thanks, Walt Shipley RV-8, RV-8A,=C2- RV-12 under construction ________________________________________________________________________________
Subject: nose wheel wheelpant bracket
Date: Mar 27, 2011
After 400 hours, the left side bracket developed a crack; If allowed to continue will result in destruction of the wheel pant. Pictures tomorrow of crack and fix. ________________________________________________________________________________
Date: Mar 27, 2011
Subject: ACK ELT - is anyone getting them shipped?
Just curious.. and ready. I've had one on order thru ACS since forever. Bill ________________________________________________________________________________
Subject: Re: ACK ELT - is anyone getting them shipped?
Date: Mar 27, 2011
They shipped some out already, and more will go right after the AEA show they said....and they have a pile of programmers to ship to the distributors too. I was hoping to get mine by 3/31, but it sounds like a couple weeks perhaps before everyone has the programmers and knows how to use them. They did say if you didnt care about international use you could get it unprogrammed or something like that perhaps...with no country code, but I'm not sure about that. I'd just wait for the dealers to have the programmers....the ELT is such a minor install, you could do it just before flying. So anyway, that's what I heard when I called them late last week....they were pumped up and shipping some, but had to get to the AEA show for a few days before they sent out tons more. I'm #8 in line from the dealer I bought from so it should be pretty soon for me. Tim On Mar 27, 2011, at 8:00 PM, Bill Watson wrote: > > Just curious.. and ready. I've had one on order thru ACS since forever. > > Bill > > > > ________________________________________________________________________________
Subject: Re: For those that haven't bought their avionics yet..................
Date: Mar 27, 2011
I'm behind on my reading and thus late to the fight but had something to contribute. William noted the advancement of touch screens in military and now GA aircraft and the importance of human factors. All are subject to the effects of turbulence regarding the ability of the pilot to enter data. GA aircraft are more susceptible to turbulence due to light wing loading. The key is anchoring your hand to effect inputs to the device. I saw the video on the new Garmin touch screen device but could not visualize the ability to stabilize your hand while inputing data. Even in the mid eighties, the Brits and others discovered ways to input data into nav computers, in this case the Jaguar, while flying low level at significant speeds when even heavy aircraft were susceptible to the effects turbulence. I remember holding the glare shield with my left hand fingers while entering the data one number at a time with my thumb into a remote data key pad as the airplane is jumping all around. This remote pad was conveniently located on the left glare shield so I could still fly with the right hand and stay heads-up during the low-level flying. It worked quite well. Maybe we don't need a glare shield mounted remote key pad but I'm not yet sold on the touch screens mid-panel mounted in GA aircraft susceptible to effects of turbulence until I see how to anchor my hand while entering data. Need to see this one in-flight to make a determination. My 2-cents, Tom On Mar 24, 2011, at 12:43 PM, William Curtis wrote: > > For better or worse (and I think better) touch screen interface in > aircraft, cars, etc are here to stay at least until reliable voice > control or maybe direct mind control :-) comes about. Touch screen > can be done badly, such as the Bendix/King AV8OR line, and it can be > done well such as Garmin and iPad. > > Anchoring your hand with an intuitive touch screen interface is IMHO > quicker and easier for data entry than knobs or buttons. I've flown > with my land Nuvi RAM mounted on the panel and iPad and have no issues > with entering commands in turbulence. If you look on the Avweb video > you will see the Garmin pilot rest three fingers on the bezel while > entering commands with his index finger. All operations were faster > than if those commands were being entered with knobs. When done this > was, data entry is effortless. If you allow you hand to freely float > above the screen it will be difficult. > > The F-18 Super Hornet upgrade and the next generation F-35 fighter has > touch screen interfaces. The military usually invests a significant > amount of time and money in human factory testing. If touch screen was > such a bad thing, no consideration would be given to using it in the > "turbulent" environment of a combat cockpit. > > In 1998 Garmin introduced the GNS-430 with a list price of $10,995. > In 2007? Garmin introduced the GNS-430W with a list price of $11,295. > In 2011 Garmin introduces the GTN 650 with a list price of $11,495. > > Is this a new product too fast or too expensive? I guess it is a > matter of perspective. For comparison, consider that the Bendix/King > KX-155 Nav/Comm transceiver with glidescope has a list price of > $5,008. > > -- > William > N40237 - http://wcurtis.nerv10.com/ > > On Thu, Mar 24, 2011 at 12:24 PM, Dave Saylor > wrote: >> >> It seems like touch screen would work a lot better as a kneeboard or >> on a console. Rubberbanding a route seems hopeless, about as difficult >> as writing legibly in the same position. I haven't flown with an ipad >> yet but the GPS in my car is mounted vertically next to the rear view >> mirror and even on smooth roads it can be difficult to use, especially >> doing stuff like entering text on the "keyboard". >> >> Also, I like the fact that I have three major brands in my panel. >> They work well together, and if something goes TU I don't have all my >> eggs in one basket. I guess you can still spread things around with >> this new hardware but the intention seems to be a single-brand >> solution. > > > > > ________________________________________________________________________________
Subject: Panel Pics
Date: Mar 27, 2011
Thought I would share some panel pics. Still finishing interior. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335230#335230 Attachments: http://forums.matronics.com//files/cid_img_1849_122.jpg http://forums.matronics.com//files/cid_img_1852_292.jpg ________________________________________________________________________________
Date: Mar 27, 2011
Subject: Panel Pics
Looking very stealth like. . I think my 8A seats might look like a good color combination for your interior. Very tidy workplace. Well done. BTW RV-list the G3X system updates are dirt simple. Robin Seats less blurry in person: [image: 2011-03-20 14.49.34.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Sunday, March 27, 2011 9:41 PM Subject: RV10-List: Panel Pics Thought I would share some panel pics. Still finishing interior. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335230#335230 Attachments: http://forums.matronics.com//files/cid_img_1849_122.jpg http://forums.matronics.com//files/cid_img_1852_292.jpg ________________________________________________________________________________
Subject: fuel valve bracket & clearance
Date: Mar 28, 2011
I have the old style fuel valve bracket that came with my quick build and see that there was a change later on so that the heat ducting can go above the valve and not below. I'm not sure that simply inverting the bracket will allow enough clearance, is someone familiar with the steps needed to modify to allow clearance? Seems the rudder cable uhmw guides are in the way, will also have to re-make fuel lines. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335256#335256 ________________________________________________________________________________
Subject: Key switch wiring
Date: Mar 28, 2011
Still having some issues in getting the Plasma III to fire correctly. I suspect I may have something wrong at the switch, or at least that is where I am starting my continued troubleshooting. I have been through the archives and saw several variations. I have the ACS keyswitch, Unison slick mag on the left and the Plasma III on the right. Does anyone with the exact same set-up working for them have a wire by wire connection diagram and a pic they can share? Eric Kallio N518RV... Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335259#335259 ________________________________________________________________________________
Date: Mar 28, 2011
Subject: Re: fuel valve bracket & clearance
I would first recommend deciding whether you want to stick with the Vans valve or upgrade to an Andair valve. That will influence where you ultimately mount the valve. I seem to recall one of the "new" style Vans valves failing at around 300 hours. Whether you move your valve at all probably depends on whether you will use heater for rear seat much or not. Or you could just ignore the issue and see whether you have any issues in the first year of flying. You will have to go back in there for first condition inspection anyway. On Mon, Mar 28, 2011 at 6:15 AM, rvdave wrote: > > I have the old style fuel valve bracket that came with my quick build and see that there was a change later on so that the heat ducting can go above the valve and not below. I'm not sure that simply inverting the bracket will allow enough clearance, is someone familiar with the steps needed to modify to allow clearance? Seems the rudder cable uhmw guides are in the way, will also have to re-make fuel lines. > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335256#335256 > > ________________________________________________________________________________
Subject: Re: Key switch wiring
Date: Mar 28, 2011
That's what I have and documented on my site, but don't trust it blindly because although it works great for me, it certainly isn't standard and doesnt make sense totally to me. I found it from another guy it worked for. Tim On Mar 28, 2011, at 8:50 AM, "Eric_Kallio" wrote: > > Still having some issues in getting the Plasma III to fire correctly. I suspect I may have something wrong at the switch, or at least that is where I am starting my continued troubleshooting. I have been through the archives and saw several variations. I have the ACS keyswitch, Unison slick mag on the left and the Plasma III on the right. Does anyone with the exact same set-up working for them have a wire by wire connection diagram and a pic they can share? > > Eric Kallio > N518RV... Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335259#335259 > > > > > > > > > ________________________________________________________________________________
Date: Mar 28, 2011
Hi Eric: I don't have my info handy at the moment but I wired mine up using Tim's (myrv10.com) as a reference and it works fine. search for "Electrical system tips" then Wiring a keyswitch. Should take care of it. Byron N253RV Phase 1 On Mon, Mar 28, 2011 at 9:50 AM, Eric_Kallio wrote: > > Still having some issues in getting the Plasma III to fire correctly. > I suspect I may have something wrong at the switch, or at least that > is where I am starting my continued troubleshooting. I have been > through the archives and saw several variations. I have the ACS > keyswitch, Unison slick mag on the left and the Plasma III on the > right. Does anyone with the exact same set-up working for them have a > wire by wire connection diagram and a pic they can share? > > Eric Kallio > N518RV... Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335259#335259 > > ________________________________________________________________________________
Date: Mar 28, 2011
I originally had mine (Andair) mounted at the top so I would not need an extension. After I got things plumbed up and rudder cables installed, I had to snake the heat scat to get it to the back. I was not at all happy that the heat duct was right next to the valve and fuel line plumbing, let alone riding next to the rudder cable for potential wear. I ended up mov ing the valve to the plans position and machining an extension myself. (Andair does offer extensions). I am happy with the results and feel a whole lot better that I am not exposing the valve and fuel lines to the heat carried in the duct. I really like the Andair valve but thinking back I should have probably stuck with the Van's supplied valve for simplicity of installation. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "rvdave" <davidbf(at)centurytel.net> Sent: Monday, March 28, 2011 9:15:15 AM Subject: RV10-List: fuel valve bracket & clearance I have the old style fuel valve bracket that came with my quick build and see that there was a change later on so that the heat ducting can go above the valve and not below. I'm not sure that simply inverting the bracket will allow enough clearance, is someone familiar with the steps needed to modify to allow clearance? Seems the rudder cable uhmw guides are in the way, will also have to re-make fuel lines. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335256#335256 ________________________________________________________________________________
Date: Mar 28, 2011
I received a 'bastard' QB kit - some parts for the old configuration, some for the new, so I had a chance to look at all the parts. Inverting the bracket will leave some holes in the wrong place. You need the new brackets. The rudder cables clear either installation. The fuel lines will need to be re-done, removing the "cross over". The 'new' setup also uses a few more AN fittings, rather than continuous tube and rubber grommets, going into the tunnel area. The 'new' valve is identical to the old one, except the shaft has been thinned slightly to allow an extender tube to go over it. IMHO the best (only?) reason to change to the new set up is that the new handle looks much nicer, and has a positive 'lift to change tanks' detent. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335293#335293 ________________________________________________________________________________
Date: Mar 28, 2011
I received a 'bastard' QB kit - some parts for the old configuration, some for the new, so I had a chance to look at all the parts. Inverting the bracket will leave some holes in the wrong place. You need the new brackets. The rudder cables clear either installation. The fuel lines will need to be re-done, removing the "cross over". The 'new' setup also uses a few more AN fittings, rather than continuous tube and rubber grommets, going into the tunnel area. The 'new' valve is identical to the old one, except the shaft has been thinned slightly to allow an extender tube to go over it. IMHO the best (only?) reason to change to the new set up is that the new handle looks much nicer, and has a positive 'lift to change tanks' detent. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335294#335294 ________________________________________________________________________________
Date: Mar 28, 2011
Tim, I did base what I have on you site. Much of what I have used as a reference has come from you and Deems. I am just not getting any spark from the lightspeed, ever. So I am fishing to see how someone else may have cracked this nut. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335297#335297 ________________________________________________________________________________
Date: Mar 28, 2011
David, I was with you all the way till the simplicity part. I personally feel the Andair fuel valve is worth the effort over the Vans Fuel valve. Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of * davidsoutpost(at)comcast.net *Sent:* Monday, March 28, 2011 9:58 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: fuel valve bracket & clearance I originally had mine (Andair) mounted at the top so I would not need an extension. After I got things plumbed up and rudder cables installed, I had to snake the heat scat to get it to the back. I was not at all happy that the heat duct was right next to the valve and fuel line plumbing, let alone riding next to the rudder cable for potential wear. I ended up moving the valve to the plans position and machining an extension myself. (Andair does offer extensions). I am happy with the results and feel a whole lot better that I am not exposing the valve and fuel lines to the heat carried in the duct. I really like the Andair valve but thinking back I should have probably stuck with the Van's supplied valve for simplicity of installation. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "rvdave" <davidbf(at)centurytel.net> Sent: Monday, March 28, 2011 9:15:15 AM Subject: RV10-List: fuel valve bracket & clearance I have the old style fuel valve bracket that came with my quick build and see that there was a change later on so that the heat ducting can go above the valve and not below. I'm not sure that simply inverting the bracket will allow enough clearance, is someone familiar with the steps needed to modify to allow clearance? Seems the rudder cable uhmw guides are in the way, will also have to re-make fuel lines. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335256#335256 ; -Mat============== * * * * * * ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 28, 2011
Eric did you verify the gap between the magnets and the sensor-this can be very critical and can lead to intermittent problems-Just a thought based on my experience-Jim -----Original Message----- From: Eric_Kallio <scout019(at)msn.com> Sent: Mon, Mar 28, 2011 11:29 am Subject: RV10-List: Re: Key switch wiring Tim, I did base what I have on you site. Much of what I have used as a refe rence as come from you and Deems. I am just not getting any spark from the ightspeed, ever. So I am fishing to see how someone else may have cracked t his ut. Eric ead this topic online here: http://forums.matronics.com/viewtopic.php?p=335297#335297 -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Mar 28, 2011
Tim, It will fire like that. I had worked through that the first time I was having issues with it kicking back the engine during crank. Although I could start the engine fine with the CB pulled then reset it and everything ran fine. I know it will fire, it is just a matter of getting it wired right on the keyswitch so I am getting the correct ignition retarded and the engine starts. The first time I had it wired to the sheet from ACS. The second time I wired it as you did, and I am getting the Plasma constantly disabled. I have checked the switch with a multi-meter and it appears to be functioning correctly. I am going to SunNFun this weekend so I may do some poking around down there and chat with the Stein and his folks. I think my big issue is going to be where to jumper the key switch and where the p-lead form the mag ground go. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335326#335326 ________________________________________________________________________________
Date: Mar 28, 2011
I guess what I meant by simplicity is that if I had just stuck with the pla ns fuel valve set-up,,,,it would have been done right the first time. I spe nt the better part of a full day redoing everything and machining the valve extension. Contrary to what someone else said,,,I had interference with th e rudder cable and would have had to make the scat tube oval shaped around the Andair valve and fuel line/fitting,,,,then fasten it to the valve to ho ld it in place,,,,something I was not willing to do. Another option was to sheath the cable,,,,,but I really wanted to get some distance from the fuel valve and fuel lines so it was worth the effort. The discussion on the And air vs. Van's fuel valve has been pretty well hashed over many times. The m ajority of builders have had very good success with Van's valve set up. I e ven went so far as to assemble the valve with the van's detent kit and like d the way it operated,,,,,you have to lift the selector pointer to change t anks and it locks back down into position similiar to the way the Andair op erates. The one thing I did not like about the Andair is that the L/R tank position can be changed without lifting the pointer handle,,,,it is only he ld in position by an internal valve "click" detent that is easily moved wit h little effort. Fearing accidentally bumping the valve pointer somewhere i n between the L/R position,,,I made mine so that the pointer handle has to be lifted to move from L/R and to the OFF position. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Robin Marks" <robin(at)PaintTheWeb.com> Sent: Monday, March 28, 2011 3:45:41 PM Subject: RE: RV10-List: fuel valve bracket & clearance David, I was with you all the way till the simplicity part. I personally feel the Andair fuel valve is worth the effort over the Vans Fuel valve. Robin From: owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server@ matronics.com ] On Behalf Of davidsoutpost(at)comcast.net Sent: Monday, March 28, 2011 9:58 AM Subject: Re: RV10-List: fuel valve bracket & clearance I originally had mine (Andair) mounted at the top so I would not need an ex tension. After I got things plumbed up and rudder cables installed, I had t o snake the heat scat to get it to the back. I was not at all happy that th e heat duct was right next to the valve and fuel line plumbing, let alone r iding next to the rudder cable for potential wear. I ended up moving the va lve to the plans position and machining an extension myself. (Andair does o ffer extensions). I am happy with the results and feel a whole lot better t hat I am not exposing the valve and fuel lines to the heat carried in the d uct. I really like the Andair valve but thinking back I should have probabl y stuck with the Van's supplied valve for simplicity of installation. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "rvdave" < davidbf(at)centurytel.net > Sent: Monday, March 28, 2011 9:15:15 AM Subject: RV10-List: fuel valve bracket & clearance I have the old style fuel valve bracket that came with my quick build and s ee that there was a change later on so that the heat ducting can go above t he valve and not below. I'm not sure that simply inverting the bracket will allow enough clearance, is someone familiar with the steps needed to modif y to allow clearance? Seems the rudder cable uhmw guides are in the way, wi ll also have to re-make fuel lines. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335256#335256 ; -Mat=============== Day Browse, Chat, FAQ, w.matronics.com/Navigator?RV10-List">http://www.matr onics.com/Navigator?RV1 ================= ====== m">http://forums.matronics.com http://www.matronics.com/ contribution ==================== === No virus found in this message. Checked by AVG - www.avg.com ================ == ________________________________________________________________________________
Date: Mar 28, 2011
Subject: Flight Guide - Airguide publications
Hmmmmm, My wife just dropped an envelope on my desk and on opening it I find a copy of Airguides new format 'Flight Guide' for the Western States. I did Not order this. When, I received the renewal form in the mail, I tossed it in favor of my Foreflight ipad app. Is this some kind of marketing ploy? I checked my bank acct and no debits have been entered. Has something similar happened to anyone else? Deems ________________________________________________________________________________
Date: Mar 28, 2011
? I ordered and paid for mine and have not received it yet. I guess I made someone mad....... :) Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Monday, March 28, 2011 7:39 PM Subject: RV10-List: Flight Guide - Airguide publications Hmmmmm, My wife just dropped an envelope on my desk and on opening it I find a copy of Airguides new format 'Flight Guide' for the Western States. I did Not order this. When, I received the renewal form in the mail, I tossed it in favor of my Foreflight ipad app. Is this some kind of marketing ploy? I checked my bank acct and no debits have been entered. Has something similar happened to anyone else? Deems ________________________________________________________________________________
Subject: Re: Elevator trim setting
From: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Date: Mar 28, 2011
I would like to know others opinions on this topic. I might be willing to set mine up this way. Here's where I am at now, going by the plans. I set both trim tabs to 35 degrees down and when I bring them up to trail position, the right side is higher than the left side. Please help me set my trim tabs up correctly. Thanks, Jake Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335375#335375 ________________________________________________________________________________
Date: Mar 28, 2011
Subject: Re: Flight Guide - Airguide publications
Hmmmmmmm, Deems it is either a marketing ploy or someone at your airport or another airport heard you fly in to the wrong airport, on the wrong frequency, landed on the wrong runway, taxied on the wrong taxi way, tied down in the wrong spot and took the wrong airport car and they are just trying to help out. Yaeeee, definitely a marketing ploy. Do no archive -Scott Schmidt ________________________________ From: Deems Davis <deemsdavis(at)cox.net> Sent: Mon, March 28, 2011 7:39:05 PM Subject: RV10-List: Flight Guide - Airguide publications Hmmmmm, My wife just dropped an envelope on my desk and on opening it I find a copy of Airguides new format 'Flight Guide' for the Western States. I did Not order this. When, I received the renewal form in the mail, I tossed it in favor of my Foreflight ipad app. Is this some kind of marketing ploy? I checked my bank acct and no debits have been entered. Has something similar happened to anyone else? Deems ________________________________________________________________________________
Date: Mar 29, 2011
I set mine up as Bill DeRouchey suggests in the post above yours. Mine works fine, with no problems. I believe you will have more nose up trim authority this way. Others have set theirs up this way, and others have done it per the plans. You get to choose. :) -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335383#335383 ________________________________________________________________________________
Date: Mar 29, 2011
Here is Bill's revised post, works great for us. Later, - Lew Date: Tue, 12 Feb 2008 10:55:08 -0800 From: billderou(at)yahoo.com Subject: RE: RV10-List: alternate elevator trim settings or twisted tail John- Talking about nose up/down and elevator trim up/down could be causing the confusion since they move opposite to one another. Its also important to recognize when the positioning is created by the servo end travel or the trim trailing edge. Another problem causing confusion is communicating in degrees. I do not believe that when Van says "-35 degrees" that this setting can be accurately repeated for X hundred aircraft, nor do I believe that Vans two factory RV-10's are set to -35 degrees. All of my settings and conclusions were drawn from doing the Trig and cutting out accurate triangles. This is also why I specified a vertical 3" of measurement to eliminate the errors. So - lets take another run at it: 1. Run the trim servo to its end point where the right (starboard) elevator trim tab is full down. Full down is determined by the servo stopping and not the trim tab jamming. 2. Set the trim tab trailing edge to 3" vertically below and normal to the elevator trailing edge. 3. Get someone else to run the trim servo switch and have them slowly raise the right elevator trim tab until it exactly aligns with the elevator trailing edge. This is not the end of the servo run - it is determined by the trailing edges matching. 4. Set the left (port) elevator trim tab trailing edge to align with the elevator trailing edge. Its very simple and much easier than working with the -35 degree spec for each surface. I did communicate and was supported by Vans engineering on this subject. However, I believe the priority of the RV-12 got in the way of following this issue to its conclusion. Bill -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335387#335387 ________________________________________________________________________________
Date: Mar 29, 2011
I also used Bill's info and took some photos and did a write-up here: http://www.myrv10.com/N104CD/maintenance/20080622/index.html In short, you want to get it so that both are neutral at the same time, and you never have a situation where one is up and the other is down. If you can do that, you're probably doing just fine. Tim On 3/29/2011 6:55 AM, Lew Gallagher wrote: > --> RV10-List message posted by: "Lew Gallagher" > > Here is Bill's revised post, works great for us. > Later, - Lew > > > Date: Tue, 12 Feb 2008 10:55:08 -0800 > From: billderou(at)yahoo.com > Subject: RE: RV10-List: alternate elevator trim settings or twisted tail > To: rv10-list(at)matronics.com > > John- > Talking about nose up/down and elevator trim up/down could be causing the confusion since they move opposite to one another. Its also important to recognize when the positioning is created by the servo end travel or the trim trailing edge. > Another problem causing confusion is communicating in degrees. I do not believe that when Van says "-35 degrees" that this setting can be accurately repeated for X hundred aircraft, nor do I believe that Vans two factory RV-10's are set to -35 degrees. All of my settings and conclusions were drawn from doing the Trig and cutting out accurate triangles. This is also why I specified a vertical 3" of measurement to eliminate the errors. > So - lets take another run at it: > 1. Run the trim servo to its end point where the right (starboard) elevator trim tab is full down. Full down is determined by the servo stopping and not the trim tab jamming. > 2. Set the trim tab trailing edge to 3" vertically below and normal to the elevator trailing edge. > 3. Get someone else to run the trim servo switch and have them slowly raise the right elevator trim tab until it exactly aligns with the elevator trailing edge. This is not the end of the servo run - it is determined by the trailing edges matching. > 4. Set the left (port) elevator trim tab trailing edge to align with the elevator trailing edge. > Its very simple and much easier than working with the -35 degree spec for each surface. > I did communicate and was supported by Vans engineering on this subject. However, I believe the priority of the RV-12 got in the way of following this issue to its conclusion. > Bill > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335387#335387 > > ________________________________________________________________________________
Date: Mar 29, 2011
I followed the write up on Tim's web site and it worked out perfect in trail from neutral thru full up elevator the neutral and one tab on the down elevator. Tim has a great how to write up on his site I would highly recommend this to anyone. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Tuesday, March 29, 2011 6:33 AM Subject: Re: RV10-List: Re: Elevator trim setting I also used Bill's info and took some photos and did a write-up here: http://www.myrv10.com/N104CD/maintenance/20080622/index.html In short, you want to get it so that both are neutral at the same time, and you never have a situation where one is up and the other is down. If you can do that, you're probably doing just fine. Tim On 3/29/2011 6:55 AM, Lew Gallagher wrote: > --> RV10-List message posted by: "Lew Gallagher" > > Here is Bill's revised post, works great for us. > Later, - Lew > > > Date: Tue, 12 Feb 2008 10:55:08 -0800 > From: billderou(at)yahoo.com > Subject: RE: RV10-List: alternate elevator trim settings or twisted > tail > To: rv10-list(at)matronics.com > > John- > Talking about nose up/down and elevator trim up/down could be causing the confusion since they move opposite to one another. Its also important to recognize when the positioning is created by the servo end travel or the trim trailing edge. > Another problem causing confusion is communicating in degrees. I do not believe that when Van says "-35 degrees" that this setting can be accurately repeated for X hundred aircraft, nor do I believe that Vans two factory RV-10's are set to -35 degrees. All of my settings and conclusions were drawn from doing the Trig and cutting out accurate triangles. This is also why I specified a vertical 3" of measurement to eliminate the errors. > So - lets take another run at it: > 1. Run the trim servo to its end point where the right (starboard) elevator trim tab is full down. Full down is determined by the servo stopping and not the trim tab jamming. > 2. Set the trim tab trailing edge to 3" vertically below and normal to the elevator trailing edge. > 3. Get someone else to run the trim servo switch and have them slowly raise the right elevator trim tab until it exactly aligns with the elevator trailing edge. This is not the end of the servo run - it is determined by the trailing edges matching. > 4. Set the left (port) elevator trim tab trailing edge to align with the elevator trailing edge. > Its very simple and much easier than working with the -35 degree spec for each surface. > I did communicate and was supported by Vans engineering on this subject. However, I believe the priority of the RV-12 got in the way of following this issue to its conclusion. > Bill > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335387#335387 > > ________________________________________________________________________________
Subject: brake linings
Date: Mar 29, 2011
Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is 066-11200)? Spruce does not carry and Vans wants $60 + for a set of Clevelands. ________________________________________________________________________________
Date: Mar 29, 2011
Subject: Re: brake linings
http://www.trade-a-plane.com/detail/1258510.html Aircraft Supply in PA...$18.50 It is also used on the Beech Skipper On Tue, Mar 29, 2011 at 4:31 PM, DLM wrote: > Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is > 066-11200)? Spruce does not carry and Vans wants $60 + for a set of > Clevelands. > > ________________________________________________________________________________
Date: Mar 29, 2011
Spruce has carried them in the past. I just found them online I think from Skygeek.com too for $18.99 each. There are no Rapco's available yet. Rapco is in the process of making them and getting them out but they said 2-3 more months. I started talking to them back in 2006 or 2007 about making them for the RV-10 and they're finally about to get them in production. They told me last week that when they're available, Desser Tire will have them first, but that it will at least be 2-3 months yet. For now, your only choice is Cleveland. Oh, and I saw that Desser will likely be selling them for $16.99, so sadly, it's not going to be a huge savings...only $8 for a complete brake job. Tim On 3/29/2011 6:31 PM, DLM wrote: > Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is > 066-11200)? Spruce does not carry and Vans wants $60 + for a set of > Clevelands. > > * ________________________________________________________________________________
Date: Mar 29, 2011
Just talked to the Rapco guys here at Sun and Fun, and they are going to go ahead and release them to Desser for sale... prior to attaining the FAA blessing.... probably 2 to 3 weeks, and at a much better price. Don McDonald Here at Lakeland in my RV41. ________________________________ From: DLM <dlm34077(at)q.com> Sent: Tue, March 29, 2011 6:31:55 PM Subject: RV10-List: brake linings Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is 066-11200)? Spruce does not carry and Vans wants $60 + for a set of Clevelands. ________________________________________________________________________________
Subject: Brakes and wheels info
Date: Mar 29, 2011
Another nice RV-10 builder tipped me off that a couple of offsite links to nice wheel/brake parts diagrams were broken so I did one better and found them again, along with more stuff. Towards the bottom of this page are some links you may want for future maintenance an parts needs. http://www.myrv10.com/N104CD/maintenance/20061104/index.html Have at it! Tim ________________________________________________________________________________
Date: Mar 29, 2011
desser carries them http://www.vansaircrafttires.com/categories/RV%252d10/Brakes/ From: DLM Sent: Tuesday, March 29, 2011 4:31 PM Subject: RV10-List: brake linings Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is 066-11200)? Spruce does not carry and Vans wants $60 + for a set of Clevelands. ________________________________________________________________________________
Date: Mar 29, 2011
I hope the "much better" that Desser is advertising them for ends up changing to a real actual "much" better. The Clevelands I saw for $18.99. Desser wanted $16.99 for the Rapcos. I think many other types of pads are under $10 for Rapco's. If they can't do better than cutting $2 off, I can't consider it "much". I'd love to see them for $10 each. Tim On 3/29/2011 8:54 PM, Don McDonald wrote: > Just talked to the Rapco guys here at Sun and Fun, and they are going to > go ahead and release them to Desser for sale... prior to attaining the > FAA blessing.... probably 2 to 3 weeks, and at a much better price. > Don McDonald > Here at Lakeland in my RV41. > > ------------------------------------------------------------------------ > *From:* DLM > *To:* rv10-list(at)matronics.com > *Sent:* Tue, March 29, 2011 6:31:55 PM > *Subject:* RV10-List: brake linings > > Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is > 066-11200)? Spruce does not carry and Vans wants $60 + for a set of > Clevelands. > > * ________________________________________________________________________________
Date: Mar 30, 2011
Vans quotes $66 for a set of four plus rivets - that's $16.50 each, Rodger --- On Wed, 30/3/11, Tim Olson wrote: > From: Tim Olson <Tim(at)myrv10.com> > Subject: Re: RV10-List: brake linings > To: rv10-list(at)matronics.com > Date: Wednesday, 30 March, 2011, 5:39 > Tim Olson > > I hope the "much better" that Desser is advertising them > for > ends up changing to a real actual "much" better. The > Clevelands I saw for $18.99. Desser wanted $16.99 > for > the Rapcos. I think many other types of pads are under > $10 for Rapco's. If they can't do better than > cutting > $2 off, I can't consider it "much". I'd love to > see them for $10 each. > Tim > > > On 3/29/2011 8:54 PM, Don McDonald wrote: > > Just talked to the Rapco guys here at Sun and Fun, and > they are going to > > go ahead and release them to Desser for sale... prior > to attaining the > > FAA blessing.... probably 2 to 3 weeks, and at a much > better price. > > Don McDonald > > Here at Lakeland in my RV41. > > > > > ------------------------------------------------------------------------ > > *From:* DLM > > *To:* rv10-list(at)matronics.com > > *Sent:* Tue, March 29, 2011 6:31:55 PM > > *Subject:* RV10-List: brake linings > > > > Anyone found a good source for Rapco RA66-112 > (Cleveland equivalent is > > 066-11200)? Spruce does not carry and Vans wants $60 + > for a set of > > Clevelands. > > > > * > > Forum - > FAQ, > - MATRONICS WEB FORUMS - > List Contribution Web Site - > -Matt > Dralle, List Admin. > > > > ________________________________________________________________________________
Date: Mar 30, 2011
Today, that's a good deal. I should warn you RV-10 guys....brakes may not last you long until you get it in your head not to ride them. My first set lasted 150 hours or so, as a guess....I hit 170 and the rivets were hitting the rotors. My next set went longer. But, if you fly 100 hrs/year, you'll want to inspect every spring and fall and you will likely replace them every other year. I'm sure many people will do better than me, too, but either way, always keep a spare set on hand....you will find that it is nice not to scramble to order them when you suddenly need them, because they're not convenient to change with wheel fairings. That's why I have no air fill ports on the fairings....it provides the necessary Motivation to pop off the fairing occasionally and replace or inspect the brakes. Tim On Mar 30, 2011, at 2:22 AM, Rodger Todd wrote: > > Vans quotes $66 for a set of four plus rivets - that's $16.50 each, > > Rodger > > --- On Wed, 30/3/11, Tim Olson wrote: > >> From: Tim Olson <Tim(at)myrv10.com> >> Subject: Re: RV10-List: brake linings >> To: rv10-list(at)matronics.com >> Date: Wednesday, 30 March, 2011, 5:39 >> Tim Olson >> >> I hope the "much better" that Desser is advertising them >> for >> ends up changing to a real actual "much" better. The >> Clevelands I saw for $18.99. Desser wanted $16.99 >> for >> the Rapcos. I think many other types of pads are under >> $10 for Rapco's. If they can't do better than >> cutting >> $2 off, I can't consider it "much". I'd love to >> see them for $10 each. >> Tim >> >> >> On 3/29/2011 8:54 PM, Don McDonald wrote: >>> Just talked to the Rapco guys here at Sun and Fun, and >> they are going to >>> go ahead and release them to Desser for sale... prior >> to attaining the >>> FAA blessing.... probably 2 to 3 weeks, and at a much >> better price. >>> Don McDonald >>> Here at Lakeland in my RV41. >>> >>> >> ------------------------------------------------------------------------ >>> *From:* DLM >>> *To:* rv10-list(at)matronics.com >>> *Sent:* Tue, March 29, 2011 6:31:55 PM >>> *Subject:* RV10-List: brake linings >>> >>> Anyone found a good source for Rapco RA66-112 >> (Cleveland equivalent is >>> 066-11200)? Spruce does not carry and Vans wants $60 + >> for a set of >>> Clevelands. >>> >>> * >> >> Forum - >> FAQ, >> - MATRONICS WEB FORUMS - >> List Contribution Web Site - >> -Matt >> Dralle, List Admin. >> >> >> >> > > > > > > > ________________________________________________________________________________
Date: Mar 30, 2011
I've had the opportunity to fly RV-10's with and without rudder pedal extensions. I believe the rudder pedal extensions make staying off the brakes a whole lot easier. The angle of the pedals make it pretty hard to do without the extensions. This seems to be more true for taller pilots with bigger feet. I gave some transition training to a gentleman who purchased a flying RV-10 a couple of weeks ago. He was a big guy and had a real problem keeping his feet off the brakes. I am not sure, but suspect the rudder pedals were in the aft position on his airplane and that probably aggravated the problem. I installed the rudder pedal extensions from http://www.mlblueskunk.com/Rudder_pedal_Extensions.html and they are working great for me. There are other vendors selling similar extensions as well. I planned to change brake linings at my last condition inspection in December, but they were only about half worn at 300+ hours. I am going to take another look at them this week. Now that I am using my airplane for a little bit of Transition Training, I am sure the wear will accelerate. -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335495#335495 Attachments: http://forums.matronics.com//files/img_1640_970.jpg http://forums.matronics.com//files/img_1637_189.jpg http://forums.matronics.com//files/img_1546_342.jpg ________________________________________________________________________________
Date: Mar 30, 2011
I agree that a lot of pilots ride the brakes. While checking out another pilot in my 10, I did not notice he was on the brakes until we touched and then hopped on the nose wheel. I now fly with my feet on the weldments and deliberately move feet to centers to apply brakes. I will be suggesting that others who fly my aircraft avoid using the brakes on landing. ----- Original Message ----- From: "Tim Olson" <Tim(at)myrv10.com> Sent: Wednesday, March 30, 2011 4:46 AM Subject: Re: RV10-List: brake linings > > Today, that's a good deal. I should warn you RV-10 guys....brakes may not > last you long until you get it in your head not to ride them. My first > set lasted 150 hours or so, as a guess....I hit 170 and the rivets were > hitting the rotors. My next set went longer. But, if you fly 100 > hrs/year, you'll want to inspect every spring and fall and you will likely > replace them every other year. I'm sure many people will do better than > me, too, but either way, always keep a spare set on hand....you will find > that it is nice not to scramble to order them when you suddenly need them, > because they're not convenient to change with wheel fairings. That's why > I have no air fill ports on the fairings....it provides the necessary > Motivation to pop off the fairing occasionally and replace or inspect the > brakes. > Tim > > > On Mar 30, 2011, at 2:22 AM, Rodger Todd wrote: > >> >> Vans quotes $66 for a set of four plus rivets - that's $16.50 each, >> >> Rodger >> >> --- On Wed, 30/3/11, Tim Olson wrote: >> >>> From: Tim Olson <Tim(at)myrv10.com> >>> Subject: Re: RV10-List: brake linings >>> To: rv10-list(at)matronics.com >>> Date: Wednesday, 30 March, 2011, 5:39 >>> Tim Olson >>> >>> I hope the "much better" that Desser is advertising them >>> for >>> ends up changing to a real actual "much" better. The >>> Clevelands I saw for $18.99. Desser wanted $16.99 >>> for >>> the Rapcos. I think many other types of pads are under >>> $10 for Rapco's. If they can't do better than >>> cutting >>> $2 off, I can't consider it "much". I'd love to >>> see them for $10 each. >>> Tim >>> >>> >>> On 3/29/2011 8:54 PM, Don McDonald wrote: >>>> Just talked to the Rapco guys here at Sun and Fun, and >>> they are going to >>>> go ahead and release them to Desser for sale... prior >>> to attaining the >>>> FAA blessing.... probably 2 to 3 weeks, and at a much >>> better price. >>>> Don McDonald >>>> Here at Lakeland in my RV41. >>>> >>>> >>> ------------------------------------------------------------------------ >>>> *From:* DLM >>>> *To:* rv10-list(at)matronics.com >>>> *Sent:* Tue, March 29, 2011 6:31:55 PM >>>> *Subject:* RV10-List: brake linings >>>> >>>> Anyone found a good source for Rapco RA66-112 >>> (Cleveland equivalent is >>>> 066-11200)? Spruce does not carry and Vans wants $60 + >>> for a set of >>>> Clevelands. >>>> >>>> * >>> >>> Forum - >>> FAQ, >>> - MATRONICS WEB FORUMS - >>> List Contribution Web Site - >>> -Matt >>> Dralle, List Admin. >>> >>> >>> >>> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 30, 2011
My suggestion is those at SnF talk to Ken at the Desser booth, he is the one driving all the parts for the -10, the other folks there wont know. Ask him about the pads and other -10 parts in the works. Tell him you want better pricing on the pads. He has been more than willing to make it work for the RV's in general and I have found he listens to suggestions. Pascal -------------------------------------------------- From: "Tim Olson" <Tim(at)myrv10.com> Sent: Tuesday, March 29, 2011 8:39 PM Subject: Re: RV10-List: brake linings > > I hope the "much better" that Desser is advertising them for > ends up changing to a real actual "much" better. The > Clevelands I saw for $18.99. Desser wanted $16.99 for > the Rapcos. I think many other types of pads are under > $10 for Rapco's. If they can't do better than cutting > $2 off, I can't consider it "much". I'd love to > see them for $10 each. > Tim > > > On 3/29/2011 8:54 PM, Don McDonald wrote: >> Just talked to the Rapco guys here at Sun and Fun, and they are going to >> go ahead and release them to Desser for sale... prior to attaining the >> FAA blessing.... probably 2 to 3 weeks, and at a much better price. >> Don McDonald >> Here at Lakeland in my RV41. >> >> ------------------------------------------------------------------------ >> *From:* DLM >> *To:* rv10-list(at)matronics.com >> *Sent:* Tue, March 29, 2011 6:31:55 PM >> *Subject:* RV10-List: brake linings >> >> Anyone found a good source for Rapco RA66-112 (Cleveland equivalent is >> 066-11200)? Spruce does not carry and Vans wants $60 + for a set of >> Clevelands. >> >> * > > > ________________________________________________________________________________
Date: Mar 30, 2011
Mike Seager taught me to keep my heels on the floor until after the nosewheel touches down. Seems to work well. -Rob On Wed, Mar 30, 2011 at 6:50 AM, DLM wrote: > > I agree that a lot of pilots ride the brakes. While checking out another > pilot in my 10, I did not notice he was on the brakes until we touched and > then hopped on the nose wheel. I now fly with my feet on the weldments and > deliberately move feet to centers to apply brakes. I will be suggesting that > others who fly my aircraft avoid using the brakes on landing. > ----- Original Message ----- From: "Tim Olson" <Tim(at)myrv10.com> > > To: > Sent: Wednesday, March 30, 2011 4:46 AM > > Subject: Re: RV10-List: brake linings > > >> >> Today, that's a good deal. I should warn you RV-10 guys....brakes may not >> last you long until you get it in your head not to ride them. My first set >> lasted 150 hours or so, as a guess....I hit 170 and the rivets were hitting >> the rotors. My next set went longer. But, if you fly 100 hrs/year, you'll >> want to inspect every spring and fall and you will likely replace them every >> other year. I'm sure many people will do better than me, too, but either >> way, always keep a spare set on hand....you will find that it is nice not to >> scramble to order them when you suddenly need them, because they're not >> convenient to change with wheel fairings. That's why I have no air fill >> ports on the fairings....it provides the necessary >> Motivation to pop off the fairing occasionally and replace or inspect the >> brakes. >> Tim >> >> >> >> On Mar 30, 2011, at 2:22 AM, Rodger Todd wrote: >> >>> >>> Vans quotes $66 for a set of four plus rivets - that's $16.50 each, >>> >>> Rodger >>> >>> --- On Wed, 30/3/11, Tim Olson wrote: >>> >>> From: Tim Olson <Tim(at)myrv10.com> >>>> Subject: Re: RV10-List: brake linings >>>> To: rv10-list(at)matronics.com >>>> Date: Wednesday, 30 March, 2011, 5:39 >>>> Tim Olson >>>> >>>> I hope the "much better" that Desser is advertising them >>>> for >>>> ends up changing to a real actual "much" better. The >>>> Clevelands I saw for $18.99. Desser wanted $16.99 >>>> for >>>> the Rapcos. I think many other types of pads are under >>>> $10 for Rapco's. If they can't do better than >>>> cutting >>>> $2 off, I can't consider it "much". I'd love to >>>> see them for $10 each. >>>> Tim >>>> >>>> >>>> On 3/29/2011 8:54 PM, Don McDonald wrote: >>>> >>>>> Just talked to the Rapco guys here at Sun and Fun, and >>>>> >>>> they are going to >>>> >>>>> go ahead and release them to Desser for sale... prior >>>>> >>>> to attaining the >>>> >>>>> FAA blessing.... probably 2 to 3 weeks, and at a much >>>>> >>>> better price. >>>> >>>>> Don McDonald >>>>> Here at Lakeland in my RV41. >>>>> >>>>> >>>>> >>>> ------------------------------------------------------------------------ >>>> >>>>> *From:* DLM >>>>> *To:* rv10-list(at)matronics.com >>>>> *Sent:* Tue, March 29, 2011 6:31:55 PM >>>>> *Subject:* RV10-List: brake linings >>>>> >>>>> Anyone found a good source for Rapco RA66-112 >>>>> >>>> (Cleveland equivalent is >>>> >>>>> 066-11200)? Spruce does not carry and Vans wants $60 + >>>>> >>>> for a set of >>>> >>>>> Clevelands. >>>>> >>>>> * >>>>> >>>> >>>> Forum - >>>> FAQ, >>>> - MATRONICS WEB FORUMS - >>>> List Contribution Web Site - >>>> -Matt >>>> Dralle, List Admin. >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 30, 2011
Re: RV10-List: brake linings HEALS ON THE FLOOR! That was what was drilled into me from early on in my flight training. It is nearly impossible to actuate the breaks with your heals touching the floor boards. For me I do that & keep the balls of my feet on the corners of the peddle assemblies until I need to apply the brakes. My first set of brakes lasts 195 hours including about 40 hours flying off of grass strips which can be substantially harder on the pads. Those pads still had 20+% left but since we were changing tires & tubes we changed the shoes as well. I hope to get 300 hours out of my second set flying exclusively on pavement. I am sure the rudder pedal extensions will help prevent brake riding. I am however reticent to add more weight & costs to my flying -10, especially for something I can do without if I use basic piloting skills. Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *DLM *Sent:* Wednesday, March 30, 2011 6:51 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: brake linings I agree that a lot of pilots ride the brakes. While checking out another pilot in my 10, I did not notice he was on the brakes until we touched and then hopped on the nose wheel. I now fly with my feet on the weldments and deliberately move feet to centers to apply brakes. I will be suggesting that others who fly my aircraft avoid using the brakes on landing. ----- Original Message ----- From: "Tim Olson" <Tim(at)myrv10.com> Sent: Wednesday, March 30, 2011 4:46 AM Subject: Re: RV10-List: brake linings > > Today, that's a good deal. I should warn you RV-10 guys....brakes may not > last you long until you get it in your head not to ride them. My first > set lasted 150 hours or so, as a guess....I hit 170 and the rivets were > hitting the rotors. My next set went longer. But, if you fly 100 > hrs/year, you'll want to inspect every spring and fall and you will likely > replace them every other year. I'm sure many people will do better than > me, too, but either way, always keep a spare set on hand....you will find > that it is nice not to scramble to order them when you suddenly need them, > because they're not convenient to change with wheel fairings. That's why > I have no air fill ports on the fairings....it provides the necessary > Motivation to pop off the fairing occasionally and replace or inspect the > brakes. > Tim > > > On Mar 30, 2011, at 2:22 AM, Rodger Todd wrote: > >> >> Vans quotes $66 for a set of four plus rivets - that's $16.50 each, >> >> Rodger >> >> --- On Wed, 30/3/11, Tim Olson wrote: >> >>> From: Tim Olson <Tim(at)myrv10.com> >>> Subject: Re: RV10-List: brake linings >>> To: rv10-list(at)matronics.com >>> Date: Wednesday, 30 March, 2011, 5:39 >>> Tim Olson >>> >>> I hope the "much better" that Desser is advertising them >>> for >>> ends up changing to a real actual "much" better. The >>> Clevelands I saw for $18.99. Desser wanted $16.99 >>> for >>> the Rapcos. I think many other types of pads are under >>> $10 for Rapco's. If they can't do better than >>> cutting >>> $2 off, I can't consider it "much". I'd love to >>> see them for $10 each. >>> Tim >>> >>> >>> On 3/29/2011 8:54 PM, Don McDonald wrote: >>>> Just talked to the Rapco guys here at Sun and Fun, and >>> they are going to >>>> go ahead and release them to Desser for sale... prior >>> to attaining the >>>> FAA blessing.... probably 2 to 3 weeks, and at a much >>> better price. >>>> Don McDonald >>>> Here at Lakeland in my RV41. >>>> >>>> >>> ------------------------------------------------------------------------ >>>> *From:* DLM >>>> *To:* rv10-list(at)matronics.com >>>> *Sent:* Tue, March 29, 2011 6:31:55 PM >>>> *Subject:* RV10-List: brake linings >>>> >>>> Anyone found a good source for Rapco RA66-112 >>> (Cleveland equivalent is >>>> 066-11200)? Spruce does not carry and Vans wants $60 + >>> for a set of >>>> Clevelands. >>>> >>>> * >>> >>> Forum - >>> FAQ, >>> - MATRONICS WEB FORUMS - >>> List Contribution Web Site - >>> -Matt >>> Dralle, List Admin. >>> >>> >>> >>> >> >> >> >> >> >> >> > > ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: Transition Training LODA
Date: Mar 30, 2011
The FAA today released a new Advisory Circular that addresses the need for transition training in Experimental AB aircraft, as well as any airplane that is new to a pilot. It can be seen here. http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentID/1018499 -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335523#335523 ________________________________________________________________________________
Date: Mar 30, 2011
Wow. That was easy. Thanks. -------- Jake Hearnsberger RV-10 Empennage Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335534#335534 ________________________________________________________________________________
Subject: Slanted Right Elevator Trim Tab
Date: Mar 30, 2011
I noticed last night when looking down the back of the tail cone that the trim tab on the right elevator appears to be slanted upward toward where the vs attaches. Maybe the photos can better explain. Jake H. -------- Jake Hearnsberger RV-10 Empennage Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335539#335539 Attachments: http://forums.matronics.com//files/img_0310_217.jpg http://forums.matronics.com//files/img_0307_155.jpg http://forums.matronics.com//files/img_0305_169.jpg ________________________________________________________________________________
Subject: ipad weather
Date: Mar 30, 2011
While at Sun n Fun I talked to wxworx about and ipad version. They just came out with a Mobile link that sends the wxworx receiver data to the ipad via wifi. They have their own app to show the weather on the ipad, but they also said they are in talks with ForeFlight and WingX using the weather with their programs. Any one interested can go to this link to this the info. https://www.baronservices.com/new Sun n Fun so far is like Oshkosh -- WET! This weekend may not be that bad but homebuilt turn out on Tuesday was very light. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335540#335540 ________________________________________________________________________________
Subject: Re: ipad weather
Date: Mar 30, 2011
For some reason the link did not come through. Try this: https://www.baronservices.com/news_pdf/MobileLink.pdf Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335541#335541 ________________________________________________________________________________
Subject: Re: Panel Pics
Date: Mar 30, 2011
Looks terrific - very professional! -------- Dave Moore RV-6 flying RV-10 QB - FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335542#335542 ________________________________________________________________________________
Date: Mar 30, 2011
Subject: Re: Slanted Right Elevator Trim Tab
It's really easy to build a twisted trim tab--I built two of them! It would probably fly fine but looks silly, so I rebuilt mine with new skins and spars. After you glue the foam ribs in, it's impossible to straighten (or at least I couldn't figure it out). -Rob On Wed, Mar 30, 2011 at 6:43 PM, JHearnsberger wrote: > jakehearnsberger(at)gmail.com> > > I noticed last night when looking down the back of the tail cone that the > trim tab on the right elevator appears to be slanted upward toward where the > vs attaches. Maybe the photos can better explain. > > Jake H. > > -------- > Jake Hearnsberger > RV-10 Empennage > Springhill, LA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335539#335539 > > > Attachments: > > http://forums.matronics.com//files/img_0310_217.jpg > http://forums.matronics.com//files/img_0307_155.jpg > http://forums.matronics.com//files/img_0305_169.jpg > > -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 31, 2011
Try to sight straight down the trailing edge, from the side....see if there is any bowing or fishtailing to the way the edge is. It looks like their either is some of that, or maybe some bending on the end, but it's hard to say from those photos. If you had a straight and true trim tab, it wouldn't likely be doing that. Try to do all photos or visuals from real consistent centered places though. All those photos are off center a bit so it's hard to tell what's an optical illusion and what's real. None of the parts in the fail feathers are very expensive, so if you find something that just isn't great and you figure out the cause, it wouldn't be a big deal to re-build. Tim Olson - RV-10 N104CD On 3/30/2011 8:43 PM, JHearnsberger wrote: > --> RV10-List message posted by: "JHearnsberger" > > I noticed last night when looking down the back of the tail cone that the trim tab on the right elevator appears to be slanted upward toward where the vs attaches. Maybe the photos can better explain. > > Jake H. > > -------- > Jake Hearnsberger > RV-10 Empennage > Springhill, LA > > > Attachments: > > http://forums.matronics.com//files/img_0310_217.jpg > http://forums.matronics.com//files/img_0307_155.jpg > http://forums.matronics.com//files/img_0305_169.jpg > > ________________________________________________________________________________
Subject: pedal extensions
Date: Mar 31, 2011
Could someone with the rudder pedal extensions measure the distance they stick back and possibly sent me offline a better picture or drawing of them? My pedals are aft mounted and I'm 6' 4", so I may need them, but at any rate, sounds like a cool project for my new mill! Thanks Chris Hukill ________________________________________________________________________________
Date: Mar 31, 2011
Looking down the edge of the elevator, it looks straight all the way up to the trim tab. Then, the whole trim tab appear two slant upward. To be honest, the trim tabs have always bothered me and I was hoping I could one day install new ones. I had a very hard time squeezing my hand in and bucking the rivets and I would up using pop rivets in places. Is it hard to mount new trim tabs on? -------- Jake Hearnsberger RV-10 Empennage Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335582#335582 ________________________________________________________________________________
Date: Mar 31, 2011
No, it's easy to do. I ended up doing it about a month before my first flight, but you could probably even fly it like that for a while until you feel like rebuilding it. -Rob On Thu, Mar 31, 2011 at 8:46 AM, JHearnsberger wrote: > jakehearnsberger(at)gmail.com> > > Looking down the edge of the elevator, it looks straight all the way up to > the trim tab. Then, the whole trim tab appear two slant upward. > > To be honest, the trim tabs have always bothered me and I was hoping I > could one day install new ones. I had a very hard time squeezing my hand in > and bucking the rivets and I would up using pop rivets in places. Is it > hard to mount new trim tabs on? > > -------- > Jake Hearnsberger > RV-10 Empennage > Springhill, LA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335582#335582 > > -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 31, 2011
Subject: Re: This could be bad....(storms in S-N-F)
On 03/31/2011 01:11 PM, Tim Olson wrote: > > > If you hear anything with good links, I'd love to hear > that nothing happened to all the airplanes.... http://www.cfnews13.com/article/news/2011/march/225911/Storm-causes-hangar-to-collapse-at-Sun-N-Fun <http://www.cfnews13.com/article/news/2011/march/225911/Storm-causes-hangar-to-collapse-at-Sun-N-Fun> -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Mar 31, 2011
http://www.cnn.com/2011/US/03/31/florida.weather/index.html?hpt=T1&iref=BN1 -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Mar 31, 2011
On 03/31/2011 01:11 PM, Tim Olson wrote: > If you hear anything with good links, I'd love to hear > that nothing happened to all the airplanes.... There is more news on the Sun n Fun Facebook page. http://www.facebook.com/SunNFunFlyIn -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Mar 31, 2011
Subject: This could be bad....(storms in S-N-F)
Re: RV10-List: This could be bad....(storms in S-N-F) MARCH 31, 2011 *Strong Storms Batter Sun 'n Fun*<http://links.bonniermarinegroup.com/ctt?kn=18&m=4803797&r=NDc4NjIxOTY5OQS2&b=0&j=MTc1MDkzMTk2S0&mt=1&rt=0> ** [image: SNF damage]<http://links.bonniermarinegroup.com/ctt?kn=18&m=4803797&r=NDc4NjIxOTY5OQS2&b=0&j=MTc1MDkzMTk2S0&mt=1&rt=0> *Damage to total hundreds of millions of dollars.* *(Photo: Pia Bergqvist)* The scene at Sun 'n Fun at Lakeland Linder Regional Airport turned to chaos on Thursday as strong storms hammered the show site, flipping airplanes, knocking out power to the exhibit halls and collapsing a building, trapping dozens of people inside. The National Weather Service reported confirmed tornadoes in the area, and said more than 70 people were trapped inside the collapsed building at the Sun 'n Fun show site. Even though the first couple of days of the show were largely storm free, the week continued to be defined by heavy rain that soaked the grounds the day before the festivities started and kept thousands of airplanes from arriving in Lakeland. Despite the slow start to the week, some vendors reported doing good business even with the smaller crowds. Launch events by Aspen, Piper, Garmin and Cessna generated a good deal of buzz at the show, and as the week progressed and the scattered areas of decent weather surfaced, the mood of show goers seemed decidedly upbeat. But on Thursday morning show goers awoke to heavy rains and threatening skies before a massive storm cell swept through the area late in the morning. A tornado warning for the area remained in effect on Thursday afternoon. *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Dj Merrill *Sent:* Thursday, March 31, 2011 11:06 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: This could be bad....(storms in S-N-F) On 03/31/2011 01:11 PM, Tim Olson wrote: > If you hear anything with good links, I'd love to hear > that nothing happened to all the airplanes.... There is more news on the Sun n Fun Facebook page. http://www.facebook.com/SunNFunFlyIn -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Fwd: Pictures at Sun N Fun
Date: Mar 31, 2011
Here are some pictures of the mess down here. 3 pictures have our 801 in it . Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone Begin forwarded message: > From: "Doug Leppard" <doug(at)itecusa.org> > Date: March 31, 2011 4:48:06 PM EDT > To: "'Dan Barlow'" , "'Mark Stringer'" , "'Ronbo Lytle'" , "'Jesse'" , " 'Jaime Saint'" , "'Stephen Saint'" , "Be cky Leppard" , "'Troy Townsend'" > Subject: Pictures at Sun N Fun > > =46rom Facebook > > > > http://www.facebook.com/album.php?fbid=10150192388678623&id=1920816886 22&aid=358039#!/album.php?fbid=10150192388678623&id=192081688622&aid= 358039&closeTheater=1 > > > > > > Doug Leppard > > I-TEC > > ________________________________________________________________________________
Subject: Re: This could be bad....(storms in S-N-F) UPDATE from AVWEB
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 31, 2011
Seems like ours made it through OK, need to do a through inspection to know for sure. Had "Claw" tie downs, they gave a bit but did not give up. If you have ever been down here you know how sandy the soil is. I can't even count the number of the thread in dog leash type tie downs that were on aircraft that didn't do so well. After the first wave of bad weather they said an even bigger storm was coming, so we bought a second set to help hold it in place. Thankfully the storm did not materialize. The wind blew so hard it stripped all of the paint off of our airplane, well at least that is the excuse we can use for a while for not being painted yet. My heart goes out to all of those who lost their labor of love to the storm, first sploshkosh now this... Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335691#335691 ________________________________________________________________________________
Date: Mar 31, 2011
www.grassrootsnews.tv has a good video of the storm (including a clip of adam from TruTrak and Alex D). not sure if the earlier email made it to the list. I dont know of any RV-10's damaged except minor wingtip damage to the van's plane. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Apr 01, 2011
Subject: Insurance
When this thing crashes, will it affect our insurance rates, since it's in Brazil (or wherever outside the US)? http://www.youtube.com/watch?v=ItFluGPKpOQ -Rob -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Apr 01, 2011
Subject: Re: Insurance
Why was he flying from the right seat? ________________________________ From: Rob Kochman <rv10rob(at)gmail.com> Sent: Fri, April 1, 2011 8:59:32 AM Subject: RV10-List: Insurance When this thing crashes, will it affect our insurance rates, since it's in Brazil (or wherever outside the US)? http://www.youtube.com/watch?v=ItFluGPKpOQ -Rob -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Date: Apr 01, 2011
I noticed he couldn't be bothered with the shoulder belt..... -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335808#335808 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Apr 01, 2011
Why does he not have shoulder harnesses?? Sent from my iPhone On Apr 1, 2011, at 6:29 PM, Bruce Johnson wrote: > Why was he flying from the right seat? > > From: Rob Kochman <rv10rob(at)gmail.com> > To: rv10-list > Sent: Fri, April 1, 2011 8:59:32 AM > Subject: RV10-List: Insurance > > When this thing crashes, will it affect our insurance rates, since it's in Brazil (or wherever outside the US)? > http://www.youtube.com/watch?v=ItFluGPKpOQ > > -Rob > > -- > Rob Kochman > RV-10 Flying, Phase 1 > http://kochman.net/N819K > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 01, 2011
Here are a couple more pictures. Jake -------- Jake Hearnsberger RV-10 Empennage Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335817#335817 Attachments: http://forums.matronics.com//files/img_1535_199.jpg http://forums.matronics.com//files/img_1531_796.jpg ________________________________________________________________________________
Date: Apr 01, 2011
I was there today, I could not get out to the flight line to see the tens. How many are there? David Leikam RV10 Flying On Mar 31, 2011, at 10:09 PM, Jesse Saint wrote: > > www.grassrootsnews.tv has a good video of the storm (including a clip of adam from TruTrak and Alex D). not sure if the earlier email made it to the list. > > I dont know of any RV-10's damaged except minor wingtip damage to the van's plane. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > > ________________________________________________________________________________
Subject: Any -10 builders near Shreveport, LA?
Date: Apr 01, 2011
Are there any RV-10 builders out there close to NW Louisiana? I'm located about 60 miles north of Shreveport, LA. Jake -------- Jake Hearnsberger RV-10 Empennage Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335821#335821 ________________________________________________________________________________
Subject: Insurance???
Date: Apr 01, 2011
If you're impatient=2C forward the video to 3:20 I don't think the brazilian piloting was so crazy. This video reminds me of Luke Skywalker doing his alley run on the deathstar. http://www.youtube.com/watch?v=QjTmNJmJXbk I think there might even be pee on the camera lense at the end of the run. ________________________________________________________________________________
Date: Apr 01, 2011
Yeah, they look to have a built in twist. I'd rebuild new ones. On Apr 1, 2011, at 8:05 PM, "JHearnsberger" wrote: > > Here are a couple more pictures. > > Jake > > -------- > Jake Hearnsberger > RV-10 Empennage > Springhill, LA > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335817#335817 > > > > > Attachments: > > http://forums.matronics.com//files/img_1535_199.jpg > http://forums.matronics.com//files/img_1531_796.jpg > > > > > > ________________________________________________________________________________
Date: Apr 02, 2011
While you are at it, build them yourself with the aluminum wedge in the trailing edge and they will match the elevators and look much nicer..... Just a thought..... -Mike Sent from my iPhone On Apr 2, 2011, at 12:20 AM, Tim Olson wrote: > > Yeah, they look to have a built in twist. I'd rebuild new ones. > > > > > On Apr 1, 2011, at 8:05 PM, "JHearnsberger" wrote: > >> >> Here are a couple more pictures. >> >> Jake >> >> -------- >> Jake Hearnsberger >> RV-10 Empennage >> Springhill, LA >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=335817#335817 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_1535_199.jpg >> http://forums.matronics.com//files/img_1531_796.jpg >> >> >> >> >> >> > > > > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Subject: FW: Burt Rutan Retires From Scaled Composites
Date: Apr 02, 2011
U29tZXRoaW5nIHRoYXQgbWFueSBmb3Jnb3Qgd2l0aCB0aGUgbmlnaHRtYXJlIG9mIFNuRi4gIEkg bG92ZSB0aGUgZmFjdCB0aGF0IGV2ZW4gU2xhc2hkb3R0ZXJzIHJlY29nbml6ZWQgdGhlIGNvbnRy aWJ1dGlvbnMgQnVydCBtYWRlIHRvIGF2aWF0aW9uIGFuZCB0aGUgd29ybGTigKbigKYNCg0KRmVl ZDogU2xhc2hkb3QNClBvc3RlZCBvbjogU2F0dXJkYXksIEFwcmlsIDAyLCAyMDExIDExOjQwIEFN DQpBdXRob3I6IHRpbW90aHkNClN1YmplY3Q6IEJ1cnQgUnV0YW4gUmV0aXJlcyBGcm9tIFNjYWxl ZCBDb21wb3NpdGVzDQoNCmhvbmRvNzcgd3JpdGVzICJMb3N0IGluIGFsbCBvZiB0aGUgQXByaWwg Rm9vbCdzIERheSBmdW4gd2FzIHRoZSBuZXdzIHRoYXQgQnVydCBSdXRhbiByZXRpcmVkIG9uIEFw cmlsIDEuICdGaXZlIG9mIGhpcyBwbGFuZXMgbm93IGhhbmcgaW4gdGhlIFNtaXRoc29uaWFuIE5h dGlvbmFsIEFpciBhbmQgU3BhY2UgTXVzZXVtLCBpbmNsdWRpbmcgdGhlIFZveWFnZXIsIHdoaWNo IGluIDE5ODYgYmVjYW1lIHRoZSBmaXJzdCBhaXJwbGFuZSB0byBmbHkgYXJvdW5kIHRoZSB3b3Js ZCB3aXRob3V0IHJlZnVlbGluZywgYW5kIFNwYWNlU2hpcE9uZSwgd2hpY2ggaW4gMjAwNCBiZWNh bWUgdGhlIGZpcnN0IHByaXZhdGUgcm9ja2V0IHBsYW5lIGV2ZXIgdG8gcHV0IGEgbWFuIGludG8g c3BhY2UuJyBFbmpveSB5b3VyIHJldGlyZW1lbnQsIEJ1cnQuIFlvdSd2ZSBlYXJuZWQgaXQuIiBX YXRjaGluZyBTcGFjZVNoaXBPbmUgZmx5IGluIDIwMDQgaXMgb25lIG9mIHRoZSBoYXBwaWVzdCBt ZW1vcmllcyBvZiBteSBsaWZlLiBUaGFua3MsIE1yLiBSdXRhbi4NCg0KW2h0dHA6Ly9hLmZzZG4u Y29tL3NkL2ZhY2Vib29rX2ljb25fbGFyZ2UucG5nXTxodHRwOi8vd3d3LmZhY2Vib29rLmNvbS9z aGFyZXIucGhwP3U9aHR0cCUzQSUyRiUyRnRlY2guc2xhc2hkb3Qub3JnJTJGc3RvcnklMkYxMSUy RjA0JTJGMDIlMkYxNTQ0MjQ1JTJGQnVydC1SdXRhbi1SZXRpcmVzLUZyb20tU2NhbGVkLUNvbXBv c2l0ZXMlM0Zmcm9tJTNEZmI+W2h0dHA6Ly9hLmZzZG4uY29tL3NkL3R3aXR0ZXJfaWNvbl9sYXJn ZS5wbmddPGh0dHA6Ly90d2l0dGVyLmNvbS9ob21lP3N0YXR1cz1CdXJ0K1J1dGFuK1JldGlyZXMr RnJvbStTY2FsZWQrQ29tcG9zaXRlcyUzQStodHRwJTNBJTJGJTJGYml0Lmx5JTJGZW03Y0ljPg0K DQpSZWFkIG1vcmUgb2YgdGhpcyBzdG9yeTxodHRwOi8vdGVjaC5zbGFzaGRvdC5vcmcvc3Rvcnkv MTEvMDQvMDIvMTU0NDI0NS9CdXJ0LVJ1dGFuLVJldGlyZXMtRnJvbS1TY2FsZWQtQ29tcG9zaXRl cz9mcm9tPXJzcz4gYXQgU2xhc2hkb3QuDQoNCltodHRwOi8vZmVlZGFkcy5nLmRvdWJsZWNsaWNr Lm5ldC9+YXQvbnZiNnFRM2N3OHdUZGNuNEVQOFlHMHJoVXlnLzAvZGldPGh0dHA6Ly9mZWVkYWRz LmcuZG91YmxlY2xpY2submV0L35hdC9udmI2cVEzY3c4d1RkY240RVA4WUcwcmhVeWcvMC9kYT4N CltodHRwOi8vZmVlZGFkcy5nLmRvdWJsZWNsaWNrLm5ldC9+YXQvbnZiNnFRM2N3OHdUZGNuNEVQ OFlHMHJoVXlnLzEvZGldPGh0dHA6Ly9mZWVkYWRzLmcuZG91YmxlY2xpY2submV0L35hdC9udmI2 cVEzY3c4d1RkY240RVA4WUcwcmhVeWcvMS9kYT4NCg0KDQoNClZpZXcgYXJ0aWNsZS4uLjxodHRw Oi8vcnNzLnNsYXNoZG90Lm9yZy9+ci9TbGFzaGRvdC9zbGFzaGRvdC9+My91WnJ4RlRVRVExMC9C dXJ0LVJ1dGFuLVJldGlyZXMtRnJvbS1TY2FsZWQtQ29tcG9zaXRlcz4NCg= ________________________________________________________________________________
Date: Apr 03, 2011
Subject: Well, Narco Avionics has folded...
Like, hate, whatever, this isn't good for the avionics business: > > http://www.narco-avionics.com/ > > ________________________________________________________________________________
Date: Apr 03, 2011
Subject: Re: Well, Narco Avionics has folded...
I have two of their products in my 6A... Altitude encoder - which has a backup in my AFS3400SP. NAV122D/GPS Nav/GS/LOC receiver which also doubles as a backup CDI. Interested to see how they handle ongoing support of their existing customer base. -----Original Message----- >From: Kelly McMullen <apilot2(at)gmail.com> >Sent: Apr 3, 2011 9:15 AM >To: rv10-list(at)matronics.com >Subject: RV10-List: Well, Narco Avionics has folded... > > >Like, hate, whatever, this isn't good for the avionics business: > > >> >> http://www.narco-avionics.com/ >> >> > > ________________________________________________________________________________
Subject: ray allen potentiometer flap indicator
Date: Apr 03, 2011
I am having trouble figuring out where and how to mount the ray allen poten tiometer flap indicator. Does anybody in the system have a picture or sugge stion as to where and how to mount this? Thank you for your help, pilotdds Trying not to butcher Stein's work -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: ray allen potentiometer flap indicator
Date: Apr 03, 2011
If you search the archives for my name/email and/or flap stuff, you should f ind the info for an easy installation. Let me know if you can't find it and I will resend when I am at home. -Mike Kraus Sent from my iPhone On Apr 3, 2011, at 11:27 AM, pilotdds wrote: > I am having trouble figuring out where and how to mount the ray allen pote ntiometer flap indicator. Does anybody in the system have a picture or sugge stion as to where and how to mount this? > Thank you for your help, > pilotdds > Trying not to butcher Stein's work > > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 03, 2011
Was their a tornado and severe weather forecast predicted? Or was it hiding behind a heavy rain forecast. Just curious if you knew it was coming if you could've tried to fly out of its path. cjay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335967#335967 ________________________________________________________________________________
Date: Apr 03, 2011
I never heard any warnings. It just got real dark and then the rain. I took shelter from the rain inside one of the four hangars. They closed the doors as the wind picked up. With the noise from the rain on the metal roof, we did not notice the extra heavy wind. Garmin had to pickup some of there units as the roof was leaking. On Wed. and Thursday I counted two RV-10 in HB and two more in HBC. We made it as far as Hilton Head, SC with our RV-10 and rented a car to make it to Sun n Fun. Just over seven hrs from Hilton Head to Nova Scotia and got home at noon today. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335976#335976 ________________________________________________________________________________
Date: Apr 03, 2011
Can't remember who I borrowed this from, but this is the way I did it. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335980#335980 Attachments: http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg ________________________________________________________________________________
Date: Apr 03, 2011
2 points. The movement is non linear because of the hinge. It is great for indicating flaps up or down but not partial flaps. Also if the POS overextends it breaks and you will get no reading so be careful how far you let it extend. Alan -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Sunday, April 03, 2011 5:30 PM Subject: RV10-List: Re: ray allen potentiometer flap indicator Can't remember who I borrowed this from, but this is the way I did it. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335980#335980 Attachments: http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg ________________________________________________________________________________
Date: Apr 03, 2011
Yep, that's mine. Thanks for reposting it... I didn't have the picture handy -Mike Kraus Sent from my iPhone On Apr 3, 2011, at 5:30 PM, "Jim Berry" wrote: > > Can't remember who I borrowed this from, but this is the way I did it. > > Jim Berry > RV-10 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335980#335980 > > > > > Attachments: > > http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg > > > > > > > ________________________________________________________________________________
Subject: Re: Bose X headset for sale
Date: Apr 03, 2011
We have one for sale. Just purchased last summer , AC has 75 hrs. I think we are only replacing one at this time for a 20 with Blue Tooth. This set has the lemo plug. We will have to purchase the new set to get you the ac side of the plug. As others, we are asking $500. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335986#335986 ________________________________________________________________________________
Date: Apr 03, 2011
I mount mine in the tunnel with a small "L" iron that I epoxied to the flap actuating tube. Seems to work well there away from moisture. I get almost no reading on the first 3 degrees of flaps, but works well after that with the flap positioning system. I would add caution as was mentioned before - DO NOT LET THE SHAFT HYPER-EXTEND. I did and the replacement is $40. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336012#336012 ________________________________________________________________________________
Subject: Re: Burt Rutan Retires From Scaled Composites
Date: Apr 03, 2011
I know that Burt Rutan has had some serious health problems in the past 2 year. I hope that a worry free retirement improves his health and well being and yields him a long life. He is one awesomely creative individual. Godspeed Burt Rutan ! -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336013#336013 ________________________________________________________________________________
Date: Apr 03, 2011
The A20's don't come with the aircraft side jack, so everyone has to purchase them separately now. Bose or ACS both have them. The actual wire colors differ between the A20 or X type jacks but they are functionally identical. If you get an older jack, you just use the older wiring diagram so the black/blue wire differences are identified properly. Tim On Apr 3, 2011, at 4:26 PM, "Ron B." wrote: > > We have one for sale. Just purchased last summer , AC has 75 hrs. I think we are only replacing one at this time for a 20 with Blue Tooth. This set has the lemo plug. We will have to purchase the new set to get you the ac side of the plug. As others, we are asking $500. > Ron > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335986#335986 > > > > > > > > > ________________________________________________________________________________
Date: Apr 04, 2011
Thanks for all the help-the ingenuity of this group never ceases to amaze m e Jim -----Original Message----- From: Michael Kraus <n223rv(at)wolflakeairport.net> Sent: Sun, Apr 3, 2011 3:27 pm Subject: Re: RV10-List: Re: ray allen potentiometer flap indicator Yep, that's mine. Thanks for reposting it... I didn't have the picture ha ndy Mike Kraus Sent from my iPhone On Apr 3, 2011, at 5:30 PM, "Jim Berry" wrote: Can't remember who I borrowed this from, but this is the way I did it. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=335980#335980 Attachments: http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg -======================== -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Apr 04, 2011
Date: Apr 04, 2011
I like Mike's better. -Scott Sent from my iPhone On Apr 3, 2011, at 4:24 PM, Michael Kraus wrote: > > Yep, that's mine. Thanks for reposting it... I didn't have the picture handy > -Mike Kraus > > Sent from my iPhone > > On Apr 3, 2011, at 5:30 PM, "Jim Berry" wrote: > >> >> Can't remember who I borrowed this from, but this is the way I did it. >> >> Jim Berry >> RV-10 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=335980#335980 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 03, 2011
I will take it. Do't need the AC side of the plug, I have one. Besides, you will need it for your 20. It you decide to sell another one in the future, I will take that too. How do you want to do the transaction? If you give me the S/N under the headset pad, I will check the warrant with Bose. Thanks. Rob. On Apr 3, 2011, at 6:26 PM, Ron B. wrote: > > We have one for sale. Just purchased last summer , AC has 75 hrs. I think we are only replacing one at this time for a 20 with Blue Tooth. This set has the lemo plug. We will have to purchase the new set to get you the ac side of the plug. As others, we are asking $500. > Ron > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=335986#335986 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 04, 2011
Thanks for the heads up. How do you remember all this? Damn... How old are you? On Apr 3, 2011, at 10:24 PM, Tim Olson wrote: > > The A20's don't come with the aircraft side jack, so everyone has to purchase them separately now. Bose or ACS both have them. The actual wire colors differ between the A20 or X type jacks but they are functionally identical. If you get an older jack, you just use the older wiring diagram so the black/blue wire differences are identified properly. > Tim > > > > On Apr 3, 2011, at 4:26 PM, "Ron B." wrote: > >> >> We have one for sale. Just purchased last summer , AC has 75 hrs. I think we are only replacing one at this time for a 20 with Blue Tooth. This set has the lemo plug. We will have to purchase the new set to get you the ac side of the plug. As others, we are asking $500. >> Ron >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=335986#335986 >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 04, 2011
We always keep our aircraft at my home grass strip, but due to spring thaw we decided to stop at the local airport on our way back from Sun n Fun yesterday. It's 30 minutes away and we will get you the serial # next trip in. Should be soon. Thanks Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336064#336064 ________________________________________________________________________________
Date: Apr 04, 2011
I wouldn't have known but only a month ago I was talking to another builder about wiring in the jacks and I had just reworked mine with my Bluetooth audio system and I noticed his wire colors were different. We figured out that I ordered my jacks when X's were out but he got his recently for his A20's....so I checked the 2 wiring diagrams and saw the difference was just wire color. So I didn't have to dig too far back. ;) Tim On Apr 4, 2011, at 12:27 PM, Rob Kermanj wrote: > > Thanks for the heads up. How do you remember all this? Damn... How old are you? > > > On Apr 3, 2011, at 10:24 PM, Tim Olson wrote: > >> >> The A20's don't come with the aircraft side jack, so everyone has to purchase them separately now. Bose or ACS both have them. The actual wire colors differ between the A20 or X type jacks but they are functionally identical. If you get an older jack, you just use the older wiring diagram so the black/blue wire differences are identified properly. >> Tim >> >> >> >> On Apr 3, 2011, at 4:26 PM, "Ron B." wrote: >> >>> >>> We have one for sale. Just purchased last summer , AC has 75 hrs. I think we are only replacing one at this time for a 20 with Blue Tooth. This set has the lemo plug. We will have to purchase the new set to get you the ac side of the plug. As others, we are asking $500. >>> Ron >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=335986#335986 >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 04, 2011
I'm working on the second head set with my RV-10 partners, I'll let you know. We have 2006 vintage Bose X head sets in our Supercubs (two Supercubs builders that joined with two other pilots to build an RV-10). I think that I can talk them into parting with two of the headsets from one the supercubs. These sets are five years old but have always been kept in a heated hangar and are in great condition. They don't seem to fancy parting with two new headsets at this time, at such a loss. Hopefully this explanation makes sense to you. Thanks Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336099#336099 ________________________________________________________________________________
Subject: First Flight Video
Date: Apr 04, 2011
http://www.youtube.com/watch?v=8ZlBCkQE9fo -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336138#336138 ________________________________________________________________________________
Date: Apr 04, 2011
Subject: Re: First Flight Video
Congratulations Sean. Looks great, especially your high tech turn and bank indicators on the center post. On Mon, Apr 4, 2011 at 9:49 PM, Strasnuts wrote: > > http://www.youtube.com/watch?v=8ZlBCkQE9fo > > -------- > Cust. #40936 > RV-10 SB Fuselage > N801VR reserved > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336138#336138 > > ________________________________________________________________________________
Date: Apr 05, 2011
Very cool. Leon Everett > Date: Mon=2C 4 Apr 2011 22:02:54 -0700 > Subject: Re: RV10-List: First Flight Video > From: apilot2(at)gmail.com > To: rv10-list(at)matronics.com > > > Congratulations Sean. Looks great=2C especially your high tech turn and > bank indicators on the center post. > > On Mon=2C Apr 4=2C 2011 at 9:49 PM=2C Strasnuts wro te: > > > > http://www.youtube.com/watch?v=8ZlBCkQE9fo > > > > -------- > > Cust. #40936 > > RV-10 SB Fuselage > > N801VR reserved > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=336138#336138 > > > > > > > > > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 05, 2011
The dice are actually an antigravity indicator, he stole the idea from Spaceship One. Sean really covered all the bases. I never considered what I would do if I encountered a weightless environment. http://airbum.com/pireps/PirepSS1.html I flew chase and his flight went off perfectly with no problems. It was really fun to see it fly. Congratulations Sean and Hollie. -Scott Sent from my iPad On Apr 4, 2011, at 11:02 PM, Kelly McMullen wrote: > > Congratulations Sean. Looks great, especially your high tech turn and > bank indicators on the center post. > > On Mon, Apr 4, 2011 at 9:49 PM, Strasnuts wrote: >> >> http://www.youtube.com/watch?v=8ZlBCkQE9fo >> >> -------- >> Cust. #40936 >> RV-10 SB Fuselage >> N801VR reserved >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=336138#336138 >> >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Subject: RV-10 HQ - OSH10
Date: Apr 05, 2011
Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (From 51 to just 16 WOW). I am supplying beer again. Who is game! John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry Sent: Mon 8/2/2010 5:06 PM Subject: Re: RV10-List: RV-10 HQ - OSH10 I want to throw in my appreciation to those who coordinated the RV-10 HQ too. I especially want to thank John Cox for providing local beer. After a full day of crowds and 100LL, it hit the spot. :) Most importantly, I think the ladies really enjoyed themselves too. She also commented how much fun the RV-10 crowd was. We'll see you all in 51 weeks, if not sooner. Phil ________________________________________________________________________________
Subject: Re: RV-10 HQ - OSH10
Date: Apr 05, 2011
In!!!!!! Spotted Cow to the rescue!! On Apr 5, 2011, at 2:24 PM, "John Cox" wrote: > Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (=46rom 51 to just 16 WOW). I am supplying beer again. Who is game! > > John Cox > > From: owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry > Sent: Mon 8/2/2010 5:06 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: RV-10 HQ - OSH10 > > I want to throw in my appreciation to those who coordinated the RV-10 HQ t oo. > > I especially want to thank John Cox for providing local beer. After a ful l day of crowds and 100LL, it hit the spot. :) > > Most importantly, I think the ladies really enjoyed themselves too. She a lso commented how much fun the RV-10 crowd was. > > We'll see you all in 51 weeks, if not sooner. > > Phil > > > > > ========== > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > ========== > href="http://forums.matronics.com/">http://forums.matronics.com > ========== > href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution > ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 05, 2011
I'm in as well! -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336201#336201 ________________________________________________________________________________
Date: Apr 05, 2011
I keep hearing about this Spotted Cow. Gotta try it this year. -Scott Sent from my iPad On Apr 5, 2011, at 1:40 PM, Phil Perry wrote: > In!!!!!! > > Spotted Cow to the rescue!! > > > > > > On Apr 5, 2011, at 2:24 PM, "John Cox" wrote: > >> Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (=46rom 51 to just 16 WOW). I am supplying beer again. Who is game! >> >> John Cox >> >> From: owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry >> Sent: Mon 8/2/2010 5:06 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: RV-10 HQ - OSH10 >> >> I want to throw in my appreciation to those who coordinated the RV-10 HQ t oo. >> >> I especially want to thank John Cox for providing local beer. After a fu ll day of crowds and 100LL, it hit the spot. :) >> >> Most importantly, I think the ladies really enjoyed themselves too. She a lso commented how much fun the RV-10 crowd was. >> >> We'll see you all in 51 weeks, if not sooner. >> >> Phil >> >> >> >> >> ========== >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List >> ========== >> href="http://forums.matronics.com/">http://forums.matronics.com >> ========== >> href="http://www.matronics.com/contribution">http://www.matronics.com/c ontribution >> ========== >> >> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Apr 05, 2011
Good stuff. My favorite when in Wisconsin Geoff Combs President 614-834-5227p 614-834-5230f www.aerosportmodeling.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Tuesday, April 05, 2011 4:10 PM Subject: [SPAM?] Re: RV10-List: RV-10 HQ - OSH10 Importance: Low I keep hearing about this Spotted Cow. Gotta try it this year. -Scott Sent from my iPad On Apr 5, 2011, at 1:40 PM, Phil Perry wrote: In!!!!!! Spotted Cow to the rescue!! On Apr 5, 2011, at 2:24 PM, "John Cox" < johnwcox(at)pacificnw.com> wrote: Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (From 51 to just 16 WOW). I am supplying beer again. Who is game! John Cox _____ From: <mailto:owner-rv10-list-server(at)matronics.com> owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry Sent: Mon 8/2/2010 5:06 PM rv10-list(at)matronics.com Subject: Re: RV10-List: RV-10 HQ - OSH10 I want to throw in my appreciation to those who coordinated the RV-10 HQ too. I especially want to thank John Cox for providing local beer. After a full day of crowds and 100LL, it hit the spot. :) Most importantly, I think the ladies really enjoyed themselves too. She also commented how much fun the RV-10 crowd was. We'll see you all in 51 weeks, if not sooner. Phil ========== href=" http://www.matronics.com/Navigator?RV10-List"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List ========== href=" http://forums.matronics.com/"> <http://forums.matronics.com> http://forums.matronics.com ========== href=" http://www.matronics.com/contribution"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Apr 05, 2011
Haven't had the spotted cow before as I missed last years event. Plane comes out of paint early June. As long as my deployment schedule doesn't change AGAIN I am in. Eric Kallio N518RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336223#336223 ________________________________________________________________________________
Date: Apr 05, 2011
Eric, Has anyone told you about the tradition? Historically those who have flown in the past year buy for those who are still building.... It's been that way for years. I assume you're still planning on keeping with tradition - right? Phil On Tue, Apr 5, 2011 at 5:16 PM, Eric_Kallio wrote: > > Haven't had the spotted cow before as I missed last years event. Plane > comes out of paint early June. As long as my deployment schedule doesn't > change AGAIN I am in. > > Eric Kallio > N518RV > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336223#336223 > > ________________________________________________________________________________
Date: Apr 05, 2011
I'll be there for the first half of the week. Gotta do a forum on building Pietenpols. Don't know yet whether I'll fly the RV-4 or the Pietenpol. Round trip from Raleigh to OSH and back is 34 hours of flying in the Piet. Jack Phillips Raleigh, NC #40610 Still working (slowly) on the wings _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Tuesday, April 05, 2011 4:10 PM Subject: Re: RV10-List: RV-10 HQ - OSH10 I keep hearing about this Spotted Cow. Gotta try it this year. -Scott Sent from my iPad On Apr 5, 2011, at 1:40 PM, Phil Perry wrote: In!!!!!! Spotted Cow to the rescue!! On Apr 5, 2011, at 2:24 PM, "John Cox" < johnwcox(at)pacificnw.com> wrote: Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (From 51 to just 16 WOW). I am supplying beer again. Who is game! John Cox _____ From: <mailto:owner-rv10-list-server(at)matronics.com> owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry Sent: Mon 8/2/2010 5:06 PM rv10-list(at)matronics.com Subject: Re: RV10-List: RV-10 HQ - OSH10 I want to throw in my appreciation to those who coordinated the RV-10 HQ too. I especially want to thank John Cox for providing local beer. After a full day of crowds and 100LL, it hit the spot. :) Most importantly, I think the ladies really enjoyed themselves too. She also commented how much fun the RV-10 crowd was. We'll see you all in 51 weeks, if not sooner. Phil ========== href=" http://www.matronics.com/Navigator?RV10-List"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List ========== href=" http://forums.matronics.com/"> <http://forums.matronics.com> http://forums.matronics.com ========== href=" http://www.matronics.com/contribution"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Apr 05, 2011
I'll be there all week again. Not sure who will be in tow yet.. Brad and Ashley want to come, but we won't know if Ashley can get leave until it gets closer. Renee has talked about going if Ashley goes, but won't know for sure until she hears about her internship this summer. Janice just came back from a trip with her sister, so I don't think she'll have enough vacation time to join us this year. I don't think I'll be flying by then, but it's going to be really close. Counting down the days! bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Tuesday, April 05, 2011 8:32 PM Subject: RE: RV10-List: RV-10 HQ - OSH10 I'll be there for the first half of the week. Gotta do a forum on building Pietenpols. Don't know yet whether I'll fly the RV-4 or the Pietenpol. Round trip from Raleigh to OSH and back is 34 hours of flying in the Piet. Jack Phillips Raleigh, NC #40610 Still working (slowly) on the wings _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Scott Schmidt Sent: Tuesday, April 05, 2011 4:10 PM Subject: Re: RV10-List: RV-10 HQ - OSH10 I keep hearing about this Spotted Cow. Gotta try it this year. -Scott Sent from my iPad On Apr 5, 2011, at 1:40 PM, Phil Perry wrote: In!!!!!! Spotted Cow to the rescue!! On Apr 5, 2011, at 2:24 PM, "John Cox" wrote: Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (From 51 to just 16 WOW). I am supplying beer again. Who is game! John Cox _____ From: owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry Sent: Mon 8/2/2010 5:06 PM Subject: Re: RV10-List: RV-10 HQ - OSH10 I want to throw in my appreciation to those who coordinated the RV-10 HQ too. I especially want to thank John Cox for providing local beer. After a full day of crowds and 100LL, it hit the spot. :) Most importantly, I think the ladies really enjoyed themselves too. She also commented how much fun the RV-10 crowd was. We'll see you all in 51 weeks, if not sooner. Phil ========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List ========== href="http://forums.matronics.com/">http://forums.matronics.com ========== href="http://www.matronics.com/contribution">http://www.matronics.com/contri bution ========== ________________________________________________________________________________
Date: Apr 05, 2011
Made right here in New Glarus WI. My personal favorite. David Leikam RV10 Flying On Apr 5, 2011, at 3:10 PM, Scott Schmidt wrote: > I keep hearing about this Spotted Cow. > Gotta try it this year. > > -Scott > > Sent from my iPad > > On Apr 5, 2011, at 1:40 PM, Phil Perry wrote: > >> In!!!!!! >> >> Spotted Cow to the rescue!! >> >> >> >> >> >> On Apr 5, 2011, at 2:24 PM, "John Cox" wrote: >> >>> Sun N' Fun 2011 is over. OSH is back to being just 16 weeks away. (=46rom 51 to just 16 WOW). I am supplying beer again. Who is game! >>> >>> John Cox >>> >>> From: owner-rv10-list-server(at)matronics.com on behalf of Phillip Perry >>> Sent: Mon 8/2/2010 5:06 PM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: RV-10 HQ - OSH10 >>> >>> I want to throw in my appreciation to those who coordinated the RV-10 HQ too. >>> >>> I especially want to thank John Cox for providing local beer. After a full day of crowds and 100LL, it hit the spot. :) >>> >>> Most importantly, I think the ladies really enjoyed themselves too. She also commented how much fun the RV-10 crowd was. >>> >>> We'll see you all in 51 weeks, if not sooner. >>> >>> Phil >>> >>> >>> >>> >>> ========== >>> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >>> ========== >>> href="http://forums.matronics.com/">http://forums.matronics.com >>> ========== >>> href="http://www.matronics.com/contribution">http://www.matronics.com/co ntribution >>> ========== >>> >>> >>> >>> >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > ________________________________________________________________________________
Date: Apr 06, 2011
Subject: RV-10 Builders/Flyers Gathering - April 9th (Houston, TX)
Hi Everyone, I'm opening this up to a broader audience in case I missed a few folks. There are 15 RV-10's either flying or being built in the Houston area and most of the folks don't know each other. So I started this project of gathering the "Birds of a Feather" so everyone could meet. I'm opening it up to others who might want to fly-in for lunch. I talked to Don McDonald and a few others in Texas and I'm hoping they're looking for a good excuse to fly their RV-10's on that day. Below is a message I just sent out to the local crowd. If you believe you can attend, let me know and we'll be watching for you. More details can be found on this post: http://www.vansairforce.com/community/showthread.php?t=70339 Phil ======= Hi Everyone, Just and update on the gathering on Saturday. The weather is looking great with the exception of some wind in the forecast. I updated the list with the -10 builders who have said they're coming. I'm hoping we get some other folks flying in so we get a good mix of RV's and hopefully I don't end up with too much food left over. On Monday I went and bought some food for ~50 BBQ Baked Potatoes. If you would like to bring a side dish (chips, breads, etc) that would be nice. I have five 8' folding tables and 52 chairs so we should be fine in those areas. I will be at the airport to setup around 9AM if some of you want to show up early. A map can be found here: http://goo.gl/maps/n6Q2 It will be very easy to find us on the field. There's only one way in and only one large hanger. You can't miss it, so do sweat those details. I look forward to seeing you there. If you don't have my cell number send m e an e-mail and I'll give it to you. Looking forward to seeing everyone! Phil *Name* *Stage* *Confirmed?* Bill Gipson Flying Yes Nick Nafsinger Flying Bill Hicks Flying Pat Thyssen Flying Possibly Hank Nolin Finish Kit Dave Syverton Finish Kit Yes Phil Perry Finish Kit Yes Peter Lammers Finish Kit Yes Don Baker Wing Kit Yes Dave Murphy Wing Kit Yes Charlie Brown Wing Kit Shannon Hick Empennage Bill Donahoe Empennage Tom Biggs Empennage Yes Gaylon Koenning Empennage Yes *Interested builders* Bradley Kerr Research Mark Griffith Research Yes Dave Macdonald Research Yes *From:* Nick Nafsinger [mailto:nicknaf(at)gmail.com] *Sent:* Wednesday, April 06, 2011 1:48 AM *To:* HoustonRVBuilders(at)yahoogroups.com *Cc:* <katie@williams-airport.com>; Chris Lionudakis *Subject:* Re: [HoustonRVBuilders] Houston RV-10 Builders/Flyers Gathering - April 9th Guys, I would absolutely love to come, however I'm stuck at work Friday - Monday this month. I swear, one of these years I'll be able to hold weekends off. Nick Sent from my iPhone On Mar 30, 2011, at 10:42 AM, "Perry, Phil" wrote: Houston RV Builders, It=92s been awhile since I sent a note on the RV-10 builders meet-and-greet . Work has been keeping me busy but now that we=92re within a couple of weeks and I wanted to remind you of the gathering. We have 15 RV-10=92s either flying or being built in the Houston area and m ost of us don=92t know each other. This is an opportunity to get the group together for lunch and to make a few friends with a common interstest. On April 9th I=92m going to be cooking lunch at North Houston Busienss Airp ort (9X1 - formerly known as Williams). We can being gathering around 11AM ' but I=92ll be out there much earlier setting up tables and food, etc. *If you believe you=92re going to attend, please let me know how many. It =92ll help me judge how much food I need to buy and prepare*. Also, if you=92re not a 10 builder or driver, you=92re still welcome to att end. If this is successful, we can try and have another one in the fall and hopefully put together a builders workshop for those interested in the techniques required to build an RV of any type. *Date:* April 9th *Time:* 11AM -> whenever *Location:* 9X1 ' Formerly Williams *Rain Date:* April 16th *Name* *Stage* *Tail Number* Bill Gipson Flying N730WL Nick Nafsinger Flying N569JC Bill Hicks Flying N64TX Pat Thyssen Flying N15PT Hank Nolin Finish Kit Dave Syverton Finish Kit Phil Perry Finish Kit Peter Lammers Finish Kit Don Baker Wing Kit Dave Murphy Wing Kit Charlie Brown Wing Kit Shannon Hick Empennage Bill Donahoe Empennage Tom Biggs Empennage Gaylon Koenning Empennage *Interested builders* Bradley Kerr Research Mark Griffith Research Dave Macdonald Research __._,_.___ Reply to *sender*| Reply to *group*| Reply *via web post*<http://groups.yahoo.com/group/HoustonRVBuilders/post;_ylc= X3oDMTJwa3V1dDFzBF9TAzk3MzU5NzE0BGdycElkAzMxMzczNzkEZ3Jwc3BJZAMxNzA1MzQwMDg 1BG1zZ0lkAzE2MTAEc2VjA2Z0cgRzbGsDcnBseQRzdGltZQMxMzAyMDcyNDk4?act=reply&m essageNum=1610>| *Start a New Topic*<http://groups.yahoo.com/group/HoustonRVBuilders/post;_y lc=X3oDMTJldnRuNXBjBF9TAzk3MzU5NzE0BGdycElkAzMxMzczNzkEZ3Jwc3BJZAMxNzA1Mz QwMDg1BHNlYwNmdHIEc2xrA250cGMEc3RpbWUDMTMwMjA3MjQ5OA--> Messages in this topic<http://groups.yahoo.com/group/HoustonRVBuilders/message/1604;_ylc=X 3oDMTM0cmN2OXJzBF9TAzk3MzU5NzE0BGdycElkAzMxMzczNzkEZ3Jwc3BJZAMxNzA1MzQwMDg1 BG1zZ0lkAzE2MTAEc2VjA2Z0cgRzbGsDdnRwYwRzdGltZQMxMzAyMDcyNDk4BHRwY0lkAzE2MDQ ->( *3*) *Recent Activity:* Visit Your Group<http://groups.yahoo.com/group/HoustonRVBuilders;_ylc=X3o DMTJlam5rMzN2BF9TAzk3MzU5NzE0BGdycElkAzMxMzczNzkEZ3Jwc3BJZAMxNzA1MzQwMDg1BH NlYwN2dGwEc2xrA3ZnaHAEc3RpbWUDMTMwMjA3MjQ5Nw--> Be sure to check the Files section of HoustonRVBuilders to see photos of groups RV aircraft. http://groups.yahoo.com/group/HoustonRVBuilders/files/ *MARKETPLACE* *Stay on top of your group activity without leaving the page you're on - Ge t the Yahoo! Toolbar now.<http://global.ard.yahoo.com/SIG=15onaferq/M=493064.14543979.143654 78.13298430/D=groups/S=1705340085:MKP1/Y=YAHOO/EXP=1302079698/L=d b32a2da-6019-11e0-9f30-4fff6148bb2a/B=iSjnbGKImh0-/J=1302072498943250/K =NyYgiZM0INZ8SqETCQ40oA/A=6060255/R=0/SIG=1194m4keh/*http:/us.toolb ar.yahoo.com/?.cpdl=grpj> * ** * ------------------------------ * *Find useful articles and helpful tips on living with Fibromyalgia. Visit the Fibromyalgia Zone today!<http://global.ard.yahoo.com/SIG=15ofrcp7r/M=493064.14543977.1436 5476.10835568/D=groups/S=1705340085:MKP1/Y=YAHOO/EXP=1302079698/L =db32a2da-6019-11e0-9f30-4fff6148bb2a/B=iijnbGKImh0-/J=13020724989432 50/K=NyYgiZM0INZ8SqETCQ40oA/A=6260316/R=0/SIG=11bc8n8gt/*http:/cust om.yahoo.com/fibromyalgiazone/> * ** [image: Yahoo! Groups]<http://groups.yahoo.com/;_ylc=X3oDMTJkaWthMW91BF9T Azk3NDc2NTkwBGdycElkAzMxMzczNzkEZ3Jwc3BJZAMxNzA1MzQwMDg1BHNlYwNmdHIEc2xrA2d mcARzdGltZQMxMzAyMDcyNDk4> Switch to: Text-Only, Daily Digest- Unsubscribe- Terms of Use <http://docs.yahoo.com/info/terms/> . __,_._,___ ________________________________________________________________________________
Date: Apr 06, 2011
Subject: Re: RV-10 Builders/Flyers Gathering - April 9th (Houston, TX)
I live in Round Rock, Tx. I have been monitoring the list, and its predeces sor, since the rv10 was first announced. I guess I'm a lurker. I would like to come and meet you all but I have an important engagement on the 9th. If you would, keep me in mind for future get together s. --- On Wed, 4/6/11, Phillip Perry wrote: From: Phillip Perry <philperry9(at)gmail.com> Subject: RV10-List: RV-10 Builders/Flyers Gathering - April 9th (Houston, T X) Date: Wednesday, April 6, 2011, 9:54 AM Hi Everyone, I'm opening this up to a broader audience in case I missed a few folks. There are 15 RV-10's either flying or being built in the Houston area and m ost of the folks don't know each other.=C2- So I started this project of gathering the "Birds of a Feather" so everyone could meet.=C2- I'm openin g it up to others who might want to fly-in for lunch.=C2- I talked to Don McDonald and a few others in Texas and I'm hoping they're looking for a go od excuse to fly their RV-10's on that day. =0A Below is a message I just sent out to the local crowd.=C2- If you believe you can attend, let me know and we'll be watching for you. More details can be found on this post: http://www.vansairforce.com/community/showthread.php?t=70339 =0A Phil ======= =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AHi Everyone, =0A =0AJust and update on the gathering on Saturday. The weather is looking gre at with=0Athe exception of some wind in the forecast. =0A =0AI updated the list with the -10 builders who have said they're coming. I 'm=0Ahoping we get some other folks flying in so we get a good mix of RV's and=0Ahopefully I don't end up with too much food left over. =0A =0AOn Monday I went and bought some food for ~50 BBQ Baked Potatoes. If you would=0Alike to bring a side dish (chips, breads, etc) that would be nice. I have five=0A8' folding tables and 52 chairs so we should be fine in thos e areas. =0A =0AI will be at the airport to setup around 9AM if some of you want to show up=0Aearly. A map can be found here: =0Ahttp://goo.gl/maps/n6Q2 =0A =0AIt will be very easy to find us on the field. There's only one way in an d only=0Aone large hanger. You can't miss it, so do sweat those details. =0A =0AI look forward to seeing you there. If you don't have my cell number sen d me an=0Ae-mail and I'll give it to you. =0A =0A=0A=0ALooking forward to seeing everyone! =0APhil=0A=0A=C2-=0A=0A=0A=0A=0A =0A =0A Name=0A =0A =0A Stage=0A =0A =0A Confirmed?=0A =0A =0A =0A =0A Bill Gipson=0A =0A =0A=0A Fly ing=0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Nick Nafsinger=0A =0A =0A =0A Flying=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Bill Hicks=0A =0A =0A=0A Flying=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Pat Thyss en=0A =0A =0A=0A Flying=0A =0A =0A=0A Possibly=0A =0A =0A =0A =0A Hank Nolin=0A =0A =0A=0A Finish Kit =0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Dave Syverton=0A =0A =0A=0A Finish Kit =0A =0A =0A=0A Yes =0A =0A =0A =0A =0A Phil Perry=0A =0A =0A=0A Finish Kit =0A =0A =0A =0A Yes=0A =0A =0A =0A =0A Peter Lammers=0A =0A =0A=0A Finish Kit =0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Don Baker=0A =0A =0A=0A Wing Kit=0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Dave Murphy=0A =0A =0A=0A Wing Kit=0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Charlie Brown=0A =0A =0A=0A Wing Kit=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Shannon Hi ck=0A =0A =0A=0A Empennage=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Bill Donahoe=0A =0A =0A=0A Empennage=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Tom Biggs=0A =0A =0A=0A Empennage=0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Gaylon Koenning=0A =0A =0A=0A Empennage=0A =0A =0A =0A Yes=0A =0A =0A =0A =0A =C2-=0A =0A =0A =C2-=0A =0A =0A =C2-=0A =0A =0A =0A =0A Interested builders=0A =0A =0A=0A =C2-=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Bradley Kerr=0A =0A =0A=0A R esearch=0A =0A =0A=0A =C2-=0A =0A =0A =0A =0A Mark Griffith=0A =0A =0A=0A Research=0A =0A =0A=0A Yes=0A =0A =0A =0A =0A Dave Macdonal d=0A =0A =0A=0A Research=0A =0A =0A=0A Yes=0A =0A =0A=0A=0A=C2-=0A =0A=C2-=0A=0A=0A=0A=C2-=0A=0A=0A=0A=0A=0AFrom: Nick Nafsinger=0A[mailto :nicknaf(at)gmail.com] =0ASent: Wednesday, April 06, 2011 1:48 AM =0ATo: HoustonRVBuilders(at)yahoogroups.com =0ACc: <katie@williams-airport.com>; Chris Lionudakis =0ASubject: Re: [HoustonRVBuilders] Houston RV-10 Builders/Flyers Gathering =0A- April 9th=0A=0A=0A=0A=0A=0A=C2-=0A=0A=C2- =0A=0A=0A=0A=0A=0A=0A=0A =0A=0AGuys,=0A=0A=0A=0A=0A=0A=C2-=0A=0A=0A=0A=0A=0AI would absolutely lov e to come, however I'm stuck at work=0AFriday - Monday this month. =C2- I swear, one of these years I'll be able to=0Ahold weekends off.=C2-=0A=0A =0A=0A=0A=0A=C2-=0A=0A=0A=0A=0A=0ANick =0A =0ASent from my iPhone=0A=0A=0A=0A=0A=0A =0AOn Mar 30, 2011, at 10:42 AM, "Perry, Phil" wrot e:=0A=0A=0A=0A=0A=0A=0A=0A=C2- =0A=0A=0A=0A=0A=0A=0A=0A=0A=0AHouston RV B uilders,=0A=0A=C2-=0A=0AIt=99s=0Abeen awhile since I sent a note on the RV-10 builders meet-and-greet.=C2-=0AWork has been keeping me busy b ut now that we=99re within a couple of weeks and I=0Awanted to remind you of the gathering.=0A=0A=C2-=0A=0AWe=0Ahave 15 RV-10=99s either flying or being built in the Houston area and most of us=0Adon=99t k now each other.=C2- This is an opportunity to get the group together=0Afo r lunch and to make a few friends with a common interstest.=0A=0A=C2-=0A =0AOn=0AApril 9th I=99m going to be cooking lunch at North Houston Bu sienss=0AAirport (9X1 - formerly known as Williams).=C2- We can being gat hering around=0A11AM =93 but I=99ll=C2- be out there much ear lier setting up tables and food,=0Aetc.=0A=0A=C2-=0A=0AIf=0Ayou believe y ou=99re going to attend, please let me know how many.=C2- It =99ll=0Ahelp me judge how much food I need to buy and prepare.=0A=0A=C2- =0A=0AAlso,=0Aif you=99re not a 10 builder or driver, you=99re still welcome to attend.=C2- If=0Athis is successful, we can try and have another one in the fall and hopefully=0Aput together a builders workshop f or those interested in the techniques=0Arequired to build an RV of any type .=0A=0A=C2-=0A=0ADate:=0A=C2-=C2-=C2-=0A=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=0AApril 9th =0A=0ATime:=0A=C2-=C2-=0A=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=0A11AM -> whenever=0A=0ALocat ion:=0A=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 9 X1 =93=0AFormerly Williams=0A=0ARain=0ADate:=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2- April=0A16th=0A=0A=C2-=0A=0A=0A =0A =0A Name=0A =0A =0A Stage=0A =0A =0A Tail Number=0A =0A =0A =0A =0A Bill Gipson=0A =0A =0A Flying=0A =0A =0A N730WL=0A =0A =0A =0A =0A Nick Nafsinger=0A =0A =0A Flying=0A =0A =0A N569JC=0A =0A =0A =0A =0A Bill Hicks=0A =0A =0A Flying=0A =0A =0A N64TX=0A =0A =0A =0A =0A Pat Thyssen=0A =0A =0A Flying=0A =0A =0A N15PT=0A =0A =0A =0A =0A Hank Nolin=0A =0A =0A Finish Kit =0A =0A =0A =C2-=0A =0A =0A =0A =0A Dave Syverton=0A =0A =0A Finish Kit =0A =0A =0A =C2- =0A =0A =0A =0A =0A Phil Perry=0A =0A =0A Finish Kit =0A =0A =0A =C2-=0A =0A =0A =0A =0A Peter Lammers=0A =0A =0A Finish Kit =0A =0A =0A =C2-=0A =0A =0A =0A =0A Don Baker=0A =0A =0A Wing Kit=0A =0A =0A =C2-=0A =0A =0A =0A =0A Dave Murphy=0A =0A =0A Wing Kit =0A =0A =0A =C2-=0A =0A =0A =0A =0A Charlie Brown=0A =0A =0A Win g Kit=0A =0A =0A =C2-=0A =0A =0A =0A =0A Shannon Hick=0A =0A =0A Empennage=0A =0A =0A =C2-=0A =0A =0A =0A =0A Bill Donahoe=0A =0A =0A Empennage=0A =0A =0A =C2-=0A =0A =0A =0A =0A Tom Biggs=0A =0A =0A Empennage=0A =0A =0A =C2-=0A =0A =0A =0A =0A Gaylon Koenn ing=0A =0A =0A Empennage=0A =0A =0A =C2-=0A =0A =0A =0A =0A =C2 -=0A =0A =0A =C2-=0A =0A =0A =C2-=0A =0A =0A =0A =0A Interes ted builders=0A =0A =0A =C2-=0A =0A =0A =C2-=0A =0A =0A =0A =0A Bradley Kerr=0A =0A =0A Research=0A =0A =0A =C2-=0A =0A =0A =0A =0A Mark Griffith=0A =0A =0A Research=0A =0A =0A =C2-=0A =0A =0A =0A =0A Dave Macdonald=0A =0A =0A Research=0A =0A =0A =C2-=0A =0A =0A=0A=0A=C2-=0A=0A=C2-=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A =0A=0A=0A=0A__._,_.___=0A=0A=0A=0A=0A=0A=0A=0AReply=0Ato sender | Reply=0At o group | Reply=0Avia web post | Start=0Aa New Topic =0A=0A=0A=0AMessages =0Ain this topic (3) =0A=0A=0A=0A=0A=0ARecent=0AActivity:=0A=0A=0A=0A=0AVis it Your Group =0A=0A=0A=0A=0A=0A=0A=0A=0ABe=0Asure to check the Files secti on of HoustonRVBuilders to see photos of groups RV=0Aaircraft. =0A =0Ahttp://groups.yahoo.com/group/HoustonRVBuilders/files/=0A=0A=0A=0A=0A=0A =0A=0A=0AMARKETPLACE=0A=0A=0A=0A=0A=0A=0A=0AStay=0Aon top of your group act ivity without leaving the page you're on - Get the=0AYahoo! Toolbar now.=0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AFind=0Auseful articles and helpfu l tips on living with Fibromyalgia. Visit the=0AFibromyalgia Zone today!=0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0ASwitch to: Text-Only, Da ily Digest =A2 Unsubscribe =A2 Terms=0Aof Use=0A=0A=0A=0A=0A=0A =0A=0A=0A=0A.=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A__,_._,___=0A=0A=0A=0A=0A=0A=0A =0A=0A =0A=0A ________________________________________________________________________________
Date: Apr 06, 2011
I don't remember the tradition as a builder :) but who am I to argue. I will come prepared with some of our local brew from the Abita brewery. Just need somewhere to ice it down when I get there. Eric Eric_Kallio wrote: > Haven't had the spotted cow before as I missed last years event. Plane comes out of paint early June. As long as my deployment schedule doesn't change AGAIN I am in. > > Eric Kallio > N518RV :D :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336316#336316 ________________________________________________________________________________
Date: Apr 06, 2011
Rob I went to the airport yesterday for the serial # but could not find it. I looked in the manual when I got back home and it's under the head band. I'll get it asap. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336323#336323 ________________________________________________________________________________
Date: Apr 06, 2011
I don't remember the tradition as a builder :) but who am I to argue. I will come prepared with some of our local brew from the Abita brewery. Just need somewhere to ice it down when I get there. Eric Eric_Kallio wrote: > Haven't had the spotted cow before as I missed last years event. Plane comes out of paint early June. As long as my deployment schedule doesn't change AGAIN I am in. > > Eric Kallio > N518RV :D :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336325#336325 ________________________________________________________________________________
Date: Apr 07, 2011
No big rush. Reply to my personal email so we don't jam the list. flysrv10 at gmail.com. Thanks. On Apr 6, 2011, at 7:56 PM, Ron B. wrote: > > Rob > I went to the airport yesterday for the serial # but could not find it. I looked in the manual when I got back home and it's under the head band. I'll get it asap. > Ron > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336323#336323 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2011
Subject: Andair Extension - anyone need a short piece
I just finished installing my Andair fuel valve. After cutting the extension I have a piece 2-3/4" long. Anyone want it, before I put it into the scrap pile. Larry #356 and still building ________________________________________________________________________________
Date: Apr 08, 2011
Phil, it happens to be the Sat for our EEA meeting,,,, so most of the guys =0Aprobably won't make it.=C2- Tom Lewis is still updating his 10 panel.. .. haven't =0Aheard from Dave Moore (building) or Bill Steppling.=C2- We are keeping an eye on =0Athe weather... at this point it looks doable.... s o Kim and I will probably see =0Ayou tomorrow.=C2- Anything I should know about the airspace down there?=0ADon=0A=0A=0A=0A=0A_______________________ _________=0AFrom: Phillip Perry <philperry9(at)gmail.com>=0ATo: rv10-list@matr onics.com=0ASent: Wed, April 6, 2011 9:54:25 AM=0ASubject: RV10-List: RV-10 Builders/Flyers Gathering - April 9th (Houston, TX)=0A=0AHi Everyone,=0A =0AI'm opening this up to a broader audience in case I missed a few folks. =0A=0AThere are 15 RV-10's either flying or being built in the Houston area and most =0Aof the folks don't know each other.=C2- So I started this pr oject of gathering the =0A"Birds of a Feather" so everyone could meet.=C2 - I'm opening it up to others who =0Amight want to fly-in for lunch.=C2 - I talked to Don McDonald and a few others in =0ATexas and I'm hoping th ey're looking for a good excuse to fly their RV-10's on =0Athat day.=0A=0AB elow is a message I just sent out to the local crowd.=C2- If you believe you can =0Aattend, let me know and we'll be watching for you.=0A=0AMore det ails can be found on this post:=0Ahttp://www.vansairforce.com/community/sho wthread.php?t=70339=0A=0APhil=0A=0A=========0A=0A=0A=0A =0A=0AHi Everyone,=0A=0AJust and update on the gathering on Saturday. The w eather is looking great with =0Athe exception of some wind in the forecast. =0A=0AI updated the list with the -10 builders who have said they're coming . I'm =0Ahoping we get some other folks flying in so we get a good mix of R V's and =0Ahopefully I don't end up with too much food left over.=0A=0AOn M onday I went and bought some food for ~50 BBQ Baked Potatoes. If you would =0Alike to bring a side dish (chips, breads, etc) that would be nice. I hav e five =0A8' folding tables and 52 chairs so we should be fine in those are as.=0A=0AI will be at the airport to setup around 9AM if some of you want t o show up =0Aearly. A map can be found here:=0Ahttp://goo.gl/maps/n6Q2=0A =0AIt will be very easy to find us on the field. There's only one way in an d only =0Aone large hanger. You can't miss it, so do sweat those details. =0A=0AI look forward to seeing you there. If you don't have my cell number send me an =0Ae-mail and I'll give it to you.=0A=0A=0ALooking forward to se eing everyone!=0APhil=0A=C2-=0AName Stage Confirmed? =0ABill Gipson Flyin g Yes =0ANick Nafsinger Flying =C2- =0ABill Hicks Flying =C2- =0APat Th yssen Flying Possibly =0AHank Nolin Finish Kit =C2- =0ADave Syverton Fin ish Kit Yes =0APhil Perry Finish Kit Yes =0APeter Lammers Finish Kit Yes =0ADon Baker Wing Kit Yes =0ADave Murphy Wing Kit Yes =0ACharlie Brown Win g Kit =C2- =0AShannon Hick Empennage =C2- =0ABill Donahoe Empennage =C2 - =0ATom Biggs Empennage Yes =0AGaylon Koenning Empennage Yes =0A=C2- =C2- =C2- =0AInterested builders =C2- =C2- =0ABradley Kerr Research =C2- =0AMark Griffith Research Yes =0ADave Macdonald Research Yes =0A=C2 -=0A=C2-=0A=C2-=0AFrom:Nick Nafsinger [mailto:nicknaf(at)gmail.com] =0AS ent: Wednesday, April 06, 2011 1:48 AM=0ATo: HoustonRVBuilders@yahoogroups. com=0ACc: <katie@williams-airport.com>; Chris Lionudakis=0ASubject: Re: [Ho ustonRVBuilders] Houston RV-10 Builders/Flyers Gathering - April =0A9th=0A =C2-=0A=C2- =0AGuys,=0A=C2-=0AI would absolutely love to come, howeve r I'm stuck at work Friday - Monday this =0Amonth. =C2- I swear, one of t hese years I'll be able to hold weekends off.=C2-=0A=C2-=0ANick=0A=0ASe nt from my iPhone=0A=0AOn Mar 30, 2011, at 10:42 AM, "Perry, Phil" wrote:=0A=C2- =0A>Houston RV Builders,=0A>=C2-=0A>It =99s been awhile since I sent a note on the RV-10 builders meet-and-gree t.=C2- Work =0A>has been keeping me busy but now that we=99re withi n a couple of weeks and I =0A>wanted to remind you of the gathering.=0A>=C2 -=0A>We have 15 RV-10=99s either flying or being built in the Houst on area and most of =0A>us don=99t know each other.=C2- This is an opportunity to get the group together for =0A>lunch and to make a few frien ds with a common interstest.=0A>=C2-=0A>On April 9th I=99m going to be cooking lunch at North Houston Busienss Airport =0A>(9X1 - formerly kno wn as Williams).=C2- We can being gathering around 11AM =93 but =0A >I=99ll=C2- be out there much earlier setting up tables and food, e tc.=0A>=C2-=0A>If you believe you=99re going to attend, please let me know how many.=C2- It=99ll help =0A>me judge how much food I nee d to buy and prepare.=0A>=C2-=0A>Also, if you=99re not a 10 builder or driver, you=99re still welcome to attend.=C2- If =0A>this is su ccessful, we can try and have another one in the fall and hopefully =0A>put together a builders workshop for those interested in the techniques requir ed =0A>to build an RV of any type.=0A>=C2-=0A>Date: =C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2 -=C2-=C2- April 9th=0A>Time: =C2-=C2- =C2-=C2-=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- 11AM -> whe never=0A>Location: =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2- 9X1 =93 Formerly Williams=0A>Rain Date:=C2-=C2-=C2 -=C2-=C2-=C2-=C2-=C2-=C2-=C2- April 16th=0A>=C2-=0A>Name Stage Tail Number =0A>Bill Gipson Flying N730WL =0A>Nick Nafsinger Flying N 569JC =0A>Bill Hicks Flying N64TX =0A>Pat Thyssen Flying N15PT =0A>Hank Nol in Finish Kit =C2- =0A>Dave Syverton Finish Kit =C2- =0A>Phil Perry F inish Kit =C2- =0A>Peter Lammers Finish Kit =C2- =0A>Don Baker Wing K it =C2- =0A>Dave Murphy Wing Kit =C2- =0A>Charlie Brown Wing Kit =C2- =0A>Shannon Hick Empennage =C2- =0A>Bill Donahoe Empennage =C2- =0A>To m Biggs Empennage =C2- =0A>Gaylon Koenning Empennage =C2- =0A>=C2- =C2- =C2- =0A>Interested builders =C2- =C2- =0A>Bradley Kerr Resear ch =C2- =0A>Mark Griffith Research =C2- =0A>Dave Macdonald Research =C2 - =0A>=C2-=0A>=C2-=0A__._,_.___=0AReply to sender | Reply to group | Reply via web post | Start a New Topic =0AMessages in this topic (3) =0ARec ent Activity:=0AVisit Your Group =0ABe sure to check the Files section of H oustonRVBuilders to see photos of groups =0ARV aircraft.=0A=0Ahttp://groups .yahoo.com/group/HoustonRVBuilders/files/ =0AMARKETPLACE=0AStay on top of y our group activity without leaving the page you're on - Get the =0AYahoo! T oolbar now.=0A=0A________________________________=0A=0AFind useful articles and helpful tips on living with Fibromyalgia. Visit the =0AFibromyalgia Zo ne today!=0ASwitch to: Text-Only, Daily Digest =A2 Unsubscribe =0A ________________________________________________________________________________
Date: Apr 08, 2011
Hey Don, et al. There's nothing too special about getting into 9X1. Coming from your direct ion, once you get to the class B veil you can drop to 1500' and you will rem ain clear of the Bravo all the way in. Over the field the floor of the Brav o is 2000'. The Class B surface area is south of the field by ~ 2 miles. S o you want to stay close in to the field and not stray too far south. I just walked the field and it's firm for parking. We haven't had rain in a few weeks. I will try and get someone out to help park as the planes arriv e. I think you have my cell. Give me a shout if you need anything. Have a safe flight and I look forward to seeing you. Phil On Apr 8, 2011, at 3:59 PM, Don McDonald wrote: > Phil, it happens to be the Sat for our EEA meeting,,,, so most of the guys probably won't make it. Tom Lewis is still updating his 10 panel.... haven 't heard from Dave Moore (building) or Bill Steppling. We are keeping an ey e on the weather... at this point it looks doable.... so Kim and I will prob ably see you tomorrow. Anything I should know about the airspace down there ? > Don > > From: Phillip Perry <philperry9(at)gmail.com> > To: rv10-list(at)matronics.com > Sent: Wed, April 6, 2011 9:54:25 AM > Subject: RV10-List: RV-10 Builders/Flyers Gathering - April 9th (Houston, T X) > > Hi Everyone, > > I'm opening this up to a broader audience in case I missed a few folks. > > There are 15 RV-10's either flying or being built in the Houston area and m ost of the folks don't know each other. So I started this project of gather ing the "Birds of a Feather" so everyone could meet. I'm opening it up to o thers who might want to fly-in for lunch. I talked to Don McDonald and a fe w others in Texas and I'm hoping they're looking for a good excuse to fly th eir RV-10's on that day. > > Below is a message I just sent out to the local crowd. If you believe you can attend, let me know and we'll be watching for you. > > More details can be found on this post: > http://www.vansairforce.com/community/showthread.php?t=70339 > > Phil > > ======= > > > > Hi Everyone, > > Just and update on the gathering on Saturday. The weather is looking great with the exception of some wind in the forecast. > > I updated the list with the -10 builders who have said they're coming. I'm hoping we get some other folks flying in so we get a good mix of RV's and h opefully I don't end up with too much food left over. > > On Monday I went and bought some food for ~50 BBQ Baked Potatoes. If you w ould like to bring a side dish (chips, breads, etc) that would be nice. I ha ve five 8' folding tables and 52 chairs so we should be fine in those areas. > > I will be at the airport to setup around 9AM if some of you want to show u p early. A map can be found here: > http://goo.gl/maps/n6Q2 > > It will be very easy to find us on the field. There's only one way in and o nly one large hanger. You can't miss it, so do sweat those details. > > I look forward to seeing you there. If you don't have my cell number send m e an e-mail and I'll give it to you. > > > Looking forward to seeing everyone! > Phil > > > > Name > > Stage > > Confirmed? > > Bill Gipson > > Flying > > Yes > > Nick Nafsinger > > Flying > > > > Bill Hicks > > Flying > > > > Pat Thyssen > > Flying > > Possibly > > Hank Nolin > > Finish Kit > > > > Dave Syverton > > Finish Kit > > Yes > > Phil Perry > > Finish Kit > > Yes > > Peter Lammers > > Finish Kit > > Yes > > Don Baker > > Wing Kit > > Yes > > Dave Murphy > > Wing Kit > > Yes > > Charlie Brown > > Wing Kit > > > > Shannon Hick > > Empennage > > > > Bill Donahoe > > Empennage > > > > Tom Biggs > > Empennage > > Yes > > Gaylon Koenning > > Empennage > > Yes > > > > > > > > Interested builders > > > > > > Bradley Kerr > > Research > > > > Mark Griffith > > Research > > Yes > > Dave Macdonald > > Research > > Yes > > > > > > > > From: Nick Nafsinger [mailto:nicknaf(at)gmail.com] > Sent: Wednesday, April 06, 2011 1:48 AM > To: HoustonRVBuilders(at)yahoogroups.com > Cc: <katie@williams-airport.com>; Chris Lionudakis > Subject: Re: [HoustonRVBuilders] Houston RV-10 Builders/Flyers Gathering - April 9th > > > > > > Guys, > > > > I would absolutely love to come, however I'm stuck at work Friday - Monday this month. I swear, one of these years I'll be able to hold weekends off . > > > > Nick > > Sent from my iPhone > > > On Mar 30, 2011, at 10:42 AM, "Perry, Phil" wrote: > > > > Houston RV Builders, > > > > It=99s been awhile since I sent a note on the RV-10 builders meet-an d-greet. Work has been keeping me busy but now that we=99re within a c ouple of weeks and I wanted to remind you of the gathering. > > > > We have 15 RV-10=99s either flying or being built in the Houston are a and most of us don=99t know each other. This is an opportunity to g et the group together for lunch and to make a few friends with a common inte rstest. > > > > On April 9th I=99m going to be cooking lunch at North Houston Busien ss Airport (9X1 - formerly known as Williams). We can being gathering aroun d 11AM =93 but I=99ll be out there much earlier setting up tabl es and food, etc. > > > > If you believe you=99re going to attend, please let me know how many . It=99ll help me judge how much food I need to buy and prepare. > > > > Also, if you=99re not a 10 builder or driver, you=99re still w elcome to attend. If this is successful, we can try and have another one in the fall and hopefully put together a builders workshop for those intereste d in the techniques required to build an RV of any type. > > > > Date: April 9th > > Time: 11AM -> whenever > > Location: 9X1 =93 Formerly Williams > > Rain Date: April 16th > > > > Name > > Stage > > Tail Number > > Bill Gipson > > Flying > > N730WL > > Nick Nafsinger > > Flying > > N569JC > > Bill Hicks > > Flying > > N64TX > > Pat Thyssen > > Flying > > N15PT > > Hank Nolin > > Finish Kit > > > > Dave Syverton > > Finish Kit > > > > Phil Perry > > Finish Kit > > > > Peter Lammers > > Finish Kit > > > > Don Baker > > Wing Kit > > > > Dave Murphy > > Wing Kit > > > > Charlie Brown > > Wing Kit > > > > Shannon Hick > > Empennage > > > > Bill Donahoe > > Empennage > > > > Tom Biggs > > Empennage > > > > Gaylon Koenning > > Empennage
March 20, 2011 - April 08, 2011
RV10-Archive.digest.vol-ic
