RV10-Archive.digest.vol-jl
July 07, 2013 - August 06, 2013
      Checked by AVG - www.avg.com
      r>
Subject: Re: Choosing the switches
Date: Jul 07, 2013
These work well.... (g) -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404142#404142 Attachments: http://forums.matronics.com//files/3pole_f_copy_162.jpg ________________________________________________________________________________
Subject: Choosing the switches
Date: Jul 08, 2013
V2hhdCBkbyB5b3Uga25vdyBhYm91dCBlbGVjdHJvbmljcz8NCg0KUm9iaW4NCkRvIE5vdCBBcmNo aXZlDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRv Om93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIEJvYi10 Y3cNClNlbnQ6IFN1bmRheSwgSnVseSAwNywgMjAxMyA0OjI2IFBNDQpUbzogcnYxMC1saXN0QG1h dHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IENob29zaW5nIHRoZSBzd2l0Y2hl cw0KDQpJIHVzZWQgdGhlIEF2ZW8gc3dpdGNoZXMgYW5kIGhhZCBhIGZldyBjdXN0b20gbGFzZXIg ZW5ncmF2ZWQuDQoNCkJvYiBOZXdtYW4NClRDVyBUZWNobm9sb2dpZXMsIExMQy4NCg0KDQoNCg0K DQpGcm9tOiBSb2JpbiBNYXJrczxtYWlsdG86cm9iaW5AUGFpbnRUaGVXZWIuY29tPg0KU2VudDog U3VuZGF5LCBKdWx5IDA3LCAyMDEzIDEyOjQ0IFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5j b208bWFpbHRvOnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUkU6IFJWMTAtTGlz dDogQ2hvb3NpbmcgdGhlIHN3aXRjaGVzDQoNCg0KUlYtMTAgQnVpbGQ6DQoNCltjaWQ6aW1hZ2Uw MDEuanBnQDAxQ0U3QjQ1LkMxRkU2RTQwXQ0KDQpSVi04QSBCdWlsZA0KW2NpZDppbWFnZTAwMi5q cGdAMDFDRTdCNDUuQzFGRTZFNDBdDQoNClJvYmluDQoNCg0KRnJvbTogb3duZXItcnYxMC1saXN0 LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJv bmljcy5jb20+IFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBP biBCZWhhbGYgT2YgQ2FybG9zIFRyaWdvDQpTZW50OiBTdW5kYXksIEp1bHkgMDcsIDIwMTMgMjoz MiBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPG1haWx0bzpydjEwLWxpc3RAbWF0cm9u aWNzLmNvbT4NClN1YmplY3Q6IFJWMTAtTGlzdDogQ2hvb3NpbmcgdGhlIHN3aXRjaGVzDQoNCkd1 eXMNCg0KSXTigJlzIHRpbWUgdG8gY2hvb3NlIHRoZSBzd2l0Y2hlcyBmb3IgdGhlIFJWLTEwIHBh bmVsLCBhbmQgSSB3b25kZXIgd2hpY2ggb25lcyBhcmUgbW9yZSBwb3B1bGFyIGJldHdlZW4gdGhl IFJWLTEwIGJ1aWxkZXJzOg0KDQpGb3IgdGhlIE1hc3RlciBhbmQgQUxUIGZpZWxkLCBoYXZlIHlv dSB1c2VkIHRoZSBDZXNzbmEgc3BsaXQgcm9ja2VyIG9yIGp1c3QgMiBzZXBhcmF0ZSB0b2dnbGUg c3dpdGNoZXM/DQoNCkZvciB0aGUgbWFnbmV0b3MgYW5kIHN0YXJ0ZXIsIGRpZCBldmVyeWJvZHkg dXNlIHRoZSBBQ1MgY29tYmluZWQga2V5ZWQgc3dpdGNoLCBvciBpcyBpdCBiZXR0ZXIgdG8gdXNl IDIgdG9nZ2xlcyBhbmQgb25lIHB1c2gtYnV0dG9uIG1vbWVudGFyeSBzdGFydGVyIHN3aXRjaD8N Cg0KQW5kIGZvciB0aGUgbGlnaHRzIGFuZCBvdGhlciBlbGVjdHJpY2FsIGVxdWlwbWVudCwgd2hp Y2ggaGFzIGJlZW4gdGhlIGNob2ljZTogdGhlIGNsYXNzaWMgcm9ja2VyIHN3aXRjaGVzIG9yIHRo ZSBjb2xvciBjb2RlZCB0b2dnbGUgc3dpdGNoZXM/DQoNClRoYW5rcyBmb3IgeW91ciBvcGluaW9u cw0KQ2FybG9zDQoNCg0KDQoNCg0KDQoNCg0KPT09PT09PT09PT09PT09PT09PT0NCmJzcDsgIC0g VGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQpvIGJyb3dzZQ0Kc2NyaXB0aW9uLA0KLCBDaGF0 LCBGQVEsDQovc3Bhbj4NCnRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QiPmh0dHA6Ly93 d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo9PT09PT09PT09PT09PT09PT09 PQ0KYnNwOyAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCmViIEZvcnVtcyENCi5tYXRy b25pY3MuY29tIj5odHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCj09PT09PT09PT09PT09PT09 PT09DQpic3A7ICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCm86cD4NCmJzcDsg ICAgICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KdHJvbmljcy5j b20vY29udHJpYnV0aW9uIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo9 PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KX19fX19fX19fX19fX19fX19fX19fX19fX19fX19f X18NCk5vIHZpcnVzIGZvdW5kIGluIHRoaXMgbWVzc2FnZS4NCkNoZWNrZWQgYnkgQVZHIC0gd3d3 LmF2Zy5jb208aHR0cDovL3d3dy5hdmcuY29tPg0Kcj4NCl9fX19fX19fX19fX19fX19fX19fX19f X19fX19fX19fDQpObyB2aXJ1cyBmb3VuZCBpbiB0aGlzIG1lc3NhZ2UuDQpDaGVja2VkIGJ5IEFW RyAtIHd3dy5hdmcuY29tPGh0dHA6Ly93d3cuYXZnLmNvbT4NClZlcnNpb246IDIwMTMuMC4yOTA0 IC8gVmlydXMgRGF0YWJhc2U6IDMyMDQvNjQ0MiAtIFJlbGVhc2UgRGF0ZTogMDYvMjYvMTMNCklu dGVybmFsIFZpcnVzIERhdGFiYXNlIGlzIG91dCBvZiBkYXRlLg0K ________________________________________________________________________________
Subject: Andair boost pump and filter
Date: Jul 08, 2013
> I have just started my RV10 fuselage and plan to use an IO540. I already p urchased the Andair FS20X7-T (looks very well engineered).... and I am leani ng toward using the Andair PX500-TC Pump and FX500-MK filter. Would like to better understand why the fuel filter on most -10s are in the tunnel. What drawbacks would there be for an "out of the cockpit" solution for the filte r. Appreciate any/all thoughts. I will be at Osh...looking forward to put faces with names. Terry Moushon Peoria Illinois Builder 41393 ________________________________________________________________________________
Date: Jul 08, 2013
On 7/7/2013 8:11 AM, Jesse Saint wrote: > The classy rocker switches are very nice to look at, and I like the > way they can be labeled right on the switch, but they are more > expensive and harder to add or remove. I recently worked on a plane > that had all rocker switches (the big black ones that were engraved > with labels. There are 4-5 switches that aren't used any more and if I > remove them, there will be big holes in the panel. > I used white Honeywell rockers (AML34,24) with labels and backlighting. All the above certainly applies though I haven't had to face any of that yet beyond initial expense. My selection was based purely on personal desire with the knowledge that toggles would be easier, cheaper, and more flexible. But since I did my own panel, I enjoyed the challenge and the finished appearance. I didn't include a split rocker, nothing missed there. I did use the ACS key switch and find it a good selection for my '10. It's easy to leave the baggage key dangling outside unless you have to have it to start the plane (there are other approaches to this problem but this one works). Since you need a key for the baggage door, using the same for ignition and just plain requiring a key ring is a handy thing (my fuel key is on the ring too which is a great reminder). Re the Honeywells - finding the right switches for a couple of functions required some searching, e.g. AP source switching, flaps. Newark Electronics turned out to be a great (stocked) source for switch items. Cutting rectangular holes in an aluminum panel turned out to be surprisingly easy with a hand file. The lights for the switches turn out to be troublesome... it takes some fooling around to get the little lights to consistently stay lit in a vibrating environment. There are LED lights available as well as the standard incandescent. I use the LEDs but went to incandescent for my LRC3 low voltage lights in order for them to function properly. B&C can tell you how to make the LEDs work there as well. I used AML41 indicators for the idiot lights. Very handsome when combined with the rockers. I used dimmers on all switches and 2 of the idiot lights. No VPN, did use Faststack, fuses along with 4 breakers, Z-14 a few pics here http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=5253 (I should include a pic of the whole panel) Bill "300+ hours and still haven't replaced stick-on panel labels" Watson ________________________________________________________________________________
Date: Jul 08, 2013
VG8gcGlsZSBvbiB3aGF0IEJpbGwgc2FpZCBJIHVzZWQgdGhlIGJhY2tsaXQgSG9uZXl3ZWxsIHN3 aXRjaGVzICh3aXRoIGRpbW1lcikgZm9yIHRoZSAtMTAgYW5kIGxpa2UgaXQgYSBsb3QgYnV0IHdo ZW4gaXQgd2FzIHRpbWUgdG8gYnVpbGQgdGhlIDhBIEkgdXNlZCB0aGUgc2FtZSBzd2l0Y2hlcyBi dXQgdW5saWdodGVkLiBJdCBzYXZlZCAzMC00MCUgb24gc29tZSBvZiB0aGUgc3dpdGNoZXMuIEkg dXNlZCBhIG1ldGFsIFJlZC9XaGl0ZSBMRUQgY29ja3BpdCBsaWdodCB0aGF0IGNhbiBsaWdodCB1 cCB0aGUgc3dpdGNoZXMgKGFuZC9vciBjaGFydHMpIHdoZW4gbmVlZGVkLg0KDQpbaHR0cDovL3d3 dy5haXJjcmFmdHNwcnVjZS5jb20vY2F0YWxvZy9ncmFwaGljcy8xMS0wNDM5My5qcGddDQoNCkkg YWxzbyBwbGFjZWQgc29tZSBMRUQgc3RyaXAgbGlnaHRzIHVuZGVyIHRoZSBsb25nZXJvbnMgdGhh dCBnaXZlIGEgYmVhdXRpZnVsIOKAnGRvd24gZ2xvd+KAnSBhbmQgYWxsb3dzIG1lIHRvIHJlYWQg anVzdCBhYm91dCBhbnl0aGluZyBJIHdhbnQgd2hpbGUgbmlnaHQgZmx5aW5nIGluY2x1ZGluZyB0 aGUgc3dpdGNoZXMuIFdvcmtzIGdyZWF0IGFuZCBwcm92aWRlcyBhIGxvdCBvZiBsaWdodCBidXQg c3RpbGwgZWFzeSB0byBmbHkvbGFuZCB3aGVuIGRhcmsuIFNvcnJ5LCBubyBwaG90b3MuIOKYuQ0K DQpSb2Jpbg0KDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBb bWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9m IEJpbGwgV2F0c29uDQpTZW50OiBNb25kYXksIEp1bHkgMDgsIDIwMTMgOTozOSBBTQ0KVG86IHJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBDaG9vc2luZyB0 aGUgc3dpdGNoZXMNCg0KT24gNy83LzIwMTMgODoxMSBBTSwgSmVzc2UgU2FpbnQgd3JvdGU6DQpU aGUgY2xhc3N5IHJvY2tlciBzd2l0Y2hlcyBhcmUgdmVyeSBuaWNlIHRvIGxvb2sgYXQsIGFuZCBJ IGxpa2UgdGhlIHdheSB0aGV5IGNhbiBiZSBsYWJlbGVkIHJpZ2h0IG9uIHRoZSBzd2l0Y2gsIGJ1 dCB0aGV5IGFyZSBtb3JlIGV4cGVuc2l2ZSBhbmQgaGFyZGVyIHRvIGFkZCBvciByZW1vdmUuIEkg cmVjZW50bHkgd29ya2VkIG9uIGEgcGxhbmUgdGhhdCBoYWQgYWxsIHJvY2tlciBzd2l0Y2hlcyAo dGhlIGJpZyBibGFjayBvbmVzIHRoYXQgd2VyZSBlbmdyYXZlZCB3aXRoIGxhYmVscy4gVGhlcmUg YXJlIDQtNSBzd2l0Y2hlcyB0aGF0IGFyZW4ndCB1c2VkIGFueSBtb3JlIGFuZCBpZiBJIHJlbW92 ZSB0aGVtLCB0aGVyZSB3aWxsIGJlIGJpZyBob2xlcyBpbiB0aGUgcGFuZWwuDQoNCkkgdXNlZCB3 aGl0ZSBIb25leXdlbGwgcm9ja2VycyAoQU1MMzQsMjQpIHdpdGggbGFiZWxzIGFuZCBiYWNrbGln aHRpbmcuICBBbGwgdGhlIGFib3ZlIGNlcnRhaW5seSBhcHBsaWVzIHRob3VnaCBJIGhhdmVuJ3Qg aGFkIHRvIGZhY2UgYW55IG9mIHRoYXQgeWV0IGJleW9uZCBpbml0aWFsIGV4cGVuc2UuICBNeSBz ZWxlY3Rpb24gd2FzIGJhc2VkIHB1cmVseSBvbiBwZXJzb25hbCBkZXNpcmUgd2l0aCB0aGUga25v d2xlZGdlIHRoYXQgdG9nZ2xlcyB3b3VsZCBiZSBlYXNpZXIsIGNoZWFwZXIsIGFuZCBtb3JlIGZs ZXhpYmxlLiAgQnV0IHNpbmNlIEkgZGlkIG15IG93biBwYW5lbCwgSSBlbmpveWVkIHRoZSBjaGFs bGVuZ2UgYW5kIHRoZSBmaW5pc2hlZCBhcHBlYXJhbmNlLg0KDQpJIGRpZG4ndCBpbmNsdWRlIGEg c3BsaXQgcm9ja2VyLCBub3RoaW5nIG1pc3NlZCB0aGVyZS4NCg0KSSBkaWQgdXNlIHRoZSBBQ1Mg a2V5IHN3aXRjaCBhbmQgZmluZCBpdCBhIGdvb2Qgc2VsZWN0aW9uIGZvciBteSAnMTAuICBJdCdz IGVhc3kgdG8gbGVhdmUgdGhlIGJhZ2dhZ2Uga2V5IGRhbmdsaW5nIG91dHNpZGUgdW5sZXNzIHlv dSBoYXZlIHRvIGhhdmUgaXQgdG8gc3RhcnQgdGhlIHBsYW5lICh0aGVyZSBhcmUgb3RoZXIgYXBw cm9hY2hlcyB0byB0aGlzIHByb2JsZW0gYnV0IHRoaXMgb25lIHdvcmtzKS4gIFNpbmNlIHlvdSBu ZWVkIGEga2V5IGZvciB0aGUgYmFnZ2FnZSBkb29yLCB1c2luZyB0aGUgc2FtZSBmb3IgaWduaXRp b24gYW5kIGp1c3QgcGxhaW4gcmVxdWlyaW5nIGEga2V5IHJpbmcgaXMgYSBoYW5keSB0aGluZyAo bXkgZnVlbCBrZXkgaXMgb24gdGhlIHJpbmcgdG9vIHdoaWNoIGlzIGEgZ3JlYXQgcmVtaW5kZXIp Lg0KDQpSZSB0aGUgSG9uZXl3ZWxscyAtIGZpbmRpbmcgdGhlIHJpZ2h0IHN3aXRjaGVzIGZvciBh IGNvdXBsZSBvZiBmdW5jdGlvbnMgcmVxdWlyZWQgc29tZSBzZWFyY2hpbmcsIGUuZy4gQVAgc291 cmNlIHN3aXRjaGluZywgZmxhcHMuICAgTmV3YXJrIEVsZWN0cm9uaWNzIHR1cm5lZCBvdXQgdG8g YmUgYSBncmVhdCAoc3RvY2tlZCkgc291cmNlIGZvciBzd2l0Y2ggaXRlbXMuICBDdXR0aW5nIHJl Y3Rhbmd1bGFyIGhvbGVzIGluIGFuIGFsdW1pbnVtIHBhbmVsIHR1cm5lZCBvdXQgdG8gYmUgc3Vy cHJpc2luZ2x5IGVhc3kgd2l0aCBhIGhhbmQgZmlsZS4gIFRoZSBsaWdodHMgZm9yIHRoZSBzd2l0 Y2hlcyB0dXJuIG91dCB0byBiZSB0cm91Ymxlc29tZS4uLiBpdCB0YWtlcyBzb21lIGZvb2xpbmcg YXJvdW5kIHRvIGdldCB0aGUgbGl0dGxlIGxpZ2h0cyB0byBjb25zaXN0ZW50bHkgc3RheSBsaXQg aW4gYSB2aWJyYXRpbmcgZW52aXJvbm1lbnQuICBUaGVyZSBhcmUgTEVEIGxpZ2h0cyBhdmFpbGFi bGUgYXMgd2VsbCBhcyB0aGUgc3RhbmRhcmQgaW5jYW5kZXNjZW50LiAgSSB1c2UgdGhlIExFRHMg YnV0IHdlbnQgdG8gaW5jYW5kZXNjZW50IGZvciBteSBMUkMzIGxvdyB2b2x0YWdlIGxpZ2h0cyBp biBvcmRlciBmb3IgdGhlbSB0byBmdW5jdGlvbiBwcm9wZXJseS4gIEImQyBjYW4gdGVsbCB5b3Ug aG93IHRvIG1ha2UgdGhlIExFRHMgd29yayB0aGVyZSBhcyB3ZWxsLg0KDQpJIHVzZWQgQU1MNDEg aW5kaWNhdG9ycyBmb3IgdGhlIGlkaW90IGxpZ2h0cy4gICAgVmVyeSAgaGFuZHNvbWUgd2hlbiBj b21iaW5lZCB3aXRoIHRoZSByb2NrZXJzLg0KDQpJIHVzZWQgZGltbWVycyBvbiBhbGwgc3dpdGNo ZXMgYW5kIDIgb2YgdGhlIGlkaW90IGxpZ2h0cy4NCg0KTm8gVlBOLCBkaWQgdXNlIEZhc3RzdGFj aywgZnVzZXMgYWxvbmcgd2l0aCA0IGJyZWFrZXJzLCBaLTE0DQoNCmEgZmV3IHBpY3MgaGVyZQ0K aHR0cDovL3d3dy5teWtpdGxvZy5jb20vdXNlcnMvY2F0ZWdvcnkucGhwP3VzZXI9TWF1bGVEcml2 ZXImcHJvamVjdD0yMjQmY2F0ZWdvcnk9NTI1Mw0KKEkgc2hvdWxkIGluY2x1ZGUgYSBwaWMgb2Yg dGhlIHdob2xlIHBhbmVsKQ0KDQpCaWxsICIzMDArIGhvdXJzIGFuZCBzdGlsbCBoYXZlbid0IHJl cGxhY2VkIHN0aWNrLW9uIHBhbmVsIGxhYmVscyIgV2F0c29uDQoNCg0KDQoNCg0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0K Xy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPSBB cmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0KXy09 IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0N Cg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQpfX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KTm8gdmlydXMgZm91bmQgaW4gdGhpcyBtZXNz YWdlLg0KQ2hlY2tlZCBieSBBVkcgLSB3d3cuYXZnLmNvbTxodHRwOi8vd3d3LmF2Zy5jb20+DQpW ZXJzaW9uOiAyMDEzLjAuMjkwNCAvIFZpcnVzIERhdGFiYXNlOiAzMjA0LzY0NDIgLSBSZWxlYXNl IERhdGU6IDA2LzI2LzEzDQpJbnRlcm5hbCBWaXJ1cyBEYXRhYmFzZSBpcyBvdXQgb2YgZGF0ZS4N Cg= ________________________________________________________________________________
Subject: o-540
From: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Date: Jul 08, 2013
I have an A&P friend whom I trust that has offered to help me rebuild an o-540. He said he has two o-540's in his shop and that we could go with the 235hp or we could change the pistons in one to make it a 250hp. He mentioned that with the 235hp you would have the ability to use auto gas in case you got in a bind somewhere. I've been planning on spending around $50,000 for a new io-540. If I go this route with my friend, it could save me probably 35-40%. How will using an 0-540 235hp or 250hp affect my fuel efficiency over a 260hp io-540? What kind of extra work will be required on the firewall, cowling, etc. for using a carbureted engine instead of a non-carbureted engine? I'm open to suggestions. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404218#404218 ________________________________________________________________________________
Subject: Safety Wire for Plane-Power Alternator Installation
Date: Jul 08, 2013
Does anyone have pics of their safety wiring the tension arm bolts? The distance between them seems a bit much to tie one to the other. Jeff Carpenter 40304 ________________________________________________________________________________
Subject: Re: Safety Wire for Plane-Power Alternator Installation
Date: Jul 08, 2013
Safety wire the bolt to the arm.... Sent from my iPhone On Jul 8, 2013, at 2:51 PM, Jeff Carpenter wrote: > > Does anyone have pics of their safety wiring the tension arm bolts? The distance between them seems a bit much to tie one to the other. > > Jeff Carpenter > 40304 > > > > ________________________________________________________________________________
Subject: o-540
Date: Jul 08, 2013
I believe there's more involved than a simple piston swap to convert it for 250 or 260 hp use, depending on the engine model. (I assume they are -A1A5?) Still might not be a bad way to go, but make sure you not just putting a heavy 8.5:1 piston in it. Rhonda Barrett-Bewley Barrett Precision Engines 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JHearnsberger Sent: Monday, July 08, 2013 2:23 PM Subject: RV10-List: o-540 I have an A&P friend whom I trust that has offered to help me rebuild an o-540. He said he has two o-540's in his shop and that we could go with the 235hp or we could change the pistons in one to make it a 250hp. He mentioned that with the 235hp you would have the ability to use auto gas in case you got in a bind somewhere. I've been planning on spending around $50,000 for a new io-540. If I go this route with my friend, it could save me probably 35-40%. How will using an 0-540 235hp or 250hp affect my fuel efficiency over a 260hp io-540? What kind of extra work will be required on the firewall, cowling, etc. for using a carbureted engine instead of a non-carbureted engine? I'm open to suggestions. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404218#404218 ________________________________________________________________________________
Date: Jul 08, 2013
Subject: Re: o-540
Save 35-40%?=C2- Yes you will save but you are not comparing= .=C2- I n the one case you have a new engine with factory warranty =C2-and in the other you have something all together different.=C2-One is fuel injected the other is carbureted . =C2-Not that going the mod route is bad, it is just that the savings you anticipated =C2-is because you changed the end result,=C2- not because of actual savings on equal engines. Extending that out to the ridiculous you could save 60 or 90%, but again yo u wouldn't be comparing = engines Gary Specketer ----- Original Message ----- From: "JHearnsberger" <jakehearnsberger(at)gmail.com> Sent: Monday, July 8, 2013 2:23:18 PM Subject: RV10-List: o-540 m> I have an A&P friend whom I trust that has offered to help me rebuild an o- 540. =C2-He said he has two o-540's in his shop and that we could go with =C2-the 235hp or we could change the pistons in one to make it a 250hp. =C2-He mentioned that with the 235hp you would have the ability to use au to gas in case you got in a bind somewhere. =C2-I've been planning on spe nding around $50,000 for a new io-540. =C2-If I go this route with my fri end, it could save me probably 35-40%. How will using an 0-540 235hp or 250hp affect my fuel efficiency over a 260 hp io-540? What kind of extra work will be required on the firewall, cowling, etc. for using a carbureted engine instead of a non-carbureted engine? I'm open to suggestions. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404218#404218 =========== =========== MS - =========== e - =C2- =C2- =C2- =C2- =C2--Matt Dralle, List Admin. =========== ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 08, 2013
I agree mostly with what others have said. The 235HP engine is 7:1 (or 7.2:1, maybe) compression pistons running at 2575 RPM max. The 250HP is 8.5:1 pistons running at 2575 RPM max. The 260HP is 8.5:1 running 2700 RPM max. Some engines have cast connecting rods and others have forged connecting rods (according to Allen Barrett). The counterweights are also different between engines. If you put 8.5:1 pistons in that engine, and run it at 2575 RPM, it will make roughly 250HP. This is what we have in N256H and have 1,350 hours on it. We may be slightly outclimbed by someone with 260HP for 1-2,000 ft, but then it would equal out, because once you pull the RPM back under 2575, the rest is equal with 8.5:1 pistons. The Carburetor vs Fuel Injection this is just a matter of personal preference. I would highly recommend Fuel Injection. That way you can lean much better and can tune your injectors for smoother running and overall better leaning yet. This shouldn't make any difference on HP. What engine would you be getting? Is it a new engine or a used engine? If you were expecting $50,000 on a new IO-540, then I would expect at least a 50% savings going with a used engine, and that should include new cylinders, new accessories, and a new fuel injection system. If it is a newly overhauled engine that he is trying to sell you, then 35-40% is reasonable, but it should also include new cylinders, new accessories (or overhauled) and a new or overhauled fuel injection system. There shouldn't be much difference on firewall, cowling or baffles with this engine, whether with a carburetor or fuel injection system. The baffles fit slightly different on different cases, but it's not a big deal. All parallel valve 540's should fit on the -10 just about the same. Some people have had to slightly modify their engine mount for different cases, but you could run into that with any engine, as I understand. I have never run into that, and have put lots of different sub-model-number 540's on -10's. Again, there should be nothing wrong with running either of his engines on your plane, but the cost of the engine and what you are getting is the biggest issue. Feel free to call me at my cell number below once you have information on what he has and we can talk further. The lower compression pistons will let you run low octane mogas, but if you are planning to have that just so you can get out of a jam, it really won't help. If you have to lug gas cans from a gas station to your plane because the airport doesn't have gas, then you are most likely going to be hauling gas with ethanol. If so, then why have pistons that can run 87 octane when you could just get the 91-93 octane gas from the same station with high compression pistons? That is the only benefit of the low compression pistons. I have an RV-9A that I put low compression pistons in because the no-ethanol mogas that we can get here in Florida is max 89 octane, and you need 91 or better for 8.5:1. There is possibly another difference in the cylinders that won't allow higher compression pistons, but I don't know for sure. If you are paying that much for an engine (and airplane as a whole, for that matter), throw a new set of 8.5:1 jugs on and a fuel injection system. You will be glad you did. By the way, most of this information I learned from Allen Barrett, and I hear he's a pretty smart guy when it comes to engines. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Jul 8, 2013, at 3:23 PM, JHearnsberger wrote: > > I have an A&P friend whom I trust that has offered to help me rebuild an o-540. He said he has two o-540's in his shop and that we could go with the 235hp or we could change the pistons in one to make it a 250hp. He mentioned that with the 235hp you would have the ability to use auto gas in case you got in a bind somewhere. I've been planning on spending around $50,000 for a new io-540. If I go this route with my friend, it could save me probably 35-40%. > > How will using an 0-540 235hp or 250hp affect my fuel efficiency over a 260hp io-540? > > What kind of extra work will be required on the firewall, cowling, etc. for using a carbureted engine instead of a non-carbureted engine? > > I'm open to suggestions. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404218#404218 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 08, 2013
Subject: Re: o-540
Some, not all 235 hp O-540s can run on 80/87 or most any grade mogas. Most 250/260 hp (I)O-540s can run on 91+ octane mogas as they were certified on 91/96 avgas, and have same octane requirements as the O-360, 180hp engines with the same cylinders that have STC's for mogas, like the Cherokee 180. As Rhonda says, you would need to be certain that the parts used were appropriate to the C4B% or A4D5 versions of the engine. There are a lot of different cranks that depend on the application and balance wts for the prop being considered. Then there are issues with ADs specific to certain models, what size/style mounting ears the engine has. While they can be changed, just another thing to get right from the start.If the mechanic is experienced, has all the needed micrometers and other measuring tools, to build a quality, new limits (not service limits) overhaul, it can be a good deal, but there are a number of pitfalls for someone that isn't familiar with the precise version engine you need. The lower compression engine version of the 235 will not be as fuel efficient, but is very durable. On 7/8/2013 12:23 PM, JHearnsberger wrote: > > I have an A&P friend whom I trust that has offered to help me rebuild an o-540. He said he has two o-540's in his shop and that we could go with the 235hp or we could change the pistons in one to make it a 250hp. He mentioned that with the 235hp you would have the ability to use auto gas in case you got in a bind somewhere. I've been planning on spending around $50,000 for a new io-540. If I go this route with my friend, it could save me probably 35-40%. > > How will using an 0-540 235hp or 250hp affect my fuel efficiency over a 260hp io-540? > > What kind of extra work will be required on the firewall, cowling, etc. for using a carbureted engine instead of a non-carbureted engine? > > I'm open to suggestions. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404218#404218 > > ________________________________________________________________________________
Date: Jul 08, 2013
Ran into the same issue a few months back. Just drill some small holes into the tension arm and run the safety wire from the bolt to the hole and tie it off. -------- Todd Stovall aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace RV-10 N728TT Empacone, Wings, Fuse, Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404239#404239 ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 08, 2013
Thank you guys for your responses. I've brought up several topics. I should have kept my question to fuel efficiency only. Comparing the 235 to the 260. -------- Jake Hearnsberger RV-10 Wings Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404242#404242 ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Re: o-540
You can throttle back on the 260 hp models to get the same hp and fuel burn as the 235 hp if fuel burn is of concern. Its nice to have those extra ponies available though for when you need them. David Clifford RV-10 Builder Howell, MI ----- Original Message ----- From: "JHearnsberger" <jakehearnsberger(at)gmail.com> Sent: Monday, July 8, 2013 8:43:56 PM Subject: RV10-List: Re: o-540 Thank you guys for your responses. I've brought up several topics. I should have kept my question to fuel efficiency only. Comparing the 235 to the 260. -------- Jake Hearnsberger RV-10 Wings Springhill, LA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404242#404242 ________________________________________________________________________________
Date: Jul 08, 2013
While it may be "okay" to drill a hole, there is no need to. You can easily safety directly to the arm. That is done all the time on certified aircraft. On Mon, Jul 8, 2013 at 2:50 PM, tsts4 wrote: > > Ran into the same issue a few months back. Just drill some small holes > into the tension arm and run the safety wire from the bolt to the hole and > tie it off. > > -------- > Todd Stovall > aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace > RV-10 N728TT > Empacone, Wings, Fuse, Finishing > www.mykitlog.com/auburntsts > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404239#404239 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jul 08, 2013
Subject: Re: o-540
Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also means you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel burn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would cost you around $2,800 in additional fuel cost..... so over the life of the TBO, over $10,000!!!!!!!! Don McDonald ________________________________________________________________________________
Date: Jul 08, 2013
Subject: Re: o-540
Actually, the 260 operated at 176 hp, or 75 percent for a 235, will get better economy because of the higher compression. For example, a Mooney 201 with 200 hp Lycoming will out run a Mooney 231 with Continental turbocharged 210 hp engine below 8000 ft, simply because the turbo isn't producing any more power there than the normally aspirated engine. The Lyc is 8.7 to 1 while the Cont is 7 to 1. Lyc operates at atmospheric pressure, Cont at 39 inches to make up for the lower compression. The Lyc burns 11 gph in cruise ROP, the Cont burns 12-13 at same power. The 231 doesn't shine until it gets above 10,000 ft where it can produce more power than the normally aspirated 201. Their airframes are pretty identical outside powerplant differences. Another example...Bonanza with IO-470 260hp engine will burn more fuel on all but very short flights than one with STC'd IO-550 310 hp, especially if they both operate at the same indicated airspeed, just because the bigger engine breathes more efficiently and can get up to altitude faster. On Mon, Jul 8, 2013 at 7:03 PM, wrote: > You can throttle back on the 260 hp models to get the same hp and fuel > burn as the 235 hp if fuel burn is of concern. Its nice to have those > extra ponies available though for when you need them. > > David Clifford > > RV-10 Builder > Howell, MI > > ------------------------------ > *From: *"JHearnsberger" <jakehearnsberger(at)gmail.com> > *To: *rv10-list(at)matronics.com > *Sent: *Monday, July 8, 2013 8:43:56 PM > *Subject: *RV10-List: Re: o-540 > > > jakehearnsberger(at)gmail.com> > > Thank you guys for your responses. I've brought up several topics. I > should have kept my question to fuel efficiency only. Comparing the 235 to > the 260. > > -------- > Jake Hearnsberger > RV-10 Wings > Springhill, LA > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p= &= > > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 08, 2013
Performance Engines out of La Verne, CA built my IO-540. With 10:1 compression and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have put 8003 gallons of 100LL in, just about exactly 10 GPH average. (I'm not going to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also means you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel burn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would cost you around $2,800 in additional fuel cost..... so over the life of the TBO, over $10,000!!!!!!!! Don McDonald _____ ________________________________________________________________________________
Subject: servos
Date: Jul 09, 2013
Hi all, I posted an ad at http://www.vansairforce.com/community/showthread.php?t=101646 selling my TT servos. Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
Date: Jul 09, 2013
Thank you all for your opinions, I=99m still undecided but I think I=99ll go for the toggles. Best Carlos ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Re: o-540
Since Performance Engines has been brought up in this thread . . . Many have had great experiences with them, but the Lancair community has had some pretty serious safety issues come up. I personally have no facts, so I will not judge, but my opinion is that it should be disclosed that past customers have brought to light some issues with Continental engines. Below is a snippet from the Lancair Yahoo group from 2010 and more info can be found on LML (Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down fo r inspection only to find unserviceable or out of tolerance parts installed. In one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very close attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner wrot e: > Performance Engines out of La Verne, CA built my IO-540. With 10:1 > compression and 1 Lightspeed they rated it at 310 HP. With 799 hours on i t > I have put 8003 gallons of 100LL in, just about exactly 10 GPH average. > (I=92m not going to tell my wife how much 8K gallons of gas costs)**** > > Albert Gardner**** > > N991RV**** > > Yuma, AZ**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Don McDonald > *Sent:* Monday, July 08, 2013 8:27 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Re: o-540**** > > ** ** > > Every RV'er that has ever gone with less hp or smaller displacement, > always pays the price. They have to run a higher percentage of power just > to keep up, and because of that they also end up burning more fuel. Also if > you're carbeurated you have more difficulty running lean of peak, which > also means you burn more fuel. > A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel > burn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do > the math, I now have over 500 hours, at a 1+ gph more fuel burn, that wou ld > cost you around $2,800 in additional fuel cost..... so over the life of t he > TBO, over $10,000!!!!!!!! > Don McDonald**** > > ** ** > ------------------------------ > > * > =========== =========== =========== =========== > * > > -- *Aircrafters* 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 09, 2013
Hard to go wrong with Barrett unless you don't like to be pushed back in yo ur seat when you advance the throttle. :). Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Tim Farrell Sent: Tuesday, July 09, 2013 9:42 AM Subject: Re: RV10-List: Re: o-540 Since Performance Engines has been brought up in this thread . . . Many ha ve had great experiences with them, but the Lancair community has had some pretty serious safety issues come up. I personally have no facts, so I wil l not judge, but my opinion is that it should be disclosed that past custom ers have brought to light some issues with Continental engines. Below is a snippet from the Lancair Yahoo group from 2010 and more info can be found on LML (Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down fo r inspection only to find unserviceable or out of tolerance parts installed. In one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very clo se attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner > wrote: Performance Engines out of La Verne, CA built my IO-540. With 10:1 compress ion and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have p ut 8003 gallons of 100LL in, just about exactly 10 GPH average. (I'm not go ing to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also mean s you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel bu rn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would co st you around $2,800 in additional fuel cost..... so over the life of the T BO, over $10,000!!!!!!!! Don McDonald ________________________________ get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Aircrafters 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com<http://www.AircraftersLLC.com> ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 09, 2013
I concur. I wish they were still selling new kits when I bought mine. I di d help facilitate getting a neighbor's engine overhauled by Barrett. Qualit y was second to none. You can't beat the support both Rhonda and Alan have g iven the RV-10 community. They've been known to hang out at the RV-10 hq at OSH. Given folks their pe rsonal cell numbers and taking calls during off hours. Help folks when ther e is no money in it for them. Hang out here and on VAF. Generally all arou nd good people that do their best to support the experimental community. Yo u can't ask for better support. Bob Sent from my iPhone On Jul 9, 2013, at 1:31 PM, Robin Marks wrote: Hard to go wrong with Barrett unless you don=99t like to be pushed bac k in your seat when you advance the throttle. J. Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ma tronics.com] On Behalf Of Tim Farrell Sent: Tuesday, July 09, 2013 9:42 AM Subject: Re: RV10-List: Re: o-540 Since Performance Engines has been brought up in this thread . . . Many hav e had great experiences with them, but the Lancair community has had some pr etty serious safety issues come up. I personally have no facts, so I will n ot judge, but my opinion is that it should be disclosed that past customers h ave brought to light some issues with Continental engines. Below is a snipp et from the Lancair Yahoo group from 2010 and more info can be found on LML ( Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down for inspection only to find unserviceable or out of tolerance parts installed. I n one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very clos e attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner wrot e: Performance Engines out of La Verne, CA built my IO-540. With 10:1 compressi on and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have put 8003 gallons of 100LL in, just about exactly 10 GPH average. (I=99m n ot going to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ma tronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always p ays the price. They have to run a higher percentage of power just to keep up , and because of that they also end up burning more fuel. Also if you're car beurated you have more difficulty running lean of peak, which also means you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel bur n between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the m ath, I now have over 500 hours, at a 1+ gph more fuel burn, that would cost y ou around $2,800 in additional fuel cost..... so over the life of the TBO, o ver $10,000!!!!!!!! Don McDonald get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Aircrafters 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com ============== V10-List Email Forum - > :p> /o:p > tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ===== ========= bsp; - MATRONICS WEB FORUMS - :p> tp://forums .matronics.com ============== bsp; - List Contr ibution Web Site - e> bsp; -Matt Dralle, List Admin. butio n">http://www.matronics.com/contribution ============ = No virus found in this message. Checked by AVG - www.avg.com r> ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 09, 2013
We hope to see you all at the RV gathering hosted by the beer fairy on Monday night at Osh. We'll be there with bells on! Rhonda Barrett-Bewley Barrett Precision Engines 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Tuesday, July 09, 2013 12:54 PM Subject: Re: RV10-List: Re: o-540 I concur. I wish they were still selling new kits when I bought mine. I did help facilitate getting a neighbor's engine overhauled by Barrett. Quality was second to none. You can't beat the support both Rhonda and Alan have given the RV-10 community. They've been known to hang out at the RV-10 hq at OSH. Given folks their personal cell numbers and taking calls during off hours. Help folks when there is no money in it for them. Hang out here and on VAF. Generally all around good people that do their best to support the experimental community. You can't ask for better support. Bob Sent from my iPhone On Jul 9, 2013, at 1:31 PM, Robin Marks wrote: Hard to go wrong with Barrett unless you don't like to be pushed back in your seat when you advance the throttle. :-). Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Farrell Sent: Tuesday, July 09, 2013 9:42 AM Subject: Re: RV10-List: Re: o-540 Since Performance Engines has been brought up in this thread . . . Many have had great experiences with them, but the Lancair community has had some pretty serious safety issues come up. I personally have no facts, so I will not judge, but my opinion is that it should be disclosed that past customers have brought to light some issues with Continental engines. Below is a snippet from the Lancair Yahoo group from 2010 and more info can be found on LML (Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down for inspection only to find unserviceable or out of tolerance parts installed. In one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very close attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner wrote: Performance Engines out of La Verne, CA built my IO-540. With 10:1 compression and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have put 8003 gallons of 100LL in, just about exactly 10 GPH average. (I'm not going to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also means you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel burn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would cost you around $2,800 in additional fuel cost..... so over the life of the TBO, over $10,000!!!!!!!! Don McDonald ________________________________ get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Aircrafters 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com ============== V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============== bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============== bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============== ________________________________ No virus found in this message. Checked by AVG - www.avg.com r> ========= ://www.matronics.com/Navigator?RV10-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: Jul 09, 2013
Subject: Blocking heater vent outlets
My rear heater leaks--the door is bent, so even when it's closed, it still lets a decent amount of hot air through. As a temporary fix, does anyone see a problem with using aluminum tape to block the air outlets, by the rear passenger feet? I figure there will be no air flow, so no issue. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Subject: Looking for some tools
Date: Jul 09, 2013
My RV 10 is set for delivery in August. Im getting the shop in order and I would like to buy some used tools for the build. If you are tired of dust collecting on those tools you used for your build and you would like to get rid of them, send me a PM with your contact info, what you have to sell, or both. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404337#404337 ________________________________________________________________________________
Subject: Re: Blocking heater vent outlets
Date: Jul 09, 2013
Block the inlet in the engine compartment. Dave Leikam On Jul 9, 2013, at 4:32 PM, Rob Kochman wrote: > My rear heater leaks--the door is bent, so even when it's closed, it still lets a decent amount of hot air through. As a temporary fix, does anyone see a problem with using aluminum tape to block the air outlets, by the rear passenger feet? I figure there will be no air flow, so no issue. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > > ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 10, 2013
... and they love to put in Lightspeed Ignitions. Or at least they loved m ine. :) Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Robin Marks Sent: Tuesday, July 09, 2013 12:32 PM Subject: RE: RV10-List: Re: o-540 Hard to go wrong with Barrett unless you don't like to be pushed back in yo ur seat when you advance the throttle. :). Robin From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Farrell Sent: Tuesday, July 09, 2013 9:42 AM Subject: Re: RV10-List: Re: o-540 Since Performance Engines has been brought up in this thread . . . Many ha ve had great experiences with them, but the Lancair community has had some pretty serious safety issues come up. I personally have no facts, so I wil l not judge, but my opinion is that it should be disclosed that past custom ers have brought to light some issues with Continental engines. Below is a snippet from the Lancair Yahoo group from 2010 and more info can be found on LML (Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down fo r inspection only to find unserviceable or out of tolerance parts installed. In one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very clo se attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner > wrote: Performance Engines out of La Verne, CA built my IO-540. With 10:1 compress ion and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have p ut 8003 gallons of 100LL in, just about exactly 10 GPH average. (I'm not go ing to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com<mailto:owner-rv10-list-server@ma tronics.com> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also mean s you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel bu rn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would co st you around $2,800 in additional fuel cost..... so over the life of the T BO, over $10,000!!!!!!!! Don McDonald ________________________________ get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Aircrafters 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com<http://www.AircraftersLLC.com> ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= ________________________________ No virus found in this message. Checked by AVG - www.avg.com<http://www.avg.com> r> ________________________________________________________________________________
Subject: Re: o-540
Date: Jul 10, 2013
That's it....you owe me a beer! Rhonda Barrett-Bewley Barrett Precision Engines 2870-B N. Sheridan Rd. Tulsa, OK 74115 (918) 835-1089 phone (918) 835-1754 fax www.barrettprecisionengines.com ________________________________ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Sausen Sent: Wednesday, July 10, 2013 1:23 PM Subject: RE: RV10-List: Re: o-540 ... and they love to put in Lightspeed Ignitions. Or at least they loved mine. :) Michael From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks Sent: Tuesday, July 09, 2013 12:32 PM Subject: RE: RV10-List: Re: o-540 Hard to go wrong with Barrett unless you don't like to be pushed back in your seat when you advance the throttle. :-). Robin From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Farrell Sent: Tuesday, July 09, 2013 9:42 AM Subject: Re: RV10-List: Re: o-540 Since Performance Engines has been brought up in this thread . . . Many have had great experiences with them, but the Lancair community has had some pretty serious safety issues come up. I personally have no facts, so I will not judge, but my opinion is that it should be disclosed that past customers have brought to light some issues with Continental engines. Below is a snippet from the Lancair Yahoo group from 2010 and more info can be found on LML (Lancair Mailing List). "There's been a lot of talk lately on other sites regarding the overhauled engines delivered by Performance Engines of La Vern, CA. There have been several total failures lately and a few others have had theirs torn down for inspection only to find unserviceable or out of tolerance parts installed. In one case, the engine case was cracked. This is causing many owners a lot of money and putting their lives at risk. The FAA is currently paying very close attention to PE." On Mon, Jul 8, 2013 at 10:26 PM, Albert Gardner wrote: Performance Engines out of La Verne, CA built my IO-540. With 10:1 compression and 1 Lightspeed they rated it at 310 HP. With 799 hours on it I have put 8003 gallons of 100LL in, just about exactly 10 GPH average. (I'm not going to tell my wife how much 8K gallons of gas costs) Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald Sent: Monday, July 08, 2013 8:27 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: Re: o-540 Every RV'er that has ever gone with less hp or smaller displacement, always pays the price. They have to run a higher percentage of power just to keep up, and because of that they also end up burning more fuel. Also if you're carbeurated you have more difficulty running lean of peak, which also means you burn more fuel. A friend of mine with a new Mattituck, carbed 540 has an avg cruise fuel burn between 11 and 12 gph.... whereas I burn between 9.6 and 10.2.... do the math, I now have over 500 hours, at a 1+ gph more fuel burn, that would cost you around $2,800 in additional fuel cost..... so over the life of the TBO, over $10,000!!!!!!!! Don McDonald ________________________________ get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Aircrafters 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= ________________________________ No virus found in this message. Checked by AVG - www.avg.com r> ============= V10-List Email Forum - > :p> /o:p> tor?RV10-List">http://www.matronics.com/Navigator?RV10-List ============= bsp; - MATRONICS WEB FORUMS - :p> tp://forums.matronics.com ============= bsp; - List Contribution Web Site - e> bsp; -Matt Dralle, List Admin. bution">http://www.matronics.com/contribution ============= ________________________________________________________________________________
Subject: Re: 2013 RV-10 Airventure Group Camping
Date: Jul 10, 2013
SeKAmW0gcHJldHR5IHN1cmUgSm9obiBvd2VzIG1lIGEgZmV3IHlldC4gIE5pY2UgdG8gc2VlIHRo YXQgSSBjYW4gZHJvcCBvZmYgdGhlIGxpc3QgZm9yIGEgd2hpbGUgYW5kIGl04oCZcyBzdGlsbCBt b3N0bHkgdGhlIHNhbWUgZmFjZXMuICBTZWUgeW91IGd1eXMgaW4gYSBjb3VwbGUgd2Vla3MuDQoN Ck1pY2hhZWwNCg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFtt YWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Yg Qm9iIENvbmRyZXkNClNlbnQ6IFdlZG5lc2RheSwgSnVseSAwMywgMjAxMyAzOjU1IFBNDQpUbzog cnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFJlOiAyMDEz IFJWLTEwIEFpcnZlbnR1cmUgR3JvdXAgQ2FtcGluZw0KDQpJIGdvdCBoaW0gY292ZXJlZCBKb2hu LCBidXQgc3RvcCBieSBhbnl3YXkhICBUaGUgYmVlciBpcyBvbiBtZSB0aGlzIHRpbWUuDQoNCkJv Yg0KDQpPbiBXZWRuZXNkYXksIEp1bHkgMywgMjAxMywgSm9obiBDb3ggd3JvdGU6DQpDb21pbmcg aW4gZnJvbSBNS0Ugd2l0aCBhIEZvcmQgRURHRSBTVVYuICBIb3cgY2FuIEkgaGVscC4NCg0KSm9o biBDb3gNCg0KT24gVHVlLCBKdWwgMiwgMjAxMyBhdCAyOjU0IFBNLCBlaXNvbiA8ZWlzb24xOTY5 QHlhaG9vLmNvbTxqYXZhc2NyaXB0Ol9lKCU3YiU3ZCwlMjAnY3ZtbCcsJTIwJ2Vpc29uMTk2OUB5 YWhvby5jb20nKTs+PiB3cm90ZToNCi0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJl aXNvbiIgPGVpc29uMTk2OUB5YWhvby5jb208amF2YXNjcmlwdDpfZSglN2IlN2QsJTIwJ2N2bWwn LCUyMCdlaXNvbjE5NjlAeWFob28uY29tJyk7Pj4NCg0KSSBhbSBpbiB0aGUgZmluYWwgcGxhbm5p bmcgc3RhZ2VzIGZvciBPc2guICBJIGFtIGNhbXBpbmcgd2l0aCB0aGUgZ3JvdXAgYW5kIGhhdmlu ZyBhbiBSViBkcm9wcGVkIG9mZiBvbiBGcmlkYXkuICBJIGFtIHBsYW5uaW5nIG9uIGZseWluZyBp biBTYXR1cmRheSBsYXRlIG1vcm5pbmcuDQoNCkkgaGF2ZSBvbmUgb3BlbiBpdGVtLCBJIGhhdmUg cmVudGVkIGZyb20gVW5pdGVkIFJlbnRhbHMvUlNDIGluIE9zaGtvc2ggYSBnZW5lcmF0b3IgaW4g b3JkZXIgdG8gaGF2ZSBhIG5pY2UgY29vbCBwbGFjZSB0byBoYW5nIG91dCBpbiB0aGUgbWlkZGxl IG9mIHRoZSBkYXkuICBIb3dldmVyLCB0aGUgUlYgcGxhY2UgaXNuJ3QgYWxsb3dlZCB0byBwaWNr IHVwIGdlbmVyYXRvcnMsIGFuZCB1bml0ZWQgUmVudGFscyB3YW50cyBtb3JlIHRvIHBpY2sgdXAg YW5kIGRyb3Agb2ZmIHRoYW4gdGhlIGNvc3Qgb2YgdGhlIHJlbnRhbC4gIEFkZGl0aW9uYWxseSwg dGhleSBhcmVuJ3Qgb3BlbiBvbiB0aGUgd2Vla2VuZHMuLi4uLg0KDQpJcyBhbnlvbmUgZHJpdmlu ZyBpbiBvbiBGcmlkYXkgdGhlIDI2dGggdGhhdCB3b3VsZG4ndCBtaW5kIGdyYWJiaW5nIGEgZ2Vu ZXJhdG9yIGZvciBtZT8gIEZhaWxpbmcgdGhhdCwgTW9uZGF5Pw0KDQpJZiBhbGwgZWxzZSBmYWls cywgd2UgY2FuIGdvIHBvd2VybGVzcyBvciBwYXkgdGhlIGV4dHJhIGZlZS4gIEtlZXBpbmcgdGhl IHdpZmUgYW5kIGtpZCBoYXBweSBpcyBpbXBvcnRhbnQgcmlnaHQ/Pz8/DQoNCllvdSBjYW4gZW1h aWwgbWUgYXQgRWlzb24xOTY5IGF0IHlhaG9vIGRvdCBjb20NCg0KDQpUaGFua3MNCg0KRXJpYyBJ c29uDQoNCi0tLS0tLS0tDQpFcmljIElzb24NClJWIDEwICM0MDc2NA0KTjk4NEVEIChyZXNlcnZl ZCkNCg0KDQoNCg0KUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0KDQpodHRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQwMzgyOCM0MDM4MjgNCg0KDQoNCg0KDQoN Cg0KPT09PT09PT09PT0NCmFyZ2V0PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9O YXZpZ2F0b3I/UlYxMC1MaXN0DQo9PT09PT09PT09PQ0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tDQo9PT09PT09PT09PQ0KbGUsIExpc3QgQWRtaW4uDQo9Il9ibGFuayI+aHR0cDovL3d3dy5t YXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPT09PT09PT09PT0NCg0KDQoNCg0KDQoNCg0KDQpn ZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QN Cg0KdHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9jb250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAgICAg IC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2UgdGhlIE1hdHJvbmljcyBM aXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRoZSBtYW55IExpc3QgdXRp bGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8tPSBBcmNoaXZlIFNlYXJj aCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0KXy09IFBob3Rvc2hhcmUs IGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAg ICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBTYW1lIGdyZWF0IGNvbnRl bnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpfLT0NCg0KXy09ICAgLS0+ IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KXy09ICAgICAg ICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpfLT0gIFRoYW5rIHlvdSBm b3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1h dHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0K ________________________________________________________________________________
Subject: Re: Things needed for the build
Date: Jul 10, 2013
Just want to say thanks. I have a good list put together based on all your input. It was very helpful and informative. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404406#404406 ________________________________________________________________________________
Date: Jul 10, 2013
V2hhdOKAmXMgYW1hemluZyAodG8gbWUpIGlzIGhvdyBsaXR0bGUgYnVpbGRpbmcgUeKAmXMgaGFw cGVuIG9uIHRoZSBsaXN0IHRoZXNlIGRheXMuIEkgaGFkIGFib3V0IGEgbWlsbGlvbiBR4oCZcyB3 aGVuIGJ1aWxkaW5nIGJ1dCBhcHBhcmVudGx5IHRoZSAtMTAganVzdCBzbmFwcyB0b2dldGhlciBu b3cuDQoNClJvYmluDQpEbyBOb3QgQXJjaGl2ZQ0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmlj cy5jb21dIE9uIEJlaGFsZiBPZiBNaWNoYWVsIFNhdXNlbg0KU2VudDogV2VkbmVzZGF5LCBKdWx5 IDEwLCAyMDEzIDExOjMwIEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6 IFJFOiBSVjEwLUxpc3Q6IFJlOiAyMDEzIFJWLTEwIEFpcnZlbnR1cmUgR3JvdXAgQ2FtcGluZw0K DQpJ4oCZbSBwcmV0dHkgc3VyZSBKb2huIG93ZXMgbWUgYSBmZXcgeWV0LiAgTmljZSB0byBzZWUg dGhhdCBJIGNhbiBkcm9wIG9mZiB0aGUgbGlzdCBmb3IgYSB3aGlsZSBhbmQgaXTigJlzIHN0aWxs IG1vc3RseSB0aGUgc2FtZSBmYWNlcy4gIFNlZSB5b3UgZ3V5cyBpbiBhIGNvdXBsZSB3ZWVrcy4N Cg0KTWljaGFlbA0KDQpGcm9tOiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb208 bWFpbHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbT4gW21haWx0bzpvd25l ci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBCb2IgQ29uZHJl eQ0KU2VudDogV2VkbmVzZGF5LCBKdWx5IDAzLCAyMDEzIDM6NTUgUE0NClRvOiBydjEwLWxpc3RA bWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+DQpTdWJqZWN0OiBS ZTogUlYxMC1MaXN0OiBSZTogMjAxMyBSVi0xMCBBaXJ2ZW50dXJlIEdyb3VwIENhbXBpbmcNCg0K SSBnb3QgaGltIGNvdmVyZWQgSm9obiwgYnV0IHN0b3AgYnkgYW55d2F5ISAgVGhlIGJlZXIgaXMg b24gbWUgdGhpcyB0aW1lLg0KDQpCb2INCg0KT24gV2VkbmVzZGF5LCBKdWx5IDMsIDIwMTMsIEpv aG4gQ294IHdyb3RlOg0KQ29taW5nIGluIGZyb20gTUtFIHdpdGggYSBGb3JkIEVER0UgU1VWLiAg SG93IGNhbiBJIGhlbHAuDQoNCkpvaG4gQ294DQoNCk9uIFR1ZSwgSnVsIDIsIDIwMTMgYXQgMjo1 NCBQTSwgZWlzb24gPGVpc29uMTk2OUB5YWhvby5jb208amF2YXNjcmlwdDpfZSglN2IlN2QsJTIw J2N2bWwnLCUyMCdlaXNvbjE5NjlAeWFob28uY29tJyk7Pj4gd3JvdGU6DQotLT4gUlYxMC1MaXN0 IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiZWlzb24iIDxlaXNvbjE5NjlAeWFob28uY29tPGphdmFzY3Jp cHQ6X2UoJTdiJTdkLCUyMCdjdm1sJywlMjAnZWlzb24xOTY5QHlhaG9vLmNvbScpOz4+DQoNCkkg YW0gaW4gdGhlIGZpbmFsIHBsYW5uaW5nIHN0YWdlcyBmb3IgT3NoLiAgSSBhbSBjYW1waW5nIHdp dGggdGhlIGdyb3VwIGFuZCBoYXZpbmcgYW4gUlYgZHJvcHBlZCBvZmYgb24gRnJpZGF5LiAgSSBh bSBwbGFubmluZyBvbiBmbHlpbmcgaW4gU2F0dXJkYXkgbGF0ZSBtb3JuaW5nLg0KDQpJIGhhdmUg b25lIG9wZW4gaXRlbSwgSSBoYXZlIHJlbnRlZCBmcm9tIFVuaXRlZCBSZW50YWxzL1JTQyBpbiBP c2hrb3NoIGEgZ2VuZXJhdG9yIGluIG9yZGVyIHRvIGhhdmUgYSBuaWNlIGNvb2wgcGxhY2UgdG8g aGFuZyBvdXQgaW4gdGhlIG1pZGRsZSBvZiB0aGUgZGF5LiAgSG93ZXZlciwgdGhlIFJWIHBsYWNl IGlzbid0IGFsbG93ZWQgdG8gcGljayB1cCBnZW5lcmF0b3JzLCBhbmQgdW5pdGVkIFJlbnRhbHMg d2FudHMgbW9yZSB0byBwaWNrIHVwIGFuZCBkcm9wIG9mZiB0aGFuIHRoZSBjb3N0IG9mIHRoZSBy ZW50YWwuICBBZGRpdGlvbmFsbHksIHRoZXkgYXJlbid0IG9wZW4gb24gdGhlIHdlZWtlbmRzLi4u Li4NCg0KSXMgYW55b25lIGRyaXZpbmcgaW4gb24gRnJpZGF5IHRoZSAyNnRoIHRoYXQgd291bGRu J3QgbWluZCBncmFiYmluZyBhIGdlbmVyYXRvciBmb3IgbWU/ICBGYWlsaW5nIHRoYXQsIE1vbmRh eT8NCg0KSWYgYWxsIGVsc2UgZmFpbHMsIHdlIGNhbiBnbyBwb3dlcmxlc3Mgb3IgcGF5IHRoZSBl eHRyYSBmZWUuICBLZWVwaW5nIHRoZSB3aWZlIGFuZCBraWQgaGFwcHkgaXMgaW1wb3J0YW50IHJp Z2h0Pz8/Pw0KDQpZb3UgY2FuIGVtYWlsIG1lIGF0IEVpc29uMTk2OSBhdCB5YWhvbyBkb3QgY29t DQoNCg0KVGhhbmtzDQoNCkVyaWMgSXNvbg0KDQotLS0tLS0tLQ0KRXJpYyBJc29uDQpSViAxMCAj NDA3NjQNCk45ODRFRCAocmVzZXJ2ZWQpDQoNCg0KDQoNClJlYWQgdGhpcyB0b3BpYyBvbmxpbmUg aGVyZToNCg0KaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MDM4 MjgjNDAzODI4DQoNCg0KDQoNCg0KDQoNCj09PT09PT09PT09DQphcmdldD0iX2JsYW5rIj5odHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KPT09PT09PT09PT0NCmh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPT09PT09PT09PT0NCmxlLCBMaXN0IEFkbWluLg0K PSJfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj09PT09PT09 PT09DQoNCg0KDQoNCg0KDQoNCmdldD0iX2JsYW5rIj5odHRwOi8vd3d3Lm1hdHJvbmljcy5jb20v TmF2aWdhdG9yP1JWMTAtTGlzdA0KDQp0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCl9ibGFu ayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQoNCg0KDQoNCg0KDQpf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KDQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCg0KXy09 IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KDQpf LT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwN Cg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFR LA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KDQpfLT0NCg0KXy09ICAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQoNCl8tPQ0K DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCg0K Xy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMh DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCl8tPQ0K DQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAt DQoNCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQoNCl8tPSAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCg0KXy09 ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0KXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0K DQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpObyB2aXJ1cyBmb3VuZCBpbiB0 aGlzIG1lc3NhZ2UuDQpDaGVja2VkIGJ5IEFWRyAtIHd3dy5hdmcuY29tPGh0dHA6Ly93d3cuYXZn LmNvbT4NClZlcnNpb246IDIwMTMuMC4zMzQ5IC8gVmlydXMgRGF0YWJhc2U6IDMyMDQvNjQ3NiAt IFJlbGVhc2UgRGF0ZTogMDcvMDkvMTMNCmt577+977+977+9Iu+/ve2color77+9TTTvv71H77+9 ce+/vSjvv73vv73vv73vv71377+9cu+/ve+/ve+/ve+/vdOF77+9Ve+/vULvv73vv70mailF77+9 77+977+9Uset77+977+977+977+9J++/ve+/vQ0K77+977+9RXnvv71u77+977+9IGrvv73vv71q 77+9K++/ve+/ve+/vQ0K4oCR77+977+9anzvv73vv73vv71u77+9KWLvv70n77+977+977+9IWrv v73vv73vv70n77+9K++/ve+/ve+/ve+/vdio77+9INyGK++/vUnvv71y77+977+9eWhp77+977+9 ayBr77+9DQrigJEg77+9FO+/ve+/vWjvv73vv71577+93Zrvv70h77+977+9Ie+/ve+/ve+/vWrv v71+be+/ve+/ve+/ve+/vSDvv73vv73vv70n77+977+9HO+/vW/vv71q77+977+9au+/vStFXXQu Ky3vv73vv71p77+977+9MO+/vWbvv73vv73vv73vv71y77+9KO+/ve+/vVrvv70o77+977+977+9 V10NCu+/ve+/vX9o77+9E0Tvv71IICXvv71T77+9UMSSamfvv73vv73vv71y77+977+9enta77+9 77+977+977+977+9ae+/vV7vv70m77+977+977+9bFor77+9a++/ve+/ve+/ve+/ve+/vWnvv73v v73vv73prJnvv71r77+9eO+/ve+/ve+/vSbvv73vv71p77+977+977+96ayZ77+9a++/vXjvv73v v73vv70m77+977+977+90Kjvv73vv73vv71u77+9Yu+/vXXvv71tKO+/vXk4Wu+/vUzvv73vv73v v70ryovvv73vv73vv73eru+/ve+/ve+/ve+/vWnvv73vv71Mau+/vUPvv73vv71leO+/ve+/ve+/ vWbvv71277+977+977+977+977+9f++/vQ0KMO+/ve+/vWvvv71477+977+977+9Ju+/ve+/vSfv v73vv73vv73vv73YqO+/vW3vv73vv73vv73vv70g77+977+977+9J++/ve+/vRzvv71v3KJ7a++/ ve+/ve+/ve+/ve+/ve+/vWvvv73vv71+77+977+977+977+977+977+977+977+977+9be+/vQ0K ________________________________________________________________________________
Date: Jul 10, 2013
Subject: Re: o-540
And a keyboard! ;-0 On 7/10/2013 11:26 AM, Rhonda Bewley wrote: > > That's it....you owe me a beer! > > **Rhonda Barrett-Bewley** > > //Barrett Precision Engines// > > 2870-B N. Sheridan Rd. > > Tulsa, OK 74115 > > (918) 835-1089 phone > > (918) 835-1754 fax > > www.barrettprecisionengines.com <http://www.barrettprecisionengines.com> > > ------------------------------------------------------------------------ > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Michael > Sausen > *Sent:* Wednesday, July 10, 2013 1:23 PM > *To:* rv10-list(at)matronics.com > *Subject:* RE: RV10-List: Re: o-540 > > ... and they love to put in Lightspeed Ignitions. Or at least they > loved mine. :) > > Michael > > ________________________________________________________________________________
Date: Jul 10, 2013
SGV5IGNhcmVmdWwgd2hhdCB5b3Ugd2lzaCBmb3IgUm9iaW4uICBJJ20ganVzdCB3b3JraW5nIG9u IGZpdHRpbmcgdGhlIGRvb3JzDQpub3csIGFuZCBJIGNvdWxkIHNlbmQgbG90cyBvZiBxdWVzdGlv bnMgeW91ciB3YXkuLi4uLi47LSkNCg0KUmljaw0KU291dGhhbXB0b24sIE9udA0KDQoNCk9uIFdl ZCwgSnVsIDEwLCAyMDEzIGF0IDU6MTcgUE0sIFJvYmluIE1hcmtzIDxyb2JpbkBwYWludHRoZXdl Yi5jb20+IHdyb3RlOg0KDQo+ICBXaGF04oCZcyBhbWF6aW5nICh0byBtZSkgaXMgaG93IGxpdHRs ZSBidWlsZGluZyBR4oCZcyBoYXBwZW4gb24gdGhlIGxpc3QNCj4gdGhlc2UgZGF5cy4gSSBoYWQg YWJvdXQgYSBtaWxsaW9uIFHigJlzIHdoZW4gYnVpbGRpbmcgYnV0IGFwcGFyZW50bHkgdGhlIC0x MA0KPiBqdXN0IHNuYXBzIHRvZ2V0aGVyIG5vdy4gKioqKg0KPg0KPiAqKiAqKg0KPg0KPiBSb2Jp bioqKioNCj4NCj4gRG8gTm90IEFyY2hpdmUqKioqDQo+DQo+ICoqICoqDQo+DQo+ICpGcm9tOiog b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86DQo+IG93bmVyLXJ2 MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gKk9uIEJlaGFsZiBPZiAqTWljaGFlbCBTYXVz ZW4NCj4gKlNlbnQ6KiBXZWRuZXNkYXksIEp1bHkgMTAsIDIwMTMgMTE6MzAgQU0NCj4gKlRvOiog cnYxMC1saXN0QG1hdHJvbmljcy5jb20NCj4gKlN1YmplY3Q6KiBSRTogUlYxMC1MaXN0OiBSZTog MjAxMyBSVi0xMCBBaXJ2ZW50dXJlIEdyb3VwIENhbXBpbmcqKioqDQo+DQo+ICoqICoqDQo+DQo+ IEnigJltIHByZXR0eSBzdXJlIEpvaG4gb3dlcyBtZSBhIGZldyB5ZXQuICBOaWNlIHRvIHNlZSB0 aGF0IEkgY2FuIGRyb3Agb2ZmDQo+IHRoZSBsaXN0IGZvciBhIHdoaWxlIGFuZCBpdOKAmXMgc3Rp bGwgbW9zdGx5IHRoZSBzYW1lIGZhY2VzLiAgU2VlIHlvdSBndXlzIGluDQo+IGEgY291cGxlIHdl ZWtzLioqKioNCj4NCj4gKiogKioNCj4NCj4gTWljaGFlbCoqKioNCj4NCj4gKiogKioNCj4NCj4g KkZyb206KiBvd25lci1ydjEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gWw0KPiBtYWlsdG86 b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG93bmVyLXJ2MTAtbGlzdC1zZXJ2 ZXJAbWF0cm9uaWNzLmNvbT5dDQo+ICpPbiBCZWhhbGYgT2YgKkJvYiBDb25kcmV5DQo+ICpTZW50 OiogV2VkbmVzZGF5LCBKdWx5IDAzLCAyMDEzIDM6NTUgUE0NCj4gKlRvOiogcnYxMC1saXN0QG1h dHJvbmljcy5jb20NCj4gKlN1YmplY3Q6KiBSZTogUlYxMC1MaXN0OiBSZTogMjAxMyBSVi0xMCBB aXJ2ZW50dXJlIEdyb3VwIENhbXBpbmcqKioqDQo+DQo+ICoqICoqDQo+DQo+IEkgZ290IGhpbSBj b3ZlcmVkIEpvaG4sIGJ1dCBzdG9wIGJ5IGFueXdheSEgIFRoZSBiZWVyIGlzIG9uIG1lIHRoaXMg dGltZS4qDQo+ICoqKg0KPg0KPiAqKiAqKg0KPg0KPiBCb2INCj4NCj4gT24gV2VkbmVzZGF5LCBK dWx5IDMsIDIwMTMsIEpvaG4gQ294IHdyb3RlOioqKioNCj4NCj4gQ29taW5nIGluIGZyb20gTUtF IHdpdGggYSBGb3JkIEVER0UgU1VWLiAgSG93IGNhbiBJIGhlbHAuKioqKg0KPg0KPiAqKiAqKg0K Pg0KPiBKb2huIENveCoqKioNCj4NCj4gKiogKioNCj4NCj4gT24gVHVlLCBKdWwgMiwgMjAxMyBh dCAyOjU0IFBNLCBlaXNvbiA8ZWlzb24xOTY5QHlhaG9vLmNvbT4gd3JvdGU6KioqKg0KPg0KPiAt LT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAiZWlzb24iIDxlaXNvbjE5NjlAeWFob28u Y29tPg0KPg0KPiBJIGFtIGluIHRoZSBmaW5hbCBwbGFubmluZyBzdGFnZXMgZm9yIE9zaC4gIEkg YW0gY2FtcGluZyB3aXRoIHRoZSBncm91cA0KPiBhbmQgaGF2aW5nIGFuIFJWIGRyb3BwZWQgb2Zm IG9uIEZyaWRheS4gIEkgYW0gcGxhbm5pbmcgb24gZmx5aW5nIGluDQo+IFNhdHVyZGF5IGxhdGUg bW9ybmluZy4NCj4NCj4gSSBoYXZlIG9uZSBvcGVuIGl0ZW0sIEkgaGF2ZSByZW50ZWQgZnJvbSBV bml0ZWQgUmVudGFscy9SU0MgaW4gT3Noa29zaCBhDQo+IGdlbmVyYXRvciBpbiBvcmRlciB0byBo YXZlIGEgbmljZSBjb29sIHBsYWNlIHRvIGhhbmcgb3V0IGluIHRoZSBtaWRkbGUgb2YNCj4gdGhl IGRheS4gIEhvd2V2ZXIsIHRoZSBSViBwbGFjZSBpc24ndCBhbGxvd2VkIHRvIHBpY2sgdXAgZ2Vu ZXJhdG9ycywgYW5kDQo+IHVuaXRlZCBSZW50YWxzIHdhbnRzIG1vcmUgdG8gcGljayB1cCBhbmQg ZHJvcCBvZmYgdGhhbiB0aGUgY29zdCBvZiB0aGUNCj4gcmVudGFsLiAgQWRkaXRpb25hbGx5LCB0 aGV5IGFyZW4ndCBvcGVuIG9uIHRoZSB3ZWVrZW5kcy4uLi4uDQo+DQo+IElzIGFueW9uZSBkcml2 aW5nIGluIG9uIEZyaWRheSB0aGUgMjZ0aCB0aGF0IHdvdWxkbid0IG1pbmQgZ3JhYmJpbmcgYQ0K PiBnZW5lcmF0b3IgZm9yIG1lPyAgRmFpbGluZyB0aGF0LCBNb25kYXk/DQo+DQo+IElmIGFsbCBl bHNlIGZhaWxzLCB3ZSBjYW4gZ28gcG93ZXJsZXNzIG9yIHBheSB0aGUgZXh0cmEgZmVlLiAgS2Vl cGluZyB0aGUNCj4gd2lmZSBhbmQga2lkIGhhcHB5IGlzIGltcG9ydGFudCByaWdodD8/Pz8NCj4N Cj4gWW91IGNhbiBlbWFpbCBtZSBhdCBFaXNvbjE5NjkgYXQgeWFob28gZG90IGNvbQ0KPg0KPg0K PiBUaGFua3MNCj4NCj4gRXJpYyBJc29uDQo+DQo+IC0tLS0tLS0tDQo+IEVyaWMgSXNvbg0KPiBS ViAxMCAjNDA3NjQNCj4gTjk4NEVEIChyZXNlcnZlZCkNCj4NCj4NCj4NCj4NCj4gUmVhZCB0aGlz IHRvcGljIG9ubGluZSBoZXJlOg0KPg0KPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmll d3RvcGljLnBocD9wPTQwMzgyOCM0MDM4MjgNCj4NCj4NCj4NCj4NCj4NCj4NCj4NCj4gPT09PT09 PT09PT0NCj4gYXJnZXQ9Il9ibGFuayI+aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRv cj9SVjEwLUxpc3QNCj4gPT09PT09PT09PT0NCj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29t DQo+ID09PT09PT09PT09DQo+IGxlLCBMaXN0IEFkbWluLg0KPiA9Il9ibGFuayI+aHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KPiA9PT09PT09PT09PQ0KPg0KPiAqKioqDQo+ DQo+ICoqICoqDQo+DQo+ICogKg0KPg0KPiAqICoNCj4NCj4gKmdldD0iX2JsYW5rIj5odHRwOi8v d3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdCoNCj4NCj4gKnRwOi8vZm9ydW1z Lm1hdHJvbmljcy5jb20qDQo+DQo+ICpfYmxhbmsiPmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24qDQo+DQo+ICogKg0KPg0KPiAgKiAqDQo+DQo+ICogKg0KPg0KPiAqXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0q DQo+DQo+ICpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0qDQo+DQo+ ICpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3Nl Kg0KPg0KPiAqXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sKg0KPg0KPiAqXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJy b3dzZSwgQ2hhdCwgRkFRLCoNCj4NCj4gKl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1v cmU6Kg0KPg0KPiAqXy09Kg0KPg0KPiAqXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNv bS9OYXZpZ2F0b3I/UlYxMC1MaXN0Kg0KPg0KPiAqXy09Kg0KPg0KPiAqXy09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0qDQo+DQo+ICpf LT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0qDQo+DQo+ICpfLT0gU2Ft ZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyEqDQo+DQo+ ICpfLT0qDQo+DQo+ICpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tKg0KPg0K PiAqXy09Kg0KPg0KPiAqXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0qDQo+DQo+ICpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtKg0KPg0KPiAqXy09ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJv dXMgc3VwcG9ydCEqDQo+DQo+ICpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0 dCBEcmFsbGUsIExpc3QgQWRtaW4uKg0KPg0KPiAqXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9u aWNzLmNvbS9jb250cmlidXRpb24qDQo+DQo+ICpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PSoNCj4NCj4gKiAqDQo+DQo+ICAtLS0t LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0NCj4NCj4gTm8gdmlydXMgZm91bmQgaW4gdGhpcyBt ZXNzYWdlLg0KPiBDaGVja2VkIGJ5IEFWRyAtIHd3dy5hdmcuY29tDQo+IFZlcnNpb246IDIwMTMu MC4zMzQ5IC8gVmlydXMgRGF0YWJhc2U6IDMyMDQvNjQ3NiAtIFJlbGVhc2UgRGF0ZTogMDcvMDkv MTMqDQo+ICoqKg0KPg0KPiBree+/ve+/ve+/vSLvv73tnKJaK++/vU0077+9R++/vXHvv70o77+9 77+977+977+9d++/vXLvv73vv73vv73vv73The+/vVXvv71C77+977+9JmopRe+/ve+/ve+/vVLH re+/ve+/ve+/ve+/vSfvv73vv70NCj4g77+977+9RXnvv71u77+977+9IGrvv73vv71q77+9K++/ ve+/ve+/vQ0KPiDigJHvv73vv71qfO+/ve+/ve+/vW7vv70pYu+/vSfvv73vv73vv70hau+/ve+/ ve+/vSfvv70r77+977+977+977+92Kjvv70g3IYr77+9Se+/vXLvv73vv715aGnvv73vv71rIGvv v70NCj4g4oCRIO+/vRTvv73vv71o77+977+9ee+/vd2a77+9Ie+/ve+/vSHvv73vv73vv71q77+9 fm3vv73vv73vv73vv70g77+977+977+9J++/ve+/vRzvv71v77+9au+/ve+/vWrvv70rRV10List 77+977+9ae+/ve+/vTDvv71m77+977+977+977+9cu+/vSjvv73vv71a77+9KO+/ve+/ve+/vQ0K PiBXXQ0KPiDvv73vv71/aO+/vRNE77+9SCAl77+9U++/vVDEkmpn77+977+977+9cu+/ve+/vXp7 Wu+/ve+/ve+/ve+/ve+/vWnvv71e77+9Ju+/ve+/ve+/vWxaK++/vWvvv73vv73vv73vv73vv71p 77+977+977+96ayZ77+9a++/vXjvv73vv73vv70m77+977+9ae+/ve+/ve+/vemsme+/vWvvv714 DQo+IO+/ve+/ve+/vSbvv73vv73vv73QqO+/ve+/ve+/vW7vv71i77+9de+/vW0o77+9eTha77+9 TO+/ve+/ve+/vSvKi++/ve+/ve+/vd6u77+977+977+977+9ae+/ve+/vUxq77+9Q++/ve+/vWV4 77+977+977+9Zu+/vXbvv73vv73vv73vv73vv71/77+9DQo+IDDvv73vv71r77+9eO+/ve+/ve+/ vSbvv73vv70n77+977+977+977+92Kjvv71t77+977+977+977+9IO+/ve+/ve+/vSfvv73vv70c 77+9b9yie2vvv73vv73vv73vv73vv73vv71r77+977+9fu+/ve+/ve+/ve+/ve+/ve+/ve+/ve+/ ve+/vW3vv70qKioqDQo+DQo ________________________________________________________________________________
Date: Jul 11, 2013
Subject: Fuel Filters in the wing roots or under seats?
I'm starting to lay out my fuel system, and I need to decide where I'm going to place my fuel filter(s). So far, my fuel system consists of an EFII boost pump and a Andair valve. The EFII pump came with two fuel filters (one to install and a spare), but I'm thinking that it might be nice to run two fuel filters. First, it gives me redundancy, and second, it should be easier to change them out if they aren't buried in the tunnel. The con would be that I would need to drain the tank/tanks before changing the filter as there wouldn't be a valve in between the filter and tank. But even this might be a good thing as it would probably be a good idea to remove the tank drains to fully check for contaminants from time to time. Does anyone have any thoughts about this? How about pictures of where people have mounted their filters? Ed ________________________________________________________________________________
Subject: Re: Fuel Filters in the wing roots or under seats?
Date: Jul 11, 2013
I installed two filters in my -10. One in each wing root. None in the tun nel. Checking and Cleaning the filter had been very easy via the wing root access. I used the Andair gas collator style filter and since the fuel ha s to go up a bit after leaving the tank pick up I have not had to drain the t anks for inspection, just run them down to about 10 gallons a side. I would this this again no question. I'll see if I can find some pics on my picsa web album. Bob Newman. TCW tech. N541RV Sent from my iPhone On Jul 11, 2013, at 7:50 AM, Ed Kranz wrote: > I'm starting to lay out my fuel system, and I need to decide where I'm goi ng to place my fuel filter(s). > > So far, my fuel system consists of an EFII boost pump and a Andair valve. T he EFII pump came with two fuel filters (one to install and a spare), but I' m thinking that it might be nice to run two fuel filters. First, it gives me redundancy, and second, it should be easier to change them out if they aren 't buried in the tunnel. > > The con would be that I would need to drain the tank/tanks before changing the filter as there wouldn't be a valve in between the filter and tank. But even this might be a good thing as it would probably be a good idea to remo ve the tank drains to fully check for contaminants from time to time. > > Does anyone have any thoughts about this? > > How about pictures of where people have mounted their filters? > > Ed > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 12, 2013
I installed a small fuel filter in each wing root. They have AN-6 fittings on each end and have stainless filters (I think mine are 40 micron). I only have one photo and it was taken for a different reason, but I'll post it. I'll also post a web photo of the filter. Here is a link to where I bought them: http://www.summitracing.com/parts/sum-230101/overview/ It is not a problem to get them out. I mounted them at a 45 angle. The tank line first goes up almost to the skin, and turns to attach on the top of the filter. The bottom of the filter is connected straight to the line from Van's plans. Even with full tanks, there is no leakage (maybe if I did it with absolutely full tanks it might). The only leakage is the tiny amount that is actually inside the filter. I simply drop down the front half on the lower wing root skin and put a catch basin underneath to catch the small bit of fuel. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404533#404533 Attachments: http://forums.matronics.com//files/sum_230101_w_ml_120.jpg http://forums.matronics.com//files/wingroot_139.jpg ________________________________________________________________________________
Subject: USB Charger Adapter
Date: Jul 12, 2013
I installed a cigarette lighter outlet (now called courtesy outlet in my car owners manual) but all we use it for is to plug in an adapter with USB outlets in it. I'm thinking of replacing it with some USB ports mounted on the panel. I haven't found a device that mounts directly to the panel like the cig lighter outlet did but did find a 4 USB port adapter. Has anyone else run across what I'm looking for? I'm thinking 4 ports because now I plug in the Stratus, iPad, cell phone or music player. Here is a pic of the 4 port I found on the internet. Albert Gardner N991RV Yuma, AZ BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, just me and about 77 temp as I recall, plane preformed well. Wonder how it would have been a gross? ________________________________________________________________________________
Date: Jul 12, 2013
Subject: Re: USB Charger Adapter
I have 2 subpanel mounted lighter outlets. I use 1 of them with a charger, a Dual Scosche brand charger, to run two panel mount USB jacks (you can get those from SteinAir), for charging the ipad and phone. My advice is.... A) Don't buy that 4-port 1. B) Buy something name brand. You don't want some cheap chinese knockoff burning up your plane...I've bought a bunch of chinese USB chargers and had high failure rates. So I stick with Scosche brand. They've never went bad on me at least. C) Buy chargers specifically that are capable of 2.1A charging, so that you can charge an iPad. Many are 500mA, 700mA, or 1A. The 1A will do a phone fine, but not an iPad. I have a great Scosche that does 1A and 2.1A. I just bought (before OSH) a new mini model scosche that does dual 2.1A. D) Find a way to make the connection snug so the thing doesn't slip out easily...especially if you buy a larger one. The new Mini ones I bought are going to go into the plane, since they're tiny and light and low profile. But beyond that, yeah, USB charging is great. If you really need 4 ports, I'd say do 2 lighter outlets.....because you'll never find a good 4-port charger that can do 2.1A...at least not yet this year. I also have 1A chargers in the rear seat, one for each passenger. The lighter outlets are under the armwrests. They are part of the Belkin bluetooth adapters that the kids use. That gives us 4 USB ports in the plane to charge with, and I still have the ability to add 2 more up front if I need, since I have an available lighter outlet. Tim On 7/12/2013 2:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports mounted on > the panel. I haven't found a device that mounts directly to the panel like > the cig lighter outlet did but did find a 4 USB port adapter. Has anyone > else run across what I'm looking for? I'm thinking 4 ports because now I > plug in the Stratus, iPad, cell phone or music player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as > Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, > just me and about 77 temp as I recall, plane preformed well. Wonder how it > would have been a gross? > ________________________________________________________________________________
Date: Jul 12, 2013
There are lots of USB panel mount adapters out there (Google or Bing usb panel mount) but you still need to drop the 12V down to the nominal 5V. Your 4-port adapter is a really good solution ..... and it's portable. Linn On 7/12/2013 3:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports mounted on > the panel. I haven't found a device that mounts directly to the panel like > the cig lighter outlet did but did find a 4 USB port adapter. Has anyone > else run across what I'm looking for? I'm thinking 4 ports because now I > plug in the Stratus, iPad, cell phone or music player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as > Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, > just me and about 77 temp as I recall, plane preformed well. Wonder how it > would have been a gross? > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 12, 2013
Aspen topic, I did Aspen a couple weeks ago in my RV10 at 2600 lbs and 10700 DA. It performed well. I did the VFR departure of 360 degree heading at threshold for at least two miles then turned left early per tower''s request and cleared the mountains to the SE. I always underestimate the airplane , which is a good thing I guess. Short takeoff in calm winds but helps with a 2% slope down! -----Original Message----- From: Albert Gardner Sent: Friday, July 12, 2013 1:50 PM Subject: RV10-List: USB Charger Adapter I installed a cigarette lighter outlet (now called courtesy outlet in my car owners manual) but all we use it for is to plug in an adapter with USB outlets in it. I'm thinking of replacing it with some USB ports mounted on the panel. I haven't found a device that mounts directly to the panel like the cig lighter outlet did but did find a 4 USB port adapter. Has anyone else run across what I'm looking for? I'm thinking 4 ports because now I plug in the Stratus, iPad, cell phone or music player. Here is a pic of the 4 port I found on the internet. Albert Gardner N991RV Yuma, AZ BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, just me and about 77 temp as I recall, plane preformed well. Wonder how it would have been a gross? ________________________________________________________________________________
Date: Jul 12, 2013
I agree with Tim on all comments. I have however been very pleased with these adapters I picked up on eBay. I think I have purchased about 15 so far. They are ultra-low profile and are very snug in the receptacle. They charge iPhone &iPads. NOTE" some of these two socket chargers are "sided" in that one side will charge 2.1A and the other will only charge 1A. http://www.ebay.com/itm/281027829654?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 I also liked my 12V Honda outlet with a spring loaded square cover so much I ordered them from the dealership and stuck them in a number of places in the -10 including the back bulkhead in case I had some device I wanted charging back there. I have yet to use that plug but the others have worked out as planned. Sorry no photos. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, July 12, 2013 1:07 PM Subject: Re: RV10-List: USB Charger Adapter I have 2 subpanel mounted lighter outlets. I use 1 of them with a charger, a Dual Scosche brand charger, to run two panel mount USB jacks (you can get those from SteinAir), for charging the ipad and phone. My advice is.... A) Don't buy that 4-port 1. B) Buy something name brand. You don't want some cheap chinese knockoff burning up your plane...I've bought a bunch of chinese USB chargers and had high failure rates. So I stick with Scosche brand. They've never went bad on me at least. C) Buy chargers specifically that are capable of 2.1A charging, so that you can charge an iPad. Many are 500mA, 700mA, or 1A. The 1A will do a phone fine, but not an iPad. I have a great Scosche that does 1A and 2.1A. I just bought (before OSH) a new mini model scosche that does dual 2.1A. D) Find a way to make the connection snug so the thing doesn't slip out easily...especially if you buy a larger one. The new Mini ones I bought are going to go into the plane, since they're tiny and light and low profile. But beyond that, yeah, USB charging is great. If you really need 4 ports, I'd say do 2 lighter outlets.....because you'll never find a good 4-port charger that can do 2.1A...at least not yet this year. I also have 1A chargers in the rear seat, one for each passenger. The lighter outlets are under the armwrests. They are part of the Belkin bluetooth adapters that the kids use. That gives us 4 USB ports in the plane to charge with, and I still have the ability to add 2 more up front if I need, since I have an available lighter outlet. Tim On 7/12/2013 2:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports > mounted on the panel. I haven't found a device that mounts directly to > the panel like the cig lighter outlet did but did find a 4 USB port > adapter. Has anyone else run across what I'm looking for? I'm thinking > 4 ports because now I plug in the Stratus, iPad, cell phone or music > player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as > well as Aspen were interesting landings. Aspen especially. Lightly > loaded, 1/3 fuel, just me and about 77 temp as I recall, plane > preformed well. Wonder how it would have been a gross? > ________________________________________________________________________________
Date: Jul 12, 2013
Stein is now making panel mount usb outlets... I believe mine are somewhere here in this very expensive box of goodies. Jeff Carpeter 40304 On Jul 12, 2013, at 12:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports mounted on > the panel. I haven't found a device that mounts directly to the panel like > the cig lighter outlet did but did find a 4 USB port adapter. Has anyone > else run across what I'm looking for? I'm thinking 4 ports because now I > plug in the Stratus, iPad, cell phone or music player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as > Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, > just me and about 77 temp as I recall, plane preformed well. Wonder how it > would have been a gross? > > ________________________________________________________________________________
Date: Jul 12, 2013
Here are a couple of pics On Jul 12, 2013, at 12:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports mounted on > the panel. I haven't found a device that mounts directly to the panel like > the cig lighter outlet did but did find a 4 USB port adapter. Has anyone > else run across what I'm looking for? I'm thinking 4 ports because now I > plug in the Stratus, iPad, cell phone or music player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as > Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, > just me and about 77 temp as I recall, plane preformed well. Wonder how it > would have been a gross? > > ________________________________________________________________________________
Date: Jul 12, 2013
His site describes this as 1.5A, which I do not think is enough to charge an iPad. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Sent: Friday, July 12, 2013 5:40 PM Subject: Re: RV10-List: USB Charger Adapter Here are a couple of pics ________________________________________________________________________________
Date: Jul 12, 2013
with a 2a fuse, as seen in the picture, I guarantee it would not work on an Ipad. -----Original Message----- From: William Greenley Sent: Friday, July 12, 2013 2:53 PM Subject: RE: RV10-List: USB Charger Adapter His site describes this as 1.5A, which I do not think is enough to charge an iPad. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Sent: Friday, July 12, 2013 5:40 PM Subject: Re: RV10-List: USB Charger Adapter Here are a couple of pics ________________________________________________________________________________
Date: Jul 12, 2013
They are 2A units, but experience and lots of testing has shown us that the real world usable output of these things is closer to 1.6-1.8 instead of 2.1 when plugged into a running iPad. That means that if you have a regular iPad up and running something like Foreflight along with Bluetooth, gps and music going then this will just keep a float on it and not charge aggressively...but if you shut off the intensive apps or it's resting then it charges it just fine. It'll also charge an iPad mini in all conditions (apps running or not). We spent a whole lot of time testing these out on the bench and in the planes and I wouldn't sell something based on just magazine info...you can find plenty of those out there that in fact don't perform in the real world as advertised. Anyway, it's the best that can easily be done in a reasonable price point and will cover a large majority of what it's intended to do; so as usual I'd rather under promise and over deliver instead of the other way around. Just my 2 cents as usual! Cheers, Stein Bruch President - SteinAir, Inc. 651-460-6955 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of William Greenley Sent: Friday, July 12, 2013 4:54 PM Subject: RE: RV10-List: USB Charger Adapter His site describes this as 1.5A, which I do not think is enough to charge an iPad. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter Sent: Friday, July 12, 2013 5:40 PM Subject: Re: RV10-List: USB Charger Adapter Here are a couple of pics ________________________________________________________________________________
Date: Jul 12, 2013
Date: Jul 12, 2013
I'm using a unit from Blue Sea. http://www.bluesea.com/products/1016/Dual_USB_Charger_Socket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404579#404579 Attachments: http://forums.matronics.com//files/usb_2_980.png ________________________________________________________________________________
Subject: Re: alodine
Date: Jul 13, 2013
Patrick, I am very interested in where you source your alodine and deoxidine. I am in Loxton SA. Roger palark(at)tpg.com.au [quote="rv10free2fly(at)yahoo.com"]Bill, I keep the alodine solution in a 20 litre container and top up the crystal concentration when I notice the dip time is starting to get longer to achieve the same level of coating. I always prepare the parts by scrubbing them with a maroon 3M Scotchbrite pad in a solution of 'Deoxidine' (a Henkel product), just scrub enough to get the shine off the aluminium, then fresh water rinse and air dry before dipping in the alodine solution. I use a storage water heater overflow tray, which is about 1.5" deep & about 4' in diameter to dip the large parts. The advantage of this tray is that it has a plastic ball valve plumbed into the tray and allows me to easily decant the solution back into the storage container for reuse. I use black plastic irrigation fittings and pipe which attach to the ball valve. Can send you pictures. For longer, slender parts, I've made up a long bath using 6" diameter PVC sewer pipe with caps each end and another plastic ball valve fitted as described above. I've cut the top 2" off the entire length of the pipe to allow you to sit the pipe horizontally on an old pallet. Great for long parts and gives a solution depth of about 4". Please ensure that you read the Material Safety Data Sheet for the alodine more so, as its toxic stuff. I've seen guys also use wheelie bins as dip baths and lowering parts in with tie wire and suspending them from some dowel placed across the bin opening. Doing this means you'll need a lot of solution and the bin is very heavy to move. I get away with 20 litres, which is stored when not required. Yell out if you need any more info. Google the Henkel site for technical advice. Warm regards from Oz. Patrick Adelaide, South Australia On 08/02/2013, at 3:15 AM, "Billy Britton" wrote: > A while back I recall a thread about alodine and where to get it. This particular post I remember was about a powder form. I've searched aircraft spruce and cannot find a powder form of alodine. Can anybody tell me where I might find it? Also, Ive never done the alodine before. What prep is required of the parts before using the alodine? > > Thanks > Bill > > > > > > > ================================== > > ://www.matronics.com/Navigator?RV10-List > > ================================== > > cs.com > > ================================== > > matronics.com/contribution > > ================================== > > > > > > [b] -------- Roger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404588#404588 ________________________________________________________________________________
Date: Jul 13, 2013
Albert, Here is a product on Amazon that I have installed in my plane. It has 2 USBs and it is a very clean installation. It does gradually charge the ipad in flight with the display set on bright. http://www.amazon.com/gp/product/B0082CXEI8/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1 On Jul 12, 2013, at 3:50 PM, Albert Gardner wrote: > I installed a cigarette lighter outlet (now called courtesy outlet in my car > owners manual) but all we use it for is to plug in an adapter with USB > outlets in it. I'm thinking of replacing it with some USB ports mounted on > the panel. I haven't found a device that mounts directly to the panel like > the cig lighter outlet did but did find a 4 USB port adapter. Has anyone > else run across what I'm looking for? I'm thinking 4 ports because now I > plug in the Stratus, iPad, cell phone or music player. Here is a pic of the > 4 port I found on the internet. > > Albert Gardner > N991RV > Yuma, AZ > > BTW, landed at Leadville (KLXV) 9927', DA 12,600' yesterday. It as well as > Aspen were interesting landings. Aspen especially. Lightly loaded, 1/3 fuel, > just me and about 77 temp as I recall, plane preformed well. Wonder how it > would have been a gross? > > ________________________________________________________________________________
Date: Jul 13, 2013
If you put a access panel in your tunnel then it is no big deal to remove t he filter.=C2- You will find that the filter doesn't need cleaning after the first year. Gary ----- Original Message ----- From: "Ed Kranz" <ed.kranz(at)gmail.com> Sent: Thursday, July 11, 2013 8:50:48 AM Subject: RV10-List: Fuel Filters in the wing roots or under seats? I'm starting to lay out my fuel system, and I need to decide where I'm goin g to place my fuel filter(s). So far, my fuel system consists of an EFII boost pump and a Andair valve. T he EFII pump came with two fuel filters (one to install and a spare), but I 'm thinking that it might be nice to run two fuel filters. First, it gives me redundancy, and second, it should be easier to change them out if they a ren't buried in the tunnel. The con would be that I would need to drain the tank/tanks before changing the filter as there wouldn't be a valve in between the filter and tank. But even this might be a good thing as it would probably be a good idea to rem ove the tank drains to fully check for contaminants from time to time. Does anyone have any thoughts about this? How about pictures of where people have mounted their filters? Ed == ________________________________________________________________________________
Date: Jul 13, 2013
Subject: Ipad Mini PIREPs ?
I like the form factor of the mini as an 'in-cockpit' device, I was about to buy one, But a conversation I had with a pilot at the airport said he was extremely disappointed with it's screen readability. In his eyes the screen wasn't nearly bright enough for in-cockpit use. I haven't compared the NIT rating of each, Anybody have any real experience they'd like to share? Deems ________________________________________________________________________________
Date: Jul 13, 2013
I see this similar to what Deems just asked in another thread, but I=99ll reply here. I find I like the mini as much or more than the big one because it=99s literally half the weight, but about 2/3 the screen sizeand surprisingly almost exactly the size/shape of a standard plate. Also, arguments about which one is more readable is a bit of a dubious discussion because to be blunt, all of them (apple or droids) pretty much suck in direct sunlight no matter which screen protector you use (though there are some that are FAR superior to others for reflectivity). In something like an RV10, both of them seem pretty usable to me depending on the various lighting conditions. I just find the smaller one easier to stow, to hold, to use, and all around easier to travel with regarding small planes. That said, I love the larger one for normal daily use (emails, videos, etc..). Both are good units, just seems that the smaller one is the one I gravitate to in the actual planes and I=99ve found more and more pilots going the same way. If I give them both to someone to use with the same apps on them and they spend time with both, most will come back liking the smaller one in the smaller planes that we normally fly (yes the RV10 is larger, but still a =9Csmall=9D plane). I would get the form factor you like and not worry too terribly much about nits, resolution, etc.. As I said, they ALL are poor in direct sunlight and none of them are going to look like a 696 (so if you are expecting them to look like that in the sun based on some pictures in a magazine ad you WILL be disappointed); but that=99s not what we mostly use them for anyway. Even some of the more reasonably priced droid tablets seem to work pretty well, though my experience is that he apps running on that OS aren=99t quite as polished and as stable as the same app running on iOS (at least for WingX, ForeFligth and Garmin Pilot). Tim Olson would also be a good one for advice on this, as he=99s FAR more geeky than I am when it comes to the bits/bytes of these things and has superior experience in using them for longer periods of time and on trips in the cockpit than I do. J That=99s just my 2 cents, but everyone has their own opinions based on their own experiences, needs, budget, etc.. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen Sent: Saturday, July 13, 2013 12:12 PM Subject: Re: RV10-List: USB Charger Adapter Stein, I don't want to derail the topic, but could you give a brief summary why the mini iPad preference over the full? Is it just the size, or is it something more? Thanks, John J On Jul 13, 2013, at 8:58 AM, "Stein Bruch" wrote: ________________________________________________________________________________
Date: Jul 13, 2013
Hi Deems, As I mentioned in the other thread, I think you'll find that any/all of the consumer grade tablets will be disappointing in direct sunlight as compared to an aviation grade unit like a 696 or something. Anti-glare screen protectors go a long way, but still they are in a different league. If you go into this experience knowing that even the "best" of the consumer tablets are still poor in direct sunlight, then you'll be fine. But, if anyone tells you that certain ones are so much better in comparison, then you'll likely find that no matter which one you buy it'll still seem pretty meager in direct sun. I say go get a tablet and don't look back - you WILL fall in love with the thing after you play around with it for awhile; whether you use Garmin Pilot (my new fav), Foreflight, or WingX, any of them are a terrific addition to your flight bag. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Saturday, July 13, 2013 12:12 PM Subject: RV10-List: Ipad Mini PIREPs ? I like the form factor of the mini as an 'in-cockpit' device, I was about to buy one, But a conversation I had with a pilot at the airport said he was extremely disappointed with it's screen readability. In his eyes the screen wasn't nearly bright enough for in-cockpit use. I haven't compared the NIT rating of each, Anybody have any real experience they'd like to share? Deems ________________________________________________________________________________
Date: Jul 13, 2013
Subject: Re: Ipad Mini PIREPs ?
Thanks Stein, I've been flying with an Ipad w/glareshield ever since ForeFlight was available. I guess I should have asked: is the mini better/worse/same as the full size ipad wrt readability? On Sat, Jul 13, 2013 at 11:42 AM, Stein Bruch wrote: > Hi Deems,**** > > ** ** > > As I mentioned in the other thread, I think you=92ll find that any/all of > the consumer grade tablets will be disappointing in direct sunlight as > compared to an aviation grade unit like a 696 or something. Anti-glare > screen protectors go a long way, but still they are in a different league . > If you go into this experience knowing that even the =93best=94 of the co nsumer > tablets are still poor in direct sunlight, then you=92ll be fine. But, i f > anyone tells you that certain ones are so much better in comparison, then > you=92ll likely find that no matter which one you buy it=92ll still seem pretty > meager in direct sun. I say go get a tablet and don=92t look back ' yo u WILL > fall in love with the thing after you play around with it for awhile; > whether you use Garmin Pilot (my new fav), Foreflight, or WingX, any of > them are a terrific addition to your flight bag.**** > > ** ** > > Cheers,**** > > Stein **** > > ** ** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Deems Davis > *Sent:* Saturday, July 13, 2013 12:12 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Ipad Mini PIREPs ?**** > > ** ** > > I like the form factor of the mini as an 'in-cockpit' device, I was about > to buy one, But a conversation I had with a pilot at the airport said he > was extremely disappointed with it's screen readability. In his eyes the > screen wasn't nearly bright enough for in-cockpit use. I haven't compared > the NIT rating of each,**** > > Anybody have any real experience they'd like to share?**** > > ** ** > > Deems**** > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Jul 13, 2013
I=99d love any suggestions for a good anti-glare screen protector... From: Stein Bruch Sent: Saturday, July 13, 2013 2:42 PM Subject: RE: RV10-List: Ipad Mini PIREPs ? Hi Deems, As I mentioned in the other thread, I think you=99ll find that any/all of the consumer grade tablets will be disappointing in direct sunlight as compared to an aviation grade unit like a 696 or something. Anti-glare screen protectors go a long way, but still they are in a different league. If you go into this experience knowing that even the =9Cbest=9D of the consumer tablets are still poor in direct sunlight, then you=99ll be fine. But, if anyone tells you that certain ones are so much better in comparison, then you=99ll likely find that no matter which one you buy it=99ll still seem pretty meager in direct sun. I say go get a tablet and don=99t look back =93 you WILL fall in love with the thing after you play around with it for awhile; whether you use Garmin Pilot (my new fav), Foreflight, or WingX, any of them are a terrific addition to your flight bag. Cheers, Stein From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Saturday, July 13, 2013 12:12 PM Subject: RV10-List: Ipad Mini PIREPs ? I like the form factor of the mini as an 'in-cockpit' device, I was about to buy one, But a conversation I had with a pilot at the airport said he was extremely disappointed with it's screen readability. In his eyes the screen wasn't nearly bright enough for in-cockpit use. I haven't compared the NIT rating of each, Anybody have any real experience they'd like to share? Deems http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 13, 2013
Brando anti-glare. I buy them for ever i-device I have and have bought doze ns for me and others at work. On Jul 13, 2013, at 4:35 PM, wrote: > I=99d love any suggestions for a good anti-glare screen protector... > > From: Stein Bruch > Sent: Saturday, July 13, 2013 2:42 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Ipad Mini PIREPs ? > > Hi Deems, > > As I mentioned in the other thread, I think you=99ll find that any/a ll of the consumer grade tablets will be disappointing in direct sunlight as compared to an aviation grade unit like a 696 or something. Anti-glare scr een protectors go a long way, but still they are in a different league. If y ou go into this experience knowing that even the =9Cbest=9D of t he consumer tablets are still poor in direct sunlight, then you=99ll b e fine. But, if anyone tells you that certain ones are so much better in co mparison, then you=99ll likely find that no matter which one you buy i t=99ll still seem pretty meager in direct sun. I say go get a tablet a nd don=99t look back =93 you WILL fall in love with the thing af ter you play around with it for awhile; whether you use Garmin Pilot (my new fav), Foreflight, or WingX, any of them are a terrific addition to your fli ght bag. > > Cheers, > Stein > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Deems Davis > Sent: Saturday, July 13, 2013 12:12 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Ipad Mini PIREPs ? > > I like the form factor of the mini as an 'in-cockpit' device, I was about t o buy one, But a conversation I had with a pilot at the airport said he was e xtremely disappointed with it's screen readability. In his eyes the screen w asn't nearly bright enough for in-cockpit use. I haven't compared the NIT ra ting of each, > Anybody have any real experience they'd like to share? > > Deems > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 13, 2013
I agree with the above. My mini with a Brando glare shield is nowhere as good as the display on my Cheltons, but it is good enough. It is mounted right of center to my panel with a RAM ball mount. I can almost always tilt it to eliminate glare. Jim Berry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404654#404654 ________________________________________________________________________________
Date: Jul 14, 2013
I initially sourced mine through John Johanson, however he's no longer in business. Try Henkell and I think there agent is at Lonsdale here in Adelaide. Tell them you'd prefer the crystals to mix up yourself. They also sell the Deoxidine phosphoric acid pre-etch. You should purchase a box of 3M maroon scouring pads from Weber Abrasives here in Adelaide. If you need any further information or ad advice, please call me (Mob: 0418 850 156). Warm regards Patrick On 13/07/2013, at 18:57, "palark" wrote: > > Patrick, > I am very interested in where you source your alodine and deoxidine. I am in Loxton SA. > > Roger > > palark(at)tpg.com.au > > [quote="rv10free2fly(at)yahoo.com"]Bill, > > > I keep the alodine solution in a 20 litre container and top up the crystal concentration when I notice the dip time is starting to get longer to achieve the same level of coating. > > > I always prepare the parts by scrubbing them with a maroon 3M Scotchbrite pad in a solution of 'Deoxidine' (a Henkel product), just scrub enough to get the shine off the aluminium, then fresh water rinse and air dry before dipping in the alodine solution. > > > I use a storage water heater overflow tray, which is about 1.5" deep & about 4' in diameter to dip the large parts. The advantage of this tray is that it has a plastic ball valve plumbed into the tray and allows me to easily decant the solution back into the storage container for reuse. I use black plastic irrigation fittings and pipe which attach to the ball valve. Can send you pictures. > > > For longer, slender parts, I've made up a long bath using 6" diameter PVC sewer pipe with caps each end and another plastic ball valve fitted as described above. > > > I've cut the top 2" off the entire length of the pipe to allow you to sit the pipe horizontally on an old pallet. Great for long parts and gives a solution depth of about 4". > > > Please ensure that you read the Material Safety Data Sheet for the alodine more so, as its toxic stuff. > > > I've seen guys also use wheelie bins as dip baths and lowering parts in with tie wire and suspending them from some dowel placed across the bin opening. Doing this means you'll need a lot of solution and the bin is very heavy to move. I get away with 20 litres, which is stored when not required. > > > Yell out if you need any more info. Google the Henkel site for technical advice. > > Warm regards from Oz. > > Patrick > > Adelaide, South Australia > > > > On 08/02/2013, at 3:15 AM, "Billy Britton" wrote: > > > >> A while back I recall a thread about alodine and where to get it. This particular post I remember was about a powder form. I've searched aircraft spruce and cannot find a powder form of alodine. Can anybody tell me where I might find it? Also, Ive never done the alodine before. What prep is required of the parts before using the alodine? >> >> Thanks >> Bill >> >>> >>> >>> ================================== >>> ://www.matronics.com/Navigator?RV10-List >>> ================================== >>> cs.com >>> ================================== >>> matronics.com/contribution >>> ================================== >> >> [b] > > > -------- > Roger > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404588#404588 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Safety Wire for Plane-Power Alternator Installation
Date: Jul 14, 2013
I re-read AC43.13 and didn't find any mention of a limit to the length of safety wire that can be used. I simply brought the wire from bolt to bolt in a typical arrangement and the span looks to be about 3". Is this a problem? Seems ok to me. -------- David Halmos RV-10 Electrical/avionics Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404667#404667 ________________________________________________________________________________
Date: Jul 14, 2013
There's no doubt that shorter is better. The longer the span the 'potential' for loosening becomes greater. So, ask yourself what the consequences of that (those) particular fasteners loosening a little. This could be an 'experiment' so get back to us ...... IMHO, of course. Linn On 7/14/2013 11:46 AM, dhmoose wrote: > > I re-read AC43.13 and didn't find any mention of a limit to the length of safety wire that can be used. I simply brought the wire from bolt to bolt in a typical arrangement and the span looks to be about 3". Is this a problem? Seems ok to me. > > -------- > David Halmos > RV-10 > Electrical/avionics > Portland, OR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404667#404667 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 14, 2013
I suspect, in my experiment, I'll get a "backup alternator" light illumination on my panel. I'll then fly on or land...and adjust the belt tension when back on the ground. I'll then recall this thread, enjoy a good chuckle... and press on. :) Or... I'll re-safety it now prior to first flight. Haha. flying-nut(at)cfl.rr.com wrote: > There's no doubt that shorter is better. The longer the span the > 'potential' for loosening becomes greater. > So, ask yourself what the consequences of that (those) particular > fasteners loosening a little. > This could be an 'experiment' so get back to us ...... > IMHO, of course. > Linn > > On 7/14/2013 11:46 AM, dhmoose wrote: > > > > > > > I re-read AC43.13 and didn't find any mention of a limit to the length of safety wire that can be used. I simply brought the wire from bolt to bolt in a typical arrangement and the span looks to be about 3". Is this a problem? Seems ok to me. > > > > -------- > > David Halmos > > RV-10 > > Electrical/avionics > > Portland, OR > > > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=404667#404667 > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > > > > -------- David Halmos RV-10 Electrical/avionics Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404671#404671 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Nose gear slot - to cover or not cover
Date: Jul 14, 2013
All, Last winter I installed a plate in the lower cowl that covers most of the nose gear leg slot going forward from the gear leg (I left enough gap to allow for the gear leg to flex). I found that it did reduce some cowl drag, but at the expense of engine cooling on hard climb outs. As today was standard east coast hot and humid, I took the plate out. With the plate out I noted a 10 to 15 degree cooler peak CHT on a hard climb to 8500'. I also again noted a knot or two off my typical cruise setting. So - winter the plate is in, summer the plate is out. Carl RV-10 (115 hrs) RV-8A (sold last month) ________________________________________________________________________________
Subject: Re: Nose gear slot - to cover or not cover
Date: Jul 14, 2013
Interesting, I have heard another builder report cooler climbs doing this too. I have a plate and now I=99ll have to test this on my 10. Thanks for the report. From: Carl Froehlich Sent: Sunday, July 14, 2013 1:22 PM Subject: RV10-List: Nose gear slot - to cover or not cover All, Last winter I installed a plate in the lower cowl that covers most of the nose gear leg slot going forward from the gear leg (I left enough gap to allow for the gear leg to flex). I found that it did reduce some cowl drag, but at the expense of engine cooling on hard climb outs. As today was standard east coast hot and humid, I took the plate out. With the plate out I noted a 10 to 15 degree cooler peak CHT on a hard climb to 8500'. I also again noted a knot or two off my typical cruise setting. So - winter the plate is in, summer the plate is out. Carl RV-10 (115 hrs) RV-8A (sold last month) ________________________________________________________________________________
Date: Jul 14, 2013
Great feedback! I just pulled my plate for cooling troubleshooting. Wondered if it mattered. Now I know Thx On Jul 14, 2013, at 12:22 PM, "Carl Froehlich" w rote: > All, > > Last winter I installed a plate in the lower cowl that covers most of the n ose gear leg slot going forward from the gear leg (I left enough gap to allo w for the gear leg to flex). I found that it did reduce some cowl drag, but at the expense of engine cooling on hard climb outs. As today was standard east coast hot and humid, I took the plate out. With the plate out I noted a 10 to 15 degree cooler peak CHT on a hard climb to 8500'. I also again n oted a knot or two off my typical cruise setting. > > So - winter the plate is in, summer the plate is out. > > Carl > RV-10 (115 hrs) > RV-8A (sold last month) > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 16, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
Subject: Re: AOA installation in wings
Where did you purchase parker pneumatic line? Dave Fritzsche ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage On 2/27/2012 6:45 PM, Seano wrote: > > I bought parker pneumatic line to run coax in my wing. It is 5/16 OD > and it runs down the "J" channels in the wing. You can push coax > through with ease. I ran coax through it to keep it away from powered > linesin the conduit. You could easily pull the AOA lines through this > as well. It stays in place so you don't have to tack it in the channel. > > > ----- Original Message ----- From: "Sean Stephens" > > To: > Sent: Monday, February 27, 2012 7:27 PM > Subject: Re: RV10-List: AOA installation in wings > > >> >> Here's my installation. I routed the tubes out to the end then back >> to the fuselage. >> >> http://rv10.stephensville.com/2010/06/06/routing-aoa-tubes/ >> >> Also, the ports in no way conflict with the install of the Duckworks >> lights. They are plenty aft of the mount. >> >> -Sean #40303 (Still wiring panel) >> >> On 2/27/12 6:32 PM, Billy & Tami Britton wrote: >>> On the third bay in from the wingtip on the spar there's a hole in >>> the web. I assume these are tooling holes. This will probably >>> warrant a phone call to Vans, but, does anybody have any thoughts >>> (other than "don't mess with the wing spar any more than you need >>> to!!!") about enlarging that hole to 7/16 for a snap bushing? I'm >>> looking for a route for the pressure lines on my AOA. Aside from >>> ordering a longer tubing length from AFS and running the tubing to >>> the wingtip, then the full length of the wing through my conduit, I >>> cannot see any easier way. I do already have my outboard leading >>> edges installed, so this will be fairly difficult anyway. >>> My only other thought is to just run both tubes through the hole and >>> then gob proseal around them to keep them from rubbing. >>> Anybody have any other general suggestions about the wing install >>> part of this??? Pictures??? Using the stock location suggested on >>> the AFS site, does anybody know how this will affect--if any--the >>> install of the Duckworks leading edge landing lights in the same bay? >>> Thanks again for any help, >>> Bill >>> * >>> >>> >>> * >> >> >> >> > > ________________________________________________________________________________
Subject: Go Pro mounts
Date: Jul 16, 2013
I have some mounts for sale at PlaneAround that screw into any tie down ring on RV's. It has worked well for under the tail or wings and filming video. I recently made another mount which uses the tie down mount but is made to mount on the wingtip. I know it fits an RV-10 and RV6 and it should fit all the RV's and actually a lot of other aircraft. I test flew it today and dove over 200mph to make sure the side load wouldn't distort the skin. It doesn't. I pointed it at a 45 degree angle thinking this would produce the strongest side load at 200 mph. No problem for the mount. It has a rubber bottom so it won't scratch the paint and is made out of aluminum. Just looking to see if others are interested to see how many I should start with. I still have the fuel cap mount but thought the wingtip would be more popular. They can be pointed any direction. -------- 40936 RV-10 SB N801VR Flying 400 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404786#404786 Attachments: http://forums.matronics.com//files/wingtip_mount3_786.jpg http://forums.matronics.com//files/wingtip_mount2_230.jpg http://forums.matronics.com//files/wingtip_mount1_191.jpg http://forums.matronics.com//files/wingtip_mount_155.jpg ________________________________________________________________________________
Date: Jul 16, 2013
Subject: Engine control cables, McFarlane
I'm looking at the RV-10 offerings at McFarlane. While they list for both stock panel and Aerosport panel, I don't see any actual lengths, nor do I recall anyone actually reporting experience with them. I've bought cables from them for certified planes, and I like the quality. Just would like to hear anyone's experience with them, both with install fit issues, and operational. I have one of the Aerosport panels, so I guess that is what I need to order, just not sure how it is all that different from stock. ________________________________________________________________________________
Subject: Alternatives to RockRack Switches
Date: Jul 17, 2013
Hi there. When it comes to switches for my panel, I like the idea of LED illuminated switches with some kind of text/icon directly visible on the switch to indicate its function. I'd rather not have to label the panel itself. The Aveo RockRack switches, though a bit on the large side, seemed exactly what I was working for. However, when I went to contact a distributor about them, I was told that they're no longer being made, in anticipation for a "new version" with no ETA. I can wait a bit if I knew how long the wait would be, but not indefinitely, so I'm exploring different options. Does anybody have something else they could suggest (or does someone know a source for RockRack switches that has them in stock)? One possibility is perhaps something that allows me to laser print on acetate my own labels to slide into a window on the switch? I was looking at the Carling Contura V series, with some of their actuators that provide a square illumination window, but the more closely I look into them, I'm suspecting its just a frosted window with no ability for custom labelling. I also looked at NKK SmartSwitches, but though they may look nice, add a lot of extra complication. (The primary complication I see is that I'd need to design an interface board to convert their momentary contact into a latched on or off state, and it seems that the reliability when introducing that kind of complication would go way down). I've seen the rocker switches available from AeroSport Products (I'm already using their carbon fibre panel and interior), but from their photos on the web site, their labels look somewhat "washed out" (though this could just be a side effect of the photos overexposing the labelled portion). Has anyone seen them to know what they look like in reality? From what I've seen so far, they seem like my best bet, but I wanted to check with the members of the list here first to get opinions on what makes a nice looking switch for the RV-10. Dan -- Syzygy Research & Technology Box 83, Legal, AB T0G 1L0 Canada Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Alternatives to RockRack Switches
Date: Jul 17, 2013
I have Geoff's switches in my RV-10. The labels are black lettered decals applied to the led window on the switch, They are very well defined and sharp. Sent from my iPad On Jul 17, 2013, at 5:53 AM, Dan Charrois wrote: > > > I've seen the rocker switches available from AeroSport Products (I'm already using their carbon fibre panel and interior), but from their photos on the web site, their labels look somewhat "washed out" (though this could just be a side effect of the photos overexposing the labelled portion). Has anyone seen them to know what they look like in reality? From what I've seen so far, they seem like my best bet, but I wanted to check with the members of the list here first to get opinions on what makes a nice looking switch for the RV-10. > > Dan > > > > ________________________________________________________________________________
Subject: Pink Slip
Date: Jul 17, 2013
John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. I asked John why my pink slip was salmon. He didnt have an answer. I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. -------- Bob Leffler N410BL - Phase I http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404830#404830 ________________________________________________________________________________
Date: Jul 17, 2013
Subject: Re: Pink Slip
Way to hang in there Bob.... now the fun begins. Don McDonald -------------------------------------------- On Wed, 7/17/13, rleffler wrote: Subject: RV10-List: Pink Slip To: rv10-list(at)matronics.com Date: Wednesday, July 17, 2013, 7:46 AM "rleffler" John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. I asked John why my pink slip was salmon. He didnt have an answer. I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. -------- Bob Leffler N410BL - Phase I http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404830#404830 Forum - - MATRONICS WEB FORUMS - List Contribution Web Site - -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Pink Slip
Date: Jul 17, 2013
Congrats. When are you planning to do your first flight? My first flight was one of the most significant events in my life....I will always remember it. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rleffler Sent: Wednesday, July 17, 2013 6:47 AM Subject: RV10-List: Pink Slip John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. I asked John why my pink slip was salmon. He didnt have an answer. I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. -------- Bob Leffler N410BL - Phase I http://mykitlog.com/rleffler Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404830#404830 ________________________________________________________________________________
Date: Jul 17, 2013
Awesome, Bob! So next year you'll have it at OSH for sure!!! Are you coming this year without it, or staying home to fly those hours off? Or, are you putting in some extra vacation time and flying it off before OSH? Tim On 7/17/2013 7:46 AM, rleffler wrote: > > John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. > > > > I asked John why my pink slip was salmon. He didnt have an answer. > > I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. > > -------- > Bob Leffler > N410BL - Phase I > http://mykitlog.com/rleffler > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404830#404830 > > ________________________________________________________________________________
Date: Jul 17, 2013
Huge congrats Bob! Seems like the finishing phase will never end. Have followed your build for a long time and it has been big help in making my choices. Kelly On 7/17/2013 5:46 AM, rleffler wrote: > > John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. > > > > I asked John why my pink slip was salmon. He didnt have an answer. > > I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. > > -------- > Bob Leffler > N410BL - Phase I > http://mykitlog.com/rleffler > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404830#404830 > > ________________________________________________________________________________
Subject: Re: Go Pro mounts
Date: Jul 17, 2013
My website is updated to show the wingtip mount and the tie down mount sold separately or together. -------- 40936 RV-10 SB N801VR Flying 400 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404838#404838 ________________________________________________________________________________
Date: Jul 17, 2013
Rene, for me too. 32 years ago I flew my Pitts S-1E for the first time. Every part of that first flight is still fresh and indelibly etched in my memory. My checkride for my private in 74 is the same way. Very momentous occasions!!! Linn On 7/17/2013 9:16 AM, Rene Felker wrote: > > Congrats. When are you planning to do your first flight? My first flight was one of the most significant events in my life....I will always remember it. > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rleffler > Sent: Wednesday, July 17, 2013 6:47 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Pink Slip > > > John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. > > > > I asked John why my pink slip was salmon. He didnt have an answer. > > I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. > > -------- > Bob Leffler > N410BL - Phase I > http://mykitlog.com/rleffler > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404830#404830 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 17, 2013
Subject: Part Number for Third Keyed Lock From Aircraft Spruce
I tried to order a keyed ignition switch and lock set A-510-2k (part number 11-03172) from Aircraft Spruce this morning. I wanted to include a third lock with all keyed alike to cover the two doors and baggage door as others have done on this list. The person taking the order asked me for a part number for the additional lock. No part number is shown on the web page. He said he could not order the additional lock without a part number. Does anyone have the part number for the third lock? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
From: Byron Gillespie <bgill1(at)mediastreamus.net>
Date: Jul 17, 2013
More congrats Bob! Look forward to the first flight review.. I fully agree with the Matronics list group and the individual web sites that are available for reference.Don't believe that I would have jumped in without the available support. Byron N253RV flying - but still need paint Sent from my iPad On Jul 17, 2013, at 8:46 AM, "rleffler" wrote: > > John Welsh, of the CMH FSDO, office stopped by the hanger today to inspect N410BL. Two hours later I had both the Airworthiness certificate and my temporary Repairman's certificate. > > > > I asked John why my pink slip was salmon. He didnt have an answer. > > I would like to thank my family, Janice, Brad, and Renee for all their work on the project. Now the fun can begin! I also want to thank Geoff Combs, Jim Baldwin, Joe Strausbaugh, Tom Webster Sr., Dana Saucier, Todd Stanton, Brent Owens, and all of the RV-10 Matronics list for all their assistance, mentoring, and friendship throughout the build. > > -------- > Bob Leffler > N410BL - Phase I > http://mykitlog.com/rleffler > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404830#404830 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 17, 2013
I used white Honeywell rockers (AML34,24) with labels and backlighting. I'm assuming you aware of the these already and have already decided they are not what you want. But LEDs or incandescent bulbs can be used. There is a vendor that does quality custom lettering as well. Here's a pic of part of my panel with them http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=4053&log=122434&row=2 On 7/17/2013 5:53 AM, Dan Charrois wrote: > > Hi there. > > When it comes to switches for my panel, I like the idea of LED illuminated switches with some kind of text/icon directly visible on the switch to indicate its function. I'd rather not have to label the panel itself. The Aveo RockRack switches, though a bit on the large side, seemed exactly what I was working for. > > However, when I went to contact a distributor about them, I was told that they're no longer being made, in anticipation for a "new version" with no ETA. I can wait a bit if I knew how long the wait would be, but not indefinitely, so I'm exploring different options. > > Does anybody have something else they could suggest (or does someone know a source for RockRack switches that has them in stock)? One possibility is perhaps something that allows me to laser print on acetate my own labels to slide into a window on the switch? I was looking at the Carling Contura V series, with some of their actuators that provide a square illumination window, but the more closely I look into them, I'm suspecting its just a frosted window with no ability for custom labelling. > > I also looked at NKK SmartSwitches, but though they may look nice, add a lot of extra complication. (The primary complication I see is that I'd need to design an interface board to convert their momentary contact into a latched on or off state, and it seems that the reliability when introducing that kind of complication would go way down). > > I've seen the rocker switches available from AeroSport Products (I'm already using their carbon fibre panel and interior), but from their photos on the web site, their labels look somewhat "washed out" (though this could just be a side effect of the photos overexposing the labelled portion). Has anyone seen them to know what they look like in reality? From what I've seen so far, they seem like my best bet, but I wanted to check with the members of the list here first to get opinions on what makes a nice looking switch for the RV-10. > > Dan > ________________________________________________________________________________
Subject: Re: Part Number for Third Keyed Lock From Aircraft Spruce
Date: Jul 17, 2013
I would have to look it up and all my records are packed for an upcoming move. I was told that they really don't have a option for adding a single lock. I suspect it's a lack of defined process issue. ACS does have a sku for a custom order for the switch and four identical keyed locks. It's not on their website. That's what I did. It took about two weeks to get the locks. Bob Sent from my iPhone On Jul 17, 2013, at 12:26 PM, "Dave Fritzsche (Building)" wrote: I tried to order a keyed ignition switch and lock set A-510-2k (part number 11-03172) from Aircraft Spruce this morning. I wanted to include a third lock with all keyed alike to cover the two doors and baggage door as others have done on this list. The person taking the order asked me for a part number for the additional lock. No part number is shown on the web page. He said he could not order the additional lock without a part number. Does anyone have the part number for the third lock? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Date: Jul 17, 2013
The Rockrack switches are easily in stock at ACS. I would recommend purchasing them there. The "future" version has never materialized so I wouldn't wait for them. The dual colored lights are difficult to get ahold of and if ACS doesn't have them, it could be 6+ months. But if you are sticking to a single color lamp, then you should be good to go with them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404854#404854 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jul 17, 2013
Dan We have sold many of these switches and everyone that likes rockers switches seems to like them. The lettering Is very easy to read and you are not limited to only certain lettering or graphics. We can do custom lettering if Needed for a small up charge. Pricing is way less than AVEO See attached photos Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Wednesday, July 17, 2013 12:37 PM Subject: Re: RV10-List: Alternatives to RockRack Switches I used white Honeywell rockers (AML34,24) with labels and backlighting. I'm assuming you aware of the these already and have already decided they are not what you want. But LEDs or incandescent bulbs can be used. There is a vendor that does quality custom lettering as well. Here's a pic of part of my panel with them http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&c ategory=4053&log=122434&row=2 On 7/17/2013 5:53 AM, Dan Charrois wrote: > > Hi there. > > When it comes to switches for my panel, I like the idea of LED illuminated switches with some kind of text/icon directly visible on the switch to indicate its function. I'd rather not have to label the panel itself. The Aveo RockRack switches, though a bit on the large side, seemed exactly what I was working for. > > However, when I went to contact a distributor about them, I was told that they're no longer being made, in anticipation for a "new version" with no ETA. I can wait a bit if I knew how long the wait would be, but not indefinitely, so I'm exploring different options. > > Does anybody have something else they could suggest (or does someone know a source for RockRack switches that has them in stock)? One possibility is perhaps something that allows me to laser print on acetate my own labels to slide into a window on the switch? I was looking at the Carling Contura V series, with some of their actuators that provide a square illumination window, but the more closely I look into them, I'm suspecting its just a frosted window with no ability for custom labelling. > > I also looked at NKK SmartSwitches, but though they may look nice, add a lot of extra complication. (The primary complication I see is that I'd need to design an interface board to convert their momentary contact into a latched on or off state, and it seems that the reliability when introducing that kind of complication would go way down). > > I've seen the rocker switches available from AeroSport Products (I'm already using their carbon fibre panel and interior), but from their photos on the web site, their labels look somewhat "washed out" (though this could just be a side effect of the photos overexposing the labelled portion). Has anyone seen them to know what they look like in reality? From what I've seen so far, they seem like my best bet, but I wanted to check with the members of the list here first to get opinions on what makes a nice looking switch for the RV-10. > > Dan > ________________________________________________________________________________
Date: Jul 17, 2013
I bought a similar lock at Lowes and took it to the local locksmith. They made it fit my ignition key. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Jul 18, 2013
Subject: Matt's KLVK ATC Streaming...
Dear Listers, A couple of weeks ago I found a web site on the Internet called LiveATC.net that has the Air Traffic Control (ATC) tower communications on line for streaming for a number of airports around the country. Lo 'n behold, they even have a stream for my home base, the Livermore Airport. But, much to my dismay, the quality of their KLVK feed was just plain awful. It was obvious the airband source didn't have a decent antenna or perhaps even a good radio. I suppose that given that their site is a consortium of local citizens providing the feeds, the lack of quality goes with the territory. But, I really liked the idea of being able to monitor the LVK ATC and also the ability to bring up the archives and listen to my personal communications with the tower after a flight. Since I had a computer at the hangar along with a pretty decent Internet connection and, in the spirit of Experimental Homebuilding, I had an idea... I mounted an air-band antenna on the top of the hangar and brought the RG-58 coax down to near the computer and plugged it into my trusty Icom IC-A20 hand held. I was AMAZED at the quality of signal I was getting. It was picking up guys in airplanes 19 miles out like they were sitting next to my hangar! I set the radio to high-speed scan between the Tower and Ground frequencies so with a single feed I could get all communications. So next, I made an audio connection from the handheld to the Line In input on the computer. Sure enough, now I was getting great sound from the hand held on the computer! I found some software from Australia called BroadWave from a company called NCH ( http://www.nch.com.au/streaming ). It lets you connect to the Line In port on the computer and then generate real time audio streams that can be served up via the Internet. And sure enough, it works great! Next, I found some software from Germany called Loop Recorder ( http://looprecorder.de ) that let's you monitor an audio input on your computer and generate archive files. You can select an increment in which to rotate the files automatically, for example, every 30 minutes. I downloaded this software and installed it and sure enough, I was able to start archiving the ATC transmissions coming in, all the while streaming them live as well! The last piece of the puzzle was to enable the Web and FTP servers on the Windows 7 system and come up with a front-end web page that would tie all of these new resources together for easy access from the Internet. I'm happy to report, the whole thing came together very nicely and even allows you stream directly to your Android or iPhone as well as your desktop! Pretty darn cool! And so, without further ado, here is my new web site for monitoring the ATC communications at KLVK: http://klvk.matronics.com/ Just to state the obvious, the stream is silent if there isn't any current ATC or aircraft communications. During the day, you'll usually hear something within five or ten minutes. Sometimes much quicker. I contacted LiveATC.net and they were excited about adding my new stream to their web site as well. So, at some point soon, the LiveATC.net feed for Livermore Airport will be coming from my hangar! My site http://klvk.matronics.com will continue to be available as well. For entertainment purposes only! - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 170+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Re: Matt's KLVK ATC Streaming...
Date: Jul 18, 2013
Matt: So very cool. Jay in #164 just behind you at KLVK. Sent from my iPhone On Jul 18, 2013, at 2:31 PM, Matt Dralle wrote: > continue to be available as well. ________________________________________________________________________________
Subject: Re: 2013 RV-10 Airventure Group Camping
Date: Jul 19, 2013
Just bumping as a reminder to those who procrastinate... Also, sounds like there will be a large cookout this year, probably on Wednesday afternoon/evening after the daytime airshow and before the night show. Nothing is firmed up yet, stay tuned for more info. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404931#404931 ________________________________________________________________________________
Subject: Brain trust stick wiring poll
Date: Jul 20, 2013
I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404980#404980 ________________________________________________________________________________
Date: Jul 20, 2013
Subject: Re: Brain trust stick wiring poll
I ran mine on the inside .... full blown infinity stick grips. I had to 'relieve' the sharp bend at the bottom of the straight portion and the wire exits through a 1/4" hole at the rear of the mount. Linn On 7/20/2013 3:22 PM, woxofswa wrote: > > I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback. > > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=404980#404980 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 20, 2013
I have the infinity grips. I drilled and put the wires on the inside, however I also had an issue and needed to replace one of the switches on the grip. It would have been a lot easier to have the wires on the outside. Also, if you plan to put a boot over the stick, outside is fine. Only reason to think outside is time, it is really easy to run the wires up the stick and zip tie, but if you do, make sure you cover them with a full stick boot. Pascal -----Original Message----- From: woxofswa Sent: Saturday, July 20, 2013 12:22 PM Subject: RV10-List: Brain trust stick wiring poll I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404980#404980 ________________________________________________________________________________
Date: Jul 21, 2013
I ran mine inside also. There is no reason not to, and it looks better. You will have to drill a hole at the top of the stick where the vertical attaches to the main part of the stick. You don't need a large hole. I covered the wires with anti chafe skin and left enough slack at the bottom where it exits, to pull the grip up off the stick very easily if they need servicing. The downside is removing the stick requires disconnecting the wires. To aid in making this a bit easier, I used a barrier block with screw terminals. If you put a connector on the end of the wires, you will not be able to pull them all the way back out. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405005#405005 Attachments: http://forums.matronics.com//files/exit_stick_176.jpg ________________________________________________________________________________
Date: Jul 21, 2013
Here is a solution for running inside the stick. We welded a doubler on the stick receiver since we slotted it. This allows complete removal of the stick with the wiring/CPC connector. Infinity grips used. -Chris Lucas N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Saturday, July 20, 2013 3:22 PM Subject: RV10-List: Brain trust stick wiring poll I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404980#404980 ________________________________________________________________________________
Date: Jul 21, 2013
Inside. In fact even if I had a stick boot (which I never will) I would run them inside. With the Infinity wire bundle there are a LOT of wires. I think we ended up using a common ground so we were able to remove more than a third of the wires leaving extras in case I wanted to expand in the future. This made it a lot easier to fish through the stick. On the tail end we used a D Shell style connector in the rare event we would have to remove the stick. We did the same set up on all the 2 place RV's as we often removed the Co-pilots stick for various reasons. One note on grip buttons. If I were to do it over again with all the modern tech and push button items in our cockpit I would now dedicate one button to an OK or Accept button. We get the most random notifications on these glass displays that simply request acknowledgement. It would be nice the flick a pinky to confirm the notification. One note on the grips themselves. I see so many installs that have the grip facing straight forward. I strongly suggest you sit in your seat properly located forward & aft to see what angle your stick hand lands on the stick. Put the grip in our hand un-mounted or over the stick to see what feels best. Close your eyes and drop your hand into position. Do it several times. You will notice the ideal orientation has significant rotation from directly forward. Mine was about a 40 Degree rotation. No way would straight forward be comfortable for long hand flying. Even worse on takeoff when you often have to flick the trim several times, flip the Flaps Up toggle and push the flip/flop not having the correct & natural orientation on the grip makes for something less than ideal button orientation as well as a less natural placement in your hand. Just something to consider. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Saturday, July 20, 2013 12:22 PM Subject: RV10-List: Brain trust stick wiring poll I'm at the stage of wiring my stick grips and wondering what sage advice there is on running the wires inside the stick or outside. I'm leaning inside, but love to hear some feedback. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=404980#404980 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 21, 2013
My plane is definitely function first, beauty last. I ran the wires, in a protective covering, on the outside. Adding to Robin's comment, one nice feature of the Tosten grip is that the hold down screw rides in a groove. With it snug but not tight the grip rotates naturally with your hand, as you move the stick. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405036#405036 ________________________________________________________________________________
Date: Jul 21, 2013
Thanks for the replies. I went for the inside option tied to a bus terminal on mounted on the gear tree. I ran enough slack to just clip off ring terminals and re-crimp several times if I ever have to remove. My stick grips are unique. To have a little of the day job flavor, I used a battle worn salvage Boeing 737 yoke. I cut off the uprights to make them my stick grips. My trim, A/P disco, and PTT will all be original Boeing on the left grip. To attach the grips to the sticks I hillbilly engineered an interface from a stack of the scrap spar spacers. (http://s125.photobucket.com/user/myronnelson/media/photo_zpsd50c2674.jpg.html) (http://s125.photobucket.com/user/myronnelson/media/photo_zps740aa321.jpg.html) -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405040#405040 ________________________________________________________________________________
Date: Jul 21, 2013
Subject: Encouragement
Well, this morning, as I pull my Mooney out of hangar for a breakfast run, I see Doug Petersen launch in his RV-10. I fly to Glendale for breakfast and meet Dave McNeil there with his RV-10. I fly back to Chandler, put Mooney away, go to terminal and there is Doug Petersen, just back from his breakfast run to Payson. So I go back to RV-10 hangar and try to be productive moving along my RV-10 project. In the 90-90 phase. ________________________________________________________________________________
Date: Jul 22, 2013
While usually Robin and I are on the same page, here I differ a bit. I think too much is made of the rotating of the grip. Yeah, you will want it rotated slightly, but I don't think any major rotation is warranted. I would probably be more likely to recommend AGAINST going very far in rotation and here's why... When flying the RV-10, even during landing, I rarely use more than 2 or 3 fingertips on the stick....LITERALLY. You just give it gentle nudges with 1 or 2 fingers and it does what you want. Honestly I never ever have the need to grab the grip with a full hand on most flights. You could throw an mis-shapen blob of rocks on the end of the stick and I could fly with it, because gripping it is just not something you would do for hours on end. Your forearm rests on your legs and it's very comfortable to fly. I could fly with it cockeyed by 40 degrees, 90 degrees, or 180 degrees. But, when the rubber meets the road, and you DO need to grip it hard, that's likely going to be during a time of trouble....some time when you're going to actually exert yourself to push or pull or yank and bank like during some event or bad turbulence. At that point I would recommend that the yoke be rotated in the direction that gives you the most arm "solid" control ability. Sit at your desk right now, and try to push yourself back from your desk with your fist, and see what position your arm wants to be in. Mine certainly doesn't have full strength at 40 degrees offset. In fact, it's probably not many degrees off straight...maybe 5-10 at most. So my position on it is basically....rotate the grip so that if you needed to do a hard push to override an autopilot or break a stall or perform a hard maneuver, you could do it with a locked wrist and be comfortable. And, beyond that, don't worry about it much because if you're giving the stick your full grip during normal maneuvers you're probably trying too hard...it's a plane that can be flown with fingertips and trim alone. As Dave Mason sung years ago..... "We just disagree", Robin. :) No worries though....this one falls into that "do whatever you wish" category as far as I'm concerned. I'm just providing the counterpoint. Tim On 7/21/2013 4:58 PM, Robin Marks wrote: > > Inside. In fact even if I had a stick boot (which I never will) I would run them inside. With the Infinity wire bundle there are a LOT of wires. I think we ended up using a common ground so we were able to remove more than a third of the wires leaving extras in case I wanted to expand in the future. This made it a lot easier to fish through the stick. On the tail end we used a D Shell style connector in the rare event we would have to remove the stick. We did the same set up on all the 2 place RV's as we often removed the Co-pilots stick for various reasons. > One note on grip buttons. If I were to do it over again with all the modern tech and push button items in our cockpit I would now dedicate one button to an OK or Accept button. We get the most random notifications on these glass displays that simply request acknowledgement. It would be nice the flick a pinky to confirm the notification. > One note on the grips themselves. I see so many installs that have the grip facing straight forward. I strongly suggest you sit in your seat properly located forward & aft to see what angle your stick hand lands on the stick. Put the grip in our hand un-mounted or over the stick to see what feels best. Close your eyes and drop your hand into position. Do it several times. You will notice the ideal orientation has significant rotation from directly forward. Mine was about a 40 Degree rotation. No way would straight forward be comfortable for long hand flying. Even worse on takeoff when you often have to flick the trim several times, flip the Flaps Up toggle and push the flip/flop not having the correct & natural orientation on the grip makes for something less than ideal button orientation as well as a less natural placement in your hand. Just something to consider. > > Robin > ________________________________________________________________________________
Date: Jul 22, 2013
Infinity grip with the wires on the outside. Full boot cover from Flightline Interiors. Very slightly rotated. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405071#405071 ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Baggage Tie Downs
Are many people putting baggage tie downs in the baggage compartment? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Date: Jul 22, 2013
I tried to strike a reasonable balance between beauty and function. Actually I just got lazy. Tosten grips and external wire run without a boot. Looks utilitarian but neat to my eyes. No regrets until this thread. I chose the Tosten grip because the Infinity had 1 or two more functions than I could see using. I also liked the rotating ability because the most comfortable position is far from straight ahead as someone else has noted. Rotating is even better and the Tosten does that very well. After 2 years of flying I use the mic button and trim hat all the time. But since the AP is normally connected, I use the the AP disco 100% and the Transponder ident 50% of the time. Don't use the flip flop at all. Can't think of another function I would actually use if on the stick. Bill "only slightly embarrassed as I look at my taped up stick move all by itself" Watson On 7/21/2013 7:37 PM, Bob Turner wrote: > > My plane is definitely function first, beauty last. I ran the wires, in a protective covering, on the outside. > Adding to Robin's comment, one nice feature of the Tosten grip is that the hold down screw rides in a groove. With it snug but not tight the grip rotates naturally with your hand, as you move the stick. > > -------- > Bob Turner > RV-10 QB > > ________________________________________________________________________________
Date: Jul 22, 2013
I did and removed them two years ago for the condition inspection and have not put them back in. After flying two hundred hours I found I did not need them. I do not have things flying up from the back........YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Monday, July 22, 2013 12:23 PM Subject: RV10-List: Baggage Tie Downs Are many people putting baggage tie downs in the baggage compartment? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Date: Jul 22, 2013
On 7/22/2013 2:38 PM, Bill Watson wrote: snip > I chose the Tosten grip because the Infinity had 1 or two more > functions than I could see using. I also liked the rotating ability > because the most comfortable position is far from straight ahead as > someone else has noted. Rotating is even better and the Tosten does > that very well. I just didn't like the looks of the Tosten, although the swivel function was pretty neat. > > After 2 years of flying I use the mic button and trim hat all the > time. But since the AP is normally connected, I use the the AP disco > 100% and the Transponder ident 50% of the time. Don't use the flip > flop at all. Can't think of another function I would actually use if > on the stick. Part of the reason for my choosing the Infinity is .... I'll have aileron and rudder trim driven by model airplane servos. Maxed out the switches with only one momentary switch not spoke for. I figured that I could let switches go unused Vs. adding switches later ....... One comment on running the huge number of wires .... I have all wires running through a DB-25 that connects to a harness. The harness is 3 DB-25s, one mounted each side behind the pilot/copilot calf and one in the center tunnel for distribution .... all in parallel. I can easily install a switch to break the copilots ground rendering that stick inop .... just haven't found a good place to put the switch. Linn .... through the stick. > > Bill "only slightly embarrassed as I look at my taped up stick move > all by itself" Watson > > > On 7/21/2013 7:37 PM, Bob Turner wrote: >> >> My plane is definitely function first, beauty last. I ran the wires, >> in a protective covering, on the outside. >> Adding to Robin's comment, one nice feature of the Tosten grip is >> that the hold down screw rides in a groove. With it snug but not >> tight the grip rotates naturally with your hand, as you move the stick. >> >> -------- >> Bob Turner >> RV-10 QB >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Fast When They Don't Have To Be
Here I was planning ahead by a few months to get my registration into the FAA as recommended. Well, I got it back in a week. Guess all I have to do now is finish that last 10%. Oh and pay the tax bill that will now be triggered. :) -Sean #40303 (prepping for paint) ________________________________________________________________________________
Date: Jul 22, 2013
I found some nice indoor/outdoor carpet in the aviation section at Lowes. This is about 1/8" think with a rubber back. A few inches of double sided tape and you have a surface that limits stuff moving around - and it looks good. $20 got me enough to change out this carpet several times. Carl RV-10 (120 hrs) RV-8A (sold) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker Sent: Monday, July 22, 2013 2:46 PM Subject: RE: RV10-List: Baggage Tie Downs I did and removed them two years ago for the condition inspection and have not put them back in. After flying two hundred hours I found I did not need them. I do not have things flying up from the back........YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Monday, July 22, 2013 12:23 PM Subject: RV10-List: Baggage Tie Downs Are many people putting baggage tie downs in the baggage compartment? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: Fast When They Don't Have To Be
Date: Jul 22, 2013
Just remember that it will need to be renewed 3 years from now (July) not 3 years from when you get your A/W certificate. Here in CA tax is assessed on property you own on Jan first. I was careful to not send in the application until after that. Nevertheless, I got a letter from the tax assessor asking, "How long have you owned this aircraft?". I replied that as I had no A/W certificate, that I did not yet own any airplane, just airplane parts. That seemed to work, they left me alone until the next year. They are still appraising it for more than it is insured for, but that's another story. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405092#405092 ________________________________________________________________________________
Date: Jul 22, 2013
If you're in a place like California where you'll get a huge tax bill for the plane, call the Tax agency and tell them ahead of time. I was able to get deferred a year while I finished up the plane to make it "flyable". Once you explain it's a home built and the FAA registration is needed for the pink slip, that may not come for months, the agency usually understands and works with you. Just get it done in less than a year ;-) -----Original Message----- From: Sean Stephens Sent: Monday, July 22, 2013 12:08 PM Subject: RV10-List: Fast When They Don't Have To Be Here I was planning ahead by a few months to get my registration into the FAA as recommended. Well, I got it back in a week. Guess all I have to do now is finish that last 10%. Oh and pay the tax bill that will now be triggered. :) -Sean #40303 (prepping for paint) ________________________________________________________________________________
Date: Jul 22, 2013
Yep. Already talked to the Illinois folks. I'll be sending in the form with my costs/invoices so I don't have to rely on their valuation. We'll see how that works out. On 7/22/13 4:15 PM, Pascal wrote: > > If you're in a place like California where you'll get a huge tax bill > for the plane, call the Tax agency and tell them ahead of time. I was > able to get deferred a year while I finished up the plane to make it > "flyable". Once you explain it's a home built and the FAA registration > is needed for the pink slip, that may not come for months, the agency > usually understands and works with you. > Just get it done in less than a year ;-) > > > -----Original Message----- From: Sean Stephens > Sent: Monday, July 22, 2013 12:08 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fast When They Don't Have To Be > > > Here I was planning ahead by a few months to get my registration into > the FAA as recommended. Well, I got it back in a week. Guess all I > have to do now is finish that last 10%. Oh and pay the tax bill that > will now be triggered. :) > > -Sean #40303 (prepping for paint) > > ________________________________________________________________________________
Subject: : RV10-List:Stick Rotation - Was: Brain trust stick wiring poll
Date: Jul 22, 2013
My main point about stick grip rotation was less about an absolute number and more about avoiding blindly installing a grip (especially an Infinity Grip) straight forward. 10 degrees, 40 degrees whatever you want just don't near permanently affix your grip without some forethought. I say especially an Infinity Grip because they seem to be more "molded" than say the Tosten grips. As for the desk test mentioned below maybe pushing away gives an ideal rotation of 5-10 but I doubt pulling gives you the same result. I hope to never have to exert that much pressure on an RV stick. I take that back when doing Power On Stalls in the -10 either solo or with my light weight instructor and half tanks the -10 feels like you have to stand it on its tail to cause it to stall. In that instance I find you might want even more rotation as it feels more like a curling a heavy weight. Man that -10 is hard to stall with power on. I remember being totally drenched after 3 Power On Stalls, followed by the most gentle and predictable break. I love my RV's! Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, July 22, 2013 6:06 AM Subject: Re: RV10-List: Brain trust stick wiring poll While usually Robin and I are on the same page, here I differ a bit. I think too much is made of the rotating of the grip. Yeah, you will want it rotated slightly, but I don't think any major rotation is warranted. I would probably be more likely to recommend AGAINST going very far in rotation and here's why... When flying the RV-10, even during landing, I rarely use more than 2 or 3 fingertips on the stick....LITERALLY. You just give it gentle nudges with 1 or 2 fingers and it does what you want. Honestly I never ever have the need to grab the grip with a full hand on most flights. You could throw an mis-shapen blob of rocks on the end of the stick and I could fly with it, because gripping it is just not something you would do for hours on end. Your forearm rests on your legs and it's very comfortable to fly. I could fly with it cockeyed by 40 degrees, 90 degrees, or 180 degrees. But, when the rubber meets the road, and you DO need to grip it hard, that's likely going to be during a time of trouble....some time when you're going to actually exert yourself to push or pull or yank and bank like during some event or bad turbulence. At that point I would recommend that the yoke be rotated in the direction that gives you the most arm "solid" control ability. Sit at your desk right now, and try to push yourself back from your desk with your fist, and see what position your arm wants to be in. Mine certainly doesn't have full strength at 40 degrees offset. In fact, it's probably not many degrees off straight...maybe 5-10 at most. So my position on it is basically....rotate the grip so that if you needed to do a hard push to override an autopilot or break a stall or perform a hard maneuver, you could do it with a locked wrist and be comfortable. And, beyond that, don't worry about it much because if you're giving the stick your full grip during normal maneuvers you're probably trying too hard...it's a plane that can be flown with fingertips and trim alone. As Dave Mason sung years ago..... "We just disagree", Robin. :) No worries though....this one falls into that "do whatever you wish" category as far as I'm concerned. I'm just providing the counterpoint. Tim On 7/21/2013 4:58 PM, Robin Marks wrote: > > Inside. In fact even if I had a stick boot (which I never will) I would run them inside. With the Infinity wire bundle there are a LOT of wires. I think we ended up using a common ground so we were able to remove more than a third of the wires leaving extras in case I wanted to expand in the future. This made it a lot easier to fish through the stick. On the tail end we used a D Shell style connector in the rare event we would have to remove the stick. We did the same set up on all the 2 place RV's as we often removed the Co-pilots stick for various reasons. > One note on grip buttons. If I were to do it over again with all the modern tech and push button items in our cockpit I would now dedicate one button to an OK or Accept button. We get the most random notifications on these glass displays that simply request acknowledgement. It would be nice the flick a pinky to confirm the notification. > One note on the grips themselves. I see so many installs that have the grip facing straight forward. I strongly suggest you sit in your seat properly located forward & aft to see what angle your stick hand lands on the stick. Put the grip in our hand un-mounted or over the stick to see what feels best. Close your eyes and drop your hand into position. Do it several times. You will notice the ideal orientation has significant rotation from directly forward. Mine was about a 40 Degree rotation. No way would straight forward be comfortable for long hand flying. Even worse on takeoff when you often have to flick the trim several times, flip the Flaps Up toggle and push the flip/flop not having the correct & natural orientation on the grip makes for something less than ideal button orientation as well as a less natural placement in your hand. Just something to consider. > > Robin > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Re: : RV10-List:Stick Rotation - Was: Brain trust stick wiring poll
I don't recall doing a power on stall yet in a -10. However, since the point of the exercise is in a max gross wt and high density altitude scenario, I would think that one would want to limit power to around 60-70% for such a maneuver if you aren't in fact at full gross. You want what it feels to take off at gross from Big Bear, Flagstaff, Leadville, Aspen, etc on a summer day so as to not inadvertently stall in that situation. Having all the excess power of a -10 at 30% useful load is not going to give you any idea of what a typical departure stall feels like. On 7/22/2013 3:40 PM, Robin Marks wrote: > > I take that back when doing Power On Stalls in the -10 either solo or with my light weight instructor and half tanks the -10 feels like you have to stand it on its tail to cause it to stall. In that instance I find you might want even more rotation as it feels more like a curling a heavy weight. Man that -10 is hard to stall with power on. I remember being totally drenched after 3 Power On Stalls, followed by the most gentle and predictable break. I love my RV's! > > Robin > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 22, 2013
Subject: Re: Baggage Tie Downs
YMMV when you come to a sudden, unplanned stop. Yes, we sell tie downs ($49, available on our web site), but mostly because I'm pretty fanatic about securing stuff in the cabin and the baggage compartment. Early in my career I worked for a company that lost a customer after he survived the crash but not the baggage. I have tiedowns and a cargo net. Belt and suspenders, literally. Dave Saylor 831-750-0284 CL On Mon, Jul 22, 2013 at 11:45 AM, Rene Felker wrote: > > I did and removed them two years ago for the condition inspection and have > not put them back in. After flying two hundred hours I found I did not > need > them. I do not have things flying up from the back........YMMV > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche > (Building) > Sent: Monday, July 22, 2013 12:23 PM > To: RV-10 Matronics > Subject: RV10-List: Baggage Tie Downs > > > > Are many people putting baggage tie downs in the baggage compartment? > > Dave > > -- > ~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > Fuselage > > ________________________________________________________________________________
Date: Jul 22, 2013
I tried Power On Stalls in several configurations including right near Max Gross Weight. The Lightly loaded one was particularly memorable that is why I mentioned it. It is the time I recall having to pull most on an RV stick. Robin -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Monday, July 22, 2013 4:31 PM Subject: Re: RV10-List:Stick Rotation - Was: Brain trust stick wiring poll I don't recall doing a power on stall yet in a -10. However, since the point of the exercise is in a max gross wt and high density altitude scenario, I would think that one would want to limit power to around 60-70% for such a maneuver if you aren't in fact at full gross. You want what it feels to take off at gross from Big Bear, Flagstaff, Leadville, Aspen, etc on a summer day so as to not inadvertently stall in that situation. Having all the excess power of a -10 at 30% useful load is not going to give you any idea of what a typical departure stall feels like. On 7/22/2013 3:40 PM, Robin Marks wrote: > > I take that back when doing Power On Stalls in the -10 either solo or with my light weight instructor and half tanks the -10 feels like you have to stand it on its tail to cause it to stall. In that instance I find you might want even more rotation as it feels more like a curling a heavy weight. Man that -10 is hard to stall with power on. I remember being totally drenched after 3 Power On Stalls, followed by the most gentle and predictable break. I love my RV's! > > Robin > ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Date: Jul 22, 2013
Subject: Re: : RV10-List:Stalls,,was Stick Rotation -
The reason it was memorable is it is a flight scenario you will never get yourself into inadvertently. The whole point of doing stalls is to do them in the way that they would inadvertently bite you when you are distracted. Like the power off base to final turn, the accelerated steep turn about a moose or nudist camp, etc. You know, when you are totally focused on something outside the plane, like obstacles off the end of runway on full gross takeoff at 10,000 DA, and you mind is saying "what is that annoying buzzing outside my ANR headset". On 7/22/2013 4:45 PM, Robin Marks wrote: > > I tried Power On Stalls in several configurations including right near Max Gross Weight. The Lightly loaded one was particularly memorable that is why I mentioned it. It is the time I recall having to pull most on an RV stick. > > Robin > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Monday, July 22, 2013 4:31 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List:Stick Rotation - Was: Brain trust stick wiring poll > > > I don't recall doing a power on stall yet in a -10. However, since the point of the exercise is in a max gross wt and high density altitude scenario, I would think that one would want to limit power to around 60-70% for such a maneuver if you aren't in fact at full gross. > You want what it feels to take off at gross from Big Bear, Flagstaff, Leadville, Aspen, etc on a summer day so as to not inadvertently stall in that situation. > Having all the excess power of a -10 at 30% useful load is not going to give you any idea of what a typical departure stall feels like. > > On 7/22/2013 3:40 PM, Robin Marks wrote: >> >> I take that back when doing Power On Stalls in the -10 either solo or with my light weight instructor and half tanks the -10 feels like you have to stand it on its tail to cause it to stall. In that instance I find you might want even more rotation as it feels more like a curling a heavy weight. Man that -10 is hard to stall with power on. I remember being totally drenched after 3 Power On Stalls, followed by the most gentle and predictable break. I love my RV's! >> >> Robin >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 22, 2013
On 7/22/2013 6:40 PM, Robin Marks wrote: > > My main point about stick grip rotation was less about an absolute number and more about avoiding blindly installing a grip (especially an Infinity Grip) straight forward. 10 degrees, 40 degrees whatever you want just don't near permanently affix your grip without some forethought. I say especially an Infinity Grip because they seem to be more "molded" than say the Tosten grips. Good point. I have flown with a stick that had a bicycle grip with the 'knuckles' straight forward. Really uncomfortable. You can get a good idea fo the angle if you place your hand in a 'loose grip' and see where the thumb intersection is in relation to the 2nd or 3rd finger joints. Just hold the stick grip where it's comfortable. I always thought a Tosten grip would work really well in an airplane with a center stick. Linn > As for the desk test mentioned below maybe pushing away gives an ideal rotation of 5-10 but I doubt pulling gives you the same result. I hope to never have to exert that much pressure on an RV stick. I take that back when doing Power On Stalls in the -10 either solo or with my light weight instructor and half tanks the -10 feels like you have to stand it on its tail to cause it to stall. In that instance I find you might want even more rotation as it feels more like a curling a heavy weight. Man that -10 is hard to stall with power on. I remember being totally drenched after 3 Power On Stalls, followed by the most gentle and predictable break. I love my RV's! > > Robin > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Monday, July 22, 2013 6:06 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Brain trust stick wiring poll > > > While usually Robin and I are on the same page, here I differ a bit. > I think too much is made of the rotating of the grip. Yeah, you will want it rotated slightly, but I don't think any major rotation is warranted. > I would probably be more likely to recommend AGAINST going very far in rotation and here's why... > > When flying the RV-10, even during landing, I rarely use more than > 2 or 3 fingertips on the stick....LITERALLY. You just give it gentle nudges with 1 or 2 fingers and it does what you want. Honestly I never ever have the need to grab the grip with a full hand on most flights. You could throw an mis-shapen blob of rocks on the end of the stick and I could fly with it, because gripping it is just not something you would do for hours on end. Your forearm rests on your legs and it's very comfortable to fly. I could fly with it cockeyed by 40 degrees, 90 degrees, or 180 degrees. > > But, when the rubber meets the road, and you DO need to grip it hard, that's likely going to be during a time of trouble....some time when you're going to actually exert yourself to push or pull or yank and bank like during some event or bad turbulence. At that point I would recommend that the yoke be rotated in the direction that gives you the most arm "solid" control ability. Sit at your desk right now, and try to push yourself back from your desk with your fist, and see what position your arm wants to be in. Mine certainly doesn't have full strength at 40 degrees offset. In fact, it's probably not many degrees off straight...maybe 5-10 at most. > > So my position on it is basically....rotate the grip so that if you needed to do a hard push to override an autopilot or break a stall or perform a hard maneuver, you could do it with a locked wrist and be comfortable. And, beyond that, don't worry about it much because if you're giving the stick your full grip during normal maneuvers you're probably trying too hard...it's a plane that can be flown with fingertips and trim alone. > > As Dave Mason sung years ago..... "We just disagree", Robin. :) No worries though....this one falls into that "do whatever you wish" > category as far as I'm concerned. I'm just providing the counterpoint. > > Tim > > > On 7/21/2013 4:58 PM, Robin Marks wrote: >> >> Inside. In fact even if I had a stick boot (which I never will) I would run them inside. With the Infinity wire bundle there are a LOT of wires. I think we ended up using a common ground so we were able to remove more than a third of the wires leaving extras in case I wanted to expand in the future. This made it a lot easier to fish through the stick. On the tail end we used a D Shell style connector in the rare event we would have to remove the stick. We did the same set up on all the 2 place RV's as we often removed the Co-pilots stick for various reasons. >> One note on grip buttons. If I were to do it over again with all the modern tech and push button items in our cockpit I would now dedicate one button to an OK or Accept button. We get the most random notifications on these glass displays that simply request acknowledgement. It would be nice the flick a pinky to confirm the notification. >> One note on the grips themselves. I see so many installs that have the grip facing straight forward. I strongly suggest you sit in your seat properly located forward & aft to see what angle your stick hand lands on the stick. Put the grip in our hand un-mounted or over the stick to see what feels best. Close your eyes and drop your hand into position. Do it several times. You will notice the ideal orientation has significant rotation from directly forward. Mine was about a 40 Degree rotation. No way would straight forward be comfortable for long hand flying. Even worse on takeoff when you often have to flick the trim several times, flip the Flaps Up toggle and push the flip/flop not having the correct & natural orientation on the grip makes for something less than ideal button orientation as well as a less natural placement in your hand. Just something to consider. >> >> Robin >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 22, 2013
Website address? Rob Kermanj Sent from my iPad On Jul 22, 2013, at 7:34 PM, Dave Saylor wrote: > YMMV when you come to a sudden, unplanned stop. Yes, we sell tie downs ($ 49, available on our web site), but mostly because I'm pretty fanatic about s ecuring stuff in the cabin and the baggage compartment. Early in my career I worked for a company that lost a customer after he survived the crash but n ot the baggage. > > I have tiedowns and a cargo net. Belt and suspenders, literally. > > Dave Saylor > 831-750-0284 CL > > > On Mon, Jul 22, 2013 at 11:45 AM, Rene Felker wrote: >> >> I did and removed them two years ago for the condition inspection and hav e >> not put them back in. After flying two hundred hours I found I did not n eed >> them. I do not have things flying up from the back........YMMV >> >> Rene' Felker >> N423CF >> 801-721-6080 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche >> (Building) >> Sent: Monday, July 22, 2013 12:23 PM >> To: RV-10 Matronics >> Subject: RV10-List: Baggage Tie Downs >> >> >> >> Are many people putting baggage tie downs in the baggage compartment? >> >> Dave >> >> -- >> ~~~~~~~~~~~~~~ >> Dave Fritzsche >> 40813 >> Puyallup, WA >> Fuselage >> >> >> >> >> >> >> >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 22, 2013
Third item down . . . http://www.aircraftersllc.com/products.html Tim On 7/22/2013 5:45 PM, Rob Kermanj wrote: > Website address? > > Rob Kermanj > Sent from my iPad > > On Jul 22, 2013, at 7:34 PM, Dave Saylor > > wrote: > >> YMMV when you come to a sudden, unplanned stop. Yes, we sell tie >> downs ($49, available on our web site), but mostly because I'm pretty >> fanatic about securing stuff in the cabin and the baggage >> compartment. Early in my career I worked for a company that lost a >> customer after he survived the crash but not the baggage. >> >> I have tiedowns and a cargo net. Belt and suspenders, literally. >> >> Dave Saylor >> 831-750-0284 CL >> >> >> On Mon, Jul 22, 2013 at 11:45 AM, Rene Felker > > wrote: >> >> > >> >> I did and removed them two years ago for the condition inspection >> and have >> not put them back in. After flying two hundred hours I found I >> did not need >> them. I do not have things flying up from the back........YMMV >> >> Rene' Felker >> N423CF >> 801-721-6080 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com >> ] On Behalf Of Dave >> Fritzsche >> (Building) >> Sent: Monday, July 22, 2013 12:23 PM >> To: RV-10 Matronics >> Subject: RV10-List: Baggage Tie Downs >> >> > >> >> Are many people putting baggage tie downs in the baggage compartment? >> >> Dave >> >> -- >> ~~~~~~~~~~~~~~ >> Dave Fritzsche >> 40813 >> Puyallup, WA >> Fuselage >> >> >> >> >> >> >> >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> * >> >> >> * > * > > > * -- Tim Farrell - Aircrafters - Owner/Manager - (831) 722-9141 - www.aircraftersLLC.com ________________________________________________________________________________
Date: Jul 22, 2013
Put them in and never used them,,,, so I removed them.=0ADon McDonald=0A=0A =0A=0A=0A________________________________=0A From: Dave Fritzsche (Building ) =0ATo: RV-10 Matronics =0ASe nt: Monday, July 22, 2013 1:22 PM=0ASubject: RV10-List: Baggage Tie Downs itz(at)bpgsim.com>=0A=0AAre many people putting baggage tie downs in the bagga ge compartment?=0A=0ADave=0A=0A-- =0A~~~~~~~~~~~~~~=0ADave Fritzsche=0A4081 = ________________________________________________________________________________
Date: Jul 22, 2013
Just a quick post to let everybody know that we're on-site, sites are staked out and the group is located along 54th St, just south of Lindbergh. The tags will be picked up in the morning to make it official. I'll send more details to those camping with us tomorrow. It's raining now but the long term forecast looks spectacular! It also appears to be more crowded than in past years and we haven't yet been able to secure any picnic tables... Feel free to swing by even if not camping with us. As always, we'll have the coffee going in the mornings! Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405128#405128 ________________________________________________________________________________
Date: Jul 22, 2013
Subject: AirVenture trams run on Sunday?
I'm soliciting list insight into tram availability Sunday at OSH. This will be my first time arriving at OSH the day before the show officially starts. I'll need to get from homebuilt parking over to the FBO area to get my car. Thanks, Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 400 hrs ________________________________________________________________________________
Date: Jul 22, 2013
Just an FYI.... in Texas the tax on planes is the same as the income tax... .. ZERO=0A=0ADon=0A=0A=0A=0A________________________________=0A From: Bob T urner =0ATo: rv10-list(at)matronics.com =0ASent: Monda y, July 22, 2013 3:23 PM=0ASubject: RV10-List: Re: Fast When They Don't Hav lum.rpi.edu>=0A=0AJust remember that it will need to be renewed 3 years fro m now (July) not 3 years from when you get your A/W certificate.=0A=0AHere in CA tax is assessed on property you own on Jan first. I was careful to no t send in the application until after that. Nevertheless, I got a letter fr om the tax assessor asking, "How long have you owned this aircraft?". I rep lied that as I had no A/W certificate, that I did not yet own any airplane, just airplane parts. That seemed to work, they left me alone until the nex t year.=0A=0AThey are still appraising it for more than it is insured for, but that's another story.=0A=0A--------=0ABob Turner=0ARV-10 QB=0A=0A=0A=0A =0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/viewtopic. == ________________________________________________________________________________
Date: Jul 22, 2013
I built mine from the hinge material used to secure the cowls, basically made a few holes and pop riveted them in, cost about.. $1 dollar in pop rivets and spare parts. I use it on every flight for holding down a bin with extra oil, plexi cleaner, tie down material, chocks (made from spare angle), etc.. I have a rug in the area as well, cut around the hinges.. I used a tie down net from my motorcycle, but can be easily acquired from the car dept. in Walmart. Put the tie down in, they dont take much space and it's there if you need it for whatever that may be. If you decide not to do so, just dont practice negative G's with anything back there. Keep in mind I do not use the tie down for large luggage any for smaller pieces I want secured. Pascal -----Original Message----- From: Dave Fritzsche (Building) Sent: Monday, July 22, 2013 11:22 AM Subject: RV10-List: Baggage Tie Downs Are many people putting baggage tie downs in the baggage compartment? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: AirVenture trams run on Sunday?
Date: Jul 22, 2013
Tim, The tram does not go to the FBO, call the "Welcom Wagon" they can take you where ever. I don't have their number but they are right next to the sign in area at the flight line. Dick Sipp -----Original Message----- From: Tim Lewis Sent: Monday, July 22, 2013 10:27 PM Subject: RV10-List: AirVenture trams run on Sunday? I'm soliciting list insight into tram availability Sunday at OSH. This will be my first time arriving at OSH the day before the show officially starts. I'll need to get from homebuilt parking over to the FBO area to get my car. Thanks, Tim -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 400 hrs ________________________________________________________________________________
Date: Jul 22, 2013
They've got busses that go that way. Just go in and work your way to the bu s pickup and ride it all the way around 9/27. It shouldn't be too bad at al l from the RV parking area. Tim On Jul 22, 2013, at 9:27 PM, Tim Lewis wrote: > > I'm soliciting list insight into tram availability Sunday at OSH. This wil l be my first time arriving at OSH the day before the show officially starts . I'll need to get from homebuilt parking over to the FBO area to get my ca r. > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Jul 22, 2013
Tim, The trams don't run over to the FBO but I can probably help. I sent you an email offline with my contact info. Bob On Mon, Jul 22, 2013 at 9:27 PM, Tim Lewis wrote: > > I'm soliciting list insight into tram availability Sunday at OSH. This > will be my first time arriving at OSH the day before the show officially > starts. I'll need to get from homebuilt parking over to the FBO area to > get my car. > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > ________________________________________________________________________________
Date: Jul 22, 2013
Red Warbird tram to North Forty Yellow school bus over to Basket. John On Jul 22, 2013 7:30 PM, "Tim Lewis" wrote: > > I'm soliciting list insight into tram availability Sunday at OSH. This > will be my first time arriving at OSH the day before the show officially > starts. I'll need to get from homebuilt parking over to the FBO area to > get my car. > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > ________________________________________________________________________________
Date: Jul 22, 2013
Yup. I said busses. I'm not sure the welcome wagon would go over there....they would go to home bullseye HQ and to Scholler though. The trams for anywhere internal. So no matter where you want to go there's a way. On Jul 22, 2013, at 10:07 PM, "Dick & Vicki Sipp" wrote: > > Tim, > > The tram does not go to the FBO, call the "Welcom Wagon" they can take you where ever. I don't have their number but they are right next to the sign in area at the flight line. > > Dick Sipp > > -----Original Message----- From: Tim Lewis > Sent: Monday, July 22, 2013 10:27 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: AirVenture trams run on Sunday? > > > I'm soliciting list insight into tram availability Sunday at OSH. This > will be my first time arriving at OSH the day before the show officially > starts. I'll need to get from homebuilt parking over to the FBO area to > get my car. > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > > > > > > > ________________________________________________________________________________
Date: Jul 23, 2013
Tim, Ask for a ride at homebuilt registration. We get a ride in their open air minivan over to Basler every year to get our car. Donate a couple of bucks for operational expenses. Rick McBride On Jul 22, 2013, at 10:27 PM, Tim Lewis wrote: > > I'm soliciting list insight into tram availability Sunday at OSH. This will be my first time arriving at OSH the day before the show officially starts. I'll need to get from homebuilt parking over to the FBO area to get my car. > > Thanks, > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > > > > ________________________________________________________________________________
Date: Jul 23, 2013
I installed baggage tie downs both in the baggage compartment and behind the copilot seat. I use 'em... Very handy to secure sandbags at the moment. It would seem counter intuitive to not secure baggage and/or loose items. These were easy to install... http://www.aircraftersllc.com/products.html Cheers, Jay 433RV - Phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405157#405157 ________________________________________________________________________________
Date: Jul 23, 2013
I have Tosten grips and like them a lot. I ran the wires inside the stick (a pain) and then decided to use the Flightline stick covers. Does wiring inside or outside matter? Not much. Once you get in the plane and close the door, all you see is the panel and outside. I did wire in DB15 connectors and am glad I did so as they've been in and out several times. Be advised that lots of folks (me included) have had to bend the sticks to allow for adequate fwd clearance. I used a mandrel that my ME buddy made instead of a hydraulic press. Cheers, Jay 433RV - Phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405158#405158 ________________________________________________________________________________
Date: Jul 23, 2013
Those look nice but I don't see any added utility to the D-ring type from the hardware store. What am I missing??? Linn ..... installing FAB On 7/23/2013 10:17 AM, hotwheels wrote: > > I installed baggage tie downs both in the baggage compartment and behind the copilot seat. I use 'em... Very handy to secure sandbags at the moment. It would seem counter intuitive to not secure baggage and/or loose items. These were easy to install... http://www.aircraftersllc.com/products.html > > Cheers, > Jay > 433RV - Phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405157#405157 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 23, 2013
Those of you that used DB15 and DB 25 connectors and ran the wires inside the stick, I suppose that you are not able to pull the grips off without unsoldering the DB connectors, because they don't fit through the stick, right? Carlos -----Mensagem original----- De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels Enviada: 23 de julho de 2013 15:23 Para: rv10-list(at)matronics.com Assunto: RV10-List: Re: Brain trust stick wiring poll I have Tosten grips and like them a lot. I ran the wires inside the stick (a pain) and then decided to use the Flightline stick covers. Does wiring inside or outside matter? Not much. Once you get in the plane and close the door, all you see is the panel and outside. I did wire in DB15 connectors and am glad I did so as they've been in and out several times. Be advised that lots of folks (me included) have had to bend the sticks to allow for adequate fwd clearance. I used a mandrel that my ME buddy made instead of a hydraulic press. Cheers, Jay 433RV - Phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405158#405158 ________________________________________________________________________________
Date: Jul 23, 2013
I don't know how much the D-rings weigh, but I bet these are much lighter. They are made from extruded aluminum hinge. Plus they have a little lip so they are easy flip up with your finger. Tim Sent from my iPhone On Jul 23, 2013, at 7:36 AM, Linn Walters wrote: > > Those look nice but I don't see any added utility to the D-ring type from the hardware store. What am I missing??? > Linn ..... installing FAB > > On 7/23/2013 10:17 AM, hotwheels wrote: >> >> I installed baggage tie downs both in the baggage compartment and behind the copilot seat. I use 'em... Very handy to secure sandbags at the moment. It would seem counter intuitive to not secure baggage and/or loose items. These were easy to install... http://www.aircraftersllc.com/products.html >> >> Cheers, >> Jay >> 433RV - Phase 1 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=405157#405157 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Jul 23, 2013
There's no way to get the solder-cup connectors through the stick socket without really weakening the socket. Just drill a hole the size you need for the number of wires. I have one stick with the connector on to do testing. I'll have to pull the wires from the connector and feed them through the hole and re-insert them back into the housing .... very carefully!!!! I'm a NASA certified solderer and have good tools but I HATE solder cup DB connectors. I changed out all my solder cup connectors for crimp-on pins. I had to pull a lot of wires loose from my DB connectors because I can't see or can't count!!!! ;-) Using the crimp pins also helps when you want to add a wire to a connector that's buried down in the innards where you can't solder well. You can get connectors, shells, pins, crimper and removal tool at http://steinair.com/. No, I don't get any discount!!! If you're replacing solder cups with crimps you can use the shells you have. I used DB connectors for all the low current cabling and Molex for the high current ones. Molex for the same reasons ... removeable and crimp. I have ratcheting crimp tools, one for lugs one for DB pins and one for molex pins. Pricey, but well worth it to make good air-tight connections. You can't go wrong using the proper tools. Linn On 7/23/2013 11:39 AM, Carlos Trigo wrote: > > Those of you that used DB15 and DB 25 connectors and ran the wires inside > the stick, I suppose that you are not able to pull the grips off without > unsoldering the DB connectors, because they don't fit through the stick, > right? > > Carlos > > > -----Mensagem original----- > De: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels > Enviada: 23 de julho de 2013 15:23 > Para: rv10-list(at)matronics.com > Assunto: RV10-List: Re: Brain trust stick wiring poll > > > I have Tosten grips and like them a lot. I ran the wires inside the stick (a > pain) and then decided to use the Flightline stick covers. Does wiring > inside or outside matter? Not much. Once you get in the plane and close the > door, all you see is the panel and outside. > > I did wire in DB15 connectors and am glad I did so as they've been in and > out several times. > > Be advised that lots of folks (me included) have had to bend the sticks to > allow for adequate fwd clearance. I used a mandrel that my ME buddy made > instead of a hydraulic press. > > Cheers, > Jay > 433RV - Phase 1 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405158#405158 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Re: Brain trust stick wiring poll
Date: Jul 23, 2013
Ok, Linn, I was not only referring to unsoldering but also to "uncrimping". What I meant is that, after you ran the fat blue cable inside the stick, and you install the DB connector, you will never be able to pull off the Infinity (or other) grip without cutting the wires. Carlos P.S. - if you would be interested in crossing the big pond and come to Europe, I could use a NASA certified solderer! I hate installing DB connectors inside the fuselage. De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Linn Walters Enviada: 23 de julho de 2013 17:18 Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: Re: Brain trust stick wiring poll There's no way to get the solder-cup connectors through the stick socket without really weakening the socket. Just drill a hole the size you need for the number of wires. I have one stick with the connector on to do testing. I'll have to pull the wires from the connector and feed them through the hole and re-insert them back into the housing .... very carefully!!!! I'm a NASA certified solderer and have good tools but I HATE solder cup DB connectors. I changed out all my solder cup connectors for crimp-on pins. I had to pull a lot of wires loose from my DB connectors because I can't see or can't count!!!! ;-) Using the crimp pins also helps when you want to add a wire to a connector that's buried down in the innards where you can't solder well. You can get connectors, shells, pins, crimper and removal tool at http://steinair.com/. No, I don't get any discount!!! If you're replacing solder cups with crimps you can use the shells you have. I used DB connectors for all the low current cabling and Molex for the high current ones. Molex for the same reasons ... removeable and crimp. I have ratcheting crimp tools, one for lugs one for DB pins and one for molex pins. Pricey, but well worth it to make good air-tight connections. You can't go wrong using the proper tools. Linn On 7/23/2013 11:39 AM, Carlos Trigo wrote: Those of you that used DB15 and DB 25 connectors and ran the wires inside the stick, I suppose that you are not able to pull the grips off without unsoldering the DB connectors, because they don't fit through the stick, right? Carlos -----Mensagem original----- De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels Enviada: 23 de julho de 2013 15:23 Para: rv10-list(at)matronics.com Assunto: RV10-List: Re: Brain trust stick wiring poll I have Tosten grips and like them a lot. I ran the wires inside the stick (a pain) and then decided to use the Flightline stick covers. Does wiring inside or outside matter? Not much. Once you get in the plane and close the door, all you see is the panel and outside. I did wire in DB15 connectors and am glad I did so as they've been in and out several times. Be advised that lots of folks (me included) have had to bend the sticks to allow for adequate fwd clearance. I used a mandrel that my ME buddy made instead of a hydraulic press. Cheers, Jay 433RV - Phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405158#405158 ----- No virus found in this message. Checked by AVG - www.avg.com <http://www.avg.com> ________________________________________________________________________________
Date: Jul 23, 2013
With crimped pins I don't you'd need to cut the wires. After you extracted the pins from the D-sub connector, the diameter of the mass of freed pins would be close to that of the "blue" wire, or at least close enough to allow you to pull it all back up through the stick. -------- Todd Stovall aka Auburntsts on EAA, AOPA, Purple Pilots, VAF, and RVairspace RV-10 N728TT Empacone, Wings, Fuse, Finishing www.mykitlog.com/auburntsts Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405175#405175 ________________________________________________________________________________
Date: Jul 23, 2013
You don't "un-crimp", just simply pull the pins out of the connector. Sent from my iPhone On Jul 23, 2013, at 12:35 PM, "Carlos Trigo" wrote: Ok, Linn, I was not only referring to unsoldering but also to =9Cuncri mping=9D. What I meant is that, after you ran the fat blue cable inside the stick, and you install the DB connector, you will never be able to pull off the Infini ty (or other) grip without cutting the wires Carlos P.S. =93 if you would be interested in crossing the big pond and come t o Europe, I could use a NASA certified solderer! I hate installing DB connec tors inside the fuselage De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@matr onics.com] Em nome de Linn Walters Enviada: 23 de julho de 2013 17:18 Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: Re: Brain trust stick wiring poll There's no way to get the solder-cup connectors through the stick socket wit hout really weakening the socket. Just drill a hole the size you need for t he number of wires. I have one stick with the connector on to do testing. I 'll have to pull the wires from the connector and feed them through the hole and re-insert them back into the housing .... very carefully!!!! I'm a NASA certified solderer and have good tools but I HATE solder cup DB c onnectors. I changed out all my solder cup connectors for crimp-on pins. I had to pull a lot of wires loose from my DB connectors because I can't see or can't count!!!! ;-) Using the crimp pins also helps when you want to add a wire to a connector t hat's buried down in the innards where you can't solder well. You can get connectors, shells, pins, crimper and removal tool at http://ste inair.com/. No, I don't get any discount!!! If you're replacing solder cups with crimps you can use the shells you have. I used DB connectors for all the low current cabling and Molex for the hig h current ones. Molex for the same reasons ... removeable and crimp. I hav e ratcheting crimp tools, one for lugs one for DB pins and one for molex pin s. Pricey, but well worth it to make good air-tight connections. You can't go wrong using the proper tools. Linn On 7/23/2013 11:39 AM, Carlos Trigo wrote: Those of you that used DB15 and DB 25 connectors and ran the wires inside the stick, I suppose that you are not able to pull the grips off without unsoldering the DB connectors, because they don't fit through the stick, right? Carlos -----Mensagem original----- De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels Enviada: 23 de julho de 2013 15:23 Para: rv10-list(at)matronics.com Assunto: RV10-List: Re: Brain trust stick wiring poll I have Tosten grips and like them a lot. I ran the wires inside the stick (a pain) and then decided to use the Flightline stick covers. Does wiring inside or outside matter? Not much. Once you get in the plane and close the door, all you see is the panel and outside. I did wire in DB15 connectors and am glad I did so as they've been in and out several times. Be advised that lots of folks (me included) have had to bend the sticks to allow for adequate fwd clearance. I used a mandrel that my ME buddy made instead of a hydraulic press. Cheers, Jay 433RV - Phase 1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405158#405158 ----- No virus found in this message. Checked by AVG - www.avg.com http://www.matronic================ http://forums.matronics.com - List Contribution Web generous nbsp; --> http://www.matronics.com/c ========================== ======== ========================== ======== ========================== ======== ========================== ======== ________________________________________________________________________________
Date: Jul 23, 2013
The crimp DB pins come out of the shell using the removal tool. If you 'stagger' the pins and tape them down so they're not right next to each other they'll fit through a hole better. I thought I drilled a 1/4" hole but it may be a 5/16." I have 24 wires (infinity) that fit through the hole I drilled. You can tie all the 'common' wires together and only run 1 common wire through the hole. Linn On 7/23/2013 12:35 PM, Carlos Trigo wrote: > > Ok, Linn, I was not only referring to unsoldering but also to > "uncrimping". > > What I meant is that, after you ran the fat blue cable inside the > stick, and you install the DB connector, you will never be able to > pull off the Infinity (or other) grip without cutting the wires... > > Carlos > > P.S. -- if you would be interested in crossing the big pond and come > to Europe, I could use a NASA certified solderer! I hateinstalling DB > connectors inside the fuselage... > > *De:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *Em nome de *Linn Walters > *Enviada:* 23 de julho de 2013 17:18 > *Para:* rv10-list(at)matronics.com > *Assunto:* Re: RV10-List: Re: Brain trust stick wiring poll > > There's no way to get the solder-cup connectors through the stick > socket without really weakening the socket. Just drill a hole the > size you need for the number of wires. I have one stick with the > connector on to do testing. I'll have to pull the wires from the > connector and feed them through the hole and re-insert them back into > the housing .... very carefully!!!! > > I'm a NASA certified solderer and have good tools but I HATE solder > cup DB connectors. I changed out all my solder cup connectors for > crimp-on pins. > > I had to pull a lot of wires loose from my DB connectors because I > can't see or can't count!!!! ;-) > > Using the crimp pins also helps when you want to add a wire to a > connector that's buried down in the innards where you can't solder well. > You can get connectors, shells, pins, crimper and removal tool at > http://steinair.com/. No, I don't get any discount!!! > > If you're replacing solder cups with crimps you can use the shells you > have. I used DB connectors for all the low current cabling and Molex > for the high current ones. Molex for the same reasons ... removeable > and crimp. I have ratcheting crimp tools, one for lugs one for DB > pins and one for molex pins. Pricey, but well worth it to make good > air-tight connections. You can't go wrong using the proper tools. > Linn > > On 7/23/2013 11:39 AM, Carlos Trigo wrote: > > > > > Those of you that used DB15 and DB 25 connectors and ran the wires inside > > the stick, I suppose that you are not able to pull the grips off without > > unsoldering the DB connectors, because they don't fit through the stick, > > right? > > > > Carlos > > > > > > -----Mensagem original----- > > De:owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] Em nome de hotwheels > > Enviada: 23 de julho de 2013 15:23 > > Para:rv10-list(at)matronics.com > > Assunto: RV10-List: Re: Brain trust stick wiring poll > > > > > > > I have Tosten grips and like them a lot. I ran the wires inside the stick (a > > pain) and then decided to use the Flightline stick covers. Does wiring > > inside or outside matter? Not much. Once you get in the plane and close the > > door, all you see is the panel and outside. > > > > I did wire in DB15 connectors and am glad I did so as they've been in and > > out several times. > > > > Be advised that lots of folks (me included) have had to bend the sticks to > > allow for adequate fwd clearance. I used a mandrel that my ME buddy made > > instead of a hydraulic press. > > > > Cheers, > > Jay > > 433RV - Phase 1 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=405158#405158 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG -www.avg.com <http://www.avg.com> > > > > > > * *http://www.matronic================ > http://forums.matronics.com- List Contribution Web generous > nbsp; --> http://www.matronics.com/c > * * > <http://www.matronics.com/contribution> > <http://www.matronics.com/contribution> > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jul 23, 2013
Subject: OSH13 RV10 Builder's Cookout
After the success of the 2012 OSH potluck dinner, I've decided to put on another cookout this year (maybe I'm just a glutton for punishment...) This year, instead of dealing with the coordination and uncertainty of a potluck style dinner, I'm thinking I'm just going to get the majority of the food myself, and rely on the donation bucket. If people want to bring some miscellaneous side dishes or desserts or beers, that's great too! The location of the cookout is going to be the RV10 HQ on 54th Street just south of Lindbergh (Oak Lane), in Camp Scholler. As for the date and time, I'm thinking Wednesday, July 31st, starting around 5:30-6, and going till 8. The night airshow/Terrafugia demo start at 8PM that same night. I'd love to hear your feed back on whether this is a great/terrible idea. Thoughts? ________________________________________________________________________________
Date: Jul 23, 2013
Subject: Re: OSH13 RV10 Builder's Cookout
Great idea Ed, thanks for stepping up to the plate! Bob On Tuesday, July 23, 2013, Ed Kranz wrote: > After the success of the 2012 OSH potluck dinner, I've decided to put on > another cookout this year (maybe I'm just a glutton for punishment...) > > This year, instead of dealing with the coordination and uncertainty of a > potluck style dinner, I'm thinking I'm just going to get the majority of > the food myself, and rely on the donation bucket. If people want to bring > some miscellaneous side dishes or desserts or beers, that's great too! > > The location of the cookout is going to be the RV10 HQ on 54th Street just > south of Lindbergh (Oak Lane), in Camp Scholler. > > As for the date and time, I'm thinking Wednesday, July 31st, starting > around 5:30-6, and going till 8. The night airshow/Terrafugia demo start at > 8PM that same night. > > > I'd love to hear your feed back on whether this is a great/terrible idea. > Thoughts? > > * > > * > > ________________________________________________________________________________
Subject: RV10 CFI
Date: Jul 23, 2013
Wondering if there will be any CFI RV10 owners able to do 1 Hr. of dual while you are here at OSH? I am ready to take my completed 10 on it=92s maiden flight and my insurer is requiring 1 hr. in make and model. I am located at CLI 1 hr. north of OSH. You can reply to this email or contact me directly at 920-213-9307. Tom Ganster, 40778, awaiting my airworthiness inspection ________________________________________________________________________________
Date: Jul 23, 2013
Great idea. My wife and I would love to came. If we can bring something, let us know. If you want to buy everything (a big job but probably the best way to go), may I suggest that you prepare a tentative menu and then ask people to reserve a place thru a simple email and then after ascertaining the cost, to sell tickets for food and separate tickets for alcohol or beer. If you need tickets, I have a new roll that I would be delighted to donate. :D -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405215#405215 ________________________________________________________________________________
Date: Jul 23, 2013
I have a very lightly finished plane 1720# and need about 40-50# in the aft baggage area (removed for overnighters with baggage) when flying with one or two folks up front. I use two "billets" of lead shot placed in a 2" ABS pipe. This way the lead is isolated and clean. The two "billets" take up almost no space. I secure them with lots of bungees and have tie-down eyes also that I got from a trashed Cessna. The Cessna tie-downs are really neat and they are removable - they screw into a #10 nut plate. For the nay sayers on baggage tie downs...........Why wear a seat belt if the crap in the back is going to bash your head and back in the event of a crash? -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405216#405216 ________________________________________________________________________________
Date: Jul 23, 2013
Warning, thread drift... Why not carry 5 or more gallons of water in collapsible plastic jugs? If you have to fly somewhere solo to pick up a full load, it's easy to pour out the water; not so great to pour out lead shot! Btw , I do not consider 1720 lbs to be particularly light for a ten. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405217#405217 ________________________________________________________________________________
Date: Jul 24, 2013
Amy and I would love to come; we will follow this thread to see what we can bring Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405225#405225 ________________________________________________________________________________
Date: Jul 24, 2013
Well since I started this with saying I removed my tie downs, I feel I need to at least add one response to the shots (pun intended) being fired. The baggage compartment of the -10 is somewhat isolated from the passenger compartment by the rear seats, so movement of items is restricted in flight. I understand the point that if you have a sudden stop that everything loose is moving forward. But on the other hand, I do not fly around ever with two 20 pound slugs in my baggage compartment.....I just land the airplane when I am light...don't need any weight in the back to help and pull the flaps up just a little if I am extremely light (rear seats removed). My CG is aft of Vans due to a larger battery and O2 in the back. But lets be clear, I am not recommending anyone remove their tie downs or not put them in. It only takes 8 screws for me to put mine back in and if I ever think I need them, I will do that. If I ever go cargo mode again (rear seats removed), I am sure to put them back in to hold down what I am carrying. I have thought about putting a net between the rear seats and the baggage compartment....but then the kids would have trouble reaching back to get a snack during the flight. If we ever come to a sudden stop, I am sure I will be hit in the back of the head with an I-pad or two....plus whatever they have not eaten yet. :) Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Tuesday, July 23, 2013 9:40 PM Subject: RV10-List: Re: Baggage Tie Downs I have a very lightly finished plane 1720# and need about 40-50# in the aft baggage area (removed for overnighters with baggage) when flying with one or two folks up front. I use two "billets" of lead shot placed in a 2" ABS pipe. This way the lead is isolated and clean. The two "billets" take up almost no space. I secure them with lots of bungees and have tie-down eyes also that I got from a trashed Cessna. The Cessna tie-downs are really neat and they are removable - they screw into a #10 nut plate. For the nay sayers on baggage tie downs...........Why wear a seat belt if the crap in the back is going to bash your head and back in the event of a crash? -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405216#405216 ________________________________________________________________________________
Date: Jul 24, 2013
Based on feedback I've gotten from people, we are going to make the cookout more of a potluck style dinner, with the option to bring cash instead of food. So, like last year, I've created a sign up sheet at: *http://www.perfectpotluck.com/meals.php?t=BXYH0155* Please sign up if you're planning on attending! We're not going to turn anyone away, but it's helpful to have some rough idea of who's bringing what! See you all soon! On Wed, Jul 24, 2013 at 8:21 AM, Barry wrote: > > Amy and I would love to come; we will follow this thread to see what we > can bring > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405225#405225 > > ________________________________________________________________________________
Date: Jul 24, 2013
Tony bringing brisket, Ed bring pulled pork, you guys are making it tough for somebody that can't make it. This will be the first OSH in ten years that I've missed. What I'm going to miss the most is the comradeliness of the RV-10 community. But I will be there next with my Rv-10. I better be out of phase 1 by then. :^) ________________________________________________________________________________
Date: Jul 24, 2013
Ed, I love the idea and am happy to contribute in whatever manner is helpful. I have a party of four. We can bring contributions of cash or goods, whichever is best for you. We are camping the HQ, so we can finalize things this weekend. Eric -------- Eric Ison RV 10 #40764 N984ED (reserved) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405241#405241 ________________________________________________________________________________
Date: Jul 24, 2013
Ed Great Idea Since I am not camping at Scholer, I will love to attend but contribute fin ancially. Larry Klein N420LK -----Original Message----- From: Ed Kranz <ed.kranz(at)gmail.com> Sent: Wed, Jul 24, 2013 3:29 pm Subject: Re: RV10-List: Re: OSH13 RV10 Builder's Cookout Based on feedback I've gotten from people, we are going to make the cookout more of a potluck style dinner, with the option to bring cash instead of f ood. So, like last year, I've created a sign up sheet at: http://www.perfectpotluck.com/meals.php?t=BXYH0155 Please sign up if you're planning on attending! We're not going to turn any one away, but it's helpful to have some rough idea of who's bringing what! See you all soon! On Wed, Jul 24, 2013 at 8:21 AM, Barry wrote: Amy and I would love to come; we will follow this thread to see what we can bring Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405225#405225 arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com le, List Admin. ="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Aerosport Products at Oshkosh
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Jul 24, 2013
I have had many calls and emails about if we will be at Oshkosh. I will be there Sunday 7-28 thru 8-1. No booth but should be at the Airplane in HB parking from 9-1 all days. Also we will be hanging at the RV-10 HQ. If you need to get a hold of me call this # 614-834-8659 and they will track me down. Geoff -------- Geoff Combs RV-10 QB N829GW Flying 395 hrs 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405261#405261 ________________________________________________________________________________
Date: Jul 24, 2013
what's your N number?? > Subject: RV10-List: Aerosport Products at Oshkosh > From: g.combs(at)aerosportmodeling.com > Date: Wed=2C 24 Jul 2013 12:47:51 -0700 > To: rv10-list(at)matronics.com > com> > > I have had many calls and emails about if we will be at Oshkosh. > I will be there Sunday 7-28 thru 8-1. No booth but should be at the Airpl ane > in HB parking from 9-1 all days. Also we will be hanging at the RV-10 HQ. > If you need to get a hold of me call this # 614-834-8659 and they will tr ack > me down. > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying 395 hrs > 40033 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405261#405261 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jul 24, 2013
N829GW Geoff Combs _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Wednesday, July 24, 2013 5:06 PM Subject: RE: RV10-List: Aerosport Products at Oshkosh what's your N number?? > Subject: RV10-List: Aerosport Products at Oshkosh > From: g.combs(at)aerosportmodeling.com > Date: Wed, 24 Jul 2013 12:47:51 -0700 > To: rv10-list(at)matronics.com > > > I have had many calls and emails about if we will be at Oshkosh. > I will be there Sunday 7-28 thru 8-1. No booth but should be at the Airplane > in HB parking from 9-1 all days. Also we will be hanging at the RV-10 HQ. > If you need to get a hold of me call this # 614-834-8659 and they will track > me down. > > Geoff > > -------- > Geoff Combs > RV-10 QB N829GW > Flying 395 hrs > 40033 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405261#405261 > > > > > > > > > ________________________________________________________________________________
Subject: Re: Aerosport Products at Oshkosh
Date: Jul 24, 2013
I'll also be there in N801VR showing a lot of Aerosport Products, PlaneAroun d, and Garmin stuff. Come try closing my doors on the RV10. Sent from my iPhone On Jul 24, 2013, at 14:08, "Geoff Combs" wro te: > N829GW > > Geoff Combs > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Danny Riggs > Sent: Wednesday, July 24, 2013 5:06 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Aerosport Products at Oshkosh > > what's your N number?? > > > Subject: RV10-List: Aerosport Products at Oshkosh > > From: g.combs(at)aerosportmodeling.com > > Date: Wed, 24 Jul 2013 12:47:51 -0700 > > To: rv10-list(at)matronics.com > > .com> > > > > I have had many calls and emails about if we will be at Oshkosh. > > I will be there Sunday 7-28 thru 8-1. No booth but should be at the Airp lane > > in HB parking from 9-1 all days. Also we will be hanging at the RV-10 HQ . > > If you need to get a hold of me call this # 614-834-8659 and they will t rack > > me down. > > > > Geoff > > > > -------- > > Geoff Combs > > RV-10 QB N829GW > > Flying 395 hrs > > 40033 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=405261#405261 > > > > > > > > > > > > > > > > > > > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics .com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jul 24, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
Subject: Enlarging Holes for Conduit in Fuselage
I would like to run a 1" conduit down each side of the fuselage rear of the main spar to the tail cone. Both F1034A and F1005A have 5/8 " holes on either end for wiring in this area. I would have to enlarge those holes to 1 1/4 " to accommodate the conduit. However I am not sure what that would do to the integrity of the airplane. Looking in the archives, others seem to have done this. What type of assurance was found that this would not weaken the airplane? Dave -- ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Fuselage ________________________________________________________________________________
Subject: Re: Enlarging Holes for Conduit in Fuselage
Date: Jul 24, 2013
You have a couple options without having such a large hole. Why not run multiple smaller conduit lines, or use grommets in the existing holes and not use conduit at all. Additionally you can run lines under the rear seat and baggage compartment floors. -------- Dave Moore RV-6 flying RV-10 QB - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405280#405280 ________________________________________________________________________________
Date: Jul 24, 2013
If integrity is a concern, why noy add doblers around the enlarged holes on the bulkhead? Cheers, Jason On Jul 24, 2013 4:21 PM, "Dave Fritzsche (Building)" wrote: > dfritz(at)bpgsim.com> > > I would like to run a 1" conduit down each side of the fuselage rear of > the main spar to the tail cone. Both F1034A and F1005A have 5/8 " holes on > either end for wiring in this area. I would have to enlarge those holes to > 1 1/4 " to accommodate the conduit. However I am not sure what that would > do to the integrity of the airplane. Looking in the archives, others seem > to have done this. What type of assurance was found that this would not > weaken the airplane? > > Dave > > -- > ~~~~~~~~~~~~~~ > Dave Fritzsche > 40813 > Puyallup, WA > Fuselage > > ________________________________________________________________________________
Subject: Re: Baggage Tie Downs
Date: Jul 25, 2013
I bought the tie downs that Van sells. I like them a lot, but really don't use them too much. I also bought some baggage netting for Aircraft Spruce. I also don't use it much. As far as weight, lead shot costs $3 a pound, while pennies cost $2 a pound. Water can leak or freeze. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405305#405305 ________________________________________________________________________________
Date: Jul 25, 2013
I did enlarge the holes in my aircraft to run the conduit. I was told by one of the staff at Vans that it would not compromise the integrity of the air frame. I did do the minimum of enlargement so that I had to really pull the conduit through. Also, run an extra string through there if you need to pull another wire through there in the future. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405309#405309 ________________________________________________________________________________
Subject: Test Fit on the Panel
Date: Jul 25, 2013
... this is fun Jeff Carpenter 40304 ________________________________________________________________________________
Date: Jul 25, 2013
Subject: Re: Test Fit on the Panel
Glad you continued to fight through life's trials and tribulations to keep going on the 10... Soon you'll be part of the growing family. Don McDonald ________________________________ From: Jeff Carpenter <jeff(at)westcottpress.com> Sent: Thursday, July 25, 2013 3:46 PM Subject: RV10-List: Test Fit on the Panel ... this is fun Jeff Carpenter 40304 ________________________________________________________________________________
Date: Jul 25, 2013
Jeff Yes, it only gets more fun, although the wiring wasn't all that much fun, tu rning it all on and seeing it work.. Worth every hour to that point. First flight will here sooner than you know. Still remember that day 5 years ago we saw the project and asked if building the plane would be easy.. Glad to see that you have stuck through it during the tough times. Look forward to seeing you in Chino. Call me when the wings need to go on, I 'll fly out and get it done! Pascal On Jul 25, 2013, at 6:41 PM, "Don McDonald" wro te: > Glad you continued to fight through life's trials and tribulations to keep going on the 10... Soon you'll be part of the growing family. > Don McDonald > > > From: Jeff Carpenter <jeff(at)westcottpress.com> > To: rv10-list(at)matronics.com > Sent: Thursday, July 25, 2013 3:46 PM > Subject: RV10-List: Test Fit on the Panel > > > > ... this is fun > > Jeff Carpenter > 40304 > > > > ________________________________________________________________________________
Subject: Garmin Unveils GTR 200
Date: Jul 26, 2013
http://www.flyingmag.com/avionics-gear/instrumentaccessories/garmin-unveils -gtr-200-comm-radio That's pretty inexpensive for a quality Garmin Comm. Robin ________________________________________________________________________________
Subject: Re: Insurance
Date: Jul 26, 2013
There is still a certain amount of seat of the pants guess work in aviation underwritting. This year, the company that covered me last year wanted a small increase, despite more time in type (and no claims). But a second company quoted less. Hard to figure. But as long as I can get multiple quotes at least there's competition for my business. The reason the "pool" idea doesn't work: everyone thinks they should pay less than the other guy. And with good reason. Shouldn't the two seat guys, with 1/3 the passengers and half the hull values, pay half or less compared to the RV-10 guys? And should pilots with 1000 hours pay the same as those with 100? etc. Something no one has mentioned (and the companies won't say much about it either) is age. At some point - 60, 65, 70,... - they start worrying about a deterioration in abilities and charge more. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405394#405394 ________________________________________________________________________________
Date: Jul 26, 2013
Yes exactly. Also, the last time it came up, my thought was "there are just too many others I've met or heard about that I don't want in my risk pool." And I'm sure there are some who may feel that way about me. Personally, I'd never want to allow automotive engine conversions in my pool, for instance. But, some of them feel that way about "lycosaurs". And of course many of us have met "that guy" who we know is gonna kill himself and/or passengers some day.....but in my case, it only took a few months from when I knew it, until it happened at one time. So no, I probably wouldn't join a small risk pool that was built in such a way. I think if we all focused on picking the best risk cases to have in the pool, it could save a lot of money, but to narrow it down to those we "trust" the most, would turn it into a much smaller pool. Tim On Jul 26, 2013, at 11:00 PM, "Bob Turner" wrote: > > There is still a certain amount of seat of the pants guess work in aviation underwritting. This year, the company that covered me last year wanted a small increase, despite more time in type (and no claims). But a second company quoted less. Hard to figure. But as long as I can get multiple quotes at least there's competition for my business. > > The reason the "pool" idea doesn't work: everyone thinks they should pay less than the other guy. And with good reason. Shouldn't the two seat guys, with 1/3 the passengers and half the hull values, pay half or less compared to the RV-10 guys? And should pilots with 1000 hours pay the same as those with 100? etc. > > Something no one has mentioned (and the companies won't say much about it either) is age. At some point - 60, 65, 70,... - they start worrying about a deterioration in abilities and charge more. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405394#405394 > > > > > > > > > > ________________________________________________________________________________
Subject: Fuel system revisited
Date: Jul 27, 2013
Fellow RV-10 builders and aviators Following some recent considerations about the fuel system to adopt in the -10 I am building, I am now thinking in putting the "Red cube" flow meter in the engine compartment, near the mechanical pump, and the filters in the wings roots, leaving only the fuel pump "buried" in the tunnel. What do you think about the "red cube" near the mechanical pump? And what about putting the filters (2) in both wing roots? Do you recommend putting filters or gascolators here? Best regards Carlos ________________________________________________________________________________
Date: Jul 27, 2013
Subject: Re: Fuel system revisited
Filters in wings, yes....cube by mechanical, not so good....install it between the servo and spider. Don McDonald ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jul 27, 2013
There are a lot of options. I have the filter, fuel pump and flow sender in the tunnel per plans and have no issues. The fuel totalizer is always within half a gallon when I fill up. That said, the most accurate place to put the red cube is between the throttle body and the spider (I did that on my 8A). So if you go away from plans you may as well put it in the best spot. Do not however hard mount it to the engine. For the 8A I enclosed the flow sender in a large fire sleeve. I figured this to be my back up plan for the 10 if the red cube did not work in the tunnel. I do not find it difficult to service the filter with it mounted in the stock position in the tunnel. On annual you are taking the seats out and tunnel cover off anyway - that's 90% of the effort to get to the fuel filter. Filers only - there is no value of installing a gascolator in a low wing airplane other than the inherent filter element in the gascolator. Water collects in a gascolator when it is mounted in the lowest spot of the fuel system. With the aircraft parked water slowly gravity drains to that low point. The gascolator provides no mechanical water separation function with flowing fuel. For a low wing airplane you cannot mount the gascolator such that the inlet is below the bottom of the fuel tank. The fuel tank sump is the means to detect and remove water from the tank. Carl 120 hours From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Saturday, July 27, 2013 8:47 AM Subject: RV10-List: Fuel system revisited Fellow RV-10 builders and aviators Following some recent considerations about the fuel system to adopt in the -10 I am building, I am now thinking in putting the "Red cube" flow meter in the engine compartment, near the mechanical pump, and the filters in the wings roots, leaving only the fuel pump "buried" in the tunnel. What do you think about the "red cube" near the mechanical pump? And what about putting the filters (2) in both wing roots? Do you recommend putting filters or gascolators here? Best regards Carlos ________________________________________________________________________________
Date: Jul 27, 2013
I give a 3rd vote for the cube just before spider. Keep it away from pumps w hen possible. They, sometimes, seem to be affected by the pulsations of the p umps. Sent from my iPhone On Jul 27, 2013, at 9:46 AM, "Carl Froehlich" w rote: > There are a lot of options. I have the filter, fuel pump and flow sender i n the tunnel per plans and have no issues. The fuel totalizer is always wit hin half a gallon when I fill up. That said, the most accurate place to put the red cube is between the throttle body and the spider (I did that on my 8 A). So if you go away from plans you may as well put it in the best spot. D o not however hard mount it to the engine. For the 8A I enclosed the flow s ender in a large fire sleeve. I figured this to be my back up plan for the 1 0 if the red cube did not work in the tunnel. > > I do not find it difficult to service the filter with it mounted in the st ock position in the tunnel. On annual you are taking the seats out and tunn el cover off anyway - that's 90% of the effort to get to the fuel filter. > > Filers only - there is no value of installing a gascolator in a low wing a irplane other than the inherent filter element in the gascolator. Water col lects in a gascolator when it is mounted in the lowest spot of the fuel syst em. With the aircraft parked water slowly gravity drains to that low point. The gascolator provides no mechanical water separation function with flowi ng fuel. For a low wing airplane you cannot mount the gascolator such that t he inlet is below the bottom of the fuel tank. The fuel tank sump is the me ans to detect and remove water from the tank. > > Carl > 120 hours > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Carlos Trigo > Sent: Saturday, July 27, 2013 8:47 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fuel system revisited > > Fellow RV-10 builders and aviators > > Following some recent considerations about the fuel system to adopt in the -10 I am building, I am now thinking in putting the =9CRed cube =9D flow meter in the engine compartment, near the mechanical pump, and the f ilters in the wings roots, leaving only the fuel pump =9Cburied=9D in the tunnel. > > What do you think about the =9Cred cube=9D near the mechanical pump? > > And what about putting the filters (2) in both wing roots? Do you recommen d putting filters or gascolators here? > > Best regards > Carlos > > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jul 27, 2013
Subject: Insurance
Regarding self insurance: If (IF) you could get 6000 RV owners all moving in the same direction, that's 500 applications per month to collect, input, store, verify, etc...geez, I hate just filling out my own once a year! Sounds like a LOT of work, a lot of individuals to corral, checks to process, files to keep, etc. Plus claims, accounts, IT--the list goes on. It'd be at least one full time job. My broker has several long term and well-trained people on staff. I just don't think it would be a simple, or even worthwhile, proposition. But--has anyone approached their broker about a group buy? Maybe we could get 20 or 30 buyers to pull the trigger all at once. Of course the brokers pocket some of the premium--that's how they make their living--but if a group could make the broker's job a little easier some how, maybe they'd lower their cut enough to make a difference. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Jul 27, 2013
Q2hlY2sgdGhlIEFyY2hpdmVzIGZvciBwaG90b3Mgb2YgU2VhbuKAmXMgUmVkIEN1YmUgcGxhY2Vt ZW50IGJldHdlZW4gdGhlIFNlcnZvICYgU3BpZGVyLg0KDQpSb2Jpbg0KDQpGcm9tOiBvd25lci1y djEwLWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2Vy dmVyQG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBUaW0gRmFycmVsbA0KU2VudDogU2F0dXJk YXksIEp1bHkgMjcsIDIwMTMgNzoyNiBBTQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQpT dWJqZWN0OiBSZTogUlYxMC1MaXN0OiBGdWVsIHN5c3RlbSByZXZpc2l0ZWQNCg0KSSBnaXZlIGEg M3JkIHZvdGUgZm9yIHRoZSBjdWJlIGp1c3QgYmVmb3JlICBzcGlkZXIuIEtlZXAgaXQgYXdheSBm cm9tIHB1bXBzIHdoZW4gcG9zc2libGUuIFRoZXksIHNvbWV0aW1lcywgc2VlbSB0byBiZSBhZmZl Y3RlZCBieSB0aGUgcHVsc2F0aW9ucyBvZiB0aGUgcHVtcHMuDQoNClNlbnQgZnJvbSBteSBpUGhv bmUNCg0KT24gSnVsIDI3LCAyMDEzLCBhdCA5OjQ2IEFNLCAiQ2FybCBGcm9laGxpY2giIDxjYXJs LmZyb2VobGljaEB2ZXJpem9uLm5ldDxtYWlsdG86Y2FybC5mcm9laGxpY2hAdmVyaXpvbi5uZXQ+ PiB3cm90ZToNClRoZXJlIGFyZSBhIGxvdCBvZiBvcHRpb25zLiAgSSBoYXZlIHRoZSBmaWx0ZXIs IGZ1ZWwgcHVtcCBhbmQgZmxvdyBzZW5kZXIgaW4gdGhlIHR1bm5lbCBwZXIgcGxhbnMgYW5kIGhh dmUgbm8gaXNzdWVzLiAgVGhlIGZ1ZWwgdG90YWxpemVyIGlzIGFsd2F5cyB3aXRoaW4gaGFsZiBh IGdhbGxvbiB3aGVuIEkgZmlsbCB1cC4gIFRoYXQgc2FpZCwgdGhlIG1vc3QgYWNjdXJhdGUgcGxh Y2UgdG8gcHV0IHRoZSByZWQgY3ViZSBpcyBiZXR3ZWVuIHRoZSB0aHJvdHRsZSBib2R5IGFuZCB0 aGUgc3BpZGVyIChJIGRpZCB0aGF0IG9uIG15IDhBKS4gIFNvIGlmIHlvdSBnbyBhd2F5IGZyb20g cGxhbnMgeW91IG1heSBhcyB3ZWxsIHB1dCBpdCBpbiB0aGUgYmVzdCBzcG90LiAgRG8gbm90IGhv d2V2ZXIgaGFyZCBtb3VudCBpdCB0byB0aGUgZW5naW5lLiAgRm9yIHRoZSA4QSBJIGVuY2xvc2Vk IHRoZSBmbG93IHNlbmRlciBpbiBhIGxhcmdlIGZpcmUgc2xlZXZlLiAgSSBmaWd1cmVkIHRoaXMg dG8gYmUgbXkgYmFjayB1cCBwbGFuIGZvciB0aGUgMTAgaWYgdGhlIHJlZCBjdWJlIGRpZCBub3Qg d29yayBpbiB0aGUgdHVubmVsLg0KDQpJIGRvIG5vdCBmaW5kIGl0IGRpZmZpY3VsdCB0byBzZXJ2 aWNlIHRoZSBmaWx0ZXIgd2l0aCBpdCBtb3VudGVkIGluIHRoZSBzdG9jayBwb3NpdGlvbiBpbiB0 aGUgdHVubmVsLiAgT24gYW5udWFsIHlvdSBhcmUgdGFraW5nIHRoZSBzZWF0cyBvdXQgYW5kIHR1 bm5lbCBjb3ZlciBvZmYgYW55d2F5IC0gdGhhdCdzIDkwJSBvZiB0aGUgZWZmb3J0IHRvIGdldCB0 byB0aGUgZnVlbCBmaWx0ZXIuDQoNCkZpbGVycyBvbmx5IC0gdGhlcmUgaXMgbm8gdmFsdWUgb2Yg aW5zdGFsbGluZyBhIGdhc2NvbGF0b3IgaW4gYSBsb3cgd2luZyBhaXJwbGFuZSBvdGhlciB0aGFu IHRoZSBpbmhlcmVudCBmaWx0ZXIgZWxlbWVudCBpbiB0aGUgZ2FzY29sYXRvci4gIFdhdGVyIGNv bGxlY3RzIGluIGEgZ2FzY29sYXRvciB3aGVuIGl0IGlzIG1vdW50ZWQgaW4gdGhlIGxvd2VzdCBz cG90IG9mIHRoZSBmdWVsIHN5c3RlbS4gIFdpdGggdGhlIGFpcmNyYWZ0IHBhcmtlZCB3YXRlciBz bG93bHkgZ3Jhdml0eSBkcmFpbnMgdG8gdGhhdCBsb3cgcG9pbnQuICBUaGUgZ2FzY29sYXRvciBw cm92aWRlcyBubyBtZWNoYW5pY2FsIHdhdGVyIHNlcGFyYXRpb24gZnVuY3Rpb24gd2l0aCBmbG93 aW5nIGZ1ZWwuICBGb3IgYSBsb3cgd2luZyBhaXJwbGFuZSB5b3UgY2Fubm90IG1vdW50IHRoZSBn YXNjb2xhdG9yIHN1Y2ggdGhhdCB0aGUgaW5sZXQgaXMgYmVsb3cgdGhlIGJvdHRvbSBvZiB0aGUg ZnVlbCB0YW5rLiAgVGhlIGZ1ZWwgdGFuayBzdW1wIGlzIHRoZSBtZWFucyB0byBkZXRlY3QgYW5k IHJlbW92ZSB3YXRlciBmcm9tIHRoZSB0YW5rLg0KDQpDYXJsDQoxMjAgaG91cnMNCg0KRnJvbTog b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tPG1haWx0bzpvd25lci1ydjEwLWxp c3Qtc2VydmVyQG1hdHJvbmljcy5jb20+IFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBt YXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgQ2FybG9zIFRyaWdvDQpTZW50OiBTYXR1cmRheSwg SnVseSAyNywgMjAxMyA4OjQ3IEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb208bWFpbHRv OnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tPg0KU3ViamVjdDogUlYxMC1MaXN0OiBGdWVsIHN5c3Rl bSByZXZpc2l0ZWQNCg0KRmVsbG93IFJWLTEwIGJ1aWxkZXJzIGFuZCBhdmlhdG9ycw0KDQpGb2xs b3dpbmcgc29tZSByZWNlbnQgY29uc2lkZXJhdGlvbnMgYWJvdXQgdGhlIGZ1ZWwgc3lzdGVtIHRv IGFkb3B0IGluIHRoZSAtMTAgSSBhbSBidWlsZGluZywgSSBhbSBub3cgdGhpbmtpbmcgaW4gcHV0 dGluZyB0aGUg4oCcUmVkIGN1YmXigJ0gZmxvdyBtZXRlciBpbiB0aGUgZW5naW5lIGNvbXBhcnRt ZW50LCBuZWFyIHRoZSBtZWNoYW5pY2FsIHB1bXAsIGFuZCB0aGUgZmlsdGVycyBpbiB0aGUgd2lu Z3Mgcm9vdHMsIGxlYXZpbmcgb25seSB0aGUgZnVlbCBwdW1wIOKAnGJ1cmllZOKAnSBpbiB0aGUg dHVubmVsLg0KDQpXaGF0IGRvIHlvdSB0aGluayBhYm91dCB0aGUg4oCccmVkIGN1YmXigJ0gbmVh ciB0aGUgbWVjaGFuaWNhbCBwdW1wPw0KDQpBbmQgd2hhdCBhYm91dCBwdXR0aW5nIHRoZSBmaWx0 ZXJzICgyKSBpbiBib3RoIHdpbmcgcm9vdHM/IERvIHlvdSByZWNvbW1lbmQgcHV0dGluZyBmaWx0 ZXJzIG9yIGdhc2NvbGF0b3JzIGhlcmU/DQoNCkJlc3QgcmVnYXJkcw0KQ2FybG9zDQoNCg0KDQoN Cg0KDQoNCg0KaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0K aHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQoNCmh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9j b250cmlidXRpb24NCg0KDQoNCg0KDQoNCg0KPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCg0KOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQo9PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQpjcy5jb20NCg0KPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT0NCg0KbWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCg0K PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KDQoNCg0KDQoNCg0KXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cg0KXy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQoNCl8tPSBVc2Ug dGhlIE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCg0KXy09IHRo ZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQoNCl8t PSBBcmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCg0K Xy09IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCg0KXy09DQoNCl8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KDQpfLT0NCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQoNCl8tPSBT YW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KDQpf LT0NCg0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KDQpfLT0NCg0KXy09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT0NCg0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KDQpf LT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KDQpfLT0gICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQoNCl8tPSAgIC0t PiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQoNCl8tPT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoNCg0KDQpf X19fX19fX19fX19fX19fX19fX19fX19fX19fX19fXw0KTm8gdmlydXMgZm91bmQgaW4gdGhpcyBt ZXNzYWdlLg0KQ2hlY2tlZCBieSBBVkcgLSB3d3cuYXZnLmNvbTxodHRwOi8vd3d3LmF2Zy5jb20+ DQpWZXJzaW9uOiAyMDEzLjAuMzM0OSAvIFZpcnVzIERhdGFiYXNlOiAzMjA0LzY1MTYgLSBSZWxl YXNlIERhdGU6IDA3LzI0LzEzDQo ________________________________________________________________________________
Date: Jul 27, 2013
Don't forget that credit scores affect our insurance premiums too. Being debt free at 38 does have some benefits. -------- Wayne G. SB 12/01/2009-12/01/2011 TT= 103 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405473#405473 ________________________________________________________________________________
Date: Jul 28, 2013
Actually I was warned (after I was 100% debt free) that NOT having an active home loan was likely going to LOWER my credit score, and that having a track record of paying steadily on a mortgage was actually a key thing to having a high credit score. Also, I had a friend and boss who had far more money, stocks, income, and things than me that had an issue with his car insurance premium going up AFTER he paid his house off for that exact reason....there was no active loan. So to some extent, a small amount of debt can actually boost your credit rating just because there is something that is able to be tracked so that people know you're reliable. Its a very odd twist to the whole insurance/credit thing. Tim On Jul 28, 2013, at 12:53 AM, "rv10flyer" wrote: > > Don't forget that credit scores affect our insurance premiums too. Being debt free at 38 does have some benefits. > > -------- > Wayne G. > SB 12/01/2009-12/01/2011 > TT= 103 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405473#405473 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 28, 2013
Subject: Re: Want To Buy: RV-10 Kit
> Looking for an RV-10 QB kit. Prefer NE location, but any considered. > High quality non QB also considered. Any state of completion, so long as > work quality is high. > > Please email info to frankdombroski at gmail > > Thanks > Frank ________________________________________________________________________________
Date: Jul 28, 2013
Frank=0A-=0APlease find attached the EAA tech report on my completed empe nnage kit.-Since the wing kit is not fully complete it has not been inspe cted by the EAA. The wing kit is however more complete than a "Quick Build" wing kit. The winng is ready to install the pitot of your choice. The Emp is completed. This will save you hundreds of hours and over $6000 in "quick Build" charges.=0A-=0AIf you have any questions please email.=0A-=0ASt eve=0A =0A=0A________________________________=0A From: Frank Dombroski <f.d ombroski(at)yahoo.com>=0ATo: rv10-list(at)matronics.com =0ASent: Sunday, July 28, 2013 8:48 AM=0ASubject: RV10-List: Re: Want To Buy: RV-10 Kit=0A =0A=0A =0A-=0A=0ALooking for an RV-10 QB kit.- Prefer NE location, but any con sidered.- =0AHigh quality non QB also considered.- Any state of complet ion, so long =0Aas work quality is high.=0A>=0A>Please email info to frankd = ________________________________________________________________________________
Date: Jul 29, 2013
Subject: Aveo Engineering Conforma Zip Tips
To all those lucky enough to be able to attend Oshkosh,=0A-=0AHas anyone taken the opportunity to visit the Aveo tent to see their Conforma Zip Tips ?=0A-=0AWhat did you think of them?- Are they supplied ready to fit (as I suspect) or do Aveo supply a kit to fit into the kit supplied wing tips? =0ADid Aveo mention a price and proposed availability?=0A-=0AI find the c oncept fascinating even though I have the parts to install PAR36 lights int o the wings.=0A-=0AWith many thanks,=0A-=0ARodger=0AStill wondering wha t happened to the sun in a somewhat stormy Perth. ________________________________________________________________________________
Date: Jul 29, 2013
*To clarify my post... I am located in NJ, and prefer a Northeast project, with a strong preference for a complete set of kits. Many Thanks, Frank From:* Frank Dombroski *To:* rv10-list(at)matronics.com *Sent:* Sunday, July 28, 2013 8:48 AM *Subject:* RV10-List: Re: Want To Buy: RV-10 Kit Looking for an RV-10 QB kit. Prefer NE location, but any considered. High quality non QB also considered. Any state of completion, so long as work quality is high. Please email info to frankdombroski at gmail Thanks Frank ________________________________________________________________________________
Date: Jul 29, 2013
Frank; Glad to see you are getting back up and doing the RV-10 again. If I was still in Hillsborough I would help you out. Maybe next summer well come out to Somerset and see your progress. Pascal From: Frank Dombroski Sent: Monday, July 29, 2013 3:02 PM Subject: RV10-List: Re: Want To Buy: RV-10 Kit To clarify my post... I am located in NJ, and prefer a Northeast project, with a strong preference for a complete set of kits. Many Thanks, Frank From: Frank Dombroski <f.dombroski(at)yahoo.com> Sent: Sunday, July 28, 2013 8:48 AM Subject: RV10-List: Re: Want To Buy: RV-10 Kit Looking for an RV-10 QB kit. Prefer NE location, but any considered. High quality non QB also considered. Any state of completion, so long as work quality is high. Please email info to frankdombroski at gmail Thanks Frank ________________________________________________________________________________
Date: Jul 30, 2013
Subject: TD-300
Walking around OSH I noticed Continental is supposedly starting productio n on a 240HP air cooled, direct drive diesel motor (TD-300 see attachment ). Seems a bit heavy but otherwise it appears to be a potential fit for t he RV-10 airframe. I'm wondering if anyone has considered this engine for their -10. -Brian Iowa City, IA ________________________________________________________________________________
Subject: TD-300
Date: Jul 30, 2013
VGhlcmUgaXMgYSAzNTAgSHAgRGllc2VsIEF2aWF0aW9uIGVuZ2luZSB1bmRlciBkZXZlbG9wbWVu dCBieSBFUFMgdGhhdCBoYXMgc29tZSBwcm9taXNlIGJ1dCBzdGlsbCBzb21ld2hhdCBlYXJseSBz dGFnZXM6DQoNCkVQUyBhY3F1aXJlcyBDaXJydXMgU1IyMnMgZm9yIFZpc2lvbiAzNTAgZGllc2Vs IGFlcm8tZW5naW5lIGNlcnRpZmljYXRpb24NCltodHRwOi8vc2tpZXNtYWcuY29tL25ld3MvYXJ0 aWNsZV9maWxlcy82MjEyNTI4MTI5MTA4MjUuanBnXQ0KDQoNCmh0dHA6Ly9za2llc21hZy5jb20v bmV3cy9hcnRpY2xlcy8xOTUzNy1lcHMtYWNxdWlyZXMtY2lycnVzLXNyMjJzLWZvci12aXNpb24t MzUwLWRpZXNlbC1hZXJvLWVuZ2luZS0uaHRtbA0KDQpSb2Jpbg0KDQpGcm9tOiBvd25lci1ydjEw LWxpc3Qtc2VydmVyQG1hdHJvbmljcy5jb20gW21haWx0bzpvd25lci1ydjEwLWxpc3Qtc2VydmVy QG1hdHJvbmljcy5jb21dIE9uIEJlaGFsZiBPZiBic3BvbmNpbEBiZWxpbmJsYW5rLm9yZw0KU2Vu dDogVHVlc2RheSwgSnVseSAzMCwgMjAxMyA4OjUwIEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmlj cy5jb20NClN1YmplY3Q6IFJWMTAtTGlzdDogVEQtMzAwDQoNCldhbGtpbmcgYXJvdW5kIE9TSCBJ IG5vdGljZWQgQ29udGluZW50YWwgaXMgc3VwcG9zZWRseSBzdGFydGluZyBwcm9kdWN0aW9uIG9u IGEgMjQwSFAgYWlyIGNvb2xlZCwgZGlyZWN0IGRyaXZlIGRpZXNlbCBtb3RvciAoVEQtMzAwIHNl ZSBhdHRhY2htZW50KS4gIFNlZW1zIGEgYml0IGhlYXZ5IGJ1dCBvdGhlcndpc2UgaXQgYXBwZWFy cyB0byBiZSBhIHBvdGVudGlhbCBmaXQgZm9yIHRoZSBSVi0xMCBhaXJmcmFtZS4gIEknbSB3b25k ZXJpbmcgaWYgYW55b25lIGhhcyBjb25zaWRlcmVkIHRoaXMgZW5naW5lIGZvciB0aGVpciAtMTAu DQoNCg0KLUJyaWFuDQpJb3dhIENpdHksIElBDQpfX19fX19fX19fX19fX19fX19fX19fX19fX19f X19fXw0KTm8gdmlydXMgZm91bmQgaW4gdGhpcyBtZXNzYWdlLg0KQ2hlY2tlZCBieSBBVkcgLSB3 d3cuYXZnLmNvbTxodHRwOi8vd3d3LmF2Zy5jb20+DQpWZXJzaW9uOiAyMDEzLjAuMzM5MiAvIFZp cnVzIERhdGFiYXNlOiAzMjA5LzY1MzUgLSBSZWxlYXNlIERhdGU6IDA3LzMwLzEzDQo ________________________________________________________________________________
Date: Jul 30, 2013
Subject: Re: TD-300
Two reasons it won't work. "Only 230 hp", and weight is more than Cont IO-550, at least 50 lbs heavier than Lyc IO-540. W&B won't work with that much wt out front. While the hp would be sufficient, especially if it was turbo-charged, you would need the wt to be equal to or less than Lyc O-540. You would also need someone to build an engine mount for it. On Tue, Jul 30, 2013 at 8:50 AM, wrote: > Walking around OSH I noticed Continental is supposedly starting production > on a 240HP air cooled, direct drive diesel motor (TD-300 see attachment). > Seems a bit heavy but otherwise it appears to be a potential fit for the > RV-10 airframe. I'm wondering if anyone has considered this engine for > their -10. > > > -Brian > Iowa City, IA > ________________________________________________________________________________
Subject: Osh13 Builders Cookout
Date: Jul 31, 2013
Tonight is the night for the builders cookout in Camp Scholler. Make sure you sign up at http://www.perfectpotluck.com/meals.php?t=BXYH015 5 especially if your planning on bringing some food or drink to share. Hope to see you all there! ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
Right on Kelly.... but for quite a while refueling would certainly be an is sue.... who has diesel at the airport.=0A =0A=0A___________________________ _____=0A From: Kelly McMullen <apilot2(at)gmail.com>=0ATo: rv10-list@matronics .com =0ASent: Tuesday, July 30, 2013 7:51 PM=0ASubject: Re: RV10-List: TD-3 00=0A =0A=0A=0ATwo reasons it won't work. "Only 230 hp", and weight is mor e than Cont IO-550, at least 50 lbs heavier than Lyc IO-540. W&B won't work with that much wt out front.=0AWhile the hp would be sufficient, especiall y if it was turbo-charged, you would need the wt to be equal to or less tha n Lyc O-540. You would also need someone to build an engine mount for it. =0A=0A=0A=0A=0AOn Tue, Jul 30, 2013 at 8:50 AM, w rote:=0A=0AWalking around OSH I noticed Continental is supposedly starting production on a 240HP air cooled, direct drive diesel motor (TD-300 see att achment).- Seems a bit heavy but otherwise it appears to be a potential f it for the RV-10 airframe.- I'm wondering if anyone has considered this e ngine for their -10.=0A>=0A>=0A>-Brian=0A>Iowa City, IA=0A> =0A=0A=0A- ============= ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
Right on Kelly..... as usual.... but for quite a while refueling would be a definite challenge.... who has diesel at the airport.=0A =0A=0A___________ _____________________=0A From: Kelly McMullen <apilot2(at)gmail.com>=0ATo: rv1 0-list(at)matronics.com =0ASent: Tuesday, July 30, 2013 7:51 PM=0ASubject: Re: RV10-List: TD-300=0A =0A=0A=0ATwo reasons it won't work. "Only 230 hp", a nd weight is more than Cont IO-550, at least 50 lbs heavier than Lyc IO-540 . W&B won't work with that much wt out front.=0AWhile the hp would be suffi cient, especially if it was turbo-charged, you would need the wt to be equa l to or less than Lyc O-540. You would also need someone to build an engine mount for it.=0A=0A=0A=0A=0AOn Tue, Jul 30, 2013 at 8:50 AM, wrote:=0A=0AWalking around OSH I noticed Continental is suppos edly starting production on a 240HP air cooled, direct drive diesel motor ( TD-300 see attachment).- Seems a bit heavy but otherwise it appears to be a potential fit for the RV-10 airframe.- I'm wondering if anyone has con sidered this engine for their -10.=0A>=0A>=0A>-Brian=0A>Iowa City, IA=0A> ================= ________________________________________________________________________________
Subject: Re: TD-300
Date: Jul 31, 2013
It was FAA certified in April 2013. No thanks, I won't support communist China if I have a choice. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405713#405713 ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
At the airport it is called Jet A and virtually all aircraft diesel engines are designed to run on it. Yes, it has somewhat different additives, but is a real close cousin to Diesel #2. It could be a problem at airports that don't have any turbine powered customers, but a lot of crop dusters, King Airs, Caravans, TBM's etc are creating demand for jet fuel at many "small" airports. I don't see fueling as much of a limitation. Wt, Bal, and mounting are likely to be the deal killers. On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald wrote: > Right on Kelly.... but for quite a while refueling would certainly be an > issue.... who has diesel at the airport. > > > *http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/contribution" target="_blank" rel="nofollo= > * > > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: Osh13 Builders Cookout
Signed Up, will bring CASH. Thanks! John Cox On Jul 31, 2013 7:26 AM, "Ed Kranz" wrote: > Tonight is the night for the builders cookout in Camp Scholler. > > Make sure you sign up at > http://www.perfectpotluck.com/meals.php?t=BXYH0155 especially if your > planning on bringing some food or drink to share. > > Hope to see you all there! > > * > > * > > ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
-I could bewrong but the dry weight of the lyc IO-540 is something like 440lbs which wouldmake the TD-300 20lbs heavier rather than 50.And by th e time you throw in the accessories I?m guessing thatdifference narrows a bit more.Thesemotors are flying in front of 182s so it doesn't seem like they could be THAT far out in terms of W&B.I would say the biggest hurdl e would befabricating a cowling.As someone elsesaid, at least it?s a star t. -Brian -----Original Message----- From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Wednesday, July 31, 2013 10:11 AM Subject: Re: RV10-List: TD-300 At the airport it is called Jet A and virtually all aircraft diesel engin es are designed to run on it. Yes, it has somewhat different additives, b ut is a real close cousin to Diesel #2. It could be a problem at airports that don't have any turbine powered customers, but a lot of crop dusters , King Airs, Caravans, TBM's etc are creating demand for jet fuel at many "small" airports. I don't see fueling as much of a limitation. Wt, Bal, and mounting are likely to be the deal killers. On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald wrote: Right on Kelly.... but for quite a while refueling would certainly be an issue.... who has diesel at the airport. http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/cont ribution" target="_blank" rel="nofollo= get="_blank">http://www.matronics.com/Navigator?RV10-Listtp://forums.ma tronics.com_blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm -======================== ======================== ________________________________________________________________________________
Subject: Re: TD-300
Date: Jul 31, 2013
I see the power is very similar to an IO-540 at the same RPM. Anyone know why the rpm's are limited to such a low value? Too much spinning mass? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405721#405721 ________________________________________________________________________________
Subject: TD-300
Date: Jul 31, 2013
The biggest hurdle is the price tag. With the lawyers controlling what we pay for aviation related components the price of any new engine will be governed by liability cost. Carl Still dreaming of 91/96UL wide distribution to drive down fuel cost From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bsponcil(at)belinblank.org Sent: Wednesday, July 31, 2013 11:27 AM Subject: Re: RV10-List: TD-300 I could be wrong but the dry weight of the lyc IO-540 is something like 440lbs which would make the TD-300 20lbs heavier rather than 50. And by the time you throw in the accessories I?m guessing that difference narrows a bit more. These motors are flying in front of 182s so it doesn't seem like they could be THAT far out in terms of W&B. I would say the biggest hurdle would be fabricating a cowling. As someone else said, at least it?s a start. -Brian -----Original Message----- From: Kelly McMullen [mailto:apilot2(at)gmail.com] Sent: Wednesday, July 31, 2013 10:11 AM Subject: Re: RV10-List: TD-300 At the airport it is called Jet A and virtually all aircraft diesel engines are designed to run on it. Yes, it has somewhat different additives, but is a real close cousin to Diesel #2. It could be a problem at airports that don't have any turbine powered customers, but a lot of crop dusters, King Airs, Caravans, TBM's etc are creating demand for jet fuel at many "small" airports. I don't see fueling as much of a limitation. Wt, Bal, and mounting are likely to be the deal killers. On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald wrote: Right on Kelly.... but for quite a while refueling would certainly be an issue.... who has diesel at the airport. http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/contribut ion" target="_blank" rel="nofollo= get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm ce_href="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List /forums.matronics.com" target="_blank">http://forums.matronics.com ="http://www.matronics.com/contribution" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
The Lycoming Operator's Manual puts the IO540-D4A5 engine dry wt as 402 lbs, so yes the wt difference is at least 40 or more lbs. Very significant. On 7/31/2013 8:26 AM, bsponcil(at)belinblank.org wrote: > > I could be wrong but the dry weight of the lyc IO-540 is something > like 440lbs which would make the TD-300 20lbs heavier rather than > 50.And by the time you throw in the accessories I?m guessing that > difference narrows a bit more.These motors are flying in front of 182s > so it doesn't seem like they could be THAT far out in terms of W&B.I > would say the biggest hurdle would be fabricating a cowling.As someone > else said, at least it?s a start. > > > -Brian > > > -----Original Message----- > *From:* Kelly McMullen [mailto:apilot2(at)gmail.com] > *Sent:* Wednesday, July 31, 2013 10:11 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: TD-300 > > At the airport it is called Jet A and virtually all aircraft > diesel engines are designed to run on it. Yes, it has somewhat > different additives, but is a real close cousin to Diesel #2. It > could be a problem at airports that don't have any turbine powered > customers, but a lot of crop dusters, King Airs, Caravans, TBM's > etc are creating demand for jet fuel at many "small" airports. I > don't see fueling as much of a limitation. Wt, Bal, and mounting > are likely to be the deal killers. > > > On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald > > > wrote: > > Right on Kelly.... but for quite a while refueling would > certainly be an issue.... who has diesel at the airport. > > > *http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/contribution" target="_blank" rel="nofollo= > > * > > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > -- > > - sent from the microchip implanted in my forearm > > * > > ce_href="http://www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List > /forums.matronics.com" target="_blank">http://forums.matronics.com > ="http://www.matronics.com/contribution" target="_blank">http://www.matronics.com/contribution > > * > > * > > > * ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
Diesels are "torque" producers at low rpm, unlike gas engines that tend to produce more power the higher rpm you can spin them. On 7/31/2013 9:07 AM, Bob Turner wrote: > > I see the power is very similar to an IO-540 at the same RPM. > Anyone know why the rpm's are limited to such a low value? Too much spinning mass? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405721#405721 > > ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
Most diesels are limited to a low RPM because of the stresses involved with compression ignition engine. Even most truck/equipment/industrial diesels redline below 2000RPM. On Jul 31, 2013 9:10 AM, "Bob Turner" wrote: > > I see the power is very similar to an IO-540 at the same RPM. > Anyone know why the rpm's are limited to such a low value? Too much > spinning mass? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405721#405721 > > ________________________________________________________________________________
Date: Jul 31, 2013
SSB3aXNoIHdlIGhhZCBhIHdlYmNhbSAmIGRpc3BsYXkgdGhlcmUgc28gdGhvc2UgdGhhdCBjb3Vs ZCBub3QgbWFrZSBPU0ggY291bGQgYXR0ZW5kIHRoZSBjb29rb3V0IHZpcnR1YWxseS4NCg0KSGF2 ZSBhIGdyZWF0IHRpbWUsDQpSb2Jpbg0KRG8gTm90IEFyY2hpdmUNCg0KRnJvbTogb3duZXItcnYx MC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZl ckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2YgRWQgS3JhbnoNClNlbnQ6IFdlZG5lc2RheSwg SnVseSAzMSwgMjAxMyA1OjIyIEFNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1Ympl Y3Q6IFJWMTAtTGlzdDogT3NoMTMgQnVpbGRlcnMgQ29va291dA0KDQpUb25pZ2h0IGlzIHRoZSBu aWdodCBmb3IgdGhlIGJ1aWxkZXJzIGNvb2tvdXQgaW4gQ2FtcCBTY2hvbGxlci4NCg0KTWFrZSBz dXJlIHlvdSBzaWduIHVwIGF0IGh0dHA6Ly93d3cucGVyZmVjdHBvdGx1Y2suY29tL21lYWxzLnBo cD90PUJYWUgwMTU1IGVzcGVjaWFsbHkgaWYgeW91ciBwbGFubmluZyBvbiBicmluZ2luZyBzb21l IGZvb2Qgb3IgZHJpbmsgdG8gc2hhcmUuDQoNCg0KSG9wZSB0byBzZWUgeW91IGFsbCB0aGVyZSEN Cg0KDQoNCg0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZv cnVtIC0NCg0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRv IGJyb3dzZQ0KDQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1 YnNjcmlwdGlvbiwNCg0KXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dz ZSwgQ2hhdCwgRkFRLA0KDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KDQpf LT0NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1M aXN0DQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIg Rk9SVU1TIC0NCg0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhl IFdlYiBGb3J1bXMhDQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3Mu Y29tDQoNCl8tPQ0KDQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PQ0KDQpfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlv biBXZWIgU2l0ZSAtDQoNCl8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQh DQoNCl8tPSAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBB ZG1pbi4NCg0KXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24N Cg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0NCg0KDQoNCl9fX19fX19fX19fX19fX19fX19fX19fX19fX19fX19fDQpObyB2aXJ1 cyBmb3VuZCBpbiB0aGlzIG1lc3NhZ2UuDQpDaGVja2VkIGJ5IEFWRyAtIHd3dy5hdmcuY29tPGh0 dHA6Ly93d3cuYXZnLmNvbT4NClZlcnNpb246IDIwMTMuMC4zMzkyIC8gVmlydXMgRGF0YWJhc2U6 IDMyMDkvNjUzNSAtIFJlbGVhc2UgRGF0ZTogMDcvMzAvMTMNCg= ________________________________________________________________________________
Subject: Re: TD-300
Date: Jul 31, 2013
My Cummings 6.7 redlines at 3,100 Dodge Pickup. From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jason Wodack Sent: Wednesday, July 31, 2013 9:17 AM Subject: Re: RV10-List: Re: TD-300 Most diesels are limited to a low RPM because of the stresses involved with compression ignition engine. Even most truck/equipment/industrial diesels redline below 2000RPM. On Jul 31, 2013 9:10 AM, "Bob Turner" > wrote: > I see the power is very similar to an IO-540 at the same RPM. Anyone know why the rpm's are limited to such a low value? Too much spinning mass? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405721#405721 ========== arget="_blank">http://www.matronics.com/Navigator?RV10-List ========== http://forums.matronics.com ========== le, List Admin. ="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Jul 31, 2013
Subject: Re: TD-300
Sorry Jim, didn't specify. I was speaking of Heavy truck diesels, heavy equipment, and industrial engine applications. Jason On Jul 31, 2013 10:37 AM, "JimVillani" wrote: > My Cummings 6.7 redlines at 3,100 Dodge Pickup=85 **** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jason Wodack > *Sent:* Wednesday, July 31, 2013 9:17 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Re: TD-300**** > > ** ** > > Most diesels are limited to a low RPM because of the stresses involved > with compression ignition engine. Even most truck/equipment/industrial > diesels redline below 2000RPM.**** > > On Jul 31, 2013 9:10 AM, "Bob Turner" wrote:**** > > > I see the power is very similar to an IO-540 at the same RPM. > Anyone know why the rpm's are limited to such a low value? Too much > spinning mass? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405721#405721 > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > **** > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?RV10-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: Re: TD-300
Date: Jul 31, 2013
Just for fun can any of you lucky enough to be "on location" find out what p rop it was certified with? At 17:1 compression ratio a direct drive engine w ill give a prop a real hard time, which is why Hartzell developed a special o ne for the SMA engine some years ago. Lots of carbon and $$$ to match, whic h helped neither W&B nor the pocketbook. Gordon Anderson 41015 Switzerland On 31.07.2013, at 16:11, Kelly McMullen wrote: > At the airport it is called Jet A and virtually all aircraft diesel engine s are designed to run on it. Yes, it has somewhat different additives, but i s a real close cousin to Diesel #2. It could be a problem at airports that d on't have any turbine powered customers, but a lot of crop dusters, King Air s, Caravans, TBM's etc are creating demand for jet fuel at many "small" airp orts. I don't see fueling as much of a limitation. Wt, Bal, and mounting are likely to be the deal killers. > > > On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald wrote: > Right on Kelly.... but for quite a while refueling would certainly be an i ssue.... who has diesel at the airport. > > > > > > > > > > http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/contr ibution" target="_blank" rel="nofollo= > > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > -- > > - sent from the microchip implanted in my forearm > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Re: TD-300
Date: Jul 31, 2013
A composite MT prop would make up for some of the weight difference and for t he rest you might need 5 or 10 lbs in the tail I remember attending a presentation by Deltahawk maybe 5 years ago. They cl aimed that the MT prop worked with their engine where as the standard metal p rops did not. No idea if thats true or not at this point. Nikolaos Napoli On Jul 31, 2013, at 11:26 AM, bsponcil(at)belinblank.org wrote: > > I could be wrong but the dry weight of the lyc IO-540 is something like 44 0lbs which would make the TD-300 20lbs heavier rather than 50. And by the t ime you throw in the accessories I?m guessing that difference narrows a bit m ore. These motors are flying in front of 182s so it doesn't seem like they c ould be THAT far out in terms of W&B. I would say the biggest hurdle would b e fabricating a cowling. As someone else said, at least it?s a start. > > -Brian > > -----Original Message----- > From: Kelly McMullen [mailto:apilot2(at)gmail.com] > Sent: Wednesday, July 31, 2013 10:11 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: TD-300 > > At the airport it is called Jet A and virtually all aircraft diesel engine s are designed to run on it. Yes, it has somewhat different additives, but i s a real close cousin to Diesel #2. It could be a problem at airports that d on't have any turbine powered customers, but a lot of crop dusters, King Air s, Caravans, TBM's etc are creating demand for jet fuel at many "small" airp orts. I don't see fueling as much of a limitation. Wt, Bal, and mounting are likely to be the deal killers. > > > On Wed, Jul 31, 2013 at 5:52 AM, Don McDonald wrote: >> Right on Kelly.... but for quite a while refueling would certainly be an i ssue.... who has diesel at the airport. >> >> >> >> >> >> >> >> >> >> http://www.matronics.com/Navigator?RV10-="http://www.matronics.com/cont ribution" target="_blank" rel="nofollo= >> >> >> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > > -- > > - sent from the microchip implanted in my forearm > > > ce_href="http://www.matronics.com/Navigator?RV10-List" target="_blank" >http://www.matronics.com/Navigator?RV10-List > /forums.matronics.com" target="_blank">http://forums.matronics.com > ="http://www.matronics.com/contribution" target="_blank">http://www.ma tronics.com/contribution > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 02, 2013
Ed, Thank you for hosting a great party. Looking forward to next year. Bill Ziesenitz Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405807#405807 ________________________________________________________________________________
Subject: New RV (and other experimental) t-shirts!
Date: Aug 02, 2013
Hi Everyone! I wanted to introduce my new EXPERIMENTAL AVIATION T-SHIRT web store! www.iFlyShirts.com I just went live with the first 16 men's designs. Women, youth, and much more on the way soon! Follow us on Facebook and win FREE stuff! Thanks! Sean Sullivan -------- Sean Sullivan N116EX (reserved) RV10 - SB Wings, Emp Complete Builder #40919 Fort Worth, TX www.iRV10.com EAA Chapter 34 http://www.eaa34.org/index.htm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405842#405842 Attachments: http://forums.matronics.com//files/rv10_superman_mens_blk_ss_117.png ________________________________________________________________________________
Subject: Cowl flaps and Gust Locks.
Date: Aug 03, 2013
I have been suffering from high CHTs during the climb in Oklahoma's hot summer. I made a cowl flap installation that cured my high temps. I also made a simple and secure gust lock for the airplane when it is outside. Both of these ideas were copied from previous builders ideas - thanks Nick and Robin. I have supplied drawings for each for any that want to do the same. Greg... www.nwacaptain.com -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405866#405866 ________________________________________________________________________________
Date: Aug 03, 2013
Subject: Re: Cowl flaps and Gust Locks.
Greg as usual you've engineered some great mods. Well Done! Regarding the gust locks. I began with a similar installation on a single side. After a weekend at an away airport w/ gusts up to 60mph, the brace had wobbled Up so that the unkeyed end came loose and subsequently tore the bracket. I ended up putting the brace on both side, and have the safety pins in 4 points. It's deal lock solid now. Deems On Sat, Aug 3, 2013 at 10:59 AM, greghale wrote: > > I have been suffering from high CHTs during the climb in Oklahoma's hot > summer. I made a cowl flap installation that cured my high temps. > > I also made a simple and secure gust lock for the airplane when it is > outside. > > Both of these ideas were copied from previous builders ideas - thanks Nick > and Robin. I have supplied drawings for each for any that want to do the > same. > > Greg... > www.nwacaptain.com > > -------- > Greg Hale rv10 -- N210KH > www.nwacaptain.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405866#405866 > > ________________________________________________________________________________
Subject: Slick Mag AD?
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Aug 04, 2013
All, while at Oshkosh I had a conversation with the slick mag guys. Joe warned me of a service bulletin (Slick SB1-98, Lycoming SB 537) which turned into an AD that should apply to our engines IO540-D4A5 but for some reason does not explicitly list our model. Instead they make reference to a list of models and engines with fifth order balancers which the last "5" in our suffix refers to. The service bulletin calls for mandatory 250 hour inspections of impulse couplings, ultimately advising replacement of impulse coupled mags with retard breakers and slick start. So to the brain trust - what is your interpretation of this SB (a short Google search will find it)? I wonder why they continue to offer impulse coupled mags on new IO540-XXX5 engines. When I talked to Lycoming they said, "yup it looks like this applies to your engine". - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405907#405907 ________________________________________________________________________________
Subject: Re: OSH13 RV10 Builder's Cookout
Date: Aug 04, 2013
Amy and I (Peter) had a blast, we met lots of RV-10 builders and saw a few on the flightline as well. it is a great stimulance to make sure that I work every free moment on my plane. Peter Lammers RV-10, working on baffles and engine installation EFII fuel injected and electronic ignition IO 540 N469PL reserved. ________________________________________________________________________________
Subject: Re: Slick Mag AD?
Date: Aug 04, 2013
does it only apply to an impulse mag? Sent from my iPhone On Aug 4, 2013, at 11:53 AM, "jkreidler" wrote: All, while at Oshkosh I had a conversation with the slick mag guys. Joe warned me of a service bulletin (Slick SB1-98, Lycoming SB 537) which turned into an AD that should apply to our engines IO540-D4A5 but for some reason does not explicitly list our model. Instead they make reference to a list of models and engines with fifth order balancers which the last "5" in our suffix refers to. The service bulletin calls for mandatory 250 hour inspections of impulse couplings, ultimately advising replacement of impulse coupled mags with retard breakers and slick start. So to the brain trust - what is your interpretation of this SB (a short Google search will find it)? I wonder why they continue to offer impulse coupled mags on new IO540-XXX5 engines. When I talked to Lycoming they said, "yup it looks like this applies to your engine". - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405907#405907 ________________________________________________________________________________
Date: Aug 04, 2013
Yes, only impulse mags if it applies at all, I am still very curious why the D4A5 would not have been listed if it applied. At the same time I don't want an omission on their part to leave us with the same real issue even if the paperwork didn't follow. - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405923#405923 ________________________________________________________________________________
Date: Aug 04, 2013
Thanks. I just moved and my network access is limited. I can get the 10 ready for first flight or wire the new house. Fortunately for me, the engines that Vans sell all have a retard mag. Bob Sent from my iPad On Aug 4, 2013, at 4:14 PM, "jkreidler" wrote: > > Yes, only impulse mags if it applies at all, I am still very curious why the D4A5 would not have been listed if it applied. At the same time I don't want an omission on their part to leave us with the same real issue even if the paperwork didn't follow. - Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405923#405923 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2013
The way the Lycoming and Slick service bulletins are written at this time, they do not apply to the C4B5 or D4A5 engines. Given that those engines were extensively used on the Aztec and Comanche aircraft, if the bulletin was to apply to them, it would state that. Not saying you shouldn't keep an eye on the impulse coupling, but the SB names all affected aircraft. Since the engines normally used in the -10 don't come from any of those aircraft, probably does not apply. Of course many of the donor aircraft didn't have problems with Slick mags because they were originally certified with Bendix mags (which have some of their own ADs, but are generally more durable and more rebuildable than Slicks) On Sun, Aug 4, 2013 at 8:53 AM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > All, while at Oshkosh I had a conversation with the slick mag guys. Joe > warned me of a service bulletin (Slick SB1-98, Lycoming SB 537) which > turned into an AD that should apply to our engines IO540-D4A5 but for some > reason does not explicitly list our model. Instead they make reference to > a list of models and engines with fifth order balancers which the last "5" > in our suffix refers to. The service bulletin calls for mandatory 250 hour > inspections of impulse couplings, ultimately advising replacement of > impulse coupled mags with retard breakers and slick start. > > So to the brain trust - what is your interpretation of this SB (a short > Google search will find it)? I wonder why they continue to offer impulse > coupled mags on new IO540-XXX5 engines. When I talked to Lycoming they > said, "yup it looks like this applies to your engine". - Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405907#405907 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Aug 05, 2013
Kelly, can you tell me if the Aztec or Comanche came with Slick impulse mags? I think the problem might be that the D4A5 technically did not come with impulse mags. For us, Lycoming offered them as an 'upgrade', but still called the engine a D4A5. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405978#405978 ________________________________________________________________________________
Date: Aug 05, 2013
jkreidler wrote: > Kelly, can you tell me if the Aztec or Comanche came with Slick impulse mags? I think the problem might be that the D4A5 technically did not come with impulse mags. For us, Lycoming offered them as an 'upgrade', but still called the engine a D4A5. Jason, I can tell you that my C4B5 came off an Aztec and it had the Slick impulse mags on it. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405979#405979 ________________________________________________________________________________
Date: Aug 05, 2013
David, I glanced at Lycoming SSP-401 which gives the lineage of the engines. Here is how the IO-540-C4B5 plays out.... IO-540-C4B5 - Same as C1B5 but with more effective counter weights for use with Hartzell compact propeller IO-540-C1B5 - Same as O-540-A1D5 but with Bendix fuel injector O-540-A1D5 - Same as A1B5 except for Retard Breaker Magnetos O-540-A1B5 - Same as A1A5 except for short propeller governor studs and two impulse Magnetos O-540-A1A5 - Same as A1A but one fifth and one sixth order counterweights O-540-A1A - Two sixth order counterweights So from the looks of it your engine should have had retard breakers tracing back to the -A1D5 and a fifth order counterweight traced back to the A1A5... Is there a more efficient way to find out exactly what accessories were on which engines? -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405981#405981 ________________________________________________________________________________
Date: Aug 05, 2013
I don't know, Jason. I googled the sb and found this 1999 bulletin from Piper. Clear from this that the C4B5 on the Aztec was not on the list at that time. ftp://64.191.142.163/pub/piper%20SE/pa32/ServPubs/VSP-SA/VSP%20117.pdf -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=405987#405987 ________________________________________________________________________________
Date: Aug 05, 2013
The c4b5 does not have the option of impulse coupling. Look up slick magneto and engine and I believe you will not find that option. The Aztec engine I first used did not have impulse coupling 1980. When we were thinking of switching from slick start to impulse we did a intense search and that is what we found out. Impulse will work but joe at champion really advises against it. My two cents Patrick Thyssen Ps another note we just found was the k&n filter shrinks over time and needs to be replaced its not a life time filter. Sent from my iPhone On Aug 5, 2013, at 2:21 PM, "dmaib(at)me.com" wrote: > > I don't know, Jason. I googled the sb and found this 1999 bulletin from Piper. Clear from this that the C4B5 on the Aztec was not on the list at that time. > ftp://64.191.142.163/pub/piper%20SE/pa32/ServPubs/VSP-SA/VSP%20117.pdf > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405987#405987 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 05, 2013
I found the same thing this year on the filter. Mine had shrunk CONSIDERABLY. I bought a replacement, but didn't replace it yet...first I had to re-rivet in those holder tabs that keep it from moving around. Or maybe I did replace it. I can't remember right now. But, I know the new one will shrink too. Tim On 8/5/2013 2:54 PM, Patrick Thyssen wrote: > > The c4b5 does not have the option of impulse coupling. Look up slick magneto and engine and I believe you will not find that option. > The Aztec engine I first used did not have impulse coupling 1980. > When we were thinking of switching from slick start to impulse we did a intense search and that is what we found out. Impulse will work but joe at champion really advises against it. > My two cents > Patrick Thyssen > Ps another note we just found was the k&n filter shrinks over time and needs to be replaced its not a life time filter. > ________________________________________________________________________________
Date: Aug 05, 2013
No Lycoming engine came with Slick mags until Continental bought Bendix mags (long after both aircraft were out of production). It was a Textron corporate decision to change to Slick mags for everything except those for which there was not a Slick equivalent, like the dual headed single mag engines. So no table of differences between engines is going to tell you what they are currently shipped with. However, ALL new and rebuilt/overhauled engines from Lycoming will come with Slick mags with the above noted exception. Changeover was more than 20 years ago. Service bulletins and ADs are written to either be very specific about what engines or airframes, OR to say they apply to all engines with this specific appliance, batch of parts, etc. Almost all lists of parallel valve O-540 and IO-540 engines suitable for the RV-10 are models with 5 as the last digit. Only a handful of those appear on this Service Bulletin, so there is some characteristic about the specific engines they aren't telling you. I would suggest contacting both Vans and Lycoming to ask their tech support as to whether the SB applies to the D4A5 engine or not, whether installed in a Comanche or RV-10, and if so, why the Comanche as a certified aircraft is not listed on the SB. No need to ask about the C4B5 because it is an identical engine except for data plate and governor redline setting. On 8/5/2013 11:17 AM, jkreidler wrote: > > Kelly, can you tell me if the Aztec or Comanche came with Slick impulse mags? I think the problem might be that the D4A5 technically did not come with impulse mags. For us, Lycoming offered them as an 'upgrade', but still called the engine a D4A5. > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=405978#405978 > > ________________________________________________________________________________
Date: Aug 05, 2013
I don't know why an Aztec couldn't have impulse coupled engine. There are several versions of the engine that do have impulse coupling, including the C4C5D the D4A5, the D4B5, etc. Piper and other manufacturers went back and forth between impulse coupling and retard breaker starting systems quite a bit back in the sixties and 70s. Only the presence of a vibrator, the wiring and ignition switch are different. The retard breaker has had less ADs, both otherwise both are pretty equivalent for starting. On 8/5/2013 12:54 PM, Patrick Thyssen wrote: > > The c4b5 does not have the option of impulse coupling. Look up slick magneto and engine and I believe you will not find that option. > The Aztec engine I first used did not have impulse coupling 1980. > When we were thinking of switching from slick start to impulse we did a intense search and that is what we found out. Impulse will work but joe at champion really advises against it. > My two cents > Patrick Thyssen > Ps another note we just found was the k&n filter shrinks over time and needs to be replaced its not a life time filter. > > > Sent from my iPhone > > On Aug 5, 2013, at 2:21 PM, "dmaib(at)me.com" wrote: > >> >> I don't know, Jason. I googled the sb and found this 1999 bulletin from Piper. Clear from this that the C4B5 on the Aztec was not on the list at that time. >> ftp://64.191.142.163/pub/piper%20SE/pa32/ServPubs/VSP-SA/VSP%20117.pdf >> >> -------- >> David Maib >> RV-10 #40559 >> Transition Trainer >> New Smyrna Beach, FL >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=405987#405987 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Aug 05, 2013
I had the same thing with my filter. Mine shrunk and also was cutting into the fiberglass. I did replace Mine at my annual. I prosealed A .03-.04 aluminum ring in the fiberglass housing. It worked really good. Got the idea from someone else On VAF. My filter was almost a 1/3 thru the fiberglass. Here is a PDF full scale of the ring Geoff Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, August 05, 2013 4:03 PM Subject: Re: RV10-List: Re: Slick Mag AD? I found the same thing this year on the filter. Mine had shrunk CONSIDERABLY. I bought a replacement, but didn't replace it yet...first I had to re-rivet in those holder tabs that keep it from moving around. Or maybe I did replace it. I can't remember right now. But, I know the new one will shrink too. Tim On 8/5/2013 2:54 PM, Patrick Thyssen wrote: > > The c4b5 does not have the option of impulse coupling. Look up slick magneto and engine and I believe you will not find that option. > The Aztec engine I first used did not have impulse coupling 1980. > When we were thinking of switching from slick start to impulse we did a intense search and that is what we found out. Impulse will work but joe at champion really advises against it. > My two cents > Patrick Thyssen > Ps another note we just found was the k&n filter shrinks over time and needs to be replaced its not a life time filter. > ________________________________________________________________________________
Subject: K&n filter
Date: Aug 05, 2013
Her's what happened both of mine. I had two that I swapped out alternately a nd this is what happens so I have 570 hr. so it looks like 150 hr will be ti me to switch to new one. Sent from my iPhone
Subject: K&n filter
Date: Aug 05, 2013
Like dropping the family jewels in ice cold water Geoff Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen Sent: Monday, August 05, 2013 5:47 PM Subject: RV10-List: K&n filter Her's what happened both of mine. I had two that I swapped out alternately and this is what happens so I have 570 hr. so it looks like 150 hr will be time to switch to new one. ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: K&n filter
Date: Aug 05, 2013
All, I posted a couple of notes on this awhile back. This is how I solved the problem. This is a mod to the air box I did on the RV-10, and just now back fitted onto the RV-8A. Over the years with the RV-8A I've had to repair the air box and replace the filter. As you can see from the first photo, the bottom of the filter deforms (curves in). This tends to shorten the filter such that it drops out of the top and impairs the seal with the top plate. I also had to add fiberglass to the bottom of the air box as the relative motion between the bottom of the air filter the air box eroded away the fiberglass bottom. The fix was to add a .032" aluminum plate to the bottom of the air box. The plate eliminates the bottom erosion and the added brackets hold the filter shape. A side benefit is that alternate air door now sandwiches the bottom fiberglass between two piece of metal making a sturdier install. I also took the step to add proseal between the aluminum plate and the air box bottom. And a note on using a larger K&N filter for the RV-10 I found that the Van's air box can be easily modified to handle the larger K&N E-1000 filter. Photo attached. This air box is made for the James Cowl. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen Sent: Monday, August 05, 2013 5:47 PM Subject: RV10-List: K&n filter Her's what happened both of mine. I had two that I swapped out alternately and this is what happens so I have 570 hr. so it looks like 150 hr will be time to switch to new one. ________________________________________________________________________________
Date: Aug 06, 2013
Speaking of mags, did the e-mag/p-mag people have anything new concerning 6 cylinder models at Oshkosh? Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Aug 06, 2013
Subject: Re: P-Mags
How many years now have they been promising a 6 cyl version? Not to mention a replacement for the D2000/3000 series that Bendix stopped supporting. On 8/6/2013 6:36 AM, Albert Gardner wrote: > Speaking of mags, did the e-mag/p-mag people have anything new concerning 6 cylinder models at Oshkosh? > Albert Gardner > N991RV > Yuma, AZ > * * > ________________________________________________________________________________
Subject: IO-540-C4B5 Cylinders
Date: Aug 06, 2013
I'm getting ready to rebuild my engine.
July 07, 2013 - August 06, 2013
RV10-Archive.digest.vol-jl
