RV10-Archive.digest.vol-ih
July 11, 2011 - July 20, 2011
Subject: Re: External Brake Lines - crack
Date: Jul 11, 2011
I believe that Vans is using poor quality tubing. In production aircraft they use 5052 based alum tubing. Vans supplies 301 based soft tubing. So I have decided to not use any tubing material from Vans and order all 5052 tubing that one can get a good flare on with out the worries of cracking like the 301 based tubing. I will use Teflon hosed with fire sleeve on all fluid hoses in the engine compartment. Just my 3 cents worth John Cumins President 707-425-7100 707-425-7576 Fax -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Saturday, July 09, 2011 9:32 PM Subject: Re: RV10-List: Re: External Brake Lines - crack --> I think the decision ..... flex or hard ..... probably boiled down to weight and cost, and the hard lines win on both counts. Hard line failures on certified aircraft happen..... but mostly with many, many hours on them. I have no data, but I'd bet money on the RV brake line failures on poor flaring technique, or cheap equipment. Scoring the tubing with the flaring tool clamp is just asking for a stress fracture. For me it's really difficult to get a flare I'm happy with. I had to clean up my Rolo-Flair dies because of marks on the tubing. Linn On 7/9/2011 11:56 PM, William Curtis wrote: > --> RV10-List message posted by: William Curtis > > Kelly, > > > I beg to differ but in certified aircraft that I am familiar, (Cessna) > flexible lines are used only where absolutely necessary. The > preference by certified aircraft designers is to use hard lines as > much as practicable if only so that there is no life limit on the > line. > > This was driven home to me when I stood on the rear door of a C-17 and > looked up at all the hydraulic plumbing. With all those movable parts > and doors, NOT a single flexible line --not even at the actuators. > Where the line required movement, solid lines with mechanical (banjo > style) flexible fluid couplings were used. I took a picture of it but > I have to find it. > > I know some Pipers use a short flexible line between their fuel tanks > and the fuselage fuel coupling. However on the Cardinal that; when in > doubt I ask "what would Cessna do" just as with Vans, flexible lines > are kept to a minimum and used only where absolutely necessary. > > In the Cardinal fuel system, there are NO flexible lines. In the > Cardinal electro-hydraulic gear system there are only four short > flexible lines at the nose and main gear actuators. In the > retractable gear Cardinal, the brake line in the main gear is a solid > line. A the top of the RG brake line is a solid mechanical swivel > fitting and only on the lower portion by the wheel is a short easily > replaced flexible line used--remember this is a retractable gear > aircraft. > > The point in all this is that hard lines ARE the standard in the > certified and military world in most areas and flexible lines are the > exception. Flexible lines are used only where hard lines are > impractical or expensive such as the movable mechanical (banjo type) > fluid connectors. > > Just an alternative $0.02. > > William > N237VX > > > On Jul 9, 2011, at 10:25, Kelly McMullen wrote: > >> --> RV10-List message posted by: Kelly McMullen >> >> Van's would consider adding flex lines about the same time as they >> consider stocking the correct nose wheel. They won't change the nose >> wheel even though the correct one is exactly the same price. Flex >> lines could add over $100 to the cost, especially if you include flex >> lines in place of the crummy nylon lines in the cabin. Somehow we >> have been deluded into wanting durability similar to certified >> aircraft................what a crazy idea. >> >> On Fri, Jul 8, 2011 at 10:06 PM, E& T Andrews wrote: >> Vans should consider including the >>> flexible hose lines in the RV10 kit... has this been raised with >>> Vans before? >>> >>> all the best >>> >>> Evan Andrews > > ________________________________________________________________________________
Subject: Interior lights
Date: Jul 11, 2011
My dad and I made these rectangle LED lights for my RV-10. I may make them available for sale but didn't know if there was a market for them. They should be a lot cheaper than what's currently out there. I had mine hard anodized black. I hooked them up on a dimmer and they work great. I have the small size for the floor lights with 8 LED's and the large have 24. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=345972#345972 Attachments: http://forums.matronics.com//files/photo_3_252.jpg http://forums.matronics.com//files/photo_2_148.jpg http://forums.matronics.com//files/photo_1_926.jpg http://forums.matronics.com//files/photo_1_128.jpg ________________________________________________________________________________
Date: Jul 11, 2011
Subject: Re: Interior lights
Sean, Your timing is impeccable. I am about to order the swivel lights that you have, and was looking around for what to get for dome lights. I would be interested in natural aluminum color anodizing. Black and silver is probably plenty for choice. I didn't see a small size in your photos. Kelly On Mon, Jul 11, 2011 at 4:55 PM, Strasnuts wrote: > > My dad and I made these rectangle LED lights for my RV-10. I may make them available for sale but didn't know if there was a market for them. They should be a lot cheaper than what's currently out there. I had mine hard anodized black. I hooked them up on a dimmer and they work great. I have the small size for the floor lights with 8 LED's and the large have 24. > > -------- > 40936 > RV-10 SB N801VR Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=345972#345972 > > > Attachments: > > http://forums.matronics.com//files/photo_3_252.jpg > http://forums.matronics.com//files/photo_2_148.jpg > http://forums.matronics.com//files/photo_1_926.jpg > http://forums.matronics.com//files/photo_1_128.jpg > > ________________________________________________________________________________
Date: Jul 11, 2011
Kelly, The first pic that is labeled Photo 3 is the 8 LED vs. the 24 bulb on the overhead on the other pics. Are you going to OSH? I will be there!!!!!! -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346002#346002 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Subject: Re: Greg Hale is in Sport Aviation this month
Date: Jul 12, 2011
That brings to mind a whole number of things that required a mustache; door pins, nose wheel, bulkhead cracks due to poor QC. I could go on but my poi nt is the -10 is an awesome platform to build on but far from perfect. We are building experimental aircraft, not factory clones so by all means, exp eriment (within reason)! Michael Sent from my iPad2 On Jul 4, 2011, at 5:42 PM, "John Gonzalez" > wrote: Way to go Dick! Think of all the people who have wanted to put a mustache on the Mona Lisa! Don't mess with DaVinci, Don't mess with Dick's creation. Thanks William for posting this. ________________________________ Date: Sun, 3 Jul 2011 21:57:49 -0400 Subject: RV10-List: Greg Hale is in Sport Aviation this month From: <mailto:wcurtis(at)nerv10.com> wcurtis(at)nerv10.com<mailto:wcurtis(at)nerv10. com> st(at)matronics.com> I don't do Facebook and so have previously ignored the Facebook icon on the Van's homepage. I decided to take a look at what was out there and I see Van's has a pretty pointed commentary on Greg's aircraft. The title of the article is "WHAT PRICE MASTERPIECE?<http://www.facebook.com/notes/vans-air craft-inc/what-price-masterpiece-by-dick-vangrunsven/237594966250883>" <http://www.facebook.com/notes/vans-aircraft-inc/what-price-masterpiece-by- dick-vangrunsven/237594966250883>http://www.facebook.com/notes/vans-aircraf t-inc/what-price-masterpiece-by-dick-vangrunsven/237594966250883 The article touches on a number of items, increased gross weight, seats, sh oulder harness and additional fuel tanks in the wings. The additional fuel in the wings is relevant to Matronics thread 75832<http://www.matronics.co m/forums/viewtopic.php?t=78532>. -- William N40237 - <http://wcurtis.nerv10.com/> http://wcurtis.nerv10.com/ arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ="_blank">http://www.matronics.com/contribution nics.com/Navigator?RV10-List m/contribution ________________________________________________________________________________
Subject: Re: ATSB Transceiver...
Date: Jul 12, 2011
Matt, What are you using this with GRT's gear? I've been considering it for some time but the interface to the Advanced Flight gear seems to be permanently "under development" so I'm stuck with my 496 for weather. Sent from my iPad2 On Jul 3, 2011, at 5:30 PM, "Matt Dralle" wrote: > > At 02:07 PM 7/3/2011 Sunday, you wrote: >> >> Have been thinking about doing the same. Are you going with navworx? > > > I ordered the ADS600-B unit from NavWorx: > > <http://www.navworx.com/ads600-b.asp>http://www.navworx.com/ads600-b.asp > > Here's their main site: > > <http://www.navworx.com/index.asp>http://www.navworx.com/index.asp > > They're not exactly cheap. Here's the price list: > > <http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx>http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx > > I also ordered it with the WIFI module and the ARINC-429 for fun. > > Matt > > > > > - > Matt Dralle > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > > > > ________________________________________________________________________________
Subject: Re: Flying Magazine/Dan Lloyd/Aftermath
Date: Jul 12, 2011
I never understood why people seemed to generally avoid saying Jan's name when referring to the engine builder. While dan made the vast majority of poor decisions in this, Jan was right there beside him encouraging him to keep going. I remember looking at eggenfellers RV-10 package at the same time as Dan so we talked a fair amount early on. Neither one of us was a fan of using 1940s technology in our modern aircraft. But as I poked and prodded Jans solution, I became very apparent that this was a case of napkin engineering, he not only couldn't explain why his performance numbers were changing almost weekly, but I was banned from his user group for asking legitimate questions around the performance. I was labeled a non-believer and exiled so to speak. So I went with the safe bet and ordered a new IO540x from Barrett and have never had a second thought. Jan would never test his packages himself on aircraft, he refused to post performance numbers other than ones he developed based on what it should do based on automotive applications. He changed his design almost yearly and routinely dropped support for his "legacy" products. His redrive was redesigned almost as often and each time it was the best design, according to him, while leaving owners of previous designs high and dry. And now he has pulled the ultimate in dropping all support and responsibility for past solutions by starting a new company and closing the old. As you can tell I have a very low opinion of Jan, he loves to threaten and try to intimidate if you don't believe what he is shoveling or question it in any way. Sure there have been successful installs of his package but there appears to be far more incomplete installations. Even his one time highest supporters seemed to abandon him after months and years in delivery delays and failed promises. This is all my opinion and, In my opinion, Jan was a contributing factor in what happened and is one of the sleaziest of businessmen out there with no ethics. I hope karma bites him in the ass hard. Buyer be warned! Sent from my iPad2 On Jul 3, 2011, at 1:00 AM, "woxofswa" wrote: > > I joined the community right before this tragic accident. > > Rightly or wrongly, my impression after reading the article is to place more blame on the engine packager than I previously felt. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=344762#344762 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2011
Intimidation is perhaps contagious? I don't know. I've never been involved with the guy. I perhaps shook his hand at Osh that fateful year... but then spent the rest of my first Osh trip listening to stories about the guy (including Dan's). I recognized the sleaze but noticed that people were either strong 'believers' or 'avoiders'. Ironically, people in both camps had been burnt. Amazing. I'm actually a bit impressed by those who can do this stuff that well. He weaves a story we all want to respond to; "with all this fine automotive engine technology, there has to be a cheaper more efficient solution than a Lycosaur". Well yeah! Hell Yeah! Then he actually develops and makes stuff... chips fly, pretty anodized parts are fabricated, real aircraft are adapted.... all this makes him 'one of us'. But his marketing and promotion skills tip over into the Svengali camp. I just went on his Viking site and was transfixed. All this jumbled content. Some of it broken, some of it not quite working, actually showing very little, but all of it strangely compelling. Especially to the person who wants to buy into the core story. I mean his comparative thrust tests are right out of a carney show. The man knows how to push buttons. And he makes a living at it I assume. The guy is a small business entrepreneur, a hands on job creator, a hero! "Putting information online is damaging to a small business and can end up hurting the very support you need the most." Really? Have some of this Kool-aid. He's really good at stuff that will get the vulnerable in trouble. Run. On 7/11/2011 11:04 PM, RV Builder (Michael Sausen) wrote: > --> RV10-List message posted by: "RV Builder (Michael Sausen)" > > I never understood why people seemed to generally avoid saying Jan's name when referring to the engine builder. While dan made the vast majority of poor decisions in this, Jan was right there beside him encouraging him to keep going. I remember looking at eggenfellers RV-10 package at the same time as Dan so we talked a fair amount early on. Neither one of us was a fan of using 1940s technology in our modern aircraft. But as I poked and prodded Jans solution, I became very apparent that this was a case of napkin engineering, he not only couldn't explain why his performance numbers were changing almost weekly, but I was banned from his user group for asking legitimate questions around the performance. I was labeled a non-believer and exiled so to speak. So I went with the safe bet and ordered a new IO540x from Barrett and have never had a second thought. > > Jan would never test his packages himself on aircraft, he refused to post performance numbers other than ones he developed based on what it should do based on automotive applications. He changed his design almost yearly and routinely dropped support for his "legacy" products. His redrive was redesigned almost as often and each time it was the best design, according to him, while leaving owners of previous designs high and dry. And now he has pulled the ultimate in dropping all support and responsibility for past solutions by starting a new company and closing the old. > > As you can tell I have a very low opinion of Jan, he loves to threaten and try to intimidate if you don't believe what he is shoveling or question it in any way. Sure there have been successful installs of his package but there appears to be far more incomplete installations. Even his one time highest supporters seemed to abandon him after months and years in delivery delays and failed promises. > > This is all my opinion and, In my opinion, Jan was a contributing factor in what happened and is one of the sleaziest of businessmen out there with no ethics. I hope karma bites him in the ass hard. Buyer be warned! > > ________________________________________________________________________________
Date: Jul 12, 2011
Yes, I have three GRT HX EFIS's in the RV-8 (see attached pictures). According to GRT, the Navworx transceiver should hook right up to the ARNIC interface and go. Still haven't gotten my transciever from Navworx yet, though. I ordered it on 6/10/2011 so its been over a month now... They did charge my credit card, though... ;-/ Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... At 07:41 PM 7/11/2011 Monday, you wrote: > >Matt, > > What are you using this with GRT's gear? I've been considering it for some time but the interface to the Advanced Flight gear seems to be permanently "under development" so I'm stuck with my 496 for weather. > >Sent from my iPad2 > >On Jul 3, 2011, at 5:30 PM, "Matt Dralle" wrote: > >> >> At 02:07 PM 7/3/2011 Sunday, you wrote: >>> >>> Have been thinking about doing the same. Are you going with navworx? >> >> >> I ordered the ADS600-B unit from NavWorx: >> >> <http://www.navworx.com/ads600-b.asp>http://www.navworx.com/ads600-b.asp >> >> Here's their main site: >> >> <http://www.navworx.com/index.asp>http://www.navworx.com/index.asp >> >> They're not exactly cheap. Here's the price list: >> >> <http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx>http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx >> >> I also ordered it with the WIFI module and the ARINC-429 for fun. >> >> Matt ________________________________________________________________________________
Subject: Engine Referral
Date: Jul 12, 2011
As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346091#346091 ________________________________________________________________________________
Date: Jul 12, 2011
Matt, What is the screen in the lower right corner? What are you driving it with etc.? Thanks, Jerry Folkerts -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Tuesday, July 12, 2011 11:43 AM Subject: Re: RV10-List: Re: ATSB Transceiver... Yes, I have three GRT HX EFIS's in the RV-8 (see attached pictures). According to GRT, the Navworx transceiver should hook right up to the ARNIC interface and go. Still haven't gotten my transciever from Navworx yet, though. I ordered it on 6/10/2011 so its been over a month now... They did charge my credit card, though... ;-/ Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... At 07:41 PM 7/11/2011 Monday, you wrote: >--> > >Matt, > > What are you using this with GRT's gear? I've been considering it for some time but the interface to the Advanced Flight gear seems to be permanently "under development" so I'm stuck with my 496 for weather. > >Sent from my iPad2 > >On Jul 3, 2011, at 5:30 PM, "Matt Dralle" wrote: > >> >> At 02:07 PM 7/3/2011 Sunday, you wrote: >>> --> >>> >>> Have been thinking about doing the same. Are you going with navworx? >> >> >> I ordered the ADS600-B unit from NavWorx: >> >> <http://www.navworx.com/ads600-b.asp>http://www.navworx.com/ads600-b. >> asp >> >> Here's their main site: >> >> <http://www.navworx.com/index.asp>http://www.navworx.com/index.asp >> >> They're not exactly cheap. Here's the price list: >> >> <http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600- >> or-PADS600-Online-Now.aspx>http://navworx.americommerce.com/store/c/2 >> 1-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx >> >> I also ordered it with the WIFI module and the ARINC-429 for fun. >> >> Matt ________________________________________________________________________________
Subject: Re: Engine Referral
Date: Jul 12, 2011
America's in Oklahoma, on the other hand, has been first rate. -----Original Message----- From: N306PB Sent: Tuesday, July 12, 2011 10:17 AM Subject: RV10-List: Engine Referral As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346091#346091 ________________________________________________________________________________
Date: Jul 12, 2011
I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > America's in Oklahoma, on the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2011
I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > America's in Oklahoma, on the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2011
It could be options. I purchased the new certified IO540 from Vans in 2004 and it was drop shipped from Lycoming to my house. It remained in the crate until install in 2007; I purchased the hartzell blended airfoil in 2007. No problems with Vans, but if I wanted electronic ignition, it was not possible because I had a certified engine. ----- Original Message ----- From: "Sean Stephens" <sean(at)stephensville.com> Sent: Tuesday, July 12, 2011 12:01 PM Subject: Re: RV10-List: Engine Referral > > I'm about to the point of ordering engine and prop and was curious as to > most I hear not ordering from Vans. Is it price or service or something > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > >> >> America's in Oklahoma, on the other hand, has been first rate. >> >> >> -----Original Message----- From: N306PB >> Sent: Tuesday, July 12, 2011 10:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Engine Referral >> >> >> As Oshkosh approaches I am sure there are some out there looking for an >> engine. Should you be tempted by the New Firewall Forward out of Colorado >> contact me privately for a referral. In a nutshell, dealing with them has >> been the most frustrating, disappointing, and infuriating experience of >> my entire RV-10 build. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=346091#346091 >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 12, 2011
Many do order form Vans but you are getting a Vanilla set up. With specialized engine builders you get what you want including custom color, chrome, Cold Induction etc... You can specify ignition style, preferred starter and alternator that sort of thing. Often the $ differences are minimal but these options can add up. I am a fan of BPE as they have treated me and others I know exceptionally well and build a heck of an engine with their decades of experience. These days there are not that many really bad builders because word gets around quickly. No reason to use an unknown builder as the savings can't be that significant. The prop is another story. You have to decide what you want to be swinging. If it's the Hartzell BA prop then the Vans one time discounted price with your kit purchase is probably the best deal. I'm not sure about other prop pricing offered by Vans. I personally think the BA prop is by far the best value/performance for the $. Robin On Tue, Jul 12, 2011 at 12:01 PM, Sean Stephens wrote: > > I'm about to the point of ordering engine and prop and was curious as to > most I hear not ordering from Vans. Is it price or service or something > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > > > > America's in Oklahoma, on the other hand, has been first rate. > > > > > > -----Original Message----- From: N306PB > > Sent: Tuesday, July 12, 2011 10:17 AM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Engine Referral > > > > > > As Oshkosh approaches I am sure there are some out there looking for an > engine. Should you be tempted by the New Firewall Forward out of Colorado > contact me privately for a referral. In a nutshell, dealing with them has > been the most frustrating, disappointing, and infuriating experience of my > entire RV-10 build. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2011
I will tell you that I went the way I did because I researched narrow deck versus wide deck and was told that narrow was a better core due to cracking. So, by default new and Vans were removed from my options. I also have the Eci cylinders, I was concerned with the issues they were having but was assured that it was not an issue I would need to worry about. I hear I get about another 2hp per cylinder going this way, I dont care about the power just cost and reliability over the long run. See what Vans offers for OSH, they usually have a great package when you buy both prop and engine, $1000 off I believe. I bought the prop from Vans BTW. Pascal -----Original Message----- From: Sean Stephens Sent: Tuesday, July 12, 2011 12:01 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > America's in Oklahoma, on the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for an > engine. Should you be tempted by the New Firewall Forward out of Colorado > contact me privately for a referral. In a nutshell, dealing with them has > been the most frustrating, disappointing, and infuriating experience of my > entire RV-10 build. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > ________________________________________________________________________________
Date: Jul 12, 2011
I wonder how you did so well to get it within $2000? Without any airshow deals, it was like $3000 more for certified, and about $6000 more than the Vans experimental when I researched this option. if I throw in the airshow special of $1000 off package that gets up there even more. For $2000, there is no doubt Thunderbolt engines is the way to go, but for someone like me that couldn't care if it's certified or experimental when the rest of my aircraft is experimental, $7000 more was not an option. With that said I have most of this in my engine for far less than a Vans certified. BUT it is experimental. I support the decision you made, and I would have considered it as well for such a small amount, but for someone looking for an engine I need to mention that they may be surprised to see the price difference being a little more than you were able to get it for. If anyone is wondering Vans offers the engines at OEM prices, hence only being able to get one per builder number. I discovered the price was about the same a some rebuilds out there. It's a good deal for a simple vanilla IO540. -----Original Message----- From: John Cumins Sent: Tuesday, July 12, 2011 12:22 PM Subject: RE: RV10-List: Engine Referral I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > America's in Oklahoma, on the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > ________________________________________________________________________________
Date: Jul 12, 2011
I'm seeing $1,500 - $2,000 too. Nothing in the range of 5-6K. On Tue, Jul 12, 2011 at 3:11 PM, Pascal wrote: > > I wonder how you did so well to get it within $2000? Without any airshow > deals, it was like $3000 more for certified, and about $6000 more than the > Vans experimental when I researched this option. if I throw in the airshow > special of $1000 off package that gets up there even more. > For $2000, there is no doubt Thunderbolt engines is the way to go, but for > someone like me that couldn't care if it's certified or experimental when > the rest of my aircraft is experimental, $7000 more was not an option. With > that said I have most of this in my engine for far less than a Vans > certified. BUT it is experimental. > I support the decision you made, and I would have considered it as well for > such a small amount, but for someone looking for an engine I need to mention > that they may be surprised to see the price difference being a little more > than you were able to get it for. > If anyone is wondering Vans offers the engines at OEM prices, hence only > being able to get one per builder number. I discovered the price was about > the same a some rebuilds out there. It's a good deal for a simple vanilla > IO540. > > > -----Original Message----- From: John Cumins > Sent: Tuesday, July 12, 2011 12:22 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Engine Referral > > > I did a lot of research while I was at OSH last year. If I wanted a stock > engine new I would go Vans route. Since I want the most for my bucks, > like > balancing to less then a gram, port and flow matching approx 30-40 hp for > free, and light weight started, and Air Performance Fuel Injection I would > go with a Lycombing Thunder custom built engine. For approx. $1000-2000 > difference in price from Vans, I get a lot more and it is totally brand new > with full factory warranty. > > I looked at all vendors and build a spreadsheet and dollar to quality and > performance and being 100% new Thunder is hard to Beat. > > > John Cumins > 40864 Wings > > > -----Original Message----- > From: owner-rv10-list-server@**matronics.com<owner-rv10-list-server(at)matronics.com> > [mailto:owner-rv10-list-**server(at)matronics.com] > On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2011 12:02 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Engine Referral > > > I'm about to the point of ordering engine and prop and was curious as to > most I hear not ordering from Vans. Is it price or service or something > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > >> >> America's in Oklahoma, on the other hand, has been first rate. >> >> >> -----Original Message----- From: N306PB >> Sent: Tuesday, July 12, 2011 10:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Engine Referral >> >> >> As Oshkosh approaches I am sure there are some out there looking for an >> > engine. Should you be tempted by the New Firewall Forward out of Colorado > contact me privately for a referral. In a nutshell, dealing with them has > been the most frustrating, disappointing, and infuriating experience of my > entire RV-10 build. > >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=346091#346091> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Andair Fuel Pump & Filter
From: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
Date: Jul 12, 2011
Hi, is anyone already flying with the Andair fuel pump & filter installation in the RV-10? I wonder why there are two "return" lines in the original setup but in the Andair setup only the internal pump return line. Any ideas? Cheers Mike -------- RV-10 builder (interior,avionics, wiring) #511 Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=346115#346115 ________________________________________________________________________________
Date: Jul 12, 2011
The thunderbolt is not a certified engine it comes from there custom shop non certified. It was basically the sam3e price as BPE and the Company from Canada. I want all new parts and BPI cannot due a new 10540 only rebuilds since Lycoming will not see the new engines as a kit any more. Yes all company's were offering a OSH discount so when one is ready to order OSH is the place to buy that's for sure. John Cumins -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Tuesday, July 12, 2011 1:11 PM Subject: Re: RV10-List: Engine Referral I wonder how you did so well to get it within $2000? Without any airshow deals, it was like $3000 more for certified, and about $6000 more than the Vans experimental when I researched this option. if I throw in the airshow special of $1000 off package that gets up there even more. For $2000, there is no doubt Thunderbolt engines is the way to go, but for someone like me that couldn't care if it's certified or experimental when the rest of my aircraft is experimental, $7000 more was not an option. With that said I have most of this in my engine for far less than a Vans certified. BUT it is experimental. I support the decision you made, and I would have considered it as well for such a small amount, but for someone looking for an engine I need to mention that they may be surprised to see the price difference being a little more than you were able to get it for. If anyone is wondering Vans offers the engines at OEM prices, hence only being able to get one per builder number. I discovered the price was about the same a some rebuilds out there. It's a good deal for a simple vanilla IO540. -----Original Message----- From: John Cumins Sent: Tuesday, July 12, 2011 12:22 PM Subject: RE: RV10-List: Engine Referral I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > > America's in Oklahoma, on the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for > an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > ________________________________________________________________________________
Date: Jul 12, 2011
Also when one purchases a core for 6-8k then rebuilds it, which I can do my self since I am a a&p, and have done a few. The cost difference used ver new is not that much difference. And I am putting all new equipment in my -10 so going used on the engine did not get past the auditor (wife). She was firm about going all new. And I have to agree, John Cumins 40864 Wings From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Tuesday, July 12, 2011 1:21 PM Subject: Re: RV10-List: Engine Referral I'm seeing $1,500 - $2,000 too. Nothing in the range of 5-6K. On Tue, Jul 12, 2011 at 3:11 PM, Pascal wrote: I wonder how you did so well to get it within $2000? Without any airshow deals, it was like $3000 more for certified, and about $6000 more than the Vans experimental when I researched this option. if I throw in the airshow special of $1000 off package that gets up there even more. For $2000, there is no doubt Thunderbolt engines is the way to go, but for someone like me that couldn't care if it's certified or experimental when the rest of my aircraft is experimental, $7000 more was not an option. With that said I have most of this in my engine for far less than a Vans certified. BUT it is experimental. I support the decision you made, and I would have considered it as well for such a small amount, but for someone looking for an engine I need to mention that they may be surprised to see the price difference being a little more than you were able to get it for. If anyone is wondering Vans offers the engines at OEM prices, hence only being able to get one per builder number. I discovered the price was about the same a some rebuilds out there. It's a good deal for a simple vanilla IO540. -----Original Message----- From: John Cumins Sent: Tuesday, July 12, 2011 12:22 PM Subject: RE: RV10-List: Engine Referral I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: America's in Oklahoma, on the other hand, has been first rate. -----Original Message----- From: N306PB Sent: Tuesday, July 12, 2011 10:17 AM Subject: RV10-List: Engine Referral As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346091#346091 =================================== arget="_blank">http://www.matronics.com/Navigator?RV10-List =================================== http://forums.matronics.com =================================== le, List Admin. ="_blank">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Jul 12, 2011
Must be me than.. but I just looked and the difference is as follows: Thunderbolt website- Base Price: YIO-540-D4A5 Fuel System: Injected Aerobatic Kit: No Horsepower: 260 Displacement (Cubic Inches): 540 Stock Compression Ratio: 8.5:1 Cylinder Type: Parallel Valve $49,500.00 Vans Website: Experimental IO-540 260HP (RV-10 only) Part Number = EA XIO-540-D4A5 RT Price = $42300.00 IO-540 260HP (RV-10 only) Part Number = EA IO-540-D4A5 RT Price = $46050.00 This looks about the same as it was when I was researching the engines. I can only imagine that if one calls Thunderbolt the difference is less than? From: Phillip Perry Sent: Tuesday, July 12, 2011 1:21 PM Subject: Re: RV10-List: Engine Referral I'm seeing $1,500 - $2,000 too. Nothing in the range of 5-6K. On Tue, Jul 12, 2011 at 3:11 PM, Pascal wrote: I wonder how you did so well to get it within $2000? Without any airshow deals, it was like $3000 more for certified, and about $6000 more than the Vans experimental when I researched this option. if I throw in the airshow special of $1000 off package that gets up there even more. For $2000, there is no doubt Thunderbolt engines is the way to go, but for someone like me that couldn't care if it's certified or experimental when the rest of my aircraft is experimental, $7000 more was not an option. With that said I have most of this in my engine for far less than a Vans certified. BUT it is experimental. I support the decision you made, and I would have considered it as well for such a small amount, but for someone looking for an engine I need to mention that they may be surprised to see the price difference being a little more than you were able to get it for. If anyone is wondering Vans offers the engines at OEM prices, hence only being able to get one per builder number. I discovered the price was about the same a some rebuilds out there. It's a good deal for a simple vanilla IO540. -----Original Message----- From: John Cumins Sent: Tuesday, July 12, 2011 12:22 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: Engine Referral I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: America's in Oklahoma, on the other hand, has been first rate. -----Original Message----- From: N306PB Sent: Tuesday, July 12, 2011 10:17 AM To: rv10-list(at)matronics.com Subject: RV10-List: Engine Referral As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346091#346091 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 12, 2011
As an expatriate living/working outside the USA for 16 years, I would caution anyone doing business outside their country boundaries. If you want history just check the problems getting Crossflow firewall forward engines in the USA after they have been paid to the company in Canada. Legal action across state boundaries is nothing compared to another country's legal system. ----- Original Message ----- From: "John Cumins" <jcumins(at)jcis.net> Sent: Tuesday, July 12, 2011 1:27 PM Subject: RE: RV10-List: Engine Referral > > The thunderbolt is not a certified engine it comes from there custom shop > non certified. It was basically the sam3e price as BPE and the Company > from > Canada. I want all new parts and BPI cannot due a new 10540 only rebuilds > since Lycoming will not see the new engines as a kit any more. > > Yes all company's were offering a OSH discount so when one is ready to > order > OSH is the place to buy that's for sure. > > > John Cumins > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal > Sent: Tuesday, July 12, 2011 1:11 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Engine Referral > > > I wonder how you did so well to get it within $2000? Without any airshow > deals, it was like $3000 more for certified, and about $6000 more than the > Vans experimental when I researched this option. if I throw in the airshow > special of $1000 off package that gets up there even more. > For $2000, there is no doubt Thunderbolt engines is the way to go, but for > someone like me that couldn't care if it's certified or experimental when > the rest of my aircraft is experimental, $7000 more was not an option. > With > that said I have most of this in my engine for far less than a Vans > certified. BUT it is experimental. > I support the decision you made, and I would have considered it as well > for > such a small amount, but for someone looking for an engine I need to > mention > that they may be surprised to see the price difference being a little more > than you were able to get it for. > If anyone is wondering Vans offers the engines at OEM prices, hence only > being able to get one per builder number. I discovered the price was about > the same a some rebuilds out there. It's a good deal for a simple vanilla > IO540. > > > -----Original Message----- > From: John Cumins > Sent: Tuesday, July 12, 2011 12:22 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Engine Referral > > > I did a lot of research while I was at OSH last year. If I wanted a stock > engine new I would go Vans route. Since I want the most for my bucks, > like > balancing to less then a gram, port and flow matching approx 30-40 hp for > free, and light weight started, and Air Performance Fuel Injection I would > go with a Lycombing Thunder custom built engine. For approx. $1000-2000 > difference in price from Vans, I get a lot more and it is totally brand > new > with full factory warranty. > > I looked at all vendors and build a spreadsheet and dollar to quality and > performance and being 100% new Thunder is hard to Beat. > > > John Cumins > 40864 Wings > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2011 12:02 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Engine Referral > > > I'm about to the point of ordering engine and prop and was curious as to > most I hear not ordering from Vans. Is it price or service or something > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: > >> >> America's in Oklahoma, on the other hand, has been first rate. >> >> >> -----Original Message----- From: N306PB >> Sent: Tuesday, July 12, 2011 10:17 AM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Engine Referral >> >> >> As Oshkosh approaches I am sure there are some out there looking for >> an > engine. Should you be tempted by the New Firewall Forward out of Colorado > contact me privately for a referral. In a nutshell, dealing with them has > been the most frustrating, disappointing, and infuriating experience of my > entire RV-10 build. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=346091#346091 >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 12, 2011
Although we cannot offer new engines anymore because of the end of our contractual agreement with Lycoming, I can tell you that an overhauled IO-540 built in this configuration to factory new limits, including new cylinders, starter, mags, and new fuel injection currently costs $10,000 less than the Thunderbolt option. I understand that Lycoming very recently passed on a substantial price increase to their remaining "kit" engine shops. That may be where the difference is seen between a new engine from a custom builder and Thunderbolt or Van's assembly line factory engine. For you new factory engine owners, you might be advised to check Service Bulletin 240U, in which Lycoming requires the replacement of roller tappets at prop strike, and they are not cheap. Ouch! Rhonda Barrett-Bewley Barrett Precision Engines, Inc. ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Tuesday, July 12, 2011 3:55 PM Subject: Re: RV10-List: Engine Referral Must be me than.. but I just looked and the difference is as follows: Thunderbolt website- Base Price: YIO-540-D4A5 Fuel System: Injected Aerobatic Kit: No Horsepower: 260 Displacement (Cubic Inches): 540 Stock Compression Ratio: 8.5:1 Cylinder Type: Parallel Valve $49,500.00 Vans Website: Experimental IO-540 260HP (RV-10 only) Part Number = EA XIO-540-D4A5 RT Price = $42300.00 IO-540 260HP (RV-10 only) Part Number = EA IO-540-D4A5 RT Price = $46050.00 This looks about the same as it was when I was researching the engines. I can only imagine that if one calls Thunderbolt the difference is less than? From: Phillip Perry <mailto:philperry9(at)gmail.com> Sent: Tuesday, July 12, 2011 1:21 PM Subject: Re: RV10-List: Engine Referral I'm seeing $1,500 - $2,000 too. Nothing in the range of 5-6K. On Tue, Jul 12, 2011 at 3:11 PM, Pascal wrote: I wonder how you did so well to get it within $2000? Without any airshow deals, it was like $3000 more for certified, and about $6000 more than the Vans experimental when I researched this option. if I throw in the airshow special of $1000 off package that gets up there even more. For $2000, there is no doubt Thunderbolt engines is the way to go, but for someone like me that couldn't care if it's certified or experimental when the rest of my aircraft is experimental, $7000 more was not an option. With that said I have most of this in my engine for far less than a Vans certified. BUT it is experimental. I support the decision you made, and I would have considered it as well for such a small amount, but for someone looking for an engine I need to mention that they may be surprised to see the price difference being a little more than you were able to get it for. If anyone is wondering Vans offers the engines at OEM prices, hence only being able to get one per builder number. I discovered the price was about the same a some rebuilds out there. It's a good deal for a simple vanilla IO540. -----Original Message----- From: John Cumins Sent: Tuesday, July 12, 2011 12:22 PM Subject: RE: RV10-List: Engine Referral I did a lot of research while I was at OSH last year. If I wanted a stock engine new I would go Vans route. Since I want the most for my bucks, like balancing to less then a gram, port and flow matching approx 30-40 hp for free, and light weight started, and Air Performance Fuel Injection I would go with a Lycombing Thunder custom built engine. For approx. $1000-2000 difference in price from Vans, I get a lot more and it is totally brand new with full factory warranty. I looked at all vendors and build a spreadsheet and dollar to quality and performance and being 100% new Thunder is hard to Beat. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Tuesday, July 12, 2011 12:02 PM Subject: Re: RV10-List: Engine Referral I'm about to the point of ordering engine and prop and was curious as to most I hear not ordering from Vans. Is it price or service or something else? Sean #40303 Sent from my iPhone On Jul 12, 2011, at 1:36 PM, "Pascal" wrote: America's in Oklahoma, on the other hand, has been first rate. -----Original Message----- From: N306PB Sent: Tuesday, July 12, 2011 10:17 AM Subject: RV10-List: Engine Referral As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346091#346091 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s .com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 12, 2011
So far I have been really happy with my Aerosport Power IO-540-N1A5 Almost 50 hours on it. Sent from my iPhone On Jul 12, 2011, at 12:17, "N306PB" wrote: > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 12, 2011
Barrett builds great engines Sent from my Verizon Wireless BlackBerry -----Original Message----- From: "Rhonda Bewley" <Rhonda(at)bpaengines.com> Sender: owner-rv10-list-server(at)matronics.com Date: Tue, 12 Jul 2011 16:20:07 Subject: RE: RV10-List: Engine Referral This is a multi-part message in MIME format. ________________________________________________________________________________
Date: Jul 12, 2011
SGFzIGFueW9uZSBtZW50aW9uZWQgYSByZWJ1aWx0IEJhcnJldHQgaXMgb2Z0ZW4gYmV0dGVyIHRo YW4gYSBicmFuZCBuZXcgZmFjdG9yeSBidWlsdCBWQU5TLiAgSXQganVzdCBtaWdodCBoYXZlIG9u ZSBsZXNzIHJlYnVpbGQgaW4gaXRzIGxpZmVjeWNsZSBidXQgdGhlIHRvbGVyYW5jZXMgYXJlIGdy ZWF0LiAgTmV3IGVuZ2luZXMgYXJlIGFsc28gcHJvbmUgdG8gIkJyZWFrLUluIi4gIEEgUHJlLWRl bGl2ZXJ5IGR5bm8gcnVuLCBub3cgdGhhdCBzZXRzIGJ1aWxkZXJzIGFwYXJ0LiAgQWlyc2hvdyBw ZXJmb3JtZXJzIGFyZSBhIGdvb2QgYmVuY2htYXJrIGZvciBwaWxvdHMgd2hvIGtub3cgZW5naW5l cyBhbmQgaGFuZyB0aGVpciBsaXZlcyBvbiB0aGUgZW5naW5lIGFuZCBwcm9wIGJsYWRlcy4gIERv IHJlc2VhcmNoLiAgR2V0IHdoYXQgeW91IHBheSBmb3IuDQoNCiANCg0KSm9obg0KDQogDQoNCiAN Cg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3du ZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Ygc3BvcnRmbHlp bmdAeWFob28uY29tDQpTZW50OiBUdWVzZGF5LCBKdWx5IDEyLCAyMDExIDI6MzEgUE0NClRvOiBy djEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogRW5naW5lIFJl ZmVycmFsDQoNCiANCg0KQmFycmV0dCBidWlsZHMgZ3JlYXQgZW5naW5lcyANCg0KU2VudCBmcm9t IG15IFZlcml6b24gV2lyZWxlc3MgQmxhY2tCZXJyeQ0KDQpfX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fXw0KDQpGcm9tOiAiUmhvbmRhIEJld2xleSIgPFJob25kYUBicGFlbmdpbmVzLmNv bT4gDQoNClNlbmRlcjogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIA0KDQpE YXRlOiBUdWUsIDEyIEp1bCAyMDExIDE2OjIwOjA3IC0wNTAwDQoNClRvOiA8cnYxMC1saXN0QG1h dHJvbmljcy5jb20+DQoNClJlcGx5VG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIA0KDQpTdWJq ZWN0OiBSRTogUlYxMC1MaXN0OiBFbmdpbmUgUmVmZXJyYWwNCg0KIA0KDQpBbHRob3VnaCB3ZSBj YW5ub3Qgb2ZmZXIgbmV3ID0gZW5naW5lcyBhbnltb3JlIGJlY2F1c2Ugb2YgdGhlIGVuZCBvZiBv dXIgY29udHJhY3R1YWwgYWdyZWVtZW50IHdpdGggTHljb21pbmcsIEkgPSBjYW4gdGVsbCB5b3Ug dGhhdCBhbiBvdmVyaGF1bGVkIElPLTU0MCBidWlsdCBpbiB0aGlzIGNvbmZpZ3VyYXRpb24gdG8g PSBmYWN0b3J5IG5ldyBsaW1pdHMsIGluY2x1ZGluZyBuZXcgY3lsaW5kZXJzLCBzdGFydGVyLCBt YWdzLCBhbmQgbmV3IGZ1ZWwgaW5qZWN0aW9uIGN1cnJlbnRseSBjb3N0cyAkMTAsMDAwIGxlc3Mg dGhhbiB0aGUgVGh1bmRlcmJvbHQgPSBvcHRpb24uDQoNCiANCg0KSSB1bmRlcnN0YW5kIHRoYXQg THljb21pbmcgdmVyeSA9IHJlY2VudGx5IHBhc3NlZCBvbiBhIHN1YnN0YW50aWFsIHByaWNlIGlu Y3JlYXNlIHRvIHRoZWlyIHJlbWFpbmluZyA9IOKAnGtpdOKAnSBlbmdpbmUgc2hvcHMuICBUaGF0 IG1heSBiZSB3aGVyZSB0aGUgZGlmZmVyZW5jZSBpcyBzZWVuIGJldHdlZW4gYSA9IG5ldyBlbmdp bmUgZnJvbSBhIGN1c3RvbSBidWlsZGVyIGFuZCBUaHVuZGVyYm9sdCBvciBWYW7igJlzIGFzc2Vt Ymx5ID0gbGluZSBmYWN0b3J5IGVuZ2luZS4NCg0KIA0KDQpGb3IgeW91IG5ldyBmYWN0b3J5IGVu Z2luZSBvd25lcnMsID0geW91IG1pZ2h0IGJlIGFkdmlzZWQgdG8gY2hlY2sgU2VydmljZSBCdWxs ZXRpbiAyNDBVLCBpbiB3aGljaCBMeWNvbWluZyA9IHJlcXVpcmVzIHRoZSByZXBsYWNlbWVudCBv ZiByb2xsZXIgdGFwcGV0cyBhdCBwcm9wIHN0cmlrZSwgYW5kIHRoZXkgYXJlIG5vdCBjaGVhcC4g PSAgT3VjaCENCg0KIA0KDQpSaG9uZGEgPSBCYXJyZXR0LUJld2xleQ0KDQpCYXJyZXR0IFByZWNp c2lvbiBFbmdpbmVzLCA9IEluYy4NCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18N Cg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tID0gW21haWx0bzpv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBQYXNjYWwN ClNlbnQ6IFR1ZXNkYXksIEp1bHkgMTIsID0gMjAxMSAzOjU1IFBNDQpUbzogcnYxMC1saXN0QG1h dHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6ID0gRW5naW5lIFJlZmVycmFsDQoN CiANCg0KTXVzdCBiZSBtZSA9IHRoYW4uLiBidXQgSSBqdXN0IGxvb2tlZCBhbmQgdGhlIGRpZmZl cmVuY2UgaXMgYXMgPSBmb2xsb3dzOg0KDQpUaHVuZGVyYm9sdCA9IHdlYnNpdGUtIA0KDQpCYXNl ID0gUHJpY2U6IFlJTy01NDAtRDRBNSA9IA0KDQpGdWVsID0gU3lzdGVtOg0KDQpJbmplY3RlZA0K DQpBZXJvYmF0aWMgPSBLaXQ6DQoNCk5vDQoNCkhvcnNlcG93ZXI6DQoNCjI2MA0KDQpEaXNwbGFj ZW1lbnQgKEN1YmljIEluY2hlcyk6DQoNCjU0MA0KDQpTdG9jayA9IENvbXByZXNzaW9uIFJhdGlv Og0KDQo4LjU6MTw9IC9mb250Pg0KDQpDeWxpbmRlciA9IFR5cGU6DQoNClBhcmFsbGVsID0gVmFs dmUNCg0KJDQ5LDUwMC4wMA0KDQogDQoNClZhbnMgPSBXZWJzaXRlOg0KDQpFeHBlcmltZW50YWwg SU8tNTQwIDI2MEhQIChSVi0xMCA9IG9ubHkpDQpQYXJ0IE51bWJlciA9M0QgRUEgWElPLTU0MC1E NEE1ID0gUlQNClByaWNlID0zRCA9ICQ0MjMwMC4wMCANCg0KIA0KDQpJTy01NDAgMjYwSFAgKFJW LTEwID0gb25seSkNClBhcnQgTnVtYmVyID0zRCBFQSBJTy01NDAtRDRBNSA9IFJUDQpQcmljZSA9 M0QgPSAkNDYwNTAuMDAgDQoNCiANCg0KIA0KDQogDQoNClRoaXMgbG9va3MgPSBhYm91dCB0aGUg c2FtZSBhcyBpdCB3YXMgd2hlbiBJIHdhcyByZXNlYXJjaGluZyB0aGUgZW5naW5lcy4NCg0KSSBj YW4gb25seSA9IGltYWdpbmUgdGhhdCBpZiBvbmUgY2FsbHMgVGh1bmRlcmJvbHQgdGhlIGRpZmZl cmVuY2UgaXMgbGVzcyA9IHRoYW4/DQoNCiANCg0KIA0KDQogDQoNCkZyb206IFBoaWxsaXAgUGVy cnkgDQoNClNlbnQ6IFR1ZXNkYXksIEp1bHkgPSAxMiwgMjAxMSAxOjIxIFBNDQoNClRvOiBydjEw LWxpc3RAbWF0cm9uaWNzLmNvbSANCg0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogRW5naW5lIFJl ZmVycmFsDQoNCiANCg0KSSdtIHNlZWluZyAkMSw1MDAgLSAkMiwwMDAgdG9vLiAgIE5vdGhpbmcg aW4gdGhlIHJhbmdlIG9mID0gNS02Sy4NCg0KT24gVHVlLCBKdWwgPSAxMiwgMjAxMSBhdCAzOjEx IFBNLCBQYXNjYWwgPHJ2MTBmbHllckB2ZXJpem9uLm5ldD4gd3JvdGU6DQoNCi0tPiBSVjEwLUxp c3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJQYXNjYWwiIDxydjEwZmx5ZXJAdmVyaXpvbi5uZXQ+DQoN Ckkgd29uZGVyIGhvdyB5b3UgZGlkIHNvIHdlbGwgdG8gZ2V0IGl0IHdpdGhpbiAkMjAwMD8gV2l0 aG91dCBhbnkgYWlyc2hvdyA9IGRlYWxzLCBpdCB3YXMgbGlrZSAkMzAwMCBtb3JlIGZvciBjZXJ0 aWZpZWQsIGFuZCBhYm91dCAkNjAwMCBtb3JlIHRoYW4gdGhlIFZhbnMgZXhwZXJpbWVudGFsIHdo ZW4gSSByZXNlYXJjaGVkIHRoaXMgb3B0aW9uLiBpZiBJIHRocm93IGluIHRoZSBhaXJzaG93ID0g c3BlY2lhbCBvZiAkMTAwMCBvZmYgcGFja2FnZSB0aGF0IGdldHMgdXAgdGhlcmUgZXZlbiBtb3Jl Lg0KRm9yICQyMDAwLCB0aGVyZSBpcyBubyBkb3VidCBUaHVuZGVyYm9sdCBlbmdpbmVzIGlzIHRo ZSB3YXkgdG8gZ28sIGJ1dCA9IGZvciBzb21lb25lIGxpa2UgbWUgdGhhdCBjb3VsZG4ndCBjYXJl IGlmIGl0J3MgY2VydGlmaWVkIG9yIGV4cGVyaW1lbnRhbCA9IHdoZW4gdGhlIHJlc3Qgb2YgbXkg YWlyY3JhZnQgaXMgZXhwZXJpbWVudGFsLCAkNzAwMCBtb3JlIHdhcyBub3QgYW4gb3B0aW9uLiBX aXRoID0gdGhhdCBzYWlkIEkgaGF2ZSBtb3N0IG9mIHRoaXMgaW4gbXkgZW5naW5lIGZvciBmYXIg bGVzcyB0aGFuIGEgVmFucyA9IGNlcnRpZmllZC4gQlVUIGl0IGlzIGV4cGVyaW1lbnRhbC4NCkkg c3VwcG9ydCB0aGUgZGVjaXNpb24geW91IG1hZGUsIGFuZCBJIHdvdWxkIGhhdmUgY29uc2lkZXJl ZCBpdCBhcyB3ZWxsID0gZm9yIHN1Y2ggYSBzbWFsbCBhbW91bnQsIGJ1dCBmb3Igc29tZW9uZSBs b29raW5nIGZvciBhbiBlbmdpbmUgSSBuZWVkIHRvID0gbWVudGlvbiB0aGF0IHRoZXkgbWF5IGJl IHN1cnByaXNlZCB0byBzZWUgdGhlIHByaWNlIGRpZmZlcmVuY2UgYmVpbmcgYSBsaXR0bGUgPSBt b3JlIHRoYW4geW91IHdlcmUgYWJsZSB0byBnZXQgaXQgZm9yLg0KSWYgYW55b25lIGlzIHdvbmRl cmluZyBWYW5zIG9mZmVycyB0aGUgZW5naW5lcyBhdCBPRU0gcHJpY2VzLCBoZW5jZSBvbmx5ID0g YmVpbmcgYWJsZSB0byBnZXQgb25lIHBlciBidWlsZGVyIG51bWJlci4gSSBkaXNjb3ZlcmVkIHRo ZSBwcmljZSB3YXMgYWJvdXQgdGhlID0gc2FtZSBhIHNvbWUgcmVidWlsZHMgb3V0IHRoZXJlLiBJ dCdzIGEgZ29vZCBkZWFsIGZvciBhIHNpbXBsZSB2YW5pbGxhID0gSU81NDAuDQoNCg0KLS0tLS1P cmlnaW5hbCBNZXNzYWdlLS0tLS0gRnJvbTogSm9obiBDdW1pbnMNClNlbnQ6IFR1ZXNkYXksIEp1 bHkgMTIsIDIwMTEgMTI6MjIgUE0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVj dDogUkU6IFJWMTAtTGlzdDogRW5naW5lIFJlZmVycmFsDQoNCi0tPiBSVjEwLUxpc3QgbWVzc2Fn ZSBwb3N0ZWQgYnk6ICJKb2huIEN1bWlucyIgPGpjdW1pbnNAamNpcy5uZXQ+DQoNCkkgZGlkIGEg bG90IG9mIHJlc2VhcmNoIHdoaWxlIEkgd2FzIGF0IE9TSCBsYXN0IHllYXIuICBJZiBJIHdhbnRl ZCBhIHN0b2NrDQplbmdpbmUgbmV3IEkgd291bGQgZ28gVmFucyByb3V0ZS4gIFNpbmNlIEkgd2Fu dCAgdGhlIG1vc3QgZm9yID0gbXkgYnVja3MsIGxpa2UNCmJhbGFuY2luZyB0byBsZXNzIHRoZW4g YSBncmFtLCBwb3J0IGFuZCBmbG93IG1hdGNoaW5nIGFwcHJveCAgMzAtNDAgPSBocCBmb3INCmZy ZWUsIGFuZCBsaWdodCB3ZWlnaHQgc3RhcnRlZCwgYW5kIEFpciBQZXJmb3JtYW5jZSBGdWVsIElu amVjdGlvbiBJID0gd291bGQNCmdvIHdpdGggYSBMeWNvbWJpbmcgVGh1bmRlciBjdXN0b20gYnVp bHQgZW5naW5lLiAgRm9yIGFwcHJveC4gPSAkMTAwMC0yMDAwDQpkaWZmZXJlbmNlIGluIHByaWNl IGZyb20gVmFucywgSSBnZXQgYSBsb3QgbW9yZSBhbmQgaXQgaXMgdG90YWxseSBicmFuZCA9IG5l dw0Kd2l0aCBmdWxsIGZhY3Rvcnkgd2FycmFudHkuDQoNCkkgbG9va2VkIGF0IGFsbCB2ZW5kb3Jz IGFuZCBidWlsZCBhIHNwcmVhZHNoZWV0IGFuZCBkb2xsYXIgdG8gcXVhbGl0eSA9IGFuZA0KcGVy Zm9ybWFuY2UgYW5kIGJlaW5nIDEwMCUgbmV3IFRodW5kZXIgaXMgaGFyZCB0byBCZWF0Lg0KDQoN CkpvaG4gQ3VtaW5zDQo0MDg2NCBXaW5ncw0KDQoNCg0KLS0tLS1PcmlnaW5hbCBNZXNzYWdlLS0t LS0NCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KW21haWx0bzpv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBTZWFuIFN0 ZXBoZW5zDQpTZW50OiBUdWVzZGF5LCBKdWx5IDEyLCAyMDExIDEyOjAyIFBNDQpUbzogcnYxMC1s aXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IEVuZ2luZSBSZWZlcnJh bA0KDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBTZWFuIFN0ZXBoZW5zIDxzZWFu QHN0ZXBoZW5zdmlsbGUuY29tPg0KDQpJJ20gYWJvdXQgdG8gdGhlIHBvaW50IG9mIG9yZGVyaW5n IGVuZ2luZSBhbmQgcHJvcCBhbmQgd2FzIGN1cmlvdXMgYXMgPSB0bw0KbW9zdCBJIGhlYXIgbm90 IG9yZGVyaW5nIGZyb20gVmFucy4gIElzIGl0IHByaWNlIG9yIHNlcnZpY2Ugb3IgPSBzb21ldGhp bmcNCmVsc2U/DQoNClNlYW4gIzQwMzAzDQoNClNlbnQgZnJvbSBteSBpUGhvbmUNCg0KT24gSnVs IDEyLCAyMDExLCBhdCAxOjM2IFBNLCAiUGFzY2FsIiA8cnYxMGZseWVyQHZlcml6b24ubmV0PiB3 cm90ZToNCg0KLS0+ID0gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiUGFzY2FsIiA8cnYx MGZseWVyQHZlcml6b24ubmV0Pg0KDQpBbWVyaWNhJ3MgaW4gPSBPa2xhaG9tYSwgb24gPSB0aGUg b3RoZXIgaGFuZCwgaGFzIGJlZW4gZmlyc3QgcmF0ZS4NCg0KDQotLS0tLU9yaWdpbmFsIE1lc3Nh Z2UtLS0tLSBGcm9tOiBOMzA2UEINClNlbnQ6IFR1ZXNkYXksIEp1bHkgMTIsIDIwMTEgMTA6MTcg QU0NClRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUlYxMC1MaXN0OiBFbmdp bmUgUmVmZXJyYWwNCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTogIk4zMDZQQiIg PHdyYXRoYnVuQGlodHcuY29tPg0KDQpBcyBPc2hrb3NoIGFwcHJvYWNoZXMgSSBhbSBzdXJlIHRo ZXJlIGFyZSBzb21lIG91dCB0aGVyZSBsb29raW5nIGZvciA9IGFuDQoNCmVuZ2luZS4gPSBTaG91 bGQgeW91IGJlIHRlbXB0ZWQgYnkgdGhlIE5ldyBGaXJld2FsbCBGb3J3YXJkIG91dCBvZiBDb2xv cmFkbw0KY29udGFjdCBtZSBwcml2YXRlbHkgZm9yIGEgcmVmZXJyYWwuIEluIGEgbnV0c2hlbGws IGRlYWxpbmcgd2l0aCB0aGVtID0gaGFzDQpiZWVuIHRoZSBtb3N0IGZydXN0cmF0aW5nLCBkaXNh cHBvaW50aW5nLCBhbmQgaW5mdXJpYXRpbmcgZXhwZXJpZW5jZSBvZiA9IG15DQplbnRpcmUgUlYt MTAgYnVpbGQuDQoNCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTNEMzQ2MDkxIzM0PSA2MDkx DQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCj0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KYXJnZXQ9M0QiX2JsYW5rIj5odHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzPSB0DQo9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0QNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEDQpsZSwgTGlzdCBBZG1pbi4NCj0zRCJfYmxhbmsiPmh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRA0KDQoNCg0KDQoNCiANCg0KIDw9DQovcHJlPg0KIA0KaHJlZj0zRCJodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGk9DQpzdCI+aHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCmhyZWY9M0QiaHR0cDovL2ZvcnVtcy5tYXRy b25pY3MuY29tIj5odHRwOj0NCi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCmhyZWY9M0QiaHR0cDov L3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbiI9DQo7Pmh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jDQogDQogDQogDQogDQogDQogDQogPD0NCi9wcmU+DQogDQpodHRwOi8vd3d3Lm1hdHJv bmljPQ0Kcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KPD0NCmZvbnQNCnNpemU9M0QyIGNvbG9y PTNEYmxhY2sgZmFjZT0zRCJDb3VyaWVyIE5ldyI+DQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5j b209DQpodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vYz0NCm9udHJpYnV0aW9uDQogDQogDQogDQog DQogDQogDQogDQogDQogDQpfLT0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KXy09M0QgICAgICAgICAgLSBUaGUgUlYxMC1M aXN0IEVtYWlsIEZvcnVtIC0NCl8tPTNEIFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMg TmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09M0QgdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBh cyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8tPTNEIEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KXy09M0QgUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVj aCBtb3JlOg0KXy09M0QNCl8tPTNEICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/UlYxMC1MaXN0DQpfLT0zRA0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCl8tPTNEICAgICAgICAgICAgICAg LSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0zRCBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBh dmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KXy09M0QNCl8tPTNEICAgLS0+IGh0dHA6Ly9m b3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09M0QNCl8tPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEDQpfLT0zRCAgICAgICAgICAg ICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPTNEICBUaGFuayB5b3UgZm9yIHlv dXIgZ2VuZXJvdXMgc3VwcG9ydCENCl8tPTNEICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KXy09M0QgICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCiANCg0KwqbCt+KAun7igLDDrcKyLMOe DQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpww7Zy4oCwaMKsIMOTTX3Cpw0K X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCg0KcMKiw6p6wrnDgcOKwq4nDQpfX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpfX19fX19fX19fX19fX19fX19fX19fX19f X19fX19fXw0KDQpww5zDvcK/w5/Cont/wqbCt8K/buKAoXLDvmYNCg0K ________________________________________________________________________________
Date: Jul 12, 2011
Now John, you are just trying to curry favor with Rhonda..................she is on to your schtick already. ;-)) On Tue, Jul 12, 2011 at 4:11 PM, John Cox wrote: > Has anyone mentioned a rebuilt Barrett is often better than a brand new > factory built VANS. It just might have one less rebuild in its lifecycle > but the tolerances are great. New engines are also prone to "Break-In". A > Pre-delivery dyno run, now that sets builders apart. Airshow performers are > a good benchmark for pilots who know engines and hang their lives on the > engine and prop blades. Do research. Get what you pay for.**** > > ** ** > > John**** > > ** ** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *sportflying(at)yahoo.co m > *Sent:* Tuesday, July 12, 2011 2:31 PM > > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Engine Referral**** > > ** ** > > Barrett builds great engines **** > > Sent from my Verizon Wireless BlackBerry**** > ------------------------------ > > *From: *"Rhonda Bewley" <Rhonda(at)bpaengines.com> **** > > *Sender: *owner-rv10-list-server(at)matronics.com **** > > *Date: *Tue, 12 Jul 2011 16:20:07 -0500**** > > *To: ***** > > *ReplyTo: *rv10-list(at)matronics.com **** > > *Subject: *RE: RV10-List: Engine Referral**** > > ** ** > > Although we cannot offer new = engines anymore because of the end of ou r > contractual agreement with Lycoming, I = can tell you that an overhaule d > IO-540 built in this configuration to = factory new limits, including n ew > cylinders, starter, mags, and new fuel injection currently costs $10,000 > less than the Thunderbolt = option.**** > > **** > > I understand that Lycoming very = recently passed on a substantial pric e > increase to their remaining = =9Ckit=9D engine shops. That may be where the > difference is seen between a = new engine from a custom builder and > Thunderbolt or Van=99s assembly = line factory engine.**** > > **** > > For you new factory engine owners, = you might be advised to check Serv ice > Bulletin 240U, in which Lycoming = requires the replacement of roller > tappets at prop strike, and they are not cheap. = Ouch!**** > > **** > > Rhonda = Barrett-Bewley**** > > Barrett Precision Engines, = Inc.**** > ------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com = [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Pascal > *Sent:* Tuesday, July 12, = 2011 3:55 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: = Engine Referral**** > > **** > > Must be me = than.. but I just looked and the difference is as = foll ows:* > *** > > Thunderbolt = website- **** > > *Base = Price: **YIO-540-D4A5** = ***** > > *Fuel = System:***** > > Injected**** > > *Aerobatic = Kit:***** > > No**** > > *Horsepower:***** > > 260**** > > *Displacement (Cubic Inches):***** > > 540**** > > *Stock = Compression Ratio:***** > > 8.5:1<= /font>**** > > *Cylinder = Type:***** > > Parallel = Valve**** > > $49,500.00**** > > **** > > Vans = Website:**** > > *Experimental IO-540 260HP (RV-10 = only)* > Part Number =3D EA XIO-540-D4A5 = RT > Price =3D = $42300.00 **** > > **** > > *IO-540 260HP (RV-10 = only)* > Part Number =3D EA IO-540-D4A5 = RT > Price =3D = $46050.00 **** > > **** > > **** > > **** > > This looks = about the same as it was when I was researching the engine s.* > *** > > I can only = imagine that if one calls Thunderbolt the difference is le ss > than?**** > > **** > > **** > > **** > > *From:* Phillip Perry **** > > *Sent:* Tuesday, July = 12, 2011 1:21 PM**** > > *To:* rv10-list(at)matronics.com **** > > *Subject:* Re: RV10-List: Engine Referral**** > > **** > > I'm seeing $1,500 - $2,000 too. Nothing in the range of = 5-6K.**** > > On Tue, Jul = 12, 2011 at 3:11 PM, Pascal wrote :** > ** > > > I wonder how you did so well to get it within $2000? Without any airshow > deals, it was like $3000 more for certified, and about $6000 more than th e > Vans experimental when I researched this option. if I throw in the airsho w > special of $1000 off package that gets up there even more. > For $2000, there is no doubt Thunderbolt engines is the way to go, but > for someone like me that couldn't care if it's certified or experimental > when the rest of my aircraft is experimental, $7000 more was not an optio n. > With = that said I have most of this in my engine for far less than a V ans > certified. BUT it is experimental. > I support the decision you made, and I would have considered it as well > for such a small amount, but for someone looking for an engine I need to > mention that they may be surprised to see the price difference being a > little = more than you were able to get it for. > If anyone is wondering Vans offers the engines at OEM prices, hence only > being able to get one per builder number. I discovered the price was abou t > the = same a some rebuilds out there. It's a good deal for a simple van illa > = IO540. > > > -----Original Message----- From: John Cumins > Sent: Tuesday, July 12, 2011 12:22 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Engine Referral > > > I did a lot of research while I was at OSH last year. If I wanted a stoc k > engine new I would go Vans route. Since I want the most for = my buck s, > like > balancing to less then a gram, port and flow matching approx 30-40 = h p > for > free, and light weight started, and Air Performance Fuel Injection I > would > go with a Lycombing Thunder custom built engine. For approx. = $1000-2 000 > difference in price from Vans, I get a lot more and it is totally brand > new > with full factory warranty. > > I looked at all vendors and build a spreadsheet and dollar to quality = and > performance and being 100% new Thunder is hard to Beat. > > > John Cumins > 40864 Wings > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2011 12:02 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Engine Referral > > > I'm about to the point of ordering engine and prop and was curious as = to > most I hear not ordering from Vans. Is it price or service or = someth ing > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote:**** > > --> = RV10-List message posted by: "Pascal" > > America's in = Oklahoma, on = the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for = an* > *** > > engine. = Should you be tempted by the New Firewall Forward out of Colo rado > contact me privately for a referral. In a nutshell, dealing with them = has > been the most frustrating, disappointing, and infuriating experience of > my > entire RV-10 build.**** > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=3D346091#34= 6091 > > > **** > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > arget=3D"_blank">http://www.matronics.com/Navigator?RV10-Lis= t > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > http://forums.matronics.com > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > le, List Admin. > =3D"_blank">http://www.matronics.com/contribution > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > **** > > **** > > * *<=**** > > /pre>**** > > * ***** > > *href=3D"http://www.matronics.com/Navigator?RV10-Li=* > > *st">http://www.matronics.com/Navigator?RV10-List***** > > *href=3D"http://forums.matronics.com">http:=* > > *//forums.matronics.com***** > > *href=3D"http://www.matronics.com/contribution"=* > > *;>http://www.matronics.com/c***** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > * *<=**** > > /pre>**** > > * ***** > > *http://www.matronic=* > > *s.com/Navigator?RV10-List***** > > *<=* > > *font* > > *size=3D2 color=3Dblack face=3D"Courier New">***** > > *http://forums.matronics.com=* > > *http://www.matronics.com/c=* > > *ontribution***** > > * ***** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > * * > > * * > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > * * > > =C2=C2=B7=BA~=B0=C3=AD=C2=B2,=C3=9E > ------------------------------ > p=C3=B6r=B0h=C2=AC =C3=93M}=C2=A7 > ------------------------------ > p=C2=A2=C3z=C2=B9=C3=81=C3=8A=C2=AE' > ------------------------------ > ------------------------------ > p=C3=9C=C3=BD=C2=C3=9F=C2=A2{ =C2=C2=B7=C2n=A1r=C3=BEf**** > > ________________________________________________________________________________
Date: Jul 12, 2011
Subject: Re: Engine Referral
I paid for extra bench running time with BPE so as to leave some of the break-in to the professionals well before first flight. So far so good. Robin On Tue, Jul 12, 2011 at 4:11 PM, John Cox wrote: > Has anyone mentioned a rebuilt Barrett is often better than a brand new > factory built VANS. It just might have one less rebuild in its lifecycle > but the tolerances are great. New engines are also prone to "Break-In". A > Pre-delivery dyno run, now that sets builders apart. Airshow performers are > a good benchmark for pilots who know engines and hang their lives on the > engine and prop blades. Do research. Get what you pay for.**** > > ** ** > > John**** > > ** ** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *sportflying(at)yahoo.co m > *Sent:* Tuesday, July 12, 2011 2:31 PM > > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Engine Referral**** > > ** ** > > Barrett builds great engines **** > > Sent from my Verizon Wireless BlackBerry**** > ------------------------------ > > *From: *"Rhonda Bewley" <Rhonda(at)bpaengines.com> **** > > *Sender: *owner-rv10-list-server(at)matronics.com **** > > *Date: *Tue, 12 Jul 2011 16:20:07 -0500**** > > *To: ***** > > *ReplyTo: *rv10-list(at)matronics.com **** > > *Subject: *RE: RV10-List: Engine Referral**** > > ** ** > > Although we cannot offer new = engines anymore because of the end of ou r > contractual agreement with Lycoming, I = can tell you that an overhaule d > IO-540 built in this configuration to = factory new limits, including n ew > cylinders, starter, mags, and new fuel injection currently costs $10,000 > less than the Thunderbolt = option.**** > > **** > > I understand that Lycoming very = recently passed on a substantial pric e > increase to their remaining = =9Ckit=9D engine shops. That may be where the > difference is seen between a = new engine from a custom builder and > Thunderbolt or Van=99s assembly = line factory engine.**** > > **** > > For you new factory engine owners, = you might be advised to check Serv ice > Bulletin 240U, in which Lycoming = requires the replacement of roller > tappets at prop strike, and they are not cheap. = Ouch!**** > > **** > > Rhonda = Barrett-Bewley**** > > Barrett Precision Engines, = Inc.**** > ------------------------------ > > *From:* owner-rv10-list-server(at)matronics.com = [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Pascal > *Sent:* Tuesday, July 12, = 2011 3:55 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: = Engine Referral**** > > **** > > Must be me = than.. but I just looked and the difference is as = foll ows:* > *** > > Thunderbolt = website- **** > > *Base = Price: **YIO-540-D4A5** = ***** > > *Fuel = System:***** > > Injected**** > > *Aerobatic = Kit:***** > > No**** > > *Horsepower:***** > > 260**** > > *Displacement (Cubic Inches):***** > > 540**** > > *Stock = Compression Ratio:***** > > 8.5:1<= /font>**** > > *Cylinder = Type:***** > > Parallel = Valve**** > > $49,500.00**** > > **** > > Vans = Website:**** > > *Experimental IO-540 260HP (RV-10 = only)* > Part Number =3D EA XIO-540-D4A5 = RT > Price =3D = $42300.00 **** > > **** > > *IO-540 260HP (RV-10 = only)* > Part Number =3D EA IO-540-D4A5 = RT > Price =3D = $46050.00 **** > > **** > > **** > > **** > > This looks = about the same as it was when I was researching the engine s.* > *** > > I can only = imagine that if one calls Thunderbolt the difference is le ss > than?**** > > **** > > **** > > **** > > *From:* Phillip Perry **** > > *Sent:* Tuesday, July = 12, 2011 1:21 PM**** > > *To:* rv10-list(at)matronics.com **** > > *Subject:* Re: RV10-List: Engine Referral**** > > **** > > I'm seeing $1,500 - $2,000 too. Nothing in the range of = 5-6K.**** > > On Tue, Jul = 12, 2011 at 3:11 PM, Pascal wrote :** > ** > > > I wonder how you did so well to get it within $2000? Without any airshow > deals, it was like $3000 more for certified, and about $6000 more than th e > Vans experimental when I researched this option. if I throw in the airsho w > special of $1000 off package that gets up there even more. > For $2000, there is no doubt Thunderbolt engines is the way to go, but > for someone like me that couldn't care if it's certified or experimental > when the rest of my aircraft is experimental, $7000 more was not an optio n. > With = that said I have most of this in my engine for far less than a V ans > certified. BUT it is experimental. > I support the decision you made, and I would have considered it as well > for such a small amount, but for someone looking for an engine I need to > mention that they may be surprised to see the price difference being a > little = more than you were able to get it for. > If anyone is wondering Vans offers the engines at OEM prices, hence only > being able to get one per builder number. I discovered the price was abou t > the = same a some rebuilds out there. It's a good deal for a simple van illa > = IO540. > > > -----Original Message----- From: John Cumins > Sent: Tuesday, July 12, 2011 12:22 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Engine Referral > > > I did a lot of research while I was at OSH last year. If I wanted a stoc k > engine new I would go Vans route. Since I want the most for = my buck s, > like > balancing to less then a gram, port and flow matching approx 30-40 = h p > for > free, and light weight started, and Air Performance Fuel Injection I > would > go with a Lycombing Thunder custom built engine. For approx. = $1000-2 000 > difference in price from Vans, I get a lot more and it is totally brand > new > with full factory warranty. > > I looked at all vendors and build a spreadsheet and dollar to quality = and > performance and being 100% new Thunder is hard to Beat. > > > John Cumins > 40864 Wings > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Tuesday, July 12, 2011 12:02 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Engine Referral > > > I'm about to the point of ordering engine and prop and was curious as = to > most I hear not ordering from Vans. Is it price or service or = someth ing > else? > > Sean #40303 > > Sent from my iPhone > > On Jul 12, 2011, at 1:36 PM, "Pascal" wrote:**** > > --> = RV10-List message posted by: "Pascal" > > America's in = Oklahoma, on = the other hand, has been first rate. > > > -----Original Message----- From: N306PB > Sent: Tuesday, July 12, 2011 10:17 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Engine Referral > > > As Oshkosh approaches I am sure there are some out there looking for = an* > *** > > engine. = Should you be tempted by the New Firewall Forward out of Colo rado > contact me privately for a referral. In a nutshell, dealing with them = has > been the most frustrating, disappointing, and infuriating experience of > my > entire RV-10 build.**** > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=3D346091#34= 6091 > > > **** > > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > arget=3D"_blank">http://www.matronics.com/Navigator?RV10-Lis= t > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > http://forums.matronics.com > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > le, List Admin. > =3D"_blank">http://www.matronics.com/contribution > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > **** > > **** > > * *<=**** > > /pre>**** > > * ***** > > *href=3D"http://www.matronics.com/Navigator?RV10-Li=* > > *st">http://www.matronics.com/Navigator?RV10-List***** > > *href=3D"http://forums.matronics.com">http:=* > > *//forums.matronics.com***** > > *href=3D"http://www.matronics.com/contribution"=* > > *;>http://www.matronics.com/c***** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > * *<=**** > > /pre>**** > > * ***** > > *http://www.matronic=* > > *s.com/Navigator?RV10-List***** > > *<=* > > *font* > > *size=3D2 color=3Dblack face=3D"Courier New">***** > > *http://forums.matronics.com=* > > *http://www.matronics.com/c=* > > *ontribution***** > > * ***** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > * * > > * * > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D* > > * * > > =C2=C2=B7=BA~=B0=C3=AD=C2=B2,=C3=9E > ------------------------------ > p=C3=B6r=B0h=C2=AC =C3=93M}=C2=A7 > ------------------------------ > p=C2=A2=C3z=C2=B9=C3=81=C3=8A=C2=AE' > ------------------------------ > ------------------------------ > p=C3=9C=C3=BD=C2=C3=9F=C2=A2{ =C2=C2=B7=C2n=A1r=C3=BEf**** > > ________________________________________________________________________________
Date: Jul 12, 2011
Subject: Re: ATSB Transceiver...
That's a Kenwood DNX-8120 Indash car entertainment system: http://www.kenwoodusa.com/Car_Entertainment/2008_Car_Entertainment/DNX8120 I've got the Garmin GPS map up on the display in those pictures. Attached are a few pictures of some of the other displays. The output on the display including the Garmin GPS map is also shown on the 7" LCD screen in the pilot's headrest that the passenger can see. There's also a review cam mounted at the top of the display in the headrest to give me a check-six view of the passenger. The Garmin GPS map display nice for passengers that aren't necessarily airplane savvy. It also shows the altitude and ground speed. I like having the Garmin map up front too as a cross reference to the GRT mapping. Also, the Garmin shows Airport names instead of the dopey 4-letter IDs! :-) On the Kenwood, I've got a 128GB and a 64GB USB thumb drives plugged in and they contain my whole MP3 music library! It also has XM Radio, HD digital AM/FM, and plays DVDs. The audio output is mixed through a PS Engineering 3000 intercom and then into Bose X (upgraded to A20s) NR headphones. The audio is pretty awesome. Very clear and easy to understand. By the way, I just got the UPS shipping notification from NavWorx (7/12/2011) on the ADS-B Transceiver so it took a little over a month from the order to the shipping. FYI. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... At 10:25 AM 7/12/2011 Tuesday, you wrote: > >Matt, > What is the screen in the lower right corner? What are you driving >it with etc.? >Thanks, >Jerry Folkerts > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Tuesday, July 12, 2011 11:43 AM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Re: ATSB Transceiver... > > >Yes, I have three GRT HX EFIS's in the RV-8 (see attached pictures). >According to GRT, the Navworx transceiver should hook right up to the ARNIC >interface and go. Still haven't gotten my transciever from Navworx yet, >though. I ordered it on 6/10/2011 so its been over a month now... They did >charge my credit card, though... ;-/ > >Matt > > >At 07:41 PM 7/11/2011 Monday, you wrote: >>--> >> >>Matt, >> >> What are you using this with GRT's gear? I've been considering it for >some time but the interface to the Advanced Flight gear seems to be >permanently "under development" so I'm stuck with my 496 for weather. >> >>Sent from my iPad2 >> >>On Jul 3, 2011, at 5:30 PM, "Matt Dralle" wrote: >> >>> >>> At 02:07 PM 7/3/2011 Sunday, you wrote: >>>> --> >>>> >>>> Have been thinking about doing the same. Are you going with navworx? >>> >>> >>> I ordered the ADS600-B unit from NavWorx: >>> >>> <http://www.navworx.com/ads600-b.asp>http://www.navworx.com/ads600-b. >>> asp >>> >>> Here's their main site: >>> >>> <http://www.navworx.com/index.asp>http://www.navworx.com/index.asp >>> >>> They're not exactly cheap. Here's the price list: >>> >>> <http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600->> or-PADS600-Online-Now.aspx>http://navworx.americommerce.com/store/c/2 >>> 1-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx >>> >>> I also ordered it with the WIFI module and the ARINC-429 for fun. >>> >>> Matt > ________________________________________________________________________________
Subject: Engine Referral
Date: Jul 12, 2011
VGhhbmtzIGZvciBjaGltaW5nIGluLiAgV2hlbiBjYWxjdWxhdGluZyBjb21wYXJhYmxlIGVuZ2lu ZSBjb3N0cywgIFRoZSB2YWx1ZSBvZiBhIHNvbGlkIGJyZWFrLWluIGNhbiBvZnRlbiBoZWxwIHdp dGggb3RoZXIgZmFjdG9ycyB0byByZWFjaCBUQk8gd2l0aCB0aGUgcmluZ3MgYW5kIHJlbGF0ZWQg Y29tcG9uZW50cy4NCg0KIA0KDQpKb2huDQoNCiANCg0KIA0KDQpGcm9tOiBvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBSb2JpbiBNYXJrcw0KU2VudDogVHVlc2RheSwgSnVs eSAxMiwgMjAxMSA1OjI1IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6 IFJlOiBSVjEwLUxpc3Q6IEVuZ2luZSBSZWZlcnJhbA0KDQogDQoNCkkgcGFpZCBmb3IgZXh0cmEg YmVuY2ggcnVubmluZyB0aW1lIHdpdGggQlBFIHNvIGFzIHRvIGxlYXZlIHNvbWUgb2YgdGhlIGJy ZWFrLWluIHRvIHRoZSBwcm9mZXNzaW9uYWxzIHdlbGwgYmVmb3JlIGZpcnN0IGZsaWdodC4gU28g ZmFyIHNvIGdvb2QuDQoNCiANCg0KUm9iaW4gIA0KDQpPbiBUdWUsIEp1bCAxMiwgMjAxMSBhdCA0 OjExIFBNLCBKb2huIENveCA8am9obndjb3hAcGFjaWZpY253LmNvbT4gd3JvdGU6DQoNCkhhcyBh bnlvbmUgbWVudGlvbmVkIGEgcmVidWlsdCBCYXJyZXR0IGlzIG9mdGVuIGJldHRlciB0aGFuIGEg YnJhbmQgbmV3IGZhY3RvcnkgYnVpbHQgVkFOUy4gIEl0IGp1c3QgbWlnaHQgaGF2ZSBvbmUgbGVz cyByZWJ1aWxkIGluIGl0cyBsaWZlY3ljbGUgYnV0IHRoZSB0b2xlcmFuY2VzIGFyZSBncmVhdC4g IE5ldyBlbmdpbmVzIGFyZSBhbHNvIHByb25lIHRvICJCcmVhay1JbiIuICBBIFByZS1kZWxpdmVy eSBkeW5vIHJ1biwgbm93IHRoYXQgc2V0cyBidWlsZGVycyBhcGFydC4gIEFpcnNob3cgcGVyZm9y bWVycyBhcmUgYSBnb29kIGJlbmNobWFyayBmb3IgcGlsb3RzIHdobyBrbm93IGVuZ2luZXMgYW5k IGhhbmcgdGhlaXIgbGl2ZXMgb24gdGhlIGVuZ2luZSBhbmQgcHJvcCBibGFkZXMuICBEbyByZXNl YXJjaC4gIEdldCB3aGF0IHlvdSBwYXkgZm9yLg0KDQogDQoNCkpvaG4NCg0KIA0KDQogDQoNCkZy b206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2 MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIHNwb3J0Zmx5aW5nQHlh aG9vLmNvbQ0KU2VudDogVHVlc2RheSwgSnVseSAxMiwgMjAxMSAyOjMxIFBNDQoNCg0KVG86IHJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBFbmdpbmUgUmVm ZXJyYWwNCg0KIA0KDQpCYXJyZXR0IGJ1aWxkcyBncmVhdCBlbmdpbmVzIA0KDQpTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoNCl9fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fDQoNCkZyb206ICJSaG9uZGEgQmV3bGV5IiA8UmhvbmRhQGJwYWVuZ2luZXMuY29t PiANCg0KU2VuZGVyOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gDQoNCkRh dGU6IFR1ZSwgMTIgSnVsIDIwMTEgMTY6MjA6MDcgLTA1MDANCg0KVG86IDxydjEwLWxpc3RAbWF0 cm9uaWNzLmNvbT4NCg0KUmVwbHlUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20gDQoNClN1Ympl Y3Q6IFJFOiBSVjEwLUxpc3Q6IEVuZ2luZSBSZWZlcnJhbA0KDQogDQoNCkFsdGhvdWdoIHdlIGNh bm5vdCBvZmZlciBuZXcgPSBlbmdpbmVzIGFueW1vcmUgYmVjYXVzZSBvZiB0aGUgZW5kIG9mIG91 ciBjb250cmFjdHVhbCBhZ3JlZW1lbnQgd2l0aCBMeWNvbWluZywgSSA9IGNhbiB0ZWxsIHlvdSB0 aGF0IGFuIG92ZXJoYXVsZWQgSU8tNTQwIGJ1aWx0IGluIHRoaXMgY29uZmlndXJhdGlvbiB0byA9 IGZhY3RvcnkgbmV3IGxpbWl0cywgaW5jbHVkaW5nIG5ldyBjeWxpbmRlcnMsIHN0YXJ0ZXIsIG1h Z3MsIGFuZCBuZXcgZnVlbCBpbmplY3Rpb24gY3VycmVudGx5IGNvc3RzICQxMCwwMDAgbGVzcyB0 aGFuIHRoZSBUaHVuZGVyYm9sdCA9IG9wdGlvbi4NCg0KIA0KDQpJIHVuZGVyc3RhbmQgdGhhdCBM eWNvbWluZyB2ZXJ5ID0gcmVjZW50bHkgcGFzc2VkIG9uIGEgc3Vic3RhbnRpYWwgcHJpY2UgaW5j cmVhc2UgdG8gdGhlaXIgcmVtYWluaW5nID0g4oCca2l04oCdIGVuZ2luZSBzaG9wcy4gIFRoYXQg bWF5IGJlIHdoZXJlIHRoZSBkaWZmZXJlbmNlIGlzIHNlZW4gYmV0d2VlbiBhID0gbmV3IGVuZ2lu ZSBmcm9tIGEgY3VzdG9tIGJ1aWxkZXIgYW5kIFRodW5kZXJib2x0IG9yIFZhbuKAmXMgYXNzZW1i bHkgPSBsaW5lIGZhY3RvcnkgZW5naW5lLg0KDQogDQoNCkZvciB5b3UgbmV3IGZhY3RvcnkgZW5n aW5lIG93bmVycywgPSB5b3UgbWlnaHQgYmUgYWR2aXNlZCB0byBjaGVjayBTZXJ2aWNlIEJ1bGxl dGluIDI0MFUsIGluIHdoaWNoIEx5Y29taW5nID0gcmVxdWlyZXMgdGhlIHJlcGxhY2VtZW50IG9m IHJvbGxlciB0YXBwZXRzIGF0IHByb3Agc3RyaWtlLCBhbmQgdGhleSBhcmUgbm90IGNoZWFwLiA9 ICBPdWNoIQ0KDQogDQoNClJob25kYSA9IEJhcnJldHQtQmV3bGV5DQoNCkJhcnJldHQgUHJlY2lz aW9uIEVuZ2luZXMsID0gSW5jLg0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0K DQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gPSBbbWFpbHRvOm93 bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIFBhc2NhbA0K U2VudDogVHVlc2RheSwgSnVseSAxMiwgPSAyMDExIDM6NTUgUE0NClRvOiBydjEwLWxpc3RAbWF0 cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogPSBFbmdpbmUgUmVmZXJyYWwNCg0K IA0KDQpNdXN0IGJlIG1lID0gdGhhbi4uIGJ1dCBJIGp1c3QgbG9va2VkIGFuZCB0aGUgZGlmZmVy ZW5jZSBpcyBhcyA9IGZvbGxvd3M6DQoNClRodW5kZXJib2x0ID0gd2Vic2l0ZS0gDQoNCkJhc2Ug PSBQcmljZTogWUlPLTU0MC1ENEE1ID0gDQoNCkZ1ZWwgPSBTeXN0ZW06DQoNCkluamVjdGVkDQoN CkFlcm9iYXRpYyA9IEtpdDoNCg0KTm8NCg0KSG9yc2Vwb3dlcjoNCg0KMjYwDQoNCkRpc3BsYWNl bWVudCAoQ3ViaWMgSW5jaGVzKToNCg0KNTQwDQoNClN0b2NrID0gQ29tcHJlc3Npb24gUmF0aW86 DQoNCjguNToxPD0gL2ZvbnQ+DQoNCkN5bGluZGVyID0gVHlwZToNCg0KUGFyYWxsZWwgPSBWYWx2 ZQ0KDQokNDksNTAwLjAwDQoNCiANCg0KVmFucyA9IFdlYnNpdGU6DQoNCkV4cGVyaW1lbnRhbCBJ Ty01NDAgMjYwSFAgKFJWLTEwID0gb25seSkNClBhcnQgTnVtYmVyID0zRCBFQSBYSU8tNTQwLUQ0 QTUgPSBSVA0KUHJpY2UgPTNEID0gJDQyMzAwLjAwIA0KDQogDQoNCklPLTU0MCAyNjBIUCAoUlYt MTAgPSBvbmx5KQ0KUGFydCBOdW1iZXIgPTNEIEVBIElPLTU0MC1ENEE1ID0gUlQNClByaWNlID0z RCA9ICQ0NjA1MC4wMCANCg0KIA0KDQogDQoNCiANCg0KVGhpcyBsb29rcyA9IGFib3V0IHRoZSBz YW1lIGFzIGl0IHdhcyB3aGVuIEkgd2FzIHJlc2VhcmNoaW5nIHRoZSBlbmdpbmVzLg0KDQpJIGNh biBvbmx5ID0gaW1hZ2luZSB0aGF0IGlmIG9uZSBjYWxscyBUaHVuZGVyYm9sdCB0aGUgZGlmZmVy ZW5jZSBpcyBsZXNzID0gdGhhbj8NCg0KIA0KDQogDQoNCiANCg0KRnJvbTogUGhpbGxpcCBQZXJy eSANCg0KU2VudDogVHVlc2RheSwgSnVseSA9IDEyLCAyMDExIDE6MjEgUE0NCg0KVG86IHJ2MTAt bGlzdEBtYXRyb25pY3MuY29tIA0KDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBFbmdpbmUgUmVm ZXJyYWwNCg0KIA0KDQpJJ20gc2VlaW5nICQxLDUwMCAtICQyLDAwMCB0b28uICAgTm90aGluZyBp biB0aGUgcmFuZ2Ugb2YgPSA1LTZLLg0KDQpPbiBUdWUsIEp1bCA9IDEyLCAyMDExIGF0IDM6MTEg UE0sIFBhc2NhbCA8cnYxMGZseWVyQHZlcml6b24ubmV0PiB3cm90ZToNCg0KLS0+IFJWMTAtTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogIlBhc2NhbCIgPHJ2MTBmbHllckB2ZXJpem9uLm5ldD4NCg0K SSB3b25kZXIgaG93IHlvdSBkaWQgc28gd2VsbCB0byBnZXQgaXQgd2l0aGluICQyMDAwPyBXaXRo b3V0IGFueSBhaXJzaG93ID0gZGVhbHMsIGl0IHdhcyBsaWtlICQzMDAwIG1vcmUgZm9yIGNlcnRp ZmllZCwgYW5kIGFib3V0ICQ2MDAwIG1vcmUgdGhhbiB0aGUgVmFucyBleHBlcmltZW50YWwgd2hl biBJIHJlc2VhcmNoZWQgdGhpcyBvcHRpb24uIGlmIEkgdGhyb3cgaW4gdGhlIGFpcnNob3cgPSBz cGVjaWFsIG9mICQxMDAwIG9mZiBwYWNrYWdlIHRoYXQgZ2V0cyB1cCB0aGVyZSBldmVuIG1vcmUu DQpGb3IgJDIwMDAsIHRoZXJlIGlzIG5vIGRvdWJ0IFRodW5kZXJib2x0IGVuZ2luZXMgaXMgdGhl IHdheSB0byBnbywgYnV0ID0gZm9yIHNvbWVvbmUgbGlrZSBtZSB0aGF0IGNvdWxkbid0IGNhcmUg aWYgaXQncyBjZXJ0aWZpZWQgb3IgZXhwZXJpbWVudGFsID0gd2hlbiB0aGUgcmVzdCBvZiBteSBh aXJjcmFmdCBpcyBleHBlcmltZW50YWwsICQ3MDAwIG1vcmUgd2FzIG5vdCBhbiBvcHRpb24uIFdp dGggPSB0aGF0IHNhaWQgSSBoYXZlIG1vc3Qgb2YgdGhpcyBpbiBteSBlbmdpbmUgZm9yIGZhciBs ZXNzIHRoYW4gYSBWYW5zID0gY2VydGlmaWVkLiBCVVQgaXQgaXMgZXhwZXJpbWVudGFsLg0KSSBz dXBwb3J0IHRoZSBkZWNpc2lvbiB5b3UgbWFkZSwgYW5kIEkgd291bGQgaGF2ZSBjb25zaWRlcmVk IGl0IGFzIHdlbGwgPSBmb3Igc3VjaCBhIHNtYWxsIGFtb3VudCwgYnV0IGZvciBzb21lb25lIGxv b2tpbmcgZm9yIGFuIGVuZ2luZSBJIG5lZWQgdG8gPSBtZW50aW9uIHRoYXQgdGhleSBtYXkgYmUg c3VycHJpc2VkIHRvIHNlZSB0aGUgcHJpY2UgZGlmZmVyZW5jZSBiZWluZyBhIGxpdHRsZSA9IG1v cmUgdGhhbiB5b3Ugd2VyZSBhYmxlIHRvIGdldCBpdCBmb3IuDQpJZiBhbnlvbmUgaXMgd29uZGVy aW5nIFZhbnMgb2ZmZXJzIHRoZSBlbmdpbmVzIGF0IE9FTSBwcmljZXMsIGhlbmNlIG9ubHkgPSBi ZWluZyBhYmxlIHRvIGdldCBvbmUgcGVyIGJ1aWxkZXIgbnVtYmVyLiBJIGRpc2NvdmVyZWQgdGhl IHByaWNlIHdhcyBhYm91dCB0aGUgPSBzYW1lIGEgc29tZSByZWJ1aWxkcyBvdXQgdGhlcmUuIEl0 J3MgYSBnb29kIGRlYWwgZm9yIGEgc2ltcGxlIHZhbmlsbGEgPSBJTzU0MC4NCg0KDQotLS0tLU9y aWdpbmFsIE1lc3NhZ2UtLS0tLSBGcm9tOiBKb2huIEN1bWlucw0KU2VudDogVHVlc2RheSwgSnVs eSAxMiwgMjAxMSAxMjoyMiBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0 OiBSRTogUlYxMC1MaXN0OiBFbmdpbmUgUmVmZXJyYWwNCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogIkpvaG4gQ3VtaW5zIiA8amN1bWluc0BqY2lzLm5ldD4NCg0KSSBkaWQgYSBs b3Qgb2YgcmVzZWFyY2ggd2hpbGUgSSB3YXMgYXQgT1NIIGxhc3QgeWVhci4gIElmIEkgd2FudGVk IGEgc3RvY2sNCmVuZ2luZSBuZXcgSSB3b3VsZCBnbyBWYW5zIHJvdXRlLiAgU2luY2UgSSB3YW50 ICB0aGUgbW9zdCBmb3IgPSBteSBidWNrcywgbGlrZQ0KYmFsYW5jaW5nIHRvIGxlc3MgdGhlbiBh IGdyYW0sIHBvcnQgYW5kIGZsb3cgbWF0Y2hpbmcgYXBwcm94ICAzMC00MCA9IGhwIGZvcg0KZnJl ZSwgYW5kIGxpZ2h0IHdlaWdodCBzdGFydGVkLCBhbmQgQWlyIFBlcmZvcm1hbmNlIEZ1ZWwgSW5q ZWN0aW9uIEkgPSB3b3VsZA0KZ28gd2l0aCBhIEx5Y29tYmluZyBUaHVuZGVyIGN1c3RvbSBidWls dCBlbmdpbmUuICBGb3IgYXBwcm94LiA9ICQxMDAwLTIwMDANCmRpZmZlcmVuY2UgaW4gcHJpY2Ug ZnJvbSBWYW5zLCBJIGdldCBhIGxvdCBtb3JlIGFuZCBpdCBpcyB0b3RhbGx5IGJyYW5kID0gbmV3 DQp3aXRoIGZ1bGwgZmFjdG9yeSB3YXJyYW50eS4NCg0KSSBsb29rZWQgYXQgYWxsIHZlbmRvcnMg YW5kIGJ1aWxkIGEgc3ByZWFkc2hlZXQgYW5kIGRvbGxhciB0byBxdWFsaXR5ID0gYW5kDQpwZXJm b3JtYW5jZSBhbmQgYmVpbmcgMTAwJSBuZXcgVGh1bmRlciBpcyBoYXJkIHRvIEJlYXQuDQoNCg0K Sm9obiBDdW1pbnMNCjQwODY0IFdpbmdzDQoNCg0KDQotLS0tLU9yaWdpbmFsIE1lc3NhZ2UtLS0t LQ0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tDQpbbWFpbHRvOm93 bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIFNlYW4gU3Rl cGhlbnMNClNlbnQ6IFR1ZXNkYXksIEp1bHkgMTIsIDIwMTEgMTI6MDIgUE0NClRvOiBydjEwLWxp c3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogRW5naW5lIFJlZmVycmFs DQoNCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IFNlYW4gU3RlcGhlbnMgPHNlYW5A c3RlcGhlbnN2aWxsZS5jb20+DQoNCkknbSBhYm91dCB0byB0aGUgcG9pbnQgb2Ygb3JkZXJpbmcg ZW5naW5lIGFuZCBwcm9wIGFuZCB3YXMgY3VyaW91cyBhcyA9IHRvDQptb3N0IEkgaGVhciBub3Qg b3JkZXJpbmcgZnJvbSBWYW5zLiAgSXMgaXQgcHJpY2Ugb3Igc2VydmljZSBvciA9IHNvbWV0aGlu Zw0KZWxzZT8NCg0KU2VhbiAjNDAzMDMNCg0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpPbiBKdWwg MTIsIDIwMTEsIGF0IDE6MzYgUE0sICJQYXNjYWwiIDxydjEwZmx5ZXJAdmVyaXpvbi5uZXQ+IHdy b3RlOg0KDQotLT4gPSBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJQYXNjYWwiIDxydjEw Zmx5ZXJAdmVyaXpvbi5uZXQ+DQoNCkFtZXJpY2EncyBpbiA9IE9rbGFob21hLCBvbiA9IHRoZSBv dGhlciBoYW5kLCBoYXMgYmVlbiBmaXJzdCByYXRlLg0KDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2Fn ZS0tLS0tIEZyb206IE4zMDZQQg0KU2VudDogVHVlc2RheSwgSnVseSAxMiwgMjAxMSAxMDoxNyBB TQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSVjEwLUxpc3Q6IEVuZ2lu ZSBSZWZlcnJhbA0KDQotLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiTjMwNlBCIiA8 d3JhdGhidW5AaWh0dy5jb20+DQoNCkFzIE9zaGtvc2ggYXBwcm9hY2hlcyBJIGFtIHN1cmUgdGhl cmUgYXJlIHNvbWUgb3V0IHRoZXJlIGxvb2tpbmcgZm9yID0gYW4NCg0KZW5naW5lLiA9IFNob3Vs ZCB5b3UgYmUgdGVtcHRlZCBieSB0aGUgTmV3IEZpcmV3YWxsIEZvcndhcmQgb3V0IG9mIENvbG9y YWRvDQpjb250YWN0IG1lIHByaXZhdGVseSBmb3IgYSByZWZlcnJhbC4gSW4gYSBudXRzaGVsbCwg ZGVhbGluZyB3aXRoIHRoZW0gPSBoYXMNCmJlZW4gdGhlIG1vc3QgZnJ1c3RyYXRpbmcsIGRpc2Fw cG9pbnRpbmcsIGFuZCBpbmZ1cmlhdGluZyBleHBlcmllbmNlIG9mID0gbXkNCmVudGlyZSBSVi0x MCBidWlsZC4NCg0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQoNCmh0dHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9M0QzNDYwOTEjMzQ9IDYwOTEN Cg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCj0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KYXJnZXQ9M0QiX2JsYW5rIj5odHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzPSB0DQo9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0QNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEDQpsZSwgTGlzdCBBZG1pbi4NCj0zRCJfYmxhbmsiPmh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRA0KDQoNCg0KDQogDQoNCiA8PQ0KL3ByZT4NCiANCiANCmhyZWY9M0QiaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpPQ0KIA0Kc3QiPmh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQpocmVmPTNEImh0dHA6Ly9mb3J1bXMubWF0 cm9uaWNzLmNvbSI+aHR0cDo9DQovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQpocmVmPTNEImh0dHA6 Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24iPQ0KOz5odHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vYw0KIA0KIA0KIA0KIA0KIA0KIA0KIDw9DQovcHJlPg0KIA0KaHR0cDovL3d3dy5tYXRy b25pYz0NCnMuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCjw9DQpmb250DQpzaXplPTNEMiBjb2xv cj0zRGJsYWNrIGZhY2U9M0QiQ291cmllciBOZXciPg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tPQ0KaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2M9DQpvbnRyaWJ1dGlvbg0KIA0KIA0KIA0K IA0KIA0KIA0KIA0KIA0KIA0KDQogICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoNCkxpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQog ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KM0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0KICAgICAgICAgLSBN QVRST05JQ1MgV0VCIEZPUlVNM0QgU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZp YSB0aGUgV2ViIEZvcnVtcyENCg0KdW1zLm1hdHJvbmljcy5jb20NCg0KPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEDQoNCiANCg0KwqbCt+KAun7igLDDrcKyLMOe DQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQoNCnDDtnLigLBowqwgw5NNfcKn DQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQoNCnDCosOqesK5w4HDisKuJw0K DQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KDQpfX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fXw0KDQpww5zDvcK/w5/ConsgwqbCt8K/buKAoXLDvmYNCg0KIA0KDQogDQog DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQpfLT0g VXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQpfLT0g dGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCl8t PSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQpfLT0NCl8tPSAgIC0tPiBodHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KXy09DQpfLT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAg ICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQpfLT0gU2FtZSBncmVhdCBjb250 ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCl8tPQ0KXy09ICAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KXy09DQpfLT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KXy09ICAgICAgICAgICAgIC0g TGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2Vu ZXJvdXMgc3VwcG9ydCENCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERy YWxsZSwgTGlzdCBBZG1pbi4NCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29u dHJpYnV0aW9uDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KIA0K ________________________________________________________________________________
Date: Jul 12, 2011
I've just gone through all the decisions about an engine for my RV-10 and settled on a Thunderbolt from Lycoming. There are many quality field facilities to go to, but the price and value lead me to the Thunderbolt. The price was only a little more than the stock OEM engine, but had the added internal component balancing, cylinder volumetric balancing and port and polish intake and exhaust chambers. They are providing the AirFlow Performance injector system, configured to my spec. I had many conflicting thoughts concerning engine break-in. I even considered buying a used engine, run it for a couple of hundred hours then have it overhauled. I decided to go with extra run-time in the Lycoming test cell. It's only an extra $200 to have a total of 5 hrs test cell time. This should get me through the worst of the break-in concerns. I'm having the engine prepared for long term storage with desiccant plugs and preservation oil in the crankcase and cylinders. (This was included for free.) This should provide protection during installation, cowl fitting, etc. I was able to delay delivery and hold the current price ($43K) for delivery next June, when I expect to be ready for it. Lycoming will deliver the engine anywhere in the CONUS for a flat $199. I can't drive there and back for less than that! If anyone is seriously interested in a Thunderbolt, call Jeff at Lycoming (the Thunderbolt guy) and see if he will honor that price. The price only changed in the last few days. Anyway this what I decided to do. Everyone should do what works best for them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346162#346162 ________________________________________________________________________________
Date: Jul 12, 2011
Also makes for safer first flight, when you don't have to rush things worrying about glazing rings, etc. On Tue, Jul 12, 2011 at 5:54 PM, John Cox wrote: > > Thanks for chiming in. When calculating comparable engine costs, The value of a solid break-in can often help with other factors to reach TBO with the rings and related components. > > > John > > ________________________________________________________________________________
Date: Jul 12, 2011
Bill, the choice of AirFlow Performance is a solid one. Be sure and research their "balancing their injectors" instructions. If you have time, their Carolina hospitality is wonderful and the twice a year training school well worth the time invested. Bring your aircraft! John -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of billz Sent: Tuesday, July 12, 2011 7:25 PM Subject: RV10-List: Re: Engine Referral I've just gone through all the decisions about an engine for my RV-10 and settled on a Thunderbolt from Lycoming. There are many quality field facilities to go to, but the price and value lead me to the Thunderbolt. The price was only a little more than the stock OEM engine, but had the added internal component balancing, cylinder volumetric balancing and port and polish intake and exhaust chambers. They are providing the AirFlow Performance injector system, configured to my spec. I had many conflicting thoughts concerning engine break-in. I even considered buying a used engine, run it for a couple of hundred hours then have it overhauled. I decided to go with extra run-time in the Lycoming test cell. It's only an extra $200 to have a total of 5 hrs test cell time. This should get me through the worst of the break-in concerns. I'm having the engine prepared for long term storage with desiccant plugs and preservation oil in the crankcase and cylinders. (This was included for free.) This should provide protection during installation, cowl fitting, etc. I was able to delay delivery and hold the current price ($43K) for delivery next June, when I expect to be ready for it. Lycoming will deliver the engine anywhere in the CONUS for a flat $199. I can't drive there and back for less than that! If anyone is seriously interested in a Thunderbolt, call Jeff at Lycoming (the Thunderbolt guy) and see if he will honor that price. The price only change! d in the last few days. Anyway this what I decided to do. Everyone should do what works best for them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346162#346162 ________________________________________________________________________________
Date: Jul 13, 2011
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
John: Were you just referenced in the latest Popular Mechanics? In the article on air safety? I also have to keep on Rhonda's good side. I bought a Barrett engine "second hand" and they have been nothing more than great in answering my questions and helping on the install. Fred Williams 515FW See you Sunday at osh. On 7/12/2011 10:11 PM, John Cox wrote: > --> RV10-List message posted by: "John Cox" > > Bill, the choice of AirFlow Performance is a solid one. Be sure and > research their "balancing their injectors" instructions. If you have > time, their Carolina hospitality is wonderful and the twice a year > training school well worth the time invested. Bring your aircraft! > > John > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of billz > Sent: Tuesday, July 12, 2011 7:25 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Engine Referral > > --> RV10-List message posted by: "billz" > > I've just gone through all the decisions about an engine for my RV-10 > and settled on a Thunderbolt from Lycoming. There are many quality > field facilities to go to, but the price and value lead me to the > Thunderbolt. The price was only a little more than the stock OEM > engine, but had the added internal component balancing, cylinder > volumetric balancing and port and polish intake and exhaust chambers. > They are providing the AirFlow Performance injector system, configured > to my spec. > > I had many conflicting thoughts concerning engine break-in. I even > considered buying a used engine, run it for a couple of hundred hours > then have it overhauled. I decided to go with extra run-time in the > Lycoming test cell. It's only an extra $200 to have a total of 5 hrs > test cell time. This should get me through the worst of the break-in > concerns. I'm having the engine prepared for long term storage with > desiccant plugs and preservation oil in the crankcase and cylinders. > (This was included for free.) This should provide protection during > installation, cowl fitting, etc. I was able to delay delivery and hold > the current price ($43K) for delivery next June, when I expect to be > ready for it. Lycoming will deliver the engine anywhere in the CONUS > for a flat $199. I can't drive there and back for less than that! If > anyone is seriously interested in a Thunderbolt, call Jeff at Lycoming > (the Thunderbolt guy) and see if he will honor that price. The price > only change! > d in the last few days. > > Anyway this what I decided to do. Everyone should do what works best > for them. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346162#346162 > > ________________________________________________________________________________
Date: Jul 13, 2011
I would echo Sean on this one.- As many new RV-10's come to the market ma ke sure you contact and talk to Bart at Aerosport as well. =0A=0AThe great news is that the companies like Aerosport, Barret and others are growing be cause they offer great products and great customer service. =0A=0AAerosport offers rebuilt engines at a great price, they are not listed on his websit e but the price of his rebuilt and a new prop from Van's is still cheaper t han the deal that Van's has done in the past. =0A=0A-=0AScott Schmidt=0As cottmschmidt(at)yahoo.com=0A=0A=0A=0A>________________________________=0A>From : Seano =0A>To: "rv10-list(at)matronics.com" =0A>Sent: Tuesday, July 12, 2011 3:18 PM=0A>Subject: Re: RV10- raunandco.com>=0A>=0A>So far I have been really happy with my Aerosport Pow er IO-540-N1A5=0A>Almost 50 hours on it.=0A>=0A>Sent from my iPhone=0A>=0A> On Jul 12, 2011, at 12:17, "N306PB" wrote:=0A>=0A>> --> RV10-List message posted by: "N306PB" =0A>> =0A>> As Os hkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact m e privately for a referral. In a nutshell, dealing with them has been the m ost frustrating, disappointing, and infuriating experience of my entire RV- 10 build.=0A>> =0A>> =0A>> =0A>> =0A>> Read this topic online here:=0A>> =0A>> http://forums.matronics.com/viewtopic.php?p=346091#346091=0A>> =0A> ==================0A>=0A>=0A>=0A>=0A>=0A> ________________________________________________________________________________
Date: Jul 13, 2011
I've been amazed at Bart's service so far. Whenever I've had a question, I call and get an answer. When I've needed some gaskets or seals, he just sends them without charge. It's been above and beyond. Tim Olson - RV-10 N104CD On 7/13/2011 10:30 AM, Scott Schmidt wrote: > I would echo Sean on this one. As many new RV-10's come to the market > make sure you contact and talk to Bart at Aerosport as well. > The great news is that the companies like Aerosport, Barret and others > are growing because they offer great products and great customer service. > Aerosport offers rebuilt engines at a great price, they are not listed > on his website but the price of his rebuilt and a new prop from Van's is > still cheaper than the deal that Van's has done in the past. > Scott Schmidt > scottmschmidt(at)yahoo.com > > ------------------------------------------------------------------------ > *From:* Seano > *To:* "rv10-list(at)matronics.com" > *Sent:* Tuesday, July 12, 2011 3:18 PM > *Subject:* Re: RV10-List: Engine Referral > > > > > So far I have been really happy with my Aerosport Power IO-540-N1A5 > Almost 50 hours on it. > > Sent from my iPhone > > On Jul 12, 2011, at 12:17, "N306PB" > wrote: > > > > > > > As Oshkosh approaches I am sure there are some out there looking > for an engine. Should you be tempted by the New Firewall Forward out > of Colorado contact me privately for a referral. In a nutshell, > dealing with them has been the most frustrating, disappointing, and > infuriating experience of my entire RV-10 build. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > > > &10-List" > target="_blank">http://www.matronics.com/Navigator?RV10-Lista > href="http://forums.matronics.com" = --> > > > <http://www.matronics.com/contribution> > > * > > > * ________________________________________________________________________________
Date: Jul 13, 2011
Scott, That wasn't the case at OSH last year. I agree that both Aerosport and Barr ett do great work. I looked at getting rebuilds from both of them. They we re both several thousand more than Van's OSH deal. If you are cash strapped , it's hard to beat Van's OSH special. With Barrett and Mattituck unable to sell new kits, it makes you wonder how l ong Aerosport will be able to do the same. Bob Sent from my iPhone On Jul 13, 2011, at 11:30 AM, Scott Schmidt wrote: > I would echo Sean on this one. As many new RV-10's come to the market mak e sure you contact and talk to Bart at Aerosport as well. > The great news is that the companies like Aerosport, Barret and others are growing because they offer great products and great customer service. > Aerosport offers rebuilt engines at a great price, they are not listed on h is website but the price of his rebuilt and a new prop from Van's is still c heaper than the deal that Van's has done in the past. > > Scott Schmidt > scottmschmidt(at)yahoo.com > > From: Seano <sean(at)braunandco.com> > To: "rv10-list(at)matronics.com" > Sent: Tuesday, July 12, 2011 3:18 PM > Subject: Re: RV10-List: Engine Referral > > > So far I have been really happy with my Aerosport Power IO-540-N1A5 > Almost 50 hours on it. > > Sent from my iPhone > > On Jul 12, 2011, at 12:17, "N306PB" wrote: > > > > > As Oshkosh approaches I am sure there are some out there looking for an e ngine. Should you be tempted by the New Firewall Forward out of Colorado con tact me privately for a referral. In a nutshell, dealing with them has been t he most frustrating, disappointing, and infuriating experience of my entire R V-10 build. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > > > &10-List" target="_blank">http://www.matronics.com/Navigator?RV10-Lista h ref="http://forums.matronics.com" = --> > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 13, 2011
There is nothing wrong with a old, but in good shape, Narrow deck core. They are hard to come by but once located by Barrett or other reputable builder can be made to be very close to new specs. I have no idea if Lycoming resolved the wide deck cracking issues they were having, hopefully they have by now. Also older technology are easier to replace (read less expensive) than the roller-tappets are.. A good engine builder can do wonders with anything given to them, in some cases better than a new engine from Lycoming that I don=99t think is even =9Crun in=9D before going out. New isn=99t always better, reputation of a builder is everything. You want new, if one can get the Thunderbolt for 2K more than Vans, do that, If your cash strapped and want new, check out the Vans special at OSH. If you want a good engine and don=99t care if it=99s new or rebuilt, call the builders that have come recommended on this list, you wont be disappointed either way. From: Bob Leffler Sent: Wednesday, July 13, 2011 10:12 AM Subject: Re: RV10-List: Engine Referral Scott, That wasn't the case at OSH last year. I agree that both Aerosport and Barrett do great work. I looked at getting rebuilds from both of them. They were both several thousand more than Van's OSH deal. If you are cash strapped, it's hard to beat Van's OSH special. With Barrett and Mattituck unable to sell new kits, it makes you wonder how long Aerosport will be able to do the same. Bob Sent from my iPhone On Jul 13, 2011, at 11:30 AM, Scott Schmidt wrote: I would echo Sean on this one. As many new RV-10's come to the market make sure you contact and talk to Bart at Aerosport as well. The great news is that the companies like Aerosport, Barret and others are growing because they offer great products and great customer service. Aerosport offers rebuilt engines at a great price, they are not listed on his website but the price of his rebuilt and a new prop from Van's is still cheaper than the deal that Van's has done in the past. Scott Schmidt scottmschmidt(at)yahoo.com ------------------------------------------------------------------------- --- From: Seano <sean(at)braunandco.com> To: "rv10-list(at)matronics.com" Sent: Tuesday, July 12, 2011 3:18 PM Subject: Re: RV10-List: Engine Referral So far I have been really happy with my Aerosport Power IO-540-N1A5 Almost 50 hours on it. Sent from my iPhone On Jul 12, 2011, at 12:17, "N306PB" wrote: > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > &10-List" target="_blank">http://www.matronics.com/Navigator?RV10-Lista href="http://forums.matronics.com" = --> ========= courier new,courier">http://www.matronics.com/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contribut ion ========= ________________________________________________________________________________
Date: Jul 13, 2011
FYI all engines from Lycoming and thunder are ran in a test cell. My Overhauled engine for my old Cardinal thanks to Chevron was ran for 2 hours and a full report was with the engine. Thunder also runs all engines I think for the same amount of time. And they will do an extended run in, I do believe as requested by the purchaser for a cost I am sure Avgas is way to expensive to do free. John Cumins 40864 Wings From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Wednesday, July 13, 2011 11:04 AM Subject: Re: RV10-List: Engine Referral There is nothing wrong with a old, but in good shape, Narrow deck core. They are hard to come by but once located by Barrett or other reputable builder can be made to be very close to new specs. I have no idea if Lycoming resolved the wide deck cracking issues they were having, hopefully they have by now. Also older technology are easier to replace (read less expensive) than the roller-tappets are.. A good engine builder can do wonders with anything given to them, in some cases better than a new engine from Lycoming that I don=99t think is even =9Crun in=9D before going out. New isn=99t always better, reputation of a builder is everything. You want new, if one can get the Thunderbolt for 2K more than Vans, do that, If your cash strapped and want new, check out the Vans special at OSH. If you want a good engine and don=99t care if it=99s new or rebuilt, call the builders that have come recommended on this list, you wont be disappointed either way. From: Bob Leffler <mailto:rv(at)thelefflers.com> Sent: Wednesday, July 13, 2011 10:12 AM Subject: Re: RV10-List: Engine Referral Scott, That wasn't the case at OSH last year. I agree that both Aerosport and Barrett do great work. I looked at getting rebuilds from both of them. They were both several thousand more than Van's OSH deal. If you are cash strapped, it's hard to beat Van's OSH special. With Barrett and Mattituck unable to sell new kits, it makes you wonder how long Aerosport will be able to do the same. Bob Sent from my iPhone On Jul 13, 2011, at 11:30 AM, Scott Schmidt wrote: I would echo Sean on this one. As many new RV-10's come to the market make sure you contact and talk to Bart at Aerosport as well. The great news is that the companies like Aerosport, Barret and others are growing because they offer great products and great customer service. Aerosport offers rebuilt engines at a great price, they are not listed on his website but the price of his rebuilt and a new prop from Van's is still cheaper than the deal that Van's has done in the past. Scott Schmidt scottmschmidt(at)yahoo.com _____ From: Seano <sean(at)braunandco.com> Sent: Tuesday, July 12, 2011 3:18 PM Subject: Re: RV10-List: Engine Referral So far I have been really happy with my Aerosport Power IO-540-N1A5 Almost 50 hours on it. Sent from my iPhone On Jul 12, 2011, at 12:17, "N306PB" wrote: > > As Oshkosh approaches I am sure there are some out there looking for an engine. Should you be tempted by the New Firewall Forward out of Colorado contact me privately for a referral. In a nutshell, dealing with them has been the most frustrating, disappointing, and infuriating experience of my entire RV-10 build. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > &10-List" target="_blank">http://www.matronics.com/Navigator?RV10-Lista href="http://forums.matronics.com" = --> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> <http://www.matronics.com/contribution> ========= <http://www.matronics.com/contribution> courier new,courier">http://www.matronics.com/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution <http://www.matronics.com/contribution%22%3ehttp:/www.matronics.com/contr ibution> ">http://www.matronics.com/contribution ========= href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: Main wheels and brakes
Date: Jul 13, 2011
I just talked to parts at Van's and was told the new RV-10 kits now ship with Matco wheels and brake kits. I would like to know if this is right and if so witch wheels and brakes on the Matco site they are. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346221#346221 ________________________________________________________________________________
Date: Jul 13, 2011
Subject: Re: Main wheels and brakes
Year and a half ago for mine. I got clevelands. On Jul 13, 2011 1:46 PM, "mds4878" wrote: > > I just talked to parts at Van's and was told the new RV-10 kits now ship with Matco wheels and brake kits. I would like to know if this is right and if so witch wheels and brakes on the Matco site they are. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346221#346221 > > ________________________________________________________________________________
Date: Jul 13, 2011
As I'll be shopping for an engine at OSH (mainly because of the Van's special), this is a timely discussion. So how does the re-built option work? Do you have to provide the builder a core? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346226#346226 ________________________________________________________________________________
Subject: Re: Interior lights
Date: Jul 13, 2011
The lights look great I would buy them. Mike Schulz RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346227#346227 ________________________________________________________________________________
Date: Jul 13, 2011
You can provide a core, but it isn't a requirement. Naturally there is a price difference on the two options. Talk with Rhonda @ Barrett, she can explain the process. Although I end up buying the Van's special, both Rhonda and Alan were extremely open and answered any question that I had. Sent from my iPhone On Jul 13, 2011, at 3:22 PM, "tsts4" wrote: > > As I'll be shopping for an engine at OSH (mainly because of the Van's special), this is a timely discussion. So how does the re-built option work? Do you have to provide the builder a core? > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346226#346226 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2011
I'm sure I'd buy two or three. On Wed, Jul 13, 2011 at 2:36 PM, mds4878 wrote: > > The lights look great I would buy them. > > > Mike Schulz > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346227#346227 > > ________________________________________________________________________________
Date: Jul 13, 2011
Here is my 2c worth. In 2009, i went with the Van's special, as the default option. I wish I had known more about the Thunderbolt option. If the cost really was only marginally more, I would have seriously considered that route. However, i thought the difference was more along the lines of a few thousand, esp. give the extra $1k with prop offer. The Thunderbolt options vs factory seems to give you: - more customization: AirFlow FI, dsesicant plugs (i had to find my own), maybe custom colors, and maybe more hand-holding. clearly, the Lycoming factory is setup to drop ship engines to the Cessna factory or some other production facility. - $200 for 5 hours. what a deal! Factory does a 1 hour test run, i believe. - I had to do more install work like the engine mount ears (took a bit of work) and FI unit. In '09, i did talk with Aerosport, esp. about a rebuild. However, the main issue was the availability of cores. Their supply was up and down. The early builders had their pick of cores, but supply quickly disappeared. Jae 40533 ________________________________________________________________________________
Date: Jul 13, 2011
Subject: Rapco brake linings and discs now available
As you know if you've read my write-ups, I've been bugging Rapco for 4 or 5 years to start making the 66-112 brake linings for us so we have an alternate price and supply. The Cleveland ones go in and out of stock too often and the price is top dollar. I got a set of the new Rapco linings and replaced my discs at the same time since I scored one of them on the first brake pad run....running the rivets into the discs. So here's a write-up with pictures of the new discs. http://www.myrv10.com/N104CD/maintenance/20110711/index.html If you haven't seen the brake lining replacement write-up, also follow the link to that one from within this page. -- Tim Olson - RV-10 N104CD ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 13, 2011
Guess I'll be looking at a NavWorx after all. Turns out AFS got weather working in the last couple months. Sweet! I'm doing something similar with the radio. I originally started with a slide out receiver with a 7" screen that I picked up 5 or 6 years ago. It has a couple of external boxes and a boat load of wires running between them. I recently switched to a double DIN unit with no external boxes and a much cleaner install, same size screen, and less than half what I paid for the original. I'll be using a dock for my Sirius radio so I can move it between my truck/bike/ RV-10 and not have to pay the fees for three radios. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Tuesday, July 12, 2011 7:52 PM Subject: RE: RV10-List: Re: ATSB Transceiver... That's a Kenwood DNX-8120 Indash car entertainment system: http://www.kenwoodusa.com/Car_Entertainment/2008_Car_Entertainment/DNX8120 I've got the Garmin GPS map up on the display in those pictures. Attached are a few pictures of some of the other displays. The output on the display including the Garmin GPS map is also shown on the 7" LCD screen in the pilot's headrest that the passenger can see. There's also a review cam mounted at the top of the display in the headrest to give me a check-six view of the passenger. The Garmin GPS map display nice for passengers that aren't necessarily airplane savvy. It also shows the altitude and ground speed. I like having the Garmin map up front too as a cross reference to the GRT mapping. Also, the Garmin shows Airport names instead of the dopey 4-letter IDs! :-) On the Kenwood, I've got a 128GB and a 64GB USB thumb drives plugged in and they contain my whole MP3 music library! It also has XM Radio, HD digital AM/FM, and plays DVDs. The audio output is mixed through a PS Engineering 3000 intercom and then into Bose X (upgraded to A20s) NR headphones. The audio is pretty awesome. Very clear and easy to understand. By the way, I just got the UPS shipping notification from NavWorx (7/12/2011) on the ADS-B Transceiver so it took a little over a month from the order to the shipping. FYI. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... At 10:25 AM 7/12/2011 Tuesday, you wrote: >--> > >Matt, > What is the screen in the lower right corner? What are you >driving it with etc.? >Thanks, >Jerry Folkerts > >-----Original Message----- >From: owner-rv10-list-server(at)matronics.com >[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle >Sent: Tuesday, July 12, 2011 11:43 AM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Re: ATSB Transceiver... > > >Yes, I have three GRT HX EFIS's in the RV-8 (see attached pictures). >According to GRT, the Navworx transceiver should hook right up to the >ARNIC interface and go. Still haven't gotten my transciever from >Navworx yet, though. I ordered it on 6/10/2011 so its been over a >month now... They did charge my credit card, though... ;-/ > >Matt > > >At 07:41 PM 7/11/2011 Monday, you wrote: >>--> >> >>Matt, >> >> What are you using this with GRT's gear? I've been considering it >> for >some time but the interface to the Advanced Flight gear seems to be >permanently "under development" so I'm stuck with my 496 for weather. >> >>Sent from my iPad2 >> >>On Jul 3, 2011, at 5:30 PM, "Matt Dralle" wrote: >> >>> >>> At 02:07 PM 7/3/2011 Sunday, you wrote: >>>> --> >>>> >>>> Have been thinking about doing the same. Are you going with navworx? >>> >>> >>> I ordered the ADS600-B unit from NavWorx: >>> >>> <http://www.navworx.com/ads600-b.asp>http://www.navworx.com/ads600-b. >>> asp >>> >>> Here's their main site: >>> >>> <http://www.navworx.com/index.asp>http://www.navworx.com/index.asp >>> >>> They're not exactly cheap. Here's the price list: >>> >>> <http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600 >>> ->> >>> or-PADS600-Online-Now.aspx>http://navworx.americommerce.com/store/c/ >>> 2 1-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx >>> >>> I also ordered it with the WIFI module and the ARINC-429 for fun. >>> >>> Matt > ________________________________________________________________________________
Date: Jul 13, 2011
Very nice, I too would buy them if they wern't unreasonable.=0A=0A=0AFrom: Strasnuts =0ATo: rv10-list(at)matronics.com=0ASent: Monda y, July 11, 2011 4:55 PM=0ASubject: RV10-List: Interior lights=0A=0A--> RV1 0-List message posted by: "Strasnuts" =0A=0AMy dad and I made these rectangle LED lights for my RV-10.- I may make them availab le for sale but didn't know if there was a market for them.- They should be a lot cheaper than what's currently out there.- I had mine hard anodiz ed black.- I hooked them up on a dimmer and they work great.- I have th e small size for the floor lights with 8 LED's and the large have 24.=0A=0A --------=0A40936=0ARV-10 SB N801VR Flying=0A=0A=0A=0A=0ARead this topic onl ine here:=0A=0Ahttp://forums.matronics.com/viewtopic.php?p=345972#345972 =0A=0A=0A=0A=0AAttachments: =0A=0Ahttp://forums.matronics.com//files/photo_ 3_252.jpg=0Ahttp://forums.matronics.com//files/photo_2_148.jpg=0Ahttp://for ums.matronics.com//files/photo_1_926.jpg=0Ahttp://forums.matronics.com//fil ======================= ________________________________________________________________________________
Date: Jul 13, 2011
Same with Barrett's, always available for questions and if I need something I need seals or to borrow a tool they always send it. You can't beat the family run shops that take pride in their work! Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, July 13, 2011 10:46 AM Subject: Re: RV10-List: Engine Referral I've been amazed at Bart's service so far. Whenever I've had a question, I call and get an answer. When I've needed some gaskets or seals, he just sends them without charge. It's been above and beyond. Tim Olson - RV-10 N104CD On 7/13/2011 10:30 AM, Scott Schmidt wrote: > I would echo Sean on this one. As many new RV-10's come to the market > make sure you contact and talk to Bart at Aerosport as well. > The great news is that the companies like Aerosport, Barret and others > are growing because they offer great products and great customer service. > Aerosport offers rebuilt engines at a great price, they are not listed > on his website but the price of his rebuilt and a new prop from Van's > is still cheaper than the deal that Van's has done in the past. > Scott Schmidt > scottmschmidt(at)yahoo.com > > ------------------------------------------------------------------------ > *From:* Seano > *To:* "rv10-list(at)matronics.com" > *Sent:* Tuesday, July 12, 2011 3:18 PM > *Subject:* Re: RV10-List: Engine Referral > > > > > So far I have been really happy with my Aerosport Power IO-540-N1A5 > Almost 50 hours on it. > > Sent from my iPhone > > On Jul 12, 2011, at 12:17, "N306PB" > wrote: > > > > > > > As Oshkosh approaches I am sure there are some out there looking > for an engine. Should you be tempted by the New Firewall Forward out > of Colorado contact me privately for a referral. In a nutshell, > dealing with them has been the most frustrating, disappointing, and > infuriating experience of my entire RV-10 build. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=346091#346091 > > > > > > > > > > > > > > > &10-List" > target="_blank">http://www.matronics.com/Navigator?RV10-Lista > href="http://forums.matronics.com" = --> > > > <http://www.matronics.com/contribution> > > * > > > * ________________________________________________________________________________
Date: Jul 13, 2011
I just got mine in a few weeks ago and they were Matco. I will look at which ones they are specifically when I get out to the hanger this evening. I left them in the box. Shannon On Wed, Jul 13, 2011 at 1:36 PM, mds4878 wrote: > > I just talked to parts at Van's and was told the new RV-10 kits now ship > with Matco wheels and brake kits. I would like to know if this is right and > if so witch wheels and brakes on the Matco site they are. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346221#346221 > > ________________________________________________________________________________
Date: Jul 13, 2011
Count me in for a pair as well. Shannon On Wed, Jul 13, 2011 at 2:36 PM, mds4878 wrote: > > The lights look great I would buy them. > > > Mike Schulz > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346227#346227 > > ________________________________________________________________________________
Subject: Re: Engine Referral
Date: Jul 13, 2011
I got the afp injection on the vans osh special. It also was run for two hours. It was almost $4k cheaper than the thunderbolt when I ordered mine last year. Look me up at camp Scholler if you want more details. I suspect my tent will be near where the old rv-10 hq used to be, or within a street or two. Sent from my iPhone On Jul 13, 2011, at 4:19 PM, Jae Chang wrote: > > Here is my 2c worth. In 2009, i went with the Van's special, as the default option. I wish I had known more about the Thunderbolt option. If the cost really was only marginally more, I would have seriously considered that route. However, i thought the difference was more along the lines of a few thousand, esp. give the extra $1k with prop offer. > > The Thunderbolt options vs factory seems to give you: > - more customization: AirFlow FI, dsesicant plugs (i had to find my own), maybe custom colors, and maybe more hand-holding. clearly, the Lycoming factory is setup to drop ship engines to the Cessna factory or some other production facility. > - $200 for 5 hours. what a deal! Factory does a 1 hour test run, i believe. > - I had to do more install work like the engine mount ears (took a bit of work) and FI unit. > > In '09, i did talk with Aerosport, esp. about a rebuild. However, the main issue was the availability of cores. Their supply was up and down. The early builders had their pick of cores, but supply quickly disappeared. > > Jae > 40533 > > > > > > > > ________________________________________________________________________________
From: "John MacCallum" <vk2gcn(at)cirruscomms.com.au>
Date: Jul 14, 2011
Me as well J Cheers John MacCallum Builder # 41016 VH-DUU From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Shannon Hicks Sent: Thursday, 14 July 2011 7:18 AM Subject: Re: RV10-List: Re: Interior lights Count me in for a pair as well. Shannon On Wed, Jul 13, 2011 at 2:36 PM, mds4878 wrote: The lights look great I would buy them. Mike Schulz RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346227#346227 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: Re: Rapco brake linings and discs now available
Date: Jul 13, 2011
Desser sells the Rapco's as a reminder. -----Original Message----- From: Tim Olson Sent: Wednesday, July 13, 2011 1:19 PM Subject: RV10-List: Rapco brake linings and discs now available As you know if you've read my write-ups, I've been bugging Rapco for 4 or 5 years to start making the 66-112 brake linings for us so we have an alternate price and supply. The Cleveland ones go in and out of stock too often and the price is top dollar. I got a set of the new Rapco linings and replaced my discs at the same time since I scored one of them on the first brake pad run....running the rivets into the discs. So here's a write-up with pictures of the new discs. http://www.myrv10.com/N104CD/maintenance/20110711/index.html If you haven't seen the brake lining replacement write-up, also follow the link to that one from within this page. -- Tim Olson - RV-10 N104CD ________________________________________________________________________________
Date: Jul 13, 2011
It turned out that the main wheels and brakes that I received from Van's were Grove. 2 ea 60-2M Wheel Assy 2 ea 36-2M Caliper Assy 020-006 Torque Plate Ass Let me know if you want some photos. Shannon On Jul 13, 2011 4:16 PM, "Shannon Hicks" wrote: > I just got mine in a few weeks ago and they were Matco. I will look at > which ones they are specifically when I get out to the hanger this evening. > I left them in the box. > > Shannon > > On Wed, Jul 13, 2011 at 1:36 PM, mds4878 wrote: > >> >> I just talked to parts at Van's and was told the new RV-10 kits now ship >> with Matco wheels and brake kits. I would like to know if this is right and >> if so witch wheels and brakes on the Matco site they are. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=346221#346221 >> >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Jul 13, 2011
Your right the lady told me the wrong name it is Grove. Thanks for the info. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346254#346254 ________________________________________________________________________________
Date: Jul 13, 2011
Desser gave me a very nice deal on tires and tubes, buying their standard recaps exchanged for worn out cores. I've had very good service from their recaps here in Aridzona heat, much better than new tires. IIRC the exchange price gave about $10 credit for each core. On 7/13/2011 2:34 PM, Pascal wrote: > > Desser sells the Rapco's as a reminder. > > -----Original Message----- From: Tim Olson Sent: Wednesday, July 13, > 2011 1:19 PM To: RV10 Subject: RV10-List: Rapco brake linings and > discs now available > > As you know if you've read my write-ups, I've been > bugging Rapco for 4 or 5 years to start making the > 66-112 brake linings for us so we have an alternate > price and supply. The Cleveland ones go in and out > of stock too often and the price is top dollar. > I got a set of the new Rapco linings and replaced > my discs at the same time since I scored one of > them on the first brake pad run....running the rivets > into the discs. > > So here's a write-up with pictures of the new > discs. > > http://www.myrv10.com/N104CD/maintenance/20110711/index.html > > If you haven't seen the brake lining replacement write-up, > also follow the link to that one from within this page. > ________________________________________________________________________________
Date: Jul 13, 2011
Interesting. Grove are supposed to be very nice. I can't believe Vans would switch from Cleveland for any reason other than money. On 7/13/2011 4:00 PM, mds4878 wrote: > --> RV10-List message posted by: "mds4878" > > Your right the lady told me the wrong name it is Grove. > Thanks for the info. > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346254#346254 > > ________________________________________________________________________________
Date: Jul 13, 2011
I see Grove has a very simple nose wheel setup for the 10 with the ability to upgrade the axel to prevent it from rotating and uses standard felt seals, unlike the matco wheel. Looks like I will go the matco route when I get there for nose gear. John Cumins 40864 Wings -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, July 13, 2011 4:13 PM Subject: Re: RV10-List: Re: Main wheels and brakes Interesting. Grove are supposed to be very nice. I can't believe Vans would switch from Cleveland for any reason other than money. On 7/13/2011 4:00 PM, mds4878 wrote: > --> RV10-List message posted by: "mds4878" > > Your right the lady told me the wrong name it is Grove. > Thanks for the info. > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346254#346254 > > ________________________________________________________________________________
Subject: Spacers under windows
Date: Jul 13, 2011
Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ________________________________________________________________________________
Date: Jul 14, 2011
Subject: Re: Spacers under windows
I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: > > Life got in the way for a bit but I'm back on track building and airplane > again....... > > Curious to know how many people installed washers under their plexiglas at > the time they were installed. Mine sit proud enough as it is and I'd really > prefer not to use them if possible. Any results from those who didn't use > them and how long have you been flying? > > Hope to catch some of you at Osh this year.... > > Phil > > ________________________________________________________________________________
Date: Jul 14, 2011
I did not use spacers... but did level out the recessed areas with flox using the windows as forms Jeff Carpenter 40304 On Jul 14, 2011, at 8:55 AM, Phillip Perry wrote: > I guess everyone used spacers - huh?? > > :) > > > On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry > wrote: > > Life got in the way for a bit but I'm back on track building and > airplane again....... > > Curious to know how many people installed washers under their > plexiglas at the time they were installed. Mine sit proud enough as > it is and I'd really prefer not to use them if possible. Any > results from those who didn't use them and how long have you been > flying? > > Hope to catch some of you at Osh this year.... > > Phil > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Jul 14, 2011
As I recall, the only reason to use spacers is if the plexi sits below the fiberglass. Jim Berry N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346330#346330 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jul 14, 2011
I didn't use spacers at all on any windows. Sent from my iPhone On Jul 14, 2011, at 12:40 PM, "Jim Berry" wrote: > > As I recall, the only reason to use spacers is if the plexi sits below the fiberglass. > > Jim Berry > N15JB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346330#346330 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 14, 2011
I used one or two total for all 4 windows..if I remember correctly. J Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, July 14, 2011 9:55 AM Subject: Re: RV10-List: Spacers under windows I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 14, 2011
Be sure to add two one inch biased glass strips around the external frame to prevent the flange line appearing out of the paint in a hindered hours or so. ----- Original Message ----- From: "Jim Berry" <jimberry(at)qwest.net> Sent: Thursday, July 14, 2011 9:40 AM Subject: RV10-List: Re: Spacers under windows > > As I recall, the only reason to use spacers is if the plexi sits below the > fiberglass. > > Jim Berry > N15JB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346330#346330 > > > ________________________________________________________________________________
Date: Jul 14, 2011
I did use spacers but thinking back I wish I would have let the plexi sit low and carve a little of the cabin down to accept the thickness of the glass tape around the windows. That way it wouldn't have been such a big job to transition the hump out of the glass tape around the windows to the cabin. ----- Original Message ----- From: "Jim Berry" <jimberry(at)qwest.net> Sent: Thursday, July 14, 2011 10:40 AM Subject: RV10-List: Re: Spacers under windows > > As I recall, the only reason to use spacers is if the plexi sits below the > fiberglass. > > Jim Berry > N15JB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346330#346330 > > > ________________________________________________________________________________
Date: Jul 14, 2011
The purpose of the spacers is to fill a gap. Sounds like that is not your issue. Leave it I say! From: Phillip Perry Sent: Thursday, July 14, 2011 8:55 AM Subject: Re: RV10-List: Spacers under windows I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 14, 2011
No washers, just the thicker Weld-On 45 to fill any gaps. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346388#346388 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jul 14, 2011
No washers and no Weld-On. I used Hysol (http://shop.lancair.com/inventoryD.asp?item_no=9360-QT&CatId={992B7B06-E01B -4918-BB0C-79343CDB7869} adding just a little flox to thicken as required (this is enough Hysol for 2 or 3 RV-10s). I used clamps to make the glass panels flush with the canopy cut outs, letting it sit for 24 hours before removing the clamps. The Hysol is full strength after a week or so. I did add a narrow two bid layup over the window/canopy junction to prevent the window paint cracking problem. Carl Froehlich RV-8A (650 hrs) RV-10 (moving the fuselage into the paint booth this weekend) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Thursday, July 14, 2011 6:37 PM Subject: RV10-List: Re: Spacers under windows No washers, just the thicker Weld-On 45 to fill any gaps. -------- Wayne Gillispie, A&P 5/93, PPC 10/08 Bldr# 40983 SB Started 12/1/09. Fuselage Sec 46 Eng mount/Gear- 1359 hrs to date. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346388#346388 ________________________________________________________________________________
Subject: TIRES AND TUBES
Date: Jul 14, 2011
I'm looking at Michelin Aviator tires. My question is Leakguard tubes or Michelin tubes and why? Also is Michelin good or bad. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346418#346418 ________________________________________________________________________________
Date: Jul 14, 2011
Subject: Re: TIRES AND TUBES
I don't know the answer to your question, but it got me to thinking .... which may not be a good thing. I wonder why we can't use the tire puncture sealer in a can to seal the standard aircraft tube? You should be able to use one can to seal all three tubes. You could distribute the sealer inside the tube really well before installing the tubes in the tire. Also Michelin makes Airstop tubes. I think the Leakguard are Aero Classic. Linn On 7/14/2011 9:47 PM, mds4878 wrote: > --> RV10-List message posted by: "mds4878" > > I'm looking at Michelin Aviator tires. > My question is Leakguard tubes or Michelin tubes and why? > Also is Michelin good or bad. > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346418#346418 > > ________________________________________________________________________________
Date: Jul 14, 2011
Leakguard work fine. They may be sourced through Desser's recap division. Depends on what objective is for tire. Most cost effective, or top of the line, what ever perceived benefit that is, or something else. If you want aramid belted, top of the line Goodyear is the only one. If you want new but low cost, Condor(by Michelin) through Desser is probably best buy. Or if you are okay with recap, Desser on W coast or Wilkerson on E coast are your sources. Van supplies Specialty Tires(aka McCreary) which seem to be favorite of flight schools. On Thu, Jul 14, 2011 at 7:14 PM, Linn Walters wrote: > > I don't know the answer to your question, but it got me to thinking .... > which may not be a good thing. > I wonder why we can't use the tire puncture sealer in a can to seal the > standard aircraft tube? You should be able to use one can to seal all three > tubes. You could distribute the sealer inside the tube really well before > installing the tubes in the tire. > > Also Michelin makes Airstop tubes. I think the Leakguard are Aero Classic. > Linn > > > On 7/14/2011 9:47 PM, mds4878 wrote: > >> --> RV10-List message posted by: "mds4878"<mike@**profishenterprises.com >> > >> >> I'm looking at Michelin Aviator tires. >> My question is Leakguard tubes or Michelin tubes and why? >> Also is Michelin good or bad. >> >> -------- >> RV-10 #40447 >> Fuselage almost done. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=346418#346418> >> >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 15, 2011
I was just going by the name and really don't know what tire to buy. The plane will be at a grass strip as long as I own it and will probably see hard surface strips 30% of it's landings. Everybody's input will be looked at and considered. -------- RV-10 #40447 Fuselage almost done. Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=346480#346480 ________________________________________________________________________________
Date: Jul 15, 2011
Michelin Airstop tubes on my RV6 for the last six years. May have added a little air twice at the most. They just don't leak. Jerry Calvert Edmond Ok From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, July 14, 2011 10:03 PM Subject: Re: RV10-List: TIRES AND TUBES Leakguard work fine. They may be sourced through Desser's recap division. Depends on what objective is for tire. Most cost effective, or top of the line, what ever perceived benefit that is, or something else. If you want aramid belted, top of the line Goodyear is the only one. If you want new but low cost, Condor(by Michelin) through Desser is probably best buy. Or if you are okay with recap, Desser on W coast or Wilkerson on E coast are your sources. Van supplies Specialty Tires(aka McCreary) which seem to be favorite of flight schools. On Thu, Jul 14, 2011 at 7:14 PM, Linn Walters wrote: I don't know the answer to your question, but it got me to thinking .... which may not be a good thing. I wonder why we can't use the tire puncture sealer in a can to seal the standard aircraft tube? You should be able to use one can to seal all three tubes. You could distribute the sealer inside the tube really well before installing the tubes in the tire. Also Michelin makes Airstop tubes. I think the Leakguard are Aero Classic. Linn On 7/14/2011 9:47 PM, mds4878 wrote: --> RV10-List message posted by: "mds4878" I'm looking at Michelin Aviator tires. My question is Leakguard tubes or Michelin tubes and why? Also is Michelin good or bad. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346418#346418 =================================== arget="_blank">http://www.matronics.com/Navigator?RV10-List =================================== http://forums.matronics.com =================================== le, List Admin. ="_blank">http://www.matronics.com/contribution =================================== ________________________________________________________________________________
Date: Jul 15, 2011
Thanks for the feedback. One last question. What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: > The purpose of the spacers is to fill a gap. Sounds like that is not > your issue. Leave it I say! > > > *From:* Phillip Perry > *Sent:* Thursday, July 14, 2011 8:55 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Spacers under windows > > I guess everyone used spacers - huh?? > > :) > > > On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: > >> >> Life got in the way for a bit but I'm back on track building and airplane >> again....... >> >> Curious to know how many people installed washers under their plexiglas at >> the time they were installed. Mine sit proud enough as it is and I'd really >> prefer not to use them if possible. Any results from those who didn't use >> them and how long have you been flying? >> >> Hope to catch some of you at Osh this year.... >> >> Phil >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Jul 15, 2011
Acetone is very hard on Acrylic. It will cause chemical crazing. I would recommend something else. Gary Specketer _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Friday, July 15, 2011 11:00 AM Subject: Re: RV10-List: Spacers under windows Thanks for the feedback. One last question. What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: The purpose of the spacers is to fill a gap. Sounds like that is not your issue. Leave it I say! From: Phillip <mailto:philperry9(at)gmail.com> Perry Sent: Thursday, July 14, 2011 8:55 AM Subject: Re: RV10-List: Spacers under windows I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 15, 2011
Phil acetone is very bad for acrylic. I would avoid the Weld on and use Lord urethane adhesive. Stronger than Weld on and you get a longer cure time And you can clean the oozing off with Enamel reducer. Ppg dt 870 is what I used. Will not hurt the acrylic Geoff Sent from my iPhone Geoff On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: > Thanks for the feedback. One last question. > > What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing off with acetone on the interior and exterior sides. > > Is there something that works better? > > Phil > > > > > > > On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: > The purpose of the spacers is to fill a gap. Sounds like that is not your i ssue. Leave it I say! > > > From: Phillip Perry > Sent: Thursday, July 14, 2011 8:55 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Spacers under windows > > I guess everyone used spacers - huh?? > > :) > > > > > On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: > > Life got in the way for a bit but I'm back on track building and airplane a gain....... > > Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd reall y prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? > > Hope to catch some of you at Osh this year.... > > Phil > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 15, 2011
I hope denatured alcohol isn't a problem. That's what I cleaned the mating surfaces with last night. Phil On Fri, Jul 15, 2011 at 1:02 PM, g.combs wrote: > Phil acetone is very bad for acrylic. > I would avoid the Weld on and use > Lord urethane adhesive. Stronger than > Weld on and you get a longer cure time > And you can clean the oozing off with > Enamel reducer. Ppg dt 870 is what > I used. Will not hurt the acrylic > Geoff > > Sent from my iPhone Geoff > > > On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: > > Thanks for the feedback. One last question. > > What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing > off with acetone on the interior and exterior sides. > > Is there something that works better? > > Phil > > > On Thu, Jul 14, 2011 at 2:36 PM, Pascal < > rv10flyer(at)verizon.net> wrote: > >> The purpose of the spacers is to fill a gap. Sounds like that is not >> your issue. Leave it I say! >> >> >> *From:* Phillip Perry >> *Sent:* Thursday, July 14, 2011 8:55 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: RV10-List: Spacers under windows >> >> I guess everyone used spacers - huh?? >> >> :) >> >> >> >> >> On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry < >> philperry9(at)gmail.com> wrote: >> >>> philperry9(at)gmail.com> >>> >>> Life got in the way for a bit but I'm back on track building and airplane >>> again....... >>> >>> Curious to know how many people installed washers under their plexiglas >>> at the time they were installed. Mine sit proud enough as it is and I'd >>> really prefer not to use them if possible. Any results from those who >>> didn't use them and how long have you been flying? >>> >>> Hope to catch some of you at Osh this year.... >>> >>> Phil >>> >>> ========== >>> arget="_blank"> <http://www.matronics.com/Navigator?RV10-List> >>> http://www.matronics.com/Navigator?RV10-List >>> ========== >>> <http://forums.matronics.com>http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank"> <http://www.matronics.com/contribution> >>> http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> * >> >> href=" http://www.matronics.com/Navigator?RV10-List"> http://www.matronics.com/Navigator?RV10-List >> href=" http://forums.matronics.com"> http://forums.matronics.com >> href=" http://www.matronics.com/contribution"> http://www.matronics.com/c* >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > * > > * > > ________________________________________________________________________________
Date: Jul 15, 2011
I used a 50/50 mixture of acetone and mineral spirits to clear away the west system epoxy. ----- Original Message ----- From: gary To: rv10-list(at)matronics.com Sent: Friday, July 15, 2011 9:58 AM Subject: RE: RV10-List: Spacers under windows Acetone is very hard on Acrylic. It will cause chemical crazing. I would recommend something else. Gary Specketer ------------------------------------------------------------------------- ----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Friday, July 15, 2011 11:00 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Spacers under windows Thanks for the feedback. One last question. What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: The purpose of the spacers is to fill a gap. Sounds like that is not your issue. Leave it I say! From: Phillip Perry Sent: Thursday, July 14, 2011 8:55 AM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Spacers under windows I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://foru ms.matronics.comhref="http://www.matronics.com/contribution">http://www .matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.ma tronics.com_blank">http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jul 15, 2011
Phil I would be careful with that as well. That can affect some acrylics. Sometimes it can cause crazing later on in the Life of the window. Geoff Geoff Combs President 614-834-5227p 614-834-5230f www.aerosportmodeling.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Friday, July 15, 2011 2:27 PM Subject: Re: RV10-List: Spacers under windows I hope denatured alcohol isn't a problem. That's what I cleaned the mating surfaces with last night. Phil On Fri, Jul 15, 2011 at 1:02 PM, g.combs wrote: Phil acetone is very bad for acrylic. I would avoid the Weld on and use Lord urethane adhesive. Stronger than Weld on and you get a longer cure time And you can clean the oozing off with Enamel reducer. Ppg dt 870 is what I used. Will not hurt the acrylic Geoff Sent from my iPhone Geoff On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: Thanks for the feedback. One last question. What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozing off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal < rv10flyer(at)verizon.net> wrote: The purpose of the spacers is to fill a gap. Sounds like that is not your issue. Leave it I say! From: Phillip <mailto:philperry9(at)gmail.com> Perry Sent: Thursday, July 14, 2011 8:55 AM Subject: Re: RV10-List: Spacers under windows I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry < philperry9(at)gmail.com> wrote: philperry9(at)gmail.com> Life got in the way for a bit but I'm back on track building and airplane again....... Curious to know how many people installed washers under their plexiglas at the time they were installed. Mine sit proud enough as it is and I'd really prefer not to use them if possible. Any results from those who didn't use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil ========== arget="_blank"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List ========== <http://forums.matronics.com> http://forums.matronics.com ========== le, List Admin. ="_blank"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution ========== href=" http://www.matronics.com/Navigator?RV10-List"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List href=" http://forums.matronics.com"> <http://forums.matronics.com> http://forums.matronics.com href=" http://www.matronics.com/contribution"> http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution 3D=========================3 D=================== 3D=========================3 D=================== 3D=========================3 D=================== 3D=========================3 D=================== ________________________________________________________________________________
Date: Jul 15, 2011
Kerosene is what you want. Tim On 7/15/2011 1:57 PM, Geoff Combs wrote: > Phil I would be careful with that as well. That can affect some > acrylics. Sometimes it can cause crazing later on in the > > Life of the window. > > Geoff > > **Geoff Combs** > > President > > **614-834-5227p** > 614-834-5230f > > www.aerosportmodeling.com <http://www.aerosportmodeling.com> > > ------------------------------------------------------------------------ > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry > *Sent:* Friday, July 15, 2011 2:27 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Spacers under windows > > I hope denatured alcohol isn't a problem. That's what I cleaned the > mating surfaces with last night. > > Phil > > > On Fri, Jul 15, 2011 at 1:02 PM, g.combs > wrote: > > Phil acetone is very bad for acrylic. > > I would avoid the Weld on and use > > Lord urethane adhesive. Stronger than > > Weld on and you get a longer cure time > > And you can clean the oozing off with > > Enamel reducer. Ppg dt 870 is what > > I used. Will not hurt the acrylic > > Geoff > > Sent from my iPhone Geoff > > > On Jul 15, 2011, at 11:59 AM, Phillip Perry > wrote: > >> Thanks for the feedback. One last question. >> >> What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the >> oozing off with acetone on the interior and exterior sides. >> >> Is there something that works better? >> >> Phil >> >> >> >> >> >> On Thu, Jul 14, 2011 at 2:36 PM, Pascal >> <rv10flyer(at)verizon.net >> > wrote: >> >> The purpose of the spacers is to fill a gap. Sounds like that is not >> your issue. Leave it I say! >> >> *From:*Phillip Perry >> >> *Sent:*Thursday, July 14, 2011 8:55 AM >> >> *To:*rv10-list(at)matronics.com >> >> >> *Subject:*Re: RV10-List: Spacers under windows >> >> I guess everyone used spacers - huh?? >> >> :) >> >> >> >> On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry >> <philperry9(at)gmail.com >> > wrote: >> >> <philperry9(at)gmail.com >> > >> >> Life got in the way for a bit but I'm back on track building and >> airplane again....... >> >> Curious to know how many people installed washers under their >> plexiglas at the time they were installed. Mine sit proud enough as it >> is and I'd really prefer not to use them if possible. Any results from >> those who didn't use them and how long have you been flying? >> >> Hope to catch some of you at Osh this year.... >> >> Phil >> >> ========== >> arget="_blank"><http://www.matronics.com/Navigator?RV10-List>http://www.matronics.com/Navigator?RV10-List >> ========== >> <http://forums.matronics.com>http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank"><http://www.matronics.com/contribution>http://www.matronics.com/contribution >> ========== >> >> >> * * >> * * >> *href=" http://www.matronics.com/Navigator?RV10-List"> http://www.matronics.com/Navigator?RV10-List* >> *href=" http://forums.matronics.com"> http://forums.matronics.com* >> *href=" http://www.matronics.com/contribution"> http://www.matronics.com/c* >> * * >> * * >> *get="_blank">http://www.matronics.com/Navigator?RV10-List* >> *tp://forums.matronics.com <http://forums.matronics.com>* >> *_blank">http://www.matronics.com/contribution* >> * * >> >> * * >> * * >> * * > * * > > * * > > *3D=============================================* > > *3D=============================================* > > *3D=============================================* > > *3D=============================================* > > * * > > * * > > * * > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > *http://www.matronics.com/contribution* > > * * > > * > > > * ________________________________________________________________________________
Date: Jul 16, 2011
Scary, I've actually wondered the same thing about using Slime in the tubes for a little added protection from grass strips or errant FOD. I would think the major issues would be, weight, rapid acceleration of the tire, and any temperature issues. Thoughts anyone? Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Thursday, July 14, 2011 9:14 PM Subject: Re: RV10-List: TIRES AND TUBES --> I don't know the answer to your question, but it got me to thinking .... which may not be a good thing. I wonder why we can't use the tire puncture sealer in a can to seal the standard aircraft tube? You should be able to use one can to seal all three tubes. You could distribute the sealer inside the tube really well before installing the tubes in the tire. Also Michelin makes Airstop tubes. I think the Leakguard are Aero Classic. Linn On 7/14/2011 9:47 PM, mds4878 wrote: > --> RV10-List message posted by: > --> "mds4878" > > I'm looking at Michelin Aviator tires. > My question is Leakguard tubes or Michelin tubes and why? > Also is Michelin good or bad. > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346418#346418 > > ________________________________________________________________________________
Date: Jul 16, 2011
I'm wondering if the spacers were needed with the old style tops more than the current gen. Mine was first gen and needed space but In my Weld-On rush I forgot to add them back in so mine ended up a bit low. You have such little room between the door frame and the side windows I wasn't keen on cutting it out for the tap and risk weakening the structure so I just built it up as is. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano Sent: Thursday, July 14, 2011 12:36 PM Subject: Re: RV10-List: Re: Spacers under windows I did use spacers but thinking back I wish I would have let the plexi sit low and carve a little of the cabin down to accept the thickness of the glass tape around the windows. That way it wouldn't have been such a big job to transition the hump out of the glass tape around the windows to the cabin. ----- Original Message ----- From: "Jim Berry" <jimberry(at)qwest.net> Sent: Thursday, July 14, 2011 10:40 AM Subject: RV10-List: Re: Spacers under windows > > As I recall, the only reason to use spacers is if the plexi sits below the > fiberglass. > > Jim Berry > N15JB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346330#346330 > > > ________________________________________________________________________________
Subject: Re: Main gear fire
Date: Jul 16, 2011
At least they have it by the quart now, when I picked it up a few years back they only had it by the gallon. I should have enough to do several aircraft at this point. :) Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Saturday, July 09, 2011 3:07 PM Subject: Re: RV10-List: Re: Main gear fire On 7/9/2011 2:50 PM, Tim Olson wrote: > > I can't find the flash point on the 83282 stuff, but, this link says > it's over 200F HIGHER than the 5606. Skygeek has some specs on it: http://www.skygeek.com/royco-782-synthetic-fire-resistant-hydraulic-fluid.html then click the "Specifications" tab. Flash point 218C, 424F Fire point 251C, 483F -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Jul 15, 2011
Some years ago we put a Michelin tire on the nose, after a brand new Goodyear was obviously out of round. It did seem a little better balanced than the typical Goodyears we had been using. Even more years ago, Aviation Consumer did an article on tires. Their conclusion: The better (more expensive) tires were much more resistant to atmospheric contaminants (ozone, uv light). The inexpensive tires could die of old age (sidewall cracking) before their tread wore out. So their recommendation was that if you did a lot of landings (flight school) then the cheaper tires were a better deal, because you'd wear out the tread before they had a chance to die from old age. Of course, where you live (near a chemical plant?) and whether or not the plane is hangared factor in, too. As I recall, they rated Desser's Monster Retread a "best buy". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346611#346611 ________________________________________________________________________________
Date: Jul 16, 2011
Geoff, - Where can we overseas types get Lord adhesives; their website doesn't provi de that info? - Many thanks, - Rodger In storm cast Oz --- On Fri, 15/7/11, g.combs wrote: From: g.combs <g.combs(at)aerosportmodeling.com> Subject: Re: RV10-List: Spacers under windows Date: Friday, 15 July, 2011, 20:02 Phil acetone is very bad for acrylic. I would avoid the Weld on and use Lord -urethane adhesive. Stronger than Weld on and you get a longer cure time And you can clean the oozing off with Enamel reducer. Ppg dt 870 is what I used. Will not hurt the acrylic Geoff Sent from my iPhone Geoff On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: Thanks for the feedback.- One last question. What can I use to wipe off wet Weld-on?- I'm thinking I'll wipe the oozin g off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: The purpose of the spacers is to fill a gap. Sounds like that is not your i ssue. Leave it I say! - - From: Phillip Perry Sent: Thursday, July 14, 2011 8:55 AM Subject: Re: RV10-List: Spacers under windows - I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane a gain....... Curious to know how many people installed washers under their plexiglas at the time they were installed.- Mine sit proud enough as it is and I'd rea lly prefer not to use them if possible.- Any results from those who didn' t use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Cleaning Cannulas
Date: Jul 16, 2011
For those of you that regularly use O2, how do you clean the cannulas? I purchased a portable Aerox system for the 7A 4-5 years ago when my son flew it out to Las Vagas but I have never used it. I'm thinking of giving the O2 a try in the -10 to see how well my wife and I can tolerate the cannulas and they need a good cleaning before we give O2 a try. Doug 180 hrs in year one. What a great plane! -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346717#346717 ________________________________________________________________________________
Date: Jul 16, 2011
Subject: Re: Cleaning Cannulas
I use 91% isopropyl alcohol. Would use pure if there was a handy source. Just good rub down with the alcohol with cotton swab or paper towel. Qtip would probably be best. On Sat, Jul 16, 2011 at 7:33 PM, n277dl wrote: > > For those of you that regularly use O2, how do you clean the cannulas? > > I purchased a portable Aerox system for the 7A 4-5 years ago when my son > flew it out to Las Vagas but I have never used it. > > I'm thinking of giving the O2 a try in the -10 to see how well my wife and > I can tolerate the cannulas and they need a good cleaning before we give O2 > a try. > > Doug > > 180 hrs in year one. What a great plane! > > -------- > Doug > "Fools" are always more creative than process people and will always find > ways to ruin a perfectly good set of processes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346717#346717 > > ________________________________________________________________________________
Date: Jul 16, 2011
I have been on O2 11 hours in the last 2 days. Really helps with freshness and alertness. 13,500 CA to Atlanta and beyond. Robin Sent from my iPad2. On Jul 16, 2011, at 10:55 PM, Kelly McMullen wrote: I use 91% isopropyl alcohol. Would use pure if there was a handy source. Just good rub down with the alcohol with cotton swab or paper towel. Qtip would probably be best. On Sat, Jul 16, 2011 at 7:33 PM, n277dl wrote: > > For those of you that regularly use O2, how do you clean the cannulas? > > I purchased a portable Aerox system for the 7A 4-5 years ago when my son > flew it out to Las Vagas but I have never used it. > > I'm thinking of giving the O2 a try in the -10 to see how well my wife and > I can tolerate the cannulas and they need a good cleaning before we give O2 > a try. > > Doug > > 180 hrs in year one. What a great plane! > > -------- > Doug > "Fools" are always more creative than process people and will always find > ways to ruin a perfectly good set of processes. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346717#346717 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > * * ________________________________________________________________________________
Date: Jul 16, 2011
When asked what the best thing in my airplane is......I say the O2 system. 12 hours on O2 in the past two weeks. I use alcohol swabs to clean them off.......but have ones assigned to the family and only clean the "spares" that other people use. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of n277dl Sent: Saturday, July 16, 2011 8:33 PM Subject: RV10-List: Cleaning Cannulas For those of you that regularly use O2, how do you clean the cannulas? I purchased a portable Aerox system for the 7A 4-5 years ago when my son flew it out to Las Vagas but I have never used it. I'm thinking of giving the O2 a try in the -10 to see how well my wife and I can tolerate the cannulas and they need a good cleaning before we give O2 a try. Doug 180 hrs in year one. What a great plane! -------- Doug "Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346717#346717 ________________________________________________________________________________
Subject: OSH camping
Date: Jul 16, 2011
Anyone in the RV10 area have room on your campsite for a 5 x 7 tent ? I just got an opportuniy to fly to OSH in a Grumman Albatross HU-16B arriving July 24-25 and departing July 31. Not certain of the ride yet. want to look at the aircraft and read about the type. ________________________________________________________________________________
Date: Jul 16, 2011
My 10 went to Arlington this year and is in the hangar awaiting the repaired Trutrak Digiflite VSGV. David N46007 ________________________________________________________________________________
Date: Jul 17, 2011
Rodger I will check into this and let you know. Geoff Sent from my iPad On Jul 16, 2011, at 6:05 AM, Rodger Todd wrote: > Geoff, > > Where can we overseas types get Lord adhesives; their website doesn't prov ide that info? > > Many thanks, > > Rodger > In storm cast Oz > --- On Fri, 15/7/11, g.combs wrote: > > From: g.combs <g.combs(at)aerosportmodeling.com> > Subject: Re: RV10-List: Spacers under windows > To: "rv10-list(at)matronics.com" > Date: Friday, 15 July, 2011, 20:02 > > Phil acetone is very bad for acrylic. > I would avoid the Weld on and use > Lord urethane adhesive. Stronger than > Weld on and you get a longer cure time > And you can clean the oozing off with > Enamel reducer. Ppg dt 870 is what > I used. Will not hurt the acrylic > Geoff > > Sent from my iPhone Geoff > > > On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: > >> Thanks for the feedback. One last question. >> >> What can I use to wipe off wet Weld-on? I'm thinking I'll wipe the oozin g off with acetone on the interior and exterior sides. >> >> Is there something that works better? >> >> Phil >> >> >> >> >> >> >> On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: >> The purpose of the spacers is to fill a gap. Sounds like that is not your issue. Leave it I say! >> >> >> From: Phillip Perry >> Sent: Thursday, July 14, 2011 8:55 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Spacers under windows >> >> I guess everyone used spacers - huh?? >> >> :) >> >> >> >> >> On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote : >> >> Life got in the way for a bit but I'm back on track building and airplane again....... >> >> Curious to know how many people installed washers under their plexiglas a t the time they were installed. Mine sit proud enough as it is and I'd real ly prefer not to use them if possible. Any results from those who didn't us e them and how long have you been flying? >> >> Hope to catch some of you at Osh this year.... >> >> Phil >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > List > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 17, 2011
Unless you are sharing cannulas with someone who has Tb or HIV, alcohol is perfectly adequate. Jim Berry N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346778#346778 ________________________________________________________________________________
Date: Jul 17, 2011
Clorehexidine Peridex or Cidex would work well and can be purchased from a dental supply house. Use a Q-tip and a paper towel. With all cleaning methods=2C be careful that you do not get the solution be tween the thin ballon inside the rubber housing. If the ballon ends up stic king to the outside housing the ballon will not deflate when you inhale and you will not be getting the O2. Running nose=2C food=2C or Gatoraid will do the same thing causing it to stick to the housing. > Subject: RV10-List: Re: Cleaning Cannulas > From: jimberry(at)qwest.net > Date: Sun=2C 17 Jul 2011 10:01:24 -0700 > To: rv10-list(at)matronics.com > > > Unless you are sharing cannulas with someone who has Tb or HIV=2C alcohol is perfectly adequate. > > Jim Berry > N15JB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346778#346778 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Circuit Diagram Software
Date: Jul 18, 2011
G'day all, It's time for me to actually make up some circuit diagrams for my RV10. Can someone suggest a good software package that has The required symbols etc for Aeronautical use and doesn't cost the earth ? Cheers John MacCallum Builder # 41016 VH-DUU ________________________________________________________________________________
Date: Jul 17, 2011
drug store alcohol. We have the Aerox cannulas too, and I can say you will love them. They are so non-intrusive that I frequently don't even both to take it off until after I've landed. My wife used to get headaches above 10,000'; just a few wiffs of oxygen and she is good as new. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346800#346800 ________________________________________________________________________________
Subject: Re: OSH camp conditions report
Date: Jul 17, 2011
Tim Making plans for our first time flying into Oshkosh. We tried for Sun n Fun this spring but only made it to South Carolina, LUCKLY. We cannot leave before next Sunday afternoon at the earliest. I would like to arrive at Oshkosh early in the morning to avoid the mad rush and get situated. That being said it would have to be Tuesday morning. I would like to camp near the other RV-10s , any chance that might happen? Any tips/help would be greatly appreciated. Ron in Nova Scotia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346822#346822 ________________________________________________________________________________
Subject: Re: OSH camping
Date: Jul 17, 2011
Just to confirm I will need a tent spot for the week from 7/24 through 7/30. The aircraft will be parked in the War Bird section N10019; the 19th Grumman HU16B Albatross produced in 1951. R1820 radial engines of 1475 HP each. It will be the gray ghost until it returns to the Grumman factory for a repaint. My phone is 480-626-4048 if you have extra space. ----- Original Message ----- From: DLM To: rv10-list(at)matronics.com Sent: Saturday, July 16, 2011 9:16 PM Subject: RV10-List: OSH camping My 10 went to Arlington this year and is in the hangar awaiting the repaired Trutrak Digiflite VSGV. David N46007 ________________________________________________________________________________
Date: Jul 17, 2011
Subject: Second Ride In 7.5 Years
Hi Everyone, Just want to give a big THANKS!!! to Ivan Kristensen for giving my son Thomas and I a wonderful flight in his beautiful bird this evening. This is only the second flight for me in an RV-10 and the first for Thomas. Both of us were astounded at the quality of flight and the roominess of the plane. Thank You Ivan for a most needed motivational flight so late in my lengthy construction. Dave and Thomas Hertner Just about to put fuel in the tanks. #40164 * * ________________________________________________________________________________
Date: Jul 18, 2011
Thanks very much, - Rodger --- On Sun, 17/7/11, g.combs wrote: From: g.combs <g.combs(at)aerosportmodeling.com> Subject: Re: RV10-List: Spacers under windows Date: Sunday, 17 July, 2011, 16:15 Rodger I will check into this and let you know.- Geoff Sent from my iPad On Jul 16, 2011, at 6:05 AM, Rodger Todd wrote: Geoff, - Where can we overseas types get Lord adhesives; their website doesn't provi de that info? - Many thanks, - Rodger In storm cast Oz --- On Fri, 15/7/11, g.combs wrote: From: g.combs <g.combs(at)aerosportmodeling.com> Subject: Re: RV10-List: Spacers under windows Date: Friday, 15 July, 2011, 20:02 Phil acetone is very bad for acrylic. I would avoid the Weld on and use Lord -urethane adhesive. Stronger than Weld on and you get a longer cure time And you can clean the oozing off with Enamel reducer. Ppg dt 870 is what I used. Will not hurt the acrylic Geoff Sent from my iPhone Geoff On Jul 15, 2011, at 11:59 AM, Phillip Perry wrote: Thanks for the feedback.- One last question. What can I use to wipe off wet Weld-on?- I'm thinking I'll wipe the oozin g off with acetone on the interior and exterior sides. Is there something that works better? Phil On Thu, Jul 14, 2011 at 2:36 PM, Pascal wrote: The purpose of the spacers is to fill a gap. Sounds like that is not your i ssue. Leave it I say! - - From: Phillip Perry Sent: Thursday, July 14, 2011 8:55 AM Subject: Re: RV10-List: Spacers under windows - I guess everyone used spacers - huh?? :) On Wed, Jul 13, 2011 at 10:10 PM, Phil Perry wrote: Life got in the way for a bit but I'm back on track building and airplane a gain....... Curious to know how many people installed washers under their plexiglas at the time they were installed.- Mine sit proud enough as it is and I'd rea lly prefer not to use them if possible.- Any results from those who didn' t use them and how long have you been flying? Hope to catch some of you at Osh this year.... Phil arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ========= ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.c om/Navigator?RV10-List ========= ums.matronics.com">http://forums.matronics.com ========= http://www.matronics.com/contribution">http://www.matronics.com/contributio n ========= ________________________________________________________________________________
Subject: FCC Comments regarding Lightsquared and GPS interference
Date: Jul 18, 2011
Done... John J -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Monday, July 18, 2011 7:58 AM Subject: Re: RV10-List: FCC Comments regarding Lightsquared and GPS interference I just submitted a comment. It took about 5 minutes. Guys, we all need to doing this. Pass it on, too. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell ________________________________________________________________________________
Subject: Re: FCC Comments regarding Lightsquared and GPS interference
Date: Jul 18, 2011
I submitted a comment as well. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346904#346904 ________________________________________________________________________________
Date: Jul 18, 2011
Done. Thanks. On 7/18/2011 9:14 AM, Tim Olson wrote: > > The FCC has an open comment period now for this whole > Lightsquared mess. Here's the link, and you enter 11-109 > in the proceeding number field. ________________________________________________________________________________
Date: Jul 18, 2011
Ditto On Mon, Jul 18, 2011 at 2:03 PM, tsts4 wrote: > > I submitted a comment as well. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=346904#346904 > > ________________________________________________________________________________
Date: Jul 18, 2011
Thanks Tim Yes I think we plan on camping with out RV-10. I've never stayed overnight while at Oshkosh. I think we miss out on meeting a lot of people. I'm going to Oshkosh this year to hopefully meet with guy's like you and others I corresponded with on the various forums. I just received news that a prior commitment has been postponed so I can leave whenever I want now. What day would you suggest we arrive in order to get a half decent site and avoid the masses in arrival. Thanks Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346915#346915 ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Jul 19, 2011
Hopefully the overall weather improves. North of OSH we've had severe thunderstorms, some tornados, high 90's with humidity near 100% the last couple days and the heat index is supposed to be in the 115 range this week. Of course last week it was in the 70's and I had my windows open and the AC shut down. No flooding though, that was a few weeks back. :) Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron B. Sent: Monday, July 18, 2011 3:07 PM Subject: RV10-List: Re: OSH camp conditions report Thanks Tim Yes I think we plan on camping with out RV-10. I've never stayed overnight while at Oshkosh. I think we miss out on meeting a lot of people. I'm going to Oshkosh this year to hopefully meet with guy's like you and others I corresponded with on the various forums. I just received news that a prior commitment has been postponed so I can leave whenever I want now. What day would you suggest we arrive in order to get a half decent site and avoid the masses in arrival. Thanks Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=346915#346915 ________________________________________________________________________________
Subject: Oshkosh Cookout
Date: Jul 18, 2011
Are there any plans to get together for a cookout this year? We will be there all week staying over by the museum. Last year's cookouts were great but I know a tremendous amount of effort went into them. Perhaps we could make it BYO everything including food and chairs if we had a grill available and a place/time to meet. Steve Roberts RV-10 Tailkit 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown TN ________________________________________________________________________________
Subject: GPS
Date: Jul 19, 2011
I'm in there! Chris Hukill ________________________________________________________________________________
Date: Jul 19, 2011
Tim Olson wrote: > Personally, I love it when it's busy, other than when some schmo takes a digger on the runway and causes the traffic to back up over Ripon, but I'm a bit weird that way. > > Tim Olson - RV-10 N104CD > Or get behind a J-3 Cub. He has to fly almost straight down to get up to an airspeed equal to our stall speed [Mr. Green] -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347041#347041 ________________________________________________________________________________
Subject: Re: So did they really rename Aeroshell Square?
Date: Jul 19, 2011
Yep, IIRC sometime earlier this year EAA made an announcement about the change. I also seemed to recall the major concern was whether the AeroShell cow posters would still be available. :D -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347042#347042 ________________________________________________________________________________
Subject: Re: OSH Notam
Date: Jul 19, 2011
They've already announced that they are ditching the current OSHKOSH365 software after our continual complaints on how crappy it is. However, they haven't announced what the replacement will be although if I was a betting man I'd place my money on some version of vBulletin. They also had originally wanted to re-launch prior to AirVenture but it doens't look like that's going to happen. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347048#347048 ________________________________________________________________________________
Date: Jul 19, 2011
Subject: Re: Oshkosh Cookout
There are no specific plans at this point. We do however have space available in Camp Scholler if you'd like to put something together. Bob On Mon, Jul 18, 2011 at 10:40 PM, Steve Roberts wrote: > > Are there any plans to get together for a cookout this year? We will be > there all week staying over by the museum. > > Last year's cookouts were great but I know a tremendous amount of effort > went into them. > > Perhaps we could make it BYO everything including food and chairs if we had > a grill available and a place/time to meet. > > Steve Roberts > RV-10 Tailkit > 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown TN > > ________________________________________________________________________________
Subject: My "fix" for dragging brakes
Date: Jul 19, 2011
I've been reading about the various dragging brake issues on the forum, talked with several folks and experienced the problem with a friend's RV-10. 1. I found out, from the folks at Matco, that it is critical for the master cylinder to fully extend when pressure is removed from the brake pedals. The last 1/16th in. of piston extension is needed for fluid to bypass internally allowing the brake pads to retract. It doesn't take much to keep pressure on the brake pads. My friend fixed his with a spring arrangement on the pedals. 2. I also learned that minimizing friction in the brake pedals is important. They should move freely with no binding. All bolt holes should be properly drilled to assure free movement. The bolts should not be overly tightened, to minimize drag. 3. The Van's design uses two short AN3 bolts on each side of the bottom of the pedals. This can result in some minor twisting that can add resistance to the pedal movement. Matco suggested replacing these with one long bolt. (I purchased AN3-60 bolts, $10 each) I also used some aluminum tubing over the bolt to provide a spacer inside the pedal flanges. I found springs at McMaster (part # 9271K542 and 9271K542, 270 deg, left and right hand). These were put over the through bolt and aluminum tube. The springs I settled on (to get enough return force) were larger inside diameter than the aluminum tube so I found some old garden hose to put over the tubing as a spacer. As you can see from the pictures, the springs provide return force and work nicely to provide positive pressure on the pedal and master cylinders. So far, it seems like a "no drag" configuration. Since I'm not flying, a final report will have to wait for the future. Does all this make sense from what others have learned from experience?? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347079#347079 Attachments: http://forums.matronics.com//files/img_1388_336.jpg http://forums.matronics.com//files/img_1387_104.jpg http://forums.matronics.com//files/img_1386_109.jpg ________________________________________________________________________________
Date: Jul 19, 2011
Subject: Re: My "fix" for dragging brakes
Your spring idea is good. However placing a compression spring over the cylinder shaft would be lighter and maybe more effective solution. Linn On 7/19/2011 3:53 PM, billz wrote: > --> RV10-List message posted by: "billz" > > I've been reading about the various dragging brake issues on the forum, talked with several folks and experienced the problem with a friend's RV-10. > > 1. I found out, from the folks at Matco, that it is critical for the master cylinder to fully extend when pressure is removed from the brake pedals. The last 1/16th in. of piston extension is needed for fluid to bypass internally allowing the brake pads to retract. It doesn't take much to keep pressure on the brake pads. My friend fixed his with a spring arrangement on the pedals. > > 2. I also learned that minimizing friction in the brake pedals is important. They should move freely with no binding. All bolt holes should be properly drilled to assure free movement. The bolts should not be overly tightened, to minimize drag. > > 3. The Van's design uses two short AN3 bolts on each side of the bottom of the pedals. This can result in some minor twisting that can add resistance to the pedal movement. Matco suggested replacing these with one long bolt. (I purchased AN3-60 bolts, $10 each) I also used some aluminum tubing over the bolt to provide a spacer inside the pedal flanges. I found springs at McMaster (part # 9271K542 and 9271K542, 270 deg, left and right hand). These were put over the through bolt and aluminum tube. The springs I settled on (to get enough return force) were larger inside diameter than the aluminum tube so I found some old garden hose to put over the tubing as a spacer. > > As you can see from the pictures, the springs provide return force and work nicely to provide positive pressure on the pedal and master cylinders. So far, it seems like a "no drag" configuration. Since I'm not flying, a final report will have to wait for the future. Does all this make sense from what others have learned from experience?? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347079#347079 > > > Attachments: > > http://forums.matronics.com//files/img_1388_336.jpg > http://forums.matronics.com//files/img_1387_104.jpg > http://forums.matronics.com//files/img_1386_109.jpg > > ________________________________________________________________________________
Date: Jul 19, 2011
On 07/19/2011 08:45 AM, Tim Olson wrote: > > Hi Ron, > > To get the best sites, you'd probably want to drop everything > and leave NOW. But, to avoid the mass arrivals, you probably > should shoot for Saturday at the very latest. Mass arrivals: Saturday 1:00pm - Bonanza & Cherokee Saturday 2:30pm - Cessna Saturday 4:00pm - Mooney Sunday 11:30am - Comanche Sunday 3:00pm - racers ________________________________________________________________________________
Date: Jul 19, 2011
I forgot who did that but I've seen it before and it is what I plan to do. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Tuesday, July 19, 2011 3:23 PM Subject: Re: RV10-List: My "fix" for dragging brakes --> Your spring idea is good. However placing a compression spring over the cylinder shaft would be lighter and maybe more effective solution. Linn On 7/19/2011 3:53 PM, billz wrote: > --> RV10-List message posted by: "billz" > > I've been reading about the various dragging brake issues on the forum, talked with several folks and experienced the problem with a friend's RV-10. > > 1. I found out, from the folks at Matco, that it is critical for the master cylinder to fully extend when pressure is removed from the brake pedals. The last 1/16th in. of piston extension is needed for fluid to bypass internally allowing the brake pads to retract. It doesn't take much to keep pressure on the brake pads. My friend fixed his with a spring arrangement on the pedals. > > 2. I also learned that minimizing friction in the brake pedals is important. They should move freely with no binding. All bolt holes should be properly drilled to assure free movement. The bolts should not be overly tightened, to minimize drag. > > 3. The Van's design uses two short AN3 bolts on each side of the bottom of the pedals. This can result in some minor twisting that can add resistance to the pedal movement. Matco suggested replacing these with one long bolt. (I purchased AN3-60 bolts, $10 each) I also used some aluminum tubing over the bolt to provide a spacer inside the pedal flanges. I found springs at McMaster (part # 9271K542 and 9271K542, 270 deg, left and right hand). These were put over the through bolt and aluminum tube. The springs I settled on (to get enough return force) were larger inside diameter than the aluminum tube so I found some old garden hose to put over the tubing as a spacer. > > As you can see from the pictures, the springs provide return force and work nicely to provide positive pressure on the pedal and master cylinders. So far, it seems like a "no drag" configuration. Since I'm not flying, a final report will have to wait for the future. Does all this make sense from what others have learned from experience?? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347079#347079 > > > Attachments: > > http://forums.matronics.com//files/img_1388_336.jpg > http://forums.matronics.com//files/img_1387_104.jpg > http://forums.matronics.com//files/img_1386_109.jpg > > ________________________________________________________________________________
Date: Jul 19, 2011
Hmm, that should be exciting...Cherokees mixing with Bonanzas with same arrival time. On Tue, Jul 19, 2011 at 1:48 PM, Rick Beebe wrote: > > On 07/19/2011 08:45 AM, Tim Olson wrote: >> >> >> Hi Ron, >> >> To get the best sites, you'd probably want to drop everything >> and leave NOW. But, to avoid the mass arrivals, you probably >> should shoot for Saturday at the very latest. > > Mass arrivals: > > Saturday 1:00pm - Bonanza & Cherokee > Saturday 2:30pm - Cessna > Saturday 4:00pm - Mooney > > Sunday 11:30am - Comanche > Sunday 3:00pm - racers > > ________________________________________________________________________________
Date: Jul 19, 2011
I tried a variety of compression springs with collars, as previously shown on the forum. I kept having problems with the spring only having a limited range of compression which limited the travel of the piston. I could only get about 1 in compression before the spring was fully compressed. Matco says all you need is 3/4 in travel, but I wanted to keep the option for greater travel, if needed. Maybe someone else will have better luck with that approach than I did. Good Luck! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347095#347095 ________________________________________________________________________________
Date: Jul 19, 2011
I replied to Ralph off-line, but just a reminder ...... Slight brake dragging is a natural function of disc brakes. The area just outside the O-ring collects dirt which doesn't allow the puck to retract more, and that O-ring gets stiff with time/heat. The spring remedy only allows the cylinder shaft to extend fully allowing the fluid pressure to relax. Nothing is available to 'suck' the brake puck back. Linn On 7/19/2011 5:22 PM, billz wrote: > --> RV10-List message posted by: "billz" > > I tried a variety of compression springs with collars, as previously shown on the forum. I kept having problems with the spring only having a limited range of compression which limited the travel of the piston. I could only get about 1 in compression before the spring was fully compressed. Matco says all you need is 3/4 in travel, but I wanted to keep the option for greater travel, if needed. > > Maybe someone else will have better luck with that approach than I did. > > Good Luck! > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347095#347095 > > ________________________________________________________________________________
Date: Jul 19, 2011
Guys I stand corrected. The new EAA forum site is up and it is vBulletin based: www.eaaforums.org -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347103#347103 ________________________________________________________________________________
Date: Jul 19, 2011
It was me. I'll see if I can find some old write ups and photos of the mod. It was easy, cheap, and effective. If I were building another one, I'd do the same thing again. Phil On Jul 19, 2011, at 4:05 PM, "RV Builder (Michael Sausen)" wrote: > > I forgot who did that but I've seen it before and it is what I plan to do. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters > Sent: Tuesday, July 19, 2011 3:23 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: My "fix" for dragging brakes > > --> > > Your spring idea is good. However placing a compression spring over the cylinder shaft would be lighter and maybe more effective solution. > Linn > > On 7/19/2011 3:53 PM, billz wrote: >> --> RV10-List message posted by: "billz" >> >> I've been reading about the various dragging brake issues on the forum, talked with several folks and experienced the problem with a friend's RV-10. >> >> 1. I found out, from the folks at Matco, that it is critical for the master cylinder to fully extend when pressure is removed from the brake pedals. The last 1/16th in. of piston extension is needed for fluid to bypass internally allowing the brake pads to retract. It doesn't take much to keep pressure on the brake pads. My friend fixed his with a spring arrangement on the pedals. >> >> 2. I also learned that minimizing friction in the brake pedals is important. They should move freely with no binding. All bolt holes should be properly drilled to assure free movement. The bolts should not be overly tightened, to minimize drag. >> >> 3. The Van's design uses two short AN3 bolts on each side of the bottom of the pedals. This can result in some minor twisting that can add resistance to the pedal movement. Matco suggested replacing these with one long bolt. (I purchased AN3-60 bolts, $10 each) I also used some aluminum tubing over the bolt to provide a spacer inside the pedal flanges. I found springs at McMaster (part # 9271K542 and 9271K542, 270 deg, left and right hand). These were put over the through bolt and aluminum tube. The springs I settled on (to get enough return force) were larger inside diameter than the aluminum tube so I found some old garden hose to put over the tubing as a spacer. >> >> As you can see from the pictures, the springs provide return force and work nicely to provide positive pressure on the pedal and master cylinders. So far, it seems like a "no drag" configuration. Since I'm not flying, a final report will have to wait for the future. Does all this make sense from what others have learned from experience?? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=347079#347079 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_1388_336.jpg >> http://forums.matronics.com//files/img_1387_104.jpg >> http://forums.matronics.com//files/img_1386_109.jpg >> >> >> >> >> >> >> >> > > > > > > > > > > ________________________________________________________________________________
Date: Jul 19, 2011
Subject: NavWorx ADS600-B Transceiver Arrives...
Dear Listers, The NavWorx ADS600-B Transceiver kit arrived today. Included in the box were the following: 1ea ADS600-B Transceiver Unit 1ea DB37 Connector w/ Shell 2ea RG-142 BNC Antenna Coax Cables (terminated on one end) 1ea Wireless receiver option (802.11) 1ea End User License sheet 1ea Attention Warning sheet Missing from the package, it seemed to me were: 1ea Installation Manual 1ea Instruction Manual 1ea Wiring Diagram 2ea BNC connectors for Terminating Antenna Cable 1ea UAT Antenna 1ea GPS Antenna Attached are a couple of pictures of what I received. Looking over the NavWorx web site, I'm not finding anywhere to download instruction manuals or installation manuals. Am I suppose to buy the UAT and GPS antennas separately? I didn't see these available separately on the NavWorx web site when I ordered the package. I called and left NavWorx a voicemail. At this point, I'm kind at a loss...? :-/ Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... ________________________________________________________________________________
Date: Jul 19, 2011
While I'm not going to say you shouldn't improve it if you want to, I will make a couple of comments: 1) We need to make sure that builders understand NOT to torque the bolts too tight that the pedals hinge on. If you don't torque them too tight, you're unlikely to have an issue with them even with the standard bolts. Improving them isn't going to hurt, but I would say that it isn't necessary for most people...maybe those with some parts or things that aren't in normal tolerances. 2) Regarding the springs, that's the same deal. I don't think most people will need anything like that. Sure, it may not hurt, but if you're going to do it, just do it in a way that doesn't have any other possible failure mode that could jam the brakes. As long as you do that, modify them if you think you need to. I just don't think most people will need to. 3) As was already noted, disc brakes just work with a bit of drag on them because there is no "retract" spring for the pistons. You push the brakes, they go out and touch the discs, and when you release the brakes they still just barely touch the discs. Even a standard design for the pedals should not cause any additional drag, as long as your pedals retract and you keep your heels on the floor and don't ride the brakes. So again, while improving them to your satisfaction isn't a bad thing, It's really not a necessary thing. You're never going to eliminate the inherent disc brake drag. With 750+ hours on mine, and using the standard setup, I've never seen any reason to have anything more. The one-piece bolt isn't a bad idea at all, and if they included it all in the kit, I'd be happy with it. But don't make all the other builders think there is some problem with the design, because those pedals will work just fine per-plans, provided you don't overtorque or have some other misalignment that causes the pedals to not move freely. All builders should make sure that THIS isn't a problem as they build...then they'll end up with a fine working system. Tim Olson - RV-10 N104CD On 7/19/2011 2:53 PM, billz wrote: > --> RV10-List message posted by: "billz" > > I've been reading about the various dragging brake issues on the > forum, talked with several folks and experienced the problem with a > friend's RV-10. > > 1. I found out, from the folks at Matco, that it is critical for the > master cylinder to fully extend when pressure is removed from the > brake pedals. The last 1/16th in. of piston extension is needed for > fluid to bypass internally allowing the brake pads to retract. It > doesn't take much to keep pressure on the brake pads. My friend > fixed his with a spring arrangement on the pedals. > > 2. I also learned that minimizing friction in the brake pedals is > important. They should move freely with no binding. All bolt holes > should be properly drilled to assure free movement. The bolts should > not be overly tightened, to minimize drag. > > 3. The Van's design uses two short AN3 bolts on each side of the > bottom of the pedals. This can result in some minor twisting that > can add resistance to the pedal movement. Matco suggested replacing > these with one long bolt. (I purchased AN3-60 bolts, $10 each) I > also used some aluminum tubing over the bolt to provide a spacer > inside the pedal flanges. I found springs at McMaster (part # > 9271K542 and 9271K542, 270 deg, left and right hand). These were put > over the through bolt and aluminum tube. The springs I settled on > (to get enough return force) were larger inside diameter than the > aluminum tube so I found some old garden hose to put over the tubing > as a spacer. > > As you can see from the pictures, the springs provide return force > and work nicely to provide positive pressure on the pedal and master > cylinders. So far, it seems like a "no drag" configuration. Since > I'm not flying, a final report will have to wait for the future. > Does all this make sense from what others have learned from > experience?? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347079#347079 > > > Attachments: > > http://forums.matronics.com//files/img_1388_336.jpg > http://forums.matronics.com//files/img_1387_104.jpg > http://forums.matronics.com//files/img_1386_109.jpg > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 19, 2011
What Tim said. Plus, keep in mind that the master cylinders have internal springs that push the piston back out. If they aren't sufficient there could be another problem. The clothes pin springs and long bolts are a nice touch but I see a couple of wear points that might need to eventually be addressed. Fewer parts are usually better! Make sure the assembly is free, even a little sloppy, and it should work fine. Dave Saylor 895 hours AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Tue, Jul 19, 2011 at 8:33 PM, Tim Olson wrote: > > While I'm not going to say you shouldn't improve it if > you want to, I will make a couple of comments: > > 1) We need to make sure that builders understand NOT > to torque the bolts too tight that the pedals hinge on. > If you don't torque them too tight, you're unlikely > to have an issue with them even with the standard bolts. > Improving them isn't going to hurt, but I would say > that it isn't necessary for most people...maybe those > with some parts or things that aren't in normal > tolerances. > > 2) Regarding the springs, that's the same deal. I don't > think most people will need anything like that. Sure, > it may not hurt, but if you're going to do it, just do > it in a way that doesn't have any other possible failure > mode that could jam the brakes. As long as you > do that, modify them if you think you need to. I just > don't think most people will need to. > > 3) As was already noted, disc brakes just work with a > bit of drag on them because there is no "retract" > spring for the pistons. You push the brakes, they > go out and touch the discs, and when you release > the brakes they still just barely touch the discs. > Even a standard design for the pedals should not > cause any additional drag, as long as your pedals > retract and you keep your heels on the floor and > don't ride the brakes. So again, while improving > them to your satisfaction isn't a bad thing, It's really > not a necessary thing. You're never going to eliminate > the inherent disc brake drag. > > With 750+ hours on mine, and using the standard > setup, I've never seen any reason to have anything > more. The one-piece bolt isn't a bad idea at all, > and if they included it all in the kit, I'd be > happy with it. But don't make all the other builders > think there is some problem with the design, because > those pedals will work just fine per-plans, provided > you don't overtorque or have some other misalignment > that causes the pedals to not move freely. All > builders should make sure that THIS isn't a problem > as they build...then they'll end up with a fine > working system. > > Tim Olson - RV-10 N104CD > > > On 7/19/2011 2:53 PM, billz wrote: >> >> >> I've been reading about the various dragging brake issues on the >> forum, talked with several folks and experienced the problem with a >> friend's RV-10. >> >> 1. I found out, from the folks at Matco, that it is critical for the >> master cylinder to fully extend when pressure is removed from the >> brake pedals. The last 1/16th in. of piston extension is needed for >> fluid to bypass internally allowing the brake pads to retract. It >> doesn't take much to keep pressure on the brake pads. My friend >> fixed his with a spring arrangement on the pedals. >> >> 2. I also learned that minimizing friction in the brake pedals is >> important. They should move freely with no binding. All bolt holes >> should be properly drilled to assure free movement. The bolts should >> not be overly tightened, to minimize drag. >> >> 3. The Van's design uses two short AN3 bolts on each side of the >> bottom of the pedals. This can result in some minor twisting that >> can add resistance to the pedal movement. Matco suggested replacing >> these with one long bolt. (I purchased AN3-60 bolts, $10 each) I >> also used some aluminum tubing over the bolt to provide a spacer >> inside the pedal flanges. I found springs at McMaster (part # >> 9271K542 and 9271K542, 270 deg, left and right hand). These were put >> over the through bolt and aluminum tube. The springs I settled on >> (to get enough return force) were larger inside diameter than the >> aluminum tube so I found some old garden hose to put over the tubing >> as a spacer. >> >> As you can see from the pictures, the springs provide return force >> and work nicely to provide positive pressure on the pedal and master >> cylinders. So far, it seems like a "no drag" configuration. Since >> I'm not flying, a final report will have to wait for the future. >> Does all this make sense from what others have learned from >> experience?? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=347079#347079 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/img_1388_336.jpg >> http://forums.matronics.com//files/img_1387_104.jpg >> http://forums.matronics.com//files/img_1386_109.jpg >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jul 20, 2011
We'll have to "ditto" Tim's comments on this issue. We got almost 300 hours on the first set of pads with a standard per the plans brake installation. The earlier RV's all had similar issues. In my opinion most of these are related to the somewhat severe angle that the pedals meet your feet, i.e. it is very easy to apply brake pressure when you would think you are not. The -10, IMHO, is the least problematic in this regard so far. (The RV-12 kit includes plastic blocks installed on the bottom of the pedals to reduce this angle not unlike what others have done as a mod on the 10) I believe a little practice in the technique of keeping heels on the floor at all times unless brake application is desired will go a long way to getting good brake pad life and minimal heating. Tailwinds, Dick Sipp RV-4, RV-10, B-25D all castering nose wheels and sensitive brakes :) ________________________________________________________________________________
Date: Jul 20, 2011
CORRECTION: My bad, of course the RV-4 does not have a castering nose wheel. Dick -----Original Message----- From: Dick & Vicki Sipp Sent: Wednesday, July 20, 2011 12:40 AM Subject: Re: RV10-List: My "fix" for dragging brakes We'll have to "ditto" Tim's comments on this issue. We got almost 300 hours on the first set of pads with a standard per the plans brake installation. The earlier RV's all had similar issues. In my opinion most of these are related to the somewhat severe angle that the pedals meet your feet, i.e. it is very easy to apply brake pressure when you would think you are not. The -10, IMHO, is the least problematic in this regard so far. (The RV-12 kit includes plastic blocks installed on the bottom of the pedals to reduce this angle not unlike what others have done as a mod on the 10) I believe a little practice in the technique of keeping heels on the floor at all times unless brake application is desired will go a long way to getting good brake pad life and minimal heating. Tailwinds, Dick Sipp RV-4, RV-10, B-25D all castering nose wheels and sensitive brakes :) ________________________________________________________________________________
Subject: Re: NavWorx ADS600-B Transceiver Arrives...
Date: Jul 20, 2011
Matt Dralle wrote: > > Missing from the package, it seemed to me were: > > 1ea Installation Manual > 1ea Instruction Manual > 1ea Wiring Diagram > 2ea BNC connectors for Terminating Antenna Cable > 1ea UAT Antenna > 1ea GPS Antenna > > Sorry to hear but that is correct. I have talked to Bill many times getting my unit up and running. The manual should be or should have been sent as a pdf by email. The wiring is in the manual. What EFIS are you conecting it to? They have some of the units/makes in the manual, other wise the EFIS mfg should be assisting in the wiring. I don't know why Bill doesn't include the BNC's with the unit for the 'other end' of the cables, other then the length of the cables is unknown and the types of antennas is not known. Bill offers a UAT antenna on his web site but you can go with several others. There is a list of GPS antennas compatible. I went with the Garmin GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. I know you don't have a -10 but in my -10 I installed the 600B just behind the aft baggage bulkhead. The UAT antenna is mounted about 12" from the unit in the floor of the tail section and the GPS is mounted under the fiber glass cover between the tail section and the vertical stab. Note: When you get it all installed, if you are using the GA-56, there is a printout that you will call back from the unit to your computer while you are testing it outside. It will give you all the diagnostics and what is really going on. If you are not getting 7 satellites or more, call Bill to see if they installed the extra filtering. It seems that some of the older -56 units put out to much noise and the 600B can't keep track of things. I had to send my unit back and they updated it and all is working now. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347145#347145 ________________________________________________________________________________
Date: Jul 20, 2011
Is it necessary to install an external GPS antenna if you have a 430W? I thought you could get the GPS data from it. Shannon On Jul 20, 2011 7:07 AM, "orchidman" wrote: > > > Matt Dralle wrote: >> >> Missing from the package, it seemed to me were: >> >> 1ea Installation Manual >> 1ea Instruction Manual >> 1ea Wiring Diagram >> 2ea BNC connectors for Terminating Antenna Cable >> 1ea UAT Antenna >> 1ea GPS Antenna >> >> > > Sorry to hear but that is correct. I have talked to Bill many times getting my unit up and running. The manual should be or should have been sent as a pdf by email. The wiring is in the manual. What EFIS are you conecting it to? They have some of the units/makes in the manual, other wise the EFIS mfg should be assisting in the wiring. > I don't know why Bill doesn't include the BNC's with the unit for the 'other end' of the cables, other then the length of the cables is unknown and the types of antennas is not known. > Bill offers a UAT antenna on his web site but you can go with several others. There is a list of GPS antennas compatible. I went with the Garmin GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. > I know you don't have a -10 but in my -10 I installed the 600B just behind the aft baggage bulkhead. The UAT antenna is mounted about 12" from the unit in the floor of the tail section and the GPS is mounted under the fiber glass cover between the tail section and the vertical stab. > > Note: When you get it all installed, if you are using the GA-56, there is a printout that you will call back from the unit to your computer while you are testing it outside. It will give you all the diagnostics and what is really going on. If you are not getting 7 satellites or more, call Bill to see if they installed the extra filtering. It seems that some of the older -56 units put out to much noise and the 600B can't keep track of things. I had to send my unit back and they updated it and all is working now. > > -------- > Gary Blankenbiller > RV10 - # 40674 > (N2GB Flying) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347145#347145 > > ________________________________________________________________________________
Date: Jul 20, 2011
I didn't know the ga-56 was supported. It wasn't listed in the manual that I have. I guess I need to get an updated manual. I'm currently stuck in his backlog queue waiting for mine to arrive. I'm surprised that your not having reception issues with the antenna under the empennage fairing. The garmin install manual states to stay clear of the VS. Sent from my iPhone On Jul 20, 2011, at 8:00 AM, "orchidman" wrote: > > > Matt Dralle wrote: >> >> Missing from the package, it seemed to me were: >> >> 1ea Installation Manual >> 1ea Instruction Manual >> 1ea Wiring Diagram >> 2ea BNC connectors for Terminating Antenna Cable >> 1ea UAT Antenna >> 1ea GPS Antenna >> >> > > Sorry to hear but that is correct. I have talked to Bill many times getting my unit up and running. The manual should be or should have been sent as a pdf by email. The wiring is in the manual. What EFIS are you conecting it to? They have some of the units/makes in the manual, other wise the EFIS mfg should be assisting in the wiring. > I don't know why Bill doesn't include the BNC's with the unit for the 'other end' of the cables, other then the length of the cables is unknown and the types of antennas is not known. > Bill offers a UAT antenna on his web site but you can go with several others. There is a list of GPS antennas compatible. I went with the Garmin GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. > I know you don't have a -10 but in my -10 I installed the 600B just behind the aft baggage bulkhead. The UAT antenna is mounted about 12" from the unit in the floor of the tail section and the GPS is mounted under the fiber glass cover between the tail section and the vertical stab. > > Note: When you get it all installed, if you are using the GA-56, there is a printout that you will call back from the unit to your computer while you are testing it outside. It will give you all the diagnostics and what is really going on. If you are not getting 7 satellites or more, call Bill to see if they installed the extra filtering. It seems that some of the older -56 units put out to much noise and the 600B can't keep track of things. I had to send my unit back and they updated it and all is working now. > > -------- > Gary Blankenbiller > RV10 - # 40674 > (N2GB Flying) > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347145#347145 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 20, 2011
The ads600-b has an internal gps, all you have to supply is the antenna. Sent from my iPhone On Jul 20, 2011, at 8:14 AM, Shannon Hicks wrote: > Is it necessary to install an external GPS antenna if you have a 430W? I t hought you could get the GPS data from it. > > Shannon > > On Jul 20, 2011 7:07 AM, "orchidman" wrote: > > > > > > Matt Dralle wrote: > >> > >> Missing from the package, it seemed to me were: > >> > >> 1ea Installation Manual > >> 1ea Instruction Manual > >> 1ea Wiring Diagram > >> 2ea BNC connectors for Terminating Antenna Cable > >> 1ea UAT Antenna > >> 1ea GPS Antenna > >> > >> > > > > Sorry to hear but that is correct. I have talked to Bill many times gett ing my unit up and running. The manual should be or should have been sent as a pdf by email. The wiring is in the manual. What EFIS are you conecting it to? They have some of the units/makes in the manual, other wise the EFIS mf g should be assisting in the wiring. > > I don't know why Bill doesn't include the BNC's with the unit for the 'o ther end' of the cables, other then the length of the cables is unknown and t he types of antennas is not known. > > Bill offers a UAT antenna on his web site but you can go with several ot hers. There is a list of GPS antennas compatible. I went with the Garmin GA- 56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV s hop. They are surplus when GA planes upgrade from the 430 to the 430W. > > I know you don't have a -10 but in my -10 I installed the 600B just behi nd the aft baggage bulkhead. The UAT antenna is mounted about 12" from the u nit in the floor of the tail section and the GPS is mounted under the fiber g lass cover between the tail section and the vertical stab. > > > > Note: When you get it all installed, if you are using the GA-56, there i s a printout that you will call back from the unit to your computer while yo u are testing it outside. It will give you all the diagnostics and what is r eally going on. If you are not getting 7 satellites or more, call Bill to se e if they installed the extra filtering. It seems that some of the older -56 units put out to much noise and the 600B can't keep track of things. I had t o send my unit back and they updated it and all is working now. > > > > -------- > > Gary Blankenbiller > > RV10 - # 40674 > > (N2GB Flying) > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=347145#347145 > ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List > ://forums.matronics.com">http://forums.matronics.com > min. > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 20, 2011
I was trying to avoid a third GPS antenna if possible. On Wed, Jul 20, 2011 at 7:28 AM, Bob Leffler wrote: > The ads600-b has an internal gps, all you have to supply is the antenna. > > Sent from my iPhone > > On Jul 20, 2011, at 8:14 AM, Shannon Hicks wrote: > > Is it necessary to install an external GPS antenna if you have a 430W? I > thought you could get the GPS data from it. > > Shannon > On Jul 20, 2011 7:07 AM, "orchidman" < gary(at)wingscc.com> > wrote: > gary(at)wingscc.com> > > > > > > Matt Dralle wrote: > >> > >> Missing from the package, it seemed to me were: > >> > >> 1ea Installation Manual > >> 1ea Instruction Manual > >> 1ea Wiring Diagram > >> 2ea BNC connectors for Terminating Antenna Cable > >> 1ea UAT Antenna > >> 1ea GPS Antenna > >> > >> > > > > Sorry to hear but that is correct. I have talked to Bill many times > getting my unit up and running. The manual should be or should have been > sent as a pdf by email. The wiring is in the manual. What EFIS are you > conecting it to? They have some of the units/makes in the manual, other wise > the EFIS mfg should be assisting in the wiring. > > I don't know why Bill doesn't include the BNC's with the unit for the > 'other end' of the cables, other then the length of the cables is unknown > and the types of antennas is not known. > > Bill offers a UAT antenna on his web site but you can go with several > others. There is a list of GPS antennas compatible. I went with the Garmin > GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local > AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. > > I know you don't have a -10 but in my -10 I installed the 600B just > behind the aft baggage bulkhead. The UAT antenna is mounted about 12" from > the unit in the floor of the tail section and the GPS is mounted under the > fiber glass cover between the tail section and the vertical stab. > > > > Note: When you get it all installed, if you are using the GA-56, there is > a printout that you will call back from the unit to your computer while you > are testing it outside. It will give you all the diagnostics and what is > really going on. If you are not getting 7 satellites or more, call Bill to > see if they installed the extra filtering. It seems that some of the older > -56 units put out to much noise and the 600B can't keep track of things. I > had to send my unit back and they updated it and all is working now. > > > > -------- > > Gary Blankenbiller > > RV10 - # 40674 > > (N2GB Flying) > > > > > > > > > > Read this topic online here: > > > > <http://forums.matronics.com/viewtopic.php?p=347145#347145> > http://forums.matronics.com/viewtopic.php?p=347145#347145 > ="http://www.matronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List > ://forums.matronics.com"> <http://forums.matronics.com> > http://forums.matronics.com > min. > > > > > > > > > * > > * > > * > > * > > ________________________________________________________________________________
Date: Jul 20, 2011
One does have to wonder just how many satellites you would miss that were shadowed by the vertical stab. Seems like you would still have more than 300 degree view of the sky there. Has anyone had success with GPS antenna under the cabin cover(without making holes in the fiberglass)? Seems like there shouldn't be a problem behind the door posts where there is no honeycomb. On 7/20/2011 5:26 AM, Bob Leffler wrote: > > > I'm surprised that your not having reception issues with the antenna under the empennage fairing. The garmin install manual states to stay clear of the VS. > > > On Jul 20, 2011, at 8:00 AM, "orchidman" wrote: > > >> The UAT antenna is mounted about 12" from the unit in the floor of the tail section and the GPS is mounted under the fiber glass cover between the tail section and the vertical stab. >> ________________________________________________________________________________
Subject: =?Windows-1252?Q?The_Model_367_=93BiPod=94_hybrid_flying_car_designed_by_?=
=?Windows-1252?Q?Burt_Rutan?
Date: Jul 20, 2011
With the tribute to Burt at Airventure, this seemed rather pertinent=85. http://www.gizmag.com/bipod-hybrid-flying-car/19258/ Michael ________________________________________________________________________________
Date: Jul 20, 2011
I know the feeling, I have four. Gtn-650 Ads600b Aprs Garmin/afs for efis backup Fortunately, two can sit on the glareshield Sent from my iPhone On Jul 20, 2011, at 8:35 AM, Shannon Hicks wrote: > I was trying to avoid a third GPS antenna if possible. > > On Wed, Jul 20, 2011 at 7:28 AM, Bob Leffler wrote: > The ads600-b has an internal gps, all you have to supply is the antenna. > > Sent from my iPhone > > On Jul 20, 2011, at 8:14 AM, Shannon Hicks wrote: > >> Is it necessary to install an external GPS antenna if you have a 430W? I thought you could get the GPS data from it. >> >> Shannon >> >> On Jul 20, 2011 7:07 AM, "orchidman" wrote: >> > >> > >> > Matt Dralle wrote: >> >> >> >> Missing from the package, it seemed to me were: >> >> >> >> 1ea Installation Manual >> >> 1ea Instruction Manual >> >> 1ea Wiring Diagram >> >> 2ea BNC connectors for Terminating Antenna Cable >> >> 1ea UAT Antenna >> >> 1ea GPS Antenna >> >> >> >> >> > >> > Sorry to hear but that is correct. I have talked to Bill many times get ting my unit up and running. The manual should be or should have been sent a s a pdf by email. The wiring is in the manual. What EFIS are you conecting i t to? They have some of the units/makes in the manual, other wise the EFIS m fg should be assisting in the wiring. >> > I don't know why Bill doesn't include the BNC's with the unit for the ' other end' of the cables, other then the length of the cables is unknown and the types of antennas is not known. >> > Bill offers a UAT antenna on his web site but you can go with several o thers. There is a list of GPS antennas compatible. I went with the Garmin GA -56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV s hop. They are surplus when GA planes upgrade from the 430 to the 430W. >> > I know you don't have a -10 but in my -10 I installed the 600B just beh ind the aft baggage bulkhead. The UAT antenna is mounted about 12" from the u nit in the floor of the tail section and the GPS is mounted under the fiber g lass cover between the tail section and the vertical stab. >> > >> > Note: When you get it all installed, if you are using the GA-56, there i s a printout that you will call back from the unit to your computer while yo u are testing it outside. It will give you all the diagnostics and what is r eally going on. If you are not getting 7 satellites or more, call Bill to se e if they installed the extra filtering. It seems that some of the older -5 6 units put out to much noise and the 600B can't keep track of things. I had to send my unit back and they updated it and all is working now. >> > >> > -------- >> > Gary Blankenbiller >> > RV10 - # 40674 >> > (N2GB Flying) >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=347145#347145 >> ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m/Navigator?RV10-List >> ://forums.matronics.com">http://forums.matronics.com >> min. >> >> > >> > >> > >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 20, 2011
I tried giving ARINC from a 530W to the 600 for GPS data but it didn't work. Bill told me (then) that it had to have a dedicated GPS antenna. I was in a rush so I tried both types of antennas from a 496 with no success, but the small external antenna from a 696 works like a champ. It sees something like 12 sats, in the hangar. Dave Saylor AirCrafters 140 Aviation Way Watsonville, CA 95076 831-722-9141 Shop 831-750-0284 Cell On Wed, Jul 20, 2011 at 5:14 AM, Shannon Hicks wrote: > Is it necessary to install an external GPS antenna if you have a 430W? I > thought you could get the GPS data from it. > > Shannon > > On Jul 20, 2011 7:07 AM, "orchidman" wrote: >> >> >> Matt Dralle wrote: >>> >>> Missing from the package, it seemed to me were: >>> >>> 1ea Installation Manual >>> 1ea Instruction Manual >>> 1ea Wiring Diagram >>> 2ea BNC connectors for Terminating Antenna Cable >>> 1ea UAT Antenna >>> 1ea GPS Antenna >>> >>> >> >> Sorry to hear but that is correct. I have talked to Bill many times >> getting my unit up and running. The manual should be or should have been >> sent as a pdf by email. The wiring is in the manual. What EFIS are you >> conecting it to? They have some of the units/makes in the manual, other wise >> the EFIS mfg should be assisting in the wiring. >> I don't know why Bill doesn't include the BNC's with the unit for the >> 'other end' of the cables, other then the length of the cables is unknown >> and the types of antennas is not known. >> Bill offers a UAT antenna on his web site but you can go with several >> others. There is a list of GPS antennas compatible. I went with the Garmin >> GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local >> AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. >> I know you don't have a -10 but in my -10 I installed the 600B just behind >> the aft baggage bulkhead. The UAT antenna is mounted about 12" from the unit >> in the floor of the tail section and the GPS is mounted under the fiber >> glass cover between the tail section and the vertical stab. >> >> Note: When you get it all installed, if you are using the GA-56, there is >> a printout that you will call back from the unit to your computer while you >> are testing it outside. It will give you all the diagnostics and what is >> really going on. If you are not getting 7 satellites or more, call Bill to >> see if they installed the extra filtering. It seems that some of the older >> -56 units put out to much noise and the 600B can't keep track of things. I >> had to send my unit back and they updated it and all is working now. >> >> -------- >> Gary Blankenbiller >> RV10 - # 40674 >> (N2GB Flying) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=347145#347145 > ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > ://forums.matronics.com">http://forums.matronics.com > min. > >> >> >> > > ________________________________________________________________________________
Date: Jul 20, 2011
Subject: -10 Plans
I have started scanning all of my -10 plans for my own personal use and was wondering if there would be any issues with making them available for everyone to see. Thanks for your input. Shannon ________________________________________________________________________________
Date: Jul 20, 2011
My old GNS-480 antenna is what I used. I had to get a new antenna when the GNS-480 update was done a couple years ago. I put it under the VS fairing, which I think Gary copied from me, not that it matters, but he did it because I was having great luck there. Normally I wouldn't put a GPS antenna in a crappy spot, but in this particular case, the GPS isn't for my own navigation, so I wasn't as particular. All I need are 4 satellites and it gets more than that by far. I myself understand why they don't include the antennas. It gives you the ability to choose a certified model if you're putting it in a certified plane, or an experimental antenna of your choice, and connector type choice. So it isn't surprising. The sad thing is just the communication of that being left out should be better, and as we noted, the .pdf manual should be made available online. To answer the question on can't you feed it GPS from some other system, yes you can, but it's a very specific GPS signal...that has something called TimeMark and something about pulse-per-second. So if you feed it an external GPS, it needs to be a specific flavor. To me it was just as easy to use the built-in and hide the antenna because I didn't want just one more topside wart for not reason either. The GNS480 with the latest software, was able to provide the proper GPS signal. I'm not sure between the 430/430W/530/530W/and new models which ones would support that proper GPS signal...but if you figure that one out and have one that works, you could use that GPS to feed the ADS600B. Once you get the system up and running it's pretty slick. I've had a few flights as of recent, 2 times to OSH now in the last week, and yesterday I could see traffic over 10 miles away that was going to be a factor, and I was able to adjust course and bypass them. Last Friday as I was flying in a MOA, I saw F-somethings in the Restricted bombing range doing maneuvers, and could watch them zip around me...they were dang fast. One flew overhead last week and I could tell that since I was busting into the MOA, he climbed and did a little circle above me to get a visual, and then went about his day. I don't use the WX features, but the traffic is very nice to have and it blows away my Mode S transponder for traffic. Also, I'd encourage people with problems with NavWorx or ANY vendor, to communicate....not just with the forum, but hound the vendor. You'll find that sometimes you need to kick the vendor in the pants a little, but if you're nice, and you ask questions without negative insinuations, you can develop a good relationship and work through issues much better. I haven't worked with too many vendors yet that have been perfect at doing their business...it seems that even the nice ones have issues sometimes. But, I've found that by keeping a good relationship you can end up a very happy customer. Tim Olson - RV-10 N104CD On 7/20/2011 7:00 AM, orchidman wrote: > --> RV10-List message posted by: "orchidman" > > > Matt Dralle wrote: >> >> Missing from the package, it seemed to me were: >> >> 1ea Installation Manual >> 1ea Instruction Manual >> 1ea Wiring Diagram >> 2ea BNC connectors for Terminating Antenna Cable >> 1ea UAT Antenna >> 1ea GPS Antenna >> >> > > Sorry to hear but that is correct. I have talked to Bill many times getting my unit up and running. The manual should be or should have been sent as a pdf by email. The wiring is in the manual. What EFIS are you conecting it to? They have some of the units/makes in the manual, other wise the EFIS mfg should be assisting in the wiring. > I don't know why Bill doesn't include the BNC's with the unit for the 'other end' of the cables, other then the length of the cables is unknown and the types of antennas is not known. > Bill offers a UAT antenna on his web site but you can go with several others. There is a list of GPS antennas compatible. I went with the Garmin GA-56 witch is the old 430 (non-WAAS) antenna. Got it for $50 from a local AV shop. They are surplus when GA planes upgrade from the 430 to the 430W. > I know you don't have a -10 but in my -10 I installed the 600B just behind the aft baggage bulkhead. The UAT antenna is mounted about 12" from the unit in the floor of the tail section and the GPS is mounted under the fiber glass cover between the tail section and the vertical stab. > > Note: When you get it all installed, if you are using the GA-56, there is a printout that you will call back from the unit to your computer while you are testing it outside. It will give you all the diagnostics and what is really going on. If you are not getting 7 satellites or more, call Bill to see if they installed the extra filtering. It seems that some of the older -56 units put out to much noise and the 600B can't keep track of things. I had to send my unit back and they updated it and all is working now. > > -------- > Gary Blankenbiller > RV10 - # 40674 > (N2GB Flying) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=347145#347145 > > ________________________________________________________________________________
Date: Jul 20, 2011
There is a gentleman on VAF offering a GPS antenna as a decal that can go top center of the windshield behind the center post. Uses a BNC connector and price IIRC is reasonable. I expect to use one for one of GPSs. On 7/20/2011 7:08 AM, Tim Olson wrote: > > My old GNS-480 antenna is what I used. I had to get a new > antenna when the GNS-480 update was done a couple years > ago. ________________________________________________________________________________
Subject: Re: -10 Plans
Date: Jul 20, 2011
Check Tim's site . already done. ----- Original Message ----- From: Shannon Hicks To: rv10-list(at)matronics.com Sent: Wednesday, July 20, 2011 6:59 AM Subject: RV10-List: -10 Plans I have started scanning all of my -10 plans for my own personal use and was wondering if there would be any issues with making them available for everyone to see. Thanks for your input. Shannon ________________________________________________________________________________
Date: Jul 20, 2011
I think the FG is still pretty thick back there. The VS fairing would be thinner ...... and there's a whole lot of aircraft out there flying with the GPS antenna on the glareshield. I like the glareshield mountiung .... shorter coax, less weight (those ounces add up!) and easier installation. Linn On 7/20/2011 8:48 AM, Kelly McMullen wrote: > > One does have to wonder just how many satellites you would miss that > were shadowed by the vertical stab. Seems like you would still have > more than 300 degree view of the sky there. > Has anyone had success with GPS antenna under the cabin cover(without > making holes in the fiberglass)? Seems like there shouldn't be a > problem behind the door posts where there is no honeycomb. > > > On 7/20/2011 5:26 AM, Bob Leffler wrote: >> >> >> I'm surprised that your not having reception issues with the antenna >> under the empennage fairing. The garmin install manual states to >> stay clear of the VS. >> >> >> >> On Jul 20, 2011, at 8:00 AM, "orchidman" wrote: >> >>> The UAT antenna is mounted about 12" from the unit in the floor of >>> the tail section and the GPS is mounted under the fiber glass cover >>> between the tail section and the vertical stab. > > ________________________________________________________________________________
Date: Jul 20, 2011
Actually Tim took it down a year ago. It is not legal to copy the plans and distribute. The best suggestion is ask Vans if you can do it and if so, do it and state so. Pascal From: DLM Sent: Wednesday, July 20, 2011 7:30 AM Subject: Re: RV10-List: -10 Plans Check Tim's site . already done. ----- Original Message ----- From: Shannon Hicks To: rv10-list(at)matronics.com Sent: Wednesday, July 20, 2011 6:59 AM Subject: RV10-List: -10 Plans I have started scanning all of my -10 plans for my own personal use and was wondering if there would be any issues with making them available for everyone to see. Thanks for your input. Shannon href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 20, 2011
rleffler wrote: > I didn't know the ga-56 was supported. It wasn't listed in the manual that I have. I guess I need to get an updated manual. I'm currently stuck in his backlog queue waiting for mine to arrive. > It's not listed even in the new manual but it is pulling in 12 sats. > I'm surprised that your not having reception issues with the antenna under the empennage fairing. The garmin install manual states to stay clear of the VS. Works great. I seem to be pulling in at least 9 and mostly 12. I mounted it the same place Tim mounted his antenna (different type though). The front 2 screws go into the turtle back, and the coax comes up on the aft side of the bulkhead. The only sat that would be blocked would be any one directly over head and aft. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347182#347182 ________________________________________________________________________________
Date: Jul 20, 2011
Thanks Guys. I was afraid that there might be some copyright issues involved. Right now I have them in my Google Docs with access restricted to only those that have permission. Right now, that is just me and a friend that is helping me out. It is handy to have them available when away from the hanger if a question or concern comes up. Shannon On , Pascal wrote: > Actually Tim took it down a year ago. It is not legal to copy the plans > and > distribute. > The best suggestion is ask Vans if you can do it and if so, do it and > state > so. > Pascal > From: DLM > Sent: Wednesday, July 20, 2011 7:30 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: -10 Plans > Check Tim's site . already done. > ----- Original Message ----- > From: > Shannon > Hicks > To: rv10-list(at)matronics.com > Sent: Wednesday, July 20, 2011 6:59 > AM > Subject: RV10-List: -10 Plans > I have started scanning all of my -10 plans for my own > personal use and was wondering if there would be any issues with making > them > available for everyone to see. > Thanks for your > input. > Shannon > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Jul 20, 2011
Bill said a GA35 GPS antenna works fine. CI-105 works for the xponder. Garmin 430W, etc. don't support digital antenna out stream (and may never). So you have no choice but to use the built-in ADS600 GPS + extra antenna. I found a manual on their website, but can't seem to locate it now. Navworx sent me the latest version: "ADS600-B Installation Manual 240-0008-00-14.pdf" (email me offline if you wish to get a copy). The newer doc has at least one addition that I hadn't noticed before: ADS600 Pin35 "Transponder Suppression Input". The power wire size (two inputs) is way oversubscribed for the required current draw. I'm planning to pull wire for ADS600 connections to external connector to facilitate easy future access / expansion as required. Notes from Bill at Navworx: 1) GTX330 to ADS600 shows shield grounds on both ends of ARINC connection. Only one shield ground is required. Notes from Carlos at GRT: 1) GRT doesn't currently support built-in Maintenance Serial port connects shown for HX display in WD-1008-00.pdf GRT doc. Wire to DB9 as shown in Navworx install doc. 2) ADS600-Pin25 "TISA TX" to EFIS is not supported by GRT. I don't know why... ADS600 offers ARINC connect to GTX330, so maybe it doesn't matter. 3) EFIS Serial Out 7 "Display TX" to ADS600 is not supported at present. Okay to wire, but leave it turned off in the EFIS for now. So my 3 screen GRT to ADS600B connections are as follows: ADS600: Maint Port RX-Pin 4 --- To DB9 for PC ADS600: Maint Port TX-Pin 22 --- To DB9 for PC ADS600: Maint Port GND-Pin 3 --- To DB9 for PC ADS600: ALT Enc Serial RX-Pin 7 --- To GRT DU1A-Pin1 (Serial Out 6) ADS600: ALT TIS TX-Pin 25 --- Not Connected ADS600: ALT Enc GND-Pin6 --- To GRT DU1A-Pin17 GND ADS600: Display Serial TX-Pin 5 --- To GRT DU1B,2A,3A-Pin23 (Serial IN 7) ADS600: Display Serial RX-Pin 24 --- To GRT DU2B-Pin22 (Serial OUT 7) Note: Wired, but GRT Port to be disabled. ~~~ Other connections are ADS600: ARINC IN1B-Pin28 --- To GTX330 ARINC OUT2B-Pin28 ADS600: ARINC IN1A-Pin09 --- To GTX330 ARINC OUT2A-Pin30 ADS600: UAT Fail OUT-Pin 14 --- Wire to ext connector for future use ADS600: Transponder Suppression Input-Pin35 --- Wire to ext connector for future use. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347186#347186 ________________________________________________________________________________
Date: Jul 20, 2011
Subject: Re: RV10-List: -10 Plans Shannon, How about making them available to anyone with a valid RV-10 customer number with Vans? I think it would be a very helpful option Van's could even offer if you sent them the file. Matthew RV-10 phase 1 flight testing On Wed, Jul 20, 2011 at 10:08 AM, wrote: > Thanks Guys. I was afraid that there might be some copyright issues > involved. Right now I have them in my Google Docs with access restricted to > only those that have permission. Right now, that is just me and a friend > that is helping me out. It is handy to have them available when away from > the hanger if a question or concern comes up. > > Shannon > > > On , Pascal wrote: > > > > > > > > > > > > > > > > > > Actually Tim took it down a year ago. It is not legal to copy the plans > and > > distribute. > > > > The best suggestion is ask Vans if you can do it and if so, do it and > state > > so. > > > > Pascal > > > > > > > > > > > > > > From: DLM > > > > Sent: Wednesday, July 20, 2011 7:30 AM > > > > To: rv10-list(at)matronics.com > > > > Subject: Re: RV10-List: -10 Plans > > > > > > > > > > > > > > > > Check Tim's site . already done. > > > > > > ----- Original Message ----- > > > > From: > > Shannon > > Hicks > > > > To: rv10-list(at)matronics.com > > > > Sent: Wednesday, July 20, 2011 6:59 > > AM > > > > Subject: RV10-List: -10 Plans > > > > > > I have started scanning all of my -10 plans for my own > > personal use and was wondering if there would be any issues with making > them > > available for everyone to see. > > > > Thanks for your > > input. > > > > Shannon > > > > > > href="http://www.matronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List > > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > href="http://www.matronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List > > href="http://forums.matronics.com">http://forums.matronics.com > > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > > > > > > > >========= > > > > > > > > * > > * > > ________________________________________________________________________________
Date: Jul 20, 2011
I just spoke with Van's and they do not have a problem with me sharing the plans with other -10 builders. They just don't want them accessible to everyone in the world with an internet connection. If anyone would like to have access to them, please email me directly along with your builder number and I will get you access to the plans. Shannon On Wed, Jul 20, 2011 at 12:44 PM, Matthew Collier wrote: > Subject: Re: RV10-List: -10 Plans > > Shannon, > How about making them available to anyone with a valid RV-10 customer > number with Vans? I think it would be a very helpful option Van's could even > offer if you sent them the file. > > Matthew > RV-10 phase 1 flight testing > > > On Wed, Jul 20, 2011 at 10:08 AM, wrote: > >> Thanks Guys. I was afraid that there might be some copyright issues >> involved. Right now I have them in my Google Docs with access restricted to >> only those that have permission. Right now, that is just me and a friend >> that is helping me out. It is handy to have them available when away from >> the hanger if a question or concern comes up. >> >> Shannon >> >> >> On , Pascal wrote: >> > >> > >> > >> > >> > >> > >> > >> > >> > Actually Tim took it down a year ago. It is not legal to copy the plans >> and >> > distribute. >> > >> > The best suggestion is ask Vans if you can do it and if so, do it and >> state >> > so. >> > >> > Pascal >> > >> > >> > >> > >> > >> > >> > From: DLM >> > >> > Sent: Wednesday, July 20, 2011 7:30 AM >> > >> > To: rv10-list(at)matronics.com >> > >> > Subject: Re: RV10-List: -10 Plans >> > >> > >> > >> > >> > >> > >> > >> > Check Tim's site . already done. >> > >> > >> > ----- Original Message ----- >> > >> > From: >> > Shannon >> > Hicks >> > >> > To: rv10-list(at)matronics.com >> > >> > Sent: Wednesday, July 20, 2011 6:59 >> > AM >> > >> > Subject: RV10-List: -10 Plans >> > >> > >> > I have started scanning all of my -10 plans for my own >> > personal use and was wondering if there would be any issues with making >> them >> > available for everyone to see. >> > >> > Thanks for your >> > input. >> > >> > Shannon >> > >> > >> > href="http://www.matronics.com/Navigator?RV10-List"> >> http://www.matronics.com/Navigator?RV10-List >> > href="http://forums.matronics.com">http://forums.matronics.com >> > href="http://www.matronics.com/contribution">http://www.matronics.com/c >> > >> > >> > href="http://www.matronics.com/Navigator?RV10-List"> >> http://www.matronics.com/Navigator?RV10-List >> > href="http://forums.matronics.com">http://forums.matronics.com >> > href="http://www.matronics.com/contribution">http://www.matronics.com/c >> > >> > >> > >> > >> >========= >> > >> > >> > >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
Date: Jul 20, 2011
Subject: Abe's Tiedowns for OSH
After the disaster at Sun-N-Fun where the planes flipped all over the place, I paid attention to the stuff going on when the discussion turned to tiedowns. At the time, Aviation Consumer decided to test them after the big blow and get feedback too, from sun-n-fun attenders. So they did a tie-down comparison and basically the thrust of it was that The Claw was probably just slightly on top as the best. But, then came info about the Storm Force tie down, which purported to be better yet. So I watched with interest because I really care about my plane and care not to have it thrashed at OSH, and every year... and I mean EVERY year, we get at least one storm going through that scares the heck out of me. (Remember that bozo with the stuck horn in camp scholler that sounded like a tornado horn that one year?) So I wanted to make sure that whatever I had, it was very very good, if not the best I could practically do. Well, after Aviation Consumer did that review, a couple others that they hadn't heard about were made known to them. One of them was Abe's Tiedowns...one that I had never heard of. As it turns out, Abe's tiedowns were vastly stronger than the other offerings when they tested them. You can go to Abe's Aviation site here, and see the Aviation Consumer review and test. http://www.abesaviation.com/ (actually, it looks like the link on their site has gotten mixed up but either google it or go to youtube here) Youtube: http://www.youtube.com/watch?v=UIuYK_eEQ9c Google: "Aviation Consumer's Tiedown Shootout" The way the test turned out, they used an engine hoist to test them, and the Abe's were so strong that the engine hoist wouldn't do it without tipping over so they hooked up a truck, and pulled to 1000lbs and the tires on the truck spun without pulling the tiedown anchors out. I was pretty impressed, and I'd never even heard of them before. The Abe's set aren't cheap...I bought the deluxe-5 set that costs $305, but there are cheaper options if you wish. I got them last week and opened them up and saw that they were really nice, made of stainless. They're going to be a little heavier in the 5-set that I got, than my claw set, but the anchoring hold is much much stronger. My thought is that if I were going somewhere for a simple overnight, perhaps I'd take the claw for weight savings if it were an issue (it's only about 3 lbs less). But sometimes you're traveling to a place like OSH. At OSH, you can't really just LEAVE if a storm is imminent. The rules don't allow it, and you can't just get up at 9pm and decide to bug out before a huge line of storms is coming. So for a show like OSH, I don't want my plane flying around into someone else's, or flipping over, and I'd gladly haul the best tiedown anchors I could get for such a show. I know, it's paranoid, but it did just happen at OSH. So anyway, I thought I'd pass on the note, since I wasn't aware of them. I was impressed enough that I asked Abe's guy to send me some flyers that I can set down by the plane next to the tiedowns, to have something for people to grab if they are interested in such a thing. I know it might not be something you could get in time for OSH, unless you scramble, but for builders who don't have them, you may want to stop over and take a peek. Just thought I'd pass that along. Tim -- Tim Olson - RV-10 N104CD ________________________________________________________________________________
Date: Jul 20, 2011
Subject: Re: Abe's Tiedowns for OSH
The problem I had with the Aviation Consumer test was that they pulled straight up. Just another data point: I volunteer at the Aerobatic center .... the tent next to the warbird ramp ..... and the aircraft on display were tied down with the doggy screw-in anchors. The storm picked up our tent and flipped it over, but the aircraft tied down didn't move. Why? All the tiedowns were offset from the tiedown rings (or the gear legs etc) so the pulling force was sideways on the stakes. I looked at a large number of aircraft that were still tied down with the doggy stakes ..... and the stakes were very close to being right under the tiedown rings. I think they just dodged the bullet. I have no knowledge of how the damaged aircraft were tied down, but I'm of the opinion that with the tornado, no tiedown would have survived. Look at how the Abes Stakes are laid out. Pulling two flat plates sideways takes an awesome amount of force. Linn On 7/20/2011 3:26 PM, Tim Olson wrote: > > After the disaster at Sun-N-Fun where the planes flipped all over > the place, I paid attention to the stuff going on when the > discussion turned to tiedowns. At the time, Aviation Consumer > decided to test them after the big blow and get feedback too, > from sun-n-fun attenders. So they did a tie-down comparison > and basically the thrust of it was that The Claw was probably > just slightly on top as the best. But, then came info > about the Storm Force tie down, which purported to be better > yet. > > So I watched with interest because I really care about my > plane and care not to have it thrashed at OSH, and every year... > and I mean EVERY year, we get at least one storm going through > that scares the heck out of me. (Remember that bozo with the > stuck horn in camp scholler that sounded like a tornado horn > that one year?) So I wanted to make sure that whatever I > had, it was very very good, if not the best I could practically > do. > > Well, after Aviation Consumer did that review, a couple others > that they hadn't heard about were made known to them. > One of them was Abe's Tiedowns...one that I had never heard > of. As it turns out, Abe's tiedowns were vastly stronger > than the other offerings when they tested them. > > You can go to Abe's Aviation site here, and see the > Aviation Consumer review and test. http://www.abesaviation.com/ > (actually, it looks like the link on their site has > gotten mixed up but either google it or go to youtube here) > > Youtube: http://www.youtube.com/watch?v=UIuYK_eEQ9c > Google: "Aviation Consumer's Tiedown Shootout" > > The way the test turned out, they used an engine hoist > to test them, and the Abe's were so strong that the > engine hoist wouldn't do it without tipping over so they > hooked up a truck, and pulled to 1000lbs and the tires > on the truck spun without pulling the tiedown anchors out. > I was pretty impressed, and I'd never even heard of them > before. > > The Abe's set aren't cheap...I bought the deluxe-5 set > that costs $305, but there are cheaper options if you > wish. I got them last week and opened them up and > saw that they were really nice, made of stainless. They're > going to be a little heavier in the 5-set that I got, than > my claw set, but the anchoring hold is much much stronger. > My thought is that if I were going somewhere for a simple > overnight, perhaps I'd take the claw for weight savings > if it were an issue (it's only about 3 lbs less). But > sometimes you're traveling to a place like OSH. At OSH, > you can't really just LEAVE if a storm is imminent. The > rules don't allow it, and you can't just get up at > 9pm and decide to bug out before a huge line of storms > is coming. So for a show like OSH, I don't want my plane > flying around into someone else's, or flipping over, and > I'd gladly haul the best tiedown anchors I could get > for such a show. I know, it's paranoid, but it did just > happen at OSH. > > So anyway, I thought I'd pass on the note, since I wasn't > aware of them. I was impressed enough that I asked Abe's > guy to send me some flyers that I can set down by the plane > next to the tiedowns, to have something for people to > grab if they are interested in such a thing. I know it > might not be something you could get in time for OSH, > unless you scramble, but for builders who don't have them, > you may want to stop over and take a peek. > > Just thought I'd pass that along. > Tim > ________________________________________________________________________________
Date: Jul 20, 2011
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Oshkosh wireless sites
Can anybody update me on wireless internet connections at Oshkosh? Where are the good places? Dr Fred. ________________________________________________________________________________
Date: Jul 20, 2011
Corrections to after additional input from Navworx... ADS600B connection list for GRT HX: ADS600: Maint Port RX-Pin 4 --- To DB9 for PC ADS600: Maint Port TX-Pin 22 --- To DB9 for PC ADS600: Maint Port GND-Pin28 --- To DB9 for PC ADS600: ALT Enc Serial RX-Pin 7 --- To GRT DU1A-Pin1 (Serial Out 6) ADS600: ALT TIS TX-Pin 25 --- Not Connected (provided by Display) ADS600: ALT Enc GND-Pin6 --- To GRT DU1A-Pin17 GND ADS600: Display Serial TX-Pin 5 --- To GRT DU1B,2A,3A-Pin23 (Serial IN 7) ADS600: Display Serial RX-Pin 24 --- To GRT DU2B-Pin22 (Serial OUT 7) Wire for future GRT support. Disable Serial OUT 7. ~~~ Other connections are ADS600: ARINC IN1B-Pin28 --- To GTX330 ARINC OUT2B-Pin28 ADS600: ARINC IN1A-Pin09 --- To GTX330 ARINC OUT2A-Pin30 ADS600: UAT Fail OUT-Pin 14 --- Wire to ext connector for future use ADS600: Transponder Suppression OUT-Pin35 --- Not connected (provided by GTX330 ARINC) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=347209#347209 ________________________________________________________________________________
Date: Jul 20, 2011
Subject: Re: Oshkosh wireless sites
On 07/20/2011 04:08 PM, Fred Williams, M.D. wrote: > > > Can anybody update me on wireless internet connections at Oshkosh? Where > are the good places? http://www.airventure.org/news/2011/110718_wifi.html The AirVenture site map has the hotspots marked on it. --Rick ________________________________________________________________________________
Date: Jul 20, 2011
They're located on the Airventure map this year. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Fred Williams, M.D. Sent: Wednesday, July 20, 2011 4:09 PM Subject: RV10-List: Oshkosh wireless sites --> Can anybody update me on wireless internet connections at Oshkosh? Where are the good places? Dr Fred. ________________________________________________________________________________
Date: Jul 20, 2011
Mr Hicks, I would like to share the plans. James Stribling Vans # 40140 Thanks On Wed, Jul 20, 2011 at 9:59 AM, Shannon Hicks wrote: > I have started scanning all of my -10 plans for my own personal use and was > wondering if there would be any issues with making them available for > everyone to see. > > Thanks for your input. > > Shannon > > * > > * > > ________________________________________________________________________________
Date: Jul 20, 2011
I forgot to provide my email address: jlstrib(at)comcast.net On Wed, Jul 20, 2011 at 1:08 PM, wrote: > Thanks Guys. I was afraid that there might be some copyright issues > involved. Right now I have them in my Google Docs with access restricted to > only those that have permission. Right now, that is just me and a friend > that is helping me out. It is handy to have them available when away from > the hanger if a question or concern comes up. > > Shannon > > > On , Pascal wrote: > > > > > > > > > > > > > > > > > > Actually Tim took it down a year ago. It is not legal to copy the plans > and > > distribute. > > > > The best suggestion is ask Vans if you can do it and if so, do it and > state > > so. > > > > Pascal > > > > > > > > > > > > > > From: DLM > > > > Sent: Wednesday, July 20, 2011 7:30 AM > > > > To: rv10-list(at)matronics.com > > > > Subject: Re: RV10-List: -10 Plans > > > > > > > > > > > > > > > > Check Tim's site . already done. > > > > > > ----- Original Message ----- > > > > From: > > Shannon > > Hicks > > > > To: rv10-list(at)matronics.com > > > > Sent: Wednesday, July 20, 2011 6:59 > > AM > > > > Subject: RV10-List: -10 Plans > > > > > > I have started scanning all of my -10 plans for my own > > personal use and was wondering if there would be any issues with making > them > > available for everyone to see. > > > > Thanks for your > > input. > > > > Shannon > > > > > > href="http://www.matronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List
July 11, 2011 - July 20, 2011
RV10-Archive.digest.vol-ih
