RV10-Archive.digest.vol-iy
September 07, 2012 - October 02, 2012
Jason,
I purchased those rings as my triple fall back option. I grabbed them because they
looked like a solution but not a convenient one considering all that would
be entailed with the conversion on an already flying -10. As far as pressure
readings we performed ~30 flights during and just after Phase 1 measuring different
DP's to get the plane reasonably flyable. That was nearly 3 years ago and
I am long past being interested in more R&D. To answer your question there will
be no Before & After as I plan on switching cowls vs. modifying the same cowl
so it will be an Apples & Oranges situation which at best would provide minimal
actionable information. I wish you the best in developing a solution for
this issue but the answer is already out there. It's called the stock Vans cowl
& baffle system. I would (and probably should go that route for my replacement
cowl but because of my Barrett FFCI / FM300 I have decided to try an impressive
new cowl that was specifically developed with that combination of hardware.
This is still a leap of faith but there is actually a flying version vs. just
going to market with something that "should work." Additionally I will be
replacing my Plenum with standard baffles and I hope to never own a plenum again.
Best of luck with your development. I will follow your thread on VAF and the RV
List.
Robin
-----Original Message-----
From: | owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler |
Sent: Friday, September 07, 2012 5:19 AM
Subject: | Re: Inlet Ring Size |
Robin - thanks for posting. Those things look giant! I would think your entering
the zone of external pressure recovery. I know you are absolutely sick of
this whole cooling thing and just want to move on and get it solved. Before
you do that is there any chance we could get you to take some before and after
pressure measurements in your cowl? I know I am asking a lot of a guy who is
as frustrated as you are.
By the way, as Ben said the interior shape of the inlet is really critical on internal
pressure recovery type systems (small inlets) like the James Cowl & Plenum.
I am of the unverified opinion right now that the interior shape of the
James cowl inlet is the problem. Putting together the test plan and data right
now to verify that.
Check out: http://www.vansairforce.com/community/showthread.php?t=12633
Thanks - Jason
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617
http://forums.matronics.com/viewtopic.php?p=382580#382580
From: | "Geoff Combs" <g.combs(at)aerosportmodeling.com> |
Subject: | Button For Exterior Door Handle C-1007 |
Here is what I did. Made a little aluminum cap that pressed into the rod.
Looks good and
Is easy on the thumb
Geoff
Geoff Combs
Aerosport Modeling and Design
8090 howe industrial pkwy
canal winchester, ohio 43110
614.834.5227p
614.834.5230f
www.aerosportmodeling.com
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens
Sent: Friday, September 07, 2012 12:47 PM
Subject: RV10-List: Button For Exterior Door Handle C-1007
Anyone fab a button, cover, whatever that fits over the C-1007 that is
depressed to rotate the exterior door handle? Seems odd that there's
nothing that covers the hole and it may be uncomfortable to press it.
-Sean #40303 (finishing cabin top interior)
Subject: | Re: Button For Exterior Door Handle C-1007 |
I used a nylon button from HD, held in place with some RTV.
Jim Berry
N15JB
http://forums.matronics.com/viewtopic.php?p=382618#382618
I used a plastic cover from HD as well. Sorry can not locate the part number
nor which section I got it from.
Sent: Friday, September 07, 2012 10:25 AM
Subject: RV10-List: Re: Button For Exterior Door Handle C-1007
Jim Berry
N15JB
Jason
They are considerably larger @ 6.25 ID for about an additional 4.5 sq-in
over the originals.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From: | Scott Schmidt <scottmschmidt(at)yahoo.com> |
I typically fly between 100 - 200 hours per year and put new pads on every
annual.- My first two years I flew 250 hours and I replaced them at 230 h
ours. =0A=0Ahttp://www.vansairforce.com/community/showthread.php?p=149271
#post149271=0A=0AIt is a pretty cheap item compared to the problems it may
cause when your on a trip away from your tools.- If you replaced them at
200 hours you would probably be safe and could start to extend the time dep
ending on your flying and braking.- =0A=0A-=0AScott Schmidt=0Ascottmsch
midt(at)yahoo.com=0A=0A=0A=0A>________________________________=0A> From: Pasca
l =0A>To: rv10-list(at)matronics.com =0A>Sent: Tuesday,
September 4, 2012 9:58 AM=0A>Subject: Re: RV10-List: Re: Brake Pads?=0A>
=0A>My contact is out this week but I'll follow-up next week and see if I c
an get a status on the pads. I thought he told me he was getting a new supp
ly after OSH, maybe he sold off that stock already, which is surprising con
sidering how many he was getting. Supposedly the "old" stock was far more d
urable than the new ones Rapco is working on getting certified or something
. A few months back Rapco mentioned that the new ones would be out by SnF,
than it was OSH.=0A>Hopefully I'll be able to get a more official response
on options by next week.=0A>=0A>=0A>-----Original Message----- From: rv10fl
yer=0A>Sent: Monday, September 03, 2012 6:16 PM=0A>To: rv10-list@matronics.
com=0A>Subject: RV10-List: Re: Brake Pads?=0A>=0A>--> RV10-List message pos
ted by: "rv10flyer" =0A>=0A>When someone hears t
hey are available again, please post.=0A>=0A>I am only at 76.9 hrs, but I l
ike keeping spares on hand of oil filter/oil/tires/tubes/pads/start & maste
r contactors/fuel selector valve/prop oring/caliper oring. I have all but p
ads and caliper oring in case someone gets in a bind and is near S. Ohio.
=0A>=0A>--------=0A>Wayne Gillispie=0A>=0A>=0A>=0A>=0A>Read this topic onli
ne here:=0A>=0A>http://forums.matronics.com/viewtopic.php?p=382350#382350
=- - - - - - - - - - - - - - - -Matt Dralle
===========0A>=0A>=0A>=0A>=0A>=0A>
I could have sworn the kit came with a little plastic cap that I pressed
into the button hole - don't recall having to source from HD or anywhere.
Only thing I don't like now is that the shaft has a little corrosion ring
around it.
-Chris
N919AR
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, September 07, 2012 1:41 PM
Subject: Re: RV10-List: Re: Button For Exterior Door Handle C-1007
Jim Berry
N15JB
I am one who believes in that hypothesis. Caressing rather than torturing
for the desired result.
On Sep 7, 2012 5:22 AM, "jkreidler" wrote:
> jason.kreidler(at)regalbeloit.com>
> entering the zone of external pressure recovery. I know you are absolutely
> sick of this whole cooling thing and just want to move on and get it
> solved. Before you do that is there any chance we could get you to take
> some before and after pressure measurements in your cowl? I know I am
> asking a lot of a guy who is as frustrated as you are.
> on internal pressure recovery type systems (small inlets) like the James
> Cowl & Plenum. I am of the unverified opinion right now that the interior
> shape of the James cowl inlet is the problem. Putting together the test
> plan and data right now to verify that.
> Thanks - Jason
> Jason Kreidler
From: | Michael Kraus <n223rv(at)wolflakeairport.net> |
Mine also have this nylon button. Came with my kit....
-Mike Kraus
RV-10 Flying
> around it.
> -Chris
> N919AR
> From: owner-rv10-list-server(at)matronics.com
er
> From: Jim Berry
> Jim Berry
> N15JB
