RV10-Archive.digest.vol-ir
March 31, 2012 - April 30, 2012
Date: Mar 31, 2012
Subject: Re: Palo Duro Canyon
Wayne, I've never used the AMA airport, so can't comment on it. Nearby and cheaper fuel is the Tradewinds airport, which I have used probably a dozen times. Tradewinds is closer to the hotels lining I-10, so you can pick whatever flavor you prefer. There is ground reception with approach control/clearance del at Tradewinds, so Class C clearance is no problem. At the time I was flying by there, one or more of the hotels would pick you up, as they are less than 2 mi away. Kelly On 3/31/2012 5:57 AM, Wayne Edgerton wrote: > My wife and I are thinking of flying out to Palo Duro Canyon at > Amarillo, TX. Anyone been there or live there that could give me some > ideas on what to see/do and where would be the best place for lodging. > Also is the main airport in Amarillo the desired airport to fly in to? > Wayne Edgerton N602WT > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 31, 2012
Wayne, My wife and I went there on our circle tour of the west last year. We used KAMA because the rental cars at Tradewinds airport were ridiculous. TacAir at KAMA did a great job and shuttled us over to the terminal for the rental. We stayed at the Holiday Inn Express in Canyon, the Best Western was full of firefighters. These are the closest hotels to the park. Buffalo's has good food. Palo Duro Canyon was very interesting. We hiked to the Lighthouses, 85 when we started, 105 when we finished. Take at least three quarts of water per person as the dry air will dehydrate you quickly. The burgers at the park concession are from the local longhorn steers and are awesome. Steve Roberts (swrpilot(at)bellsouth.net) RV10 Tailkit N2700W 1966 Mooney M20E 'Ms. Obsession' KMOR Morristown, TN From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton Sent: Saturday, March 31, 2012 8:57 AM Subject: RV10-List: Palo Duro Canyon My wife and I are thinking of flying out to Palo Duro Canyon at Amarillo, TX. Anyone been there or live there that could give me some ideas on what to see/do and where would be the best place for lodging. Also is the main airport in Amarillo the desired airport to fly in to? Wayne Edgerton N602WT ________________________________________________________________________________
Subject: Re: RV10s and S&F Departures
Date: Mar 31, 2012
We flew in Thursday morning and just left before 1100 today - Saturday. Hot and Dusty. I was behind a C-172 coming in so I just flew it at 85knots with half flaps. I didn't go last year, but I can say that there were only half the home builts there that I saw in 2010. Actually, lots of empty spaces on all the ramps. The big problem for HBs is they close the ramp a half hour before any show and wait until the final act pilot is half way to the bar before they open back up. If the shows actually started on time, I could understand. IF I go again, I'm not parking at HB. I'll find a ramp that doesn't close during the show. I only saw two other RV-10s at HB during the two days we were there. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369693#369693 ________________________________________________________________________________
Date: Mar 31, 2012
Maybe fuel prices, last years tornadoes, and the excessively long airshow had something to do with it. I have been once in 2009 and may go with my brother from KSEF next year. I'll make sure I don't park in HB area. Triple Tree will probably be much nicer for me. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369700#369700 ________________________________________________________________________________
Date: Mar 31, 2012
Subject: Re: length of exhaust pipes
That's not soot. That's rubber from the tires. Tim On 3/31/2012 7:16 AM, Bill Watson wrote: > With the 'factory' engine setup and exhaust, I don't really get any soot > at 125hrs+. I'll try to remember to measure the clearance next time I > get to the plane > > I do get oil which seems to all come from the breather tube. I should > have a better measure but it seems to be down about a quart per 25 - 30 > hours. It stays pretty clean. > > I do get a little soot coming out of the gear exit points at the wing > roots (??) > > Bill > > Sent from my iPad > > On Mar 30, 2012, at 4:01 PM, "DLM" > wrote: > >> Any correlation between the length of exhaust tubes and the length and >> breadth of the exhaust soot on the belly? How long are your exhaust >> tubes? How much crud on the underside? >> ________________________________________________________________________________
Date: Mar 31, 2012
.......or brake pad powder. Tim Olson wrote: > That's not soot. That's rubber from the tires. > > Tim > > On 3/31/2012 7:16 AM, Bill Watson wrote: > > > With the 'factory' engine setup and exhaust, I don't really get any soot > > at 125hrs+. I'll try to remember to measure the clearance next time I > > get to the plane > > > > I do get oil which seems to all come from the breather tube. I should > > have a better measure but it seems to be down about a quart per 25 - 30 > > hours. It stays pretty clean. > > > > I do get a little soot coming out of the gear exit points at the wing > > roots (??) > > > > Bill > > > > Sent from my iPad > > > > On Mar 30, 2012, at 4:01 PM, "DLM" wrote: > > > > > Any correlation between the length of exhaust tubes and the length and > > > breadth of the exhaust soot on the belly? How long are your exhaust > > > tubes? How much crud on the underside? > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369730#369730 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 31, 2012
So sad, used to be a premier show... I went from 1998 to 2008, but haven't been since.... Just doesn't seem the same.... -Mike Sent from my iPhone On Mar 31, 2012, at 1:18 PM, "rv10flyer" wrote: > > Maybe fuel prices, last years tornadoes, and the excessively long airshow had something to do with it. I have been once in 2009 and may go with my brother from KSEF next year. I'll make sure I don't park in HB area. Triple Tree will probably be much nicer for me. > > -------- > Wayne Gillispie, A&P 05/93 PP 10/08 > 40983SB 12/1/2009-12/1/2011 > N715WD 382nd Flying. TT= 41 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=369700#369700 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 01, 2012
And brake dust..... Sent from my iPhone On Mar 31, 2012, at 2:36 PM, Tim Olson wrote: > > That's not soot. That's rubber from the tires. > > Tim > > On 3/31/2012 7:16 AM, Bill Watson wrote: >> With the 'factory' engine setup and exhaust, I don't really get any soot >> at 125hrs+. I'll try to remember to measure the clearance next time I >> get to the plane >> >> I do get oil which seems to all come from the breather tube. I should >> have a better measure but it seems to be down about a quart per 25 - 30 >> hours. It stays pretty clean. >> >> I do get a little soot coming out of the gear exit points at the wing >> roots (??) >> >> Bill >> >> Sent from my iPad >> >> On Mar 30, 2012, at 4:01 PM, "DLM" > > wrote: >> >>> Any correlation between the length of exhaust tubes and the length and >>> breadth of the exhaust soot on the belly? How long are your exhaust >>> tubes? How much crud on the underside? >>> > > > > > ________________________________________________________________________________
Subject: Re: Desser offers tire deal
Date: Apr 01, 2012
I really like the monster retreads and will always use them, but what makes them particularly attractive is their hefty tread which also makes their circumference larger than the plans specify which means that the geometry of the pant fitting is different than the plan specifications and must be accounted for starting with a thinner spacing block (discovered the hard way). -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369788#369788 ________________________________________________________________________________
Subject: door struts
Date: Apr 02, 2012
Has anyone found a stronger replacement than the original equipment sent with the kit? Anyone have the dimensions and force specifications of the original equipment? After four years even the temperatures in AZ do not reliably keep the doors open. If anyone has it, I need the open and closed length of the strut and the force required to close ________________________________________________________________________________
Date: Apr 02, 2012
Subject: please help me...........Rick
- I am presently in Istanbul , Turkey for an urgent trip. Unfortunately i was robbed in the hotel i lodged, all my valuables including cash, cell ph ones was stolen during the attack but luckily i still have my passport with me. I have been to the Embassy and the Police here but they're not helping issues at all. Please i really need your financial assistance now because things are really getting tough on me here. Kindly lend me $2,500 usd or an y amount you can afford to me now,so i can sort out things and leave here, i promise to refund it immediately i get back. Please send it through Weste rn Union with my name and the address below: Name: Keryn Lee HaynesAddress:Acisu Sok No 5 D 4MackaIstanbulTurkey Kindly send me the transfer details including the Transfer Number (MTCN) as soon as you send it. I await your urgent response. Waiting for your help Regards,Keryn- ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Apr 02, 2012
Subject: Re: door struts
Vans sells a stronger strut than the one in the kit. I tried to find them less expensively but didn't have any luck so I got a set from Vans. They've been on for a couple years now, working well. --Dave Saylor On Mon, Apr 2, 2012 at 12:18 PM, DLM wrote: > Has anyone found a stronger replacement than the original equipment sent > with the kit? Anyone have the dimensions and force specifications of the > original equipment? After four years even the temperatures in AZ do not > reliably keep the doors open. If anyone has it, I need the open and closed > length of the strut and the force required to close**** > > * > > * > > ________________________________________________________________________________
Date: Apr 02, 2012
The answer is 'yes'. I don't have the information myself, but I've seen it posted before. Do a search, you'll find the answers. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369899#369899 ________________________________________________________________________________
Date: Apr 02, 2012
Subject: Re: AeroElectric-List: please help me...........Rick
Guys, sorry about the message below.- It appears someone somehow hijacked my yahoo account.- I've changed the password for now and depending on wh at the Yahoo administration says I may change the whole account.- The wor st thing about this is that all my saved-emails containing-tips/advise have been deleted.-Hopefully Yahoo can restore them. Again, sorry about this.............Rick- --- On Mon, 4/2/12, Robert L. Nuckolls, III wrote: From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> Subject: Re: AeroElectric-List: please help me...........Rick Received: Monday, April 2, 2012, 9:46 PM Rick Lark, It appears that your email address has been hijacked by somebody in Turkey who is hopeful that someone on this List is going to 'loan' him a bucket full of money. Suggest you attend to changing your email address with Yahoo. Bob . . . At 03:43 PM 4/2/2012, you wrote: - I am presently in Istanbul , Turkey for an urgent trip. Unfortunately i was robbed in the hotel i lodged, all my valuables including cash, cell ph ones was stolen during the attack but luckily i still have my passport with me. I have been to the Embassy and the Police here but they're not helping issues at all. Please i really need your financial assistance now because things are really getting tough on me here. Kindly lend me $2,500 usd or an y amount you can afford to me now,so i can sort out things and leave here, i promise to refund it immediately i get back. Please send it through Weste rn Union with my name and the address below: Name: Keryn Lee Haynes Address:Acisu Sok No 5 D 4 Macka Istanbul Turkey Kindly send me the transfer details including the Transfer Number (MTCN) as soon as you send it. I await your urgent response. Waiting for your help Regards, Keryn ________________________________________________________________________________
Date: Apr 02, 2012
Are you saying I shouldn't have sent all my savings that were for the RV14 t o Istanbul? Sent from my iPhone On Apr 2, 2012, at 19:34, Rick Lark wrote: > > Guys, sorry about the message below. It appears someone somehow hijacked m y yahoo account. I've changed the password for now and depending on what th e Yahoo administration says I may change the whole account. The worst thing about this is that all my saved emails containing tips/advise have been del eted. Hopefully Yahoo can restore them. > Again, sorry about this.............Rick > > --- On Mon, 4/2/12, Robert L. Nuckolls, III wrote: > > From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: please help me...........Rick > To: aeroelectric-list(at)matronics.com > Received: Monday, April 2, 2012, 9:46 PM > > Rick Lark, > > It appears that your email address has been hijacked > by somebody in Turkey who is hopeful that someone on > this List is going to 'loan' him a bucket full of money. Suggest > you attend to changing your email address with Yahoo. > > Bob . . . > > At 03:43 PM 4/2/2012, you wrote: >> I am presently in Istanbul , Turkey for an urgent trip. Unfortunately i was robbed in the hotel i lodged, all my valuables including cash, cell pho nes was stolen during the attack but luckily i still have my passport with m e. I have been to the Embassy and the Police here but they're not helping is sues at all. Please i really need your financial assistance now because thin gs are really getting tough on me here. Kindly lend me $2,500 usd or any amo unt you can afford to me now,so i can sort out things and leave here, i prom ise to refund it immediately i get back. Please send it through Western Unio n with my name and the address below: >> >> >> Name: Keryn Lee Haynes >> Address:Acisu Sok No 5 D 4 >> Macka >> Istanbul >> Turkey >> >> Kindly send me the transfer details including the Transfer Number (MTCN) a s soon as you send it. I await your urgent response. >> >> >> Waiting for your help >> >> Regards, >> Keryn > > > ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Aer oElectric-List > et=_blank>http://forums.matronics.com > llow target=_blank>http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 02, 2012
I want my $2500 back. Rick Sent from my iPhone On Apr 2, 2012, at 6:34 PM, Rick Lark wrote: > > Guys, sorry about the message below. It appears someone somehow hijacked m y yahoo account. I've changed the password for now and depending on what th e Yahoo administration says I may change the whole account. The worst thing about this is that all my saved emails containing tips/advise have been del eted. Hopefully Yahoo can restore them. > Again, sorry about this.............Rick > > --- On Mon, 4/2/12, Robert L. Nuckolls, III wrote: > > From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> > Subject: Re: AeroElectric-List: please help me...........Rick > To: aeroelectric-list(at)matronics.com > Received: Monday, April 2, 2012, 9:46 PM > > Rick Lark, > > It appears that your email address has been hijacked > by somebody in Turkey who is hopeful that someone on > this List is going to 'loan' him a bucket full of money. Suggest > you attend to changing your email address with Yahoo. > > Bob . . . > > At 03:43 PM 4/2/2012, you wrote: >> I am presently in Istanbul , Turkey for an urgent trip. Unfortunately i was robbed in the hotel i lodged, all my valuables including cash, cell pho nes was stolen during the attack but luckily i still have my passport with m e. I have been to the Embassy and the Police here but they're not helping is sues at all. Please i really need your financial assistance now because thin gs are really getting tough on me here. Kindly lend me $2,500 usd or any amo unt you can afford to me now,so i can sort out things and leave here, i prom ise to refund it immediately i get back. Please send it through Western Unio n with my name and the address below: >> >> >> Name: Keryn Lee Haynes >> Address:Acisu Sok No 5 D 4 >> Macka >> Istanbul >> Turkey >> >> Kindly send me the transfer details including the Transfer Number (MTCN) a s soon as you send it. I await your urgent response. >> >> >> Waiting for your help >> >> Regards, >> Keryn > > > ist" rel=nofollow target=_blank>http://www.matronics.com/Navigator?Aer oElectric-List > et=_blank>http://forums.matronics.com > llow target=_blank>http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 02, 2012
I have Van's heavy duty struts and they work well, but are pricey at $120 as I recall. Struts from McMaster-Carr and others are less expensive, but results have been variable. Search here and VAF for details. Jim Berry N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369919#369919 ________________________________________________________________________________
Date: Apr 03, 2012
JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com . The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was ~$80 each. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369935#369935 ________________________________________________________________________________
Date: Apr 03, 2012
John I was standing next to your plane and waiting to shake the hand of a fellow RV-10 pilot when they kicked us out for the show. I've been to at least ten Sun N Fun's and might have watched the show once. Not important to me it's the homebuilts that get me there. As said here not sure I will attend again soon, even left our RV at Kissimmee. Not the show of a few years ago. One thing they did improve on was the drinks, there were numerous outlets this year although they cost more than an aircraft. Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369983#369983 ________________________________________________________________________________
Subject: Exhaust installation plan
Date: Apr 05, 2012
Hi, I cant find the handwritten exhaust installation plans from Vetterman. Could someone please post them as pdf? I installed them from what I remember seeing but I cant get them fit close enough to the belly and to the gear to not inter fear with the bottom cowling. Installation pictures are welcome as well. Thanks Michael -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370069#370069 ________________________________________________________________________________
Subject: Re: Exhaust installation plan
Date: Apr 05, 2012
You will need to cut a half moon shape out in lower cowl to provide 1/2" clearance. No more than that is needed due to large amount of cooling air at high power settings. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370091#370091 ________________________________________________________________________________
Date: Apr 05, 2012
I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would not cut the cowl except as a last resort. Jim Berry N15JB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370108#370108 ________________________________________________________________________________
Date: Apr 05, 2012
I agree Jim, could someone please send me a scan of the plan though because the way I did mount it, it doest really fit. Mike Jim Berry wrote: > I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would not cut the cowl except as a last resort. > > Jim Berry > N15JB -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370115#370115 ________________________________________________________________________________
Date: Apr 05, 2012
I trimmed my cowl per plans and there is plenty of clearance for the pipes. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Mike Whisky" <rv-10(at)wellenzohn.net> Sent: Thursday, April 5, 2012 2:16:55 PM Subject: RV10-List: Re: Exhaust installation plan I agree Jim, could someone please send me a scan of the plan though because the way I di d mount it, it does=C3=82=C2=B4t really fit. Mike Jim Berry wrote: > I did not need to cut the lower cowl to get clearance, but it did take a fair amount of fiddling with the exhaust hangers to get it right. I would n ot cut the cowl except as a last resort. > > Jim Berry > N15JB -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370115#370115 =========== =========== =========== =========== ________________________________________________________________________________
Date: Apr 05, 2012
Have you seen these revisions? Mine worked just about like the prototype in these pictures, no cutting on anything but a fair amount of jockeying around and bending of the support strap to pull the exhaust up higher and keep it there such that the clearance to the bottom edge of the firewall is close but ok. -Chris N919AR Flying http://www.vansaircraft.com/pdf/revisions/RV-10/FF6-06.pdf http://www.vansaircraft.com/pdf/revisions/RV-10/FF6-05.pdf http://www.vansaircraft.com/pdf/revisions/RV-10/FF6-01.pdf -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mike Whisky Sent: Thursday, April 05, 2012 7:36 AM Subject: RV10-List: Exhaust installation plan Hi, I cant find the handwritten exhaust installation plans from Vetterman. Could someone please post them as pdf? I installed them from what I remember seeing but I cant get them fit close enough to the belly and to the gear to not inter fear with the bottom cowling. Installation pictures are welcome as well. Thanks Michael -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370069#370069 ________________________________________________________________________________
Date: Apr 05, 2012
Thanks Chris, This is exactly what I needed! It looks as if I'll have to cut back my breather tube a bit as it is in the way of the exhaust pipe. Regards Michael -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370144#370144 ________________________________________________________________________________
Subject: Seatbelts - lap belt adjusters
Date: Apr 06, 2012
Quick question, regarding the buckles of my lap belt, where did you choose to mount the adjusters, at the buckle or at the endfittings. See attached drawing. Thanks Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370174#370174 ________________________________________________________________________________
Subject: Length of the shoulder harness sections
Date: Apr 06, 2012
And here is one more questions, I measured the different length of the shoulder harness (see attached picture) I was wondering if this is matching your length. Appreciate your feedback Thanks Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370176#370176 Attachments: http://forums.matronics.com//files/shoulder_harness_length_988.jpg ________________________________________________________________________________
Subject: Tank Vent/Newton Fuel Caps
Date: Apr 07, 2012
I have been living with this problem for quite a while and would like to solicit some ideas for dealing with the problem. I purchased and installed the retrofit locking caps that Van's sells for tanks that are already built. http://tinyurl.com/7fbvpyw You receive a sleeve that fits into the existing fuel cap flange. You install this sleeve into the flange using tank sealant to secure it, and then the new caps fit into the sleeve. Easy job and it looks great. The caps are manufactured by Newton and are very nice. The problem is that when tanks are filled, the fuel comes into contact with the bottom of the cap (the cap is about 1 1/2 inches deep), and, after takeoff, fuel siphons out of the key slot on the cap until the fuel level drops below the bottom of the cap. Usually, the problem stops quickly if you are burning fuel out of the tank. I also have the SafeAir1 extended range tip tanks and have installed these caps, but they do not have this problem. The tank vents are different on the tip tanks. They are a coiled aluminum tube versus the simple 90 degree bent tube on the main tanks. Both vents have the beveled opening facing forward. Could the difference in the vent lines be the key to solving this? I was admiring a Harmon Rocket a couple of weeks ago and I noticed that it had the Newton caps installed. I talked to the owner and he confirmed that they were the same caps from Van's. He said he fills his to the top routinely and never has any fuel siphon through the key slot. I did not think to take a look at his tank vents. I am aware of several RV-10's that have these caps and, as far as I know, they all have this problem. I emailed Newton about this, but have received no response so far. Any thoughts or suggestions, guys/gals? [Question] -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370242#370242 ________________________________________________________________________________
Subject: Re: Tank Vent/Newton Fuel Caps
Date: Apr 07, 2012
I don't have these caps but it sounds to me as if there is a design defect, or perhaps an O ring that needs replacing. Since the fuel caps are on the top of the wing, a low pressure area, they will siphon fuel out if they leak at all. This will also make the fuel pump work harder, especially if the normal vent can't keep up with the pressure loss out the top. And if gas can get out, then rain can get in. Fuel caps shouldn't leak. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370262#370262 ________________________________________________________________________________
Date: Apr 07, 2012
Bob Turner wrote: > I don't have these caps but it sounds to me as if there is a design defect, or perhaps an O ring that needs replacing. > > Since the fuel caps are on the top of the wing, a low pressure area, they will siphon fuel out if they leak at all. This will also make the fuel pump work harder, especially if the normal vent can't keep up with the pressure loss out the top. And if gas can get out, then rain can get in. > > Fuel caps shouldn't leak. I certainly agree that caps should not leak. But, all of these caps installed on RV-10's seem to do this. I can't imagine it is an o ring problem when this seems to be a fleet problem limited to RV-10's. So, I would lean towards the design defect, except that it does not seem to be a problem on other types of aircraft. (that I know of) Interestingly enough, My airplane has had to sit out in significant rain a few times and I have never had one drop of water in my fuel samples. Ever. I am zeroing in on the RV-10 tank vent design because I cannot think of anything else at this point. I hope somebody on the forum has some insight on this issue. -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370263#370263 ________________________________________________________________________________
Subject: Re: Seatbelts - lap belt adjusters
Date: Apr 08, 2012
Hi Marcus Tanks for your feedback I guess you are right it will make pulling the belt tight easier. Thanks Michael -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370274#370274 ________________________________________________________________________________
Date: Apr 08, 2012
Ok the right right muffler is mounted an it worked out perfectly. However the left one doesn't work at all because the metal muffler bracing either is not wide enough when bent to achieve the necessary height to keep the exhaust pipe up. Or it interferes with the heating duct. Not sure if I am the only one with this issue and what is wrong. Any ideas anyone. Regards Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370276#370276 ________________________________________________________________________________
Date: Apr 08, 2012
We have the Newton caps. We fill up after every flight but we leave each tank down by 2 gallons. We do this so it doesn't vent out the normal vents onto the floor. There isn't much expansion room in these tanks. I've heard of fuel coming out the key hole but if it happens to us it's very rare. I very much doubt you would loose a meaningful amount of fuel. I've never seen any water get in. --Dave Saylor 1015 hrs On Apr 7, 2012, at 23:44, "dmaib(at)me.com" wrote: > > > Bob Turner wrote: >> I don't have these caps but it sounds to me as if there is a design defect, or perhaps an O ring that needs replacing. >> >> Since the fuel caps are on the top of the wing, a low pressure area, they will siphon fuel out if they leak at all. This will also make the fuel pump work harder, especially if the normal vent can't keep up with the pressure loss out the top. And if gas can get out, then rain can get in. >> >> Fuel caps shouldn't leak. > > > I certainly agree that caps should not leak. But, all of these caps installed on RV-10's seem to do this. I can't imagine it is an o ring problem when this seems to be a fleet problem limited to RV-10's. So, I would lean towards the design defect, except that it does not seem to be a problem on other types of aircraft. (that I know of) > > Interestingly enough, My airplane has had to sit out in significant rain a few times and I have never had one drop of water in my fuel samples. Ever. > > I am zeroing in on the RV-10 tank vent design because I cannot think of anything else at this point. I hope somebody on the forum has some insight on this issue. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370263#370263 > > > > > > > > > > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Apr 08, 2012
Yep - same problem with my left side. I ended up cutting the lower hanger bolt (the one on the end of the cable) and snugging up the brackets such that I had the shortest overall length between the bent hanger and the exhaust attach point. Cutting the lower bolt is needed as the end hits the exhaust attach point long before you run out of threads. I also mounted the bent hanger as high as possible. Combined these solved the problem. Carl First engine start - next week. On Apr 8, 2012, at 8:20 AM, "Mike Whisky" wrote: > > Ok the right right muffler is mounted an it worked out perfectly. > > However the left one doesn't work at all because the metal muffler bracing either is not wide enough when bent to achieve the necessary height to keep the exhaust pipe up. Or it interferes with the heating duct. > > Not sure if I am the only one with this issue and what is wrong. > > Any ideas anyone. > > Regards > Mike > > -------- > RV-10 builder (interior & finishing) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370276#370276 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 08, 2012
Leaving the tank down enough to keep the fuel from contacting the bottom of the caps does work, but I would really like to be able to get the tanks close to full when leaving on a long cross country. I agree that the amount of fuel vented is not significant, but it makes a mess on the wing with the blue dye. Full tanks will definitely lose fuel through the vent tubes as fuel expands with rising temperatures. I've seen that happen on many different airplanes. I may try modifying my vent tubes with a couple of coils, like my tip tank vent tubes. I can't see why that should make a difference, but I guess it is worth a try. -------- David Maib RV-10 #40559 Transition Trainer Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370287#370287 ________________________________________________________________________________
Subject: Turboprop RV10
Date: Apr 08, 2012
http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_SunNFun2012_DiemechDieselEngine_206389-1.html -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370344#370344 ________________________________________________________________________________
Date: Apr 08, 2012
Subject: Re: Turboprop RV10
So you are going to switch to this and need to dispose of your Lycasaurus to fund this. Of course W&B and fuel capacity will need some minor adjustments. On Sun, Apr 8, 2012 at 9:00 PM, woxofswa wrote: > > http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_SunNFun2012_DiemechDieselEngine_206389-1.html > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370344#370344 > > ________________________________________________________________________________
Date: Apr 08, 2012
Not for me thanks. Just thought it was interesting. The 210k cost difference, fuel burn difference, insurance difference, etc, just doesn't add up to me. Not that anything in aviation makes sense, but if gotta have a turbine, you can buy an MU-2 for the cost of that motor. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse in mostly done, finishing kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370347#370347 ________________________________________________________________________________
Date: Apr 09, 2012
I didn't see it at SNF, but I'm surprised at the weight - only 128 pounds before accessories. A 17 to 1 gear reduction, so the gearbox should be included in the 128 pounds. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370370#370370 ________________________________________________________________________________
Date: Apr 09, 2012
Subject: Aircraft Spruce Story Contest
http://www.aircraftspruce.com/menus/kits/0aircraftstories.html Rv-10 dedication story Adrian Moses 719AM Flying 167 hrs This message may contain confidential information. If you are not the desig nated recipient, please notify the sender immediately, and delete the origi nal and any copies. Any use of the message by you is prohibited. ________________________________________________________________________________
Date: Apr 09, 2012
Subject: Door Gutter and McMaster Seals
I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? Thanks, -Sean #40303 (very dim light at the end of the tunnel) ________________________________________________________________________________
Subject: Re: Door Gutter and McMaster Seals
Date: Apr 09, 2012
Hi Sean There is a very big difference - I believe it is the colour. Cheers Les Ps. I was told by someone who knows that there really isn't any difference. Sent from my iPhone On 2012-04-09, at 6:48 PM, Sean Stephens wrote: > > I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. > > I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. > > His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? > > Thanks, > > -Sean #40303 (very dim light at the end of the tunnel) > > > > ________________________________________________________________________________
Date: Apr 09, 2012
Sean, Part of installing the seal is to build up the area on both sides of the old gutter rail. Once you cut it flat it needs to be extended out and thickened both on the inside and the out. Ultimately, the seal will be about 50% compressed when you are complete. Here is how my seal fits. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370413#370413 Attachments: http://forums.matronics.com//files/img_1396_198.jpg ________________________________________________________________________________
Date: Apr 09, 2012
There are differences, but they arent significant. The pink tops are slightly better finished. Only important if you aren't using a headliner. There appears to be two different pink top molds, as well as the green mold, that have the step up behind the front seat line in different places. it makes delivering an after market overhead more difficult. I'm not aware of any differences around the door gutter. Sent from my iPad On Apr 9, 2012, at 9:17 PM, Les Kearney wrote: > > Hi Sean > > There is a very big difference - I believe it is the colour. > > Cheers > > Les > > Ps. I was told by someone who knows that there really isn't any difference. > > Sent from my iPhone > > On 2012-04-09, at 6:48 PM, Sean Stephens wrote: > >> >> I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. >> >> I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. >> >> His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? >> >> Thanks, >> >> -Sean #40303 (very dim light at the end of the tunnel) >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 09, 2012
Be careful on ordering the trim. If I remember Les's doc, the picture showed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want the barb to add thickness to the seal into between the free and the door. Go to Ivan Kristense's phanfare.com photo site. In the middle o f his door photos, there is a video showing in detail how to trim the door gutter. I cut off the full radius and my doors are very tight fitting with the seals on. I have a pink top. Sent from my iPad On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: > > I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. > > I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. > > His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? > > Thanks, > > -Sean #40303 (very dim light at the end of the tunnel) > > > > ________________________________________________________________________________
Date: Apr 09, 2012
Hi Again Bob is right about my seals. That being said, I did make mine work. I am not sure if the barb orientation makes a significant difference but would probably go with the inside barb if I was doing things again. Cheers Les Cheers Les Sent from my iPhone On 2012-04-09, at 8:27 PM, Bob Leffler wrote: > > Be careful on ordering the trim. If I remember Les's doc, the picture showed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want the barb to add thickness to the seal into between the free and the door. > > Go to Ivan Kristense's phanfare.com photo site. In the middle o f his door photos, there is a video showing in detail how to trim the door gutter. > > I cut off the full radius and my doors are very tight fitting with the seals on. I have a pink top. > > Sent from my iPad > > On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: > >> >> I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. >> >> I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. >> >> His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? >> >> Thanks, >> >> -Sean #40303 (very dim light at the end of the tunnel) >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 09, 2012
Ivan's pictures were a big help. After looking at them and the video it seems like the following rough steps can be taken. - Once the doors are trimmed to fit, mark the interior edge of the gutter for a consistent gap (less than 3/8 for the bulb) - Sand down the radius to marks on interior edge of gutter and trim/sand gutter width to dimensions at various locations given by Ivan - Fill/sand to achieve necessary gutter thickness of 1/4 inch for attaching seal Thanks for pointing me to Ivan's pictures. -Sean On 4/9/12 9:27 PM, Bob Leffler wrote: > --> RV10-List message posted by: Bob Leffler > > Be careful on ordering the trim. If I remember Les's doc, the picture showed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want the barb to add thickness to the seal into between the free and the door. > > Go to Ivan Kristense's phanfare.com photo site. In the middle o f his door photos, there is a video showing in detail how to trim the door gutter. > > I cut off the full radius and my doors are very tight fitting with the seals on. I have a pink top. > > Sent from my iPad > > On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: > >> --> RV10-List message posted by: Sean Stephens >> >> I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. >> >> I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. >> >> His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? >> >> Thanks, >> >> -Sean #40303 (very dim light at the end of the tunnel) >> >> >> >> > > ________________________________________________________________________________
Date: Apr 10, 2012
We were the first to use the McM seal. We started a grinder and added a spa cer for even reveal. Seemed to work out well on the old top. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Sean Stephens Sent: Monday, April 09, 2012 9:16 PM Subject: Re: RV10-List: Door Gutter and McMaster Seals Ivan's pictures were a big help. After looking at them and the video it se ems like the following rough steps can be taken. - Once the doors are trimmed to fit, mark the interior edge of the gutter f or a consistent gap (less than 3/8 for the bulb) - Sand down the radius to marks on interior edge of gutter and trim/sand gu tter width to dimensions at various locations given by Ivan - Fill/sand to achieve necessary gutter thickness of 1/4 inch for attaching seal Thanks for pointing me to Ivan's pictures. -Sean On 4/9/12 9:27 PM, Bob Leffler wrote: > --> RV10-List message posted by: Bob Leffler > > Be careful on ordering the trim. If I remember Les's doc, the picture sh owed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want t he barb to add thickness to the seal into between the free and the door. > > Go to Ivan Kristense's phanfare.com photo site. In the middle o f his d oor photos, there is a video showing in detail how to trim the door gutter. > > I cut off the full radius and my doors are very tight fitting with the se als on. I have a pink top. > > Sent from my iPad > > On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: > >> --> RV10-List message posted by: Sean >> --> Stephens >> >> I've read Les' document on using McMaster Carr door seals. He trimmed o ff the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. >> >> I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touc h and seal against the door. Seems the gap between the gutter and the door would be too large. >> >> His doc showed the older green canopy instead of the pink. Is there a d ifference there? Did others using the McMaster seals trim off the full rad ius on the gutter and have it work with the 3/8 inch bulb? >> >> Thanks, >> >> -Sean #40303 (very dim light at the end of the tunnel) >> >> >> >> > > ________________________________________________________________________________
Date: Apr 10, 2012
That all sounds about right. Getting the barb on the right side helps. Two other things: If you plan any sort of fabric covering for the door, you have to account for that in the bulb gap. Flightline's interior would be an example Don't trim for final length until you are absolutely finished with the gap work. Any gap work increases the length of seal. You can patch it, or better yet just buy the full 50/100 foot length so you can do it 2 or 3 times, then sell extra to a friend. DAHIK Bill Sent from my iPad On Apr 10, 2012, at 12:15 AM, Sean Stephens wrote: > > Ivan's pictures were a big help. After looking at them and the video it seems like the following rough steps can be taken. > > - Once the doors are trimmed to fit, mark the interior edge of the gutter for a consistent gap (less than 3/8 for the bulb) > - Sand down the radius to marks on interior edge of gutter and trim/sand gutter width to dimensions at various locations given by Ivan > - Fill/sand to achieve necessary gutter thickness of 1/4 inch for attaching seal > > Thanks for pointing me to Ivan's pictures. > > -Sean > > On 4/9/12 9:27 PM, Bob Leffler wrote: >> --> RV10-List message posted by: Bob Leffler >> >> Be careful on ordering the trim. If I remember Les's doc, the picture showed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want the barb to add thickness to the seal into between the free and the door. >> >> Go to Ivan Kristense's phanfare.com photo site. In the middle o f his door photos, there is a video showing in detail how to trim the door gutter. >> >> I cut off the full radius and my doors are very tight fitting with the seals on. I have a pink top. >> >> Sent from my iPad >> >> On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: >> >>> --> RV10-List message posted by: Sean Stephens >>> >>> I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used. >>> >>> I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large. >>> >>> His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb? >>> >>> Thanks, >>> >>> -Sean #40303 (very dim light at the end of the tunnel) >>> >>> >>> >>> >> >> >> >> >> > > > > ________________________________________________________________________________
Date: Apr 10, 2012
I saw it at SnF. It was pretty impressive, and there was a ton of room around the engine--especially the back. I would love to have one, but I think it might be a bit pricey. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370430#370430 ________________________________________________________________________________
Date: Apr 10, 2012
I used the McMaster seals as well, but did the following: After grinding the gutter lip down, I took a scrap piece of door seal about 3 foot long and filled it (about 50% full) with epoxy/structural filler mix and applied it to the door frame. When cured I had the perfect mating detail for the door seal as part of the cabin top. Step and repeat around the door frame opening then discard the scrap seal and use new seal for the final installation. The following album has the details, seal pictures start about 1/3 of the way into the album. https://picasaweb.google.com/aviator1964/DoorsLatchesSeals?authuser=0&feat=directlink Bob Newman N541RV flying -----Original Message----- From: Bill Watson Sent: Tuesday, April 10, 2012 7:04 AM Subject: Re: RV10-List: Door Gutter and McMaster Seals That all sounds about right. Getting the barb on the right side helps. Two other things: If you plan any sort of fabric covering for the door, you have to account for that in the bulb gap. Flightline's interior would be an example Don't trim for final length until you are absolutely finished with the gap work. Any gap work increases the length of seal. You can patch it, or better yet just buy the full 50/100 foot length so you can do it 2 or 3 times, then sell extra to a friend. DAHIK Bill Sent from my iPad On Apr 10, 2012, at 12:15 AM, Sean Stephens wrote: > > Ivan's pictures were a big help. After looking at them and the video it > seems like the following rough steps can be taken. > > - Once the doors are trimmed to fit, mark the interior edge of the gutter > for a consistent gap (less than 3/8 for the bulb) > - Sand down the radius to marks on interior edge of gutter and trim/sand > gutter width to dimensions at various locations given by Ivan > - Fill/sand to achieve necessary gutter thickness of 1/4 inch for > attaching seal > > Thanks for pointing me to Ivan's pictures. > > -Sean > > On 4/9/12 9:27 PM, Bob Leffler wrote: >> --> RV10-List message posted by: Bob Leffler >> >> Be careful on ordering the trim. If I remember Les's doc, the picture >> showed a version of the seal with the barb on the exterior. You'll want >> the version that has the barb on the inside of the door frame. You don't >> want the barb to add thickness to the seal into between the free and the >> door. >> >> Go to Ivan Kristense's phanfare.com photo site. In the middle o f his >> door photos, there is a video showing in detail how to trim the door >> gutter. >> >> I cut off the full radius and my doors are very tight fitting with the >> seals on. I have a pink top. >> >> Sent from my iPad >> >> On Apr 9, 2012, at 8:48 PM, Sean Stephens wrote: >> >>> --> RV10-List message posted by: Sean Stephens >>> >>> I've read Les' document on using McMaster Carr door seals. He trimmed >>> off the entire radius on the door gutter. I ordered the same 1/4 inch >>> with 3/8 inch bulb seals he used. >>> >>> I have yet to trim off the full radius as he did, but it seems that if I >>> do, there will me no way the 3/8 inch bulb will be enough to actually >>> touch and seal against the door. Seems the gap between the gutter and >>> the door would be too large. >>> >>> His doc showed the older green canopy instead of the pink. Is there a >>> difference there? Did others using the McMaster seals trim off the full >>> radius on the gutter and have it work with the 3/8 inch bulb? >>> >>> Thanks, >>> >>> -Sean #40303 (very dim light at the end of the tunnel) >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Apr 10, 2012
We each build our own airplanes and make our own decisions please dont take this as criticism just food for thought. I had a conversation with Ken K. regarding drilling holes in the gutter in order to add sun visors the cabin top, specifically the cabin top posts. Ken indicated that one of the challenges in the design was getting the cabin top to pass the inverted drop test. He was visibly uncomfortable with the idea of drilling any holes in the gutter to mount visors, for those who have had conversations with Ken K. in person you may know the wince he gives. By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design. Again, these are your decisions I am only trying to provide an alternate perspective to the decision. Thanks Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370434#370434 ________________________________________________________________________________
Date: Apr 10, 2012
Maybe it's obvious, but maybe not... After cutting the door edges flush and sanding, I used an ~18" section of door seal as a mold. Filling each section with structural epoxy made for a really tight fit and minimal additional prep work to get the seal right. Just add cosmetic filler to blend into the cabin top and door edges. I bought lots more edge than required as it tends to get tired and look wavy after fitting lots of times (you can see some of that in the photos). Save the good stuff for the end. Regards, Jay finishing up Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370436#370436 Attachments: http://forums.matronics.com//files/img_20110910_115316_138.jpg http://forums.matronics.com//files/hpim0911_134.jpg http://forums.matronics.com//files/hpim0913_351.jpg http://forums.matronics.com//files/hpim0915_141.jpg ________________________________________________________________________________
Date: Apr 10, 2012
I ran into the same problem with fabric covering the door - I didn't account for it and ended up with the door seal too tight, so I had to trim the fabric short. As a side note, everyone please try to size down your photos before posting, it takes too much side scrolling to read the message. All it takes is one huge photo. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370444#370444 ________________________________________________________________________________
Subject: Re: Length of the shoulder harness sections
Date: Apr 11, 2012
Sorry to bring this thread up again but I really need to know what the length, especially of the top part of the harness needs to be. Is 17 inch a correct assumption? Thanks Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370508#370508 ________________________________________________________________________________
Date: Apr 11, 2012
There is an adjustment buckle near the attachment point. Adjust them to suit, and if there is too much tag end, get an upholstery shop to cut it off and restitch a new tag end. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370541#370541 ________________________________________________________________________________
Date: Apr 11, 2012
Subject: Looking for an RV10
I am helping a friend in his search to purchase an RV10. I'm also helping another widow of a friend sell her late husbands -10. This plane has not been advertised and is seriously being considered by my friend. The obvious thing that would come to mind would be to steer him to the local -10. But since this is his 1st airplane purchase, and because he is my friend, I want him to look at as many options as possible before deciding. If you know of someone who is selling or interested in selling their plane, please email me or have them email me offline. I'm aware of all of the -10's that are advertised on the major sites. No brokers. Owners/builders only. I have a pretty good idea of what the condition of the aircraft market is now (soft), and my friend is not a deep pockets buyer. Thanks for your help Deems Davis www.deemsrv10.com ________________________________________________________________________________
Subject: Engine baffles
Date: Apr 12, 2012
Hi all, I'm working on assembling my engine baffles using Van's stock baffle kit on a stock IO-540. The space behind number 6 cylinder is so small I'm wondering how to get this left aft baffle section set into the area around the left upper engine mount while at the same time tucking it behind the number 6 cylinder. Anyone else have this problem? In search of an idea... Lee Otto RV-10 Builder Finishing this year or bust. lotto(at)ciembroidery.com ________________________________________________________________________________
Subject: Re: Engine baffles
Date: Apr 12, 2012
IIRC, you have to do a little bot of bending/distorting of the piece to get it in there and then it fits nicely. It's quite tight getting it in, but once it's in there isn't any strain on it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Apr 12, 2012, at 12:31 PM, Lee Otto wrote: > Hi all, > > I'm working on assembling my engine baffles using Van's stock baffle kit on a stock IO-540. The space behind number 6 cylinder is so small I'm wondering how to get this left aft baffle section set into the area around the left upper engine mount while at the same time tucking it behind the number 6 cylinder. Anyone else have this problem? In search of an idea... > > Lee Otto > RV-10 Builder > Finishing this year or bust. > > lotto(at)ciembroidery.com > > > > ________________________________________________________________________________
Date: Apr 12, 2012
It's awkward at best. A combination on twisting and pushing will get it on. While I can't remember the exact procedure, once you figure it out it beco mes more predictable and repeatable. I remember being simililar level of fr ustration Sent from my iPhone On Apr 12, 2012, at 12:31 PM, "Lee Otto" wrote: Hi all, I'm working on assembling my engine baffles using Van's stock baffle kit on a stock IO-540. The space behind number 6 cylinder is so small I'm wondering how to get this left aft baffle section set into the area around the left u pper engine mount while at the same time tucking it behind the number 6 cyli nder. Anyone else have this problem? In search of an idea... Lee Otto RV-10 Builder Finishing this year or bust. lotto(at)ciembroidery.com ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Apr 12, 2012
Subject: Fw: EFIS Product Update
For the Aerosonic/OP Technology EFIS owners that haven't seen this. =C2- From: Strickland, L Jearl <LJS2(at)pge.com> Subject: Fw: EFIS Product Update Date: Thursday, April 12, 2012, 3:33 PM ------------------------- =C2- From: Ken Martin [mailto:KMartin(at)aerosonic.com] Sent: Thursday, April 12, 2012 09:53 AM Subject: EFIS Product Update =C2- On behalf of Mark Perkins =93 Executive Vice President =C2- =C2- Dear Aviator =C2- =C2- In 2007 Aerosonic purchased the Op Tech display product line with the inten tion of completing any further development that may have been required to o btain FAA certification. Our business plan at that time reflected a market need for an affordable, highly capable alternative to existing display syst ems aimed at the general aviation market. In the years since that transacti on much has happened both in our industry and within our company. Shortly a fter the transaction we suffered a devastating fire that destroyed a large part of our facility and impacted our ability to produce nearly every produ ct that we supply to our many valued civil and military customers. After se veral years of hard work we have now recovered from that tragedy however mu ch has changed. =C2- The market for general aviation and business aircraft remains depressed and recovery still appears to be several years in the future. The Flight Displ ay competitive landscape has grown from a few manufactures to many with new advanced technologies, improved capabilities and enhanced features. =C2- For these reasons we have made a business decision to discontinue further d evelopment and certification efforts on the Op Tech Flight Display product. Our intention going forward is to focus on our core products.=C2- We are actively looking for a buyer for the Op Tech product line whose current bu siness model would be enhanced by the addition of this product. =C2- Support for current owners of these display systems is available through Av iation Instrument Technologies Inc (AITI).in Zephyrhills Fl. 39520 Aviation Ave., Zephyrhills, FL 33542.=C2-=C2- Phone: 813.783.3361 www.aircrafti nstruments.com . AITI has inventory, test equipment and associated document ation to service these systems and has been trained to provide immediate su pport.=C2- In the future please direct any units that require repair to A ITI. All products that are currently at our facility for repair or update w ill be completed by us and returned within the next 3 to 4 weeks. Should yo u have any questions please contact me at 727-461-3000 ext 133. =C2- =C2- Sincerely, =C2- =C2- Mark Perkins Executive Vice President=C2- =C2- =C2- =C2- =C2- Ken Martin Field Service Engineer Aerosonic Corporation (727) 461-3000, ext. 174 kmartin(at)aerosonic.com =C2- ________________________________________________________________________________
Date: Apr 12, 2012
Giving due consideration to the desirability of keeping the gutter, one has to consider the other weather striping options. The stock Vans stuff doesn't look all that hot. Other suggestions? On Tue, Apr 10, 2012 at 5:35 AM, jkreidler wrote: > By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design. > > Again, these are your decisions I am only trying to provide an alternate perspective to the decision. > > Thanks Jason > ________________________________________________________________________________
Subject: Manual Trim
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Apr 13, 2012
Has anyone considered or fitted manual trim in an RV10 to eliminate any runaway trim issues, give infinite fine trim capability & just reduce electric complexity. [Rolling Eyes] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370655#370655 ________________________________________________________________________________
Date: Apr 13, 2012
Kelly, we used seals made by Abby at Flightline Interiors. They are custom made to match the interior colors, in our case she made them from light grey material. They look great, match, and work.we also attached them to the door just a bit differently. We had Velcro sewn to the back of the seal, then attached Velcro to the door. This way we could adjust the seal as required, that has proven to work fine (370 hours). No pictures handy,sorry - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370658#370658 ________________________________________________________________________________
Subject: Re: Manual Trim
Date: Apr 13, 2012
Hey Greg, I just ran across the manual elevator trim option last week while I'm on this detour helping guys build RV-8's. I was amazed at how simple it was. I asked if anyone had tried it on the RV-10. He didn't know, but our guess is that the -8 uses only one tab and it's a small one vs. the -10's two tabs. I never have liked the idea of funky cams and twisted tail effect on the -10, but with the correct alignment it works OK. If you'd like, I can track down the hardware for the manual -8 ... perhaps there is an adaptor to split the cable for the two tabs, or you could be the inventor/experimenter. Later, - Lew -----Original Message----- From: Greg McFarlane Sent: Friday, April 13, 2012 6:36 AM Subject: RV10-List: Manual Trim Has anyone considered or fitted manual trim in an RV10 to eliminate any runaway trim issues, give infinite fine trim capability & just reduce electric complexity. [Rolling Eyes] ________________________________________________________________________________
Date: Apr 13, 2012
Thanks Lew, I was thinking more along the lines of keeping the "funky" cam and just replacing the servo with a "normal" Vans manual type cable set up. [Rolling Eyes] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370660#370660 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Intersection Fairings for RV10
Date: Apr 13, 2012
All, I need to finish the wheel pants - and the top and bottom intersection fairing from Van's are so bad that I either need to spend a lot of time reworking them or buy replacements. I note that Cleaveland tool sells these fairings: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RV10IF4 They look to be the same product as: http://rvbits.mybigcommerce.com/products/RV10-INTERSECTION-FAIRINGS.html I also heard the fairings Van's is now sending out are better. Recommendations? Carl First engine start tomorrow.. ________________________________________________________________________________
Date: Apr 13, 2012
I installed a pitch trim enable push button next to my panel mounted rocker. No relays, trim speed controllers and definitely no runaways. KISS. One would have severe cramping in your arm if you had to fly very far. Yes it is sensitive at cruise...just don't tap the rocker long. Once trimmed close at cruise my AP takes care of it and will let me know if I need to retrim. I love the setup, cost and will even more when it breaks. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370664#370664 ________________________________________________________________________________
Date: Apr 13, 2012
Here is a source if you are looking for one... http://www.periheliondesign.com/moreproducts.htm -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370665#370665 ________________________________________________________________________________
Date: Apr 13, 2012
I used the ones on this page. http://www.rvtraining.com/html/atp/html/accessories.html They work great for me.....a little pricy. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, April 12, 2012 11:03 PM Subject: Re: RV10-List: Re: Door Gutter and McMaster Seals Giving due consideration to the desirability of keeping the gutter, one has to consider the other weather striping options. The stock Vans stuff doesn't look all that hot. Other suggestions? On Tue, Apr 10, 2012 at 5:35 AM, jkreidler wrote: > --> > By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design. > > Again, these are your decisions I am only trying to provide an alternate perspective to the decision. > > Thanks Jason > ________________________________________________________________________________
Date: Apr 13, 2012
I just install my auto trim this annual. Works great, wish I had done it in the beginning. Thos trutrak guys are great. If you go manual trim, you lose that option. YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lewgall(at)charter.net Sent: Friday, April 13, 2012 5:59 AM Subject: Re: RV10-List: Manual Trim Hey Greg, I just ran across the manual elevator trim option last week while I'm on this detour helping guys build RV-8's. I was amazed at how simple it was. I asked if anyone had tried it on the RV-10. He didn't know, but our guess is that the -8 uses only one tab and it's a small one vs. the -10's two tabs. I never have liked the idea of funky cams and twisted tail effect on the -10, but with the correct alignment it works OK. If you'd like, I can track down the hardware for the manual -8 ... perhaps there is an adaptor to split the cable for the two tabs, or you could be the inventor/experimenter. Later, - Lew -----Original Message----- From: Greg McFarlane Sent: Friday, April 13, 2012 6:36 AM Subject: RV10-List: Manual Trim --> Has anyone considered or fitted manual trim in an RV10 to eliminate any runaway trim issues, give infinite fine trim capability & just reduce electric complexity. [Rolling Eyes] ________________________________________________________________________________
Date: Apr 13, 2012
Subject: Re: Intersection Fairings for RV10
Carl, I had a problem with one of mine.... can't remember what it was... ma ybe I lost it..... anyway, I ended up making up one from scratch fitting it right to the bottom of the plane.=C2- It's lighter and fits perfectly... should have done them both.=C2- Just used clay.=0ADon=0A =0A=0A_________ _______________________=0A From: Carl Froehlich <carl.froehlich(at)verizon.net >=0ATo: rv10-list(at)matronics.com =0ASent: Friday, April 13, 2012 7:41 AM=0AS ubject: RV10-List: Intersection Fairings for RV10=0A =0A=0AAll,=0A=C2- =0AI need to finish the wheel pants =93 and the top and bottom inters ection fairing from Van=99s are so bad that I either need to spend a lot of time reworking them or buy replacements.=0A=C2-=0AI note that Clea veland tool sells these fairings:=C2- http://www.cleavelandtoolstore.com/ prodinfo.asp?number=RV10IF4=0AThey look to be the same product as: http:/ /rvbits.mybigcommerce.com/products/RV10-INTERSECTION-FAIRINGS.html=0A=C2- =0AI also heard the fairings Van=99s is now sending out are better. =0A=C2-=0ARecommendations?=0A=0ACarl=0AFirst engine start tomorrow ================ ________________________________________________________________________________
Date: Apr 13, 2012
Cleveland does resell Jan's fairings. I just got a pair and there is no com parison with the set I got from Vans. My wife has been assisting with sandi ng filler. Once she saw the state of the Vans fairing, she immediately agree d it was a worthwhile investment. Sent from my iPhone On Apr 13, 2012, at 8:41 AM, "Carl Froehlich" w rote: All, I need to finish the wheel pants =93 and the top and bottom intersecti on fairing from Van=99s are so bad that I either need to spend a lot o f time reworking them or buy replacements. I note that Cleaveland tool sells these fairings: http://www.cleavelandtool store.com/prodinfo.asp?number=RV10IF4 They look to be the same product as: http://rvbits.mybigcommerce.com/product s/RV10-INTERSECTION-FAIRINGS.html I also heard the fairings Van=99s is now sending out are better. Recommendations? Carl First engine start tomorrow. ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Apr 13, 2012
If you are referring to pitch trim; my auto trim works in auto when the AP is in actively drving the aircraft. During manual control of the aircraft the trim switch works. I also fashioned a plug so that it reconnects the completely manual system if the auto pitch trim must be removed for maintenance; the aircraft is still operational. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Friday, April 13, 2012 6:02 AM Subject: RE: RV10-List: Manual Trim I just install my auto trim this annual. Works great, wish I had done it in the beginning. Thos trutrak guys are great. If you go manual trim, you lose that option. YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lewgall(at)charter.net Sent: Friday, April 13, 2012 5:59 AM Subject: Re: RV10-List: Manual Trim Hey Greg, I just ran across the manual elevator trim option last week while I'm on this detour helping guys build RV-8's. I was amazed at how simple it was. I asked if anyone had tried it on the RV-10. He didn't know, but our guess is that the -8 uses only one tab and it's a small one vs. the -10's two tabs. I never have liked the idea of funky cams and twisted tail effect on the -10, but with the correct alignment it works OK. If you'd like, I can track down the hardware for the manual -8 ... perhaps there is an adaptor to split the cable for the two tabs, or you could be the inventor/experimenter. Later, - Lew -----Original Message----- From: Greg McFarlane Sent: Friday, April 13, 2012 6:36 AM Subject: RV10-List: Manual Trim --> Has anyone considered or fitted manual trim in an RV10 to eliminate any runaway trim issues, give infinite fine trim capability & just reduce electric complexity. [Rolling Eyes] ________________________________________________________________________________
Date: Apr 13, 2012
Trim to fit; new fairings just like the old. I replaced one after a bird strike. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Friday, April 13, 2012 5:41 AM Subject: RV10-List: Intersection Fairings for RV10 All, I need to finish the wheel pants - and the top and bottom intersection fairing from Van's are so bad that I either need to spend a lot of time reworking them or buy replacements. I note that Cleaveland tool sells these fairings: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RV10IF4 They look to be the same product as: http://rvbits.mybigcommerce.com/products/RV10-INTERSECTION-FAIRINGS.html I also heard the fairings Van's is now sending out are better. Recommendations? Carl First engine start tomorrow.. ________________________________________________________________________________
Subject: ADSB In Coverage
Date: Apr 13, 2012
I am trying to determine if the ADSB In only receivers will get the weather info from a broadcast tower all the time. I have heard that the tower needs to be in contact with a ADSB Out aircraft before it will send the weather info. Thanks Barry ________________________________________________________________________________
Date: Apr 13, 2012
Just a note that TT send out the plug mentioned below with the AutoTrim now, so there's no need to make one yourself. One was supplied with my AutoTrim purchase. -Sean #40303 (Fitting Doors) On 4/13/12 8:37 AM, DLM wrote: > > If you are referring to pitch trim; my auto trim works in auto when > the AP is in actively drving the aircraft. During manual control of > the aircraft the trim switch works. I also fashioned a plug so that it > reconnects the completely manual system if the auto pitch trim must be > removed for maintenance; the aircraft is still operational. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker > Sent: Friday, April 13, 2012 6:02 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Manual Trim > > > I just install my auto trim this annual. Works great, wish I had done > it in > > the beginning. Thos trutrak guys are great. > > If you go manual trim, you lose that option. > > YMMV > > Rene' Felker > > N423CF > > 801-721-6080 > > -----Original Message----- > > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of > > lewgall(at)charter.net > > Sent: Friday, April 13, 2012 5:59 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Manual Trim > > > Hey Greg, > > I just ran across the manual elevator trim option last week while I'm on > > this detour helping guys build RV-8's. I was amazed at how simple it > was. > > I asked if anyone had tried it on the RV-10. He didn't know, but our > guess > > is that the -8 uses only one tab and it's a small one vs. the -10's two > > tabs. I never have liked the idea of funky cams and twisted tail > effect on > > the -10, but with the correct alignment it works OK. If you'd like, I can > > track down the hardware for the manual -8 ... perhaps there is an adaptor > > to split the cable for the two tabs, or you could be the > > inventor/experimenter. > > Later, - Lew > > -----Original Message----- > > From: Greg McFarlane > > Sent: Friday, April 13, 2012 6:36 AM > > To: rv10-list(at)matronics.com > > Subject: RV10-List: Manual Trim > > > --> > > Has anyone considered or fitted manual trim in an RV10 to eliminate any > > runaway trim issues, give infinite fine trim capability & just reduce > > electric complexity. [Rolling Eyes] > > * > > > * ________________________________________________________________________________
Date: Apr 13, 2012
Thanks Rene', That looks like the easiest solution, should eliminate a lot of rework of the gutter. On 4/13/2012 6:00 AM, Rene Felker wrote: > --> RV10-List message posted by: "Rene Felker" > > I used the ones on this page. > > http://www.rvtraining.com/html/atp/html/accessories.html > > They work great for me.....a little pricy. > > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Thursday, April 12, 2012 11:03 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Door Gutter and McMaster Seals > > --> RV10-List message posted by: Kelly McMullen > > Giving due consideration to the desirability of keeping the gutter, one has > to consider the other weather striping options. The stock Vans stuff doesn't > look all that hot. Other suggestions? > > On Tue, Apr 10, 2012 at 5:35 AM, jkreidler > wrote: >> --> RV10-List message posted by: "jkreidler" >> --> >> By removing the entire inside radius of the gutter in order to install the > McMaster Carr style seal you are significantly changing the section modulus > of the cabin top post and COULD be significantly increasing the likelihood > of a cabin top failure in a roll over type accident. Just something to > consider as you make what may seem to be a harmless improvement to the > design. >> Again, these are your decisions I am only trying to provide an alternate > perspective to the decision. >> Thanks Jason > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 13, 2012
I've always wondered if they are fiberglass or some other form of plastic. Do you know what they are made of? Sent from my iPhone On Apr 13, 2012, at 8:35 AM, Bob Leffler wrote: > Cleveland does resell Jan's fairings. I just got a pair and there is no c omparison with the set I got from Vans. My wife has been assisting with san ding filler. Once she saw the state of the Vans fairing, she immediately agr eed it was a worthwhile investment. > > Sent from my iPhone > > On Apr 13, 2012, at 8:41 AM, "Carl Froehlich" wrote: > > All, > > I need to finish the wheel pants =93 and the top and bottom intersec tion fairing from Van=99s are so bad that I either need to spend a lot of time reworking them or buy replacements. > > I note that Cleaveland tool sells these fairings: http://www.cleavelandto olstore.com/prodinfo.asp?number=RV10IF4 > They look to be the same product as: http://rvbits.mybigcommerce.com/produ cts/RV10-INTERSECTION-FAIRINGS.html > > I also heard the fairings Van=99s is now sending out are better. > > Recommendations? > > Carl > First engine start tomorrow. > > > ========================= ========= > ://www.matronics.com/Navigator?RV10-List > ========================= ========= > cs.com > ========================= ========= > matronics.com/contribution > ========================= ========= > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 13, 2012
Make your own. Collision wrap Black Christy's plumbing tape Modeling clay Release wax 7 once loose weave fiberglass 3 once satin weave fiberglass. West Systems slow set epoxy Aluminum sheet flashing Use the wheel faring=2C the leg faring and the underside of the fuselage as your mold in addition to the above items. The parts come out perfect=2C fit like a glove and are light and do not cra ck like the ones Van's sells because with the Van's ones you need to use so much filler to make the fit. Filler is weak=2C heavy and looks like crap. John G 409. Engine run up. Plane complete including paint=2C 98 percent don e! From: carl.froehlich(at)verizon.net Subject: RV10-List: Intersection Fairings for RV10 Date: Fri=2C 13 Apr 2012 08:41:14 -0400 All=2C I need to finish the wheel pants ' and the top and bottom intersec tion fairing from Van=92s are so bad that I either need to spend a lot of t ime reworking them or buy replacements. I note that Cleaveland tool sells t hese fairings: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RV 10IF4They look to be the same product as: http://rvbits.mybigcommerce.com/p roducts/RV10-INTERSECTION-FAIRINGS.html I also heard the fairings Van=92s i s now sending out are better. Recommendations? CarlFirst engine start tomorrow=85. ________________________________________________________________________________
Date: Apr 13, 2012
We're very happy with the foam seals that Alex sells. Straightforward installation, expecially compared to the rest of the door work.... :-)] http://www.aviationtechproducts.com John Ackerman 40458 On Apr 12, 2012, at 10:02 PM, Kelly McMullen wrote: > > Giving due consideration to the desirability of keeping the gutter, > one has to consider the other weather striping options. The stock Vans > stuff doesn't look all that hot. Other suggestions? > > On Tue, Apr 10, 2012 at 5:35 AM, jkreidler > wrote: > >> By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design. >> >> Again, these are your decisions I am only trying to provide an alternate perspective to the decision. >> >> Thanks Jason > > >> > > > > > ________________________________________________________________________________
Date: Apr 13, 2012
Love'em too. Simple and I've flown with them in past. They're quite tight and I couldn't find any leaks anywhere in the door. I made a point to look for them while we were in route. They're great. Sent from my iPhone On Apr 13, 2012, at 11:38 AM, John Ackerman wrote: > > We're very happy with the foam seals that Alex sells. Straightforward installation, expecially compared to the rest of the door work.... :-)] > > http://www.aviationtechproducts.com > > John Ackerman > 40458 > > > On Apr 12, 2012, at 10:02 PM, Kelly McMullen wrote: > >> >> Giving due consideration to the desirability of keeping the gutter, >> one has to consider the other weather striping options. The stock Vans >> stuff doesn't look all that hot. Other suggestions? >> >> On Tue, Apr 10, 2012 at 5:35 AM, jkreidler >> wrote: >> >>> By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design. >>> >>> Again, these are your decisions I am only trying to provide an alternate perspective to the decision. >>> >>> Thanks Jason >> >> >>> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Apr 13, 2012
SSBqdXN0IGNoZWNrZWQgbWluZSBhbmQgdGhleSBhcmUgZmliZXJnbGFzcy4KClNoYW5ub24KT24g QXByIDEzLCAyMDEyIDEwOjQ3IEFNLCAiUGhpbCBQZXJyeSIgPHBoaWxwZXJyeTlAZ21haWwuY29t PiB3cm90ZToKCj4gSSd2ZSBhbHdheXMgd29uZGVyZWQgaWYgdGhleSBhcmUgZmliZXJnbGFzcyBv ciBzb21lIG90aGVyIGZvcm0gb2YgcGxhc3RpYy4KPiAgIERvIHlvdSBrbm93IHdoYXQgdGhleSBh cmUgbWFkZSBvZj8KPgo+IFNlbnQgZnJvbSBteSBpUGhvbmUKPgo+IE9uIEFwciAxMywgMjAxMiwg YXQgODozNSBBTSwgQm9iIExlZmZsZXIgPHJ2QHRoZWxlZmZsZXJzLmNvbT4gd3JvdGU6Cj4KPiBD bGV2ZWxhbmQgZG9lcyByZXNlbGwgSmFuJ3MgZmFpcmluZ3MuICBJIGp1c3QgZ290IGEgcGFpciBh bmQgdGhlcmUgaXMgbm8KPiBjb21wYXJpc29uIHdpdGggdGhlIHNldCBJIGdvdCBmcm9tIFZhbnMu ICBNeSB3aWZlIGhhcyBiZWVuIGFzc2lzdGluZyB3aXRoCj4gc2FuZGluZyBmaWxsZXIuIE9uY2Ug c2hlIHNhdyB0aGUgc3RhdGUgb2YgdGhlIFZhbnMgZmFpcmluZywgc2hlIGltbWVkaWF0ZWx5Cj4g YWdyZWVkIGl0IHdhcyBhIHdvcnRod2hpbGUgaW52ZXN0bWVudC4KPgo+IFNlbnQgZnJvbSBteSBp UGhvbmUKPgo+IE9uIEFwciAxMywgMjAxMiwgYXQgODo0MSBBTSwgIkNhcmwgRnJvZWhsaWNoIiA8 Y2FybC5mcm9laGxpY2hAdmVyaXpvbi5uZXQ+Cj4gd3JvdGU6Cj4KPiBBbGwsKioqKgo+Cj4gKiog KioKPgo+IEkgbmVlZCB0byBmaW5pc2ggdGhlIHdoZWVsIHBhbnRzIJYgYW5kIHRoZSB0b3AgYW5k IGJvdHRvbSBpbnRlcnNlY3Rpb24KPiBmYWlyaW5nIGZyb20gVmFuknMgYXJlIHNvIGJhZCB0aGF0 IEkgZWl0aGVyIG5lZWQgdG8gc3BlbmQgYSBsb3Qgb2YgdGltZQo+IHJld29ya2luZyB0aGVtIG9y IGJ1eSByZXBsYWNlbWVudHMuKioqKgo+Cj4gKiogKioKPgo+IEkgbm90ZSB0aGF0IENsZWF2ZWxh bmQgdG9vbCBzZWxscyB0aGVzZSBmYWlyaW5nczoKPiBodHRwOi8vd3d3LmNsZWF2ZWxhbmR0b29s c3RvcmUuY29tL3Byb2RpbmZvLmFzcD9udW1iZXI9UlYxMElGNCoqKioKPgo+IFRoZXkgbG9vayB0 byBiZSB0aGUgc2FtZSBwcm9kdWN0IGFzOgo+IGh0dHA6Ly9ydmJpdHMubXliaWdjb21tZXJjZS5j b20vcHJvZHVjdHMvUlYxMC1JTlRFUlNFQ1RJT04tRkFJUklOR1MuaHRtbCoqCj4gKioKPgo+ICoq ICoqCj4KPiBJIGFsc28gaGVhcmQgdGhlIGZhaXJpbmdzIFZhbpJzIGlzIG5vdyBzZW5kaW5nIG91 dCBhcmUgYmV0dGVyLioqKioKPgo+ICoqICoqCj4KPiBSZWNvbW1lbmRhdGlvbnM/KioqKgo+Cj4K PiBDYXJsKioqKgo+Cj4gRmlyc3QgZW5naW5lIHN0YXJ0IHRvbW9ycm93hS4qKioqCj4KPiAqCj4K PiA9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+IDovL3d3dy5tYXRyb25pY3Mu Y29tL05hdmlnYXRvcj9SVjEwLUxpc3QKPiA9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PWNzLmNvbQo+ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09bWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24KPiA9PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQo+ ICoKPgo+ICoKPgo+ID09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09Cj4gOi8vd3d3 Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdAo+ID09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09Y3MuY29tCj4gPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT1tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgo+ID09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09Cj4gKgo+Cj4gKgo+Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KPiBfLT0gICAgICAgICAgLSBUaGUgUlYxMC1M aXN0IEVtYWlsIEZvcnVtIC0KPiBfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBO YXZpZ2F0b3IgdG8gYnJvd3NlCj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMg TGlzdCBVbi9TdWJzY3JpcHRpb24sCj4gXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDct RGF5IEJyb3dzZSwgQ2hhdCwgRkFRLAo+IF8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1v cmU6Cj4gXy09Cj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/ UlYxMC1MaXN0Cj4gXy09Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0KPiBfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBX RUIgRk9SVU1TIC0KPiBfLT0gU2FtZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0 aGUgV2ViIEZvcnVtcyEKPiBfLT0KPiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tCj4gXy09Cj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0KPiBfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBX ZWIgU2l0ZSAtCj4gXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCEKPiBf LT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4u Cj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24KPiBfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQo+ICoKPgo+Cg= ________________________________________________________________________________
Date: Apr 13, 2012
If you have a Trio autopilot with auto trim, not only does it trim when you use the autopilot; you can also use the trim function when hand-flying the aircraft. And, it is programable to run fast at low airspeeds, slow at high airspeeds. I use it all the time in cruise when hand-flying, for fine adjustments to the trim. Also, it is a workaround against a stuck trim "hat" switch. (pull trim CB, you can still trim thru the autopilot). Negative side, if the trim runs away, you need to pull both the trim and the autopilot CB's and then trouble-shoot where the problem is. For this reason I have those breakers side by side, directly in front of me. Of course it is still electrical; if the motors, wires to the motors, or battery fails, there's no trim. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370723#370723 ________________________________________________________________________________
Subject: Re: ADSB In Coverage
Date: Apr 13, 2012
My understanding is that Jesse is correct. Weather is just broadcast. The ground station only sends out traffic that is near aircraft that it knows are listening. And it know they're listening only if they're sending an ADS-B signal out. If it knows about no aircraft listening, no traffic is sent. If another aircraft is near you AND that aircraft is sending out the ADS-B out signal, then the ground station will send out traffic that it knows about around that airplane, and you may get that information even though you're just listening. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370726#370726 ________________________________________________________________________________
Date: Apr 13, 2012
I've found the easiest way to trim for any climb, descent or for level flight is to simply engage the TT AP. If I want to hand fly at that point (??), I just disconnect the TT and there we are. With that said, trimming "manually" with the trim button could hardly be easier. Bill On 4/13/2012 9:02 AM, Rene Felker wrote: > --> RV10-List message posted by: "Rene Felker" > > I just install my auto trim this annual. Works great, wish I had done it in > the beginning. Thos trutrak guys are great. > > If you go manual trim, you lose that option. > ________________________________________________________________________________
Date: Apr 13, 2012
Subject: Fitting Fairings to the Fuselage, how I do it......
From: Michael Kraus <n223rv(at)wolflakeairport.net>
I am resending this as there have been a lot of talk about fuselage intersection fairings..... Do not use filler to fit the fairings, use filler to fill the pin holes and minor imperfections.... I hope this helps...... ------ Forwarded Message From: Michael Kraus <n223rv(at)wolflakeairport.net> Date: Wed, 29 Feb 2012 22:12:11 -0400 "rv-list(at)matronics.com" Conversation: Fitting Fairing to the Fuselage, how I do it...... Subject: Fitting Fairing to the Fuselage, how I do it...... Here is a better description of how I fit my fairings..... Can be used for the gear leg to fuse, gear leg to wheel pant, or rear empennage intersection fairing. * Rough cut and dry fit up fairing to airplane. Drill #30 holes in locations where screws will eventually hold fairing to fuselage. When satisfied with the fit, draw a marker line on the fuselage around perimeter of fairing. Remove fairing. * Use mold release (I use the car wax stuff from Aircraft Spruce) and wipe it all over the fuselage about 2-4=B2 or more around both sides of the line you drew. DO NOT FORGET TO DO THIS STEP OR YOU WILL VERY UNHAPPY!! * Scuff up inside of fairing with 36-40 grit sandpaper on all surfaces wher e they will come into contact with the fuselage. * Clean fairings real good with acetone or similar to remove any dust/dirt/residue/mold release, etc * Work on one side of one fairing at a time (for instance, if you are working on the upper fuselage to gear leg intersection fairing, work on the fuselage to fairing interface first. Second time around work on the fairin g to gear leg interface). Lay up 2-3 layers of approximately 9 oz cloth on the fuselage over the line drawn in step 1. * Mix up flox and epoxy to a peanut butter consistency and apply about 1/16=B2-1/8=B2 onto the fairing surface that mates to the fuselage. This will help fill any gaps that may be present due to poorly formed fairings. * Mash the fairing onto the fuselage in position. Use cleco=B9s/clamps/screws/whatever you desire to hold it in place exactly where you want it until dry. * * Once dry, use compressed air to blow it free from the fuselage. Its amazing how well the compressed air works. Just get a little spot to break free, then blow air in the spot and the whole thing will pop off pretty easily. * Clean the fuselage up with a plastic scraper and acetone and clean real well. * Trim the fairing edge as desired to get a smooth edge. * * Repeat the process for the other side of the same fairing. For this example, that would be the upper gear leg to fairing surface (or the lower line as described above). DON=B9T FORGET THE MOLD RELEASE ON THE SURFACE YOU DON=B9T WANT IT BONDED TOO! * * Once complete, fill and sand, and fill, and sand, and fill, and sand unti l it is smooth to your satisfaction. For the rear empannage intersection fairing, I followed the same process, but layed up the HS to fairing surface first, then the VS to fairing surfac e second. I hope this is not too confusing. It is actually quite easy, just takes time.....especially in the Michigan winters when even fast drying epoxy takes 2 days to cure! -Mike Kraus RV-4 Flying and Sold RV-10 Flying ------ End of Forwarded Message ________________________________________________________________________________
Subject: Brake Spacers
Date: Apr 14, 2012
If anyone has replaced the U-1004B wheel nut extensions with something more substantial to alleviate the failure which will happen when using rough airstrips, then a good use for the original extensions is to drill completely through the length of them then cut them up to make the six U-1008 brake spacers. Much better material for the spacers than the soft ATS-058 tube called for in the plans. [pages 46-4 & 46-5 in plans] 8) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370771#370771 ________________________________________________________________________________
Subject: Re: Brake Spacers
Date: Apr 14, 2012
Best to go with one of the solid options like this: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RVAE10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370778#370778 ________________________________________________________________________________
Date: Apr 14, 2012
They are solid and agree with Charlie, better to go this route than try anything else. I was fortunate to get the Don McDonald spacers. He made a certain amount and are now carried by Plane Innovations http://www.planeinnovations.com/axlesbrackets.html, if you scroll down the webpage there are a couple of other items, again Don specials that I also have and they have been great for the seatbelts, passenger side never dropped out in the air when not in use. As a side note, I have the steel heater bypass http://www.planeinnovations.com/heaterbypass.html. From experience, they block all the heat and I dont have a tunnel heat issue, not sure they are related but I know from testing that the aluminum ones from the kit leak and these dont. There is a deflector that covers the door when closed which helps block the forced air. Pascal -----Original Message----- From: charliewaffles Sent: Saturday, April 14, 2012 8:36 AM Subject: RV10-List: Re: Brake Spacers Best to go with one of the solid options like this: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RVAE10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370778#370778 ________________________________________________________________________________
Date: Apr 14, 2012
Hey Guys, I think you may have missed Greg's point -- he has replaced the axel extension as you have, and is using the old extension for brake spacers. Later, - Lew -----Original Message----- From: Pascal Sent: Saturday, April 14, 2012 12:06 PM Subject: Re: RV10-List: Re: Brake Spacers They are solid and agree with Charlie, better to go this route than try anything else. I was fortunate to get the Don McDonald spacers. He made a certain amount and are now carried by Plane Innovations http://www.planeinnovations.com/axlesbrackets.html, if you scroll down the webpage there are a couple of other items, again Don specials that I also have and they have been great for the seatbelts, passenger side never dropped out in the air when not in use. As a side note, I have the steel heater bypass http://www.planeinnovations.com/heaterbypass.html. From experience, they block all the heat and I dont have a tunnel heat issue, not sure they are related but I know from testing that the aluminum ones from the kit leak and these dont. There is a deflector that covers the door when closed which helps block the forced air. Pascal -----Original Message----- From: charliewaffles Sent: Saturday, April 14, 2012 8:36 AM Subject: RV10-List: Re: Brake Spacers Best to go with one of the solid options like this: http://www.cleavelandtoolstore.com/prodinfo.asp?number=RVAE10 . ________________________________________________________________________________
Subject: RV-10 transition training
Date: Apr 14, 2012
All, Looks like the FSDO will be out the first week or so in May to sign off the RV-10 project. My insurance requires 2 hours of transition time in an RV-10 with a CFI. While I know the Van's guy in Dallas is available, I would prefer something closer to home (Fredericksburg, Virginia). Any RV-10 CFI guy/gals out there on this side of the Mississippi willing to help me out? Carl ________________________________________________________________________________
Subject: Re: RV-10 transition training
Date: Apr 14, 2012
My insurance gave me two options 1) Oregon 2) Texas both Vans signed off =9Cofficial RV-10 Cfi=99s=9D. I didn=99t care as I had my training in Texas, but make sure the 2 hours is with any Cfi and not the signed off ones. I asked when I called EAA for the quote-is was pretty clear it HAD to be with the signed off cfi=99s and not my neighbor who was a Cfi that owned a RV-10. Sounds like you have this covered however. From: Carl Froehlich Sent: Saturday, April 14, 2012 3:31 PM Subject: RV10-List: RV-10 transition training All, Looks like the FSDO will be out the first week or so in May to sign off the RV-10 project. My insurance requires 2 hours of transition time in an RV-10 with a CFI. While I know the Van=99s guy in Dallas is available, I would prefer something closer to home (Fredericksburg, Virginia). Any RV-10 CFI guy/gals out there on this side of the Mississippi willing to help me out? Carl ________________________________________________________________________________
Subject: Re: [Mid-AtlRVwing] RV-10 transition training
Date: Apr 14, 2012
Carl, You may try Chip Locke at St Mary's may be able to help, not sure he is a CFI but he probably knows one. Ralph Sent from my iPad On Apr 14, 2012, at 6:31 PM, "Carl Froehlich" w rote: > All, > > > > Looks like the FSDO will be out the first week or so in May to sign off th e RV-10 project. My insurance requires 2 hours of transition time in an RV- 10 with a CFI. While I know the Van=99s guy in Dallas is available, I would prefer something closer to home (Fredericksburg, Virginia). > > > > Any RV-10 CFI guy/gals out there on this side of the Mississippi willing t o help me out? > > > Carl > > __._,_.___ > Reply to sender | Reply to group | Reply via web post | Start a New Topic > Messages in this topic (1) > RECENT ACTIVITY: > Visit Your Group > Switch to: Text-Only, Daily Digest =A2 Unsubscribe =A2 Terms o f Use > . > > __,_._,___ ________________________________________________________________________________
Date: Apr 14, 2012
Carl, I did my transition training with Dave Maib in New Smyrna Beach, FL. It was a great experience and I certainly would highly recommend Dave=99s training services. Bob Newman N541RV 60 hrs. From: Carl Froehlich Sent: Saturday, April 14, 2012 6:31 PM Subject: RV10-List: RV-10 transition training All, Looks like the FSDO will be out the first week or so in May to sign off the RV-10 project. My insurance requires 2 hours of transition time in an RV-10 with a CFI. While I know the Van=99s guy in Dallas is available, I would prefer something closer to home (Fredericksburg, Virginia). Any RV-10 CFI guy/gals out there on this side of the Mississippi willing to help me out? Carl ________________________________________________________________________________
From: "carl.froehlich(at)verizon.net" <carl.froehlich(at)verizon.net>
Date: Apr 14, 2012
WWVwLCBTdC4gTWFyeSdzIHdhcyBwbGFuIEEsIGJ1dCByaWdodCBub3cgdGhhdCBpcyBub3QgYXZh aWxhYmxlIGFuZCBubyBsaW5lIG9mIHNpZ2h0IG9uIHdoZW4gaXQgd2lsbC4KCkNhcmwKClNlbnQg ZnJvbSBteSBwaG9uZS7CoCBQbGVhc2UgcmVhZCBwYXNzIHRoZSB0eXBvcy4KCi0tLS0tT3JpZ2lu YWwgbWVzc2FnZS0tLS0tCkZyb206IFJhbHBoIDxob292ZXJyYUBjb21jYXN0Lm5ldD4KVG86ICJN aWQtQXRsUlZ3aW5nQHlhaG9vZ3JvdXBzLmNvbSIgPE1pZC1BdGxSVndpbmdAeWFob29ncm91cHMu Y29tPgpDYzogIjxydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4iIDxydjEwLWxpc3RAbWF0cm9uaWNz LmNvbT4sICI8TWlkLUF0bFJWd2luZ0B5YWhvb2dyb3Vwcy5jb20+IiA8TWlkLUF0bFJWd2luZ0B5 YWhvb2dyb3Vwcy5jb20+ClNlbnQ6IFNhdCwgQXByIDE0LCAyMDEyIDIzOjExOjQ1IEdNVCswMDow MApTdWJqZWN0OiBSZTogW01pZC1BdGxSVndpbmddIFJWLTEwIHRyYW5zaXRpb24gdHJhaW5pbmcK CkNhcmwsCllvdSBtYXkgdHJ5IENoaXAgTG9ja2UgYXQgU3QgTWFyeSdzIG1heSBiZSBhYmxlIHRv IGhlbHAsIG5vdCBzdXJlIGhlIGlzIGEgQ0ZJIGJ1dCBoZSBwcm9iYWJseSBrbm93cyBvbmUuIAoK UmFscGgKClNlbnQgZnJvbSBteSBpUGFkCgpPbiBBcHIgMTQsIDIwMTIsIGF0IDY6MzEgUE0sICJD YXJsIEZyb2VobGljaCIgPGNhcmwuZnJvZWhsaWNoQHZlcml6b24ubmV0PiB3cm90ZToKCj4gQWxs LAo+IAo+ICAKPiAKPiBMb29rcyBsaWtlIHRoZSBGU0RPIHdpbGwgYmUgb3V0IHRoZSBmaXJzdCB3 ZWVrIG9yIHNvIGluIE1heSB0byBzaWduIG9mZiB0aGUgUlYtMTAgcHJvamVjdC4gIE15IGluc3Vy YW5jZSByZXF1aXJlcyAyIGhvdXJzIG9mIHRyYW5zaXRpb24gdGltZSBpbiBhbiBSVi0xMCB3aXRo IGEgQ0ZJLiAgV2hpbGUgSSBrbm93IHRoZSBWYW7igJlzIGd1eSBpbiBEYWxsYXMgaXMgYXZhaWxh YmxlLCBJIHdvdWxkIHByZWZlciBzb21ldGhpbmcgY2xvc2VyIHRvIGhvbWUgKEZyZWRlcmlja3Ni dXJnLCBWaXJnaW5pYSkuCj4gCj4gIAo+IAo+IEFueSBSVi0xMCBDRkkgZ3V5L2dhbHMgb3V0IHRo ZXJlIG9uIHRoaXMgc2lkZSBvZiB0aGUgTWlzc2lzc2lwcGkgd2lsbGluZyB0byBoZWxwIG1lIG91 dD8KPiAKPiAKPiBDYXJsCj4gCj4gCgo ________________________________________________________________________________
Date: Apr 14, 2012
Carl I spent a couple of days with David in early March. It was a great experienc e. Cheers Les Sent from my iPhone On 2012-04-14, at 5:26 PM, bob-tcw wrote: > Carl, I did my transition training with Dave Maib in New Smyrna Beach, FL. It was a great experience and I certainly would highly recommend Dav e=99s training services. > > Bob Newman > N541RV > 60 hrs. > > > From: Carl Froehlich > Sent: Saturday, April 14, 2012 6:31 PM > To: rv10-list(at)matronics.com ; Mid-AtlRVwing(at)yahoogroups.com > Subject: RV10-List: RV-10 transition training > > All, > > Looks like the FSDO will be out the first week or so in May to sign off th e RV-10 project. My insurance requires 2 hours of transition time in an RV- 10 with a CFI. While I know the Van=99s guy in Dallas is available, I would prefer something closer to home (Fredericksburg, Virginia). > > Any RV-10 CFI guy/gals out there on this side of the Mississippi willing t o help me out? > > Carl > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 15, 2012
Carl, send me an email or PM. I should be able to help with your Transition Training. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370830#370830 ________________________________________________________________________________
Date: Apr 15, 2012
Carl, I seen to recall Mitch Lock, Van's East Coast rep in Maryland, was providing transition training. It might be worth and e-mail or call to find out for sure: mitchl(at)vansaircraft.com, 240.427.8847 Let me know the results because I'll be needing transition training soon myself and would prefer something local as well being just up I-95 from you. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370840#370840 ________________________________________________________________________________
Date: Apr 15, 2012
Todd, That was Plan A - using the Van's RV-10 at St. Mary's in Maryland (about 10min by air from my place - VA42). Chip Lock told me this was no longer available. Swing by Dogwood and you can look over the project if you like. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tsts4 Sent: Sunday, April 15, 2012 9:18 AM Subject: RV10-List: Re: RV-10 transition training Carl, I seen to recall Mitch Lock, Van's East Coast rep in Maryland, was providing transition training. It might be worth and e-mail or call to find out for sure: mitchl(at)vansaircraft.com, 240.427.8847 Let me know the results because I'll be needing transition training soon myself and would prefer something local as well being just up I-95 from you. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370840#370840 ________________________________________________________________________________
Date: Apr 15, 2012
There are several very qualified cfi's providing transition training. I actually decided to change cfi when somebody reconfigured their panel to something very similar to mine. For me, I decided the transition training would be more beneficial using the same efis and autopilot I have in my panel. Just something you may want to consider besides geographic location. Bob Sent from my iPhone On Apr 15, 2012, at 9:18 AM, "tsts4" wrote: Carl, I seen to recall Mitch Lock, Van's East Coast rep in Maryland, was providing transition training. It might be worth and e-mail or call to find out for sure: mitchl(at)vansaircraft.com, 240.427.8847 Let me know the results because I'll be needing transition training soon myself and would prefer something local as well being just up I-95 from you. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370840#370840 ________________________________________________________________________________
Date: Apr 15, 2012
Bob, Good point on the equipment. I'd like to transition with at least the same EFIS. But first thing first, does anyone have a list of all the CFIs providing RV-10 transition training? If we collectively can come up with one perhaps we can their avionics so pilots can have that info to help inform their choice. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370858#370858 ________________________________________________________________________________
Subject: intersection farings, bad fit, bad filler, home made is better
Date: Apr 15, 2012
I used the term filler to describe a mixture of epoxy=2C chopped glass=2C c otton flox=2C micro ballons- mixed in varing concentrations to make the sol ution fill in gaps between where the faring is warped due to poor molding o r removal from mold prior to full cure. You vary the cancentrations of each component to make it strong and as light as possible. However=2C because t he farings are built so poorly=2C they still come out leaving you with a de sire for something more. The included photos and the prior email I wrote decribe the materials used to make your own. The thin aluminum flashing is used as a parting line off the back of all intersection farings. you insert it between the gear leg fa ring trailing edge. The top faring is made from scratch. The bottom was Van's stock. The bottom required so much work and they got so thick and heavy that I did them from scratch on the top. The top ones in these photos are only being held in place by their fit=2C n o screws=2C tape or adheasive. They are light=2C thin=2C and strong and fit perfectly because they were made on the plane. The photos may be uploaded out of order. John 409 intersection farings=2C bad fit=2C bad filler=2C home made is better View photos Download all You are invited to view John's album. This album has 10 files. ________________________________________________________________________________
Date: Apr 15, 2012
Bob, Do you have a list of these CFI? Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Sunday, April 15, 2012 10:36 AM Subject: Re: RV10-List: Re: RV-10 transition training There are several very qualified cfi's providing transition training. I actually decided to change cfi when somebody reconfigured their panel to something very similar to mine. For me, I decided the transition training would be more beneficial using the same efis and autopilot I have in my panel. Just something you may want to consider besides geographic location. Bob Sent from my iPhone On Apr 15, 2012, at 9:18 AM, "tsts4" wrote: Carl, I seen to recall Mitch Lock, Van's East Coast rep in Maryland, was providing transition training. It might be worth and e-mail or call to find out for sure: mitchl(at)vansaircraft.com, 240.427.8847 Let me know the results because I'll be needing transition training soon myself and would prefer something local as well being just up I-95 from you. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370840#370840 ________________________________________________________________________________
Date: Apr 15, 2012
I don't have list that is compiled. I think most of them are pretty well know. I am going with Alex D. Since he is the. My one that I am aware of that has an AFS panel. David Maib and Pierre Smith are the only other east coast ones that I'm aware. Also, be forewarned I know that several are considering stopping due insurance rates increasing this year for loda trainers. Sent from my iPad On Apr 15, 2012, at 1:46 PM, "Carl Froehlich" wrote: > > Bob, > > Do you have a list of these CFI? > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler > Sent: Sunday, April 15, 2012 10:36 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV-10 transition training > > > There are several very qualified cfi's providing transition training. I > actually decided to change cfi when somebody reconfigured their panel to > something very similar to mine. For me, I decided the transition training > would be more beneficial using the same efis and autopilot I have in my > panel. Just something you may want to consider besides geographic location. > > > > Bob > Sent from my iPhone > > On Apr 15, 2012, at 9:18 AM, "tsts4" wrote: > > > Carl, > I seen to recall Mitch Lock, Van's East Coast rep in Maryland, was providing > transition training. It might be worth and e-mail or call to find out for > sure: mitchl(at)vansaircraft.com, 240.427.8847 > > Let me know the results because I'll be needing transition training soon > myself and would prefer something local as well being just up I-95 from you. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > www.mykitlog.com/auburntsts > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370840#370840 > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 15, 2012
Sort of a follow up on Bob's post: I'm a cfii, and I went to the trouble of getting a letter of deviation authority (LODA) from the local FSDO allowing me to give transition training in my RV-10. Jenny at NationAir thought that I'd be acceptable to insurance companies. However, I've been quoted an extra $2K, above and beyond what I pay now, for the insurance. I'm just not sure the market in the Bay area (I'm at KLVK, 30 miles east of SFO) can support that, financially, so I've held off on any advertising. I was able to add my next-door hangar pilot to my existing policy for a not-outrageous rate, so I will give him the instruction. I'd be curious to know how many pilots, in a typical year, seek out or need RV-10 type-specific training. As you are probably aware, CFI's are limited to that in their own airplanes. No flight reviews, no IPCs, etc. As to this thread: I wouldn't put too much weight on having the same EFIS. The thrust of this training is really basic VFR piloting. I'd say what's more important, can you land the plane if the EFIS totally quits? Which it may do on a first flight. In a few hours of dual you really want to concentrate on making flying the plane second nature, so that, when you do have your first flight, you can be familiar enough with the flying that you can also look at engine instruments, scan for traffic, etc. Once you're out of phase 1 then hire an instructor, if need be, to instruct you in your plane, using your EFIS, autopilot, GPS navigator, etc. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370893#370893 ________________________________________________________________________________
Date: Apr 15, 2012
I trained 5 pilots at no charge except fuel; I was able to temporarily add them to my insurance as named while training at no additional expense. If you decide to try the LODA route your bucket can not be full (as a retiree, mine was); the ability to provide specific endorsements, for example, high performance or complex airplane (a normal result of transition training), may not be acceptable in the LODA. I concur with the EFIS comment; transition training is basic "fly the airplane" stuff, not button pushing. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Sunday, April 15, 2012 2:34 PM Subject: RV10-List: Re: RV-10 transition training Sort of a follow up on Bob's post: I'm a cfii, and I went to the trouble of getting a letter of deviation authority (LODA) from the local FSDO allowing me to give transition training in my RV-10. Jenny at NationAir thought that I'd be acceptable to insurance companies. However, I've been quoted an extra $2K, above and beyond what I pay now, for the insurance. I'm just not sure the market in the Bay area (I'm at KLVK, 30 miles east of SFO) can support that, financially, so I've held off on any advertising. I was able to add my next-door hangar pilot to my existing policy for a not-outrageous rate, so I will give him the instruction. I'd be curious to know how many pilots, in a typical year, seek out or need RV-10 type-specific training. As you are probably aware, CFI's are limited to that in their own airplanes. No flight reviews, no IPCs, etc. As to this thread: I wouldn't put too much weight on having the same EFIS. The thrust of this training is really basic VFR piloting. I'd say what's more important, can you land the plane if the EFIS totally quits? Which it may do on a first flight. In a few hours of dual you really want to concentrate on making flying the plane second nature, so that, when you do have your first flight, you can be familiar enough with the flying that you can also look at engine instruments, scan for traffic, etc. Once you're out of phase 1 then hire an instructor, if need be, to instruct you in your plane, using your EFIS, autopilot, GPS navigator, etc. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370893#370893 ________________________________________________________________________________
Date: Apr 15, 2012
"I was able to temporarily add them to my insurance as named while training at no additional expense" Wow! That's what I've done too but it was not at no extra cost. Can you say who you use as agent and what insurance company? You're right about training in an experimental aircraft which the cfi provides, for compensation or hire: The FAA will not allow anything other than "transition training". Even though you accomplish all the things that would normally be done in a Flight Review, or for a High Performance endorsement, my LODA explicitly forbids me from signing off on these things. (PS As I'm sure you know, a complex endorsement requires a retractable, so it's not applicable to a -10 anyway). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370905#370905 ________________________________________________________________________________
Date: Apr 15, 2012
I did my training with David Maib and highly recommend him. I spent 5.8 hours learning to fly the plane. Well worth the money. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370909#370909 ________________________________________________________________________________
Subject: RV10-List User Name
Date: Apr 16, 2012
Hi Matt, Sorry to bother you, but I'm wanting to resurrect an RV-10 archive topic and I can't find my Username to log on. My previous messages appear under the name Gordon Anderson from e-mail address "mregoan(at)hispeed.ch" but I can't find myself on the member list under any of the obvious names (Anderson, Gordon, mregoan). Is there any way you can help me find out the username? Thanks a lot! Gordon ________________________________________________________________________________
Subject: Wing wiring / bushing size
Date: Apr 16, 2012
I am working on the left wing and am to the point where I need to drill the holes for the snap bushings for pulling wires. I want to do this BEFORE I put the ribs on the spar to rivet. The question is, what size bushings do I need? I have HID landing light wires all the way to the end, I will have heated pitot tube wires to where the pitot tube mounts (I know that Tim mounted his a bit further out, I will have wires running to the Trutrak servos....... How big a bushing did you need to start? Did you mount the HID landing light wires through the same bushing? what about the ones for the pitot tube heat? Curious what solutions were used. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370961#370961 ________________________________________________________________________________
Date: Apr 16, 2012
I used conduit and no bushings. Sorry I do not remember the whole size. I think it is in the Archives. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Biggs Sent: Monday, April 16, 2012 11:01 AM Subject: RV10-List: Wing wiring / bushing size I am working on the left wing and am to the point where I need to drill the holes for the snap bushings for pulling wires. I want to do this BEFORE I put the ribs on the spar to rivet. The question is, what size bushings do I need? I have HID landing light wires all the way to the end, I will have heated pitot tube wires to where the pitot tube mounts (I know that Tim mounted his a bit further out, I will have wires running to the Trutrak servos....... How big a bushing did you need to start? Did you mount the HID landing light wires through the same bushing? what about the ones for the pitot tube heat? Curious what solutions were used. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370961#370961 ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Subject: Re: Wing wiring / bushing size
Date: Apr 16, 2012
Plastic water pipe (not PVC) from the aviation department at Lowes. Light and tough. 3/4" hole. The pipe is big enough for all the runs you listed, and a coax line for a wing tip NAV antenna. Carl On Apr 16, 2012, at 1:23 PM, "Rene Felker" wrote: > > I used conduit and no bushings. Sorry I do not remember the whole size. I > think it is in the Archives. > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tom Biggs > Sent: Monday, April 16, 2012 11:01 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Wing wiring / bushing size > > > I am working on the left wing and am to the point where I need to drill the > holes for the snap bushings for pulling wires. I want to do this BEFORE I > put the ribs on the spar to rivet. The question is, what size bushings do I > need? I have HID landing light wires all the way to the end, I will have > heated pitot tube wires to where the pitot tube mounts (I know that Tim > mounted his a bit further out, I will have wires running to the Trutrak > servos....... > How big a bushing did you need to start? > Did you mount the HID landing light wires through the same bushing? > what about the ones for the pitot tube heat? > > Curious what solutions were used. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370961#370961 > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: VDO 360-003 fuel pressure sensor transducer
Date: Apr 16, 2012
I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem? ________________________________________________________________________________
Subject: Re: VDO 360-003 fuel pressure sensor transducer
Date: Apr 17, 2012
Yep, I am on my 3rd. one. I have just over 215 TT. Sure wish they were more robust!! Thane States RV-10 ----- Original Message ----- From: DLM To: rv10-list(at)matronics.com Sent: Monday, April 16, 2012 8:58 PM Subject: RV10-List: VDO 360-003 fuel pressure sensor transducer I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem? No virus found in this message. Checked by AVG - www.avg.com 04/16/12 ________________________________________________________________________________
Date: Apr 17, 2012
I am a yes also, lost my first one at about 70 hours..the second is still going strong at 150 hours. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Tuesday, April 17, 2012 5:31 AM Subject: Re: RV10-List: VDO 360-003 fuel pressure sensor transducer Yep, I am on my 3rd. one. I have just over 215 TT. Sure wish they were more robust!! Thane States RV-10 ----- Original Message ----- From: DLM <mailto:dlm34077(at)q.com> Sent: Monday, April 16, 2012 8:58 PM Subject: RV10-List: VDO 360-003 fuel pressure sensor transducer I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem? href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 17, 2012
Go to the VAF forums, this thread http://www.vansairforce.com/community/showthread.php?t=75694&highlight=wing+wiring for a complete discussion...... -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371027#371027 ________________________________________________________________________________
Date: Apr 17, 2012
I used SB625-7 in ribs 1-11. I used SB500-6 in ribs 12-15. Once I dropped roll servo wiring in right wing and pitot heat/stall warning wiring in left wing, size can be reduced. I have DW hid's and Whelen strobes. I can barely hear hid's start up at idle and no noise after 15 seconds. No noise heard from strobes unless engine is off. No noise from anything else. Yes, I used airframe ground for everything. All my wires bundled tight with wire ties and no condiut. I did not want wires vibrating inside of flammable plastic tubing or not having cooling air across wire bundle. Wires are insulated with Tefzel for a reason. I installed one spare 18 ga wire per wing. We have removable wing root fairings, tips and insp panels in case I need to run a new wire. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371030#371030 ________________________________________________________________________________
Date: Apr 17, 2012
Sounds like GRT ought to sell the industrial one only with new EIS shipments. Cheap purchase just means that you get to change them frequently. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Tuesday, April 17, 2012 4:31 AM Subject: Re: RV10-List: VDO 360-003 fuel pressure sensor transducer Yep, I am on my 3rd. one. I have just over 215 TT. Sure wish they were more robust!! Thane States RV-10 ----- Original Message ----- From: DLM <mailto:dlm34077(at)q.com> Sent: Monday, April 16, 2012 8:58 PM Subject: RV10-List: VDO 360-003 fuel pressure sensor transducer I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem? href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 17, 2012
They use them in race cars, too... http://www.summitracing.com/search/Part-Type/Gauge-Sending-Units/?keyword=VDO Don't tell them it's for an airplane, however. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371049#371049 ________________________________________________________________________________
Date: Apr 17, 2012
Subject: Measurements Needed - Throttle/Prop/Mixture (Vernier)
Hi Everyone, I'm having some custom length vernier cables manufactured by McFarlane and need some basic measurements from Vans stock cables before I can proceed. Does anyone have a set of cables that are not installed and who can make some measurements for me? I had no idea it was this complex of a process. Attached to this message is the McFarlane spec sheet for their cables. Once I get the basic measurements from a stock set of cables, I can figure out the rest. I'll be happy to share all the dimensions for the future builders so they don't have to go through the process. Thanks in advance for your help! Phil ________________________________________________________________________________
Subject: Re: Measurements Needed - Throttle/Prop/Mixture (Vernier)
Date: Apr 17, 2012
I know the length I need. It is the other intermediate measurements on the document that are needed. Sent from my iPhone On Apr 17, 2012, at 11:40 AM, Deems Davis wrote: > Phil use some weedwacker line and route it like you plan to route your cables, then mark AME measure it. > > Sent from my Droid Charge on Verizon 4GLTE > > ------Original Message------ > From: Phillip Perry <philperry9(at)gmail.com> > To: > Date: Tuesday, April 17, 2012 10:14:20 AM GMT-0500 > Subject: RV10-List: Measurements Needed - Throttle/Prop/Mixture (Vernier) > > Hi Everyone, > > I'm having some custom length vernier cables manufactured by McFarlane and > need some basic measurements from Vans stock cables before I can proceed. > > Does anyone have a set of cables that are not installed and who can make > some measurements for me? I had no idea it was this complex of a process. > > Attached to this message is the McFarlane spec sheet for their cables. > > Once I get the basic measurements from a stock set of cables, I can figure > out the rest. I'll be happy to share all the dimensions for the future > builders so they don't have to go through the process. > > Thanks in advance for your help! > Phil > ________________________________________________________________________________
Date: Apr 17, 2012
One caution: I bought the stock cables with the Firewall Forward kit, and they were not long enough to route as shown in the plans. I made them fit, but it is a little tighter than I would have liked. And I think I'm not the only one who has had this problem. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371091#371091 ________________________________________________________________________________
Date: Apr 17, 2012
That's exactly the reason I'm getting custom length cables made. On Tue, Apr 17, 2012 at 2:37 PM, Bob Turner wrote: > > One caution: I bought the stock cables with the Firewall Forward kit, and > they were not long enough to route as shown in the plans. I made them fit, > but it is a little tighter than I would have liked. And I think I'm not the > only one who has had this problem. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371091#371091 > > ________________________________________________________________________________
Date: Apr 17, 2012
I talked with Sandy and Gregg at GRT yesterday; there is a way to determine whether it is the sensor good or bad with the top cowl off. Mine, however, is intermittent, I am going to try and clean the terminals to determine whether my problems currently could be connections. The choices are two: (1) keep replacing the cheap sensor (I carry an extra with me) or (2) install the robust one which requires slight changes to the wiring. I will make a decision on it in a month or so; IIRC the three wires from it go to power, ground and the sensor. Since the current sensor already has a 4.8V power interconnection with the sensor line it must be removed which for me means removing some panel units to find and cut the offending wire. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Tuesday, April 17, 2012 4:31 AM Subject: Re: RV10-List: VDO 360-003 fuel pressure sensor transducer Yep, I am on my 3rd. one. I have just over 215 TT. Sure wish they were more robust!! Thane States RV-10 ----- Original Message ----- From: DLM <mailto:dlm34077(at)q.com> Sent: Monday, April 16, 2012 8:58 PM Subject: RV10-List: VDO 360-003 fuel pressure sensor transducer I am on my second; the first lasted about 500 hours; the second has lasted about 50 hours. They begin to fail by showing fuel pressures that are abnormally high intermittently. Anyone else has a similar problem? href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Apr 18, 2012
Hi Phil, I will measure mine for you tonight. I think that I am going to have the same problem as I have the Aerosport Products Carbon Fibre Panel and the Cables sit a little lower and a little further rearwards than the stock support bracket. Cheers John MacCallum #41016 VH-DUU From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Wednesday, 18 April 2012 1:14 AM Subject: RV10-List: Measurements Needed - Throttle/Prop/Mixture (Vernier) Hi Everyone, I'm having some custom length vernier cables manufactured by McFarlane and need some basic measurements from Vans stock cables before I can proceed. Does anyone have a set of cables that are not installed and who can make some measurements for me? I had no idea it was this complex of a process. Attached to this message is the McFarlane spec sheet for their cables. Once I get the basic measurements from a stock set of cables, I can figure out the rest. I'll be happy to share all the dimensions for the future builders so they don't have to go through the process. Thanks in advance for your help! Phil ________________________________________________________________________________
Date: Apr 18, 2012
John, check out the third to last post in this thread from Ivan. Phil, there may be some info in there for you also. http://forums.matronics.com/viewtopic.php?p=321568 -Sean #40303 (fitting doors) On 4/18/12 2:23 AM, John MacCallum wrote: > > Hi Phil, > > I will measure mine for you tonight. I think that I am going to have > the same problem as I have the Aerosport Products Carbon Fibre Panel > > and the Cables sit a little lower and a little further rearwards than > the stock support bracket. > > Cheers > > John MacCallum > > #41016 > > VH-DUU > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry > *Sent:* Wednesday, 18 April 2012 1:14 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Measurements Needed - Throttle/Prop/Mixture > (Vernier) > > Hi Everyone, > > I'm having some custom length vernier cables manufactured by McFarlane > and need some basic measurements from Vans stock cables before I can > proceed. > > Does anyone have a set of cables that are not installed and who can > make some measurements for me? I had no idea it was this complex of a > process. > > Attached to this message is the McFarlane spec sheet for their cables. > > Once I get the basic measurements from a stock set of cables, I can > figure out the rest. I'll be happy to share all the dimensions for > the future builders so they don't have to go through the process. > > Thanks in advance for your help! > Phil > > * > > > * ________________________________________________________________________________
Date: Apr 18, 2012
Thanks John... Sean, I've seen that post and I'm using those lengths for my final lengths, but there are a few more measurements that McFarlane is looking for and I can't get them without having my hands on a set of controls to measure. Phil On Wed, Apr 18, 2012 at 7:45 AM, Sean Stephens wrote: > > John, check out the third to last post in this thread from Ivan. Phil, > there may be some info in there for you also. > > http://forums.matronics.com/**viewtopic.php?p=321568> > > -Sean #40303 (fitting doors) > > ________________________________________________________________________________
Subject: Oshkosh motorhome
Date: Apr 18, 2012
I wanted to post here first. I just cancelled this motorhome because I received a trailer rental that will be delivered to my campsite. This is there last one. Just thought I would post here if anyone is interested.
http://www.wisconsinrvworld.com/custompage2.asp?pg=31krental -Scott Sent from my iPad ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: iPad in the cockipt
Date: Apr 18, 2012
iPad users: I'm more inclined to have the iPad in the RV-10 cockpit up in front by the dash somewhere, rather than as a kneeboard. What experience have others had? Is a RAM mount clamped on the edge of the glareshield rigid enough? Other mounting ideas? Tim N52KS ________________________________________________________________________________
Subject: Re: iPad in the cockipt
Date: Apr 18, 2012
Tim, I have mine mounted on the tunnel just in front of the fuel valve. Alan Sent from my iPhone On Apr 18, 2012, at 1:51 PM, "Dawson-Townsend,Timothy" wrote: > iPad users: > > I'm more inclined to have the iPad in the RV-10 cockpit up in front by the dash somewhere, rather than as a kneeboard. > > What experience have others had? Is a RAM mount clamped on the edge of th e glareshield rigid enough? Other mounting ideas? > > Tim > N52KS > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Video: Pipistrel Panthera Revealed
Date: Apr 18, 2012
http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_Aero2012_PipistrelPanthera_206547-1.html Wow, this will be interesting. Looks like another 4-seat plane similar to the -10 and Cirrus. Jae -------- #40533 RV-10 First flight 10/19/2011 Phase 1 Done 11/26/2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371174#371174 ________________________________________________________________________________
Date: Apr 18, 2012
Any though given to mounting it to the center post along the windscreen? It could double as a sun visor. Jeff Carpenter 40304 On Apr 18, 2012, at 11:12 AM, Alan Mekler MD wrote: > Tim, > I have mine mounted on the tunnel just in front of the fuel valve. > Alan > > Sent from my iPhone > > On Apr 18, 2012, at 1:51 PM, "Dawson-Townsend,Timothy" > wrote: > >> iPad users: >> >> I'm more inclined to have the iPad in the RV-10 cockpit up in front >> by the dash somewhere, rather than as a kneeboard. >> >> What experience have others had? Is a RAM mount clamped on the >> edge of the glareshield rigid enough? Other mounting ideas? >> >> Tim >> N52KS >> >> >> > > > _- > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > _- > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > _- > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > _- > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > = > 3D > ====================== > ________________________________________________________________________________
Subject: Re: Video: Pipistrel Panthera Revealed
Date: Apr 18, 2012
200 kts on 10gph! 1000nm range No price mentioned Alan Sent from my iPhone On Apr 18, 2012, at 2:31 PM, "jchang10" wrote: > > http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_Aero2012_PipistrelPanthera_206547-1.html > > Wow, this will be interesting. Looks like another 4-seat plane similar to the -10 and Cirrus. > > Jae > > -------- > #40533 RV-10 > First flight 10/19/2011 > Phase 1 Done 11/26/2011 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371174#371174 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 18, 2012
Avweb listed it as $500,000 On Wed, Apr 18, 2012 at 1:41 PM, Alan Mekler MD wrote: > > 200 kts on 10gph! > 1000nm range > No price mentioned > > Alan > > Sent from my iPhone > > On Apr 18, 2012, at 2:31 PM, "jchang10" > wrote: > > > > > > > > http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_Aero2012_PipistrelPanthera_206547-1.html > > > > Wow, this will be interesting. Looks like another 4-seat plane similar > to the -10 and Cirrus. > > > > Jae > > > > -------- > > #40533 RV-10 > > First flight 10/19/2011 > > Phase 1 Done 11/26/2011 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=371174#371174 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 18, 2012
Sexy airplane. I don't know about the economics... $390K for 200knot/10gph airplane is quite a lot. I could fly the RV-10 a lifetime before ever breaking even. That doesn't even include the costs of maintaining/insuring a retract either. Very sexy, but I just don't think it makes sense when compared to what the -10 offers. It's pretty much the ultimate in performance, carrying capacity, and economics. (Even though RV-10's aren't cheap) I'd like to see more details like stalling speed, etc. I suspect it's really really high. Like Lancair high. Phil On Wed, Apr 18, 2012 at 1:31 PM, jchang10 wrote: > > > http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_Aero2012_PipistrelPanthera_206547-1.html > > Wow, this will be interesting. Looks like another 4-seat plane similar to > the -10 and Cirrus. > > Jae > > -------- > #40533 RV-10 > First flight 10/19/2011 > Phase 1 Done 11/26/2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371174#371174 > > ________________________________________________________________________________
Date: Apr 18, 2012
They said 350,000 Euros ($459,000 USD) for a certificated version, 300,000 euros ($393,000 USD) for a kit version. On Wed, Apr 18, 2012 at 1:41 PM, Alan Mekler MD wrote: > > 200 kts on 10gph! > 1000nm range > No price mentioned > > Alan > > Sent from my iPhone > > On Apr 18, 2012, at 2:31 PM, "jchang10" > wrote: > > > > > > > > http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_Aero2012_PipistrelPanthera_206547-1.html > > > > Wow, this will be interesting. Looks like another 4-seat plane similar > to the -10 and Cirrus. > > > > Jae > > > > -------- > > #40533 RV-10 > > First flight 10/19/2011 > > Phase 1 Done 11/26/2011 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=371174#371174 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 18, 2012
Date: Apr 18, 2012
Subject: Virtual Hangar Visit
Google Plus has something called Hangouts. Basically, it's a very simple to use group video chat that supports up to 9 people. All you need is a webcam and an internet connection. Just for fun, I'm going to create a hangout this evening (4/18/12) while I'm fiddling with my elevators. I'll make it open to the public so even people that I don't have in a circle (Google Plus's version of a group of friends) will be able to join. So please join in! I'd like to meet more of you guys, and this is the best (non text based) way to do some hangar flying I can think of short of actually being there. My Google Plus page is https://plus.google.com/u/0/104915858356518723094, or you can just search Google plus for Ed Kranz. Add me to a circle, as I'd like to get an RV builders circle together. ( I also posted this on VAF, but I'd really like to "meet" some fellow -10 builders) ________________________________________________________________________________
Date: Apr 18, 2012
Thanks Sean and thank you Ivan. I think I will have to go with the 3 " extension to all the cables. I'm not sure if Vans will take the others back after 2 years :). Phil I measured my cables but they don,t have the firewall wear sleeves or the Clamp reduced diameter Dimension E. Throttle is 47.5 " Extended Dimension B + C Dim D is 6" (retracted) Prop 72.5" B + C Extended Dim D is 6 " (retracted) Mixture 51.5 B + C and D is 6" (retracted) cheers John MacCallum VH-DUU #41016 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371226#371226 ________________________________________________________________________________
Date: Apr 18, 2012
I like that! I'm using a knee board and it's working well but is less than ideal. My instrument instructor uses a suction cup on the windshield but I don't see that working for the left seat pilot. Plus I don't like the idea of blocking out any of the view (ironic since no matter where you put it, the time spent looking at it effectively blocks the view). I'm working on a center console to enclose an O2 bottle. I'm thinking that a hardpoint for a swivel mount that would enable the ipad to hover over my right knee would be ideal. In the end, that position seems best since it doesn't block any instruments and is comfortable for right hand operation. Bill "old glider guider" Watson http://youtu.be/JYKubzq9r18 On 4/18/2012 3:11 PM, Robin Marks wrote: > That would be perfect dual sun visor iPads when not using the iPad > function but needing the visor you just turn on the rear camera and > you get forward facing view while still blocking the sun. Patent anyone? > > Robin > ________________________________________________________________________________
Date: Apr 19, 2012
Isn't there an FAR that prohibits sunvisors that block the view out of the windshield? -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371270#371270 ________________________________________________________________________________
Date: Apr 19, 2012
Very Helpful - Thank you! I'm guessing there wasn't a protective sleeve for the firewall penetration on the factory cables? Thanks, Phil On Wed, Apr 18, 2012 at 7:23 PM, maca2790 wrote: > > Thanks Sean and thank you Ivan. I think I will have to go with the 3 " > extension to all the cables. I'm not sure if Vans will take the others > back > after 2 years :). > > Phil I measured my cables but they don,t have the firewall wear sleeves or > the Clamp reduced diameter Dimension E. > > Throttle is 47.5 " Extended Dimension B + C Dim D is 6" (retracted) > > Prop 72.5" B + C Extended Dim D is 6 " (retracted) > > Mixture 51.5 B + C and D is 6" (retracted) > > cheers > > John MacCallum > VH-DUU > #41016 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371226#371226 > > ________________________________________________________________________________
Date: Apr 19, 2012
"Isn't there an FAR that prohibits sunvisors that block the view out of the windshield?" Cessna built 1000's of aircraft with solid (like a car) sunvisors, so I think the answer is "no". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371320#371320 ________________________________________________________________________________
Date: Apr 19, 2012
Guys, I've just started on the firewall construction. Do any of the aftermarket (non Vans type) cables require different sized holes through the firewall recess (F-1001K)? Thx, Rick #40956 Southampton, Ont On Thu, Apr 19, 2012 at 12:03 PM, Phillip Perry wrote: > Very Helpful - Thank you! > > I'm guessing there wasn't a protective sleeve for the firewall penetration > on the factory cables? > > Thanks, > Phil > > > On Wed, Apr 18, 2012 at 7:23 PM, maca2790 wrote: > >> >> Thanks Sean and thank you Ivan. I think I will have to go with the 3 " >> extension to all the cables. I'm not sure if Vans will take the others >> back >> after 2 years :). >> >> Phil I measured my cables but they don,t have the firewall wear sleeves or >> the Clamp reduced diameter Dimension E. >> >> Throttle is 47.5 " Extended Dimension B + C Dim D is 6" (retracted) >> >> Prop 72.5" B + C Extended Dim D is 6 " (retracted) >> >> Mixture 51.5 B + C and D is 6" (retracted) >> >> cheers >> >> John MacCallum >> VH-DUU >> #41016 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=371226#371226 >> >> >> >> >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > ________________________________________________________________________________
Date: Apr 20, 2012
G'day Rick There are quite a few different options for cables and some do require larger holes. My QB Fuselage already had the pilot holes drilled into the firewall for the cables so I'm going with the Vans plans for the holes. I have sent the cables supplied with the FF back and I will be using the VANS type cables from Aircraft spruce but 3 inches longer than the original ones supplied from Vans. If you have a look at the Aircraft Spruce web page you will get some idea of the different types available. Phil, yes your right there were no firewall wear sleeves on Vans Cables. What they say to do in the Plans is to put an SB500 inside a SB625 and then to fill it with heat proof RTV. cheers John MacCallum #41016 VH-DUU Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371334#371334 ________________________________________________________________________________
Date: Apr 20, 2012
Typically not. However there are a variety of devices available to protec t the cables and to minimize co into the cabin that require different spacin g if you choose to use them. Sent from my iPad On Apr 19, 2012, at 10:57 PM, Rick Lark wrote: > Guys, I've just started on the firewall construction. Do any of the after market (non Vans type) cables require different sized holes through the fire wall recess (F-1001K)? > > Thx, Rick > #40956 > Southampton, Ont > > > > > On Thu, Apr 19, 2012 at 12:03 PM, Phillip Perry wro te: > Very Helpful - Thank you! > > I'm guessing there wasn't a protective sleeve for the firewall penetration on the factory cables? > > Thanks, > Phil > > > > > On Wed, Apr 18, 2012 at 7:23 PM, maca2790 wrot e: > > Thanks Sean and thank you Ivan. I think I will have to go with the 3 " > extension to all the cables. I'm not sure if Vans will take the others ba ck > after 2 years :). > > Phil I measured my cables but they don,t have the firewall wear sleeves or > the Clamp reduced diameter Dimension E. > > Throttle is 47.5 " Extended Dimension B + C Dim D is 6" (retracted) > > Prop 72.5" B + C Extended Dim D is 6 " (retracted) > > Mixture 51.5 B + C and D is 6" (retracted) > > cheers > > John MacCallum > VH-DUU > #41016 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371226#371226 > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 20, 2012
Subject: ipad in the cockpit
Just thought to post my old email to the list in reference to iPad discussions. Do nt archive. ---------- Forwarded message ---------- From: Rob Kermanj <flysrv10(at)gmail.com> Date: Thu, Sep 23, 2010 at 7:55 PM Subject: Fwd: RV10-List: iPad Mount update I decided to relocate my iPad after my a flight test last weekend. I found the previous location a little too distant for my taste. I think the most ideal position is at eye level where John Miller has installed his. Hopefully the Gizmo guys will come up with a panel mount and give those in process of planning their panel another option. I swapped the 2" standard clamp leg with a 6" long leg from Ram Mount (they are great people to deal with) and I think that I like this arrangement much better. The second picture shows the iPad in it's pilot-exit configuration. Will post a flight test report this weekend. Begin forwarded message: *From: *Rob Kermanj <flysrv10(at)gmail.com> *Date: *September 13, 2010 6:17:08 PM EDT *To: *rv10-list(at)matronics.com *Subject: **RV10-List: iPad Mount* *Reply-To: *rv10-list(at)matronics.com I finally received my iPad mount from Ram Mounts. It is a good quality and strong mount. I used a sheet of aluminum and formed it around the tunnel to use as a temporary bracket and to mount the iPad. Once flight testing t is complete, I will most likely remove the extra aluminum bracket and attach the mount with thru bolts to the tunnel cover. I have pointed the iPad's charging port up under the panel; so that I can get a 12V charger and connect it behind the panel to charge continuously during flights. Flight test, this weekend. IMG_0046.JPG IMG_0047.JPG -- Rob Kermanj ________________________________________________________________________________
Subject: Flap Question
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Apr 21, 2012
I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? Thanks -Mike Sent from my iPhone ________________________________________________________________________________
Subject: Re: Flap Question
Date: Apr 21, 2012
I put the protective tape on the underside of the top skin instead of the top of the flap. This way it still doesn't get scratched and the uv doesn't yellow it. Sent from my iPhone On Apr 21, 2012, at 5:15, Michael Kraus wrote: > > I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. > > Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? > > Thanks > -Mike > > Sent from my iPhone > > > > ________________________________________________________________________________
Date: Apr 21, 2012
I have tape on the underside of the top skin to prevent scratches. I also bent the top skin up just slightly. Dave Leikam On Apr 21, 2012, at 7:15 AM, Michael Kraus wrote: > > I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. > > Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? > > Thanks > -Mike > > Sent from my iPhone > > > > ________________________________________________________________________________
Date: Apr 21, 2012
ditto bottom of skin Patrick Thyssen N15PT Sent from my iPad On Apr 21, 2012, at 7:25 AM, Seano wrote: > > I put the protective tape on the underside of the top skin instead of the top of the flap. This way it still doesn't get scratched and the uv doesn't yellow it. > > Sent from my iPhone > > On Apr 21, 2012, at 5:15, Michael Kraus wrote: > >> >> I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. >> >> Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? >> >> Thanks >> -Mike >> >> Sent from my iPhone >> >> >> >> > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Apr 21, 2012
I did the top of the flap. My thought was that anything getting stuck between the tape and the skin will scratch the underside of the wing skin, not the top of the flap. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen Sent: Saturday, April 21, 2012 9:17 AM Subject: Re: RV10-List: Flap Question ditto bottom of skin Patrick Thyssen N15PT Sent from my iPad On Apr 21, 2012, at 7:25 AM, Seano wrote: > > I put the protective tape on the underside of the top skin instead of the top of the flap. This way it still doesn't get scratched and the uv doesn't yellow it. > > Sent from my iPhone > > On Apr 21, 2012, at 5:15, Michael Kraus wrote: > >> --> >> >> I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. >> >> Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? >> >> Thanks >> -Mike >> >> Sent from my iPhone >> >> >> >> > > > > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Apr 21, 2012
Mine's under the top skin. But a customer had his tape on the top of the flap. After a few years the tape got brittle and began to flake off. He was complaining about a significant rolling moment when he put the flaps down. I'd seen that on my plane because the flaps were initially a little out of rig, so that's what we looked for. The rigging was fine so we cleaned up the flaking tape and that solved the problem--no more roll with flaps down. --Dave Saylor On Sat, Apr 21, 2012 at 5:15 AM, Michael Kraus wrote: > > > > I noticed my flap leading edge hits my wing top skin in the fully up > position just barely. I know the design of the other RV's necessitate a > protective tape as they are always in contact with the upper skin in any > position. > > Just curious what other RV-10ers are doing, bending the top skin trailing > edge slightly, or adding a protective tape? > > Thanks > -Mike > > Sent from my iPhone > > ________________________________________________________________________________
Date: Apr 21, 2012
And what specifically are the type of tapes that are being used?? Thank Chris N919AR ----- Original Message ----- From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com> Subject: Re: RV10-List: Flap Question Mine's under the top skin. But a customer had his tape on the top of the flap. After a few years the tape got brittle and began to flake off. He was complaining about a significant rolling moment when he put the flaps down. I'd seen that on my plane because the flaps were initially a little out of rig, so that's what we looked for. The rigging was fine so we cleaned up the flaking tape and that solved the problem--no more roll with flaps down. --Dave Saylor On Sat, Apr 21, 2012 at 5:15 AM, Michael Kraus wrote: I noticed my flap leading edge hits my wing top skin in the fully up position just barely. I know the design of the other RV's necessitate a protective tape as they are always in contact with the upper skin in any position. Just curious what other RV-10ers are doing, bending the top skin trailing edge slightly, or adding a protective tape? Thanks -Mike Sent from my iPhone ========== " target="_blank">http://www.matronics.com/Navigator?RV10-List ========== MS - k">http://forums.matronics.com ========== e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Apr 21, 2012
Subject: Firewall
Hi all, I'm in new territory here guys, but do I debur the firewall as I would a piece of aluminum? Lot's of edges and holes. I expect the stainless firewall won't stress crack like 2024T3 will, but I'm unsure. What's the bottom line??? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: Firewall
Date: Apr 21, 2012
Rick, Yes but for several reasons. One is it will cut the crap out on you in the n ormal course of the build. Second, although it's not as prone to stress crac ks as aluminum, smooth the edges to prevent any chance of stress risers. You can be much more aggressive than aluminum. I've found Dremel sanding barrel s and carbide cutters work well. Time spent smoothing these edges will save m any bandaids and painful steel cuts over the long run. Just my humble advic e, worth everything you paid for it. :D Rick Sked Building RV-10 n=C3=BAmero dos! Sent from my iPhone On Apr 21, 2012, at 7:19 PM, Rick Lark wrote: > Hi all, I'm in new territory here guys, but do I debur the firewall as I w ould a piece of aluminum? Lot's of edges and holes. I expect the stainless firewall won't stress crack like 2024T3 will, but I'm unsure. > > What's the bottom line??? > > Thx, Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: MT 860 Governor
Date: Apr 22, 2012
Hi all, To get the Prop Governor to work with the Vans Baffle and cable mounting arrangement I will have to move the stop plate and the control arm. Has anyone else done this with their MT Governor? Cheers John MacCallum VH-DUU 41016 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371520#371520 ________________________________________________________________________________
Subject: Re: MT 860 Governor
Date: Apr 22, 2012
Read the directions! There is a right way, and wrong way to do it. If i recall correctly, basically loosen up the 6 safety wired screws and the assembly rotates. I would be sure to read the instructions though.... Sent from my iPhone On Apr 22, 2012, at 5:07 PM, "maca2790" wrote: > > Hi all, > To get the Prop Governor to work with the Vans Baffle and cable mounting arrangement I will have to move the stop plate and the control arm. > > Has anyone else done this with their MT Governor? > > Cheers > > John MacCallum > VH-DUU > 41016 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371520#371520 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 22, 2012
Exactly. I did it, no problems following the very specific directions. Bill Sent from my iPad On Apr 22, 2012, at 5:44 PM, Michael Kraus wrote: > > Read the directions! There is a right way, and wrong way to do it. If i recall correctly, basically loosen up the 6 safety wired screws and the assembly rotates. I would be sure to read the instructions though.... > > Sent from my iPhone > > On Apr 22, 2012, at 5:07 PM, "maca2790" wrote: > >> >> Hi all, >> To get the Prop Governor to work with the Vans Baffle and cable mounting arrangement I will have to move the stop plate and the control arm. >> >> Has anyone else done this with their MT Governor? >> >> Cheers >> >> John MacCallum >> VH-DUU >> 41016 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=371520#371520 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Apr 23, 2012
Thanks Guys, yes I have read the Instructions and I worked it out that I have to rotate the Plate. I guess to be succinct, I should ask has anyone got a photo of what you did so that I can copy it :) Cheers John MacCallum #41016 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371560#371560 ________________________________________________________________________________
Date: Apr 23, 2012
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Friend of mine is using the loop side of velcro on the underside of the wing for his RV8 . Less expensive than the tape. Dr Fred 515FW. On 4/21/2012 7:39 PM, Chris wrote: > And what specifically are the type of tapes that are being used?? > Thank > Chris > N919AR > > ----- Original Message ----- > From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com> > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Flap Question > > Mine's under the top skin. But a customer had his tape on the top of > the flap. After a few years the tape got brittle and began to flake > off. He was complaining about a significant rolling moment when he > put the flaps down. I'd seen that on my plane because the flaps were > initially a little out of rig, so that's what we looked for. The > rigging was fine so we cleaned up the flaking tape and that solved the > problem--no more roll with flaps down. > > --Dave Saylor > > > On Sat, Apr 21, 2012 at 5:15 AM, Michael Kraus > > wrote: > > > > > I noticed my flap leading edge hits my wing top skin in the fully > up position just barely. I know the design of the other RV's > necessitate a protective tape as they are always in contact with > the upper skin in any position. > > Just curious what other RV-10ers are doing, bending the top skin > trailing edge slightly, or adding a protective tape? > > Thanks > -Mike > > Sent from my iPhone > > ========== > " target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > MS - > k">http://forums.matronics.com > ========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========== > > > * > > et="_blank">http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank">http://www.matronics.com/contribution > > * > * > > > * ________________________________________________________________________________
Date: Apr 23, 2012
I used this: http://www.aircraftspruce.com/catalog/cspages/teflonantichafetape.php John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371595#371595 ________________________________________________________________________________
Date: Apr 23, 2012
Ahhh! I have an old partial roll of that stuff, so I guess that's what I will try. Thanks -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Monday, April 23, 2012 9:46 AM Subject: RV10-List: Re: Flap Question I used this: http://www.aircraftspruce.com/catalog/cspages/teflonantichafetape.php John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371595#371595 ________________________________________________________________________________
Date: Apr 24, 2012
Subject: RV10 Training in Calif
I just completed RV10 transition training with Bob Turner in his RV10; he is located at the Livermore CA airport in the SF Bay area. If you are located in this part of the country and will need RV10 training, I highly recommend that you contact Bob (bobturner(at)alum.rpi.edu). He has been flying and instructing for many years (CFII), is comfortable to fly with and quite knowledgeable about things airplane. And since he recently retired from Lawrence Livermore Labs (physicist), his schedule is flexible. Let Bob know if you might be interested; I think he is investigating future RV10 training insurance options. Dave Head RV10 QB First Flight Imminent ________________________________________________________________________________
Date: Apr 24, 2012
Subject: firewall sealing
Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess with pro seal..Did anyone use some other type of high temp sealant for this purpose. Seems to me even hi temp RTV would be beter than pro seal? Comments?? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Apr 24, 2012
Subject: Re: firewall sealing
I used some extra biotherm I had left over from buying the firewall pass-throughs found here... http://www.planeinnovations.com/firewallkits.html (bottom of page) I've been looking for a local source for the biotherm 100, but have yet to find it. -Sean #40303 (Doors) On 4/24/12 8:47 PM, Rick Lark wrote: > Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess > with pro seal..Did anyone use some other type of high temp sealant for > this purpose. Seems to me even hi temp RTV would be beter than pro seal? > Comments?? > Thx, Rick > #40956 > Southampton, Ont > * > > > * ________________________________________________________________________________
Date: Apr 24, 2012
I prefer the high temp RTV personally. I don't like any pro seal in the engine compartment. Some people have done tests on the pro seal with high heat and it didn't react well, IIRC. I use black high-temp RTV to seal the firewall and all other things in the engine compartment. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Apr 24, 2012, at 9:47 PM, Rick Lark wrote: > Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess with pro seal..Did anyone use some other type of high temp sealant for this purpose. Seems to me even hi temp RTV would be beter than pro seal? > > Comments?? > > Thx, Rick > #40956 > Southampton, Ont > > > ________________________________________________________________________________
Date: Apr 24, 2012
Rick,* the area in question deserves the best sealant possible*. RTV is a cheap and easy solution that does NOT meet the challenge. I installed a product Desoto Proseal CS-1900 which was a fiberous proseal type "fire-retandant" sealant with the manufacturers endorsement of higher temperature. *When your fire annunciator system fails*. * When Your Fire Suppression system fails*, *your only recourse is to think of Bob Hoover and pray*. *Dont use RTV*. Time from point of crisis awareness to remediation is the longest period in your life. FLY the damn aircraft to a safe landing point. Fly the aircraft to the accident site and insure that all POBs are safely away. From the moment of acknowledgement of a fire to the moment of safety, your actions speak volumes on your instruction and skill as a pilot. I lost a friend leaving OSH a few years ago that failed to heed those words in his Lancair Legacy 2000. Thought he could be a HERO. "From the moment of acknowledgement to the moment of reflection on your actions , a great pilot knows the aircraft instantly belongs to the insurance company. Your responsibility is to your passengers, your family and your brothers-in-arms who love flying after your memorial service. "Dan Lloyd, I still miss you and pray I follow the wiser choice and don't place human life on a $ savings on RTV.". CHOOSE WISELY, FLY OFTEN, THINK ABOUT THOSE WHO WILL FOLLOW. You guys slay me occasionally on the decision process you follow! DAMN I AM GETTING OLD. John #40600 On Tue, Apr 24, 2012 at 6:47 PM, Rick Lark wrote: > Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess > with pro seal..Did anyone use some other type of high temp sealant for this > purpose. Seems to me even hi temp RTV would be beter than pro seal? > > Comments?? > > Thx, Rick > #40956 > Southampton, Ont > > * > > * > > ________________________________________________________________________________
Date: Apr 25, 2012
Thx all, I am on my way to Aircraft Spruce this morning to pick up a few things. I probably will buy a tube of Biotherm 100 which is rated to 2000 degrees. I did find a write up on the Plane Innovations web site, www.planeinnovations.com/firewallkits.html. I will stay away from the RVT. Rick ----- Original Message ----- From: John Cox To: rv10-list(at)matronics.com Sent: Wednesday, April 25, 2012 1:39 AM Subject: Re: RV10-List: firewall sealing Rick, the area in question deserves the best sealant possible. RTV is a cheap and easy solution that does NOT meet the challenge. I installed a product Desoto Proseal CS-1900 which was a fiberous proseal type "fire-retandant" sealant with the manufacturers endorsement of higher temperature. When your fire annunciator system fails. When Your Fire Suppression system fails, your only recourse is to think of Bob Hoover and pray. Dont use RTV. Time from point of crisis awareness to remediation is the longest period in your life. FLY the damn aircraft to a safe landing point. Fly the aircraft to the accident site and insure that all POBs are safely away. From the moment of acknowledgement of a fire to the moment of safety, your actions speak volumes on your instruction and skill as a pilot. I lost a friend leaving OSH a few years ago that failed to heed those words in his Lancair Legacy 2000. Thought he could be a HERO. "From the moment of acknowledgement to the moment of reflection on your actions , a great pilot knows the aircraft instantly belongs to the insurance company. Your responsibility is to your passengers, your family and your brothers-in-arms who love flying after your memorial service. "Dan Lloyd, I still miss you and pray I follow the wiser choice and don't place human life on a $ savings on RTV.". CHOOSE WISELY, FLY OFTEN, THINK ABOUT THOSE WHO WILL FOLLOW. You guys slay me occasionally on the decision process you follow! DAMN I AM GETTING OLD. John #40600 On Tue, Apr 24, 2012 at 6:47 PM, Rick Lark wrote: Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess with pro seal..Did anyone use some other type of high temp sealant for this purpose. Seems to me even hi temp RTV would be beter than pro seal? Comments?? Thx, Rick #40956 Southampton, Ont get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Alternative glue for the elevators foam ribs
Date: Apr 25, 2012
I am building the elevators, and as you know, one has to glue the trailing edge foam ribs to the elevator skins interior. Van's plans want you to use that ##$&&%% tank sealant, which I really hate to use (probably one of the reasons I always go with the QB kit . :-)). What are the alternative glues that can be used is this case, which obviously don't melt the foam and don't corrode the aluminium skins? Carlos ________________________________________________________________________________
Subject: Re: Alternative glue for the elevators foam ribs
Date: Apr 25, 2012
Just stick to the Proseal, it's tried and proven and not all that bad compar ed with itchy fibreglass. Wait until you get to the cabin top & doors. Warm regards Patrick On 25/04/2012, at 9:54 PM, "Carlos Trigo" wrote: > I am building the elevators, and as you know, one has to glue the trailing edge foam ribs to the elevator skins interior. > Van=99s plans want you to use that ##$&&%% tank sealant, which I rea lly hate to use (probably one of the reasons I always go with the QB kit J). > > What are the alternative glues that can be used is this case, which obviou sly don=99t melt the foam and don=99t corrode the aluminium skin s? > > Carlos > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 25, 2012
If you don't want to deal with the pint or quart containers, Van's sells the 1/2 oz film cannister size which is all you need for the trailing edge. Only wish they would offer it in B-2 instead of B-1/2, as the 30 min pot life gets shortened by 50% for each ten degrees over 75, a rather common condition here in Aridzona. On 4/25/2012 5:24 AM, Carlos Trigo wrote: > > I am building the elevators, and as you know, one has to glue the > trailing edge foam ribs to the elevator skins interior. > > Vans plans want you to use that ##$&&%% tank sealant, which I really > hate to use (probably one of the reasons I always go with the QB kit J). > > What are the alternative glues that can be used is this case, which > obviously dont melt the foam and dont corrode the aluminium skins? > > Carlos > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 25, 2012
I fault Van's for simply calling for proseal when they clearly should be calling for the Proseal 1900 or other suitable sealant. While proseal may be adequate for keeping carbon monoxide from seeping through the firewall, it gives no fire protection. Not to mention Van's supplying aluminum heater control boxes that simply defeat the benefits of having a firewall completely. The Plane innovations or other stainless heater control boxes both work better and restore the all stainless content on the firewall, and come with a small tube of Biotherm. Also unfortunate that Van's doesn't do much product improvement over time. Apparently afraid to admit that something could be better than their original specifications. On 4/24/2012 10:39 PM, John Cox wrote: > Rick,*the area in question deserves the best sealant possible*. > John #40600 > > On Tue, Apr 24, 2012 at 6:47 PM, Rick Lark > wrote: > > Hi Guys, I see that Vans wants you to seal the F-1001K stainles > recess with pro seal..Did anyone use some other type of high temp > sealant for this purpose. Seems to me even hi temp RTV would be > beter than pro seal? > ** > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 25, 2012
Kelly, > firewall, it gives no fire protection. Not to mention Van's supplying > aluminum heater control boxes that simply defeat the benefits of having you forgot to mention, that the FW is as well riveted with alu rivets to the structure, so that will not help either in case of a fire. Cheers Werner ________________________________________________________________________________
Date: Apr 25, 2012
My answer to the fire problem (hope I never need it), 10# of Halon sprayed between the firewall and baffling and over the engine. From Stroud Fire Safety OKC _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, April 25, 2012 7:34 AM Subject: Re: RV10-List: firewall sealing I fault Van's for simply calling for proseal when they clearly should be calling for the Proseal 1900 or other suitable sealant. While proseal may be adequate for keeping carbon monoxide from seeping through the firewall, it gives no fire protection. Not to mention Van's supplying aluminum heater control boxes that simply defeat the benefits of having a firewall completely. The Plane innovations or other stainless heater control boxes both work better and restore the all stainless content on the firewall, and come with a small tube of Biotherm. Also unfortunate that Van's doesn't do much product improvement over time. Apparently afraid to admit that something could be better than their original specifications. On 4/24/2012 10:39 PM, John Cox wrote: Rick, the area in question deserves the best sealant possible. John #40600 On Tue, Apr 24, 2012 at 6:47 PM, Rick Lark wrote: Hi Guys, I see that Vans wants you to seal the F-1001K stainles recess with pro seal..Did anyone use some other type of high temp sealant for this purpose. Seems to me even hi temp RTV would be beter than pro seal? No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 25, 2012
Werner, the fact that there are aluminum rivets crossed my mind too. None the less John Cox is right, you owe it to your pasengers and yourself to make the firewall as good as possible. Solid rivets are still more fire resistant than normal pro seal, and using the Biotherm 100 is a step in the right direction. Perhaps another look at the David McNeils under cowling fire suppresion system is in order. Rick ----- Original Message ----- From: "Werner Schneider" <glastar(at)gmx.net> Sent: Wednesday, April 25, 2012 11:14 AM Subject: Re: RV10-List: firewall sealing > > Kelly, > >> firewall, it gives no fire protection. Not to mention Van's supplying >> aluminum heater control boxes that simply defeat the benefits of having > > you forgot to mention, that the FW is as well riveted with alu rivets to > the structure, so that will not help either in case of a fire. > > Cheers Werner > > > ________________________________________________________________________________
Date: Apr 25, 2012
Your hosed if there is a fire! Rivets are the least of your problem, the issue is sealing the area around the rivets and the areas that are most prone to "holding off" the fire and smoke with a heat sealant. We are talking buying time here, the smoke will blind and cause all sorts of breathing issues, hence the solid steel vents (that I know seal better than the Vans one) but inhaling burning proseal is not something I would want to add to the issue. There are many rivets, there is a whole lot of fiberglass above the area, the glass will give far sooner than the rivets ever will. -----Original Message----- From: Rick Lark Sent: Wednesday, April 25, 2012 9:25 AM Subject: Re: RV10-List: firewall sealing Werner, the fact that there are aluminum rivets crossed my mind too. None the less John Cox is right, you owe it to your pasengers and yourself to make the firewall as good as possible. Solid rivets are still more fire resistant than normal pro seal, and using the Biotherm 100 is a step in the right direction. Perhaps another look at the David McNeils under cowling fire suppresion system is in order. Rick ----- Original Message ----- From: "Werner Schneider" <glastar(at)gmx.net> Sent: Wednesday, April 25, 2012 11:14 AM Subject: Re: RV10-List: firewall sealing > > Kelly, > >> firewall, it gives no fire protection. Not to mention Van's supplying >> aluminum heater control boxes that simply defeat the benefits of having > > you forgot to mention, that the FW is as well riveted with alu rivets to > the structure, so that will not help either in case of a fire. > > Cheers Werner > > ________________________________________________________________________________
Date: Apr 25, 2012
A before and after photo; I teed it at the firewall, one sprayer was clamped near the spider and the other was between the firewall and baffling. Be sure and isolate engine vibrations from the sprayers by a rubber flex tube between with hose clamps. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Wednesday, April 25, 2012 9:25 AM Subject: Re: RV10-List: firewall sealing Werner, the fact that there are aluminum rivets crossed my mind too. None the less John Cox is right, you owe it to your pasengers and yourself to make the firewall as good as possible. Solid rivets are still more fire resistant than normal pro seal, and using the Biotherm 100 is a step in the right direction. Perhaps another look at the David McNeils under cowling fire suppresion system is in order. Rick ----- Original Message ----- From: "Werner Schneider" <glastar(at)gmx.net> Sent: Wednesday, April 25, 2012 11:14 AM Subject: Re: RV10-List: firewall sealing > > Kelly, > >> firewall, it gives no fire protection. Not to mention Van's supplying >> aluminum heater control boxes that simply defeat the benefits of having > > you forgot to mention, that the FW is as well riveted with alu rivets to > the structure, so that will not help either in case of a fire. > > Cheers Werner > > > ________________________________________________________________________________
Date: Apr 25, 2012
If you are worried about fire, think fire suppression. Try http://www.stroudsafety.com/FireExtinguisherSystems.html All of that fiberglass is going to burn well with a lot of noxious fumes. It's best to put it out. Fuel selector OFF, pull the pin and blow the bottle. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Wednesday, April 25, 2012 10:04 AM Subject: Re: RV10-List: firewall sealing Your hosed if there is a fire! Rivets are the least of your problem, the issue is sealing the area around the rivets and the areas that are most prone to "holding off" the fire and smoke with a heat sealant. We are talking buying time here, the smoke will blind and cause all sorts of breathing issues, hence the solid steel vents (that I know seal better than the Vans one) but inhaling burning proseal is not something I would want to add to the issue. There are many rivets, there is a whole lot of fiberglass above the area, the glass will give far sooner than the rivets ever will. -----Original Message----- From: Rick Lark Sent: Wednesday, April 25, 2012 9:25 AM Subject: Re: RV10-List: firewall sealing Werner, the fact that there are aluminum rivets crossed my mind too. None the less John Cox is right, you owe it to your pasengers and yourself to make the firewall as good as possible. Solid rivets are still more fire resistant than normal pro seal, and using the Biotherm 100 is a step in the right direction. Perhaps another look at the David McNeils under cowling fire suppresion system is in order. Rick ----- Original Message ----- From: "Werner Schneider" <glastar(at)gmx.net> Sent: Wednesday, April 25, 2012 11:14 AM Subject: Re: RV10-List: firewall sealing > > Kelly, > >> firewall, it gives no fire protection. Not to mention Van's supplying >> aluminum heater control boxes that simply defeat the benefits of having > > you forgot to mention, that the FW is as well riveted with alu rivets to > the structure, so that will not help either in case of a fire. > > Cheers Werner > > > > ________________________________________________________________________________
Date: Apr 25, 2012
Email check -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Wednesday, April 25, 2012 10:04 AM Subject: Re: RV10-List: firewall sealing Your hosed if there is a fire! Rivets are the least of your problem, the issue is sealing the area around the rivets and the areas that are most prone to "holding off" the fire and smoke with a heat sealant. We are talking buying time here, the smoke will blind and cause all sorts of breathing issues, hence the solid steel vents (that I know seal better than the Vans one) but inhaling burning proseal is not something I would want to add to the issue. There are many rivets, there is a whole lot of fiberglass above the area, the glass will give far sooner than the rivets ever will. -----Original Message----- From: Rick Lark Sent: Wednesday, April 25, 2012 9:25 AM Subject: Re: RV10-List: firewall sealing Werner, the fact that there are aluminum rivets crossed my mind too. None the less John Cox is right, you owe it to your pasengers and yourself to make the firewall as good as possible. Solid rivets are still more fire resistant than normal pro seal, and using the Biotherm 100 is a step in the right direction. Perhaps another look at the David McNeils under cowling fire suppresion system is in order. Rick ----- Original Message ----- From: "Werner Schneider" <glastar(at)gmx.net> Sent: Wednesday, April 25, 2012 11:14 AM Subject: Re: RV10-List: firewall sealing > > Kelly, > >> firewall, it gives no fire protection. Not to mention Van's supplying >> aluminum heater control boxes that simply defeat the benefits of having > > you forgot to mention, that the FW is as well riveted with alu rivets to > the structure, so that will not help either in case of a fire. > > Cheers Werner > > ________________________________________________________________________________
Date: Apr 25, 2012
I just did the elevator trailing edges, ribs, and trim tab ribs last night. I used the "mix in the tube" 3.5oz tank sealant from Vans, and it was just enough for all those parts. (Part number MC-236-B1/2) You can stick the tube in a caulk gun and just shoot it onto the part and spread it out. It took me about 30 minutes for the entire process. Simple, and no measuring needed. On Wed, Apr 25, 2012 at 9:22 AM, Kelly McMullen wrote: > > If you don't want to deal with the pint or quart containers, Van's sells the > 1/2 oz film cannister size which is all you need for the trailing edge. Only > wish they would offer it in B-2 instead of B-1/2, as the 30 min pot life > gets shortened by 50% for each ten degrees over 75, a rather common > condition here in Aridzona. > > > On 4/25/2012 5:24 AM, Carlos Trigo wrote: >> >> >> I am building the elevators, and as you know, one has to glue the trailing >> edge foam ribs to the elevator skins interior. >> >> Vans plans want you to use that ##$&&%% tank sealant, which I really hate >> to use (probably one of the reasons I always go with the QB kit J). >> >> What are the alternative glues that can be used is this case, which >> obviously dont melt the foam and dont corrode the aluminium skins? >> >> Carlos >> >> * >> >> >> * > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Apr 25, 2012
From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
Subject: Gretz Pitot & Aileron Trim
Two questions: 1. Where have you mounted the Gretz control module? Ideally it would be mounted so that the face of the wire connecting block and the screws that hold the wire in place would be easily accessible from the inspection opening. The location of the three attachment points on the module make that a little difficult. I have placed the head mount in the position called for by the plans. Access would seem to dictate that it be mounted on the inspection hole side (outboard side) of the rib with the pitot mount on the inboard side of the rib, but I can's seem to find a position that would make both the connecting face and the screws on the module easy to see and tighten. 2. It would appear to be much easier to install the aileron trim before the bottom skin was attached. But as I read the instructions for the trim servo, it looks like one has to wait until the ailerons are attached to the wings and possibly the wings are attached to the airplane. Is that correct? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings ~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Apr 25, 2012
I mounted my Gretz control module to the inspection plate. Easy and accessible. I did my Aileron trim after the wing was on the airplane....but I think you could do it after the bottom skin was on but before you put the wing on the airplane. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Wednesday, April 25, 2012 5:05 PM Subject: RV10-List: Gretz Pitot & Aileron Trim --> Two questions: 1. Where have you mounted the Gretz control module? Ideally it would be mounted so that the face of the wire connecting block and the screws that hold the wire in place would be easily accessible from the inspection opening. The location of the three attachment points on the module make that a little difficult. I have placed the head mount in the position called for by the plans. Access would seem to dictate that it be mounted on the inspection hole side (outboard side) of the rib with the pitot mount on the inboard side of the rib, but I can's seem to find a position that would make both the connecting face and the screws on the module easy to see and tighten. 2. It would appear to be much easier to install the aileron trim before the bottom skin was attached. But as I read the instructions for the trim servo, it looks like one has to wait until the ailerons are attached to the wings and possibly the wings are attached to the airplane. Is that correct? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings ~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Apr 25, 2012
You can of course fit up the aileron trim servo mount onto the inboard left wing inspection plate. You cannot fit the aileron trim spring attachments to the aileron push tube until after the wings are on and the control surfaces are rigged. The aileron push tube needs to first be correct, "stick centered" position to determine where to put the spring attachments. Remember that the push tube is easily removed via the wing tip once you mark where the attachments go. Carl Pitot static test completed today - trying to get the FSDO out the first week in May. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Wednesday, April 25, 2012 7:53 PM Subject: RE: RV10-List: Gretz Pitot & Aileron Trim I mounted my Gretz control module to the inspection plate. Easy and accessible. I did my Aileron trim after the wing was on the airplane....but I think you could do it after the bottom skin was on but before you put the wing on the airplane. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Wednesday, April 25, 2012 5:05 PM Subject: RV10-List: Gretz Pitot & Aileron Trim --> Two questions: 1. Where have you mounted the Gretz control module? Ideally it would be mounted so that the face of the wire connecting block and the screws that hold the wire in place would be easily accessible from the inspection opening. The location of the three attachment points on the module make that a little difficult. I have placed the head mount in the position called for by the plans. Access would seem to dictate that it be mounted on the inspection hole side (outboard side) of the rib with the pitot mount on the inboard side of the rib, but I can's seem to find a position that would make both the connecting face and the screws on the module easy to see and tighten. 2. It would appear to be much easier to install the aileron trim before the bottom skin was attached. But as I read the instructions for the trim servo, it looks like one has to wait until the ailerons are attached to the wings and possibly the wings are attached to the airplane. Is that correct? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings ~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Apr 25, 2012
I thought it would be easier to install the gretz using molex connectors for the wires so I mounted the assembly just inside of the wing rib inside the inspection plate. I split the wires leading from the pitot to the control unit and added appropriately sized molex connector. The thought being that installing the pitot is just a matter of snapping the molex connector tight instead of trying to work those little screws while upside down. Not flying yet so as to effectiveness and reliability.... WAG. Ben Westfall 40579 Portland, OR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Wednesday, April 25, 2012 4:05 PM Subject: RV10-List: Gretz Pitot & Aileron Trim Two questions: 1. Where have you mounted the Gretz control module? Ideally it would be mounted so that the face of the wire connecting block and the screws that hold the wire in place would be easily accessible from the inspection opening. The location of the three attachment points on the module make that a little difficult. I have placed the head mount in the position called for by the plans. Access would seem to dictate that it be mounted on the inspection hole side (outboard side) of the rib with the pitot mount on the inboard side of the rib, but I can's seem to find a position that would make both the connecting face and the screws on the module easy to see and tighten. 2. It would appear to be much easier to install the aileron trim before the bottom skin was attached. But as I read the instructions for the trim servo, it looks like one has to wait until the ailerons are attached to the wings and possibly the wings are attached to the airplane. Is that correct? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings ~~~~~~~~~~~~~~~ ________________________________________________________________________________
Subject: Re: Gretz Pitot & Aileron Trim
Date: Apr 25, 2012
Dave, I don't normally post but I think my installation worked out well. I have posted three different views. I would not place the controller outboard of the rib. The two AN3's are easily reached thru the access cover. Ron Mara Addison, Texas ----- Original Message ----- From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com> Sent: Wednesday, April 25, 2012 6:04 PM Subject: RV10-List: Gretz Pitot & Aileron Trim > > > Two questions: > > 1. Where have you mounted the Gretz control module? Ideally it would be > mounted so that the face of the wire connecting block and the screws that > hold the wire in place would be easily accessible from the inspection > opening. The location of the three attachment points on the module make > that a little difficult. I have placed the head mount in the position > called for by the plans. Access would seem to dictate that it be mounted > on the inspection hole side (outboard side) of the rib with the pitot > mount on the inboard side of the rib, but I can's seem to find a position > that would make both the connecting face and the screws on the module easy > to see and tighten. > > 2. It would appear to be much easier to install the aileron trim before > the bottom skin was attached. But as I read the instructions for the trim > servo, it looks like one has to wait until the ailerons are attached to > the wings and possibly the wings are attached to the airplane. Is that > correct? > > Dave > > -- > ~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > Wings > ~~~~~~~~~~~~~~~ > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 7086 (20120425) __________ > > The message was checked by ESET NOD32 Antivirus. > > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 7086 (20120425) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Apr 25, 2012
Sorry, size restriction... here's the third photo. ----- Original Message ----- From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com> Sent: Wednesday, April 25, 2012 6:04 PM Subject: RV10-List: Gretz Pitot & Aileron Trim > > > Two questions: > > 1. Where have you mounted the Gretz control module? Ideally it would be > mounted so that the face of the wire connecting block and the screws that > hold the wire in place would be easily accessible from the inspection > opening. The location of the three attachment points on the module make > that a little difficult. I have placed the head mount in the position > called for by the plans. Access would seem to dictate that it be mounted > on the inspection hole side (outboard side) of the rib with the pitot > mount on the inboard side of the rib, but I can's seem to find a position > that would make both the connecting face and the screws on the module easy > to see and tighten. > > 2. It would appear to be much easier to install the aileron trim before > the bottom skin was attached. But as I read the instructions for the trim > servo, it looks like one has to wait until the ailerons are attached to > the wings and possibly the wings are attached to the airplane. Is that > correct? > > Dave > > -- > ~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > Wings > ~~~~~~~~~~~~~~~ > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 7086 (20120425) __________ > > The message was checked by ESET NOD32 Antivirus. > > > __________ Information from ESET NOD32 Antivirus, version of virus signature database 7086 (20120425) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Date: Apr 26, 2012
Subject: Foreflight with Stratus Review
I received my Stratus unit from Sporty's the other day and wanted to give a report on my impressions for the group. I know there is a lot of debate over which app is best for the iPad, especially with the new Garmin app released at Sun-N-Fun, but I'm going to try not to get into that beyond this statement. I have used Foreflight since version 1 or 2 and have only tried WingX a little. Because I am used to Foreflight and the navigation and functionality, I have not liked my experiences with WingX, but as has been said before, we like what we are used to. I use Foreflight for all of my flight planning (I usually use www.weathermeister.com for keeping up with the weather for my trip, but use Foreflight for all actually route planning, flight plan filing, and charts and plates while flying). I have Foreflight on my iPad 2 Wifi and iPhone 4. I have used a bluetooth GPS that required jailbreaking the iPad, but when that broke (left it on the glarshield in the Florida sun for 3-4 hours one day and the battery swelled and broke the case), I bought the Bad Elf. I wasn't very happy with the Bad Elf because I didn't like having it attached to the iPad in use, especially when bouncing around in IMC. I almost pulled the trigger on the new iPad, in which case I would have bought the 4G version, but when I didn't get the call from MacMall on the day they were starting to ship (like they promised they would), I didn't follow through with the purchase. I was walking through the hangars at Sun-N-Fun and saw the Stratus on the first day. After a short talk with a friend of mine, we decided to buy it. We had both been saying that as soon as there was a portable ADS-B box that worked with Foreflight, we would get it. We split the cost and ordered it as well as the external antenna (which we haven't received yet). We mainly wanted ADS-B for weather, because we were almost to the point of getting the unit that would get XM weather onto the iPad, but liked the thought of no subscription better. We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida through a lot of IMC, but it was a couple of days too early for the Stratus. That would be the real test, especially because of the ADS-B service areas and all of the local radar activity. Unfortunately, the screen shots I have now are shots with no rain within 250nm or more of where I was flying, and not a cloud in the sky, but I will share some of them anyway. Now, for my experience with the Stratus. YMMV, but this is my thought after my short time using it. For the cost, I think it's about as cheap as any ADS-B unit that I have seen, and I figured it would cost about the same as a year work of activation and subscription to XM with the better plan, not counting the XM hardware. As far as what coverage is available through ADS-B, I was pleasantly surprised to find out today that winds aloft are actually available. There are no lightning strikes or Echo Tops, but METARSs, TAFs, NOTAMs, Winds Aloft, Radar (high resolution regional and low resolution nationwide) and PIREPs are all available (among a few other things that I usually don't spend much time with). Personally I really like flying with Echo Tops in the -10 because it usually accurately lets me know if I will be able to get over the tops or will have to go through. Lightning would be nice to have, but usually avoiding the red nexrad (which is a good idea) will keep you away from most strikes (which is a very good idea), in my experience. I will miss those two features, but the most important features for me are METARs, TAFs and Radar. We took off from X35 with the Stratus on the glare shield of the RV-10 and watched the LED's on the unit as well as the indication in Foreflight of when we got a signal. We got the signal at about 5-600 feet AGL. Remember that we are in central Florida, so the ADS-B coverage here is very good. We had as many as 9 stations at a time in our short flight up to 5,500 feet MSL. I really like the Status page (see attached pictures) that gives you the information on the Stratus. It shows the connectivity, battery status, power source, etc and then gives information on what data has been downloaded and how long ago. It also shows the grid of satellites that the unit is receiving location from and how good the signal is. The accuracy of location, including GPS altitude, is the best I have seen among the bluetooth GPS, Bad Elf, onboard GPS and the Stratus, with Accuracy usually 1-2m. As you can see from the pictures attached, and as I have already mentioned, the weather here was way too good to get great pictures as to the usefulness of the Stratus, but it's the best I can offer so far. I usually just keep up the map screen with the Radar and Flight Rules shown. For information on a specific airport, you can just tap on the dot and it will pull up the Metar (and TAF and Winds Aloft if available). If you scroll down on the pop-up, you can see the METARs of other local airports, as well as how old the report is. We must have been getting some medium and/or high altitude ADS-B stations, because we were getting national CONUS Radar as well as a good range of METARs, PIREPs, etc. If you zoom out on the map, only the bigger airport Flight Rules show up. If you zoom in, it shows everywhere that reports. It will also paint the surface winds, cielings, temperature, dew point spread, cloud cover, etc. the same way that it does the Flight Rules, but this display is my favorite for overall information. It will only show one of these at a time, as well as Radar at the same time. It will also show TFR's on the map for those who aren't flying "in the system". My overall impression is very good. I am looking forward to taking a trip outside the normally shown coverage area, especially after I get the external antenna, so I can see how accurate the coverage maps are in the 10-18,000 foot range. One nice thing is that if you are going through a relatively small area of weak coverage, the information stays on the iPad. It just doesn't update, so you still should have information, which will start updating as soon as you get back within coverage. The battery on the Stratus has been quite impressive so far. It comes with a USB cable for charging, as well as an AC adapter, but in a 45 minute flight the battery was still in the 90%'s. It seemed to stay put really well on the glare shield and it is low profile, so it doesn't get in my way at all for flying. Can it replace XM? In my opinion, for a great deal of my flying, yes, mainly because of where I live and where and how I fly. I much prefer the screen size of the iPad to the Garmin Aera, and I like the interface much better than the Aera. As an all-in-one unit for flight planning, preflight weather, enroute charts, plates, enroute weather (with the Stratus), I haven't used anything I think would work better (especially for moving from plane to plane) than the iPad, Foreflight and the Stratus. It is not for everybody, but for those within the coverage area, who move from plane to plane, who don't want to have the monthly subscription, I highly recommend it based on my experience so far. I'll try to post again after I have taken it on a longer trip through some IMC. One thing I would really like to see in Foreflight would be a Winds Aloft display on the map, like with most XM products. They have surface winds at airports, which helps, but picking an altitude with Winds Aloft information would help. It does calculate Time Enroute and overall wind effect for your route in the route planner, so I guess you could pick different altitudes and see which one would be fastest, but it would be nice to have a chart (like on the Flight Cheetah, for the few of you who might have flown with it). Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Date: Apr 26, 2012
Jesse, I also bought the stratus and love the way it works with ForeFlight . When you go to winds under airport info you get winds aloft in a numerical display. I do hope they will add lightning strike but xm only shows air to ground strikes. I currently have xm on a 496 so going to the ipad was such an improvement in display. The GPs accuracy on the stratus is phenomenal. I never saw more than a 2 meter accuracy. I can't receive the info on the ground at my home airport and use my wifi(internet) connection to get the weather before takeoff. At about 2000 feet I get ADS-B . I'll experiment some more this weekend but my initial impression is favorable. Alan N668G From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Thursday, April 26, 2012 4:11 PM Subject: RV10-List: Foreflight with Stratus Review I received my Stratus unit from Sporty's the other day and wanted to give a report on my impressions for the group. I know there is a lot of debate over which app is best for the iPad, especially with the new Garmin app released at Sun-N-Fun, but I'm going to try not to get into that beyond this statement. I have used Foreflight since version 1 or 2 and have only tried WingX a little. Because I am used to Foreflight and the navigation and functionality, I have not liked my experiences with WingX, but as has been said before, we like what we are used to. I use Foreflight for all of my flight planning (I usually use www.weathermeister.com for keeping up with the weather for my trip, but use Foreflight for all actually route planning, flight plan filing, and charts and plates while flying). I have Foreflight on my iPad 2 Wifi and iPhone 4. I have used a bluetooth GPS that required jailbreaking the iPad, but when that broke (left it on the glarshield in the Florida sun for 3-4 hours one day and the battery swelled and broke the case), I bought the Bad Elf. I wasn't very happy with the Bad Elf because I didn't like having it attached to the iPad in use, especially when bouncing around in IMC. I almost pulled the trigger on the new iPad, in which case I would have bought the 4G version, but when I didn't get the call from MacMall on the day they were starting to ship (like they promised they would), I didn't follow through with the purchase. I was walking through the hangars at Sun-N-Fun and saw the Stratus on the first day. After a short talk with a friend of mine, we decided to buy it. We had both been saying that as soon as there was a portable ADS-B box that worked with Foreflight, we would get it. We split the cost and ordered it as well as the external antenna (which we haven't received yet). We mainly wanted ADS-B for weather, because we were almost to the point of getting the unit that would get XM weather onto the iPad, but liked the thought of no subscription better. We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida through a lot of IMC, but it was a couple of days too early for the Stratus. That would be the real test, especially because of the ADS-B service areas and all of the local radar activity. Unfortunately, the screen shots I have now are shots with no rain within 250nm or more of where I was flying, and not a cloud in the sky, but I will share some of them anyway. Now, for my experience with the Stratus. YMMV, but this is my thought after my short time using it. For the cost, I think it's about as cheap as any ADS-B unit that I have seen, and I figured it would cost about the same as a year work of activation and subscription to XM with the better plan, not counting the XM hardware. As far as what coverage is available through ADS-B, I was pleasantly surprised to find out today that winds aloft are actually available. There are no lightning strikes or Echo Tops, but METARSs, TAFs, NOTAMs, Winds Aloft, Radar (high resolution regional and low resolution nationwide) and PIREPs are all available (among a few other things that I usually don't spend much time with). Personally I really like flying with Echo Tops in the -10 because it usually accurately lets me know if I will be able to get over the tops or will have to go through. Lightning would be nice to have, but usually avoiding the red nexrad (which is a good idea) will keep you away from most strikes (which is a very good idea), in my experience. I will miss those two features, but the most important features for me are METARs, TAFs and Radar. We took off from X35 with the Stratus on the glare shield of the RV-10 and watched the LED's on the unit as well as the indication in Foreflight of when we got a signal. We got the signal at about 5-600 feet AGL. Remember that we are in central Florida, so the ADS-B coverage here is very good. We had as many as 9 stations at a time in our short flight up to 5,500 feet MSL. I really like the Status page (see attached pictures) that gives you the information on the Stratus. It shows the connectivity, battery status, power source, etc and then gives information on what data has been downloaded and how long ago. It also shows the grid of satellites that the unit is receiving location from and how good the signal is. The accuracy of location, including GPS altitude, is the best I have seen among the bluetooth GPS, Bad Elf, onboard GPS and the Stratus, with Accuracy usually 1-2m. As you can see from the pictures attached, and as I have already mentioned, the weather here was way too good to get great pictures as to the usefulness of the Stratus, but it's the best I can offer so far. I usually just keep up the map screen with the Radar and Flight Rules shown. For information on a specific airport, you can just tap on the dot and it will pull up the Metar (and TAF and Winds Aloft if available). If you scroll down on the pop-up, you can see the METARs of other local airports, as well as how old the report is. We must have been getting some medium and/or high altitude ADS-B stations, because we were getting national CONUS Radar as well as a good range of METARs, PIREPs, etc. If you zoom out on the map, only the bigger airport Flight Rules show up. If you zoom in, it shows everywhere that reports. It will also paint the surface winds, cielings, temperature, dew point spread, cloud cover, etc. the same way that it does the Flight Rules, but this display is my favorite for overall information. It will only show one of these at a time, as well as Radar at the same time. It will also show TFR's on the map for those who aren't flying "in the system". My overall impression is very good. I am looking forward to taking a trip outside the normally shown coverage area, especially after I get the external antenna, so I can see how accurate the coverage maps are in the 10-18,000 foot range. One nice thing is that if you are going through a relatively small area of weak coverage, the information stays on the iPad. It just doesn't update, so you still should have information, which will start updating as soon as you get back within coverage. The battery on the Stratus has been quite impressive so far. It comes with a USB cable for charging, as well as an AC adapter, but in a 45 minute flight the battery was still in the 90%'s. It seemed to stay put really well on the glare shield and it is low profile, so it doesn't get in my way at all for flying. Can it replace XM? In my opinion, for a great deal of my flying, yes, mainly because of where I live and where and how I fly. I much prefer the screen size of the iPad to the Garmin Aera, and I like the interface much better than the Aera. As an all-in-one unit for flight planning, preflight weather, enroute charts, plates, enroute weather (with the Stratus), I haven't used anything I think would work better (especially for moving from plane to plane) than the iPad, Foreflight and the Stratus. It is not for everybody, but for those within the coverage area, who move from plane to plane, who don't want to have the monthly subscription, I highly recommend it based on my experience so far. I'll try to post again after I have taken it on a longer trip through some IMC. One thing I would really like to see in Foreflight would be a Winds Aloft display on the map, like with most XM products. They have surface winds at airports, which helps, but picking an altitude with Winds Aloft information would help. It does calculate Time Enroute and overall wind effect for your route in the route planner, so I guess you could pick different altitudes and see which one would be fastest, but it would be nice to have a chart (like on the Flight Cheetah, for the few of you who might have flown with it). Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: Re: Foreflight with Stratus Review
Date: Apr 27, 2012
Thanks Jesse. I just wanted to piggyback on your comments with an iPad obse rvation. Having owned all three (1, 2 & New) I really like the reduced cost of the iPad 2 3G. Don't get me wrong the New iPad is nice with 4G and the retina screen but it does get hotter that it's predecessors for sure and th e minor weight difference is noticeable. The New is definitely an improvem ent in screen and speed but the iPad 2 seems to do it all quite well and wi th a minimum $100 savings. I say minimum because you can only get the 2 in a 16GB unit. When you buy the New iPad you may be temped to get the 32 or 6 4GB as I did for a mere $829.00 before mandatory cover. So $529.00 vs. $829 .00. I know Tim O would chime in with the need for extra storage but I have done everything I needed wo going over my 16 GB with a little memory manag ement. So my 2 (can't find the cents key on my iPad) are you have a choice between good and better. You can't lose. Robin Sent from the new iPad On Apr 26, 2012, at 7:33 PM, "Jesse Saint" wrote: > I received my Stratus unit from Sporty's the other day and wanted to give a report on my impressions for the group. I know there is a lot of debate over which app is best for the iPad, especially with the new Garmin app rel eased at Sun-N-Fun, but I'm going to try not to get into that beyond this s tatement. I have used Foreflight since version 1 or 2 and have only tried W ingX a little. Because I am used to Foreflight and the navigation and funct ionality, I have not liked my experiences with WingX, but as has been said before, we like what we are used to. I use Foreflight for all of my flight planning (I usually use www.weathermeister.com<http://www.weathermeister.co m> for keeping up with the weather for my trip, but use Foreflight for all actually route planning, flight plan filing, and charts and plates while fl ying). I have Foreflight on my iPad 2 Wifi and iPhone 4. I have used a blue tooth GPS that required jailbreaking the iPad, but when that broke (left it on the glarshield in the Florida sun for 3-4 hours one day and the battery swelled and broke the case), I bought the Bad Elf. I wasn't very happy wit h the Bad Elf because I didn't like having it attached to the iPad in use, especially when bouncing around in IMC. I almost pulled the trigger on the new iPad, in which case I would have bought the 4G version, but when I didn 't get the call from MacMall on the day they were starting to ship (like th ey promised they would), I didn't follow through with the purchase. > > I was walking through the hangars at Sun-N-Fun and saw the Stratus on the first day. After a short talk with a friend of mine, we decided to buy it. We had both been saying that as soon as there was a portable ADS-B box tha t worked with Foreflight, we would get it. We split the cost and ordered it as well as the external antenna (which we haven't received yet). We mainly wanted ADS-B for weather, because we were almost to the point of getting t he unit that would get XM weather onto the iPad, but liked the thought of n o subscription better. > > We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida thro ugh a lot of IMC, but it was a couple of days too early for the Stratus. Th at would be the real test, especially because of the ADS-B service areas an d all of the local radar activity. Unfortunately, the screen shots I have n ow are shots with no rain within 250nm or more of where I was flying, and n ot a cloud in the sky, but I will share some of them anyway. > > Now, for my experience with the Stratus. YMMV, but this is my thought aft er my short time using it. > > For the cost, I think it's about as cheap as any ADS-B unit that I have s een, and I figured it would cost about the same as a year work of activatio n and subscription to XM with the better plan, not counting the XM hardware . > > As far as what coverage is available through ADS-B, I was pleasantly surp rised to find out today that winds aloft are actually available. There are no lightning strikes or Echo Tops, but METARSs, TAFs, NOTAMs, Winds Aloft, Radar (high resolution regional and low resolution nationwide) and PIREPs a re all available (among a few other things that I usually don't spend much time with). Personally I really like flying with Echo Tops in the -10 becau se it usually accurately lets me know if I will be able to get over the top s or will have to go through. Lightning would be nice to have, but usually avoiding the red nexrad (which is a good idea) will keep you away from most strikes (which is a very good idea), in my experience. I will miss those t wo features, but the most important features for me are METARs, TAFs and Ra dar. > > We took off from X35 with the Stratus on the glare shield of the RV-10 an d watched the LED's on the unit as well as the indication in Foreflight of when we got a signal. We got the signal at about 5-600 feet AGL. Remember t hat we are in central Florida, so the ADS-B coverage here is very good. We had as many as 9 stations at a time in our short flight up to 5,500 feet MS L. I really like the Status page (see attached pictures) that gives you the information on the Stratus. It shows the connectivity, battery status, pow er source, etc and then gives information on what data has been downloaded and how long ago. It also shows the grid of satellites that the unit is rec eiving location from and how good the signal is. The accuracy of location, including GPS altitude, is the best I have seen among the bluetooth GPS, Ba d Elf, onboard GPS and the Stratus, with Accuracy usually 1-2m. > > As you can see from the pictures attached, and as I have already mentione d, the weather here was way too good to get great pictures as to the useful ness of the Stratus, but it's the best I can offer so far. I usually just k eep up the map screen with the Radar and Flight Rules shown. For informatio n on a specific airport, you can just tap on the dot and it will pull up th e Metar (and TAF and Winds Aloft if available). If you scroll down on the p op-up, you can see the METARs of other local airports, as well as how old t he report is. We must have been getting some medium and/or high altitude AD S-B stations, because we were getting national CONUS Radar as well as a goo d range of METARs, PIREPs, etc. > > If you zoom out on the map, only the bigger airport Flight Rules show up. If you zoom in, it shows everywhere that reports. It will also paint the s urface winds, cielings, temperature, dew point spread, cloud cover, etc. th e same way that it does the Flight Rules, but this display is my favorite f or overall information. It will only show one of these at a time, as well a s Radar at the same time. It will also show TFR's on the map for those who aren't flying "in the system". > > My overall impression is very good. I am looking forward to taking a trip outside the normally shown coverage area, especially after I get the exter nal antenna, so I can see how accurate the coverage maps are in the 10-18,0 00 foot range. One nice thing is that if you are going through a relatively small area of weak coverage, the information stays on the iPad. It just do esn't update, so you still should have information, which will start updati ng as soon as you get back within coverage. > > The battery on the Stratus has been quite impressive so far. It comes wit h a USB cable for charging, as well as an AC adapter, but in a 45 minute fl ight the battery was still in the 90%'s. It seemed to stay put really well on the glare shield and it is low profile, so it doesn't get in my way at a ll for flying. > > Can it replace XM? In my opinion, for a great deal of my flying, yes, mai nly because of where I live and where and how I fly. I much prefer the scre en size of the iPad to the Garmin Aera, and I like the interface much bette r than the Aera. As an all-in-one unit for flight planning, preflight weath er, enroute charts, plates, enroute weather (with the Stratus), I haven't u sed anything I think would work better (especially for moving from plane to plane) than the iPad, Foreflight and the Stratus. It is not for everybody, but for those within the coverage area, who move from plane to plane, who don't want to have the monthly subscription, I highly recommend it based on my experience so far. I'll try to post again after I have taken it on a lo nger trip through some IMC. > > One thing I would really like to see in Foreflight would be a Winds Aloft display on the map, like with most XM products. They have surface winds at airports, which helps, but picking an altitude with Winds Aloft informatio n would help. It does calculate Time Enroute and overall wind effect for yo ur route in the route planner, so I guess you could pick different altitude s and see which one would be fastest, but it would be nice to have a chart (like on the Flight Cheetah, for the few of you who might have flown with i t). > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > [cid:86CE3124-CB81-4E76-BAA4-55CB22DB8E23] > [cid:3D4F42E2-F601-45DD-ADB8-DC3D6AC161C6] > [cid:324708F2-838B-4D6C-9A35-D0A8BDA208CD] > [cid:F789AB5F-23F9-4C2B-9877-7374F493E0B7] > [cid:643C74C0-5044-408E-8B40-837BBCEB0512] > [cid:EB19C300-84D9-4272-9B36-FEC0D1C03A33] > > > > > > ________________________________________________________________________________
Date: Apr 27, 2012
Thanks for the comments on the 3 different iPads. I will comment on the 16GB version, which I have in the iPad 2. I do wish I had the 32GB version. That is probably one of the main reasons I have not used WingX much. I was given a subscription to the charts for a year, but because I can't download all of the charts for both Foreflight and WingX (I usually try to keep most or all of the US charts downloaded on Foreflight all the time, even though I very seldom fly out West) as well as keep my other apps on the iPad. I do use the iPad for a lot more than just flying, so if you are just flying, then 16GB should be plenty, but if you want to have movies, audio, lots of apps, etc on the iPad as well as Foreflight (uses a lot more storage than WingX), then you might want to look at 32GB. Just my 2 cents (can't find the cents key on my Macbook). Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Apr 26, 2012, at 10:10 PM, Robin Marks wrote: > Thanks Jesse. I just wanted to piggyback on your comments with an iPad observation. Having owned all three (1, 2 & New) I really like the reduced cost of the iPad 2 3G. Don't get me wrong the New iPad is nice with 4G and the retina screen but it does get hotter that it's predecessors for sure and the minor weight difference is noticeable. The New is definitely an improvement in screen and speed but the iPad 2 seems to do it all quite well and with a minimum $100 savings. I say minimum because you can only get the 2 in a 16GB unit. When you buy the New iPad you may be temped to get the 32 or 64GB as I did for a mere $829.00 before mandatory cover. So $529.00 vs. $829.00. I know Tim O would chime in with the need for extra storage but I have done everything I needed wo going over my 16 GB with a little memory management. > So my 2 (can't find the cents key on my iPad) are you have a choice between good and better. You can't lose. > > Robin > Sent from the new iPad > > On Apr 26, 2012, at 7:33 PM, "Jesse Saint" wrote: > >> I received my Stratus unit from Sporty's the other day and wanted to give a report on my impressions for the group. I know there is a lot of debate over which app is best for the iPad, especially with the new Garmin app released at Sun-N-Fun, but I'm going to try not to get into that beyond this statement. I have used Foreflight since version 1 or 2 and have only tried WingX a little. Because I am used to Foreflight and the navigation and functionality, I have not liked my experiences with WingX, but as has been said before, we like what we are used to. I use Foreflight for all of my flight planning (I usually use www.weathermeister.com<http://www.weathermeister.com> for keeping up with the weather for my trip, but use Foreflight for all actually route planning, flight plan filing, and charts and plates while flying). I have Foreflight on my iPad 2 Wifi and iPhone 4. I have used a bluetooth GPS that required jailbreaking the iPad, but when that broke (left it on the glarshield in the Florida sun for 3-4 hours one day and the battery swelled and broke the case), I bought the Bad Elf. I wasn't very happy with the Bad Elf because I didn't like having it attached to the iPad in use, especially when bouncing around in IMC. I almost pulled the trigger on the new iPad, in which case I would have bought the 4G version, but when I didn't get the call from MacMall on the day they were starting to ship (like they promised they would), I didn't follow through with the purchase. >> >> I was walking through the hangars at Sun-N-Fun and saw the Stratus on the first day. After a short talk with a friend of mine, we decided to buy it. We had both been saying that as soon as there was a portable ADS-B box that worked with Foreflight, we would get it. We split the cost and ordered it as well as the external antenna (which we haven't received yet). We mainly wanted ADS-B for weather, because we were almost to the point of getting the unit that would get XM weather onto the iPad, but liked the thought of no subscription better. >> >> We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida through a lot of IMC, but it was a couple of days too early for the Stratus. That would be the real test, especially because of the ADS-B service areas and all of the local radar activity. Unfortunately, the screen shots I have now are shots with no rain within 250nm or more of where I was flying, and not a cloud in the sky, but I will share some of them anyway. >> >> Now, for my experience with the Stratus. YMMV, but this is my thought after my short time using it. >> >> For the cost, I think it's about as cheap as any ADS-B unit that I have seen, and I figured it would cost about the same as a year work of activation and subscription to XM with the better plan, not counting the XM hardware. >> >> As far as what coverage is available through ADS-B, I was pleasantly surprised to find out today that winds aloft are actually available. There are no lightning strikes or Echo Tops, but METARSs, TAFs, NOTAMs, Winds Aloft, Radar (high resolution regional and low resolution nationwide) and PIREPs are all available (among a few other things that I usually don't spend much time with). Personally I really like flying with Echo Tops in the -10 because it usually accurately lets me know if I will be able to get over the tops or will have to go through. Lightning would be nice to have, but usually avoiding the red nexrad (which is a good idea) will keep you away from most strikes (which is a very good idea), in my experience. I will miss those two features, but the most important features for me are METARs, TAFs and Radar. >> >> We took off from X35 with the Stratus on the glare shield of the RV-10 and watched the LED's on the unit as well as the indication in Foreflight of when we got a signal. We got the signal at about 5-600 feet AGL. Remember that we are in central Florida, so the ADS-B coverage here is very good. We had as many as 9 stations at a time in our short flight up to 5,500 feet MSL. I really like the Status page (see attached pictures) that gives you the information on the Stratus. It shows the connectivity, battery status, power source, etc and then gives information on what data has been downloaded and how long ago. It also shows the grid of satellites that the unit is receiving location from and how good the signal is. The accuracy of location, including GPS altitude, is the best I have seen among the bluetooth GPS, Bad Elf, onboard GPS and the Stratus, with Accuracy usually 1-2m. >> >> As you can see from the pictures attached, and as I have already mentioned, the weather here was way too good to get great pictures as to the usefulness of the Stratus, but it's the best I can offer so far. I usually just keep up the map screen with the Radar and Flight Rules shown. For information on a specific airport, you can just tap on the dot and it will pull up the Metar (and TAF and Winds Aloft if available). If you scroll down on the pop-up, you can see the METARs of other local airports, as well as how old the report is. We must have been getting some medium and/or high altitude ADS-B stations, because we were getting national CONUS Radar as well as a good range of METARs, PIREPs, etc. >> >> If you zoom out on the map, only the bigger airport Flight Rules show up. If you zoom in, it shows everywhere that reports. It will also paint the surface winds, cielings, temperature, dew point spread, cloud cover, etc. the same way that it does the Flight Rules, but this display is my favorite for overall information. It will only show one of these at a time, as well as Radar at the same time. It will also show TFR's on the map for those who aren't flying "in the system". >> >> My overall impression is very good. I am looking forward to taking a trip outside the normally shown coverage area, especially after I get the external antenna, so I can see how accurate the coverage maps are in the 10-18,000 foot range. One nice thing is that if you are going through a relatively small area of weak coverage, the information stays on the iPad. It just doesn't update, so you still should have information, which will start updating as soon as you get back within coverage. >> >> The battery on the Stratus has been quite impressive so far. It comes with a USB cable for charging, as well as an AC adapter, but in a 45 minute flight the battery was still in the 90%'s. It seemed to stay put really well on the glare shield and it is low profile, so it doesn't get in my way at all for flying. >> >> Can it replace XM? In my opinion, for a great deal of my flying, yes, mainly because of where I live and where and how I fly. I much prefer the screen size of the iPad to the Garmin Aera, and I like the interface much better than the Aera. As an all-in-one unit for flight planning, preflight weather, enroute charts, plates, enroute weather (with the Stratus), I haven't used anything I think would work better (especially for moving from plane to plane) than the iPad, Foreflight and the Stratus. It is not for everybody, but for those within the coverage area, who move from plane to plane, who don't want to have the monthly subscription, I highly recommend it based on my experience so far. I'll try to post again after I have taken it on a longer trip through some IMC. >> >> One thing I would really like to see in Foreflight would be a Winds Aloft display on the map, like with most XM products. They have surface winds at airports, which helps, but picking an altitude with Winds Aloft information would help. It does calculate Time Enroute and overall wind effect for your route in the route planner, so I guess you could pick different altitudes and see which one would be fastest, but it would be nice to have a chart (like on the Flight Cheetah, for the few of you who might have flown with it). >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> [cid:86CE3124-CB81-4E76-BAA4-55CB22DB8E23] >> [cid:3D4F42E2-F601-45DD-ADB8-DC3D6AC161C6] >> [cid:324708F2-838B-4D6C-9A35-D0A8BDA208CD] >> [cid:F789AB5F-23F9-4C2B-9877-7374F493E0B7] >> [cid:643C74C0-5044-408E-8B40-837BBCEB0512] >> [cid:EB19C300-84D9-4272-9B36-FEC0D1C03A33] >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 27, 2012
And I use my iPad with both Foreflight and WingX (and I had skycharts on there long ago too but never use it anymore). I also use mine for work (remote access) a bunch, and it's also an entertainment device on vacations....movies mostly. So for me, 32Gb would be a minimum, and 64Gb is do-able. In fact, my biggest complaint about the iPhone and iPad is that I wish each had one model higher in capacity. I could really use 64Gb on my iPhone, and I'd love a 128Gb iPad. It's the primary reason I didn't buy an iPhone 4S and "New" iPad...had they increased the capacity I'd have bought one the first day. So Robin is right....you can really save money and if you only want to use it for flying and some minor things, a 16Gb model would work but we aware that you will only be able to have one major app on there for flight software, most likely. I'd *always* recommend the 3G/4G models because even when just in the car the built-in GPS is worth the extra, if you use it for any navigation or mapping. (I keep a road GPS app on there too, with all US coverage) So for many non-entertainment users, 32Gb would be a logical happy medium. If you have kids though, spring for the biggest one you can find. We loaded all of our iPads and iPhones up with movies and entertainment for our last trip and it was nice to have. Tim On 4/27/2012 7:23 AM, Jesse Saint wrote: > --> RV10-List message posted by: Jesse Saint > > Thanks for the comments on the 3 different iPads. I will comment on the 16GB version, which I have in the iPad 2. I do wish I had the 32GB version. That is probably one of the main reasons I have not used WingX much. I was given a subscription to the charts for a year, but because I can't download all of the charts for both Foreflight and WingX (I usually try to keep most or all of the US charts downloaded on Foreflight all the time, even though I very seldom fly out West) as well as keep my other apps on the iPad. I do use the iPad for a lot more than just flying, so if you are just flying, then 16GB should be plenty, but if you want to have movies, audio, lots of apps, etc on the iPad as well as Foreflight (uses a lot more storage than WingX), then you might want to look at 32GB. Just my 2 cents (can't find the cents key on my Macbook). > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Apr 26, 2012, at 10:10 PM, Robin Marks wrote: > >> Thanks Jesse. I just wanted to piggyback on your comments with an iPad observation. Having owned all three (1, 2& New) I really like the reduced cost of the iPad 2 3G. Don't get me wrong the New iPad is nice with 4G and the retina screen but it does get hotter that it's predecessors for sure and the minor weight difference is noticeable. The New is definitely an improvement in screen and speed but the iPad 2 seems to do it all quite well and with a minimum $100 savings. I say minimum because you can only get the 2 in a 16GB unit. When you buy the New iPad you may be temped to get the 32 or 64GB as I did for a mere $829.00 before mandatory cover. So $529.00 vs. $829.00. I know Tim O would chime in with the need for extra storage but I have done everything I needed wo going over my 16 GB with a little memory management. >> So my 2 (can't find the cents key on my iPad) are you have a choice between good and better. You can't lose. >> >> Robin >> Sent from the new iPad >> >> On Apr 26, 2012, at 7:33 PM, "Jesse Saint" wrote: >> >>> I received my Stratus unit from Sporty's the other day and wanted to give a report on my impressions for the group. I know there is a lot of debate over which app is best for the iPad, especially with the new Garmin app released at Sun-N-Fun, but I'm going to try not to get into that beyond this statement. I have used Foreflight since version 1 or 2 and have only tried WingX a little. Because I am used to Foreflight and the navigation and functionality, I have not liked my experiences with WingX, but as has been said before, we like what we are used to. I use Foreflight for all of my flight planning (I usually use www.weathermeister.com<http://www.weathermeister.com> for keeping up with the weather for my trip, but use Foreflight for all actually route planning, flight plan filing, and charts and plates while flying). I have Foreflight on my iPad 2 Wifi and iPhone 4. I have used a bluetooth GPS that required jailbreaking the iPad, but when that broke (left it on the gla! rs! > hield in the Florida sun for 3-4 hours one day and the battery swelled and broke the case), I bought the Bad Elf. I wasn't very happy with the Bad Elf because I didn't like having it attached to the iPad in use, especially when bouncing around in IMC. I almost pulled the trigger on the new iPad, in which case I would have bought the 4G version, but when I didn't get the call from MacMall on the day they were starting to ship (like they promised they would), I didn't follow through with the purchase. >>> >>> I was walking through the hangars at Sun-N-Fun and saw the Stratus on the first day. After a short talk with a friend of mine, we decided to buy it. We had both been saying that as soon as there was a portable ADS-B box that worked with Foreflight, we would get it. We split the cost and ordered it as well as the external antenna (which we haven't received yet). We mainly wanted ADS-B for weather, because we were almost to the point of getting the unit that would get XM weather onto the iPad, but liked the thought of no subscription better. >>> >>> We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida through a lot of IMC, but it was a couple of days too early for the Stratus. That would be the real test, especially because of the ADS-B service areas and all of the local radar activity. Unfortunately, the screen shots I have now are shots with no rain within 250nm or more of where I was flying, and not a cloud in the sky, but I will share some of them anyway. >>> >>> Now, for my experience with the Stratus. YMMV, but this is my thought after my short time using it. >>> >>> For the cost, I think it's about as cheap as any ADS-B unit that I have seen, and I figured it would cost about the same as a year work of activation and subscription to XM with the better plan, not counting the XM hardware. >>> >>> As far as what coverage is available through ADS-B, I was pleasantly surprised to find out today that winds aloft are actually available. There are no lightning strikes or Echo Tops, but METARSs, TAFs, NOTAMs, Winds Aloft, Radar (high resolution regional and low resolution nationwide) and PIREPs are all available (among a few other things that I usually don't spend much time with). Personally I really like flying with Echo Tops in the -10 because it usually accurately lets me know if I will be able to get over the tops or will have to go through. Lightning would be nice to have, but usually avoiding the red nexrad (which is a good idea) will keep you away from most strikes (which is a very good idea), in my experience. I will miss those two features, but the most important features for me are METARs, TAFs and Radar. >>> >>> We took off from X35 with the Stratus on the glare shield of the RV-10 and watched the LED's on the unit as well as the indication in Foreflight of when we got a signal. We got the signal at about 5-600 feet AGL. Remember that we are in central Florida, so the ADS-B coverage here is very good. We had as many as 9 stations at a time in our short flight up to 5,500 feet MSL. I really like the Status page (see attached pictures) that gives you the information on the Stratus. It shows the connectivity, battery status, power source, etc and then gives information on what data has been downloaded and how long ago. It also shows the grid of satellites that the unit is receiving location from and how good the signal is. The accuracy of location, including GPS altitude, is the best I have seen among the bluetooth GPS, Bad Elf, onboard GPS and the Stratus, with Accuracy usually 1-2m. >>> >>> As you can see from the pictures attached, and as I have already mentioned, the weather here was way too good to get great pictures as to the usefulness of the Stratus, but it's the best I can offer so far. I usually just keep up the map screen with the Radar and Flight Rules shown. For information on a specific airport, you can just tap on the dot and it will pull up the Metar (and TAF and Winds Aloft if available). If you scroll down on the pop-up, you can see the METARs of other local airports, as well as how old the report is. We must have been getting some medium and/or high altitude ADS-B stations, because we were getting national CONUS Radar as well as a good range of METARs, PIREPs, etc. >>> >>> If you zoom out on the map, only the bigger airport Flight Rules show up. If you zoom in, it shows everywhere that reports. It will also paint the surface winds, cielings, temperature, dew point spread, cloud cover, etc. the same way that it does the Flight Rules, but this display is my favorite for overall information. It will only show one of these at a time, as well as Radar at the same time. It will also show TFR's on the map for those who aren't flying "in the system". >>> >>> My overall impression is very good. I am looking forward to taking a trip outside the normally shown coverage area, especially after I get the external antenna, so I can see how accurate the coverage maps are in the 10-18,000 foot range. One nice thing is that if you are going through a relatively small area of weak coverage, the information stays on the iPad. It just doesn't update, so you still should have information, which will start updating as soon as you get back within coverage. >>> >>> The battery on the Stratus has been quite impressive so far. It comes with a USB cable for charging, as well as an AC adapter, but in a 45 minute flight the battery was still in the 90%'s. It seemed to stay put really well on the glare shield and it is low profile, so it doesn't get in my way at all for flying. >>> >>> Can it replace XM? In my opinion, for a great deal of my flying, yes, mainly because of where I live and where and how I fly. I much prefer the screen size of the iPad to the Garmin Aera, and I like the interface much better than the Aera. As an all-in-one unit for flight planning, preflight weather, enroute charts, plates, enroute weather (with the Stratus), I haven't used anything I think would work better (especially for moving from plane to plane) than the iPad, Foreflight and the Stratus. It is not for everybody, but for those within the coverage area, who move from plane to plane, who don't want to have the monthly subscription, I highly recommend it based on my experience so far. I'll try to post again after I have taken it on a longer trip through some IMC. >>> >>> One thing I would really like to see in Foreflight would be a Winds Aloft display on the map, like with most XM products. They have surface winds at airports, which helps, but picking an altitude with Winds Aloft information would help. It does calculate Time Enroute and overall wind effect for your route in the route planner, so I guess you could pick different altitudes and see which one would be fastest, but it would be nice to have a chart (like on the Flight Cheetah, for the few of you who might have flown with it). >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> jesse(at)saintaviation.com >>> C: 352-427-0285 >>> F: 815-377-3694 ________________________________________________________________________________
Date: Apr 27, 2012
Subject: Building and my knees - the last leg (long & personal)
Having just returned from my doctor's office with a relatively clean bill of health, I thought I'd share the story of my knees. Background; I've had bad knees since adolescence. The initial diagnosis was something called "Osgood-Schlatter Disease" while in junior high. I was threatened with an immobilizing cast on the left knee if I didn't RICE it (Rest, Ice, Compression and Elevation). Training to become a tackling dummy, I stressed them in the weight room and never made it to summer practice in high school. So instead I swam, played volleyball, jogged and RICEd the knees as required. Thirty-some years later, I started building the '10. The knees had aged gracefully. Naproxen was always effective and recently became cheap (Alleve). However, a scan some years ago had shown that I had tears in the menisci and that surgery would be required at some point. Carpet or rubber pads on the floor kept the pain and swelling down for the most part. Otherwise it was a comfortable build since I was lucky enough to have my workshop/hangar 200 yards out back along with a Maule to fly while maintaining a steady but leisurely building pace. The '10 was getting close to flight. Painting started in late 2010 and I actually had a schedule laid out for completing the paint and doing the final assembly. I also decided to get arthroscopic surgery on both knees following final assembly. Yes, I was 99% done, 99% to go, or however that saying goes. I first discovered that you can't paint in the winter so the schedule started to fall apart. When spring returned, the painting was completed and only final assembly remained. The plan was to take the project to another airport with a hard surface runway and friendlier terrain for the initial flights. The challenge was to find some hangar space at a nearby airport where the project could be completed. It worked out better than I could have expected. The airport manager at the nearest airport graciously agreed to let me do the assembly in his main hangar. It had a painted floor, great lighting, friendly dogs, and a mechanic who freely shared his tools and expertise. The '10 was trucked in and assembly began. However, when the painting was halted for winter, I stayed with the schedule for bilateral arthroscopic knee surgery. Recovery hurt, but throughout, the medical team encouraged movement and use of the knees. When asked, "can I resume normal activities?" The answer was always a qualified "yes, as much as you can do comfortably". They have no idea how motivated a homebuilder is, especially on the eve of flight. And I had no idea how much harder I would work now that I was away from home and in borrowed space. Once the final assembly began my days started at sunrise when I had the privilege of jumping in the Maule with a couple of tool boxes and flying to my temporary workshop. The airport manager/mechanic worked 8 hours/day, 7 days/week so I did too. Standing, walking, stooping all put stress on my recently cleaned up knees. There was pain so I RICEd them when I could. However, the bar on "what I could do comfortably" had risen. At post-operative checkups, I told the doctor of the pain and he could see the swelling. We tried cortisone shots to see if we could get back on the curve towards recovery. Things would get a little better before getting worse again. The '10 was looking fantastic! Wings on, seats in, wiring completed... each step more exciting. Commuting by Maule each day was some of the best flying I had done since starting the project. With summer temps, I removed the door on the Maule for some open cockpit fun. But as you can imagine, the final assembly took 2 or 3 times longer than expected though it was moving forward without a hitch. That is, except for the fact that I could barely step up into the Maule and was otherwise severely hobbled. The fact that my airport host crunched around all day, without complaint, on an artificial leg probably spurred me on even further. Though every time he dropped to his knee with a sound only titanium on concrete can make, it did get my attention. First flight and the RV grin; it was better than I could have imagined and it just keeps getting better. The '10 is a fantastic aircraft!! Really!!! Yes, I'm very proud of having built it but the real kudos go to Vans for the design and the (quick build) kit. The build was fun, the flying even better! Anyway, four months after first flight and one year after surgery, I was still hobbled and in pain. The doctor went from dismissal to concern and we decided to do an MRI. I knew my knees were bad but it didn't sink until I realized that the doctor and his team were a bit shocked and surprised by what they saw. My left knee in particular looked worse than before the surgery. It was all rough surfaces with several pieces of stuff floating around. So, we re-did the surgery on the left knee. This time I RICEd them more aggressively as I balanced the injectors on the '540. Five months after the second surgery, I seem to be on a path to recovery. Earlier today, my doctor finally smiled and with some relief "released" me. I admitted that I knew I was abusing my knees after the first surgery but continued nonetheless. He admitted to having made the mistake of relying on a patient's tendency to self-limit their activities based on the pain. It appears that the challenge with most patients is to keep them moving to maintain flexibility and strength. With a motivated '10 builder, the challenge was to get me to slow down and treat my health with the respect it required. Screwing up my knees is the ONLY regret I have with the experience, but it was worth it anyway. Bill "hoping this story is of some value to someone" Watson http://www.mykitlog.com/mauledriver N215TG 40605 ________________________________________________________________________________
Subject: Re: Building and my knees - the last leg (long & personal)
Date: Apr 27, 2012
Sorry to hear about your knees Bill. I have one knee pad observation. About a year ago I was stumbling through an army/navy store when I came across the knee and elbow pads our boys wear when in country. The knee pads are the best I have ever seen or used. Very comfortable with both wrap around fabric with Velcro plus upper and lower straps that can be crossed or strung straight. They have a hard knee cap with a padded section above and below the knee cap for added protection. They can be worn for long periods of time comfortably without slipping. And the best part is I paid $10.00 a set. Your tax dollars at work. Robin Bill Watson wrote: Having just returned from my doctor's office with a relatively clean bill of health, I thought I'd share the story of my knees. Background; I've had bad knees since adolescence. The initial diagnosis was something called "Osgood-Schlatter Disease" while in junior high. I was threatened with an immobilizing cast on the left knee if I didn't RICE it (Rest, Ice, Compression and Elevation). Training to become a tackling dummy, I stressed them in the weight room and never made it to summer practice in high school. So instead I swam, played volleyball, jogged and RICEd the knees as required. Thirty-some years later, I started building the '10. The knees had aged gracefully. Naproxen was always effective and recently became cheap (Alleve). However, a scan some years ago had shown that I had tears in the menisci and that surgery would be required at some point. Carpet or rubber pads on the floor kept the pain and swelling down for the most part. Otherwise it was a comfortable build since I was lucky enough to have my workshop/hangar 200 yards out back along with a Maule to fly while maintaining a steady but leisurely building pace. The '10 was getting close to flight. Painting started in late 2010 and I actually had a schedule laid out for completing the paint and doing the final assembly. I also decided to get arthroscopic surgery on both knees following final assembly. Yes, I was 99% done, 99% to go, or however that saying goes. I first discovered that you can't paint in the winter so the schedule started to fall apart. When spring returned, the painting was completed and only final assembly remained. The plan was to take the project to another airport with a hard surface runway and friendlier terrain for the initial flights. The challenge was to find some hangar space at a nearby airport where the project could be completed. It worked out better than I could have expected. The airport manager at the nearest airport graciously agreed to let me do the assembly in his main hangar. It had a painted floor, great lighting, friendly dogs, and a mechanic who freely shared his tools and expertise. The '10 was trucked in and assembly began. However, when the painting was halted for winter, I stayed with the schedule for bilateral arthroscopic knee surgery. Recovery hurt, but throughout, the medical team encouraged movement and use of the knees. When asked, "can I resume normal activities?" The answer was always a qualified "yes, as much as you can do comfortably". They have no idea how motivated a homebuilder is, especially on the eve of flight. And I had no idea how much harder I would work now that I was away from home and in borrowed space. Once the final assembly began my days started at sunrise when I had the privilege of jumping in the Maule with a couple of tool boxes and flying to my temporary workshop. The airport manager/mechanic worked 8 hours/day, 7 days/week so I did too. Standing, walking, stooping all put stress on my recently cleaned up knees. There was pain so I RICEd them when I could. However, the bar on "what I could do comfortably" had risen. At post-operative checkups, I told the doctor of the pain and he could see the swelling. We tried cortisone shots to see if we could get back on the curve towards recovery. Things would get a little better before getting worse again. The '10 was looking fantastic! Wings on, seats in, wiring completed... each step more exciting. Commuting by Maule each day was some of the best flying I had done since starting the project. With summer temps, I removed the door on the Maule for some open cockpit fun. But as you can imagine, the final assembly took 2 or 3 times longer than expected though it was moving forward without a hitch. That is, except for the fact that I could barely step up into the Maule and was otherwise severely hobbled. The fact that my airport host crunched around all day, without complaint, on an artificial leg probably spurred me on even further. Though every time he dropped to his knee with a sound only titanium on concrete can make, it did get my attention. First flight and the RV grin; it was better than I could have imagined and it just keeps getting better. The '10 is a fantastic aircraft!! Really!!! Yes, I'm very proud of having built it but the real kudos go to Vans for the design and the (quick build) kit. The build was fun, the flying even better! Anyway, four months after first flight and one year after surgery, I was still hobbled and in pain. The doctor went from dismissal to concern and we decided to do an MRI. I knew my knees were bad but it didn't sink until I realized that the doctor and his team were a bit shocked and surprised by what they saw. My left knee in particular looked worse than before the surgery. It was all rough surfaces with several pieces of stuff floating around. So, we re-did the surgery on the left knee. This time I RICEd them more aggressively as I balanced the injectors on the '540. Five months after the second surgery, I seem to be on a path to recovery. Earlier today, my doctor finally smiled and with some relief "released" me. I admitted that I knew I was abusing my knees after the first surgery but continued nonetheless. He admitted to having made the mistake of relying on a patient's tendency to self-limit their activities based on the pain. It appears that the challenge with most patients is to keep them moving to maintain flexibility and strength. With a motivated '10 builder, the challenge was to get me to slow down and treat my health with the respect it required. Screwing up my knees is the ONLY regret I have with the experience, but it was worth it anyway. Bill "hoping this story is of some value to someone" Watson http://www.mykitlog.com/mauledriver N215TG 40605 ________________________________________________________________________________
Date: Apr 27, 2012
Subject: Starting the Annual Oshkosh Camping Thread
Thought I'd kick start the yearly OSH camping thread... :) Being a first time OSH camper this year I was curious if arriving the Saturday before the show is enough to get a halfway decent spot. I know the group HQ stake-out is no longer happening, but I'm assuming everyone tries to get in the same area as the HQ has been? Just wondering if the Sat. before is soon enough to get that area. -Sean #40303 ________________________________________________________________________________
Date: Apr 27, 2012
Bill, glad to see you are finally recovering. I've torn the meniscus in both my knees, once in my late teens and once again last year. The one last year I had repaired in January and I'm lucky enough to say that I'm back at 100%. But much like you I over did it in the beginning which lengthened the full recovery. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Friday, April 27, 2012 11:56 AM Subject: RV10-List: Building and my knees - the last leg (long & personal) Having just returned from my doctor's office with a relatively clean bill of health, I thought I'd share the story of my knees. Background; I've had bad knees since adolescence. The initial diagnosis was something called "Osgood-Schlatter Disease" while in junior high. I was threatened with an immobilizing cast on the left knee if I didn't RICE it (Rest, Ice, Compression and Elevation). Training to become a tackling dummy, I stressed them in the weight room and never made it to summer practice in high school. So instead I swam, played volleyball, jogged and RICEd the knees as required. Thirty-some years later, I started building the '10. The knees had aged gracefully. Naproxen was always effective and recently became cheap (Alleve). However, a scan some years ago had shown that I had tears in the menisci and that surgery would be required at some point. Carpet or rubber pads on the floor kept the pain and swelling down for the most part. Otherwise it was a comfortable build since I was lucky enough to have my workshop/hangar 200 yards out back along with a Maule to fly while maintaining a steady but leisurely building pace. The '10 was getting close to flight. Painting started in late 2010 and I actually had a schedule laid out for completing the paint and doing the final assembly. I also decided to get arthroscopic surgery on both knees following final assembly. Yes, I was 99% done, 99% to go, or however that saying goes. I first discovered that you can't paint in the winter so the schedule started to fall apart. When spring returned, the painting was completed and only final assembly remained. The plan was to take the project to another airport with a hard surface runway and friendlier terrain for the initial flights. The challenge was to find some hangar space at a nearby airport where the project could be completed. It worked out better than I could have expected. The airport manager at the nearest airport graciously agreed to let me do the assembly in his main hangar. It had a painted floor, great lighting, friendly dogs, and a mechanic who freely shared his tools and expertise. The '10 was trucked in and assembly began. However, when the painting was halted for winter, I stayed with the schedule for bilateral arthroscopic knee surgery. Recovery hurt, but throughout, the medical team encouraged movement and use of the knees. When asked, "can I resume normal activities?" The answer was always a qualified "yes, as much as you can do comfortably". They have no idea how motivated a homebuilder is, especially on the eve of flight. And I had no idea how much harder I would work now that I was away from home and in borrowed space. Once the final assembly began my days started at sunrise when I had the privilege of jumping in the Maule with a couple of tool boxes and flying to my temporary workshop. The airport manager/mechanic worked 8 hours/day, 7 days/week so I did too. Standing, walking, stooping all put stress on my recently cleaned up knees. There was pain so I RICEd them when I could. However, the bar on "what I could do comfortably" had risen. At post-operative checkups, I told the doctor of the pain and he could see the swelling. We tried cortisone shots to see if we could get back on the curve towards recovery. Things would get a little better before getting worse again. The '10 was looking fantastic! Wings on, seats in, wiring completed... each step more exciting. Commuting by Maule each day was some of the best flying I had done since starting the project. With summer temps, I removed the door on the Maule for some open cockpit fun. But as you can imagine, the final assembly took 2 or 3 times longer than expected though it was moving forward without a hitch. That is, except for the fact that I could barely step up into the Maule and was otherwise severely hobbled. The fact that my airport host crunched around all day, without complaint, on an artificial leg probably spurred me on even further. Though every time he dropped to his knee with a sound only titanium on concrete can make, it did get my attention. First flight and the RV grin; it was better than I could have imagined and it just keeps getting better. The '10 is a fantastic aircraft!! Really!!! Yes, I'm very proud of having built it but the real kudos go to Vans for the design and the (quick build) kit. The build was fun, the flying even better! Anyway, four months after first flight and one year after surgery, I was still hobbled and in pain. The doctor went from dismissal to concern and we decided to do an MRI. I knew my knees were bad but it didn't sink until I realized that the doctor and his team were a bit shocked and surprised by what they saw. My left knee in particular looked worse than before the surgery. It was all rough surfaces with several pieces of stuff floating around. So, we re-did the surgery on the left knee. This time I RICEd them more aggressively as I balanced the injectors on the '540. Five months after the second surgery, I seem to be on a path to recovery. Earlier today, my doctor finally smiled and with some relief "released" me. I admitted that I knew I was abusing my knees after the first surgery but continued nonetheless. He admitted to having made the mistake of relying on a patient's tendency to self-limit their activities based on the pain. It appears that the challenge with most patients is to keep them moving to maintain flexibility and strength. With a motivated '10 builder, the challenge was to get me to slow down and treat my health with the respect it required. Screwing up my knees is the ONLY regret I have with the experience, but it was worth it anyway. Bill "hoping this story is of some value to someone" Watson http://www.mykitlog.com/mauledriver N215TG 40605 ________________________________________________________________________________
Subject: Re: Starting the Annual Oshkosh Camping Thread
Date: Apr 27, 2012
Unfortunately, I think you'll need to show up a week early. The stories I've heard from Tom, Bob, and Gary are that folks are coming earlier ever year. When I've showed in the past on Saturday, most sites around the group area have been taken. But I wouldn't let that stop you from looking. You never know what's available. Sent from my iPhone On Apr 27, 2012, at 2:21 PM, Sean Stephens wrote: Thought I'd kick start the yearly OSH camping thread... :) Being a first time OSH camper this year I was curious if arriving the Saturday before the show is enough to get a halfway decent spot. I know the group HQ stake-out is no longer happening, but I'm assuming everyone tries to get in the same area as the HQ has been? Just wondering if the Sat. before is soon enough to get that area. -Sean #40303 ________________________________________________________________________________
Date: Apr 27, 2012
EAA has made some changes which might alleviate some of the issues hat caused me to "retire" from the group campsite biz. I haven't had time to read/understand them yet so can't say for sure. If I decide to jump back in I'll post something. Bob (Condrey) On Friday, April 27, 2012, Bob Leffler wrote: > > > > Unfortunately, I think you'll need to show up a week early. The stories > I've heard from Tom, Bob, and Gary are that folks are coming earlier ever > year. > > When I've showed in the past on Saturday, most sites around the group area > have been taken. But I wouldn't let that stop you from looking. You > never know what's available. > > Sent from my iPhone > > On Apr 27, 2012, at 2:21 PM, Sean Stephens > > wrote: > > > > > Thought I'd kick start the yearly OSH camping thread... :) > > Being a first time OSH camper this year I was curious if arriving the > Saturday before the show is enough to get a halfway decent spot. I know > the group HQ stake-out is no longer happening, but I'm assuming everyone > tries to get in the same area as the HQ has been? Just wondering if the > Sat. before is soon enough to get that area. > > -Sean #40303 > > ________________________________________________________________________________
Subject: Re: White House user fee petition
Date: Apr 28, 2012
Added one more vote. Progress again after about a year of waffling whether to sell. Mazda 20B installed, exhaust mfld done, intake mfld need final welding next week, then design oil cooler mount and make hoses for oil & water cooling. Only 6 more months, IF I keep my nose to the grindstone !! Phil (busy moving house & plane 3 miles away) White Downers Grove, IL #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372006#372006 Attachments: http://forums.matronics.com//files/intake_manifold_2_sml_205.jpg ________________________________________________________________________________
Subject: Re: Video: Pipistrel Panthera Revealed
Date: Apr 28, 2012
Some of the features that are unique to the rv-10 that might be worth watching; unique cowling cooling outlets left rear seat gull wing door, certainly gives some loading advantages aerodynamic wing tip t-tail ballistic parachute claimed 1000nm range 12% faster cruise with 210 hp 4 cylinder probably designed around the IO390 similarities the gull wings are very similar to rv-10 that I suspect will have the same problems/challenges. surprising load very similar to rv-10 of course all of these are assertions, but impressive if proven true should offer a competitive alternative to the high end SR22 and Corvalis market, not quite as fast, but 40% less fuel burn should make it very attractive offering a kit should hit into the rv-10 market a bit too, pricey, but the quick build will probably be pretty quick with composite parts. cjay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372026#372026 ________________________________________________________________________________
Date: Apr 28, 2012
If you really want some revolutionary claims, check this one out: LP1 http://www.woodward-aerospace.com/lp1.html $200K build cost (similar to rv-10) 334 ktas on 14.5 gph designed around the corvette v8 engine block which makes it faster than a lot of these multi-million $$ turbine/jets at a fraction the cost and fuel burn: Diamond D-Jet 315 ktas 70 gph Epic LT 350 ktas 70 gph Evolution Turbine 320 ktas 40 gph Cessna Mustang 340 ktas 120 gph Piper Meridian 260 ktas 45 gph Propjet DLX 250 ktas 35 gph TBM 850 320 ktas 65 gph Can anyone explain how this is possible if even believable? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372032#372032 ________________________________________________________________________________
Date: Apr 29, 2012
The development photos are quite impressive. The designer is not a pilot which is both refreshing and disturbing all at the same time. I am going to keep my eye on it. Robin Sent from the new iPad On Apr 28, 2012, at 7:53 PM, "cjay" wrote: > > If you really want some revolutionary claims, check this one out: > > LP1 > http://www.woodward-aerospace.com/lp1.html > > $200K build cost (similar to rv-10) > 334 ktas on 14.5 gph > designed around the corvette v8 engine block > > which makes it faster than a lot of these multi-million $$ turbine/jets at a fraction the cost and fuel burn: > Diamond D-Jet 315 ktas 70 gph > Epic LT 350 ktas 70 gph > Evolution Turbine 320 ktas 40 gph > Cessna Mustang 340 ktas 120 gph > Piper Meridian 260 ktas 45 gph > Propjet DLX 250 ktas 35 gph > TBM 850 320 ktas 65 gph > > Can anyone explain how this is possible if even believable? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=372032#372032 > > > > > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Fuel vent modification
Date: Apr 29, 2012
Here is a simple way to keep mud-dabbers from clogging your fuel vent. I think more than one RV has collapsed a fuel tank from a clogged vent. Take a few inches of 3/8=94 aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material. Once the JB Weld is cured, clean up the edge on a ScotchBrite wheel or similar. Do a =BE=94 cut in the other end for a hose clamp, then slide this over the now somewhat shortened standard =BC=94 vent tubing. Have the =BC=94 tubing extend well past where the clamp goes. Carl RV-8A (800 hours) RV-10 (FSDO comes to inspect May 23rd) ________________________________________________________________________________
Date: Apr 29, 2012
A simpler solution; just drill a size 50 hole inside the intersection fairing on the back side of the vent tube. It will also prevent impact ice from sealing a vent. _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Sunday, April 29, 2012 2:54 PM rv-list(at)matronics.com Subject: RV10-List: Fuel vent modification Here is a simple way to keep mud-dabbers from clogging your fuel vent. I think more than one RV has collapsed a fuel tank from a clogged vent. Take a few inches of 3/8=94 aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material. Once the JB Weld is cured, clean up the edge on a ScotchBrite wheel or similar. Do a =BE=94 cut in the other end for a hose clamp, then slide this over the now somewhat shortened standard =BC=94 vent tubing. Have the =BC=94 tubing extend well past where the clamp goes. Carl RV-8A (800 hours) RV-10 (FSDO comes to inspect May 23rd) ________________________________________________________________________________
Date: Apr 29, 2012
From: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com>
Subject: Gretz Pitot Connection Conflict
I have the mount ready to install according to plans but wish now that I would have moved it two bays out. As received, the tube from the head will interfere with the torque tube going to the bell crank. My options seem to be to shorten it or bend it. The aluminum tube running to it will also have to be changed to align with the head tube. I can see a pretty sharp bend being needed if the head tube is shortened and wonder if I will create problems inserting the head into the mount if I bend the head tube. What have others done to solve this problem? This would not be an issue if I had moved the mount out two bays. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings ~~~~~~~~~~~~~~~ ________________________________________________________________________________
Date: Apr 29, 2012
Bill, went through a tear myself, although I was only about 20 and in peak physical condition so it wasn't long before I was back in the game playing soldier. Recovery can put a damper on many things so it is great to see you push through it all. I have worn the knee pads Robin mentioned in country. They are one of the few things the Army got right. Grab a pair and you won't look back. Your knees will thank you. Mine have! Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372106#372106 ________________________________________________________________________________
Subject: Re: Fuel vent modification
Date: Apr 29, 2012
That looks like a great solution, Carl. I have tried to use JB Weld to glue a similar piece of window screen on the existing vent, and it is so small that it is difficult to get the screen to stay in place. It seems to me that the #50 hole on the back of the tube inside the wing root would work as a way to prevent ice from blocking your vent tube, but couldn't a mud dauber go past the hole and do it's thing? I also think I would prefer not to have a vent inside the fairing because of the potential for fumes or avgas venting inside the fairing. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372110#372110 ________________________________________________________________________________
Subject: Storing wings vertically?
Date: Apr 29, 2012
It's going to be a while until I get to the wings, and I'm short on space in the hanger. I've googled but have found nothing on anyone building a stand to hold the wings vertically. Obviously I can't work on them that way, but until I start work on them it would sure free up some space. Any thoughts on a vertical wing stand? Anyone seen it done already? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372115#372115 ________________________________________________________________________________
From: "John Ciolino" <JohnCiolino(at)carolina.rr.com>
Subject: RE: RV8-List: Fuel vent modification
Date: Apr 30, 2012
An alternate method: flare the end of the tube, cut a circular patch of flexible fiberglass screening and make radial cuts leaving center =BC=94 uncut. The cuts will allow you to wrap the screen around the tube overlapping the cut pieces. Secure the screen with a piece of shrink tubing. Easy to do, lasts a long time (2 years so far on my -8) but can be easily replaced if necessary. John Ciolino RV-8 N894Y From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Sunday, April 29, 2012 5:54 PM rv-list(at)matronics.com Subject: RV8-List: Fuel vent modification Here is a simple way to keep mud-dabbers from clogging your fuel vent. I think more than one RV has collapsed a fuel tank from a clogged vent. Take a few inches of 3/8=94 aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material. Once the JB Weld is cured, clean up the edge on a ScotchBrite wheel or similar. Do a =BE=94 cut in the other end for a hose clamp, then slide this over the now somewhat shortened standard =BC=94 vent tubing. Have the =BC=94 tubing extend well past where the clamp goes. Carl RV-8A (800 hours) RV-10 (FSDO comes to inspect May 23rd) ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Apr 30, 2012
Yep, the 1/4" tubing is just too small to do this. I think I will add the small hole for the ice issue. I've had this vent mod on my 8A for 10 years - works fine. Carl On Apr 29, 2012, at 9:21 PM, "dmaib(at)me.com" wrote: > > That looks like a great solution, Carl. I have tried to use JB Weld to glue a similar piece of window screen on the existing vent, and it is so small that it is difficult to get the screen to stay in place. > It seems to me that the #50 hole on the back of the tube inside the wing root would work as a way to prevent ice from blocking your vent tube, but couldn't a mud dauber go past the hole and do it's thing? I also think I would prefer not to have a vent inside the fairing because of the potential for fumes or avgas venting inside the fairing. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=372110#372110 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 30, 2012
For anyone that lives in an area where these critters are common, I highl y recommend you do something to keep them from blocking your vent. I had o ne block the crankcase vent on my motorcycle years ago and it took me two t rips to the dealership to try and figure out why I had oil coming up the cl utch cable before one of the guys said check your breather for mud daubers and sure enough, it was plugged tight. Couple of good raps on the tube and a whole lot of dirt later and the problem went away. I'm confident that o ne of these guys could cause a tank collapse from the vacuum. Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Carl Froehlich Sent: Sunday, April 29, 2012 4:54 PM Subject: RV10-List: Fuel vent modification Here is a simple way to keep mud-dabbers from clogging your fuel vent. I t hink more than one RV has collapsed a fuel tank from a clogged vent. Take a few inches of 3/8" aluminum tubing, cut one end at 45 degrees or so, then JB Weld on a piece of aluminum window screen material. Once the JB W eld is cured, clean up the edge on a ScotchBrite wheel or similar. Do a =BE" cut in the other end for a hose clamp, then slide this over the now so mewhat shortened standard =BC" vent tubing. Have the =BC" tubing extend we ll past where the clamp goes. Carl RV-8A (800 hours) RV-10 (FSDO comes to inspect May 23rd) ________________________________________________________________________________
Date: Apr 30, 2012
From: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
Subject: Deutschland
I will be over in Germany next week, north of Frankfurt. Any RV 10 builders over there? It would be fun to see another project across the pond. Send me an email. Dr Fred N515 FW drfred1960(at)gmail.com ________________________________________________________________________________
Date: Apr 30, 2012
There just might be some pitot tube covers that would do the trick. Old aircraft from the post WWII era had pitots that were just 1/4" tubing, like the Cessnas of that era. Reminds me, should check with airport maintenance...they collect pitot covers by the dozens off the runways....... On 4/30/2012 6:18 AM, Michael Sausen wrote: > > For anyone that lives in an area where these critters are common, I > highly recommend you do something to keep them from blocking your > vent. I had one block the crankcase vent on my motorcycle years ago > and it took me two trips to the dealership to try and figure out why I > had oil coming up the clutch cable before one of the guys said check > your breather for mud daubers and sure enough, it was plugged tight. > Couple of good raps on the tube and a whole lot of dirt later and the > problem went away. Im confident that one of these guys could cause a > tank collapse from the vacuum. > > Michael > > **** ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: Storing wings vertically?
Date: Apr 30, 2012
Bill: The attached photo shows my wing cradle (sorry for the clutter in front; a challenge of building in a garage). It was made from wood scraps. Plywood cut to leading-edge curves, with the two wings bottom out, and a slot in the center for the horizontal stab. Cutouts lined with felt strips. (Some have made carpet slings instead of using plywood.) Another ply piece at the bottom to keep things squared up, with casters underneath. Then joined by a 2 x 4 to put them about 8' apart, plus a diagonal brace to keep the vertical ply straight up. With the 4" casters, it has been rolled two blocks away to another garage for storage when I was moving. Also made it easy to roll up onto a trailer for moving. Phil White #40220 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372141#372141 Attachments: http://forums.matronics.com//files/wing_cradle_123.jpg ________________________________________________________________________________
Date: Apr 30, 2012
Subject: Re: Foreflight with Stratus Review
I had an update to WingX that I downloaded this weekend. In the notes it says that it now supports ADS-B Traffic. I know Foreflight says they will NOT support traffic and do not plan to. They have their reasons for this. At any rate, it now is another differentiating factor between the 2 apps. I do NOT have ADS-B on my WingX, (I feel that having ADS-B/WX integrated in the panel is much better than having it on a separate device, if possible) so I can't comment on how it works. I also do not know if it works with the Stratus device or not. But, I just wanted to pass on this tidbit since it is also new information. Tim On 4/27/2012 7:51 AM, Tim Olson wrote: > > And I use my iPad with both Foreflight and WingX (and I had skycharts on > there long ago too but never use it anymore). I also use mine for > work (remote access) a bunch, and it's also an entertainment device on > vacations....movies mostly. So for me, 32Gb would be a minimum, > and 64Gb is do-able. In fact, my biggest complaint about the iPhone > and iPad is that I wish each had one model higher in capacity. > I could really use 64Gb on my iPhone, and I'd love a 128Gb iPad. > It's the primary reason I didn't buy an iPhone 4S and "New" iPad...had > they increased the capacity I'd have bought one the first day. > > So Robin is right....you can really save money and if you only want > to use it for flying and some minor things, a 16Gb model would work > but we aware that you will only be able to have one major app on > there for flight software, most likely. I'd *always* recommend > the 3G/4G models because even when just in the car the built-in > GPS is worth the extra, if you use it for any navigation or mapping. > (I keep a road GPS app on there too, with all US coverage) > So for many non-entertainment users, 32Gb would be a logical happy > medium. If you have kids though, spring for the biggest one you > can find. We loaded all of our iPads and iPhones up with movies > and entertainment for our last trip and it was nice to have. > > Tim > > > On 4/27/2012 7:23 AM, Jesse Saint wrote: >> >> Thanks for the comments on the 3 different iPads. I will comment on >> the 16GB version, which I have in the iPad 2. I do wish I had the 32GB >> version. That is probably one of the main reasons I have not used >> WingX much. I was given a subscription to the charts for a year, but >> because I can't download all of the charts for both Foreflight and >> WingX (I usually try to keep most or all of the US charts downloaded >> on Foreflight all the time, even though I very seldom fly out West) as >> well as keep my other apps on the iPad. I do use the iPad for a lot >> more than just flying, so if you are just flying, then 16GB should be >> plenty, but if you want to have movies, audio, lots of apps, etc on >> the iPad as well as Foreflight (uses a lot more storage than WingX), >> then you might want to look at 32GB. Just my 2 cents (can't find the >> cents key on my Macbook). >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> On Apr 26, 2012, at 10:10 PM, Robin Marks wrote: >> >>> Thanks Jesse. I just wanted to piggyback on your comments with an >>> iPad observation. Having owned all three (1, 2& New) I really like >>> the reduced cost of the iPad 2 3G. Don't get me wrong the New iPad is >>> nice with 4G and the retina screen but it does get hotter that it's >>> predecessors for sure and the minor weight difference is noticeable. >>> The New is definitely an improvement in screen and speed but the iPad >>> 2 seems to do it all quite well and with a minimum $100 savings. I >>> say minimum because you can only get the 2 in a 16GB unit. When you >>> buy the New iPad you may be temped to get the 32 or 64GB as I did for >>> a mere $829.00 before mandatory cover. So $529.00 vs. $829.00. I know >>> Tim O would chime in with the need for extra storage but I have done >>> everything I needed wo going over my 16 GB with a little memory >>> management. >>> So my 2 (can't find the cents key on my iPad) are you have a choice >>> between good and better. You can't lose. >>> >>> Robin >>> Sent from the new iPad >>> >>> On Apr 26, 2012, at 7:33 PM, "Jesse Saint" >>> wrote: >>> >>>> I received my Stratus unit from Sporty's the other day and wanted to >>>> give a report on my impressions for the group. I know there is a lot >>>> of debate over which app is best for the iPad, especially with the >>>> new Garmin app released at Sun-N-Fun, but I'm going to try not to >>>> get into that beyond this statement. I have used Foreflight since >>>> version 1 or 2 and have only tried WingX a little. Because I am used >>>> to Foreflight and the navigation and functionality, I have not liked >>>> my experiences with WingX, but as has been said before, we like what >>>> we are used to. I use Foreflight for all of my flight planning (I >>>> usually use www.weathermeister.com<http://www.weathermeister.com> >>>> for keeping up with the weather for my trip, but use Foreflight for >>>> all actually route planning, flight plan filing, and charts and >>>> plates while flying). I have Foreflight on my iPad 2 Wifi and iPhone >>>> 4. I have used a bluetooth GPS that required jailbreaking the iPad, >>>> but when that broke (left it on the gla! > > rs! >> hield in the Florida sun for 3-4 hours one day and the battery swelled >> and broke the case), I bought the Bad Elf. I wasn't very happy with >> the Bad Elf because I didn't like having it attached to the iPad in >> use, especially when bouncing around in IMC. I almost pulled the >> trigger on the new iPad, in which case I would have bought the 4G >> version, but when I didn't get the call from MacMall on the day they >> were starting to ship (like they promised they would), I didn't follow >> through with the purchase. >>>> >>>> I was walking through the hangars at Sun-N-Fun and saw the Stratus >>>> on the first day. After a short talk with a friend of mine, we >>>> decided to buy it. We had both been saying that as soon as there was >>>> a portable ADS-B box that worked with Foreflight, we would get it. >>>> We split the cost and ordered it as well as the external antenna >>>> (which we haven't received yet). We mainly wanted ADS-B for weather, >>>> because we were almost to the point of getting the unit that would >>>> get XM weather onto the iPad, but liked the thought of no >>>> subscription better. >>>> >>>> We just made a flight in N33DQ (Cessna 182) from Arkansas to Florida >>>> through a lot of IMC, but it was a couple of days too early for the >>>> Stratus. That would be the real test, especially because of the >>>> ADS-B service areas and all of the local radar activity. >>>> Unfortunately, the screen shots I have now are shots with no rain >>>> within 250nm or more of where I was flying, and not a cloud in the
March 31, 2012 - April 30, 2012
RV10-Archive.digest.vol-ir
