RV10-Archive.digest.vol-jo
October 24, 2013 - December 06, 2013
      ns that I need?
      > Chris Hukill
      3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
      D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
Date: Oct 24, 2013
Subject: Re: Prop spinner cutouts
Hmm, I'd be surprised if Lycoming had that information, but Hartzell likely has it, because Hartzell makes spinners for their props. On 10/24/2013 1:02 AM, Patrick Pulis wrote: > Chris > > Lycoming can issue you with the correct cut out template. I don't have > it on my iPad, however ill send it to you once I'm on my computer. > > Warm regards > > Patrick Pulis > > > On 21 Oct 2013, at 8:33, "Chris Hukill" > wrote: > >> I'm trying to determine the optimum cutout dimensions for the blades >> on the 2 bladed Hartzell blended airfoil prop as Vans sells, using >> the standard spinner kit. The instructions tell you to rotate the >> blades thru full travel to check for clearance, however I don't have >> an engine to mount the prop to yet, and it's not possible to move the >> blades without one. I am trying to get as tight of fit as is >> possible. I have looked at production airplane's installations, and >> they have a much larger clearance than I would consider aesthetic. >> Has anyone made a template or drawings that would provide the >> dimensions that I need? >> Chris Hukill >> * >> >> >> * > * > > > * ________________________________________________________________________________
Date: Oct 24, 2013
Is this what you are looking for? On Thu, Oct 24, 2013 at 8:51 AM, Kelly McMullen wrote: > > Hmm, I'd be surprised if Lycoming had that information, but Hartzell > likely has it, because Hartzell makes spinners for their props. > > On 10/24/2013 1:02 AM, Patrick Pulis wrote: > >> Chris >> >> Lycoming can issue you with the correct cut out template. I don't have it >> on my iPad, however ill send it to you once I'm on my computer. >> >> Warm regards >> >> Patrick Pulis >> >> >> On 21 Oct 2013, at 8:33, "Chris Hukill" > cjhukill(at)cox.net>> wrote: >> >> I'm trying to determine the optimum cutout dimensions for the blades on >>> the 2 bladed Hartzell blended airfoil prop as Vans sells, using the >>> standard spinner kit. The instructions tell you to rotate the blades thru >>> full travel to check for clearance, however I don't have an engine to mount >>> the prop to yet, and it's not possible to move the blades without one. I am >>> trying to get as tight of fit as is possible. I have looked at production >>> airplane's installations, and they have a much larger clearance than I >>> would consider aesthetic. Has anyone made a template or drawings that would >>> provide the dimensions that I need? >>> Chris Hukill >>> * >>> >>> >>> * >>> >> * >> >> >> * >> > > ________________________________________________________________________________
Subject: Re: Copperstate RV-10 Nest 2013
Date: Oct 24, 2013
All set up due south of the Van's display. Easier to get to now that the fence is gone. Lots of seating and shade. Cold drinks in the cooler. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411376#411376 ________________________________________________________________________________
Subject: Dynon D10A EFIS
Date: Oct 26, 2013
I am Considering the Dynon D10A as a backup EFIS. I noted that the operating temp range limit was 122F on the high side. As a reference point, I compared it to the temp range of the L-3's Trilogy ESI-1000 which is 165F on the high side. I would appreciate the observations from those of you that have used this unit. Thanks ________________________________________________________________________________
Subject: Re: Dynon D10A EFIS
Date: Oct 26, 2013
Terry, I use the D10A as a backup and have been very pleased with it. The internal 2 hour battery is what sold me initially (although in 2006 there weren't a lot of options). It does have some heat issues and I had to put a cooling fan above it (it is at the top of my stack) which conveniently serves as a defroster just in case. Since then I have had no problems whatsoever and it saved my bacon once already when the alternator gave out. Marcus On Oct 26, 2013, at 6:56 PM, Terry Moushon wrote: I am Considering the Dynon D10A as a backup EFIS. I noted that the operating temp range limit was 122F on the high side. As a reference point, I compared it to the temp range of the L-3's Trilogy ESI-1000 which is 165F on the high side. I would appreciate the observations from those of you that have used this unit. Thanks ________________________________________________________________________________
Date: Oct 26, 2013
We used one as a primary for years. A few temp issues when parked in the sun for a period of time, but never in flight. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Oct 26, 2013, at 6:56 PM, Terry Moushon wrote: > > > I am Considering the Dynon D10A as a backup EFIS. I noted that the operating temp range limit was 122F on the high side. As a reference point, I compared it to the temp range of the L-3's Trilogy ESI-1000 which is 165F on the high side. I would appreciate the observations from those of you that have used this unit. Thanks > > > > ________________________________________________________________________________
Date: Oct 26, 2013
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
More of the same: it's a good unit but it can overheat so plan accordingly. I installed a very small cooling fan after it blanked a couple times and it's been fine now for 1000 hrs. On Saturday, October 26, 2013, Terry Moushon wrote: ript:;> > > > > I am Considering the Dynon D10A as a backup EFIS. I noted that the > operating temp range limit was 122=C2=B0F on the high side. As a referen ce > point, I compared it to the temp range of the L-3's Trilogy ESI-1000 whic h > is 165=C2=B0F on the high side. I would appreciate the observations from those > of you that have used this unit. Thanks > =========== =========== =========== =========== > > -- --Dave Saylor ________________________________________________________________________________
Date: Oct 26, 2013
Why not go with the Dynon D1 that is less money, doesn't need pitot static system hookups and gives you most of what the D10A will? Granted you would be depending on GPS ground speed and ground track, but in most cases that isn't a big deal if you know what the wind is at point of intended landing. I guess it partly depends on where your main EFIS connection to ADAHRS and pitot/static system is located. Mine is in tail cone to avoid moving magnetic sources, so I didn't plumb pitot and static lines up to instrument panel. On 10/26/2013 3:56 PM, Terry Moushon wrote: > > I am Considering the Dynon D10A as a backup EFIS. I noted that the operating temp range limit was 122F on the high side. As a reference point, I compared it to the temp range of the L-3's Trilogy ESI-1000 which is 165F on the high side. I would appreciate the observations from those of you that have used this unit. Thanks > > ________________________________________________________________________________
Subject: Re: Fuel Pump Issue
Date: Oct 28, 2013
I went out on a weekend x-country flight (6 hours) and noticed some strange behavior. In cruise, my fuel flow readings would occasionally fluctuate between 9.5 and 10.5 gph without me touching anything... At the same time, the fuel psi changed from ~18 (normal) and 14psi. At 14 the engine would stumble. Same behavior on either tank... even after richening the mixture. Turning on the electric fuel pump caused the symptom to go away. No obvious leaks and no fuel smells. I'm wondering if I too have an issue lurking in the pump department. It's nearly time for my annual, so it's good timing as everything has to come apart anyway. Jay N433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411584#411584 ________________________________________________________________________________
Date: Oct 28, 2013
Myron; Sorry I missed the last carne asada this weekend. We were completely weathered in all weekend in SoCal, I was looking forward to seeing everyone. Maybe next time there is the "last and final", even if it means you fly in the RV versus drive in. Pascal -----Original Message----- From: woxofswa Sent: Thursday, October 24, 2013 8:29 PM Subject: RV10-List: Re: Copperstate RV-10 Nest 2013 All set up due south of the Van's display. Easier to get to now that the fence is gone. Lots of seating and shade. Cold drinks in the cooler. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411376#411376 ________________________________________________________________________________
Date: Oct 28, 2013
This was a strange year RV-10 wise. I can only think of two on the ground at any one time, Rob Hickman's, and a new one from Houston. In years past we've had upwards of 10 or more. Lots of "regulars " over several years didn't make it this year. Vendors I talked to said attendance was down, but higher percentage of serious buyers. My unofficial guess would be that RV-8's ruled the show, even with a formation flyby. Oh, and gyro copters, they seemed to be always in the pattern. Lack of a tower seemed to be no big deal even with jets mixing with ultralights. Our lunch numbers were down a bit this year, but those who came were fun, hungry, and generous. First time we've ever served all the asada we brought. The camping area was nice that it is now paved and seemed as full as any year. The weather was perfect and as far as I could tell, no aluminum or fabric was damaged. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411601#411601 ________________________________________________________________________________
Date: Oct 28, 2013
I seem to have the same problem when the RV10 is in warmer climates (Hangar in Las Vegas)... I take off out of colder climates Parowan Utah (5970 MSL) 32 degrees or so (with Cool Fuel) and the problem seems to disappear. I replaced the mechanical fuel pump about 30 hours ago thinking it was the pump. No change with the new pump. Fuel flow always remains the same, Boost pump makes the pressure issue go away... Jim Villani Kit# 41084 N10KQ 142.7 and counting Jim(at)JimVillani.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hotwheels Sent: Monday, October 28, 2013 6:43 AM Subject: RV10-List: Re: Fuel Pump Issue I went out on a weekend x-country flight (6 hours) and noticed some strange behavior. In cruise, my fuel flow readings would occasionally fluctuate between 9.5 and 10.5 gph without me touching anything... At the same time, the fuel psi changed from ~18 (normal) and 14psi. At 14 the engine would stumble. Same behavior on either tank... even after richening the mixture. Turning on the electric fuel pump caused the symptom to go away. No obvious leaks and no fuel smells. I'm wondering if I too have an issue lurking in the pump department. It's nearly time for my annual, so it's good timing as everything has to come apart anyway. Jay N433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411584#411584 ________________________________________________________________________________
Date: Oct 28, 2013
I suspect that some of the fuel pump issues are the fuel line rise to the selector valve as Van's plans call for. Some of us have worked to lower the valve as much as possible in the tunnel to reduce the uphill pull from the tanks. The mechanical pump can only generate about 1-2 psi of suction to pull fuel over that rise. Lowering the fuel pressure with that suction is going to make it easier for fuel to vaporize and create bubbles in the line. Pump does not do well with bubbles. On Mon, Oct 28, 2013 at 9:53 AM, JimVillani wrote: > > I seem to have the same problem when the RV10 is in warmer climates (Hangar > in Las Vegas)... I take off out of colder climates Parowan Utah (5970 MSL) > 32 degrees or so (with Cool Fuel) and the problem seems to disappear. > I replaced the mechanical fuel pump about 30 hours ago thinking it was the > pump. > No change with the new pump. > Fuel flow always remains the same, Boost pump makes the pressure issue go > away... > > Jim Villani > Kit# 41084 > N10KQ > 142.7 and counting > Jim(at)JimVillani.com > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hotwheels > Sent: Monday, October 28, 2013 6:43 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Fuel Pump Issue > > > I went out on a weekend x-country flight (6 hours) and noticed some strange > behavior. > > In cruise, my fuel flow readings would occasionally fluctuate between 9.5 > and 10.5 gph without me touching anything... At the same time, the fuel psi > changed from ~18 (normal) and 14psi. At 14 the engine would stumble. Same > behavior on either tank... even after richening the mixture. Turning on the > electric fuel pump caused the symptom to go away. No obvious leaks and no > fuel smells. > > I'm wondering if I too have an issue lurking in the pump department. It's > nearly time for my annual, so it's good timing as everything has to come > apart anyway. > > Jay > N433RV - flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411584#411584 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Oct 28, 2013
I'm using an Andair selector and the valve is pretty low in the tunnel as I had to buy an extender to reach it. Have occasionally seen engine stumble during very high AOA stall work if electric full pump is not running. Same when switching fuel tanks, but not always. Is 18psi fuel pressure off mechanical within "normal" range? Thanks, Jay N433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411613#411613 ________________________________________________________________________________
Date: Oct 28, 2013
You may want to read over this write up I did last year on this issue. I t hink this may be your issue. http://tcwtech.com/Fuel%20flow%20write-up.pdf Bob Newman N541RV Sent from my iPhone On Oct 28, 2013, at 7:42 AM, "hotwheels" wrote: > > I went out on a weekend x-country flight (6 hours) and noticed some strang e behavior. > > In cruise, my fuel flow readings would occasionally fluctuate between 9.5 a nd 10.5 gph without me touching anything... At the same time, the fuel psi c hanged from ~18 (normal) and 14psi. At 14 the engine would stumble. Same beh avior on either tank... even after richening the mixture. Turning on the ele ctric fuel pump caused the symptom to go away. No obvious leaks and no fuel s mells. > > I'm wondering if I too have an issue lurking in the pump department. It's n early time for my annual, so it's good timing as everything has to come apar t anyway. > > Jay > N433RV - flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411584#411584 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Oct 28, 2013
The physicist in me feels compelled to point out that the fuel pump does not pull fuel up to the fuel valve. This is like a siphon; atmospheric air pressure is sufficient to push the fuel up to the valve, and back to the tunnel floor. However, the conclusion that pressure is reduced at the high point is correct. I have a stock Vans setup and have never seen anything like a vapor lock issue, including some very hot weather flying. But I also have the post 2008 setup where Vans lowered the fuel valve location. Do those seeing problems have the earlier, higher mounted valves? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411621#411621 ________________________________________________________________________________
Date: Oct 28, 2013
I have the Andair valve mounted low in the tunnel actuated by an extension arm a few inches long. Bob Newman Sent from my iPhone On Oct 28, 2013, at 1:28 PM, "Bob Turner" wrote: > > The physicist in me feels compelled to point out that the fuel pump does not pull fuel up to the fuel valve. This is like a siphon; atmospheric air pressure is sufficient to push the fuel up to the valve, and back to the tunnel floor. However, the conclusion that pressure is reduced at the high point is correct. > > I have a stock Vans setup and have never seen anything like a vapor lock issue, including some very hot weather flying. But I also have the post 2008 setup where Vans lowered the fuel valve location. Do those seeing problems have the earlier, higher mounted valves? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411621#411621 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 28, 2013
Is the "rise" a cumulative effect or overall from the tanks to engine driven pump? I would think that the rise from the electric pump to the firewall AN fitting is greater than the rise from tunnel floor to the valve body. If cumulative then maybe the two put together is an issue? -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Monday, October 28, 2013 12:28 PM Subject: RV10-List: Re: Fuel Pump Issue The physicist in me feels compelled to point out that the fuel pump does not pull fuel up to the fuel valve. This is like a siphon; atmospheric air pressure is sufficient to push the fuel up to the valve, and back to the tunnel floor. However, the conclusion that pressure is reduced at the high point is correct. I have a stock Vans setup and have never seen anything like a vapor lock issue, including some very hot weather flying. But I also have the post 2008 setup where Vans lowered the fuel valve location. Do those seeing problems have the earlier, higher mounted valves? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411621#411621 ________________________________________________________________________________
Date: Oct 28, 2013
I have the same Sent from my iPhone On Oct 28, 2013, at 3:52 PM, Tcwtech wrote: I have the Andair valve mounted low in the tunnel actuated by an extension arm a few inches long. Bob Newman Sent from my iPhone > On Oct 28, 2013, at 1:28 PM, "Bob Turner" wrote: > > > The physicist in me feels compelled to point out that the fuel pump does not pull fuel up to the fuel valve. This is like a siphon; atmospheric air pressure is sufficient to push the fuel up to the valve, and back to the tunnel floor. However, the conclusion that pressure is reduced at the high point is correct. > > I have a stock Vans setup and have never seen anything like a vapor lock issue, including some very hot weather flying. But I also have the post 2008 setup where Vans lowered the fuel valve location. Do those seeing problems have the earlier, higher mounted valves? > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411621#411621 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 28, 2013
Bob, Very well written explanation of at least one factor in the problem. Not to mention that having the FF sending unit in the tunnel introduces two more connections in the tunnel that could leak. Van's reasoning is rather faulty in my view, since the red cube is FAA certified for use in the engine compartment, and in fact the STC that I have on my Mooney using the same sending unit requires the sending unit between the mechanical pump and the fuel servo on certified planes without a return line, and between the servo and the flow divider on planes with a return line. Also, IMHO, 18 PSI is inadequate for normal operation. My Mooney with IO-360 and the same pump sees 24-25 PSI as normal from fuel flow of 8 gph up to 18 gph, with normal cruise around 10 gph on mechanical pump only. Boost pump will add 1-2 psi with engine running. 14 psi is the absolute minimum for the Bendix RSA fuel injection, with 45 max. Unless I am looking at my fuselage crooked the stock Van's selector location is near the full fuel level of the tanks and way above the empty tank level, so gravity at less than something like 3/4 tank is not going to provide any flow of fuel through the selector without some initiating suction and a siphon to keep it going. Introduce any air or vapor and the siphon will be lost. On Mon, Oct 28, 2013 at 11:48 AM, Tcwtech wrote: > You may want to read over this write up I did last year on this issue. I > think this may be your issue. > > http://tcwtech.com/Fuel%20flow%20write-up.pdf > > Bob Newman > N541RV > > > Sent from my iPhone > > On Oct 28, 2013, at 7:42 AM, "hotwheels" wrote: > > > I went out on a weekend x-country flight (6 hours) and noticed some > strange behavior. > > In cruise, my fuel flow readings would occasionally fluctuate between 9.5 > and 10.5 gph without me touching anything... At the same time, the fuel psi > changed from ~18 (normal) and 14psi. At 14 the engine would stumble. Same > behavior on either tank... even after richening the mixture. Turning on the > electric fuel pump caused the symptom to go away. No obvious leaks and no > fuel smells. > > I'm wondering if I too have an issue lurking in the pump department. It's > nearly time for my annual, so it's good timing as everything has to come > apart anyway. > > Jay > N433RV - flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411584#411584 > > > ****http://www.matronics.com/Navigator?RV10-List > **http://forums.matr====================================================sp;   > href="http://www.matronics.com/contribution"> > http://www.matronics.com/con============================================ > > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Oct 28, 2013
I have a post 2008 and I have seen fuel pressure issues in a climb once out of 101F in Arizona and after a 2nd takeoff in 90F SoCal, right after refueling. In both cases the VP-200 threw in the autoboost and it was gone. It happens, but rarely. Engine has no idea there is a problem or it doesnt sound like it does anyway My biggest issue remains the fuel flow- it will vary from 10.2gph to 9.9 without changing a thing, than go back up to 10.1 and back and forth in-between. Pascal -----Original Message----- From: Bob Turner Sent: Monday, October 28, 2013 12:28 PM Subject: RV10-List: Re: Fuel Pump Issue The physicist in me feels compelled to point out that the fuel pump does not pull fuel up to the fuel valve. This is like a siphon; atmospheric air pressure is sufficient to push the fuel up to the valve, and back to the tunnel floor. However, the conclusion that pressure is reduced at the high point is correct. I have a stock Vans setup and have never seen anything like a vapor lock issue, including some very hot weather flying. But I also have the post 2008 setup where Vans lowered the fuel valve location. Do those seeing problems have the earlier, higher mounted valves? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411621#411621 ________________________________________________________________________________
Date: Oct 28, 2013
I see 24 psi from my mechanical pump. 28 or so for electric. Dave Leikam On Oct 28, 2013, at 12:43 PM, hotwheels wrote: > > I'm using an Andair selector and the valve is pretty low in the tunnel as I had to buy an extender to reach it. Have occasionally seen engine stumble during very high AOA stall work if electric full pump is not running. Same when switching fuel tanks, but not always. Is 18psi fuel pressure off mechanical within "normal" range? > > Thanks, > Jay > N433RV - flying > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411613#411613 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2013
From: "Dave Fritzsche (Building)" <dfritz(at)bpgsim.com>
Subject: Re: Oil Canning of the Bottom Wing Skin
I know this is an old message, but you mentioned trimming the bottom skin. How did you trim the skin to remove the small amount and preserve the squareness of the bottom skin? Dave ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings On 7/16/2008 5:47 AM, Wayne Hadath wrote: > > There has been discussion in the past about oil canning of the bottom > wing skin. I do not know if this will be true for all kits but I just > installed the right skin and it needed trimming at the main spar edge. > It was necessary to remove between 1/32 and 1/16 to get the skin to > lay flat. If I had not trimmed it the skin would have butted up > against the forward skin and this would have created lots of oil > canning. With the skin trimmed and largely using Vans instruction the > skin is tight, a small ding here and there but tight. Bruising should > heal in a week or so. > > Wayne Hadath > > F1 Rocket C-FAUH 260 hrs > > > Checked by AVG. > 15/07/2008 6:03 PM > * > > > * ________________________________________________________________________________
Date: Oct 29, 2013
This might be semantics but that looks like a +/-1.5% fluctuation. Assuming you're using a red cube, EI claims 2%, but they don't say if it's +/- or overall. I see similar fluctuations. I figured it was just noise. Dave Saylor 831-750-0284 CL On Mon, Oct 28, 2013 at 6:02 PM, Pascal wrote: > > I have a post 2008 and I have seen fuel pressure issues in a climb once > out of 101F in Arizona and after a 2nd takeoff in 90F SoCal, right after > refueling. In both cases the VP-200 threw in the autoboost and it was gon e. > It happens, but rarely. Engine has no idea there is a problem or it doesn =99t > sound like it does anyway > > My biggest issue remains the fuel flow- it will vary from 10.2gph to 9.9 > without changing a thing, than go back up to 10.1 and back and forth > in-between. > Pascal > > -----Original Message----- From: Bob Turner > Sent: Monday, October 28, 2013 12:28 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Fuel Pump Issue > > > The physicist in me feels compelled to point out that the fuel pump does > not pull fuel up to the fuel valve. This is like a siphon; atmospheric ai r > pressure is sufficient to push the fuel up to the valve, and back to the > tunnel floor. However, the conclusion that pressure is reduced at the hig h > point is correct. > > I have a stock Vans setup and have never seen anything like a vapor lock > issue, including some very hot weather flying. But I also have the post > 2008 setup where Vans lowered the fuel valve location. Do those seeing > problems have the earlier, higher mounted valves? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/**viewtopic.php?p=411621#411621 ms.matronics.com/viewtopic.php?p=411621#411621> > > =====**=================== ===========**= ronics.com/Navigator?RV10-List> =====**=================== ===========**= =====**=================== ===========**= com/contribution> =====**=================== ===========**= > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Oil Canning of the Bottom Wing Skin
Date: Oct 29, 2013
Very carefully using your Vixen file. Take a little at a time, cleko the skin back on, remark the area to trim, repeat. Easier than it sounds. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Fritzsche (Building) Sent: Tuesday, October 29, 2013 11:46 AM Subject: Re: RV10-List: Oil Canning of the Bottom Wing Skin I know this is an old message, but you mentioned trimming the bottom skin. How did you trim the skin to remove the small amount and preserve the squareness of the bottom skin? Dave ~~~~~~~~~~~~~~ Dave Fritzsche 40813 Puyallup, WA Wings On 7/16/2008 5:47 AM, Wayne Hadath wrote: There has been discussion in the past about oil canning of the bottom wing skin. I do not know if this will be true for all kits but I just installed the right skin and it needed trimming at the main spar edge. It was necessary to remove between 1/32 and 1/16 to get the skin to lay flat. If I had not trimmed it the skin would have butted up against the forward skin and this would have created lots of oil canning. With the skin trimmed and largely using Vans instruction the skin is tight, a small ding here and there but tight. Bruising should heal in a week or so. Wayne Hadath F1 Rocket C-FAUH 260 hrs Checked by AVG. 15/07/2008 6:03 PM ________________________________________________________________________________
Subject: power settings for descent or climbs
Date: Oct 29, 2013
Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if it=99s 500fpm it would be 5X that setting) Thank you! Pascal ________________________________________________________________________________
Subject: Re: power settings for descent or climbs
Date: Oct 29, 2013
If you are landing at 120 K, I hope you have a very long runway. Only partially answering your question, I get the following from my -10: 17" clean = 120K 15" clean = 110K 12" & flaps1 = 85K with 500 fpm descent Jim Berry RV-10 Read this topic online here:
http://forums.matronics.com/viewtopic.php?p=411688#411688 ________________________________________________________________________________
Date: Oct 29, 2013
Here is a start I did for this. Adjust as needed. I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). Carl N7ZK Power/Speed Configuration Setting May 26, 2013 MP RPM IAS VS Climb 24 2400 130 1000 Cruise Dec 14 2300 130 -500 18 2350 170 -500 Appr Level 18 2200 120 ---- Prec Appr Dec 14 2200 87 -300 N-Pres Appr Dec 12 2200 87 -700 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Tuesday, October 29, 2013 12:24 PM Subject: RV10-List: power settings for descent or climbs Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if it=99s 500fpm it would be 5X that setting) Thank you! Pascal ________________________________________________________________________________
Date: Oct 29, 2013
Thank you Carl! what I was looking for as a start. Pascal From: Carl Froehlich Sent: Tuesday, October 29, 2013 11:12 AM Subject: RE: RV10-List: power settings for descent or climbs Here is a start I did for this. Adjust as needed. I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). Carl N7ZK Power/Speed Configuration Setting May 26, 2013 MP RPM IAS VS Climb 24 2400 130 1000 Cruise Dec 14 2300 130 -500 18 2350 170 -500 Appr Level 18 2200 120 ---- Prec Appr Dec 14 2200 87 -300 N-Pres Appr Dec 12 2200 87 -700 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Tuesday, October 29, 2013 12:24 PM Subject: RV10-List: power settings for descent or climbs Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if it=99s 500fpm it would be 5X that setting) Thank you! Pascal http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 29, 2013
You must not fly into very many busy airports. Why not fly 120 to Loc intercept and 100 from FAF to DH? Most any precision approach will have at least 7-8000 ft runway to get slowed down to land, and you are only needing to lose 30 kts with flaps. I use 105 from turn on to final in my Mooney and that is due to gear speed limit of 105, so I can drop gear at glideslope intercept. No problem slowing from there to 70 kts over runway end with the same 87kt flap speed limit as the -10. I don't use flaps until have runway in sight. Makes for easier missed approach and better fit with faster traffic. On 10/29/2013 11:12 AM, Carl Froehlich wrote: > Here is a start I did for this. Adjust as needed. > > > > I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). > > > > Carl > > > > N7ZK Power/Speed Configuration Setting > > May 26, 2013 > > > > MP RPM IAS VS > > Climb 24 2400 130 1000 > > > > Cruise Dec 14 2300 130 -500 > > 18 2350 170 -500 > > > > Appr Level 18 2200 120 ---- > > > > Prec Appr Dec 14 2200 87 -300 > > > > N-Pres Appr Dec 12 2200 87 -700 > > > > > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal > Sent: Tuesday, October 29, 2013 12:24 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: power settings for descent or climbs > > > > Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if its 500fpm it would be 5X that setting) > > Thank you! > > > > Pascal > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2013
I think if the weather is down to minimums you might want to come in slow to give yourself the best chance of seeing the runway. Nikolaos Napoli > On Oct 29, 2013, at 4:28 PM, Kelly McMullen wrote: > > > You must not fly into very many busy airports. Why not fly 120 to Loc intercept and 100 from FAF to DH? Most any precision approach will have at least 7-8000 ft runway to get slowed down to land, and you are only needing to lose 30 kts with flaps. > I use 105 from turn on to final in my Mooney and that is due to gear speed limit of 105, so I can drop gear at glideslope intercept. No problem slowing from there to 70 kts over runway end with the same 87kt flap speed limit as the -10. I don't use flaps until have runway in sight. Makes for easier missed approach and better fit with faster traffic. > >> On 10/29/2013 11:12 AM, Carl Froehlich wrote: >> Here is a start I did for this. Adjust as needed. >> >> >> I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). >> >> >> Carl >> >> >> N7ZK Power/Speed Configuration Setting >> >> May 26, 2013 >> >> >> MP RPM IAS VS >> >> Climb 24 2400 130 1000 >> >> >> Cruise Dec 14 2300 130 -500 >> >> 18 2350 170 -500 >> >> >> Appr Level 18 2200 120 ---- >> >> >> Prec Appr Dec 14 2200 87 -300 >> >> >> N-Pres Appr Dec 12 2200 87 -700 >> >> >> >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal >> Sent: Tuesday, October 29, 2013 12:24 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: power settings for descent or climbs >> >> >> Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if its 500fpm it would be 5X that setting) >> >> Thank you! >> >> >> Pascal >> >> >> > > > > > ________________________________________________________________________________
Date: Oct 29, 2013
Before this goes off on landing approaches, I was using that as an example. I really should have asked what power change is needed at cruise to keep airspeed at (constant) for a 500fpm descent or climb. I'll go out and fly around and figure this out. Was just trying to recall what a change of 1MP would do. Thx Pascal Sent from my iPad > On Oct 29, 2013, at 1:35 PM, "Kelly McMullen" wrote: > > > You must not fly into very many busy airports. Why not fly 120 to Loc intercept and 100 from FAF to DH? Most any precision approach will have at least 7-8000 ft runway to get slowed down to land, and you are only needing to lose 30 kts with flaps. > I use 105 from turn on to final in my Mooney and that is due to gear speed limit of 105, so I can drop gear at glideslope intercept. No problem slowing from there to 70 kts over runway end with the same 87kt flap speed limit as the -10. I don't use flaps until have runway in sight. Makes for easier missed approach and better fit with faster traffic. > >> On 10/29/2013 11:12 AM, Carl Froehlich wrote: >> Here is a start I did for this. Adjust as needed. >> >> >> I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). >> >> >> Carl >> >> >> N7ZK Power/Speed Configuration Setting >> >> May 26, 2013 >> >> >> MP RPM IAS VS >> >> Climb 24 2400 130 1000 >> >> >> Cruise Dec 14 2300 130 -500 >> >> 18 2350 170 -500 >> >> >> Appr Level 18 2200 120 ---- >> >> >> Prec Appr Dec 14 2200 87 -300 >> >> >> N-Pres Appr Dec 12 2200 87 -700 >> >> >> >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal >> Sent: Tuesday, October 29, 2013 12:24 PM >> To: rv10-list(at)matronics.com >> Subject: RV10-List: power settings for descent or climbs >> >> >> Looking for the initial reduction/increase power change needed for climbs or descents to keep the same airspeed? (example- landing at 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how much power would I need to pull for every 100 fpm? so if its 500fpm it would be 5X that setting) >> >> Thank you! >> >> >> Pascal > > > > > ________________________________________________________________________________
Date: Oct 29, 2013
The traditional rule of thumb is 1" MP gives you 100 ft per minute, same speed. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411705#411705 ________________________________________________________________________________
Date: Oct 29, 2013
Yep - adjust approach speed as needed for the environment. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Tuesday, October 29, 2013 4:29 PM Subject: Re: RV10-List: power settings for descent or climbs You must not fly into very many busy airports. Why not fly 120 to Loc intercept and 100 from FAF to DH? Most any precision approach will have at least 7-8000 ft runway to get slowed down to land, and you are only needing to lose 30 kts with flaps. I use 105 from turn on to final in my Mooney and that is due to gear speed limit of 105, so I can drop gear at glideslope intercept. No problem slowing from there to 70 kts over runway end with the same 87kt flap speed limit as the -10. I don't use flaps until have runway in sight. Makes for easier missed approach and better fit with faster traffic. On 10/29/2013 11:12 AM, Carl Froehlich wrote: > Here is a start I did for this. Adjust as needed. > > > > I have been using 120 knots for initial approach, 100 knots at the IAP, and 87 knots at the FAF (full flap speed). > > > > Carl > > > > N7ZK Power/Speed Configuration Setting > > May 26, 2013 > > > > MP RPM IAS VS > > Climb 24 2400 130 1000 > > > > Cruise Dec 14 2300 130 -500 > > 18 2350 170 -500 > > > > Appr Level 18 2200 120 ---- > > > > Prec Appr Dec 14 2200 87 -300 > > > > N-Pres Appr Dec 12 2200 87 -700 > > > > > > > > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal > Sent: Tuesday, October 29, 2013 12:24 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: power settings for descent or climbs > > > > Looking for the initial reduction/increase power change needed for > climbs or descents to keep the same airspeed? (example- landing at > 120kts, aircraft is setup at cruise to be at 120kts when reach OM, how > much power would I need to pull for every 100 fpm? so if its 500fpm > it would be 5X that setting) > > Thank you! > > > > Pascal > > > > > > > ________________________________________________________________________________
Date: Oct 29, 2013
I spoke to a couple of vendors and my A&P of choice yesterday. The consensus was to: * Revisit sensor settings and connections (I don't expect this one to reveal much) * Closely examine the fuel system for anything obvious. * Replace the Tempest Fuel Pump with a (new, not rebuilt) genuine Lycoming Pump 18 psi is definitely not acceptable. Van's had no input (guess who sold me the fuel pump). They claimed they'd never heard of such a thing and were out of touch (their words) with builders. Really? If so, that's disturbing on several levels. This particular component is too darn critical to screw around with. It needs to work and be a known quantity. Jay 433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411712#411712 ________________________________________________________________________________
Date: Oct 29, 2013
I did simulated take offs at altitude with the boost pump off. My fuel pump was rock steady at 22-23 psi. I still don't know if the pump replacement or the cooling shroud was the solution. bob -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hotwheels Sent: Tuesday, October 29, 2013 6:03 PM Subject: RV10-List: Re: Fuel Pump Issue I spoke to a couple of vendors and my A&P of choice yesterday. The consensus was to: * Revisit sensor settings and connections (I don't expect this one to reveal much) * Closely examine the fuel system for anything obvious. * Replace the Tempest Fuel Pump with a (new, not rebuilt) genuine Lycoming Pump 18 psi is definitely not acceptable. Van's had no input (guess who sold me the fuel pump). They claimed they'd never heard of such a thing and were out of touch (their words) with builders. Really? If so, that's disturbing on several levels. This particular component is too darn critical to screw around with. It needs to work and be a known quantity. Jay 433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411712#411712 ________________________________________________________________________________
Date: Oct 29, 2013
Well, the Lycoming pump had an AD on it, as did the AC pump that it was copied from. I don't recall there being one on Tempest. I've been flying behind an overhauled AC pump for about 14 years with no problem at all, roughly 650 hours. If those recommending new Lycoming are involved in the procurement in any way, I'd disregard the advice. The pump is one of the easiest devices out there to overhaul, mostly replace two diaphragms. Talk to Tempest about it, they might be interested, as they are generally one of the more reputable parts vendors. Kelly A&P/IA On 10/29/2013 3:03 PM, hotwheels wrote: > > I spoke to a couple of vendors and my A&P of choice yesterday. The consensus was to: > > * Revisit sensor settings and connections (I don't expect this one to reveal much) > > * Closely examine the fuel system for anything obvious. > > * Replace the Tempest Fuel Pump with a (new, not rebuilt) genuine Lycoming Pump > > 18 psi is definitely not acceptable. Van's had no input (guess who sold me the fuel pump). They claimed they'd never heard of such a thing and were out of touch (their words) with builders. Really? If so, that's disturbing on several levels. > > This particular component is too darn critical to screw around with. It needs to work and be a known quantity. > > Jay > 433RV - flying > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411712#411712 > > ________________________________________________________________________________
Date: Nov 01, 2013
Subject: PLEASE READ - Matronics Email List Fund Raiser During November!
Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Tires and tubes
Based on feedback here, I think I'm going to stick with the Aero Classics tires, but switch to Michelan Airstop tubes. Anyone have an issue with this combination? Are there different valve stem angle options with these tubes? Thanks much... -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Re: Tires and tubes
This is what I have my -10 sitting on: 15/600-6 "Leakguard" Butyl Tube with the "New Easy Valve" for the mains, and 500-5 "Leakguard" Butyl Tube with the TR-67 Valve for the nose. The tube for the mains was designed for Cirri, that have similar wheel pants access issues. Leakguard is Desser's in-house branding of what is supposed to be same as Air Stop at lower cost. I think I put air in them once over past year to make moving fuselage easier. On Fri, Nov 1, 2013 at 1:03 PM, Rob Kochman wrote: > Based on feedback here, I think I'm going to stick with the Aero Classics > tires, but switch to Michelan Airstop tubes. Anyone have an issue with > this combination? Are there different valve stem angle options with these > tubes? Thanks much... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 01, 2013
I have been using the same tires & tubes as Kelly for 2-3 years without any issues. I do have to add air about every 6 months; probably because our air in Colorado is thinner. [Wink] Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411940#411940 ________________________________________________________________________________
Subject: Re: PLEASE READ - Matronics Email List Fund Raiser During
November!
Date: Nov 01, 2013
Please unsubscribe me from this forum -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Fri, 1 Nov 2013 4:28 Subject: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During N ovember! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operat ion and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or othe r related pages such as the List Search Engine http://www.matronics.com/searc h , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjo y - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every coup le of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regu lar messages. The Fund Raiser is only financial support mechanism I have to pa y all of the bills associated with running these lists. YOUR personal Contributi on counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go al ong with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some o f the vary members and vendors that you'll find on the Matronics Lists and they h ave been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric .com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product lin e. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their gener ous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three met hods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot ________________________________________________________________________________
November!
Date: Nov 01, 2013
follow instructions: - http://www.matronics.com/Navigator?RV10-List Use the Matronics List Un/Subscription From: Jmsfrnch Sent: Friday, November 01, 2013 6:32 PM Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Please unsubscribe me from this forum -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> Sent: Fri, 1 Nov 2013 4:28 Subject: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com ________________________________________________________________________________
Date: Nov 01, 2013
Subject: Re: PLEASE READ - Matronics Email List Fund Raiser During November!
"The Unsubscribed" The cold fog thickened noticeably as the newcomer hurried towards his destination. He pulled his heavy overcoat around his neck a little more tightly. This part of the city was not a place to tarry. Thieves and whores were the only permanent residents here. Even the cops rolled through these streets with a nervousness and an edge to heir normal macho banter. Trouble and misery closed around everyone who ventured into this pustule of urban blight like a leech on a warm vein. "Damn!", he hissed under his breath as he stepped on something soft that squealed and skittered off into the darkness and dankness of the mist. It can't be much farther he thought. It mustn't be much farther. The sickly yellow flicker of light from a street lamp shone dimly through the fog as he quickened his pace. There it was. The doorway seemed to be just blackness without definition. As he got closer, two winos eyed him suspiciously through bloodshot and yellowed eyes. He hustled past them, their breath leaving a rank scent that lingered on his clothes. The door pushed inward and the newcomer was inside. The room was smoky and dim. The bar stank of liquor and broken dreams. Several tables decorated the periphery. The man he had come to see was sitting at one of those tables and beckoned him over to sit. The man was darkly clothed and utterly shapeless. He might have weighed three hundred pounds... or he may have been only bone. His shape was indecipherable. The dark mans eyes were gazing down at the dirty glass in his hand, half filled with cheap whiskey. He had been reading a glossy magazine filled with lurid and obscene images. He folded it tenderly and stuffed it quickly into his coat pocket like a vulture gobbling a rotten piece of flesh. "What is it you want of me?", the dark man asked, not lifting his eyes from the glass. His voice rumbled deep in his belly like a toad. "I need you to tell me how to unsubscribe", said the newcomer in as even a tone as he could muster. The dark man looked up from his glass slowly to gaze at the newcomer. His eyes were a pale watery blue. And his gaze lingered on the newcomer. "You wish to unsubscribe?", he said, with a hint of amusement in his voice but no trace of a smile on his thick pasty lips. "You come to me with a need to unsubscribe?", he said, his voice getting louder now and any hint of amusement gone. He sucked in his breath and hissed through his teeth spraying the newcomer with a repulsive mist of spittle, "Why? Tell me why it is that you wish to unsubscribe." The newcomer felt fear now creeping up his spine. "I don't have the time to sort through all the posts", he mumbled. The dark man sat unmoved, his eyes stared at the newcomer without emotion. His eyes were cold and amphibian. "And I sold the RV and bought a Bonanza ", added the newcomer. He realized in a heart beat that he should not have said that. The dark man had him by the throat with a quickness that seemed otherworldly. And the dark man squeezed that throat as the newcomer wriggled and squirmed in a voiceless scream. The dark man pulled the newcomers face to his own until they nearly touched noses. He breathed his fetid breath on the newcomer and a trickle of drool escaped his mouth to plop loudly on the table between them. "Go!", he rumbled. "Go now you fool!", he bellowed. "Run if you can. It shall do you no good! Once you have subscribed, all hope of ever unsubscribing is gone! We will find you. Your email is now ours to control. Your email box will fill to bursting with our messages. And there is no hope for you. There is no good deed you can do to change what you have done. The List will not be denied!" And with that he released the newcomer who reeled and staggered towards the door, gagging and stumbling. The dark man began to laugh, a low rumbling laugh that grew louder. The newcomer fled up the streets as he had come with the croaking bellowing laughter chasing him. He was doomed... and he knew it. The dark man sat back at the table in the dimly lit bar and sipped at his drink. "I guess I could have just told him to go to * http://www.matronics.com/Navigator?RV10-List* and use the one click unsubscribe URL at the end of page", he muttered under his breath. No, he smiled to himself. That would have been all too easy. Still chuckling to himself, he reached into his pocket and pulled out the magazine he had been reading before the newcomer interrupted him. He quickly thumbed through the slick and edge worn pages until he found his place. He never missed a single word of each and every issue of Martha Stewart Living... Anonymous On Fri, Nov 1, 2013 at 8:27 PM, Pascal wrote: > follow instructions: > *- http://www.matronics.com/Navigator?RV10-List Use the Matronics List > Features Navigator to many List utilities such as List Un/Subscription* > > *From:* Jmsfrnch > *Sent:* Friday, November 01, 2013 6:32 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser > During November! > > Please unsubscribe me from this forum > > > -----Original Message----- > From: Matt Dralle <dralle(at)matronics.com> > To: rv10-list > Sent: Fri, 1 Nov 2013 4:28 > Subject: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During > November! > > > Dear Listers, > > Each November I hold a PBS-like fund raiser to support the continued operation > and upgrade of the Email List and Fourm Services at Matronics. It's solely > through the Contributions of List members (you) that these Matronics Lists are > possible. > > You have probably noticed that there are no banner ads or pop-up windows on any > of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other > related pages such as the List Search Engine http://www.matronics.com/search , > List Browse http://www.matronics.com/listbrowse , etc. This is because I > believe in a List experience that is completely about the sport we all enjoy - > namely Airplanes and not about annoying advertisements. > > During the month of November I will be sending out List messages every couple of > days reminding everyone that the Fund Raiser is underway. I ask for your > patience and understanding during the Fund Raiser and throughout these regular > messages. The Fund Raiser is only financial support mechanism I have to pay all > of the bills associated with running these lists. YOUR personal Contribution > counts! > > This year we have a really HUGE and TERRIFIC line up of free gifts to go along > with the various Contribution levels. In fact, there are over 30 different > gifts to choose from - more than we've ever had before! There's something for > everyone, to be sure. Most all of these gifts have been provided by some of the > vary members and vendors that you'll find on the Matronics Lists and they have > been either donated or provided at substantially discounted rates. > > This year, these generous members include: > > > Andy Gold of the Builder's Bookstore http://www.buildersbooks.com > > Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com > > Corbin Glowacki of My Pilot Store http://www.mypilotstore.com > > George Race of Race Consulting http://www.mrrace.com/ > > Jon Croke of HomebuiltHELP http://www.homebuilthelp.com > > > These are very generous guys and I encourage you to visit their respective web > sites. Each one offers a unique and excellent aviation-related product line. I > would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous > support of the Lists again this year!! > > Please make your List Contribution using any one of three secure methods > including using a credit card, PayPal, or by personal check. All three methods > afford you the opportunity to select one of this year's free gifts with a > qualifying Contribution amount!! > > To make your Contribution, please visit the secure web site: > > http://www.matronics.com/contribution > > I would like to thank everyone in advance for their generous financial AND moral > support over the years! > > Thank you! > > Matt Dralle > Matronics Email List Administrator > RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot > > > _blank">www.aeroelectric.com > " target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > ="_blank">www.mypilotstore.com > ank">www.mrrace.com > _blank">http://www.matronics.com/contribution > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > > > * > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.mypilotstore.com">www.mypilotstore.com > href="http://www.mrrace.com">www.mrrace.com > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com* > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 02, 2013
Subject: Front Tire Installation
From: Vernon Franklin <vernon.franklin(at)gmail.com>
Has anyone run into this situation? Either my U-1009 Axle is to short, or my U-1023 spacers are to long. You can see by the attached pictures that I am about 1/8" short on the axle. When I went to install the wheel, and torqued the AN6, the wheel didn't turn very well. All of the pressure appears to be placed on the spacers as opposed to the axle. I verified the wheel halves are tight against each other. Any ideas? Thanks, -- Vernon Franklin ________________________________________________________________________________
Subject: Re: Front Tire Installation
Date: Nov 02, 2013
That is the way it is supposed to be. The spacers are supposed to put a preload on the bearings so the axle doesn't turn. In the past I have turned down the axle w little to increase the preload. The wheel will not turn very freely, but you want to make sure the spacers do NOT turn, but rather the wheel turns while the bearings don't. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Nov 2, 2013, at 3:22 PM, Vernon Franklin wrote: > > Has anyone run into this situation? Either my U-1009 Axle is to > short, or my U-1023 spacers are to long. You can see by the attached > pictures that I am about 1/8" short on the axle. > > When I went to install the wheel, and torqued the AN6, the wheel > didn't turn very well. All of the pressure appears to be placed on > the spacers as opposed to the axle. > > I verified the wheel halves are tight against each other. > Any ideas? > > Thanks, > > -- > Vernon Franklin > <20131102_135338.jpg> > <20131102_135324.jpg> ________________________________________________________________________________
Date: Nov 02, 2013
Easily cured with a Matco axle in place of Van's home brew solution. Lets you set preload on bearings independent of the nose gear forks. On Sat, Nov 2, 2013 at 12:22 PM, Vernon Franklin wrote: > Has anyone run into this situation? Either my U-1009 Axle is to > short, or my U-1023 spacers are to long. You can see by the attached > pictures that I am about 1/8" short on the axle. > > When I went to install the wheel, and torqued the AN6, the wheel > didn't turn very well. All of the pressure appears to be placed on > the spacers as opposed to the axle. > > I verified the wheel halves are tight against each other. > Any ideas? > > Thanks, > > -- > Vernon Franklin > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 02, 2013
Now that=99s funny. Michael ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- From: Kelly McMullen Sent: Friday, November 1, 2013 9:08 PM Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! "The Unsubscribed" The cold fog thickened noticeably as the newcomer hurried towards his destination. He pulled his heavy overcoat around his neck a little more tightly. This part of the city was not a place to tarry. Thieves and whores were the only permanent residents here. Even the cops rolled through these streets with a nervousness and an edge to heir normal macho banter. Trouble and misery closed around everyone who ventured into this pustule of urban blight like a leech on a warm vein. "Damn!", he hissed under his breath as he stepped on something soft that squealed and skittered off into the darkness and dankness of the mist. It can't be much farther he thought. It mustn't be much farther. The sickly yellow flicker of light from a street lamp shone dimly through the fog as he quickened his pace. There it was. The doorway seemed to be just blackness without definition. As he got closer, two winos eyed him suspiciously through bloodshot and yellowed eyes. He hustled past them, their breath leaving a rank scent that lingered on his clothes. The door pushed inward and the newcomer was inside. The room was smoky and dim. The bar stank of liquor and broken dreams. Several tables decorated the periphery. The man he had come to see was sitting at one of those tables and beckoned him over to sit. The man was darkly clothed and utterly shapeless. He might have weighed three hundred pounds... or he may have been only bone. His shape was indecipherable. The dark mans eyes were gazing down at the dirty glass in his hand, half filled with cheap whiskey. He had been reading a glossy magazine filled with lurid and obscene images. He folded it tenderly and stuffed it quickly into his coat pocket like a vulture gobbling a rotten piece of flesh. "What is it you want of me?", the dark man asked, not lifting his eyes from the glass. His voice rumbled deep in his belly like a toad. "I need you to tell me how to unsubscribe", said the newcomer in as even a tone as he could muster. The dark man looked up from his glass slowly to gaze at the newcomer. His eyes were a pale watery blue. And his gaze lingered on the newcomer. "You wish to unsubscribe?", he said, with a hint of amusement in his voice but no trace of a smile on his thick pasty lips. "You come to me with a need to unsubscribe?", he said, his voice getting louder now and any hint of amusement gone. He sucked in his breath and hissed through his teeth spraying the newcomer with a repulsive mist of spittle, "Why? Tell me why it is that you wish to unsubscribe." The newcomer felt fear now creeping up his spine. "I don't have the time to sort through all the posts", he mumbled. The dark man sat unmoved, his eyes stared at the newcomer without emotion. His eyes were cold and amphibian. "And I sold the RV and bought a Bonanza ", added the newcomer. He realized in a heart beat that he should not have said that. The dark man had him by the throat with a quickness that seemed otherworldly. And the dark man squeezed that throat as the newcomer wriggled and squirmed in a voiceless scream. The dark man pulled the newcomers face to his own until they nearly touched noses. He breathed his fetid breath on the newcomer and a trickle of drool escaped his mouth to plop loudly on the table between them. "Go!", he rumbled. "Go now you fool!", he bellowed. "Run if you can. It shall do you no good! Once you have subscribed, all hope of ever unsubscribing is gone! We will find you. Your email is now ours to control. Your email box will fill to bursting with our messages. And there is no hope for you. There is no good deed you can do to change what you have done. The List will not be denied!" And with that he released the newcomer who reeled and staggered towards the door, gagging and stumbling. The dark man began to laugh, a low rumbling laugh that grew louder. The newcomer fled up the streets as he had come with the croaking bellowing laughter chasing him. He was doomed... and he knew it. The dark man sat back at the table in the dimly lit bar and sipped at his drink. "I guess I could have just told him to go to http://www.matronics.com/Navigator?RV10-List and use the one click unsubscribe URL at the end of page", he muttered under his breath. No, he smiled to himself. That would have been all too easy. Still chuckling to himself, he reached into his pocket and pulled out the magazine he had been reading before the newcomer interrupted him. He quickly thumbed through the slick and edge worn pages until he found his place. He never missed a single word of each and every issue of Martha Stewart Living... Anonymous On Fri, Nov 1, 2013 at 8:27 PM, Pascal wrote: follow instructions: - http://www.matronics.com/Navigator?RV10-List Use the Matronics List Features Navigator to many List utilities such as List Un/Subscription From: Jmsfrnch Sent: Friday, November 01, 2013 6:32 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Please unsubscribe me from this forum -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> To: rv10-list Sent: Fri, 1 Nov 2013 4:28 Subject: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.mypilotstore.com">www.mypilotstore.com href="http://www.mrrace.com">www.mrrace.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com -- - sent from the microchip implanted in my forearm No virus found in this message. Checked by AVG - www.avg.com 10/25/13 ________________________________________________________________________________
Date: Nov 03, 2013
I would definitely order the Matco axle. It allows you to pre-load the bearings independent of tightening the axle nut. I think you will find a thread in regards to this issue either here or on VAF. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411996#411996 ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Please Make A Contribution To Support Your Lists
Dear Listers, There is no advertising income to support the Matronics Email Lists and Forums. The operation is supported 100% by your personal Contributions during the November Fund Raiser. Please make your Contribution today to support the continued operation and upgrade of these services. You can pick up a really nice gift for making your Contribution too! You may use a Credit Card or Paypal at the Matronics Contribution Site here: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you in advance for your generous support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 04, 2013
Subject: Re: RV10-List Digest: 2 Msgs - 11/03/13
Adrian ----- Original Message ----- From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> Sent: Mon Nov 04 03:02:10 2013 Subject: RV10-List Digest: 2 Msgs - 11/03/13 * ================================================= Online Versions of Today's List Digest Archive ================================================= Today's complete RV10-List Digest can also be found in either of the two Web Links listed below. The .html file includes the Digest formatted in HTML for viewing with a web browser and features Hyperlinked Indexes and Message Navigation. The .txt file includes the plain ASCII version of the RV10-List Digest and can be viewed with a generic text editor such as Notepad or with a web browser. HTML Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-11-03&Archive=RV10 Text Version: http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-11-03&Archive=RV10 =============================================== EMail Version of Today's List Digest Archive =============================================== ---------------------------------------------------------- RV10-List Digest Archive --- Total Messages Posted Sun 11/03/13: 2 ---------------------------------------------------------- Today's Message Index: ---------------------- 1. 02:10 AM - Re: PLEASE READ - Matronics Email List Fund Raiser During November! (Michael Orth) 2. 06:50 AM - Re: Front Tire Installation (bill.peyton) ________________________________ Message 1 _____________________________________ From: "Michael Orth" <mosurf(at)xplornet.com> Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Now that=99s funny. Michael ------------------------------------------------------------------------- ------- ------------------------------------------------------------------------- ------- From: Kelly McMullen Sent: Friday, November 1, 2013 9:08 PM Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! "The Unsubscribed" The cold fog thickened noticeably as the newcomer hurried towards his destination. He pulled his heavy overcoat around his neck a little more tightly. This part of the city was not a place to tarry. Thieves and whores were the only permanent residents here. Even the cops rolled through these streets with a nervousness and an edge to heir normal macho banter. Trouble and misery closed around everyone who ventured into this pustule of urban blight like a leech on a warm vein. "Damn!", he hissed under his breath as he stepped on something soft that squealed and skittered off into the darkness and dankness of the mist. It can't be much farther he thought. It mustn't be much farther. The sickly yellow flicker of light from a street lamp shone dimly through the fog as he quickened his pace. There it was. The doorway seemed to be just blackness without definition. As he got closer, two winos eyed him suspiciously through bloodshot and yellowed eyes. He hustled past them, their breath leaving a rank scent that lingered on his clothes. The door pushed inward and the newcomer was inside. The room was smoky and dim. The bar stank of liquor and broken dreams. Several tables decorated the periphery. The man he had come to see was sitting at one of those tables and beckoned him over to sit. The man was darkly clothed and utterly shapeless. He might have weighed three hundred pounds... or he may have been only bone. His shape was indecipherable. The dark mans eyes were gazing down at the dirty glass in his hand, half filled with cheap whiskey. He had been reading a glossy magazine filled with lurid and obscene images. He folded it tenderly and stuffed it quickly into his coat pocket like a vulture gobbling a rotten piece of flesh. "What is it you want of me?", the dark man asked, not lifting his eyes from the glass. His voice rumbled deep in his belly like a toad. "I need you to tell me how to unsubscribe", said the newcomer in as even a tone as he could muster. The dark man looked up from his glass slowly to gaze at the newcomer. His eyes were a pale watery blue. And his gaze lingered on the newcomer. "You wish to unsubscribe?", he said, with a hint of amusement in his voice but no trace of a smile on his thick pasty lips. "You come to me with a need to unsubscribe?", he said, his voice getting louder now and any hint of amusement gone. He sucked in his breath and hissed through his teeth spraying the newcomer with a repulsive mist of spittle, "Why? Tell me why it is that you wish to unsubscribe." The newcomer felt fear now creeping up his spine. "I don't have the time to sort through all the posts", he mumbled. The dark man sat unmoved, his eyes stared at the newcomer without emotion. His eyes were cold and amphibian. "And I sold the RV and bought a Bonanza ", added the newcomer. He realized in a heart beat that he should not have said that. The dark man had him by the throat with a quickness that seemed otherworldly. And the dark man squeezed that throat as the newcomer wriggled and squirmed in a voiceless scream. The dark man pulled the newcomers face to his own until they nearly touched noses. He breathed his fetid breath on the newcomer and a trickle of drool escaped his mouth to plop loudly on the table between them. "Go!", he rumbled. "Go now you fool!", he bellowed. "Run if you can. It shall do you no good! Once you have subscribed, all hope of ever unsubscribing is gone! We will find you. Your email is now ours to control. Your email box will fill to bursting with our messages. And there is no hope for you. There is no good deed you can do to change what you have done. The List will not be denied!" And with that he released the newcomer who reeled and staggered towards the door, gagging and stumbling. The dark man began to laugh, a low rumbling laugh that grew louder. The newcomer fled up the streets as he had come with the croaking bellowing laughter chasing him. He was doomed... and he knew it. The dark man sat back at the table in the dimly lit bar and sipped at his drink. "I guess I could have just told him to go to http://www.matronics.com/Navigator?RV10-List and use the one click unsubscribe URL at the end of page", he muttered under his breath. No, he smiled to himself. That would have been all too easy. Still chuckling to himself, he reached into his pocket and pulled out the magazine he had been reading before the newcomer interrupted him. He quickly thumbed through the slick and edge worn pages until he found his place. He never missed a single word of each and every issue of Martha Stewart Living... Anonymous On Fri, Nov 1, 2013 at 8:27 PM, Pascal wrote: follow instructions: - http://www.matronics.com/Navigator?RV10-List Use the Matronics List Features Navigator to many List utilities such as List Un/Subscription From: Jmsfrnch Sent: Friday, November 01, 2013 6:32 PM To: rv10-list(at)matronics.com Subject: Re: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Please unsubscribe me from this forum -----Original Message----- From: Matt Dralle <dralle(at)matronics.com> To: rv10-list Sent: Fri, 1 Nov 2013 4:28 Subject: RV10-List: PLEASE READ - Matronics Email List Fund Raiser During November! Dear Listers, Each November I hold a PBS-like fund raiser to support the continued operation and upgrade of the Email List and Fourm Services at Matronics. It's solely through the Contributions of List members (you) that these Matronics Lists are possible. You have probably noticed that there are no banner ads or pop-up windows on any of the Matronics Lists or related web sites such as the Forums site http://forums.matronics.com , Wiki site http://wiki.matronics.com , or other related pages such as the List Search Engine http://www.matronics.com/search , List Browse http://www.matronics.com/listbrowse , etc. This is because I believe in a List experience that is completely about the sport we all enjoy - namely Airplanes and not about annoying advertisements. During the month of November I will be sending out List messages every couple of days reminding everyone that the Fund Raiser is underway. I ask for your patience and understanding during the Fund Raiser and throughout these regular messages. The Fund Raiser is only financial support mechanism I have to pay all of the bills associated with running these lists. YOUR personal Contribution counts! This year we have a really HUGE and TERRIFIC line up of free gifts to go along with the various Contribution levels. In fact, there are over 30 different gifts to choose from - more than we've ever had before! There's something for everyone, to be sure. Most all of these gifts have been provided by some of the vary members and vendors that you'll find on the Matronics Lists and they have been either donated or provided at substantially discounted rates. This year, these generous members include: Andy Gold of the Builder's Bookstore http://www.buildersbooks.com Bob Nuckolls of the AeroElectric Connection http://www.aeroelectric.com Corbin Glowacki of My Pilot Store http://www.mypilotstore.com George Race of Race Consulting http://www.mrrace.com/ Jon Croke of HomebuiltHELP http://www.homebuilthelp.com These are very generous guys and I encourage you to visit their respective web sites. Each one offers a unique and excellent aviation-related product line. I would like publicly to thank Andy, Bob, Corbin, George, and Jon their generous support of the Lists again this year!! Please make your List Contribution using any one of three secure methods including using a credit card, PayPal, or by personal check. All three methods afford you the opportunity to select one of this year's free gifts with a qualifying Contribution amount!! To make your Contribution, please visit the secure web site: http://www.matronics.com/contribution I would like to thank everyone in advance for their generous financial AND moral support over the years! Thank you! Matt Dralle Matronics Email List Administrator RV-4/RV-6/RV-8 Builder/Rebuilder/Pilot _blank">www.aeroelectric.com " target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.mypilotstore.com">www.mypilotstore.com href="http://www.mrrace.com">www.mrrace.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com -- - sent from the microchip implanted in my forearm No virus found in this message. Checked by AVG - www.avg.com 10/25/13 ________________________________ Message 2 _____________________________________ Subject: RV10-List: Re: Front Tire Installation From: "bill.peyton" <peyton.b(at)sbcglobal.net> I would definitely order the Matco axle. It allows you to pre-load the bearings independent of tightening the axle nut. I think you will find a thread in regards to this issue either here or on VAF. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=411996#411996 This message may contain confidential information. If you are not the designated recipient, please notify the sender immediately, and delete the original and any copies. Any use of the message by you is prohibited. ________________________________________________________________________________
Date: Nov 04, 2013
Thank you. Found it, and ordered the Matco axle and spacers. Next question, on the main's bearings, is it advised to grease up the felt dust covers or leave them dry? What is the best practice with these? Vernon On Sun, Nov 3, 2013 at 8:49 AM, bill.peyton wrote: > > I would definitely order the Matco axle. It allows you to pre-load the bearings independent of tightening the axle nut. I think you will find a thread in regards to this issue either here or on VAF. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=411996#411996 > > -- Vernon Franklin ________________________________________________________________________________
Subject: Oil/Air Separator
Date: Nov 04, 2013
If I searched the archives properly it looks like the last time this subject was brought up was about 2008, or 5 years ago. Would sure appreciate some good feedback from some flying folks who have used the Andair OS850#4 Oil/Air Separator, and the CT850 Condensation Trap. I bought these at OSH and am ready to install them - but see a few issues. One is the IO-540 breather line is 1 inch on the Lycoming Vans bought engine. The Andair separator line is 3/4 inch, in and out. Probably not a problem, but don't like the reduction in size on a breather line. So before I select to go this route, would sure appreciate any input from anyone who has installed this unit and how it works - good, bad, or indifferent. Did you reduce the line only at the separator (in and out)? Stated another way, at the 1 inch breather output fitting on the engine, did you go immediately to a 3/4 inch hose, or run 1 inch hose to the separator, then reduce to the 3/4? Did it reduce your belly oil??? Did it work as advertised? Am I going to be the guinea pig on this one? On my 6A with new engine not rebuilt, I just set it up per plans and wiped the belly a few times per year - not a big deal. Just wanted to at least improve upon/reduce, or, (wishful thinking) eliminate this need! What say you drivers? Thanks Much, Rich Hansen ________________________________________________________________________________
Date: Nov 06, 2013
Subject: Network Issues At Matronics Last Few Days...
Dear Listers, Starting sometime on Friday November 1st, my Internet Service Provider (ISP) began "upgrading" their Domain Name Servers (DNS). DNS servers allow the resolution of computer names such as "www.matronics.com" to real addresses such as 64.81.74.3. This also impacts email delivery as well, since there is another layer of resolution that applies to email names. Because of this upgrade on the part of my ISP, DNS service started getting unreliable around Friday sometime, but I didn't notice it until sometime on Saturday. When I used a tool called "nslookup" to test the resolution of name-to-address, about 50-75% of the time my ISP's servers would response with an "SERVFAIL" indicating that they didn't know the answer. I opened a ticket with the ISP on Saturday, and by Sunday afternoon I had no feedback on the ticket so I called in to support. "We upgrading the DNS servers, and it should back by Sunday at 5pm." 5pm came and went with no resolution. Well, long story short by Tuesday morning things were still not fixed and in fact much worse. So, I opted to move all my DNS service to a different service provider. I have a lot of DNS entries, so it took a while to get everything moved over. It generally takes about 24 hours for a change like that to fully propagate across the Internet which would be Wednesday morning sometime. I've noticed that the Matronics web server traffic is picking up again, so many sites have already propagated the new information. I really should have just moved the DNS on Saturday when I first noticed the troubles, but with stuff like this, you just keep believing that it gonna be fixed any minute now.... And, in fact, that's what my ISP kept telling me... Its always a giant bummer when stuff like this happens and particularly during the Fund Raiser. I apologize to anyone that has tried to make a Contribution in the last few days and had issues or was simply unable to connect. By the time you read this email, the DNS should be fully propagated, and I ask that you please try again. The Contribution web site URL is: http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you for your kind consideration and patience, Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 05, 2013
Subject: Fwd: AeroElectric-List: matronics servers have the flu
FYI -------- Original Message -------- Subject: AeroElectric-List: matronics servers have the flu Date: Tue, 05 Nov 2013 22:15:50 -0600 From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" It seems that the ISP that hosts Matt's Internet portal did something dumb with their domain name servers. My access to any features on matronics have been sketchy at best. Matt's not getting very good answers from the so-called 'service reps' . . . I think we're in good hands . . . Matt's trying to chase the rats out of the woodpile. Bob . . . ________________________________________________________________________________
Subject: Extra fuel tank
Date: Nov 07, 2013
Guys My partner insists in installing an extra fuel tank in the -10. In fact he has a point because he intends to use the airplane in Africa, where it is very difficult to find AvGas in vast extensions of the territory. Does anybody know if any builder has already installed an extra fuel tank (in the baggage compartment or anywhere else), or if there is any aftermarket kit? Regards Carlos Enviado do meu iPhone ________________________________________________________________________________
Subject: Re: Extra fuel tank
Date: Nov 06, 2013
I have seen at least one -10 with two standard tanks per wing. Their is an aftermarket tip tank kit but I don't have the info. Dave Leikam On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote: > > Guys > > My partner insists in installing an extra fuel tank in the -10. > In fact he has a point because he intends to use the airplane in Africa, where it is very difficult to find AvGas in vast extensions of the territory. > > Does anybody know if any builder has already installed an extra fuel tank (in the baggage compartment or anywhere else), or if there is any aftermarket kit? > > Regards > Carlos > > Enviado do meu iPhone > > > > ________________________________________________________________________________
Date: Nov 06, 2013
We have installed an additional half tank outboard of the stock tanks for a total of 90 gallons on a number of planes. The tanks are separate and you transfer into the mains. It's a big job, but it works well. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Nov 6, 2013, at 8:07 PM, David Leikam wrote: > > > I have seen at least one -10 with two standard tanks per wing. > Their is an aftermarket tip tank kit but I don't have the info. > > Dave Leikam > >> On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote: >> >> >> Guys >> >> My partner insists in installing an extra fuel tank in the -10. >> In fact he has a point because he intends to use the airplane in Africa, where it is very difficult to find AvGas in vast extensions of the territory. >> >> Does anybody know if any builder has already installed an extra fuel tank (in the baggage compartment or anywhere else), or if there is any aftermarket kit? >> >> Regards >> Carlos >> >> Enviado do meu iPhone >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Nov 06, 2013
I recall some one offered a 7.5 gal tank to go in each wing tip to achieve 75 gal, or 1 extra hour endurance. Many aircraft have added baggage compartment tanks, either ridgid or bladder, that could be teed into one of the main tanks with a wobble pump or electric pump. On Wed, Nov 6, 2013 at 6:24 PM, Jesse Saint wrote: > > We have installed an additional half tank outboard of the stock tanks for > a total of 90 gallons on a number of planes. The tanks are separate and you > transfer into the mains. It's a big job, but it works well. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > > On Nov 6, 2013, at 8:07 PM, David Leikam wrote: > > > > > > I have seen at least one -10 with two standard tanks per wing. > > Their is an aftermarket tip tank kit but I don't have the info. > > > > Dave Leikam > > > >> On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote: > >> > >> > >> Guys > >> > >> My partner insists in installing an extra fuel tank in the -10. > >> In fact he has a point because he intends to use the airplane in > Africa, where it is very difficult to find AvGas in vast extensions of the > territory. > >> > >> Does anybody know if any builder has already installed an extra fuel > tank (in the baggage compartment or anywhere else), or if there is any > aftermarket kit? > >> > >> Regards > >> Carlos > >> > >> Enviado do meu iPhone > >> > >> > >> > >> > > > > > > > > > > > > > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 06, 2013
Subject: Front seats value
I need to ship my front seats off for upholstery. Given the nature of shipping, I would like to insure them for something near replacement cost for the seat frames and conforfoam cushions. I cannot find any listing on "the List" to give a price, and the plans don't have a part number. Anyone have what Van's would charge (or is it Oregon Aero?) to replace the seats if the shipping company lost them or put a fork lift through the box? ________________________________________________________________________________
Subject: Re: Front seats value
Date: Nov 06, 2013
I priced the seats one year ago and they were 4,400.00 -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412306#412306 ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Nov 06, 2013
I've tried to get a quote for the seats so we could use them in other planes. The short answer is they're only available to Vans and Vans doesn't sell the seats outright. I imagine you could get replacements if they were damaged, but it wouldn't be a straightforward order. During my efforts I did glean the cost for a pair of seats...$15,000. Three zeros. Why the seats are more than the finish kit is beyond me. That price was from Oregon Aero before they told me they weren't actually for sale. Get a quote from Vans before you insure them. Or take them to upholstery yourself! Dave Saylor 831-750-0284 CL On Wed, Nov 6, 2013 at 6:12 PM, Kelly McMullen wrote: > I need to ship my front seats off for upholstery. Given the nature of > shipping, I would like to insure them for something near replacement cost > for the seat frames and conforfoam cushions. > I cannot find any listing on "the List" to give a price, and the plans > don't have a part number. Anyone have what Van's would charge (or is it > Oregon Aero?) to replace the seats if the shipping company lost them or put > a fork lift through the box? > > * > > * > > ________________________________________________________________________________
Date: Nov 06, 2013
each, which is less than what I was told they were by Oregon Aero. -----Original Message----- From: mds4878 Sent: Wednesday, November 06, 2013 6:23 PM Subject: RV10-List: Re: Front seats value I priced the seats one year ago and they were 4,400.00 -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412306#412306 ________________________________________________________________________________
Date: Nov 06, 2013
Finish kit is $15,000 and change now. Includes main gear, engine mount, cowling, wheel pants and fairings, among other items. So it sounds like 2/3 the cost is the front seats. That seems hugely out of line for cushions that are worth maybe $500 and aluminum frame with canvass seat bottom. That will definitely put insurance cost above shipping cost. On Wed, Nov 6, 2013 at 7:30 PM, Pascal wrote: > > each, which is less than what I was told they were by Oregon Aero. > > -----Original Message----- From: mds4878 Sent: Wednesday, November 06, > 2013 6:23 PM To: rv10-list(at)matronics.com Subject: RV10-List: Re: Front > seats value > > I priced the seats one year ago and they were 4,400.00 > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=412306#412306 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 06, 2013
Safeair1, I think, has the tip tanks. Sent from my iPad > On Nov 6, 2013, at 9:07 PM, Kelly McMullen wrote: > > I recall some one offered a 7.5 gal tank to go in each wing tip to achieve 75 gal, or 1 extra hour endurance. > Many aircraft have added baggage compartment tanks, either ridgid or bladd er, that could be teed into one of the main tanks with a wobble pump or elec tric pump. > > >> On Wed, Nov 6, 2013 at 6:24 PM, Jesse Saint wro te: >> >> We have installed an additional half tank outboard of the stock tanks for a total of 90 gallons on a number of planes. The tanks are separate and you transfer into the mains. It's a big job, but it works well. >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org >> www.mavericklsa.com >> C: 352-427-0285 >> O: 352-465-4545 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> > On Nov 6, 2013, at 8:07 PM, David Leikam wrote: >> > >> > >> > I have seen at least one -10 with two standard tanks per wing. >> > Their is an aftermarket tip tank kit but I don't have the info. >> > >> > Dave Leikam >> > >> >> On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote : >> >> >> >> >> >> Guys >> >> >> >> My partner insists in installing an extra fuel tank in the -10. >> >> In fact he has a point because he intends to use the airplane in Afric a, where it is very difficult to find AvGas in vast extensions of the territ ory. >> >> >> >> Does anybody know if any builder has already installed an extra fuel t ank (in the baggage compartment or anywhere else), or if there is any afterm arket kit? >> >> >> >> Regards >> >> Carlos >> >> >> >> Enviado do meu iPhone >> >> >> >> >> >> >> >> >> > >> > >> > >> > >> > >> > >> >> >> ========== >> ="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> ========== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> http://forums.matronics.com >> ========== >> >> >> > > > > -- > > - sent from the microchip implanted in my forearm > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 06, 2013
The reason why I got a price for seats was that I have been buying my finish kit as I needed parts of it and I need the seats soon. I called about one year ago and asked how much and it took about a day or so and they called me back with 4,400.00 plus shipping for the pair with foam. I did have to provide my kit number. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412312#412312 ________________________________________________________________________________
Date: Nov 06, 2013
Thank you. Very helpful. Kelly 40866, forever finishing On 11/6/2013 8:00 PM, mds4878 wrote: > > The reason why I got a price for seats was that I have been buying my finish kit as I needed parts of it and I need the seats soon. I called about one year ago and asked how much and it took about a day or so and they called me back with 4,400.00 plus shipping for the pair with foam. I did have to provide my kit number. > > -------- > RV-10 #40447 > Fuselage almost done. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=412312#412312 > > ________________________________________________________________________________
Date: Nov 06, 2013
I talked to Oregon Aero also about the seats and the only way they could sell them to me was as certified models that are used in other aircraft. He told me the same seat is used in three other aircraft but He could not sell a "RV10" seat because of the agreement with Van's. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412313#412313 ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Coming Soon - The List of Contributors - Please Make A Contribution
Today! Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 07, 2013
Subject: Re: Tires and tubes
Isn't "leakguard" the stock tubes Van's sells? I'm still finding they lose about 10 psi over 2-3 months, so would rather go with something less leaky. On Fri, Nov 1, 2013 at 1:54 PM, Kelly McMullen wrote: > This is what I have my -10 sitting on: > 15/600-6 "Leakguard" Butyl Tube with the "New Easy Valve" for the > mains, and 500-5 "Leakguard" Butyl Tube with the TR-67 Valve for the > nose. > The tube for the mains was designed for Cirri, that have similar wheel > pants access issues. > Leakguard is Desser's in-house branding of what is supposed to be same as > Air Stop at lower cost. I think I put air in them once over past year to > make moving fuselage easier. > > > On Fri, Nov 1, 2013 at 1:03 PM, Rob Kochman wrote: > >> Based on feedback here, I think I'm going to stick with the Aero Classics >> tires, but switch to Michelan Airstop tubes. Anyone have an issue with >> this combination? Are there different valve stem angle options with these >> tubes? Thanks much... >> >> -Rob >> >> -- >> Rob Kochman >> RV-10 Flying since March 2011 >> Woodinville, WA >> http://kochman.net/N819K >> >> * >> >> _blank">www.aeroelectric.com <http://www.aeroelectric.com> >> .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> >> ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> ank">www.mrrace.com <http://www.mrrace.com> >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> * >> >> > > > -- > > - sent from the microchip implanted in my forearm > > * > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Nov 07, 2013
Leakguard is what Desser Tire sells as lower cost equivalent to Michelin Air Stop. I doubt that Vans supplies anything but the cheapest standard variety tubes. On 11/7/2013 1:54 PM, Rob Kochman wrote: > Isn't "leakguard" the stock tubes Van's sells? I'm still finding they > lose about 10 psi over 2-3 months, so would rather go with something > less leaky. > > > On Fri, Nov 1, 2013 at 1:54 PM, Kelly McMullen > wrote: > > This is what I have my -10 sitting on: > 15/600-6 "Leakguard" Butyl Tube with the "New Easy Valve" for the > mains, and 500-5 "Leakguard" Butyl Tube with the TR-67 Valve for the > nose. > The tube for the mains was designed for Cirri, that have similar > wheel pants access issues. > Leakguard is Desser's in-house branding of what is supposed to be > same as Air Stop at lower cost. I think I put air in them once > over past year to make moving fuselage easier. > > > On Fri, Nov 1, 2013 at 1:03 PM, Rob Kochman > wrote: > > Based on feedback here, I think I'm going to stick with the > Aero Classics tires, but switch to Michelan Airstop tubes. > Anyone have an issue with this combination? Are there > different valve stem angle options with these tubes? Thanks > much... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > _blank">www.aeroelectric.com <http://www.aeroelectric.com> > .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> > ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> > ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> > ank">www.mrrace.com <http://www.mrrace.com> > _blank">http://www.matronics.com/contribution > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > * > > > -- > > - sent from the microchip implanted in my forearm > > * > > _blank">www.aeroelectric.com > .com" target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > ="_blank">www.mypilotstore.com > ank">www.mrrace.com > _blank">http://www.matronics.com/contribution > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > * > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > * > > * ________________________________________________________________________________
Date: Nov 08, 2013
Not in my kit. I just replaced all my tubes with the Leakguards. The ones I took off were not Leakguards. My experience has been the same with the non-leakguards. I will know in a few months whether the Leakguards are better. Why did I replace them all? Because 1) I swapped tires for even wear and one is supposed to replace the tubes at that point as I understand it, and 2) I had a badly cracked front Matco wheel which I replaced. Just FYI, I did replace the kit supplied wheel with the Matco WHLNW511.25 which as others have explained, is a better spec for this application. http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=7984&log=180210&row=1 Bill "trying to conjure up a heat duct scheme for the rear heat vents so my copilot doesn't have to pack a blanket" Watson On 11/7/2013 3:54 PM, Rob Kochman wrote: > Isn't "leakguard" the stock tubes Van's sells? I'm still finding they > lose about 10 psi over 2-3 months, so would rather go with something > less leaky. > > > On Fri, Nov 1, 2013 at 1:54 PM, Kelly McMullen > wrote: > > This is what I have my -10 sitting on: > 15/600-6 "Leakguard" Butyl Tube with the "New Easy Valve" for the > mains, and 500-5 "Leakguard" Butyl Tube with the TR-67 Valve for the > nose. > The tube for the mains was designed for Cirri, that have similar > wheel pants access issues. > Leakguard is Desser's in-house branding of what is supposed to be > same as Air Stop at lower cost. I think I put air in them once > over past year to make moving fuselage easier. > > > On Fri, Nov 1, 2013 at 1:03 PM, Rob Kochman > wrote: > > Based on feedback here, I think I'm going to stick with the > Aero Classics tires, but switch to Michelan Airstop tubes. > Anyone have an issue with this combination? Are there > different valve stem angle options with these tubes? Thanks > much... > > -Rob > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > * > > _blank">www.aeroelectric.com <http://www.aeroelectric.com> > .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> > ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> > ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> > ank">www.mrrace.com <http://www.mrrace.com> > _blank">http://www.matronics.com/contribution > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > * > > > -- > > - sent from the microchip implanted in my forearm > > * > > _blank">www.aeroelectric.com > .com" target="_blank">www.buildersbooks.com > ="_blank">www.homebuilthelp.com > ="_blank">www.mypilotstore.com > ank">www.mrrace.com > _blank">http://www.matronics.com/contribution > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > * > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > * > > * ________________________________________________________________________________
Subject: Re: Cabin Cover Headliner
Date: Nov 08, 2013
John: How did you finish the depressions around the hinge bolts? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412466#412466 ________________________________________________________________________________
Date: Nov 08, 2013
I just covered it with the fabric as if the depression wasn't there. It stays in place with a touch of rubber cement and the McMaster Carr edging. No air leaks because of the edging. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412467#412467 ________________________________________________________________________________
Date: Nov 08, 2013
Thanks for the prompt reply. Do you mind telling me which edging you used? Thanks, Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412470#412470 ________________________________________________________________________________
Date: Nov 08, 2013
I can't find the exact part number, but it's the same stuff everyone else is using from McMaster Carr. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412473#412473 ________________________________________________________________________________
Date: Nov 08, 2013
Are you rerferring to the weather stripping around the door? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412475#412475 ________________________________________________________________________________
Date: Nov 08, 2013
It is the 'weatherstripping' but do take some care with the ordering. The McMaster Carr part I used was 1120A411 - bulb opposite grabber (very important, especially if using a headliner), 1/4" edge. I also played around with the 3/8" edge. If you go this route, decide what edge width you want, make it that width, and order the weatherstripping size you want. There's plenty of info in the archives. On 11/8/2013 5:27 PM, johngoodman wrote: > > I can't find the exact part number, but it's the same stuff everyone else is using from McMaster Carr. > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=412473#412473 > > ________________________________________________________________________________
Date: Nov 08, 2013
Subject: Re: Coming Soon - The List of Contributors - Please Make A
Contrib... hello Please take me off the rv10 list Thanks In a message dated 11/7/2013 3:58:35 A.M. Eastern Standard Time, dralle(at)matronics.com writes: --> RV10-List message posted by: Matt Dralle Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Contrib...
Date: Nov 08, 2013
Use the Matronics List Features Navigator to browse_http://www.matronics.com/Navigator?RV10-List =93= for UnSubscription From: MB86967(at)aol.com Sent: Friday, November 08, 2013 6:22 PM Subject: Re: RV10-List: Coming Soon - The List of Contributors - Please Make A Contrib... hello Please take me off the rv10 list Thanks In a message dated 11/7/2013 3:58:35 A.M. Eastern Standard Time, dralle(at)matronics.com writes: Each year at the end of the List Fund Raiser, I post a message acknowledging everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Please take a moment and assure that your name is on that List of Contributors (LOC)! As a number of members have pointed out over the years, the List seems at least as valuable a building / entertainment tool as your typical magazine subscription! Assure that your name is on this year's LOC! Show others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Credit card or Paypal on the Secure Web Site: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far in this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists going and improving! Don't forget to include a little comment about how the Lists have helped you! Best regards, Matt Dralle Matronics Email List ======================= ________________________________________________________________________________
Date: Nov 09, 2013
Subject: Please Make a Contribution to Support Your Lists...
Dear Listers, Just a reminder that November is the Annual List Fund Raiser. Please make a Contribution today to support the continued operation and upgrade of these great List services!! Pick up a really nice free gift with your qualifying Contribution too! The Contribution Site is fast and easy: http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94551-0347 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 09, 2013
Thank you all for the answers. Since almost all were about extra tanks in the wings, is anyone out there aware of extra tanks on the baggage compartment? Builders who done it, or after-market kit? Carlos From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: quinta-feira, 7 de Novembro de 2013 02:51 Subject: Re: RV10-List: Extra fuel tank Safeair1, I think, has the tip tanks. Sent from my iPad On Nov 6, 2013, at 9:07 PM, Kelly McMullen wrote: I recall some one offered a 7.5 gal tank to go in each wing tip to achieve 75 gal, or 1 extra hour endurance. Many aircraft have added baggage compartment tanks, either ridgid or bladder, that could be teed into one of the main tanks with a wobble pump or electric pump. On Wed, Nov 6, 2013 at 6:24 PM, Jesse Saint wrote: We have installed an additional half tank outboard of the stock tanks for a total of 90 gallons on a number of planes. The tanks are separate and you transfer into the mains. It's a big job, but it works well. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Nov 6, 2013, at 8:07 PM, David Leikam wrote: > > > I have seen at least one -10 with two standard tanks per wing. > Their is an aftermarket tip tank kit but I don't have the info. > > Dave Leikam > >> On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote: >> >> >> Guys >> >> My partner insists in installing an extra fuel tank in the -10. >> In fact he has a point because he intends to use the airplane in Africa, where it is very difficult to find AvGas in vast extensions of the territory. >> >> Does anybody know if any builder has already installed an extra fuel tank (in the baggage compartment or anywhere else), or if there is any aftermarket kit? >> >> Regards >> Carlos >> >> Enviado do meu iPhone >> >> >> >> > > ="_blank">www.aeroelectric.com ooks.com" target="_blank">www.buildersbooks.com et="_blank">www.homebuilthelp.com et="_blank">www.mypilotstore.com "_blank">www.mrrace.com ="_blank">http://www.matronics.com/contribution le, List Admin. arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com -- - sent from the microchip implanted in my forearm 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Nov 09, 2013
One Caution. Putting additional weight out at the tips of the wings will change spin / roll characteristics. Make sure who ever is supplying the tanks will verify spin testing has been performed for the additional mass / moment arms involved. But then you are the manufacturer and you own that verification. Jim C Almost flying again N312F On Sat, Nov 9, 2013 at 5:25 AM, Carlos Trigo wrote: > Thank you all for the answers. > > > Since almost all were about extra tanks in the wings, is anyone out there > aware of extra tanks on the baggage compartment? > > Builders who done it, or after-market kit? > > > Carlos > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jesse Saint > *Sent:* quinta-feira, 7 de Novembro de 2013 02:51 > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Extra fuel tank > > > Safeair1, I think, has the tip tanks. > > Sent from my iPad > > > On Nov 6, 2013, at 9:07 PM, Kelly McMullen wrote: > > I recall some one offered a 7.5 gal tank to go in each wing tip to achieve > 75 gal, or 1 extra hour endurance. > > Many aircraft have added baggage compartment tanks, either ridgid or > bladder, that could be teed into one of the main tanks with a wobble pump > or electric pump. > > > On Wed, Nov 6, 2013 at 6:24 PM, Jesse Saint > wrote: > > > We have installed an additional half tank outboard of the stock tanks for > a total of 90 gallons on a number of planes. The tanks are separate and you > transfer into the mains. It's a big job, but it works well. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > > > On Nov 6, 2013, at 8:07 PM, David Leikam wrote: > > > > > > I have seen at least one -10 with two standard tanks per wing. > > Their is an aftermarket tip tank kit but I don't have the info. > > > > Dave Leikam > > > >> On Nov 6, 2013, at 6:58 PM, Carlos Trigo wrote: > >> > >> > >> Guys > >> > >> My partner insists in installing an extra fuel tank in the -10. > >> In fact he has a point because he intends to use the airplane in > Africa, where it is very difficult to find AvGas in vast extensions of the > territory. > >> > >> Does anybody know if any builder has already installed an extra fuel > tank (in the baggage compartment or anywhere else), or if there is any > aftermarket kit? > >> > >> Regards > >> Carlos > >> > >> Enviado do meu iPhone > >> > >> > >> > >> > > > > > > > > > > > > > > > ========== > ="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > et="_blank">www.mypilotstore.com > "_blank">www.mrrace.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > > > -- > > - sent from the microchip implanted in my forearm > > > *www.aeroelectric.com <http://www.aeroelectric.com>* > > *www.buildersbooks.com <http://www.buildersbooks.com>* > > *www.homebuilthelp.com <http://www.homebuilthelp.com>* > > *www.mypilotstore.com <http://www.mypilotstore.com>* > > *www.mrrace.com <http://www.mrrace.com>* > > *http://www.matronics.com/contribution * > > *http://www.matronics.com/Navigator?RV10-List * > > *http://forums.matronics.com * > > * > > * > > ________________________________________________________________________________
Date: Nov 10, 2013
I have an 18 gal metal tank in baggage comp. plumb it directly into and and air four way valve. Use while enroute Wt and bal is good. Helps with forward cg. Am very pleased with it. Weighs about 15#. Had a local fabricator build it for me. Obviously cannot use with four people in ac. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412630#412630 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Nov 10, 2013
While I don't see any need for an extra fuel tank for my needs, I can see someone wanting a ferry tank. My neighbor is the guy who now owns the world record for single engine non-stop endurance, Guam to Jacksonville. He did it in a Lancair 4. I watched him make the five or so ferry tanks that fit exactly into each available space inside the airplane. All tanks were made of carbon fiber and are exceptionally light. If I ever want a ferry tank I'd go the same way he did. I suspect I'd build them to fit in the rear seat passenger foot wells, then perhaps another tank going across the top of those two tanks and extending over the rear seat deck. This would help with W&B and as there would be no rear passengers with all this added fuel weight taking up the passenger space is not an issue. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kevino Sent: Sunday, November 10, 2013 9:38 AM Subject: RV10-List: Re: Extra fuel tank I have an 18 gal metal tank in baggage comp. plumb it directly into and and air four way valve. Use while enroute Wt and bal is good. Helps with forward cg. Am very pleased with it. Weighs about 15#. Had a local fabricator build it for me. Obviously cannot use with four people in ac. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412630#412630 ________________________________________________________________________________
Date: Nov 11, 2013
Subject: A List Contribution - It's Your Personal Squelch Button...
There is an automatic "squelch button" of sorts for the Fund Raiser messages. Here's how it works... As soon as a List member makes a Contribution through the Matronics Fund Raiser web site, their email address is automatically added to this year's Contributor List and they instantly cease to receive further Fund Raiser messages for the rest of the month! Its just that simple! :-) I really do appreciate each and every one of your individual Contributions to support the Lists. It is your support that enables me to upgrade the hardware and software that are required to run a List Site such as this one. It also goes to pay for the commercial-grade Internet connection and to pay the huge electric bill to keep the computer gear running and the air conditioner powered on. I run all of the Matronics Email List and Forums sites here locally which allows me to control and monitor every aspect of the system for the utmost in reliably and performance. Your personal Contribution matters because, when combined with other Listers such as yourself, it pays the bills to keep this site up and running. I accept exactly ZERO advertising dollars for the Matronics Lists sites. I can't stand the pop-up ads and all other commercials that are so prevalent on the Internet these days and I particularly don't want to have it on my Email List sites. If you appreciate the ad-free, grass-roots, down-home feel of the Matronics Email Lists, please make a Contribution to keep it that way!! http://www.matronics.com/contribution or, you can send a personal check to the following address: Matronics / Matt Dralle 581 Jeannie Way Livermore, CA 94550 Thank you! Matt Dralle Matronics Email List Administrator [Note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them.] ________________________________________________________________________________
Date: Nov 11, 2013
Subject: Matronics Email Disruption Fixed...
Dear Listers, Starting around midnight this morning 11/11/13, the Matronics Barracuda spam filter that receives all incoming email from the Internet, developed a problem and started rejecting all incoming email. I just got off the phone with the Barracuda technical support and we have If you have posted to any of the Lists during this time, you will need to resend your email to the respective List. My apologies for the disruption! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 11, 2013
Hi Kevino That's exactly what I was looking for. I am going to to send you a PM. Thanks Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kevino Sent: domingo, 10 de Novembro de 2013 14:38 Subject: RV10-List: Re: Extra fuel tank I have an 18 gal metal tank in baggage comp. plumb it directly into and and air four way valve. Use while enroute Wt and bal is good. Helps with forward cg. Am very pleased with it. Weighs about 15#. Had a local fabricator build it for me. Obviously cannot use with four people in ac. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412630#412630 ________________________________________________________________________________
Date: Nov 11, 2013
I note that the 18 gal tank will put 120 lbs in the baggage area. When I built my 10, Vans recommended a max of 150 lbs in the baggage area. But I see that current kits have a recommended limit of 100 lbs. Does anyone know why the change was made? Does the recommendation apply to all aircraft or only newer ones (was there a structural change?)? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412833#412833 ________________________________________________________________________________
Date: Nov 11, 2013
I think it may have always been 100. I know I've seen that for many years and was always curious as to why. Tim On 11/11/2013 12:39 PM, Bob Turner wrote: > > I note that the 18 gal tank will put 120 lbs in the baggage area. When I built my 10, Vans recommended a max of 150 lbs in the baggage area. But I see that current kits have a recommended limit of 100 lbs. Does anyone know why the change was made? Does the recommendation apply to all aircraft or only newer ones (was there a structural change?)? > > -------- > Bob Turner > RV-10 QB > ________________________________________________________________________________
Date: Nov 11, 2013
When you do the weight and balance it pulls everything aft. forget trying to put an adult back there with the fuel loaded up, however, that will take you out of C/G. I can tell you that the tail section can tolerate 170lbs. I tested it when I did and do my annuals, so I doubt it's a structural issue with the baggage area. -----Original Message----- From: Bob Turner Sent: Monday, November 11, 2013 10:39 AM Subject: RV10-List: Re: Extra fuel tank I note that the 18 gal tank will put 120 lbs in the baggage area. When I built my 10, Vans recommended a max of 150 lbs in the baggage area. But I see that current kits have a recommended limit of 100 lbs. Does anyone know why the change was made? Does the recommendation apply to all aircraft or only newer ones (was there a structural change?)? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412833#412833 ________________________________________________________________________________
Date: Nov 11, 2013
Tim Olson wrote: > I think it may have always been 100. I know I've seen that for many years > and was always curious as to why. > > Tim > On 11/11/2013 12:39 PM, Bob Turner wrote: > > > > > > > > > > > > The weight and balance paperwork that came with my finish kit definitely says 150 lbs. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412838#412838 ________________________________________________________________________________
Date: Nov 11, 2013
rv10flyer(at)live.com wrote: > > I can tell you that the tail section can tolerate 170lbs. I tested it when I > did and do my annuals, so I doubt it's a structural issue with the baggage > area. > > -- I believe the issue is what it can tolerate if you pull 3.8g, e.g., if the load limit is 100 lbs then it needs to be able to support 380 lbs static. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412841#412841 ________________________________________________________________________________
Subject: Re: Oil/Air Separator
Date: Nov 12, 2013
Rich, I am using the Andair air/oil separator with the condensation trap. The unit works as advertised. With the old separator I originally used, I always had an oil stream on the bottom of the aircraft after flying. The Andair separator eliminates the need to wipe the bottom of the airplane after each flight. I used a hose reducer fitting to hook a 1" hose to a 3/4" hose. Greg... Www.nwacaptain.com -------- Greg Hale rv10 -- N210KH www.nwacaptain.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=412883#412883 ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Please Make A List Contribution Today; Some Nice Comments...
Dear Listers, I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. Please make a Contribution today to support the continued upgrade and operation of these services. There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! You may use a credit card or your PayPal account here: http://www.matronics.com/contribution Or feel free to send a personal check to: Matronics / Matt Dralle 581 Jeannie Way Livermore CA 94550 Thank you in advance for your generous support! It is very much appreciated! Best regards, Matt Dralle Matronics Email List Administrator -------------------- What Listers Are Saying About The Lists -------------------- I wondered off for a few years & am coming back. I firmly believe you provide greater value to us than some magazine subscriptions. William F Thanks for helping me connect to people have truly blazed the trail. Terry M Thank you for the time and effort you put into keeping these lists going. I am on the verge of flying my RV 8 and would not be here without the help of Matronics. Michael W Thank you for providing a valuable service. Vaughn T Matt I like your forums. Jerry D Thank you for another year of service. Oscar Z Been a "member" for years - this has been a fantastic resource and a great gift to the aviation community. Reade G Thanks for the many years of support to RV builders. Roy H Best run list on the net. Roger C Thanks for your excellent forum! Fred D Truly respect your work and service to many readers!! Fergus K Thanks for an ad-free list! William A Thank you for your GREAT service. I read it every day. John B ..great service! Ralph C Thanks so much for being there. Your contribution to aviation knowledge is invaluable. Benjamin B Thank you for providing the list service. It's great! William V I'd never have finished my Glasair without them. Ronald C Thank you Matt for the valuable forum, am pleased to contribute! Jeffrey J Fine service. Byron G Thanks for your support of our community! Kenneth B -------------------- What Listers Are Saying About The Lists -------------------- ________________________________________________________________________________
Subject: Oil/ Air Separator
Date: Nov 13, 2013
Thank you Greg, That is exactly the info/pirep I was looking for. I appreciate your input! Rich Sent from my iPhone > On Nov 13, 2013, at 12:02 AM, RV10-List Digest Server wrote: > > * > > ================================================= > Online Versions of Today's List Digest Archive > ================================================= > > Today's complete RV10-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the RV10-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 13-11-12&Archive=RV10 > > Text Version: > > http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 13-11-12&Archive=RV10 > > > =============================================== > EMail Version of Today's List Digest Archive > =============================================== > > > ---------------------------------------------------------- > RV10-List Digest Archive > --- > Total Messages Posted Tue 11/12/13: 1 > ---------------------------------------------------------- > > > Today's Message Index: > ---------------------- > > 1. 09:03 AM - Re: Oil/Air Separator (greghale) > > > > ________________________________ Message 1 _____________________________________ > > > Subject: RV10-List: Re: Oil/Air Separator > From: "greghale" <ghale5224(at)aol.com> > > > Rich, > I am using the Andair air/oil separator with the condensation trap. The unit works > as advertised. With the old separator I originally used, I always had an > oil stream on the bottom of the aircraft after flying. The Andair separator eliminates > the need to wipe the bottom of the airplane after each flight. > I used a hose reducer fitting to hook a 1" hose to a 3/4" hose. > > > > > > ________________________________________________________________________________
Subject: Re: Please Make A List Contribution Today; Some Nice Comments...
Date: Nov 13, 2013
Please take me off the list Sent from my iPhone > On Nov 13, 2013, at 3:12 AM, Matt Dralle wrote: > > > > Dear Listers, > > I've been getting some very nice comments from Listers along with their List Support Contributions. I've shared a number of them below. Please read them over and see what your fellow Listers think of the Lists and Forums. > > Please make a Contribution today to support the continued upgrade and operation of these services. > > There are lots of really nice gifts available this year, so please browse the selections and pickup something fun with your qualifying Contribution! > > You may use a credit card or your PayPal account here: > > http://www.matronics.com/contribution > > Or feel free to send a personal check to: > > Matronics / Matt Dralle > 581 Jeannie Way > Livermore CA 94550 > > Thank you in advance for your generous support! It is very much appreciated! > > Best regards, > > Matt Dralle > Matronics Email List Administrator > > > > -------------------- What Listers Are Saying About The Lists -------------------- > > I wondered off for a few years & am coming back. I firmly > believe you provide greater value to us than some > magazine subscriptions. > William F > > Thanks for helping me connect to people have truly blazed > the trail. > Terry M > > Thank you for the time and effort you put into keeping these > lists going. I am on the verge of flying my RV 8 and would > not be here without the help of Matronics. > Michael W > > Thank you for providing a valuable service. > Vaughn T > > Matt I like your forums. > Jerry D > > Thank you for another year of service. > Oscar Z > > Been a "member" for years - this has been a fantastic > resource and a great gift to the aviation community. > Reade G > > Thanks for the many years of support to RV builders. > Roy H > > Best run list on the net. > Roger C > > Thanks for your excellent forum! > Fred D > > Truly respect your work and service to many readers!! > Fergus K > > Thanks for an ad-free list! > William A > > Thank you for your GREAT service. I read it every day. > John B > > ..great service! > Ralph C > > Thanks so much for being there. Your contribution to aviation > knowledge is invaluable. > Benjamin B > > Thank you for providing the list service. It's great! > William V > > I'd never have finished my Glasair without them. > Ronald C > > Thank you Matt for the valuable forum, am pleased to > contribute! > Jeffrey J > > Fine service. > Byron G > > Thanks for your support of our community! > Kenneth B > > > -------------------- What Listers Are Saying About The Lists -------------------- > > > > > > > > ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Re: RV-7 loss -> tail inspections -> spar cracks and loose
jam nuts found Tim, I've had a reminder about this on my desk for a few weeks now. I finally got around to checking my rudder and found the center hinge jam nut loose. All the others, rudder and elevator, were tight. I'll pay closer attention on preflight now. Thanks for the heads up. Dave Saylor 831-750-0284 CL On Sun, Oct 6, 2013 at 7:30 AM, Tim Lewis wrote: > > A thread at VAF discusses the results of empenage inspections after the > recent loss of an RV-7. (http://www.vansairforce.com/ > community/showthread.php?t=104551) A couple of spar cracks were found, > as were several instances of loose jam nuts on rudder/elevator rod end > bearings. > > Those rod end bearings form the hinge pivot for our elevators and rudders. > My understanding: If the jam nut is tight, the spar is held in > compression between the rod end bearing's plate nut and jam nut. If the > jam nut comes loose, the loads from the rod end bearing transfer to the > rudder/elevator spar only through the rivets holding the platenuts to the > spar. Not so good. > > Prompted by this thread, I inspected my RV-10 tail structure. No spar > cracks found. But I found that the top rudder rod end bearing jam nut > (page 11-7, similar to plans page 11-2) was loose. The torque seal on > this nut was (obviously) broken. > > Tim > > -- Tim Lewis -- HEF (Manassas, VA) > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 400 hrs > > ________________________________________________________________________________
Date: Nov 13, 2013
Subject: Door Struts,
Where have we been getting replacement door struts?=0A-=0AGod Bless Ameri ca=0A(please) -:)=0A=0A=0ABruce ________________________________________________________________________________
Subject: Re: Door Struts,
Date: Nov 14, 2013
Vans stocks both the standard and heavy duty struts, I know there are a co uple places that sells them for a few bucks less, but I don't recall their n ames. Bob Sent from my iPad > On Nov 13, 2013, at 5:40 PM, Bruce Johnson wro te: > > Where have we been getting replacement door struts? > > God Bless America > (please) :) > > > Bruce > ________________________________________________________________________________
Date: Nov 14, 2013
IIRC you can google the part number on the strut and locate at one of your favorite automotive sources. Shockingly, I don't believe they are an aircraft part. ;-) On Thu, Nov 14, 2013 at 3:22 AM, Bob Leffler wrote: > > Vans stocks both the standard and heavy duty struts, I know there are a > couple places that sells them for a few bucks less, but I don't recall > their names. > > Bob > Sent from my iPad > > On Nov 13, 2013, at 5:40 PM, Bruce Johnson > wrote: > > Where have we been getting replacement door struts? > > God Bless America > (please) :) > > > Bruce > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Nov 14, 2013
Does anyone have the part number for the heavy duty strut? I'm ordering new, not replacing. On Thu, Nov 14, 2013 at 6:51 AM, Kelly McMullen wrote: > IIRC you can google the part number on the strut and locate at one of your > favorite automotive sources. Shockingly, I don't believe they are an > aircraft part. ;-) > ________________________________________________________________________________
Date: Nov 14, 2013
Stabilus, Lift-O-Mat part number 2218LP On 11/14/13, 7:53 AM, Ed Kranz wrote: > Does anyone have the part number for the heavy duty strut? I'm > ordering new, not replacing. > > > On Thu, Nov 14, 2013 at 6:51 AM, Kelly McMullen > wrote: > > IIRC you can google the part number on the strut and locate at one > of your favorite automotive sources. Shockingly, I don't believe > they are an aircraft part. ;-) > > * > > * ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Make Sure You're Listed! List of Contributors Published in
December! Dear Listers, The List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: door struts
Date: Nov 15, 2013
-----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hotwheels Sent: Tuesday, April 03, 2012 7:17 AM Subject: RV10-List: Re: door struts JWF Technologies, 6820 Fairfield Business Drive, Fairfield, OH 45014. Phone 513-769-9611. www.JWFtechnologies.com . The struts are Stabilus, Lift-O-Mat part number 2218LP and cost was ~$80 each. Regards, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=369935#369935 ________________________________________________________________________________
Date: Nov 15, 2013
Subject: Builders Insurance
I was shocked today to get renewal quote covering my project, same broker, at same limits, same deductible, same underwriter, for not in motion coverage, in a locked hangar at airport, equipped with sprinklers, to be 50% higher than last year. What has happened in insurance world for such an increase? On the other hand, coverage for flight insurance when I need that, is in line with what has been mentioned here previously. Kelly Finishing and finishing and finishing ________________________________________________________________________________
Subject: Is there more than one location to install an oil temp probe
Date: Nov 16, 2013
Hi, I am thinking to install the oil temp controller from experimentalgoodies.com, I am not sure if there is a second port on the TMX-IO-540 to install an oil temp probe. I don't have my manual with me and won't be in the hangar for a couple of days so I 'd appreciate if someone could help. Thanks Mike -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413202#413202 ________________________________________________________________________________
Date: Nov 16, 2013
Subject: Re: Is there more than one location to install an oil temp
probe
Yes. There are plugs at the front of the engine that are used during overhaul to clean the oil galleys. You can remove one (very carefully) with an appropriately sized allen socket. It is worth having the right size that you can put a 3/8s ratchet wrench on. You may have to also apply some heat with a propane torch in that area to loosen whatever sealant was used on the plug. They are difficult to get loose, and you darn sure do not want to round off the flats on the allen plug. On Sat, Nov 16, 2013 at 8:52 AM, Mike Whisky wrote: > > Hi, > I am thinking to install the oil temp controller from > experimentalgoodies.com, I am not sure if there is a second port on the > TMX-IO-540 to install an oil temp probe. I don't have my manual with me and > won't be in the hangar for a couple of days so I 'd appreciate if someone > could help. > > Thanks > Mike > > -------- > RV-10 builder (flying, test phase) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413202#413202 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Re: Builders Insurance
Date: Nov 16, 2013
"Builders' Insurance" remains a mystery to me. When I was building the cost of the Builders' Insurance was 2/3 what I pay now for a flying airplane, including liability as well as hull. Do insurance companies think that 2/3 of the risk happens in the hangar? It could be that (1) theft is easier when avionics, and maybe engines, are in nice boxes instead of mounted; or (2) last year saw some low cost carriers drop out of the -10 market. Maybe there now is no competition? Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413215#413215 ________________________________________________________________________________
Date: Nov 16, 2013
Where are you guys getting builder's insurance? I got mine through EAA. I don't have "real" insurance yet, but I know the $$ I am paying for builder's insurance is not going to even be 1/3 of what it will be. I think I am paying around $800/yr for builder's insurance. -Sean #40303 (putting everything back on) On 11/16/13, 3:24 PM, Bob Turner wrote: > > "Builders' Insurance" remains a mystery to me. When I was building the cost of the Builders' Insurance was 2/3 what I pay now for a flying airplane, including liability as well as hull. Do insurance companies think that 2/3 of the risk happens in the hangar? > It could be that (1) theft is easier when avionics, and maybe engines, are in nice boxes instead of mounted; or (2) last year saw some low cost carriers drop out of the -10 market. Maybe there now is no competition? > > Bob > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413215#413215 > > ________________________________________________________________________________
Date: Nov 16, 2013
I also got mine thru EAA which really means the Falcon agency, and I forget the actual carrier. It cost 1% of the declared value, which pushed it well into 4 figures by the time I had virtually all the pieces in the hangar. I think it was $1400, for $140,000 coverage. I paid for it mostly because it covered the 15 mile trip to the airport from my garage. Maybe that was where all the risk was, I do not know. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413217#413217 ________________________________________________________________________________
Date: Nov 16, 2013
I self insured until the big move to the airport. That being said my work shop is 50' from my house and is well lite, secured, and alarmed. It was still a relief when I purchased full coverage insurance a few days before I moved it to the hanger. ----- Original Message ----- From: "Bob Turner" <bobturner(at)alum.rpi.edu> Sent: Saturday, November 16, 2013 5:29:21 PM Subject: RV10-List: Re: Builders Insurance I also got mine thru EAA which really means the Falcon agency, and I forget the actual carrier. It cost 1% of the declared value, which pushed it well into 4 figures by the time I had virtually all the pieces in the hangar. I think it was $1400, for $140,000 coverage. I paid for it mostly because it covered the 15 mile trip to the airport from my garage. Maybe that was where all the risk was, I do not know. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413217#413217 ________________________________________________________________________________
Date: Nov 16, 2013
I guess I have a bit different situation. I have done all of my building at my hangar, at a public airport, which has security gates, police patrol, well lit, with well maintained sprinkler system. I only bought insurance once I had over $120K into the project. My coverage through NationAir and Global last year was $600, and for same exact coverage and stated value, this year, they want $900. I only pay around $1400 for my retractable gear Mooney for full coverage in flight etc. Granted the hull value is much less, but the exposure to damage is much higher. On 11/16/2013 4:19 PM, davidsoutpost(at)comcast.net wrote: > I self insured until the big move to the airport. That being said my > work shop is 50' from my house and is well lite, secured, and > alarmed. It was still a relief when I purchased full coverage > insurance a few days before I moved it to the hanger. > > ------------------------------------------------------------------------ > *From: *"Bob Turner" <bobturner(at)alum.rpi.edu> > *To: *rv10-list(at)matronics.com > *Sent: *Saturday, November 16, 2013 5:29:21 PM > *Subject: *RV10-List: Re: Builders Insurance > > > I also got mine thru EAA which really means the Falcon agency, and I > forget the actual carrier. It cost 1% of the declared value, which > pushed it well into 4 figures by the time I had virtually all the > pieces in the hangar. I think it was $1400, for $140,000 coverage. I > paid for it mostly because it covered the 15 mile trip to the airport > from my garage. Maybe that was where all the risk was, I do not know. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413217#413217 > > > * > > * ________________________________________________________________________________
Date: Nov 16, 2013
So, 3 years ago I would have been paying $1200, so you're still ahead. I think two years ago the premiums went from 1% to 0.5%; maybe they decided the reduction was too much. One issue is that the market is so small, overhead costs get amortized over relatively few policies. I'll bet they can't generate a piece of paper for less than $100. Similar issue: What do you think the insurance companies want to cover me while giving transition training (I have a LODA)? How about a 50% premium increase, for an estimated 20 hours of dual given per year? The risk/cost ratio seems all out of wack to me. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413224#413224 ________________________________________________________________________________
Date: Nov 17, 2013
Perhaps the low initial rate was to get you as a new customer? -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413243#413243 ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Fund Raiser Behind By 25% - Please Contribute Today!
Dear Listers, The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! Matt Dralle Email List and Forums Administrator ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Re: Fund Raiser Behind By 25% - Please Contribute Today!
Matt, I donated several weeks ago but still receive appeal messages. Did you receive my donation? Dave Fritzsche ~~~~~~~~~~~~~~~~~~ David J. Fritzsche Professor, Retired Penn State ~~~~~~~~~~~~~~~~~~ On 11/18/2013 12:26 AM, Matt Dralle wrote: > > Dear Listers, > > The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! > > Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. > > Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: > > http://www.matronics.com/contribution > > Or, drop a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > USA > > I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! > > Matt Dralle > Email List and Forums Administrator > > ________________________________________________________________________________
Date: Nov 18, 2013
Subject: Re: Contribution Received
At 08:45 AM 11/18/2013 Monday, you wrote: > >Matt, > >I donated several weeks ago but still receive appeal messages. Did you receive my donation? > >Dave Fritzsche Hi Dave, Yes, your Contribution was received on 11/9. The reason the squelch isn't working is because the email address you are subscribed with "dfritz(at)bpgsim.com" doesn't match the email address with which you made your Contribution. The two email addresses have to match exactly for the squelch to function properly. I've updated your Contribution email to match your subscription email, so you should be good for the future. Thank you for your generous Contribution, Dave. It is very much appreciated. Matt Dralle Matronics Email List & Forum Administrator Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 18, 2013
Same here. I donated several weeks ago, but still receive these messages. David Maib On Nov 18, 2013, at 11:45 AM, David J. Fritzsche wrote: Matt, I donated several weeks ago but still receive appeal messages. Did you receive my donation? Dave Fritzsche ~~~~~~~~~~~~~~~~~~ David J. Fritzsche Professor, Retired Penn State ~~~~~~~~~~~~~~~~~~ On 11/18/2013 12:26 AM, Matt Dralle wrote: > > Dear Listers, > > The percentage of members making a Contribution to support the Lists this year is currently behind last year by at this time by roughly 25%. We got off to a slow start this year with the network DNS issues on the kickoff weekend, so please take this opportunity to show your support for the Matronics Lists and Forums! > > Please remember that it is *solely* your direct Contributions that keep these Lists and Forums up and running and most importantly - AD FREE! If the members don't want to support the Lists directly, then I might have to add advertisements to offset the costs of running the Lists. But I don't want to have to do that. I really like the non-commercial atmosphere here and I think that a lot of the members appreciate that too. > > Please take a moment to make a Contribution today in support of the continued ad-free operation of all these Lists: > > http://www.matronics.com/contribution > > Or, drop a personal check in the mail to: > > Matt Dralle / Matronics > 581 Jeannie Way > Livermore CA 94550 > USA > > I want to send out a word of appreciation to all of the members that have already made their generous Contribution to support the Lists! Thank you! > > Matt Dralle > Email List and Forums Administrator > > > > > > > > David Maib dmaib(at)me.com ________________________________________________________________________________
Date: Nov 18, 2013
I'd just shoot him a note to Matt Dralle and let him know. I'm not sure how the names get removed from the list, but it seems some people slip through. I donated a couple weeks ago and didn't see anything after that. It could be that in the area that you select which lists you're subscribed to, you missed one....I'm not sure how that works, but I know I had to remember to check 6 or 7 lists. Tim Olson - RV-10 N104CD On 11/18/2013 8:07 PM, David Maib wrote: > Same here. I donated several weeks ago, but still receive these messages. > > David Maib > > On Nov 18, 2013, at 11:45 AM, David J. Fritzsche wrote: > > > > > Matt, > > I donated several weeks ago but still receive appeal messages. Did you > receive my donation? > > Dave Fritzsche > > ~~~~~~~~~~~~~~~~~~ > David J. Fritzsche > Professor, Retired > Penn State > ~~~~~~~~~~~~~~~~~~ > > On 11/18/2013 12:26 AM, Matt Dralle wrote: >> > >> >> Dear Listers, >> >> The percentage of members making a Contribution to support the Lists >> this year is currently behind last year by at this time by roughly >> 25%. We got off to a slow start this year with the network DNS issues >> on the kickoff weekend, so please take this opportunity to show your >> support for the Matronics Lists and Forums! >> >> Please remember that it is *solely* your direct Contributions that >> keep these Lists and Forums up and running and most importantly - AD >> FREE! If the members don't want to support the Lists directly, then I >> might have to add advertisements to offset the costs of running the >> Lists. But I don't want to have to do that. I really like the >> non-commercial atmosphere here and I think that a lot of the members >> appreciate that too. >> >> Please take a moment to make a Contribution today in support of the >> continued ad-free operation of all these Lists: >> >> http://www.matronics.com/contribution >> >> Or, drop a personal check in the mail to: >> >> Matt Dralle / Matronics >> 581 Jeannie Way >> Livermore CA 94550 >> USA >> >> I want to send out a word of appreciation to all of the members that >> have already made their generous Contribution to support the Lists! >> Thank you! >> >> Matt Dralle >> Email List and Forums Administrator >> >> >> >> >> >> >> > http://www.matronics.com/co -Matt > Dralle, List - The RV10-List --> > http://www.matronics======================= > > > <http://www.matronics.com/Navigator?RV10-List> > > > <http://www.matronics.com/Navigator?RV10-List> > David Maib > <http://www.matronics.com/Navigator?RV10-List> > <http://www.matronics.com/Navigator?RV10-List>dmaib@me.com > > > ________________________________________________________________________________
Date: Nov 18, 2013
Matt responded earlier: The reason the squelch isn't working is because the email address you are subscribed with "XX(at)xx.x" doesn't match the email address with which you made your Contribution. The two email addresses have to match exactly for the squelch to function properly. I've updated your Contribution email to match your subscription email, so you should be good for the future. I have not seen anything either so it works for me Pascal grateful to Matt for this forum.. (and his Dynon / VP200 support!) -----Original Message----- From: Tim Olson Sent: Monday, November 18, 2013 6:26 PM Subject: Re: RV10-List: Fund Raiser Behind By 25% - Please Contribute Today! I'd just shoot him a note to Matt Dralle and let him know. I'm not sure how the names get removed from the list, but it seems some people slip through. I donated a couple weeks ago and didn't see anything after that. It could be that in the area that you select which lists you're subscribed to, you missed one....I'm not sure how that works, but I know I had to remember to check 6 or 7 lists. Tim Olson - RV-10 N104CD On 11/18/2013 8:07 PM, David Maib wrote: > Same here. I donated several weeks ago, but still receive these messages. > > David Maib > > On Nov 18, 2013, at 11:45 AM, David J. Fritzsche wrote: > > > > > Matt, > > I donated several weeks ago but still receive appeal messages. Did you > receive my donation? > > Dave Fritzsche > > ~~~~~~~~~~~~~~~~~~ > David J. Fritzsche > Professor, Retired > Penn State > ~~~~~~~~~~~~~~~~~~ > > On 11/18/2013 12:26 AM, Matt Dralle wrote: >> > >> >> Dear Listers, >> >> The percentage of members making a Contribution to support the Lists >> this year is currently behind last year by at this time by roughly >> 25%. We got off to a slow start this year with the network DNS issues >> on the kickoff weekend, so please take this opportunity to show your >> support for the Matronics Lists and Forums! >> >> Please remember that it is *solely* your direct Contributions that >> keep these Lists and Forums up and running and most importantly - AD >> FREE! If the members don't want to support the Lists directly, then I >> might have to add advertisements to offset the costs of running the >> Lists. But I don't want to have to do that. I really like the >> non-commercial atmosphere here and I think that a lot of the members >> appreciate that too. >> >> Please take a moment to make a Contribution today in support of the >> continued ad-free operation of all these Lists: >> >> http://www.matronics.com/contribution >> >> Or, drop a personal check in the mail to: >> >> Matt Dralle / Matronics >> 581 Jeannie Way >> Livermore CA 94550 >> USA >> >> I want to send out a word of appreciation to all of the members that >> have already made their generous Contribution to support the Lists! >> Thank you! >> >> Matt Dralle >> Email List and Forums Administrator >> >> >> >> >> >> >> > http://www.matronics.com/co -Matt > Dralle, List - The RV10-List --> > http://www.matronics======================= > > > <http://www.matronics.com/Navigator?RV10-List> > > > <http://www.matronics.com/Navigator?RV10-List> > David Maib > <http://www.matronics.com/Navigator?RV10-List> > <http://www.matronics.com/Navigator?RV10-List>dmaib@me.com > > > ________________________________________________________________________________
Date: Nov 18, 2013
Yes, that is correct. The subscribed email address and the contribution email address must match exactly for the squelch to work. Also note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them. Thank you to everyone that has made a contribution so far! It is very much appreciated! Matt Dralle Email List Administrator At 07:20 PM 11/18/2013 Monday, you wrote: > >Matt responded earlier: >The reason the squelch isn't working is because the email address you are subscribed with "XX(at)xx.x" doesn't match the email address with which you made your Contribution. The two email addresses have to match exactly for the squelch to function properly. > >I've updated your Contribution email to match your subscription email, so you should be good for the future. >I have not seen anything either so it works for me > >Pascal >grateful to Matt for this forum.. (and his Dynon / VP200 support!) > >-----Original Message----- From: Tim Olson >Sent: Monday, November 18, 2013 6:26 PM >To: rv10-list(at)matronics.com >Subject: Re: RV10-List: Fund Raiser Behind By 25% - Please Contribute Today! > > >I'd just shoot him a note to Matt Dralle and >let him know. I'm not sure how the names get removed from the list, >but it seems some people slip through. I donated a couple weeks ago >and didn't see anything after that. It could be that in the >area that you select which lists you're subscribed to, you missed >one....I'm not sure how that works, but I know I had to remember >to check 6 or 7 lists. > > >Tim Olson - RV-10 N104CD > >On 11/18/2013 8:07 PM, David Maib wrote: >>Same here. I donated several weeks ago, but still receive these messages. >> >>David Maib >> >>On Nov 18, 2013, at 11:45 AM, David J. Fritzsche wrote: >> >>> >> >>Matt, >> >>I donated several weeks ago but still receive appeal messages. Did you >>receive my donation? >> >>Dave Fritzsche >> >>~~~~~~~~~~~~~~~~~~ >>David J. Fritzsche >>Professor, Retired >>Penn State >>~~~~~~~~~~~~~~~~~~ >> >>On 11/18/2013 12:26 AM, Matt Dralle wrote: >>>> >>> >>>Dear Listers, >>> >>>The percentage of members making a Contribution to support the Lists >>>this year is currently behind last year by at this time by roughly >>>25%. We got off to a slow start this year with the network DNS issues >>>on the kickoff weekend, so please take this opportunity to show your >>>support for the Matronics Lists and Forums! >>> >>>Please remember that it is *solely* your direct Contributions that >>>keep these Lists and Forums up and running and most importantly - AD >>>FREE! If the members don't want to support the Lists directly, then I >>>might have to add advertisements to offset the costs of running the >>>Lists. But I don't want to have to do that. I really like the >>>non-commercial atmosphere here and I think that a lot of the members >>>appreciate that too. >>> >>>Please take a moment to make a Contribution today in support of the >>>continued ad-free operation of all these Lists: >>> >>>http://www.matronics.com/contribution >>> >>>Or, drop a personal check in the mail to: >>> >>> Matt Dralle / Matronics >>> 581 Jeannie Way >>> Livermore CA 94550 >>> USA >>> >>>I want to send out a word of appreciation to all of the members that >>>have already made their generous Contribution to support the Lists! >>> Thank you! >>> >>>Matt Dralle >>>Email List and Forums Administrator >>> >>> >>> >>> >>> >>> >> http://www.matronics.com/co -Matt >> Dralle, List - The RV10-List --> >> http://www.matronics======================= >> >> >> <http://www.matronics.com/Navigator?RV10-List> >> >> >><http://www.matronics.com/Navigator?RV10-List> >>David Maib >> <http://www.matronics.com/Navigator?RV10-List> >><http://www.matronics.com/Navigator?RV10-List>dmaib@me.com >> >> > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Nov 19, 2013
Matt, I was not upset by getting the extra messages. I just wanted to make sure you received my contribution. Sorry about the mixup on the addresses. I have several addresses for different purposes as I suspect many of us do and sometimes forget to make sure the correct address is being shown. As others have said, I really appreciate your efforts in making this a wonderful, useful list. Dave ~~~~~~~~~~~~~~~~~~ David J. Fritzsche Professor, Retired Penn State ~~~~~~~~~~~~~~~~~~ On 11/18/2013 7:48 PM, Matt Dralle wrote: > > > Yes, that is correct. The subscribed email address and the contribution email address must match exactly for the squelch to work. > > Also note that there are certain circumstances where you might still see a Contribution related message. For example, if someone replies to one of the messages, when using the List Browse feature, or when accessing List message via the Forum. The system keys on the given email address and since most of these are anonymous public access methods, there is no simple way to filter them. > > Thank you to everyone that has made a contribution so far! It is very much appreciated! > > Matt Dralle > Email List Administrator > > At 07:20 PM 11/18/2013 Monday, you wrote: >> >> Matt responded earlier: >> The reason the squelch isn't working is because the email address you are subscribed with "XX(at)xx.x" doesn't match the email address with which you made your Contribution. The two email addresses have to match exactly for the squelch to function properly. >> >> I've updated your Contribution email to match your subscription email, so you should be good for the future. >> I have not seen anything either so it works for me >> >> Pascal >> grateful to Matt for this forum.. (and his Dynon / VP200 support!) >> >> -----Original Message----- From: Tim Olson >> Sent: Monday, November 18, 2013 6:26 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Fund Raiser Behind By 25% - Please Contribute Today! >> >> >> I'd just shoot him a note to Matt Dralle and >> let him know. I'm not sure how the names get removed from the list, >> but it seems some people slip through. I donated a couple weeks ago >> and didn't see anything after that. It could be that in the >> area that you select which lists you're subscribed to, you missed >> one....I'm not sure how that works, but I know I had to remember >> to check 6 or 7 lists. >> >> >> Tim Olson - RV-10 N104CD >> >> On 11/18/2013 8:07 PM, David Maib wrote: >>> Same here. I donated several weeks ago, but still receive these messages. >>> >>> David Maib >>> >>> On Nov 18, 2013, at 11:45 AM, David J. Fritzsche wrote: >>> >>> > >>> >>> Matt, >>> >>> I donated several weeks ago but still receive appeal messages. Did you >>> receive my donation? >>> >>> Dave Fritzsche >>> >>> ~~~~~~~~~~~~~~~~~~ >>> David J. Fritzsche >>> Professor, Retired >>> Penn State >>> ~~~~~~~~~~~~~~~~~~ >>> >>> On 11/18/2013 12:26 AM, Matt Dralle wrote: >>>> > >>>> >>>> Dear Listers, >>>> >>>> The percentage of members making a Contribution to support the Lists >>>> this year is currently behind last year by at this time by roughly >>>> 25%. We got off to a slow start this year with the network DNS issues >>>> on the kickoff weekend, so please take this opportunity to show your >>>> support for the Matronics Lists and Forums! >>>> >>>> Please remember that it is *solely* your direct Contributions that >>>> keep these Lists and Forums up and running and most importantly - AD >>>> FREE! If the members don't want to support the Lists directly, then I >>>> might have to add advertisements to offset the costs of running the >>>> Lists. But I don't want to have to do that. I really like the >>>> non-commercial atmosphere here and I think that a lot of the members >>>> appreciate that too. >>>> >>>> Please take a moment to make a Contribution today in support of the >>>> continued ad-free operation of all these Lists: >>>> >>>> http://www.matronics.com/contribution >>>> >>>> Or, drop a personal check in the mail to: >>>> >>>> Matt Dralle / Matronics >>>> 581 Jeannie Way >>>> Livermore CA 94550 >>>> USA >>>> >>>> I want to send out a word of appreciation to all of the members that >>>> have already made their generous Contribution to support the Lists! >>>> Thank you! >>>> >>>> Matt Dralle >>>> Email List and Forums Administrator >>>> >>>> >>>> >>>> >>>> >>>> >>> http://www.matronics.com/co -Matt >>> Dralle, List - The RV10-List --> >>> http://www.matronics======================= >>> >>> >>> <http://www.matronics.com/Navigator?RV10-List> >>> >>> >>> <http://www.matronics.com/Navigator?RV10-List> >>> David Maib >>> <http://www.matronics.com/Navigator?RV10-List> >>> <http://www.matronics.com/Navigator?RV10-List>dmaib@me.com >>> >>> >> >> >> >> >> >> > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > ________________________________________________________________________________
Date: Nov 20, 2013
Subject: Value of the List...
If you look forward to checking your List email everyday (and a lot of you have written to say that you do!), then you're probably getting at least $20 or $30 worth of Entertainment from the Lists each year. You'd pay twice that for a subscription to some magazine or even a dinner out. Isn't the List worth at least that much to you? Wouldn't it be great if you could pay that amount and get a well-managed media source free of advertising, SPAM, and viruses? Come to think of it, you do... :-) Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA I want to say THANK YOU to everyone that has made a Contribution thus far during this year's List Fund Raiser!! These Lists are made possible exclusively through YOUR generosity!! Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Subject: Paint question
Date: Nov 20, 2013
My airplane will be complete by end of year, just unassembled. I plan to take it to the paint shop in pieces, then do final assembly of the painted parts. The only potential fly in the ointment I see so far are the wing tips. I've had the wings on for the fairing work, but they are off now. I know it is best to match the tips to rigged ailerons. Are there serious potential paint issues of attaching the tips after paint? Any other considerations? I'm really hoping to not have to assemble everything and tear it down again. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413599#413599 ________________________________________________________________________________
Date: Nov 20, 2013
That is what I did. Only downside (if you call it that) is that the screws holding it in aren't painted on the plane. Otherwise=2C no problem. I have heard other opinions and I've come to the conclusion it's a personal choice . > Subject: RV10-List: Paint question > From: woxof(at)aol.com > Date: Wed=2C 20 Nov 2013 12:09:08 -0800 > To: rv10-list(at)matronics.com > > > My airplane will be complete by end of year=2C just unassembled. I plan t o take it to the paint shop in pieces=2C then do final assembly of the pain ted parts. > > The only potential fly in the ointment I see so far are the wing tips. I 've had the wings on for the fairing work=2C but they are off now. I know it is best to match the tips to rigged ailerons. Are there serious potenti al paint issues of attaching the tips after paint? Any other consideration s? I'm really hoping to not have to assemble everything and tear it down a gain. > Thanks in advance. > > -------- > Myron Nelson > Mesa=2C AZ > Emp completed=2C QB wings completed=2C legacy build fuse on gear. FWF co mplete. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413599#413599 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: Re: Paint question
Date: Nov 20, 2013
Only if you got one of the wing tips whose shape is distorted. Then you have to cut and re-align the tip, which would screw up your paint job. I did the same as you are planning, but I rigged the ailerons before taking to paint, then again during final assembly. Even doing this, I've got one tip that ended up being off slightly. Not a big deal if your wings are still on in your shop. As you mentioned, a real PITA if you have to reassemble everything. The other option is to delay painting the tips until you get the wings back on after paint. Bob Sent from my iPhone On Nov 20, 2013, at 3:09 PM, "woxofswa" wrote: My airplane will be complete by end of year, just unassembled. I plan to take it to the paint shop in pieces, then do final assembly of the painted parts. The only potential fly in the ointment I see so far are the wing tips. I've had the wings on for the fairing work, but they are off now. I know it is best to match the tips to rigged ailerons. Are there serious potential paint issues of attaching the tips after paint? Any other considerations? I'm really hoping to not have to assemble everything and tear it down again. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413599#413599 ________________________________________________________________________________
Date: Nov 20, 2013
I painted everything separately. I chose to use stainless steel screws ever ywhere for fairings and the fuel tanks. I've never been satisfied with the look of painted screws after a few years in service. So I'm real pleased w ith the result of painting the airplane in pieces and doing final assembly a fterwards. Of course I did have all the parts together for rigging of wi ngs/flaps and ailerons unpainted- one time. Bob Newman N541RV. Sent from my iPhone On Nov 20, 2013, at 3:18 PM, Danny Riggs wrote: > That is what I did. Only downside (if you call it that) is that the screws holding it in aren't painted on the plane. Otherwise, no problem. I have he ard other opinions and I've come to the conclusion it's a personal choice. > > > Subject: RV10-List: Paint question > > From: woxof(at)aol.com > > Date: Wed, 20 Nov 2013 12:09:08 -0800 > > To: rv10-list(at)matronics.com > > > > > > My airplane will be complete by end of year, just unassembled. I plan to take it to the paint shop in pieces, then do final assembly of the painted p arts. > > > > The only potential fly in the ointment I see so far are the wing tips. I 've had the wings on for the fairing work, but they are off now. I know it i s best to match the tips to rigged ailerons. Are there serious potential pa int issues of attaching the tips after paint? Any other considerations? I'm r eally hoping to not have to assemble everything and tear it down again. > > Thanks in advance. > > > > -------- > > Myron Nelson > > Mesa, AZ > > Emp completed, QB wings completed, legacy build fuse on gear. FWF comple te. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=413599#413599 > > > >===== > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Nov 20, 2013
Don't do it. You risk messing up an expensive paint job. Fit up the wings, flaps, ailerons and wing tips before paint. A 1/4" wingtip trailing edge offset will totally screw up your trim. It is impossible to get the wing tips on correctly unless you work from the fuselage out - flaps, then ailerons, then wingtips. Before you start drilling and clekoing the tips, the trailing edge of the wing tips can be moved up or down over an inch. There is no way to get this right unless you have the aileron in exactly the right rig to align the trailing edges. After you are really sure you don't have any twist in your flaps, spend a lot of time measuring aileron rigging every which way from Tuesday. This includes careful measurement of aileron height both at the inboard and outboard mounts. Most RVs have a slight height difference between ailerons. Fix this first, then work the linkage lengths on rigging. After all that you are ready to rig the wingtips. Ask any RV builder that chased a heavy wing - aileron height tends to be the last thing they look at but the most common cause (assuming no gross linkage issues). Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of woxofswa Sent: Wednesday, November 20, 2013 3:09 PM Subject: RV10-List: Paint question My airplane will be complete by end of year, just unassembled. I plan to take it to the paint shop in pieces, then do final assembly of the painted parts. The only potential fly in the ointment I see so far are the wing tips. I've had the wings on for the fairing work, but they are off now. I know it is best to match the tips to rigged ailerons. Are there serious potential paint issues of attaching the tips after paint? Any other considerations? I'm really hoping to not have to assemble everything and tear it down again. Thanks in advance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413599#413599 ________________________________________________________________________________
Date: Nov 20, 2013
Thanks for the input. I should have mentioned that the plan is to paint just the base coat before assembly and the accents afterwards. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413609#413609 ________________________________________________________________________________
Subject: Re: life of the Odyssey
Date: Nov 20, 2013
How did you mount the two 680s...just looking at dimentions, I don't thinbk they will sit side by side in the stock battery tray. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413612#413612 ________________________________________________________________________________
Date: Nov 20, 2013
Bob, I am not sure if you are addressing me, but I do not have two PC680's. I have a PC925L in the main tray, which will fit in the standard mount without modification, and a PC680 in a battery box supplied by Odyssey. The PC680 second battery is mounted on a shelf next to the existing tray. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413614#413614 ________________________________________________________________________________
Date: Nov 20, 2013
Really easy to modify the tray.... I originally had 2 ea 680's, but just modified it a second time to host a 925 and a 680. ________________________________________________________________________________
Date: Nov 20, 2013
I agree with Carl re rigging the flaps, ailerons and wing tips, but there is no reason that the wings need to be mounted to the fuselage; in fact I think it is easier to do all of that with the wings in a rack, leading edge down. No crawling around under the wings, fighting gravity to keep the flaps against the stops, etc. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413617#413617 ________________________________________________________________________________
Date: Nov 21, 2013
Here is how I did mine: http://s403.photobucket.com/user/dclifford01/media/RV10/IMG_0006.jpg.html ----- Original Message ----- From: "bob88" <marty.crooks(at)comcast.net> Sent: Wednesday, November 20, 2013 5:18:15 PM Subject: RV10-List: Re: life of the Odyssey How did you mount the two 680s...just looking at dimentions, I don't thinbk they will sit side by side in the stock battery tray. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413612#413612 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Nov 20, 2013
I used two PC-625s and modified the mount. The hold down bolts remain in the same place. I find the 625s (17ah, 200CCA and 15 lb) a better form factor to work with than the PC-680s (16ah, 170CCA and 16lbs). Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Wednesday, November 20, 2013 5:18 PM Subject: RV10-List: Re: life of the Odyssey How did you mount the two 680s...just looking at dimentions, I don't thinbk they will sit side by side in the stock battery tray. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413612#413612 ________________________________________________________________________________
Date: Nov 20, 2013
Hey Don, why the change back to the 925 and 680 combo? Thx, Rick #40956 On Wed, Nov 20, 2013 at 6:49 PM, Don McDonald wrote: > Really easy to modify the tray.... I originally had 2 ea 680's, but just > modified it a second time to host a 925 and a 680. > > ------------------------------ > * From: * bill.peyton <peyton.b(at)sbcglobal.net>; > * To: * ; > * Subject: * RV10-List: Re: life of the Odyssey > * Sent: * Wed, Nov 20, 2013 11:03:56 PM > > * > > * > > ________________________________________________________________________________
Subject: 680 life
Date: Nov 21, 2013
I had two 680s in parallel in the aft battery compartment; They had been in there since first flight in April 2008. The cranking was starting to slow so I changed them September 2013 after 750TT. One had a manufacture date of 2005 and the other 2007. The batteries were still starting the aircraft but I felt that I wanted the reliability of two new batteries. Just for reference , I have a third insulated 680 on the firewall, installed in about 2010 for weight and balance purposes. It is trickle charged from the primary bus and powers the essential bus if the charging system or the field breaker fails. I have a picture somewhere but basically I placed both 680s in a modified tray and used two master contactors 002 wire to send power to the starter relay. David McNeill N46007 ________________________________________________________________________________
Subject: Paint Question
Date: Nov 21, 2013
Hi Myron, An exciting time coming for you with paint right around the corner! One consideration that I didn't see anyone else speak of is skin dimpling. I sort of cringe thinking of dimpling a nicely painted surface! As you know, the procedure would be fit the tip, drill it, deburr it, then finally dimple the skin and c/s the wing tip. Somewhere in there riveting on some platenuts ( nutplates too) to those tips. Also if you are talking about doing a base coat/clear coat there is usually a max. 24 hour window between base and clear to consider - so my thinking is way too much work on those tips for that window? Having to scuff the base coat and add more is the only option and that doesn't sound like much fun! Just some thoughts.. Regards, Rich Hansen > My airplane will be complete by end of year, just unassembled. I plan to take it > to the paint shop in pieces, then do final assembly of the painted parts. > > The only potential fly in the ointment I see so far are the wing tips. I've had > the wings on for the fairing work, but they are off now. I know it is best > to match the tips to rigged ailerons. Are there serious potential paint issues > of attaching the tips after paint? Any other considerations? I'm really hoping > to not have to assemble everything and tear it down again. > Thanks in advance. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > ________________________________________________________________________________
Date: Nov 21, 2013
Here's how I mounted my (2) 680s for a Z-14 http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=2155&log=43554&row=26 It's been working great thru 350hours. Bill Watson On 11/20/2013 5:18 PM, bob88 wrote: > > How did you mount the two 680s...just looking at dimentions, I don't thinbk they will sit side by side in the stock battery tray. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413612#413612 > > ________________________________________________________________________________
Date: Nov 21, 2013
Myron, We just received ours back from paint. As far as wing tips, we had to cut them to length and slit the rear edge apart in order to match to align. Both tips had a tip up and it was impossible on ours to align with out cutting them apart. One thing I will mention is our painter had experience with finishing and painting Lancair, I think he did a excellent job around the windows and I hope no cracking the way they did this. I can send you some pictures if you are interested. -------- Jackm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413655#413655 ________________________________________________________________________________
Subject: Rv10 #40458 for sale
Date: Nov 21, 2013
Hey folks - one of the nicest and best equipped 10s is for sale. I won't be flying any more for health reasons. Drop me a line for an extensive description and pics. John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 ________________________________________________________________________________
Date: Nov 22, 2013
Subject: Please Make A Contribution Today...
Dear Listers, A quick reminder that November is the annual List Fund Raiser and the List of Contributors is quickly approching. The Matronics Lists are 100% member supported and all of the operational costs are provided for by your Contributions during this time of the year. Your personal Contribution makes a big difference and keeps all of the Matronics Email Lists and Forums completely ad-free. Please make your Contribution today to keep these services up and running! http://www.matronics.com/contribution or by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you in advance! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Subject: Seat question
Date: Nov 22, 2013
I just got my interior kit from Abby at Flightline and I am quite pleased. In attaching the seat bottom cushion it dawned on me that it will be a PITA to attach the seat retainer plunger. Unless I'm missing something, you have undo everything to put the nuts on the inside of the frame. The only solution I've come up with is to put nut plates on the inside of the frame right below the "do not alter or modify" sticker. Any ideas? -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413796#413796 ________________________________________________________________________________
Subject: Re: Seat question
Date: Nov 22, 2013
I put nut plates on the outside of the black bracket. I then can in install the bolts from the inside of the seat frame. No more attempting to get a wrench in that small space. It looks ugly, but since it's next to impossible see, nobody will notice but you. Sent from my iPhone On Nov 22, 2013, at 1:05 PM, "woxofswa" wrote: I just got my interior kit from Abby at Flightline and I am quite pleased. In attaching the seat bottom cushion it dawned on me that it will be a PITA to attach the seat retainer plunger. Unless I'm missing something, you have undo everything to put the nuts on the inside of the frame. The only solution I've come up with is to put nut plates on the inside of the frame right below the "do not alter or modify" sticker. Any ideas? -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413796#413796 ________________________________________________________________________________
Date: Nov 22, 2013
I "altered or modified" for the same reasons you mentioned. :) See here - http://www.flickr.com/photos/stephensville/9684701079/ On 11/22/13, 12:05 PM, woxofswa wrote: > > I just got my interior kit from Abby at Flightline and I am quite pleased. > > In attaching the seat bottom cushion it dawned on me that it will be a PITA to attach the seat retainer plunger. Unless I'm missing something, you have undo everything to put the nuts on the inside of the frame. The only solution I've come up with is to put nut plates on the inside of the frame right below the "do not alter or modify" sticker. Any ideas? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413796#413796 > > ________________________________________________________________________________
Date: Nov 22, 2013
Myron, Mount the seat plunger before installing the bottom cushion. I did install nutplates and they work great. Some have also threaded the side rail, doing away with the need for any type of nuts. Probably not as strong that way. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413802#413802 ________________________________________________________________________________
Date: Nov 22, 2013
I have a removable seat cushion and nut plates on the plunger. Works great. I also have the IFLYRV10 seat slide lever. Works great. www.iflyrv10.com Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Friday, November 22, 2013 11:47 AM Subject: RV10-List: Re: Seat question Myron, Mount the seat plunger before installing the bottom cushion. I did install nutplates and they work great. Some have also threaded the side rail, doing away with the need for any type of nuts. Probably not as strong that way. Jim Berry RV-10 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413802#413802 ________________________________________________________________________________
Date: Nov 22, 2013
Yep, Flightline does a nice job and it is a very nice seat. Yes, the plunger is a bit of pain to remove/install. Yes, you have to half lift out the bottom cushion to get at it (not everything) But having done it about a half a dozen times over 2 years of flying, it's really not that bad. In my opinion, not worth doing the whole nutplate thing. BTW, if you put the nutplates on the plunger, you still have to lift out the cushion, so the inside rail is where you want the nutplates I would suppose. However, with the Flight line side panels, getting a bolt turned and out gets tough. Not sure there is enough clearance to get a ratchet of any normal kind on it. Without the nutplates, I put an open end wrench on the plunger side and a ratchet on the seat side and it all works pretty easily. Unlike during the build, when flying you will probably only remove the seat for 1) Condition Inspections (to get under the seat) and 2) to get in the center tunnel (for the Condition Inspection). So consider that against the amount of work you may want to do. However, what is a bigger PITA, especially in a carpeted interior, is having to remove the flap actuator/horn covers in order to remove the seats. Recently, just after my condition inspection, I had to get back in the center tunnel and that required removing the seats again. Having to remove the rear seats, lift the carpet, unscrew the two covers and otherwise trash the interior just to remove the two seats IS a PITA. And this time I didn't even mind the plunger removal/install. The two different fixes for that has been posted and documented; 1) grind away a fraction of the seat rail or 2) cut back the Delrin/Nylon seat slides in the seat. Number 2 is what I did and it is definitely the way to go. I removed exactly 3/8" and beveled the cut at 45deg in the obvious direction. Works perfectly. Now I can remove the seat by just removing the plungers and sliding the seat out. Definitely do the seat slide/rail cutting, especially if you have a carpeted floor. I wll continue on without nutplates. Bill "done with the seats for awhile" Watson On 11/22/2013 1:05 PM, woxofswa wrote: > > I just got my interior kit from Abby at Flightline and I am quite pleased. > > In attaching the seat bottom cushion it dawned on me that it will be a PITA to attach the seat retainer plunger. Unless I'm missing something, you have undo everything to put the nuts on the inside of the frame. The only solution I've come up with is to put nut plates on the inside of the frame right below the "do not alter or modify" sticker. Any ideas? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413796#413796 > > ________________________________________________________________________________
Date: Nov 22, 2013
I don't know if Geoff Combs has advertised it yet, but he has come up with a very nice lever extension to the front of the seat that gives easier access and more leverage. On 11/22/2013 12:27 PM, Rene Felker wrote: > > I have a removable seat cushion and nut plates on the plunger. Works great. > I also have the IFLYRV10 seat slide lever. Works great. www.iflyrv10.com > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry > Sent: Friday, November 22, 2013 11:47 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Seat question > > > Myron, > > Mount the seat plunger before installing the bottom cushion. I did install > nutplates and they work great. Some have also threaded the side rail, doing > away with the need for any type of nuts. Probably not as strong that way. > > Jim Berry > RV-10 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413802#413802 > > ________________________________________________________________________________
Date: Nov 22, 2013
Yep....... http://aerosportproducts.com/seat lever.htm Sent from my iPhone On Nov 22, 2013, at 3:54 PM, Kelly McMullen wrote: I don't know if Geoff Combs has advertised it yet, but he has come up with a very nice lever extension to the front of the seat that gives easier access and more leverage. > On 11/22/2013 12:27 PM, Rene Felker wrote: > > I have a removable seat cushion and nut plates on the plunger. Works great. > I also have the IFLYRV10 seat slide lever. Works great. www.iflyrv10.com > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry > Sent: Friday, November 22, 2013 11:47 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Seat question > > > Myron, > > Mount the seat plunger before installing the bottom cushion. I did install > nutplates and they work great. Some have also threaded the side rail, doing > away with the need for any type of nuts. Probably not as strong that way. > > Jim Berry > RV-10 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413802#413802 ________________________________________________________________________________
Date: Nov 22, 2013
Slight edit, it should be: http://aerosportproducts.com/seatlever.htm -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Friday, November 22, 2013 4:10 PM Subject: Re: RV10-List: Re: Seat question Yep....... http://aerosportproducts.com/seat lever.htm Sent from my iPhone On Nov 22, 2013, at 3:54 PM, Kelly McMullen wrote: I don't know if Geoff Combs has advertised it yet, but he has come up with a very nice lever extension to the front of the seat that gives easier access and more leverage. > On 11/22/2013 12:27 PM, Rene Felker wrote: > > I have a removable seat cushion and nut plates on the plunger. Works great. > I also have the IFLYRV10 seat slide lever. Works great. > www.iflyrv10.com > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry > Sent: Friday, November 22, 2013 11:47 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Seat question > > > Myron, > > Mount the seat plunger before installing the bottom cushion. I did > install nutplates and they work great. Some have also threaded the > side rail, doing away with the need for any type of nuts. Probably not as strong that way. > > Jim Berry > RV-10 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413802#413802 ________________________________________________________________________________
Subject: Wheel grease seal part number
Date: Nov 22, 2013
When changing my main tires I ran into a problem with a part on the wheel. On page 46-3 of my plans ,and on the outboard side of the wheel I had an issue with what the plans call "molded grease seal". The original is a narrow channel ring of aluminum. When I ordered what appeared to be the new part from Cleveland I received a rubberized part that has the same outer diameter, but the inner diameter is different. My wheels were part of a kit shipped in '08 so perhaps this has been a change since built, but it just doesn't seem right. Hopefully I have been able to attach a picture with the original on the left (before I dropped it and stepped on it, then tried to straighten it) and the new one on the right. Can anyone either confirm that the new seal is now the correct part, and if so any idea where to get the felt ring to go with it? Or, if it is not the right part, has anyone found the correct part number for Cleveland or aircraft spruce so I can order the correct part? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413834#413834 Attachments: http://forums.matronics.com//files/grease_ring_946.jpg ________________________________________________________________________________
Date: Nov 23, 2013
Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413859#413859 ________________________________________________________________________________
Date: Nov 23, 2013
The seats can also be mounted from the front if you just unbolt the stick and lay it out of the way. On 11/23/2013 6:54 AM, woxofswa wrote: > > Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > ________________________________________________________________________________
Date: Nov 23, 2013
Great idea Kelly except I ran my wire harness through the stick to a connection bus ... Under the seat pan. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413861#413861 ________________________________________________________________________________
Date: Nov 23, 2013
Take a look at this VAF forum link - it explains the track mod: http://www.vansairforce.com/community/showthread.php?t=57756&highlight=seat+rail+mod John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413862#413862 ________________________________________________________________________________
Date: Nov 23, 2013
You don't have to take stick off, just take bolt out and lay it on the floor. Hopefully you left some slack in the wiring. On 11/23/2013 7:20 AM, woxofswa wrote: > > Great idea Kelly except I ran my wire harness through the stick to a connection bus ... Under the seat pan. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413861#413861 > > ________________________________________________________________________________
Date: Nov 23, 2013
The forward part of the Delrin/Nylon guide to clear the rail. The metal part of the guide that the Nylon mounts in is not touched so externally there is no visible change. (You'll see when you take a close look at the seat hardware while installing/removing a seat that trimming the rear part of the Nylon guide would have no effect). It requires removing several bolts so the Nylon guides can be slipped out, shortened by 3/8" (I don't think any bevel is required though I did bevel mine) and reinstalled. A painless and easy bit of work that can be done now or later. I think the first people that tried to address this situation trimmed rear part of the rail itself. It's the most obvious approach. This requires some metal grinding. Though the results are mostly hidden, it looks a bit raw if not finished and requires more work. It's not obvious that trimming the Nylon guide would work but it does. Others have some pics posted elsewhere on both approaches but I can't find them easily. I wish I had photographed my work. Bill Watson On 11/23/2013 8:54 AM, woxofswa wrote: > > Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > ________________________________________________________________________________
Date: Nov 23, 2013
Yes. There is absolutely no reason to trim the rear seat rail. As others have done, I removed the insert guides and took 3/8" off the forward ends, beveled the tips and re-installed. I also swapped my seat rails and seat's so that the T handles are now next to the tunnel. Makes it a lot easier to adjust the seats in this location. Finally, I removed the seat rail rear stops and drilled though the seat pedestals and installed nut-plates and replaced the AN4 bolts with longer ones. I can now remove my seats very easily by removing 2 easily accessible bolts holding the stop and sliding the seats aft, and off the rails. No fooling around and no need to unbolt the T handle to get the seats off any longer. ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Saturday, November 23, 2013 9:29:00 AM Subject: Re: RV10-List: Re: Seat question The forward part of the Delrin/Nylon guide to clear the rail. The metal part of the guide that the Nylon mounts in is not touched so externally there is no visible change. (You'll see when you take a close look at the seat hardware while installing/removing a seat that trimming the rear part of the Nylon guide would have no effect). It requires removing several bolts so the Nylon guides can be slipped out, shortened by 3/8" (I don't think any bevel is required though I did bevel mine) and reinstalled. A painless and easy bit of work that can be done now or later. I think the first people that tried to address this situation trimmed rear part of the rail itself. It's the most obvious approach. This requires some metal grinding. Though the results are mostly hidden, it looks a bit raw if not finished and requires more work. It's not obvious that trimming the Nylon guide would work but it does. Others have some pics posted elsewhere on both approaches but I can't find them easily. I wish I had photographed my work. Bill Watson On 11/23/2013 8:54 AM, woxofswa wrote: > > Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 23, 2013
If I understand correctly, that negates the need to anything with the T-handles. (I have to keep them outboard due to an center console/O2 tank). I took a half hearted look at how the rear seat stops worked but couldn't figure it out. I'll have to take another look. Thanks! Bill On 11/23/2013 9:59 AM, davidsoutpost(at)comcast.net wrote: > Yes. There is absolutely no reason to trim the rear seat rail. As > others have done, I removed the insert guides and took 3/8" off the > forward ends, beveled the tips and re-installed. I also swapped my > seat rails and seat's so that the T handles are now next to the > tunnel. Makes it a lot easier to adjust the seats in this location. > Finally, I removed the seat rail rear stops and drilled though the > seat pedestals and installed nut-plates and replaced the AN4 bolts > with longer ones. I can now remove my seats very easily by removing 2 > easily accessible bolts holding the stop and sliding the seats aft, > and off the rails. No fooling around and no need to unbolt the T > handle to get the seats off any longer. > > ------------------------------------------------------------------------ > *From: *"Bill Watson" <Mauledriver(at)nc.rr.com> > *To: *rv10-list(at)matronics.com > *Sent: *Saturday, November 23, 2013 9:29:00 AM > *Subject: *Re: RV10-List: Re: Seat question > > > The forward part of the Delrin/Nylon guide to clear the rail. The metal > part of the guide that the Nylon mounts in is not touched so externally > there is no visible change. (You'll see when you take a close look at > the seat hardware while installing/removing a seat that trimming the > rear part of the Nylon guide would have no effect). > > It requires removing several bolts so the Nylon guides can be slipped > out, shortened by 3/8" (I don't think any bevel is required though I did > bevel mine) and reinstalled. A painless and easy bit of work that can > be done now or later. > > I think the first people that tried to address this situation trimmed > rear part of the rail itself. It's the most obvious approach. This > requires some metal grinding. Though the results are mostly hidden, it > looks a bit raw if not finished and requires more work. It's not > obvious that trimming the Nylon guide would work but it does. > > Others have some pics posted elsewhere on both approaches but I can't > find them easily. I wish I had photographed my work. > > Bill Watson > On 11/23/2013 8:54 AM, woxofswa wrote: > > > > Thanks for the responses. I think I'm going to go with the nut > plates on the inside. I am intrigued by the rail guide trimming idea > to clear the footwell cover. Are you trimming the forward part to > clear the rail or trimming the aft to clear the cover? > > > > -------- > > Myron Nelson > > Mesa, AZ > > Emp completed, QB wings completed, legacy build fuse on gear. FWF > complete. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > > > > > > > > > > > > > > > > > > ><-= (And Get Some AWESOME FREE Gifts!)<============= > > > * > > * ________________________________________________________________________________
Date: Nov 23, 2013
That's right Bill. No need to remove the T handles to remove the seat doing it this way. ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Saturday, November 23, 2013 11:54:53 AM Subject: Re: RV10-List: Re: Seat question If I understand correctly, that negates the need to anything with the T-handles. (I have to keep them outboard due to an center console/O2 tank). I took a half hearted look at how the rear seat stops worked but couldn't figure it out. I'll have to take another look. Thanks! Bill On 11/23/2013 9:59 AM, davidsoutpost(at)comcast.net wrote: Yes. There is absolutely no reason to trim the rear seat rail. As others have done, I removed the insert guides and took 3/8" off the forward ends, beveled the tips and re-installed. I also swapped my seat rails and seat's so that the T handles are now next to the tunnel. Makes it a lot easier to adjust the seats in this location. Finally, I removed the seat rail rear stops and drilled though the seat pedestals and installed nut-plates and replaced the AN4 bolts with longer ones. I can now remove my seats very easily by removing 2 easily accessible bolts holding the stop and sliding the seats aft, and off the rails. No fooling around and no need to unbolt the T handle to get the seats off any longer. ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Saturday, November 23, 2013 9:29:00 AM Subject: Re: RV10-List: Re: Seat question The forward part of the Delrin/Nylon guide to clear the rail. The metal part of the guide that the Nylon mounts in is not touched so externally there is no visible change. (You'll see when you take a close look at the seat hardware while installing/removing a seat that trimming the rear part of the Nylon guide would have no effect). It requires removing several bolts so the Nylon guides can be slipped out, shortened by 3/8" (I don't think any bevel is required though I did bevel mine) and reinstalled. A painless and easy bit of work that can be done now or later. I think the first people that tried to address this situation trimmed rear part of the rail itself. It's the most obvious approach. This requires some metal grinding. Though the results are mostly hidden, it looks a bit raw if not finished and requires more work. It's not obvious that trimming the Nylon guide would work but it does. Others have some pics posted elsewhere on both approaches but I can't find them easily. I wish I had photographed my work. Bill Watson On 11/23/2013 8:54 AM, woxofswa wrote: > > Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > > > > > > > > ><-= (And Get Some AWESOME FREE Gifts!)<============== ________________________________________________________________________________
Date: Nov 23, 2013
I believe I beveled the delrin without even removing it from the seat structure. Took all of five minutes. David Maib 40559 700 hours On Nov 23, 2013, at 9:29 AM, Bill Watson wrote: The forward part of the Delrin/Nylon guide to clear the rail. The metal part of the guide that the Nylon mounts in is not touched so externally there is no visible change. (You'll see when you take a close look at the seat hardware while installing/removing a seat that trimming the rear part of the Nylon guide would have no effect). It requires removing several bolts so the Nylon guides can be slipped out, shortened by 3/8" (I don't think any bevel is required though I did bevel mine) and reinstalled. A painless and easy bit of work that can be done now or later. I think the first people that tried to address this situation trimmed rear part of the rail itself. It's the most obvious approach. This requires some metal grinding. Though the results are mostly hidden, it looks a bit raw if not finished and requires more work. It's not obvious that trimming the Nylon guide would work but it does. Others have some pics posted elsewhere on both approaches but I can't find them easily. I wish I had photographed my work. Bill Watson On 11/23/2013 8:54 AM, woxofswa wrote: > > Thanks for the responses. I think I'm going to go with the nut plates on the inside. I am intrigued by the rail guide trimming idea to clear the footwell cover. Are you trimming the forward part to clear the rail or trimming the aft to clear the cover? > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413859#413859 > > > > > > > > > > > David Maib dmaib(at)me.com ________________________________________________________________________________
Date: Nov 23, 2013
schmoboy wrote: > I "altered or modified" for the same reasons you mentioned. :) > > See here - http://www.flickr.com/photos/stephensville/9684701079/ > > Bingo! This is exactly what I had in mind to avoid removal of the seat cushion. I was concerned about modifying the seat rail and also about access for the bolt. Are you happy on both accounts? -------- David Halmos RV-10 Electrical/avionics Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413905#413905 ________________________________________________________________________________
Subject: seat
Date: Nov 24, 2013
I have not yet installed my seats, and am confused about the seat plunger issue. Why is it necessary to remove the plunger from the seat to remove the seat from the rails? If it=99s because you can=99t get your hand down between the seat and side of the fuselage while sliding the seat aft, will the extention handle mod allow you to remove the seat without removing the plunger? Chris Hukill waiting for engine to arrive ________________________________________________________________________________
Subject: Re: seat
Date: Nov 24, 2013
There are two large nuts that the plunger will hit and prevent the seat from sliding off the rails. Sent from my iPad > On Nov 24, 2013, at 9:01 AM, "Chris Hukill" wrote: > > I have not yet installed my seats, and am confused about the seat plunger i ssue. Why is it necessary to remove the plunger from the seat to remove the s eat from the rails? If it=99s because you can=99t get your hand d own between the seat and side of the fuselage while sliding the seat aft, wi ll the extention handle mod allow you to remove the seat without removing th e plunger? > Chris Hukill > waiting for engine to arrive > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Subject: seat
Date: Nov 24, 2013
Nope, there is a stop on the rail that cannot be removed (without mod). The plunger cannot get past the stop and thus needs to be removed for the seat to slide off the back of the rails. I have looked at ways of making the stop removable (like others have done), but looks like too much work on completed airframe. You would not want to remove the stop permanently for safety reasonsi.e. the Cessna seat rail issue and mod. You would not want the pilot sliding into the back seat on rotation..if the plunger go stuck in the up position. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Sunday, November 24, 2013 7:01 AM Subject: RV10-List: seat I have not yet installed my seats, and am confused about the seat plunger issue. Why is it necessary to remove the plunger from the seat to remove the seat from the rails? If it=99s because you can=99t get your hand down between the seat and side of the fuselage while sliding the seat aft, will the extention handle mod allow you to remove the seat without removing the plunger? Chris Hukill waiting for engine to arrive ________________________________________________________________________________
Date: Nov 24, 2013
Happy so far with the 50 or so times I've had the seats on and off. :) Oh, and I switched the two seats and rails so the t-handle is on the inside next to the tunnel. As I have no center console there, it is easier to get to the bolts. Even if you use bolts with nutplates, it is still a tight fit between the seat and the fuse side. On 11/23/13, 10:58 PM, dhmoose wrote: > > > schmoboy wrote: >> I "altered or modified" for the same reasons you mentioned. :) >> >> See here - http://www.flickr.com/photos/stephensville/9684701079/ >> >> > > Bingo! This is exactly what I had in mind to avoid removal of the seat cushion. I was concerned about modifying the seat rail and also about access for the bolt. Are you happy on both accounts? > > -------- > David Halmos > RV-10 > Electrical/avionics > Portland, OR > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413905#413905 > > ________________________________________________________________________________
Date: Nov 24, 2013
The track mod was a great idea and worked slick. Somehow, I hadn't heard about that one before. The other mod for the AFT stop of the seat rail didn't make sense to me at first reading, but now makes perfect sense and I will be doing that one as well. If I may be so cheeky as to restate that one so a dummy like me can grasp it. The rear stop on the notched seat rail is held in place by two bolts/nuts integral to the rail piece itself. If you remove those bolts, drill down through the underlying seat pedestal cover, and add nutplates to the bottom, by using longer bolts that now reach down to the nutplate, you can remove the rear stop by with a simple socket on an extension to the bolt heads that are now upright and accessible. With the rear stop removed, you can slide the seat out without removing the T-handle apparatus at all. Easy on/easy off. This one thread has made the annual dues worthwhile for me. Thanks fellers. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413956#413956 ________________________________________________________________________________
Subject: Re: seat
Date: Nov 24, 2013
I posted an explanation on the other thread before reading this thread. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=413957#413957 ________________________________________________________________________________
Date: Nov 25, 2013
Subject: [PLEASE READ] Why I Have A Fund Raiser...
>From the beginning, the Matronics List and Forum experience has been free from advertising. I have been approached by fair number of vendors wanting to tap into the large volume of activity across the various lists hosted here, but have always flatly refused. Everywhere you go on the Internet these days, a user is pummeled with flashing banners and videos and ads for crap that they don't want. Yahoo, Google and that elk are not "free". The user must constantly endure their barrage of commercialism thrust into their face at an ever increasing rate. Enough is enough, and the Lists at Matronics choose not to succumb to that. That being said, running a service of this size is not "free". It costs a lot of money to maintain the hardware, pay for the electricity, air conditioning, maintenance contracts, etc, etc. etc. I choose to hold a PBS-like fund raiser each year during the month of November where I simply send out a short email every other day asking the members to make a small contribution to support the operation. That being said, that contribution is completely voluntary and non-compulsory. Many members choose not to contribute and that's fine. However, a very modest percentage of the members do choose to make a contribution and it is that financial support that keeps the Lists running. And that's it. To my way of thinking, it is a much more pleasant way of maintaining the Lists and Forums. The other 11 months of the year, you don't see a single advertisement or request for support. That's refreshing and that is a List and Forum that I want to belong to. I think other people feel the same way. Won't you please take a minute to make your Contribution today and support these Lists? http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Email List Admin. ________________________________________________________________________________
Date: Nov 25, 2013
That helps. Now I think I get it but it sounds like something much more easily done during the build than post-build, correct? At least if nutplates are involved. But tapping the new hole in seat pedestal could work as well? Bill "Dues? I thought it was a tribute" Watson On 11/24/2013 10:00 PM, woxofswa wrote: > If I may be so cheeky as to restate that one so a dummy like me can grasp it. The rear stop on the notched seat rail is held in place by two bolts/nuts integral to the rail piece itself. If you remove those bolts, drill down through the underlying seat pedestal cover, and add nutplates to the bottom, by using longer bolts that now reach down to the nutplate, you can remove the rear stop by with a simple socket on an extension to the bolt heads that are now upright and accessible. With the rear stop removed, you can slide the seat out without removing the T-handle apparatus at all. Easy on/easy off. > > This one thread has made the annual dues worthwhile for me. Thanks fellers. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413956#413956 > > ________________________________________________________________________________
Date: Nov 25, 2013
It's not a big job at all. It took me about 45 minutes to do both seats. Remove your seat. Now remove the pedestal cover Unscrew the seat rail with the rear seat stop Remove the stop Use a few screws for location and screw the rail back on Using the empty seat stop mounting holes as guides, drill 1/4" holes through the pedestal Remove rail again and install 1/4" nut plates with flush rivets Modify delrin glide inserts and re-assemble ----- Original Message ----- From: "Bill Watson" <Mauledriver(at)nc.rr.com> Sent: Monday, November 25, 2013 9:37:52 AM Subject: Re: RV10-List: Re: Seat question That helps. Now I think I get it but it sounds like something much more easily done during the build than post-build, correct? At least if nutplates are involved. But tapping the new hole in seat pedestal could work as well? Bill "Dues? I thought it was a tribute" Watson On 11/24/2013 10:00 PM, woxofswa wrote: > If I may be so cheeky as to restate that one so a dummy like me can grasp it. The rear stop on the notched seat rail is held in place by two bolts/nuts integral to the rail piece itself. If you remove those bolts, drill down through the underlying seat pedestal cover, and add nutplates to the bottom, by using longer bolts that now reach down to the nutplate, you can remove the rear stop by with a simple socket on an extension to the bolt heads that are now upright and accessible. With the rear stop removed, you can slide the seat out without removing the T-handle apparatus at all. Easy on/easy off. > > This one thread has made the annual dues worthwhile for me. Thanks fellers. > > -------- > Myron Nelson > Mesa, AZ > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=413956#413956 > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 25, 2013
Much appreciated! Will do at next seat removal... I just did the Delrin mod but I'll have to wait for the next removal for the stop. I like it, a lot. Bill On 11/25/2013 10:06 AM, davidsoutpost(at)comcast.net wrote: > It's not a big job at all. It took me about 45 minutes to do both seats. > Remove your seat. > Now remove the pedestal cover > Unscrew the seat rail with the rear seat stop > Remove the stop > Use a few screws for location and screw the rail back on > Using the empty seat stop mounting holes as guides, drill 1/4" holes > through the pedestal > Remove rail again and install 1/4" nut plates with flush rivets > Modify delrin glide inserts and re-assemble > > > ------------------------------------------------------------------------ > *From: *"Bill Watson" <Mauledriver(at)nc.rr.com> > *To: *rv10-list(at)matronics.com > *Sent: *Monday, November 25, 2013 9:37:52 AM > *Subject: *Re: RV10-List: Re: Seat question > > > That helps. Now I think I get it but it sounds like something much more > easily done during the build than post-build, correct? At least if > nutplates are involved. But tapping the new hole in seat pedestal could > work as well? > > Bill "Dues? I thought it was a tribute" Watson > > On 11/24/2013 10:00 PM, woxofswa wrote: > > If I may be so cheeky as to restate that one so a dummy like me can > grasp it. The rear stop on the notched seat rail is held in place by > two bolts/nuts integral to the rail piece itself. If you remove those > bolts, drill down through the underlying seat pedestal cover, and add > nutplates to the bottom, by using longer bolts that now reach down to > the nutplate, you can remove the rear stop by with a simple socket on > an extension to the bolt heads that are now upright and accessible. > With the rear stop removed, you can slide the seat out without > removing the T-handle apparatus at all. Easy on/easy off. > > > > This one thread has made the annual dues worthwhile for me. Thanks > fellers. > > > > -------- > > Myron Nelson > > Mesa, AZ > > Emp completed, QB wings completed, legacy build fuse on gear. FWF > complete. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=413956#413956 > > > > > > > > > > > > > > > > > > > > > > > * > > * ________________________________________________________________________________
Date: Nov 25, 2013
Excellent tips, thanks to all. I was just at this point in the build and have spent the evening fitting up the seat rails and looking at whether to put the plunger inboard or outboard. It struck me that there is very little clearance (max 40thou) between the plunger and tunnel cover in the inboard position - not enough for any carpet to fit in the gap. Has anyone else experienced this? Incidentally I had already fitted my T-handles with a cheap and cheerful extension by using a loop of bowden cable inner (bicycle brake cable) through the roll pin, fastened with some heat shrink. Cost about 1USD and took 15 minutes for both sides. Gordon Anderson 41015 Switzerland On Nov 25, 2013, at 4:06 PM, davidsoutpost(at)comcast.net wrote: > It's not a big job at all. It took me about 45 minutes to do both seats. > Remove your seat. > Now remove the pedestal cover > Unscrew the seat rail with the rear seat stop > Remove the stop > Use a few screws for location and screw the rail back on > Using the empty seat stop mounting holes as guides, drill 1/4" holes through the pedestal > Remove rail again and install 1/4" nut plates with flush rivets > Modify delrin glide inserts and re-assemble > > > From: "Bill Watson" <Mauledriver(at)nc.rr.com> > To: rv10-list(at)matronics.com > Sent: Monday, November 25, 2013 9:37:52 AM > Subject: Re: RV10-List: Re: Seat question > > > That helps. Now I think I get it but it sounds like something much more > easily done during the build than post-build, correct? At least if > nutplates are involved. But tapping the new hole in seat pedestal could > work as well? > > Bill "Dues? I thought it was a tribute" Watson > > On 11/24/2013 10:00 PM, woxofswa wrote: > > If I may be so cheeky as to restate that one so a dummy like me can grasp it. The rear stop on the notched seat rail is held in place by two bolts/nuts integral to the rail piece itself. If you remove those bolts, drill down through the underlying seat pedestal cover, and add nutplates to the bottom, by using longer bolts that now reach down to the nutplate, you can remove the rear stop by with a simple socket on an extension to the bolt heads that are now upright and accessible. With the rear stop removed, you can slide the seat out without removing the T-handle apparatus at all. Easy on/easy off. > > > > This one thread has made the annual dues worthwhile for me. Thanks fellers. > > > > -------- > > Myron Nelson > > Mesa, AZ > > Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=413956#413956 > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 26, 2013
Subject: Of Pencils & Airplanes [Repost From AeroElectric-List]...
[Dear Listers, last week, Bob Nuckolls of the AeroElectric fame, posted a very nice message discussing the Lists and Forums at Matronics. It is a very insightful piece and I asked Bob if I could forward it to the rest of the Lists for the other members to enjoy and contemplate as well. He gladly agreed, and so below I have included the text from that message. Enjoy. -Matt Dralle, Matronics Email List and Forum Administrator] "As most of you know, Matt's ISP was fiddling with some crucial details for the exchange of data on the 'net a few weeks ago. The Lists, Matt's business site, and AeroElectric.com got really flakey. . . I was 'unhooked' from the List and all of three of my e-mail services for several days. Out of business and out of touch. After two days, I was beginning to worry. I had no idea as to root cause nor was there a time table for resolution . . . I began to mull over plan-B options. Of course, plan-B would have entailed seeking a new home for aeroelectric.com and ancillary services. NOT a quick, inexpensive or happy thing to contemplate. The time talents and resources that go into fabrication and maintenance of some of the 'simplest' features of our lives often go unnoticed . . . not because they're unappreciated . . . but simply because we're unaware of their significance. I will invite you all to read an essay by one Leonard Read written in 1958 titled "I pencil". See: http://tinyurl.com/me3q3hj It's a fascinating and well crafted peek into a society of unacquainted, self-interested individuals who exploited uncountable windows of opportunity for what has been called "spontaneous order" in the manufacture and sales of the simple wood pencil. The point of citing Mr. Read's essay is to examine two features of the human experience that contribute to the success of this List and our various interests in airplanes. The first point I'd like to make is that we cannot know the millions of individuals who contributed to the materials and infrastructure that make this List possible. We sit at the top of a pyramid of work-product derived from the time, talents and resources of millions of people who we'll never know. Another feature I'd like to emphasis is our ignorance of the criticality for any single component for a host of materials and components for the manufacture and sales of a simple pencil or an affordable airplane. Suppose any one of the materials or processes described in Read's essay were simply unavailable. How would that impact the price of a pencil? Would the pencil even continue to exist at it's new price? The really big question is, "How might some seemingly small loss ripple throughout the economy of our existence?" The time, talent and resources that support infrastructure for this List, my website, Matt's website, and our e-mails cannot be accurately known. That infrastructure stands on an exceedingly complex array of activities that arose from the ingenuity and spontaneous organization of free- market enterprises. But from our perch at the top of this pyramid we need only look down a few layers and see that this resource upon which we depend is vulnerable. There are risks we all assume . . . Matt could get t-boned in an intersection tomorrow. Lightning could strike the pole behind his facility and do catastrophic damage to the hardware. Yours truly could take a deer through the windshield on his way to Wichita some morning. Other risks are less catastrophic. They include things like amateurish behaviors by maintainers of the Internet highway's potholes. Perhaps some material critical to the manufacture of terabyte hard drives dries up. Or maybe the cost of keeping the lights on and the bytes herded become more than Matt can justify given his personal needs for existence. Several times a year I get an opportunity to plant new seeds of thought in the minds of fellow citizens. One of my favorites is to be standing in a long line at Panera's waiting to purchase a bagel and coffee and hear somebody in line complaining about the wait. I suggest to them that to wait in line for a much desired product is a GOOD thing. Not having to wait is a BAD thing if there is not enough business to encourage them to be open tomorrow. It goes without saying that few, if any of us, possess the talents, resources or motivation to step up and do what Matt does. At last count, there were about 1600 individuals who subscribe to this List [Aeroelectric-List]. . . certainly many more make up the population of subscribers to all of the Lists on Matronics. A few years back, Matt was besieged by legal trials and tribulations over the naming of his products . . . seems somebody claimed ownership of the words 'scan' and/or 'scanner' . . . We here on the AeroElectric-List perceived a risk to Matt's operations and came up with several thousands of dollars to contribute to his defense fund. We need make no greater 'investment' in Matt's operations now than it takes to stand in a line for a Quarter-Pounder Combo . . . or a fist full of pencils. You and I can have no more positive influence over the manufacture of pencils and hard drives than to continue to purchase such things and encourage those with the time, talent and resources to continue doing what they do best. Let's contribute to the comfortable maintenance of this service which is probably more valuable than we know. Just a little bit from thousands of us on the Matronics Lists can make a big difference. Bob . . ." Please take a minute to make your Contribution today: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 USA Thank you for your support! Matt Dralle Matronics Email List and Forum Administrator ________________________________________________________________________________
Date: Nov 26, 2013
> It struck me that there is very little clearance (max 40thou) between the plunger and tunnel cover in the inboard position - not enough for any carpet to fit in the gap. Has anyone else experienced this? It works fine with carpeting on the tunnel. It's snug but I like it better than outboard. I switched from outside to tunnel side and have not regretted it. John[/quote] -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414181#414181 ________________________________________________________________________________
Date: Nov 26, 2013
Though I didn't set the T-handle up on the tunnel side, it's pretty clear that it will work with carpet (I have a Flightline interior). It also works on the outboard side even with Flightline's sidepanels in place. I'm thinking that if many of my flights were with 'strangers' I would prefer the tunnel. For a plane flown 100% by the pilot/builder and his wife 99% of the time, the outboard side works fine because one quickly gets the feel for operating it easily. You can clearly take your choice. And you can change your choice later by swapping seat rails. One other consideration is if one plans to put in a center console. I put one in after my plane was flying that holds an O2 tank and iPad mount: http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=8533 It was designed to have a minimal cross section and I think you can see that even with a thin console, you still have the choice of having the T-handle on either side (I still have it outboard). This is a great thread on a topic that doesn't impact the planes performance, has a little impact on seat operation, and has a not insignificant impact on maintenance. FWIW, I've concluded that: * Assembling the seats per Van's direction works just fine, as one would expect. However improvements can be made. * The T-handle can be installed on the tunnel side or outboard side without a problem. * The seat rail should be modified by trimming back the Nylon/Delrin seat slides 3/8" on the forward ends of the slides to enable seat removal without removal of the flap actuator covers. * The seat stops bolts should be made removable to enable seat removal without removal of the T-handles (I haven't done this yet but will be) I love this list. Thanks! Bill On 11/26/2013 8:43 AM, johngoodman wrote: > > >> It struck me that there is very little clearance (max 40thou) between the plunger and tunnel cover in the inboard position - not enough for any carpet to fit in the gap. Has anyone else experienced this? > > It works fine with carpeting on the tunnel. It's snug but I like it better than outboard. I switched from outside to tunnel side and have not regretted it. > John[/quote] > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414181#414181 > > ________________________________________________________________________________
Date: Nov 27, 2013
Subject: Make Sure You're Listed! List of Contributors Coming Soon!
Dear Listers, There's just a few more days left in this year's List Fund Raiser and that means the List of Contributors (LOC) is just around the corner! In December I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 29, 2013
Subject: Just Two Days Left...
Dear Listers, There are just a couple days left for this year's List Fund Raiser. If you've been putting off making a Contribution until the last minute, well, this is it! The last minute, that is... :-) There are some GREAT new gift selections to choose from this year. I personally want at least four of them! There's probably something you can't live without too! And, best of all it supports your Lists! Please remember that there isn't any sort of commercial advertising on the Lists and the *only* means of keeping these Lists running is through your Contributions during this Fund Raiser. Let's make this a "Black Friday" for the Lists! Please make a Contribution today! http://www.matronics.com/contribution Or, drop a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Switches
Date: Nov 29, 2013
Gents I am using toggle switches for non-lights (e.g. Fuel pump, Pitot heat, Aux Battery, etc.) and both for aesthetical reasons and non-confusing reasons, I am planning to use rocker illuminated switches for the Lights (Landing Light, Taxi Light, Strobes, Beacon, NAV Lights, Cabin Light). I am not finding a source for good rocker switches, like for example the ones from Klixon or other good brand. Neither ACS or Stein Air seems to carry those. Can someone please point me to a source for good rocker illuminated switches? Regards Carlos ________________________________________________________________________________
Subject: Re: Switches
Date: Nov 29, 2013
I have the rocker switches from Aerosport Products. Sent from my iPhone On Nov 29, 2013, at 12:19 PM, "Carlos Trigo" wrote: Gents I am using toggle switches for non-lights (e.g. Fuel pump, Pitot heat, Aux B attery, etc.) and both for aesthetical reasons and non-confusing reasons, I a m planning to use rocker illuminated switches for the Lights (Landing Light, Taxi Light, Strobes, Beacon, NAV Lights, Cabin Light). I am not finding a source for good rocker switches, like for example the one s from Klixon or other good brand. Neither ACS or Stein Air seems to carry t hose. Can someone please point me to a source for good rocker illuminated switches ? Regards Carlos D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Subject: Switches
Date: Nov 29, 2013
Me too (also??) They are good switches From: rv(at)thelefflers.com Subject: Re: RV10-List: Switches Date: Fri=2C 29 Nov 2013 12:45:21 -0500 I have the rocker switches from Aerosport Products. Sent from my iPhone On Nov 29=2C 2013=2C at 12:19 PM=2C "Carlos Trigo" wrote: Gents I am using toggle switches for non-lights (e.g. Fuel pump=2C Pitot he at=2C Aux Battery=2C etc.) and both for aesthetical reasons and non-confusi ng reasons=2C I am planning to use rocker illuminated switches for the Ligh ts (Landing Light=2C Taxi Light=2C Strobes=2C Beacon=2C NAV Lights=2C Cabin Light). I am not finding a source for good rocker switches=2C like for exa mple the ones from Klixon or other good brand. Neither ACS or Stein Air see ms to carry those. Can someone please point me to a source for good rocker illuminated switches? RegardsCarlos D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ot=3B">www.aeroelectric.com books.com"">www.buildersbooks.com quot=3B">www.homebuilthelp.com quot=3B">www.mypilotstore.com ">www.mrrace.com ot=3B">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D ________________________________________________________________________________
Date: Nov 29, 2013
Try Digikey.com Cheers Les Sent from my iPhone > On Nov 29, 2013, at 12:47 PM, Danny Riggs wrote: > > Me too (also??) > They are good switches > > From: rv(at)thelefflers.com > Subject: Re: RV10-List: Switches > Date: Fri, 29 Nov 2013 12:45:21 -0500 > To: rv10-list(at)matronics.com > > I have the rocker switches from Aerosport Products. > > Sent from my iPhone > > On Nov 29, 2013, at 12:19 PM, "Carlos Trigo" wrote : > > Gents > > > > I am using toggle switches for non-lights (e.g. Fuel pump, Pitot heat, Aux Battery, etc.) and both for aesthetical reasons and non-confusing reasons, I am planning to use rocker illuminated switches for the Lights (Landing Ligh t, Taxi Light, Strobes, Beacon, NAV Lights, Cabin Light). > > > > I am not finding a source for good rocker switches, like for example the o nes from Klixon or other good brand. Neither ACS or Stein Air seems to carry those. > > > > Can someone please point me to a source for good rocker illuminated switch es? > > > > Regards > > Carlos > > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">www.aeroelectric.com > books.com"">www.buildersbooks.com > quot;">www.homebuilthelp.com > quot;">www.mypilotstore.com > ">www.mrrace.com > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > List"">http://www.matronics.com/Navigator?RV10-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > et=_blank>www.aeroelectric.com > ks.com" target=_blank>www.buildersbooks.com > rget=_blank>www.homebuilthelp.com > rget=_blank>www.mypilotstore.com > =_blank>www.mrrace.com > rget=_blank>http://www.matronics.com/contribution > ist" target=_blank>http://www.matronics.com/Navigator?RV10-List > ank>http://forums.matronics.com > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Nov 29, 2013
Try spruce aircraft look under aevoengineering or go to aevoengineering web site also look at the wing tip lighting On Friday, November 29, 2013, Les Kearney wrote: > Try Digikey.com > > Cheers > > Les > > > Sent from my iPhone > > On Nov 29, 2013, at 12:47 PM, Danny Riggs > > wrote: > > Me too (also??) > They are good switches > > ------------------------------ > From: rv(at)thelefflers.com <javascript:_e({}, 'cvml', > 'rv(at)thelefflers.com');> > Subject: Re: RV10-List: Switches > Date: Fri, 29 Nov 2013 12:45:21 -0500 > To: rv10-list(at)matronics.com 'rv10-list(at)matronics.com');> > > I have the rocker switches from Aerosport Products. > > Sent from my iPhone > > On Nov 29, 2013, at 12:19 PM, "Carlos Trigo" > > wrote: > > Gents > > > I am using toggle switches for non-lights (e.g. Fuel pump, Pitot heat, Aux > Battery, etc.) and both for aesthetical reasons and non-confusing reasons, > I am planning to use rocker illuminated switches for the Lights (Landing > Light, Taxi Light, Strobes, Beacon, NAV Lights, Cabin Light). > > > I am not finding a source for good rocker switches, like for example the > ones from Klixon or other good brand. Neither ACS or Stein Air seems to > carry those. > > > Can someone please point me to a source for good rocker illuminated > switches? > > > Regards > > Carlos > > * > > D============================================ > ot;">www.aeroelectric.com <http://www.aeroelectric.com> > books.com <http://books.com>"">www.buildersbooks.com > quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> > quot;">www.mypilotstore.com <http://www.mypilotstore.com> > ">www.mrrace.com <http://www.mrrace.com> > ot;">http://www.matronics.com/contribution > D============================================ > List"">http://www.matronics.com/Navigator?RV10-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > * > > * > > et=_blank>www.aeroelectric.com <http://www.aeroelectric.com> > ks.com <http://ks.com>" target=_blank>www.buildersbooks.com > rget=_blank>www.homebuilthelp.com <http://www.homebuilthelp.com> > rget=_blank>www.mypilotstore.com <http://www.mypilotstore.com> > =_blank>www.mrrace.com <http://www.mrrace.com> > rget=_blank>http://www.matronics.com/contribution > ist" target=_blank>http://www.matronics.com/Navigator?RV10-List > ank>http://forums.matronics.com > * > > > * > > * > > ________________________________________________________________________________
Date: Nov 30, 2013
Subject: [Please Read] - Last Official Day of List Fund Raiser!
Dear Listers, It's November 30th and that always means a couple of things. Its my birthday again; the big 50, in fact! But it also means that it's that last official day of the Matronics Email List Fund Raiser! If you been thinking about picking up one of those really nice incentive gifts now is the time to jump on it!! If you've been meaning to make a Contribution this month but have been putting it off for some reason, NOW is the time! I will be posting the List of Contributors in a few days, so you'll probably want to be known as a person that supported the Lists! I want to thank everyone that has so generously made a Contribution this year in support of our Lists. It is your generosity that keeps this operation running and I don't ever forget it. The List Contribution Web Site is fast and easy. Please support our habit by making your Contribution right now: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 Thank you to all in advance! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Subject: Re: RV 10 Aileron Trim
Date: Dec 04, 2013
Does the Garmin GSA 28 servo replace the Ray Allen trim system that Vans sells? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414867#414867 ________________________________________________________________________________
Date: Dec 04, 2013
Not a strong opinion, but I don't have roll trim, and it's not high on my upgrade list. Maybe that's because I flew for 20 years behind a 182 that we just couldn't seem to get trimmed in roll, so I don't know any better! I do change tanks every 30 minutes to keep the imbalance to a minimum. I do not have a speed control on my "top hat" switch, it runs full speed. I do not use it at cruise; instead, I use the trim function on the Trio autopilot (this works even when the servos are disengaged) which is programable to your taste and is speed sensitive. I have it set up to make very fine adjustments at cruise speeds. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414871#414871 ________________________________________________________________________________
Date: Dec 04, 2013
Bob, no. You still need a trim servo of some sort. I'm just about to wire up my GSA 28 roll servo with the Ray Allen trim servo. It's all laid out in the G3X install manual if you want some light reading ;-) Rick #40956 Southampton, Ont On Wed, Dec 4, 2013 at 7:42 PM, bob88 wrote: > > Does the Garmin GSA 28 servo replace the Ray Allen trim system that Vans > sells? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414867#414867 > > ________________________________________________________________________________
Date: Dec 05, 2013
No, the garmin servo is for the autopilot, it can however control the trim servo for you to autotrim. It also controls the trim speed I believe. On Wed, Dec 4, 2013 at 7:42 PM, bob88 wrote: > > Does the Garmin GSA 28 servo replace the Ray Allen trim system that Vans > sells? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414867#414867 > > ________________________________________________________________________________
Date: Dec 05, 2013
> I do not have a speed control on my "top hat" switch, it runs full speed. I do not use it at cruise; instead, I use the trim function on the Trio autopilot (this works even when the servos are disengaged) which is programable to your taste and is speed sensitive. I have it set up to make very fine adjustments at cruise speeds. Bob, Tell me more about this feature in the Trio - I happen to have a Trio Pro w/autotrim and am not aware of this. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414905#414905 ________________________________________________________________________________
Date: Dec 05, 2013
I would like to know also as I have the identical setup as John. Thanks! > Subject: RV10-List: Re: RV 10 Aileron Trim > From: johngoodman(at)earthlink.net > Date: Thu=2C 5 Dec 2013 06:54:33 -0800 > To: rv10-list(at)matronics.com > > > > > > I do not have a speed control on my "top hat" switch=2C it runs full sp eed. I do not use it at cruise=3B instead=2C I use the trim function on the Trio autopilot (this works even when the servos are disengaged) which is p rogramable to your taste and is speed sensitive. I have it set up to make v ery fine adjustments at cruise speeds. > > > Bob=2C > Tell me more about this feature in the Trio - I happen to have a Trio Pro w/autotrim and am not aware of this. > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414905#414905 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Subject: RV 10 Aileron Trim easy fix...
Date: Dec 05, 2013
Easy Cheap Dependable fix. 1) Replace your "Flap Toggle Switch" with a Double Pole (on) off on switch. (Same as original but Double Pole) 2) On the 2nd pole (not controlling your flaps) install a single pole double throw "Relay". Install the relay so when your flaps are in the -3degree position (Cruse position) the relay is activated. Any other position "Off" (On) climb out or landing configuration the relay will not be energized or normally closed. 3) Split the 14v power to both legs of the relay (Line side of the relay) "Normally open and normally closed legs of the relay". 4) On the "Normally Closed" (1st leg) pin on the relay (Load side of the relay) run your 14 volt power through the closed contacts, You now have full power to your trim motor. You will need full speed trim for takeoff and landing configurations. 5) On the 2nd leg of the relay (load side) the relay hook up a 9 volt 7809t voltage regulator with a capacitor. Connect the 9 volt wire to the 14v wire on the (LOAD SIDE OF THE RELAY) that connects back to your trim motor power. Now when you are in the -3 Degree cruse position the relay is activated. You are now feeding your trim motor with 9 volts and this will slow your trim motor down enough for "Fine Feathering". 6) So when your flap switch is in the Off or (ON) position your relay will be closed and feeding 14volts to the trim motor. When your flaps are in the ON position (Normal Cruse -3 degrees) your relay is active and switches the power to 9volts for your trim motor speed reduction. Works like a dream. Costs about $20. $10 for the Double Pole On Off (ON) toggle switch $5 for the 12v/14v relay (Fog light, horn, etc relay) Checker auto $3 for the voltage regulator Radio Shack or Fry's $2 for the capacitor Radio Shack or Fry's Optional computer fan 3 wire plug to plug the voltage regulator into for easy termination $.99. Radio Shack or Fry's Jim Villani Kit# 41084 164.3 hours Flying 11 months Jim(at)JimVillani.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Thursday, December 05, 2013 7:49 AM Subject: RE: RV10-List: Re: RV 10 Aileron Trim I would like to know also as I have the identical setup as John. Thanks! > Subject: RV10-List: Re: RV 10 Aileron Trim > From: johngoodman(at)earthlink.net <mailto:johngoodman(at)earthlink.net> > Date: Thu, 5 Dec 2013 06:54:33 -0800 > To: rv10-list(at)matronics.com > > > > > > I do not have a speed control on my "top hat" switch, it runs full speed. I do not use it at cruise; instead, I use the trim function on the Trio autopilot (this works even when the servos are disengaged) which is programable to your taste and is speed sensitive. I have it set up to make very fine adjustments at cruise speeds. > > > Bob, > Tell me more about this feature in the Trio - I happen to have a Trio Pro w/autotrim and am not aware of this. > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414905#414905 > > > > > >====================== &g================= > > > <http://www.buildersbooks.com> ________________________________________________________________________________
Subject: Motivation: Testflight
Date: Dec 05, 2013
Speed calibration runs over Switzerland -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414928#414928 Attachments: http://forums.matronics.com//files/bildschirmfoto_2013_12_05_um_182939_247.png ________________________________________________________________________________
Date: Dec 05, 2013
The set up for the Trio pitch trim is described on page 60 of the Trio manual (you can download it from their web site). In the set up, for example if you put TL=18, TH=06, LAS = 60, HAS = 170; Then the trim will run at speed 18 (almost max speed) when the airspeed is 60 or less; it will run at speed 6 (slow) at speeds of 170 knots or more; and in between it is linearly extrapolated (e.g., at 115 knots it runs at speed 12). IF YOU SET the speed to less than 4 the trim function is turned off. To access the manual function, just boot up the autopilot, set the altitude as normal, then push the right hand (vertical) function button. The display should say "manual trim". (If it doesn't, cycle thru the vertical functions by pushing the V button). Turn the rotary knob clockwise to trim up, counterclockwise to go down. Note: if you have multiple trim control switches (like the top hat plus the autopilot) then you need an isolation system (either a hard switch or relays) which allows the autopilot trim signal to go "straight thru". It uses pulse width modulation which is too high a frequency for a relay to follow. I built my own relay board using Digikey parts. Personally I love this system, I don't know why Trio doesn't advertise it more. I have never been able to smoothly trim in cruise with the top hat, just because of the force I put on the stick when trying to use the top hat. I have my autopilot near the top of the stack, but easily reached with my right hand. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414931#414931 ________________________________________________________________________________
Subject: Re: RV 10 Aileron Trim easy fix...
Date: Dec 05, 2013
A few thoughts. I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414938#414938 ________________________________________________________________________________
Date: Dec 05, 2013
You dont have a separate "Cut off switch" for flap motor? Put it in the Minus 3 position then turn it to off (center position) still works at full speed... It is On "top position" Off "Middle position" (On) "bottom position." It stalled because you didnt use a capacitor... And if the Pulse Modulator fails?.. I like the KISS plan... Keep it simple... Jim Villani Cell: (702) 379 5524 Fax: (702) 946-1185 Email: Jim(at)Sold702.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Thursday, December 05, 2013 11:23 AM Subject: RV10-List: Re: RV 10 Aileron Trim easy fix... A few thoughts. I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414938#414938 ________________________________________________________________________________
Date: Dec 06, 2013
October 24, 2013 - December 06, 2013
RV10-Archive.digest.vol-jo
