RV10-Archive.digest.vol-iq
February 28, 2012 - March 31, 2012
Subject: Re: Antenna locations
Date: Feb 28, 2012
Mine is up top and out of the way. It would have been easier to mount it earlier in construction but it worked out great. I made a nutplated doubler to mount the CI-157P and used the 5/16 pneumatic airline to run the coax up the nose of the vertical ribs. Best pic of it I found. Apex is toward the nose. ----- Original Message ----- From: Ed Kranz To: rv10-list(at)matronics.com Sent: Tuesday, February 28, 2012 9:10 AM Subject: RV10-List: Antenna locations I'm just getting ready to finish up the vertical stab, and I need to make a decision about antenna locations... specifically the Nav antenna(s). The options I've seen are: a.. Whiskers on top of the VS (on the rib below the rudder) b.. Whiskers below the VS c.. Wingtip antenna I'm leaning towards whiskers on top of the VS and a NAV2 in a wingtip, as I'm worried about dogs and kids finding the antennas with their eyes (also concerned about the COM antennas on the belly for the same reason, but that's something to worry about further down the line). My question is: is there a performance hit from mounting the whiskers on top of the VS? Do you get any shadowing from the wings and body of the plane? Also, which whiskers (with removable elements) are giving the best performance for your buck? Thanks! Ed Kranz 41347 edandcolleen.com ________________________________________________________________________________
Date: Feb 28, 2012
BTW, I have the bob archer in the wingtip for my nav two. A lot of discussion on the reception. My personal experience is roughly 20 miles. The cat whisker will pick up the signal twenty miles farther than the bob archer. ----- Original Message ----- From: Ed Kranz To: rv10-list(at)matronics.com Sent: Tuesday, February 28, 2012 9:10 AM Subject: RV10-List: Antenna locations I'm just getting ready to finish up the vertical stab, and I need to make a decision about antenna locations... specifically the Nav antenna(s). The options I've seen are: a.. Whiskers on top of the VS (on the rib below the rudder) b.. Whiskers below the VS c.. Wingtip antenna I'm leaning towards whiskers on top of the VS and a NAV2 in a wingtip, as I'm worried about dogs and kids finding the antennas with their eyes (also concerned about the COM antennas on the belly for the same reason, but that's something to worry about further down the line). My question is: is there a performance hit from mounting the whiskers on top of the VS? Do you get any shadowing from the wings and body of the plane? Also, which whiskers (with removable elements) are giving the best performance for your buck? Thanks! Ed Kranz 41347 edandcolleen.com ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Feb 28, 2012
Ed, You are touching on an area close to "primers" as to strong opinions. Here is what I'm doing: - VOR antenna; home brew wingtip similar in design to the Bob Archer design, but dimensions changed to take advantage of the larger wingtip dimensions. I did this on my 8A and consistently get VOR reception at 40+ miles, and IL S/LOC reception way beyond useful range. - On the eyeball hazard I share your concerns. I have two bent whip antenna on the bottom of the10. First thing after it goes back in the hangar I put a hose (with the end capped) over each one. I don't want my dogs to jam th e antenna tips into their eyes - and I also found it a great safety step to p reserve my vision when cleaning the belly. - You mentioned "Nav 2". If you are striving for bang for the buck, perhaps you consider not having a second VOR receiver. I find the SL-30 in the 8A p rovides the "cross bearing to a second VOR" function well using the primary/ secondary VOR feature. If you really need a second VOR, the a single antenn a with a splitter works (for all practical purposes) as well as two antennas . Carl On Feb 28, 2012, at 12:27 PM, "Seano" wrote: > BTW, I have the bob archer in the wingtip for my nav two. A lot of discus sion on the reception. My personal experience is roughly 20 miles. The cat whisker will pick up the signal twenty miles farther than the bob archer. > ----- Original Message ----- > From: Ed Kranz > To: rv10-list(at)matronics.com > Sent: Tuesday, February 28, 2012 9:10 AM > Subject: RV10-List: Antenna locations > > I'm just getting ready to finish up the vertical stab, and I need to make a decision about antenna locations... specifically the Nav antenna(s). > > The options I've seen are: > Whiskers on top of the VS (on the rib below the rudder) > Whiskers below the VS > Wingtip antenna > I'm leaning towards whiskers on top of the VS and a NAV2 in a wingtip, as I 'm worried about dogs and kids finding the antennas with their eyes (also co ncerned about the COM antennas on the belly for the same reason, but that's something to worry about further down the line). > > My question is: is there a performance hit from mounting the whiskers on t op of the VS? Do you get any shadowing from the wings and body of the plane? Also, which whiskers (with removable elements) are giving the best performa nce for your buck? > > Thanks! > > Ed Kranz > 41347 > edandcolleen.com > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 28, 2012
I don't think finishing the vertical stab is the time to decide on that antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates and #4 flush screws instead of rivets, so I can get in there if I ever decide I want something there. Yes, it adds about $20 to overall cost, but to me that is easier than having to drill out rivets if the need arises. I'd be interested in what changes were made to the Bob Archer design to improve the range. If 40+ mile range is possible, I'd much rather have antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at 10K cruising alt on H class VORs. On 2/28/2012 11:14 AM, Carl Froehlich wrote: > Ed, > > You are touching on an area close to "primers" as to strong opinions. > > Here is what I'm doing: > - VOR antenna; home brew wingtip similar in design to the Bob Archer > design, but dimensions changed to take advantage of the larger wingtip > dimensions. I did this on my 8A and consistently get VOR reception at > 40+ miles, and ILS/LOC reception way beyond useful range. > - On the eyeball hazard I share your concerns. I have two bent whip > antenna on the bottom of the10. First thing after it goes back in the > hangar I put a hose (with the end capped) over each one. I don't want > my dogs to jam the antenna tips into their eyes - and I also found it > a great safety step to preserve my vision when cleaning the belly. > - You mentioned "Nav 2". If you are striving for bang for the buck, > perhaps you consider not having a second VOR receiver. I find the > SL-30 in the 8A provides the "cross bearing to a second VOR" function > well using the primary/secondary VOR feature. If you really need a > second VOR, the a single antenna with a splitter works (for all > practical purposes) as well as two antennas. > > Carl > > > On Feb 28, 2012, at 12:27 PM, "Seano" > wrote: > >> BTW, I have the bob archer in the wingtip for my nav two. A lot of >> discussion on the reception. My personal experience is roughly 20 >> miles. The cat whisker will pick up the signal twenty miles farther >> than the bob archer. >> >> ----- Original Message ----- >> *From:* Ed Kranz >> *To:* rv10-list(at)matronics.com >> *Sent:* Tuesday, February 28, 2012 9:10 AM >> *Subject:* RV10-List: Antenna locations >> >> I'm just getting ready to finish up the vertical stab, and I need >> to make a decision about antenna locations... specifically the >> Nav antenna(s). >> >> The options I've seen are: >> >> * Whiskers on top of the VS (on the rib below the rudder) >> * Whiskers below the VS >> * Wingtip antenna >> >> I'm leaning towards whiskers on top of the VS and a NAV2 in a >> wingtip, as I'm worried about dogs and kids finding the antennas >> with their eyes (also concerned about the COM antennas on the >> belly for the same reason, but that's something to worry about >> further down the line). >> >> My question is: is there a performance hit from mounting the >> whiskers on top of the VS? Do you get any shadowing from the >> wings and body of the plane? Also, which whiskers (with removable >> elements) are giving the best performance for your buck? >> >> Thanks! >> >> Ed Kranz >> 41347 >> edandcolleen.com <http://edandcolleen.com> >> >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> >> * >> >> ================================== >> ://www.matronics.com/Navigator?RV10-List >> ================================== >> cs.com >> ================================== >> matronics.com/contribution >> ================================== >> >> * > * > > > * ________________________________________________________________________________
Date: Feb 28, 2012
Kelly, I don't think he changed the design, it's more that the performance is extremely sensitive to installation. Grounding using the wingtip attach nutplates (not a wire or strap), routing of other wiring along the edge, etc. In fact, I exchanged emails with Bob A. when I did my install in the first -10. I was concerned about the heat protective foil from the halogen landing light kit - he said to make the antenna as close as possible to the foil without touching it. I had one of his antennas in each wingtip (and a GS antenna along with it in one tip) and they worked great. I'd routinely see 50+ miles when I was actually checking distance. I've also heard of really poor performance but without seeing the install hard to say why. FWIW, he will readily admit that his wingtip comm antenna is a poor performer because of the signal polarization. Bob On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrote: > > I don't think finishing the vertical stab is the time to decide on that > antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates > and #4 flush screws instead of rivets, so I can get in there if I ever > decide I want something there. Yes, it adds about $20 to overall cost, but > to me that is easier than having to drill out rivets if the need arises. > *I'd be interested in what changes were made to the Bob Archer design to > improve the range. If 40+ mile range is possible,* I'd much rather have > antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at > 10K cruising alt on H class VORs. > > ________________________________________________________________________________
Date: Feb 28, 2012
My post made it look like I only got 20 miles of reception when I meant 20 miles is the difference between my Bob Archer and my cat whiskers. ----- Original Message ----- From: Bob Condrey To: rv10-list(at)matronics.com Sent: Tuesday, February 28, 2012 1:59 PM Subject: Re: RV10-List: Antenna locations Kelly, I don't think he changed the design, it's more that the performance is extremely sensitive to installation. Grounding using the wingtip attach nutplates (not a wire or strap), routing of other wiring along the edge, etc. In fact, I exchanged emails with Bob A. when I did my install in the first -10. I was concerned about the heat protective foil from the halogen landing light kit - he said to make the antenna as close as possible to the foil without touching it. I had one of his antennas in each wingtip (and a GS antenna along with it in one tip) and they worked great. I'd routinely see 50+ miles when I was actually checking distance. I've also heard of really poor performance but without seeing the install hard to say why. FWIW, he will readily admit that his wingtip comm antenna is a poor performer because of the signal polarization. Bob On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrote: I don't think finishing the vertical stab is the time to decide on that antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates and #4 flush screws instead of rivets, so I can get in there if I ever decide I want something there. Yes, it adds about $20 to overall cost, but to me that is easier than having to drill out rivets if the need arises. I'd be interested in what changes were made to the Bob Archer design to improve the range. If 40+ mile range is possible, I'd much rather have antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at 10K cruising alt on H class VORs. ________________________________________________________________________________
Date: Feb 28, 2012
Having flown with both, do you think you'd be comfortable with just the Bob Archer? Do you use it for GS as well as VOR/LOC? On Tue, Feb 28, 2012 at 3:43 PM, Seano wrote: > ** > My post made it look like I only got 20 miles of reception when I meant 20 > miles is the difference between my Bob Archer and my cat whiskers. > > ----- Original Message ----- > *From:* Bob Condrey > *To:* rv10-list(at)matronics.com > *Sent:* Tuesday, February 28, 2012 1:59 PM > *Subject:* Re: RV10-List: Antenna locations > > Kelly, > > I don't think he changed the design, it's more that the performance is > extremely sensitive to installation. Grounding using the wingtip attach > nutplates (not a wire or strap), routing of other wiring along the edge, > etc. In fact, I exchanged emails with Bob A. when I did my install in the > first -10. I was concerned about the heat protective foil from the halogen > landing light kit - he said to make the antenna as close as possible to the > foil without touching it. I had one of his antennas in each wingtip (and a > GS antenna along with it in one tip) and they worked great. I'd routinely > see 50+ miles when I was actually checking distance. I've also heard of > really poor performance but without seeing the install hard to say why. > FWIW, he will readily admit that his wingtip comm antenna is a poor > performer because of the signal polarization. > > Bob > > On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrote: > >> >> I don't think finishing the vertical stab is the time to decide on that >> antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates >> and #4 flush screws instead of rivets, so I can get in there if I ever >> decide I want something there. Yes, it adds about $20 to overall cost, but >> to me that is easier than having to drill out rivets if the need arises. >> *I'd be interested in what changes were made to the Bob Archer design to >> improve the range. If 40+ mile range is possible,* I'd much rather have >> antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at >> 10K cruising alt on H class VORs. >> >> * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * > > ________________________________________________________________________________
Date: Feb 28, 2012
Personally, no. I would only install the cat whiskers if I only had one NAV. I use the CI-157P for GS/VOR/LOC and it is ran to the 430W (nav 1) with a Diplexer since the 430w needs the NAV/LOC separate from the GS.(see link below). The Bob Archer is ran to my SL-30 nav portion. I thought the cat whiskers were easier to install and it gets a better signal. http://www.aircraftspruce.com/catalog/avpages/coupler507.php ----- Original Message ----- From: Ed Kranz To: rv10-list(at)matronics.com Sent: Tuesday, February 28, 2012 2:54 PM Subject: Re: RV10-List: Antenna locations Having flown with both, do you think you'd be comfortable with just the Bob Archer? Do you use it for GS as well as VOR/LOC? On Tue, Feb 28, 2012 at 3:43 PM, Seano wrote: My post made it look like I only got 20 miles of reception when I meant 20 miles is the difference between my Bob Archer and my cat whiskers. ----- Original Message ----- From: Bob Condrey To: rv10-list(at)matronics.com Sent: Tuesday, February 28, 2012 1:59 PM Subject: Re: RV10-List: Antenna locations Kelly, I don't think he changed the design, it's more that the performance is extremely sensitive to installation. Grounding using the wingtip attach nutplates (not a wire or strap), routing of other wiring along the edge, etc. In fact, I exchanged emails with Bob A. when I did my install in the first -10. I was concerned about the heat protective foil from the halogen landing light kit - he said to make the antenna as close as possible to the foil without touching it. I had one of his antennas in each wingtip (and a GS antenna along with it in one tip) and they worked great. I'd routinely see 50+ miles when I was actually checking distance. I've also heard of really poor performance but without seeing the install hard to say why. FWIW, he will readily admit that his wingtip comm antenna is a poor performer because of the signal polarization. Bob On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrote: I don't think finishing the vertical stab is the time to decide on that antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates and #4 flush screws instead of rivets, so I can get in there if I ever decide I want something there. Yes, it adds about $20 to overall cost, but to me that is easier than having to drill out rivets if the need arises. I'd be interested in what changes were made to the Bob Archer design to improve the range. If 40+ mile range is possible, I'd much rather have antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at 10K cruising alt on H class VORs. href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Feb 28, 2012
I did modify the design slightly when I made the antenna (a few pieces of sc rap aluminum, some hardware and a piece of bakelite or fiberglass to make th e gama match). I did a hard mount (piece of .032 angle) to the outboard win g rib such that the antenna stays on the plane when you pull the wing tip of f. This solves the grounding issues. I also extended the piece that angles away from the rib such that the piece that runs parallel to the rib is tuck ed all the way into the outboard edge of the wingtip. This is a quarter wav elength antenna - which means the part that does most of the work (the high c urrent part) is close to the base. The end of the antenna (the high voltage part) provides the electrical length to resonate the antenna at the desired frequency. This is why bent whip antennas work as well as they do. The pa rt near the base is mostly vertical (communications are vertically polarized , VORs are horizontally polarized). I use the one antenna for both VOR and G S reception. As with all antennas, the performance is only as good as the tuning. I used an MFJ antenna analyzer to adjust the gama match and the overall length to r esonance. Most amateur radio operators have one of these analyzers and for a quick hop will most likely just make the antenna for you. Someplace I have an old AeroElectric book that provides details for the ante nna. Carl On Feb 28, 2012, at 3:59 PM, Bob Condrey wrote: > Kelly, > > I don't think he changed the design, it's more that the performance is ext remely sensitive to installation. Grounding using the wingtip attach nutpla tes (not a wire or strap), routing of other wiring along the edge, etc. In f act, I exchanged emails with Bob A. when I did my install in the first -10. I was concerned about the heat protective foil from the halogen landing lig ht kit - he said to make the antenna as close as possible to the foil withou t touching it. I had one of his antennas in each wingtip (and a GS antenna a long with it in one tip) and they worked great. I'd routinely see 50+ miles when I was actually checking distance. I've also heard of really poor perf ormance but without seeing the install hard to say why. FWIW, he will readi ly admit that his wingtip comm antenna is a poor performer because of the si gnal polarization. > > Bob > > On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrot e: > > I don't think finishing the vertical stab is the time to decide on that an tenna. I just closed off the fiberglass tip with Clickbond #4 nutplates and # 4 flush screws instead of rivets, so I can get in there if I ever decide I w ant something there. Yes, it adds about $20 to overall cost, but to me that i s easier than having to drill out rivets if the need arises. > I'd be interested in what changes were made to the Bob Archer design to im prove the range. If 40+ mile range is possible, I'd much rather have antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at 10K crui sing alt on H class VORs. > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 28, 2012
I have a single Archer in the right wing tip, running to an SL-30, as my only VOR. (As another poster mentioned, if you need to save money, I'd drop the #2 VOR - assuming you have a GPS backup). I easily pick up good signals at 50 miles @ 5000', except if the station is 90 degrees left of the aircraft (so the antenna has to look thru the fuselage). I can't say for certain what the range degradation is then. Picking up the localizer and GS signals has never been a problem. I ignored Bob A's instructions to some extent. I put the antenna fairly far back, away from the landing light, the aluminum foil, and the wiring for the lights (I ran these wires against the wing rib, and brought them out well in front of the antenna.). I also have a second antenna, an Archer clone slightly modified for slightly higher frequencies, in the left tip which I use for the #2 com (G420). I fastened the ground side of this antenna as high up as I could, under the top side plate nuts, and ran the element down to the bottom side of the tip, as steeply as I could, to get some vertical polarization. (most of the current flows in the first part of the radiating element). At 10 miles and pointed at the tower, 3000', tower reports the SL-30/belly whip as "5x5"; the G420 and wing tip antenna as "5x4", eg, slightly weaker. This agrees with my reception of the ATIS signal, the Archer/G420 is slightly weaker than the SL-30/external belly whip, although just barely noticeable. Again, I notice that at 15 miles or more I loose the ATIS on #2 if the left wing is pointed directly away from the tower. If I were doing it again, I would do it exactly the same as it is now. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367479#367479 ________________________________________________________________________________
Subject: Re: AP procedure
Date: Feb 28, 2012
I have a Trio autopilot (which I like a lot btw), and I also boot it up prior to takeoff, not because I have to (it boots in flight just fine) but because it is my "third source" of attitude information, should there be a disagreement between the other two. The Trio shows a symbolic turn coordinator, even when disengaged, so it is easy to compare to the other 2 attitude sources. I also use the autotrim feature, manually, if the autopilot is not engaged. So I always boot it up prior to takeoff. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367480#367480 ________________________________________________________________________________
Subject: SFO Trip This Week
Date: Feb 28, 2012
I am in the Bay area for a couple days, business trip. Does anyone need an excuse to go out and burn some 100LL Wednesday afternoon/evening? I'll buy fuel or food. Cheers, Frank -------- Frank Dombroski RV-10 N10FD Flying RV-8 N84FD Finished and sold :-{ SMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367487#367487 ________________________________________________________________________________
Subject: LED tail light strobe
Date: Feb 28, 2012
Does anyone know a good source to purchase an LED tail light strobe combo to replace my Whelen? I found a couple but they are out of stock. Also, does anyone have experience with clear wing walk tape? Does it discolor? Thx. Dave Leikam ________________________________________________________________________________
Date: Feb 29, 2012
Subject: Re: LED tail light strobe
Dave, I have the product made by AeroLeds.=C2- http://www.aeroleds.com/products /navigation-lights/experimental.aspx =C2- Nice product.=C2- No experience with clear wingwalk. Sean Blair COS RV7=C2- ----- Original Message ----- From: "David Leikam" <arplnplt(at)gmail.com> Sent: Tuesday, February 28, 2012 10:32:06 PM Subject: RV10-List: LED tail light strobe Does anyone know a good source to purchase an LED tail light strobe combo t o replace my Whelen? =C2-I found a couple but they are out of stock. Also, does anyone have experience with clear wing walk tape? =C2-Does it discolor? Thx. Dave Leikam =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Date: Feb 28, 2012
This is what I used. http://www.kestrobes.com/ -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367502#367502 ________________________________________________________________________________
Subject: Clear Wing Walk (was LED tail light strobe)
Date: Feb 29, 2012
Dave, Always interested in trying something new (for better or worse) I used a ma terial designed to add a non-skid texture to paint and painted my wing walk s clear over the white basecoat. Then color matched the outline. See below: [Description: http://painttheweb.com/painttheweb/rv-10/Images/Paint/Wing%20 Walk.jpg] I wanted to extend the length of the wing graphically which I think has wor ked to nice effect. That being said it's not ideal for most people, muddy f eet and all. If I were to do it again I would use the exact same non-skid m aterial but color match the step area my dark blue/grey. Oh, one more thing. When I chose to go this route I slightly undersized the area vs. the standard wing walk tape Van's sells in case I had to cover up my mistake but I am pleased with the performance of this surface. Sorry I don't recall the non-skid material. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of David Leikam Sent: Tuesday, February 28, 2012 9:32 PM Subject: RV10-List: LED tail light strobe plnplt(at)gmail.com>> Does anyone know a good source to purchase an LED tail light strobe combo t o replace my Whelen? I found a couple but they are out of stock. Also, does anyone have experience with clear wing walk tape? Does it disco lor? Thx. Dave Leikam ________________________________________________________________________________
Date: Feb 29, 2012
I have used clear wing walk that I purchased as Spruce, I believe, and I am not happy with it. I think it is less flexible than the Ray Allen stuff, so it becomes brittle. It also doesn't seem to adhere as well. I have moved back to the black stuff. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 29, 2012, at 12:32 AM, David Leikam wrote: > > Does anyone know a good source to purchase an LED tail light strobe combo to replace my Whelen? I found a couple but they are out of stock. > Also, does anyone have experience with clear wing walk tape? Does it discolor? > Thx. > > Dave Leikam > > > > ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: Van's door seal
Date: Feb 29, 2012
I've got an unused Van's door seal I'd be willing to part with, if anyone h as a use or desire for it. FREE! Just send a few bucks to ship it. Got to clean out the hangar! Tim N52KS Tdt(at)aurora.aero ________________________________________________________________________________
Subject: Re: Van's door seal
Date: Feb 29, 2012
Tim, I'll take it. Carl On Feb 29, 2012, at 6:42 AM, "Dawson-Townsend,Timothy" wrote: > I've got an unused Van's door seal I'd be willing to part with, if anyone h as a use or desire for it. FREE! Just send a few bucks to ship it. > Got to clean out the hangar! > > Tim > N52KS > Tdt(at)aurora.aero > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 29, 2012
I installed 2 Archer nav antennas in each wing tip, one for each radio. My rationale was that you will loose 3.5db through a splitter, which is around 50% signal strength. As an earlier post stated, you can tune the antenna for your installation using a piece of test equipment that most hams have. I have not flown the aircraft as of yet, but based on most reports, I think this should work fine. In today's environment, only real use for a VOR antenna is to receive the localizer and GS. Normally the distance on this is less than 7nm. I also installed an Archer MB antenna in the wingtip on the top surface above and outside of the Archer antenna. -------- Bill Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367514#367514 ________________________________________________________________________________
Subject: Re: A I just got a new upper intersection fairing from Vans
Date: Feb 29, 2012
Bill, Just out of curiosity, how did the fairing come loose? Bill -------- Bill Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367516#367516 ________________________________________________________________________________
Date: Feb 29, 2012
Subject: A few reflections at 115 hours from a very happy builder.
Just a few thoughts that may be of some value. Rudder Trim: Not really needed I've been climbing and cruising at full power. I've been descending at high and low power settings. I've found that the 'natural' friction of the rudder control system will hold the necessary trim in typical calm cruising conditions. The lightest pressure on the right rudder will handle things for initial climbout. Though I've made provisions for a spring type rudder trim, at this point I don't see any reason to install it. Trimming for roll: The elevator trim tabs have a significant effect on roll trim As we all know or will find out, the elevator trim tab setup is disturbingly asymmetric in operation. Not a problem, just strange. When doing the final setup, there are some guidelines for how this asymmetry should be handled. What I've found is that a few turns of the clevis at one trim tab can have a noticeable effect on roll trim. So if you seem to require the aileron trim to be set one way or the other, consider a small adjustment of the elevator trim tabs. You can make noticeable changes while still staying within the guidelines for general setup. On a related topic.... Building a 'straight' airframe: This plane just 'snaps' together.... it really does (this is a QB statement). There isn't a significant bit of jigging required anywhere to build a straight aircraft.... with one possible exception... or maybe it was just me. The one task I initially screwed up was drilling the elevator horns. I screwed it up so badly that a complete rework was required with the gracious help of my Tech Counselor. But even with the rework and a second chance to get it right, I ever so slightly screwed it again. That is, my elevators are ever so slightly misaligned. Grrrrr! I'm living with it now and it's all okay (see "trimming for roll"). But, take time and care with the drilling of the elevator horns! Economy: LOP ops Rock! I'm getting far better economy from the 260HP efficient '10 than I ever got from my 180HP Maule... in all regimes. No surprise in retrospect but I just didn't expect it. Long term effects of LOP? I'm confident it's the best thing I can do to my engine. Time will tell. Overall: For this pilot It's hard to imagine a better 4 place homebuilt cruiser than he '10. Easy and fun to fly, great performance in all respects, roomy, good looking, etc, etc. I don't have that much experience in that many aircraft to make credible comparisons so I'll just leave it at that. One thing it doesn't do well is flying in the convective chop that is common on most sunny days. The nose hunts all over the place, especially in yaw. I try not to give rides in the middle of the day or below 4k to 6k on a normal Carolina day. So What! Bill "happily buzzing at 6 months and 115 hours" Watson #40605 MyRV10.com - The RV10 Builders Page <http://www.myrv10.com/> ________________________________________________________________________________
Date: Feb 29, 2012
Vans Good question. I don't have a clue. One day during preflight, it wasn't there. Wish I knew. Bill On 2/29/2012 8:43 AM, bill.peyton wrote: > --> RV10-List message posted by: "bill.peyton" > > Bill, > Just out of curiosity, how did the fairing come loose? > Bill > > -------- > Bill > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367516#367516 > > ________________________________________________________________________________
Date: Feb 29, 2012
I suggest looking at the ztron unit, seems like one of the most affordable choices. It is at ztronlabs.com Bill Greenley On Wed, Feb 29, 2012 at 12:32 AM, David Leikam wrote: > > Does anyone know a good source to purchase an LED tail light strobe combo to replace my Whelen? I found a couple but they are out of stock. > Also, does anyone have experience with clear wing walk tape? Does it discolor? > Thx. > > Dave Leikam > > ________________________________________________________________________________
Date: Feb 29, 2012
Vans I guess I should add that it was screwed on with #6 truss heads into those self locking Riv-nuts or whatever they are called. The Riv-nut things remain in place... I forget whether all the screws were still there or not. Seems like the fairing just ripped away. They were the standard Vans part with maybe only one layer of cloth added. I would note that the new fairing seems to be of higher quality and I'm thinking of not adding any additional cloth contrary to the directions. Am I setting myself up to lose another? On 2/29/2012 8:55 AM, Bill Watson wrote: > > Good question. I don't have a clue. One day during preflight, it > wasn't there. Wish I knew. > > Bill > > On 2/29/2012 8:43 AM, bill.peyton wrote: >> --> RV10-List message posted by: "bill.peyton" >> >> Bill, >> Just out of curiosity, how did the fairing come loose? >> Bill >> >> -------- >> Bill >> Aviation Partners, LLC ________________________________________________________________________________
Date: Feb 29, 2012
Subject: Re: A few reflections at 115 hours from a very happy builder.
Ditto Ditto Ditto Ditto Ditto.... and that's all I have to say.=0ADon=0A =0A=0A________________________________=0A From: Bill Watson <Mauledriver@nc .rr.com>=0ATo: rv10-list(at)matronics.com =0ASent: Wednesday, February 29, 201 2 7:53 AM=0ASubject: RV10-List: A few reflections at 115 hours from a very happy builder.=0A =0A=0AJust a few thoughts that may be of some value.=0A =0ARudder Trim: Not really needed=0AI've been climbing and cruising at full power.- I've been=0A descending- at high and low power settings.- I've found that the=0A 'natural' friction of the rudder control system will hold the=0A necessary trim in typical calm cruising conditions.- The lightest=0A pressure on the right rudder will handle things for init ial=0A climbout.- Though I've made provisions for a spring type rudder =0A trim, at this point I don't see any reason to install it.=0A=0ATrimm ing for roll: The elevator trim tabs have a significant effect=0A on rol l trim=0AAs we all know or will find out, the elevator trim tab setup is=0A disturbingly asymmetric in operation.- Not a problem, just strange. -=0A When doing the final setup, there are some guidelines for how thi s=0A asymmetry should be handled.- What I've found is that a few turns of=0A the clevis at one trim tab can have a noticeable effect on roll =0A trim.- So if you seem to require the aileron trim to be set one wa y=0A or the other, consider a small adjustment of the elevator trim=0A tabs.- You can make noticeable changes while still staying within=0A the guidelines for general setup.- On a related topic....=0A=0ABuilding a 'straight' airframe:- This plane just 'snaps'=0A together.... it rea lly does (this is a QB statement).- There isn't a=0A significant bit o f jigging required anywhere to build a straight=0A aircraft.... with one possible exception... or maybe it was just=0A me.- The one task I ini tially screwed up was drilling the elevator=0A horns.- I screwed it up so badly that a complete rework was required=0A with the gracious help of my Tech Counselor.- But even with the=0A rework and a second chance to get it right, I ever so slightly=0A screwed it again.- That is, my elevators are ever so slightly=0A misaligned.- Grrrrr!- I'm living with it now and it's all okay (see=0A "trimming for roll").- But, take time and care with the drilling of=0A the elevator horns!=0A=0AEconomy: - LOP ops Rock!- I'm getting far better economy from the=0A 260HP ef ficient '10 than I ever got from my 180HP Maule... in all=0A regimes.- No surprise in retrospect but I just didn't expect it.-=0A Long term effects of LOP?- I'm confident it's the best thing I can=0A do to my e ngine.- Time will tell.=0A=0AOverall: For this pilot It's hard to imagine a better 4 place=0A homebuilt cruiser than he '10.-- Easy and fun t o fly, great=0A performance in all respects, roomy, good looking, etc, e tc.- I don't=0A have that much experience in that many aircraft to mak e credible=0A comparisons so I'll just leave it at that. - One thing i t doesn't do=0A well is flying in the convective chop that is common on most sunny=0A days.- The- nose hunts all over the place, especially in yaw.- I try=0A not to give rides in the middle of the day or below 4k to 6k on a=0A normal Carolina day.- =0ASo What!=0A=0ABill "happily buzzing at 6 months and 115 hours" Watson=0A#40605=0AMyRV10.com - The RV10 ===================== ________________________________________________________________________________
Subject: RV 10 power plant question...
Date: Feb 29, 2012
Hey Guys. What other versions of the IO 540 have been successfully installed in the 10? Has anyone installed versions other than the IO 540 D4A5? If so please advise. I am about 6 months out until I need a power plant. Thanks!!! Jim Villani Kit# 41084 Jim(at)JimVillani.com ________________________________________________________________________________
Date: Feb 29, 2012
Subject: Re: RV 10 power plant question...
C4B5 Sent from my Verizon Wireless 4G LTE DROID -----Original message----- From: JimVillani <Jim(at)JimVillani.com> Subject: RV10-List: RV 10 power plant question... Hey Guys. What other versions of the IO 540 have been successfully installed in the 10? Has anyone installed versions other than the IO 540 D4A5? If so please advise. I am about 6 months out until I need a power plant. Thanks!!! Jim Villani Kit# 41084 Jim(at)JimVillani.com ________________________________________________________________________________
Date: Feb 29, 2012
[quote="Jim(at)JimVillani.com"]Hey Guys What other versions of the IO 540 have been successfully installed in the 10? Has anyone installed versions other than the IO 540 D4A5? If so please advise I am about 6 months out until I need a power plant Thanks!!! Jim Villani Kit# 41084 Jim(at)JimVillani.com (Jim(at)JimVillani.com) > [b] I installed a C4B5, as have many others. This engine was installed on Piper Aztec's and perhaps some other Piper's, but I don't know for sure about that. The engine mount ears from the Aztec will not fit the Van's engine mount, but the correct ears are available. The C4B5 was rated at 250 HP on the Aztec by limiting max RPM to 2575. Lycoming says that it is identical to the D4A5 otherwise, so can be operated at 260HP/2700 RPM on the RV-10. -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367535#367535 ________________________________________________________________________________
Date: Feb 29, 2012
I have to decent from the Rudder Trim observation. I LOVE having my rudder trim. Maybe because we design a trick one for the 10 & 8A but if you want t he plane perfectly coordinated in most phases of flight (I never bother on climb out) having an adjustable rudder trim is nice. One note, I included a position sensor which is indicated on my G900x for the 10. After flying fo r a while I figured out we already have a position indicator called the sli p ball. On the 8A I just installed the servo, no position sensor or indicat or needed just center the ball. Duhhh Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Don McDonald Sent: Wednesday, February 29, 2012 7:21 AM Subject: Re: RV10-List: A few reflections at 115 hours from a very happy bu ilder. Ditto Ditto Ditto Ditto Ditto.... and that's all I have to say. Don From: Bill Watson <Mauledriver(at)nc.rr.com<mailto:Mauledriver(at)nc.rr.com>> Sent: Wednesday, February 29, 2012 7:53 AM Subject: RV10-List: A few reflections at 115 hours from a very happy builde r. Just a few thoughts that may be of some value. Rudder Trim: Not really needed I've been climbing and cruising at full power. I've been descending at hi gh and low power settings. I've found that the 'natural' friction of the r udder control system will hold the necessary trim in typical calm cruising conditions. The lightest pressure on the right rudder will handle things f or initial climbout. Though I've made provisions for a spring type rudder trim, at this point I don't see any reason to install it. Trimming for roll: The elevator trim tabs have a significant effect on roll trim As we all know or will find out, the elevator trim tab setup is disturbingl y asymmetric in operation. Not a problem, just strange. When doing the fi nal setup, there are some guidelines for how this asymmetry should be handl ed. What I've found is that a few turns of the clevis at one trim tab can have a noticeable effect on roll trim. So if you seem to require the ailer on trim to be set one way or the other, consider a small adjustment of the elevator trim tabs. You can make noticeable changes while still staying wi thin the guidelines for general setup. On a related topic.... Building a 'straight' airframe: This plane just 'snaps' together.... it re ally does (this is a QB statement). There isn't a significant bit of jiggi ng required anywhere to build a straight aircraft.... with one possible exc eption... or maybe it was just me. The one task I initially screwed up was drilling the elevator horns. I screwed it up so badly that a complete rew ork was required with the gracious help of my Tech Counselor. But even wit h the rework and a second chance to get it right, I ever so slightly screwe d it again. That is, my elevators are ever so slightly misaligned. Grrrrr ! I'm living with it now and it's all okay (see "trimming for roll"). But , take time and care with the drilling of the elevator horns! Economy: LOP ops Rock! I'm getting far better economy from the 260HP effi cient '10 than I ever got from my 180HP Maule... in all regimes. No surpri se in retrospect but I just didn't expect it. Long term effects of LOP? I 'm confident it's the best thing I can do to my engine. Time will tell. Overall: For this pilot It's hard to imagine a better 4 place homebuilt cru iser than he '10. Easy and fun to fly, great performance in all respects, roomy, good looking, etc, etc. I don't have that much experience in that many aircraft to make credible comparisons so I'll just leave it at that. One thing it doesn't do well is flying in the convective chop that is comm on on most sunny days. The nose hunts all over the place, especially in y aw. I try not to give rides in the middle of the day or below 4k to 6k on a normal Carolina day. So What! Bill "happily buzzing at 6 months and 115 hours" Watson #40605 MyRV10.com - The RV10 Builders Page<http://www.myrv10.com/> http://www.matronics.com/Navigator?R============= ======== ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Feb 29, 2012
I didn't think rudder trim was necessary but I was talked in to installing it and now I wouldn't be without. Bill, I think you may have explained something strange that happens to me in cruise from time to time. Every now and then, in calm air, straight and level, the plane suddenly yaws to one side pretty significantly. Enough so that I have to re-trim the rudder. It really gets my attention. I assume there is a detectable amount of cross-talk between yaw and roll. That is, yaw puts in a little roll and vice-verse. I have auto-trim on the elevator (which I love) and after reading Bill's note about asymmetric elevator trim, it occurred to me that maybe at some point the auto-trim moves the tabs through zero, from slightly rudder-trimmed for left-roll to completely untrimmed for the new right-roll condition. Maybe I need auto-yaw... --Dave Saylor On Wed, Feb 29, 2012 at 8:47 AM, Robin Marks wrote: > I have to decent from the Rudder Trim observation. I LOVE having my rudder > trim. Maybe because we design a trick one for the 10 & 8A but if you want > the plane perfectly coordinated in most phases of flight (I never bother on > climb out) having an adjustable rudder trim is nice. One note, I included a > position sensor which is indicated on my G900x for the 10. After flying for > a while I figured out we already have a position indicator called the slip > ball. On the 8A I just installed the servo, no position sensor or indicator > needed just center the ball. Duhhh > > > Robin > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald > Sent: Wednesday, February 29, 2012 7:21 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: A few reflections at 115 hours from a very happy > builder. > > > Ditto Ditto Ditto Ditto Ditto.... and that's all I have to say. > > Don > > > From: Bill Watson <Mauledriver(at)nc.rr.com> > To: rv10-list(at)matronics.com > Sent: Wednesday, February 29, 2012 7:53 AM > Subject: RV10-List: A few reflections at 115 hours from a very happy > builder. > > > Just a few thoughts that may be of some value. > > Rudder Trim: Not really needed > I've been climbing and cruising at full power. I've been descending at > high and low power settings. I've found that the 'natural' friction of the > rudder control system will hold the necessary trim in typical calm cruising > conditions. The lightest pressure on the right rudder will handle things > for initial climbout. Though I've made provisions for a spring type rudder > trim, at this point I don't see any reason to install it. > > Trimming for roll: The elevator trim tabs have a significant effect on roll > trim > As we all know or will find out, the elevator trim tab setup is disturbingly > asymmetric in operation. Not a problem, just strange. When doing the final > setup, there are some guidelines for how this asymmetry should be handled. > What I've found is that a few turns of the clevis at one trim tab can have a > noticeable effect on roll trim. So if you seem to require the aileron trim > to be set one way or the other, consider a small adjustment of the elevator > trim tabs. You can make noticeable changes while still staying within the > guidelines for general setup. On a related topic.... > > Building a 'straight' airframe: This plane just 'snaps' together.... it > really does (this is a QB statement). There isn't a significant bit of > jigging required anywhere to build a straight aircraft.... with one possible > exception... or maybe it was just me. The one task I initially screwed up > was drilling the elevator horns. I screwed it up so badly that a complete > rework was required with the gracious help of my Tech Counselor. But even > with the rework and a second chance to get it right, I ever so slightly > screwed it again. That is, my elevators are ever so slightly misaligned. > Grrrrr! I'm living with it now and it's all okay (see "trimming for > roll"). But, take time and care with the drilling of the elevator horns! > > Economy: LOP ops Rock! I'm getting far better economy from the 260HP > efficient '10 than I ever got from my 180HP Maule... in all regimes. No > surprise in retrospect but I just didn't expect it. Long term effects of > LOP? I'm confident it's the best thing I can do to my engine. Time will > tell. > > Overall: For this pilot It's hard to imagine a better 4 place homebuilt > cruiser than he '10. Easy and fun to fly, great performance in all > respects, roomy, good looking, etc, etc. I don't have that much experience > in that many aircraft to make credible comparisons so I'll just leave it at > that. One thing it doesn't do well is flying in the convective chop that > is common on most sunny days. The nose hunts all over the place, > especially in yaw. I try not to give rides in the middle of the day or > below 4k to 6k on a normal Carolina day. > So What! > > Bill "happily buzzing at 6 months and 115 hours" Watson > #40605 > MyRV10.com - The RV10 Builders Page > > http://www.matronics.com/Navigator?R===================== > > > ============== V10-List Email Forum - > :p> /o:p> > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= > bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com > ============== bsp; - List Contribution Web Site - e> > bsp; -Matt Dralle, List Admin. > bution">http://www.matronics.com/contribution ============= > > ________________________________________________________________________________
Vans
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Feb 29, 2012
I have never found a fairing that fits to my liking without laying up mold release then 2-3 layers of glass on the fuselage and gear leg and then setting the prefabbed fairing into it to cure. Pop it off, clean it up, and it'll fit like a glove. I did the same thing on the empannage intersection fairing.... It gives the 'molded on' look.... -Mike Sent from my iPhone On Feb 29, 2012, at 10:16 AM, Bill Watson wrote: > > I guess I should add that it was screwed on with #6 truss heads into those self locking Riv-nuts or whatever they are called. The Riv-nut things remain in place... I forget whether all the screws were still there or not. Seems like the fairing just ripped away. They were the standard Vans part with maybe only one layer of cloth added. > > I would note that the new fairing seems to be of higher quality and I'm thinking of not adding any additional cloth contrary to the directions. Am I setting myself up to lose another? > > On 2/29/2012 8:55 AM, Bill Watson wrote: >> >> Good question. I don't have a clue. One day during preflight, it wasn't there. Wish I knew. >> >> Bill >> >> On 2/29/2012 8:43 AM, bill.peyton wrote: >>> --> RV10-List message posted by: "bill.peyton" >>> >>> Bill, >>> Just out of curiosity, how did the fairing come loose? >>> Bill >>> >>> -------- >>> Bill >>> Aviation Partners, LLC > > > > > ________________________________________________________________________________
Date: Feb 29, 2012
I am using an IO-540 V4A5. It came out of a 2001 Maule. The fuel servo is h orizontal and more forward of the D4A5 if you use an elbow to convert it to horizontal induction. It also rides higher and tighter to the engine. This has been a challenge fitting the cowl and snorkel which require major surg ery and fabrication but I am happy with the results so far. Its not flying yet so I have no idea how my home brew ram air system is going to work. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "JimVillani" <Jim(at)JimVillani.com> Sent: Wednesday, February 29, 2012 11:11:59 AM Subject: RV10-List: RV 10 power plant question... Hey Guys What other versions of the IO 540 have been successfully installed in the 1 0? Has anyone installed versions other than the IO 540 D4A5? If so please advise I am about 6 months out until I need a power plant Thanks!!! Jim Villani Kit# 41084 Jim(at)JimVillani.com == ________________________________________________________________________________
Date: Feb 29, 2012
I agree with Robin, i did not have rudder trim on first flight, but it was the very first thing i added after the 40 hours. The one i have (skunkworks) is less than ideal with a skunky klunky control knob but i got it working good enough. I heard rumors a well known aftermarket supplier is working on their own version, which will undoubtedly be much better than the one i tweaked. My plane is very sensitive to CG and loading. Aileron trim takes care of side to side. The rudder trim was important for forward and aft loading. Fwd and aft sensitivity also varied on speed. I suppose others might get lucky and not have the same issues. In cruise with fwd CG, the ball is ever so slightly left. With mid CG, the ball was always right. With aft CG, the ball was way way right. Now, my rudder trim is mostly always set slightly biased right in cruise, and my right leg can relax. I will tweak it slightly left or right based on loading and speed. Finally, the spring system helps keep the rudder from flopping around so much in winds. You feel like a helpless lamb the first time you watch your poor rudder flopping around with the original system while parked without the rudder secured. I agree about building the plane as true and straight as possible. The truer and straighter the plane is built, means the easier the finishing stage is when the whole plane comes together. Later on, it means the easier the maintenance is when you continue to take things off and on and off and on, etc. This is the long-term reward for scrapping something or redoing it until it is just right. Finally, about wind, we get a fair amount of wind on the coast. No plane is immune to the effects of wind. However, I think the -10 does pretty good compared to most of the Cessnas at least. I hear them giving pireps to each other to stay away, which is amusing because I am happy as a clam. We wont do as well as a Lanciar or Cirrus, but we don't have to land at 120knots either! Jae -------- #40533 RV-10 First flight 10/19/2011 Phase 1 Done 11/26/2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367541#367541 ________________________________________________________________________________
Date: Feb 29, 2012
Wow, that would be an interesting situation if true. I too have auto-trim (LOVE IT) but haven't noticed the same thing. Of course, I usually have a toe or two on the rudders and would probably catch it without noticing. Will keep an eye out for it. On 2/29/2012 12:21 PM, Dave Saylor wrote: > --> RV10-List message posted by: Dave Saylor > > I didn't think rudder trim was necessary but I was talked in to > installing it and now I wouldn't be without. > > Bill, I think you may have explained something strange that happens to > me in cruise from time to time. Every now and then, in calm air, > straight and level, the plane suddenly yaws to one side pretty > significantly. Enough so that I have to re-trim the rudder. It > really gets my attention. > > I assume there is a detectable amount of cross-talk between yaw and > roll. That is, yaw puts in a little roll and vice-verse. > > I have auto-trim on the elevator (which I love) and after reading > Bill's note about asymmetric elevator trim, it occurred to me that > maybe at some point the auto-trim moves the tabs through zero, from > slightly rudder-trimmed for left-roll to completely untrimmed for the > new right-roll condition. > > Maybe I need auto-yaw... > > --Dave Saylor > > ________________________________________________________________________________
Date: Feb 29, 2012
Well, I still have an almost complete homegrown trim system that I can install but for now, it will have a hard time making the priority squawk list. The slip ball indeed....ha ha! How far we've come. Bill On 2/29/2012 11:47 AM, Robin Marks wrote: > > I have to decent from the Rudder Trim observation. I LOVE having my > rudder trim. Maybe because we design a trick one for the 10 & 8A but > if you want the plane perfectly coordinated in most phases of flight > (I never bother on climb out) having an adjustable rudder trim is > nice. One note, I included a position sensor which is indicated on my > G900x for the 10. After flying for a while I figured out we already > have a position indicator called the slip ball. On the 8A I just > installed the servo, no position sensor or indicator needed just > center the ball. Duhhh > > Robin > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Don McDonald > *Sent:* Wednesday, February 29, 2012 7:21 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: A few reflections at 115 hours from a very > happy builder. > > Ditto Ditto Ditto Ditto Ditto.... and that's all I have to say. > > Don > > *From:*Bill Watson > > *To:* rv10-list(at)matronics.com > *Sent:* Wednesday, February 29, 2012 7:53 AM > *Subject:* RV10-List: A few reflections at 115 hours from a very happy > builder. > > Just a few thoughts that may be of some value. > > Rudder Trim: Not really needed > I've been climbing and cruising at full power. I've been descending > at high and low power settings. I've found that the 'natural' > friction of the rudder control system will hold the necessary trim in > typical calm cruising conditions. The lightest pressure on the right > rudder will handle things for initial climbout. Though I've made > provisions for a spring type rudder trim, at this point I don't see > any reason to install it. > > Trimming for roll: The elevator trim tabs have a significant effect on > roll trim > As we all know or will find out, the elevator trim tab setup is > disturbingly asymmetric in operation. Not a problem, just strange. > When doing the final setup, there are some guidelines for how this > asymmetry should be handled. What I've found is that a few turns of > the clevis at one trim tab can have a noticeable effect on roll trim. > So if you seem to require the aileron trim to be set one way or the > other, consider a small adjustment of the elevator trim tabs. You can > make noticeable changes while still staying within the guidelines for > general setup. On a related topic.... > > Building a 'straight' airframe: This plane just 'snaps' together.... > it really does (this is a QB statement). There isn't a significant > bit of jigging required anywhere to build a straight aircraft.... with > one possible exception... or maybe it was just me. The one task I > initially screwed up was drilling the elevator horns. I screwed it up > so badly that a complete rework was required with the gracious help of > my Tech Counselor. But even with the rework and a second chance to > get it right, I ever so slightly screwed it again. That is, my > elevators are ever so slightly misaligned. Grrrrr! I'm living with > it now and it's all okay (see "trimming for roll"). But, take time > and care with the drilling of the elevator horns! > > Economy: LOP ops Rock! I'm getting far better economy from the 260HP > efficient '10 than I ever got from my 180HP Maule... in all regimes. > No surprise in retrospect but I just didn't expect it. Long term > effects of LOP? I'm confident it's the best thing I can do to my > engine. Time will tell. > > Overall: For this pilot It's hard to imagine a better 4 place > homebuilt cruiser than he '10. Easy and fun to fly, great > performance in all respects, roomy, good looking, etc, etc. I don't > have that much experience in that many aircraft to make credible > comparisons so I'll just leave it at that. One thing it doesn't do > well is flying in the convective chop that is common on most sunny > days. The nose hunts all over the place, especially in yaw. I try > not to give rides in the middle of the day or below 4k to 6k on a > normal Carolina day. > So What! > > Bill "happily buzzing at 6 months and 115 hours" Watson > #40605 > MyRV10.com - The RV10 Builders Page <http://www.myrv10.com/> > > *http://www.matronics.com/Navigator?R======================* > * * > > * * > * * > ==============V10-List Email Forum -> :p> /o:p> > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List==============bsp; > - MATRONICS WEB FORUMS -:p> > tp://forums.matronics.com==============bsp; - List Contribution Web > Site -e> bsp; -Matt Dralle, List > Admin.bution">http://www.matronics.com/contribution============= > * * > * > > > * ________________________________________________________________________________
Date: Feb 29, 2012
Vans Thanks for that chunk of technique! That's what I'll be doing on this new one. On 2/29/2012 12:24 PM, Michael Kraus wrote: > --> RV10-List message posted by: Michael Kraus > > I have never found a fairing that fits to my liking without laying up mold release then 2-3 layers of glass on the fuselage and gear leg and then setting the prefabbed fairing into it to cure. Pop it off, clean it up, and it'll fit like a glove. I did the same thing on the empannage intersection fairing.... It gives the 'molded on' look.... > > -Mike > ________________________________________________________________________________
Subject: Re: Antenna locations
Date: Feb 29, 2012
True, a matched signal splitter will knock your signal strength down by a factor of two. But it also will knock down any external noise coming down the coax by a factor of two as well. What counts is the signal to noise ratio - the receivers always have plenty of gain. If you have a good receiver which generates little internal noise, then the splitter doesn't hurt at all - just turn up the volume. If your background noise is dominated by noise generated by the electronics of the receiver itself, then you lose the 2x. So the answer is, "it depends". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367548#367548 ________________________________________________________________________________
Date: Feb 29, 2012
I got an O-540-E4B5 from a Cherokee 6-260 and added AFP fuel injection. fit perfectly without any modifications and used van=99s baffle kit. Bob Newman N541RV From: JimVillani Sent: Wednesday, February 29, 2012 11:11 AM Subject: RV10-List: RV 10 power plant question... Hey Guys What other versions of the IO 540 have been successfully installed in the 10? Has anyone installed versions other than the IO 540 D4A5? If so please advise I am about 6 months out until I need a power plant Thanks!!! Jim Villani Kit# 41084 Jim(at)JimVillani.com ________________________________________________________________________________
Date: Feb 29, 2012
Bob, You have it incorrect. The signal to noise ratio is just that. More gain at the antenna given the same amount of internally generated receiver noise will yield a higher S/N ratio through the entire system. Cutting the gain of the antenna also cuts out externally received, (through the antenna) noise, the the S/N is unchanged due to the fact that you not only decreased the wanted signal, but decreased the unwanted signal at the same time. As long as the noise comes in prior to the radio's antenna connector, inserting a splitter does just that. It decreases the signal AND the noise by the same exact amount. I will agree that for the most part, especially when using an externally mounted antenna, such as a cat wiskers, you have plenty of signal to split between two VOR receivers. The issue that the Archer antennas present is, they do not have the gain nor are they mounted in an optimum location on the aircraft. In addition, with the Archer antenna, you do not have an omnidirectional pattern due to the mounting location. So having one antenna in each wing tip, connected to separate receivers is good insurance. So in this instance, maximizing the signal coming down the coax is a good idea. Bill -------- Bill Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367557#367557 ________________________________________________________________________________
Date: Feb 29, 2012
Mike, do you have any photos of the process and the result? It sounds like a great idea Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367558#367558 ________________________________________________________________________________
Date: Feb 29, 2012
I have an IO-540-N1A5. 260hp Sent from my iPhone On Feb 29, 2012, at 9:11, "JimVillani" wrote: > Hey Guys > > What other versions of the IO 540 have been successfully installed in the 1 0? > Has anyone installed versions other than the IO 540 D4A5? > If so please advise > I am about 6 months out until I need a power plant > Thanks!!! > > Jim Villani > Kit# 41084 > Jim(at)JimVillani.com > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 29, 2012
Dave, I just purchased the AeoLed Suntail.- It is a awesome little light. - I think it is quite expensive though.- It took me a long time to talk myself into buying it.- I haven't installed it yet though, except to try it out with a battery.- Great company to deal with too. Rick #40956 Southampton, Ont --- On Wed, 2/29/12, David Leikam wrote: From: David Leikam <arplnplt(at)gmail.com> Subject: RV10-List: LED tail light strobe Received: Wednesday, February 29, 2012, 5:32 AM Does anyone know a good source to purchase an LED tail light strobe combo t o replace my Whelen?- I found a couple but they are out of stock. Also, does anyone have experience with clear wing walk tape?- Does it dis color? Thx. Dave Leikam le, List Admin. ________________________________________________________________________________
Subject: Windscreen Gap
Date: Feb 29, 2012
Hi Guys, I'm getting ready to Bond the Windscreen in but I am worried about how to close a Gap that is between the Glare Shield and the Windscreen. On the Starboard side it's worse than the Port side see the attached Photo. cheers John MacCallum 41016 VH-DUU Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367577#367577 Attachments: http://forums.matronics.com//files/img_2035_176.jpg ________________________________________________________________________________
Date: Feb 29, 2012
Subject: Fitting Fairing to the Fuselage, how I do it......
Here is a better description of how I fit my fairings..... Can be used for the gear leg to fuse, gear leg to wheel pant, or rear empennage intersection fairing. * Rough cut and dry fit up fairing to airplane. Drill #30 holes in locations where screws will eventually hold fairing to fuselage. When satisfied with the fit, draw a marker line on the fuselage around perimeter of fairing. Remove fairing. * Use mold release (I use the car wax stuff from Aircraft Spruce) and wipe it all over the fuselage about 2-4=B2 or more around both sides of the line you drew. DO NOT FORGET TO DO THIS STEP OR YOU WILL VERY UNHAPPY!! * Scuff up inside of fairing with 36-40 grit sandpaper on all surfaces wher e they will come into contact with the fuselage. * Clean fairings real good with acetone or similar to remove any dust/dirt/residue/mold release, etc * Work on one side of one fairing at a time (for instance, if you are working on the upper fuselage to gear leg intersection fairing, work on the fuselage to fairing interface first. Second time around work on the fairin g to gear leg interface). Lay up 2-3 layers of approximately 9 oz cloth on the fuselage over the line drawn in step 1. * Mix up flox and epoxy to a peanut butter consistency and apply about 1/16=B2-1/8=B2 onto the fairing surface that mates to the fuselage. This will help fill any gaps that may be present due to poorly formed fairings. * Mash the fairing onto the fuselage in position. Use cleco=B9s/clamps/screws/whatever you desire to hold it in place exactly where you want it until dry. * * Once dry, use compressed air to blow it free from the fuselage. Its amazing how well the compressed air works. Just get a little spot to break free, then blow air in the spot and the whole thing will pop off pretty easily. * Clean the fuselage up with a plastic scraper and acetone and clean real well. * Trim the fairing edge as desired to get a smooth edge. * * Repeat the process for the other side of the same fairing. For this example, that would be the upper gear leg to fairing surface (or the lower line as described above). DON=B9T FORGET THE MOLD RELEASE ON THE SURFACE YOU DON=B9T WANT IT BONDED TOO! * * Once complete, fill and sand, and fill, and sand, and fill, and sand unti l it is smooth to your satisfaction. For the rear empannage intersection fairing, I followed the same process, but layed up the HS to fairing surface first, then the VS to fairing surfac e second. I hope this is not too confusing. It is actually quite easy, just takes time.....especially in the Michigan winters when even fast drying epoxy takes 2 days to cure! -Mike Kraus RV-4 Flying and Sold RV-10 Flying ________________________________________________________________________________
Subject: Re: Windscreen Gap
Date: Feb 29, 2012
Get it down as tight as you can, then fill the gap with flox and epoxy slurry mixed to a peanut butter consistency then immediately start your Lay-up. -Mike Kraus Sent from my iPhone On Feb 29, 2012, at 10:10 PM, "maca2790" wrote: > > Hi Guys, > I'm getting ready to Bond the Windscreen in but I am worried about how to close a Gap that is between the Glare Shield and the Windscreen. > > On the Starboard side it's worse than the Port side see the attached Photo. > > cheers > > John MacCallum > 41016 > VH-DUU > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367577#367577 > > > > > Attachments: > > http://forums.matronics.com//files/img_2035_176.jpg > > > > > > > ________________________________________________________________________________
Date: Feb 29, 2012
You may also wish to mix a black pigment into the resin so the fabric doesn 't stand out so much while viewing from inside the plane. > Subject: Re: RV10-List: Windscreen Gap > From: n223rv(at)wolflakeairport.net > Date: Wed=2C 29 Feb 2012 22:38:28 -0500 > To: rv10-list(at)matronics.com > t> > > Get it down as tight as you can=2C then fill the gap with flox and epoxy slurry mixed to a peanut butter consistency then immediately start your Lay -up. > > -Mike Kraus > Sent from my iPhone > > On Feb 29=2C 2012=2C at 10:10 PM=2C "maca2790" wrote: > > > > > Hi Guys=2C > > I'm getting ready to Bond the Windscreen in but I am worried about how to close a Gap that is between the Glare Shield and the Windscreen. > > > > On the Starboard side it's worse than the Port side see the attached Ph oto. > > > > cheers > > > > John MacCallum > > 41016 > > VH-DUU > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=367577#367577 > > > > > > > > > > Attachments: > > > > http://forums.matronics.com//files/img_2035_176.jpg > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Feb 29, 2012
Bill, I think we both said the same thing about S/N ratios... You left out another small advantage of 2 wing tip antennas, over one split 2 ways: given the cost of splitters, 2 antennas may be cheaper than 1+splitter! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367583#367583 ________________________________________________________________________________
Date: Mar 01, 2012
Good point, I used black epoxy dye in all the resin used around all the wind ows, including the flox. Sent from my iPhone On Feb 29, 2012, at 11:44 PM, John Gonzalez wrote: > You may also wish to mix a black pigment into the resin so the fabric does n't stand out so much while viewing from inside the plane. > > > Subject: Re: RV10-List: Windscreen Gap > > From: n223rv(at)wolflakeairport.net > > Date: Wed, 29 Feb 2012 22:38:28 -0500 > > To: rv10-list(at)matronics.com > > et> > > > > Get it down as tight as you can, then fill the gap with flox and epoxy s lurry mixed to a peanut butter consistency then immediately start your Lay-u p. > > > > -Mike Kraus > > Sent from my iPhone > > > > On Feb 29, 2012, at 10:10 PM, "maca2790" wro te: > > > > > > > > > Hi Guys, > > > I'm getting ready to Bond the Windscreen in but I am worried about how to close a Gap that is between the Glare Shield and the Windscreen. > > > > > > On the Starboard side it's worse than the Port side see the attached P hoto. > > > > > > cheers > > > > > > John MacCallum > > > 41016 > > > VH-DUU > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=367577#367577 > > > > > > > > > > > > > > > Attachments: > > > > > > http://forums.matronics.com//files/img_2035_176.jpg > > > > > > > > > > > > > > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Mar 01, 2012
On the narrow gap between the bottom of the windscreen and fuselage itself, f ill with micro balloons. This is not a structural issue. Sand to make a ni ce fillet to overlay the cloth. I used carbon fiber and standard West epoxy for the bottom windscreen fairin g instead of fiberglass. It looks nice from the inside and I find for appli cations such as this it is easier to work with. Make sure you rough up the g lass and fuselage bond areas with 30 or so grit paper. I used a bunch of c heap Harbor Freight black electrical tape to mask off the glass and fuselage . A couple of layers and it provides a nice sanding shield for your finish m icro balloon sanding. Carl On Feb 29, 2012, at 11:44 PM, John Gonzalez wrote: > You may also wish to mix a black pigment into the resin so the fabric does n't stand out so much while viewing from inside the plane. > > > Subject: Re: RV10-List: Windscreen Gap > > From: n223rv(at)wolflakeairport.net > > Date: Wed, 29 Feb 2012 22:38:28 -0500 > > To: rv10-list(at)matronics.com > > et> > > > > Get it down as tight as you can, then fill the gap with flox and epoxy s lurry mixed to a peanut butter consistency then immediately start your Lay-u p. > > > > -Mike Kraus > > Sent from my iPhone > > > > On Feb 29, 2012, at 10:10 PM, "maca2790" wro te: > > > > > > > > > Hi Guys, > > > I'm getting ready to Bond the Windscreen in but I am worried about how to close a Gap that is between the Glare Shield and the Windscreen. > > > > > > On the Starboard side it's worse than the Port side see the attached P hoto. > > > > > > cheers > > > > > > John MacCallum > > > 41016 > > > VH-DUU > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=367577#367577 > > > > > > > > > > > > > > > Attachments: > > > > > > http://forums.matronics.com//files/img_2035_176.jpg > > > > > > > > > > > > > > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 01, 2012
Good point Bob. The Archer antennas are a bargain compared to the signal splitters. Having said all this, I still ran a spare coax back to the tail in case the Archer's don't work out as planned! -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367592#367592 ________________________________________________________________________________
Date: Mar 01, 2012
Thanks for the input everyone! Although I think I now have more questions than when I started, I've decided to not decide, but provision for different possibilities while the VS is still open... mostly with conduit runs and using nutplates for the tips like Kelly suggested. Ed On Tue, Feb 28, 2012 at 4:16 PM, Carl Froehlich wrote: > I did modify the design slightly when I made the antenna (a few pieces of > scrap aluminum, some hardware and a piece of bakelite or fiberglass to make > the gama match). I did a hard mount (piece of .032 angle) to the outboard > wing rib such that the antenna stays on the plane when you pull the wing > tip off. This solves the grounding issues. I also extended the piece that > angles away from the rib such that the piece that runs parallel to the rib > is tucked all the way into the outboard edge of the wingtip. This is a > quarter wavelength antenna - which means the part that does most of the > work (the high current part) is close to the base. The end of the antenna > (the high voltage part) provides the electrical length to resonate the > antenna at the desired frequency. This is why bent whip antennas work as > well as they do. The part near the base is mostly vertical (communications > are vertically polarized, VORs are horizontally polarized). I use the one > antenna for both VOR and GS reception. > > As with all antennas, the performance is only as good as the tuning. I > used an MFJ antenna analyzer to adjust the gama match and the overall > length to resonance. Most amateur radio operators have one of these > analyzers and for a quick hop will most likely just make the antenna for > you. > > Someplace I have an old AeroElectric book that provides details for the > antenna. > > Carl > > > On Feb 28, 2012, at 3:59 PM, Bob Condrey wrote: > > Kelly, > > I don't think he changed the design, it's more that the performance is > extremely sensitive to installation. Grounding using the wingtip attach > nutplates (not a wire or strap), routing of other wiring along the edge, > etc. In fact, I exchanged emails with Bob A. when I did my install in the > first -10. I was concerned about the heat protective foil from the halogen > landing light kit - he said to make the antenna as close as possible to the > foil without touching it. I had one of his antennas in each wingtip (and a > GS antenna along with it in one tip) and they worked great. I'd routinely > see 50+ miles when I was actually checking distance. I've also heard of > really poor performance but without seeing the install hard to say why. > FWIW, he will readily admit that his wingtip comm antenna is a poor > performer because of the signal polarization. > > Bob > > On Tue, Feb 28, 2012 at 3:22 PM, Kelly McMullen wrote: > >> >> I don't think finishing the vertical stab is the time to decide on that >> antenna. I just closed off the fiberglass tip with Clickbond #4 nutplates >> and #4 flush screws instead of rivets, so I can get in there if I ever >> decide I want something there. Yes, it adds about $20 to overall cost, but >> to me that is easier than having to drill out rivets if the need arises. >> *I'd be interested in what changes were made to the Bob Archer design to >> improve the range. If 40+ mile range is possible,* I'd much rather have >> antenna in wingtip. OTOH, on other planes I have gotten 100+ mile range at >> 10K cruising alt on H class VORs. >> >> * > > ================================== > ://www.matronics.com/Navigator?RV10-List > > ===================================cs.com > ===================================matronics.com/contribution > ================================== > > * > > * > > > * > > ________________________________________________________________________________
Date: Mar 01, 2012
I also started with a large gap such as you have. I was able to narrow it down a bit by some additional sanding at the front. I still ended up with an 1/8 on the right side. I mixed up a peanut butter consistency of West 404 and 105 epoxy structural filler to fill the gap. The issue you have with leaving the gap is when you finish the side for paint, you will end up with a bulge. Be sure to paint the area directly under the window with whatever color you are going to end up with on the dash, it is easy to do prior and hard to do after. If you are going to use textile on the dash, paint the color of the material around the edges where the plexi meets the metal. You might also consider painting a mask on the INSIDE of the plexi around the entire perimeter. This will hide any gaps or bad areas of glass seen from the inside. Also be sure you add black dye to the epoxy. You can obtain this from West Marine. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367595#367595 ________________________________________________________________________________
Date: Mar 01, 2012
arplnplt(at)gmail.com wrote: > Does anyone know a good source to purchase an LED tail light strobe combo to replace my Whelen? I found a couple but they are out of stock. > Also, does anyone have experience with clear wing walk tape? Does it discolor? > Thx. > > Dave Leikam I used Kuntzleman lights. No problems. As far as the clear wing walk, I bought some from Aircraft Spruce. Put it on one wing and absolutely hated it. Thankfully, it came off without damaging the paint. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367598#367598 ________________________________________________________________________________
Date: Mar 01, 2012
I went with a metal fairing instead. Got it from M.L. Skunk Works. Here is his site: http://www.mlblueskunk.com/Windscreen_Fairings.html John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367599#367599 ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 02, 2012
"I used carbon fiber and standard West epoxy for the bottom windscreen fairing instead of fiberglass." I thought I read somewhere that you should not use carbon fiber cloth in direct contact with aluminum because it promotes corrosion. Not sure if this is a tale or based in fact - but probably worth further research. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367629#367629 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Corrosion - was Windscreen Gap
Date: Mar 02, 2012
Yep - the warning is to avoid aluminum contact with finished carbon on fittings and such. This typically (as I understand it) is transitioning carbon tubing to an aluminum fitting. In this case you have the condition of moisture trapped between the two dissimilar but conductive materials, creating the corrosion potential. In my application carbon fiber and epoxy where applied to the aluminum skin in assembly. This eliminates the issue. Expanding the topic, this highlights the typical corrosion issues in our planes. Mainly steal bolts in aluminum holes (e.g. spar bolts) and steel gear legs in steel gear leg mounts. I use a liberal amount of white grease for all such metal to metal contact. Some may recall when Van's did the SB on the two seat tri-gear RVs to modify the front gear leg. Many needed a torch to get the gear leg out of the mount because of corrosion. On my 8A the leg slipped right out - 8 years after install. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Friday, March 02, 2012 8:19 AM Subject: RV10-List: Re: Windscreen Gap "I used carbon fiber and standard West epoxy for the bottom windscreen fairing instead of fiberglass." I thought I read somewhere that you should not use carbon fiber cloth in direct contact with aluminum because it promotes corrosion. Not sure if this is a tale or based in fact - but probably worth further research. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367629#367629 ________________________________________________________________________________
Date: Mar 02, 2012
It is a fact. The material has both advantages and clear disadvantages. Fasteners are usually the first to fail. Search out the " Nobility" table of materials. John #40600. On Mar 2, 2012 5:26 AM, "jkreidler" wrote: > jason.kreidler(at)regalbeloit.com> > > "I used carbon fiber and standard West epoxy for the bottom windscreen > fairing instead of fiberglass." > > I thought I read somewhere that you should not use carbon fiber cloth in > direct contact with aluminum because it promotes corrosion. Not sure if > this is a tale or based in fact - but probably worth further research. > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=367629#367629 > > ________________________________________________________________________________
Date: Mar 02, 2012
The different conductivity of aluminum vs. carbon is increased by using the aluminum as the aircraft voltage ground return path. The carbon can retain moisture. Adhesives of carbon to aluminum and carbon to other fibers set off the difference - Nobility Table. One technique is a cloth boundary between the two dissimilar materials. Then all the electron flow is through the fasteners. Carbon, Kevlar, combinations bring a higher level of sophistication that "Good old E glass or S glass" against aluminum alclad. Research the FAA AC pubs on Inspection Techniques for various forms of corrosion. Research builders of plastic aircraft for the challenges such as the carbon cub, Lancair Evolution, Legacy or comparable builds. All decisions carry risk. Weigh them and fly safe. John On Fri, Mar 2, 2012 at 8:31 AM, John Cox wrote: > It is a fact. The material has both advantages and clear disadvantages. > Fasteners are usually the first to fail. > > Search out the " Nobility" table of materials. > > John #40600. > On Mar 2, 2012 5:26 AM, "jkreidler" > wrote: > >> jason.kreidler(at)regalbeloit.com> >> >> "I used carbon fiber and standard West epoxy for the bottom windscreen >> fairing instead of fiberglass." >> >> I thought I read somewhere that you should not use carbon fiber cloth in >> direct contact with aluminum because it promotes corrosion. Not sure if >> this is a tale or based in fact - but probably worth further research. >> >> -------- >> Jason Kreidler >> 4 Partner Build - Sheboygan Falls, WI >> Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler >> N44YH - Flying - #40617 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=367629#367629 >> >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Mar 02, 2012
From: "egodfrey(at)ameritech.net" <egodfrey(at)ameritech.net>
Subject: Cee Baileys windows
For those of you who have ordered the Cee Baileys windows, what level of tint did you order that would match the windscreen. They have the clear, light gray and light green. I have called them and they did not know and said that they would get back to me. Am still waiting. Ed Godfrey 40717 ________________________________________________________________________________
Subject: Re: Cee Baileys windows
Date: Mar 02, 2012
Get the clear. You will be very happy you went with the Cee baileys versus the Vans. The one I got was plug n play I needed to make some minor adjustments that took all of 30 minutes, but truthfully I could have installed it without touching a thing. I had the Vans initially and it took me hours to get it right, than to discover there is a bulge on the copilot seat. Actually night an day comparison. I did not install the sides but I hear they are plug n play as well. Pascal -----Original Message----- From: egodfrey(at)ameritech.net Sent: Friday, March 02, 2012 12:10 PM Subject: RV10-List: Cee Baileys windows For those of you who have ordered the Cee Baileys windows, what level of tint did you order that would match the windscreen. They have the clear, light gray and light green. I have called them and they did not know and said that they would get back to me. Am still waiting. Ed Godfrey 40717 ________________________________________________________________________________
Date: Mar 02, 2012
Subject: Did I wreck my rudder skin?
After final drilling my rudder skin, I got to the step about putting a slight bend in the rudder skin at the trailing edge. I bought the Cleaveland Tools edge forming tool for just these situations. Well, I managed to mangle the edge by using too much pressure and going too fast... and it seems to have stretched the skin a bit. After the debacle with the first skin, I went light an slow on the second skin and the edge came out perfectly. I went over the first skin the opposite way to take some of the bad bends out, then made a bend in the correct direction to smooth it as much as possible, but the edge is pretty wavy. I was sure the skin was junk, but I figured I'd cleco it up with the good skin and wedge to see how it lays... and it doesn't look too bad. I'm leaning towards attempting to use the skin, but what do you all think? I'm attaching a pic of the bad skin, the good skin, and the two jointed together. ________________________________________________________________________________
Date: Mar 02, 2012
As long as the trailing edge is straight, I would build on. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ed Kranz Sent: Friday, March 02, 2012 4:39 PM Subject: RV10-List: Did I wreck my rudder skin? After final drilling my rudder skin, I got to the step about putting a slight bend in the rudder skin at the trailing edge. I bought the Cleaveland Tools edge forming tool for just these situations. Well, I managed to mangle the edge by using too much pressure and going too fast... and it seems to have stretched the skin a bit. After the debacle with the first skin, I went light an slow on the second skin and the edge came out perfectly. I went over the first skin the opposite way to take some of the bad bends out, then made a bend in the correct direction to smooth it as much as possible, but the edge is pretty wavy. I was sure the skin was junk, but I figured I'd cleco it up with the good skin and wedge to see how it lays... and it doesn't look too bad. I'm leaning towards attempting to use the skin, but what do you all think? I'm attaching a pic of the bad skin, the good skin, and the two jointed together. ________________________________________________________________________________
Date: Mar 02, 2012
True, but if the carbon is encased in epoxy, there shouldn't be an issue. bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Friday, March 02, 2012 8:19 AM Subject: RV10-List: Re: Windscreen Gap --> "I used carbon fiber and standard West epoxy for the bottom windscreen fairing instead of fiberglass." I thought I read somewhere that you should not use carbon fiber cloth in direct contact with aluminum because it promotes corrosion. Not sure if this is a tale or based in fact - but probably worth further research. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367629#367629 ________________________________________________________________________________
Date: Mar 02, 2012
I agree. If I remember right, you proseal it anyway. Did you create a riveting plate to do the trailing edge? If so, that will help keep it straight.. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Friday, March 02, 2012 3:15 PM Subject: RE: RV10-List: Did I wreck my rudder skin? As long as the trailing edge is straight, I would build on. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ed Kranz Sent: Friday, March 02, 2012 4:39 PM Subject: RV10-List: Did I wreck my rudder skin? After final drilling my rudder skin, I got to the step about putting a slight bend in the rudder skin at the trailing edge. I bought the Cleaveland Tools edge forming tool for just these situations. Well, I managed to mangle the edge by using too much pressure and going too fast... and it seems to have stretched the skin a bit. After the debacle with the first skin, I went light an slow on the second skin and the edge came out perfectly. I went over the first skin the opposite way to take some of the bad bends out, then made a bend in the correct direction to smooth it as much as possible, but the edge is pretty wavy. I was sure the skin was junk, but I figured I'd cleco it up with the good skin and wedge to see how it lays... and it doesn't look too bad. I'm leaning towards attempting to use the skin, but what do you all think? I'm attaching a pic of the bad skin, the good skin, and the two jointed together. ________________________________________________________________________________
Date: Mar 02, 2012
Subject: Re: Did I wreck my rudder skin?
I'm going to use the angle-iron method, cleco every hole, and use the clothespin trick that I've seen a few builders use to stop pillowing between rivets while the pro-seal sets (especially important to me now that the one edge is a little stretched...) On Fri, Mar 2, 2012 at 4:41 PM, Rene Felker wrote: > I agree. If I remember right, you proseal it anyway.**** > > ** ** > > Did you create a riveting plate to do the trailing edge? If so, that wil l > help keep it straight=85=85**** > > ** ** > > Rene' Felker**** > > N423CF**** > > 801-721-6080**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler > *Sent:* Friday, March 02, 2012 3:15 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Did I wreck my rudder skin?**** > > ** ** > > As long as the trailing edge is straight, I would build on.**** > > ** ** > > bob**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Ed Kranz > *Sent:* Friday, March 02, 2012 4:39 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Did I wreck my rudder skin?**** > > ** ** > > After final drilling my rudder skin, I got to the step about putting a > slight bend in the rudder skin at the trailing edge. I bought the > Cleaveland Tools edge forming tool for just these situations. Well, I > managed to mangle the edge by using too much pressure and going too fast. .. > and it seems to have stretched the skin a bit.**** > > ** ** > > After the debacle with the first skin, I went light an slow on the second > skin and the edge came out perfectly. **** > > ** ** > > I went over the first skin the opposite way to take some of the bad bends > out, then made a bend in the correct direction to smooth it as much as > possible, but the edge is pretty wavy. I was sure the skin was junk, but I > figured I'd cleco it up with the good skin and wedge to see how it lays.. . > and it doesn't look too bad.**** > > ** ** > > I'm leaning towards attempting to use the skin, but what do you all think ? > **** > > ** ** > > I'm attaching a pic of the bad skin, the good skin, and the two jointed > together.**** > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Mar 02, 2012
It'll probably turn out ok, but it's hard to say for sure. You are definitely putting way too much of a bend in the skin edge. You just want to break the edge a very slight amount. Almost where you can't see the bend line. You just need an ever so slight bend and you'll be fine. -Mike Kraus Sent from my iPhone On Mar 2, 2012, at 4:39 PM, Ed Kranz wrote: > After final drilling my rudder skin, I got to the step about putting a slight bend in the rudder skin at the trailing edge. I bought the Cleaveland Tools edge forming tool for just these situations. Well, I managed to mangle the edge by using too much pressure and going too fast... and it seems to have stretched the skin a bit. > > After the debacle with the first skin, I went light an slow on the second skin and the edge came out perfectly. > > I went over the first skin the opposite way to take some of the bad bends out, then made a bend in the correct direction to smooth it as much as possible, but the edge is pretty wavy. I was sure the skin was junk, but I figured I'd cleco it up with the good skin and wedge to see how it lays... and it doesn't look too bad. > > I'm leaning towards attempting to use the skin, but what do you all think? > > I'm attaching a pic of the bad skin, the good skin, and the two jointed together. > > > ________________________________________________________________________________
Date: Mar 02, 2012
Hey Ed, What the others are saying. The pictures look like it pulls together very well. Keep in mind that more than likely you are going to paint your plane. We thought we had done a pretty good job on the rudder until we got much further along in the build and cringed when we looked back at our first stage of building. So before priming/painting, I simply went back over the rudder and filled any dings with epoxy/micro beads, sanded it flush, and after priming/paint, it looks perfect. For those who are proud of their rivet work, or want to be judged for best of show =93 don=99t fill your rivets. I kind of like the =9Cplastic plane=9D slick look, so I filled all the rivets in/around all leading edges, and most in the tail section. No problems 2.5 yrs. out. Later, =93 Lew From: Ed Kranz Sent: Friday, March 02, 2012 4:39 PM Subject: RV10-List: Did I wreck my rudder skin? After final drilling my rudder skin, I got to the step about putting a slight bend in the rudder skin at the trailing edge. I bought the Cleaveland Tools edge forming tool for just these situations. Well, I managed to mangle the edge by using too much pressure and going too fast... and it seems to have stretched the skin a bit. After the debacle with the first skin, I went light an slow on the second skin and the edge came out perfectly. I went over the first skin the opposite way to take some of the bad bends out, then made a bend in the correct direction to smooth it as much as possible, but the edge is pretty wavy. I was sure the skin was junk, but I figured I'd cleco it up with the good skin and wedge to see how it lays... and it doesn't look too bad. I'm leaning towards attempting to use the skin, but what do you all think? I'm attaching a pic of the bad skin, the good skin, and the two jointed together. ________________________________________________________________________________
Date: Mar 03, 2012
Ed, You'll be fine. Build on! John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367674#367674 ________________________________________________________________________________
Subject: Re: New Gust Lock
Date: Mar 03, 2012
Robin, nice design, is this something your planning to sell? I am getting ready for Sun-N-Fun and need a new gust lock. Ours was lost last year during the tornado. By the way, we do have crotch belts in the front seats. We ran cables from two bolts on the back of the seat (kind of made a Y) so the belt moves back and forth with the seat. Bad explanation, no pics sorry - but it is possible and I really like having the belt there to keep the lap belt positioned correctly down low across the hips. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367701#367701 ________________________________________________________________________________
Date: Mar 04, 2012
Jason. Not trying to sell just share with the community. It works extremely well but one has to be willing to add the stick tab. The tab has been a non issue since install and the lock is rock solid. Good luck, Robin Sent from my Galaxy Nexus jkreidler wrote: Robin, nice design, is this something your planning to sell? I am getting ready for Sun-N-Fun and need a new gust lock. Ours was lost last year during the tornado. By the way, we do have crotch belts in the front seats. We ran cables from two bolts on the back of the seat (kind of made a Y) so the belt moves back and forth with the seat. Bad explanation, no pics sorry - but it is possible and I really like having the belt there to keep the lap belt positioned correctly down low across the hips. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367701#367701 ________________________________________________________________________________
Date: Mar 03, 2012
Thanks Robin - I was looking for the easy way out! :) -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367704#367704 ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: A little press coverage
Date: Mar 06, 2012
Just the local-yokel paper, but hey, it was on the front page! http://www.wickedlocal.com/hingham/topstories/x565046221/Hingham-pilots-sup port-Fisher-House-program#axzz1oIyuQZPZ Tim D-T N52KS ________________________________________________________________________________
Subject: Lightsquared
Date: Mar 06, 2012
I read in my Farm-press magazine yesterday that the FCC has revoked light-squared permission to pursue there 4g attempt because they could not do it with out interference. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367846#367846 ________________________________________________________________________________
Subject: Re: A little press coverage
Date: Mar 06, 2012
Great article. Promotes aviation awareness and the Fisher House! ----- Original Message ----- From: Dawson-Townsend,Timothy To: RV10-List Digest Server Sent: Tuesday, March 06, 2012 6:50 AM Subject: RV10-List: A little press coverage Just the local-yokel paper, but hey, it was on the front page! http://www.wickedlocal.com/hingham/topstories/x565046221/Hingham-pilots-s upport-Fisher-House-program#axzz1oIyuQZPZ Tim D-T N52KS ________________________________________________________________________________
Date: Mar 06, 2012
Very nice Tim. Where are you flying up to KLCI? Alan Sent from my iPhone On Mar 6, 2012, at 8:50 AM, "Dawson-Townsend,Timothy" wrote: > Just the local-yokel paper, but hey, it was on the front page! > > http://www.wickedlocal.com/hingham/topstories/x565046221/Hingham-pilots-su pport-Fisher-House-program#axzz1oIyuQZPZ > > > Tim D-T > N52KS > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 06, 2012
Great write up Tim to a great case. Good seeing you this weekend. Steve From: Alan Mekler MD Sent: Tuesday, March 06, 2012 11:23 AM Subject: Re: RV10-List: A little press coverage Very nice Tim. Where are you flying up to KLCI? Alan Sent from my iPhone On Mar 6, 2012, at 8:50 AM, "Dawson-Townsend,Timothy" wrote: Just the local-yokel paper, but hey, it was on the front page! http://www.wickedlocal.com/hingham/topstories/x565046221/Hingham-pilots-s upport-Fisher-House-program#axzz1oIyuQZPZ Tim D-T N52KS 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Apple users
Date: Mar 08, 2012
flashing; the button on screen and on the unit either did not work or performed different functions. The charge value was between 27-37%. The unit could not be powered down. I put it on charge and after a few minutes it performed normally. My first thought was that my daughter had loaded some new app but this morning I read that a large solar flare engulfed the earth last night. Did anyone else experience any strange computer phenomena last night? ________________________________________________________________________________
Date: Mar 08, 2012
Subject: Re: Apple users
Nothing strange on my iPad. Did you try to force a power-down by holding both buttons for more than 5 seconds? I've had some iDevices freeze until a hard reset. If it's still acting up, there is always the Genius Bar. They've replaced hardware for me, even when the failure was my fault (like dropping my 1 day old iPhone 4), or my MacBook motherboard even though I bought it 4.5 years ago. On Thu, Mar 8, 2012 at 8:19 AM, DLM wrote: > flashing; the button on screen and on the unit either did not work or > performed different functions. The charge value was between 27-37%. The > unit could not be powered down. I put it on charge and after a few minutes > it performed normally. My first thought was that my daughter had loaded > some new app but this morning I read that a large solar flare engulfed the > earth last night. Did anyone else experience any strange computer phenomena > last night?**** > > * > > * > > ________________________________________________________________________________
Date: Mar 08, 2012
On 3/8/2012 9:19 AM, DLM wrote: > > We get it. This is just an excuse to tell your wife so you can go buy the new iPad 3? ;-) -Dj ________________________________________________________________________________
Date: Mar 08, 2012
It might have been caused by the big solar storm reported on the news last night. The news said it may effect GPS and other sensitive electronics. Dick Sipp From: DLM Sent: Thursday, March 08, 2012 9:19 AM Subject: RV10-List: Apple users flashing; the button on screen and on the unit either did not work or performed different functions. The charge value was between 27-37%. The unit could not be powered down. I put it on charge and after a few minutes it performed normally. My first thought was that my daughter had loaded some new app but this morning I read that a large solar flare engulfed the earth last night. Did anyone else experience any strange computer phenomena last night? ________________________________________________________________________________
Date: Mar 08, 2012
Wrong; I was mistakenly on her case about it because she and my daughter had been downloading and using it for several hours. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill Sent: Thursday, March 08, 2012 7:47 AM Subject: Re: RV10-List: Apple users On 3/8/2012 9:19 AM, DLM wrote: We get it. This is just an excuse to tell your wife so you can go buy the new iPad 3? ;-) -Dj ________________________________________________________________________________
Subject: Fw: list of kudos
Date: Mar 09, 2012
I had a fellow mentor and RV-10 pilot in town this week. Anytime he=99s in town I take advantage of his humble knowledge. This week he helped with all sorts of loose issues, which of course opened up numerous other items to be tightened and adjusted. One item I have been fighting from the start has been oil! It has been on the bottom and back of my engine from day one. Appears there is a issue somewhere on the bottom front of the case that oil drips out of- while standing still. AMERICA=99s Engine told me they would do whatever I needed to get the issue resolved. They had their engine builder call me and discuss options to minimize the leaks. It will be a long process and hopefully it will get resolved but I give Kudos to them for standing by their product, regardless of time and any warranty- neither ever brought up Another oil leak I have is from my CURTIS oil drain valve. I called Curtis, a small company a few months back and they told me to do a few things. The issue was not resolved and they are sending me a new valve, again kudos to them for making the process easy. Another great kudos goes out to DYNON, they are outstanding in taking care of their customers. Everytime I call them for help they are quick to respond and work with me to get the issues completed. They have sent me new hardware, in the form of a Autopilot servo and bracket, without question, when they realized that the servo they had in the past was not a good solution for the RV-10, no upgrade fees nothing. This is only one of many times they have spared no expense to resolve my issues. I want to assure others know that there are so many companies out there that are excellent with customer service. If one is on the wall between an expensive certified PFD or a Dynon that is almost as nice, but free database updates for life, just know that these companies will take care of you. Pascal ________________________________________________________________________________
Subject: Aux fuel tank
Date: Mar 10, 2012
I have a source for an (approx.) 19 gal welded aluminum tank that installs directly behind the rear seats. Mods to the baggage floor must be made before the floor is closed up, which include two additional ribs and hard points for nutplates for steel straps that anchor the tank. The tank takes up about 2/3 of the volume and all of the weight capacity of the baggage area (when full). It is easily removable thru the baggage door. Provisions for electrical, plumbing, venting, and filling are made to pump the fuel into the left main tank as in similar certified installations. The tank includes a machined, flush, fuel cap port that is glassed into the cabin top. You provide a vertical, marine type, capacitance sender, which are compatible with a standard gauge or any of the EMS/EFIS systems. The cost is $650 plus shipping. Email me off-list for contact information if your interested. Chris Hukill back at it after 8 month "distraction" ________________________________________________________________________________
Date: Mar 11, 2012
Subject: Navworx deliveries - anybody rec'd any recently?
Bill/Tom, Did you ever receive you ADS-B unit from Navworx? I'm still waiting on word/eturn of my unit sent in for upgrade back in September. >According to Bill Moffit, one of the planned software upgrades is to give GPS output. I want to use this to drive my ELT. Hopefully, it will come with this software upgrade. Given that we already have to enter a number of software commands into the ADS-600B for setup and ID purposes, I don=92t understand why Navworx doesn=92t make the software available for online downloading as opposed to requiring the unit to be sent back in. >Tom H. >>Subject: Re: Navworx deliveries - anybody rec'd any recently? >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade back in September. I did get a reply from Bill Moffitt yesterday that "they are trying to get the latest software into all units prior to shipment." He gave me the option for them to ship it now, but if they did, "I would have to return it before it will support an future software upgrades, new features, etc." I opted to wait. >> >>William >>----------- -- William N40237 - http://wcurtis.nerv10.com/ ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 11, 2012
I received a software update (3.10.0) from Bill on Feb. 27. I just installed it Friday and I haven't flown with it yet but it seems to have resolved an issue that the last two didn't address. I sent my unit back to them about a month ago and was pleasantly surprised to have it turned around pretty quickly. But I know how you feel. It's usually pretty quiet at Navworx... --Dave Saylor On Sun, Mar 11, 2012 at 4:35 PM, William Curtis wrote: > Bill/Tom, > > Did you ever receive you ADS-B unit from Navworx? I'm still waiting on > word/eturn of my unit sent in for upgrade back in September. > > > >According to Bill Moffit, one of the planned software upgrades is to giv e > GPS output. I want to use this to drive my ELT. Hopefully, it will come > with this software upgrade. Given that we already have to enter a number of > software commands into the ADS-600B for setup and ID purposes, I don =99t > understand why Navworx doesn=99t make the software available for on line > downloading as opposed to requiring the unit to be sent back in. > >Tom H. > > >>Subject: Re: Navworx deliveries - anybody rec'd any recently? > >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade > back in September. I did get a reply from Bill Moffitt yesterday that "th ey > are trying to get the latest software into all units prior to shipment." He > gave me the option for them to ship it now, but if they did, "I would hav e > to return it before it will support an future software upgrades, new > features, etc." I opted to wait. > >> > >>William > >>----------- > > > -- > > William > N40237 - http://wcurtis.nerv10.com/ > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Mar 11, 2012
This a comment I received from Bill about a month ago. I've not received any communication since then. "There is a new software release, but it's in beta testing right now. You'll be notified when it's available." I just sent him the following question, but I'll ask it here since there are plenty of folks that have already installed an ADS600-B. I was finishing the wiring for mine this afternoon, when I noticed an omission. In the 10/31/2011 version of the ADS600-B manual, it highlights connecting the RS-232 output from the GTX-327 to Pin 33 for transponder control. On the ADS600 to AFS page, it highlights connecting Pin 35 for Transponder suppression. Although it's not formally documented on the GTX-327 page, I'm assuming that I need to connect pin 35 on the ADS600-B to pin 17 on the GTX-327, which is the external suppression pin. Is my assumption correct Bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Sunday, March 11, 2012 7:35 PM Subject: RV10-List: Navworx deliveries - anybody rec'd any recently? Bill/Tom, Did you ever receive you ADS-B unit from Navworx? I'm still waiting on word/eturn of my unit sent in for upgrade back in September. >According to Bill Moffit, one of the planned software upgrades is to give GPS output. I want to use this to drive my ELT. Hopefully, it will come with this software upgrade. Given that we already have to enter a number of software commands into the ADS-600B for setup and ID purposes, I don't understand why Navworx doesn't make the software available for online downloading as opposed to requiring the unit to be sent back in. >Tom H. >>Subject: Re: Navworx deliveries - anybody rec'd any recently? >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade back in September. I did get a reply from Bill Moffitt yesterday that "they are trying to get the latest software into all units prior to shipment." He gave me the option for them to ship it now, but if they did, "I would have to return it before it will support an future software upgrades, new features, etc." I opted to wait. >> >>William >>----------- -- William N40237 - http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Mar 11, 2012
Bill, I last spoke with Moffit approximately two months ago and decided not to send my unit in as Moffit said that he didn't have the hardware needed for upgrades at that time. I'm copying my friend Hugo on this email. He sent his unit in and was still waiting. Hugo, any details on what's going on with your unit. I guess Navworx goes on my list of people I need to talk to at Sun and Fun. DAR final inspection tomorrow at 10 AM. Hoo Yah!!!! Tom From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Curtis Sent: Sunday, March 11, 2012 7:35 PM Subject: RV10-List: Navworx deliveries - anybody rec'd any recently? Bill/Tom, Did you ever receive you ADS-B unit from Navworx? I'm still waiting on word/eturn of my unit sent in for upgrade back in September. >According to Bill Moffit, one of the planned software upgrades is to give GPS output. I want to use this to drive my ELT. Hopefully, it will come with this software upgrade. Given that we already have to enter a number of software commands into the ADS-600B for setup and ID purposes, I don't understand why Navworx doesn't make the software available for online downloading as opposed to requiring the unit to be sent back in. >Tom H. >>Subject: Re: Navworx deliveries - anybody rec'd any recently? >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade back in September. I did get a reply from Bill Moffitt yesterday that "they are trying to get the latest software into all units prior to shipment." He gave me the option for them to ship it now, but if they did, "I would have to return it before it will support an future software upgrades, new features, etc." I opted to wait. >> >>William >>----------- -- William N40237 - http://wcurtis.nerv10.com/ ________________________________________________________________________________
Date: Mar 11, 2012
I rec'd a unit a couple of weeks ago. Unfortunately I haven't really gotten into the technical details of the installation but it looks like I may have ordered a unit without the ARINC module. I'm thinking that with GRT HX units, a GTX327 and G430 that ARINC is needed. I have a wiring harness from FastStack that I think assumes ARINC support. Looking forward to talking to NavWorx tomorrow. Bill Watson On 3/11/2012 7:35 PM, William Curtis wrote: > Bill/Tom, > Did you ever receive you ADS-B unit from Navworx? I'm still waiting > on word/eturn of my unit sent in for upgrade back in September. > > >According to Bill Moffit, one of the planned software upgrades is > to give GPS output. I want to use this to drive my ELT. Hopefully, > it will come with this software upgrade. Given that we already > have to enter a number of software commands into the ADS-600B for > setup and ID purposes, I dont understand why Navworx doesnt make > the software available for online downloading as opposed to > requiring the unit to be sent back in. > >Tom H. > >>Subject: Re: Navworx deliveries - anybody rec'd any recently? > >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for > upgrade back in September. I did get a reply from Bill Moffitt > yesterday that "they are trying to get the latest software into > all units prior to shipment." He gave me the option for them to > ship it now, but if they did, "I would have to return it before it > will support an future software upgrades, new features, etc." I > opted to wait. > >> > >>William > >>----------- > ________________________________________________________________________________
Date: Mar 11, 2012
I don't think arnic is a requirement. Most of the efis vendors support the d isplay port output which is rs232. Sent from my iPhone On Mar 11, 2012, at 9:29 PM, Bill Watson wrote: I rec'd a unit a couple of weeks ago. Unfortunately I haven't really gotten into the technical details of the inst allation but it looks like I may have ordered a unit without the ARINC modul e. I'm thinking that with GRT HX units, a GTX327 and G430 that ARINC is nee ded. I have a wiring harness from FastStack that I think assumes ARINC supp ort. Looking forward to talking to NavWorx tomorrow. Bill Watson On 3/11/2012 7:35 PM, William Curtis wrote: > > Bill/Tom, > > Did you ever receive you ADS-B unit from Navworx? I'm still waiting on wo rd/eturn of my unit sent in for upgrade back in September. > > >According to Bill Moffit, one of the planned software upgrades is to give GPS output. I want to use this to drive my ELT. Hopefully, it will come wit h this software upgrade. Given that we already have to enter a number of sof tware commands into the ADS-600B for setup and ID purposes, I don=99t u nderstand why Navworx doesn=99t make the software available for online downloading as opposed to requiring the unit to be sent back in. > >Tom H. > > >>Subject: Re: Navworx deliveries - anybody rec'd any recently? > >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade ba ck in September. I did get a reply from Bill Moffitt yesterday that "they ar e trying to get the latest software into all units prior to shipment." He ga ve me the option for them to ship it now, but if they did, "I would have to r eturn it before it will support an future software upgrades, new features, e tc." I opted to wait. > >> > >>William > >>----------- ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Subject: IPAD Mount
Date: Mar 12, 2012
I want to mount my IPAD on the tunnel forward of the fuel selector. What mounts work good in that location? Thanks Barry ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Date: Mar 12, 2012
WW91IGxpa2VseSBvbmx5IG5lZWQgQVJJTkMgaWYgeW91IHdhbnQgdG8gc2VuZCB0cmFmZmljIHRv IGEgR2FybWluIGxpa2UgdGhlIEdOUyBvciBHVE4uDQoNCk1pY2hhZWwNCg0KRnJvbTogb3duZXIt cnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNl cnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgQm9iIExlZmZsZXINClNlbnQ6IFN1bmRh eSwgTWFyY2ggMTEsIDIwMTIgNzoxNyBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpT dWJqZWN0OiBSZTogUlYxMC1MaXN0OiBOYXZ3b3J4IGRlbGl2ZXJpZXMgLSBhbnlib2R5IHJlYydk IGFueSByZWNlbnRseT8NCg0KSSBkb24ndCB0aGluayBhcm5pYyBpcyBhIHJlcXVpcmVtZW50LiBN b3N0IG9mIHRoZSBlZmlzIHZlbmRvcnMgc3VwcG9ydCB0aGUgZGlzcGxheSBwb3J0IG91dHB1dCB3 aGljaCBpcyByczIzMi4NCg0KU2VudCBmcm9tIG15IGlQaG9uZQ0KDQpPbiBNYXIgMTEsIDIwMTIs IGF0IDk6MjkgUE0sIEJpbGwgV2F0c29uIDxNYXVsZWRyaXZlckBuYy5yci5jb208bWFpbHRvOk1h dWxlZHJpdmVyQG5jLnJyLmNvbT4+IHdyb3RlOg0KSSByZWMnZCBhIHVuaXQgYSBjb3VwbGUgb2Yg d2Vla3MgYWdvLg0KDQpVbmZvcnR1bmF0ZWx5IEkgaGF2ZW4ndCByZWFsbHkgZ290dGVuIGludG8g dGhlIHRlY2huaWNhbCBkZXRhaWxzIG9mIHRoZSBpbnN0YWxsYXRpb24gYnV0IGl0IGxvb2tzIGxp a2UgSSBtYXkgaGF2ZSBvcmRlcmVkIGEgdW5pdCB3aXRob3V0IHRoZSBBUklOQyBtb2R1bGUuICBJ J20gdGhpbmtpbmcgdGhhdCB3aXRoIEdSVCBIWCB1bml0cywgYSBHVFgzMjcgYW5kIEc0MzAgdGhh dCBBUklOQyBpcyBuZWVkZWQuICBJIGhhdmUgYSB3aXJpbmcgaGFybmVzcyBmcm9tIEZhc3RTdGFj ayB0aGF0IEkgdGhpbmsgYXNzdW1lcyBBUklOQyBzdXBwb3J0LiAgTG9va2luZyBmb3J3YXJkIHRv IHRhbGtpbmcgdG8gTmF2V29yeCB0b21vcnJvdy4NCg0KQmlsbCBXYXRzb24NCg0KT24gMy8xMS8y MDEyIDc6MzUgUE0sIFdpbGxpYW0gQ3VydGlzIHdyb3RlOg0KQmlsbC9Ub20sDQoNCkRpZCB5b3Ug ZXZlciByZWNlaXZlIHlvdSBBRFMtQiB1bml0IGZyb20gTmF2d29yeD8gIEknbSBzdGlsbCB3YWl0 aW5nIG9uIHdvcmQvZXR1cm4gb2YgbXkgdW5pdCBzZW50IGluIGZvciB1cGdyYWRlIGJhY2sgaW4g U2VwdGVtYmVyLg0KDQo+QWNjb3JkaW5nIHRvIEJpbGwgTW9mZml0LCBvbmUgb2YgdGhlIHBsYW5u ZWQgc29mdHdhcmUgdXBncmFkZXMgaXMgdG8gZ2l2ZSBHUFMgb3V0cHV0LiBJIHdhbnQgdG8gdXNl IHRoaXMgdG8gZHJpdmUgbXkgRUxULiBIb3BlZnVsbHksIGl0IHdpbGwgY29tZSB3aXRoIHRoaXMg c29mdHdhcmUgdXBncmFkZS4gR2l2ZW4gdGhhdCB3ZSBhbHJlYWR5IGhhdmUgdG8gZW50ZXIgYSBu dW1iZXIgb2Ygc29mdHdhcmUgY29tbWFuZHMgaW50byB0aGUgQURTLTYwMEIgZm9yIHNldHVwIGFu ZCBJRCBwdXJwb3NlcywgSSBkb27igJl0IHVuZGVyc3RhbmQgd2h5IE5hdndvcnggZG9lc27igJl0 IG1ha2UgdGhlIHNvZnR3YXJlIGF2YWlsYWJsZSBmb3Igb25saW5lIGRvd25sb2FkaW5nIGFzIG9w cG9zZWQgdG8gcmVxdWlyaW5nIHRoZSB1bml0IHRvIGJlIHNlbnQgYmFjayBpbi4NCj5Ub20gSC4N Cg0KPj5TdWJqZWN0OiBSZTogTmF2d29yeCBkZWxpdmVyaWVzIC0gYW55Ym9keSByZWMnZCBhbnkg cmVjZW50bHk/DQo+PkknbSBzdGlsbCBhd2FpdGluZyBteSBBRFMtNjAwQiB1bml0LiBTZW50IG15 IEFEUy02MDAgdW5pdCBmb3IgdXBncmFkZSBiYWNrIGluIFNlcHRlbWJlci4gSSBkaWQgZ2V0IGEg cmVwbHkgZnJvbSBCaWxsIE1vZmZpdHQgeWVzdGVyZGF5IHRoYXQgInRoZXkgYXJlIHRyeWluZyB0 byBnZXQgdGhlIGxhdGVzdCBzb2Z0d2FyZSBpbnRvIGFsbCB1bml0cyBwcmlvciB0byBzaGlwbWVu dC4iIEhlIGdhdmUgbWUgdGhlIG9wdGlvbiBmb3IgdGhlbSB0byBzaGlwIGl0IG5vdywgYnV0IGlm IHRoZXkgZGlkLCAiSSB3b3VsZCBoYXZlIHRvIHJldHVybiBpdCBiZWZvcmUgaXQgd2lsbCBzdXBw b3J0IGFuIGZ1dHVyZSBzb2Z0d2FyZSB1cGdyYWRlcywgbmV3IGZlYXR1cmVzLCBldGMuIiBJIG9w dGVkIHRvIHdhaXQuDQo+Pg0KPj5XaWxsaWFtDQo+Pi0tLS0tLS0tLS0tDQoNCg0KDQoNCg0KDQo9 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQo6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQoNCj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09DQoNCmNzLmNvbQ0KDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpt YXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQo9PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KDQoNCg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1M aXN0IEVtYWlsIEZvcnVtIC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMg TmF2aWdhdG9yIHRvIGJyb3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBh cyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVj aCBtb3JlOg0KDQpfLT0NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZp Z2F0b3I/UlYxMC1MaXN0DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWls YWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tDQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgLSBMaXN0 IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQoNCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVy b3VzIHN1cHBvcnQhDQoNCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERy YWxsZSwgTGlzdCBBZG1pbi4NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24NCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Date: Mar 12, 2012
Still not a requirement. I have the display port (wx & traffic) going to the afs4500 and the tis port going to the gtn650. Both are serial. Arnic may have some other benefits, but for the $$. I stayed with the serial connections. Sent from my iPhone On Mar 12, 2012, at 11:32 AM, "RV Builder (Michael Sausen)" wrote: You likely only need ARINC if you want to send traffic to a Garmin like the G NS or GTN. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ma tronics.com] On Behalf Of Bob Leffler Sent: Sunday, March 11, 2012 7:17 PM Subject: Re: RV10-List: Navworx deliveries - anybody rec'd any recently? I don't think arnic is a requirement. Most of the efis vendors support the d isplay port output which is rs232. Sent from my iPhone On Mar 11, 2012, at 9:29 PM, Bill Watson wrote: I rec'd a unit a couple of weeks ago. Unfortunately I haven't really gotten into the technical details of the inst allation but it looks like I may have ordered a unit without the ARINC modul e. I'm thinking that with GRT HX units, a GTX327 and G430 that ARINC is nee ded. I have a wiring harness from FastStack that I think assumes ARINC supp ort. Looking forward to talking to NavWorx tomorrow. Bill Watson On 3/11/2012 7:35 PM, William Curtis wrote: Bill/Tom, Did you ever receive you ADS-B unit from Navworx? I'm still waiting on word /eturn of my unit sent in for upgrade back in September. >According to Bill Moffit, one of the planned software upgrades is to give G PS output. I want to use this to drive my ELT. Hopefully, it will come with t his software upgrade. Given that we already have to enter a number of softwa re commands into the ADS-600B for setup and ID purposes, I don=99t und erstand why Navworx doesn=99t make the software available for online d ownloading as opposed to requiring the unit to be sent back in. >Tom H. >>Subject: Re: Navworx deliveries - anybody rec'd any recently? >>I'm still awaiting my ADS-600B unit. Sent my ADS-600 unit for upgrade back in September. I did get a reply from Bill Moffitt yesterday that "they are t rying to get the latest software into all units prior to shipment." He gave m e the option for them to ship it now, but if they did, "I would have to retu rn it before it will support an future software upgrades, new features, etc. " I opted to wait. >> >>William >>----------- ========================== ======== ://www.matronics.com/Navigator?RV10-List ========================== ======== cs.com ========================== ======== matronics.com/contribution ========================== ======== ========================== ======== ========================== ======== ========================== ======== ========================== ======== =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD,=EF=BD=EF=BD=EF=BD%=EF =BD=EF=BD4=EF=BDM4}=EF=BD=1Er=EF=BD=EF=BD=EF=BD=EF=BD =EF=BD{=07(=EF=BD=EF=BD=EF=BD=EF=BD8^E]t.+-=12f=EF=BD=EF =BDZ+=EF=BDe,z=EF=BD^1=EF=BDk=EF=BDx=EF=BD=EF=BD=EF=BD=EF =BD=EF=BDW=EF=BD=EF=BD=EF=BD=DE=B0=D6=AF=EF=BD=06=EF=BD =EF=BD=EF=BDhn=EF=BD0=EF=BD=EF=BDazf=EF=BD=C8=B8=EF=BD=EF =BD=EF=BDb=EF=BD+bz=EF=BD.r=16=EF=BD.+-R=7F=D2=B9=EF=BD=1C =EF=BD*m=EF=BD=EF=BD=EF=BD=EF=BDb=EF=BD=EF=BDj=EF=BD !=0E=EF=BD'=EF=BD=EF=BD=EF=BD=EF=BD6=EF=BD=06=EF=BD0=EF =BD=EF=BDj=EF=BD@@=EF=BDh=EF=BD=EF=BD!j=EF=BD=EF=BD=EF =BD=D9=AEr=19=EF=BDr=19=EF=BD=EF=BD=E6=A1=AD=EF=BD=EF=BD=EF =BD=7F=EF=BD=0C0=EF=BD=EF=BDk=EF=BDx=EF=BD=EF=BD=EF=BD &=EF=BD=D6=AF=EF=BD=06=EF=BD=EF=BD=EF=BDU=EF=BDB=EF=BD=EF =BDm=EF=BD=EF=BD=EF=BD=EF=BD=0C&j=EF=BD=EF=BD',r=EF=BD =EF=BD5=EF=BD=81=ABh=EF=BD=15u=D0=B8=EF=BD=EF=BD=EF=BD=01 4N4=EF=BD=EF=BDX@E9=15=0CI&=EF=BDz =EF=BDj=EF=BD(=EF=BD=D7 =A7=EF=BD=EF=BDl=EF=BD=EF=BD=DA=8AV=EF=BD=EF=BD=EF=BD=EF =BDj=EF=BD^Y=EF=BD=C5=A2=EF=BD=EF=BD=EF=BD=EF=BDky=EF =BDm=EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD=C9=9A=EF=BD=EF=BD'=EF =BD=EF=BD=1C=EF=BDhm=EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD=C9 =9A=EF=BD=EF=BD'=EF=BD=EF=BD=1C=EF=BDo=EF=BD.+- =EF=BD=EF =BD&=EF=BD*'Y=EF=BD=D2=8A=D7=93=EF=BD=EF=BD=EF=BD=CA=8B=EF =BD=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=1E=EF=BD=EF=BD=EF =BD=EF=BD.=EF=BD=EF=BD+=EF=BD=C6=AD=EF=BD:=DA'W=EF=BD=EF =BD=EF=BD@vh=EF=BDj=1A=EF=BD~=1Bm=EF=BD=EF=BD=EF=BD=EF =BD =EF=BD=EF=BD=EF=BD'=EF=BD=EF=BD=1C=EF=BDo=DC=A2{k =EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=7F=EF=BD=0C 0=EF=BD=EF=BDk=EF=BDx=EF=BD=EF=BD=EF=BD&=EF=BD=EF=BD '=EF=BD=EF=BD=EF=BD=EF=BD=D8=A8=EF=BD=EF=BDo=EF=BD=EF =BD=EF=BD=EF=BD=EF=BD=DB=A1=DC=EF=BD=D9=A5 ________________________________________________________________________________
Date: Mar 12, 2012
SSBuZWVkIEFSSU5DIGZvciBkaXNwbGF5aW5nIHRyYWZmaWMgb24gYSA1MzAuICBJJ20gcHJldHR5 IHN1cmUgdGhlcmUncyBubwp3YXkgdG8gbWFrZSBpdCB3b3JrIGZvciBtZSB1c2luZyAyMzIuCgpI b3cgZG8geW91IGxpa2UgdGhlIHdheSB0aGUgNjUwIHNob3dzIHRyYWZmaWM/ICBJcyBpdCBzZXQg dXAgZm9yIHRyYWZmaWMKYWR2aXNvcmllcywgR1RYMzMwLCBvciBzb21ldGhpbmcgZWxzZT8KCi0t RGF2ZSBTYXlsb3IKCgoKT24gTW9uLCBNYXIgMTIsIDIwMTIgYXQgOTozNiBBTSwgQm9iIExlZmZs ZXIgPHJ2QHRoZWxlZmZsZXJzLmNvbT4gd3JvdGU6Cgo+IFN0aWxsIG5vdCBhIHJlcXVpcmVtZW50 Lgo+Cj4gSSBoYXZlIHRoZSBkaXNwbGF5IHBvcnQgKHd4ICYgdHJhZmZpYykgZ29pbmcgdG8gdGhl IGFmczQ1MDAgYW5kIHRoZSB0aXMKPiBwb3J0IGdvaW5nIHRvIHRoZSBndG42NTAuICBCb3RoIGFy ZSBzZXJpYWwuCj4KPiBBcm5pYyBtYXkgaGF2ZSBzb21lIG90aGVyIGJlbmVmaXRzLCBidXQgZm9y IHRoZSAkJC4gSSBzdGF5ZWQgd2l0aCB0aGUKPiBzZXJpYWwgY29ubmVjdGlvbnMuCj4KPiBTZW50 IGZyb20gbXkgaVBob25lCj4KPiBPbiBNYXIgMTIsIDIwMTIsIGF0IDExOjMyIEFNLCAiUlYgQnVp bGRlciAoTWljaGFlbCBTYXVzZW4pIiA8Cj4gcnZidWlsZGVyQHNhdXNlbi5uZXQ+IHdyb3RlOgo+ Cj4gIFlvdSBsaWtlbHkgb25seSBuZWVkIEFSSU5DIGlmIHlvdSB3YW50IHRvIHNlbmQgdHJhZmZp YyB0byBhIEdhcm1pbiBsaWtlCj4gdGhlIEdOUyBvciBHVE4uKioqKgo+Cj4gKiogKioKPgo+IE1p Y2hhZWwqKioqCj4KPiAqKiAqKgo+Cj4gKkZyb206KiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb20gW21haWx0bzoKPiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5j b21dICpPbiBCZWhhbGYgT2YgKkJvYiBMZWZmbGVyCj4gKlNlbnQ6KiBTdW5kYXksIE1hcmNoIDEx LCAyMDEyIDc6MTcgUE0KPiAqVG86KiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQo+ICpTdWJqZWN0 OiogUmU6IFJWMTAtTGlzdDogTmF2d29yeCBkZWxpdmVyaWVzIC0gYW55Ym9keSByZWMnZCBhbnkg cmVjZW50bHk/Cj4gKioqKgo+Cj4gKiogKioKPgo+IEkgZG9uJ3QgdGhpbmsgYXJuaWMgaXMgYSBy ZXF1aXJlbWVudC4gTW9zdCBvZiB0aGUgZWZpcyB2ZW5kb3JzIHN1cHBvcnQgdGhlCj4gZGlzcGxh eSBwb3J0IG91dHB1dCB3aGljaCBpcyByczIzMi4KPgo+IFNlbnQgZnJvbSBteSBpUGhvbmUqKioq Cj4KPgo+IE9uIE1hciAxMSwgMjAxMiwgYXQgOToyOSBQTSwgQmlsbCBXYXRzb24gPE1hdWxlZHJp dmVyQG5jLnJyLmNvbT4gd3JvdGU6KioqCj4gKgo+Cj4gSSByZWMnZCBhIHVuaXQgYSBjb3VwbGUg b2Ygd2Vla3MgYWdvLgo+Cj4gVW5mb3J0dW5hdGVseSBJIGhhdmVuJ3QgcmVhbGx5IGdvdHRlbiBp bnRvIHRoZSB0ZWNobmljYWwgZGV0YWlscyBvZiB0aGUKPiBpbnN0YWxsYXRpb24gYnV0IGl0IGxv b2tzIGxpa2UgSSBtYXkgaGF2ZSBvcmRlcmVkIGEgdW5pdCB3aXRob3V0IHRoZSBBUklOQwo+IG1v ZHVsZS4gIEknbSB0aGlua2luZyB0aGF0IHdpdGggR1JUIEhYIHVuaXRzLCBhIEdUWDMyNyBhbmQg RzQzMCB0aGF0IEFSSU5DCj4gaXMgbmVlZGVkLiAgSSBoYXZlIGEgd2lyaW5nIGhhcm5lc3MgZnJv bSBGYXN0U3RhY2sgdGhhdCBJIHRoaW5rIGFzc3VtZXMKPiBBUklOQyBzdXBwb3J0LiAgTG9va2lu ZyBmb3J3YXJkIHRvIHRhbGtpbmcgdG8gTmF2V29yeCB0b21vcnJvdy4KPgo+IEJpbGwgV2F0c29u Cj4KPiBPbiAzLzExLzIwMTIgNzozNSBQTSwgV2lsbGlhbSBDdXJ0aXMgd3JvdGU6ICoqKioKPgo+ IEJpbGwvVG9tLCoqKioKPgo+ICAqKioqCj4KPiBEaWQgeW91IGV2ZXIgcmVjZWl2ZSB5b3UgQURT LUIgdW5pdCBmcm9tIE5hdndvcng/ICBJJ20gc3RpbGwgd2FpdGluZyBvbgo+IHdvcmQvZXR1cm4g b2YgbXkgdW5pdCBzZW50IGluIGZvciB1cGdyYWRlIGJhY2sgaW4gU2VwdGVtYmVyLioqKioKPgo+ ICAqKioqCj4KPiAgPkFjY29yZGluZyB0byBCaWxsIE1vZmZpdCwgb25lIG9mIHRoZSBwbGFubmVk IHNvZnR3YXJlIHVwZ3JhZGVzIGlzIHRvCj4gZ2l2ZSBHUFMgb3V0cHV0LiBJIHdhbnQgdG8gdXNl IHRoaXMgdG8gZHJpdmUgbXkgRUxULiBIb3BlZnVsbHksIGl0IHdpbGwKPiBjb21lIHdpdGggdGhp cyBzb2Z0d2FyZSB1cGdyYWRlLiBHaXZlbiB0aGF0IHdlIGFscmVhZHkgaGF2ZSB0byBlbnRlciBh Cj4gbnVtYmVyIG9mIHNvZnR3YXJlIGNvbW1hbmRzIGludG8gdGhlIEFEUy02MDBCIGZvciBzZXR1 cCBhbmQgSUQgcHVycG9zZXMsIEkKPiBkb27igJl0IHVuZGVyc3RhbmQgd2h5IE5hdndvcnggZG9l c27igJl0IG1ha2UgdGhlIHNvZnR3YXJlIGF2YWlsYWJsZSBmb3Igb25saW5lCj4gZG93bmxvYWRp bmcgYXMgb3Bwb3NlZCB0byByZXF1aXJpbmcgdGhlIHVuaXQgdG8gYmUgc2VudCBiYWNrIGluLiAq KioqCj4KPiA+VG9tIEguICoqKioKPgo+ICAqKioqCj4KPiA+PlN1YmplY3Q6IFJlOiBOYXZ3b3J4 IGRlbGl2ZXJpZXMgLSBhbnlib2R5IHJlYydkIGFueSByZWNlbnRseT8gKioqKgo+Cj4gPj5JJ20g c3RpbGwgYXdhaXRpbmcgbXkgQURTLTYwMEIgdW5pdC4gU2VudCBteSBBRFMtNjAwIHVuaXQgZm9y IHVwZ3JhZGUKPiBiYWNrIGluIFNlcHRlbWJlci4gSSBkaWQgZ2V0IGEgcmVwbHkgZnJvbSBCaWxs IE1vZmZpdHQgeWVzdGVyZGF5IHRoYXQgInRoZXkKPiBhcmUgdHJ5aW5nIHRvIGdldCB0aGUgbGF0 ZXN0IHNvZnR3YXJlIGludG8gYWxsIHVuaXRzIHByaW9yIHRvIHNoaXBtZW50LiIgSGUKPiBnYXZl IG1lIHRoZSBvcHRpb24gZm9yIHRoZW0gdG8gc2hpcCBpdCBub3csIGJ1dCBpZiB0aGV5IGRpZCwg Ikkgd291bGQgaGF2ZQo+IHRvIHJldHVybiBpdCBiZWZvcmUgaXQgd2lsbCBzdXBwb3J0IGFuIGZ1 dHVyZSBzb2Z0d2FyZSB1cGdyYWRlcywgbmV3Cj4gZmVhdHVyZXMsIGV0Yy4iIEkgb3B0ZWQgdG8g d2FpdC4gKioqKgo+Cj4gPj4gKioqKgo+Cj4gPj5XaWxsaWFtICoqKioKPgo+ID4+LS0tLS0tLS0t LS0qKioqCj4KPiAqKiAqKgo+Cj4gKiAqCj4KPiAqICoKPgo+ICo9PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PSoKPgo+ICo6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYx MC1MaXN0Kgo+Cj4gKj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Kgo+Cj4gKmNz LmNvbSoKPgo+ICo9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PSoKPgo+ICptYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbioKPgo+ICo9PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PSoKPgo+ICogKgo+Cj4gICogKgo+Cj4gKiAqCj4KPiA9PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PSoqKiogMTAtTGlzdCBFbWFpbCBGb3J1bSAtKioqKiBwPgo+IG86 cD4gb3I/UlYxMC1MaXN0Ij5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAt TGlzdCoqKio9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+ICoqKiogc3A7 ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLSoqKiogcD4gcDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tKioqKj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4gKioqKiBzcDsg IC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLSoqKiogPiBzcDsKPiAgICAgIC1NYXR0IERy YWxsZSwgTGlzdCBBZG1pbi4qKioqIHV0aW9uIj4KPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v Y29udHJpYnV0aW9uKioqKj09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4g KioqKgo+Cj4gKiAqCj4KPiAg77+977+977+9fu+/ve+/vSzvv73vv73vv70l77+977+9NO+/vU00 fe+/vSBy77+977+977+977+977+9eyAo77+977+977+977+9OF5FXXQuKy0gZu+/ve+/vVor77+9 ZSx677+9XjHvv71r77+9eO+/ve+/ve+/ve+/ve+/vVfvv73vv73vv73esNav77+9Cj4g77+977+9 77+9aG7vv70w77+977+9YXpm77+9yLjvv73vv73vv71i77+9K2J677+9LnIg77+9ListUiDSue+/ vSDvv70qbe+/ve+/ve+/ve+/vWLvv73vv71q77+9ISDvv70n77+977+977+977+9Nu+/vQo+IO+/ vTDvv73vv71q77+9QEDvv71o77+977+9IWrvv73vv73vv73ZrnIg77+9ciDvv73vv73moa3vv73v v73vv70g77+9IDDvv73vv71r77+9eO+/ve+/ve+/vSbvv73Wr++/vSDvv73vv73vv71V77+9Qu+/ ve+/vW3vv73vv73vv73vv70gJmrvv73vv70nLHLvv73vv70177+94oGraO+/vQo+IHXQuO+/ve+/ ve+/vSA0TjTvv73vv71YQEU5IEkm77+9eiDvv71q77+9KO+/vden77+977+9bO+/ve+/vdqKVu+/ ve+/ve+/ve+/vWrvv71eWe+/vcWi77+977+977+977+9a3nvv71t77+977+977+9fu+/ve+/vcma 77+977+9J++/ve+/vQo+IO+/vWht77+977+977+9fu+/ve+/vcma77+977+9J++/ve+/vSDvv71v 77+9ListIO+/ve+/vSbvv70qJ1nvv73SiteT77+977+977+9yovvv73vv73vv73vv73vv73vv70g 77+977+977+977+9Lu+/ve+/vSvvv73Gre+/vTrallfvv73vv73vv71Admjvv71qIO+/vX4gbe+/ ve+/ve+/ve+/vQo+IO+/ve+/ve+/vSfvv73vv70g77+9b9yie2vvv73vv73vv73vv73vv73vv73v v70g77+9IDDvv73vv71r77+9eO+/ve+/ve+/vSbvv73vv70n77+977+977+977+92Kjvv73vv71v 77+977+977+977+977+926Hcv++/vdmlCj4KPiAqCj4KPiBfLT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+IF8tPSAgICAgICAgICAt IFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQo+IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0 IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UKPiBfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRp ZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKPiBfLT0gQXJjaGl2ZSBTZWFyY2ggJiBE b3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCj4gXy09IFBob3Rvc2hhcmUsIGFuZCBt dWNoIG11Y2ggbW9yZToKPiBfLT0KPiBfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29t L05hdmlnYXRvcj9SVjEwLUxpc3QKPiBfLT0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+IF8tPSAgICAgICAgICAgICAgIC0g TUFUUk9OSUNTIFdFQiBGT1JVTVMgLQo+IF8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFp bGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQo+IF8tPQo+IF8tPSAgIC0tPiBodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20KPiBfLT0KPiBfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+IF8tPSAgICAgICAgICAgICAtIExpc3QgQ29u dHJpYnV0aW9uIFdlYiBTaXRlIC0KPiBfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBz dXBwb3J0IQo+IF8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwg TGlzdCBBZG1pbi4KPiBfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1 dGlvbgo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09Cj4gKgo+Cj4K ________________________________________________________________________________
Date: Mar 12, 2012
Well, I have a GNS 430W but I didn't envision it as a primary source of traffic info... if it would display it at all. I'm guessing that the 430 would probably display traffic if connected via ARINC. My wire harness from FastStack is wired for it but FastStack can't confirm whether it would function that way and Garmin probably has no opinion. Hoping to talk to Bill at Navworx soon. Different question; why the heck, with all the GPS receivers I have, can't the Navworx box use one of those signals instead of requiring yet another GPS antenna? Seems like we're going from "bristling with antenna whips" to "covered with GPS boils". But apparently it doesn't so.... Bill "antenna shopping and siting once again" Watson On 3/12/2012 11:32 AM, RV Builder (Michael Sausen) wrote: > > You likely only need ARINC if you want to send traffic to a Garmin > like the GNS or GTN. > > Michael > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler > *Sent:* Sunday, March 11, 2012 7:17 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Navworx deliveries - anybody rec'd any recently? > > I don't think arnic is a requirement. Most of the efis vendors support > the display port output which is rs232. > > Sent from my iPhone > > > On Mar 11, 2012, at 9:29 PM, Bill Watson > wrote: > > I rec'd a unit a couple of weeks ago. > > Unfortunately I haven't really gotten into the technical details of > the installation but it looks like I may have ordered a unit without > the ARINC module. I'm thinking that with GRT HX units, a GTX327 and > G430 that ARINC is needed. I have a wiring harness from FastStack > that I think assumes ARINC support. Looking forward to talking to > NavWorx tomorrow. > > Bill Watson > ________________________________________________________________________________
Date: Mar 12, 2012
The good news is that you don't need much of an antenna. I'm using this on the glare shield and it works just fine: http://www.aircraftspruce.com/catalog/avpages/garminAcss5.php It was left over from our 696, which doesn't need an external antenna. I cut off the extra wire and put a TNC on it, but I used a bunch of adapters before I got around to that. I also learned that the larger antenna from a 496 doesn't work. --Dave Saylor On Mon, Mar 12, 2012 at 10:49 AM, Bill Watson wrote: > Well, I have a GNS 430W but I didn't envision it as a primary source of > traffic info... if it would display it at all. I'm guessing that the 430 > would probably display traffic if connected via ARINC. My wire harness > from FastStack is wired for it but FastStack can't confirm whether it would > function that way and Garmin probably has no opinion. Hoping to talk to > Bill at Navworx soon. > > Different question; why the heck, with all the GPS receivers I have, can't > the Navworx box use one of those signals instead of requiring yet another > GPS antenna? Seems like we're going from "bristling with antenna whips" to > "covered with GPS boils". But apparently it doesn't so.... > > Bill "antenna shopping and siting once again" Watson > > > On 3/12/2012 11:32 AM, RV Builder (Michael Sausen) wrote: > > You likely only need ARINC if you want to send traffic to a Garmin like > the GNS or GTN.**** > > ** ** > > Michael**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [ > mailto:owner-rv10-list-server(at)matronics.com] > *On Behalf Of *Bob Leffler > *Sent:* Sunday, March 11, 2012 7:17 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Navworx deliveries - anybody rec'd any recently? > **** > > ** ** > > I don't think arnic is a requirement. Most of the efis vendors support the > display port output which is rs232. > > Sent from my iPhone**** > > > On Mar 11, 2012, at 9:29 PM, Bill Watson wrote:*** > * > > I rec'd a unit a couple of weeks ago. > > Unfortunately I haven't really gotten into the technical details of the > installation but it looks like I may have ordered a unit without the ARINC > module. I'm thinking that with GRT HX units, a GTX327 and G430 that ARINC > is needed. I have a wiring harness from FastStack that I think assumes > ARINC support. Looking forward to talking to NavWorx tomorrow. > > Bill Watson > > > * > > > * > > ________________________________________________________________________________
Subject: Re: IPAD Mount
Date: Mar 12, 2012
I used the RAM cradle and lil buddy suction cup. Works very well and easy to remove. Alan Sent from my iPhone On Mar 12, 2012, at 10:34 AM, Barry Marz wrote: > > I want to mount my IPAD on the tunnel forward of the fuel selector. What mounts work good in that location? Thanks Barry > > > > ________________________________________________________________________________
Date: Mar 12, 2012
SG1tIGludGVyZXN0aW5nLCBkaWRuJ3Qga25vdyB0aGF0LiBJIHdvbmRlciBpZiB0aGVyZSBpcyBh bnkgYWR2YW50YWdlIGluIHVzaW5nIEFSSU5DIGluIHRoYXQgY2FzZSBzdWNoIGFzIHdlYXRoZXIu IE1pZ2h0IGJlIGFibGUgdG8gc2F2ZSBhIGNvdXBsZSBodW5kcmVkIGJ1Y2tzIGJ5IGRpdGNoaW5n IHRoYXQgaW50ZXJmYWNlLg0KDQpNaWNoYWVsDQoNCk9uIE1hciAxMiwgMjAxMiwgYXQgMTI6NTAg UE0sICJCb2IgTGVmZmxlciIgPHJ2QHRoZWxlZmZsZXJzLmNvbTxtYWlsdG86cnZAdGhlbGVmZmxl cnMuY29tPj4gd3JvdGU6DQoNClN0aWxsIG5vdCBhIHJlcXVpcmVtZW50Lg0KDQpJIGhhdmUgdGhl IGRpc3BsYXkgcG9ydCAod3ggJiB0cmFmZmljKSBnb2luZyB0byB0aGUgYWZzNDUwMCBhbmQgdGhl IHRpcyBwb3J0IGdvaW5nIHRvIHRoZSBndG42NTAuICBCb3RoIGFyZSBzZXJpYWwuDQoNCkFybmlj IG1heSBoYXZlIHNvbWUgb3RoZXIgYmVuZWZpdHMsIGJ1dCBmb3IgdGhlICQkLiBJIHN0YXllZCB3 aXRoIHRoZSBzZXJpYWwgY29ubmVjdGlvbnMuDQoNClNlbnQgZnJvbSBteSBpUGhvbmUNCg0KT24g TWFyIDEyLCAyMDEyLCBhdCAxMTozMiBBTSwgIlJWIEJ1aWxkZXIgKE1pY2hhZWwgU2F1c2VuKSIg PHJ2YnVpbGRlckBzYXVzZW4ubmV0PG1haWx0bzpydmJ1aWxkZXJAc2F1c2VuLm5ldD4+IHdyb3Rl Og0KDQpZb3UgbGlrZWx5IG9ubHkgbmVlZCBBUklOQyBpZiB5b3Ugd2FudCB0byBzZW5kIHRyYWZm aWMgdG8gYSBHYXJtaW4gbGlrZSB0aGUgR05TIG9yIEdUTi4NCg0KTWljaGFlbA0KDQpGcm9tOiBv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb208bWFpbHRvOm93bmVyLXJ2MTAtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1h dHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBCb2IgTGVmZmxlcg0KU2VudDogU3VuZGF5LCBNYXJj aCAxMSwgMjAxMiA3OjE3IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogTmF2d29yeCBk ZWxpdmVyaWVzIC0gYW55Ym9keSByZWMnZCBhbnkgcmVjZW50bHk/DQoNCkkgZG9uJ3QgdGhpbmsg YXJuaWMgaXMgYSByZXF1aXJlbWVudC4gTW9zdCBvZiB0aGUgZWZpcyB2ZW5kb3JzIHN1cHBvcnQg dGhlIGRpc3BsYXkgcG9ydCBvdXRwdXQgd2hpY2ggaXMgcnMyMzIuDQoNClNlbnQgZnJvbSBteSBp UGhvbmUNCg0KT24gTWFyIDExLCAyMDEyLCBhdCA5OjI5IFBNLCBCaWxsIFdhdHNvbiA8TWF1bGVk cml2ZXJAbmMucnIuY29tPG1haWx0bzpNYXVsZWRyaXZlckBuYy5yci5jb20+PiB3cm90ZToNCkkg cmVjJ2QgYSB1bml0IGEgY291cGxlIG9mIHdlZWtzIGFnby4NCg0KVW5mb3J0dW5hdGVseSBJIGhh dmVuJ3QgcmVhbGx5IGdvdHRlbiBpbnRvIHRoZSB0ZWNobmljYWwgZGV0YWlscyBvZiB0aGUgaW5z dGFsbGF0aW9uIGJ1dCBpdCBsb29rcyBsaWtlIEkgbWF5IGhhdmUgb3JkZXJlZCBhIHVuaXQgd2l0 aG91dCB0aGUgQVJJTkMgbW9kdWxlLiAgSSdtIHRoaW5raW5nIHRoYXQgd2l0aCBHUlQgSFggdW5p dHMsIGEgR1RYMzI3IGFuZCBHNDMwIHRoYXQgQVJJTkMgaXMgbmVlZGVkLiAgSSBoYXZlIGEgd2ly aW5nIGhhcm5lc3MgZnJvbSBGYXN0U3RhY2sgdGhhdCBJIHRoaW5rIGFzc3VtZXMgQVJJTkMgc3Vw cG9ydC4gIExvb2tpbmcgZm9yd2FyZCB0byB0YWxraW5nIHRvIE5hdldvcnggdG9tb3Jyb3cuDQoN CkJpbGwgV2F0c29uDQoNCk9uIDMvMTEvMjAxMiA3OjM1IFBNLCBXaWxsaWFtIEN1cnRpcyB3cm90 ZToNCkJpbGwvVG9tLA0KDQpEaWQgeW91IGV2ZXIgcmVjZWl2ZSB5b3UgQURTLUIgdW5pdCBmcm9t IE5hdndvcng/ICBJJ20gc3RpbGwgd2FpdGluZyBvbiB3b3JkL2V0dXJuIG9mIG15IHVuaXQgc2Vu dCBpbiBmb3IgdXBncmFkZSBiYWNrIGluIFNlcHRlbWJlci4NCg0KPkFjY29yZGluZyB0byBCaWxs IE1vZmZpdCwgb25lIG9mIHRoZSBwbGFubmVkIHNvZnR3YXJlIHVwZ3JhZGVzIGlzIHRvIGdpdmUg R1BTIG91dHB1dC4gSSB3YW50IHRvIHVzZSB0aGlzIHRvIGRyaXZlIG15IEVMVC4gSG9wZWZ1bGx5 LCBpdCB3aWxsIGNvbWUgd2l0aCB0aGlzIHNvZnR3YXJlIHVwZ3JhZGUuIEdpdmVuIHRoYXQgd2Ug YWxyZWFkeSBoYXZlIHRvIGVudGVyIGEgbnVtYmVyIG9mIHNvZnR3YXJlIGNvbW1hbmRzIGludG8g dGhlIEFEUy02MDBCIGZvciBzZXR1cCBhbmQgSUQgcHVycG9zZXMsIEkgZG9u4oCZdCB1bmRlcnN0 YW5kIHdoeSBOYXZ3b3J4IGRvZXNu4oCZdCBtYWtlIHRoZSBzb2Z0d2FyZSBhdmFpbGFibGUgZm9y IG9ubGluZSBkb3dubG9hZGluZyBhcyBvcHBvc2VkIHRvIHJlcXVpcmluZyB0aGUgdW5pdCB0byBi ZSBzZW50IGJhY2sgaW4uDQo+VG9tIEguDQoNCj4+U3ViamVjdDogUmU6IE5hdndvcnggZGVsaXZl cmllcyAtIGFueWJvZHkgcmVjJ2QgYW55IHJlY2VudGx5Pw0KPj5JJ20gc3RpbGwgYXdhaXRpbmcg bXkgQURTLTYwMEIgdW5pdC4gU2VudCBteSBBRFMtNjAwIHVuaXQgZm9yIHVwZ3JhZGUgYmFjayBp biBTZXB0ZW1iZXIuIEkgZGlkIGdldCBhIHJlcGx5IGZyb20gQmlsbCBNb2ZmaXR0IHllc3RlcmRh eSB0aGF0ICJ0aGV5IGFyZSB0cnlpbmcgdG8gZ2V0IHRoZSBsYXRlc3Qgc29mdHdhcmUgaW50byBh bGwgdW5pdHMgcHJpb3IgdG8gc2hpcG1lbnQuIiBIZSBnYXZlIG1lIHRoZSBvcHRpb24gZm9yIHRo ZW0gdG8gc2hpcCBpdCBub3csIGJ1dCBpZiB0aGV5IGRpZCwgIkkgd291bGQgaGF2ZSB0byByZXR1 cm4gaXQgYmVmb3JlIGl0IHdpbGwgc3VwcG9ydCBhbiBmdXR1cmUgc29mdHdhcmUgdXBncmFkZXMs IG5ldyBmZWF0dXJlcywgZXRjLiIgSSBvcHRlZCB0byB3YWl0Lg0KPj4NCj4+V2lsbGlhbQ0KPj4t LS0tLS0tLS0tLQ0KDQoNCg0KDQoNCg0KPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQo9PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpjcy5jb208aHR0cDovL2NzLmNvbT4NCg0K PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KbWF0cm9uaWNzLmNvbS9jb250 cmlidXRpb248aHR0cDovL21hdHJvbmljcy5jb20vY29udHJpYnV0aW9uPg0KDQo9PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KDQoNCg0KDQo9PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PSAxMC1MaXN0IEVtYWlsIEZvcnVtIC0gcD4gbzpwPiBvcj9S VjEwLUxpc3QiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0ID09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09IHNwOyAgICAtIE1BVFJPTklDUyBX RUIgRk9SVU1TIC0gcD4gcDovL2ZvcnVtcy5tYXRyb25pY3MuY29tID09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09IHNwOyAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAt ID4gc3A7ICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4gdXRpb24i Pmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24gPT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCu+/ve+/ve+/vX7vv73vv70s77+977+977+9Je+/ ve+/vTTvv71NNH3vv70ecu+/ve+/ve+/ve+/ve+/vXsHKO+/ve+/ve+/ve+/vTheRV10ListEmbv v73vv71aK++/vWUseu+/vV4x77+9a++/vXjvv73vv73vv73vv73vv71X77+977+977+93rDWr++/ vQbvv73vv73vv71obu+/vTDvv73vv71hembvv73IuO+/ve+/ve+/vWLvv70rYnrvv70uchbvv70u Ky1Sf9K577+9HO+/vSpt77+977+977+977+9Yu+/ve+/vWrvv70hDu+/vSfvv73vv73vv73vv702 77+9Bu+/vTDvv73vv71q77+9QEDvv71o77+977+9IWrvv73vv73vv73ZrnIZ77+9chnvv73vv73m oa3vv73vv73vv71/77+9IDDvv73vv71r77+9eO+/ve+/ve+/vSbvv73Wr++/vQbvv73vv73vv71V 77+9Qu+/ve+/vW3vv73vv73vv73vv70gJmrvv73vv70nLHLvv73vv70177+94oGraO+/vRV10Ljv v73vv73vv70BNE4077+977+9WEBFORUgSSbvv716IO+/vWrvv70o77+916fvv73vv71s77+977+9 2opW77+977+977+977+9au+/vV5Z77+9xaLvv73vv73vv73vv71ree+/vW3vv73vv73vv71+77+9 77+9yZrvv73vv70n77+977+9HO+/vWht77+977+977+9fu+/ve+/vcma77+977+9J++/ve+/vRzv v71v77+9ListIO+/ve+/vSbvv70qJ1nvv73SiteT77+977+977+9yovvv73vv73vv73vv73vv73v v70e77+977+977+977+9Lu+/ve+/vSvvv73Gre+/vTrallfvv73vv73vv71Admjvv71qGu+/vX4b be+/ve+/ve+/ve+/vSDvv73vv73vv70n77+977+9HO+/vW/contr77+977+977+977+977+977+9 77+9f++/vSAw77+977+9a++/vXjvv73vv73vv70m77+977+9J++/ve+/ve+/ve+/vdio77+977+9 b++/ve+/ve+/ve+/ve+/vduh3L/vv73ZpQ0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRo ZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1 Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9h ZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVj aCBtb3JlOg0KXy09DQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRv cj9SVjEwLUxpc3QNCl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdF QiBGT1JVTVMgLQ0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhl IFdlYiBGb3J1bXMhDQpfLT0NCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20N Cl8tPQ0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT0NCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRl IC0NCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAt LT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQo ________________________________________________________________________________
Subject: Lightspeed engineering
Date: Mar 12, 2012
Having heard of difficulties in the past; has anyone current experience with the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? ________________________________________________________________________________
Subject: Re: Lightspeed engineering
Date: Mar 12, 2012
I have it on my IO-540-N1A5 built by Aerosport with 185 hours and have had no issues. I'm still impressed with the 20 rpm drop during the "mag" check. Even though my spark plugs looked close to new at 150 hours I swapped them for newer ones. ----- Original Message ----- From: DLM To: rv10-list(at)matronics.com Sent: Monday, March 12, 2012 1:21 PM Subject: RV10-List: Lightspeed engineering Having heard of difficulties in the past; has anyone current experience with the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Mar 12, 2012
I have had the same experience on the same engine after more than 300 hours. N661G On Mar 12, 2012, at 2:21 PM, DLM wrote: > Having heard of difficulties in the past; has anyone current experience with the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? > > > > ________________________________________________________________________________
Date: Mar 12, 2012
The 6 cylinder P-Mag will be available any day now. Oh check that, I was re calling a conversation I had with them at SNF and OSH and SNF and OSH and.. . I will be going P-Mag when FINALLY available. I love the one on my 8A. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of DLM Sent: Monday, March 12, 2012 12:22 PM Subject: RV10-List: Lightspeed engineering Having heard of difficulties in the past; has anyone current experience wit h the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? ________________________________________________________________________________
Subject: Anyone near Myrtle Beach SC or Naples Fl?
Date: Mar 12, 2012
I am planning a trip down the south of the US from California to Myrtle Beach, than down to Naples Florida in mid June. I am looking for smaller airports and anyone in the area that can recommend a place to park my plane in either/both locations. I have the route going out covered, but am wide open for returning from Florida to SoCal. I plan to stop 2-3 times on the way back and would welcome any feedback on places to stay for the night. Two daughters that would love a pool, if that helps! Pascal ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 12, 2012
Great product.... Can't say the same for their customer interface. If you c all, make sure you memorized the manual first, which I did. Then he will co ntinue to blame you for everything, just like he did for me when he drilled t he magnet holes in the wrong place. It was my fault because I didn't tell h im where the holes were supposed to be?!?!? Really!?!?! -Mike Kraus I really like the Lightspeed because I no longer have to talk to Klaus Sent from my iPhone On Mar 12, 2012, at 3:21 PM, "DLM" wrote: > Having heard of difficulties in the past; has anyone current experience wi th the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: Windscreen Gap
Date: Mar 12, 2012
It's the same reason you should never use a pencil for marking aluminum. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Friday, March 02, 2012 8:19 AM Subject: RV10-List: Re: Windscreen Gap --> "I used carbon fiber and standard West epoxy for the bottom windscreen fairing instead of fiberglass." I thought I read somewhere that you should not use carbon fiber cloth in direct contact with aluminum because it promotes corrosion. Not sure if this is a tale or based in fact - but probably worth further research. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=367629#367629 ________________________________________________________________________________
Subject: Re: Anyone near Myrtle Beach SC or Naples Fl?
Date: Mar 12, 2012
Try Sherman Texas for free car, great gas prices and good hotels nearby. Try meridian Mississippi for great gas prices, free airport van and nice downto wn restaurants. Rob Kermanj Sent from my iPhone On Mar 12, 2012, at 12:52 PM, "Pascal" wrote: > I am planning a trip down the south of the US from California to Myrtle Be ach, than down to Naples Florida in mid June. I am looking for smaller airpo rts and anyone in the area that can recommend a place to park my plane in ei ther/both locations. > > I have the route going out covered, but am wide open for returning from Fl orida to SoCal. I plan to stop 2-3 times on the way back and would welcome a ny feedback on places to stay for the night. Two daughters that would love a pool, if that helps! > > Pascal > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 12, 2012
New Braunfels, Tex. Has a great water park and river floating on the Guadalupe. The best place to park would be at San Marcos nearby. On Mar 12, 2012, at 2:52 PM, Pascal wrote: > I am planning a trip down the south of the US from California to Myrtle Beach, than down to Naples Florida in mid June. I am looking for smaller airports and anyone in the area that can recommend a place to park my plane in either/both locations. > > I have the route going out covered, but am wide open for returning from Florida to SoCal. I plan to stop 2-3 times on the way back and would welcome any feedback on places to stay for the night. Two daughters that would love a pool, if that helps! > > Pascal > > > > > ________________________________________________________________________________
Date: Mar 12, 2012
Learned at my IA renewal seminar last week that Electroair has 6 cylinder units shipping right now, direct from them or through Spruce. EIS-2 kit. Replaces either mag. http://www.aircraftspruce.com/catalog/eppages/electroair.php So at least there is another competitor. Electroair has their 4 cyl version certified for use on most Lycoming 4 cyl engines in certified aircraft with STC. On Mon, Mar 12, 2012 at 12:21 PM, DLM wrote: > Having heard of difficulties in the past; has anyone current experience > with the buying, installing and support process of the Plasma III six > cylinder system from Lightspeed engineering?**** > > * > > * > > ________________________________________________________________________________
Date: Mar 12, 2012
Don't know exactly what your Myrtle destination may be but I strongly suggest KCRE Grand Strand aka North Myrtle for the place to park and operate from. Ramp 66 is a long time, great FBO. Gas isn't cheap but they earn it with service. North Myrtle is a nicer part of the whole Myrtle Beach area but an easy drive into the honky tonk part. I don't recommend KMYR. Been in there a few times. It's really not closer and some things are awkward (like rental cars) because GA and Carrier ops are on opposite sides of the runway. The FBO was fine though and fuel is always a bit cheaper. I hope to do the opposite run sometime this year with Phoenix and Lake Tahoe on the agenda. All it takes is fuel.... Bill "it is spring!!" Watson On 3/12/2012 3:52 PM, Pascal wrote: > I am planning a trip down the south of the US from California to > Myrtle Beach, than down to Naples Florida in mid June. I am looking > for smaller airports and anyone in the area that can recommend a place > to park my plane in either/both locations. > I have the route going out covered, but am wide open for returning > from Florida to SoCal. I plan to stop 2-3 times on the way back and > would welcome any feedback on places to stay for the night. Two > daughters that would love a pool, if that helps! > Pascal > * > > > * ________________________________________________________________________________
Date: Mar 12, 2012
Per my discussion with Bill today, the ARINC isn't really needed in my config since the GRTs are the display devices. ARINC -may- display traffic on the GNS430 but he wasn't sure and Garmin isn't saying. I'm wired for it but nothing he said indicated that I should add the ARINC interface. Will just use the serial. Bill "really appreciating the FastStack hub and wiring harnesses" Watson On 3/12/2012 2:26 PM, RV Builder (Michael Sausen) wrote: > Hmm interesting, didn't know that. I wonder if there is any advantage > in using ARINC in that case such as weather. Might be able to save a > couple hundred bucks by ditching that interface. > > Michael > > On Mar 12, 2012, at 12:50 PM, "Bob Leffler" > wrote: > >> Still not a requirement. >> >> I have the display port (wx & traffic) going to the afs4500 and the >> tis port going to the gtn650. Both are serial. >> >> Arnic may have some other benefits, but for the $$. I stayed with the >> serial connections. >> >> Sent from my iPhone >> >> On Mar 12, 2012, at 11:32 AM, "RV Builder (Michael Sausen)" >> > wrote: >> >> You likely only need ARINC if you want to send traffic to a Garmin >> like the GNS or GTN. >> >> Michael >> >> ________________________________________________________________________________
Date: Mar 12, 2012
I nice stop out of Naples is Key West. Only one option for an airport but everything you need is there. A day trip is very feasible but given that it's main pastime involves drink, overnight options abound. It's one of those destinations that is so easy by plane but at least 4x further by car. The option that may trip you up is routing. Direct from Naples is over (warm) water but you can scoot over and follow the keys down from Miami. IMHO, flying over the gulf on say V601 is a lot more comfortable than flying V601 over the 'glades. On 3/12/2012 3:52 PM, Pascal wrote: > I am planning a trip down the south of the US from California to > Myrtle Beach, than down to Naples Florida in mid June. I am looking > for smaller airports and anyone in the area that can recommend a place > to park my plane in either/both locations. > I have the route going out covered, but am wide open for returning > from Florida to SoCal. I plan to stop 2-3 times on the way back and > would welcome any feedback on places to stay for the night. Two > daughters that would love a pool, if that helps! > ** ________________________________________________________________________________
Date: Mar 12, 2012
When was your last dealing with LSE? With Klaus? The reason I ask is that another shop here in Mesa AZ seems to think that they have greatly improved their customer relations??? _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Monday, March 12, 2012 12:56 PM Subject: Re: RV10-List: Lightspeed engineering Great product.... Can't say the same for their customer interface. If you call, make sure you memorized the manual first, which I did. Then he will continue to blame you for everything, just like he did for me when he drilled the magnet holes in the wrong place. It was my fault because I didn't tell him where the holes were supposed to be?!?!? Really!?!?! -Mike Kraus I really like the Lightspeed because I no longer have to talk to Klaus Sent from my iPhone On Mar 12, 2012, at 3:21 PM, "DLM" wrote: Having heard of difficulties in the past; has anyone current experience with the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? ________________________________________________________________________________
Date: Mar 12, 2012
On Mon, Mar 12, 2012 at 2:24 PM, Alan Mekler MD wrote: > > I used the RAM cradle and lil buddy suction cup. Works very well and easy > to remove. > Alan > > Sent from my iPhone > > On Mar 12, 2012, at 10:34 AM, Barry Marz wrote: > > > > > I want to mount my IPAD on the tunnel forward of the fuel selector. What > mounts work good in that location? Thanks Barry > > > > > > > > > > ________________________________________________________________________________
Date: Mar 12, 2012
It depends on the surface you are mounting it to. If it a smooth surface than the ram mount with the suction cup from Sporty's will work perfectly. I have used this set up on the wind shield of a Piper Archer and it works great. Easy to use and stays in place. Hope this helps. On Mon, Mar 12, 2012 at 7:02 PM, John Zazulka wrote: > > > On Mon, Mar 12, 2012 at 2:24 PM, Alan Mekler MD wrote: > >> --> RV10-List message post ed by: Alan Mekler MD >> >> I used the RAM cradle and lil buddy suction cup. Works very well and easy >> to remove. >> Alan >> >> Sent from my iPhone >> >> On Mar 12, 2012, at 10:34 AM, Barry Marz wrote: >> >> > >> > I want to mount my IPAD on the tunnel forward of the fuel selector. >> What mounts work good in that location? Thanks Barry >> > >> > >> > >> > >> >> >> >> >> >> > ________________________________________________________________________________
Date: Mar 12, 2012
I have worked directly with Klaus over the past few months to resolve an issue and order some parts. Very helpful and no problems at all. Albert Gardner N991RV Yuma, AZ BTW: An RV-10 (N410BR) cleared customs at Yuma today. I was hoping to meet him but they gassed up and took off. Climbed well, looked good and sounded great. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Monday, March 12, 2012 12:22 PM Subject: RV10-List: Lightspeed engineering Having heard of difficulties in the past; has anyone current experience with the buying, installing and support process of the Plasma III six cylinder system from Lightspeed engineering? ________________________________________________________________________________
Date: Mar 12, 2012
Yes, he does want you to read the manual.... I had an issue and he was wond erful.... on a Sunday, answered the phone, went through a detailed trouble shooting process, identified the problem, I fixed it, and that was 360 hour s ago.... dual plasma III's.- Just got back from SoCal today, 193kts on 9 .8 gph, 2,200rpm, 19"mp, 11,500'.... and, of course, a tail wind!=0ADon McD onald=0A =0A=0A________________________________=0A From: Michael Kraus <n22 3rv(at)wolflakeairport.net>=0ATo: "rv10-list(at)matronics.com" =0ASent: Monday, March 12, 2012 2:56 PM=0ASubject: Re: RV10-List: L ightspeed engineering=0A =0A=0AGreat product.... -Can't say the same for their customer interface. -If you call, make sure you memorized the manu al first, which I did. -Then he will continue to blame you for everything , just like he did for me when he drilled the magnet holes in the wrong pla ce. -It was my fault because I didn't tell him where the holes were suppo sed to be?!?!? -Really!?!?!=0A-Mike Kraus=0AI really like the Lightspeed because I no longer have to talk to Klaus=0A=0ASent from my iPhone=0A=0AOn Mar 12, 2012, at 3:21 PM, "DLM" wrote:=0A=0A=0A =0A>Having heard of difficulties in the past; has anyone current=0Aexperience with th e buying, installing and support process of the Plasma III=0Asix cylinder s 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Mar 12, 2012
Look at KTHA in southern middle TN. Great airport, courtesy van, great (and reasonable) motels, close to Jack Daniel and George Dickel distilleries. grumpy On Mar 12, 2012, at 2:52 PM, Pascal wrote: > I am planning a trip down the south of the US from California to Myrtle Beach, than down to Naples Florida in mid June. I am looking for smaller airports and anyone in the area that can recommend a place to park my plane in either/both locations. > > I have the route going out covered, but am wide open for returning from Florida to SoCal. I plan to stop 2-3 times on the way back and would welcome any feedback on places to stay for the night. Two daughters that would love a pool, if that helps! > > Pascal > > > > > ________________________________________________________________________________
Date: Mar 13, 2012
I have the system on my 540 and it works well, Only one dealing with Klaus and although it took awhile for him to get back to me he finally did and an swered my questions.I guess he is much better than he used to be. Good luck -=0A=0A151BJ 71 hrs and counting=0A=0A=========== ========== cs.com ============ ======================= matro nics.com/contribution=0A================= ==============0A ________________________________________________________________________________
From: "Creative Eagles Corp" <info@creative-eagles.com>
Subject: First Composite Pedal Kitplane
Date: Mar 13, 2012
Good day everyone! I thought that I mention here that the First Composite Pedal Kitplane is now available! The first model they called GOTCHA! Gotcha3.jpg Gotcha Composite Pedal Kitplane turns your kids tricycle into something wonderful and exciting rides. The Gotcha composite pedal kitplane is a bolt-in project into your kids existing tricycle. The kit consist of the fuselage, the propeller, seat back, wings, horizontal stabilizer and hardwares. Build your Gotcha now and enjoy watching your young pilots as they fly around the neighborhood. Their smile will touch your heart! Their website www.creative-eagles.com or contact at info@creative-eagles.com Gotcha Pedal Plane.JPG Unleash your young eagles and let them enjoy the power of flight. Enjoy! ________________________________________________________________________________
Date: Mar 13, 2012
So what is the advantage of these products? Are they really worth the extra dollars? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368386#368386 ________________________________________________________________________________
Date: Mar 13, 2012
Less weight and supposedly better reliability. Only time will tell on the r eliability part.=0A=0A=0A________________________________=0A From: rwwende =0ATo: rv10-list(at)matronics.com =0ASent: Tuesday, March 13 , 2012 12:39 PM=0ASubject: RV10-List: Re: Lightspeed engineering=0A =0A--> RV10-List message posted by: "rwwende" =0A=0ASo what is t he advantage of these products?- Are they really worth the extra dollars? =0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.co - - - - - - - - - - - - - - -Matt Dralle, List ====== ________________________________________________________________________________
Date: Mar 13, 2012
Also better performance, due to a hotter spark and variable timing. On Tue, Mar 13, 2012 at 3:24 PM, Bruce Johnson wrote: > Less weight and supposedly better reliability. Only time will tell on the > reliability part. > > ------------------------------ > *From:* rwwende > *To:* rv10-list(at)matronics.com > *Sent:* Tuesday, March 13, 2012 12:39 PM > *Subject:* RV10-List: Re: Lightspeed engineering > > > So what is the advantage of these products? Are they really worth the > extra dollars? > > > Read this topic online here: > > http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" > - List Contribution Web Site -** > > > * > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 14, 2012
Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. Michael On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" > wrote: Less weight and supposedly better reliability. Only time will tell on the r eliability part. ________________________________ From: rwwende <n7006w(at)gmail.com<mailto:n7006w(at)gmail.com>> Sent: Tuesday, March 13, 2012 12:39 PM Subject: RV10-List: Re: Lightspeed engineering gmail.com>> So what is the advantage of these products? Are they really worth the extr a dollars? Read this topic online here: http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Mar 14, 2012
Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now h ave 300+ hours on dual pMags and they have been flawless. First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not y et delivered my ignitions for the IO-540. I guess I'll put up with the mags for the first few hours. Carl On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" wrote: > Lightspeed has been around for quite some time so there is plenty of peopl e that can speak to the reliability of that system. > > Michael > > On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" w rote: > >> Less weight and supposedly better reliability. Only time will tell on the reliability part. >> >> From: rwwende <n7006w(at)gmail.com> >> To: rv10-list(at)matronics.com >> Sent: Tuesday, March 13, 2012 12:39 PM >> Subject: RV10-List: Re: Lightspeed engineering >> >> >> So what is the advantage of these products? Are they really worth the ex tra dollars? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - >> >> >> >> >> >> >> p://www.matronics.com/Navigator?RV10-List >> ics.com >> .matronics.com/contribution >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 14, 2012
There are many of us that have been talking to eMag for years and they keep saying that they are almost there. On the 6-cyl version, I guess they decided to go the certification route from the get-go, instead of making it available to the experimental market. =46rom the looks of it, the P-mag is going to be a great product. Again, the reliability will take time to know, but the concept is great and the backup power coming from the engine is a great idea. Timing them is also very easy. Can't wait to hear how they work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 14, 2012, at 6:44 AM, Carl Froehlich wrote: > Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now have 300+ hours on dual pMags and they have been flawless. > > First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not yet delivered my ignitions for the IO-540. I guess I'll put up with the mags for the first few hours. > > Carl > > > > On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" wrote: > >> Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. >> >> Michael >> >> On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" wrote: >> >>> Less weight and supposedly better reliability. Only time will tell on the reliability part. >>> >>> From: rwwende <n7006w(at)gmail.com> >>> To: rv10-list(at)matronics.com >>> Sent: Tuesday, March 13, 2012 12:39 PM >>> Subject: RV10-List: Re: Lightspeed engineering >>> >>> >>> So what is the advantage of these products? Are they really worth the extra dollars? >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - >>> >>> >>> >>> >>> >>> >>> p://www.matronics.com/Navigator?RV10-List >>> ics.com >>> .matronics.com/contribution >>> >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > ________________________________________________________________________________
Subject: Re: Lightspeed engineering)
Date: Mar 14, 2012
I talked with E-Mag yesterday. I was told to visit their booth at Sun-N-Fu n to see the IO-540 "production" P-Mag unit. (They are gearing up for production. I told them they needed to shot the e ngineer to go into production. :-) I hope they didn't take that literally.) I have my "deposit in" on their (just started) buyers list for the IO-540 P -Mag. I believe they will be taking names at their booth at Sun-N-Fun, or you can wait for a while to see how it goes. JIm Ayers Less Drag Products, Inc. Less Drag Special (modified HR2) IO-540 with 86 hours using Slick mags. -----Original Message----- From: Jesse Saint <jesse(at)saintaviation.com> Sent: Wed, Mar 14, 2012 4:50 am Subject: Re: RV10-List: Re: Lightspeed engineering There are many of us that have been talking to eMag for years and they keep saying that they are almost there. On the 6-cyl version, I guess they deci ded to go the certification route from the get-go, instead of making it ava ilable to the experimental market. From the looks of it, the P-mag is going to be a great product. Again, the reliability will take time to know, but the concept is great and the backup power coming from the engine is a great idea. Timing them is also very easy. Can't wait to hear how they work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 14, 2012, at 6:44 AM, Carl Froehlich wrote: Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now have 300+ hours on dual pMags and they have been flawless. First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not yet delivered my ignitions for the IO-540. I guess I'll put up with the ma gs for the first few hours. Carl On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" wrote: Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. Michael On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" wr ote: Less weight and supposedly better reliability. Only time will tell on the r eliability part. From: rwwende <n7006w(at)gmail.com> Sent: Tuesday, March 13, 2012 12:39 PM Subject: RV10-List: Re: Lightspeed engineering So what is the advantage of these products? Are they really worth the extr a dollars? Read this topic online here: http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - p://www.matronics.com/Navigator?RV10-List cs.com matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D -=3D - The RV10-List Email Forum - -=3D Use the Matronics List Features Navigator to browse -=3D the many List utilities such as List Un/Subscription, -=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, -=3D Photoshare, and much much more: -=3D -=3D --> http://www.matronics.com/Navigator?RV10-List -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D -=3D - MATRONICS WEB FORUMS - -=3D Same great content also available via the Web Forums! -=3D -=3D --> http://forums.matronics.com -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D -=3D - List Contribution Web Site - -=3D Thank you for your generous support! -=3D -Matt Dralle, List Admin. -=3D --> http://www.matronics.com/contribution -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ________________________________________________________________________________
Subject: FWF Fuel Line Torque Values
Date: Mar 14, 2012
I am wondering what the correct torque value for the FWF fuel and oil lines is. The Lycoming Overhaul Manual has fairly low torque values for "flexible hose or tube fittings " in the order of 30 to 35 in-lbs with corresponding values of over 100in-lb from Aeroquip and similar sources. Not sure which values to use. Thanks Niko ________________________________________________________________________________
Subject: Re: FWF Fuel Line Torque Values
Date: Mar 14, 2012
I used Aeroquip's settings for all lines. (brake, oil, fuel, etc) -----Original Message----- From: Nikolaos Napoli Sent: Wednesday, March 14, 2012 9:40 AM Subject: RV10-List: FWF Fuel Line Torque Values I am wondering what the correct torque value for the FWF fuel and oil lines is. The Lycoming Overhaul Manual has fairly low torque values for "flexible hose or tube fittings " in the order of 30 to 35 in-lbs with corresponding values of over 100in-lb from Aeroquip and similar sources. Not sure which values to use. Thanks Niko ________________________________________________________________________________
Date: Mar 14, 2012
Have they gotten their certification yet for the 6 cyl? They were working on it last year at Osh. grumpy On Mar 14, 2012, at 11:41 AM, Jim Ayers wrote: > I talked with E-Mag yesterday. I was told to visit their booth at Sun-N-Fun to see the IO-540 "production" P-Mag unit. > (They are gearing up for production. I told them they needed to shot the engineer to go into production. :-) > I hope they didn't take that literally.) > > I have my "deposit in" on their (just started) buyers list for the IO-540 P-Mag. I believe they will be taking names at their booth at Sun-N-Fun, or you can wait for a while to see how it goes. > > JIm Ayers > Less Drag Products, Inc. > Less Drag Special (modified HR2) IO-540 with 86 hours using Slick mags. > > -----Original Message----- > From: Jesse Saint <jesse(at)saintaviation.com> > To: rv10-list > Sent: Wed, Mar 14, 2012 4:50 am > Subject: Re: RV10-List: Re: Lightspeed engineering > > There are many of us that have been talking to eMag for years and they keep saying that they are almost there. On the 6-cyl version, I guess they decided to go the certification route from the get-go, instead of making it available to the experimental market. =46rom the looks of it, the P-mag is going to be a great product. Again, the reliability will take time to know, but the concept is great and the backup power coming from the engine is a great idea. Timing them is also very easy. Can't wait to hear how they work. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Mar 14, 2012, at 6:44 AM, Carl Froehlich wrote: > >> Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now have 300+ hours on dual pMags and they have been flawless. >> >> First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not yet delivered my ignitions for the IO-540. I guess I'll put up with the mags for the first few hours. >> >> Carl >> >> >> >> On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" wrote: >> >>> Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. >>> >>> Michael >>> >>> On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" wrote: >>> >>>> Less weight and supposedly better reliability. Only time will tell on the reliability part. >>>> >>>> From: rwwende <n7006w(at)gmail.com> >>>> To: rv10-list(at)matronics.com >>>> Sent: Tuesday, March 13, 2012 12:39 PM >>>> Subject: RV10-List: Re: Lightspeed engineering >>>> >>>> >>>> So what is the advantage of these products? Are they really worth the extra dollars? >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - >>>> >>>> >>>> >>>> >>>> >>>> >>>> p://www.matronics.com/Navigator?RV10-List >>>> ics.com >>>> .matronics.com/contribution >>>> >>> >>> >>> >> >> >> > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > > > > ________________________________________________________________________________
Date: Mar 15, 2012
E-Mag has been working on the certification for at least three years that I know. I don't know if they have the FAA certification. But I would guess that th ey are close. Jim Ayers -----Original Message----- From: Miller John <gengrumpy(at)aol.com> Sent: Wed, Mar 14, 2012 6:10 pm Subject: Re: IO-540 P-Mag (was Re: RV10-List: Re: Lightspeed engineering) Have they gotten their certification yet for the 6 cyl? They were working on it last year at Osh. grumpy On Mar 14, 2012, at 11:41 AM, Jim Ayers wrote: I talked with E-Mag yesterday. I was told to visit their booth at Sun-N-Fu n to see the IO-540 "production" P-Mag unit. (They are gearing up for production. I told them they needed to shot the e ngineer to go into production. :-) I hope they didn't take that literally.) I have my "deposit in" on their (just started) buyers list for the IO-540 P -Mag. I believe they will be taking names at their booth at Sun-N-Fun, or you can wait for a while to see how it goes. JIm Ayers Less Drag Products, Inc. Less Drag Special (modified HR2) IO-540 with 86 hours using Slick mags. -----Original Message----- From: Jesse Saint <jesse(at)saintaviation.com> Sent: Wed, Mar 14, 2012 4:50 am Subject: Re: RV10-List: Re: Lightspeed engineering There are many of us that have been talking to eMag for years and they keep saying that they are almost there. On the 6-cyl version, I guess they deci ded to go the certification route from the get-go, instead of making it ava ilable to the experimental market. From the looks of it, the P-mag is going to be a great product. Again, the reliability will take time to know, but the concept is great and the backup power coming from the engine is a great idea. Timing them is also very easy. Can't wait to hear how they work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 14, 2012, at 6:44 AM, Carl Froehlich wrote: Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now have 300+ hours on dual pMags and they have been flawless. First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not yet delivered my ignitions for the IO-540. I guess I'll put up with the ma gs for the first few hours. Carl On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" wrote: Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. Michael On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" wr ote: Less weight and supposedly better reliability. Only time will tell on the r eliability part. From: rwwende <n7006w(at)gmail.com> Sent: Tuesday, March 13, 2012 12:39 PM Subject: RV10-List: Re: Lightspeed engineering So what is the advantage of these products? Are they really worth the extr a dollars? Read this topic online here: http://forums.matronics.com//www.matronics.com/Navigator?RV10-List" - List Contribution Web Site - p://www.matronics.com/Navigator?RV10-List cs.com matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D -=3D - The RV10-List Email Forum - -=3D Use the Matronics List Features Navigator to browse -=3D the many List utilities such as List Un/Subscription, -=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, -=3D Photoshare, and much much more: -=3D -=3D --> http://www.matronics.com/Navigator?RV10-List -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D -=3D - MATRONICS WEB FORUMS - -=3D Same great content also available via the Web Forums! -=3D -=3D --> http://forums.matronics.com -=3D -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D -=3D - List Contribution Web Site - -=3D Thank you for your generous support! -=3D -Matt Dralle, List Admin. -=3D --> http://www.matronics.com/contribution -=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ________________________________________________________________________________
Date: Mar 15, 2012
c25pcCA+PiBJIGd1ZXNzIEknbGwgcHV0IHVwIHdpdGggdGhlIG1hZ3MgZm9yIHRoZSBmaXJzdCBm ZXcgaG91cnMuDQoNClRoYXQgaXMgd2hhdCBJIHNhaWQuIDMwMCsgaG91cnMgbGF0ZXIuIEJ1dCBJ IGxvdmUgbXkgUC1NYWcgb24gdGhlIDhBLg0KU3RpbGwgd2FpdGluZ+KApg0KUg0KDQpGcm9tOiBv d25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDYXJsIEZyb2VobGljaA0KU2Vu dDogV2VkbmVzZGF5LCBNYXJjaCAxNCwgMjAxMiAzOjQ1IEFNDQpUbzogcnYxMC1saXN0QG1hdHJv bmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFJlOiBMaWdodHNwZWVkIGVuZ2luZWVy aW5nDQoNClRocmVlIGhhcmQgZmFpbHVyZXMgaW4gMzUwIGhvdXJzLCBkdWFsIFBsYXNtYSBJSSsg aW5zdGFsbCBpbiBteSA4QS4gIEkgbm93IGhhdmUgMzAwKyAgaG91cnMgb24gZHVhbCBwTWFncyBh bmQgdGhleSBoYXZlIGJlZW4gZmxhd2xlc3MuDQoNCkZpcnN0IGVuZ2luZSBzdGFydCBvbiB0aGUg UlYtMTAgaXMgMi0zIHdlZWtzIGF3YXkgYW5kIEJyYWQgYXQgZU1hZyBoYXMgbm90IHlldCBkZWxp dmVyZWQgbXkgaWduaXRpb25zIGZvciB0aGUgSU8tNTQwLiAgSSBndWVzcyBJJ2xsIHB1dCB1cCB3 aXRoIHRoZSBtYWdzIGZvciB0aGUgZmlyc3QgZmV3IGhvdXJzLg0KDQpDYXJsDQoNCg0KT24gTWFy IDEzLCAyMDEyLCBhdCAxMDowNyBQTSwgIlJWIEJ1aWxkZXIgKE1pY2hhZWwgU2F1c2VuKSIgPHJ2 YnVpbGRlckBzYXVzZW4ubmV0PG1haWx0bzpydmJ1aWxkZXJAc2F1c2VuLm5ldD4+IHdyb3RlOg0K TGlnaHRzcGVlZCBoYXMgYmVlbiBhcm91bmQgZm9yIHF1aXRlIHNvbWUgdGltZSBzbyB0aGVyZSBp cyBwbGVudHkgb2YgcGVvcGxlIHRoYXQgY2FuIHNwZWFrIHRvIHRoZSByZWxpYWJpbGl0eSBvZiB0 aGF0IHN5c3RlbS4NCg0KTWljaGFlbA0KDQpPbiBNYXIgMTMsIDIwMTIsIGF0IDU6MzMgUE0sICJC cnVjZSBKb2huc29uIiA8YnJ1Y2UxaHdqb2huc29uQHlhaG9vLmNvbTxtYWlsdG86YnJ1Y2UxaHdq b2huc29uQHlhaG9vLmNvbT4+IHdyb3RlOg0KTGVzcyB3ZWlnaHQgYW5kIHN1cHBvc2VkbHkgYmV0 dGVyIHJlbGlhYmlsaXR5LiBPbmx5IHRpbWUgd2lsbCB0ZWxsIG9uIHRoZSByZWxpYWJpbGl0eSBw YXJ0Lg0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KRnJvbTogcnd3ZW5kZSA8 bjcwMDZ3QGdtYWlsLmNvbTxtYWlsdG86bjcwMDZ3QGdtYWlsLmNvbT4+DQpUbzogcnYxMC1saXN0 QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU2VudDogVHVl c2RheSwgTWFyY2ggMTMsIDIwMTIgMTI6MzkgUE0NClN1YmplY3Q6IFJWMTAtTGlzdDogUmU6IExp Z2h0c3BlZWQgZW5naW5lZXJpbmcNCg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdlIHBvc3RlZCBieTog InJ3d2VuZGUiIDxuNzAwNndAZ21haWwuY29tPG1haWx0bzpuNzAwNndAZ21haWwuY29tPj4NCg0K U28gd2hhdCBpcyB0aGUgYWR2YW50YWdlIG9mIHRoZXNlIHByb2R1Y3RzPyAgQXJlIHRoZXkgcmVh bGx5IHdvcnRoIHRoZSBleHRyYSBkb2xsYXJzPw0KDQoNCg0KDQpSZWFkIHRoaXMgdG9waWMgb25s aW5lIGhlcmU6DQoNCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS8vd3d3Lm1hdHJvbmljcy5j b20vTmF2aWdhdG9yP1JWMTAtTGlzdDxodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vd3d3Lm1h dHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdD4iICAgICAgICAgICAgIC0gTGlzdCBDb250 cmlidXRpb24gV2ViIFNpdGUgLQ0KDQoNCg0KDQoNCg0KDQoNCg0KDQpwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQppY3MuY29tPGh0dHA6Ly9pY3MuY29tPg0KDQou bWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KXy09 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0QNCg0KXy09M0QgICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0N Cg0KXy09M0QgVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJv d3NlDQoNCl8tPTNEIHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sDQoNCl8tPTNEIEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dz ZSwgQ2hhdCwgRkFRLA0KDQpfLT0zRCBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQoN Cl8tPTNEDQoNCl8tPTNEICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ UlYxMC1MaXN0PDNEJTIyaHR0cDovd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlz dCUyMj4NCg0KXy09M0QNCg0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0KXy09M0QgICAgICAgICAgICAgICAtIE1B VFJPTklDUyBXRUIgRk9SVU1TIC0NCg0KXy09M0QgU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZh aWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09M0QNCg0KXy09M0QgICAtLT4gaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tPDNEJTIyaHR0cDovZm9ydW1zLm1hdHJvbmljcy5jb20lMjI+ DQoNCl8tPTNEDQoNCl8tPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEDQoNCl8tPTNEICAgICAgICAgICAgIC0gTGlzdCBDb250 cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0zRCAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3Vz IHN1cHBvcnQhDQoNCl8tPTNEICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJh bGxlLCBMaXN0IEFkbWluLg0KDQpfLT0zRCAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v Y29udHJpYnV0aW9uPDNEJTIyaHR0cDovd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uJTIy Pg0KDQpfLT0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRA0KDQoNCg= ________________________________________________________________________________
Date: Mar 15, 2012
Jessie, >From my last converstion (late-February) eMag is now going to offer an expe rimental and a certified version. That was a surprise to me. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Jesse Saint Sent: Wednesday, March 14, 2012 4:48 AM Subject: Re: RV10-List: Re: Lightspeed engineering There are many of us that have been talking to eMag for years and they keep saying that they are almost there. On the 6-cyl version, I guess they deci ded to go the certification route from the get-go, instead of making it ava ilable to the experimental market. From the looks of it, the P-mag is going to be a great product. Again, the reliability will take time to know, but the concept is great and the backup power coming from the engine is a great idea. Timing them is also very easy. Can't wait to hear how they work. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 14, 2012, at 6:44 AM, Carl Froehlich wrote: Three hard failures in 350 hours, dual Plasma II+ install in my 8A. I now have 300+ hours on dual pMags and they have been flawless. First engine start on the RV-10 is 2-3 weeks away and Brad at eMag has not yet delivered my ignitions for the IO-540. I guess I'll put up with the ma gs for the first few hours. Carl On Mar 13, 2012, at 10:07 PM, "RV Builder (Michael Sausen)" > wrote: Lightspeed has been around for quite some time so there is plenty of people that can speak to the reliability of that system. Michael On Mar 13, 2012, at 5:33 PM, "Bruce Johnson" > wrote: Less weight and supposedly better reliability. Only time will tell on the r eliability part. ________________________________ From: rwwende <n7006w(at)gmail.com<mailto:n7006w(at)gmail.com>> Sent: Tuesday, March 13, 2012 12:39 PM Subject: RV10-List: Re: Lightspeed engineering gmail.com>> So what is the advantage of these products? Are they really worth the extr a dollars? Read this topic online here: http://forums.matronics.com//www.matronics.com/Navigator?RV10-List orums.matronics.com/www.matronics.com/Navigator?RV10-List>" - L ist Contribution Web Site - p://www.matronics.com/Navigator?RV10-List ics.com<http://ics.com/> .matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D atronics.com/Navigator?RV10-List%22> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 2> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D s.com/contribution%22> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: rudder trim
Date: Mar 15, 2012
I just installed a rudder trim today that Aerosport Products made. I am testing the design and was very pleased with the results. I didn't want the electric rudder trim since it was a lot of labor and put weight in the rudder. I was holding out for a bias system that used the entire rudder. I know builders who installed the electric version and like them but this new product was just what I was looking for. It literally took me 30 minutes to install and worked perfect. I didn't know where to set it for the first test run so I took off normally. At cruise I dialed it in and immediately was grateful to pull my foot off the right rudder where I had been resting it for the 180 hours I have on the plane. This system uses a dial which is geared to two cables attached to springs and finally hooked on to two clamped arms on the rudder crossover tubes. I can dial in the cruise descent and cruise climb in a few seconds. It is very compact as you can see in the photo. I'm already happy with it and I only flew with it for a fairly short flight today. I took a quick pic with my iphone and will get some better pics later. Feel free to contact me with any questions. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368664#368664 Attachments: http://forums.matronics.com//files/photo_2_164.jpg ________________________________________________________________________________
Date: Mar 15, 2012
Thank you everyone for your replies. I have applied two layers of Glass and then built up the side of the Glare shield so that the gap is only around 1/8 ". I will be using Sikaflex 295 UV and then the Glass layup as per the plans. cheers John MacCallum 41016 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368665#368665 ________________________________________________________________________________
Subject: Re: rudder trim
Date: Mar 17, 2012
It looks like the same system that I installed - bought from M.L. Skunk Works several years ago. It works great. I will admit that the RV-10 needs very little rudder trim in cruise that I can see. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368764#368764 ________________________________________________________________________________
Date: Mar 17, 2012
Not really, the concept is similar. The control head is significantly smaller and my very biased opinion is that it's better engineered. Sent from my iPhone On Mar 17, 2012, at 9:29 AM, "johngoodman" wrote: It looks like the same system that I installed - bought from M.L. Skunk Works several years ago. It works great. I will admit that the RV-10 needs very little rudder trim in cruise that I can see. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368764#368764 ________________________________________________________________________________
Date: Mar 17, 2012
Subject: Florida Transition Trainng
Hi While hiding from winter for a couple of weeks in Florida, i decided to do a few hours of transition training with David Maib. To say that I was pleased with the experience would be an understatement. David's air conditioned -10 was a pleasure to fly. His teaching style is relaxed and not the least bit stressful. I was very happy that he focussed not just on his syllabus but also on what I wanted (lots of landings and getting a good feel for the a/c in various flight modes). I wanted to know what a -10 should feel like so I can be prepared for my own a/c. Flying an approach to the shuttle strip at Kennedy was a bonus. IMHO, David is a great choice for transition training. Cheers Les ________________________________________________________________________________
Subject: Re: Florida Transition Trainng
Date: Mar 17, 2012
I feel the same. Mine was in November 2011. 25 kt direct crosswind with the family was no problem recently, after my windy two days with David. Wind was what I was hoping for, but sure did not expect to fly, as my primary flight training was always canceled above 10 knots. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368796#368796 ________________________________________________________________________________
Date: Mar 18, 2012
Subject: Flap actuation
I have the Van's flap system (reflex, zero degrees, half flaps, full flaps) . -A momentary press down on the panel flap switch will take them down to the next position -- up until a month ago so that now, in flight, reflex t o zero to half is still the same but to go from half to full flaps I have t o press and hold the switch down until full flaps is achieved. -However, on the ground taxiing or at standstill, I don't have to hold the switch to go from half to full, it'll go with the momentary press like it always did heretofore. -Suggestions anyone? ________________________________________________________________________________
Date: Mar 18, 2012
Subject: Re: Flap actuation
Curtis, I also have the same flap system in my RV-10. I have not had this issue but can only imagine that the limit switch that falls into the grooves on your flap position rod is barely being kept in place until the next groove. In flight its possible the air loads flex things in the system just enough that the switch won't engage. A simple tweak of the metal arm on the switch should do the trick. Try moving the switch and listening for the click when it's in a groove. If you have to move the metal arm almost all the way before it clicks then bend it a little so it clicks sooner. I think this will solve your issue. Matthew Collier Fibercraft Inc. www.fibercraft.us ivdiggs(at)gmail.com On Sun, Mar 18, 2012 at 3:11 PM, curtis groote wrote: > I have the Van's flap system (reflex, zero degrees, half flaps, full > flaps). A momentary press down on the panel flap switch will take them > down to the next position -- up until a month ago so that now, in flight, > reflex to zero to half is still the same but to go from half to full flaps > I have to press and hold the switch down until full flaps is achieved. > However, on the ground taxiing or at standstill, I don't have to hold the > switch to go from half to full, it'll go with the momentary press like it > always did heretofore. Suggestions anyone? > > * > > * > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 18, 2012
I tried adjusting the rod a few times and it seems to help for a while. But it's a pain taking the tunnel cover off and on so I got in the habit of just holding the switch for a half-second or so. I hold it down while saying "flaps 1", "flaps 2", etc. It has to do with motoring the rod past the groove long enough to activate the switch. For a while we had a problem with the flaps getting stuck down. But that always seemed to resolve itself before we had to do anything about it. The microswitch must have jiggled back to where it belonged, and that was years ago. These days we don't see that happening any more. --Dave Saylor On Sun, Mar 18, 2012 at 3:11 PM, curtis groote wrote: > I have the Van's flap system (reflex, zero degrees, half flaps, full > flaps). A momentary press down on the panel flap switch will take them > down to the next position -- up until a month ago so that now, in flight, > reflex to zero to half is still the same but to go from half to full flaps > I have to press and hold the switch down until full flaps is achieved. > However, on the ground taxiing or at standstill, I don't have to hold the > switch to go from half to full, it'll go with the momentary press like it > always did heretofore. Suggestions anyone? > > * > > * > > ________________________________________________________________________________
Subject: N541RV phase1 complete
Date: Mar 18, 2012
Phase 1 is complete, all went very well. First family trip this weekend to pick up my daughter for spring break from college was absolutely awesome. My wife, younger daughter and I went to get my older daughter. The 11 hour round trip car ride was replaced by 3.3 hours of RV-10 action. KXLL (Allentown PA) to KGKJ (Meadville PA). We all had a blast and as a bonus we had hot dogs at Eddie=99s Famous Hot Dog Stand, now in business for 65 years, (within walking distance from the airport). (highly recommended stop if you are every in northwestern PA). The smiles on their in-flight self-portrait says it all... Bob Newman N541RV RV grin set on MAX. oh yeah, the technical details: 171 knots TAS @ 8000 ft, WOT. 12.4 gph, both ways. this airplane rocks! ________________________________________________________________________________
Subject: Inlet rings
Date: Mar 18, 2012
In the eternal quest to make the Sam James cowl functional I am on the hunt for some inlet rings. Looking to increase the inlet area so ideally a 5.5" diameter ring would work, but I am willing to try up to a 6" ring. Anyone out there have a production run with a spare set leftover they might be willing to part with? PM or email me at scout019(at)msn.com if you have some or know where they might be procured. Thanks. Eric Kallio N518RV Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368859#368859 ________________________________________________________________________________
Date: Mar 18, 2012
Subject: Re: N541RV phase1 complete
Great news to read the progress and review the grins. John 40600 On Mar 18, 2012 5:49 PM, "bob-tcw" wrote: > Phase 1 is complete, all went very well. First family trip this > weekend to pick up my daughter for spring break from college was absolute ly > awesome. My wife, younger daughter and I went to get my older > daughter. The 11 hour round trip car ride was replaced by 3.3 hours of > RV-10 action. KXLL (Allentown PA) to KGKJ (Meadville PA). We all h ad > a blast and as a bonus we had hot dogs at Eddie=92s Famous Hot Dog Stand, > now in business for 65 years, (within walking distance from the airport) . > (highly recommended stop if you are every in northwestern PA). > The smiles on their in-flight self-portrait says it all... > > > Bob Newman > N541RV > RV grin set on MAX. > > oh yeah, the technical details: 171 knots TAS @ 8000 ft, WOT. 12.4 gph, > both ways. this airplane rocks! > ________________________________________________________________________________
Date: Mar 19, 2012
I'm having roughly the same problem. Just doing it manually now. Bill On 3/18/2012 6:11 PM, curtis groote wrote: > I have the Van's flap system (reflex, zero degrees, half flaps, full > flaps). A momentary press down on the panel flap switch will take > them down to the next position -- up until a month ago so that now, in > flight, reflex to zero to half is still the same but to go from half > to full flaps I have to press and hold the switch down until full > flaps is achieved. However, on the ground taxiing or at standstill, I > don't have to hold the switch to go from half to full, it'll go with > the momentary press like it always did heretofore. Suggestions anyone? > * > > > * ________________________________________________________________________________
Date: Mar 19, 2012
It is great to really go somewhere, especially with all four seats filled. No crazy interstate drivers to watch out for while getting 15 mpg. How many kids get to say my Dad, Mom and Sister picked me up from college in our plane. I know you are loving that plane as much as I am. Now for some summer trip plans. We are planning FL and SW US(2 separate trips). -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368872#368872 ________________________________________________________________________________
Date: Mar 19, 2012
My Show Planes from Vans has always required two taps down to go from half to full. I will pull that whole mess out and install a manual switch if I have any additional faults. One less wire and much simpler to troublehoot or repair. As for landing and takeoff with or without flaps, it is no problem with a CS prop and 260 hp. Having a manual switch would not be any more distracting than dealing with this. It may just be a matter of the micro switch rods not having the cutouts in the right place at the right time. Anybody troubleshot this problem yet? -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368873#368873 ________________________________________________________________________________
Date: Mar 19, 2012
This is the first email I've read of this thread. Do you really have to hold the switch down the whole way, or does it just have to be more than the normal press? I have seen it where you had to hold it down for a little longer than normal for it to get past the limit switch on the rod. I know that when using a position sensor, the flap position on the ground and the position in flight does not match. I assume that is because on the ground gravity is pulling the flaps as far down as it can, and in the air the relative wind is pushing the flaps up as far as it can, so that may have something to do with it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 19, 2012, at 12:57 AM, Bill Watson wrote: > I'm having roughly the same problem. Just doing it manually now. > > Bill > > On 3/18/2012 6:11 PM, curtis groote wrote: >> >> I have the Van's flap system (reflex, zero degrees, half flaps, full flaps). A momentary press down on the panel flap switch will take them down to the next position -- up until a month ago so that now, in flight, reflex to zero to half is still the same but to go from half to full flaps I have to press and hold the switch down until full flaps is achieved. However, on the ground taxiing or at standstill, I don't have to hold the switch to go from half to full, it'll go with the momentary press like it always did heretofore. Suggestions anyone? >> >> >> > > > > ________________________________________________________________________________
Date: Mar 19, 2012
This might be a good time to plug Vertical Power. With the VP-200 you set 4 total positions and have a sensor for location. You can click the switch down 3 times and it will go down all the way. Click twice to go down 2 "notches". Click up once to go all the way up. Very nice to work with. I have not affiliation with VP. I just really like flying with their equipment. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 19, 2012, at 8:11 AM, "rv10flyer" wrote: > > My Show Planes from Vans has always required two taps down to go from half to full. I will pull that whole mess out and install a manual switch if I have any additional faults. One less wire and much simpler to troublehoot or repair. As for landing and takeoff with or without flaps, it is no problem with a CS prop and 260 hp. Having a manual switch would not be any more distracting than dealing with this. It may just be a matter of the micro switch rods not having the cutouts in the right place at the right time. Anybody troubleshot this problem yet? > > -------- > Wayne Gillispie, A&P 05/93 PP 10/08 > 40983SB 12/1/2009-12/1/2011 > N715WD 382nd Flying. TT= 37 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368873#368873 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 19, 2012
Subject: Re: Inlet rings
Eric, Are you familiar with the inlet rings Alan Bickle was marketing through Airflow Technologies? He didn't get enough interest to carry on, but I made the rings for him. If you want some, I could make a run. Contact me offline or at Plane Innovations LLC. (435) 826-4662 www.planeinnovations.com Paul Bowmar On Mar 18, 2012, at 8:04 PM, Eric_Kallio wrote: > > In the eternal quest to make the Sam James cowl functional I am on the hunt for some inlet rings. Looking to increase the inlet area so ideally a 5.5" diameter ring would work, but I am willing to try up to a 6" ring. Anyone out there have a production run with a spare set leftover they might be willing to part with? PM or email me at scout019(at)msn.com if you have some or know where they might be procured. Thanks. > > Eric Kallio > N518RV > Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=368859#368859 > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 19, 2012
Yup. -Have to hold the switch down the whole way or the flaps stop moveme nt on release.=0A=0A=0A________________________________=0A From: Jesse Sain t =0ATo: rv10-list(at)matronics.com =0ASent: Monday, March 19, 2012 6:11 AM=0ASubject: Re: RV10-List: Flap actuation=0A =0A=0AT his is the first email I've read of this thread. Do you really have to hold the switch down the whole way, or does it just have to be more than the no rmal press? I have seen it where you had to hold it down for a little longe r than normal for it to get past the limit switch on the rod. I know that w hen using a position sensor, the flap position on the ground and the positi on in flight does not match. I assume that is because on the ground gravity is pulling the flaps as far down as it can, and in the air the relative wi nd is pushing the flaps up as far as it can, so that may have something to do with it.=0A=0A=0AJesse Saint=0ASaint Aviation, Inc.=0Ajesse@saintaviatio n.com=0AC: 352-427-0285=0AF: 815-377-3694 =0A=0AOn Mar 19, 2012, at 12:57 A M, Bill Watson wrote:=0A=0AI'm having roughly the same problem.- Just doi ng it manually now.=0A>=0A>Bill=0A>=0A>On 3/18/2012 6:11 PM, curtis groote wrote: =0A>I have the Van's flap system (reflex, zero degrees, half flaps, full flaps). -A momentary press down on the panel flap switch will take t hem down to the next position -- up until a month ago so that now, in fligh t, reflex to zero to half is still the same but to go from half to full fla ps I have to press and hold the switch down until full flaps is achieved. -However, on the ground taxiing or at standstill, I don't have to hold th e switch to go from half to full, it'll go with the momentary press like it =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D ________________________________________________________________________________
Date: Mar 19, 2012
Yes two of us here had that problem of flaps working in air but not on grou nd.Little pressures on the flaps on ground and they would start moving agai n.After I figured out what was happening I sent mine back and they fixed it and sent two more washers to keep the actuator from rotating so far and we aring away at the guide holes. Had nothing to do with too much grease. That seems to have fixed the problem. for both of ours. And yes its one Hit down to get neutral the second is half flap and third is full flaps. Alll this was happening around 150 -200 hrs. Patrick Thyssen N15PT 407 hrs. --- On Mon, 3/19/12, rv10flyer wrote: From: rv10flyer <wayne.gillispie(at)gmail.com> Subject: RV10-List: Re: Flap actuation Date: Monday, March 19, 2012, 7:11 AM My Show Planes from Vans has always required two taps down to go from half to full. I will pull that whole mess out and install a manual switch if I h ave any additional faults. One less wire and much simpler to troublehoot or repair. As for landing and takeoff with or without flaps, it is no problem with a CS prop and 260 hp. Having a manual switch would not be any more di stracting than dealing with this. It may just be a matter of the micro swit ch rods not having the cutouts in the right place at the right time. Anybod y troubleshot this problem yet? -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=368873#368873 le, List Admin. ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Mar 19, 2012
The problem is that your actuator pivots a slight bit when you are putting the flaps down and because the 1/8' sensor rod with notches is worn now the twist that happens when the air flow is hitting the flaps when flying makes it react differently then just sitting. You will need to get into your tunnel area and re-adjust the sensor unit which mounts to the flap motor. This is a problem with the Show planes unit after a while. Operate your flaps and watch how the unit twist and you will see it. You need to stop the the flap rod end from rotating so much. Geoff Geoff Combs Aerosport Modeling & Design www.aerosportmodeling.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of curtis groote Sent: Monday, March 19, 2012 10:44 AM Subject: Re: RV10-List: Flap actuation Yup. Have to hold the switch down the whole way or the flaps stop movement on release. _____ From: Jesse Saint <jesse(at)saintaviation.com> Sent: Monday, March 19, 2012 6:11 AM Subject: Re: RV10-List: Flap actuation This is the first email I've read of this thread. Do you really have to hold the switch down the whole way, or does it just have to be more than the normal press? I have seen it where you had to hold it down for a little longer than normal for it to get past the limit switch on the rod. I know that when using a position sensor, the flap position on the ground and the position in flight does not match. I assume that is because on the ground gravity is pulling the flaps as far down as it can, and in the air the relative wind is pushing the flaps up as far as it can, so that may have something to do with it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 19, 2012, at 12:57 AM, Bill Watson wrote: I'm having roughly the same problem. Just doing it manually now. Bill On 3/18/2012 6:11 PM, curtis groote wrote: I have the Van's flap system (reflex, zero degrees, half flaps, full flaps). A momentary press down on the panel flap switch will take them down to the next position -- up until a month ago so that now, in flight, reflex to zero to half is still the same but to go from half to full flaps I have to press and hold the switch down until full flaps is achieved. However, on the ground taxiing or at standstill, I don't have to hold the switch to go from half to full, it'll go with the momentary press like it always did heretofore. Suggestions anyone? http://www.matronics.com/Navigator?RV10-List 3D=========================3 D====================D===== 3D=========================3 D======================== == _======================== ========================= ________________________________________________________________________________
Date: Mar 20, 2012
Subject: Navworx maintenance terminal - USB - Com Port adapters?
I've just physically installed my Navworx ADS-B box and now need to configure it. Neither of my laptops have the required Com port. Short of transporting an old tower system down to the hangar, has anyone used a USB - Com port adaptor? Price? I've started researching it but if anyone has some experience to share... please do. Bill Watson ________________________________________________________________________________
Date: Mar 20, 2012
Subject: Re: Navworx maintenance terminal - USB - Com Port adapters?
Similar problem here--I have to borrow back an old laptop from my daughter to do the updates--it's the only windows laptop in the house. I use a USB adapter from Staples. There's no P/N on it, and it actually has the Staples logo engraved in the plastic shell. It works fine. Sure would be nice to have an app for that... --Dave Saylor On Tue, Mar 20, 2012 at 8:12 AM, Bill Watson wrote: > > I've just physically installed my Navworx ADS-B box and now need to > configure it. > > Neither of my laptops have the required Com port. Short of transporting > an old tower system down to the hangar, has anyone used a USB - Com port > adaptor? Price? > > I've started researching it but if anyone has some experience to share... > please do. > > Bill Watson > > ________________________________________________________________________________
Date: Mar 20, 2012
Yes, they work fine most of the time. I've used Belkin ones with luck, and some cheap Chinese ones I bought on Ebay I think with "prolific" chipsets that worked too. If you're in a hurry I'd buy one locally and pay maybe $20-30 and get a good one. If you just want spares and want to have something sitting around, you can get them for maybe $2-3 on Ebay I think. Tim On 3/20/2012 10:12 AM, Bill Watson wrote: > > I've just physically installed my Navworx ADS-B box and now need to > configure it. > > Neither of my laptops have the required Com port. Short of transporting > an old tower system down to the hangar, has anyone used a USB - Com port > adaptor? Price? > > I've started researching it but if anyone has some experience to > share... please do. > > Bill Watson > > ________________________________________________________________________________
Date: Mar 20, 2012
An app would just require even more software to run on the device, and that could lead to more issues with FAA certification, and more delays in getting the config interface working when they tweak software. While serial configuration is old technology, on a screenless box like that, it's actually perfect for keeping low overhead. It just isn't as nice that laptops dropped support for Serial ports. I configure things all day long at work using serial ports to get them running on the network. I actually far prefer command-line text configuration to all the stupid web interfaces out there these days. Tim On 3/20/2012 10:27 AM, Dave Saylor wrote: > Similar problem here--I have to borrow back an old laptop from my > daughter to do the updates--it's the only windows laptop in the house. > I use a USB adapter from Staples. There's no P/N on it, and it actually > has the Staples logo engraved in the plastic shell. It works fine. > > Sure would be nice to have an app for that... > > --Dave Saylor > ________________________________________________________________________________
Date: Mar 20, 2012
Remembering back to something you and I talked about before Dave, you're right on one thing...what would be nice is to find a wi-fi/bluetooth type box you could plug in to the serial port and configure wirelessly from an iPad. That would be cool. I use an iPad a lot to configure network devices using telnet and ssh, so it would be easy to do if the box could handle telnet. I know they are out there, too....I just don't have one. Then you could use an app like "iSSH" on the ipad to configure the navworx. FWIW, at work I ordered a bunch of ethernet to serial devices so we could remotely configure network devices at other sites. Something like that would work, but you wouldn't want to spend the money we spent on them. Tim On 3/20/2012 10:27 AM, Dave Saylor wrote: > Similar problem here--I have to borrow back an old laptop from my > daughter to do the updates--it's the only windows laptop in the house. > I use a USB adapter from Staples. There's no P/N on it, and it actually > has the Staples logo engraved in the plastic shell. It works fine. > > Sure would be nice to have an app for that... > > --Dave Saylor > > ________________________________________________________________________________
Subject: Furnace Creek L06
Date: Mar 20, 2012
The airport is on the NW corner of a spring fed oasis on the East end of Death Valley National Park. Airnav is accurate regards non availability of fuel and tiedowns. The runway was originally much longer but is now overgrown with numerous obstacles on the north end; otherwise smooth and wide. To enter the valley you will be at least 6000 MSL; my last APRS hit was at 5690 MSL about 5 miles from the field. Since the field is at -210 MSL there will be circling to land and after takeoff. I landed on 15 per the wind T to almost calm winds. About two days later I went back to the airport and moved the aircraft behind a small stand of dense trees that sheltered it. For about 48 hours the winds in the valley were 30 KTS with gust to 50 KTS. The aircraft was secured with =BD=94 nylon ropes to steel wires that transverse the pavement. In addition I had a pitot cover, belt tied controls and significant rudder lock and aileron lock. After the first night of blow, I wondered whether the aircraft would still be there. I walked to the airport and there was no damage. In fact the wind behind the small tree stand was almost non existent. I left it there for another night as there was no escape from the valley via flight. By Sunday morning the winds were again less than 10KTS. Surprisingly even during the big blow, the stars ere outstanding; a sky full. There has been little rain there so far, about .03 inches since December; hence the wild flowers were non existent. There are two nice places to stay (hotels) and several places to eat, also expensive. Several campgrounds within walking distance of Furnace Creek Ranch. All in all an interesting history of a desert which was occupied 80 years ago by miners and other fortune hunters. ________________________________________________________________________________
Date: Mar 20, 2012
Bill said there is a "UAT Console" program that now includes the current level of software or will include the current level. Sounds like the intent is to supply new releases integrated with a console program so you kind of get the latest of both anytime you update. The release he sent me on Mar 12 was 3.10.1. I went out an bought a cable at RadioShack for $40.... not sure I want to open it yet for that price. Amazon has a number of selections under $20 and I can wait a few days. We'll see. Bill On 3/20/2012 12:06 PM, Dave Saylor wrote: > Rob, > > Bill sent me a link to 3.10.0 on Feb 27. I'm not sure if just > forwarding the link will work, but here it is: > > https://rcpt.yousendit.com/1392889324/ba70bb6639d6336cf1592704f80a3bb6 > > He didn't say anything about it being beta. It resolved an altitude > display issue we were having. So far, so good. > > --Dave Saylor ________________________________________________________________________________
Date: Mar 20, 2012
For a cable, you can also find someone with an "old" Dynon system, since those are serial-only, too. On Tue, Mar 20, 2012 at 11:09 AM, Bill Watson wrote: > Bill said there is a "UAT Console" program that now includes the current > level of software or will include the current level. Sounds like the > intent is to supply new releases integrated with a console program so you > kind of get the latest of both anytime you update. > > The release he sent me on Mar 12 was 3.10.1. > > I went out an bought a cable at RadioShack for $40.... not sure I want to > open it yet for that price. Amazon has a number of selections under $20 > and I can wait a few days. We'll see. > > Bill > > > On 3/20/2012 12:06 PM, Dave Saylor wrote: > > Rob, > > Bill sent me a link to 3.10.0 on Feb 27. I'm not sure if just forwarding > the link will work, but here it is: > > https://rcpt.yousendit.com/1392889324/ba70bb6639d6336cf1592704f80a3bb6 > > He didn't say anything about it being beta. It resolved an altitude > display issue we were having. So far, so good. > > --Dave Saylor > > > * > > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 20, 2012
From: "David J. Fritzsche" <fritzsch(at)eskimo.com>
Subject: Corrugated Tube Question
I am using Van's corrugated tube in my wings to protect my wiring. I need to cut holes for the pitot wire and the landing light wires. Is that normally done with a soldering iron to poke the hole? And should you insert a rubber grommet to protect the wire through the hole? Dave -- Dave Fritzsche Professor, Retired Penn State ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Mar 20, 2012
In the 8A I cut a hole I the corrugated tubing to run those wires. After you finish the wire run use some silicon seal around the hole/wires to eliminate relative motion - protecting the wires. For the 10 I used Lowes polyurethane water line tubing for the wire runs. The tubing is a snug fit in 3/4" holes, very sturdy but light weight, and big enough for all the wires and even a coax run to the wingtip VOR antenna. I simply have a 2" or so space where there is not tubing for things such as pitot heat, auto pilot, and aileron trim. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David J. Fritzsche Sent: Tuesday, March 20, 2012 6:45 PM Subject: RV10-List: Corrugated Tube Question I am using Van's corrugated tube in my wings to protect my wiring. I need to cut holes for the pitot wire and the landing light wires. Is that normally done with a soldering iron to poke the hole? And should you insert a rubber grommet to protect the wire through the hole? Dave -- Dave Fritzsche Professor, Retired Penn State ________________________________________________________________________________
Subject: Re: Corrugated Tube Question
Date: Mar 20, 2012
Soldering iron worked great for me. It kind of curls the plastic so I didn't use grommets or at least I thought they weren't required. I think the conduit is soft enough not to cut into the wiring insulation. Sean ----- Original Message ----- From: "David J. Fritzsche" <fritzsch(at)eskimo.com> Sent: Tuesday, March 20, 2012 4:45 PM Subject: RV10-List: Corrugated Tube Question > > > I am using Van's corrugated tube in my wings to protect my wiring. I need > to cut holes for the pitot wire and the landing light wires. Is that > normally done with a soldering iron to poke the hole? And should you > insert a rubber grommet to protect the wire through the hole? > > Dave > > -- > > Dave Fritzsche > Professor, Retired > Penn State > > > ________________________________________________________________________________
Date: Mar 20, 2012
Subject: Re: flap actuation
Thanks for the responses. -A great help. ________________________________________________________________________________
Date: Mar 20, 2012
Subject: Re: First long cross country
I got the original SPOT when it was introduced at Oshkosh a few years ago a nd then last year got the newer and present one. -The latter eliminates a step going from location notification to tracking. -It's worked very nic ely for us. -Before upgrading I was toying with the idea of letting it go but my wife asked me to continue. -She likes knowing when I go up and wh en I get back. -My son likes to know where I'm going on the tracking feat ure. -All in all, I think it's a neat unit and recommend it.=0A=0A=0A____ ____________________________=0A From: David Leikam <arplnplt(at)gmail.com>=0AT o: RV-10 matronics =0ASent: Tuesday, March 20, 20 12 3:50 PM=0ASubject: RV10-List: First long cross country=0A =0A--> RV10-Li st message posted by: David Leikam =0A=0AMy son and I a re taking the plane from KUES (Waukesha WI) to KSEZ (Sedona) next week on o ur first long cross country.- We plan to make a fuel stop somewhere in KS .- Then fly southward to Santa Fe.- Then on to Sedona, trying to avoid the really high country.=0A=0AAlso, does anyone have any experience with Sp ot PLB's?=0A=0AAny advice or airport recommendations would be appreciated! - - - - - - - - - - - - - -Matt Dralle, List Adm ===== ________________________________________________________________________________
Subject: Re: Furnace Creek L06
Date: Mar 20, 2012
Thanks for the nice write-up. Hope more continue to do this, as it helps us low timers. We will be taking our first 200 nm+ trips this summer. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369034#369034 ________________________________________________________________________________
Subject: First long cross country
Date: Mar 20, 2012
For those newly flying, don't ignore the Amateur Radio tracking system or Amateur Position Reporting System (APRS). It uses a small, inexpensive 2 meter burst transmitter, a web site http://aprs.fi and has no fees for usage. You are required to have a Ham License but they are not difficult to study for and obtain. My transmitter is one of the early one costing about $300 but later ones are less than $200 and there are portable models. After the transmitter is programmed with your call sign and optionally, your tail number, it will automatically transmit at pre-selected intervals on the 2 meter amateur band. Other ham operators will pick it up and-in most areas of the US-put it on the internet where it can be viewed in real time at aprs.fi superimposed on a map. Each dot that makes up the track shows altitude, heading, speed, lat/long. Benefits are no cost and anyone with your call sign can follow your track. Drawbacks are spotty coverage in some areas and anyone with your call sign can follow your track. My transmitter is controlled by a panel switch so it only works when I want it to. Check out http://www.byonics.com/microtrak/ for equipment and prices. He will also pre-program your transmitter for you if desired. I have used it flying in all of the lower 48 and found very few holes in coverage. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Mar 21, 2012
I just cut a slit in it to fish out the wire, but I'm sure the soldering iron will work as well. If you ever want to buy it in different sizes or colors, you'll find it on the web as "Convoluted Nylon Tubing", or "Nylon Wire Loom." Here is a web site of a major manufacturer of it: http://www.taylorvertex.com/Products/index.cgi/bulkTubing John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369042#369042 ________________________________________________________________________________
Date: Mar 21, 2012
Subject: Brake Pads?
I am looking for a supplier of brake pads for the -10. I have rivets and the rivet tool to set them. Anyone got a good supplier they could recommend or not? Jim Combs (N312F - 350 hours) ________________________________________________________________________________
Date: Mar 21, 2012
Subject: Re: Brake Pads?
Desser Tire http://vansaircrafttires.com/ Skygeek.com Aircraft Spruce Van's I've bought from them all. Desser has the Rapco pads. For the Cleveland's you'd go to the other places. Tim On 3/21/2012 9:08 AM, Jim Combs wrote: > I am looking for a supplier of brake pads for the -10. I have rivets > and the rivet tool to set them. > > Anyone got a good supplier they could recommend or not? > > Jim Combs (N312F - 350 hours) > ________________________________________________________________________________
Date: Mar 21, 2012
Desser has a RV-10 specific page. They sell pads, rapco I believe. On Mar 21, 2012, at 7:08 AM, Jim Combs wrote: > I am looking for a supplier of brake pads for the -10. I have rivets > and the rivet tool to set them. > > Anyone got a good supplier they could recommend or not? > > Jim Combs (N312F - 350 hours) > > > > ________________________________________________________________________________
Date: Mar 21, 2012
From: "Kevin O'Shea" <kevino(at)worldwarehouse.com>
I had the UAT console shipped with the navworx in Jan. Install was very straight forward. Just loaded on a netbook. ________________________________________________________________________________
Date: Mar 21, 2012
Wayne, I haven't done anything yet but I did talk to someone at Showplanes and they described a fix involving two washers similar to what Patrick mentioned previously. My problem has been the gradual degradation of the flap detent function. It has required 2 or more clicks to get to half or full in flight and on the ground. Sometime over the next 2 or 3 months I will open up the tunnel, see if I can understand what is going on and try to apply the 2 washer fix if it makes sense. I'll share my experience here afterwards. Bill "almost ADS-B'd" Watson On 3/19/2012 8:11 AM, rv10flyer wrote: > --> RV10-List message posted by: "rv10flyer" > > My Show Planes from Vans has always required two taps down to go from half to full. I will pull that whole mess out and install a manual switch if I have any additional faults. One less wire and much simpler to troublehoot or repair. As for landing and takeoff with or without flaps, it is no problem with a CS prop and 260 hp. Having a manual switch would not be any more distracting than dealing with this. It may just be a matter of the micro switch rods not having the cutouts in the right place at the right time. Anybody troubleshot this problem yet? > > -------- > Wayne Gillispie, A&P 05/93 PP 10/08 > 40983SB 12/1/2009-12/1/2011 > N715WD 382nd Flying. TT= 37 > > ________________________________________________________________________________
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Subject: APRS
Date: Mar 21, 2012
Lots of info on aviation use here: http://www.vansairforce.com/community/forumdisplay.php?f=104 Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Albert Gardner Sent: Wednesday, March 21, 2012 12:28 AM Subject: RE: RV10-List: First long cross country For those newly flying, don't ignore the Amateur Radio tracking system or A mateur Position Reporting System (APRS). It uses a small, inexpensive 2 met er burst transmitter, a web site http://aprs.fi and has no fees for usage. You are required to have a Ham License but they are not difficult to study for and obtain. My transmitter is one of the early one costing about $300 b ut later ones are less than $200 and there are portable models. After the t ransmitter is programmed with your call sign and optionally, your tail numb er, it will automatically transmit at pre-selected intervals on the 2 meter amateur band. Other ham operators will pick it up and-in most areas of the US-put it on the internet where it can be viewed in real time at aprs.fi s uperimposed on a map. Each dot that makes up the track shows altitude, head ing, speed, lat/long. Benefits are no cost and anyone with your call sign c an follow your track. Drawbacks are spotty coverage in some areas and anyon e with your call sign can follow your track. My transmitter is controlled b y a panel switch so it only works when I want it to. Check out http://www.b yonics.com/microtrak/ for equipment and prices. He will also pre-program yo ur transmitter for you if desired. I have used it flying in all of the lowe r 48 and found very few holes in coverage. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Mar 21, 2012
Subject: Re: APRS
I'd have to agree with Albert. Don't pass up checking out APRS. There's not a lot of work to go into it to get it working on your plane, and in the long run it is the cheapest AND the best resolution method to go with for most people, if your friends and family want to track you. I actually own all 3 methods of tracking or position finding: (4 if you count ELT) 1) 406Mhz GPS integrated PLB 2) APRS GPS Tracker 3) SPOT Connect messenger 4) 406 Mhz GPS integrated ELT Of these, nothing compares to the track you'll get with APRS. You can set the interval down to 1-2 minutes and get a nice smooth track, or, in the config options, it will automatically send your position info if you vary in heading by X degrees, and repeat at a faster interval. This gives a really good smooth track on many turns. You can see altitude and speed and all that good stuff too. Makes it fun to have people watch and see when you're doing 250kts in a tailwind. Also, because it's a free, no-subscription, no-batteries service, you can get one and have years and years of tracking and not be forking over money all the time. The SPOT Connect does work, just like any SPOT does, and I do have the tracking option. It gives a pretty crude track because it only updates every 10 minutes. Even if you force an update, it won't update at fast intervals. That is an annoying feature but they do it to save satellite bandwidth. With the SPOT connect, you can at least send text email messages (very small ones), which is kind of nice. But, I find that it's not a service I'd use much. It has it's place though. The message packs aren't dirt cheap for custom messages, so rather than keep paying fees (I think I pay $150/yr?), I just don't use it for messaging much. Where it *is* nice, is that it gives you a tracker to use while off the 48 continental states. You can get a ways off the coast with APRS, but only about TO the islands of the Bahamas. Once further, you can't be tracked on APRS. I bought one just for the Bahamas trip and a planned Alaska trip. Other than that, I really could do without it. I've been bouncing around the idea of renting it out for a nominal fee, just to cut the wasted cost...since I only need it maybe 1-2 weeks in a year. It would be the first item I'd skip, if push comes to shove. APRS would be hard to give up. I am NOT a fan of subscription fees...we pay far too much for navdata and cellphones, and internet, and TV and all the other things to have one more thing to pay for. The SPOT can make a good search/recovery tool, but I'd argue that while it is good, if you're just looking to be rescued you'd probably do better with a PLB. Even the Lithium battery costs will add up over time. The 406Mhz PLB is the actual NOAA registered location device that I think would be my last to give up. It's the one thing that you know will be searched for if you're alive and on foot after a crash. They're great for boats, for planes, and other travels too. A SPOT could be useful as well, but at least with a PLB you don't pay annual fees. You only have to worry about the 5 year battery replacement. You know though, that if you push the button, they'll come looking. The 406Mhz ELT really just adds the benefit of something that will automatically work if you crash. I think it's a good idea to have one, but throw in a handheld PLB and you're really in good shape to get found if you're lost. No sense not putting in a 406 anymore, if you plan on traveling outside the 48. If it sounds like I'm anti-SPOT, I'm not. I really think it's a nice thing. If I could hardwire the power, and it had a remote antenna, I'd even be happier. I just dislike subscription fees, and I think the quality of your track is so much nicer with APRS that you should really look at your goal. If you want to be tracked, APRS is fantastic. If you want to be found, the 406 Mhz products are great. The SPOT is just a compromise between both of them....not perfect for either but does both fairly well....at a price. Tim On 3/21/2012 12:44 PM, RV Builder (Michael Sausen) wrote: > Lots of info on aviation use here: > > http://www.vansairforce.com/community/forumdisplay.php?f=104 > > Michael > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Albert > Gardner *Sent:* Wednesday, March 21, 2012 12:28 AM *To:* > rv10-list(at)matronics.com *Subject:* RE: RV10-List: First long cross > country > > For those newly flying, dont ignore the Amateur Radio tracking > system or Amateur Position Reporting System (APRS). It uses a small, > inexpensive 2 meter burst transmitter, a web sitehttp://aprs.fi and > has no fees for usage. You are required to have a Ham License but > they are not difficult to study for and obtain. My transmitter is one > of the early one costing about $300 but later ones are less than $200 > and there are portable models. After the transmitter is programmed > with your call sign and optionally, your tail number, it will > automatically transmit at pre-selected intervals on the 2 meter > amateur band. Other ham operators will pick it up andin most areas > of the USput it on the internet where it can be viewed in real time > at aprs.fi superimposed on a map. Each dot that makes up the track > shows altitude, heading, speed, lat/long. Benefits are no cost and > anyone with your call sign can follow your track. Drawbacks are > spotty coverage in some areas and anyone with your call sign can > follow your track. My transmitter is controlled by a panel switch so > it only works when I want it to. Check > outhttp://www.byonics.com/microtrak/ for equipment and prices. He > will also pre-program your transmitter for you if desired. I have > used it flying in all of the lower 48 and found very few holes in > coverage. > > Albert Gardner > > N991RV > > Yuma, AZ > > * * ________________________________________________________________________________
Subject: APRS
Date: Mar 21, 2012
The only advantage I see to SPOT is that you can pay extra per year if you travel in countries that do not have organized SAR. If you go missing they will pay for a private SAR. I use APRS, Flight Aware, PLBs and 121.5 ELT. I think that SPOT would work even for international airline travel. Imagine a SAR effort in central Africa? Or Egypt? Or current Libya? BTW, there are areas of the US where APRS coverage is non existent at low altitudes. For example, my last APRS hit was 5690 MSL about five miles SE of L06 (elevation -210) on the flight into L06. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, March 21, 2012 1:51 PM Subject: Re: RV10-List: APRS I'd have to agree with Albert. Don't pass up checking out APRS. There's not a lot of work to go into it to get it working on your plane, and in the long run it is the cheapest AND the best resolution method to go with for most people, if your friends and family want to track you. I actually own all 3 methods of tracking or position finding: (4 if you count ELT) 1) 406Mhz GPS integrated PLB 2) APRS GPS Tracker 3) SPOT Connect messenger 4) 406 Mhz GPS integrated ELT Of these, nothing compares to the track you'll get with APRS. You can set the interval down to 1-2 minutes and get a nice smooth track, or, in the config options, it will automatically send your position info if you vary in heading by X degrees, and repeat at a faster interval. This gives a really good smooth track on many turns. You can see altitude and speed and all that good stuff too. Makes it fun to have people watch and see when you're doing 250kts in a tailwind. Also, because it's a free, no-subscription, no-batteries service, you can get one and have years and years of tracking and not be forking over money all the time. The SPOT Connect does work, just like any SPOT does, and I do have the tracking option. It gives a pretty crude track because it only updates every 10 minutes. Even if you force an update, it won't update at fast intervals. That is an annoying feature but they do it to save satellite bandwidth. With the SPOT connect, you can at least send text email messages (very small ones), which is kind of nice. But, I find that it's not a service I'd use much. It has it's place though. The message packs aren't dirt cheap for custom messages, so rather than keep paying fees (I think I pay $150/yr?), I just don't use it for messaging much. Where it *is* nice, is that it gives you a tracker to use while off the 48 continental states. You can get a ways off the coast with APRS, but only about TO the islands of the Bahamas. Once further, you can't be tracked on APRS. I bought one just for the Bahamas trip and a planned Alaska trip. Other than that, I really could do without it. I've been bouncing around the idea of renting it out for a nominal fee, just to cut the wasted cost...since I only need it maybe 1-2 weeks in a year. It would be the first item I'd skip, if push comes to shove. APRS would be hard to give up. I am NOT a fan of subscription fees...we pay far too much for navdata and cellphones, and internet, and TV and all the other things to have one more thing to pay for. The SPOT can make a good search/recovery tool, but I'd argue that while it is good, if you're just looking to be rescued you'd probably do better with a PLB. Even the Lithium battery costs will add up over time. The 406Mhz PLB is the actual NOAA registered location device that I think would be my last to give up. It's the one thing that you know will be searched for if you're alive and on foot after a crash. They're great for boats, for planes, and other travels too. A SPOT could be useful as well, but at least with a PLB you don't pay annual fees. You only have to worry about the 5 year battery replacement. You know though, that if you push the button, they'll come looking. The 406Mhz ELT really just adds the benefit of something that will automatically work if you crash. I think it's a good idea to have one, but throw in a handheld PLB and you're really in good shape to get found if you're lost. No sense not putting in a 406 anymore, if you plan on traveling outside the 48. If it sounds like I'm anti-SPOT, I'm not. I really think it's a nice thing. If I could hardwire the power, and it had a remote antenna, I'd even be happier. I just dislike subscription fees, and I think the quality of your track is so much nicer with APRS that you should really look at your goal. If you want to be tracked, APRS is fantastic. If you want to be found, the 406 Mhz products are great. The SPOT is just a compromise between both of them....not perfect for either but does both fairly well....at a price. Tim On 3/21/2012 12:44 PM, RV Builder (Michael Sausen) wrote: > Lots of info on aviation use here: > > http://www.vansairforce.com/community/forumdisplay.php?f=104 > > Michael > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Albert > Gardner *Sent:* Wednesday, March 21, 2012 12:28 AM *To:* > rv10-list(at)matronics.com *Subject:* RE: RV10-List: First long cross > country > > For those newly flying, don't ignore the Amateur Radio tracking > system or Amateur Position Reporting System (APRS). It uses a small, > inexpensive 2 meter burst transmitter, a web sitehttp://aprs.fi and > has no fees for usage. You are required to have a Ham License but > they are not difficult to study for and obtain. My transmitter is one > of the early one costing about $300 but later ones are less than $200 > and there are portable models. After the transmitter is programmed > with your call sign and optionally, your tail number, it will > automatically transmit at pre-selected intervals on the 2 meter > amateur band. Other ham operators will pick it up and-in most areas > of the US-put it on the internet where it can be viewed in real time > at aprs.fi superimposed on a map. Each dot that makes up the track > shows altitude, heading, speed, lat/long. Benefits are no cost and > anyone with your call sign can follow your track. Drawbacks are > spotty coverage in some areas and anyone with your call sign can > follow your track. My transmitter is controlled by a panel switch so > it only works when I want it to. Check > outhttp://www.byonics.com/microtrak/ for equipment and prices. He > will also pre-program your transmitter for you if desired. I have > used it flying in all of the lower 48 and found very few holes in > coverage. > > Albert Gardner > > N991RV > > Yuma, AZ > > * * ________________________________________________________________________________
Date: Mar 21, 2012
I have this cheap chinese USB to serial adapter from ebay: USB to RS232 Serial DB9 COM Cable Adapter HL340 Z http://www.ebay.com/itm/USB-to-RS232-Serial-DB9-COM-Cable-Adapter-HL340-Z-/160506203551?pt=LH_DefaultDomain_0&hash=item255eea4d9f#ht_3251wt_1396 It says HL-340 on it. It works fine with the NavWorx box, or any other rs232 device. Windows 7 also installs drivers for it automatically, no driver CD needed. I also have an IoGear GBS301 rs232 to bluetooth adapter. I never tried it with the NavWorx box, but i don't see why it wouldn't work as it works with most serial devices i have tried. Used a windows laptop though, not an iPad. It's probably easier to just plug in a $5 cable... Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369116#369116 ________________________________________________________________________________
Date: Mar 22, 2012
Those are the exact same ones I found that were cheap. I got some with a cable, and some that were just a 2" port adapter. Back when I got them I think I even paid like $1-$2 each for the short ones and maybe $3-5 for these, but probably with combined shipping. I wanted to have a bunch around. Some day it would be cool to have that bluetooth adapter, but I don't know that the iPad would support the Serial bluetooth profile, and even if it did, I don't know that they have a Com terminal app....so I'm still hoping to find one that works via wi-fi so I can use a telnet/ssh app. If I had a wi-fi one, I'd use it often at work. Tim On 3/22/2012 1:11 AM, Lenny Iszak wrote: > --> RV10-List message posted by: "Lenny > Iszak" > > I have this cheap chinese USB to serial adapter from ebay: > > USB to RS232 Serial DB9 COM Cable Adapter HL340 Z > > http://www.ebay.com/itm/USB-to-RS232-Serial-DB9-COM-Cable-Adapter-HL340-Z-/160506203551?pt=LH_DefaultDomain_0&hash=item255eea4d9f#ht_3251wt_1396 > > It says HL-340 on it. It works fine with the NavWorx box, or any > other rs232 device. Windows 7 also installs drivers for it > automatically, no driver CD needed. > > I also have an IoGear GBS301 rs232 to bluetooth adapter. I never > tried it with the NavWorx box, but i don't see why it wouldn't work > as it works with most serial devices i have tried. Used a windows > laptop though, not an iPad. > > It's probably easier to just plug in a $5 cable... > > Lenny > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369116#369116 > ________________________________________________________________________________
Subject: Re: APRS
Date: Mar 22, 2012
> Imagine a SAR effort in central Africa? Or Egypt? Or current Libya? Since 70.8% of the earth is covered by water (leaving only 29.2% for land), I would suggest something more practical.... John[/quote] -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369141#369141 ________________________________________________________________________________
Subject: Re: FWF Fuel Line Torque Values
Date: Mar 22, 2012
Pascal Thanks for the reply. I notice that the torque values for some of the fittings themselves such as fuel inlet to fuel servo are lower than what Aeroquip specifies for the hoses. I wonder if the intent is to have a lower torque onthe flexible hose fitting than the fitting to fuel servo so one doesnot inadvertantly loosen the fitting from the fuel servo while removing the flexible hose. Nikolaos Napoli On Mar 14, 2012, at 1:16 PM, Pascal wrote: > > I used Aeroquip's settings for all lines. (brake, oil, fuel, etc) > > -----Original Message----- From: Nikolaos Napoli > Sent: Wednesday, March 14, 2012 9:40 AM > To: Matronics > Subject: RV10-List: FWF Fuel Line Torque Values > > > I am wondering what the correct torque value for the FWF fuel and oil lines is. The Lycoming Overhaul Manual has fairly low torque values for "flexible hose or tube fittings " in the order of 30 to 35 in-lbs with corresponding values of over 100in-lb from Aeroquip and similar sources. Not sure which values to use. > > > Thanks > Niko > > > > > > > > ________________________________________________________________________________
Date: Mar 22, 2012
Bill, Keep me posted on both flap and ads-b, as I will be right behind you. Thanks to all you -10 guys! -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369168#369168 ________________________________________________________________________________
Subject: Tunnel access panels
Date: Mar 22, 2012
I remember someone having access panels for the tunnel for sale but I can't seem to find them Anyone have that info? Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: Tunnel access panels
Date: Mar 22, 2012
I installed this one and it works great! http://www.airward.com/amelia/search.asp?store=airward&action=Search& ShowDetails=True&ShowImages=True&cat=10000016&subcat_10000003=100 00016 ----- Original Message ----- From: Wayne Edgerton To: rv10-list(at)matronics.com Sent: Thursday, March 22, 2012 4:40 PM Subject: RV10-List: Tunnel access panels I remember someone having access panels for the tunnel for sale but I can't seem to find them Anyone have that info? Wayne Edgerton N602WT ________________________________________________________________________________
Date: Mar 22, 2012
Date: Mar 22, 2012
An update; I just finished the install in my RV-10 and it seems to work fine. The configuration includes display on 3 GRT HX displays, a GTX327, and a G430W. I have a few pictures and random notes here: http://www.mykitlog.com/mauledriver The various wiring options can be challenging to decipher. I circumvented that by asking FastStack to provide a wiring harness to add to my FastStack wiring hub. They wired every option that was possible between the GRT HXs, the GTX 327, the G430W, and the NavWorx box. I just had to determine what options I actually had (e.g. no ARINC on the Navworx) and configure accordingly. I got both Nexrad images and traffic going on one display. Need to make some GRT config changes to get them across all 3 displays. The way I understand things is that the ADS-B box supplies 2 separate functions - weather and the 'traffic stuff'. The box takes 2 power leads and 2 ground leads which I think reflects the separation. It also requires 2 antenna - a GPS antenna and a UAT (transponder type) antenna. I installed both just to keep things simple rather than trying to share a GPS antenna or signal. * The weather is on all the time. According to Bill Moffitt there are 12 weather functions but access to them is dependent on the equipment you are displaying on. GRT supports 3 of them - Nexrad, Metars, and TAFs at this time. Someone on the GRT group pointed out that if you turn off the Nexrad, airports are colored coded into VFR, MFR and IFR... I'll call that a 4th function. * The traffic stuff is 'controlled' in a sense by the GTX327 which acts as a control panel. When in standby or off - no traffic in or out. No real operation or control required but good to understand that. The 'suppression' function is operational so there should be no need to coordinate squawk codes. The Navworx box sees what the 327 is squawking and doesn't produce or display duplicate info. * The G430W is wired in but is not functional in my installation. No desire to display traffic there. People have reported some difficulties with the install and I can see how it has had to evolve but I can report that it seems to be in a pretty good place right now. The need to use a PC as a configuration console was one of the obstacles but NavWorx seems to have upgraded the terminal software and integrated it with the process for delivering software updates. Once I figured out how to recycle some junk to get a com port for my laptop, no problems. The only time the console is required is for future software updates. Bill Moffitt at NavWorx is a good guy to work with and seems more than willing to provide the needed assistance. I've never had traffic before so being able to see nearby traffic on my first test flight was a revelation. The Nexrad imagery seemed a bit more 'pixelated' than the XM but looks fine. Still testing but I was just thinking that a run down to Sun & Fun might be called for.... Bill Watson ________________________________________________________________________________
Subject: Re: APRS
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 23, 2012
I am not a user of APRS, a HAM license has been on my to do list for a while. After reading Tims post I started thinking about sending a text message via the armature radio bands while in flight. Essentially that is all they are doing with APRS, right? So a quick search revealed this link: http://www.winlink.org/ Are text messages to the iPad the limit, how about a ping to a service to return a METAR Might be a day late and dollar short in these days of XM and ADSB, but food for thought. - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369210#369210 ________________________________________________________________________________
Date: Mar 23, 2012
Subject: Re: APRS
Some of that stuff could be done, I'm sure, but it would take a person actually wanting to spend time on the programming end to run the service. Given that these days you can get that METAR data via Satellite with WSI/XM, and plenty of Wx with ADS-B for no cost, I don't know that there would be enough practical interest in it. But short emails would definitely be useful. I know many people who would like that. You'd likely end up with a 1 way capability, just like on a SPOT though....but it's better than nothing. I know there are people out there doing it today, if you read the APRS forum on VAF, but I think it's a bit clumsy in that you have to put a control head on the APRS to do it. If it were a slick iphone interface, then I bet there would be tons of people doing it. In time, I'm sure you'll see more. You won't want to use it for sending emails as long as this one though. ;) Besides that, it isn't private, so anyone could read them. Tim On 3/23/2012 7:54 AM, jkreidler wrote: > --> RV10-List message posted by: "jkreidler" > > I am not a user of APRS, a HAM license has been on my to do list for a while. After reading Tims post I started thinking about sending a text message via the armature radio bands while in flight. Essentially that is all they are doing with APRS, right? > So a quick search revealed this link: http://www.winlink.org/ > Are text messages to the iPad the limit, how about a ping to a service to return a METAR Might be a day late and dollar short in these days of XM and ADSB, but food for thought. - Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369210#369210 > ________________________________________________________________________________
Subject: Re: APRS
Date: Mar 23, 2012
The suggestion to get METAR and METAF in flight is also being done by WingX on the IPAD with the cellular ON. I have been riding to OSH in a warbird and with a cellular active IPAD have been sending and receiving emails as I pass cell towers along the way. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, March 23, 2012 6:33 AM Subject: Re: RV10-List: Re: APRS Some of that stuff could be done, I'm sure, but it would take a person actually wanting to spend time on the programming end to run the service. Given that these days you can get that METAR data via Satellite with WSI/XM, and plenty of Wx with ADS-B for no cost, I don't know that there would be enough practical interest in it. But short emails would definitely be useful. I know many people who would like that. You'd likely end up with a 1 way capability, just like on a SPOT though....but it's better than nothing. I know there are people out there doing it today, if you read the APRS forum on VAF, but I think it's a bit clumsy in that you have to put a control head on the APRS to do it. If it were a slick iphone interface, then I bet there would be tons of people doing it. In time, I'm sure you'll see more. You won't want to use it for sending emails as long as this one though. ;) Besides that, it isn't private, so anyone could read them. Tim On 3/23/2012 7:54 AM, jkreidler wrote: > --> RV10-List message posted by: "jkreidler" > > I am not a user of APRS, a HAM license has been on my to do list for a while. After reading Tims post I started thinking about sending a text message via the armature radio bands while in flight. Essentially that is all they are doing with APRS, right? > So a quick search revealed this link: http://www.winlink.org/ > Are text messages to the iPad the limit, how about a ping to a service to return a METAR Might be a day late and dollar short in these days of XM and ADSB, but food for thought. - Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369210#369210 > ________________________________________________________________________________
Date: Mar 23, 2012
Subject: Pirep On Rod End Bearing Tool...
Fellow Builders, I building a new rudder for 'ol Ruby Vixen and was pondering how to install the rod end bearings after the leading edge is formed. I think I did it the first time with a pliers or something that kind of scratched the bearing and ran the risk of tweaking the leading edge. I was surfing around on Flyboy Accessories this week and found this sweet Rod End Bearing Tool. It arrived today and I can't believe how awesome it is. It totally works as good as you would imagine. Order one today!! You won't be sorry. (No connection with FB or the tool maker; just a really impressed owner.) http://www.flyboyaccessories.com/store/index.php?main_page=product_info&cPath=70&products_id=408 Rod End Bearing Tool - Click Image to Close - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 70+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode ________________________________________________________________________________
Subject: Re: Pirep On Rod End Bearing Tool...
Date: Mar 24, 2012
Honestly, I made the same thing with about $1 in parts from Home Depot. If you don't want to do that, or prefer someone else to to it, then by all means, get it from Fly Boy. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369291#369291 ________________________________________________________________________________
Subject: Milestone: How to mount the wings and take them off in 6 min
Date: Mar 25, 2012
[Wink] Enjoy http://www.youtube.com/watch?v=exnL2QTnzJc Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369327#369327 ________________________________________________________________________________
Subject: Riveting HS "horizontally"?
Date: Mar 26, 2012
Does anyone see any potential issues riveting the HS together as it sits flat in the cradles instead of vertically as depicted in the plans? It seems like it will be MUCH easier to buck the rivets in this orientation. Pic included to clarify: -------- Ed Kranz 41347 Working on Emp Kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369367#369367 Attachments: http://forums.matronics.com//files/timelapse47960_723.jpg ________________________________________________________________________________
Subject: Re: Milestone: How to mount the wings and take them off in
6 min
Date: Mar 26, 2012
SIX Minutes?!? Geesh, it took us 90 minutes to move mine out of the one car garage, hang 2 wings and the tail feathers, photograph it, then put it all back. But, of course, we only had 2 people to do the work. [Wink] Mazda 20-B conversion progressing. This one will fly yet! (And, it will likely be the least expensive one in the air.) Phil White #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369368#369368 ________________________________________________________________________________
Date: Mar 26, 2012
Subject: Re: Riveting HS "horizontally"?
That's how I did it (one person). Didn't use the cradles, just laid it down on 2 workbenches. Allowed me to sit while riveting and as you soon find out, the more comfortable you are, the better job you tend to do. Bill Watson N215TG flying On 3/26/2012 4:04 PM, EdKranz wrote: > --> RV10-List message posted by: "EdKranz" > > Does anyone see any potential issues riveting the HS together as it sits flat in the cradles instead of vertically as depicted in the plans? It seems like it will be MUCH easier to buck the rivets in this orientation. > > Pic included to clarify: > > -------- > Ed Kranz > 41347 > Working on Emp Kit > > ________________________________________________________________________________
Date: Mar 26, 2012
Subject: Anybody here going to S&F?
We're planning to go down this Wednesday - maybe 2 days. Hopefully meet some of the vendor folks I've been talking to. Bill Watson N215TG ________________________________________________________________________________
Date: Mar 26, 2012
Subject: AOPA Digital Charts survey
Hi all, If you have time to take AOPA's survey, they're gathering ammo in the fight against digital chart fees. Go here: http://aopa.qualtrics.com/SE/?SID=SV_b7yMajDKsRqAmEc It took me about 5 minutes. I added some comments in the comment blank too. Good thing it wraps...it's a 1 line field so it looked too small. Tim ________________________________________________________________________________
Subject: Re: Anybody here going to S&F?
Date: Mar 26, 2012
I'll be in the Maverick booth most of the week (right next to Van's). Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 26, 2012, at 4:48 PM, Bill Watson wrote: > > We're planning to go down this Wednesday - maybe 2 days. Hopefully meet some of the vendor folks I've been talking to. > > Bill Watson > N215TG > > > > ________________________________________________________________________________
Date: Mar 26, 2012
Subject: Re: AOPA Digital Charts survey
Thanks Tim. Done. I've gone completely paperless now...it's fun not having to carry that big 'ol flight bag/chart case around any longer! One of the things I quickly realized is how the low cost and ease of use digital charts allows me 1) to fly only with current charts, 2) to always have all the charts covering a particular area, 3) to have multiple digital backups. Number 3 is a big deal if you really are going paperless. Foreflight on the iPad for x bucks, maps and approach plates on the GRT for zero bucks, AirWx plates on my Android phone for ? bucks. Bill "a day at S&F" Watson On 3/26/2012 4:51 PM, Tim Olson wrote: > > Hi all, > If you have time to take AOPA's survey, they're gathering > ammo in the fight against digital chart fees. Go here: > > > http://aopa.qualtrics.com/SE/?SID=SV_b7yMajDKsRqAmEc > > It took me about 5 minutes. I added some comments in > the comment blank too. Good thing it wraps...it's a > 1 line field so it looked too small. > Tim ________________________________________________________________________________
Date: Mar 26, 2012
For me it's a huge safety and convenience thing. I used to buy only my portion of the US and then buy individual charts for trips. Planning a trip to Florida meant spending $75 on paper that I'd only use that week. It was a freakin' waste. I didn't use the charts most of the time, but you had to have them. With the RV-10, I often don't know where I'm even going until the day we leave, and that may mean tomorrow we could go Wisconsin to South Carolina. There is no time to order charts and plan. So having 100% US coverage is a huge bonus. It's also a huge safety thing...to have proper chart data so you don't bust airspace, use improper freq's, and such. But, if they jack the cost up I'll just drop most of my subscriptions. It will come at a cost of safety, but I'm not paying for 3 EFB products (well, one is lifetime), if I have to pay big chart fees. So they need to consider the long term effects of some of the choices they make. Charge planes $100 to file an IFR plan? Fine, just fly VFR and stay low. Now, how safe will THAT be? Most aviation rule changes were paid for in blood... honestly...and they should remember that. Tim On 3/26/2012 4:19 PM, Bill Watson wrote: > > Thanks Tim. Done. > > I've gone completely paperless now...it's fun not having to carry that > big 'ol flight bag/chart case around any longer! > > One of the things I quickly realized is how the low cost and ease of use > digital charts allows me 1) to fly only with current charts, 2) to > always have all the charts covering a particular area, 3) to have > multiple digital backups. > > Number 3 is a big deal if you really are going paperless. Foreflight on > the iPad for x bucks, maps and approach plates on the GRT for zero > bucks, AirWx plates on my Android phone for ? bucks. > > Bill "a day at S&F" Watson > > On 3/26/2012 4:51 PM, Tim Olson wrote: >> >> Hi all, >> If you have time to take AOPA's survey, they're gathering >> ammo in the fight against digital chart fees. Go here: >> >> >> http://aopa.qualtrics.com/SE/?SID=SV_b7yMajDKsRqAmEc >> >> It took me about 5 minutes. I added some comments in >> the comment blank too. Good thing it wraps...it's a >> 1 line field so it looked too small. >> Tim ________________________________________________________________________________
Date: Mar 26, 2012
On 3/26/2012 5:36 PM, Marcus Cooper wrote: > I know it's been discussed a bunch already, but when my Foreflight subscription runs out I'll be looking at alternatives. Seems like a lot of folks prefer Wingx, any updated thoughts? > I was looking for a replacement for my aging Garmin 295 handheld, and WingX easily won the competition with Foreflight for the in-flight stuff. I think Foreflight has better pre-flight planning, but doesn't really compare for the in-flight needs. WingX has a 30 day free trial. You may consider giving it a try before your Foreflight subscription runs out to see how you like it. -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Mar 26, 2012
Snf 2013 yes. Osh 2012 yes. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369383#369383 ________________________________________________________________________________
Date: Mar 26, 2012
Note that the survey link Tim sent includes a session ID (SID) string. It is possible, depending on how this is set up, that anyone who follows Tim's link and fills out the survey simply overwrites the previous person's data. To make sure your answers count, search your inbox for an email from AOPA titled "AOPA Digital Chart Use Survey". That will have a personalized and unique link just for you to use. Chris On Mon, Mar 26, 2012 at 1:51 PM, Tim Olson wrote: > > Hi all, > If you have time to take AOPA's survey, they're gathering > ammo in the fight against digital chart fees. Go here: > > > http://aopa.qualtrics.com/SE/?**SID=SV_b7yMajDKsRqAmEc> > > It took me about 5 minutes. I added some comments in > the comment blank too. Good thing it wraps...it's a > 1 line field so it looked too small. > Tim > > ________________________________________________________________________________
Date: Mar 27, 2012
Arrived on Sunday and will be here for the week. I will be in the workshops teaching how to rivet. - Jason Do no archive -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=369395#369395 ________________________________________________________________________________
Date: Mar 27, 2012
Only two rv10 s. here. Pretty sparse turn out as of Monday night. Weather is great. Patrick thyssen Sent from my iPhone On Mar 26, 2012, at 9:29 PM, "rv10flyer" wrote: > > Snf 2013 yes. Osh 2012 yes. > > -------- > Wayne Gillispie, A&P 05/93 PP 10/08 > 40983SB 12/1/2009-12/1/2011 > N715WD 382nd Flying. TT= 37 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369383#369383 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2012
I'll be there Thursday through Saturday. Haven't seen Bill since our fiberglass class at Dave Saylor's place years ago. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369403#369403 ________________________________________________________________________________
Date: Mar 27, 2012
Watch out for the 1,000 lb gorilla! Garmin has jumped into the iPad market, and is directly competing with WingX and Foreflight. Same price for annual subscription; I think they're cheaper for geo-referenced. How long before they drive the others out, have a monopoly, raise prices? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369432#369432 ________________________________________________________________________________
Date: Mar 27, 2012
Another interesting development is the Stratus ADS-B receiver exclusively for Foreflight, sold by Sporty's. $799 for the box, which has a Li-Ion battery and internal antennas (including GPS & Wifi), and can connect to up to 4 devices at a time. You can also hook up an external ADS-B antenna for areas where the coverage is weak. I was considering getting the Baron box to hook up to XM, but this will pay for itself in a year vs XM, and is extremely portable. Traffic "is not supported yet." Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 27, 2012, at 7:31 PM, "Bob Turner" wrote: > > Watch out for the 1,000 lb gorilla! > > Garmin has jumped into the iPad market, and is directly competing with WingX and Foreflight. > > Same price for annual subscription; I think they're cheaper for geo-referenced. > > How long before they drive the others out, have a monopoly, raise prices? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369432#369432 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 27, 2012
Looks like one needs the future fore flight release 4.5 in April before it will work however Wing X has the same option with another vendor Now if they can get traffic with ADS versus just the weather. Good start Pascal On Mar 27, 2012, at 5:29 PM, Jesse Saint wrote: > > Another interesting development is the Stratus ADS-B receiver exclusively for Foreflight, sold by Sporty's. $799 for the box, which has a Li-Ion battery and internal antennas (including GPS & Wifi), and can connect to up to 4 devices at a time. You can also hook up an external ADS-B antenna for areas where the coverage is weak. I was considering getting the Baron box to hook up to XM, but this will pay for itself in a year vs XM, and is extremely portable. Traffic "is not supported yet." > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > On Mar 27, 2012, at 7:31 PM, "Bob Turner" wrote: > >> >> Watch out for the 1,000 lb gorilla! >> >> Garmin has jumped into the iPad market, and is directly competing with WingX and Foreflight. >> >> Same price for annual subscription; I think they're cheaper for geo-referenced. >> >> How long before they drive the others out, have a monopoly, raise prices? >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=369432#369432 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Mar 27, 2012
On 3/27/2012 8:54 PM, Preid wrote: > Now if they can get traffic with ADS versus just the weather. Good start > Pascal > That is the magic mark for me. If/When WingX supports the display of ADS-B traffic, I will be investing in the ADS-B hardware (transmitter and receiver). The traffic is actually more important to me than the weather. No word from Hilton if this will happen, though, and I'm also hoping we will see lower cost ADS-B hardware this year, maybe at OSH? -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: Mar 27, 2012
My understanding is that Skyradar has had traffic for a year or more. Not sure if it was in WingX or not, but believe it was. On 3/27/2012 6:31 PM, Dj Merrill wrote: > > On 3/27/2012 8:54 PM, Preid wrote: >> Now if they can get traffic with ADS versus just the weather. Good start >> Pascal >> > > That is the magic mark for me. If/When WingX supports the display > of ADS-B traffic, I will be investing in the ADS-B hardware > (transmitter and receiver). The traffic is actually more important to > me than the weather. No word from Hilton if this will happen, though, > and I'm also hoping we will see lower cost ADS-B hardware this year, > maybe at OSH? > > -Dj > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 27, 2012
On 3/27/2012 11:00 PM, Kelly McMullen wrote: > > My understanding is that Skyradar has had traffic for a year or more. > Not sure if it was in WingX or not, but believe it was. > The Skyradar ADS-B hardware does send both weather and traffic info to the iPad. However, the WingX program only displays the weather. The current version does not display traffic. Yes, if you run the Skyradar iPad app you will get both weather and traffic displayed, but then you'd be giving up the WingX program, which was the whole point of putting the iPad in my plane in the first place... :-) -Dj -- Dj Merrill - N1JOV Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Stratus: New for iPad and Foreflight
Date: Mar 28, 2012
This looks interesting. Albert Gardner N991RV Yuma, AZ Appareo Rolls Out Portable In-Flight Weather For iPad High Performance, Subscription-Free Receiver Made For Foreflight The first completely wire-free weather receiver for the iPad has been introduced by Appareo, and it requires no monthly subscription. Stratus combines an ADS-B and GPS receiver into a single unit that wirelessly streams NEXRAD radar, text weather, TFRs and aircraft position to the popular ForeFlight Mobile app for iOS devices. $799.00 http://www.appareo.com/store/index.php?main_page=product_info&cPath=2&produc ts_id=6 ________________________________________________________________________________
Date: Mar 28, 2012
Foreflight said on their Facebook page that they have no plans to develop traffic capability. On Tue, Mar 27, 2012 at 8:08 PM, Dj Merrill wrote: > > On 3/27/2012 11:00 PM, Kelly McMullen wrote: > >> >> My understanding is that Skyradar has had traffic for a year or more. Not >> sure if it was in WingX or not, but believe it was. >> >> > > The Skyradar ADS-B hardware does send both weather and traffic info to > the iPad. However, the WingX program only displays the weather. The > current version does not display traffic. > > Yes, if you run the Skyradar iPad app you will get both weather and > traffic displayed, but then you'd be giving up the WingX program, which was > the whole point of putting the iPad in my plane in the first place... :-) > > > -Dj > > -- > Dj Merrill - N1JOV > Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ > Glastar Flyer N866RH - http://deej.net/glastar/ > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 30, 2012
The same unit that Sporty's is promoting. http://www.sportys.com/PilotShop/product/17165 I am happy someone is sticking it to XM. BTW backordered 1 month, probably longer after SNF. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Albert Gardner Sent: Wednesday, March 28, 2012 12:06 PM Subject: RV10-List: Stratus: New for iPad and Foreflight This looks interesting. Albert Gardner N991RV Yuma, AZ Appareo Rolls Out Portable In-Flight Weather For iPad High Performance, Subscription-Free Receiver Made For Foreflight The first completely wire-free weather receiver for the iPad has been intro duced by Appareo, and it requires no monthly subscription. Stratus combines an ADS-B and GPS receiver into a single unit that wirelessly streams NEXRA D radar, text weather, TFRs and aircraft position to the popular ForeFlight Mobile app for iOS devices. $799.00 http://www.appareo.com/store/index.php?main_page=product_info&cPath=2&p roducts_id=6 ________________________________________________________________________________
Subject: Re: Stratus: New for iPad and Foreflight
Date: Mar 30, 2012
I ordered one the first day of the show, so I'll do a report after I have it up and running. They said they would be shipping around April 23rd. Has anyone downloaded the Garmin App? I've heard mixed feelings from people w ho have seen the demo. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 30, 2012, at 12:35 AM, Robin Marks wrote: > The same unit that Sporty's is promoting. > http://www.sportys.com/PilotShop/product/17165 > I am happy someone is sticking it to XM. > BTW backordered 1 month, probably longer after SNF. > Robin > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Albert Gardner > Sent: Wednesday, March 28, 2012 12:06 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Stratus: New for iPad and Foreflight > > This looks interesting. > Albert Gardner > N991RV > Yuma, AZ > > Appareo Rolls Out Portable In-Flight Weather For iPad > High Performance, Subscription-Free Receiver Made For Foreflight > The first completely wire-free weather receiver for the iPad has been intr oduced by Appareo, and it requires no monthly subscription. Stratus combines an ADS-B and GPS receiver into a single unit that wirelessly streams NEXRAD radar, text weather, TFRs and aircraft position to the popular ForeFlight M obile app for iOS devices. $799.00 > http://www.appareo.com/store/index.php?main_page=product_info&cPath=2& products_id=6 > > > ============== V10-List Email Forum - > :p> /o :p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ==== ========== bsp; - MATRONICS WEB FORUMS - :p> tp://for ums.matronics.com ============== bsp; - List Co ntribution Web Site - e> bsp; -Matt Dralle, List Admin. bu tion">http://www.matronics.com/contribution =========== == > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 30, 2012
Subject: RV10s and S&F Departures
So we did our day trip to S&F and it was fine. Met most of the people I've been talking to while flying off the first year. Upon departure the 'air boss', for lack of a better handle, seemed to be sorting fast traffic from slower traffic by assigning 9L to the slow (Cessna and Cherokee type) from the fast (RVs Lancelots, and Cirri) on 9R. If that was the plan, I found it wanting as I lined up behind several Piper products on 9L while the many RVs on 9R were given a "... that fine red and gold RV 7 is cleared to go on 9R". Okay, so on a gray daythe 10 resembles a lot of Lock Haven product , but it is an RV! And btw, it out climbs and out runs just about everything that looks like it. Well, after throttling back and S-turning trying to stay in trail for those first 3 miles, I couldn't avoid passing 2 planes before decidind to exit the conga line while running up on a third. This thing can really go! So, Mr. 'air boss', figure out what an RV10 looks like, understand that it performs like every other RV, and keep that slower sheet metal out of the freakin' way! Bill 'nuff said' Watson -smile- ________________________________________________________________________________
Subject: Re: RV10s and S&F Departures
Date: Mar 30, 2012
Maybe that RV-10 logo on my cowling will help after all. Glad you made it back safely. At least you could start leaning early this way. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 37 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369607#369607 ________________________________________________________________________________
Date: Mar 30, 2012
Subject: Inertial Reels and fuel exhaustion
I just read an article in the latest "Sport Aviation" about a Lancair IV-P pilot who crashed due to fuel exhaustion. After the crash, the cabin was intact, and the crash should have been survivable. Unfortunately, he hit his head on the dash because he wasn't wearing his shoulder harness. The reason he wasn't wearing the shoulder harness was that you couldn't reach the fuel selector switch in that version of the Lancair while fully strapped in. The pilot most likely removed his harness when the engine quit in order to switch tanks, then either couldn't reach the belts again, or never had time to. This raises two questions for me. First, when you are fully strapped in tight in a -10, is there anything critical that you can't reach? And second, is there a safe setup for inertial reel shoulder harnesses for the -10? Here is the article I referenced. It's a good read: http://www.sportaviationonline.org/sportaviation/201204?folio=24#pg26 ________________________________________________________________________________
Subject: Re: Inertial Reels and fuel exhaustion
Date: Mar 30, 2012
There is nothing important I cannot easily reach while strapped in tightly. The main nuisance thing I can't reach without loosening the shoulder harness a bit, is the copilot air vent. There are some inertia reel installations in -10's out there. One was a kit that beefed up the attach points in a big way. There were some posts on that kit recently either on this forum or VAF. I think the manufacturer has stopped producing the kit due to lack of demand, but was open to the idea of offering it again if there is some demand. I've looked at a couple that would simply bolt to the existing harness bolts, but have not followed up. -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369614#369614 ________________________________________________________________________________
Date: Mar 30, 2012
I have played with the Garmin app for a few hours. It is graphically pleasi ng and seems to do most if not all of the same things Foreflight does. I am more comfortable with Foreflight and there are many little things that bot h apps do that are just more intuitive and faster responding in Foreflight. Basic items like selecting an airport to get the specifics in FF you just tap on the chart airport icon but in the Garmin app you have to touch and h old to bring up a Ring with multiple options such as info, direct to, curre nt weather icon etc... Unfortunately you really need to zoom in a bit to pr operly tap the airport graphic and the hold time required seems awkward vs the Tap on FF, especially when you miss the icon a bit and it asks if you w ant to add this spot as a waypoint. So far I also prefer the graphical flig ht planning on FF better. All that being said for a fresh release it is a v ery strong flight app that takes its graphical cues from Garmins new touchs creen 650/750 products which I suspect will become more and more ubiquitous over time. Robin Sent from my iPad2. On Mar 30, 2012, at 6:14 AM, "Jesse Saint" > wrote: I ordered one the first day of the show, so I'll do a report after I have i t up and running. They said they would be shipping around April 23rd. Has anyone downloaded the Garmin App? I've heard mixed feelings from people who have seen the demo. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org<http://www.itecusa.org> www.mavericklsa.co<http://www.mavericklsa.com> C: 352-427-0285 O: 352-465-4545th F: 815-377-3694 Sent from my iPhone On Mar 30, 2012, at 12:35 AM, Robin Marks > wrote: The same unit that Sporty's is promoting. http://www.sportys.com/PilotShop/product/17165 I am happy someone is sticking it to XM. BTW backordered 1 month, probably longer after SNF. Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alb ert Gardner Sent: Wednesday, March 28, 2012 12:06 PM Subject: RV10-List: Stratus: New for iPad and Foreflight This looks interesting. Albert Gardner N991RV Yuma, AZ Appareo Rolls Out Portable In-Flight Weather For iPad High Performance, Subscription-Free Receiver Made For Foreflight The first completely wire-free weather receiver for the iPad has been intro duced by Appareo, and it requires no monthly subscription. Stratus combines an ADS-B and GPS receiver into a single unit that wirelessly streams NEXRA D radar, text weather, TFRs and aircraft position to the popular ForeFlight Mobile app for iOS devices. $799.00 http://www.appareo.com/store/index.php?main_page=product_info&cPath=2&p roducts_id=6 ============== V10-List Email Forum - > :p> /o: p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ==== ========== bsp; - MATRONICS WEB FORUMS - :p> tp://fo rums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ========= ==== 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D tronics.com/Navigator?RV10-List"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D .com/contribution"> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Mar 30, 2012
David said it exactly as I would have, the only thing I can't reach is the co-pilot air vent, so no worries.-=0A=0A=0A______________________________ __=0A From: Ed Kranz <ed.kranz(at)gmail.com>=0ATo: rv10-list(at)matronics.com =0A Sent: Friday, March 30, 2012 7:51 AM=0ASubject: RV10-List: Inertial Reels a nd fuel exhaustion=0A =0A=0AI just read an article in the latest "Sport Avi ation" about a Lancair IV-P pilot who crashed due to fuel exhaustion. After the crash, the cabin was intact, and the crash should have been survivable . Unfortunately, he hit his head on the dash because he wasn't wearing his shoulder harness.-=0A=0AThe reason he wasn't wearing the shoulder harness was that you couldn't reach the fuel selector switch in that version of th e Lancair while fully strapped in. The pilot most likely removed his harnes s when the engine quit in order to switch tanks, then either couldn't reach the belts again, or never had time to.=0A=0AThis raises two questions for me. First, when you are fully strapped in tight in a -10, is there anything critical that you can't reach? And second, is there a safe setup for inert ial reel shoulder harnesses for the -10?=0A=0AHere is the article I referen ced. It's a good read:-http://www.sportaviationonline.org/sportaviation/2 ====================== ________________________________________________________________________________
Date: Mar 30, 2012
I have the inertial reels belts and love them.... http://www.n423cf.com/belts/ I do not sell them or represent David. Just have his pages on my site as a service. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dmaib(at)me.com Sent: Friday, March 30, 2012 9:07 AM Subject: RV10-List: Re: Inertial Reels and fuel exhaustion There is nothing important I cannot easily reach while strapped in tightly. The main nuisance thing I can't reach without loosening the shoulder harness a bit, is the copilot air vent. There are some inertia reel installations in -10's out there. One was a kit that beefed up the attach points in a big way. There were some posts on that kit recently either on this forum or VAF. I think the manufacturer has stopped producing the kit due to lack of demand, but was open to the idea of offering it again if there is some demand. I've looked at a couple that would simply bolt to the existing harness bolts, but have not followed up. -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369614#369614 ________________________________________________________________________________
Subject: Inertia reels
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 30, 2012
This is how I mounted mine. This is one for the back but the fronts are esse ntially the same and essentially use the stock mounting bolt. In a crash, I don't think the bolt gets pulled down through the roof but rather dragged r adially through the cabin top. The greenish part is a simple section of .063 steel tube. --Dave
Subject: Desser offers tire deal
Date: Mar 30, 2012
Tim made mention on his site about the set of tires to get instead of from Vans. http://www.myrv10.com/N104CD/upgrades/20110326/index.html There was some confusion on what to get and where to find the tires on Desser=99s site http://www.vansaircrafttires.com/categories/RV%252d10/ To make it easier for those going this route I spoke with Desser and they have come up with a deal for Builders to make it easier to locate it all at once. It has the right valve (90 degree) and better (albeit retread) tires than the new Vans tires. As a bonus get a 10% deal by going this route http://www.vansaircrafttires.com/products/RV%252d10-New-Builders-Special- %283-tires-%26-3-tubes%29-save-10%25.html Rear tires for those flying when you need a new set http://www.vansaircrafttires.com/products/-RV%252d10-Main-Tire-Package-Sp ecial-save-10%25.html same deal- 10% by getting all at once. Pascal ________________________________________________________________________________
Date: Mar 30, 2012
I would just add, that if you don't go the inertial belt route, you do need a means to keep the shoulder harnesses out of the way when you aren't strapped in. I think just about everyone ends up with some kind of roof bracket. Some for sale, some fabricated, but it seems to me they are necessary to make their regular use a pleasure. A couple of hours with some aluminum sheet and a few blind nuts allowed me to produce a useable set. Bill On 3/30/2012 10:51 AM, Ed Kranz wrote: > I just read an article in the latest "Sport Aviation" about a Lancair > IV-P pilot who crashed due to fuel exhaustion. After the crash, the > cabin was intact, and the crash should have been survivable. > Unfortunately, he hit his head on the dash because he wasn't wearing > his shoulder harness. > > The reason he wasn't wearing the shoulder harness was that you > couldn't reach the fuel selector switch in that version of the Lancair > while fully strapped in. The pilot most likely removed his harness > when the engine quit in order to switch tanks, then either couldn't > reach the belts again, or never had time to. > > This raises two questions for me. First, when you are fully strapped > in tight in a -10, is there anything critical that you can't reach? > And second, is there a safe setup for inertial reel shoulder harnesses > for the -10? > > Here is the article I referenced. It's a good read: > http://www.sportaviationonline.org/sportaviation/201204?folio=24#pg26 > ________________________________________________________________________________
Subject: length of exhaust pipes
Date: Mar 30, 2012
Any correlation between the length of exhaust tubes and the length and breadth of the exhaust soot on the belly? How long are your exhaust tubes? How much crud on the underside? ________________________________________________________________________________
Subject: Re: length of exhaust pipes
Date: Mar 30, 2012
I think most of the crud comes from the oil blow-by. I don=99t really have any soot on my belly, I have a oil separator that I drain every once in while. From: DLM Sent: Friday, March 30, 2012 1:01 PM Subject: RV10-List: length of exhaust pipes Any correlation between the length of exhaust tubes and the length and breadth of the exhaust soot on the belly? How long are your exhaust tubes? How much crud on the underside? ________________________________________________________________________________
Date: Mar 30, 2012
I bet you haven't even been under your plane to even think about cleaning t he belly!=C2- Boy was the flight down to the keys and the lunch in Marath in GREAT today.=0A=0A=0AFrom: Pascal <rv10flyer(at)verizon.net>=0ATo: rv10-lis t(at)matronics.com =0ASent: Friday, March 30, 2012 3:36 PM=0ASubject: Re: RV10 -List: length of exhaust pipes=0A=0A=0AI think most of the crud comes from the oil blow-by. I don=99t really have any soot on my=C2- belly, I have a oil separator that I drain every once in while.=0A=0AFrom: DLM =0ASe nt: Friday, March 30, 2012 1:01 PM=0ATo: rv10-list(at)matronics.com =0ASubject : RV10-List: length of exhaust pipes=0AAny correlation between the length o f exhaust tubes and the length and breadth of the exhaust soot on the belly ? How long are your exhaust tubes? How much crud on the underside?=0Ahref ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/ Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.ma tronics.comhref="http://www.matronics.com/contribution">http://www.mat ================ ________________________________________________________________________________
Date: Mar 30, 2012
Mine are really long. I run lean except for takeoff/climbout. During break in a ran rich and exhaust pipes were black inside. Now tan. After 10 hrs I get a really thin layer of oil on the bottom. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369649#369649 ________________________________________________________________________________
Date: Mar 31, 2012
With the 'factory' engine setup and exhaust, I don't really get any soot at 1 25hrs+. I'll try to remember to measure the clearance next time I get to th e plane I do get oil which seems to all come from the breather tube. I should have a better measure but it seems to be down about a quart per 25 - 30 hours. It stays pretty clean. I do get a little soot coming out of the gear exit points at the wing roots ( ??) Bill Sent from my iPad On Mar 30, 2012, at 4:01 PM, "DLM" wrote: > Any correlation between the length of exhaust tubes and the length and bre adth of the exhaust soot on the belly? How long are your exhaust tubes? How m uch crud on the underside? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Palo Duro Canyon
Date: Mar 31, 2012
My wife and I are thinking of flying out to Palo Duro Canyon at Amarillo, TX. Anyone been there or live there that could give me some ideas on what to see/do and where would be the best place for lodging. Also is the main airport in Amarillo the desired airport to fly in to? Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: Palo Duro Canyon
Date: Mar 31, 2012
Don't miss the play Texas in the evening. Great event and make sure you get their dinner too. Lots of hiking in the area too. If you want to fly ~1hr west, you can reach the mountains of northern New Me xico. Red River is one of our favorite places. Phil Sent from my iPhone On Mar 31, 2012, at 7:57 AM, "Wayne Edgerton" wrote : > My wife and I are thinking of flying out to Palo Duro Canyon at Amarillo, T X. Anyone been there or live there that could give me some ideas on what to s ee/do and where would be the best place for lodging. Also is the main airpor t in Amarillo the desired airport to fly in to? > > Wayne Edgerton N602WT > > ==========================
February 28, 2012 - March 31, 2012
RV10-Archive.digest.vol-iq
