RV10-Archive.digest.vol-id
April 08, 2011 - May 02, 2011
      > Interested builders
      > Bradley Kerr
      > Research
      > Mark Griffith
      > Research
      > Dave Macdonald
      > Research
      > __._,_.___
      > Reply to sender | Reply to group | Reply via web post | Start a New Topic
      > Messages in this topic (3)
      > RECENT ACTIVITY:
      > Visit Your Group
      > Be sure to check the Files section of HoustonRVBuilders to see photos of g
      roups RV aircraft.
      > http://groups.yahoo.com/group/HoustonRVBuilders/files/
      > MARKETPLACE
      > Stay on top of your group activity without leaving the page you're on - Ge
      t the Yahoo! Toolbar now.
      > Find useful articles and helpful tips on living with Fibromyalgia. Visit t
      he Fibromyalgia Zone today!
      > Switch to: Text-Only, Daily Digest =A2 Unsubscribe =A2 Terms o
      f Use
      > __,_._,___
      > http://www.matronics.com/contributi=============
Subject: Ack E-04 shipping
Date: Apr 08, 2011
Talked to someone at the dealer where I got my new ELT and they were verifying if I still wanted my ELT because it was shipping. It may have shipped Friday, I'm not sure, but it sounded like they had already received them and were sending them right out the door. I'll post when I receive it....and probably a write up as soon as it's installed which won't be far behind. Tim ________________________________________________________________________________
Subject: I-Pad2 and Bad elf question
Date: Apr 09, 2011
I have a I-Pad2 3G (ATT) unit and I do not quite understand the GPS functions of the machine. I have not yet subscribed to ATT 3G service, but intend to do so in a a month or so. Do I need to buy the Bad Elf unit to exploit the GPS capabilities on land and in the air or will it do fine in the US without Bad elf. -------- See you OSH '11 Q/B - flying 1 yr+ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336500#336500 ________________________________________________________________________________
Subject: Re: I-Pad2 and Bad elf question
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Apr 10, 2011
The internal GPS works fine for on road or in flight use. You do not have to have a data subscription to use the GPS you only have to ignore the pop up that keeps asking you if you want to add a data subscription. One little detail, if you turn on airplane mode the GPS also gets turned off. You want to turn off wifi and cellular data separately, then the GPS still works. This is not to say that the built in GPS is great, I am sure the external receivers are better. But we have been flying with only the internal GPS for almost a year now and find the accuracy and lock to be just fine. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336503#336503 ________________________________________________________________________________
Date: Apr 10, 2011
It will work fine. For me it was pretty good. The chipset in my ipad 2 verizon version is different I believe and that one worked excellent for me on a trip I just got back on. My AT&T ipad 1 wasn't quite as good and quick to acquire but it worked ok. The bad elf stuff would make it even quicker, if you want the extra bump sticking out to bang around. I don't. The jailbreak isn't out for ipad 2 yet so the jailbreak and bluetooth method i used on my old ipad isn't an option on that one yet. But my verizon ipad 2 worked fine with the internal GPS on my trip to the Baja of over 4000miles and it didn't let mr down once.....so I don't think I'll even do anything different there. Tim On Apr 10, 2011, at 1:25 AM, "AirMike" wrote: > > I have a I-Pad2 3G (ATT) unit and I do not quite understand the GPS functions of the machine. I have not yet subscribed to ATT 3G service, but intend to do so in a a month or so. > > Do I need to buy the Bad Elf unit to exploit the GPS capabilities on land and in the air or will it do fine in the US without Bad elf. > > -------- > See you OSH '11 > Q/B - flying 1 yr+ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336500#336500 > > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2011
Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. Tim On Apr 10, 2011, at 6:21 AM, "jkreidler" wrote: > > The internal GPS works fine for on road or in flight use. You do not have to have a data subscription to use the GPS you only have to ignore the pop up that keeps asking you if you want to add a data subscription. One little detail, if you turn on airplane mode the GPS also gets turned off. You want to turn off wifi and cellular data separately, then the GPS still works. > > This is not to say that the built in GPS is great, I am sure the external receivers are better. But we have been flying with only the internal GPS for almost a year now and find the accuracy and lock to be just fine. > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336503#336503 > > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2011
Tim, I flew with my Ipad2 for the first time yesterday on a kneeboard. It was a bright sunny day. I had trouble reading it. Any suggestions? Alan Ps. Would like to hear more about your Baha trip -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, April 10, 2011 8:34 AM Subject: Re: RV10-List: I-Pad2 and Bad elf question It will work fine. For me it was pretty good. The chipset in my ipad 2 verizon version is different I believe and that one worked excellent for me on a trip I just got back on. My AT&T ipad 1 wasn't quite as good and quick to acquire but it worked ok. The bad elf stuff would make it even quicker, if you want the extra bump sticking out to bang around. I don't. The jailbreak isn't out for ipad 2 yet so the jailbreak and bluetooth method i used on my old ipad isn't an option on that one yet. But my verizon ipad 2 worked fine with the internal GPS on my trip to the Baja of over 4000miles and it didn't let mr down once.....so I don't think I'll even do anything different there. Tim On Apr 10, 2011, at 1:25 AM, "AirMike" wrote: > > I have a I-Pad2 3G (ATT) unit and I do not quite understand the GPS functions of the machine. I have not yet subscribed to ATT 3G service, but intend to do so in a a month or so. > > Do I need to buy the Bad Elf unit to exploit the GPS capabilities on land and in the air or will it do fine in the US without Bad elf. > > -------- > See you OSH '11 > Q/B - flying 1 yr+ > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336500#336500 > > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2011
I use the brando anti-glare screen protector. They come from china but are the only one I really found that I like. Also, turn the brightness all the way up. With those 2 things it was working well for me over the southwest on bright sunny days. It's better than my motion le1600 tablet with viewanywhere. Tim On Apr 10, 2011, at 8:04 AM, "Alan Mekler" wrote: > > Tim, > I flew with my Ipad2 for the first time yesterday on a kneeboard. It was a > bright sunny day. I had trouble reading it. Any suggestions? > Alan > Ps. Would like to hear more about your Baha trip > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Sunday, April 10, 2011 8:34 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: I-Pad2 and Bad elf question > > > It will work fine. For me it was pretty good. The chipset in my ipad 2 > verizon version is different I believe and that one worked excellent for me > on a trip I just got back on. My AT&T ipad 1 wasn't quite as good and quick > to acquire but it worked ok. The bad elf stuff would make it even quicker, > if you want the extra bump sticking out to bang around. I don't. The > jailbreak isn't out for ipad 2 yet so the jailbreak and bluetooth method i > used on my old ipad isn't an option on that one yet. But my verizon ipad 2 > worked fine with the internal GPS on my trip to the Baja of over 4000miles > and it didn't let mr down once.....so I don't think I'll even do anything > different there. > Tim > > > > On Apr 10, 2011, at 1:25 AM, "AirMike" wrote: > >> >> I have a I-Pad2 3G (ATT) unit and I do not quite understand the GPS > functions of the machine. I have not yet subscribed to ATT 3G service, but > intend to do so in a a month or so. >> >> Do I need to buy the Bad Elf unit to exploit the GPS capabilities on land > and in the air or will it do fine in the US without Bad elf. >> >> -------- >> See you OSH '11 >> Q/B - flying 1 yr+ >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=336500#336500 >> >> >> >> >> >> >> >> >> > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2011
How is the altitude accuracy in GPS only mode? I notice substantial improvement with WAAS equipped GPS vs non-WAAS on altitude, not so much in horizontal position. Has anyone compared having Bad Elf vs internal? On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > Tim ________________________________________________________________________________
Date: Apr 10, 2011
My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ________________________________________________________________________________
Date: Apr 10, 2011
I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitu de when I looked a couple times on this trip. But, you're better off using b aro altitudes. If you're relying on the ipad to be a backup vertical approa ch gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: > My internal was absolutely perfect last night on the iPad 2. > On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > > > > How is the altitude accuracy in GPS only mode? I notice substantial > > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > > much in horizontal position. Has anyone compared having Bad Elf vs > > internal? > > > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T o r verizon ipad. The worst thing about either is just that you can't put it i n full airplane mode. Other than that, it works well. I wish the gps chip w as separate and you could turn it on separately. But what Jason said works g ood. > > > Tim > > > > > ============ > st">http://www.matronics.com/Navigator?RV10-List > ============ > .matronics.com > ============ > Dralle, List Admin. > p://www.matronics.com/contribution > ============ > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 10, 2011
To avoid the annoying subscription requests from your carrier on a 3G iPad 2 I went to Settings > Cellular Data > Off and have not had a subscription request prompt since. I also own the Bad Elf for my iPad 1 and the iPad 2 (Verizon) version seems to be good enough for me to not want to use the Bad Elf with the new iPad. Robin *From:* owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson *Sent:* Sunday, April 10, 2011 8:46 AM *To:* rv10-list(at)matronics.com *Subject:* Re: RV10-List: Re: I-Pad2 and Bad elf question I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitude when I looked a couple times on this trip. But, you're better off using baro altitudes. If you're relying on the ipad to be a backup vertical approach gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ============ st">http://www.matronics.com/Navigator?RV10-List ============ .matronics.com ============ Dralle, List Admin. p://www.matronics.com/contribution ============ > > * * * * * * * * * * <3D%22http:/www.matronics.com/Navigator?RV10-List>* <3D%22http:/www.matronics.com/contribution>* * * ------------------------------ No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 10, 2011
My first flight with the iPad2 was a 400 mile round trip over two days. Running Foreflight my altitude was within 10ft, and ground speed within 1kt of my Garmin 430W. It's the Verizon version using only the internal gps. I was amazed at the accuracy. But I'm not shooting IFR approaches. Here's a fun test. Install Google Earth on your iPad2. Zoom in on your current location. Then walk around your house. Bobby Hughes N416AS ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, April 10, 2011 9:46 AM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitude when I looked a couple times on this trip. But, you're better off using baro altitudes. If you're relying on the ipad to be a backup vertical approach gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" < apilot2(at)gmail.com> wrote: > apilot2(at)gmail.com> > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson < Tim(at)myrv10.com> wrote: Tim(at)myrv10.com> > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ============ st"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List ============ .matronics.com ============ Dralle, List Admin. p://www.matronics.com/contribution ============ > > > ________________________________________________________________________________
Date: Apr 10, 2011
Sounds like the new version has significantly better GPS engine than the original. On Sun, Apr 10, 2011 at 11:52 AM, Bobby J. Hughes wrote: > My first flight with the iPad2 was a 400 mile round trip over two days. > Running Foreflight my altitude was within 10ft, and ground speed within 1kt > of my Garmin 430W. Its the Verizon version using only the internal gps. I > was amazed at the accuracy. But Im not shooting IFR approaches. > > > Heres a fun test. Install Google Earth on your iPad2. Zoom in on your > current location. Then walk around your house. > > > Bobby Hughes > > N416AS > > > ________________________________ > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Sunday, April 10, 2011 9:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question > > > I didn't really care about altitude. IMHO, lateral is really the only thing > that matters. Trusting any cheap gps for vertical guidance isn't something > I'd want to to. That said, my ipad 2 gps was pretty close to actual > altitude when I looked a couple times on this trip. But, you're better off > using baro altitudes. If you're relying on the ipad to be a backup vertical > approach gps, bad elf or not, you're putting too much faith in it. > > Tim > > > On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: > > My internal was absolutely perfect last night on the iPad 2. > On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: >> >> >> How is the altitude accuracy in GPS only mode? I notice substantial >> improvement with WAAS equipped GPS vs non-WAAS on altitude, not so >> much in horizontal position. Has anyone compared having Bad Elf vs >> internal? >> >> On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: >> > >> > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or >> > verizon ipad. The worst thing about either is just that you can't put it in >> > full airplane mode. Other than that, it works well. I wish the gps chip >> > was separate and you could turn it on separately. But what Jason said works >> > good. >> > Tim >> >> > ============ > st">http://www.matronics.com/Navigator?RV10-List > ============ > .matronics.com > ============ > Dralle, List Admin. > p://www.matronics.com/contribution > ============ >> >> >> > > ________________________________________________________________________________
Date: Apr 10, 2011
Actually, in digging to find out what chipset they used on the new iPad2's, it looks like BOTH the Verizon and AT&T should be in better shape than previous iPhone/iPad models. It looks like both iPad 2's, got new chipsets for GPS. Here are a few links and a little info grabbed from them: iPad 2 3G teardown proves ties to iPhone 4 design, upgrades ** The EVDO-based 3G version is near identical to the Verizon iPhone 4 and has the same dual-mode Qualcomm MDM6600 chipset. The MDM6600 is a GSM/UMTS/HSPA+/EV-DO multi-mode processor. ** The HSPA-based 3G version for AT&T and the world is using an Infineon 337S3833 baseband chip to get online but has upgraded to a newer Broadcom BCM4751 for the GPS chipset http://www.electronista.com/articles/11/03/30/ipad.2.3g.torn.down.by.ifixit/ http://wirelesse2e.wordpress.com/2011/03/15/iphone-cdma-and-ipad-2-no-obvious-path-for-lte/ The GPS in the iPad is part of the 3G chipset. That does not mean it isn't a true GPS. Assisted GPS means that you have a 'real' GPS that has other services associated. http://en.wikipedia.org/wiki/Assisted_GPS iPhone 5 will be a world-phone using Qualcomm MDM6600. Even though Apple prefers not to change its proven designs frequently, MDM6600 is simply superior to legacy Infineon baseband processor and it simplifies GPS implementation. So you're likely to be better off with GPS in any 3G version of iPad 2, than you are with iPad 1, or with iPhones prior to iPhone 4. The MDM6600 chipset may be why the Verizon ones are really pretty good with the GPS acquisition and accuracy. And I'm sure that Apple wouldn't have moved to the Broadcom BCM4751 for the AT&T version unless it provided something better too. Tim > > Sounds like the new version has significantly better GPS engine than > the original. > ________________________________________________________________________________
Date: Apr 10, 2011
Just a reminder to all that gps altitude (True altitude) and our barometric altimeter will not agree, except on the ground or on a "standard day" (which of course almost never exists). I find it interesting to see by how much they can sometimes differ. It's a reminder to give oneself a good cushion if using baro altitude for terrain avoidance. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336569#336569 ________________________________________________________________________________
Date: Apr 10, 2011
Or, if you're using baro vnav, make sure you always check and use the current altimeter setting. Been done that way for years. And, get get regular required pitot static tests for ifr flight, and, and verify your plane's static error so that your airspeed reads correct and your altimeter does too. When it comes to gps, I'd only trust one that's made for ifr use to be fast enough to provide the altitude accuracy for an approach. Tim On Apr 10, 2011, at 5:16 PM, "Bob Turner" wrote: > > Just a reminder to all that gps altitude (True altitude) and our barometric altimeter will not agree, except on the ground or on a "standard day" (which of course almost never exists). > > I find it interesting to see by how much they can sometimes differ. It's a reminder to give oneself a good cushion if using baro altitude for terrain avoidance. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336569#336569 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Bose X headset for sale
Date: Apr 11, 2011
I tried to send you the serial # but the e-mail address flysrv10(at)gmail.com was returned undeliverable . I used @ instead of (at) . Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336653#336653 ________________________________________________________________________________
Date: Apr 11, 2011
Hmm. Interesting. Your email bounces also. Call at 772-418-1417. Thanks. On Apr 11, 2011, at 3:57 PM, Ron B. wrote: > > I tried to send you the serial # but the e-mail address flysrv10(at)gmail.com was returned undeliverable . I used @ instead of (at) . > Ron > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336653#336653 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 11, 2011
Subject: FS: PS Engineering 8000B
I have a PS Engineering 8000B audio panel with new tray for sale for $1000. The unit works perfect and is in great condition. I can send pictures to anyone interested. Scott Schmidt scottmschmidt(at)yahoo.com ________________________________________________________________________________
Subject: TCAS ground plane
Date: Apr 13, 2011
Thought I would share my experience installing a ground plane on the RV-10 cabin top for the GTS800 and hopefully save some building time for others. Like every other Garmin device, the installation manual gives you a detailed list of priorities for mounting and location of antennas. Some items, such as the GMU44 would only meet all the criteria if it was mounted to a 20 foot rigid line hanging off the plane. My experience with Garmin is they are extremely sensitive units. This is great for operation but tough for installation. The GTS800 is no different. The first location priority is to mount the top GA58 antenna on the highest and most forward location on the aircraft with no antennas in front of it. It has to be mounted level and in the middle. OK so far so good. Next it needs an 18 x 18 ground plane. WHOA. We have roughly a 10 x 30 spot on the top between the doors hinges. I have the sweet Aerosport overhead console installed and it has the 10 x 30 dimensions inside. I came to the conclusion I could use a copper wire mesh inside the overhead console with a backing plate. The ground plane should see through the honeycomb and fiberglass. I could get the square inches needed but not the 18 x 18 width. I also mounted a bottom monopole antenna for the TAS so there will not be any shadowing from the fuselage. This is a simple transponder blade mounted right below the GA58. BTW the top requires 4 coax and the bottom requires 1. I then powered up the plane, configured the GTS800 to talk to the 430w and 330es. Check the self test on the TAS and "FAILED" shows up. The configuration program is a downloadable exe. for windows that hooks to the GTS800 via USB connection. You can configure all the settings and diagnose problems. There is also an assert file you can save as a txt file and email to Garmin for troubleshooting. Mine returned with a "receive cal" fault, which translates to coax or/and antenna ground plane. I was pretty confident with my coax crimping abilities and really believed it was the ground plane size. After a few attempts of backing plates and wire mesh combinations I finally tried placing a 20 x 20 scrap sheet of .016 to the top of the cabin. Obviously this is overhanging the doors and is only for testing purposes. The self test passed with the giant ground plane on TOP of the cabin. After trying different sizes on the top and the bottom it was very apparent that I HAD to have a ground plane on the top of the cabin under the GA58. I don't know how Cirrus does it but their new planes show the GA58 on the top between the doors. Their span is even narrower than the RV-10. They must use a mesh inside the glass or carbon fiber. Just a 10x 18 span of aluminum tape on the top of my cabin worked great. BTW I also tried grounding the ground plane to the airframe and that had no affect on passing or failing the self test. I also wrapped aluminum tape from the inside ground plane/backing plate through the coax hole and made a footprint of the antenna out of the aluminum tape. I left this on. I called Garmin and they said to move the antenna to the tailcone area. This wasn't an option for me. #1 it's not level, #2 my two gps antennas are already there, #3 too close to my GMU44, #4 too far back on the plane, #5 not inline with the bottom antenna anymore. After knowing I had to make a ground plane on the top of the cabin, I slowly cut it down in size to see how small I could make it while still passing the self test. I eventually ended up with a 6 x 18 piece of .025 aluminum. I wanted thicker than .016 so it wouldn't de-laminate from the cabin. Before I attached it I ran the self test. It passed. I then wanted to epoxy it to the cabin top and glass over it with a few sheets of fiberglass. I drilled the rivet holes for cs4-4's and ran the test.....FAILED. WTH??? I thought it was a mistake and ran it again....FAILED. I couldn't believe it was the rivet holes so I temporarily taped over them with the aluminum tape......PASSED! Just the open holes caused the antenna to fail consistently. I thought the rivets in the holes would cure it and they did. I now have a glassed over ground plane 6 x 18 on the top of the cabin and it has worked flawlessly for 12 hours now. I still don't know why the ground plane doesn't work inside the cabin. It must be a distance from the antenna deal but I tried everything inside. This is also a good example why I didn't paint my plane before my first flight:) Attached is a photo of two layers of glass. I put down one more and feathered it in. -------- Cust. #40936 RV-10 SB Fuselage N801VR reserved Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336856#336856 Attachments: http://forums.matronics.com//files/photo_822.jpg ________________________________________________________________________________
Subject: New Bose
Date: Apr 13, 2011
For those flying with the new Bose who have used the old ones, how much better are the new ones? David Leikam RV10 Flying ________________________________________________________________________________
Subject: Re: New Bose
Date: Apr 14, 2011
Dave, if you've flown with the old and find them completely comfortable and quiet, the A20's will just be a step up in both but I can't say it's a huge step up or anything. It's a noticeable difference in quiet, but truthfully the old X's were plenty quiet. You should really just fly with both or at least the one you want to buy first, because fit and comfort is of utmost importance. The biggest difference for me personally is that the A20 ear cups are a bit larger, so my ears flop in comfortably easier. If you use the X's and find no fit issue at all, then you probably would like either. If you plan to get 4, you could do a mix for front and back seats and you're unlikely to have people complain. You're basically asking "hey, you porsche and Ferrari owners out there...how much better is a top of the line Ferrari over a top of the line Porsche?". Either one will make most drivers happy. I like them both....but I like the A20's just a little more. One other positive is that it's much easier and cheaper to adapt a Lemo plug a20 to standard jacks with an adapter....so if that interests you, I'd go A20. The biggest downside is that my X's I could leave powered on all the time and they'd stay on. The A20's I have to hit the power button to turn on every flight. The only other major/minor difference is if you plan to use the Bluetooth or music input.....but most people will do that on their audio panel (the music at least) anyway. I'm halfway through my latest trip write up and I mentioned the a20's since this was the first long trip with them. You'll see that in a couple days when I can finish typing. Tim On Apr 13, 2011, at 11:10 PM, David Leikam wrote: > > For those flying with the new Bose who have used the old ones, how much better are the new ones? > > David Leikam > RV10 > Flying > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: TCAS ground plane
Date: Apr 14, 2011
Nice write up... You are brave to cut into the cabin top. Isn't that a structural change? I googled GTS800... "Feature-rich yet affordably priced, the Garmin GTS 800 system is designed to bring full TAS traffic surveillance capability well within reach of most GA..." Almost $9000 for a GTS800. Really? Are there other alternatives out there? I'm assuming that this is the sort of box the FAA will eventually require all of us to swallow. Thanks, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336917#336917 ________________________________________________________________________________
Date: Apr 14, 2011
I just made a hole for the coax and mounting screws. If anything all the new glass I put down on it made it stronger. with NextGen the GTS800 won't be required but ads-b capability might be. I think it is around 2020??? There are cheaper options I'm sure like the Navworx stuff. Since I wanted real active interrogated TAS I went with the GTS800. The ads-b portion was just a bonus and since it received ads-b I thought I would get the GTX330(es) to send the ads-b out and get the entire loop. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336919#336919 ________________________________________________________________________________
Date: Apr 14, 2011
I bought the A20's for my plane. I used them with Scott and compared them to his x's in his plane. We both could tell quite a difference. Scott has A20's now. I believe the ANR portion gets "broke in" and over a 5-7 years they start fading. Maybe Scott's X's were just as good or close when they were new. On the citation I replaced our old telex ANR 850's for new ones because the material was coming apart. I couldn't believe how different the new 850's sound and how loud they were. I had to turn the intercoms and radios way down from the previous settings. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=336920#336920 ________________________________________________________________________________
Date: Apr 14, 2011
Thx Tim. I'll wait till OSH. I know comfort is the most important. And I did try some on at Sun N' Fun and they felt good, but you never know for sure until you fly with them for an hour or more. David Leikam RV10 Flying On Apr 14, 2011, at 12:46 AM, Tim Olson wrote: > > Dave, if you've flown with the old and find them completely comfortable and quiet, the A20's will just be a step up in both but I can't say it's a huge step up or anything. It's a noticeable difference in quiet, but truthfully the old X's were plenty quiet. You should really just fly with both or at least the one you want to buy first, because fit and comfort is of utmost importance. The biggest difference for me personally is that the A20 ear cups are a bit larger, so my ears flop in comfortably easier. If you use the X's and find no fit issue at all, then you probably would like either. If you plan to get 4, you could do a mix for front and back seats and you're unlikely to have people complain. > You're basically asking "hey, you porsche and Ferrari owners out there...how much better is a top of the line Ferrari over a top of the line Porsche?". Either one will make most drivers happy. > I like them both....but I like the A20's just a little more. > One other positive is that it's much easier and cheaper to adapt a Lemo plug a20 to standard jacks with an adapter....so if that interests you, I'd go A20. The biggest downside is that my X's I could leave powered on all the time and they'd stay on. The A20's I have to hit the power button to turn on every flight. > > The only other major/minor difference is if you plan to use the Bluetooth or music input.....but most people will do that on their audio panel (the music at least) anyway. > > I'm halfway through my latest trip write up and I mentioned the a20's since this was the first long trip with them. You'll see that in a couple days when I can finish typing. > > Tim > > > > On Apr 13, 2011, at 11:10 PM, David Leikam wrote: > >> >> For those flying with the new Bose who have used the old ones, how much better are the new ones? >> >> David Leikam >> RV10 >> Flying >> >> >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 14, 2011
Subject: Re: Baja Trip Write-Up
Instead you will be burning holes in the sky and spending your money at the pump. All with grins ear to ear. :-) Larry Having fun with fiberglass and resin On 4/14/2011 9:31 PM, Tim Olson wrote: > > I finally got to sit down and finish the Baja Trip write-up. > I included some other stuff that some people may find interesting > and others might not. Before the trip I got a new Camera lens > that worked out great for traveling. It was also the first > big trip with WingX's latest update, and Foreflight Pro HD, > and all sorts of new things that I've gathered over the winter > months. For a while there I was feeling pretty broke. Good thing > it's spring and I won't be as close to my keyboard where I can > do online shopping. ;) > > http://www.myrv10.com/N104CD/Trips/2011_Baja/index.html > ________________________________________________________________________________
Date: Apr 14, 2011
Do you get FIS-B (ads-b wx) on anything too, or are you getting XM only? Tim On Apr 14, 2011, at 3:46 PM, "Strasnuts" wrote: > > I just made a hole for the coax and mounting screws. If anything all the new glass I put down on it made it stronger. > with NextGen the GTS800 won't be required but ads-b capability might be. I think it is around 2020??? There are cheaper options I'm sure like the Navworx stuff. Since I wanted real active interrogated TAS I went with the GTS800. The ads-b portion was just a bonus and since it received ads-b I thought I would get the GTX330(es) to send the ads-b out and get the entire loop. > > -------- > 40936 > RV-10 SB N801VR Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336919#336919 > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2011
XM only. It sounds like the GTS800 won't bring in wx. Just traffic. I haven't read anything on FIS-b in the GTS manuals. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337004#337004 ________________________________________________________________________________
Subject: another RV10
Date: Apr 15, 2011
I watched a first flight this evening; I will allow the proud papa the pleasure of announcing the reasons for his RV grin. ________________________________________________________________________________
Date: Apr 16, 2011
Wow. I just finished the write-up while waiting for some paint to dry on the project. Great report! Got a little of everything in that trip. Jae Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337154#337154 ________________________________________________________________________________
Subject: Baja Trip Write-Up
Date: Apr 16, 2011
For those planning on trips south, http://www.bajabushpilots.com/ Baja Bush Pilots can be a great resource. You can get comments from pilots who have just completed trips to the airport you might be considering landing at. Expected fees, problems, whether they accept dollars, fuel prices, and reports on the airport or accommodations. Might be worth your while even for 1 trip a year. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Subject: FS: Sikaflex 295UV system for bonding RV-10 windows
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Apr 17, 2011
Date: Apr 17, 2011
Subject: Thunder over Louisville - Cold and windy but still good!
Well at least two RV-10 owners made it to "Thunder over Louisville Air Show and Fireworks". Darned weather was the pits but still got to see some great flying and fireworks. F-22, C-17 and the Sea Stallion helo are amazing! The flight tribute with the P-51, F4 Phantom and the F-22 were sweet too. Heck it's all good! Always good to meet other RV-10 people! Jim Combs N312F - 220 Hours - Still unpainted - Soon! ________________________________________________________________________________
Subject: Re: FS: Sikaflex 295UV system for bonding RV-10 windows
Date: Apr 17, 2011
Don't know what your question was, but if you are thinking about using the Sikaflex system for bonding the windows, you can go to my web page link of how I replaced a windshield using this system. I can highly recommend it for windshield replacement http://www.nwacaptain.com/windshield.html It is very easy to clean up by using mineral spirits. Plenty of time to place and adjust the windshield position. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337240#337240 ________________________________________________________________________________
Date: Apr 17, 2011
I used this system to install my windows on my RV-10. New from Jamestown Dis trubters costs over $113 plus shipping. I have one new unopened tube of the 2 95 UV adhesive, and well over 1/2 can of the 209D primer and Aktivator. Prim er expires in August 2011, Aktivator in September 2011. This is enough to bo nd in a full set of RV-10 windows. $75 plus free shipping via FedEx Ground. -Mike Kraus Sent from my iPhone Sent from my iPhone ________________________________________________________________________________
Date: Apr 17, 2011
Wasn't there some concern whether Sikaflex provided as strong a bond as Weld-on? On Sun, Apr 17, 2011 at 12:50 PM, greghale wrote: > > Don't know what your question was, but if you are thinking about using the Sikaflex system for bonding the windows, you can go to my web page link of how I replaced a windshield using this system. I can highly recommend it for windshield replacement > > http://www.nwacaptain.com/windshield.html > > It is very easy to clean up by using mineral spirits. Plenty of time to place and adjust the windshield position. > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=337240#337240 > > ________________________________________________________________________________
Date: Apr 17, 2011
Subject: "Worn Out" CT-Q67 Cable Assembly (Warning!)
Dear Listers, At 170 hours on my RV-8 now, the Prop control had become increasing more difficult to move starting around 100 hours. The Mixture and Throttle have worked fine and continue to. All three controls use the standard "Green" control cables from Vans, typically a "CT-Qxx" part. A couple of weeks ago, I disassembled the Governor end of the assembly and made sure that there was no binding or issues on that end. I even lightly lubed up the various moving bits. Yesterday, the Prop control became so difficult to move that I had trouble cycling the prop during run up. I pulled the whole throttle quadrant installation apart today to have a look. I got the cable completely out of the airplane and there are NO outward signs of wear or abuse of *any kind*. But even with the cable completely out of the plane and nothing connected to either end, it is almost impossible to move the cable!! I have a new CT-Q67 cable assembly for my front-mounted governor installation and I'm going to install that next. But, I wanted to give everyone a heads up on these CT-Q controls. These things are built like they go on a Caterpillar Tractor, so I can't figure out why they would wear out like this. If one of these controls starts getting stiff and tight, its probably not going to get any better. Replace it before it becomes a safety issue! Not a big deal on the Prop control, but on a throttle or mixture it could be a serious concern. Best regards, Matt - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours Total Time Since May 2 2010 Test Flight! ________________________________________________________________________________
Date: Apr 17, 2011
Many of these control cables have a plastic liner. If they are routed near a heat source they tend to melt internally and become difficult to move. That might be your issue, it was for me. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Sunday, April 17, 2011 5:24 PM Subject: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) Dear Listers, At 170 hours on my RV-8 now, the Prop control had become increasing more difficult to move starting around 100 hours. The Mixture and Throttle have worked fine and continue to. All three controls use the standard "Green" control cables from Vans, typically a "CT-Qxx" part. A couple of weeks ago, I disassembled the Governor end of the assembly and made sure that there was no binding or issues on that end. I even lightly lubed up the various moving bits. Yesterday, the Prop control became so difficult to move that I had trouble cycling the prop during run up. I pulled the whole throttle quadrant installation apart today to have a look. I got the cable completely out of the airplane and there are NO outward signs of wear or abuse of *any kind*. But even with the cable completely out of the plane and nothing connected to either end, it is almost impossible to move the cable!! I have a new CT-Q67 cable assembly for my front-mounted governor installation and I'm going to install that next. But, I wanted to give everyone a heads up on these CT-Q controls. These things are built like they go on a Caterpillar Tractor, so I can't figure out why they would wear out like this. If one of these controls starts getting stiff and tight, its probably not going to get any better. Replace it before it becomes a safety issue! Not a big deal on the Prop control, but on a throttle or mixture it could be a serious concern. Best regards, Matt - Matt Dralle RV-8 #82880 N998RV http://www.mattsrv8.com - Matt's RV-8 Construction Blog http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours Total Time Since May 2 2010 Test Flight! ________________________________________________________________________________
Subject: Re: Thunder over Louisville - Cold and windy but still good!
Date: Apr 17, 2011
Glad you enjoyed the show. I am looking forward to joining you guys this fall. Finished cabin cover finally! Pin hole/filler epoxy coat curing now. Working on some panel/wiring before installing on gear. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 45 Doors/Transparencies- 1228 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337282#337282 ________________________________________________________________________________
Subject: Re: "Worn Out" CT-Q67 Cable Assembly (Warning!)
Date: Apr 17, 2011
Contact John in purchasing at Vans; I had the same problem (at 400 TT) with quadrant prop and mixture; He acknowledged that these are made from Cablecraft Tuthill parts by an Oregon company and should last to TBO. It was a PITA changing these with the engine on the airframe. ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Sunday, April 17, 2011 3:23 PM Subject: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) > > Dear Listers, > > At 170 hours on my RV-8 now, the Prop control had become increasing more > difficult to move starting around 100 hours. The Mixture and Throttle > have worked fine and continue to. All three controls use the standard > "Green" control cables from Vans, typically a "CT-Qxx" part. > > A couple of weeks ago, I disassembled the Governor end of the assembly and > made sure that there was no binding or issues on that end. I even lightly > lubed up the various moving bits. Yesterday, the Prop control became so > difficult to move that I had trouble cycling the prop during run up. I > pulled the whole throttle quadrant installation apart today to have a > look. I got the cable completely out of the airplane and there are NO > outward signs of wear or abuse of *any kind*. But even with the cable > completely out of the plane and nothing connected to either end, it is > almost impossible to move the cable!! I have a new CT-Q67 cable assembly > for my front-mounted governor installation and I'm going to install that > next. > > But, I wanted to give everyone a heads up on these CT-Q controls. These > things are built like they go on a Caterpillar Tractor, so I can't figure > out why they would wear out like this. > > If one of these controls starts getting stiff and tight, its probably not > going to get any better. Replace it before it becomes a safety issue! > Not a big deal on the Prop control, but on a throttle or mixture it could > be a serious concern. > > Best regards, > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours Total Time Since May 2 2010 Test Flight! > > > ________________________________________________________________________________
Date: Apr 17, 2011
Routing of my cables was per Vans specifications and they were protected by additional external heat sleeves ----- Original Message ----- From: "gary" <speckter(at)comcast.net> Sent: Sunday, April 17, 2011 4:47 PM Subject: RE: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) > > Many of these control cables have a plastic liner. If they are routed > near > a heat source they tend to melt internally and become difficult to move. > That might be your issue, it was for me. > > Gary Specketer > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Sunday, April 17, 2011 5:24 PM > To: rv9-list(at)matronics.com; rv10-list(at)matronics.com; > rv12-list(at)matronics.com > Subject: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) > > > Dear Listers, > > At 170 hours on my RV-8 now, the Prop control had become increasing more > difficult to move starting around 100 hours. The Mixture and Throttle > have > worked fine and continue to. All three controls use the standard "Green" > control cables from Vans, typically a "CT-Qxx" part. > > A couple of weeks ago, I disassembled the Governor end of the assembly and > made sure that there was no binding or issues on that end. I even lightly > lubed up the various moving bits. Yesterday, the Prop control became so > difficult to move that I had trouble cycling the prop during run up. I > pulled the whole throttle quadrant installation apart today to have a > look. > I got the cable completely out of the airplane and there are NO outward > signs of wear or abuse of *any kind*. But even with the cable completely > out of the plane and nothing connected to either end, it is almost > impossible to move the cable!! I have a new CT-Q67 cable assembly for my > front-mounted governor installation and I'm going to install that next. > > But, I wanted to give everyone a heads up on these CT-Q controls. These > things are built like they go on a Caterpillar Tractor, so I can't figure > out why they would wear out like this. > > If one of these controls starts getting stiff and tight, its probably not > going to get any better. Replace it before it becomes a safety issue! > Not > a big deal on the Prop control, but on a throttle or mixture it could be a > serious concern. > > Best regards, > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours Total Time Since May 2 2010 Test Flight! > > > ________________________________________________________________________________
Date: Apr 17, 2011
I also have a partial tube of Weld-On 45 and some mixing tubes an RV-10 builder can have for shipping along with borrowing the gun. I want the $102 gun back when finished. Bond strength is 2000 vs 2200 psi for Weld On 10 and the viscosity makes it much easier to fill gaps and almost no runs/clean up afterwards. I don't believe the 200 psi difference will cause me any problems. I tested plexiglass/aluminum/fiberglass samples and it holds better than West epoxy on all three. You need two 13.5 oz cartridges(approx $35/ea) and you will have a least 1/2 tube leftover. Costs are just slightly more than Weld On 10 since you don't have to buy the gun. Get your cartridges/mixing tubes from The Engineer Guy in Atlanta. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 45 Doors/Transparencies- 1228 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337287#337287 ________________________________________________________________________________
Date: Apr 18, 2011
Subject: Door Pin Lube?
Good Monday morning.... The J.O.B. is slowing down a bit and that's giving me a chance to get started on the airplane again. :) Last night I was installing the door pins in one of the doors and while I can operate them with one hand I still feel like they're tight. I put a slight bend in the rear pin but that didn't seem to help too much. The only thing I can figure is that it's simply drag between the pins and the delrin blocks. Is there a lube that others have used to free up the friction? I'm using Sean's kit if that matters. Thanks, Phil "Finally back to building!" Perry ________________________________________________________________________________
Date: Apr 18, 2011
Subject: Re: Door Pin Lube?
I put a few drops of Triflow on mine, but Boelube is probably just as good. Mainly want something that is a dry paraffin or silicone type lube, that won't attract dirt. On Mon, Apr 18, 2011 at 8:24 AM, Phillip Perry wrote: > Good Monday morning.... > > The J.O.B. is slowing down a bit and that's giving me a chance to get > started on the airplane again. :) > > Last night I was installing the door pins in one of the doors and while I > can operate them with one hand I still feel like they're tight. I put a > slight bend in the rear pin but that didn't seem to help too much. The only > thing I can figure is that it's simply drag between the pins and the delrin > blocks. > > Is there a lube that others have used to free up the friction? > > I'm using Sean's kit if that matters. > > Thanks, > Phil "Finally back to building!" Perry > > ________________________________________________________________________________
Date: Apr 18, 2011
Do yourself a huge favor. Toss the delrin and get the aluminum. You=99ll find the door will close easier and it will be much more secure than the Delrin blocks. From: Phillip Perry Sent: Monday, April 18, 2011 8:24 AM Subject: RV10-List: Door Pin Lube? Good Monday morning.... The J.O.B. is slowing down a bit and that's giving me a chance to get started on the airplane again. :) Last night I was installing the door pins in one of the doors and while I can operate them with one hand I still feel like they're tight. I put a slight bend in the rear pin but that didn't seem to help too much. The only thing I can figure is that it's simply drag between the pins and the delrin blocks. Is there a lube that others have used to free up the friction? I'm using Sean's kit if that matters. Thanks, Phil "Finally back to building!" Perry ________________________________________________________________________________
Date: Apr 18, 2011
Delrin is NOT the problem. UHMW that Vans supplies is the problem. Specifically the pin guides on the door itself. Delrin is an excellent self lubing material, much more resistant to wear, harder material than the UHMW. Does someone offer pin guides for the door in other than Van's UHMW? The stuff that Sean and Steve(iflyrv10) are the door frame side guides. On Mon, Apr 18, 2011 at 8:42 AM, Pascal wrote: > Do yourself a huge favor. Toss the delrin and get the aluminum. Youll find > the door will close easier and it will be much more secure than the Delrin > blocks. > > From: Phillip Perry > Sent: Monday, April 18, 2011 8:24 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Door Pin Lube? > > Good Monday morning.... > > The J.O.B. is slowing down a bit and that's giving me a chance to get > started on the airplane again. :) > > Last night I was installing the door pins in one of the doors and while I > can operate them with one hand I still feel like they're tight. I put a > slight bend in the rear pin but that didn't seem to help too much. The only > thing I can figure is that it's simply drag between the pins and the delrin > blocks. > > Is there a lube that others have used to free up the friction? > > I'm using Sean's kit if that matters. > > Thanks, > Phil "Finally back to building!" Perry > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ________________________________________________________________________________
Date: Apr 18, 2011
My door pin guides (180) kit and my fuselage guides come in Delrin. Sent from my iPhone On Apr 18, 2011, at 10:00, Kelly McMullen wrote: > > Delrin is NOT the problem. UHMW that Vans supplies is the problem. > Specifically the pin guides on the door itself. Delrin is an > excellent self lubing material, much more resistant to wear, harder > material than the UHMW. Does someone offer pin guides for the door in > other than Van's UHMW? The stuff that Sean and Steve(iflyrv10) are the > door frame side guides. > > On Mon, Apr 18, 2011 at 8:42 AM, Pascal wrote: >> Do yourself a huge favor. Toss the delrin and get the aluminum. Youll find >> the door will close easier and it will be much more secure than the Delrin >> blocks. >> >> From: Phillip Perry >> Sent: Monday, April 18, 2011 8:24 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Door Pin Lube? >> >> Good Monday morning.... >> >> The J.O.B. is slowing down a bit and that's giving me a chance to get >> started on the airplane again. :) >> >> Last night I was installing the door pins in one of the doors and while I >> can operate them with one hand I still feel like they're tight. I put a >> slight bend in the rear pin but that didn't seem to help too much. The only >> thing I can figure is that it's simply drag between the pins and the delrin >> blocks. >> >> Is there a lube that others have used to free up the friction? >> >> I'm using Sean's kit if that matters. >> >> Thanks, >> Phil "Finally back to building!" Perry >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 18, 2011
Phil. It is probably not the Delrin. Does your handle turn easy if the door is ope n? Do you think it is the alignment on the fuselage guides or the door guid es? If it is on the fuselage try paralleling the pushrod movement into the f uselage guide with a 7/16 reamer. Feel free to call me. I have done a bunch o f these. 8015803737 Sent from my iPhone On Apr 18, 2011, at 9:24, Phillip Perry wrote: > Good Monday morning.... > > The J.O.B. is slowing down a bit and that's giving me a chance to get star ted on the airplane again. :) > > Last night I was installing the door pins in one of the doors and while I c an operate them with one hand I still feel like they're tight. I put a slig ht bend in the rear pin but that didn't seem to help too much. The only thi ng I can figure is that it's simply drag between the pins and the delrin blo cks. > > Is there a lube that others have used to free up the friction? > > I'm using Sean's kit if that matters. > > Thanks, > Phil "Finally back to building!" Perry > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 18, 2011
Does someone offer pin guides for the door in other than Van's UHMW? Yeah - Sean's kit is delrin. It's much nicer, smoother, and harder than the UHMW that shipped with Vans. Phil ________________________________________________________________________________
Date: Apr 18, 2011
Instrument Sales and Service on Airport Way, Portland, OR. They manufacture for the OEM and will make any length, got a set once in 20 minutes during a lunch 1/2 hour. The initial lengths can sometimes be problematically too short or slightly too long. Just right is a good thing. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Sunday, April 17, 2011 5:37 PM Subject: Re: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) Contact John in purchasing at Vans; I had the same problem (at 400 TT) with quadrant prop and mixture; He acknowledged that these are made from Cablecraft Tuthill parts by an Oregon company and should last to TBO. It was a PITA changing these with the engine on the airframe. ----- Original Message ----- From: "Matt Dralle" <dralle(at)matronics.com> Sent: Sunday, April 17, 2011 3:23 PM Subject: RV10-List: "Worn Out" CT-Q67 Cable Assembly (Warning!) > > Dear Listers, > > At 170 hours on my RV-8 now, the Prop control had become increasing more > difficult to move starting around 100 hours. The Mixture and Throttle > have worked fine and continue to. All three controls use the standard > "Green" control cables from Vans, typically a "CT-Qxx" part. > > A couple of weeks ago, I disassembled the Governor end of the assembly and > made sure that there was no binding or issues on that end. I even lightly > lubed up the various moving bits. Yesterday, the Prop control became so > difficult to move that I had trouble cycling the prop during run up. I > pulled the whole throttle quadrant installation apart today to have a > look. I got the cable completely out of the airplane and there are NO > outward signs of wear or abuse of *any kind*. But even with the cable > completely out of the plane and nothing connected to either end, it is > almost impossible to move the cable!! I have a new CT-Q67 cable assembly > for my front-mounted governor installation and I'm going to install that > next. > > But, I wanted to give everyone a heads up on these CT-Q controls. These > things are built like they go on a Caterpillar Tractor, so I can't figure > out why they would wear out like this. > > If one of these controls starts getting stiff and tight, its probably not > going to get any better. Replace it before it becomes a safety issue! > Not a big deal on the Prop control, but on a throttle or mixture it could > be a serious concern. > > Best regards, > > Matt > > - > Matt Dralle > RV-8 #82880 N998RV > http://www.mattsrv8.com - Matt's RV-8 Construction Blog > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours Total Time Since May 2 2010 Test Flight! > > > ________________________________________________________________________________
Date: Apr 18, 2011
Sean, It's still simply sitting on the bench. I haven't bolted it to the airframe and drilled those holes yet. Phil On Mon, Apr 18, 2011 at 11:14 AM, Seano wrote: > Phil. > > It is probably not the Delrin. Does your handle turn easy if the door is > open? Do you think it is the alignment on the fuselage guides or the door > guides? If it is on the fuselage try paralleling the pushrod movement into > the fuselage guide with a 7/16 reamer. Feel free to call me. I have done a > bunch of these. > 8015803737 > > Sent from my iPhone > > ________________________________________________________________________________
Date: Apr 18, 2011
I dont have my computer with me so I can't tell you you bought the 90 or the 180 kit. If you want the delrin sleeves for the door guides Let me know. Th ey come with the 180 kits. The whole mechanism should have little drag even after everything is installed with the seal in place. Sean Sent from my iPhone On Apr 18, 2011, at 10:26, Phillip Perry wrote: > Sean, > > It's still simply sitting on the bench. I haven't bolted it to the airfra me and drilled those holes yet. > > Phil > > > > On Mon, Apr 18, 2011 at 11:14 AM, Seano wrote: > Phil. > > It is probably not the Delrin. Does your handle turn easy if the door is o pen? Do you think it is the alignment on the fuselage guides or the door gu ides? If it is on the fuselage try paralleling the pushrod movement into th e fuselage guide with a 7/16 reamer. Feel free to call me. I have done a bun ch of these. > 8015803737 > > Sent from my iPhone > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 18, 2011
I'm a 180 kind of guy. I think it's simply friction because they are pretty firm to push on. Phil On Apr 18, 2011 11:53 AM, "Seano" wrote: > I dont have my computer with me so I can't tell you you bought the 90 or the 180 kit. If you want the delrin sleeves for the door guides Let me know. They come with the 180 kits. The whole mechanism should have little drag even after everything is installed with the seal in place. > > > Sean > > > Sent from my iPhone > > On Apr 18, 2011, at 10:26, Phillip Perry wrote: > >> Sean, >> >> It's still simply sitting on the bench. I haven't bolted it to the airframe and drilled those holes yet. >> >> Phil >> >> >> >> On Mon, Apr 18, 2011 at 11:14 AM, Seano wrote: >> Phil. >> >> It is probably not the Delrin. Does your handle turn easy if the door is open? Do you think it is the alignment on the fuselage guides or the door guides? If it is on the fuselage try paralleling the pushrod movement into the fuselage guide with a 7/16 reamer. Feel free to call me. I have done a bunch of these. >> 8015803737 >> >> Sent from my iPhone >> >> >> > =================================== > =================================== > =================================== > =================================== >> ________________________________________________________________________________
Date: Apr 18, 2011
Do not!!!!!!! Get silicone any where near your unpainted aircraft. It causes fish eyes when you go to paint, and it migrates everywhere. Gary Specketer -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, April 18, 2011 10:37 AM Subject: Re: RV10-List: Door Pin Lube? I put a few drops of Triflow on mine, but Boelube is probably just as good. Mainly want something that is a dry paraffin or silicone type lube, that won't attract dirt. On Mon, Apr 18, 2011 at 8:24 AM, Phillip Perry wrote: > Good Monday morning.... > > The J.O.B. is slowing down a bit and that's giving me a chance to get > started on the airplane again. :) > > Last night I was installing the door pins in one of the doors and while I > can operate them with one hand I still feel like they're tight. I put a > slight bend in the rear pin but that didn't seem to help too much. The only > thing I can figure is that it's simply drag between the pins and the delrin > blocks. > > Is there a lube that others have used to free up the friction? > > I'm using Sean's kit if that matters. > > Thanks, > Phil "Finally back to building!" Perry > > ________________________________________________________________________________
Date: Apr 18, 2011
I opened the holes on Sean's kit and on Van's uhmw/bulkheads until friction was where I liked it. If you don't take care of the increased drag of the doors now it will really increase once on the plane. I also took a chunk of boelube and rubbed it across all gear teeth then used a propane torch to melt it in slightly before final latch assembly(no fiberglass nearby during this procedure). Smooth as can be now. If you look back in the holes in the airframe once your doors are on and latches actuated, you will notice areas that are darker than others. Those are the areas to take down some. I sanded with 180 then vacuumed holes out. I put a small amount of vaseline on mine. Hey, whatever works to decrease the friction right? My doors sitting static are 1/4" away from cabin surface and I can close with thumb on the button release and one finger on the handle. Thanks again Sean for my extra safety latch that does not stick out of the door exterior and require another hand to operate. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337438#337438 ________________________________________________________________________________
Subject: door pins
Date: Apr 19, 2011
While rigging the pins, I had no real friction when the bolts that hold the aluminum guides to the fuselage were loose. When they were tight however, the friction was there. The fix was to put some epoxy/cabosil between the blocks and fuselage, install the bolts , but do not tighten, close the door with the pins engaged (with mold release on them) and let harden. The results were that the blocks are now aligned with the pins and the pins engage with no friction. Chris Hukill ________________________________________________________________________________
Date: Apr 20, 2011
Ron, I have been caught up in travel. Sorry for the delay after our phone conversation. I will take one 2009 model. Will pay however you are comfortable. Call or email. 772-418-1417. Rob Kermanj Sent from my iPhone On Apr 11, 2011, at 3:57 PM, "Ron B." wrote: > > I tried to send you the serial # but the e-mail address flysrv10(at)gmail.com was returned undeliverable . I used @ instead of (at) . > Ron > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=336653#336653 > > > > > > > > > > ________________________________________________________________________________
Subject: ICE PILOTS
Date: Apr 20, 2011
Hey everyone, If you didn't see it in the paper, the tv show ICE PILOTS starts Friday on the National Geographic channel. I saw this in Calgary last year and was really fascinated with the show. They are in production of season 2, but we the USA will get season 1 this year. Greg... -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337641#337641 ________________________________________________________________________________
Subject: ICE PILOTS
Date: Apr 20, 2011
That's great! I was able to see about six bootlegged episodes before they w ere removed from the net. Great show if you like round engines. > Subject: RV10-List: ICE PILOTS > From: ghale5224(at)aol.com > Date: Wed=2C 20 Apr 2011 16:48:30 -0700 > To: rv10-list(at)matronics.com > > > Hey everyone=2C > > If you didn't see it in the paper=2C the tv show ICE PILOTS starts Friday on the National Geographic channel. I saw this in Calgary last year and w as really fascinated with the show. They are in production of season 2=2C but we the USA will get season 1 this year. > > Greg... > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=337641#337641 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 21, 2011
Rob I noticed I had my old e-mail listed on here. I've updated it on here, so give it a try. Ron P.S. I contacted my friend (airplane partner) Allister, and he's looking for payment options. He's doing the deal! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337723#337723 ________________________________________________________________________________
Subject: Control surface balancing
Date: Apr 21, 2011
Hey guys, This comes under the category of things I still need to learn. I was listening to a discussion at the hangar the other day about what a huge "no-no" it was when a certified plane got sent off for a paint job and came back with paint on the connections of the control surfaces. The conclusion was that the control surfaces had not been removed after painting to be rebalanced ... big stink with FAA involvement. I think I vaguely remember someone mentioning here about balancing control surfaces, but I've never run across any instructions in the RV-10 build process about what the specs might be and how to balance. Not knowing anything different, I just painted everything in pieces on Wes's plane before final assembly, put it together, and no problems, he says it flies beautifully. Now I'm concerned. Any info out there? Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337758#337758 ________________________________________________________________________________
Subject: APRS Antenna
Date: Apr 21, 2011
For those of you using APRS: What antenna are you using and where did you mount it. Rene' N423CF 801-721-6080 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Apr 21, 2011
I had the same issue. Building my 8A I carefully trimmed the elevator weights to get exact balance, then found I needed to add some additional lead after paint to rebalance the elevators (the vast majority of the paint is aft of the hinge line). Building the 10 I noted the elevators are way trailing edge heavy using the weights in the kit. I sent a note to Van's about this and the reply was along the line of 'that is correct, that is how it is supposed to be'. Bottom line, the elevators are nowhere near balance, paint or no paint. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Thursday, April 21, 2011 9:50 PM Subject: RV10-List: Control surface balancing Hey guys, This comes under the category of things I still need to learn. I was listening to a discussion at the hangar the other day about what a huge "no-no" it was when a certified plane got sent off for a paint job and came back with paint on the connections of the control surfaces. The conclusion was that the control surfaces had not been removed after painting to be rebalanced ... big stink with FAA involvement. I think I vaguely remember someone mentioning here about balancing control surfaces, but I've never run across any instructions in the RV-10 build process about what the specs might be and how to balance. Not knowing anything different, I just painted everything in pieces on Wes's plane before final assembly, put it together, and no problems, he says it flies beautifully. Now I'm concerned. Any info out there? Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337758#337758 ________________________________________________________________________________
Date: Apr 21, 2011
>From VANS, Scott R: Chris, Balance limits are a 'maximum' so if your measurements fall anywhere between zero and the limit, you're good. We've done extensive GVT (ground vibration testing) and flight testing on the RV-10. The intent is to be able to trim the weights according to the plans (if called out), bolt them in and be well within the limits. We put the balance limits in the flight test section because some builders alter the control surfaces during construction...additional or different trim mechanisms, skin thicknesses etc. If your control surfaces are built according to the plans and your paint job is not 'extreme', you should easily fall within the limits. If you chose to check the balance, (excluding the rudder) you can just disconnect the specific control surface from any control linkage (weight elevators separately), get it in the level flight attitude and put a scale under the trailing edge. The rudder would have to be removed, of course to do this. scott at van's -Chris #40072 (out of paint) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher Sent: Thursday, April 21, 2011 9:50 PM Subject: RV10-List: Control surface balancing Hey guys, This comes under the category of things I still need to learn. I was listening to a discussion at the hangar the other day about what a huge "no-no" it was when a certified plane got sent off for a paint job and came back with paint on the connections of the control surfaces. The conclusion was that the control surfaces had not been removed after painting to be rebalanced ... big stink with FAA involvement. I think I vaguely remember someone mentioning here about balancing control surfaces, but I've never run across any instructions in the RV-10 build process about what the specs might be and how to balance. Not knowing anything different, I just painted everything in pieces on Wes's plane before final assembly, put it together, and no problems, he says it flies beautifully. Now I'm concerned. Any info out there? Thanks, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337758#337758 ________________________________________________________________________________
Subject: Re: APRS Antenna
Date: Apr 21, 2011
a stubby inside the tail fairing. ----- Original Message ----- From: "Rene" <rene(at)felker.com> Sent: Thursday, April 21, 2011 6:52 PM Subject: RV10-List: APRS Antenna > > For those of you using APRS: What antenna are you using and where did you > mount it. > > Rene' > N423CF > 801-721-6080 > > > ________________________________________________________________________________
Date: Apr 21, 2011
Excellent=2C thank you for sharing the information! > From: toaster73(at)embarqmail.com > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Control surface balancing > Date: Thu=2C 21 Apr 2011 22:37:28 -0400 > > > >From VANS=2C Scott R: > > Chris=2C Balance limits are a 'maximum' so if your measurements fall any where > between zero and the limit=2C you're good. We've done extensive GVT (gro und > vibration testing) and flight testing on the RV-10. The intent is to be > able to trim the weights according to the plans (if called out)=2C bolt t hem > in and be well within the limits. We put the balance limits in the fligh t > test section because some builders alter the control surfaces during > construction...additional or different trim mechanisms=2C skin thicknesse s > etc. > > If your control surfaces are built according to the plans and your paint job > is not 'extreme'=2C you should easily fall within the limits. > > If you chose to check the balance=2C (excluding the rudder) you can just > disconnect the specific control surface from any control linkage (weight > elevators separately)=2C get it in the level flight attitude and put a sc ale > under the trailing edge. The rudder would have to be removed=2C of cours e to > do this. > > scott at van's > > -Chris > #40072 (out of paint) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > Sent: Thursday=2C April 21=2C 2011 9:50 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Control surface balancing > > > Hey guys=2C > > This comes under the category of things I still need to learn. I was > listening to a discussion at the hangar the other day about what a huge > "no-no" it was when a certified plane got sent off for a paint job and ca me > back with paint on the connections of the control surfaces. The conclusi on > was that the control surfaces had not been removed after painting to be > rebalanced ... big stink with FAA involvement. > > I think I vaguely remember someone mentioning here about balancing contro l > surfaces=2C but I've never run across any instructions in the RV-10 buil d > process about what the specs might be and how to balance. Not knowing > anything different=2C I just painted everything in pieces on Wes's plane > before final assembly=2C put it together=2C and no problems=2C he says it flies > beautifully. > > Now I'm concerned. Any info out there? > > Thanks=2C - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=337758#337758 > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: Control surface balancing
Date: Apr 22, 2011
Ahhh, it's in the TEST section! Thanks, I'll check it out. More reason to know -- I'm closing in on experimenting with Linn's idea of using a microcontoller and high torque model airplane servos IN the aileron and rudder for trim. That would definitely change the balance, so I will find the axis of rotation, mount a counterbalance, etc. but I need that reference first. Later, - Lew -------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549 Fly off completed ! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=337793#337793 ________________________________________________________________________________
Subject: runwayfinder
Date: Apr 22, 2011
I'm probably the last to know but it appears runwayfinder agreed to a flightprep license and is back in operation. Flightprep's actions really pisses me off. I worked for a software/web company a while back that ended up settling a patent lawsuit filed against it for $2M. The money was paid out of the proceeds from the sale of the company. The suing company did not make any money they just covered their costs. The lawyers combined from both sides netted somewhere between $3-4M in roughly a 2 year process. The patent clearly did not apply using the laws of common sense (and probably would not have held up in continuing the trial) but in the end was cheaper to settle than continue to fight it. I hope that flight-un-prep withers and dies Ben Westfall PDX ________________________________________________________________________________
Date: Apr 22, 2011
FWIW, someone at Van's told me to just bolt the counterweights on as-is and don't worry about it. The tail-heavy limits for elevator balance listed in the flight test doc seem really generous. I don't have paint yet, but even with paint, I'd be surprised if I got near the limit. -Rob On Thu, Apr 21, 2011 at 10:28 PM, John Gonzalez wrote: > Excellent, thank you for sharing the information! > > > From: toaster73(at)embarqmail.com > > > To: rv10-list(at)matronics.com > > Subject: RE: RV10-List: Control surface balancing > > Date: Thu, 21 Apr 2011 22:37:28 -0400 > > > > > > > >From VANS, Scott R: > > > > Chris, Balance limits are a 'maximum' so if your measurements fall > anywhere > > between zero and the limit, you're good. We've done extensive GVT (ground > > vibration testing) and flight testing on the RV-10. The intent is to be > > able to trim the weights according to the plans (if called out), bolt > them > > in and be well within the limits. We put the balance limits in the flight > > test section because some builders alter the control surfaces during > > construction...additional or different trim mechanisms, skin thicknesses > > etc. > > > > If your control surfaces are built according to the plans and your paint > job > > is not 'extreme', you should easily fall within the limits. > > > > If you chose to check the balance, (excluding the rudder) you can just > > disconnect the specific control surface from any control linkage (weight > > elevators separately), get it in the level flight attitude and put a > scale > > under the trailing edge. The rudder would have to be removed, of course > to > > do this. > > > > scott at van's > > > > -Chris > > #40072 (out of paint) > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lew Gallagher > > Sent: Thursday, April 21, 2011 9:50 PM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Control surface balancing > > > > > > Hey guys, > > > > This comes under the category of things I still need to learn. I was > > listening to a discussion at the hangar the other day about what a huge > > "no-no" it was when a certified plane got sent off for a paint job and > came > > back with paint on the connections of the control surfaces. The > conclusion > > was that the control surfaces had not been removed after painting to be > > rebalanced ... big stink with FAA involvement. > > > > I think I vaguely remember someone mentioning here about balancing > control > > surfaces, but I've never run across any instructions in the RV-10 build > > process about what the specs might be and how to balance. Not knowing > > anything different, I just painted everything in pieces on Wes's plane > > before final assembly, put it together, and no problems, he says it flies > > beautifully. > > > > Now I'm concerned. Any info out there? > > > > Thanks, - Lew > > > > -------- > > non-pilot > > crazy about building > > NOW OFICIALLY BUILDER #40549 > > Fly off completed ! > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=337758#337758 > > > > > > > > > > > > > > > > > > > &============ > > > > > > > > * > > * > > -- Rob Kochman RV-10 Flying, Phase 1 http://kochman.net/N819K ________________________________________________________________________________
Subject: Airguide's new Flight Guide
Date: Apr 22, 2011
I have recently received the new format flight Guide. While I like the inclusion of more material I don't like the larger size and increasing coverage of the US from 3 smaller volumes to 6 larger ones. I ordered mine in the punched binder format so that I can remove states and pages I don't need on long cross country flights. My smaller format fit well in my glove box but the larger format won't. (My friend put a small piece of Velcro on the back of his small volume so it would stick to his carpet on the tunnel.) I guess I'll get used to it but I'm old fashioned - change is bad. (Electronic ignition, GPS, XM weather, moving map wasn't change, just "improvements".) Albert Gardner N991RV Yuma, AZ (Is there an iPad in my future?) ________________________________________________________________________________
Subject: Re: I-Pad2 and Bad elf question
Date: Apr 23, 2011
Tim, I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works great and has an app that shows battery life as well as satellites and displays your position on Google earth. It locks on fast. I=99m using foreflight and considering changing to wingX when my foreflight subscription expires in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attention constantly if you are zoomed in. Is wing X the same way? If would be nice to have a moving map program on the IPAD not a moving airplane. Alan N668G From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, April 10, 2011 11:46 AM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitude when I looked a couple times on this trip. But, you're better off using baro altitudes. If you're relying on the ipad to be a backup vertical approach gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ============ st">http://www.matronics.com/Navigator?RV10-List ============ .matronics.com ============ Dralle, List Admin. p://www.matronics.com/contribution ============ > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Apr 23, 2011
Awesome. Sorry so short...am driving. Just checked it in the car and Wingx m oves the map so it would work. Tim On Apr 23, 2011, at 10:39 PM, "Alan Mekler" wrote: > Tim, > > I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works gr eat and has an app that shows battery life as well as satellites and display s your position on Google earth. It locks on fast. I=99m using forefli ght and considering changing to wingX when my foreflight subscription expire s in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attent ion constantly if you are zoomed in. Is wing X the same way? If would be ni ce to have a moving map program on the IPAD not a moving airplane. > > Alan > > N668G > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Sunday, April 10, 2011 11:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question > > > > I didn't really care about altitude. IMHO, lateral is really the only thi ng that matters. Trusting any cheap gps for vertical guidance isn't somethi ng I'd want to to. That said, my ipad 2 gps was pretty close to actual alti tude when I looked a couple times on this trip. But, you're better off usin g baro altitudes. If you're relying on the ipad to be a backup vertical app roach gps, bad elf or not, you're putting too much faith in it. > > Tim > > > > On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: > > My internal was absolutely perfect last night on the iPad 2. > On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > > > > How is the altitude accuracy in GPS only mode? I notice substantial > > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > > much in horizontal position. Has anyone compared having Bad Elf vs > > internal? > > > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T o r verizon ipad. The worst thing about either is just that you can't put it i n full airplane mode. Other than that, it works well. I wish the gps chip w as separate and you could turn it on separately. But what Jason said works g ood. > > > Tim > > > > > ============ > st">http://www.matronics.com/Navigator?RV10-List > ============ > .matronics.com > ============ > Dralle, List Admin. > p://www.matronics.com/contribution > ============ > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 23, 2011
Foreflight moves the map, you just need to hit the little arrow or triangle i con. It will recenter the map on the plane and keep the plane in the center of the map. Unless you touch and zoom or zoom out, then you need to hit th e little arrow icon again. I haven't used WingX yet, but I absolutely love Foreflight! -Mike Kraus Sent from my iPhone On Apr 23, 2011, at 11:39 PM, "Alan Mekler" wrote: > Tim, > > I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works gr eat and has an app that shows battery life as well as satellites and display s your position on Google earth. It locks on fast. I=99m using forefli ght and considering changing to wingX when my foreflight subscription expire s in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attent ion constantly if you are zoomed in. Is wing X the same way? If would be ni ce to have a moving map program on the IPAD not a moving airplane. > > Alan > > N668G > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Sunday, April 10, 2011 11:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question > > > > I didn't really care about altitude. IMHO, lateral is really the only thi ng that matters. Trusting any cheap gps for vertical guidance isn't somethi ng I'd want to to. That said, my ipad 2 gps was pretty close to actual alti tude when I looked a couple times on this trip. But, you're better off usin g baro altitudes. If you're relying on the ipad to be a backup vertical app roach gps, bad elf or not, you're putting too much faith in it. > > Tim > > > > On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: > > My internal was absolutely perfect last night on the iPad 2. > On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > > > > How is the altitude accuracy in GPS only mode? I notice substantial > > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > > much in horizontal position. Has anyone compared having Bad Elf vs > > internal? > > > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T o r verizon ipad. The worst thing about either is just that you can't put it i n full airplane mode. Other than that, it works well. I wish the gps chip w as separate and you could turn it on separately. But what Jason said works g ood. > > > Tim > > > > > ============ > st">http://www.matronics.com/Navigator?RV10-List > ============ > .matronics.com > ============ > Dralle, List Admin. > p://www.matronics.com/contribution > ============ > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 24, 2011
Tim, I just got this reply from foreflight. I don=99t have the HD version. Deciding which on to go with . Alan Hi Alan, No problem. The charts in ForeFlight HD can be used in either mode (moving map/moving airplane). To toggle this, use the crosshairs icon in the far upper right of the 'Maps' view. Note that if you toggle this on, the map will stay centered on your aircraft and you won't have to pan the map- but if you *do* pan the map manually, the auto-center feature disengages, so you'd need to use the icon again to re-engage. Give that a try and let us know if you continue to have difficulty or any other questions arise -- we're happy to help! Best Regards, Jeff Schuster ForeFlight Customer Support ForeFlight LLC From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Saturday, April 23, 2011 12:17 PM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question Awesome. Sorry so short...am driving. Just checked it in the car and Wingx moves the map so it would work. Tim On Apr 23, 2011, at 10:39 PM, "Alan Mekler" wrote: Tim, I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works great and has an app that shows battery life as well as satellites and displays your position on Google earth. It locks on fast. I=99m using foreflight and considering changing to wingX when my foreflight subscription expires in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attention constantly if you are zoomed in. Is wing X the same way? If would be nice to have a moving map program on the IPAD not a moving airplane. Alan N668G From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, April 10, 2011 11:46 AM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitude when I looked a couple times on this trip. But, you're better off using baro altitudes. If you're relying on the ipad to be a backup vertical approach gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ============ st">http://www.matronics.com/Navigator?RV10-List ============ .matronics.com ============ Dralle, List Admin. p://www.matronics.com/contribution ============ > > http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contribut ion ========= ________________________________________________________________________________
Subject: Foreflight centering button
Date: Apr 23, 2011
Hi Alan, Foreflight does have a centering button. It is in the upper right corner of the map page-- it is a circle with 4 short lines on the cardial points. It took me awhile to find it too. Sheldon Olesen N475PV. Sent from my iPad ________________________________________________________________________________
Date: Apr 24, 2011
Mike, I don=99t have the HD version so I don=99t have this feature. Alan From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Saturday, April 23, 2011 1:27 PM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question Foreflight moves the map, you just need to hit the little arrow or triangle icon. It will recenter the map on the plane and keep the plane in the center of the map. Unless you touch and zoom or zoom out, then you need to hit the little arrow icon again. I haven't used WingX yet, but I absolutely love Foreflight! -Mike Kraus Sent from my iPhone On Apr 23, 2011, at 11:39 PM, "Alan Mekler" wrote: Tim, I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works great and has an app that shows battery life as well as satellites and displays your position on Google earth. It locks on fast. I=99m using foreflight and considering changing to wingX when my foreflight subscription expires in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attention constantly if you are zoomed in. Is wing X the same way? If would be nice to have a moving map program on the IPAD not a moving airplane. Alan N668G From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Sunday, April 10, 2011 11:46 AM Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question I didn't really care about altitude. IMHO, lateral is really the only thing that matters. Trusting any cheap gps for vertical guidance isn't something I'd want to to. That said, my ipad 2 gps was pretty close to actual altitude when I looked a couple times on this trip. But, you're better off using baro altitudes. If you're relying on the ipad to be a backup vertical approach gps, bad elf or not, you're putting too much faith in it. Tim On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: My internal was absolutely perfect last night on the iPad 2. On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > How is the altitude accuracy in GPS only mode? I notice substantial > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > much in horizontal position. Has anyone compared having Bad Elf vs > internal? > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T or verizon ipad. The worst thing about either is just that you can't put it in full airplane mode. Other than that, it works well. I wish the gps chip was separate and you could turn it on separately. But what Jason said works good. > > Tim > > ============ st">http://www.matronics.com/Navigator?RV10-List ============ .matronics.com ============ Dralle, List Admin. p://www.matronics.com/contribution ============ > > http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contribut ion ========= ________________________________________________________________________________
Date: Apr 23, 2011
That's one thing about foreflight....they have awesome support. WingX is beating them in in-flight features but they still have zoom-to-TAC c hart and the best filing/briefing/weather, so I can't see dropping them, eve n though I use WingX more while flying. In contrast I basically never use W ingx on the ground. Tim On Apr 24, 2011, at 12:36 AM, "Alan Mekler" wrote: > Tim, > > I just got this reply from foreflight. I don=99t have the HD version . Deciding which on to go with . > > Alan > > Hi Alan, > > > > No problem. The charts in ForeFlight HD can be used in either mode (moving map/moving airplane). To toggle this, use the crosshairs icon in the far up per right of the 'Maps' view. > > > > Note that if you toggle this on, the map will stay centered on your aircra ft and you won't have to pan the map- but if you *do* pan the map manually, t he auto-center feature disengages, so you'd need to use the icon again to re -engage. > > > > Give that a try and let us know if you continue to have difficulty or any o ther questions arise -- we're happy to help! > > > > Best Regards, > > Jeff Schuster > > ForeFlight Customer Support > > ForeFlight LLC > > > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Saturday, April 23, 2011 12:17 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question > > > > Awesome. Sorry so short...am driving. Just checked it in the car and Wing x moves the map so it would work. > > Tim > > > > On Apr 23, 2011, at 10:39 PM, "Alan Mekler" wrote: > > Tim, > > I starting using the Dual xgps150 Bluetooth gps with my ipad2. It works gr eat and has an app that shows battery life as well as satellites and display s your position on Google earth. It locks on fast. I=99m using forefli ght and considering changing to wingX when my foreflight subscription expire s in May. One thing I don=99t like about foreflight is the plane moves and you have to move the map image to keep up with it. This requires attent ion constantly if you are zoomed in. Is wing X the same way? If would be ni ce to have a moving map program on the IPAD not a moving airplane. > > Alan > > N668G > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Tim Olson > Sent: Sunday, April 10, 2011 11:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: I-Pad2 and Bad elf question > > > > I didn't really care about altitude. IMHO, lateral is really the only thi ng that matters. Trusting any cheap gps for vertical guidance isn't somethi ng I'd want to to. That said, my ipad 2 gps was pretty close to actual alti tude when I looked a couple times on this trip. But, you're better off usin g baro altitudes. If you're relying on the ipad to be a backup vertical app roach gps, bad elf or not, you're putting too much faith in it. > > Tim > > > > > On Apr 10, 2011, at 9:33 AM, Phillip Perry wrote: > > My internal was absolutely perfect last night on the iPad 2. > On Apr 10, 2011 9:30 AM, "Kelly McMullen" wrote: > > > > > > How is the altitude accuracy in GPS only mode? I notice substantial > > improvement with WAAS equipped GPS vs non-WAAS on altitude, not so > > much in horizontal position. Has anyone compared having Bad Elf vs > > internal? > > > > On Sun, Apr 10, 2011 at 5:38 AM, Tim Olson wrote: > > > > > > Exactly. The gps in my iPhone 3GS was less quick than either my AT&T o r verizon ipad. The worst thing about either is just that you can't put it i n full airplane mode. Other than that, it works well. I wish the gps chip w as separate and you could turn it on separately. But what Jason said works g ood. > > > Tim > > > > > ============ > st">http://www.matronics.com/Navigator?RV10-List > ============ > .matronics.com > ============ > Dralle, List Admin. > p://www.matronics.com/contribution > ============ > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > ========================= ========= > ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List > ========================= ========= > ums.matronics.com">http://forums.matronics.com > ========================= ========= > http://www.matronics.com/contribution">http://www.matronics.com/contributi on > ========================= ========= > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Iphone / Android
Date: Apr 23, 2011
It seems there are a lot of Iphone users among the 10 list. Perhaps need to review the article. http://online.wsj.com/article/SB10001424052748703983704576277101723453610 .html?mod=WSJ_hp_MIDDLETopStories ________________________________________________________________________________
Date: Apr 25, 2011
Kelly McMullen wrote: > I believe the Bad Elf GPS has a pass through connector so the dock > port is still available, at least from the description I recall. But I > agree I wouldn't want an appendage there. > The Bad Elf GPS does have a pass-thru micro-USB port for charging the iPad during use. We know there are pros and cons for the dongle form-factor, the big downsides being antenna placement and having something hang off the iPad. I've been flying with it for over a year and neither IMHO are major issues. The upsides are true plug and play operation, zero configuration, and no batteries to keep charged. Not to mention that some pilots just don't like (or aren't allowed to use) Bluetooth in the cockpit. Luckily there are lots of apps and hardware accessories to match the wide range of personal preferences, all contributing to making the iPad the ultimate EFB. And Bad Elf has some exciting stuff in the works -- looking forward to Oshkosh ;-). Brett Hackleman Bad Elf, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338071#338071 ________________________________________________________________________________
Date: Apr 25, 2011
Subject: leading edge
Hi all - I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? - Since I'm only installing a single Duckworks HID landing light, is there an y reason it has to go in the left, as opposed to the right?- Convention s eems to dictate the stall switch and pitot tube all go in the left as well. - Is there a good reason for using the left?- Opinions welcome. - Thx. - Rick Southampton, Ont #40956 ________________________________________________________________________________
Date: Apr 25, 2011
Subject: Re: leading edge
I really like having two lights and the wig wag function. I feel it adds significantly to safety. Also I set one for taxi and one for in landing rotation so there is always light where I want it. Robin Sent from Android phone Probably while driving On Apr 25, 2011 12:20 PM, "Rick Lark" wrote: Hi all I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? Since I'm only installing a single Duckworks HID landing light, is there any reason it has to go in the left, as opposed to the right? Convention seems to dictate the stall switch and pitot tube all go in the left as well. Is there a good reason for using the left? Opinions welcome. Thx. Rick Southampton, Ont #40956 * * ________________________________________________________________________________
Date: Apr 25, 2011
The only reason I could think of would be for shorter runs to the left side of the instrument panel, but there's not much difference if you use the right side. Of course, if you put the landing light in the right side, its weight could help balance the weight of all that stuff in the left side. Jack Phillips #40610 Wings Raleigh, NC _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Monday, April 25, 2011 12:11 PM Subject: RV10-List: leading edge Hi all I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? Since I'm only installing a single Duckworks HID landing light, is there any reason it has to go in the left, as opposed to the right? Convention seems to dictate the stall switch and pitot tube all go in the left as well. Is there a good reason for using the left? Opinions welcome. Thx. Rick Southampton, Ont #40956 ________________________________________________________________________________
Date: Apr 25, 2011
You could move all the stuff you mentioned to the right side, but I'd still put the landing light on the left because that 's the side you'll be on (most likely) and the light's coverage will be more to that side of the plane. The mounting kit isn't really designed for left-right adjustment so you'd have to tinker to get the light aimed just right if you put it on the right side and wanted to optimize the lighting target area for the left seat. Not a show stopper by any stretch, but also not really something worth wasting time on IMO. Every mod, no matter how simple seems to add a lot of extra time to the build. Unless you have a good reason to relocate things from one side to the other, I recommend following the plans and build on. YMMV.... -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338082#338082 ________________________________________________________________________________
Date: Apr 25, 2011
If you only put one light in, you want it on the left side, the pilot side. If you put it on Rt side when taxing you do not get full vision. Rt side l anding, left side taxi. Just my two cents. Patrick Thyssen N15PT --- On Mon, 4/25/11, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: RE: RV10-List: leading edge Date: Monday, April 25, 2011, 11:48 AM =0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0A=0AThe only reason I could think of woul d be=0Afor shorter runs to the left side of the instrument panel, but there =99s=0Anot much difference if you use the right side.=C2- Of course , if you put the=0Alanding light in the right side, its weight could help b alance the weight of=0Aall that stuff in the left side. =0A=0A =C2- =0A =0AJack Phillips =0A=0A#40610 Wings =0A=0ARaleigh, NC =0A=0A =C2- =0A=0A =0A=0A=0A=0A=0A=0A=0A=0AFrom:=0Aowner-rv10-list-server(at)matronics.com=0A[mai lto:owner-rv10-list-server(at)matronics.com] On=0ABehalf Of Rick Lark =0ASent: Monday, April 25, 2011 12:11=0APM =0ATo: RV10-list =0ASubject: RV10-List: leading edge =0A=0A=0A=0A =C2- =0A=0A=0A =0A =0A =0A =0A =0A =0A =0A Hi all =0A =0A =0A =C2- =0A =0A =0A I'm slowly getting my leading edge sections ready for=0A p riming and assembly and am wondering why everything seems to go in the=0A left wing? =0A =0A =0A =C2- =0A =0A =0A Since I'm onl y installing a single Duckworks HID landing=0A light, is there any reaso n it has to go in the left, as opposed to the=0A right?=C2- Convention seems to dictate the stall switch and pitot tube=0A all go in the left as well.=C2- Is there a good reason for using the=0A left?=C2- Opini ons welcome. =0A =0A =0A =C2- =0A =0A =0A Thx. =0A =0A =0A =C2- =0A =0A =0A Rick =0A =0A =0A Southa mpton, Ont =0A =0A =0A #40956 =0A =0A =0A =0A =0A =0A =0A =0A =0A=0A=0A =C2- =C2-http://www.matronics.com/Navigator?RV10-Lis thttp://forums.matronics.comhttp://www.matronics.com/contribution =C2- =0A=0A=0A=0A=0A=0A=0A ________________________________________________________________________________
Date: Apr 25, 2011
I like the thought process. Why on the Left? The balance of CG from Left of Center to Over Center coupled with the reflection of light off of objects at a distance is easy with the old "Angle of Reflection Rule". Having twice as many Landing lights is fine, but I like the pursuit of CG as a reason for going to the Right. Our entire fleet has Pulse-Lights and both Landing/Flare circuits. Then there are those on the list that know I am no fan of the left and always right leaning. John #40600 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jack Phillips Sent: Monday, April 25, 2011 9:49 AM Subject: RE: RV10-List: leading edge The only reason I could think of would be for shorter runs to the left side of the instrument panel, but there's not much difference if you use the right side. Of course, if you put the landing light in the right side, its weight could help balance the weight of all that stuff in the left side. Jack Phillips #40610 Wings Raleigh, NC ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Monday, April 25, 2011 12:11 PM Subject: RV10-List: leading edge Hi all I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? Since I'm only installing a single Duckworks HID landing light, is there any reason it has to go in the left, as opposed to the right? Convention seems to dictate the stall switch and pitot tube all go in the left as well. Is there a good reason for using the left? Opinions welcome. Thx. Rick Southampton, Ont #40956 http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 25, 2011
Just to let everyone know, I am going to pulse the wing tip lights, and int ended to use them for taxi/landing if need be.=C2- I kind of figured havi ng the landing light as close as possible to being in-line with the PIC wou ld be the proper way to go.=C2- =C2- None the less, I will ensure I'm able to add another HID to the right wing in the future if need be. =C2- Hmmm, maybe I'll move the pitot tube to the right side.... =C2- Thx guys,=C2- Rick --- On Mon, 4/25/11, John Cox wrote: From: John Cox <johnwcox(at)pacificnw.com> Subject: RE: RV10-List: leading edge Received: Monday, April 25, 2011, 6:57 PM I like the thought process.=C2- Why on the Left?=C2- The balance of CG from Left of Center to Over Center coupled with the reflection of light off of objects at a distance is easy with the old "Angle of Reflection Rule". =C2- Having twice as many Landing lights is fine, but I like the pursuit of CG as a reason for going to the Right.=C2- Our entire fleet has Pulse- Lights and both Landing/Flare circuits. =C2- Then there are those on the list that know I am no fan of the left and alwa ys right leaning. =C2- John #40600 =C2- =C2- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Jack Phillips Sent: Monday, April 25, 2011 9:49 AM Subject: RE: RV10-List: leading edge =C2- The only reason I could think of would be for shorter runs to the left side of the instrument panel, but there=99s not much difference if you us e the right side.=C2- Of course, if you put the landing light in the righ t side, its weight could help balance the weight of all that stuff in the l eft side. =C2- Jack Phillips #40610 Wings Raleigh, NC =C2- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Rick Lark Sent: Monday, April 25, 2011 12:11 PM Subject: RV10-List: leading edge =C2- Hi all =C2- I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? =C2- Since I'm only installing a single Duckworks HID landing light, is there an y reason it has to go in the left, as opposed to the right?=C2- Conventio n seems to dictate the stall switch and pitot tube all go in the left as we ll.=C2- Is there a good reason for using the left?=C2- Opinions welcome . =C2- Thx. =C2- Rick Southampton, Ont #40956 =C2- =C2-http://www.matronics.com/Navigator?RV10-List =C2-http ://forums.matronics.com =C2-http://www.matronics.com/contribution =C2- =C2- =C2-http://www.matronics.com/Navigator?RV10-Listhttp://forums.matr onics.comhttp://www.matronics.com/contribution =C2- ________________________________________________________________________________
Date: Apr 25, 2011
My roll servo and aileron trim is in the right wing. They are by far heaver than the pitot tube and stall warning that are in the left wing. Also there are 7 wires to the servo and 5 (i thing) to the trim, filling up the conduit. Larry On 4/25/2011 3:40 PM, Rick Lark wrote: > Just to let everyone know, I am going to pulse the wing tip lights, > and intended to use them for taxi/landing if need be. I kind of > figured having the landing light as close as possible to being in-line > with the PIC would be the proper way to go. > None the less, I will ensure I'm able to add another HID to the right > wing in the future if need be. > Hmmm, maybe I'll move the pitot tube to the right side.... > Thx guys, Rick > > --- On *Mon, 4/25/11, John Cox //* wrote: > > > From: John Cox <johnwcox(at)pacificnw.com> > Subject: RE: RV10-List: leading edge > To: rv10-list(at)matronics.com > Received: Monday, April 25, 2011, 6:57 PM > > I like the thought process. Why on the Left? The balance of CG > from Left of Center to Over Center coupled with the reflection of > light off of objects at a distance is easy with the old "Angle of > Reflection Rule". Having twice as many Landing lights is fine, > but I like the pursuit of CG as a reason for going to the Right. > Our entire fleet has Pulse-Lights and both Landing/Flare circuits. > > Then there are those on the list that know I am no fan of the left > and always right leaning. > > John > > #40600 > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jack > Phillips > *Sent:* Monday, April 25, 2011 9:49 AM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: leading edge > > The only reason I could think of would be for shorter runs to the > left side of the instrument panel, but theres not much difference > if you use the right side. Of course, if you put the landing > light in the right side, its weight could help balance the weight > of all that stuff in the left side. > > Jack Phillips > > #40610 Wings > > Raleigh, NC > > ------------------------------------------------------------------------ > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick Lark > *Sent:* Monday, April 25, 2011 12:11 PM > *To:* RV10-list > *Subject:* RV10-List: leading edge > > Hi all > > I'm slowly getting my leading edge sections ready for priming and > assembly and am wondering why everything seems to go in the left wing? > > Since I'm only installing a single Duckworks HID landing light, is > there any reason it has to go in the left, as opposed to the > right? Convention seems to dictate the stall switch and pitot > tube all go in the left as well. Is there a good reason for using > the left? Opinions welcome. > > Thx. > > Rick > > Southampton, Ont > > #40956 > > * * > > * * > > *http://www.matronics.com/Navigator?RV10-List* > > * * > > *http://forums.matronics.com* > > * * > > *http://www.matronics.com/contribution* > > * * > > * * > > * > * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List > et=_blank>http://forums.matronics.com > llow target=_blank>http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Apr 25, 2011
I have the pitot on the right, because when I started I had this vision of the simple Van's pitot on the left, a heated pitot on the right. Well, that vision went away, and now there's an OAT probe in the hole where Van's pitot would have gone. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338119#338119 ________________________________________________________________________________
Date: Apr 25, 2011
Larry, after I wrote the reply below, I started thinking exactly as you hav e, and realized my -10 will have the servo and trim just like yours, so I g uess I will leave "well enough alone". =C2- Thx guys......... =C2- Rick --- On Tue, 4/26/11, Larry Rosen wrote: From: Larry Rosen <N205EN(at)gmail.com> Subject: Re: RV10-List: leading edge Received: Tuesday, April 26, 2011, 12:47 AM My roll servo and aileron trim is in the right wing.=C2- They are by far heaver than the pitot tube and stall warning that are in the left wing.=C2 - Also there are 7 wires to the servo and 5 (i thing) to the trim, fillin g up the conduit.=C2- Larry On 4/25/2011 3:40 PM, Rick Lark wrote: Just to let everyone know, I am going to pulse the wing tip lights, and int ended to use them for taxi/landing if need be.=C2- I kind of figured havi ng the landing light as close as possible to being in-line with the PIC wou ld be the proper way to go.=C2- =C2- None the less, I will ensure I'm able to add another HID to the right wing in the future if need be. =C2- Hmmm, maybe I'll move the pitot tube to the right side.... =C2- Thx guys,=C2- Rick --- On Mon, 4/25/11, John Cox wrote: From: John Cox <johnwcox(at)pacificnw.com> Subject: RE: RV10-List: leading edge Received: Monday, April 25, 2011, 6:57 PM I like the thought process.=C2- Why on the Left?=C2- The balance of CG from Left of Center to Over Center coupled with the reflection of light off of objects at a distance is easy with the old "Angle of Reflection Rule". =C2- Having twice as many Landing lights is fine, but I like the pursuit of CG as a reason for going to the Right.=C2- Our entire fleet has Pulse- Lights and both Landing/Flare circuits. =C2- Then there are those on the list that know I am no fan of the left and alwa ys right leaning. =C2- John #40600 =C2- =C2- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Jack Phillips Sent: Monday, April 25, 2011 9:49 AM Subject: RE: RV10-List: leading edge =C2- The only reason I could think of would be for shorter runs to the left side of the instrument panel, but there=99s not much difference if you us e the right side.=C2- Of course, if you put the landing light in the righ t side, its weight could help balance the weight of all that stuff in the l eft side. =C2- Jack Phillips #40610 Wings Raleigh, NC =C2- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Rick Lark Sent: Monday, April 25, 2011 12:11 PM Subject: RV10-List: leading edge =C2- Hi all =C2- I'm slowly getting my leading edge sections ready for priming and assembly and am wondering why everything seems to go in the left wing? =C2- Since I'm only installing a single Duckworks HID landing light, is there an y reason it has to go in the left, as opposed to the right?=C2- Conventio n seems to dictate the stall switch and pitot tube all go in the left as we ll.=C2- Is there a good reason for using the left?=C2- Opinions welcome . =C2- Thx. =C2- Rick Southampton, Ont #40956 =C2- =C2-http://www.matronics.com/Navigator?RV10-List =C2-http ://forums.matronics.com =C2-http://www.matronics.com/contribution =C2- =C2- =C2-http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics. comhttp://www.matronics.com/contribution =C2- =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List et=_blank>http://forums.matronics.com llow target=_blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Ted Chang
Date: Apr 27, 2011
Ted just posted to facebook that he had an inflight fire and landed 4nm off a irport during his phase 1. Ted is ok, but the rv-10's gear collapsed. The re was no mention as to the cause of the fire. He posted some photos to facebook Sent from my iPhone__,_._,___ ________________________________________________________________________________
Subject: Re: Ted Chang
Date: Apr 27, 2011
Too many Ted changs on face book Sent from my iPhone On Apr 27, 2011, at 3:39 PM, Bob Leffler wrote: > > Ted just posted to facebook that he had an inflight fire and landed 4nm of f airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. T here was no mention as to the cause of the fire. > > He posted some photos to facebook > > Sent from my iPhone__,_._,___ > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 27, 2011
http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 David Leikam RV10 Flying On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: > > Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. > > He posted some photos to facebook > > Sent from my iPhone__,_._,___ > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > ________________________________________________________________________________
Date: Apr 27, 2011
Really sad, but good Ted walked away. Be interesting to know what happened? does not look like any fire damage to the aircraft. Pascal From: David Leikam Sent: Wednesday, April 27, 2011 3:39 PM Subject: Re: RV10-List: Ted Chang http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 David Leikam RV10 Flying On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. He posted some photos to facebook Sent from my iPhone__,_._,___ 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22 ">http://www.matronics.com/Navigator?RV10-List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.m atronics.com 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href="x-msg://1484/3D%22http://www.matronics.com/contribution%22">http: //www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Apr 27, 2011
Glad Ted walked away-wonder what happened to the door,Inflight fire is a sc ary thing-Hope you regroup and get back in the air quickly -----Original Message----- From: Pascal <rv10flyer(at)verizon.net> Sent: Wed, Apr 27, 2011 4:17 pm Subject: Re: RV10-List: Ted Chang Really sad, but good Ted walked away. Be interesting to know what happened? does not look like any fire damage to the aircraft. Pascal From: David Leikam Sent: Wednesday, April 27, 2011 3:39 PM Subject: Re: RV10-List: Ted Chang http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 David Leikam RV10 Flying On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. He posted some photos to facebook Sent from my iPhone__,_._,___ 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ref="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22">h ttp://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ref="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.matr onics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ref="x-msg://1484/3D%22http://www.matronics.com/contribution%22">http://w ww.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Ted Chang
Date: Apr 27, 2011
Ted posted the following to the local RV list: Thank you for your concern. I have been busy today and finally get a chance to organize my pictures and thoughts. Here is a link to my photos. It works as long as you click on this link. https://picasaweb.google.com/tc1234c/4272011RV10Accident?authkey=Gv1sRgCPjmt viSyuKsQg# I had a fuel fire while four miles up wind to runway 18. I discharged fire extinguisher to put off the fire that is outside of the tunnel. In a few seconds the blinding smoke filled the cabin (from paint or SCAT tube? not wires since there is only fuel pump and fuel flow sensor wires in there.). I turned the fuel selector to shut off the fuel supply . Since I could not see, I popped open the pilot side door and it quickly flew off. Now I saw that I have a pasture on my left. This is a hilly country with streams, trees and houses, not too many landing choices. Engine quit and I banked left sharply to make to the field. I saw a telephone line along the road and ducked down under it. As soon as I cleared the phone line I pull the nose up and the airplane impacted the ground (with the stall warning beeping) which is sloping up. The impact bent all three landing gears and absorbed the impact. I did not feel a very hard bump at all. The airplane slided uphill for a few hundred feet and stopped over the top of the hill. I got out and saw a little smoke still coming out under the tunnel. I grabbed my phone and camera and began calling 911. That began a very long day taking the statement and waiting for the FAA inspector. The only injury I sustained is a 1/8" size burn on my hand, no blister even. Our local TV station reported that I burnt my hand. It is a little exaggerated. This is the first accident I have had. I hope it is the last too. From this experience I learned a few things: a. Whatever happens keep cool. b. Don't try to save your airplane, save yourself first. c. Fly your airplane until you have no control of it. I will open the cowling and tunnel cover after the airplane is brought back to my hangar and find what is the cause of the fire. At that time I will share with you my findings. Be safe! Ted From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds Sent: Wednesday, April 27, 2011 8:18 PM Subject: Re: RV10-List: Ted Chang Glad Ted walked away-wonder what happened to the door,Inflight fire is a scary thing-Hope you regroup and get back in the air quickly -----Original Message----- From: Pascal <rv10flyer(at)verizon.net> Sent: Wed, Apr 27, 2011 4:17 pm Subject: Re: RV10-List: Ted Chang Really sad, but good Ted walked away. Be interesting to know what happened? does not look like any fire damage to the aircraft. Pascal From: David Leikam <mailto:daveleikam(at)wi.rr.com> Sent: Wednesday, April 27, 2011 3:39 PM Subject: Re: RV10-List: Ted Chang http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 David Leikam RV10 Flying On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. He posted some photos to facebook Sent from my iPhone__,_._,___ 3D=========================3 D=================== href="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22 <http://www.matronics.com/Navigator?RV10-List%22%22%3ehttp://www.matronics.c om/Navigator?RV10-List> ">http://www.matronics.com/Navigator?RV10-List 3D=========================3 D=================== href="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.matron ics.com <http://forums.matronics.com/> 3D=========================3 D=================== href="x-msg://1484/3D%22http://www.matronics.com/contribution%22 <http://www.matronics.com/contribution%22%22%3Ehttp:/www.matronics.com/contr ibution> ">http://www.matronics.com/contribution 3D=========================3 D=================== href="http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List%22%3ehttp://www.matronics.com/ Navigator?RV10-List> ">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com <http://forums.matronics.com%22%3ehttp/forums.matronics.com> ">http://forums.matronics.com href="http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3Ehttp:/www.matronics.com/c> ">http://www.matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Trutrak autopilot
Date: Apr 27, 2011
I have the DigiFlite II VSGV; when I was building I specifically asked TT whether the AP should be off on the buss while cranking. I was told the AP could be on while cranking. Experience has shown and TT has confirmed that the AP should be off during cranking and the aircraft should remain stopped for about 30 seconds to allow the internal sensors to determine the parameters for straight and level flight. At the next annual I intend to switch the pullable breaker for the AP to a toggle breaker. ________________________________________________________________________________
Date: Apr 27, 2011
That is what Stein recommended with my panel. It also gives you a switch to turn off if the AP goes crazy and tries to crash the airplane. J Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Wednesday, April 27, 2011 8:45 AM Subject: RV10-List: Trutrak autopilot I have the DigiFlite II VSGV; when I was building I specifically asked TT whether the AP should be off on the buss while cranking. I was told the AP could be on while cranking. Experience has shown and TT has confirmed that the AP should be off during cranking and the aircraft should remain stopped for about 30 seconds to allow the internal sensors to determine the parameters for straight and level flight. At the next annual I intend to switch the pullable breaker for the AP to a toggle breaker. ________________________________________________________________________________
Date: Apr 27, 2011
Interesting. Glad he is safe and I hope he will share some honest detail re garding his fuel system and any modifications he made. I guess that answers the question about being able to open a door in flight. We now know it is possible. I always wondered if it could be done or if t he sucking action on the doors would cause so much friction at the pins that they wouldn't move. That question is now answered (at least at maneuvering speeds). Most importantly - I'm really glad he is safe. Phil On Apr 27, 2011, at 8:22 PM, "Bob Leffler" wrote: > Ted posted the following to the local RV list: > > > > Thank you for your concern. I have been busy today and finally get a chanc e to organize my pictures and thoughts. Here is a link to my photos. It wor ks as long as you click on this link. > > > > https://picasaweb.google.com/tc1234c/4272011RV10Accident?authkey=Gv1sRgC PjmtviSyuKsQg# > > > > I had a fuel fire while four miles up wind to runway 18. I discharged fire extinguisher to put off the fire that is outside of the tunnel. In a few se conds the blinding smoke filled the cabin (from paint or SCAT tube? not wire s since there is only fuel pump and fuel flow sensor wires in there.). I tur ned the fuel selector to shut off the fuel supply . Since I could not see, I popped open the pilot side door and it quickly flew off. Now I saw that I h ave a pasture on my left. This is a hilly country with streams, trees and ho uses, not too many landing choices. Engine quit and I banked left sharply to make to the field. I saw a telephone line along the road and ducked down un der it. As soon as I cleared the phone line I pull the nose up and the airpl ane impacted the ground (with the stall warning beeping) which is sloping up . The impact bent all three landing gears and absorbed the impact. I did not feel a very hard bump at all. The airplane slided uphill for a few hundred f eet and stopped over the top of the hill. I got out and saw a little smoke s till coming out under the tunnel. I grabbed my phone and camera and began ca lling 911. That began a very long day taking the statement and waiting for t he FAA inspector. The only injury I sustained is a 1/8" size burn on my hand , no blister even. Our local TV station reported that I burnt my hand. It is a little exaggerated. > > > > This is the first accident I have had. I hope it is the last too. =46rom t his experience I learned a few things: > > > > a. Whatever happens keep cool. > > b. Don't try to save your airplane, save yourself first. > > c. Fly your airplane until you have no control of it. > > > > I will open the cowling and tunnel cover after the airplane is brought bac k to my hangar and find what is the cause of the fire. At that time I will s hare with you my findings. > > > > Be safe! > > > > Ted > > > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of pilotdds > Sent: Wednesday, April 27, 2011 8:18 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Ted Chang > > > > Glad Ted walked away-wonder what happened to the door,Inflight fire is a s cary thing-Hope you regroup and get back in the air quickly > > > > -----Original Message----- > From: Pascal <rv10flyer(at)verizon.net> > To: rv10-list > Sent: Wed, Apr 27, 2011 4:17 pm > Subject: Re: RV10-List: Ted Chang > > Really sad, but good Ted walked away. Be interesting to know what happened ? does not look like any fire damage to the aircraft. > > Pascal > > > > From: David Leikam > > Sent: Wednesday, April 27, 2011 3:39 PM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Ted Chang > > > > http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 > > > > David Leikam > > RV10 > > Flying > > > > > > > > > > > > > > > > On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: > > > > > > Ted just posted to facebook that he had an inflight fire and landed 4nm of f airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. T here was no mention as to the cause of the fire. > > > > He posted some photos to facebook > > > Sent from my iPhone__,_._,___ > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > href="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22" >http://www.matronics.com/Navigator?RV10-List > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > href="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.ma tronics.com > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > href="x-msg://1484/3D%22http://www.matronics.com/contribution%22">http:/ /www.matronics.com/contribution > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 27, 2011
I never thought the doors opening/flying off in air was an issue, they do it without trying too! it was trying to close them/save them if they became open that I always wondered about. From: Phil Perry Sent: Wednesday, April 27, 2011 7:00 PM Subject: Re: RV10-List: Ted Chang Interesting. Glad he is safe and I hope he will share some honest detail regarding his fuel system and any modifications he made. I guess that answers the question about being able to open a door in flight. We now know it is possible. I always wondered if it could be done or if the sucking action on the doors would cause so much friction at the pins that they wouldn't move. That question is now answered (at least at maneuvering speeds). Most importantly - I'm really glad he is safe. Phil On Apr 27, 2011, at 8:22 PM, "Bob Leffler" wrote: Ted posted the following to the local RV list: Thank you for your concern. I have been busy today and finally get a chance to organize my pictures and thoughts. Here is a link to my photos. It works as long as you click on this link. https://picasaweb.google.com/tc1234c/4272011RV10Accident?authkey=Gv1sRg CPjmtviSyuKsQg# I had a fuel fire while four miles up wind to runway 18. I discharged fire extinguisher to put off the fire that is outside of the tunnel. In a few seconds the blinding smoke filled the cabin (from paint or SCAT tube? not wires since there is only fuel pump and fuel flow sensor wires in there.). I turned the fuel selector to shut off the fuel supply . Since I could not see, I popped open the pilot side door and it quickly flew off. Now I saw that I have a pasture on my left. This is a hilly country with streams, trees and houses, not too many landing choices. Engine quit and I banked left sharply to make to the field. I saw a telephone line along the road and ducked down under it. As soon as I cleared the phone line I pull the nose up and the airplane impacted the ground (with the stall warning beeping) which is sloping up. The impact bent all three landing gears and absorbed the impact. I did not feel a very hard bump at all. The airplane slided uphill for a few hundred feet and stopped over the top of the hill. I got out and saw a little smoke still coming out under the tunnel. I grabbed my phone and camera and began calling 911. That began a very long day taking the statement and waiting for the FAA inspector. The only injury I sustained is a 1/8" size burn on my hand, no blister even. Our local TV station reported that I burnt my hand. It is a little exaggerated. This is the first accident I have had. I hope it is the last too. From this experience I learned a few things: a. Whatever happens keep cool. b. Don't try to save your airplane, save yourself first. c. Fly your airplane until you have no control of it. I will open the cowling and tunnel cover after the airplane is brought back to my hangar and find what is the cause of the fire. At that time I will share with you my findings. Be safe! Ted From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds Sent: Wednesday, April 27, 2011 8:18 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Ted Chang Glad Ted walked away-wonder what happened to the door,Inflight fire is a scary thing-Hope you regroup and get back in the air quickly -----Original Message----- From: Pascal <rv10flyer(at)verizon.net> To: rv10-list Sent: Wed, Apr 27, 2011 4:17 pm Subject: Re: RV10-List: Ted Chang Really sad, but good Ted walked away. Be interesting to know what happened? does not look like any fire damage to the aircraft. Pascal From: David Leikam Sent: Wednesday, April 27, 2011 3:39 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Ted Chang http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 David Leikam RV10 Flying On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. He posted some photos to facebook Sent from my iPhone__,_._,___ 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3Dhref="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List% 22">http://www.matronics.com/Navigator?RV10-List3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref="x-msg://1484/ 3D%22http://forums.matronics.com%22">http://forums.matronics.com3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dhref= "x-msg://1484/3D%22http://www.matronics.com/contribution%22">http://www.m atronics.com/contribution3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://foru ms.matronics.comhref="http://www.matronics.com/contribution">http://www .matronics.com/c get=_blank>http://www.matronics.com/Navigator?RV10-Listp://forums.matro nics.comblank>http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contribut ion ========= ________________________________________________________________________________
Date: Apr 27, 2011
Has anyone considered putting a vent window on either door window, such as Bonanza, Piper, Mooney do? Might be awful handy to ventilate the cockpit without losing a door. On 4/27/2011 7:16 PM, Pascal wrote: > I never thought the doors opening/flying off in air was an issue, they > do it without trying too! it was trying to close them/save them if they > became open that I always wondered about. ________________________________________________________________________________
Date: Apr 27, 2011
Looks and sounds like some really good flying by Ted. Getting the thing under a power line and then a full stall touch down!? Thank God he walked away. The fuel valve selector looks like it has a different handle on it. Like the door handle supplied in the kit. I wonder what valve he used. I wish the tunnel was easier to access to inspect the fuel plumbing more often. David Leikam RV10 Flying On Apr 27, 2011, at 5:39 PM, David Leikam wrote: > http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 > > David Leikam > RV10 > Flying > > > > > > > > > On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: > >> >> Ted just posted to facebook that he had an inflight fire and landed 4nm off airport during his phase 1. Ted is ok, but the rv-10's gear collapsed. There was no mention as to the cause of the fire. >> >> He posted some photos to facebook >> >> Sent from my iPhone__,_._,___ >> >> >> >> >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D >> href="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22" >http://www.matronics.com/Navigator?RV10-List >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D >> href="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.ma tronics.com >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D >> href="x-msg://1484/3D%22http://www.matronics.com/contribution%22">http:/ /www.matronics.com/contribution >> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D >> > > > > ________________________________________________________________________________
Date: Apr 27, 2011
There was one at OSH 2 years ago with one installed but I can't remember who had it. On Apr 27, 2011 9:40 PM, "Kelly McMullen" wrote: > > Has anyone considered putting a vent window on either door window, such > as Bonanza, Piper, Mooney do? Might be awful handy to ventilate the > cockpit without losing a door. > > On 4/27/2011 7:16 PM, Pascal wrote: >> I never thought the doors opening/flying off in air was an issue, they >> do it without trying too! it was trying to close them/save them if they >> became open that I always wondered about. > > ________________________________________________________________________________
Date: Apr 27, 2011
"I wish the tunnel was easier to access to inspect the fuel plumbing more often." Tunnel Access Kit... http://airward.com/amelia/search.asp?advnav=&action=Search&store=&cat=10000016&subcat_10000003=10000016&ShowImages=&ShowDetails=&menuID=15~15&id=17 Actually looks like he had at least one of these on the pilot side. On 4/27/11 9:44 PM, David Leikam wrote: > Looks and sounds like some really good flying by Ted. Getting the > thing under a power line and then a full stall touch down!? Thank God > he walked away. > The fuel valve selector looks like it has a different handle on it. > Like the door handle supplied in the kit. I wonder what valve he > used. I wish the tunnel was easier to access to inspect the fuel > plumbing more often. > > David Leikam > RV10 > Flying > > > On Apr 27, 2011, at 5:39 PM, David Leikam wrote: > >> http://newsodrome.com/aviation_news/ted-s-plane-and-the-voice-25394830 >> >> David Leikam >> RV10 >> Flying >> >> >> >> >> >> >> >> >> On Apr 27, 2011, at 2:39 PM, Bob Leffler wrote: >> >>> >>> Ted just posted to facebook that he had an inflight fire and landed >>> 4nm off airport during his phase 1. Ted is ok, but the rv-10's >>> gear collapsed. There was no mention as to the cause of the fire. >>> >>> He posted some photos to facebook >>> >>> Sent from my iPhone__,_._,___ >>> >>> >>> * >>> >>> 3D============================================ >>> href="x-msg://1484/3D%22http://www.matronics.com/Navigator?RV10-List%22">http://www.matronics.com/Navigator?RV10-List >>> 3D============================================ >>> href="x-msg://1484/3D%22http://forums.matronics.com%22">http://forums.matronics.com >>> 3D============================================ >>> href="x-msg://1484/3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution >>> 3D============================================ >>> >>> * >> >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> * > > * > > > * ________________________________________________________________________________
Subject: Ted Chang
Date: Apr 27, 2011
Hmmm Speaking of vents, has anyone put a vent in the tunnel. I am wondering if a piece of tubing, facing rearward and mounted on the exterior skin under the tunnel, could be used to keep negative pressure in the tunnel. Inquiring miinds need to know Les PS: I am very glad Ted was able to land safely. It sounds like he did an amazing job in a very sticky situation. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: April-27-11 8:34 PM Subject: Re: RV10-List: Ted Chang Has anyone considered putting a vent window on either door window, such as Bonanza, Piper, Mooney do? Might be awful handy to ventilate the cockpit without losing a door. On 4/27/2011 7:16 PM, Pascal wrote: > I never thought the doors opening/flying off in air was an issue, they > do it without trying too! it was trying to close them/save them if > they became open that I always wondered about. ________________________________________________________________________________
Date: Apr 27, 2011
"The fuel valve selector looks like it has a different handle on it." That is the handle from Vans, supplied on kits after about March 2008. The "new" fuel setup has the (essentially) same valve but lower in the tunnel, with a long shaft up to the handle. There is an AN fitting on the line where it penetrates the tunnel, unlike the original design where it was a continuous piece of aluminum going thru a rubber grommet. Handle appears to be in between left and right, which I guess is off. I'd have put it to the rear for a more positive 'off'. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338267#338267 ________________________________________________________________________________
Date: Apr 28, 2011
Subject: Fire and off field landing
I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. Ted ________________________________________________________________________________
Date: Apr 28, 2011
Ted Thank you for your candour and willingness to share whatever can be learned from your accident. Everyone one the list is relieved that you came out okay on this. Regards Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang Sent: April-28-11 4:53 AM Subject: RV10-List: Fire and off field landing I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. Ted ________________________________________________________________________________
Date: Apr 28, 2011
Subject: Re: Fire and off field landing
Ted, Thank you for the summary. I think you did a great job getting the plane on the ground without personal injury.Your story makes me want to get a smoke hood for my flying. Regards, Alan On Thu 04/28/11 6:53 AM , Ted Chang wrote: I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. Ted Links: ------ [2] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fwww.matron ics.com%2FNavigator%3FRV10-List [3] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fforums.mat ronics.com [4] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fwww.matron ics.com%2Fcontribution ________________________________________________________________________________
Date: Apr 28, 2011
Ted and RV-10, Just found this link to smoke evac hoods. http://www.avweb.com/news/safety/cockpit_smoke_hoods_197712-1.html [1] Regards, Alan Mekler n668g On Thu 04/28/11 6:53 AM , Ted Chang wrote: I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. Ted Links: ------ [1] http://www.avweb.com/news/safety/cockpit_smoke_hoods_197712-1.html [3] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fwww.matron ics.com%2FNavigator%3FRV10-List [4] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fforums.mat ronics.com [5] http://metromail.metrocast.net/parse.php?redirect=http%3A%2F%2Fwww.matron ics.com%2Fcontribution ________________________________________________________________________________
Date: Apr 28, 2011
Ted, Thanks for sharing your experiences and thoughts! The community will be better from learning from your experience. If you need any help, let me know. I'm only a couple hours away. bob -------- Bob Leffler N410BL - FWF RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338292#338292 ________________________________________________________________________________
Subject: Tunnel Access From Below
Date: Apr 28, 2011
After reading about an earlier RV-10 tunnel fire I made an opening in the belly skin so I could quickly check the tunnel and clean the filter without spilling fuel in the tunnel. It's a lot easier to remove the bottom cover than to remove the carpet and tunnel cover. In my case I have to remove the seats to get access to some of the screws. I left a piece of the original skin that has the saddle and clamp that holds the filter so that the filter would be at the right height. After a filter cleaning and inspection that piece with the filter clamp is repositioned using a small plate to locate it. There are 20 screws that attach the cover which may be overkill but I put a nutplate at every other rivet. Would have been easier to do when building. Albert Gardner N991RV Yuma, AZ BTW, I would be concerned that any kind of vent would introduce exhaust gasses. ________________________________________________________________________________
Date: Apr 28, 2011
You are a good man Ted Chang--glad you are still with us. Jay Rowe #301 ---- Ted Chang wrote: > > I thought I owe you, my fellow RV-10 builder some information. At this > point the plane is still sitting in the field and I have been spending > the time doing statements and answering inquiries from friends. Without > opening the tunnel and cowling I can not say for sure what happened. > Here are my observations: > > a. Fire was limited to the tunnel. > b. It is a fuel leak inside the tunnel that fed into the fire. > c. Fuel has been leaking some time before the fire started on this > particular flight (based on the high fuel flow). Fuel flow was normal > when I taxied out and on the take off. > d. The smoke thinned out soon after I jettisoned the door. Although I > still did not have much in-flight visibility, by the time the airplane > stopped the cabin was almost cleared of smoke. > e. There is no time to think. When my right leg felt warm I banked > quickly and put it on the ground soon. > f. After I turn off the fuel (it did shut off) there were still small > fire but limited to inside the tunnel. > g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool > boxes in my baggage compartment to keep the CG in the limit (my W&B > requirement). > h. I have not calibrated my stall warning system. The buzzer goes off at > around 60 kts. So, it was not a full stall landing. The field slopes up > and I had a three point. > i. Don't rely on emergency checklist. Remember the important steps and > just do it. There is no time and visibility to find the checklist. > > > Some facts: > > a. There is no modification on my fuel system. > b. The door is still good except the area where bolts go through. It is > the quickest way to get ride of the smoke and get visibility from the > opening. > c. The fire damage seems to be limited to around tunnel and firewall. I > do have insulation inside the tunnel floor and up on firewall. > d. Propeller strike and powder fire extinguisher from the fire > department probably caused more damage than the fire. > > > I have to admit that for a few seconds when the smoke came out and my > leg felt the heat I had a thought that I was in deep trouble (burn to > death). I quickly focused on the tasks in front of me and tried to fly > the airplane and solve the problems I was facing. From that point on > there was no fear or regret. After I called 911 and my insurance agent > I got to walk down the hill, wait and think. My only negative thought > was that my accident might negatively impact a lot of builders. I don't > want to see anyone get disencouraged. I am pretty sure that what > happened to me is not a design flaw, but a builder mistake. After I > found the problem I will share with you so you can avoid this problem. > > > > Ted > > > > ________________________________________________________________________________
Date: Apr 28, 2011
donning it is the problem; I have smoke hood but not quick donning type, so unless the AP is flying the hood won't happen. ----- Original Message ----- From: amekler(at)metrocast.net To: rv10-list(at)matronics.com Sent: Thursday, April 28, 2011 6:00 AM Subject: Re: RV10-List: Fire and off field landing Ted, Thank you for the summary. I think you did a great job getting the plane on the ground without personal injury.Your story makes me want to get a smoke hood for my flying. Regards, Alan On Thu 04/28/11 6:53 AM , Ted Chang wrote: I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. Ted ========== tp%3A%2F%2Fwww.matronics.com%2FNavigator%3FRV10-List" target=_blank>http://www.matronics.com/Navigator?RV10-List ========== tp%3A%2F%2Fforums.matronics.com" target=_blank>http://forums.matronics.com ========== tp%3A%2F%2Fwww.matronics.com%2Fcontribution" target=_blank>http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Re: Tunnel Access From Below
Date: Apr 28, 2011
Your solution is the best, Albert. If I was building again, I would definitely do this mod. Now I have to decide if I am up to tackling it as a retrofit on my airplane. [Rolling Eyes] Getting to my filter from above is a real pain! -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338308#338308 ________________________________________________________________________________
Date: Apr 28, 2011
Here's how I attempted to tackle the filter access issue from above. I think it makes it quite a bit easier when getting everything aligned. http://www.youtube.com/watch?v=x3mpcapeBA8 Phil On Thu, Apr 28, 2011 at 9:47 AM, dmaib(at)me.com wrote: > > Your solution is the best, Albert. If I was building again, I would > definitely do this mod. Now I have to decide if I am up to tackling it as a > retrofit on my airplane. [Rolling Eyes] > Getting to my filter from above is a real pain! > > -------- > David Maib > RV-10 #40559 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338308#338308 > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Apr 28, 2011
Hi Ted, Thanks so much for your report. Great job! One thing I'm wondering about is whether you remember using the flaps at the time the fire started. There's been some discussion about the flap motor as an ignition source. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Thu, Apr 28, 2011 at 3:53 AM, Ted Chang wrote: > > I thought I owe you, my fellow RV-10 builder some information. At this point ________________________________________________________________________________
Date: Apr 28, 2011
I used the Airward access cover on the side. It is very large and easy to get to. I only have 12 hours on the plane so I can't say how it is to pull in and out but it looks easy. Here is a link: http://www.airward.com/amelia/search.asp?advnav=&action=Search&store=&cat=10000016&subcat_10000003=10000016&ShowImages=&ShowDetails=&menuID=15~15&id=17 -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338314#338314 ________________________________________________________________________________
Date: Apr 28, 2011
Wow, Phil. That is really nice! -------- David Maib RV-10 #40559 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338315#338315 ________________________________________________________________________________
Date: Apr 28, 2011
Thanks... The only thing that has changed since I shot the video. 1) I decided to keep the aluminum hardline from the boost pump to the firewall. 2) I added a two cross support (between the tunnel walls) to support that aluminum line with Adel clamps. The photo is attached to this e-mail. Phil On Thu, Apr 28, 2011 at 10:15 AM, dmaib(at)me.com wrote: > > Wow, Phil. That is really nice! > > -------- > David Maib > RV-10 #40559 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338315#338315 > > ________________________________________________________________________________
Date: Apr 28, 2011
So very happy you made it through this event, Ted. Great job! John J ________________________________________________________________________________
Date: Apr 28, 2011
Thanks for the info Ted. I've had two off-field landings ..... engine related .... and there's no real way of knowing how you will react to an emergency until you really do have one. Your reactions appear to be excellent. Without knowing anything about you, you've got my respect (for what that's worth!). I'm counting two RV-10 tunnel fires so far. the first one was destroyed so no definitive info (that I have) emerged. Your investigation will be valuable to the rest of us builders. I have two questions: 1) Where did the fuel escape from the system? 2) What was the ignition source? If you can answer those, you'll give a lot of builders more sleep at night. To echo the many other comments .... I'm glad the outcome was successful. The plane can be repaired. Linn On 4/28/2011 6:53 AM, Ted Chang wrote: > > I thought I owe you, my fellow RV-10 builder some information. At this > point the plane is still sitting in the field and I have been spending > the time doing statements and answering inquiries from friends. > Without opening the tunnel and cowling I can not say for sure what > happened. Here are my observations: > > a. Fire was limited to the tunnel. > b. It is a fuel leak inside the tunnel that fed into the fire. > c. Fuel has been leaking some time before the fire started on this > particular flight (based on the high fuel flow). Fuel flow was normal > when I taxied out and on the take off. > d. The smoke thinned out soon after I jettisoned the door. Although I > still did not have much in-flight visibility, by the time the airplane > stopped the cabin was almost cleared of smoke. > e. There is no time to think. When my right leg felt warm I banked > quickly and put it on the ground soon. > f. After I turn off the fuel (it did shut off) there were still small > fire but limited to inside the tunnel. > g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool > boxes in my baggage compartment to keep the CG in the limit (my W&B > requirement). > h. I have not calibrated my stall warning system. The buzzer goes off > at around 60 kts. So, it was not a full stall landing. The field > slopes up and I had a three point. > i. Don't rely on emergency checklist. Remember the important steps and > just do it. There is no time and visibility to find the checklist. > > > Some facts: > > a. There is no modification on my fuel system. > b. The door is still good except the area where bolts go through. It > is the quickest way to get ride of the smoke and get visibility from > the opening. > c. The fire damage seems to be limited to around tunnel and firewall. > I do have insulation inside the tunnel floor and up on firewall. > d. Propeller strike and powder fire extinguisher from the fire > department probably caused more damage than the fire. > > > I have to admit that for a few seconds when the smoke came out and my > leg felt the heat I had a thought that I was in deep trouble (burn to > death). I quickly focused on the tasks in front of me and tried to fly > the airplane and solve the problems I was facing. From that point on > there was no fear or regret. After I called 911 and my insurance > agent I got to walk down the hill, wait and think. My only negative > thought was that my accident might negatively impact a lot of > builders. I don't want to see anyone get disencouraged. I am pretty > sure that what happened to me is not a design flaw, but a builder > mistake. After I found the problem I will share with you so you can > avoid this problem. > > > Ted > > ________________________________________________________________________________
Date: Apr 28, 2011
Ted glad you are ok. Great job. Let me know if I can help. Geoff Combs N829GW Sent from my iPhone Geoff On Apr 28, 2011, at 12:29 PM, Linn Walters wrote: > > Thanks for the info Ted. I've had two off-field landings ..... engine related .... and there's no real way of knowing how you will react to an emergency until you really do have one. Your reactions appear to be excellent. Without knowing anything about you, you've got my respect (for what that's worth!). > > I'm counting two RV-10 tunnel fires so far. the first one was destroyed so no definitive info (that I have) emerged. Your investigation will be valuable to the rest of us builders. > > I have two questions: > 1) Where did the fuel escape from the system? > 2) What was the ignition source? > > If you can answer those, you'll give a lot of builders more sleep at night. > > To echo the many other comments .... I'm glad the outcome was successful. The plane can be repaired. > > Linn > > > On 4/28/2011 6:53 AM, Ted Chang wrote: >> >> I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: >> >> a. Fire was limited to the tunnel. >> b. It is a fuel leak inside the tunnel that fed into the fire. >> c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. >> d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. >> e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. >> f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. >> g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). >> h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. >> i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. >> >> >> Some facts: >> >> a. There is no modification on my fuel system. >> b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. >> c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. >> d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. >> >> >> I have to admit that for a few seconds when the smoke came out and my leg felt the heat I had a thought that I was in deep trouble (burn to death). I quickly focused on the tasks in front of me and tried to fly the airplane and solve the problems I was facing. From that point on there was no fear or regret. After I called 911 and my insurance agent I got to walk down the hill, wait and think. My only negative thought was that my accident might negatively impact a lot of builders. I don't want to see anyone get disencouraged. I am pretty sure that what happened to me is not a design flaw, but a builder mistake. After I found the problem I will share with you so you can avoid this problem. >> >> >> >> Ted >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Apr 28, 2011
That is very clean. I'd think that anything which reduces the number of fittings required in the fuel system can only be a good thing. Anyone wanna buy an installed only once and never turned on Airflow pump and filter? :) - Sean #40303 On 4/28/11 10:32 AM, Phillip Perry wrote: > Thanks... > > The only thing that has changed since I shot the video. > > 1) I decided to keep the aluminum hardline from the boost pump to the > firewall. > > 2) I added a two cross support (between the tunnel walls) to support > that aluminum line with Adel clamps. The photo is attached to this > e-mail. > > Phil > > > On Thu, Apr 28, 2011 at 10:15 AM, dmaib(at)me.com > > wrote: > > " > > > Wow, Phil. That is really nice! > > -------- > David Maib > RV-10 #40559 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338315#338315 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Apr 28, 2011
Ted - several of your actions are Commendable. #1 you flew the aircraft to the landing site and walked away. The remaining builders and your underwriter should be appreciative. #2 You were willing to share and encourage other builders with the facts, when known. - Invaluable! #3 You removed your EFIS screens and took steps to protect the residual value of what looks like a repairable incident. Thank you. Several questions came immediately to mind after considering those actions. Condition of Aluminum fuel tubing, flares and fittings? Fire Annunciation & Suppression systems? What would or could have happened if the tunnel had been composite rather than aluminum? Smoke evacuation and hoods. All will come out in time. This incident is the second most valuable RV-10 incident since the loss of Dan Lloyd and much will be gained from the post incident review. What comes to my mind is I seem to remember Scott Schmidt (#40111) as the first builder to provide side access panels to reach/inspect to the maze of tubing and to service fuel filters. I reflect on DLM (#40168) and his Halon (non dry powder) onboard suppression system. I now reflect on the comment of lowering the inherent pressure in the tunnel and venting fumes/smoke to the outside atmosphere and will await the flap switch query. Your Picasso pictures are stunning! Glad your around to share. Your summation should be reviewed by all builders. No modification to the VANS system. Limiting fire damage is critical. Fuel shutoff worked, as advertized. Your prop strike damage was that to just the "now needed" engine teardown or did it migrate into your avionics? As a Tech Advisor, no one wants to hear from us how often we find flares on tubing incorrectly manufactured or improperly torqued (under and over). Many builders have not added the test of their "Shutoff Valve to cut engine operation" and confirm continued function at each conditional inspection. This drives that action home. I am thrilled that you are reporting and I look forward to more news of the landing gear mounts, legs and what you find. I am willing to kick-in $100 for a N718PF Chang Relief Fund, cause your data will be worth far more than that to current aviators, current builders, future builders and loved ones. If I could bring Dan back I would spend even more. Geoff can you weigh in on steps that can be applied to mitigate flame damage to a composite tunnel under similar circumstance? Lizard skin a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant topcoat chemical application? John #40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang Sent: Thursday, April 28, 2011 3:53 AM Subject: RV10-List: Fire and off field landing I thought I owe you, my fellow RV-10 builder some information. At this point the plane is still sitting in the field and I have been spending the time doing statements and answering inquiries from friends. Without opening the tunnel and cowling I can not say for sure what happened. Here are my observations: a. Fire was limited to the tunnel. b. It is a fuel leak inside the tunnel that fed into the fire. c. Fuel has been leaking some time before the fire started on this particular flight (based on the high fuel flow). Fuel flow was normal when I taxied out and on the take off. d. The smoke thinned out soon after I jettisoned the door. Although I still did not have much in-flight visibility, by the time the airplane stopped the cabin was almost cleared of smoke. e. There is no time to think. When my right leg felt warm I banked quickly and put it on the ground soon. f. After I turn off the fuel (it did shut off) there were still small fire but limited to inside the tunnel. g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in my baggage compartment to keep the CG in the limit (my W&B requirement). h. I have not calibrated my stall warning system. The buzzer goes off at around 60 kts. So, it was not a full stall landing. The field slopes up and I had a three point. i. Don't rely on emergency checklist. Remember the important steps and just do it. There is no time and visibility to find the checklist. Some facts: a. There is no modification on my fuel system. b. The door is still good except the area where bolts go through. It is the quickest way to get ride of the smoke and get visibility from the opening. c. The fire damage seems to be limited to around tunnel and firewall. I do have insulation inside the tunnel floor and up on firewall. d. Propeller strike and powder fire extinguisher from the fire department probably caused more damage than the fire. Ted ________________________________________________________________________________
Date: Apr 28, 2011
For what it's worth, I have a Halon bottle mounted on top of the console with the pin and handle in easy reach (right above the fuel pump). I took aviation consumer's advice some time ago and removed the dry powder one from my airplane (if you've ever discharged one of these in a small area, you'll understand!). I have a spring-loaded-closed, quarter-sized access hole in the tunnel cover. Connected to the Halon nozzle is a flexible, plastic hose that I can quickly stick the end through the hole and then squeeze the Halon handle discharging into the tunnel. grumpy N184JM On Apr 28, 2011, at 2:03 PM, John Cox wrote: > > Ted - several of your actions are Commendable. #1 you flew the aircraft > to the landing site and walked away. The remaining builders and your > underwriter should be appreciative. #2 You were willing to share and > encourage other builders with the facts, when known. - Invaluable! #3 > You removed your EFIS screens and took steps to protect the residual > value of what looks like a repairable incident. Thank you. > > Several questions came immediately to mind after considering those > actions. Condition of Aluminum fuel tubing, flares and fittings? Fire > Annunciation & Suppression systems? What would or could have happened > if the tunnel had been composite rather than aluminum? Smoke evacuation > and hoods. All will come out in time. This incident is the second most > valuable RV-10 incident since the loss of Dan Lloyd and much will be > gained from the post incident review. > > What comes to my mind is I seem to remember Scott Schmidt (#40111) as > the first builder to provide side access panels to reach/inspect to the > maze of tubing and to service fuel filters. I reflect on DLM (#40168) > and his Halon (non dry powder) onboard suppression system. I now > reflect on the comment of lowering the inherent pressure in the tunnel > and venting fumes/smoke to the outside atmosphere and will await the > flap switch query. Your Picasso pictures are stunning! Glad your around > to share. > > Your summation should be reviewed by all builders. > > No modification to the VANS system. > Limiting fire damage is critical. > Fuel shutoff worked, as advertized. > Your prop strike damage was that to just the "now needed" engine > teardown or did it migrate into your avionics? > > As a Tech Advisor, no one wants to hear from us how often we find flares > on tubing incorrectly manufactured or improperly torqued (under and > over). Many builders have not added the test of their "Shutoff Valve to > cut engine operation" and confirm continued function at each conditional > inspection. This drives that action home. I am thrilled that you are > reporting and I look forward to more news of the landing gear mounts, > legs and what you find. I am willing to kick-in $100 for a N718PF Chang > Relief Fund, cause your data will be worth far more than that to current > aviators, current builders, future builders and loved ones. If I could > bring Dan back I would spend even more. > > Geoff can you weigh in on steps that can be applied to mitigate flame > damage to a composite tunnel under similar circumstance? Lizard skin > a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant > topcoat chemical application? > > John > #40600 > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang > Sent: Thursday, April 28, 2011 3:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fire and off field landing > > > I thought I owe you, my fellow RV-10 builder some information. At this > point the plane is still sitting in the field and I have been spending > the time doing statements and answering inquiries from friends. Without > > opening the tunnel and cowling I can not say for sure what happened. > Here are my observations: > > a. Fire was limited to the tunnel. > b. It is a fuel leak inside the tunnel that fed into the fire. > c. Fuel has been leaking some time before the fire started on this > particular flight (based on the high fuel flow). Fuel flow was normal > when I taxied out and on the take off. > d. The smoke thinned out soon after I jettisoned the door. Although I > still did not have much in-flight visibility, by the time the airplane > stopped the cabin was almost cleared of smoke. > e. There is no time to think. When my right leg felt warm I banked > quickly and put it on the ground soon. > f. After I turn off the fuel (it did shut off) there were still small > fire but limited to inside the tunnel. > g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool > boxes in my baggage compartment to keep the CG in the limit (my W&B > requirement). > h. I have not calibrated my stall warning system. The buzzer goes off at > > around 60 kts. So, it was not a full stall landing. The field slopes up > and I had a three point. > i. Don't rely on emergency checklist. Remember the important steps and > just do it. There is no time and visibility to find the checklist. > > > Some facts: > > a. There is no modification on my fuel system. > b. The door is still good except the area where bolts go through. It is > the quickest way to get ride of the smoke and get visibility from the > opening. > c. The fire damage seems to be limited to around tunnel and firewall. I > do have insulation inside the tunnel floor and up on firewall. > d. Propeller strike and powder fire extinguisher from the fire > department probably caused more damage than the fire. > > Ted > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2011
Phil, Wow! the Andair pump is a much cleaner install. If mine goes bad I'm switching. Simpler plumbing and belly access look like winners to me. Fortunately, in 4 filter inspections to date I have never found anything in the filter. Before the belly access I always spilled a bit and left the tunnel open to air out for a few hours. Now, through the bottom, there's no problem and I inspect that area much more often. I did leave a tee fitting near the valve in case I wanted to add a purge valve later. Hot starts in hot country aren't always easy. From: Phillip Perry Here's how I attempted to tackle the filter access issue from above. I think it makes it quite a bit easier when getting everything aligned. http://www.youtube.com/watch?v=x3mpcapeBA8 Phil ________________________________________________________________________________
Subject: Second fire in RV10 to date
Date: Apr 28, 2011
It took about one day to decide to order this product and another two hours to install it. It is a no brainer. http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?productI d=30673&catalogId=10001&langId=-1&storeId=11151&storeNum=10107&su bdeptNum=10534&classNum=10535 The alarm is load as hell even with a headset on and an engine running. The key point=2C the alarm sounds before the fire happens! JOhn ________________________________________________________________________________
Subject: Re: Second fire in RV10 to date
Date: Apr 28, 2011
Ordered portable made by UEI today. $179+shpg. Mod cd200. I already have two smoke hoods. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338349#338349 ________________________________________________________________________________
Date: Apr 28, 2011
I am considering using the unused port on my Halon bottle to plumb a line into the tunnel. WE are still discussing the Halon discharge in the cabin as the tunnel has some big holes to cabin. ----- Original Message ----- From: "Miller John" <gengrumpy(at)aol.com> Sent: Thursday, April 28, 2011 12:17 PM Subject: Re: RV10-List: Fire and off field landing > > For what it's worth, I have a Halon bottle mounted on top of the console > with the pin and handle in easy reach (right above the fuel pump). > > I took aviation consumer's advice some time ago and removed the dry powder > one from my airplane (if you've ever discharged one of these in a small > area, you'll understand!). > > I have a spring-loaded-closed, quarter-sized access hole in the tunnel > cover. > > Connected to the Halon nozzle is a flexible, plastic hose that I can > quickly stick the end through the hole and then squeeze the Halon handle > discharging into the tunnel. > > grumpy > N184JM > > On Apr 28, 2011, at 2:03 PM, John Cox wrote: > >> >> Ted - several of your actions are Commendable. #1 you flew the aircraft >> to the landing site and walked away. The remaining builders and your >> underwriter should be appreciative. #2 You were willing to share and >> encourage other builders with the facts, when known. - Invaluable! #3 >> You removed your EFIS screens and took steps to protect the residual >> value of what looks like a repairable incident. Thank you. >> >> Several questions came immediately to mind after considering those >> actions. Condition of Aluminum fuel tubing, flares and fittings? Fire >> Annunciation & Suppression systems? What would or could have happened >> if the tunnel had been composite rather than aluminum? Smoke evacuation >> and hoods. All will come out in time. This incident is the second most >> valuable RV-10 incident since the loss of Dan Lloyd and much will be >> gained from the post incident review. >> >> What comes to my mind is I seem to remember Scott Schmidt (#40111) as >> the first builder to provide side access panels to reach/inspect to the >> maze of tubing and to service fuel filters. I reflect on DLM (#40168) >> and his Halon (non dry powder) onboard suppression system. I now >> reflect on the comment of lowering the inherent pressure in the tunnel >> and venting fumes/smoke to the outside atmosphere and will await the >> flap switch query. Your Picasso pictures are stunning! Glad your around >> to share. >> >> Your summation should be reviewed by all builders. >> >> No modification to the VANS system. >> Limiting fire damage is critical. >> Fuel shutoff worked, as advertized. >> Your prop strike damage was that to just the "now needed" engine >> teardown or did it migrate into your avionics? >> >> As a Tech Advisor, no one wants to hear from us how often we find flares >> on tubing incorrectly manufactured or improperly torqued (under and >> over). Many builders have not added the test of their "Shutoff Valve to >> cut engine operation" and confirm continued function at each conditional >> inspection. This drives that action home. I am thrilled that you are >> reporting and I look forward to more news of the landing gear mounts, >> legs and what you find. I am willing to kick-in $100 for a N718PF Chang >> Relief Fund, cause your data will be worth far more than that to current >> aviators, current builders, future builders and loved ones. If I could >> bring Dan back I would spend even more. >> >> Geoff can you weigh in on steps that can be applied to mitigate flame >> damage to a composite tunnel under similar circumstance? Lizard skin >> a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant >> topcoat chemical application? >> >> John >> #40600 >> >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang >> Sent: Thursday, April 28, 2011 3:53 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Fire and off field landing >> >> >> I thought I owe you, my fellow RV-10 builder some information. At this >> point the plane is still sitting in the field and I have been spending >> the time doing statements and answering inquiries from friends. Without >> >> opening the tunnel and cowling I can not say for sure what happened. >> Here are my observations: >> >> a. Fire was limited to the tunnel. >> b. It is a fuel leak inside the tunnel that fed into the fire. >> c. Fuel has been leaking some time before the fire started on this >> particular flight (based on the high fuel flow). Fuel flow was normal >> when I taxied out and on the take off. >> d. The smoke thinned out soon after I jettisoned the door. Although I >> still did not have much in-flight visibility, by the time the airplane >> stopped the cabin was almost cleared of smoke. >> e. There is no time to think. When my right leg felt warm I banked >> quickly and put it on the ground soon. >> f. After I turn off the fuel (it did shut off) there were still small >> fire but limited to inside the tunnel. >> g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool >> boxes in my baggage compartment to keep the CG in the limit (my W&B >> requirement). >> h. I have not calibrated my stall warning system. The buzzer goes off at >> >> around 60 kts. So, it was not a full stall landing. The field slopes up >> and I had a three point. >> i. Don't rely on emergency checklist. Remember the important steps and >> just do it. There is no time and visibility to find the checklist. >> >> >> Some facts: >> >> a. There is no modification on my fuel system. >> b. The door is still good except the area where bolts go through. It is >> the quickest way to get ride of the smoke and get visibility from the >> opening. >> c. The fire damage seems to be limited to around tunnel and firewall. I >> do have insulation inside the tunnel floor and up on firewall. >> d. Propeller strike and powder fire extinguisher from the fire >> department probably caused more damage than the fire. >> >> Ted >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Apr 28, 2011
Can someone post a link to the picassa photos? Shannon On Thu, Apr 28, 2011 at 2:17 PM, Miller John wrote: > > For what it's worth, I have a Halon bottle mounted on top of the console > with the pin and handle in easy reach (right above the fuel pump). > > I took aviation consumer's advice some time ago and removed the dry powder > one from my airplane (if you've ever discharged one of these in a small > area, you'll understand!). > > I have a spring-loaded-closed, quarter-sized access hole in the tunnel > cover. > > Connected to the Halon nozzle is a flexible, plastic hose that I can > quickly stick the end through the hole and then squeeze the Halon handle > discharging into the tunnel. > > grumpy > N184JM > > On Apr 28, 2011, at 2:03 PM, John Cox wrote: > > > > > Ted - several of your actions are Commendable. #1 you flew the aircraft > > to the landing site and walked away. The remaining builders and your > > underwriter should be appreciative. #2 You were willing to share and > > encourage other builders with the facts, when known. - Invaluable! #3 > > You removed your EFIS screens and took steps to protect the residual > > value of what looks like a repairable incident. Thank you. > > > > Several questions came immediately to mind after considering those > > actions. Condition of Aluminum fuel tubing, flares and fittings? Fire > > Annunciation & Suppression systems? What would or could have happened > > if the tunnel had been composite rather than aluminum? Smoke evacuation > > and hoods. All will come out in time. This incident is the second most > > valuable RV-10 incident since the loss of Dan Lloyd and much will be > > gained from the post incident review. > > > > What comes to my mind is I seem to remember Scott Schmidt (#40111) as > > the first builder to provide side access panels to reach/inspect to the > > maze of tubing and to service fuel filters. I reflect on DLM (#40168) > > and his Halon (non dry powder) onboard suppression system. I now > > reflect on the comment of lowering the inherent pressure in the tunnel > > and venting fumes/smoke to the outside atmosphere and will await the > > flap switch query. Your Picasso pictures are stunning! Glad your around > > to share. > > > > Your summation should be reviewed by all builders. > > > > No modification to the VANS system. > > Limiting fire damage is critical. > > Fuel shutoff worked, as advertized. > > Your prop strike damage was that to just the "now needed" engine > > teardown or did it migrate into your avionics? > > > > As a Tech Advisor, no one wants to hear from us how often we find flares > > on tubing incorrectly manufactured or improperly torqued (under and > > over). Many builders have not added the test of their "Shutoff Valve to > > cut engine operation" and confirm continued function at each conditional > > inspection. This drives that action home. I am thrilled that you are > > reporting and I look forward to more news of the landing gear mounts, > > legs and what you find. I am willing to kick-in $100 for a N718PF Chang > > Relief Fund, cause your data will be worth far more than that to current > > aviators, current builders, future builders and loved ones. If I could > > bring Dan back I would spend even more. > > > > Geoff can you weigh in on steps that can be applied to mitigate flame > > damage to a composite tunnel under similar circumstance? Lizard skin > > a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant > > topcoat chemical application? > > > > John > > #40600 > > > > > > > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang > > Sent: Thursday, April 28, 2011 3:53 AM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Fire and off field landing > > > > > > I thought I owe you, my fellow RV-10 builder some information. At this > > point the plane is still sitting in the field and I have been spending > > the time doing statements and answering inquiries from friends. Without > > > > opening the tunnel and cowling I can not say for sure what happened. > > Here are my observations: > > > > a. Fire was limited to the tunnel. > > b. It is a fuel leak inside the tunnel that fed into the fire. > > c. Fuel has been leaking some time before the fire started on this > > particular flight (based on the high fuel flow). Fuel flow was normal > > when I taxied out and on the take off. > > d. The smoke thinned out soon after I jettisoned the door. Although I > > still did not have much in-flight visibility, by the time the airplane > > stopped the cabin was almost cleared of smoke. > > e. There is no time to think. When my right leg felt warm I banked > > quickly and put it on the ground soon. > > f. After I turn off the fuel (it did shut off) there were still small > > fire but limited to inside the tunnel. > > g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool > > boxes in my baggage compartment to keep the CG in the limit (my W&B > > requirement). > > h. I have not calibrated my stall warning system. The buzzer goes off at > > > > around 60 kts. So, it was not a full stall landing. The field slopes up > > and I had a three point. > > i. Don't rely on emergency checklist. Remember the important steps and > > just do it. There is no time and visibility to find the checklist. > > > > > > Some facts: > > > > a. There is no modification on my fuel system. > > b. The door is still good except the area where bolts go through. It is > > the quickest way to get ride of the smoke and get visibility from the > > opening. > > c. The fire damage seems to be limited to around tunnel and firewall. I > > do have insulation inside the tunnel floor and up on firewall. > > d. Propeller strike and powder fire extinguisher from the fire > > department probably caused more damage than the fire. > > > > Ted > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2011
Would someone mind posting a link to the picassa photos? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338351#338351 ________________________________________________________________________________
Subject: Using Matronics Site
Date: Apr 28, 2011
I am new to this site and am having some issues using it properly. I have signed up to get messages via email and that seems to be working just fine. The problem is that I have replied, via email, to some of them, but they never get posted on here or get sent out to the list. Am I doing something wrong or are you only able to reply via the website? Thanks in advance Shannon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338352#338352 ________________________________________________________________________________
Subject: Re: Garmin XM weather
Date: Apr 28, 2011
When I called Garmin tech support yesterday, the prerecorded message stated that the update was NOT mandatory for 696 users. BTW, I complained about the price of the updates in relation to the cost of just purchasing an IPAD and using foreflight and they gave me a 50% discount code for the yearly subscription! Shannon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338355#338355 ________________________________________________________________________________
Date: Apr 28, 2011
https://picasaweb.google.com/tc1234c/4272011RV10Accident?authkey=Gv1sRgCPjmtviSyuKsQg# ----- Original Message ----- From: Shannon Hicks <civeng123(at)gmail.com> To: Cc: Date: Thursday, April 28 2011 04:27 PM Subject: Re: RV10-List: Fire and off field landing Can someone post a link to the picassa photos? Shannon On Thu, Apr 28, 2011 at 2:17 PM, Miller John wrote: For what it's worth, I have a Halon bottle mounted on top of the console with the pin and handle in easy reach (right above the fuel pump). I took aviation consumer's advice some time ago and removed the dry powder one from my airplane (if you've ever discharged one of these in a small area, you'll understand!). I have a spring-loaded-closed, quarter-sized access hole in the tunnel cover. Connected to the Halon nozzle is a flexible, plastic hose that I can quickly stick the end through the hole and then squeeze the Halon handle discharging into the tunnel. grumpy N184JM On Apr 28, 2011, at 2:03 PM, John Cox wrote: > > Ted - several of your actions are Commendable. #1 you flew the aircraft > to the landing site and walked away. The remaining builders and your > underwriter should be appreciative. #2 You were willing to share and > encourage other builders with the facts, when known. - Invaluable! #3 > You removed your EFIS screens and took steps to protect the residual > value of what looks like a repairable incident. Thank you. > > Several questions came immediately to mind after considering those > actions. Condition of Aluminum fuel tubing, flares and fittings? Fire > Annunciation & Suppression systems? What would or could have happened > if the tunnel had been composite rather than aluminum? Smoke evacuation > and hoods. All will come out in time. This incident is the second most > valuable RV-10 incident since the loss of Dan Lloyd and much will be > gained from the post incident review. > > What comes to my mind is I seem to remember Scott Schmidt (#40111) as > the first builder to provide side access panels to reach/inspect to the > maze of tubing and to service fuel filters. I reflect on DLM (#40168) > and his Halon (non dry powder) onboard suppression system. I now > reflect on the comment of lowering the inherent pressure in the tunnel > and venting fumes/smoke to the outside atmosphere and will await the > flap switch query. Your Picasso pictures are stunning! Glad your around > to share. > > Your summation should be reviewed by all builders. > > No modification to the VANS system. > Limiting fire damage is critical. > Fuel shutoff worked, as advertized. > Your prop strike damage was that to just the "now needed" engine > teardown or did it migrate into your avionics? > > As a Tech Advisor, no one wants to hear from us how often we find flares > on tubing incorrectly manufactured or improperly torqued (under and > over). Many builders have not added the test of their "Shutoff Valve to > cut engine operation" and confirm continued function at each conditional > inspection. This drives that action home. I am thrilled that you are > reporting and I look forward to more news of the landing gear mounts, > legs and what you find. I am willing to kick-in $100 for a N718PF Chang > Relief Fund, cause your data will be worth far more than that to current > aviators, current builders, future builders and loved ones. If I could > bring Dan back I would spend even more. > > Geoff can you weigh in on steps that can be applied to mitigate flame > damage to a composite tunnel under similar circumstance? Lizard skin > a.k.a. Johnston (#40410) or Zetex heat shield batting or flame-resistant > topcoat chemical application? > > John > #40600 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted Chang > Sent: Thursday, April 28, 2011 3:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fire and off field landing > > > I thought I owe you, my fellow RV-10 builder some information. At this > point the plane is still sitting in the field and I have been spending > the time doing statements and answering inquiries from friends. Without > > opening the tunnel and cowling I can not say for sure what happened. > Here are my observations: > > a. Fire was limited to the tunnel. > b. It is a fuel leak inside the tunnel that fed into the fire. > c. Fuel has been leaking some time before the fire started on this > particular flight (based on the high fuel flow). Fuel flow was normal > when I taxied out and on the take off. > d. The smoke thinned out soon after I jettisoned the door. Although I > still did not have much in-flight visibility, by the time the airplane > stopped the cabin was almost cleared of smoke. > e. There is no time to think. When my right leg felt warm I banked > quickly and put it on the ground soon. > f. After I turn off the fuel (it did shut off) there were still small > fire but limited to inside the tunnel. > g. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool > boxes in my baggage compartment to keep the CG in the limit (my W&B > requirement). > h. I have not calibrated my stall warning system. The buzzer goes off at > > around 60 kts. So, it was not a full stall landing. The field slopes up > and I had a three point. > i. Don't rely on emergency checklist. Remember the important steps and > just do it. There is no time and visibility to find the checklist. > > > Some facts: > > a. There is no modification on my fuel system. > b. The door is still good except the area where bolts go through. It is > the quickest way to get ride of the smoke and get visibility from the > opening. > c. The fire damage seems to be limited to around tunnel and firewall. I > do have insulation inside the tunnel floor and up on firewall. > d. Propeller strike and powder fire extinguisher from the fire > department probably caused more damage than the fire. > > Ted > > ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Apr 28, 2011
Subject: Re: Using Matronics Site
At 01:14 PM 4/28/2011 Thursday, civengpe wrote: > >I am new to this site and am having some issues using it properly. I have signed up to get messages via email and that seems to be working just fine. The problem is that I have replied, via email, to some of them, but they never get posted on here or get sent out to the list. Am I doing something wrong or are you only able to reply via the website? > > >Thanks in advance >Shannon Hi Shannon, Welcome to the group! You should be able to just do a normal email "Reply" to any message you receive from the RV10-List and it will automatically go back to the whole List. Make sure that your email client is sending the replies to "rv10-list(at)matronics.com" and not just the originator of the given post. I checked the spam filter and didn't see that your email address had been blocked for any reason. Matt - Matt "Fox" Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Paint job is all that's left... ________________________________________________________________________________
Date: Apr 28, 2011
Yeah, it is very simple and very clean. Almost too simple. I keep waiting on someone who knows more than I do to say I missed something , but that hasn't occurred yet. I do like the combo assembly and the engine ering of the Andair pump vs AFP's (not that there is anything wrong with AFP ). Besides the recirculation feature, the Andair does not use vanes and ther efore won't wear like the AFP. Instead it uses a series of expanding cavit ies to create a siphon effect that moves fuel through it. I like the setup a lot but I don't know what I don't know. Hopefully there i s no obvious fuctionality missing from the system or any additional liabilit y I created in the process. I am a believer that fewer fittings and less pl umbing equates to a safer and more reliable system. Phil On Apr 28, 2011, at 2:25 PM, "Albert Gardner" wrote: > Phil, Wow! the Andair pump is a much cleaner install. If mine goes bad I =99m switching. Simpler plumbing and belly access look like winners to me . Fortunately, in 4 filter inspections to date I have never found anything i n the filter. Before the belly access I always spilled a bit and left the tu nnel open to air out for a few hours. Now, through the bottom, there=99 s no problem and I inspect that area much more often. > > I did leave a tee fitting near the valve in case I wanted to add a purge v alve later. Hot starts in hot country aren=99t always easy. > > > > From: Phillip Perry > > Here's how I attempted to tackle the filter access issue from above. I th ink it makes it quite a bit easier when getting everything aligned. > http://www.youtube.com/watch?v=x3mpcapeBA8 > Phil > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 28, 2011
Subject: West Coast Formation Clinic (WCFC) This Weekend...
Any listers planning on attending the WCFC this weekend in Madera California? I'm planning on being there with the 'ol RV-8. Come up and say 'hi' and introduce yourself; I'd love to meet some of the Listers in person! - Matt "Fox" Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's RV-8 Construction Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Paint job is all that's left... ________________________________________________________________________________
Date: Apr 28, 2011
One great solution. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez Sent: Thursday, April 28, 2011 12:29 PM Subject: RV10-List: Second fire in RV10 to date It took about one day to decide to order this product and another two hours to install it. It is a no brainer. http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?produ ctId=30673&catalogId=10001&langId=-1&storeId=11151&storeNum=101 07&subdep tNum=10534&classNum=10535 The alarm is load as hell even with a headset on and an engine running. The key point, the alarm sounds before the fire happens! JOhn ________________________________________________________________________________
Subject: Fire and off field landing
Date: Apr 28, 2011
I was! At work, we use Halon under high pressure nitrogen in a s.steel accumulator bottle along with a squib. Your system could be quite effective if directed to the most logical area around the fuel filter and shutoff valve. Just pull the valve, no squib to worry about. Heat rises so I am interested in steps which could be taken to provide additional temperature protection to a composite cover. The one Picasso shot Img. 1882 gives clarity to a "Sense of Urgency" with a hot seat. There have been other posts on hydrocarbon sensors to alert when a combustible source is sensed, temperature is rising above an established threshold or other indicators. It was great that Ted responded quickly and accurately to getting the aircraft on the ground. "When the engine stops, the aircraft is on fire, or a medical emergency requires immediate action, the obligation of the pilot is to get the aircraft on the ground." Think of it as becoming immediately the underwriter's aircraft. The pilots job is to be around to settle the claim at a successful conclusion. A friend was lost 5 years ago leaving OSH while attempting solutions "in-flight" and conscientiously passing over 8 perfectly good airports. He made it up to the point of touchdown in Madison, WI. Kudos to Ted regardless of what is going to be found as the cause. Fire Annunciation? Fire Suppression? Pilot Skill? We should all be discussing the various solutions and pursue enhanced pilot training like LOBO. John C. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Thursday, April 28, 2011 1:02 PM Subject: Re: RV10-List: Fire and off field landing I am considering using the unused port on my Halon bottle to plumb a line into the tunnel. WE are still discussing the Halon discharge in the cabin as the tunnel has some big holes to cabin. ________________________________________________________________________________
Date: Apr 28, 2011
A product called " Pig Mat" is an absorbent material which can be placed under the valve before servicing. Less fumes to evacuate. Just through it outside, in the trash, away from a combustible structure. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner Sent: Thursday, April 28, 2011 12:26 PM Subject: RE: RV10-List: Re: Tunnel Access From Below Phil, Wow! the Andair pump is a much cleaner install. If mine goes bad I'm switching. Simpler plumbing and belly access look like winners to me. Fortunately, in 4 filter inspections to date I have never found anything in the filter. Before the belly access I always spilled a bit and left the tunnel open to air out for a few hours. Now, through the bottom, there's no problem and I inspect that area much more often. I did leave a tee fitting near the valve in case I wanted to add a purge valve later. Hot starts in hot country aren't always easy. From: Phillip Perry Here's how I attempted to tackle the filter access issue from above. I think it makes it quite a bit easier when getting everything aligned. http://www.youtube.com/watch?v=x3mpcapeBA8 Phil ________________________________________________________________________________
Date: Apr 28, 2011
The one thing I heard in the video was that pump was for the o-360. So the Question is how much fuel will it pump? Patrick Thyssen N15PT --- On Thu, 4/28/11, Phil Perry wrote: From: Phil Perry <philperry9(at)gmail.com> Subject: Re: RV10-List: Re: Tunnel Access From Below Date: Thursday, April 28, 2011, 4:03 PM Yeah, it is very simple and very clean. =C2-Almost too simple. I keep waiting on someone who knows more than I do to say I missed somethin g, but that hasn't occurred yet. =C2-I do like the combo assembly and the engineering of the Andair pump vs AFP's (not that there is anything wrong with AFP). Besides the recirculation feature, the Andair does not use vanes and therefore won't wear like the AFP. =C2- Instead it uses a series of expanding cavities to create a siphon effect that moves fuel through it. I like the setup a lot but I don't know what I don't know. =C2-Hopefully there is no obvious fuctionality missing from the system or any additional liability I created in the process. =C2-I am a believer that fewer fittin gs and less plumbing equates to a safer and more reliable system. Phil On Apr 28, 2011, at 2:25 PM, "Albert Gardner" wrote : Phil, Wow! the Andair pump is a much cleaner install. If mine goes bad I =99m switching. Simpler plumbing and belly access look like winners to m e. Fortunately, =C2-in 4 filter inspections to date I have never found an ything in the filter. Before the belly access I always spilled a bit and le ft the tunnel open to air out for a few hours. Now, through the bottom, the re=99s no problem and I inspect that area much more often.I did leave a tee fitting near the valve in case I wanted to add a purge valve later. Hot starts in hot country aren=99t always easy. =C2-From: Phillip P erryHere's how I attempted to tackle the filter access issue from above.=C2 - I think it makes it quite a bit easier when getting everything aligned. http://www.youtube.com/watch?v=x3mpcapeBA8 Phil =C2- =0A=0A=0A ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.c om/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contributio n ========= =0A ________________________________________________________________________________
Date: Apr 28, 2011
Subject: Re: Fire and off field landing
Good write up Ted. Glad your OK and sorry it happened. Good Luck=0A=0A=0A =0A=0A________________________________=0AFrom: Ted Chang <tc1234c@roadrunne r.com>=0ATo: rv10-list(at)matronics.com=0ASent: Thu, April 28, 2011 3:53:00 AM =0ASubject: RV10-List: Fire and off field landing=0A=0A--> RV10-List messag e posted by: Ted Chang =0A=0AI thought I owe you, m y fellow RV-10 builder some information. At this point the =0Aplane is stil l sitting in the field and I have been spending the time doing =0Astatement s and answering inquiries from friends.- Without opening the tunnel and =0Acowling I can not say for sure what happened.- Here are my observation s:=0A=0Aa. Fire was limited to the tunnel.=0Ab. It is a fuel leak inside th e tunnel that fed into the fire.=0Ac. Fuel has been leaking some time befor e the fire started on this particular =0Aflight (based on the high fuel flo w). Fuel flow was normal when I taxied out and =0Aon the take off.=0Ad. The smoke thinned out soon after I jettisoned the door. Although I still did =0Anot have much in-flight visibility, by the time the airplane stopped the cabin =0Awas almost cleared of smoke.=0Ae. There is no time to think. When my right leg felt warm I banked quickly and =0Aput it on the ground soon. =0Af.- After I turn off the fuel (it did shut off) there were still small fire but =0Alimited to inside the tunnel.=0Ag. Dead stick is very hard to do. RV-10 is nose heavy. I put two tool boxes in =0Amy baggage compartment to keep the CG in the limit (my W&B requirement).=0Ah. I have not calibrate d my stall warning system. The buzzer goes off at around =0A60 kts. So, it was not a full stall landing. The field slopes up and I had a =0Athree poin t.=0Ai. Don't rely on emergency checklist. Remember the important steps and just do =0Ait. There is no time and visibility to find the checklist.=0A =0A=0ASome facts:=0A=0Aa. There is no modification on my fuel system.=0Ab. The door is still good except the area where bolts go through. It is the =0Aquickest way to get ride of the smoke and get visibility from the openin g.=0Ac. The fire damage seems to be limited to around tunnel and firewall. I do have =0Ainsulation inside the tunnel floor and up on firewall.=0Ad. Pr opeller strike and powder fire extinguisher from the fire department =0Apro bably caused more damage than the fire.=0A=0A=0AI have to admit that for a few seconds when the smoke came out and my leg felt =0Athe heat I had a tho ught that I was in deep trouble (burn to death). I quickly =0Afocused on th e tasks in front of me and tried to fly the airplane and solve the =0Aprobl ems I was facing. From that point on there was no fear or regret.- After I =0Acalled 911 and my insurance agent I got to walk down the hill, wait an d think. =0AMy only negative thought was that my accident might negatively impact a lot of =0Abuilders. I don't want to see anyone get disencouraged. I am pretty sure that =0Awhat happened to me is not a design flaw, but a bu ilder mistake. After I found =0Athe problem I will share with you so you ca ======================== ________________________________________________________________________________
Date: Apr 28, 2011
Pat, Here is a thread that discusses it and includes Andair's response. http://www.vansairforce.com/community/showthread.php?t=63129 It's actually more of a function of line size and pressure relief valve cali bration according to those who engineer this stuff. Phil On Apr 28, 2011, at 5:58 PM, Patrick Thyssen wrote: > The one thing I heard in the video was that pump was for the o-360. So the Question is how much fuel will it pump? > Patrick Thyssen > N15PT > > --- On Thu, 4/28/11, Phil Perry wrote: > > From: Phil Perry <philperry9(at)gmail.com> > Subject: Re: RV10-List: Re: Tunnel Access =46rom Below > To: "rv10-list(at)matronics.com" > Date: Thursday, April 28, 2011, 4:03 PM > > Yeah, it is very simple and very clean. Almost too simple. > > I keep waiting on someone who knows more than I do to say I missed somethi ng, but that hasn't occurred yet. I do like the combo assembly and the engi neering of the Andair pump vs AFP's (not that there is anything wrong with A FP). Besides the recirculation feature, the Andair does not use vanes and th erefore won't wear like the AFP. Instead it uses a series of expanding cav ities to create a siphon effect that moves fuel through it. > > I like the setup a lot but I don't know what I don't know. Hopefully ther e is no obvious fuctionality missing from the system or any additional liabi lity I created in the process. I am a believer that fewer fittings and less plumbing equates to a safer and more reliable system. > > Phil > > > > > > > > On Apr 28, 2011, at 2:25 PM, "Albert Gardner" wrot e: > >> Phil, Wow! the Andair pump is a much cleaner install. If mine goes bad I =99m switching. Simpler plumbing and belly access look like winners to me . Fortunately, in 4 filter inspections to date I have never found anything i n the filter. Before the belly access I always spilled a bit and left the tu nnel open to air out for a few hours. Now, through the bottom, there=99 s no problem and I inspect that area much more often. >> >> I did leave a tee fitting near the valve in case I wanted to add a purge v alve later. Hot starts in hot country aren=99t always easy. >> >> >> >> From: Phillip Perry >> >> Here's how I attempted to tackle the filter access issue from above. I t hink it makes it quite a bit easier when getting everything aligned. >> http://www.youtube.com/watch?v=x3mpcapeBA8 >> Phil >> >> >> >> >> >> >> ========= >> ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List >> ========= >> ums.matronics.com">http://forums.matronics.com >> ========= >> http://www.matronics.com/contribution">http://www.matronics.com/contribut ion >> ========================= ========= >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 28, 2011
I got the airplane back to the hangar and took a look into the engine compartment. Now I am pretty sure the cause of the fire is a loose fuel line b-nut on the mechanical fuel pump. It is entirely my mistake. So, my follow builders, make sure all your nuts and fittings are tightened. You don't need to worry about the fire problem I experienced. A few observations to follow: a. The fuel flow down and under the tunnel. I did not know when the fire started since it was burning underneath. b. After the fire burnt through the tunnel floor, it sent up some smoke smell. c. Soon brake line and fuel line melted and the brake fluid produced a lot of smoke. d. After brake fluid was consumed there were little smoke. e. Fire did burn up around the mechanical fuel pump and up around left mag. Wire bundle attached to the engine mount on top the mag is charred. f. Fire did not burn through the aluminum heat boxes. The sealant on top of the heat boxes are gone but not the ones around them. g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier sealant for firewall penetration. None of them get compromised. h. I brought firewall insulator but have not installed yet. It would not do anything for this particular case. i. The insulator on the tunnel floor can not withstand the fire. Most of them are gone with the floor. j. Nose gear link (WD1016) folded and the rest of the nose gear are in good shape. ________________________________________________________________________________
Date: Apr 28, 2011
Ted, Thanks for the report. Any idea what sparked the fuel? I'd like to figure out what the ignition source is. Phil On Apr 28, 2011, at 6:55 PM, Ted Chang wrote: > > I got the airplane back to the hangar and took a look into the engine compartment. Now I am pretty sure the cause of the fire is a loose fuel line b-nut on the mechanical fuel pump. It is entirely my mistake. So, my follow builders, make sure all your nuts and fittings are tightened. You don't need to worry about the fire problem I experienced. A few observations to follow: > > a. The fuel flow down and under the tunnel. I did not know when the fire started since it was burning underneath. > b. After the fire burnt through the tunnel floor, it sent up some smoke smell. > c. Soon brake line and fuel line melted and the brake fluid produced a lot of smoke. > d. After brake fluid was consumed there were little smoke. > e. Fire did burn up around the mechanical fuel pump and up around left mag. Wire bundle attached to the engine mount on top the mag is charred. > f. Fire did not burn through the aluminum heat boxes. The sealant on top of the heat boxes are gone but not the ones around them. > g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier sealant for firewall penetration. None of them get compromised. > h. I brought firewall insulator but have not installed yet. It would not do anything for this particular case. > i. The insulator on the tunnel floor can not withstand the fire. Most of them are gone with the floor. > j. Nose gear link (WD1016) folded and the rest of the nose gear are in good shape. > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2011
Awesome data gathering Ted. Thanks so much for the follow-up. When I do a final assembly I use the yellow torque seal on the hardware. If it's missing, I know I've not tightened it down. Back when I was a baby pilot, I bought the Grumman AA-1B I got my ticket in. I took it back to the FBO I bought it from and they did the 'first' annual ..... just before the fly-in at Lakeland FL (which started Sun-n-Fun the next year). I started up to leave and I noticed a handfull of folks running around giving me the 'cut off' sign. I shut down and climbed out to find that they saw fluid spraying out from under the cowl. When the FBO did the annual, the A&P pulled the B nut off the inlet to the electric fuel pump to check and clean the screen. It went back on finger tight, if that. I flew about 100 miles all total before the problem was discovered. My Angels were at work. And that's the last annual anyone else wrenched on my planes. I do all the owner-assisted annuals and fix the squawks. MY A&P/IA does the paperwork. Is the airframe undamaged?? Just gear and door??? Linn On 4/28/2011 7:55 PM, Ted Chang wrote: > > I got the airplane back to the hangar and took a look into the engine > compartment. Now I am pretty sure the cause of the fire is a loose > fuel line b-nut on the mechanical fuel pump. It is entirely my > mistake. So, my follow builders, make sure all your nuts and fittings > are tightened. You don't need to worry about the fire problem I > experienced. A few observations to follow: > > a. The fuel flow down and under the tunnel. I did not know when the > fire started since it was burning underneath. > b. After the fire burnt through the tunnel floor, it sent up some > smoke smell. > c. Soon brake line and fuel line melted and the brake fluid produced a > lot of smoke. > d. After brake fluid was consumed there were little smoke. > e. Fire did burn up around the mechanical fuel pump and up around left > mag. Wire bundle attached to the engine mount on top the mag is charred. > f. Fire did not burn through the aluminum heat boxes. The sealant on > top of the heat boxes are gone but not the ones around them. > g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier > sealant for firewall penetration. None of them get compromised. > h. I brought firewall insulator but have not installed yet. It would > not do anything for this particular case. > i. The insulator on the tunnel floor can not withstand the fire. Most > of them are gone with the floor. > j. Nose gear link (WD1016) folded and the rest of the nose gear are in > good shape. > > ________________________________________________________________________________
Date: Apr 28, 2011
Just a guess but the mechanical pump is right above the hot exhaust, by not that great a distance. Thanks Ted, it's been informational! Glad you made it out fine. I had a fuel fitting that was loose too, before first start, due to last minute hose removal post-nut-check. It was on the fuel servo. Luckily I did a boost pump fuel pressure test and found the dripping before I fired it up. Even though I used torque seal all over on bolts, I think if for no other reason, it would be worth doing it on the tunnel and fuel lines just to ensure that you mark them after they are torqued. Could help prevent this type of failure. I think I'll plan to do that next time I pull a fuel line. Tim On Apr 28, 2011, at 7:24 PM, Phil Perry wrote: > > Ted, > > Thanks for the report. Any idea what sparked the fuel? I'd like to figure out what the ignition source is. > > Phil > > > > On Apr 28, 2011, at 6:55 PM, Ted Chang wrote: > >> >> I got the airplane back to the hangar and took a look into the engine compartment. Now I am pretty sure the cause of the fire is a loose fuel line b-nut on the mechanical fuel pump. It is entirely my mistake. So, my follow builders, make sure all your nuts and fittings are tightened. You don't need to worry about the fire problem I experienced. A few observations to follow: >> >> a. The fuel flow down and under the tunnel. I did not know when the fire started since it was burning underneath. >> b. After the fire burnt through the tunnel floor, it sent up some smoke smell. >> c. Soon brake line and fuel line melted and the brake fluid produced a lot of smoke. >> d. After brake fluid was consumed there were little smoke. >> e. Fire did burn up around the mechanical fuel pump and up around left mag. Wire bundle attached to the engine mount on top the mag is charred. >> f. Fire did not burn through the aluminum heat boxes. The sealant on top of the heat boxes are gone but not the ones around them. >> g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier sealant for firewall penetration. None of them get compromised. >> h. I brought firewall insulator but have not installed yet. It would not do anything for this particular case. >> i. The insulator on the tunnel floor can not withstand the fire. Most of them are gone with the floor. >> j. Nose gear link (WD1016) folded and the rest of the nose gear are in good shape. >> >> >> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 28, 2011
which flight was the accident flight? how many hours into Phase I? ----- Original Message ----- From: "Ted Chang" <tc1234c(at)roadrunner.com> Sent: Thursday, April 28, 2011 4:55 PM Subject: RV10-List: Re: Fire and off field landing > > I got the airplane back to the hangar and took a look into the engine > compartment. Now I am pretty sure the cause of the fire is a loose fuel > line b-nut on the mechanical fuel pump. It is entirely my mistake. So, > my follow builders, make sure all your nuts and fittings are tightened. > You don't need to worry about the fire problem I experienced. A few > observations to follow: > > a. The fuel flow down and under the tunnel. I did not know when the fire > started since it was burning underneath. > b. After the fire burnt through the tunnel floor, it sent up some smoke > smell. > c. Soon brake line and fuel line melted and the brake fluid produced a > lot of smoke. > d. After brake fluid was consumed there were little smoke. > e. Fire did burn up around the mechanical fuel pump and up around left > mag. Wire bundle attached to the engine mount on top the mag is charred. > f. Fire did not burn through the aluminum heat boxes. The sealant on top > of the heat boxes are gone but not the ones around them. > g. I used plastic bushing, RTV, then a thick coat of 3M fire barrier > sealant for firewall penetration. None of them get compromised. > h. I brought firewall insulator but have not installed yet. It would not > do anything for this particular case. > i. The insulator on the tunnel floor can not withstand the fire. Most of > them are gone with the floor. > j. Nose gear link (WD1016) folded and the rest of the nose gear are in > good shape. > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2011
I just log on and read some of your comments. Here are answers to a few questions. The accident flight was my sixth flight and 8th time running the engine. I estimated that I had 1.2 min from the time I noticed the smoke to a sharp bank to land. During that time I had to get the fire extinguisher, shut the fuel, open the door, identify the landing site and of course fly the airplane. There was really no time to get the checklist, put on the smoke hood (I have two in my hangar that I brought for my RV-9A first flight), and doing some other things. If you had a fuel fire the best thing is to shut the fuel valve. I never shut the fuel valve before and in a hurry I turn the selector to in between left and right. I am not even sure it was completely shut. But engine stopped and fire reduced. So it worked for me. Do make sure you practice shut off the fuel. When the fire begins there won't be time to figure it out. Fire extinguisher works only when you remove the supply of fuel. Of course shut off the fuel means the fan in front is going to stop and you must find a place to put the airplane down. My RV9A will glide a long distance without power. 10 really drop like a rock when compared with 9. I landed without flap not because I was thinking about the spark (fire already started) problem, but I just did not have time to lower it. It turned out good since my flaps are not damaged. There are a lot of factors that made my emergency landing a success. Most of them I have no control of. There are many things I did not do correctly, for example, I forgot to turn off the electrical system. With the smoke and fire I was busy trying to land the airplane and did not think about turning off switches. I was not analyzing the situation and figuring out the solution, I was just reacting to the situation with my instinct. If I say that I have the skill to handle an emergency like this I will be lying to myself. ________________________________________________________________________________
Date: Apr 28, 2011
"If I say that I have the skill to handle an emergency like this I will be lying to myself." You did/do have the skill=2C you are alive and uninjured. You will need to get your confidence back and get back on the horse. Altitude is life. Unless it takes too much time to get on the ground and ju mp out due to being burned...then a parachute is a good thing. Good work!!! Date: Thu=2C 28 Apr 2011 23:32:42 -0400 From: tc1234c(at)roadrunner.com Subject: RV10-List: Re: Fire and off field landing I just log on and read some of your comments. Here are answers to a few que stions. The accident flight was my sixth flight and 8th time running the engine. I estimated that I had 1.2 min from the time I noticed the smoke to a sharp bank to land. During that time I had to get the fire extinguisher=2C shut the fuel=2C ope n the door=2C identify the landing site and of course fly the airplane. There was really no time to get the checklist=2C put on the smoke hood (I h ave two in my hangar that I brought for my RV-9A first flight)=2C and doing some other things. If you had a fuel fire the best thing is to shut the fuel valve. I never shut the fuel valve before and in a hurry I turn the selector to in between left and right. I am not even sure it was completely shut. But engine stopped and fire reduced. So it worked for me. Do make sure you practice shut off the fuel. When the fire begins there won't be time to figure it out. Fire extinguisher works only when you remove the supply o f fuel. Of course shut off the fuel means the fan in front is going to stop and you must find a place to put the airplane down. My RV9A will glide a lo ng distance without power. 10 really drop like a rock when compared with 9. I landed without flap not because I was thinking about the spark (fire alre ady started) problem=2C but I just did not have time to lower it. It turned out good since my flaps are not damaged. There are a lot of facto rs that made my emergency landing a success. Most of them I have no control of. There are many things I did not do correctly=2C for example=2C I forgot to turn off the electrical system. With the smoke and fire I was busy trying t o land the airplane and did not think about turning off switches. I was not a nalyzing the situation and figuring out the solution=2C I was just reacting to the situation with my instinct. If I say that I have the skill to handle an emergency like this I will be lying to myself. ________________________________________________________________________________
Subject: Rudder gust lock
Date: Apr 29, 2011
I am trying to figure out how to create a rudder gust lock that is on the rudder, not the pedals. I would rather control the movement at the source rather than 20 feet away at the pedals. My RV8 has a 1/8 inch thick angle longeron that runs aft at the same height as the rudder horn, to which you mount the external rudder stops. A couple of U shaped pieces of stainless rod connecting the horn to the stops acts as a ground lock. The problem with the 10 is there is no longeron down by the rudder horn to mount a similar type of bracket. I could make a bracket that mounts through the skin and into the aft bulkhead of the tailcone at the proper height to mate up to the horn, but I would like to hear if anyone else has used a similar approach, and could send me a picture of the results. Chris Hukill ________________________________________________________________________________
Date: Apr 29, 2011
Subject: Re: Rudder gust lock
Chris, this is exactly what we did on my -10 and I think it's an excellent solution. Very simple to install & remove, extremely light & compact. Just hang a huge Remove Before Flight ribbon off of it and you are set. Mine clips on to my pitot tube cover when not in use so I pull both out at the same time. Sorry I am on the road and do not have any photos to share. I have posted images in the past so they should be in the archives. Ping me in 3 days if you want a photo posted. Robin On Fri, Apr 29, 2011 at 9:27 AM, Chris Hukill wrote: > I am trying to figure out how to create a rudder gust lock that is on the > rudder, not the pedals. I would rather control the movement at the source > rather than 20 feet away at the pedals. My RV8 has a 1/8 inch thick angle > longeron that runs aft at the same height as the rudder horn, to which you > mount the external rudder stops. A couple of U shaped pieces of stainless > rod connecting the horn to the stops acts as a ground lock. The problem with > the 10 is there is no longeron down by the rudder horn to mount a similar > type of bracket. I could make a bracket that mounts through the skin and > into the aft bulkhead of the tailcone at the proper height to mate up to the > horn, but I would like to hear if anyone else has used a similar approach, > and could send me a picture of the results. > Chris Hukill > > * > > * > > ________________________________________________________________________________
Date: Apr 29, 2011
two alumium angles (1/8") 24" long); padded with foam (attach foam with RTV) single long bolt thru the center of each angle; paint RED; use wing nut on bolt. This will securely lock rudder when inserted at/around the lower hinge. If desired make a smaller one for the aileron and/or elevator. I use the belts for control lock, except rudder, for short periods; otherwise I use individual control locks on each surface. light weight but very secure. ----- Original Message ----- From: Chris Hukill To: rv10-list(at)matronics.com Sent: Friday, April 29, 2011 6:27 AM Subject: RV10-List: Rudder gust lock I am trying to figure out how to create a rudder gust lock that is on the rudder, not the pedals. I would rather control the movement at the source rather than 20 feet away at the pedals. My RV8 has a 1/8 inch thick angle longeron that runs aft at the same height as the rudder horn, to which you mount the external rudder stops. A couple of U shaped pieces of stainless rod connecting the horn to the stops acts as a ground lock. The problem with the 10 is there is no longeron down by the rudder horn to mount a similar type of bracket. I could make a bracket that mounts through the skin and into the aft bulkhead of the tailcone at the proper height to mate up to the horn, but I would like to hear if anyone else has used a similar approach, and could send me a picture of the results. Chris Hukill ________________________________________________________________________________
Date: Apr 29, 2011
Here's a link to Robin's rudder gust lock pictures... http://forums.matronics.com/viewtopic.php?t=58911 -Sean #40303 On 4/29/11 8:51 AM, Robin Marks wrote: > Chris, this is exactly what we did on my -10 and I think it's an > excellent solution. Very simple to install & remove, extremely light & > compact. Just hang a huge Remove Before Flight ribbon off of it and > you are set. Mine clips on to my pitot tube cover when not in use so I > pull both out at the same time. > Sorry I am on the road and do not have any photos to share. I have > posted images in the past so they should be in the archives. Ping me > in 3 days if you want a photo posted. > > Robin > > > On Fri, Apr 29, 2011 at 9:27 AM, Chris Hukill > wrote: > > I am trying to figure out how to create a rudder gust lock that is > on the rudder, not the pedals. I would rather control the movement > at the source rather than 20 feet away at the pedals. My RV8 has a > 1/8 inch thick angle longeron that runs aft at the same height as > the rudder horn, to which you mount the external rudder stops. A > couple of U shaped pieces of stainless rod connecting the horn to > the stops acts as a ground lock. The problem with the 10 is there > is no longeron down by the rudder horn to mount a similar type of > bracket. I could make a bracket that mounts through the skin and > into the aft bulkhead of the tailcone at the proper height to mate > up to the horn, but I would like to hear if anyone else has used a > similar approach, and could send me a picture of the results. > Chris Hukill > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Date: Apr 29, 2011
Thanks Sean! OK, on all my other RV's we built gust locks that "dropped" down instead of the way this one is done with one down leg & one leg going up. This was a test unit that worked well so I moved on to other items on "the list". At some point we may fabricate a new unit that just "drops" into place. There is no benefit to the one up one down design. Regardless it works GREAT in either configuration but the drop into place design has gravity working for you and is a touch easier to install. Robin On Fri, Apr 29, 2011 at 10:13 AM, Sean Stephens wrote: > > Here's a link to Robin's rudder gust lock pictures... > > http://forums.matronics.com/viewtopic.php?t=58911 > > -Sean #40303 > > > On 4/29/11 8:51 AM, Robin Marks wrote: > >> Chris, this is exactly what we did on my -10 and I think it's an excellent >> solution. Very simple to install & remove, extremely light & compact. Just >> hang a huge Remove Before Flight ribbon off of it and you are set. Mine >> clips on to my pitot tube cover when not in use so I pull both out at the >> same time. >> Sorry I am on the road and do not have any photos to share. I have posted >> images in the past so they should be in the archives. Ping me in 3 days if >> you want a photo posted. >> >> Robin >> >> >> On Fri, Apr 29, 2011 at 9:27 AM, Chris Hukill > cjhukill(at)cox.net>> wrote: >> >> I am trying to figure out how to create a rudder gust lock that is >> on the rudder, not the pedals. I would rather control the movement >> at the source rather than 20 feet away at the pedals. My RV8 has a >> 1/8 inch thick angle longeron that runs aft at the same height as >> the rudder horn, to which you mount the external rudder stops. A >> couple of U shaped pieces of stainless rod connecting the horn to >> the stops acts as a ground lock. The problem with the 10 is there >> is no longeron down by the rudder horn to mount a similar type of >> bracket. I could make a bracket that mounts through the skin and >> into the aft bulkhead of the tailcone at the proper height to mate >> up to the horn, but I would like to hear if anyone else has used a >> similar approach, and could send me a picture of the results. >> Chris Hukill >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> >> * >> > > ________________________________________________________________________________
Date: Apr 29, 2011
Subject: Flare Fitting Torque
On 4/28/11 2:03 PM, John Cox wrote: > As a Tech Advisor, no one wants to hear from us how often we find flares > on tubing incorrectly manufactured or improperly torqued (under and > over) I changed the subject line to start a new thread here. Yes, this brought me back to reviewing what I need to do in the tunnel. I wanted to put this info out there to make sure I am "doing it right". In AC 43.13-1B CHG1 on page 9-19 there is a table for flare nut torque values. -4 nut = 50-65 inch pounds -6 nut = 110-130 inch pounds Also on page 7-8 of AC 43.13-1B there is a formula for determining the correct torque reading when using adapters such as crows feet. E - Distance from drive centerline to adapter centerline T - Recommended torque value L - Length or torque wrench, drive centerline to handle centerline Y - What the wrench should be set at with adapter in place TxL / L+E = Y So for my wrench with a crows foot and to torque a -6 flare nut to 110 inch lbs works out like this... 110x10 / 10+1 = 100 My wrench should be set at 100 and *not* 110 in this case. So, do I have all this right? A few questions.. 1. I've seen different tables out there with different torque values for the flare nuts. Is what I'm using above correct? 2. So the torque range for -4 above is 50-65. What do people use to set their wrench? low end of 50? high end of 65? Split the difference for 57? 2. There are some places in the tunnel where it just doesn't work getting a torque wrench in there even with a crows foot and/or extension. What are folks doing in this case? -Sean #40303 ________________________________________________________________________________
Date: Apr 29, 2011
I did something similar to Robin, but with the ' drop down' . One word of caution, when I initially installed the gust lock, I installed it only on one side, and I did not put 'retainer pins/clips' to hold in place, During a trip, we experienced some extremely strong winds one evening (40-50 mph gusts) and with the drop down retainer 'crept' upward bit by bit until it allowed some movement in the rudder, and then it progressively crept up until the movement was large enough to pull the attachment bracket off the plane. The solution for me, was to replicate the gust lock on 'Both' sides of the rudder, and to add retaining clips to the drop in brackets that do not allow for any 'creep'. The retainers are just some 3/16" ss rod bent in a wide "U" and drilled for some retaining clips which are wired together ( so as not to loose them) with a Remove before Flight flag. It's rock solid now and haven't had any subsequent issues. Attached is an early picture before I added the other side and snugged up the retaining pins. Deems ________________________________________________________________________________
From: "fehdxlbb(at)gmail.com" <fehdxlbb(at)gmail.com>
Date: Apr 29, 2011
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: Apr 29, 2011
Each builder is the Manufacturer (not VANS), many have happily followed the mantra "just build it". Every builder receiving my Tech Inspection hears the story of hats. On this list most of the readers are wearing "The Builder/Manufacturer" hat. The moment the DAR is through with his paperwork, you will learn the perspective of wearing "The Technician's" hat. Often profanity follows and a dialog which goes something like "Why didn't I think of that". Access to an area, service loops, application of torque to any fitting carrying fluids, support of electrical wires from chafing, they all play into the dialog. The reason for at least two tables are possibly the difference in B nut construction between aluminum or steel. The proper use of a torque wrench requires access, range of movement and proper application. Hopefully the torque reading required is not at the lowest or highest end of the measurement range. Both "under-torque" or more common "over torque" lead to potential leaks and product failures. Every time you open/loosen a fitting on a fluid line, you should pressurize, fly the aircraft then reinspect for telltale signs. An improperly formed flare, an over-torqued fitting, weak aluminum tubing or angular mis-match can lead to potential leaks. Always remember to have the input or output tubing with a bend to take up errors of using a straight run that can be too short or too long. Access to the tunnel whether from your favorite side or from the bottom seem good points of consideration. Think about what it will feel like when you re-enter a space for servicing. Several of the readers have been great on the "I would have done it this way, or I am thinking about changing" the product provided or method suggested by a parts supplier. AC 43.13 is only a baseline in the absence of one selected method or standard by the responsible manufacturer. Often, such as with electrical considerations, much has improved over the ideas of the 1940's - 50s techniques. Chose wisely. In the absence of a standard in Experimental Built, Anything Goes. It's an experiment. We are blessed with many somewhat similar aircraft in reasonably similar construction. On your torque calculation problem you did not mention if the 1" was straight in line, at a 90 degree or some variant. Prop Hub bolts provide a challenge. John -#40600 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Friday, April 29, 2011 8:06 AM Subject: RV10-List: Flare Fitting Torque On 4/28/11 2:03 PM, John Cox wrote: > As a Tech Advisor, no one wants to hear from us how often we find flares > on tubing incorrectly manufactured or improperly torqued (under and > over) I changed the subject line to start a new thread here. Yes, this brought me back to reviewing what I need to do in the tunnel. I wanted to put this info out there to make sure I am "doing it right". In AC 43.13-1B CHG1 on page 9-19 there is a table for flare nut torque values. -4 nut = 50-65 inch pounds -6 nut = 110-130 inch pounds Also on page 7-8 of AC 43.13-1B there is a formula for determining the correct torque reading when using adapters such as crows feet. E - Distance from drive centerline to adapter centerline T - Recommended torque value L - Length or torque wrench, drive centerline to handle centerline Y - What the wrench should be set at with adapter in place TxL / L+E = Y So for my wrench with a crows foot and to torque a -6 flare nut to 110 inch lbs works out like this... 110x10 / 10+1 = 100 My wrench should be set at 100 and *not* 110 in this case. So, do I have all this right? A few questions.. 1. I've seen different tables out there with different torque values for the flare nuts. Is what I'm using above correct? 2. So the torque range for -4 above is 50-65. What do people use to set their wrench? low end of 50? high end of 65? Split the difference for 57? 2. There are some places in the tunnel where it just doesn't work getting a torque wrench in there even with a crows foot and/or extension. What are folks doing in this case? -Sean #40303 ________________________________________________________________________________
Date: Apr 29, 2011
Subject: Re: Flare Fitting Torque
Perhaps a larger potential problem than torque values for B nuts , is how to construct the proper flare. There are several different tools for doing so, and the techniques of using the tools vary, It's quite possible with at least one tool (Parker) to 'over torque' the flaring tool and product a flare that becomes too thin and subject to breaking. (Ask me how I know:-) ). Years ago I posted my experience of 'accidentally' finding that some fuel lines in the tunnel had been 'over flared' and 'over torqued' and resulted in the flare breaking and the line pulling free from the B nut! Fortunately I found it and redid all of the alum lines, or I would have found myself in a similar situation as Ted. Deems ________________________________________________________________________________
Date: Apr 29, 2011
Sorry, yes the 1" is straight inline. So if I understand correctly with the torque range, it's best to split the difference as to be further away from both under and over torque. The range numbers I gave were for Aluminum. Are the numbers below what other builders are using? I'd like to "chose wisely" in this particular case, but my choice is what the piece of paper tells me. -4 nut = 50-65 inch pounds -6 nut = 110-130 inch pounds Thanks, -Sean #40303 On 4/29/11 1:42 PM, John Cox wrote: > --> RV10-List message posted by: "John Cox" > > Each builder is the Manufacturer (not VANS), many have happily followed > the mantra "just build it". Every builder receiving my Tech Inspection > hears the story of hats. On this list most of the readers are wearing > "The Builder/Manufacturer" hat. The moment the DAR is through with his > paperwork, you will learn the perspective of wearing "The Technician's" > hat. Often profanity follows and a dialog which goes something like > "Why didn't I think of that". > > Access to an area, service loops, application of torque to any fitting > carrying fluids, support of electrical wires from chafing, they all play > into the dialog. > > The reason for at least two tables are possibly the difference in B nut > construction between aluminum or steel. The proper use of a torque > wrench requires access, range of movement and proper application. > Hopefully the torque reading required is not at the lowest or highest > end of the measurement range. Both "under-torque" or more common "over > torque" lead to potential leaks and product failures. Every time you > open/loosen a fitting on a fluid line, you should pressurize, fly the > aircraft then reinspect for telltale signs. An improperly formed flare, > an over-torqued fitting, weak aluminum tubing or angular mis-match can > lead to potential leaks. Always remember to have the input or output > tubing with a bend to take up errors of using a straight run that can be > too short or too long. > > Access to the tunnel whether from your favorite side or from the bottom > seem good points of consideration. > > Think about what it will feel like when you re-enter a space for > servicing. Several of the readers have been great on the "I would have > done it this way, or I am thinking about changing" the product provided > or method suggested by a parts supplier. > > AC 43.13 is only a baseline in the absence of one selected method or > standard by the responsible manufacturer. Often, such as with > electrical considerations, much has improved over the ideas of the > 1940's - 50s techniques. Chose wisely. > > In the absence of a standard in Experimental Built, Anything Goes. It's > an experiment. We are blessed with many somewhat similar aircraft in > reasonably similar construction. > > On your torque calculation problem you did not mention if the 1" was > straight in line, at a 90 degree or some variant. Prop Hub bolts > provide a challenge. > > John -#40600 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Friday, April 29, 2011 8:06 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Flare Fitting Torque > > --> RV10-List message posted by: Sean Stephens > > On 4/28/11 2:03 PM, John Cox wrote: >> As a Tech Advisor, no one wants to hear from us how often we find > flares >> on tubing incorrectly manufactured or improperly torqued (under and >> over) > I changed the subject line to start a new thread here. > > > Yes, this brought me back to reviewing what I need to do in the tunnel. > > I wanted to put this info out there to make sure I am "doing it right". > > In AC 43.13-1B CHG1 on page 9-19 there is a table for flare nut torque > values. > > -4 nut = 50-65 inch pounds > -6 nut = 110-130 inch pounds > > Also on page 7-8 of AC 43.13-1B there is a formula for determining the > correct torque reading when using adapters such as crows feet. > > E - Distance from drive centerline to adapter centerline > T - Recommended torque value > L - Length or torque wrench, drive centerline to handle centerline > Y - What the wrench should be set at with adapter in place > > TxL / L+E = Y > > So for my wrench with a crows foot and to torque a -6 flare nut to 110 > inch lbs works out like this... > > 110x10 / 10+1 = 100 > > My wrench should be set at 100 and *not* 110 in this case. > > So, do I have all this right? A few questions.. > > 1. I've seen different tables out there with different torque values > for the flare nuts. Is what I'm using above correct? > > 2. So the torque range for -4 above is 50-65. What do people use to > set their wrench? low end of 50? high end of 65? Split the difference > > for 57? > > 2. There are some places in the tunnel where it just doesn't work > getting a torque wrench in there even with a crows foot and/or > extension. What are folks doing in this case? > > -Sean #40303 > > ________________________________________________________________________________
Date: Apr 29, 2011
instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 ________________________________________________________________________________
Date: Apr 29, 2011
Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 ________________________________________________________________________________
Date: Apr 30, 2011
Thanks guys for the response. Robin's method is just the ticket, however I'm not sure how much of the tailcone structure I need to pick up, so I don't damage anything in winds like we had all day long yesterday, here in Vegas. If I was building the tailcone now, and things were accessible, I would put in some serious reinforcement to carry the load, but now as an afterthought, I think an external bracket could be made that goes forward and bolts to the little stiffener that attaches to the aft bulkhead. The bracket could then go down to line up with the horn, and catch a couple of inches of the aft bulkhead along the way. Or maybe just one that runs up and down the bulkhead a few inches is strong enough? A bracket on both sides with retaining clips is also a good idea. Chris Hukill finding projects for the new mill ________________________________________________________________________________
Date: Apr 30, 2011
John et al The flash point of Aeroshell 31 is 83 degrees C. The flash point of Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of brake fires due to leaking brake fluid onto hot brakes. I believe the cost difference is trival. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: April-29-11 11:59 PM Subject: RE: RV10-List: Re: Flare Fitting Torque Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 ________________________________________________________________________________
Date: Apr 30, 2011
After seeing brake fluid fires, I do not recommend H-5606. Then again working with Skydrol (phosphate ester), I won't chose that either. Tim posted sources for 1 gallon cans of Aeroshell 41. It can make all the difference in a better day with composite wheel pants in close proximity to the heat and fuel. John Cox ________________________________ From: owner-rv10-list-server(at)matronics.com on behalf of Les Kearney Sent: Sat 4/30/2011 9:13 AM Subject: RE: RV10-List: Re: Flare Fitting Torque John et al The flash point of Aeroshell 31 is 83 degrees C. The flash point of Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of brake fires due to leaking brake fluid onto hot brakes. I believe the cost difference is trival. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: April-29-11 11:59 PM Subject: RE: RV10-List: Re: Flare Fitting Torque Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 ________________________________________________________________________________
Date: May 01, 2011
http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-fluid.html If you don't mind another brand, and don't want to have 3.5 qts unused for the life of your plane. On Sat, Apr 30, 2011 at 12:13 PM, Les Kearney wrote: > > John et al > > The flash point of Aeroshell 31 is 83 degrees C. The flash point of > Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of > brake fires due to leaking brake fluid onto hot brakes. > > I believe the cost difference is trival. > > Cheers > > Les > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox > Sent: April-29-11 11:59 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Flare Fitting Torque > > > Improved product quality helps in the overall build. Getting rid of > H-5606 and upgrading hydraulic fluid is another Manufacturer decision. > Great call Wayne. > > John > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer > Sent: Friday, April 29, 2011 5:36 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Flare Fitting Torque > > > instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac > scrap. > > 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on > certified aircraft for a reason. As noted above it flares much nicer. > I used Bonaco flex hoses at the pedals and down the gear legs. > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338482#338482 > > ________________________________________________________________________________
Date: May 01, 2011
another reason to pitch the vans tubing solution and install manufactured Teflon lines with the stainless steel braid from fuselage bulkhead fitting to brake.. ----- Original Message ----- From: "Les Kearney" <kearney(at)shaw.ca> Sent: Saturday, April 30, 2011 9:13 AM Subject: RE: RV10-List: Re: Flare Fitting Torque > > John et al > > The flash point of Aeroshell 31 is 83 degrees C. The flash point of > Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of > brake fires due to leaking brake fluid onto hot brakes. > > I believe the cost difference is trival. > > Cheers > > Les > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox > Sent: April-29-11 11:59 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Flare Fitting Torque > > > Improved product quality helps in the overall build. Getting rid of > H-5606 and upgrading hydraulic fluid is another Manufacturer decision. > Great call Wayne. > > John > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer > Sent: Friday, April 29, 2011 5:36 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Flare Fitting Torque > > > instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac > scrap. > > 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on > certified aircraft for a reason. As noted above it flares much nicer. > I used Bonaco flex hoses at the pedals and down the gear legs. > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338482#338482 > > > ________________________________________________________________________________
Date: May 01, 2011
Les, I think you got it backwards...-- Aeroshell 31 is 205C, and 41 is 90C.=0ADon McDonald=0A=0A=0A=0A=0A________________________________=0AFrom: Les Kearney =0ATo: rv10-list(at)matronics.com=0ASent: Sat, Ap ril 30, 2011 11:13:07 AM=0ASubject: RE: RV10-List: Re: Flare Fitting Torque =0AJohn et al=0A=0AThe flash point of Aeroshell 31 is 83 degrees C. The fla sh point of=0AAeroshell 41 is 254 degreees C. Take you pick. I seem to reca ll reading of=0Abrake fires due to leaking brake fluid onto hot brakes.=0A =0AI believe the cost difference is trival.=0A=0ACheers=0A=0ALes=0A=0A=0A =0A=0A-----Original Message-----=0AFrom: owner-rv10-list-server(at)matronics.c om=0A[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox=0A Sent: April-29-11 11:59 PM=0ATo: rv10-list(at)matronics.com=0ASubject: RE: RV1 n Cox" =0A=0AImproved product quality helps in the overall build.- Getting rid of=0AH-5606 and upgrading hydraulic fluid is another Manufacturer decision.=0AGreat call Wayne.=0A=0AJohn=0A=0A=0A=0A--- --Original Message-----=0AFrom: owner-rv10-list-server(at)matronics.com=0A[mai lto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer=0ASent: Fr iday, April 29, 2011 5:36 PM=0ATo: rv10-list(at)matronics.com=0ASubject: RV10- lyer" =0A=0Ainstead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac=0Ascrap. =0A=0A5052 has nearly twice the fatigue and tensile strength. 5052-O is used on=0Acertified aircraft fo r a reason. As noted above it flares much nicer.=0AI used Bonaco flex hoses at the pedals and down the gear legs.=0A=0A--------=0AWayne Gillispie, A&a mp;P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09.=0AFuselage Sec 46 Eng mount/Gear- 1359 hrs to date.=0A=0A=0A=0A=0ARead this topic online here:=0A =0Ahttp://forums.matronics.com/viewtopic.php?p=338482#338482=0A=0A=0A=0A ======================== ________________________________________________________________________________
Date: May 01, 2011
Guys, In the FWIW category, here is what I've been using for brake fluid since first flight in Nov 2006: Valvoline DEX/MERC auto trans fluid VV324, flash point 202=B0 C / 395=B0 F. It is readily available and very affordable. grumpy N184JM On May 1, 2011, at 10:40 AM, Don McDonald wrote: > Les, I think you got it backwards... Aeroshell 31 is 205C, and 41 is 90C. > Don McDonald > > From: Les Kearney <kearney(at)shaw.ca> > To: rv10-list(at)matronics.com > Sent: Sat, April 30, 2011 11:13:07 AM > Subject: RE: RV10-List: Re: Flare Fitting Torque > > > John et al > > The flash point of Aeroshell 31 is 83 degrees C. The flash point of > Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of > brake fires due to leaking brake fluid onto hot brakes. > > I believe the cost difference is trival. > > Cheers > > Les > > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox > Sent: April-29-11 11:59 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Flare Fitting Torque > > > Improved product quality helps in the overall build. Getting rid of > H-5606 and upgrading hydraulic fluid is another Manufacturer decision. > Great call Wayne. > > John > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer > Sent: Friday, April 29, 2011 5:36 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Flare Fitting Torque > > > instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac > scrap. > > 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on > certified aircraft for a reason. As noted above it flares much nicer. > I used Bonaco flex hoses at the pedals and down the gear legs. > > -------- > Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. > Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=338482#338482 > http://forums.matronics.comhttp://www.matronics.com/contribution==== ======= > > > http://www.matronics.com/contribution =========== ________________________________________________________________________________
Date: May 01, 2011
Milspec H-83282 is the improved product over H-5606 regardless of manufacturer name. Coming in hot on a short runway requires converting the energy to heat transferred into the rotors. Another improvement is increased rotor mass or larger surface area of calipers. You cannot go wrong increasing a safety margin regarding fire. Tim James went with improved mass and pad area. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Sunday, May 01, 2011 4:36 AM Subject: Re: RV10-List: Re: Flare Fitting Torque http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-flui d.html If you don't mind another brand, and don't want to have 3.5 qts unused for the life of your plane. On Sat, Apr 30, 2011 at 12:13 PM, Les Kearney wrote: John et al The flash point of Aeroshell 31 is 83 degrees C. The flash point of Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of brake fires due to leaking brake fluid onto hot brakes. I believe the cost difference is trival. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: April-29-11 11:59 PM Subject: RE: RV10-List: Re: Flare Fitting Torque Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 01, 2011
Several improvements can be made to stopping distances; Matco is developing a wheel/brake (dual puck) which can be used in lieu of the Cleveland mains; secondly making certain that the prop control is full forward will increase aerodynamic braking. On a different note using Arial font and size 12 will increase the readability of the email; my main computer display is an HD TV screen, so I am sitting 6-8 feet from the screen. You last answer must have been about size 8 and faint. Thanks. ----- Original Message ----- From: John Cox To: rv10-list(at)matronics.com Sent: Sunday, May 01, 2011 12:09 PM Subject: RE: RV10-List: Re: Flare Fitting Torque Milspec H-83282 is the improved product over H-5606 regardless of manufacturer name. Coming in hot on a short runway requires converting the energy to heat transferred into the rotors. Another improvement is increased rotor mass or larger surface area of calipers. You cannot go wrong increasing a safety margin regarding fire. Tim James went with improved mass and pad area. John From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Sunday, May 01, 2011 4:36 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Re: Flare Fitting Torque http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-fluid .html If you don't mind another brand, and don't want to have 3.5 qts unused for the life of your plane. On Sat, Apr 30, 2011 at 12:13 PM, Les Kearney wrote: John et al The flash point of Aeroshell 31 is 83 degrees C. The flash point of Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of brake fires due to leaking brake fluid onto hot brakes. I believe the cost difference is trival. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: April-29-11 11:59 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Re: Flare Fitting Torque Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM To: rv10-list(at)matronics.com Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Date: May 01, 2011
Subject: searchable part list
I am looking for a link to a set of searchable .doc or .pdf parts list for the various rv-10 kits. I can't seem to loacate a document online. A friend of mine has just purchased an emp kit from an estate sale and is doing an inventory. Thanks, Jim Combs N312F - Flying 240 hours (Still needs paint!) Note: Paint it BEFORE you fly it! ________________________________________________________________________________
Subject: Retrofit locking fuel caps
Date: May 01, 2011
I've been researching retrofit locking fuel caps. I've seen some write-ups on the Van's retrofit locking fuel caps and the Andair ones. Both require an insert to be pro-sealed into the existing fuel cap. I just found some at Aircraft Spruce that don't require an insert (see link). Has anyone tried these? http://www.aircraftspruce.ca/catalog/appages/retrofitfc.php Thanks. Jim N312JE - temporarily grounded for Dynon Skyview panel upgrade ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: May 01, 2011
Subject: Re: Retrofit locking fuel caps
It's a little hard to tell exactly from the picture on ACS, but the locking cap shown in the link looks a lot like the ones I have. They did require an insert. I think the clue is the "1-3/8" orifice", after the insert goes in. Isn't the original filler closer to 2" in diameter? I've been happy with these caps although the opening doesn't offer much of a view inside the tank. I also tried the caps just above, the SPRLs, which fell apart and dropped their guts in the tank after a few hours. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Sun, May 1, 2011 at 5:48 PM, James McGrew wrote: > Ive been researching retrofit locking fuel caps. Ive seen some write-ups > on the Vans retrofit locking fuel caps and the Andair ones. Both require an > insert to be pro-sealed into the existing fuel cap. I just found some at > Aircraft Spruce that dont require an insert (see link). > > > Has anyone tried these? > > http://www.aircraftspruce.ca/catalog/appages/retrofitfc.php > > > Thanks. > > > Jim > > N312JE temporarily grounded for Dynon Skyview panel upgrade > > ________________________________________________________________________________
Date: May 01, 2011
Don That was a test! You passed. The specs from Shell say that the fire point on the Aeroshell 31 is 254C so you only get part marks . Brett at Bonaco Inc does a wonderful job supplying high quality brake / fuel lines. I have eliminated the plastic lines in the Van's spec and have also used his hoses on the gear legs to the brakes. All my fuel lines will be / are braided steel lines. Cheers Les _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: May-01-11 9:40 AM Subject: Re: RV10-List: Re: Flare Fitting Torque Les, I think you got it backwards... Aeroshell 31 is 205C, and 41 is 90C. Don McDonald _____ From: Les Kearney <kearney(at)shaw.ca> Sent: Sat, April 30, 2011 11:13:07 AM Subject: RE: RV10-List: Re: Flare Fitting Torque John et al The flash point of Aeroshell 31 is 83 degrees C. The flash point of Aeroshell 41 is 254 degreees C. Take you pick. I seem to recall reading of brake fires due to leaking brake fluid onto hot brakes. I believe the cost difference is trival. Cheers Les -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: April-29-11 11:59 PM Subject: RE: RV10-List: Re: Flare Fitting Torque Improved product quality helps in the overall build. Getting rid of H-5606 and upgrading hydraulic fluid is another Manufacturer decision. Great call Wayne. John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Friday, April 29, 2011 5:36 PM Subject: RV10-List: Re: Flare Fitting Torque instead of Van's supplied 3003-O. My 3003-O went in with my aluminum hvac scrap. 5052 has nearly twice the fatigue and tensile strength. 5052-O is used on certified aircraft for a reason. As noted above it flares much nicer. I used Bonaco flex hoses at the pedals and down the gear legs. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=338482#338482 http://forums.matronics.comhttp://www.matronics.com/contribution=========== ________________________________________________________________________________
Subject: Re: [LML] Re: Beware update
Date: May 02, 2011
Here's a post from another group that may be of intrest to some. It appears AOPA has been in contact with CBP regarding a "new trend". I find AOPA's (Craig Spence) comments disturbing. Bobby Hughes N416AS ________________________________ ----- Original Message ----- From: vtailjeff(at)aol.com Sent: Sunday, May 01, 2011 10:00 AM Subject: [LML] Re: Beware update As most of you on the list know we had an incident in April here in St. Louis where one of our own was "stopped" by local police based on a "tip" from Customs and Border Patrol. Here is an update to that story: Bob Rickard (who was the individual stopped) and I have received more emails from other Lancair pilots who have been stopped as well based on "tips" from CBP. So this is not an isolated incident. I contacted AOPA, my congressman's staff, and CBP themselves. AOPA's Craig Spence is presently working this issue on our behalf. He already had ascheduled meeting with CBP on Wednesday, so he brought this subject up. He said that CBP wants to be the new "skycop". He conveyed our concerns to them --targeting GA for poloce searches and the issue of the fax that is sent to police agencies justifying detaining pilots. Mr. Spence told them that the fax has errors on it and agreed to help them correct those. On the issue of tracking GA flights and detaining pilots, Mr. Spence said the CBP is not budging. He believes we need to take this to Congressional leaders --he said we are in for a long battle with CBP. The day after Mr. Spence's meeting I received two phone calls from CBP (so it is true about smelly stuff rolling downhill). The first call was from "Carlos" at CBP HQ. Carlos works in Gen. Mike Kostelnik's office in DC. Kostelnik, a retired AF two star, is the head of the CBP Air and Marine Center. Carlos wanted to know what our concerns were and I repeated that we did not like getting stopped based on bogus information. He wanted to know how I was certain CBP was behind these stops (he implied they had nothing to do with it) and I said it was from information from the local police and the fax AMOC sent to them. (Ah, the truth and evidence is so great) He was pretty agitated during our conversation and said if we were stopped and the police questioned us then we should tell them what they wanted to know. I said I disagreed (Fifth Amendment) . I gave him the specifics of Bobaloos stop two weeks ago and he agreed to look into it. I said that in the best light their intell is either unvetted or their analyis is poor. He disagreed (of course) and gave many other reasons (all bogus) as to why their intel was good. He said it could have been because the aircraft was a prior drug aircraft. I replied that would be pretty difficult since I built it, flew it and then sold it to Col. Rickard. I said that in the worst light --their folks are making up stories to get the local police to stop GA pilots--for the crime of ....flying. Of course he about blew a gasket. I asked him to tell me where CBP got this information about Bob carrying a fugitive. He replied that is a matter of national security and could not tell me. A couple of hours later I receive a phone call from Tony C. at the CBP AMOC in Riverside, CA asking again about my concerns. Again I expressed the same and while he was very polite and cordial and appears to be a
April 08, 2011 - May 02, 2011
RV10-Archive.digest.vol-id
