RV10-Archive.digest.vol-jh
March 18, 2013 - April 05, 2013
      > Mesa, AZ
      > Emp completed, QB wings completed, legacy build fuse on gear.  Finishing
      > kit and FWF kit in progress.
      > http://forums.matronics.com/viewtopic.php?p=396489#396489
Subject: Re: Square footage for painting
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Mar 18, 2013
The paint adherence is only as good as the surface preparation. The hardest part of painting is the surface preparation. Once that is done, painting i s fairly quick. I painted my RV-4 and was very happy with it. Apparently Van's is too, beca use here it is! http://vansaircraft.com/public/rv4.htm But for my RV-10, I wasn't going to touch it..... especially after all that f iberglass work.... I knew how big of a job the -4 was and the -10 is even b igger.... But, if painting your own plane is on your bucket list, this might be your o nly opportunity!! :-) -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) On Mar 18, 2013, at 6:01 PM, "Pascal" wrote: > > Granted I'm no pro, but if someone is on a budget, I painted my whole plan e for under $1.5K, that included my paint gun and materials (sand paper). I d o not have a professional looking plane by ANY means, but it does the job of protecting it. Because I painted in my garage, in California I was limited t o only a waterbased paint. I used Stewarts system with good enough success- h ttp://www.stewartsystems.aero/default.aspx. A good painter, like Don McDonal d made my recoated wing looks very nice, so a good painter can get a nice jo b done with this paint. Spray painting is actually a lot of fun! > I did it myself and would do it again. Worse case, a professional will tak e your job and repaint with less paint and make it look really good. An exam ple, a local plane had a terrible paint job and after 1 week at a good shop i t came back looking great, cost $4000K since all the prep involved was sandi ng for 2 coats of paint. > If I can paint the plane in a garage , with no prior experience in spray p ainting, anyone can do it. > > > > -----Original Message----- From: Carl Froehlich > Sent: Monday, March 18, 2013 2:31 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Square footage for painting > t> > > For high end products (PPG multicolor base/clear coat), $4000 in material i s a good guess - a little less if you know what you are doing. The hangar p aint booth was 12'X26'x8' tall, 2x4 frame with plastic covering (wings and t ail not on the plane for paint). > > I live near a PPG store so I bought paint as needed, but always made sure I had enough for whatever section I was doing. > > Bottom line - if you can find someone to paint your plane for under $12K, j ump at it. The RV-10 is a bear to paint. I did the RV-8A with the same bas e/clear coat products but the shear size of the RV-10 made for many hours of sanding and rework for me - a typical amateur painter. > > Carl > > On Mar 18, 2013, at 12:53 PM, "woxofswa" wrote: > >> >> Anybody calc out a square footage or similar area dimension for painting m aterials/cost purposes? >> >> Thanks in advance. >> >> -------- >> Myron Nelson >> Mesa, AZ >> Emp completed, QB wings completed, legacy build fuse on gear. Finishing k it and FWF kit in progress. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=396489#396489 > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Mar 18, 2013
I'll add to my previous email...... I spent about $3,700 on paint from a Sherwin Williams distributor. $300 on materials like tape, paper, mek, plastic, etc. The painter spent 99 hours and my wife and I probably put in another 30 hours or so each assisting with the masking and tape. Most the time was consumed by masking for the four colors And the compound curves of the trim lines. Bob Sent from my iPad On Mar 18, 2013, at 5:31 PM, Carl Froehlich wrote: > > For high end products (PPG multicolor base/clear coat), $4000 in material is a good guess - a little less if you know what you are doing. The hangar paint booth was 12'X26'x8' tall, 2x4 frame with plastic covering (wings and tail not on the plane for paint). > > I live near a PPG store so I bought paint as needed, but always made sure I had enough for whatever section I was doing. > > Bottom line - if you can find someone to paint your plane for under $12K, jump at it. The RV-10 is a bear to paint. I did the RV-8A with the same base/clear coat products but the shear size of the RV-10 made for many hours of sanding and rework for me - a typical amateur painter. > > Carl > > On Mar 18, 2013, at 12:53 PM, "woxofswa" wrote: > >> >> Anybody calc out a square footage or similar area dimension for painting materials/cost purposes? >> >> Thanks in advance. >> >> -------- >> Myron Nelson >> Mesa, AZ >> Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=396489#396489 > > > > > ________________________________________________________________________________
Date: Mar 18, 2013
Thanks for the input. What I was actually doing was querying a couple of auto shops near the airport to paint the pieces for me to final assemble. They were asking for approximate square footage since RV10 meant nothing to them, but a couple of them have done aircraft projects before. In the end, I decided against the auto shop idea. I still might self paint for the challenge, but for the time it would take me I can easily pick up extra trips at work and be money and time ahead. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396555#396555 ________________________________________________________________________________
Subject: aircraft painting
Date: Mar 19, 2013
Just a data point. My aircraft was the first painted by Crider in Mena; cost including ferry the aircraft in and Mena pickup, took 10 days and about $6000; that was $4500 for painting and $1500 for my expenses; Paint (Azko Nobel) was a base Jetglo Matterhorn white and trim in Cranberry craze Acryglo. That was July 2008; just received another quart of white and hardener at no charge to repaint leg fairings and wheel pants while installing new mains from Matco. N46007 670TT ________________________________________________________________________________
Subject: Re: aircraft painting
Date: Mar 19, 2013
That was a good deal! Looks like paint went up these past five years. Specific costs from my paint job JetGlo Matterhorn White was $145/gal and the hardener was $163/gal. I use the following ArcyGlo colors Phantom Gray metallic was$145/gal Seminole Red Metallic was$126/qt Silver Metallic was $126/qt Hardener was$54/qt Stabilizer was $37/pint Clear coat was$103/gal Primer was $157/gal PrimerAdduct was $96/gal I priced several PPG products which cost about the same locally. Like I mentioned previously, I spent about $3,700 just for the paint. It wa s clearly sticker shock to me. I hadn't realized that paint was so expensiv e until I started getting quotes. Bob Sent from my iPhone On Mar 19, 2013, at 8:31 AM, "DLM" wrote: Just a data point. My aircraft was the first painted by Crider in Mena; cost including ferry the aircraft in and Mena pickup, took 10 days and about $60 00; that was $4500 for painting and $1500 for my expenses; Paint (Azko Nobel ) was a base Jetglo Matterhorn white and trim in Cranberry craze Acryglo. Th at was July 2008; just received another quart of white and hardener at no ch arge to repaint leg fairings and wheel pants while installing new mains from Matco. N46007 670TT ________________________________________________________________________________
Date: Mar 19, 2013
I used a high end auto shop to do the painting on my RV-12, which is much more amenable to auto shop work with its removable wings, and all of the components will fit in a car-sized paint booth. The shop owner was a Rans builder and he had his employees do his airplane first. The result on my -12 looked great at first but I discovered later they did not alodine aluminum as agreed upon since they weren't familiar with alodine and didn't think it necessary, some alclad areas were not sufficiently scuffed to get good adhesion and the paint started lifting off some components like the canopy skirts after about a year (again because they weren't accustomed to vehicles built with metals having a coat of pure aluminum). And in trying to make a thick automotive wet look on all those pop rivets they generally put too much paint on the plane, and had rivet-associated runs. The cost was over $10K. But it was very cool to be able to send the wings over locally to get painted while I was still working on the fuselage, etc. If I had it to do again I would use the same pro aircraft shop that painted my RV-10, which was AOG painting in Mena, Arkansas (http://www.aogpaint.com/ ). They did a great job with JetGlo on a complex curvy RV-10 design (see http://faculty.washington.edu/dmasys/N104LDinflight.jpg ) at an amazingly low price. So I learned there are some 'cultural' issues when having auto paint shops work on airplanes, even very good shops such as this one was/is. Caveat emptor... -Dan Masys RV-10 N104LD RV-12 N122LD >Subject: RV10-List: Re: Square footage for painting >From: "woxofswa" <woxof(at)aol.com> >Thanks for the input. What I was actually doing was querying a couple of auto >shops near the airport to paint the pieces for me to final assemble. They were >asking for approximate square footage since RV10 meant nothing to them, but >a couple of them have done aircraft projects before. >In the end, I decided against the auto shop idea. I still might self paint for >the challenge, but for the time it would take me I can easily pick up extra trips >at work and be money and time ahead. >-------- >Myron Nelson >Mesa, AZ >Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and >FWF kit in progress. ________________________________________________________________________________
Date: Mar 19, 2013
Just looking into this also as I'm 90% done and 90% to go. :) One thing I was curious about is does the builder normally do the control surface removal and re-assembly at the paint shop? I think I would want to just to have piece of mind that it was put back together per plans. -Sean #40303 (fwf) On 3/19/13 9:42 AM, Dan Masys wrote: > > I used a high end auto shop to do the painting on my RV-12, which is much > more amenable to auto shop work with its removable wings, and all of the > components will fit in a car-sized paint booth. The shop owner was a Rans > builder and he had his employees do his airplane first. The result on my > -12 looked great at first but I discovered later they did not alodine > aluminum as agreed upon since they weren't familiar with alodine and didn't > think it necessary, some alclad areas were not sufficiently scuffed to get > good adhesion and the paint started lifting off some components like the > canopy skirts after about a year (again because they weren't accustomed to > vehicles built with metals having a coat of pure aluminum). And in trying > to make a thick automotive wet look on all those pop rivets they generally > put too much paint on the plane, and had rivet-associated runs. The cost > was over $10K. But it was very cool to be able to send the wings over > locally to get painted while I was still working on the fuselage, etc. > > If I had it to do again I would use the same pro aircraft shop that painted > my RV-10, which was AOG painting in Mena, Arkansas (http://www.aogpaint.com/ > ). They did a great job with JetGlo on a complex curvy RV-10 design (see > http://faculty.washington.edu/dmasys/N104LDinflight.jpg ) at an amazingly > low price. > > So I learned there are some 'cultural' issues when having auto paint shops > work on airplanes, even very good shops such as this one was/is. Caveat > emptor... > > -Dan Masys > RV-10 N104LD > RV-12 N122LD > >> Subject: RV10-List: Re: Square footage for painting >> From: "woxofswa" <woxof(at)aol.com> > >> Thanks for the input. What I was actually doing was querying a couple of > auto >> shops near the airport to paint the pieces for me to final assemble. They > were >> asking for approximate square footage since RV10 meant nothing to them, but >> a couple of them have done aircraft projects before. >> In the end, I decided against the auto shop idea. I still might self paint > for >> the challenge, but for the time it would take me I can easily pick up extra > trips >> at work and be money and time ahead. >> -------- >> Myron Nelson >> Mesa, AZ >> Emp completed, QB wings completed, legacy build fuse on gear. Finishing > kit and >> FWF kit in progress. > > ________________________________________________________________________________
Date: Mar 19, 2013
Subject: Routing Fuel Line To Spider
My engine came with the spider located between cylinders 3 and 5 with the fuel line access coming up between those cylinders. Most of the pics I have seen, the spider is situated so the line runs up between 1 and 3 which makes for easier routing. Does anyone have the line routing up between 3 and 5 and have pics of how they ran the line from the servo? Thanks, -Sean #40303 (fwf) ________________________________________________________________________________
Subject: Re: Routing Fuel Line To Spider
Date: Mar 20, 2013
Sean, My came from Lycoming mounted in the same location as yours. The fuel line runs vertically beneath the spider. Since I installed Rod Bowers ram air mod, my servo is not located in the traditional location. I can take pictures this weekend if you need them. Bob Sent from my iPad On Mar 19, 2013, at 9:09 PM, Sean Stephens wrote: > > My engine came with the spider located between cylinders 3 and 5 with the fuel line access coming up between those cylinders. Most of the pics I have seen, the spider is situated so the line runs up between 1 and 3 which makes for easier routing. > > Does anyone have the line routing up between 3 and 5 and have pics of how they ran the line from the servo? > > Thanks, > > -Sean #40303 (fwf) > > > > ________________________________________________________________________________
Date: Mar 20, 2013
What I'm trying to figure out is after dropping between the cylinders the line should curve at the sump bolts and run along the sump over the 1 and 3 intakes or drop past the sump bolts and just free hang under the intakes. I'm placing the red cube mounted similar to others by the servo. Trying to envision the best route to take as I have to order that pricey hose and would like to only order one of them. :) -Sean On 3/20/13 4:21 AM, Bob Leffler wrote: > > Sean, > > My came from Lycoming mounted in the same location as yours. The fuel line runs vertically beneath the spider. Since I installed Rod Bowers ram air mod, my servo is not located in the traditional location. I can take pictures this weekend if you need them. > > Bob > > Sent from my iPad > > On Mar 19, 2013, at 9:09 PM, Sean Stephens wrote: > >> >> My engine came with the spider located between cylinders 3 and 5 with the fuel line access coming up between those cylinders. Most of the pics I have seen, the spider is situated so the line runs up between 1 and 3 which makes for easier routing. >> >> Does anyone have the line routing up between 3 and 5 and have pics of how they ran the line from the servo? >> >> Thanks, >> >> -Sean #40303 (fwf) >> >> >> >> > > ________________________________________________________________________________
Subject: FW: Panel design
Date: Mar 20, 2013
Guys Not directly related with RV-10's, but I wonder if somebody knows about a free software to help design the instrument panel layout. Regards Carlos ________________________________________________________________________________
Subject: Re: Panel design
Date: Mar 20, 2013
A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396641#396641 ________________________________________________________________________________
Subject: Re: FW: Panel design
Date: Mar 20, 2013
I use TurboCAD software. It is relatively inexpensive. If you found some free CAD software that would allow for 2D design and output to DWG or DXF format, that should work well. Then you just need to draw up your instruments and your radio stack and work on the arrangement on the panel with the constraints behind the panel taken into account. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Mar 20, 2013, at 8:35 AM, Carlos Trigo wrote: > Guys > > Not directly related with RV-10=92s, but I wonder if somebody knows about a free software to help design the instrument panel layout. > > Regards > Carlos > > > > ________________________________________________________________________________
Date: Mar 20, 2013
I just reviewed the photos I have online, but didn't have any that shows what you are looking for. I have a 90 degree elbow between the sump and fuel servo. The servo is horizontal instead of the traditional vertical orientation. I fabricated a mounting bracket that uses the same studs on the sump as the elbow. I've mounted the fuel flow sensor to that, which is almost directly below the spider. The Lycoming supplied hose that was installed is a little long, but I can make it work. All my other hoses aren't the standard lengths and were custom made by tsflightlines. Remind me again if I don't follow up with a picture this weekend. Bob Sent from my iPhone On Mar 20, 2013, at 8:18 AM, Sean Stephens wrote: What I'm trying to figure out is after dropping between the cylinders the line should curve at the sump bolts and run along the sump over the 1 and 3 intakes or drop past the sump bolts and just free hang under the intakes. I'm placing the red cube mounted similar to others by the servo. Trying to envision the best route to take as I have to order that pricey hose and would like to only order one of them. :) -Sean On 3/20/13 4:21 AM, Bob Leffler wrote: > > Sean, > > My came from Lycoming mounted in the same location as yours. The fuel line runs vertically beneath the spider. Since I installed Rod Bowers ram air mod, my servo is not located in the traditional location. I can take pictures this weekend if you need them. > > Bob > > Sent from my iPad > > On Mar 19, 2013, at 9:09 PM, Sean Stephens wrote: > >> >> My engine came with the spider located between cylinders 3 and 5 with the fuel line access coming up between those cylinders. Most of the pics I have seen, the spider is situated so the line runs up between 1 and 3 which makes for easier routing. >> >> Does anyone have the line routing up between 3 and 5 and have pics of how they ran the line from the servo? >> >> Thanks, >> >> -Sean #40303 (fwf) >> >> >> >> > > > > ________________________________________________________________________________
Date: Mar 20, 2013
I used XPanel. Its not free but IMHO its worth the $80.00. It saves much ti me with the RV blank panel templates pre-designated plus all the avionics I needed already in the system. Simple enough to learn and use. If you want free; Google Chrome has a free CAD style app you can download f or free and use to lay out a kitchen, backyard or panel. Just go to the Chr ome app store. Sorry on my tablet now or would send you a link. Robin Carlos Trigo wrote: Guys Not directly related with RV-10=92s, but I wonder if somebody knows about a free software to help design the instrument panel layout. Regards Carlos ________________________________________________________________________________
Date: Mar 20, 2013
I know John, I did it several times many moons ago ... But having a simple to use software, which has the actual digital pictures of the various equipments that can be dragged with the mouse to the panel is really that simple. No learning curve at all. By the way, I do remember using, not so long ago, one called =93epanelbuilder=94 or something like that, that I can=92t seem to find now. Anyone knows about this? Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: quarta-feira, 20 de Mar=E7o de 2013 12:51 Subject: RV10-List: Re: Panel design --> < johngoodman(at)earthlink.net> A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap. John -------- #40572 Phase One complete and flying. Read this topic online here: <http://forums.matronics.com/viewtopic.php?p=396641#396641> http://forums.matronics.com/viewtopic.php?p=396641#396641 List 7-Day http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 20, 2013
On my Glastar I did the paper setup first then used an acrylic 3mm "sheet" to mount them, so I could see what is behind. Werner On 20.03.2013 13:50, johngoodman wrote: > > A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap. > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396641#396641 > > ________________________________________________________________________________
Date: Mar 20, 2013
Werner For the actual layout in the panel, in order to cut the holes, I will use that technique or something similar. What I am looking right now is to begin from scratch, trying to figure out what goes where, what fits and what don=92t =85. Initial approach to the layout Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: quarta-feira, 20 de Mar=E7o de 2013 15:14 Subject: Re: RV10-List: Re: Panel design glastar(at)gmx.net> On my Glastar I did the paper setup first then used an acrylic 3mm "sheet" to mount them, so I could see what is behind. Werner On 20.03.2013 13:50, johngoodman wrote: > --> < johngoodman(at)earthlink.net> > > A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap. > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > <http://forums.matronics.com/viewtopic.php?p=396641#396641> http://forums.matronics.com/viewtopic.php?p=396641#396641 > > > > > > > > > > > List 7-Day http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 20, 2013
I think you can negotiate what you want regarding reassembly with most paint shops. My RV-7A was painted at Gillespie field in San Diego, and the painter just left a hangar full of painted assemblies (rudder, elevators, flaps, ailerons, canopy) sitting there for me to put back on the plane. Which I remember doing on a day when the temperature was 102 degrees. :-P The shop in Arkansas used a local A&P for disassembly and reassembly and included that in the price, saying it was part of their normal workflow with certificated aircraft and they didn't really want to change the process to have a builder working on his plane in their shop areas. Which was fine with me since it seemed like a pretty toxic environment - no dust or pverspray but lots of fumes that everybody was breathing in. But I sure checked everything when I picked the plane up, for which I flew the RV-7A with a CFI friend from Nashville over to Arkansas. This gave the opportunity for one of the coolest pictures of the -10 fresh out of the paint shop, with its little brother: http://faculty.washington.edu/dmasys/RV7-RV10-Mena.jpg Funny story about that RV-10 paint job was that I took the plane in sometime in November of 2007 and they told me there would be a ten day delay in starting the project, since deer hunting season started the day after I delivered the plane, and the entire shop staff would be out in the woods. :) -Dan >From: Sean Stephens <sean(at)stephensville.com> >Subject: Re: RV10-List: Re: Square footage for painting > >Just looking into this also as I'm 90% done and 90% to go. :) > >One thing I was curious about is does the builder normally do the control surface removal and re-assembly >at the paint shop? I think I would want to just to have piece of mind that it was put back together per >plans. > >-Sean #40303 (fwf) ________________________________________________________________________________
Date: Mar 20, 2013
Carlos You can use Panel Planner to do the layout. It has templates that also have slave requirements for behind the panel. You can drag and rearrange until you are happy with the result. Cheers Les Sent from my iPhone On 2013-03-20, at 9:53 AM, "Carlos Trigo" wrote: > Werner > > For the actual layout in the panel, in order to cut the holes, I will use t hat technique or something similar. > > What I am looking right now is to begin from scratch, trying to figure out what goes where, what fits and what don=99t . Initial approa ch to the layout > > Carlos > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Werner Schneider > Sent: quarta-feira, 20 de Mar=C3=A7o de 2013 15:14 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Panel design > > > On my Glastar I did the paper setup first then used an acrylic 3mm "sheet" to mount them, so I could see what is behind. > > Werner > > On 20.03.2013 13:50, johngoodman wrote: > > --> > > > > A large sheet of paper cut to the size of the panel would work better an d doesn't have a learning curve. Number 2 pencils are pretty cheap. > > John > > > > -------- > > #40572 Phase One complete and flying. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=396641#396641 > > > > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 20, 2013
If you own Photoshop, or visio or can locate a free app that can read the Vans panel than should be able to grab pictures off of brochures or on the web of your planned avionics and place it on the Vans panel. I think I measured all the dimensions than made the templates in Visio once I worked out the spacing issues I put it all in photoshop to see how it all looked. From: Carlos Trigo Sent: Wednesday, March 20, 2013 8:53 AM Subject: RE: RV10-List: Re: Panel design Werner For the actual layout in the panel, in order to cut the holes, I will use that technique or something similar. What I am looking right now is to begin from scratch, trying to figure out what goes where, what fits and what don=99t . Initial approach to the layout Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: quarta-feira, 20 de Mar=C3=A7o de 2013 15:14 Subject: Re: RV10-List: Re: Panel design On my Glastar I did the paper setup first then used an acrylic 3mm "sheet" to mount them, so I could see what is behind. Werner On 20.03.2013 13:50, johngoodman wrote: > --> > > A large sheet of paper cut to the size of the panel would work better and doesn't have a learning curve. Number 2 pencils are pretty cheap. > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396641#396641 > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 20, 2013
Hi Carlos, If you're after 2D CAD software, you can download Dassault DraftSight free. This is not a "panel planner" in the sense of showing the instruments and avionics, but more of a "hole planner" and something you can then use to CNC cut the panel. Attached is the .dwg file for my RV-10 panel (in development). Cheers, Gordon On Mar 20, 2013, at 1:35 PM, Carlos Trigo wrote: > Guys > > Not directly related with RV-10=92s, but I wonder if somebody knows about a free software to help design the instrument panel layout. > > Regards > Carlos > > > > ________________________________________________________________________________
Subject: Cabin heat control knobs
Date: Mar 20, 2013
Regarding the cabin heat system, I have a couple of questions: - Where did you put the control knobs of the cables which control the rear and front cabin heat? Is it good to put the front heat control knob in the instrument panel, and the rear heat control knob behind the front seats, thus leaving this control (only) reachable by the rear passengers? - Those of you who used the modified "T" (VA175), in order to have left / right control, where did you put the control knob for this feature? Cheers Carlos ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Mar 20, 2013
Both heat control knobs need to be accessible to the pilot. I find that 90% of the time when I have heat on I just have the rear on. I find no real need for a left/right control - but to each his/her own. I have the oil cooler air butterfly valve (blank knob) control on the pilot only side of the panel, next to the alternate engine air (red knob) control. The heat knobs are next to each other on the co-pilot side (but reachable from the pilot seat). That way the co-pilot will not mistakenly touch the oil cooler or alt air controls. All controls are on the panel apron. When you pick the spots, make sure you do not create interference for full stick travel. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Wednesday, March 20, 2013 2:15 PM Subject: RV10-List: Cabin heat control knobs Regarding the cabin heat system, I have a couple of questions: - Where did you put the control knobs of the cables which control the rear and front cabin heat? Is it good to put the front heat control knob in the instrument panel, and the rear heat control knob behind the front seats, thus leaving this control (only) reachable by the rear passengers? - Those of you who used the modified "T" (VA175), in order to have left / right control, where did you put the control knob for this feature? Cheers Carlos ________________________________________________________________________________
Date: Mar 20, 2013
One thing to keep in mind ..... equipment mounting data can be had from the manufacturer but may not include the dimensions of the bezel ..... which you need to know when mounting items close together. Linn On 3/20/2013 11:53 AM, Carlos Trigo wrote: > > Werner > > For the actual layout in the panel, in order to cut the holes, I will > use that technique or something similar. > > What I am looking right now is to begin from scratch, trying to figure > out what goes where, what fits and what don't .... Initial approach to > the layout > > Carlos > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner > Schneider > Sent: quarta-feira, 20 de Mar=E7o de 2013 15:14 > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Panel design > > > > > On my Glastar I did the paper setup first then used an acrylic 3mm > "sheet" to mount them, so I could see what is behind. > > Werner > > On 20.03.2013 13:50, johngoodman wrote: > > > > --> > > > > > > > A large sheet of paper cut to the size of the panel would work > better and doesn't have a learning curve. Number 2 pencils are pretty > cheap. > > > John > > > > > > -------- > > > #40572 Phase One complete and flying. > > > > > > > > > > > > > > > Read this topic online here: > > > > > > http://forums.matronics.com/viewtopic.php?p=396641#396641 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > * > =========== =========== =========== =========== > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> 13 > ________________________________________________________________________________
Date: Mar 20, 2013
Don't forget to sit in the real airplane, in the actual flying seating position, and look at paper cutouts on the panel. You can check the ease and feel as you reach for things; that nothing important is hidden under the glare shield; and that important things like the PFD are in focus (important for me as I wear bifocals!). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396678#396678 ________________________________________________________________________________
Date: Mar 20, 2013
We will be making an announcement once we get the website fully updated. We are planning on videos of the whole process. But for now, if you are interested, we offer Cnc design, panel cutting, powd ercoat and screen labeling of panels at incredible prices. We will make an a nnouncement once we have the full site up, but go to www.aircraftspecialty.com for more Information. Or, please email us at steve(at)aircraftspecialty.com We have already started designing and cutting panels and would be happy to w ork with you. We are home builders and will be happy to help you with all t he little ins and outs of getting your panel perfect. Have a great day Steve Sent from my iPhone On Mar 20, 2013, at 10:06, "Carlos Trigo" wrote: > I know John, I did it several times many moons ago ... > > But having a simple to use software, which has the actual digital pictures of the various equipments that can be dragged with the mouse to the panel i s really that simple. No learning curve at all. > > By the way, I do remember using, not so long ago, one called =9Cepan elbuilder=9D or something like that, that I can=99t seem to find now. Anyone knows about this? > > Carlos > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of johngoodman > Sent: quarta-feira, 20 de Mar=C3=A7o de 2013 12:51 > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Panel design > > --> > > A large sheet of paper cut to the size of the panel would work better and d oesn't have a learning curve. Number 2 pencils are pretty cheap. > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396641#396641 > > > > > > > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: RV-10 chases me on the Autobahn ;-)
Date: Mar 20, 2013
Today I took my RV-10 fuselage from the paintshop to the airport. In the stop-motion video it looks as if the RV is chasing me through Switzerland, funny to watch. Please don't ask why I kept the rear trunk window open while unloading the RV, I guess I meant to hide the secret on how to do it ;-) Wings & tail feathers are coming shortly as well. http://www.youtube.com/watch?v=hjGn8UKagJM ....and yes in the tunnel I accelerated to the speed of light as the the video proofs. Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396695#396695 ________________________________________________________________________________
Subject: Re: Cabin heat control knobs
Date: Mar 20, 2013
I put these controls and the air filter bypass on a plate that attached to t he rear of the panel with screws from the front. The knobs fit through an ov al hole cut in the panel. Otherwise the controls will have to be removed if y ou want to take the panel out. Makes service much easier. Sent from my iPad On Mar 20, 2013, at 2:14 PM, "Carlos Trigo" wrote: > Regarding the cabin heat system, I have a couple of questions: > > - Where did you put the control knobs of the cables which control t he rear and front cabin heat? > Is it good to put the front heat control knob in the instrument panel, and the rear heat control knob behind the front seats, thus leaving this contro l (only) reachable by the rear passengers? > > - Those of you who used the modified =9CT=9D (VA175), i n order to have left / right control, where did you put the control knob for this feature? > > Cheers > Carlos > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 20, 2013
In addition to Bob's excellent advice, when it comes to switch layout; think about a logical order of switch usage i.e. going down a row rather than jumping around when running the checklist. Also consider where the important autopilot power switch and fuel pump switches will be; these should readily available and easily reached. Finally the primary flight display should be as close to centered in front of the pilots head as possible. Looking cross cockpit at the flight display will bug you. Stay away from unconventional arrangements; most certified panels are similar for a reason, they work. A good conventional panel will add much to your enjoyment of the airplane and add to resale value. Dick Sipp 470 hours Dick Sipp -----Original Message----- From: Bob Turner Sent: Wednesday, March 20, 2013 3:32 PM Subject: RV10-List: Re: Panel design Don't forget to sit in the real airplane, in the actual flying seating position, and look at paper cutouts on the panel. You can check the ease and feel as you reach for things; that nothing important is hidden under the glare shield; and that important things like the PFD are in focus (important for me as I wear bifocals!). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396678#396678 ________________________________________________________________________________
Subject: Re: RV-10 chases me on the Autobahn ;-)
Date: Mar 20, 2013
Very cool Michael! The airplane looks beautiful. BTW, package from Mary will be heading your way tomorrow. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396708#396708 ________________________________________________________________________________
Date: Mar 20, 2013
Subject: Disabling front cabin heat?
Has anyone disabled the front cabin heat in their RV-10? I'm finding that even on really cold days, I only need partial rear heat to keep things warm, and I never use the front heat, since I want to minimize heat behind the panel. In the warm summer months, I don't want all that hot air blowing on the firewall. I don't think I can just disconnect the air hose to the muff, since the exhaust pipe would probably get too hot. If nothing else, I figure I could disconnect the air hose between the muff and firewall at the firewall and just point it down toward the cowl exit. Of course, I would have to seal the hole in the firewall. Anyone have any suggestions? Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 21, 2013
Jesse Will you please send me a picture of your setup. Thanks Carlos From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: quarta-feira, 20 de Mar=C3=A7o de 2013 23:16 Subject: Re: RV10-List: Cabin heat control knobs I put these controls and the air filter bypass on a plate that attached to the rear of the panel with screws from the front. The knobs fit through an oval hole cut in the panel. Otherwise the controls will have to be removed if you want to take the panel out. Makes service much easier. Sent from my iPad On Mar 20, 2013, at 2:14 PM, "Carlos Trigo" wrote: Regarding the cabin heat system, I have a couple of questions: - Where did you put the control knobs of the cables which control the rear and front cabin heat? Is it good to put the front heat control knob in the instrument panel, and the rear heat control knob behind the front seats, thus leaving this control (only) reachable by the rear passengers? - Those of you who used the modified =9CT=9D (VA175), in order to have left / right control, where did you put the control knob for this feature? Cheers Carlos ========= ://www.matronics.com/Navigator?RV10-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: Mar 21, 2013
Subject: Re: Disabling front cabin heat?
On 3/20/2013 11:54 PM, Rob Kochman wrote: > Has anyone disabled the front cabin heat in their RV-10? I'm finding > that even on really cold days, I only need partial rear heat to keep > things warm, and I never use the front heat, since I want to minimize > heat behind the panel. In the warm summer months, I don't want all > that hot air blowing on the firewall. I don't think I can just > disconnect the air hose to the muff, since the exhaust pipe would > probably get too hot. If nothing else, I figure I could disconnect > the air hose between the muff and firewall at the firewall and just > point it down toward the cowl exit. Of course, I would have to seal > the hole in the firewall. > > Anyone have any suggestions? Thanks... You can block off some of the hole going to the heat muff with metal-tape for winter and cover it all during summer. Or you can route around the heat muff during summer so you get cool air through the heat vents. I wouldn't worry about overheating that exhaust pipe ...... Linn > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 21, 2013
One other tip in case it helps. I used the plastic covers for switches to make them easily identifiable and layer them in an order that makes sense to me. I used red for power (battery and alternator), green for avionics (cause they cost a lot of money), blue for fuel pump, white for lights and yellow for pitot heat. This way a quick glance and I'm ready for any phase be it engine start, takeoff or shutdown. Cheers, Marcus On Mar 20, 2013, at 7:37 PM, "Dick & Vicki Sipp" wrote: In addition to Bob's excellent advice, when it comes to switch layout; think about a logical order of switch usage i.e. going down a row rather than jumping around when running the checklist. Also consider where the important autopilot power switch and fuel pump switches will be; these should readily available and easily reached. Finally the primary flight display should be as close to centered in front of the pilots head as possible. Looking cross cockpit at the flight display will bug you. Stay away from unconventional arrangements; most certified panels are similar for a reason, they work. A good conventional panel will add much to your enjoyment of the airplane and add to resale value. Dick Sipp 470 hours Dick Sipp -----Original Message----- From: Bob Turner Sent: Wednesday, March 20, 2013 3:32 PM Subject: RV10-List: Re: Panel design Don't forget to sit in the real airplane, in the actual flying seating position, and look at paper cutouts on the panel. You can check the ease and feel as you reach for things; that nothing important is hidden under the glare shield; and that important things like the PFD are in focus (important for me as I wear bifocals!). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396678#396678 ________________________________________________________________________________
Date: Mar 21, 2013
I have disabled mine for the summer months too. I disconnected the SCAT tube so hot air no longer blows on the firewall. I also blocked the vent adapter at the baffle to prevent any bypass air flow around the cylinders. It helped a bit and I would not worry about the exhaust pipes. -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396730#396730 ________________________________________________________________________________
Date: Mar 21, 2013
Rob, Not all exhaust pipes even have heat muffs. I can't imagine it getting too h ot there and being ok with the temperature along the rest of the exhaust. I' d leave it off completely. Instead, you might hook it up as normal and just c over over the hole in the baffles so you could easily add it if you want to. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 20, 2013, at 11:54 PM, Rob Kochman wrote: > Has anyone disabled the front cabin heat in their RV-10? I'm finding that even on really cold days, I only need partial rear heat to keep things warm , and I never use the front heat, since I want to minimize heat behind the p anel. In the warm summer months, I don't want all that hot air blowing on t he firewall. I don't think I can just disconnect the air hose to the muff, s ince the exhaust pipe would probably get too hot. If nothing else, I figu re I could disconnect the air hose between the muff and firewall at the fire wall and just point it down toward the cowl exit. Of course, I would have t o seal the hole in the firewall. > > Anyone have any suggestions? Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 21, 2013
Thanks, guys... my concern is that with no airflow into the muff, it's acting as an insulator on the exhaust pipe. Perhaps it's nothing to worry about, though. -Rob On Thu, Mar 21, 2013 at 5:32 AM, Jesse Saint wrote: > Rob, > > Not all exhaust pipes even have heat muffs. I can't imagine it getting too > hot there and being ok with the temperature along the rest of the exhaust. > I'd leave it off completely. Instead, you might hook it up as normal and > just cover over the hole in the baffles so you could easily add it if you > want to. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > On Mar 20, 2013, at 11:54 PM, Rob Kochman wrote: > > Has anyone disabled the front cabin heat in their RV-10? I'm finding that > even on really cold days, I only need partial rear heat to keep things > warm, and I never use the front heat, since I want to minimize heat behind > the panel. In the warm summer months, I don't want all that hot air > blowing on the firewall. I don't think I can just disconnect the air hose > to the muff, since the exhaust pipe would probably get too hot. If > nothing else, I figure I could disconnect the air hose between the muff and > firewall at the firewall and just point it down toward the cowl exit. Of > course, I would have to seal the hole in the firewall. > > Anyone have any suggestions? Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > ================================== > ://www.matronics.com/Navigator?RV10-List > ===================================cs.com > ===================================matronics.com/contribution > ================================== > * > > * > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 21, 2013
I spoke with Vetterman on this subject. His advice was adamant, do not just disconnect the air going through the muff. It will get to hot in that one area, but to remove the heat muff completely and install a heat shield on the exhaust tubing as necessary to keep the heat away from the cowl. It is my belief that the air outlet at the rear of #6 cylinder actually helps the cooling of #6 by not allowing stagnant air to dam at the rear of the baffle. On the right side, #5 is always the hottest cylinder, and the fix is to allow more air to escape either around #5 or through the rear. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396743#396743 ________________________________________________________________________________
Date: Mar 21, 2013
Subject: Steel Fittings FWF - Which coating?
I am a bit confused by all the different coatings available on the steel AN fittings. I ordered some steel fittings from ACS, but they were not as pictured and were black. I don't think they have a coating at all. I've seen some that are zinc and some that are yellow dichromate. Which ones are suitable for use as fuel line fittings firewall forward? Or does it even really matter and my un-coated steel fittings are fine? Thanks, -Sean #40303 ________________________________________________________________________________
Subject: Re: Steel Fittings FWF - Which coating?
Date: Mar 21, 2013
All my FWF Steel fittings are uncoated. There are some that are black coated - these appear to be from the racing world and are acceptable in experimental. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396750#396750 ________________________________________________________________________________
Date: Mar 21, 2013
photo attached... Cheers, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396759#396759 Attachments: http://forums.matronics.com//files/hpim0946_872.jpg ________________________________________________________________________________
Date: Mar 21, 2013
Rob, I think your concern is valid. The muff will insulate the exhaust pipe and you may end up with a high temperature gradient between the section outside the muff and inside it, possibly resulting in deformation or cracking after a while. Since cracking would release exhaust into the cowl area, it could become a real concern. Personally I would keep the cool air supply to the muff and dump the hot air coming out of it. Since that is what happens in the stock system when the heater flap valve is closed, I don't follow why you want to disable it at all, rather than just not use it. If I really wanted to disable it I would probably just disconnect the control cable and use Biotherm to seal the flap in the closed position. Gordon Anderson On Mar 21, 2013, at 2:44 PM, Rob Kochman wrote: > Thanks, guys... my concern is that with no airflow into the muff, it's acting as an insulator on the exhaust pipe. Perhaps it's nothing to worry about, though. > > -Rob > > > On Thu, Mar 21, 2013 at 5:32 AM, Jesse Saint wrote: > Rob, > > Not all exhaust pipes even have heat muffs. I can't imagine it getting too hot there and being ok with the temperature along the rest of the exhaust. I'd leave it off completely. Instead, you might hook it up as normal and just cover over the hole in the baffles so you could easily add it if you want to. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > On Mar 20, 2013, at 11:54 PM, Rob Kochman wrote: > >> Has anyone disabled the front cabin heat in their RV-10? I'm finding that even on really cold days, I only need partial rear heat to keep things warm, and I never use the front heat, since I want to minimize heat behind the panel. In the warm summer months, I don't want all that hot air blowing on the firewall. I don't think I can just disconnect the air hose to the muff, since the exhaust pipe would probably get too hot. If nothing else, I figure I could disconnect the air hose between the muff and firewall at the firewall and just point it down toward the cowl exit. Of course, I would have to seal the hole in the firewall. >> >> Anyone have any suggestions? Thanks... >> >> -Rob >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> >> >> ========= >> ://www.matronics.com/Navigator?RV10-List >> ========= >> cs.com >> ========= >> matronics.com/contribution >> ========= >> > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > > ________________________________________________________________________________
Subject: Main landing gear leg dimension
Date: Mar 21, 2013
Can someone who does not have the landing gear strut pants on, measure the width of the leg for me? I think it is 2=9D but need confirmation. Thank you! Pascal ________________________________________________________________________________
Date: Mar 22, 2013
Thanks, Gordon... the reason I want to disable it is that it dumps hot air directly onto the firewall, which makes the cabin warmer. Anyone know if it's possible to remove the heat muff completely? On Thu, Mar 21, 2013 at 2:00 PM, Gordon Anderson wrote: > Rob, > > I think your concern is valid. The muff will insulate the exhaust pipe > and you may end up with a high temperature gradient between the section > outside the muff and inside it, possibly resulting in deformation or > cracking after a while. Since cracking would release exhaust into the cowl > area, it could become a real concern. Personally I would keep the cool air > supply to the muff and dump the hot air coming out of it. Since that is > what happens in the stock system when the heater flap valve is closed, I > don't follow why you want to disable it at all, rather than just not use > it. If I really wanted to disable it I would probably just disconnect the > control cable and use Biotherm to seal the flap in the closed position. > > Gordon Anderson > > On Mar 21, 2013, at 2:44 PM, Rob Kochman wrote: > > Thanks, guys... my concern is that with no airflow into the muff, it's > acting as an insulator on the exhaust pipe. Perhaps it's nothing to worry > about, though. > > -Rob > > > On Thu, Mar 21, 2013 at 5:32 AM, Jesse Saint wrote: > >> Rob, >> >> Not all exhaust pipes even have heat muffs. I can't imagine it getting >> too hot there and being ok with the temperature along the rest of the >> exhaust. I'd leave it off completely. Instead, you might hook it up as >> normal and just cover over the hole in the baffles so you could easily add >> it if you want to. >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org >> www.mavericklsa.com >> C: 352-427-0285 >> O: 352-465-4545 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> On Mar 20, 2013, at 11:54 PM, Rob Kochman wrote: >> >> Has anyone disabled the front cabin heat in their RV-10? I'm finding >> that even on really cold days, I only need partial rear heat to keep things >> warm, and I never use the front heat, since I want to minimize heat behind >> the panel. In the warm summer months, I don't want all that hot air >> blowing on the firewall. I don't think I can just disconnect the air hose >> to the muff, since the exhaust pipe would probably get too hot. If >> nothing else, I figure I could disconnect the air hose between the muff and >> firewall at the firewall and just point it down toward the cowl exit. Of >> course, I would have to seal the hole in the firewall. >> >> Anyone have any suggestions? Thanks... >> >> -Rob >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> >> * >> >> ========= >> ://www.matronics.com/Navigator?RV10-List >> ==========cs.com >> ==========matronics.com/contribution >> ========= >> * >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com/">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/contribution > * > > > * > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 22, 2013
It took me a while, but I finally understand!!! Which causes my addled brain to ask ..... Did anyone insulate the firewall??? On the engine side or cabin side ..... and with what??? Linn .... so many things to think about .... On 3/22/2013 4:46 PM, Rob Kochman wrote: > Thanks, Gordon... the reason I want to disable it is that it dumps hot > air directly onto the firewall, which makes the cabin warmer. Anyone > know if it's possible to remove the heat muff completely? > > > On Thu, Mar 21, 2013 at 2:00 PM, Gordon Anderson > wrote: > > Rob, > > I think your concern is valid. The muff will insulate the exhaust > pipe and you may end up with a high temperature gradient between > the section outside the muff and inside it, possibly resulting in > deformation or cracking after a while. Since cracking would > release exhaust into the cowl area, it could become a real > concern. Personally I would keep the cool air supply to the muff > and dump the hot air coming out of it. Since that is what happens > in the stock system when the heater flap valve is closed, I don't > follow why you want to disable it at all, rather than just not use > it. If I really wanted to disable it I would probably just > disconnect the control cable and use Biotherm to seal the flap in > the closed position. > > Gordon Anderson > > On Mar 21, 2013, at 2:44 PM, Rob Kochman wrote: > >> Thanks, guys... my concern is that with no airflow into the muff, >> it's acting as an insulator on the exhaust pipe. Perhaps it's >> nothing to worry about, though. >> >> -Rob >> >> >> On Thu, Mar 21, 2013 at 5:32 AM, Jesse Saint >> > wrote: >> >> Rob, >> >> Not all exhaust pipes even have heat muffs. I can't imagine >> it getting too hot there and being ok with the temperature >> along the rest of the exhaust. I'd leave it off completely. >> Instead, you might hook it up as normal and just cover over >> the hole in the baffles so you could easily add it if you >> want to. >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org <http://www.itecusa.org/> >> www.mavericklsa.com <http://www.mavericklsa.com/> >> C: 352-427-0285 >> O: 352-465-4545 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> On Mar 20, 2013, at 11:54 PM, Rob Kochman > > wrote: >> >>> Has anyone disabled the front cabin heat in their RV-10? >>> I'm finding that even on really cold days, I only need >>> partial rear heat to keep things warm, and I never use the >>> front heat, since I want to minimize heat behind the panel. >>> In the warm summer months, I don't want all that hot air >>> blowing on the firewall. I don't think I can just >>> disconnect the air hose to the muff, since the exhaust pipe >>> would probably get too hot. If nothing else, I figure I >>> could disconnect the air hose between the muff and firewall >>> at the firewall and just point it down toward the cowl exit. >>> Of course, I would have to seal the hole in the firewall. >>> >>> Anyone have any suggestions? Thanks... >>> >>> -Rob >>> >>> -- >>> Rob Kochman >>> RV-10 Flying since March 2011 >>> Woodinville, WA >>> http://kochman.net/N819K >>> * >>> >>> ========= >>> ://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> >>> ========= >>> cs.com <http://cs.com/> >>> ========= >>> matronics.com/contribution <http://matronics.com/contribution> >>> ========= >>> >>> * >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com/">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/contribution >> >> * > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 22, 2013
On my other plan, the Glastar we had the same problem, the closed valve did dump all hot air direct into the upper FW area, nothing we did like. One of our builders manufactured an enclosure around the heat valve and that enclosure did dump all air via another scat tube directly to the exit ramp of the cowling. Now the Glastar has a different type of valve but I see no reason why one could fabricate a similar thing for the RV-10. Werner On 22.03.2013 21:46, Rob Kochman wrote: > Thanks, Gordon... the reason I want to disable it is that it dumps hot > air directly onto the firewall, which makes the cabin warmer. ________________________________________________________________________________
Date: Mar 22, 2013
No. Anything fwf can oil soaked and potentially interfere with servicing. Leave as is. Robin Linn wrote: It took me a while, but I finally understand!!! Which causes my addled bra in to ask ..... Did anyone insulate the firewall??? On the engine side or cabin side ..... and with what??? Linn .... so many things to think about .... On 3/22/2013 4:46 PM, Rob Kochman wrote: Thanks, Gordon... the reason I want to disable it is that it dumps hot air directly onto the firewall, which makes the cabin warmer. Anyone know if i t's possible to remove the heat muff completely? On Thu, Mar 21, 2013 at 2:00 PM, Gordon Anderson > wrote: Rob, I think your concern is valid. The muff will insulate the exhaust pipe and you may end up with a high temperature gradient between the section outsid e the muff and inside it, possibly resulting in deformation or cracking aft er a while. Since cracking would release exhaust into the cowl area, it co uld become a real concern. Personally I would keep the cool air supply to the muff and dump the hot air coming out of it. Since that is what happens in the stock system when the heater flap valve is closed, I don't follow w hy you want to disable it at all, rather than just not use it. If I really wanted to disable it I would probably just disconnect the control cable an d use Biotherm to seal the flap in the closed position. Gordon Anderson On Mar 21, 2013, at 2:44 PM, Rob Kochman wrote: Thanks, guys... my concern is that with no airflow into the muff, it's acti ng as an insulator on the exhaust pipe. Perhaps it's nothing to worry abou t, though. -Rob On Thu, Mar 21, 2013 at 5:32 AM, Jesse Saint > wrote: Rob, Not all exhaust pipes even have heat muffs. I can't imagine it getting too hot there and being ok with the temperature along the rest of the exhaust. I'd leave it off completely. Instead, you might hook it up as normal and ju st cover over the hole in the baffles so you could easily add it if you wan t to. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org<http://www.itecusa.org/> www.mavericklsa.com<http://www.mavericklsa.com/> C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 20, 2013, at 11:54 PM, Rob Kochman @gmail.com>> wrote: Has anyone disabled the front cabin heat in their RV-10? I'm finding that even on really cold days, I only need partial rear heat to keep things warm , and I never use the front heat, since I want to minimize heat behind the panel. In the warm summer months, I don't want all that hot air blowing on the firewall. I don't think I can just disconnect the air hose to the muf f, since the exhaust pipe would probably get too hot. If nothing else, I figure I could disconnect the air hose between the muff and firewall at th e firewall and just point it down toward the cowl exit. Of course, I would have to seal the hole in the firewall. Anyone have any suggestions? Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ========= ://www.matronics.com/Navigator?RV10-List<http://www.matronics.com/Navigator ?RV10-List> ========= cs.com<http://cs.com/> ========= matronics.com/contribution<http://matronics.com/contribution> ========= get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/Navigator?RV10-List href="http://forums.matronics.com/">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/con tribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> 03/21/13 ________________________________________________________________________________
Date: Mar 22, 2013
I posted this awhile back on what I did: I have a small piece of KoolMat http://www.aircraftspruce.com/pages/ap/insulation/koolmat.php on the firewall. It is between the cabin heat control valves and the firewall, then extents up and over the top of the valves. The idea is to not blast the engine and fuel pump with hot heat muff air that bounces off the valves back toward the engine when the valves are shut (on hot days when you least want hot air banging on the fuel pump). So the KoolMat insulates some thermal heat transfer to the firewall, and looping the KoolMat over the top and then down in front of the valves directs the dumped heat muff air down and away from the engine. Regarding the heat muff air itself, there is a balance between having heat on a cold day, and on hot days robbing engine cooling air off the top of the engine just to dump hot air near the cowl exit - right where you want the lowest pressure possible to draw more cooling air through the engine. I have two 2" SCAT hose flanges over #5 cylinder, one for each heat muff. This proved to be way too much air volume. I put a piece of .025 aluminum disc with a 1" hole in it over the edge of each flange (the disc is just a bit bigger than the flange diameter). The disc is held in with aluminum tape and the SCAT hose slides over it. This does two things; reduces the volume of air coming off the top of the engine and slows down the air in the heat muff so the air is warmer, but less flow in the cabin. This is still more heat than I'll likely ever need, but I'm happy with the compromise. If you are still building, an easier way to do this is to just have one 2" flange on the rear baffle, then a Y to connect two SCAT hoses. One other trick I did was fabricate a couple of 2" to 1.5" reducers so I could run 1.5" SCAT hose in the tunnel for the rear heat. This solves a lot of clearance issues caused by the 2" rear heat SCAT hose. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Werner Schneider Sent: Friday, March 22, 2013 5:50 PM Subject: Re: RV10-List: Disabling front cabin heat? On my other plan, the Glastar we had the same problem, the closed valve did dump all hot air direct into the upper FW area, nothing we did like. One of our builders manufactured an enclosure around the heat valve and that enclosure did dump all air via another scat tube directly to the exit ramp of the cowling. Now the Glastar has a different type of valve but I see no reason why one could fabricate a similar thing for the RV-10. Werner On 22.03.2013 21:46, Rob Kochman wrote: > Thanks, Gordon... the reason I want to disable it is that it dumps hot > air directly onto the firewall, which makes the cabin warmer. ________________________________________________________________________________
Date: Mar 22, 2013
Unrelated post but has anyone veiwed the new conforma tips for the RV-7,8,9, and RV-10 and F1 rocket from aveoengineering.com. They look really nice. On Thu, Mar 21, 2013 at 6:47 AM, Carlos Trigo wrote : > Jesse**** > > ** ** > > Will you please send me a picture of your setup.**** > > ** ** > > Thanks**** > > Carlos **** > > ** ** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jesse Saint > *Sent:* quarta-feira, 20 de Mar=E7o de 2013 23:16 > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Cabin heat control knobs**** > > ** ** > > I put these controls and the air filter bypass on a plate that attached t o > the rear of the panel with screws from the front. The knobs fit through a n > oval hole cut in the panel. Otherwise the controls will have to be remove d > if you want to take the panel out. Makes service much easier. > > Sent from my iPad**** > > > On Mar 20, 2013, at 2:14 PM, "Carlos Trigo" wrote : > **** > > Regarding the cabin heat system, I have a couple of questions:**** > > **** > > - Where did you put the control knobs of the cables which control > the rear and front cabin heat?**** > > Is it good to put the front heat control knob in the instrument panel, an d > the rear heat control knob behind the front seats, thus leaving this > control (only) reachable by the rear passengers?**** > > **** > > - Those of you who used the modified =93T=94 (VA175), in order to have > left / right control, where did you put the control knob for this feature ? > **** > > **** > > Cheers**** > > Carlos **** > > * * > > * * > > *======================== ===========* > > *://www.matronics.com/Navigator?RV10-List* > > *======================== ===========* > > *cs.com* > > *======================== ===========* > > *matronics.com/contribution* > > *======================== ===========* > > * * > > * * > > * * > > *< - The RV10-List Email Forum Use the Matronics List Features Navig ator to browse* > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== > =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Mar 22, 2013
Go to Blog and scroll down. On Fri, Mar 22, 2013 at 11:28 PM, John Zazulka wrote: > Unrelated post but has anyone veiwed the new conforma tips for the > RV-7,8,9, and RV-10 and F1 rocket from aveoengineering.com. They look > really nice. > > > On Thu, Mar 21, 2013 at 6:47 AM, Carlos Trigo wrot e: > >> Jesse**** >> >> ** ** >> >> Will you please send me a picture of your setup.**** >> >> ** ** >> >> Thanks**** >> >> Carlos **** >> >> ** ** >> >> ** ** >> >> *From:* owner-rv10-list-server(at)matronics.com [mailto: >> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jesse Saint >> *Sent:* quarta-feira, 20 de Mar=E7o de 2013 23:16 >> *To:* rv10-list(at)matronics.com >> *Subject:* Re: RV10-List: Cabin heat control knobs**** >> >> ** ** >> >> I put these controls and the air filter bypass on a plate that attached >> to the rear of the panel with screws from the front. The knobs fit throu gh >> an oval hole cut in the panel. Otherwise the controls will have to be >> removed if you want to take the panel out. Makes service much easier. >> >> Sent from my iPad**** >> >> >> On Mar 20, 2013, at 2:14 PM, "Carlos Trigo" >> wrote:**** >> >> Regarding the cabin heat system, I have a couple of questions:**** >> >> **** >> >> - Where did you put the control knobs of the cables which control >> the rear and front cabin heat?**** >> >> Is it good to put the front heat control knob in the instrument panel, >> and the rear heat control knob behind the front seats, thus leaving this >> control (only) reachable by the rear passengers?**** >> >> **** >> >> - Those of you who used the modified =93T=94 (VA175), in order to have >> left / right control, where did you put the control knob for this featur e? >> **** >> >> **** >> >> Cheers**** >> >> Carlos **** >> >> * * >> >> * * >> >> *======================= ============* >> >> *://www.matronics.com/Navigator?RV10-List* >> >> *======================= ============* >> >> *cs.com* >> >> *======================= ============* >> >> *matronics.com/contribution* >> >> *======================= ============* >> >> * * >> >> * * >> >> * * >> >> *< - The RV10-List Email Forum Use the Matronics List Features Navi gator to browse* >> >> ** >> >> ** >> >> ** >> >> *http://www.matronics.com/Navigator?RV10-List* >> >> ** >> >> ** >> >> *http://forums.matronics.com* >> >> ** >> >> ** >> >> ** >> >> ** >> >> *http://www.matronics.com/contribution* >> >> ** >> >> * * >> >> * >> =========== >> =========== =========== =========== >> >> * >> >> > ________________________________________________________________________________
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Mar 23, 2013
One simple way of keeping both front and rear heat from blasting hot air on the firewall, fuel pump etc when not needed is to install Aircraft Spruce Part # 08-07296 and dump the hot air down near the bottom. The down side is one or two more push- pulls. Cheers Greg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396846#396846 ________________________________________________________________________________
Date: Mar 23, 2013
> It took me a while, but I finally understand!!! Which causes my addled brain to ask ..... Did anyone insulate the firewall??? On the engine side or cabin side ..... and with what??? > Linn .... so many things to think about .... Firewall heat is not an issue for me because of my LS1 Corvette engine, which is water cooled. I use hoses from the water pump connected to a race car defroster/heater. The two speed motor on the heater works fine. I also have a water cutoff push/pull for heat control and/or leaks. But, that's not what you're asking.... Here is what I used on the engine side of the firewall: http://www.aircraftspruce.com/catalog/appages/firewall2000.php?clickkey=97077 It's actually called a firewall ceramic blanket. I used a combination of rivets and a caulk type adhesive that is recommended for the blanket. The stainless steel side will cut you like nobody's business! It's holding up great. I used the standard Soundex insulation on the cabin side of the firewall. I also used Abesco FP200 expanding foam in the floors, etc. Here is a link to it: http://fp200abesco.com/ Hope this helps, John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396853#396853 ________________________________________________________________________________
Date: Mar 23, 2013
Sure you can remove the heat muff.... I did... And as far as I know.... =0A no =0Aone has done this....- I have cold air induction, and one of the th ings I=0A did to cool things down a bit was to run the rear cabin heat air =0Astraight out of the back of #5 cyl over the top and into a fiberglass =0A"Y" I made that has the 4" line from #6 and that 2" line from #5 going =0Ainto the "Y", and into the oil cooler.- In the winter I put alum tape =0Aover the outlet for the 2" line (at the back of the plenum for #5) and =0Ause the butterfly valve on the 4" line to keep the oil temp exactly =0Aw here I want it. I also used a "Y" to split the heat from the remaining muff into both the f ront and rear heat ducts. Don McDonald 500+ hours, ad it gets better every day! --- On Fri, 3/22/13, Linn wrote: From: Linn <flying-nut(at)cfl.rr.com> Subject: Re: RV10-List: Disabling front cabin heat? Date: Friday, March 22, 2013, 4:36 PM =0A =0A=0A =0A =0A =0A It took me a while, but I finally=0A u nderstand!!!- Which causes my addled brain to ask ..... Did=0A anyon e insulate the firewall???- On the engine side or cabin side=0A .... . and with what??? =0A Linn .... so many things to think about .... =0A =0A =0A On 3/22/2013 4:46 PM, Rob Kochman wrote: =0A =0A =0A Thanks, Gordon... the reason I want to disable it=0A is that it dumps hot air directly onto the firewall, which makes=0A the cabin warmer. -Anyone know if it's possible to remove the=0A heat muff completely?=0A =0A =0A On Thu, Mar 21, 2013 at 2:00 PM, Gordon=0A Anderson =0A wrote: =0A =0A Rob,=0A =0A =0A I think your concern is valid. -The muf f will=0A insulate the exhaust pipe and you may end up with a high=0A temperature gradient between the section outside t he=0A muff and inside it, possibly resulting in deformation or=0A cracking after a while. -Since cracking would releas e=0A exhaust into the cowl area, it could become a real=0A concern. -Personally I would keep the cool air supply to=0A the muff and dump the hot air coming out of it. Since=0A that is what happens in the stock system when the heater=0A flap valve is closed, I -don't follow why you want to=0A disable it at all, rather than just not use it. -If I=0A really wanted to disable it I would probably just=0A disconnect the control cable and use Biotherm to seal=0A the flap in the closed position.=0A =0A =0A Gordon Anderson=0A =0A =0A =0A =0A On Mar 21, 2013, at 2:44 PM, Rob Kochman=0A wrote:=0A =0A =0A =0A =0A =0A =0A Thanks, gu ys... my concern is=0A that with no airflow into t he muff, it's=0A acting as an insulator on the exh aust pipe.=0A -Perhaps it's nothing to worry abo ut, though.=0A =0A =0A =0A -Rob=0A =0A =0A =0A =0A =0A =0A =0A On Thu, Mar 21, 2013 at 5:32=0A AM, Jesse Saint =0A wrote: =0A =0A =0A =0A =0A =0A =0A Rob,=0A =0A =0A Not a ll exhaust pipes even have=0A heat muffs. I can't imagine it getting=0A too hot ther e and being ok with the=0A temperature alo ng the rest of the=0A exhaust. I'd leave i t off completely.=0A Instead, you might ho ok it up as=0A normal and just cover over the hole in=0A the baffles so you could ea sily add it=0A if you want to.- =0A =0A Jesse Saint=0A I-TEC, Inc.=0A jesse(at)itecusa.org =0A www.itecusa.org=0A www.mavericklsa.com=0A C: 35 2-427-0285=0A O: 352-465-4545=0A F: 815-377-3694=0A =0A =0A S ent from my iPhone=0A =0A =0A =0A On Mar 20, 2013, at 11:54 PM, Rob=0A Kochman =0A wrote: =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A =0A Has anyone disabled the front=0A cabin heat in their RV-10? -I'm=0A finding that even on real ly cold=0A days, I only need partial rear=0A heat to keep things warm, a nd I=0A never use the front heat, si nce=0A I want to minimize heat behin d=0A the panel. -In the warm summe r=0A months, I don't want all that =0A hot air blowing on the firewall. =0A -I don't think I can just=0A disconnect the air hose to the=0A muff, since the exhaust pipe=0A would probably get too hot. -=0A -If nothing else, I figure I=0A could disconnect the air hose=0A between the muff and firewall at=0A the firewall and just point it=0A down toward the cowl exit. -Of=0A course, I would have to seal the=0A hole in the firewall. -=0A =0A =0A =0A Anyone have any=0A sugg estions? -Thanks...=0A =0A =0A =0A =0A -Rob =0A =0A =0A -- =0A Rob Kochman =0A RV-10 Flying since March=0A 2011=0A Woodinville, WA=0A http://kochman.net/N819K=0A =0A =0A =0A =0A =0A =0A=0A===========0A://w ww.matronics.com/Navigator?RV10-List=0A===========0Acs. com=0A===========0Amatronics.com/contribution=0A== =========0A=0A=0A =0A =0A =0A =0A=0Aget="_blank">http://www.matronics.com/Navigator?RV10-List =0Atp://forums.matronics.com=0A_blank">http://www.matronics.com/contributio n=0A=0A=0A =0A =0A =0A =0A =0A =0A =0A =0A -- =0A Rob Kochman =0A RV-10 Flying since March 2011=0A Woodinville, WA=0A http://kochman.net/N819 K=0A =0A =0A =0A =0Ahref="http://www.matronics.com/Navigator?RV10-List">http://www.matroni cs.com/Navigator?RV10-List=0Ahref="http://forums.matronics.com/">http://f orums.matronics.com=0Ahref="http://www.matronics.com/contribution">http:/ /www.matronics.com/contribution=0A=0A=0A =0A =0A =0A =0A =0A =0A=0Aget="_blank">h ttp://www.matronics.com/Navigator?RV10-List=0Atp://forums.matronics.com=0A_ blank">http://www.matronics.com/contribution=0A=0A=0A =0A =0A =0A =0A =0A =0A =0A =0A -- =0A Rob Kochman =0A RV-10 Flying since March 2011=0A Woodinville, WA=0A http://kochman.net/N819K=0A =0A =0A=0A=0A=0A No virus=0A found in this message. =0A Checked by AVG - www.avg.com =0A 03/21/13=0A =0A ======================0A=0A ________________________________________________________________________________
Subject: Airport Tower Closures
Date: Mar 23, 2013
I was reviewing the published list of 149 airport tower closure s and was really surprised that I have landed 26 of the 149 on the list. I was further surprised that one of my home airports Whiteman (WHP) is slated for tower closure. Now I totally understand that if some towers MUST be cl osed than choices need to be made and I further understand the NIMBY attitu de of sure close some towers but not MY towers. That being said let me desc ribe WHP to you and you can decide if this tower closure is a good idea. WHP is a one runway airport that sits under the Los Angeles Cla ss B veil for LAX. WHP is 4 miles from Burbank commercial airport and 4 mil es from Van Nuys airport both very busy hubs if aviation. Furthermore WHP s its near the Newhall pass which is a bit of a funnel for aircraft feeding i nto and out the San Fernando Valley. Additionally WHP hosts 5 of LA's news helicopters which park and hover taxi maybe 90 feet from the runway centerl ine adjacent to the 30 run up area. Whitman is also home for the CDF (Calif ornia Fire Department) heavy lift fire helicopters. Wikipedia says that Cal Fire is "one of the largest non-military air programs in the country that includes 11 UH01H Super Huey helicopters flying out of WHP. I know because they park and take off right behind my WHP hangar. The launch/landing area for CDF is "not visible" from the tower and requires extra tower control ca re for transitioning in and out of this area. WHP also hosts a modest amoun t of student training. Not a great deal of student training because costs h ave driven away many who may be interested in learning to fly. Additionall y there is a fair amount of police helicopter activity in the area because WHP is near some major highways 5, 118, 405, 101, 134, 210. Police tent to hover right at TPA for WHP. So the typical WHP weekend scenario is the student pilot doing T & G's while 3 737's are queued up to land Burbank as Golf streams are roc keting out of VNY with police helicopters hovering over the nearby freeways while the news choppers hover taxi back to their landing pad after their m ornings work and small aircraft transition into and out of BUR or VNY. All while CDF heavy lift choppers fly in and out of their compound directly und er the Left Downwind but blind to what is happening on and around the activ e runway. This is all occurring under LAX's Class B vial, under the VNY air space and in a little carve out of the Burbank airspace (SFC/4800'). All th is with mountain peaks covering 180 degrees and within 5 miles of WHP. I ha ve heard the tower chew out oblivious pilots dozens and dozens of times for clueless & illegal transitioning of the airspace. I literally fear what i t will be like w/o any control. It is not unusual for me to see 15+ traffic targets on my display. Last week I flew into WHP VFR but reporting 3 miles and haze. N ot that uncommon. I have flown into WHP well over 500 times and it was very difficult for me to pick up the runway 3 miles out even though I am quite familiar with the topography. I am fortunate to have beautiful large PFD/MF D with traffic but I am painfully aware that most aircraft in the area do n ot have nearly my experience and knowledge of the area or my selection of e quipment. This is just one story of 149. I hope it does not end up a horr or story. Robin ________________________________________________________________________________
Date: Mar 23, 2013
Subject: Re: Airport Tower Closures
Robin, all that being said.... and said very well... thanks..... but isn't the savior talking to SoCal approach.- Seems like when I fly into Fullert on, SoCal is providing the best info.- But I guess with everything going on at WHP, it probably should be one of the last to be considered for closu re.- I try not to be in the air in the L.A. area on the weekends... you a lmost always have 2-5 bogeys on the screen!- Last trip down there I lande d at Aqua Dulce, but my cousin says WHP is closer... so next time it'll be WHP... thanks for the heads up for what's going on there. In the Sacramento are, I sure could see the savings of closing the towers a t Chico, Mather and Sac Exec.... and here in Texas there are at least 5 tow ered airports in the DFW area that certainly could be closed.- It seems t he municipalities are convinced that if they have a tower it'll bring in bu siness and jets, so they can sell more fuel.... but jets fly in and out of Lincoln Ca. with no tower.- We flew into Janesville WI and were the only plane talking to the tower, and also the only plane we saw for an hour eith er taking off or landing. --- On Sat, 3/23/13, Robin Marks wrote: From: Robin Marks <robin(at)PaintTheWeb.com> Subject: RV10-List: Airport Tower Closures om" Date: Saturday, March 23, 2013, 12:06 PM =0A=0A =0A =0A=0A=0A=0A=0A----------- I was reviewing the published list of 149 airport tower closures and was really surprised that I have landed 26 of the 149 on the list. I was further surprised=0A th at one of my home airports Whiteman (WHP) is slated for tower closure. Now I totally understand that if some towers MUST be closed than choices need t o be made and I further understand the NIMBY attitude of sure close some to wers but not MY towers. That=0A being said let me describe WHP to you and y ou can decide if this tower closure is a good idea. =0A------ ----- WHP is a one runway airport that sits under the Los Angeles Class B veil for LAX. WHP is 4 miles from Burbank commercial airport and 4 miles from Van Nuys airport=0A both very busy hubs if aviation. Furthermor e WHP sits near the Newhall pass which is a bit of a funnel for aircraft fe eding into and out the San Fernando Valley. Additionally WHP hosts 5 of LA' s news helicopters which park and hover taxi maybe 90 feet from=0A the runw ay centerline adjacent to the 30 run up area. Whitman is also home for the CDF (California Fire Department) heavy lift fire helicopters. Wikipedia say s that Cal Fire is "one of the largest non-military air programs in the cou ntry that includes 11 UH01H=0A Super Huey helicopters flying out of WHP. I know because they park and take off right behind my WHP hangar. The launch/ landing area for CDF is "not visible" from the tower and requires extra tow er control care for transitioning in and out of this area. WHP=0A also host s a modest amount of student training. Not a great deal of student training because costs have driven away many who may be interested in learning to f ly. -Additionally there is a fair amount of police helicopter activity in the area because WHP is=0A near some major highways 5, 118, 405, 101, 134, 210. Police tent to hover right at TPA for WHP.=0A =0A------ ----- So the typical WHP weekend scenario is the student pilot do ing T & G's while 3 737's are queued up to land Burbank as Golf streams are rocketing out of VNY with=0A police helicopters hovering over the nearby f reeways while the news choppers hover taxi back to their landing pad after their mornings work and small aircraft transition into and out of BUR or VN Y. All while CDF heavy lift choppers fly in and out of their=0A compound di rectly under the Left Downwind but blind to what is happening on and around the active runway. This is all occurring under LAX's Class B vial, under t he VNY airspace and in a little carve out of the Burbank airspace (SFC/4800 '). All this with mountain=0A peaks covering 180 degrees and within 5 miles of WHP. I have heard the tower chew out oblivious pilots dozens and dozens of times for clueless & -illegal transitioning of the airspace. I litera lly fear what it will be like w/o any control. It is not unusual=0A for me to see 15+ traffic targets on my display. =0A---------- - Last week I flew into WHP VFR but reporting 3 miles and haze. Not that uncommon. I have flown into WHP well over 500 times and it was very difficu lt for me to pick=0A up the runway 3 miles out even though I am quite famil iar with the topography. I am fortunate to have beautiful large PFD/MFD wit h traffic but I am painfully aware that most aircraft in the area do not ha ve nearly my experience and knowledge of the area or=0A my selection of equ ipment. =0A----------- This is just one story of 149. I hope it does not end up a horror story.=0A =0A - =0ARobin =0A - =0A =====================0A=0A ________________________________________________________________________________
Date: Mar 23, 2013
Robin Fullerton, that has EMS, LA fire helos, flight schools and , a couple of cit y police helos is also on the list. It is a busy airport under the B airspac e as well. Always busy and knowing its going to be a Corona on a larger scale is quite c oncerning. Airports under busy airspace like LA are going to suffer. Hopefully scal app roach will be able to handle flight following because it is going to be need ed. On Mar 23, 2013, at 10:06 AM, Robin Marks wrote: > I was reviewing the published list of 149 airport tower closur es and was really surprised that I have landed 26 of the 149 on the list. I w as further surprised that one of my home airports Whiteman (WHP) is slated f or tower closure. Now I totally understand that if some towers MUST be close d than choices need to be made and I further understand the NIMBY attitude o f sure close some towers but not MY towers. That being said let me describe W HP to you and you can decide if this tower closure is a good idea. > WHP is a one runway airport that sits under the Los Angeles Cl ass B veil for LAX. WHP is 4 miles from Burbank commercial airport and 4 mil es from Van Nuys airport both very busy hubs if aviation. Furthermore WHP si ts near the Newhall pass which is a bit of a funnel for aircraft feeding int o and out the San Fernando Valley. Additionally WHP hosts 5 of LA's news hel icopters which park and hover taxi maybe 90 feet from the runway centerline a djacent to the 30 run up area. Whitman is also home for the CDF (California Fire Department) heavy lift fire helicopters. Wikipedia says that Cal Fire i s "one of the largest non-military air programs in the country that includes 11 UH01H Super Huey helicopters flying out of WHP. I know because they park and take off right behind my WHP hangar. The launch/landing area for CDF is "not visible" from the tower and requires extra tower control care for tran sitioning in and out of this area. WHP also hosts a modest amount of student training. Not a great deal of student training because costs have driven aw ay many who may be interested in learning to fly. Additionally there is a f air amount of police helicopter activity in the area because WHP is near som e major highways 5, 118, 405, 101, 134, 210. Police tent to hover right at T PA for WHP. > So the typical WHP weekend scenario is the student pilot doing T & G's while 3 737's are queued up to land Burbank as Golf streams are roc keting out of VNY with police helicopters hovering over the nearby freeways w hile the news choppers hover taxi back to their landing pad after their morn ings work and small aircraft transition into and out of BUR or VNY. All whil e CDF heavy lift choppers fly in and out of their compound directly under th e Left Downwind but blind to what is happening on and around the active runw ay. This is all occurring under LAX's Class B vial, under the VNY airspace a nd in a little carve out of the Burbank airspace (SFC/4800'). All this with m ountain peaks covering 180 degrees and within 5 miles of WHP. I have heard t he tower chew out oblivious pilots dozens and dozens of times for clueless & illegal transitioning of the airspace. I literally fear what it will be li ke w/o any control. It is not unusual for me to see 15+ traffic targets on m y display. > Last week I flew into WHP VFR but reporting 3 miles and haze. N ot that uncommon. I have flown into WHP well over 500 times and it was very d ifficult for me to pick up the runway 3 miles out even though I am quite fam iliar with the topography. I am fortunate to have beautiful large PFD/MFD wi th traffic but I am painfully aware that most aircraft in the area do not ha ve nearly my experience and knowledge of the area or my selection of equipme nt. > This is just one story of 149. I hope it does not end up a hor ror story. > > Robin > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 23, 2013
Subject: Re: Main landing gear leg dimension
TWluZSBhcmUgMS43NSBpbmNoZXMgYXQgdGhlIHdpZGVzdCBwb2ludHMuDQpPbiBNYXIgMjEsIDIw MTMgNToyOCBQTSwgIlBhc2NhbCIgPHJ2MTBmbHllckBsaXZlLmNvbT4gd3JvdGU6DQoNCj4gICBD YW4gc29tZW9uZSB3aG8gZG9lcyBub3QgaGF2ZSB0aGUgbGFuZGluZyBnZWFyIHN0cnV0IHBhbnRz IG9uLCBtZWFzdXJlDQo+IHRoZSB3aWR0aCBvZiB0aGUgbGVnIGZvciBtZT8gSSB0aGluayBpdCBp cyAylCBidXQgbmVlZCBjb25maXJtYXRpb24uDQo+IFRoYW5rIHlvdSENCj4gUGFzY2FsDQo+DQo+ ICoNCj4NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1 bSAtDQo+IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBi cm93c2UNCj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sDQo+IF8tPSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2Us IENoYXQsIEZBUSwNCj4gXy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09 DQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlz dA0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZP UlVNUyAtDQo+IF8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBX ZWIgRm9ydW1zIQ0KPiBfLT0NCj4gXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNv bQ0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24g V2ViIFNpdGUgLQ0KPiBfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0K PiBfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRt aW4uDQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+ IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09DQo+ICoNCj4NCj4NCg= ________________________________________________________________________________
Date: Mar 23, 2013
SSByZWNhbGwgdGhlIGZpcnN0IHRpbWUgSSBmbGV3IGludG8gRnVsbGVydG9uLiBJIHdhcyBhIHN1 Yi0yMDAgaG91ciBwaWxvdCBvbiBvbmUgb2YgdGhvc2UgaGF6eSBMQSBkYXlzIHdpdGggYSBHYXJt aW4gMzk2IGFuZCBJIG5lZWRlZCB0b3dlciBhc3Npc3RhbmNlIGxvY2F0aW5nIHRoZSBhaXJwb3J0 IGRpcmVjdGx5IGluIGZyb250IG9mIG1lLiBJbiB0aGUgc2VhIG9mIGFzcGhhbHQgdGhhdCBpcyB0 aGUgTEEgYmFzaW4gaXQgd2FzIG5lYXIgaW1wb3NzaWJsZSB0byBwaWNrIG91dCB0aGUgYWlycG9y dCBmcm9tIHRoZSBkb3plbnMgVGFyZ2V0ICYgQ29zdGNvIHBhcmtpbmcgbG90cy4gT2gsIGFuZCB0 aGF0IHRhbGwgYW50ZW5uYSBuZWFyIEZ1bGxlcnRvbiBtYXkgZ2V0IHNvbWUgYWN0aW9uIHRvby4g VW5saWtlIHNvbWUgcnVyYWwgYXJlYXMsIGEgbWlkLWFpciBpbiBMQSB3aWxsIGxpa2VseSBpbnZv bHZlIHBlb3BsZSBvbiB0aGUgZ3JvdW5kLg0KSSBkb27igJl0IHdhbnQgdG8gc2VlbSBvdmVybHkg ZHJhbWF0aWMgYnV0IHBsYWdpYXJpemluZyB0aGUgbW92aWUgdGl0bGXigKYgIlRoZXJlIHdpbGwg YmUgYmxvb2QiLg0KDQpSb2Jpbg0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJv bmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9u IEJlaGFsZiBPZiBQYXNjYWwNClNlbnQ6IFNhdHVyZGF5LCBNYXJjaCAyMywgMjAxMyAxMjoyOSBQ TQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tOyBTb0NBTC1SVmxpc3RAeWFob29ncm91cHMu Y29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBBaXJwb3J0IFRvd2VyIENsb3N1cmVzDQoNClJv YmluDQpGdWxsZXJ0b24sIHRoYXQgaGFzIEVNUywgTEEgZmlyZSBoZWxvcywgZmxpZ2h0IHNjaG9v bHMgYW5kICwgYSBjb3VwbGUgb2YgY2l0eSBwb2xpY2UgaGVsb3MgaXMgYWxzbyBvbiB0aGUgbGlz dC4gSXQgaXMgYSBidXN5IGFpcnBvcnQgdW5kZXIgdGhlIEIgYWlyc3BhY2UgYXMgd2VsbC4NCkFs d2F5cyBidXN5IGFuZCBrbm93aW5nIGl0cyBnb2luZyB0byBiZSBhIENvcm9uYSBvbiBhIGxhcmdl ciBzY2FsZSBpcyBxdWl0ZSBjb25jZXJuaW5nLg0KQWlycG9ydHMgdW5kZXIgYnVzeSBhaXJzcGFj ZSBsaWtlIExBIGFyZSBnb2luZyB0byBzdWZmZXIuIEhvcGVmdWxseSBzY2FsIGFwcHJvYWNoIHdp bGwgYmUgYWJsZSB0byBoYW5kbGUgZmxpZ2h0IGZvbGxvd2luZyBiZWNhdXNlIGl0IGlzIGdvaW5n IHRvIGJlIG5lZWRlZC4NCg0KT24gTWFyIDIzLCAyMDEzLCBhdCAxMDowNiBBTSwgUm9iaW4gTWFy a3MgPHJvYmluQFBhaW50VGhlV2ViLmNvbTxtYWlsdG86cm9iaW5AUGFpbnRUaGVXZWIuY29tPj4g d3JvdGU6DQogICAgICAgICAgICBJIHdhcyByZXZpZXdpbmcgdGhlIHB1Ymxpc2hlZCBsaXN0IG9m IDE0OSBhaXJwb3J0IHRvd2VyIGNsb3N1cmVzIGFuZCB3YXMgcmVhbGx5IHN1cnByaXNlZCB0aGF0 IEkgaGF2ZSBsYW5kZWQgMjYgb2YgdGhlIDE0OSBvbiB0aGUgbGlzdC4gSSB3YXMgZnVydGhlciBz dXJwcmlzZWQgdGhhdCBvbmUgb2YgbXkgaG9tZSBhaXJwb3J0cyBXaGl0ZW1hbiAoV0hQKSBpcyBz bGF0ZWQgZm9yIHRvd2VyIGNsb3N1cmUuIE5vdyBJIHRvdGFsbHkgdW5kZXJzdGFuZCB0aGF0IGlm IHNvbWUgdG93ZXJzIE1VU1QgYmUgY2xvc2VkIHRoYW4gY2hvaWNlcyBuZWVkIHRvIGJlIG1hZGUg YW5kIEkgZnVydGhlciB1bmRlcnN0YW5kIHRoZSBOSU1CWSBhdHRpdHVkZSBvZiBzdXJlIGNsb3Nl IHNvbWUgdG93ZXJzIGJ1dCBub3QgTVkgdG93ZXJzLiBUaGF0IGJlaW5nIHNhaWQgbGV0IG1lIGRl c2NyaWJlIFdIUCB0byB5b3UgYW5kIHlvdSBjYW4gZGVjaWRlIGlmIHRoaXMgdG93ZXIgY2xvc3Vy ZSBpcyBhIGdvb2QgaWRlYS4NCiAgICAgICAgICAgIFdIUCBpcyBhIG9uZSBydW53YXkgYWlycG9y dCB0aGF0IHNpdHMgdW5kZXIgdGhlIExvcyBBbmdlbGVzIENsYXNzIEIgdmVpbCBmb3IgTEFYLiBX SFAgaXMgNCBtaWxlcyBmcm9tIEJ1cmJhbmsgY29tbWVyY2lhbCBhaXJwb3J0IGFuZCA0IG1pbGVz IGZyb20gVmFuIE51eXMgYWlycG9ydCBib3RoIHZlcnkgYnVzeSBodWJzIGlmIGF2aWF0aW9uLiBG dXJ0aGVybW9yZSBXSFAgc2l0cyBuZWFyIHRoZSBOZXdoYWxsIHBhc3Mgd2hpY2ggaXMgYSBiaXQg b2YgYSBmdW5uZWwgZm9yIGFpcmNyYWZ0IGZlZWRpbmcgaW50byBhbmQgb3V0IHRoZSBTYW4gRmVy bmFuZG8gVmFsbGV5LiBBZGRpdGlvbmFsbHkgV0hQIGhvc3RzIDUgb2YgTEEncyBuZXdzIGhlbGlj b3B0ZXJzIHdoaWNoIHBhcmsgYW5kIGhvdmVyIHRheGkgbWF5YmUgOTAgZmVldCBmcm9tIHRoZSBy dW53YXkgY2VudGVybGluZSBhZGphY2VudCB0byB0aGUgMzAgcnVuIHVwIGFyZWEuIFdoaXRtYW4g aXMgYWxzbyBob21lIGZvciB0aGUgQ0RGIChDYWxpZm9ybmlhIEZpcmUgRGVwYXJ0bWVudCkgaGVh dnkgbGlmdCBmaXJlIGhlbGljb3B0ZXJzLiBXaWtpcGVkaWEgc2F5cyB0aGF0IENhbCBGaXJlIGlz ICJvbmUgb2YgdGhlIGxhcmdlc3Qgbm9uLW1pbGl0YXJ5IGFpciBwcm9ncmFtcyBpbiB0aGUgY291 bnRyeSB0aGF0IGluY2x1ZGVzIDExIFVIMDFIIFN1cGVyIEh1ZXkgaGVsaWNvcHRlcnMgZmx5aW5n IG91dCBvZiBXSFAuIEkga25vdyBiZWNhdXNlIHRoZXkgcGFyayBhbmQgdGFrZSBvZmYgcmlnaHQg YmVoaW5kIG15IFdIUCBoYW5nYXIuIFRoZSBsYXVuY2gvbGFuZGluZyBhcmVhIGZvciBDREYgaXMg Im5vdCB2aXNpYmxlIiBmcm9tIHRoZSB0b3dlciBhbmQgcmVxdWlyZXMgZXh0cmEgdG93ZXIgY29u dHJvbCBjYXJlIGZvciB0cmFuc2l0aW9uaW5nIGluIGFuZCBvdXQgb2YgdGhpcyBhcmVhLiBXSFAg YWxzbyBob3N0cyBhIG1vZGVzdCBhbW91bnQgb2Ygc3R1ZGVudCB0cmFpbmluZy4gTm90IGEgZ3Jl YXQgZGVhbCBvZiBzdHVkZW50IHRyYWluaW5nIGJlY2F1c2UgY29zdHMgaGF2ZSBkcml2ZW4gYXdh eSBtYW55IHdobyBtYXkgYmUgaW50ZXJlc3RlZCBpbiBsZWFybmluZyB0byBmbHkuICBBZGRpdGlv bmFsbHkgdGhlcmUgaXMgYSBmYWlyIGFtb3VudCBvZiBwb2xpY2UgaGVsaWNvcHRlciBhY3Rpdml0 eSBpbiB0aGUgYXJlYSBiZWNhdXNlIFdIUCBpcyBuZWFyIHNvbWUgbWFqb3IgaGlnaHdheXMgNSwg MTE4LCA0MDUsIDEwMSwgMTM0LCAyMTAuIFBvbGljZSB0ZW50IHRvIGhvdmVyIHJpZ2h0IGF0IFRQ QSBmb3IgV0hQLg0KICAgICAgICAgICAgU28gdGhlIHR5cGljYWwgV0hQIHdlZWtlbmQgc2NlbmFy aW8gaXMgdGhlIHN0dWRlbnQgcGlsb3QgZG9pbmcgVCAmIEcncyB3aGlsZSAzIDczNydzIGFyZSBx dWV1ZWQgdXAgdG8gbGFuZCBCdXJiYW5rIGFzIEdvbGYgc3RyZWFtcyBhcmUgcm9ja2V0aW5nIG91 dCBvZiBWTlkgd2l0aCBwb2xpY2UgaGVsaWNvcHRlcnMgaG92ZXJpbmcgb3ZlciB0aGUgbmVhcmJ5 IGZyZWV3YXlzIHdoaWxlIHRoZSBuZXdzIGNob3BwZXJzIGhvdmVyIHRheGkgYmFjayB0byB0aGVp ciBsYW5kaW5nIHBhZCBhZnRlciB0aGVpciBtb3JuaW5ncyB3b3JrIGFuZCBzbWFsbCBhaXJjcmFm dCB0cmFuc2l0aW9uIGludG8gYW5kIG91dCBvZiBCVVIgb3IgVk5ZLiBBbGwgd2hpbGUgQ0RGIGhl YXZ5IGxpZnQgY2hvcHBlcnMgZmx5IGluIGFuZCBvdXQgb2YgdGhlaXIgY29tcG91bmQgZGlyZWN0 bHkgdW5kZXIgdGhlIExlZnQgRG93bndpbmQgYnV0IGJsaW5kIHRvIHdoYXQgaXMgaGFwcGVuaW5n IG9uIGFuZCBhcm91bmQgdGhlIGFjdGl2ZSBydW53YXkuIFRoaXMgaXMgYWxsIG9jY3VycmluZyB1 bmRlciBMQVgncyBDbGFzcyBCIHZpYWwsIHVuZGVyIHRoZSBWTlkgYWlyc3BhY2UgYW5kIGluIGEg bGl0dGxlIGNhcnZlIG91dCBvZiB0aGUgQnVyYmFuayBhaXJzcGFjZSAoU0ZDLzQ4MDAnKS4gQWxs IHRoaXMgd2l0aCBtb3VudGFpbiBwZWFrcyBjb3ZlcmluZyAxODAgZGVncmVlcyBhbmQgd2l0aGlu IDUgbWlsZXMgb2YgV0hQLiBJIGhhdmUgaGVhcmQgdGhlIHRvd2VyIGNoZXcgb3V0IG9ibGl2aW91 cyBwaWxvdHMgZG96ZW5zIGFuZCBkb3plbnMgb2YgdGltZXMgZm9yIGNsdWVsZXNzICYgIGlsbGVn YWwgdHJhbnNpdGlvbmluZyBvZiB0aGUgYWlyc3BhY2UuIEkgbGl0ZXJhbGx5IGZlYXIgd2hhdCBp dCB3aWxsIGJlIGxpa2Ugdy9vIGFueSBjb250cm9sLiBJdCBpcyBub3QgdW51c3VhbCBmb3IgbWUg dG8gc2VlIDE1KyB0cmFmZmljIHRhcmdldHMgb24gbXkgZGlzcGxheS4NCiAgICAgICAgICAgIExh c3Qgd2VlayBJIGZsZXcgaW50byBXSFAgVkZSIGJ1dCByZXBvcnRpbmcgMyBtaWxlcyBhbmQgaGF6 ZS4gTm90IHRoYXQgdW5jb21tb24uIEkgaGF2ZSBmbG93biBpbnRvIFdIUCB3ZWxsIG92ZXIgNTAw IHRpbWVzIGFuZCBpdCB3YXMgdmVyeSBkaWZmaWN1bHQgZm9yIG1lIHRvIHBpY2sgdXAgdGhlIHJ1 bndheSAzIG1pbGVzIG91dCBldmVuIHRob3VnaCBJIGFtIHF1aXRlIGZhbWlsaWFyIHdpdGggdGhl IHRvcG9ncmFwaHkuIEkgYW0gZm9ydHVuYXRlIHRvIGhhdmUgYmVhdXRpZnVsIGxhcmdlIFBGRC9N RkQgd2l0aCB0cmFmZmljIGJ1dCBJIGFtIHBhaW5mdWxseSBhd2FyZSB0aGF0IG1vc3QgYWlyY3Jh ZnQgaW4gdGhlIGFyZWEgZG8gbm90IGhhdmUgbmVhcmx5IG15IGV4cGVyaWVuY2UgYW5kIGtub3ds ZWRnZSBvZiB0aGUgYXJlYSBvciBteSBzZWxlY3Rpb24gb2YgZXF1aXBtZW50Lg0KICAgICAgICAg ICAgVGhpcyBpcyBqdXN0IG9uZSBzdG9yeSBvZiAxNDkuIEkgaG9wZSBpdCBkb2VzIG5vdCBlbmQg dXAgYSBob3Jyb3Igc3RvcnkuDQoNClJvYmluDQoNCg0KDQoNCg0KDQoNCg0KDQoNCg0KDQpfLT0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRA0KDQpfLT0zRCAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0K DQpfLT0zRCBVc2UgdGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93 c2UNCg0KXy09M0QgdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNj cmlwdGlvbiwNCg0KXy09M0QgQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3Nl LCBDaGF0LCBGQVEsDQoNCl8tPTNEIFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0K Xy09M0QNCg0KXy09M0QgICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S VjEwLUxpc3Q8M0QlMjJodHRwOi93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0 JTIyPg0KDQpfLT0zRA0KDQpfLT0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KDQpfLT0zRCAgICAgICAgICAgICAgIC0gTUFU Uk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0zRCBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFp bGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0zRA0KDQpfLT0zRCAgIC0tPiBodHRwOi8v Zm9ydW1zLm1hdHJvbmljcy5jb208M0QlMjJodHRwOi9mb3J1bXMubWF0cm9uaWNzLmNvbSUyMj4N Cg0KXy09M0QNCg0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0KXy09M0QgICAgICAgICAgICAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtDQoNCl8tPTNEICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMg c3VwcG9ydCENCg0KXy09M0QgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFs bGUsIExpc3QgQWRtaW4uDQoNCl8tPTNEICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb248M0QlMjJodHRwOi93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24lMjI+ DQoNCl8tPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEDQoNCg0K ________________________________________________________________________________
Date: Mar 23, 2013
Yes SoCal ATC is helpful for sure I usually have 4 hand off' s within 20 mi les of WHP between Magoo, LA Center & SoCal but 8 miles out as one approac hes WHP, VNY and BUR we are handed off to the tower freq. Anything under 30 00 MSL goes to the tower as SoCal either can't see you or does not have the time to help or both. I use Flight Following basically 100% of the time in and out of LA and sometimes SoCal can't take the handoff due to workload. Add trying to get Flight Following with SoCal on climb out (vs. on the grou nd with WHP Ground Control) will bogies everywhere further taxes the pilot and an already thin system. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Don McDonald Sent: Saturday, March 23, 2013 10:47 AM Subject: Re: RV10-List: Airport Tower Closures Robin, all that being said.... and said very well... thanks..... but isn't the savior talking to SoCal approach. Seems like when I fly into Fullerton , SoCal is providing the best info. But I guess with everything going on a t WHP, it probably should be one of the last to be considered for closure. I try not to be in the air in the L.A. area on the weekends... you almost always have 2-5 bogeys on the screen! Last trip down there I landed at Aqu a Dulce, but my cousin says WHP is closer... so next time it'll be WHP... t hanks for the heads up for what's going on there. In the Sacramento are, I sure could see the savings of closing the towers a t Chico, Mather and Sac Exec.... and here in Texas there are at least 5 tow ered airports in the DFW area that certainly could be closed. It seems the municipalities are convinced that if they have a tower it'll bring in busi ness and jets, so they can sell more fuel.... but jets fly in and out of Li ncoln Ca. with no tower. We flew into Janesville WI and were the only plan e talking to the tower, and also the only plane we saw for an hour either t aking off or landing. --- On Sat, 3/23/13, Robin Marks > wrote: From: Robin Marks <robin(at)PaintTheWeb.com<mailto:robin(at)PaintTheWeb.com>> Subject: RV10-List: Airport Tower Closures s.com>, "rv10-list(at)matronics.com" > Date: Saturday, March 23, 2013, 12:06 PM I was reviewing the published list of 149 airport tower closure s and was really surprised that I have landed 26 of the 149 on the list. I was further surprised that one of my home airports Whiteman (WHP) is slated for tower closure. Now I totally understand that if some towers MUST be cl osed than choices need to be made and I further understand the NIMBY attitu de of sure close some towers but not MY towers. That being said let me desc ribe WHP to you and you can decide if this tower closure is a good idea. WHP is a one runway airport that sits under the Los Angeles Cla ss B veil for LAX. WHP is 4 miles from Burbank commercial airport and 4 mil es from Van Nuys airport both very busy hubs if aviation. Furthermore WHP s its near the Newhall pass which is a bit of a funnel for aircraft feeding i nto and out the San Fernando Valley. Additionally WHP hosts 5 of LA's news helicopters which park and hover taxi maybe 90 feet from the runway centerl ine adjacent to the 30 run up area. Whitman is also home for the CDF (Calif ornia Fire Department) heavy lift fire helicopters. Wikipedia says that Cal Fire is "one of the largest non-military air programs in the country that includes 11 UH01H Super Huey helicopters flying out of WHP. I know because they park and take off right behind my WHP hangar. The launch/landing area for CDF is "not visible" from the tower and requires extra tower control ca re for transitioning in and out of this area. WHP also hosts a modest amoun t of student training. Not a great deal of student training because costs h ave driven away many who may be interested in learning to fly. Additionall y there is a fair amount of police helicopter activity in the area because WHP is near some major highways 5, 118, 405, 101, 134, 210. Police tent to hover right at TPA for WHP. So the typical WHP weekend scenario is the student pilot doing T & G's while 3 737's are queued up to land Burbank as Golf streams are roc keting out of VNY with police helicopters hovering over the nearby freeways while the news choppers hover taxi back to their landing pad after their m ornings work and small aircraft transition into and out of BUR or VNY. All while CDF heavy lift choppers fly in and out of their compound directly und er the Left Downwind but blind to what is happening on and around the activ e runway. This is all occurring under LAX's Class B vial, under the VNY air space and in a little carve out of the Burbank airspace (SFC/4800'). All th is with mountain peaks covering 180 degrees and within 5 miles of WHP. I ha ve heard the tower chew out oblivious pilots dozens and dozens of times for clueless & illegal transitioning of the airspace. I literally fear what i t will be like w/o any control. It is not unusual for me to see 15+ traffic targets on my display. Last week I flew into WHP VFR but reporting 3 miles and haze. N ot that uncommon. I have flown into WHP well over 500 times and it was very difficult for me to pick up the runway 3 miles out even though I am quite familiar with the topography. I am fortunate to have beautiful large PFD/MF D with traffic but I am painfully aware that most aircraft in the area do n ot have nearly my experience and knowledge of the area or my selection of e quipment. This is just one story of 149. I hope it does not end up a horr or story. Robin http://www.matrolow" target="_blank" href="http://forums.matronics.com" >http://forums.m= --> <http://www.matro========%3c/font%3e%3c/b%3e%3c/pre%3e%3c/ div%3e%3c/div%3e%3c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3e%3c b%3e%3cfont%20size=2%20color=000000> ===========<http://www.matro========% 3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e%3c/blockquote%3e%3c/td%3e% 3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20size=2%20color=000000> ====%3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e%3c/blockquote %3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20size=2%20color =000000> ========%3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e%3 c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20size =2%20color=000000> o========%3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e% 3c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20siz e=2%20color=000000> ========%3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e%3 c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20size =2%20color=000000> =%3c/font%3e%3c/b%3e%3c/pre%3e%3c/div%3e%3c/div%3e%3c/blockquote%3e%3c/td %3e%3c/tr%3e%3c/table%3e%3cpre%3e%3cb%3e%3cfont%20size=2%20color=000000 > %3c/div%3e%3c/div%3e%3c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e%3cpre%3 e%3cb%3e%3cfont%20size=2%20color=000000> /pre%3e%3c/div%3e%3c/div%3e%3c/blockquote%3e%3c/td%3e%3c/tr%3e%3c/table%3e% 3cpre%3e%3cb%3e%3cfont%20size=2%20color=000000> http://www.matronics.co m/Navigator?RV10-List ________________________________________________________________________________
Date: Mar 23, 2013
Right on! On Mar 23, 2013, at 12:45 PM, Robin Marks wrote: > I recall the first time I flew into Fullerton. I was a sub-200 hour pilot o n one of those hazy LA days with a Garmin 396 and I needed tower assistance l ocating the airport directly in front of me. In the sea of asphalt that is t he LA basin it was near impossible to pick out the airport from the dozens T arget & Costco parking lots. Oh, and that tall antenna near Fullerton may ge t some action too. Unlike some rural areas, a mid-air in LA will likely invo lve people on the ground. > I don=99t want to seem overly dramatic but plagiarizing the movie ti tle "There will be blood". > > Robin > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Pascal > Sent: Saturday, March 23, 2013 12:29 PM > To: rv10-list(at)matronics.com; SoCAL-RVlist(at)yahoogroups.com > Subject: Re: RV10-List: Airport Tower Closures > > Robin > Fullerton, that has EMS, LA fire helos, flight schools and , a couple of c ity police helos is also on the list. It is a busy airport under the B airsp ace as well. > Always busy and knowing its going to be a Corona on a larger scale is quit e concerning. > Airports under busy airspace like LA are going to suffer. Hopefully scal a pproach will be able to handle flight following because it is going to be ne eded. > > > On Mar 23, 2013, at 10:06 AM, Robin Marks wrote: > > I was reviewing the published list of 149 airport tower closur es and was really surprised that I have landed 26 of the 149 on the list. I w as further surprised that one of my home airports Whiteman (WHP) is slated f or tower closure. Now I totally understand that if some towers MUST be close d than choices need to be made and I further understand the NIMBY attitude o f sure close some towers but not MY towers. That being said let me describe W HP to you and you can decide if this tower closure is a good idea. > WHP is a one runway airport that sits under the Los Angeles Cl ass B veil for LAX. WHP is 4 miles from Burbank commercial airport and 4 mil es from Van Nuys airport both very busy hubs if aviation. Furthermore WHP si ts near the Newhall pass which is a bit of a funnel for aircraft feeding int o and out the San Fernando Valley. Additionally WHP hosts 5 of LA's news hel icopters which park and hover taxi maybe 90 feet from the runway centerline a djacent to the 30 run up area. Whitman is also home for the CDF (California Fire Department) heavy lift fire helicopters. Wikipedia says that Cal Fire i s "one of the largest non-military air programs in the country that includes 11 UH01H Super Huey helicopters flying out of WHP. I know because they park and take off right behind my WHP hangar. The launch/landing area for CDF is "not visible" from the tower and requires extra tower control care for tran sitioning in and out of this area. WHP also hosts a modest amount of student training. Not a great deal of student training because costs have driven aw ay many who may be interested in learning to fly. Additionally there is a f air amount of police helicopter activity in the area because WHP is near som e major highways 5, 118, 405, 101, 134, 210. Police tent to hover right at T PA for WHP. > So the typical WHP weekend scenario is the student pilot doing T & G's while 3 737's are queued up to land Burbank as Golf streams are roc keting out of VNY with police helicopters hovering over the nearby freeways w hile the news choppers hover taxi back to their landing pad after their morn ings work and small aircraft transition into and out of BUR or VNY. All whil e CDF heavy lift choppers fly in and out of their compound directly under th e Left Downwind but blind to what is happening on and around the active runw ay. This is all occurring under LAX's Class B vial, under the VNY airspace a nd in a little carve out of the Burbank airspace (SFC/4800'). All this with m ountain peaks covering 180 degrees and within 5 miles of WHP. I have heard t he tower chew out oblivious pilots dozens and dozens of times for clueless & illegal transitioning of the airspace. I literally fear what it will be li ke w/o any control. It is not unusual for me to see 15+ traffic targets on m y display. > Last week I flew into WHP VFR but reporting 3 miles and haze. N ot that uncommon. I have flown into WHP well over 500 times and it was very d ifficult for me to pick up the runway 3 miles out even though I am quite fam iliar with the topography. I am fortunate to have beautiful large PFD/MFD wi th traffic but I am painfully aware that most aircraft in the area do not ha ve nearly my experience and knowledge of the area or my selection of equipme nt. > This is just one story of 149. I hope it does not end up a hor ror story. > > Robin > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > )=EF=BD=EF=BD=DF=A2{l=EF=BD7=EF=BDr=EF=BDh=EF=BDM4=EF =BDM=1Fi=C7=9C=EF=BD=EF=BD=EF=BDz=EF=BD=EF=BD=EF=BD=EF=BD .=EF=BD'=EF=BDN=17=EF=BDW]=0B=EF=BD=EF=BDD=EF=BD=EF=BD=EF =BD=16=EF=BD=EF=BDK=1E=EF=BD=17=EF=BDj=EF=BD=EF=BD',.+- =15=E6=AD=BA=EF=BD=EF=BD5=EF=BD=81=ABh=EF=BD=EF=BD=1B=EF =BD=EF=BD,z=EF=BD^=EF=BD=EF=BD=EF=BD.+-=EF=BD=D8=A5=EF=BD =D8=9E=EF=BD=CB=9C=EF=BD=EF=BD=0B=EF=BD=EF=BDT=EF=BD=EF =BDn=EF=BD+=EF=BD=EF=BDb=EF=BDp+r=18=EF=BDy'=EF=BD=EF=BD =EF=BDC=EF=BD =E5=A1=A7{ =EF=BD=EF=BD=EF=BD=EF=BD,x(Z =EF=BDP=10>=1A-=EF=BD=EF=BDZ=EF=BD=EF=BDvk=EF=BD=EF=BDk =EF=BD=EF=BDj+y=EF=BDky=EF=BDm=EF=BD=EF=BD=EF=BD=EF=BD =0C&j=EF=BD=EF=BD',r=EF=BD=EF=BD5=EF=BD=81=ABh=EF=BD=15 u=D0=B8=EF=BD=EF=BD=1Bm=EF=BD=EF=BD=EF=BD=EF=BD =EF =BD=EF=BD=EF=BD'=EF=BD=EF=BD=1C=EF=BDo=EF=BDj=EF=BDj =EF=BD+E]t.+-=EF=BDM=13=EF=BD $=EF=BD=10=11NEC=12I=EF=BD=EF =BD=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD'=EF=BD=EF=BD=EF=BD j[(j=EF=BD=EF=BDz=EF=BD=17=EF=BDy=EF=BDh=EF=BD=EF=BDj=1A =EF=BD~=1Bm=EF=BD=EF=BD=DF=A2=EF=BD=EF=BD=EF=BDf=EF=BD=EF =BD=EF=BD=EF=BDr=EF=BD(=EF=BD=1Bm=EF=BD=EF=BD=DF=A2=EF =BD=EF=BD=EF=BDf=EF=BD=EF=BD=EF=BD=EF=BDr=EF=BD(=EF=BD =EF=BD=EF=BDB=EF=BD{k=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=EF =BDy=EF=BD=EF=BD=EF=BD=EF=BD=EF=BDjy2=EF=BD=EF=BD=EF =BD*.=EF=BD=07=EF=BDz=EF=BD.=EF=BD=CB=A9=EF=BD=EF=BD=EF =BD1=EF=BDm=0E=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=EF=BD=1D =EF=BD)=DA=86=EF=BD=EF=BD=EF=BD=EF=BDi=EF=BD=EF=BD0=EF =BDf=EF=BD=EF=BD=EF=BD=EF=BDr=EF=BD(=EF=BD=EF=BD(=EF =BD=EF=BD=EF=BDn=EF=BDb=EF=BDxm=EF=BD=EF=BD=EF=BD=EF =BD=0C&j=EF=BD=EF=BD',r=EF=BD=EF=BDr=EF=BD=EF=BD&=EF=BD *'=EF=BD=EF=BD=EF=BD=EF=BD'=EF=BD=EF=BDk{=EF=BD=EF=BD w/=EF=BDi ________________________________________________________________________________
Subject: Re: Seat adjusters
Date: Mar 23, 2013
I am also interested in a set. Johan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396891#396891 ________________________________________________________________________________
Date: Mar 23, 2013
We should have a bunch of sets available by the end of next week. I'll post on this thread when they are ready. Thanks, Tim Aircrafters 831-722-9141 Sent from my iPhone On Mar 23, 2013, at 10:21 PM, "Dorfie" wrote: > > I am also interested in a set. > Johan > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=396891#396891 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 24, 2013
They need to get a work slow down or close the airports in DC to get congress off its collective rear ends and end the ridiculous chopping of useful government services that we are paying for in income taxes and fuel taxes. The FAA should be fully funded and able to run in the black from the funds it collects. This entire closure thing is congress made. My airport KSUA is closing too. Real people are being laid off, will lose their homes, and add to those getting paid unemployment to not work. They won't find a job In another tower. Stupid. My friend works for the army corps of engineers and they are getting cut one day a week startinh April 1st, a 20% forced pay cut as if the budget issue is their fault? It will kill his family budget, obligstions he made while working, so congress can play games. This is by politicsl choice. Congress has no downside to continue on this path unless we ALL act now. Pick up your phone and tell congress this is NOT an acceptable way to fix the budget, real people are being hurt, and lives will be lost over LA. We can probably live without a tower here, with mostly an inconvenience to the weekend jet set that arrive in some top dollar jets, IFR hand off from Palm Beach to play golf. But they continue to get a tax cut?? And the guy in the tower loses his job? Pick up your phone and let your congressman know you are angry or they will do nothing and real people will suffer. Stephen Blank, DDS Port Saint Lucie, FL ________________________________________________________________________________
Date: Mar 24, 2013
I think the problem lies with tghe President .... who predicted a disaster if sequestration happened ..... and the disaster never came. So he directs the agencies to cut in the most visible ways. He doesn't care what happens to the unemployment figures anymore. He'd rather play golf. I, for one, feel the Gov't (and all the agencies) is bloated and needs to be cut. Not all at once, mind you, but through attrition. That doesn't ever seem to happen though and the elephant in the room keeps getting bigger and bigger. I feel the pain for the people in the towers that get laid off, just as I feel for those that lost jobs in the civil sector. It ain't pretty out there so fly safely and we'll get past this. Pilots are a pretty flexible bunch. Laying off IFR controllers would be far more devastating than closing towers IMHO. Linn On 3/24/2013 8:13 AM, Stephen Blank,DDS wrote: > > They need to get a work slow down or close the airports in DC to get > congress off its collective rear ends and end the ridiculous chopping > of useful government services that we are paying for in income taxes > and fuel taxes. The FAA should be fully funded and able to run in the > black from the funds it collects. > This entire closure thing is congress made. My airport KSUA is > closing too. Real people are being laid off, will lose their homes, > and add to those getting paid unemployment to not work. They won't > find a job In another tower. Stupid. > My friend works for the army corps of engineers and they are > getting cut one day a week startinh April 1st, a 20% forced pay cut as > if the budget issue is their fault? It will kill his family budget, > obligstions he made while working, so congress can play games. This is > by politicsl choice. Congress has no downside to continue on this path > unless we ALL act now. > Pick up your phone and tell congress this is NOT an acceptable > way to fix the budget, real people are being hurt, and lives will be > lost over LA. We can probably live without a tower here, with mostly > an inconvenience to the weekend jet set that arrive in some top dollar > jets, IFR hand off from Palm Beach to play golf. But they continue to > get a tax cut?? And the guy in the tower loses his job? Pick up your > phone and let your congressman know you are angry or they will do > nothing and real people will suffer. > > Stephen Blank, DDS > Port Saint Lucie, FL > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 24, 2013
The president in America does not write legislation, congress does. The president is obligated to follow the budgetary rules they created. Only congress can fix this. It helps no one for you to blast your opinion that you think the president would rather play golf and doesnt care about the unemployed. That is just complaining without results. Call your congressman and let then know you want results or their pay should be cut, not working government employees. This does not have to be a dem vs rep fight. We all want effective laws and congressman that work for the common good. There is a ton of common ground, many things could be passed if they stop playing political games and pandering to the extremes of either party. Call your congressman, that is how it works. Google your state name (Florida us congressman, for example) and look up some phone numbers. They are always nice when I call, and I am seldomly agreeing with them. If no one calls they think they are doing a great job. They have no clue the country is pissed off with inaction. FYI did you know the DOD is the largest consumer of oil world wide? Is our military big enough yet? Stephen Blank, DDS On Mar 24, 2013 8:43 AM, "Linn" wrote: > I think the problem lies with tghe President .... who predicted a > disaster if sequestration happened ..... and the disaster never came. So > he directs the agencies to cut in the most visible ways. He doesn't care > what happens to the unemployment figures anymore. He'd rather play golf. > I, for one, feel the Gov't (and all the agencies) is bloated and needs to > be cut. Not all at once, mind you, but through attrition. That doesn't > ever seem to happen though and the elephant in the room keeps getting > bigger and bigger. I feel the pain for the people in the towers that get > laid off, just as I feel for those that lost jobs in the civil sector. It > ain't pretty out there so fly safely and we'll get past this. Pilots are a > pretty flexible bunch. > Laying off IFR controllers would be far more devastating than closing > towers IMHO. > Linn > > > On 3/24/2013 8:13 AM, Stephen Blank,DDS wrote: > > They need to get a work slow down or close the airports in DC to get > congress off its collective rear ends and end the ridiculous chopping of > useful government services that we are paying for in income taxes and fuel > taxes. The FAA should be fully funded and able to run in the black from the > funds it collects. > This entire closure thing is congress made. My airport KSUA is closing > too. Real people are being laid off, will lose their homes, and add to > those getting paid unemployment to not work. They won't find a job In > another tower. Stupid. > My friend works for the army corps of engineers and they are getting > cut one day a week startinh April 1st, a 20% forced pay cut as if the > budget issue is their fault? It will kill his family budget, obligstions > he made while working, so congress can play games. This is by politicsl > choice. Congress has no downside to continue on this path unless we ALL act > now. > Pick up your phone and tell congress this is NOT an acceptable way to > fix the budget, real people are being hurt, and lives will be lost over LA. > We can probably live without a tower here, with mostly an inconvenience to > the weekend jet set that arrive in some top dollar jets, IFR hand off from > Palm Beach to play golf. But they continue to get a tax cut?? And the guy > in the tower loses his job? Pick up your phone and let your congressman > know you are angry or they will do nothing and real people will suffer. > > Stephen Blank, DDS > Port Saint Lucie, FL > > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com > 03/23/13 > > > * > > * > > ________________________________________________________________________________
Date: Mar 24, 2013
Like you I call and write, and I encourage others to do the same. True, the President doesn't write legislation, but he surely directs policy and signs legislation that he likes. My country is in deep trouble and I see no progress in fixing that. I will survive (for a long time, hopefully) but I fear for my children and my grandkids future. There's no doubt the basic problems lie in the legislators that cater to their constituents because their jobs are on the line every four years. The voters spoke, and I think we will suffer for it. As for the golf .... it's just what I see. Linn ..... last call. On 3/24/2013 9:08 AM, Stephen Blank,DDS wrote: > > The president in America does not write legislation, congress does. > The president is obligated to follow the budgetary rules they created. > Only congress can fix this. It helps no one for you to blast your > opinion that you think the president would rather play golf and doesnt > care about the unemployed. That is just complaining without results. > Call your congressman and let then know you want results or their > pay should be cut, not working government employees. This does not > have to be a dem vs rep fight. We all want effective laws and > congressman that work for the common good. There is a ton of common > ground, many things could be passed if they stop playing political > games and pandering to the extremes of either party. > Call your congressman, that is how it works. Google your state > name (Florida us congressman, for example) and look up some phone > numbers. They are always nice when I call, and I am seldomly agreeing > with them. If no one calls they think they are doing a great job. They > have no clue the country is pissed off with inaction. > FYI did you know the DOD is the largest consumer of oil world wide? > Is our military big enough yet? > > Stephen Blank, DDS > > On Mar 24, 2013 8:43 AM, "Linn" > wrote: > > I think the problem lies with tghe President .... who predicted a > disaster if sequestration happened ..... and the disaster never > came. So he directs the agencies to cut in the most visible > ways. He doesn't care what happens to the unemployment figures > anymore. He'd rather play golf. I, for one, feel the Gov't (and > all the agencies) is bloated and needs to be cut. Not all at > once, mind you, but through attrition. That doesn't ever seem to > happen though and the elephant in the room keeps getting bigger > and bigger. I feel the pain for the people in the towers that get > laid off, just as I feel for those that lost jobs in the civil > sector. It ain't pretty out there so fly safely and we'll get > past this. Pilots are a pretty flexible bunch. > Laying off IFR controllers would be far more devastating than > closing towers IMHO. > Linn > > > On 3/24/2013 8:13 AM, Stephen Blank,DDS wrote: >> >> They need to get a work slow down or close the airports in DC to >> get congress off its collective rear ends and end the ridiculous >> chopping of useful government services that we are paying for in >> income taxes and fuel taxes. The FAA should be fully funded and >> able to run in the black from the funds it collects. >> This entire closure thing is congress made. My airport KSUA >> is closing too. Real people are being laid off, will lose their >> homes, and add to those getting paid unemployment to not work. >> They won't find a job In another tower. Stupid. >> My friend works for the army corps of engineers and they are >> getting cut one day a week startinh April 1st, a 20% forced pay >> cut as if the budget issue is their fault? It will kill his >> family budget, obligstions he made while working, so congress can >> play games. This is by politicsl choice. Congress has no downside >> to continue on this path unless we ALL act now. >> Pick up your phone and tell congress this is NOT an >> acceptable way to fix the budget, real people are being hurt, and >> lives will be lost over LA. We can probably live without a tower >> here, with mostly an inconvenience to the weekend jet set that >> arrive in some top dollar jets, IFR hand off from Palm Beach to >> play golf. But they continue to get a tax cut?? And the guy in >> the tower loses his job? Pick up your phone and let your >> congressman know you are angry or they will do nothing and real >> people will suffer. >> >> Stephen Blank, DDS >> Port Saint Lucie, FL >> >> * >> >> >> * >> >> No virus found in this message. >> Checked by AVG - www.avg.com <http://www.avg.com> >> 03/23/13 >> > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 24, 2013
Ok, enough politics.... but the sequestration was the presidents idea. --- On Sun, 3/24/13, Stephen Blank,DDS wrote: From: Stephen Blank,DDS <sblankdds(at)gmail.com> Subject: Re: RV10-List: Airport Tower Closures Date: Sunday, March 24, 2013, 8:08 AM The president in America does not write legislation, congress does. The pre sident is obligated to follow the budgetary rules they created. Only congre ss can fix this. It helps no one for you to blast your opinion that you thi nk the president would rather play golf and doesnt care about the unemploye d. That is just complaining without results. =0A=0A--- Call your congressman and let then know you want results or their pay should be cut, not working government employees. This does not h ave to be a dem vs rep fight. We all want effective laws and congressman th at work for the common good. There is a ton of common ground, many things c ould be passed if they stop playing political games and pandering to the ex tremes of either party. =0A=0A-- Call your congressman, that is how it works. Google your state name- (Florida us congressman, for example) and look up some phone numbe rs. They are always nice when I call, and I am seldomly agreeing with them. If no one calls they think they are doing a great job. They have no clue t he country is pissed off with inaction. =0A=0A-- FYI did you know the DOD is the largest consumer of oil world wide? Is our military big enough yet?=0AStephen Blank, DDS=0AOn Mar 24, 201 3 8:43 AM, "Linn" wrote: =0A=0A =0A =0A =0A =0A I think the problem lies with tghe=0A President .... who predicted a disaster if sequestration happened=0A . .... and the disaster never came.- So he directs the agencies to=0A cut in the most visible ways.- He doesn't care what happens to the=0A unemployment figures anymore.- He'd rather play golf.- I, for one,=0A feel the Gov't (and all the agencies) is bloated and needs to be=0A cut.- Not all at once, mind you, but through attrition.- That=0A doesn't ever seem to happen though and the elephant in the room=0A keeps getting bigger and bigger.- I feel the pain for the people=0A in the towers that get laid off, just as I feel for those that=0A lost jobs in the civil sector.- It ain't pretty out there so fly=0A safe ly and we'll get past this.- Pilots are a pretty flexible=0A bunch. =0A Laying off IFR controllers would be far more devastating than=0A closing towers IMHO. =0A Linn =0A =0A =0A On 3/24/2013 8:13 AM, Stephen Blank,DDS wrote: =0A =0A =0A They need to get a work slow down or close the=0A airports in DC to get congress off its collective rear ends and=0A end the ridiculous chopping of useful government services that=0A we are paying for in income taxes and fuel taxes. The FAA should=0A be fully funded and able to run in the black from the funds it=0A collects. =0A --- This entire closure thing is congress made. My airport KSUA=0A is closing too.- Real people are being laid off, will los e their=0A homes, and add to those getting paid unemployment to not work.=0A They won't find a job In another tower. Stupid. =0A ---- My friend works for the army corps of engineers and they=0A are getting cut one day a week startinh April 1st, a 20% fo rced=0A pay cut as if the budget issue is their fault?- It will ki ll his=0A family budget, obligstions he made while working, so congr ess=0A can play games. This is by politicsl choice. Congress has no =0A downside to continue on this path unless we ALL act now. =0A ---- Pick up your phone and tell congress this is NOT an =0A acceptable way to fix the budget, real people are being hurt,=0A and lives will be lost over LA. We can probably live without a=0A tower here, with mostly an inconvenience to the weekend jet set=0A that arrive in some top dollar jets, IFR hand off from Palm=0A Beach to play golf. But they continue to get a tax cut??- And=0A t he guy in the tower loses his job? Pick up your phone and let=0A you r congressman know you are angry or they will do nothing and=0A real people will suffer.=0A Stephen Blank, DDS =0A Port Saint Lucie, FL=0A =0A=0A=0A=0A No virus=0A found in this message. =0A Checked by AVG - www.avg.com =0A 03/23/13=0A =0A =0A =0A=0A=0A=0A=0Aget="_blank">http://www.matronics.com/Navigator?RV10- List=0Atp://forums.matronics.com=0A_blank">http://www.matronics.com/contrib =======================0A=0A ________________________________________________________________________________
Date: Mar 24, 2013
FYI did you know the DOD is the largest consumer of oil world wide? Is our military big enough yet? It may be large enough, and it can be more efficient. But that is not the sequestration question. The question is who is responsible for the mess we are in today. I don't think you should waste your time calling your congress person...call you senators, they are the ones not taking action. The house has passed many bills..the senate just will not take them up. But to get back to flying...flew from Idaho Falls Id to Ogden Utah yesterday. The guys up in Idaho Falls were all upset about losing their tower and worried that it really will affect their business. Here at Ogden it is a mixed bag about losing the tower..of the people I have talked to it is about 50/50. I am on the I don't care list.I care about the people losing their job, but I don't care about not having a tower. Our bigger problem at Ogden is that we now have commercial service (2 days a week) and the TSA has come in and I would say with the City's overwhelming cooperation and made life at the airport a pain, to say the least. The airport is now divided in half, fly in to the local dinner (the Auger Inn), is almost impossible and doing things like Young Eagle rally's are almost impossible. Out local EAA chapter has lost it meeting location to boot. Well I will stop whining and get back to work so I can get to the airport later today to work on my annual condition inspect and yearly modes...this year..replacing BMA Lite with a third GRT screen, handles for the seats, new headset hangers, putting on door straps, and adding piper battery charging connector. Rene' N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Stephen Blank,DDS Sent: Sunday, March 24, 2013 7:08 AM Subject: Re: RV10-List: Airport Tower Closures The president in America does not write legislation, congress does. The president is obligated to follow the budgetary rules they created. Only congress can fix this. It helps no one for you to blast your opinion that you think the president would rather play golf and doesnt care about the unemployed. That is just complaining without results. Call your congressman and let then know you want results or their pay should be cut, not working government employees. This does not have to be a dem vs rep fight. We all want effective laws and congressman that work for the common good. There is a ton of common ground, many things could be passed if they stop playing political games and pandering to the extremes of either party. Call your congressman, that is how it works. Google your state name (Florida us congressman, for example) and look up some phone numbers. They are always nice when I call, and I am seldomly agreeing with them. If no one calls they think they are doing a great job. They have no clue the country is pissed off with inaction. FYI did you know the DOD is the largest consumer of oil world wide? Is our military big enough yet? Stephen Blank, DDS On Mar 24, 2013 8:43 AM, "Linn" wrote: I think the problem lies with tghe President .... who predicted a disaster if sequestration happened ..... and the disaster never came. So he directs the agencies to cut in the most visible ways. He doesn't care what happens to the unemployment figures anymore. He'd rather play golf. I, for one, feel the Gov't (and all the agencies) is bloated and needs to be cut. Not all at once, mind you, but through attrition. That doesn't ever seem to happen though and the elephant in the room keeps getting bigger and bigger. I feel the pain for the people in the towers that get laid off, just as I feel for those that lost jobs in the civil sector. It ain't pretty out there so fly safely and we'll get past this. Pilots are a pretty flexible bunch. Laying off IFR controllers would be far more devastating than closing towers IMHO. Linn On 3/24/2013 8:13 AM, Stephen Blank,DDS wrote: They need to get a work slow down or close the airports in DC to get congress off its collective rear ends and end the ridiculous chopping of useful government services that we are paying for in income taxes and fuel taxes. The FAA should be fully funded and able to run in the black from the funds it collects. This entire closure thing is congress made. My airport KSUA is closing too. Real people are being laid off, will lose their homes, and add to those getting paid unemployment to not work. They won't find a job In another tower. Stupid. My friend works for the army corps of engineers and they are getting cut one day a week startinh April 1st, a 20% forced pay cut as if the budget issue is their fault? It will kill his family budget, obligstions he made while working, so congress can play games. This is by politicsl choice. Congress has no downside to continue on this path unless we ALL act now. Pick up your phone and tell congress this is NOT an acceptable way to fix the budget, real people are being hurt, and lives will be lost over LA. We can probably live without a tower here, with mostly an inconvenience to the weekend jet set that arrive in some top dollar jets, IFR hand off from Palm Beach to play golf. But they continue to get a tax cut?? And the guy in the tower loses his job? Pick up your phone and let your congressman know you are angry or they will do nothing and real people will suffer. Stephen Blank, DDS Port Saint Lucie, FL No virus found in this message. Checked by AVG - www.avg.com 03/23/13 get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 24, 2013
WHAT SEQUESTER? FEDERAL JOBS WEBSITE LISTS THOUSANDS OF OPENINGS! I am relocating to Dayton to take the job as director for the Air Force History and Museums Policies and Programs. All that I need to do is issue memos promoting gay marriage, muslim rights, legalization of pot, and watch porn on my computer all day! http://www.breitbart.com/Big-Government/2013/03/23/USA-Jobs-postings-thousands For all the talk about the dramatic spending cuts to hit the federal government under the bipartisan sequestration, the federal government isnt exactly tightening its belt. According to USAJobs.gov, the job posting site for the feds, approximately 2,200 jobs listings became available during one week in March. As Eileen Ambrose reports, Add in new postings open only to current or former federal workers, including those laid off, and the number of new openings jumps to more than 4,600. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396903#396903 ________________________________________________________________________________
Date: Mar 24, 2013
It doesn't matter WHOSE idea it was. Might as well have been Donald Ducks, or Farmer McDonald. Both houses of Congress passed it, the President signed, and both Houses of Congress failed to carryout the mandates in the bill, which left us stuck with the stupidquester. Doesn't matter what party, who did what, it took the whole "team" to fail. It took the "team" unwillingness to pay the bills for the spending "they" approved. On Sun, Mar 24, 2013 at 7:32 AM, Don McDonald wrote: > Ok, enough politics.... but the sequestration was the presidents idea. > * * > > ** > > ________________________________________________________________________________
Date: Mar 24, 2013
Subject: Airport Tower Closures
To keep us flying we need to understand just a bit on decision making. The budget starts in the House, not the senate. The problem is the house refusing to get creative and pass anything the senate or president would sign. It is fact, like it or not, that the democrats control the senate and presidency. It is not the president or Senate that have to change to appease the house. The house chooses to obstruct for political gains and they don't want to do anything that would make the current president look good. We need to ask them to work for the good of the nation and to get past their own political agendas. Not demo or rep, but good decisions for everyone. I agree the the TSA is a government entity that needs to be cut or trimmed. Ask your congressman to do just that, it was formed overnight into a huge economic drain and intrudes on our freedom to fly. It is second in size only to the department of defense, and the need for a separate department escapes me. Stephen Blank, DDS ________________________________________________________________________________
Date: Mar 24, 2013
Hey mister DDS.... what about the first FUC----- two years of this assholes term when they had control of both the Senate and the House... still no da mn budget.- Why do you think Bush's last 2 years were so bad!- They con trolled both houses then tooooo!!!!!!!!!!!!!!!!!!! What could you possibly add to that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Pretty hard to blame that on the Republicans. Gee come to think of it, California, which I left 3 years ago, after 59 yea rs, now has a Democratic super majority.- According to you they should be doing just splendid!-- NOT! DDR, SAS, PBW , just kidding about the initials,,,, I'm just a plain ole ci tizen...don't see the need to flash credentials around. Don McDonald --- On Sun, 3/24/13, Stephen Blank,DDS wrote: From: Stephen Blank,DDS <sblankdds(at)gmail.com> Subject: RE: RV10-List: Airport Tower Closures Date: Sunday, March 24, 2013, 12:37 PM --- To keep us flying we need to understand just a bit on decision ma king. The budget starts in the House, not the senate. The problem is the ho use refusing to get creative and pass anything the senate or president woul d sign. It is- fact, like it or not, that the democrats control the senat e and presidency. It is not the president or Senate that have to change to appease the house. The house chooses to obstruct for political gains and th ey don't want to do anything that would make the current president look goo d. We need to ask them to work for the good of the nation and to get past t heir own political agendas. Not demo or rep, but good decisions for everyon e. =0A=0A---I agree the the TSA is a government entity that needs to be cut or trimmed. Ask your congressman to do just that, it was formed overnig ht into a huge economic drain and intrudes on our freedom to fly. It is sec ond in size only to the department of defense, and the need for a separate ==========0A=0A ________________________________________________________________________________
Date: Mar 24, 2013
Subject: Re: Airport Tower Closures
Hey Don, There is no constitutional requirement for a budget, period. If you did a quick word search in the constitution, you won't find the word budget. Who gives a damn? It is appropriations bills that matter, which the House refuses to pass any that are even close to acceptable. How about just finding a way to do something instead of being roadblocks? Now. Back to building RVs and to hell with politicians of all stripes. On Sun, Mar 24, 2013 at 7:44 PM, Don McDonald wrote: > > Hey mister DDS.... what about the first FUC----- two years of this assholes term when they had control of both the Senate and the House... still no damn budget. Why do you think Bush's last 2 years were so bad! They controlled both houses then tooooo!!!!!!!!!!!!!!!!!!! > What could you possibly add to that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! > Pretty hard to blame that on the Republicans. > > Gee come to think of it, California, which I left 3 years ago, after 59 years, now has a Democratic super majority. According to you they should be doing just splendid! NOT! > > DDR, SAS, PBW , just kidding about the initials,,,, I'm just a plain ole citizen...don't see the need to flash credentials around. > > Don McDonald > > > --- On Sun, 3/24/13, Stephen Blank,DDS wrote: > > > From: Stephen Blank,DDS <sblankdds(at)gmail.com> > Subject: RE: RV10-List: Airport Tower Closures > To: "RV10 List" > Date: Sunday, March 24, 2013, 12:37 PM > > To keep us flying we need to understand just a bit on decision making. The budget starts in the House, not the senate. The problem is the house refusing to get creative and pass anything the senate or president would sign. It is fact, like it or not, that the democrats control the senate and presidency. It is not the president or Senate that have to change to appease the house. The house chooses to obstruct for political gains and they don't want to do anything that would make the current president look good. We need to ask them to work for the good of the nation and to get past their own political agendas. Not demo or rep, but good decisions for everyone. > I agree the the TSA is a government entity that needs to be cut or trimmed. Ask your congressman to do just that, it was formed overnight into a huge economic drain and intrudes on our freedom to fly. It is second in size only to the department of defense, and the need for a separate department escapes me. > > Stephen Blank, DDS > > http://www.matronics.com/Navigator?ank" href="http://forums.matronics.com">http://forums.matronics.com rel="nofollow" target="_blank" href="http://www.matronics.com/contri== > > ________________________________________________________________________________
Date: Mar 24, 2013
My last two cents... I- find it funny that the Dems say that the Rep's ar e restricting a certain process... then when it's pointed out that when Dem s had complete control, and still didn't get anything done, then the statem ent changes to It's not required.- I think they call that bait and switch . Kelly, we can still be friends.... but my planes been done for 3 years.... get back to building before 100LL gets to $10 gal. --- On Sun, 3/24/13, Kelly McMullen wrote: From: Kelly McMullen <apilot2(at)gmail.com> Subject: Re: RV10-List: Airport Tower Closures Date: Sunday, March 24, 2013, 9:59 PM Hey Don, There is no constitutional requirement for a budget, period. If you did a quick word search in the constitution, you won't find the word budget. Who gives a damn? It is appropriations bills that matter, which the House refuses to pass any that are even close to acceptable. How about just finding a way to do something instead of being roadblocks? Now. Back to building RVs and to hell with politicians of all stripes. On Sun, Mar 24, 2013 at 7:44 PM, Don McDonald wrote: > > Hey mister DDS.... what about the first FUC----- two years of this asshol es term when they had control of both the Senate and the House... still no damn budget.- Why do you think Bush's last 2 years were so bad!- They c ontrolled both houses then tooooo!!!!!!!!!!!!!!!!!!! > What could you possibly add to that!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! > Pretty hard to blame that on the Republicans. > > Gee come to think of it, California, which I left 3 years ago, after 59 y ears, now has a Democratic super majority.- According to you they should be doing just splendid!---NOT! > > DDR, SAS, PBW , just kidding about the initials,,,, I'm just a plain ole citizen...don't see the need to flash credentials around. > > Don McDonald > > > --- On Sun, 3/24/13, Stephen Blank,DDS wrote: > > > From: Stephen Blank,DDS <sblankdds(at)gmail.com> > Subject: RE: RV10-List: Airport Tower Closures > To: "RV10 List" > Date: Sunday, March 24, 2013, 12:37 PM > >- ---To keep us flying we need to understand just a bit on decisio n making. The budget starts in the House, not the senate. The problem is th e house refusing to get creative and pass anything the senate or president would sign. It is- fact, like it or not, that the democrats control the s enate and presidency. It is not the president or Senate that have to change to appease the house. The house chooses to obstruct for political gains an d they don't want to do anything that would make the current president look good. We need to ask them to work for the good of the nation and to get pa st their own political agendas. Not demo or rep, but good decisions for eve ryone. >- - I agree the the TSA is a government entity that needs to be cut or trimmed. Ask your congressman to do just that, it was formed overnight int o a huge economic drain and intrudes on our freedom to fly. It is second in size only to the department of defense, and the need for a separate depart ment escapes me. > > Stephen Blank, DDS > > http://www.matronics.com/Navigator?ank" href="http://forums.matronics.c om">http://forums.matronics.com rel="nofollow" target="_blank" href=" http://www.matronics.com/contri== > > le, List Admin. ________________________________________________________________________________
Date: Mar 24, 2013
At no time did either party have full control. It would take more than 60 votes in Senate to be even close, since a single obstinate Senator can hold up most anything. We also do not have a system where leaders can tell a Congressman how to vote. Sure they can be strong armed, lobbied, attacked in next election, but none of the leaders, majority nor minority can consistently deliver 100% of their caucus. Look at all the trouble Boehner has had, making deals that his caucus refuses to support, forcing him to back out of deals. Trying to control Congress is like trying to herd a cat. I know of slow build RV-10 built in 12 months, by solo builder without assist. Not what I would want, but suits the owner. We all make our own choices and have our own limitations on how fast we can build, and it has nothing to do with politicians. On 3/24/2013 8:24 PM, Don McDonald wrote: > My last two cents... I find it funny that the Dems say that the Rep's > are restricting a certain process... then when it's pointed out that > when Dems had complete control, and still didn't get anything done, > then the statement changes to It's not required. I think they call > that bait and switch. > Kelly, we can still be friends.... but my planes been done for 3 > years.... get back to building before 100LL gets to $10 gal. > > --- On *Sun, 3/24/13, Kelly McMullen //* wrote: > > > From: Kelly McMullen <apilot2(at)gmail.com> > Subject: Re: RV10-List: Airport Tower Closures > To: rv10-list(at)matronics.com > Date: Sunday, March 24, 2013, 9:59 PM > > > > > Hey Don, > There is no constitutional requirement for a budget, period. If you > did a quick word search in the constitution, you won't find the word > budget. Who gives a damn? It is appropriations bills that matter, > which the House refuses to pass any that are even close to acceptable. > How about just finding a way to do something instead of being > roadblocks? > Now. Back to building RVs and to hell with politicians of all stripes. > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 25, 2013
CUT OUT THE POLITICAL CRAP!!! -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=396973#396973 ________________________________________________________________________________
Subject: re:
Date: Mar 25, 2013
http://www.aminatex.com/includes/surprise.php?pmozfvmrt711ajdh -------- Democracy is also a form of worship. It is the worship of Jackals by Jackas ses. -- H.L. Mencken ________________________________________________________________________________
Subject: re:--THIS IS A BUG--- DO NOT OPEN
Date: Mar 25, 2013
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of dsyvert(at)aol.com Sent: Monday, March 25, 2013 12:59 PM Subject: RV10-List: re: -------- Democracy is also a form of worship. It is the worship of Jackals by Jackasses. -- H.L. Mencken ________________________________________________________________________________
Subject: "No Title" is Spam
Date: Mar 25, 2013
Get rid of it Matt! -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397045#397045 ________________________________________________________________________________
Date: Mar 25, 2013
Subject: Oil Temps
This winter I figured out a way to fix 2 Heat related issues that have been with me since day one. 1. My # 6 cylinder ran 20-30 degrees hotter than any of the other. On hot (AZ) summer day's, I had to pay close attention to keep the Cyl temp under 420-430 deg on climbs. 2. my oil temps would also exceed 220 on long climbs to altitude and during the middle of summer if the OAT didn't get below 70F degs, the Oil Temp would stay above 200. Even on 'cooler days' it would rarely go below 196. So I fabricated a fiberglass intake that replaces to the slot cover in the lower cowl in front of the nose gear. and plumbed it to the Oil Cooler (in the same std location). I plugged the old 4" opening behind the # 6 cyl. The results after a couple of flights look encouraging. The #6 cyl, is now in line with the other cyls. (12 deg spread across all cyls). Last weekon a trip from DVT to SLC, in cruise the oil temp never got above 165 degrees. the OAT @ 10-11k was 0 to -4 C. So I'm a bit worried that the oil temps are now too cool. I've been of the opinion that the ideal oil temp is aprox 180 deg in order to cook off any moisture in the oil. So I'm wondering if I need to put a valve in-line somewhere to help regulate the oil temps. Any feedback is appreciated. Deems ________________________________________________________________________________
Subject: Re: Oil Temps
Date: Mar 25, 2013
I believe nonstop aviation makes the oil cooler butterfly valves. I have one and it works great. Very easy to adjust by using a control knob with detent s. Vans sells them. Glad to hear you fixed the issue. My #5 is the hottest. Sent from my iPhone On Mar 25, 2013, at 22:23, Deems Davis wrote: > This winter I figured out a way to fix 2 Heat related issues that have bee n with me since day one. 1. My # 6 cylinder ran 20-30 degrees hotter than an y of the other. On hot (AZ) summer day's, I had to pay close attention to ke ep the Cyl temp under 420-430 deg on climbs. 2. my oil temps would also exce ed 220 on long climbs to altitude and during the middle of summer if the OAT didn't get below 70F degs, the Oil Temp would stay above 200. Even on 'cool er days' it would rarely go below 196. > So I fabricated a fiberglass intake that replaces to the slot cover in the lower cowl in front of the nose gear. and plumbed it to the Oil Cooler (in t he same std location). I plugged the old 4" opening behind the # 6 cyl. The r esults after a couple of flights look encouraging. The #6 cyl, is now in lin e with the other cyls. (12 deg spread across all cyls). Last weekon a trip f rom DVT to SLC, in cruise the oil temp never got above 165 degrees. the OAT @ 10-11k was 0 to -4 C. > So I'm a bit worried that the oil temps are now too cool. I've been of the opinion that the ideal oil temp is aprox 180 deg in order to cook off any m oisture in the oil. So I'm wondering if I need to put a valve in-line somewh ere to help regulate the oil temps. Any feedback is appreciated. > > Deems > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 26, 2013
Great news Deems. Another option for oil cooler control is to place a hinge d flap on the back side of the oil cooler. I have one with my new cowl set up that closes off up to 60% of the oil cooler and has allowed me to gain m uch control. Only 60% due to motor mount conflict (yours may be different) but it seems to be all the control I need. I have also had the butterfly v ersion on other aircraft and generally prefer that solution mostly due to n o additional room is required FWF. But this hinged flap was a simple soluti on that worked with my current control cable set up and functions well. If I lived in UT I would opt for 100% closure (and a good realtor) :-) Robin Sent from the new iPad On Mar 25, 2013, at 9:50 PM, "Seano" > wrote: I believe nonstop aviation makes the oil cooler butterfly valves. I have on e and it works great. Very easy to adjust by using a control knob with dete nts. Vans sells them. Glad to hear you fixed the issue. My #5 is the hottes t. Sent from my iPhone On Mar 25, 2013, at 22:23, Deems Davis > wrote: This winter I figured out a way to fix 2 Heat related issues that have been with me since day one. 1. My # 6 cylinder ran 20-30 degrees hotter than an y of the other. On hot (AZ) summer day's, I had to pay close attention to k eep the Cyl temp under 420-430 deg on climbs. 2. my oil temps would also ex ceed 220 on long climbs to altitude and during the middle of summer if the OAT didn't get below 70F degs, the Oil Temp would stay above 200. Even on ' cooler days' it would rarely go below 196. So I fabricated a fiberglass intake that replaces to the slot cover in the lower cowl in front of the nose gear. and plumbed it to the Oil Cooler (in the same std location). I plugged the old 4" opening behind the # 6 cyl. Th e results after a couple of flights look encouraging. The #6 cyl, is now in line with the other cyls. (12 deg spread across all cyls). Last weekon a t rip from DVT to SLC, in cruise the oil temp never got above 165 degrees. th e OAT @ 10-11k was 0 to -4 C. So I'm a bit worried that the oil temps are now too cool. I've been of the opinion that the ideal oil temp is aprox 180 deg in order to cook off any m oisture in the oil. So I'm wondering if I need to put a valve in-line somew here to help regulate the oil temps. Any feedback is appreciated. Deems ========= ://www.matronics.com/Navigator?RV10-List<http://www.matronics.com/Navigator ?RV10-List> ========= cs.com<http://cs.com> ========= matronics.com/contribution<http://matronics.com/contribution> ========= ________________________________________________________________________________
Date: Mar 25, 2013
Sounds good Deems. I think you are fine on oil temp. Remember that the temp sensor is at the return line from the oil cooler, and temps in the sump can run as much as 50 degrees hotter. On Mon, Mar 25, 2013 at 9:23 PM, Deems Davis wrote: > This winter I figured out a way to fix 2 Heat related issues that have been > with me since day one. 1. My # 6 cylinder ran 20-30 degrees hotter than any > of the other. On hot (AZ) summer day's, I had to pay close attention to keep > the Cyl temp under 420-430 deg on climbs. 2. my oil temps would also exceed > 220 on long climbs to altitude and during the middle of summer if the OAT > didn't get below 70F degs, the Oil Temp would stay above 200. Even on > 'cooler days' it would rarely go below 196. > So I fabricated a fiberglass intake that replaces to the slot cover in the > lower cowl in front of the nose gear. and plumbed it to the Oil Cooler (in > the same std location). I plugged the old 4" opening behind the # 6 cyl. The > results after a couple of flights look encouraging. The #6 cyl, is now in > line with the other cyls. (12 deg spread across all cyls). Last weekon a > trip from DVT to SLC, in cruise the oil temp never got above 165 degrees. > the OAT @ 10-11k was 0 to -4 C. > So I'm a bit worried that the oil temps are now too cool. I've been of the > opinion that the ideal oil temp is aprox 180 deg in order to cook off any > moisture in the oil. So I'm wondering if I need to put a valve in-line > somewhere to help regulate the oil temps. Any feedback is appreciated. > > Deems > > ________________________________________________________________________________
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Mar 26, 2013
Sounds good Deems, does your fiberglass vent in front of the nose gear leg hang down into the airstream and did you use the four inch scat to the oil cooler? Also have you figured out a quick on/off for the scat to cooler when you remove the cowls? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397071#397071 ________________________________________________________________________________
Subject: Clamping blocks for fuse skins?
Date: Mar 26, 2013
I'm getting close to needing to build the clamping block needed for the fuse skin rolls. Since I don't have a table saw, I was wondering if anyone out there still had theirs laying around? -------- Ed Kranz 41347 Working on Emp Kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397086#397086 ________________________________________________________________________________
Date: Mar 26, 2013
Greg, yes it does hang down into the air stream I used a 3.12" mailing tube as the mandrel to form the inlet tube and then faired it into the attach/cover plate with micro/body filler , put a 3/4+ radius around the inlet and then covered the whole thing with another couple of layers of fiberglass. I used 3 1/4 " scat tube, and fabricated a fiberglass reducer elbow that connects the scat to the oil cooler box. I may have some pics. I use a stainless steel expandable clamp to attach/remove the scat tube when taking the cowl off. Deems On Tue, Mar 26, 2013 at 3:47 AM, Greg McFarlane wrote: > > > > Sounds good Deems, does your fiberglass vent in front of the nose gear leg > hang down into the airstream and did you use the four inch scat to the oil > cooler? Also have you figured out a quick on/off for the scat to cooler > when you remove the cowls? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397071#397071 > > ________________________________________________________________________________
Date: Mar 26, 2013
Hey Deems, you never got back with me on the $5 bet I sent you on who's-1 0 is faster. Whats up?=0A=0A=0A________________________________=0A From: De ems Davis =0ATo: rv10-list(at)matronics.com =0ASent: Tuesd ay, March 26, 2013 9:19 AM=0ASubject: Re: RV10-List: Re: Oil Temps=0A =0A =0AGreg,=0A=0Ayes it does hang down into the-air stream- I used a 3.12" mailing tube as the -mandrel to form the inlet tube and then faired it i nto the attach/cover plate with micro/body filler , put a 3/4+ radius aroun d the inlet and then covered the whole thing with another couple of layers of fiberglass. I used 3 1/4 " scat tube, and fabricated a fiberglass reduce r elbow that connects the scat to the oil cooler box. I may have some pics. I use a stainless steel-expandable-clamp to attach/remove the scat tub e when taking the cowl off.-=0A=0ADeems -=0A=0AOn Tue, Mar 26, 2013 at 3:47 AM, Greg McFarlane wrote:=0A=0A--> RV10-List message posted by: "Greg McFarlane" =0A>=0A>Sound s good Deems, does your fiberglass vent in front of the nose gear leg hang down into the airstream and did you use the four inch scat to the oil coole r? Also have you figured out a quick on/off for the scat to cooler when you remove the cowls?=0A>=0A>=0A>=0A>=0A>Read this topic online here:=0A>=0A>h ttp://forums.matronics.com/viewtopic.php?p=397071#397071=0A>=0A>=0A>=0A> =0A>=0A>=0A>=0A>============0A>arget="_blank">http: //www.matronics.com/Navigator?RV10-List=0A>========== ==0A>http://forums.matronics.com=0A>============0A> le, List Admin.=0A>="_blank">http://www.matronics.com/contribution=0A>= ===== ________________________________________________________________________________
Subject: Re: Clamping blocks for fuse skins?
Date: Mar 27, 2013
I do Ed, however it a long way from Adelaide, South Australia to North America. You're welcome to it if you pay the freight. I had a carpenter make one up for me using seasoned recycled Jarah (hardwood) beam. Hard as buggery! Warm regards Patrick On 27/03/2013, at 1:09 AM, "EdKranz" wrote: > > I'm getting close to needing to build the clamping block needed for the fuse skin rolls. > > Since I don't have a table saw, I was wondering if anyone out there still had theirs laying around? > > -------- > Ed Kranz > 41347 > Working on Emp Kit > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397086#397086 > > > > > > > > > > ________________________________________________________________________________
Date: Mar 28, 2013
Subject: Rear Windows
From: Vernon Franklin <vernon.franklin(at)gmail.com>
Does everyone's rear windows stick out from the lip this much? Picture attached. Is this area going to built up to make it flush when the windows get installed? Or should I sand down and rebuild the lip to push the window into the fuselage more? [image: Inline image 1] -- Vernon Franklin ________________________________________________________________________________
Subject: Re: Rear Windows
Date: Mar 28, 2013
Hi Vernon, I'd do a little bit of everything... sand down the inside of the joggle, build up the rail with flox and feather back in to meet the door. I my case, I built up with flox and micro to meet the window, overlapped the window with glass tape and transitioned back in to the door (pic attathed). Jeff Carpenter 40304... getting there. On Mar 28, 2013, at 9:13 AM, Vernon Franklin wrote: > Does everyone's rear windows stick out from the lip this much? Picture attached. > > Is this area going to built up to make it flush when the windows get installed? Or should I sand down and rebuild the lip to push the window into the fuselage more? > > > > > > > -- > Vernon Franklin ________________________________________________________________________________
Date: Mar 28, 2013
Date: Mar 28, 2013
I know of one instance in which the wrong windows were shipped from the Van's supplier. They were too thick. The more common reason is the there is a flat spot on the canopy near the window. While not a 100% sure, I think they all come this way. Check that curve with you door on. You may find that you have to build up you canopy which may also resolve you window problem. Another metric to check is to see if the relief area around the window perimeter is a constant depth. Are both windows the same? Sent from my iPhone On Mar 28, 2013, at 12:13 PM, Vernon Franklin wrote: Does everyone's rear windows stick out from the lip this much? Picture attached. Is this area going to built up to make it flush when the windows get installed? Or should I sand down and rebuild the lip to push the window into the fuselage more? -- Vernon Franklin ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 28, 2013
That looks pretty normal. The joggle isn't quite deep enough. You can build it up to be flush with the window. I recall seeing that a few times before. Dave Saylor 831-750-0284 CL On Thu, Mar 28, 2013 at 9:13 AM, Vernon Franklin wrote: > > Does everyone's rear windows stick out from the lip this much? Picture > attached. > > Is this area going to built up to make it flush when the windows get > installed? Or should I sand down and rebuild the lip to push the window > into the fuselage more? > > > -- > Vernon Franklin ________________________________________________________________________________
Date: Mar 28, 2013
I measure the thickness of the window all the way around.... it varied by q uite a bit.- So I sent it back to Van's and they sent me another one... m uch better.... but as everyone has told you, do a little bit of everything. ... especially glassing around the window.... it will keep the paint from c racking later.... hopefully. Don Mc --- On Thu, 3/28/13, Bob Leffler wrote: From: Bob Leffler <rv(at)thelefflers.com> Subject: Re: RV10-List: Rear Windows Date: Thursday, March 28, 2013, 12:14 PM I know of one instance in which the wrong windows were shipped from the Van 's supplier.- They were too thick. The more common reason is the there is a flat spot on the canopy near the w indow.---While not a 100% sure, I think they all come this way.-- -Check that curve with you door on.- You may find that you have to buil d up you canopy which may also resolve you window problem. Another metric to check is to see if the relief area around the window peri meter- is a constant depth. Are both windows the same? Sent from my iPhone On Mar 28, 2013, at 12:13 PM, Vernon Franklin w rote: Does everyone's rear windows stick out from the lip this much?- Picture a ttached. Is this area going to built up to make it flush when the windows get instal led?- Or should I sand down and rebuild the lip to push the window into t he fuselage more? -- Vernon Franklin le, List Admin. ________________________________________________________________________________
Date: Mar 30, 2013
Subject: Re: Heated pitot
I bought and installed the Gretz very early in my build. When I finally hooked it up and flew, it melted. While there may be several reasons for this, a number of people seem to have experienced it. Even though it was 5+ years since purchase, and the current supplier is in AUS, he made me more than whole and I've been very happy after a year of flying with it. After a few ice encounters, it apparently works well. I really like the "always on, constantly monitored, automatic operation" aspect of it. I'd recommend it. Bill " hopefully finished with the icing until next year" Watson On 3/1/2013 3:02 PM, Tim Olson wrote: > > Me either. I wonder if they changed the plastics formula > or something strange. Sean, are they being good about support? > Will they send you another one? So far I'm planning to use > one again on the RV-14, unless I hear of lots of issues. I've > got the gretz mount for it already. > ________________________________________________________________________________
Date: Mar 30, 2013
Subject: Re: RV-10 Stall Characteristics (what just happened here?)
Dave, I can't add anything here except some reflection... I have to admit to not having fully explored the stall characteristics near the aft CG limits because it's so difficult to do. On one hand, loading enough sand or water for a single pilot test is very difficult to do safely. On the other hand, I don't know 3 other people I want to subject to the exercise. As we all know, stalls in a "typically" loaded '10 are benign and well behaved. Recovery doesn't really require the 'textbook' response, you just have to relax the pro-stall controls and add some power. I'm thinking that I may be subject to extrapolating the benign stall and recovery characteristics at typical loadings to stall and recovery characteristics at more rearward loadings. This is a wake up call to me to remember to remain assertive in my recoveries. On that point, thanks for the post! On a somewhat related matter, I've just now fully realized just how different the landing characteristics of the '10 are at fore and aft loadings. I find it difficult to get anything but stick back, roll on greasers when I'm loaded with 2 in front and bags in the baggage compartment (about 110.4" behind datum). The easiest landing plane I've ever flown. With 4 on board, bags and low tanks, I find carrying a bit of power into the flare gives me the best chance of smooth one. But it's pretty easy to arrive with authority if I come in power-off. It's pretty easy to get a typical 'student' landing if I come in too fast. And with stalls and landings, I keep in mind that while my old Maule's CG moved forward as I burned off fuel, the '10 does the opposite. Though the difference is not great. Bill On 3/2/2013 12:35 PM, Dave Saylor wrote: > > Last weekend I took some folks on demo rides. All are -10 builders, > not yet flying. > > On one flight, I had one big guy in the back seat. My CG range is 8.4 > to 16.8 (inches aft of the wing leading edge). My CG on takeoff was > 14.4--I ran the number before we departed because I knew the CG was > "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we > loaded the plane at aft CG, max gross, and did some stalls. I don't > recall anything strange at all about those maneuvers. > > First, I demonstrated an approach stall, which I've done many times. > My normal recovery is just to add a little power, stick neutral if > necessary, and the plane just flys out. On the first stall, that's > just how it went. > > Of course then it was time for a little "Watch this!"... > > Actually, I wanted to demonstrate the AOA audio warning, > "Angle-Angle-Push", which was kind of faint on the first stall. So I > let the stall develop further, keeping wings level with the rudder. > The wings rocked a bit but nothing serious. The nose stayed straight > ahead. Then, the nose pitched WAY down. I added power to break the > stall and fly it out but there was no change. It felt like we were > descending, not flying. It felt like we were about 45* nose down, but > the EFIS logs didn't capture anything that extreme. I was concerned > about entering a spin. So was the guy in the front seat--he said so > as it was happening...I added more power, stick neutral, and still the > nose was pointed down. I kept the wings more or less level but at > this point things seemed out of the ordinary so I got more agressive > with the controls. I pushed forward, adding more power. The plane > then seemed to fly, and I seemed to be going pretty fast, but I didn't > look at the airspeed. I pulled up gently and the controls eventually > started feeling normal again. The EFIS logs showed the whole event > lasted less than 10 seconds--two data captures--but it sure seemed > longer. We lost about 300 feet. > > I spoke to another -10 owner who has a lot of acro and formation > experience. He said, yeah, it'll do that...he concurred that from a > deep stall, an RV-10 requires extra effort to break it. That's > probably not a huge surprise if you think about it and expect it, but > in this case it gave me (and unfortunately my passengers) a little > concern. > > I'd be interested to hear if others have had similar experiences, and > if anyone has an explanation for what's going on aerodynamically. > > Dave Saylor > 831-750-0284 CL > > ________________________________________________________________________________
Date: Mar 30, 2013
I am curious......I get these emails at two different email addresses. At both I received Bill's response, but didn't receive Dave's initial email. Wondering if the list has a deep stall black hole. On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote: > > Dave, I can't add anything here except some reflection... > > > Bill > > On 3/2/2013 12:35 PM, Dave Saylor wrote: > >> gmail.com > >> >> Last weekend I took some folks on demo rides. All are -10 builders, >> not yet flying. >> >> On one flight, I had one big guy in the back seat. >> >> >> > -- > - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Mar 30, 2013
Subject: F-1013 Twist: R but not L ?
Hi all, I'm on section 29-3, Step 3: "Clamp the F-1013-R Fwd Fuse Longeron in a padded vise at the "forward twist mark". Twist the fwd fuse longeron with a crescent wrench as shown in Figure 2 to obtain the dimension shown in Figure 3. Clamp the fwd fuse longeron at the "aft twist mark". Repeat the process using the twist direction shown in Figure 1 to obtain the dimension shown in Figure 3." So they say to twist the forward and aft parts of the right longeron, but what about the forward part of the LEFT longeron? (The aft twist does not apply to the left longeron, since the dimension shown won't allow it.) I can't see any difference in symmetry in the forward sections of either L or R F-1013 longerons. Is it the plans missing it, or are you really not supposed to twist the forward part F-1013 left longeron? Thanks for your time! -Jim #40384 ________________________________________________________________________________
Date: Mar 30, 2013
On Mar 30, 2013, at 9:45 AM, Kelly McMullen wrote: > I am curious......I get these emails at two different email addresses. At b oth I received Bill's response, but didn't receive Dave's initial email. Won dering if the list has a deep stall black hole. > > On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote : >> >> Dave, I can't add anything here except some reflection... >> >> >> Bill >> >> On 3/2/2013 12:35 PM, Dave Saylor wrote: ail.com> >>> >>> Last weekend I took some folks on demo rides. All are -10 builders, >>> not yet flying. >>> >>> On one flight, I had one big guy in the back seat. >> >> -- > - sent from the microchip implanted in my forearm > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 30, 2013
The original conversation was a few weeks ago... On Mar 30, 2013, at 9:45 AM, Kelly McMullen wrote: > I am curious......I get these emails at two different email addresses. At b oth I received Bill's response, but didn't receive Dave's initial email. Won dering if the list has a deep stall black hole. > > On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote : >> >> Dave, I can't add anything here except some reflection... >> >> >> Bill >> >> On 3/2/2013 12:35 PM, Dave Saylor wrote: ail.com> >>> >>> Last weekend I took some folks on demo rides. All are -10 builders, >>> not yet flying. >>> >>> On one flight, I had one big guy in the back seat. >> >> -- > - sent from the microchip implanted in my forearm > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 30, 2013
Bill, I think you'll find that as you burn gas the cg moves aft if you start out with the cg fairly far aft. But if you start out near the forward limit, then the cg moves forward as you burn gas. It is important with the 10 to check cg in the landing configuration, regardless of where you start. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397337#397337 ________________________________________________________________________________
Date: Mar 30, 2013
Thanks Tim, that explains, and I vaguely recall seeing it. On Sat, Mar 30, 2013 at 8:47 AM, Tim Olson wrote: > The original conversation was a few weeks ago... > > On Mar 30, 2013, at 9:45 AM, Kelly McMullen wrote: > > I am curious......I get these emails at two different email addresses. At > both I received Bill's response, but didn't receive Dave's initial email. > Wondering if the list has a deep stall black hole. > > On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote: > >> >> Dave, I can't add anything here except some reflection... >> >> >> Bill >> >> On 3/2/2013 12:35 PM, Dave Saylor wrote: >> >>> gmail.com > >>> >>> Last weekend I took some folks on demo rides. All are -10 builders, >>> not yet flying. >>> >>> On one flight, I had one big guy in the back seat. >>> >>> >>> >> -- >> > - sent from the microchip implanted in my forearm > > * > > * > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Mar 30, 2013
B =8Bill, I agree, aft vs. fwd cg makes =8Bfor two very different landing airplanes. Someone recently posted that their best approaches seem very steep, and I feel the same way. The runway comes up real fast but there's plenty of elevator--even more when loaded aft--to arrest decent and land gently. =8BFlying a different -10 recently, solo and light, I noticed the pla ne lands much more nose-down, like a flatter attitude. I need to get it a little slower in the flare than I'm used to, and see if the nose comes up any higher. That plane doesn't have AOA so I'm just going by speed. Maybe that's the difference.=8B Dave Saylor 831-750-0284 CL On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote: > > Dave, I can't add anything here except some reflection... > > I have to admit to not having fully explored the stall characteristics > near the aft CG limits because it's so difficult to do. On one hand, > loading enough sand or water for a single pilot test is very difficult to > do safely. On the other hand, I don't know 3 other people I want to > subject to the exercise. > > As we all know, stalls in a "typically" loaded '10 are benign and well > behaved. Recovery doesn't really require the 'textbook' response, you ju st > have to relax the pro-stall controls and add some power. > > I'm thinking that I may be subject to extrapolating the benign stall and > recovery characteristics at typical loadings to stall and recovery > characteristics at more rearward loadings. This is a wake up call to me to > remember to remain assertive in my recoveries. On that point, thanks for > the post! > > On a somewhat related matter, I've just now fully realized just how > different the landing characteristics of the '10 are at fore and aft > loadings. I find it difficult to get anything but stick back, roll on > greasers when I'm loaded with 2 in front and bags in the baggage > compartment (about 110.4" behind datum). The easiest landing plane I've > ever flown. With 4 on board, bags and low tanks, I find carrying a bit o f > power into the flare gives me the best chance of smooth one. But it's > pretty easy to arrive with authority if I come in power-off. It's pretty > easy to get a typical 'student' landing if I come in too fast. > > And with stalls and landings, I keep in mind that while my old Maule's CG > moved forward as I burned off fuel, the '10 does the opposite. Though th e > difference is not great. > > Bill > > On 3/2/2013 12:35 PM, Dave Saylor wrote: > >> gmail.com > >> >> Last weekend I took some folks on demo rides. All are -10 builders, >> not yet flying. >> >> On one flight, I had one big guy in the back seat. My CG range is 8.4 >> to 16.8 (inches aft of the wing leading edge). My CG on takeoff was >> 14.4--I ran the number before we departed because I knew the CG was >> "aft-ish"--and the weight was 2614 lbs. Years ago during phase 1 we >> loaded the plane at aft CG, max gross, and did some stalls. I don't >> recall anything strange at all about those maneuvers. >> >> First, I demonstrated an approach stall, which I've done many times. >> My normal recovery is just to add a little power, stick neutral if >> necessary, and the plane just flys out. On the first stall, that's >> just how it went. >> >> Of course then it was time for a little "Watch this!"... >> >> Actually, I wanted to demonstrate the AOA audio warning, >> "Angle-Angle-Push", which was kind of faint on the first stall. So I >> let the stall develop further, keeping wings level with the rudder. >> The wings rocked a bit but nothing serious. The nose stayed straight >> ahead. Then, the nose pitched WAY down. I added power to break the >> stall and fly it out but there was no change. It felt like we were >> descending, not flying. It felt like we were about 45* nose down, but >> the EFIS logs didn't capture anything that extreme. I was concerned >> about entering a spin. So was the guy in the front seat--he said so >> as it was happening...I added more power, stick neutral, and still the >> nose was pointed down. I kept the wings more or less level but at >> this point things seemed out of the ordinary so I got more agressive >> with the controls. I pushed forward, adding more power. The plane >> then seemed to fly, and I seemed to be going pretty fast, but I didn't >> look at the airspeed. I pulled up gently and the controls eventually >> started feeling normal again. The EFIS logs showed the whole event >> lasted less than 10 seconds--two data captures--but it sure seemed >> longer. We lost about 300 feet. >> >> I spoke to another -10 owner who has a lot of acro and formation >> experience. He said, yeah, it'll do that...he concurred that from a >> deep stall, an RV-10 requires extra effort to break it. That's >> probably not a huge surprise if you think about it and expect it, but >> in this case it gave me (and unfortunately my passengers) a little >> concern. >> >> I'd be interested to hear if others have had similar experiences, and >> if anyone has an explanation for what's going on aerodynamically. >> >> Dave Saylor >> 831-750-0284 CL >> >> >> > =====**=================== ===========**= ronics.com/Navigator?RV10-List> =====**=================== ===========**= =====**=================== ===========**= com/contribution> =====**=================== ===========**= > > ________________________________________________________________________________
Date: Mar 30, 2013
Kelly, I think you're right, sometimes I see a conversation that is well-developed that I definitely would have read...only to find it's pretty far into the thread. Like I missed the original post and a few replies. If I go to the forum, it's all there and I can catch up. Huh. I like the black hole theory. Dave Saylor 831-750-0284 CL On Sat, Mar 30, 2013 at 7:45 AM, Kelly McMullen wrote: > I am curious......I get these emails at two different email addresses. At > both I received Bill's response, but didn't receive Dave's initial email. > Wondering if the list has a deep stall black hole. > > On Sat, Mar 30, 2013 at 5:06 AM, Bill Watson wrote: > >> >> Dave, I can't add anything here except some reflection... >> >> >> Bill >> >> On 3/2/2013 12:35 PM, Dave Saylor wrote: >> >>> gmail.com > >>> >>> Last weekend I took some folks on demo rides. All are -10 builders, >>> not yet flying. >>> >>> On one flight, I had one big guy in the back seat. >>> >>> >>> >> -- >> > - sent from the microchip implanted in my forearm > > * > > * > > ________________________________________________________________________________
Date: Mar 30, 2013
Subject: EFIS failure checklist
Some time ago Avweb had an article about EFIS failure including some suggestions about what to do. I've meant ever since to develop a page for my checklist just in case. Using the basic ideas from Avweb I formatted it like my other checklists and added what I thought was appropriate. So...with the understanding that I don't have a lot of IMC experience, please let me know if this seems appropriate, or if there are obvious errors. I know it's kind of a longshot to have a complete failure IMC with a happy ending. Still, ya gotta try. For example, I put in Airspeed: VA because it seemed like a good idea. I don't know if there's an accepted practice here. Just seemed prudent. For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My only mechanical instruments are airspeed and vertical card compass. I have aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Subject: Re: F-1013 Twist: R but not L ?
Date: Mar 30, 2013
You twist both front ends the same way, as shown in Figure 2. You are essentially twisting the longeron UP so that it transitions to the firewall weldaments later on. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397362#397362 ________________________________________________________________________________
Subject: Re: EFIS failure checklist
Date: Mar 30, 2013
Dave, I'd suggest: "Airspeed: maintain". In the heat of the moment there's no need to be messing around with airspeed, especially if pitot data is in question. You might add: "cross check with gps ground speed". If, like many, you can drive your autopilot off your EFIS or directly off a gps source, make sure you add:"Autopilot: EFIS source off" or however your EFIS/independent op switch is labeled. And of course, if your autopilot is only driven off the EFIS it should be "autopilot - off". Finally, all is definitely not lost. My last IPC the cfii shut down all my GRT screens (put them all on an engine page, actually), turned off all NAV's in the panel. Using the internal battery powered D-6, and a battery powered, hand held VOR (could have been a gps, too) I was able to make a passable VOR approach to non precision minimums. But if the visibility were less than a mile, it would definitely be best to go somewhere else! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397366#397366 ________________________________________________________________________________
Date: Mar 30, 2013
That was my first thought as well, but if you read the whole page carefully, it never says to twist the left F-1013. Although it wouldn't be the first omission I've seen so far (the most recent was the roll construction angles - it doesn't say what thickness material to use!). -Jim 40384 On 3/30/2013 8:19 PM, charliewaffles wrote: > > You twist both front ends the same way, as shown in Figure 2. You are essentially twisting the longeron UP so that it transitions to the firewall weldaments later on. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397362#397362 > > ________________________________________________________________________________
Date: Mar 30, 2013
You will find many places they give drawing/instructions for one side and tell you to mirror image the other side, if they mention it at all. On 3/30/2013 6:08 PM, James Hein wrote: > > That was my first thought as well, but if you read the whole page > carefully, it never says to twist the left F-1013. > > Although it wouldn't be the first omission I've seen so far (the most > recent was the roll construction angles - it doesn't say what > thickness material to use!). > > -Jim 40384 > > On 3/30/2013 8:19 PM, charliewaffles wrote: >> >> You twist both front ends the same way, as shown in Figure 2. You are >> essentially twisting the longeron UP so that it transitions to the >> firewall weldaments later on. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=397362#397362 >> >> >> >> >> >> >> >> >> >> >> > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 30, 2013
That is when you call the nearest radar facility, say "I have lost my gyros, need no-gyro surveillance approach to nearest airport. Anything that limits your need to do more than stay straight and level. If you haven't done one, or not in many moons, good to go to less busy approach control that has radar approach listed in approach plates book, and ask for one. It is definitely different than doing your own nav approaches. On 3/30/2013 5:35 PM, Bob Turner wrote: > - > Finally, all is definitely not lost. My last IPC the cfii shut down all my GRT screens (put them all on an engine page, actually), turned off all NAV's in the panel. Using the internal battery powered D-6, and a battery powered, hand held VOR (could have been a gps, too) I was able to make a passable VOR approach to non precision minimums. But if the visibility were less than a mile, it would definitely be best to go somewhere else! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397366#397366 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 30, 2013
Thanks Bob. "Airspeed: maintain" is better. I changed the autopilot item reply from "ON" to "PUSH AP". That way the EFIS is out of the system and the AP holds current heading and vertical speed by its own gyros. Hopefully I can stabilize things from there. Maybe it's best to avoid following a GPS flight plan altogether, and just fly an assigned heading. When I said there wouldn't be much hope, I meant in a total and complete failure...even then I'm still gonna try! I thoroughly expect to land if a single item or two should fail. Edits to checklist attached. Dave Saylor 831-750-0284 CL On Sat, Mar 30, 2013 at 5:35 PM, Bob Turner wrote: > > Dave, > > I'd suggest: "Airspeed: maintain". In the heat of the moment there's no > need to be messing around with airspeed, especially if pitot data is in > question. You might add: "cross check with gps ground speed". > > If, like many, you can drive your autopilot off your EFIS or directly off > a gps source, make sure you add:"Autopilot: EFIS source off" or however > your EFIS/independent op switch is labeled. And of course, if your > autopilot is only driven off the EFIS it should be "autopilot - off". > > Finally, all is definitely not lost. My last IPC the cfii shut down all my > GRT screens (put them all on an engine page, actually), turned off all > NAV's in the panel. Using the internal battery powered D-6, and a battery > powered, hand held VOR (could have been a gps, too) I was able to make a > passable VOR approach to non precision minimums. But if the visibility were > less than a mile, it would definitely be best to go somewhere else! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397366#397366 > > ________________________________________________________________________________
Date: Mar 30, 2013
Kelly, isn't that the ol' "turn left--stop turn, turn right--stop turn" thing? Yes, it's been a while. And never frequent. Dave Saylor 831-750-0284 CL On Sat, Mar 30, 2013 at 7:35 PM, Kelly McMullen wrote: > > That is when you call the nearest radar facility, say "I have lost my > gyros, need no-gyro surveillance approach to nearest airport. > Anything that limits your need to do more than stay straight and level. If > you haven't done one, or not in many moons, good to go to less busy > approach control that has radar approach listed in approach plates book, > and ask for one. It is definitely different than doing your own nav > approaches. > > > On 3/30/2013 5:35 PM, Bob Turner wrote: > >> - >> Finally, all is definitely not lost. My last IPC the cfii shut down all >> my GRT screens (put them all on an engine page, actually), turned off all >> NAV's in the panel. Using the internal battery powered D-6, and a battery >> powered, hand held VOR (could have been a gps, too) I was able to make a >> passable VOR approach to non precision minimums. But if the visibility were >> less than a mile, it would definitely be best to go somewhere else! >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=397366#397366> >> >> >> >> >> >> >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Mar 30, 2013
Yes, with 1/2 standard rate turns. On 3/30/2013 8:52 PM, Dave Saylor wrote: > Kelly, isn't that the ol' "turn left--stop turn, turn right--stop > turn" thing? Yes, it's been a while. And never frequent. > > Dave Saylor > 831-750-0284 CL > > > On Sat, Mar 30, 2013 at 7:35 PM, Kelly McMullen > wrote: > > > > > That is when you call the nearest radar facility, say "I have lost > my gyros, need no-gyro surveillance approach to nearest airport. > Anything that limits your need to do more than stay straight and > level. If you haven't done one, or not in many moons, good to go > to less busy approach control that has radar approach listed in > approach plates book, and ask for one. It is definitely different > than doing your own nav approaches. > > > On 3/30/2013 5:35 PM, Bob Turner wrote: > > - > Finally, all is definitely not lost. My last IPC the cfii shut > down all my GRT screens (put them all on an engine page, > actually), turned off all NAV's in the panel. Using the > internal battery powered D-6, and a battery powered, hand held > VOR (could have been a gps, too) I was able to make a passable > VOR approach to non precision minimums. But if the visibility > were less than a mile, it would definitely be best to go > somewhere else! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > >
http://forums.matronics.com/viewtopic.php?p=397366#397366 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > > > =================================== > " target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > MS - > k">http://forums.matronics.com > =================================== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > =================================== > > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 31, 2013
Dave, I think it is a great idea to work through items of consideration for various failures. I developed several pages of emergency procedures for my POH. >From an electrical systems point of view, I think it is a good idea to lay out what you can do to try to get the EFIS back (or solve other problems). However, from an aircraft control point of view, with a failure in IMC I doubt you will have time to reference a checklist. I'm not to saying this is a bad exercise, nor am I saying that you shouldn't put these checklists in your POH - maybe I'm merely saying, these might be the kind of checklists that you know by heart. Maybe I missed something, but I think your current checklist version shows that with a black screen, complete failure you no longer have a reference for pitch or wings level. This would be a very bad situation. In my -10 I had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I lost both, I could keep myself right using my 'partial panel' gauges (3 of which work on Pitot-Static alone, the turn and bank was on my emergency electrical bus). Based on the way I designed my system, a lot of things would have to fail to lose all of those. -Jim N312JE: Built, Flown and Sold :( On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > Some time ago Avweb had an article about EFIS failure including some > suggestions about what to do. > > I've meant ever since to develop a page for my checklist just in case. > Using the basic ideas from Avweb I formatted it like my other checklists > and added what I thought was appropriate. > > So...with the understanding that I don't have a lot of IMC experience, > please let me know if this seems appropriate, or if there are obvious > errors. I know it's kind of a longshot to have a complete failure IMC with > a happy ending. Still, ya gotta try. > > For example, I put in Airspeed: VA because it seemed like a good idea. I > don't know if there's an accepted practice here. Just seemed prudent. > > For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My only > mechanical instruments are airspeed and vertical card compass. I have aux > standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. > > > Dave Saylor > 831-750-0284 CL > ________________________________________________________________________________
Date: Mar 31, 2013
Dave, On Mar 31, 2013, at 8:37 AM, James McGrew wrote: > Dave, > > I think it is a great idea to work through items of consideration for various failures. I developed several pages of emergency procedures for my POH. > > =46rom an electrical systems point of view, I think it is a good idea to lay out what you can do to try to get the EFIS back (or solve other problems). However, from an aircraft control point of view, with a failure in IMC I doubt you will have time to reference a checklist. I'm not to saying this is a bad exercise, nor am I saying that you shouldn't put these checklists in your POH - maybe I'm merely saying, these might be the kind of checklists that you know by heart. > > Maybe I missed something, but I think your current checklist version shows that with a black screen, complete failure you no longer have a reference for pitch or wings level. This would be a very bad situation. In my -10 I had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I lost both, I could keep myself right using my 'partial panel' gauges (3 of which work on Pitot-Static alone, the turn and bank was on my emergency electrical bus). Based on the way I designed my system, a lot of things would have to fail to lose all of those. > > -Jim > N312JE: Built, Flown and Sold :( > > > > On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor wrote: > Some time ago Avweb had an article about EFIS failure including some suggestions about what to do. > > I've meant ever since to develop a page for my checklist just in case. Using the basic ideas from Avweb I formatted it like my other checklists and added what I thought was appropriate. > > So...with the understanding that I don't have a lot of IMC experience, please let me know if this seems appropriate, or if there are obvious errors. I know it's kind of a longshot to have a complete failure IMC with a happy ending. Still, ya gotta try. > > For example, I put in Airspeed: VA because it seemed like a good idea. I don't know if there's an accepted practice here. Just seemed prudent. > > For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My only mechanical instruments are airspeed and vertical card compass. I have aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. > > > Dave Saylor > 831-750-0284 CL > > > > ________________________________________________________________________________
Date: Mar 31, 2013
Dave, If you have the D10A with the backup lithium battery you should be all set if the AFS quits. Alan On Mar 31, 2013, at 8:37 AM, James McGrew wrote: > Dave, > > I think it is a great idea to work through items of consideration for various failures. I developed several pages of emergency procedures for my POH. > > =46rom an electrical systems point of view, I think it is a good idea to lay out what you can do to try to get the EFIS back (or solve other problems). However, from an aircraft control point of view, with a failure in IMC I doubt you will have time to reference a checklist. I'm not to saying this is a bad exercise, nor am I saying that you shouldn't put these checklists in your POH - maybe I'm merely saying, these might be the kind of checklists that you know by heart. > > Maybe I missed something, but I think your current checklist version shows that with a black screen, complete failure you no longer have a reference for pitch or wings level. This would be a very bad situation. In my -10 I had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I lost both, I could keep myself right using my 'partial panel' gauges (3 of which work on Pitot-Static alone, the turn and bank was on my emergency electrical bus). Based on the way I designed my system, a lot of things would have to fail to lose all of those. > > -Jim > N312JE: Built, Flown and Sold :( > > > > On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor wrote: > Some time ago Avweb had an article about EFIS failure including some suggestions about what to do. > > I've meant ever since to develop a page for my checklist just in case. Using the basic ideas from Avweb I formatted it like my other checklists and added what I thought was appropriate. > > So...with the understanding that I don't have a lot of IMC experience, please let me know if this seems appropriate, or if there are obvious errors. I know it's kind of a longshot to have a complete failure IMC with a happy ending. Still, ya gotta try. > > For example, I put in Airspeed: VA because it seemed like a good idea. I don't know if there's an accepted practice here. Just seemed prudent. > > For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My only mechanical instruments are airspeed and vertical card compass. I have aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. > > > Dave Saylor > 831-750-0284 CL > > > > ________________________________________________________________________________
Date: Mar 31, 2013
Worse case you have altitude information displayed on the transponder (327) in the right hand side of the display. (You can set it up to show altitude). I also have a free app on my cell phone (GPS STATUS) that shows altitude heading and speed as a fully isolated powered backup. Jim C On Sun, Mar 31, 2013 at 8:52 AM, Alan Mekler MD wrote: > Dave, > On Mar 31, 2013, at 8:37 AM, James McGrew wrote: > > Dave, > > I think it is a great idea to work through items of consideration for > various failures. I developed several pages of emergency procedures for my > POH. > > From an electrical systems point of view, I think it is a good idea to lay > out what you can do to try to get the EFIS back (or solve other problems). > However, from an aircraft control point of view, with a failure in IMC I > doubt you will have time to reference a checklist. I'm not to saying this > is a bad exercise, nor am I saying that you shouldn't put these checklists > in your POH - maybe I'm merely saying, these might be the kind of > checklists that you know by heart. > > Maybe I missed something, but I think your current checklist version shows > that with a black screen, complete failure you no longer have a reference > for pitch or wings level. This would be a very bad situation. In my -10 I > had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a > turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I > lost both, I could keep myself right using my 'partial panel' gauges (3 of > which work on Pitot-Static alone, the turn and bank was on my emergency > electrical bus). Based on the way I designed my system, a lot of things > would have to fail to lose all of those. > > -Jim > N312JE: Built, Flown and Sold :( > > > On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor < > dave.saylor.aircrafters(at)gmail.com> wrote: > >> Some time ago Avweb had an article about EFIS failure including some >> suggestions about what to do. >> >> I've meant ever since to develop a page for my checklist just in case. >> Using the basic ideas from Avweb I formatted it like my other checklists >> and added what I thought was appropriate. >> >> So...with the understanding that I don't have a lot of IMC experience, >> please let me know if this seems appropriate, or if there are obvious >> errors. I know it's kind of a longshot to have a complete failure IMC with >> a happy ending. Still, ya gotta try. >> >> For example, I put in Airspeed: VA because it seemed like a good idea. I >> don't know if there's an accepted practice here. Just seemed prudent. >> >> For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My >> only mechanical instruments are airspeed and vertical card compass. I have >> aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. >> >> >> Dave Saylor >> 831-750-0284 CL >> > > * > > * > > > * > > * > > ________________________________________________________________________________
Date: Mar 31, 2013
Some comments (IMHO). I don't fly IMC but do use checklists ...... and have suffered my own inflight emergencies. I think a few of us will handle emergencies correctly, but until you really have one (hope you don't) you really don't know how you'll react ..... will you be cool or hit the panic button. In my emergencies I didn't even think of looking up a checklist ..... too busy. Remember the three basic items: Aviate, Communicate, Navigate. You should have everything in your checklist 'automatic' when something fails but separated into categories: The first item is 'FLY THE AIRPLANE'. If the engine fails your 'engine checklist' covers those items pertinent to a smooth running engine. If something electrical fails your checklist covers things you can change .... circuit breakers/fuses etc. although I don't recommend changing fuses in flight, and only one attempt at resetting a circuit breaker. With essential buss and/or individual EFIS backup batteries you should never have a total EFIS failure that you have any control over. I'm also reminded of the suggestion: 'Fly the airplane as deep into the crash as you can.' And I have one other suggestion .... practice those emergencies every so often, and involve your front seat passenger, if you have one, in handling your 'emergency'. It's a safe bet that you'll forget items unless you practice. Checklists are great when you have the time to use them, but under pressure ...... I really don't think we will take the time. Maybe it's just me and y'all are far more cool under pressure than I am. Linn PS My off-field emergencies did no further damage to the airplane nor property on the ground. I was terribly lucky and had a whole lot of Angels (they sit on my shoulders) to help me out. On 3/30/2013 11:47 PM, Dave Saylor wrote: > Thanks Bob. "Airspeed: maintain" is better. I changed the autopilot > item reply from "ON" to "PUSH AP". That way the EFIS is out of the > system and the AP holds current heading and vertical speed by its own > gyros. Hopefully I can stabilize things from there. Maybe it's best > to avoid following a GPS flight plan altogether, and just fly an > assigned heading. > > When I said there wouldn't be much hope, I meant in a total and > complete failure...even then I'm still gonna try! I thoroughly expect > to land if a single item or two should fail. > > Edits to checklist attached. > > Dave Saylor > 831-750-0284 CL > > > On Sat, Mar 30, 2013 at 5:35 PM, Bob Turner > wrote: > > > > > Dave, > > I'd suggest: "Airspeed: maintain". In the heat of the moment > there's no need to be messing around with airspeed, especially if > pitot data is in question. You might add: "cross check with gps > ground speed". > > If, like many, you can drive your autopilot off your EFIS or > directly off a gps source, make sure you add:"Autopilot: EFIS > source off" or however your EFIS/independent op switch is labeled. > And of course, if your autopilot is only driven off the EFIS it > should be "autopilot - off". > > Finally, all is definitely not lost. My last IPC the cfii shut > down all my GRT screens (put them all on an engine page, > actually), turned off all NAV's in the panel. Using the internal > battery powered D-6, and a battery powered, hand held VOR (could > have been a gps, too) I was able to make a passable VOR approach > to non precision minimums. But if the visibility were less than a > mile, it would definitely be best to go somewhere else! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397366#397366 > > > ========== > " target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > MS - > k">http://forums.matronics.com > ========== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========== > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Mar 31, 2013
Flying into Seattle about a decade ago, lost vacuum pump on an old 182 (I know, what is a vacuum pump), I had just entered the clouds....Forget the checklist, it was hard enough just to go through the memory items and keep the airplane going in the right direction....declared an emergency, and the controller immediately offered an no gyro approach and tuned me to an area with higher bases. Once I felt I was back in control, the only indication I had of the vacuum failure was the disconnect between the attitude indicator and turn/slip, I had my father in law pull the instrument covers out of my flight bag and I covered the affected instruments and it was just like I was flying with my instructor. In my current airplane, RV-10, I have two levels of backup, with the autopilot being the primary safety instrument...... BTW, I saw a comment about the altitude being on the transponder, that would not work for me if I lose my EFIS, the grey code for the transponder comes from EFIS. Above everything else I have in the airplane panel....I will NOT fly IFR without my Ipad (Wingx Pro is my choice). That will give me everything I need to navigate including GPS altitude..... Rene N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, March 30, 2013 10:00 PM Subject: Re: RV10-List: Re: EFIS failure checklist Yes, with 1/2 standard rate turns. On 3/30/2013 8:52 PM, Dave Saylor wrote: > Kelly, isn't that the ol' "turn left--stop turn, turn right--stop > turn" thing? Yes, it's been a while. And never frequent. > > Dave Saylor > 831-750-0284 CL > > > On Sat, Mar 30, 2013 at 7:35 PM, Kelly McMullen > wrote: > > > > > That is when you call the nearest radar facility, say "I have lost > my gyros, need no-gyro surveillance approach to nearest airport. > Anything that limits your need to do more than stay straight and > level. If you haven't done one, or not in many moons, good to go > to less busy approach control that has radar approach listed in > approach plates book, and ask for one. It is definitely different > than doing your own nav approaches. > > > On 3/30/2013 5:35 PM, Bob Turner wrote: > > - > Finally, all is definitely not lost. My last IPC the cfii shut > down all my GRT screens (put them all on an engine page, > actually), turned off all NAV's in the panel. Using the > internal battery powered D-6, and a battery powered, hand held > VOR (could have been a gps, too) I was able to make a passable > VOR approach to non precision minimums. But if the visibility > were less than a mile, it would definitely be best to go > somewhere else! > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397366#397366 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > > > =================================== > " target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > MS - > k">http://forums.matronics.com > =================================== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > =================================== > > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Mar 31, 2013
Takes you back to basic failure analysis and goals. What are potential single points of failure, besides CFI covering display or turning it off. One example...two full size EFIS/MFD for flight instrumentation with dual adahars. Yes, software bug is prime suspect, although if they aren't set to display the same items, unlikely to glitch at same place. Alternator is backed by ships battery. Ship's power backed by independent backup battery for each screen. GNS-430W/GTN650 or better, independent of EFIS giving ground track and ground speed. Compared to original turn and bank, inclinometer, airspeed, altimeter and low freq range receiver. We have come a long ways in 75 years. The one thing I learned from a lot of partial panel time was that keeping the dirty side down with a basic six pack keeps your brain so busy scanning and processing your basic attitude while giving you severe case of the "leans" that you have less than 1% left for figuring navigation and pushing buttons, so the simpler system you have, that takes minimal brain power to interpret/extract info, the better. That is why I suggest that if you are in radar coverage you off load all navigation responsibility to a controller. I seriously question the ability to be messing with a cell phone while trying to maintain straight and level in clouds at night with no gyros. On Sun, Mar 31, 2013 at 6:23 AM, Jim Combs wrote: > Worse case you have altitude information displayed on the transponder > (327) in the right hand side of the display. (You can set it up to show > altitude). I also have a free app on my cell phone (GPS STATUS) that shows > altitude heading and speed as a fully isolated powered backup. > > Jim C > -------------------- > sent from the microchip implanted in my forearm > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Mar 31, 2013
Dave, this is a good topic - I like the idea. For those of us who have been through the entire build process we are usually aware of how the systems interact (where the encoded altitude is coming from, where the autopilot gets its data, etc.). If this was a factory airplane it would have an extensive POH / data section written to explain all of this. At least I assume a Cessna 172 with all glass has an extended POH. If nothing else it is useful to document how all of these things are interacting to help trouble shoot when something starts not working. Sometimes, not always, a failure can occur when you are in clear blue on top looking at an ocean of clouds below wondering just how you are going to get back down. In these cases you do have some time to do some basic trouble shooting. Many will never consider selling or letting others fly our airplanes, but documentation is key to helping new users understand how the systems work - although I would argue no amount of documentation can replace actually building and the decision making that went into the build. After building an airplane I now realize just how ignorant I was back in the days I first started to rent, even after I had purchased a factory airplane I was still in the dark as to how these thing are really put together. A great side benefit to this portion of our hobby is the depth of knowledge we gain about our airplanes. It is truly ashamed that this is not reflected in our accident rates. Sorry - now onto my question... Back when I was writing our POH I looked at an example that had IFR procedures included, like what the basics setup of the GPS, EFIS, and Autopilot should be for various approaches. Does anyone know where I can find an example (I looked at the examples on Tim's site and VAF)? -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397418#397418 ________________________________________________________________________________
Date: Mar 31, 2013
This discussion has been beneficial and reconfirms my feeling that in an emergency when everything appears as if you are looking through a straw and your head fills with conflicting decision paths that the safest bet is on a 100% independent back up system on its own battery (if needed). I was thrilled to see a new back up EFIS advertised in one of the aviation magazines I receive. Its a sweet little unit that appears to be well designed. After reading of its capabilities and watching the company video I was impressed with the SAM back up EFIS. I had to dig a little deeper to find the unit pricing. $10,800.00. Bahhhahahha Those poor bastards in the certified world will probably have $15K once installed by a certified mechanic. The SAM is a unit that is comparable to the TT Gemini EFIS I have in my 8A for $1,300. I have been very pleased and impressed with my TT Gemini EFIS and I feel comfortable using that as my sole navigation device in an emergency. For $15K I can install 3 TT Gemini back up units each with its own back up battery, buy two Dynon D1 pocket EFIS, buy 3 iPads and an iPad mini plus a years worth of AV gas. My point is there are some quality backup devices that will provide full 6 pack info in a small footprint that are eminently affordable. Retrofitting for a TT Gemini or the like is a pretty simple task and gives great peace of mind should primary instruments start going dark on you. Robin ________________________________________________________________________________
Date: Mar 31, 2013
Subject: seat belts
Hi all, a question for the Canadian RV10 builders. I had a pre cover inspection done yesterday and the inspector stated that seat belts had to be TSO'd. Does anyone know if Vans belts are up to the standard we require in Canada? Vans web site does say the belts meet certification standards, so I would have to assume they are ok with Transport Canada too. Anyone know for sure? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Mar 31, 2013
Somebody said it's not the stuff you know about that gets you, it's the stuff you don't know about...I do expect to rely on the D10A if the AFS fails. I just want to be able to get from one to the other without going too far into the weeds. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 5:56 AM, Alan Mekler MD wrote: > Dave, > If you have the D10A with the backup lithium > battery you should be all set if the AFS quits. > Alan > > On Mar 31, 2013, at 8:37 AM, James McGrew wrote: > > Dave, > > I think it is a great idea to work through items of consideration for > various failures. I developed several pages of emergency procedures for my > POH. > > From an electrical systems point of view, I think it is a good idea to lay > out what you can do to try to get the EFIS back (or solve other problems). > However, from an aircraft control point of view, with a failure in IMC I > doubt you will have time to reference a checklist. I'm not to saying this > is a bad exercise, nor am I saying that you shouldn't put these checklists > in your POH - maybe I'm merely saying, these might be the kind of > checklists that you know by heart. > > Maybe I missed something, but I think your current checklist version shows > that with a black screen, complete failure you no longer have a reference > for pitch or wings level. This would be a very bad situation. In my -10 I > had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a > turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I > lost both, I could keep myself right using my 'partial panel' gauges (3 of > which work on Pitot-Static alone, the turn and bank was on my emergency > electrical bus). Based on the way I designed my system, a lot of things > would have to fail to lose all of those. > > -Jim > N312JE: Built, Flown and Sold :( > > > On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor < > dave.saylor.aircrafters(at)gmail.com> wrote: > >> Some time ago Avweb had an article about EFIS failure including some >> suggestions about what to do. >> >> I've meant ever since to develop a page for my checklist just in case. >> Using the basic ideas from Avweb I formatted it like my other checklists >> and added what I thought was appropriate. >> >> So...with the understanding that I don't have a lot of IMC experience, >> please let me know if this seems appropriate, or if there are obvious >> errors. I know it's kind of a longshot to have a complete failure IMC with >> a happy ending. Still, ya gotta try. >> >> For example, I put in Airspeed: VA because it seemed like a good idea. I >> don't know if there's an accepted practice here. Just seemed prudent. >> >> For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My >> only mechanical instruments are airspeed and vertical card compass. I have >> aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. >> >> >> Dave Saylor >> 831-750-0284 CL >> > > * > > * > > > * > > * > > ________________________________________________________________________________
Date: Mar 31, 2013
Jim, as Linn touched on as well, the checklist is to verify that I'm on the right track. I don't expect to be calm enough to know I'm out of control and also cooly reach for the checklist. As you've said, memorize the first items (Autopilot:AP, Refer to backups) and then use the checklist to refocus and do things in the right order. I think referring to the checklist at some point is very important. A few things have to be automatic though. As far as how to set up equipment, the AFS manual is pretty good to get you in the ballpark for normal operations. Everyone has preferences and training that makes each setup unique. It's good to write it down, though, to force yourself to think about it. I've modified my checklist a bunch of times to fine tune it and to account for changing equipment. I don't have a spinning mass gyro. If I loose all attitude reference it's up to the autopilot's separate gyros and whatever info I can cobble together. If I built it again, or if I do a remodel, I'd add one. My thinking has changed over the years to want to now include at least a TC. But a decent electric attitude indicator is pretty dang expensive. A TC is a lot less and probably more reliable for a given dollar amount. That's a whole different thread though, I was hoping for (and getting) some feedback on the structure of the checklist. Thanks! Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 5:37 AM, James McGrew wrote: > Dave, > > I think it is a great idea to work through items of consideration for > various failures. I developed several pages of emergency procedures for my > POH. > > From an electrical systems point of view, I think it is a good idea to lay > out what you can do to try to get the EFIS back (or solve other problems). > However, from an aircraft control point of view, with a failure in IMC I > doubt you will have time to reference a checklist. I'm not to saying this > is a bad exercise, nor am I saying that you shouldn't put these checklists > in your POH - maybe I'm merely saying, these might be the kind of > checklists that you know by heart. > > Maybe I missed something, but I think your current checklist version shows > that with a black screen, complete failure you no longer have a reference > for pitch or wings level. This would be a very bad situation. In my -10 I > had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a > turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I > lost both, I could keep myself right using my 'partial panel' gauges (3 of > which work on Pitot-Static alone, the turn and bank was on my emergency > electrical bus). Based on the way I designed my system, a lot of things > would have to fail to lose all of those. > > -Jim > N312JE: Built, Flown and Sold :( > > > On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor < > dave.saylor.aircrafters(at)gmail.com> wrote: > >> Some time ago Avweb had an article about EFIS failure including some >> suggestions about what to do. >> >> I've meant ever since to develop a page for my checklist just in case. >> Using the basic ideas from Avweb I formatted it like my other checklists >> and added what I thought was appropriate. >> >> So...with the understanding that I don't have a lot of IMC experience, >> please let me know if this seems appropriate, or if there are obvious >> errors. I know it's kind of a longshot to have a complete failure IMC with >> a happy ending. Still, ya gotta try. >> >> For example, I put in Airspeed: VA because it seemed like a good idea. I >> don't know if there's an accepted practice here. Just seemed prudent. >> >> For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My >> only mechanical instruments are airspeed and vertical card compass. I have >> aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. >> >> >> Dave Saylor >> 831-750-0284 CL >> > > * > > * > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Mar 31, 2013
Good point to cover the inop instruments. I don't know if the big red X on the AFS or grey screen on the D10A will suffice to make me not want to look at them. Hopefully I could ignore them but I've heard at least one study that says they're irresistible to our eyeballs, even knowing they're inop. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 7:03 AM, Rene wrote: > > Flying into Seattle about a decade ago, lost vacuum pump on an old 182 (I > know, what is a vacuum pump), I had just entered the clouds....Forget the > checklist, it was hard enough just to go through the memory items and kee p > the airplane going in the right direction....declared an emergency, and t he > controller immediately offered an no gyro approach and tuned me to an are a > with higher bases. Once I felt I was back in control, the only indicatio n > I had of the vacuum failure was the disconnect between the attitude > indicator and turn/slip, I had my father in law pull the instrument cover s > out of my flight bag and I covered the affected instruments and it was ju st > like I was flying with my instructor. > > In my current airplane, RV-10, I have two levels of backup, with the > autopilot being the primary safety instrument...... > > BTW, I saw a comment about the altitude being on the transponder, that > would not work for me if I lose my EFIS, the grey code for the transponde r > comes from EFIS. > > Above everything else I have in the airplane panel....I will NOT fly IFR > without my Ipad (Wingx Pro is my choice). That will give me everything I > need to navigate including GPS altitude..... > > Rene=99 > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Saturday, March 30, 2013 10:00 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: EFIS failure checklist > > > Yes, with 1/2 standard rate turns. > > On 3/30/2013 8:52 PM, Dave Saylor wrote: > > Kelly, isn't that the ol' "turn left--stop turn, turn right--stop > > turn" thing? Yes, it's been a while. And never frequent. > > > > Dave Saylor > > 831-750-0284 CL > > > > > > On Sat, Mar 30, 2013 at 7:35 PM, Kelly McMullen > > wrote: > > > > > > > > > That is when you call the nearest radar facility, say "I have lost > > my gyros, need no-gyro surveillance approach to nearest airport. > > Anything that limits your need to do more than stay straight and > > level. If you haven't done one, or not in many moons, good to go > > to less busy approach control that has radar approach listed in > > approach plates book, and ask for one. It is definitely different > > than doing your own nav approaches. > > > > > > On 3/30/2013 5:35 PM, Bob Turner wrote: > > > > - > > Finally, all is definitely not lost. My last IPC the cfii shut > > down all my GRT screens (put them all on an engine page, > > actually), turned off all NAV's in the panel. Using the > > internal battery powered D-6, and a battery powered, hand held > > VOR (could have been a gps, too) I was able to make a passable > > VOR approach to non precision minimums. But if the visibility > > were less than a mile, it would definitely be best to go > > somewhere else! > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=397366#397366 > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com> > > > > > > > > ====================== ============= > > " target="_blank">http://www.matronics.com/Navigator?RV10-List > > ====================== ============= > > MS - > > k">http://forums.matronics.com > > ====================== ============= > > e - > > -Matt Dralle, List Admin. > > t="_blank">http://www.matronics.com/contribution > > ====================== ============= > > > > > > > > > > * > > > > > > * > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 31, 2013
J =8Bason, I think I put a reply to you in another post...anyway, the A FS manual is pretty good at getting you set up for different scenarios. They don't use a checklist format, more of a paragraph description, but you can glean the information from that. Of course you have to using similar equipment--digiflght or AFS autopilot and G430/530. They might have procedures for the GTNs by now.=8B Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 8:35 AM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > Dave, this is a good topic - I like the idea. For those of us who have > been through the entire build process we are usually aware of how the > systems interact (where the encoded altitude is coming from, where the > autopilot gets its data, etc.). If this was a factory airplane it would > have an extensive POH / data section written to explain all of this. At > least I assume a Cessna 172 with all glass has an extended POH. If nothi ng > else it is useful to document how all of these things are interacting to > help trouble shoot when something starts not working. Sometimes, not > always, a failure can occur when you are in clear blue on top looking at an > ocean of clouds below wondering just how you are going to get back down. > In these cases you do have some time to do some basic trouble shooting. > Many will never consider selling or letting others fly our airplanes, bu t > documentation is key to helping new users understand how the systems work - > although I would argue no amount of do! > cumentation can replace actually building and the decision making that > went into the build. After building an airplane I now realize just how > ignorant I was back in the days I first started to rent, even after I had > purchased a factory airplane I was still in the dark as to how these thin g > are really put together. A great side benefit to this portion of our hob by > is the depth of knowledge we gain about our airplanes. It is truly asham ed > that this is not reflected in our accident rates. > > Sorry - now onto my question... Back when I was writing our POH I looked > at an example that had IFR procedures included, like what the basics setu p > of the GPS, EFIS, and Autopilot should be for various approaches. Does > anyone know where I can find an example (I looked at the examples on Tim' s > site and VAF)? > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397418#397418 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Mar 31, 2013
Is that the L3 unit? I remember seeing the price and thinking oh brother. I'd rather install a vacuum system, and buy the 3 indicators that are gonna to fail over a couple thousand hours. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 8:48 AM, Robin Marks wrote: > > This discussion has been beneficial and reconfirms my feeling that in an > emergency when everything appears as if you are looking through a straw and > your head fills with conflicting decision paths that the safest bet is on a > 100% independent back up system on its own battery (if needed). > I was thrilled to see a new back up EFIS advertised in one of the aviation > magazines I receive. Its a sweet little unit that appears to be well > designed. After reading of its capabilities and watching the company video > I was impressed with the SAM back up EFIS. I had to dig a little deeper to > find the unit pricing. $10,800.00. Bahhhahahha > Those poor bastards in the certified world will probably have $15K once > installed by a certified mechanic. The SAM is a unit that is comparable to > the TT Gemini EFIS I have in my 8A for $1,300. > I have been very pleased and impressed with my TT Gemini EFIS and I feel > comfortable using that as my sole navigation device in an emergency. For > $15K I can install 3 TT Gemini back up units each with its own back up > battery, buy two Dynon D1 pocket EFIS, buy 3 iPads and an iPad mini plus a > years worth of AV gas. > My point is there are some quality backup devices that will provide full 6 > pack info in a small footprint that are eminently affordable. Retrofitting > for a TT Gemini or the like is a pretty simple task and gives great peace > of mind should primary instruments start going dark on you. > > Robin > > ________________________________________________________________________________
Date: Mar 31, 2013
I agree I'll have my hands full. Geez, I could barely keep up with trimming the airplane during an approach til I installed autotrim. I've already decided that just about any little glitch is pretty serious, in which case I'm asking for as much help as I can get. Maybe a delay vector to sort things out or maybe the E word...it's even on the checklist as a reminder that it's an option. Again, aviate, navigate, communicate. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 7:35 AM, Kelly McMullen wrote: > Takes you back to basic failure analysis and goals. What are potential > single points of failure, besides CFI covering display or turning it off. > One example...two full size EFIS/MFD for flight instrumentation with dual > adahars. Yes, software bug is prime suspect, although if they aren't set to > display the same items, unlikely to glitch at same place. Alternator is > backed by ships battery. Ship's power backed by independent backup battery > for each screen. GNS-430W/GTN650 or better, independent of EFIS giving > ground track and ground speed. > Compared to original turn and bank, inclinometer, airspeed, altimeter and > low freq range receiver. We have come a long ways in 75 years. > The one thing I learned from a lot of partial panel time was that keeping > the dirty side down with a basic six pack keeps your brain so busy scanning > and processing your basic attitude while giving you severe case of the > "leans" that you have less than 1% left for figuring navigation and pushing > buttons, so the simpler system you have, that takes minimal brain power to > interpret/extract info, the better. That is why I suggest that if you are > in radar coverage you off load all navigation responsibility to a > controller. I seriously question the ability to be messing with a cell > phone while trying to maintain straight and level in clouds at night with > no gyros. > > On Sun, Mar 31, 2013 at 6:23 AM, Jim Combs wrote: > >> Worse case you have altitude information displayed on the transponder >> (327) in the right hand side of the display. (You can set it up to show >> altitude). I also have a free app on my cell phone (GPS STATUS) that shows >> altitude heading and speed as a fully isolated powered backup. >> >> Jim C >> -------------------- > > >> sent from the microchip implanted in my forearm >> > * > > * > > ________________________________________________________________________________
Date: Mar 31, 2013
When using a backup EFIS how do you know which one is failing? Does the software of the EFIS identify that it is failing? When we decided to go with mechanical backups of the altimeter, compass, ADI, and airspeed it was so we could go back to the old fashioned way of diagnosing which system was failing. Of course back then none of us had experience glass cockpits and how they fail. I am really not sure which way I would go today. I just wonder when in the soup if I had primary and backup EFISs' not agreeing which direction I would go. As someone just said - it's what you don't know.... -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397452#397452 ________________________________________________________________________________
Date: Mar 31, 2013
Jason, I think that is why many are recommending 3 sources of information. For me, the Trio autopilot will display a symbolic turn coordinator. So if main and backup efis don't agree there is a tie breaker. Also don't forget that old fashioned wet compass. If your efis shows wings level but that compass is moving chances are good that you are not wings level. GPS based moving map will also show if the wings aren't level. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397455#397455 ________________________________________________________________________________
Date: Mar 31, 2013
Q: Does the Air Force still use PAR approaches? Years ago we civilians could sometimes practice them, as long as we did not actually touch down. If you were to find yourself in a bad situation in bad weather the PAR is vastly superior to an ASR approach. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397457#397457 ________________________________________________________________________________
Date: Mar 31, 2013
I believe most EFIS panels will tell you exactly what fails ...... when the compass/ahars fails it's usually no send data, not erroneous data, although that may happen in some instances. Degrading instruments (such as with vacuum failure or gyro failure) are a thing of the past. Electronics, once passed the infant failure mode are pretty reliable, but not bullet proof. On my systems (MGL Odysseys) when items fail I get "X"s or FAIL messages or alarms when data goes out of limits. It all depends on the system and how it's programmed. Linn On 3/31/2013 5:09 PM, jkreidler wrote: > > When using a backup EFIS how do you know which one is failing? Does the software of the EFIS identify that it is failing? When we decided to go with mechanical backups of the altimeter, compass, ADI, and airspeed it was so we could go back to the old fashioned way of diagnosing which system was failing. Of course back then none of us had experience glass cockpits and how they fail. I am really not sure which way I would go today. I just wonder when in the soup if I had primary and backup EFISs' not agreeing which direction I would go. As someone just said - it's what you don't know.... > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397452#397452 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Mar 31, 2013
If you really want a spinning gyro, a turn and bank will give you a more correct indication of whether you are turning or not than a turn coordinator will. The TC responds to bank or turn, and can be confused for pitch that it doesn't have. On the other hand, it is pretty hard to beat either a Dynon D1 EFIS, or I think it is the D6 that is similar cost but adds static system connection for real airspeed/altitude instead of GPS derived ground speed and altitude. Also avoids needing to switch mental gears from EFIS to round dial. On Sun, Mar 31, 2013 at 11:52 AM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > > I don't have a spinning mass gyro. If I loose all attitude reference > it's up to the autopilot's separate gyros and whatever info I can cobble > together. If I built it again, or if I do a remodel, I'd add one. My > thinking has changed over the years to want to now include at least a TC. > But a decent electric attitude indicator is pretty dang expensive. A TC > is a lot less and probably more reliable for a given dollar amount. > > That's a whole different thread though, I was hoping for (and getting) > some feedback on the structure of the checklist. > > Thanks! > > Dave Saylor > 831-750-0284 CL > > > On Sun, Mar 31, 2013 at 5:37 AM, James McGrew wrote: > >> Dave, >> >> I think it is a great idea to work through items of consideration for >> various failures. I developed several pages of emergency procedures for my >> POH. >> >> From an electrical systems point of view, I think it is a good idea to >> lay out what you can do to try to get the EFIS back (or solve other >> problems). However, from an aircraft control point of view, with a failure >> in IMC I doubt you will have time to reference a checklist. I'm not to >> saying this is a bad exercise, nor am I saying that you shouldn't put these >> checklists in your POH - maybe I'm merely saying, these might be the kind >> of checklists that you know by heart. >> >> Maybe I missed something, but I think your current checklist version >> shows that with a black screen, complete failure you no longer have a >> reference for pitch or wings level. This would be a very bad situation. In >> my -10 I had 2 separate EFIS plus round-dial airspeed, altitude, VSI, and a >> turn-and-bank coordinator. If I lost 1 EFIS, I used the other one. If I >> lost both, I could keep myself right using my 'partial panel' gauges (3 of >> which work on Pitot-Static alone, the turn and bank was on my emergency >> electrical bus). Based on the way I designed my system, a lot of things >> would have to fail to lose all of those. >> >> -Jim >> N312JE: Built, Flown and Sold :( >> >> >> >> On Sat, Mar 30, 2013 at 6:15 PM, Dave Saylor < >> dave.saylor.aircrafters(at)gmail.com> wrote: >> >>> Some time ago Avweb had an article about EFIS failure including some >>> suggestions about what to do. >>> >>> I've meant ever since to develop a page for my checklist just in case. >>> Using the basic ideas from Avweb I formatted it like my other checklists >>> and added what I thought was appropriate. >>> >>> So...with the understanding that I don't have a lot of IMC experience, >>> please let me know if this seems appropriate, or if there are obvious >>> errors. I know it's kind of a longshot to have a complete failure IMC with >>> a happy ending. Still, ya gotta try. >>> >>> For example, I put in Airspeed: VA because it seemed like a good idea. >>> I don't know if there's an accepted practice here. Just seemed prudent. >>> >>> For reference, I have an AFS EFIS, D10A backup, and 696 for GPS2. My >>> only mechanical instruments are airspeed and vertical card compass. I have >>> aux standby batteries powering EFIS 1&2, GPS 1&2, COM1, autopilot, and trim. >>> >>> >>> Dave Saylor >>> 831-750-0284 CL >>> >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Mar 31, 2013
They still show in my approach plate books. Policy varies by command whether you can get a practice or not. I know Luke AFB does not allow, not sure about Davis Monthan or Yuma MCAS. If you are skilled enough or desperate enough, they can talk you all the way to touch down, but it will take the E word to get them to continue guidance below minimums that are normally 200 & one half. On 3/31/2013 2:34 PM, Bob Turner wrote: > > Q: Does the Air Force still use PAR approaches? Years ago we civilians could sometimes practice them, as long as we did not actually touch down. If you were to find yourself in a bad situation in bad weather the PAR is vastly superior to an ASR approach. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397457#397457 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: seat belts
Date: Mar 31, 2013
Rick, TSOd belts come with a certification tag attached to the belt. The belts i received from Vans did not have any documentation. I would check with vans on the cert. documents if they exist. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397490#397490 ________________________________________________________________________________
Date: Mar 31, 2013
Subject: Re: EFIS failure checklist
I've seen my AFS fail, on the ground. The AHRS blew something inside and it literally smoked. It put a big red X on the screen. I flew it home, 12 miles, VMC, and the X remained the whole time. Very obvious. I've also seen my D10A fail, indicating about a 10* bank but otherwise normal. No outward signs telling me it failed, just a clearly false indication. If it isn't spooled up it sometimes reverts to a grey-on-grey screen to indicate that all is not well, instead of the normal blue/brown screen. But it didn't do that when it indicated the false bank. So, no real answer to that question--best case, some do and some don't. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 2:09 PM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > When using a backup EFIS how do you know which one is failing? Does the > software of the EFIS identify that it is failing? When we decided to go > with mechanical backups of the altimeter, compass, ADI, and airspeed it was > so we could go back to the old fashioned way of diagnosing which system was > failing. Of course back then none of us had experience glass cockpits and > how they fail. I am really not sure which way I would go today. I just > wonder when in the soup if I had primary and backup EFISs' not agreeing > which direction I would go. As someone just said - it's what you don't > know.... > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397452#397452 > > ________________________________________________________________________________
Date: Mar 31, 2013
Date: Apr 01, 2013
Hmmm, yeah I will call then today. I was going to order a few things from Vans to send to my sisters when we get to St Louis. Is there anything you need? While I'm thinking of it, did you buy the rear seat foam from Vans? The front seats obviously have a frame, but I'm assuming the rear seats just have the foam covered and then velcro in place? Thx, Rick On Sun, Mar 31, 2013 at 11:04 PM, bill.peyton wrote: > > Rick, > TSOd belts come with a certification tag attached to the belt. The belts > i received from Vans did not have any documentation. I would check with > vans on the cert. documents if they exist. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=397490#397490 > > ________________________________________________________________________________
Date: Apr 01, 2013
You could install just an inclinometer for a few bucks that would at least tell you whether you were coordinated, whether in bank or not. Odds are that in unintended bank you might also be uncoordinated. On Sun, Mar 31, 2013 at 10:54 PM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > I've seen my AFS fail, on the ground. The AHRS blew something inside and > it literally smoked. It put a big red X on the screen. I flew it home, 12 > miles, VMC, and the X remained the whole time. Very obvious. > > I've also seen my D10A fail, indicating about a 10* bank but otherwise > normal. No outward signs telling me it failed, just a clearly false > indication. If it isn't spooled up it sometimes reverts to a grey-on-grey > screen to indicate that all is not well, instead of the normal blue/brown > screen. But it didn't do that when it indicated the false bank. > > So, no real answer to that question--best case, some do and some don't. > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Apr 01, 2013
I purchased my belts from Hooker Harness. They worked well in the 8A so I d ecided to go with them again. Carl On Apr 1, 2013, at 10:10 AM, Rick Lark wrote: > Hmmm, yeah I will call then today. I was going to order a few things from Vans to send to my sisters when we get to St Louis. Is there anything you n eed? > > While I'm thinking of it, did you buy the rear seat foam from Vans? The f ront seats obviously have a frame, but I'm assuming the rear seats just have the foam covered and then velcro in place? > > Thx, Rick > > > On Sun, Mar 31, 2013 at 11:04 PM, bill.peyton wro te: >> >> Rick, >> TSOd belts come with a certification tag attached to the belt. The belts i received from Vans did not have any documentation. I would check with va ns on the cert. documents if they exist. >> >> -------- >> Bill >> WA0SYV >> Aviation Partners, LLC >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=397490#397490 >> >> >> >> >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 01, 2013
I just saw an RV8 yesterday, being prepped for DAR inspection. Problem #1, seat belt hardware in stock rear seat location interfered with flap operation. Problem #2, front seat belt anchors were too close together in stock plans location for anyone over 125 lbs and 28 in waist. Something to ponder long before nearing completion. Fabrication of new anchors or offsets in last few days causes stress in more ways than one. On 4/1/2013 7:56 AM, Carl Froehlich wrote: > I purchased my belts from Hooker Harness. They worked well in the 8A > so I decided to go with them again. > > Carl > > On Apr 1, 2013, at 10:10 AM, Rick Lark > wrote: > >> Hmmm, yeah I will call then today. I was going to order a few things >> from Vans to send to my sisters when we get to St Louis. Is there >> anything you need? >> >> While I'm thinking of it, did you buy the rear seat foam from Vans? >> The front seats obviously have a frame, but I'm assuming the rear >> seats just have the foam covered and then velcro in place? >> >> Thx, Rick >> >> >> On Sun, Mar 31, 2013 at 11:04 PM, bill.peyton > > wrote: >> >> > >> >> Rick, >> TSOd belts come with a certification tag attached to the belt. >> The belts i received from Vans did not have any documentation. >> I would check with vans on the cert. documents if they exist. >> >> -------- >> Bill >> WA0SYV >> Aviation Partners, LLC >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=397490#397490 >> >> >> >> >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> * >> >> >> * > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 01, 2013
I do not remember that being a requirement or even being discussed. I think we have Hooker harnesses in ours, but I don't know if they are TSO'd. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397530#397530 ________________________________________________________________________________
Date: Apr 01, 2013
SSBzcG9rZSB3aXRoIEhvb2tlciBhdCBPU0ggYW5kIGNvdWxkIG5vdCBiZWxpZXZlIHdoYXQgQS4u SC4uJ3MgdGhleSB3ZXJlIHRvIG1lLiBJIGhhZCBub3QgZXZlbiBnb3QgbXkgYmFzaWMgcXVlc3Rp b24gb3V0IGJlZm9yZSB0aGV5IHdlcmUgZGlzbWlzc2l2ZSBhbmQgY29uZGVzY2VuZGluZy4gSSBk aWQgZW5kIHVwIG9yZGVyaW5nIGEgInN0YW5kYXJkIiBzZXQgb2YgUlYtMTAgcm90YXJ5IHJlbGVh c2UgKHRvcCBvZiB0aGUgbGluZSkgYmVsdHMgZnJvbSB0aGVtIGJ5IHBob25lIGxhdGVyLiBIb29r ZXIgYmVsdHMgYXJlIHdlbGwgbWFkZSBhbmQgSEVBVlkgcGx1cyBxdWl0ZSBleHBlbnNpdmUuIFdo ZW4geW91IHJlY2VpdmUgdGhlIHBhY2thZ2UgKHdpdGggUm90YXJ5IHJlbGVhc2UpIHlvdSBjYW5u b3QgYmVsaWV2ZSBob3cgaGVhdnkgNCBmdWxsIHNldHMgd2VpZ2guIEl0IHR1cm5lZCBvdXQgaW4g dGhlIGZyb250IHNlYXQgdGhlIGlubmVyIHNlYXQgYWRqdXN0bWVudCBtZWNoYW5pc20gY29uZmxp Y3RzIHdpdGggbXkgY3VzdG9tIGNlbnRlciBjb25zb2xlIG1ha2luZyBpdCBleHRyZW1lbHkgZGlm ZmljdWx0IHRvIGFkanVzdC4gVGhlIGZyb250IG91dHNpZGUgYWRqdXN0bWVudCBtZWNoYW5pc20g YXJlIHR1Y2tlZCBzbyBmYXIgYXJvdW5kIHRoZSBzaWRlIG9mIHRoZSBzZWF0IHRoYXQgYWRqdXN0 aW5nIHRoYXQgc2lkZSBpcyBhbHNvIGRpZmZpY3VsdC4gSW4gdGhlIHJlYXIgdGhlIGhhcmQgc2V3 biBsZW5ndGggbWVhbnMgdGhhdCBteSAxOSB5ZWFyIG9sZCBkYXVnaHRlciB3aG8gaXMgdmVyeSBw ZXRpdGUgKDk1IExicy4pIGNhbm5vdCBiZSBwcm9wZXJseSByZXN0cmFpbmVkIGJlY2F1c2UgdGhl IGxhcCBzZWN0aW9uIHdpbGwgbm90IGdldCBzbWFsbCBlbm91Z2ggZHVlIHRoZSBsaW1pdGF0aW9u cyBvbiBob3cgc2hvcnQgdGhlIGxhcCBiZWx0cyB3aWxsIGdldC4gRm9yZ2V0IGFib3V0IGFueSBz a2lubnkgeW91dGggSSBwbGFjZSBiYWNrIHRoZXJlLiBCb2xzdGVycyBhcmUgYSByZXF1aXJlbWVu dCBmb3IgbXkgY29uZmlndXJhdGlvbiBpbiB0aGUgcmVhciBvZiB0aGUgLTEwLg0KQWRkaXRpb25h bGx5IHRoZSBIb29rZXIgYmVsdHMgYXJlIHF1aXRlIHN0aWZmIGFuZCBub3QgZXNwZWNpYWxseSBj b21mb3J0YWJsZSB0aWxsIHlvdSBzaXQgbWFueSBob3VycyBzdHJhcHBlZCBpbiBhdCB3aGljaCBw b2ludCB0aGV5IGJlY29tZSBhY2NlcHRhYmxlLiBUaGUgdmFucyBiZWx0cyBhcmUgc29mdCBhcyBi dXR0ZXIgb3V0IG9mIHRoZSBwYWNrYWdlIGNvbXBhcmVkIHRvIHRoZSBIb29rZXIgYmVsdHMuDQpX aGVuIEkgYnVpbHQgbXkgOEEgSSBzdGlsbCB3YW50ZWQgdGhlIHJvdGFyeSByZWxlYXNlIGJ1dCB3 YXMgbm90IGdvaW5nIHRvIHBhdHJvbml6ZSBIb29rZXIgYWdhaW4uIFN0aWxsIGFubm95ZWQgYXQg bXkgT1NIIGV4cGVyaWVuY2UuIEkgd2VudCB3aXRoIENyb3cgRW50ZXJwcmlzZSBiZWx0cy4gSSBz YXcgdGhlbSBpbiBhbm90aGVyIFJWIGFuZCBsaWtlZCB0aGVtLiBUaGUgcm90YXJ5IHJlbGVhc2Ug d2VpZ2hzIHdheSBsZXNzIHRoYW4gdGhlIEhvb2tlciBidWNrbGVzIGJ1dCBpcyBub3QgbGlrZSB0 aGUgY2hlYXAgcm90YXJ5IHJlbGVhc2UgdW5pdHMgeW91IGdldCBvbiBlQmF5IGZvciBhIGZldyBi dWNrcy4gVGhlIGJ1Y2tsZXMgZnVuY3Rpb24gaWRlbnRpY2FsbHkgdG8gdGhlIEhvb2tlciB1bml0 cyBhbmQgaGF2ZSBhIHZlcnkgcG9zaXRpdmUgYWN0aW9uLiBUaGUgYmVsdCBzdHJhcHMgYXJlIGNs b3NlciBpbiBmZWVsIHRvIHRoZSBWYW5zIHVuaXRzIGFuZCBhcmUgdmVyeSBjb21mb3J0YWJsZSBy aWdodCBvdXQgb2YgdGhlIGJveC4gQmVzdCBvZiBhbGwgdGhleSBhcmUgb24gdGhlIG9yZGVyIG9m IGhhbGYgdGhlIHByaWNlIG9mIHRoZSBIb29rZXIgdW5pdHMuIEkgaGF2ZSBhYm91dCAxNTAgaG91 cnMgb24gbXkgQ3JvdyBiZWx0cyBhbmQgd291bGQgZG8gaXQgYWdhaW4gZm9yIGJvdGggbXkgLTEw IGFuZCA4QSBpZiBJIGhhZCB0aGUgY2hvaWNlLg0KQlRXIENyb3cgYWxzbyBtYWtlcyB0aGUgIkxh dGNoICYgTGluayIgc3R5bGUgYnVja2xlIHdoaWNoIHdpbGwgc2F2ZSB5b3UgZXZlbiBtb3JlIHdl aWdodCAmIGNvbXBsZXhpdHkuIFRoZXNlIGFyZSB0aGUgc2FtZSBidWNrbGVzIEkgaGFkIG9uIG15 IHJhY2luZyBNNiBCTVcgZnJvbSBTaW1wc29uLiBUaGV5IGFsc28gd29yayB2ZXJ5IHdlbGwgYW5k IGFyZSBzaW1wbGUgZGVzaWduLg0KaHR0cDovL3d3dy5jcm93ZW50ZXJwcml6ZXMuY29tL3BhZ2Vz L0RyaXZlclJlc3RyYWludHMuaHRtbA0KDQpHb29kIGx1Y2ssDQpSb2Jpbg0KDQpGcm9tOiBvd25l ci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qt c2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBDYXJsIEZyb2VobGljaA0KU2VudDog TW9uZGF5LCBBcHJpbCAwMSwgMjAxMyA3OjU2IEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5j b20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFJlOiBzZWF0IGJlbHRzDQoNCkkgcHVyY2hhc2Vk IG15IGJlbHRzIGZyb20gSG9va2VyIEhhcm5lc3MuICBUaGV5IHdvcmtlZCB3ZWxsIGluIHRoZSA4 QSBzbyBJIGRlY2lkZWQgdG8gZ28gd2l0aCB0aGVtIGFnYWluLg0KDQpDYXJsDQoNCk9uIEFwciAx LCAyMDEzLCBhdCAxMDoxMCBBTSwgUmljayBMYXJrIDxsYXJrcnYxMEBnbWFpbC5jb208bWFpbHRv OmxhcmtydjEwQGdtYWlsLmNvbT4+IHdyb3RlOg0KSG1tbSwgeWVhaCBJIHdpbGwgY2FsbCB0aGVu IHRvZGF5LiAgSSB3YXMgZ29pbmcgdG8gb3JkZXIgYSBmZXcgdGhpbmdzIGZyb20gVmFucyB0byBz ZW5kIHRvIG15IHNpc3RlcnMgd2hlbiB3ZSBnZXQgdG8gU3QgTG91aXMuICBJcyB0aGVyZSBhbnl0 aGluZyB5b3UgbmVlZD8NCldoaWxlIEknbSB0aGlua2luZyBvZiBpdCwgZGlkIHlvdSBidXkgdGhl IHJlYXIgc2VhdCBmb2FtIGZyb20gVmFucz8gIFRoZSBmcm9udCBzZWF0cyBvYnZpb3VzbHkgaGF2 ZSBhIGZyYW1lLCBidXQgSSdtIGFzc3VtaW5nIHRoZSByZWFyIHNlYXRzIGp1c3QgaGF2ZSB0aGUg Zm9hbSBjb3ZlcmVkIGFuZCB0aGVuIHZlbGNybyBpbiBwbGFjZT8NClRoeCwgIFJpY2sNCg0KT24g U3VuLCBNYXIgMzEsIDIwMTMgYXQgMTE6MDQgUE0sIGJpbGwucGV5dG9uIDxwZXl0b24uYkBzYmNn bG9iYWwubmV0PG1haWx0bzpwZXl0b24uYkBzYmNnbG9iYWwubmV0Pj4gd3JvdGU6DQotLT4gUlYx MC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiYmlsbC5wZXl0b24iIDxwZXl0b24uYkBzYmNnbG9i YWwubmV0PG1haWx0bzpwZXl0b24uYkBzYmNnbG9iYWwubmV0Pj4NCg0KUmljaywNClRTT2QgYmVs dHMgY29tZSB3aXRoIGEgY2VydGlmaWNhdGlvbiB0YWcgYXR0YWNoZWQgdG8gdGhlIGJlbHQuICBU aGUgYmVsdHMgaSByZWNlaXZlZCBmcm9tIFZhbnMgZGlkIG5vdCBoYXZlIGFueSBkb2N1bWVudGF0 aW9uLiAgSSB3b3VsZCBjaGVjayB3aXRoIHZhbnMgb24gdGhlIGNlcnQuIGRvY3VtZW50cyBpZiB0 aGV5IGV4aXN0Lg0KDQotLS0tLS0tLQ0KQmlsbA0KV0EwU1lWDQpBdmlhdGlvbiBQYXJ0bmVycywg TExDDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KaHR0cDovL2ZvcnVt cy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD0zOTc0OTAjMzk3NDkwDQoNCg0KDQoNCg0K DQoNCj09PT09PT09PT09DQphcmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP1JWMTAtTGlzdA0KPT09PT09PT09PT0NCmh0dHA6Ly9mb3J1bXMubWF0cm9uaWNz LmNvbQ0KPT09PT09PT09PT0NCmxlLCBMaXN0IEFkbWluLg0KPSJfYmxhbmsiPmh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj09PT09PT09PT09DQoNCg0KDQoNCg0KDQoNCg0K DQoNCg0KDQoNCg0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0KXy09M0QgICAgICAgICAgLSBUaGUgUlYxMC1MaXN0 IEVtYWlsIEZvcnVtIC0NCg0KXy09M0QgVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBO YXZpZ2F0b3IgdG8gYnJvd3NlDQoNCl8tPTNEIHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2gg YXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPTNEIEFyY2hpdmUgU2VhcmNoICYgRG93bmxv YWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KDQpfLT0zRCBQaG90b3NoYXJlLCBhbmQgbXVj aCBtdWNoIG1vcmU6DQoNCl8tPTNEDQoNCl8tPTNEICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNz LmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0PDNEJTIyaHR0cDovd3d3Lm1hdHJvbmljcy5jb20vTmF2 aWdhdG9yP1JWMTAtTGlzdCUyMj4NCg0KXy09M0QNCg0KXy09M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9 M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0Q9M0QNCg0KXy09M0QgICAg ICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCg0KXy09M0QgU2FtZSBncmVhdCBj b250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09M0QNCg0KXy09 M0QgICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tPDNEJTIyaHR0cDovZm9ydW1zLm1h dHJvbmljcy5jb20lMjI+DQoNCl8tPTNEDQoNCl8tPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNE PTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEPTNEDQoNCl8tPTNEICAgICAgICAg ICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0zRCAgVGhhbmsgeW91IGZv ciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQoNCl8tPTNEICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0zRCAgIC0tPiBodHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uPDNEJTIyaHR0cDovd3d3Lm1hdHJvbmljcy5jb20v Y29udHJpYnV0aW9uJTIyPg0KDQpfLT0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0z RD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRD0zRA0KDQoNCg0KX19fX19fX19fX19fX19fX19f X19fX19fX19fX19fX18NCk5vIHZpcnVzIGZvdW5kIGluIHRoaXMgbWVzc2FnZS4NCkNoZWNrZWQg YnkgQVZHIC0gd3d3LmF2Zy5jb208aHR0cDovL3d3dy5hdmcuY29tPg0KVmVyc2lvbjogMjAxMy4w LjI5MDQgLyBWaXJ1cyBEYXRhYmFzZTogMjY0MS82MjA3IC0gUmVsZWFzZSBEYXRlOiAwMy8yNy8x Mw0K ________________________________________________________________________________
Date: Apr 01, 2013
Subject: rear seat foam
I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of those from Oregon Aero. I would like opinions on whether the extra cost is worth the comfort. I'd also like to sit in both the Oregon Aero seats and Vans so if you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. Linn ________________________________________________________________________________
Date: Apr 01, 2013
Subject: Re: rear seat foam
Linn, one way of looking at you dilemma is.....how often will you sit in the back seat? ;-) Rick On Mon, Apr 1, 2013 at 1:50 PM, Linn wrote: > I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of > those from Oregon Aero. > I would like opinions on whether the extra cost is worth the comfort. > > I'd also like to sit in both the Oregon Aero seats and Vans so if you're > bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see > what they're like. > > Linn > > * > > * > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Apr 01, 2013
Linn I have the rear seat foams available like the ones Vans sells for $200.00 Here is a photo of recent seats I did. These have memory foam in bottom cushions and high quality bolster foam Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p <http://www.aerosportproducts.com/> www.aerosportproducts.com _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Monday, April 01, 2013 3:06 PM Subject: Re: RV10-List: rear seat foam Linn, one way of looking at you dilemma is.....how often will you sit in the back seat? ;-) Rick On Mon, Apr 1, 2013 at 1:50 PM, Linn wrote: I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of those from Oregon Aero. I would like opinions on whether the extra cost is worth the comfort. I'd also like to sit in both the Oregon Aero seats and Vans so if you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. Linn get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 01, 2013
it=99s all the same foam. You=99re paying for the Name only. I know Oregon Aero told me that needed to get their money back for their R&D on the front seats and rear seats. I built my own rear seats and think I should get $50 for my R&D. I don=99t recall where the foam comes from, When I was helping Desser put together a airframe package I saw they had rolls of the foam. They told me they provided the seats for the RV=99s, but I don=99t think it was for the RV-10. Bottom line, I bought some of the blue and pink (softer) foam online for about $40 for my custom built (by me) seats, have plenty left over too. Most of the seats are formed foam that is rather cheap in general. From: Linn Sent: Monday, April 01, 2013 10:50 AM Subject: RV10-List: rear seat foam I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of those from Oregon Aero. I would like opinions on whether the extra cost is worth the comfort. I'd also like to sit in both the Oregon Aero seats and Vans so if you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. Linn ________________________________________________________________________________
Date: Apr 01, 2013
worse than that.. how often will your family sit in the back seat? If they aint happy no one is flying with you.. Ask me how I know, they are happy as clams back there and never complain. Usually when we fly as a family I=99m going 4hr legs. Good point however, if no one is really going to be back there for long save the money and use a few pillows covered by a walmart seat cover.. Just don=99t let anyone see it however From: Rick Lark Sent: Monday, April 01, 2013 12:06 PM Subject: Re: RV10-List: rear seat foam Linn, one way of looking at you dilemma is.....how often will you sit in the back seat? ;-) Rick On Mon, Apr 1, 2013 at 1:50 PM, Linn wrote: I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of those from Oregon Aero. I would like opinions on whether the extra cost is worth the comfort. I'd also like to sit in both the Oregon Aero seats and Vans so if you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. Linn get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 01, 2013
I'll only sit in the back ...... at SNF :-D I'm going to travel around the country, possibly with a full load, so the comfort of the rear seats is kinda important ..... especially if I can get whacked by the passenger behind me!!! Thanks for the note .... made me chuckle! Linn On 4/1/2013 3:06 PM, Rick Lark wrote: > Linn, one way of looking at you dilemma is.....how often will you sit > in the back seat? ;-) > Rick > > > On Mon, Apr 1, 2013 at 1:50 PM, Linn > wrote: > > I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost > of those from Oregon Aero. > I would like opinions on whether the extra cost is worth the comfort. > > I'd also like to sit in both the Oregon Aero seats and Vans so if > you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd > like to see what they're like. > > Linn > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Apr 01, 2013
Van's has RV-10 rear seat foam cores that have 3 pieces (seat, back, lumbar) X 2 seats for $315 now. The O.A. seats are $342/seat and don't have the lumbar cushion. O.A. says their seats are pure memory foam while Vans has cheaper foam in places. Makes choosing difficult. Linn On 4/1/2013 3:49 PM, Geoff Combs wrote: > Linn > I have the rear seat foams available like the ones Vans sells for > $200.00 Here is a photo of recent seats I did. These have memory foam > in bottom cushions and high quality bolster foam > Geoff > * > *Geoff Combs * > Aerosport Products > 8090 howe industrial pkwy > canal winchester, ohio 43110 > *614.834.8659p > *www.aerosportproducts.com <http://www.aerosportproducts.com/> > * > > ------------------------------------------------------------------------ > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rick Lark > *Sent:* Monday, April 01, 2013 3:06 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: rear seat foam > > Linn, one way of looking at you dilemma is.....how often will you sit > in the back seat? ;-) > Rick > > > On Mon, Apr 1, 2013 at 1:50 PM, Linn > wrote: > > I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost > of those from Oregon Aero. > I would like opinions on whether the extra cost is worth the comfort. > > I'd also like to sit in both the Oregon Aero seats and Vans so if > you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd > like to see what they're like. > > Linn > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Apr 01, 2013
Geoff did my seats and I'm very pleased how they came out. Photos are on mykitlog.com site. Bob ________________________________________________________________________________
Date: Apr 01, 2013
I have Van's foam, covered by a local shop. Wife and friends have sat back there, they say it's comfortable. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397570#397570 ________________________________________________________________________________
Date: Apr 01, 2013
not really. Memory foam is over rated. None of my cars have it and they are quite comfortable when we drove for hours. When it gets cold, memory foam are like rock until warmed up. Forget the hype buy 2-3 sq ft of the memory foam for your bum and the rest can be the same foam used at car shops. I enclosed my seats layout for your review. This setup works today, I think this is the same setup as Vans- but I bet a good shop can duplicate it. From: Linn Sent: Monday, April 01, 2013 1:56 PM Subject: Re: RV10-List: rear seat foam Van's has RV-10 rear seat foam cores that have 3 pieces (seat, back, lumbar) X 2 seats for $315 now. The O.A. seats are $342/seat and don't have the lumbar cushion. O.A. says their seats are pure memory foam while Vans has cheaper foam in places. Makes choosing difficult. Linn On 4/1/2013 3:49 PM, Geoff Combs wrote: Linn I have the rear seat foams available like the ones Vans sells for $200.00 Here is a photo of recent seats I did. These have memory foam in bottom cushions and high quality bolster foam Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com ------------------------------------------------------------------------- ----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Lark Sent: Monday, April 01, 2013 3:06 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: rear seat foam Linn, one way of looking at you dilemma is.....how often will you sit in the back seat? ;-) Rick On Mon, Apr 1, 2013 at 1:50 PM, Linn wrote: I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of those from Oregon Aero. I would like opinions on whether the extra cost is worth the comfort. I'd also like to sit in both the Oregon Aero seats and Vans so if you're bringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. Linn get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c No virus found in this message. Checked by AVG - www.avg.com 04/01/13 ________________________________________________________________________________
Date: Apr 01, 2013
I recommend giving Geoff a call to ask about the things he does to different iate his product from others. Ask him about how he ties down pleats and sea ms. Or how he adds foam to soften the edges around the seat frame. Many of you know that Geoff and I are friends, but I'm also a satisfied cust omer. I believe he'll be flying to SnF, so you can see his seats in person. Ther e are also a few other forum members that have Geoff's seat too. Bob Sent from my iPhone On Apr 1, 2013, at 4:56 PM, Linn wrote: Van's has RV-10 rear seat foam cores that have 3 pieces (seat, back, lumbar) X 2 seats for $315 now. The O.A. seats are $342/seat and don't have the lu mbar cushion. O.A. says their seats are pure memory foam while Vans has cheaper foam in pl aces. Makes choosing difficult. Linn On 4/1/2013 3:49 PM, Geoff Combs wrote: > Linn > I have the rear seat foams available like the ones Vans sells for $200.00 H ere is a photo of recent seats I did. These have memory foam > in bottom cushions and high quality bolster foam > > > > Geoff > > Geoff Combs > Aerosport Products > 8090 howe industrial pkwy > canal winchester, ohio 43110 > 614.834.8659p > www.aerosportproducts.com > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Rick Lark > Sent: Monday, April 01, 2013 3:06 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: rear seat foam > > Linn, one way of looking at you dilemma is.....how often will you sit in t he back seat? ;-) > > Rick > > > On Mon, Apr 1, 2013 at 1:50 PM, Linn wrote: >> I have a dilemma ..... Van's RV-10 rear seat foam is 1/2 the cost of thos e from Oregon Aero. >> I would like opinions on whether the extra cost is worth the comfort. >> >> I'd also like to sit in both the Oregon Aero seats and Vans so if you're b ringing your RV-10 with Oregon Aero seats to Sun-n-Fun I'd like to see what they're like. >> >> Linn >> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > No virus found in this message. > Checked by AVG - www.avg.com > 04/01/13 > ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Apr 01, 2013
I went with the Van's rear seat foam. I get consistently good reports on back seat comfort from adults. I rode in Tim Olson's back seat in 2006 or 2007 and was impressed at how roomy the back seat is and how comfortable the seats are. I am 6'1" and usually (but not always!!) a bit north of 200 pounds. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397601#397601 ________________________________________________________________________________
Date: Apr 02, 2013
I don't think so. http://utubeclassic.com/watch.php?v=j4IE9DMpj0U I am having a difficult time sourcing the company page or the original vide o. Above is a 3rd party video. Sent from the new iPad On Mar 31, 2013, at 12:27 PM, "Dave Saylor" <dave.saylor.aircrafters@gmail. com> wrote: Is that the L3 unit? I remember seeing the price and thinking oh brother. I'd rather install a vacuum system, and buy the 3 indicators that are gonn a to fail over a couple thousand hours. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 8:48 AM, Robin Marks > wrote: robin(at)painttheweb.com>> This discussion has been beneficial and reconfirms my feeling that in an em ergency when everything appears as if you are looking through a straw and y our head fills with conflicting decision paths that the safest bet is on a 100% independent back up system on its own battery (if needed). I was thrilled to see a new back up EFIS advertised in one of the aviation magazines I receive. Its a sweet little unit that appears to be well design ed. After reading of its capabilities and watching the company video I was impressed with the SAM back up EFIS. I had to dig a little deeper to find t he unit pricing. $10,800.00. Bahhhahahha Those poor bastards in the certified world will probably have $15K once ins talled by a certified mechanic. The SAM is a unit that is comparable to the TT Gemini EFIS I have in my 8A for $1,300. I have been very pleased and impressed with my TT Gemini EFIS and I feel co mfortable using that as my sole navigation device in an emergency. For $15K I can install 3 TT Gemini back up units each with its own back up battery, buy two Dynon D1 pocket EFIS, buy 3 iPads and an iPad mini plus a years wo rth of AV gas. My point is there are some quality backup devices that will provide full 6 pack info in a small footprint that are eminently affordable. Retrofitting for a TT Gemini or the like is a pretty simple task and gives great peace o f mind should primary instruments start going dark on you. Robin " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 02, 2013
http://sarasotaavionics.com/avionics/md302-sam There is a button to "add to cart" . I bet you could schedule it for Saturd ay delivery. :-) Robin Sent from the new iPad On Mar 31, 2013, at 12:27 PM, "Dave Saylor" <dave.saylor.aircrafters@gmail. com> wrote: Is that the L3 unit? I remember seeing the price and thinking oh brother. I'd rather install a vacuum system, and buy the 3 indicators that are gonn a to fail over a couple thousand hours. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 8:48 AM, Robin Marks > wrote: robin(at)painttheweb.com>> This discussion has been beneficial and reconfirms my feeling that in an em ergency when everything appears as if you are looking through a straw and y our head fills with conflicting decision paths that the safest bet is on a 100% independent back up system on its own battery (if needed). I was thrilled to see a new back up EFIS advertised in one of the aviation magazines I receive. Its a sweet little unit that appears to be well design ed. After reading of its capabilities and watching the company video I was impressed with the SAM back up EFIS. I had to dig a little deeper to find t he unit pricing. $10,800.00. Bahhhahahha Those poor bastards in the certified world will probably have $15K once ins talled by a certified mechanic. The SAM is a unit that is comparable to the TT Gemini EFIS I have in my 8A for $1,300. I have been very pleased and impressed with my TT Gemini EFIS and I feel co mfortable using that as my sole navigation device in an emergency. For $15K I can install 3 TT Gemini back up units each with its own back up battery, buy two Dynon D1 pocket EFIS, buy 3 iPads and an iPad mini plus a years wo rth of AV gas. My point is there are some quality backup devices that will provide full 6 pack info in a small footprint that are eminently affordable. Retrofitting for a TT Gemini or the like is a pretty simple task and gives great peace o f mind should primary instruments start going dark on you. Robin " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 02, 2013
Pascal, they came out very nice, you could marketing them and sell to get your R&D back ;) On 01.04.2013 22:16, Pascal wrote: > its all the same foam. Youre paying for the Name only. I know Oregon > Aero told me that needed to get their money back for their R&D on the > front seats and rear seats. I built my own rear seats and think I should > get $50 for my R&D. ________________________________________________________________________________
Date: Apr 02, 2013
Hi Robin, - The standby EFIS you are referring to is the Mid-Continent-MD 302, $9475 at Spruce.- The unit Dave is quoting is the L3 Trilogy which is approx $1 3k if I remember correctly.- A third alternative would be the Aspen stand by unit announced at the end of last year. - Best wishes, - Rodger --- On Tue, 2/4/13, Robin Marks wrote: From: Robin Marks <robin(at)PaintTheWeb.com> Subject: Re: RV10-List: EFIS failure checklist Date: Tuesday, 2 April, 2013, 6:36 I don't think so. http://utubeclassic.com/watch.php?v=j4IE9DMpj0U I am having a difficult time sourcing the company page or the original vide o. Above is a 3rd party video. Sent from the new iPad On Mar 31, 2013, at 12:27 PM, "Dave Saylor" <dave.saylor.aircrafters@gmail. com> wrote: Is that the L3 unit? -I remember seeing the price and thinking oh brother . -I'd rather install a vacuum system, and buy the 3 indicators that are gonna to fail over a couple thousand hours. Dave Saylor 831-750-0284 CL On Sun, Mar 31, 2013 at 8:48 AM, Robin Marks wrote: This discussion has been beneficial and reconfirms my feeling that in an em ergency when everything appears as if you are looking through a straw and y our head fills with conflicting decision paths that the safest bet is on a 100% independent back up system on its own battery (if needed). I was thrilled to see a new back up EFIS advertised in one of the aviation magazines I receive. Its a sweet little unit that appears to be well design ed. After reading of its capabilities and watching the company video I was impressed with the SAM back up EFIS. I had to dig a little deeper to find t he unit pricing. $10,800.00. Bahhhahahha Those poor bastards in the certified world will probably have $15K once ins talled by a certified mechanic. The SAM is a unit that is comparable to the TT Gemini EFIS I have in my 8A for $1,300. I have been very pleased and impressed with my TT Gemini EFIS and I feel co mfortable using that as my sole navigation device in an emergency. For $15K I can install 3 TT Gemini back up units each with its own back up battery, buy two Dynon D1 pocket EFIS, buy 3 iPads and an iPad mini plus a years wo rth of AV gas. My point is there are some quality backup devices that will provide full 6 pack info in a small footprint that are eminently affordable. Retrofitting for a TT Gemini or the like is a pretty simple task and gives great peace o f mind should primary instruments start going dark on you. Robin " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - - - - - --Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution p://www.matronics.com/Navigator?RV10-List ics.com .matronics.com/contribution ________________________________________________________________________________
Subject: Oil level
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Apr 02, 2013
How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) ________________________________________________________________________________
Subject: Oil level
Date: Apr 02, 2013
Michael, I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Tuesday, April 02, 2013 12:35 PM Subject: RV10-List: Oil level --> How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 02, 2013
Subject: Re: Oil level
I like it at 9, top it off when it gets to 8. I put a couple extra marks on the dipstick at 7 and 8. On Tuesday, April 2, 2013, Michael Kraus wrote: > > > > How many quarts of oil do you all typically run in your RV-10? Anything > over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > -- Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Apr 02, 2013
I discovered that anything above 7qts would "disappear". I have a can that holds the blowby so I can see how much oil is blown and it sure isn't much. I have been running mine at 6.5-6.0qt before adding another qt. The advice my engine builder gave me was let the oil go until it stops. Some io-540 can run at 6, some at 8 or 9qts. In other words the oil stopped going down at around 6qts. I can go about 5 hours or so before I see any drop, but if I take it to 8qts the oil goes down within 2-3 hours to 7qts, than slowly to 6 where it seems to hold without loss.. -----Original Message----- From: Robin Marks Sent: Tuesday, April 02, 2013 1:22 PM Subject: RE: RV10-List: Oil level Michael, I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Tuesday, April 02, 2013 12:35 PM Subject: RV10-List: Oil level --> How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Oil level
Date: Apr 02, 2013
I have been starting at 9 and letting it go to 8 where is stabilizes. Anything above 9 and in a couple of hours it will be at 9.... YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Tuesday, April 02, 2013 2:58 PM Subject: Re: RV10-List: Oil level I discovered that anything above 7qts would "disappear". I have a can that holds the blowby so I can see how much oil is blown and it sure isn't much. I have been running mine at 6.5-6.0qt before adding another qt. The advice my engine builder gave me was let the oil go until it stops. Some io-540 can run at 6, some at 8 or 9qts. In other words the oil stopped going down at around 6qts. I can go about 5 hours or so before I see any drop, but if I take it to 8qts the oil goes down within 2-3 hours to 7qts, than slowly to 6 where it seems to hold without loss.. -----Original Message----- From: Robin Marks Sent: Tuesday, April 02, 2013 1:22 PM Subject: RE: RV10-List: Oil level Michael, I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus Sent: Tuesday, April 02, 2013 12:35 PM Subject: RV10-List: Oil level --> How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. -Mike Kraus RV-4 sold :-( RV-10 flying :-) KitFox SS7 Radial building :-) ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Apr 02, 2013
For the first 200+ hours, I was putting in 10 quarts At 260 hours, I put in 7 which registers at 6. Why? I've been attempting to get my oil temperature up to at least 150F. Bill "changing it again as we speak" Watson On 4/2/2013 3:35 PM, Michael Kraus wrote: > > How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > ________________________________________________________________________________
Date: Apr 03, 2013
Robin, Do you have an oil separator in the breather line, with the new 1" line or previously with the 3/4"? Gordon On Apr 2, 2013, at 10:22 PM, Robin Marks wrote: > > Michael, > I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV. > > Robin > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Kraus > Sent: Tuesday, April 02, 2013 12:35 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oil level > > --> > > How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Subject: Oil level
Date: Apr 03, 2013
I had the Andair Air/Oil with the 3/4" line in the prior cowl set up. That is probably why we used 3/4". The new set up has no Air/Oil unit. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Gordon Anderson Sent: Tuesday, April 02, 2013 10:37 PM Subject: Re: RV10-List: Oil level Robin, Do you have an oil separator in the breather line, with the new 1" line or previously with the 3/4"? Gordon On Apr 2, 2013, at 10:22 PM, Robin Marks wrote: > > Michael, > I usually put a bit in the oil filter then 7 quarts in the case. I then add another quart 20+ hours in. On my old cowl the breather tube was undersized at 3/4" which I now realize was a problem. With 7 Quarts I didn't have any blow by on the belly but if I put 8 quarts in it coated the belly. When we replaced the cowl we also replaced the 3/4" breather with a 1" breather tube. At the same time they did an oil change and put in 11 Quarts. Holly S*** 11 Quarts. I know I would be degreasing for the next 10 flight hours. That didn't happen. My belly is bone dry after 2 - 3+ hour flights and another 10 - 1 hour flights. Big surprise to me. I will still probably stay with 8 quarts for me on a go forward basis. YMMV. > > Robin > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael > Kraus > Sent: Tuesday, April 02, 2013 12:35 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Oil level > > --> > > How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: First Flight
Date: Apr 03, 2013
After almost 9 years with a slow build with a few years sabatical in there I got N516NA airborne on 3/30/13. The plane flew very well with no problems. Flew for about 45 minutes with two takeoffs and landings at different airp orts. Although its airworthy its is still not "finished" Thanks to everyone on this list for the help over the years and specially to David Maib for the transition training. You can see the takeoff and landing from my home airport 58M at the link bel ow. https://www.dropbox.com/sh/hrkii7sgzw7x77w/hPy-wHKaBe Good luck to everyone yet to reach this stage and hope to meet some of my fe llow RV10 fliers at flying events. Niko Nikolaos Napoli ________________________________________________________________________________
Date: Apr 03, 2013
I have tried numerous levels, but come to the conclusion that anything over 9 is just a waste of money. The biggest changes I observed with consumption was going from the aeroshell 15/50 to Phillips XC 20/50. I used to burn a quart every 8 hours with the aero, now I have gone 10 hours with the Phillips product and I am only down 1/4qt after 10 hours. My engine has 110 hrs. I intend to not add oil until the 7 qt level. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397723#397723 ________________________________________________________________________________
Date: Apr 03, 2013
9. Dave Leikam On Apr 2, 2013, at 2:35 PM, Michael Kraus wrote: > > How many quarts of oil do you all typically run in your RV-10? Anything over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Re: First Flight
Sweet! Congratulations! Bill Watson N215TG On 4/3/2013 7:35 AM, Nikolaos Napoli wrote: > After almost 9 years with a slow build with a few years sabatical in > there I got N516NA airborne on 3/30/13. The plane flew very well with > no problems. Flew for about 45 minutes with two takeoffs and landings > at different airports. > > > Although its airworthy its is still not "finished" > > Thanks to everyone on this list for the help over the years and > specially to David Maib for the transition training. > > You can see the takeoff and landing from my home airport 58M at the > link below. > > https://www.dropbox.com/sh/hrkii7sgzw7x77w/hPy-wHKaBe > > Good luck to everyone yet to reach this stage and hope to meet some of > my fellow RV10 fliers at flying events. > > Niko > > Nikolaos Napoli > Date: 04/02/13 ________________________________________________________________________________
Date: Apr 03, 2013
Way to go Niko! Nice to see other multi-year builders finishing up. Chris Lucas N919AR From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nikolaos Napoli Sent: Wednesday, April 03, 2013 7:35 AM Subject: RV10-List: First Flight After almost 9 years with a slow build with a few years sabatical in there I got N516NA airborne on 3/30/13. The plane flew very well with no problems. Flew for about 45 minutes with two takeoffs and landings at different airports. Although its airworthy its is still not "finished" Thanks to everyone on this list for the help over the years and specially to David Maib for the transition training. You can see the takeoff and landing from my home airport 58M at the link below. https://www.dropbox.com/sh/hrkii7sgzw7x77w/hPy-wHKaBe Good luck to everyone yet to reach this stage and hope to meet some of my fellow RV10 fliers at flying events. Niko Nikolaos Napoli ________________________________________________________________________________
Date: Apr 03, 2013
Congratulations! I remember the experience well! -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397729#397729 ________________________________________________________________________________
Date: Apr 03, 2013
Fantastic Niko! I am happy to see you flying that airplane! Have fun and call if you have any more questions. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397730#397730 ________________________________________________________________________________
Date: Apr 03, 2013
I never put in more that 7.5, and add when it gets to 6.5.... in the winter run closer to the 6.5. summer closer to the 7.5. Don Mc --- On Wed, 4/3/13, David Leikam wrote: From: David Leikam <arplnplt(at)gmail.com> Subject: Re: RV10-List: Oil level Date: Wednesday, April 3, 2013, 7:19 AM 9. Dave Leikam On Apr 2, 2013, at 2:35 PM, Michael Kraus wrote: t> > > How many quarts of oil do you all typically run in your RV-10?- Anythin g over 10 quarts for me typically blows out. > > -Mike Kraus > RV-4 sold :-( > RV-10 flying :-) > KitFox SS7 Radial building :-) > > > > le, List Admin. ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: ADSB antenna
Date: Apr 03, 2013
I now have a few hours flying with the integrated Dynon SkyView ADSB receiver and can report it works as advertised. For those looking for an ADSB antenna, this is what I'm using: http://deltapopaviation.com/Delta_Pop_Aviation/ADS-B_Antenna.html Carl ________________________________________________________________________________
Date: Apr 03, 2013
Subject: Re: ADSB antenna
Carl, Do you have any installation pictures? Where did you install it? Did you use a doubler? Ralph Already have the same antenna - just trying to figure out where / how to install. -----Original Message----- From: Carl Froehlich Sent: Apr 3, 2013 9:36 AM Subject: RV10-List: ADSB antenna I now have a few hours flying with the integrated Dynon SkyView ADSB receiver and can report it works as advertised. For those looking for an ADSB antenna, this is what Im using: http://deltapopaviation.com/Delta_Pop_Aviation/ADS-B_Antenna.html Carl ________________________________________________________________________________
Date: Apr 03, 2013
Congrats!! On Wed, Apr 3, 2013 at 7:48 AM, Chris wrote: > Way to go Niko! **** > > Nice to see other multi-year builders finishing up.**** > > Chris Lucas**** > > N919AR**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Nikolaos Napoli > *Sent:* Wednesday, April 03, 2013 7:35 AM > *To:* Matronics > *Subject:* RV10-List: First Flight**** > > ** ** > > After almost 9 years with a slow build with a few years sabatical in there > I got N516NA airborne on 3/30/13. The plane flew very well with no > problems. Flew for about 45 minutes with two takeoffs and landings at > different airports.**** > > ** ** > > ** ** > > Although its airworthy its is still not "finished"**** > > ** ** > > Thanks to everyone on this list for the help over the years and specially > to David Maib for the transition training. **** > > ** ** > > You can see the takeoff and landing from my home airport 58M at the link > below.**** > > ** ** > > https://www.dropbox.com/sh/hrkii7sgzw7x77w/hPy-wHKaBe > > Good luck to everyone yet to reach this stage and hope to meet some of my > fellow RV10 fliers at flying events.**** > > > Niko**** > > > Nikolaos Napoli**** > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > * > > ________________________________________________________________________________
Date: Apr 04, 2013
Congratulations. Great accomplishment. Don't forget to post on Van's. Fly safe and have fun. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397853#397853 ________________________________________________________________________________
Date: Apr 04, 2013
Congrats Niko! Looking forward to mine as well. Mike -------- RV-10 builder (interior & finishing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397864#397864 ________________________________________________________________________________
Subject: PP ZOT 04/04 2013
Date: Apr 05, 2013
Hello Guys, My new toy flew yesterday, almost 4 years after start. Beautiful plane!! Thank you Geoff Combs (Aerosportproducts) Rgds. Beto. ________________________________________________________________________________
Subject: Re: PP ZOT 04/04 2013
Date: Apr 05, 2013
Congratulations on your flight. You have a gorgeous looking RV-10! -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=397895#397895 ________________________________________________________________________________
Date: Apr 05, 2013
Roberto Congrats. The plane looks awesome. Love the paint scheme. Enjoy the ride. The RV-10 is a great airplane Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roberto Brito Sent: Friday, April 05, 2013 8:01 AM Subject: RV10-List: PP ZOT 04/04 2013 Hello Guys, My new toy flew yesterday, almost 4 years after start. Beautiful plane!! Thank you Geoff Combs (Aerosportproducts) Rgds. Beto. ________________________________________________________________________________
Date: Apr 05, 2013
Agreed! Well done Roberto! Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs Sent: Friday, April 05, 2013 9:08 AM Subject: RE: RV10-List: PP ZOT 04/04 2013 --> Roberto Congrats. The plane looks awesome. Love the paint scheme. Enjoy the ride. The RV-10 is a great airplane Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Roberto Brito Sent: Friday, April 05, 2013 8:01 AM Subject: RV10-List: PP ZOT 04/04 2013 Hello Guys, My new toy flew yesterday, almost 4 years after start. Beautiful plane!! Thank you Geoff Combs (Aerosportproducts) Rgds. Beto. ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
March 18, 2013 - April 05, 2013
RV10-Archive.digest.vol-jh
