RV10-Archive.digest.vol-jk
May 23, 2013 - July 07, 2013
      >> Not to hijack the thread or change focus, but here's another point to
      >> consider. Timing specifics notwithstanding, our engines were tested
      >> rigorously and certificated using two synchronized sparks. (Yes, I
      >> understand that many of us are not operating in as-certificated
      >> configuration, but isn't that the basis of our safety and performance
      >> expectations?). Certification includes prop combinations and
      >> vibration analysis for structural integrity.
      >     To be fair, the only ignition system available at the time of
      > certification was the mag.  I highly doubt any new engine being
      > certificated today would use mags.
      >     Your point about prop combinations and vibration analysis is well
      > taken, however.
      > -Dj
      Checked by AVG - www.avg.com
Date: May 23, 2013
Subject: Re: Electronic Ignition
On 5/23/2013 9:03 PM, Kelly McMullen wrote: > Advanced timing does not increase the burn time. That is correct, and not what I was trying to say. Because the spark happens earlier in the cycle compared to the mag, the fuel has more time to burn before the piston hits maximum compression with the EI than it does with the mag. This is one reason why it doesn't really matter that only the one spark plug of the EI is firing versus the two simultaneous mag plugs firing. -Dj -- Dj Merrill - N1JOV - VP EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Date: May 23, 2013
Just thinking out loud ..... I wonder if the increase in burn time is significant since while the EI ignition occurs earlier the fuel is not compressed as much and the flame front is actually slower at that ignition point. The increased compression may cause secondary ignition by the mag ...... Just thinking .... Linn On 5/23/2013 9:13 PM, Dj Merrill wrote: > > On 5/23/2013 9:03 PM, Kelly McMullen wrote: >> Advanced timing does not increase the burn time. > > That is correct, and not what I was trying to say. > > Because the spark happens earlier in the cycle compared to the > mag, the fuel has more time to burn before the piston hits maximum > compression with the EI than it does with the mag. This is one reason > why it doesn't really matter that only the one spark plug of the EI is > firing versus the two simultaneous mag plugs firing. > > -Dj > ________________________________________________________________________________
Subject: Static system
Date: May 25, 2013
Has anyone come up with a good way to attach the 1/8 tubing to the rivet Van's recommends for a static port? The Van's suggestion of using RTV sealant does not seem to be secure enough. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401367#401367 ________________________________________________________________________________
Subject: Re: Static system
Date: May 26, 2013
Many people seem to be happy with the Vans solution. Another option is offered by Cleaveland Tool(and others). The Cleaveland solution appears to have the same profile as the Vans rivet. Static port design seems to stimulate discussion on the scale of the Primer Wars, you might like to search for other posts on the subject. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401372#401372 ________________________________________________________________________________
Date: May 26, 2013
Well, given that airframe, engine and avionics/panel average out to near equal thirds, depending on how much priority you put in each, most figure on spending around $150K or more on a -10, and you are going to rely on a couple pop rivets for everything that depends on static system? Really goes to Van's viewpoint that all their products are for day VFR leisure trips, only. That may start some discussion. ;-) On Sun, May 26, 2013 at 1:31 AM, mdaniell wrote: > > Many people seem to be happy with the Vans solution. Another option is > offered by Cleaveland Tool(and others). The Cleaveland solution appears to > have the same profile as the Vans rivet. Static port design seems to > stimulate discussion on the scale of the Primer Wars, you might like to > search for other posts on the subject. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401372#401372 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: May 26, 2013
Couldn't agree more Kelly. I used the ones sold by Avery tool, I believe they are actually safe-air1. My air speeds are within a knot of being spot on. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401378#401378 Attachments: http://forums.matronics.com//files/static_ports_01_902.jpg ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: May 26, 2013
But - a simple design that works is hard to beat. I solved a static error on my first plane created by "very nicely machined commercial static ports" and used the same approach on the RV-10. No static error. Below is what I posted on this awhile back. Carl I used a couple of 3/16" AN470 rivets with a 1/16" hole drilled through the head and the rivet shank. I made a 1" diameter x 1/4" thick aluminum ring (disc with a 3/16" hole drill in the center) as a backing plate to the rivet. The round rivet head sits on the outside of the skin (3/16" hole in the skin). The 1" diameter, 1/4" thick backing plate (with a 3/16" hole in the middle) is epoxied over the rivet shank to the inside of the skin. The protruding rivet head moves the static port just a little out of the skin flow layer - this is what helps mitigate against static port error. The backing plate just adds some rigidity to the install and more glue area for the rivet. This provides a sturdy connection to RTV on the 1/4" static tubing. The 3/16" rivet shack is a perfect fit for 1/4" tubing to slide over. No fittings required or desired. Get a dozen or so of the rivets as it takes a couple of tries to get the hole drill right in the center of the shank. You want a rivet shank an inch or so long. I did final paint over the rivet heads with a toothpick in the 1/16" holes to keep them open. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Sunday, May 26, 2013 8:55 AM Subject: Re: RV10-List: Re: Static system Well, given that airframe, engine and avionics/panel average out to near equal thirds, depending on how much priority you put in each, most figure on spending around $150K or more on a -10, and you are going to rely on a couple pop rivets for everything that depends on static system? Really goes to Van's viewpoint that all their products are for day VFR leisure trips, only. That may start some discussion. ;-) On Sun, May 26, 2013 at 1:31 AM, mdaniell wrote: Many people seem to be happy with the Vans solution. Another option is offered by Cleaveland Tool(and others). The Cleaveland solution appears to have the same profile as the Vans rivet. Static port design seems to stimulate discussion on the scale of the Primer Wars, you might like to search for other posts on the subject. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401372#401372 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: ADS-B
Date: May 26, 2013
Looking at installing ADS-B. What are most people going with? one inexpensive option is upgrading my garmin gtx330 transponder to ES and receiving traffic on fore flight through stratus2(which i already had because i wanted to get rid of xm weather fees) Has anyone done the 330 upgrade? My concern with the 330 upgrade to 1090ES is unless i'm near a ground station I won't get air to air from UAT ADS-B planes. Why the FAA had to go with 2 bands sure makes this more complicated than it should. Alan ________________________________________________________________________________
Subject: ADS-B
Date: May 26, 2013
--- MIME Errors - No Plain-Text Section Found --- A message with no text/plain MIME section was received. The entire body of the message was removed. Please resend the email using Plain Text formatting. HOTMAIL is notorious for only including an HTML section in their client's default configuration. If you're using HOTMAIL, please see your email application's settings and switch to a default mail option that uses "Plain Text". --- MIME Errors No Plain-Text Section Found --- ________________________________________________________________________________
Date: May 26, 2013
Subject: Spinner Size
I'm about to order my prop. Is there any reason to go with anything other than stock 13" with the stock cowling? -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Re: Spinner Size
Date: May 26, 2013
Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl a nd have been very pleased. Perfect temps all the way around plus an inducti on system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. In general plans built is best but I have yet to see a downside to the SP c owl. Very well designed, and produced. Robin Kelly McMullen wrote: I'm about to order my prop. Is there any reason to go with anything other t han stock 13" with the stock cowling? -- - sent from the microchip implanted in my forearm ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: May 26, 2013
Here is a source for the polished aluminum 14" Hartzell spinner, at a much reduced price, if you decide to do the James Cowl: Chris Tieman Mustang Aeronautics, Inc. 1470 Temple City Troy, MI 48084 (248) 649-6818 www.MustangAero.com Chris Tieman [Chris(at)MustangAero.com] Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Sunday, May 26, 2013 5:45 PM Subject: Re: RV10-List: Spinner Size Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. Robin Kelly McMullen wrote: I'm about to order my prop. Is there any reason to go with anything other than stock 13" with the stock cowling? -- - sent from the microchip implanted in my forearm p://www.matronics.com/Navigator?RV10-List ics.com .matronics.com/contribution _____ No virus found in this message. Checked by AVG - www.avg.com r> ________________________________________________________________________________
Date: May 27, 2013
I have one of those 14" plus another sitting on the shelf if interested. Robin Carl Froehlich wrote: Here is a source for the polished aluminum 14" Hartzell spinner, at a much reduced price, if you decide to do the James Cowl: Chris Tieman Mustang Aeronautics, Inc. 1470 Temple City Troy, MI 48084 (248) 649-6818 www.MustangAero.com<http://www.MustangAero.com> Chris Tieman [Chris(at)MustangAero.com] Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Robin Marks Sent: Sunday, May 26, 2013 5:45 PM Subject: Re: RV10-List: Spinner Size Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl a nd have been very pleased. Perfect temps all the way around plus an inducti on system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. In general plans built is best but I have yet to see a downside to the SP c owl. Very well designed, and produced. Robin Kelly McMullen > wrote: I'm about to order my prop. Is there any reason to go with anything other t han stock 13" with the stock cowling? -- - sent from the microchip implanted in my forearm p://www.matronics.com/Navigator?RV10-List ics.com .matronics.com/contribution ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> r> &nbs====================http://www. matronic================ http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c= ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: May 26, 2013
Since I have been stuck at the 90/90 level for awhile, I am NOT looking to do any more mods/expense, even though the Showplanes cowling looks very nice. So 13" it will be on stock cowl. On 5/26/2013 7:38 PM, Robin Marks wrote: > I have one of those 14" plus another sitting on the shelf if interested. > > Robin > > Carl Froehlich wrote: > > Here is a source for the polished aluminum 14" Hartzell spinner, at a > much reduced price, if you decide to do the James Cowl: > > Chris Tieman > > Mustang Aeronautics, Inc. > > 1470 Temple City > > Troy, MI 48084 > > (248) 649-6818 > > www.MustangAero.com <http://www.MustangAero.com> > > Chris Tieman [Chris(at)MustangAero.com] > > Carl > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Robin Marks > *Sent:* Sunday, May 26, 2013 5:45 PM > *To:* rv10-list@matronics com > *Subject:* Re: RV10-List: Spinner Size > > Ha! Probably the best choice is stock. I had a James Cowl disaster that is well documented. I switched over to the first production Showplanes cowl and have been very pleased. Perfect temps all the way around plus an induction system that is well designed and executed. The finish on the SP cowl is superior to any Vans fiberglass. But you will need a 15" spinner which is pricy. > In general plans built is best but I have yet to see a downside to the SP cowl. Very well designed, and produced. > > Robin > > Kelly McMullen > wrote: > > > I'm about to order my prop. Is there any reason to go with anything > other than stock 13" with the stock cowling? > > > -- > > - sent from the microchip implanted in my forearm > > * * > * * > *p://www.matronics.com/Navigator?RV10-List* > *ics.com* > *.matronics.com/contribution* > * * > ------------------------------------------------------------------------ > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > r> > > * * > *&nbs====================http://www.matronic=================* > http://forums.matronics.com - List Contribution Web generous > nbsp; --> http://www.matronics.com/c > * * > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > >http://www.matronics.com/Navigator?RV10-List* * > ics.com > .matronics.com/contribution > > * > ------------------------------------------------------------------------ > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > r> > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: how can I find out the gear reduction for the governor drive
Date: May 27, 2013
I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one. Thanks Mike -------- RV-10 builder (final assembly) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401444#401444 ________________________________________________________________________________
Date: May 27, 2013
Subject: Re: how can I find out the gear reduction for the governor
drive The only thing that determines what gear reduction you need is whether you have a narrow deck version or a wide deck. Which one you have depends on the core used to build the engine, not who assembled it. You can easily tell by the cylinder hold down bolts. Narrow deck have hollow allen key bolts. Wide deck has conventional hex nuts on studs. The governor Van's sells has reduction for narrow deck. (despite the fact that all new engines Vans sells are wide deck). While adjustments can be made to make the Vans governor work on a wide deck, it still won't be correct. Jim Ayers has often posted here the correct information. A wide deck engine is supposed to get a P-860-5 MT governor. More detail on the differences at http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ On 5/27/2013 3:51 PM, Mike Whisky wrote: > > I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one. > Thanks > Mike > > -------- > RV-10 builder (final assembly) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401444#401444 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
drive
Date: May 28, 2013
All TMX engines should be wide deck. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 27, 2013, at 7:59 PM, Kelly McMullen wrote: > > The only thing that determines what gear reduction you need is whether you have a narrow deck version or a wide deck. Which one you have depends on the core used to build the engine, not who assembled it. > You can easily tell by the cylinder hold down bolts. Narrow deck have hollow allen key bolts. Wide deck has conventional hex nuts on studs. > The governor Van's sells has reduction for narrow deck. (despite the fact that all new engines Vans sells are wide deck). While adjustments can be made to make the Vans governor work on a wide deck, it still won't be correct. Jim Ayers has often posted here the correct information. A wide deck engine is supposed to get a P-860-5 MT governor. > More detail on the differences at http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ > On 5/27/2013 3:51 PM, Mike Whisky wrote: >> >> I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one. >> Thanks >> Mike >> >> -------- >> RV-10 builder (final assembly) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401444#401444 >> >> >> >> >> >> >> >> >> >> > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: May 28, 2013
drive
Assuming that they are built from new parts kits or WD cores. It didn't occur to me that anyone would still have an engine built from new parts kit, since Lyc priced those out of the market about 18 months ago. As has been noted before, if one has a wide deck engine, then the MT P-860-5 governor is the correct unit of that brand. It is unfortunate that Van's still only supplies the narrow deck P-860-3 governor, when they have never sold a new narrow deck engine. (Lyc stopped making narrow deck more than 10 yrs before Van founded his company). On Tue, May 28, 2013 at 6:06 AM, Jesse Saint wrote: > > All TMX engines should be wide deck. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On May 27, 2013, at 7:59 PM, Kelly McMullen wrote: > > > > > The only thing that determines what gear reduction you need is whether > you have a narrow deck version or a wide deck. Which one you have depends > on the core used to build the engine, not who assembled it. > > You can easily tell by the cylinder hold down bolts. Narrow deck have > hollow allen key bolts. Wide deck has conventional hex nuts on studs. > > The governor Van's sells has reduction for narrow deck. (despite the > fact that all new engines Vans sells are wide deck). While adjustments can > be made to make the Vans governor work on a wide deck, it still won't be > correct. Jim Ayers has often posted here the correct information. A wide > deck engine is supposed to get a P-860-5 MT governor. > > More detail on the differences at > http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ > > On 5/27/2013 3:51 PM, Mike Whisky wrote: > >> > >> I own an TMXIO-540 and wonder what the governor reduction drive is, I > don`t have my engine documentation currently with me. Does anyone know who > has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT > governor is really the correct one. > >> Thanks > >> Mike > >> > >> -------- > >> RV-10 builder (final assembly) > >> #511 > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401444#401444 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > > > > > > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
drive
Date: May 28, 2013
Not sure if it has been brought up already but I have an MT -3 governor on a wide deck IO-540-N1A5 and it works fine with full RPM range. ----- Original Message ----- From: Kelly McMullen To: rv10-list(at)matronics.com Sent: Tuesday, May 28, 2013 8:19 AM Subject: Re: RV10-List: how can I find out the gear reduction for the governor drive Assuming that they are built from new parts kits or WD cores. It didn't occur to me that anyone would still have an engine built from new parts kit, since Lyc priced those out of the market about 18 months ago. As has been noted before, if one has a wide deck engine, then the MT P-860-5 governor is the correct unit of that brand. It is unfortunate that Van's still only supplies the narrow deck P-860-3 governor, when they have never sold a new narrow deck engine. (Lyc stopped making narrow deck more than 10 yrs before Van founded his company). On Tue, May 28, 2013 at 6:06 AM, Jesse Saint wrote: All TMX engines should be wide deck. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 27, 2013, at 7:59 PM, Kelly McMullen wrote: > > The only thing that determines what gear reduction you need is whether you have a narrow deck version or a wide deck. Which one you have depends on the core used to build the engine, not who assembled it. > You can easily tell by the cylinder hold down bolts. Narrow deck have hollow allen key bolts. Wide deck has conventional hex nuts on studs. > The governor Van's sells has reduction for narrow deck. (despite the fact that all new engines Vans sells are wide deck). While adjustments can be made to make the Vans governor work on a wide deck, it still won't be correct. Jim Ayers has often posted here the correct information. A wide deck engine is supposed to get a P-860-5 MT governor. > More detail on the differences at http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-d eck-engines/ > On 5/27/2013 3:51 PM, Mike Whisky wrote: >> >> I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one. >> Thanks >> Mike >> >> -------- >> RV-10 builder (final assembly) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401444#401444 >> >> >> >> >> >> >> >> >> >> > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: May 28, 2013
drive Whew!!! I'm really glad to hear that!!!! I just checked, and mine is a -3 also. I'm in the baffling baffling section and scratched mine all up. Don't think they'll trade now. My group flies to Deland (FL) for food (none where we live ;-) ) right next to the MT facility which we'll try and tour. I'll pose the question. Linn On 5/28/2013 10:43 AM, Seano wrote: > Not sure if it has been brought up already but I have an MT -3 > governor on a wide deck IO-540-N1A5 and it works fine with full RPM range. > > ----- Original Message ----- > *From:* Kelly McMullen > *To:* rv10-list(at)matronics.com > *Sent:* Tuesday, May 28, 2013 8:19 AM > *Subject:* Re: RV10-List: how can I find out the gear reduction > for the governor drive > > Assuming that they are built from new parts kits or WD cores. It > didn't occur to me that anyone would still have an engine built > from new parts kit, since Lyc priced those out of the market about > 18 months ago. As has been noted before, if one has a wide deck > engine, then the MT P-860-5 governor is the correct unit of that > brand. It is unfortunate that Van's still only supplies the narrow > deck P-860-3 governor, when they have never sold a new narrow deck > engine. (Lyc stopped making narrow deck more than 10 yrs before > Van founded his company). > > > On Tue, May 28, 2013 at 6:06 AM, Jesse Saint > > wrote: > > > > > All TMX engines should be wide deck. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On May 27, 2013, at 7:59 PM, Kelly McMullen > > wrote: > > > > > > > The only thing that determines what gear reduction you need > is whether you have a narrow deck version or a wide deck. > Which one you have depends on the core used to build the > engine, not who assembled it. > > You can easily tell by the cylinder hold down bolts. Narrow > deck have hollow allen key bolts. Wide deck has conventional > hex nuts on studs. > > The governor Van's sells has reduction for narrow deck. > (despite the fact that all new engines Vans sells are wide > deck). While adjustments can be made to make the Vans governor > work on a wide deck, it still won't be correct. Jim Ayers has > often posted here the correct information. A wide deck engine > is supposed to get a P-860-5 MT governor. > > More detail on the differences at > http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ > > On 5/27/2013 3:51 PM, Mike Whisky wrote: > > > >> > >> I own an TMXIO-540 and wonder what the governor reduction > drive is, I don`t have my engine documentation currently with > me. Does anyone know who has an TMX-io540 Red/Gold? I just > want to be sure that the P-860-3 MT governor is really the > correct one. > >> Thanks > >> Mike > >> > >> -------- > >> RV-10 builder (final assembly) > >> #511 > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401444#401444 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com> > > > > > > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > > - sent from the microchip implanted in my forearm > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
drive
Date: May 28, 2013
My -3 also has worked fine after some minor speed adjustments. I spoke to MT and it is acceptable. The -3 or -5 defines the settings relief valve pressure, max. RPM, control arm travel and position etc. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401477#401477 ________________________________________________________________________________
Date: May 28, 2013
drive
Kelly, if I read your post correctly, all of the new Lycoming engines sold by VANS of the IO-540 variant are now only Wide Deck and not Narrow Deck. Aren't each of the wide deck jugs heavier and too wide to fit the stock RV-10 fiberglass cowl design? Or is that just for the Angle Valve Heads versus Parallel Valve? John C. On Tue, May 28, 2013 at 7:19 AM, Kelly McMullen wrote: > Assuming that they are built from new parts kits or WD cores. It didn't > occur to me that anyone would still have an engine built from new parts > kit, since Lyc priced those out of the market about 18 months ago. As has > been noted before, if one has a wide deck engine, then the MT P-860-5 > governor is the correct unit of that brand. It is unfortunate that Van's > still only supplies the narrow deck P-860-3 governor, when they have never > sold a new narrow deck engine. (Lyc stopped making narrow deck more than 10 > yrs before Van founded his company). > > > On Tue, May 28, 2013 at 6:06 AM, Jesse Saint wrote: > >> >> All TMX engines should be wide deck. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> On May 27, 2013, at 7:59 PM, Kelly McMullen wrote: >> >> > >> > The only thing that determines what gear reduction you need is whether >> you have a narrow deck version or a wide deck. Which one you have depends >> on the core used to build the engine, not who assembled it. >> > You can easily tell by the cylinder hold down bolts. Narrow deck have >> hollow allen key bolts. Wide deck has conventional hex nuts on studs. >> > The governor Van's sells has reduction for narrow deck. (despite the >> fact that all new engines Vans sells are wide deck). While adjustments can >> be made to make the Vans governor work on a wide deck, it still won't be >> correct. Jim Ayers has often posted here the correct information. A wide >> deck engine is supposed to get a P-860-5 MT governor. >> > More detail on the differences at >> http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ >> > On 5/27/2013 3:51 PM, Mike Whisky wrote: >> >> >> >> I own an TMXIO-540 and wonder what the governor reduction drive is, I >> don`t have my engine documentation currently with me. Does anyone know who >> has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT >> governor is really the correct one. >> >> Thanks >> >> Mike >> >> >> >> -------- >> >> RV-10 builder (final assembly) >> >> #511 >> >> >> >> >> >> >> >> >> >> Read this topic online here: >> >> >> >> http://forums.matronics.com/viewtopic.php?p=401444#401444 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > >> > >> > >> > ----- >> > No virus found in this message. >> > Checked by AVG - www.avg.com >> > >> > >> > >> > >> > >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > -- > > - sent from the microchip implanted in my forearm > > * > > * > > ________________________________________________________________________________
drive
Date: May 28, 2013
John, That's just for the angle head cylinders. Both narrow deck and wide deck engines fit the RV-10 cowl. Allen -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Tuesday, May 28, 2013 9:48 AM Subject: Re: RV10-List: how can I find out the gear reduction for the governor drive Kelly, if I read your post correctly, all of the new Lycoming engines sold by VANS of the IO-540 variant are now only Wide Deck and not Narrow Deck. Aren't each of the wide deck jugs heavier and too wide to fit the stock RV-10 fiberglass cowl design? Or is that just for the Angle Valve Heads versus Parallel Valve? John C. On Tue, May 28, 2013 at 7:19 AM, Kelly McMullen wrote: Assuming that they are built from new parts kits or WD cores. It didn't occur to me that anyone would still have an engine built from new parts kit, since Lyc priced those out of the market about 18 months ago. As has been noted before, if one has a wide deck engine, then the MT P-860-5 governor is the correct unit of that brand. It is unfortunate that Van's still only supplies the narrow deck P-860-3 governor, when they have never sold a new narrow deck engine. (Lyc stopped making narrow deck more than 10 yrs before Van founded his company). On Tue, May 28, 2013 at 6:06 AM, Jesse Saint wrote: All TMX engines should be wide deck. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On May 27, 2013, at 7:59 PM, Kelly McMullen wrote: > > The only thing that determines what gear reduction you need is whether you have a narrow deck version or a wide deck. Which one you have depends on the core used to build the engine, not who assembled it. > You can easily tell by the cylinder hold down bolts. Narrow deck have hollow allen key bolts. Wide deck has conventional hex nuts on studs. > The governor Van's sells has reduction for narrow deck. (despite the fact that all new engines Vans sells are wide deck). While adjustments can be made to make the Vans governor work on a wide deck, it still won't be correct. Jim Ayers has often posted here the correct information. A wide deck engine is supposed to get a P-860-5 MT governor. > More detail on the differences at http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow- deck-engines/ > On 5/27/2013 3:51 PM, Mike Whisky wrote: >> >> I own an TMXIO-540 and wonder what the governor reduction drive is, I don`t have my engine documentation currently with me. Does anyone know who has an TMX-io540 Red/Gold? I just want to be sure that the P-860-3 MT governor is really the correct one. >> Thanks >> Mike >> >> -------- >> RV-10 builder (final assembly) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401444#401444 >> >> >> >> >> >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 28, 2013
drive I'm not Kelly .... nor do I play him on TV .... but there's a big misconception about WD/ND engines. There's a good treatise here: *http://tinyurl.com/qjk83xk Linn * On 5/28/2013 11:47 AM, John Cox wrote: > Kelly, if I read your post correctly, all of the new Lycoming engines > sold by VANS of the IO-540 variant are now only Wide Deck and not > Narrow Deck. Aren't each of the wide deck jugs heavier and too wide > to fit the stock RV-10 fiberglass cowl design? Or is that just for > the Angle Valve Heads versus Parallel Valve? > > John C. > > > On Tue, May 28, 2013 at 7:19 AM, Kelly McMullen > wrote: > > Assuming that they are built from new parts kits or WD cores. It > didn't occur to me that anyone would still have an engine built > from new parts kit, since Lyc priced those out of the market about > 18 months ago. As has been noted before, if one has a wide deck > engine, then the MT P-860-5 governor is the correct unit of that > brand. It is unfortunate that Van's still only supplies the narrow > deck P-860-3 governor, when they have never sold a new narrow deck > engine. (Lyc stopped making narrow deck more than 10 yrs before > Van founded his company). > > > On Tue, May 28, 2013 at 6:06 AM, Jesse Saint > > wrote: > > > > > All TMX engines should be wide deck. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On May 27, 2013, at 7:59 PM, Kelly McMullen > > wrote: > > > > > > > The only thing that determines what gear reduction you need > is whether you have a narrow deck version or a wide deck. > Which one you have depends on the core used to build the > engine, not who assembled it. > > You can easily tell by the cylinder hold down bolts. Narrow > deck have hollow allen key bolts. Wide deck has conventional > hex nuts on studs. > > The governor Van's sells has reduction for narrow deck. > (despite the fact that all new engines Vans sells are wide > deck). While adjustments can be made to make the Vans governor > work on a wide deck, it still won't be correct. Jim Ayers has > often posted here the correct information. A wide deck engine > is supposed to get a P-860-5 MT governor. > > More detail on the differences at > http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ > > On 5/27/2013 3:51 PM, Mike Whisky wrote: > > > >> > >> I own an TMXIO-540 and wonder what the governor reduction > drive is, I don`t have my engine documentation currently with > me. Does anyone know who has an TMX-io540 Red/Gold? I just > want to be sure that the P-860-3 MT governor is really the > correct one. > >> Thanks > >> Mike > >> > >> -------- > >> RV-10 builder (final assembly) > >> #511 > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401444#401444 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com> > > > > > > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > > - sent from the microchip implanted in my forearm > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: May 28, 2013
drive Yes, the -3 works with some adjustment. However, the -5 has the correct gear reduction and pressures to begin with, so given the opportunity to get the correct one rather than having to make adjustments, for the same money seems like one of the easier build decisions. On 5/28/2013 8:03 AM, rv10flyer wrote: > > My -3 also has worked fine after some minor speed adjustments. I spoke to MT and it is acceptable. > > The -3 or -5 defines the settings relief valve pressure, max. RPM, control arm travel and position etc. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 103 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401477#401477 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: May 28, 2013
drive It is more fun when the lovely Miss Rhonda shows John the errors in his thinking. ;-)) I don't think there is more than about 1/4" difference between wide and narrow deck engines. Narrow deck allegedly is about 4 lbs lighter, but the newest ND case is likely to be approaching 40 yrs old. Kelly On 5/28/2013 9:05 AM, BPA wrote: > > John, > > Thats just for the angle head cylinders. Both narrow deck and wide > deck engines fit the RV-10 cowl. > > Allen > > -----Original Message----- > *From:* owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *John Cox > *Sent:* Tuesday, May 28, 2013 9:48 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: how can I find out the gear reduction for > the governor drive > > Kelly, if I read your post correctly, all of the new Lycoming engines > sold by VANS of the IO-540 variant are now only Wide Deck and not > Narrow Deck. Aren't each of the wide deck jugs heavier and too wide to > fit the stock RV-10 fiberglass cowl design? Or is that just for the > Angle Valve Heads versus Parallel Valve? > > John C. > > On Tue, May 28, 2013 at 7:19 AM, Kelly McMullen > wrote: > > Assuming that they are built from new parts kits or WD cores. It > didn't occur to me that anyone would still have an engine built from > new parts kit, since Lyc priced those out of the market about 18 > months ago. As has been noted before, if one has a wide deck engine, > then the MT P-860-5 governor is the correct unit of that brand. It is > unfortunate that Van's still only supplies the narrow deck P-860-3 > governor, when they have never sold a new narrow deck engine. (Lyc > stopped making narrow deck more than 10 yrs before Van founded his > company). > > On Tue, May 28, 2013 at 6:06 AM, Jesse Saint > wrote: > > > > > All TMX engines should be wide deck. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On May 27, 2013, at 7:59 PM, Kelly McMullen > wrote: > > > > > > > The only thing that determines what gear reduction you need is > whether you have a narrow deck version or a wide deck. Which one you > have depends on the core used to build the engine, not who assembled it. > > You can easily tell by the cylinder hold down bolts. Narrow deck > have hollow allen key bolts. Wide deck has conventional hex nuts on studs. > > The governor Van's sells has reduction for narrow deck. (despite the > fact that all new engines Vans sells are wide deck). While adjustments > can be made to make the Vans governor work on a wide deck, it still > won't be correct. Jim Ayers has often posted here the correct > information. A wide deck engine is supposed to get a P-860-5 MT governor. > > More detail on the differences at > http://www.generalaviationnews.com/2009/10/ask-paul-wide-deck-vs-narrow-deck-engines/ > > On 5/27/2013 3:51 PM, Mike Whisky wrote: > > > >> > >> I own an TMXIO-540 and wonder what the governor reduction drive is, > I don`t have my engine documentation currently with me. Does anyone > know who has an TMX-io540 Red/Gold? I just want to be sure that the > P-860-3 MT governor is really the correct one. > >> Thanks > >> Mike > >> > >> -------- > >> RV-10 builder (final assembly) > >> #511 > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401444#401444 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com> > > > > > > > > > > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > -- > > - sent from the microchip implanted in my forearm > > * * > * * > *get="_blank">http://www.matronics.com/Navigator?RV10-List* > *tp://forums.matronics.com* > *_blank">http://www.matronics.com/contribution* > * * > > * * > * * > ** > ** > ** > ** > ** > ** > ** > *http://www.matronics.com/Navigator?RV10-List* > ** > ** > ** > ** > ** > *http://forums.matronics.com* > ** > ** > ** > ** > ** > *http://www.matronics.com/contribution* > ** > * * > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
driv
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: May 29, 2013
I understand you can make the MT governor sold by Van's work by changing the arm position and making a few adjustments as that is what we did. But can someone tell me what the operational impact is of having the incorrect one installed? Slower reaction, incorrect pitch for a given power, pitch changes too quickly, etc.? Just because it works doesn't mean it is right, just trying to understand what trade off is being made. -Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401517#401517 ________________________________________________________________________________
Subject: Hartzell Governor with C2YR Prop
Date: May 29, 2013
> > Does anyone FLYING have the Hartzell Governor - Vans number: PROP GOV HZ IO-540? If so, any issues? Set up, oil leaks, RPM hunting, or just any performance or regrets for not getting the MT or some other governor? Having trouble understanding why if we bought a Hartzell Prop from Vans that we would not use a Hartzell Governor. In the FWF kit they automatically ship the MT: P-860-3. I called MT and they said it would work just fine and they would be happy to walk me through the set up procedures if needed. So I would appreciate some active feedback from some FLYING 10's with this Hartzell Governor. I believe in my 6 that we used a Woodward (sp?) Governor. Over 1000 hours and many years, absolutely no problems. Thanks much, Rich Hansen RV-6A sold 10-FWF > > ________________________________________________________________________________
Subject: Re: Hartzell Governor with C2YR Prop
Date: May 30, 2013
I have a Hartzell governor, but am a few weeks from flying. Sent from my iPad On May 30, 2013, at 2:04 AM, Karol Hansen wrote: > > >> >> Does anyone FLYING have the Hartzell Governor - Vans number: PROP GOV HZ IO-540? If so, any issues? Set up, oil leaks, RPM hunting, or just any performance or regrets for not getting the MT or some other governor? Having trouble understanding why if we bought a Hartzell Prop from Vans that we would not use a Hartzell Governor. In the FWF kit they automatically ship the MT: P-860-3. I called MT and they said it would work just fine and they would be happy to walk me through the set up procedures if needed. So I would appreciate some active feedback from some FLYING 10's with this Hartzell Governor. I believe in my 6 that we used a Woodward (sp?) Governor. Over 1000 hours and many years, absolutely no problems. > Thanks much, > > Rich Hansen > RV-6A sold > 10-FWF > > > > > > ________________________________________________________________________________
Date: May 30, 2013
"a few weeks from flying" that sounds promising. :) Enjoy Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Thursday, May 30, 2013 3:49 AM Subject: Re: RV10-List: Hartzell Governor with C2YR Prop I have a Hartzell governor, but am a few weeks from flying. Sent from my iPad On May 30, 2013, at 2:04 AM, Karol Hansen wrote: > --> > > >> >> Does anyone FLYING have the Hartzell Governor - Vans number: PROP GOV HZ IO-540? If so, any issues? Set up, oil leaks, RPM hunting, or just any performance or regrets for not getting the MT or some other governor? Having trouble understanding why if we bought a Hartzell Prop from Vans that we would not use a Hartzell Governor. In the FWF kit they automatically ship the MT: P-860-3. I called MT and they said it would work just fine and they would be happy to walk me through the set up procedures if needed. So I would appreciate some active feedback from some FLYING 10's with this Hartzell Governor. I believe in my 6 that we used a Woodward (sp?) Governor. Over 1000 hours and many years, absolutely no problems. > Thanks much, > > Rich Hansen > RV-6A sold > 10-FWF > > > > > > ________________________________________________________________________________
Date: May 30, 2013
I have 120+ hours on stock Vans YIO-540, 2 blade Hartzell, and Hartzell governor from Vans. No problems. I asked Vans for this governor, as I recall I think it was the same price as the MT. You do NOT need a new arm. You do need to re-orient the arm, easily done. Hartzell gave instructions after an email request. Mine was set for 2650 rpm out of the box. I left it there. My hangar neighbor also has a -10 with the same Hartzell set up, a few fewer hours. No issues for him, either. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401593#401593 ________________________________________________________________________________
Date: May 30, 2013
Subject: Sound Proofing and Heat Shield
Any recommendations for sound proofing and firewall heat shield? Obviously many choices are available=8A Soundex, 3M, Super Sound Proof, Heat Shield Mat , etc. What is working well in RV10 land? It would be interesting to see how many people have selected to install sound proofing vs. going =B3au naturale=B2 . ---- Jonathan Beasley ________________________________________________________________________________
Date: May 30, 2013
Check out this discussion on vans air force. http://www.vansairforce.com/community/showthread.php?t=97778 Bill Greenley, RV-10 in progress From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jonathan Beasley Sent: Thursday, May 30, 2013 11:32 AM Subject: RV10-List: Sound Proofing and Heat Shield Any recommendations for sound proofing and firewall heat shield? Obviously many choices are available. Soundex, 3M, Super Sound Proof, Heat Shield Mat, etc. What is working well in RV10 land? It would be interesting to see how many people have selected to install sound proofing vs. going "au naturale". ---- Jonathan Beasley ________________________________________________________________________________
driv
Date: May 30, 2013
The -3 and -5 governors are identical, except for the final adjustments. For the -3 governor on the wide deck IO-540 engine, the high RPM stop screw has to be turned out quite a bit to get to 2700 RPM from the factory setti ng of about 2550 RPM. (For the narrow deck IO-540 engine, the initial stop setting on the -3 governor would be at about 2700 RPM.) The -3 governor on a wide deck IO-540 now has a longer travel to get to th e low RPM stop. The governor arm should have full travel from the high RPM stop to the low RPM stop. Perhaps someone already flying can say if they have full travel (stop to st op) available with Van's governor cable. Full governor arm travel is helpful to have for the mag check so it is poss ible to get the expected 450 RPM drop when the governor/propeller is cycled . Jim Ayers -----Original Message----- From: jkreidler <jason.kreidler(at)regalbeloit.com> Sent: Wed, May 29, 2013 8:52 am Subject: RV10-List: Re: how can I find out the gear reduction for the gover nor driv m> I understand you can make the MT governor sold by Van's work by changing th e arm position and making a few adjustments as that is what we did. But can some one tell me what the operational impact is of having the incorrect one installe d? Slower reaction, incorrect pitch for a given power, pitch changes too quick ly, etc.? Just because it works doesn't mean it is right, just trying to under stand what trade off is being made. -Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401517#401517 ________________________________________________________________________________
Subject: Re: Sound Proofing and Heat Shield
Date: May 30, 2013
I sprayed on a sound proofer. and heat shield. If I was doing it again. I would get a heat blanket for the firewall and keep the top of the line headsets, skip the sound proofing all together. Even with all the sound proofing I did I still have a plane that is so loud when cruising that I wonder what it would be like with out it, so I wear Lightspeed Zulu and it all goes away. As a reference when I knocked on the skin it had a noise that went away with the sound proofer so it does something, just not much up in the air. From: Jonathan Beasley Sent: Thursday, May 30, 2013 8:32 AM Subject: RV10-List: Sound Proofing and Heat Shield Any recommendations for sound proofing and firewall heat shield? Obviously many choices are available Soundex, 3M, Super Sound Proof, Heat Shield Mat, etc. What is working well in RV10 land? It would be interesting to see how many people have selected to install sound proofing vs. going =9Cau naturale=9D. ---- Jonathan Beasley ________________________________________________________________________________
Date: May 30, 2013
FiberFrax sandwiched between Stainless Steel. Pics start here: http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/D SC03158.html read about it: : http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Secv 41 Faux... On Thu, May 30, 2013 at 9:22 AM, Pascal wrote: > I sprayed on a sound proofer. and heat shield. If I was doing it again. > I would get a heat blanket for the firewall and keep the top of the line > headsets, skip the sound proofing all together. Even with all the sound > proofing I did I still have a plane that is so loud when cruising that I > wonder what it would be like with out it, so I wear Lightspeed Zulu and i t > all goes away. > As a reference when I knocked on the skin it had a noise that went away > with the sound proofer so it does something, just not much up in the air. > > > *From:* Jonathan Beasley > *Sent:* Thursday, May 30, 2013 8:32 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Sound Proofing and Heat Shield > > Any recommendations for sound proofing and firewall heat shield? > Obviously many choices are available=85 Soundex, 3M, Super Sound Proof, H eat > Shield Mat, etc. What is working well in RV10 land? It would be interesti ng > to see how many people have selected to install sound proofing vs. going =93 > *au naturale*=94. > > ---- > Jonathan Beasley > > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: First Engine Run :-))))))
Date: May 30, 2013
Yesterday I achieved a major milestone, first engine start. All went well and all systems work as expected. The video is cut a bit because watching a prop turn without any instruments isn't that exciting for the audience ;-) http://www.youtube.com/watch?v=DxwI5bNZ1Uk Cheers Mike -------- RV-10 builder (final assembly) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401618#401618 ________________________________________________________________________________
Subject: Re: First Engine Run :-))))))
Date: May 31, 2013
Congratulations! It looks like you are getting very close, even the paint is done. Have a fantastic and safe first flight. If the WX cooperates mine should be out of the paint shop next week. -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401654#401654 ________________________________________________________________________________
Subject: Floscan location and Matronics fuel line pulsation damper
Date: May 31, 2013
I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401718#401718 ________________________________________________________________________________
Subject: Re: Floscan location and Matronics fuel line pulsation damper
Date: May 31, 2013
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=99641917?KEYS=pulsation_damper?LISTNAME=RV10?HITNUMBER=1?SERIAL=1955173315?SHOWBUTTONS=YES Have mine in the tunnel. I had a low fuel pressure warning twice- it was 0ver 85F on a climb, otherwise never had any issue with it's accuracy. Many will tell you to move it to the firewall, Dynon, for one, tells the installers not to, and all I can think is that it would be even hotter there than in the tunnel. -----Original Message----- From: bob88 Sent: Friday, May 31, 2013 7:04 PM Subject: RV10-List: Floscan location and Matronics fuel line pulsation damper I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401718#401718 ________________________________________________________________________________
Date: May 31, 2013
I have Skyview Revision N Install manual. I see nothing in that manual saying the sensor should not go forward of the firewall. The EI Red Cube (current Dynon sensor) is installed on many certified aircraft. For Lycoming engines with Bendix fuel injection, the STC required location is between the mechanical pump and the fuel servo inlet, away from exhaust pipes. I have one in that location on my Mooney. The tunnel has known problems, more likely from the fact it is on the suction side of the mechanical pump than from heat. On 5/31/2013 7:58 PM, Pascal wrote: > > http://www.matronics.com/searching/getmsg_script.cgi?INDEX=99641917?KEYS=pulsation_damper?LISTNAME=RV10?HITNUMBER=1?SERIAL=1955173315?SHOWBUTTONS=YES > > > Have mine in the tunnel. I had a low fuel pressure warning twice- it > was 0ver 85F on a climb, otherwise never had any issue with it's > accuracy. > Many will tell you to move it to the firewall, Dynon, for one, tells > the installers not to, and all I can think is that it would be even > hotter there than in the tunnel. > > > -----Original Message----- From: bob88 > Sent: Friday, May 31, 2013 7:04 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Floscan location and Matronics fuel line pulsation > damper > > > I'm trying to decide whether to place the floscan in the tunnel > (standard location) vs engine compartment. Anyone have strong opinion? > What about experience with the Matronics pulsation damper which seems > like it would solve the problems the tunnel location has? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401718#401718 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 01, 2013
The beauty of putting the cube in the tunnel is that you get to remove & relocate it once you are flying. Talk about enjoyable! I did as the plans describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 GPH... sometimes. Other times it would read 4.3 GPH. Want another indication just flip on your boost pump and you get a whole different reading. No way for me to balance injectors w/o accurate fuel flow. I relocated FWF (I like Sean's install in archives) and all issues went away. I still get the occasional 0.4 GPH fluctuations but that is because I don't have the ideal length flow in/out of the cube. I only have read one pirep on the damper and it was No Joy. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Friday, May 31, 2013 7:04 PM Subject: RV10-List: Floscan location and Matronics fuel line pulsation damper I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401718#401718 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 01, 2013
I ditto Robins remarks. Why take the chance of having a problem and then have to move it. PIREP from everyone Having it FWF is positive. 400 hrs and Great results for myself. Soft mount it up front and be a happy. Geoff Sent from my iPhone On Jun 1, 2013, at 3:16 AM, Robin Marks wrote: > > The beauty of putting the cube in the tunnel is that you get to remove & relocate it once you are flying. Talk about enjoyable! I did as the plans describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 GPH... sometimes. Other times it would read 4.3 GPH. Want another indication just flip on your boost pump and you get a whole different reading. No way for me to balance injectors w/o accurate fuel flow. I relocated FWF (I like Sean's install in archives) and all issues went away. I still get the occasional 0.4 GPH fluctuations but that is because I don't have the ideal length flow in/out of the cube. > I only have read one pirep on the damper and it was No Joy. > Robin > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: Friday, May 31, 2013 7:04 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Floscan location and Matronics fuel line pulsation damper > > > I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401718#401718 > > > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > > ________________________________________________________________________________
Date: Jun 01, 2013
Thank you all and interesting read on the FiberFrax. From: Deems Davis <deemsdavis(at)cox.net> Date: Thursday, May 30, 2013 1:24 PM Subject: Re: RV10-List: Sound Proofing and Heat Shield FiberFrax sandwiched between Stainless Steel. Pics start here: http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/D S C03158.html read about it: : http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Secv 41 Faux... On Thu, May 30, 2013 at 9:22 AM, Pascal wrote: > I sprayed on a sound proofer. and heat shield. If I was doing it again. I > would get a heat blanket for the firewall and keep the top of the line > headsets, skip the sound proofing all together. Even with all the sound > proofing I did I still have a plane that is so loud when cruising that I > wonder what it would be like with out it, so I wear Lightspeed Zulu and i t all > goes away. > As a reference when I knocked on the skin it had a noise that went away w ith > the sound proofer so it does something, just not much up in the air. > > > From: Jonathan Beasley <mailto:jbeasley(at)nc.rr.com> > Sent: Thursday, May 30, 2013 8:32 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Sound Proofing and Heat Shield > > Any recommendations for sound proofing and firewall heat shield? Obviousl y > many choices are available=8A Soundex, 3M, Super Sound Proof, Heat Shield M at, > etc. What is working well in RV10 land? It would be interesting to see ho w > many people have selected to install sound proofing vs. going =B3au natural e=B2. > > ---- > Jonathan Beasley > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/N > avigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Jun 01, 2013
Definitely put it between the servo and spider. I talked directly with Flo-Scan about this and they said the worst place is between the the two fuel pumps. They said the best would be before the valve. (We can't do this obviously.) I installed mine just in front of the servo (or after as flow goes,) with a somewhat floating, flexible mount on the air box. I'm within a 1/2 gallon on every fill. Use flexible hose, do not make it rigid. Dave Leikam N89DA On Jun 1, 2013, at 9:22 AM, g.combs wrote: > > I ditto Robins remarks. Why take the chance of having a problem and then have to move it. PIREP from everyone > Having it FWF is positive. 400 hrs and > Great results for myself. Soft mount it up front and be a happy. > > Geoff > > > > Sent from my iPhone > > On Jun 1, 2013, at 3:16 AM, Robin Marks wrote: > >> >> The beauty of putting the cube in the tunnel is that you get to remove & relocate it once you are flying. Talk about enjoyable! I did as the plans describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 GPH... sometimes. Other times it would read 4.3 GPH. Want another indication just flip on your boost pump and you get a whole different reading. No way for me to balance injectors w/o accurate fuel flow. I relocated FWF (I like Sean's install in archives) and all issues went away. I still get the occasional 0.4 GPH fluctuations but that is because I don't have the ideal length flow in/out of the cube. >> I only have read one pirep on the damper and it was No Joy. >> Robin >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 >> Sent: Friday, May 31, 2013 7:04 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Floscan location and Matronics fuel line pulsation damper >> >> >> I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401718#401718 >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 01, 2013
I mounted my Dynon "red cube" in the tunnel. I knew some had issues with this location but it was the easy option. I do see some minor flow fluctuation when I turn on the boost pump. Overall operation however is fine and rock steady. My fuel used total is always within half a gallon when I fill up. At this point I have no reason to move it. If I had it to do over however I'd would likely put the cube between the throttle body and the spider like I did in the 8A. I did insulate the tunnel at the firewall and the tunnel floor, and I put a piece of insulation between the red cube and the tunnel mount. I don't have any tunnel heat issues. Carl 90 hours. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Friday, May 31, 2013 10:04 PM Subject: RV10-List: Floscan location and Matronics fuel line pulsation damper I'm trying to decide whether to place the floscan in the tunnel (standard location) vs engine compartment. Anyone have strong opinion? What about experience with the Matronics pulsation damper which seems like it would solve the problems the tunnel location has? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401718#401718 ________________________________________________________________________________
Subject: Can you fix a broken BNC connector on a COM antenna?
Date: Jun 01, 2013
Don't ask me I got there but I managed to shear off the guiding/locking pins of my com antenna connector. See pictures. Does anyone know if it can be fixed without buying a new antenna? -------- RV-10 builder (final assembly) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401758#401758 Attachments: http://forums.matronics.com//files/image_204.jpg http://forums.matronics.com//files/image_699.jpg ________________________________________________________________________________
Date: Jun 01, 2013
The flip side is Dynon does tell one (pg7-41) "It is common to place the sender downstream of any auxiliary electric boost pumps but upstream of the engine driven fuel pump." as does Vans. I think they need to consult Floscan on getting that perception updated!! I am usually less than .3 off at fillups, could be user error as well since I say 60 gallons and there may be 59.X, but it is pretty consistent and minor. My point is that it works just fine for me in the tunnel. It probably is easier to install in the spider/ servo area as the tunnel setup was a bear for me from the boost pump, but it works and I dont see a need to move it.. With all that said- If I was doing this again- I would seriously consider putting it up front by the servo/spider. -----Original Message----- From: David Leikam Sent: Saturday, June 01, 2013 9:02 AM Subject: Re: RV10-List: Floscan location and Matronics fuel line pulsation damper Definitely put it between the servo and spider. I talked directly with Flo-Scan about this and they said the worst place is between the the two fuel pumps. They said the best would be before the valve. (We can't do this obviously.) I installed mine just in front of the servo (or after as flow goes,) with a somewhat floating, flexible mount on the air box. I'm within a 1/2 gallon on every fill. Use flexible hose, do not make it rigid. Dave Leikam N89DA On Jun 1, 2013, at 9:22 AM, g.combs wrote: > > I ditto Robins remarks. Why take the chance of having a problem and then > have to move it. PIREP from everyone > Having it FWF is positive. 400 hrs and > Great results for myself. Soft mount it up front and be a happy. > > Geoff > > > Sent from my iPhone > > On Jun 1, 2013, at 3:16 AM, Robin Marks wrote: > >> >> The beauty of putting the cube in the tunnel is that you get to remove & >> relocate it once you are flying. Talk about enjoyable! I did as the plans >> describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 >> GPH... sometimes. Other times it would read 4.3 GPH. Want another >> indication just flip on your boost pump and you get a whole different >> reading. No way for me to balance injectors w/o accurate fuel flow. I >> relocated FWF (I like Sean's install in archives) and all issues went >> away. I still get the occasional 0.4 GPH fluctuations but that is because >> I don't have the ideal length flow in/out of the cube. >> I only have read one pirep on the damper and it was No Joy. >> Robin >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 >> Sent: Friday, May 31, 2013 7:04 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: Floscan location and Matronics fuel line pulsation >> damper >> >> >> I'm trying to decide whether to place the floscan in the tunnel (standard >> location) vs engine compartment. Anyone have strong opinion? What about >> experience with the Matronics pulsation damper which seems like it would >> solve the problems the tunnel location has? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401718#401718 >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> >> >> >> > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 01, 2013
Subject: Re: Can you fix a broken BNC connector on a COM antenna?
I would try making a short pigtail adapter and soldering the downstream BNC housing to the antenna. Just have to make sure the center conductors are engaged. Or just solder your existing connector to the antenna and put an additional connector in when you have to remove it. Dave Saylor 831-750-0284 CL On Sat, Jun 1, 2013 at 9:42 AM, Mike Whisky wrote: > > Don't ask me I got there but I managed to shear off the guiding/locking > pins of my com antenna connector. See pictures. Does anyone know if it can > be fixed without buying a new antenna? > > -------- > RV-10 builder (final assembly) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401758#401758 > > > Attachments: > > http://forums.matronics.com//files/image_204.jpg > http://forums.matronics.com//files/image_699.jpg > > ________________________________________________________________________________
Date: Jun 01, 2013
On 6/1/2013 12:42 PM, Mike Whisky wrote: > > Don't ask me I got there but I managed to shear off the guiding/locking pins of my com antenna connector. See pictures. Does anyone know if it can be fixed without buying a new antenna? Can't be fixed. I've never seen that before, and I've seen a lot of BNC connections!!! So, inquiring minds really do want to ask .... how. The prudent thing to do would be to purchase another antenna. I hate to even suggest this but you MAY be successful in cleaning the antenna connections real good with MEK, gooping up the outside of the antenna side with red silicone, and sliding on the cable. I have no idea whether that will work because, as I said, I've never been there!!! Linn > > -------- > RV-10 builder (final assembly) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401758#401758 > > > Attachments: > > http://forums.matronics.com//files/image_204.jpg > http://forums.matronics.com//files/image_699.jpg > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 01, 2013
The pins keep the connector tight to provide a good ground connection, so without those you'll have problems- may burn out your transmitter. Replace it. Sent from my iPhone On Jun 1, 2013, at 11:42 AM, "Mike Whisky" wrote: > > Don't ask me I got there but I managed to shear off the guiding/locking pins of my com antenna connector. See pictures. Does anyone know if it can be fixed without buying a new antenna? > > -------- > RV-10 builder (final assembly) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=401758#401758 > > > > > Attachments: > > http://forums.matronics.com//files/image_204.jpg > http://forums.matronics.com//files/image_699.jpg > > > > > > > ________________________________________________________________________________
Date: Jun 01, 2013
"Can't be fixed. " I have always taken the position that if man made it, man (or woman) can fix it. It may take some careful surgery, sharp knives, a Dremel tool, holding your tongue just right and one kind of prayer or another. Always try to return the assembly to as near to original as possible. The use of duct tape is not acceptable. It doesn't even work on ducts. Adhesives are sometimes acceptable if the original assembly used adhesive. Choosing the adhesive is the problem. What was originally used. What material is being reassembled. Yes, some things are not worth the time to fix them. Some things have been assembled in such a way that even a sharp knife will not defeat the assembly process. It is always worth an attempt. On 6/1/2013 1:26 PM, Linn wrote: > > On 6/1/2013 12:42 PM, Mike Whisky wrote: >> >> Don't ask me I got there but I managed to shear off the >> guiding/locking pins of my com antenna connector. See pictures. Does >> anyone know if it can be fixed without buying a new antenna? > Can't be fixed. I've never seen that before, and I've seen a lot of > BNC connections!!! So, inquiring minds really do want to ask .... how. > The prudent thing to do would be to purchase another antenna. > I hate to even suggest this but you MAY be successful in cleaning the > antenna connections real good with MEK, gooping up the outside of the > antenna side with red silicone, and sliding on the cable. I have no > idea whether that will work because, as I said, I've never been there!!! > Linn > >> >> -------- >> RV-10 builder (final assembly) >> #511 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=401758#401758 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/image_204.jpg >> http://forums.matronics.com//files/image_699.jpg >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> > > ________________________________________________________________________________
Date: Jun 02, 2013
Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? Albert Gardner N991RV Yuma, AZ ---- Pascal wrote: > > The flip side is Dynon does tell one (pg7-41) "It is common to place the > sender downstream of any auxiliary electric boost pumps but upstream of the > engine driven fuel pump." as does Vans. I think they need to consult Floscan > on getting that perception updated!! I am usually less than .3 off at > fillups, could be user error as well since I say 60 gallons and there may be > 59.X, but it is pretty consistent and minor. > My point is that it works just fine for me in the tunnel. It probably is > easier to install in the spider/ servo area as the tunnel setup was a bear > for me from the boost pump, but it works and I dont see a need to move it.. > With all that said- If I was doing this again- I would seriously consider > putting it up front by the servo/spider. > > > > -----Original Message----- > From: David Leikam > Sent: Saturday, June 01, 2013 9:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Floscan location and Matronics fuel line pulsation > damper > > > Definitely put it between the servo and spider. > I talked directly with Flo-Scan about this and they said the worst place is > between the the two fuel pumps. They said the best would be before the > valve. (We can't do this obviously.) > I installed mine just in front of the servo (or after as flow goes,) with a > somewhat floating, flexible mount on the air box. I'm within a 1/2 gallon > on every fill. > Use flexible hose, do not make it rigid. > > Dave Leikam > N89DA > > On Jun 1, 2013, at 9:22 AM, g.combs wrote: > > > > > I ditto Robins remarks. Why take the chance of having a problem and then > > have to move it. PIREP from everyone > > Having it FWF is positive. 400 hrs and > > Great results for myself. Soft mount it up front and be a happy. > > > > Geoff > > > > > > > > Sent from my iPhone > > > > On Jun 1, 2013, at 3:16 AM, Robin Marks wrote: > > > >> > >> The beauty of putting the cube in the tunnel is that you get to remove & > >> relocate it once you are flying. Talk about enjoyable! I did as the plans > >> describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 > >> GPH... sometimes. Other times it would read 4.3 GPH. Want another > >> indication just flip on your boost pump and you get a whole different > >> reading. No way for me to balance injectors w/o accurate fuel flow. I > >> relocated FWF (I like Sean's install in archives) and all issues went > >> away. I still get the occasional 0.4 GPH fluctuations but that is because > >> I don't have the ideal length flow in/out of the cube. > >> I only have read one pirep on the damper and it was No Joy. > >> Robin > >> > >> -----Original Message----- > >> From: owner-rv10-list-server(at)matronics.com > >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > >> Sent: Friday, May 31, 2013 7:04 PM > >> To: rv10-list(at)matronics.com > >> Subject: RV10-List: Floscan location and Matronics fuel line pulsation > >> damper > >> > >> > >> I'm trying to decide whether to place the floscan in the tunnel (standard > >> location) vs engine compartment. Anyone have strong opinion? What about > >> experience with the Matronics pulsation damper which seems like it would > >> solve the problems the tunnel location has? > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401718#401718 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> ----- > >> No virus found in this message. > >> Checked by AVG - www.avg.com > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 01, 2013
It is an unusual installation for a Lycoming fuel injected engine to have a fuel return line. Bendix FI does not. AF has a purge line which may or may not return to the tank, but is only used for shutdown, there is no return when engine is running. Only Continental injection or systems modeled after it have an active return line, and there are sensors to account for that fuel, but not something that most RV-10 operations need to be concerned with. On 6/1/2013 9:56 PM, ibspud(at)roadrunner.com wrote: > > Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? > Albert Gardner > N991RV > Yuma, AZ > > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 02, 2013
In the tunnel my cube absolutely reported more than consumed. Robin ibspud(at)roadrunner.com wrote: Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? Albert Gardner N991RV Yuma, AZ ---- Pascal wrote: > > The flip side is Dynon does tell one (pg7-41) "It is common to place the > sender downstream of any auxiliary electric boost pumps but upstream of the > engine driven fuel pump." as does Vans. I think they need to consult Floscan > on getting that perception updated!! I am usually less than .3 off at > fillups, could be user error as well since I say 60 gallons and there may be > 59.X, but it is pretty consistent and minor. > My point is that it works just fine for me in the tunnel. It probably is > easier to install in the spider/ servo area as the tunnel setup was a bear > for me from the boost pump, but it works and I dont see a need to move it.. > With all that said- If I was doing this again- I would seriously consider > putting it up front by the servo/spider. > > > -----Original Message----- > From: David Leikam > Sent: Saturday, June 01, 2013 9:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Floscan location and Matronics fuel line pulsation > damper > > > Definitely put it between the servo and spider. > I talked directly with Flo-Scan about this and they said the worst place is > between the the two fuel pumps. They said the best would be before the > valve. (We can't do this obviously.) > I installed mine just in front of the servo (or after as flow goes,) with a > somewhat floating, flexible mount on the air box. I'm within a 1/2 gallon > on every fill. > Use flexible hose, do not make it rigid. > > Dave Leikam > N89DA > > On Jun 1, 2013, at 9:22 AM, g.combs wrote: > > > > > I ditto Robins remarks. Why take the chance of having a problem and then > > have to move it. PIREP from everyone > > Having it FWF is positive. 400 hrs and > > Great results for myself. Soft mount it up front and be a happy. > > > > Geoff > > > > > > > > Sent from my iPhone > > > > On Jun 1, 2013, at 3:16 AM, Robin Marks wrote: > > > >> > >> The beauty of putting the cube in the tunnel is that you get to remove & > >> relocate it once you are flying. Talk about enjoyable! I did as the plans > >> describe and had 2-3 gph fluctuations including 800 RPM taxi showing 12 > >> GPH... sometimes. Other times it would read 4.3 GPH. Want another > >> indication just flip on your boost pump and you get a whole different > >> reading. No way for me to balance injectors w/o accurate fuel flow. I > >> relocated FWF (I like Sean's install in archives) and all issues went > >> away. I still get the occasional 0.4 GPH fluctuations but that is because > >> I don't have the ideal length flow in/out of the cube. > >> I only have read one pirep on the damper and it was No Joy. > >> Robin > >> > >> -----Original Message----- > >> From: owner-rv10-list-server(at)matronics.com > >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > >> Sent: Friday, May 31, 2013 7:04 PM > >> To: rv10-list(at)matronics.com > >> Subject: RV10-List: Floscan location and Matronics fuel line pulsation > >> damper > >> > >> > >> I'm trying to decide whether to place the floscan in the tunnel (standard > >> location) vs engine compartment. Anyone have strong opinion? What about > >> experience with the Matronics pulsation damper which seems like it would > >> solve the problems the tunnel location has? > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=401718#401718 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> ----- > >> No virus found in this message. > >> Checked by AVG - www.avg.com > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 02, 2013
Just to add some additional clarification to what Kelly stated. With the AFP purge valve in addition to cutting off the fuel feed for shutdown, it also functions to flush warm fuel with cold to aid in hot starts. I am also aware of one RV-10 with a Bendix that added a AFP purge valve. I suspect when you flush the fuel it will cause the EFIS to report more fuel consumed than actually used, but it really isn't a significant amount. Sent from my iPad On Jun 2, 2013, at 1:01 AM, Kelly McMullen wrote: > > It is an unusual installation for a Lycoming fuel injected engine to have a fuel return line. Bendix FI does not. AF has a purge line which may or may not return to the tank, but is only used for shutdown, there is no return when engine is running. Only Continental injection or systems modeled after it have an active return line, and there are sensors to account for that fuel, but not something that most RV-10 operations need to be concerned with. > On 6/1/2013 9:56 PM, ibspud(at)roadrunner.com wrote: >> >> Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? >> Albert Gardner >> N991RV >> Yuma, AZ > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Subject: Re: how can I find out the gear reduction for the governor
driv
Date: Jun 02, 2013
Thanks everyone for your input. I'll report the adjustments I had to do in order to reach the low an high RPMs. Mike -------- RV-10 builder (final assembly) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401798#401798 ________________________________________________________________________________
Date: Jun 02, 2013
damper I was referring to the return loop on the Airflow Performance pumps that goes from the pump manifold back to a T fitting at the fuel selector valve input. My calculated fuel consumption agrees closely with actual consumption so it appears there is little recirculated fuel involved. Just wondering what the return loop's function is? Albert Gardner N991RV Yuma, AZ ---- Kelly McMullen wrote: > > It is an unusual installation for a Lycoming fuel injected engine to > have a fuel return line. Bendix FI does not. AF has a purge line which > may or may not return to the tank, but is only used for shutdown, there > is no return when engine is running. Only Continental injection or > systems modeled after it have an active return line, and there are > sensors to account for that fuel, but not something that most RV-10 > operations need to be concerned with. > On 6/1/2013 9:56 PM, ibspud(at)roadrunner.com wrote: > > > > Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? > > Albert Gardner > > N991RV > > Yuma, AZ > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Jun 02, 2013
The return line helps set the fuel pressure. There is a check valve, and it relieves excess pressure by sending some fuel back to the pump's inlet side. So some fuel goes round and round, but not back to the tank. If your flowscan was between the return T and the pump you would read high, but anywhere else should be okay. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401838#401838 ________________________________________________________________________________
Date: Jun 02, 2013
Your transducer is after that loop regardless of whether it is in the tunnel or on the engine. Has no effect on measurement going through the transducer. The loop simply allows the pump output to be held to a preset maximum, with any excess going back to the pump inlet. On 6/2/2013 10:01 AM, ibspud(at)roadrunner.com wrote: > I was referring to the return loop on the Airflow Performance pumps that goes from the pump manifold back to a T fitting at the fuel selector valve input. My calculated fuel consumption agrees closely with actual consumption so it appears there is little recirculated fuel involved. Just wondering what the return loop's function is? > Albert Gardner > N991RV > Yuma, AZ > > ---- Kelly McMullen wrote: >> >> It is an unusual installation for a Lycoming fuel injected engine to >> have a fuel return line. Bendix FI does not. AF has a purge line which >> may or may not return to the tank, but is only used for shutdown, there >> is no return when engine is running. Only Continental injection or >> systems modeled after it have an active return line, and there are >> sensors to account for that fuel, but not something that most RV-10 >> operations need to be concerned with. >> On 6/1/2013 9:56 PM, ibspud(at)roadrunner.com wrote: >>> >>> Since, on injected engines, there is a fuel return line that goes from the pump back to the fuel selector valve, does the Floscan sender report higher flue flow than is actually used by the engine? Or is there only a small amount of fuel returned via that bypass route? >>> Albert Gardner >>> N991RV >>> Yuma, AZ >>> >>> >>> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> >> >> ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 02, 2013
Simplest solution would be to purchase a BNC female to male adapter (or elbow connector), solder it onto the present antenna connector using a 'sweat solder' approach, very carefully not using too much heat to melt the inner insulation of the broken connector. If you've ever soldered copper water pipe, you know the concept. The pins are just there to provide a positive mechanical connection, the shell itself makes the negative electrical connection, center pin the positive. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401840#401840 ________________________________________________________________________________
Date: Jun 03, 2013
Michael, I'm running a special deal at the moment. Drop by and collect 1 spare bent whip (I can't afford the 2nd radio anyway) and get one beer free. Trade them for a cork to fit the hole already drilled in the fuselage. Cheers, Gordon On Jun 1, 2013, at 10:47 PM, Lyle Peterson wrote: > > "Can't be fixed. " I have always taken the position that if man made it, man (or woman) can fix it. It may take some careful surgery, sharp knives, a Dremel tool, holding your tongue just right and one kind of prayer or another. Always try to return the assembly to as near to original as possible. The use of duct tape is not acceptable. It doesn't even work on ducts. Adhesives are sometimes acceptable if the original assembly used adhesive. Choosing the adhesive is the problem. What was originally used. What material is being reassembled. > > Yes, some things are not worth the time to fix them. Some things have been assembled in such a way that even a sharp knife will not defeat the assembly process. > > It is always worth an attempt. > > On 6/1/2013 1:26 PM, Linn wrote: >> >> On 6/1/2013 12:42 PM, Mike Whisky wrote: >>> >>> Don't ask me I got there but I managed to shear off the guiding/locking pins of my com antenna connector. See pictures. Does anyone know if it can be fixed without buying a new antenna? >> Can't be fixed. I've never seen that before, and I've seen a lot of BNC connections!!! So, inquiring minds really do want to ask .... how. >> The prudent thing to do would be to purchase another antenna. >> I hate to even suggest this but you MAY be successful in cleaning the antenna connections real good with MEK, gooping up the outside of the antenna side with red silicone, and sliding on the cable. I have no idea whether that will work because, as I said, I've never been there!!! >> Linn >> >>> >>> -------- >>> RV-10 builder (final assembly) >>> #511 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=401758#401758 >>> >>> >>> >>> >>> Attachments: >>> >>> http://forums.matronics.com//files/image_204.jpg >>> http://forums.matronics.com//files/image_699.jpg >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> >>> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jun 03, 2013
Deems, where did you source your sheet of stainless? I'm guessing it was a 3' x 4' sheet of=8A 301 1/4 hard temper? Thank you! From: Deems Davis <deemsdavis(at)cox.net> Date: Thursday, May 30, 2013 1:24 PM Subject: Re: RV10-List: Sound Proofing and Heat Shield FiberFrax sandwiched between Stainless Steel. Pics start here: http://deemsrv10.com/album/Sec%2041%20Upper%20Fwd%20Fuse%20Install/slides/D S C03158.html read about it: : http://deemsrv10.com/upperfwdfuseinstallationlogindex.html Secv 41 Faux... On Thu, May 30, 2013 at 9:22 AM, Pascal wrote: > I sprayed on a sound proofer. and heat shield. If I was doing it again. I > would get a heat blanket for the firewall and keep the top of the line > headsets, skip the sound proofing all together. Even with all the sound > proofing I did I still have a plane that is so loud when cruising that I > wonder what it would be like with out it, so I wear Lightspeed Zulu and i t all > goes away. > As a reference when I knocked on the skin it had a noise that went away w ith > the sound proofer so it does something, just not much up in the air. > > > From: Jonathan Beasley <mailto:jbeasley(at)nc.rr.com> > Sent: Thursday, May 30, 2013 8:32 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Sound Proofing and Heat Shield > > Any recommendations for sound proofing and firewall heat shield? Obviousl y > many choices are available=8A Soundex, 3M, Super Sound Proof, Heat Shield M at, > etc. What is working well in RV10 land? It would be interesting to see ho w > many people have selected to install sound proofing vs. going =B3au natural e=B2. > > ---- > Jonathan Beasley > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics. com/N > avigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > ________________________________________________________________________________
Date: Jun 03, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
Subject: Quick Build Fuselage Advice
I am starting on my quick build fuselage trying to discover what has been done and what is left to do. I have removed the floor panels, except for the front panels, and found only two washers. I think I will inspect under the front floor panels using an inspection camera. The heat vent tee, VA-175, in mid fuselage points to the rear of the fuselage, not up as shown in the plans. I suspect that needs changing. There is an extra fuel valve mount, F-1048C1, taped to the installed mount stating that the mount is installed inverted and needs to be changed. I am installing an Andair valve and from reading Tim's pages I suspect that I will need to fabricate and bracket so I will need to simply remove the current one. Insulation seems something that needs addressing fairly soon. Insulation for the firewall and the tunnel seems to make sense. I am wondering what insulating the floor would gain as the noise comes from in front of the firewall, not below the fuselage. At the risk of starting an insulation war, what insulation would you recommend? I know Tim mentioned Flightline Interiors. There appears to be a lot of extras that need to be procured to finish the plane and at this point in time the issues seem to be ones of timing the procurement and installations so that something that has been done does not need to be undone to install an item. Looking at the jig saw puzzle and trying to see all the pieces and how they fit together. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: Quick Build Fuselage Advice
Date: Jun 03, 2013
Just be aware that since Tim built his plane Vans has changed the plumbing and fuel valve location. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401919#401919 ________________________________________________________________________________
Subject: IO 540 C4B5 WANTED
Date: Jun 03, 2013
I'm looking for a IO 540 that I can rebuild for my 10. Please PM me with price and condition if anybody has one. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401926#401926 ________________________________________________________________________________
Date: Jun 03, 2013
I'm just a little ahead of you, and though I went slow build, it's mostly the same from this point on. You should be able to simply twist the heat vent tee. It's just friction fitted to the fittings that are riveted to the tunnel sides. As for figuring out what you need to get when, I've just been doing a lot of reading of other's build logs. Some thing that you'll need to figure out coming up soon are: -- Where you're going to route conduit to the rear -- Antenna choices if you're going to mount them on the belly -- Whether or not you want access panels for your step bolts -- Fuel Pump -- Fuel Valve -- Hard line or flexible line for fuel and brakes Those are just a few of the things I'm working thru right now off the top of my head. Some items may have a significant delay in shipment. I haven't yet had building held up by shipping delays, but I'm sure it's only a matter of time. Still many more decisions to come! On Mon, Jun 3, 2013 at 5:33 PM, Dave Fritzsche (Building) wrote: > dfritz(at)bpgsim.com> > > I am starting on my quick build fuselage trying to discover what has been > done and what is left to do. I have removed the floor panels, except for > the front panels, and found only two washers. I think I will inspect under > the front floor panels using an inspection camera. The heat vent tee, > VA-175, in mid fuselage points to the rear of the fuselage, not up as shown > in the plans. I suspect that needs changing. There is an extra fuel valve > mount, F-1048C1, taped to the installed mount stating that the mount is > installed inverted and needs to be changed. I am installing an Andair > valve and from reading Tim's pages I suspect that I will need to fabricate > and bracket so I will need to simply remove the current one. Insulation > seems something that needs addressing fairly soon. Insulation for the > firewall and the tunnel seems to make sense. I am wondering what > insulating the floor would gain as the noise comes from in front of the > firewall, not below the fuselage. At the risk of starting an insulation > war, what insulation would you recommend? I know Tim mentioned Flightline > Interiors. > > There appears to be a lot of extras that need to be procured to finish the > plane and at this point in time the issues seem to be ones of timing the > procurement and installations so that something that has been done does not > need to be undone to install an item. Looking at the jig saw puzzle and > trying to see all the pieces and how they fit together. > > Dave > > -- > ~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > Fuselage > > ________________________________________________________________________________
Date: Jun 03, 2013
My red cube works fine in the tunnel. With the boost pump on, fuel line disconnected at servo inlet, I was getting 42 gph flow. Plenty for an engine that needs 26-27 gph at takeoff. I made a 5052 tube to take the place of my red cube/two hard lines if I ever need to move it. Same as others...accurate to .5 gallon. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401952#401952 ________________________________________________________________________________
Date: Jun 03, 2013
1/8" fiberfrax on aft side of firewall. No other sound proofing, painted interior, Lightspeed Zulu's. I'd do the same all over. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401954#401954 ________________________________________________________________________________
Date: Jun 04, 2013
I used fiberglass insulation under the forward floor panels. This can be added via the lightening holes on the aft side of the floor so you don't have to remove the panel. In the rear seat and baggage compartment I used closed cell foam. Having said that I am not convinced that it is worth it. For heat insulation you need to focus on the firewall and tunnel. Most of the noise in the airplane comes from the air vents, followed by engine. I doubt the floor insulation does much. As stated in the earlier response this is the time to figure your electrical routing, i.e., conduit and big cable runs. Under the floor is a good place for this, in particular thru the baggage compartment. Don't forget electrical and antenna runs to the wings which will pass via the center section fuselage. Consider adding conduit from front to aft of the baggage bulkhead, conduit from front to each wing opening, and front to the center section (for things like flap motor, rear seat headphones, and antenna cable). -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=401965#401965 ________________________________________________________________________________
Date: Jun 04, 2013
I affirm what Dave Moore said...."run lots of the conduit now." Excellent advice. I also put in an inspection plate (2) for the boarding step WHEN it loosens (which it will). It is also a good idea to put it in just for corrosion inspections. There is an excellent and ultra light insulation that I found at OSH. I also have the heavy - foil backed fiberglass on the cowl and firewall. I never had the tunnel heat issue. My tunnel is NOT insulated. I found that the fuel lines are a real pain, so I bought the Bonaco kit - excellent choice and saved me a lot of swearing. I have nothing but kuddos for the Vans QB kit that was delivered to me in 2007. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402047#402047 ________________________________________________________________________________
Date: Jun 04, 2013
I seem to recall folks have had trouble with the AN 3 bolts Vans supplies for steps wearing the hole and loosening. There are three possible upgrades. Putting inspection plate on baggage floor as mentioned, reaming the holes up to AN 4 size, and inserting dowel of wood, or milled aluminum or steel inside the step pipe to prevent the pipe from being distorted by tightening the bolt(with appropriate anti-corrosive treatment). I have done the first two items. On Tue, Jun 4, 2013 at 9:49 PM, AirMike wrote: > > I affirm what Dave Moore said...."run lots of the conduit now." Excellent > advice. I also put in an inspection plate (2) for the boarding step WHEN it > loosens (which it will). It is also a good idea to put it in just for > corrosion inspections. There is an excellent and ultra light insulation > that I found at OSH. I also have the heavy - foil backed fiberglass on the > cowl and firewall. I never had the tunnel heat issue. My tunnel is NOT > insulated. I found that the fuel lines are a real pain, so I bought the > Bonaco kit - excellent choice and saved me a lot of swearing. I have > nothing but kuddos for the Vans QB kit that was delivered to me in 2007. > > -------- > See you OSH '13 > Q/B - flying 3 yrs. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402047#402047 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jun 05, 2013
Some thoughts from a 2011 completion and 300 hours later. On 6/3/2013 11:42 PM, Ed Kranz wrote: > As for figuring out what you need to get when, I've just been doing a > lot of reading of other's build logs. Some thing that you'll need to > figure out coming up soon are: > -- Where you're going to route conduit to the rear I went with the Vans wiring kit routing hardware to run fat power wires and some other lines. It has a few brackets and and clamp locations. I did not buy or use the Vans wiring kit or configuration, just used the plans to mimic their routing and order a few select pieces (plus some access hatches and avionic mounts for the tail). Then, I ran 2 empty conduits (Van's material) for running all the avionics stuff that were going to be finalized after the floor was closed. 3 empty conduits is even better. This has all worked very well. > -- Antenna choices if you're going to mount them on the belly I had some churn around antenna choices. Ultimately I found that with one comm antenna installed under the floor before the floor is closed up, additional antennas could be added after completion (e.g. transponder, another comm under the seat, ADS-B and ELT stuff is all in the tailcone and remains accessible (see desirability of 3rd conduit)) > -- Whether or not you want access panels for your step bolts > -- Fuel Pump > -- Fuel Valve > -- Hard line or flexible line for fuel and brakes I did it exactly per Vans plus Andair mods. Still doing fine at 300hours on a rough field (think brake lines). You don't have to learn to bend aluminum tubing if you get the flexible lines I guess. I learned but have been unable to transfer the skills to much of anything else. > > Still many more decisions to come! The decisions are the real joy of the project. not withstanding that Vans per the plans works too. "Less is more" applies as does "but Mama, that's where the fun is" > > > On Mon, Jun 3, 2013 at 5:33 PM, Dave Fritzsche (Building) > > wrote: > > > > > I am starting on my quick build fuselage trying to discover what > has been done and what is left to do. I have removed the floor > panels, except for the front panels, and found only two washers. > I think I will inspect under the front floor panels using an > inspection camera. The heat vent tee, VA-175, in mid fuselage > points to the rear of the fuselage, not up as shown in the plans. > I suspect that needs changing. There is an extra fuel valve > mount, F-1048C1, taped to the installed mount stating that the > mount is installed inverted and needs to be changed. I am > installing an Andair valve and from reading Tim's pages I suspect > that I will need to fabricate and bracket so I will need to simply > remove the current one. Insulation seems something that needs > addressing fairly soon. Insulation for the firewall and the > tunnel seems to make sense. I am wondering what insulating the > floor would gain as the noise comes from in front of the firewall, > not below the fuselage. At the risk of starting an insulation > war, what insulation would you recommend? I know Tim mentioned > Flightline Interiors. > I have a Flightline interior which probably deadens some sound. We like it because it looks nice and works well. Otherwise we depend on Bose (or your favorite ANL device). I put some low tech material on the back of the firewall, don't know if it does anything. You don't need to insulate in my opinion. A painted interior and good ANL headsets would seem to do the trick. It's up to you where you want to spend your time. > > > There appears to be a lot of extras that need to be procured to > finish the plane and at this point in time the issues seem to be > ones of timing the procurement and installations so that something > that has been done does not need to be undone to install an item. > Looking at the jig saw puzzle and trying to see all the pieces and > how they fit together. > > Dave > ________________________________________________________________________________
Date: Jun 06, 2013
I'm insulated to the hilt. Both sides of the firewall, tunnel, under the floors, etc. I have no hot floors, tunnel, etc. I'm glad I did it. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402132#402132 ________________________________________________________________________________
Date: Jun 06, 2013
Kelly McMullen wrote: > I seem to recall folks have had trouble with the AN 3 bolts Vans supplies for steps wearing the hole and loosening. There are three possible upgrades. Putting inspection plate on baggage floor as mentioned, reaming the holes up to AN 4 size, and inserting dowel of wood, or milled aluminum or steel inside the step pipe to prevent the pipe from being distorted by tightening the bolt(with appropriate anti-corrosive treatment). I have done the first two items. > I used an AN174 close tolerance bolt from Spruce. No wobble yet. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402133#402133 ________________________________________________________________________________
Subject: Time to sell the RV-8A
Date: Jun 07, 2013
All, Now that the RV-10 is pretty well tweaked in, and considering my son Steve is at sea on the Nimitz and 10 years from a stable shore job, I decided to sell the RV-8A. I would appreciate you all letting anyone know who may be looking. Here are some details: Airplane: 2002 Van's RV-8A. I am the original owner and builder. 660 total hours. Always in a hangar. Day/night VFR/IFR. Price: $80,000 Engine: Lycoming IO-360 (180hp), 660 hours since new Prop: Hartzell constant speed blended airfoil, 320 hours since new Dual pMag electronic ignitions Dual batteries feeding independent power busses GX-60 GPS comm/nav SL-30 comm/nav SL-70 XPDR Dynon D10A EFIS Garmin 396 PS Engineering audio panel JPI fuel flow computer Grand Rapids Engine Information System Wing leveler autopilot Location: Dogwood Airpark (VA42), Fredericksburg Virginia Thanks, Carl ________________________________________________________________________________
Subject: Re: RV-10 Glide Ratio
Date: Jun 09, 2013
Solo, 40 gal, prop at coarse pitch, rpm 640 and airspeed 80 kias today, I was getting about 10:1. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402344#402344 ________________________________________________________________________________
Date: Jun 09, 2013
Usually best glide is much closer to Vy or even above Vy. I would expect it to be somewhere between 90&100kts. On 6/9/2013 2:06 PM, rv10flyer wrote: > > Solo, 40 gal, prop at coarse pitch, rpm 640 and airspeed 80 kias today, I was getting about 10:1. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 103 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402344#402344 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 09, 2013
Shut off the engine and the glide ratio will be lower. Stop the prop and it'll be better. Sent from my iPhone On Jun 9, 2013, at 4:06 PM, "rv10flyer" wrote: > > Solo, 40 gal, prop at coarse pitch, rpm 640 and airspeed 80 kias today, I was getting about 10:1. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 103 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402344#402344 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 09, 2013
Are there two terms for best glide like there are for best climb? Bob Turner expounded on this a few weeks ago but I'll admit I didn't pay close enough attention. One would be to get you the furthest, another to keep you aloft for the greatest duration...or are they the same thing? I changed my emergency checklist a few years ago from 80 (KIAS) to 95 for best glide because it seemed that 95 got me further. But earlier I was pretty sure that 80 gave me the minimum sink rate. Bob?? On Sunday, June 9, 2013, Kelly McMullen wrote: > > Usually best glide is much closer to Vy or even above Vy. I would expect > it to be somewhere between 90&100kts. > > On 6/9/2013 2:06 PM, rv10flyer wrote: > >> >> Solo, 40 gal, prop at coarse pitch, rpm 640 and airspeed 80 kias today, I >> was getting about 10:1. >> >> -------- >> Wayne G. >> SB 12/01/2009-12/01/2011 >> TT= 103 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=402344#402344> >> >> >> >> >> >> >> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > -- Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Jun 09, 2013
I also keep my TT AP "Min Airspd" set at 80 kts. If one has a lot of altitude it might help out and keeps us from stalling in an AP climb. With an actual engine out, we would gain a little more by opening the throttle. If I was at gross weight, I would shoot for 90 kts. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=402358#402358 ________________________________________________________________________________
Date: Jun 09, 2013
Minimum sink speed (maximum time before you hit the ground) is not the same as best glide (cover maximum horizontal distance before you hit the ground). Minimum sink speed is at the "minimum power required" speed, and in most single engine GA airplanes is close to Vx and often just a few knots faster than stall speed Vs1. Best glide speed in an ideal airplane is greater than Vy, but in every real certified GA single that I've been in the reverse is true. This is because virtually all aircraft have cruise props, and the increasing prop efficiency as speed increases in the Vy speed range pushes real world Vy to higher values. Best glide (no wind) occurs at max L/D angle of attack. Therefore, it varies with weight (variation is as the square root of the weight, so, approximately, if you are under gross by 20%, then best glide is reduced (from gross weight number) by 10%.). At Wayne's weight I'd say 80 kias is about right. In the real world, where you want to cover distance over the ground in a glide, the wind can come into play. With a tailwind, you want to go slower than published best glide speed, but never slower than minimum sink. With a headwind, increase speed, roughly by 40% of the wind speed if known. As a side note, in many training situations where the cfi pulls the throttle and says "make the runway", the decrease in best speed because you are below gross weight and the increase in best glide because of the headwind tend to cancel out. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402366#402366 ________________________________________________________________________________
Date: Jun 09, 2013
So am I right in thinking that if you had an AOA indicator, and were able to glide at L/Dmax, then you could reduce speed on final to increase sink and not overshoot the landing spot? For that matter you could also *increase* speed to increase sink, but then you'd touch down going faster. Dave Saylor 831-750-0284 CL On Sun, Jun 9, 2013 at 9:07 PM, Bob Turner wrote: > > Minimum sink speed (maximum time before you hit the ground) is not the > same as best glide (cover maximum horizontal distance before you hit the > ground). > Minimum sink speed is at the "minimum power required" speed, and in most > single engine GA airplanes is close to Vx and often just a few knots faster > than stall speed Vs1. > Best glide speed in an ideal airplane is greater than Vy, but in every > real certified GA single that I've been in the reverse is true. This is > because virtually all aircraft have cruise props, and the increasing prop > efficiency as speed increases in the Vy speed range pushes real world Vy to > higher values. > > Best glide (no wind) occurs at max L/D angle of attack. Therefore, it > varies with weight (variation is as the square root of the weight, so, > approximately, if you are under gross by 20%, then best glide is reduced > (from gross weight number) by 10%.). At Wayne's weight I'd say 80 kias is > about right. > > In the real world, where you want to cover distance over the ground in a > glide, the wind can come into play. With a tailwind, you want to go slower > than published best glide speed, but never slower than minimum sink. With a > headwind, increase speed, roughly by 40% of the wind speed if known. > > As a side note, in many training situations where the cfi pulls the > throttle and says "make the runway", the decrease in best speed because you > are below gross weight and the increase in best glide because of the > headwind tend to cancel out. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402366#402366 > > ________________________________________________________________________________
Date: Jun 09, 2013
Dave, Yes that is correct. Typical approach speeds are at or less than best glide, so if the pilot pulls back on the stick with no power change, then once the transients die out, he'll be slower and have a steeper approach than before. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402372#402372 ________________________________________________________________________________
Date: Jun 10, 2013
I don't have a real AOA and have never flown with one so I just practice a lot at solo and gross. The family understands the importance. I do not practice with full baggage, low fuel and at my aft limit with the family on board. I already did that with dogfood in phase 1. So far, no tendencies to enter a spin. I unload and raise the wing with rudder then gently add power back in. There is plenty of tail buffet warning without flaps. The GRT has a "derived" AOA that I calibrated, but I feel looking out the window with the feel in the seat and sound do more for me. I went out yesterday and did some power off stalls with/without flaps and level/30 deg banks. Also some no flap landings. After a while you can feel when you are at the "right" speed with or without flaps. Pulling that prop back to 640 rpm really makes a big difference in glide. I get a little engine shake at that low rpm, something I did not notice on David Maib's 3-blade during transition training. It does seem to have a slightly better glide, possibly due to less drag on the 2-blade and solo. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402392#402392 ________________________________________________________________________________
Date: Jun 10, 2013
Certainly drag is important, and others have mentioned ways to reduce it (low rpm on the prop, full throttle, stop the prop). Depending on what happened to the engine you may or may not be able to control these things. Curiously, while weight affects the optimum glide speed it does not affect the glide distance, no wind. In a headwind you can glide further if you're heavy, vice versa in a tailwind. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402404#402404 ________________________________________________________________________________
Date: Jun 10, 2013
Subject: Max RPM adjustment
I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max RPM set to 2700 RPM initially, but over time it has been declining slowly, to the point that it's about 2640 on climbout now, at 2+ years and 200+ hours. Is that to be expected (i.e. I should just adjust the stop screw) or is this indicative of a problem requiring further investigation? The governor appears normal and in all other respects operates normally. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Jun 10, 2013
Subject: Inspection Camera
I do not plan on removing the front floor panels from my QB fuselage, but I do want to look under them. Thus I am in the market for an inspection camera which I assume will come in handy in the future. I have looked at the one Costco sells and wonder if anyone has used it? Camera recommendations from users would be appreciated. Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: Max RPM adjustment
Date: Jun 10, 2013
My MT was set at 2700 and still runs between 2690-2710 depending on temperatures. I would ensure you are hitting the high rpm stop when prop knob is fully forward and ensure the adjustment screw has not moved. I doubt it is normal wear and tear. Call MT. They may just tell you to readjust. Let us know what you find out. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402453#402453 ________________________________________________________________________________
Subject: Re: Inspection Camera
Date: Jun 10, 2013
I don't have one but if I buy one, it will have to fit through my spark plug hole. They would be great for valve/piston/cylinder wall/muffler/corrosion inspections. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402455#402455 ________________________________________________________________________________
Date: Jun 10, 2013
A friend of mine just bought this one from Oasis Scientific on Amazon http://www.amazon.com/Waterproof-Inspection-Borescope-Endoscope-Attachment/d p/B006SNRUL0/ref=sr_1_1?m=ARYO9J9UQ3I8W&s=merchant-items&ie=UTF8&qid=1370925 872&sr=1-1 So far, for $80 it looks ok. Albert Gardner N991RV Yuma, AZ -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Monday, June 10, 2013 9:33 PM Subject: RV10-List: Re: Inspection Camera I don't have one but if I buy one, it will have to fit through my spark plug hole. They would be great for valve/piston/cylinder wall/muffler/corrosion inspections. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402455#402455 ________________________________________________________________________________
Date: Jun 10, 2013
I'd back the screw out a bit and see if you get the RPM back. Make sure you have full travel to the screw. If you get to the screw but don't get the RPM back then I'd think your pitch stop inside the hub has changed but that seems very unlikely. Try the simple adjustment first and like Wayne said if you feel calling MT is helpful then by all means do that too. Dave Saylor 831-750-0284 CL On Mon, Jun 10, 2013 at 8:13 PM, Rob Kochman wrote: > I have the standard MT governor on my RV-10 (IO-540-D4A5). I had the max > RPM set to 2700 RPM initially, but over time it has been declining slowly, > to the point that it's about 2640 on climbout now, at 2+ years and 200+ > hours. Is that to be expected (i.e. I should just adjust the stop screw) or > is this indicative of a problem requiring further investigation? The > governor appears normal and in all other respects operates normally. > Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > * > > ________________________________________________________________________________
Date: Jun 10, 2013
Only make very small adjustment at a time. You do NOT want a prop overspeed. You want to achieve about 2650-2670 static rpm on the ground, which will get you darn close to 2700 on takeoff roll. On 6/10/2013 10:19 PM, Dave Saylor wrote: > I'd back the screw out a bit and see if you get the RPM back. Make > sure you have full travel to the screw. If you get to the screw but > don't get the RPM back then I'd think your pitch stop inside the hub > has changed but that seems very unlikely. Try the simple adjustment > first and like Wayne said if you feel calling MT is helpful then by > all means do that too. > > Dave Saylor > 831-750-0284 CL > > > On Mon, Jun 10, 2013 at 8:13 PM, Rob Kochman > wrote: > > I have the standard MT governor on my RV-10 (IO-540-D4A5). I had > the max RPM set to 2700 RPM initially, but over time it has been > declining slowly, to the point that it's about 2640 on climbout > now, at 2+ years and 200+ hours. Is that to be expected (i.e. I > should just adjust the stop screw) or is this indicative of a > problem requiring further investigation? The governor appears > normal and in all other respects operates normally. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jun 11, 2013
I got a color model from Harbor Freight that was on sale plus I had one of their 20% off coupons. Very handy in several ways. HF has stepped up their quality on several types of items of late, (although they still sell junk as well.) I'm very impressed with this unit for what it ended up costing. (About $65 as I recall) -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402460#402460 ________________________________________________________________________________
Date: Jun 11, 2013
I got a color model from Harbor Freight that was on sale plus I had one of their 20% off coupons. Very handy in several ways. HF has stepped up their quality on several types of items of late, (although they still sell junk as well.) I'm very impressed with this unit for what it ended up costing. (About $65 as I recall) -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402461#402461 ________________________________________________________________________________
Date: Jun 11, 2013
Subject: RV-10 Nose Wheel
> Back when I was building my RV-10 side by side with a buddy who was also > building an RV-10 I ordered in 2 Matco Wheels as per Tim Olson's Must Fixes: > > http://www.myrv10.com/tips/mods/Top_10_MustFixes.html Fix #3 on the > list. > > My buddy died of a heart attack before I had the chance to give him one of > the Matco Nose Wheels. I was doing the quick build and he was doing the > slow build so he had not yet ordered his finish kit. My buddy's widow sold > his unfinished RV-10 kit and I had not noticed that I still had the extra > Matco Wheel still in the shipping box until recently when I was doing some > cleaning out of my build hanger. > > I completely agree with Tim Olson that you should delete the Van's wheel > from your order of the finish kit and get the correct Matco wheel instead. > You can see a more complete write up by Tim Olson here: > > http://www.myrv10.com/N104CD/upgrades/20110326/index.html > > The Matco wheel sells for $130.00, if you want my extra Matco WHLNW511.25 > wheel send me a check for $100.00 and I will ship it to you. > > Russ Daves > 1111 Main Street > Lubbock, TX 79401 > > N710RV - Flying RV-10 > ________________________________________________________________________________
Date: Jun 11, 2013
I'll take you up on this if I'm the first to respond. Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves Sent: Tuesday, June 11, 2013 4:09 AM Subject: RV10-List: RV-10 Nose Wheel > Back when I was building my RV-10 side by side with a buddy who was also > building an RV-10 I ordered in 2 Matco Wheels as per Tim Olson's Must Fixes: > > http://www.myrv10.com/tips/mods/Top_10_MustFixes.html Fix #3 on the > list. > > My buddy died of a heart attack before I had the chance to give him one of > the Matco Nose Wheels. I was doing the quick build and he was doing the > slow build so he had not yet ordered his finish kit. My buddy's widow sold > his unfinished RV-10 kit and I had not noticed that I still had the extra > Matco Wheel still in the shipping box until recently when I was doing some > cleaning out of my build hanger. > > I completely agree with Tim Olson that you should delete the Van's wheel > from your order of the finish kit and get the correct Matco wheel instead. > You can see a more complete write up by Tim Olson here: > > http://www.myrv10.com/N104CD/upgrades/20110326/index.html > > The Matco wheel sells for $130.00, if you want my extra Matco WHLNW511.25 > wheel send me a check for $100.00 and I will ship it to you. > > Russ Daves > 1111 Main Street > Lubbock, TX 79401 > > N710RV - Flying RV-10 > ________________________________________________________________________________
Date: Jun 11, 2013
I think that applies to a fixed pitch prop or CS on the ground. Notice he said on climbout. As soon as you are rolling down the runway our prop pitch starts increasing. If he was developing 5% less power, his pitch would just start increasing later down the runway but should have still reached 2700. If he was developing less power than that then he should notice MP, FF, EGT and performance changes too. I usually get about 26.5 gph FF and 1250-1275 EGT's and on takeoff. I keep pictures on my I pad/I phone of climb and cruise numbers from my 1st flights and occassionally after to reference back to. This will help me to troubleshoot if things slowly change. I also wrote all numbers down during most phase 1 flights. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402494#402494 ________________________________________________________________________________
Date: Jun 11, 2013
I bought one a few years ago from Snap-On. It works great, but does go through the batteries. One caution in the instructions that probably applies to all of them - don't get petroleum products on the mineral lens. Since going through a spark plug hole almost guarantees that, I always have a clean dry rag to clean the lens handy. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402498#402498 ________________________________________________________________________________
Date: Jun 11, 2013
I have one of the HF cameras, and it will be OK for looking under your floor plans to find tools and hardware, but it doesn't have the resolution to see much detail. As others have mentioned, it wont fit through a plug hole, so don't plan on using it as a boroscope. I tried the Costco camera, and found it very similar to the HF. Also tried 3 of the cheapy Chinese dental cameras; focal length and optics were terrible on all 3. While watching one of the Mike Busch webinars, I noticed a picture of the high end dental camera he uses for boroscoping engines. Originally about $7,000, I found one on eBay for $280. They currently list several in the $200-250 range. It is outstanding; great optics, high resolution, excellent color, and it fits easily through a spark plug hole. Comes with a 7 ft. cable, so you could even do colonoscopies in your spare time. I hook it to a 7" led battery powered TV I found on Amazon for $70. The combo gives me amazing picture quality. If I want a permanent record for condition inspections, or to send a copy to someone, I connect it to my laptop. Search for Acucam UltraCam II. More money than the HF/Costco cameras, but much more useful. Jim Berry Rv-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402523#402523 ________________________________________________________________________________
Date: Jun 11, 2013
Jim I got a good laugh from your post. Armed with this info I am now ready to change careers Niko Nikolaos Napoli On Jun 11, 2013, at 4:54 PM, Jim Berry wrote: > > I have one of the HF cameras, and it will be OK for looking under your floor plans to find tools and hardware, but it doesn't have the resolution to see much detail. As others have mentioned, it wont fit through a plug hole, so don't plan on using it as a boroscope. I tried the Costco camera, and found it very similar to the HF. Also tried 3 of the cheapy Chinese dental cameras; focal length and optics were terrible on all 3. > > While watching one of the Mike Busch webinars, I noticed a picture of the high end dental camera he uses for boroscoping engines. Originally about $7,000, I found one on eBay for $280. They currently list several in the $200-250 range. It is outstanding; great optics, high resolution, excellent color, and it fits easily through a spark plug hole. Comes with a 7 ft. cable, so you could even do colonoscopies in your spare time. I hook it to a 7" led battery powered TV I found on Amazon for $70. The combo gives me amazing picture quality. If I want a permanent record for condition inspections, or to send a copy to someone, I connect it to my laptop. > > Search for Acucam UltraCam II. More money than the HF/Costco cameras, but much more useful. > > Jim Berry > Rv-10 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402523#402523 > > > > > > > > > > ________________________________________________________________________________
Subject: Prep of Vans wash primer
Date: Jun 11, 2013
What prep or cleaning solvent could/should be used on the Vans primed QB parts before spraying the final coat? Does it need to be scuffed before painting? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402532#402532 ________________________________________________________________________________
Subject: Re: Prep of Vans wash primer
Date: Jun 11, 2013
You need to talk with your painter or paint manufacturer. It is likely that they want you to apply their recommended primer before their final coat. They will also tell you what to do as far as surface prep prior to applying their primer. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402534#402534 ________________________________________________________________________________
Subject: MT Propeller
Date: Jun 11, 2013
Is Lessdrag with Jim Ayers still around? Where else can a good deal be found on a MT 3 blade propeller for a RV10? -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402535#402535 ________________________________________________________________________________
Date: Jun 11, 2013
I just bought a spinner from him. So I know he is still in business. He see ms to have a good line into MT in Germany. I bought my three blade from hi m two years ago and when I went to a bigger spinner I also just purchased i t from him. Dan > Subject: RV10-List: MT Propeller > From: mike(at)profishenterprises.com > Date: Tue=2C 11 Jun 2013 19:12:07 -0700 > To: rv10-list(at)matronics.com > > > Is Lessdrag with Jim Ayers still around? Where else can a good deal be fo und on a MT 3 blade propeller for a RV10? > > -------- > RV-10 #40447 > Fuselage almost done. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402535#402535 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 11, 2013
Subject: Re: MT Propeller
Yes, just ordered prop and governor from him a few weeks ago. jim(at)lesdrag.com Very competitive pricing. On Tue, Jun 11, 2013 at 7:12 PM, mds4878 wrote: > > Is Lessdrag with Jim Ayers still around? Where else can a good deal be > found on a MT 3 blade propeller for a RV10? > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402535#402535 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jun 12, 2013
Mike, I found this number for Jim. 805-795-5377 -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402545#402545 ________________________________________________________________________________
Date: Jun 12, 2013
I have a number for Jim,but it is at the airport. I will send it to you today. I think he is still at Oxnard airport,but have not seen him in over a year.Craig On Tue, Jun 11, 2013 at 7:12 PM, mds4878 wrote: > > Is Lessdrag with Jim Ayers still around? Where else can a good deal be > found on a MT 3 blade propeller for a RV10? > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402535#402535 > > ________________________________________________________________________________
Subject: Hartzell Governor
Date: Jun 12, 2013
I have the Hartzell governor. You have to replace the arm if you are using the throttle quadrant. If you do not, you will get about half the travel on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadrant. I have not had any issues after 150 hours. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402560#402560 ________________________________________________________________________________
Subject: Re: Hartzell Governor with C2YR Prop
Date: Jun 12, 2013
I have the Hartzell governor. You have to replace the arm if you are using the throttle quadrant. If you do not, you will get about half the travel on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadrant. I have not had any issues after 150 hours. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402561#402561 ________________________________________________________________________________
Date: Jun 12, 2013
Subject: Hosting change
Being forced to change my website hosting. Shopping for a hosting provider....just a heads up that the site may be suddenly gone until I find one. Tim ________________________________________________________________________________
Date: Jun 12, 2013
Jim I saw your post on the RV-10 list concerning these cameras. Can you provide a little information on how they work? For instance, how big is the camera probe? Can the picture be rotated while viewing, to avoid seeing things upside down or sideways? Can the camera angle be changed in order to look at a valve face that might be at an angle to the spark plug hole? Perhaps a link to the manufacturer's website to view the user manual? Any info would be appreciated. Bill Reining, Oakland CA RV-10 40514 Bill, I thought your questions might be of interest to others, so I am posting my response here. The probe will easily fit through a Lyc. plug hole. I can measure the exact diameter next time I am at the hangar. The picture can be rotated. The camera angle is not adjustable, but the field of view is wide enough that you can see everything within the cylinders i.e. piston head, cylinder walls, head, both valves and seats, plug holes. No blind spots. I did not receive, and could not find a users manual. I believe these cameras were made through the 90's. the company has been sold and changed directions. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402564#402564 ________________________________________________________________________________
Date: Jun 13, 2013
Bill Where did you source the new governor arm from please, as I'm installing the quadrant? Do you have a part number? Warm regards Patrick Pulis Adelaide, South Australia #40299 On 13/06/2013, at 2:51, "bill.peyton" wrote: > > I have the Hartzell governor. You have to replace the arm if you are using the throttle quadrant. If you do not, you will get about half the travel on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadrant. > I have not had any issues after 150 hours. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402560#402560 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 12, 2013
This bracket went on my prop governor when we put to Showplanes Cowl & Van' s Baffles on the -10. Looks good in place. Not sure if it's right for other setups. http://www.showplanes.com/ecom-prodshow/Propeller-Governor-Control-Bracket. html [Propeller Governor Control Bracket] [Propeller Governor Control Bracket] Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Patrick Pulis Sent: Wednesday, June 12, 2013 1:56 PM Subject: Re: RV10-List: Hartzell Governor --> > Bill Where did you source the new governor arm from please, as I'm installing th e quadrant? Do you have a part number? Warm regards Patrick Pulis Adelaide, South Australia #40299 On 13/06/2013, at 2:51, "bill.peyton" > wrote: > --> > > > I have the Hartzell governor. You have to replace the arm if you are usi ng the throttle quadrant. If you do not, you will get about half the trave l on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadran t. > I have not had any issues after 150 hours. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402560#402560 > > > > > > > > > > ----- No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: Jun 12, 2013
Bill Where did you get the Hartzell governor replacement arm? I am using the sta ndard one from Hartzell with the throttle quadrand and it works well but yo u are right. It only has half the travel on the quadrant. Leon > Subject: RV10-List: Re: Hartzell Governor with C2YR Prop > From: peyton.b(at)sbcglobal.net > Date: Wed=2C 12 Jun 2013 10:23:08 -0700 > To: rv10-list(at)matronics.com > > > I have the Hartzell governor. You have to replace the arm if you are usin g the throttle quadrant. If you do not=2C you will get about half the trave l on the quadrant=2C and half the leverage. Yes=2C it will work with the st ock arm=2C but it looks unprofessional when used in conjunction with the qu adrant. > I have not had any issues after 150 hours. > > -------- > Bill > WA0SYV > Aviation Partners=2C LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402561#402561 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 12, 2013
Direct from Hartzell. I can get the part number when I get home late tonight, but I know it's on Bill's mykitlog site, it's also on mark cooper's (charliewaffle), and I think I may have posted in on mykitlog site. Several places to find it in the mean time. It's a perfect fit if you already drilled the hole in the front baffle per the plans Sent from my iPhone On Jun 12, 2013, at 4:56 PM, Patrick Pulis wrote: Bill Where did you source the new governor arm from please, as I'm installing the quadrant? Do you have a part number? Warm regards Patrick Pulis Adelaide, South Australia #40299 On 13/06/2013, at 2:51, "bill.peyton" wrote: > > I have the Hartzell governor. You have to replace the arm if you are using the throttle quadrant. If you do not, you will get about half the travel on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadrant. > I have not had any issues after 150 hours. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402560#402560 ________________________________________________________________________________
Date: Jun 12, 2013
Thank you for your help I have the propeller spinner and governor ordered. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402579#402579 ________________________________________________________________________________
Date: Jun 12, 2013
I called Hartzell, and $27 later I had the part. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402582#402582 Attachments: http://forums.matronics.com//files/image_214.jpg ________________________________________________________________________________
Date: Jun 12, 2013
Hartzell part number 103568 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Wednesday, June 12, 2013 9:23 PM Subject: RV10-List: Re: Hartzell Governor with C2YR Prop I called Hartzell, and $27 later I had the part. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402582#402582 Attachments: http://forums.matronics.com//files/image_214.jpg ________________________________________________________________________________
Subject: Slickstart and electronic tachs
Date: Jun 13, 2013
Anybody who installed a slickstart and also has a electronic tach (which probably is everybody.)The installation instructions for the SLICKSTART wants it wired thru the left mag and comments that any electronics tachs should therefore be wired thru the RIGHT mag. The problem is that my ELECTRONICS INT"l tach instructions has me wiring to both P leads both left and right. Anyone experience this? Don Pfeiffer ________________________________________________________________________________
Subject: RV10 project for sale
Date: Jun 13, 2013
My RV10 project is for sale. Complete from firewall aft, this airplane is ready for the new builder/repairman to add the engine and paint of his choice, and fly to OSH this summer. $98,000. For a complete description, and pictures, email cjhukill(at)gmail.com ________________________________________________________________________________
Date: Jun 13, 2013
Don, I tried the "P lead" hookup without much success. I ended up going with a "Signal Generator" from Aircraft Spruce. Screws on your existing tach drive and a simple 2 wire hookup. Solves a lot of headaches.. Readout is plus or minus 3 rpm... About $70.00 http://www.aircraftspruce.com/catalog/inpages/adirh60-sg.php0.00 Jim Villani N10KQ 100 plus hours -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don Pfeiffer Sent: Thursday, June 13, 2013 4:21 AM Subject: RV10-List: Slickstart and electronic tachs Anybody who installed a slickstart and also has a electronic tach (which probably is everybody.)The installation instructions for the SLICKSTART wants it wired thru the left mag and comments that any electronics tachs should therefore be wired thru the RIGHT mag. The problem is that my ELECTRONICS INT"l tach instructions has me wiring to both P leads both left and right. Anyone experience this? Don Pfeiffer ________________________________________________________________________________
Date: Jun 14, 2013
Thanks Bill. Warm regards Patrick On 13/06/2013, at 8:15, Bob Leffler wrote: > > Direct from Hartzell. I can get the part number when I get home late tonight, but I know it's on Bill's mykitlog site, it's also on mark cooper's (charliewaffle), and I think I may have posted in on mykitlog site. Several places to find it in the mean time. > > It's a perfect fit if you already drilled the hole in the front baffle per the plans > > > Sent from my iPhone > > On Jun 12, 2013, at 4:56 PM, Patrick Pulis wrote: > > > Bill > > Where did you source the new governor arm from please, as I'm installing the quadrant? > > Do you have a part number? > > Warm regards > > Patrick Pulis > Adelaide, South Australia > #40299 > > > On 13/06/2013, at 2:51, "bill.peyton" wrote: > >> >> I have the Hartzell governor. You have to replace the arm if you are using the throttle quadrant. If you do not, you will get about half the travel on the quadrant, and half the leverage. Yes, it will work with the stock arm, but it looks unprofessional when used in conjunction with the quadrant. >> I have not had any issues after 150 hours. >> >> -------- >> Bill >> WA0SYV >> Aviation Partners, LLC >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=402560#402560 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Slickstart and electronic tachs
Date: Jun 13, 2013
I have GRT EFIS and slick start. I installed resistors in both circuits then into a spdt switch then to GRT EIS. Works great on either mag position. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402662#402662 ________________________________________________________________________________
Date: Jun 13, 2013
I have exactly the same as Wayne except I skipped the switch and wired them both into the GRT EIS. The EIS automatically shows whatever is wired to #1 unless it's zero (as during mag check) in which case it goes to #2 (and shows "#1 RPM failed" message or something like that. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402663#402663 ________________________________________________________________________________
Subject: Re: IO 540 C4B5 WANTED
Date: Jun 13, 2013
Call LyCon Engines in Visalia, CA. They seem to have a lot of engines in all stages of repair and disrepair. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402666#402666 ________________________________________________________________________________
Subject: Routing electrical conduit
Date: Jun 13, 2013
Who has figured out how to route the conduit supplied in Van's electrical kit from front to the rear of baggage area? Other than the too small holes provided on the left and occupied by the P27 battery cable plus similar on the right, it appears to me that cutting holes in some fairly beefy looking structural members may be the only way. Am I missing something? OK to cut? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402667#402667 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 14, 2013
I didn't use the Van's electrical kit but here is how I ran the three conduits on each side. Note - where these lines pass through the rear seat pan or ribs I used an adhesive to make sure there was no relative motion between the corrugated conduit and the aluminum. On the side lightning holes I added large rubber grommets in the lighting holes. I figured I needed two runs on each side, but added a third just in case. I ended up using it. I have the two ADHRS modules mounted aft of the baggage compartment as most do, so they have two 1/4" lines from the wing going aft (pitot and AOA) and two going from aft up to the panel (pitot and static) as I have a couple of analog gauges in the panel. All wire and tubing runs are in the conduit including the #2 welding cable from both masters to the starter solenoid. Carl RV-8A (sold last week) RV-10, 95 hrs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Friday, June 14, 2013 1:48 AM Subject: RV10-List: Routing electrical conduit Who has figured out how to route the conduit supplied in Van's electrical kit from front to the rear of baggage area? Other than the too small holes provided on the left and occupied by the P27 battery cable plus similar on the right, it appears to me that cutting holes in some fairly beefy looking structural members may be the only way. Am I missing something? OK to cut? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402667#402667 ________________________________________________________________________________
Date: Jun 14, 2013
Subject: Re: Routing electrical conduit
Avoid cutting structure. See Carl's response for one way to do it. On Thu, Jun 13, 2013 at 10:48 PM, bob88 wrote: > > Who has figured out how to route the conduit supplied in Van's electrical > kit from front to the rear of baggage area? Other than the too small holes > provided on the left and occupied by the P27 battery cable plus similar on > the right, it appears to me that cutting holes in some fairly beefy looking > structural members may be the only way. Am I missing something? OK to cut? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402667#402667 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: RTV silicone
Date: Jun 14, 2013
Is there an RTV silicone available from regular hardware store that is safe on aluminum? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402687#402687 ________________________________________________________________________________
Date: Jun 14, 2013
I contacted Vans when I was doing this step, and they said it was OK to enlarge the holes in the bulkhead sides to 1". Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402694#402694 ________________________________________________________________________________
Subject: How many turns to adjust low RPM on Silver Hawk EX injector
Date: Jun 14, 2013
Hi, my idle RPM is too high 900 RPM, I need to adjust the throttle lever on the Silver Hawk EX and wonder if someone knows how many turns on the adjustment nut equal 100 RPM. Thanks Mike -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402696#402696 ________________________________________________________________________________
Subject: Re: RV-10 Shop Humor
Date: Jun 14, 2013
Moral of the story, move to Nova Scotia. You will always need to wear at least a T-shirt here. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402699#402699 ________________________________________________________________________________
Date: Jun 15, 2013
The real problem is that the convoluted tubing is very difficult to fish through when it has bends and turns. That's why you need so much conduit. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402728#402728 ________________________________________________________________________________
Date: Jun 16, 2013
Carl Indeed 1 image is better than a thousand words!... Thanks However in your 2nd picture one cannot see how the 3 conduits pass through the F-1004 C & D Center section bulkheads (the plans show only two 5/8" holes), or did you stop the conduits there and only continued the electric wires forward of those bulkheads? Do you have a picture that shows forward of those bulkheads? Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: sexta-feira, 14 de Junho de 2013 12:09 Subject: RE: RV10-List: Routing electrical conduit I didn't use the Van's electrical kit but here is how I ran the three conduits on each side. Note - where these lines pass through the rear seat pan or ribs I used an adhesive to make sure there was no relative motion between the corrugated conduit and the aluminum. On the side lightning holes I added large rubber grommets in the lighting holes. I figured I needed two runs on each side, but added a third just in case. I ended up using it. I have the two ADHRS modules mounted aft of the baggage compartment as most do, so they have two 1/4" lines from the wing going aft (pitot and AOA) and two going from aft up to the panel (pitot and static) as I have a couple of analog gauges in the panel. All wire and tubing runs are in the conduit including the #2 welding cable from both masters to the starter solenoid. Carl RV-8A (sold last week) RV-10, 95 hrs ________________________________________________________________________________
Date: Jun 16, 2013
trigo(at)mail.telepac.pt wrote: > Carl > > However in your 2nd picture one cannot see how the 3 conduits pass through > the F-1004 C & D Center section bulkheads (the plans show only two 5/8" > holes), or did you stop the conduits there and only continued the electric > wires forward of those bulkheads? > -- I believe there were lightening holes - hence my comment about bends and turns. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402798#402798 ________________________________________________________________________________
Date: Jun 16, 2013
The attached photos are the only ones I can find that have more detail. The conduit ends after it goes forward through the side rib lighting holes (the ones where I installed the large grommets). Forward of that the runs just use snap bushings like Van's has in his plans. I think I had to add one additional hole on one side. Note - there is no way to get all the wires and such past the panel bulkhead just using the left side (with the supplied cover plate) per the planes. I ran a 1" or so wire bundle up the inside of the last right side rib then past the panel bulkhead in the side channel. I slightly enlarged the panel notch that straddles the side channel for added clearance. I used some plastic mesh conduit for this run. Most of it is hidden behind the little side cover plate (photos #8 & #9). Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, June 16, 2013 12:57 PM Subject: RE: RV10-List: Routing electrical conduit Carl Indeed 1 image is better than a thousand words!... Thanks However in your 2nd picture one cannot see how the 3 conduits pass through the F-1004 C & D Center section bulkheads (the plans show only two 5/8" holes), or did you stop the conduits there and only continued the electric wires forward of those bulkheads? Do you have a picture that shows forward of those bulkheads? Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: sexta-feira, 14 de Junho de 2013 12:09 Subject: RE: RV10-List: Routing electrical conduit I didn't use the Van's electrical kit but here is how I ran the three conduits on each side. Note - where these lines pass through the rear seat pan or ribs I used an adhesive to make sure there was no relative motion between the corrugated conduit and the aluminum. On the side lightning holes I added large rubber grommets in the lighting holes. I figured I needed two runs on each side, but added a third just in case. I ended up using it. I have the two ADHRS modules mounted aft of the baggage compartment as most do, so they have two 1/4" lines from the wing going aft (pitot and AOA) and two going from aft up to the panel (pitot and static) as I have a couple of analog gauges in the panel. All wire and tubing runs are in the conduit including the #2 welding cable from both masters to the starter solenoid. Carl RV-8A (sold last week) RV-10, 95 hrs ________________________________________________________________________________
Date: Jun 16, 2013
I ran my conduit straight forward like picture #8 on both sides (step drill works nice here) and made a side panel cover out of some thin aluminum I had laying around. Some PEM nuts/screws hold the side panel on. I don't use the long angled piece at all. Linn The attached photos are the only ones I can find that have more detail. The conduit ends after it goes forward through the side rib lighting holes (the ones where I installed the large grommets). Forward of that the runs just use snap bushings like Van's has in his plans. I think I had to add one additional hole on one side. Note - there is no way to get all the wires and such past the panel bulkhead just using the left side (with the supplied cover plate) per the planes. I ran a 1" or so wire bundle up the inside of the last right side rib then past the panel bulkhead in the side channel. I slightly enlarged the panel notch that straddles the side channel for added clearance. I used some plastic mesh conduit for this run. Most of it is hidden behind the little side cover plate (photos #8 & #9). Carl ________________________________________________________________________________
Date: Jun 17, 2013
I went with the solution that puts a sensor into one of the two mags. I forget the details.... and whether it operates when the mag is switched off. Why? Because I no longer look for a mag drop as a mag check. Rather, with a GRT EFIS and EIS I watch EGTs during the mag check. When one is switched off, all EGTs should rise. If there is a problem with a plug or a cylinder, that EGT won't rise. ________________________________________________________________________________
Subject: Fwd: RE: Routing electrical conduit
Date: Jun 17, 2013
Why is this a separate thread? -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402862#402862 ________________________________________________________________________________
Subject: Re: How many turns to adjust low RPM on Silver Hawk EX injector
Date: Jun 17, 2013
Probably about half a turn, IIRC. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Jun 14, 2013, at 2:41 PM, Mike Whisky wrote: > > Hi, > my idle RPM is too high 900 RPM, I need to adjust the throttle lever on the Silver Hawk EX and wonder if someone knows how many turns on the adjustment nut equal 100 RPM. > > Thanks > Mike > > -------- > RV-10 builder (final system testing) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=402696#402696 > > > > > > > > > > ________________________________________________________________________________
Subject: 2013 RV-10 Airventure Group Camping
Date: Jun 18, 2013
It's that time again! Short version: - I will once again facilitate an RV-10 group camping area in Camp Scholler. - Same basic setup routine as in past years pay starting Tuesday the week prior and get a refund if you leave early. - Pay direct to EAA for the site(s). - Contact me directly at bcondrey (at) gmail (dot) com with your name, EAA number, ticket number so I can pick up your site tags to mark your site(s). - Tim still has info from past years on his website at: http://www.myrv10.com/osh/. Except for revised payment and arrival procedures, most of the rest of it should still be valid. Long version: AirVenture is getting close and I will again facilitate an RV-10 group camping area in Camp Scholler for those interested. As in the past I will stake out sites on Tuesday (7/23 this year) the week prior to the show starting. It's done this early simply because we like the close proximity to the show, entry gates, showers, etc. Camp sites will be marked off and "staked out" that Tuesday morning and MUST have a registration tag. Yes, that means that you may be paying for a few nights you where wont be physically there camping, but the tradeoff is that youll be in a primo location, with other like-minded RV-10 builders/flyers and without having to actually get there early yourself. EAA has ramped up their scrutiny of those marking off sites and not actually paying for them (no tags). Please understand - I cannot mark off sites that that dont have paid registrations! In order to keep the workload to a minimum, I'm going to do things just like last year, so here's the deal: - Make payment to EAA direct. They now allow for prepaying campsites and specifying any arrival date. There's a link at the bottom of this page to make payment http://www.airventure.org/planning/advance_camp.html. Cost this year is $25/night and EAA charges from the first night you're registered through the end of the show (including Sunday night). If you leave early you get a refund for unused nights directly from EAA. - I will mark off and tag sites the morning of Tuesday, 7/23. The camping area really starts filling up quickly that week. - You'll need to email me your info (EAA #, name, ticket #) after you've made payment so I can build a list of the tags to pick up from EAA. To make things a little easier, please also include whether youll be in a tent, 40 Class A, etc. so we can accomoate that when laying out the sites. Theres a little latitude to make sites larger than the standard 20x30 if necessary. Please email me direct at bcondrey (at) gmail (dot) com with your info. - I'll send an email out to those on my list after the sites are staked out so you know where we'll be, along with instructions on picking up the rest of your credentials. Ill try to leave the info packs & credentials with EAA so you can just go through the express registration gate and pick them up. Last year there was a little confusion there so it may be that Ill keep them and you can call when you get close (just like I did prior to last year) Ill make that decision when I see how organized they are this year. - If you're flying in and will be camping with us I'll pick up your entire credential package so you won't have to make your way to the entry gate. If you've never camped with us, we generally will be in the area of 52nd and Lindbergh in Camp Scholler which is about a 5 minute walk to either the FlyMarket or Theater in the Woods gates. The Camp Store and a shower building are across from the FlyMarket entry gate, so about a 5 minute walk to any of the necessities. For the airshows we walk straight east across Knapp St., through the Vintage area and sit along the west side of 18/36. It's about a 10-15 minute walk from our campsites. http://www.airventure.org/planning/av11_schollermap.pdf I dont have any details yet about activities that might get organized in the camping area. Several people have contacted me offline and I've told everybody that I'd post something in June so here it is! In the past there has been at least one large group cookout. Whether we have one this year will depend on whether somebody steps up to the plate to organize it! Many of us are happy to help with that, we just need somebody to work out the up-front logistics. Here's a link to Tim's website where he's accumulated a lot of info on our group camping from past years. Except for revised payment and arrival procedures, most of the rest of it should still be valid: http://www.myrv10.com/osh/. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402952#402952 ________________________________________________________________________________
Date: Jun 18, 2013
Thanks Jesse, your right, I tried it over three iterations until I realized it just takes minor adjustments. Mike -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=402961#402961 ________________________________________________________________________________
Subject: Takeoff and Landing chart
Date: Jun 19, 2013
Anyone have a chart for their POH that covers runway takeoffs at different altitudes, over the 50 foot obstacles, landing distances, etc. Thank you! Pascal ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 19, 2013
Subject: Re: Takeoff and Landing chart
I don't have graphs and tables but I did record some empirical information in the POH, as follows: *********************************** *Take-off Performance* Safe takeoff has been demonstrated at 10,000 foot density altitude conditions. At a takeoff weight of 2600 pounds, the aircraft was 100 feet AGL after 4000 feet of runway. There was no headwind. The aircraft was run up and leaned for best performance before starting the ground roll. Flaps were set at 1/3. Typical sea level takeoff generally requires less than 1000 feet. *********************************** That's not a ton of information but it's a useful data point. We did this on the way back from OSH at KEMM. 4000' was approximately mid-field. Dave Saylor 831-750-0284 CL On Wed, Jun 19, 2013 at 12:38 PM, Pascal wrote: > Anyone have a chart for their POH that covers runway takeoffs at > different altitudes, over the 50 foot obstacles, landing distances, etc. > Thank you! > > Pascal > > > * > > * > > ________________________________________________________________________________
Date: Jun 19, 2013
Thank you Dave. Any information is helpful. Pascal From: Dave Saylor Sent: Wednesday, June 19, 2013 5:57 PM Subject: Re: RV10-List: Takeoff and Landing chart I don't have graphs and tables but I did record some empirical information in the POH, as follows: *********************************** Take-off Performance Safe takeoff has been demonstrated at 10,000 foot density altitude conditions. At a takeoff weight of 2600 pounds, the aircraft was 100 feet AGL after 4000 feet of runway. There was no headwind. The aircraft was run up and leaned for best performance before starting the ground roll. Flaps were set at 1/3. Typical sea level takeoff generally requires less than 1000 feet. *********************************** That's not a ton of information but it's a useful data point. We did this on the way back from OSH at KEMM. 4000' was approximately mid-field. Dave Saylor 831-750-0284 CL On Wed, Jun 19, 2013 at 12:38 PM, Pascal wrote: Anyone have a chart for their POH that covers runway takeoffs at different altitudes, over the 50 foot obstacles, landing distances, etc. Thank you! Pascal get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 22, 2013
Subject: NAS517-5-9 Countersink Still Making The Rounds?
Is the cabin top seat belt NAS517-5-9 countersink still making the rounds? If so, can I be put on the list? -Sean #40303 (sand, fill, rinse, repeat...) ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Subject: Re: NAS517-5-9 Countersink Still Making The Rounds?
Date: Jun 22, 2013
Recommend about 8 layers of glass on the inside of the cabin top, perhaps 6" or so in diameter around where the seat belt screw goes. I didn't view the top alone being adequate to hold the screw head from pulling out after it was properly countersunk. I also took a step to flatten out the screw head and make it a square, then imbedded it in flox. That way the screw would not rotated when tightening the nut on the inside. Sand the flox down, add some mico to feather, then ready for paint prep. Carl On Jun 22, 2013, at 2:09 PM, Sean Stephens wrote: > > Is the cabin top seat belt NAS517-5-9 countersink still making the rounds? If so, can I be put on the list? > > -Sean #40303 (sand, fill, rinse, repeat...) > > > > ________________________________________________________________________________
Date: Jun 23, 2013
Thanks Carl That is exactly what I needed to know! Cheers Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: domingo, 16 de Junho de 2013 20:12 Subject: RE: RV10-List: Routing electrical conduit The attached photos are the only ones I can find that have more detail. The conduit ends after it goes forward through the side rib lighting holes (the ones where I installed the large grommets). Forward of that the runs just use snap bushings like Van's has in his plans. I think I had to add one additional hole on one side. Note - there is no way to get all the wires and such past the panel bulkhead just using the left side (with the supplied cover plate) per the planes. I ran a 1" or so wire bundle up the inside of the last right side rib then past the panel bulkhead in the side channel. I slightly enlarged the panel notch that straddles the side channel for added clearance. I used some plastic mesh conduit for this run. Most of it is hidden behind the little side cover plate (photos #8 & #9). Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, June 16, 2013 12:57 PM Subject: RE: RV10-List: Routing electrical conduit Carl Indeed 1 image is better than a thousand words!... Thanks However in your 2nd picture one cannot see how the 3 conduits pass through the F-1004 C & D Center section bulkheads (the plans show only two 5/8" holes), or did you stop the conduits there and only continued the electric wires forward of those bulkheads? Do you have a picture that shows forward of those bulkheads? Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich Sent: sexta-feira, 14 de Junho de 2013 12:09 Subject: RE: RV10-List: Routing electrical conduit I didn't use the Van's electrical kit but here is how I ran the three conduits on each side. Note - where these lines pass through the rear seat pan or ribs I used an adhesive to make sure there was no relative motion between the corrugated conduit and the aluminum. On the side lightning holes I added large rubber grommets in the lighting holes. I figured I needed two runs on each side, but added a third just in case. I ended up using it. I have the two ADHRS modules mounted aft of the baggage compartment as most do, so they have two 1/4" lines from the wing going aft (pitot and AOA) and two going from aft up to the panel (pitot and static) as I have a couple of analog gauges in the panel. All wire and tubing runs are in the conduit including the #2 welding cable from both masters to the starter solenoid. Carl RV-8A (sold last week) RV-10, 95 hrs ________________________________________________________________________________
Date: Jun 23, 2013
Subject: doors
Hi all. I can=92t seem to find in the archives if this question has been asked before. I have my door halves roughed out and am at the stage where they are to be bonded together before the plans direct you to install the hinges. Has anyone not bonded the door halves and proceeded with the hinge install? I have just purchased the Plane Around centre latch and would like to leave the door halves separate for the time being. My concern is whether the #40 clecoes around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes . Any / all opinions are welcomed. Thx. Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: doors
Date: Jun 23, 2013
I think you will want both halves together for the hinge fitting. The doors are going to morph around enough that the hinges would likely bind later. Sent from my iPhone On Jun 23, 2013, at 4:40 PM, Rick Lark wrote: > Hi all. I can=99t seem to find in the archives if this question has been asked before. > > I have my door halves roughed out and am at the stage where they are to b e bonded together before the plans direct you to install the hinges. Has an yone not bonded the door halves and proceeded with the hinge install? I hav e just purchased the Plane Around centre latch and would like to leave the d oor halves separate for the time being. My concern is whether the #40 cleco es around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. > > Any / all opinions are welcomed. Thx. > > Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: doors
Date: Jun 23, 2013
Rick, Personally I would wait until the halves are together before drilling the hi nges. They change a lot during the process and the other skin will affect th em. Sent from my iPhone On Jun 23, 2013, at 15:40, Rick Lark wrote: > Hi all. I can=99t seem to find in the archives if this question has been asked before. > > I have my door halves roughed out and am at the stage where they are to b e bonded together before the plans direct you to install the hinges. Has an yone not bonded the door halves and proceeded with the hinge install? I hav e just purchased the Plane Around centre latch and would like to leave the d oor halves separate for the time being. My concern is whether the #40 cleco es around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. > > Any / all opinions are welcomed. Thx. > > Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: doors
Date: Jun 23, 2013
I agree with this as well. Wait until door halves are bonded to install hing es. Sent from my iPad On Jun 23, 2013, at 5:57 PM, Seano wrote: > Rick, > Personally I would wait until the halves are together before drilling the h inges. They change a lot during the process and the other skin will affect t hem. > > Sent from my iPhone > > On Jun 23, 2013, at 15:40, Rick Lark wrote: > >> Hi all. I can=99t seem to find in the archives if this question ha s been asked before. >> >> I have my door halves roughed out and am at the stage where they are to b e bonded together before the plans direct you to install the hinges. Has an yone not bonded the door halves and proceeded with the hinge install? I hav e just purchased the Plane Around centre latch and would like to leave the d oor halves separate for the time being. My concern is whether the #40 cleco es around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. >> >> Any / all opinions are welcomed. Thx. >> >> Rick >> #40956 >> Southampton, Ont >> >> >> ========================= ========= >> ://www.matronics.com/Navigator?RV10-List >> ========================= ========= >> cs.com >> ========================= ========= >> matronics.com/contribution >> ========================= ========= >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: doors
Date: Jun 23, 2013
Hi Rick The doors are a major pain. The fit WILL change SS you go through the fittin g process. I installed the billet handles after the fact. It was not a big d eal. The doors and the fitting is a big job. Cheers Les Sent from my iPhone On 2013-06-23, at 3:40 PM, Rick Lark wrote: > Hi all. I can=99t seem to find in the archives if this question has been asked before. > > I have my door halves roughed out and am at the stage where they are to b e bonded together before the plans direct you to install the hinges. Has an yone not bonded the door halves and proceeded with the hinge install? I hav e just purchased the Plane Around centre latch and would like to leave the d oor halves separate for the time being. My concern is whether the #40 cleco es around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. > > Any / all opinions are welcomed. Thx. > > Rick > #40956 > Southampton, Ont > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 23, 2013
Subject: Re: doors
The doors are flimsy even when the halves are bonded. I wish I had filled the voids with blue foam before I bonded the halves together. As it is I plan on injecting expanding foam through holes in the doors and then cleaning up the mess. Just another departure that takes up so much time. Linn On 6/23/2013 5:40 PM, Rick Lark wrote: > > Hi all.I cant seem to find in the archives if this question has been > asked before. > > Ihave my door halves roughed out and am at the stage where they are to > be bonded together before the plans direct you to install the > hinges.Has anyone not bonded the door halves and proceeded with the > hinge install?I have just purchased the Plane Around centre latch and > would like to leave the door halves separate for the time being.My > concern is whether the #40 clecoes around the window opening are > sufficient to keep the door from flexing as I position it in the > opening to drill the hinge attachment holes. > > Any / all opinions are welcomed.Thx. > > Rick > > #40956 > > Southampton, Ont > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jun 24, 2013
Subject: Re: doors
That is what I did and it helps to stiffen them up. I drilled several strat egically located 1/4" holes so that I could fit the tube of the foam can in and filled up the cavities. Make sure you use the "minimal expansion" type foam and let the access foam out the injection holes, otherwise it can def orm the door skins. When cured just clean out and fill in the holes with so me micro. I had to pick some of the foam out where the pin rods go through. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Linn Walters" <flying-nut(at)cfl.rr.com> Sent: Sunday, June 23, 2013 8:19:06 PM Subject: Re: RV10-List: doors The doors are flimsy even when the halves are bonded. I wish I had filled t he voids with blue foam before I bonded the halves together. As it is I pla n on injecting expanding foam through holes in the doors and then cleaning up the mess. Just another departure that takes up so much time. Linn On 6/23/2013 5:40 PM, Rick Lark wrote: Hi all. I can=99t seem to find in the archives if this question has b een asked before. I have my door halves roughed out and am at the stage where they are to be bonded together before the plans direct you to install the hinges. Has anyo ne not bonded the door halves and proceeded with the hinge install? I have just purchased the Plane Around centre latch and would like to leave the do or halves separate for the time being. My concern is whether the #40 clecoe s around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. Any / all opinions are welcomed. Thx. Rick #40956 Southampton, Ont No virus found in this message. Checked by AVG - www.avg.com 06/23/13 == ________________________________________________________________________________
Date: Jun 23, 2013
Subject: Re: doors
Hey thx to all that replied. I expected that bonding the doors first would be the general consensus. I guess the Plane Around latch is easy enough to install after the fact. I like the idea of using low expansion foam in any voids. I will take a good look before I do the bonding and figure out where to drill some holes. Regards, Rick On Sun, Jun 23, 2013 at 8:32 PM, wrote: > That is what I did and it helps to stiffen them up. I drilled several > strategically located 1/4" holes so that I could fit the tube of the foam > can in and filled up the cavities. Make sure you use the "minimal > expansion" type foam and let the access foam out the injection holes, > otherwise it can deform the door skins. When cured just clean out and fi ll > in the holes with some micro. I had to pick some of the foam out where t he > pin rods go through. > > David Clifford > > RV-10 Builder > Howell, MI > > ------------------------------ > *From: *"Linn Walters" <flying-nut(at)cfl.rr.com> > *To: *rv10-list(at)matronics.com > *Sent: *Sunday, June 23, 2013 8:19:06 PM > *Subject: *Re: RV10-List: doors > > The doors are flimsy even when the halves are bonded. I wish I had fille d > the voids with blue foam before I bonded the halves together. As it is I > plan on injecting expanding foam through holes in the doors and then > cleaning up the mess. Just another departure that takes up so much time. > Linn > > On 6/23/2013 5:40 PM, Rick Lark wrote: > > Hi all. I can=92t seem to find in the archives if this question has bee n > asked before. > > > I have my door halves roughed out and am at the stage where they are to > be bonded together before the plans direct you to install the hinges. Ha s > anyone not bonded the door halves and proceeded with the hinge install? I > have just purchased the Plane Around centre latch and would like to leave > the door halves separate for the time being. My concern is whether the > #40 clecoes around the window opening are sufficient to keep the door fro m > flexing as I position it in the opening to drill the hinge attachment hol es. > > > Any / all opinions are welcomed. Thx. > > > Rick > > #40956 > > Southampton, Ont > > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com > 06/23/13 > > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: doors
Date: Jun 24, 2013
U28gbm8gaXNzdWUgd2l0aCBhZGRlZCB3ZWlnaHQgb3IgdGhlIHBvdGVudGlhbCBvZiByZXRhaW5p bmcgbW9pc3R1cmUgb3Igd2F0ZXIgaW4gdGhlIGZpbGxlZCBkb29ycz8NCg0KUm9iaW4NCg0KRnJv bTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYx MC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgZGF2aWRzb3V0cG9zdEBj b21jYXN0Lm5ldA0KU2VudDogU3VuZGF5LCBKdW5lIDIzLCAyMDEzIDU6MzIgUE0NClRvOiBydjEw LWxpc3RAbWF0cm9uaWNzLmNvbQ0KU3ViamVjdDogUmU6IFJWMTAtTGlzdDogZG9vcnMNCg0KVGhh dCBpcyB3aGF0IEkgZGlkIGFuZCBpdCBoZWxwcyB0byBzdGlmZmVuIHRoZW0gdXAuICBJIGRyaWxs ZWQgc2V2ZXJhbCBzdHJhdGVnaWNhbGx5IGxvY2F0ZWQgMS80IiBob2xlcyBzbyB0aGF0IEkgY291 bGQgZml0IHRoZSB0dWJlIG9mIHRoZSBmb2FtIGNhbiBpbiBhbmQgZmlsbGVkIHVwIHRoZSBjYXZp dGllcy4gIE1ha2Ugc3VyZSB5b3UgdXNlIHRoZSAibWluaW1hbCBleHBhbnNpb24iIHR5cGUgZm9h bSBhbmQgbGV0IHRoZSBhY2Nlc3MgZm9hbSBvdXQgdGhlIGluamVjdGlvbiBob2xlcywgIG90aGVy d2lzZSBpdCBjYW4gZGVmb3JtIHRoZSBkb29yIHNraW5zLiAgV2hlbiBjdXJlZCBqdXN0IGNsZWFu IG91dCBhbmQgZmlsbCBpbiB0aGUgaG9sZXMgd2l0aCBzb21lIG1pY3JvLiAgSSBoYWQgdG8gcGlj ayBzb21lIG9mIHRoZSBmb2FtIG91dCB3aGVyZSB0aGUgcGluIHJvZHMgZ28gdGhyb3VnaC4NCkRh dmlkIENsaWZmb3JkDQoNClJWLTEwIEJ1aWxkZXINCkhvd2VsbCwgIE1JDQoNCl9fX19fX19fX19f X19fX19fX19fX19fX19fX19fX19fDQpGcm9tOiAiTGlubiBXYWx0ZXJzIiA8Zmx5aW5nLW51dEBj ZmwucnIuY29tPG1haWx0bzpmbHlpbmctbnV0QGNmbC5yci5jb20+Pg0KVG86IHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4NClNlbnQ6IFN1bmRh eSwgSnVuZSAyMywgMjAxMyA4OjE5OjA2IFBNDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBkb29y cw0KVGhlIGRvb3JzIGFyZSBmbGltc3kgZXZlbiB3aGVuIHRoZSBoYWx2ZXMgYXJlIGJvbmRlZC4g IEkgd2lzaCBJIGhhZCBmaWxsZWQgdGhlIHZvaWRzIHdpdGggYmx1ZSBmb2FtIGJlZm9yZSBJIGJv bmRlZCB0aGUgaGFsdmVzIHRvZ2V0aGVyLiAgQXMgaXQgaXMgSSBwbGFuIG9uIGluamVjdGluZyBl eHBhbmRpbmcgZm9hbSB0aHJvdWdoIGhvbGVzIGluIHRoZSBkb29ycyBhbmQgdGhlbiBjbGVhbmlu ZyB1cCB0aGUgbWVzcy4gIEp1c3QgYW5vdGhlciBkZXBhcnR1cmUgdGhhdCB0YWtlcyB1cCBzbyBt dWNoIHRpbWUuDQpMaW5uDQoNCk9uIDYvMjMvMjAxMyA1OjQwIFBNLCBSaWNrIExhcmsgd3JvdGU6 DQoNCkhpIGFsbC4gIEkgY2Fu4oCZdCBzZWVtIHRvIGZpbmQgaW4gdGhlIGFyY2hpdmVzIGlmIHRo aXMgcXVlc3Rpb24gaGFzIGJlZW4gYXNrZWQgYmVmb3JlLg0KDQoNCg0KSSAgaGF2ZSBteSBkb29y IGhhbHZlcyByb3VnaGVkIG91dCBhbmQgYW0gYXQgdGhlIHN0YWdlIHdoZXJlIHRoZXkgYXJlIHRv IGJlIGJvbmRlZCB0b2dldGhlciBiZWZvcmUgdGhlIHBsYW5zIGRpcmVjdCB5b3UgdG8gaW5zdGFs bCB0aGUgaGluZ2VzLiAgSGFzIGFueW9uZSBub3QgYm9uZGVkIHRoZSBkb29yIGhhbHZlcyBhbmQg cHJvY2VlZGVkIHdpdGggdGhlIGhpbmdlIGluc3RhbGw/ICBJIGhhdmUganVzdCBwdXJjaGFzZWQg dGhlIFBsYW5lIEFyb3VuZCBjZW50cmUgbGF0Y2ggYW5kIHdvdWxkIGxpa2UgdG8gbGVhdmUgdGhl IGRvb3IgaGFsdmVzIHNlcGFyYXRlIGZvciB0aGUgdGltZSBiZWluZy4gIE15IGNvbmNlcm4gaXMg d2hldGhlciB0aGUgIzQwIGNsZWNvZXMgYXJvdW5kIHRoZSB3aW5kb3cgb3BlbmluZyBhcmUgc3Vm ZmljaWVudCB0byBrZWVwIHRoZSBkb29yIGZyb20gZmxleGluZyBhcyBJIHBvc2l0aW9uIGl0IGlu IHRoZSBvcGVuaW5nIHRvIGRyaWxsIHRoZSBoaW5nZSBhdHRhY2htZW50IGhvbGVzLg0KDQoNCg0K QW55IC8gYWxsIG9waW5pb25zIGFyZSB3ZWxjb21lZC4gIFRoeC4NCg0KDQoNClJpY2sNCg0KIzQw OTU2DQoNClNvdXRoYW1wdG9uLCBPbnQNCg0KDQoNCg0KDQoNCk5vIHZpcnVzIGZvdW5kIGluIHRo aXMgbWVzc2FnZS4NCkNoZWNrZWQgYnkgQVZHIC0gd3d3LmF2Zy5jb208aHR0cDovL3d3dy5hdmcu Y29tPg0KMDYvMjMvMTMNCg0KDQoNCg0KDQoNCmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQp0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t DQoNCl9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0K DQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVt IC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJy b3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNj cmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwg Q2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KDQpfLT0N Cg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0 DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9S VU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdl YiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBX ZWIgU2l0ZSAtDQoNCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQoN Cl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1p bi4NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KDQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpObyB2aXJ1cyBm b3VuZCBpbiB0aGlzIG1lc3NhZ2UuDQpDaGVja2VkIGJ5IEFWRyAtIHd3dy5hdmcuY29tPGh0dHA6 Ly93d3cuYXZnLmNvbT4NClZlcnNpb246IDIwMTMuMC4yOTA0IC8gVmlydXMgRGF0YWJhc2U6IDMx OTkvNjQyOCAtIFJlbGVhc2UgRGF0ZTogMDYvMjAvMTMNCg= ________________________________________________________________________________
Date: Jun 24, 2013
Subject: Re: doors
Foam adds very little weight to the door, stiffens the door considerably an d there should not be any exterior openings for water to enter if you drill your filling holes on the interior side of the doors and plug them when yo u are done. All of the Rutan based plans built aircraft such as the Long-EZ and Cozy are made of foam sandwiched by fiberglass. Here's an old demo vid eo from Burt himself. http://www.youtube.com/watch?v=7eUt0YnNF3o David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Robin Marks" <robin(at)PaintTheWeb.com> Sent: Sunday, June 23, 2013 11:03:08 PM Subject: RE: RV10-List: doors So no issue with added weight or the potential of retaining moisture or wat er in the filled doors? Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of davidsoutpost(at)comcast.net Sent: Sunday, June 23, 2013 5:32 PM Subject: Re: RV10-List: doors That is what I did and it helps to stiffen them up. I drilled several strat egically located 1/4" holes so that I could fit the tube of the foam can in and filled up the cavities. Make sure you use the "minimal expansion" type foam and let the access foam out the injection holes, otherwise it can def orm the door skins. When cured just clean out and fill in the holes with so me micro. I had to pick some of the foam out where the pin rods go through. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Linn Walters" < flying-nut(at)cfl.rr.com > Sent: Sunday, June 23, 2013 8:19:06 PM Subject: Re: RV10-List: doors The doors are flimsy even when the halves are bonded. I wish I had filled t he voids with blue foam before I bonded the halves together. As it is I pla n on injecting expanding foam through holes in the doors and then cleaning up the mess. Just another departure that takes up so much time. Linn On 6/23/2013 5:40 PM, Rick Lark wrote: Hi all. I can=99t seem to find in the archives if this question has b een asked before. I have my door halves roughed out and am at the stage where they are to be bonded together before the plans direct you to install the hinges. Has anyo ne not bonded the door halves and proceeded with the hinge install? I have just purchased the Plane Around centre latch and would like to leave the do or halves separate for the time being. My concern is whether the #40 clecoe s around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. Any / all opinions are welcomed. Thx. Rick #40956 Southampton, Ont No virus found in this message. Checked by AVG - www.avg.com 06/23/13 get="_blank"> http://www.matronics.com/Navigator?RV10-List tp://forums.ma -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- -=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- =C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2-=C2- -M ============== No virus found in this message. Checked by AVG - www.avg.com =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD,=EF=BD=EF=BD=EF=BD% =EF=BD=EF=BDM4=EF=BD=EF=BD=EF=BDx=EF=BD=EF=BD=EF=BD =EF=BDw=EF=BDr=EF=BD=EF=BD=EF=BD=EF=BD ________________________________________________________________________________
Subject: doors
Date: Jun 24, 2013
QXdlc29tZSB2aWRlby4NClJvYmluDQpEbyBOb3QgQXJjaGl2ZQ0KDQpGcm9tOiBvd25lci1ydjEw LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBkYXZpZHNvdXRwb3N0QGNvbWNhc3QubmV0DQpT ZW50OiBTdW5kYXksIEp1bmUgMjMsIDIwMTMgODo0NiBQTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25p Y3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBkb29ycw0KDQpGb2FtIGFkZHMgdmVyeSBs aXR0bGUgd2VpZ2h0IHRvIHRoZSBkb29yLCBzdGlmZmVucyB0aGUgZG9vciBjb25zaWRlcmFibHkg YW5kIHRoZXJlIHNob3VsZCBub3QgYmUgYW55IGV4dGVyaW9yIG9wZW5pbmdzIGZvciB3YXRlciB0 byBlbnRlciBpZiB5b3UgZHJpbGwgeW91ciBmaWxsaW5nIGhvbGVzIG9uIHRoZSBpbnRlcmlvciBz aWRlIG9mIHRoZSBkb29ycyBhbmQgcGx1ZyB0aGVtIHdoZW4geW91IGFyZSBkb25lLiAgIEFsbCBv ZiB0aGUgUnV0YW4gYmFzZWQgcGxhbnMgYnVpbHQgYWlyY3JhZnQgc3VjaCBhcyB0aGUgTG9uZy1F WiBhbmQgQ296eSBhcmUgbWFkZSBvZiBmb2FtIHNhbmR3aWNoZWQgYnkgZmliZXJnbGFzcy4gICBI ZXJlJ3MgYW4gb2xkIGRlbW8gdmlkZW8gZnJvbSBCdXJ0IGhpbXNlbGYuICBodHRwOi8vd3d3Lnlv dXR1YmUuY29tL3dhdGNoP3Y9N2VVdDBZbk5GM28NCkRhdmlkIENsaWZmb3JkDQoNClJWLTEwIEJ1 aWxkZXINCkhvd2VsbCwgIE1JDQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpG cm9tOiAiUm9iaW4gTWFya3MiIDxyb2JpbkBQYWludFRoZVdlYi5jb208bWFpbHRvOnJvYmluQFBh aW50VGhlV2ViLmNvbT4+DQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2MTAt bGlzdEBtYXRyb25pY3MuY29tPg0KU2VudDogU3VuZGF5LCBKdW5lIDIzLCAyMDEzIDExOjAzOjA4 IFBNDQpTdWJqZWN0OiBSRTogUlYxMC1MaXN0OiBkb29ycw0KDQoNClNvIG5vIGlzc3VlIHdpdGgg YWRkZWQgd2VpZ2h0IG9yIHRoZSBwb3RlbnRpYWwgb2YgcmV0YWluaW5nIG1vaXN0dXJlIG9yIHdh dGVyIGluIHRoZSBmaWxsZWQgZG9vcnM/DQoNClJvYmluDQoNCkZyb206IG93bmVyLXJ2MTAtbGlz dC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbTxtYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRy b25pY3MuY29tPiBbbWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0g T24gQmVoYWxmIE9mIGRhdmlkc291dHBvc3RAY29tY2FzdC5uZXQ8bWFpbHRvOmRhdmlkc291dHBv c3RAY29tY2FzdC5uZXQ+DQpTZW50OiBTdW5kYXksIEp1bmUgMjMsIDIwMTMgNTozMiBQTQ0KVG86 IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9uaWNzLmNvbT4N ClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IGRvb3JzDQoNClRoYXQgaXMgd2hhdCBJIGRpZCBhbmQg aXQgaGVscHMgdG8gc3RpZmZlbiB0aGVtIHVwLiAgSSBkcmlsbGVkIHNldmVyYWwgc3RyYXRlZ2lj YWxseSBsb2NhdGVkIDEvNCIgaG9sZXMgc28gdGhhdCBJIGNvdWxkIGZpdCB0aGUgdHViZSBvZiB0 aGUgZm9hbSBjYW4gaW4gYW5kIGZpbGxlZCB1cCB0aGUgY2F2aXRpZXMuICBNYWtlIHN1cmUgeW91 IHVzZSB0aGUgIm1pbmltYWwgZXhwYW5zaW9uIiB0eXBlIGZvYW0gYW5kIGxldCB0aGUgYWNjZXNz IGZvYW0gb3V0IHRoZSBpbmplY3Rpb24gaG9sZXMsICBvdGhlcndpc2UgaXQgY2FuIGRlZm9ybSB0 aGUgZG9vciBza2lucy4gIFdoZW4gY3VyZWQganVzdCBjbGVhbiBvdXQgYW5kIGZpbGwgaW4gdGhl IGhvbGVzIHdpdGggc29tZSBtaWNyby4gIEkgaGFkIHRvIHBpY2sgc29tZSBvZiB0aGUgZm9hbSBv dXQgd2hlcmUgdGhlIHBpbiByb2RzIGdvIHRocm91Z2guDQpEYXZpZCBDbGlmZm9yZA0KDQpSVi0x MCBCdWlsZGVyDQpIb3dlbGwsICBNSQ0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fX18N CkZyb206ICJMaW5uIFdhbHRlcnMiIDxmbHlpbmctbnV0QGNmbC5yci5jb208bWFpbHRvOmZseWlu Zy1udXRAY2ZsLnJyLmNvbT4+DQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRvOnJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU2VudDogU3VuZGF5LCBKdW5lIDIzLCAyMDEzIDg6MTk6 MDYgUE0NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IGRvb3JzDQpUaGUgZG9vcnMgYXJlIGZsaW1z eSBldmVuIHdoZW4gdGhlIGhhbHZlcyBhcmUgYm9uZGVkLiAgSSB3aXNoIEkgaGFkIGZpbGxlZCB0 aGUgdm9pZHMgd2l0aCBibHVlIGZvYW0gYmVmb3JlIEkgYm9uZGVkIHRoZSBoYWx2ZXMgdG9nZXRo ZXIuICBBcyBpdCBpcyBJIHBsYW4gb24gaW5qZWN0aW5nIGV4cGFuZGluZyBmb2FtIHRocm91Z2gg aG9sZXMgaW4gdGhlIGRvb3JzIGFuZCB0aGVuIGNsZWFuaW5nIHVwIHRoZSBtZXNzLiAgSnVzdCBh bm90aGVyIGRlcGFydHVyZSB0aGF0IHRha2VzIHVwIHNvIG11Y2ggdGltZS4NCkxpbm4NCg0KT24g Ni8yMy8yMDEzIDU6NDAgUE0sIFJpY2sgTGFyayB3cm90ZToNCg0KSGkgYWxsLiAgSSBjYW7igJl0 IHNlZW0gdG8gZmluZCBpbiB0aGUgYXJjaGl2ZXMgaWYgdGhpcyBxdWVzdGlvbiBoYXMgYmVlbiBh c2tlZCBiZWZvcmUuDQoNCg0KDQpJICBoYXZlIG15IGRvb3IgaGFsdmVzIHJvdWdoZWQgb3V0IGFu ZCBhbSBhdCB0aGUgc3RhZ2Ugd2hlcmUgdGhleSBhcmUgdG8gYmUgYm9uZGVkIHRvZ2V0aGVyIGJl Zm9yZSB0aGUgcGxhbnMgZGlyZWN0IHlvdSB0byBpbnN0YWxsIHRoZSBoaW5nZXMuICBIYXMgYW55 b25lIG5vdCBib25kZWQgdGhlIGRvb3IgaGFsdmVzIGFuZCBwcm9jZWVkZWQgd2l0aCB0aGUgaGlu Z2UgaW5zdGFsbD8gIEkgaGF2ZSBqdXN0IHB1cmNoYXNlZCB0aGUgUGxhbmUgQXJvdW5kIGNlbnRy ZSBsYXRjaCBhbmQgd291bGQgbGlrZSB0byBsZWF2ZSB0aGUgZG9vciBoYWx2ZXMgc2VwYXJhdGUg Zm9yIHRoZSB0aW1lIGJlaW5nLiAgTXkgY29uY2VybiBpcyB3aGV0aGVyIHRoZSAjNDAgY2xlY29l cyBhcm91bmQgdGhlIHdpbmRvdyBvcGVuaW5nIGFyZSBzdWZmaWNpZW50IHRvIGtlZXAgdGhlIGRv b3IgZnJvbSBmbGV4aW5nIGFzIEkgcG9zaXRpb24gaXQgaW4gdGhlIG9wZW5pbmcgdG8gZHJpbGwg dGhlIGhpbmdlIGF0dGFjaG1lbnQgaG9sZXMuDQoNCg0KDQpBbnkgLyBhbGwgb3BpbmlvbnMgYXJl IHdlbGNvbWVkLiAgVGh4Lg0KDQoNCg0KUmljaw0KDQojNDA5NTYNCg0KU291dGhhbXB0b24sIE9u dA0KDQoNCg0KDQoNCg0KTm8gdmlydXMgZm91bmQgaW4gdGhpcyBtZXNzYWdlLg0KQ2hlY2tlZCBi eSBBVkcgLSB3d3cuYXZnLmNvbTxodHRwOi8vd3d3LmF2Zy5jb20+DQowNi8yMy8xMw0KDQoNCg0K DQoNCg0KZ2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYx MC1MaXN0DQoNCnRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KX2JsYW5rIj5odHRwOi8vd3d3 Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCg0KDQoNCg0KDQo9PT09PT09PT09PT09PQ0K VjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KZT4gcHJlPiB0b3I/UlYxMC1MaXN0IiB0YXJnZXQ9Il9i bGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCj09PT09 PT09PT09PT09DQpic3A7ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KZT4gcmdldD0iX2Js YW5rIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCj09PT09PT09PT09PT09DQpic3A7ICAt IExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCmJzcDsgICAgICAgICAgICAgICAgICAgLU1h dHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KYnV0aW9uIiB0YXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPT09PT09PT09PT09PT0NCg0KDQoNCl9fX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fDQpObyB2aXJ1cyBmb3VuZCBpbiB0aGlzIG1lc3Nh Z2UuDQpDaGVja2VkIGJ5IEFWRyAtIHd3dy5hdmcuY29tPGh0dHA6Ly93d3cuYXZnLmNvbT4NCnA+ DQrvv73vv73vv71+77+977+9LO+/ve+/ve+/vSXvv73vv71NNO+/ve+/ve+/vXjvv73vv73vv73v v71377+9cu+/ve+/ve+/ve+/vQ0KDQoNCg0KDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAtIFRo ZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBG ZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoNCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGll cyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBE b3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQoNCl8tPSBQaG90b3NoYXJlLCBhbmQg bXVjaCBtdWNoIG1vcmU6DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3Mu Y29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAg ICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0gU2FtZSBncmVhdCBjb250ZW50IGFs c28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09DQoNCl8tPSAgIC0tPiBodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KXy09DQoNCl8tPT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCl8tPSAgICAgICAgICAg ICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCg0KXy09ICBUaGFuayB5b3UgZm9yIHlv dXIgZ2VuZXJvdXMgc3VwcG9ydCENCg0KXy09ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRyb25p Y3MuY29tL2NvbnRyaWJ1dGlvbg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fX18NCk5vIHZpcnVzIGZvdW5kIGluIHRoaXMgbWVzc2FnZS4NCkNoZWNrZWQgYnkg QVZHIC0gd3d3LmF2Zy5jb208aHR0cDovL3d3dy5hdmcuY29tPg0KVmVyc2lvbjogMjAxMy4wLjI5 MDQgLyBWaXJ1cyBEYXRhYmFzZTogMzE5OS82NDI4IC0gUmVsZWFzZSBEYXRlOiAwNi8yMC8xMw0K ________________________________________________________________________________
Subject: Re: doors
Date: Jun 24, 2013
Rick, It would not be wise to try to drill the hinges until after the doors are bonded. I installed foam inside the doors in selected areas for insulating purposes. I also was able to install the center door latch prior to bonding the second door. It actually was a lot easier. The only thing you need to be aware of with the center door latch is to make sure it is installed no lower than what is called out in the instructions. A little higher, like 1/16", is better. The reason for this is the latching cam will rub on the Mcmaster-Carr trim as the door closes, and once it is bonded in place there is no way to change it. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403287#403287 ________________________________________________________________________________
Subject: Re: doors
Date: Jun 24, 2013
For stiffening the doors I would also recommend filling the epoxy with flox and not cab-o-sil (p45-05, step 5) as suggested in the plans. I tried both. With micro it was easy and oh so amusing to pull the door halves apart. The flox is rock solid and noticeably stiffer. After bonding you can use a high power light (e.g. 150W flood lamp) to backlight the joint and spot if you left any voids. It helps to leave one void deliberately to calibrate your inspection process ;-) Cheers, Gordon 41015 Switzerland On Jun 24, 2013, at 3:22 AM, Rick Lark wrote: > Hey thx to all that replied. I expected that bonding the doors first would be the general consensus. I guess the Plane Around latch is easy enough to install after the fact. I like the idea of using low expansion foam in any voids. I will take a good look before I do the bonding and figure out where to drill some holes. > Regards, Rick > > > On Sun, Jun 23, 2013 at 8:32 PM, wrote: > That is what I did and it helps to stiffen them up. I drilled several strategically located 1/4" holes so that I could fit the tube of the foam can in and filled up the cavities. Make sure you use the "minimal expansion" type foam and let the access foam out the injection holes, otherwise it can deform the door skins. When cured just clean out and fill in the holes with some micro. I had to pick some of the foam out where the pin rods go through. > > David Clifford > > RV-10 Builder > Howell, MI > > From: "Linn Walters" <flying-nut(at)cfl.rr.com> > To: rv10-list(at)matronics.com > Sent: Sunday, June 23, 2013 8:19:06 PM > Subject: Re: RV10-List: doors > > The doors are flimsy even when the halves are bonded. I wish I had filled the voids with blue foam before I bonded the halves together. As it is I plan on injecting expanding foam through holes in the doors and then cleaning up the mess. Just another departure that takes up so much time. > Linn > > On 6/23/2013 5:40 PM, Rick Lark wrote: > Hi all. I can=92t seem to find in the archives if this question has been asked before. > > I have my door halves roughed out and am at the stage where they are to be bonded together before the plans direct you to install the hinges. Has anyone not bonded the door halves and proceeded with the hinge install? I have just purchased the Plane Around centre latch and would like to leave the door halves separate for the time being. My concern is whether the #40 clecoes around the window opening are sufficient to keep the door from flexing as I position it in the opening to drill the hinge attachment holes. > > Any / all opinions are welcomed. Thx. > > Rick > #40956 > Southampton, Ont > > > > No virus found in this message. > Checked by AVG - www.avg.com > 06/23/13 > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > ________________________________________________________________________________
Subject: Re: 2013 RV-10 Airventure Group Camping
Date: Jun 24, 2013
It was pointed out to me that the original post had a typo on the email address. I corrected that but just to restate, the correct email address should be: condreyb (at) gmail (dot) com. If you sent an email to that address about camping at Airventure this year, please resend to me. I understand that "Barry" (owner of the incorrect email address) has been good enough to redirect at least one person... Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403347#403347 ________________________________________________________________________________
Subject: Re: doors
Date: Jun 24, 2013
Rick, I agree with all the above...one thing I would add is when you go to cleco your door skins to the fuse, One,make sure your cabin top is bolted to fuse in place as you would on final install and Two DO NOT use the two fore and aft dimple index to fix the doors to the fuse during epoxy fit. I found the indicator dimples to be aprox 3/16 to high on the door on ours. You will find the doors will be too low when you go trim to the cabin top opening. I did this on left door and had to roll the complete door up to get adequate clearance between the lower jam and door. You don't want this as you formed the door to fit the cabin top curve. Right side we built spacers for the lower and sides to fit between the jam and door inner ledge. Remember to add the door skins thickness dim to the spacer as the door needs to drop down to be flush with the cabin top when you trim door to fit the opening. This will also ensure that Seans latch will clear the lower jam when you install them. Hope this makes sense....I almost threw away the left door after I realized what I did. -------- Jackm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403371#403371 ________________________________________________________________________________
Subject: Re: doors
Date: Jun 25, 2013
Thx Jack I also had index holes that didn't match up worth a darn, so I used a spacer to raise the doors and then drilled the doors to the fuse all this while the top was bolted to the fuse. I'm hoping they are high enough to have Sean's latch clears the McMaster seal. Thx, Rick Sent from my iPhone On 2013-06-25, at 1:53 AM, "Jackm" wrote: > > Rick, > > I agree with all the above...one thing I would add is when you go to cleco your door skins to the fuse, One,make sure your cabin top is bolted to fuse in place as you would on final install and Two DO NOT use the two fore and aft dimple index to fix the doors to the fuse during epoxy fit. I found the indicator dimples to be aprox 3/16 to high on the door on ours. You will find the doors will be too low when you go trim to the cabin top opening. I did this on left door and had to roll the complete door up to get adequate clearance between the lower jam and door. You don't want this as you formed the door to fit the cabin top curve. Right side we built spacers for the lower and sides to fit between the jam and door inner ledge. Remember to add the door skins thickness dim to the spacer as the door needs to drop down to be flush with the cabin top when you trim door to fit the opening. This will also ensure that Seans latch will clear the lower jam when you install them. Hope ! > this makes sense....I almost threw away the left door after I realized what I did. > > -------- > Jackm > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403371#403371 > > > > > > > > > > ________________________________________________________________________________
Subject: FAB Box Servo Mixture Arm
Date: Jun 25, 2013
I have a IO 540 with a bendix fuel servo that has a straight mixture arm but I need the offset arm. Does anyone have one for sale or trade? The straight arm doesn't fit the FAB box from Van's. :( -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403437#403437 ________________________________________________________________________________
Subject: C/S-13 SPINNER FOR SALE
Date: Jun 25, 2013
I bought a C/S-13 spinner for my plane but I will not be using it because a spinner comes with my prop. I want 120.00 plus shipping. Mike 612-590-8604. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403439#403439 ________________________________________________________________________________
Subject: Re: FAB Box Servo Mixture Arm
Date: Jun 27, 2013
I would check with your engine provider. Barrett, swapped the arm out for me. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403534#403534 ________________________________________________________________________________
Date: Jun 30, 2013
Subject: Fuel Question
A little background: we just finished the Hayward Air Rally ( www.hwdairrally.org) for about the 10th time. We placed 8th out of 22, which is about where we usually place. The rally judges us on fuel and time estimates during routes from the Hayward, CA to Redding, then to Bend, OR. We were 1.2 gallons off of our fuel estimate and 37 seconds off our time estimate. The winner was 6 seconds and 0.3 gallons off his estimate, in a 172. This year we tried the "Glass Class", which allows us to us to use all available technology, instead of just a compass, map, and stopwatch. The penalties are tripled and our score ended up similar to our past entries. The winner was in traditional class. Every year the fuel penalty is our nemesis. We know why our time was off, and next year we'll adjust for that. But we can't nail the fuel for any amount of trying, even using the totalizer. There seem to be two issues. First, the totalizer doesn't seem to be as accurate at low ie, idle, power settings. It generally reads 2-3 gph, which we think is high. Second is refilling the tanks to the same level each time. We can't top the tanks or it will vent enough overboard to ruin our score. We use tabs that I installed to fill the tanks to about 28.5 gallons. Even refilling to the same spot on the tab doesn't really return the results we want. We need a system that will show when a tank is refilled to just the same level each time. Any suggestions? The rules allow us to level the plane, which we started doing this year, and we can use a stick so long as it only has a single calibration mark. We haven't used a stick yet. I'm also interested in what others have noticed as far as extreme accuracy of their totalizer. Plenty of folks report sub-gallon accuracy. Anyone doing much better than that? How? Last thing, the rally will be going from Hayward, California to Oshkosh for AirVenture next year. It's a lot of fun, even if somewhat frustrating, and of course a great challenge. If anyone is interested, please look into it. More RVs would be great! Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Subject: Re: Fuel Question
Date: Jun 30, 2013
It is surprising how much temperature plays a role in the volumetric measurement of fuel. For extreme accuracy, you would need a temperature adjustment formula or graph to fine tune a dipstick measurement. Airliners use dripsticks underneath the wings but the reference tables are graphed by different temperature ranges. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. Finishing kit and FWF kit in progress. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403670#403670 ________________________________________________________________________________
Date: Jun 30, 2013
37 seconds? That could just be the tower sequencing you #2 instead of #1. How can you plan for that? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403671#403671 ________________________________________________________________________________
Date: Jul 01, 2013
These days we're all assigned GPS loggers. Ideally, the flagger gives us the "GO" sign at the top of the minute but even if they don't, the data shows pretty clearly when we start moving within a second or so. We get a dedicated runway (usually) so we can take our time for the start. ATC isn't involved, and it's the total flight time we're concerned with, not the UTC start and stop--thankfully. The end time is a low pass over an airport near the end point. Dave Saylor 831-750-0284 CL On Sun, Jun 30, 2013 at 8:45 PM, Bob Turner wrote: > > 37 seconds? That could just be the tower sequencing you #2 instead of #1. > How can you plan for that? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403671#403671 > > ________________________________________________________________________________
Date: Jul 01, 2013
Yep, temp is huge, especially when we used to vent half a gallon overboard before we even started! The planes are topped and impounded the night before departure, so the fuel gets to warm up all afternoon. I think we've handled that but I wouldn't be surprised if the fuel flow is also affected. But it's not impossible, and it's not dumb luck...I just don't know how it's done yet. Dave Saylor 831-750-0284 CL On Sun, Jun 30, 2013 at 8:42 PM, woxofswa wrote: > > It is surprising how much temperature plays a role in the volumetric > measurement of fuel. > > For extreme accuracy, you would need a temperature adjustment formula or > graph to fine tune a dipstick measurement. Airliners use dripsticks > underneath the wings but the reference tables are graphed by different > temperature ranges. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. Finishing > kit and FWF kit in progress. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403670#403670 > > ________________________________________________________________________________
Subject: Fuselage Mobile Jig
Date: Jul 01, 2013
Wanted to share this for those that might be ready for fuselage mobility. Attached photos show a simple and inexpensive way to have a mobile yet secure fuselage structure as you build. I have gotten in and out of the fuselage hundreds of times and moved it everywhere from front yard to backwards in the garage and it worked great. Didn=92t want to share it with the group until I was sure it worked for me..... It did, and I=92d do it again. Use air tires, not hardened rubber. Mine just moved up in the world to permanent gear. Not it=92s first time either as I=92ve already fit and finished legs, fairings, and pants some time ago. At that time this jig came off, then when complete, went right back on. It is much easier to work on the fuselage when down low then when on its gear. Hope this helps some of you fellow builders...=85. Rich Hansen RV-6A Sold RV-10 Forever finishing! ________________________________________________________________________________
Date: Jul 01, 2013
Subject: Re: Fuselage Mobile Jig
I did this same thing. After I was up on the landing gear I donated the set to another builder. Hope it is still making the rounds. Works really well and the fuselage is low to the ground. Makes getting the top fitted and access to the top portion really easy. Jim C 40192 - Flying 460 hours! No Regrets On Mon, Jul 1, 2013 at 10:38 AM, Karol Hansen wrot e: > > Wanted to share this for those that might be ready for fuselage mobility. > Attached photos show a simple and inexpensive way to have a mobile yet > secure fuselage structure as you build. > I have gotten in and out of the fuselage hundreds of times and moved it > everywhere from front yard to backwards in the garage and it worked great . > Didn=92t want to share it with the group > until I was sure it worked for me..... It did, and I=92d do it again. U se > air tires, not hardened rubber. > > Mine just moved up in the world to permanent gear. Not it=92s first time > either as I=92ve already fit and finished legs, fairings, and pants some time > ago. At that time this jig came off, then when > complete, went right back on. It is much easier to work on the fuselage > when down low then when on its gear. Hope this helps some of you fellow > builders...=85. > > Rich Hansen > > RV-6A Sold > RV-10 Forever finishing! > > ________________________________________________________________________________
Subject: iPad I For Sale
Date: Jul 02, 2013
_____ iPad 1 64GB with GPS & wiFi in near perfect condition and leather case for sale: $250.00 including Express Mail Shipping to US. FltPlan.Com with maps and approach plates installed. I plan on upgrading to an iPad mini when sold. __________________ Russ Daves Lubbock, TX N710RV - RV-10 Flying N65RV - RV-6A Sold N686RV - RV-6A FWF Rebuild & N number change N742PZ - RV-8 Co-Builder Sold N-867RV -RV-7 Finish Kit ________________________________________________________________________________
Subject: Things needed for the build
Date: Jul 02, 2013
I have my RV 10 fast build kit set for delivery in August. My wife and I will be flying to Osh and camping in the North 40 for a week to take a few courses and shop for needed items. I want to make a list of tools and things that I should get while there. I will have the complete kit minus the finish kit. I have a shop with all the basic mechanic tools, for working on cars and things. Any recommendations . Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403791#403791 ________________________________________________________________________________
Date: Jul 02, 2013
SOLD. Call or Email me ASAP. Jim Villani Cell: (702) 379 5524 Fax: (702) 946-1185 Email: Jim(at)Sold702.com N10KQ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves Sent: Tuesday, July 02, 2013 4:06 AM Subject: RV10-List: iPad I For Sale _____ iPad 1 64GB with GPS & wiFi in near perfect condition and leather case for sale: $250.00 including Express Mail Shipping to US. FltPlan.Com with maps and approach plates installed. I plan on upgrading to an iPad mini when sold. __________________ Russ Daves Lubbock, TX N710RV - RV-10 Flying N65RV - RV-6A Sold N686RV - RV-6A FWF Rebuild & N number change N742PZ - RV-8 Co-Builder Sold N-867RV -RV-7 Finish Kit ________________________________________________________________________________
Date: Jul 02, 2013
Russ, I mis read that, Was that an I-Pad 1 or 1 I-Pad? If it was a 1 Sorry I cannot use it. Jim Villani Cell: (702) 379 5524 Fax: (702) 946-1185 Email: Jim(at)Sold702.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Russell Daves Sent: Tuesday, July 02, 2013 4:06 AM Subject: RV10-List: iPad I For Sale _____ iPad 1 64GB with GPS & wiFi in near perfect condition and leather case for sale: $250.00 including Express Mail Shipping to US. FltPlan.Com with maps and approach plates installed. I plan on upgrading to an iPad mini when sold. __________________ Russ Daves Lubbock, TX N710RV - RV-10 Flying N65RV - RV-6A Sold N686RV - RV-6A FWF Rebuild & N number change N742PZ - RV-8 Co-Builder Sold N-867RV -RV-7 Finish Kit ________________________________________________________________________________
Date: Jul 02, 2013
Subject: Re: Things needed for the build
All the good tool shops offer "RV Tool Kits". They publish a list of tools. I sort of remember Vans having a list of tools needed. Most of them will work with you for adding or deleting as you need. Their kits are substantial discount over buying separately. Avery Tools http://www.averytools.com/ Cleaveland Tools http://www.cleavelandtoolstore.com/ Isham Tools http://www.planetools.com/ I'm probably forgetting others with kits. Other sources, Brown Tools, The Yard, Aircraft Tool Supply, US Aircraft Tools. You will need more clecos (3/32 and 1/8") than anyone offers in the kits, especially up to point where tail and fuselage are joined. You would find a complete 0-60 numbered drill set from Harbor Freight useful for the occasional times you need a size that is not in any of the kits. After that you won't need that many. I'm sure that some builders would be happy to unload some clecos. Some of us have a hard time getting rid of any tools, long after they are no longer needed. All of the kits will have a generic 3/8" air drill, preferably with a keyless chuck. For the majority of drilling you don't need the size or weight of a 3/8" drill, and most of the generics don't have a light pull, easy to control trigger. I didn't upgrade until after developing trigger finger syndrome on my middle finger. http://www.averytools.com/prodinfo.asp?number=7300R is a relatively low cost, light wt Chicago Pneumatics drill. Excellent trigger. While I prefer a keyless chuck, it would add weight and cost, and the vast majority of your drilling will be either 3/32 or 1/8" (#30(). Oh, also consider getting a few chucking reamers. Specifically #41 and #30. #41 is closer to 3/32 than #40, and dimpling enlarges the hole anyway, so you get better rivet fit, and you can just ream all the prepunched holes without even using drill bit. A reamed hole needs less deburring, is rounder, etc. http://www.averytools.com/prodinfo.asp?number=15365 I'm sure others will offer more suggestions. If you haven't found some of the excellent builder websites, start with Tim Olson's http://www.myrv10.com/N104CD/index.html He has links to others. Kelly 40866 90% done, 90% to finish On Tue, Jul 2, 2013 at 6:31 AM, RichGurr wrote: > > I have my RV 10 fast build kit set for delivery in August. My wife and I > will > be flying to Osh and camping in the North 40 for a week to take a few > courses and shop for needed items. I want to make a list of tools and > things that I should get while there. I will have the complete kit minus > the finish kit. > I have a shop with all the basic mechanic tools, for working on cars and > things. Any recommendations . Thanks > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403791#403791 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jul 02, 2013
Take a look at the Avery or Cleaveland RV toolkits on their websites and subtract out the things you already have. Extras I purchased over time: tungsten bucking bar (best tool purchase I made) pneumatic squeezer additional 300 or so 3/32 (silver) clecos extra #30 & #40 bits long #10 & #12 bits long backrivet set .2495 & .311 reamers odd ball bits (#27, #28, #31) tube flaring tool tube bending tool tank 3/32 dimple dies safety wire pliers I already had a Dremel, but I highly recommend one. For a hand squeezer, I also recommend Cleaveland's "Main Squeeze" with at least a 3" yoke and a longeron yoke. -------- Todd Stovall aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace RV-10 N728TT Empacone, Wings, Fuse, Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403798#403798 ________________________________________________________________________________
Date: Jul 02, 2013
Yes, definitely a tungsten bucking bar. I use mine at least 90% of the time and all the rest occasionally. Pneumatic and hand squeezer. DRDT=2 Dimpler is very useful and much faster than a hammer style C-Frame. He won't need tank dimple dies if getting quick build wings. Long and offset backrivet set are handy, wouldn't consider essential. I also use http://www.averytools.com/prodinfo.asp?number=635 round bucking bar for back riveting where it isn't easy to use back rivet plate. On Tue, Jul 2, 2013 at 7:18 AM, tsts4 wrote: > > Take a look at the Avery or Cleaveland RV toolkits on their websites and > subtract out the things you already have. > > Extras I purchased over time: > tungsten bucking bar (best tool purchase I made) > pneumatic squeezer > additional 300 or so 3/32 (silver) clecos > extra #30 & #40 bits > long #10 & #12 bits > long backrivet set > .2495 & .311 reamers > odd ball bits (#27, #28, #31) > tube flaring tool > tube bending tool > tank 3/32 dimple dies > safety wire pliers > > I already had a Dremel, but I highly recommend one. For a hand squeezer, > I also recommend Cleaveland's "Main Squeeze" with at least a 3" yoke and a > longeron yoke. > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace > RV-10 N728TT > Empacone, Wings, Fuse, Finishing > www.mykitlog.com/auburntsts > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403798#403798 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jul 02, 2013
I have a DRDT=2 Dimpler for sale if anyone is interested. Date: Tue=2C 2 Jul 2013 07:38:05 -0700 Subject: Re: RV10-List: Re: Things needed for the build From: apilot2(at)gmail.com Yes=2C definitely a tungsten bucking bar. I use mine at least 90% of the ti me and all the rest occasionally. Pneumatic and hand squeezer. DRDT=2 Dimpler is very useful and much faster than a hammer style C-Frame . He won't need tank dimple dies if getting quick build wings. Long and offset backrivet set are handy=2C wouldn't consider essential. I also use http://www.averytools.com/prodinfo.asp?number=635 round buckin g bar for back riveting where it isn't easy to use back rivet plate. On Tue=2C Jul 2=2C 2013 at 7:18 AM=2C tsts4 wrote: Take a look at the Avery or Cleaveland RV toolkits on their websites and su btract out the things you already have. Extras I purchased over time: tungsten bucking bar (best tool purchase I made) pneumatic squeezer additional 300 or so 3/32 (silver) clecos extra #30 & #40 bits long #10 & #12 bits long backrivet set .2495 & .311 reamers odd ball bits (#27=2C #28=2C #31) tube flaring tool tube bending tool tank 3/32 dimple dies safety wire pliers I already had a Dremel=2C but I highly recommend one. For a hand squeezer =2C I also recommend Cleaveland's "Main Squeeze" with at least a 3" yoke an d a longeron yoke. -------- Todd Stovall aka Auburntsts on EAA=2C AOPA=2C Purple Pilots=2C VAF=2C and RVairspace RV-10 N728TT Empacone=2C Wings=2C Fuse=2C Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403798#403798 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le=2C List Admin. ="_blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jul 02, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
I would add my vote for the Cleveland angle drill kit and second the recommendation for the Cleveland hand squeezer. While I have been happy with my tools from Avery (I also have some from Cleveland), I wish I had purchased both of these items from Cleveland. The squeezer is easier to use and the angle drill kit head is much smaller and will fit in tighter places. Dave Fritzsche RV-10 N965DF Fuselage, Finishing Take a look at the Avery or Cleaveland RV toolkits on their websites and subtract out the things you already have. Extras I purchased over time: tungsten bucking bar (best tool purchase I made) pneumatic squeezer additional 300 or so 3/32 (silver) clecos extra #30 & #40 bits long #10 & #12 bits long backrivet set .2495 & .311 reamers odd ball bits (#27, #28, #31) tube flaring tool tube bending tool tank 3/32 dimple dies safety wire pliers I already had a Dremel, but I highly recommend one. For a hand squeezer, I also recommend Cleaveland's "Main Squeeze" with at least a 3" yoke and a longeron yoke. -------- Todd Stovall aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace RV-10 N728TT Empacone, Wings, Fuse, Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403798#403798 ________________________________________________________________________________
Date: Jul 02, 2013
Subject: 33 hours with a 1-year-old
(I also posted this on VAF) A few weeks ago we completed a 2-week trip in our RV-10, covering 5000+ miles in 33 hours with our 1-year-old boy. I thought we were a little crazy to try it, but it worked out really well. I did a write-up on our site: http://kochman.net/N819K/?p=1437 As always, I have to thank my wife for suggesting the RV-10 instead of the -7. What an amazing family cross-country machine. -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Jul 02, 2013
I am in the final planning stages for Osh. I am camping with the group and having an RV dropped off on Friday. I am planning on flying in Saturday late morning. I have one open item, I have rented from United Rentals/RSC in Oshkosh a generator in order to have a nice cool place to hang out in the middle of the day. However, the RV place isn't allowed to pick up generators, and united Rentals wants more to pick up and drop off than the cost of the rental. Additionally, they aren't open on the weekends..... Is anyone driving in on Friday the 26th that wouldn't mind grabbing a generator for me? Failing that, Monday? If all else fails, we can go powerless or pay the extra fee. Keeping the wife and kid happy is important right???? You can email me at Eison1969 at yahoo dot com Thanks Eric Ison -------- Eric Ison RV 10 #40764 N984ED (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403828#403828 ________________________________________________________________________________
Subject: Re: NAS517-5-9 Countersink Still Making The Rounds?
Date: Jul 02, 2013
Hey Sean, The traveling countersink is back home with me. I was waiting to see if anyone else was ready for it, and forgot to check with you ... if you still need it, get me your address and I'll get it out to you. Later, - Lew -----Original Message----- From: Sean Stephens Sent: Saturday, June 22, 2013 2:09 PM Subject: RV10-List: NAS517-5-9 Countersink Still Making The Rounds? Is the cabin top seat belt NAS517-5-9 countersink still making the rounds? If so, can I be put on the list? -Sean #40303 (sand, fill, rinse, repeat...) ________________________________________________________________________________
Subject: G3x Autopilot & Accessories
Date: Jul 03, 2013
Not sure everyone has seen the new Garmin G3x AP & servos but it looks like they are kicking it into high gear with full G3x accessories. The AP is on ly $750! Servos are also $750 ea. Garmin is also offering a AOA Pitot & Heated AOA Pitot for $199 & $299 with a regulated AOA Pitot coming. They also have a new back up ADAHRS. Products http://www.garmin.com/us/products/intheair/sport-aviation/prices Here are some videos http://www.garmin.com/us/products/intheair/sport-aviation/media/ [https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation /sf/gmc305.jpg] [https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation /sf/gap26.jpg] [https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation /sf/gsa28.jpg] [https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation /sf/gsu25.jpg] Robin ________________________________________________________________________________
Subject: Re: G3x Autopilot & Accessories
Date: Jul 02, 2013
I was shocked how light everything is. Sent from my iPhone On Jul 2, 2013, at 21:55, Robin Marks wrote: > Not sure everyone has seen the new Garmin G3x AP & servos but it looks lik e they are kicking it into high gear with full G3x accessories. The AP is on ly $750! Servos are also $750 ea. > Garmin is also offering a AOA Pitot & Heated AOA Pitot for $199 & $299 wit h a regulated AOA Pitot coming. They also have a new back up ADAHRS. > > Products > > http://www.garmin.com/us/products/intheair/sport-aviation/prices > > Here are some videos > > http://www.garmin.com/us/products/intheair/sport-aviation/media/ > > > > > > > > Robin ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jul 03, 2013
Considering they are matching Dynon on autopilot pricing, I'm thrilled that Garmin is finally feeling some competition pressure. Considering the grossly overpriced GTN-650 I put in my RV-10 (and horrible Garmin after the sale service), perhaps we will soon have more value based options for the rest of our avionics. I predict Dynon will again lead the way. Carl RV-10 (105 hours) RV-8A (sold - but it went to a good home) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, July 02, 2013 11:56 PM Subject: RV10-List: G3x Autopilot & Accessories Not sure everyone has seen the new Garmin G3x AP & servos but it looks like they are kicking it into high gear with full G3x accessories. The AP is only $750! Servos are also $750 ea. Garmin is also offering a AOA Pitot & Heated AOA Pitot for $199 & $299 with a regulated AOA Pitot coming. They also have a new back up ADAHRS. Products http://www.garmin.com/us/products/intheair/sport-aviation/prices Here are some videos http://www.garmin.com/us/products/intheair/sport-aviation/media/ https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation/s f/gmc305.jpg https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation/s f/gap26.jpg https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation/s f/gsa28.jpg https://static.garmincdn.com/en/m/g/custom-pages/in-the-air/sport-aviation/s f/gsu25.jpg Robin ________________________________________________________________________________
Date: Jul 03, 2013
Ok. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@Ok...matronics.com] On Behalf Of Carl Froehlich Sent: Wednesday, July 03, 2013 5:43 AM Subject: RE: RV10-List: G3x Autopilot & Accessories Considering they are matching Dynon on autopilot pricing, I'm thrilled that Garmin is finally feeling some competition pressure. Considering the grossly overpriced GTN-650 I put in my RV-10 (and horrible Garmin after the sale service), perhaps we will soon have more value based options for the rest of our avionics. I predict Dynon will again lead the way. Carl RV-10 (105 hours) RV-8A (sold - but it went to a good home) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, July 02, 2013 11:56 PM rv-list(at)matronics.com Subject: RV10-List: G3x Autopilot & Accessories Not sure everyone has seen the new Garmin G3x AP & servos but it looks like they are kicking it into high gear with full G3x accessories. The AP is only $750! Servos are also $750 ea. Garmin is also offering a AOA Pitot & Heated AOA Pitot for $199 & $299 with a regulated AOA Pitot coming. They also have a new back up ADAHRS. Products http://www.garmin.com/us/products/intheair/sport-aviation/prices Here are some videos http://www.garmin.com/us/products/intheair/sport-aviation/media/ Robin ________________________________________________________________________________
Date: Jul 03, 2013
Thanks for the help. I have compiled a list. As far as the drills, what RPMs are preferred for the build. Is slower ie 2000 or higher ie 3600 a better choice. Do you see much difference between the Harbor Freight drills compared to the ones at Cleaveland, or other suppliers. How many cleco do I need, approximately, do I need foe the job. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403856#403856 ________________________________________________________________________________
Date: Jul 03, 2013
For aluminum the higher speed is better. For steel and stainless, slower is better. I now think 2 different drills are better than just one. Harbor freight drill bits are good for occasional use. Aircraft drill bits from the good suppliers last much longer. I lost count on clecos. On 7/3/2013 6:05 AM, RichGurr wrote: > > Thanks for the help. I have compiled a list. As far as the drills, what RPMs are preferred for the build. Is slower ie 2000 or higher ie 3600 a better choice. Do you see much difference between the Harbor Freight drills compared to the ones at Cleaveland, or other suppliers. How many cleco do I need, approximately, do I need foe the job. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403856#403856 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 03, 2013
IMO drill speed really didnt make a difference. I did my tailcone and wings with a pneumatic, but most of the fuse was done with a combination of corded and cordless electric drills. Where the pneumatics shine is in size and weight as their compact size lets you get into tighter places and the lighter weight is less fatiguing. Cant speak to Harbor Freight vs. any of the major suppliers for drills, but I tend to steer clear of Harbor Freight for anything other than items I consider to be expendable/throw-away stuff. IOW I tend to spend more in order to get quality tools As for Clecos, most the kits come with around 375Id go up to at least 500. However, truth in lending, Im anal about clecoing things together. I tend to cleco a lot of holes when I drill or rivet as I want things nice and tight. Probably overkill but it gave me piece of mind. -------- Todd Stovall aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace RV-10 N728TT Empacone, Wings, Fuse, Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403860#403860 ________________________________________________________________________________
Date: Jul 03, 2013
I was able to acquire one in the meantime. Thanks for the reply. -Sean #40303 On 7/2/13 5:16 PM, lewgall(at)charter.net wrote: > > Hey Sean, > > The traveling countersink is back home with me. I was waiting to see > if anyone else was ready for it, and forgot to check with you ... if > you still need it, get me your address and I'll get it out to you. > Later, - Lew > > -----Original Message----- From: Sean Stephens > Sent: Saturday, June 22, 2013 2:09 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: NAS517-5-9 Countersink Still Making The Rounds? > > > Is the cabin top seat belt NAS517-5-9 countersink still making the > rounds? If so, can I be put on the list? > > -Sean #40303 (sand, fill, rinse, repeat...) > > ________________________________________________________________________________
Date: Jul 03, 2013
If you have a chance, try to use some of these tools before selecting and buying. Oshkosh may give you an opportunity to do that. I started my build with a no longer offered 5 day "build the tail kit" class where I had the chance to try a variety of tools - e.g. 4 different manual rivet squeezers, power squeezers, countersinks, etc. I had no idea there was so much variation even between quality tools. I came away with a distinct preference for a brand of manual squeezers (and a classmate had a distinctly different preference). I'm not sure that pneumatic cleco guns are all that popular.... I used one that convinced me I didn't want one, I used a second and it became a good friend. There are not a lot of opportunities to try before you buy and my guess is that most of us don't get the chance. No worries since whatever you end up with is likely to become 'the best tool for the job' no matter what. As others have said, definitely get a power squeezer, a DRT2 (sic), and at least one good pneumatic drill with a hand twist chuck. Whether you use an electric drill or not, get a lightweight electric driver. General purpose tools include a good drill press, floor standing if you can, and a good band saw. You also need a bench grinder with 1 or 2 Scotchbrite wheels on it for deburring. This should be mounted on a pedestal rather than a bench for easy handling of the aluminum. A good heavy vice is more than handy throughout the build. I bought a lot of HF stuff and still do but good is not equal to HF. Single use and disposable = HF but that can definitely have a place in your project (see fiberglass work). Bill "missing the build just a little but I'm done" Watson ________________________________________________________________________________
Date: Jul 03, 2013
I agree about the Harbor Freight tools, usual I buy for a one time project. I can shop prices before Osh now to check for the best deals. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403885#403885 ________________________________________________________________________________
Date: Jul 03, 2013
No one mentioned the obvious - you need an air compressor. 'Oil free' are useful if you are going to use it for painting, but they're also much louder than oil lubricated ones. Look at the cubic ft per minute numbers. Some of the smaller ones cannot keep up if you're doing a lot of drilling, and definitely can't keep up with spray painting. Shop supplies: boelube or cutting oil for drilling hard metals, lube oil for air tools, thread sealant for pipe threads, scotch brite pads, felt tip pens, etc. Center punch for starting the process of removing rivets, 1/8 and 3/32 pin punches for the same reason! I found a scotch bright grinding wheel much more useful than I ever thought. Also, stuff gets lost. Almost everyone ends up buying an assortment of rivets, bolts, nuts, etc. And get some "opps" rivets from Vans. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403887#403887 ________________________________________________________________________________
Date: Jul 03, 2013
Coming in from MKE with a Ford EDGE SUV. How can I help. John Cox On Tue, Jul 2, 2013 at 2:54 PM, eison wrote: > > I am in the final planning stages for Osh. I am camping with the group > and having an RV dropped off on Friday. I am planning on flying in > Saturday late morning. > > I have one open item, I have rented from United Rentals/RSC in Oshkosh a > generator in order to have a nice cool place to hang out in the middle of > the day. However, the RV place isn't allowed to pick up generators, and > united Rentals wants more to pick up and drop off than the cost of the > rental. Additionally, they aren't open on the weekends..... > > Is anyone driving in on Friday the 26th that wouldn't mind grabbing a > generator for me? Failing that, Monday? > > If all else fails, we can go powerless or pay the extra fee. Keeping the > wife and kid happy is important right???? > > You can email me at Eison1969 at yahoo dot com > > > Thanks > > Eric Ison > > -------- > Eric Ison > RV 10 #40764 > N984ED (reserved) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403828#403828 > > ________________________________________________________________________________
Date: Jul 03, 2013
I got him covered John, but stop by anyway! The beer is on me this time. Bob On Wednesday, July 3, 2013, John Cox wrote: > Coming in from MKE with a Ford EDGE SUV. How can I help. > > John Cox > > > On Tue, Jul 2, 2013 at 2:54 PM, eison > > wrote: > >> > >> >> I am in the final planning stages for Osh. I am camping with the group >> and having an RV dropped off on Friday. I am planning on flying in >> Saturday late morning. >> >> I have one open item, I have rented from United Rentals/RSC in Oshkosh a >> generator in order to have a nice cool place to hang out in the middle of >> the day. However, the RV place isn't allowed to pick up generators, and >> united Rentals wants more to pick up and drop off than the cost of the >> rental. Additionally, they aren't open on the weekends..... >> >> Is anyone driving in on Friday the 26th that wouldn't mind grabbing a >> generator for me? Failing that, Monday? >> >> If all else fails, we can go powerless or pay the extra fee. Keeping the >> wife and kid happy is important right???? >> >> You can email me at Eison1969 at yahoo dot com >> >> >> Thanks >> >> Eric Ison >> >> -------- >> Eric Ison >> RV 10 #40764 >> N984ED (reserved) >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=403828#403828 >> >> >> >> >> >> >> >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > * > > ________________________________________________________________________________
Date: Jul 03, 2013
The "oops" rivet selection from Avery worked better for me, because I used the NAS1097-3 size to install nutplates by countersinking for that tiny head instead of dimpling. Makes a much nicer install. The liquid Boelube is excellent for drilling stainless steel, like firewall. It also is great for first time install of screw/bolt into a new nutplate. Oil lube compressor IMHO is far better than oiless, because you do so much work needing compressed air, and unless compressor is in another room/noise cabinet the oiless noise will drive you crazy. I got 30 gal Husky. I think Lowes may have a bit nicer 30 gal now. Some of the kits come with Scotchbrite wheel. Builder's hardware kit for those extra bolts and screws you always need will save time. On 7/3/2013 1:43 PM, Bob Turner wrote: > > No one mentioned the obvious - you need an air compressor. 'Oil free' are useful if you are going to use it for painting, but they're also much louder than oil lubricated ones. Look at the cubic ft per minute numbers. Some of the smaller ones cannot keep up if you're doing a lot of drilling, and definitely can't keep up with spray painting. > > Shop supplies: boelube or cutting oil for drilling hard metals, lube oil for air tools, thread sealant for pipe threads, scotch brite pads, felt tip pens, etc. > > Center punch for starting the process of removing rivets, 1/8 and 3/32 pin punches for the same reason! > > I found a scotch bright grinding wheel much more useful than I ever thought. > > Also, stuff gets lost. Almost everyone ends up buying an assortment of rivets, bolts, nuts, etc. And get some "opps" rivets from Vans. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403887#403887 > > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 03, 2013
Date: Jul 03, 2013
> > No one mentioned the obvious - you need an air compressor. 'Oil free' are useful if you are going to use it for painting, but they're also much louder than oil lubricated ones. Look at the cubic ft per minute numbers. Some of the smaller ones cannot keep up if you're doing a lot of drilling, and definitely can't keep up with spray painting. Yes, I got a pretty large one from Home Depot/Lowes. My sense is that oil free is for casual use - building the '10 is not casual - but I don't really know. The one thing I was absolutely not going to do was paint... but I ended up painting. Instead of creating a clean, dry air supply, I went with a turbine HVLP system. But I digress, that's all waaaay down the line so don't get hung up on finishing at the start, just get what you need for a lot of aluminum work. > > Center punch for starting the process of removing rivets, 1/8 and 3/32 pin punches for the same reason! I never used a center punch for rivet removal! I should have. I just relied on the little hole on the top of each rivet to guide the drill. It worked, usually. > > I found a scotch bright grinding wheel much more useful than I ever thought. Had never heard of them before but at class, I learned to deburr every single piece of aluminum as the first step in any assembly. Do the plans tell you to do that? Don't know, but relative to all the anal activities you can get involved with, deburring seems to be a big one to me.... priming, not so much (helmet on). > > Also, stuff gets lost. Almost everyone ends up buying an assortment of rivets, bolts, nuts, etc. And get some "opps" rivets from Vans. > Speaking of anal... if you really get into using the right rivet to get the right sized head in every instance, you quickly discover that Vans supplies a limited range of sizes but doesn't include half sizes or enough of certain sizes. My build-the-tail class instructor loved watching us struggle with a particular rivet, then pulling out a bottle of half size rivets to try. He knew every single mismatch. But of course, Vans knows what really matters. None of those half size rivets were really needed because every single rivet didn't need to be perfect. Bill "Sorry for getting lost in the weeds here" Watson ________________________________________________________________________________
Date: Jul 04, 2013
I would suggest biting the bullet and getting a complete RV-10 build kit from one of the tool suppliers (I used Avery). They will include stuff that your not familiar with, but will be invaluable at the right time. The best thing I got was the Sioux air drill with an optional keyless chuck. The suggestions on extra clecos and drill bits are good. Don't try to save a few bucks on cheap bits - get plenty. I need to rephrase this - the best thing was the pneumatic squeezer. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403915#403915 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jul 04, 2013
Must haves (in my book): - start with a RV tool kit - spend the money on the Sioux drill, worth every penny! - buy a keyless quick change chuck for the drill, you'll save tons of time in bit changes. - buy a second countersink drill cage, leave one set up for #40 and one for #30. - pneumatic riveter with deep throat and longeron yokes - tungsten bucking bar - the DRDT is very nice too. Not a must have in my book unless you are building at home, then it is a must have as it makes no sound.... - you can never have too many clecos - also buy 10-20 of the larger clecos (black, gold) -Mike Sent from my iPhone On Jul 4, 2013, at 9:13 AM, "johngoodman" wrote: > > I would suggest biting the bullet and getting a complete RV-10 build kit from one of the tool suppliers (I used Avery). They will include stuff that your not familiar with, but will be invaluable at the right time. > > The best thing I got was the Sioux air drill with an optional keyless chuck. The suggestions on extra clecos and drill bits are good. Don't try to save a few bucks on cheap bits - get plenty. > I need to rephrase this - the best thing was the pneumatic squeezer. > > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403915#403915 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 04, 2013
Never saw this mentioned, so in case it wasn't: One of my MOST used tools was and is a Die Grinder. Mine I believe is a CP and I've used it so much that it should have died long ago, but still survives as if it were new. Shaping, fitting, cutting, elongating holes, etc. If you put it to work for you it may become your best friend quickly! I also agree with others about the pneumatic squeezers - also a best friend. Find one that fits your liking and learn how to use it. It can give you quick, professional, repeatable and consistent rivet sets. This is my second plane and I don't even own a hand squeezer! Certainly there were a few areas where I could have used it, but your choice. Hope that helps. Oh, and yes both of these require a compressor - my choice is one with a separate electric motor and separate compressor motor - for the most part they seem much more quiet. I've painted lots of things with mine and had no bleed in problems with oil or moisture using a filter/dryer in-line, before the gun. Rich Hansen RV-6A Sold RV-10 forever finishing ________________________________________________________________________________
Date: Jul 04, 2013
Subject: RV10 Emp & Wings for sale
I have decided to sell my RV10 project. If you know of any one who is inter ested please refer them to this link.=0A-=0Ahttp://www.vansairforce.com/c ommunity/showthread.php?p=785146#post785146=0A-=0AThanks=0ASteve ________________________________________________________________________________
Date: Jul 04, 2013
I will check out the RV tool kits while at Osh. As pointed out, I can delete any tools I may have. Based on everyones input, a Pneumatic Squeezer is on the must have list. Have a safe Independence Day! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403943#403943 ________________________________________________________________________________
Date: Jul 04, 2013
Stop at KPMH on your way home. I have a DRDT-2, books, trays, oops rivets and many other items left over. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403944#403944 ________________________________________________________________________________
Date: Jul 05, 2013
I have read about various colors for clecos. What color equals the size. Are silver 40, copper 30 etc. also, if anyone wants to get rid of some tools collecting dust, I am interested in things I will need for the build. PM me if you want to depart with something. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=403973#403973 ________________________________________________________________________________
Date: Jul 05, 2013
I copied this from Aircraft Spruce. Linn Description Fastener Size Color Code Drill Size Part Number Buy Sub-Total Sheet Holders M-1/8 Cleco 1/8" Copper #30 12-01138 *$0.48* Sheet Holders M-3/16 Cleco 3/16" Brass #10 12-01139 *$0.49* Sheet Holders M-3/32 Cleco 3/32" Cadmium #40 12-01140 *$0.49* Sheet Holders M-5/32 Cleco 5/32" Black #20 12-01141 *$0.48* On 7/5/2013 8:25 AM, RichGurr wrote: > > I have read about various colors for clecos. What color equals the size. Are silver 40, copper 30 etc. also, if anyone wants to get rid of some tools collecting dust, I am interested in things I will need for the build. PM me if you want to depart with something. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=403973#403973 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 05, 2013
For clarification, #40 is silver for #3 (3/32) rivets, #30 is Copper for #4 (4/32 = 1/8) rivets, #19/20 is Black for #5 rivets or #8 screws, and #10/12 is Gold/Brass for #6 rivets, #10 screws or AN3 bolts. Sent from my iPad On Jul 5, 2013, at 8:34 AM, Linn Walters wrote: > I copied this from Aircraft Spruce. > Linn > Description Fastener Size Color Code Drill Size Part Number Buy Sub-Total > Sheet Holders M-1/8 Cleco 1/8" Copper #30 12-01138 $0. 48 > Sheet Holders M-3/16 Cleco 3/16" Brass #10 12-01139 $0. 49 > Sheet Holders M-3/32 Cleco 3/32" Cadmium #40 12-01140 $0.49 > Sheet Holders M-5/32 Cleco 5/32" Black #20 12-01141 $0. 48 > > On 7/5/2013 8:25 AM, RichGurr wrote: >> >> I have read about various colors for clecos. What color equals the size. Are silver 40, copper 30 etc. also, if anyone wants to get rid of some to ols collecting dust, I am interested in things I will need for the build. P M me if you want to depart with something. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=403973#403973 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: FF1-2 & FF1-3
Date: Jul 05, 2013
The instructions for the finish kit indicate that it's best to complete the instructions on pages FF1-2 & FF1-3 of the firewall forward kit PRIOR to installing the engine mount. Does someone have a scan or picture of these two pages ? I am not ordering the FF kit and would like to know what to install/complete. Many thanks --Ron ________________________________________________________________________________
Date: Jul 05, 2013
Here you go. Bill -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron Walker Sent: Friday, July 05, 2013 1:21 PM Subject: RV10-List: FF1-2 & FF1-3 The instructions for the finish kit indicate that it's best to complete the instructions on pages FF1-2 & FF1-3 of the firewall forward kit PRIOR to installing the engine mount. Does someone have a scan or picture of these two pages ? I am not ordering the FF kit and would like to know what to install/complete. Many thanks --Ron ________________________________________________________________________________
Date: Jul 06, 2013
Subject: Fwd: B: Seven Devices, One Chip to Navigate without GPS
For those going to OSH, see if you can find one of the EFIS vendors that will incorporate an INS like this into their ADAHARS and/or GPS: http://www.vectornav.com/ Seems just the ticket for times that RAIM is insufficient on GPS or the military decides to jam an area. Now if they would just package that as a replacement for the VFR GPS antenna that Dynon sells for $250, we could really cause some serious envy in the certified world.. ________________________________________________________________________________
Subject: "Suitable" Release Agent for Prop Governor Gasket
Date: Jul 06, 2013
ah... the simple things can be so hard. I'm trying to install my PCU5000-X Prop Governor. The instructions call for a "suitable" release agent to be applied to the gasket. Any idea what that might be? Jeff Carpenter 40304 95/95 ________________________________________________________________________________
Subject: Choosing the switches
Date: Jul 07, 2013
Guys It's time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? For the magnetos and starter, did everybody use the ACS combined keyed switch, or is it better to use 2 toggles and one push-button momentary starter switch? And for the lights and other electrical equipment, which has been the choice: the classic rocker switches or the color coded toggle switches? Thanks for your opinions Carlos ________________________________________________________________________________
Date: Jul 07, 2013
I think there is too much customization and personal preference, that there really isn't a defacto popular choice. For example, for those of us that have Vertical Power units, all the switches are just logic switches and carry no real current. This means we can be a little more creative on which switches we use. For most of my switches I took the easy way out. It also means that the VP device controls the master and alternator functions. Since I have an Aerosport Products' instrument panel and I have a relationship with Aerosport Products (I manage the website for them), I went with Geoff's rocker switches. They work just fine. I did use the ACS keyed switch, since I only wanted to carry a single key for the ignition, doors, and baggage door. Almost all my switches are rockers. I have only one color coded switch, the rest are all black. I started to color coded them, but quickly realized all the same colors were grouped together. i.e. a bank of four all red. Since the banks of switches all have different functions, I used the physical placement to differentiate rather than color. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, July 07, 2013 5:32 AM Subject: RV10-List: Choosing the switches Guys It's time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? For the magnetos and starter, did everybody use the ACS combined keyed switch, or is it better to use 2 toggles and one push-button momentary starter switch? And for the lights and other electrical equipment, which has been the choice: the classic rocker switches or the color coded toggle switches? Thanks for your opinions Carlos ________________________________________________________________________________
Date: Jul 07, 2013
Tite Seal: http://www.aircraftspruce.com/search/search.php?s=TITE+SEAL+NO.+55&x=0&y=0 It does not harden. One can will last a lifetime. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Sent: Saturday, July 06, 2013 10:28 PM Subject: RV10-List: "Suitable" Release Agent for Prop Governor Gasket ah... the simple things can be so hard. I'm trying to install my PCU5000-X Prop Governor. The instructions call for a "suitable" release agent to be applied to the gasket. Any idea what that might be? Jeff Carpenter 40304 95/95 ________________________________________________________________________________
Subject: Re: Choosing the switches
Date: Jul 07, 2013
I have usually installed simple toggle switches for most things, with the no rmal key switch for mags and starter. I also like separate toggle switches f or mags. For master and alt, I like to use a toggle switch for master and to put alt f ield on my avionics bus so it comes on with the avionics master. I use the K lixon pull able breakers so I can reset it if necessary. I prefer toggle switches because it is easier to add one after the panel is f inished by simply drilling a round hole. The classy rocker switches are very nice to look at, and I like the way they can be labeled right on the switch, but they are more expensive and harder t o add or remove. I recently worked on a plane that had all rocker switches ( the big black ones that were engraved with labels. There are 4-5 switches th at aren't used any more and if I remove them, there will be big holes in the panel. Just MHO. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Jul 7, 2013, at 5:32 AM, "Carlos Trigo" wrote: > Guys > > It=99s time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: > > For the Master and ALT field, have you used the Cessna split rocker or jus t 2 separate toggle switches? > > For the magnetos and starter, did everybody use the ACS combined keyed swi tch, or is it better to use 2 toggles and one push-button momentary starter s witch? > > And for the lights and other electrical equipment, which has been the choi ce: the classic rocker switches or the color coded toggle switches? > > Thanks for your opinions > Carlos > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 07, 2013
Toggle switches for me also. I really like the look of the rock rack switch es but went with the toggles in the end for reasons others have already sta ted. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "Carlos Trigo" <trigo(at)mail.telepac.pt> Sent: Sunday, July 7, 2013 5:32:15 AM Subject: RV10-List: Choosing the switches Guys It=99s time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? For the magnetos and starter, did everybody use the ACS combined keyed swit ch, or is it better to use 2 toggles and one push-button momentary starter switch? And for the lights and other electrical equipment, which has been the choic e: the classic rocker switches or the color coded toggle switches? Thanks for your opinions Carlos == ________________________________________________________________________________
Date: Jul 07, 2013
Classic toggles on my panel other than a standard keyed mag/start switch for a bit of security and large two position toggle for BATT and ALT. You can purchase a toggle almost anywhere in a pinch and silly simple to install, wire and operate. Dave Leikam On Jul 7, 2013, at 4:32 AM, Carlos Trigo wrote: > Guys > > It=92s time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: > > For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? > > For the magnetos and starter, did everybody use the ACS combined keyed switch, or is it better to use 2 toggles and one push-button momentary starter switch? > > And for the lights and other electrical equipment, which has been the choice: the classic rocker switches or the color coded toggle switches? > > Thanks for your opinions > Carlos > > > > > > > > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 07, 2013
I prefer the mags on toggles so if I want to clear the engine I can turn it with the ignition off. I used to have a separate position for the alternator field but now it comes on with the battery. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Jul 07, 2013
Especially for those with light 3 bladed props, having seperate switches for either mags or elec ignition, you can leave the ignition off until the blades get turning, then flip them on..... no kickpack or backfiring. Works everytime. Don McDonald 520 hours and loving every minute. ________________________________________________________________________________
Date: Jul 07, 2013
RV-10 Build: [cid:image005.jpg(at)01CE7AF6.9CD74460] RV-8A Build [cid:image006.jpg(at)01CE7AF6.9CD74460] Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Carlos Trigo Sent: Sunday, July 07, 2013 2:32 AM Subject: RV10-List: Choosing the switches Guys It's time to choose the switches for the RV-10 panel, and I wonder which on es are more popular between the RV-10 builders: For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? For the magnetos and starter, did everybody use the ACS combined keyed swit ch, or is it better to use 2 toggles and one push-button momentary starter switch? And for the lights and other electrical equipment, which has been the choic e: the classic rocker switches or the color coded toggle switches? Thanks for your opinions Carlos ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Date: Jul 07, 2013
I used the Aveo switches and had a few custom laser engraved. Bob Newman TCW Technologies, LLC. From: Robin Marks Sent: Sunday, July 07, 2013 12:44 PM Subject: RE: RV10-List: Choosing the switches RV-10 Build: RV-8A Build Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Sunday, July 07, 2013 2:32 AM Subject: RV10-List: Choosing the switches Guys It=99s time to choose the switches for the RV-10 panel, and I wonder which ones are more popular between the RV-10 builders: For the Master and ALT field, have you used the Cessna split rocker or just 2 separate toggle switches? For the magnetos and starter, did everybody use the ACS combined keyed switch, or is it better to use 2 toggles and one push-button momentary starter switch? And for the lights and other electrical equipment, which has been the choice: the classic rocker switches or the color coded toggle switches? Thanks for your opinions Carlos =================== bsp; - The RV10-List Email Forum - o browse scription, , Chat, FAQ, /span> tronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10- List =================== bsp; - MATRONICS WEB FORUMS - eb Forums! .matronics.com">http://forums.matronics.com =================== bsp; - List Contribution Web Site - o:p> bsp; -Matt Dralle, List Admin. tronics.com/contribution">http://www.matronics.com/contribution
May 23, 2013 - July 07, 2013
RV10-Archive.digest.vol-jk
