RV10-Archive.digest.vol-ie
May 02, 2011 - May 30, 2011
dedicated public servant doing a tough job I reiterated that law abiding
GA pilots do not enjoy getting stopped by law enforcement based on
seemingly bogus information. Tony said they are just trying to "put
their eyes on people"--meaning us. I remarked that there has to be a
better way of doing that than surrounding a pilot with 6 police cars and
ten officers. He said they have tough job catching bad guys. I said
that that they need to do a better job screening their intel. It seemed
both he and Carlos went back and forth on whether the intel came from
internal sources or external ones. At one point he said people were
calling their hotline with tips -- so I challenged him as to how someone
would know the Mr. McCrae was on Bob's airplane and then called them in
Riverside to report it. The story seemed to change to they had strong
intel internally. Never an admission that they screwed up. Just more
reasons why their intel is solid. Even at one point denying it is their
intel-- "it comes from somewhere else-- they are just the middle man."
Tony said they are all ex military and are all pilots so I pointed oujt
that the fax has numerous errors and the FARs contains no language
allowing detention of a pilot for failing to have his medical or
logbook on his person (look for that to change as CBP will probably
write criminal regulations re: pilots) . The whole time I could hear a
beep every ten seconds or so probably indicating I was being recorded.
Althoug Tony was pleasant there was no progress on this issue. None.
I spoke with my congressman's senior staffer as well. I relayed the
details of the issue to her and she seemed sincerely interested. She
said it is best to generate a letter from our organizations (we are) and
forward that with a personal note to all of our congressmen. She said I
should be carefull so that I don't become a target.
All for now.
Jeff "Bullseye" Edwards
Subject: | Re: searchable part list |
Vans Will email you the listings.
Sent via DROID on Verizon Wireless
-----Original message-----
Sent: Sun, May 1, 2011 20:04:38 GMT+00:00
Subject: RV10-List: searchable part list
I am looking for a link to a set of searchable .doc or .pdf parts list for
the various rv-10 kits. I can't seem to loacate a document online.
A friend of mine has just purchased an emp kit from an estate sale and is
doing an inventory.
Thanks, Jim Combs
N312F - Flying 240 hours (Still needs paint!)
Note: Paint it BEFORE you fly it!
Just go to Tim Olson's website. I don't remember if they are in the
protected area or not. If so, just register with Tim. Then you can download
all of the lists, from the early kits to some of the most recent, that let
you see how the kits have evolved. May let you match whatever vintage the
serial number kit purchased is.
On Mon, May 2, 2011 at 10:04 AM, Ross Wendell <rwendell@hydro-splash.com>wrote:
> *Sent via DROID on Verizon Wireless*
> *From: *Jim Combs <jiminlexky(at)gmail.com>*
> To: *rv10-list(at)matronics.com*
> Sent: *Sun, May 1, 2011 20:04:38 GMT+00:00*
> Subject: *RV10-List: searchable part list
> doing an inventory.
> Thanks, Jim Combs
Subject: | Ignition wire routing on IO-540 with lightspeed ignition |
From: | "Michael Wellenzohn" <rv-10(at)wellenzohn.net> |
Hello builders,
I am trying to find my way back into building and plan to finalize the FWF wiring.
How did other route the ignition wires from the Lightspeed ignition coils to the
spark plugs. I have an TMX-540 with single Lightspeed ignition.
It would be great to see some pictures.
Many thanks
RV-10 builder (interior,avionics, wiring)
#511
http://forums.matronics.com/viewtopic.php?p=338651#338651
Subject: | Re: Retrofit locking fuel caps |
I am interested in the Andair retrofit fuel caps. Did anyone use them and is already
flying? Pictures of the installation would be much appreciated.
Michael
#511
http://forums.matronics.com/viewtopic.php?p=338654#338654
RV10-List: Re: Retrofit locking fuel caps
I LOVE Andair products but I recall a discussion stating that the locking
fuel tend to vent out of the lock mechanism and that builders that fill
their tanks up nearly all the way experience blue fuel streaks coming off of
the fuel cap opening in flight. The best solution seems to be to paint your
wings blue.
Not 100% sure this was an Andair cap issue or another locking cap.
Robin
*From:* owner-rv10-list-server(at)matronics.com [mailto:
owner-rv10-list-server(at)matronics.com] *On Behalf Of *Michael Wellenzohn
*Sent:* Monday, May 02, 2011 12:32 PM
*To:* rv10-list(at)matronics.com
*Subject:* RV10-List: Re: Retrofit locking fuel caps
already flying? Pictures of the installation would be much appreciated.
Michael
#511
Checked by AVG - www.avg.com
Subject: | Re: Ignition wire routing on IO-540 with lightspeed ignition |
From: | Michael Kraus <n223rv(at)wolflakeairport.net> |
Here is what I did.
-Mike Kraus
On May 2, 2011, at 3:26 PM, "Michael Wellenzohn" wrot
e:
t>
> Hello builders,
wiring.
o the spark plugs. I have an TMX-540 with single Lightspeed ignition.
> Many thanks
> Mike
> #511
