RV10-Archive.digest.vol-jg
February 20, 2013 - March 18, 2013
      RV-4 sold :-(
      RV-10 flying :-)
      KitFox SS7 Radial building :-)
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Subject: Re: SkyView Autopilot Settings
Date: Feb 20, 2013
Mike, I have never changed the SkyView default setting. It has worked perfectly for me. Any chance something else is going on? Carl On Feb 20, 2013, at 1:03 PM, Michael Kraus wrote: > > Does anyone have a flying -10 with a Dynon Skyview with good autopilot settings then can share? Mine works great in calm air, but chases altitude and sometimes course in turbulence more than I expect. I'm pretty site it's just settings. > > Thanks > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > ________________________________________________________________________________
Date: Feb 20, 2013
I would like them too. I haven't even messed with settings at all yet. It does pretty good, but wanders a little. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Feb 20, 2013, at 1:03 PM, Michael Kraus wrote: > > Does anyone have a flying -10 with a Dynon Skyview with good autopilot settings then can share? Mine works great in calm air, but chases altitude and sometimes course in turbulence more than I expect. I'm pretty site it's just settings. > > Thanks > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > ________________________________________________________________________________
Subject: Re: Cabin Top Grab Handle
Date: Feb 20, 2013
No handle, but I do have a plastic two step stepstool. The top step goes over the aircraft step. It give passengers two steps, much wider steps, and a little closer to the wing so the step onto the wing is easier. My short legged passengers find it helps. Folds to fit thru the baggage door. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394701#394701 ________________________________________________________________________________
From: "Carroll L. Verhage" <cv93436(at)windstream.net>
Subject: Grab handles
Date: Feb 20, 2013
Patrick: Grab handles are nice and work well. They are easy to install. I have seen all sizes of grab handles but ones that look nice and are just the right size are Lowes' stainless 128mm BP27021-G drawer pull. I mounted them just above the rear windows 12 inches aft of the door opening. Their additional aeronautical drag is negligable. Make a template of the mounting holes on the handle. Drill a #8 screw size pilot hole through each layer of the Lexan into the cabin. Make sure these holes match the handle. Reem a little if necessary. Then drill the outer layer of the Lexan the OD of an aluminum spacer with an ID about the size of the #8 screw (I think it was 3/16 OD and 1/8 ID). Cut the spacer the length of the thickness of the Lexan so it stops against the inner layer of the Lexan and is flush with the outside Lexan surface. Mix about a tablespoon of epoxy with fiberglass filler for each handle the consistancy of peanut butter. Put 1/2 the epoxy in each mounting hole. Put a spacer in each hole so it has some fiberglass around the spacer filling up the cavity between the two layers of Lexan. Align the spacers by putting the handles back on. Let the fiberglass harden. Permanently mount the handles using a stainless steel fender washer inside the cabin. If the spacer is a little long, you can file it down flush with the outside. The spacer has to be long enough to press against the inner layer. With the spacers surrounded by fiberglass, it will stay in place when the handle is removed and also assure you don't collapse the shell when the handle is tightened down. You can add handles after you have your 10 built and flying and the cabin upholstery installed. Carroll ________________________________________________________________________________
Subject: Ground Power Attach
Date: Feb 20, 2013
Realizing it would be very inconvenient to remove the back cabin bulkhead to jump the battery, we installed a Piper-type power plug just aft of the baggage door across from the battery. We used a reinforcing plate, cut shim gaskets out of aluminum and gasket material so it lies smoothly on the outside. We sealed it with silicone. It works well and has saved several quite frustrating efforts to remove the back panel at the most inconvenient times to jump the battery. RV-10 41087 N123CV ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Feb 20, 2013
Subject: Re: ground power attach
Last time we installed an APU plug we made a batch of the doublers. This is for the big AN connector. It comes ready to countersink and attach. You just use the doubler for a template. We're going to put this on the web site for sale but I thought I'd mention it here first. It works really well. Comes with the heavy duty doubler plate, hex stand-offs, and fiberglass push-on cover. I like the APU plug forward of the left door so you can see if it's plugged in before you taxi away. Price is $100 plus shipping for the doubler, standoffs, and fiberglass cover. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Feb 20, 2013
The rule I have is if you need to jump a battery(s) to start the engine, you need instead to charge the battery(s) so you have it for flight. Considering Odyssey batteries retain ~90% of charge after sitting for 6 months, there is little need to charge other than prolonged ground running of the panel. If you leave a master on and kill the battery, you don't want to fly until you know it will hold a charge - so again jumping for engine start is not an option. Most of us are heavily reliant on uninterrupted power to sophisticated panels. I took the easy way to provide access to connect a battery charger. Photos attached. Carl ________________________________________________________________________________
Date: Feb 21, 2013
I would like to add that it was strongly recommended to me that one not dep end on a battery charger to support your expensive avionics when running w/ o ships power. For both my G900x & Dual G3x I use the same 14V? regulated p ower supply. I have a small socket that plugs into the power supply for all ground work. I am told the power supply gives a spike free juice not achie ved by a battery charger. I don't fully understand why if one is using the battery to buffer the load other than the possibility energizing the entire system with dirty juice. Sorry no pix of the power supply. I know mine cos t about $150US. Again I am no expert but my preference is to minimize the amount of smoke c oming out of my panel. Robin [cid:image001.jpg(at)01CE0F8B.7399C090] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Carl Froehlich Sent: Wednesday, February 20, 2013 3:14 PM Subject: RE: RV10-List: Ground Power Attach The rule I have is if you need to jump a battery(s) to start the engine, yo u need instead to charge the battery(s) so you have it for flight. Conside ring Odyssey batteries retain ~90% of charge after sitting for 6 months, th ere is little need to charge other than prolonged ground running of the pan el. If you leave a master on and kill the battery, you don't want to fly u ntil you know it will hold a charge - so again jumping for engine start is not an option. Most of us are heavily reliant on uninterrupted power to sophisticated pane ls. I took the easy way to provide access to connect a battery charger. Photos attached. Carl
http://www.matronic================ http://forums.matronics.com - List Contribution Web generous nbsp; --> http:/ /www.matronics.com/c=<http://www.matronics.com/contribution> <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Feb 20, 2013
Subject: Re: Ground Power Attach
Date: Feb 21, 2013
Date: Feb 20, 2013
I mounted a pair of banana jacks to a bracket attached to the center support behind the aft bulkhead. They protrude forward slightly, thru a pair of small holes in the bulkhead. Attached to the battery via an in-line fuse. For charging only, not jump starting. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394721#394721 ________________________________________________________________________________
Subject: Re: Grab handles
Date: Feb 20, 2013
Hey Carroll, I couldn=99t find the handles by your number online with Lowe=99s here, but did find it at Home Depot. Later, =93 Lew From: Carroll L. Verhage Sent: Wednesday, February 20, 2013 5:08 PM Subject: RV10-List: Grab handles Patrick: Grab handles are nice and work well. They are easy to install. I have seen all sizes of grab handles but ones that look nice and are just the right size are Lowes' stainless 128mm BP27021-G drawer pull. I mounted them just above the rear windows 12 inches aft of the door opening. Their additional aeronautical drag is negligable. Make a template of the mounting holes on the handle. Drill a #8 screw size pilot hole through each layer of the Lexan into the cabin. Make sure these holes match the handle. Reem a little if necessary. Then drill the outer layer of the Lexan the OD of an aluminum spacer with an ID about the size of the #8 screw (I think it was 3/16 OD and 1/8 ID). Cut the spacer the length of the thickness of the Lexan so it stops against the inner layer of the Lexan and is flush with the outside Lexan surface. Mix about a tablespoon of epoxy with fiberglass filler for each handle the consistancy of peanut butter. Put 1/2 the epoxy in each mounting hole. Put a spacer in each hole so it has some fiberglass around the spacer filling up the cavity between the two layers of Lexan. Align the spacers by putting the handles back on. Let the fiberglass harden. Permanently mount the handles using a stainless steel fender washer inside the cabin. If the spacer is a little long, you can file it down flush with the outside. The spacer has to be long enough to press against the inner layer. With the spacers surrounded by fiberglass, it will stay in place when the handle is removed and also assure you don't collapse the shell when the handle is tightened down. You can add handles after you have your 10 built and flying and the cabin upholstery installed. Carroll ________________________________________________________________________________
Subject: PC925L & PC680 mounting
Date: Feb 21, 2013
I have searched the archives and can't seem to fine any pictures or discussion on mounting a dual battery system comprising of a PC925L and PC680. Anybody have any pictures of their mounting configuration or "if I had to do it again" confessions? I have considered the PC925L in standard rear position and PC680 on the firewall as in the RV7. Thanks Wayne RV10 final wiring RV7"eh?" flying ________________________________________________________________________________
Date: Feb 22, 2013
Many thanks Carroll. Warm regards Patrick On 21/02/2013, at 8:38 AM, "Carroll L. Verhage" wro te: > Patrick: Grab handles are nice and work well. They are easy to install. I have seen all sizes of grab handles but ones that look nice and are just the right size are Lowes' stainless 128mm BP27021-G drawer pull. I mounted them just above the rear windows 12 inches aft of the door opening. Their a dditional aeronautical drag is negligable. Make a template of the mounting h oles on the handle. Drill a #8 screw size pilot hole through each layer of t he Lexan into the cabin. Make sure these holes match the handle. Reem a l ittle if necessary. Then drill the outer layer of the Lexan the OD of an al uminum spacer with an ID about the size of the #8 screw (I think it was 3/16 OD and 1/8 ID). Cut the spacer the length of the thickness of the Lexan so it stops against the inner layer of the Lexan and is flush with the outside Lexan surface. Mix about a tablespoon of epoxy with fiberglass filler for e ach handle the consistancy of peanut butter. Put 1/2 the epoxy in each moun ting hole. Put a spacer in each hole so it has some fiberglass around the s pacer filling up the cavity between the two layers of Lexan. Align the spac ers by putting the handles back on. Let the fiberglass harden. Permanently m ount the handles using a stainless steel fender washer inside the cabin. If the spacer is a little long, you can file it down flush with the outside. T he spacer has to be long enough to press against the inner layer. With the s pacers surrounded by fiberglass, it will stay in place when the handle is re moved and also assure you don't collapse the shell when the handle is tighte ned down. You can add handles after you have your 10 built and flying and t he cabin upholstery installed. > > > Carroll > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 22, 2013
Any pictures please Lew? Warm regards Patrick On 21/02/2013, at 3:17 PM, wrote: > Hey Carroll, > > I couldn=99t find the handles by your number online with Lowe=99 s here, but did find it at Home Depot. > > Later, =93 Lew > > From: Carroll L. Verhage > Sent: Wednesday, February 20, 2013 5:08 PM > To: RV-10 > Subject: RV10-List: Grab handles > > Patrick: Grab handles are nice and work well. They are easy to install. I have seen all sizes of grab handles but ones that look nice and are just the right size are Lowes' stainless 128mm BP27021-G drawer pull. I mounted them just above the rear windows 12 inches aft of the door opening. Their a dditional aeronautical drag is negligable. Make a template of the mounting h oles on the handle. Drill a #8 screw size pilot hole through each layer of t he Lexan into the cabin. Make sure these holes match the handle. Reem a li ttle if necessary. Then drill the outer layer of the Lexan the OD of an alu minum spacer with an ID about the size of the #8 screw (I think it was 3/16 O D and 1/8 ID). Cut the spacer the length of the thickness of the Lexan so i t stops against the inner layer of the Lexan and is flush with the outside L exan surface. Mix about a tablespoon of epoxy with fiberglass filler for ea ch handle the consistancy of peanut butter. Put 1/2 the epoxy in each mount ing hole. Put a spacer in each hole so it has some fiberglass around the sp acer filling up the cavity between the two layers of Lexan. Align the space rs by putting the handles back on. Let the fiberglass harden. Permanently m ount the handles using a stainless steel fender washer inside the cabin. If the spacer is a little long, you can file it down flush with the outside. T he spacer has to be long enough to press against the inner layer. With the s pacers surrounded by fiberglass, it will stay in place when the handle is re moved and also assure you don't collapse the shell when the handle is tighte ned down. You can add handles after you have your 10 built and flying and t he cabin upholstery installed. > > > Carroll > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: PC925L & PC680 mounting
Date: Feb 21, 2013
That's the same configuration I'm looking at. Vans as you point out has a firewall kit for the pc680, I'm also looking at the Hawker tray. It's similar to the one I have in my flying 6 although the battery in the 6 is smaller. I believe someone has installed the firewall 680 and am looking for photos as well. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394764#394764 ________________________________________________________________________________
Date: Feb 21, 2013
I put a 680 on my firewall and have managed to kill the battery in two years. I think it was a heat problem. Next month while I am doing my condition inspection I am planning on taking the battery down to the battery shop and having them check it out and see if they can help tell me what went wrong. I have a 925 in the back that dates back to 2007. It is still going strong, but I am planning on having that checked out also. I put the 680 on the firewall after I was flying for extra reserve power and.....to move the CG forward. When I was building the airplane, because of some online discussions, I was concerned about the forward CG position of the stock airplane and made some decisions that drove the CG back (o2 and ELT placement). But after I was flying I found the CG to far back. So, I added the battery. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rvdave Sent: Thursday, February 21, 2013 2:44 PM Subject: RV10-List: Re: PC925L & PC680 mounting That's the same configuration I'm looking at. Vans as you point out has a firewall kit for the pc680, I'm also looking at the Hawker tray. It's similar to the one I have in my flying 6 although the battery in the 6 is smaller. I believe someone has installed the firewall 680 and am looking for photos as well. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394764#394764 ________________________________________________________________________________
Date: Feb 21, 2013
I understand the jump start argument, but still think options and flexibility are good. There is a big difference in risk between night/IFR and day/vfr. Most EFIS systems have independent power backup. Getting stuck where a battery or AC power for a charge is either unavailable or a ripoff might change perspective. A lot of airplanes fly without electrical systems, but a 540 would be a tough and dangerous hand throw. A jump is much safer if a solo pilot can remain at the controls and the Samaritan just needs to pull the plug and either keep or mail the cables. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394767#394767 ________________________________________________________________________________
Date: Feb 21, 2013
Here is our set up. The PC925 fits perfect in the existing Vans designed tray. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394768#394768 Attachments: http://forums.matronics.com//files/img_1978_561.jpg ________________________________________________________________________________
Subject: Aircraft Lifting
Date: Feb 21, 2013
I used a coupla of Harbor Freight Jacks and made some jack stands using plywood to hold them vertical. Used a short length of ready-bolt to screw into the tie down ring holes. Works well. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Feb 21, 2013
Seems like you need the 925L to match the cables as Vans supplies them, with the negative at the front end of the battery and positive to the rear. On Thu, Feb 21, 2013 at 5:09 PM, bill.peyton wrote: > > Here is our set up. The PC925 fits perfect in the existing Vans designed > tray. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=394768#394768 > > > Attachments: > > http://forums.matronics.com//files/img_1978_561.jpg > > ________________________________________________________________________________
Date: Feb 21, 2013
Nice setup Bill, do you have any photos of your tray construction and supports for the battery and accessories? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394774#394774 ________________________________________________________________________________
Date: Feb 22, 2013
Nice! Robin Sent from the new iPad On Feb 21, 2013, at 7:13 PM, "bill.peyton" wrote: > > Here is our set up. The PC925 fits perfect in the existing Vans designed tray. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=394768#394768 > > > > > Attachments: > > http://forums.matronics.com//files/img_1978_561.jpg > > > > > > > ________________________________________________________________________________
Date: Feb 21, 2013
The 925L polarity is correct for the installation. Sorry, I don't have any other photos of the tray. :( -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394777#394777 ________________________________________________________________________________
Date: Feb 21, 2013
Hey Patrick, Try http://www.homedepot.com/h_d1/N-5yc1v/R-100631483/h_d2/ProductDisplay?cat alogId=10053&langId=-1&keyword=BP27021-G&storeId=10051&superSkuId 2784539 for the actual Home Depot online item. I=99ll attach their picture to see if it goes through. Later, =93 Lew From: Patrick Pulis Sent: Thursday, February 21, 2013 3:02 PM Subject: Re: RV10-List: Grab handles Any pictures please Lew? Warm regards Patrick ________________________________________________________________________________
Date: Feb 21, 2013
Mine is set up almost like Bill's. I made my own 680 holder. It is supported off of the factory battery mount. The bottom of holder is bonded to bottom skin with proseal. If I had it to do over, I would have installed the 680 on the firewall since 95% of my flights are with family and baggage. It limits my baggage to 99 lbs with existing rear seat passenger weights. I like the 30-45 minutes of panel power and aux starting capabilities. No ext power connector needed. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394779#394779 ________________________________________________________________________________
Date: Feb 22, 2013
Bill, how did you support the additional tray both under and toward the f1047 rib? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394803#394803 ________________________________________________________________________________
Subject: RV-10 down
Date: Feb 22, 2013
h ttp://www.northcountrypublicradio.org/news/story/21496/20130222/friday-s-n ews-briefs-from-the-associated-press http://online.wsj.com/article/AP64479ee6392741ab994d76cc02180839.html ________________________________________________________________________________
Subject: RV-8 Packing List
Date: Feb 22, 2013
I'm helping a friend build an RV-8 and I'm wondering if anyone has or knows of a scanned copy of the packing lists and bag contents that could be downloaded. Certainly would be easier than scanning our copy, correcting all the scanning errors and putting it into Excel for sorting. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Feb 22, 2013
That side of the tray has a stiffener that slides under the rib to reinforce the rib. I used 3 #8 hardware to attach to the rib. It's very solid. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394820#394820 ________________________________________________________________________________
Subject: Re: RV-10 down
Date: Feb 22, 2013
[quote="rleffler"]Look at the flight data around 6:09pm. It shows the decent from 9400 to 3200 and multiple changes of direction. But after 6:09pm is looks like what may have been filed. Sent from my iPhone On Feb 22, 2013, at 2:35 PM, Seano wrote: Sent from my iPhone On Feb 22, 2013, at 12:08, Chris wrote: > > > > From internet sleuthing might be N10FD > > -Chris > > --- Filed 105KTs....seems slow for a 10. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394826#394826 ________________________________________________________________________________
Date: Feb 23, 2013
Came across this on Associated Press this morning: LAKE PLACID, N.Y. -- An experimental aircraft crashed into a wooded area just outside the village of Lake Placid, leaving three men to spend more than 10 hours in frigid conditions before they could be rescued early Friday. The men, all in their 50s and all from Westfield, were checked out by an ambulance crew but declined additional medical treatment when state forest rangers brought them out of the woods on snowmobiles around 4 a.m. Friday, according to the Department of Environmental Conservation. Agency spokesman David Winchell said state police contacted a department dispatcher around 6:30 p.m. Thursday seeking forest rangers to head to the scene of a plane crash in a wooded area near the Lake Placid Airport, just south of the village. The men on board the Vans RV-10 experimental aircraft had used a cellphone to call Essex County emergency dispatchers and provide coordinates of the crash site, Winchell said. Related Content MORE: Follow us @EyewitnessNYC MORE: Contact the WABC-TV New Jersey Bureau A state police helicopter dispatched from nearby Lake Clear Airport was unable to reach the crash site because of weather conditions and darkness. The men's information placed the crash site at Nye Mountain, near the airport. But by the time two rangers hiked to the location at 11 p.m., officials had determined they were in the wrong spot because the men's coordinates had been provided in a format not typically used by environmental department search teams, Winchell said. Plotting the coordinates in another format placed the actual crash site about a mile from Whiteface Inn Road, about 2 miles northwest of the village. Rangers reached the site around 2 a.m., Winchell said. The men had used extra clothing and a tarp to stay warm in temperatures that dipped into the single digits, he said. Officials identified the men as Michael Oster, 54; Jeff O'Connor, 58; and Frank Dombroski, 51, all of Westfield in Union County, N.J., just west of New York City. The men were believed to be staying in the Lake Placid area, but officials didn't know where, Winchell said. Attempts by The Associated Press to contact the men were unsuccessful. The Federal Aviation Administration said the plane departed from Somerset Airport in Bedminster, N.J, and was headed to Lake Placid Airport when it crashed. The FAA is investigating what caused the crash. -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394862#394862 ________________________________________________________________________________
Date: Feb 23, 2013
The pilot posted on VAF, on some of his experiences during this accident. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394866#394866 ________________________________________________________________________________
Date: Feb 23, 2013
http://kathrynaviationnews.com/?p=130333 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394870#394870 ________________________________________________________________________________
Date: Feb 23, 2013
Not under rv10 Please send link Thanks On Feb 23, 2013, at 8:27 AM, "Ron B." wrote: > > The pilot posted on VAF, on some of his experiences during this accident. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=394866#394866 > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 23, 2013
Lat and Long given to the 911 operator 4 times was 100% accurate. They failed on the communication to the SAR team. I can't say enough for the fortitude of the SAR team that hiked in to help us. We are very upset with the cover up of the errors in the dispatch system. We will foia the 911 calls to clarify the truth. We spent 10 hours in single digit temperatures, which was worse than the plane crash. While we greatly appreciate the efforts of everyone that helped us, we do not appreciate their misrepresentation of the facts. My RV-10 took a beating, yet the cabin protected us incredibly well. I am not in a position to post the details of the crash, as there were many factors yet to reconcile. The plane performed flawlessly and was not a factor in this accident. Best, Frank __________________ Frank Dombroski, NJ KSMQ RV-10 N10FD -----Original Message----- From: Pascal Sent: Saturday, February 23, 2013 2:05 PM Subject: Re: RV10-List: Re: RV-10 down Not under rv10 Please send link Thanks On Feb 23, 2013, at 8:27 AM, "Ron B." wrote: > > The pilot posted on VAF, on some of his experiences during this accident. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=394866#394866 > > ________________________________________________________________________________
Date: Feb 23, 2013
I flew from Boston area to NJ around that same time and while MY entire flight was in clear air, icing and the approaching Wx was at the top of my concern. Forecast showed much of the Wx concern was north of my flightpath from OWD to 47N. The altitude deviations lead me to speculate --and I stress speculate-- that this was icing related. Glad there were no fatalities. On a related note, traveling to far flung cities the past two years has brought my RV-10 construction to a crawl as I can work on it only when I'm back home on the weekends. At least now at my latest destination, I can commute with my own aircraft. Any builders in the Boston south shore area (Braintree, Quincy, Norwood, etc) that would like some help with their construction Mon-Thurs evenings? William http://wcurtis.nerv10.com/ 40237 On Feb 23, 2013, at 14:22, wrote: > > Lat and Long given to the 911 operator 4 times was 100% accurate. They failed on the communication to the SAR team. I can't say enough for the fortitude of the SAR team that hiked in to help us. > > We are very upset with the cover up of the errors in the dispatch system. We will foia the 911 calls to clarify the truth. We spent 10 hours in single digit temperatures, which was worse than the plane crash. While we greatly appreciate the efforts of everyone that helped us, we do not appreciate their misrepresentation of the facts. > > My RV-10 took a beating, yet the cabin protected us incredibly well. I am not in a position to post the details of the crash, as there were many factors yet to reconcile. The plane performed flawlessly and was not a factor in this accident. > > Best, > Frank > > __________________ > Frank Dombroski, NJ KSMQ > RV-10 N10FD > > > > -----Original Message----- From: Pascal > Sent: Saturday, February 23, 2013 2:05 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV-10 down > > > Not under rv10 > Please send link > Thanks > > > > On Feb 23, 2013, at 8:27 AM, "Ron B." wrote: > >> >> The pilot posted on VAF, on some of his experiences during this accident. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=394866#394866 > > > > > > > ________________________________________________________________________________
Date: Feb 23, 2013
It's under, " RV general discussion/news" Ron Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394895#394895 ________________________________________________________________________________
Subject: Re: Baffling tips
Date: Feb 23, 2013
jfrjr, You were right and I was wrong. My squeezer had sat for a bit and wasn't properly primed. Once I dialed it in, it pulled those rivets with no trouble. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394900#394900 ________________________________________________________________________________
Date: Feb 23, 2013
Here was the wx around that time. Sunset was about 1 hr prior. Wx 12.7 nm NW of LKP: KSLK 212251Z AUTO 20003KT 5SM BR OVC014 M12/M14 A3012 RMK AO2 SNB04E18 SLP241 P0000 T11221139 TSNO Wx 31.4 nm NE of LKP: KPBG 212253Z AUTO 10003KT 8SM -SN BKN035 OVC044 M07/M09 A3020 RMK AO2 SLP233 P0000 T10721094 Night, weather and big hills. AFS SV in the panel. Thankful for a dense Birch and Spruce forest to absorb some energy. Glad they are skiing this weekend. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394906#394906 ________________________________________________________________________________
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Subject: RV-10 on ice
Date: Feb 24, 2013
Are we the first RV-10 to land on the ice runway at Alton Bay, NH? The ice runway season for the last two years has been cut short by unpredictable w eather, but this year's earlier cold snap got a nice base of the hard stuff . Just pick a day with minimal crosswind and it's not too tricky . .. . On Flickr: http://www.flickr.com/x/t/0094009/photos/93596491@N08/850343468 7/ Tim Dawson-Townsend N52KS ________________________________________________________________________________
Subject: Re: RV-10 on ice
Date: Feb 24, 2013
Tim, I'm based close by at KLCI. Over the years there have been lots of mishaps at Alton Bay so I haven't lan ded my 10 there. I worry about the differential breaking for steering on ice . I have flown a 172 in there. With snow banks I worry about the low wing o n the 10. Friday was a nice day- light winds. Did you stop at Shibley's for lunch? Alan N668G Sent from my iPad On Feb 24, 2013, at 1:09 PM, "Dawson-Townsend,Timothy" wrote: > Are we the first RV-10 to land on the ice runway at Alton Bay, NH? The ic e runway season for the last two years has been cut short by unpredictable w eather, but this year's earlier cold snap got a nice base of the hard stuff. > > Just pick a day with minimal crosswind and it's not too tricky . .. . > > On Flickr: http://www.flickr.com/x/t/0094009/photos/93596491@N08/85034346 87/ > > Tim Dawson-Townsend > N52KS > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Feb 24, 2013
>From a BeechTalk post... I got the cliff notes of the story from Frank this morning I may not have this completely correct but here's the gist of what happened. What was most scary about hearing him tell this to me is I could see getting sucked in to the same kind of situation. Just like they always tell us, accidents are usually caused by what seems (at the time) like a a chain of minor events and if you can break the chain then it doesn't happen. If you don't break it, you look up just in time to hit the side of a mountain. Frank told his friends he didn't want to land at night but he knew they were calling it close. He got two weather briefings via AOPA & Foreflight and also called FAA for an update on the way to the airport, he also called the airport for a first hand report he said he was mostly thinking about ice. They got off on time but fought a 47 kt headwinds and so they got there later than planned (surprise 1) . He picked up an IFR clearance for the GPS approach. While shooting the approach he got a visual on the airport (when looking down, he said it looked like daylight down there) so he canceled (or got cleared for the visual I'm not sure I've got this part correct). He dropped down below the clouds and it was much darker than above (surprise 2), he clicked the airport lights and they wouldn't come on (turns out they have been having troubles with them but there were no notams) (surprise 3), at the same time one of his the big EFIS displays wouldn't dim (surprise 4). Frank said he thought he spent maybe 20-30 seconds trying to rectify these problems rather than going missed. He did decide to go missed but hit the side of the mountain as he was executing and hitting buttons. in retrospect Frank said he should have gone missed with ANY problem but these other factors sucked him into thinking he could quickly fix them and land. In another friend's words "that's why they call it an "accident" rather than an "on purpose"". Franks said it is a miracle to be alive, they hiked to the crash site today and he said it really hit him how lucky they were. A cut finger, a bruised face and frostbite is the worst of the physical injuries. He feels terrible about putting his friends in harms way and it's gonna take some time for him to forgive himself. Sent from my iPad == ________________________________________________________________________________
Date: Feb 24, 2013
Accidents happen. Glad they are ok. Interested to see if terrain aural warnings were on during IFR and/or synthetic vision. ----- Original Message ----- From: "Jim" <fehdxlbb(at)gmail.com> Sent: Sunday, February 24, 2013 7:04 PM Subject: RV10-List: Re: RV-10 down > >>From a BeechTalk post... > > I got the cliff notes of the story from Frank this morning I may not > have this completely correct but here's the gist of what happened. What > was most scary about hearing him tell this to me is I could see getting > sucked in to the same kind of situation. Just like they always tell us, > accidents are usually caused by what seems (at the time) like a a chain of > minor events and if you can break the chain then it doesn't happen. If you > don't break it, you look up just in time to hit the side of a mountain. > > Frank told his friends he didn't want to land at night but he knew they > were calling it close. He got two weather briefings via AOPA & Foreflight > and also called FAA for an update on the way to the airport, he also > called the airport for a first hand report he said he was mostly > thinking about ice. They got off on time but fought a 47 kt headwinds and > so they got there later than planned (surprise 1) . He picked up an IFR > clearance for the GPS approach. While shooting the approach he got a > visual on the airport (when looking down, he said it looked like daylight > down there) so he canceled (or got cleared for the visual I'm not sure > I've got this part correct). He dropped down below the clouds and it was > much darker than above (surprise 2), he clicked the airport lights and > they wouldn't come on (turns out they have been having troubles with them > but there were no notams) (surprise 3), at the same time one of his the > big EFIS displays wouldn't dim (surprise 4). Frank said! > he thought he spent maybe 20-30 seconds trying to rectify these problems > rather than going missed. He did decide to go missed but hit the side of > the mountain as he was executing and hitting buttons. > > in retrospect Frank said he should have gone missed with ANY problem but > these other factors sucked him into thinking he could quickly fix them and > land. In another friend's words "that's why they call it an "accident" > rather than an "on purpose"". > > Franks said it is a miracle to be alive, they hiked to the crash site > today and he said it really hit him how lucky they were. A cut finger, a > bruised face and frostbite is the worst of the physical injuries. He feels > terrible about putting his friends in harms way and it's gonna take some > time for him to forgive himself. > > Sent from my iPad > == > > > ________________________________________________________________________________
Date: Feb 24, 2013
Date: Feb 24, 2013
Date: Feb 25, 2013
CFIT on a missed approach and walking away is in the miracle category. Not that there is such a thing as a good accident, but I am glad that everyone is okay, and I am selfishly relieved that there were no apparent deficiencies in the aircraft or its design. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=394985#394985 ________________________________________________________________________________
Date: Feb 25, 2013
Subject: Fuel Lines
Hey all I started to fabricate the fuel lines in the tunnel etc today and where I attached the line to the firewall, I recently bought a AN832 steel bulkhead fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For those that have installed the fuel line to the engine, can I get away with the straight fitting or should I return it for the 45 degree fitting? I intend to mount the fuel flow transducer under the engine (if that helps). Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Ice runway videos, for those interested
Date: Feb 26, 2013
Ice Runway landing and takeoff. The "Navy landing" is accentuated by the handheld nature of the camera . . .! http://youtu.be/27xWtC0GxSw http://youtu.be/cVSJzsmg0Fo Tim N52KS ________________________________________________________________________________
Subject: Re: Ice runway videos, for those interested
Date: Feb 25, 2013
Cool videos. Did you have to use your drag chute? ;) ----- Original Message ----- From: Dawson-Townsend,Timothy To: RV10-List Digest Server Sent: Monday, February 25, 2013 7:34 PM Subject: RV10-List: Ice runway videos, for those interested Ice Runway landing and takeoff. The "Navy landing" is accentuated by the handheld nature of the camera . . .! http://youtu.be/27xWtC0GxSw http://youtu.be/cVSJzsmg0Fo Tim N52KS ________________________________________________________________________________
Date: Feb 25, 2013
Subject: Re: Fuel Lines
You should be OK but it might mean getting something other than the hose provided by Vans (Bonaco could make one). You can get a custom hose with a 45* or 90* fitting built in to the end. You did good by changing the provided aluminum fitting to steel. Dave Saylor 831-750-0284 CL On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark wrote: > Hey all > > I started to fabricate the fuel lines in the tunnel etc today and where I > attached the line to the firewall, I recently bought a AN832 steel bulkhead > fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For > those that have installed the fuel line to the engine, can I get away with > the straight fitting or should I return it for the 45 degree fitting? I > intend to mount the fuel flow transducer under the engine (if that helps). > > Thx, Rick > #40956 > Southampton, Ont > > ________________________________________________________________________________
Date: Feb 25, 2013
The reason for the 45 degree fitting or 45 degree hose end is because the engine mount and nose gear isolators are right to the left of and in front of that fitting. The angle allows the hose to loop out and around the engine mount and isolators before heading on its way to the engine driven fuel pump. -Sean #40303 (adding controls and fuel lines to engine) On 2/25/13 9:20 PM, Dave Saylor wrote: > > You should be OK but it might mean getting something other than the > hose provided by Vans (Bonaco could make one). You can get a custom > hose with a 45* or 90* fitting built in to the end. You did good by > changing the provided aluminum fitting to steel. > > Dave Saylor > 831-750-0284 CL > > > On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark wrote: >> Hey all >> >> I started to fabricate the fuel lines in the tunnel etc today and where I >> attached the line to the firewall, I recently bought a AN832 steel bulkhead >> fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For >> those that have installed the fuel line to the engine, can I get away with >> the straight fitting or should I return it for the 45 degree fitting? I >> intend to mount the fuel flow transducer under the engine (if that helps). >> >> Thx, Rick >> #40956 >> Southampton, Ont >> >> > > ________________________________________________________________________________
Subject: Window tint film
Date: Feb 25, 2013
Anybody have a source for window tint film that will work on plexi? I know it exits, I just haven't found any. Our old Socata had it on top halves of the windows and it worked fine. Unfortunately, the FBO that had it installed is OTS so I can't get a reference from them. I've seen Cirri and Velocities with it, so it must exist somewhere. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395057#395057 ________________________________________________________________________________
Date: Feb 26, 2013
Also, take a look at www.kitplanehoses.com. We have online pricing so you can "build" and order you hose directly from our website. Our hoses are all conductive Teflon with stainless ends. And, they are a true 37degree aviation flare. If you have any questions, please go to Www.kitplanehoses.com or email us at Steve(at)aircraftspecialty.com Have a great evening Sent from my iPhone On Feb 25, 2013, at 21:20, Dave Saylor wrote: > > You should be OK but it might mean getting something other than the > hose provided by Vans (Bonaco could make one). You can get a custom > hose with a 45* or 90* fitting built in to the end. You did good by > changing the provided aluminum fitting to steel. > > Dave Saylor > 831-750-0284 CL > > > On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark wrote: >> Hey all >> >> I started to fabricate the fuel lines in the tunnel etc today and where I >> attached the line to the firewall, I recently bought a AN832 steel bulkhead >> fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For >> those that have installed the fuel line to the engine, can I get away with >> the straight fitting or should I return it for the 45 degree fitting? I >> intend to mount the fuel flow transducer under the engine (if that helps). >> >> Thx, Rick >> #40956 >> Southampton, Ont >> >> > > > > ________________________________________________________________________________
Date: Feb 26, 2013
Sean/Dave, thx for the info. I'm heading to Aircraft Spruce today and will take the straight fitting with me and see if they will exchange it. For the record, I did not buy Vans engine hoses, so the custom hose option is still open. Regards, Rick On Mon, Feb 25, 2013 at 10:46 PM, Sean Stephens wrote: > > The reason for the 45 degree fitting or 45 degree hose end is because the > engine mount and nose gear isolators are right to the left of and in front > of that fitting. The angle allows the hose to loop out and around the > engine mount and isolators before heading on its way to the engine driven > fuel pump. > > -Sean #40303 (adding controls and fuel lines to engine) > > On 2/25/13 9:20 PM, Dave Saylor wrote: > >> gmail.com > >> >> You should be OK but it might mean getting something other than the >> hose provided by Vans (Bonaco could make one). You can get a custom >> hose with a 45* or 90* fitting built in to the end. You did good by >> changing the provided aluminum fitting to steel. >> >> Dave Saylor >> 831-750-0284 CL >> >> >> On Mon, Feb 25, 2013 at 3:56 PM, Rick Lark wrote: >> >>> Hey all >>> >>> I started to fabricate the fuel lines in the tunnel etc today and where I >>> attached the line to the firewall, I recently bought a AN832 steel >>> bulkhead >>> fitting (straight) instead of an AN837 bulkhead fitting (45 degree). For >>> those that have installed the fuel line to the engine, can I get away >>> with >>> the straight fitting or should I return it for the 45 degree fitting? I >>> intend to mount the fuel flow transducer under the engine (if that >>> helps). >>> >>> Thx, Rick >>> #40956 >>> Southampton, Ont >>> >>> >>> >> >> >> > > ________________________________________________________________________________
Subject: Re: Window tint film
Date: Feb 26, 2013
=46rom my uncle that does window tinting, re plexiglass tinting: Call Johnson Window films 800 448 8468. It will only form in one direction n ot two if I remember right. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Feb 25, 2013, at 10:56 PM, "woxofswa" wrote: > > Anybody have a source for window tint film that will work on plexi? > I know it exits, I just haven't found any. Our old Socata had it on top ha lves of the windows and it worked fine. Unfortunately, the FBO that had it i nstalled is OTS so I can't get a reference from them. > I've seen Cirri and Velocities with it, so it must exist somewhere. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. Finishing k it and FWF kit in progress. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395057#395057 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Feb 26, 2013
Thanks Jesse, I called them. They don't have any product that will work but they did steer me towards a static cling product that might. I'm just at the exploratory stage right now and don't need it for months, but I will report back. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395125#395125 ________________________________________________________________________________
Date: Feb 26, 2013
Rick, Here is how it looks coming out of the firewall to the pump -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395147#395147 Attachments: http://forums.matronics.com//files/img_2522_859.jpg ________________________________________________________________________________
Date: Feb 27, 2013
Have been doing a little research on pc680 & firewall mounting. The pc680mj is rated for temps of 176f vs 680 at 140f. The tray that hawker sells for the 680 only, provides nice protection though. Not sure if that would increase its rating or what real firewall temps would be behind baffling but within exhaust piping area . I have a smaller 7ah battery on my 6 with the sd8 alternator mounted high in the center of the firewall but usually change that one out every other year. I guess real question is what are real world firewall temps on the 10? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395185#395185 ________________________________________________________________________________
Date: Feb 27, 2013
They run as high as 190 F on a hot summer day at the lower firewall -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395223#395223 ________________________________________________________________________________
Date: Feb 27, 2013
Aha, thx. I got to Aircraft Spruce @ CYFD yesterday and switched the fitting I had for the 45 degree one. Glad I did by the looks of your photo. So the fuel route is fuel pump, transducer, distribution spyder, cylinders? Not sure thats correct? Rick On Tue, Feb 26, 2013 at 10:22 PM, bill.peyton wrote: > > Rick, > Here is how it looks coming out of the firewall to the pump > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395147#395147 > > > Attachments: > > http://forums.matronics.com//files/img_2522_859.jpg > > ________________________________________________________________________________
Date: Feb 27, 2013
Rick, The routing is engine driven fuel pump--fuel servo--FF transducer--spider--cylinders -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395239#395239 ________________________________________________________________________________
Date: Feb 27, 2013
firewall, fuel pump, servo, distributor, injectors. You can insert the transducer either between the pump and servo, or between the servo and the distributor. EI, who makes the transducer has it between the pump and the servo on their STC for certified planes, but several folks here have had success between servo and distributor, which is normal location for Continental fuel injection with fuel return line, that Bendix FI does not have. On Wed, Feb 27, 2013 at 6:49 PM, Rick Lark wrote: > Aha, thx. I got to Aircraft Spruce @ CYFD yesterday and switched the > fitting I had for the 45 degree one. Glad I did by the looks of your > photo. > > So the fuel route is fuel pump, transducer, distribution spyder, > cylinders? Not sure thats correct? > > Rick > ________________________________________________________________________________
Subject: Obstruction behind instrument panel
Date: Feb 27, 2013
It appears that certain large screen EFIS will not fit behind the instrument panel due to the several structural elements that are in the way. Has anyone come up with a solution or a method for cutting these down without compromising the airframe? ________________________________________________________________________________
Date: Feb 27, 2013
Subject: Re: Obstruction behind instrument panel
Vans recommends rather strongly that the triangular braces not be cut. Some certainly have done it and reinforced with aluminum angle, but no idea how sound that might be. No clearance issues with my Dynon Skyview 10" screens. On Wed, Feb 27, 2013 at 9:57 PM, BC wrote: > It appears that certain large screen EFIS will not fit behind the > instrument panel due to the several structural elements that are in the > way. Has anyone come up with a solution or a method for cutting these down > without compromising the airframe?**** > > ** ** > > * > > * > > ________________________________________________________________________________
Date: Feb 27, 2013
The Incredibly Magnificent One's (TIM O) website has what you're looking for: http://www.myrv10.com/N104CD/fuselage/20050610/index.html Did anyone notice how well the upper fuselage area held together in the Lake Placid accident? He had big AFS screens so he almost certainly had to modify these ribs. If I had to leave one intact, I'd make it the center one. Look at the pictures of the center post in the accident photos--it's pretty clearly bent. Dave Saylor 831-750-0284 CL On Wed, Feb 27, 2013 at 8:57 PM, BC wrote: > It appears that certain large screen EFIS will not fit behind the instrument > panel due to the several structural elements that are in the way. Has anyone > come up with a solution or a method for cutting these down without > compromising the airframe? > > ________________________________________________________________________________
Date: Feb 28, 2013
I just trimmed the small end back a little to fit MGL Odysseys. Linn On 2/27/2013 11:57 PM, BC wrote: > > It appears that certain large screen EFIS will not fit behind the > instrument panel due to the several structural elements that are in > the way. Has anyone come up with a solution or a method for cutting > these down without compromising the airframe? > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Feb 27, 2013
Good grief! Press quotes pilot's wife as saying "Every piece is built by Cessna or Boeing." -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395253#395253 ________________________________________________________________________________
Date: Feb 28, 2013
I can't imagine the press would ever screw up a quote. My guess is the wife said something along the lines of "Every piece is built (just like they do at) Boeing or Cessna. On Wed, Feb 27, 2013 at 11:57 PM, Bob Turner wrote: > > Good grief! Press quotes pilot's wife as saying "Every piece is built by > Cessna or Boeing." > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395253#395253 > > ________________________________________________________________________________
Date: Feb 28, 2013
It's very common to modify the structure behind the panel within reason. The ribs and sub panel are all candidates for modification, but that doesn't mean you just "remove material" and call it good. With any aircraft structure from a cub to a 747, if you remove material you traditionally need to add back material in order to give said structure it's load bearing capacity. If you remove in one place, you add in another. There are a number of ways to modify the ribs and still keep the structural integrity of the entire assembly in place, but it's also not a one size fit's all solution. The center rib from where the center brace attaches is a place that is difficult to do any reasonable modification. That said, all of the ribs between the sub panel and the main panel can be changed in differing ways (depending on your situation) to allow for avionics, efises, etc.. to be installed and still keep everything good. I'd encourage you to decide what is going in there, then decide what/where you need to modify and consult with someone before just jumping in. That doesn't mean you have to hire a structural engineer, but have a 2nd set of eyes from someone who knows structure pretty well and you'll be good! Just my 2 cents as usual. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of BC Sent: Wednesday, February 27, 2013 10:57 PM Subject: RV10-List: Obstruction behind instrument panel It appears that certain large screen EFIS will not fit behind the instrument panel due to the several structural elements that are in the way. Has anyone come up with a solution or a method for cutting these down without compromising the airframe? ________________________________________________________________________________
Subject: Granby, CO
Date: Feb 28, 2013
Can anybody offer insight into flying into Granby, CO in the summer? Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone ________________________________________________________________________________
Date: Feb 28, 2013
Subject: Re: Granby, CO
Well, the passes from the west are over 10,000 ft, from the east you are looking at over 13,000. While it might be ok for RV-10, it violates my personal high altitude airport general rule of runway length equals elevation or better(think twice and calculate carefully if that condition isn't met). I've been in and out of Steamboat Springs and Aspen, but not Granby. On Thu, Feb 28, 2013 at 4:50 PM, Jesse Saint wrote: > > Can anybody offer insight into flying into Granby, CO in the summer? > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > ________________________________________________________________________________
Date: Mar 01, 2013
From: Matt Gabrielson <m.gabrielson(at)sbcglobal.net>
My Dad lives in Colorado and does not fly his 182 into Granby for reasons similar to Kelly's. As an alternative, Kremmling Colorado just to the west of there offers more margin and although the approach is kind of around a hill it's not too bad. Matt Gabrielson ________________________________ From: Kelly McMullen <apilot2(at)gmail.com> Sent: Thu, February 28, 2013 9:06:42 PM Subject: Re: RV10-List: Granby, CO Well, the passes from the west are over 10,000 ft, from the east you are looking at over 13,000. While it might be ok for RV-10, it violates my personal high altitude airport general rule of runway length equals elevation or better(think twice and calculate carefully if that condition isn't met). I've been in and out of Steamboat Springs and Aspen, but not Granby. On Thu, Feb 28, 2013 at 4:50 PM, Jesse Saint wrote: > >Can anybody offer insight into flying into Granby, CO in the summer? > >Jesse Saint >I-TEC, Inc. >jesse(at)itecusa.org >www.itecusa.org >www.mavericklsa.com >C: 352-427-0285 >O: 352-465-4545 >F: 815-377-3694 > >Sent from my iPhone > >========== >arget="_blank">http://www.matronics.com/Navigator?RV10-List >========== >http://forums.matronics.com >========== >le, List Admin. >="_blank">http://www.matronics.com/contribution >========== > > ________________________________________________________________________________
Date: Mar 01, 2013
Subject: Heated pitot
What is the-consensus-on the choice for heated pitot? I am getting clos e to paint and want to install before I do. Thanks-=0ABruce 151BJ ________________________________________________________________________________
Date: Mar 01, 2013
I was able to avoid touching the ribs, but I used page 41-3 to the maximum. As Stein said, it takes planning and compromise. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395351#395351 ________________________________________________________________________________
Subject: Re: Heated pitot
Date: Mar 01, 2013
>From personal experience I would not buy the Gretz again. The first one melted and the second one I have now is cracked. My panel has the labeling and holes drilled permenantly for the status lights so hard to change to a different pitot at this point. ----- Original Message ----- From: Bruce Johnson To: rv10-list(at)matronics.com Sent: Friday, March 01, 2013 8:14 AM Subject: RV10-List: Heated pitot What is the consensus on the choice for heated pitot? I am getting close to paint and want to install before I do. Thanks Bruce 151BJ ________________________________________________________________________________
Date: Mar 01, 2013
Dynon SkyView. You get a heated pitot and AOA in one - for the same price as just a heated pitot. If you're not using SkyView EFIS, then never mind. The mount however is applicable to other pitot options - so perhaps just picking the mount for now solves your "get to paint" issue. I suggest however painting the wings and mount separate. Dynon recommends a mount like the Gretz: http://www.aircraftspruce.com/pages/in/pitot_accessories/gretzbrackets.php Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Johnson Sent: Friday, March 01, 2013 10:14 AM Subject: RV10-List: Heated pitot What is the consensus on the choice for heated pitot? I am getting close to paint and want to install before I do. Thanks Bruce 151BJ ________________________________________________________________________________
Date: Mar 01, 2013
Gretz and dynon are probably the most popular. Both use the same mount, wh ich is all you should need for paint. Sent from my iPhone On Mar 1, 2013, at 10:14 AM, Bruce Johnson wrote : What is the consensus on the choice for heated pitot? I am getting c lose to paint and want to install before I do. Thanks Bruce 151BJ ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Mar 01, 2013
John What do you exactly mean by using page 41-3 to the maximum? Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: sexta-feira, 1 de Mar=E7o de 2013 15:38 Subject: RV10-List: Re: Obstruction behind instrument panel --> < johngoodman(at)earthlink.net> I was able to avoid touching the ribs, but I used page 41-3 to the maximum. As Stein said, it takes planning and compromise. John -------- #40572 Phase One complete and flying. Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=395351#395351> http://forums.matronics.com/viewtopic.php?p=395351#395351 List 7-Day http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 01, 2013
It's high but I can't imagine the 10 having a problem getting out of a 5000 f oot runway even at 8200 feet. The hottest recorded temp was 89 f in July 200 2. Sounds like taking off to the east is tougher. I would try it in the summ er but would need to look into it more for max takeoff weight. Sent from my iPhone On Feb 28, 2013, at 18:57, Kelly McMullen wrote: > Well, the passes from the west are over 10,000 ft, from the east you are l ooking at over 13,000. While it might be ok for RV-10, it violates my person al high altitude airport general rule of runway length equals elevation or b etter(think twice and calculate carefully if that condition isn't met). I've been in and out of Steamboat Springs and Aspen, but not Granby. > > On Thu, Feb 28, 2013 at 4:50 PM, Jesse Saint wro te: >> >> Can anybody offer insight into flying into Granby, CO in the summer? >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org >> www.mavericklsa.com >> C: 352-427-0285 >> O: 352-465-4545 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 01, 2013
trigo(at)mail.telepac.pt wrote: > John > > What do you exactly mean by using page 41-3 to the maximum? > > Carlos > > -- My Radio Stack is immediately to the right of the center brace, and my VP-200 is just to the left. I got them as close as I could but still using Van's bracing suggestions on 41-3. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395363#395363 ________________________________________________________________________________
Date: Mar 01, 2013
Thanks for the input, -I will get the mount for paint. Just curious does the Gretz still work with the crack?=0A=0A=0A______________________________ __=0A From: Seano <sean(at)braunandco.com>=0ATo: rv10-list(at)matronics.com =0ASe nt: Friday, March 1, 2013 8:49 AM=0ASubject: Re: RV10-List: Heated pitot=0A =0A=0A =0AFrom personal experience I would not buy the Gretz =0Aagain.- The first one melted and the second one I have now is =0Acracked.- My pan el has the labeling and holes drilled permenantly for the =0Astatus lights so hard to change to a different pitot at this point.=0A----- Original Mess age ----- =0A>From: Bruce Johnson =0A>To: rv10-list(at)matronics.com =0A>Sent: Friday, March 01, 2013 8:14 =0AAM=0A>Subject: RV10-List: Heated pitot=0A> =0A>=0A>What is the-consensus-on the choice for heated pitot? I am ge tting close to paint and want to install before I do. Thanks-=0A>Bruce 151BJ=0A>href="http://www.matronics.com/Navigator?RV10-List">http://www.m atronics.com/Navigator?RV10-List=0Ahref="http://forums.matronics.com">htt p://forums.matronics.com=0Ahref="http://www.matronics.com/contribution">h ===================== ________________________________________________________________________________
Date: Mar 01, 2013
So far it does work with the crack. I've used it probably ten times in 300 hours. ----- Original Message ----- From: Bruce Johnson To: rv10-list(at)matronics.com Sent: Friday, March 01, 2013 11:01 AM Subject: Re: RV10-List: Heated pitot Thanks for the input, I will get the mount for paint. Just curious does the Gretz still work with the crack? ------------------------------------------------------------------------- ----- From: Seano <sean(at)braunandco.com> To: rv10-list(at)matronics.com Sent: Friday, March 1, 2013 8:49 AM Subject: Re: RV10-List: Heated pitot From personal experience I would not buy the Gretz again. The first one melted and the second one I have now is cracked. My panel has the labeling and holes drilled permenantly for the status lights so hard to change to a different pitot at this point. ----- Original Message ----- From: Bruce Johnson To: rv10-list(at)matronics.com Sent: Friday, March 01, 2013 8:14 AM Subject: RV10-List: Heated pitot What is the consensus on the choice for heated pitot? I am getting close to paint and want to install before I do. Thanks Bruce 151BJ href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matro=================== ________________________________________________________________________________
Date: Mar 01, 2013
The Dynon unit works pretty well. I like the "smart" aspect of the heating unit. Besides its was cheaper. :-) From: sean(at)braunandco.com Subject: Re: RV10-List: Heated pitot Date: Fri=2C 1 Mar 2013 11:16:47 -0700 So far it does work with the crack. I've used it probably ten times in 300 hours. ----- Original Message ----- From: Bruce Johnson To: rv10-list(at)matronics.com Sent: Friday=2C March 01=2C 2013 11:01 AM Subject: Re: RV10-List: Heated pitot Thanks for the input=2C I will get the mount for paint. Just curious does the Gretz still work with the crack? From: Seano <sean(at)braunandco.com> Sent: Friday=2C March 1=2C 2013 8:49 AM Subject: Re: RV10-List: Heated pitot From personal experience I would not buy the Gretz again. The first one melted and the second one I have now is cracked. My panel has the labeling and holes drilled permenantly for the status lights so hard to change to a different pitot at this point. ----- Original Message ----- From: Bruce Johnson To: rv10-list(at)matronics.com Sent: Friday=2C March 01=2C 2013 8:14 AM Subject: RV10-List: Heated pitot What is the consensus on the choice for heated pitot? I am getting close to paint and want to in stall before I do. Thanks Bruce 151BJ href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matro=================== href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 01, 2013
No issues with Getz 460 hours. Dick Sipp From: Bruce Johnson Sent: Friday, March 01, 2013 10:14 AM Subject: RV10-List: Heated pitot What is the consensus on the choice for heated pitot? I am getting close to paint and want to install before I do. Thanks Bruce 151BJ ________________________________________________________________________________
Date: Mar 01, 2013
I have the Dynon. Cannot say how well the heat works as I have never had the 10 in icing conditions. As mentioned it has a temperature controller so you can just leave it on all the time if you wish. I have a Dynon D6 as backup efis and, with the Dynon pitot, it provides a visual and audio angle of attack warning. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395376#395376 ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 02, 2013
Subject: RV-10 Stall Characteristics (what just happened here?)
Last weekend I took some folks on demo rides. All are -10 builders, not yet flying. On one flight, I had one big guy in the back seat. My CG range is 8.4 to 16.8 (inches aft of the wing leading edge). My CG on takeoff was 14.4--I ran the number before we departed because I knew the CG was "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we loaded the plane at aft CG, max gross, and did some stalls. I don't recall anything strange at all about those maneuvers. First, I demonstrated an approach stall, which I've done many times. My normal recovery is just to add a little power, stick neutral if necessary, and the plane just flys out. On the first stall, that's just how it went. Of course then it was time for a little "Watch this!"... Actually, I wanted to demonstrate the AOA audio warning, "Angle-Angle-Push", which was kind of faint on the first stall. So I let the stall develop further, keeping wings level with the rudder. The wings rocked a bit but nothing serious. The nose stayed straight ahead. Then, the nose pitched WAY down. I added power to break the stall and fly it out but there was no change. It felt like we were descending, not flying. It felt like we were about 45* nose down, but the EFIS logs didn't capture anything that extreme. I was concerned about entering a spin. So was the guy in the front seat--he said so as it was happening...I added more power, stick neutral, and still the nose was pointed down. I kept the wings more or less level but at this point things seemed out of the ordinary so I got more agressive with the controls. I pushed forward, adding more power. The plane then seemed to fly, and I seemed to be going pretty fast, but I didn't look at the airspeed. I pulled up gently and the controls eventually started feeling normal again. The EFIS logs showed the whole event lasted less than 10 seconds--two data captures--but it sure seemed longer. We lost about 300 feet. I spoke to another -10 owner who has a lot of acro and formation experience. He said, yeah, it'll do that...he concurred that from a deep stall, an RV-10 requires extra effort to break it. That's probably not a huge surprise if you think about it and expect it, but in this case it gave me (and unfortunately my passengers) a little concern. I'd be interested to hear if others have had similar experiences, and if anyone has an explanation for what's going on aerodynamically. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Subject: Re: RV-10 Stall Characteristics (what just happened here?)
Date: Mar 02, 2013
Nice job getting out of that situation, Dave. Glad you are still with us! John J On Mar 2, 2013, at 9:35 AM, Dave Saylor wrote: > > Last weekend I took some folks on demo rides. All are -10 builders, > not yet flying. > > On one flight, I had one big guy in the back seat. My CG range is 8.4 > to 16.8 (inches aft of the wing leading edge). My CG on takeoff was > 14.4--I ran the number before we departed because I knew the CG was > "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we > loaded the plane at aft CG, max gross, and did some stalls. I don't > recall anything strange at all about those maneuvers. > > First, I demonstrated an approach stall, which I've done many times. > My normal recovery is just to add a little power, stick neutral if > necessary, and the plane just flys out. On the first stall, that's > just how it went. > > Of course then it was time for a little "Watch this!"... > > Actually, I wanted to demonstrate the AOA audio warning, > "Angle-Angle-Push", which was kind of faint on the first stall. So I > let the stall develop further, keeping wings level with the rudder. > The wings rocked a bit but nothing serious. The nose stayed straight > ahead. Then, the nose pitched WAY down. I added power to break the > stall and fly it out but there was no change. It felt like we were > descending, not flying. It felt like we were about 45* nose down, but > the EFIS logs didn't capture anything that extreme. I was concerned > about entering a spin. So was the guy in the front seat--he said so > as it was happening...I added more power, stick neutral, and still the > nose was pointed down. I kept the wings more or less level but at > this point things seemed out of the ordinary so I got more agressive > with the controls. I pushed forward, adding more power. The plane > then seemed to fly, and I seemed to be going pretty fast, but I didn't > look at the airspeed. I pulled up gently and the controls eventually > started feeling normal again. The EFIS logs showed the whole event > lasted less than 10 seconds--two data captures--but it sure seemed > longer. We lost about 300 feet. > > I spoke to another -10 owner who has a lot of acro and formation > experience. He said, yeah, it'll do that...he concurred that from a > deep stall, an RV-10 requires extra effort to break it. That's > probably not a huge surprise if you think about it and expect it, but > in this case it gave me (and unfortunately my passengers) a little > concern. > > I'd be interested to hear if others have had similar experiences, and > if anyone has an explanation for what's going on aerodynamically. > > Dave Saylor > 831-750-0284 CL > > > > ________________________________________________________________________________
Date: Mar 02, 2013
Well, I didn't mean to make it seem super dangerous...it wasn't like I was seeing scenes from my childhood or anything. It got my attention and it may have resolved itself after a few more seconds--I don't know. I didn't feel terribly out of control or anything but the plane didn't respond exactly like I expected it too. Unless I hear a reason not to, I'm gonna try it again, but this time expect a slower recovery. Dave Saylor 831-750-0284 CL On Sat, Mar 2, 2013 at 9:48 AM, John Jessen wrote: > > Nice job getting out of that situation, Dave. Glad you are still with us! > > John J > > On Mar 2, 2013, at 9:35 AM, Dave Saylor wrote: > >> >> Last weekend I took some folks on demo rides. All are -10 builders, >> not yet flying. >> >> On one flight, I had one big guy in the back seat. My CG range is 8.4 >> to 16.8 (inches aft of the wing leading edge). My CG on takeoff was >> 14.4--I ran the number before we departed because I knew the CG was >> "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we >> loaded the plane at aft CG, max gross, and did some stalls. I don't >> recall anything strange at all about those maneuvers. >> >> First, I demonstrated an approach stall, which I've done many times. >> My normal recovery is just to add a little power, stick neutral if >> necessary, and the plane just flys out. On the first stall, that's >> just how it went. >> >> Of course then it was time for a little "Watch this!"... >> >> Actually, I wanted to demonstrate the AOA audio warning, >> "Angle-Angle-Push", which was kind of faint on the first stall. So I >> let the stall develop further, keeping wings level with the rudder. >> The wings rocked a bit but nothing serious. The nose stayed straight >> ahead. Then, the nose pitched WAY down. I added power to break the >> stall and fly it out but there was no change. It felt like we were >> descending, not flying. It felt like we were about 45* nose down, but >> the EFIS logs didn't capture anything that extreme. I was concerned >> about entering a spin. So was the guy in the front seat--he said so >> as it was happening...I added more power, stick neutral, and still the >> nose was pointed down. I kept the wings more or less level but at >> this point things seemed out of the ordinary so I got more agressive >> with the controls. I pushed forward, adding more power. The plane >> then seemed to fly, and I seemed to be going pretty fast, but I didn't >> look at the airspeed. I pulled up gently and the controls eventually >> started feeling normal again. The EFIS logs showed the whole event >> lasted less than 10 seconds--two data captures--but it sure seemed >> longer. We lost about 300 feet. >> >> I spoke to another -10 owner who has a lot of acro and formation >> experience. He said, yeah, it'll do that...he concurred that from a >> deep stall, an RV-10 requires extra effort to break it. That's >> probably not a huge surprise if you think about it and expect it, but >> in this case it gave me (and unfortunately my passengers) a little >> concern. >> >> I'd be interested to hear if others have had similar experiences, and >> if anyone has an explanation for what's going on aerodynamically. >> >> Dave Saylor >> 831-750-0284 CL >> >> >> >> > > ________________________________________________________________________________
Date: Mar 02, 2013
I've seen something odd like this once too. The situation was a bit different though from the sounds of it. Would you say that the elevator felt somewhat aerodynamically "disconnected" during this? The experience I had, you could hear the prop pitch change as it sounded like it quit biting the air the same, and the pitch force got real "sloppy", like you could have pulled or pushed and not gotten a lot of response at all. But, going into standard stall recovery mode automatically, I shoved the stick forward and it came right out of it. The whole thing lasted only maybe 2 seconds, but when you feel something like that you know how time goes slowly. At any rate, I think I was just so deep in the stall at the time that probably the wing wash interrupted the flow over the horizontal stabilizer, or something like that. So the elevator lost some effectiveness. At least that's what I attributed it to. It wasn't quite a normal flight situation for me, so I've been thinking of some day trying to recreate it up high, but I'm not sure if I could, without the added weight of filled seats...so I'm not sure if I'll bother. The airplane behaved pretty well through it, so I was happy for that. Tim On 3/2/2013 11:35 AM, Dave Saylor wrote: > > Last weekend I took some folks on demo rides. All are -10 builders, > not yet flying. > > On one flight, I had one big guy in the back seat. My CG range is 8.4 > to 16.8 (inches aft of the wing leading edge). My CG on takeoff was > 14.4--I ran the number before we departed because I knew the CG was > "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we > loaded the plane at aft CG, max gross, and did some stalls. I don't > recall anything strange at all about those maneuvers. > > First, I demonstrated an approach stall, which I've done many times. > My normal recovery is just to add a little power, stick neutral if > necessary, and the plane just flys out. On the first stall, that's > just how it went. > > Of course then it was time for a little "Watch this!"... > > Actually, I wanted to demonstrate the AOA audio warning, > "Angle-Angle-Push", which was kind of faint on the first stall. So I > let the stall develop further, keeping wings level with the rudder. > The wings rocked a bit but nothing serious. The nose stayed straight > ahead. Then, the nose pitched WAY down. I added power to break the > stall and fly it out but there was no change. It felt like we were > descending, not flying. It felt like we were about 45* nose down, but > the EFIS logs didn't capture anything that extreme. I was concerned > about entering a spin. So was the guy in the front seat--he said so > as it was happening...I added more power, stick neutral, and still the > nose was pointed down. I kept the wings more or less level but at > this point things seemed out of the ordinary so I got more agressive > with the controls. I pushed forward, adding more power. The plane > then seemed to fly, and I seemed to be going pretty fast, but I didn't > look at the airspeed. I pulled up gently and the controls eventually > started feeling normal again. The EFIS logs showed the whole event > lasted less than 10 seconds--two data captures--but it sure seemed > longer. We lost about 300 feet. > > I spoke to another -10 owner who has a lot of acro and formation > experience. He said, yeah, it'll do that...he concurred that from a > deep stall, an RV-10 requires extra effort to break it. That's > probably not a huge surprise if you think about it and expect it, but > in this case it gave me (and unfortunately my passengers) a little > concern. > > I'd be interested to hear if others have had similar experiences, and > if anyone has an explanation for what's going on aerodynamically. > > Dave Saylor > 831-750-0284 CL > > ________________________________________________________________________________
Date: Mar 02, 2013
I was up experimenting with the stall in my 10. Mine is at the fwd cg with me alone so keep that in mind. I stalled and kept the stick full aft. The plane just buffeted and still had good aileron control. I stomped on the rudder both directions with full aft stick and the plane just mushed along. It would not enter a spin. Like I said I am close to the fwd CG. I have a video of this I'll try to post later. Sent from my iPhone On Mar 2, 2013, at 10:02, Tim Olson wrote: > > I've seen something odd like this once too. The situation was a bit > different though from the sounds of it. Would you say that the > elevator felt somewhat aerodynamically "disconnected" during this? > The experience I had, you could hear the prop pitch change as it > sounded like it quit biting the air the same, and the pitch force > got real "sloppy", like you could have pulled or pushed and not > gotten a lot of response at all. But, going into standard stall > recovery mode automatically, I shoved the stick forward and > it came right out of it. The whole thing lasted only maybe 2 seconds, > but when you feel something like that you know how time goes slowly. > At any rate, I think I was just so deep in the stall at the time > that probably the wing wash interrupted the flow over the horizontal > stabilizer, or something like that. So the elevator lost some > effectiveness. At least that's what I attributed it to. > It wasn't quite a normal flight situation for me, so I've been > thinking of some day trying to recreate it up high, but I'm not > sure if I could, without the added weight of filled seats...so > I'm not sure if I'll bother. The airplane behaved pretty well > through it, so I was happy for that. > > Tim > > > On 3/2/2013 11:35 AM, Dave Saylor wrote: >> >> Last weekend I took some folks on demo rides. All are -10 builders, >> not yet flying. >> >> On one flight, I had one big guy in the back seat. My CG range is 8.4 >> to 16.8 (inches aft of the wing leading edge). My CG on takeoff was >> 14.4--I ran the number before we departed because I knew the CG was >> "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we >> loaded the plane at aft CG, max gross, and did some stalls. I don't >> recall anything strange at all about those maneuvers. >> >> First, I demonstrated an approach stall, which I've done many times. >> My normal recovery is just to add a little power, stick neutral if >> necessary, and the plane just flys out. On the first stall, that's >> just how it went. >> >> Of course then it was time for a little "Watch this!"... >> >> Actually, I wanted to demonstrate the AOA audio warning, >> "Angle-Angle-Push", which was kind of faint on the first stall. So I >> let the stall develop further, keeping wings level with the rudder. >> The wings rocked a bit but nothing serious. The nose stayed straight >> ahead. Then, the nose pitched WAY down. I added power to break the >> stall and fly it out but there was no change. It felt like we were >> descending, not flying. It felt like we were about 45* nose down, but >> the EFIS logs didn't capture anything that extreme. I was concerned >> about entering a spin. So was the guy in the front seat--he said so >> as it was happening...I added more power, stick neutral, and still the >> nose was pointed down. I kept the wings more or less level but at >> this point things seemed out of the ordinary so I got more agressive >> with the controls. I pushed forward, adding more power. The plane >> then seemed to fly, and I seemed to be going pretty fast, but I didn't >> look at the airspeed. I pulled up gently and the controls eventually >> started feeling normal again. The EFIS logs showed the whole event >> lasted less than 10 seconds--two data captures--but it sure seemed >> longer. We lost about 300 feet. >> >> I spoke to another -10 owner who has a lot of acro and formation >> experience. He said, yeah, it'll do that...he concurred that from a >> deep stall, an RV-10 requires extra effort to break it. That's >> probably not a huge surprise if you think about it and expect it, but >> in this case it gave me (and unfortunately my passengers) a little >> concern. >> >> I'd be interested to hear if others have had similar experiences, and >> if anyone has an explanation for what's going on aerodynamically. >> >> Dave Saylor >> 831-750-0284 CL > > > > ________________________________________________________________________________
Date: Mar 02, 2013
Sounds good! I'll pencil it in. Cheers, Stein Bruch President - SteinAir, Inc. 651-460-6955 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano Sent: Saturday, March 02, 2013 12:34 PM Subject: Re: RV10-List: RV-10 Stall Characteristics (what just happened here?) I was up experimenting with the stall in my 10. Mine is at the fwd cg with me alone so keep that in mind. I stalled and kept the stick full aft. The plane just buffeted and still had good aileron control. I stomped on the rudder both directions with full aft stick and the plane just mushed along. It would not enter a spin. Like I said I am close to the fwd CG. I have a video of this I'll try to post later. Sent from my iPhone On Mar 2, 2013, at 10:02, Tim Olson wrote: > > I've seen something odd like this once too. The situation was a bit > different though from the sounds of it. Would you say that the > elevator felt somewhat aerodynamically "disconnected" during this? > The experience I had, you could hear the prop pitch change as it > sounded like it quit biting the air the same, and the pitch force got > real "sloppy", like you could have pulled or pushed and not gotten a > lot of response at all. But, going into standard stall recovery mode > automatically, I shoved the stick forward and it came right out of it. > The whole thing lasted only maybe 2 seconds, but when you feel > something like that you know how time goes slowly. > At any rate, I think I was just so deep in the stall at the time that > probably the wing wash interrupted the flow over the horizontal > stabilizer, or something like that. So the elevator lost some > effectiveness. At least that's what I attributed it to. > It wasn't quite a normal flight situation for me, so I've been > thinking of some day trying to recreate it up high, but I'm not sure > if I could, without the added weight of filled seats...so I'm not sure > if I'll bother. The airplane behaved pretty well through it, so I was > happy for that. > > Tim > > > On 3/2/2013 11:35 AM, Dave Saylor wrote: >> --> >> >> Last weekend I took some folks on demo rides. All are -10 builders, >> not yet flying. >> >> On one flight, I had one big guy in the back seat. My CG range is >> 8.4 to 16.8 (inches aft of the wing leading edge). My CG on takeoff >> was 14.4--I ran the number before we departed because I knew the CG >> was "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 >> we loaded the plane at aft CG, max gross, and did some stalls. I >> don't recall anything strange at all about those maneuvers. >> >> First, I demonstrated an approach stall, which I've done many times. >> My normal recovery is just to add a little power, stick neutral if >> necessary, and the plane just flys out. On the first stall, that's >> just how it went. >> >> Of course then it was time for a little "Watch this!"... >> >> Actually, I wanted to demonstrate the AOA audio warning, >> "Angle-Angle-Push", which was kind of faint on the first stall. So I >> let the stall develop further, keeping wings level with the rudder. >> The wings rocked a bit but nothing serious. The nose stayed straight >> ahead. Then, the nose pitched WAY down. I added power to break the >> stall and fly it out but there was no change. It felt like we were >> descending, not flying. It felt like we were about 45* nose down, but >> the EFIS logs didn't capture anything that extreme. I was concerned >> about entering a spin. So was the guy in the front seat--he said so >> as it was happening...I added more power, stick neutral, and still >> the nose was pointed down. I kept the wings more or less level but >> at this point things seemed out of the ordinary so I got more >> agressive with the controls. I pushed forward, adding more power. >> The plane then seemed to fly, and I seemed to be going pretty fast, >> but I didn't look at the airspeed. I pulled up gently and the >> controls eventually started feeling normal again. The EFIS logs >> showed the whole event lasted less than 10 seconds--two data >> captures--but it sure seemed longer. We lost about 300 feet. >> >> I spoke to another -10 owner who has a lot of acro and formation >> experience. He said, yeah, it'll do that...he concurred that from a >> deep stall, an RV-10 requires extra effort to break it. That's >> probably not a huge surprise if you think about it and expect it, but >> in this case it gave me (and unfortunately my passengers) a little >> concern. >> >> I'd be interested to hear if others have had similar experiences, and >> if anyone has an explanation for what's going on aerodynamically. >> >> Dave Saylor >> 831-750-0284 CL > > > > ________________________________________________________________________________
Date: Mar 02, 2013
There's a huge difference between forward and aft cg's. Near the forward limit mine just mushes, it won't really stall. Aft limit is another story, although I've always found the stalls to be conventional. I wonder about the "stick neutral" business. Most aircraft call for some forward stick, for prompt stall recovery. You want to lower the angle of attack as quickly as possible. At low speeds it takes a pretty good control deflection to make the plane respond quickly. From a stall starting from a steep power on climb attitude, and aft cg, I definitely need some forward stick to un-stall promptly. How long were you flying? As I'm sure you know, if you start with cg near the aft limit, it will move further aft as you burn gas. (Also true that if you start near the forward limit, cg moves forward as you burn gas.) -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395431#395431 ________________________________________________________________________________
Date: Mar 02, 2013
>Would you say that the > elevator felt somewhat aerodynamically "disconnected" during this? Yep, that's how it felt. No result from pushing the stick further and further forward. > you could hear the prop pitch change as it sounded like it quit biting the air I felt that too. I added more and more power without the results I expected. Usually, adding power gives an immediate result but not in this case. The plane didn't "snap out" like it usually does, where you feel a clear difference between stalled vs. flying. It just felt less and less stalled, at some point it felt normal, but not a really clear line. Which is very different from virtually every other mode of flight. Everywhere else the plane just feels solid and predictable. I've told lots of people that it just doesn't have any bad habits. Not that I'd call this dangerous but it's good for people to be aware that some behavior isn't perfectly linear. I thought about this some more and so going back to Airplane 101, I'd expect the nose to pitch down if the Hstab quits flying. Isn't that why we have a (conservative) aft CG limit, to make sure the nose falls first in a "freefall situation? Imagine if the tail dropped...yikes. ________________________________________________________________________________
Date: Mar 02, 2013
Sean, that sounds pretty normal. I've seen that too, where if you slow down gently and just ease the stick to the stop, it sort of just mushes along and you can steer around with the rudder. If you give the stick a sharp pull for the last couple inches you might get it to break. That's what I'd call a normal RV-10 stall. Very gentle and relaxed. Dave Saylor 831-750-0284 CL On Sat, Mar 2, 2013 at 10:34 AM, Seano wrote: > > I was up experimenting with the stall in my 10. Mine is at the fwd cg with me alone so keep that in mind. I stalled and kept the stick full aft. The plane just buffeted and still had good aileron control. I stomped on the rudder both directions with full aft stick and the plane just mushed along. It would not enter a spin. Like I said I am close to the fwd CG. I have a video of this I'll try to post later. > > Sent from my iPhone > > On Mar 2, 2013, at 10:02, Tim Olson wrote: > >> >> I've seen something odd like this once too. The situation was a bit >> different though from the sounds of it. Would you say that the >> elevator felt somewhat aerodynamically "disconnected" during this? >> The experience I had, you could hear the prop pitch change as it >> sounded like it quit biting the air the same, and the pitch force >> got real "sloppy", like you could have pulled or pushed and not >> gotten a lot of response at all. But, going into standard stall >> recovery mode automatically, I shoved the stick forward and >> it came right out of it. The whole thing lasted only maybe 2 seconds, >> but when you feel something like that you know how time goes slowly. >> At any rate, I think I was just so deep in the stall at the time >> that probably the wing wash interrupted the flow over the horizontal >> stabilizer, or something like that. So the elevator lost some >> effectiveness. At least that's what I attributed it to. >> It wasn't quite a normal flight situation for me, so I've been >> thinking of some day trying to recreate it up high, but I'm not >> sure if I could, without the added weight of filled seats...so >> I'm not sure if I'll bother. The airplane behaved pretty well >> through it, so I was happy for that. >> >> Tim >> >> >> On 3/2/2013 11:35 AM, Dave Saylor wrote: >>> >>> Last weekend I took some folks on demo rides. All are -10 builders, >>> not yet flying. >>> >>> On one flight, I had one big guy in the back seat. My CG range is 8.4 >>> to 16.8 (inches aft of the wing leading edge). My CG on takeoff was >>> 14.4--I ran the number before we departed because I knew the CG was >>> "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we >>> loaded the plane at aft CG, max gross, and did some stalls. I don't >>> recall anything strange at all about those maneuvers. >>> >>> First, I demonstrated an approach stall, which I've done many times. >>> My normal recovery is just to add a little power, stick neutral if >>> necessary, and the plane just flys out. On the first stall, that's >>> just how it went. >>> >>> Of course then it was time for a little "Watch this!"... >>> >>> Actually, I wanted to demonstrate the AOA audio warning, >>> "Angle-Angle-Push", which was kind of faint on the first stall. So I >>> let the stall develop further, keeping wings level with the rudder. >>> The wings rocked a bit but nothing serious. The nose stayed straight >>> ahead. Then, the nose pitched WAY down. I added power to break the >>> stall and fly it out but there was no change. It felt like we were >>> descending, not flying. It felt like we were about 45* nose down, but >>> the EFIS logs didn't capture anything that extreme. I was concerned >>> about entering a spin. So was the guy in the front seat--he said so >>> as it was happening...I added more power, stick neutral, and still the >>> nose was pointed down. I kept the wings more or less level but at >>> this point things seemed out of the ordinary so I got more agressive >>> with the controls. I pushed forward, adding more power. The plane >>> then seemed to fly, and I seemed to be going pretty fast, but I didn't >>> look at the airspeed. I pulled up gently and the controls eventually >>> started feeling normal again. The EFIS logs showed the whole event >>> lasted less than 10 seconds--two data captures--but it sure seemed >>> longer. We lost about 300 feet. >>> >>> I spoke to another -10 owner who has a lot of acro and formation >>> experience. He said, yeah, it'll do that...he concurred that from a >>> deep stall, an RV-10 requires extra effort to break it. That's >>> probably not a huge surprise if you think about it and expect it, but >>> in this case it gave me (and unfortunately my passengers) a little >>> concern. >>> >>> I'd be interested to hear if others have had similar experiences, and >>> if anyone has an explanation for what's going on aerodynamically. >>> >>> Dave Saylor >>> 831-750-0284 CL >> >> >> >> > > ________________________________________________________________________________
Date: Mar 02, 2013
Bob, Yes, I could probably stand to move the stick forward faster, especially with aft CG. My basic philosophy until now has been to break the stall by adding power if possible. I figure that what I'm practicing is an approach stall, on final or elsewhere in the pattern, close to the ground. In that case, I want to loose as little altitude as possible so it makes sense to me to avoid very much forward stick. That goes out the window if it doesn't work, though, so I'm reevaluating what I've been taught. I wanted to stay in the stall long enough to hear the AOA through a few cycles, so I was asking for it. We'd only be flying a few minutes. CG probably hadn't changed much from takeoff. And, I took the rear passenger's word for it when I input his weight in the calculator. But he couldn't have been off by much. It seemed reasonable. I was 2+ inches forward of the aft limit, so I didn't examine the data with a microscope, but I did take the opportunity to demo the W&B program before we departed. Dave Saylor 831-750-0284 CL On Sat, Mar 2, 2013 at 12:18 PM, Bob Turner wrote: > > There's a huge difference between forward and aft cg's. Near the forward limit mine just mushes, it won't really stall. Aft limit is another story, although I've always found the stalls to be conventional. > > I wonder about the "stick neutral" business. Most aircraft call for some forward stick, for prompt stall recovery. You want to lower the angle of attack as quickly as possible. At low speeds it takes a pretty good control deflection to make the plane respond quickly. From a stall starting from a steep power on climb attitude, and aft cg, I definitely need some forward stick to un-stall promptly. > > How long were you flying? As I'm sure you know, if you start with cg near the aft limit, it will move further aft as you burn gas. (Also true that if you start near the forward limit, cg moves forward as you burn gas.) > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395431#395431 > > ________________________________________________________________________________
Date: Mar 02, 2013
Dave, were your flaps Up when this happened? Tim On Mar 2, 2013, at 2:34 PM, Dave Saylor wrote: > >> Would you say that the >> elevator felt somewhat aerodynamically "disconnected" during this? > > Yep, that's how it felt. No result from pushing the stick further and > further forward. > >> you could hear the prop pitch change as it sounded like it quit biting the air > > I felt that too. I added more and more power without the results I > expected. Usually, adding power gives an immediate result but not in > this case. > > The plane didn't "snap out" like it usually does, where you feel a > clear difference between stalled vs. flying. It just felt less and > less stalled, at some point it felt normal, but not a really clear > line. > > Which is very different from virtually every other mode of flight. > Everywhere else the plane just feels solid and predictable. I've told > lots of people that it just doesn't have any bad habits. Not that I'd > call this dangerous but it's good for people to be aware that some > behavior isn't perfectly linear. > > I thought about this some more and so going back to Airplane 101, I'd > expect the nose to pitch down if the Hstab quits flying. Isn't that > why we have a (conservative) aft CG limit, to make sure the nose falls > first in a "freefall situation? Imagine if the tail dropped...yikes. > > > ________________________________________________________________________________
Date: Mar 02, 2013
Subject: Front seat heat
Has anyone come up with a good way to have the front heat duct be able to heat the pilots side and copilots side differently? My wife is a freeze baby, and I hate being hot. I don't there there is a temperature range that we're both comfortable at. Dual zone climate control in our cars has saved my sanity! I'm guessing at the simple end of things, could I just put some eyeball vents on the ducts? Has anyone built some sort of adjustable differential airflow valve to go in place of the tee fitting? ________________________________________________________________________________
Subject: Re: Front seat heat
Date: Mar 02, 2013
My short arms could never reach eyeball vents at my feet, in flight. Sounds like what you want is a butterfly valve in the middle of the T that splits the heat. Maybe driven by an electric motor? Or duct tape covering 3/4 the opening on your side? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395443#395443 ________________________________________________________________________________
Date: Mar 02, 2013
I have an aluminum door that is adjustable on my side only. Saves me, my wif e has the same issue. Sent from my iPhone On Mar 2, 2013, at 13:20, Ed Kranz wrote: > Has anyone come up with a good way to have the front heat duct be able to h eat the pilots side and copilots side differently? My wife is a freeze baby, and I hate being hot. I don't there there is a temperature range that we're both comfortable at. Dual zone climate control in our cars has saved my san ity! > > I'm guessing at the simple end of things, could I just put some eyeball ve nts on the ducts? Has anyone built some sort of adjustable differential airf low valve to go in place of the tee fitting? > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 02, 2013
Subject: Another use for an RV-10: hauling an RV-12
We flew our RV-10 down to Oregon yesterday to become, as far as Van's employees could remember, the first ones ever to pick up an RV-12 fuselage kit and fly away with it in a -10. Great fun. Full story and pics at: http://faculty.washington.edu/dmasys/RV12inRV10.html -Dan Masys RV-10 N104LD RV-12 N122LD ________________________________________________________________________________
Date: Mar 02, 2013
I'd buy into Tim's theory - combination of low airspeed plus some blanking of the airflow by the wings could leave the elevators with little effectiveness until the rotation caused by the cg location (slower for aft cg) brought them back to normal. Prop noise change could be the inner part of the blade stalling at low forward speed. Dave, I'll bet you already apply forward pressure, as well as power, to recover from an approach stall. If you didn't, the airspeed would decay even more due to the trim feeling the prop blast and "thinking" that it's going to fast. This is one of the hardest things to teach students, that an application of power on final approach requires forward stick pressure, to avoid a loss of airspeed (in most low tail airplanes). That being said, it's probably not a bad idea to practice stalls with power off and staying off, just in case you ever find yourself without power and trying to glide just a little more than is possible. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395446#395446 ________________________________________________________________________________
Date: Mar 02, 2013
I'm working on something that may help ..... For background, my RV-10 friend said that the back seat heat blows up right behind his right shoulder while the left is cold. I'm adapting a snap-vent from aircraft Spruce so the heat can be directed. Here's where I'm at: One prototype with just a round disk, one with a 'handle'. and The tube is 2"PVC pipe that fits inside the "T" holes. the ring is a thin section of 2" pipe glued to the end ..... and no, it doesn't go all the way around. The tube needs to be about 2" long to fit the back seat heat vents. I used a 3 1/4" hole saw to cut a disk out of 1/16" plastic I had laying in my scrap bin. A 1 7/8 hole saw cuts the hole for the PVC tube. Some sanding needs to be done to fit the PVC tube. I'm planning on using the red silicone to glue the snap-vent to the plastic disk and on the PVC tube to keep it inside the vent hole. The rear can be adjusted by the back seaters .... but the front will have to be set on the ground. Similarly, plastic plugs can be inserted in the "T" holes with various size holes (think baby powder cap) to regulate the amount of air. Actually, blocking off part of the hole with metal-tape would be easier ....... Linn On 3/2/2013 4:20 PM, Ed Kranz wrote: > Has anyone come up with a good way to have the front heat duct be able > to heat the pilots side and copilots side differently? My wife is a > freeze baby, and I hate being hot. I don't there there is a > temperature range that we're both comfortable at. Dual zone climate > control in our cars has saved my sanity! > > I'm guessing at the simple end of things, could I just put some > eyeball vents on the ducts? Has anyone built some sort of adjustable > differential airflow valve to go in place of the tee fitting? > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 02, 2013
Duct tape would melt into a sticky mess but a guillotine valve would work nice. Tim On Mar 2, 2013, at 3:45 PM, "Bob Turner" wrote: > > My short arms could never reach eyeball vents at my feet, in flight. Sounds like what you want is a butterfly valve in the middle of the T that splits the heat. Maybe driven by an electric motor? > Or duct tape covering 3/4 the opening on your side? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395443#395443 > > > > > > > > > ________________________________________________________________________________
Date: Mar 02, 2013
That's what mine is. I put two shoulder bolts into nutplates. One to pivot on and one to slide down a slotted arc. The aluminum piece looks like a small pizza slice. ----- Original Message ----- From: "Tim Olson" <Tim(at)myrv10.com> Sent: Saturday, March 02, 2013 3:49 PM Subject: Re: RV10-List: Re: Front seat heat > > Duct tape would melt into a sticky mess but a guillotine valve would work > nice. > Tim > > > On Mar 2, 2013, at 3:45 PM, "Bob Turner" wrote: > >> >> My short arms could never reach eyeball vents at my feet, in flight. >> Sounds like what you want is a butterfly valve in the middle of the T >> that splits the heat. Maybe driven by an electric motor? >> Or duct tape covering 3/4 the opening on your side? >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=395443#395443 >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Mar 02, 2013
Yeah, flaps up. Dave Saylor 831-750-0284 CL On Sat, Mar 2, 2013 at 1:03 PM, Tim Olson wrote: > > Dave, were your flaps Up when this happened? > Tim > > > On Mar 2, 2013, at 2:34 PM, Dave Saylor wrote: > >> >>> Would you say that the >>> elevator felt somewhat aerodynamically "disconnected" during this? >> >> Yep, that's how it felt. No result from pushing the stick further and >> further forward. >> >>> you could hear the prop pitch change as it sounded like it quit biting the air >> >> I felt that too. I added more and more power without the results I >> expected. Usually, adding power gives an immediate result but not in >> this case. >> >> The plane didn't "snap out" like it usually does, where you feel a >> clear difference between stalled vs. flying. It just felt less and >> less stalled, at some point it felt normal, but not a really clear >> line. >> >> Which is very different from virtually every other mode of flight. >> Everywhere else the plane just feels solid and predictable. I've told >> lots of people that it just doesn't have any bad habits. Not that I'd >> call this dangerous but it's good for people to be aware that some >> behavior isn't perfectly linear. >> >> I thought about this some more and so going back to Airplane 101, I'd >> expect the nose to pitch down if the Hstab quits flying. Isn't that >> why we have a (conservative) aft CG limit, to make sure the nose falls >> first in a "freefall situation? Imagine if the tail dropped...yikes. >> >> >> > > ________________________________________________________________________________
Date: Mar 02, 2013
I think mine were too. I've never had anything strange happen when with full flaps. Tim On 3/2/2013 8:54 PM, Dave Saylor wrote: > > Yeah, flaps up. > > Dave Saylor > 831-750-0284 CL > > ________________________________________________________________________________
Subject: Re: Another use for an RV-10: hauling an RV-12
Date: Mar 03, 2013
Neat Story. On Mar 2, 2013, at 5:08 PM, Dan Masys wrote: > > We flew our RV-10 down to Oregon yesterday to become, as far as Van's employees could remember, the first ones ever to pick up an RV-12 fuselage kit and fly away with it in a -10. Great fun. Full story and pics at: http://faculty.washington.edu/dmasys/RV12inRV10.html > > -Dan Masys > RV-10 N104LD > RV-12 N122LD > > > > > > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 03, 2013
So from now on it can be claimed that this is the fastest RV-12 which on its first flight cruised at 170+ TAS. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395485#395485 ________________________________________________________________________________
Date: Mar 03, 2013
Electric Seat heaters work great. We rarely need much heated air. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395490#395490 ________________________________________________________________________________
Date: Mar 03, 2013
I practice full power, idle, flap and no flap stalls every few months with the family and xc trip loading at 3-5,000' AGL. This puts us at gross and my CG at 15.93" with full fuel. At the end of our 4.5 hr trip to Florida we were at 16.70", which made for a very touchy landing. I am pretty aggressive getting the stick very far forward on recovery and once flying nose low add power in slowly. I don't lose more than 200-300'. By myself and no flaps, I experience the same as you guys. Full aft stick with a little pitch rocking and plenty of pre-stall warning. Release pressure on stick and your flying again. Now with full flaps you don't get as much warning before the stall solo or gross. My stall buzzer goes off about 6 kts above stall. It is good for us to practice stalls often. My wife always calls my speeds on final using our D6 backup. Unless we are over the runway, she knows my min speeds of 70/75/80 KIAS(full, half, no flaps) as marked on the panel. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395494#395494 ________________________________________________________________________________
Date: Mar 03, 2013
I wouldn't discount the possible effects of air mass changes (wind). A swirl, eddy, or gust at the wrong moment can create a defacto shear over the flying surfaces. A 10 knot loss is normally no big deal, but a sudden loss of 10 knots of a wing approaching stall can have a huge effect on what that wing or tail feels at that precise moment and can affect the recovery. The slower the aircraft the more pronounced the effect will be. That is one way identical maneuvers can have different results. Think of a child's kite that flies steady then seemingly takes a plunge for no reason. Even in 150k lb aircraft, we add the gust factor of the winds to the approach target speed up to Vref +20 -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395501#395501 ________________________________________________________________________________
Date: Mar 03, 2013
Been following this thread .... not flying yet so this may be way out in left field. I wonder if the RV-10 at gross and slow ends up behind the power curve??? Linn ..... hoping to find out some day .... ________________________________________________________________________________
Date: Mar 03, 2013
Subject: front seat heat
here is what you need (scroll to last item on the page) http://www.aviacompinternational.com/connectors.html Chris Hukill ________________________________________________________________________________
Date: Mar 03, 2013
Thanks Wayne. I think what I did differently was to let the stall develop, thinking it would act about like it does at lighter weights/fwd CG. I wanted to demonstrate mushing along "sort of stalled" but it showed me "very stalled" instead. Dave Saylor 831-750-0284 CL On Sun, Mar 3, 2013 at 7:29 AM, rv10flyer wrote: > > I practice full power, idle, flap and no flap stalls every few months with the family and xc trip loading at 3-5,000' AGL. This puts us at gross and my CG at 15.93" with full fuel. At the end of our 4.5 hr trip to Florida we were at 16.70", which made for a very touchy landing. I am pretty aggressive getting the stick very far forward on recovery and once flying nose low add power in slowly. I don't lose more than 200-300'. > > By myself and no flaps, I experience the same as you guys. Full aft stick with a little pitch rocking and plenty of pre-stall warning. Release pressure on stick and your flying again. Now with full flaps you don't get as much warning before the stall solo or gross. My stall buzzer goes off about 6 kts above stall. It is good for us to practice stalls often. My wife always calls my speeds on final using our D6 backup. Unless we are over the runway, she knows my min speeds of 70/75/80 KIAS(full, half, no flaps) as marked on the panel. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 97.6 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395494#395494 > > ________________________________________________________________________________
Date: Mar 03, 2013
Good point. That could certainly be a contributing factor. The wind at the airport was kind of weird that day. We were landing on a runway that we only use about twice a year, and it was gusty. Dave Saylor 831-750-0284 CL On Sun, Mar 3, 2013 at 8:02 AM, woxofswa wrote: > > I wouldn't discount the possible effects of air mass changes (wind). > > A swirl, eddy, or gust at the wrong moment can create a defacto shear over the flying surfaces. A 10 knot loss is normally no big deal, but a sudden loss of 10 knots of a wing approaching stall can have a huge effect on what that wing or tail feels at that precise moment and can affect the recovery. The slower the aircraft the more pronounced the effect will be. That is one way identical maneuvers can have different results. > > Think of a child's kite that flies steady then seemingly takes a plunge for no reason. > > Even in 150k lb aircraft, we add the gust factor of the winds to the approach target speed up to Vref +20 > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395501#395501 > > ________________________________________________________________________________
Subject: Re: front seat heat
Date: Mar 03, 2013
Nice find Chris! I bet this would work great. I would have bought this if it was available when I was building. ----- Original Message ----- From: <cjhukill(at)cox.net> Sent: Sunday, March 03, 2013 10:31 AM Subject: RV10-List: front seat heat > > > here is what you need (scroll to last item on the page) > http://www.aviacompinternational.com/connectors.html > Chris Hukill > > > ________________________________________________________________________________
Date: Mar 03, 2013
I have both seat heat and seat cooling in mine. Both work Great. If you balance the rear and front heat vents you can control the temperature very easily. Its a GREAT airplane I like it better than my Mooney Bravo ------Original Message------ From: Seano Sender: owner-rv10-list-server(at)matronics.com ReplyTo: rv10-list(at)matronics.com Subject: Re: RV10-List: front seat heat Sent: Mar 3, 2013 10:41 AM Nice find Chris! I bet this would work great. I would have bought this if it was available when I was building. ----- Original Message ----- From: <cjhukill(at)cox.net> Sent: Sunday, March 03, 2013 10:31 AM Subject: RV10-List: front seat heat > > > here is what you need (scroll to last item on the page) > http://www.aviacompinternational.com/connectors.html > Chris Hukill > > > Sent from my Verizon Wireless BlackBerry ________________________________________________________________________________
Subject: go pro mounts
Date: Mar 03, 2013
If anyone is interested let me know. I may start making more. I have this style of mount which can be used on the wing tie-downs or tail tie-down. I also have a fuel cap mount I'm still testing which can move any direction before flight by simply turning the cap. attached is a pic of the tie down mount. It is made of steel. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395516#395516 Attachments: http://forums.matronics.com//files/goprp_mount_771.jpg ________________________________________________________________________________
Date: Mar 03, 2013
Linn, my understanding of "behind the power curve" is far from intuitive...I have to really think about what that means and how it applies. I can say that power was off and the stall speed was around 65 knots. My understanding is that at low speed and high power, the stall can be delayed by propwash over the wing. That wouldn't have been the case until I tried to recover since I wasn't really carrying any power into the stall. If I understand being behind the curve, it's more a function of decision making than of airframe design, that is, the plane may or may not be behind the curve in a given configuration. It depends on what the pilot does, either intentionally or not. I'm pretty sure we weren't behind the curve. Sure would be interesting to hear how the 10 behaves behind the curve--new thread anyone? Dave Saylor 831-750-0284 CL On Sun, Mar 3, 2013 at 8:54 AM, Linn wrote: > > Been following this thread .... not flying yet so this may be way out in > left field. > I wonder if the RV-10 at gross and slow ends up behind the power curve??? > Linn ..... hoping to find out some day .... > > ________________________________________________________________________________
Date: Mar 03, 2013
flying-nut(at)cfl.rr.com wrote: > Been following this thread .... not flying yet so this may be way out in > left field. > I wonder if the RV-10 at gross and slow ends up behind the power curve??? > Linn ..... hoping to find out some day .... With power at idle, prop at fine pitch you can really feel and see your descent increase once below 70 KIAS at gross with full flaps. Hence, we try to never get below 70 KIAS on a steep/no power approach, which is the way we come in 75% of the time. Timing your flare is very critical at 1,200-1,500 fpm descent! No slipping needed so far in the -10, as you have a lot of runway in the windshield already. Slipping does not increase your descent rate like it did in 172's. I have had a few pilots say after landing that they had never came in so steep before. We are not initially trained this way for a reason, but I always prepare for that day when I have to come in steep without power. Initially in transition training and Phase 1, I approached with a little power in and a normal 3* glide slope which gave me more time in the flare. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395519#395519 ________________________________________________________________________________
Date: Mar 03, 2013
Any idea on price for the tie down mount? Bill -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts Sent: Sunday, March 03, 2013 12:59 PM Subject: RV10-List: go pro mounts If anyone is interested let me know. I may start making more. I have this style of mount which can be used on the wing tie-downs or tail tie-down. I also have a fuel cap mount I'm still testing which can move any direction before flight by simply turning the cap. attached is a pic of the tie down mount. It is made of steel. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395516#395516 Attachments: http://forums.matronics.com//files/goprp_mount_771.jpg ________________________________________________________________________________
Date: Mar 03, 2013
What I learn by doing no power, steep, full gross, full flap approaches behind the power curve is...if I want to descend faster pull back on the stick and if I want to descend slower push forward on the stick(area of reverse command). There is a slight lag, but by practicing this it may prevent us from "pulling" away from the earth at low altitude with no power. If you get slow on final, correct it immediately by pushing with no delay. If you get too low, you won't have time for gravity to help you. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395524#395524 ________________________________________________________________________________
Subject: Re: go pro mounts
Date: Mar 03, 2013
Not sure without knowing how many are interested. I'm suspecting around 25 bucks. Sent from my iPhone On Mar 3, 2013, at 10:25, "William Greenley" wrote: > > Any idea on price for the tie down mount? > Bill > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Strasnuts > Sent: Sunday, March 03, 2013 12:59 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: go pro mounts > > > If anyone is interested let me know. I may start making more. I have this > style of mount which can be used on the wing tie-downs or tail tie-down. I > also have a fuel cap mount I'm still testing which can move any direction > before flight by simply turning the cap. attached is a pic of the tie down > mount. It is made of steel. > > -------- > 40936 > RV-10 SB N801VR Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395516#395516 > > > > > Attachments: > > http://forums.matronics.com//files/goprp_mount_771.jpg > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 03, 2013
All my approaches to landing (final) are steep. Doesn't matter if I'm in my Pitts, Cherokee, or the Traumahawk. I wish the Pitts had flaps like the Pipers!!! For me it's an energy management issue. If you drag an airplane into the runway the energy vector is long down the runway. In a steep approach the energy vector down the runway is way shorter. True, it takes more finesse that way so your hangar mates won't talk about your landing, but you won't use your brakes as much or use a lot of runway ..... good if you have to taxi-back to an intersection. Linn On 3/3/2013 1:15 PM, rv10flyer wrote: > > > flying-nut(at)cfl.rr.com wrote: >> Been following this thread .... not flying yet so this may be way out in >> left field. >> I wonder if the RV-10 at gross and slow ends up behind the power curve??? >> Linn ..... hoping to find out some day .... > > With power at idle, prop at fine pitch you can really feel and see your descent increase once below 70 KIAS at gross with full flaps. Hence, we try to never get below 70 KIAS on a steep/no power approach, which is the way we come in 75% of the time. Timing your flare is very critical at 1,200-1,500 fpm descent! No slipping needed so far in the -10, as you have a lot of runway in the windshield already. Slipping does not increase your descent rate like it did in 172's. I have had a few pilots say after landing that they had never came in so steep before. We are not initially trained this way for a reason, but I always prepare for that day when I have to come in steep without power. > > Initially in transition training and Phase 1, I approached with a little power in and a normal 3* glide slope which gave me more time in the flare. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 97.6 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395519#395519 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Mar 03, 2013
I'm planning heated seats, and have been playing around with the idea of cooled seats. What did you use? I know there are a few different kits out there. On Sun, Mar 3, 2013 at 11:56 AM, wrote: > > I have both seat heat and seat cooling in mine. Both work Great. If you > balance the rear and front heat vents you can control the temperature very > easily. Its a GREAT airplane I like it better than my Mooney Bravo > ------Original Message------ > From: Seano > Sender: owner-rv10-list-server(at)matronics.com > To: rv10-list(at)matronics.com > ReplyTo: rv10-list(at)matronics.com > Subject: Re: RV10-List: front seat heat > Sent: Mar 3, 2013 10:41 AM > > > Nice find Chris! I bet this would work great. I would have bought this if > it was available when I was building. > > > ----- Original Message ----- > From: <cjhukill(at)cox.net> > To: > Sent: Sunday, March 03, 2013 10:31 AM > Subject: RV10-List: front seat heat > > > > > > > > here is what you need (scroll to last item on the page) > > http://www.aviacompinternational.com/connectors.html > > Chris Hukill > > > > > > > > > > > Sent from my Verizon Wireless BlackBerry > > ________________________________________________________________________________
Date: Mar 03, 2013
U2VhdGNvb2xlcnMuY29tIEkgcHVyY2hhc2VkIHRoZW0gYSBmZXcgeWVhcnMgYWdvLiA3NSBlYWNo Pz9vciBzby4NCkxpa2UgSSBzYWlkIHRoZXkgZG8gd29yay4uLg0KDQpTZW50IGZyb20gbXkgVmVy aXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tDQpG cm9tOiBFZCBLcmFueiA8ZWQua3JhbnpAZ21haWwuY29tPg0KU2VuZGVyOiBvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20NCkRhdGU6IFN1biwgMyBNYXIgMjAxMyAxNTo0Mzo0NiAN ClRvOiA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpSZXBseS1UbzogcnYxMC1saXN0QG1hdHJv bmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IGZyb250IHNlYXQgaGVhdA0KDQpJJ20g cGxhbm5pbmcgaGVhdGVkIHNlYXRzLCBhbmQgaGF2ZSBiZWVuIHBsYXlpbmcgYXJvdW5kIHdpdGgg dGhlIGlkZWEgb2YNCmNvb2xlZCBzZWF0cy4gV2hhdCBkaWQgeW91IHVzZT8gSSBrbm93IHRoZXJl IGFyZSBhIGZldyBkaWZmZXJlbnQga2l0cyBvdXQNCnRoZXJlLg0KDQoNCk9uIFN1biwgTWFyIDMs IDIwMTMgYXQgMTE6NTYgQU0sIDxqaW1AamltdmlsbGFuaS5jb20+IHdyb3RlOg0KDQo+IC0tPiBS VjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6IGppbUBqaW12aWxsYW5pLmNvbQ0KPg0KPiBJIGhh dmUgYm90aCBzZWF0IGhlYXQgYW5kIHNlYXQgY29vbGluZyBpbiBtaW5lLiBCb3RoIHdvcmsgR3Jl YXQuIElmIHlvdQ0KPiBiYWxhbmNlIHRoZSByZWFyIGFuZCBmcm9udCBoZWF0IHZlbnRzIHlvdSBj YW4gY29udHJvbCB0aGUgdGVtcGVyYXR1cmUgdmVyeQ0KPiBlYXNpbHkuIEl0cyBhIEdSRUFUIGFp cnBsYW5lIEkgbGlrZSBpdCBiZXR0ZXIgdGhhbiBteSBNb29uZXkgQnJhdm8NCj4gLS0tLS0tT3Jp Z2luYWwgTWVzc2FnZS0tLS0tLQ0KPiBGcm9tOiBTZWFubw0KPiBTZW5kZXI6IG93bmVyLXJ2MTAt bGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbQ0KPiBUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20N Cj4gUmVwbHlUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NCj4gU3ViamVjdDogUmU6IFJWMTAt TGlzdDogZnJvbnQgc2VhdCBoZWF0DQo+IFNlbnQ6IE1hciAzLCAyMDEzIDEwOjQxIEFNDQo+DQo+ IC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJTZWFubyIgPHNlYW5AYnJhdW5hbmRj by5jb20+DQo+DQo+IE5pY2UgZmluZCBDaHJpcyEgIEkgYmV0IHRoaXMgd291bGQgd29yayBncmVh dC4gIEkgd291bGQgaGF2ZSBib3VnaHQgdGhpcyBpZg0KPiBpdCB3YXMgYXZhaWxhYmxlIHdoZW4g SSB3YXMgYnVpbGRpbmcuDQo+DQo+DQo+IC0tLS0tIE9yaWdpbmFsIE1lc3NhZ2UgLS0tLS0NCj4g RnJvbTogPGNqaHVraWxsQGNveC5uZXQ+DQo+IFRvOiA8cnYxMC1saXN0QG1hdHJvbmljcy5jb20+ DQo+IFNlbnQ6IFN1bmRheSwgTWFyY2ggMDMsIDIwMTMgMTA6MzEgQU0NCj4gU3ViamVjdDogUlYx MC1MaXN0OiBmcm9udCBzZWF0IGhlYXQNCj4NCj4NCj4gPiAtLT4gUlYxMC1MaXN0IG1lc3NhZ2Ug cG9zdGVkIGJ5OiA8Y2podWtpbGxAY294Lm5ldD4NCj4gPg0KPiA+DQo+ID4gaGVyZSBpcyB3aGF0 IHlvdSBuZWVkIChzY3JvbGwgdG8gbGFzdCBpdGVtIG9uIHRoZSBwYWdlKQ0KPiA+IGh0dHA6Ly93 d3cuYXZpYWNvbXBpbnRlcm5hdGlvbmFsLmNvbS9jb25uZWN0b3JzLmh0bWwNCj4gPiBDaHJpcyBI dWtpbGwNCj4gPg0KPiA+DQo+ID4NCj4gPg0KPg0KPg0KPg0KPg0KPg0KPg0KPiBTZW50IGZyb20g bXkgVmVyaXpvbiBXaXJlbGVzcyBCbGFja0JlcnJ5DQo+DQo+DQo+DQo+DQo+DQo+DQoNCg= ________________________________________________________________________________
Date: Mar 03, 2013
I'm interested Dave Bowman 40831 N831DB Flying -----Original Message----- From: Strasnuts Sent: Sunday, March 03, 2013 9:58 AM Subject: RV10-List: go pro mounts If anyone is interested let me know. I may start making more. I have this style of mount which can be used on the wing tie-downs or tail tie-down. I also have a fuel cap mount I'm still testing which can move any direction before flight by simply turning the cap. attached is a pic of the tie down mount. It is made of steel. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395516#395516 Attachments: http://forums.matronics.com//files/goprp_mount_771.jpg ________________________________________________________________________________
Date: Mar 03, 2013
Thanks for the interest. I'll make a batch and let you know when they are available. I'm going to make them out of Stainless so they won't rust. I'll post my video I made going to Baja Mexico and landing on the beach and some dirt runways. The camera is really fun. ----- Original Message ----- From: "Dave Bowman" <davidbowman1(at)verizon.net> Sent: Sunday, March 03, 2013 5:07 PM Subject: Re: RV10-List: go pro mounts > > I'm interested > Dave Bowman > 40831 > N831DB Flying > > -----Original Message----- > From: Strasnuts > Sent: Sunday, March 03, 2013 9:58 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: go pro mounts > > > If anyone is interested let me know. I may start making more. I have > this style of mount which can be used on the wing tie-downs or tail > tie-down. I also have a fuel cap mount I'm still testing which can move > any direction before flight by simply turning the cap. attached is a pic > of the tie down mount. It is made of steel. > > -------- > 40936 > RV-10 SB N801VR Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395516#395516 > > > Attachments: > > http://forums.matronics.com//files/goprp_mount_771.jpg > > > ________________________________________________________________________________
Date: Mar 03, 2013
Speaking of GoPro, I am about to purchase a vid cam for inside the cockpit. I've been researching the GoPro and also the NflightCam. http://www.sportys.com/Pilotshop/product/16638 The thing I like about the nflightcam is the special lens which reduces the prop blur effect. Has anyone tried both? If so, plus and minus? Thanks, -Sean #40303 On 3/3/13 6:07 PM, Dave Bowman wrote: > > I'm interested > Dave Bowman > 40831 > N831DB Flying > > -----Original Message----- From: Strasnuts > Sent: Sunday, March 03, 2013 9:58 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: go pro mounts > > > If anyone is interested let me know. I may start making more. I have > this style of mount which can be used on the wing tie-downs or tail > tie-down. I also have a fuel cap mount I'm still testing which can > move any direction before flight by simply turning the cap. attached > is a pic of the tie down mount. It is made of steel. > > -------- > 40936 > RV-10 SB N801VR Flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395516#395516 > > > Attachments: > > http://forums.matronics.com//files/goprp_mount_771.jpg > > ________________________________________________________________________________
Subject: Re: RV-10 Stall Characteristics (what just happened here?)
Date: Mar 03, 2013
Being "behind the power curve" means that you are flying slower than minimum sink speed. If you plot the power required to maintain level, unaccelerated flight, it is U shaped, sort of. The bottom, minimum point is the speed at which you will have minimum sink in a power out situation. (It is not best glide speed). In many light aircraft minimum sink speed is just a little faster than stall speed. Let's say it's 65 kias. Then to fly straight and level at 64 kias takes more, not less, power than at 65 kias. Flying straight and level at 63 kias requires even more power. For this reason this region is also called the "region of reverse command". In a power off glide, as already pointed out, once you are below minimum sink, a lower speed results in an increased vertical descent rate (since it requires more power which in this case is coming from gravity). In high density altitude takeoffs (limited engine power) pilots sometimes get into trouble by lifting off at too low an airspeed. e.g., they lift off at 60 kias and climb in ground effect to 30 ft agl. They then find themselves in a situation where they are using every bit of power they have to just maintain level flight. If they had instead lifted off at 65 kias they would find they needed less power to maintain that same level flight at 30 ft agl, and could use the excess power to accelerate or climb. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395563#395563 ________________________________________________________________________________
Date: Mar 03, 2013
I used UL 181 aluminum foil tape rated at 260F. Simple, out of sight and works great. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395564#395564 ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 03, 2013
Subject: Behind the curve, was RV-10 Stall Characteristics
Am I correct in relating minimum sink to best angle? And best glide distance to best rate? Or is it the other way around, or just nonsense? FWIW, I use about 80 KIAS for best angle, and I see about 95 for best rate. I usually try to use the AOA for best glide, though, at the split bar. Are other people seeing very different numbers? Then basically, at some point on the approach are we almost certainly behind the power curve? My understanding has been that it meant you were "dragging it in", using a lot of power and still sinking, and that if you pulled the power off without lowering the nose, you'd stall. Maybe I'm stating the obvious... Dave Saylor 831-750-0284 CL On Sun, Mar 3, 2013 at 5:29 PM, Bob Turner wrote: > > Being "behind the power curve" means that you are flying slower than minimum sink speed. If you plot the power required to maintain level, unaccelerated flight, it is U shaped, sort of. The bottom, minimum point is the speed at which you will have minimum sink in a power out situation. (It is not best glide speed). In many light aircraft minimum sink speed is just a little faster than stall speed. Let's say it's 65 kias. Then to fly straight and level at 64 kias takes more, not less, power than at 65 kias. Flying straight and level at 63 kias requires even more power. For this reason this region is also called the "region of reverse command". In a power off glide, as already pointed out, once you are below minimum sink, a lower speed results in an increased vertical descent rate (since it requires more power which in this case is coming from gravity). In high density altitude takeoffs (limited engine power) pilots sometimes get into trouble by lifting off at too low an airsp! > eed. e.g., they lift off at 60 kias and climb in ground effect to 30 ft agl. They then find themselves in a situation where they are using every bit of power they have to just maintain level flight. If they had instead lifted off at 65 kias they would find they needed less power to maintain that same level flight at 30 ft agl, and could use the excess power to accelerate or climb. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395563#395563 > > ________________________________________________________________________________
Date: Mar 04, 2013
Hay Sean (303), I have been playing with these cams for some time. I don't have experience with all of the cameras but I do have time with most form factors. While th e NFCam is a nice unit I do suggest you give the GoPro strong consideration for a number of reasons. First the new GoPro is a wonderful design and ver y good quality. GoPro has built a really good platform including the abilit y to link a couple of units for both 3D and 4K filming. If you don't know w hat 4K<http://en.wikipedia.org/wiki/4K_resolution> is you will in a few yea rs. I have been in conversations with a fellow doing some amazing air foota ge from his Velocity with something like 11 GoPro cams mounted to his bird. The images are amazing. The waterproof housing and apple/android integrati on are also a bonus. Throw in the best remote of all the cameras and you ha ve a pretty compelling package. Plus much like the RV list there is a GoPro community that is unmatched by any other action camera company. Another advantage to GoPro is one of the owners of FoxConn (where you cell phone was probably made) just dropped $200 MM<http://www.forbes.com/sites/r yanmac/2012/12/20/foxconn-buys-stake-in-camera-maker-gopro-turning-founder- into-a-billionaire/> into GoPro for 8% of the company valuing it at over a billion dollars. That means the GoPro eco system is probably only going to get more robust. I was just in FL on a wave runner doing a self-tape movie through a ski sla lom course. I used the chest mount, head mount, reversed the chest mount fo r a trailing video. Held the cam very close to the waterline fore & aft for a cool speed effect. Not too many action cam's would be comfortable or saf e in that environment. It was no problem with the GP. Ultra easy to use wit h the waterproof housing. 1080P 48 FPS video looks pure! I am part way thro ugh editing and the video could be used in a theater setting. Good luck, Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Sean Stephens Sent: Sunday, March 03, 2013 5:09 PM Subject: Re: RV10-List: go pro mounts to:sean(at)stephensville.com>> Speaking of GoPro, I am about to purchase a vid cam for inside the cockpit. I've been researching the GoPro and also the NflightCam. http://www.sportys.com/Pilotshop/product/16638 The thing I like about the nflightcam is the special lens which reduces the prop blur effect. Has anyone tried both? If so, plus and minus? Thanks, -Sean #40303 On 3/3/13 6:07 PM, Dave Bowman wrote: > --> > > > I'm interested > Dave Bowman > 40831 > N831DB Flying > > -----Original Message----- From: Strasnuts > Sent: Sunday, March 03, 2013 9:58 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: go pro mounts > sean(at)braunandco.com>> > > If anyone is interested let me know. I may start making more. I have > this style of mount which can be used on the wing tie-downs or tail > tie-down. I also have a fuel cap mount I'm still testing which can > move any direction before flight by simply turning the cap. attached > is a pic of the tie down mount. It is made of steel. > > -------- > 40936 > RV-10 SB N801VR Flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=395516#395516 > > > > > Attachments: > > http://forums.matronics.com//files/goprp_mount_771.jpg onics.com/files/goprp_mount_771.jpg> > > > > > > > > > > ----- No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Subject: Re: Behind the curve, was RV-10 Stall Characteristics
Date: Mar 03, 2013
In an ideal airplane best rate of climb speed would be the same as minimum sink speed. But real props, even CS props, can only be optimized at one speed, and that is nearly always cruise speed. The result is that as airspeed increases from 60 to 70 to 80 to 90 .... knots the prop efficiency is increasing, and by quite a bit. The increase of prop efficiency pushes Vy to much larger values than minimum sink. Graphically you would plot power available (basically 260 HP times the prop efficiency) on top of power required. Vy is where the difference between the two curves is a maximum. Maximum level speed is where the curves cross, on the right. It is unlikely you get behind the power curve on a typical approach prior to the flare. Minimum sink for an ideal airplane is 0.77 (actually the fourth root of one third) times best glide, typically just a bit higher than stall speed. But if you drag it in just a few knots above stall, then yes. If you want to know exactly, just fly straight and level at 70, 69, 68, etc knots, and note the power setting needed. When the power required starts going up, you're on the back side. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395568#395568 ________________________________________________________________________________
Date: Mar 04, 2013
All, one of the best books around to explain all of this is "Aerodynamic for Naval Aviators". The book is available for free download on the FAA's web site at the address below. Actually they have a number of free books with good info, check out: http://www.faa.gov/regulations_policies/handbooks_manuals/aviation/ http://www.faa.gov/regulations_policies/handbooks_manuals/aviation/media/00-80T-80.pdf Since nearly every build eventually becomes a test pilot it is a good idea to understand the basics. Please know that below is my interpretation of behind the curve, I do not have formal training in aerodynamics but I did stay at a Holiday Inn Express. If you look at page 42 of the PDF (book page 24) you see a plot of the coefficient of lift (CL) relative to the angle of attack (AOA). At the top of the curve the AOA increases while the CL decreases up until the wing stalls. This is one aspect of 'behind the curve'. The second aspect of 'behind the curve' is found on pages 46 & 47 of the PDF (book pages 28 & 29), where they talk about the drag coefficient (CD) relative to lift (L/D). This says that as the AOA is increased the CD will increase. The AOA which yields the best L/D is called L/D Max (the most lift for the least drag), at AOAs greater than what produces L/D Max you are using more AOA to produce less lift with more drag until stall. The powerplant (gravity or Lycoming) needs to provide extra power to overcome the extra drag to produce lift. You will notice that everything refers to angle of attack and not airspeed as a wing will always act the same at a certain angle of attack, not true with airspeed. Which is one reason why AOA indicators are such neat tools; they help you know where the edge is rather than trying to predict the edge based on airspeed combined with other factors. One last point from page 46 of the PDF (28 of the book) notice the differences in shapes of the curves for different airfoils. Some of the curves have fairly flat backsides (NACA 63-006), while some have dramatic drop offs (NACA 63-009). The flat backs are typical of training aircraft where the back side of the curve wasnt as bad. Our RVs have steeper backsides as a result of the tradeoffs made to get a good high speed wing with low stall speeds. This is something that gets new RV pilots sometimes when they get on the backside, they are not as used to how much power it can take to correct a fast sink, remember that power can come from Lycoming or gravity, push the throttle or the stick, but it has got to happen quicker and more aggressively than that trainer we all got used to. I do not have a plot for the RV-10 sorry. Feel free to correct me on this, as I said I do not have formal training in this area of engineering. Beyond that please take some time to investigate this for yourselves, you may learn something, or at very least find a cure to insomnia. Above all please continue to share with the group things that surprised you, I have not experienced this one first hand, but I remember when a slip nearly got me (see the archives). Thanks Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395586#395586 ________________________________________________________________________________
From: "Richard Barnes" <rickbarnes(at)highlanddental.com>
Date: Mar 04, 2013
Robin, I particularly like the 4K Panasonic playback monitor for $500,000.00. Rick From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, March 03, 2013 8:52 PM Subject: RE: RV10-List: go pro mounts Hay Sean (303), I have been playing with these cams for some time. I don't have experience with all of the cameras but I do have time with most form factors. While the NFCam is a nice unit I do suggest you give the GoPro strong consideration for a number of reasons. First the new GoPro is a wonderful design and very good quality. GoPro has built a really good platform including the ability to link a couple of units for both 3D and 4K filming. If you don't know what 4K <http://en.wikipedia.org/wiki/4K_resolution> is you will in a few years. I have been in conversations with a fellow doing some amazing air footage from his Velocity with something like 11 GoPro cams mounted to his bird. The images are amazing. The waterproof housing and apple/android integration are also a bonus. Throw in the best remote of all the cameras and you have a pretty compelling package. Plus much like the RV list there is a GoPro community that is unmatched by any other action camera company. Another advantage to GoPro is one of the owners of FoxConn (where you cell phone was probably made) just dropped $200 MM <http://www.forbes.com/sites/ryanmac/2012/12/20/foxconn-buys-stake-in-camera -maker-gopro-turning-founder-into-a-billionaire/> into GoPro for 8% of the company valuing it at over a billion dollars. That means the GoPro eco system is probably only going to get more robust. I was just in FL on a wave runner doing a self-tape movie through a ski slalom course. I used the chest mount, head mount, reversed the chest mount for a trailing video. Held the cam very close to the waterline fore & aft for a cool speed effect. Not too many action cam's would be comfortable or safe in that environment. It was no problem with the GP. Ultra easy to use with the waterproof housing. 1080P 48 FPS video looks pure! I am part way through editing and the video could be used in a theater setting. Good luck, Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Sunday, March 03, 2013 5:09 PM Subject: Re: RV10-List: go pro mounts sean(at)stephensville.com> Speaking of GoPro, I am about to purchase a vid cam for inside the cockpit. I've been researching the GoPro and also the NflightCam. <http://www.sportys.com/Pilotshop/product/16638> http://www.sportys.com/Pilotshop/product/16638 The thing I like about the nflightcam is the special lens which reduces the prop blur effect. Has anyone tried both? If so, plus and minus? Thanks, -Sean #40303 On 3/3/13 6:07 PM, Dave Bowman wrote: > --> < davidbowman1(at)verizon.net> > > I'm interested > Dave Bowman > 40831 > N831DB Flying > > -----Original Message----- From: Strasnuts > Sent: Sunday, March 03, 2013 9:58 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: go pro mounts > sean(at)braunandco.com> > > If anyone is interested let me know. I may start making more. I have > this style of mount which can be used on the wing tie-downs or tail > tie-down. I also have a fuel cap mount I'm still testing which can > move any direction before flight by simply turning the cap. attached > is a pic of the tie down mount. It is made of steel. > > -------- > 40936 > RV-10 SB N801VR Flying > > > > > Read this topic online here: > > <http://forums.matronics.com/viewtopic.php?p=395516#395516> http://forums.matronics.com/viewtopic.php?p=395516#395516 > > > > > Attachments: > > <http://forums.matronics.com/files/goprp_mount_771.jpg> http://forums.matronics.com//files/goprp_mount_771.jpg > > > > > > > > > > =================== bsp; - The RV10-List Email Forum - nd much much more: tronics.com/Navigator?RV10-List"> http://www.matronics.com/Navigator?RV10-List =================== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com">http://forums.matronics.com =================== bsp; - List Contribution Web Site - o:p> bsp; -Matt Dralle, List Admin. tronics.com/contribution"> http://www.matronics.com/contribution =================== ----- No virus found in this message. Checked by AVG - <http://www.avg.com> www.avg.com - Release Date: 03/03/13 ________________________________________________________________________________
Subject: Certifying the RV-10
Date: Mar 04, 2013
An one sided debate on certifying the RV-10 on the red board. http://forums.aopa.org/showthread.php?t=86327 Some of the responses are pretty comical and truly uninformed. bob -------- Bob Leffler N410BL - Paint - 90% done, 90% to go stage RV-10 #40684 http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395611#395611 ________________________________________________________________________________
Subject: Composites for RV-10s Class
Date: Mar 04, 2013
Hello all This is a brief note to publicly thank the guys from Aircrafters, in Watsonville - CA, to where I travelled several thousand miles to attend their class on Composites for the RV-10. It was time and money well spent, I learned a lot of tips that will help me to do a much better job with the fiberglass parts (and there are plenty.). I also met a bunch of fellow homebuilders, we exchanged experiences and some ideas, not only on the FB subject itself. Thank you Dave Saylor and Tim Farrell Best Carlos Trigo P.S. - ah, well, and also had the opportunity to have a demo flight on Dave's -10. Thanks Dave Pretty fun and very useful stay at Watsonville. ________________________________________________________________________________
Date: Mar 04, 2013
Jason, since you said it's okay to offer some corrections... One of the hardest concepts for physics students to grasp is that when they're holding a big rock in front of them, they are in fact doing no work (in the physics sense), since work (also called energy) requires a force acting through a distance. Power (which is energy per second) cannot be directly compared to lift or drag, which are forces. So L/D max (I find it easiest to think of the lift fixed at the airplane's weight, and the drag varying) is where the least force is required to keep the airplane in unaccelerated flight. But it is not where the least power is required, because at slightly lower speeds the force is slightly greater, but the distance per time (speed) is lower, and the product of the two (power) is less. So you end up with minimum sink (minimum power required) speed being less than best glide speed. Remember best glide is not an attempt to minimize power, but rather to maximize the ratio of forward distance traveled over vertical distance lost. In some ways comparable to the fact that maximum range speed is higher than maximum endurance speed. So you don't get behind the power curve (the region where it takes more power to maintain level flight as you go slower) until you are slower than minimum sink speed, which, as I said, is 0.76 (fourth root of 1/3) slower than best L/D speed for an ideal plane. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395619#395619 ________________________________________________________________________________
Date: Mar 04, 2013
Thanks Bob - let me say this a bit differently, maybe we are saying the same thing. As you reduce power to slow down and increase AOA to maintain level flight you will continue to reduce drag, at some point (L/D Max) the drag will again start to increase, which is the point you have moved to the backside of the curve. You will need further increase AOA and increase power to maintain level flight, until you slow to a speed where maximum AOA is reached and the wing stalls regardless of power setting. Important to note the distinction, before reaching L/D Max you can decrease power, increase AOA and maintain altitude, after passing L/D Max you will need to increase power and AOA to hold altitude. The higher power setting is required to offset the increased drag. In order to get out of the stall we need to reduce the AOA either by adding enough power to overcome the drag plus the power needed to alter the relative wind (AOA), or by pushing the nose over to alter the relative wind (AOA) ideally both. Question on the formula you sight, is that good for all types of airplanes, or is the number different for say a Cessna versus a Cirrus? Either way thanks for the feedback, and by all means let me (and the group know) if I still dont get it, I am not sure I fully understand you distinction between power and force as it applies here, from a theoretical standpoint I understand perfectly. I guess when I say power I am referring to engine settings, maybe not the best form. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395625#395625 ________________________________________________________________________________
Date: Mar 04, 2013
Jason, not quite right yet. Power is calculated by multiplying the force times the velocity. I know it is not intuitive but you can get away with less power by slowing down, even though the drag force goes up. To make up numbers for the airplane, suppose at best L/D the force required to overcome the drag is 100 lbs, and the speed is 80 knots. The power required is 8000 (in some strange units). Now if you slow to 70 knots, the drag is up to, say 110 lbs. But the power required is lower, 7700 (same strange units), than it was at best L/D, because while the drag force went up, it went up more slowly than the speed went down. As you go still slower, the rate of increase of drag gets larger, and eventually it goes up faster than speed goes down. That's minimum sink speed, and slower than that you have the strange phenomenon that level flight requires more power if you want to go even slower. BTW, as speed goes to zero power required goes to infinity, not zero, because the drag goes to infinity "faster" than the speed goes to zero. The usual ideal airplane model approximations are: parasitic drag proportional to v squared; wing lift proportional to angle of attack and v squared, and equal to weight, induced drag equal to angle of attack times weight which makes induced drag proportional to one divided by v squared. When you multiply the force (drag) by v to get power you end up with terms that are proportional to v cubed and 1/v. When you solve this equation you'll end up with v to the fourth, that's where the fourth root comes from. When you differentiate the v cubed term (to find the minimum) it becomes 3 v squared; that's where the 3 comes from. Minimum sink is fourth root of 1/3 times best glide. This is all a lot simpler if you can find graphs of "Power required" and "power available (including prop efficiency)". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395627#395627 ________________________________________________________________________________
Date: Mar 04, 2013
Another mount we made and worked great. You can just turn your fuel cap to view the fuse. I may make this as a one piece unit to replace the top of the cap instead of Drilling and tapping your cap like I did. -------- 40936 RV-10 SB N801VR Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395655#395655 Attachments: http://forums.matronics.com//files/photo_3_214.jpg http://forums.matronics.com//files/photo_1_113.jpg http://forums.matronics.com//files/photo_4_165.jpg http://forums.matronics.com//files/photo_2_152.jpg ________________________________________________________________________________
Date: Mar 04, 2013
Have a look at the Naval Aviators Handbook starting on page 353 - they explain operating on the backside of the curve (region of reverse command). They reference power as thrust. You are going a bit further and talking about energy management. Thanks for your help in understanding this Bob - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395657#395657 ________________________________________________________________________________
Date: Mar 04, 2013
Yes, that's a good reference. Look at the graph of power required at the bottom of page 98. It shows how minimum power occurs at a lower speed than max L/D, and in fact is about 0.8 less. This reference frequently mixes turbojet engines with propeller driving engines. There are some important differences, explained around page 96 and following. Turbojets tend to put out constant thrust regardless of speed ( and so put out more power at higher speeds), while our internal combustion engines put out constant power, not changing with speed (actually we can get a small amount of extra power at higher speeds due to ram air pushing the manifold pressure up a bit). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395660#395660 ________________________________________________________________________________
Subject: Re: RV-10 down
Date: Mar 04, 2013
http://www.aviationinspector.com/?p=13785 -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 97.6 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395662#395662 ________________________________________________________________________________
Date: Mar 06, 2013
Subject: control stick bushing
Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Mar 06, 2013
Subject: Re: control stick bushing
Its a brass bushing about 3" long and comes in the kit. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Rick Lark" <larkrv10(at)gmail.com> Sent: Wednesday, March 6, 2013 11:32:45 AM Subject: RV10-List: control stick bushing Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 ________________________________________________________________________________
Date: Mar 06, 2013
I just replaced mine. I was sick of the play and machined a Delrin bushing. No play and smoother feel. The bushing ID was too small for my OD using the brass bushing supplied in the kit. From: davidsoutpost(at)comcast.net To: rv10-list(at)matronics.com Sent: Wednesday, March 06, 2013 4:01 PM Subject: Re: RV10-List: control stick bushing Its a brass bushing about 3" long and comes in the kit. David Clifford RV-10 Builder Howell, MI ------------------------------------------------------------------------- ----- From: "Rick Lark" <larkrv10(at)gmail.com> To: rv10-list(at)matronics.com Sent: Wednesday, March 6, 2013 11:32:45 AM Subject: RV10-List: control stick bushing Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Mar 06, 2013
Interested in selling a couple of those. I have some play in mine, not a lot, but enough that I don=99t like it. I tried a couple of things to tighten it up.but have not been totally successful. I am also interested in your gopro mount once you produce them. I made one myself..but it is nowhere near as cool as yours. J Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano Sent: Wednesday, March 06, 2013 5:10 PM Subject: Re: RV10-List: control stick bushing I just replaced mine. I was sick of the play and machined a Delrin bushing. No play and smoother feel. The bushing ID was too small for my OD using the brass bushing supplied in the kit. From: davidsoutpost(at)comcast.net Sent: Wednesday, March 06, 2013 4:01 PM Subject: Re: RV10-List: control stick bushing Its a brass bushing about 3" long and comes in the kit. David Clifford RV-10 Builder Howell, MI _____ From: "Rick Lark" <larkrv10(at)gmail.com> Sent: Wednesday, March 6, 2013 11:32:45 AM Subject: RV10-List: control stick bushing Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 Southampton, Ont href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 06, 2013
Hey Rene', I am reluctant to sell the bushings for the controls. Not only am I afraid to sell them but they are all different lengths and different IDs'. I noticed my weldment is not perfectly round from Vans. They weld this unit and warp it in the process so the hole is not consistant. The only way they get a bushing in there is to make it way undersize. They would do better if they welded it and then drilled/reamed the hole afterward. That's what we did. I took out the weldment and redrilled the hole barely oversize then made the custom plastic bushing to fit in the new hole. A lot of work for it but worth it. I'll put you on the list for the GoPro mount and let you know when they come available. Thanks Rene, Let me know if I can help otherwise. Sean ----- Original Message ----- From: Rene Felker To: rv10-list(at)matronics.com Sent: Wednesday, March 06, 2013 5:23 PM Subject: RE: RV10-List: control stick bushing Interested in selling a couple of those. I have some play in mine, not a lot, but enough that I don=99t like it. I tried a couple of things to tighten it up.but have not been totally successful. I am also interested in your gopro mount once you produce them. I made one myself..but it is nowhere near as cool as yours. J Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano Sent: Wednesday, March 06, 2013 5:10 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: control stick bushing I just replaced mine. I was sick of the play and machined a Delrin bushing. No play and smoother feel. The bushing ID was too small for my OD using the brass bushing supplied in the kit. From: davidsoutpost(at)comcast.net To: rv10-list(at)matronics.com Sent: Wednesday, March 06, 2013 4:01 PM Subject: Re: RV10-List: control stick bushing Its a brass bushing about 3" long and comes in the kit. David Clifford RV-10 Builder Howell, MI ------------------------------------------------------------------------- --- From: "Rick Lark" <larkrv10(at)gmail.com> To: rv10-list(at)matronics.com Sent: Wednesday, March 6, 2013 11:32:45 AM Subject: RV10-List: control stick bushing Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 Southampton, Ont href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://foru ms.matronics.comhref="http://www.matronics.com/contribution">http://www .matronics.com/c http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 06, 2013
Hmmm, It appears I never got those bushings in the kit or used them somewhere else. I could make bushings out of brass I have a piece of Delrin here I could use too. Sean, do you think the delrin is tough enough? (I guess obviously you do) Looking at the piece of Delrin I have, it sure appears tough/strong enough. Thx for the good idea. Rick On Wed, Mar 6, 2013 at 7:09 PM, Seano wrote: > ** > I just replaced mine. I was sick of the play and machined a Delrin > bushing. No play and smoother feel. The bushing ID was too small for my > OD using the brass bushing supplied in the kit. > > *From:* davidsoutpost(at)comcast.net > > *To:* rv10-list(at)matronics.com > *Sent:* Wednesday, March 06, 2013 4:01 PM > *Subject:* Re: RV10-List: control stick bushing > > Its a brass bushing about 3" long and comes in the kit. > > David Clifford > > RV-10 Builder > Howell, MI > > ------------------------------ > *From: *"Rick Lark" <larkrv10(at)gmail.com> > *To: *rv10-list(at)matronics.com > *Sent: *Wednesday, March 6, 2013 11:32:45 AM > *Subject: *RV10-List: control stick bushing > > Hey guys, section 39-8 talks about inserting a bushing in the control > stick base before bolting it to the WD-1010 control arm. I can't find any > info about this bushing, whether I made it or it came in the kit etc. Can > anyone shed light on what I'm to do here? > > Thx, Rick > #40956 > Southampton, Ont > > * > > * > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Mar 06, 2013
Subject: SNF Showcase Event
Are any RV-10 folks coming to Sun 'n Fun and maybe interested in showing what you and your airplane can do in a timed event? See http://www.sun-n-fun.org/FlyIn/EventActivitiesAndSchedules/SprintsandCatShots.aspx for details and registration. We are trying to bring back some competitive fun for fly-in attendees. Craig Payne ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Mar 06, 2013
For what it's worth, recommend just getting the part from Van's. One of the pure RV characteristics is the silky, no play controls. Ream out the bell crank assembly per the plans, then trim the brass bushing slightly longer than the bell crank tube. This ensures the bushing is fully captured by the through bolt such that the bell crank rotates on the bushing, not the through bolt. Add a film of grease on the bushing during assembly and you have years of worry free operation. Carl RV-8A (700 hrs) RV-10 (65 hours) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Wednesday, March 06, 2013 7:38 PM Subject: Re: RV10-List: control stick bushing Hmmm, It appears I never got those bushings in the kit or used them somewhere else. I could make bushings out of brass I have a piece of Delrin here I could use too. Sean, do you think the delrin is tough enough? (I guess obviously you do) Looking at the piece of Delrin I have, it sure appears tough/strong enough. Thx for the good idea. Rick On Wed, Mar 6, 2013 at 7:09 PM, Seano wrote: I just replaced mine. I was sick of the play and machined a Delrin bushing. No play and smoother feel. The bushing ID was too small for my OD using the brass bushing supplied in the kit. From: davidsoutpost(at)comcast.net Sent: Wednesday, March 06, 2013 4:01 PM Subject: Re: RV10-List: control stick bushing Its a brass bushing about 3" long and comes in the kit. David Clifford RV-10 Builder Howell, MI _____ From: "Rick Lark" <larkrv10(at)gmail.com> Sent: Wednesday, March 6, 2013 11:32:45 AM Subject: RV10-List: control stick bushing Hey guys, section 39-8 talks about inserting a bushing in the control stick base before bolting it to the WD-1010 control arm. I can't find any info about this bushing, whether I made it or it came in the kit etc. Can anyone shed light on what I'm to do here? Thx, Rick #40956 Southampton, Ont href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com /Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: fuel float parts
Date: Mar 10, 2013
Anyone know of a place that might sell just the float wire for the resistive fuel sender? Seem to have broken the wire on my right fuel float? Forgot on install to put that last little bend in the arm wire and when I pulled the whole sender on the annual... I broke it. Just looking for the wire for the float arm but if I have to order the whole thing because I did not pay attention to the instructions so be it. Thanks Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395966#395966 ________________________________________________________________________________
Date: Mar 10, 2013
Subject: Re: fuel float parts
I believe you can order just the wire from Van's. I'd give them a call first to make sure, but I believe this is what you want: REPLACEMNT FLOAT WIRE IE F-385 FLOAT ARM PJ On 3/10/2013 09:47, Eric_Kallio wrote: > Anyone know of a place that might sell just the float wire for the resistive fuel sender? Seem to have broken the wire on my right fuel float? Forgot on install to put that last little bend in the arm wire and when I pulled the whole sender on the annual... I broke it. Just looking for the wire for the float arm but if I have to order the whole thing because I did not pay attention to the instructions so be it. Thanks ________________________________________________________________________________
Date: Mar 10, 2013
That looks like it. Thanks. I will call them tomorrow. I could not get it to come up on a search in the parts store. I kept spelling replacement correctly, but that us apparently not how they spell it. Eric Read this topic online here: http://forums.matronics.com/viewtopic.php?p=395974#395974 ________________________________________________________________________________
Date: Mar 10, 2013
I expect they sell a fair number, as probably a lot are not bent correctly on the first try. On Sun, Mar 10, 2013 at 11:37 AM, PJ Seipel wrote: > > I believe you can order just the wire from Van's. I'd give them a call > first to make sure, but I believe this is what you want: > > REPLACEMNT FLOAT WIRE IE F-385 FLOAT ARM > > PJ > > > On 3/10/2013 09:47, Eric_Kallio wrote: > >> Anyone know of a place that might sell just the float wire for the >> resistive fuel sender? Seem to have broken the wire on my right fuel float? >> Forgot on install to put that last little bend in the arm wire and when I >> pulled the whole sender on the annual... I broke it. Just looking for the >> wire for the float arm but if I have to order the whole thing because I did >> not pay attention to the instructions so be it. Thanks >> > > ________________________________________________________________________________
Date: Mar 11, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
Subject: Finishing Kit Substitution Costs
I pretty much went with the list of substitutions suggested on Tim's site and this list. My windshield and back side windows came with the fuselage kit I already had. I chose to delete the two door windows for which Van's credited me $110 each. The door windows from Dresser cost $150 each. Van's credited me $100.38 for the nose wheel. MATCO charged 130.49 for the nose wheel. Van's credited me $68 each for the main gear tires and $52.40 for the nose wheel tire. Dresser charge $69 each for the main gear retreads and $69.95 for the nose wheel retread. Thus these were not direct cost substitutes, but the nose wheel is a must and I hope the windows are worth the difference and I understand the tires wear longer. I thought this might be of interest to those at this stage of the build. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: Finishing Kit Substitution Costs
Date: Mar 11, 2013
Dave; I helped Desser with the front window/windscreen another builder with the sides- they fit perfectly versus having to do all the trimming to make it fit. The quality of Cee baileys is also better than that sent from Vans. Keep in mind that you may pay more for the windows, Matco and tires but you are far better off for it. In the end you really saved a whole lot of time and eventually money as the parts you replaced from the Vans parts will last far longer. I make nothing on this, but believe me I worked with Desser/Cee Baileys because the windows are lacking from Vans and the product Desser came up with was based on thriving for perfection and a perfect fit "as is". Until you have put the windows on and off 20 times to get the gap right one would not understand the advantage of having a nearly perfect fitting piece on arrival. I tossed my windscreen as I had a "bulge" on the co-pilot side and used the Desser version that was rounded and tight fitting throughout. Thanks for the feedback! Pascal -----Original Message----- From: Dave Fritzsche (Building) Sent: Monday, March 11, 2013 11:07 AM Subject: RV10-List: Finishing Kit Substitution Costs I pretty much went with the list of substitutions suggested on Tim's site and this list. My windshield and back side windows came with the fuselage kit I already had. I chose to delete the two door windows for which Van's credited me $110 each. The door windows from Dresser cost $150 each. Van's credited me $100.38 for the nose wheel. MATCO charged 130.49 for the nose wheel. Van's credited me $68 each for the main gear tires and $52.40 for the nose wheel tire. Dresser charge $69 each for the main gear retreads and $69.95 for the nose wheel retread. Thus these were not direct cost substitutes, but the nose wheel is a must and I hope the windows are worth the difference and I understand the tires wear longer. I thought this might be of interest to those at this stage of the build. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Step intallation
Date: Mar 11, 2013
Hi there On the QB fuselage, I came to the conclusion that most of the step installation work is already done, you only have to insert the step and final-drill the vertical hole for the AN3-20A bolt. My problem is that, with the existing pilot holes aligned, neither the 45 =BC=94 distance (between the aft edge of the wing attachment bulkhead and the leading edge of the step) indicated in fig. 2 of page 30-3 is good (I have around 1=94 more), nor the weld at the top of the step sits flush with the skin=85 Should I change anything to mate those 2 conditions, or can I just final-drill the hole like it is? Thanks Carlos ________________________________________________________________________________
Date: Mar 11, 2013
Subject: Re: Step intallation
Carlos, I only had pilot holes in the powder coated support, not the step tube, so I slid the steps in as far as required to get the right dimension. Also search the archives as lots of later builders are putting in a solid plug in the step tube, and then drilling through the whole assembly to help keep the bolt from lossening up over time. See Bob Newmans web site for details. Rick #40956 Southampton, Ont On Mon, Mar 11, 2013 at 5:18 PM, Carlos Trigo wrote : > Hi there**** > > ** ** > > On the QB fuselage, I came to the conclusion that most of the step > installation work is already done, you only have to insert the step and > final-drill the vertical hole for the AN3-20A bolt.**** > > ** ** > > My problem is that, with the existing pilot holes aligned, neither the 45 > =BC=94 distance (between the aft edge of the wing attachment bulkhead and the > leading edge of the step) indicated in fig. 2 of page 30-3 is good (I hav e > around 1=94 more), nor the weld at the top of the step sits flush with th e > skin=85**** > > ** ** > > Should I change anything to mate those 2 conditions, or can I just > final-drill the hole like it is?**** > > ** ** > > Thanks**** > > Carlos **** > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Mar 11, 2013
Are you sure you have the correct step on the correct side ? Also, you may want to create an access plate for the bolt in case it loosens up or the weld cracks. I believe bob Newman sells an insert for the step as Rick has posted above -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396048#396048 ________________________________________________________________________________
Date: Mar 11, 2013
Subject: Firewall insulation
All, I am trying to make a decision as to a decent method of firewall insulation. I have looked through the arhives and have seen where some have used a Fiberfrax type of material and some have used a foam material. Is there anything that might not be a good idea to use bot the Fiberfrax as a thermal insulation and a foam insulation for acoustic?Any thoughts would be greatly appreciated. Ed Godfrey 40717 ________________________________________________________________________________
Date: Mar 11, 2013
Subject: cabin top trimming data point
Guys, I started trimming the cabin top today and made 2 discoveries. 1) as others have found normal jig saw blades dull incredibly quickly. 2) I also tried a carbide jig saw blade I purchased years ago to cut ceramic tile. This blade was mounted in my Makita jig saw and worked great. I completed all the rough trimming in probably a 1/2 hour, and with little dust compared to a rotary tool. Unfortunately I have no idea where I purchased this blade now but if you can find one, give it a try. Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: Firewall insulation
Date: Mar 12, 2013
Ed, You need to read the thread in the VAF archives about Dan horton's testing of all the materials. Unfortunately, as Ted found out, that black foam insulation turns into caustic black smoke pretty quickly. I wouldn't use it on the firewall or tunnel. I did use the black foam in areas that most likely would be exposed to flames in flight, like the side walls. I used fiberfrax in the tunnel. On the firewall I used a product from acs that is a ceramic blanket with stainless foil on the firewall side and aluminum foil on the aft side. There is no 100% answer here. You need to determine the best way to mitigate the risk of heat/fire, since many of the solutions introduce other risks if implemented. Bob Sent from my iPad On Mar 11, 2013, at 9:48 PM, Ed Godfrey wrote: > > All, > I am trying to make a decision as to a decent method of firewall insulation. I have looked through the arhives and have seen where some have used a Fiberfrax type of material and some have used a foam material. Is there anything that might not be a good idea to use bot the Fiberfrax as a thermal insulation and a foam insulation for acoustic?Any thoughts would be greatly appreciated. > > Ed Godfrey > 40717 > > > > ________________________________________________________________________________
Date: Mar 12, 2013
Subject: Re: cabin top trimming data point
What grit of carbide blade did you find worked best for you? On Mon, Mar 11, 2013 at 10:04 PM, Rick Lark wrote: > Guys, I started trimming the cabin top today and made 2 discoveries. 1) > as others have found normal jig saw blades dull incredibly quickly. 2) I > also tried a carbide jig saw blade I purchased years ago to cut ceramic > tile. This blade was mounted in my Makita jig saw and worked great. I > completed all the rough trimming in probably a 1/2 hour, and with little > dust compared to a rotary tool. > > Unfortunately I have no idea where I purchased this blade now but if you > can find one, give it a try. > > Rick > #40956 > Southampton, Ont > > * > > * > > ________________________________________________________________________________
Date: Mar 12, 2013
I used the this and like it: http://www.aircraftspruce.com/catalog/appages/insulator3.php The double sided, one layer thick is fine. Get the aluminum foil tape to install: http://www.aircraftspruce.com/catalog/appages/insultape.php I used this insulation on the inside of the firewall, all floors and sidewalls (with an interior fabric covering the cabin side of the insulation for areas not enclosed). I did not use it for the cabin top (I found a nice marine grade upholstery product for that). I have this on the bottom of the tunnel but not the sides. I have not experienced any issues with tunnel heat. I have some KoolMat http://www.aircraftspruce.com/pages/ap/insulation/koolmat.php on the firewall. It is between the cabin heat control valves and the firewall, then extents up and over the top of the valves. The idea is to not blast the engine and fuel pump with hot heat muff air that bounces off the valves back toward the engine when the valves are shut (on hot days when you least want hot air banging on the fuel pump). So the KoolMat insulates some thermal heat transfer to the firewall, and looping the KoolMat over the top and then down in front of the valves directs the dumped heat muff air down and away from the engine. I know one RV-10 builder who used the black foam in the floor area that had to pull it out - it started to smell up the airplane when it got warm. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Tuesday, March 12, 2013 5:51 AM Subject: Re: RV10-List: Firewall insulation Ed, You need to read the thread in the VAF archives about Dan horton's testing of all the materials. Unfortunately, as Ted found out, that black foam insulation turns into caustic black smoke pretty quickly. I wouldn't use it on the firewall or tunnel. I did use the black foam in areas that most likely would be exposed to flames in flight, like the side walls. I used fiberfrax in the tunnel. On the firewall I used a product from acs that is a ceramic blanket with stainless foil on the firewall side and aluminum foil on the aft side. There is no 100% answer here. You need to determine the best way to mitigate the risk of heat/fire, since many of the solutions introduce other risks if implemented. Bob Sent from my iPad On Mar 11, 2013, at 9:48 PM, Ed Godfrey wrote: > > All, > I am trying to make a decision as to a decent method of firewall insulation. I have looked through the arhives and have seen where some have used a Fiberfrax type of material and some have used a foam material. Is there anything that might not be a good idea to use bot the Fiberfrax as a thermal insulation and a foam insulation for acoustic?Any thoughts would be greatly appreciated. > > Ed Godfrey > 40717 > > > > ________________________________________________________________________________
Date: Mar 12, 2013
I did my cabin top trimming with the harbor freight body saw and about 2 packs of blades or more making lots of dust and spending way too much time doing it. I suffered through trimming the rear windows with the typical 4" cutoff wheel then another builder, Mark Cooper, turned me on to a great alternative the diamond wheel for dremel tools. http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=EZ545 This works really well for both fiberglass and plexi and seems to last quite a while. I trimmed the door windows with this in minutes compared to the hours it took using the vans supplied cutoff wheel. It doesn't take side loading very well but given its smaller size it works pretty good still trimming the corners. -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Monday, March 11, 2013 7:04 PM Subject: RV10-List: cabin top trimming data point Guys, I started trimming the cabin top today and made 2 discoveries. 1) as others have found normal jig saw blades dull incredibly quickly. 2) I also tried a carbide jig saw blade I purchased years ago to cut ceramic tile. This blade was mounted in my Makita jig saw and worked great. I completed all the rough trimming in probably a 1/2 hour, and with little dust compared to a rotary tool. Unfortunately I have no idea where I purchased this blade now but if you can find one, give it a try. Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: GPS Shelf FWF
Date: Mar 12, 2013
Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF tha t had 4+ GPS antenna mounted. I recall the shelf was painted black and conn ected the firewall with the motor mount? Can the owner share the photo agai n with the group? I need something similar for my 8A and cannot locate the post. Thanks, Robin ________________________________________________________________________________
Date: Mar 12, 2013
Subject: Re: GPS Shelf FWF
Here's the post in the forums with a bunch of options including the one you are referring to. http://forums.matronics.com/viewtopic.php?p=392689#392689 -Sean #40303 (FAB) On 3/12/13 1:55 PM, Robin Marks wrote: > > Someone on the RV-10 list shared a photo of their GPS shelf mounted > FWF that had 4+ GPS antenna mounted. I recall the shelf was painted > black and connected the firewall with the motor mount? Can the owner > share the photo again with the group? I need something similar for my > 8A and cannot locate the post. > > Thanks, > > Robin > > * > > > * ________________________________________________________________________________
Date: Mar 12, 2013
Just curious ..... why not put the GPS antennas on the glareshield??? Linn On 3/12/2013 2:55 PM, Robin Marks wrote: > > Someone on the RV-10 list shared a photo of their GPS shelf mounted > FWF that had 4+ GPS antenna mounted. I recall the shelf was painted > black and connected the firewall with the motor mount? Can the owner > share the photo again with the group? I need something similar for my > 8A and cannot locate the post. > > Thanks, > > Robin > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 12, 2013
For me it was just-assedics, they work well under the cowl and are out of sight.-=0A=0ABruce 151BJ in the paint shop=0A=0A=0A_____________________ ___________=0A From: Linn <flying-nut(at)cfl.rr.com>=0ATo: rv10-list@matronics .com =0ASent: Tuesday, March 12, 2013 2:05 PM=0ASubject: Re: RV10-List: GPS Shelf FWF=0A =0A=0AJust curious ..... why not put the GPS antennas on the glareshield???=0ALinn=0A=0AOn 3/12/2013 2:55 PM, Robin Marks wrote:=0A=0A =0A>Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post.=0A>-=0A>Thanks,=0A>Robin =0A>No virus found in this message.=0A ===== ________________________________________________________________________________
Date: Mar 12, 2013
I received a couple e-mails asking for more information on the parts the Desser replace. I am pretty certain Tim has this already somewhere on his website however for easy reference. I broke down the Desser/Cee Bailey's packages and the respective Vans part number it replaces. Keep in mind that I recall the windows came with a earlier kit than the finish kit. Best to have Vans send a copy of the parts list at each point and review to see if any of the parts that are being replaced are removed. Desser site: Wingtip position light lenses- VA193 http://www.vansaircrafttires.com/products/RV%252d10-Clear-Wing-tip-lenses-%28pair%29.html Complete Windows kit - http://www.vansaircrafttires.com/products/Cee-Bailey%27s-RV%252d10-Windshield%2C-pilot-%26-co%252dpilot-door-windows%2C-left-and-right-rear-window-set.html Individual kits: Side rear windows- C-1004L/C1004R http://www.vansaircrafttires.com/products/RV%252d10-Rear-%28Left-or-Right%29-Window.html side DOOR windows C1003L/1003R http://www.vansaircrafttires.com/products/RV%252d10-pilot-%26-co%252dpilot-door-windows%2C-left-and-right-rear-window-set.html front windscreen (C-1005) http://www.vansaircrafttires.com/products/Cee-Baileys-RV%252d10-Windshield.html tires http://www.vansaircrafttires.com/products/RV%252d10-New-Builders-Special-save-10%25-%28two-15%7B47%7D600%252d6PR-Retreads%2C-two-Aero-Classic-Easy-Flate-Tubes%2C-one-5.00%252d5-6PR-Elite-Retreads%2C-and-one-Aero-Classic-5.00%252d5-Butyl-Tube%29.html The advantage of getting the retreads now, if one is ever going to go this route, is that the wheel pants are spaced correctly around the tires when building, otherwise one may find they need to make the area larger after replacing the stock tires with retread. Hope this helps! Pascal -----Original Message----- From: Pascal Sent: Monday, March 11, 2013 11:29 AM Subject: Re: RV10-List: Finishing Kit Substitution Costs Dave; I helped Desser with the front window/windscreen another builder with the sides- they fit perfectly versus having to do all the trimming to make it fit. The quality of Cee baileys is also better than that sent from Vans. Keep in mind that you may pay more for the windows, Matco and tires but you are far better off for it. In the end you really saved a whole lot of time and eventually money as the parts you replaced from the Vans parts will last far longer. I make nothing on this, but believe me I worked with Desser/Cee Baileys because the windows are lacking from Vans and the product Desser came up with was based on thriving for perfection and a perfect fit "as is". Until you have put the windows on and off 20 times to get the gap right one would not understand the advantage of having a nearly perfect fitting piece on arrival. I tossed my windscreen as I had a "bulge" on the co-pilot side and used the Desser version that was rounded and tight fitting throughout. Thanks for the feedback! Pascal -----Original Message----- From: Dave Fritzsche (Building) Sent: Monday, March 11, 2013 11:07 AM Subject: RV10-List: Finishing Kit Substitution Costs I pretty much went with the list of substitutions suggested on Tim's site and this list. My windshield and back side windows came with the fuselage kit I already had. I chose to delete the two door windows for which Van's credited me $110 each. The door windows from Dresser cost $150 each. Van's credited me $100.38 for the nose wheel. MATCO charged 130.49 for the nose wheel. Van's credited me $68 each for the main gear tires and $52.40 for the nose wheel tire. Dresser charge $69 each for the main gear retreads and $69.95 for the nose wheel retread. Thus these were not direct cost substitutes, but the nose wheel is a must and I hope the windows are worth the difference and I understand the tires wear longer. I thought this might be of interest to those at this stage of the build. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Date: Mar 12, 2013
Here is my solution. Jim Combs N312F - Flying 460+ Hours On Tue, Mar 12, 2013 at 2:55 PM, Robin Marks wrote: > Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF > that had 4+ GPS antenna mounted. I recall the shelf was painted black and > connected the firewall with the motor mount? Can the owner share the photo > again with the group? I need something similar for my 8A and cannot locate > the post.**** > > ** ** > > Thanks,**** > > Robin **** > > ________________________________________________________________________________
Date: Mar 12, 2013
Subject: seat back handle improvement?
Anyone know of a better solution for the seat back handle? I'm concerned that the handle may be hard to reach quickly in an emergency, which could slow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Subject: More on GoPro Mounts
Date: Mar 12, 2013
I found this scheme on Van's Air Force I think. The mount is the standard go pro flat adhesive base but with backing still on adhesive. The adhesive pad acts as a paint protector/cushion. A hole is drilled in the mount and countersunk. I have used on the top and the bottom of the wing using a longer fuel tank screw to hold it on. At cruise and in the pattern no issues and pretty stable - sometimes I can tell the automatic stabilization is kicking in on the camera or rather not keeping up with a slight vibe. -Chris Lucas N919AR ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 12, 2013
Subject: Re: seat back handle improvement?
Mine are positioned to stick back into the footwell, on the outboard sides. They're pretty easy to get to from just about everywhere. Dave Saylor 831-750-0284 CL On Tue, Mar 12, 2013 at 5:44 PM, Rob Kochman wrote: > Anyone know of a better solution for the seat back handle? I'm concerned > that the handle may be hard to reach quickly in an emergency, which could > slow down egress from the rear seats. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > ________________________________________________________________________________
Date: Mar 13, 2013
Rob, Not sure you are speaking of this handle but the photo attached is of my fr ont seat position adjustment handles prior to install. I have always had th em and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emerg ency egress. If you were to design a set yourself you could place a rear fa cing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubi ng. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned t hat the handle may be hard to reach quickly in an emergency, which could sl ow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: Mar 13, 2013
Lynn, I dislike anything on the glare shield. I won't even fly (build) with a das h or pole mounted compass. RV's have such great visibility why gunk it up w ith random odds & ends. Over time you will add, remove antenna and I prefer to do that out of sight. Just keeping it clean! Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Bruce Johnson Sent: Tuesday, March 12, 2013 2:31 PM Subject: Re: RV10-List: GPS Shelf FWF For me it was just assedics, they work well under the cowl and are out of s ight. Bruce 151BJ in the paint shop ________________________________ From: Linn <flying-nut(at)cfl.rr.com<mailto:flying-nut(at)cfl.rr.com>> Sent: Tuesday, March 12, 2013 2:05 PM Subject: Re: RV10-List: GPS Shelf FWF Just curious ..... why not put the GPS antennas on the glareshield??? Linn On 3/12/2013 2:55 PM, Robin Marks wrote: Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF tha t had 4+ GPS antenna mounted. I recall the shelf was painted black and conn ected the firewall with the motor mount? Can the owner share the photo agai n with the group? I need something similar for my 8A and cannot locate the post. Thanks, Robin No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com/> 03/12/13 -======================== =================== ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: Mar 12, 2013
Ah, Dave, you made me feel dumb. I didn't even think to reposition the handles! A perfect $0 solution. Thanks... -Rob On Tue, Mar 12, 2013 at 7:25 PM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > dave.saylor.aircrafters(at)gmail.com> > > Mine are positioned to stick back into the footwell, on the outboard > sides. They're pretty easy to get to from just about everywhere. > Dave Saylor > 831-750-0284 CL > > > On Tue, Mar 12, 2013 at 5:44 PM, Rob Kochman wrote: > > Anyone know of a better solution for the seat back handle? I'm concerned > > that the handle may be hard to reach quickly in an emergency, which could > > slow down egress from the rear seats. Thanks... > > > > -Rob > > > > -- > > Rob Kochman > > RV-10 Flying since March 2011 > > Woodinville, WA > > http://kochman.net/N819K > > > > > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 12, 2013
Robin, I'm talking about the other handle, though I was thinking about replacing the other one. That said, I don't adjust it frequently. Thanks... On Tue, Mar 12, 2013 at 8:23 PM, Robin Marks wrote: > Rob,**** > > Not sure you are speaking of this handle but the photo attached is of my > front seat position adjustment handles prior to install. I have always had > them and thought they were a huge improvement over the stock design. I am > not sure how beneficial they would be for a rear passenger to access for > emergency egress. If you were to design a set yourself you could place a > rear facing handle extension that one pushes down?**** > > The first generation handle extensions were made of thin walled square > tubing. Thicker tubing improved the longevity substantially.**** > > ** ** > > Good luck,**** > > Robin**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman > *Sent:* Tuesday, March 12, 2013 5:44 PM > *To:* rv10-list > *Subject:* RV10-List: seat back handle improvement?**** > > ** ** > > Anyone know of a better solution for the seat back handle? I'm concerned > that the handle may be hard to reach quickly in an emergency, which could > slow down egress from the rear seats. Thanks...**** > > ** ** > > -Rob > **** > > ** ** > > -- **** > > Rob Kochman > RV-10 Flying since March 2011**** > > Woodinville, WA**** > > http://kochman.net/N819K**** > > * * > > * * > > ==============**** V10-List Email Forum -**** > :p> /o:p> tor?RV10-List"> > http://www.matronics.com/Navigator?RV10-List**** ==============****bsp; - MATRONICS WEB FORUMS - > **** :p> tp://forums.matronics.com**** ==============**** bsp; - List > Contribution Web Site -**** e> bsp; -Matt Dralle, List > Admin.**** bution">http://www.matronics.com/contribution****============= > **** > > * * > > ------------------------------ > > No virus found in this message. > Checked by AVG - www.avg.com > r> > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 13, 2013
Thanks Robin. I feel as you do .... wanted to not install the front cabin top brace for the same reason. I learned from others that they use it a lot .... so in it goes. One problem I have flying my traumahawk ..... there's nothing to use to 'aim' the airplane to keep it on track. I have two small pucks for GPS antennas .... and was thinking of mounting them on the glareshield as a 'sight'. Again, thanks for the reply. Linn .... still learning On 3/12/2013 11:32 PM, Robin Marks wrote: > > Lynn, > > I dislike anything on the glare shield. I won't even fly (build) with > a dash or pole mounted compass. RV's have such great visibility why > gunk it up with random odds & ends. Over time you will add, remove > antenna and I prefer to do that out of sight. Just keeping it clean! > > Robin > > ________________________________________________________________________________
Date: Mar 13, 2013
Lynn, I recall the brace conversation. I as much as just about anyone didn't want the brace there till I flew the 10. The brace is invaluable for getting in and out, for stabilization during turbulence and for routing wires from my overhead console. I'm embarrassed to say I love the brace now. Might I suggest you consider installing flush defrost fans and use those as your aiming device and move the small GPS pucks to the FWF? Occasionally I can see the reflection of my black computer fan grills on the windscreen. It looks kind of like a machine gun site. Another option is to press the Heading button on the AP and not worry about the site. Over time you will be comfortable flying a plane you built with your own hands w/o the need for a site line. Good luck with your choices. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Linn Sent: Tuesday, March 12, 2013 10:17 PM Subject: Re: RV10-List: GPS Shelf FWF Thanks Robin. I feel as you do .... wanted to not install the front cabin top brace for the same reason. I learned from others that they use it a lo t .... so in it goes. One problem I have flying my traumahawk ..... there's nothing to use to 'ai m' the airplane to keep it on track. I have two small pucks for GPS antenn as .... and was thinking of mounting them on the glareshield as a 'sight'. Again, thanks for the reply. Linn .... still learning On 3/12/2013 11:32 PM, Robin Marks wrote: Lynn, I dislike anything on the glare shield. I won't even fly (build) with a das h or pole mounted compass. RV's have such great visibility why gunk it up w ith random odds & ends. Over time you will add, remove antenna and I prefer to do that out of sight. Just keeping it clean! Robin ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 13, 2013
Mine are on the inside of the seats (vs between the seat and the door). It is a little inconvenient reaching over the seat at times, but I liked it better than trying to get at it between the door and the seat. It is very easy for the rear seat pax to reach... I like the idea of pointing them backwards on the onboard side, never thought of that! -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) On Mar 12, 2013, at 10:25 PM, Dave Saylor wrote: > > Mine are positioned to stick back into the footwell, on the outboard > sides. They're pretty easy to get to from just about everywhere. > Dave Saylor > 831-750-0284 CL > > > On Tue, Mar 12, 2013 at 5:44 PM, Rob Kochman wrote: >> Anyone know of a better solution for the seat back handle? I'm concerned >> that the handle may be hard to reach quickly in an emergency, which could >> slow down egress from the rear seats. Thanks... >> >> -Rob >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K > > > > ________________________________________________________________________________
Date: Mar 13, 2013
Date: Mar 13, 2013
William, I don't have any idea what grit it is. I attached a photo which should help. I would say that the grit could have been more coarse which would have made it cut even faster. The blade is pretty beat up now. I was in a machine shop/tool place yesterday and they had similar blades, so they must be available. Certainlt a tile installtion place would know where to get them. Good luck, Rick On Tue, Mar 12, 2013 at 9:44 AM, William Greenley wrote: > What grit of carbide blade did you find worked best for you? > > On Mon, Mar 11, 2013 at 10:04 PM, Rick Lark wrote: > >> Guys, I started trimming the cabin top today and made 2 discoveries. 1) >> as others have found normal jig saw blades dull incredibly quickly. 2) I >> also tried a carbide jig saw blade I purchased years ago to cut ceramic >> tile. This blade was mounted in my Makita jig saw and worked great. I >> completed all the rough trimming in probably a 1/2 hour, and with little >> dust compared to a rotary tool. >> >> Unfortunately I have no idea where I purchased this blade now but if you >> can find one, give it a try. >> >> Rick >> #40956 >> Southampton, Ont >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > ________________________________________________________________________________
Date: Mar 13, 2013
Robin, Where did you get your seat handles from? Jim N10KQ 81.5 hrs From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, March 12, 2013 8:24 PM Subject: RE: RV10-List: seat back handle improvement? Rob, Not sure you are speaking of this handle but the photo attached is of my front seat position adjustment handles prior to install. I have always had them and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emergency egress. If you were to design a set yourself you could place a rear facing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubing. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned that the handle may be hard to reach quickly in an emergency, which could slow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= _____ No virus found in this message. Checked by AVG - www.avg.com r> ________________________________________________________________________________
Date: Mar 13, 2013
Jim, So sorry I don't recall. Anyone else know on the list? Regardless the first set didn't last due to thin wall design. We remade the m ourselves with better material for near nothing. I suggest you do the sam e. It should take very little time to duplicate the units pictured in the p rior email. I really like this simple mod and it is used twice on every fli ght. I recall the stock Vans design is a bit of a knuckle scraper. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of JimVillani Sent: Wednesday, March 13, 2013 7:09 AM Subject: RE: RV10-List: seat back handle improvement? Robin, Where did you get your seat handles from? Jim N10KQ 81.5 hrs From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob in Marks Sent: Tuesday, March 12, 2013 8:24 PM Subject: RE: RV10-List: seat back handle improvement? Rob, Not sure you are speaking of this handle but the photo attached is of my fr ont seat position adjustment handles prior to install. I have always had th em and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emerg ency egress. If you were to design a set yourself you could place a rear fa cing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubi ng. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned t hat the handle may be hard to reach quickly in an emergency, which could sl ow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> r> ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: Mar 13, 2013
Absolutely. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Wednesday, March 13, 2013 7:27 AM Subject: RE: RV10-List: seat back handle improvement? Jim, So sorry I don't recall. Anyone else know on the list? Regardless the first set didn't last due to thin wall design. We remade them ourselves with better material for near nothing. I suggest you do the same. It should take very little time to duplicate the units pictured in the prior email. I really like this simple mod and it is used twice on every flight. I recall the stock Vans design is a bit of a knuckle scraper. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JimVillani Sent: Wednesday, March 13, 2013 7:09 AM Subject: RE: RV10-List: seat back handle improvement? Robin, Where did you get your seat handles from? Jim N10KQ 81.5 hrs From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, March 12, 2013 8:24 PM Subject: RE: RV10-List: seat back handle improvement? Rob, Not sure you are speaking of this handle but the photo attached is of my front seat position adjustment handles prior to install. I have always had them and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emergency egress. If you were to design a set yourself you could place a rear facing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubing. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned that the handle may be hard to reach quickly in an emergency, which could slow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= _____ No virus found in this message. Checked by AVG - www.avg.com r> ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= _____ No virus found in this message. Checked by AVG - www.avg.com :p> ________________________________________________________________________________
Date: Mar 13, 2013
32 years ago I built my Pitts S-1 ..... and it never stays on heading more than a few seconds .. :-D I was planning on fans ..... and promptly forgot them. Thanks for the reminder!!!! You also reminded me about those hardpoints on the wings ......... Linn On 3/13/2013 2:13 AM, Robin Marks wrote: > > Lynn, > > I recall the brace conversation. I as much as just about anyone didn't > want the brace there till I flew the 10. The brace is invaluable for > getting in and out, for stabilization during turbulence and for > routing wires from my overhead console. I'm embarrassed to say I love > the brace now. > > Might I suggest you consider installing flush defrost fans and use > those as your aiming device and move the small GPS pucks to the FWF? > Occasionally I can see the reflection of my black computer fan grills > on the windscreen. It looks kind of like a machine gun site. > > Another option is to press the Heading button on the AP and not worry > about the site. Over time you will be comfortable flying a plane you > built with your own hands w/o the need for a site line. > > Good luck with your choices. > > Robin > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Linn > *Sent:* Tuesday, March 12, 2013 10:17 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: GPS Shelf FWF > > Thanks Robin. I feel as you do .... wanted to not install the front > cabin top brace for the same reason. I learned from others that they > use it a lot .... so in it goes. > One problem I have flying my traumahawk ..... there's nothing to use > to 'aim' the airplane to keep it on track. I have two small pucks for > GPS antennas .... and was thinking of mounting them on the glareshield > as a 'sight'. > Again, thanks for the reply. > Linn .... still learning > > On 3/12/2013 11:32 PM, Robin Marks wrote: > > Lynn, > > I dislike anything on the glare shield. I won't even fly (build) > with a dash or pole mounted compass. RV's have such great > visibility why gunk it up with random odds & ends. Over time you > will add, remove antenna and I prefer to do that out of sight. > Just keeping it clean! > > Robin > > * * > * * > ==============V10-List Email Forum -> :p> /o:p> > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List==============bsp; > - MATRONICS WEB FORUMS -:p> > tp://forums.matronics.com==============bsp; - List Contribution Web > Site -e> bsp; -Matt Dralle, List > Admin.bution">http://www.matronics.com/contribution============= > * * > ------------------------------------------------------------------------ > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > r> > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 13, 2013
Greg Hale originally did the design and I believe Steve DiNeri is selling t hem. http://capsteve.wix.com/iflyrv10 Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of JimVillani Sent: Wednesday, March 13, 2013 9:09 AM Subject: RE: RV10-List: seat back handle improvement? Robin, Where did you get your seat handles from? Jim N10KQ 81.5 hrs From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob in Marks Sent: Tuesday, March 12, 2013 8:24 PM Subject: RE: RV10-List: seat back handle improvement? Rob, Not sure you are speaking of this handle but the photo attached is of my fr ont seat position adjustment handles prior to install. I have always had th em and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emerg ency egress. If you were to design a set yourself you could place a rear fa cing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubi ng. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned t hat the handle may be hard to reach quickly in an emergency, which could sl ow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> r> ________________________________________________________________________________
Subject: Seat adjusters
Date: Mar 13, 2013
They're not as slick as Robin's but these 2" extensions work a lot better th an the stock T handle position. They're pretty easy to make. If anybody wan ts some let me know and we'll make a batch. --Dave
Date: Mar 13, 2013
Disregard my last offer--Steve sells the same thing. Dave Saylor 831-750-0284 CL On Wed, Mar 13, 2013 at 8:11 AM, Michael Sausen wrote: > Greg Hale originally did the design and I believe Steve DiNeri is selling > them. http://capsteve.wix.com/iflyrv10 > > > Michael > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JimVillani > Sent: Wednesday, March 13, 2013 9:09 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: seat back handle improvement? > > > Robin, > > Where did you get your seat handles from? > > Jim > > N10KQ > > 81.5 hrs > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks > Sent: Tuesday, March 12, 2013 8:24 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: seat back handle improvement? > > > Rob, > > Not sure you are speaking of this handle but the photo attached is of my > front seat position adjustment handles prior to install. I have always had > them and thought they were a huge improvement over the stock design. I am > not sure how beneficial they would be for a rear passenger to access for > emergency egress. If you were to design a set yourself you could place a > rear facing handle extension that one pushes down? > > The first generation handle extensions were made of thin walled square > tubing. Thicker tubing improved the longevity substantially. > > > Good luck, > > Robin > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman > Sent: Tuesday, March 12, 2013 5:44 PM > To: rv10-list > Subject: RV10-List: seat back handle improvement? > > > Anyone know of a better solution for the seat back handle? I'm concerned > that the handle may be hard to reach quickly in an emergency, which could > slow down egress from the rear seats. Thanks... > > > -Rob > > > -- > > Rob Kochman > RV-10 Flying since March 2011 > > Woodinville, WA > > http://kochman.net/N819K > > > ============= > > V10-List Email Forum - > >> > > :p> > > /o:p> > > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List > > ============= > > bsp; - MATRONICS WEB FORUMS - > > :p> > > tp://forums.matronics.com > > ============= > > bsp; - List Contribution Web Site - > > e> bsp; -Matt Dralle, List Admin. > > bution">http://www.matronics.com/contribution > > ============= > > > ________________________________ > > No virus found in this message. > Checked by AVG - www.avg.com > r> > > > ============== V10-List Email Forum - > :p> /o:p> > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= > bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com > ============== bsp; - List Contribution Web Site - e> bsp; > -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution > ============= > > ________________________________________________________________________________
Subject: Re: Seat adjusters
Date: Mar 13, 2013
I bought some just like those from Steve Dinieri at IflyRV10.com and they work fine. I originally had the ones that Greg Hale designed. They looked great and worked well, but the thin wall of the lever eventually gave out. I looked at Steve's version of the Greg Hale lever and they are really nice, but won't match the holes I drilled for the Greg Hale lever. So, I settled on the T handle extensions and am satisfied. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396172#396172 ________________________________________________________________________________
Date: Mar 13, 2013
Steve Dinieri's seat adjustment levers shown here http://capsteve.wix.com/iflyrv10#!__seat-lever are a real improvement over the originals designed and built by Greg Hale. They are much more robust and the attachment to the seat mechanism is very simple. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396173#396173 ________________________________________________________________________________
Date: Mar 13, 2013
Yeah, I made mine but if I knew they were available I'd have just bought his extensions as well. Dave Saylor 831-750-0284 CL On Wed, Mar 13, 2013 at 9:18 AM, dmaib(at)me.com wrote: > > I bought some just like those from Steve Dinieri at IflyRV10.com and they work fine. I originally had the ones that Greg Hale designed. They looked great and worked well, but the thin wall of the lever eventually gave out. I looked at Steve's version of the Greg Hale lever and they are really nice, but won't match the holes I drilled for the Greg Hale lever. So, I settled on the T handle extensions and am satisfied. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396172#396172 > > ________________________________________________________________________________
Date: Mar 13, 2013
At 11:55 AM 3/12/2013 Tuesday, you wrote: >Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post. > >Thanks, >Robin Hi Robin, Here are some pictures of how I did the GPS antenna installations on my RV-8. Works great. Blast tubes keeps them cool. No unsightly pucks on the dash! Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode ________________________________________________________________________________
Date: Mar 13, 2013
At the RV-10 Composite course we just did, we brought out a whole pile of tools and settled on the following as being the best: Permagrit Composite cutoff wheel on a Die Grinder for trimming all but the thickest parts Angle Die Grinder with a 1.5 or 2" Drum sander took down the thick stuff very well, use it when you've trimmed off all the flange are are working on the actual frame. Maybe 80 grit? A nice long block with 30 or 40 grit was great for cleaning up after the sanding drum/wheel. And a tungsten or permagrit bit for making small radius' was essential. Other traditional cut-off wheels were too slow and a straight line air sander didn't have the power to be as fast as a hand block. Sanding discs weren't as fast as the drums We didn't have, but would like to have tried, the composite jig saw (although my experience with those in the past is that the composite cut-off wheels are almost as fast and cut better lines), or the composite tips for an oscillating tool. Here are pics of what worked: http://www.easycomposites.co.uk/Images/products/medium/permagrit-RD2.jpg http://ecx.images-amazon.com/images/I/51yWy%2BZk1vL._SL500_SS500_.jpg http://di1-4.shoppingshadow.com/images/pi/b4/5b/37/103251036-260x260-0-0_Dura+Block+Dura+Block+Long+Board+3+Piece+Durablock.jpg http://www.permagrit.com/images/rf5c.jpg Tim -- Tim Farrell - Aircrafters - Owner/Manager - (831) 722-9141 - www.aircraftersLLC.com ________________________________________________________________________________
Date: Mar 13, 2013
I turned most of the 'excess' into FG dust with a 4" angle grinder from Harbor freight. Used a fan to blow the dust out the shop door. Also used my air angle grinder with a 3" cutoff wheel ..... angled so I could 'swipe' at the edge for finer work. Dual action air sander with 6" pad worked great also. PVC pipe with stick on sandpaper makes a great tool for rounded corners ..... and comes in a lot of great sizes!! I've also used pill bottles, spice bottles etc. with stick on sandpaper. Dremel tool with carbide bits/cutoff wheels for tight spots. Linn On 3/13/2013 12:59 PM, Tim Farrell wrote: > > At the RV-10 Composite course we just did, we brought out a whole pile > of tools and settled on the following as being the best: > > Permagrit Composite cutoff wheel on a Die Grinder for trimming all but > the thickest parts > Angle Die Grinder with a 1.5 or 2" Drum sander took down the thick > stuff very well, use it when you've trimmed off all the flange are are > working on the actual frame. Maybe 80 grit? > A nice long block with 30 or 40 grit was great for cleaning up after > the sanding drum/wheel. > And a tungsten or permagrit bit for making small radius' was essential. > > Other traditional cut-off wheels were too slow and a straight line air > sander didn't have the power to be as fast as a hand block. Sanding > discs weren't as fast as the drums > > We didn't have, but would like to have tried, the composite jig saw > (although my experience with those in the past is that the composite > cut-off wheels are almost as fast and cut better lines), or the > composite tips for an oscillating tool. > > Here are pics of what worked: > > http://www.easycomposites.co.uk/Images/products/medium/permagrit-RD2.jpg > http://ecx.images-amazon.com/images/I/51yWy%2BZk1vL._SL500_SS500_.jpg > http://di1-4.shoppingshadow.com/images/pi/b4/5b/37/103251036-260x260-0-0_Dura+Block+Dura+Block+Long+Board+3+Piece+Durablock.jpg > > http://www.permagrit.com/images/rf5c.jpg > > > Tim > ________________________________________________________________________________
Date: Mar 13, 2013
I just purchased a carbide blade at a menards ( similar to lowes). It was manufactured by bosch and it said 30 grit, part number is U30RF1. It really did work well for initial trimming, thanks for the tip. Sent from my iPad On Mar 13, 2013, at 12:19 PM, Linn wrote: > > I turned most of the 'excess' into FG dust with a 4" angle grinder from Harbor freight. Used a fan to blow the dust out the shop door. > Also used my air angle grinder with a 3" cutoff wheel ..... angled so I could 'swipe' at the edge for finer work. > Dual action air sander with 6" pad worked great also. > PVC pipe with stick on sandpaper makes a great tool for rounded corners ..... and comes in a lot of great sizes!! > I've also used pill bottles, spice bottles etc. with stick on sandpaper. > Dremel tool with carbide bits/cutoff wheels for tight spots. > Linn > > On 3/13/2013 12:59 PM, Tim Farrell wrote: >> >> At the RV-10 Composite course we just did, we brought out a whole pile of tools and settled on the following as being the best: >> >> Permagrit Composite cutoff wheel on a Die Grinder for trimming all but the thickest parts >> Angle Die Grinder with a 1.5 or 2" Drum sander took down the thick stuff very well, use it when you've trimmed off all the flange are are working on the actual frame. Maybe 80 grit? >> A nice long block with 30 or 40 grit was great for cleaning up after the sanding drum/wheel. >> And a tungsten or permagrit bit for making small radius' was essential. >> >> Other traditional cut-off wheels were too slow and a straight line air sander didn't have the power to be as fast as a hand block. Sanding discs weren't as fast as the drums >> >> We didn't have, but would like to have tried, the composite jig saw (although my experience with those in the past is that the composite cut-off wheels are almost as fast and cut better lines), or the composite tips for an oscillating tool. >> >> Here are pics of what worked: >> >> http://www.easycomposites.co.uk/Images/products/medium/permagrit-RD2.jpg >> http://ecx.images-amazon.com/images/I/51yWy%2BZk1vL._SL500_SS500_.jpg >> http://di1-4.shoppingshadow.com/images/pi/b4/5b/37/103251036-260x260-0-0_Dura+Block+Dura+Block+Long+Board+3+Piece+Durablock.jpg >> http://www.permagrit.com/images/rf5c.jpg >> >> >> Tim >> > > > > > ________________________________________________________________________________
Date: Mar 13, 2013
Would there be any temperature concerns for the antennas being located in the engine compartment? -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle Sent: Wednesday, March 13, 2013 12:43 PM Subject: RV10-List: Re: GPS Shelf FWF At 11:55 AM 3/12/2013 Tuesday, you wrote: >Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF that had 4+ GPS antenna mounted. I recall the shelf was painted black and connected the firewall with the motor mount? Can the owner share the photo again with the group? I need something similar for my 8A and cannot locate the post. > >Thanks, >Robin Hi Robin, Here are some pictures of how I did the GPS antenna installations on my RV-8. Works great. Blast tubes keeps them cool. No unsightly pucks on the dash! Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode ________________________________________________________________________________
Date: Mar 13, 2013
Anyone have an address for Steven (or whoever sells these seat adjustment levers)? The email address on the website bounced. I might get one for my right seat. thanks.. -Rob On Tue, Mar 12, 2013 at 9:30 PM, Rob Kochman wrote: > Robin, I'm talking about the other handle, though I was thinking about > replacing the other one. That said, I don't adjust it frequently. > Thanks... > > > On Tue, Mar 12, 2013 at 8:23 PM, Robin Marks wrote: > >> Rob,**** >> >> Not sure you are speaking of this handle but the photo attached is of my >> front seat position adjustment handles prior to install. I have always had >> them and thought they were a huge improvement over the stock design. I am >> not sure how beneficial they would be for a rear passenger to access for >> emergency egress. If you were to design a set yourself you could place a >> rear facing handle extension that one pushes down?**** >> >> The first generation handle extensions were made of thin walled square >> tubing. Thicker tubing improved the longevity substantially.**** >> >> ** ** >> >> Good luck,**** >> >> Robin**** >> >> ** ** >> >> *From:* owner-rv10-list-server(at)matronics.com [mailto: >> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman >> *Sent:* Tuesday, March 12, 2013 5:44 PM >> *To:* rv10-list >> *Subject:* RV10-List: seat back handle improvement?**** >> >> ** ** >> >> Anyone know of a better solution for the seat back handle? I'm concerned >> that the handle may be hard to reach quickly in an emergency, which could >> slow down egress from the rear seats. Thanks...**** >> >> ** ** >> >> -Rob >> **** >> >> ** ** >> >> -- **** >> >> Rob Kochman >> RV-10 Flying since March 2011**** >> >> Woodinville, WA**** >> >> http://kochman.net/N819K**** >> >> * * >> >> * * >> >> ==============**** V10-List Email Forum -**** > :p> /o:p> tor?RV10-List"> >> http://www.matronics.com/Navigator?RV10-List**** ==============****bsp; - MATRONICS WEB FORUMS - >> **** :p> tp://forums.matronics.com**** ==============**** bsp; - List >> Contribution Web Site -**** e> bsp; -Matt Dralle, List >> Admin.**** bution">http://www.matronics.com/contribution****============= >> **** >> >> * * >> >> ------------------------------ >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> r> >> > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 13, 2013
There are two email addresses on the site. On is rvsteve and the other is sales. One of them always bounces, but the other does not. I have had the best luck calling Steve on the phone. He is sometimes hard to get hold of. David Maib 40559 Flying 635 hours On Mar 13, 2013, at 2:43 PM, Rob Kochman wrote: Anyone have an address for Steven (or whoever sells these seat adjustment levers)? The email address on the website bounced. I might get one for my right seat. thanks.. -Rob On Tue, Mar 12, 2013 at 9:30 PM, Rob Kochman wrote: Robin, I'm talking about the other handle, though I was thinking about replacing the other one. That said, I don't adjust it frequently. Thanks... On Tue, Mar 12, 2013 at 8:23 PM, Robin Marks wrote: Rob, Not sure you are speaking of this handle but the photo attached is of my front seat position adjustment handles prior to install. I have always had them and thought they were a huge improvement over the stock design. I am not sure how beneficial they would be for a rear passenger to access for emergency egress. If you were to design a set yourself you could place a rear facing handle extension that one pushes down? The first generation handle extensions were made of thin walled square tubing. Thicker tubing improved the longevity substantially. Good luck, Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Tuesday, March 12, 2013 5:44 PM Subject: RV10-List: seat back handle improvement? Anyone know of a better solution for the seat back handle? I'm concerned that the handle may be hard to reach quickly in an emergency, which could slow down egress from the rear seats. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============ == bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= No virus found in this message. Checked by AVG - www.avg.com r> -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 13, 2013
have 110 hours on mine and had the same set up in my RV-4 for 350 hours with no issues. Not saying it won't be a problem, but no issues for me so far. YMMV -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) On Mar 13, 2013, at 1:51 PM, "William Greenley" wrote: > > Would there be any temperature concerns for the antennas being located in > the engine compartment? > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Wednesday, March 13, 2013 12:43 PM > To: rv10-list(at)matronics.com; rv-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV10-List: Re: GPS Shelf FWF > > At 11:55 AM 3/12/2013 Tuesday, you wrote: >> Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF > that had 4+ GPS antenna mounted. I recall the shelf was painted black and > connected the firewall with the motor mount? Can the owner share the photo > again with the group? I need something similar for my 8A and cannot locate > the post. >> >> Thanks, >> Robin > > Hi Robin, > > Here are some pictures of how I did the GPS antenna installations on my > RV-8. Works great. Blast tubes keeps them cool. No unsightly pucks on the > dash! > > Matt > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer > Mode > > > > > ________________________________________________________________________________
Date: Mar 13, 2013
750 hours in RV4 470 so far in a 10 so far so good. Dick Sipp -----Original Message----- From: Michael Kraus Sent: Wednesday, March 13, 2013 3:11 PM Subject: Re: RV10-List: Re: GPS Shelf FWF have 110 hours on mine and had the same set up in my RV-4 for 350 hours with no issues. Not saying it won't be a problem, but no issues for me so far. YMMV -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) On Mar 13, 2013, at 1:51 PM, "William Greenley" wrote: > > Would there be any temperature concerns for the antennas being located in > the engine compartment? > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Matt Dralle > Sent: Wednesday, March 13, 2013 12:43 PM > To: rv10-list(at)matronics.com; rv-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV10-List: Re: GPS Shelf FWF > > At 11:55 AM 3/12/2013 Tuesday, you wrote: >> Someone on the RV-10 list shared a photo of their GPS shelf mounted FWF > that had 4+ GPS antenna mounted. I recall the shelf was painted black and > connected the firewall with the motor mount? Can the owner share the photo > again with the group? I need something similar for my 8A and cannot locate > the post. >> >> Thanks, >> Robin > > Hi Robin, > > Here are some pictures of how I did the GPS antenna installations on my > RV-8. Works great. Blast tubes keeps them cool. No unsightly pucks on > the > dash! > > Matt > > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 140+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer > Mode > > ________________________________________________________________________________
Date: Mar 14, 2013
I'd be interested in a set. Alan N668G Sent from my iPhone On Mar 13, 2013, at 11:23 AM, Dave Saylor wrote: > They're not as slick as Robin's but these 2" extensions work a lot better than the stock T handle position. They're pretty easy to make. If anybody wants some let me know and we'll make a batch. > > > > > > --Dave > > >
Date: Mar 14, 2013
I'd also be interested, Dave. -------- David Halmos RV-10 Cowl and baffles Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396236#396236 ________________________________________________________________________________
Date: Mar 14, 2013
Me too. Rob Kermanj Sent from my iPhone On Mar 14, 2013, at 8:50 AM, Alan Mekler MD wrote: > > I'd be interested in a set. > Alan > N668G > > Sent from my iPhone > > On Mar 13, 2013, at 11:23 AM, Dave Saylor wrote: > >> They're not as slick as Robin's but these 2" extensions work a lot better than the stock T handle position. They're pretty easy to make. If anybody wants some let me know and we'll make a batch. >> >> >> >> >> >> --Dave >> >> >>
Date: Mar 14, 2013
Has anybody thought about a modification where you don't have to painfully remove the four bolts so the whole seat can be removed? Maybe some nutplates or something? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396273#396273 ________________________________________________________________________________
Date: Mar 14, 2013
I put nutplates on the handle. Makes it a lot easier. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Thursday, March 14, 2013 4:27 PM Subject: RV10-List: Re: Seat adjusters --> Has anybody thought about a modification where you don't have to painfully remove the four bolts so the whole seat can be removed? Maybe some nutplates or something? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396273#396273 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: FW: Bill's polar flight - not RV related
Date: Mar 14, 2013
A neighbor at Dogwood (VA42) took off this morning to circumnavigate the globe, via the poles. Bill broke the distance record a couple of weeks ago, flying non-stop from Guam to Jacksonville Florida. His modified Lancair 4 holds 360 gallons of fuel, and the inherently efficient design allows him to cruise at 180 knots averaging less than 9gph fuel burn. Use the below link to follow his flight. He is up linking a data point every four minutes. His first refuel is southern Brazil, then the southern tip of Argentina, from there over the South Pole to New Zealand, then Hawaii, Fairbanks, then over the North Pole back to Bangor Maine. Carl Begin forwarded message: From: sh < <mailto:kitplanesue(at)gmail.com> kitplanesue(at)gmail.com> Subject: Bill's polar flight Good morning, In case you're interested in following Bill's attempt to fly around both poles, here's the web link: https://go.spidertracks.com/fleetpro/public/zqpilot There are 4 small icons at the top left, the airplane icon puts a panel at the left that shows what ZQ is doing. Use the plus to zoom in or the minus to zoom out. You use the pile of papers icon to determine the view. Try hybrid view. If you click the X, it will take you to a screen where you select Tracks and then click on the top latest date. Once he's flying this will get you Bill's track as it is reported by Spidertracks. (it also shows him taxiing while on the ground) You must click on the last little teardrop to get his latest position info in a box on the screen. As he gets closer to some interesting landmarks you can zoom in. Let's all keep our fingers crossed for a safe journey, Sue ________________________________________________________________________________
Date: Mar 14, 2013
Subject: Trimming Push-Pull Cables To Length
Looking for help on the best way to go about trimming the length of the CT A-740 push-pull cables. That spiral material is a bugger to cut. Maybe using a tube cutter? Thanks, -Sean #40303 (fab) ________________________________________________________________________________
Date: Mar 14, 2013
Dremel cutoff wheel.. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Thursday, March 14, 2013 5:43 PM Subject: RV10-List: Trimming Push-Pull Cables To Length Looking for help on the best way to go about trimming the length of the CT A-740 push-pull cables. That spiral material is a bugger to cut. Maybe using a tube cutter? Thanks, -Sean #40303 (fab) ________________________________________________________________________________
Subject: Re: FW: Bill's polar flight - not RV related
Date: Mar 14, 2013
http://www.eaa.org/news/2013/2013-03-05_long-distance-lancair.asp Happen to see a write up on him today on eaa.org From: Carl Froehlich Sent: Thursday, March 14, 2013 4:25 PM rv8-list(at)matronics.com Subject: RV10-List: FW: Bill's polar flight - not RV related A neighbor at Dogwood (VA42) took off this morning to circumnavigate the globe, via the poles. Bill broke the distance record a couple of weeks ago, flying non-stop from Guam to Jacksonville Florida. His modified Lancair 4 holds 360 gallons of fuel, and the inherently efficient design allows him to cruise at 180 knots averaging less than 9gph fuel burn. Use the below link to follow his flight. He is up linking a data point every four minutes. His first refuel is southern Brazil, then the southern tip of Argentina, from there over the South Pole to New Zealand, then Hawaii, Fairbanks, then over the North Pole back to Bangor Maine. Carl Begin forwarded message: From: sh <kitplanesue(at)gmail.com> Subject: Bill's polar flight Good morning, In case you're interested in following Bill's attempt to fly around both poles, here's the web link: https://go.spidertracks.com/fleetpro/public/zqpilot There are 4 small icons at the top left, the airplane icon puts a panel at the left that shows what ZQ is doing. Use the plus to zoom in or the minus to zoom out. You use the pile of papers icon to determine the view. Try hybrid view. If you click the X, it will take you to a screen where you select Tracks and then click on the top latest date. Once he's flying this will get you Bill's track as it is reported by Spidertracks. (it also shows him taxiing while on the ground) You must click on the last little teardrop to get his latest position info in a box on the screen. As he gets closer to some interesting landmarks you can zoom in. Let's all keep our fingers crossed for a safe journey, Sue ________________________________________________________________________________
Date: Mar 14, 2013
Along the same lines I put helicoils in the handles but I probably wouldn't do that again. If nut plates worked for Rene then I'd try that. It's nice to have the bolt heads on the inside an no other hardware to deal with. On Thursday, March 14, 2013, Rene Felker wrote: > > I put nutplates on the handle. Makes it a lot easier. > > Rene' Felker > N423CF > 801-721-6080 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman > Sent: Thursday, March 14, 2013 4:27 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Seat adjusters > > --> > > Has anybody thought about a modification where you don't have to painfully > remove the four bolts so the whole seat can be removed? Maybe some > nutplates > or something? > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396273#396273 > > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 15, 2013
We installed two nut plates where the rear stops are bolted in. This way by removing the two -4 bolts that hold the rear stop the seat can be removed. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396314#396314 ________________________________________________________________________________
Date: Mar 15, 2013
Subject: Re: Trimming Push-Pull Cables To Length
Ok, I was informed of something that wasn't obvious to me. Pull the cable wire back, then just cut through it at the desired location. I was trying to figure out how to cut the spiral without damaging the internal cable wire. Sometimes I miss the obvious. Thanks Joe... -Sean #40303 ________________________________________________________________________________
Date: Mar 15, 2013
Just be careful, some cables have a small ball and maybe a spring in them for the detents. Just make sure you don't lose it. -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) On Mar 15, 2013, at 10:04 AM, Sean Stephens wrote: > > Ok, I was informed of something that wasn't obvious to me. Pull the cable wire back, then just cut through it at the desired location. I was trying to figure out how to cut the spiral without damaging the internal cable wire. Sometimes I miss the obvious. Thanks Joe... > > -Sean #40303 > > > > > ________________________________________________________________________________
Subject: Re: RV10-List Digest: 10 Msgs - 03/14/13
Date: Mar 15, 2013
A set here, too. Curtis Groote On Mar 15, 2013, at 12:01 AM, RV10-List Digest Server wrote: > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV10-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV10-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-03-14&Archive=RV10 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-03-14&Archive=RV10 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV10-List Digest Archive > --- > Total Messages Posted Thu 03/14/13: 10 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 05:51 AM - Re: Seat adjusters (Alan Mekler MD) > 2. 06:48 AM - Re: Seat adjusters (dhmoose) > 3. 07:00 AM - Re: Seat adjusters (Rob Kermanj) > 4. 03:27 PM - Re: Seat adjusters (johngoodman) > 5. 03:35 PM - Re: Re: Seat adjusters (Rene Felker) > 6. 04:26 PM - FW: Bill's polar flight - not RV related (Carl Froehlich) > 7. 04:43 PM - Trimming Push-Pull Cables To Length (Sean Stephens) > 8. 04:56 PM - Re: Trimming Push-Pull Cables To Length (Rene Felker) > 9. 06:26 PM - Re: FW: Bill's polar flight - not RV related (Pascal) > 10. 07:55 PM - Re: Re: Seat adjusters (Dave Saylor) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: Re: RV10-List: Seat adjusters > From: Alan Mekler MD <amekler(at)metrocast.net> > > > I'd be interested in a set. > Alan > N668G > > Sent from my iPhone > > On Mar 13, 2013, at 11:23 AM, Dave Saylor wrote: > >> They're not as slick as Robin's but these 2" extensions work a lot better than > the stock T handle position. They're pretty easy to make. If anybody wants > some let me know and we'll make a batch. >> >> >> >> >> >> --Dave >> >> >>
> > > ________________________________ Message 2 _____________________________________ > > > Subject: RV10-List: Re: Seat adjusters > From: "dhmoose" <dhmoose(at)yahoo.com> > > > I'd also be interested, Dave. > > -------- > David Halmos > RV-10 > Cowl and baffles > Portland, OR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396236#396236 > > > ________________________________ Message 3 _____________________________________ > > > Subject: Re: RV10-List: Seat adjusters > From: Rob Kermanj <flysrv10(at)gmail.com> > > > Me too. > > Rob Kermanj > Sent from my iPhone > > On Mar 14, 2013, at 8:50 AM, Alan Mekler MD wrote: > >> >> I'd be interested in a set. >> Alan >> N668G >> >> Sent from my iPhone >> >> On Mar 13, 2013, at 11:23 AM, Dave Saylor > wrote: >> >>> They're not as slick as Robin's but these 2" extensions work a lot better than > the stock T handle position. They're pretty easy to make. If anybody wants > some let me know and we'll make a batch. >>> >>> >>> >>> >>> >>> --Dave >>> >>> >>>
> > > ________________________________ Message 4 _____________________________________ > > > Subject: RV10-List: Re: Seat adjusters > From: "johngoodman" <johngoodman(at)earthlink.net> > > > Has anybody thought about a modification where you don't have to painfully remove > the four bolts so the whole seat can be removed? Maybe some nutplates or something? > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396273#396273 > > > ________________________________ Message 5 _____________________________________ > > > From: "Rene Felker" <rene(at)felker.com> > Subject: RE: RV10-List: Re: Seat adjusters > > > I put nutplates on the handle. Makes it a lot easier. > > Rene' Felker > N423CF > 801-721-6080 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman > Sent: Thursday, March 14, 2013 4:27 PM > Subject: RV10-List: Re: Seat adjusters > > --> > > Has anybody thought about a modification where you don't have to painfully > remove the four bolts so the whole seat can be removed? Maybe some nutplates > or something? > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396273#396273 > > > ________________________________ Message 6 _____________________________________ > > > From: "Carl Froehlich" <carl.froehlich(at)verizon.net> > Subject: RV10-List: FW: Bill's polar flight - not RV related > > A neighbor at Dogwood (VA42) took off this morning to circumnavigate the > globe, via the poles. Bill broke the distance record a couple of weeks ago, > flying non-stop from Guam to Jacksonville Florida. His modified Lancair 4 > holds 360 gallons of fuel, and the inherently efficient design allows him to > cruise at 180 knots averaging less than 9gph fuel burn. > > Use the below link to follow his flight. He is up linking a data point > every four minutes. His first refuel is southern Brazil, then the southern > tip of Argentina, from there over the South Pole to New Zealand, then > Hawaii, Fairbanks, then over the North Pole back to Bangor Maine. > > Carl > > > Begin forwarded message: > > From: sh < <mailto:kitplanesue(at)gmail.com> kitplanesue(at)gmail.com> > > Subject: Bill's polar flight > > Good morning, > > In case you're interested in following Bill's attempt to fly around both > poles, > here's the web link: > > > https://go.spidertracks.com/fleetpro/public/zqpilot > > There are 4 small icons at the top left, the airplane icon puts a panel at > the left that shows what ZQ is doing. > Use the plus to zoom in or the minus to zoom out. You use the pile of papers > icon to determine the view. Try hybrid view. > > If you click the X, it will take you to a screen where you select Tracks and > then click on the top latest date. > Once he's flying this will get you Bill's track as it is reported by > Spidertracks. (it also shows him taxiing while on the ground) > You must click on the last little teardrop to get his latest position info > in a box on the screen. > As he gets closer to some interesting landmarks you can zoom in. > > Let's all keep our fingers crossed for a safe journey, > > Sue > > > ________________________________ Message 7 _____________________________________ > > > From: Sean Stephens <sean(at)stephensville.com> > Subject: RV10-List: Trimming Push-Pull Cables To Length > > > Looking for help on the best way to go about trimming the length of the > CT A-740 push-pull cables. That spiral material is a bugger to cut. > Maybe using a tube cutter? > > Thanks, > > -Sean #40303 (fab) > > > ________________________________ Message 8 _____________________________________ > > > From: "Rene Felker" <rene(at)felker.com> > Subject: RE: RV10-List: Trimming Push-Pull Cables To Length > > > Dremel cutoff wheel.. > > Rene' Felker > N423CF > 801-721-6080 > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens > Sent: Thursday, March 14, 2013 5:43 PM > Subject: RV10-List: Trimming Push-Pull Cables To Length > > > Looking for help on the best way to go about trimming the length of the CT > A-740 push-pull cables. That spiral material is a bugger to cut. > Maybe using a tube cutter? > > Thanks, > > -Sean #40303 (fab) > > > ________________________________ Message 9 _____________________________________ > > > From: "Pascal" <rv10flyer(at)live.com> > Subject: Re: RV10-List: FW: Bill's polar flight - not RV related > > http://www.eaa.org/news/2013/2013-03-05_long-distance-lancair.asp > > Happen to see a write up on him today on eaa.org > > From: Carl Froehlich > Sent: Thursday, March 14, 2013 4:25 PM > rv8-list(at)matronics.com > Subject: RV10-List: FW: Bill's polar flight - not RV related > > A neighbor at Dogwood (VA42) took off this morning to circumnavigate the > globe, via the poles. Bill broke the distance record a couple of weeks > ago, flying non-stop from Guam to Jacksonville Florida. His modified > Lancair 4 holds 360 gallons of fuel, and the inherently efficient design > allows him to cruise at 180 knots averaging less than 9gph fuel burn. > > Use the below link to follow his flight. He is up linking a data point > every four minutes. His first refuel is southern Brazil, then the > southern tip of Argentina, from there over the South Pole to New > Zealand, then Hawaii, Fairbanks, then over the North Pole back to Bangor > Maine. > > Carl > > > Begin forwarded message: > > From: sh <kitplanesue(at)gmail.com> > > Subject: Bill's polar flight > > Good morning, > > In case you're interested in following Bill's attempt to fly around both > poles, > here's the web link: > > https://go.spidertracks.com/fleetpro/public/zqpilot > > There are 4 small icons at the top left, the airplane icon puts a panel > at the left that shows what ZQ is doing. > Use the plus to zoom in or the minus to zoom out. You use the pile of > papers icon to determine the view. Try hybrid view. > > If you click the X, it will take you to a screen where you select Tracks > and then click on the top latest date. > Once he's flying this will get you Bill's track as it is reported by > Spidertracks. (it also shows him taxiing while on the ground) > You must click on the last little teardrop to get his latest position > info in a box on the screen. > As he gets closer to some interesting landmarks you can zoom in. > > Let's all keep our fingers crossed for a safe journey, > > Sue > > > ________________________________ Message 10 ____________________________________ > > > From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com> > Subject: Re: RV10-List: Re: Seat adjusters > > Along the same lines I put helicoils in the handles but I probably wouldn't > do that again. If nut plates worked for Rene then I'd try that. It's nice > to have the bolt heads on the inside an no other hardware to deal with. > > On Thursday, March 14, 2013, Rene Felker wrote: > >> >> I put nutplates on the handle. Makes it a lot easier. >> >> Rene' Felker >> N423CF >> 801-721-6080 >> >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman >> Sent: Thursday, March 14, 2013 4:27 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Re: Seat adjusters >> >> --> >> >> Has anybody thought about a modification where you don't have to painfully >> remove the four bolts so the whole seat can be removed? Maybe some >> nutplates >> or something? >> John >> >> -------- >> #40572 Phase One complete and flying. >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=396273#396273 > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2013
Photos? Thanks, Jay jkreidler wrote: > We installed two nut plates where the rear stops are bolted in. This way by removing the two -4 bolts that hold the rear stop the seat can be removed. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396355#396355 ________________________________________________________________________________
Date: Mar 16, 2013
Sorry, I don't have any photos and will not be able to get any in the near future. So I will offer a better description, the outside seat rails have notched tracks where the pin on the t-handle engages to hold the seat in position. On the aft end of the notched piece there is a stop that keeps the seat from sliding off the back of the rails. It is a stop that the pin from the t-handle hits if you lift up the handle and slide the seat all the way aft. The stop is held on with two AN-4 bolts, the plans call for nuts to be installed under the seat pan. Instead of using nuts we installed nut-plates. So by removing the two bolts the rear stop can be removed, then just lift up on the handle and slide the seat off the rail. Hope that helps - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396374#396374 ________________________________________________________________________________
Date: Mar 16, 2013
jkreidler wrote: > Sorry, I don't have any photos and will not be able to get any in the near future. So I will offer a better description, the outside seat rails have notched tracks where the pin on the t-handle engages to hold the seat in position. On the aft end of the notched piece there is a stop that keeps the seat from sliding off the back of the rails. It is a stop that the pin from the t-handle hits if you lift up the handle and slide the seat all the way aft. The stop is held on with two AN-4 bolts, the plans call for nuts to be installed under the seat pan. Instead of using nuts we installed nut-plates. So by removing the two bolts the rear stop can be removed, then just lift up on the handle and slide the seat off the rail. Hope that helps - Jason That sounds like a great idea. Wish I'd thought about that when I was building. I'm going to take a look next time the seat is out and see if I can perhaps retrofit. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396376#396376 ________________________________________________________________________________
Subject: Re: Bill's polar flight - not RV related
Date: Mar 16, 2013
Is this cool or what? Bill is a VERY Daring fellow. Note that he is flying out over the Atlantic, not much of a back up plan there if the engine quits. We must pray that all of his equipment holds together over Antarctica. Even this month it is very cold down there on the plateau of the South Pole. Best wishes and Godspeed. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396396#396396 ________________________________________________________________________________
Subject: Square footage for painting
Date: Mar 18, 2013
Anybody calc out a square footage or similar area dimension for painting materials/cost purposes? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396489#396489 ________________________________________________________________________________
Subject: Re: Square footage for painting
Date: Mar 18, 2013
from Tims site I used about 3 gallons of white, but I could have used a whole lot more paint than I did. My goal was to paint the plane enough to hold me over for a few years than get it redone, so 4-5 gallons may be more appropriate. -----Original Message----- From: woxofswa Sent: Monday, March 18, 2013 9:53 AM Subject: RV10-List: Square footage for painting Anybody calc out a square footage or similar area dimension for painting materials/cost purposes? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396489#396489 ________________________________________________________________________________
Date: Mar 18, 2013
No, but I can tell you how much Sherwin Williams Jetglo and Acryglo I used. Sent from my iPhone On Mar 18, 2013, at 12:53 PM, "woxofswa" wrote: Anybody calc out a square footage or similar area dimension for painting materials/cost purposes? Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396489#396489 ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Mar 18, 2013
For high end products (PPG multicolor base/clear coat), $4000 in material is a good guess - a little less if you know what you are doing. The hangar paint booth was 12'X26'x8' tall, 2x4 frame with plastic covering (wings and tail not on the plane for paint). I live near a PPG store so I bought paint as needed, but always made sure I had enough for whatever section I was doing. Bottom line - if you can find someone to paint your plane for under $12K, jump at it. The RV-10 is a bear to paint. I did the RV-8A with the same base/clear coat products but the shear size of the RV-10 made for many hours of sanding and rework for me - a typical amateur painter. Carl On Mar 18, 2013, at 12:53 PM, "woxofswa" wrote: > > Anybody calc out a square footage or similar area dimension for painting materials/cost purposes? > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396489#396489 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 18, 2013
Granted I'm no pro, but if someone is on a budget, I painted my whole plane for under $1.5K, that included my paint gun and materials (sand paper). I do not have a professional looking plane by ANY means, but it does the job of protecting it. Because I painted in my garage, in California I was limited to only a waterbased paint. I used Stewarts system with good enough success- http://www.stewartsystems.aero/default.aspx. A good painter, like Don McDonald made my recoated wing looks very nice, so a good painter can get a nice job done with this paint. Spray painting is actually a lot of fun! I did it myself and would do it again. Worse case, a professional will take your job and repaint with less paint and make it look really good. An example, a local plane had a terrible paint job and after 1 week at a good shop it came back looking great, cost $4000K since all the prep involved was sanding for 2 coats of paint. If I can paint the plane in a garage , with no prior experience in spray painting, anyone can do it. -----Original Message----- From: Carl Froehlich Sent: Monday, March 18, 2013 2:31 PM Subject: Re: RV10-List: Square footage for painting For high end products (PPG multicolor base/clear coat), $4000 in material is a good guess - a little less if you know what you are doing. The hangar paint booth was 12'X26'x8' tall, 2x4 frame with plastic covering (wings and tail not on the plane for paint). I live near a PPG store so I bought paint as needed, but always made sure I had enough for whatever section I was doing. Bottom line - if you can find someone to paint your plane for under $12K, jump at it. The RV-10 is a bear to paint. I did the RV-8A with the same base/clear coat products but the shear size of the RV-10 made for many hours of sanding and rework for me - a typical amateur painter. Carl On Mar 18, 2013, at 12:53 PM, "woxofswa" wrote: > > Anybody calc out a square footage or similar area dimension for painting > materials/cost purposes? > > Thanks in advance. > > -------- > Myron Nelson
February 20, 2013 - March 18, 2013
RV10-Archive.digest.vol-jg
