RV10-Archive.digest.vol-jp
December 06, 2013 - February 03, 2014
      Since I'm not there yet, is the flap speed really a 'problem' worth all
      this trouble? Is the flap position 'critical' for safe operation?
      Linn
      On 12/5/2013 2:23 PM, Bob Turner wrote:
      > A few thoughts.
      > I like to cruise with the flap switch in the off position, but your set up requires
      one to leave it in the up position. If the flap limit switch fails the
      flap motor will run continuously.
      > If one desires to take off with no flaps (-3 reflex) he has to put the switch
      in the off position - opposite of cruise. My point is, there are operational
      choices to be made, so this is not too different from just putting in a dedicated
      trim speed switch.
      > I found it difficult to slow the trim as much as I would like, using just lower
      voltages, without using voltages so low that the trim motor would stall. Since
      you've already got some electronics there, for just a few bucks more you could
      put in a pulse width modulation system and adjust it to go as slow as you
      like.
      > Bob Turner
      > RV-10 QB
      > http://forums.matronics.com/viewtopic.php?p=414938#414938
      > No virus found in this message.
      > Checked by AVG - www.avg.com
Date: Dec 06, 2013
Subject: Re: RV 10 Aileron Trim easy fix...
Flap speed is not a problem. Elevator trim speed is definitely a problem in cruise, and I'd call it critical for safe operation that the speed be reduced above about 110kts. Tim On 12/6/2013 11:09 AM, Linn Walters wrote: > > Since I'm not there yet, is the flap speed really a 'problem' worth > all this trouble? Is the flap position 'critical' for safe operation? > Linn > > On 12/5/2013 2:23 PM, Bob Turner wrote: >> >> A few thoughts. >> I like to cruise with the flap switch in the off position, but your >> set up requires one to leave it in the up position. If the flap limit >> switch fails the flap motor will run continuously. >> If one desires to take off with no flaps (-3 reflex) he has to put >> the switch in the off position - opposite of cruise. My point is, >> there are operational choices to be made, so this is not too >> different from just putting in a dedicated trim speed switch. >> I found it difficult to slow the trim as much as I would like, using >> just lower voltages, without using voltages so low that the trim >> motor would stall. Since you've already got some electronics there, >> for just a few bucks more you could put in a pulse width modulation >> system and adjust it to go as slow as you like. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=414938#414938 >> >> ________________________________________________________________________________
Date: Dec 06, 2013
I think you mis-read, this post is about pitch trim motor speed, not flap speeds. One poster has tied a change in trim speed to his flap position, others are using a speed sensitive device (safe trim). Yes, the trim speed as it comes from Vans is about right for takeoff and landing but too fast for cruise. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=414984#414984 ________________________________________________________________________________
Date: Dec 06, 2013
I've not found the trim speed to be that much of a problem. I just have 'bu mped' the hat switch in the direction it needs trim. At least that's the wa y it works on the -10 I've flown. My suggestion is to see how your plane o perates and then make changes as needed. There may be some variations betwe en individual systems and or operator desires. > Date: Fri=2C 6 Dec 2013 12:09:57 -0500 > From: flying-nut(at)cfl.rr.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... > > > Since I'm not there yet=2C is the flap speed really a 'problem' worth all > this trouble? Is the flap position 'critical' for safe operation? > Linn > > On 12/5/2013 2:23 PM=2C Bob Turner wrote: > > > > A few thoughts. > > I like to cruise with the flap switch in the off position=2C but your s et up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. > > If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is=2C there are o perational choices to be made=2C so this is not too different from just put ting in a dedicated trim speed switch. > > I found it difficult to slow the trim as much as I would like=2C using just lower voltages=2C without using voltages so low that the trim motor wo uld stall. Since you've already got some electronics there=2C for just a fe w bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=414938#414938 > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 06, 2013
Thanks Bob, getting old sucks!!! So, to continue on with the thread, why not install a PW control as you suggested or run the trim off 6V? Linn On 12/6/2013 12:25 PM, Bob Turner wrote: > > I think you mis-read, this post is about pitch trim motor speed, not flap speeds. One poster has tied a change in trim speed to his flap position, others are using a speed sensitive device (safe trim). > Yes, the trim speed as it comes from Vans is about right for takeoff and landing but too fast for cruise. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414984#414984 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 06, 2013
I have not had a problem. I did put in the safety trim system so the most I can do is 3 seconds at a time. I think 3 seconds at cruse could lead to a little bit of challenge, but not impossible to handle. Rene' Felker N423CF 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Friday, December 06, 2013 10:42 AM Subject: RE: RV10-List: Re: RV 10 Aileron Trim easy fix... I've not found the trim speed to be that much of a problem. I just have 'bumped' the hat switch in the direction it needs trim. At least that's the way it works on the -10 I've flown. My suggestion is to see how your plane operates and then make changes as needed. There may be some variations between individual systems and or operator desires. > Date: Fri, 6 Dec 2013 12:09:57 -0500 > From: flying-nut(at)cfl.rr.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... > > > Since I'm not there yet, is the flap speed really a 'problem' worth all > this trouble? Is the flap position 'critical' for safe operation? > Linn > > On 12/5/2013 2:23 PM, Bob Turner wrote: > > > > A few thoughts. > > I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. > > If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. > > I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=414938#414938 > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com > > > > > > http://www.matronics.com/Navigator?RV10-List > > > ________________________________________________________________________________
Date: Dec 06, 2013
I use to bump my hat also with limited control. With the speed reduction in cruse position your adjustment is so fine it is almost like an altitude hold. A 30% reduction in speed really makes a difference in feathering the trim. Jim Villani Kit# 41084 Jim(at)JimVillani.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs Sent: Friday, December 06, 2013 9:43 AM Subject: RE: RV10-List: Re: RV 10 Aileron Trim easy fix... I've not found the trim speed to be that much of a problem. I just have 'bumped' the hat switch in the direction it needs trim. At least that's the way it works on the -10 I've flown. My suggestion is to see how your plane operates and then make changes as needed. There may be some variations between individual systems and or operator desires. > Date: Fri, 6 Dec 2013 12:09:57 -0500 > From: flying-nut(at)cfl.rr.com <mailto:flying-nut(at)cfl.rr.com> > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... > > > > Since I'm not there yet, is the flap speed really a 'problem' worth all > this trouble? Is the flap position 'critical' for safe operation? > Linn > > On 12/5/2013 2:23 PM, Bob Turner wrote: > > > > > A few thoughts. > > I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. > > If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. > > I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. > > > > -------- > > Bob Turner > > RV-10 QB > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=414938#414938 > > > > > > > > > > > > > > > > > > > > > > > > > > ----- > > No virus found in this message. > > Checked by AVG - www.avg.com <http://www.avg.com> > > > > > > <http://www.buildersbooks.com> http://www.matronics.com/Navigator?RV10-List > > > <http://www.buildersbooks.com> ________________________________________________________________________________
Date: Dec 06, 2013
Danny, This isn't an issue of how easy it is to trim, this is an issue of safety. Yes, bumping it for a fraction of a second will indeed make it trim reasonably slow and you can indeed use it that way. The issue of safety is what happens when you accidently hit the switch. Even as early as my flyoff period, I had a clipboard hit the trim hat, and within a couple seconds I was in a hard nose-up climb. I did some testing later after adding safety trim to see just how bad it gets, and really if you have anything (ipad, book, checklist, chart, person) lay on that switch for a full second or more, it gets scary and for much longer than a second you could get close to having g-rating problems perhaps. So best to just do speed reduction for sure. The side benefit is that you can then even have MORE fine control over trim, because that same bump you use now is reduced to maybe 1/8th what it is. Tim On 12/6/2013 11:42 AM, Danny Riggs wrote: > I've not found the trim speed to be that much of a problem. I just > have 'bumped' the hat switch in the direction it needs trim. At least > that's the way it works on the -10 I've flown. My suggestion is to > see how your plane operates and then make changes as needed. There may > be some variations between individual systems and or operator desires. > > > Date: Fri, 6 Dec 2013 12:09:57 -0500 > > From: flying-nut(at)cfl.rr.com > > To: rv10-list(at)matronics.com > > Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... > > > > > > Since I'm not there yet, is the flap speed really a 'problem' worth all > > this trouble? Is the flap position 'critical' for safe operation? > > Linn > > > > On 12/5/2013 2:23 PM, Bob Turner wrote: > > > > > > A few thoughts. > > > I like to cruise with the flap switch in the off position, but > your set up requires one to leave it in the up position. If the flap > limit switch fails the flap motor will run continuously. > > > If one desires to take off with no flaps (-3 reflex) he has to put > the switch in the off position - opposite of cruise. My point is, > there are operational choices to be made, so this is not too different > from just putting in a dedicated trim speed switch. > > > I found it difficult to slow the trim as much as I would like, > using just lower voltages, without using voltages so low that the trim > motor would stall. Since you've already got some electronics there, > for just a few bucks more you could put in a pulse width modulation > system and adjust it to go as slow as you like. > > > > > > -------- > > > Bob Turner > > > RV-10 QB > > > ________________________________________________________________________________
Date: Dec 06, 2013
I concur 100%. That is what drove me to slow it down, a sudden bump and you are in another world. Jim Villani Kit# 41084 Jim(at)JimVillani.com From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, December 06, 2013 9:57 AM Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... Danny, This isn't an issue of how easy it is to trim, this is an issue of safety. Yes, bumping it for a fraction of a second will indeed make it trim reasonably slow and you can indeed use it that way. The issue of safety is what happens when you accidently hit the switch. Even as early as my flyoff period, I had a clipboard hit the trim hat, and within a couple seconds I was in a hard nose-up climb. I did some testing later after adding safety trim to see just how bad it gets, and really if you have anything (ipad, book, checklist, chart, person) lay on that switch for a full second or more, it gets scary and for much longer than a second you could get close to having g-rating problems perhaps. So best to just do speed reduction for sure. The side benefit is that you can then even have MORE fine control over trim, because that same bump you use now is reduced to maybe 1/8th what it is. Tim On 12/6/2013 11:42 AM, Danny Riggs wrote: I've not found the trim speed to be that much of a problem. I just have 'bumped' the hat switch in the direction it needs trim. At least that's the way it works on the -10 I've flown. My suggestion is to see how your plane operates and then make changes as needed. There may be some variations between individual systems and or operator desires. > Date: Fri, 6 Dec 2013 12:09:57 -0500 > From: flying-nut(at)cfl.rr.com <mailto:flying-nut(at)cfl.rr.com> > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... > > > Since I'm not there yet, is the flap speed really a 'problem' worth all > this trouble? Is the flap position 'critical' for safe operation? > Linn > > On 12/5/2013 2:23 PM, Bob Turner wrote: > > > > A few thoughts. > > I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. > > If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. > > I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. > > > > -------- > > Bob Turner > > RV-10 QB > > <http://www.buildersbooks.com> ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Dec 06, 2013
I have the flap controller install just as Van's provides. Works just fine. Flap position indication is a simple look out the window. I have the two speed safety trim controller and I recommend it. After 10 years of flying an 8A with just the single speed elevator & aileron trim I am used to not having the slow trim speed option - so I rarely use it in the RV-10. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Friday, December 06, 2013 12:10 PM Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... Since I'm not there yet, is the flap speed really a 'problem' worth all this trouble? Is the flap position 'critical' for safe operation? Linn On 12/5/2013 2:23 PM, Bob Turner wrote: > > A few thoughts. > I like to cruise with the flap switch in the off position, but your set up requires one to leave it in the up position. If the flap limit switch fails the flap motor will run continuously. > If one desires to take off with no flaps (-3 reflex) he has to put the switch in the off position - opposite of cruise. My point is, there are operational choices to be made, so this is not too different from just putting in a dedicated trim speed switch. > I found it difficult to slow the trim as much as I would like, using just lower voltages, without using voltages so low that the trim motor would stall. Since you've already got some electronics there, for just a few bucks more you could put in a pulse width modulation system and adjust it to go as slow as you like. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414938#414938 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 06, 2013
Tim Olson wrote: > > > The issue of safety is what happens when you accidently hit the switch. > > Tim > > > > [b] Because of this I did not put a top hat on the right side (there is a panel rocker switch for when I fly from the right seat). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415016#415016 ________________________________________________________________________________
Date: Dec 06, 2013
I wired both stick in parallel ..... with a switch in the co-pilot ground to disable that stick. All the other buttons on the co-pilot side can cause consternation to the pilot!!!! Linn On 12/6/2013 6:03 PM, Bob Turner wrote: > > > Tim Olson wrote: > > The issue of safety is what happens when you accidently hit the switch. > > Tim > Because of this I did not put a top hat on the right side (there is a panel rocker switch for when I fly from the right seat). > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415016#415016 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 06, 2013
Yep - I did the same except the switch on the panel controls the common ground such that the pilot or co-pilot trim top hat and flaps work. This way if the pilot stick switch breaks (as on sticks shut) moving the panel toggle switch to the co-pilot position isolates the fault as well as restores trim/flap control buy using the co-pilot grip switches. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Friday, December 06, 2013 8:11 PM Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... I wired both stick in parallel ..... with a switch in the co-pilot ground to disable that stick. All the other buttons on the co-pilot side can cause consternation to the pilot!!!! Linn On 12/6/2013 6:03 PM, Bob Turner wrote: > > > Tim Olson wrote: > > The issue of safety is what happens when you accidently hit the switch. > > Tim > Because of this I did not put a top hat on the right side (there is a panel rocker switch for when I fly from the right seat). > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415016#415016 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 06, 2013
I like that idea! Simple switch change. Thanks. Linn On 12/6/2013 8:28 PM, Carl Froehlich wrote: > > Yep - I did the same except the switch on the panel controls the common > ground such that the pilot or co-pilot trim top hat and flaps work. This > way if the pilot stick switch breaks (as on sticks shut) moving the panel > toggle switch to the co-pilot position isolates the fault as well as > restores trim/flap control buy using the co-pilot grip switches. > > Carl ________________________________________________________________________________
Subject: Re: rudder trim RV-10
Date: Dec 06, 2013
Anyone have experience with the electric rudder trim kit that is available for the RV10? Is rudder trim important in the 10? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415035#415035 ________________________________________________________________________________
Date: Dec 06, 2013
I have rudder trim in my -10, and like it. That said, I consider it a nice to have feature, not something essential. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415036#415036 ________________________________________________________________________________
Date: Dec 06, 2013
Same here................. Rene' N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim Berry Sent: Friday, December 06, 2013 8:29 PM Subject: RV10-List: Re: rudder trim RV-10 I have rudder trim in my -10, and like it. That said, I consider it a nice to have feature, not something essential. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415036#415036 ________________________________________________________________________________
Date: Dec 06, 2013
I have a tab on the rudder, ball is pretty much centered in cruise most of the time. You will need something more than nothing. Pascal -----Original Message----- From: bob88 Sent: Friday, December 06, 2013 7:21 PM Subject: RV10-List: Re: rudder trim RV-10 Anyone have experience with the electric rudder trim kit that is available for the RV10? Is rudder trim important in the 10? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415035#415035 ________________________________________________________________________________
Date: Dec 07, 2013
I've seen rudder trim tabs hacked out of the rudder, riveted bendable tabs, big wedges, small wedges ...... but nobody could tell me 'how much tab do you need?'. So I decided to use small RC servos to implement my aileron and rudder trim which will drive a hinge segment, controllable from the stick. I'll probably leave the installation of the hinges 'till after phase 1. Linn On 12/6/2013 11:44 PM, Pascal wrote: > > I have a tab on the rudder, ball is pretty much centered in cruise > most of the time. You will need something more than nothing. > Pascal > > -----Original Message----- From: bob88 > Sent: Friday, December 06, 2013 7:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: rudder trim RV-10 > > > Anyone have experience with the electric rudder trim kit that is > available for the RV10? Is rudder trim important in the 10? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415035#415035 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 07, 2013
My aileron trim consists of switching the fuel selector to to heavy side. Works every time and no runaway issues. N312F - flying again after the bird strike repairs! Jim C Sent from my iPhone On Dec 6, 2013, at 12:25 PM, "Bob Turner" wrote: > > I think you mis-read, this post is about pitch trim motor speed, not flap speeds. One poster has tied a change in trim speed to his flap position, others are using a speed sensitive device (safe trim). > Yes, the trim speed as it comes from Vans is about right for takeoff and landing but too fast for cruise. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=414984#414984 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 07, 2013
No experience here but after 350 hours of flying without rudder trim, I've decided not to install the trim system because it's not worth the effort. I've found that on one hand, I like flying with my feet on the pedals. It may be a holdover from the Maule. It takes very little pressure to adjust for climb, cruise and descent. Flying with the AP engaged, the pedals help keep me engaged. On the other hand, there is enough friction in the system (and so little pressure is required) that I can set the right pedal where I need it and it will stay there in most conditions. I know that people have simply added some friction or even a temporary stop to the cable to help accomplish the same thing. That didn't sound right to me before I flew but makes sense now. Adding a bit of friction to increase the breakout force would have little or no effect on the operating friction and would be sufficient for 'setting the trim' in this particular plane. I do recommend aileron trim and something to slow down the pitch trim and/or limit its effects (I use Safety Trim). Bill On 12/6/2013 10:21 PM, bob88 wrote: > > Anyone have experience with the electric rudder trim kit that is available for the RV10? Is rudder trim important in the 10? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415035#415035 > > ________________________________________________________________________________
Date: Dec 07, 2013
[quote="flying-nut(at)cfl.rr.com"]nobody could tell me 'how much tab do you need?'. So I decided to use small RC servos to implement my aileron and rudder trim which will drive a hinge segment, controllable from the stick. I'll probably leave the installation of the hinges 'till after phase 1. Linn I use a 12" hinge segment as you describe, and it is more than enough. Very small deflections will maintain trim. I think 6" would do the job; maybe even less. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415069#415069 ________________________________________________________________________________
Date: Dec 07, 2013
Subject: Re: re bird strike repairs
Wow, that was fast! I started on my windshield install shortly after your incident report. Still working on getting the fiberglass fairing finished. On 12/7/2013 8:12 AM, Jim Combs wrote: > - > N312F - flying again after the bird strike repairs! > > Jim C > > ________________________________________________________________________________
Date: Dec 07, 2013
The second time goes a LOT quicker than the first time! The fear of screwing it up is not there. Its the 3 hours of grinding out the old one that was the worst. Jim C On Sat, Dec 7, 2013 at 2:52 PM, Kelly McMullen wrote: > > Wow, that was fast! I started on my windshield install shortly after your > incident report. Still working on getting the fiberglass fairing finished. > > On 12/7/2013 8:12 AM, Jim Combs wrote: > >> - >> N312F - flying again after the bird strike repairs! >> >> Jim C >> >> >> > > ________________________________________________________________________________
Date: Dec 07, 2013
Hopefully you used the desser/Cee Baileys, That would explain the quick time to repair On Dec 7, 2013, at 3:23 PM, Jim Combs wrote: > The second time goes a LOT quicker than the first time! > > The fear of screwing it up is not there. Its the 3 hours of grinding out t he old one that was the worst. > > Jim C > > > On Sat, Dec 7, 2013 at 2:52 PM, Kelly McMullen wrote : > > Wow, that was fast! I started on my windshield install shortly after your i ncident report. Still working on getting the fiberglass fairing finished. > > On 12/7/2013 8:12 AM, Jim Combs wrote: > - > N312F - flying again after the bird strike repairs! > > Jim C > > > > > ========================= > om" target="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > et="_blank">www.mypilotstore.com > "_blank">www.mrrace.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > ========================= > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========================= > http://forums.matronics.com > ========================= > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ________________________________________________________________________________
Date: Dec 07, 2013
Thanks Jim. I was going to start out with 12" and trim as necessary. I can adjust the speed of the servo easily so I hope to end up with smallest added drag and good trim function. Linn On 12/7/2013 1:20 PM, Jim Berry wrote: > > [quote="flying-nut(at)cfl.rr.com"]nobody could tell me 'how much > tab do you need?'. So I decided to use small RC servos to implement my > aileron and rudder trim which will drive a hinge segment, controllable > from the stick. I'll probably leave the installation of the hinges > 'till after phase 1. > Linn > > > I use a 12" hinge segment as you describe, and it is more than enough. Very small deflections will maintain trim. I think 6" would do the job; maybe even less. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415069#415069 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 08, 2013
I tried to contact them and could not. So I put a Vans window back in. It goes a lot easier the second time around. On Sat, Dec 7, 2013 at 8:01 PM, Pascal wrote: > Hopefully you used the desser/Cee Baileys, > That would explain the quick time to repair > > > On Dec 7, 2013, at 3:23 PM, Jim Combs wrote: > > The second time goes a LOT quicker than the first time! > > The fear of screwing it up is not there. Its the 3 hours of grinding out > the old one that was the worst. > > Jim C > > > On Sat, Dec 7, 2013 at 2:52 PM, Kelly McMullen wrote: > >> >> Wow, that was fast! I started on my windshield install shortly after your >> incident report. Still working on getting the fiberglass fairing finished. >> >> On 12/7/2013 8:12 AM, Jim Combs wrote: >> >>> - >>> N312F - flying again after the bird strike repairs! >>> >>> Jim C >>> >>> >>> >> >> =================================== >> om" target="_blank">www.aeroelectric.com >> ooks.com" target="_blank">www.buildersbooks.com >> et="_blank">www.homebuilthelp.com >> et="_blank">www.mypilotstore.com >> "_blank">www.mrrace.com >> ="_blank">http://www.matronics.com/contribution >> le, List Admin. >> =================================== >> arget="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> http://forums.matronics.com >> =================================== >> >> >> >> > > * > > * > > ________________________________________________________________________________
Date: Dec 08, 2013
I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 [Shocked] Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415117#415117 ________________________________________________________________________________
Date: Dec 08, 2013
Yep - I looked at this and decided that while it is simple and effective, it is way overpriced. The M.L. Skunkworks version is still listed for $115 - much more reasonable. http://www.mlblueskunk.com/Rudder_Trim_System.html After all the rigging tweaks during Phase One I have not found a need for rudder trim in cruise. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 08, 2013 10:56 AM Subject: RV10-List: Re: rudder trim RV-10 --> I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 [Shocked] Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415117#415117 ________________________________________________________________________________
Date: Dec 08, 2013
I mentioned the tab, that fellow Don McDonald helped me create and it was not a big deal. You grab a piece of aluminum, 4" X 2" and you bend it slightly. Fly and see what happens at cruise. adjust as needed and repeat flight until ball is centered. If I add up the cost of gas I guess it was about $75, except I was flying anyway so it was practically free. My ball is centered than not and I rarely need to adjust it in cruise, John is right on, once you get the rudder tab tuned in there is very little trim adjustments needed. I know Tim Olson went the route of the trim tab to electronic trim, I would encourage all you debating this to check out his extensive review and steps to do oneself. Pascal -----Original Message----- From: johngoodman Sent: Sunday, December 08, 2013 7:56 AM Subject: RV10-List: Re: rudder trim RV-10 I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 [Shocked] Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415117#415117 ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Dec 08, 2013
John Aerosport Products rudder trim is a much more refined unit then the skunkworks. You get what you pay for with our rudder trim. It might not be for everyone. If you saw What goes into making this a quality unit and you may or may not understand. Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 08, 2013 10:56 AM Subject: RV10-List: Re: rudder trim RV-10 --> I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 [Shocked] Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415117#415117 ________________________________________________________________________________
Date: Dec 08, 2013
I love my rudder trim form Aerosport. It works perfect and doesn't add weight to the rudder assembly. As a great by-product it holds the rudder from being slammed around in winds. Of course you need to put in a gust lock in strong gusts. -----Original Message----- From: Geoff Combs Sent: Sunday, December 8, 2013 9:30 AM Subject: RE: RV10-List: Re: rudder trim RV-10 John Aerosport Products rudder trim is a much more refined unit then the skunkworks. You get what you pay for with our rudder trim. It might not be for everyone. If you saw What goes into making this a quality unit and you may or may not understand. Geoff Geoff Combs Aerosport Products 8090 howe industrial pkwy canal winchester, ohio 43110 614.834.8659p www.aerosportproducts.com -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Sunday, December 08, 2013 10:56 AM Subject: RV10-List: Re: rudder trim RV-10 --> I used a spring-based rudder trim system. I got it in 2008 from M.L.Skunkworks for $75. I think he is out of business, but there is a company called Aerosport that sells the same thing for $250 [Shocked] Regardless, it works great and I rarely have to change it. I don't think the RV-10 needs much rudder trim, unless you have crooked pants.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415117#415117 ________________________________________________________________________________
Subject: Full power =?ISO-8859-1?Q?30=C2=B0?= bank stall
Date: Dec 08, 2013
My test program asks for a full power 30 bank stall. M question is if this has been done by others and what is the aircrafts behavior. I'd expect that the low wing would stall first due to lower airspeed compared to the outer turn wing. What did you experience? Thanks Mike -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415139#415139 ________________________________________________________________________________
Subject: Re: Full power =?ISO-8859-1?Q?30=C2=B0?= bank stall
Date: Dec 08, 2013
That's a strange one for a non-acrobatic RV-10. It would take a LOT of nose up at full power to stall. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415144#415144 ________________________________________________________________________________
Date: Dec 08, 2013
Subject: Re: Full power =?ISO-8859-1?Q?30=B0_bank_stall?
Michael, please discuss with your flight advisor, I would do a step up approach first with 60% power to get a feeling (and start enough high). My Glastar does exactly the opposite to what you describe (and I can repeat it) so the outer wing stalls and the plane goes into a straight and level attitude with nose down, very tame. However I did hear from Lancair/Glasair pilot from wing overs! (Andre Beusch might be a good person to talk about his experience.) Good luck (and I'm impressed with your landings, seems the 10 has a lot of elevator authority on slow speed as well as that nose gear is up about half the runway long :) Cheers Werner On 08.12.2013 20:17, Mike Whisky wrote: > > My test program asks for a full power 30 bank stall. > M question is if this has been done by others and what is the aircrafts behavior. I'd expect that the low wing would stall first due to lower airspeed compared to the outer turn wing. > > What did you experience? > > Thanks > Mike > > -------- > RV-10 builder (flying, test phase) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415139#415139 > > ________________________________________________________________________________
Date: Dec 08, 2013
Subject: Re: Full power =?ISO-8859-1?Q?30=B0_bank_stal?= =?ISO-8859-1?Q?l?
John, the idea behind that point is to simulate a large bank on a go around. It should not be done that way, but in Switzerland the test flying includes that program point. Cheers Werner On 08.12.2013 21:23, johngoodman wrote: > > That's a strange one for a non-acrobatic RV-10. ________________________________________________________________________________
Date: Dec 08, 2013
Remember that stall depends on angle of attack, not airspeed. The raised wing has a slightly higher angle of attack due to the lowered aileron. The plane just falls out of the turn, if the ball is centered. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415151#415151 ________________________________________________________________________________
Date: Dec 08, 2013
Subject: =?ISO-8859-1?Q?Re=3A_RV10=2DList=3A_Full_power_30=C2=B0_bank_stall?
If you are forced to do such a test, I would load to near gross weight, and bring the power in very slowly. Someone should be able to explain what scenario it is supposed to duplicate. Flaps should be up for most any scenario including missed approach or go around, as there should be no turning before flaps are retracted. On Sun, Dec 8, 2013 at 12:17 PM, Mike Whisky wrote: > > My test program asks for a full power 30=B0 bank stall. > M question is if this has been done by others and what is the aircrafts > behavior. I'd expect that the low wing would stall first due to lower > airspeed compared to the outer turn wing. > > What did you experience? > > Thanks > Mike > > -------- > RV-10 builder (flying, test phase) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415139#415139 > > =========== =========== =========== =========== > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 08, 2013
Subject: Re: RV10-List: Full power =?ISO-8859-1?Q?30=B0_?= =?ISO-8859-1?Q?bank_stall?
I'm thinking that the test is just a plain accelerated stall ..... and the stall should be occur about 20 knots above straight and level stall speed. So, at some comfortable speed 90 to 100 knots .... roll into the 30 degree bank and apply back pressure to hold altitude. The airspeed should decrease as you add back pressure until the stall occurs. Different airframes act differently. Some will roll to the outside of the turn and some will just drop the nose and roll to the inside. Let us know if that satisfies the test and what the resulting unusual attitude you get!!! I may be wrong, but this is my take. Linn On 12/8/2013 7:00 PM, Kelly McMullen wrote: > If you are forced to do such a test, I would load to near gross > weight, and bring the power in very slowly. Someone should be able to > explain what scenario it is supposed to duplicate. Flaps should be up > for most any scenario including missed approach or go around, as there > should be no turning before flaps are retracted. > > > On Sun, Dec 8, 2013 at 12:17 PM, Mike Whisky > wrote: > > > > > My test program asks for a full power 30 bank stall. > M question is if this has been done by others and what is the > aircrafts behavior. I'd expect that the low wing would stall first > due to lower airspeed compared to the outer turn wing. > > What did you experience? > > Thanks > Mike > > -------- > RV-10 builder (flying, test phase) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415139#415139 > > > ========== > ="_blank">www.aeroelectric.com > ooks.com" target="_blank">www.buildersbooks.com > et="_blank">www.homebuilthelp.com > et="_blank">www.mypilotstore.com > "_blank">www.mrrace.com > ="_blank">http://www.matronics.com/contribution > le, List Admin. > ========== > arget="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > http://forums.matronics.com > ========== > > > -- > > - sent from the microchip implanted in my forearm > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Re: Full power =?ISO-8859-1?Q?30=B0?= bank stall
Date: Dec 08, 2013
Technically yes it's an accelerated stall but at a 30 degree bank the load factor is only 1.15, so stall speed should go up 7.5% -about 5 kias. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415159#415159 ________________________________________________________________________________
Date: Dec 09, 2013
It's always funny to watch this thread pop up, it's almost like someone has it on their calendar to re-start the debate every 4 or 6 months. Basically, my thoughts on Rudder trim are these: First and foremost, rudder trim is not something that is a one-size-fits-all thing. It is not a NEEDED thing, and it isn't a big safety thing. There isn't any reason people HAVE to have rudder trim. I flew something like 285 hours before I had any rudder trim, flying with a wooden block painted to match and attached and in general it was nearly sufficient. Nearly. Everyone flies a different mission, and I fly very little short-hop local flights. I probably spend over 90% of my flying on longer legs. Some of them loaded to gross wt. Some light. Some in between. Airspeeds vary between 150kts and 170kts. It all depends. In that environment, those first 285 hours had the annoyance of always requiring a foot on a pedal putting just the right pressure on to keep in trim. What happens if you are not in trim? Well, it's worse than just having a constant crab angle....the view out the window is tilted. To have a nice level horizon, you need to be in trim. I find it annoying to not be level....because it just isn't right, and shouldn't be that way. For a short hop you wouldn't even notice it. But, if you are an X/C flier, it is a pain. A rudder block, or fixed tab (bendable), would suffice if you almost always fly the same speeds and weights. It is simple, easy, and as Pascal did, the bendable tab is about as simple and easy and quick to do as you can get. For a static tab I think I prefer the wedge block, for aesthetics, but once you have it set right, it will fix probably much of your trim issues. Some of my trips pre-trim were ok. Many of them were not. It all depended on if I flew LOP, ROP, heavy, or light. It's not wrong to go that way. For many people, you'll be satisfied. Then there's the spring-bias trim. Now that there are good choices out there, I think this is a plenty reasonable alternative for many. As Sean mentioned, it does give some spring to the rudder to prevent minor movement in light breeze. It does not at all mean you don't need a gust lock. It's fairly simple to install, and should do the job pretty well. Personally, I would recommend that if you go with spring bias trim, you also do a fixed wedge to correct most of it. That way the spring bias is nearly 100% neutralized most of the time, and you only use it slightly. There's nothing at all wrong with the spring bias trim, and I think many people will love it. It's the minimum that I personally would be happy with....and it can be added post-build, so that's nice too. Then there's the adjustable tab trim. This is what I have. It's something that I *personally* would absolutely do again, and my preference hasn't changed...I'd do it the same way. In fact, I'll be rebuilding my rudder someday and I plan to incorporate it almost identically into the new build. I had debated adding a cutout tab, but I don't know if it's worth the work and the increased thinking about how to structurally reinforce things. The hinge tab on the trailing edge is simple, works well, and is fairly minimal impact. I don't remember exactly (I think it's in my write-up) how long it took, but I'm sure it wasn't more than one weekend, with the bulk of it being one evening. So time invested was minimal. To me, aerodynamic trim like this is about as good as you can get for trimming. You're actually trimming your flying surface of the rudder to be in trim, just like you do with the elevator. It means that there is no tension on either rudder cable in flight, which isn't necessarily a benefit...it just means that the rudder has no need for any actuation to keep it perfect. I actually think a little spring return on the pedals may be a good thing, but again, there are ways that it will also be less convenient. Van's has a very simple system, and any change to it adds some degree of negative side, even if there is a benefit added. The world isn't 100% black or 100% white....anything you do will involve a little grey. The biggest downside to the electric trim is that you will be BETTER off doing it pre-paint. I did mine post-paint and while it turned out good, it would have been better pre-paint. The biggest upside is the absolute perfect adjustment to trim with no effect on the pedals or feel whatsoever. Do I use it, yes....I just did a round trip to Florida and I used it on that trip both ways. I had a sloped horizon at one point that was ticking me off, so I trimmed it out. It worked well. But, it's not necessarily "better" than any other method. All of them can work. I do think that for most x/c fliers, at least those who are really in tune to their airplane, will enjoy at least some form of adjustable trim. I also think that for those who don't have adjustable trim, their opinions may actually change as they fly more and more long x/c legs. The fact is, trim is not a static thing unless all flight characteristics are also static....it's just the individual's toleration for imperfection as it gets more out of trim. It's just funny to see the thread come back again and again. You can ask if rudder trim is needed, and either answer, Yes or No, is correct. And which system is best? Well, that is all up to the builder too. You're going to find satisfied people with ANY method. So I'd encourage the builder to actually sit and think about it on their own. Spend some time pondering it. Then just pick one and go. Aileron trim....that I think is needed. Yes, there are those who don't agree, but the -10 tanks are so long, and it doesn't take too much imbalance to develop that rolling tendency. You can minimize it with good fuel management, but if this one were put to a vote, my guess is you'd have maybe 5-10% of the people who fly lots of X/C time who would vote no. Rudder trim, if electric, would be ok either at full speed or reduced. If you have safety trim, which is probably ideal from a simplicity standpoint in wiring, I'd just do speed reduction so you can be very precise. Otherwise, full-speed will work. Aileron trim you'll want to run full speed for sure. Elevator trim I believe is a safety issue if you don't do speed reduction on it, but ONLY at airspeeds over 100 or 110kts. You definitely want full speed when in the pattern. But you absolutely don't want full speed while flying. It is just too dangerous if you get a stuck switch, shorted ground, bumped switch, or anything that could cause more than 1 second of accidental trim. Even 1 second of accidental trim is almost guaranteed to cause you to bust your IFR assigned altitude, so even from that aspect it's just not worth leaving it full speed. Yes, I also flew many hours with only full-speed trim, but that wasn't incident free. It did work, and I learned to live with it for a while, but there are safety issues and I think Safety Trim basically fixed all those issues for me. This isn't meant to be a plug for Safety Trim, because it gets annoying when people constantly plug products on the forums, but, they did a great job on it. If you have Vertical Power and do it there, fine. If you did a roll-your own, fine. Even if you don't deal with runaway trim, you really need to do something to have a dual-stage speed on the trim. Do it however you want...but just do it. Tim On 12/8/2013 10:29 AM, Pascal wrote: > > I mentioned the tab, that fellow Don McDonald helped me create and it > was not a big deal. You grab a piece of aluminum, 4" X 2" and you bend > it slightly. Fly and see what happens at cruise. adjust as needed and > repeat flight until ball is centered. If I add up the cost of gas I > guess it was about $75, except I was flying anyway so it was > practically free. My ball is centered than not and I rarely need to > adjust it in cruise, John is right on, once you get the rudder tab > tuned in there is very little trim adjustments needed. > I know Tim Olson went the route of the trim tab to electronic trim, I > would encourage all you debating this to check out his extensive > review and steps to do oneself. > Pascal ________________________________________________________________________________
Date: Dec 09, 2013
Absolutely, without a doubt, an excellent post. I really learned a lot and also got some valuable info. I agree that building a stock airframe isn't 'bad' except to say that departure from the plans adds immense additional build time. At least it does for me. I chose to use model airplane servos because of the light weight (one of my 'hot buttons') and low cost. Ease of installation using the hinge method is also a plus. However I had to install a pulse width controller for the servos ..... and instead of a simple 555 chip I chose to do it with an evaluation processor so I could control it's speed and position 'better'. Because I can! I have already wired the elevator trim and flap controls through relays and thanks to Tim's take on the elevator trim speed I'll go ahead and add both of them to the processor program to 'pulse' the relays and thereby control the speed of those two functions as well. Making the speed variable with the length of time the button is pressed becomes a simple programming task. The change does, however, add to my build time, but I take Tim's concern with elevator trim speed as a safety factor seriously. As for Tim's 'funny part' ..... I don't think there's real effort to start a food fight every so often. I like to search a subject to see what has been written before but may post the same question again since there's more 'experience' gained by those fortunate to get their project finished and gaining additional knowledge on whether the mods they made were successful or a waste of time. OK, lunch is over so it's back to building!!! Linn On 12/9/2013 11:12 AM, Tim Olson wrote: > > It's always funny to watch this thread pop up, it's almost like > someone has > it on their calendar to re-start the debate every 4 or 6 months. > > Basically, my thoughts on Rudder trim are these: > > First and foremost, rudder trim is not something that is a > one-size-fits-all > thing. It is not a NEEDED thing, and it isn't a big safety thing. > There isn't > any reason people HAVE to have rudder trim. I flew something like > 285 hours before I had any rudder trim, flying with a wooden block > painted > to match and attached and in general it was nearly sufficient. > Nearly. > > Everyone flies a different mission, and I fly very little short-hop local > flights. I probably spend over 90% of my flying on longer legs. > Some of them loaded to gross wt. Some light. Some in between. > Airspeeds vary between 150kts and 170kts. It all depends. > In that environment, those first 285 hours had the annoyance of > always requiring a foot on a pedal putting just the right pressure > on to keep in trim. What happens if you are not in trim? Well, it's > worse than just having a constant crab angle....the view out the > window is tilted. To have a nice level horizon, you need to be in trim. > I find it annoying to not be level....because it just isn't right, and > shouldn't be that way. For a short hop you wouldn't even notice > it. But, if you are an X/C flier, it is a pain. > > A rudder block, or fixed tab (bendable), would suffice if you almost > always > fly the same speeds and weights. It is simple, easy, and as Pascal > did, the bendable tab is about as simple and easy and quick to do as you > can get. For a static tab I think I prefer the wedge block, for > aesthetics, > but once you have it set right, it will fix probably much of your trim > issues. Some of my trips pre-trim were ok. Many of them were not. > It all depended on if I flew LOP, ROP, heavy, or light. It's not > wrong to > go that way. For many people, you'll be satisfied. > > Then there's the spring-bias trim. Now that there are good choices > out there, I think this is a plenty reasonable alternative for many. > As Sean mentioned, it does give some spring to the rudder to prevent > minor movement in light breeze. It does not at all mean you don't > need a gust lock. It's fairly simple to install, and should do the job > pretty well. Personally, I would recommend that if you go with spring > bias trim, you also do a fixed wedge to correct most of it. That way > the spring bias is nearly 100% neutralized most of the time, and > you only use it slightly. There's nothing at all wrong with the > spring bias trim, and I think many people will love it. It's the minimum > that I personally would be happy with....and it can be added post-build, > so that's nice too. > > Then there's the adjustable tab trim. This is what I have. > It's something that I *personally* would absolutely do again, > and my preference hasn't changed...I'd do it the same way. In fact, > I'll be > rebuilding my rudder someday and I plan to incorporate it almost > identically > into the new build. I had debated adding a cutout tab, but I don't > know if it's > worth the work and the increased thinking about how to structurally > reinforce > things. The hinge tab on the trailing edge is simple, works well, and > is fairly > minimal impact. I don't remember exactly (I think it's in my > write-up) how long > it took, but I'm sure it wasn't more than one weekend, with the bulk > of it > being one evening. So time invested was minimal. To me, aerodynamic > trim like this is about as good as you can get for trimming. You're > actually > trimming your flying surface of the rudder to be in trim, just like > you do > with the elevator. It means that there is no tension on either rudder > cable in flight, which isn't necessarily a benefit...it just means > that the > rudder has no need for any actuation to keep it perfect. I actually > think a little spring return on the pedals may be a good thing, but > again, > there are ways that it will also be less convenient. Van's has a very > simple system, and any change to it adds some degree of > negative side, even if there is a benefit added. The world isn't > 100% black or 100% white....anything you do will involve a little > grey. The biggest downside to the electric trim is that you will be > BETTER > off doing it pre-paint. I did mine post-paint and while it turned out > good, > it would have been better pre-paint. The biggest upside is > the absolute perfect adjustment to trim with no effect on the pedals > or feel whatsoever. Do I use it, yes....I just did a round trip to > Florida > and I used it on that trip both ways. I had a sloped horizon at one > point > that was ticking me off, so I trimmed it out. It worked well. But, > it's not > necessarily "better" than any other method. All of them can work. > > I do think that for most x/c fliers, at least those who are really in > tune > to their airplane, will enjoy at least some form of adjustable trim. > I also think that for those who don't have adjustable trim, their > opinions > may actually change as they fly more and more long x/c legs. The fact > is, trim is not a static thing unless all flight characteristics are > also static....it's just the individual's toleration for imperfection > as it > gets more out of trim. > > It's just funny to see the thread come back again and again. > You can ask if rudder trim is needed, and either answer, Yes or No, > is correct. And which system is best? Well, that is all up to > the builder too. You're going to find satisfied people with ANY method. > So I'd encourage the builder to actually sit and think about it on their > own. Spend some time pondering it. Then just pick one and go. > > Aileron trim....that I think is needed. Yes, there are those who don't > agree, > but the -10 tanks are so long, and it doesn't take too much imbalance to > develop that rolling tendency. You can minimize it with good fuel > management, but if this one were put to a vote, my guess is you'd > have maybe 5-10% of the people who fly lots of X/C time who > would vote no. > > Rudder trim, if electric, would be ok either at full speed or reduced. > If you have safety trim, which is probably ideal from a simplicity > standpoint in wiring, I'd just do speed reduction so you can be > very precise. Otherwise, full-speed will work. > > Aileron trim you'll want to run full speed for sure. > > Elevator trim I believe is a safety issue if you don't do speed reduction > on it, but ONLY at airspeeds over 100 or 110kts. You definitely > want full speed when in the pattern. But you absolutely don't want > full speed while flying. It is just too dangerous if you get a stuck > switch, shorted ground, bumped switch, or anything that could cause > more than 1 second of accidental trim. Even 1 second of accidental > trim is almost guaranteed to cause you to bust your IFR assigned > altitude, so even from that aspect it's just not worth leaving it full > speed. Yes, I also flew many hours with only full-speed trim, but > that wasn't incident free. It did work, and I learned to live with it > for a while, but there are safety issues and I think Safety Trim > basically > fixed all those issues for me. This isn't meant to be a plug for > Safety Trim, because it gets annoying when people constantly > plug products on the forums, but, they did a great job on it. > If you have Vertical Power and do it there, fine. If you did a > roll-your own, fine. Even if you don't deal with runaway trim, > you really need to do something to have a dual-stage speed > on the trim. Do it however you want...but just do it. > > Tim > > > On 12/8/2013 10:29 AM, Pascal wrote: >> >> I mentioned the tab, that fellow Don McDonald helped me create and it >> was not a big deal. You grab a piece of aluminum, 4" X 2" and you >> bend it slightly. Fly and see what happens at cruise. adjust as >> needed and repeat flight until ball is centered. If I add up the cost >> of gas I guess it was about $75, except I was flying anyway so it was >> practically free. My ball is centered than not and I rarely need to >> adjust it in cruise, John is right on, once you get the rudder tab >> tuned in there is very little trim adjustments needed. >> I know Tim Olson went the route of the trim tab to electronic trim, I >> would encourage all you debating this to check out his extensive >> review and steps to do oneself. >> Pascal > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Re: EZ Heat engine block heater
Date: Dec 09, 2013
I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters. ________________________________________________________________________________
Date: Dec 09, 2013
I only have about 65 hours on the 10 but I just flew from MD to FL. I found that it doesnt take much force on the pedals to center the ball and there is enough friction in the system to keep it there a good part of the time. Right now I dont see any need for rudder trim. On the other hand I dont have the wheel pants or landing gear fairings installed yet and if they arent aligned perfectly rudder trim might become more important Nikolaos Napoli > On Dec 6, 2013, at 10:21 PM, bob88 wrote: > > > Anyone have experience with the electric rudder trim kit that is available for the RV10? Is rudder trim important in the 10? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415035#415035 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 09, 2013
Tell me more about this turning on via cell phone thingy. -Sean #40303 On 12/9/13, 12:59 PM, Bob Leffler wrote: > > I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters. > > ________________________________________________________________________________
Date: Dec 09, 2013
Switchboxcontrol.com It's got a built in T-Mobile cell phone that can receive and send SMS messages. It's a prepaid device and the minimum you can load is $10. $10 over three months gives you more texts than I'll ever need. You can let it go dormant over the summer. Works pretty well. I'm sure that you seen Phillips threads on VAF. He also supplies a simple iOS and/or android app for those that don't want to learn the SMS syntax Sent from my iPhone On Dec 9, 2013, at 3:11 PM, Sean Stephens wrote: Tell me more about this turning on via cell phone thingy. -Sean #40303 > On 12/9/13, 12:59 PM, Bob Leffler wrote: > > I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters. ________________________________________________________________________________
Date: Dec 09, 2013
That's awesome. Now I need to figure out how to hook it up to my hangar heater thermostat to get the hangar from 46 to 64 degrees before I arrive. :) On 12/9/13, 2:35 PM, Bob Leffler wrote: > > Switchboxcontrol.com > > It's got a built in T-Mobile cell phone that can receive and send SMS messages. It's a prepaid device and the minimum you can load is $10. $10 over three months gives you more texts than I'll ever need. You can let it go dormant over the summer. > > Works pretty well. I'm sure that you seen Phillips threads on VAF. He also supplies a simple iOS and/or android app for those that don't want to learn the SMS syntax > > Sent from my iPhone > > On Dec 9, 2013, at 3:11 PM, Sean Stephens wrote: > > > Tell me more about this turning on via cell phone thingy. > > -Sean #40303 > >> On 12/9/13, 12:59 PM, Bob Leffler wrote: >> >> I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters. > > ________________________________________________________________________________
Date: Dec 09, 2013
Here is a schematic for those of you in cold areas who would like to preheat your engine or hangar by SMS texts. It uses a Waferstar SMS relay with 7 available relays. It's available through DHGate on the web. The rest of the parts are Radio Shack DPDT 12v switching 110v relays and about 1.5a 12v source. The SMS relay will send a text message to you telling you that the requested action was done. I used an SMA connector to RG-58 coax to make an antenna going out the wall of my metal hangar. I stripped the exterior braid the length of the factory antenna and that yields a signal strength of under 10 out of 32 which seems to be good enough. I use an H2O Wireless card from Best Buy at $10 for 3 months. Texts are $.05 and there will be 4/use. I use it to turn of the engine heater or the furnace and ceiling fans either together or singly. Any combination of the seven relays is possible. The timer section of the schematic is used when I want to leave early in the AM and don't want to getup the send the message 2-3 hours ahead of time. The timer is preprogrammed for any day with a start time of 3AM and turns off at 9AM. The system is wired so that heater, furnace and fans can all be turned on by hand at the hangar. There was no electrical inspection done this so I have no clue if it would pass. I probably got a little carried away with this project but I really like it. Sheldon Olesen N475PV 527hrs On Dec 9, 2013, at 3:03 PM, Sean Stephens wrote: > > That's awesome. Now I need to figure out how to hook it up to my hangar heater thermostat to get the hangar from 46 to 64 degrees before I arrive. :) > > > > On 12/9/13, 2:35 PM, Bob Leffler wrote: >> >> Switchboxcontrol.com >> >> It's got a built in T-Mobile cell phone that can receive and send SMS messages. It's a prepaid device and the minimum you can load is $10. $10 over three months gives you more texts than I'll ever need. You can let it go dormant over the summer. >> >> Works pretty well. I'm sure that you seen Phillips threads on VAF. He also supplies a simple iOS and/or android app for those that don't want to learn the SMS syntax >> >> Sent from my iPhone >> >> On Dec 9, 2013, at 3:11 PM, Sean Stephens wrote: >> >> >> Tell me more about this turning on via cell phone thingy. >> >> -Sean #40303 >> >>> On 12/9/13, 12:59 PM, Bob Leffler wrote: >>> >>> I have the same Reiff heaters that Tim mentioned. I'm getting similar results. It was in the twenties this weekend and the temps were in the nineties at start. I turned on the heat with my cell about four hours before the flight. A much nicer arrangement that I had with my Cherokee using propane heaters. >> >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Subject: Re: RV 10 Aileron Trim easy fix...
Date: Dec 10, 2013
The Vertical Power systems have trim speeds built in, and runaway cutoff as well. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415319#415319 ________________________________________________________________________________
Date: Dec 10, 2013
Unfortunately VP has just been sold. Remains to be seen if the new company will continue production and support for E-AB equipment. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415334#415334 ________________________________________________________________________________
Subject: Vertical Power sold
Date: Dec 10, 2013
Announcement I am pleased to announce that Astronics acquired the Vertical Power Electronic Circuit Breaker product line on November 26, 2013. Astronics is a leading provider of advanced technologies for the global aerospace and defense industries, including Electronic Circuit Breakers for business jets such as the Eclipse 500, Pilatus PC-24, and Lear 85, under the Astronics=92 CorePower=AE brand. Astronics will continue to manufacture, sell and support the Vertical Power ECB products and is excited to enter into the experimental aircraft and Light Sport aircraft markets under the Vertical Power brand. Vertical Power offices will be closed during the month of December as the team moves to the Astronics=92 offices in Everett, Washington. Please be patient with us during this transition; E-mail and telephone call-back support will be provided during this period. Thank you for your support over the years, and I hope you are as excited about this next step in the journey as we are here. I truly believe that we have found a great new home for our products with Astronics. Kind regards, Marc Ausman ________________________________________________________________________________
Date: Dec 10, 2013
I saw where they did not pick up the VP-400 product line, I wonder if that became an orphan? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John Sent: Tuesday, December 10, 2013 1:05 PM Subject: RV10-List: Vertical Power sold Announcement I am pleased to announce that Astronics <http://www.astronics.com> acquired the Vertical Power Electronic Circuit Breaker product line on November 26, 2013. Astronics is a leading provider of advanced technologies for the global aerospace and defense industries, including Electronic Circuit Breakers for business jets such as the Eclipse 500, Pilatus PC-24, and Lear 85, under the Astronics' CorePowerR brand. Astronics will continue to manufacture, sell and support the Vertical Power ECB products and is excited to enter into the experimental aircraft and Light Sport aircraft markets under the Vertical Power brand. Vertical Power offices will be closed during the month of December as the team moves to the Astronics' offices in Everett, Washington. Please be patient with us during this transition; E-mail and telephone call-back support will be provided during this period. Thank you for your support over the years, and I hope you are as excited about this next step in the journey as we are here. I truly believe that we have found a great new home for our products with Astronics. Kind regards, Marc Ausman ________________________________________________________________________________
Subject: Re: Vertical Power sold
Date: Dec 10, 2013
I suspect that due to the intellectual capital from Austin Myers in the prod uct may have something to do with that. Perhaps Austin will do something w ith it like the original vp-300 application. Per speculation on my part Sent from my iPhone On Dec 10, 2013, at 1:53 PM, "William Greenley" wrote: I saw where they did not pick up the VP-400 product line, I wonder if that b ecame an orphan? From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ma tronics.com] On Behalf Of Miller John Sent: Tuesday, December 10, 2013 1:05 PM Subject: RV10-List: Vertical Power sold Announcement I am pleased to announce that Astronics acquired the Vertical Power Electron ic Circuit Breaker product line on November 26, 2013. Astronics is a leading provider of advanced technologies for the global aerospace and defense indu stries, including Electronic Circuit Breakers for business jets such as the E clipse 500, Pilatus PC-24, and Lear 85, under the Astronics=99 CorePow er=C2=AE brand. Astronics will continue to manufacture, sell and support the Vertical Power ECB products and is excited to enter into the experimental a ircraft and Light Sport aircraft markets under the Vertical Power brand. Vertical Power offices will be closed during the month of December as the te am moves to the Astronics=99 offices in Everett, Washington. Please be patient with us during this transition; E-mail and telephone call-back supp ort will be provided during this period. Thank you for your support over the years, and I hope you are as excited abo ut this next step in the journey as we are here. I truly believe that we hav e found a great new home for our products with Astronics. Kind regards, Marc Ausman www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 10, 2013
Bob Turner wrote: > Unfortunately VP has just been sold. Remains to be seen if the new company will continue production and support for E-AB equipment. Nothing unfortunate about it at all. Here is a quote from their web site: "Astronics will continue to manufacture, sell and support the Vertical Power ECB products and is excited to enter into the experimental aircraft and Light Sport aircraft markets under the Vertical Power brand." John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415345#415345 ________________________________________________________________________________
Date: Dec 10, 2013
And here is another famous quote; "If you Doctor,, you can keep your Doctor". ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Tuesday, December 10, 2013 3:17:12 PM Subject: RV10-List: Re: RV 10 Aileron Trim easy fix... Bob Turner wrote: > Unfortunately VP has just been sold. Remains to be seen if the new company will continue production and support for E-AB equipment. Nothing unfortunate about it at all. Here is a quote from their web site: "Astronics will continue to manufacture, sell and support the Vertical Power ECB products and is excited to enter into the experimental aircraft and Light Sport aircraft markets under the Vertical Power brand." John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415345#415345 ________________________________________________________________________________
Date: Dec 10, 2013
davidsoutpost(at)comcast. wrote: > And here is another famous quote; "If you Doctor,, you can keep your Doctor". And just what is that supposed to mean? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415349#415349 ________________________________________________________________________________
Date: Dec 10, 2013
Typo..."If you like your doctor,,,,, you can keep your doctor". (Obama's big lie) ----- Original Message ----- From: "johngoodman" <johngoodman(at)earthlink.net> Sent: Tuesday, December 10, 2013 4:03:59 PM Subject: RV10-List: Re: RV 10 Aileron Trim easy fix... davidsoutpost(at)comcast. wrote: > And here is another famous quote; "If you Doctor,, you can keep your Doctor". And just what is that supposed to mean? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415349#415349 ________________________________________________________________________________
Date: Dec 10, 2013
I thought politics were supposed to be verboten here. Failed political "promise" does not equal "big lie". We don't need to sully this list with all the failed promises of both parties. I'll take the health care foibles any day over the lies about "proof of weapons of mass destruction" and starting wars against people that have not attacked our country. Back to trimming my cowling and continued fiberglass hell. On Tue, Dec 10, 2013 at 3:01 PM, wrote: > Typo..."If you like your doctor,,,,, you can keep your doctor". (Obama's > big lie) > > ------------------------------ > *From: *"johngoodman" <johngoodman(at)earthlink.net> > *To: *rv10-list(at)matronics.com > *Sent: *Tuesday, December 10, 2013 4:03:59 PM > > *Subject: *RV10-List: Re: RV 10 Aileron Trim easy fix... > > > davidsoutpost(at)comcast. wrote: > > And here is another famous quote; "If you Doctor,, you can keep your > Doctor". > > > And just what is that supposed to mean? > > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415349#415349 > > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 11, 2013
The point I am making is that just because someone, or company in this case, makes a statement as factual, does not always mean its true. The ACA tie-in was only because it is something fresh that pretty much everyone can relate to. Take a chill-pill Kelly and fit your cowl. ----- Original Message ----- From: "Kelly McMullen" <apilot2(at)gmail.com> Sent: Tuesday, December 10, 2013 7:04:40 PM Subject: Re: RV10-List: Re: RV 10 Aileron Trim easy fix... I thought politics were supposed to be verboten here. Failed political "promise" does not equal "big lie". We don't need to sully this list with all the failed promises of both parties. I'll take the health care foibles any day over the lies about "proof of weapons of mass destruction" and starting wars against people that have not attacked our country. Back to trimming my cowling and continued fiberglass hell. On Tue, Dec 10, 2013 at 3:01 PM, < davidsoutpost(at)comcast.net > wrote: Typo..."If you like your doctor,,,,, you can keep your doctor". (Obama's big lie) From: "johngoodman" < johngoodman(at)earthlink.net > Sent: Tuesday, December 10, 2013 4:03:59 PM Subject: RV10-List: Re: RV 10 Aileron Trim easy fix... davidsoutpost(at)comcast. wrote: > And here is another famous quote; "If you Doctor,, you can keep your Doctor". And just what is that supposed to mean? John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415349#415349 _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 10, 2013
I sure hope it's a good thing, I'm in the middle of designing? the electrical system. Perhaps I should pause for a while to see what may be coming out? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415372#415372 ________________________________________________________________________________
Date: Dec 11, 2013
Oh, forgot to mention I bought the VP-X system already, and have begun installing it. -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415391#415391 ________________________________________________________________________________
Date: Dec 12, 2013
Subject: WIng Bolt Check
Wondering if anybody out there is checking torque on wing bolts at conditional or some other interval of hours? (Regardless of torque stripe being good) Thanks Chris N919AR ________________________________________________________________________________
Date: Dec 12, 2013
Subject: Re: WIng Bolt Check
Why? The friction to start the nut moving will exceed the existing torque setting. If isn't like an old engine with temperature cycles and gaskets that shrink with break-in and heat. If your torque seal hasn't budged, the bolt and nut haven't either. On Thu, Dec 12, 2013 at 1:23 PM, Chris wrote: > Wondering if anybody out there is checking torque on wing bolts at > conditional or some other interval of hours? (Regardless of torque stripe > being good) > Thanks > Chris > N919AR > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 13, 2013
I think the torque value is considerably greater than the friction on the nu t locking mechanism. I have not checked the torque on these bolts as its not critical. These bol ts are in double shear and do not need much torque to do their job. In gene ral torque is critical in bolts that see considerable tension loading. I check the torque seal, number of exposed threads, and for any annomalies. Niko Nikolaos Napoli > On Dec 12, 2013, at 5:34 PM, Kelly McMullen wrote: > > Why? The friction to start the nut moving will exceed the existing torque s etting. If isn't like an old engine with temperature cycles and gaskets that shrink with break-in and heat. If your torque seal hasn't budged, the bolt a nd nut haven't either. > > >> On Thu, Dec 12, 2013 at 1:23 PM, Chris wrote: >> Wondering if anybody out there is checking torque on wing bolts at condit ional or some other interval of hours? (Regardless of torque stripe being g ood) >> Thanks >> Chris >> N919AR >> >> >> _blank">www.aeroelectric.com >> .com" target="_blank">www.buildersbooks.com >> ="_blank">www.homebuilthelp.com >> ="_blank">www.mypilotstore.com >> ank">www.mrrace.com >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com > > > > -- > > - sent from the microchip implanted in my forearm > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 13, 2013
Agreed. I was referring to the torque that would actually tighten the nut, not that to just overcome the nylock friction. On Fri, Dec 13, 2013 at 2:03 PM, Nikolaos Napoli wrote: > I think the torque value is considerably greater than the friction on the > nut locking mechanism. > > I have not checked the torque on these bolts as its not critical. These > bolts are in double shear and do not need much torque to do their job. In > general torque is critical in bolts that see considerable tension loading. > > I check the torque seal, number of exposed threads, and for any annomalies. > > Niko > > Nikolaos Napoli > > On Dec 12, 2013, at 5:34 PM, Kelly McMullen wrote: > > Why? The friction to start the nut moving will exceed the existing torque > setting. If isn't like an old engine with temperature cycles and gaskets > that shrink with break-in and heat. If your torque seal hasn't budged, the > bolt and nut haven't either. > > > On Thu, Dec 12, 2013 at 1:23 PM, Chris wrote: > >> Wondering if anybody out there is checking torque on wing bolts at >> conditional or some other interval of hours? (Regardless of torque stripe >> being good) >> Thanks >> Chris >> N919AR >> >> * >> >> _blank">www.aeroelectric.com <http://www.aeroelectric.com> >> .com" target="_blank">www.buildersbooks.com <http://www.buildersbooks.com> >> ="_blank">www.homebuilthelp.com <http://www.homebuilthelp.com> >> ="_blank">www.mypilotstore.com <http://www.mypilotstore.com> >> ank">www.mrrace.com <http://www.mrrace.com> >> _blank">http://www.matronics.com/contribution >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> * >> >> > > > -- > > - sent from the microchip implanted in my forearm > > * > > D============================================ > ot;">www.aeroelectric.com <http://www.aeroelectric.com> > books.com <http://books.com>"">www.buildersbooks.com > quot;">www.homebuilthelp.com <http://www.homebuilthelp.com> > quot;">www.mypilotstore.com <http://www.mypilotstore.com> > ">www.mrrace.com <http://www.mrrace.com> > ot;">http://www.matronics.com/contribution > D============================================ > List"">http://www.matronics.com/Navigator?RV10-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > * > > * > > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Fiberfrax on the firewall
Date: Dec 15, 2013
Has anyone out there used a product called FYREWRAP to insulate their firewall? It is a fiberfrax-like product with stainless steel foil on one side. Regardless of the product, is it better to insulate on the engine side or the cabin side (or not insulate at all?) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415631#415631 ________________________________________________________________________________
Date: Dec 15, 2013
Subject: Re: Fiberfrax on the firewall
Probably approaches primer in various opinions. I used fiberfrax on the cabin side of firewall. I prefer having engine side of firewall smooth, so that oil and dirt can be easily cleaned. Others will wax poetic about advantages of engine side of firewall. On 12/15/2013 6:25 PM, bob88 wrote: > > Has anyone out there used a product called FYREWRAP to insulate their firewall? It is a fiberfrax-like product with stainless steel foil on one side. Regardless of the product, is it better to insulate on the engine side or the cabin side (or not insulate at all?) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415631#415631 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Dec 15, 2013
Cabin side. That way the grease and grime does not get into the insulation. I used this for the whole plane (the double sided version): http://www.aircraftspruce.com/pages/cs/insulation/insulator3.php And this tape to hold it all in: http://www.aircraftspruce.com/pages/cs/insulation/insultape.php If you want to do the minimalistic approach then just do the inside of the firewall and the tunnel floor. I did all the hidden areas between the floorboards, under the seats and the where the hull has a double wall. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Sunday, December 15, 2013 8:26 PM Subject: RV10-List: Fiberfrax on the firewall Has anyone out there used a product called FYREWRAP to insulate their firewall? It is a fiberfrax-like product with stainless steel foil on one side. Regardless of the product, is it better to insulate on the engine side or the cabin side (or not insulate at all?) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415631#415631 ________________________________________________________________________________
Date: Dec 16, 2013
Subject: 2013 List of Contributors
Dear Listers, The 2013 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2013 Fund Raiser List of Contributors: http://www.matronics.com/loc/2013.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Dec 16, 2013
Carl, I used almost exactly the same thing. At the time I think it was called Foss Thermozite Plus. But the stuff I got (the "plus") was silver on 2 sides. You didn't run across that anywhere, did you? I will probably use it again on the RV-14. I used red RTV to stick it to the side walls and firewall, and it hasn't loosened up at all....that was the benefit to me of the silver on 2 sides. The tape would work too of course, but if I can find the "plus" stuff easily I'll do that. Tim On 12/15/2013 8:48 PM, Carl Froehlich wrote: > > Cabin side. That way the grease and grime does not get into the insulation. > > I used this for the whole plane (the double sided version): > http://www.aircraftspruce.com/pages/cs/insulation/insulator3.php > And this tape to hold it all in: > http://www.aircraftspruce.com/pages/cs/insulation/insultape.php > > If you want to do the minimalistic approach then just do the inside of the > firewall and the tunnel floor. I did all the hidden areas between the > floorboards, under the seats and the where the hull has a double wall. > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: Sunday, December 15, 2013 8:26 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fiberfrax on the firewall > > > Has anyone out there used a product called FYREWRAP to insulate their > firewall? It is a fiberfrax-like product with stainless steel foil on one > side. Regardless of the product, is it better to insulate on the engine side > or the cabin side (or not insulate at all?) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415631#415631 > > ________________________________________________________________________________
Date: Dec 16, 2013
Carl, link below has an option to buy it with foil on both sides. -Sean #40303 (struggling to complete the last 90%) > Tim Olson > December 16, 2013 at 8:31 AM > > Carl, > I used almost exactly the same thing. At the time I think it was called > Foss Thermozite Plus. But the stuff I got (the "plus") was silver on 2 > sides. You didn't run across that anywhere, did you? I will probably > use > it again on the RV-14. I used red RTV to stick it to the side walls > and firewall, and it hasn't loosened up at all....that was the benefit > to me of the silver on 2 sides. The tape would work too of course, but > if I can find the "plus" stuff easily I'll do that. > > Tim > > ________________________________________________________________________________
Date: Dec 16, 2013
ACS has both the single and double side aluminum versions. They are listed as different part numbers (09-06016 for double sided). The double side makes the most sense as it provides a barrier to getting "stuff" into the insulation material. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, December 16, 2013 9:31 AM Subject: Re: RV10-List: Fiberfrax on the firewall Carl, I used almost exactly the same thing. At the time I think it was called Foss Thermozite Plus. But the stuff I got (the "plus") was silver on 2 sides. You didn't run across that anywhere, did you? I will probably use it again on the RV-14. I used red RTV to stick it to the side walls and firewall, and it hasn't loosened up at all....that was the benefit to me of the silver on 2 sides. The tape would work too of course, but if I can find the "plus" stuff easily I'll do that. Tim On 12/15/2013 8:48 PM, Carl Froehlich wrote: > --> > > Cabin side. That way the grease and grime does not get into the insulation. > > I used this for the whole plane (the double sided version): > http://www.aircraftspruce.com/pages/cs/insulation/insulator3.php > And this tape to hold it all in: > http://www.aircraftspruce.com/pages/cs/insulation/insultape.php > > If you want to do the minimalistic approach then just do the inside of > the firewall and the tunnel floor. I did all the hidden areas between > the floorboards, under the seats and the where the hull has a double wall. > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: Sunday, December 15, 2013 8:26 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Fiberfrax on the firewall > > > Has anyone out there used a product called FYREWRAP to insulate their > firewall? It is a fiberfrax-like product with stainless steel foil on > one side. Regardless of the product, is it better to insulate on the > engine side or the cabin side (or not insulate at all?) > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415631#415631 > > ________________________________________________________________________________
Date: Dec 16, 2013
I guess it's Monday...I looked right at it and didn't see. Thanks Carl! Tim On 12/16/2013 8:50 AM, Carl Froehlich wrote: > > ACS has both the single and double side aluminum versions. They are listed > as different part numbers (09-06016 for double sided). The double side > makes the most sense as it provides a barrier to getting "stuff" into the > insulation material. > > Carl > ________________________________________________________________________________
Date: Dec 16, 2013
I didn't see a link. I did look at the Foss Thermozite product just now. I am concerned that the fiber between the foil layers is polyester, from shredded plastic bottles. I wonder how well that stands up to heat compared to ceramic materials like fiberfrax. If I could find genuine fiberfrax sandwiched in foil I would love to add that to the fiberfrax I already installed. On Mon, Dec 16, 2013 at 7:45 AM, Sean Stephens wrote: > > Carl, link below has an option to buy it with foil on both sides. > > -Sean #40303 (struggling to complete the last 90%) > > Tim Olson >> December 16, 2013 at 8:31 AM >> >> >> Carl, >> I used almost exactly the same thing. At the time I think it was called >> Foss Thermozite Plus. But the stuff I got (the "plus") was silver on 2 >> sides. You didn't run across that anywhere, did you? I will probably use >> it again on the RV-14. I used red RTV to stick it to the side walls >> and firewall, and it hasn't loosened up at all....that was the benefit >> to me of the silver on 2 sides. The tape would work too of course, but >> if I can find the "plus" stuff easily I'll do that. >> >> Tim >> >> >> >> >> >> >> >> > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 16, 2013
I used a product from Aircraft Spruce called Firewall 2000 Ceramic Blanket: http://www.aircraftspruce.com/catalog/appages/firewall2000.php I used a special adhesive to attach it - still holding strong after 2.5 years of flying. The hardest part is not cutting yourself with the stainless steel foil side. On the cockpit side I used Soundex. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415737#415737 ________________________________________________________________________________
Date: Dec 16, 2013
I used 1/8" bare fiberfrax on cabin side of fw, tunnel bottom and tunnel fwd. I used the recommended 2000F glue from ACS. No problems with it coming loose or tunnel heat. I burn tested a sample and was not overwelmed with outgassing. I installed an adjustable snap switch limit set to 230F near cowl outlet. It has went off once cruising at 16,500', full gross, LOP, 6 deg pos pitch(normally 2-3). Assuming thin air heated up more passing cylinders. Knowing you have a fire should be top priority. Along with switch/led, I have set my fuel flow limit to 26 gph. Normal on takeoff is 25.6 -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415761#415761 ________________________________________________________________________________
Date: Dec 16, 2013
I did and would recommend checking at first condition insp or 100 hrs after build completion. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415763#415763 ________________________________________________________________________________
Date: Dec 16, 2013
Kind of a belt and suspenders thing. If you properly torqued on final assembly, and put torque seal on each bolt, to check it you have to remove the torque seal, and if the nut does not move at proper torque you haven't learned much. If you really have doubt about the torque, you need to back off the nut, and bring it back up to proper torque. Questionable whether you gain much. The wing bolts aren't something that will work loose with changing forces on the wing, or with temperature changes. There was a service bulletin to change wing bolts on Bonanzas and Barons, which were also close tolerance bolts. Found they did more damage than leaving them alone. On 12/16/2013 3:04 PM, rv10flyer wrote: > > I did and would recommend checking at first condition insp or 100 hrs after build completion. > > -------- > Wayne G. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415763#415763 > > ________________________________________________________________________________
Date: Dec 16, 2013
The one thing I can think of is that if the bolt shank was pinched or really tight during installation, could the nut come to final torque without pulling the bolt head tight against the spar? After flying, the bolt head could move aft and now there is no torque? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415772#415772 ________________________________________________________________________________
Date: Dec 16, 2013
I'm not there yet so bear with me. The spar bolts, in this installation, are in shear so I'm having a hard time understanding why the focus is on the proper torque at some time later .... while the torque seal is intact. Kelly, IMHO, got it right the first time .... checking the torque in this instance doesn't mean diddly unless you back off the nut and re-torque .... and the exercise hasn't accomplished anything except to place the mind at ease. It was a waste of worry to begin with. So, where did I go wrong??? Linn On 12/16/2013 9:48 PM, Bob Turner wrote: > > The one thing I can think of is that if the bolt shank was pinched or really tight during installation, could the nut come to final torque without pulling the bolt head tight against the spar? After flying, the bolt head could move aft and now there is no torque? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415772#415772 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 17, 2013
See this thread http://www.vansairforce.com/community/showthread.php?t=37012&highlight=insulation+glue -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415783#415783 ________________________________________________________________________________
Subject: Re: Fuel Pump Issue
Date: Dec 17, 2013
Update on my fuel pump issue... I replaced the suspect Tempest fuel with a new Lycoming pump and no longer have any engine stumble issues. The fuel pressure now consistently displays ~20psi. No more stumbles when switching tanks or at high angles of attack. I just finished up my annual and closely examined the entire fuel system for any blockages... Nothing was found in any screen. I also opted to leave my Flowscan sensor in the tunnel as it's not broke, so there's nothing to fix. Cheers, Jay N433RV - Flying [quote="hotwheels"]I spoke to a couple of vendors and my A&P of choice yesterday. The consensus was to: * Revisit sensor settings and connections (I don't expect this one to reveal much) * Closely examine the fuel system for anything obvious. * Replace the Tempest Fuel Pump with a (new, not rebuilt) genuine Lycoming Pump 18 psi is definitely not acceptable. Van's had no input (guess who sold me the fuel pump). They claimed they'd never heard of such a thing and were out of touch (their words) with builders. Really? If so, that's disturbing on several levels. This particular component is too darn critical to screw around with. It needs to work and be a known quantity. Jay 433RV - flying[/quote] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415800#415800 ________________________________________________________________________________
Date: Dec 17, 2013
The wing bolt question was a question to discuss any potential issues that maybe I had not thought of... not a "worry". I do know I do not want to fly around with them loose so I will leave it at that. Maybe it entered my mind from having a Bonanza years ago and having the wing bolt bulletin Kelly mentioned. Thanks for the replies and considerations. Chris N9191AR ----- Original Message ----- From: Linn Walters <flying-nut(at)cfl.rr.com> Subject: Re: RV10-List: Re: WIng Bolt Check I'm not there yet so bear with me. The spar bolts, in this installation, are in shear so I'm having a hard time understanding why the focus is on the proper torque at some time later .... while the torque seal is intact. Kelly, IMHO, got it right the first time .... checking the torque in this instance doesn't mean diddly unless you back off the nut and re-torque .... and the exercise hasn't accomplished anything except to place the mind at ease. It was a waste of worry to begin with. So, where did I go wrong??? Linn On 12/16/2013 9:48 PM, Bob Turner wrote: > > The one thing I can think of is that if the bolt shank was pinched or really tight during installation, could the nut come to final torque without pulling the bolt head tight against the spar? After flying, the bolt head could move aft and now there is no torque? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415772#415772 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Wire labels
Date: Dec 17, 2013
Anyone out there have a good system or product for labeling wires. I'm starting to lose track of which goes where... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415805#415805 ________________________________________________________________________________
Date: Dec 18, 2013
Subject: Re: Wire labels
Bob, on my last project I produced wire labels out of an Excel sheet (very tiny font) cut it and did put it on the wire with some clear heatshrink. Worked out fine, however there are as well nice labeling units around (check in google for wire label printer. Cheers Werner On 18.12.2013 07:40, bob88 wrote: > > Anyone out there have a good system or product for labeling wires. I'm starting to lose track of which goes where... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415805#415805 > > ________________________________________________________________________________
Subject: Cutting UHMV blocks
Date: Dec 18, 2013
Guys I have a thing cutting UHMV blocks, like the ones used in the flaps system. My cuts are never straight, they leave many burrs and the look of the final piece is not good. I don't have a band saw, I'm using a hack saw and sometimes a cutting disc in a Dremell tool. Can someone point me out the best method and tool to cut UHMV blocks, please. Thanks Carlos ________________________________________________________________________________
Date: Dec 18, 2013
Subject: Re: Cutting UHMV blocks
Carlos, use a very fine tooth metal cutting blade and a slow speed. Burrs can be removed with a file. I had good success as well with a standard hand metall saw and the block clamped in a vise. Cheers Werner On 18.12.2013 09:39, Carlos Trigo wrote: > Guys > > I have a thing cutting UHMV blocks, like the ones used in the flaps system. > > My cuts are never straight, they leave many burrs and the look of the > final piece is not good. > > I dont have a band saw, Im using a hack saw and sometimes a cutting > disc in a Dremell tool. > > Can someone point me out the best method and tool to cut UHMV blocks, > please. > > Thanks > > Carlos > > * > > * > ________________________________________________________________________________
Date: Dec 18, 2013
I've used this system from Hawk Labeling on three airplanes. With the cost of the machine and the heat shrink tubing it's certainly not the least expensive option. But it produces an exceptionally nice wire labels that looks very professional and are easy to produce and read. http://www.hawklabeling.com/store/department.php?cPath=3_495 Rick > On Dec 18, 2013, at 1:40 AM, bob88 wrote: > > > Anyone out there have a good system or product for labeling wires. I'm starting to lose track of which goes where... > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415805#415805 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 18, 2013
I bought white heat-shrink and wrote the info on before shrinking. Use the ultra fine sharpie. In places where the wire was smaller than the heated shrink I put on a couple layers of blue painters tape. I have a couple sizes of drift pins/nail sets that I used to hold the heat shrink while marking. Linn On 12/18/2013 1:40 AM, bob88 wrote: > > Anyone out there have a good system or product for labeling wires. I'm starting to lose track of which goes where... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415805#415805 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: wire labels
Date: Dec 18, 2013
I use white, blue and yellow heat shrink tubing, write the label on the tubing with a sharpie and then shrink. The writing shrinks down with the tubing and is very legible. It actually looks cool, (like how did you write so small?!?). The color of the tubing can be coded as well. Yellow is power from CB to switch, Blue is power from switch to devise, as an example. Using a sharpie makes a very permanent label, and if you use the correct size tubing, the label is difficult to slide off the wire, but can be slid down to the terminal after crimping. Initially shrink the label back about six inches so it won=99t slide off until you final trim the wire, then move it down to the terminal. Been doing it this way for many years and the labels still look like the day they were done. Chris Hukill finishing up wiring and getting ready to hang the motor ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Dec 18, 2013
The sharpie method is quick and easy, as others are describing. Works great. One thing about every label printer I've used is that they waste a lot of tubing. I buy white tubing on a reel and just snip each =8Bpi ece as needed. Dave Saylor 831-750-0284 CL On Tue, Dec 17, 2013 at 10:40 PM, bob88 wrote: > > Anyone out there have a good system or product for labeling wires. I'm > starting to lose track of which goes where... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415805#415805 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Fuel Pump & Filter for sale
Date: Dec 18, 2013
Thanks to all, just to let you know the pump and filter are sold. Rich ________________________________________________________________________________
Date: Dec 18, 2013
At 10:40 PM 12/17/2013 Tuesday, you wrote: > >Anyone out there have a good system or product for labeling wires. I'm starting to lose track of which goes where... I use this product and love it: <http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=2273&category=9044&log=173811&row=1>http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=2273&category=9044&log=173811&row=1 Attached are a few samples of what they look like in action. Matt - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Dec 18, 2013
Matt: Your labels look great but you didn't mention what you use to do them... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415828#415828 ________________________________________________________________________________
Date: Dec 19, 2013
Check out this web page from my RV-8 building site. All the det's are there: http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=2273&category=9044&log=173811&row=1 Matt Dralle At 10:27 AM 12/18/2013 Wednesday, you wrote: > >Matt: >Your labels look great but you didn't mention what you use to do them... Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Dec 19, 2013
I bought a gadget called a Bee3. It was pretty cheap and easy to use with nice results, but I do have probably $50 into the cartridges. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415860#415860 ________________________________________________________________________________
Date: Dec 19, 2013
I use a BRADY BMP21 label printer that sells for around 200.00. With it you can print wire marker sleeves that slide on the wire and shrink with heat. They have 4 sizes and you can also buy 3 sizes of flat label tape. The system works great. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415866#415866 ________________________________________________________________________________
Date: Dec 19, 2013
Matt, You should be ashamed [Laughing] Putting on photos so big that we have to scroll left to right to read even one sentence. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415872#415872 ________________________________________________________________________________
Date: Dec 19, 2013
John, You just need a larger monitor and/or phone! :^) Bob Sent from my iPhone On Dec 19, 2013, at 3:37 PM, "johngoodman" wrote: Matt, You should be ashamed [Laughing] Putting on photos so big that we have to scroll left to right to read even one sentence. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415872#415872 ________________________________________________________________________________
Date: Dec 20, 2013
Yeah, you're totally right, John. I feel guilty! I was going to use my normal scaled versions but the detail of the lettering wasn't good enough to show them off. So I took the full-resolution versions and just cropped down to the detail I wanted. Trouble is, those were STILL too huge! Darn that 36MP Nikon D800! :-) Matt At 12:37 PM 12/19/2013 Thursday, you wrote: > >Matt, >You should be ashamed [Laughing] Putting on photos so big that we have to scroll left to right to read even one sentence. >John > >-------- >#40572 Phase One complete and flying. - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Subject: Windshield fairing
Date: Dec 20, 2013
Does anyone have an opinion and/or experience with the Blue Skunk windshield fairing? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415925#415925 ________________________________________________________________________________
Date: Dec 20, 2013
Subject: Re: Windshield fairing
I considered it for a long time. I ultimately decided to stick with the plans. Two reasons. The windshield is already bonded on 3 sides, meaning it cannot be removed without a complete rework of the canopy lip and the other reason is that a metal fairing on the bottom means drilling for a bunch of rivets that you would have to drill out for replacement and the plane would look more like a typical spam can. So windshield replacement is going to require both cleaning out old canopy lip and smoothing to take new glass, and removing the fiberglass fairing and making a new one isn't going to be nearly as hard the 2nd time around. I don't plan on being able to physically fly as long as the original windshield should last, absent physical damage, so I decided to stay with the plans. On Fri, Dec 20, 2013 at 10:53 AM, bob88 wrote: > > Does anyone have an opinion and/or experience with the Blue Skunk > windshield fairing? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415925#415925 > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: oil filter and B&C alternator
Date: Dec 20, 2013
Has anyone used a B&C stby alternator on the vacuum pad with an angle oil filter? I need to know if there is an engine mount clearance issue, and if so, what thickness spacers are needed to make it all fit. Chris Hukill ________________________________________________________________________________
Date: Dec 20, 2013
I have the B and C standby alternator and the B and C oil filter adaptor. N o clearance issues. Leon Everett From: cjhukill(at)cox.net Subject: RV10-List: oil filter and B&C alternator Date: Fri=2C 20 Dec 2013 16:42:07 -0800 Has anyone used a B&C stby alternator on the vacuum pad with an angle oil filter? I need to know if there is an engine mount clearance issue=2C a nd if so=2C what thickness spacers are needed to make it all fit. Chris Hukill ________________________________________________________________________________
Subject: Re: oil filter and B&C alternator
Date: Dec 20, 2013
You can do it. Call B&C and they will specify the spacers needed to fit the - 10. Sent from my iPad > On Dec 20, 2013, at 7:42 PM, "Chris Hukill" wrote: > > Has anyone used a B&C stby alternator on the vacuum pad with an angle oil f ilter? I need to know if there is an engine mount clearance issue, and if so , what thickness spacers are needed to make it all fit. > Chris Hukill > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 20, 2013
I have angled oil filter. Fits fine but if it wasn't angled it would not fi t! From: leeverett(at)msn.com Subject: RE: RV10-List: oil filter and B&C alternator Date: Fri=2C 20 Dec 2013 18:56:04 -0600 I have the B and C standby alternator and the B and C oil filter adaptor. N o clearance issues. Leon Everett From: cjhukill(at)cox.net Subject: RV10-List: oil filter and B&C alternator Date: Fri=2C 20 Dec 2013 16:42:07 -0800 Has anyone used a B&C stby alternator on the vacuum pad with an angle oil filter? I need to know if there is an engine mount clearance issue=2C a nd if so=2C what thickness spacers are needed to make it all fit. Chris Hukill et=_blank>www.aeroelectric.com ks.com" target=_blank>www.buildersbooks.com rget=_blank>www.homebuilthelp.com rget=_blank>www.mypilotstore.com =_blank>www.mrrace.com rget=_blank>http://www.matronics.com/contribution ist" target=_blank>http://www.matronics.com/Navigator?RV10-List ank>http://forums.matronics.com ________________________________________________________________________________
Date: Dec 20, 2013
Sounds like most have had no problems. However, I could not make it work. I have the B&C 20 Amp Stby Alternator on the vacuum pad and I could not find an adapter that would permit me to mount the oil filter. I tried various spacers and adapters from B&C and one or two other vendors, to no avail. My engine is a C4B5, so that might be the difference. The good news is, I decided to bite the bullet and purchase and install the Airwolf remote oil filter. I mounted it on the lower RH firewall. Sure makes for easy, mess free, oil filter changes. I am glad it turned out that way. -------- David Maib RV-10 #40559 Transition Trainer New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415945#415945 ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Dec 21, 2013
I have a C4B5 and I had no issues getting it to work out. I have the angle o il adapter and the B&C vacuum pad SD20. I think the spacer I used was 3/4". If you look on their web page under gear driven alternators and SD20, you' ll find the RV-10 specific info. http://www.bandc.biz/extensionforsd-20forrv10homebuilt.aspx -Mike Kraus Sent from my iPhone > On Dec 20, 2013, at 9:19 PM, "dmaib(at)me.com" wrote: > > > Sounds like most have had no problems. However, I could not make it work. I have the B&C 20 Amp Stby Alternator on the vacuum pad and I could not find a n adapter that would permit me to mount the oil filter. I tried various spac ers and adapters from B&C and one or two other vendors, to no avail. My engi ne is a C4B5, so that might be the difference. The good news is, I decided t o bite the bullet and purchase and install the Airwolf remote oil filter. I m ounted it on the lower RH firewall. Sure makes for easy, mess free, oil filt er changes. I am glad it turned out that way. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415945#415945 > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Dec 21, 2013
Subject: Extended Tankage
HI,=0A=0ATo those who have converted their leading edges to fully wet can y ou please advise what changes you made to the structure, if any, and if any one has had the final result structurally tested/analysed?- I know here i n Oz a few people have added extra tankage to the outboard leading edge (15 Gal and that has been structurally tested) but I know of no one who has gon e for the full 30 Gal.=0A=0AJohn Nys obviously did this with the first cust omer built RV-10 but he appears to have disappeared without trace.=0A=0AWit h best wishes and Seasons Greetings,=0A=0ARodger=0AIn sun drenched Perth, W A=0A ________________________________________________________________________________
Date: Dec 21, 2013
To make the combo work you need a spacer for both the alternator and oil filter adapter. For the oil filter adapter it's the 1.4" spacer. For the SD-20 it's a spacer kit that includes a replacement shear coupling. If you buy the spacer kit at the same time as the SD-20 they probably swap out the shear coupling before you get it. The SD-20 spacer is .75". I worked with Bill (B&C) as the original installation of this combo on an RV-10. Bob On Friday, December 20, 2013, Michael Kraus wrote: > I have a C4B5 and I had no issues getting it to work out. I have the > angle oil adapter and the B&C vacuum pad SD20. I think the spacer I used > was 3/4". If you look on their web page under gear driven alternators and > SD20, you'll find the RV-10 specific info. > > http://www.bandc.biz/extensionforsd-20forrv10homebuilt.aspx > > -Mike Kraus > > Sent from my iPhone > > On Dec 20, 2013, at 9:19 PM, "dmaib(at)me.com 'dmaib(at)me.com');>" 'dmaib(at)me.com');>> wrote: > > 'dmaib(at)me.com');>" 'dmaib(at)me.com');>> > > Sounds like most have had no problems. However, I could not make it work. > I have the B&C 20 Amp Stby Alternator on the vacuum pad and I could not > find an adapter that would permit me to mount the oil filter. I tried > various spacers and adapters from B&C and one or two other vendors, to no > avail. My engine is a C4B5, so that might be the difference. The good news > is, I decided to bite the bullet and purchase and install the Airwolf > remote oil filter. I mounted it on the lower RH firewall. Sure makes for > easy, mess free, oil filter changes. I am glad it turned out that way. > > -------- > David Maib > RV-10 #40559 > Transition Trainer > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415945#415945 > > > www.iltHELP www.homebuilthelp.comwwwbsp;--> <http://www.mrrace.com>http://www.matrp; -Matt > Dralle, List Admin. <http://www.matronics.com/contribution> > ==========================; - The RV10-List Email > Forumm/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > > > * > > * > > ________________________________________________________________________________
Date: Dec 21, 2013
Just a little more explanation for those that may have had issues with this and/or those trying to understand why the spacers. To install the B&C oil filter adapter on an RV-10 you need to use their 1.4" spacer regardless of whether or not you intend to also use their SD-20 alternator. This adapter orients the filter so it's sticking up at about the 11 o'clock position. The spacer is needed to shift the filter aft for clearance with the top engine mount cross-member. If you are installing an SD-20 with a stock oil filter adapter, it will bolt right up to the stock vacuum pad. If however you've got their oil filter adapter, one of the SD-20 case screw bosses sticks out far enough that the filter adapter causes interference. So, the final solution Bill came up with was adding a 3/4" spacer for the SD-20. This also required that the standard SD-20 shear coupling get replaced with one that ties into account the extra 3/4". Bill then made a kit for the SD-20 that includes the spacer, new shear coupling and longer studs for the vacuum pad. As I said in my earlier post, I'm pretty sure if you order the SD-20 and kit at the same time that they install the new shear coupling but it's pretty simple to do yourself. There are other brands of both angled oil filter adapters and vacuum pad alternators but I don't know the specifics of what it takes to make all those permutations work. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415969#415969 ________________________________________________________________________________
Date: Dec 21, 2013
bob88 wrote: > Does anyone have an opinion and/or experience with the Blue Skunk windshield fairing? Yes, I used the M.L. Skunk Works windshield fairing. I got the impression that Kelly thought that it's a whole windshield, it isn't. All it is, is a replacement for the built up fiberglass fairing at the bottom of the windshield. It's simply two partially shaped strips of aluminum that you rivet together and custom shape to your windshield. With minimum use of a shrinker/stretcher I got a great fit. As you fit, you will drill cleco holes to hold it in place. Once it's the way you want, you can glue it to the windshield (I used Silpruf 2000) and rivet it on. The real purpose of the Silpruf was to give it a good, black, look on the inside. It was easy to rivet if the panel is out. Just make sure the holes were drilled in places not-too-close to anything else, so it's easy to get a bucking bar in there. When it comes time to paint, you just feather on some micro to hide it. I am very pleased with the results and would definitely do it again. By the way, the price is the same that I paid in 2009. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415973#415973 ________________________________________________________________________________
Date: Dec 21, 2013
You mis-understood what I wrote (or meant to write). I understand what it is, just an aluminum strip formed to enclose the base of the windshield. It is individual choice as to whether you like that appearance. If you plan to cover the aluminum with micro to smooth out the appearance, I'm not sure that you are saving a lot of work. I did the 10 layer fiberglass layup in about 4 stages. I will do final micro work when our weather warms up a bit. Maybe 10-12 hours total work between sanding and layup. There will still be glass/micro work around the sides and top of the windshield as well as side windows. So you probably can save 6-8 hours overall. Yes, I hate fiberglass work, which made me consider the aluminum seriously. The glass fairing was not as bad as I anticipated. Certainly much less than the canopy and doors. So the pros are time savings and maybe slightly easier removal for replacement windshield. I choose to hope I never have to replace the windshield. Never have on the 2 certified aircraft I have owned for a total 38 years. Cons are cost and need to do riveting behind instrument panel, and maybe perceived appearance. On 12/21/2013 7:39 AM, johngoodman wrote: > > > bob88 wrote: >> Does anyone have an opinion and/or experience with the Blue Skunk windshield fairing? > > Yes, I used the M.L. Skunk Works windshield fairing. I got the impression that Kelly thought that it's a whole windshield, it isn't. All it is, is a replacement for the built up fiberglass fairing at the bottom of the windshield. It's simply two partially shaped strips of aluminum that you rivet together and custom shape to your windshield. With minimum use of a shrinker/stretcher I got a great fit. As you fit, you will drill cleco holes to hold it in place. Once it's the way you want, you can glue it to the windshield (I used Silpruf 2000) and rivet it on. The real purpose of the Silpruf was to give it a good, black, look on the inside. > It was easy to rivet if the panel is out. Just make sure the holes were drilled in places not-too-close to anything else, so it's easy to get a bucking bar in there. > When it comes time to paint, you just feather on some micro to hide it. I am very pleased with the results and would definitely do it again. By the way, the price is the same that I paid in 2009. > > John > > -------- > #40572 Phase One complete and flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415973#415973 > > > > ________________________________________________________________________________
Subject: Re: Extended Tankage
Date: Dec 21, 2013
Rodger, I was in Perth back in March of 2011 - beautiful place. Anyway, I feel I should comment on the extended tanks. I've seen a lot of them, and I got the two dollar tour of John's right after he flew it to Sun 'n fun. I would NOT do it. It was told to me that you need to be "very careful" taking off with a full load of fuel, and that you definitely had to have them empty before landing. As far as the "tip tank" approach, I only know of people putting 7 or 8 gallons per side. Frankly, I wouldn't even do that. I have seen one that had the tip tank very close to the existing tank, to minimize the moment arm. I'm very happy with a 60 gallon limit - so is my bladder. Just stop for gas. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415978#415978 ________________________________________________________________________________
Date: Dec 21, 2013
Bob, I'm sure you'll do what you want. Here is a photo I took during fit. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415979#415979 Attachments: http://forums.matronics.com//files/windshieldfit_170.jpg ________________________________________________________________________________
Date: Dec 21, 2013
Thanks John .. valuable comments!=0A=0ARodger=0A=0A=0A=0AOn Saturday, 21 De cember 2013, 23:14, johngoodman wrote:=0A =0A- =0A=0ARodger, I was in Perth back in March of 2011 - beautiful place.=0AAny way, I feel I should comment on the extended tanks. I've seen a lot of them , and I got the two dollar tour of John's right after he flew it to Sun 'n fun.=0AI would NOT do it. It was told to me that you need to be "very caref ul" taking off with a full load of fuel, and that you definitely had to hav e them empty before landing.=0AAs far as the "tip tank" approach, I only kn ow of people putting 7 or 8 gallons per side. Frankly, I wouldn't even do t hat. I have seen one that had the tip tank very close to the existing tank, to minimize the moment arm.=0A=0AI'm very happy with a 60 gallon limit - s o is my bladder. Just stop for gas.=0A=0AJohn=0A=0A--------=0A#40572 Phase One complete and flying.=0A=0A=0A=0A=0ARead this topic online here:=0A=0Aht tp://forums.matronics.com/viewtopic.php?p=415978#415978=0A=0A=0A=0A=0A=0A ======== ________________________________________________________________________________
Date: Dec 21, 2013
Another data point for general information: I have the B&C SD20 alternator and used the straight oil filter adapter that comes with standard Vans powerplant - the D4A5. The difficulty of removing and installing filters is less than that I had on my Maule so no problem there. It's easy to get a box wrench on the end of the filter. I use the same length of angle vinyl flashing, about 2" a side and 4' long, as a gutter to catch the drip as the filter comes off. A one step foot stool is required to get over the top access for the change. The angle filter mount looked attractive but I didn't do it. Installing the SD20 in the first place is a bear and I hopefully won't have to replace it soon. I'm not sure that the difficulty changes with the various oil filter adapters, spacers and such. There's one nut and stud that is impossible to reach with any standard wrench. For about $30, Snap-on sells a thin crows foot wrench specifically for this particular stud & nut. Hmmmm.... a single use $30 tool, let me see if I can borrow one. Experienced mechanics seem familiar with the difficulties around this vacuum pad stud and nut so I asked around with no joy. My local guy says he "turns the nut by using the end of a straight screwdriver". Torque values? A well calibrated mallet and screw driver seems to be the key for him. So I bought the wrench and with difficulty installed the SD20 and torqued it properly. No big deal, never looked back. All is well 350 hours later. Only problem discovered 300 hours in was the lead to the SD20 fatigued and broke off when I gave it a tug during my second conditional. Make sure you allow for an extra large relief loop in the lead because the geometry of the engine mount and SD20 location results in a surprising amount of movement during operation. Bill "found out the '10 can easily transport 2 Labs and a carrier with 2 more dogs" Watson On 12/20/2013 7:42 PM, Chris Hukill wrote: > Has anyone used a B&C stby alternator on the vacuum pad with an angle > oil filter? I need to know if there is an engine mount clearance > issue, and if so, what thickness spacers are needed to make it all fit. > Chris Hukill > * > * ________________________________________________________________________________
Date: Dec 21, 2013
After recent trip to Hawaii, I was fantasizing about flying the RV10 down to the islands. I figure that to cover the approximately 2050 miles from the SFO area to Hilo (the closest airport to the mainland) that you would need 14 hours of fuel to be safe or about 150 gallons (900#) of fuel at economy cruise. with my lightweight RV10 (1620#) and two 180# pilots that would put me 200# over gross with no food, water or emergency equipment and a 20# aux. fuel tank. One pilot might be can do, but still over gross. I like the idea of an internal fuel tank. The obvious issues are CG, safety, sloshing in turbulence, and maneuvering speed. Except for safety, all of these issues are easily managed. I like the idea of a removable internal L/R tank. You are not flying these flights all of the time and the RV10 has reasonably long legs with the regular 60 gallon tanks. Baffles can prevent sloshing in turbulence. With the internal tank, venting can be done outside, and the pilot can control the plumbing/flow in flight. Plus it can be easily installed and removed from a secure position the back seat. Just my thoughts, but I invite your comments! -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415990#415990 ________________________________________________________________________________
Date: Dec 21, 2013
If you're really serious about extra fuel, check this out... http://www.turtlepac.com/en/photo-gallery/aircraft-ferry-tanks.html John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415998#415998 ________________________________________________________________________________
Date: Dec 21, 2013
Bill Harrelson is a neighbor of mine here at Dogwood Airpark. Five of the seven ferry tanks he used for his Guam to Jacksonville non-stop hop where built from carbon fiber prepreg board and carbon fiber for the joints to exactly match the available space inside the cabin. The two big collapsible fuel blatters were on top of two of the carbon fiber tanks. The plumbing and fuel manifolds were a work of art. If I ever wanted to do extended fuel in the RV-10 (which I don't) I would go the same way - tailored carbine fiber tanks fitted into the real seat foot wells, simple transfer pump and plumbing with a common vent overboard. I'd not consider the collapsible fuel blatter. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Saturday, December 21, 2013 1:33 PM Subject: RV10-List: Re: Extended Tankage --> If you're really serious about extra fuel, check this out... http://www.turtlepac.com/en/photo-gallery/aircraft-ferry-tanks.html John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=415998#415998 ________________________________________________________________________________
Date: Dec 21, 2013
We see this Australian guy at Oshkosh every year selling these > Subject: RV10-List: Re: Extended Tankage > From: johngoodman(at)earthlink.net > Date: Sat=2C 21 Dec 2013 10:32:52 -0800 > To: rv10-list(at)matronics.com > > > > If you're really serious about extra fuel=2C check this out... > > http://www.turtlepac.com/en/photo-gallery/aircraft-ferry-tanks.html > > John > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=415998#415998 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Dec 22, 2013
Thanks everyone for your comments to date.=0A=0AJohn, I was aware of the Tu rtlepac products and indeed their Drum 66 would seem ideal for the back sea t except it would mean refuelling within the cabin - the spec they supplied me several years ago confirmed that the filler tube was too short to route out of the cabin and I didn't want to alter the cabin top any further to i nsert some sort of pass through/adaptor for the filler head.--My guess is that they would extend the filler tube if asked.- However, it's-very simple-to either use it to refresh the main tanks or as a direct feed to the engine.=0A- =0AI became seriously-interested in extending the capa city when I saw what Patrick did with his aircraft and heard his reasoning - a very nice job it is too but don't tell him - and became inspired when I read of Ian Pullin's magnificent effort when he flew his RV-6 (or possibly 7) from Jandakot (Perth's GA airport - busiest a/p-in OZ) to the UK and back earlier this year.- I remember at the time-of its first flight thi nking-that John Nys' conversion must have been the work of-a mad man. - However seven, almost 8 years later, here I am actively considering doi ng something similar. -We enjoy the delight of almost always having perfe ct flying weather but at the cost of huge distances between alternates.- This is-the virtual total opposite of the US situation where you have an alternate every 50 miles but also-what can be pretty dire weather.- In the Australian situation, this has the effect that unless you are flying up the populated East Coast most destinations are near the end of the 10's cruising range.--Our cl osest way to Asia, for example,-is Port Hedland to Denpasar which-at- 723 nm is right at the limit for a 10 (and then with little reserve) and en route it's all water full of large scary beasties as well as some small ex ceptionally scary ones (but they're seasonal!).- Thus to use the full uti lity of this craft it really needs extra fuel.- It's worth noting that th e Brazilians ship their factory built 10's with 90 gallons capacity standar d.- Most of my flying will necessarily be over remote areas so safety and fuel reserves are my number one priorities.=0A=0AI am still hoping that so me one who has real world experience will chime in about the fully wet lead ing edge.- My plan would be to add separate 30 gallon tanks in place of t he standard outboard leading edge - I don't know how others have done it bu t I suspect they have created a single 60 gallon tank which I would see as not optimum.-- As an aside I believe there is someone in Victoria who o ffers tank conversions so it would be nice to hear from them.=0A=0AThanking you all,=0A=0ABest Wishes,=0A=0ARodger--=0A=0A=0A=0AOn Sunday, 22 Dece mber 2013, 9:19, Danny Riggs wrote:=0A =0A =0AWe see t his Australian guy at Oshkosh every year selling these=0A=0A> Subject: RV10 -List: Re: Extended Tankage=0A> From: johngoodman(at)earthlink.net=0A> Date: S RV10-List message posted by: "johngoodman" =0A> =0A> If you're really serious about extra fuel, check this out...=0A> =0A> http://www.turtlepac.com/en/photo-gallery/aircraft-ferry-tanks.html=0A> =0A> John=0A> =0A> --------=0A> #40572 Phase One complete and flying.=0A> =0A> =0A> =0A> =0A> Read this topic online here:=0A> =0A> http://forums.mat ronics.com/viewtopic.php?p=415998#415998=0A> =0A> =0A> =0A> =0A> =0A> =0A ======== ________________________________________________________________________________
Date: Dec 22, 2013
Rodger Robert Herring from Mildura, Victoria engineered the extended tank leading e dge tanks that I have incorporated into my aircraft. Robert modified my wings (fitted pressed access panels to my bottom skins to enable me to access the faucet transfer pumps and isolating solenoid) and h as done all the engineering calculations. Rob has also designed and built two experimental aircraft of his own design a nd is a Licensed Aircraft Maintenance Engineer. The reserve tanks hold 60 litres each (three ribs wide) in the leading edge t anks, which attach to the wing just like the main tanks using Z-attach brack ets. We modified the outboard leading edge and cut down a full size inboard tank leading edge and I fabricated and built the tanks, as Rob hated Prosea l. I have installed a float sensor in each tank, vents, lockable fuel caps a nd fuel drains. As indicated by Rodger they'll be used for going a long way from home and ho pefully returning on my own fuel, rather than paying some crazy price like $ 5.00 per litre for fuel at some remote out station, or having to purchase a f ull 44 Gallon drum, regardless of the fact that you might not be able to use the entire 45 Gallons based on limited fuel tank capacity. Oz is big, fuel is few and far between in the outback and when it is availab le, you'll pay through the nose for it! Warm regards and Merry Christmas and Happy New Year to you all. Safe skies and tailwinds. Patrick > On 22 Dec 2013, at 18:55, Rodger Todd wrote: > > Thanks everyone for your comments to date. > > John, I was aware of the Turtlepac products and indeed their Drum 66 would seem ideal for the back seat except it would mean refuelling within the cab in - the spec they supplied me several years ago confirmed that the filler t ube was too short to route out of the cabin and I didn't want to alter the c abin top any further to insert some sort of pass through/adaptor for the fil ler head. My guess is that they would extend the filler tube if asked. How ever, it's very simple to either use it to refresh the main tanks or as a di rect feed to the engine. > > I became seriously interested in extending the capacity when I saw what Pa trick did with his aircraft and heard his reasoning - a very nice job it is t oo but don't tell him - and became inspired when I read of Ian Pullin's magn ificent effort when he flew his RV-6 (or possibly 7) from Jandakot (Perth's G A airport - busiest a/p in OZ) to the UK and back earlier this year. I reme mber at the time of its first flight thinking that John Nys' conversion must have been the work of a mad man. However seven, almost 8 years later, here I am actively considering doing something similar. We enjoy the delight of almost always having perfect flying weather but at the cost of huge distanc es between alternates. This is the virtual total opposite of the US situati on where you have an alternate every 50 miles but also what can be pretty di re weather. In the Australian situation, this has the effect that unless yo u are flying up the populated East Coast most destinations are near the end o f the 10's cruising range. Our closest way to Asia, for example, is Port He dland to Denpasar which at 723 nm is right at the limit for a 10 (and then w ith little reserve) and en route it's all water full of large scary beasties as well as some small exceptionally scary ones (but they're seasonal!). Th us to use the full utility of this craft it really needs extra fuel. It's w orth noting that the Brazilians ship their factory built 10's with 90 gallon s capacity standard. Most of my flying will necessarily be over remote area s so safety and fuel reserves are my number one priorities. > > I am still hoping that some one who has real world experience will chime i n about the fully wet leading edge. My plan would be to add separate 30 gal lon tanks in place of the standard outboard leading edge - I don't know how o thers have done it but I suspect they have created a single 60 gallon tank w hich I would see as not optimum. As an aside I believe there is someone in Victoria who offers tank conversions so it would be nice to hear from them. > > Thanking you all, > > Best Wishes, > > Rodger > > > On Sunday, 22 December 2013, 9:19, Danny Riggs wrote: > We see this Australian guy at Oshkosh every year selling these > > > Subject: RV10-List: Re: Extended Tankage > > From: johngoodman(at)earthlink.net > > Date: Sat, 21 Dec 2013 10:32:52 -0800 > > To: rv10-list(at)matronics.com > > t> > > > > If you're really serious about extra fuel, check this out... > > > > http://www.turtlepac.com/en/photo-gallery/aircraft-ferry-tanks.html > > > > John > > > > -------- > > #40572 Phase One complete and flying. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=415998#415998 > > > > > > > >====================== > &gr to =============== > > > > > > > http://www.aeroww.buildersbooks.com/" target="_blank" rel="nofollow">h ttp://www.buildethelp.com/" target="_blank" rel="nofollow">http://www.ho mebuilthelp.com= * Race Consulting http://www.matronics.avigator?RV10- List" target="_blank" rel="nofollow">http://www.matronics===== ================== > forums.matronics.com/" target="_blank" rel="nofollow">http://forums.ma t=================== > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 23, 2013
I am most entertained at the response to my fantasy flights across the Pacific in my RV10. I have received several private communications on the subject. One person has an auto racing style plastic fuel tank in the back of his RV10 (removable) and auto racing style quick-connect-dripless connectors. Several people have mentioned that the standard Van's fuel valve has a 4th position that has a plug in it on the stock set up. This fact, we all should know from our annual inspections. Several RV10's have tip tanks fitted. There is also an RV10 out there with a 90 gallon internal tank fitted to the back seat and back seat foot well - wow! I was told that it is well baffled and fitted close to the front seats in deference to the CG. They made a mock up first to make sure that the tank would fit in the door. Lots of anchoring calculations. The life raft goes on top of the tank. Hilo here I come. Goodbye to those overpriced flights on American, United and Hawaiian airlines. -------- See you OSH '13 Q/B - flying 3 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416157#416157 ________________________________________________________________________________
Subject: Rudder lock possible?
Date: Dec 25, 2013
Hi, I posted this at VAF as well but would like to get your opinion as well. I did a couple days ago a stability test flight to check how the aircraft behaves when you apply full rudder in climb, cruise and descent with full flaps. In climb at about 100 kt with wings level I applied slowly more and more right rudder until I hit the limit. that process took a couple of seconds about approximately an inch before the limit the rudder got soft and locked aerodynamically. I immediately gave opposite rudder to go straight again. My question now is if other experienced this as well, would it come back and I just need to wait a bit? I guess one is expected to give full rudder more swiftly and check the behavior then. If you apply it slowly the aircraft is at so much slip that the bigger part of the rudder is covered by the VS near the end of its range and only the counter balance gets the airstream, just a guess though. I replicated this about four times left and right in cruise and climb. Interesting enough that in landing config at 70kt it did not appear but it might be that I pressed the rudder more swiftly du to the speed loss when you yaw the aircraft. Regards Mike -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416194#416194 ________________________________________________________________________________
Subject: Stick grip
Date: Dec 25, 2013
Guys Those of you who used the Infinity (military type) stick grip, do you remember how much tube did you cut to shorten your stick? And what did you use to adapt the stick grip internal diameter (1") to the stick tube outside diameter (7/8")? Regards Carlos ________________________________________________________________________________
Subject: Re: Stick grip
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Dec 25, 2013
Assuming you are staying with Van's panel, cut the stick such that the Infin ity grip is as low as it can go (as in the bottom of the grip is touching th e weld for the curved portion of the stick). I got the adapter from Infinity - it came with the grip. Carl > On Dec 25, 2013, at 3:23 PM, "Carlos Trigo" wrote: > > Guys > > Those of you who used the Infinity (military type) stick grip, do you reme mber how much tube did you cut to shorten your stick? > > And what did you use to adapt the stick grip internal diameter (1=9D ) to the stick tube outside diameter (7/8=9D)? > > Regards > Carlos > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 25, 2013
I don't remember how much was cut off, but infinity sells an adapter/spacer t o make up the difference in diameter. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 25, 2013, at 3:23 PM, "Carlos Trigo" wrote: > > Guys > > Those of you who used the Infinity (military type) stick grip, do you reme mber how much tube did you cut to shorten your stick? > > And what did you use to adapt the stick grip internal diameter (1=9D ) to the stick tube outside diameter (7/8=9D)? > > Regards > Carlos > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Subject: RV-10 ride in California
Date: Dec 25, 2013
Hi My partner in the RV-10 is now in California, till Jan,4th, and is willing to have a ride in an RV-10. Can someone from the San Francisco area, or not very far from there, who could take him for a ride, please contact me by email. Thanks Carlos ________________________________________________________________________________
Date: Dec 25, 2013
I think you will find that you should not take off the last 1-1.5" of the vertical part of the stick, so there is something to support the grip. The other aspect is that you need to make an elevator stop in the tail section to limit nose down elevator travel to Van's minimum of around 20 degrees. They allow a tolerance to 25 degrees, but that will have the stick grip hitting the panel no matter how short you make it. Other choice is to have the stick curved section bent to a smaller radius, but you are talking about bending heat treated chrome moly tubing with powder coating on it, so lots of ways to screw that up. On Wed, Dec 25, 2013 at 1:23 PM, Carlos Trigo wrote : > Guys > > > Those of you who used the Infinity (military type) stick grip, do you > remember how much tube did you cut to shorten your stick? > > > And what did you use to adapt the stick grip internal diameter (1=94) to the > stick tube outside diameter (7/8=94)? > > > Regards > > Carlos > > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?RV10-List> =========== =========== > * > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 25, 2013
If you have an Aerosport panel, you'll want to cut it pretty short. I thin k I have about an inch below the grip. Sent from my iPad > On Dec 25, 2013, at 3:55 PM, Jesse Saint wrote: > > I don't remember how much was cut off, but infinity sells an adapter/space r to make up the difference in diameter. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > >> On Dec 25, 2013, at 3:23 PM, "Carlos Trigo" wrote : >> >> Guys >> >> Those of you who used the Infinity (military type) stick grip, do you rem ember how much tube did you cut to shorten your stick? >> >> And what did you use to adapt the stick grip internal diameter (1=9D ) to the stick tube outside diameter (7/8=9D)? >> >> Regards >> Carlos >> >> >> >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">www.aeroelectric.com >> books.com"">www.buildersbooks.com >> quot;">www.homebuilthelp.com >> quot;">www.mypilotstore.com >> ">www.mrrace.com >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> List"">http://www.matronics.com/Navigator?RV10-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Dec 25, 2013
I used the Tosten grip (which I like a lot for a couple of reasons - the Infinity seems great too). My panel is roughly standard. The stick with the grip definitely interfered with the panel. I cut it a bit, can't say how much, but more was required. I bent the sticks in a press to increase the standard curvature. Using wood blocks it was pretty easy to do but clearly one could go too far and perhaps start to buckle the sticks. Going slow and checking the clearance until it just cleared worked great. It's not hard to do. I requires a simple hydraulic press (think HF). I went and used a neighbor's press. Bill On 12/25/2013 3:23 PM, Carlos Trigo wrote: > > Guys > > Those of you who used the Infinity (military type) stick grip, do you > remember how much tube did you cut to shorten your stick? > > And what did you use to adapt the stick grip internal diameter (1") to > the stick tube outside diameter (7/8")? > > Regards > > Carlos > > * > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Re: Rudder lock possible?
Date: Dec 25, 2013
Mike Whisky wrote: > Hi, > > I posted this at VAF as well but would like to get your opinion as well. > > I did a couple days ago a stability test flight to check how the aircraft behaves when you apply full rudder in climb, cruise and descent with full flaps. > > In climb at about 100 kt with wings level I applied slowly more and more right rudder until I hit the limit. that process took a couple of seconds about approximately an inch before the limit the rudder got soft and locked aerodynamically. I immediately gave opposite rudder to go straight again. > > My question now is if other experienced this as well, would it come back and I just need to wait a bit? I guess one is expected to give full rudder more swiftly and check the behavior then. If you apply it slowly the aircraft is at so much slip that the bigger part of the rudder is covered by the VS near the end of its range and only the counter balance gets the airstream, just a guess though. > > I replicated this about four times left and right in cruise and climb. Interesting enough that in landing config at 70kt it did not appear but it might be that I pressed the rudder more swiftly du to the speed loss when you yaw the aircraft. > > Regards > Mike I did not test that flight regime. Imagine if one flap departed and how your little ailerons would counter the roll. It happened in a Cherokee one time. He rolled and ended up losing a wing too. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416208#416208 ________________________________________________________________________________
Subject: Stick grip
Date: Dec 26, 2013
Thanks for your answers. I just ordered the adapter from ACS, and now I confirmed that I should cut the tube in order to avoid the grip to hit the panel, that was what I expected. Thanks Carlos From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: quinta-feira, 26 de Dezembro de 2013 00:09 Subject: Re: RV10-List: Stick grip I think you will find that you should not take off the last 1-1.5" of the vertical part of the stick, so there is something to support the grip. The other aspect is that you need to make an elevator stop in the tail section to limit nose down elevator travel to Van's minimum of around 20 degrees. They allow a tolerance to 25 degrees, but that will have the stick grip hitting the panel no matter how short you make it. Other choice is to have the stick curved section bent to a smaller radius, but you are talking about bending heat treated chrome moly tubing with powder coating on it, so lots of ways to screw that up. On Wed, Dec 25, 2013 at 1:23 PM, Carlos Trigo wrote: Guys Those of you who used the Infinity (military type) stick grip, do you remember how much tube did you cut to shorten your stick? And what did you use to adapt the stick grip internal diameter (1") to the stick tube outside diameter (7/8")? Regards Carlos _blank">www.aeroelectric.com .com" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com ="_blank">www.mypilotstore.com ank">www.mrrace.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Date: Dec 26, 2013
Geeez, Mike, that's like practicing to bleed.... John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416215#416215 ________________________________________________________________________________
Date: Dec 26, 2013
This is part of the test flight regime. I know one would not be in this situation in normal operations however, I still believe that the test flight program is exactly built to understand the aircraft behavior within the design envelope. Mike -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416220#416220 ________________________________________________________________________________
Date: Dec 26, 2013
I've seen this in my plane and a customer's -10. He described it to me first. He's a very careful and conscientious pilot. Also lots of acro and formation. We did this straight-and-level at moderate IAS. It's a little surprising at first but so far it's been completely manageable. If you expect it, it's a non-event. Just opposite rudder and it unsticks. I haven't tried it in a climb. Dave Saylor 831-750-0284 CL On Wed, Dec 25, 2013 at 11:32 AM, Mike Whisky wrote: > > Hi, > > I posted this at VAF as well but would like to get your opinion as well. > > I did a couple days ago a stability test flight to check how the aircraft > behaves when you apply full rudder in climb, cruise and descent with full > flaps. > > In climb at about 100 kt with wings level I applied slowly more and more > right rudder until I hit the limit. that process took a couple of seconds > about approximately an inch before the limit the rudder got soft and locked > aerodynamically. I immediately gave opposite rudder to go straight again. > > My question now is if other experienced this as well, would it come back > and I just need to wait a bit? I guess one is expected to give full rudder > more swiftly and check the behavior then. If you apply it slowly the > aircraft is at so much slip that the bigger part of the rudder is covered > by the VS near the end of its range and only the counter balance gets the > airstream, just a guess though. > > I replicated this about four times left and right in cruise and climb. > Interesting enough that in landing config at 70kt it did not appear but it > might be that I pressed the rudder more swiftly du to the speed loss when > you yaw the aircraft. > > Regards > Mike > > -------- > RV-10 builder (flying, test phase) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416194#416194 > > ________________________________________________________________________________
Subject: Re: RV-10 ride in California
Date: Dec 26, 2013
I am in sck could pick him up at lvk this weekend-Jim -----Original Message----- From: Carlos Trigo <trigo(at)mail.telepac.pt> Sent: Wed, Dec 25, 2013 2:52 pm Subject: RV10-List: RV-10 ride in California Hi My partner in the RV-10 is now in California, till Jan,4th, and is willing to have a ride in an RV-10. Can someone from the San Francisco area, or not very far from there, who co uld take him for a ride, please contact me by email. Thanks Carlos ________________________________________________________________________________
Date: Dec 27, 2013
Thanks Dave, I guess that most RV-10 would react that way if they are built to plans and the rudder will stop at the control stops. As said before it was easy to get her straight with opposite rudder. I will repeat the test with a faster full rudder deflection and see if this changes anything. Regards Mike -------- RV-10 builder (flying, test phase) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416243#416243 ________________________________________________________________________________
Subject: Fw: 1920 OILFIELD DODGE
Date: Dec 28, 2013
----- Original Message ----- From: Sent: Friday, December 27, 2013 8:50 PM Subject: Fwd: 1920 OILFIELD DODGE -------- Original Message -------- Subject: 1920 OILFIELD DODGE Date: Fri, 04 Oct 2013 14:46:22 -0500 From: Jim Johnson <jimjohnson100(at)icloud.com> To: Johnson Jim D Don't make 'em like they used to! How do you think a modern car would stack up against this one? Oilfield Dodge 1920- Unblievable Who needs four wheel drive anyway?? Oilfield Dodge 1920- Unbelievable And less than 100 years ago.... Oilfield Dodge 1920 No virus found in this message. Checked by AVG - www.avg.com 12/27/13 ________________________________________________________________________________
Subject: Aftermarket wingtip lenses
Date: Jan 03, 2014
I seem to remember someone mentioning aftermarket wingtip lenses. Can someone point me in the right direction? -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416532#416532 ________________________________________________________________________________
Subject: Re: Aftermarket wingtip lenses
Date: Jan 03, 2014
http://www.vansaircrafttires.com/products/RV%252d10-Clear-Wing-tip-lenses-%28pair%29.html no need to trim and better quality than what Vans has in kit. Pascal -----Original Message----- From: woxofswa Sent: Friday, January 03, 2014 8:30 PM Subject: RV10-List: Aftermarket wingtip lenses I seem to remember someone mentioning aftermarket wingtip lenses. Can someone point me in the right direction? -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416532#416532 ________________________________________________________________________________
Date: Jan 03, 2014
Ordered thanks! -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416535#416535 ________________________________________________________________________________
Date: Jan 04, 2014
Subject: nose wheel
Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove main wheels and Matco nose wheel. A couple of observations/questions. The valve stem on the nose wheel tube has a washer and nut on it tight to the tube. Matco's drawing doesn't really show where the washer should go, but as far as I can tell, it has to go between the tube and the nut which fits in the nose wheel slot. Has anyone else come across this? 2nd observation. The Grove main wheels have nylon lock nuts which I replaced when I torqued the wheel bolts. The Matco wheel has metal lock nuts. I would think that due to heat from the brakes the main wheels should have the metal lock nuts. Does this seem reasonable or of no consequence? Thx, Rick #40956 Southampton, Ont ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jan 04, 2014
Subject: Re: nose wheel
Can't help with Q1 but for Q2: I have seen plastic lock nuts on brake calipers melted due to brake heat. So metal nuts are called for on the calipers. If you mean the nuts holding the wheel halves together, I'd expect much less issue there, but if you're concerned then go with metal. Dave Saylor 831-750-0284 CL On Sat, Jan 4, 2014 at 3:21 PM, Rick Lark wrote: > Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove > main wheels and Matco nose wheel. A couple of observations/questions. > > The valve stem on the nose wheel tube has a washer and nut on it tight to > the tube. Matco's drawing doesn't really show where the washer should go, > but as far as I can tell, it has to go between the tube and the nut which > fits in the nose wheel slot. Has anyone else come across this? > > 2nd observation. The Grove main wheels have nylon lock nuts which I > replaced when I torqued the wheel bolts. The Matco wheel has metal lock > nuts. I would think that due to heat from the brakes the main wheels > should have the metal lock nuts. Does this seem reasonable or of no > consequence? > > Thx, Rick > #40956 > Southampton, Ont > > * > > * > > ________________________________________________________________________________
Date: Jan 04, 2014
[quote="larkrv10(at)gmail.com"]Hi all, I mounted my Desser tires and Leakstop tubes today on my Grove main wheels and Matco nose wheel. A couple of observations/questions. The valve stem on the nose wheel tube has a washer and nut on it tight to the tube. Matco's drawing doesn't really show where the washer should go, but as far as I can tell, it has to go between the tube and the nut which fits in the nose wheel slot. Has anyone else come across this? 2nd observation. The Grove main wheels have nylon lock nuts which I replaced when I torqued the wheel bolts. The Matco wheel has metal lock nuts. I would think that due to heat from the brakes the main wheels should have the metal lock nuts. Does this seem reasonable or of no consequence? Thx, Rick #40956 Southampton, Ont > [b] I threw the nut and washer in the trash. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416582#416582 ________________________________________________________________________________
From: "Bill and Tami Britton" <william(at)gbta.net>
Subject: Re: Rv10 #40458 for sale
Date: Jan 09, 2014
Still available??? Can you send pictures and details and location? Bill ----- Original Message ----- From: "John" <johnag5b(at)cableone.net> Sent: Thursday, November 21, 2013 4:01 PM Subject: RV10-List: Rv10 #40458 for sale Hey folks - one of the nicest and best equipped 10s is for sale. I won't be flying any more for health reasons. Drop me a line for an extensive description and pics. John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 ________________________________________________________________________________
Date: Jan 10, 2014
Hi folks I have taken an earnest money deposit on N8863. I dont anticipate problems with the sale, but will let you know if they occur. Best wishes John Ackerman On Jan 9, 2014, at 7:37 AM, Bill and Tami Britton wrote > > Still available??? Can you send pictures and details and location? > > Bill > ----- Original Message ----- From: "John" <johnag5b(at)cableone.net> > To: "Rv10 Listf" > Sent: Thursday, November 21, 2013 4:01 PM > Subject: RV10-List: Rv10 #40458 for sale > > > > Hey folks - one of the nicest and best equipped 10s is for sale. I won't be flying any more for health reasons. Drop me a line for an extensive description and pics. > John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 > > > > > > > > ________________________________________________________________________________
Date: Jan 10, 2014
Speaking of -10s for sale, what are well equipped -10s going for these days? Just wondering. On Jan 10, 2014, at 5:29 PM, John Ackerman wrote: > > Hi folks > I have taken an earnest money deposit on N8863. I dont anticipate problems with the sale, but will let you know if they occur. > Best wishes > John Ackerman > > > > On Jan 9, 2014, at 7:37 AM, Bill and Tami Britton wrote > >> >> Still available??? Can you send pictures and details and location? >> >> Bill >> ----- Original Message ----- From: "John" <johnag5b(at)cableone.net> >> To: "Rv10 Listf" >> Sent: Thursday, November 21, 2013 4:01 PM >> Subject: RV10-List: Rv10 #40458 for sale >> >> >> >> Hey folks - one of the nicest and best equipped 10s is for sale. I won't be flying any more for health reasons. Drop me a line for an extensive description and pics. >> John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 >> >> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Jan 13, 2014
It seems like everything is listing in the $200k range these days. The used prices have gone up considerably. I don't know if they are selling, but that is what people are asking. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 On Jan 10, 2014, at 8:42 PM, David Leikam wrote: > > Speaking of -10s for sale, what are well equipped -10s going for these days? > Just wondering. > > On Jan 10, 2014, at 5:29 PM, John Ackerman wrote: > >> >> Hi folks >> I have taken an earnest money deposit on N8863. I dont anticipate problems with the sale, but will let you know if they occur. >> Best wishes >> John Ackerman >> >> >> >> On Jan 9, 2014, at 7:37 AM, Bill and Tami Britton wrote >> >>> >>> Still available??? Can you send pictures and details and location? >>> >>> Bill >>> ----- Original Message ----- From: "John" <johnag5b(at)cableone.net> >>> To: "Rv10 Listf" >>> Sent: Thursday, November 21, 2013 4:01 PM >>> Subject: RV10-List: Rv10 #40458 for sale >>> >>> >>> >>> Hey folks - one of the nicest and best equipped 10s is for sale. I won't be flying any more for health reasons. Drop me a line for an extensive description and pics. >>> John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Jan 13, 2014
Amazing. I fear I will not get enough for my old Mooney to even pay for my IO-540. Old certified plane market seems real soft between aging airframes, aging avionics and super expensive fuel. On Mon, Jan 13, 2014 at 2:40 PM, Jesse Saint wrote : > > It seems like everything is listing in the $200k range these days. The > used prices have gone up considerably. I don't know if they are selling, > but that is what people are asking. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > On Jan 10, 2014, at 8:42 PM, David Leikam wrote: > > > > > Speaking of -10=92s for sale, what are well equipped -10=92s going for these > days? > > Just wondering. > > > > On Jan 10, 2014, at 5:29 PM, John Ackerman > wrote: > > > >> > >> Hi folks > >> I have taken an earnest money deposit on N8863. I don=92t anticipate > problems with the sale, but will let you know if they occur. > >> Best wishes > >> John Ackerman > >> > >> > >> > >> On Jan 9, 2014, at 7:37 AM, Bill and Tami Britton > wrote > >> > william(at)gbta.net> > >>> > >>> Still available??? Can you send pictures and details and location? > >>> > >>> Bill > >>> ----- Original Message ----- From: "John" <johnag5b(at)cableone.net> > >>> To: "Rv10 Listf" > >>> Sent: Thursday, November 21, 2013 4:01 PM > >>> Subject: RV10-List: Rv10 #40458 for sale > >>> > >>> > >>> > >>> Hey folks - one of the nicest and best equipped 10s is for sale. I > won't be flying any more for health reasons. Drop me a line for an > extensive description and pics. > >>> John Ackerman. Johnag5b(at)cableone.net. 928-308-0471 > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > =========== =========== =========== =========== > > -- - sent from the microchip implanted in my forearm ________________________________________________________________________________
Subject: Placement of phone jacks for back seats
Date: Jan 15, 2014
Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 15, 2014
Subject: Re: Placement of phone jacks for back seats
I mounted my headset jacks on the tunnel covers between the seats. The headsets will hang on my overhead plenum out of the way of people boarding/exiting the plane. No charging ports though!!! Linn On 1/15/2014 12:48 PM, bob88 wrote: > > Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416944#416944 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 15, 2014
whats wrong with the back seat vent areas? probably the best in my mind. I put a aux jack (which I have yet to use) below one of the seats, would do the same for a USB. The hot tunnel top would really be the only other area to put headset jacks and connections for easy access. the side panels below the vents is the best for routing and connections. If its a tripping over them issue, move the headset onto the seats. I have yet to have an issue with my 5yr old and older passengers, when I move the headset into the corner and have the passengers pull the headset from that area. Having it in the center would cause issues in flight as we are moving things all over that area (food, books, etc) from back to front and back. -----Original Message----- From: bob88 Sent: Wednesday, January 15, 2014 9:48 AM Subject: RV10-List: Placement of phone jacks for back seats Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 15, 2014
I fabricated a vertical plate below the vent. Not as subject to being damaged. Allows padded armrest extending along the full horizontal shelf. I'm going to down to the plane now - I'll try to remember to take a pic or two. B On 1/15/2014 12:48 PM, bob88 wrote: > > Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416944#416944 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jan 15, 2014
I installed mine on the flap rod covers, each side mounted close to the tunnel side of each cover, one plug over the other. My thought was to not have the jacks such that the headphone wires would pass over their laps or get tangled if they tried to get out with the headphones still on. This is also an easy place to route the connection wires via the tunnel. Never had a rear seat passenger needing to charge anything. If on rare instance I do I'll just have them use the panel jack. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Wednesday, January 15, 2014 12:49 PM Subject: RV10-List: Placement of phone jacks for back seats Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 15, 2014
You must not carry kids (re the charging)....we use the back seat charging ports all the time. Tim On 1/15/2014 12:15 PM, Carl Froehlich wrote: > > I installed mine on the flap rod covers, each side mounted close to the > tunnel side of each cover, one plug over the other. My thought was to not > have the jacks such that the headphone wires would pass over their laps or > get tangled if they tried to get out with the headphones still on. This is > also an easy place to route the connection wires via the tunnel. > > Never had a rear seat passenger needing to charge anything. If on rare > instance I do I'll just have them use the panel jack. > > Carl ________________________________________________________________________________
Date: Jan 15, 2014
Mine are on the rear of the Aerosport Products center arm console. Sent from my iPhone On Jan 15, 2014, at 12:48 PM, "bob88" wrote: Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 15, 2014
So there was a thread, probably on Aeroelectric, regarding USB ports. As I recall it was never brought to a conclusion. What are y'all using for USB charging ports? I have a cigarette port poorly located but I'd love to install a USB port or two. On 1/15/2014 2:40 PM, Tim Olson wrote: > > You must not carry kids (re the charging)....we use > the back seat charging ports all the time. > Tim ________________________________________________________________________________
Date: Jan 15, 2014
Having built my RV-10 long before I recognized the need for a USB port, I just bought a cigarette plug adapter that has two cigarette plugs and two USB ports, one with 2.1 amps for the mighty iPad. Purchased it on Amazon and it works great. Not to helpful for the folks in back though unless you have a long cord or another jack in the back. Marcus On Jan 15, 2014, at 2:55 PM, Bill Watson wrote: So there was a thread, probably on Aeroelectric, regarding USB ports. As I recall it was never brought to a conclusion. What are y'all using for USB charging ports? I have a cigarette port poorly located but I'd love to install a USB port or two. On 1/15/2014 2:40 PM, Tim Olson wrote: > > You must not carry kids (re the charging)....we use > the back seat charging ports all the time. > Tim ________________________________________________________________________________
Date: Jan 15, 2014
Stein sells these... On Jan 15, 2014, at 11:55 AM, Bill Watson wrote: > > So there was a thread, probably on Aeroelectric, regarding USB ports. As I recall it was never brought to a conclusion. > > What are y'all using for USB charging ports? > > I have a cigarette port poorly located but I'd love to install a USB port or two. > > > On 1/15/2014 2:40 PM, Tim Olson wrote: >> >> You must not carry kids (re the charging)....we use >> the back seat charging ports all the time. >> Tim > > > > > ________________________________________________________________________________
Date: Jan 15, 2014
Our headset jacks are in a panel below the vent. The panel extends from the diagonal brace above it. FWIW I wired the back seat music input with a 24" wire/1/8" plug (not a jack) so the kids can plug their stuff in and I don't have to keep track of a patch cord. It exits from inside a pocket so I just coil it up and leave in there when not in use. Dave Saylor 831-750-0284 CL On Wed, Jan 15, 2014 at 9:48 AM, bob88 wrote: > > Any ideas re placement of headphone jacks, aux music input jack, USB > charging port for back seaters...other than the horizontal area just below > the back seat vent? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416944#416944 > > ________________________________________________________________________________
Date: Jan 15, 2014
Nice, looks like Stein has several USB options. Thanks, Marcus On Jan 15, 2014, at 3:43 PM, Jeff Carpenter wrote: Stein sells these... ________________________________________________________________________________
Date: Jan 15, 2014
Mounted mine in the overhead. Seems to be a good location so far. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416978#416978 Attachments: http://forums.matronics.com//files/dscn3089_149.jpg ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jan 15, 2014
If you have a center armrest front inside and the rear passengers on the back side. It keeps all the wiring In the center. Also less likely to catch them on their feet when getting out of the Airplane. Charge jacks and music inputs work great there as well. FWIW Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Wednesday, January 15, 2014 12:49 PM Subject: RV10-List: Placement of phone jacks for back seats Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 15, 2014
I put mine (head sets only) on the seat back support. Seems like a bad place at first but most of the people I have in the back are other than family so I usually end up assisting them in getting strapped in. All the cords are out of the way, works good for me. Dick Sipp -----Original Message----- From: Geoff Combs Sent: Wednesday, January 15, 2014 5:37 PM Subject: RE: RV10-List: Placement of phone jacks for back seats If you have a center armrest front inside and the rear passengers on the back side. It keeps all the wiring In the center. Also less likely to catch them on their feet when getting out of the Airplane. Charge jacks and music inputs work great there as well. FWIW Geoff Combs -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Wednesday, January 15, 2014 12:49 PM Subject: RV10-List: Placement of phone jacks for back seats Any ideas re placement of headphone jacks, aux music input jack, USB charging port for back seaters...other than the horizontal area just below the back seat vent? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=416944#416944 ________________________________________________________________________________
Date: Jan 16, 2014
+1 on back seat support. Looks like this: http://kochman.smugmug.com/RV-10/Trips/2013-Cross-Country-Trip/i-7DXQJ82/0/M/2013-05-25%2009.44.15-M.jpg. Downside is that I couldn't easily install the cover for the back seat support that came with my Flightline interior. I don't really miss it, though. On USB charging ports, I'm a big fan of installing cigarette lighter ports if you can, then using a low-profile USB charger that plugs in. That way, if it ever breaks, it's super-easy to replace. On Wed, Jan 15, 2014 at 7:07 PM, Dick & Vicki Sipp wrote: > > I put mine (head sets only) on the seat back support. Seems like a bad > place at first but most of the people I have in the back are other than > family so I usually end up assisting them in getting strapped in. All the > cords are out of the way, works good for me. > > Dick Sipp > > -----Original Message----- From: Geoff Combs > Sent: Wednesday, January 15, 2014 5:37 PM > To: rv10-list(at)matronics.com > Subject: RE: RV10-List: Placement of phone jacks for back seats > > > If you have a center armrest front inside and the rear passengers on the > back side. It keeps all the wiring > In the center. Also less likely to catch them on their feet when getting > out > of the > Airplane. Charge jacks and music inputs work great there as well. > FWIW > > > Geoff Combs > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 > Sent: Wednesday, January 15, 2014 12:49 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Placement of phone jacks for back seats > > > Any ideas re placement of headphone jacks, aux music input jack, USB > charging port for back seaters...other than the horizontal area just below > the back seat vent? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=416944#416944 > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Jan 17, 2014
Subject: Fuel Injection 101 Class at Airflow
I just got this notice from Airflow and am planning to attend. Even though I've done a round of flow balancing for LOP ops, I'm figuring that some training on the fuel injection system would be a good thing. Just posting FYI. From past experience, I recall that the challenge may be to get enough people to hold the class rather than it being over-subscribed. ________________________________________________________________________________
Subject: Re: Fuel Injection 101 Class at Airflow
Date: Jan 17, 2014
Thanks for the heads up. Just signed up. Since we moved to Murphy, NC , this is only two hours away by car. Driving since the 10 is sold and 8A is under construction. Look forward to seeing you again. Tom H. Sent from my iPad > On Jan 17, 2014, at 12:41 PM, Bill Watson wrote: > > I just got this notice from Airflow and am planning to attend. Even though I've done a round of flow balancing for LOP ops, I'm figuring that some training on the fuel injection system would be a good thing. > > Just posting FYI. From past experience, I recall that the challenge may be to get enough people to hold the class rather than it being over-subscribed. > ________________________________________________________________________________
Date: Jan 17, 2014
What are the class dates? Sent from my iPhone On Jan 17, 2014, at 1:56 PM, Tomhanaway wrote: Thanks for the heads up. Just signed up. Since we moved to Murphy, NC , this is only two hours away by car. Driving since the 10 is sold and 8A is under construction. Look forward to seeing you again. Tom H. Sent from my iPad > On Jan 17, 2014, at 12:41 PM, Bill Watson wrote: > > I just got this notice from Airflow and am planning to attend. Even though I've done a round of flow balancing for LOP ops, I'm figuring that some training on the fuel injection system would be a good thing. > > Just posting FYI. From past experience, I recall that the challenge may be to get enough people to hold the class rather than it being over-subscribed. > ________________________________________________________________________________
Date: Jan 17, 2014
Wish I could go, but I would love to read the handout, but not readable for me. Bill Greenley -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Friday, January 17, 2014 12:42 PM Subject: RV10-List: Fuel Injection 101 Class at Airflow I just got this notice from Airflow and am planning to attend. Even though I've done a round of flow balancing for LOP ops, I'm figuring that some training on the fuel injection system would be a good thing. Just posting FYI. From past experience, I recall that the challenge may be to get enough people to hold the class rather than it being over-subscribed. ________________________________________________________________________________
Date: Jan 17, 2014
March 7 (evening) to March 9 (noon Sunday) Sent from my iPad > On Jan 17, 2014, at 2:44 PM, Bob Leffler wrote: > > > What are the class dates? > > Sent from my iPhone > > On Jan 17, 2014, at 1:56 PM, Tomhanaway wrote: > > > Thanks for the heads up. Just signed up. Since we moved to Murphy, NC , this is only two hours away by car. > Driving since the 10 is sold and 8A is under construction. > > Look forward to seeing you again. > > Tom H. > > Sent from my iPad > >> On Jan 17, 2014, at 12:41 PM, Bill Watson wrote: >> >> I just got this notice from Airflow and am planning to attend. Even though I've done a round of flow balancing for LOP ops, I'm figuring that some training on the fuel injection system would be a good thing. >> >> Just posting FYI. From past experience, I recall that the challenge may be to get enough people to hold the class rather than it being over-subscribed. >> > > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2014
Subject: Comp Air Aircraft
Listers, Has anyone purchased an XIO-540-D4A5 from Comp Air Aircraft of Titusville, FL? I tried looking in the archives and did not find any information about them. Ed Godfrey 40717 ________________________________________________________________________________
Subject: Advance flight systems
Date: Jan 18, 2014
Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and others that you don't like? I have watched some of the videos and am looking to find how user friendly and practical the system is. Anything that trips you while shooting approaches? Thanks in advance. ________________________________________________________________________________
Subject: Re: Advance flight systems
Date: Jan 18, 2014
I have a three screen AFS system, 2- 4500's and a 3400 in a symmetrical panel layout. I've been flying the plane for 2 years now and have done a pretty good amount of IFR work including approaches. I have about 30 hours in IMC with the plane and really enjoy how the system works. I've primarily shot GPS approach in actual, both with and without vertical guidance, and just a few ILS approaches. I feel the AFS system coupled to GNS navigator and the AFS/tru-trak autopilot have been truly awesome. The display of information and the organization of the buttons and menus is very intuitive. I believe those with the 5000 series products have it even better with more buttons and less menus. Another feature that is really intuitive is the operation of the autopilot via the knobs on the EFIS, it makes the operation of the whole system, especially in IMC, quite straight forward. Lastly, when I designed my panel I thought that a separate screen, (the 3400) primarily for showing the moving map and geo-referenced approach plates was going to be very useful. I now think of it as essential. In terms of situational awareness, I think the center screen is one of the best tools going. I also have Navworx ADS displaying weather and traffic on the center screen. Flying in the Northeast with traffic on screen is spectacular. Lastly, I installed the AFS AOA system when I built the plane but did not turn it on during the first year of flying, I had never used AOA before and just wasn't ready to wrap my head around another gizmo. Then I turned it on and calibrated it. I'm now a AOA evangelist. It totally changed (improved) how I flew and especially landed the plane. Since the RV-10 has such a wide range of capability from single pilot and unloaded to super fully loaded with all seats occupied, knowing exactly where you are with respect to lift reserve is just huge. My advice, if you don't have it, get it, if you got it, turn it ON! In my RV-8 I'll use AFS gear again. Bob Newman N541RV -----Original Message----- From: Rob Kermanj Sent: Saturday, January 18, 2014 6:05 PM Subject: RV10-List: Advance flight systems Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and others that you don't like? I have watched some of the videos and am looking to find how user friendly and practical the system is. Anything that trips you while shooting approaches? Thanks in advance. ________________________________________________________________________________
Date: Jan 18, 2014
I have no experience with the system other than having Rob Hickman demonstrate at airshows. I like the ability to switch between an EFIS display and a conventional six pack(for cross training or individual preference). I like the ability to display the approach plates. AFS and Dynon have the latter capability. I think the main features to look for is how user friendly the menu/buttons and other controls are, how sharp the display is, does it have features you want like angle of attack, screen layout, etc. and what nav source inputs it will display. Lastly, what is the cost to update its databases. The latter is pretty much a deal killer for the Garmin displays, IMHO, while most of the others are more reasonable. Lastly, how does the autopilot interface with the EFIS and what does that add to the cost. Between Grand Rapids, AFS and Dynon these days mostly a personal choice on displays, buttons, features and menus, they all are good and fairly price competitive. On 1/18/2014 4:05 PM, Rob Kermanj wrote: > > Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and others that you don't like? > > I have watched some of the videos and am looking to find how user friendly and practical the system is. Anything that trips you while shooting approaches? > > Thanks in advance. > > ________________________________________________________________________________
Date: Jan 18, 2014
I agree with Kelly. Remember that nearly everyone, including myself, thinks that their choices were the best choices! Best you can do is educate yourself as much as possible, then make YOUR choice. (BTW GRT will display approach plates) -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417146#417146 ________________________________________________________________________________
Date: Jan 18, 2014
Good discussion. The other aspect to overlay on selection is one's confidence the company will be there in the long run. Dynon and Grand Rapids have the most market share and equally important I can report they both have superb after the sale service. Carl Dual Dynon SkyView and just got my IFR check ride in the RV-10. The SkyView will go into the upcoming RV-8 project as well. -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Saturday, January 18, 2014 7:32 PM Subject: Re: RV10-List: Advance flight systems I have no experience with the system other than having Rob Hickman demonstrate at airshows. I like the ability to switch between an EFIS display and a conventional six pack(for cross training or individual preference). I like the ability to display the approach plates. AFS and Dynon have the latter capability. I think the main features to look for is how user friendly the menu/buttons and other controls are, how sharp the display is, does it have features you want like angle of attack, screen layout, etc. and what nav source inputs it will display. Lastly, what is the cost to update its databases. The latter is pretty much a deal killer for the Garmin displays, IMHO, while most of the others are more reasonable. Lastly, how does the autopilot interface with the EFIS and what does that add to the cost. Between Grand Rapids, AFS and Dynon these days mostly a personal choice on displays, buttons, features and menus, they all are good and fairly price competitive. On 1/18/2014 4:05 PM, Rob Kermanj wrote: > > Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and others that you don't like? > > I have watched some of the videos and am looking to find how user friendly and practical the system is. Anything that trips you while shooting approaches? > > Thanks in advance. > > ________________________________________________________________________________
Date: Jan 18, 2014
Keep in mind that AFS is now a Dynon subsidiary, so I expect support will be around for AFS, Dynon and Grand Rapids for quite awhile. Nothing wrong with Garmin either, although I find their menus less friendly and their database update pricing obscene. On 1/18/2014 6:31 PM, Carl Froehlich wrote: > > Good discussion. The other aspect to overlay on selection is one's > confidence the company will be there in the long run. Dynon and Grand > Rapids have the most market share and equally important I can report they > both have superb after the sale service. > > Carl > Dual Dynon SkyView and just got my IFR check ride in the RV-10. The SkyView > will go into the upcoming RV-8 project as well. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Saturday, January 18, 2014 7:32 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Advance flight systems > > > I have no experience with the system other than having Rob Hickman > demonstrate at airshows. > I like the ability to switch between an EFIS display and a conventional six > pack(for cross training or individual preference). I like the ability to > display the approach plates. AFS and Dynon have the latter capability. > I think the main features to look for is how user friendly the menu/buttons > and other controls are, how sharp the display is, does it have features you > want like angle of attack, screen layout, etc. and what nav source inputs it > will display. Lastly, what is the cost to update its databases. The latter > is pretty much a deal killer for the Garmin displays, IMHO, while most of > the others are more reasonable. > Lastly, how does the autopilot interface with the EFIS and what does that > add to the cost. Between Grand Rapids, AFS and Dynon these days mostly a > personal choice on displays, buttons, features and menus, they all are good > and fairly price competitive. > > On 1/18/2014 4:05 PM, Rob Kermanj wrote: >> >> Anyone with Advanced flight systems EFIS that can comment about it's use > for IFR flight and approaches? Features that you think are great and others > that you don't like? >> I have watched some of the videos and am looking to find how user friendly > and practical the system is. Anything that trips you while shooting > approaches? >> Thanks in advance. >> >> >> >> > > ________________________________________________________________________________
Date: Jan 18, 2014
There are some advantages to both the AFS and Dynon. AFS is using the sky net system used on the synonym. Me I would buy Dynon again, even if AFS has better synvis, simply put the support and attention to the comments of the users is huge for Dynon. I flew 1 hr into the sun today. I ended up flying strictly from the panel and let flight following keep traffic away, the Dynon literally can fly one into the final 100 feet from the runway just from the synvis. Very different from the state of the art HSI we had in our Vietnam era helos. Had to think back in those days. Pascal > On Jan 18, 2014, at 5:31 PM, "Carl Froehlich" wrote: > > > Good discussion. The other aspect to overlay on selection is one's > confidence the company will be there in the long run. Dynon and Grand > Rapids have the most market share and equally important I can report they > both have superb after the sale service. > > Carl > Dual Dynon SkyView and just got my IFR check ride in the RV-10. The SkyView > will go into the upcoming RV-8 project as well. > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen > Sent: Saturday, January 18, 2014 7:32 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Advance flight systems > > > I have no experience with the system other than having Rob Hickman > demonstrate at airshows. > I like the ability to switch between an EFIS display and a conventional six > pack(for cross training or individual preference). I like the ability to > display the approach plates. AFS and Dynon have the latter capability. > I think the main features to look for is how user friendly the menu/buttons > and other controls are, how sharp the display is, does it have features you > want like angle of attack, screen layout, etc. and what nav source inputs it > will display. Lastly, what is the cost to update its databases. The latter > is pretty much a deal killer for the Garmin displays, IMHO, while most of > the others are more reasonable. > Lastly, how does the autopilot interface with the EFIS and what does that > add to the cost. Between Grand Rapids, AFS and Dynon these days mostly a > personal choice on displays, buttons, features and menus, they all are good > and fairly price competitive. > >> On 1/18/2014 4:05 PM, Rob Kermanj wrote: >> >> Anyone with Advanced flight systems EFIS that can comment about it's use > for IFR flight and approaches? Features that you think are great and others > that you don't like? >> >> I have watched some of the videos and am looking to find how user friendly > and practical the system is. Anything that trips you while shooting > approaches? >> >> Thanks in advance. > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Comp Air Aircraft
Date: Jan 18, 2014
I'm not sure they are still in business, I spent months trying to research them about a 6+ seat homebuilt and came up empty. Please post if you find anything. Marcus Sent from my iPhone > On Jan 18, 2014, at 2:59 PM, Ed Godfrey wrote: > > > Listers, > Has anyone purchased an XIO-540-D4A5 from Comp Air Aircraft of Titusville, FL? I tried looking in the archives and did not find any information about them. > > Ed Godfrey > 40717 > > > > ________________________________________________________________________________
Date: Jan 19, 2014
I have a very similar configuration as Bob, except my physical layout is different. If doing my panel again, I would use Aerosport Products symmetrical panel and put one large screen on each side, with a smaller one in the middle for map display. That's a little OT since you can do the same with most vendors. I've been very pleased with the support I've received from AFS. We are fortunate that most of the EFIS vendors today provide great support. I think the merger with Dynon has strengthen both companies. As soon as the weather starts improving, I've got to get my IPC. So I can't really comment on what it's like to fly with the 4500s in IMC. Since you can't buy them anymore, it really doesn't matter. Like Bob mentioned, the buttons and knobs on the 5000 series are greatly improved. The menus are flatter and once they are learned easier to use. If I had the spare cash, I would be upgrading my panel. Bob touched on the use of the autopilot. I'm a strong proponent on which ever EFIS vendor you choose, I highly recommend implementing a stand alone autopilot like Trutrak or Trio. The reason is if there should ever be an EFIS failure, the AP can keep your wings level and on course independently of the EFIS. This buys you significant think time. With the AP functions built into the EFIS and something fails, you are now hand flying. Which scenario would you prefer? For those that know me from conversations at the RV-10 at OSH, are aware that I almost went with GRT. While there is nothing wrong with GRT. Several years later, I'm now glad that I went with AFS. I think AFS has been leading the experimental EFIS vendors bringing innovation to the platform for the last several years. Although my opinion is biased, I'm happy with the decision that I made. Bob Sent from my iPad > On Jan 18, 2014, at 7:23 PM, "Bob-tcw" wrote: > > I have a three screen AFS system, 2- 4500's and a 3400 in a symmetrical panel layout. I've been flying the plane for 2 years now and have done a pretty good amount of IFR work including approaches. I have about 30 hours in IMC with the plane and really enjoy how the system works. I've primarily shot GPS approach in actual, both with and without vertical guidance, and just a few ILS approaches. I feel the AFS system coupled to GNS navigator and the AFS/tru-trak autopilot have been truly awesome. The display of information and the organization of the buttons and menus is very intuitive. I believe those with the 5000 series products have it even better with more buttons and less menus. Another feature that is really intuitive is the operation of the autopilot via the knobs on the EFIS, it makes the operation of the whole system, especially in IMC, quite straight forward. Lastly, when I designed my panel I thought that a separate screen, (the 3400) primarily for showing the moving map and geo-referenced approach plates was going to be very useful. I now think of it as essential. In terms of situational awareness, I think the center screen is one of the best tools going. I also have Navworx ADS displaying weather and traffic on the center screen. Flying in the Northeast with traffic on screen is spectacular. > > Lastly, I installed the AFS AOA system when I built the plane but did not turn it on during the first year of flying, I had never used AOA before and just wasn't ready to wrap my head around another gizmo. Then I turned it on and calibrated it. I'm now a AOA evangelist. It totally changed (improved) how I flew and especially landed the plane. Since the RV-10 has such a wide range of capability from single pilot and unloaded to super fully loaded with all seats occupied, knowing exactly where you are with respect to lift reserve is just huge. My advice, if you don't have it, get it, if you got it, turn it ON! > > In my RV-8 I'll use AFS gear again. > > > Bob Newman > N541RV > > > > > > > > > > > > > > -----Original Message----- From: Rob Kermanj > Sent: Saturday, January 18, 2014 6:05 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Advance flight systems > > > Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and others that you don't like? > > I have watched some of the videos and am looking to find how user friendly and practical the system is. Anything that trips you while shooting approaches? > > Thanks in advance. > > > ________________________________________________________________________________
Date: Jan 19, 2014
Last I knew they were still in business beside Merritt Island Airport ..... I'll ask around. Linn On 1/18/2014 11:50 PM, Marcus Cooper wrote: > > I'm not sure they are still in business, I spent months trying to research them about a 6+ seat homebuilt and came up empty. Please post if you find anything. > Marcus > > Sent from my iPhone > >> On Jan 18, 2014, at 2:59 PM, Ed Godfrey wrote: >> >> >> Listers, >> Has anyone purchased an XIO-540-D4A5 from Comp Air Aircraft of Titusville, FL? I tried looking in the archives and did not find any information about them. >> >> Ed Godfrey >> 40717 >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 19, 2014
I have 2 AFS 4500 and 1 3400. The 3400 is on the copilot side. I have the AFS AP and AOA. I really like controlling the AP from the EFIS. Rob Hickman is always reachable for any questions and Ken Chard is also very helpful with tech questions. The only thing missing from the 4500 in my opinion for IFR is the low enroute maps.(the 5000 series has them as well as touch screen and if I had the money I could upgrade the 4500s) I use an iPad mini with fore flight for this purpose) Being able to set minimum altitudes on an approach is an invaluable safety feature . Flying ILS with the AP is not as smooth as the GPS approaches. You have to remember to set the ILS course correctly.It is not automatic like with some other systems. Alan N668G On Jan 18, 2014, at 10:26 PM, PReid wrote: > > There are some advantages to both the AFS and Dynon. AFS is using the sky net system used on the synonym. > Me I would buy Dynon again, even if AFS has better synvis, simply put the support and attention to the comments of the users is huge for Dynon. > I flew 1 hr into the sun today. I ended up flying strictly from the panel and let flight following keep traffic away, the Dynon literally can fly one into the final 100 feet from the runway just from the synvis. Very different from the state of the art HSI we had in our Vietnam era helos. Had to think back in those days. > Pascal > >> On Jan 18, 2014, at 5:31 PM, "Carl Froehlich" wrote: >> >> >> Good discussion. The other aspect to overlay on selection is one's >> confidence the company will be there in the long run. Dynon and Grand >> Rapids have the most market share and equally important I can report they >> both have superb after the sale service. >> >> Carl >> Dual Dynon SkyView and just got my IFR check ride in the RV-10. The SkyView >> will go into the upcoming RV-8 project as well. >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen >> Sent: Saturday, January 18, 2014 7:32 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Advance flight systems >> >> >> I have no experience with the system other than having Rob Hickman >> demonstrate at airshows. >> I like the ability to switch between an EFIS display and a conventional six >> pack(for cross training or individual preference). I like the ability to >> display the approach plates. AFS and Dynon have the latter capability. >> I think the main features to look for is how user friendly the menu/buttons >> and other controls are, how sharp the display is, does it have features you >> want like angle of attack, screen layout, etc. and what nav source inputs it >> will display. Lastly, what is the cost to update its databases. The latter >> is pretty much a deal killer for the Garmin displays, IMHO, while most of >> the others are more reasonable. >> Lastly, how does the autopilot interface with the EFIS and what does that >> add to the cost. Between Grand Rapids, AFS and Dynon these days mostly a >> personal choice on displays, buttons, features and menus, they all are good >> and fairly price competitive. >> >>> On 1/18/2014 4:05 PM, Rob Kermanj wrote: >>> >>> Anyone with Advanced flight systems EFIS that can comment about it's use >> for IFR flight and approaches? Features that you think are great and others >> that you don't like? >>> >>> I have watched some of the videos and am looking to find how user friendly >> and practical the system is. Anything that trips you while shooting >> approaches? >>> >>> Thanks in advance. >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jan 19, 2014
Upon further review, I missed the statement that the prices are for builders of Comp Air aircraft only, just the same as Van's OEM deal. Only about $3,000 cheaper. Ed Godfrey On 1/18/2014 1:59 PM, Ed Godfrey wrote: > > Listers, > Has anyone purchased an XIO-540-D4A5 from Comp Air Aircraft of > Titusville, FL? I tried looking in the archives and did not find any > information about them. > > Ed Godfrey > 40717 > > ________________________________________________________________________________
Date: Jan 19, 2014
I will also echo these previous statements....if there was a perfect system for everyone then the other companies just wouldn't exist. They ALL are good solutions for the right folks depending on their budget, use, mission, aesthetics, etc.. Same reason some of us like Blue cars and some like Red cars. In the end, I often recommend folks buy what fits their personal desires and needs. Building an airplane by committee is only an exercise in compromises - because as noted each person for the most part will be biased towards what they chose. How do I know?....look at this thread and you'll see a few comments on various systems that are somewhat repeats of marketing statements made by various mfgr's against other mfgr's. For example, once and awhile I still see database costs get thrown around, but people don't realize they often times are comparing apples and oranges - for the most part if you consider the same data across most systems the costs are the pretty much the same. Folks also neglect to mention that while some mfgr's offer "free" VFR data, they charge $500 to turn it on when you buy the system. My point isn't that one method is good or bad, just that you need to take specific bits of data like that in their complete context and look at the overall picture - not just a sales sound byte! Some systems require stuff like separate ARINC adapters to talk to certified GPSes, others don't. Some offer external A/P controls, others don't. Some offer AOA and others don't. Some have big screens while others don't. Some offer things like automatic pitch trim while some don't. Some will fly synthetic approaches to any waypoint, others won't. My point is that I could go on and on for pages about the little nuances and differences that make each system unique on its own but won't make it perfect for all folks in all instances. The fact is AFS, Dynon, Garmin and GRT are all good systems that for the most part are 85% the same as far as functionality. One thing you might try to do is get some time behind the actual units if you can, or go play with them in person as much as you can without any sales pressures. Each system has its own benefits that those mfgr's will tout - and some are more important to some folks than others are. We sell a whole lot of EFISes each year (many hundreds of them) and if one were perfect I wouldn't need to sell the other three, but so far I haven't found that perfect system for everyone. Just my 2 cents as usual! Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner Sent: Saturday, January 18, 2014 6:55 PM Subject: RV10-List: Re: Advance flight systems I agree with Kelly. Remember that nearly everyone, including myself, thinks that their choices were the best choices! Best you can do is educate yourself as much as possible, then make YOUR choice. (BTW GRT will display approach plates) -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417146#417146 ________________________________________________________________________________
Date: Jan 19, 2014
Well put! Now, if someone who knew of all these differences could list them, THAT would be a great contribution! > On Jan 19, 2014, at 10:12 AM, "Stein Bruch" wrote: > > > I will also echo these previous statements....if there was a perfect system > for everyone then the other companies just wouldn't exist. They ALL are > good solutions for the right folks depending on their budget, use, mission, > aesthetics, etc.. Same reason some of us like Blue cars and some like Red > cars. In the end, I often recommend folks buy what fits their personal > desires and needs. Building an airplane by committee is only an exercise in > compromises - because as noted each person for the most part will be biased > towards what they chose. How do I know?....look at this thread and you'll > see a few comments on various systems that are somewhat repeats of marketing > statements made by various mfgr's against other mfgr's. For example, once > and awhile I still see database costs get thrown around, but people don't > realize they often times are comparing apples and oranges - for the most > part if you consider the same data across most systems the costs are the > pretty much the same. Folks also neglect to mention that while some mfgr's > offer "free" VFR data, they charge $500 to turn it on when you buy the > system. My point isn't that one method is good or bad, just that you need > to take specific bits of data like that in their complete context and look > at the overall picture - not just a sales sound byte! Some systems require > stuff like separate ARINC adapters to talk to certified GPSes, others don't. > Some offer external A/P controls, others don't. Some offer AOA and others > don't. Some have big screens while others don't. Some offer things like > automatic pitch trim while some don't. Some will fly synthetic approaches > to any waypoint, others won't. My point is that I could go on and on for > pages about the little nuances and differences that make each system unique > on its own but won't make it perfect for all folks in all instances. > > The fact is AFS, Dynon, Garmin and GRT are all good systems that for the > most part are 85% the same as far as functionality. One thing you might try > to do is get some time behind the actual units if you can, or go play with > them in person as much as you can without any sales pressures. Each system > has its own benefits that those mfgr's will tout - and some are more > important to some folks than others are. We sell a whole lot of EFISes each > year (many hundreds of them) and if one were perfect I wouldn't need to sell > the other three, but so far I haven't found that perfect system for > everyone. > > Just my 2 cents as usual! > > Cheers, > > Stein > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Saturday, January 18, 2014 6:55 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Advance flight systems > > > I agree with Kelly. Remember that nearly everyone, including myself, thinks > that their choices were the best choices! Best you can do is educate > yourself as much as possible, then make YOUR choice. > > (BTW GRT will display approach plates) > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417146#417146 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2014
I think you hit it on the head. There is no one system better for all people. One of the more important things, I think, for an IFR panel, is not so much CAN the system fly the type of approach you need (because many/most can), but more how EASILY they can be configured and managed on the approach. You will find big differences in the way individuals learn and understand knobology. Look back at the old arguments between the original 480 and 430 from garmin. There are people who will swear one is far easier to use than the other. People are all different so I think it's important to try them out and see what fits your style. Tim > On Jan 19, 2014, at 12:12 PM, "Stein Bruch" wrote: > > > I will also echo these previous statements....if there was a perfect system > for everyone then the other companies just wouldn't exist. They ALL are > good solutions for the right folks depending on their budget, use, mission, > aesthetics, etc.. Same reason some of us like Blue cars and some like Red > cars. In the end, I often recommend folks buy what fits their personal > desires and needs. Building an airplane by committee is only an exercise in > compromises - because as noted each person for the most part will be biased > towards what they chose. How do I know?....look at this thread and you'll > see a few comments on various systems that are somewhat repeats of marketing > statements made by various mfgr's against other mfgr's. For example, once > and awhile I still see database costs get thrown around, but people don't > realize they often times are comparing apples and oranges - for the most > part if you consider the same data across most systems the costs are the > pretty much the same. Folks also neglect to mention that while some mfgr's > offer "free" VFR data, they charge $500 to turn it on when you buy the > system. My point isn't that one method is good or bad, just that you need > to take specific bits of data like that in their complete context and look > at the overall picture - not just a sales sound byte! Some systems require > stuff like separate ARINC adapters to talk to certified GPSes, others don't. > Some offer external A/P controls, others don't. Some offer AOA and others > don't. Some have big screens while others don't. Some offer things like > automatic pitch trim while some don't. Some will fly synthetic approaches > to any waypoint, others won't. My point is that I could go on and on for > pages about the little nuances and differences that make each system unique > on its own but won't make it perfect for all folks in all instances. > > The fact is AFS, Dynon, Garmin and GRT are all good systems that for the > most part are 85% the same as far as functionality. One thing you might try > to do is get some time behind the actual units if you can, or go play with > them in person as much as you can without any sales pressures. Each system > has its own benefits that those mfgr's will tout - and some are more > important to some folks than others are. We sell a whole lot of EFISes each > year (many hundreds of them) and if one were perfect I wouldn't need to sell > the other three, but so far I haven't found that perfect system for > everyone. > > Just my 2 cents as usual! > > Cheers, > > Stein > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Saturday, January 18, 2014 6:55 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Advance flight systems > > > I agree with Kelly. Remember that nearly everyone, including myself, thinks > that their choices were the best choices! Best you can do is educate > yourself as much as possible, then make YOUR choice. > > (BTW GRT will display approach plates) > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417146#417146 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2014
Everyone is different. For example Tim uses "knobology" and I use "buttonology" I know which one is better... -----Original Message----- From: Tim Olson Sent: Sunday, January 19, 2014 12:09 PM Subject: Re: RV10-List: Re: Advance flight systems I think you hit it on the head. There is no one system better for all people. One of the more important things, I think, for an IFR panel, is not so much CAN the system fly the type of approach you need (because many/most can), but more how EASILY they can be configured and managed on the approach. You will find big differences in the way individuals learn and understand knobology. Look back at the old arguments between the original 480 and 430 from garmin. There are people who will swear one is far easier to use than the other. People are all different so I think it's important to try them out and see what fits your style. Tim > On Jan 19, 2014, at 12:12 PM, "Stein Bruch" wrote: > > > I will also echo these previous statements....if there was a perfect > system > for everyone then the other companies just wouldn't exist. They ALL are > good solutions for the right folks depending on their budget, use, > mission, > aesthetics, etc.. Same reason some of us like Blue cars and some like Red > cars. In the end, I often recommend folks buy what fits their personal > desires and needs. Building an airplane by committee is only an exercise > in > compromises - because as noted each person for the most part will be > biased > towards what they chose. How do I know?....look at this thread and you'll > see a few comments on various systems that are somewhat repeats of > marketing > statements made by various mfgr's against other mfgr's. For example, once > and awhile I still see database costs get thrown around, but people don't > realize they often times are comparing apples and oranges - for the most > part if you consider the same data across most systems the costs are the > pretty much the same. Folks also neglect to mention that while some mfgr's > offer "free" VFR data, they charge $500 to turn it on when you buy the > system. My point isn't that one method is good or bad, just that you need > to take specific bits of data like that in their complete context and look > at the overall picture - not just a sales sound byte! Some systems > require > stuff like separate ARINC adapters to talk to certified GPSes, others > don't. > Some offer external A/P controls, others don't. Some offer AOA and others > don't. Some have big screens while others don't. Some offer things like > automatic pitch trim while some don't. Some will fly synthetic approaches > to any waypoint, others won't. My point is that I could go on and on for > pages about the little nuances and differences that make each system > unique > on its own but won't make it perfect for all folks in all instances. > > The fact is AFS, Dynon, Garmin and GRT are all good systems that for the > most part are 85% the same as far as functionality. One thing you might > try > to do is get some time behind the actual units if you can, or go play with > them in person as much as you can without any sales pressures. Each > system > has its own benefits that those mfgr's will tout - and some are more > important to some folks than others are. We sell a whole lot of EFISes > each > year (many hundreds of them) and if one were perfect I wouldn't need to > sell > the other three, but so far I haven't found that perfect system for > everyone. > > Just my 2 cents as usual! > > Cheers, > > Stein > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Saturday, January 18, 2014 6:55 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Advance flight systems > > > I agree with Kelly. Remember that nearly everyone, including myself, > thinks > that their choices were the best choices! Best you can do is educate > yourself as much as possible, then make YOUR choice. > > (BTW GRT will display approach plates) > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417146#417146 > > ________________________________________________________________________________
Date: Jan 19, 2014
I tried, but wasn't successful. Many of the differentiators aren't documented well in the manuals. You really have to fly with them. Most people will know the unit they have, but not the others. This make comparisons difficult. Even seeing them side by side in Stein's or Aerotronics at OSH it's difficult to make comparisons because it's hard to evaluate process flows in a booth. There was a group of us making the rounds at OSH looking at screens. There was the hot vendor that was first to bring great graphics to the market. There was another vendor whose graphics weren't as hot, but used a font that was a little larger in font size. Since don't size isn't adjustable on most screens, if you're just starting to wear bi-focals, this could be a factor to you. If not, you won't care. This is hard to distinguish in the documentation. It also hard to determine single pilot work load and process flows by watching the vendor's videos. These are several reasons to find somebody that has your preferred screen installed and go fly with them. Sent from my iPhone On Jan 19, 2014, at 1:31 PM, John Jessen wrote: Well put! Now, if someone who knew of all these differences could list them, THAT would be a great contribution! > On Jan 19, 2014, at 10:12 AM, "Stein Bruch" wrote: > > > I will also echo these previous statements....if there was a perfect system > for everyone then the other companies just wouldn't exist. They ALL are > good solutions for the right folks depending on their budget, use, mission, > aesthetics, etc.. Same reason some of us like Blue cars and some like Red > cars. In the end, I often recommend folks buy what fits their personal > desires and needs. Building an airplane by committee is only an exercise in > compromises - because as noted each person for the most part will be biased > towards what they chose. How do I know?....look at this thread and you'll > see a few comments on various systems that are somewhat repeats of marketing > statements made by various mfgr's against other mfgr's. For example, once > and awhile I still see database costs get thrown around, but people don't > realize they often times are comparing apples and oranges - for the most > part if you consider the same data across most systems the costs are the > pretty much the same. Folks also neglect to mention that while some mfgr's > offer "free" VFR data, they charge $500 to turn it on when you buy the > system. My point isn't that one method is good or bad, just that you need > to take specific bits of data like that in their complete context and look > at the overall picture - not just a sales sound byte! Some systems require > stuff like separate ARINC adapters to talk to certified GPSes, others don't. > Some offer external A/P controls, others don't. Some offer AOA and others > don't. Some have big screens while others don't. Some offer things like > automatic pitch trim while some don't. Some will fly synthetic approaches > to any waypoint, others won't. My point is that I could go on and on for > pages about the little nuances and differences that make each system unique > on its own but won't make it perfect for all folks in all instances. > > The fact is AFS, Dynon, Garmin and GRT are all good systems that for the > most part are 85% the same as far as functionality. One thing you might try > to do is get some time behind the actual units if you can, or go play with > them in person as much as you can without any sales pressures. Each system > has its own benefits that those mfgr's will tout - and some are more > important to some folks than others are. We sell a whole lot of EFISes each > year (many hundreds of them) and if one were perfect I wouldn't need to sell > the other three, but so far I haven't found that perfect system for > everyone. > > Just my 2 cents as usual! > > Cheers, > > Stein > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Turner > Sent: Saturday, January 18, 2014 6:55 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Advance flight systems > > > I agree with Kelly. Remember that nearly everyone, including myself, thinks > that their choices were the best choices! Best you can do is educate > yourself as much as possible, then make YOUR choice. > > (BTW GRT will display approach plates) > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417146#417146 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2014
To answer your last question, I fly in IMC behind a GRT HX, and am happy. There is no button pushing if hand flying. If controlling an autopilot (Trio in my case) I push a knob to bring up the menu, push a button to arm the approach (choose ILS, LPV, etc), exit menu. All this is done prior to final course intercept. One button push plus add power will start the miss, if needed. Another little thing that no one thinks about: count the number of serial ports you get, and try to figure how many you need. Do you have enough? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417220#417220 ________________________________________________________________________________
Date: Jan 19, 2014
I have AFS 4500s and I love them. The only weakness I see is VOR approaches . But the AFS autopilot flys the GPS overlay perfectly. It flys a GPS and I LS much better than you can hand fly it. The only other issue I have is tha t it does not support stormscope data on its screen. Leon Everett > From: flysrv10(at)gmail.com > Subject: RV10-List: Advance flight systems > Date: Sat=2C 18 Jan 2014 18:05:31 -0500 > To: rv10-list(at)matronics.com > > > Anyone with Advanced flight systems EFIS that can comment about it's use for IFR flight and approaches? Features that you think are great and other s that you don't like? > > I have watched some of the videos and am looking to find how user friendl y and practical the system is. Anything that trips you while shooting appr oaches? > > Thanks in advance. > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jan 20, 2014
Bob Turner wrote: > To answer your last question, I fly in IMC behind a GRT HX, and am happy. > There is no button pushing if hand flying. If controlling an autopilot (Trio in my case) I push a knob to bring up the menu, push a button to arm the approach (choose ILS, LPV, etc), exit menu. All this is done prior to final course intercept. One button push plus add power will start the miss, if needed. > > Another little thing that no one thinks about: count the number of serial ports you get, and try to figure how many you need. Do you have enough? Bob, I also have a GRT HX with a TrioPro. The arming is true enough, but there is a lot of button pushing to get the ILS in the first place, unless you have an SL-30. I have the GNS430W and it's a pita to get the approach set up on the 430W. Since I can switch the Trio to the 430W, I just do that and monitor everything on the HX. The 430W will fly the missed, but the single button push is on the 430W - not on the HX. What's your source for the ILS? In fact, that's the real discussion on EFIS selection - you Nav sources. I agree that you need lots of serial ports - like the GRT HX, or HXr. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417260#417260 ________________________________________________________________________________
Date: Jan 20, 2014
Assumptions.... Approach loaded in 430 (note no w) EFIS in heading mode (which commands heading and altitude) AP (tt) coupled to EFIS When ready, pull up soft keys, select ILS, and then respond to one warning. Then when the you are close enough to capture the localizer the EFIS commands the AP to fly the ILS..... There are other ways to get there, but I am almost always being vectored to the approach, thus the heading mode. If you are hand flying, then you would have to engage the AP once the EFIS has captured the localizer and you were ready to stop flying. Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of johngoodman Sent: Monday, January 20, 2014 7:27 AM Subject: RV10-List: Re: Advance flight systems --> Bob Turner wrote: > To answer your last question, I fly in IMC behind a GRT HX, and am happy. > There is no button pushing if hand flying. If controlling an autopilot (Trio in my case) I push a knob to bring up the menu, push a button to arm the approach (choose ILS, LPV, etc), exit menu. All this is done prior to final course intercept. One button push plus add power will start the miss, if needed. > > Another little thing that no one thinks about: count the number of serial ports you get, and try to figure how many you need. Do you have enough? Bob, I also have a GRT HX with a TrioPro. The arming is true enough, but there is a lot of button pushing to get the ILS in the first place, unless you have an SL-30. I have the GNS430W and it's a pita to get the approach set up on the 430W. Since I can switch the Trio to the 430W, I just do that and monitor everything on the HX. The 430W will fly the missed, but the single button push is on the 430W - not on the HX. What's your source for the ILS? In fact, that's the real discussion on EFIS selection - you Nav sources. I agree that you need lots of serial ports - like the GRT HX, or HXr. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417260#417260 ________________________________________________________________________________
Date: Jan 20, 2014
John - yes I have an SL-30 and G420W (GPS-no VOR) combo, so I have a little less button pushing on the Nav's than you do. Still, at my home field (KLVK), I need to enter the ILS approach on the 420W because it's needed in case of a miss, in lieu of an ADF. So my ILS procedure is: enter the approach on the 420W, enter the localizer frequency on the SL-30. Go to the autopilot menu and select "gnav" (if I'm going to have the 420W provide guidance to the localizer, including any procedure turns/holding pattern entries) or "Heading" (if on vectors). Select "ILS arm". Exit the menu. On the main EFIS page push "Execute". The GRT HX does everything from here on except that I need to adjust the throttle to control speed (Trio will auto trim). HX puts final approach course in, scans all nav inputs looking for a localizer and, at localizer intercept, automatically switches to the SL-30. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417304#417304 ________________________________________________________________________________
Subject: Re: Vertical Power sold
Date: Jan 22, 2014
Astronics is fully committed to the VP-X and legacy product lines. They have re-started manufacturing in their Seattle offices, hired a new tech support person, and are working on new upcoming products for the experimental market. -------- Marc Ausman http://www.verticalpower.com "Move up to a modern electrical system" RV-7 IO-390 Flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417454#417454 ________________________________________________________________________________
Subject: FS Wire Harnesses for Slick 6Cyl Mags
Date: Jan 23, 2014
I have 2 Wire Harnesses from a IO/O 540 with Slick Mags. I went with EI and auto plugs; these harnesses have 200hr on them, have been tested and are in good shape. The p/n are M-2878 for RH and M-2877 for LH and M-6002 for both. These fit the 5/8" by 24 REM type plugs. I will sell both for $275.00 or $180.00 each. The prices include shipping ConUS via PayPal. Thanks Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417500#417500 ________________________________________________________________________________
Subject: FS REM38E Spark Plugs
Date: Jan 23, 2014
8 Champion REM38E Spark Plugs with 200hr of use. These plugs have been cleaned, gapped, and tested (Resistance and on the Machine) and are in good shape. The gaskets have been annealed and the plugs have been painted. $95.00 includes shipping ConUS via PayPal. I have pictures I can email, send me a PM. Thanks Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417501#417501 ________________________________________________________________________________
Subject: Re: FS Wire Harnesses for Slick 6Cyl Mags
Date: Jan 25, 2014
Wire Harnesses have been sold. Thanks Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417565#417565 ________________________________________________________________________________
Subject: antenna question
Date: Jan 25, 2014
Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417578#417578 ________________________________________________________________________________
Subject: Re: antenna question
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Jan 25, 2014
Mines not cost effective, but I have 2 Comant bent whip antennas and they work great!! Sent from my iPhone > On Jan 25, 2014, at 1:58 PM, "bob88" wrote: > > > Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417578#417578 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 25, 2014
I used the cheap bent whip, http://www.aircraftspruce.com/pages/av/antenna_com/av534.php, and it works great. Just make sure you dont tighten the nut on the ceramics too tight. After 7 years no issues with talking to tower on the ground even though its below the airplane, mine is located abeam the battery behind the baggage bulkhead. Marcus On Jan 25, 2014, at 1:58 PM, bob88 wrote: Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417578#417578 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jan 25, 2014
Electrically you would need a very sensitive antenna range to measure any performance difference between the straight or bent whip. The bent whip however provides practical advantage for mounting. Get one with the BNC connector to mitigate ring connectors corroding over time - and the BNC connector minimizes the "impedance bump" introduced with ring connectors. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Saturday, January 25, 2014 1:59 PM Subject: RV10-List: antenna question Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417578#417578 ________________________________________________________________________________
Date: Jan 25, 2014
I like the Rami bent whip for a good mount with BNC connector but cheaper than the Commant. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jan 25, 2014, at 1:58 PM, "bob88" wrote: > > > Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417578#417578 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 25, 2014
From: David Clifford <davidsoutpost(at)comcast.net>
Deltapop Aviation. Great high quality antenna's at a very reasonable cost. http://www.deltapopaviation.com/Home.html ----- Original Message ----- From: "bob88" <marty.crooks(at)comcast.net> Sent: Saturday, January 25, 2014 1:58:59 PM Subject: RV10-List: antenna question Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417578#417578 ________________________________________________________________________________
Date: Jan 25, 2014
Take a look at Delta Pop Aviation. They make great antennas at a great price. Bob Sent from my iPad > On Jan 25, 2014, at 4:14 PM, Jesse Saint wrote: > > > I like the Rami bent whip for a good mount with BNC connector but cheaper than the Commant. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > >> On Jan 25, 2014, at 1:58 PM, "bob88" wrote: >> >> >> Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417578#417578 > > > > > ________________________________________________________________________________
Subject: I have a question regarding a Ray Allen Trim System for the
RV-10
Date: Jan 26, 2014
I purchased a RV-10 tail kit and part of the pkg was a T3-12A-TS system. I'm just starting the kit and I'm not sure which AP I will eventually use. What AP is this system compatible with? Does it work with Garmin, AFS or Dynon? It's never been installed. Should I sell it and buy something different closer to avionics? Thanks Tal Holloway ________________________________________________________________________________
Date: Jan 26, 2014
Subject: Re: I have a question regarding a Ray Allen Trim System for
the RV-10 I've often thought that having the autopilot drive the trim servo (the Ray Allen you have is the trim servo) would be far better than having the autopilot control the elevator directly. I went the 'traditional' route ... the Ray Allen is elevator trim and the autopilot controls the elevator. So, to answer your question .... (IMHO) you should keep the Ray Allen and buy AP servos from the same vendor as the AP. Linn On 1/26/2014 6:38 PM, Tal Holloway wrote: > > I purchased a RV-10 tail kit and part of the pkg was a T3-12A-TS system. I'm just starting the kit and I'm not sure which AP I will eventually use. What AP is this system compatible with? Does it work with Garmin, AFS or Dynon? It's never been installed. Should I sell it and buy something different closer to avionics? > > Thanks > > Tal Holloway > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
the RV-10
Date: Jan 26, 2014
Tal. This is the trim servo, not an autopilot servo. Now if you go with an autopilot that supports auto-trimming, the autopilot system will connect into this servo. The trim servo is compatible with all major brands of autopilots Bob Newman N541RV Sent from my iPhone On Jan 26, 2014, at 6:38 PM, Tal Holloway wrote: > > I purchased a RV-10 tail kit and part of the pkg was a T3-12A-TS system. I'm just starting the kit and I'm not sure which AP I will eventually use. What AP is this system compatible with? Does it work with Garmin, AFS or Dynon? It's never been installed. Should I sell it and buy something different closer to avionics? > > Thanks > > Tal Holloway > > > > > > ________________________________________________________________________________
Date: Jan 26, 2014
the RV-10
The servo you have is part of the standard RV-10 tail kit. It is useful and necessary regardless of autopilot installation or brand. Some autopilots support auto-trim and would use this also for that purpose. Bob On Sunday, January 26, 2014, Tcwtech wrote: > > > > Tal. > > This is the trim servo, not an autopilot servo. Now if you go with an > autopilot that supports auto-trimming, the autopilot system will connect > into this servo. The trim servo is compatible with all major brands of > autopilots > > Bob Newman > N541RV > > Sent from my iPhone > > On Jan 26, 2014, at 6:38 PM, Tal Holloway > > wrote: > > > > > > > I purchased a RV-10 tail kit and part of the pkg was a T3-12A-TS system. > I'm just starting the kit and I'm not sure which AP I will eventually use. > What AP is this system compatible with? Does it work with Garmin, AFS or > Dynon? It's never been installed. Should I sell it and buy something > different closer to avionics? > > > > Thanks > > > > Tal Holloway > > > > > > > > > > > > > > ________________________________________________________________________________
the
Date: Jan 26, 2014
Hi Tal! As the others have already posted, all of the available RV autopilots use a servo which drives the elevator directly, not the trim. I suspect the trim doesn't run fast enough in turbulence. Different autopilots deal with trim differently. If you change airspeed, some units will simply indicate that you need to re-trim, manually. Others will drive the Ray Allen trim servos automatically (I know the Trio will do that, if ordered with "auto trim". I think the same is true for TruTrak). This is a ways off, but you will find the trim speed about right at takeoff and landing speeds, but quite fast at cruise speeds. There is a box available ("safe-t-trim"??) which will automatically slow the trim speed as airspeed goes up; and at the same time will cut off trim if it runs more than 3 seconds, as a safety precaution against a runaway trim. An option to consider, when you get to the panel building. Bob -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417637#417637 ________________________________________________________________________________
for the
Date: Jan 26, 2014
Bob mentioned our Safety-trim product, all the details are on our web site: www.tcwtech.com On Jan 26, 2014, at 8:40 PM, "Bob Turner" wrote: > > Hi Tal! > > As the others have already posted, all of the available RV autopilots use a servo which drives the elevator directly, not the trim. I suspect the trim doesn't run fast enough in turbulence. > > Different autopilots deal with trim differently. If you change airspeed, some units will simply indicate that you need to re-trim, manually. Others will drive the Ray Allen trim servos automatically (I know the Trio will do that, if ordered with "auto trim". I think the same is true for TruTrak). > > This is a ways off, but you will find the trim speed about right at takeoff and landing speeds, but quite fast at cruise speeds. There is a box available ("safe-t-trim"??) which will automatically slow the trim speed as airspeed goes up; and at the same time will cut off trim if it runs more than 3 seconds, as a safety precaution against a runaway trim. An option to consider, when you get to the panel building. > > Bob > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417637#417637 > > > > > > > > > > ________________________________________________________________________________
for the
Date: Jan 26, 2014
The same is true for Trutrak with the auto trim module. I also recommend a module that controls trim spend like Safety-trim or the built in trim control in the VPX. Sent from my iPad > On Jan 26, 2014, at 8:40 PM, "Bob Turner" wrote: > > > Hi Tal! > > As the others have already posted, all of the available RV autopilots use a servo which drives the elevator directly, not the trim. I suspect the trim doesn't run fast enough in turbulence. > > Different autopilots deal with trim differently. If you change airspeed, some units will simply indicate that you need to re-trim, manually. Others will drive the Ray Allen trim servos automatically (I know the Trio will do that, if ordered with "auto trim". I think the same is true for TruTrak). > > This is a ways off, but you will find the trim speed about right at takeoff and landing speeds, but quite fast at cruise speeds. There is a box available ("safe-t-trim"??) which will automatically slow the trim speed as airspeed goes up; and at the same time will cut off trim if it runs more than 3 seconds, as a safety precaution against a runaway trim. An option to consider, when you get to the panel building. > > Bob > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417637#417637 > > > > > > > > > > ________________________________________________________________________________
Subject: turf runways
Date: Jan 26, 2014
I have steered clear of grass runways in my RV-10 since there is so little clearance below the wheelpants, but I was wondering what experience others have had? Those of you who fly off of grass, what sort of criteria and conditions do you require? I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunities. Thanks, Marcus ________________________________________________________________________________
Date: Jan 26, 2014
Subject: Re: turf runways
We're talking grass here. If the grass is long enough to cause damage to the pants it's probably long enough to prevent you getting in the air. The thing that destroys the pants are vibrations from many operations on a rough runway. Drive a car down the runway .... at 40 MPH or more you'll feel roughness. Linn ..... lots of ops on grass strips On 1/26/2014 10:48 PM, Cooprv7 wrote: > > I have steered clear of grass runways in my RV-10 since there is so little clearance below the wheelpants, but I was wondering what experience others have had? Those of you who fly off of grass, what sort of criteria and conditions do you require? > I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunities. > > Thanks, > Marcus > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 27, 2014
I live on a 2200' grass runway. When I built my -10 I raised the wheel pants a little higher, maybe an extra 3/4-1" is all I could get. I also made the clearance around the wheel approximately 1" all the way around. I've had no issues and no wheel pant damage so far in 3 years and ~270 hours. -Mike Kraus Sent from my iPhone > On Jan 26, 2014, at 10:48 PM, Cooprv7 wrote: > > > I have steered clear of grass runways in my RV-10 since there is so little clearance below the wheelpants, but I was wondering what experience others have had? Those of you who fly off of grass, what sort of criteria and conditions do you require? > I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunities. > > Thanks, > Marcus > > > > ________________________________________________________________________________
Date: Jan 27, 2014
Go Pantless, like I did. -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417667#417667 ________________________________________________________________________________
Date: Jan 27, 2014
I thought about that but just can't do it. 7 years with pants on has me used to them. > On Jan 27, 2014, at 8:10 AM, "johngoodman" wrote: > > > Go Pantless, like I did. > > -------- > #40572 Phase One complete and flying. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417667#417667 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 27, 2014
What might seem counter-intuitive, in the desert Southwest, pants are needed for engine cooling. The added drag and lower airspeed reduces air over the engine, resulting in hotter temps. I've forgotten how much Deems said his temps came down after he added wheel pants, and I seem to recall the speed penalty was over 10 kts without the pants. Currently planning on doing pants during phase 1, and not before first flight. On 1/27/2014 7:34 AM, Marcus Cooper wrote: > > I thought about that but just can't do it. 7 years with pants on has me used to them. > > >> On Jan 27, 2014, at 8:10 AM, "johngoodman" wrote: >> >> >> Go Pantless, like I did. >> >> -------- >> #40572 Phase One complete and flying. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417667#417667 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Jan 27, 2014
I operate almost exclusively off of grass. I have had some issues with vibration causing the mounting hardware to shake loose. I solved that with Sean's spacer for the mains. The only other thing I notice is a very slow erosion of paint on the bottoms. You need to watch out for ant mounds and gopher holes though. The 10 works great on grass. Gary Specketer ----- Original Message ----- From: "Cooprv7" <cooprv7(at)yahoo.com> Sent: Sunday, January 26, 2014 10:48:03 PM Subject: RV10-List: turf runways I have steered clear of grass runways in my RV-10 since there is so little clearance below the wheelpants, but I was wondering what experience others have had? Those of you who fly off of grass, what sort of criteria and conditions do you require? I'm interested in moving to an Airpark (probably TN) in the next few years and not having to limit the search to paved runways would sure open the opportunities. Thanks, Marcus ________________________________________________________________________________
Date: Jan 27, 2014
I operate my RV-10 in and out of a turf runway at my residential airpark on a regular basis (WN29 - see http://www.blueribbonfarmsassociation.com/airstrip.shtml ) and it is a fine performer. Occasionally the wheel pants get a little ding on the bottom, but it is not from the grass but rather crossing ruts made by others. The RV-10 has such a luxurious amount of power that even soft turf runways are not a problem unless you combine that with high altitude, short field, and obstacles that would make a Maule driver have second thoughts. And if you EVER DRIVE A CAR down our turf runway, especially at high speed, there is going to be an angry mob taking photos and chasing you out of town. Don't do it unless it is your privately owned turf runway. -Dan Masys RV10 N104LD - 660 hrs RV12 N122LD - 180 hrs > From: Linn Walters <flying-nut(at)cfl.rr.com> > Subject: Re: RV10-List: turf runways > We're talking grass here. If the grass is long enough to cause damage > to the pants it's probably long enough to prevent you getting in the air. > The thing that destroys the pants are vibrations from many operations on > a rough runway. Drive a car down the runway .... at 40 MPH or more > you'll feel roughness. > Linn ..... lots of ops on grass strips ________________________________________________________________________________
Date: Jan 27, 2014
No chance of damaging these pants... [Wink] John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417689#417689 Attachments: http://forums.matronics.com//files/img_1936_134.jpg ________________________________________________________________________________
Date: Jan 27, 2014
I have flown into SC00 Triple Tree SC twice. We sat watching everyones pants shake like crazy and that runway is supposedly golf course smooth. If I lived on a grass strip I would beef up wheel pant mounts(switch to stainless) and fiberglass or just remove them. Maybe we will hear from Bill "Living the life in an airpark with turf" Watson. He might have to put some snow skis on this week. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417725#417725 ________________________________________________________________________________
Date: Jan 27, 2014
jchang10 wrote: > Looks nice. Normally, the gear fairing is held in place by the lower > pant. How did you keep the gear fairings in place without the pants? > > Jae > They actually stay on just fine. They are attached at the top, and the only thing I did different is taper them down as far as I could. They actually stay in place without any special work on the bottom. The nose strut is even easier, it already has screws to hold it in place. I did have to change the piano hinge set up on the mains - a pin to go up, and a pin to go down. Without the pant brackets, and with hub caps, there's not much drag to worry about. John -------- #40572 Phase One complete and flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417726#417726 ________________________________________________________________________________
Date: Jan 27, 2014
johngoodman wrote: > > jchang10 wrote: > > Looks nice. Normally, the gear fairing is held in place by the lower > > pant. How did you keep the gear fairings in place without the pants? > > > > Jae > > > > > They actually stay on just fine. They are attached at the top, and the only thing I did different is taper them down as far as I could. They actually stay in place without any special work on the bottom. The nose strut is even easier, it already has screws to hold it in place. I did have to change the piano hinge set up on the mains - a pin to go up, and a pin to go down. > Without the pant brackets, and with hub caps, there's not much drag to worry about. > > John What you lose in speed/time, guessing...6 kias/15 min per long xc would be nothing compared to time and materials repairing broke pants on a grass strip. I would take my pants off in a heartbeat to save $170/mo hangar rent and walk out to my hangar. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417730#417730 ________________________________________________________________________________
Subject: RV project
Date: Jan 27, 2014
Hey all I'm in Cocoa Beach FL for the next 4 weeks, and am looking possibly for a bit of a deversion from my time away, from the Canadian winter. I have a 75% completed RV 10 at home, so I have a little experience pounding rivets. If anyone in the area could use some help please contact me (doesn't have to be an RV10 project). Rick #40956 Southampton, Ont (Cocoa Beach at present) Sent from my iPad ________________________________________________________________________________
Subject: Relocating the fuel filter
Date: Jan 27, 2014
It looks to me that the Vans fuel filter in the tunnel will be beyond inconvenient when inspection time comes around. What about two fuel filters, one on each side, in a more convenient location such as under pilot/copilot seat or the wing attach area? Any major reasons NOT to do this? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417743#417743 ________________________________________________________________________________
Subject: Re: Relocating the fuel filter
Date: Jan 28, 2014
I can't comment on any reasons to why not to relocate the fuel filter. It's not my area of expertise. I can share with you that if you put an access panel on the side of the tunnel, taking the filter out isn't a big deal. I've taken mine out twice with out removing the top tunnel cover. Some folks have gone as far as putting an access panel on both sides. David Ward sells a kit for this and in less than a half hour, you can have it installed. It's not rocket science, so it's also not that big of deal to fabricate your own parts too. It only takes me 5-10 minutes to remove the fuel filter. Another key benefit is being able to inspect the forward part of the tunnel with out having to take everything apart. This is important for those of us that have center consoles install. Bob Sent from my iPad > On Jan 28, 2014, at 1:11 AM, "bob88" wrote: > > > It looks to me that the Vans fuel filter in the tunnel will be beyond inconvenient when inspection time comes around. What about two fuel filters, one on each side, in a more convenient location such as under pilot/copilot seat or the wing attach area? Any major reasons NOT to do this? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=417743#417743 > > > > > > > > > > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Jan 28, 2014
Another way to look at this - the annual inspection requires the tunnel cover be removed anyway. Once the cover is removed pulling the fuel filter if mounted in the per-plan location is fairly easy. I found that the tunnel cover itself needs to be shortened to allow more clearance with tubing and such on the forward end. The cover is shorten enough so that I don't use the most forward screws. This one thing makes the cover removal/install much easier. Carl > On Jan 28, 2014, at 5:19 AM, Bob Leffler wrote: > > > I can't comment on any reasons to why not to relocate the fuel filter. It's not my area of expertise. > > I can share with you that if you put an access panel on the side of the tunnel, taking the filter out isn't a big deal. I've taken mine out twice with out removing the top tunnel cover. Some folks have gone as far as putting an access panel on both sides. > > David Ward sells a kit for this and in less than a half hour, you can have it installed. It's not rocket science, so it's also not that big of deal to fabricate your own parts too. It only takes me 5-10 minutes to remove the fuel filter. > > Another key benefit is being able to inspect the forward part of the tunnel with out having to take everything apart. This is important for those of us that have center consoles install. > > Bob > > Sent from my iPad > >> On Jan 28, 2014, at 1:11 AM, "bob88" wrote: >> >> >> It looks to me that the Vans fuel filter in the tunnel will be beyond inconvenient when inspection time comes around. What about two fuel filters, one on each side, in a more convenient location such as under pilot/copilot seat or the wing attach area? Any major reasons NOT to do this? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417743#417743 > > > > > ________________________________________________________________________________
Date: Jan 28, 2014
There are more than one way to skin a cat...... The access panels allow me to inspect everything forward of the fuel valve. I can easily remove the filter and pump through this opening. I cut my cover at the fuel valve as to not require removing the forward cover unless something I find dictates it. For those of use that have center consoles, this allows us the flexibility of leaving the stack in place during an inspection. I then only have to remove the section aft of the cut. Sent from my iPhone On Jan 28, 2014, at 6:54 AM, Carl Froehlich wrote: Another way to look at this - the annual inspection requires the tunnel cover be removed anyway. Once the cover is removed pulling the fuel filter if mounted in the per-plan location is fairly easy. I found that the tunnel cover itself needs to be shortened to allow more clearance with tubing and such on the forward end. The cover is shorten enough so that I don't use the most forward screws. This one thing makes the cover removal/install much easier. Carl > On Jan 28, 2014, at 5:19 AM, Bob Leffler wrote: > > > I can't comment on any reasons to why not to relocate the fuel filter. It's not my area of expertise. > > I can share with you that if you put an access panel on the side of the tunnel, taking the filter out isn't a big deal. I've taken mine out twice with out removing the top tunnel cover. Some folks have gone as far as putting an access panel on both sides. > > David Ward sells a kit for this and in less than a half hour, you can have it installed. It's not rocket science, so it's also not that big of deal to fabricate your own parts too. It only takes me 5-10 minutes to remove the fuel filter. > > Another key benefit is being able to inspect the forward part of the tunnel with out having to take everything apart. This is important for those of us that have center consoles install. > > Bob > > Sent from my iPad > >> On Jan 28, 2014, at 1:11 AM, "bob88" wrote: >> >> >> It looks to me that the Vans fuel filter in the tunnel will be beyond inconvenient when inspection time comes around. What about two fuel filters, one on each side, in a more convenient location such as under pilot/copilot seat or the wing attach area? Any major reasons NOT to do this? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=417743#417743 > > > > > ________________________________________________________________________________
Date: Jan 28, 2014
Another consideration is that the stock location is downstream of the shutoff valve. If the filters are upstream of the shutoff valve you'll have to deal with that also. Bob On Tue, Jan 28, 2014 at 8:37 AM, Bob Leffler wrote: > > There are more than one way to skin a cat...... > > The access panels allow me to inspect everything forward of the fuel > valve. I can easily remove the filter and pump through this opening. > > I cut my cover at the fuel valve as to not require removing the forward > cover unless something I find dictates it. > > For those of use that have center consoles, this allows us the flexibility > of leaving the stack in place during an inspection. > > I then only have to remove the section aft of the cut. > > Sent from my iPhone > > On Jan 28, 2014, at 6:54 AM, Carl Froehlich > wrote: > > carl.froehlich(at)verizon.net> > > Another way to look at this - the annual inspection requires the tunnel > cover be removed anyway. Once the cover is removed pulling the fuel filter > if mounted in the per-plan location is fairly easy. > > I found that the tunnel cover itself needs to be shortened to allow more > clearance with tubing and such on the forward end. The cover is shorten > enough so that I don't use the most forward screws. This one thing makes > the cover removal/install much easier. > > Carl > > > On Jan 28, 2014, at 5:19 AM, Bob Leffler wrote: > > > > > > I can't comment on any reasons to why not to relocate the fuel filter. > It's not my area of expertise. > > > > I can share with you that if you put an access panel on the side of the > tunnel, taking the filter out isn't a big deal. I've taken mine out twice > with out removing the top tunnel cover. Some folks have gone as far as > putting an access panel on both sides. > > > > David Ward sells a kit for this and in less than a half hour, you can > have it installed. It's not rocket science, so it's also not that big of > deal to fabricate your own parts too. It only takes me 5-10 minutes to > remove the fuel filter. > > > > Another key benefit is being able to inspect the forward part of the > tunnel with out having to take everything apart. This is important for > those of us that have center consoles install. > > > > Bob > > > > Sent from my iPad > > > >> On Jan 28, 2014, at 1:11 AM, "bob88" wrote: > >> > >> > >> It looks to me that the Vans fuel filter in the tunnel will be beyond > inconvenient when inspection time comes around. What about two fuel > filters, one on each side, in a more convenient location such as under > pilot/copilot seat or the wing attach area? Any major reasons NOT to do > this? > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=417743#417743 > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 28, 2014
Well, what does or doesn't need to be removed for the annual condition inspection is dictated by what access panels exist to allow inspection of components. If a side panel access is installed, there is no reason that the tunnel cover would ever need to be removed. Since I and a few others have Paul Grimstead's Control Approach rudder pedal system, which puts the rudder control arms through the tunnel cover, cover removal would involve disassembly of a primary control system, something that should be avoided for routine inspections. Thus a side panel access cover is needed in my particular "modified" RV-10. Keep in mind that what does or doesn't need to be inspected is governed solely by Part 43 Appendix D, not some one's arbitrary annual check list. As to one filter or two, keep in mind that many type certified aircraft do not have any filter between the tanks and the fuel servo inlet, and if they do have one, it is often placed downstream of the boost pump, rather than upstream as Van's has it. While filters could be put at the wing roots, that means twice the work to service, and you would need to be careful to locate well clear of the aileron pushrods travel. Kelly On 1/28/2014 4:54 AM, Carl Froehlich wrote: > > Another way to look at this - the annual inspection requires the tunnel cover be removed anyway. Once the cover is removed pulling the fuel filter if mounted in the per-plan location is fairly easy. > ________________________________________________________________________________
Date: Jan 28, 2014
Also, any debris like o-rings and such that the valve throws off will no longer be filtered. I came to the conclusion that the filter was positioned in a decent place, and that after checking it a few times and finding nothing, I was just going to stretch out my inspection interval of that filter, and make it somewhat also reliant on what I find in my regular sumpings of the tanks. The access panel is about all I'd bother doing to improve things. Tim On 1/28/2014 8:20 AM, Bob Condrey wrote: > Another consideration is that the stock location is downstream of the > shutoff valve. If the filters are upstream of the shutoff valve you'll > have to deal with that also. > Bob > > On Tue, Jan 28, 2014 at 8:37 AM, Bob Leffler > wrote: > > > > > There are more than one way to skin a cat...... > > The access panels allow me to inspect everything forward of the fuel > valve. I can easily remove the filter and pump through this opening. > > I cut my cover at the fuel valve as to not require removing the > forward cover unless something I find dictates it. > > For those of use that have center consoles, this allows us the > flexibility of leaving the stack in place during an inspection. > > I then only have to remove the section aft of the cut. > > Sent from my iPhone > > On Jan 28, 2014, at 6:54 AM, Carl Froehlich > > wrote: > > > > > Another way to look at this - the annual inspection requires the > tunnel cover be removed anyway. Once the cover is removed pulling > the fuel filter if mounted in the per-plan location is fairly easy. > > I found that the tunnel cover itself needs to be shortened to allow > more clearance with tubing and such on the forward end. The cover > is shorten enough so that I don't use the most forward screws. This > one thing makes the cover removal/install much easier. > > Carl > > > On Jan 28, 2014, at 5:19 AM, Bob Leffler > wrote: > > > > > > > > I can't comment on any reasons to why not to relocate the fuel > filter. It's not my area of expertise. > > > > I can share with you that if you put an access panel on the side > of the tunnel, taking the filter out isn't a big deal. I've taken > mine out twice with out removing the top tunnel cover. Some folks > have gone as far as putting an access panel on both sides. > > > > David Ward sells a kit for this and in less than a half hour, you > can have it installed. It's not rocket science, so it's also not > that big of deal to fabricate your own parts too. It only takes me > 5-10 minutes to remove the fuel filter. > > > > Another key benefit is being able to inspect the forward part of > the tunnel with out having to take everything apart. This is > important for those of us that have center consoles install. > > > > Bob > > > > Sent from my iPad > > > >> On Jan 28, 2014, at 1:11 AM, "bob88" > wrote: > >> > > > >> > >> It looks to me that the Vans fuel filter in the tunnel will be > beyond inconvenient when inspection time comes around. What about > two fuel filters, one on each side, in a more convenient location > such as under pilot/copilot seat or the wing attach area? Any major > reasons NOT to do this? > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=417743#417743 > r to browse > nics.com/Navigator?RV10-List" > target="_blank">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com/" > target="_blank">http://forums.matronics.com > -Matt Dralle, List Admin. > ==== > > ________________________________________________________________________________
Date: Jan 28, 2014
On 1/28/2014 9:38 AM, Kelly McMullen wrote: > > Well, what does or doesn't need to be removed for the annual condition > inspection is dictated by what access panels exist to allow inspection > of components. > If a side panel access is installed, there is no reason that the > tunnel cover would ever need to be removed. Since I and a few others > have Paul Grimstead's Control Approach rudder pedal system, which puts > the rudder control arms through the tunnel cover, cover removal would > involve disassembly of a primary control system, something that should > be avoided for routine inspections. Thus a side panel access cover is > needed in my particular "modified" RV-10. I modified the rudder pedals to go through the side of the tunnel instead of through the cover. I also have a console from the tunnel cover up to the bottom of the instrument panel that will have to be removed so the side access panel is a really good mod .... that I'll do. > Keep in mind that what does or doesn't need to be inspected is > governed solely by Part 43 Appendix D, not some one's arbitrary annual > check list. I'd use the word 'guided' rather than 'governed' unless things have changed since I built my Pitts years ago. You can't go wrong using Part 43 liberally in our homebuilts. > > As to one filter or two, keep in mind that many type certified > aircraft do not have any filter between the tanks and the fuel servo > inlet, and if they do have one, it is often placed downstream of the > boost pump, rather than upstream as Van's has it. While filters could > be put at the wing roots, that means twice the work to service, and > you would need to be careful to locate well clear of the aileron > pushrods travel. The Vans filter fits nicely under the seats ...... between the tunnel and the fuselage side. I still might do that instead of the access panel. Linn > Kelly > > On 1/28/2014 4:54 AM, Carl Froehlich wrote: >> >> >> Another way to look at this - the annual inspection requires the >> tunnel cover be removed anyway. Once the cover is removed pulling >> the fuel filter if mounted in the per-plan location is fairly easy. >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 28, 2014
Well, your Pitts probably had older operating limits language than what is standard today. While a plane today could have different language, my understanding of the standard ops limits requires you to use Part 43 Appendix D as a "minimum" checklist, same as it is for type certified aircraft. You can do a more thorough, more detailed checklist, but not less than Appendix D. One of the few sections of Part 43 that applies to amateur built aircraft. On 1/28/2014 8:15 AM, Linn Walters wrote: > >> Keep in mind that what does or doesn't need to be inspected is >> governed solely by Part 43 Appendix D, not some one's arbitrary >> annual check list. > I'd use the word 'guided' rather than 'governed' unless things have > changed since I built my Pitts years ago. You can't go wrong using > Part 43 liberally in our homebuilts. ________________________________________________________________________________
Date: Jan 28, 2014
Thanks Kelly. It's taken me 35 years to get back to building ...... I have a lot of catching up to do!!! Linn On 1/28/2014 10:22 AM, Kelly McMullen wrote: > > Well, your Pitts probably had older operating limits language than > what is standard today. While a plane today could have different > language, my understanding of the standard ops limits requires you to > use Part 43 Appendix D as a "minimum" checklist, same as it is for > type certified aircraft. You can do a more thorough, more detailed > checklist, but not less than Appendix D. One of the few sections of > Part 43 that applies to amateur built aircraft. > > On 1/28/2014 8:15 AM, Linn Walters wrote: >> >>> Keep in mind that what does or doesn't need to be inspected is >>> governed solely by Part 43 Appendix D, not some one's arbitrary >>> annual check list. >> I'd use the word 'guided' rather than 'governed' unless things have >> changed since I built my Pitts years ago. You can't go wrong using >> Part 43 liberally in our homebuilts. > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Re: FS REM38E Spark Plugs
Date: Jan 28, 2014
Spark Plugs Sold Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417786#417786 ________________________________________________________________________________
Date: Jan 30, 2014
If you go with the Desser Monster retreads you'll sit a bit higher and have more clearance. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=417867#417867 ________________________________________________________________________________
Date: Jan 30, 2014
December 06, 2013 - February 03, 2014
RV10-Archive.digest.vol-jp
