RV10-Archive.digest.vol-iv
June 26, 2012 - July 16, 2012
Date: Jun 26, 2012
Subject: Re: Wing kit crate in a pickup?
I picked mine up back in May and 4 feet of the crate hung out from the edge of the tailgate.- I put a strap around it and a red flag and brought it home without any issues.- See attachment.=0A=0A=0AJeremy=0A=0A-=0AFrom: Ed Kranz =0ATo: rv10-list(at)matronics.com =0ASent: Tuesd ay, June 26, 2012 9:34 AM=0ASubject: RV10-List: Wing kit crate in a pickup? =0A=0A=0AMy (SB) wing kit is sitting at the local FedEx terminal, and I'm w ondering if I need a trailer to pick it up. I know the longest crate is a t ad over 14' long... which is right at the edge what I'm comfortable hauling in the back of a pickup with an 8' box. =0A=0AHas anyone else picked up th -======================== =========== ________________________________________________________________________________
Subject: Wing kit crate in a pickup?
Date: Jun 26, 2012
I carried a bit more and it all fit. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jun 26, 2012
Ed, I picked mine up in my full size Chev pickup, used tie down sraps to keep everything secure, crossed the US Canada border, and had no issues. Also drove approx 3 hours from the Port Huron MI, Fed Ex terminal to home. Very do-able. I remember putting the the longest box on top. Go for it........ Rick #40956 Southampton, Ont On Tue, Jun 26, 2012 at 9:34 AM, Ed Kranz wrote: > My (SB) wing kit is sitting at the local FedEx terminal, and I'm wondering > if I need a trailer to pick it up. I know the longest crate is a tad over > 14' long... which is right at the edge what I'm comfortable hauling in the > back of a pickup with an 8' box. > > Has anyone else picked up their wings in a pickup? Or should I try to > scrounge up a trailer? > > * > > * > > ________________________________________________________________________________
Date: Jun 27, 2012
Thanks for all the info! I was able to pick up my crates at the FedEx freight depot (instead of being home from 1-5). We were able to slide the boxes right off the forklift and into the back of the truck. One strap around the back of each box to hold them in kept them very secure for the 30 minute drive home. Now all I have to do is build them! ________________________________________________________________________________
Subject: Re: Skybolt Fasteners - Installation
Date: Jun 27, 2012
Lew, I was the original inquirer. The issue I am struggling with is using the "Solid Flange" installation using Skybolt. I talked to Skybolt and was informed that using solid flange (Aluminum strip) was a problem due to the angle at the top of the firewall (~15degrees). I am working on a RV9A. I follow the RV10 list as most of the experienced builders post there. My concern is a using a modified cowl ( I bought a project) which may be too short. I am exploring the possibility of using the AL strip to extend the cowl by 1/2 to 3/4 inch. I will not receive my engine from Lyc for another month or so. Once I hang the engine the cowl length issue will be clearer. Any advice or guidance would be appreciated. Bill DeLacey On Jun 20, 2012, at 5:34 PM, Lew Gallagher wrote: > > I just had an email inquiring about my comment on installing the solid flange around the firewall being easier than using the "ears" supplied with the new skybolt kits. > > I briefly read it in my email screener, then inadvertently deleted it. So here's hoping you get this as a general post. > > Yes, you just rivet it around the firewall, then when your cowl is fit, simply measure where you want to put the skybolts and pilot drill through the cowl and flange -- perfect fit. > > Originally I think everybody had to install their own flange (the kit was just male/female fasteners,collars, retaining rings), some scalloped it out, others didn't -- your preference for weight, easier to bend to fit if scalloped, etc. See Tim's site for pictures, specs on the aluminum, where to order it. The ears work OK, but personally, I don't see them as an improvement. > > I hope this addressed your inquiry, if not, send it again or post it here for other feedback. > > Later, - Lew > > -------- > non-pilot > crazy about building > NOW OFICIALLY BUILDER #40549 > Fly off completed ! > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376175#376175 > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2012
Hey Bill, Let me start with, I'm not familiar with the -9A, (~15 degrees), so here goes for what it's worth. The solid flange with scallop cut would be easy to bend the individual scallops to whatever angle works. Another suggestion about the "maybe too short cowl": several times I have extended the aft edge of the cowl itself for guys who want the "Swiss watch" fit, but had already cut it too short. I sand a shallow on the inner surface of the edge at least 1/2 inch wide (think of the edge of sheetrock where the joining tape will fill) so that you can glass in a strip of fiberglass cloth that overlaps from the original cowl in the shallow to a little beyond what you need on the new aft edge. Let it harden overnight then come back with resin/cabosil to finish the outer surface flush. Sand inner and outer surfaces flush so that you have your extension on the aft edge with the glass cloth bonding the new edge to the original cowl. Done. And do this before drilling for the skybolts. Don't get impatient; mount the engine, prop, and spinner before doing any of this since the cowl is fit from the spinner back. Hope this helps. Later, - Lew -----Original Message----- From: William DeLacey Sent: Wednesday, June 27, 2012 11:38 AM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Lew, I was the original inquirer. The issue I am struggling with is using the "Solid Flange" installation using Skybolt. I talked to Skybolt and was informed that using solid flange (Aluminum strip) was a problem due to the angle at the top of the firewall (~15degrees). I am working on a RV9A. I follow the RV10 list as most of the experienced builders post there. My concern is a using a modified cowl ( I bought a project) which may be too short. I am exploring the possibility of using the AL strip to extend the cowl by 1/2 to 3/4 inch. I will not receive my engine from Lyc for another month or so. Once I hang the engine the cowl length issue will be clearer. Any advice or guidance would be appreciated. Bill DeLacey ________________________________________________________________________________
Date: Jun 27, 2012
Subject: Re: Flying the US
Tim, did you get a chance to meet up with our neighbor, the Wilsons, Steve and Barb... in the Swift.=0AWe are currently in Steamboat Springs.... and F riday will be joined by Dave and Windy Moore in their newly commisioned RV1 0... So that gives us 3 RV10's and one RV7.=0ADon McDonald=0A =0A=0A_______ _________________________=0A From: Tim Olson <Tim(at)myrv10.com>=0ATo: RV10 <R V10-list(at)matronics.com> =0ASent: Wednesday, June 27, 2012 11:25 AM=0ASubjec t: RV10-List: Flying the US=0A =0AYesterday Ed Hayden and I finished the l ast Northbound leg=0Aof our trip, arriving in Fairbanks, AK!- So far this has been=0Aa really great trip, and some of the flying has been pretty=0Ac hallenging in terms of weather conditions and such, with heavy=0Ause of the freedom allowed by flying in the class G airspace=0Aunder 1200' being the only way we could have made it here=0Athus far. It's been a real adventure! =0A=0AAlthough I am sad to have to cheat on claiming Hawaii, landing=0Ain N orthway, AK did complete my flying and landing in all of the=0A50 US states (I rented a twin and brought the keys from N104CD to=0Afly Hawaii), and Ca nada, Mexico, and the Bahamas.- The RV-10=0Ahas brought us to all of thes e places in more comfort and=0Afun than I ever would have imagined when I d id my first flight=0Ain it nearly 6.5 years ago.- Van's put together a gr eat kit,=0Athat is for sure.- The $3000 or $4000 or whatever it is that w e=0Apaid for the seats has proven valuable in comfort, as I've=0Anever spen t so many traveling hours in a seat as comfortable as=0Athese by Oregon Aer o.=0A=0AWe'll have a good trip report when I get back, of course, but I'm =0Astill looking forward to many more stops and many more days with=0Alots more great photos.- So far from what I see, Alaska=0Aprobably not only ri vals, but beats Hawaii for scenic beauty, and=0AI didn't know if that was p ossible.=0A=0AIt's been a heck of a ride, but with 50 states done, I now ha ve to=0Acontemplate if I want to give it a shot at doing the North Atlantic =0Aroute to Europe some day.... :)=0A=0A-- Tim Olson - RV-10 N104CD=0Ado no t archive ________________________________________________________________________________
Date: Jun 28, 2012
You should read the thread on VAF regarding the installation using the newer "gray" cowling. It is posted here http://www.vansairforce.com/community/showthread.php?t=86547&highlight=skybolt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went back to the hinge, I should have made the top edge installation work. Using the hinges on the sides makes for a much nicer and stronger joint. The hinge pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a great improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376765#376765 ________________________________________________________________________________
Date: Jun 28, 2012
Subject: Brake Back Plate Bolts Not Drilled?
Assembling the brakes on the mains the other day and I noticed that the two bolts that came with the brake assemblies which attach the back plate were not drilled head bolts. Every plane I've seen has these two bolts safety-wired. Did others get non-drilled head bolts with their brake assemblies, or is it just me? I believe that those two bolts are AN4-20? Is that what others replaced them with for safety wiring? -Sean #40303 (Overhead Console) ________________________________________________________________________________
Date: Jun 28, 2012
Subject: Re: Brake Back Plate Bolts Not Drilled?
Having drilled head bolts there is a belt and suspenders approach. In most Cleveland brake calipers the bolts go into self locking threads and need no additional retention. The Cessna 170/172 Cleveland retrofit kits don't have drilled bolts either...flew with them for 20+ years with no problems. On 6/28/2012 6:42 AM, Sean Stephens wrote: > > Assembling the brakes on the mains the other day and I noticed that > the two bolts that came with the brake assemblies which attach the > back plate were not drilled head bolts. Every plane I've seen has > these two bolts safety-wired. > > Did others get non-drilled head bolts with their brake assemblies, or > is it just me? > > I believe that those two bolts are AN4-20? Is that what others > replaced them with for safety wiring? > > -Sean #40303 (Overhead Console) > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 28, 2012
They are not drilled head bolts. The DAR noticed this during our AW inspection and asked about it. We looked in the plans and found that they do not call for drilled heads. He was surprised, but OK with it since it was per plans. I decided to go ahead and install drilled head bolts and safety wire for peace of mind. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376775#376775 ________________________________________________________________________________
Subject: Re: Nose Gear Insert tool
Date: Jun 28, 2012
Hi Tom, I received the insert pack, I will send them along with the kit. Many thanks... Frank -------- Frank Dombroski RV-10 N10FD Flying Rv-7A N453DM Flying Subaru RV-8 N84FD Finished and sold :-{ SMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376777#376777 ________________________________________________________________________________
Date: Jun 28, 2012
Note that it is Cleveland that supplies the brakes without drilled head bolts. I don't recall which variety of self locking they use, but the calipers definitely have self locking on those bolts. You cannot back a bolt out 1/2 turn and then hand turn bolt as you could if they were ordinary threads. On Thu, Jun 28, 2012 at 6:56 AM, dmaib(at)me.com wrote: > > They are not drilled head bolts. The DAR noticed this during our AW > inspection and asked about it. We looked in the plans and found that they > do not call for drilled heads. He was surprised, but OK with it since it > was per plans. I decided to go ahead and install drilled head bolts and > safety wire for peace of mind. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376775#376775 > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 28, 2012
Another area that could be addressed is that Cleveland uses nylock nuts to secure the guide pins. I've seen the plastic melted away after the brakes get hot. That's a good place for a metal nut. Not that there's a huge chance of the guide pins falling out but it couldn't hurt. Dave Saylor 831-750-0284 CL On Thu, Jun 28, 2012 at 6:56 AM, Kelly McMullen wrote: > > Having drilled head bolts there is a belt and suspenders approach. In most > Cleveland brake calipers the bolts go into self locking threads and need no > additional retention. The Cessna 170/172 Cleveland retrofit kits don't have > drilled bolts either...flew with them for 20+ years with no problems. > > > On 6/28/2012 6:42 AM, Sean Stephens wrote: > >> >> Assembling the brakes on the mains the other day and I noticed that the >> two bolts that came with the brake assemblies which attach the back plate >> were not drilled head bolts. Every plane I've seen has these two bolts >> safety-wired. >> >> Did others get non-drilled head bolts with their brake assemblies, or is >> it just me? >> >> I believe that those two bolts are AN4-20? Is that what others replaced >> them with for safety wiring? >> >> -Sean #40303 (Overhead Console) >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 28, 2012
Yes, the non-drilled bolts come with the kit from Parker/Cleveland. I noticed that locking effect when I was removing the bolts. It would seem to prevent the bolt from backing out under most if not all vibration scenarios when torqued to the spec on the calipers. I was just wondering if some folks but on their belt and suspenders and swapped them out for AN4H-20A. On 6/28/12 10:17 AM, Kelly McMullen wrote: > Note that it is Cleveland that supplies the brakes without drilled > head bolts. I don't recall which variety of self locking they use, but > the calipers definitely have self locking on those bolts. You cannot > back a bolt out 1/2 turn and then hand turn bolt as you could if they > were ordinary threads. > > On Thu, Jun 28, 2012 at 6:56 AM, dmaib(at)me.com > > wrote: > > " > > > They are not drilled head bolts. The DAR noticed this during our > AW inspection and asked about it. We looked in the plans and found > that they do not call for drilled heads. He was surprised, but OK > with it since it was per plans. I decided to go ahead and install > drilled head bolts and safety wire for peace of mind. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376775#376775 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * ________________________________________________________________________________
Date: Jun 28, 2012
the wheel assemblies are supplied by MATCO. Matco has changed to Nordlock washers as the fastener of choice. The AN4H (with hole in the head) has been replaced with Nordlocks. Johnny Horizon On Thu, Jun 28, 2012 at 6:56 AM, Kelly McMullen wrote: > > Having drilled head bolts there is a belt and suspenders approach. In most > Cleveland brake calipers the bolts go into self locking threads and need no > additional retention. The Cessna 170/172 Cleveland retrofit kits don't have > drilled bolts either...flew with them for 20+ years with no problems. > > > On 6/28/2012 6:42 AM, Sean Stephens wrote: > >> >> Assembling the brakes on the mains the other day and I noticed that the >> two bolts that came with the brake assemblies which attach the back plate >> were not drilled head bolts. Every plane I've seen has these two bolts >> safety-wired. >> >> Did others get non-drilled head bolts with their brake assemblies, or is >> it just me? >> >> I believe that those two bolts are AN4-20? Is that what others replaced >> them with for safety wiring? >> >> -Sean #40303 (Overhead Console) >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 28, 2012
My "main" wheels and brake kits are from Parker Cleveland. It came with AN4-20A bolts to attach the back plate. The nose wheel axle has the Nordlock washers, not the main wheels/brakes. At least on my kit. -Sean #40303 On 6/28/12 11:16 AM, John Cox wrote: > the wheel assemblies are supplied by MATCO. Matco has changed to > Nordlock washers as the fastener of choice. The AN4H (with hole in > the head) has been replaced with Nordlocks. > Johnny Horizon > > On Thu, Jun 28, 2012 at 6:56 AM, Kelly McMullen > wrote: > > > > > Having drilled head bolts there is a belt and suspenders approach. > In most Cleveland brake calipers the bolts go into self locking > threads and need no additional retention. The Cessna 170/172 > Cleveland retrofit kits don't have drilled bolts either...flew > with them for 20+ years with no problems. > > > On 6/28/2012 6:42 AM, Sean Stephens wrote: > > > > > Assembling the brakes on the mains the other day and I noticed > that the two bolts that came with the brake assemblies which > attach the back plate were not drilled head bolts. Every > plane I've seen has these two bolts safety-wired. > > Did others get non-drilled head bolts with their brake > assemblies, or is it just me? > > I believe that those two bolts are AN4-20? Is that what > others replaced them with for safety wiring? > > -Sean #40303 (Overhead Console) > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > > > =================================== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > http://forums.matronics.com > =================================== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > =================================== > > > * > > > * ________________________________________________________________________________
Subject: Re: high oil PSI.
Date: Jun 28, 2012
After validating my oil PSI was ok with a mechanical gauge. I then began to hunt for the cause of my oil PSI going up to 99 PSI. What I found was that I had a failure in the one wire that comes off the sender. After replacing the whole wire the Oil PSI was back to normal. Initially, I replaced the connector on the sender and that did nothing. I had to go back to basics and get the old continuity tester out, and that was how I found the failed connector under the panel. Thanks to those who posted with helpful ideas. Thane Sates ----- Original Message ----- From: pilotdds To: rv10-list(at)matronics.com Sent: Wednesday, June 13, 2012 3:03 PM Subject: Re: RV10-List: high oil PSI. Thane keep me posted on this I made an unscheduled stop in blythe Ca after a 7000 mile trip Over the course of 300 miles the oil pressure indication went from83to 95 when I landed.Temp dropped but I richened the mixture and reduced RPM.I removed the cowl at BLH and tapped on the vernitherm,wiggled wires and turned down oilpressure adjustment but only one turn in case it was an erroneos reading.On talkoff it was 92 but came down to 85 and I was able to return home.I am using grt equipment also but have had no trouble.This weekend I will check accuracy with a mechanical gauge.Sac sky ranch talks about possible blockage inthe right oil gallery but that may be jumping the gun.My engine is a narrow deck 540 that i overhauled myself with 450 hours using aeroshell 100 plus.To: rv10-list Sent: Wed, Jun 13, 2012 11:27 am Subject: Re: RV10-List: high oil PSI. Ok Guys, finally got the Oil PSi. sender changed today, and now am even more confused. Upon start, the Oil psi was at 99 psi and stayed there. I did a 5-7 minute engine run, and the psi never changed from 99 psi. Any ideas?? Could I have a brand new sender that is bad? Thanks in advance, Thane ----- Original Message ----- From: DLM To: rv10-list(at)matronics.com Sent: Monday, June 04, 2012 10:25 PM Subject: RE: RV10-List: high oil PSI. welcome to the club.the VDO 360-003 is the same used on a certified Piper product. The cost with the FAA PMA stamped exceeds $200. they are available to the experimental machines for $28 from http://www.jegs.com/i/VDO/918/360-003/10002/-1. The first lasted about $500 hours; the second gave intermittent high readings in about 25 hours. ------------------------------------------------------------------------- --- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: Monday, June 04, 2012 6:42 PM To: rv10-list(at)matronics.com Subject: RE: RV10-List: high oil PSI. I=C2=92ve seen the GRT fuel pressure sender go bad and read real high. I=C2=92d guess you have a bad sender. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Thane States Sent: Monday, June 04, 2012 8:01 PM To: rv10-list(at)matronics.com Subject: RV10-List: high oil PSI. Hey guys, I went out flying this weekend and had a strange rise in oil psi. Ist, I have a BPE, IO-540. 222 hrs. I was at 4500 msl when I glanced over to see my oil psi at 91 psi. Within a minute it jumped one more psi and so on until it showed 99 psi. By this time I already turned back for home, and had reduced power to see if that helped. That didn't change anything. Once I landed, and was at taxi power, it showed in the low 70's. Anyone else ever see this? BTW, I have the GRT system, and I am on my 3rd. fuel psi sender. Could this be the same problem, bad sender?? Thane states RV-10 321BY ===================http://www.matro nic=================http://forums.matro nics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c No virus found in this message. Checked by AVG - www.avg.com div> get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com 06/13/12 ________________________________________________________________________________
Date: Jun 28, 2012
Has Van's changed from Cleveland wheels/brakes for the mains? When I got my finish kit 18 mo ago it was all Cleveland on the mains. The Clevelands do not use drilled head bolts. Kelly 40866 On Thu, Jun 28, 2012 at 9:16 AM, John Cox wrote: > the wheel assemblies are supplied by MATCO. Matco has changed to Nordlock > washers as the fastener of choice. The AN4H (with hole in the head) has > been replaced with Nordlocks. > > Johnny Horizon > > ________________________________________________________________________________
Date: Jun 28, 2012
Hmmm. My brakes are Grove and the bolts came drilled. Has Van's been changing suppliers? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376804#376804 ________________________________________________________________________________
Date: Jun 28, 2012
I just got my finish kit on Tuesday and the brakes were also Grove. Steve Stella #40654 521RV (reserved) Finishing -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of tsts4 Sent: Thursday, June 28, 2012 5:51 PM Subject: RV10-List: Re: Brake Back Plate Bolts Not Drilled? Hmmm. My brakes are Grove and the bolts came drilled. Has Van's been changing suppliers? -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376804#376804 ________________________________________________________________________________
Date: Jun 28, 2012
Here is our solution for the -10. Works well. I opted for S/S screws on the 8A to save $, weight and simplify the build. On the -10 especially I have had issues with the lower side cowl piano hing es damaging the fuse paint when removing & installing the lower cowl. A lon ger nose wheel slot would have been beneficial to ease all the on/off. Absolutely don't use Skybolts on the underside of the cowl (IMHO). Just too much vibration, oil etc... for them to hold up long term. Ask me how I kno w? Robin http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl-Fitting-6.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2448.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2453.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2450.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl_Left.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of bill.peyton Sent: Thursday, June 28, 2012 5:53 AM Subject: RV10-List: Re: Skybolt Fasteners - Installation to:peyton.b(at)sbcglobal.net>> You should read the thread on VAF regarding the installation using the newe r "gray" cowling. It is posted here http://www.vansairforce.com/community /showthread.php?t=86547&highlight=skybolt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went bac k to the hinge, I should have made the top edge installation work. Using t he hinges on the sides makes for a much nicer and stronger joint. The hing e pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a g reat improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376765#376765 ________________________________________________________________________________
Date: Jun 28, 2012
I think I read that Vans had changed the main wheels. Are the Grove brake pads less expensive than the $18 each Clevelands? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376813#376813 ________________________________________________________________________________
Date: Jun 28, 2012
Robin, just trying to comprehend what you said and what I see in the photos. Looks like you have Skybolts or some other camlock fasterners over the top and out to the front, with piano hinge for the bottom half attach to firewall. Is that correct, or are my eyes fooling me? On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks wrote: > Here is our solution for the -10. Works well. I opted for S/S screws on > the 8A to save $, weight and simplify the build.**** > > On the -10 especially I have had issues with the lower side cowl piano > hinges damaging the fuse paint when removing & installing the lower cowl. A > longer nose wheel slot would have been beneficial to ease all the on/off. * > *** > > Absolutely don=92t use Skybolts on the underside of the cowl (IMHO). Just > too much vibration, oil etc=85 for them to hold up long term. Ask me how I > know?**** > > ** ** > > Robin**** > > ** ** > > http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx **** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl-Fitting- 6.jpg] > **** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2448.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2453.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2450.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl_Left.jpg ] > **** > > ** ** > > ** ** > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton > Sent: Thursday, June 28, 2012 5:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Skybolt Fasteners - Installation > > ** ** > * > * > > ** ** > > You should read the thread on VAF regarding the installation using the > newer "gray" cowling. It is posted here > http://www.vansairforce.com/community/showthread.php?t=86547&highlight =skybolt > **** > > There are issues with the new cowling that require grinding out around > each one of the fasteners for clearance. In spite of the fact that I we nt > back to the hinge, I should have made the top edge installation work. > Using the hinges on the sides makes for a much nicer and stronger joint. > The hinge pins remove very easily. Around the top is the area that reall y > sees and improvement in regards to removing and re-installing the cowling . > The top hinges, due to the curvature, prevent you from lifting directly > upwards to remove the cowl. installing the Skybolt fasteners on the top > would be a great improvement.**** > > ** ** > > --------**** > > Bill**** > > WA0SYV**** > > Aviation Partners, LLC**** > > ** ** > > ** ** > > ** ** > > ** ** > > Read this topic online here:**** > > ** ** > > http://forums.matronics.com/viewtopic.php?p=376765#376765**** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > > ** ** > ====================**** bsp; - The RV10-List Email Forum -**** o browse* > *** scription,**** , Chat, FAQ,**** /p> tronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List**** ======== ============****bsp; - MATRONICS WEB FORUMS - > **** eb Forums!**** .matronics.com">http://forums.matronics.com****== ================= > **** bsp; - List Contribution Web Site -**** o:p>**bsp; -Matt Dralle, List Admin. > **** tronics.com/contribution"> http://www.matronics.com/contribution**** =================== > **** > > ** ** > > ** ** > > ** ** > ________________________________________________________________________________
Date: Jun 29, 2012
Correct, the locks are along all the edges of the top cowl. I forgot which locks I got but they are the ones that allow you to adjust for height. On t he 8A I used all #SS screws & washers in place of the locks. Saved $500 and some weight. Plus much easier & cheaper to replace in the field. The Piano hinges are on the sides of the lower cowl and have damaged some o f the fuse paint when taking on / off the cowl so many times (mostly due to the SJ cowl). If I had made the nose gear slot longer it may have been eas ier to drop the lower cowl down enough to better position it for installati on without smacking the fuse with the shark tooth like piano hinges. Did that answer your Q's? Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 28, 2012 5:50 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Robin, just trying to comprehend what you said and what I see in the photos . Looks like you have Skybolts or some other camlock fasterners over the to p and out to the front, with piano hinge for the bottom half attach to fire wall. Is that correct, or are my eyes fooling me? On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks > wrote: Here is our solution for the -10. Works well. I opted for S/S screws on the 8A to save $, weight and simplify the build. On the -10 especially I have had issues with the lower side cowl piano hing es damaging the fuse paint when removing & installing the lower cowl. A lon ger nose wheel slot would have been beneficial to ease all the on/off. Absolutely don't use Skybolts on the underside of the cowl (IMHO). Just too much vibration, oil etc... for them to hold up long term. Ask me how I kno w? Robin http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl-Fitting-6.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2448.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2453.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2450.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl_Left.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Thursday, June 28, 2012 5:53 AM Subject: RV10-List: Re: Skybolt Fasteners - Installation to:peyton.b(at)sbcglobal.net>> You should read the thread on VAF regarding the installation using the newe r "gray" cowling. It is posted here http://www.vansairforce.com/community /showthread.php?t=86547&highlight=skybolt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went bac k to the hinge, I should have made the top edge installation work. Using t he hinges on the sides makes for a much nicer and stronger joint. The hing e pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a g reat improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376765#376765 ==================== bsp; - The RV 10-List Email Forum - o browse scription, , Chat, FAQ, /p> tronics.com/Navi gator?RV10-List<http://tronics.com/Navigator?RV10-List>"> http://www.matron ics.com/Navigator?RV10-List =============== ===== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.c om<http://matronics.com>">http://forums.matronics.com ======= ============= bsp; - List Contribution Web Si te - o:p> bsp; -Matt Dralle, List Admin. tronics.com/c ontribution<http://tronics.com/contribution>"> http://www.matronics.com/con tribution =================== ________________________________________________________________________________
Date: Jun 28, 2012
Yes, mostly. I'm assuming with the SS screws you are using an aluminum strip with nutplates on the inside of cowling? On Thu, Jun 28, 2012 at 6:29 PM, Robin Marks wrote: > Correct, the locks are *along all the edges of the top cowl*. I forgot > which locks I got but they are the ones that allow you to adjust for > height. On the 8A I used all #SS screws & washers in place of the locks. > Saved $500 and some weight. Plus much easier & cheaper to replace in the > field.**** > > The Piano hinges are on the sides of the lower cowl and have damaged some > of the fuse paint when taking on / off the cowl so many times (mostly due > to the SJ cowl). If I had made the nose gear slot longer it may have been > easier to drop the lower cowl down enough to better position it for > installation without smacking the fuse with the shark tooth like piano > hinges.**** > > Did that answer your Q's?**** > > ** ** > > Robin**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Kelly McMullen > *Sent:* Thursday, June 28, 2012 5:50 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Re: Skybolt Fasteners - Installation**** > > ** ** > > Robin, just trying to comprehend what you said and what I see in the > photos. Looks like you have Skybolts or some other camlock fasterners ove r > the top and out to the front, with piano hinge for the bottom half attach > to firewall. Is that correct, or are my eyes fooling me?**** > > On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks > wrote:**** > > Here is our solution for the -10. Works well. I opted for S/S screws on > the 8A to save $, weight and simplify the build.**** > > On the -10 especially I have had issues with the lower side cowl piano > hinges damaging the fuse paint when removing & installing the lower cowl. A > longer nose wheel slot would have been beneficial to ease all the on/off. * > *** > > Absolutely don=92t use Skybolts on the underside of the cowl (IMHO). Just > too much vibration, oil etc=85 for them to hold up long term. Ask me how I > know?**** > > **** > > Robin**** > > **** > > http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx **** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl-Fitting- 6.jpg] > **** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2448.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2453.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2450.jpg] * > *** > > [image: Description: > http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl_Left.jpg ] > **** > > **** > > **** > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton > Sent: Thursday, June 28, 2012 5:53 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Skybolt Fasteners - Installation**** > > **** > * > * > > **** > > You should read the thread on VAF regarding the installation using the > newer "gray" cowling. It is posted here > http://www.vansairforce.com/community/showthread.php?t=86547&highlight =skybolt > **** > > There are issues with the new cowling that require grinding out around > each one of the fasteners for clearance. In spite of the fact that I we nt > back to the hinge, I should have made the top edge installation work. > Using the hinges on the sides makes for a much nicer and stronger joint. > The hinge pins remove very easily. Around the top is the area that reall y > sees and improvement in regards to removing and re-installing the cowling . > The top hinges, due to the curvature, prevent you from lifting directly > upwards to remove the cowl. installing the Skybolt fasteners on the top > would be a great improvement.**** > > **** > > --------**** > > Bill**** > > WA0SYV**** > > Aviation Partners, LLC**** > > **** > > **** > > **** > > **** > > Read this topic online here:**** > > **** > > http://forums.matronics.com/viewtopic.php?p=376765#376765**** > > **** > > **** > > **** > > **** > > **** > > **** > > **** > > ==================== bsp; - The RV10-List Email Forum - o browse > scription, , Chat, FAQ, /p> tronics.com/Navigator?RV10-List"> > http://www.matronics.com/Navigator?RV10-List ========= > bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com"> > http://forums.matronics.com =============== ===== bsp; - List > Contribution Web Site - o:p> bsp; -Matt Dralle, List > Admin. tronics.com/contribution"> http://www.matronics.com/contribution =================== > **** > > **** > > **** > > **** > > ** ** > ________________________________________________________________________________
Date: Jun 28, 2012
Bob Turner wrote: > I think I read that Vans had changed the main wheels. > Are the Grove brake pads less expensive than the $18 each Clevelands? Appears to be. From the Grove Website, the pads for the the 36-2M caliper that came in my kit: 066-105 Brake Pad Each - P/N: 066-105 - $7.45 Kit - P/N: 066-105K - $26.50 Includes 4 pads and 8 rivets -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376821#376821 Attachments: http://forums.matronics.com//files/66_105_660.jpg ________________________________________________________________________________
Date: Jun 29, 2012
Exactly. Used #8 with hellman ? Washers. always wanted to try next larger size and a couple fewer sets but didn't. Robin Kelly McMullen wrote: Yes, mostly. I'm assuming with the SS screws you are using an aluminum stri p with nutplates on the inside of cowling? On Thu, Jun 28, 2012 at 6:29 PM, Robin Marks > wrote: Correct, the locks are along all the edges of the top cowl. I forgot which locks I got but they are the ones that allow you to adjust for height. On t he 8A I used all #SS screws & washers in place of the locks. Saved $500 and some weight. Plus much easier & cheaper to replace in the field. The Piano hinges are on the sides of the lower cowl and have damaged some o f the fuse paint when taking on / off the cowl so many times (mostly due to the SJ cowl). If I had made the nose gear slot longer it may have been eas ier to drop the lower cowl down enough to better position it for installati on without smacking the fuse with the shark tooth like piano hinges. Did that answer your Q's? Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 28, 2012 5:50 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Robin, just trying to comprehend what you said and what I see in the photos . Looks like you have Skybolts or some other camlock fasterners over the to p and out to the front, with piano hinge for the bottom half attach to fire wall. Is that correct, or are my eyes fooling me? On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks > wrote: Here is our solution for the -10. Works well. I opted for S/S screws on the 8A to save $, weight and simplify the build. On the -10 especially I have had issues with the lower side cowl piano hing es damaging the fuse paint when removing & installing the lower cowl. A lon ger nose wheel slot would have been beneficial to ease all the on/off. Absolutely don=92t use Skybolts on the underside of the cowl (IMHO). Just t oo much vibration, oil etc=85 for them to hold up long term. Ask me how I k now? Robin http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl-Fitting-6.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2448.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2453.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2450.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl_Left.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Thursday, June 28, 2012 5:53 AM Subject: RV10-List: Re: Skybolt Fasteners - Installation to:peyton.b(at)sbcglobal.net>> You should read the thread on VAF regarding the installation using the newe r "gray" cowling. It is posted here http://www.vansairforce.com/community /showthread.php?t=86547&highlight=skybolt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went bac k to the hinge, I should have made the top edge installation work. Using t he hinges on the sides makes for a much nicer and stronger joint. The hing e pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a g reat improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376765#376765 ==================== bsp; - The RV 10-List Email Forum - o browse scription, , Chat, FAQ, /p> tronics.com/Navi gator?RV10-List<http://tronics.com/Navigator?RV10-List>"> http://www.matron ics.com/Navigator?RV10-List =============== ===== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.c om<http://matronics.com>">http://forums.matronics.com ======= ============= bsp; - List Contribution Web Si te - o:p> bsp; -Matt Dralle, List Admin. tronics.com/c ontribution<http://tronics.com/contribution>"> http://www.matronics.com/con tribution =================== ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Jun 29, 2012
In looking at the differences between the Grove and Cleveland brakes the Grove's appear to be a bit stronger. The Grove's are rated at 7000lbs with 186792 lb-ft and the Cleveland's are rated 6000 lbs with 185000 ft-lbs. Not that the Cleveland brakes are all that bad, but I sure am glad they moved in the right direction by beefing them up just a bit. Noticed the other night we are approaching 400 hours - how time flies when you're, well, flying! -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376832#376832 ________________________________________________________________________________
Date: Jun 29, 2012
Correction: Not Hellman Washers. They are more famous for their mayonnaise. We use Tinnerman Washers http://www.aircraftspruce.com/catalog/hapages/nas549washers2.php Of note, we didn't want as large a flange on the Tinnerman washers (especia lly on the spinner) so we took about a hundred washers and laced them on an appropriate size bolt then used a grinding wheel to remove about half the flange. This took less than 5 minutes to make 100 custom Tinnerman washers. One can use standard washers, we just thought the reduced flange looked be tter for this application. [Description: C:\Users\Robin\Desktop\Washer Detail.jpg] Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Robin Marks Sent: Thursday, June 28, 2012 8:03 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Exactly. Used #8 with hellman ? Washers. always wanted to try next larger size and a couple fewer sets but didn't. Robin Kelly McMullen > wrote: Yes, mostly. I'm assuming with the SS screws you are using an aluminum stri p with nutplates on the inside of cowling? On Thu, Jun 28, 2012 at 6:29 PM, Robin Marks > wrote: Correct, the locks are along all the edges of the top cowl. I forgot which locks I got but they are the ones that allow you to adjust for height. On t he 8A I used all #SS screws & washers in place of the locks. Saved $500 and some weight. Plus much easier & cheaper to replace in the field. The Piano hinges are on the sides of the lower cowl and have damaged some o f the fuse paint when taking on / off the cowl so many times (mostly due to the SJ cowl). If I had made the nose gear slot longer it may have been eas ier to drop the lower cowl down enough to better position it for installati on without smacking the fuse with the shark tooth like piano hinges. Did that answer your Q's? Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 28, 2012 5:50 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Robin, just trying to comprehend what you said and what I see in the photos . Looks like you have Skybolts or some other camlock fasterners over the to p and out to the front, with piano hinge for the bottom half attach to fire wall. Is that correct, or are my eyes fooling me? On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks > wrote: Here is our solution for the -10. Works well. I opted for S/S screws on the 8A to save $, weight and simplify the build. On the -10 especially I have had issues with the lower side cowl piano hing es damaging the fuse paint when removing & installing the lower cowl. A lon ger nose wheel slot would have been beneficial to ease all the on/off. Absolutely don't use Skybolts on the underside of the cowl (IMHO). Just too much vibration, oil etc... for them to hold up long term. Ask me how I kno w? Robin http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl-Fitting-6.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2448.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2453.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/1 00_2450.jpg] [Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/C owl_Left.jpg] -----Original Message----- From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Thursday, June 28, 2012 5:53 AM Subject: RV10-List: Re: Skybolt Fasteners - Installation to:peyton.b(at)sbcglobal.net>> You should read the thread on VAF regarding the installation using the newe r "gray" cowling. It is posted here http://www.vansairforce.com/community /showthread.php?t=86547&highlight=skybolt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went bac k to the hinge, I should have made the top edge installation work. Using t he hinges on the sides makes for a much nicer and stronger joint. The hing e pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a g reat improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376765#376765 ==================== bsp; - The RV 10-List Email Forum - o browse scription, , Chat, FAQ, /p> tronics.com/Navi gator?RV10-List<http://tronics.com/Navigator?RV10-List>"> http://www.matron ics.com/Navigator?RV10-List =============== ===== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.c om<http://matronics.com>">http://forums.matronics.com ======= ============= bsp; - List Contribution Web Si te - o:p> bsp; -Matt Dralle, List Admin. tronics.com/c ontribution<http://tronics.com/contribution>"> http://www.matronics.com/con tribution =================== ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 29, 2012
Another way to do the spinner is to take #6 Tinnerman washers and drill them out to take a #8 screw. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Friday, June 29, 2012 7:55 PM Subject: RE: RV10-List: Re: Skybolt Fasteners - Installation Correction: Not Hellman Washers. They are more famous for their mayonnaise. We use Tinnerman Washers http://www.aircraftspruce.com/catalog/hapages/nas549washers2.php Of note, we didn't want as large a flange on the Tinnerman washers (especially on the spinner) so we took about a hundred washers and laced them on an appropriate size bolt then used a grinding wheel to remove about half the flange. This took less than 5 minutes to make 100 custom Tinnerman washers. One can use standard washers, we just thought the reduced flange looked better for this application. Description: C:\Users\Robin\Desktop\Washer Detail.jpg Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Thursday, June 28, 2012 8:03 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Exactly. Used #8 with hellman ? Washers. always wanted to try next larger size and a couple fewer sets but didn't. Robin Kelly McMullen wrote: Yes, mostly. I'm assuming with the SS screws you are using an aluminum strip with nutplates on the inside of cowling? On Thu, Jun 28, 2012 at 6:29 PM, Robin Marks wrote: Correct, the locks are along all the edges of the top cowl. I forgot which locks I got but they are the ones that allow you to adjust for height. On the 8A I used all #SS screws & washers in place of the locks. Saved $500 and some weight. Plus much easier & cheaper to replace in the field. The Piano hinges are on the sides of the lower cowl and have damaged some of the fuse paint when taking on / off the cowl so many times (mostly due to the SJ cowl). If I had made the nose gear slot longer it may have been easier to drop the lower cowl down enough to better position it for installation without smacking the fuse with the shark tooth like piano hinges. Did that answer your Q's? Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, June 28, 2012 5:50 PM Subject: Re: RV10-List: Re: Skybolt Fasteners - Installation Robin, just trying to comprehend what you said and what I see in the photos. Looks like you have Skybolts or some other camlock fasterners over the top and out to the front, with piano hinge for the bottom half attach to firewall. Is that correct, or are my eyes fooling me? On Thu, Jun 28, 2012 at 4:23 PM, Robin Marks wrote: Here is our solution for the -10. Works well. I opted for S/S screws on the 8A to save $, weight and simplify the build. On the -10 especially I have had issues with the lower side cowl piano hinges damaging the fuse paint when removing & installing the lower cowl. A longer nose wheel slot would have been beneficial to ease all the on/off. Absolutely don't use Skybolts on the underside of the cowl (IMHO). Just too much vibration, oil etc. for them to hold up long term. Ask me how I know? Robin http://www.painttheweb.com/painttheweb/rv-10/SjCowl.aspx Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl-Fitting-6.j pg Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2448.jpg Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2453.jpg Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/100_2450.jpg Description: http://www.painttheweb.com/painttheweb/rv-10/Images/SJ_Cowl/Cowl_Left.jpg -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Thursday, June 28, 2012 5:53 AM Subject: RV10-List: Re: Skybolt Fasteners - Installation peyton.b(at)sbcglobal.net> You should read the thread on VAF regarding the installation using the newer "gray" cowling. It is posted here <http://www.vansairforce.com/community/showthread.php?t=86547&highlight=skyb olt> http://www.vansairforce.com/community/showthread.php?t=86547&highlight=skybo lt There are issues with the new cowling that require grinding out around each one of the fasteners for clearance. In spite of the fact that I went back to the hinge, I should have made the top edge installation work. Using the hinges on the sides makes for a much nicer and stronger joint. The hinge pins remove very easily. Around the top is the area that really sees and improvement in regards to removing and re-installing the cowling. The top hinges, due to the curvature, prevent you from lifting directly upwards to remove the cowl. installing the Skybolt fasteners on the top would be a great improvement. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=376765#376765> http://forums.matronics.com/viewtopic.php?p=376765#376765 ==================== bsp; - The RV10-List Email Forum - o browse scription, , Chat, FAQ, /p> tronics.com/Navigator?RV10-List"> http://www.matronics.com/Navigator?RV10-List ==================== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com">http://forums.matronics.com ==================== bsp; - List Contribution Web Site - o:p> bsp; -Matt Dralle, List Admin. tronics.com/contribution"> http://www.matronics.com/contribution ==================== ________________________________________________________________________________
Date: Jun 29, 2012
Talkeetna, AK is a very cool place to stop on an airplane adventure. It is the jumping off point for 98% of all McKinley climbs and the airplanes that fly there are really neat with the ski/wheel combo gear. They also have a great museum. Stay with Paula at the Northern guest house, uber reasonable and quiet - right across from the airport. If you get a deal on a base camp glacier landing, I will be jealous........not the regular glacier landing that they do at 1500 ft - but the base camp landing at 7000 ft! -------- See you OSH '12 Q/B - flying 2 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376898#376898 ________________________________________________________________________________
Date: Jun 30, 2012
Subject: AirVenture ride wanted
Anyone close to New England flying themselves to AirVenture this year with an empty seat? There's a delightful young woman in our EAA chapter who is looking for a ride. She would, of course, share expenses. We're in Connecticut. --Rick ________________________________________________________________________________
Subject: IO-540 crankcase breather
Date: Jun 30, 2012
All, I was going to use the same crankcase breather oil separator that I have on the 8A http://www.aircraftspruce.com/catalog/eppages/hboilbreather.php but then I noted the IO-540 has a huge crankcase breather fitting for a 1" inside diameter hose. The above separator uses 5/8" hose. This separator works well on the IO-360 in the 8A. Is anyone using this on a IO-540? Does the IO-540 really need a 1" breather hose? Carl ________________________________________________________________________________
Date: Jul 01, 2012
Subject: Re: IO-540 crankcase breather
Yes, the debates with no data. Everything that comes out the breather started in the engine and will be in just as high concentration there. Folks get confused, thinking the separator somehow concentrates contaminates, or condenses water vapor. On Sun, Jul 1, 2012 at 7:06 AM, Rob Kermanj wrote: > > > Also, there are debates regarding putting the oil byproducts in the > breather back into the engine. > > ________________________________________________________________________________
Date: Jul 01, 2012
I don't get any noceable oil out the breather, either. I run about 8 qts as indicated on the dipstick. On Sun, Jul 1, 2012 at 7:43 AM, Kelly McMullen wrote: > Yes, the debates with no data. Everything that comes out the breather > started in the engine and will be in just as high concentration there. > Folks get confused, thinking the separator somehow concentrates > contaminates, or condenses water vapor. > > > On Sun, Jul 1, 2012 at 7:06 AM, Rob Kermanj wrote: > >> >> >> Also, there are debates regarding putting the oil byproducts in the >> breather back into the engine. >> >> > * > > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Subject: Tire Jack
Date: Jul 01, 2012
Has anybody tried this on an RV-10: http://www.aircraftspruce.com/catalog/topages/rvjack.php I'm looking for a traveling jack for changing tires, not a wing jack. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=376995#376995 ________________________________________________________________________________
Subject: Re: Tire Jack
Date: Jul 01, 2012
Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? Also I think our axles are solid? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377009#377009 ________________________________________________________________________________
Subject: FW: Building order
Date: Jul 01, 2012
Guys I have 2 questions about the building order you used when building your -10: - When did you make the empennage attachment to the tail cone? Was it right after finishing the tail cone, without attaching it to rest of the fuselage or only after attaching the tail cone to the rest of the fuselage? - When did you begin the wiring in the fuselage? Was it before or after installing the fibreglass cabin cover? Best Carlos ________________________________________________________________________________
Subject: Re: FW: Building order
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jul 01, 2012
I attached the tail cone to the fuse, then final mounted the empannage after that. I'd wire as much as you can before landing gear and before cabin top. The l anding gear makes the plane real tall and the cabin top gets in the way for w iring. In the end, it doesn't matter, but I found it easier to wire with it low to the ground and open. -Mike Kraus RV-10 Flying and Painted! Sent from my iPhone On Jul 1, 2012, at 6:37 PM, "Carlos Trigo" wrote: > Guys > > I have 2 questions about the building order you used when building your -1 0: > - When did you make the empennage attachment to the tail cone? Was it ri ght after finishing the tail cone, without attaching it to rest of the fusel age or only after attaching the tail cone to the rest of the fuselage? > - When did you begin the wiring in the fuselage? Was it before or after i nstalling the fibreglass cabin cover? > > Best > Carlos > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 01, 2012
On my =9310, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com ________________________________________________________________________________
Date: Jul 01, 2012
Same as Bob. Except for shop dolly which sounds like a great idea. Tom Hanaway N518TP 42.6 hours From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: Sunday, July 01, 2012 7:19 PM Subject: Re: RV10-List: FW: Building order On my =9310, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com ________________________________________________________________________________
Date: Jul 01, 2012
I recall a leaver arm and wire cable set up that worked on the 2 place RV's. Sorry no further info but seemed to be a nifty design and easy to replicate in your shop if so inclined. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Sunday, July 01, 2012 3:01 PM Subject: RV10-List: Re: Tire Jack Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? Also I think our axles are solid? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377009#377009 ________________________________________________________________________________
Date: Jul 01, 2012
Don't attach the cabin cover if you are planning on installing and overhead c onsole. It is easy to install with the cabin cover upside down. The same goes for the upper fuselage assembly. I wired my panel with the u pper fuselage assembly on the dining room table. Much easier than one the airplane. It also goes on and off the aircraft with the cabin cover install . I think on the gear made wiring easier. You can stand along the fuselage an d not have to bend over all the time. I'm just now fiberglassing the cabin cover and putting in the windows as one of the last tasks to complete The good thing about this is that there is no right way, just whatever works for you. Sent from my iPad On Jul 1, 2012, at 6:57 PM, Michael Kraus wrote : > I attached the tail cone to the fuse, then final mounted the empannage aft er that. > > I'd wire as much as you can before landing gear and before cabin top. The landing gear makes the plane real tall and the cabin top gets in the way fo r wiring. In the end, it doesn't matter, but I found it easier to wire with it low to the ground and open. > > -Mike Kraus > RV-10 Flying and Painted! > > Sent from my iPhone > > On Jul 1, 2012, at 6:37 PM, "Carlos Trigo" wrote: > >> Guys >> >> I have 2 questions about the building order you used when building your - 10: >> - When did you make the empennage attachment to the tail cone? Was it r ight after finishing the tail cone, without attaching it to rest of the fuse lage or only after attaching the tail cone to the rest of the fuselage? >> - When did you begin the wiring in the fuselage? Was it before or after installing the fibreglass cabin cover? >> >> Best >> Carlos >> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 01, 2012
Bob Turner wrote: > Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? > Also I think our axles are solid? I sort of thought the same thing, but I'd like to have something for my upcoming OSH trip followed by the Great NorthWest. Bound to need it somewhere. Planning on the whole week at OSH, followed by Glacier, spots in between, possibly the Pacific, then point it back towards Georgia. My fly rod will be close at hand (g). John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377026#377026 ________________________________________________________________________________
Date: Jul 02, 2012
Bob Can you please explain to a non-native English speaker what do you mean by a shop "dolly" Thanks Carlos _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: segunda-feira, 2 de Julho de 2012 0:19 Subject: Re: RV10-List: FW: Building order On my -10, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com ________________________________________________________________________________
Date: Jul 01, 2012
It is also easier to finish the cabin top (paint or in my case a headliner) with it off the fuselage and upside down. Windows are last on the list - and after final interior paint. Then comes a year or so of fiberglass prep. Doing the fiberglass structure is easy - getting it to look like something you want your name associated with is way hard. Do not fit the wingtips until after you do the trial wing attachment to the fuselage, and after you are absolutely sure you have proper rigging on the flaps and ailerons. The wing tips can move an inch or so up and down so make sure they line up with the correct aileron placement before you drill the mounting holes. I did everything up to engine mount and first wing fit with the fuselage in the basement on short legs bolted to the spar. Carl 17 hrs and still chasing my tail trying to get the wheel pants and gear leg fairings properly aligned. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Sunday, July 01, 2012 7:31 PM Subject: Re: RV10-List: FW: Building order Don't attach the cabin cover if you are planning on installing and overhead console. It is easy to install with the cabin cover upside down. The same goes for the upper fuselage assembly. I wired my panel with the upper fuselage assembly on the dining room table. Much easier than one the airplane. It also goes on and off the aircraft with the cabin cover install. I think on the gear made wiring easier. You can stand along the fuselage and not have to bend over all the time. I'm just now fiberglassing the cabin cover and putting in the windows as one of the last tasks to complete The good thing about this is that there is no right way, just whatever works for you. Sent from my iPad On Jul 1, 2012, at 6:57 PM, Michael Kraus wrote: I attached the tail cone to the fuse, then final mounted the empannage after that. I'd wire as much as you can before landing gear and before cabin top. The landing gear makes the plane real tall and the cabin top gets in the way for wiring. In the end, it doesn't matter, but I found it easier to wire with it low to the ground and open. -Mike Kraus RV-10 Flying and Painted! Sent from my iPhone On Jul 1, 2012, at 6:37 PM, "Carlos Trigo" wrote: Guys I have 2 questions about the building order you used when building your -10: - When did you make the empennage attachment to the tail cone? Was it right after finishing the tail cone, without attaching it to rest of the fuselage or only after attaching the tail cone to the rest of the fuselage? - When did you begin the wiring in the fuselage? Was it before or after installing the fibreglass cabin cover? Best Carlos D======================== =================== List"">http://www.matronics.com/Navigator?RV10-List D======================== =================== //forums.matronics.com D======================== =================== ot;">http://www.matronics.com/contribution D======================== =================== ________________________________________________________________________________
Date: Jul 01, 2012
Carlos, I made a roll around platform from 2 sheets of (4 x 8 ) plywood screwed to a 2=9D x 6=9D framework, attached swivel casters to the platform. In the attached photo you=99ll see the fuse sitting on the dolly. Bob From: Carlos Trigo Sent: Sunday, July 01, 2012 7:51 PM Subject: RE: RV10-List: FW: Building order Bob Can you please explain to a non-native English speaker what do you mean by a shop =9Cdolly=9D Thanks Carlos ------------------------------------------------------------------------- ------- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: segunda-feira, 2 de Julho de 2012 0:19 Subject: Re: RV10-List: FW: Building order On my =9310, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Subject: Re: Building order
Date: Jul 01, 2012
Same as Bob Newman, including the dolly. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377039#377039 ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 01, 2012
I just have the standard breather that exits over the exhaust pipe. I add a quart when it gets to 8. I clean the belly two or three times a year, which takes about 15 minutes. I get a drip on the floor if it doesn't fly for a couple weeks--never any more than that. Dave Saylor 831-750-0284 CL 1087 hours On Sun, Jul 1, 2012 at 11:21 AM, Rob Kochman wrote: > I don't get any noceable oil out the breather, either. I run about 8 qts > as indicated on the dipstick. > > On Sun, Jul 1, 2012 at 7:43 AM, Kelly McMullen wrote: > >> Yes, the debates with no data. Everything that comes out the breather >> started in the engine and will be in just as high concentration there. >> Folks get confused, thinking the separator somehow concentrates >> contaminates, or condenses water vapor. >> >> >> On Sun, Jul 1, 2012 at 7:06 AM, Rob Kermanj wrote: >> >>> >>> >>> Also, there are debates regarding putting the oil byproducts in the >>> breather back into the engine. >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> >> ttp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > * > > ________________________________________________________________________________
Date: Jul 01, 2012
just for clarity, 1 sheet of plywood, ripped in half, so final dolly size was 2=99 x 8=99. From: bob-tcw Sent: Sunday, July 01, 2012 8:18 PM Subject: Re: RV10-List: FW: Building order Carlos, I made a roll around platform from 2 sheets of (4 x 8 ) plywood screwed to a 2=9D x 6=9D framework, attached swivel casters to the platform. In the attached photo you=99ll see the fuse sitting on the dolly. Bob From: Carlos Trigo Sent: Sunday, July 01, 2012 7:51 PM Subject: RE: RV10-List: FW: Building order Bob Can you please explain to a non-native English speaker what do you mean by a shop =9Cdolly=9D Thanks Carlos ------------------------------------------------------------------------- ------- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: segunda-feira, 2 de Julho de 2012 0:19 Subject: Re: RV10-List: FW: Building order On my =9310, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: : RV10-List:Dolly (was Building order)
Date: Jul 02, 2012
Thanks Bob Looks good, and indeed it seems to be a very good idea. Carlos _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: segunda-feira, 2 de Julho de 2012 1:19 Subject: Re: RV10-List: FW: Building order Carlos, I made a roll around platform from 2 sheets of (4 x 8 ) plywood screwed to a 2" x 6" framework, attached swivel casters to the platform. In the attached photo you'll see the fuse sitting on the dolly. Bob From: Carlos Trigo <mailto:trigo(at)mail.telepac.pt> Sent: Sunday, July 01, 2012 7:51 PM Subject: RE: RV10-List: FW: Building order Bob Can you please explain to a non-native English speaker what do you mean by a shop "dolly" Thanks Carlos _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob-tcw Sent: segunda-feira, 2 de Julho de 2012 0:19 Subject: Re: RV10-List: FW: Building order On my -10, 1) checked fit of empennage to tail cone, then removed for painting, did not re-install until final assembly at airport. 2) did 99% of all wiring with cabin top off and fuse not on the landing gear, but on shop dolly for much better access and mobility. Bob Newman N541RV 70 hrs. www.tcwtech.com http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Jul 02, 2012
A normal small sedan scissor jack fits in under the brake side of the axle on 2 place revs (rv6 etc) is cheap, available and allows full removal of the wheel, a safety block under the axle when the wheel is removed is agood idea. On the RV10 a small mod is required to the jack because the front bottom brake attach bolt sticks out & the jack will contact that before the axle, would probably be OK but I prefer to take the weight on the axle. A rag or piece of rubber between the axle & jack prevents any marks,damage etc to the axle. If you think you need to fly with a jack in baggage this one is light safe & does not contain any oil that could leak. Cheers Greg. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377066#377066 ________________________________________________________________________________
Date: Jul 02, 2012
With regards to making a dolly to move the fuselage around. I adapted some tires during construction to allow me to roll the fuselage around. Pictures are attached. Fuselage remained low to make it easy to work on and It was easily moved around. Jim Combs N312F I gave these to someone on the list to use and forward to another builder when then finished. On Sun, Jul 1, 2012 at 6:37 PM, Carlos Trigo wrote: > Guys**** > > ** ** > > I have 2 questions about the building order you used when building your > -10:**** > > - When did you make the empennage attachment to the tail cone? Was it > right after finishing the tail cone, without attaching it to rest of the > fuselage or only after attaching the tail cone to the rest of the fuselage? > **** > > - When did you begin the wiring in the fuselage? Was it before or after > installing the fibreglass cabin cover?**** > > ** ** > > Best**** > > Carlos**** > > * > > * > > ________________________________________________________________________________
Subject: Dolly (was Building order)
Date: Jul 02, 2012
Thanks Jim Also a smart idea BR Carlos _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Combs Sent: segunda-feira, 2 de Julho de 2012 15:10 Subject: Re: RV10-List: FW: Building order With regards to making a dolly to move the fuselage around. I adapted some tires during construction to allow me to roll the fuselage around. Pictures are attached. Fuselage remained low to make it easy to work on and It was easily moved around. Jim Combs N312F I gave these to someone on the list to use and forward to another builder when then finished. ________________________________________________________________________________
Subject: Re: Dolly (was Building order)
Date: Jul 02, 2012
I'm in the printing business, so we have a lot of pallets sitting around. The larger ones, with big runners, make perfect platforms for building the fuse. I put a set of wheels on one and it was quite handy. When it came time to lift the plane up to put it on the gear, or to lift it off the ground (once on the gear) to fit the wheel pants, I just slid a scissor jack under the pallet and up she went: Jeff Carpenter 40304 On Jul 2, 2012, at 8:38 AM, Carlos Trigo wrote: > Thanks Jim > > Also a smart idea > > BR > Carlos > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Jim Combs > Sent: segunda-feira, 2 de Julho de 2012 15:10 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: FW: Building order > > With regards to making a dolly to move the fuselage around. I > adapted some tires during construction to allow me to roll the > fuselage around. > > Pictures are attached. > > Fuselage remained low to make it easy to work on and It was easily > moved around. > > Jim Combs > N312F > > I gave these to someone on the list to use and forward to another > builder when then finished. > > ________________________________________________________________________________
Date: Jul 03, 2012
Subject: Condition Inspection Checklist
Date: Jul 03, 2012
Does anyone have a good condition inspection checklist available? I had a good one from my RV-4 that I have converted for use on my RV-10, but thought I'd cross reference it with other good ones to make a master checklist of my liking. Thanks Michael Kraus RV-10 Flying ________________________________________________________________________________
Subject: Re: Condition Inspection Checklist
Date: Jul 03, 2012
Here's mine that I modified from one that I got from A&P Brian Wallis over on VAF. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377142#377142 Attachments: http://forums.matronics.com//files/728tt_annual_condition_inspection_checklist_181.doc ________________________________________________________________________________
Date: Jul 03, 2012
Here is Mine. Jim C N312F On Tue, Jul 3, 2012 at 10:44 AM, Michael Kraus wrote: > > > > Does anyone have a good condition inspection checklist available? I had a > good one from my RV-4 that I have converted for use on my RV-10, but > thought I'd cross reference it with other good ones to make a master > checklist of my liking. > > Thanks > > Michael Kraus > RV-10 Flying > > ________________________________________________________________________________
Date: Jul 03, 2012
Get your wiring and pneumatic tubing in BEFORE it's up on the legs and BEFORE the canopy is on - unless you are a contortionist.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377163#377163 ________________________________________________________________________________
Date: Jul 03, 2012
Although not part of the requirements for the condition inspection, this is a very convenient time to test the ELT, and write it into the records. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377172#377172 ________________________________________________________________________________
Date: Jul 03, 2012
I was consistently getting 2-3 drops of oil on the hanger floor where it ran down from the breather tube to the exhaust pipe. I installed Van's breather (slime fighter I think) and it has stopped it completely. -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377174#377174 ________________________________________________________________________________
Date: Jul 04, 2012
Yep, Alex sells them... http://www.rvtraining.com/html/atp/html/accessories.html Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, July 01, 2012 6:28 PM Subject: RE: RV10-List: Re: Tire Jack I recall a leaver arm and wire cable set up that worked on the 2 place RV's. Sorry no further info but seemed to be a nifty design and easy to replicate in your shop if so inclined. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Sunday, July 01, 2012 3:01 PM Subject: RV10-List: Re: Tire Jack Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? Also I think our axles are solid? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377009#377009 ________________________________________________________________________________
Subject: Starter relay issue
Date: Jul 04, 2012
Has anyone else had any issues recently with the tabs on the starter bein g narrower than the predefined nutplates allow? I just got a relay from Air craft Spruce and it looks to be =BC to =BD inch too narrow and there is no overlap for a bolt at all. I checked Vans site in case there is a differen ce but the picture on there looks to be the same as the one I just got from Spruce. Michael ________________________________________________________________________________
Date: Jul 04, 2012
Looks like a nice system but a bit long for travel. Michael do you use one on your 10? Robin Sent from the new iPad On Jul 3, 2012, at 6:59 PM, "Michael Sausen" wrote: > > Yep, Alex sells them... > > http://www.rvtraining.com/html/atp/html/accessories.html > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks > Sent: Sunday, July 01, 2012 6:28 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Re: Tire Jack > > > I recall a leaver arm and wire cable set up that worked on the 2 place RV's. Sorry no further info but seemed to be a nifty design and easy to replicate in your shop if so inclined. > > Robin > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Sunday, July 01, 2012 3:01 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Tire Jack > > > Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? > Also I think our axles are solid? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=377009#377009 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Starter relay issue
Date: Jul 04, 2012
Hi Michael, I ran into exactly the same problem with the Spruce sourced relay, also having checked the illustrations and thinking they were identical. It really surprised me that there are seemingly two different standards but no hint of this on the ACS webpage. I filed out slots in both tabs to within 40-60thou of each side, and can get the bolts in OK. However I also found it sits too low and touches the oil cooler mount. I few degrees of tweak in the brackets should relieve that, but its certainly not ideal. I will live with it for now but order the Van's one as a spare. Cheers, Gordon On Jul 4, 2012, at 3:59 AM, Michael Sausen wrote: > Has anyone else had any issues recently with the tabs on the starter being narrower than the predefined nutplates allow? I just got a relay from Aircraft Spruce and it looks to be to inch too narrow and there is no overlap for a bolt at all. I checked Vans site in case there is a difference but the picture on there looks to be the same as the one I just got from Spruce. > > Michael > ________________________________________________________________________________
Date: Jul 04, 2012
No.....The jack I described is the simple screw with a handle one that can be found in most small/medium sedans, no long levers or heavy hydraulic units that would crash around your baggage compartment. Cheers Greg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377228#377228 ________________________________________________________________________________
Subject: avipak strobes not firing during flight
Date: Jul 04, 2012
Just did my first night flight after completing phase 1. I have an Avipak box firing wing and tail strobes. If it's just on battery power on the ground, all strobes work fine. Once flying, the strobes stopped firing. If I switched them off and on, I could see the wing tips flashing for one or two sequences, then nothing. When I returned to ground and shut down engine, the strobes were working fine again. My guess is it's somehow connected to alternator output, which would increase at cruise power. However, no issues with any other electronics. Any suggestions appreciated. __________________ Tom Hanaway Boynton Beach, FL RV-10/N518TP Phase I completed 6/12/2012 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377229#377229 ________________________________________________________________________________
Date: Jul 04, 2012
Nope, just remember seeing it on his site. Michael On Jul 3, 2012, at 10:26 PM, "Robin Marks" wrote: > > Looks like a nice system but a bit long for travel. > Michael do you use one on your 10? > > Robin > > Sent from the new iPad > > On Jul 3, 2012, at 6:59 PM, "Michael Sausen" wrote: > >> >> Yep, Alex sells them... >> >> http://www.rvtraining.com/html/atp/html/accessories.html >> >> Michael >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks >> Sent: Sunday, July 01, 2012 6:28 PM >> To: rv10-list(at)matronics.com >> Subject: RE: RV10-List: Re: Tire Jack >> >> >> I recall a leaver arm and wire cable set up that worked on the 2 place RV's. Sorry no further info but seemed to be a nifty design and easy to replicate in your shop if so inclined. >> >> Robin >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner >> Sent: Sunday, July 01, 2012 3:01 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Re: Tire Jack >> >> >> Isn't that thing in the way of changing a tire? Looks like you still need a jack stand somewhere? >> Also I think our axles are solid? >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=377009#377009 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Subject: Re: OSH 2012 RV-10 Group Camping
Date: Jul 05, 2012
Since time is getting close I'm bumping this in case anybody that's interested missed the original posting. When you purchase your sites you must send me your ticket info or else I have no way of knowing and won't stake out your site! Other helpful info to include would be what you're camping in (Class A, Class C, Fifth Wheel, tent, etc) and what length it is. Standard sites are 20x30 however there is some latitude to accommodate larger campers/motorhomes. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377330#377330 ________________________________________________________________________________
Date: Jul 05, 2012
Here is my info EAA# 199107 Ticket ID 206961998 July 16th, $336 Thanks Gary ----- Original Message ----- From: "bcondrey" <condreyb(at)gmail.com> Sent: Thursday, July 5, 2012 10:39:13 AM Subject: RV10-List: Re: OSH 2012 RV-10 Group Camping Since time is getting close I'm bumping this in case anybody that's interes ted missed the original posting. When you purchase your sites you must send me your ticket info or else I ha ve no way of knowing and won't stake out your site! =C2-Other helpful inf o to include would be what you're camping in (Class A, Class C, Fifth Wheel , tent, etc) and what length it is. =C2-Standard sites are 20x30 however there is some latitude to accommodate larger campers/motorhomes. =C2- Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377330#377330 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: avipak strobes not firing during flight
Date: Jul 05, 2012
Latest detective work [Rolling Eyes] Thought I'd test my capacitor theory. Turned battery on, engine off, switched strobes on. Fired perfectly for about 4 minutes and then stopped. Turned switch off, waited thirty seconds, turned on again and they flashed about 3 times. Left switch and battery on and tested voltage at the Avipak box. It was getting 12VDC and not firing. So, black box is faulty. Unfortunately, the Avipak brand is out of business and Nova does not support them, Whelen power pack ordered. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377366#377366 ________________________________________________________________________________
Date: Jul 05, 2012
did you call strobes n more? they have a Avipak version strobe system. -----Original Message----- From: tomhanaway Sent: Thursday, July 05, 2012 2:43 PM Subject: RV10-List: Re: avipak strobes not firing during flight Latest detective work [Rolling Eyes] Thought I'd test my capacitor theory. Turned battery on, engine off, switched strobes on. Fired perfectly for about 4 minutes and then stopped. Turned switch off, waited thirty seconds, turned on again and they flashed about 3 times. Left switch and battery on and tested voltage at the Avipak box. It was getting 12VDC and not firing. So, black box is faulty. Unfortunately, the Avipak brand is out of business and Nova does not support them, Whelen power pack ordered. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377366#377366 ________________________________________________________________________________
Date: Jul 05, 2012
Pascal, I looked at the strobesnmore website but the flashers operated at more flashes per minute than I wanted. I feel more comfortable with Whelen's aircraft specific strobe power. Interestingly, Whelen mentions that power supplies that have not been used for a long period of time (the guide references earlier year models), may lose polarity in the capacitor. Thus, when subjected to full 12VDC power, they quickly overheat. This sounds like what was happening to mine. It's certainly sat for a long time not being used. The fix is to run 75% power to the unit for 10 or 15 minutes to reconfigure the capacitor. I may try this. I suspect a standard 9v battery may not have enough power but I can't think of any other 9v source. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377376#377376 ________________________________________________________________________________
Date: Jul 05, 2012
Good to hear! I wonder if a battery charger would work? When I was doing my panel hookup I used a computer power supply that was "surplus" to me and I also used a RC battery charger. Both were enough to power the strobes and LED position lights. Easy hookup with alligator clips. The 9v battery did work for my LED's but they weren't enough for the strobe power supply. May be worth a try however. Best of success with this! Pascal -----Original Message----- From: tomhanaway Sent: Thursday, July 05, 2012 5:09 PM Subject: RV10-List: Re: avipak strobes not firing during flight Pascal, I looked at the strobesnmore website but the flashers operated at more flashes per minute than I wanted. I feel more comfortable with Whelen's aircraft specific strobe power. Interestingly, Whelen mentions that power supplies that have not been used for a long period of time (the guide references earlier year models), may lose polarity in the capacitor. Thus, when subjected to full 12VDC power, they quickly overheat. This sounds like what was happening to mine. It's certainly sat for a long time not being used. The fix is to run 75% power to the unit for 10 or 15 minutes to reconfigure the capacitor. I may try this. I suspect a standard 9v battery may not have enough power but I can't think of any other 9v source. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377376#377376 ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Jul 06, 2012
Don't hook a battery charger up to the Aircraft's Busses unless there is a battery as well! The lack of regulation and the ripple on the battery charger's output will do bad things to the Avionics! A computer power supply should be ok but I would still leave a battery in parallel just as insurance. Cheers John MacCallum Builder #41016 VH-DUU -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Friday, 6 July 2012 10:23 AM Subject: Re: RV10-List: Re: avipak strobes not firing during flight Good to hear! I wonder if a battery charger would work? When I was doing my panel hookup I used a computer power supply that was "surplus" to me and I also used a RC battery charger. Both were enough to power the strobes and LED position lights. Easy hookup with alligator clips. The 9v battery did work for my LED's but they weren't enough for the strobe power supply. May be worth a try however. Best of success with this! Pascal -----Original Message----- From: tomhanaway Sent: Thursday, July 05, 2012 5:09 PM Subject: RV10-List: Re: avipak strobes not firing during flight Pascal, I looked at the strobesnmore website but the flashers operated at more flashes per minute than I wanted. I feel more comfortable with Whelen's aircraft specific strobe power. Interestingly, Whelen mentions that power supplies that have not been used for a long period of time (the guide references earlier year models), may lose polarity in the capacitor. Thus, when subjected to full 12VDC power, they quickly overheat. This sounds like what was happening to mine. It's certainly sat for a long time not being used. The fix is to run 75% power to the unit for 10 or 15 minutes to reconfigure the capacitor. I may try this. I suspect a standard 9v battery may not have enough power but I can't think of any other 9v source. Tom Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377376#377376 ________________________________________________________________________________
Date: Jul 07, 2012
Possibly try several 9 V batteries connected in parallel? Jason. On Jul 6, 2012 4:55 AM, "Pascal" wrote: > > Good to hear! > I wonder if a battery charger would work? When I was doing my panel hookup > I used a computer power supply that was "surplus" to me and I also used a > RC battery charger. Both were enough to power the strobes and LED position > lights. Easy hookup with alligator clips. > The 9v battery did work for my LED's but they weren't enough for the > strobe power supply. May be worth a try however. > Best of success with this! > Pascal > > -----Original Message----- From: tomhanaway > Sent: Thursday, July 05, 2012 5:09 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: avipak strobes not firing during flight > > > Pascal, > I looked at the strobesnmore website but the flashers operated at more > flashes per minute than I wanted. I feel more comfortable with Whelen's > aircraft specific strobe power. > > Interestingly, Whelen mentions that power supplies that have not been used > for a long period of time (the guide references earlier year models), may > lose polarity in the capacitor. Thus, when subjected to full 12VDC power, > they quickly overheat. This sounds like what was happening to mine. It's > certainly sat for a long time not being used. > The fix is to run 75% power to the unit for 10 or 15 minutes to > reconfigure the capacitor. I may try this. I suspect a standard 9v > battery may not have enough power but I can't think of any other 9v source. > > Tom > > > Read this topic online here: > > http://forums.matronics.com/**viewtopic.php?p=377376#377376> > > ________________________________________________________________________________
Date: Jul 07, 2012
My whelan power supply pulls 7 amps. That takes a pretty sizeable battery. -------- Bob Turner RV-10 QB Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=377523#377523 ________________________________________________________________________________
Subject: FS: 121.5 ELT
Date: Jul 09, 2012
While we're going there.. and your Cessna ;-) -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roger Standley Sent: Monday, July 09, 2012 7:31 PM Subject: Re: RV10-List: FS: 121.5 ELT and your hand-held mic... ________________________________________________________________________________
Subject: Flap Positioner
Date: Jul 10, 2012
Hi Guys About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo email account was hijacked, I lost that photo. A search of the archives only turned up a discussion, no photo. Anyone have that photo handy? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Jul 10, 2012
Here are some I've found searching through my outlook folder. http://forums.matronics.com/files/img_1417_171.jpg http://forums.matronics.com/files/flap_and_aoa_switch_151.jpg From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Tuesday, July 10, 2012 9:19 AM Subject: RV10-List: Flap Positioner Hi Guys About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo email account was hijacked, I lost that photo. A search of the archives only turned up a discussion, no photo. Anyone have that photo handy? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: AFS AOA flap switch
Date: Jul 10, 2012
Another from Michael Kraus w/attached pics -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Saturday, January 22, 2011 11:31 AM Subject: Re: RV10-List: AFS AOA flap switch This is what I did. I riveted a tab on the flap mechanism and mounted the switch on the bulkhead behind the flap weldments (see photos). ________________________________________________________________________________
Subject: Re: Flap Positioner
Date: Jul 10, 2012
That may have been mine. Here is a link to the picture. http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg -Mike Kraus RV-10 Flying Sent from my iPhone On Jul 10, 2012, at 12:19 PM, "Rick Lark" wrote: > Hi Guys > > About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo ema il account was hijacked, I lost that photo. A search of the archives only t urned up a discussion, no photo. Anyone have that photo handy? > > Thx, Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 10, 2012
I found a pic in the advanced flight systems manual which showed essentially how I did it. -----Original Message----- From: Rick Lark Sent: Jul 10, 2012 12:19 PM Subject: RV10-List: Flap Positioner Hi Guys About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo email account was hijacked, I lost that photo. A search of the archives only turned up a discussion, no photo. Anyone have that photo handy? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Jul 10, 2012
I also used this but be aware the movement us not linear also don't overexte nd the POS or it will break. Alan Sent from my iPhone On Jul 10, 2012, at 12:38 PM, Michael Kraus wro te: > That may have been mine. Here is a link to the picture. > > http://forums.matronics.com//files/flap_and_aoa_switch_151.jpg > > -Mike Kraus > RV-10 Flying > > Sent from my iPhone > > On Jul 10, 2012, at 12:19 PM, "Rick Lark" wrote: > >> Hi Guys >> >> About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo ema il account was hijacked, I lost that photo. A search of the archives only t urned up a discussion, no photo. Anyone have that photo handy? >> >> Thx, Rick >> #40956 >> Southampton, Ont >> >> >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: RV-10 Flap position indicator
Date: Jul 10, 2012
Here is a video of one in action from Brian and Brandi Urein's plane. Looks simple. Phil Check out this video on YouTube: http://www.youtube.com/watch?v=9nYpkSUtW_s&feature=youtube_gdata_player Sent from my iPhone ________________________________________________________________________________
Date: Jul 10, 2012
Subject: Fuel Cap Engraving and Data Plate Engraving
From: Aircraft Specialty <aircraftspecialty(at)gmail.com>
Just wanted to let everyone know that we are now fully up and running from an engraving standpoint. We have the capability to do Usher Fuel Caps, Andair Fuel Caps, and also the Newton Style "Deluxe" caps that Van's sells. Our prices are extremely competitive and we make it easy to design your cap online. If you don't see a style you like, or would like to do something custom, please contact me and I will absolutely work with you to make your caps however you like. You can see our engraving options at www.aircraftspecialty.com/engraving.html Attached is a picture of an engraved cap. Steve Aircraft Specialty www.aircraftspecialty.com www.kitplanehoses.com www.kitplanemods.com ________________________________________________________________________________
Subject: broken down in Eugene Oregon
Date: Jul 10, 2012
Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a mo nth .Thought I had the problem resolved but it returned.Oil pressure increa ses during flight to redline -it is not likely a gauge issue as i have comp ared the electronic gauge with a mechanical and they match.Any one have a s imilar experience. Engine is a narrow deck 540 converted to an io-540.I ove rhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replace d the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and cl ean ball seat and springs on pressure regulator.If problem doesnt resolve i t means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize, I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim ________________________________________________________________________________
Date: Jul 10, 2012
It's a lovely installation so I copied it too. Just beware that if you squeeze the two rivets holding the sensor to the aluminum plate as much as "normal" you will split the sensor flanges, so go easy. Using screws and nuts is probably more clever. Gordon 41015 Switzerland On Jul 10, 2012, at 6:34 PM, Ben Westfall wrote: > Here are some I=92ve found searching through my outlook folder=85 > > http://forums.matronics.com/files/img_1417_171.jpg > http://forums.matronics.com/files/flap_and_aoa_switch_151.jpg > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark > Sent: Tuesday, July 10, 2012 9:19 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Flap Positioner > > Hi Guys > > About a year ago someone published a photo of a really neat way to mount a Ray Allen POS-12 positioner for the flaps. Unfortunately when my Yahoo email account was hijacked, I lost that photo. A search of the archives only turned up a discussion, no photo. Anyone have that photo handy? > > Thx, Rick > #40956 > Southampton, Ont > > > > ________________________________________________________________________________
Subject: Re: broken down in Eugene Oregon
Date: Jul 10, 2012
I need more details on the high oil pressure first five minutes.. what is the oil pressure? what is the oil temperature? I see as high as 110psi on take off with my oil at 100f, lasts about 2-3 minutes until the oil is warmed up (aka 165 or above) than the pressure goes into the normal 89-92 psi range. 115psi and below is normal for the first 5 minutes (start-up taxiing and takeoff) per Lycoming.. what are you seeing? Pascal From: pilotdds Sent: Tuesday, July 10, 2012 1:14 PM Subject: RV10-List: broken down in Eugene Oregon Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a month .Thought I had the problem resolved but it returned.Oil pressure increases during flight to redline -it is not likely a gauge issue as i have compared the electronic gauge with a mechanical and they match.Any one have a similar experience. Engine is a narrow deck 540 converted to an io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replaced the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and clean ball seat and springs on pressure regulator.If problem doesnt resolve it means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize,I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim ________________________________________________________________________________
Date: Jul 10, 2012
My initial readings are as high as 95-97 psi for about 5 minutes .It doesn' t necessarily change proportionally with temp .In climb my temps will rise to low 200's on a warm day but settle to about 190 in typical cruise.Oil pr essure has dropped to 85 psi range after approximately 5 minutes, i incorre ctly assumed that was when the vernitherm opened.Did I answer your question ? -----Original Message----- From: Pascal <rv10flyer(at)verizon.net> Sent: Tue, Jul 10, 2012 1:47 pm Subject: Re: RV10-List: broken down in Eugene Oregon I need more details on the high oil pressure first five minutes.. what is t he oil pressure? what is the oil temperature? I see as high as 110psi on ta ke off with my oil at 100f, lasts about 2-3 minutes until the oil is warmed up (aka 165 or above) than the pressure goes into the normal 89-92 psi ran ge. 115psi and below is normal for the first 5 minutes (start-up taxiing an d takeoff) per Lycoming.. what are you seeing? Pascal From: pilotdds Sent: Tuesday, July 10, 2012 1:14 PM Subject: RV10-List: broken down in Eugene Oregon Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a mo nth .Thought I had the problem resolved but it returned.Oil pressure increa ses during flight to redline -it is not likely a gauge issue as i have comp ared the electronic gauge with a mechanical and they match.Any one have a s imilar experience. Engine is a narrow deck 540 converted to an io-540.I ove rhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replace d the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and cl ean ball seat and springs on pressure regulator.If problem doesnt resolve i t means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize, I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jul 10, 2012
What do you have as redline?? From the operators manual: Sounds like your oil pressure is normal, unless it is fluctuating wildly. Not the max for startup and warmup. On Tue, Jul 10, 2012 at 1:14 PM, pilotdds wrote: > **Anyone have any contacts for hanger space at KEUG.I have a fluctuating > oil pressure problem and looks like the plane is going to be here at least > a month .Thought I had the problem resolved but it returned.Oil pressure > increases during flight to redline -it is not likely a gauge issue as i > have compared the electronic gauge with a mechanical and they match.Any one > have a similar experience. Engine is a narrow deck 540 converted to an > io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, > lifters.I replaced the cage type oil pressure regulator with an eci > adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery > to sump and remove and clean ball seat and springs on pressure regulator.If > problem doesnt resolve it means engine tear down.One other symptom that is > that pressure always ran about 8 pounds high for the first 5 minutes of > flight the would normalize,I have been advised this is in fact not > normal.Any other thoughts from the engine gurus-thanks Jim > > * > > * > > ________________________________________________________________________________
Date: Jul 10, 2012
Hmm, one email stripped the image, one didn't. Normal redline should be 95, 115 during start and warmup, and minimum 55, except 25 for idling. On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen wrote: > What do you have as redline?? From the operators manual: > > Sounds like your oil pressure is normal, unless it is fluctuating wildly. > Not the max for startup and warmup. > > > On Tue, Jul 10, 2012 at 1:14 PM, pilotdds wrote: > >> **Anyone have any contacts for hanger space at KEUG.I have a fluctuating >> oil pressure problem and looks like the plane is going to be here at least >> a month .Thought I had the problem resolved but it returned.Oil pressure >> increases during flight to redline -it is not likely a gauge issue as i >> have compared the electronic gauge with a mechanical and they match.Any one >> have a similar experience. Engine is a narrow deck 540 converted to an >> io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, >> lifters.I replaced the cage type oil pressure regulator with an eci >> adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery >> to sump and remove and clean ball seat and springs on pressure regulator.If >> problem doesnt resolve it means engine tear down.One other symptom that is >> that pressure always ran about 8 pounds high for the first 5 minutes of >> flight the would normalize,I have been advised this is in fact not >> normal.Any other thoughts from the engine gurus-thanks Jim >> >> * >> >> * >> >> > ________________________________________________________________________________
Date: Jul 10, 2012
I agree! Nothing wrong with those temps or pressure. Sounds quite normal actually. concerning the temps- Oil Temperature: The maximum permissible oil temperature is 245=B0F (118=B0C). For maximum engine life, desired oil temperature should be maintained between 165=B0F (73.8=B0C) and 200=B0F (93.3=B0C) in level flight cruise conditions. Pascal From: Kelly McMullen Sent: Tuesday, July 10, 2012 2:30 PM Subject: Re: RV10-List: broken down in Eugene Oregon What do you have as redline?? From the operators manual: Sounds like your oil pressure is normal, unless it is fluctuating wildly. Not the max for startup and warmup. On Tue, Jul 10, 2012 at 1:14 PM, pilotdds wrote: Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a month .Thought I had the problem resolved but it returned.Oil pressure increases during flight to redline -it is not likely a gauge issue as i have compared the electronic gauge with a mechanical and they match.Any one have a similar experience. Engine is a narrow deck 540 converted to an io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replaced the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and clean ball seat and springs on pressure regulator.If problem doesnt resolve it means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize,I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 10, 2012
the owners manual from the Cherokee shows 99 as red line-but the concern is the progressive gradual increase in oil pressure during flight it will rea ch 99 which is the max the gauge will read.This is a significant change fro m the previous 350 hours.It fluctuates 3-4 pounds as it gradualy increase. -----Original Message----- From: Kelly McMullen <apilot2(at)gmail.com> Sent: Tue, Jul 10, 2012 2:38 pm Subject: Re: RV10-List: broken down in Eugene Oregon Hmm, one email stripped the image, one didn't. Normal redline should be 95, 115 during start and warmup, and minimum 55, except 25 for idling. On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen wrote: What do you have as redline?? From the operators manual: Sounds like your oil pressure is normal, unless it is fluctuating wildly. N ot the max for startup and warmup. On Tue, Jul 10, 2012 at 1:14 PM, pilotdds wrote: Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a mo nth .Thought I had the problem resolved but it returned.Oil pressure increa ses during flight to redline -it is not likely a gauge issue as i have comp ared the electronic gauge with a mechanical and they match.Any one have a s imilar experience. Engine is a narrow deck 540 converted to an io-540.I ove rhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replace d the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and cl ean ball seat and springs on pressure regulator.If problem doesnt resolve i t means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize, I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim get="_blank">http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank">http://www.matronics.com/contribution -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jul 10, 2012
I used essentially the same setup. Nice part is that you can position the Adel clamp (by choosing how high on the aft spar the hinge is) so that the first 3 degrees of travel translate into as much sensor motion as possible (e.g., sensor arm is perpendicular to the clamp); near full flaps there is less sensor motion per degree of rotation of the torque tube. I had concerns about seeing the difference between reflex (-3) and trail (0) but with this set up it works just fine. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=377947#377947 ________________________________________________________________________________
Date: Jul 10, 2012
I would try to check all the connections from your sender all the way back to the EIS. It turned out I had a failed "but" connector under my panel. Maybe in flight it vibrates, then as the resistance changes, it drives to the max indication of 99 PSI. Worth a try, eliminate the simple stuff first, cheap stuff. Try putting a continuity tester on it and have someone wiggle the wire, and see if you have any problems. Good luck. It took my 3 weeks to figure mine out, I just didnt want to think it could be so simple as a bad connection. Thane ----- Original Message ----- From: pilotdds To: rv10-list(at)matronics.com Sent: Tuesday, July 10, 2012 5:59 PM Subject: Re: RV10-List: broken down in Eugene Oregon the owners manual from the Cherokee shows 99 as red line-but the concern is the progressive gradual increase in oil pressure during flight it will reach 99 which is the max the gauge will read.This is a significant change from the previous 350 hours.It fluctuates 3-4 pounds as it gradualy increase. -----Original Message----- From: Kelly McMullen <apilot2(at)gmail.com> To: rv10-list Sent: Tue, Jul 10, 2012 2:38 pm Subject: Re: RV10-List: broken down in Eugene Oregon Hmm, one email stripped the image, one didn't. Normal redline should be 95, 115 during start and warmup, and minimum 55, except 25 for idling. On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen wrote: What do you have as redline?? From the operators manual: Sounds like your oil pressure is normal, unless it is fluctuating wildly. Not the max for startup and warmup. On Tue, Jul 10, 2012 at 1:14 PM, pilotdds wrote: Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a month .Thought I had the problem resolved but it returned.Oil pressure increases during flight to redline -it is not likely a gauge issue as i have compared the electronic gauge with a mechanical and they match.Any one have a similar experience. Engine is a narrow deck 540 converted to an io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replaced the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and clean ball seat and springs on pressure regulator.If problem doesnt resolve it means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize,I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution get=_blank>http://www.matronics.com/Navigator?RV10-List p://forums.matronics.com blank>http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com 07/10/12 ________________________________________________________________________________
Date: Jul 10, 2012
Consider that the only thing high oil pressure will hurt is seals, possibility of leaks. Cessna in fact runs around 110 psi in their IO-360 engines in 172s these days, with nothing different about the engine other than the adjustment of oil pressure relief. On 7/10/2012 2:59 PM, pilotdds wrote: > the owners manual from the Cherokee shows 99 as red line-but the > concern is the progressive gradual increase in oil pressure during > flight it will reach 99 which is the max the gauge will read.This is a > significant change from the previous 350 hours.It fluctuates 3-4 > pounds as it gradualy increase. > > -----Original Message----- > From: Kelly McMullen <apilot2(at)gmail.com> > To: rv10-list > Sent: Tue, Jul 10, 2012 2:38 pm > Subject: Re: RV10-List: broken down in Eugene Oregon > > Hmm, one email stripped the image, one didn't. Normal redline should > be 95, 115 during start and warmup, and minimum 55, except 25 for idling. > > On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen > wrote: > > What do you have as redline?? From the operators manual: > > Sounds like your oil pressure is normal, unless it is fluctuating > wildly. Not the max for startup and warmup. > > > On Tue, Jul 10, 2012 at 1:14 PM, pilotdds > wrote: > > Anyone have any contacts for hanger space at KEUG.I have a > fluctuating oil pressure problem and looks like the plane is > going to be here at least a month .Thought I had the problem > resolved but it returned.Oil pressure increases during flight > to redline -it is not likely a gauge issue as i have compared > the electronic gauge with a mechanical and they match.Any one > have a similar experience. Engine is a narrow deck 540 > converted to an io-540.I overhauled it myself 350+ hours ago > with new cylinders ,cam, lifters.I replaced the cage type oil > pressure regulator with an eci adjustable.My plan is to remove > oil filter adapter (b&C)and clean gallery to sump and remove > and clean ball seat and springs on pressure regulator.If > problem doesnt resolve it means engine tear down.One other > symptom that is that pressure always ran about 8 pounds high > for the first 5 minutes of flight the would normalize,I have > been advised this is in fact not normal.Any other thoughts > from the engine gurus-thanks Jim > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > * > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 11, 2012
Ok folks, last chance. We're physically leaving to head up to OSH this weekend and I need to take a hardcopy of my list of sites with me to make it easier on the folks working the registration stuff. I've gotten a lot of emails and phone calls offline about camping with us, getting a site, etc. The actual number of people that I've received EAA ticket numbers (for the sites) from however is far less. If you've already gotten your site but not sent me an email with the confirmation ticket number, please take a minute and do it now. If you're procrastinating and just haven't gotten your site registered yet, time is running out! Email me direct at condreyb (at) gmail (dot) com if you've got questions not answered by the first post or the FAQs pointed to in the link (in the first post). Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378011#378011 ________________________________________________________________________________
Date: Jul 11, 2012
Do you still need a place in Eugene? ... by phone On Jul 10, 2012, at 6:50 PM, Kelly McMullen wrote: > > Consider that the only thing high oil pressure will hurt is seals, possibility of leaks. Cessna in fact runs around 110 psi in their IO-360 engines in 172s these days, with nothing different about the engine other than the adjustment of oil pressure relief. > > On 7/10/2012 2:59 PM, pilotdds wrote: >> the owners manual from the Cherokee shows 99 as red line-but the concern is the progressive gradual increase in oil pressure during flight it will reach 99 which is the max the gauge will read.This is a significant change from the previous 350 hours.It fluctuates 3-4 pounds as it gradualy increase. >> >> -----Original Message----- >> From: Kelly McMullen <apilot2(at)gmail.com> >> To: rv10-list >> Sent: Tue, Jul 10, 2012 2:38 pm >> Subject: Re: RV10-List: broken down in Eugene Oregon >> >> Hmm, one email stripped the image, one didn't. Normal redline should be 95, 115 during start and warmup, and minimum 55, except 25 for idling. >> >> On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen > wrote: >> >> What do you have as redline?? From the operators manual: >> >> Sounds like your oil pressure is normal, unless it is fluctuating >> wildly. Not the max for startup and warmup. >> >> >> On Tue, Jul 10, 2012 at 1:14 PM, pilotdds > > wrote: >> >> Anyone have any contacts for hanger space at KEUG.I have a >> fluctuating oil pressure problem and looks like the plane is >> going to be here at least a month .Thought I had the problem >> resolved but it returned.Oil pressure increases during flight >> to redline -it is not likely a gauge issue as i have compared >> the electronic gauge with a mechanical and they match.Any one >> have a similar experience. Engine is a narrow deck 540 >> converted to an io-540.I overhauled it myself 350+ hours ago >> with new cylinders ,cam, lifters.I replaced the cage type oil >> pressure regulator with an eci adjustable.My plan is to remove >> oil filter adapter (b&C)and clean gallery to sump and remove >> and clean ball seat and springs on pressure regulator.If >> problem doesnt resolve it means engine tear down.One other >> symptom that is that pressure always ran about 8 pounds high >> for the first 5 minutes of flight the would normalize,I have >> been advised this is in fact not normal.Any other thoughts >> from the engine gurus-thanks Jim >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> >> * >> >> get=_blank>http://www.matronics.com/Navigator?RV10-List >> p://forums.matronics.com >> blank>http://www.matronics.com/contribution >> >> * >> * >> >> >> * > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Jul 11, 2012
yes probably 2 mos -----Original Message----- From: John Jessen <n212pj(at)gmail.com> Sent: Wed, Jul 11, 2012 2:59 pm Subject: Re: RV10-List: broken down in Eugene Oregon Do you still need a place in Eugene? ... by phone On Jul 10, 2012, at 6:50 PM, Kelly McMullen wrote: Consider that the only thing high oil pressure will hurt is seals, possibi lity f leaks. Cessna in fact runs around 110 psi in their IO-360 engines in 172s hese days, with nothing different about the engine other than the adjustmen t of il pressure relief. On 7/10/2012 2:59 PM, pilotdds wrote: > the owners manual from the Cherokee shows 99 as red line-but the concern is he progressive gradual increase in oil pressure during flight it will reach 99 hich is the max the gauge will read.This is a significant change from the revious 350 hours.It fluctuates 3-4 pounds as it gradualy increase. > > -----Original Message----- > From: Kelly McMullen <apilot2(at)gmail.com> > To: rv10-list > Sent: Tue, Jul 10, 2012 2:38 pm > Subject: Re: RV10-List: broken down in Eugene Oregon > > Hmm, one email stripped the image, one didn't. Normal redline should be 9 5, 15 during start and warmup, and minimum 55, except 25 for idling. > > On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen > wrote: > > What do you have as redline?? From the operators manual: > > Sounds like your oil pressure is normal, unless it is fluctuating > wildly. Not the max for startup and warmup. > > > On Tue, Jul 10, 2012 at 1:14 PM, pilotdds > wrote: > > Anyone have any contacts for hanger space at KEUG.I have a > fluctuating oil pressure problem and looks like the plane is > going to be here at least a month .Thought I had the problem > resolved but it returned.Oil pressure increases during flight > to redline -it is not likely a gauge issue as i have compared > the electronic gauge with a mechanical and they match.Any one > have a similar experience. Engine is a narrow deck 540 > converted to an io-540.I overhauled it myself 350+ hours ago > with new cylinders ,cam, lifters.I replaced the cage type oil > pressure regulator with an eci adjustable.My plan is to remove > oil filter adapter (b&C)and clean gallery to sump and remove > and clean ball seat and springs on pressure regulator.If > problem doesnt resolve it means engine tear down.One other > symptom that is that pressure always ran about 8 pounds high > for the first 5 minutes of flight the would normalize,I have > been advised this is in fact not normal.Any other thoughts > from the engine gurus-thanks Jim > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > > * > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > * > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com -======================== -= - The RV10-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?RV10-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Jul 11, 2012
John C, do you know of anyone? I'll also make some enquiries. ... by phone On Jul 11, 2012, at 3:03 PM, pilotdds wrote: > yes probably 2 mos > > > -----Original Message----- > From: John Jessen <n212pj(at)gmail.com> > To: rv10-list > Sent: Wed, Jul 11, 2012 2:59 pm > Subject: Re: RV10-List: broken down in Eugene Oregon > > > Do you still need a place in Eugene? > > ... by phone > > On Jul 10, 2012, at 6:50 PM, Kelly McMullen wrote: > > > > > Consider that the only thing high oil pressure will hurt is seals, possi bility > of leaks. Cessna in fact runs around 110 psi in their IO-360 engines in 17 2s > these days, with nothing different about the engine other than the adjustm ent of > oil pressure relief. > > > > On 7/10/2012 2:59 PM, pilotdds wrote: > >> the owners manual from the Cherokee shows 99 as red line-but the concer n is > the progressive gradual increase in oil pressure during flight it will rea ch 99 > which is the max the gauge will read.This is a significant change from the > previous 350 hours.It fluctuates 3-4 pounds as it gradualy increase. > >> > >> -----Original Message----- > >> From: Kelly McMullen <apilot2(at)gmail.com> > >> To: rv10-list > >> Sent: Tue, Jul 10, 2012 2:38 pm > >> Subject: Re: RV10-List: broken down in Eugene Oregon > >> > >> Hmm, one email stripped the image, one didn't. Normal redline should be 95, > 115 during start and warmup, and minimum 55, except 25 for idling. > >> > >> On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen > wrote: > >> > >> What do you have as redline?? =46rom the operators manual: > >> > >> Sounds like your oil pressure is normal, unless it is fluctuating > >> wildly. Not the max for startup and warmup. > >> > >> > >> On Tue, Jul 10, 2012 at 1:14 PM, pilotdds >> > wrote: > >> > >> Anyone have any contacts for hanger space at KEUG.I have a > >> fluctuating oil pressure problem and looks like the plane is > >> going to be here at least a month .Thought I had the problem > >> resolved but it returned.Oil pressure increases during flight > >> to redline -it is not likely a gauge issue as i have compared > >> the electronic gauge with a mechanical and they match.Any one > >> have a similar experience. Engine is a narrow deck 540 > >> converted to an io-540.I overhauled it myself 350+ hours ago > >> with new cylinders ,cam, lifters.I replaced the cage type oil > >> pressure regulator with an eci adjustable.My plan is to remove > >> oil filter adapter (b&C)and clean gallery to sump and remove > >> and clean ball seat and springs on pressure regulator.If > >> problem doesnt resolve it means engine tear down.One other > >> symptom that is that pressure always ran about 8 pounds high > >> for the first 5 minutes of flight the would normalize,I have > >> been advised this is in fact not normal.Any other thoughts > >> from the engine gurus-thanks Jim > >> > >> * > >> > >> get="_blank">http://www.matronics.com/Navigator?RV10-List > >> tp://forums.matronics.com > >> _blank">http://www.matronics.com/contribution > >> > >> * > >> > >> > >> > >> * > >> > >> get=_blank>http://www.matronics.com/Navigator?RV10-List > >> p://forums.matronics.com > >> blank>http://www.matronics.com/contribution > >> > >> * > >> * > >> > >> > >> * > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > > > > > > > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 11, 2012
That's a great solution! Just so I understand the geometry and how the Pos senor moves with the flap torque tube, in the pics posted in this thread are the flaps up? IOW full retraction of the sensor's arm indicates flaps up while full extension of the arm would indicate flaps fully extended. -------- Todd Stovall 728TT (reserved) RV-10 Empacone, Wings, Fuse www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378052#378052 ________________________________________________________________________________
Date: Jul 11, 2012
Todd, as I see it, the Ray Allen has a strictly linear motion, but because there are 2 pivot points (hinge and attachment to the adele clamp), as the sensor retracts, then yes the flaps are up. Having said that you might be able to position the sensor/clamp else where and get just the opposite indications. I think it will sort itself out with all the componets "in hand". Hopefully someone who has already done this will confirm. Rick #40956 On Wed, Jul 11, 2012 at 8:50 PM, tsts4 wrote: > > That's a great solution! Just so I understand the geometry and how the > Pos senor moves with the flap torque tube, in the pics posted in this > thread are the flaps up? IOW full retraction of the sensor's arm indicates > flaps up while full extension of the arm would indicate flaps fully > extended. > > -------- > Todd Stovall > 728TT (reserved) > RV-10 Empacone, Wings, Fuse > www.mykitlog.com/auburntsts > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=378052#378052 > > ________________________________________________________________________________
Date: Jul 11, 2012
I'm doing this from memory but I think you've got it backwards. Photos show full flaps, with sensor arm fully retracted. As the flaps retract the arm moves aft as well as down. As flaps approach fully retracted, the sensor arm is moving down and not fore or aft, maximizing its motion relative to the angular rotation of the flap torque tube. Fully extended sensor arm is flaps up. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378060#378060 ________________________________________________________________________________
Date: Jul 11, 2012
I've put out some feelers. In the meantime, maybe contact Synergy Air, an RV build assist outfit located in Eugene. They might know someone with availab le space. Their website is at http://synergyair.com/contact-us/ And phone number is: Phone Number: (541) 913-0610 ... by phone On Jul 11, 2012, at 3:03 PM, pilotdds wrote: > yes probably 2 mos > > > -----Original Message----- > From: John Jessen <n212pj(at)gmail.com> > To: rv10-list > Sent: Wed, Jul 11, 2012 2:59 pm > Subject: Re: RV10-List: broken down in Eugene Oregon > > > Do you still need a place in Eugene? > > ... by phone > > On Jul 10, 2012, at 6:50 PM, Kelly McMullen wrote: > > > > > Consider that the only thing high oil pressure will hurt is seals, possi bility > of leaks. Cessna in fact runs around 110 psi in their IO-360 engines in 17 2s > these days, with nothing different about the engine other than the adjustm ent of > oil pressure relief. > > > > On 7/10/2012 2:59 PM, pilotdds wrote: > >> the owners manual from the Cherokee shows 99 as red line-but the concer n is > the progressive gradual increase in oil pressure during flight it will rea ch 99 > which is the max the gauge will read.This is a significant change from the > previous 350 hours.It fluctuates 3-4 pounds as it gradualy increase. > >> > >> -----Original Message----- > >> From: Kelly McMullen <apilot2(at)gmail.com> > >> To: rv10-list > >> Sent: Tue, Jul 10, 2012 2:38 pm > >> Subject: Re: RV10-List: broken down in Eugene Oregon > >> > >> Hmm, one email stripped the image, one didn't. Normal redline should be 95, > 115 during start and warmup, and minimum 55, except 25 for idling. > >> > >> On Tue, Jul 10, 2012 at 2:30 PM, Kelly McMullen > wrote: > >> > >> What do you have as redline?? =46rom the operators manual: > >> > >> Sounds like your oil pressure is normal, unless it is fluctuating > >> wildly. Not the max for startup and warmup. > >> > >> > >> On Tue, Jul 10, 2012 at 1:14 PM, pilotdds >> > wrote: > >> > >> Anyone have any contacts for hanger space at KEUG.I have a > >> fluctuating oil pressure problem and looks like the plane is > >> going to be here at least a month .Thought I had the problem > >> resolved but it returned.Oil pressure increases during flight > >> to redline -it is not likely a gauge issue as i have compared > >> the electronic gauge with a mechanical and they match.Any one > >> have a similar experience. Engine is a narrow deck 540 > >> converted to an io-540.I overhauled it myself 350+ hours ago > >> with new cylinders ,cam, lifters.I replaced the cage type oil > >> pressure regulator with an eci adjustable.My plan is to remove > >> oil filter adapter (b&C)and clean gallery to sump and remove > >> and clean ball seat and springs on pressure regulator.If > >> problem doesnt resolve it means engine tear down.One other > >> symptom that is that pressure always ran about 8 pounds high > >> for the first 5 minutes of flight the would normalize,I have > >> been advised this is in fact not normal.Any other thoughts > >> from the engine gurus-thanks Jim > >> > >> * > >> > >> get="_blank">http://www.matronics.com/Navigator?RV10-List > >> tp://forums.matronics.com > >> _blank">http://www.matronics.com/contribution > >> > >> * > >> > >> > >> > >> * > >> > >> get=_blank>http://www.matronics.com/Navigator?RV10-List > >> p://forums.matronics.com > >> blank>http://www.matronics.com/contribution > >> > >> * > >> * > >> > >> > >> * > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > > > > > > > > get=_blank>http://www.matronics.com/Navigator?RV10-List > p://forums.matronics.com > blank>http://www.matronics.com/contribution > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: flap positioning
Date: Jul 12, 2012
Guys A question for those of you who have the Trutrack auto trim box. When you select flaps to a position other than the reflex position, does the auto trim adjust pitch trim as the flaps deploy? Also is it standard practise to have a on-off switch wired to the auto trim box? I've been looking at the "Aircraft Extra's" flap positioning system, but since I intend to also use the Vertical Power VP-X Pro, I think the system is basically redundant. Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Jul 12, 2012
1. I don't think I have ever moved the flaps when the autopilot was engaged, so really cannot answer. But see no reason why it would not work that way. 2. I put my autotrim in after my initial install and have it powered off the autopilot. I have a breaker switch powering the autopilot and thus I have a switch that can easily be hit to disconnect (turn off) the autopilot if I have some type of runaway. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Thursday, July 12, 2012 6:01 AM Subject: RV10-List: flap positioning Guys A question for those of you who have the Trutrack auto trim box. When you select flaps to a position other than the reflex position, does the auto trim adjust pitch trim as the flaps deploy? Also is it standard practise to have a on-off switch wired to the auto trim box? I've been looking at the "Aircraft Extra's" flap positioning system, but since I intend to also use the Vertical Power VP-X Pro, I think the system is basically redundant. Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Jul 12, 2012
Subject: Urgent: EAA Members - Action!
Hi Everyone, If many of you follow =VAF=, you're probably aware that there is a campaign within the EAA Membership community to participate in the upcoming election of the EAA Board of Directors. We figured that instead of just complaining, we should actually participate in the democratic elections. This simply idea led to more than 1 month of stone walling from the EAA. Still to this day, they have not provided a simple document that allows their members to participate in the election. So we copied their language that assigns the proxy rights to Rod Hightower and changed the name on it to reflect me. The EAA has admitted that this is a document that they can't turn down at the elections in a few weeks. In the past there were 3 choices for EAA members to participate in the election: 1) They could choose not to participate. 2) They could show up in person to cast their vote at the annual business meeting. 3) They could assign their vote to Rod Hightower. (This is a check box on your annual renewal) Long story short, the elections would look like 13 votes for some members and 16,000 votes for those that Hightower wanted. So they ended up being appointments and not elections by the members. I am receiving proxy forms from all over the globe and if you are frustrated with the EAA, I would appreciate it if you would do that same thing. The form can be found at this link. http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf You can send me a scanned copy or the original to: Phillip W. Perry C/O David Carr 1100 W Monroe St Austin, TX 78704 Here are the votes we will be placing and the justification for selecting them: http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 Today the EAA retaliated against their members and sent out a link asking them to assign proxy votes to Rod Hightower. Please don't give total control of EAA to the current membership and choose to put control of the EAA back in the hands of the membership. Here's some details on that message: http://www.vansairforce.com/community/showthread.php?p=679285 Please don't assign your proxy to the EAA Leadership, and if you feel compelled I would be honored to carry your proxy vote forward at the business meeting at AirVenture. This is the first time (that I'm aware of) in the history of EAA that the members have found a way to legitimately participate. We need to get this word out to everyone who supports the effort ASAP. So if you agree, please highlight this proxy effort and share the message on every message board you can before some unknowing soul gives his vote to Rod Hightower and his buddies. We are going to be continuing this effort going into 2013 too and can use your support and even you active participation. Thanks, Phil Perry RV-10 #40750 EAA Lifetime Member ________________________________________________________________________________
Date: Jul 12, 2012
Subject: Re: Urgent: EAA Members - Action!
Phil, Thanks for taking this up for us. I'll be handing my proxy form in at OSH. You should also mention that there are places like the Cleaveland Tools booth and people at the 10HQ that will be drop off points for the forms as an alternative to snail mailing them in. If this has changed since the last I read the thread over at VAF, I apologize! Ed On Thu, Jul 12, 2012 at 5:14 PM, Phillip Perry wrote: > Hi Everyone, > > If many of you follow =VAF=, you're probably aware that there is a > campaign within the EAA Membership community to participate in the upcoming > election of the EAA Board of Directors. We figured that instead of just > complaining, we should actually participate in the democratic elections. > > This simply idea led to more than 1 month of stone walling from the EAA. > Still to this day, they have not provided a simple document that allows > their members to participate in the election. So we copied their language > that assigns the proxy rights to Rod Hightower and changed the name on it > to reflect me. The EAA has admitted that this is a document that they > can't turn down at the elections in a few weeks. > > In the past there were 3 choices for EAA members to participate in the > election: > 1) They could choose not to participate. > 2) They could show up in person to cast their vote at the annual business > meeting. > 3) They could assign their vote to Rod Hightower. (This is a check box on > your annual renewal) > > Long story short, the elections would look like 13 votes for some members > and 16,000 votes for those that Hightower wanted. So they ended up being > appointments and not elections by the members. > > I am receiving proxy forms from all over the globe and if you are > frustrated with the EAA, I would appreciate it if you would do that same > thing. The form can be found at this link. > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > You can send me a scanned copy or the original to: > Phillip W. Perry > C/O David Carr > 1100 W Monroe St > Austin, TX 78704 > > Here are the votes we will be placing and the justification for selecting > them: > http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 > > Today the EAA retaliated against their members and sent out a link asking > them to assign proxy votes to Rod Hightower. Please don't give total > control of EAA to the current membership and choose to put control of the > EAA back in the hands of the membership. Here's some details on that > message: > http://www.vansairforce.com/community/showthread.php?p=679285 > > Please don't assign your proxy to the EAA Leadership, and if you feel > compelled I would be honored to carry your proxy vote forward at the > business meeting at AirVenture. This is the first time (that I'm aware of) > in the history of EAA that the members have found a way to legitimately > participate. > > We need to get this word out to everyone who supports the effort ASAP. So > if you agree, please highlight this proxy effort and share the message on > every message board you can before some unknowing soul gives his vote to > Rod Hightower and his buddies. > > We are going to be continuing this effort going into 2013 too and can use > your support and even you active participation. > > Thanks, > Phil Perry > > RV-10 #40750 > EAA Lifetime Member > > > * > > * > > ________________________________________________________________________________
Date: Jul 12, 2012
Ed, Thanks for your proxy. That is correct, we have a several options for proxy collection setup around the field. 1) Cleveland Tools is located beside the Vans Booth and they will be accepting proxy forms in their booth. They will also have some blank forms in their booth too, in case you forget to bring your own. 2) Gary Specketer offered to collect proxy forms at the RV-10 HQ. 3) Louise Hose will be collecting at the Vans Banquet on Tuesday night. 4) At the same time, I will be at the EAA Lifetime Members dinner collecting forms. 5) You can also reach out to me and I will find a way to meet you on the field to collect your proxy at a scheduled time. Thanks for your support. Let's return the EAA to its members. Phil On Thu, Jul 12, 2012 at 7:30 PM, Ed Kranz wrote: > Phil, > > Thanks for taking this up for us. > > I'll be handing my proxy form in at OSH. You should also mention that > there are places like the Cleaveland Tools booth and people at the 10HQ > that will be drop off points for the forms as an alternative to snail > mailing them in. If this has changed since the last I read the thread over > at VAF, I apologize! > > Ed > > ________________________________________________________________________________
Date: Jul 12, 2012
Subject: OSH12 RV10 Pot Luck Dinner
(cross-posted from VAF) OK. I'll bite. I'll coordinate the PotLuck. *Tentatively Sunday the 22nd @ the RV10 HQ in Camp Scholler. *(Logistically, I think this will work better than HBC for having grills, picnic tables, generators, ect for a large group) *7:30PM? Earlier? Later? Sign up is at http://www.perfectpotluck.com/meals.php?t=AKIL0864 * You can also go to www.perfectpotluck.com and search for last name *Kranz* with a password of *osh12* The site will let me email updates out to all contributors, so make sure the email address you enter is a good one. Add a phone number if you'd like, but it's not required. Let me know if I should add categories or make more room in existing categories on the signup list. We can also keep a paper signup sheet at the 10HQ for the non-internet types. Who's in? Also, if anyone has any strong feelings about the time or date, say something, and we'll try to go with the consensus. ________________________________________________________________________________
Date: Jul 12, 2012
Phillip, Rather than leave your 5th vote "open", I would recommend casting it for one of the existing board members, Barry Davis. At least Barry has built an airplane, a Pietenpol Air Camper (scratch/plans built), which is more than you can say for most of the board (including Hightower). You'll have my scanned proxy in the morning. Thanks for taking this on. I'm ready to leave EAA, which I've been a member of since 1974, if they don't change course drastically and get back to supporting homebuilders and the homebuilt community. We don't need another AOPA - the one we have is sufficient. Jack Phillips EAA 81225 Pietenpol Air Camper (flying) RV-10 (finished the wings, ready to start the fuselage) Smith Mountain Lake, Virginia _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, July 12, 2012 6:15 PM Subject: RV10-List: Urgent: EAA Members - Action! Hi Everyone, If many of you follow =VAF=, you're probably aware that there is a campaign within the EAA Membership community to participate in the upcoming election of the EAA Board of Directors. We figured that instead of just complaining, we should actually participate in the democratic elections. This simply idea led to more than 1 month of stone walling from the EAA. Still to this day, they have not provided a simple document that allows their members to participate in the election. So we copied their language that assigns the proxy rights to Rod Hightower and changed the name on it to reflect me. The EAA has admitted that this is a document that they can't turn down at the elections in a few weeks. In the past there were 3 choices for EAA members to participate in the election: 1) They could choose not to participate. 2) They could show up in person to cast their vote at the annual business meeting. 3) They could assign their vote to Rod Hightower. (This is a check box on your annual renewal) Long story short, the elections would look like 13 votes for some members and 16,000 votes for those that Hightower wanted. So they ended up being appointments and not elections by the members. I am receiving proxy forms from all over the globe and if you are frustrated with the EAA, I would appreciate it if you would do that same thing. The form can be found at this link. http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf You can send me a scanned copy or the original to: Phillip W. Perry C/O David Carr 1100 W Monroe St Austin, TX 78704 Here are the votes we will be placing and the justification for selecting them: http://www.vansairforce.com/community/showpost.php?p=678549 <http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68> &postcount=68 Today the EAA retaliated against their members and sent out a link asking them to assign proxy votes to Rod Hightower. Please don't give total control of EAA to the current membership and choose to put control of the EAA back in the hands of the membership. Here's some details on that message: http://www.vansairforce.com/community/showthread.php?p=679285 Please don't assign your proxy to the EAA Leadership, and if you feel compelled I would be honored to carry your proxy vote forward at the business meeting at AirVenture. This is the first time (that I'm aware of) in the history of EAA that the members have found a way to legitimately participate. We need to get this word out to everyone who supports the effort ASAP. So if you agree, please highlight this proxy effort and share the message on every message board you can before some unknowing soul gives his vote to Rod Hightower and his buddies. We are going to be continuing this effort going into 2013 too and can use your support and even you active participation. Thanks, Phil Perry RV-10 #40750 EAA Lifetime Member ________________________________________________________________________________
Date: Jul 12, 2012
Thanks Jack. There's a pretty important lesson in this year, and that is to not resign your EAA membership. But instead keep (or get) an EAA membership but don't assign your proxy to Hightower. Instead assign it to those of us fighting the fight. We need you to be a member so we can cast your vote. Without your vote, we automatically lose any opportunity to introduce reform from the grass roots. We aren't going to let this go after 2012, we've got plans to re-launch the proxy collection campaign early next year and spend 364 days obtaining member votes. Thanks again for your feedback and support. Phil RV-10 #40750 EAA Lifetime Member On Thu, Jul 12, 2012 at 8:32 PM, Jack Phillips wrote: > ** > Phillip, > > Rather than leave your 5th vote "open", I would recommend casting it for > one of the existing board members, Barry Davis. At least Barry has built > an airplane, a Pietenpol Air Camper (scratch/plans built), which is more > than you can say for most of the board (including Hightower). > > You'll have my scanned proxy in the morning. Thanks for taking this on. > I'm ready to leave EAA, which I've been a member of since 1974, if they > don't change course drastically and get back to supporting homebuilders and > the homebuilt community. We don't need another AOPA - the one we have is > sufficient. > > Jack Phillips > EAA 81225 > Pietenpol Air Camper (flying) > RV-10 (finished the wings, ready to start the fuselage) > Smith Mountain Lake, Virginia > > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Phillip Perry > *Sent:* Thursday, July 12, 2012 6:15 PM > *To:* rv10-list(at)matronics.com > > *Subject:* RV10-List: Urgent: EAA Members - Action! > > Hi Everyone, > > If many of you follow =VAF=, you're probably aware that there is a > campaign within the EAA Membership community to participate in the upcoming > election of the EAA Board of Directors. We figured that instead of just > complaining, we should actually participate in the democratic elections. > > This simply idea led to more than 1 month of stone walling from the EAA. > Still to this day, they have not provided a simple document that allows > their members to participate in the election. So we copied their language > that assigns the proxy rights to Rod Hightower and changed the name on it > to reflect me. The EAA has admitted that this is a document that they > can't turn down at the elections in a few weeks. > > In the past there were 3 choices for EAA members to participate in the > election: > 1) They could choose not to participate. > 2) They could show up in person to cast their vote at the annual business > meeting. > 3) They could assign their vote to Rod Hightower. (This is a check box on > your annual renewal) > > Long story short, the elections would look like 13 votes for some members > and 16,000 votes for those that Hightower wanted. So they ended up being > appointments and not elections by the members. > > I am receiving proxy forms from all over the globe and if you are > frustrated with the EAA, I would appreciate it if you would do that same > thing. The form can be found at this link. > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > You can send me a scanned copy or the original to: > Phillip W. Perry > C/O David Carr > 1100 W Monroe St > Austin, TX 78704 > > Here are the votes we will be placing and the justification for selecting > them: > http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 > > Today the EAA retaliated against their members and sent out a link asking > them to assign proxy votes to Rod Hightower. Please don't give total > control of EAA to the current membership and choose to put control of the > EAA back in the hands of the membership. Here's some details on that > message: > http://www.vansairforce.com/community/showthread.php?p=679285 > > Please don't assign your proxy to the EAA Leadership, and if you feel > compelled I would be honored to carry your proxy vote forward at the > business meeting at AirVenture. This is the first time (that I'm aware of) > in the history of EAA that the members have found a way to legitimately > participate. > > We need to get this word out to everyone who supports the effort ASAP. So > if you agree, please highlight this proxy effort and share the message on > every message board you can before some unknowing soul gives his vote to > Rod Hightower and his buddies. > > We are going to be continuing this effort going into 2013 too and can use > your support and even you active participation. > > Thanks, > Phil Perry > > RV-10 #40750 > EAA Lifetime Member > > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Subject: Re: OSH12 RV10 Pot Luck Dinner
Date: Jul 12, 2012
For those flying in with no local transportation for supplies, I will make a supply run that afternoon. Just need to figure out how to accommodate do nations on the page. Bob Sent from my iPad On Jul 12, 2012, at 8:23 PM, Ed Kranz wrote: > (cross-posted from VAF) > > OK. I'll bite. I'll coordinate the PotLuck. > > Tentatively Sunday the 22nd @ the RV10 HQ in Camp Scholler. (Logistically, I think this will work better than HBC for having grills, picnic tables, ge nerators, ect for a large group) > 7:30PM? Earlier? Later? > > Sign up is at http://www.perfectpotluck.com/meals.php?t=AKIL0864 > > You can also go to www.perfectpotluck.com and search for last name Kranz w ith a password of osh12 > > The site will let me email updates out to all contributors, so make sure t he email address you enter is a good one. Add a phone number if you'd like, b ut it's not required. > > Let me know if I should add categories or make more room in existing categ ories on the signup list. We can also keep a paper signup sheet at the 10HQ f or the non-internet types. > > Who's in? > > Also, if anyone has any strong feelings about the time or date, say someth ing, and we'll try to go with the consensus. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 12, 2012
I added a category of "Cash Donation". If you don't want to worry about bringing food, just sign up for a donation, and list "CASH" in the "What you'll bring" field. At least then you're on the list. On Thu, Jul 12, 2012 at 9:28 PM, Bob's Gmail wrote: > For those flying in with no local transportation for supplies, I will make > a supply run that afternoon. Just need to figure out how to accommodate > donations on the page. > Bob > > Sent from my iPad > ________________________________________________________________________________
Date: Jul 12, 2012
That time line works for me. I'll be getting into Oshkosh between 3-4PM on Sunday. I love the Red Solo Cup's sign-up. It's going to be a party! I'm good for an Andrew Jackson to be used any way necessary. Phil On Thu, Jul 12, 2012 at 10:15 PM, Ed Kranz wrote: > I added a category of "Cash Donation". If you don't want to worry about > bringing food, just sign up for a donation, and list "CASH" in the "What > you'll bring" field. At least then you're on the list. > > > On Thu, Jul 12, 2012 at 9:28 PM, Bob's Gmail wrote: > >> For those flying in with no local transportation for supplies, I will >> make a supply run that afternoon. Just need to figure out how to >> accommodate donations on the page. >> Bob >> >> Sent from my iPad >> > * > > > * > > ________________________________________________________________________________
Date: Jul 13, 2012
Phil, I've been in Afghanistan for the last year, and therefore out of the loop for a while. I was just curious about what I was missing that has caused such a reaction. I've seen claims of EAA not supporting home builders, and since I'm about to start on an RV-10 at the end of this deployment, that concerns me. I was hoping you(or someone) could bring me up to speed on what I have missed, and what the issues are that we are having. I admire your convition, and your willingness to take action. I do n't want to seem like I'm challenging you, but I do want to be well informed before I make a decision, Thanks Jason On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry wrote: > Hi Everyone, > > If many of you follow =VAF=, you're probably aware that there is a > campaign within the EAA Membership community to participate in the upcoming > election of the EAA Board of Directors. We figured that instead of just > complaining, we should actually participate in the democratic elections. > > This simply idea led to more than 1 month of stone walling from the EAA. > Still to this day, they have not provided a simple document that allows > their members to participate in the election. So we copied their language > that assigns the proxy rights to Rod Hightower and changed the name on it > to reflect me. The EAA has admitted that this is a document that they > can't turn down at the elections in a few weeks. > > In the past there were 3 choices for EAA members to participate in the > election: > 1) They could choose not to participate. > 2) They could show up in person to cast their vote at the annual business > meeting. > 3) They could assign their vote to Rod Hightower. (This is a check box on > your annual renewal) > > Long story short, the elections would look like 13 votes for some members > and 16,000 votes for those that Hightower wanted. So they ended up being > appointments and not elections by the members. > > I am receiving proxy forms from all over the globe and if you are > frustrated with the EAA, I would appreciate it if you would do that same > thing. The form can be found at this link. > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > You can send me a scanned copy or the original to: > Phillip W. Perry > C/O David Carr > 1100 W Monroe St > Austin, TX 78704 > > Here are the votes we will be placing and the justification for selecting > them: > http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 > > Today the EAA retaliated against their members and sent out a link asking > them to assign proxy votes to Rod Hightower. Please don't give total > control of EAA to the current membership and choose to put control of the > EAA back in the hands of the membership. Here's some details on that > message: > http://www.vansairforce.com/community/showthread.php?p=679285 > > Please don't assign your proxy to the EAA Leadership, and if you feel > compelled I would be honored to carry your proxy vote forward at the > business meeting at AirVenture. This is the first time (that I'm aware of) > in the history of EAA that the members have found a way to legitimately > participate. > > We need to get this word out to everyone who supports the effort ASAP. So > if you agree, please highlight this proxy effort and share the message on > every message board you can before some unknowing soul gives his vote to > Rod Hightower and his buddies. > > We are going to be continuing this effort going into 2013 too and can use > your support and even you active participation. > > Thanks, > Phil Perry > > RV-10 #40750 > EAA Lifetime Member > > > * > > * > > ________________________________________________________________________________
Subject: Re: flap positioning
Date: Jul 13, 2012
Rick I aiso have the VPX and have it hooked up to control the flps. There is no reason to have anything else controlling the flaps if you use the VPX. You will have to provide a feedback position sensor . I made a bracket and attached the Ray Allen servo to the actuator arm and attached the whole thing to the side if the tunnel. The only issue is the VPX does not distinguish the reflex position! You can set the top and the bottom positions and only 2 intermediate positions. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378180#378180 ________________________________________________________________________________
Date: Jul 13, 2012
Jason; First off, that you for the sacrifice to leave the comforts and safety of the US for our battle in Afghanistan. It=99s hard, been there, not Afghinstan but another =9Coperation in 1990-1991. Thank you for your service! I think you ask a very good question. Phil may not be able to answer it completely but my initial thought is the folks writing articles for Sport aviation are ex flying magazine writers who have no idea of what building a plane is about, there was a meeting and their has been that =9Ccombined=9D effort of AOPA and EAA to represent us with Lsa and other general flying issues, good idea, sure! I would like to see the EAA fight for homebuilders and not general aviation however. My corporation does the same thing EAA does. Phil just wants members to have more say on who is voted in versus the big kahuna at EAA himself. From: Jason Wodack Sent: Friday, July 13, 2012 1:11 AM Subject: Re: RV10-List: Urgent: EAA Members - Action! Phil, I've been in Afghanistan for the last year, and therefore out of the loop for a while. I was just curious about what I was missing that has caused such a reaction. I've seen claims of EAA not supporting home builders, and since I'm about to start on an RV-10 at the end of this deployment, that concerns me. I was hoping you(or someone) could bring me up to speed on what I have missed, and what the issues are that we are having. I admire your convition, and your willingness to take action. I do n't want to seem like I'm challenging you, but I do want to be well informed before I make a decision, Thanks Jason On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry wrote: Hi Everyone, If many of you follow =VAF=, you're probably aware that there is a campaign within the EAA Membership community to participate in the upcoming election of the EAA Board of Directors. We figured that instead of just complaining, we should actually participate in the democratic elections. This simply idea led to more than 1 month of stone walling from the EAA. Still to this day, they have not provided a simple document that allows their members to participate in the election. So we copied their language that assigns the proxy rights to Rod Hightower and changed the name on it to reflect me. The EAA has admitted that this is a document that they can't turn down at the elections in a few weeks. In the past there were 3 choices for EAA members to participate in the election: 1) They could choose not to participate. 2) They could show up in person to cast their vote at the annual business meeting. 3) They could assign their vote to Rod Hightower. (This is a check box on your annual renewal) Long story short, the elections would look like 13 votes for some members and 16,000 votes for those that Hightower wanted. So they ended up being appointments and not elections by the members. I am receiving proxy forms from all over the globe and if you are frustrated with the EAA, I would appreciate it if you would do that same thing. The form can be found at this link. http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf You can send me a scanned copy or the original to: Phillip W. Perry C/O David Carr 1100 W Monroe St Austin, TX 78704 Here are the votes we will be placing and the justification for selecting them: http://www.vansairforce.com/community/showpost.php?p=678549&postcount= 68 Today the EAA retaliated against their members and sent out a link asking them to assign proxy votes to Rod Hightower. Please don't give total control of EAA to the current membership and choose to put control of the EAA back in the hands of the membership. Here's some details on that message: http://www.vansairforce.com/community/showthread.php?p=679285 Please don't assign your proxy to the EAA Leadership, and if you feel compelled I would be honored to carry your proxy vote forward at the business meeting at AirVenture. This is the first time (that I'm aware of) in the history of EAA that the members have found a way to legitimately participate. We need to get this word out to everyone who supports the effort ASAP. So if you agree, please highlight this proxy effort and share the message on every message board you can before some unknowing soul gives his vote to Rod Hightower and his buddies. We are going to be continuing this effort going into 2013 too and can use your support and even you active participation. Thanks, Phil Perry RV-10 #40750 EAA Lifetime Member get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 13, 2012
I will be using the VPX as well. Any pictures? Couldn't you define the reflex position as top of travel, trailing as 1st intermediate and 1/2 flaps as second intermediate? On Fri, Jul 13, 2012 at 6:09 AM, bill.peyton wrote: > > Rick > I aiso have the VPX and have it hooked up to control the flps. There is > no reason to have anything else controlling the flaps if you use the VPX. > You > will have to provide a feedback position sensor . I made a bracket and > attached the Ray Allen servo to the actuator arm and attached the > whole thing to the side if the tunnel. The only issue is the VPX does not > distinguish the reflex position! You can set the top and the bottom > positions and only 2 intermediate positions. > Bill > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=378180#378180 > > ________________________________________________________________________________
Date: Jul 13, 2012
Gentlemen, I posted an inquiry on the VP forum asking about the reflex position and Bob Lefler also inquired.. Mark Austman posted that the reflex position fix (software change) was to come at a later date, but I understood that the top position could be set up as the reflex position. Am I mistaken? Rick ----- Original Message ----- From: Kelly McMullen To: rv10-list(at)matronics.com Sent: Friday, July 13, 2012 10:56 AM Subject: Re: RV10-List: Re: flap positioning I will be using the VPX as well. Any pictures? Couldn't you define the reflex position as top of travel, trailing as 1st intermediate and 1/2 flaps as second intermediate? On Fri, Jul 13, 2012 at 6:09 AM, bill.peyton wrote: Rick I aiso have the VPX and have it hooked up to control the flps. There is no reason to have anything else controlling the flaps if you use the VPX. You will have to provide a feedback position sensor . I made a bracket and attached the Ray Allen servo to the actuator arm and attached the whole thing to the side if the tunnel. The only issue is the VPX does not distinguish the reflex position! You can set the top and the bottom positions and only 2 intermediate positions. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378180#378180 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 13, 2012
Have the VP-200 and I use the Skyview for the =933 indicator, which the VPX works with. So I would assume it=99s the same setup. Here is a picture I took off the Dynon site using the VP-X, not mine. The numbers are setup on the Dynon during the configuration. 0 can be =933 and so on as Kelly states. From: Kelly McMullen Sent: Friday, July 13, 2012 7:56 AM Subject: Re: RV10-List: Re: flap positioning I will be using the VPX as well. Any pictures? Couldn't you define the reflex position as top of travel, trailing as 1st intermediate and 1/2 flaps as second intermediate? On Fri, Jul 13, 2012 at 6:09 AM, bill.peyton wrote: Rick I aiso have the VPX and have it hooked up to control the flps. There is no reason to have anything else controlling the flaps if you use the VPX. You will have to provide a feedback position sensor . I made a bracket and attached the Ray Allen servo to the actuator arm and attached the whole thing to the side if the tunnel. The only issue is the VPX does not distinguish the reflex position! You can set the top and the bottom positions and only 2 intermediate positions. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378180#378180 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 13, 2012
You are not mistaken The update impacts the speed controls and restrictions . I.e. going from reflex to 0 shouldn't have the same parameters as going t o full flaps. It will also make it more pilot intuitive. Sent from my iPhone On Jul 13, 2012, at 11:05 AM, "Rick Lark" wrote: Gentlemen, I posted an inquiry on the VP forum asking about the reflex posit ion and Bob Lefler also inquired.. Mark Austman posted that the reflex posi tion fix (software change) was to come at a later date, but I understood tha t the top position could be set up as the reflex position. Am I mistaken? Rick ----- Original Message ----- From: Kelly McMullen Sent: Friday, July 13, 2012 10:56 AM Subject: Re: RV10-List: Re: flap positioning I will be using the VPX as well. Any pictures? Couldn't you define the refl ex position as top of travel, trailing as 1st intermediate and 1/2 flaps as s econd intermediate? On Fri, Jul 13, 2012 at 6:09 AM, bill.peyton wrote: Rick I aiso have the VPX and have it hooked up to control the flps. There is no r eason to have anything else controlling the flaps if you use the VPX. You will have to provide a feedback position sensor . I made a bracket and atta ched the Ray Allen servo to the actuator arm and attached the whole thing to the side if the tunnel. The only issue is the VPX does not d istinguish the reflex position! You can set the top and the bottom positions and only 2 intermediate positions. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378180#378180 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.c om/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Jul 13, 2012
Hi Jason, Thank you for your time in Afganistan and for sacrificing a good portion of your life for those of us here typing e-mails. Pascal hit a few key area, but there are a few more that should be brought up as well. The EAA debate has been a long time coming. It actually goes all the way back to Paul Poberezny when there was a movement to remove him. But in the past 3-4 years, the frustration with EAA has reached the boiling point for many members. Long story short, since Rod Hightower has taken over the organization the charter and image of EAA has made a dramatic shift away from their core values. The EAA has become focused on being the next AOPA politcally and they're focused on the money that can be made through AirVenture. I think it's great that AirVenture represents a strong revenue stream for the organization. But the organization has become focused on milking that stream and the memership community has paid the price. If 100% of the members disappeared tomorrow, the EAA would still exist based on the airshow. So the members are now second class citizens in the organization. Our efforts to participate in this years election were blocked by EAA by being unresponsive and ignoring our requests for a simple ballot to participate. This is a right that is entitled to the membership community within the bylaws. But this right has not been made available to the membership. As a result, the EAA holds nearly all of the membership votes. It's like the fox in the hen house in some regards. I love the EAA. I am passionate about it. I am a lifetime member. I have served as a chapter VP and President. As I sit here right now, I'm wearing a red AirVenture 2009 polo. I love the legacy EAA culture, I love the EAA brand. I really do care a lot about EAA. Since Rod Hightower has taken over the organization, the EAA has seen nearly 50 employees walk out the door from the toxic environment that Rod has created. These are important people like Charlie Becker, Adam Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is an Executive Director who has spent 22 years as an employee of the organization. The EAA culture as we know it is under attack from within. You might know Dick Kohler, he has taught a number of EAA SportAir workshops and he is passionate about EAA. You should read his comments at this link because he pretty much captures the environment that Rod has created. http://www.vansairforce.com/community/showpost.php?p=675101&postcount=122 Additional information can be found at this link containing comments from EAA Board Members who have resigned. Here is a key comment if you don't go read the entire link. ============ As Mike Dale put it was time for the Board to "grow up and start having the CEO work for the Board". I cannot be part of a rubber stamp Board whose prime loyalty is to the Founder and President rather than EAA members. ============ http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb-426a-a210-5b7ee4112049 I hope you will consider supporting our effort. We won't have enough votes to change this election, but we will have enough to put a shot across the bow of EAA's leadership. Thanks, Phil On 7/13/12, Pascal wrote: > Jason; > First off, that you for the sacrifice to leave the comforts and safety of > the US for our battle in Afghanistan. Its hard, been there, not Afghinstan > but another operation in 1990-1991. Thank you for your service! > I think you ask a very good question. Phil may not be able to answer it > completely but my initial thought is the folks writing articles for Sport > aviation are ex flying magazine writers who have no idea of what building a > plane is about, there was a meeting and their has been that combined > effort of AOPA and EAA to represent us with Lsa and other general flying > issues, good idea, sure! I would like to see the EAA fight for homebuilders > and not general aviation however. > My corporation does the same thing EAA does. Phil just wants members to have > more say on who is voted in versus the big kahuna at EAA himself. > > From: Jason Wodack > Sent: Friday, July 13, 2012 1:11 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Urgent: EAA Members - Action! > > Phil, > I've been in Afghanistan for the last year, and therefore out of the loop > for a while. I was just curious about what I was missing that has caused > such a reaction. > > I've seen claims of EAA not supporting home builders, and since I'm about to > start on an RV-10 at the end of this deployment, that concerns me. I was > hoping you(or someone) could bring me up to speed on what I have missed, and > what the issues are that we are having. > > I admire your convition, and your willingness to take action. I do n't want > to seem like I'm challenging you, but I do want to be well informed before I > make a decision, > > Thanks > Jason > > > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry > wrote: > > Hi Everyone, > > If many of you follow =VAF=, you're probably aware that there is a > campaign within the EAA Membership community to participate in the upcoming > election of the EAA Board of Directors. We figured that instead of just > complaining, we should actually participate in the democratic elections. > > This simply idea led to more than 1 month of stone walling from the EAA. > Still to this day, they have not provided a simple document that allows > their members to participate in the election. So we copied their language > that assigns the proxy rights to Rod Hightower and changed the name on it to > reflect me. The EAA has admitted that this is a document that they can't > turn down at the elections in a few weeks. > > In the past there were 3 choices for EAA members to participate in the > election: > > 1) They could choose not to participate. > 2) They could show up in person to cast their vote at the annual business > meeting. > 3) They could assign their vote to Rod Hightower. (This is a check box on > your annual renewal) > > > Long story short, the elections would look like 13 votes for some members > and 16,000 votes for those that Hightower wanted. So they ended up being > appointments and not elections by the members. > > I am receiving proxy forms from all over the globe and if you are > frustrated with the EAA, I would appreciate it if you would do that same > thing. The form can be found at this link. > > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > > You can send me a scanned copy or the original to: > > Phillip W. Perry > C/O David Carr > 1100 W Monroe St > Austin, TX 78704 > > > Here are the votes we will be placing and the justification for selecting > them: > > http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 > > > Today the EAA retaliated against their members and sent out a link asking > them to assign proxy votes to Rod Hightower. Please don't give total > control of EAA to the current membership and choose to put control of the > EAA back in the hands of the membership. Here's some details on that > message: > > http://www.vansairforce.com/community/showthread.php?p=679285 > > > Please don't assign your proxy to the EAA Leadership, and if you feel > compelled I would be honored to carry your proxy vote forward at the > business meeting at AirVenture. This is the first time (that I'm aware of) > in the history of EAA that the members have found a way to legitimately > participate. > > We need to get this word out to everyone who supports the effort ASAP. So > if you agree, please highlight this proxy effort and share the message on > every message board you can before some unknowing soul gives his vote to Rod > Hightower and his buddies. > > We are going to be continuing this effort going into 2013 too and can use > your support and even you active participation. > > Thanks, > Phil Perry > > RV-10 #40750 > EAA Lifetime Member > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > ________________________________________________________________________________
Date: Jul 13, 2012
We(4) will be flying in Sat 7-9 AM, depending on wx. Looking forward to some great food and conversation. Cell: (six, zero, six) 316-9020. If we all help a little, it won't be so hard on a few and we may want to do this more often. I am a newbie, but a good cook/trash man/drink mixer/food shopper...whatever is needed. Raining now in Ky...we needed it bad, but I sure hope for beautiful wx during everyone's travels and at Osh. See ya there. -------- Wayne Gillispie, A&P 05/93 PP 10/08 40983SB 12/1/2009-12/1/2011 N715WD 382nd Flying. TT= 41 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378196#378196 ________________________________________________________________________________
Date: Jul 13, 2012
As bob states, your assumption is correct Rick. The problem is that zero degrees becomes the first stop and then you only get to choose one more prior to full flaps. I think Marc was talking about adding an additional intermediate stop. On the Garmin G3, the display is not so elaborate as the dynon. It is just a bar graph with a sliding pointer. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378202#378202 ________________________________________________________________________________
Date: Jul 13, 2012
My G3X shows each position. ----- Original Message ----- From: "bill.peyton" <peyton.b(at)sbcglobal.net> Sent: Friday, July 13, 2012 10:35 AM Subject: RV10-List: Re: flap positioning > > As bob states, your assumption is correct Rick. The problem is that zero > degrees becomes the first stop and then you only get to choose one more > prior to full flaps. I think Marc was talking about adding an additional > intermediate stop. On the Garmin G3, the display is not so elaborate as > the dynon. It is just a bar graph with a sliding pointer. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=378202#378202 > > > ________________________________________________________________________________
Date: Jul 13, 2012
That is exactly how it works on the VP-200 Kelly. I would bet that the VP-X is the same. David Maib RV-10 Transition Training 40559 520 hours. On Jul 13, 2012, at 10:56 AM, Kelly McMullen wrote: I will be using the VPX as well. Any pictures? Couldn't you define the reflex position as top of travel, trailing as 1st intermediate and 1/2 flaps as second intermediate? On Fri, Jul 13, 2012 at 6:09 AM, bill.peyton wrote: Rick I aiso have the VPX and have it hooked up to control the flps. There is no reason to have anything else controlling the flaps if you use the VPX. You will have to provide a feedback position sensor . I made a bracket and attached the Ray Allen servo to the actuator arm and attached the whole thing to the side if the tunnel. The only issue is the VPX does not distinguish the reflex position! You can set the top and the bottom positions and only 2 intermediate positions. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378180#378180 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Subject: broken down in Eugene Oregon
Date: Jul 13, 2012
Jim, try Tom Hastings at 541-912-6402. Tell Tom you got his name through me from Dick Epplett in Bend, OR, who is a friend of mine. Dick used to own a hangar at the Eugene airport, but now is retired in Bend and owns a hangar there. He says that if anyone might know of something available for you, Tom's the guy. I don't know Tom, but Dick is a great guy, built two experimentals, was a dentist in Eugene, etc. Upstanding guy. He also said that if Tom didn't know of anything that there are other names we could try. All the best of luck! John J From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of pilotdds Sent: Tuesday, July 10, 2012 1:14 PM Subject: RV10-List: broken down in Eugene Oregon Anyone have any contacts for hanger space at KEUG.I have a fluctuating oil pressure problem and looks like the plane is going to be here at least a month .Thought I had the problem resolved but it returned.Oil pressure increases during flight to redline -it is not likely a gauge issue as i have compared the electronic gauge with a mechanical and they match.Any one have a similar experience. Engine is a narrow deck 540 converted to an io-540.I overhauled it myself 350+ hours ago with new cylinders ,cam, lifters.I replaced the cage type oil pressure regulator with an eci adjustable.My plan is to remove oil filter adapter (b&C)and clean gallery to sump and remove and clean ball seat and springs on pressure regulator.If problem doesnt resolve it means engine tear down.One other symptom that is that pressure always ran about 8 pounds high for the first 5 minutes of flight the would normalize,I have been advised this is in fact not normal.Any other thoughts from the engine gurus-thanks Jim ________________________________________________________________________________
Date: Jul 13, 2012
I didn't mean to imply it did not show the position, it just is not curved and as fancy as the dynon graphic -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378243#378243 ________________________________________________________________________________
Date: Jul 14, 2012
Subject: Re: Tire Jack
I used one of those for about 10 years on my RV-6A. Works fine. You do have to modify the axle nut, but not a big deal. Also, you need a few blocks of wood so you can lower the gear leg and remove the tire jack, prior to removing the tire. I made the same axle nut modification for my RV-10 so I could use the tire jack, but I've been using a wing jack at home lately - much easier. -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 300 hrs johngoodman said the following on 7/1/2012 2:37 PM: > > Has anybody tried this on an RV-10: > http://www.aircraftspruce.com/catalog/topages/rvjack.php > > I'm looking for a traveling jack for changing tires, not a wing jack. > > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=376995#376995 > > ________________________________________________________________________________
Date: Jul 14, 2012
As a Lifetime member who joined "Just before. The Roust of 2009-2010", I still await word of those candidates we can vote for rather than proxy the continued "AOPA like" decline and unresponsiveness of EAA towards its builders. Can you advise whom to vote for? John Cox On Jul 13, 2012 9:05 AM, "Phillip Perry" wrote: > > Hi Jason, > > Thank you for your time in Afganistan and for sacrificing a good > portion of your life for those of us here typing e-mails. > > Pascal hit a few key area, but there are a few more that should be > brought up as well. > > The EAA debate has been a long time coming. It actually goes all the > way back to Paul Poberezny when there was a movement to remove him. > But in the past 3-4 years, the frustration with EAA has reached the > boiling point for many members. > > Long story short, since Rod Hightower has taken over the organization > the charter and image of EAA has made a dramatic shift away from their > core values. The EAA has become focused on being the next AOPA > politcally and they're focused on the money that can be made through > AirVenture. I think it's great that AirVenture represents a strong > revenue stream for the organization. But the organization has become > focused on milking that stream and the memership community has paid > the price. If 100% of the members disappeared tomorrow, the EAA would > still exist based on the airshow. So the members are now second class > citizens in the organization. > > Our efforts to participate in this years election were blocked by EAA > by being unresponsive and ignoring our requests for a simple ballot to > participate. This is a right that is entitled to the membership > community within the bylaws. But this right has not been made > available to the membership. As a result, the EAA holds nearly all of > the membership votes. It's like the fox in the hen house in some > regards. > > I love the EAA. I am passionate about it. I am a lifetime member. I > have served as a chapter VP and President. As I sit here right now, > I'm wearing a red AirVenture 2009 polo. I love the legacy EAA > culture, I love the EAA brand. I really do care a lot about EAA. > > Since Rod Hightower has taken over the organization, the EAA has seen > nearly 50 employees walk out the door from the toxic environment that > Rod has created. These are important people like Charlie Becker, Adam > Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is > an Executive Director who has spent 22 years as an employee of the > organization. The EAA culture as we know it is under attack from > within. > > You might know Dick Kohler, he has taught a number of EAA SportAir > workshops and he is passionate about EAA. You should read his > comments at this link because he pretty much captures the environment > that Rod has created. > > http://www.vansairforce.com/community/showpost.php?p=675101&postcount =122 > > Additional information can be found at this link containing comments > from EAA Board Members who have resigned. Here is a key comment if > you don't go read the entire link. > > ============ > As Mike Dale put it was time for the Board to "grow up and start > having the CEO work for the Board". I cannot be part of a rubber stamp > Board whose prime loyalty is to the Founder and President rather than > EAA members. > ============ > > http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb- 426a-a210-5b7ee4112049 > > > I hope you will consider supporting our effort. We won't have enough > votes to change this election, but we will have enough to put a shot > across the bow of EAA's leadership. > > Thanks, > Phil > > > On 7/13/12, Pascal wrote: > > Jason; > > First off, that you for the sacrifice to leave the comforts and safety of > > the US for our battle in Afghanistan. It=92s hard, been there, not > Afghinstan > > but another =93operation in 1990-1991. Thank you for your service! > > I think you ask a very good question. Phil may not be able to answer it > > completely but my initial thought is the folks writing articles for Spo rt > > aviation are ex flying magazine writers who have no idea of what > building a > > plane is about, there was a meeting and their has been that =93combined =94 > > effort of AOPA and EAA to represent us with Lsa and other general flyin g > > issues, good idea, sure! I would like to see the EAA fight for > homebuilders > > and not general aviation however. > > My corporation does the same thing EAA does. Phil just wants members to > have > > more say on who is voted in versus the big kahuna at EAA himself. > > > > From: Jason Wodack > > Sent: Friday, July 13, 2012 1:11 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Urgent: EAA Members - Action! > > > > Phil, > > I've been in Afghanistan for the last year, and therefore out of the lo op > > for a while. I was just curious about what I was missing that has caus ed > > such a reaction. > > > > I've seen claims of EAA not supporting home builders, and since I'm > about to > > start on an RV-10 at the end of this deployment, that concerns me. I w as > > hoping you(or someone) could bring me up to speed on what I have missed , > and > > what the issues are that we are having. > > > > I admire your convition, and your willingness to take action. I do n't > want > > to seem like I'm challenging you, but I do want to be well informed > before I > > make a decision, > > > > Thanks > > Jason > > > > > > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry > > wrote: > > > > Hi Everyone, > > > > If many of you follow =VAF=, you're probably aware that there is a > > campaign within the EAA Membership community to participate in the > upcoming > > election of the EAA Board of Directors. We figured that instead of jus t > > complaining, we should actually participate in the democratic elections . > > > > This simply idea led to more than 1 month of stone walling from the > EAA. > > Still to this day, they have not provided a simple document that allows > > their members to participate in the election. So we copied their > language > > that assigns the proxy rights to Rod Hightower and changed the name on > it to > > reflect me. The EAA has admitted that this is a document that they can 't > > turn down at the elections in a few weeks. > > > > In the past there were 3 choices for EAA members to participate in th e > > election: > > > > 1) They could choose not to participate. > > 2) They could show up in person to cast their vote at the annual > business > > meeting. > > 3) They could assign their vote to Rod Hightower. (This is a check > box on > > your annual renewal) > > > > > > Long story short, the elections would look like 13 votes for some > members > > and 16,000 votes for those that Hightower wanted. So they ended up bei ng > > appointments and not elections by the members. > > > > I am receiving proxy forms from all over the globe and if you are > > frustrated with the EAA, I would appreciate it if you would do that sam e > > thing. The form can be found at this link. > > > > > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > > > > > You can send me a scanned copy or the original to: > > > > Phillip W. Perry > > C/O David Carr > > 1100 W Monroe St > > Austin, TX 78704 > > > > > > Here are the votes we will be placing and the justification for > selecting > > them: > > > > > http://www.vansairforce.com/community/showpost.php?p=678549&postcount =68 > > > > > > Today the EAA retaliated against their members and sent out a link > asking > > them to assign proxy votes to Rod Hightower. Please don't give total > > control of EAA to the current membership and choose to put control of t he > > EAA back in the hands of the membership. Here's some details on that > > message: > > > > http://www.vansairforce.com/community/showthread.php?p=679285 > > > > > > Please don't assign your proxy to the EAA Leadership, and if you feel > > compelled I would be honored to carry your proxy vote forward at the > > business meeting at AirVenture. This is the first time (that I'm aware > of) > > in the history of EAA that the members have found a way to legitimately > > participate. > > > > We need to get this word out to everyone who supports the effort ASAP . > So > > if you agree, please highlight this proxy effort and share the message on > > every message board you can before some unknowing soul gives his vote t o > Rod > > Hightower and his buddies. > > > > We are going to be continuing this effort going into 2013 too and can > use > > your support and even you active participation. > > > > Thanks, > > Phil Perry > > > > RV-10 #40750 > > EAA Lifetime Member > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > > tp://forums.matronics.com > > _blank">http://www.matronics.com/contribution > > > > > > > > > > > > > > > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Jul 14, 2012
John, Are you going to be at the lifetime members banquet on Tues or attending the annual business meeting on Saturday morning? Here is some commentary I put together for the folks I am representing. We clearly won't have enough votes to move the election in any specific direction, so our strategy for this year is to simply cast a vote that reflects our loss of confidence in the management. Even though we won't have the votes to move the election, we will have enough votes to put a reasonable shot across the bow. For those of you who can attend the meeting at AirVenture on Saturday, I'd encourage you to do so. Apparently these meetings typically have 50 people attending and most of them are family members of the candidates. If you're dissatisfied and can be there, you need to be there. It's your responsibility to be there, be seen, and cast your own vote. Otherwise, the next best thing is to assign your proxy to me and I'll respectfully do it for you. Commentary below. Thanks, Phil =================== The most relevant piece of information involves the five Class I Director seats that are coming open as well as additional information related to the nine candidates. The biographies provided in Sport Aviation might be accurate, but there are some key details missing in a few of them. After some research, we found that five of the nine candidates are current EAA Class I Directors. This information is explicitly called out in two bios and only hinted-to in Alan Shackleton=92s bio. The five members of the board who are running for re-election are: Barry Davis John (Jack) Harrington David Lau Dan Schwinn Alan Shackleton The discovery of this information made us rethink the initial recommendations for vote distribution and that initiated a lengthy discussion about voting strategy. The EAA=92s lack of transparency (Lack of meeting minutes, no published voting records, etc.) doesn=92t allow us to evaluate each board member on their individual merit. Based on the state of affairs at EAA, it is hard for us to confidently vote for any of these individuals. I=92m sure there a re a few respectable folks in here, but that can=92t be determined because of the lack of transparency. This is the same lack of transparency they are responsible for creating/maintaining. After our discussion and the revelation that 5 of the 9 candidates are running for re-election within all 5 open seats, I have decided to adjust my own recommendations to vote for the 4 candidates who are not members of the current board of directors and leave our 5th vote unassigned. This means our five votes would be for: Doug Crumrine Ethan Martin Dave Morss Steven Oxman Open: No Vote Placed While some would argue this isn=92t an optimal list, it is the only list of candidates we have to choose from and it still provides some balance between Homebuilders, Vintage, Warbirds, and Certified GA. But most importantly a vote for these men represents a vote in favor of fresh ideas and leadership when compared to the current collection of Class I Directors . ============== Thanks, Phil On Sat, Jul 14, 2012 at 7:50 AM, John Cox wrote: > As a Lifetime member who joined "Just before. The Roust of 2009-2010", I > still await word of those candidates we can vote for rather than proxy th e > continued "AOPA like" decline and unresponsiveness of EAA towards its > builders. Can you advise whom to vote for? > > John Cox > On Jul 13, 2012 9:05 AM, "Phillip Perry" wrote: > >> >> >> Hi Jason, >> >> Thank you for your time in Afganistan and for sacrificing a good >> portion of your life for those of us here typing e-mails. >> >> Pascal hit a few key area, but there are a few more that should be >> brought up as well. >> >> The EAA debate has been a long time coming. It actually goes all the >> way back to Paul Poberezny when there was a movement to remove him. >> But in the past 3-4 years, the frustration with EAA has reached the >> boiling point for many members. >> >> Long story short, since Rod Hightower has taken over the organization >> the charter and image of EAA has made a dramatic shift away from their >> core values. The EAA has become focused on being the next AOPA >> politcally and they're focused on the money that can be made through >> AirVenture. I think it's great that AirVenture represents a strong >> revenue stream for the organization. But the organization has become >> focused on milking that stream and the memership community has paid >> the price. If 100% of the members disappeared tomorrow, the EAA would >> still exist based on the airshow. So the members are now second class >> citizens in the organization. >> >> Our efforts to participate in this years election were blocked by EAA >> by being unresponsive and ignoring our requests for a simple ballot to >> participate. This is a right that is entitled to the membership >> community within the bylaws. But this right has not been made >> available to the membership. As a result, the EAA holds nearly all of >> the membership votes. It's like the fox in the hen house in some >> regards. >> >> I love the EAA. I am passionate about it. I am a lifetime member. I >> have served as a chapter VP and President. As I sit here right now, >> I'm wearing a red AirVenture 2009 polo. I love the legacy EAA >> culture, I love the EAA brand. I really do care a lot about EAA. >> >> Since Rod Hightower has taken over the organization, the EAA has seen >> nearly 50 employees walk out the door from the toxic environment that >> Rod has created. These are important people like Charlie Becker, Adam >> Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is >> an Executive Director who has spent 22 years as an employee of the >> organization. The EAA culture as we know it is under attack from >> within. >> >> You might know Dick Kohler, he has taught a number of EAA SportAir >> workshops and he is passionate about EAA. You should read his >> comments at this link because he pretty much captures the environment >> that Rod has created. >> >> http://www.vansairforce.com/community/showpost.php?p=675101&postcount =122 >> >> Additional information can be found at this link containing comments >> from EAA Board Members who have resigned. Here is a key comment if >> you don't go read the entire link. >> >> ============ >> As Mike Dale put it was time for the Board to "grow up and start >> having the CEO work for the Board". I cannot be part of a rubber stamp >> Board whose prime loyalty is to the Founder and President rather than >> EAA members. >> ============ >> >> http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb -426a-a210-5b7ee4112049 >> >> >> I hope you will consider supporting our effort. We won't have enough >> votes to change this election, but we will have enough to put a shot >> across the bow of EAA's leadership. >> >> Thanks, >> Phil >> >> >> >> >> On 7/13/12, Pascal wrote: >> > Jason; >> > First off, that you for the sacrifice to leave the comforts and safety >> of >> > the US for our battle in Afghanistan. It=92s hard, been there, not >> Afghinstan >> > but another =93operation in 1990-1991. Thank you for your service! >> > I think you ask a very good question. Phil may not be able to answer i t >> > completely but my initial thought is the folks writing articles for >> Sport >> > aviation are ex flying magazine writers who have no idea of what >> building a >> > plane is about, there was a meeting and their has been that =93combine d=94 >> > effort of AOPA and EAA to represent us with Lsa and other general flyi ng >> > issues, good idea, sure! I would like to see the EAA fight for >> homebuilders >> > and not general aviation however. >> > My corporation does the same thing EAA does. Phil just wants members t o >> have >> > more say on who is voted in versus the big kahuna at EAA himself. >> > >> > From: Jason Wodack >> > Sent: Friday, July 13, 2012 1:11 AM >> > To: rv10-list(at)matronics.com >> > Subject: Re: RV10-List: Urgent: EAA Members - Action! >> > >> > Phil, >> > I've been in Afghanistan for the last year, and therefore out of the >> loop >> > for a while. I was just curious about what I was missing that has >> caused >> > such a reaction. >> > >> > I've seen claims of EAA not supporting home builders, and since I'm >> about to >> > start on an RV-10 at the end of this deployment, that concerns me. I >> was >> > hoping you(or someone) could bring me up to speed on what I have >> missed, and >> > what the issues are that we are having. >> > >> > I admire your convition, and your willingness to take action. I do n' t >> want >> > to seem like I'm challenging you, but I do want to be well informed >> before I >> > make a decision, >> > >> > Thanks >> > Jason >> > >> > >> > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry >> > wrote: >> > >> > Hi Everyone, >> > >> > If many of you follow =VAF=, you're probably aware that there is a >> > campaign within the EAA Membership community to participate in the >> upcoming >> > election of the EAA Board of Directors. We figured that instead of ju st >> > complaining, we should actually participate in the democratic election s. >> > >> > This simply idea led to more than 1 month of stone walling from the >> EAA. >> > Still to this day, they have not provided a simple document that allow s >> > their members to participate in the election. So we copied their >> language >> > that assigns the proxy rights to Rod Hightower and changed the name on >> it to >> > reflect me. The EAA has admitted that this is a document that they >> can't >> > turn down at the elections in a few weeks. >> > >> > In the past there were 3 choices for EAA members to participate in t he >> > election: >> > >> > 1) They could choose not to participate. >> > 2) They could show up in person to cast their vote at the annual >> business >> > meeting. >> > 3) They could assign their vote to Rod Hightower. (This is a check >> box on >> > your annual renewal) >> > >> > >> > Long story short, the elections would look like 13 votes for some >> members >> > and 16,000 votes for those that Hightower wanted. So they ended up >> being >> > appointments and not elections by the members. >> > >> > I am receiving proxy forms from all over the globe and if you are >> > frustrated with the EAA, I would appreciate it if you would do that sa me >> > thing. The form can be found at this link. >> > >> > >> > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pd f >> > >> > >> > You can send me a scanned copy or the original to: >> > >> > Phillip W. Perry >> > C/O David Carr >> > 1100 W Monroe St >> > Austin, TX 78704 >> > >> > >> > Here are the votes we will be placing and the justification for >> selecting >> > them: >> > >> > >> http://www.vansairforce.com/community/showpost.php?p=678549&postcount =68 >> > >> > >> > Today the EAA retaliated against their members and sent out a link >> asking >> > them to assign proxy votes to Rod Hightower. Please don't give total >> > control of EAA to the current membership and choose to put control of >> the >> > EAA back in the hands of the membership. Here's some details on that >> > message: >> > >> > http://www.vansairforce.com/community/showthread.php?p=679285 >> > >> > >> > Please don't assign your proxy to the EAA Leadership, and if you fee l >> > compelled I would be honored to carry your proxy vote forward at the >> > business meeting at AirVenture. This is the first time (that I'm awar e >> of) >> > in the history of EAA that the members have found a way to legitimatel y >> > participate. >> > >> > We need to get this word out to everyone who supports the effort >> ASAP. So >> > if you agree, please highlight this proxy effort and share the message >> on >> > every message board you can before some unknowing soul gives his vote >> to Rod >> > Hightower and his buddies. >> > >> > We are going to be continuing this effort going into 2013 too and ca n >> use >> > your support and even you active participation. >> > >> > Thanks, >> > Phil Perry >> > >> > RV-10 #40750 >> > EAA Lifetime Member >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > get="_blank">http://www.matronics.com/Navigator?RV10-List >> > tp://forums.matronics.com >> > _blank">http://www.matronics.com/contribution >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jul 14, 2012
Subject: Re: Urgent: EAA Members - Action!
Regulatory Advocacy to me is the most important thing EAA does, by that I mean protecting our ability to build homebuilt aircraft with the least encumbrances possible. I guess the thing I'm most concerned about is, would the new management of EAA take as seriously the threat to homebuilding that was presented when the FAA was reviewing the 51% rule? My guess is probably not, as demonstrated by the loss of the ability for instructors to charge for instruction in their own homebuilts by being an EAA member, instructing an EAA member. It used to be that anyone who was an EAA member, instructor and owned a homebuilt could charge for instruction but that loophole in the rules quietly expired. Now an instructor has to go through a lengthy letter of deviation authority process which is not standardized across the FSDOs. There used to be a guy in Florida that you could get a private multi engine ticket in an Aircam... not anymore. I think that I'm throwing my lot in with these guys. Bill N84WJ, RV-8, 791hrs. rv-8.blogspot.com Subject: Re: RV10-List: Urgent: EAA Members - Action! From: Phillip Perry <philperry9(at)gmail.com> Hi Jason, Thank you for your time in Afganistan and for sacrificing a good portion of your life for those of us here typing e-mails. Pascal hit a few key area, but there are a few more that should be brought up as well. The EAA debate has been a long time coming. It actually goes all the way back to Paul Poberezny when there was a movement to remove him. But in the past 3-4 years, the frustration with EAA has reached the boiling point for many members. Long story short, since Rod Hightower has taken over the organization the charter and image of EAA has made a dramatic shift away from their core values. The EAA has become focused on being the next AOPA politcally and they're focused on the money that can be made through AirVenture. I think it's great that AirVenture represents a strong revenue stream for the organization. But the organization has become focused on milking that stream and the memership community has paid the price. If 100% of the members disappeared tomorrow, the EAA would still exist based on the airshow. So the members are now second class citizens in the organization. Our efforts to participate in this years election were blocked by EAA by being unresponsive and ignoring our requests for a simple ballot to participate. This is a right that is entitled to the membership community within the bylaws. But this right has not been made available to the membership. As a result, the EAA holds nearly all of the membership votes. It's like the fox in the hen house in some regards. I love the EAA. I am passionate about it. I am a lifetime member. I have served as a chapter VP and President. As I sit here right now, I'm wearing a red AirVenture 2009 polo. I love the legacy EAA culture, I love the EAA brand. I really do care a lot about EAA. Since Rod Hightower has taken over the organization, the EAA has seen nearly 50 employees walk out the door from the toxic environment that Rod has created. These are important people like Charlie Becker, Adam Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is an Executive Director who has spent 22 years as an employee of the organization. The EAA culture as we know it is under attack from within. You might know Dick Kohler, he has taught a number of EAA SportAir workshops and he is passionate about EAA. You should read his comments at this link because he pretty much captures the environment that Rod has created. http://www.vansairforce.com/community/showpost.php?p=675101&postcount=122 Additional information can be found at this link containing comments from EAA Board Members who have resigned. Here is a key comment if you don't go read the entire link. =========== As Mike Dale put it was time for the Board to "grow up and start having the CEO work for the Board". I cannot be part of a rubber stamp Board whose prime loyalty is to the Founder and President rather than EAA members. =========== http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb-426a-a210-5b7ee4112049 I hope you will consider supporting our effort. We won't have enough votes to change this election, but we will have enough to put a shot across the bow of EAA's leadership. Thanks, Phil > > Subject: Re: RV10-List: Urgent: EAA Members - Action! > From: Phillip Perry <philperry9(at)gmail.com> > > > Hi Jason, > > Thank you for your time in Afganistan and for sacrificing a good > portion of your life for those of us here typing e-mails. > > Pascal hit a few key area, but there are a few more that should be > brought up as well. > > The EAA debate has been a long time coming. It actually goes all the > way back to Paul Poberezny when there was a movement to remove him. > But in the past 3-4 years, the frustration with EAA has reached the > boiling point for many members. > > Long story short, since Rod Hightower has taken over the organization > the charter and image of EAA has made a dramatic shift away from their > core values. The EAA has become focused on being the next AOPA > politcally and they're focused on the money that can be made through > AirVenture. I think it's great that AirVenture represents a strong > revenue stream for the organization. But the organization has become > focused on milking that stream and the memership community has paid > the price. If 100% of the members disappeared tomorrow, the EAA would > still exist based on the airshow. So the members are now second class > citizens in the organization. > > Our efforts to participate in this years election were blocked by EAA > by being unresponsive and ignoring our requests for a simple ballot to > participate. This is a right that is entitled to the membership > community within the bylaws. But this right has not been made > available to the membership. As a result, the EAA holds nearly all of > the membership votes. It's like the fox in the hen house in some > regards. > > I love the EAA. I am passionate about it. I am a lifetime member. I > have served as a chapter VP and President. As I sit here right now, > I'm wearing a red AirVenture 2009 polo. I love the legacy EAA > culture, I love the EAA brand. I really do care a lot about EAA. > > Since Rod Hightower has taken over the organization, the EAA has seen > nearly 50 employees walk out the door from the toxic environment that > Rod has created. These are important people like Charlie Becker, Adam > Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is > an Executive Director who has spent 22 years as an employee of the > organization. The EAA culture as we know it is under attack from > within. > > You might know Dick Kohler, he has taught a number of EAA SportAir > workshops and he is passionate about EAA. You should read his > comments at this link because he pretty much captures the environment > that Rod has created. > > http://www.vansairforce.com/community/showpost.php?p=675101&postcount=122 > > Additional information can be found at this link containing comments > from EAA Board Members who have resigned. Here is a key comment if > you don't go read the entire link. > > =========== > As Mike Dale put it was time for the Board to "grow up and start > having the CEO work for the Board". I cannot be part of a rubber stamp > Board whose prime loyalty is to the Founder and President rather than > EAA members. > =========== > > http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb-426a-a210-5b7ee4112049 > > > I hope you will consider supporting our effort. We won't have enough > votes to change this election, but we will have enough to put a shot > across the bow of EAA's leadership. > > Thanks, > Phil > > > On 7/13/12, Pascal wrote: > > Jason; > > First off, that you for the sacrifice to leave the comforts and safety of > > the US for our battle in Afghanistan. Its hard, been there, not > Afghinstan > > but another operation in 1990-1991. Thank you for your service! > > I think you ask a very good question. Phil may not be able to answer it > > completely but my initial thought is the folks writing articles for Sport > > aviation are ex flying magazine writers who have no idea of what > building a > > plane is about, there was a meeting and their has been that combined > > effort of AOPA and EAA to represent us with Lsa and other general flying > > issues, good idea, sure! I would like to see the EAA fight for > homebuilders > > and not general aviation however. > > My corporation does the same thing EAA does. Phil just wants members to > have > > more say on who is voted in versus the big kahuna at EAA himself. > > > > From: Jason Wodack > > Sent: Friday, July 13, 2012 1:11 AM > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Urgent: EAA Members - Action! > > > > Phil, > > I've been in Afghanistan for the last year, and therefore out of the loop > > for a while. I was just curious about what I was missing that has caused > > such a reaction. > > > > I've seen claims of EAA not supporting home builders, and since I'm > about to > > start on an RV-10 at the end of this deployment, that concerns me. I was > > hoping you(or someone) could bring me up to speed on what I have missed, > and > > what the issues are that we are having. > > > > I admire your convition, and your willingness to take action. I do n't > want > > to seem like I'm challenging you, but I do want to be well informed > before I > > make a decision, > > > > Thanks > > Jason > > > > > > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry > > wrote: > > > > Hi Everyone, > > > > If many of you follow =VAF=, you're probably aware that there is a > > campaign within the EAA Membership community to participate in the > upcoming > > election of the EAA Board of Directors. We figured that instead of just > > complaining, we should actually participate in the democratic elections. > > > > This simply idea led to more than 1 month of stone walling from the > EAA. > > Still to this day, they have not provided a simple document that allows > > their members to participate in the election. So we copied their > language > > that assigns the proxy rights to Rod Hightower and changed the name on > it to > > reflect me. The EAA has admitted that this is a document that they can't > > turn down at the elections in a few weeks. > > > > In the past there were 3 choices for EAA members to participate in the > > election: > > > > 1) They could choose not to participate. > > 2) They could show up in person to cast their vote at the annual > business > > meeting. > > 3) They could assign their vote to Rod Hightower. (This is a check > box on > > your annual renewal) > > > > > > Long story short, the elections would look like 13 votes for some > members > > and 16,000 votes for those that Hightower wanted. So they ended up being > > appointments and not elections by the members. > > > > I am receiving proxy forms from all over the globe and if you are > > frustrated with the EAA, I would appreciate it if you would do that same > > thing. The form can be found at this link. > > > > > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > > > > > You can send me a scanned copy or the original to: > > > > Phillip W. Perry > > C/O David Carr > > 1100 W Monroe St > > Austin, TX 78704 > > > > > > Here are the votes we will be placing and the justification for > selecting > > them: > > > > > http://www.vansairforce.com/community/showpost.php?p=678549&postcount=68 > > > > > > Today the EAA retaliated against their members and sent out a link > asking > > them to assign proxy votes to Rod Hightower. Please don't give total > > control of EAA to the current membership and choose to put control of the > > EAA back in the hands of the membership. Here's some details on that > > message: > > > > http://www.vansairforce.com/community/showthread.php?p=679285 > > > > > > Please don't assign your proxy to the EAA Leadership, and if you feel > > compelled I would be honored to carry your proxy vote forward at the > > business meeting at AirVenture. This is the first time (that I'm aware > of) > > in the history of EAA that the members have found a way to legitimately > > participate. > > > > We need to get this word out to everyone who supports the effort ASAP. > So > > if you agree, please highlight this proxy effort and share the message on > > every message board you can before some unknowing soul gives his vote to > Rod > > Hightower and his buddies. > > > > We are going to be continuing this effort going into 2013 too and can > use > > your support and even you active participation. > > > > Thanks, > > Phil Perry > > > > RV-10 #40750 > > EAA Lifetime Member > > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > > tp://forums.matronics.com > > _blank">http://www.matronics.com/contribution > > > > > > ________________________________________________________________________________
Date: Jul 14, 2012
Bill, As an RV10 owner, and CFI, I'd like to comment on your comments. Here at the OAK FSDO getting a LODA for type-specific training was not effortless, but not that difficult either. The key is telling them someone else has already done this (they never want to set precedents). Once I gave them an N number (off Van's list) everything went smoothly. I would, personally, love to give instrument instruction or Flight Reviews in my aircraft, but, as you pointed out, my LODA does not allow this. However, I do understand the FAA's position. The LODA is a waiver on the "no use for compensation or hire" clause. The FAA feels it has a duty to protect the public and it is very resistant to allowing E-AB aircraft to be held out to the public for hire. This does cause a different problem: giving only type specific instruction, there isn't enough business to justify the insurance cost, so I have decided, in general, not to do it (or only on a case by case basis, where I can get the pilot on my current insurance). This is an issue, but the FAA doesn't see it as their issue. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378290#378290 ________________________________________________________________________________
Date: Jul 14, 2012
Will be @ OSH. 503-453-6016 On Jul 14, 2012 6:49 AM, "Phillip Perry" wrote: > John, > > Are you going to be at the lifetime members banquet on Tues or attending > the annual business meeting on Saturday morning? > > Here is some commentary I put together for the folks I am representing. > We clearly won't have enough votes to move the election in any specific > direction, so our strategy for this year is to simply cast a vote that > reflects our loss of confidence in the management. Even though we won't > have the votes to move the election, we will have enough votes to put a > reasonable shot across the bow. > > For those of you who can attend the meeting at AirVenture on Saturday, I' d > encourage you to do so. Apparently these meetings typically have 50 peop le > attending and most of them are family members of the candidates. If you' re > dissatisfied and can be there, you need to be there. It's your > responsibility to be there, be seen, and cast your own vote. Otherwise, > the next best thing is to assign your proxy to me and I'll respectfully d o > it for you. > > Commentary below. > > Thanks, > Phil > > > =================== > > The most relevant piece of information involves the five Class I Director > seats that are coming open as well as additional information related to t he > nine candidates. The biographies provided in Sport Aviation might be > accurate, but there are some key details missing in a few of them. > > After some research, we found that five of the nine candidates are curren t > EAA Class I Directors. This information is explicitly called out in two > bios and only hinted-to in Alan Shackleton=92s bio. > > The five members of the board who are running for re-election are: > > Barry Davis > John (Jack) Harrington > David Lau > Dan Schwinn > Alan Shackleton > > The discovery of this information made us rethink the initial > recommendations for vote distribution and that initiated a lengthy > discussion about voting strategy. > > The EAA=92s lack of transparency (Lack of meeting minutes, no published > voting records, etc.) doesn=92t allow us to evaluate each board member on > their individual merit. Based on the state of affairs at EAA, it is hard > for us to confidently vote for any of these individuals. I=92m sure there are > a few respectable folks in here, but that can=92t be determined because o f > the lack of transparency. This is the same lack of transparency they are > responsible for creating/maintaining. > > After our discussion and the revelation that 5 of the 9 candidates are > running for re-election within all 5 open seats, I have decided to adjust > my own recommendations to vote for the 4 candidates who are not members o f > the current board of directors and leave our 5th vote unassigned. > > This means our five votes would be for: > > Doug Crumrine > Ethan Martin > Dave Morss > Steven Oxman > Open: No Vote Placed > > While some would argue this isn=92t an optimal list, it is the only list of > candidates we have to choose from and it still provides some balance > between Homebuilders, Vintage, Warbirds, and Certified GA. But most > importantly a vote for these men represents a vote in favor of fresh idea s > and leadership when compared to the current collection of Class I Directo rs. > > ============== > Thanks, > Phil > > > On Sat, Jul 14, 2012 at 7:50 AM, John Cox wrote: > >> As a Lifetime member who joined "Just before. The Roust of 2009-2010", I >> still await word of those candidates we can vote for rather than proxy t he >> continued "AOPA like" decline and unresponsiveness of EAA towards its >> builders. Can you advise whom to vote for? >> >> John Cox >> On Jul 13, 2012 9:05 AM, "Phillip Perry" wrote: >> >>> >>> >>> Hi Jason, >>> >>> Thank you for your time in Afganistan and for sacrificing a good >>> portion of your life for those of us here typing e-mails. >>> >>> Pascal hit a few key area, but there are a few more that should be >>> brought up as well. >>> >>> The EAA debate has been a long time coming. It actually goes all the >>> way back to Paul Poberezny when there was a movement to remove him. >>> But in the past 3-4 years, the frustration with EAA has reached the >>> boiling point for many members. >>> >>> Long story short, since Rod Hightower has taken over the organization >>> the charter and image of EAA has made a dramatic shift away from their >>> core values. The EAA has become focused on being the next AOPA >>> politcally and they're focused on the money that can be made through >>> AirVenture. I think it's great that AirVenture represents a strong >>> revenue stream for the organization. But the organization has become >>> focused on milking that stream and the memership community has paid >>> the price. If 100% of the members disappeared tomorrow, the EAA would >>> still exist based on the airshow. So the members are now second class >>> citizens in the organization. >>> >>> Our efforts to participate in this years election were blocked by EAA >>> by being unresponsive and ignoring our requests for a simple ballot to >>> participate. This is a right that is entitled to the membership >>> community within the bylaws. But this right has not been made >>> available to the membership. As a result, the EAA holds nearly all of >>> the membership votes. It's like the fox in the hen house in some >>> regards. >>> >>> I love the EAA. I am passionate about it. I am a lifetime member. I >>> have served as a chapter VP and President. As I sit here right now, >>> I'm wearing a red AirVenture 2009 polo. I love the legacy EAA >>> culture, I love the EAA brand. I really do care a lot about EAA. >>> >>> Since Rod Hightower has taken over the organization, the EAA has seen >>> nearly 50 employees walk out the door from the toxic environment that >>> Rod has created. These are important people like Charlie Becker, Adam >>> Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is >>> an Executive Director who has spent 22 years as an employee of the >>> organization. The EAA culture as we know it is under attack from >>> within. >>> >>> You might know Dick Kohler, he has taught a number of EAA SportAir >>> workshops and he is passionate about EAA. You should read his >>> comments at this link because he pretty much captures the environment >>> that Rod has created. >>> >>> http://www.vansairforce.com/community/showpost.php?p=675101&postcount =122 >>> >>> Additional information can be found at this link containing comments >>> from EAA Board Members who have resigned. Here is a key comment if >>> you don't go read the entire link. >>> >>> ============ >>> As Mike Dale put it was time for the Board to "grow up and start >>> having the CEO work for the Board". I cannot be part of a rubber stamp >>> Board whose prime loyalty is to the Founder and President rather than >>> EAA members. >>> ============ >>> >>> http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adc b-426a-a210-5b7ee4112049 >>> >>> >>> I hope you will consider supporting our effort. We won't have enough >>> votes to change this election, but we will have enough to put a shot >>> across the bow of EAA's leadership. >>> >>> Thanks, >>> Phil >>> >>> >>> >>> >>> On 7/13/12, Pascal wrote: >>> > Jason; >>> > First off, that you for the sacrifice to leave the comforts and safet y >>> of >>> > the US for our battle in Afghanistan. It=92s hard, been there, not >>> Afghinstan >>> > but another =93operation in 1990-1991. Thank you for your service! >>> > I think you ask a very good question. Phil may not be able to answer it >>> > completely but my initial thought is the folks writing articles for >>> Sport >>> > aviation are ex flying magazine writers who have no idea of what >>> building a >>> > plane is about, there was a meeting and their has been that =93combin ed=94 >>> > effort of AOPA and EAA to represent us with Lsa and other general >>> flying >>> > issues, good idea, sure! I would like to see the EAA fight for >>> homebuilders >>> > and not general aviation however. >>> > My corporation does the same thing EAA does. Phil just wants members >>> to have >>> > more say on who is voted in versus the big kahuna at EAA himself. >>> > >>> > From: Jason Wodack >>> > Sent: Friday, July 13, 2012 1:11 AM >>> > To: rv10-list(at)matronics.com >>> > Subject: Re: RV10-List: Urgent: EAA Members - Action! >>> > >>> > Phil, >>> > I've been in Afghanistan for the last year, and therefore out of the >>> loop >>> > for a while. I was just curious about what I was missing that has >>> caused >>> > such a reaction. >>> > >>> > I've seen claims of EAA not supporting home builders, and since I'm >>> about to >>> > start on an RV-10 at the end of this deployment, that concerns me. I >>> was >>> > hoping you(or someone) could bring me up to speed on what I have >>> missed, and >>> > what the issues are that we are having. >>> > >>> > I admire your convition, and your willingness to take action. I do >>> n't want >>> > to seem like I'm challenging you, but I do want to be well informed >>> before I >>> > make a decision, >>> > >>> > Thanks >>> > Jason >>> > >>> > >>> > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry >>> > wrote: >>> > >>> > Hi Everyone, >>> > >>> > If many of you follow =VAF=, you're probably aware that there i s a >>> > campaign within the EAA Membership community to participate in the >>> upcoming >>> > election of the EAA Board of Directors. We figured that instead of >>> just >>> > complaining, we should actually participate in the democratic >>> elections. >>> > >>> > This simply idea led to more than 1 month of stone walling from the >>> EAA. >>> > Still to this day, they have not provided a simple document that allo ws >>> > their members to participate in the election. So we copied their >>> language >>> > that assigns the proxy rights to Rod Hightower and changed the name o n >>> it to >>> > reflect me. The EAA has admitted that this is a document that they >>> can't >>> > turn down at the elections in a few weeks. >>> > >>> > In the past there were 3 choices for EAA members to participate in >>> the >>> > election: >>> > >>> > 1) They could choose not to participate. >>> > 2) They could show up in person to cast their vote at the annual >>> business >>> > meeting. >>> > 3) They could assign their vote to Rod Hightower. (This is a check >>> box on >>> > your annual renewal) >>> > >>> > >>> > Long story short, the elections would look like 13 votes for some >>> members >>> > and 16,000 votes for those that Hightower wanted. So they ended up >>> being >>> > appointments and not elections by the members. >>> > >>> > I am receiving proxy forms from all over the globe and if you are >>> > frustrated with the EAA, I would appreciate it if you would do that >>> same >>> > thing. The form can be found at this link. >>> > >>> > >>> > >>> http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf >>> > >>> > >>> > You can send me a scanned copy or the original to: >>> > >>> > Phillip W. Perry >>> > C/O David Carr >>> > 1100 W Monroe St >>> > Austin, TX 78704 >>> > >>> > >>> > Here are the votes we will be placing and the justification for >>> selecting >>> > them: >>> > >>> > >>> http://www.vansairforce.com/community/showpost.php?p=678549&postcount =68 >>> > >>> > >>> > Today the EAA retaliated against their members and sent out a link >>> asking >>> > them to assign proxy votes to Rod Hightower. Please don't give total >>> > control of EAA to the current membership and choose to put control of >>> the >>> > EAA back in the hands of the membership. Here's some details on that >>> > message: >>> > >>> > http://www.vansairforce.com/community/showthread.php?p=679285 >>> > >>> > >>> > Please don't assign your proxy to the EAA Leadership, and if you fe el >>> > compelled I would be honored to carry your proxy vote forward at the >>> > business meeting at AirVenture. This is the first time (that I'm >>> aware of) >>> > in the history of EAA that the members have found a way to legitimate ly >>> > participate. >>> > >>> > We need to get this word out to everyone who supports the effort >>> ASAP. So >>> > if you agree, please highlight this proxy effort and share the messag e >>> on >>> > every message board you can before some unknowing soul gives his vote >>> to Rod >>> > Hightower and his buddies. >>> > >>> > We are going to be continuing this effort going into 2013 too and >>> can use >>> > your support and even you active participation. >>> > >>> > Thanks, >>> > Phil Perry >>> > >>> > RV-10 #40750 >>> > EAA Lifetime Member >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > get="_blank">http://www.matronics.com/Navigator?RV10-List >>> > tp://forums.matronics.com >>> > _blank">http://www.matronics.com/contribution >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ========== >>> arget="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> http://forums.matronics.com >>> ========== >>> le, List Admin. >>> ="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jul 15, 2012
Looks like DR over on the VansAirforce Forum closed out and put the kybash on any talk of the EAA and its current direction classifying it as "politic s" which is against forum rules. What a shame considering it is one of the largest EXPIMENTAL aviation forum's and what better avenue to organize the homebuilder base. Its his sandbox though so,,,,,,,,,,,,. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "John Cox" <rv10pro(at)gmail.com> Sent: Saturday, July 14, 2012 4:29:12 PM Subject: Re: RV10-List: Urgent: EAA Members - Action! Will be @ OSH. 503-453-6016 On Jul 14, 2012 6:49 AM, "Phillip Perry" < philperry9(at)gmail.com > wrote: John, Are you going to be at the lifetime members banquet on Tues or attending th e annual business meeting on Saturday morning? Here is some commentary I put together for the folks I am representing. We clearly won't have enough votes to move the election in any specific direct ion, so our strategy for this year is to simply cast a vote that reflects o ur loss of confidence in the management. Even though we won't have the vote s to move the election, we will have enough votes to put a reasonable shot across the bow. For those of you who can attend the meeting at AirVenture on Saturday, I'd encourage you to do so. Apparently these meetings typically have 50 people attending and most of them are family members of the candidates. If you're dissatisfied and can be there, you need to be there. It's your responsibili ty to be there, be seen, and cast your own vote. Otherwise, the next best t hing is to assign your proxy to me and I'll respectfully do it for you. Commentary below. Thanks, Phil ==================== The most relevant piece of information involves the five Class I Director s eats that are coming open as well as additional information related to the nine candidates. The biographies provided in Sport Aviation might be accura te, but there are some key details missing in a few of them. After some research, we found that five of the nine candidates are current EAA Class I Directors. This information is explicitly called out in two bio s and only hinted-to in Alan Shackleton=99s bio. The five members of the board who are running for re-election are:
Barry Davis John (Jack) Harrington David Lau Dan Schwinn Alan Shackleton The discovery of this information made us rethink the initial recommendatio ns for vote distribution and that initiated a lengthy discussion about voti ng strategy. The EAA=99s lack of transparency (Lack of meeting minutes, no publish ed voting records, etc.) doesn=99t allow us to evaluate each board me mber on their individual merit. Based on the state of affairs at EAA, it is hard for us to confidently vote for any of these individuals. I=99m sure there are a few respectable folks in here, but that can=99t be d etermined because of the lack of transparency. This is the same lack of tra nsparency they are responsible for creating/maintaining. After our discussion and the revelation that 5 of the 9 candidates are runn ing for re-election within all 5 open seats, I have decided to adjust my ow n recommendations to vote for the 4 candidates who are not members of the c urrent board of directors and leave our 5th vote unassigned. This means our five votes would be for:
While some would argue this isn=99t an optimal list, it is the only l ist of candidates we have to choose from and it still provides some balance between Homebuilders, Vintage, Warbirds, and Certified GA. But most import antly a vote for these men represents a vote in favor of fresh ideas and le adership when compared to the current collection of Class I Directors. =============== Thanks, Phil On Sat, Jul 14, 2012 at 7:50 AM, John Cox < rv10pro(at)gmail.com > wrote:
As a Lifetime member who joined "Just before. The Roust of 2009-2010", I st ill await word of those candidates we can vote for rather than proxy the co ntinued "AOPA like" decline and unresponsiveness of EAA towards its builder s. Can you advise whom to vote for? John Cox On Jul 13, 2012 9:05 AM, "Phillip Perry" < philperry9(at)gmail.com > wrote:
Hi Jason, Thank you for your time in Afganistan and for sacrificing a good portion of your life for those of us here typing e-mails. Pascal hit a few key area, but there are a few more that should be brought up as well. The EAA debate has been a long time coming. It actually goes all the way back to Paul Poberezny when there was a movement to remove him. But in the past 3-4 years, the frustration with EAA has reached the boiling point for many members. Long story short, since Rod Hightower has taken over the organization the charter and image of EAA has made a dramatic shift away from their core values. The EAA has become focused on being the next AOPA politcally and they're focused on the money that can be made through AirVenture. I think it's great that AirVenture represents a strong revenue stream for the organization. But the organization has become focused on milking that stream and the memership community has paid the price. If 100% of the members disappeared tomorrow, the EAA would still exist based on the airshow. So the members are now second class citizens in the organization. Our efforts to participate in this years election were blocked by EAA by being unresponsive and ignoring our requests for a simple ballot to participate. This is a right that is entitled to the membership community within the bylaws. But this right has not been made available to the membership. As a result, the EAA holds nearly all of the membership votes. It's like the fox in the hen house in some regards. I love the EAA. I am passionate about it. I am a lifetime member. I have served as a chapter VP and President. As I sit here right now, I'm wearing a red AirVenture 2009 polo. I love the legacy EAA culture, I love the EAA brand. I really do care a lot about EAA. Since Rod Hightower has taken over the organization, the EAA has seen nearly 50 employees walk out the door from the toxic environment that Rod has created. These are important people like Charlie Becker, Adam Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is an Executive Director who has spent 22 years as an employee of the organization. The EAA culture as we know it is under attack from within. You might know Dick Kohler, he has taught a number of EAA SportAir workshops and he is passionate about EAA. You should read his comments at this link because he pretty much captures the environment that Rod has created. http://www.vansairforce.com/community/showpost.php?p=675101&postcount=1 22 Additional information can be found at this link containing comments from EAA Board Members who have resigned. Here is a key comment if you don't go read the entire link. ============= As Mike Dale put it was time for the Board to "grow up and start having the CEO work for the Board". I cannot be part of a rubber stamp Board whose prime loyalty is to the Founder and President rather than EAA members. ============= http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-adcb-42 6a-a210-5b7ee4112049 I hope you will consider supporting our effort. We won't have enough votes to change this election, but we will have enough to put a shot across the bow of EAA's leadership. Thanks, Phil On 7/13/12, Pascal < rv10flyer(at)verizon.net > wrote: > Jason; > First off, that you for the sacrifice to leave the comforts and safety of > the US for our battle in Afghanistan. It=99s hard, been there, not Afghinstan > but another =9Coperation in 1990-1991. Thank you for your service! > I think you ask a very good question. Phil may not be able to answer it > completely but my initial thought is the folks writing articles for Sport > aviation are ex flying magazine writers who have no idea of what building a > plane is about, there was a meeting and their has been that =9Ccomb ined=9D > effort of AOPA and EAA to represent us with Lsa and other general flying > issues, good idea, sure! I would like to see the EAA fight for homebuilde rs > and not general aviation however. > My corporation does the same thing EAA does. Phil just wants members to h ave > more say on who is voted in versus the big kahuna at EAA himself. > > From: Jason Wodack > Sent: Friday, July 13, 2012 1:11 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Urgent: EAA Members - Action! > > Phil, > I've been in Afghanistan for the last year, and therefore out of the loop > for a while. I was just curious about what I was missing that has caused > such a reaction. > > I've seen claims of EAA not supporting home builders, and since I'm about to > start on an RV-10 at the end of this deployment, that concerns me. I was > hoping you(or someone) could bring me up to speed on what I have missed, and > what the issues are that we are having. > > I admire your convition, and your willingness to take action. I do n't wa nt > to seem like I'm challenging you, but I do want to be well informed befor e I > make a decision, > > Thanks > Jason > > > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry < philperry9(at)gmail.com > > wrote: > > Hi Everyone, > > If many of you follow =VAF=, you're probably aware that there is a > campaign within the EAA Membership community to participate in the upcomi ng > election of the EAA Board of Directors. We figured that instead of just > complaining, we should actually participate in the democratic elections. > > This simply idea led to more than 1 month of stone walling from the EAA. > Still to this day, they have not provided a simple document that allows > their members to participate in the election. So we copied their language > that assigns the proxy rights to Rod Hightower and changed the name on it to > reflect me. The EAA has admitted that this is a document that they can't > turn down at the elections in a few weeks. > > In the past there were 3 choices for EAA members to participate in the > election: > > 1) They could choose not to participate. > 2) They could show up in person to cast their vote at the annual business > meeting. > 3) They could assign their vote to Rod Hightower. (This is a check box on > your annual renewal) > > > Long story short, the elections would look like 13 votes for some members > and 16,000 votes for those that Hightower wanted. So they ended up being > appointments and not elections by the members. > > I am receiving proxy forms from all over the globe and if you are > frustrated with the EAA, I would appreciate it if you would do that same > thing. The form can be found at this link. > > > http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf > > > You can send me a scanned copy or the original to: > > Phillip W. Perry > C/O David Carr > 1100 W Monroe St > Austin, TX 78704 > > > Here are the votes we will be placing and the justification for selecting > them: > > http://www.vansairforce.com/community/showpost.php?p=678549&postcount =68 > > > Today the EAA retaliated against their members and sent out a link asking > them to assign proxy votes to Rod Hightower. Please don't give total > control of EAA to the current membership and choose to put control of the > EAA back in the hands of the membership. Here's some details on that > message: > > http://www.vansairforce.com/community/showthread.php?p=679285 > > > Please don't assign your proxy to the EAA Leadership, and if you feel > compelled I would be honored to carry your proxy vote forward at the > business meeting at AirVenture. This is the first time (that I'm aware of ) > in the history of EAA that the members have found a way to legitimately > participate. > > We need to get this word out to everyone who supports the effort ASAP. So > if you agree, please highlight this proxy effort and share the message on > every message board you can before some unknowing soul gives his vote to Rod > Hightower and his buddies. > > We are going to be continuing this effort going into 2013 too and can use > your support and even you active participation. > > Thanks, > Phil Perry > > RV-10 #40750 > EAA Lifetime Member > > > > > > > > > > > > > > > get="_blank"> http://www.matronics.com/Navigator?RV10-List > tp:// forums.matronics.com > _blank"> http://www.matronics.com/contribution > > > > > > > =========== arget="_blank"> http://www.matronics.com/Navigator?RV10-List =========== http://forums.matronics.com =========== le, List Admin. ="_blank"> http://www.matronics.com/contribution ===========
get="_blank"> http://www.matronics.com/Navigator?RV10-List tp:// forums.m atronics.com _blank"> http://www.matronics.com/contribution
get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution
== ________________________________________________________________________________
Date: Jul 15, 2012
Yeah it's a disappointing to see that the thread went from supported to unsupported on VAF overnight. We're going to keep pushing the effort though. There are a handful of us looking for some alternative ways to spread the word. It's only a setback and not the end. We'll gain ground some days and lose ground on others. But the internet is much larger than Doug's website, so don't give up yet. Doug's site is just where it got started. Phil ________________________________________________________________________________
Date: Jul 15, 2012
Keep the faith Phil, by your actions it=99s a step to show that some members want change. I would expect there to be pushback. It does sound like Politics, EAA choses who they want and say they are doing it on behalf of the members. You are just trying to actually make that happen. Thanks! From: Phillip Perry Sent: Sunday, July 15, 2012 6:43 AM Subject: Re: RV10-List: Urgent: EAA Members - Action! Yeah it's a disappointing to see that the thread went from supported to unsupported on VAF overnight. We're going to keep pushing the effort though. There are a handful of us looking for some alternative ways to spread the word. It's only a setback and not the end. We'll gain ground some days and lose ground on others. But the internet is much larger than Doug's website, so don't give up yet. Doug's site is just where it got started. Phil ________________________________________________________________________________
Date: Jul 15, 2012
That is one reason that I rarely spend much time on VAF. Matt seems to be much more permissive about what is posted here, and the participants are better looking and more intelligent. ;-)) On Sun, Jul 15, 2012 at 6:09 AM, wrote: > Looks like DR over on the VansAirforce Forum closed out and put the kybas h > on any talk of the EAA and its current direction classifying it as > "politics" which is against forum rules. What a shame considering it is > one of the largest EXPIMENTAL aviation forum's and what better avenue to > organize the homebuilder base. Its his sandbox though so,,,,,,,,,,,,. > > David Clifford > > RV-10 Builder > Howell, MI > > ------------------------------ > *From: *"John Cox" <rv10pro(at)gmail.com> > *To: *rv10-list(at)matronics.com > *Sent: *Saturday, July 14, 2012 4:29:12 PM > > *Subject: *Re: RV10-List: Urgent: EAA Members - Action! > > Will be @ OSH. > > 503-453-6016 > On Jul 14, 2012 6:49 AM, "Phillip Perry" wrote: > >> John, >> >> Are you going to be at the lifetime members banquet on Tues or attending >> the annual business meeting on Saturday morning? >> >> Here is some commentary I put together for the folks I am representing. >> We clearly won't have enough votes to move the election in any specific >> direction, so our strategy for this year is to simply cast a vote that >> reflects our loss of confidence in the management. Even though we won't >> have the votes to move the election, we will have enough votes to put a >> reasonable shot across the bow. >> >> For those of you who can attend the meeting at AirVenture on Saturday, >> I'd encourage you to do so. Apparently these meetings typically have 50 >> people attending and most of them are family members of the candidates. If >> you're dissatisfied and can be there, you need to be there. It's your >> responsibility to be there, be seen, and cast your own vote. Otherwise, >> the next best thing is to assign your proxy to me and I'll respectfully do >> it for you. >> >> Commentary below. >> >> Thanks, >> Phil >> >> >> >> =================== >> >> The most relevant piece of information involves the five Class I Directo r >> seats that are coming open as well as additional information related to the >> nine candidates. The biographies provided in Sport Aviation might be >> accurate, but there are some key details missing in a few of them. >> >> After some research, we found that five of the nine candidates are >> current EAA Class I Directors. This information is explicitly called out in >> two bios and only hinted-to in Alan Shackleton=92s bio. >> >> The five members of the board who are running for re-election are: >> >> Barry Davis >> John (Jack) Harrington >> David Lau >> Dan Schwinn >> Alan Shackleton >> >> The discovery of this information made us rethink the initial >> recommendations for vote distribution and that initiated a lengthy >> discussion about voting strategy. >> >> The EAA=92s lack of transparency (Lack of meeting minutes, no published >> voting records, etc.) doesn=92t allow us to evaluate each board member o n >> their individual merit. Based on the state of affairs at EAA, it is hard >> for us to confidently vote for any of these individuals. I=92m sure ther e are >> a few respectable folks in here, but that can=92t be determined because of >> the lack of transparency. This is the same lack of transparency they are >> responsible for creating/maintaining. >> >> After our discussion and the revelation that 5 of the 9 candidates are >> running for re-election within all 5 open seats, I have decided to adjus t >> my own recommendations to vote for the 4 candidates who are not members of >> the current board of directors and leave our 5th vote unassigned. >> >> This means our five votes would be for: >> >> Doug Crumrine >> Ethan Martin >> Dave Morss >> Steven Oxman >> Open: No Vote Placed >> >> While some would argue this isn=92t an optimal list, it is the only list of >> candidates we have to choose from and it still provides some balance >> between Homebuilders, Vintage, Warbirds, and Certified GA. But most >> importantly a vote for these men represents a vote in favor of fresh ide as >> and leadership when compared to the current collection of Class I Direct ors. >> >> ============== >> Thanks, >> Phil >> >> >> >> On Sat, Jul 14, 2012 at 7:50 AM, John Cox wrote: >> >>> As a Lifetime member who joined "Just before. The Roust of 2009-2010", I >>> still await word of those candidates we can vote for rather than proxy the >>> continued "AOPA like" decline and unresponsiveness of EAA towards its >>> builders. Can you advise whom to vote for? >>> >>> John Cox >>> On Jul 13, 2012 9:05 AM, "Phillip Perry" wrote: >>> >>>> >>>> >>>> Hi Jason, >>>> >>>> Thank you for your time in Afganistan and for sacrificing a good >>>> portion of your life for those of us here typing e-mails. >>>> >>>> Pascal hit a few key area, but there are a few more that should be >>>> brought up as well. >>>> >>>> The EAA debate has been a long time coming. It actually goes all the >>>> way back to Paul Poberezny when there was a movement to remove him. >>>> But in the past 3-4 years, the frustration with EAA has reached the >>>> boiling point for many members. >>>> >>>> Long story short, since Rod Hightower has taken over the organization >>>> the charter and image of EAA has made a dramatic shift away from their >>>> core values. The EAA has become focused on being the next AOPA >>>> politcally and they're focused on the money that can be made through >>>> AirVenture. I think it's great that AirVenture represents a strong >>>> revenue stream for the organization. But the organization has become >>>> focused on milking that stream and the memership community has paid >>>> the price. If 100% of the members disappeared tomorrow, the EAA would >>>> still exist based on the airshow. So the members are now second class >>>> citizens in the organization. >>>> >>>> Our efforts to participate in this years election were blocked by EAA >>>> by being unresponsive and ignoring our requests for a simple ballot to >>>> participate. This is a right that is entitled to the membership >>>> community within the bylaws. But this right has not been made >>>> available to the membership. As a result, the EAA holds nearly all of >>>> the membership votes. It's like the fox in the hen house in some >>>> regards. >>>> >>>> I love the EAA. I am passionate about it. I am a lifetime member. I >>>> have served as a chapter VP and President. As I sit here right now, >>>> I'm wearing a red AirVenture 2009 polo. I love the legacy EAA >>>> culture, I love the EAA brand. I really do care a lot about EAA. >>>> >>>> Since Rod Hightower has taken over the organization, the EAA has seen >>>> nearly 50 employees walk out the door from the toxic environment that >>>> Rod has created. These are important people like Charlie Becker, Adam >>>> Smith, Barry Elk, etc. Just yesterday, they lost HG Frautschy who is >>>> an Executive Director who has spent 22 years as an employee of the >>>> organization. The EAA culture as we know it is under attack from >>>> within. >>>> >>>> You might know Dick Kohler, he has taught a number of EAA SportAir >>>> workshops and he is passionate about EAA. You should read his >>>> comments at this link because he pretty much captures the environment >>>> that Rod has created. >>>> >>>> >>>> http://www.vansairforce.com/community/showpost.php?p=675101&postcoun t=122 >>>> >>>> Additional information can be found at this link containing comments >>>> from EAA Board Members who have resigned. Here is a key comment if >>>> you don't go read the entire link. >>>> >>>> ============ >>>> As Mike Dale put it was time for the Board to "grow up and start >>>> having the CEO work for the Board". I cannot be part of a rubber stamp >>>> Board whose prime loyalty is to the Founder and President rather than >>>> EAA members. >>>> ============ >>>> >>>> http://www.aero-news.net/index.cfm?do=main.textpost&id=7d613991-ad cb-426a-a210-5b7ee4112049 >>>> >>>> >>>> I hope you will consider supporting our effort. We won't have enough >>>> votes to change this election, but we will have enough to put a shot >>>> across the bow of EAA's leadership. >>>> >>>> Thanks, >>>> Phil >>>> >>>> >>>> >>>> >>>> On 7/13/12, Pascal wrote: >>>> > Jason; >>>> > First off, that you for the sacrifice to leave the comforts and >>>> safety of >>>> > the US for our battle in Afghanistan. It=92s hard, been there, not >>>> Afghinstan >>>> > but another =93operation in 1990-1991. Thank you for your service! >>>> > I think you ask a very good question. Phil may not be able to answer >>>> it >>>> > completely but my initial thought is the folks writing articles for >>>> Sport >>>> > aviation are ex flying magazine writers who have no idea of what >>>> building a >>>> > plane is about, there was a meeting and their has been that =93combi ned=94 >>>> > effort of AOPA and EAA to represent us with Lsa and other general >>>> flying >>>> > issues, good idea, sure! I would like to see the EAA fight for >>>> homebuilders >>>> > and not general aviation however. >>>> > My corporation does the same thing EAA does. Phil just wants members >>>> to have >>>> > more say on who is voted in versus the big kahuna at EAA himself. >>>> > >>>> > From: Jason Wodack >>>> > Sent: Friday, July 13, 2012 1:11 AM >>>> > To: rv10-list(at)matronics.com >>>> > Subject: Re: RV10-List: Urgent: EAA Members - Action! >>>> > >>>> > Phil, >>>> > I've been in Afghanistan for the last year, and therefore out of the >>>> loop >>>> > for a while. I was just curious about what I was missing that has >>>> caused >>>> > such a reaction. >>>> > >>>> > I've seen claims of EAA not supporting home builders, and since I'm >>>> about to >>>> > start on an RV-10 at the end of this deployment, that concerns me. I >>>> was >>>> > hoping you(or someone) could bring me up to speed on what I have >>>> missed, and >>>> > what the issues are that we are having. >>>> > >>>> > I admire your convition, and your willingness to take action. I do >>>> n't want >>>> > to seem like I'm challenging you, but I do want to be well informed >>>> before I >>>> > make a decision, >>>> > >>>> > Thanks >>>> > Jason >>>> > >>>> > >>>> > On Fri, Jul 13, 2012 at 2:44 AM, Phillip Perry >>>> > wrote: >>>> > >>>> > Hi Everyone, >>>> > >>>> > If many of you follow =VAF=, you're probably aware that there is a >>>> > campaign within the EAA Membership community to participate in the >>>> upcoming >>>> > election of the EAA Board of Directors. We figured that instead of >>>> just >>>> > complaining, we should actually participate in the democratic >>>> elections. >>>> > >>>> > This simply idea led to more than 1 month of stone walling from th e >>>> EAA. >>>> > Still to this day, they have not provided a simple document that >>>> allows >>>> > their members to participate in the election. So we copied their >>>> language >>>> > that assigns the proxy rights to Rod Hightower and changed the name >>>> on it to >>>> > reflect me. The EAA has admitted that this is a document that they >>>> can't >>>> > turn down at the elections in a few weeks. >>>> > >>>> > In the past there were 3 choices for EAA members to participate in >>>> the >>>> > election: >>>> > >>>> > 1) They could choose not to participate. >>>> > 2) They could show up in person to cast their vote at the annual >>>> business >>>> > meeting. >>>> > 3) They could assign their vote to Rod Hightower. (This is a chec k >>>> box on >>>> > your annual renewal) >>>> > >>>> > >>>> > Long story short, the elections would look like 13 votes for some >>>> members >>>> > and 16,000 votes for those that Hightower wanted. So they ended up >>>> being >>>> > appointments and not elections by the members. >>>> > >>>> > I am receiving proxy forms from all over the globe and if you are >>>> > frustrated with the EAA, I would appreciate it if you would do that >>>> same >>>> > thing. The form can be found at this link. >>>> > >>>> > >>>> > >>>> http://dl.dropbox.com/u/26343935/EAA%20Member%20Proxy%20Statement.pdf >>>> > >>>> > >>>> > You can send me a scanned copy or the original to: >>>> > >>>> > Phillip W. Perry >>>> > C/O David Carr >>>> > 1100 W Monroe St >>>> > Austin, TX 78704 >>>> > >>>> > >>>> > Here are the votes we will be placing and the justification for >>>> selecting >>>> > them: >>>> > >>>> > >>>> http://www.vansairforce.com/community/showpost.php?p=678549&postcoun t=68 >>>> > >>>> > >>>> > Today the EAA retaliated against their members and sent out a link >>>> asking >>>> > them to assign proxy votes to Rod Hightower. Please don't give tota l >>>> > control of EAA to the current membership and choose to put control o f >>>> the >>>> > EAA back in the hands of the membership. Here's some details on tha t >>>> > message: >>>> > >>>> > http://www.vansairforce.com/community/showthread.php?p=679285 >>>> > >>>> > >>>> > Please don't assign your proxy to the EAA Leadership, and if you >>>> feel >>>> > compelled I would be honored to carry your proxy vote forward at the >>>> > business meeting at AirVenture. This is the first time (that I'm >>>> aware of) >>>> > in the history of EAA that the members have found a way to >>>> legitimately >>>> > participate. >>>> > >>>> > We need to get this word out to everyone who supports the effort >>>> ASAP. So >>>> > if you agree, please highlight this proxy effort and share the >>>> message on >>>> > every message board you can before some unknowing soul gives his vot e >>>> to Rod >>>> > Hightower and his buddies. >>>> > >>>> > We are going to be continuing this effort going into 2013 too and >>>> can use >>>> > your support and even you active participation. >>>> > >>>> > Thanks, >>>> > Phil Perry >>>> > >>>> > RV-10 #40750 >>>> > EAA Lifetime Member >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > get="_blank">http://www.matronics.com/Navigator?RV10-List >>>> > tp://forums.matronics.com >>>> > _blank">http://www.matronics.com/contribution >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> > >>>> >>>> >>>> ========== >>>> arget="_blank">http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> http://forums.matronics.com >>>> ========== >>>> le, List Admin. >>>> ="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
From: "Richard Barnes" <rickbarnes(at)highlanddental.com>
Subject: Death in the Family
Date: Jul 16, 2012
Just a note to let you know that my dear friend and RV10 builder Mike Howe passed away last week. For many of you, his web site was of great value. He took several hundred photos of each step in the build process. His passion was flying and to be able to build the RV10 brought him great joy. We used your help on the forum to keep us out of too much trouble. For those of you who may not have seen his web site: http://www.etigerrr.com/Default.htm His obituary is below. http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=micha el-dewitt-howe <http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=mich ael-dewitt-howe&pid=158527721> &pid=158527721 I know he appreciated all of your comments, especially the "primer wars". ________________________________________________________________________________
Date: Jul 16, 2012
Subject: Re: Death in the Family
He certainly will be missed. Thanks for letting us know, Rick. He was a great guy. We stopped by his hangar and saw him on one of our trips out to Utah. He was one of those fellas with an extreme love of aviation and someone who treated all of us builders as good friends. It's too bad we lost him. Tim On 7/16/2012 9:52 AM, Richard Barnes wrote: > Just a note to let you know that my dear friend and RV10 builder Mike > Howe passed away last week. For many of you, his web site was of great > value. He took several hundred photos of each step in the build > process. His passion was flying and to be able to build the RV10 > brought him great joy. We used your help on the forum to keep us out > of too much trouble. For those of you who may not have seen his web > site: http://www.etigerrr.com/Default.htm His obituary is below. > > http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=michael-dewitt-howe&pid=158527721 > > I know he appreciated all of your comments, especially the primer wars. > ________________________________________________________________________________
Date: Jul 16, 2012
I'm sorry to hear that Rick. I never met him personally but I always enjoyed following along on the site. He's going to be missed. Phil On Mon, Jul 16, 2012 at 10:15 AM, Tim Olson wrote: > > He certainly will be missed. Thanks for letting us know, Rick. > He was a great guy. We stopped by his hangar and saw him on > one of our trips out to Utah. He was one of those fellas with > an extreme love of aviation and someone who treated all of > us builders as good friends. It's too bad we lost him. > Tim > > > On 7/16/2012 9:52 AM, Richard Barnes wrote: > >> Just a note to let you know that my dear friend and RV10 builder Mike >> Howe passed away last week. For many of you, his web site was of great >> value. He took several hundred photos of each step in the build >> process. His passion was flying and to be able to build the RV10 >> brought him great joy. We used your help on the forum to keep us out >> of too much trouble. For those of you who may not have seen his web >> site: http://www.etigerrr.com/**Default.htm ult.htm> His obituary is below. >> >> http://www.legacy.com/**obituaries/saltlaketribune/** >> obituary-print.aspx?n=michael-**dewitt-howe&pid=158527721<http://www .legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=michael-dewi tt-howe&pid=158527721> >> >> I know he appreciated all of your comments, especially the =93primer war s=94. >> >> =====**=================== ===========**= ronics.com/Navigator?RV10-List> =====**=================== ===========**= =====**=================== ===========**= com/contribution> =====**=================== ===========**= > > ________________________________________________________________________________
Date: Jul 16, 2012
I used the website along with Tim Olson=99s for hundreds of references. Pictures and descriptions were excellent! A real asset to the RV-10 builders! So Glad he saw it=99s completion and won an award for the effort! He=99ll be missed! From: Richard Barnes Sent: Monday, July 16, 2012 7:52 AM Subject: RV10-List: Death in the Family Just a note to let you know that my dear friend and RV10 builder Mike Howe passed away last week. For many of you, his web site was of great value. He took several hundred photos of each step in the build process. His passion was flying and to be able to build the RV10 brought him great joy. We used your help on the forum to keep us out of too much trouble. For those of you who may not have seen his web site: http://www.etigerrr.com/Default.htm His obituary is below. http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n= michael-dewitt-howe&pid=158527721 I know he appreciated all of your comments, especially the =9Cprimer wars=9D. ________________________________________________________________________________
Date: Jul 16, 2012
My condolences. Mike was kind enough to show me around the plane you share and the hangar a couple years ago. I have relied on his website constantly. A real gentleman. Kelly On Mon, Jul 16, 2012 at 7:52 AM, Richard Barnes < rickbarnes(at)highlanddental.com> wrote: > Just a note to let you know that my dear friend and RV10 builder Mike How e > passed away last week. For many of you, his web site was of great value. > He took several hundred photos of each step in the build process. His > passion was flying and to be able to build the RV10 brought him great joy . > We used your help on the forum to keep us out of too much trouble. For > those of you who may not have seen his web site: > http://www.etigerrr.com/Default.htm His obituary is below.**** > > > http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n= michael-dewitt-howe&pid=158527721 > **** > > I know he appreciated all of your comments, especially the =93primer wars =94.* > *** > > ** ** > > ** ** > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jul 16, 2012
Terrible news! I never met him personally but chatted several times via email. Always very helpful and encouraging. You can almost build an RV10 with the instruction on his site alone. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=378407#378407 ________________________________________________________________________________
Date: Jul 16, 2012
Mike will be missed at the airport.=C2- He was the guy who was willing to do anything to help you with a project or anything else.=C2- I will miss him stopping by to say hi.=C2- =0A=0ARick, I am sure glad you helped Mik e finish the RV-10. It is great he was able to fly it and enjoy it before p assing. =0A=0A=C2-=0AScott Schmidt=0Ascottmschmidt(at)yahoo.com=0A=0A=0A=0A> ________________________________=0A> From: Richard Barnes <rickbarnes@highl anddental.com>=0A>To: rv10-list(at)matronics.com =0A>Sent: Monday, July 16, 20 12 8:52 AM=0A>Subject: RV10-List: Death in the Family=0A> =0A>=0A>Just a no te to let you know that my dear friend and RV10 builder Mike Howe passed aw ay last week.=C2- For many of you, his web site was of great value.=C2- He took several hundred photos of each step in the build process.=C2- Hi s passion was flying and to be able to build the RV10 brought him great joy .=C2- We used your help =C2-on the forum to keep us out of too much tro uble.=C2- For those of you who may not have seen his web site: http://www .etigerrr.com/Default.htm =C2-=C2-His obituary is below.=0A>http://www. legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=michael-dewit t-howe&pid=158527721=0A>I know he appreciated all of your comments, espec ========== =0A>=0A> ________________________________________________________________________________
Subject: Urgent: EAA Members - Action!
Date: Jul 16, 2012
ICBTb21lIHRoaW5ncyBuZXZlciBjaGFuZ2Ugb3ZlciB0aGVyZS4gIFRoaXMgaXMgd2h5IHdoZW4g aGUgc2h1dCBkb3duIHRoZSBvbGQgWWFob28gZm9ydW1zIHNldmVyYWwgb2YgdXMgaW5zdGVhZCBk ZWNpZGVkIHRvIHB1dCBvdXIgc3VwcG9ydCBiZWhpbmQgTWF0cm9uaWNzIHdoaWNoIGlzIHRydWx5 IGRvbmF0aW9uIHN1cHBvcnRlZCB2cy4gdGhlIGhpZ2ggJCQgcmV2ZW51ZSBoZSByZWNlaXZlcyBm cm9tIGFkdmVydGlzZXJzLiAgSGUgc3RpbGwgcGFzc2VzIHRoZSB0aW4gY3VwIGFyb3VuZCB3aXRo IHRoZSDigJhwb29yIG9sZSBtZSBhbmQgbXkgbGl0dGxlIHdlYnNpdGXigJkgcmhldG9yaWMgd2hp bGUgcHJvaGliaXRpbmcgYW55b25lIHRoYXQgc2VsbHMgYSBwcm9kdWN0IGZyb20gY29udHJpYnV0 aW5nIHRvIGFueSBkaXNjdXNzaW9ucyB3aXRob3V0IGNvdWdoaW5nIHVwIGNvbnNpZGVyYWJseSBm aXJzdC4gIEkgZHJldyB0aGUgbGluZSB3aGVuIG15IHBvc3RzIHdlcmUgZWRpdGVkLCBub3QgZGVs ZXRlZCwgZWRpdGVkIHRvIHJlbW92ZSBhbnkgY3JpdGljaXNtIG9mIGhpcyBjZW5zb3JpbmcgcHJh Y3RpY2VzIGJhY2sgZHVyaW5nIHRoZSBZYWhvbyBkYXlzLiAgSSBwcm9iYWJseSB3b3VsZG7igJl0 IGNhcmUgaWYgaGUgd291bGQgZHJvcCB0aGUgbXkgc2l0ZSBuZWVkcyB5b3VyIGRvbmF0aW9uIEJT IGFuZCBqdXN0IHJhbiBpdCBhcyBhZCBzdXBwb3J0ZWQgbGlrZSBpdCByZWFsbHkgaXMuICBHbGFk IHdlIHdlcmUgYWJsZSB0byBrZWVwIHRoaXMgZ3JvdXAgZ29pbmcgZm9yIG9wZW4gZGlzY3Vzc2lv biwgZXZlbiBpZiB3ZSBkbyBnZXQgb2ZmIHRvcGljIG9jY2FzaW9uYWxseS4NCg0KT2ZmIHNvYXBi b3ggOikNCkRvIG5vdCBhcmNoaXZlDQpNaWNoYWVsDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1z ZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9u aWNzLmNvbV0gT24gQmVoYWxmIE9mIGRhdmlkc291dHBvc3RAY29tY2FzdC5uZXQNClNlbnQ6IFN1 bmRheSwgSnVseSAxNSwgMjAxMiA4OjA5IEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20N ClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFVyZ2VudDogRUFBIE1lbWJlcnMgLSBBY3Rpb24hDQoN Ckxvb2tzIGxpa2UgRFIgb3ZlciBvbiB0aGUgVmFuc0FpcmZvcmNlIEZvcnVtIGNsb3NlZCBvdXQg YW5kIHB1dCB0aGUga3liYXNoIG9uIGFueSB0YWxrIG9mIHRoZSBFQUEgYW5kIGl0cyBjdXJyZW50 IGRpcmVjdGlvbiBjbGFzc2lmeWluZyBpdCBhcyAicG9saXRpY3MiIHdoaWNoIGlzIGFnYWluc3Qg Zm9ydW0gcnVsZXMuICBXaGF0IGEgc2hhbWUgY29uc2lkZXJpbmcgaXQgaXMgb25lIG9mIHRoZSBs YXJnZXN0IEVYUElNRU5UQUwgYXZpYXRpb24gZm9ydW0ncyAgYW5kIHdoYXQgYmV0dGVyIGF2ZW51 ZSB0byBvcmdhbml6ZSB0aGUgaG9tZWJ1aWxkZXIgYmFzZS4gIEl0cyBoaXMgc2FuZGJveCB0aG91 Z2ggc28sLCwsLCwsLCwsLCwuDQpEYXZpZCBDbGlmZm9yZA0KDQpSVi0xMCBCdWlsZGVyDQpIb3dl bGwsICBNSQ0KDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KRnJvbTogIkpvaG4g Q294IiA8cnYxMHByb0BnbWFpbC5jb208bWFpbHRvOnJ2MTBwcm9AZ21haWwuY29tPj4NClRvOiBy djEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpT ZW50OiBTYXR1cmRheSwgSnVseSAxNCwgMjAxMiA0OjI5OjEyIFBNDQpTdWJqZWN0OiBSZTogUlYx MC1MaXN0OiBVcmdlbnQ6IEVBQSBNZW1iZXJzIC0gQWN0aW9uIQ0KDQpXaWxsIGJlIEAgT1NILg0K DQo1MDMtNDUzLTYwMTYNCk9uIEp1bCAxNCwgMjAxMiA2OjQ5IEFNLCAiUGhpbGxpcCBQZXJyeSIg PHBoaWxwZXJyeTlAZ21haWwuY29tPG1haWx0bzpwaGlscGVycnk5QGdtYWlsLmNvbT4+IHdyb3Rl Og0KSm9obiwNCg0KQXJlIHlvdSBnb2luZyB0byBiZSBhdCB0aGUgbGlmZXRpbWUgbWVtYmVycyBi YW5xdWV0IG9uIFR1ZXMgb3IgYXR0ZW5kaW5nIHRoZSBhbm51YWwgYnVzaW5lc3MgbWVldGluZyBv biBTYXR1cmRheSBtb3JuaW5nPw0KDQpIZXJlIGlzIHNvbWUgY29tbWVudGFyeSBJIHB1dCB0b2dl dGhlciBmb3IgdGhlIGZvbGtzIEkgYW0gcmVwcmVzZW50aW5nLiAgV2UgY2xlYXJseSB3b24ndCBo YXZlIGVub3VnaCB2b3RlcyB0byBtb3ZlIHRoZSBlbGVjdGlvbiBpbiBhbnkgc3BlY2lmaWMgZGly ZWN0aW9uLCBzbyBvdXIgc3RyYXRlZ3kgZm9yIHRoaXMgeWVhciBpcyB0byBzaW1wbHkgY2FzdCBh IHZvdGUgdGhhdCByZWZsZWN0cyBvdXIgbG9zcyBvZiBjb25maWRlbmNlIGluIHRoZSBtYW5hZ2Vt ZW50LiAgRXZlbiB0aG91Z2ggd2Ugd29uJ3QgaGF2ZSB0aGUgdm90ZXMgdG8gbW92ZSB0aGUgZWxl Y3Rpb24sIHdlIHdpbGwgaGF2ZSBlbm91Z2ggdm90ZXMgdG8gcHV0IGEgcmVhc29uYWJsZSBzaG90 IGFjcm9zcyB0aGUgYm93Lg0KDQpGb3IgdGhvc2Ugb2YgeW91IHdobyBjYW4gYXR0ZW5kIHRoZSBt ZWV0aW5nIGF0IEFpclZlbnR1cmUgb24gU2F0dXJkYXksIEknZCBlbmNvdXJhZ2UgeW91IHRvIGRv IHNvLiAgQXBwYXJlbnRseSB0aGVzZSBtZWV0aW5ncyB0eXBpY2FsbHkgaGF2ZSA1MCBwZW9wbGUg YXR0ZW5kaW5nIGFuZCBtb3N0IG9mIHRoZW0gYXJlIGZhbWlseSBtZW1iZXJzIG9mIHRoZSBjYW5k aWRhdGVzLiAgSWYgeW91J3JlIGRpc3NhdGlzZmllZCBhbmQgY2FuIGJlIHRoZXJlLCB5b3UgbmVl ZCB0byBiZSB0aGVyZS4gIEl0J3MgeW91ciByZXNwb25zaWJpbGl0eSB0byBiZSB0aGVyZSwgYmUg c2VlbiwgYW5kIGNhc3QgeW91ciBvd24gdm90ZS4gIE90aGVyd2lzZSwgdGhlIG5leHQgYmVzdCB0 aGluZyBpcyB0byBhc3NpZ24geW91ciBwcm94eSB0byBtZSBhbmQgSSdsbCByZXNwZWN0ZnVsbHkg ZG8gaXQgZm9yIHlvdS4NCg0KQ29tbWVudGFyeSBiZWxvdy4NCg0KVGhhbmtzLA0KUGhpbA0KDQoN Cg0KPT09PT09PT09PT09PT09PT09PT0NCg0KVGhlIG1vc3QgcmVsZXZhbnQgcGllY2Ugb2YgaW5m b3JtYXRpb24gaW52b2x2ZXMgdGhlIGZpdmUgQ2xhc3MgSSBEaXJlY3RvciBzZWF0cyB0aGF0IGFy ZSBjb21pbmcgb3BlbiBhcyB3ZWxsIGFzIGFkZGl0aW9uYWwgaW5mb3JtYXRpb24gcmVsYXRlZCB0 byB0aGUgbmluZSBjYW5kaWRhdGVzLiBUaGUgYmlvZ3JhcGhpZXMgcHJvdmlkZWQgaW4gU3BvcnQg QXZpYXRpb24gbWlnaHQgYmUgYWNjdXJhdGUsIGJ1dCB0aGVyZSBhcmUgc29tZSBrZXkgZGV0YWls cyBtaXNzaW5nIGluIGEgZmV3IG9mIHRoZW0uDQoNCkFmdGVyIHNvbWUgcmVzZWFyY2gsIHdlIGZv dW5kIHRoYXQgZml2ZSBvZiB0aGUgbmluZSBjYW5kaWRhdGVzIGFyZSBjdXJyZW50IEVBQSBDbGFz cyBJIERpcmVjdG9ycy4gVGhpcyBpbmZvcm1hdGlvbiBpcyBleHBsaWNpdGx5IGNhbGxlZCBvdXQg aW4gdHdvIGJpb3MgYW5kIG9ubHkgaGludGVkLXRvIGluIEFsYW4gU2hhY2tsZXRvbuKAmXMgYmlv Lg0KDQpUaGUgZml2ZSBtZW1iZXJzIG9mIHRoZSBib2FyZCB3aG8gYXJlIHJ1bm5pbmcgZm9yIHJl LWVsZWN0aW9uIGFyZToNCkJhcnJ5IERhdmlzDQpKb2huIChKYWNrKSBIYXJyaW5ndG9uDQpEYXZp ZCBMYXUNCkRhbiBTY2h3aW5uDQpBbGFuIFNoYWNrbGV0b24NClRoZSBkaXNjb3Zlcnkgb2YgdGhp cyBpbmZvcm1hdGlvbiBtYWRlIHVzIHJldGhpbmsgdGhlIGluaXRpYWwgcmVjb21tZW5kYXRpb25z IGZvciB2b3RlIGRpc3RyaWJ1dGlvbiBhbmQgdGhhdCBpbml0aWF0ZWQgYSBsZW5ndGh5IGRpc2N1 c3Npb24gYWJvdXQgdm90aW5nIHN0cmF0ZWd5Lg0KDQpUaGUgRUFB4oCZcyBsYWNrIG9mIHRyYW5z cGFyZW5jeSAoTGFjayBvZiBtZWV0aW5nIG1pbnV0ZXMsIG5vIHB1Ymxpc2hlZCB2b3RpbmcgcmVj b3JkcywgZXRjLikgZG9lc27igJl0IGFsbG93IHVzIHRvIGV2YWx1YXRlIGVhY2ggYm9hcmQgbWVt YmVyIG9uIHRoZWlyIGluZGl2aWR1YWwgbWVyaXQuIEJhc2VkIG9uIHRoZSBzdGF0ZSBvZiBhZmZh aXJzIGF0IEVBQSwgaXQgaXMgaGFyZCBmb3IgdXMgdG8gY29uZmlkZW50bHkgdm90ZSBmb3IgYW55 IG9mIHRoZXNlIGluZGl2aWR1YWxzLiBJ4oCZbSBzdXJlIHRoZXJlIGFyZSBhIGZldyByZXNwZWN0 YWJsZSBmb2xrcyBpbiBoZXJlLCBidXQgdGhhdCBjYW7igJl0IGJlIGRldGVybWluZWQgYmVjYXVz ZSBvZiB0aGUgbGFjayBvZiB0cmFuc3BhcmVuY3kuIFRoaXMgaXMgdGhlIHNhbWUgbGFjayBvZiB0 cmFuc3BhcmVuY3kgdGhleSBhcmUgcmVzcG9uc2libGUgZm9yIGNyZWF0aW5nL21haW50YWluaW5n Lg0KDQpBZnRlciBvdXIgZGlzY3Vzc2lvbiBhbmQgdGhlIHJldmVsYXRpb24gdGhhdCA1IG9mIHRo ZSA5IGNhbmRpZGF0ZXMgYXJlIHJ1bm5pbmcgZm9yIHJlLWVsZWN0aW9uIHdpdGhpbiBhbGwgNSBv cGVuIHNlYXRzLCBJIGhhdmUgZGVjaWRlZCB0byBhZGp1c3QgbXkgb3duIHJlY29tbWVuZGF0aW9u cyB0byB2b3RlIGZvciB0aGUgNCBjYW5kaWRhdGVzIHdobyBhcmUgbm90IG1lbWJlcnMgb2YgdGhl IGN1cnJlbnQgYm9hcmQgb2YgZGlyZWN0b3JzIGFuZCBsZWF2ZSBvdXIgNXRoIHZvdGUgdW5hc3Np Z25lZC4NCg0KVGhpcyBtZWFucyBvdXIgZml2ZSB2b3RlcyB3b3VsZCBiZSBmb3I6DQpEb3VnIENy dW1yaW5lDQpFdGhhbiBNYXJ0aW4NCkRhdmUgTW9yc3MNClN0ZXZlbiBPeG1hbg0KT3BlbjogTm8g Vm90ZSBQbGFjZWQNCldoaWxlIHNvbWUgd291bGQgYXJndWUgdGhpcyBpc27igJl0IGFuIG9wdGlt YWwgbGlzdCwgaXQgaXMgdGhlIG9ubHkgbGlzdCBvZiBjYW5kaWRhdGVzIHdlIGhhdmUgdG8gY2hv b3NlIGZyb20gYW5kIGl0IHN0aWxsIHByb3ZpZGVzIHNvbWUgYmFsYW5jZSBiZXR3ZWVuIEhvbWVi dWlsZGVycywgVmludGFnZSwgV2FyYmlyZHMsIGFuZCBDZXJ0aWZpZWQgR0EuIEJ1dCBtb3N0IGlt cG9ydGFudGx5IGEgdm90ZSBmb3IgdGhlc2UgbWVuIHJlcHJlc2VudHMgYSB2b3RlIGluIGZhdm9y IG9mIGZyZXNoIGlkZWFzIGFuZCBsZWFkZXJzaGlwIHdoZW4gY29tcGFyZWQgdG8gdGhlIGN1cnJl bnQgY29sbGVjdGlvbiBvZiBDbGFzcyBJIERpcmVjdG9ycy4NCg0KPT09PT09PT09PT09PT09DQpU aGFua3MsDQpQaGlsDQoNCg0KT24gU2F0LCBKdWwgMTQsIDIwMTIgYXQgNzo1MCBBTSwgSm9obiBD b3ggPHJ2MTBwcm9AZ21haWwuY29tPG1haWx0bzpydjEwcHJvQGdtYWlsLmNvbT4+IHdyb3RlOg0K DQpBcyBhIExpZmV0aW1lIG1lbWJlciB3aG8gam9pbmVkICJKdXN0IGJlZm9yZS4gVGhlIFJvdXN0 IG9mIDIwMDktMjAxMCIsIEkgc3RpbGwgYXdhaXQgd29yZCBvZiB0aG9zZSBjYW5kaWRhdGVzIHdl IGNhbiB2b3RlIGZvciByYXRoZXIgdGhhbiBwcm94eSB0aGUgY29udGludWVkICJBT1BBIGxpa2Ui IGRlY2xpbmUgYW5kIHVucmVzcG9uc2l2ZW5lc3Mgb2YgRUFBIHRvd2FyZHMgaXRzIGJ1aWxkZXJz LiAgQ2FuIHlvdSBhZHZpc2Ugd2hvbSB0byB2b3RlIGZvcj8NCg0KSm9obiBDb3gNCk9uIEp1bCAx MywgMjAxMiA5OjA1IEFNLCAiUGhpbGxpcCBQZXJyeSIgPHBoaWxwZXJyeTlAZ21haWwuY29tPG1h aWx0bzpwaGlscGVycnk5QGdtYWlsLmNvbT4+IHdyb3RlOg0KLS0+IFJWMTAtTGlzdCBtZXNzYWdl IHBvc3RlZCBieTogUGhpbGxpcCBQZXJyeSA8cGhpbHBlcnJ5OUBnbWFpbC5jb208bWFpbHRvOnBo aWxwZXJyeTlAZ21haWwuY29tPj4NCg0KDQpIaSBKYXNvbiwNCg0KVGhhbmsgeW91IGZvciB5b3Vy IHRpbWUgaW4gQWZnYW5pc3RhbiBhbmQgZm9yIHNhY3JpZmljaW5nIGEgZ29vZA0KcG9ydGlvbiBv ZiB5b3VyIGxpZmUgZm9yIHRob3NlIG9mIHVzIGhlcmUgdHlwaW5nIGUtbWFpbHMuDQoNClBhc2Nh bCBoaXQgYSBmZXcga2V5IGFyZWEsIGJ1dCB0aGVyZSBhcmUgYSBmZXcgbW9yZSB0aGF0IHNob3Vs ZCBiZQ0KYnJvdWdodCB1cCBhcyB3ZWxsLg0KDQpUaGUgRUFBIGRlYmF0ZSBoYXMgYmVlbiBhIGxv bmcgdGltZSBjb21pbmcuICBJdCBhY3R1YWxseSBnb2VzIGFsbCB0aGUNCndheSBiYWNrIHRvIFBh dWwgUG9iZXJlem55IHdoZW4gdGhlcmUgd2FzIGEgbW92ZW1lbnQgdG8gcmVtb3ZlIGhpbS4NCkJ1 dCBpbiB0aGUgcGFzdCAzLTQgeWVhcnMsIHRoZSBmcnVzdHJhdGlvbiB3aXRoIEVBQSBoYXMgcmVh Y2hlZCB0aGUNCmJvaWxpbmcgcG9pbnQgZm9yIG1hbnkgbWVtYmVycy4NCg0KTG9uZyBzdG9yeSBz aG9ydCwgc2luY2UgUm9kIEhpZ2h0b3dlciBoYXMgdGFrZW4gb3ZlciB0aGUgb3JnYW5pemF0aW9u DQp0aGUgY2hhcnRlciBhbmQgaW1hZ2Ugb2YgRUFBIGhhcyBtYWRlIGEgZHJhbWF0aWMgc2hpZnQg YXdheSBmcm9tIHRoZWlyDQpjb3JlIHZhbHVlcy4gIFRoZSBFQUEgaGFzIGJlY29tZSBmb2N1c2Vk IG9uIGJlaW5nIHRoZSBuZXh0IEFPUEENCnBvbGl0Y2FsbHkgYW5kIHRoZXkncmUgZm9jdXNlZCBv biB0aGUgbW9uZXkgdGhhdCBjYW4gYmUgbWFkZSB0aHJvdWdoDQpBaXJWZW50dXJlLiAgSSB0aGlu ayBpdCdzIGdyZWF0IHRoYXQgQWlyVmVudHVyZSByZXByZXNlbnRzIGEgc3Ryb25nDQpyZXZlbnVl IHN0cmVhbSBmb3IgdGhlIG9yZ2FuaXphdGlvbi4gIEJ1dCB0aGUgb3JnYW5pemF0aW9uIGhhcyBi ZWNvbWUNCmZvY3VzZWQgb24gbWlsa2luZyB0aGF0IHN0cmVhbSBhbmQgdGhlIG1lbWVyc2hpcCBj b21tdW5pdHkgaGFzIHBhaWQNCnRoZSBwcmljZS4gIElmIDEwMCUgb2YgdGhlIG1lbWJlcnMgZGlz YXBwZWFyZWQgdG9tb3Jyb3csIHRoZSBFQUEgd291bGQNCnN0aWxsIGV4aXN0IGJhc2VkIG9uIHRo ZSBhaXJzaG93LiAgU28gdGhlIG1lbWJlcnMgYXJlIG5vdyBzZWNvbmQgY2xhc3MNCmNpdGl6ZW5z IGluIHRoZSBvcmdhbml6YXRpb24uDQoNCk91ciBlZmZvcnRzIHRvIHBhcnRpY2lwYXRlIGluIHRo aXMgeWVhcnMgZWxlY3Rpb24gd2VyZSBibG9ja2VkIGJ5IEVBQQ0KYnkgYmVpbmcgdW5yZXNwb25z aXZlIGFuZCBpZ25vcmluZyBvdXIgcmVxdWVzdHMgZm9yIGEgc2ltcGxlIGJhbGxvdCB0bw0KcGFy dGljaXBhdGUuICBUaGlzIGlzIGEgcmlnaHQgdGhhdCBpcyBlbnRpdGxlZCB0byB0aGUgbWVtYmVy c2hpcA0KY29tbXVuaXR5IHdpdGhpbiB0aGUgYnlsYXdzLiAgQnV0IHRoaXMgcmlnaHQgaGFzIG5v dCBiZWVuIG1hZGUNCmF2YWlsYWJsZSB0byB0aGUgbWVtYmVyc2hpcC4gIEFzIGEgcmVzdWx0LCB0 aGUgRUFBIGhvbGRzIG5lYXJseSBhbGwgb2YNCnRoZSBtZW1iZXJzaGlwIHZvdGVzLiAgSXQncyBs aWtlIHRoZSBmb3ggaW4gdGhlIGhlbiBob3VzZSBpbiBzb21lDQpyZWdhcmRzLg0KDQpJIGxvdmUg dGhlIEVBQS4gIEkgYW0gcGFzc2lvbmF0ZSBhYm91dCBpdC4gIEkgYW0gYSBsaWZldGltZSBtZW1i ZXIuICBJDQpoYXZlIHNlcnZlZCBhcyBhIGNoYXB0ZXIgVlAgYW5kIFByZXNpZGVudC4gIEFzIEkg c2l0IGhlcmUgcmlnaHQgbm93LA0KSSdtIHdlYXJpbmcgYSByZWQgQWlyVmVudHVyZSAyMDA5IHBv bG8uICBJIGxvdmUgdGhlIGxlZ2FjeSBFQUENCmN1bHR1cmUsIEkgbG92ZSB0aGUgRUFBIGJyYW5k LiAgSSByZWFsbHkgZG8gY2FyZSBhIGxvdCBhYm91dCBFQUEuDQoNClNpbmNlIFJvZCBIaWdodG93 ZXIgaGFzIHRha2VuIG92ZXIgdGhlIG9yZ2FuaXphdGlvbiwgdGhlIEVBQSBoYXMgc2Vlbg0KbmVh cmx5IDUwIGVtcGxveWVlcyB3YWxrIG91dCB0aGUgZG9vciBmcm9tIHRoZSB0b3hpYyBlbnZpcm9u bWVudCB0aGF0DQpSb2QgaGFzIGNyZWF0ZWQuICBUaGVzZSBhcmUgaW1wb3J0YW50IHBlb3BsZSBs aWtlIENoYXJsaWUgQmVja2VyLCBBZGFtDQpTbWl0aCwgQmFycnkgRWxrLCBldGMuIEp1c3QgeWVz dGVyZGF5LCB0aGV5IGxvc3QgSEcgRnJhdXRzY2h5IHdobyBpcw0KYW4gRXhlY3V0aXZlIERpcmVj dG9yIHdobyBoYXMgc3BlbnQgMjIgeWVhcnMgYXMgYW4gZW1wbG95ZWUgb2YgdGhlDQpvcmdhbml6 YXRpb24uICBUaGUgRUFBIGN1bHR1cmUgYXMgd2Uga25vdyBpdCBpcyB1bmRlciBhdHRhY2sgZnJv bQ0Kd2l0aGluLg0KDQpZb3UgbWlnaHQga25vdyBEaWNrIEtvaGxlciwgaGUgaGFzIHRhdWdodCBh IG51bWJlciBvZiBFQUEgU3BvcnRBaXINCndvcmtzaG9wcyBhbmQgaGUgaXMgcGFzc2lvbmF0ZSBh Ym91dCBFQUEuICBZb3Ugc2hvdWxkIHJlYWQgaGlzDQpjb21tZW50cyBhdCB0aGlzIGxpbmsgYmVj YXVzZSBoZSBwcmV0dHkgbXVjaCBjYXB0dXJlcyB0aGUgZW52aXJvbm1lbnQNCnRoYXQgUm9kIGhh cyBjcmVhdGVkLg0KDQpodHRwOi8vd3d3LnZhbnNhaXJmb3JjZS5jb20vY29tbXVuaXR5L3Nob3dw b3N0LnBocD9wPTY3NTEwMSZwb3N0Y291bnQ9MTIyDQoNCkFkZGl0aW9uYWwgaW5mb3JtYXRpb24g Y2FuIGJlIGZvdW5kIGF0IHRoaXMgbGluayBjb250YWluaW5nIGNvbW1lbnRzDQpmcm9tIEVBQSAg Qm9hcmQgTWVtYmVycyB3aG8gaGF2ZSByZXNpZ25lZC4gIEhlcmUgaXMgYSBrZXkgY29tbWVudCBp Zg0KeW91IGRvbid0IGdvIHJlYWQgdGhlIGVudGlyZSBsaW5rLg0KDQo9PT09PT09PT09PT09DQpB cyBNaWtlIERhbGUgcHV0IGl0IHdhcyB0aW1lIGZvciB0aGUgQm9hcmQgdG8gImdyb3cgdXAgYW5k IHN0YXJ0DQpoYXZpbmcgdGhlIENFTyB3b3JrIGZvciB0aGUgQm9hcmQiLiBJIGNhbm5vdCBiZSBw YXJ0IG9mIGEgcnViYmVyIHN0YW1wDQpCb2FyZCB3aG9zZSBwcmltZSBsb3lhbHR5IGlzIHRvIHRo ZSBGb3VuZGVyIGFuZCBQcmVzaWRlbnQgcmF0aGVyIHRoYW4NCkVBQSBtZW1iZXJzLg0KPT09PT09 PT09PT09PQ0KaHR0cDovL3d3dy5hZXJvLW5ld3MubmV0L2luZGV4LmNmbT9kbz1tYWluLnRleHRw b3N0JmlkPTdkNjEzOTkxLWFkY2ItNDI2YS1hMjEwLTViN2VlNDExMjA0OQ0KDQoNCkkgaG9wZSB5 b3Ugd2lsbCBjb25zaWRlciBzdXBwb3J0aW5nIG91ciBlZmZvcnQuICBXZSB3b24ndCBoYXZlIGVu b3VnaA0Kdm90ZXMgdG8gY2hhbmdlIHRoaXMgZWxlY3Rpb24sIGJ1dCB3ZSB3aWxsIGhhdmUgZW5v dWdoIHRvIHB1dCBhIHNob3QNCmFjcm9zcyB0aGUgYm93IG9mIEVBQSdzIGxlYWRlcnNoaXAuDQoN ClRoYW5rcywNClBoaWwNCg0KDQoNCg0KT24gNy8xMy8xMiwgUGFzY2FsIDxydjEwZmx5ZXJAdmVy aXpvbi5uZXQ8bWFpbHRvOnJ2MTBmbHllckB2ZXJpem9uLm5ldD4+IHdyb3RlOg0KPiBKYXNvbjsN Cj4gRmlyc3Qgb2ZmLCB0aGF0IHlvdSBmb3IgdGhlIHNhY3JpZmljZSB0byBsZWF2ZSB0aGUgY29t Zm9ydHMgYW5kIHNhZmV0eSBvZg0KPiB0aGUgVVMgZm9yIG91ciBiYXR0bGUgaW4gQWZnaGFuaXN0 YW4uIEl04oCZcyBoYXJkLCBiZWVuIHRoZXJlLCBub3QgQWZnaGluc3Rhbg0KPiBidXQgYW5vdGhl ciDigJxvcGVyYXRpb24gaW4gMTk5MC0xOTkxLiBUaGFuayB5b3UgZm9yIHlvdXIgc2VydmljZSEN Cj4gSSB0aGluayB5b3UgYXNrIGEgdmVyeSBnb29kIHF1ZXN0aW9uLiBQaGlsIG1heSBub3QgYmUg YWJsZSB0byBhbnN3ZXIgaXQNCj4gY29tcGxldGVseSBidXQgbXkgaW5pdGlhbCB0aG91Z2h0IGlz IHRoZSBmb2xrcyB3cml0aW5nIGFydGljbGVzIGZvciBTcG9ydA0KPiBhdmlhdGlvbiBhcmUgZXgg Zmx5aW5nIG1hZ2F6aW5lIHdyaXRlcnMgd2hvIGhhdmUgbm8gaWRlYSBvZiB3aGF0IGJ1aWxkaW5n IGENCj4gcGxhbmUgaXMgYWJvdXQsIHRoZXJlIHdhcyBhIG1lZXRpbmcgYW5kIHRoZWlyIGhhcyBi ZWVuIHRoYXQg4oCcY29tYmluZWTigJ0NCj4gZWZmb3J0IG9mIEFPUEEgYW5kIEVBQSB0byByZXBy ZXNlbnQgdXMgd2l0aCBMc2EgYW5kIG90aGVyIGdlbmVyYWwgZmx5aW5nDQo+IGlzc3VlcywgZ29v ZCBpZGVhLCBzdXJlISBJIHdvdWxkIGxpa2UgdG8gc2VlIHRoZSBFQUEgZmlnaHQgZm9yIGhvbWVi dWlsZGVycw0KPiBhbmQgbm90IGdlbmVyYWwgYXZpYXRpb24gaG93ZXZlci4NCj4gTXkgY29ycG9y YXRpb24gZG9lcyB0aGUgc2FtZSB0aGluZyBFQUEgZG9lcy4gUGhpbCBqdXN0IHdhbnRzIG1lbWJl cnMgdG8gaGF2ZQ0KPiBtb3JlIHNheSBvbiB3aG8gaXMgdm90ZWQgaW4gdmVyc3VzIHRoZSBiaWcg a2FodW5hIGF0IEVBQSBoaW1zZWxmLg0KPg0KPiBGcm9tOiBKYXNvbiBXb2RhY2sNCj4gU2VudDog RnJpZGF5LCBKdWx5IDEzLCAyMDEyIDE6MTEgQU0NCj4gVG86IHJ2MTAtbGlzdEBtYXRyb25pY3Mu Y29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NCj4gU3ViamVjdDogUmU6IFJWMTAt TGlzdDogVXJnZW50OiBFQUEgTWVtYmVycyAtIEFjdGlvbiENCj4NCj4gUGhpbCwNCj4gSSd2ZSBi ZWVuIGluIEFmZ2hhbmlzdGFuIGZvciB0aGUgbGFzdCB5ZWFyLCBhbmQgdGhlcmVmb3JlIG91dCBv ZiB0aGUgbG9vcA0KPiBmb3IgYSB3aGlsZS4gIEkgd2FzIGp1c3QgY3VyaW91cyBhYm91dCB3aGF0 IEkgd2FzIG1pc3NpbmcgdGhhdCBoYXMgY2F1c2VkDQo+IHN1Y2ggYSByZWFjdGlvbi4NCj4NCj4g SSd2ZSBzZWVuIGNsYWltcyBvZiBFQUEgbm90IHN1cHBvcnRpbmcgaG9tZSBidWlsZGVycywgYW5k IHNpbmNlIEknbSBhYm91dCB0bw0KPiBzdGFydCBvbiBhbiBSVi0xMCBhdCB0aGUgZW5kIG9mIHRo aXMgZGVwbG95bWVudCwgdGhhdCBjb25jZXJucyBtZS4gIEkgd2FzDQo+IGhvcGluZyB5b3Uob3Ig c29tZW9uZSkgY291bGQgYnJpbmcgbWUgdXAgdG8gc3BlZWQgb24gd2hhdCBJIGhhdmUgbWlzc2Vk LCBhbmQNCj4gd2hhdCB0aGUgaXNzdWVzIGFyZSB0aGF0IHdlIGFyZSBoYXZpbmcuDQo+DQo+IEkg YWRtaXJlIHlvdXIgY29udml0aW9uLCBhbmQgeW91ciB3aWxsaW5nbmVzcyB0byB0YWtlIGFjdGlv bi4gIEkgZG8gbid0IHdhbnQNCj4gdG8gc2VlbSBsaWtlIEknbSBjaGFsbGVuZ2luZyB5b3UsIGJ1 dCBJIGRvIHdhbnQgdG8gYmUgd2VsbCBpbmZvcm1lZCBiZWZvcmUgSQ0KPiBtYWtlIGEgZGVjaXNp b24sDQo+DQo+IFRoYW5rcw0KPiBKYXNvbg0KPg0KPg0KPiBPbiBGcmksIEp1bCAxMywgMjAxMiBh dCAyOjQ0IEFNLCBQaGlsbGlwIFBlcnJ5IDxwaGlscGVycnk5QGdtYWlsLmNvbTxtYWlsdG86cGhp bHBlcnJ5OUBnbWFpbC5jb20+Pg0KPiB3cm90ZToNCj4NCj4gICBIaSBFdmVyeW9uZSwNCj4NCj4g ICBJZiBtYW55IG9mIHlvdSBmb2xsb3cgPVZBRj0sIHlvdSdyZSBwcm9iYWJseSBhd2FyZSB0aGF0 IHRoZXJlIGlzIGENCj4gY2FtcGFpZ24gd2l0aGluIHRoZSBFQUEgTWVtYmVyc2hpcCBjb21tdW5p dHkgdG8gcGFydGljaXBhdGUgaW4gdGhlIHVwY29taW5nDQo+IGVsZWN0aW9uIG9mIHRoZSBFQUEg Qm9hcmQgb2YgRGlyZWN0b3JzLiAgV2UgZmlndXJlZCB0aGF0IGluc3RlYWQgb2YganVzdA0KPiBj b21wbGFpbmluZywgd2Ugc2hvdWxkIGFjdHVhbGx5IHBhcnRpY2lwYXRlIGluIHRoZSBkZW1vY3Jh dGljIGVsZWN0aW9ucy4NCj4NCj4gICBUaGlzIHNpbXBseSBpZGVhIGxlZCB0byBtb3JlIHRoYW4g MSBtb250aCBvZiBzdG9uZSB3YWxsaW5nIGZyb20gdGhlIEVBQS4NCj4gU3RpbGwgdG8gdGhpcyBk YXksIHRoZXkgaGF2ZSBub3QgcHJvdmlkZWQgYSBzaW1wbGUgZG9jdW1lbnQgdGhhdCBhbGxvd3MN Cj4gdGhlaXIgbWVtYmVycyB0byBwYXJ0aWNpcGF0ZSBpbiB0aGUgZWxlY3Rpb24uICBTbyB3ZSBj b3BpZWQgdGhlaXIgbGFuZ3VhZ2UNCj4gdGhhdCBhc3NpZ25zIHRoZSBwcm94eSByaWdodHMgdG8g Um9kIEhpZ2h0b3dlciBhbmQgY2hhbmdlZCB0aGUgbmFtZSBvbiBpdCB0bw0KPiByZWZsZWN0IG1l LiAgVGhlIEVBQSBoYXMgYWRtaXR0ZWQgdGhhdCB0aGlzIGlzIGEgZG9jdW1lbnQgdGhhdCB0aGV5 IGNhbid0DQo+IHR1cm4gZG93biBhdCB0aGUgZWxlY3Rpb25zIGluIGEgZmV3IHdlZWtzLg0KPg0K PiAgIEluIHRoZSBwYXN0IHRoZXJlIHdlcmUgMyBjaG9pY2VzIGZvciBFQUEgbWVtYmVycyB0byBw YXJ0aWNpcGF0ZSBpbiB0aGUNCj4gZWxlY3Rpb246DQo+DQo+ICAgMSkgVGhleSBjb3VsZCBjaG9v c2Ugbm90IHRvIHBhcnRpY2lwYXRlLg0KPiAgIDIpIFRoZXkgY291bGQgc2hvdyB1cCBpbiBwZXJz b24gdG8gY2FzdCB0aGVpciB2b3RlIGF0IHRoZSBhbm51YWwgYnVzaW5lc3MNCj4gbWVldGluZy4N Cj4gICAzKSBUaGV5IGNvdWxkIGFzc2lnbiB0aGVpciB2b3RlIHRvIFJvZCBIaWdodG93ZXIuICAo VGhpcyBpcyBhIGNoZWNrIGJveCBvbg0KPiB5b3VyIGFubnVhbCByZW5ld2FsKQ0KPg0KPg0KPiAg IExvbmcgc3Rvcnkgc2hvcnQsIHRoZSBlbGVjdGlvbnMgd291bGQgbG9vayBsaWtlIDEzIHZvdGVz IGZvciBzb21lIG1lbWJlcnMNCj4gYW5kIDE2LDAwMCB2b3RlcyBmb3IgdGhvc2UgdGhhdCBIaWdo dG93ZXIgd2FudGVkLiAgU28gdGhleSBlbmRlZCB1cCBiZWluZw0KPiBhcHBvaW50bWVudHMgYW5k IG5vdCBlbGVjdGlvbnMgYnkgdGhlIG1lbWJlcnMuDQo+DQo+ICAgSSBhbSByZWNlaXZpbmcgcHJv eHkgZm9ybXMgZnJvbSBhbGwgb3ZlciB0aGUgZ2xvYmUgYW5kIGlmIHlvdSBhcmUNCj4gZnJ1c3Ry YXRlZCB3aXRoIHRoZSBFQUEsIEkgd291bGQgYXBwcmVjaWF0ZSBpdCBpZiB5b3Ugd291bGQgZG8g dGhhdCBzYW1lDQo+IHRoaW5nLiAgVGhlIGZvcm0gY2FuIGJlIGZvdW5kIGF0IHRoaXMgbGluay4N Cj4NCj4NCj4gICBodHRwOi8vZGwuZHJvcGJveC5jb20vdS8yNjM0MzkzNS9FQUElMjBNZW1iZXIl MjBQcm94eSUyMFN0YXRlbWVudC5wZGYNCj4NCj4NCj4gICBZb3UgY2FuIHNlbmQgbWUgYSBzY2Fu bmVkIGNvcHkgb3IgdGhlIG9yaWdpbmFsIHRvOg0KPg0KPiAgIFBoaWxsaXAgVy4gUGVycnkNCj4g ICBDL08gRGF2aWQgQ2Fycg0KPiAgIDExMDAgVyBNb25yb2UgU3QNCj4gICBBdXN0aW4sIFRYIDc4 NzA0DQo+DQo+DQo+ICAgSGVyZSBhcmUgdGhlIHZvdGVzIHdlIHdpbGwgYmUgcGxhY2luZyBhbmQg dGhlIGp1c3RpZmljYXRpb24gZm9yIHNlbGVjdGluZw0KPiB0aGVtOg0KPg0KPiAgIGh0dHA6Ly93 d3cudmFuc2FpcmZvcmNlLmNvbS9jb21tdW5pdHkvc2hvd3Bvc3QucGhwP3A9Njc4NTQ5JnBvc3Rj b3VudD02OA0KPg0KPg0KPiAgIFRvZGF5IHRoZSBFQUEgcmV0YWxpYXRlZCBhZ2FpbnN0IHRoZWly IG1lbWJlcnMgYW5kIHNlbnQgb3V0IGEgbGluayBhc2tpbmcNCj4gdGhlbSB0byBhc3NpZ24gcHJv eHkgdm90ZXMgdG8gUm9kIEhpZ2h0b3dlci4gIFBsZWFzZSBkb24ndCBnaXZlIHRvdGFsDQo+IGNv bnRyb2wgb2YgRUFBIHRvIHRoZSBjdXJyZW50IG1lbWJlcnNoaXAgYW5kIGNob29zZSB0byBwdXQg Y29udHJvbCBvZiB0aGUNCj4gRUFBIGJhY2sgaW4gdGhlIGhhbmRzIG9mIHRoZSBtZW1iZXJzaGlw LiAgSGVyZSdzIHNvbWUgZGV0YWlscyBvbiB0aGF0DQo+IG1lc3NhZ2U6DQo+DQo+ICAgaHR0cDov L3d3dy52YW5zYWlyZm9yY2UuY29tL2NvbW11bml0eS9zaG93dGhyZWFkLnBocD9wPTY3OTI4NQ0K Pg0KPg0KPiAgIFBsZWFzZSBkb24ndCBhc3NpZ24geW91ciBwcm94eSB0byB0aGUgRUFBIExlYWRl cnNoaXAsIGFuZCBpZiB5b3UgZmVlbA0KPiBjb21wZWxsZWQgSSB3b3VsZCBiZSBob25vcmVkIHRv IGNhcnJ5IHlvdXIgcHJveHkgdm90ZSBmb3J3YXJkIGF0IHRoZQ0KPiBidXNpbmVzcyBtZWV0aW5n IGF0IEFpclZlbnR1cmUuICBUaGlzIGlzIHRoZSBmaXJzdCB0aW1lICh0aGF0IEknbSBhd2FyZSBv ZikNCj4gaW4gdGhlIGhpc3Rvcnkgb2YgRUFBIHRoYXQgdGhlIG1lbWJlcnMgaGF2ZSBmb3VuZCBh IHdheSB0byBsZWdpdGltYXRlbHkNCj4gcGFydGljaXBhdGUuDQo+DQo+ICAgV2UgbmVlZCB0byBn ZXQgdGhpcyB3b3JkIG91dCB0byBldmVyeW9uZSB3aG8gc3VwcG9ydHMgdGhlIGVmZm9ydCBBU0FQ LiAgU28NCj4gaWYgeW91IGFncmVlLCBwbGVhc2UgaGlnaGxpZ2h0IHRoaXMgcHJveHkgZWZmb3J0 IGFuZCBzaGFyZSB0aGUgbWVzc2FnZSBvbg0KPiBldmVyeSBtZXNzYWdlIGJvYXJkIHlvdSBjYW4g YmVmb3JlIHNvbWUgdW5rbm93aW5nIHNvdWwgZ2l2ZXMgaGlzIHZvdGUgdG8gUm9kDQo+IEhpZ2h0 b3dlciBhbmQgaGlzIGJ1ZGRpZXMuDQo+DQo+ICAgV2UgYXJlIGdvaW5nIHRvIGJlIGNvbnRpbnVp bmcgdGhpcyBlZmZvcnQgZ29pbmcgaW50byAyMDEzIHRvbyBhbmQgY2FuIHVzZQ0KPiB5b3VyIHN1 cHBvcnQgYW5kIGV2ZW4geW91IGFjdGl2ZSBwYXJ0aWNpcGF0aW9uLg0KPg0KPiAgIFRoYW5rcywN Cj4gICBQaGlsIFBlcnJ5DQo+DQo+ICAgUlYtMTAgIzQwNzUwDQo+ICAgRUFBIExpZmV0aW1lIE1l bWJlcg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPg0KPiBnZXQ9Il9i bGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj4gdHA6 Ly9mb3J1bXMubWF0cm9uaWNzLmNvbTxodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20+DQo+IF9i bGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPg0KPg0KPg0KPg0K Pg0KPg0KPg0KDQo9PT09PT09PT09PQ0KYXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj09PT09PT09PT09DQpodHRwOi8vZm9ydW1zLm1h dHJvbmljcy5jb20NCj09PT09PT09PT09DQpsZSwgTGlzdCBBZG1pbi4NCj0iX2JsYW5rIj5odHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo9PT09PT09PT09PQ0KDQoNCg0KDQoN Cg0KDQpnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEw LUxpc3QNCg0KdHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbTxodHRwOi8vZm9ydW1zLm1hdHJvbmlj cy5jb20+DQoNCl9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0K DQoNCg0KDQoNCg0KDQoNCmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP1JWMTAtTGlzdA0KDQp0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCl9ibGFuayI+ aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0KDQoNCg0KDQpnZXQ9 Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0K dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9jb250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAgIC0g VGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0 IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0KXy09IFBob3Rvc2hhcmUsIGFu ZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAg ICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQg YWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0NCg0KXy09ICAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAg ICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Date: Jul 16, 2012
In my short visit a couple years ago, it seemed that the EAA members at Bountiful Airport truly were a family, especially the RV-10 builders. When you look at what Mike contributed with his web site, Rick in helping Mike finish and fly, what Sean and Scott managed to do with the supplemental door latch and other mods, it is quite a contribution to the RV-10 community. Thanks to all. Kelly On 7/16/2012 9:42 AM, Scott Schmidt wrote: > Mike will be missed at the airport. He was the guy who was willing to > do anything to help you with a project or anything else. I will miss > him stopping by to say hi. > Rick, I am sure glad you helped Mike finish the RV-10. It is great he > was able to fly it and enjoy it before passing. > Scott Schmidt > scottmschmidt(at)yahoo.com > > ------------------------------------------------------------------------ > *From:* Richard Barnes > *To:* rv10-list(at)matronics.com > *Sent:* Monday, July 16, 2012 8:52 AM > *Subject:* RV10-List: Death in the Family > > Just a note to let you know that my dear friend and RV10 builder > Mike Howe passed away last week. For many of you, his web site > was of great value. He took several hundred photos of each step in > the build process. His passion was flying and to be able to build > the RV10 brought him great joy. We used your help on the forum > to keep us out of too much trouble. For those of you who may not > have seen his web site: http://www.etigerrr.com/Default.htm His > obituary is below. > http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=michael-dewitt-howe&pid=158527721 > I know he appreciated all of your comments, especially the primer > wars. > > * > > > * > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 16, 2012
This is very sad news. I never tired of watching Mike's progress, and whenever the head scratching commenced, his was one of the sites I'd invariably search, and just as invariably find the answer. Then the site seemed to go quiet (as did mine, of course), which made me feel somehow left without a mentor. I never met him, but am certainly going to miss his presence. RIP Mike. John J From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Barnes Sent: Monday, July 16, 2012 7:53 AM Subject: RV10-List: Death in the Family Just a note to let you know that my dear friend and RV10 builder Mike Howe passed away last week. For many of you, his web site was of great value. He took several hundred photos of each step in the build process. His passion was flying and to be able to build the RV10 brought him great joy. We used your help on the forum to keep us out of too much trouble. For those of you who may not have seen his web site: http://www.etigerrr.com/Default.htm His obituary is below. http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=micha el-dewitt-howe <http://www.legacy.com/obituaries/saltlaketribune/obituary-print.aspx?n=mich ael-dewitt-howe&pid=158527721> &pid=158527721 I know he appreciated all of your comments, especially the "primer wars". ________________________________________________________________________________
From: Roxanne and Mike Lefever <roxianmike(at)msn.com>
Subject: new site? why different?
Date: Jul 16, 2012
I really don't get all this consternation over the VAF site..............no secret what the rules are/were. Seems like many posters here want to run DR out of business. If you don't want to pay him don't but I don't get the begrudging.............and it seems odd to me that so many begrudge his de sire to have a donation (which apparently you would never do) but you have so much "knowledge" about what is on the site........so apparently you spen d some time there. Maybe its time to get some more fiber in your diet and/ or start another kit to burn off some energy. :) From: rv10flyer(at)verizon.net Subject: RV10-List: new site? why different? Date: Mon=2C 16 Jul 2012 17:54:22 -0700 Why? looks like the same thing to me? Maybe on what is different? looks like a whole lot of the same advertisers already? I=92m already a member and I believe this is a good thing Glenn is doing. I am all for running a business=2C but I am also all for the builders=2C whic h is what makes this (Matronics) forum what it is=2C no one doing anything other than giving opinions and focused on our planes. I bet Doug started with a good intentio n than moved on to leave his job to run the site full time- tells me he is lo oking to provide a service and make money on it. So he=92s making lot off of it =2C good for him for being successful! The problem=2C from what I am hearing=2C is w e end up paying for the advertisers fees if we buy one of their products=2C so if rvairspace.com is proving a link for advertisers at a lesser rate or as a service to the end users it would do 1 of two things- the advertisers will make more money for their products than VAF (since they are not paying upwards o f 10K
June 26, 2012 - July 16, 2012
RV10-Archive.digest.vol-iv
