RV10-Archive.digest.vol-jm
August 06, 2013 - September 09, 2013
      What cylinders would you use and why?
      RV-10  #40447
      Fuselage almost done.
      http://forums.matronics.com/viewtopic.php?p=406112#406112
Date: Aug 06, 2013
Subject: Re: IO-540-C4B5 Cylinders
The choice has as much to do with where you live/base aircraft as anything else. If you are in a corrosion prone area, like coastal, near water, etc. then ECI Cerminil treated cylinders, either new or overhauled will give better service than new Lycoming, which are nitride treated. Nitride cylinders wear very well, but are very corrosion prone. If you are in dry climate you might prefer Lycoming cylinders. New or overhauled will depend on your budget. You can save about 200-300 per cyl with overhauled. On Tue, Aug 6, 2013 at 7:30 PM, mds4878 wrote: > > I'm getting ready to rebuild my engine. > What cylinders would you use and why? > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406112#406112 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Re: K&n filter
Date: Aug 06, 2013
Just back from OSH, I had my filter out to clean yesterday. Pretty dirty after only 50 hours since my last cleaning, but after 200 hrs., I did not notice any deformation. Do you follow K&N's cleaning instructions, or are there any unique environmental factors which contribute to the shrinkage? -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406116#406116 ________________________________________________________________________________
Date: Aug 07, 2013
Cleaned them just the way k&n says to. I have two of the cleaning /oil kits. Mine did not look all deformed but shrunk. My buddy here, his shrank more bottom then top by 1/2 inch. I fly off paved runway. Only thing we could come up with is, if you flooded the engine for starting it may not like 100ll Patrick Thyssen 570hr Sent from my iPad On Aug 6, 2013, at 11:36 PM, "AirMike" wrote: > > Just back from OSH, I had my filter out to clean yesterday. Pretty dirty after only 50 hours since my last cleaning, but after 200 hrs., I did not notice any deformation. Do you follow K&N's cleaning instructions, or are there any unique environmental factors which contribute to the shrinkage? > > -------- > See you OSH '13 > Q/B - flying 3 yrs. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406116#406116 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 07, 2013
Same here. Same thing happened, and I did clean the K&N way with the K&N kit. I can't say I never flooded the engine, but my guess is that this is going to be a pretty common problem for people. I'd put filter keepers on the inside of the filter to prevent it from pulling in, but then those keepers could end up lodged in the engine if they snapped off, so I don't think that's really the way to go. I also don't know if there is a shrinkage limit....like if you let it shrink and then reposition it in the FAB, maybe you'd eventually reach a point where it would remain that size and you could use it indefinitely? Or if you could get a larger one and pre-shrink it somehow? Anyway, unless something big happens I don't see it as a major issue, but it is something you should pay attention to at annual time. Tim On 8/7/2013 4:15 AM, Patrick Thyssen wrote: > > Cleaned them just the way k&n says to. I have two of the cleaning /oil kits. Mine did not look all deformed but shrunk. My buddy here, his shrank more bottom then top by 1/2 inch. I fly off paved runway. Only thing we could come up with is, if you flooded the engine for starting it may not like 100ll > Patrick Thyssen > 570hr > > > Sent from my iPad > > On Aug 6, 2013, at 11:36 PM, "AirMike" wrote: > >> >> Just back from OSH, I had my filter out to clean yesterday. Pretty dirty after only 50 hours since my last cleaning, but after 200 hrs., I did not notice any deformation. Do you follow K&N's cleaning instructions, or are there any unique environmental factors which contribute to the shrinkage? >> >> -------- >> See you OSH '13 >> Q/B - flying 3 yrs. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=406116#406116 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 07, 2013
I agree with Kelly. You can talk to 10 engine shops and get 10 different opinions. They all seem to have 1 type they won't touch for whatever reason. I personally like the steel barrel ECI Titans. If you plan to fly at least biweekly, then you should be fine with steel barrels. Otherwise, the cerminils are a good way to go. If you're doing it yourself, then the ECI's are nice because they come assembled and ready to pop in. Also, don't forget the accessories needed, like silicone valve cover gaskets, possibly new rocker arm bushings, possibly new piston pins. ECI's include new shroud tube gaskets but may not include shroud tube clips and lock washers. You may also need new shroud tubes themselves if you have an old engine. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Aug 6, 2013, at 10:57 PM, Kelly McMullen wrote: > > The choice has as much to do with where you live/base aircraft as > anything else. If you are in a corrosion prone area, like coastal, > near water, etc. then ECI Cerminil treated cylinders, either new or > overhauled will give better service than new Lycoming, which are > nitride treated. Nitride cylinders wear very well, but are very > corrosion prone. If you are in dry climate you might prefer Lycoming > cylinders. New or overhauled will depend on your budget. You can save > about 200-300 per cyl with overhauled. > > > On Tue, Aug 6, 2013 at 7:30 PM, mds4878 wrote: >> >> I'm getting ready to rebuild my engine. >> What cylinders would you use and why? >> >> -------- >> RV-10 #40447 >> Fuselage almost done. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=406112#406112 > > > > -- > > - sent from the microchip implanted in my forearm > > > > ________________________________________________________________________________
Subject: Re: C/S-13 SPINNER FOR SALE
Date: Aug 07, 2013
Make offer I might say yes if it's not to low. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406206#406206 ________________________________________________________________________________
Subject: RV-10 Flap Controller
Date: Aug 08, 2013
Bob, Sorry we didn't get away from Oshkosh with that controller that you took for us. I thought you were going to take it to the BBQ in the campground, and I wasn't able to make it by the booth later in the week. Can you remind me the price and I will do a final verification with my customer that he wants it and I will go ahead and move forward and have you ship it to me? Thanks. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 ________________________________________________________________________________
Subject: Re: RV-10 Flap Controller
Date: Aug 08, 2013
Jessie. The list is $245. I'll give you the dealer price of $210. If you have a ups account I'll ship it on that. Just send me the details and I'll put an invoice in the box for you to pay Bob Sent from my iPhone On Aug 8, 2013, at 3:02 PM, Jesse Saint wrote: > > Bob, > > Sorry we didn't get away from Oshkosh with that controller that you took for us. I thought you were going to take it to the BBQ in the campground, and I wasn't able to make it by the booth later in the week. Can you remind me the price and I will do a final verification with my customer that he wants it and I will go ahead and move forward and have you ship it to me? > > Thanks. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > > ________________________________________________________________________________
Subject: RV-10 Cleveland Wheels and Brakes for sale
Date: Aug 08, 2013
I received Cleveland wheels and brakes in my finish kit (part number 199-104). Decided to install the new Matco wheels and brakes so these are no longer needed. Brand new in the box! They are listed in Aircraft Spruce for $2,300. (Van's price was around $900). Make me an offer. Willing to sell at a deeply discounted price. Bill Ziesenitz billz(at)roadrunner.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406255#406255 ________________________________________________________________________________
From: "tom.on.the.road(at)juno.com" <tom.on.the.road(at)juno.com>
Date: Aug 09, 2013
Subject: Re: P-Mags
E-mag/P-mag had a 6 cylinder demo unit at OSH. It looks very nice, but is still several months away from production. When it comes out, I'll try to test it and post the results. FYI, it lo oks like it will be easy to install and have very nice features. Tom 970-420-1798 ____________________________________________________________ Extended Stay America Get Fantastic Amenities, low rates! Kitchen, Ample Workspace, Free WIFI http://thirdpartyoffers.juno.com/TGL3141/52053847de97d38474a93st04vuc ________________________________________________________________________________
Date: Aug 09, 2013
Subject: Re: P-Mags
It was the same demo unit they've had at OSH before with the same story - almost word for word... Bob On Friday, August 9, 2013, tom.on.the.road(at)juno.com wrote: > E-mag/P-mag had a 6 cylinder demo unit at OSH. It looks very nice, but is > still several months away from production. > > When it comes out, I'll try to test it and post the results. FYI, it > looks like it will be easy to install and have very nice features. > > Tom > > 970-420-1798 > > > ____________________________________________________________ > *Extended Stay America* > Get Fantastic Amenities, low rates! Kitchen, Ample Workspace, Free WIFI > <http://thirdpartyoffers.juno.com/TGL3142/52053847de97d38474a93st04vuc> > extendedstayamerica.com<http://thirdpartyoffers.juno.com/TGL3142/52053847de97d38474a93st04vuc> > > * > > * > > ________________________________________________________________________________
Subject: Which quick oil drain for TMX-IO-540
Date: Aug 09, 2013
Hi, could someone please let me know which quick-oil drain I need to order for the TMX-IO-540. As I understand there are different thread sizes to choose from but I am not in the hangar. Regards Michael -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406361#406361 ________________________________________________________________________________
Subject: Shout out to Dynon
Date: Aug 09, 2013
I just want to publicly thank the folks at Dynon for stepping up to the plate and upgrading the RV10 pitch servos free of charge. It is good that companies improve their products and design and a lot of times it is appropriate to charge for the upgrade. It is fantastic when they recognize a deficiency in a previously recommended product and absorb the cost of making it right. It renews my faith in them as a partner in this build process. Well done Team Dynon. Thank you for embracing the spirit of experimental aviation. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406368#406368 ________________________________________________________________________________
Subject: Re: Shout out to Dynon
Date: Aug 09, 2013
I second your comments. Their customer support is first rate. -----Original Message----- From: woxofswa Sent: Friday, August 09, 2013 12:50 PM Subject: RV10-List: Shout out to Dynon I just want to publicly thank the folks at Dynon for stepping up to the plate and upgrading the RV10 pitch servos free of charge. It is good that companies improve their products and design and a lot of times it is appropriate to charge for the upgrade. It is fantastic when they recognize a deficiency in a previously recommended product and absorb the cost of making it right. It renews my faith in them as a partner in this build process. Well done Team Dynon. Thank you for embracing the spirit of experimental aviation. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406368#406368 ________________________________________________________________________________
Date: Aug 09, 2013
To add some color to what I am talking about, they switched from the rotational arm to a "linear actuator" (horizonal slide) that is supposed to be a big improvement according to those who have made the change. http://dynonavionics.com/downloads/Installation_Guides_Autopilot/RV10_Pitch_Kit_with_LA_Instructions_Rev_E.pdf -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406379#406379 ________________________________________________________________________________
Date: Aug 09, 2013
The guys at trutrak should take a look at the design of the force multiplier arm retainer. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406396#406396 ________________________________________________________________________________
Subject: Holes in rear Center section spar, which bolts?
Date: Aug 10, 2013
Hi, I can't find in the plans which bolts to mount in the two rear holes of the center section (see picture) a nutplate is attached inside of the center section on each hole. An AN-4 would fit but I still miss the reason for having a bolt there. I didn't find anywhere in the plans what bolts to put in there. Thanks Michael -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406410#406410 Attachments: http://forums.matronics.com//files/img_0054_165.jpg ________________________________________________________________________________
Subject: Re: Holes in rear Center section spar, which bolts?
Date: Aug 10, 2013
Two AN4 bolts, shown in the plans on page 44-11, figure 2. Help hold the "upright bar". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406415#406415 ________________________________________________________________________________
Date: Aug 10, 2013
Thanks Bob, I just realized I didn't look at the revised Plan for 44-11. Mike -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406416#406416 ________________________________________________________________________________
Subject: Re: Which quick oil drain for TMX-IO-540
Date: Aug 10, 2013
I ordered a Saf-Air P5000 from ACS. Works great. It has a 1/2" NPT, like most Lycomings. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406423#406423 ________________________________________________________________________________
Subject: Stormscope
Date: Aug 11, 2013
Has anyone installed a stormscope WX 500 in an RV10? I have the Stratus 2 with foreflight but I fly in the southeast mostly and we have a real juicy atmosphere with lots of convective weather. I have a Garmin 650 which will function as a display. I think the lightening info from spherics is better than XM which is just ground strikes. Any antenna interference issues? Thanx Leon Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406474#406474 ________________________________________________________________________________
Date: Aug 11, 2013
Subject: Stormscope
CkhhZCBvbmUgaW4gbXkgTW9vbmV5CldvcmtzIG9rIGJ1dCByZW1lbWJlciBpdCBqdXN0IHNob3dz IGhpc3RvcnkKSSByZWxpZWQgbW9yZSBvbiBteSBYTSB3ZWF0aGVyCgoKU2VudCBmcm9tIG15IFZl cml6b24gV2lyZWxlc3MgNEcgTFRFIFNtYXJ0cGhvbmUKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3Nh Z2UgLS0tLS0tLS0KRnJvbTogTGVldmVyZXR0IDxMZWV2ZXJldHRAbXNuLmNvbT4gCkRhdGU6IDA4 LzExLzIwMTMgIDc6MDggUE0gIChHTVQtMDg6MDApIApUbzogcnYxMC1saXN0QG1hdHJvbmljcy5j b20gClN1YmplY3Q6IFJWMTAtTGlzdDogU3Rvcm1zY29wZSAKIAotLT4gUlYxMC1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiAiTGVldmVyZXR0IiA8TGVldmVyZXR0QG1zbi5jb20+CgpIYXMgYW55b25l IGluc3RhbGxlZCBhIHN0b3Jtc2NvcGXCoCBXWCA1MDAgaW4gYW4gUlYxMD8gSSBoYXZlIHRoZSBT dHJhdHVzIDIgd2l0aCBmb3JlZmxpZ2h0IGJ1dCBJIGZseSBpbiB0aGUgc291dGhlYXN0IG1vc3Rs eSBhbmQgd2UgaGF2ZSBhIHJlYWwganVpY3kgYXRtb3NwaGVyZSB3aXRoIGxvdHMgb2YgY29udmVj dGl2ZSB3ZWF0aGVyLiBJIGhhdmUgYSBHYXJtaW4gNjUwIHdoaWNoIHdpbGwgZnVuY3Rpb24gYXMg YSBkaXNwbGF5LiBJIHRoaW5rIHRoZSBsaWdodGVuaW5nIGluZm8gZnJvbSBzcGhlcmljcyBpcyBi ZXR0ZXIgdGhhbiBYTSB3aGljaCBpcyBqdXN0IGdyb3VuZCBzdHJpa2VzLiBBbnkgYW50ZW5uYSBp bnRlcmZlcmVuY2UgaXNzdWVzPyBUaGFueCBMZW9uCgoKCgpSZWFkIHRoaXMgdG9waWMgb25saW5l IGhlcmU6CgpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQwNjQ3 NCM0MDY0NzQKCgoKCgoKCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoCAtIFRoZSBSVjEwLUxp c3QgRW1haWwgRm9ydW0gLQpfLT0gVXNlIHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZp Z2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUgbWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3Qg VW4vU3Vic2NyaXB0aW9uLApfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJv d3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpf LT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdApf LT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT0KXy09wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIE1BVFJPTklDUyBXRUIg Rk9SVU1TIC0KXy09IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdl YiBGb3J1bXMhCl8tPQpfLT3CoMKgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20KXy09 Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtIExpc3QgQ29udHJpYnV0aW9uIFdl YiBTaXRlIC0KXy09wqAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhCl8tPcKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAg LU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLgpfLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vY29udHJpYnV0aW9uCl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09CgoKCgo ________________________________________________________________________________
Date: Aug 11, 2013
Subject: Re: Stormscope
XM weather is 5-20 min old. Stormscope shows electrical discharges happening in real time with perhaps a minute or two of stored information. Stormscope is better for staying out of bad areas up close, XM better for strategically avoiding bad area from a greater distance. I also have stormscope in my Mooney, but will not be installing more than ADS-B weather in RV-10. On 8/11/2013 9:11 PM, jim Villani wrote: > > Had one in my Mooney > Works ok but remember it just shows history > I relied more on my XM weather > > > Sent from my Verizon Wireless 4G LTE Smartphone > > > -------- Original message -------- > From: Leeverett <Leeverett(at)msn.com> > Date: 08/11/2013 7:08 PM (GMT-08:00) > To: rv10-list(at)matronics.com > Subject: RV10-List: Stormscope > > > Has anyone installed a stormscope WX 500 in an RV10? I have the > Stratus 2 with foreflight but I fly in the southeast mostly and we > have a real juicy atmosphere with lots of convective weather. I have a > Garmin 650 which will function as a display. I think the lightening > info from spherics is better than XM which is just ground strikes. Any > antenna interference issues? Thanx Leon > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406474#406474 > > > ~,gM4Gqz.'8E]t.+-fZ+`axr^jzZ(j|n)b'!j'+ry'C > { > ,x(ZP!jrrj|-&j',r5hum > 'ojj+E]t.+-08IaT1 > jgrz{Zi^&lZ+ky+k&j',r+k&j',rhB{ky.+jY^.+-i0fr((nbxm-&j',rr&*''k{w/tml ________________________________________________________________________________
Date: Aug 12, 2013
I'm swapping because I'm right at final assembly and it makes sense to upgrade now especially if they are paying for it. It would be a tough call to make if already flying with no issues. Hopefully we can get some pireps from guys who have flown both units. Who knows how long Dynon will absorb the cost. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406485#406485 ________________________________________________________________________________
Date: Aug 12, 2013
I have one for my g500,oh that's right garmin doesn't support the gx500 with the g500 even though they said they would for four years now. So I have it on the w430's. it's mounted on shelf behind the baggage wall. Antenna way back away from all others. No problem other then garmin not quite telling the truth to us. Just like last year at osh when we bought GDL 39 and they knew it would not do traffic like they said. They did not have software ready, could not get info from w430's to talk to transponder. Not until this past April. Oh and they forgot to tell every one you need to add another wire from your wass receiver to transponder. New little insert in install manual that came out in April. Even radio shop did not know. I'ld suggest you see one working with the 650 before you buy. Patrick Thyssen N15pt Sent from my iPad On Aug 11, 2013, at 9:08 PM, "Leeverett" wrote: > > Has anyone installed a stormscope WX 500 in an RV10? I have the Stratus 2 with foreflight but I fly in the southeast mostly and we have a real juicy atmosphere with lots of convective weather. I have a Garmin 650 which will function as a display. I think the lightening info from spherics is better than XM which is just ground strikes. Any antenna interference issues? Thanx Leon > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=406474#406474 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 12, 2013
History shows Dynon will do it as long as needed to fix any issues. While you're at it, power up the units and check to see if your displays are part of the Service Bulletins. Both of mine when back and are now running flawlessly, they used to reboot randomly (not in the air) when starting up. Pascal -----Original Message----- From: woxofswa Sent: Monday, August 12, 2013 12:19 AM Subject: RV10-List: Re: Shout out to Dynon I'm swapping because I'm right at final assembly and it makes sense to upgrade now especially if they are paying for it. It would be a tough call to make if already flying with no issues. Hopefully we can get some pireps from guys who have flown both units. Who knows how long Dynon will absorb the cost. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406485#406485 ________________________________________________________________________________
Date: Aug 12, 2013
Subject: Wing Root Fairing Weather Strip
I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? Thanks, -Sean #40303 ________________________________________________________________________________
Subject: Re: Wing Root Fairing Weather Strip
Date: Aug 12, 2013
If it is on top if the wings, it's not in the plans, but a little larger gap there can be a good thing, because tight tolerances can lead to scratching the paint if you aren't careful when you remove the fairing. Sent from my iPhone On Aug 12, 2013, at 12:35 PM, Sean Stephens wrote: > > I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? > > Thanks, > > -Sean #40303 > > > > ________________________________________________________________________________
Date: Aug 12, 2013
I don't see it in the plans in Section 44 for either the top or the bottom. -Sean On 8/12/13 2:39 PM, Tim Farrell wrote: > > If it is on top if the wings, it's not in the plans, but a little larger gap there can be a good thing, because tight tolerances can lead to scratching the paint if you aren't careful when you remove the fairing. > > > Sent from my iPhone > > On Aug 12, 2013, at 12:35 PM, Sean Stephens wrote: > >> >> I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> > > ________________________________________________________________________________
Date: Aug 12, 2013
No expert and no wind tunnel tests......but I am not sure a gap seal is needed there based on my dirty airplane tests. It appears the airflow is not attached there and rides up higher on the fuselage. Also, the way the walk plate attaches to the airframe my make putting a gap seal in a challenge. Also.....in order to make room you will have a smaller edge distance on the inside screws. There may be enough room there to do that....never measured. I think the intersection looked just fine once I got done. YMMV Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Monday, August 12, 2013 1:35 PM Subject: RV10-List: Wing Root Fairing Weather Strip I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? Thanks, -Sean #40303 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Aug 12, 2013
I used the same fairing strip on the leading edge of the RV-10 as listed in the plans for the RV-8 instead of the "no rubber strip, just trip to fit" RV-10 instructions. This provides a nice clean leading edge transition to the fuselage. I ran the strip from the spar forward. I just ordered the part from Van's. Remember to put a little black RTV inside the strip when you install the fairing. Once the RTV sets up it is much less likely to come loose and flop around in the wind. Carl Fixing a dragging brake problem and waiting on new brake pads. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Monday, August 12, 2013 3:52 PM Subject: Re: RV10-List: Wing Root Fairing Weather Strip I don't see it in the plans in Section 44 for either the top or the bottom. -Sean On 8/12/13 2:39 PM, Tim Farrell wrote: > > If it is on top if the wings, it's not in the plans, but a little larger gap there can be a good thing, because tight tolerances can lead to scratching the paint if you aren't careful when you remove the fairing. > > > Sent from my iPhone > > On Aug 12, 2013, at 12:35 PM, Sean Stephens wrote: > >> --> >> >> I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? >> >> Thanks, >> >> -Sean #40303 >> >> >> >> > > ________________________________________________________________________________
Subject: Filtered Airbox needed
Date: Aug 12, 2013
I was wondering if anyone has any of the below units already assembled that they would be willing to give / sell . Maybe something you set aside because you switched to another setup. I am looking at filter box/filter issues and possible solutions. (I just assumed they do not come pre-built from Van's.) Thanks Chris Lucas N919AR Top of Form Bottom of Form Top of Form O-360/540 also IO-320 with Bendix Fuel Injection Part Number = FAB-360/540 Price = $179.00 Bottom of Form Top of Form O-320 with Airflow Performance System Part Number = FAB-320 AP-1 Price = $175.00 Bottom of Form Top of Form O-360/540 with Airflow Performance System Part Number = FAB-360/540 AP Price = $179.00 Bottom of Form FAB-360/540 AP ________________________________________________________________________________
Date: Aug 12, 2013
No its not in the plans, but I did put it there top and bottom just for (looks?). I made the gap a little larger to accommodate the strip. I used this I believe <http://www.aircraftspruce.com/catalog/appages/rubberchannel.php> it is the D-channel P/N 05-00598. I used rubber cement to attach it. When I need to remove the few screws it covers it folds out of the way locally and a little dab of cement, sometime not, on it after re-assembly and it is good to go. Also I used a continuous piece all the way round which requires a little planning (have 3 arms/hands ready) when removing the fairings at conditional, but not to much of a hassle. -Chris N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Sean Stephens Sent: Monday, August 12, 2013 3:35 PM Subject: RV10-List: Wing Root Fairing Weather Strip I've seen some with weather strip between the wing root fairing and the fuselage. Is that because the gap was too big? I didn't see it called out in the plans and was just wondering. For those that used weather strip there, you have a part number? Thanks, -Sean #40303 ________________________________________________________________________________
Date: Aug 12, 2013
I have one because I'm utilizing the Show Planes cowl and air box. Contact me directly at: jdriggs49(at)msn.com and we can discuss it. Dan From: toaster73(at)embarqmail.com Subject: RV10-List: Filtered Airbox needed Date: Mon=2C 12 Aug 2013 19:20:24 -0400 I was wondering if anyone has any of the below units already assembled that they would be willing to give / sell . Maybe something you set aside becau se you switched to another setup.I am looking at filter box/filter issues a nd possible solutions. (I just assumed they do not come pre-built from Van' s.) ThanksChris LucasN919ARTop of Form Bottom of FormTop of FormO-360/540 also IO-320 with Bendix Fuel InjectionPart Number = FAB-360/540Price = $179.00 Bottom of FormTop of FormO-320 with Airflow Performance SystemPart Number = FAB-320 AP-1Price = $175.00 Bottom of FormTop of FormO-360/540 with Airflow Performance SystemPart Number = FAB-360/540 APPrice = $17 9.00 Bottom of FormFAB-360/540 AP ________________________________________________________________________________
Date: Aug 13, 2013
Subject: Webinar
Annual Condition inspection by EAA tomorrow http://tinyurl.com/lt5tw3h ________________________________________________________________________________
Subject: Re: Webinar
Date: Aug 13, 2013
Registered. Thanks Kelly! -----Original Message----- From: Kelly McMullen Sent: Tuesday, August 13, 2013 9:28 AM Subject: RV10-List: Webinar Annual Condition inspection by EAA tomorrow http://tinyurl.com/lt5tw3h ________________________________________________________________________________
Subject: door sill finishing
Date: Aug 13, 2013
I=99m looking for ideas on how to finish the lower door sill. The Vans demo plane has a piece of wood to provide a ledge to sit or step on when entering the cabin. Does anyone have some other ideas? Maybe pictures? Chris Hukill ________________________________________________________________________________
Subject: Repair paint cracking around door window opening
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Aug 13, 2013
Anyone have an idea how to repair this condition? What is the door made of,and how do I repair it? Robert Brunkenhoefer N661G KCRP Sent from my iPad ________________________________________________________________________________
Date: Aug 13, 2013
Teak with inlay. My wood working friend did it up for me. -Chris N919AR From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Tuesday, August 13, 2013 6:00 PM Subject: RV10-List: door sill finishing I=99m looking for ideas on how to finish the lower door sill. The Vans demo plane has a piece of wood to provide a ledge to sit or step on when entering the cabin. Does anyone have some other ideas? Maybe pictures? Chris Hukill ________________________________________________________________________________
Date: Aug 13, 2013
nother shot, Chris From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Tuesday, August 13, 2013 6:00 PM Subject: RV10-List: door sill finishing I=99m looking for ideas on how to finish the lower door sill. The Vans demo plane has a piece of wood to provide a ledge to sit or step on when entering the cabin. Does anyone have some other ideas? Maybe pictures? Chris Hukill ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Aug 13, 2013
Subject: Re: Repair paint cracking around door window opening
You're probably seeing the joint between the plastic window and the fiberglass door. The window is usually painted over the first 3/4" or so. Cracks in that area are very common. The best way to prevent or repair the issue is to remove the paint, then overlay a thin layer of fiberglass almost up to the edge of the window opening. That takes some bodywork and paint but on the doors it shouldn't be too big a deal. Worse is when the same thing happens around the rear windows and windshield. The repair is the same but depending on your paint scheme, the bodywork and paint may take more effort to make look right. But it's doable, and there probably isn't any rush to get it fixed. I doubt your window is in any danger of departing. If you see the window actually start to lift or move relative to the base material, then it's time to get it fixed. Hope that helps, Dave Saylor 831-750-0284 CL On Tue, Aug 13, 2013 at 5:01 PM, Robert Brunkenhoefer wrote: > > > > Anyone have an idea how to repair this condition? What is the door made > of,and how do I repair it? Robert Brunkenhoefer N661G KCRP > > Sent from my iPad > > ________________________________________________________________________________
Date: Aug 13, 2013
I agree. It's mainly a cosmetic issue. It's a fairly big job to fix on a pai nted plane, so I'd recommend leaving it alone unless, as Dave mentioned, you notice it coming loose. The cause of the problem is that the different mate rials (fiberglass door and polycarbonate window) have different expansion co efficients, so as they heat and cool, they change sizes differently and the s eam gets a crack. Same reason the Lycoming and continentals have big piston t o cylinder wall clearances and Rotax has 0.0-0.0004" clearance. Jesse Sent from my iPad On Aug 13, 2013, at 10:10 PM, Dave Saylor wrote: > You're probably seeing the joint between the plastic window and the fiberg lass door. The window is usually painted over the first 3/4" or so. Cracks in that area are very common. > > The best way to prevent or repair the issue is to remove the paint, then o verlay a thin layer of fiberglass almost up to the edge of the window openin g. That takes some bodywork and paint but on the doors it shouldn't be too b ig a deal. > > Worse is when the same thing happens around the rear windows and windshiel d. The repair is the same but depending on your paint scheme, the bodywork a nd paint may take more effort to make look right. But it's doable, and ther e probably isn't any rush to get it fixed. I doubt your window is in any da nger of departing. If you see the window actually start to lift or move rel ative to the base material, then it's time to get it fixed. > > Hope that helps, > > > Dave Saylor > 831-750-0284 CL > > > On Tue, Aug 13, 2013 at 5:01 PM, Robert Brunkenhoefer wrote: m> >> >> Anyone have an idea how to repair this condition? What is the door made o f,and how do I repair it? Robert Brunkenhoefer N661G KCRP >> >> Sent from my iPad >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 13, 2013
It is as described by Jesse. Thanks. I know what to do now. Robert Sent from my iPad On Aug 13, 2013, at 9:26 PM, Jesse Saint wrote: > I agree. It's mainly a cosmetic issue. It's a fairly big job to fix on a p ainted plane, so I'd recommend leaving it alone unless, as Dave mentioned, y ou notice it coming loose. The cause of the problem is that the different ma terials (fiberglass door and polycarbonate window) have different expansion c oefficients, so as they heat and cool, they change sizes differently and the seam gets a crack. Same reason the Lycoming and continentals have big pisto n to cylinder wall clearances and Rotax has 0.0-0.0004" clearance. > > Jesse > > Sent from my iPad > > On Aug 13, 2013, at 10:10 PM, Dave Saylor wrote: > >> You're probably seeing the joint between the plastic window and the fiber glass door. The window is usually painted over the first 3/4" or so. Crack s in that area are very common. >> >> The best way to prevent or repair the issue is to remove the paint, then o verlay a thin layer of fiberglass almost up to the edge of the window openin g. That takes some bodywork and paint but on the doors it shouldn't be too b ig a deal. >> >> Worse is when the same thing happens around the rear windows and windshie ld. The repair is the same but depending on your paint scheme, the bodywork and paint may take more effort to make look right. But it's doable, and th ere probably isn't any rush to get it fixed. I doubt your window is in any d anger of departing. If you see the window actually start to lift or move re lative to the base material, then it's time to get it fixed. >> >> Hope that helps, >> >> >> Dave Saylor >> 831-750-0284 CL >> >> >> On Tue, Aug 13, 2013 at 5:01 PM, Robert Brunkenhoefer wrote: om> >>> >>> Anyone have an idea how to repair this condition? What is the door made o f,and how do I repair it? Robert Brunkenhoefer N661G KCRP >>> >>> Sent from my iPad >>> >>> ========== >>> " target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> MS - >>> k">http://forums.matronics.com >>> ========== >>> e - >>> -Matt Dralle, List Admin. >>> t="_blank">http://www.matronics.com/contribution >>> ========== >> >> >> >> ========================= ========= >> ://www.matronics.com/Navigator?RV10-List >> ========================= ========= >> cs.com >> ========================= ========= >> matronics.com/contribution >> ========================= ========= >> > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 13, 2013
<<=8B different materials (fiberglass door and polycarbonate window) have different expansion coefficients =8B>>=8B oh, it's much worse actually: glass, resin, window, weld-on, filler, primer, paint...all doin' the mambo in close proximity. Add a little oil canning from the window, it's now wonder the joint cracks. Lancair/Columbia/Cessna has an SB for the same issue on their windows as well, same issue. Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Aug 14, 2013
Dave, how has your window installation solution held up over the years? Just curious. I did the Van's standard with some light wt glass over the edges. You can see the edges but no cracks in the paint yet... they're coming though. Bill "just flying it" Watson On 8/13/2013 11:20 PM, Dave Saylor wrote: > << > different materials (fiberglass door and polycarbonate window) have > different expansion coefficients > >> > > > oh, it's much worse actually: glass, resin, window, weld-on, filler, > primer, paint...all doin' the mambo in close proximity. Add a little > oil canning from the window, it's now wonder the joint cracks. > Lancair/Columbia/Cessna has an SB for the same issue on their windows > as well, same issue. > > Dave Saylor > 831-750-0284 CL > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Aug 14, 2013
I used a carbon fiber angle piece to finish off the sill after the side panel was put in place. Or you can just finish off the door sill and paint it if you have no lower side panel. Geoff Combs _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Tuesday, August 13, 2013 6:00 PM Subject: RV10-List: door sill finishing I'm looking for ideas on how to finish the lower door sill. The Vans demo plane has a piece of wood to provide a ledge to sit or step on when entering the cabin. Does anyone have some other ideas? Maybe pictures? Chris Hukill ________________________________________________________________________________
Subject: Re: door sill finishing
Date: Aug 14, 2013
Walnut wood finished with Mirror Coat. The walnut matches other walnut wood finishing pieces and the stick grips. Fun side project! -------- David Halmos RV-10 Electrical/avionics Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=406696#406696 Attachments: http://forums.matronics.com//files/image_119.jpg http://forums.matronics.com//files/image_106.jpg http://forums.matronics.com//files/image_115.jpg ________________________________________________________________________________
Date: Aug 14, 2013
I laid up layers of fiberglass when I built to avoid this issue and had no p roblems for the first 300 hours. I then installed the aftermarket door latc h that draws in the bottom of the door when you close it, and got cracks alm ost immediately on both doors. I had the painter rework the fiberglass and r epaint, and it cracked again in less than 5 hours. My hypothesis is the lat ch flexes the door when it closes, causing the cracks. My solution will be d ecals that match the paint scheme at the 4 corners around the windows. Aaron Sent from my iPad On Aug 13, 2013, at 11:20 PM, Dave Saylor wrote: > <<=8Bdifferent materials (fiberglass door and polycarbonate window) h ave different expansion coefficients =8B>>=8B > > oh, it's much worse actually: glass, resin, window, weld-on, filler, prim er, paint...all doin' the mambo in close proximity. Add a little oil cannin g from the window, it's now wonder the joint cracks. Lancair/Columbia/Cessn a has an SB for the same issue on their windows as well, same issue. > > Dave Saylor > 831-750-0284 CL > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 14, 2013
The only issue with my installation is that the SilPruf has gotten a little "chalky" on the surface. It develops kind of a white powdery deposit that kind of looks like oxidation. I can polish it with various Armor-All type cleaners and it cleans up well. It's still very pliable and coherent. I'd do it again, and I'd like to come up with a method for the windshield too. Which might happen sooner rather than later since I've got a TON of little stars in the front plastic. For the time being I have the overlay on the aft edge of the windshield and it's working fine. We're approaching 1300 hours and 6 years. Dave Saylor 831-750-0284 CL On Wed, Aug 14, 2013 at 3:13 AM, Bill Watson wrote: > Dave, how has your window installation solution held up over the years? > Just curious. > > I did the Van's standard with some light wt glass over the edges. You ca n > see the edges but no cracks in the paint yet... they're coming though. > > Bill "just flying it" Watson > > On 8/13/2013 11:20 PM, Dave Saylor wrote: > > <<=8B > different materials (fiberglass door and polycarbonate window) have > different expansion coefficients > =8B>>=8B > > > oh, it's much worse actually: glass, resin, window, weld-on, filler, > primer, paint...all doin' the mambo in close proximity. Add a little oil > canning from the window, it's now wonder the joint cracks. > Lancair/Columbia/Cessna has an SB for the same issue on their windows as > well, same issue. > > Dave Saylor > 831-750-0284 CL > > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com > 08/13/13 > > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Aug 14, 2013
Aaron, Out of curiosity, can you tell how much overlap there was past the edge of the window joint, both towards the inside and the outside? And did the crack form on the window joint so that it cracked through the overlay, or was it at the edge of the overlay? I did something similar to your decal idea in that I have a gloss black ring painted around all my windows. Dave Saylor 831-750-0284 CL On Wed, Aug 14, 2013 at 8:13 AM, Aaron wrote: > I laid up layers of fiberglass when I built to avoid this issue and had n o > problems for the first 300 hours. I then installed the aftermarket door > latch that draws in the bottom of the door when you close it, and got > cracks almost immediately on both doors. I had the painter rework the > fiberglass and repaint, and it cracked again in less than 5 hours. My > hypothesis is the latch flexes the door when it closes, causing the crack s. > My solution will be decals that match the paint scheme at the 4 corners > around the windows. > > Aaron > > Sent from my iPad > > On Aug 13, 2013, at 11:20 PM, Dave Saylor < > dave.saylor.aircrafters(at)gmail.com> wrote: > > <<=8B > different materials (fiberglass door and polycarbonate window) have > different expansion coefficients > =8B>>=8B > > > oh, it's much worse actually: glass, resin, window, weld-on, filler, > primer, paint...all doin' the mambo in close proximity. Add a little oil > canning from the window, it's now wonder the joint cracks. > Lancair/Columbia/Cessna has an SB for the same issue on their windows as > well, same issue. > > Dave Saylor > 831-750-0284 CL > > * > > ======================== > ://www.matronics.com/Navigator?RV10-List > ======================== ===========cs.com > ======================== ===========matronics.com/contribution > ======================== > * > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Aug 14, 2013
Aaron, The latch will probably flex the door if you have a really tight seal and it is flexing the middle of the door. If your pins still drag a lot even after the cam pulls the door in, the seal is probably too tight. If you have the McMaster Carr seal you should have 1/4=9D reveal between the inner door skin and the outer edge of the cabin lip. I put a lot of fiberglass tape around my windows and the paint shop sanded them all down too thin. My windows all cracked so I had the paint shop fix it all. 400 hours later I notice the corner of the windshield cracking but no cracks around the other windows. I wonder if the best fix is to keep the gap around the windows unfilled and use tape or just proseal around them. From: Aaron Sent: Wednesday, August 14, 2013 9:13 AM Subject: Re: RV10-List: Repair paint cracking around door window opening I laid up layers of fiberglass when I built to avoid this issue and had no problems for the first 300 hours. I then installed the aftermarket door latch that draws in the bottom of the door when you close it, and got cracks almost immediately on both doors. I had the painter rework the fiberglass and repaint, and it cracked again in less than 5 hours. My hypothesis is the latch flexes the door when it closes, causing the cracks. My solution will be decals that match the paint scheme at the 4 corners around the windows. Aaron Sent from my iPad On Aug 13, 2013, at 11:20 PM, Dave Saylor wrote: <<=8Bdifferent materials (fiberglass door and polycarbonate window) have different expansion coefficients =8B>>=8B oh, it's much worse actually: glass, resin, window, weld-on, filler, primer, paint...all doin' the mambo in close proximity. Add a little oil canning from the window, it's now wonder the joint cracks. Lancair/Columbia/Cessna has an SB for the same issue on their windows as well, same issue. Dave Saylor 831-750-0284 CL ========= ://www.matronics.com/Navigator?RV10-List ========= cs.com ========= matronics.com/contribution ========= ________________________________________________________________________________
Date: Aug 14, 2013
One more thought, I heard someone else state the reason his window starting crazing is the stress forced on the window due to holding it from expanding and contracting with fiberglass. From: Seano Sent: Wednesday, August 14, 2013 9:47 AM Subject: Re: RV10-List: Repair paint cracking around door window opening Aaron, The latch will probably flex the door if you have a really tight seal and it is flexing the middle of the door. If your pins still drag a lot even after the cam pulls the door in, the seal is probably too tight. If you have the McMaster Carr seal you should have 1/4=9D reveal between the inner door skin and the outer edge of the cabin lip. I put a lot of fiberglass tape around my windows and the paint shop sanded them all down too thin. My windows all cracked so I had the paint shop fix it all. 400 hours later I notice the corner of the windshield cracking but no cracks around the other windows. I wonder if the best fix is to keep the gap around the windows unfilled and use tape or just proseal around them. From: Aaron Sent: Wednesday, August 14, 2013 9:13 AM Subject: Re: RV10-List: Repair paint cracking around door window opening I laid up layers of fiberglass when I built to avoid this issue and had no problems for the first 300 hours. I then installed the aftermarket door latch that draws in the bottom of the door when you close it, and got cracks almost immediately on both doors. I had the painter rework the fiberglass and repaint, and it cracked again in less than 5 hours. My hypothesis is the latch flexes the door when it closes, causing the cracks. My solution will be decals that match the paint scheme at the 4 corners around the windows. Aaron Sent from my iPad On Aug 13, 2013, at 11:20 PM, Dave Saylor wrote: <<=8Bdifferent materials (fiberglass door and polycarbonate window) have different expansion coefficients =8B>>=8B oh, it's much worse actually: glass, resin, window, weld-on, filler, primer, paint...all doin' the mambo in close proximity. Add a little oil canning from the window, it's now wonder the joint cracks. Lancair/Columbia/Cessna has an SB for the same issue on their windows as well, same issue. Dave Saylor 831-750-0284 CL ========= ://www.matronics.com/Navigator?RV10-List ========= cs.com ========= matronics.com/contribution ========= href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 14, 2013
RGF2ZS4gV291bGQgQ2FyYm9uIEZpYmVyIG92ZXJsYXkgaW4gdGhlIGNyaXRpY2FsIGNvcm5lcnMg YmUgYSBiZXR0ZXIgY2hvaWNlIHRoYW4gZmliZXJnbGFzcyBpbiB0aGVzZSBsb2NhdGlvbnM/DQoN ClJvYmluDQoNCkZyb206IG93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFp bHRvOm93bmVyLXJ2MTAtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbV0gT24gQmVoYWxmIE9mIERh dmUgU2F5bG9yDQpTZW50OiBUdWVzZGF5LCBBdWd1c3QgMTMsIDIwMTMgODoyMCBQTQ0KVG86IHJ2 MTAtbGlzdEBtYXRyb25pY3MuY29tDQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBSZXBhaXIgcGFp bnQgY3JhY2tpbmcgYXJvdW5kIGRvb3Igd2luZG93IG9wZW5pbmcNCg0KPDzigIsNCmRpZmZlcmVu dCBtYXRlcmlhbHMgKGZpYmVyZ2xhc3MgZG9vciBhbmQgcG9seWNhcmJvbmF0ZSB3aW5kb3cpIGhh dmUgZGlmZmVyZW50IGV4cGFuc2lvbiBjb2VmZmljaWVudHMNCuKAiz4+4oCLDQoNCg0Kb2gsIGl0 J3MgbXVjaCB3b3JzZSBhY3R1YWxseTogIGdsYXNzLCByZXNpbiwgd2luZG93LCB3ZWxkLW9uLCBm aWxsZXIsIHByaW1lciwgcGFpbnQuLi5hbGwgZG9pbicgdGhlIG1hbWJvIGluIGNsb3NlIHByb3hp bWl0eS4gIEFkZCBhIGxpdHRsZSBvaWwgY2FubmluZyBmcm9tIHRoZSB3aW5kb3csIGl0J3Mgbm93 IHdvbmRlciB0aGUgam9pbnQgY3JhY2tzLiAgTGFuY2Fpci9Db2x1bWJpYS9DZXNzbmEgaGFzIGFu IFNCIGZvciB0aGUgc2FtZSBpc3N1ZSBvbiB0aGVpciB3aW5kb3dzIGFzIHdlbGwsIHNhbWUgaXNz dWUuDQoNCkRhdmUgU2F5bG9yDQo4MzEtNzUwLTAyODQgQ0wNCg0KDQoNCg0KDQoNCl8tPT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQoN Cl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwgRm9ydW0gLQ0KDQpfLT0gVXNlIHRo ZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlDQoNCl8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLA0KDQpfLT0g QXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsDQoNCl8t PSBQaG90b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6DQoNCl8tPQ0KDQpfLT0gICAtLT4gaHR0 cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCg0KXy09DQoNCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KDQpfLT0gU2Ft ZSBncmVhdCBjb250ZW50IGFsc28gYXZhaWxhYmxlIHZpYSB0aGUgV2ViIEZvcnVtcyENCg0KXy09 DQoNCl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCg0KXy09DQoNCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 DQoNCl8tPSAgICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCg0KXy09 ICBUaGFuayB5b3UgZm9yIHlvdXIgZ2VuZXJvdXMgc3VwcG9ydCENCg0KXy09ICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgLU1hdHQgRHJhbGxlLCBMaXN0IEFkbWluLg0KDQpfLT0gICAtLT4g aHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KDQpfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KDQoNCg0KX19f X19fX19fX19fX19fX19fX19fX19fX19fX19fX18NCk5vIHZpcnVzIGZvdW5kIGluIHRoaXMgbWVz c2FnZS4NCkNoZWNrZWQgYnkgQVZHIC0gd3d3LmF2Zy5jb208aHR0cDovL3d3dy5hdmcuY29tPg0K VmVyc2lvbjogMjAxMy4wLjMzOTIgLyBWaXJ1cyBEYXRhYmFzZTogMzIwOS82NTM1IC0gUmVsZWFz ZSBEYXRlOiAwNy8zMC8xMw0KSW50ZXJuYWwgVmlydXMgRGF0YWJhc2UgaXMgb3V0IG9mIGRhdGUu DQo ________________________________________________________________________________
Date: Aug 14, 2013
Carbon might help if the problem is a structure that's too flexible. Then again a thicker fiberglass cloth could solve that problem too, much cheaper . I don't know enough about why the overlay cracked to say how to fix it. I'd be pretty surprised if it actually cracked through the overlay, although that may be the case. More likely I'd think the edge of the overlay lifted, which is a different problem altogether than a crack at the window joint. Hopefully Aaron can shed some light on what exactly happened there. Dave Saylor 831-750-0284 CL On Wed, Aug 14, 2013 at 11:28 AM, Robin Marks wrote : > Dave. Would Carbon Fiber overlay in the critical corners be a better > choice than fiberglass in these locations? **** > > ** ** > > Robin**** > > ** ** > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Dave Saylor > *Sent:* Tuesday, August 13, 2013 8:20 PM > > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Repair paint cracking around door window openin g > **** > > ** ** > > <<=8B**** > > different materials (fiberglass door and polycarbonate window) have > different expansion coefficients**** > > =8B>>=8B**** > > ** ** > > ** ** > > oh, it's much worse actually: glass, resin, window, weld-on, filler, > primer, paint...all doin' the mambo in close proximity. Add a little oil > canning from the window, it's now wonder the joint cracks. > Lancair/Columbia/Cessna has an SB for the same issue on their windows as > well, same issue.**** > > ** ** > > Dave Saylor > 831-750-0284 CL**** > > ** ** > > * * > > * * > ============* > > ============* > > ============* > > ============* > > * * > > ------------------------------ > > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Aug 14, 2013
Give me a couple of days to get to the airport and take a look. I think the seals are tight (Van's seals) the door is bending when the bottom gets pull ed tight, and the areas around the windows have the least stiffness and bend the most. I'll try to determine if the window or fiberglass are disbonding beneath, but I suspect not. Its just flexing of the composite material. Aaron Sent from my iPad On Aug 14, 2013, at 5:21 PM, Dave Saylor wrote: > Carbon might help if the problem is a structure that's too flexible. Then again a thicker fiberglass cloth could solve that problem too, much cheaper . > > I don't know enough about why the overlay cracked to say how to fix it. I 'd be pretty surprised if it actually cracked through the overlay, although t hat may be the case. More likely I'd think the edge of the overlay lifted, w hich is a different problem altogether than a crack at the window joint. Ho pefully Aaron can shed some light on what exactly happened there. > > Dave Saylor > 831-750-0284 CL > > > On Wed, Aug 14, 2013 at 11:28 AM, Robin Marks wrot e: >> Dave. Would Carbon Fiber overlay in the critical corners be a better choi ce than fiberglass in these locations? >> >> >> >> Robin >> >> >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server @matronics.com] On Behalf Of Dave Saylor >> Sent: Tuesday, August 13, 2013 8:20 PM >> >> >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Repair paint cracking around door window opening >> >> >> <<=8B >> >> different materials (fiberglass door and polycarbonate window) have diffe rent expansion coefficients >> >> =8B>>=8B >> >> >> >> >> >> oh, it's much worse actually: glass, resin, window, weld-on, filler, pri mer, paint...all doin' the mambo in close proximity. Add a little oil canni ng from the window, it's now wonder the joint cracks. Lancair/Columbia/Cess na has an SB for the same issue on their windows as well, same issue. >> >> >> >> Dave Saylor >> 831-750-0284 CL >> >> >> >> >> >> ============= >> V10-List Email Forum - u> > tor?RV10-List" target="_blank">http://www.m atronics.com/Navigator?RV10-List ============== - MATRONICS WEB FORUMS - u> rget="_blank">http://forums.matronics.com ============== - List Contribution Web Site - /pre> -Matt Dralle, List Admin. bution" target="_blan k">http://www.matronics.com/contribution ============ = >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> r> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: Alternator Belt
Date: Aug 18, 2013
Just wanted to share the following with all regarding alternator belt findings: Using Vans supplied Plane Power Alternator, and Vans supplied I0-540 Engine with an LW 12227 double pulley flywheel, my findings are that a Gates XL 7325 is the belt of choice. The Alternator came in a fairly recently purchased FF kit (few months ago) and the Install Instructions say: "For 7 1/2 inch ring gear support pulley locally purchase XL7300 Gates (not supplied)". A Dayco 15355 (Gates XL 7355) does come with the kit but it is way too long and meant for a 9-3/4 inch ring gear support pulley. After some web searching on VAF I found that this discussion had been been covered not too awful long ago with the conclusion being that a Gates XL7328 was the belt of choice. I bought both a 7328 and a 7320 (only 3/4 inch difference in total length) and tried them both. First tried the 7320 which is 32 5/8 inch. No matter which way you held your jaw it wasn't going to go on - not without hurting something! The 7328 (33 3/8 inch) did go on but I found that I could tighten it all the way to maximum travel on the V-1004 arm and still rotate the pulley too easily without the engine/flywheel turning. That's for a new belt. Once broken in and the belt has stretched, it would be out of capable travel adjustment range. What is the BIG DEAL you say? NOT interested in removing the spinner and the prop just to install a different belt after one hour of flight is my answer. Back to the store, got an XL 7325 and bingo - fits on the flywheel and alt. with just a bit of difficulty, but once tightened there was still about 1/4 to 3/8 inch travel on the V-1004 arm for adjustment. Log book size entry time! For those that are unfamiliar with how to, or how much to tighten the belt, PlanePower does include instructions that are good on their website. If I might add a tip that has worked well for me over the last 15 years: A new belt is a bit slippery as NEW. This will change over the first few hours of operation - the belt will also stretch a bit after these first few hours. So, what I like to do for the initial setting is snug the alternator down to the point of being able to put a 1/2 inch breaker bar with appropriate socket ( 3/4 inch - PlanePower) on the alternator center nut and in turning the breaker bar just slightly (10 - 20 degrees) it should almost turn the flywheel, hence the engine crank. For now this is good enough. Tighten and safety wire. Then after just a couple hours of flight and the belt is stretched to basically final form and no longer slippery, I like to tighten it just enough to perform the same procedure as above but have it actually turn the alt. and crank together, no slipping. No over tightening! Also these rules do not apply to an oil or fluid contaminated belt! If the belt is tightened too much, we will have alternator bearing and/or other issues, and if we don't tighten it enough it can slip causing premature belt wear and possibly poor to little output at the alternator. ***When making these adjustments be sure to put a few 1/2 inch bolts/washers in the crank to hold the flywheel in place (as in symmetrical with the crank flange) unless of course the prop is already bolted on. SORRY if this has already been posted somewhere, I couldn't find it and thought it might help some of you. It's also during the weekend, so PlanePower is closed - they may have already discovered these Gates numbers, I'll give them a call tomorrow One thing is for sure - their recommended Gates XL7300 would not have worked on my set up! The Revisions from Plane Power that I have are dated: 8/27/12 - maybe they have an updated one. Rich Hansen RV-6A sold Rv-10 Fitting Cowl, Panel Ordered! ________________________________________________________________________________
Date: Aug 19, 2013
Subject: Re: Alternator Belt
Make sure you check the alignment of the alternator and the flywheel pulleys. There have been instances where the spacers provided with the alternator place the alternator pulley forward or aft of the correct placement. There are single and dual pulley flywheels and its possible to have them staggered. Just check it now before you get to first flight. I have personally seen two instances where the pulleys were not aligned. Jim Combs N312F - Flying (540+ Hours) On Sun, Aug 18, 2013 at 9:41 PM, Karol Hansen wrot e: > > > Just wanted to share the following with all regarding alternator belt > findings: Using Vans supplied Plane Power Alternator, and Vans supplied > I0-540 Engine with an LW 12227 double pulley flywheel, my findings are th at > a Gates XL 7325 is the belt of choice. The Alternator came in a fairly > recently purchased FF kit (few months ago) and the Install Instructions > say: "For 7 1/2 inch ring gear support pulley locally purchase XL7300 > Gates (not supplied)". A Dayco 15355 (Gates XL 7355) does come with the > kit but it is way too long and meant for a 9-3/4 inch ring gear support > pulley. > > After some web searching on VAF I found that this discussion had been bee n > covered not too awful long ago with the conclusion being that a Gates > XL7328 was the belt of choice. I bought both a 7328 and a 7320 (only 3/4 > inch difference in total length) and tried them both. First tried the 73 20 > which is 32 5/8 inch. No matter which way you held your jaw it wasn't > going to go on - not without hurting something! The 7328 (33 3/8 inch) d id > go on but I found that I could tighten it all the way to maximum travel o n > the V-1004 arm and still rotate the pulley too easily without the > engine/flywheel turning. That's for a new belt. Once broken in and the > belt has stretched, it would be out of capable travel adjustment range. > What is the BIG DEAL you say? NOT interested in removing the spinner an d > the prop just to install a different belt after one hour of flight is my > answer. Back to the store, got an XL 7325 and bingo - fits on the flywhe el > and alt. with just a bit of difficult! > y, but once tightened there was still about 1/4 to 3/8 inch travel on th e > V-1004 arm for adjustment. Log book size entry time! > > For those that are unfamiliar with how to, or how much to tighten the > belt, PlanePower does include instructions that are good on their website . > If I might add a tip that has worked well for me over the last 15 years: > A new belt is a bit slippery as NEW. This will change over the first fe w > hours of operation - the belt will also stretch a bit after these first f ew > hours. So, what I like to do for the initial setting is snug the > alternator down to the point of being able to put a 1/2 inch breaker bar > with appropriate socket ( 3/4 inch - PlanePower) on the alternator center > nut and in turning the breaker bar just slightly (10 - 20 degrees) it > should almost turn the flywheel, hence the engine crank. For now this is > good enough. Tighten and safety wire. Then after just a couple hours o f > flight and the belt is stretched to basically final form and no longer > slippery, I like to tighten it just enough to perform the same procedure as > above but have it actually turn the alt.! > and crank together, no slipping. No over tightening! Also these rules > do not apply to an oil or fluid contaminated belt! > > If the belt is tightened too much, we will have alternator bearing and/or > other issues, and if we don't tighten it enough it can slip causing > premature belt wear and possibly poor to little output at the alternator. > > ***When making these adjustments be sure to put a few 1/2 inch > bolts/washers in the crank to hold the flywheel in place (as in symmetric al > with the crank flange) unless of course the prop is already bolted on. > > SORRY if this has already been posted somewhere, I couldn't find it and > thought it might help some of you. It's also during the weekend, so > PlanePower is closed - they may have already discovered these Gates > numbers, I'll give them a call tomorrow=85=85 One thing is for sure - th eir > recommended Gates XL7300 would not have worked on my set up! The Revisio ns > from Plane Power that I have are dated: 8/27/12 - maybe they have an > updated one. > > > Rich Hansen > RV-6A sold > Rv-10 Fitting Cowl, Panel Ordered! > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Aug 19, 2013
There are also single belt flywheels that look like they fit two belts ....... they don't. Linn On 8/19/2013 9:42 AM, Jim Combs wrote: > Make sure you check the alignment of the alternator and the flywheel > pulleys. There have been instances where the spacers provided with > the alternator place the alternator pulley forward or aft of the > correct placement. There are single and dual pulley flywheels and its > possible to have them staggered. > > Just check it now before you get to first flight. > > I have personally seen two instances where the pulleys were not aligned. > > Jim Combs > N312F - Flying (540+ Hours) > > > On Sun, Aug 18, 2013 at 9:41 PM, Karol Hansen > wrote: > > > > > > Just wanted to share the following with all regarding alternator > belt findings: Using Vans supplied Plane Power Alternator, and > Vans supplied I0-540 Engine with an LW 12227 double pulley > flywheel, my findings are that a Gates XL 7325 is the belt of > choice. The Alternator came in a fairly recently purchased FF kit > (few months ago) and the Install Instructions say: "For 7 1/2 > inch ring gear support pulley locally purchase XL7300 Gates (not > supplied)". A Dayco 15355 (Gates XL 7355) does come with the kit > but it is way too long and meant for a 9-3/4 inch ring gear > support pulley. > > After some web searching on VAF I found that this discussion had > been been covered not too awful long ago with the conclusion being > that a Gates XL7328 was the belt of choice. I bought both a 7328 > and a 7320 (only 3/4 inch difference in total length) and tried > them both. First tried the 7320 which is 32 5/8 inch. No matter > which way you held your jaw it wasn't going to go on - not without > hurting something! The 7328 (33 3/8 inch) did go on but I found > that I could tighten it all the way to maximum travel on the > V-1004 arm and still rotate the pulley too easily without the > engine/flywheel turning. That's for a new belt. Once broken in > and the belt has stretched, it would be out of capable travel > adjustment range. What is the BIG DEAL you say? NOT interested > in removing the spinner and the prop just to install a different > belt after one hour of flight is my answer. Back to the store, > got an XL 7325 and bingo - fits on the flywheel and alt. with just > a bit of difficult! > y, but once tightened there was still about 1/4 to 3/8 inch > travel on the V-1004 arm for adjustment. Log book size entry time! > > For those that are unfamiliar with how to, or how much to tighten > the belt, PlanePower does include instructions that are good on > their website. If I might add a tip that has worked well for me > over the last 15 years: A new belt is a bit slippery as NEW. > This will change over the first few hours of operation - the belt > will also stretch a bit after these first few hours. So, what I > like to do for the initial setting is snug the alternator down to > the point of being able to put a 1/2 inch breaker bar with > appropriate socket ( 3/4 inch - PlanePower) on the alternator > center nut and in turning the breaker bar just slightly (10 - 20 > degrees) it should almost turn the flywheel, hence the engine > crank. For now this is good enough. Tighten and safety wire. > Then after just a couple hours of flight and the belt is > stretched to basically final form and no longer slippery, I like > to tighten it just enough to perform the same procedure as above > but have it actually turn the alt.! > and crank together, no slipping. No over tightening! Also > these rules do not apply to an oil or fluid contaminated belt! > > If the belt is tightened too much, we will have alternator bearing > and/or other issues, and if we don't tighten it enough it can slip > causing premature belt wear and possibly poor to little output at > the alternator. > > ***When making these adjustments be sure to put a few 1/2 inch > bolts/washers in the crank to hold the flywheel in place (as in > symmetrical with the crank flange) unless of course the prop is > already bolted on. > > SORRY if this has already been posted somewhere, I couldn't find > it and thought it might help some of you. It's also during the > weekend, so PlanePower is closed - they may have already > discovered these Gates numbers, I'll give them a call tomorrow > One thing is for sure - their recommended Gates XL7300 would not > have worked on my set up! The Revisions from Plane Power that I > have are dated: 8/27/12 - maybe they have an updated one. > > > Rich Hansen > RV-6A sold > Rv-10 Fitting Cowl, Panel Ordered! > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 19, 2013
If you want more than 'feel', use a torque wrench instead of the breaker bar. Plane Power and Lycoming list torque limits. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407065#407065 ________________________________________________________________________________
Date: Aug 19, 2013
Correct Bob on torque, and correct Jim on alignment. FOLLOW-UP: Did speak to Plane Power today. They were not aware of belt size issues or alignment issues. They said that they would contact Vans to see what else needs to be done between the two of them. PP said that they did redesign the u-bracket and some other things (not too long ago) to accommodate Vans change to the Lycoming 2 grove pulley that was requested primarily by the Brazil builders. Regarding alignment: My mounted alt. sits forward approx .125 of where it should be. After hours of waiting on the phone for Vans, or talking to Plane Power, I'm tired of waiting so will just shave off .125 of the rear 1001 spacer and add 2 washers in the front. I'll add the same two washers at the adjustment bracket. I also did find today 6 pages on VAF regarding similar issues - (see RV-10 Alternator Alignment Issues) These seem to have started about Oct. 2011 - it is hard to believe these issues are still not resolved. Some refer to Vans having a different install kit with different spacers for $30.00? Of course, no where to be found on Vans website or parts cat. Yet one MORE issue is the #7 bolt placement. The Plane Power instructions have you placing the head of the bolt in from the front. On mine, utilizing the aforementioned newer style U-bracket, the bolt hits the ring gear and will not be removable without dropping the bolts that retain the U-bracket, or taking the prop off - should the Alternator ever need servicing! Neither a great option, so at this point i will be installing the bolt from the rear, thus placing the washer and securing nut in the front. Don't have cowl fit yet so don't know if this will work. Anybody please chime in if they tried this and it did, or didn't work? Regarding belt size, I stick to my guns, for my application the 7325 is the ticket.. Will post anything of value other than, " that's the first we've heard of that" ! Rich ________________________________________________________________________________
Date: Aug 20, 2013
Plan on drilling the nut and bolt end to secure with safety wire the reverse oriented bolt. You should be fine. John Cox On Mon, Aug 19, 2013 at 5:37 PM, Karol Hansen wrot e: > > > Correct Bob on torque, and correct Jim on alignment. > > FOLLOW-UP: > > Did speak to Plane Power today. They were not aware of belt size issues > or alignment issues. They said that they would contact Vans to see what > else needs to be done between the two of them. PP said that they did > redesign the u-bracket and some other things (not too long ago) to > accommodate Vans change to the Lycoming 2 grove pulley that was requested > primarily by the Brazil builders. > > Regarding alignment: My mounted alt. sits forward approx .125 of where i t > should be. After hours of waiting on the phone for Vans, or talking to > Plane Power, I'm tired of waiting so will just shave off .125 of the rear > 1001 spacer and add 2 washers in the front. I'll add the same two washer s > at the adjustment bracket. > I also did find today 6 pages on VAF regarding similar issues - (see RV-1 0 > Alternator Alignment Issues) These seem to have started about Oct. 2011 - > it is hard to believe these issues are still not resolved. Some refer to > Vans having a different install kit with different spacers for $30.00? O f > course, no where to be found on Vans website or parts cat. > > > Yet one MORE issue is the #7 bolt placement. The Plane Power instruction s > have you placing the head of the bolt in from the front. On mine, > utilizing the aforementioned newer style U-bracket, the bolt hits the rin g > gear and will not be removable without dropping the bolts that retain the > U-bracket, or taking the prop off - should the Alternator ever need > servicing! Neither a great option, so at this point i will be installing > the bolt from the rear, thus placing the washer and securing nut in the > front. Don't have cowl fit yet so don't know if this will work. Anybody > please chime in if they tried this and it did, or didn't work? > > Regarding belt size, I stick to my guns, for my application the 7325 is > the ticket=85.. > > Will post anything of value other than, " that's the first we've heard of > that" ! > > Rich > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Aug 20, 2013
Call Vans and tell them you need the Plane Power Alternator Adapter Spacer kit. Its not listed in the parts catalog but the tech guys will know what you need for the RV10. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407115#407115 ________________________________________________________________________________
Date: Aug 20, 2013
Thank you Charlie. Did take 10 minutes last night and shaved off .125 of the rear spacer, added 2 washers in the front as well as at the bracket and as expected, now a perfect fit and alignment. Because of your post Charlie I did try Vans again this morning and this time got right through - they did say they had a spacer kit specifically for the RV-10. I ordered it anyway, and strongly suggested that it would be helpful and the right thing to do to include those parts in the FF kit or any Alt. kit ordered for the RV-10. Just put it in the kits and change the price if you have to - its only a few dollars! Rich ________________________________________________________________________________
Date: Aug 20, 2013
Rich, Everyone but Vans agrees with you. I'm still astonished that if you buy the engine and fwf kit from vans, they expect you to know that you have to order the bushings. Plus pay $30 for them. Bob Sent from my iPhone On Aug 20, 2013, at 1:51 PM, Karol Hansen wrote: Thank you Charlie. Did take 10 minutes last night and shaved off .125 of the rear spacer, added 2 washers in the front as well as at the bracket and as expected, now a perfect fit and alignment. Because of your post Charlie I did try Vans again this morning and this time got right through - they did say they had a spacer kit specifically for the RV-10. I ordered it anyway, and strongly suggested that it would be helpful and the right thing to do to include those parts in the FF kit or any Alt. kit ordered for the RV-10. Just put it in the kits and change the price if you have to - its only a few dollars! Rich ________________________________________________________________________________
Subject: Insurance/Hours/Where to go from here
Date: Aug 22, 2013
I'm getting to the point where there aren't a whole lot of parts left, and one of them appears to be a large airplane like thing. So, this starts me thinking about things like first flights and fly off and, of course, that leads to insurance. Insurance, as I'm sure most of you are aware, wants about two hundred and fifty hours in a log book before they'll cover you in an experimental airplane... which is fine... except my log book seems to have about 161.4 hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental airplane before I can take off in my own in a financially responsible way. Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, get my high performance sign off and my transition training... but what happens after that I don't know. I could get my IFR, but had certainly hoped to do that time in my own plane... and it's sure going to be hard to see my shiny new RV-10 sitting in a hangar for the better part of a year before I can fly it. Are there any low timers out there who would like to share what you did? Are there any high timers out there with suggestions? Jeff Carpenter 40304 Prop hung and about half way through the baffles ________________________________________________________________________________
Subject: Re: Insurance/Hours/Where to go from here
Date: Aug 22, 2013
I just had a conversation with another builder that had a few hours less than you do. Unfortunately, he was with Aggressive. (So was I). Aggressive is getting out of the aviation business and just sent out non-renewal notices. In addition to the hours, many companies didn't want to cover Phase 1 , many wouldn't cover first flight. In talking with my agent, she relayed that another RV-10 was just quoted $17k w/ $10k deductible. Ouch!!! If were in your shoes, I would get current first. Not knowing you situation, I don't want to make any assumptions on how long that will take. Then I would go to an ifr boot camp were you can getting your rating in a week or so. Some will even come to you. Naturally, you won't be very ifr proficient at this stage, but you would have the rating. This would kill two birds with one stone. Get more hours and the additional rating. This will drive your premiums lower. Then after phase 1, you can work on becoming ifr proficient. I don't think there are any short cuts other than throwing cash to build hours and get your ifr rating quickly. Bob Sent from my iPhone On Aug 22, 2013, at 1:00 PM, Jeff Carpenter wrote: I'm getting to the point where there aren't a whole lot of parts left, and one of them appears to be a large airplane like thing. So, this starts me thinking about things like first flights and fly off and, of course, that leads to insurance. Insurance, as I'm sure most of you are aware, wants about two hundred and fifty hours in a log book before they'll cover you in an experimental airplane... which is fine... except my log book seems to have about 161.4 hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental airplane before I can take off in my own in a financially responsible way. Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, get my high performance sign off and my transition training... but what happens after that I don't know. I could get my IFR, but had certainly hoped to do that time in my own plane... and it's sure going to be hard to see my shiny new RV-10 sitting in a hangar for the better part of a year before I can fly it. Are there any low timers out there who would like to share what you did? Are there any high timers out there with suggestions? Jeff Carpenter 40304 Prop hung and about half way through the baffles ________________________________________________________________________________
Date: Aug 22, 2013
My thoughts start flying something, anything, now while finishing up the RV-10; buy the gas for someone to fly the phase 1; earn your instrument rating in the RV-10 with a CFII/evaluator who is RV-10 insurable; take pilots or CFIs who are RV-10 insurable on trips (breakfasts, lunch, Caribbean, etc) -- all while you are flying your RV-10 building hours. At 250 hours total time, you get to fly by yourself. Fly safe, -Jim On Aug 22, 2013, at 12:44 PM, Bob Leffler wrote: > > I'm getting to the point where there aren't a whole lot of parts left, and one of them appears to be a large airplane like thing. So, this starts me thinking about things like first flights and fly off and, of course, that leads to insurance. > > Insurance, as I'm sure most of you are aware, wants about two hundred and fifty hours in a log book before they'll cover you in an experimental airplane... which is fine... except my log book seems to have about 161.4 hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental airplane before I can take off in my own in a financially responsible way. > > Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, get my high performance sign off and my transition training... but what happens after that I don't know. I could get my IFR, but had certainly hoped to do that time in my own plane... and it's sure going to be hard to see my shiny new RV-10 sitting in a hangar for the better part of a year before I can fly it. > > Are there any low timers out there who would like to share what you did? > > Are there any high timers out there with suggestions? > > Jeff Carpenter > 40304 > Prop hung and about half way through the baffles > > > > > > > > > ________________________________________________________________________________
Date: Aug 22, 2013
Pretty much agree with Bob, above. Insurance requirements are a constantly moving target. Some thoughts: High performance endorsement. You do not just want the paperwork, you want CS prop operation to be second nature to you before you get into your plane. I presume from your post that you have never flown anything close to the speed an RV10 is capable of. You will find yourself behind the plane, mentally. Are you planning on doing the phase one testing? At a minimum, have you had some spin training and do you feel comfortable with stalls and potential spins (not that the ten is likely to spin, but you are after all a test pilot)? So, option one: go fly, get another 50 hours. Fly some faster planes. Get used to the CS prop. Use the time to get your instrument rating. Option two: Hire a commercial or ATP rated pilot who is reasonable to insure to do your phase one testing. Then hire a CFI who is reasonable to insure (could be the same person) to instruct you in your plane, get high performance endorsement, ifr rating. Neither of these will be inexpensive. Maybe others have other ideas. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407239#407239 ________________________________________________________________________________
Date: Aug 22, 2013
I think recent flight experience plays a part in this. So before you start talking serious with the insurance agent, get some. One way to get a little extra time and not that much money.....find friends who need safety pilots. Also, if you do not have an HP rating (is that what it is called, maybe endorsement), get one asap so you can fly as safety pilot for your friends with HP aircraft. I log this time when I am pilot in command. May not be a lot, but every little bit helps. For years I chased a 10% discount by doing extra training and a IPC each year. But I am a numbers guys at heart and you know, it always cost me money to save the 10%. If $$ are the driver, than make sure you look closely at all options and figure out the true costs. I know that there is value in getting an IPC each year.....but I think I get more real training when me and my instructor just go out and focus on one or two things and not worry about him covering his but signing off an IPC. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Thursday, August 22, 2013 11:44 AM Subject: Re: RV10-List: Insurance/Hours/Where to go from here I just had a conversation with another builder that had a few hours less than you do. Unfortunately, he was with Aggressive. (So was I). Aggressive is getting out of the aviation business and just sent out non-renewal notices. In addition to the hours, many companies didn't want to cover Phase 1 , many wouldn't cover first flight. In talking with my agent, she relayed that another RV-10 was just quoted $17k w/ $10k deductible. Ouch!!! If were in your shoes, I would get current first. Not knowing you situation, I don't want to make any assumptions on how long that will take. Then I would go to an ifr boot camp were you can getting your rating in a week or so. Some will even come to you. Naturally, you won't be very ifr proficient at this stage, but you would have the rating. This would kill two birds with one stone. Get more hours and the additional rating. This will drive your premiums lower. Then after phase 1, you can work on becoming ifr proficient. I don't think there are any short cuts other than throwing cash to build hours and get your ifr rating quickly. Bob Sent from my iPhone On Aug 22, 2013, at 1:00 PM, Jeff Carpenter wrote: I'm getting to the point where there aren't a whole lot of parts left, and one of them appears to be a large airplane like thing. So, this starts me thinking about things like first flights and fly off and, of course, that leads to insurance. Insurance, as I'm sure most of you are aware, wants about two hundred and fifty hours in a log book before they'll cover you in an experimental airplane... which is fine... except my log book seems to have about 161.4 hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental airplane before I can take off in my own in a financially responsible way. Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, get my high performance sign off and my transition training... but what happens after that I don't know. I could get my IFR, but had certainly hoped to do that time in my own plane... and it's sure going to be hard to see my shiny new RV-10 sitting in a hangar for the better part of a year before I can fly it. Are there any low timers out there who would like to share what you did? Are there any high timers out there with suggestions? Jeff Carpenter 40304 Prop hung and about half way through the baffles ________________________________________________________________________________
Date: Aug 22, 2013
1) go to Texas or Oregon and get the transition training. 2) Self insure during flyoff 3) fly your plane and get your 25-40 hours you need. Once you have your flyoff completed, it will be easier to get insurance. I went with Skysmith, they worked with me. Took less than 5 hours to get from not flying 20 years ago to flying the -10. After the 1st flight I figured out the plane puts up with a monkey flying it.. (dont ask me how I know) Once you have the flyoff done , you'll feel more comfortable flying instruments and you can get a great CFI in Chino to fly with you and get you back on track. I'll gladly fly with you if you want a safety pilot. Let's get out one day and you can fly my plane. Pascal -----Original Message----- From: Jeff Carpenter Sent: Thursday, August 22, 2013 10:00 AM Subject: RV10-List: Insurance/Hours/Where to go from here I'm getting to the point where there aren't a whole lot of parts left, and one of them appears to be a large airplane like thing. So, this starts me thinking about things like first flights and fly off and, of course, that leads to insurance. Insurance, as I'm sure most of you are aware, wants about two hundred and fifty hours in a log book before they'll cover you in an experimental airplane... which is fine... except my log book seems to have about 161.4 hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental airplane before I can take off in my own in a financially responsible way. Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, get my high performance sign off and my transition training... but what happens after that I don't know. I could get my IFR, but had certainly hoped to do that time in my own plane... and it's sure going to be hard to see my shiny new RV-10 sitting in a hangar for the better part of a year before I can fly it. Are there any low timers out there who would like to share what you did? Are there any high timers out there with suggestions? Jeff Carpenter 40304 Prop hung and about half way through the baffles ________________________________________________________________________________
Subject: Paul Poberezny - Gone West
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Aug 22, 2013
Word from EAA that Paul passed away this morning. This is very sad news, even if we expect the day to come - it still sucks. We owe much if not all of our hobby and joy to Paul and the others he worked with to found EAA and its values. Thanks for everything you did Paul - God Speed. -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407245#407245 ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Re: Paul Poberezny - Gone West
From: bruce breckenridge <bbreckenridge(at)gmail.com>
What a legacy! He saw his EAA dream grow for 60 years. Amazing. On Thu, Aug 22, 2013 at 11:46 AM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > Word from EAA that Paul passed away this morning. This is very sad news, > even if we expect the day to come - it still sucks. We owe much if not all > of our hobby and joy to Paul and the others he worked with to found EAA and > its values. Thanks for everything you did Paul - God Speed. > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407245#407245 > > ________________________________________________________________________________
Date: Aug 22, 2013
Just keep in mind that safety pilot time logging is complicated and only loosely related to who is PIC and who is qualified to be PIC. So read up on AOPA website on the intimate details to do it correctly. You do not need anything past single engine land to log second in command time. You can log PIC any time where you are sole manipulator of the controls, even when you are not qualified to be PIC. So travel time enroute to/from an instrument approach, if PIC will let you fly it, would count. You can log PIC as safety any time you are qualified to be PIC. That does argue for getting the HP endorsement(and complex while you are at it) early and then go play safety for Bonanza and Mooney and Cirrus pilots. Mooney is particularly good because its speeds are very similar, especially on takeoff and landing speeds. It also takes planning to get slowed up enough for landing. On 8/22/2013 11:26 AM, Rene Felker wrote: > > I think recent flight experience plays a part in this. So before you start > talking serious with the insurance agent, get some. > > One way to get a little extra time and not that much money.....find friends > who need safety pilots. > > Also, if you do not have an HP rating (is that what it is called, maybe > endorsement), get one asap so you can fly as safety pilot for your friends > with HP aircraft. I log this time when I am pilot in command. May not be > a lot, but every little bit helps. > > For years I chased a 10% discount by doing extra training and a IPC each > year. But I am a numbers guys at heart and you know, it always cost me > money to save the 10%. If $$ are the driver, than make sure you look > closely at all options and figure out the true costs. I know that there is > value in getting an IPC each year.....but I think I get more real training > when me and my instructor just go out and focus on one or two things and not > worry about him covering his but signing off an IPC. > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler > Sent: Thursday, August 22, 2013 11:44 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Insurance/Hours/Where to go from here > > > I just had a conversation with another builder that had a few hours less > than you do. Unfortunately, he was with Aggressive. (So was I). Aggressive > is getting out of the aviation business and just sent out non-renewal > notices. > > In addition to the hours, many companies didn't want to cover Phase 1 , many > wouldn't cover first flight. > > In talking with my agent, she relayed that another RV-10 was just quoted > $17k w/ $10k deductible. Ouch!!! > > If were in your shoes, I would get current first. Not knowing you situation, > I don't want to make any assumptions on how long that will take. Then I > would go to an ifr boot camp were you can getting your rating in a week or > so. Some will even come to you. Naturally, you won't be very ifr > proficient at this stage, but you would have the rating. > > This would kill two birds with one stone. Get more hours and the additional > rating. This will drive your premiums lower. > > Then after phase 1, you can work on becoming ifr proficient. > > > I don't think there are any short cuts other than throwing cash to build > hours and get your ifr rating quickly. > > Bob > Sent from my iPhone > > On Aug 22, 2013, at 1:00 PM, Jeff Carpenter wrote: > > > I'm getting to the point where there aren't a whole lot of parts left, and > one of them appears to be a large airplane like thing. So, this starts me > thinking about things like first flights and fly off and, of course, that > leads to insurance. > > Insurance, as I'm sure most of you are aware, wants about two hundred and > fifty hours in a log book before they'll cover you in an experimental > airplane... which is fine... except my log book seems to have about 161.4 > hours in it (give or take). So, I'm looking at a good 90.6 hours in a rental > airplane before I can take off in my own in a financially responsible way. > > Now, I'm sure I could use (and plan on) a good 20-30 hours to get current, > get my high performance sign off and my transition training... but what > happens after that I don't know. I could get my IFR, but had certainly hoped > to do that time in my own plane... and it's sure going to be hard to see my > shiny new RV-10 sitting in a hangar for the better part of a year before I > can fly it. > > Are there any low timers out there who would like to share what you did? > > Are there any high timers out there with suggestions? > > Jeff Carpenter > 40304 > Prop hung and about half way through the baffles > > ________________________________________________________________________________
Date: Aug 22, 2013
Sorry Kelly, that is not correct. You may log PIC time as a safety pilot if you ARE the PIC. Not just qualified to be. Generally this is not true. Here's one test: if the engine quits, who is going to decide what field to land in? In most circumstances the aircraft owner will take over all such decisions, so he is PIC. In such cases you can only log the time as "other", not PIC. Sometimes two rental pilots will make a deal, where they each agree that the safety pilot is PIC. As long as they mean it, then they both get to log PIC time! I know some pilot examiners for whom this practice raises a red flag, though. Kelly is correct, you do not need a High Performance endorsement to serve as a safety pilot in any single engine plane (assuming you hold private, single engine). You do need a medical. And you cannot serve as PIC. FYI I am a CFII and do hold a LODA (waiver) to give transition training in my 10. But I have not renewed my insurance to cover this; too expensive for too little business. LODA trainers are supposed to confine themselves to transition training, nothing else. They are not supposed to sign off high performance endorsements. Self insuring. To be safe you need to honestly answer this question: Deep down in my heart, am I willing to throw $100K down the toilet? Or, if the engine quits over a nice corn field, but I think maybe I can make it back to the airport, what will you decide? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407273#407273 ________________________________________________________________________________
Date: Aug 22, 2013
Correction: my post should have said that you cannot act as PIC in a high performance airplane without a HP endorsement. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407274#407274 ________________________________________________________________________________
Date: Aug 22, 2013
Sorry Bob but both your statements are partially incorrect. Being PIC and the ability to log PIC are two totally different things. If you don't believe me go to AOPA for both their guidance and opinion of FAA general counsel. Your example of safety pilot acting and logging PIC and the pilot flying under hood also logging PIC as sole manipulator of controls is perfect example. Anyone that is sole manipulator of controls can log PIC time regardless of whether they are qualified by endorsements to be PIC. So someone transitioning to HP can log the time as PIC while receiving dual because they are the sole manipulator and are a licensed pilot. Just as training for commercial license can all be logged as both dual and PIC. On the other hand safety pilot may not log PIC time if they are not qualified to be PIC. Like I said, it is a tricky subject that CFI's and examiners frequently get it wrong. On 8/22/2013 2:59 PM, Bob Turner wrote: > > Correction: my post should have said that you cannot act as PIC in a high performance airplane without a HP endorsement. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407274#407274 > > ________________________________________________________________________________
Date: Aug 22, 2013
Kelly, I stand by my post. Everything you said in your last post is correct. But your first post said you could log time as PIC if you were acting as a safety pilot and were qualified to be PIC. That is not good enough. You must actually be THE PIC, the person legally responsible for the safe and legal operation of the aircraft, in this particular case. The FAR 61 basis allows logging as PIC time a "required crewmember" who is acting as THE PIC. On any flight it may be possible for multiple pilots to be logging time as PIC; but only one person is THE PIC. If you allow someone else to fly your plane under the hood, and you are the safety pilot, then you are almost certainly THE PIC, and you both get to log the time as PIC time*. But if you swap seats and you fly under the hood, only you can log PiC time. Your safety pilot friend is most likely not responsible for the legal operation of the aircraft, not THE PIC, he can only log "other" time. If AOPA says otherwise they've got it wrong. *ironicly, this is only true if you are vfr. If ifr then no safety pilot is required, so no logging of time for the person not flying. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407289#407289 ________________________________________________________________________________
Date: Aug 22, 2013
Kelly, I went and read the aopa article. They have it right. They say to log PiC time when you are a safety pilot you must be ACTING as PIC. (not just qualified). As you said the rules are complicated. Trivia question: How is it possible for a non-instrument rated private pilot aircraft owner(person A), his non-instrument rated private pilot friend (B), and a CFII with no medical certificate (C), to ALL log PIC time on one flight? Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407293#407293 ________________________________________________________________________________
Date: Aug 22, 2013
I'd say we will have to agree to disagree. Theoretically, the owner/operator of the aircraft flying under the hood should agree that while he is under the hood the safety pilot will act as the PIC, but given that who is acting as PIC can change at any moment as long as the safety is qualified to be PIC they can in fact log PIC during the simulated instrument time. Just as the person manipulating the controls does not have to be qualified to be PIC to log the time. Or if the safety is instrument rated and the pilot flying isn't current they can both go get some actual to log, where there is no question who is legally PIC. For those who would like to read the article in question, it is at http://www.aopa.org/News-and-Video/All-News/2009/October/1/Answers-for-Pilots-Logging-time.aspx The whole subject is mostly counting angels on a pinhead except when using the time to qualify for a rating. All that is required is that the two pilots agree that during the simulated instrument time the safety pilot will act as PIC. They can change that decision at anytime during the flight. JMHO with 40 yrs of following the subject while licensed and 35 yrs of maintaining instrument currency. On Thu, Aug 22, 2013 at 6:19 PM, Bob Turner wrote: > > Kelly, > > I stand by my post. > Everything you said in your last post is correct. > But your first post said you could log time as PIC if you were acting as a > safety pilot and were qualified to be PIC. That is not good enough. You > must actually be THE PIC, the person legally responsible for the safe and > legal operation of the aircraft, in this particular case. The FAR 61 basis > allows logging as PIC time a "required crewmember" who is acting as THE PIC. > On any flight it may be possible for multiple pilots to be logging time as > PIC; but only one person is THE PIC. > If you allow someone else to fly your plane under the hood, and you are > the safety pilot, then you are almost certainly THE PIC, and you both get > to log the time as PIC time*. But if you swap seats and you fly under the > hood, only you can log PiC time. Your safety pilot friend is most likely > not responsible for the legal operation of the aircraft, not THE PIC, he > can only log "other" time. > If AOPA says otherwise they've got it wrong. > > *ironicly, this is only true if you are vfr. If ifr then no safety pilot > is required, so no logging of time for the person not flying. > > Bob > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407289#407289 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Aug 22, 2013
Okay, I can agree with this - theoretically! I just do not like to see misinformation being distributed on the internet. If you are going to log this type of time (PIC safety pilot time) you must claim to be the actual PIC - being qualified is not enough. Getting back to the original topic, suppose "John" applies for insurance, and says he has 300 hours of logged PIC time. He gets coverage, but unfortunately soon after has an accident, his plane is totaled, plus he is being sued. The insurance company asks to see his logbook, and they notice 50 hours logged as PIC while serving as safety pilot in "Bob's" airplane. The insurance company asks Bob to swear, under oath, that John did in fact serve as the person responsible for the operation of Bob's airplane. Bob knows that if he says 'yes' not only is he lying under oath, but his own insurance company, which would not allow John to be PIC in Bob's plane, will be very unhappy. My point is, this is fudging the rules. Just be aware that there may be consequences. No one will care unless you have an accident, or apply for a new rating or license. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407306#407306 ________________________________________________________________________________
Date: Aug 22, 2013
Subject: Re: Flight time logging
I see your point. My point was that who is acting is not set in stone from takeoff to landing. Say John is validly acting as PIC in Bob's plane while being safety pilot. A problem arises, at which point Bob tosses the "hood" and says "I got it". Bob is now PIC and resolves whatever the issue. Bob's insurance company isn't going to care that John was acting while Bob was under the hood, because in fact it makes no more difference to the safety of flight whether Bob or John is acting while Bob is under the hood. They both understand before the flight that in the case of anything unusual occurring the simulated instrument flight will discontinue until the issue is resolved, so there is no insurance issue. If Bob testifies that John in fact flew as his safety pilot and acted as PIC while Bob was under the hood, his insurance company is unlikely to hear about it, since your hypothetical costs Bob's insurance nothing, there is no claim, and Bob is being diligent at maintaining currency. John's insurance will be satisfied that his PIC time was in fact valid. So Bob's insurance company is in fact not going to be upset with him. I'm just pointing out that who is acting during any phase of flight can change in a heartbeat. There just needs to be good cockpit resource management and understanding between the two pilots. Simple version is they agree that safety pilot will act as PIC while the pilot flying is under the hood. If any urgent situation comes up, safety pilot will advise(fly if necessary) while pilot flying removes hood and takes over. Not to mention all the nonsense when insurance companies and FAA get involved and they will assume barring evidence to contrary, that the pilot most senior in ratings/experience in the cockpit is the PIC regardless of which seat occupied, and many cases where FAA has issued violations on that basis. I wasn't suggesting that anyone falsify what they log, just that it isn't that difficult to swap back and forth who is acting as PIC and logs the time. It is trickier when 2 or more pilots desire to log PIC simultaneously. The max number possible is a question reserved for bar bets. On 8/22/2013 8:36 PM, Bob Turner wrote: > > Okay, I can agree with this - theoretically! > > I just do not like to see misinformation being distributed on the internet. If you are going to log this type of time (PIC safety pilot time) you must claim to be the actual PIC - being qualified is not enough. > > Getting back to the original topic, suppose "John" applies for insurance, and says he has 300 hours of logged PIC time. He gets coverage, but unfortunately soon after has an accident, his plane is totaled, plus he is being sued. The insurance company asks to see his logbook, and they notice 50 hours logged as PIC while serving as safety pilot in "Bob's" airplane. The insurance company asks Bob to swear, under oath, that John did in fact serve as the person responsible for the operation of Bob's airplane. Bob knows that if he says 'yes' not only is he lying under oath, but his own insurance company, which would not allow John to be PIC in Bob's plane, will be very unhappy. > > My point is, this is fudging the rules. Just be aware that there may be consequences. No one will care unless you have an accident, or apply for a new rating or license. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407306#407306 > > ________________________________________________________________________________
Date: Aug 22, 2013
The truth is that, as you implied, who is really the PIC is only determined after the fact, by a court or the NTSB (in FAA enforcement actions). I know of one case where the court held the guy in the back seat to be the PIC. In the example I gave, the insurance company is going to feel that John falsified his application, by overstating his PIC time. The question is, what will a judge and jury think? If Bob states that he was prepared, on a moment's notice, to countermand any order John may have given, a reaonable jury could easily find that John was never the real PIC, and therefore was not entitled to log the safety pilot time as PIC time. People can log whatever they want; but they should know that they may have to justify and defend what they claimed, and at the most inopportune times. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407308#407308 ________________________________________________________________________________
Date: Aug 22, 2013
My last argument before I call it a night. Take a look at the definition of PIC in 14 CFR Part 1. It says the PIC is "the final authority..." If Bob can countermand John's orders, there is no way John can actually be the PIC. But I think we agree on what started all this: If you claim PIC time for time as a safety pilot, you must also claim that you were the actual PIC, as defined in part 1. Being qualified to be PIC is not enough. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407309#407309 ________________________________________________________________________________
Subject: Parachutes For Sale
Date: Aug 23, 2013
TWO PARACHUTES W/ FRESH RE-PACKS, $950 EACH OR BOTH FOR $1800.00 For Both are Butler Backpacks with 26' TriConical Canopy, Steerable w/ toggles. Pictures available upon request. Never been jumped. Keep at home in closet when not actually being flown in airplane. dav1111 at clear dot net ________________________________________________________________________________
Date: Aug 23, 2013
Jeff, Last year, Shanna Linton (877)-577-8267 from NationAir was able to find me a policy with US Specialty Insurance for about $3K. I had less than 50 total hrs, all in a C172. They required a transition training signoff which I got from David Maib (who was outstanding). Good luck. ________________________________________________________________________________
Date: Aug 23, 2013
I think the bad news here is that the insurance companies have been experiencing losses, or at least are nervous, and are pulling back. As Bob Leffer mentioned, some of the low cost companies have left this market. Others are tightening up who they will insure. I know Jenny (NationAir) recently posted that new quotes for tailwheel planes were now requiring a lot more pilot experience than previously. My insurance just renewed last month, and my previous carrier (Chartis) wanted a small increase despite my passing 100 hr time in type (which is usually a benchmark for a lower premium). Fortunately another solid company was willing to quote less. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407372#407372 ________________________________________________________________________________
Date: Aug 23, 2013
karolamy(at)roadrunner.co wrote: > Thank you Charlie. Did take 10 minutes last night and shaved off .125 of the rear spacer, added 2 washers in the front as well as at the bracket and as expected, now a perfect fit and alignment. Because of your post Charlie I did try Vans again this morning and this time got right through - they did say they had a spacer kit specifically for the RV-10. I ordered it anyway, and strongly suggested that it would be helpful and the right thing to do to include those parts in the FF kit or any Alt. kit ordered for the RV-10. Just put it in the kits and change the price if you have to - its only a few dollars! > > Rich Yes, my mod and belt size still runs fine. Plane Power and Van's were made aware of this issue 2 yrs ago by at least Bob and myself. Wonder if all of those plans errors still exist 1000 tail kits later? -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407390#407390 ________________________________________________________________________________
Date: Aug 23, 2013
On 8/23/2013 5:31 PM, rv10flyer wrote: > > > karolamy(at)roadrunner.co wrote: >> Thank you Charlie. Did take 10 minutes last night and shaved off .125 of the rear spacer, added 2 washers in the front as well as at the bracket and as expected, now a perfect fit and alignment. Because of your post Charlie I did try Vans again this morning and this time got right through - they did say they had a spacer kit specifically for the RV-10. I ordered it anyway, and strongly suggested that it would be helpful and the right thing to do to include those parts in the FF kit or any Alt. kit ordered for the RV-10. Just put it in the kits and change the price if you have to - its only a few dollars! >> >> Rich > > Yes, my mod and belt size still runs fine. Plane Power and Van's were made aware of this issue 2 yrs ago by at least Bob and myself. Wonder if all of those plans errors still exist 1000 tail kits later? I don't think so. But my case is a little special. My alternator came in a box .... by itself. No mounting hardware, no belt, no installation instructions .... just the alternator. I called Vans and got the biggest run-around ..... and no satisfaction. They told me to call Plane Power. I have friends at Plane Power/Skytek and they stepped up and made me whole. Once I got the parts everything went together and fit just fine. Since I didn't buy the alternator from Plane Power I expected Vans to take care of the problem ..... I was wrong. I sure don't have a good feeling about Vans customer service now. Linn > > -------- > Wayne G. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407390#407390 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Aug 23, 2013
Hmm, let me guess, you must have talked to some unnamed support person whose name starts with initials KS. AKA "we have never heard of that before" On Fri, Aug 23, 2013 at 3:04 PM, Linn Walters wrote: > > >> > I don't think so. But my case is a little special. My alternator came in > a box .... by itself. No mounting hardware, no belt, no installation > instructions .... just the alternator. I called Vans and got the biggest > run-around ..... and no satisfaction. They told me to call Plane Power. > I have friends at Plane Power/Skytek and they stepped up and made me > whole. Once I got the parts everything went together and fit just fine. > Since I didn't buy the alternator from Plane Power I expected Vans to take > care of the problem ..... I was wrong. I sure don't have a good feeling > about Vans customer service now. > Linn > > >> -------- >> Wayne G. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=407390#407390> >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Aug 23, 2013
As a late comer to EAA (12 years), I never met Paul, but in my 10 trips to EAA-OSH, I came to realize the awesome legacy that he has left us. What an amazing visionary! The spirit, the volunteer-ism, the ability to draw different parts of the aviation community together with new initiatives. Tom carried on his legacy in the EAA spirit till he was no longer able to continue. After the recent debacle, I feel that EAA is back on the track that Paul laid out for the organization. Mr. Pelton has done an awesome job. After attending the general meeting at AirVenture-2013, Paul can rest easy knowing that his EAA legacy lives - Bless your family and wife during this sad week. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=407403#407403 ________________________________________________________________________________
Date: Aug 25, 2013
Subject: Longer engine cables - throttle cable and mixture cable
During my 2nd condition inspection I see that both by throttle and mixture cables have started to wear through their sheathing in spots. I know needing longer cables than the stock Vans cables is a common requirement. Where are people buying longer cables these days? I see in the archives that Dave Saylor identifies someone is California. I also see ACS (not Aircraft Spruce?). Thanks. ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Aug 25, 2013
I sent this note to Van's a year and a half ago. The response back was 'many people are using the recommended cable'. The 50.5" cable from Van's worked just fine (standard Van's engine and push/pull controls). Carl From: Carl Froehlich [mailto:carl.froehlich(at)verizon.net] Sent: Wednesday, April 25, 2012 8:58 PM Subject: RV-10 Throttle Cable too short I installed the Van's recommended throttle cable (CT BLK THROTTLE 47.5) in my YIO-540 RV-10 project. It is simply too short. I just purchased and installed the IO-360 cable (CT BLK THROTTLE 50.5) and it fits better, but not perfect. Recommend offering a 49" cable for the RV-10 throttle control, or at least selling the 50.5" instead of the 47.5" cable to RV-10 builders. Your recommended prop and mixture cables worked well. Carl Froehlich 40528 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Sunday, August 25, 2013 6:34 PM Subject: RV10-List: Longer engine cables - throttle cable and mixture cable Mauledriver(at)nc.rr.com> During my 2nd condition inspection I see that both by throttle and mixture cables have started to wear through their sheathing in spots. I know needing longer cables than the stock Vans cables is a common requirement. Where are people buying longer cables these days? I see in the archives that Dave Saylor identifies someone is California. I also see ACS (not Aircraft Spruce?). Thanks. http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 25, 2013
Subject: Re: Longer engine cables - throttle cable and mixture cable
Well, I am getting close to ordering my cables. I recall that ACS offers a higher quality cable than what Vans buys from them. Top quality cables also can be obtained from McFarlane, but are priced some where between 2 an 3 times Van's price. I need to talk to McFarlane as to what the real length of their cables that they list for the RV-10 measure, as they show for stock panel and for Aerosport panels but don't say what the length is on their website. On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson wrote: > > During my 2nd condition inspection I see that both by throttle and mixture > cables have started to wear through their sheathing in spots. I know > needing longer cables than the stock Vans cables is a common requirement. > > Where are people buying longer cables these days? > > I see in the archives that Dave Saylor identifies someone is California. > I also see ACS (not Aircraft Spruce?). > > Thanks. > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Aug 25, 2013
By ACS you mean Aircraft Spruce? On 8/25/2013 7:41 PM, Kelly McMullen wrote: > Well, I am getting close to ordering my cables. I recall that ACS > offers a higher quality cable than what Vans buys from them. Top > quality cables also can be obtained from McFarlane, but are priced > some where between 2 an 3 times Van's price. I need to talk to > McFarlane as to what the real length of their cables that they list > for the RV-10 measure, as they show for stock panel and for Aerosport > panels but don't say what the length is on their website. > > > On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson > wrote: > > > > > During my 2nd condition inspection I see that both by throttle and > mixture cables have started to wear through their sheathing in > spots. I know needing longer cables than the stock Vans cables is > a common requirement. > > Where are people buying longer cables these days? > > I see in the archives that Dave Saylor identifies someone is > California. I also see ACS (not Aircraft Spruce?). > > Thanks. > > =================================== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > http://forums.matronics.com > =================================== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > =================================== > > > -- > > - sent from the microchip implanted in my forearm > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Aug 25, 2013
I'm one of the many people using the recommended cable. It works and it is going to fail. You gotta luv 'em. Seems like a case of selling what's on the truck. On 8/25/2013 7:22 PM, Carl Froehlich wrote: > > I sent this note to Van's a year and a half ago. The response back > was 'many people are using the recommended cable'. The 50.5" cable > from Van's worked just fine (standard Van's engine and push/pull > controls). > > Carl > > From: Carl Froehlich [mailto:carl.froehlich(at)verizon.net] > > Sent: Wednesday, April 25, 2012 8:58 PM > > To: 'support(at)vansaircraft.com' > > Subject: RV-10 Throttle Cable too short > > I installed the Van's recommended throttle cable (CT BLK THROTTLE > 47.5) in my YIO-540 RV-10 project. It is simply too short. I just > purchased and installed the IO-360 cable (CT BLK THROTTLE 50.5) and it > fits better, but not perfect. > > Recommend offering a 49" cable for the RV-10 throttle control, or at > least selling the 50.5" instead of the 47.5" cable to RV-10 builders. > > Your recommended prop and mixture cables worked well. > > Carl Froehlich > > 40528 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson > Sent: Sunday, August 25, 2013 6:34 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Longer engine cables - throttle cable and mixture > cable > > > > > During my 2nd condition inspection I see that both by throttle and > mixture cables have started to wear through their sheathing in spots. > I know needing longer cables than the stock Vans cables is a common > requirement. > > Where are people buying longer cables these days? > > I see in the archives that Dave Saylor identifies someone is > California. I also see ACS (not Aircraft Spruce?). > > Thanks. > > http://www.matronics.com/Navigator?RV10-List > > http://forums.matronics.com > > http://www.matronics.com/contribution > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Aug 25, 2013
California Push-Pull makes and sells CableCraft cables. The green cables from Vans are also CableCraft, but I used a different spec that seems to handle heat better. Look for 176-VTT part numbers. The part numbers in the archives should be available from any CableCraft distributor. I changed my cables at around 500 hours. The new ones have close to 800 now and are smooth as silk. Please note the measurements I gave are for a quadrant. Dave Saylor 831-750-0284 CL On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson wrote: > > During my 2nd condition inspection I see that both by throttle and mixture > cables have started to wear through their sheathing in spots. I know > needing longer cables than the stock Vans cables is a common requirement. > > Where are people buying longer cables these days? > > I see in the archives that Dave Saylor identifies someone is California. > I also see ACS (not Aircraft Spruce?). > > Thanks. > > ________________________________________________________________________________
Date: Aug 25, 2013
http://www.acsproductsaz.com/our_products.htm Which are sold by Spruce: http://www.aircraftspruce.com/menus/ap/controls_1acs.html On 8/25/2013 5:34 PM, Bill Watson wrote: > By ACS you mean Aircraft Spruce? > > On 8/25/2013 7:41 PM, Kelly McMullen wrote: >> Well, I am getting close to ordering my cables. I recall that ACS >> offers a higher quality cable than what Vans buys from them. Top >> quality cables also can be obtained from McFarlane, but are priced >> some where between 2 an 3 times Van's price. I need to talk to >> McFarlane as to what the real length of their cables that they list >> for the RV-10 measure, as they show for stock panel and for Aerosport >> panels but don't say what the length is on their website. >> >> >> On Sun, Aug 25, 2013 at 3:34 PM, Bill Watson > > wrote: >> >> > >> >> During my 2nd condition inspection I see that both by throttle >> and mixture cables have started to wear through their sheathing >> in spots. I know needing longer cables than the stock Vans >> cables is a common requirement. >> >> Where are people buying longer cables these days? >> >> I see in the archives that Dave Saylor identifies someone is >> California. I also see ACS (not Aircraft Spruce?). >> >> Thanks. >> >> =================================== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> http://forums.matronics.com >> =================================== >> le, List Admin. >> ="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> >> >> >> -- >> >> - sent from the microchip implanted in my forearm >> * >> >> >> * >> >> No virus found in this message. >> Checked by AVG - www.avg.com <http://www.avg.com> >> 08/25/13 >> > > * > > > * ________________________________________________________________________________
Subject: Engine Settling Measurement
Date: Aug 25, 2013
>From you guys with Van's engine and cowl, and that have at least 50 plus hours of flying on your 10, how much did the engine settle relative to the fixed position of the cowl? My 6 settled about 3/32 and that was about what I planned for - lucky! Also were you successful with only 1/8th inch gap between spinner bulkhead and forward cowl as per plans, or do you wish you had increased this gap just a bit to facilitate cowl removal? I'm certain I'll get quite a variety of opinions, but that's ok, please just let em rip!!! Thanks Much, Rich ________________________________________________________________________________
Subject: Re: Engine Settling Measurement
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Aug 26, 2013
My -4 settled a lot (~1/4") but my -10 did not settle any appreciable amount. I'd leave as large of a gap behind the spinner that you are comfortable with for the reasons you gave. I didn't build a race plane, I was more of "I don't want to scratch the paint and I want to be able to cowl it myself." YMMV -Mike Kraus RV-10 flying 150 hours Sent from my iPhone On Aug 25, 2013, at 11:21 PM, Karol Hansen wrote: > > >> From you guys with Van's engine and cowl, and that have at least 50 plus hours of flying on your 10, how much did the engine settle relative to the fixed position of the cowl? My 6 settled about 3/32 and that was about what I planned for - lucky! > > Also were you successful with only 1/8th inch gap between spinner bulkhead and forward cowl as per plans, or do you wish you had increased this gap just a bit to facilitate cowl removal? > > I'm certain I'll get quite a variety of opinions, but that's ok, please just let em rip!!! > > Thanks Much, > Rich > > > > > > > ________________________________________________________________________________
Date: Aug 26, 2013
We used the throttle cable for the RV-7 which is 3" longer than the one supplied for the -10. The mixture cable as supplied worked fine for us (standard panel with push pull). - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407486#407486 ________________________________________________________________________________
Date: Aug 26, 2013
For me, the standard cables supplied with the quadrant, with a standard panel, worked great. I used them for maybe 900 hours, and replaced the original green ones with black from Cablecraft for the higher temp rating, and also heat shielded them better at the time. I believe heat shielding is something that all builders should incorporate into their build, for cable longevity, as the cables all route close enough to the heat muffs that it may provide benefit. I won't know for another 1000 hours or so, but I do expect these to last much longer. When I re-ordered cables, the originals had fit perfectly. The replacement cables I ordered to the same lengths and they also fit. I don't know if they would have fit nearly as good if they were even 1/2 to 1" longer and they definitely wouldn't have worked if they were shorter. Make sure when you poll and watch the forums that you pay close attention to the panel and actuator type that people give. Any change in panel can lead to a change in cable length, and push-pull vs quadrant is significant. On a side note, I've seen it referenced many times that quadrant style is the only type that they will allow in formation flying clinics...that's for those building who may wonder why one or the other would be better for them. Tim On 8/25/2013 6:22 PM, Carl Froehlich wrote: > > I sent this note to Van's a year and a half ago. The response back > was 'many people are using the recommended cable'. The 50.5" cable > from Van's worked just fine (standard Van's engine and push/pull > controls). > > Carl > > ________________________________________________________________________________
Date: Aug 26, 2013
Replaced my Vans cable at about 150 hrs. It developed a wear spot in the plastic shield material. I tried fixing it with tank sealant. That also wore thru. Probably best to start out with the proper cable. Vans is tooooo short! -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407505#407505 ________________________________________________________________________________
Subject: Paint
Date: Aug 26, 2013
We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407507#407507 ________________________________________________________________________________
Date: Aug 26, 2013
Subject: Re: Paint
Jason, It is really a matter or opinion. The 2 finishes are different in appearance, To some people the difference matters and to some it doesn't. So the 1st question is to figure out if the difference matter. I don't believe that there are any differences in how well one protects vs the other. aA lot of that has to do with the painter and the prep. I believe that a base/clear is going to cost more than a single stage for obvious reasons (more labor). The next item would be to find your painter, some painters will only work with single stage paint. On Mon, Aug 26, 2013 at 8:43 AM, jkreidler wrote: > jason.kreidler(at)regalbeloit.com> > > We are getting ready to have the airplane painted at Watertown in > Wisconsin. Any strong opinions / reasons for a single stage top coat > versus a base coat / clear coat system? In both cases we will use aviation > finishes. > > Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407507#407507 > > ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 26, 2013
It sounds like you have selected your painter. As Deems said, ask him. He's the one who will have to stand by his work. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407512#407512 ________________________________________________________________________________
Date: Aug 26, 2013
Subject: Re: Paint
I'm going single stage ..... just look at all the cars on the road with clear coat problems. Done by professional robots. ;-) However using clear coat does make spot repairs easier and hides base coat imperfections. I'm no expert painter (nor do I play one on TV) but I doubt there's much difference between 'aviation' and 'automotive' finishes in this day and age. I do know the present day Imron (used to be my favorite) is formulated differently than the old stuff .... thanks to the EPA ...... and scratches easier. Haven't really looked, but I think you'll have far more colors to choose from with automotive paint. I really love the Dodge Viper Red!!!! Linn On 8/26/2013 11:43 AM, jkreidler wrote: > > We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. > > Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407507#407507 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Paint
Date: Aug 26, 2013
The main issue is the thickness of your wallet. For multiple colors and complex design, a couple of coats of clear over everything is the way to go. For a good paint job that won't break the bank and is easy to fix, single coat. On the RV-10 I did three color PPG base and clear and I worked my ass off. Then a neighbor did one color single stage PPG on a Lancair 4 and added vinyl stripes and N numbers. His plane was a third the work of the RV-10, looks show plane good and you can't tell the stripes are vinyl even an inch away. Get some quotes from your painter - and if you want any checkers be ready for a real big number. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Monday, August 26, 2013 11:43 AM Subject: RV10-List: Paint --> We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407507#407507 ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 26, 2013
Hey Jason/Linn, I paint, not an expert. Base/clear is very slick and provides great protection, but is more expensive, heavier, AND harder to touch up, not easier. If you get a chip in base/clear that goes through color, you have to match/touch up the base color first, then put the clear back on, then if you want it perfect you have to fine sand the clear flat to match and then buff. Single coat, just dab the chip and go -- buff if it needs it. I have doubts about those who paint multiple colors then clear it all. As I understand it, the early cars with base/clear peeled because the clear wasn't applied soon enough after the base was shot. Now it is recommended to clear within 30-40 minutes after base so that it bonds. Otherwise the base color is to be scuffed before clearing -- I've never done that. You see the problem if you have multiple colors. If multiple colors are shot at different times, then cleared days/weeks later -- you could probably get away with it if your plane is constantly hangared (the cars that peel don't spend most of their lives in a garage -- notice it is the horizontal surfaces that peel), but then the single stage paint with "wet look" hardener would look just as good and last just as long. Later, - Lew ________________________________________________________________________________
Subject: Paint
Date: Aug 26, 2013
Lew is correct on minding times. With PPG you have 24 hours from base to clear coat (tech sheet attached as example). On my plane I did paint with wings off, control surfaces and tail feathers removed. This piecemeal approach enabled me to manage times so I could always get the clear coat on in the allotted time. Simple jigs to hold the wings so they can be rotated for paint greatly simplified the work. I also agree with Lew on the merits of single coat. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lewgall(at)charter.net Sent: Monday, August 26, 2013 2:21 PM Subject: Re: RV10-List: Paint Hey Jason/Linn, I paint, not an expert. Base/clear is very slick and provides great protection, but is more expensive, heavier, AND harder to touch up, not easier. If you get a chip in base/clear that goes through color, you have to match/touch up the base color first, then put the clear back on, then if you want it perfect you have to fine sand the clear flat to match and then buff. Single coat, just dab the chip and go -- buff if it needs it. I have doubts about those who paint multiple colors then clear it all. As I understand it, the early cars with base/clear peeled because the clear wasn't applied soon enough after the base was shot. Now it is recommended to clear within 30-40 minutes after base so that it bonds. Otherwise the base color is to be scuffed before clearing -- I've never done that. You see the problem if you have multiple colors. If multiple colors are shot at different times, then cleared days/weeks later -- you could probably get away with it if your plane is constantly hangared (the cars that peel don't spend most of their lives in a garage -- notice it is the horizontal surfaces that peel), but then the single stage paint with "wet look" hardener would look just as good and last just as long. Later, - Lew ________________________________________________________________________________
Subject: Paint (checkers)
Date: Aug 26, 2013
Regarding Checkers there is a relatively fast and less expensive way to get painted checkers on your plane. It's the cheating car racers system for ch eckered patterns. They take the base painted part and apply the thinnest pa int tape available and grid out the desired section. Then they cover altern ate boxes with tape and just paint, dry & peal. The difference is the top c oat color checkers do not actually touch corner to corner. If you don't poi nt it out no one will ever notice. I had to have it pointed out to me by th e builder/painter (who was also a NASCAR mechanic) of my RV-4. All that bei ng said Checkers are not nearly as common on -10 as the rest of the fleet. Here is a photo & link: Robin [http://www.painttheweb.com/painttheweb/rv-4/RV-4%2084RM%20Photos/Fuse/RV84 RM-Fuse_%20(6).jpg] [http://www.painttheweb.com/painttheweb/rv-4/RV-4%2084RM%20Photos/Fuse/RV84 RM-Fuse_%20(19).jpg] http://www.painttheweb.com/painttheweb/rv-4/exterior.htm -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Carl Froehlich Sent: Monday, August 26, 2013 10:44 AM Subject: RE: RV10-List: Paint --> The main issue is the thickness of your wallet. For multiple colors and complex design, a couple of coats of clear over eve rything is the way to go. For a good paint job that won't break the bank a nd is easy to fix, single coat. On the RV-10 I did three color PPG base an d clear and I worked my ass off. Then a neighbor did one color single stag e PPG on a Lancair 4 and added vinyl stripes and N numbers. His plane was a third the work of the RV-10, looks show plane good and you can't tell the stripes are vinyl even an inch away. Get some quotes from your painter - and if you want any checkers be ready f or a real big number. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jkreidler Sent: Monday, August 26, 2013 11:43 AM Subject: RV10-List: Paint --> We are getting ready to have the airplane painted at Watertown in Wisconsin . Any strong opinions / reasons for a single stage top coat versus a base coa t / clear coat system? In both cases we will use aviation finishes. Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407507#407507 ________________________________________________________________________________
Date: Aug 26, 2013
Subject: Re: Paint (checkers)
Date: Aug 26, 2013
Subject: Re: Paint
I did my own paint and used a single stage Imron against the advice of a few local, non aircraft paint shops. I think I made the right decision. For the DIY painter, single stage is less work. But fixing mistakes can be harder. The paint pros explained that you can just sand out 2 stage mistakes and cover everything with clear coat for the A1 final finish. I see how 2 stage is required for a show winning finish but the single stage stuff is really nice. Get a nice flake color for your '10 in single stage and I think you'll be very happy. If your shop recommends it, then I know you'll be happy if they are any good at all. My advice for the DIY painter is to find a local paint distributor you want to work with and shoot one of the brands and lines that he carries. I started with the idea of using aviation lines from Dupont or PPG, but I ended up with a non-aviation line of Imron single stage because the distributor was closer to me than the PPG shop. And only a few places deal in the aviation lines. That turned out to be an inspired decision. I made almost daily trips there during my paint process - prices were good and while the advice was limited it was valuable for this first time painter. My guess is that that advice can be applied to paint selection by a paint shop - use what they like to use. I think skills are surprisingly product specific. Paints/coatings is very high tech stuff. Experience and manufacturers technical support are invaluable. Re regulations and their impact on paint; seems like almost everyone I met at the local paint depot, who had been shooting polyurethanes over the last decade was impaired. The guy who ran the place admitted that he was impaired, not that it wasn't apparent. His paint booth had sat idle for many years as a result. Many of his customers were impaired - it only took a short conversation to experience the impairment. Very scary indeed. The modern polyurethane paints are fantastic - single or 2 stage - but toxic as hell. Fresh air breather mandatory. My objective for each mix, shoot and cure was to never even catch a whiff of it. I mostly succeeded. I had befriended a neighbor who ran a local paint shop specializing in trucks, RVs and other big things. They were painting the hull of a big sailing ship which was too big for even their oversize booths. They shot it outside and I came by to watch along with a few others. I quickly ran out of there when I realized I was getting more exposure to Imron single stage standing 100 feet away than I was going to get in my own shop. I'm scared of the stuff. It's very bad. Aviation or non-aviation paints? For our purposes, I don't think it matters. I have no intention of dousing the plane in Skydrol. Rain is like sandpaper at 400knots but even in a dive, I just can't flog the horses that hard. 100knot rain erodes the old lacquers but good quality poly seems impervious to 200knot rain. I think the sweet spot is a top of the line Dupont Imron or PPG non-aviation paint. The lower priced automotive lines are less durable but the industrial grade top of the line stuff is "EAB aviation certified" in my unqualified opinion and just a little cheaper than the aviation lines - and certainly more available for the DIY painter. Bill "I didn't plan to paint but it turned out to be one of the most enjoyable challenges of the build" Watson On 8/26/2013 11:43 AM, jkreidler wrote: > > We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. > > Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407507#407507 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 26, 2013
I am not sure I would ever call anyone on this forum under-educated, much less throw that response at a single individual. Not what I come to this forum for and I think I can safely say I speak for more than myself. I appreciate the information, not the insults. michaelrorth wrote: > Hear! Hear! > Many Greenies are extremely under-educated. > Thanks for the truth. > > One amplification, though. > Not only has the lack of DDT resulted in the deaths of millions in the past, > the deaths continue today. > This is why the mosquito is often referred to as "the deadliest animal on > earth". > Michael > > -------------------------------------------------------------------------------- > > -- -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407541#407541 ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 26, 2013
Thanks Bill, I wish I had a place to spray. I think after doing the entire build to get to the end and say I am not capable of painting is a bit deflating, after all the best thing about the process is the education and experience. Thanks for the feedback. - Jason Mauledriver(at)nc.rr.com wrote: > I did my own paint and used a single stage Imron against the advice of a > few local, non aircraft paint shops. I think I made the right decision. > > For the DIY painter, single stage is less work. But fixing mistakes can > be harder. The paint pros explained that you can just sand out 2 stage > mistakes and cover everything with clear coat for the A1 final finish. > I see how 2 stage is required for a show winning finish but the single > stage stuff is really nice. Get a nice flake color for your '10 in > single stage and I think you'll be very happy. If your shop recommends > it, then I know you'll be happy if they are any good at all. > > My advice for the DIY painter is to find a local paint distributor you > want to work with and shoot one of the brands and lines that he > carries. I started with the idea of using aviation lines from Dupont or > PPG, but I ended up with a non-aviation line of Imron single stage > because the distributor was closer to me than the PPG shop. And only a > few places deal in the aviation lines. That turned out to be an inspired > decision. I made almost daily trips there during my paint process - > prices were good and while the advice was limited it was valuable for > this first time painter. > > My guess is that that advice can be applied to paint selection by a > paint shop - use what they like to use. I think skills are surprisingly > product specific. Paints/coatings is very high tech stuff. Experience > and manufacturers technical support are invaluable. > > Re regulations and their impact on paint; seems like almost everyone I > met at the local paint depot, who had been shooting polyurethanes over > the last decade was impaired. The guy who ran the place admitted that > he was impaired, not that it wasn't apparent. His paint booth had sat > idle for many years as a result. Many of his customers were impaired - > it only took a short conversation to experience the impairment. Very > scary indeed. > > The modern polyurethane paints are fantastic - single or 2 stage - but > toxic as hell. Fresh air breather mandatory. My objective for each > mix, shoot and cure was to never even catch a whiff of it. I mostly > succeeded. I had befriended a neighbor who ran a local paint shop > specializing in trucks, RVs and other big things. They were painting > the hull of a big sailing ship which was too big for even their oversize > booths. They shot it outside and I came by to watch along with a few > others. I quickly ran out of there when I realized I was getting more > exposure to Imron single stage standing 100 feet away than I was going > to get in my own shop. I'm scared of the stuff. It's very bad. > > Aviation or non-aviation paints? For our purposes, I don't think it > matters. I have no intention of dousing the plane in Skydrol. Rain is > like sandpaper at 400knots but even in a dive, I just can't flog the > horses that hard. 100knot rain erodes the old lacquers but good quality > poly seems impervious to 200knot rain. I think the sweet spot is a top > of the line Dupont Imron or PPG non-aviation paint. The lower priced > automotive lines are less durable but the industrial grade top of the > line stuff is "EAB aviation certified" in my unqualified opinion and > just a little cheaper than the aviation lines - and certainly more > available for the DIY painter. > > Bill "I didn't plan to paint but it turned out to be one of the most > enjoyable challenges of the build" Watson > > > On 8/26/2013 11:43 AM, jkreidler wrote: > > > > > > > We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. > > > > Jason > > > > -------- > > Jason Kreidler > > 4 Partner Build - Sheboygan Falls, WI > > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > > N44YH - Flying - #40617 > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=407507#407507 > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > > > > -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407542#407542 ________________________________________________________________________________
Date: Aug 26, 2013
Subject: Re: Paint
On 8/26/2013 6:48 PM, jkreidler wrote: > > Thanks Bill, I wish I had a place to spray. I think after doing the entire build to get to the end and say I am not capable of painting is a bit deflating, after all the best thing about the process is the education and experience. Thanks for the feedback. - Jason If you have a place to build then I think you have a place to paint. This is what works for me. YMMV. I made a 'tent' from 1/2" EMT and sheet plastic. My first booth was 9' X 9' X 20'. I use PVC fittings to attach the EMT together. Cut schedule 80 'rings and cut the side so it makes a 'c' tube and slip them in the PVC fittings to hold the EMT. I used the large 'butterfly clips' to hold the plastic to the EMT. The 9' was because I could only get 10' wide plastic at the time. There is 20' wide available now. A large squirrel cage fan exhausted outside and fiberfill on the other end was my filter. I paid good money for a paint mask because (at the time) the fresh air hose was too cumbersome. Hang lots of flourescent fixtures so you get plenty of light. I get good results (remember I'm not a professional painter) with a HF HVLP gun. I use a leaf blower to clean the dust out and wet down the floor before I move the parts in and spray. I also add some extra reducer to thin the paint, spray a light cross coat, wait 1/2 hour and spray another light cross coat. Repeat until I get good coverage and then quit. I wait 2 hours and then pull off any masking paper/tape. I only use blue and green 3M tape. For me, there is one really hard part. When you get finished with your 'wet coat(s)' and still have paint in the pot ..... throw it out and clean up the gun. It's just so hard for me to pitch all those $$$ in my paint recovery can. My paint recovery can is a coffee can that all the excess paint, reducer, etc. ends up in. It goes to the hazardous waste collector along with the empty paint cans. Good, thorough, prep will make a world of difference in the final paint. Poor prep and a professional painter will still get you a poor paint job. IMHO!!! Linn ________________________________________________________________________________
Date: Aug 26, 2013
Stock panel, engine, MT gov, vernier controls. I used the RV-7 throttle and ordered prop and mixture 1" longer from ACS. Throttle was 1" longer than needed but works okay. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407555#407555 ________________________________________________________________________________
Date: Aug 26, 2013
I built my cowl with prop spinner 1/8" higher. After i installed the .090" ss pins in the rear top hinge in place of alum .125" per instructions cowl dropped a little and rear gap enlarged. After 120 hours/20 mo my spinner is still about 1/8" higher than cowling. I think the engine settled less than 1/16" just like my cowl. I would recommend perfect alignment and not worry about it. I left 1/8" clearance between backplate and cowl. It works but entirely too tight. I would recommend 1/4-3/8". -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407556#407556 ________________________________________________________________________________
Date: Aug 27, 2013
Mine settled around 1/8, may be just a bit more. I left 1/4 gap and glad I did. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407567#407567 ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 27, 2013
Mr. Kreidler, If your name is "Many Greenies" I apologize for insulting you. If your name is NOT "Many Greenies", I stand by my original post. Never forget: 50% of Greenies are, by definition, below average. Michael -------------------------------------------------------------------------------- -----Original Message----- From: jkreidler Sent: Monday, August 26, 2013 3:44 PM Subject: RV10-List: Re: Paint I am not sure I would ever call anyone on this forum under-educated, much less throw that response at a single individual. Not what I come to this forum for and I think I can safely say I speak for more than myself. I appreciate the information, not the insults. michaelrorth wrote: > Hear! Hear! > Many Greenies are extremely under-educated. > Thanks for the truth. > > One amplification, though. > Not only has the lack of DDT resulted in the deaths of millions in the > past, > the deaths continue today. > This is why the mosquito is often referred to as "the deadliest animal on > earth". > Michael > > -------------------------------------------------------------------------------- > > -- -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407541#407541 ----- No virus found in this message. Checked by AVG - www.avg.com ________________________________________________________________________________
Subject: Re: Paint
Date: Aug 27, 2013
Jason, Having been in the car wash/auto detailing business for almost 30 years I can tell you I am very happy with the imron Watertown put on my plane. The stuff seems to be very tough. 95% of auto vehicles we detail have clear coat and it is very soft in my opinion. It is easy to polish out light scratches and blemishes, but clear coat also is very prone to them whenever you touch it. Clear coat in my opinion is like the plastic lens over your speedometer. I have about 250 hours on my plane now and detail it often with a non-polish, spray on liquid detailing wax. Takes all the bugs off easily, cleans the plane and I have yet to see any wash rash in the paint. Normal automotive clear coat on the other hand would require a polish type wax to keep it shiny. Dave Leikam On Aug 26, 2013, at 5:48 PM, jkreidler wrote: > > Thanks Bill, I wish I had a place to spray. I think after doing the entire build to get to the end and say I am not capable of painting is a bit deflating, after all the best thing about the process is the education and experience. Thanks for the feedback. - Jason > > > Mauledriver(at)nc.rr.com wrote: >> I did my own paint and used a single stage Imron against the advice of a >> few local, non aircraft paint shops. I think I made the right decision. >> >> For the DIY painter, single stage is less work. But fixing mistakes can >> be harder. The paint pros explained that you can just sand out 2 stage >> mistakes and cover everything with clear coat for the A1 final finish. >> I see how 2 stage is required for a show winning finish but the single >> stage stuff is really nice. Get a nice flake color for your '10 in >> single stage and I think you'll be very happy. If your shop recommends >> it, then I know you'll be happy if they are any good at all. >> >> My advice for the DIY painter is to find a local paint distributor you >> want to work with and shoot one of the brands and lines that he >> carries. I started with the idea of using aviation lines from Dupont or >> PPG, but I ended up with a non-aviation line of Imron single stage >> because the distributor was closer to me than the PPG shop. And only a >> few places deal in the aviation lines. That turned out to be an inspired >> decision. I made almost daily trips there during my paint process - >> prices were good and while the advice was limited it was valuable for >> this first time painter. >> >> My guess is that that advice can be applied to paint selection by a >> paint shop - use what they like to use. I think skills are surprisingly >> product specific. Paints/coatings is very high tech stuff. Experience >> and manufacturers technical support are invaluable. >> >> Re regulations and their impact on paint; seems like almost everyone I >> met at the local paint depot, who had been shooting polyurethanes over >> the last decade was impaired. The guy who ran the place admitted that >> he was impaired, not that it wasn't apparent. His paint booth had sat >> idle for many years as a result. Many of his customers were impaired - >> it only took a short conversation to experience the impairment. Very >> scary indeed. >> >> The modern polyurethane paints are fantastic - single or 2 stage - but >> toxic as hell. Fresh air breather mandatory. My objective for each >> mix, shoot and cure was to never even catch a whiff of it. I mostly >> succeeded. I had befriended a neighbor who ran a local paint shop >> specializing in trucks, RVs and other big things. They were painting >> the hull of a big sailing ship which was too big for even their oversize >> booths. They shot it outside and I came by to watch along with a few >> others. I quickly ran out of there when I realized I was getting more >> exposure to Imron single stage standing 100 feet away than I was going >> to get in my own shop. I'm scared of the stuff. It's very bad. >> >> Aviation or non-aviation paints? For our purposes, I don't think it >> matters. I have no intention of dousing the plane in Skydrol. Rain is >> like sandpaper at 400knots but even in a dive, I just can't flog the >> horses that hard. 100knot rain erodes the old lacquers but good quality >> poly seems impervious to 200knot rain. I think the sweet spot is a top >> of the line Dupont Imron or PPG non-aviation paint. The lower priced >> automotive lines are less durable but the industrial grade top of the >> line stuff is "EAB aviation certified" in my unqualified opinion and >> just a little cheaper than the aviation lines - and certainly more >> available for the DIY painter. >> >> Bill "I didn't plan to paint but it turned out to be one of the most >> enjoyable challenges of the build" Watson >> >> >> On 8/26/2013 11:43 AM, jkreidler wrote: >> >>> >>> >>> We are getting ready to have the airplane painted at Watertown in Wisconsin. Any strong opinions / reasons for a single stage top coat versus a base coat / clear coat system? In both cases we will use aviation finishes. >>> >>> Jason >>> >>> -------- >>> Jason Kreidler >>> 4 Partner Build - Sheboygan Falls, WI >>> Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler >>> N44YH - Flying - #40617 >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=407507#407507 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> ----- >>> No virus found in this message. >>> Checked by AVG - www.avg.com >>> >>> >>> >>> >> > > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407542#407542 > > > > > > > > > > ________________________________________________________________________________
Subject: Flying the Hudson through NY and to Washington DC.
Date: Aug 27, 2013
Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. What airport in the NY area is a good one to launch from to do the Hudson corridor? What publications and charts do I need and where is the best place to get them? As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? -------- Ivan Kristensen. www.ivankristensen.com Builder # 40838 Flying (430hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407592#407592 ________________________________________________________________________________
Subject: Re: Flying the Hudson through NY and to Washington DC.
Date: Aug 27, 2013
ivankris wrote: > > > I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. Understatement of all time! I suggest you start by googling "Washington DC special flight rules area". You must take an on-line course if you wish to fly close to DC, I think it is on the TSA web site. That will tell you what you need to do to get to College Park. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407593#407593 ________________________________________________________________________________
Date: Aug 27, 2013
Don't know about the Hudson area. But you can take an online course to go ov er the Special VFR airspace surrounding the DC area here. https://www.faasafety.gov/gslac/ALC/course_content.aspx?cID=55&preview=t rue Just need to plan ahead and communicate with ATC prior to entering. Tim Sent from my iPhone On Aug 27, 2013, at 3:06 PM, "ivankris" wrote: > > Next week I have a couple of old friends from Europe coming to visit me he re in Canada and I am planning to take them on a "Trip of a Life Time" (at l east for them) in my RV-10 down the Hudson River NY. VFR corridor and then o nto Washington DC for a couple of days. > > I did this trip about 20 years ago in a Comanche so I am sure there has be en some changes in the rules since then. > > If anyone out there has flown this this trip in the last year or so and wo uld share some of the Do's and Dont's with me I would sure appreciate it. > > What airport in the NY area is a good one to launch from to do the Hudson c orridor? > > What publications and charts do I need and where is the best place to get t hem? > > As far as airports in the DC area I am thinking about College Park (KCGS) b ut it falls within the vail of a current TFR. Does that mean that it is off l imits to private aircraft operations? > > -------- > Ivan Kristensen. > > www.ivankristensen.com > Builder # 40838 > Flying (430hrs.) > C-GMDV > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407592#407592 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Aug 27, 2013
Ivan, as far as the lights are concerned if so equipped . On Tuesday, August 27, 2013, ivankris wrote: > > > > Next week I have a couple of old friends from Europe coming to visit me > here in Canada and I am planning to take them on a "Trip of a Life Time" > (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and > then onto Washington DC for a couple of days. > > I did this trip about 20 years ago in a Comanche so I am sure there has > been some changes in the rules since then. > > If anyone out there has flown this this trip in the last year or so and > would share some of the Do's and Dont's with me I would sure appreciate it. > > What airport in the NY area is a good one to launch from to do the Hudson > corridor? > > What publications and charts do I need and where is the best place to get > them? > > As far as airports in the DC area I am thinking about College Park (KCGS) > but it falls within the vail of a current TFR. Does that mean that it is > off limits to private aircraft operations? > > -------- > Ivan Kristensen. > > www.ivankristensen.com > Builder # 40838 > Flying (430hrs.) > C-GMDV > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407592#407592 > > ________________________________________________________________________________
Date: Aug 27, 2013
Living and flying in the DC area I wish it were quite that easy for airports inside the Flight Restricted Zone (FRZ). The FRZ is the inside circular ar ea centered on DCA. Flying into the three GA airports inside the FRZ requir es a background clearance prior to your flight. If memory serves, and I may be incorrect, you have to apply for that clearance in person. I had a one t ime clearance into Andrews AFB to display my RV-8 at their annual open house . I'll never do that again. If you want to get in close to DC I would sugg est Gaithersburg as a better alternative. It's inside the SFRA but not the FRZ. It's relatively close to the metro or an easy drive to DC. You still n eed an SFRA flight plan etc but otherwise, as Tim said, it just takes a litt le planning...and the online course certificate. Leesburg is another good c hoice but will require a rental car or a very expensive cab ride to get into DC. Rick McBride On Aug 27, 2013, at 4:35 PM, Timothy Meyer wrote: > Don't know about the Hudson area. But you can take an online course to go o ver the Special VFR airspace surrounding the DC area here. > > https://www.faasafety.gov/gslac/ALC/course_content.aspx?cID=55&preview= true > > Just need to plan ahead and communicate with ATC prior to entering. > > Tim > > Sent from my iPhone > > On Aug 27, 2013, at 3:06 PM, "ivankris" wrote: > >> >> Next week I have a couple of old friends from Europe coming to visit me h ere in Canada and I am planning to take them on a "Trip of a Life Time" (at l east for them) in my RV-10 down the Hudson River NY. VFR corridor and then o nto Washington DC for a couple of days. >> >> I did this trip about 20 years ago in a Comanche so I am sure there has b een some changes in the rules since then. >> >> If anyone out there has flown this this trip in the last year or so and w ould share some of the Do's and Dont's with me I would sure appreciate it. >> >> What airport in the NY area is a good one to launch from to do the Hudson corridor? >> >> What publications and charts do I need and where is the best place to get them? >> >> As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is of f limits to private aircraft operations? >> >> -------- >> Ivan Kristensen. >> >> www.ivankristensen.com >> Builder # 40838 >> Flying (430hrs.) >> C-GMDV >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=407592#407592 >> >> >> >> http://ww====================== ====; - MATRONICS WEBref="http://forums.matronics.com">ht tp://forums.matronics.comhttp://www.matronics.com/contribution > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 27, 2013
Take the on line course first, then go for it. I did it north to south about two years ago and it was, at that time, a VFR at 1000-1300', enter at specific points, announce position at specific points, and depart at specific point type of flight, much like the pattern at an uncontrolled field. My mistake was that I should have turned back instead of leaving, flown it in reverse then turned and made one more pass. It is indeed a trip of a life time for many of us. Albert Gardner N991RV Yuma AZ ---- Timothy Meyer wrote: > Don't know about the Hudson area. But you can take an online course to go over the Special VFR airspace surrounding the DC area here. > > https://www.faasafety.gov/gslac/ALC/course_content.aspx?cID=55&preview=true > > Just need to plan ahead and communicate with ATC prior to entering. > > Tim > > Sent from my iPhone > > On Aug 27, 2013, at 3:06 PM, "ivankris" wrote: > > > > > Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. > > > > I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. > > > > If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. > > > > What airport in the NY area is a good one to launch from to do the Hudson corridor? > > > > What publications and charts do I need and where is the best place to get them? > > > > As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? > > > > -------- > > Ivan Kristensen. > > > > www.ivankristensen.com > > Builder # 40838 > > Flying (430hrs.) > > C-GMDV > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=407592#407592 > > > > > > > > > > > > > > > =================================== > =================================== > =================================== > =================================== > > > > > > ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Aug 27, 2013
There is also a course for flying the Hudson, if I recall correctly it is required. We fly into KTEB, even if it is more expensive. Well worth the effort! - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407603#407603 ________________________________________________________________________________
Date: Aug 27, 2013
For flying the Hudson there is a lot if information on the web such as: https://www.faasafety.gov/files/gslac/courses/content/79/775/kneeboard.pdf Recommend flying north to south. If you have enough gas then skip the stop in New York. If not, Westchester County (HPN) is one I have used. Fly from there to the Tappan Zee bridge and turn south down the Hudson. You will need the New York Terminal Area chart http://www.mypilotstore.com/MyPilotStore/chart/FAA_VFR_Terminal_Area_Charts. asp along with your other standard charts. For the DC visit, there are options inside and outside the SFRA. As noted, you are required to do the on line course even if you are just in the area. For airports your selection should depend on what you want to do. If you want close to DC, your options are limited. If you are ok with being outside the area but access to a commuter train to take you down town, there is Stafford Airport (KRMN) near Fredericksburg, VA. You can catch the VRE commuter train at a few locations in the area http://www.vre.org/ Note - VRE runs north only in the morning and south only in the afternoon, Monday-Friday only and no holidays. I believe you can also stay near Frederick airport (KFDK) in Maryland and ride the MARC commuter train to downtown DC. I believe it only runs Monday-Friday as well. If you want to drive downtown more options are of course available. I'm at Dogwood Airpark (VA42) a couple of miles from Stafford airport. Please let me know if I can help. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Timothy Meyer Sent: Tuesday, August 27, 2013 4:36 PM Subject: Re: RV10-List: Flying the Hudson through NY and to Washington DC. Don't know about the Hudson area. But you can take an online course to go over the Special VFR airspace surrounding the DC area here. https://www.faasafety.gov/gslac/ALC/course_content.aspx?cID=55 &preview=true Just need to plan ahead and communicate with ATC prior to entering. Tim Sent from my iPhone On Aug 27, 2013, at 3:06 PM, "ivankris" wrote: Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. What airport in the NY area is a good one to launch from to do the Hudson corridor? What publications and charts do I need and where is the best place to get them? As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? -------- Ivan Kristensen. www.ivankristensen.com Builder # 40838 Flying (430hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407592#407592 http://ww==========================; <http://www.matronics.com/Navigator?RV10-List> - MATRONICS WEBref="http://forums.matronics.com">http://forums.matronics.comhttp://www.m atronics.com/contribution ________________________________________________________________________________
Date: Aug 27, 2013
If you are going to that area, I'd suggest Caldwell over Teterboro. You will still get a landing fee bill in the mail($10), but the gas is much less, and you won't be in the middle of a bunch of kerosene burners. Just as close to the City. On 8/27/2013 2:45 PM, jkreidler wrote: > > There is also a course for flying the Hudson, if I recall correctly it is required. We fly into KTEB, even if it is more expensive. Well worth the effort! - Jason > > -------- > Jason Kreidler > 4 Partner Build - Sheboygan Falls, WI > Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler > N44YH - Flying - #40617 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407603#407603 > > ________________________________________________________________________________
Date: Aug 27, 2013
For DC: I flew into/out of College Park many years ago - it was fun - cleared into class B and flew up the Anacostia river right by the Capitol and into College Park. Then catch the metro and go downtown for the day; to the Air and Space museum, and then fly back to North Carolina all in one day. But check out this link for the procedure you would have to follow to do it today. Its a fun read. Sad its come to this. <http://www.collegeparkairport.org/vetting.html> Have fun, I would recommend Gaithersburg too, instead of the above procedure. For NY: Watch this video it might be helpful and its well done and they are using the skyline route. -Chris Lucas N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ivankris Sent: Tuesday, August 27, 2013 4:07 PM Subject: RV10-List: Flying the Hudson through NY and to Washington DC. Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. What airport in the NY area is a good one to launch from to do the Hudson corridor? What publications and charts do I need and where is the best place to get them? As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? -------- Ivan Kristensen. www.ivankristensen.com Builder # 40838 Flying (430hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407592#407592 ________________________________________________________________________________
Date: Aug 27, 2013
Subject: Rv-14 and BBQ at the Watsonville Fly-In this weekend.
Van's Aircraft is bringing the RV-14 to the Watsonville Airshow this Labor Day Weekend, Aug. 31- Sept. 1. They will have the aircraft on display Saturday all day and Sunday morning. A representative from Vans will be around to answer questions. Saturday evening, from 5:30 -- 7pm, Aircrafters will be hosting a BBQ with hamburgers, hot dogs and veggie burgers for all the Pilots and Passengers of Experimental Aircraft that have flown in for the show. We will have the RV-14 at the hanger at that time as well. Also come to see some new RV-10 and the RV-8 aircraft. RSVP to bbq(at)aircraftersllc.com or by phone at 831-722-9141 Thanks, Tim -- Tim Farrell - Aircrafters - Owner/Manager - (831) 722-9141 - www.aircraftersLLC.com ________________________________________________________________________________
Date: Aug 28, 2013
Ivan I don't know if you received my last post but a reminder to make sure that the NY Yankees are not playing when you fly the Hudson corridor. There will be a TFR for the game and flight service doesn't warn you about it. The TFR extends in the corridor and you will get busted On Tuesday, August 27, 2013, Chris wrote: > > > > For DC: I flew into/out of College Park many years ago - it was fun - > cleared into class B and flew up the Anacostia river right by the Capitol > and into College Park. Then catch the metro and go downtown for the day; to > the Air and Space museum, and then fly back to North Carolina all in one > day. But check out this link for the procedure you would have to follow to > do it today. Its a fun read. Sad its come to this. > > <http://www.collegeparkairport.org/vetting.html> > > Have fun, I would recommend Gaithersburg too, instead of the above > procedure. > > For NY: Watch this video it might be helpful and its well done and they are > using the skyline route. > > > -Chris Lucas > N919AR > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com <javascript:;> > [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of > ivankris > Sent: Tuesday, August 27, 2013 4:07 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Flying the Hudson through NY and to Washington DC. > > > > > Next week I have a couple of old friends from Europe coming to visit me > here > in Canada and I am planning to take them on a "Trip of a Life Time" (at > least for them) in my RV-10 down the Hudson River NY. VFR corridor and then > onto Washington DC for a couple of days. > > I did this trip about 20 years ago in a Comanche so I am sure there has > been > some changes in the rules since then. > > If anyone out there has flown this this trip in the last year or so and > would share some of the Do's and Dont's with me I would sure appreciate it. > > What airport in the NY area is a good one to launch from to do the Hudson > corridor? > > What publications and charts do I need and where is the best place to get > them? > > As far as airports in the DC area I am thinking about College Park (KCGS) > but it falls within the vail of a current TFR. Does that mean that it is > off > limits to private aircraft operations? > > -------- > Ivan Kristensen. > > www.ivankristensen.com > Builder # 40838 > Flying (430hrs.) > C-GMDV > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407592#407592 > > ________________________________________________________________________________
Date: Aug 28, 2013
Good Grief! I'm planning a trip from the Atlanta Area to New Jersey in a couple of weeks. I had planned to fly around DC, but that 60 mile arc would force me into the mountains! The coastal way would have me dodging restricted areas and a lot of water. There are a few Victor Airways around it but they all penetrate that 60 mile arc. I have no interest in seeing DC, I used to live there when it was fun to fly. What do the locals recommend? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407629#407629 ________________________________________________________________________________
Date: Aug 28, 2013
I've done the NYC corridor a number of times - years ago and recently. Amazingly not much has changed except that the options are better documented now. Others have provided the links. You basically want to decide whether you want to fly underneath in the VFR corridor or in the Class B a couple of hundred feet higher. Either is a visual flight of a lifetime. There can be a lot of traffic which makes the Class B route preferable for me but either way works well. Pilots tend to obey the rules of the road relative to altitudes and sides of the river and position announcements in the VFR section. Flying south to north allows you to practically over fly the WTC memorial site. The fact that you can do that is amazing in itself. It also puts your passengers on the scenic side of the plane. You can go low and take a circle around the Statue of Liberty - that's a notch on the stick for you and the passengers. It's a good time to stock up on some lightweight floatation devices for the plane. I felt I owed it to my passengers to have them onboard and available even if I didn't fully brief them before the flight. I go in and out of KHPN and highly recommend Panorama Flight Service if you stop. If it fits your purposes, a low flight up the Hudson with a landing at KHPN, followed by a normal altitude IFR/VFR departure south generally results in vectors directly over JFK and an excellent high altitude view of NYC. I've done DC before and after too. Used to be accessible and fun. Now, not so much. Not sure if there is anything resembling a scenic flight. Access to the several layers of airports you can fly in and out of is strictly managed and there is zero tolerance for deviations. I used to go into Potomac and/or Hyde (forget which) but you need to go thru a security procedure well in advance now. Recently, I've been flying in and out of KANP - nothing to recommend or not recommend there. A flight into W29 is Cheasapeake Bay scenic and there are crab places nearby. I used to go into Kentmorr 3W3 for crabs at the marina but haven't taken the '10 in the grass there yet. Don't know much else. You'll always have NYC.... Enjoy! On 8/27/2013 4:06 PM, ivankris wrote: > > Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. > > I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. > > If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. > > What airport in the NY area is a good one to launch from to do the Hudson corridor? > > What publications and charts do I need and where is the best place to get them? > > As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? > > -------- > Ivan Kristensen. > > www.ivankristensen.com > Builder # 40838 > Flying (430hrs.) > C-GMDV > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407592#407592 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Aug 28, 2013
John depending on where in Atlanta your coming from V1 with keep you clear of of all the trouble. On Wednesday, August 28, 2013, johngoodman wrote: > > > > Good Grief! > I'm planning a trip from the Atlanta Area to New Jersey in a couple of > weeks. I had planned to fly around DC, but that 60 mile arc would force me > into the mountains! The coastal way would have me dodging restricted areas > and a lot of water. > There are a few Victor Airways around it but they all penetrate that 60 > mile arc. I have no interest in seeing DC, I used to live there when it was > fun to fly. What do the locals recommend? > > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407629#407629 > > ________________________________________________________________________________
Date: Aug 28, 2013
You're right, V1 will do the trick. It'll add a few miles but I think a fuel stop would be prudent in the Norfolk area. Thanks, John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407639#407639 ________________________________________________________________________________
Date: Aug 28, 2013
John if your making a fuel stop by Norfolk KSFQ ($ 5.20) or KCPK ($ 5.79) both right off V1. I have flown Into CPK nice airport friendly people. Haven't flown into SFQ but for .50 a gallon it might be worth the stop. Double check the fuel prices, I got it off of foreflight. What part of New Jersey are you flying into? Have fun on the trip if there is anything else I can help you with don't hesitate to ask. John Z On Wednesday, August 28, 2013, johngoodman wrote: > > > > You're right, V1 will do the trick. It'll add a few miles but I think a > fuel stop would be prudent in the Norfolk area. Thanks, > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407639#407639 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Aug 28, 2013
The SFRA (where you need a clearance and specific squawk code) is 30nmi radius from DCA. Between 30nmi and 60nmi is a speed restriction area only (you will not be going fast enough unless you burning Jet A). No clearance is needed in that area. Just stay out of the SFRA, mind the restricted areas and fly. I do recommend flight following if VFR, especially if you are unfamiliar with the area. Don't forget to take the on line FAA SFRA course (required if you are within 60nmi of DCA - even if you don't want to enter the SFRA): https://www.faasafety.gov/gslac/ALC/course_content.aspx?cID=55&preview=true Carl RV-10, 120 hours RV-8A, sold -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Wednesday, August 28, 2013 10:43 AM Subject: RV10-List: Re: Flying the Hudson through NY and to Washington DC. --> Good Grief! I'm planning a trip from the Atlanta Area to New Jersey in a couple of weeks. I had planned to fly around DC, but that 60 mile arc would force me into the mountains! The coastal way would have me dodging restricted areas and a lot of water. There are a few Victor Airways around it but they all penetrate that 60 mile arc. I have no interest in seeing DC, I used to live there when it was fun to fly. What do the locals recommend? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407629#407629 ________________________________________________________________________________
Date: Aug 28, 2013
Do the online course. It's not difficult. Doesn't take too long. Then you are all set. I've flown around the east and west side depending on where I'm going and have had no issues. However, I have been asked by briefers and controllers if I was familiar with the procedures. Also be familiar with and have current charting for all the restricted areas. I have been asked to confirm my intentions with respect to how I was avoiding various areas. So situational awareness was critical. Overall my experience with Potomac approach has been excellent and easier to work with than the class B monster to the northeast. The Philly/ NY area is really busy and can be overwhelming at times. Bob Newman N541RV On Aug 28, 2013, at 10:42 AM, "johngoodman" wrote: > > Good Grief! > I'm planning a trip from the Atlanta Area to New Jersey in a couple of weeks. I had planned to fly around DC, but that 60 mile arc would force me into the mountains! The coastal way would have me dodging restricted areas and a lot of water. > There are a few Victor Airways around it but they all penetrate that 60 mile arc. I have no interest in seeing DC, I used to live there when it was fun to fly. What do the locals recommend? > > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=407629#407629 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 28, 2013
Subject: Plane Power Alternator Fail
I have had my alternator fail after 570 hours. Just stopped producing any power. Its the Plane Power alternator supplied with Vans FWF kit. Couple of questions: (1) How ore others doing with the Plane Power alternators (MTBF?) (2) Is there a local automotive alternative that is a bolt in replacement? (Autozone, Napa, Online source?) (3) Any ideas as to what the typical failure mechanism is? Just curious Jim Combs N312F - 570 Hours ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Aug 28, 2013
Subject: Seat Adjuster Extensions
A while back I said we'd make a run of seat adjuster extension posts. We have stock now and they're available to purchase from our web site: http://www.aircraftersllc.com/products.html?id=shop?id=products I said $30/set, and we'll hold that price for a month or so but they'll probably go up, so get'em cheap! Dave Saylor 831-750-0284 CL ________________________________________________________________________________
Date: Aug 28, 2013
Subject: Re: Plane Power Alternator Fail
I had one turn on the low voltage light after a few hundred hours, even though the output voltage was correct. When it came back it had a different style housing on the back. That was a few years ago and it still seems to be the current style. What did PP say? I'd be kind of surprised if they charged to fix it. We've installed many with just that one issue. Dave Saylor 831-750-0284 CL On Wed, Aug 28, 2013 at 1:57 PM, Jim Combs wrote: > I have had my alternator fail after 570 hours. Just stopped producing any > power. Its the Plane Power alternator supplied with Vans FWF kit. Couple > of questions: > > (1) How ore others doing with the Plane Power alternators (MTBF?) > > (2) Is there a local automotive alternative that is a bolt in replacement? > (Autozone, Napa, Online source?) > > (3) Any ideas as to what the typical failure mechanism is? > > Just curious > > Jim Combs > N312F - 570 Hours > > > * > > * > > ________________________________________________________________________________
Subject: FWF Hoses
Date: Aug 28, 2013
I=99m ordering up FWF parts and I talked to Vans about their hoses. They are now shipping all the FWF hoses as the integral fire-sleeve/Teflon type, not just the fuel lines as in the past. Has anyone received the the new hoses from Vans than can comment on the quality of the hoses? I planned on having them made, but if Vans can supply them, all the better. Thanks Chris Hukill ________________________________________________________________________________
Date: Aug 28, 2013
Give them a call... they're all good guys and great friends.- to my knowl edge they are always very fair.... Don McDonald=0A=0A=0A=0A=0A_____________ ___________________=0A From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com >=0ATo: "rv10-list(at)matronics.com" =0ASent: Wednes day, August 28, 2013 4:08 PM=0ASubject: Re: RV10-List: Plane Power Alternat or Fail=0A =0A=0A=0AI had one turn on the low voltage light after a few hun dred hours, even though the output voltage was correct.=0A=0AWhen it came b ack it had a different style housing on the back. -That was a few years a go and it still seems to be the current style.=0A=0AWhat did PP say? -I'd be kind of surprised if they charged to fix it. -We've installed many wi th just that one issue.=0A=0A=0ADave Saylor=0A831-750-0284 CL=0A=0A=0AOn We d, Aug 28, 2013 at 1:57 PM, Jim Combs wrote:=0A=0AI have had my alternator fail after 570 hours.- Just stopped producing any power.-- Its the Plane Power alternator supplied with Vans FWF kit.- Couple of questions:=0A>=0A>=0A(1) How ore others doing with the Plane Powe r alternators (MTBF?) =0A>=0A>(2) Is there a local automotive alternative t hat is a bolt in replacement? (Autozone, Napa, Online source?)=0A>=0A>(3) A ny ideas as to what the typical failure mechanism is?=0A>=0A>Just curious =0A>=0A>Jim Combs=0A>N312F - 570 Hours=0A>=0A>=0A>=0A>=0A>get="_blank">ht tp://www.matronics.com/Navigator?RV10-List=0Atp://forums.matronics.com=0A_b ==== ________________________________________________________________________________
Subject: Re: FWF Hoses
Date: Aug 28, 2013
Chris and all... We would be happy to help you with your hoses. We have hundreds of RVs usi ng our hoses. They are conductive Teflon which means that they have no max s ervice life. In addition we make them to your specs. We have found that ev eryone does their routings slightly different. While the vans hoses will fi t, they may not fit the way you want. We have more information at www.aircraftspecialty.com Or www.kitplanehoses.com Have a great day Steve Sent from my iPhone On Aug 28, 2013, at 16:37, "Chris Hukill" wrote: > I=99m ordering up FWF parts and I talked to Vans about their hoses. T hey are now shipping all the FWF hoses as the integral fire-sleeve/Teflon t ype, not just the fuel lines as in the past. Has anyone received the the new hoses from Vans than can comment on the quality of the hoses? I planned on h aving them made, but if Vans can supply them, all the better. > Thanks > Chris Hukill > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 28, 2013
Subject: HS-910
I think I have finally come to a step in the build where, no mater how hard I try, I cannot complete. Installing the horizontal stabilizer end cap fairings has got me completely frustrated. I have been working on one for probably 40 hours now and don't see the end in sight. I first had issues with the fiberglass cloth adhering to the outside of the fairing. Since its a knife like edge, it would de-bond every time I tried to remove the temporary foam rib. I then decided to just leave the foam rib and glass it in place. That seemed to do the trick and everything looked great until I clecoed it in place. I have interference in the middle of the outside layer of cloth. I could just sand an 1/8" dimple in the middle, but that doesn't seem right. This is the first step where I am absolutely stumped as how to proceed. Does anyone out there make aftermarket, complete hs-910? If not, what is the trick I am missing here. Shannon ________________________________________________________________________________
Date: Aug 28, 2013
Don knows all to well that Plane Power is a good group of folks. My starter failed within hours of the first flight. They shipped me a new starter the same day, well actually they personally delivered it to a RV-10 pilot who delivered it to me. No charge (I did need to leave a deposit, which was never posted, pending the replacement be returned) Good honest folks. To boot they even had the RV-10 pilot help me replace the starter and take the old one back. I=99m in California, they are next to Don in Texas.. If anyone is wondering how much the whole process cost me? and now.. the rest of the story... Having a great friend that was coming out the next day to visit and lives next to the owners- priceless! not to mention, but I will anyway, the timing for this failure was perfect.. and I like re-telling this story anyway. In the end, even before I mentioned names, Plane Power was first rate in taking care of my concern and issue. Their technician spent well over 1 hour with me troubleshooting the issue. Call them, if you haven't already! Pascal From: Don McDonald Sent: Wednesday, August 28, 2013 3:19 PM Subject: Re: RV10-List: Plane Power Alternator Fail Give them a call... they're all good guys and great friends. to my knowledge they are always very fair.... Don McDonald ------------------------------------------------------------------------- ------- From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com> Sent: Wednesday, August 28, 2013 4:08 PM Subject: Re: RV10-List: Plane Power Alternator Fail I had one turn on the low voltage light after a few hundred hours, even though the output voltage was correct. When it came back it had a different style housing on the back. That was a few years ago and it still seems to be the current style. What did PP say? I'd be kind of surprised if they charged to fix it. We've installed many with just that one issue. Dave Saylor 831-750-0284 CL On Wed, Aug 28, 2013 at 1:57 PM, Jim Combs wrote: I have had my alternator fail after 570 hours. Just stopped producing any power. Its the Plane Power alternator supplied with Vans FWF kit. Couple of questions: (1) How ore others doing with the Plane Power alternators (MTBF?) (2) Is there a local automotive alternative that is a bolt in replacement? (Autozone, Napa, Online source?) (3) Any ideas as to what the typical failure mechanism is? Just curious Jim Combs N312F - 570 Hours get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Aug 28, 2013
Subject: Re: HS-910
Shannon, feel free to give me a call. I think I can talk you through it. A couple little tricks make the fiberglass a lot easier. Dave Saylor =8BAirCrafters 831-750-0284 CL On Wed, Aug 28, 2013 at 3:45 PM, Shannon Hicks wrote: > I think I have finally come to a step in the build where, no mater how > hard I try, I cannot complete. > > Installing the horizontal stabilizer end cap fairings has got me > completely frustrated. I have been working on one for probably 40 hours n ow > and don't see the end in sight. I first had issues with the fiberglass > cloth adhering to the outside of the fairing. Since its a knife like edge , > it would de-bond every time I tried to remove the temporary foam rib. I > then decided to just leave the foam rib and glass it in place. That seeme d > to do the trick and everything looked great until I clecoed it in place. I > have interference in the middle of the outside layer of cloth. I could ju st > sand an 1/8" dimple in the middle, but that doesn't seem right. > > This is the first step where I am absolutely stumped as how to proceed. > > Does anyone out there make aftermarket, complete hs-910? If not, what is > the trick I am missing here. > > Shannon > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Subject: Re: HS-910
Date: Aug 28, 2013
I just sent him an email ( from his posting on VAF) explaining the tips you s hared with me four or five years ago. It just seems like yesterday when I t ook the class at your shop. Time sure flies when you're having fun. Sent from my iPad On Aug 28, 2013, at 6:55 PM, Dave Saylor wrote: > Shannon, feel free to give me a call. I think I can talk you through it. A couple little tricks make the fiberglass a lot easier. > > Dave Saylor > =8BAirCrafters > 831-750-0284 CL > > > On Wed, Aug 28, 2013 at 3:45 PM, Shannon Hicks wrote : >> I think I have finally come to a step in the build where, no mater how ha rd I try, I cannot complete. >> >> Installing the horizontal stabilizer end cap fairings has got me complete ly frustrated. I have been working on one for probably 40 hours now and don' t see the end in sight. I first had issues with the fiberglass cloth adherin g to the outside of the fairing. Since its a knife like edge, it would de-bo nd every time I tried to remove the temporary foam rib. I then decided to ju st leave the foam rib and glass it in place. That seemed to do the trick and everything looked great until I clecoed it in place. I have interference in the middle of the outside layer of cloth. I could just sand an 1/8" dimple i n the middle, but that doesn't seem right. >> >> This is the first step where I am absolutely stumped as how to proceed. >> >> Does anyone out there make aftermarket, complete hs-910? If not, what is t he trick I am missing here. >> >> Shannon >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Aug 28, 2013
Subject: Re: HS-910
I just got off of the phone with Dave and have a much better idea on how to proceed. It is amazing how something so small can derail a project. Thanks for the help! On Aug 28, 2013 6:27 PM, "Bob Leffler" wrote: > I just sent him an email ( from his posting on VAF) explaining the tips > you shared with me four or five years ago. It just seems like yesterday > when I took the class at your shop. Time sure flies when you're having > fun. > > Sent from my iPad > > On Aug 28, 2013, at 6:55 PM, Dave Saylor < > dave.saylor.aircrafters(at)gmail.com> wrote: > > Shannon, feel free to give me a call. I think I can talk you through it. > A couple little tricks make the fiberglass a lot easier. > > Dave Saylor > AirCrafters > 831-750-0284 CL > > > On Wed, Aug 28, 2013 at 3:45 PM, Shannon Hicks wrote: > >> I think I have finally come to a step in the build where, no mater how >> hard I try, I cannot complete. >> >> Installing the horizontal stabilizer end cap fairings has got me >> completely frustrated. I have been working on one for probably 40 hours now >> and don't see the end in sight. I first had issues with the fiberglass >> cloth adhering to the outside of the fairing. Since its a knife like edge, >> it would de-bond every time I tried to remove the temporary foam rib. I >> then decided to just leave the foam rib and glass it in place. That seemed >> to do the trick and everything looked great until I clecoed it in place. I >> have interference in the middle of the outside layer of cloth. I could just >> sand an 1/8" dimple in the middle, but that doesn't seem right. >> >> This is the first step where I am absolutely stumped as how to proceed. >> >> Does anyone out there make aftermarket, complete hs-910? If not, what is >> the trick I am missing here. >> >> Shannon >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > > ================================== > ://www.matronics.com/Navigator?RV10-List > ===================================cs.com > ===================================matronics.com/contribution > ================================== > * > > * > > * > > ________________________________________________________________________________
Date: Aug 28, 2013
forgot link. -----Original Message----- From: Chris [mailto:toaster73(at)embarqmail.com] Sent: Tuesday, August 27, 2013 8:11 PM Subject: RE: RV10-List: Flying the Hudson through NY and to Washington DC. For DC: I flew into/out of College Park many years ago - it was fun - cleared into class B and flew up the Anacostia river right by the Capitol and into College Park. Then catch the metro and go downtown for the day; to the Air and Space museum, and then fly back to North Carolina all in one day. But check out this link for the procedure you would have to follow to do it today. Its a fun read. Sad its come to this. <http://www.collegeparkairport.org/vetting.html> Have fun, I would recommend Gaithersburg too, instead of the above procedure. For NY: Watch this video it might be helpful and its well done and they are using the skyline route. -Chris Lucas N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ivankris Sent: Tuesday, August 27, 2013 4:07 PM Subject: RV10-List: Flying the Hudson through NY and to Washington DC. Next week I have a couple of old friends from Europe coming to visit me here in Canada and I am planning to take them on a "Trip of a Life Time" (at least for them) in my RV-10 down the Hudson River NY. VFR corridor and then onto Washington DC for a couple of days. I did this trip about 20 years ago in a Comanche so I am sure there has been some changes in the rules since then. If anyone out there has flown this this trip in the last year or so and would share some of the Do's and Dont's with me I would sure appreciate it. What airport in the NY area is a good one to launch from to do the Hudson corridor? What publications and charts do I need and where is the best place to get them? As far as airports in the DC area I am thinking about College Park (KCGS) but it falls within the vail of a current TFR. Does that mean that it is off limits to private aircraft operations? -------- Ivan Kristensen. www.ivankristensen.com Builder # 40838 Flying (430hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407592#407592 ________________________________________________________________________________
Date: Aug 29, 2013
I went ahead and did the course. Not bad and it did clear up a number of questions. The sad part is the "Maryland 3" - I used to fly VFR between them back in the '60s.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407729#407729 ________________________________________________________________________________
Subject: Re: HS-910
Date: Aug 29, 2013
Hi Shannon, I'm sure by now you have all the tips and tricks required. To give you more trouble deciding, here's how I did it. Lay up a fibreglass sheet using 2 or 3 layers of thin (circa 200gsm) glass cloth on a flat surface, with release agent on one side and peel ply on the other, weight it down and let it cure. Take the HS / rudder fairing and cut out the sheet so it is about 1/2" oversize all round. Tape the sheet to the fairing with the rough surface (peel ply removed) on the inside of the fairing. Bond it using additional glass cloth and glass tape around the edges. The glass sheet obviously has to be flexible enough to adapt to the curved rear edges of the fairing. After laying up the cured sheet to the fairings, I clecoed the fairings to the HS with the elevator installed and wedged a sheet of 1/8" to 3/16" thick foam between the elevator horn and the sheet to hold it in place while the bond cured. That way the gap was guaranteed and they even took a nice slightly concave shape conforming to the elevator horns. Afterwards trim and sand around the outside. Have fun! Gordon 41015 Switzerland On Aug 29, 2013, at 12:45 AM, Shannon Hicks wrote: > I think I have finally come to a step in the build where, no mater how hard I try, I cannot complete. > > Installing the horizontal stabilizer end cap fairings has got me completely frustrated. I have been working on one for probably 40 hours now and don't see the end in sight. I first had issues with the fiberglass cloth adhering to the outside of the fairing. Since its a knife like edge, it would de-bond every time I tried to remove the temporary foam rib. I then decided to just leave the foam rib and glass it in place. That seemed to do the trick and everything looked great until I clecoed it in place. I have interference in the middle of the outside layer of cloth. I could just sand an 1/8" dimple in the middle, but that doesn't seem right. > > This is the first step where I am absolutely stumped as how to proceed. > > Does anyone out there make aftermarket, complete hs-910? If not, what is the trick I am missing here. > > Shannon > > > ________________________________________________________________________________
Subject: Oil choice
Date: Aug 30, 2013
So after decades of blissfully thinking I was doing the right thing for my aircraft engines by feeding them Aeroshell 15W50, it now is being called evil stuff by knowledgeable folks like Mike Busch. Is there general consensus that Phillips 15W50 is better as a multiviscosity oil for our IO-540's? And if using that does it have to be supplemented by Camguard to add back the Lycoming 'snake oil' additive to protect the parts that are only splash lubricated? Not trying to set off oilfield flame wars but have the feeling that somehow I missed something... -Dan Masys N104LD 620 hrs TTSN ________________________________________________________________________________
Subject: Re: Oil choice
Date: Aug 30, 2013
15w-50 is for radial, get the XC 20w-50. I used it for well over 100 hours- straight, than I used it adding camguard, now I use Aeroshell with camguard. Ask yourself, where are you located (if 100 miles from ocean and in warmer climates, like myself in So California, I could use the Aerosheel w100 year round, I'll switch to phillips for the winter anyway, in case I go up to the mountains 20 minutes away. If you fly often, and/or not near ocean or corrosion prone areas, skip the camguard. basically everything Mike comments on on his webinar. Pascal -----Original Message----- From: Dan Masys Sent: Friday, August 30, 2013 10:51 AM Subject: RV10-List: Oil choice So after decades of blissfully thinking I was doing the right thing for my aircraft engines by feeding them Aeroshell 15W50, it now is being called evil stuff by knowledgeable folks like Mike Busch. Is there general consensus that Phillips 15W50 is better as a multiviscosity oil for our IO-540's? And if using that does it have to be supplemented by Camguard to add back the Lycoming 'snake oil' additive to protect the parts that are only splash lubricated? Not trying to set off oilfield flame wars but have the feeling that somehow I missed something... -Dan Masys N104LD 620 hrs TTSN ________________________________________________________________________________
Date: Aug 30, 2013
The problem with AS 15-50 is that it is 50% synthetic oil which does not keep solids suspended. It does contain the Lycoming addidtive. You do NOT need the Lycoming additive. It is for the "76" series engines like the O-320-H2AD that had very different cam and lifters than what your IO-540 has. The Lycoming additive is a version of tricresyl Phospate, or TCP, and is an extreme pressure lubricant. Later replaced by close cousin TPP. Phillips does not have that additive, and I don't think Camguard does either. Camguard is primarily an anti-corrosive, which is helpful in preventing pitting on the cam. The Phillips/Camguard combo gives best anti-corrosion protection. The Phillips is all mineral based, no synthetics. On Fri, Aug 30, 2013 at 10:51 AM, Dan Masys wrote: > > So after decades of blissfully thinking I was doing the right thing for my > aircraft engines by feeding them Aeroshell 15W50, it now is being called > evil stuff by knowledgeable folks like Mike Busch. Is there general > consensus that Phillips 15W50 is better as a multiviscosity oil for our > IO-540's? > > And if using that does it have to be supplemented by Camguard to add back > the Lycoming 'snake oil' additive to protect the parts that are only splash > lubricated? > > Not trying to set off oilfield flame wars but have the feeling that somehow > I missed something... > > -Dan Masys > N104LD 620 hrs TTSN > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Aug 31, 2013
Jim, What did you find out caused the failure of your PP Alternator Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407810#407810 ________________________________________________________________________________
Subject: RV-10 Empemmage Kit for Sale
Date: Sep 01, 2013
I have an RV-10 Empennage Kit for sale (s/n 40492). The Vertical Stab and Rudder are complete, the Horizontal stab is ready for finally assembly. Excellent craftsmanship reviewed by A&P. I'm asking $2,900 OBO. I also have several sheet metal tools (c-frame dimpler, rivet guns, etc.) that I am willing to sell as well. Kit is located in Southern California. e-mail me at mj.swanson(at)sbcglobal.net for pics and additional info. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407854#407854 ________________________________________________________________________________
Subject: Nose gear leg fairing
Date: Sep 01, 2013
I have noticed some apparent heat damage around my nose gear strut fairing right around the area where it exits the cowling to the first screw that attaches it to the gear leg. Seems like the fiberglass has gotten a little warm and changed shape with some of the weave showing through the paint. Have others seen this or know what can be done to prevent it?? Thanks Chris Lucas N919AR ________________________________________________________________________________
Subject: G430W Tray
Date: Sep 01, 2013
I have a tray with back plate and 2 little screws that hold the back plate to the tray. If anyone wants to buy it for $100, let me know with a personal email. -Chris ________________________________________________________________________________
Subject: Re: Nose gear leg fairing
Date: Sep 01, 2013
Posting some photos would be helpful to assist in answering your question. Are you sure that it is heat, or could it be that the fairing is in a bind when it is installed and it's trying to twist? I haven't noticed anything on mine indicating heat was an issue. Do you have any reflective heat mat on the lower cowling? -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407884#407884 ________________________________________________________________________________
Date: Sep 01, 2013
Yep I have reflective mat on the cowl bottom - I should have attached a picture, I'll try to get a photo tomorrow. -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Sunday, September 01, 2013 9:08 PM Subject: RV10-List: Re: Nose gear leg fairing Posting some photos would be helpful to assist in answering your question. Are you sure that it is heat, or could it be that the fairing is in a bind when it is installed and it's trying to twist? I haven't noticed anything on mine indicating heat was an issue. Do you have any reflective heat mat on the lower cowling? -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407884#407884 ________________________________________________________________________________
Date: Sep 02, 2013
Here are the pictures. I am wondering if hot air is coming in from the top and kind of dead heading at the screw attach triangles on the leg - or the whole leg has a lot of heat too. -Chris N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Sunday, September 01, 2013 11:00 PM Subject: RE: RV10-List: Re: Nose gear leg fairing Yep I have reflective mat on the cowl bottom - I should have attached a picture, I'll try to get a photo tomorrow. -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Sunday, September 01, 2013 9:08 PM Subject: RV10-List: Re: Nose gear leg fairing Posting some photos would be helpful to assist in answering your question. Are you sure that it is heat, or could it be that the fairing is in a bind when it is installed and it's trying to twist? I haven't noticed anything on mine indicating heat was an issue. Do you have any reflective heat mat on the lower cowling? -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407884#407884 ________________________________________________________________________________
Date: Sep 02, 2013
It almost looks like the nose gear leg brackets are distorting the fairing. Almost like the front of the fairing is resting on the gear leg to deeply. My 4 Attachment screws are much closer to the hinge edge of The fairing than yours. I don't have any photos, but I will take a look this week and see if that's the case. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407944#407944 ________________________________________________________________________________
Date: Sep 02, 2013
Hey Chris, It sure looks like heat concentrating at the screw -- checked for exhaust leaks, heat muffler leaks? Have you also checked for fuel overflow (hot start flooding, etc.)? There would probably be fuel discoloring if that were the case. Later, - Lew -----Original Message----- From: Chris Sent: Monday, September 02, 2013 7:10 PM Subject: RE: RV10-List: Re: Nose gear leg fairing Here are the pictures. I am wondering if hot air is coming in from the top and kind of dead heading at the screw attach triangles on the leg - or the whole leg has a lot of heat too. -Chris N919AR ________________________________________________________________________________
Date: Sep 02, 2013
While there is typically a negative pressure gradient that sets up cowl exhaust air to go down the nose gear fairing to the nose wheel pant, I suspect this is not heat damage as much as the fastener working the fairing. Looking at the photo, you have the same situation I had on my plane - the fairing needs to have a backing on it so that you don't deform it when you tighten the mounting screw. As a general rule, anyplace you have thin fiberglass held to something like a small steel plate with a fastener you must add reinforcement. On the nose gear leg fairings I added 4-6 bids of glass reinforcement on the inside where the fairing rubs on the gear leg bracket. This adds a lot of strength to the area where the screw goes through as well as the needed spacer so the mounting screw does not deform the fairing. The same practice goes for the wheel pants, some areas like the outboard bolt hole get much thicker layers of glass than others. On the front gear pant don't forget to add some glass reinforcement on the inside about 6" up from the tire cutout. I had the wheel pant split in this area, as have others. On the front shoulder belt to cabin top mounting screws I added (8) bids of glass on inside, 6"x10" or so in size centered on the screw hole. I did not consider the thickness of the cabin top glass adequate after I got done countersinking for the mounting screw. Carl RV-10 (125 hrs) RV-8A (sold) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Monday, September 02, 2013 7:11 PM Subject: RE: RV10-List: Re: Nose gear leg fairing Here are the pictures. I am wondering if hot air is coming in from the top and kind of dead heading at the screw attach triangles on the leg - or the whole leg has a lot of heat too. -Chris N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Sent: Sunday, September 01, 2013 11:00 PM Subject: RE: RV10-List: Re: Nose gear leg fairing Yep I have reflective mat on the cowl bottom - I should have attached a picture, I'll try to get a photo tomorrow. -Chris -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bill.peyton Sent: Sunday, September 01, 2013 9:08 PM Subject: RV10-List: Re: Nose gear leg fairing Posting some photos would be helpful to assist in answering your question. Are you sure that it is heat, or could it be that the fairing is in a bind when it is installed and it's trying to twist? I haven't noticed anything on mine indicating heat was an issue. Do you have any reflective heat mat on the lower cowling? -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407884#407884 ________________________________________________________________________________
Date: Sep 02, 2013
I had to build up on the inside of mine 1/8" at all four locations. Weekend job for you coming up. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407964#407964 ________________________________________________________________________________
Date: Sep 03, 2013
Ditto on this. I use Phillips with Camguard except during the first 50-100 hours on a new engine, where I leave out the Camguard. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Aug 30, 2013, at 4:52 PM, Kelly McMullen wrote: > The problem with AS 15-50 is that it is 50% synthetic oil which does not keep solids suspended. > It does contain the Lycoming addidtive. > You do NOT need the Lycoming additive. It is for the "76" series engines like the O-320-H2AD that had very different cam and lifters than what your IO-540 has. The Lycoming additive is a version of tricresyl Phospate, or TCP, and is an extreme pressure lubricant. Later replaced by close cousin TPP. > Phillips does not have that additive, and I don't think Camguard does either. Camguard is primarily an anti-corrosive, which is helpful in preventing pitting on the cam. > The Phillips/Camguard combo gives best anti-corrosion protection. The Phillips is all mineral based, no synthetics. > > > On Fri, Aug 30, 2013 at 10:51 AM, Dan Masys wrote: > > So after decades of blissfully thinking I was doing the right thing for my > aircraft engines by feeding them Aeroshell 15W50, it now is being called > evil stuff by knowledgeable folks like Mike Busch. Is there general > consensus that Phillips 15W50 is better as a multiviscosity oil for our > IO-540's? > > And if using that does it have to be supplemented by Camguard to add back > the Lycoming 'snake oil' additive to protect the parts that are only splash > lubricated? > > Not trying to set off oilfield flame wars but have the feeling that somehow > I missed something... > > -Dan Masys > N104LD 620 hrs TTSN > > > > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > le, List Admin. > ="_blank">http://www.matronics.com/contribution > ========== > > > > > > > -- > > - sent from the microchip implanted in my forearm > > > ________________________________________________________________________________
Date: Sep 03, 2013
Thanks to all on the replies. I guess my case is a bit isolated. I do remember adding glass to the lower attach points but I don't remember if I did to the uppers - it is drawn in a bit by the screw but the gopro camera lens might exaggerate it a little. Easy enough to go ahead and pull it off and add some glass as you say below, and check for any exhaust leaks. I did not see any fuel residue around it. Thanks Chris N919AR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of rv10flyer Sent: Tuesday, September 03, 2013 12:54 AM Subject: RV10-List: Re: Nose gear leg fairing I had to build up on the inside of mine 1/8" at all four locations. Weekend job for you coming up. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407964#407964 ________________________________________________________________________________
Subject: Re: Flying the Hudson through NY and to Washington DC.
Date: Sep 03, 2013
Thanks to all for the help, ideas and suggestions you have given me here. I have done the on-line courses for both the Washington Special Flight Rules Area (SFRA) and the NY City SFRA. Now armed with a good knowledge of the rules and the correct charts combined with the experience of having done it once before (15+ years ago) I feel quite confident that we can pull this off without any trouble. The plan is to fly directly to Westchester County (KHPN) for customs and then launch from there to do the Hudson River sight seeing tour. After the tour we will stop in Monmouth Executive (KBLM) for lunch and file an IFR flight plan to go into Gaithersburg (KGAI) where we will stay for a couple of nights and do the Washington tourist thing. Here is a link to SkyVectors.com showing my routing. http://skyvector.com/?ll=40.921260992712455,-78.63061523802082&chart=301&zoom=7&plan=A.CY.CYKF:V.K6.BUF:V.K6.CFB:F.K6.GAYEL:F.K6.VALRE:A.K6.KHPN:V.K6.COL:A.K6.KBLM:A.K6.KGAI:V.K6.HGR:V.K6.TON:V.K6.JHW:A.CY.CYKF -------- Ivan Kristensen. www.ivankristensen.com Builder # 40838 Flying (430hrs.) C-GMDV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=407994#407994 ________________________________________________________________________________
Date: Sep 04, 2013
I have a question about the louvers you are using, are those stock? It seems like they are cut in the cowl more forward than most. Could it be that your installation has more hot air being pulled out the forward portion of the cowl rather than the aft opening? If that is the case then your fairing would see more heat than others. Just a thought - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408001#408001 ________________________________________________________________________________
Date: Sep 04, 2013
They appear stock and in stock location to me. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408002#408002 ________________________________________________________________________________
From: "Carroll L. Verhage" <cv93436(at)windstream.net>
Subject: Nose Cowling Heat Shields
Date: Sep 04, 2013
RV-10 Builders: If you do not shield the lower engine cowling, it will warp and turn brown from the heat produced by the exhaust system. A permanent fix is to mount a sheet of .025 or .032 aluminum with the same contour of the cowling over the area of the cowling where it gets hot from the exhaust (about 6 in. forward of the exhaust pipes up front and back to where the mufflers end). Place 3 or 4 #6 thick washers between the heat shield and the Lexan at the top edge of the aluminum and rivet it to the Lexan with countersunk rivents on the outside. It will take 3 or 4 rivets on each side of the cowling. Shape the aluminum sheet so it is parallel to the Lexan leaving a 1/4" space between the Lexan and aluminum sheet (an air space). Rivet the lower edge of the aluminum sheet to the bottom edge of the Lexan with counter sunk rivets. You will not need spacer washers on the bottom edge. This is as light in weight as the adhesive aluminum reflector and will last forever with better heat protection. Carroll RV-10 41087 N123CV ________________________________________________________________________________
Subject: Re: Nose Cowling Heat Shields
Date: Sep 04, 2013
This makes no sense to me. My -10 has no Lexan in the cowl or elsewhere. Also can't imagine a Lexan and alum. sandwich being lighter than the adhesive alum. foil. What am I missing? Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408016#408016 ________________________________________________________________________________
Date: Sep 04, 2013
The aluminum tape we use for exhaust vents on stoves works GREAT. Its meant for High Heat Ventilation systems I have used it on my 10 for 143 hours no problem. The interior was "Browning" before I applied the tape. No problems since. I think the tape number is "704"... If my aging memory serves me correctly... Jim Villani Kit# 41084 Jim(at)JimVillani.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Wednesday, September 04, 2013 10:58 AM Subject: RV10-List: Re: Nose Cowling Heat Shields This makes no sense to me. My -10 has no Lexan in the cowl or elsewhere. Also can't imagine a Lexan and alum. sandwich being lighter than the adhesive alum. foil. What am I missing? Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408016#408016 ________________________________________________________________________________
Date: Sep 04, 2013
My FWF is all stock unless I made a plans mistake. -Chris ----- Original Message ----- From: jkreidler <jason.kreidler(at)regalbeloit.com> Subject: RV10-List: Re: Nose gear leg fairing I have a question about the louvers you are using, are those stock? It seems like they are cut in the cowl more forward than most. Could it be that your installation has more hot air being pulled out the forward portion of the cowl rather than the aft opening? If that is the case then your fairing would see more heat than others. Just a thought - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408001#408001 ________________________________________________________________________________
From: "jkreidler" <jason.kreidler(at)regalbeloit.com>
Date: Sep 05, 2013
May I ask what kind of paint you used? - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408051#408051 ________________________________________________________________________________
Date: Sep 05, 2013
Jason May I suggest that, when you ask a question regarding a previous email, you do include the text of that previous email. Best Carlos -----Mensagem original----- De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de jkreidler Enviada: 5 de setembro de 2013 12:53 Para: rv10-list(at)matronics.com Assunto: RV10-List: Re: Nose gear leg fairing --> May I ask what kind of paint you used? - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408051#408051 ________________________________________________________________________________
Subject: Has this ever been done...
Date: Sep 05, 2013
Hi, I filled up my RV-10 on its third flight and had to see that it leaks out through the vent line. The QB tank maker obviously has forgoten to tighten the nut to the an fitting inside the tank. Did anyone ever manage to build a tool that would allow to enter through the tank sensor hole to tighten it? I'd hat to take off the tank and go with Vans advice and cut a hole to get inside the tank, and ruin my paint job. The soft screws most likely won't come out easily as well. Any ideas? Mike -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408086#408086 ________________________________________________________________________________
Subject: Re: Has this ever been done...
Date: Sep 05, 2013
I had the same issue and had to cut open tank to tighten. I heard after someone made a tool but don't remember who it was. Alan N668G 202 hrs Sent from my iPhone On Sep 5, 2013, at 4:41 PM, "Mike Whisky" wrote: > > Hi, > > I filled up my RV-10 on its third flight and had to see that it leaks out through the vent line. The QB tank maker obviously has forgoten to tighten the nut to the an fitting inside the tank. > Did anyone ever manage to build a tool that would allow to enter through the tank sensor hole to tighten it? > I'd hat to take off the tank and go with Vans advice and cut a hole to get inside the tank, and ruin my paint job. The soft screws most likely won't come out easily as well. > Any ideas? > > Mike > > -------- > RV-10 builder (final system testing) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408086#408086 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 05, 2013
Do like I did. Have Vans send you a new tank. Mine leaked from the rivets.Not enough proseal. I sent a DTPA notice and got new tanks made and installed by Vans. The new tanks still leak the same. I gave up. I found another way to seal my pimply looking tanks. Regards, Robert On Sep 5, 2013, at 3:41 PM, Mike Whisky wrote: > > Hi, > > I filled up my RV-10 on its third flight and had to see that it leaks out through the vent line. The QB tank maker obviously has forgoten to tighten the nut to the an fitting inside the tank. > Did anyone ever manage to build a tool that would allow to enter through the tank sensor hole to tighten it? > I'd hat to take off the tank and go with Vans advice and cut a hole to get inside the tank, and ruin my paint job. The soft screws most likely won't come out easily as well. > Any ideas? > > Mike > > -------- > RV-10 builder (final system testing) > #511 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408086#408086 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 05, 2013
Mike Andresen in AZ had this problem and machined a tool to fix it without cutting into the wing. I'm pretty sure he is on here, but don't know his moniker. He has a blog of his build that most likely describes it. His email is azcloudflyer(at)earthlink.net -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408095#408095 ________________________________________________________________________________
Date: Sep 05, 2013
Subject: Monster retread clearance issue?
After ~300 landings on my original Aero Classics tires, it's almost time for new ones. Based on the recommendations here, I'm considering the Monster retreads. Do I need to worry about my wheel pant clearance? If so, I may just get the Aero Classics again. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Sep 05, 2013
The info you are looking for is on the VAF site. Search for azcloudflyer 2011 for a description and photos of the tool he made. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408099#408099 ________________________________________________________________________________
Subject: Re: Monster retread clearance issue?
Date: Sep 05, 2013
I blew the sides out on one pant from switching to retreads and not widening the gap. Make sure you have clearance. Sent from my iPhone On Sep 5, 2013, at 16:07, Rob Kochman wrote: > After ~300 landings on my original Aero Classics tires, it's almost time f or new ones. Based on the recommendations here, I'm considering the Monster retreads. Do I need to worry about my wheel pant clearance? If so, I may j ust get the Aero Classics again. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Sep 05, 2013
Mike, I can confirm that arizonacloudflyers's tool works. Same issue, QB wings and they hadn't tightened the nut that holds the vent line to the end of wing. In my case,, the plane wasn't painted so I pulled the tanks for easier access. After putting the tanks back on, I tested to see if it would still work with the wings on. I can confirm that you will have sufficient access with just the wing walk covers removed. Tom Hanaway -------- RV-10. Built and sold RV-8a. Building Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408104#408104 ________________________________________________________________________________
Date: Sep 05, 2013
The ones you get from Desser are NOT monster retreads. They are listed as H igh Performance Retreads. The "Monster" ones don't come in our size. Yes, t here may be a little more tread and clearance needed with any change in tire , but ours aren't Monster. Tim On Sep 5, 2013, at 6:07 PM, Rob Kochman wrote: > After ~300 landings on my original Aero Classics tires, it's almost time f or new ones. Based on the recommendations here, I'm considering the Monster retreads. Do I need to worry about my wheel pant clearance? If so, I may j ust get the Aero Classics again. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Sep 05, 2013
I just switched back to Aero Classics from Desser retreads. I got about 200 landings out of the retreads. The thing I really didn't like was that the plane was VERY hard to pull around with the towbar using the retreads. The aeroclassics are much easier, and FWIW they weigh at least 4 lbs less per tire. Dave Saylor 831-750-0284 CL On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman wrote: > After ~300 landings on my original Aero Classics tires, it's almost time > for new ones. Based on the recommendations here, I'm considering the > Monster retreads. Do I need to worry about my wheel pant clearance? If > so, I may just get the Aero Classics again. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > * > > ________________________________________________________________________________
Date: Sep 05, 2013
Tim is correct, no monster retreads in our main gear size. I just replaced both mains two weeks ago with Desser retreads. I only had 120 hours on the original Aero Classics but I found one tire ruined from a dragging brake (and that brake pad worn down to the rivets). I replaced both tires just because. The only thing I could find on the brake problem was perhaps a rolled brake caliper 'O' ring. The right side was fine and that brake pad looked brand new. No problem with clearance on the retreads. The cores are Goodyear and the quality looked good. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, September 05, 2013 8:12 PM Subject: Re: RV10-List: Monster retread clearance issue? The ones you get from Desser are NOT monster retreads. They are listed as High Performance Retreads. The "Monster" ones don't come in our size. Yes, there may be a little more tread and clearance needed with any change in tire, but ours aren't Monster. Tim On Sep 5, 2013, at 6:07 PM, Rob Kochman wrote: After ~300 landings on my original Aero Classics tires, it's almost time for new ones. Based on the recommendations here, I'm considering the Monster retreads. Do I need to worry about my wheel pant clearance? If so, I may just get the Aero Classics again. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K D======================== ========= D======================== ========= D======================== ========= D======================== ========= ________________________________________________________________________________
Date: Sep 05, 2013
Its PPG Deltron base with clear. K36 primer and alodined. -Chris ----- Original Message ----- From: jkreidler <jason.kreidler(at)regalbeloit.com> Subject: RV10-List: Re: Nose gear leg fairing May I ask what kind of paint you used? - Jason -------- Jason Kreidler 4 Partner Build - Sheboygan Falls, WI Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler N44YH - Flying - #40617 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408051#408051 ________________________________________________________________________________
Date: Sep 05, 2013
here is the link http://www.vansairforce.com/community/showthread.php?t=74258 -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408114#408114 ________________________________________________________________________________
Date: Sep 05, 2013
I would advise against the Monster Retreads. Yes they might last a bit longer, but you will do less landings as you get more time, and the landings will be ever so much smoother that the replacements will last twice as long. ;-) I use standard Desser retreads on my Mooney, where clearance in the gear wells would be an issue with the Monster retreads. Never had a clearance problem. On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman wrote: > After ~300 landings on my original Aero Classics tires, it's almost time > for new ones. Based on the recommendations here, I'm considering the > Monster retreads. Do I need to worry about my wheel pant clearance? If > so, I may just get the Aero Classics again. Thanks... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Sep 05, 2013
We were able to do it here, with a bit of patience, some smaller hands and . . . offset wrenches?? I don't remember exactly, but no need to cut your tanks open! I'll have to ask the guy who did it what he did ... On Thu, Sep 5, 2013 at 2:35 PM, woxofswa wrote: > > Mike Andresen in AZ had this problem and machined a tool to fix it without > cutting into the wing. > > I'm pretty sure he is on here, but don't know his moniker. He has a blog > of his build that most likely describes it. His email is > azcloudflyer(at)earthlink.net > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF > complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408095#408095 > > -- *Aircrafters* 140 Aviation Way Watsonville CA, 95076 KWVI 831-722-9141 www.AircraftersLLC.com ________________________________________________________________________________
Date: Sep 05, 2013
Great, thats exactly the info I was hoping for! Did I ever mention this forum is GREAT!! Mike -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408121#408121 ________________________________________________________________________________
Date: Sep 06, 2013
Thanks, guys... I may just stay with what I have for simplicity reasons and based on the other feedback. On Thu, Sep 5, 2013 at 8:10 PM, Kelly McMullen wrote: > I would advise against the Monster Retreads. Yes they might last a bit > longer, but you will do less landings as you get more time, and the > landings will be ever so much smoother that the replacements will last > twice as long. ;-) I use standard Desser retreads on my Mooney, where > clearance in the gear wells would be an issue with the Monster retreads. > Never had a clearance problem. > > > On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman wrote: > >> After ~300 landings on my original Aero Classics tires, it's almost time >> for new ones. Based on the recommendations here, I'm considering the >> Monster retreads. Do I need to worry about my wheel pant clearance? If >> so, I may just get the Aero Classics again. Thanks... >> >> -Rob >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > > > -- > > - sent from the microchip implanted in my forearm > > * > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Sep 06, 2013
I have heard good feedback on the Goodyear tires as well. Maybe more expensive but yet another option over the aero classics. From: Rob Kochman Sent: Friday, September 06, 2013 11:40 AM Subject: Re: RV10-List: Monster retread clearance issue? Thanks, guys... I may just stay with what I have for simplicity reasons and based on the other feedback. On Thu, Sep 5, 2013 at 8:10 PM, Kelly McMullen wrote: I would advise against the Monster Retreads. Yes they might last a bit longer, but you will do less landings as you get more time, and the landings will be ever so much smoother that the replacements will last twice as long. ;-) I use standard Desser retreads on my Mooney, where clearance in the gear wells would be an issue with the Monster retreads. Never had a clearance problem. On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman wrote: After ~300 landings on my original Aero Classics tires, it's almost time for new ones. Based on the recommendations here, I'm considering the Monster retreads. Do I need to worry about my wheel pant clearance? If so, I may just get the Aero Classics again. Thanks... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Sep 06, 2013
One thing to be aware of on the Goodyears, or any other tire for that matter, is that the tire shape is not identical. So always always check for good clearance. As far as I'm concerned, there isn't anything major that would swing a person towards one tire or another. The expensive ones usually get more landings, the cheaper ones usually get less...but in cost per landing it's probably not huge either way. Also, the retreads may weigh more, but they're still built on name brand cores...mine have usually been Goodyear cores. So, if they weigh more, think about it....that means there is more rubber there. So there really isn't any big sway one way or the other. Goodyear, AeroClassic, Retreads...so far I just find the retreads to be the most rubber for the buck, but there isn't really anything that you can do to make a very significant mistake in buying tires if you just get something that's known to work ok. Tim On 9/6/2013 2:18 PM, Pascal wrote: > I have heard good feedback on the Goodyear tires as well. Maybe more > expensive but yet another option over the aero classics. > *From:* Rob Kochman > *Sent:* Friday, September 06, 2013 11:40 AM > *To:* rv10-list > *Subject:* Re: RV10-List: Monster retread clearance issue? > Thanks, guys... I may just stay with what I have for simplicity > reasons and based on the other feedback. > > > On Thu, Sep 5, 2013 at 8:10 PM, Kelly McMullen > wrote: > > I would advise against the Monster Retreads. Yes they might last a > bit longer, but you will do less landings as you get more time, > and the landings will be ever so much smoother that the > replacements will last twice as long. ;-) I use standard Desser > retreads on my Mooney, where clearance in the gear wells would be > an issue with the Monster retreads. Never had a clearance problem. > > > On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman > wrote: > > After ~300 landings on my original Aero Classics tires, it's > almost time for new ones. Based on the recommendations here, > I'm considering the Monster retreads. Do I need to worry > about my wheel pant clearance? If so, I may just get the Aero > Classics again. Thanks... > -Rob > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution * > > > -- > > - sent from the microchip implanted in my forearm > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > * > > href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c > * > * > > > * ________________________________________________________________________________
Date: Sep 06, 2013
Just keep in mind that the most expensive tire, the Goodyear Flight Custom III is the heaviest tire made for any given size. Often by a couple pounds or more per tire. I have had much better wear life with Desser standard retreads than any other tire. I believe the retread is a little harder compound. I do not find them any heavier than a stock new tire. You may get any brand core. Depending on their stock and which sales person you get, you may be able to specify which brand core you want. On 9/6/2013 12:42 PM, Tim Olson wrote: > One thing to be aware of on the Goodyears, or any other tire for that > matter, is > that the tire shape is not identical. So always always check for good > clearance. > As far as I'm concerned, there isn't anything major that would swing a > person > towards one tire or another. The expensive ones usually get more > landings, > the cheaper ones usually get less...but in cost per landing it's > probably not > huge either way. Also, the retreads may weigh more, but they're still > built > on name brand cores...mine have usually been Goodyear cores. So, if they > weigh more, think about it....that means there is more rubber there. > So there really isn't any big sway one way or the other. > Goodyear, AeroClassic, Retreads...so far I just find the retreads to > be the > most rubber for the buck, but there isn't really anything that you can do > to make a very significant mistake in buying tires if you just get > something > that's known to work ok. > > Tim > > > On 9/6/2013 2:18 PM, Pascal wrote: >> I have heard good feedback on the Goodyear tires as well. Maybe more >> expensive but yet another option over the aero classics. >> *From:* Rob Kochman >> *Sent:* Friday, September 06, 2013 11:40 AM >> *To:* rv10-list >> *Subject:* Re: RV10-List: Monster retread clearance issue? >> Thanks, guys... I may just stay with what I have for simplicity >> reasons and based on the other feedback. >> >> >> On Thu, Sep 5, 2013 at 8:10 PM, Kelly McMullen > > wrote: >> >> I would advise against the Monster Retreads. Yes they might last >> a bit longer, but you will do less landings as you get more time, >> and the landings will be ever so much smoother that the >> replacements will last twice as long. ;-) I use standard Desser >> retreads on my Mooney, where clearance in the gear wells would be >> an issue with the Monster retreads. Never had a clearance problem. >> >> >> On Thu, Sep 5, 2013 at 4:07 PM, Rob Kochman > > wrote: >> >> After ~300 landings on my original Aero Classics tires, it's >> almost time for new ones. Based on the recommendations here, >> I'm considering the Monster retreads. Do I need to worry >> about my wheel pant clearance? If so, I may just get the >> Aero Classics again. Thanks... >> -Rob >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution * >> >> >> >> >> -- >> >> - sent from the microchip implanted in my forearm >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> * >> >> href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c >> * >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Subject: prop govenor
Date: Sep 08, 2013
Although I don=99t have my engine yet, I am building baffles,etc. in preparation for it. The baffle plans show bracketry for the prop governor cable coming up from the bottom of the engine. I bought the bracket that bolts to the governor and presumably routes the cable above the engine, which would be a preferred route. I can find no documentation on this routing in the plans or the instruction page that came with the bracket. Nor can I find anything in the forum searches. Does anyone have any info on this subject (links to your website, cable length, etc.) Chris Hukill ________________________________________________________________________________
Date: Sep 08, 2013
Subject: Re: prop govenor
All the 10s I've seen have it come up from the bottom, but there's no physical reason it couldn't route over the cylinders. Lots of other planes do that. You'd probably need a custom cable, though. Dave Saylor 831-750-0284 CL On Sun, Sep 8, 2013 at 6:14 PM, Chris Hukill wrote: > Although I don=99t have my engine yet, I am building baffles,etc. in > preparation for it. The baffle plans show bracketry for the prop governo r > cable coming up from the bottom of the engine. I bought the bracket that > bolts to the governor and presumably routes the cable above the engine, > which would be a preferred route. I can find no documentation on this > routing in the plans or the instruction page that came with the bracket. > Nor can I find anything in the forum searches. Does anyone have any info on > this subject (links to your website, cable length, etc.) > Chris Hukill > > * > =========== =========== =========== =========== > * > > ________________________________________________________________________________
Date: Sep 08, 2013
You would also have a greater need to have a cable with good temperature resistance as a cable on the top would be subjected to significant temperatures in after flight heat soak, more so than under the engine. I'm not sure I see any real advantage to going over the top. On Sun, Sep 8, 2013 at 7:35 PM, Dave Saylor < dave.saylor.aircrafters(at)gmail.com> wrote: > All the 10s I've seen have it come up from the bottom, but there's no > physical reason it couldn't route over the cylinders. Lots of other plan es > do that. You'd probably need a custom cable, though. > > Dave Saylor > 831-750-0284 CL > > > On Sun, Sep 8, 2013 at 6:14 PM, Chris Hukill wrote: > >> Although I don=92t have my engine yet, I am building baffles,etc. in >> preparation for it. The baffle plans show bracketry for the prop govern or >> cable coming up from the bottom of the engine. I bought the bracket that >> bolts to the governor and presumably routes the cable above the engine, >> which would be a preferred route. I can find no documentation on this >> routing in the plans or the instruction page that came with the bracket. >> Nor can I find anything in the forum searches. Does anyone have any info on >> this subject (links to your website, cable length, etc.) >> Chris Hukill >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> * >> >> > * > =========== =========== =========== =========== > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: ACK E04 ELT MOUNTING
Date: Sep 08, 2013
I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408254#408254 ________________________________________________________________________________
Subject: Cabin Cover Headliner
Date: Sep 08, 2013
Is there a significant advantage to installing the Flightline headliner before doing the final install on the cabin cover? How much inside prep is needed and how about prep of the parts that remain exposed like the door frame, etc.? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408255#408255 ________________________________________________________________________________
Subject: Re: Cabin Cover Headliner
Date: Sep 09, 2013
I can't speak specifically to the flightline headliner, since I have an Aerosport Products headliner. But I'm sure the issues are similar. You want to prep as much as you can with the cabin cover off the aircraft. It's a hundred times easier. Most folks prefer to sand smooth and fill any voids, depressions, and pin holes. This is clearly easier with the cover upside down on the bench. The door frame may need additional work depending on what type of doors seals you choose to use. There are at least three variations of cabin covers. One green and two pink. The two pink ones have slightly different dimensions from the the step down that separates the front and back. This may cause some additional tweaking of the headliner depending on which cover you received. Sent from my iPad On Sep 9, 2013, at 12:18 AM, "bob88" wrote: > > Is there a significant advantage to installing the Flightline headliner before doing the final install on the cabin cover? How much inside prep is needed and how about prep of the parts that remain exposed like the door frame, etc.? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408255#408255 > > > > > > > > > > ________________________________________________________________________________
Date: Sep 09, 2013
bob88 wrote: > Is there a significant advantage to installing the Flightline headliner before doing the final install on the cabin cover? How much inside prep is needed and how about prep of the parts that remain exposed like the door frame, etc.? I used the full Flightline headliner - no overhead console. I glued it in while it was upside down on my work table. I think it was much easier that way. I left extra fabric at the windows, ends, etc., so I could trim it later. When you work on the trim later, you will be glad you didn't have to do it "Michelangelo style". John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408261#408261 ________________________________________________________________________________
Subject: Re: ACK E04 ELT MOUNTING
Date: Sep 09, 2013
Make it easy to get to, behind the baggage bulkhead. Put the antenna on the top - nobody notices antennas anyway. Keep in mind that it uses an "almost" ordinary telephone cord between it and your panel. You need that cord in place when pulling wires. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408262#408262 ________________________________________________________________________________
Date: Sep 09, 2013
The only ones I see go over the cylinders is when there is an air conditioner installed. I don't know if this causes any problems with heat or not, but it can and has been done. Might try someone who has air conditioning, especially with the Airflow Systems unit, to see how theirs hold up. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Sep 8, 2013, at 11:49 PM, Kelly McMullen wrote: > You would also have a greater need to have a cable with good temperature resistance as a cable on the top would be subjected to significant temperatures in after flight heat soak, more so than under the engine. I'm not sure I see any real advantage to going over the top. > > > On Sun, Sep 8, 2013 at 7:35 PM, Dave Saylor wrote: > All the 10s I've seen have it come up from the bottom, but there's no physical reason it couldn't route over the cylinders. Lots of other planes do that. You'd probably need a custom cable, though. > > Dave Saylor > 831-750-0284 CL > > > On Sun, Sep 8, 2013 at 6:14 PM, Chris Hukill wrote: > Although I don=92t have my engine yet, I am building baffles,etc. in preparation for it. The baffle plans show bracketry for the prop governor cable coming up from the bottom of the engine. I bought the bracket that bolts to the governor and presumably routes the cable above the engine, which would be a preferred route. I can find no documentation on this routing in the plans or the instruction page that came with the bracket. Nor can I find anything in the forum searches. Does anyone have any info on this subject (links to your website, cable length, etc.) > Chris Hukill > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > -- > > - sent from the microchip implanted in my forearm > > > ________________________________________________________________________________
Date: Sep 09, 2013
While I agree with mounting the ELT in the area behind the baggage compartment, I don't agree with mounting the antenna just anywhere on top. Antennas and spacing do matter. You need at least 2 ft from any com or GPS antenna, and 3 ft is better. The closer the ELT antenna is to the vertical stabilizer the better it will be protected from crash damage. The neat, out of sight mounting between the vert and horiz stabilizers under the fiberglass fairing is probably the best crash protected location. While the manufacturer's instructions call for mounting within 20 or 30 degrees of vertical, it is somewhat difficult to define where vertical will be post-crash. I mounted mine on the rear most bulkhead before the vertical stab, and will use a nylon wire clamp to keep the other end of the antenna clear of any metal. There is one other issue with ELT antennas that is rarely discussed. The 121.5 transmitters are easily excited by TV and FM signals which are close in frequency, and they re-radiate that energy. If there is a com antenna anywhere near the ELT antenna it can cause a nasty squelch break that interferes. I had this problem with my Mooney when all the com antennas were on top of fuselage. I was able to greatly reduce it by moving one com antenna to the belly. Yes, newer ELTs are supposed to have better suppression of this "feature" but I doubt they have eliminated it. Likewise any VHF transmission anywhere near your GPS antenna creates potential for interference with GPS. So mounting your ELT as far away from other antennas as possible is beneficial. On 9/9/2013 6:17 AM, johngoodman wrote: > > Make it easy to get to, behind the baggage bulkhead. Put the antenna on the top - nobody notices antennas anyway. Keep in mind that it uses an "almost" ordinary telephone cord between it and your panel. You need that cord in place when pulling wires. > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408262#408262 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: prop governor
Date: Sep 09, 2013
The only install I've seen with the prop gov cable on top was an RV-10 with an AC compressor on the engine (the compressor blocked the normal cable path). The Van's prop gov cable bracket did not work on my plane. I made a cable bracket that is part of the left baffles (I did not use the Van's baffle kit). Photo attached. Please look past the temporary hardware and screws not yet having safety wire. I used the cable Van's sells. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Sunday, September 08, 2013 11:50 PM Subject: Re: RV10-List: prop govenor You would also have a greater need to have a cable with good temperature resistance as a cable on the top would be subjected to significant temperatures in after flight heat soak, more so than under the engine. I'm not sure I see any real advantage to going over the top. On Sun, Sep 8, 2013 at 7:35 PM, Dave Saylor wrote: All the 10s I've seen have it come up from the bottom, but there's no physical reason it couldn't route over the cylinders. Lots of other planes do that. You'd probably need a custom cable, though. Dave Saylor 831-750-0284 CL On Sun, Sep 8, 2013 at 6:14 PM, Chris Hukill wrote: Although I don't have my engine yet, I am building baffles,etc. in preparation for it. The baffle plans show bracketry for the prop governor cable coming up from the bottom of the engine. I bought the bracket that bolts to the governor and presumably routes the cable above the engine, which would be a preferred route. I can find no documentation on this routing in the plans or the instruction page that came with the bracket. Nor can I find anything in the forum searches. Does anyone have any info on this subject (links to your website, cable length, etc.) Chris Hukill get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Sep 09, 2013
As a guy who tests ELTs and gets paid to do it, Kelly's advise is invaluable. Cosmetically hiding ELT antenna produced too many units which won't propagate an adequate signal. It looks like you have a unit but the signal strength is inadequate. John On Sep 9, 2013 7:17 AM, "Kelly McMullen" wrote: > > While I agree with mounting the ELT in the area behind the baggage > compartment, I don't agree with mounting the antenna just anywhere on top. > Antennas and spacing do matter. You need at least 2 ft from any com or GPS > antenna, and 3 ft is better. The closer the ELT antenna is to the vertical > stabilizer the better it will be protected from crash damage. The neat, > out of sight mounting between the vert and horiz stabilizers under the > fiberglass fairing is probably the best crash protected location. While > the manufacturer's instructions call for mounting within 20 or 30 degrees > of vertical, it is somewhat difficult to define where vertical will be > post-crash. I mounted mine on the rear most bulkhead before the vertical > stab, and will use a nylon wire clamp to keep the other end of the antenna > clear of any metal. > There is one other issue with ELT antennas that is rarely discussed. The > 121.5 transmitters are easily excited by TV and FM signals which are close > in frequency, and they re-radiate that energy. If there is a com antenna > anywhere near the ELT antenna it can cause a nasty squelch break that > interferes. I had this problem with my Mooney when all the com antennas > were on top of fuselage. I was able to greatly reduce it by moving one com > antenna to the belly. Yes, newer ELTs are supposed to have better > suppression of this "feature" but I doubt they have eliminated it. Likewise > any VHF transmission anywhere near your GPS antenna creates potential for > interference with GPS. So mounting your ELT as far away from other antennas > as possible is beneficial. > > On 9/9/2013 6:17 AM, johngoodman wrote: > >> > >> >> Make it easy to get to, behind the baggage bulkhead. Put the antenna on >> the top - nobody notices antennas anyway. Keep in mind that it uses an >> "almost" ordinary telephone cord between it and your panel. You need that >> cord in place when pulling wires. >> John >> >> -------- >> #40572 Phase One complete and flying. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/**viewtopic.php?p=408262#408262> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 09, 2013
Couldn't get mine to fit there anymore when I switched, ended up making a spot for it next to the batteries like others. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Sunday, September 08, 2013 11:15 PM Subject: RV10-List: ACK E04 ELT MOUNTING I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle? Read this topic online here:
Date: Sep 09, 2013
For future builders...buy slow build and two quarts of proseal. If QB then pressurize tanks to 1 psi upon receipt. Paint after test flying. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408277#408277 ________________________________________________________________________________
Date: Sep 09, 2013
Tk9XIHlvdSB0ZWxsIG1lISDwn5iKDQpJdCdzIGEgbG90IGVhc2llciB0byBjaGVjayB0aGUgdGFu a3MgQkVGT1JFIHRoZXkgYXJlIG1vdW50ZWQgb24gdGhlIHBsYW5lLiAg8J+Ygg0KDQo+IFN1Ympl Y3Q6IFJWMTAtTGlzdDogUmU6IEhhcyB0aGlzIGV2ZXIgYmVlbiBkb25lLi4uDQo+IEZyb206IHdh eW5lLmdpbGxpc3BpZUBnbWFpbC5jb20NCj4gRGF0ZTogTW9uLCA5IFNlcCAyMDEzIDA4OjQxOjI5 IC0wNzAwDQo+IFRvOiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiANCj4gLS0+IFJWMTAtTGlz dCBtZXNzYWdlIHBvc3RlZCBieTogInJ2MTBmbHllciIgPHdheW5lLmdpbGxpc3BpZUBnbWFpbC5j b20+DQo+IA0KPiBGb3IgZnV0dXJlIGJ1aWxkZXJzLi4uYnV5IHNsb3cgYnVpbGQgYW5kIHR3byBx dWFydHMgb2YgcHJvc2VhbC4gSWYgUUIgdGhlbiBwcmVzc3VyaXplIHRhbmtzIHRvIDEgcHNpIHVw b24gcmVjZWlwdC4gUGFpbnQgYWZ0ZXIgdGVzdCBmbHlpbmcuDQo+IA0KPiAtLS0tLS0tLQ0KPiBX YXluZSBHLg0KPiANCj4gDQo+IA0KPiANCj4gUmVhZCB0aGlzIHRvcGljIG9ubGluZSBoZXJlOg0K PiANCj4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tL3ZpZXd0b3BpYy5waHA/cD00MDgyNzcj NDA4Mjc3DQo+IA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPiBfLT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAgICAg ICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCj4gXy09IFVzZSB0aGUgTWF0cm9uaWNz IExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KPiBfLT0gdGhlIG1hbnkgTGlzdCB1 dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCj4gXy09IEFyY2hpdmUgU2Vh cmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0KPiBfLT0gUGhvdG9zaGFy ZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KPiBfLT0NCj4gXy09ICAgLS0+IGh0dHA6Ly93d3cubWF0 cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAg ICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCj4gXy09IFNhbWUgZ3JlYXQgY29u dGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQo+IF8tPQ0KPiBfLT0gICAt LT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+IF8tPQ0KPiBfLT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQ0KPiBfLT0gICAg ICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQo+IF8tPSAgVGhhbmsgeW91 IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQo+IF8tPSAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCj4gXy09ICAgLS0+IGh0dHA6Ly93d3cu bWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4gXy09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gDQo+IA0KPiANCiAJCSAJICAg CQkgIA= ________________________________________________________________________________
Date: Sep 09, 2013
I used less than 1 quart, more like 3/4 used. Thus far the tanks have been solid and there have been no leaks from the build. The idea was to get the seal in enough that it "just" bulges out, than with a qtip I smoothed it all out. Every rivet was prosealed, than another quick dab around every rivet. I feared that I wasn't using enough but in the end, one just needs enough to seal everything without too much in between the pieces, too much and it is harder to rivet, unless a larger rivet is used, and proseal oozes out everywhere. It is a time consuming process and if anything requires a detailed attention, it's the tanks. I went through numerous syringes but that was the best method to get the width and application on smoothly. Pascal -----Original Message----- From: rv10flyer Sent: Monday, September 09, 2013 8:41 AM Subject: RV10-List: Re: Has this ever been done... For future builders...buy slow build and two quarts of proseal. If QB then pressurize tanks to 1 psi upon receipt. Paint after test flying. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408277#408277 ________________________________________________________________________________
Date: Sep 09, 2013
V2hhdCdzIGEgcGFpbiBpcyB3aGVuIHlvdSBwYXkgZ29vZCBtb25leSBmb3IgYSBRQiBhbmQgdGhl IHRhbmtzIHN0aWxsIGxlYWsuIPCfmKANCg0KPiBGcm9tOiBydjEwZmx5ZXJAbGl2ZS5jb20NCj4g VG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQo+IFN1YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IFJl OiBIYXMgdGhpcyBldmVyIGJlZW4gZG9uZS4uLg0KPiBEYXRlOiBNb24sIDkgU2VwIDIwMTMgMDk6 MDI6MTUgLTA3MDANCj4gDQo+IC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6ICJQYXNj YWwiIDxydjEwZmx5ZXJAbGl2ZS5jb20+DQo+IA0KPiBJIHVzZWQgbGVzcyB0aGFuIDEgcXVhcnQs IG1vcmUgbGlrZSAzLzQgdXNlZC4gVGh1cyBmYXIgdGhlIHRhbmtzIGhhdmUgYmVlbiANCj4gc29s aWQgYW5kIHRoZXJlIGhhdmUgYmVlbiBubyBsZWFrcyBmcm9tIHRoZSBidWlsZC4gVGhlIGlkZWEg d2FzIHRvIGdldCB0aGUgDQo+IHNlYWwgaW4gZW5vdWdoIHRoYXQgaXQgImp1c3QiIGJ1bGdlcyBv dXQsIHRoYW4gd2l0aCBhIHF0aXAgSSBzbW9vdGhlZCBpdCBhbGwgDQo+IG91dC4gRXZlcnkgcml2 ZXQgd2FzIHByb3NlYWxlZCwgdGhhbiBhbm90aGVyIHF1aWNrIGRhYiBhcm91bmQgZXZlcnkgcml2 ZXQuIEkgDQo+IGZlYXJlZCB0aGF0IEkgd2Fzbid0IHVzaW5nIGVub3VnaCBidXQgaW4gdGhlIGVu ZCwgb25lIGp1c3QgbmVlZHMgZW5vdWdoIHRvIA0KPiBzZWFsIGV2ZXJ5dGhpbmcgd2l0aG91dCB0 b28gbXVjaCBpbiBiZXR3ZWVuIHRoZSBwaWVjZXMsIHRvbyBtdWNoIGFuZCBpdCBpcyANCj4gaGFy ZGVyIHRvIHJpdmV0LCB1bmxlc3MgYSBsYXJnZXIgcml2ZXQgaXMgdXNlZCwgYW5kIHByb3NlYWwg b296ZXMgb3V0IA0KPiBldmVyeXdoZXJlLg0KPiBJdCBpcyBhIHRpbWUgY29uc3VtaW5nIHByb2Nl c3MgYW5kIGlmIGFueXRoaW5nIHJlcXVpcmVzIGEgZGV0YWlsZWQgDQo+IGF0dGVudGlvbiwgaXQn cyB0aGUgdGFua3MuIEkgd2VudCB0aHJvdWdoIG51bWVyb3VzIHN5cmluZ2VzIGJ1dCB0aGF0IHdh cyB0aGUgDQo+IGJlc3QgbWV0aG9kIHRvIGdldCB0aGUgd2lkdGggYW5kIGFwcGxpY2F0aW9uIG9u IHNtb290aGx5Lg0KPiBQYXNjYWwNCj4gDQo+IC0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0tIA0K PiBGcm9tOiBydjEwZmx5ZXINCj4gU2VudDogTW9uZGF5LCBTZXB0ZW1iZXIgMDksIDIwMTMgODo0 MSBBTQ0KPiBUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NCj4gU3ViamVjdDogUlYxMC1MaXN0 OiBSZTogSGFzIHRoaXMgZXZlciBiZWVuIGRvbmUuLi4NCj4gDQo+IC0tPiBSVjEwLUxpc3QgbWVz c2FnZSBwb3N0ZWQgYnk6ICJydjEwZmx5ZXIiIDx3YXluZS5naWxsaXNwaWVAZ21haWwuY29tPg0K PiANCj4gRm9yIGZ1dHVyZSBidWlsZGVycy4uLmJ1eSBzbG93IGJ1aWxkIGFuZCB0d28gcXVhcnRz IG9mIHByb3NlYWwuIElmIFFCIHRoZW4gDQo+IHByZXNzdXJpemUgdGFua3MgdG8gMSBwc2kgdXBv biByZWNlaXB0LiBQYWludCBhZnRlciB0ZXN0IGZseWluZy4NCj4gDQo+IC0tLS0tLS0tDQo+IFdh eW5lIEcuDQo+IA0KPiANCj4gDQo+IA0KPiBSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6DQo+ IA0KPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQwODI3NyM0 MDgyNzcNCj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPiBfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQ0KPiBfLT0gICAgICAgICAgLSBUaGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0NCj4gXy09IFVz ZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQ0KPiBfLT0g dGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3VjaCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwNCj4g Xy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQsIDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLA0K PiBfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KPiBfLT0NCj4gXy09ICAgLS0+ IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9OYXZpZ2F0b3I/UlYxMC1MaXN0DQo+IF8tPQ0KPiBf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KPiBfLT0gICAgICAgICAgICAgICAtIE1BVFJPTklDUyBXRUIgRk9SVU1TIC0NCj4gXy09 IFNhbWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQo+ IF8tPQ0KPiBfLT0gICAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+IF8tPQ0KPiBf LT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PQ0KPiBfLT0gICAgICAgICAgICAgLSBMaXN0IENvbnRyaWJ1dGlvbiBXZWIgU2l0ZSAtDQo+ IF8tPSAgVGhhbmsgeW91IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQo+IF8tPSAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4NCj4gXy09ICAg LS0+IGh0dHA6Ly93d3cubWF0cm9uaWNzLmNvbS9jb250cmlidXRpb24NCj4gXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gDQo+ IA0KPiANCiAJCSAJICAgCQkgIA= ________________________________________________________________________________
Date: Sep 09, 2013
There really is no excuse for not testing a tank and correcting it before it ever left the shop. Its more work to fix the tank from the outside than doing it right from the inside. From: Danny Riggs Sent: Monday, September 09, 2013 9:20 AM Subject: RE: RV10-List: Re: Has this ever been done... What's a pain is when you pay good money for a QB and the tanks still leak. > From: rv10flyer(at)live.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Has this ever been done... > Date: Mon, 9 Sep 2013 09:02:15 -0700 > > > I used less than 1 quart, more like 3/4 used. Thus far the tanks have been > solid and there have been no leaks from the build. The idea was to get the > seal in enough that it "just" bulges out, than with a qtip I smoothed it all > out. Every rivet was prosealed, than another quick dab around every rivet. I > feared that I wasn't using enough but in the end, one just needs enough to > seal everything without too much in between the pieces, too much and it is > harder to rivet, unless a larger rivet is used, and proseal oozes out > everywhere. > It is a time consuming process and if anything requires a detailed > attention, it's the tanks. I went through numerous syringes but that was the > best method to get the width and application on smoothly. > Pascal > > -----Original Message----- > From: rv10flyer > Sent: Monday, September 09, 2013 8:41 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Has this ever been done... > > > For future builders...buy slow build and two quarts of proseal. If QB then > pressurize tanks to 1 psi upon receipt. Paint after test flying. > > -------- > Wayne G. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408277#408277 > > > > > > > > > > > > > > > > > > =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD,=EF=BD=03g(=EF=BD=EF =BD=EF=BDM=EF=BDGq=EF=BDz=EF=BD=EF=BD ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Sep 09, 2013
I built little aluminum standoffs and works great Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Sausen Sent: Monday, September 09, 2013 11:23 AM Subject: RE: RV10-List: ACK E04 ELT MOUNTING Couldn't get mine to fit there anymore when I switched, ended up making a spot for it next to the batteries like others. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Sunday, September 08, 2013 11:15 PM Subject: RV10-List: ACK E04 ELT MOUNTING I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408254#408254 ________________________________________________________________________________
Date: Sep 09, 2013
I tested mine and they were both good. After about a year and a half the passenger tank started leaking, one rivet in the walk area. And, after 5 years, I now have a seep out of the pilot take walk area. Would not call it a leak yet, but it will need some attention. I thought I did a good job on the walk area.but maybe not. L Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Monday, September 09, 2013 10:36 AM Subject: Re: RV10-List: Re: Has this ever been done... There really is no excuse for not testing a tank and correcting it before it ever left the shop. Its more work to fix the tank from the outside than doing it right from the inside. From: Danny Riggs <mailto:jdriggs49(at)msn.com> Sent: Monday, September 09, 2013 9:20 AM Subject: RE: RV10-List: Re: Has this ever been done... What's a pain is when you pay good money for a QB and the tanks still leak. Emoji > From: rv10flyer(at)live.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Has this ever been done... > Date: Mon, 9 Sep 2013 09:02:15 -0700 > > > I used less than 1 quart, more like 3/4 used. Thus far the tanks have been > solid and there have been no leaks from the build. The idea was to get the > seal in enough that it "just" bulges out, than with a qtip I smoothed it all > out. Every rivet was prosealed, than another quick dab around every rivet. I > feared that I wasn't using enough but in the end, one just needs enough to > seal everything without too much in between the pieces, too much and it is > harder to rivet, unless a larger rivet is used, and proseal oozes out > everywhere. > It is a time consuming process and if anything requires a detailed > attention, it's the tanks. I went through numerous syringes but that was the > best method to get the width and application on smoothly. > Pascal > > -----Original Message----- > From: rv10flyer > Sent: Monday, September 09, 2013 8:41 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Has this ever been done... > > > For future builders...buy slow build and two quarts of proseal. If QB then > pressurize tanks to 1 psi upon receipt. Paint after test flying. > > -------- > Wayne G. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408277#408277 > > > > > > > > > > > > ========== > Features Browse, Chat, via the Web http://forums.matronics.com > http://www.matronics.com/contribution > ========== > > > =EF=BD=EF=BD=EF=BD~=EF=BD=EF=BD,=EF=BD _____ g(=EF=BD=EF=BD=EF=BDM=EF=BDGq=EF=BDz=EF=BD=EF=BD ________________________________________________________________________________
Date: Sep 09, 2013
Subject: Launching online classifieds for homebuilders: SkySwapper.com
Hey everyone. Over the past few years I've noticed that many homebuilders tend to stick to their own online groups. Also, when people are looking to buy or sell parts (or planes), that experience is also quite fragmented. There will be different postings on email lists, VAF, and all the other dedicated builder sites... but often these listings would be of interest to everyone regardless of which type of plane they are building or flying. To try to help people reach across those divisions, I am launching a new website: SkySwapper.com <http://skyswapper.com/> <http://skyswapper.com/> It's an online classifieds site purely dedicated to the experimental aviation community. Of course, since it's brand new, it's pretty empty... but I'm hoping you all can help me with that. Posting ads with one photo will always be free, but sign up using the promo code: 10builders and you'll get the ability to post ads with 4 up to pictures for free as thanks for being one of the early adopters. (Or simply register with this link:) www.skyswapper.com/register.php?registration_code=10builders Since I'm a -10 builder, I decided that this is the group that I'd launch with first. The site is still in a beta release, so comments, suggestions, and complaints are all very important to me. Thanks for your time and happy building and flying! Ed Kranz RV10 (working on cabin top) SkySwapper.com <http://www.skyswapper.com> ________________________________________________________________________________
Date: Sep 09, 2013
Thanks to AZcloudflyer his tool and method worked the vent line doesn't leak anymore. Just for information this leak can not be detected with vans proposed method o leak testing because the leak is in the vent line inside the tank. You have to plug the vent line with your finger near the fuel cap opening and apply pleasure on the vent line fitting. Now HB-YNN is filled up and after 1h of flight it seams to still to be tight. Cheers Michael -------- RV-10 builder (final system testing) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408288#408288 ________________________________________________________________________________
Subject: Re: Launching online classifieds for homebuilders: SkySwapper.com
Date: Sep 09, 2013
Looks good Ed! I just registered and will be looking for stuff around the shop to sell. Good Luck! From: Ed Kranz Sent: Monday, September 9, 2013 10:58 AM Subject: RV10-List: Launching online classifieds for homebuilders: SkySwapper.com Hey everyone. Over the past few years I've noticed that many homebuilders tend to stick to their own online groups. Also, when people are looking to buy or sell parts (or planes), that experience is also quite fragmented. There will be different postings on email lists, VAF, and all the other dedicated builder sites... but often these listings would be of interest to everyone regardless of which type of plane they are building or flying. To try to help people reach across those divisions, I am launching a new website: SkySwapper.com It's an online classifieds site purely dedicated to the experimental aviation community. Of course, since it's brand new, it's pretty empty... but I'm hoping you all can help me with that. Posting ads with one photo will always be free, but sign up using the promo code: 10builders and you'll get the ability to post ads with 4 up to pictures for free as thanks for being one of the early adopters. (Or simply register with this link:) www.skyswapper.com/register.php?registration_code=10builders Since I'm a -10 builder, I decided that this is the group that I'd launch with first. The site is still in a beta release, so comments, suggestions, and complaints are all very important to me. Thanks for your time and happy building and flying! Ed Kranz RV10 (working on cabin top) SkySwapper.com ________________________________________________________________________________
Date: Sep 09, 2013
Geoff, That's the old 121.5. The new 406 E-04 is much longer and won't fit. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs Sent: Monday, September 09, 2013 11:42 AM Subject: RE: RV10-List: ACK E04 ELT MOUNTING I built little aluminum standoffs and works great Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Sausen Sent: Monday, September 09, 2013 11:23 AM Subject: RE: RV10-List: ACK E04 ELT MOUNTING Couldn't get mine to fit there anymore when I switched, ended up making a spot for it next to the batteries like others. Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Sunday, September 08, 2013 11:15 PM Subject: RV10-List: ACK E04 ELT MOUNTING I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=408254#408254 ________________________________________________________________________________
Date: Sep 09, 2013
Not true.... I added legs to my bracket on the new E-04 and that makes it fit fine. I think that's what Geoff was referring to also. The old one was shaped differently. The new one I needed to raise up a little, and then it fit fine. Here's my write-up from 2011 when I did it. http://www.myrv10.com/N104CD/upgrades/20110506/index.html Tim On 9/9/2013 1:50 PM, Michael Sausen wrote: > > Geoff, > > That's the old 121.5. The new 406 E-04 is much longer and won't fit. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Geoff Combs > Sent: Monday, September 09, 2013 11:42 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: ACK E04 ELT MOUNTING > > I built little aluminum standoffs and works great > > > Geoff Combs > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Michael Sausen > Sent: Monday, September 09, 2013 11:23 AM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: ACK E04 ELT MOUNTING > > > Couldn't get mine to fit there anymore when I switched, ended up making a spot for it next to the batteries like others. > > Michael > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: Sunday, September 08, 2013 11:15 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: ACK E04 ELT MOUNTING > > > I noted that Tim Olson has mounted the ELT basically under the vertical stabilizer and between the elevator trim control cables. For the ACK unit, it seems that it will be a very tight fit. Anyone done it? Photo? Also, how does the antenna live under the fairing with the 20 degree angle? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=408254#408254 > > ________________________________________________________________________________
August 06, 2013 - September 09, 2013
RV10-Archive.digest.vol-jm
