RV10-Archive.digest.vol-ju
June 18, 2014 - Present
      > 1.  If the engine stopped for benign reasons, e.g., fuel depletion in one tank,
      and you switched tanks, won't the wind resistance on the prop jump start the
      engine?  and if so, is it better to have the prop in max setting or min setting
      for this?
      > 2. Why does open throttle reduce drag?
      1. If you run a tank dry, the mechanical fuel pump, which does not pump air well,
      won't help much, so RPM doesn't really matter. You'll need the boost pump.
      2. Windmilling engine is expending energy pumping air, like a vacuum cleaner. Opening
      the throttle removes a restriction, raises MP, engine doesn't do as much
      work.
      Bob Turner
      RV-10 QB
      http://forums.matronics.com/viewtopic.php?p=425062#425062
Date: Jun 18, 2014
Subject: Looking for a source of 2024
Does anyone know of a source of some 2024 T3 .032 aluminum angle? It is called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and cannot find anyone who has it smaller than .063. I would really appreciate any leads. Ed Godfrey 40717 ________________________________________________________________________________
Subject: Re: Looking for a source of 2024
Date: Jun 18, 2014
I always just use .063". Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jun 18, 2014, at 8:32 PM, Ed Godfrey wrote: > > > Does anyone know of a source of some 2024 T3 .032 aluminum angle? It is called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and cannot find anyone who has it smaller than .063. I would really appreciate any leads. > > Ed Godfrey > 40717 > > > > ________________________________________________________________________________
Date: Jun 18, 2014
It's not the extruded material like the .063, it's bent .032 sheet to make 3/4 angle. Avail from Van's. Bob On Wednesday, June 18, 2014, Ed Godfrey wrote: > > Does anyone know of a source of some 2024 T3 .032 aluminum angle? It > is called to be used for the Instrument Panel Support Angle, both inboard > and outboard, as described in Figure 1 on page 41-5. I have looked around > and cannot find anyone who has it smaller than .063. I would really > appreciate any leads. > > Ed Godfrey > 40717 > > ________________________________________________________________________________
Date: Jun 18, 2014
Jesse, I have some .063 purchased from Aircraft Spruce, but I am having issues with getting it to work on the inboard angle. I am trying to use the angle between the F1044 and the panel, but there doesn't seem to be the room for it. I spoke with Ken at Van's yesterday about notching out the part that would contact the aft portion of the F1044, the short surface with the nut plate, but he did not agree that notching it out would be a viable idea. Ed Godfrey 40717 On 6/18/2014 7:40 PM, Jesse Saint wrote: > > I always just use .063". > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Jun 18, 2014, at 8:32 PM, Ed Godfrey wrote: >> >> >> Does anyone know of a source of some 2024 T3 .032 aluminum angle? It is called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and cannot find anyone who has it smaller than .063. I would really appreciate any leads. >> >> Ed Godfrey >> 40717 >> >> >> >> > > ________________________________________________________________________________
Date: Jun 18, 2014
Bob, Thanks for the info. That might work for the space between the F1044 and the panel surface. Ed Godfrey 40717 On 6/18/2014 8:10 PM, Bob Condrey wrote: > It's not the extruded material like the .063, it's bent .032 sheet to > make 3/4 angle. Avail from Van's. > > Bob > > On Wednesday, June 18, 2014, Ed Godfrey > wrote: > > > Does anyone know of a source of some 2024 T3 .032 aluminum > angle? It is called to be used for the Instrument Panel Support > Angle, both inboard and outboard, as described in Figure 1 on page > 41-5. I have looked around and cannot find anyone who has it > smaller than .063. I would really appreciate any leads. > > Ed Godfrey > 40717 > > =================================== > " target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > MS - > k">http://forums.matronics.com > =================================== > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > =================================== > > > * > > > * ________________________________________________________________________________
Date: Jun 18, 2014
I notched mine recently. I had no choice but to rebuild the rib because of interference with the panel. I went ahead and reenforced the webbing of the rib with .063. Then I added a piece of 3/4 angle to rebuild the flange that I removed. I'm confident that is stronger than the original design and I don't think it will collapse over time, but only time will tell. If I had photos I'd share them, but the plane is in the hangar (3.5 hours away) and I'm in the recliner. :) Phil On Wed, Jun 18, 2014 at 9:32 PM, Ed Godfrey wrote: > Bob, > Thanks for the info. That might work for the space between the F1044 > and the panel surface. > > Ed Godfrey > 40717 > > > On 6/18/2014 8:10 PM, Bob Condrey wrote: > > It's not the extruded material like the .063, it's bent .032 sheet to make > 3/4 angle. Avail from Van's. > > Bob > > > On Wednesday, June 18, 2014, Ed Godfrey wrote: > >> >> Does anyone know of a source of some 2024 T3 .032 aluminum angle? It >> is called to be used for the Instrument Panel Support Angle, both inboard >> and outboard, as described in Figure 1 on page 41-5. I have looked around >> and cannot find anyone who has it smaller than .063. I would really >> appreciate any leads. >> >> Ed Godfrey >> 40717 >> >> =================================== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> MS - >> k">http://forums.matronics.com >> =================================== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > * > > > * > > ________________________________________________________________________________
Date: Jun 19, 2014
I used some of the stringer profile left over from the tail and wing kits. T he J can be arranged so as not to interfere with the cutouts, or cut off wit h a bandsaw. Sent from my iPad On 19.06.2014, at 03:10, Bob Condrey wrote: > It's not the extruded material like the .063, it's bent .032 sheet to make 3/4 angle. Avail from Van's. > > Bob > > On Wednesday, June 18, 2014, Ed Godfrey wrote: > > Does anyone know of a source of some 2024 T3 .032 aluminum angle? It i s called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and c annot find anyone who has it smaller than .063. I would really appreciate an y leads. > > Ed Godfrey > 40717 > > ========================= > " target="_blank">http://www.matronics.com/Navigator?RV10-List > ========================= > MS - > k">http://forums.matronics.com > ========================= > e - > -Matt Dralle, List Admin. > t="_blank">http://www.matronics.com/contribution > ========================= > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Jun 19, 2014
I'm not sure I understand what you're trying to do. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jun 18, 2014, at 10:30 PM, Ed Godfrey wrote: > > > Jesse, > I have some .063 purchased from Aircraft Spruce, but I am having issues with getting it to work on the inboard angle. I am trying to use the angle between the F1044 and the panel, but there doesn't seem to be the room for it. I spoke with Ken at Van's yesterday about notching out the part that would contact the aft portion of the F1044, the short surface with the nut plate, but he did not agree that notching it out would be a viable idea. > > Ed Godfrey > 40717 > >> On 6/18/2014 7:40 PM, Jesse Saint wrote: >> >> I always just use .063". >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >>> On Jun 18, 2014, at 8:32 PM, Ed Godfrey wrote: >>> >>> >>> Does anyone know of a source of some 2024 T3 .032 aluminum angle? It is called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and cannot find anyone who has it smaller than .063. I would really appreciate any leads. >>> >>> Ed Godfrey >>> 40717 > > > > > ________________________________________________________________________________
Subject: Door strut brackets
Date: Jun 19, 2014
I sent the following note to Sean at planearound.com. "I've been flying my -10 with two of the door strut brackets (and McMaster seals) for just over a year. Recently my son opened the passenger side door and the bracket snapped in two. Nothing special about the door or how he opened it as far as I could tell." Sean emailed back asking if I had plastic or metal brackets. Mine were plastic. He generously offered to send me replacement metal brackets for no charge. They arrived promptly and fit perfectly. Great customer service! It's nice when a vendor stands behind their product and goes out of their way to ensure a happy (repeat) customer. Cheers, Jay 433RV - flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425130#425130 ________________________________________________________________________________
Date: Jun 19, 2014
What Dimension do you need? John Cox - 40600 On Thu, Jun 19, 2014 at 5:10 AM, Jesse Saint wrote: > > I'm not sure I understand what you're trying to do. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On Jun 18, 2014, at 10:30 PM, Ed Godfrey wrote: > > > > > > Jesse, > > I have some .063 purchased from Aircraft Spruce, but I am having > issues with getting it to work on the inboard angle. I am trying to use the > angle between the F1044 and the panel, but there doesn't seem to be the > room for it. I spoke with Ken at Van's yesterday about notching out the > part that would contact the aft portion of the F1044, the short surface > with the nut plate, but he did not agree that notching it out would be a > viable idea. > > > > Ed Godfrey > > 40717 > > > >> On 6/18/2014 7:40 PM, Jesse Saint wrote: > >> > >> I always just use .063". > >> > >> Jesse Saint > >> Saint Aviation, Inc. > >> 352-427-0285 > >> jesse(at)saintaviation.com > >> > >> Sent from my iPad > >> > >>> On Jun 18, 2014, at 8:32 PM, Ed Godfrey > wrote: > >>> > >>> > >>> Does anyone know of a source of some 2024 T3 .032 aluminum angle? > It is called to be used for the Instrument Panel Support Angle, both > inboard and outboard, as described in Figure 1 on page 41-5. I have looked > around and cannot find anyone who has it smaller than .063. I would really > appreciate any leads. > >>> > >>> Ed Godfrey > >>> 40717 > > > > > > > > > > > > ________________________________________________________________________________
Subject: N62DN
Date: Jun 20, 2014
I came across another couple of possibilities when I received this: (1) On November 16, 2013, a Piper PA-28-140 lost engine power shortly after takeoff and crashed, resulting in a destroyed aircraft and a seriously injured pilot. Why? Read on. You are probably very familiar with the air ducts commonly referred to as "SCAT," "SCEET," "CAT," and "CEET." You may have replaced some on the aircraft engines you have worked. You might even keep a ready supply on hand. Although we are not going to go into detail about each duct here, we do caution you to ensure that the one you are using is acceptable for the particular application intended. Beware! Although it "looks like a duct," "feels like a duct," or "fits like a duct," it may not function like the "approved" duct for your specific job. Investigation revealed that the "SCAT" duct installed as a carburetor air inlet duct on the mishap PA-28-140 did not meet the specifications of the air duct authorized and provided by Piper. The duct COLLAPSED, thereby cutting off air flow to the engine. An approved Piper inlet duct is engineered and designed to operate in a vacuum of -12 inches of HG (mercury), at temperatures between -65 to +500 degrees Fahrenheit. The wire supporting the duct is .048 inches in diameter. Although the collapsed duct had the correct inside diameter, the wall thickness was thinner and the wire size was several thousandths less than the Piper duct. We believe that "off the shelf" ducts may be being used as a normal replacement part instead of the authorized Piper carburetor air inlet duct. We say this because there have been no approved carburetor air inlets ducts ordered from Piper since 1999 even though the FAA registry indicates there are over 5000 registered PA-28-140 aircraft. What can you do to help prevent another accident? Well, if applicable, check your fleet of PA-28-140 aircraft. Pass the word to the owners and operators who fly these aircraft, as well as your AMT colleagues that maintain these aircraft. The number one thing you can do is always research the manufacturer's manuals to validate you are using approved replacement parts. Finally, never replace components based on what was previously installed. Trust, but verify. See Maintenance Safety Tip-1209, "Who do YOU Trust?" published August 2012. <http://www.faasafety.gov/SPANS/noticeView.aspx?nid=4046> http://www.faasafety.gov/SPANS/noticeView.aspx?nid=4046. (2) There are SBs and ADs on the carburetors (Precision Air Motive I believe) . The carb float sinks and fails to control fuel to engine. Too much fuel will not light; perhaps a mixture at almost idle cutoff may cause a light. ________________________________________________________________________________
Date: Jun 21, 2014
Subject: plastic protector
I'm getting ready to install the windshield and am looking for a product to protect the plastic while I work near the edges. I have seen a paint-on or spray-on latex that will peel off when the installation is done .... but I can't remember what the product name is. Any ideas??? Linn ________________________________________________________________________________
Subject: Re: plastic protector
Date: Jun 22, 2014
Not the answer you were looking for, but...I used some 20 mil pipe tape to outline the area that I wanted the fiberglass to end on the windscreen. 20 mil tape is very thick and durable which allowed me to sand down to it without fear of hitting the plexi. The rest of the windscreen was just covered with the plastic it came with from Desser...but that plastic is just there to prevent the random bit of epoxy or other debris from touching or damaging it. Learned the tape trick from Wally at Synergy Air. D -------- David Halmos RV-10 Flying! Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425249#425249 ________________________________________________________________________________
Subject: Baffling Question
Date: Jun 22, 2014
I am trying to fit the CB-1001A Front Baffle (Ref. Page FF2-14) which as shown on the plans, should fit snugly over and around the MT P-420-3 propeller governor. Vans sent me the MT P-860-3 propeller governor with my Firewall Forward kit, which is now installed on my engine. This governor has a lip around the front which prevents the CB-1001A Front Baffle from slipping over the governor. I am tempted to cut the hole in the CB-1001A Front Baffle much larger, however this will then mean that I will need to seal around the opening in the CB-1001A, as once the baffle is over the front of the governor, the body of the governor reduces in diameter, leaving about a 1/4" gap around the governor to the edge of the hole in the CB-1001A. Have I buggered up my interpretations of the plan, or does the new propeller governor just not fit the CB-1001A baffle as was originally intended? If so, what are people using to seal the gap between the propeller governor and the CB-1001A. After mucking around with these baffles, I can now see why people install plenums in lieu of baffles! I'd appreciate your assistance and any links or photos that could assist me please. Warm regards and thanks in anticipation. Patrick Pulis Adelaide, South Australia #40299 ________________________________________________________________________________
Date: Jun 22, 2014
From: David Clifford <davidsoutpost(at)comcast.net>
You are probably thiking to this stuff referred to as "spraylat". http://www.aircraftspruce.com/catalog/cspages/discoat4220plexiglass1.php?clickkey=9996 It's commonly used in the Rutan based construction of the Long EZ's and Cozy's but most folks have moved away from it due to the difficulty in removal when everything is done. What we used building the Cozy and what I used on my -10 was common 3/4" wide electrical tape. It stretches to form curves very easily and peels off leaving very little to no residue. Do about 2 width's of tape wide, overlapping an 1/8", then follow up with a layer of duct tape on top of that. Gorilla tape works very well and provides a good margin of safety from marking up the glass from sanding and other cutting tools. The remainder of the transparency can be covered in heavy 10 mill plastic. ----- Original Message ----- From: "Linn Walters" <flying-nut(at)cfl.rr.com> Sent: Saturday, June 21, 2014 11:12:00 PM Subject: RV10-List: plastic protector I'm getting ready to install the windshield and am looking for a product to protect the plastic while I work near the edges. I have seen a paint-on or spray-on latex that will peel off when the installation is done .... but I can't remember what the product name is. Any ideas??? Linn ________________________________________________________________________________
Subject: Re: Baffling Question
Date: Jun 22, 2014
That part is always hard to fit. You can trim it as necessary and then seal it (RTV works well). You could also use baffle seal to fill the gap. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 22, 2014, at 6:47 AM, Patrick Pulis wrote: > > > I am trying to fit the CB-1001A Front Baffle (Ref. Page FF2-14) which as shown on the plans, should fit snugly over and around the MT P-420-3 propeller governor. > > Vans sent me the MT P-860-3 propeller governor with my Firewall Forward kit, which is now installed on my engine. This governor has a lip around the front which prevents the CB-1001A Front Baffle from slipping over the governor. > > I am tempted to cut the hole in the CB-1001A Front Baffle much larger, however this will then mean that I will need to seal around the opening in the CB-1001A, as once the baffle is over the front of the governor, the body of the governor reduces in diameter, leaving about a 1/4" gap around the governor to the edge of the hole in the CB-1001A. > > Have I buggered up my interpretations of the plan, or does the new propeller governor just not fit the CB-1001A baffle as was originally intended? > > If so, what are people using to seal the gap between the propeller governor and the CB-1001A. > > After mucking around with these baffles, I can now see why people install plenums in lieu of baffles! > > I'd appreciate your assistance and any links or photos that could assist me please. > > Warm regards and thanks in anticipation. > > Patrick Pulis > Adelaide, South Australia > #40299 > > > > ________________________________________________________________________________
Date: Jun 22, 2014
On 6/22/2014 6:47 AM, Patrick Pulis wrote: > > I am trying to fit the CB-1001A Front Baffle (Ref. Page FF2-14) which as shown on the plans, should fit snugly over and around the MT P-420-3 propeller governor. > > Vans sent me the MT P-860-3 propeller governor with my Firewall Forward kit, which is now installed on my engine. This governor has a lip around the front which prevents the CB-1001A Front Baffle from slipping over the governor. > > I am tempted to cut the hole in the CB-1001A Front Baffle much larger, however this will then mean that I will need to seal around the opening in the CB-1001A, as once the baffle is over the front of the governor, the body of the governor reduces in diameter, leaving about a 1/4" gap around the governor to the edge of the hole in the CB-1001A. > > Have I buggered up my interpretations of the plan, or does the new propeller governor just not fit the CB-1001A baffle as was originally intended? I think you've got it right! > If so, what are people using to seal the gap between the propeller governor and the CB-1001A. I haven't done it yet but I'm planning on a combination of fiberglass sheet and the cowl seal material. > After mucking around with these baffles, I can now see why people install plenums in lieu of baffles! I'm going to install a plenum .... I hate cowl seal. I also want to convert the inlets to round ones. The reason I haven't done that already is I'm on the fence with making my own or going the Sam James route. Linn ..... just riveted on the fwd upper fuselage!!! > > I'd appreciate your assistance and any links or photos that could assist me please. > > Warm regards and thanks in anticipation. > > Patrick Pulis > Adelaide, South Australia > #40299 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 22, 2014
Thanks David! I thought it was 'Spraylat' but Bing coughed up a paint company .... and I just couldn't find it. The search engine in ACS couldn't find anything either ..... used a bunch of keywords. I'll probably do your suggestion. Thanks. Linn On 6/22/2014 6:57 AM, David Clifford wrote: > You are probably thiking to this stuff referred to as "spraylat". > http://www.aircraftspruce.com/catalog/cspages/discoat4220plexiglass1.php?clickkey=9996 > It's commonly used in the Rutan based construction of the Long EZ's > and Cozy's but most folks have moved away from it due to the > difficulty in removal when everything is done. What we used building > the Cozy and what I used on my -10 was common 3/4" wide electrical > tape. It stretches to form curves very easily and peels off leaving > very little to no residue. Do about 2 width's of tape wide, > overlapping an 1/8", then follow up with a layer of duct tape on top > of that. Gorilla tape works very well and provides a good margin of > safety from marking up the glass from sanding and other cutting tools. > The remainder of the transparency can be covered in heavy 10 mill plastic. > ------------------------------------------------------------------------ > *From: *"Linn Walters" <flying-nut(at)cfl.rr.com> > *To: *rv10-list(at)matronics.com > *Sent: *Saturday, June 21, 2014 11:12:00 PM > *Subject: *RV10-List: plastic protector > > > I'm getting ready to install the windshield and am looking for a product > to protect the plastic while I work near the edges. I have seen a > paint-on or spray-on latex that will peel off when the installation is > done .... but I can't remember what the product name is. = > &= > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jun 22, 2014
Thanks Linn Warm regards Patrick > On 22 Jun 2014, at 21:41, Linn Walters wrote: > > >> On 6/22/2014 6:47 AM, Patrick Pulis wrote: >> >> I am trying to fit the CB-1001A Front Baffle (Ref. Page FF2-14) which as shown on the plans, should fit snugly over and around the MT P-420-3 propeller governor. >> >> Vans sent me the MT P-860-3 propeller governor with my Firewall Forward kit, which is now installed on my engine. This governor has a lip around the front which prevents the CB-1001A Front Baffle from slipping over the governor. >> >> I am tempted to cut the hole in the CB-1001A Front Baffle much larger, however this will then mean that I will need to seal around the opening in the CB-1001A, as once the baffle is over the front of the governor, the body of the governor reduces in diameter, leaving about a 1/4" gap around the governor to the edge of the hole in the CB-1001A. >> >> Have I buggered up my interpretations of the plan, or does the new propeller governor just not fit the CB-1001A baffle as was originally intended? > I think you've got it right! >> If so, what are people using to seal the gap between the propeller governor and the CB-1001A. > I haven't done it yet but I'm planning on a combination of fiberglass sheet and the cowl seal material. >> After mucking around with these baffles, I can now see why people install plenums in lieu of baffles! > I'm going to install a plenum .... I hate cowl seal. I also want to convert the inlets to round ones. The reason I haven't done that already is I'm on the fence with making my own or going the Sam James route. > Linn ..... just riveted on the fwd upper fuselage!!! > >> >> I'd appreciate your assistance and any links or photos that could assist me please. >> >> Warm regards and thanks in anticipation. >> >> Patrick Pulis >> Adelaide, South Australia >> #40299 >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Jun 22, 2014
If you are on the fence, there is one more alternative that may be better than Sam James: Showplanes RV-10 cowling.... http://tinyurl.com/ojlo6f5 No personal knowledge, just know it exists. On 6/22/2014 5:11 AM, Linn Walters wrote: > .... I hate cowl seal. I also want to convert the inlets to > round ones. The reason I haven't done that already is I'm on the > fence with making my own or going the Sam James route. > Linn ..... just riveted on the fwd upper fuselage!!! > ________________________________________________________________________________
Date: Jun 22, 2014
Thanks Kelly. Always good to have a couple of approaches. I already have the Van's cowl fitted and just can't justify pitching it. I'm enjoying the 'journey' and doing some mods to improve (I hope) the Van's approach. I didn't like Van's alt air ...... I know, you can reset it after shutdown .... so I did this: Because I can ...... I'd probably be flying by now if it wasn't for all the mods :-P Linn On 6/22/2014 8:45 AM, Kelly McMullen wrote: > > If you are on the fence, there is one more alternative that may be > better than Sam James: Showplanes RV-10 cowling.... > http://tinyurl.com/ojlo6f5 > No personal knowledge, just know it exists. > > On 6/22/2014 5:11 AM, Linn Walters wrote: >> .... I hate cowl seal. I also want to convert the inlets to >> round ones. The reason I haven't done that already is I'm on the >> fence with making my own or going the Sam James route. >> Linn ..... just riveted on the fwd upper fuselage!!! >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 22, 2014
I put a small piece of piano hinge on the back face of that baffle piece. That allowed me to have a nice tight fitting around the governor and be able to open the hole around the governor via the hinge to get it in and out easier. -------- Myron Nelson Mesa, AZ Emp completed, QB wings completed, legacy build fuse on gear. FWF complete. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425279#425279 ________________________________________________________________________________
Date: Jun 22, 2014
Patrick. Send email to jackm(at)vinetechequipment.com . I will reply with pictures of what we did. Prop cable is also routed above engine and left heat input is on rear right baffle. Prop cable above allows for better seal because you don't need to cut ramp for prop lever clearance -------- Jackm Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425283#425283 ________________________________________________________________________________
Subject: Paint Question
Date: Jun 23, 2014
I plan to defer painting until I have flown a bit, and then have it done professionally. The question is whether to put a coat of UV SmoothPrime on the fiberglass parts as temporary protection. Will a professional paint shop have a problem with this when the time comes for the final paint job? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425349#425349 ________________________________________________________________________________
Subject: Re: Paint Question
Date: Jun 24, 2014
That should not be a problem. Filling the pinholes before flying would assure that oil and stuff doesn't get trapped in the pinholes. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 24, 2014, at 12:32 AM, "bob88" wrote: > > > I plan to defer painting until I have flown a bit, and then have it done professionally. The question is whether to put a coat of UV SmoothPrime on the fiberglass parts as temporary protection. Will a professional paint shop have a problem with this when the time comes for the final paint job? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425349#425349 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 24, 2014
Thats what I did, no problems whatsoever. Looks a lot nicer too! Marcus 40286 On Jun 24, 2014, at 12:32 AM, bob88 wrote: I plan to defer painting until I have flown a bit, and then have it done professionally. The question is whether to put a coat of UV SmoothPrime on the fiberglass parts as temporary protection. Will a professional paint shop have a problem with this when the time comes for the final paint job? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425349#425349 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 24, 2014
A Lancair 4 builder at the airpark used SmoothPrime for protection during construction. He would do all the body work, then coat/sand the SmoothPrime until satisfied. The last step was to add another coat of SmoothPrime on top but then not sand it. The final sanding would then be just before paint. If you are going to fly before paint then recommend you do all the SmoothPrime/sand applications you want but the last step would be to use an epoxy primer on top. What I learned with SmoothPrime on my plane is it takes several days for this water based product to really cure - and then never wet sand it. SmoothPrime is not designed to withstand the elements. For the next airplane I'll most likely not use SmoothPrime. Instead I'll use PPG filler primers (K36 and K38) after surface prep. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of bob88 Sent: Tuesday, June 24, 2014 12:33 AM Subject: RV10-List: Paint Question I plan to defer painting until I have flown a bit, and then have it done professionally. The question is whether to put a coat of UV SmoothPrime on the fiberglass parts as temporary protection. Will a professional paint shop have a problem with this when the time comes for the final paint job? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425349#425349 ________________________________________________________________________________
Date: Jun 24, 2014
I used it, and really liked it. You need to put multiple coats on, so that it will peel off later. I just painted it on with a brush. I can't think of the name, but I got it from Aircraft Spruce. It comes in a quart plastic bottle, and it's blue in color. I also have an identical bottle of mould release, that is green in color - they seem to be identical. Looking on the AC site, I see two products that it might be: Plastiease 512B, or PVA Release Film. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425359#425359 ________________________________________________________________________________
Subject: RV10 performance
Date: Jun 24, 2014
Does anyone have TO performance data? I have been using the only data point I have; I have an experimental point of 2800 gross, 80F and 5200 field elevation the tower confirmed a ground roll of 2500 feet. This was not a wind the engine prior to brake release type of data point. My rule of thumb has been any density altitude less than 10000 and runway length in excess of 5000 is Ok for a gross departure. Of course there are other factors to consider like nearby terrain and weather but these are all subjective.. Has anyone created or seen the Van's data on takeoff and landing performance data? My C177RG had an empty weight of about 1800 and a gross of 2800 on 200HP; Given the 260 HP of the RV10 I would expect at least a 30% improvement in density altitude performance. Has anybody other DA data points? ________________________________________________________________________________
Subject: Re: RV10 performance
Date: Jun 24, 2014
You wont be disappointed-but I would be cautious of a gross weight departur e at 10000 density altitude in a cardinal but that's just me.TVL is a commo n airport for me and the rv-10 is one of the best,no,the best non turbo per formers I have flown out of there.Havent had to circle the lake yet.Every rv-10 is a little different things like ei and higher compressions can make an even bigger difference at high da. -----Original Message----- From: DLM <dlm34077(at)cox.net> Sent: Tue, Jun 24, 2014 5:23 pm Subject: RV10-List: RV10 performance Does anyone have TO performance data? I have been using the only data point I have; I have an experimental point of 2800 gross, 80F and 5200 field ele vation the tower confirmed a ground roll of 2500 feet. This was not a wind the engine prior to brake release type of data point. My rule of thumb has been any density altitude less than 10000 and runway length in excess of 50 00 is Ok for a gross departure. Of course there are other factors to consid er like nearby terrain and weather but these are all subjective.. Has anyon e created or seen the Van's data on takeoff and landing performance data? M y C177RG had an empty weight of about 1800 and a gross of 2800 on 200HP; Gi ven the 260 HP of the RV10 I would expect at least a 30% improvement in den sity altitude performance. Has anybody other DA data points? ________________________________________________________________________________
From: Dave Saylor <dave.saylor.aircrafters(at)gmail.com>
Date: Jun 24, 2014
I've done a max performance T/O near gross weight at a DA that was just over 10,000. Years ago we departed KEMM (ele. 7300') returning to California from Oshkosh. Not much wind, warm afternoon. We used RWY 34, which is 8000' long. Weight was gross less 15 gallons, call it 2600. We ran up and leaned for max power holding the brakes, and used half flaps. We were well off the ground and climbing abeam the terminal, which is about 3500' of runway. I decided before T/O to abort if not airborne by that point since it was easy to identify. That departure has been my rule of thumb ever since. For example, we departed KCDC last earlier this month. DA was over 9000, right at gross weight, and T/O was a complete non-event. We were at least 1000' off the ground by the end of the 8600' runway. --Dave On Tue, Jun 24, 2014 at 5:22 PM, DLM wrote: > Does anyone have TO performance data? I have been using the only data > point I have; I have an experimental point of 2800 gross, 80F and 5200 > field elevation the tower confirmed a ground roll of 2500 feet. This was > not a wind the engine prior to brake release type of data point. My rule of > thumb has been any density altitude less than 10000 and runway length in > excess of 5000 is Ok for a gross departure. Of course there are other > factors to consider like nearby terrain and weather but these are all > subjective.. Has anyone created or seen the Van's data on takeoff and > landing performance data? My C177RG had an empty weight of about 1800 and a > gross of 2800 on 200HP; Given the 260 HP of the RV10 I would expect at > least a 30% improvement in density altitude performance. Has anybody other > DA data points? > > * > > > * > > ________________________________________________________________________________
Date: Jun 24, 2014
If you're using 2800 lbs for gross you will have a tough time finding comparisons, since most people are using 2700. Remember climb rate is very sensitive to weight. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425414#425414 ________________________________________________________________________________
Date: Jun 24, 2014
We took off from UIO (SEQU) at probably 2,800 lbs, rolling uphill, and used a bout 3,000 ft or less. I think one notch of flaps. The -10 performs great th ere. A -10 in Mexico is operating out of a 5,000 MSL airport 600M long and has to stay about 2,500-2,600 max. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jun 24, 2014, at 9:13 PM, Dave Saylor wrote: > > I've done a max performance T/O near gross weight at a DA that was just ov er 10,000. > > Years ago we departed KEMM (ele. 7300') returning to California from Oshko sh. > > Not much wind, warm afternoon. We used RWY 34, which is 8000' long. > > Weight was gross less 15 gallons, call it 2600. We ran up and leaned for m ax power holding the brakes, and used half flaps. > > We were well off the ground and climbing abeam the terminal, which is abou t 3500' of runway. I decided before T/O to abort if not airborne by that po int since it was easy to identify. > > That departure has been my rule of thumb ever since. > > For example, we departed KCDC last earlier this month. DA was over 9000, r ight at gross weight, and T/O was a complete non-event. We were at least 10 00' off the ground by the end of the 8600' runway. > > --Dave > > >> On Tue, Jun 24, 2014 at 5:22 PM, DLM wrote: >> Does anyone have TO performance data? I have been using the only data poi nt I have; I have an experimental point of 2800 gross, 80F and 5200 field el evation the tower confirmed a ground roll of 2500 feet. This was not a wind t he engine prior to brake release type of data point. My rule of thumb has be en any density altitude less than 10000 and runway length in excess of 5000 i s Ok for a gross departure. Of course there are other factors to consider li ke nearby terrain and weather but these are all subjective.. Has anyone crea ted or seen the Van's data on takeoff and landing performance data? My C177R G had an empty weight of about 1800 and a gross of 2800 on 200HP; Given the 2 60 HP of the RV10 I would expect at least a 30% improvement in density altit ude performance. Has anybody other DA data points? >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 25, 2014
I attached my T/O table based on my T/O performance test. Please note that max RPM is reduced to 2500 due to noise regulation here in CH. Aircraft was at MTOW 2700 lbs / 1225 kg. take-off configuration flaps 1 = 0 degrees. -------- RV-10 builder (flying) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425436#425436 Attachments: http://forums.matronics.com//files/image_206.jpg ________________________________________________________________________________
Date: Jun 25, 2014
16,500 with the family fully loaded....but it didn't climb very well. I'm sure we could have made it higher, but I don't find much point in going over 14K very much. It starts to become work again. We don't carry O2 on all flights. I kind of missed it on the one we just got back from though (write-up coming within 24 hours). The problem (in my mind at least) with using 16-17k+ to stay above the weather is that you don't have any performance margin left. If you're plenty happy to be stuck back into the CB's, then fine, but if you really want to stay "on top", you have already pushed into the area where performance of the plane may not give you much room. To each their own, but I just find it to be more work as you pass 14K. Tim ________________________________________________________________________________
Subject: : n46007 performance
Date: Jun 25, 2014
Date: Jun 25, 2014
For you flat landers that may be high enough, but for us guys with granite at that altitude higher is needed. :) Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, June 25, 2014 8:41 AM Subject: Re: RV10-List: RV10 performance 16,500 with the family fully loaded....but it didn't climb very well. I'm sure we could have made it higher, but I don't find much point in going over 14K very much. It starts to become work again. We don't carry O2 on all flights. I kind of missed it on the one we just got back from though (write-up coming within 24 hours). The problem (in my mind at least) with using 16-17k+ to stay above the weather is that you don't have any performance margin left. If you're plenty happy to be stuck back into the CB's, then fine, but if you really want to stay "on top", you have already pushed into the area where performance of the plane may not give you much room. To each their own, but I just find it to be more work as you pass 14K. Tim ________________________________________________________________________________
Date: Jun 25, 2014
HAHA! Yeah, you got me pegged. ;) Actually, 15K I think will get you over any granite in the lower 48, right? (But definitely not with proper IFR clearances). I wouldn't mind some day, just once, taking a cross country flight where I only have the wife and I, and minimal baggage. I'm sure my opinions are set because of my common mode of flight....loaded to about gross, 4 seats filled. Man what that plane could do if it were just me in the front, and the wife in the baggage area...for better cruise C.G. performance, of course. :) Tim On 6/25/2014 11:07 AM, Rene Felker wrote: > > For you flat landers that may be high enough, but for us guys with granite > at that altitude higher is needed. :) > > Rene' Felker > N423CF > 801-721-6080 > ________________________________________________________________________________
Date: Jun 25, 2014
Or better yet with your wife in the front and you in the baggage area!!! ;-) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Wednesday, June 25, 2014 9:30 AM Subject: Re: RV10-List: RV10 performance HAHA! Yeah, you got me pegged. ;) Actually, 15K I think will get you over any granite in the lower 48, right? (But definitely not with proper IFR clearances). I wouldn't mind some day, just once, taking a cross country flight where I only have the wife and I, and minimal baggage. I'm sure my opinions are set because of my common mode of flight....loaded to about gross, 4 seats filled. Man what that plane could do if it were just me in the front, and the wife in the baggage area...for better cruise C.G. performance, of course. :) Tim On 6/25/2014 11:07 AM, Rene Felker wrote: > > For you flat landers that may be high enough, but for us guys with > granite at that altitude higher is needed. :) > > Rene' Felker > N423CF > 801-721-6080 > ________________________________________________________________________________
Date: Jun 25, 2014
Subject: Extra fuel
A friend with a Lancair IVP has plumbed in a bladder in his baggage compartment that holds ~ 20 gal. He needs that for long range, as he has a turbo-prop up front. The bladder is setup with quick disconnects so it can come out when load is more important than range. Seems like that would be ideal for the -10, to have an extra 15-20 gal to not exceed baggage compartment loading, and to give you full IFR reserve over standard tank capacity, while not changing wing loading or bending moments. Don't recall if anyone has done baggage compartment tank of any kind. I know the couple options for extra wing tanks, but am not thrilled with having more wt further out the wing span. I suppose you could plumb in a transfer pump to move the fuel to a wing tank after using up 60-90 min fuel out of that tank. ________________________________________________________________________________
Date: Jun 25, 2014
Ha! Yeah, with me back there the cruise would be even faster! Tim > On Jun 25, 2014, at 11:48 AM, "Ben Westfall" wrote: > > > Or better yet with your wife in the front and you in the baggage area!!! ;-) > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Wednesday, June 25, 2014 9:30 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: RV10 performance > > > > HAHA! Yeah, you got me pegged. ;) > > Actually, 15K I think will get you over any granite in the lower 48, right? > (But definitely not with proper IFR clearances). > > I wouldn't mind some day, just once, taking a cross country flight where I > only have the wife and I, and minimal baggage. I'm sure my opinions are set > because of my common mode of flight....loaded to about gross, 4 seats > filled. Man what that plane could do if it were just me in the front, and > the wife in the baggage area...for better cruise C.G. performance, of > course. :) Tim > > > >> On 6/25/2014 11:07 AM, Rene Felker wrote: >> >> For you flat landers that may be high enough, but for us guys with >> granite at that altitude higher is needed. :) >> >> Rene' Felker >> N423CF >> 801-721-6080 > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2014
Subject: Re: Extra fuel
I'm not fond of fuel in the cabin. I'm also not fond of sitting in an airplane and trying to relieve myself in a bottle while flying the plane. Ok, so I have an autopilot ....... I am really fond of stopping at 3-4 hours to hit the head and stretch my legs. Linn On 6/25/2014 1:20 PM, Kelly McMullen wrote: > A friend with a Lancair IVP has plumbed in a bladder in his baggage > compartment that holds ~ 20 gal. He needs that for long range, as he > has a turbo-prop up front. > The bladder is setup with quick disconnects so it can come out when > load is more important than range. > Seems like that would be ideal for the -10, to have an extra 15-20 gal > to not exceed baggage compartment loading, and to give you full IFR > reserve over standard tank capacity, while not changing wing loading > or bending moments. Don't recall if anyone has done baggage > compartment tank of any kind. I know the couple options for extra wing > tanks, but am not thrilled with having more wt further out the wing > span. I suppose you could plumb in a transfer pump to move the fuel to > a wing tank after using up 60-90 min fuel out of that tank. > * > > > * ________________________________________________________________________________
Date: Jun 25, 2014
Guys, we need OAT data too. It's density altitude that matters here. I've been no higher (that I recall) than 16,500' density altitude but that was with just 2 adults and some luggage, and it flew fine. Weight makes a big difference. As to the original post: you cannot compare a 177 and -10, even of similar weight, and extrapolate climb rates, without knowing more information, like lift and drag data. But if you could magically put 260 HP into the cardinal and keep the weight the same, you'd see a huge increase in climb rate - a lot more than 30%. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425481#425481 ________________________________________________________________________________
Date: Jun 25, 2014
Unless you throttle back you aren't going to do 4 hours IFR and have required reserves. I understand the fuel in the cabin, although not sure it is much different than the fuel in the tunnel issue. On Wed, Jun 25, 2014 at 10:52 AM, Linn Walters wrote: > > I'm not fond of fuel in the cabin. I'm also not fond of sitting in an > airplane and trying to relieve myself in a bottle while flying the plane. > Ok, so I have an autopilot ....... I am really fond of stopping at 3-4 > hours to hit the head and stretch my legs. > Linn > > > On 6/25/2014 1:20 PM, Kelly McMullen wrote: > > A friend with a Lancair IVP has plumbed in a bladder in his baggage > compartment that holds ~ 20 gal. He needs that for long range, as he has a > turbo-prop up front. > The bladder is setup with quick disconnects so it can come out when load > is more important than range. > Seems like that would be ideal for the -10, to have an extra 15-20 gal to > not exceed baggage compartment loading, and to give you full IFR reserve > over standard tank capacity, while not changing wing loading or bending > moments. Don't recall if anyone has done baggage compartment tank of any > kind. I know the couple options for extra wing tanks, but am not thrilled > with having more wt further out the wing span. I suppose you could plumb in > a transfer pump to move the fuel to a wing tank after using up 60-90 min > fuel out of that tank. > > > * > > > * > > ________________________________________________________________________________
Date: Jun 25, 2014
That's not really true. I've had numerous trips where my fuel burn came out to 10.0gph for the entire flight. That's 6 hours of total range, and I've never landed with less than 10.2 in the tanks...but that was nearly 5 hours of flying when I did it. It's plenty possible to come in with 45 minute reserves after a 4 hour flight. The trip I just flew I averaged 9.2 to 9.8gph once I reached cruise...so 4 hours very reasonable. But, we do use the bottle. Tim On 6/25/2014 1:39 PM, Kelly McMullen wrote: > Unless you throttle back you aren't going to do 4 hours IFR and have > required reserves. I understand the fuel in the cabin, although not sure > it is much different than the fuel in the tunnel issue. > ________________________________________________________________________________
Date: Jun 25, 2014
If you are burning 10 gph, you are not even close to 75%, i.e. you have throttled back or gone higher than where 75% is available. LOP 10 gph=150 hp. Even lean of peak, 75% is 13 gph or 195hp. That is 4.6 hrs of fuel, which is less than 4+45, ignoring you also need fuel to go to alternate. No question you can extend range by going slower. On 6/25/2014 12:04 PM, Tim Olson wrote: > > That's not really true. I've had numerous trips where my fuel burn > came out to 10.0gph for the entire flight. That's 6 hours of > total range, and I've never landed with less than 10.2 in the > tanks...but that was nearly 5 hours of flying when I did it. > It's plenty possible to come in with 45 minute reserves after > a 4 hour flight. The trip I just flew I averaged 9.2 to 9.8gph > once I reached cruise...so 4 hours very reasonable. > > But, we do use the bottle. > > Tim > > > On 6/25/2014 1:39 PM, Kelly McMullen wrote: >> Unless you throttle back you aren't going to do 4 hours IFR and have >> required reserves. I understand the fuel in the cabin, although not sure >> it is much different than the fuel in the tunnel issue. >> > > ________________________________________________________________________________
Date: Jun 25, 2014
Y'all be careful out there... In the aircraft I fly at work, the max speed and min speeds are shown on the airspeed tape. As we get up near the airplanes limit, it is REALLY eye opening how little margin there really is... There is a reason it's called "coffin corner"... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425504#425504 ________________________________________________________________________________
Date: Jun 25, 2014
So the nice thing about EAB is you get to choose. 700 nm trip? Your choice: put in an extra 20 gal, run 75%, get there in 4 hours; or keep standard tanks, run 10 gal/hr, get there 20 minutes later and $75 richer. If I did a lot of really long cross-countries, and was happy with the 'personal bladder' issues, an extra tank would look attractive if it could eliminate a fuel stop. Fuel stops never seem to take less than an hour. But I think I'd draw the line at re-fueling inside the cabin. How do you keep from flooding the cabin with fuel vapor? In fact I see re-fueling and venting as major issues to be figured out with aux tanks-even more so if you want them removable. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425507#425507 ________________________________________________________________________________
Date: Jun 25, 2014
I dont believe you need a vent with a bladder style tank that collapses as it empties. Dave Leikam On Jun 25, 2014, at 7:15 PM, Bob Turner wrote: > > So the nice thing about EAB is you get to choose. > 700 nm trip? Your choice: put in an extra 20 gal, run 75%, get there in 4 hours; or keep standard tanks, run 10 gal/hr, get there 20 minutes later and $75 richer. > If I did a lot of really long cross-countries, and was happy with the 'personal bladder' issues, an extra tank would look attractive if it could eliminate a fuel stop. Fuel stops never seem to take less than an hour. > But I think I'd draw the line at re-fueling inside the cabin. How do you keep from flooding the cabin with fuel vapor? In fact I see re-fueling and venting as major issues to be figured out with aux tanks-even more so if you want them removable. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425507#425507 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2014
Actually that was WOT at 9,000 and 11,000'. 13.5 gph is what I may see if I were running ROP. I almost never see flows over 11gph, and I definitely can count on being under 12gph for any x/c trip unless I'm down low (under 7000) where I don't generally fly LOP. If you fly in the 13k-14K range you'll be more in the 8's for gph, and people like Jesse Saint have had flights in the 7's at higher altitudes. So no, that wasn't pulled back...but you're correct that it was high enough to not be at 75%. It's not really a matter of "going slower" however. Sure, we're not getting full speed since we're LOP, but we're cruising in the mid 160's LOP. Tim On 6/25/2014 5:01 PM, Kelly McMullen wrote: > > If you are burning 10 gph, you are not even close to 75%, i.e. you > have throttled back or > gone higher than where 75% is available. LOP 10 gph=150 hp. > Even lean of peak, 75% is 13 gph or 195hp. That is 4.6 hrs of fuel, > which is less than 4+45, > ignoring you also need fuel to go to alternate. No question you can > extend range by going slower. > ________________________________________________________________________________
Date: Jun 25, 2014
Tim, GAMI and others have shown that for normally aspirated engines in the compression range of the 260 hp IO-540, fuel flow times 15 equals horsepower. If you are flying at 10 gph, it is not possible to be generating over 150 hp. If you are ROP, it takes 10.8 to 11.0 gph to generate the same horsepower. Vans said the plane goes 153 kts at 55%, full gross, or 156 kts at 2200 lbs. 11gph would be 165 hp or 64% LOP. So even though Van's does not give figures for 65% and you are running a bit less than that, you are at a more efficient power setting than 75%. You can generate 75% at upwards of 10,000 ft IF you choose to up engine speed to 2600 or 2700. Limiting rpm to 2300 or 2400 will also limit max power, and has the same effect as reducing throttle. Generally one does better to run 75% IF flying into significant headwind. On 6/25/2014 8:17 PM, Tim Olson wrote: > > Actually that was WOT at 9,000 and 11,000'. > 13.5 gph is what I may see if I were running ROP. > I almost never see flows over 11gph, and I definitely can count on being > under 12gph for any x/c trip unless I'm down low (under 7000) where > I don't generally fly LOP. If you fly in the 13k-14K range you'll be > more in the > 8's for gph, and people like Jesse Saint have had flights in the 7's > at higher > altitudes. So no, that wasn't pulled back...but you're correct that it > was high enough to not be at 75%. It's not really a matter of "going > slower" > however. Sure, we're not getting full speed since we're LOP, but > we're cruising > in the mid 160's LOP. > Tim > > > On 6/25/2014 5:01 PM, Kelly McMullen wrote: >> >> If you are burning 10 gph, you are not even close to 75%, i.e. you >> have throttled back or >> gone higher than where 75% is available. LOP 10 gph=150 hp. >> Even lean of peak, 75% is 13 gph or 195hp. That is 4.6 hrs of fuel, >> which is less than 4+45, >> ignoring you also need fuel to go to alternate. No question you can >> extend range by going slower. >> > > ________________________________________________________________________________
Date: Jun 25, 2014
Kellym wrote: > Tim, > > Generally one does better to run 75% IF flying into significant headwind. > If by better you mean less fuel burned, that's true - but only for headwinds over 100 knots! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425523#425523 ________________________________________________________________________________
Subject: extra fuel in baggage
Date: Jun 26, 2014
I have a 20 gallon tank that fits thru the baggage door. I installed two extra bag floor ribs to provide hard points to strap it down. The supply and vent lines were plumbed in during the build. It=99s plumbed the same as certified aux fuel systems, that is a pilot activated low pressure boost pump at the tank sends the fuel thru a check valve and into the left main tank, after you have burned enough out of the main tank. The mission for the extra gas (Vancouver Island to Alaska, with no fuel stops) no longer exists for me, but the system will be used for tankering for fuel cost savings. I highly recommend that anyone considering such a system take great care to insure the mounting of the tank is secure (for abrubt stops). I=99m sure that can be accomplished with bladders as well, but I wouldn=99t feel good about just throwing a seat belt over one. I vented my tank overboard, and I consider that a necessary design consideration as well. Anybody that would like to see pictures of my installation, send me an email, off the list. Chris Hukill finishing up the cowling Even more #%!& fiberglass!! ________________________________________________________________________________
Date: Jun 26, 2014
Here are some actual numbers out of my Garmin logs. All Ops LOP D-ALT TAS GPH OAT % PWR 11K 164 10.2 -2.3 59 7K 167 11.5 -1 66 8K 167 11.8 10.5 68 10K 164 11 9 63 In most cases I can gain 10kts running ROP, but the FF rate is in the 14 to 16GPH range. I flight plan for 11 GPH. 10 more Gallons would make this plane a bit more useful for those flights that are right on the edge of it's IFR range. But I am not willing to carry fuel in the cockpit to gain it. Bill -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425536#425536 ________________________________________________________________________________
Date: Jun 26, 2014
Here you go! During my climb performance test. I had to stop at 15k due to airspace clearance. OAT -9C at MTOW 2700lbs still climbing with 350ft/min at Vy. CHT gets quite high though. Mike -------- RV-10 builder (flying) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425556#425556 Attachments: http://forums.matronics.com//files/image_871.jpg ________________________________________________________________________________
Date: Jun 26, 2014
just returned from a Fl to Ca trip. We did a 4.6 flight with 16 gallons remaining on the LA to TX leg. This was a headwind flight and would easily have made 1000 miles with a tail wind. 4 hours is very easy, but I have a my injectors tuned for LOP so seeing 9.6 GPH at 12.5K is easily done. -----Original Message----- From: Tim Olson Sent: Wednesday, June 25, 2014 12:04 PM Subject: Re: RV10-List: Extra fuel That's not really true. I've had numerous trips where my fuel burn came out to 10.0gph for the entire flight. That's 6 hours of total range, and I've never landed with less than 10.2 in the tanks...but that was nearly 5 hours of flying when I did it. It's plenty possible to come in with 45 minute reserves after a 4 hour flight. The trip I just flew I averaged 9.2 to 9.8gph once I reached cruise...so 4 hours very reasonable. But, we do use the bottle. Tim On 6/25/2014 1:39 PM, Kelly McMullen wrote: > Unless you throttle back you aren't going to do 4 hours IFR and have > required reserves. I understand the fuel in the cabin, although not sure > it is much different than the fuel in the tunnel issue. > ________________________________________________________________________________
Date: Jun 27, 2014
OK, I've got to ask... When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425579#425579 ________________________________________________________________________________
Date: Jun 27, 2014
Or, when you get that low on fuel, do you want the fuel evenly divided between tanks, or all in one tank? Which option gives better indication of fuel remaining and is more likely to keep steady flow to engine? On Fri, Jun 27, 2014 at 6:40 AM, johngoodman wrote: > > OK, I've got to ask... > When you have 10.2 gallons left in the tanks, are the Van's floats reading > zero, but the totalizer shows that much left? > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425579#425579 > > ________________________________________________________________________________
Date: Jun 27, 2014
Is this for me? If so, then no. My floats read very far down before they don't read anymore. I would bet that the floats still bounce around with 1-2 gallons left in the tanks. I don't remember exactly how low. I know mine read fine down under 5 gallons. But, I would not trust them to give exact readings that low. The totalizer, however, is very very accurate. I usually fill within a just a couple tenths of a gallon to what I see on the totalizer as fuel burned. I have taken both fuel tanks up, one at a time, and flown at 5000' above the airport, and ran them dry, then landed on the other full tank and sumped out what was left. In the RV-10, if you run the tanks dry in level flight, you'll only have about 1-2 cups of fuel that you'll get out of the sumps. So, most fuel is useable.....but that's level flight. You may have worse luck with fuel unporting if you are on descent as the fuel flows into the nose of the tank, and you may unport quicker depending how you slip/skid the ball. That's why I don't bother landing with minimal fuel. If I were to try to stretch the fuel a little further, I don't know that I'd go less than 6 gallons, and if I were that low, I'd much rather have 6 + 0 than 3 + 3, because my guess is that you could unport fuel pretty easily at 3 gallons...so I'd rather have one tank much more full so that unporting isn't a problem on the landing tank. But that would be more risk than I'd be happy to take, so 5+5 is really more like what I'm comfortable with. Tim On 6/27/2014 8:40 AM, johngoodman wrote: > > OK, I've got to ask... > When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425579#425579 > ________________________________________________________________________________
Date: Jun 27, 2014
What is the alternative? 8^) I agree with all your points. While I have landed a couple different planes a couple times with 30 min fuel remaining, it is no where near as comfortable as landing with 45 min to 60 min fuel remaining. Especially when some planes have explicit placards of no take-off with less than 1/4 tank. I have always assumed that also meant a significant risk if a go-around was necessary with less than 1/4 in that tank. Unporting is a real problem if close to the ground. Fuel injected engines generally want around 10 seconds to relight after fuel is restored, while carbureted engines usually will relight almost instantly when they get fuel. On Fri, Jun 27, 2014 at 6:55 AM, Tim Olson wrote: > That's why I don't bother *landing* with minimal fuel. > > > Tim > > > On 6/27/2014 8:40 AM, johngoodman wrote: > >> > >> >> OK, I've got to ask... >> When you have 10.2 gallons left in the tanks, are the Van's floats >> reading zero, but the totalizer shows that much left? >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> > > ________________________________________________________________________________
Date: Jun 27, 2014
I guess you're right....there aren't many options OTHER than landing. :) And I agree 100% with your comments. I did find when I ran the tanks dry in flight that the engine went from full power to idle and as fast as I could turn the valve the power returned, so that was a positive. I think that with the prop windmilling the mechanical pump sucked in the fuel pretty quickly. Regarding the landing with 1 tank with all the fuel, or landing with split fuel that is minimal in both, personally while I don't like either option, I think the safer option is to land with one tank more full. I think the unporting is a larger risk than the risk of running one tank dry and switching to the full one for the remainder of the flight. (as long as you've been switching the tanks back and forth during the flight so you know there isn't gunk or water that you're going to get with that last switch) If I were (and I won't) trying to go for max range, I'd switch back and forth every x minutes during the flight until I got to 10 gallons remaining in one tank. Then I'd burn the other tank dry, and switch to that 10 gallon tank for the rest of the trip. I keep that in my hat for an emergency situation, but I'm not going to operate that way on a normal x/c flight, that's for sure. Tim On 6/27/2014 9:21 AM, Kelly McMullen wrote: > What is the alternative? 8^) > > I agree with all your points. While I have landed a couple different > planes a couple times with 30 min fuel remaining, it is no where near as > comfortable as landing with 45 min to 60 min fuel remaining. Especially > when some planes have explicit placards of no take-off with less than > 1/4 tank. I have always assumed that also meant a significant risk if a > go-around was necessary with less than 1/4 in that tank. Unporting is a > real problem if close to the ground. Fuel injected engines generally > want around 10 seconds to relight after fuel is restored, while > carbureted engines usually will relight almost instantly when they get fuel. > > > On Fri, Jun 27, 2014 at 6:55 AM, Tim Olson > wrote: > > > > That's why I don't bother _landing_ with minimal fuel. > > > Tim > ________________________________________________________________________________
Date: Jun 27, 2014
I'm with Tim on that. Also, when one tank is dry, I trim the ball to the empty side to reduce the risk if unporting the tank with fuel remaining. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 10:39 AM, Tim Olson wrote: > > > I guess you're right....there aren't many options OTHER than > landing. :) > > And I agree 100% with your comments. > > I did find when I ran the tanks dry in flight that > the engine went from full power to idle and as fast > as I could turn the valve the power returned, so that > was a positive. I think that with the prop windmilling > the mechanical pump sucked in the fuel pretty quickly. > > Regarding the landing with 1 tank with all the fuel, > or landing with split fuel that is minimal in both, > personally while I don't like either option, I think the > safer option is to land with one tank more full. I think > the unporting is a larger risk than the risk of running > one tank dry and switching to the full one for the > remainder of the flight. (as long as you've been > switching the tanks back and forth during the flight > so you know there isn't gunk or water that you're going > to get with that last switch) > > If I were (and I won't) trying to go for max range, > I'd switch back and forth every x minutes during > the flight until I got to 10 gallons remaining in > one tank. Then I'd burn the other tank dry, and switch > to that 10 gallon tank for the rest of the trip. > I keep that in my hat for an emergency situation, but > I'm not going to operate that way on a normal x/c > flight, that's for sure. > > Tim > >> On 6/27/2014 9:21 AM, Kelly McMullen wrote: >> What is the alternative? 8^) >> >> I agree with all your points. While I have landed a couple different >> planes a couple times with 30 min fuel remaining, it is no where near as >> comfortable as landing with 45 min to 60 min fuel remaining. Especially >> when some planes have explicit placards of no take-off with less than >> 1/4 tank. I have always assumed that also meant a significant risk if a >> go-around was necessary with less than 1/4 in that tank. Unporting is a >> real problem if close to the ground. Fuel injected engines generally >> want around 10 seconds to relight after fuel is restored, while >> carbureted engines usually will relight almost instantly when they get fuel. >> >> >> On Fri, Jun 27, 2014 at 6:55 AM, Tim Olson > > wrote: >> >> > >> That's why I don't bother _landing_ with minimal fuel. >> >> >> Tim > > > > ________________________________________________________________________________
Date: Jun 27, 2014
On 6/27/2014 9:40 AM, johngoodman wrote: Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now. My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is. With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully. > > OK, I've got to ask... > When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425579#425579 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jun 27, 2014
The floats hit the top of the tank around 24-26 gallons because if the dihedral. If installed and calibrated correctly, they will read accurately down to very close to empty. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote: > > > On 6/27/2014 9:40 AM, johngoodman wrote: > Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. > > The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now. > > My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is. > > With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully. > >> >> OK, I've got to ask... >> When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > ________________________________________________________________________________
Date: Jun 27, 2014
I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! Give yourselves a hand of applause, You've come a long way! Deems On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint wrote: > > The floats hit the top of the tank around 24-26 gallons because if the > dihedral. If installed and calibrated correctly, they will read accurately > down to very close to empty. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote: > > > > > > On 6/27/2014 9:40 AM, johngoodman wrote: > > Strangely enough, up until recently my fuel gauges always show slightly > more fuel than I actually have and the totalizer slightly less. Splitting > the difference gave me the right number. Running with the totalizer number > gave me a safety factor. > > > > The totalizer issue was due to placing the GRT unit in the Van's plans > location. It ran high when the boost pumps was on and who knows what else. > Relocating it to between the controller and spider makes it amazingly > accurate now. > > > > My fuel gauges never show completely full tanks but they will show even > the slightest amount of remaining fuel sloshing about. I assume some of > this is a calibration issue with the GRT EIS but it works fine as is. > > > > With 10 gallons left my approach is to have most of those in one tank > and to run off the other (and hard VFR with airports underneath). If > there's even a hiccup, tanks get switched and we are landing NOW. Not my > cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even > for testing but did spend a year measuring things very carefully. > > > johngoodman(at)earthlink.net> > >> > >> OK, I've got to ask... > >> When you have 10.2 gallons left in the tanks, are the Van's floats > reading zero, but the totalizer shows that much left? > >> John > >> > >> -------- > >> #40572 Phase One complete in 2011 > >> > >> > >> > >> > >> Read this topic online here: > >> > >> http://forums.matronics.com/viewtopic.php?p=425579#425579 > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> ----- > >> No virus found in this message. > >> Checked by AVG - www.avg.com > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 27, 2014
I agree with Deems. I got started on the list with no pilot or mechanic lice nse. Now I have both. I've learned a lot from this group and have enjoyed th e journey. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 1:11 PM, Deems Davis wrote: > > I've been reading the threads on fuel and performance lately, and have ben efited from the discussions. One thing that struck me, is that we have all c ome a LONG way, I feel like I "grew-up" airplane-wise with all of you as we w ent through this RV10 journey together. =46rom the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance a nd operations. I've come to know many of you 1st hand and count you as frien ds. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finish ed our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! > > Give yourselves a hand of applause, You've come a long way! > > Deems > > > >> On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint wr ote: >> >> The floats hit the top of the tank around 24-26 gallons because if the di hedral. If installed and calibrated correctly, they will read accurately dow n to very close to empty. >> >> Jesse Saint >> I-TEC, Inc. >> jesse(at)itecusa.org >> www.itecusa.org >> www.mavericklsa.com >> C: 352-427-0285 >> O: 352-465-4545 >> F: 815-377-3694 >> >> Sent from my iPhone >> >> > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote : >> > >> > >> > On 6/27/2014 9:40 AM, johngoodman wrote: >> > Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting t he difference gave me the right number. Running with the totalizer number g ave me a safety factor. >> > >> > The totalizer issue was due to placing the GRT unit in the Van's plans l ocation. It ran high when the boost pumps was on and who knows what else. R elocating it to between the controller and spider makes it amazingly accurat e now. >> > >> > My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of th is is a calibration issue with the GRT EIS but it works fine as is. >> > >> > With 10 gallons left my approach is to have most of those in one tank a nd to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of te a and I haven't had a hiccup yet. I haven't run a tank dry even for testing b ut did spend a year measuring things very carefully. >> > net> >> >> >> >> OK, I've got to ask... >> >> When you have 10.2 gallons left in the tanks, are the Van's floats rea ding zero, but the totalizer shows that much left? >> >> John >> >> >> >> -------- >> >> #40572 Phase One complete in 2011 >> >> >> >> >> >> >> >> >> >> Read this topic online here: >> >> >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> >> No virus found in this message. >> >> Checked by AVG - www.avg.com >> > >> > >> > >> > >> > >> >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 27, 2014
It really has been a great learning experience for everyone, me too. Some of the people I've met became like family. The aircraft itself has been truly amazing and now I don't know what I'd do without it. Coming from spam cans, there really is no way I'd want to go back. I think many people these days don't know what they're missing by NOT trying to do things like build your own airplane. Do they really think it's beyond them? Look at how many of us found out that it really isn't. It's also been really great that people like Deems and many others have tried new things and shared their experiences along the way. It's helped everyone to improve their own plane. It's really easy to see that those who've actually completed their RV-10 can meet the spirit of the intent of the Experimental Amateur Built category...recreation and education....because it's that's what it's been for me in a big way. Tim On 6/27/2014 12:11 PM, Deems Davis wrote: > I've been reading the threads on fuel and performance lately, and have > benefited from the discussions. One thing that struck me, is that we > have all come a LONG way, I feel like I "grew-up" airplane-wise with all > of you as we went through this RV10 journey together. From the early > day's where Tim led the 'revolt' to Matronics to the current discussions > regarding maintenance and operations. I've come to know many of you 1st > hand and count you as friends. I've owned 5 planes, a couple of them > twins with complex systems, logged lots of hours. But I have never had > the understanding on any of them that I have with the -10. I Thank you > all for contributing to that. We just finished our 6th annual trip from > DVT to the east coast. I love this airplane more each time we fly! > > Give yourselves a hand of applause, You've come a long way! > > Deems > > ________________________________________________________________________________
Date: Jun 27, 2014
Not sure on his how it would be, but on mine I adjusted the floats to the l ower end. So when full they only read 23 or 24 gallons but are pretty accur ate at the bottom.=0A-=0AGod Bless America=0A(please) -:)=0A=0A=0ABruce =0A=0A=0AOn Friday, June 27, 2014 11:24 AM, Tim Olson wrot =0A=0AIt really has been a great learning experience for everyone,=0Ame too .- Some of the people I've met became like family.=0AThe aircraft itself has been truly amazing and now I don't=0Aknow what I'd do without it.- Co ming from spam cans, there=0Areally is no way I'd want to go back.- I thi nk many people=0Athese days don't know what they're missing by NOT trying t o=0Ado things like build your own airplane.- Do they really=0Athink it's beyond them?- Look at how many of us found out=0Athat it really isn't.=0A =0AIt's also been really great that people like Deems and many=0Aothers hav e tried new things and shared their experiences=0Aalong the way.- It's he lped everyone to improve their=0Aown plane.=0A=0AIt's really easy to see th at those who've actually=0Acompleted their RV-10 can meet the spirit of the intent=0Aof the Experimental Amateur Built category...recreation=0Aand edu cation....because it's that's what it's been=0Afor me in a big way.=0ATim =0A=0A=0AOn 6/27/2014 12:11 PM, Deems Davis wrote:=0A> I've been reading th e threads on fuel and performance lately, and have=0A> benefited from the d iscussions. One thing that struck me, is that we=0A> have all come a LONG w ay, I feel like I "grew-up" airplane-wise with all=0A> of you as we went th rough this RV10 journey together. From the early=0A> day's where Tim led th e 'revolt' to Matronics to the current discussions=0A> regarding maintenanc e and operations. I've come to know many of you 1st=0A> hand and count you as friends. I've owned 5 planes, a couple of them=0A> twins with complex sy stems, logged lots of hours. But I have never had=0A> the understanding on any of them that I have with the -10. I Thank you=0A> all for contributing to that. We just finished our 6th annual trip from=0A> DVT to the east coas t. I love this airplane more each time we fly!=0A>=0A> Give yourselves a ha ________________________________________________________________________________
Date: Jun 27, 2014
I want to say that you guys are my source of inspiration. Every time I look at the project and get discouraged by the amount of work still to go, I read some of your logs and stories and am inspired. I also find Jesse dad=99s stories very encouraging having worked in overseas mission. Bill Greenley Starting to put the top on the fuselage, fiberglass here I come From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint Sent: Friday, June 27, 2014 1:36 PM Subject: Re: RV10-List: Re: Extra fuel I agree with Deems. I got started on the list with no pilot or mechanic license. Now I have both. I've learned a lot from this group and have enjoyed the journey. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Jun 27, 2014, at 1:11 PM, Deems Davis wrote: I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! Give yourselves a hand of applause, You've come a long way! Deems On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint wrote: The floats hit the top of the tank around 24-26 gallons because if the dihedral. If installed and calibrated correctly, they will read accurately down to very close to empty. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote: > > > On 6/27/2014 9:40 AM, johngoodman wrote: > Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. > > The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now. > > My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is. > > With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully. > >> >> OK, I've got to ask... >> When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jun 27, 2014
When landing in a strong crosswind I try to draw fuel from the raised wing in the side slip. If you run one tank dry there's a fifty-fifty chance you won't be able to do that. Personally, I don't transition to a slip until well into the flare, so it's not a big deal, but something to keep in mind. Especially if a go around is needed. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425618#425618 ________________________________________________________________________________
Subject: Re: Extra fuel-
Date: Jun 27, 2014
Bill; If you are encouraged by Jesse=99s dad=99s stories about missionary.. you should watch the documentary/movie =9CBeyond the gates of splendor=9D (if you haven=99t already) as a missionary you will be inspired on the sacrifice made by the Saint family and what has resulted in forgiveness and what is now an RV-10 =9Con the job training program=9D in Equador. ------------------ I want to say that you guys are my source of inspiration. Every time I look at the project and get discouraged by the amount of work still to go, I read some of your logs and stories and am inspired. I also find Jesse dad=99s stories very encouraging having worked in overseas mission. Bill Greenley From: Jesse Saint Sent: Friday, June 27, 2014 10:36 AM Subject: Re: RV10-List: Re: Extra fuel I agree with Deems. I got started on the list with no pilot or mechanic license. Now I have both. I've learned a lot from this group and have enjoyed the journey. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Jun 27, 2014, at 1:11 PM, Deems Davis wrote: I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! Give yourselves a hand of applause, You've come a long way! Deems On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint wrote: The floats hit the top of the tank around 24-26 gallons because if the dihedral. If installed and calibrated correctly, they will read accurately down to very close to empty. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote: > > > On 6/27/2014 9:40 AM, johngoodman wrote: > Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. > > The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now. > > My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is. > > With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully. > >> >> OK, I've got to ask... >> When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > > > > ========== " target="_blank">http://www.matronics.com/Navigator?RV10-List ========== MS - k">http://forums.matronics.com ========== e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ========== D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Subject: Re: Extra
fuel-
Date: Jun 27, 2014
I have seen it and greatly appreciated the message. I ran a bush hospital in Rwanda and lost my entire staff in the Genocide. I knew many of the perpetrators, so forgiveness is a challenge a struggle with daily. Bill From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal Sent: Friday, June 27, 2014 3:02 PM Subject: Jesse dad's stories being encouraging- was Re: RV10-List: Re: Extra fuel- Bill; If you are encouraged by Jesse=99s dad=99s stories about missionary.. you should watch the documentary/movie =9CBeyond the gates of splendor=9D (if you haven=99t already) as a missionary you will be inspired on the sacrifice made by the Saint family and what has resulted in forgiveness and what is now an RV-10 =9Con the job training program=9D in Equador. ------------------ I want to say that you guys are my source of inspiration. Every time I look at the project and get discouraged by the amount of work still to go, I read some of your logs and stories and am inspired. I also find Jesse dad=99s stories very encouraging having worked in overseas mission. Bill Greenley From: Jesse Saint <mailto:jesse(at)saintaviation.com> Sent: Friday, June 27, 2014 10:36 AM Subject: Re: RV10-List: Re: Extra fuel I agree with Deems. I got started on the list with no pilot or mechanic license. Now I have both. I've learned a lot from this group and have enjoyed the journey. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Jun 27, 2014, at 1:11 PM, Deems Davis wrote: I've been reading the threads on fuel and performance lately, and have benefited from the discussions. One thing that struck me, is that we have all come a LONG way, I feel like I "grew-up" airplane-wise with all of you as we went through this RV10 journey together. From the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance and operations. I've come to know many of you 1st hand and count you as friends. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finished our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! Give yourselves a hand of applause, You've come a long way! Deems On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint wrote: The floats hit the top of the tank around 24-26 gallons because if the dihedral. If installed and calibrated correctly, they will read accurately down to very close to empty. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jun 27, 2014, at 11:34 AM, Bill Watson wrote: > > > On 6/27/2014 9:40 AM, johngoodman wrote: > Strangely enough, up until recently my fuel gauges always show slightly more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. > > The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accurate now. > > My fuel gauges never show completely full tanks but they will show even the slightest amount of remaining fuel sloshing about. I assume some of this is a calibration issue with the GRT EIS but it works fine as is. > > With 10 gallons left my approach is to have most of those in one tank and to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of tea and I haven't had a hiccup yet. I haven't run a tank dry even for testing but did spend a year measuring things very carefully. > >> >> OK, I've got to ask... >> When you have 10.2 gallons left in the tanks, are the Van's floats reading zero, but the totalizer shows that much left? >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com > > " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D href="http://www.matronics.com/Navigator?RV10-List">http://www.matronic s.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Subject: The building experience
Date: Jun 27, 2014
For those going through what I went through, my guidance came from Tim, Deems for the building; Jesse for the panel and avionics guidance.. and Don McDonald who took every call I made and sent me pictures and awesome hardware to improve on some weaknesses I felt there was with the finish kit. As Tim experienced, I have made some great friends who own RV-10's (and RV's in general) and really had a life changing experience building the plane. I felt, and did, make many mistakes but in the end I have flown well over 5000 miles in the plane thus far and it has flown beautifully. I'm sorry (not really) but those who are missing out on the RV-10 experience of building, meeting builders and maturing in a certain way, are really missing out on one of my life's best times! When asked a few years back about how excited I was to finally get the building done, I actually told the RV group I loved the experience of building a custom kit with everything I would want in a Cirrus and loved the building.. yes, its frustrating at times and I dont think much about the fact that I built a plane, other than I cant believe I actually did it and I would have had a harder time if it were not for Tim, Deems and others on this forum. In the end, anyone can build a plane, just dont miss the journey. If you haven't met and spent time talking to other RV-10 builders, go to fly ins and find local builders, my experience with Deems when in Arizona, a builder 2 hours away that took me for a flight and showed me his plane, and a builder I met in Northern California when driving 10 hours to a fly in, who would become my mentor and inspiration for the rest of the builder (thanks Don!!).. all a journey. Enjoy the journey! Pascal -----Original Message----- From: Tim Olson Sent: Friday, June 27, 2014 11:08 AM Subject: Re: RV10-List: Re: Extra fuel It really has been a great learning experience for everyone, me too. Some of the people I've met became like family. The aircraft itself has been truly amazing and now I don't know what I'd do without it. Coming from spam cans, there really is no way I'd want to go back. I think many people these days don't know what they're missing by NOT trying to do things like build your own airplane. Do they really think it's beyond them? Look at how many of us found out that it really isn't. It's also been really great that people like Deems and many others have tried new things and shared their experiences along the way. It's helped everyone to improve their own plane. It's really easy to see that those who've actually completed their RV-10 can meet the spirit of the intent of the Experimental Amateur Built category...recreation and education....because it's that's what it's been for me in a big way. Tim On 6/27/2014 12:11 PM, Deems Davis wrote: > I've been reading the threads on fuel and performance lately, and have > benefited from the discussions. One thing that struck me, is that we > have all come a LONG way, I feel like I "grew-up" airplane-wise with all > of you as we went through this RV10 journey together. From the early > day's where Tim led the 'revolt' to Matronics to the current discussions > regarding maintenance and operations. I've come to know many of you 1st > hand and count you as friends. I've owned 5 planes, a couple of them > twins with complex systems, logged lots of hours. But I have never had > the understanding on any of them that I have with the -10. I Thank you > all for contributing to that. We just finished our 6th annual trip from > DVT to the east coast. I love this airplane more each time we fly! > > Give yourselves a hand of applause, You've come a long way! > > Deems > > ________________________________________________________________________________
Subject: oil cooler deflector
Date: Jun 27, 2014
Does anyone have any feedback on the affectivity of the oil cooler deflectors. I=99m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report? Chris Hukill ________________________________________________________________________________
Subject: Re: oil cooler deflector
Date: Jun 27, 2014
I don't think the theory is too bad on the device, but with all the variabil ity between builders I don't know how actually effective it was for me. If i t raised my temps it wasn't by much. I doubt you'll hurt anything by using i t though. Tim > On Jun 27, 2014, at 5:03 PM, "Chris Hukill" wrote: > > Does anyone have any feedback on the affectivity of the oil cooler deflect ors. I=99m not convinced that I should install it, as Tim Olsen says i t actually raised his temperatures. Anyone else have anything to report? > Chris Hukill > ________________________________________________________________________________
Date: Jun 27, 2014
I have totally normal 190f-200f range with deflector. OAT temps are 90f-50f From: Chris Hukill Sent: Friday, June 27, 2014 3:03 PM Subject: RV10-List: oil cooler deflector Does anyone have any feedback on the affectivity of the oil cooler deflectors. I=99m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report? Chris Hukill ________________________________________________________________________________
Date: Jun 28, 2014
Us guys from the big island to the Deep South also thank you all for sharing your experiences and knowledge. I could not have built this aircraft with s uch confidence without you all. Thank you ever so much. I'm hoping to catch up with as many of you as possible next year at Oshkosh. Warm regards Patrick Pulis Adelaide, South Australia #40299 > On 28 Jun 2014, at 3:06, Jesse Saint wrote: > > I agree with Deems. I got started on the list with no pilot or mechanic li cense. Now I have both. I've learned a lot from this group and have enjoyed t he journey. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > >> On Jun 27, 2014, at 1:11 PM, Deems Davis wrote: >> >> I've been reading the threads on fuel and performance lately, and have be nefited from the discussions. One thing that struck me, is that we have all c ome a LONG way, I feel like I "grew-up" airplane-wise with all of you as we w ent through this RV10 journey together. =46rom the early day's where Tim led the 'revolt' to Matronics to the current discussions regarding maintenance a nd operations. I've come to know many of you 1st hand and count you as frien ds. I've owned 5 planes, a couple of them twins with complex systems, logged lots of hours. But I have never had the understanding on any of them that I have with the -10. I Thank you all for contributing to that. We just finish ed our 6th annual trip from DVT to the east coast. I love this airplane more each time we fly! >> >> Give yourselves a hand of applause, You've come a long way! >> >> Deems >> >> >> >>> On Fri, Jun 27, 2014 at 8:51 AM, Jesse Saint w rote: >>> >>> The floats hit the top of the tank around 24-26 gallons because if the d ihedral. If installed and calibrated correctly, they will read accurately do wn to very close to empty. >>> >>> Jesse Saint >>> I-TEC, Inc. >>> jesse(at)itecusa.org >>> www.itecusa.org >>> www.mavericklsa.com >>> C: 352-427-0285 >>> O: 352-465-4545 >>> F: 815-377-3694 >>> >>> Sent from my iPhone >>> >>> > On Jun 27, 2014, at 11:34 AM, Bill Watson wrot e: >>> > >>> > >>> > On 6/27/2014 9:40 AM, johngoodman wrote: >>> > Strangely enough, up until recently my fuel gauges always show slightl y more fuel than I actually have and the totalizer slightly less. Splitting the difference gave me the right number. Running with the totalizer number gave me a safety factor. >>> > >>> > The totalizer issue was due to placing the GRT unit in the Van's plans location. It ran high when the boost pumps was on and who knows what else. Relocating it to between the controller and spider makes it amazingly accu rate now. >>> > >>> > My fuel gauges never show completely full tanks but they will show eve n the slightest amount of remaining fuel sloshing about. I assume some of t his is a calibration issue with the GRT EIS but it works fine as is. >>> > >>> > With 10 gallons left my approach is to have most of those in one tank a nd to run off the other (and hard VFR with airports underneath). If there's even a hiccup, tanks get switched and we are landing NOW. Not my cup of te a and I haven't had a hiccup yet. I haven't run a tank dry even for testing b ut did spend a year measuring things very carefully. >>> > .net> >>> >> >>> >> OK, I've got to ask... >>> >> When you have 10.2 gallons left in the tanks, are the Van's floats re ading zero, but the totalizer shows that much left? >>> >> John >>> >> >>> >> -------- >>> >> #40572 Phase One complete in 2011 >>> >> >>> >> >>> >> >>> >> >>> >> Read this topic online here: >>> >> >>> >> http://forums.matronics.com/viewtopic.php?p=425579#425579 >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> ----- >>> >> No virus found in this message. >>> >> Checked by AVG - www.avg.com >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ========== >>> " target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> MS - >>> k">http://forums.matronics.com >>> ========== >>> e - >>> -Matt Dralle, List Admin. >>> t="_blank">http://www.matronics.com/contribution >>> ========== >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> List"">http://www.matronics.com/Navigator?RV10-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 27, 2014
If you also put a damper vent to reduce airflow, you need to ensure the vent is perpendicular to the deflector. Otherwise when the vent is partially c losed, you'll only be sending air through half the oil cooler. I don't have any comparison temps, but I'm not having problems with oil temp s being high with the deflector Sent from my iPhone On Jun 27, 2014, at 6:30 PM, "Pascal" wrote: I have totally normal 190f-200f range with deflector. OAT temps are 90f-50f From: Chris Hukill Sent: Friday, June 27, 2014 3:03 PM Subject: RV10-List: oil cooler deflector Does anyone have any feedback on the affectivity of the oil cooler deflector s. I=99m not convinced that I should install it, as Tim Olsen says it a ctually raised his temperatures. Anyone else have anything to report? Chris Hukill href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.c om/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jun 28, 2014
Chris, just a FYI wrt oil coolers. I have bought and installed an Air Flow 2007X, the next larger sized cooler offered. I have no intentions of installing the baffle or deflector with the larger capacity cooler. I do however have Bob Newmans butterfly valve and electronic controller if its required to regulate oil temp. Having said that I`m not flying yet so this info is worth .02 or less ;-) Regards Rick #40956 Southampton, Ont On Fri, Jun 27, 2014 at 6:03 PM, Chris Hukill wrote: > Does anyone have any feedback on the affectivity of the oil cooler > deflectors. I=99m not convinced that I should install it, as Tim Ol sen says > it actually raised his temperatures. Anyone else have anything to report? > Chris Hukill > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 29, 2014
Subject: RVbits.com warning
About a month ago I ordered a pair of the engine mount covers from rvbits.com (based in South Africa). After a couple of weeks I asked the seller (Chris Adrian) for shipping status. First, he claimed he never got the order, although Paypal said he'd been paid. So I filed a dispute with Paypal. Mr Adrian's tune immediately changed -- he claimed he'd already shipped the items. He didn't respond to my request for shiping method and tracking number, and the items never arrived. I elevated the dispute to "claim" status with Paypal, and eventually got notice from Paypal that my money has been returned. Based on my experience, I'd recommend steering clear of rvbits.com. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 500 hrs ________________________________________________________________________________
Date: Jun 29, 2014
Subject: Re: RVbits.com warning
Sorry to hear about your problem. I made my own .... vacuum bagged over the form in the middle. It's a 3" foam ball cut in half with a radius made from lightweight spackle from the aircraft aisle in Home depot. It's too bad we don't have something like Angies List for aviation ..... I bought a canopy for my Pitts from Dave Garmann at Planecanopies.com. I worked hard trimming it to make it fit and when I pulled the plastic off It was wrinkled all down the right side .... He won't return my calls and won't make good of the POS he sent me. On 6/29/2014 8:19 AM, Tim Lewis wrote: > > About a month ago I ordered a pair of the engine mount covers from > rvbits.com (based in South Africa). After a couple of weeks I asked > the seller (Chris Adrian) for shipping status. First, he claimed he > never got the order, although Paypal said he'd been paid. So I filed > a dispute with Paypal. Mr Adrian's tune immediately changed -- he > claimed he'd already shipped the items. He didn't respond to my > request for shiping method and tracking number, and the items never > arrived. I elevated the dispute to "claim" status with Paypal, and > eventually got notice from Paypal that my money has been returned. > > Based on my experience, I'd recommend steering clear of rvbits.com. > ________________________________________________________________________________
Date: Jun 29, 2014
Tim, Get the mount covers from Geoff Combs. More money, but they look beautiful, which is probably the reason to get the carbon ones in the first place ;) http://www.aerosportproducts.com/rv10mount.htm Linn, nice work! What do you use for vacuum? I have a tiny medical vacuum pump, and it works great for small stuff like this, but not enough on a bigger sheet. -------- Lenny N311LZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425715#425715 ________________________________________________________________________________
Date: Jun 29, 2014
Cleaveland Tools sells many of the rvbits.com products and stocked them. Then you don't have to worry about timing an international shipment. I also agree with Lenny, just buy for Aerosport Products. It's hard to beat Geoff for support. It would be nice if carbon fiber was less expensive, but it is, what it is. Sent from my iPad > On Jun 29, 2014, at 8:19 AM, Tim Lewis wrote: > > > About a month ago I ordered a pair of the engine mount covers from rvbits.com (based in South Africa). After a couple of weeks I asked the seller (Chris Adrian) for shipping status. First, he claimed he never got the order, although Paypal said he'd been paid. So I filed a dispute with Paypal. Mr Adrian's tune immediately changed -- he claimed he'd already shipped the items. He didn't respond to my request for shiping method and tracking number, and the items never arrived. I elevated the dispute to "claim" status with Paypal, and eventually got notice from Paypal that my money has been returned. > > Based on my experience, I'd recommend steering clear of rvbits.com. > > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 500 hrs > > > > > ________________________________________________________________________________
Date: Jun 29, 2014
Tim, Sorry you had a bad experience with them. I have ordered two sets in the past without any issues. They took a while to arrive, but they were coming from africa. john On Sun, Jun 29, 2014 at 8:19 AM, Tim Lewis wrote: > > About a month ago I ordered a pair of the engine mount covers from > rvbits.com (based in South Africa). After a couple of weeks I asked the > seller (Chris Adrian) for shipping status. First, he claimed he never got > the order, although Paypal said he'd been paid. So I filed a dispute with > Paypal. Mr Adrian's tune immediately changed -- he claimed he'd already > shipped the items. He didn't respond to my request for shiping method and > tracking number, and the items never arrived. I elevated the dispute to > "claim" status with Paypal, and eventually got notice from Paypal that my > money has been returned. > > Based on my experience, I'd recommend steering clear of rvbits.com. > > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 500 hrs > > ________________________________________________________________________________
Date: Jun 29, 2014
Mail to and from countries in Africa can be a unique experience. I remember when I was working in Sierra Leone, I received a letter from my grandmother 8 months after she had passed away. It felt very strange. Still they should not have said they shipped it if they did not. Bill From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Trollinger Sent: Sunday, June 29, 2014 11:15 AM Subject: Re: RV10-List: RVbits.com warning Tim, Sorry you had a bad experience with them. I have ordered two sets in the past without any issues. They took a while to arrive, but they were coming from africa. john On Sun, Jun 29, 2014 at 8:19 AM, Tim Lewis wrote: About a month ago I ordered a pair of the engine mount covers from rvbits.com (based in South Africa). After a couple of weeks I asked the seller (Chris Adrian) for shipping status. First, he claimed he never got the order, although Paypal said he'd been paid. So I filed a dispute with Paypal. Mr Adrian's tune immediately changed -- he claimed he'd already shipped the items. He didn't respond to my request for shiping method and tracking number, and the items never arrived. I elevated the dispute to "claim" status with Paypal, and eventually got notice from Paypal that my money has been returned. Based on my experience, I'd recommend steering clear of rvbits.com. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 500 hrs " target="_blank">http://www.matronics.com/Navigator?RV10-List MS - k">http://forums.matronics.com e - -Matt Dralle, List Admin. t="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jun 29, 2014
On 6/29/2014 10:19 AM, Lenny Iszak wrote: > > Tim, > > Get the mount covers from Geoff Combs. More money, but they look beautiful, which is probably the reason to get the carbon ones in the first place ;) > http://www.aerosportproducts.com/rv10mount.htm > > Linn, nice work! What do you use for vacuum? I used the larger Harbor Freight vacuum pump. It was on sale. When I made my overhead plenum I made the form out of blue foam and bagged the whole cabin top! Linn > I have a tiny medical vacuum pump, and it works great for small stuff like this, but not enough on a bigger sheet. > > -------- > Lenny > N311LZ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425715#425715 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jun 30, 2014
Chris I have the larger oil cooler without the deflector in it. I also have a valve to control oil temperatures and everything works very good. I would recommend The oil door and the deflector would be your call. 4 plus years with this setup and still works great. In the winter months I can set oil temps to pretty much Where I want to run. In the summer it is usually wide open. Geoff Geoff Combs Aerosport 8090 Howe Industrial Parkway Canal, Winchester, Ohio 43110 614-834-5227 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Hukill Sent: Friday, June 27, 2014 6:03 PM Subject: RV10-List: oil cooler deflector Does anyone have any feedback on the affectivity of the oil cooler deflectors. I=99m not convinced that I should install it, as Tim Olsen says it actually raised his temperatures. Anyone else have anything to report? Chris Hukill ________________________________________________________________________________
Date: Jun 30, 2014
I ordered the covers from RvBits several months ago. They did take several weeks, but arrives without issue. It is a long shipping window... be slightly patient. Cheers, Frank -------- Frank Dombroski RV-10 2.0 N46VT soon to be flying KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425766#425766 ________________________________________________________________________________
Subject: L or R Mag & EI
From: "Greg McFarlane" <grbcmcfarlane(at)gmail.com>
Date: Jun 30, 2014
Ive got the Vans supplied IO-540 with Slick Retard Mag on left & Direct drive Mag right. I'm putting in a Lightspeed Plasma3 to fire the top plugs. Because the engine can only be started with the retard Mag or the Lightspeed, would it be best to have an each way bet and retain the Left Retard Mag with Booster. Or retain the Direct Drive and I presume more simple less complex Right Mag. Wondering what choice others have made, any advise appreciated. Cheers from Western Australia Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425767#425767 ________________________________________________________________________________
Date: Jun 30, 2014
Geoff, When you say "larger" do you mean the 2006X or 2007X? Both have more capacity than the Vans cooler and I think are both a bit larger. On Mon, Jun 30, 2014 at 6:08 AM, Geoff Combs wrote: > Chris > > I have the larger oil cooler without the deflector in it. I also have a > valve to control oil temperatures and everything works very good. I would > recommend > > The oil door and the deflector would be your call. 4 plus years with this > setup and still works great. In the winter months I can set oil temps to > pretty much > > Where I want to run. In the summer it is usually wide open. > > > Geoff > > > Geoff Combs > > Aerosport > > 8090 Howe Industrial Parkway > > Canal, Winchester, Ohio 43110 > > 614-834-5227 > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Chris Hukill > > *Sent:* Friday, June 27, 2014 6:03 PM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: oil cooler deflector > > > Does anyone have any feedback on the affectivity of the oil cooler > deflectors. I'm not convinced that I should install it, as Tim Olsen says > it actually raised his temperatures. Anyone else have anything to report? > > Chris Hukill > > > *http://www.matronics.com/Navigator?RV10-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > > > * > > ________________________________________________________________________________
Subject: RV-10 social at Oshkosh
Date: Jun 30, 2014
A couple of years I went to an RV-10 social at Oshkosh. Does anyone know if one is planned for this year? Bill Greenley RV-10 at the fiberglass stage ________________________________________________________________________________
Subject: Re: RV-10 social at Oshkosh
Date: Jun 30, 2014
There is talk about Sunday evening, but nothing will be finalized until it g ets a little closer. I'm sure Ed will make an announcement here as soon as a final decision is ma de. For those that haven't attended for awhile, Ed Krantz has gratuitously taken over the role of dinner host. Bob and Gary (or should I say Susan and Bre nda) have done a fantastic job over the years and deserve to sit back and re lax. Bob Sent from my iPad > On Jun 30, 2014, at 6:27 PM, "William Greenley" wrot e: > > A couple of years I went to an RV-10 social at Oshkosh. Does anyone know i f one is planned for this year? > Bill Greenley > RV-10 at the fiberglass stage > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 30, 2014
I will be arriving there Sunday morning and am willing to help. Bill Greenley From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Monday, June 30, 2014 7:27 PM Subject: Re: RV10-List: RV-10 social at Oshkosh There is talk about Sunday evening, but nothing will be finalized until it gets a little closer. I'm sure Ed will make an announcement here as soon as a final decision is made. For those that haven't attended for awhile, Ed Krantz has gratuitously taken over the role of dinner host. Bob and Gary (or should I say Susan and Brenda) have done a fantastic job over the years and deserve to sit back and relax. Bob Sent from my iPad On Jun 30, 2014, at 6:27 PM, "William Greenley" wrote: A couple of years I went to an RV-10 social at Oshkosh. Does anyone know if one is planned for this year? Bill Greenley RV-10 at the fiberglass stage 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ________________________________________________________________________________
Date: Jul 01, 2014
Yup, I'm thinking Sunday evening is probably going to work best, but I'll wait until Bob and the advance team are on site before we set anything in stone. We'll probably be doing burgers and brats, and whatever else people want to bring. There is always enough for everyone. I'll have more details about a week before OSH. 26 days to go!!! On Mon, Jun 30, 2014 at 6:39 PM, William Greenley wrote: > I will be arriving there Sunday morning and am willing to help. > > Bill Greenley > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bob Leffler > *Sent:* Monday, June 30, 2014 7:27 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: RV-10 social at Oshkosh > > > There is talk about Sunday evening, but nothing will be finalized until it > gets a little closer. > > > I'm sure Ed will make an announcement here as soon as a final decision is > made. > > > For those that haven't attended for awhile, Ed Krantz has gratuitously > taken over the role of dinner host. Bob and Gary (or should I say Susan > and Brenda) have done a fantastic job over the years and deserve to sit > back and relax. > > > Bob > > Sent from my iPad > > > On Jun 30, 2014, at 6:27 PM, "William Greenley" > wrote: > > A couple of years I went to an RV-10 social at Oshkosh. Does anyone know > if one is planned for this year? > > Bill Greenley > > RV-10 at the fiberglass stage > > > *http://www.matronics.com/Navigator?RV10-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > > > * > > ________________________________________________________________________________
Date: Jul 01, 2014
On 7/1/2014 9:00 AM, Bill Watson wrote: > I did a DIY per some other builders using a cat food dish Mauledriver > Kitlog > <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=4014&log=89653&row=1> > . Simple to do. Carbon Fiber would look fine. > > I recently ordered a set of main gear fairings from RVbits. Took > awhile for them to arrive but they finally did. Nicely formed and > finished. > > > On 6/29/2014 8:19 AM, Tim Lewis wrote: >> >> About a month ago I ordered a pair of the engine mount covers from >> rvbits.com (based in South Africa). After a couple of weeks I asked >> the seller (Chris Adrian) for shipping status. First, he claimed he >> never got the order, although Paypal said he'd been paid. So I filed >> a dispute with Paypal. Mr Adrian's tune immediately changed -- he >> claimed he'd already shipped the items. He didn't respond to my >> request for shiping method and tracking number, and the items never >> arrived. I elevated the dispute to "claim" status with Paypal, and >> eventually got notice from Paypal that my money has been returned. >> >> Based on my experience, I'd recommend steering clear of rvbits.com. >> > ________________________________________________________________________________
Date: Jul 02, 2014
I used high temp silicone and never see it. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425921#425921 ________________________________________________________________________________
Subject: Re: Rapco Brakes @ Aircraft Spuce
Date: Jul 02, 2014
Could somebody please point out which Rapco Brake lining Kit I need for the RV-10? I know the RA66-112 are the brake linings Is this the correct one listed at Aircraft spruce? Rapco Brake Lining Kit RA066-11200-4K 06-01740 $29.50 Thanks Michael -------- RV-10 builder (flying) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425936#425936 ________________________________________________________________________________
Date: Jul 02, 2014
That looks right to me. Man the prices have come down a lot now that Rapco is making them. Tim On 7/2/2014 1:31 PM, Mike Whisky wrote: > > Could somebody please point out which Rapco Brake lining Kit I need for the RV-10? > I know the RA66-112 are the brake linings > > Is this the correct one listed at Aircraft spruce? > Rapco Brake Lining Kit RA066-11200-4K 06-01740 $29.50 > > Thanks > Michael > > -------- > RV-10 builder (flying) > #511 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=425936#425936 > > ________________________________________________________________________________
Date: Jul 02, 2014
Just for future reference, those are the correct pad numbers for older -10's. Current kits are shipping with non-Cleveland wheels. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=425945#425945 ________________________________________________________________________________
Subject: brakes
Date: Jul 03, 2014
You may want to check the Matco brakes for the RV10. Price competitive and about twice the stopping power. ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
Do they work with Cleveland wheels, or do you have to buy complete Matco wheels and caliper set? On Thu, Jul 3, 2014 at 6:33 AM, DLM wrote: > You may want to check the Matco brakes for the RV10. Price competitive > and about twice the stopping power. > > * > > > * > > ________________________________________________________________________________
Subject: Re: brakes
Date: Jul 03, 2014
You have to buy the complete set. It makes a big difference over the Clevela nd setup. I recommend it. Sent from my iPhone > On Jul 3, 2014, at 6:52 AM, Kelly McMullen wrote: > > Do they work with Cleveland wheels, or do you have to buy complete Matco w heels and caliper set? > > >> On Thu, Jul 3, 2014 at 6:33 AM, DLM wrote: >> You may want to check the Matco brakes for the RV10. Price competitive an d about twice the stopping power. >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
You have to buy the complete set. But they are very nicely made. I'm not flying yet, but I'm happy with the way they went together, and the quality of the parts. On Thu, Jul 3, 2014 at 8:52 AM, Kelly McMullen wrote: > Do they work with Cleveland wheels, or do you have to buy complete Matco > wheels and caliper set? > > > On Thu, Jul 3, 2014 at 6:33 AM, DLM wrote: > >> You may want to check the Matco brakes for the RV10. Price competitive >> and about twice the stopping power. >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Subject: Re: brakes
Date: Jul 03, 2014
I just installed a set of these. It's a good day job. Twice the brakes. Nice system. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jul 3, 2014, at 9:33 AM, "DLM" wrote: > > You may want to check the Matco brakes for the RV10. Price competitive and about twice the stopping power. > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: brakes
Date: Jul 03, 2014
I was one of the first few people to install these brakes. I think Sean Strasburg was the first. They are far superior to The stock brakes. I have had them on for over a year and love them. Geoff From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Thursday, July 03, 2014 9:34 AM Subject: RV10-List: brakes You may want to check the Matco brakes for the RV10. Price competitive and about twice the stopping power. http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
Is the feeling that the Cleveland brakes are inadequate? Anyone have problems flat spotting tires with the upgraded Matco brakes? It would seem the Matco brake pads are more expensive than Rapco, and ties you to a single source for pads. It does appear that the cost is under $900, where I believe the Cleveland set was over $2000. Of course then there is the effort to sell the unused Cleveland set. On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs wrote: > I was one of the first few people to install these brakes. I think Sean > Strasburg was the first. They are far superior to > > The stock brakes. I have had them on for over a year and love them. > > > Geoff > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *DLM > *Sent:* Thursday, July 03, 2014 9:34 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: brakes > > > You may want to check the Matco brakes for the RV10. Price competitive and > about twice the stopping power. > > > *http://www.matronics.com/Navigator?RV10-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > > * > > > * > > ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
I've had Clevelands on all my airplanes .... and never had any problem in over 40 years. I can't see where twice the stopping power is a benefit! Where do y'all need to jump on the brakes like that??? Linn On 7/3/2014 11:57 AM, Kelly McMullen wrote: > Is the feeling that the Cleveland brakes are inadequate? Anyone have > problems flat spotting tires with the upgraded Matco brakes? It would > seem the Matco brake pads are more expensive than Rapco, and ties you > to a single source for pads. > > It does appear that the cost is under $900, where I believe the > Cleveland set was over $2000. Of course then there is the effort to > sell the unused Cleveland set. > > > On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs > > > wrote: > > I was one of the first few people to install these brakes. I think > Sean Strasburg was the first. They are far superior to > > The stock brakes. I have had them on for over a year and love them. > > Geoff > > *From:*owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] *On Behalf Of *DLM > *Sent:* Thursday, July 03, 2014 9:34 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: brakes > > You may want to check the Matco brakes for the RV10. Price > competitive and about twice the stopping power. > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > **http://www.matronics.com/Navigator?RV10-List**** > > ** > > ** > > **http://forums.matronics.com**** > > ** > > ** > > ** > > ** > > **http://www.matronics.com/contribution**** > > ** > > * * > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
I guess I'd tend to agree, myself, but there are two sides to the discussion I guess. I've talked to Sean about this, and he's seen some brake fade before, and with the added stopping power you wouldn't get much for brake fade. From what he says, it's not really for stopping on a landing, but stopping from an aborted takeoff that it would matter most. I can see the point, and see the benefit. That said, I've never experienced the need for more brake than I have, and in fact I've had a few times where I did some hard braking to make a turnoff and screeched a flat spot onto a tire, so I believe that 99.5% of the time the stock brakes will be plenty, and most people won't ever have the chance to use the additional stopping power, hopefully. Then from a purchase standpoint, I'd guess that if you already own one type of wheel/brake system, the economics of changing really aren't worthwhile for anyone, unless you really just have to have those powerful brakes. It's not like I'm going to get big bucks for my old brakes. Then from a standpoint of replacement parts, it is somewhat nice that if you use a standard system, you can buy standard parts at many places. I just experienced a flat in one of my main tubes while on vacation, which drove home the idea that it's kind of nice to be able to get parts from a nearby source in a pinch. If you have Cleveland, you have a good chance of being able to find some parts. With any others, you may find yourself getting some shipped overnight and taking a couple days. But then again, you may have less need for the parts, right? I'm also not a huge fan of single-source type products in that from EFIS's to Wheels, many of the things we buy for our plane rely on a very tiny number of people to supply the services. If that company got hit by a meteor, or had any number of other things go wrong, you may be without parts. This isn't to scare you from Matco, because we use their parts for many other things too. But, at least now that there are 2 lining makers for my brakes, I've got options. Then again, if you bought a spare 2 or 3 sets of pads for Matco's brakes, you may never end up needing to call them again, because they'd wear so much slower. Either way, it's nice that we have multiple options for our wheels and brakes. It keeps us well supplied for the long run. For those who love the new brakes, great, and it's nice to remind new builders that they have options. For those who would rather have the old brakes, or don't want to pony up, I don't see this as any big deal either. Myself, I am just happy to see that lining prices are now down under $8 each, so I can keep replacing them as needed and enjoy many more years of service. If I were building a new RV-10 today, I'd look at the cost difference and then decide which way to go. There really isn't a "bad" choice, but there may be a good and better. If the price is within a couple or few hundred bucks, I'd just go for the best. If not, it's time to start weighing the options. The most important thing is to pick one and move on, because agonizing over all the details is just going to cost you weeks/months/years of time that you could be FLYING instead of building. :) Tim On 7/3/2014 12:53 PM, Linn Walters wrote: > I've had Clevelands on all my airplanes .... and never had any problem > in over 40 years. I can't see where twice the stopping power is a > benefit! Where do y'all need to jump on the brakes like that??? > Linn > > On 7/3/2014 11:57 AM, Kelly McMullen wrote: >> Is the feeling that the Cleveland brakes are inadequate? Anyone have >> problems flat spotting tires with the upgraded Matco brakes? It would >> seem the Matco brake pads are more expensive than Rapco, and ties you >> to a single source for pads. >> >> It does appear that the cost is under $900, where I believe the >> Cleveland set was over $2000. Of course then there is the effort to >> sell the unused Cleveland set. >> >> >> On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs >> > >> wrote: >> >> I was one of the first few people to install these brakes. I think >> Sean Strasburg was the first. They are far superior to >> >> The stock brakes. I have had them on for over a year and love them. >> >> Geoff >> >> *From:*owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com >> ] *On Behalf Of *DLM >> *Sent:* Thursday, July 03, 2014 9:34 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* RV10-List: brakes >> >> You may want to check the Matco brakes for the RV10. Price >> competitive and about twice the stopping power. >> >> * * >> ________________________________________________________________________________
Subject: Re: brakes
Date: Jul 03, 2014
I had to abort a takeoff in my RV10 and the Cleveland brakes faded to nothin g. I used 5000' of runway. The Rv10 brakes work ok, otherwise..... Sent from my iPhone On Jul 3, 2014, at 12:53 PM, Linn Walters wrote: > I've had Clevelands on all my airplanes .... and never had any problem in o ver 40 years. I can't see where twice the stopping power is a benefit! Whe re do y'all need to jump on the brakes like that??? > Linn > > On 7/3/2014 11:57 AM, Kelly McMullen wrote: >> Is the feeling that the Cleveland brakes are inadequate? Anyone have prob lems flat spotting tires with the upgraded Matco brakes? It would seem the M atco brake pads are more expensive than Rapco, and ties you to a single sour ce for pads. >> >> It does appear that the cost is under $900, where I believe the Cleveland set was over $2000. Of course then there is the effort to sell the unused C leveland set. >> >> >> On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs wrote: >>> I was one of the first few people to install these brakes. I think Sean S trasburg was the first. They are far superior to >>> >>> The stock brakes. I have had them on for over a year and love them. >>> >>> >>> >>> Geoff >>> >>> >>> >>> >>> >>> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-serve r(at)matronics.com] On Behalf Of DLM >>> Sent: Thursday, July 03, 2014 9:34 AM >>> To: rv10-list(at)matronics.com >>> Subject: RV10-List: brakes >>> >>> >>> >>> You may want to check the Matco brakes for the RV10. Price competitive a nd about twice the stopping power. >>> >>> >>> >>> http://www.matronics.com/Navigator?RV10-List >>> http://forums.matronics.com >>> http://www.matronics.com/contribution >>> >>> >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> >> >> >> >> >> No virus found in this message. >> Checked by AVG - www.avg.com >> 07/03/14 >> > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Subject: brakes
Date: Jul 03, 2014
Ask Sean Strasburg what might have happened to him if he did not have the Matco Brakes. The brakes are not a got to have item for Everyone. There is nothing wrong with the stock brakes other than they could fade really bad when you really might need them. The Matco pads are double the size of the stock pads so they will last way longer. They feel almost Identical to the stock brakes. I agree that 90% of the time the stock brakes are fine. When driving your car in normal conditions you are not using much brake Power. Would you drive your car with the possibility of severe fade? Some will some won't. That's why we are building our airplanes And not buying certified we have options. As Tim said weigh your options There is no correct answer here. Geoff Combs From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Thursday, July 03, 2014 1:54 PM Subject: Re: RV10-List: brakes I've had Clevelands on all my airplanes .... and never had any problem in over 40 years. I can't see where twice the stopping power is a benefit! Where do y'all need to jump on the brakes like that??? Linn On 7/3/2014 11:57 AM, Kelly McMullen wrote: Is the feeling that the Cleveland brakes are inadequate? Anyone have problems flat spotting tires with the upgraded Matco brakes? It would seem the Matco brake pads are more expensive than Rapco, and ties you to a single source for pads. It does appear that the cost is under $900, where I believe the Cleveland set was over $2000. Of course then there is the effort to sell the unused Cleveland set. On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs > wrote: I was one of the first few people to install these brakes. I think Sean Strasburg was the first. They are far superior to The stock brakes. I have had them on for over a year and love them. Geoff From: <mailto:owner-rv10-list-server(at)matronics.com> owner-rv10-list-server(at)matronics.com [mailto: owner-rv10-list-server(at)matronics.com] On Behalf Of DLM Sent: Thursday, July 03, 2014 9:34 AM Subject: RV10-List: brakes You may want to check the Matco brakes for the RV10. Price competitive and about twice the stopping power. <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List <http://forums.matronics.com> http://forums.matronics.com <http://www.matronics.com/contribution> http://www.matronics.com/contribution get="_blank"> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution No virus found in this message. Checked by AVG - www.avg.com <http://www.avg.com> 07/03/14 http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution ________________________________________________________________________________
Subject: brakes
Date: Jul 03, 2014
Maybe you can just caulk it up to I am just not as good of a pilot......but I have and do see the brake fade problem once or twice a year. Normally on fast landing and trying to make a turn off. Most of my landings are at airports 4500 MSL or higher and thus the ground speeds are faster. Spent two weeks last summer flying in the low lands of Louisiana and Florida and was impressed with my relatively short landings, etc.....then I can back home and was back to normal. 40 knots and hard braking ........you will see brake fade...... I am to cheap to replace my wheels and brakes, but sooner or later I will, maybe. If I was building again, I would look for other options. I love my RV-10...... Rene' Felker N423CF 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, July 03, 2014 12:26 PM Subject: Re: RV10-List: brakes I guess I'd tend to agree, myself, but there are two sides to the discussion I guess. I've talked to Sean about this, and he's seen some brake fade before, and with the added stopping power you wouldn't get much for brake fade. From what he says, it's not really for stopping on a landing, but stopping from an aborted takeoff that it would matter most. I can see the point, and see the benefit. That said, I've never experienced the need for more brake than I have, and in fact I've had a few times where I did some hard braking to make a turnoff and screeched a flat spot onto a tire, so I believe that 99.5% of the time the stock brakes will be plenty, and most people won't ever have the chance to use the additional stopping power, hopefully. Then from a purchase standpoint, I'd guess that if you already own one type of wheel/brake system, the economics of changing really aren't worthwhile for anyone, unless you really just have to have those powerful brakes. It's not like I'm going to get big bucks for my old brakes. Then from a standpoint of replacement parts, it is somewhat nice that if you use a standard system, you can buy standard parts at many places. I just experienced a flat in one of my main tubes while on vacation, which drove home the idea that it's kind of nice to be able to get parts from a nearby source in a pinch. If you have Cleveland, you have a good chance of being able to find some parts. With any others, you may find yourself getting some shipped overnight and taking a couple days. But then again, you may have less need for the parts, right? I'm also not a huge fan of single-source type products in that from EFIS's to Wheels, many of the things we buy for our plane rely on a very tiny number of people to supply the services. If that company got hit by a meteor, or had any number of other things go wrong, you may be without parts. This isn't to scare you from Matco, because we use their parts for many other things too. But, at least now that there are 2 lining makers for my brakes, I've got options. Then again, if you bought a spare 2 or 3 sets of pads for Matco's brakes, you may never end up needing to call them again, because they'd wear so much slower. Either way, it's nice that we have multiple options for our wheels and brakes. It keeps us well supplied for the long run. For those who love the new brakes, great, and it's nice to remind new builders that they have options. For those who would rather have the old brakes, or don't want to pony up, I don't see this as any big deal either. Myself, I am just happy to see that lining prices are now down under $8 each, so I can keep replacing them as needed and enjoy many more years of service. If I were building a new RV-10 today, I'd look at the cost difference and then decide which way to go. There really isn't a "bad" choice, but there may be a good and better. If the price is within a couple or few hundred bucks, I'd just go for the best. If not, it's time to start weighing the options. The most important thing is to pick one and move on, because agonizing over all the details is just going to cost you weeks/months/years of time that you could be FLYING instead of building. :) Tim On 7/3/2014 12:53 PM, Linn Walters wrote: > I've had Clevelands on all my airplanes .... and never had any problem > in over 40 years. I can't see where twice the stopping power is a > benefit! Where do y'all need to jump on the brakes like that??? > Linn > > On 7/3/2014 11:57 AM, Kelly McMullen wrote: >> Is the feeling that the Cleveland brakes are inadequate? Anyone have >> problems flat spotting tires with the upgraded Matco brakes? It would >> seem the Matco brake pads are more expensive than Rapco, and ties you >> to a single source for pads. >> >> It does appear that the cost is under $900, where I believe the >> Cleveland set was over $2000. Of course then there is the effort to >> sell the unused Cleveland set. >> >> >> On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs >> > > >> wrote: >> >> I was one of the first few people to install these brakes. I think >> Sean Strasburg was the first. They are far superior to >> >> The stock brakes. I have had them on for over a year and love them. >> >> Geoff >> >> *From:*owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com >> ] *On Behalf Of *DLM >> *Sent:* Thursday, July 03, 2014 9:34 AM >> *To:* rv10-list(at)matronics.com >> *Subject:* RV10-List: brakes >> >> You may want to check the Matco brakes for the RV10. Price >> competitive and about twice the stopping power. >> >> * * >> ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
OK, I've never had to abort a takeoff that late so I'll put that in the + side. If I had known, maybe I would have sent the Clevelands back, saved some money and gone with the Matco. Lots of water under the bridge so I'll stick with what I've got. Tim pointed out that the cost/benefit of swapping out the Clevelands is pretty lousy and cost drives most of us ..... me included. I learned something .... way too late in the scheme of things .... Linn .... riveting aft upper fuselage!!!!!! :-) :-) :-) On 7/3/2014 3:37 PM, Geoff Combs wrote: > > Ask Sean Strasburg what might have happened to him if he did not have > the Matco Brakes. The brakes are not a got to have item for > > Everyone. There is nothing wrong with the stock brakes other than they > could fade really bad when you really might need them. The > > Matco pads are double the size of the stock pads so they will last way > longer. They feel almost Identical to the stock brakes. > > I agree that 90% of the time the stock brakes are fine. When driving > your car in normal conditions you are not using much brake > > Power. Would you drive your car with the possibility of severe fade? > Some will some won't. That's why we are building our airplanes > > And not buying certified we have options. As Tim said weigh your > options There is no correct answer here. > > Geoff Combs > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Linn Walters > *Sent:* Thursday, July 03, 2014 1:54 PM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: brakes > > I've had Clevelands on all my airplanes .... and never had any problem > in over 40 years. I can't see where twice the stopping power is a > benefit! Where do y'all need to jump on the brakes like that??? > Linn > > On 7/3/2014 11:57 AM, Kelly McMullen wrote: > > Is the feeling that the Cleveland brakes are inadequate? Anyone > have problems flat spotting tires with the upgraded Matco brakes? > It would seem the Matco brake pads are more expensive than Rapco, > and ties you to a single source for pads. > > It does appear that the cost is under $900, where I believe the > Cleveland set was over $2000. Of course then there is the effort > to sell the unused Cleveland set. > > On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs > > wrote: > > I was one of the first few people to install these brakes. I > think Sean Strasburg was the first. They are far superior to > > The stock brakes. I have had them on for over a year and love > them. > > Geoff > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com > ] *On Behalf Of *DLM > *Sent:* Thursday, July 03, 2014 9:34 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: brakes > > You may want to check the Matco brakes for the RV10. Price > competitive and about twice the stopping power. > > * * > > * * > > *http://www.matronics.com/Navigator?RV10-List* > > *http://forums.matronics.com* > > *http://www.matronics.com/contribution* > > * * > > * * > > * * > > *get="_blank">**http://www.matronics.com/Navigator?RV10-List*** > > *tp://forums.matronics.com* > > *_blank">**http://www.matronics.com/contribution*** > > * * > > * * > > * * > > * * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > 07/03/14 > > * **http://www.matro=====================* **http://forums.matronics.com**http://www.matronics.co====* * > ** * <http://www.matronics.com/contribution>* > *<http://www.matronics.com/contribution> > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > > * ________________________________________________________________________________
Date: Jul 03, 2014
Subject: Re: brakes
Ah, I see an issue here. I doubt that you're 'not as good a pilot' ..... I've always said an old, bol pilot is one that survives all his/her mistakes! I think it all boils down to how many angels you have sitting on your shoulders. I have a bunch!!! Anyway, I'm a FL resident and have almost all my 2500+ hours landing near sea level. I've made a coast-coast trip ..... and was amazed at the length of runways out west!!! I learned (or relearned) two things on that trip .... density altitude matters ..... and there's a reason the charts aren't green out west!!!! I don't use my brakes much, preferring to use drag for braking ..... and most of the runways I use around here are 4000' long ..... but I still only use 2/3 of that. Linn On 7/3/2014 3:49 PM, Rene Felker wrote: > > Maybe you can just caulk it up to I am just not as good of a pilot......but > I have and do see the brake fade problem once or twice a year. Normally on > fast landing and trying to make a turn off. Most of my landings are at > airports 4500 MSL or higher and thus the ground speeds are faster. Spent > two weeks last summer flying in the low lands of Louisiana and Florida and > was impressed with my relatively short landings, etc.....then I can back > home and was back to normal. > > 40 knots and hard braking ........you will see brake fade...... > > I am to cheap to replace my wheels and brakes, but sooner or later I will, > maybe. > > If I was building again, I would look for other options. > > I love my RV-10...... > > Rene' Felker > N423CF > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Thursday, July 03, 2014 12:26 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: brakes > > > I guess I'd tend to agree, myself, but there are two sides to the discussion > I guess. > > I've talked to Sean about this, and he's seen some brake fade before, and > with the added stopping power you wouldn't get much for brake fade. From > what he says, it's not really for stopping on a landing, but stopping from > an aborted takeoff that it would matter most. I can see the point, and see > the benefit. > > That said, I've never experienced the need for more brake than I have, and > in fact I've had a few times where I did some hard braking to make a turnoff > and screeched a flat spot onto a tire, so I believe that 99.5% of the time > the stock brakes will be plenty, and most people won't ever have the chance > to use the additional stopping power, hopefully. > > Then from a purchase standpoint, I'd guess that if you already own one type > of wheel/brake system, the economics of changing really aren't worthwhile > for anyone, unless you really just have to have those powerful brakes. It's > not like I'm going to get big bucks for my old brakes. > > Then from a standpoint of replacement parts, it is somewhat nice that if you > use a standard system, you can buy standard parts at many places. I just > experienced a flat in one of my main tubes while on vacation, which drove > home the idea that it's kind of nice to be able to get parts from a nearby > source in a pinch. If you have Cleveland, you have a good chance of being > able to find some parts. With any others, you may find yourself getting some > shipped overnight and taking a couple days. But then again, you may have > less need for the parts, right? I'm also not a huge fan of single-source > type products in that from EFIS's to Wheels, many of the things we buy for > our plane rely on a very tiny number of people to supply the services. > If that company got hit by a meteor, or had any number of other things go > wrong, you may be without parts. This isn't to scare you from Matco, > because we use their parts for many other things too. But, at least now > that there are 2 lining makers for my brakes, I've got options. Then again, > if you bought a spare 2 or 3 sets of pads for Matco's brakes, you may never > end up needing to call them again, because they'd wear so much slower. > > Either way, it's nice that we have multiple options for our wheels and > brakes. It keeps us well supplied for the long run. For those who love the > new brakes, great, and it's nice to remind new builders that they have > options. For those who would rather have the old brakes, or don't want to > pony up, I don't see this as any big deal either. Myself, I am just happy > to see that lining prices are now down under $8 each, so I can keep > replacing them as needed and enjoy many more years of service. If I were > building a new RV-10 today, I'd look at the cost difference and then decide > which way to go. There really isn't a "bad" choice, but there may be a good > and better. If the price is within a couple or few hundred bucks, I'd just > go for the best. If not, it's time to start weighing the options. The most > important thing is to pick one and move on, because agonizing over all the > details is just going to cost you weeks/months/years of time that you could > be FLYING instead of building. :) > > Tim > > > On 7/3/2014 12:53 PM, Linn Walters wrote: >> I've had Clevelands on all my airplanes .... and never had any problem >> in over 40 years. I can't see where twice the stopping power is a >> benefit! Where do y'all need to jump on the brakes like that??? >> Linn >> >> On 7/3/2014 11:57 AM, Kelly McMullen wrote: >>> Is the feeling that the Cleveland brakes are inadequate? Anyone have >>> problems flat spotting tires with the upgraded Matco brakes? It would >>> seem the Matco brake pads are more expensive than Rapco, and ties you >>> to a single source for pads. >>> >>> It does appear that the cost is under $900, where I believe the >>> Cleveland set was over $2000. Of course then there is the effort to >>> sell the unused Cleveland set. >>> >>> >>> On Thu, Jul 3, 2014 at 7:33 AM, Geoff Combs >>> >> > >>> wrote: >>> >>> I was one of the first few people to install these brakes. I think >>> Sean Strasburg was the first. They are far superior to >>> >>> The stock brakes. I have had them on for over a year and love them. >>> >>> Geoff >>> >>> *From:*owner-rv10-list-server(at)matronics.com >>> >>> [mailto:owner-rv10-list-server(at)matronics.com >>> ] *On Behalf Of *DLM >>> *Sent:* Thursday, July 03, 2014 9:34 AM >>> *To:* rv10-list(at)matronics.com >>> *Subject:* RV10-List: brakes >>> >>> You may want to check the Matco brakes for the RV10. Price >>> competitive and about twice the stopping power. >>> >>> * * >>> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Subject: Re: brakes
Date: Jul 03, 2014
I have never experienced any fade; but I do not think I've made any maximum effort stops at gross, nor have I aborted a takeoff. And the numbers say that if I started from 70 knots instead of 50 there would be twice as much heat to deal with. Maybe the Clevelands are right on the edge of fading in normal operation? I also wonder if the castoring nose wheel plays in here, for aborted takeoffs? E.g., at the start of a takeoff roll are the brakes already hot from a long taxi? Question: has anyone compared the Rapco pads vs the Clevelands, for fast/maximum effort stops? Tim, I believe current kits from Vans ship with Matco or Grove wheels, so an "upgrade(?)" to Clevelands will be more than a few hundred dollars. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426033#426033 ________________________________________________________________________________
Subject: brakes
Date: Jul 04, 2014
I believe, I was the first to install the Matco. My building partner and I determined the drilling locations for the calipers. Another pilot flies my aircraft; I told him that since there were four pads per side to go easy on the braking. On the other hand if we have to stop, DO IT and we will change the tires and tubes. I still have and extra set of used Clevelands; planned to sell them at Copperstate 2013 but was preoccupied. I use the Matco repadding surface. I have an extra set of shoes and just send in the old set for renewal and have another set ready to go in the hangar. I also like the wear indicator in the pad so inspection of wear is readily apparent. and no they do not fade. If a person has already installed and used the Clevelands or their clones, I would not necessarily go Matco but given a new build I would not question to go Matco. Also know that the caliper is and internal grip as opposed to the external grip of the Clevelands. Also the wheels are aluminum and weigh an extra pound or two but do not burn as a Class D fire. ________________________________________________________________________________
Date: Jul 04, 2014
Subject: Re: brakes
I see Vans also offers (supplies?) Grove wheels and brakes. They appear to use standard Cleveland pads (66-105 or 66-106?) and are in same price range as the Matco. I can't find a lot of detail on Grove's website to compare with the Matco. On Fri, Jul 4, 2014 at 3:24 AM, DLM wrote: > I believe, I was the first to install the Matco. My building partner and > I determined the drilling locations for the calipers. Another pilot flies > my aircraft; I told him that since there were four pads per side to go easy > on the braking. On the other hand if we *have *to stop, DO IT and we will > change the tires and tubes. I still have and extra set of used Clevelands; > planned to sell them at Copperstate 2013 but was preoccupied. I use the > Matco repadding surface. I have an extra set of shoes and just send in the > old set for renewal and have another set ready to go in the hangar. I also > like the wear indicator in the pad so inspection of wear is readily > apparent. and no they do not fade. If a person has already installed and > used the Clevelands or their clones, I would not necessarily go Matco but > given a new build I would not question to go Matco. Also know that the > caliper is and internal grip as opposed to the external grip of the > Clevelands. Also the wheels are aluminum and weigh an extra pound or two > but do not burn as a Class D fire. > > * > > > * > > ________________________________________________________________________________
Subject: Re: brakes
Date: Jul 04, 2014
In the last couple of years we have seen three failures of the Cleveland cal ipers on RV-10s. Two of them were on the same plane and with in a couple day s of each other. Sure, there's probably some relation to piloting technique or to a particular hard use of the brakes, but in my opinion, the caliper s houldn't fail. What appears to happen is that the caliper expands so much th at fluid can get by the o-ring. And something seems to happen the causes the m to the deform permanently and the fluid will slowly leak out after the eve nt. The first caliper we saw this on had almost new brake pads. The second h ad brake pads with about 100 hours on them, but they were still within spec. In the process of researching the brakes and searching for a fix, I found ou t the following, some of which has already been repeated in this thread. Van s switched from Cleveland to Grove in the kits, primarily because of pricing . They switched from the single puck Cleveland design to the single puck Gro ve design. We wanted more stopping power and no possibility of fading, so w e looked at the Matco design. We also contacted Grove and they offered up a t wo puck caliper that they would recommend for the 10. In the end we went wit h the Matco design because they had the kit dialed in. Sent from my iPhone > On Jul 4, 2014, at 7:01 AM, Kelly McMullen wrote: > > I see Vans also offers (supplies?) Grove wheels and brakes. They appear to use standard Cleveland pads (66-105 or 66-106?) and are in same price range as the Matco. I can't find a lot of detail on Grove's website to compare wi th the Matco. > > >> On Fri, Jul 4, 2014 at 3:24 AM, DLM wrote: >> I believe, I was the first to install the Matco. My building partner and I determined the drilling locations for the calipers. Another pilot flies my a ircraft; I told him that since there were four pads per side to go easy on t he braking. On the other hand if we have to stop, DO IT and we will change t he tires and tubes. I still have and extra set of used Clevelands; planned t o sell them at Copperstate 2013 but was preoccupied. I use the Matco repaddi ng surface. I have an extra set of shoes and just send in the old set for re newal and have another set ready to go in the hangar. I also like the wear i ndicator in the pad so inspection of wear is readily apparent. and no they d o not fade. If a person has already installed and used the Clevelands or the ir clones, I would not necessarily go Matco but given a new build I would no t question to go Matco. Also know that the caliper is and internal grip as o pposed to the external grip of the Clevelands. Also the wheels are aluminum and weigh an extra pound or two but do not burn as a Class D fire. >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 04, 2014
Subject: Firewall penetrations
Has anyone used or considered using the steel eyeball from Doubletree, model 6100, for the control cables passing through the firewall? http://www.doubleteeproducts.com/products.html Ed Godfrey 40717 ________________________________________________________________________________
Subject: Flap Chafing / Tape
Date: Jul 04, 2014
Hi I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. Has anyone faced this problem and if so how did you deal with it. Is there any preference to putting the tape on the flap or underneath the skin? Is there any tape that is preferable? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426106#426106 ________________________________________________________________________________
Subject: Re: Flap Chafing / Tape
Date: Jul 05, 2014
I installed tape on the bottom of the upper skin. I installed it during final assembly after painting. I made no adjustments to make the gap wider. No problems or scratches after 1.5 years. Bob Sent from my iPad > On Jul 4, 2014, at 10:36 PM, "kearney" wrote: > > > Hi > > I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. > > I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. > > Has anyone faced this problem and if so how did you deal with it. > > Is there any preference to putting the tape on the flap or underneath the skin? > > Is there any tape that is preferable? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426106#426106 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2014
Vans sells a tape that works great. It is definitely best to put it under the bottom skin, because it discolors and looks bad on the flap. I wouldn't bend the skin. The flap, when up, will bend the top skin ever so slightly, but this gives it a nice tight seal with no extra drag. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jul 5, 2014, at 6:11 AM, Bob Leffler wrote: > > > I installed tape on the bottom of the upper skin. I installed it during final assembly after painting. I made no adjustments to make the gap wider. No problems or scratches after 1.5 years. > > Bob > > Sent from my iPad > >> On Jul 4, 2014, at 10:36 PM, "kearney" wrote: >> >> >> Hi >> >> I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. >> >> I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. >> >> Has anyone faced this problem and if so how did you deal with it. >> >> Is there any preference to putting the tape on the flap or underneath the skin? >> >> Is there any tape that is preferable? >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=426106#426106 > > > > > ________________________________________________________________________________
From: "egohr1" <EGOHR86(at)alumni.carnegiemellon.edu>
Date: Jul 05, 2014
I used the Vans tape and have not had any issues in the last 5 years. Put the tape in the underside of the wing skin after paint. As the others have said you will want the tight seal in reflex to reduce drag. -------- eric gohr EGOHR86(at)alumni.carnegiemellon.edu Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426124#426124 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jul 05, 2014
I used the UHMW tape from Van's. I put the tape on the flaps after paint, the bottom of the tape flush with the wing skin with the flap in the up position. My thought was if the tape is on the bottom of the skin then if any piece of grit got between the tape and the flap it would scratch the paint on the flap. I did the same on the 8A. The tape lasted right at 10 years. When I sold the plane I replaced the tape by using just a little hot air gun to soften it the tape but not the paint. The replacement process took just a few minutes. I found other places to use the tape as well, like where the inboard rudder peddle cable links come close to the sides of the tunnel. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kearney Sent: Friday, July 04, 2014 10:37 PM Subject: RV10-List: Flap Chafing / Tape Hi I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. Has anyone faced this problem and if so how did you deal with it. Is there any preference to putting the tape on the flap or underneath the skin? Is there any tape that is preferable? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426106#426106 ________________________________________________________________________________
Date: Jul 05, 2014
I opened the gap a bit and my painter installed the tape under the skin. No issues. Dave Leikam On Jul 4, 2014, at 9:36 PM, kearney wrote: > > Hi > > I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. > > I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. > > Has anyone faced this problem and if so how did you deal with it. > > Is there any preference to putting the tape on the flap or underneath the skin? > > Is there any tape that is preferable? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426106#426106 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2014
Timely question for me. After 125 hrs I have a small line (1") of wear. I t ook it to the paint shop in Tusculoosa yesterday to have it touched up. The painter who did a great job on the plane has recommended the tape under t he trailing edge wing skin. Leon Everett > Subject: RV10-List: Flap Chafing / Tape > From: kearney(at)shaw.ca > Date: Fri=2C 4 Jul 2014 19:36:39 -0700 > To: rv10-list(at)matronics.com > > > Hi > > I am looking at getting my -10 painted in a month or so. Over the past ye ar I have noticed that the flaps chafe against the upper skin. My concern i s that when everything is painted=2C the nonexistent gap between the flap a nd upper skin will become very tight. > > I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. > > Has anyone faced this problem and if so how did you deal with it. > > Is there any preference to putting the tape on the flap or underneath the skin? > > Is there any tape that is preferable? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426106#426106 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jul 06, 2014
Les, The trailing edge of the upper skin was pretty wavy on my QB wings. In reflex position I measured everything between gaps of 1/8" to interference of almost 1/8" which I considered a bit too much preload on the flap. It is very easy to adjust these by hand to give a more or less uniform snug fit (ie. touching with very light preload) along the length of the flap. Cheers, Gordon 41015, Switzerland On Jul 5, 2014, at 4:36 AM, kearney wrote: > > Hi > > I am looking at getting my -10 painted in a month or so. Over the past year I have noticed that the flaps chafe against the upper skin. My concern is that when everything is painted, the nonexistent gap between the flap and upper skin will become very tight. > > I am planning on installing 3m tape but am wondering if I should open up the gap by putting a small upward bend in the skin. > > Has anyone faced this problem and if so how did you deal with it. > > Is there any preference to putting the tape on the flap or underneath the skin? > > Is there any tape that is preferable? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426106#426106 > > > > > > > > > > ________________________________________________________________________________
Subject: Access to tire vale stems
Date: Jul 07, 2014
Hi I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426264#426264 ________________________________________________________________________________
Date: Jul 07, 2014
Subject: Re: Access to tire vale stems
Do yourself a favor and convert you wheels to take 90 degree valve stems. Use a valve stem extender sold in truck tire stores through a small hole in the wheel pant to air up the tire. To make it easy to line up the stem/hole paint a white stripe vertically on the inside of the tire ..... you can see the stripe when you're handling the tow bar. Linn On 7/7/2014 10:40 PM, kearney wrote: > > Hi > > I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily. > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426264#426264 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jul 07, 2014
You can drill a 2" hole centered 2-2.5" aft and 1/2" above the axle screw. Cirrus sells a 2" plug that will fit the hole. You have to leave the valve cover off, but you can easily add air. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Jul 7, 2014, at 10:40 PM, "kearney" wrote: > > > Hi > > I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426264#426264 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2014
I drilled 3/4" holes then used a metal cover like Cleaveland sells. You can buy the same thing at the local hardware store for about a quarter per wheel. I also painted a mark on the tire when the valve stem is aligned with the hole. The system works well, except its a PITA if you are by yourself. It's impossible to see the marks on the tires while holding the tow bar. Sent from my iPad > On Jul 7, 2014, at 10:40 PM, "kearney" wrote: > > > Hi > > I saw a couple of pix from of -10s in SA that appear to have nicely sized access ports on the wheel pants. Does anyone know about these. I would be interested in being able to access tire valve stems simply and easily. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426264#426264 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 07, 2014
Yes, it's a bit of a pain to take off the pants. But, unless your tubes leak badly, you really ought to be looking at brakes, wheels, etc., about as often as your tubes need air. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426269#426269 ________________________________________________________________________________
Date: Jul 08, 2014
That's been my standard reply to this for years too. I personally don't need the added temptation to SKIP taking the fairings off, because I know I'd succumb. I generally only have to take them off in spring and fall,with the leak guard tubes, and I think brake pads deserve inspection more often than that. Tim > On Jul 7, 2014, at 9:39 PM, "Bob Turner" wrote: > > > Yes, it's a bit of a pain to take off the pants. But, unless your tubes leak badly, you really ought to be looking at brakes, wheels, etc., about as often as your tubes need air. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=426269#426269 > > > > > > > > > > ________________________________________________________________________________
Date: Jul 08, 2014
I added in a small door to each wheel pant. Just took a hole saw and then built up a fiberglass flange and some nutplates. Each enough to do and free. http://myrv10factory.files.wordpress.com/2014/04/20140401_222133489_ios.jpg http://myrv10factory.files.wordpress.com/2014/02/20140205_231629512_ios.jpg Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426306#426306 ________________________________________________________________________________
Date: Jul 08, 2014
Hi Thanks to everyone for the chafing suggestion. I'll go with the tape under the wing skin. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426341#426341 ________________________________________________________________________________
Date: Jul 08, 2014
Linn et al Thanks for the suggestions. I have the caps for the pants already. I didn't know that 90 degree extensions were available so I will definitely go that route. I do take Tim's point about not skipping the brake inspections though. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426342#426342 ________________________________________________________________________________
Date: Jul 09, 2014
Les, The extensions are straight, valve stems are 90 degrees, so they point straight out instead of towards the axle nut. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426356#426356 ________________________________________________________________________________
Date: Jul 09, 2014
Subject: window fiberglass
Installing the windows is coming up fast .... what fiberglass are y'all using on the outside around the windows to prevent paint cracking??? Source? ACS has 8 Oz. cloth tape but I believe I really want thinner stuff. Linn ________________________________________________________________________________
Subject: Re: window fiberglass
Date: Jul 09, 2014
To be honest, I can't remember the weight. I used two layers of whatever it was. It's been a year and a half. No cracks yet. Sent from my iPhone On Jul 9, 2014, at 1:57 PM, Linn Walters wrote: Installing the windows is coming up fast .... what fiberglass are y'all using on the outside around the windows to prevent paint cracking??? Source? ACS has 8 Oz. cloth tape but I believe I really want thinner stuff. Linn ________________________________________________________________________________
Date: Jul 09, 2014
I used the "standard" e glass: http://www.aircraftspruce.com/catalog/cmpages/120.php with 2-3 layers around each window. You of course will need to add mico on top of the glass to get it feathered into the canopy top. On the windshield I use carbon fiber for the fuselage to windshield joint. I'm happy with the outcome. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, July 09, 2014 2:16 PM Subject: Re: RV10-List: window fiberglass To be honest, I can't remember the weight. I used two layers of whatever it was. It's been a year and a half. No cracks yet. Sent from my iPhone On Jul 9, 2014, at 1:57 PM, Linn Walters wrote: Installing the windows is coming up fast .... what fiberglass are y'all using on the outside around the windows to prevent paint cracking??? Source? ACS has 8 Oz. cloth tape but I believe I really want thinner stuff. Linn ________________________________________________________________________________
Date: Jul 09, 2014
At model airplane shops you can get some very nice low profile tightly woven tape. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426413#426413 ________________________________________________________________________________
Date: Jul 10, 2014
I've been flying for three years with no cracks around the windows. I used the standard E-Cloth Carl mentioned. Having said that, I do have a small crack at the top of the windshield that I need to fill. Maybe I should have used the carbon fiber Carl mentioned.... John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426419#426419 ________________________________________________________________________________
Date: Jul 10, 2014
Try going pantless, like me.... John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426420#426420 Attachments: http://forums.matronics.com//files/img_2640_110.jpg ________________________________________________________________________________
Subject: FS: New Flightline Interiors RV-10 Carpet
Date: Jul 10, 2014
We've decided to go with a different interior color scheme on our second RV-10 and have a brand new, never opened RV-10 carpet set from Flightline Interiors (Abby). Set includes Color is dark blue - almost Navy blue but not quite that dark and is the same color that was in our first plane. Carpet covers floors, tunnel, baggage area floor and baggage area sidewall as shown on her website: http://www.flightlineinteriors.com/products/rv10/default.asp $450 and I'll include shipping to anywhere in the CONUS. Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426428#426428 ________________________________________________________________________________
Date: Jul 10, 2014
Subject: Section FF-4 - Fuel system
Page 3 I have an original copy of plans that does not show a support hanger attached to #6 intake tube, and one that came with my kit which does show said hangar, and still is labeled as revision zero. It says to fabricate the hanger from "crating strap." What have others done, and what sort of strapping did you use? I'm thinking perhaps of the strapping plumbers use to support pipes. ________________________________________________________________________________
Subject: WD-1023-PC needed.
Date: Jul 11, 2014
I am working on an RV-10 Door Repair and need the WD-1023 Strut Bracket. Problem is that Van's is out of stock until the 21st. Does anybody have their finishing kit that won't be working on the doors for a while that could loan me their part until I get the new one (which I will send to you to replace yours)? Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad ________________________________________________________________________________
Subject: Re: WD-1023-PC needed.
Date: Jul 11, 2014
I think Sean at planearound.com makes those, and he may even have materials choices. Tim > On Jul 11, 2014, at 6:09 PM, Jesse Saint wrote: > > > I am working on an RV-10 Door Repair and need the WD-1023 Strut Bracket. Problem is that Van's is out of stock until the 21st. Does anybody have their finishing kit that won't be working on the doors for a while that could loan me their part until I get the new one (which I will send to you to replace yours)? > > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > > ________________________________________________________________________________
Date: Jul 11, 2014
Jesse, I've got 2 of the Vans brackets, I used Sean's and these are surplus to my needs. Drop me an email with your address if you want 'em and I'll get them in the Mail. Bob On Friday, July 11, 2014, Tim Olson wrote: > > I think Sean at planearound.com makes those, and he may even have > materials choices. > Tim > > > > On Jul 11, 2014, at 6:09 PM, Jesse Saint > wrote: > > > > > > > > I am working on an RV-10 Door Repair and need the WD-1023 Strut Bracket. > Problem is that Van's is out of stock until the 21st. Does anybody have > their finishing kit that won't be working on the doors for a while that > could loan me their part until I get the new one (which I will send to you > to replace yours)? > > > > > > Jesse Saint > > Saint Aviation, Inc. > > 352-427-0285 > > jesse(at)saintaviation.com > > > > Sent from my iPad > > > > > > > > > > ________________________________________________________________________________
Date: Jul 13, 2014
Subject: Rusty RV-8 Steel Parts
I sent this email to Van's today. Something to watch out for... >Date: Sun, 13 Jul 2014 11:23:02 -0700 >To: support(at)vansaircraft.com >From: Matt Dralle <dralle(at)matronics.com> >Subject: Rusty RV-8 Steel Parts > > >Dear Van's, > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off. > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default. > >Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > >FYI. > >- >Matt Dralle - Matt Dralle RV-8 #82880 N998RV "Ruby Vixen" http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... RV-6 #20916 N360EM "The Flyer" http://www.mattsrv6.com - Matt's RV-6 Revitalization Log Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode Matt's Livermore Airport Live ATC Stream! Check out the live ATC stream directly from my hangar at the Livermore Airport. Includes both Tower and Ground transmissions. Archives too! For entertainment purposes only. http://klvk.matronics.com ________________________________________________________________________________
Date: Jul 14, 2014
My tape is under the top skin as many above. The only things I can add are... While flaps are down in the hangar, before every flight from home, clean and wax flap top leading edges where they contact tape. Clean tape too. When landing on a wet grass strip like Triple Tree (SC00), do not retract muddy flaps past halfway until you shut down. Then clean them and the tape. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426690#426690 ________________________________________________________________________________
Subject: Re: FS: Full RV-10 Carpet Set - New, From Flightline Interiors
Date: Jul 15, 2014
Carpet is sold Read this topic online here: http://forums.matronics.com/viewtopic.php?p=426754#426754 ________________________________________________________________________________
Subject: Rusty RV-8 Steel Parts and other problems
Date: Jul 16, 2014
I'll give you my tail of woe! Last Sunday I was making a routine landing at my home airport and on the ro llout the nose gear departed the plane and then the gear strut stuck into t he pavement and when the plane continued over it folded up underneath. It w as a main gear landing at a slow speed. Prop strike=2C very badly mangled f irewall where the nose gear strut cut into it=2C big gouge on left side whe re the nose wheel hit fusalage and then into the left flap. All at low spee d. Gas everywhere. I was fortunate that it didn't roll over when the strut dug into the pavement. The insurance adjustor come out today and looked it over. His opinion agreed with me as to cause of accident. The gear strut br oke at the weld where it attaches to the upright spindle on the wheel assem bly. Looks to be a very poor weld and not a very robust design to boot. The weld was very small in width and didn't penetrate very deep. Split right down the middle of the weld=2C I wonder how many ticking time bombs are out there ready to blow off the nose gears. Not in a place to check very often either. Dan > Date: Sun=2C 13 Jul 2014 11:28:20 -0700 > To: rv10-list(at)matronics.com > From: dralle(at)matronics.com > Subject: RV10-List: Rusty RV-8 Steel Parts > > > I sent this email to Van's today. Something to watch out for... > > > >Date: Sun=2C 13 Jul 2014 11:23:02 -0700 > >To: support(at)vansaircraft.com > >From: Matt Dralle <dralle(at)matronics.com> > >Subject: Rusty RV-8 Steel Parts > > > > > >Dear Van's=2C > > > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While strippi ng=2C I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certa in areas=2C primarily the ones made from the 4130 plate (see attached pictu res). This will eventually cause the powder to flake off. > > > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped=2C there is no surface pr eparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best pos sible protection from future rust break through. Additionally=2C the adhes ion of the powder coat is significantly better with these additional surfac e preparations. The cost differential is minimal=2C since high-end coaters usually do these steps by default. > > > >Many builders faced with changing the color of their steel parts will si mply choose to paint or powder coat over the top of the factory powder coat ing. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > > > >FYI. > > > >- > >Matt Dralle > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 180+ Hours Since Purchase - Upgrades Complete=3B Now In Full Flye r Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > ________________________________________________________________________________
Date: Jul 19, 2014
Subject: Re: Rusty RV-8 Steel Parts and other problems
Hi Danny,=0AI would like to examine my nose gear for the poor weld.- I am not sure what weld you are talking about.- Is a picture available?- Th ank you for speaking out on this issue.=0A-=0AJohn Morrow=0A#40461, airfr ame complete =0A=0A=0AOn Wednesday, July 16, 2014 4:09 PM, Danny Riggs wrote:=0A =0A=0A=0A =0AI'll give you my tail of woe!=0ALas t Sunday I was making a routine landing at my home airport and on the rollo ut the nose gear departed the plane and then the gear strut stuck into the pavement and when the plane continued over it folded up underneath. It was a main gear landing at a slow speed. Prop strike, very badly mangled firewa ll where the nose gear strut cut into it, big gouge on left side where the nose wheel hit fusalage and then into the left flap. All at low speed. Gas everywhere. I was fortunate that it didn't roll over when the strut dug int o the pavement. The insurance adjustor come out today and looked it over. H is opinion agreed with me as to cause of accident. The gear strut broke at the weld where it attaches to the upright spindle on the wheel assembly. Lo oks to be a very poor weld and not a very robust design to boot. The weld - was very small in width and didn't penetrate very deep. Split right dow n the middle of the weld, I wonder how many ticking time bombs are out there ready to blow off the nose gears. Not in a place to check very o ften either.- Dan=0A=0A=0A> Date: Sun, 13 Jul 2014 11:28:20 -0700=0A> To: rv10-list(at)matronics.com=0A> From: dralle(at)matronics.com=0A> Subject: RV10-L ist: Rusty RV-8 Steel Parts=0A> =0A> =0A> I sent this email to Van's today. Something to watch out for...=0A> =0A> =0A> >Date: Sun, 13 Jul 2014 11:23 matronics.com>=0A> >Subject: Rusty RV-8 Steel Parts=0A> >=0A> >=0A> >Dear V an's,=0A> >=0A> >I am stripping all of the steel parts on my RV-8 to have t hem re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powde r coating. Perhaps the most disturbing was the high build up rust under pa rts in certain areas, primarily the ones made from the 4130 plate (see atta ched pictures). This will eventually cause the powder to flake off.=0A> > =0A> >The other issue is the distinct lack of surface prep on all steel par ts! On every single steel part that I have stripped, there is no surface p reparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best po ssible protection from future rust break through. Additionally, the adhesi on of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters us ually do these steps by default.=0A> >=0A> >Many builders faced with changi ng the color of their steel parts will simply choose to paint or powder coa t over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above.=0A> >=0A> >FYI.=0A> >=0A> >-=0A> >Matt Dralle=0A> =0A> -=0A> Matt Dralle=0A> =0A> RV- 8 #82880 N998RV "Ruby Vixen"=0A> http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log=0A> http://www.mattsrv8.com/Mishap - Landing Mishap R ebuild Log=0A> http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube C hannel=0A> Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mish ap...=0A> =0A> RV-6 #20916 N360EM "The Flyer"=0A> http://www.mattsrv6.com - Matt's RV-6 Revitalization Log=0A> Status: 180+ Hours Since Purchase - Upg rades Complete; Now In Full Flyer Mode=0A> =0A> Matt's Livermore Airport Li ve ATC Stream!=0A> Check out the live ATC stream directly from my hangar at the Livermore=0A> Airport. Includes both Tower and Ground transmissions. Archives too!=0A> For entertainment purposes only. http://klvk.matronics. ================ ________________________________________________________________________________
Date: Jul 21, 2014
Subject: OSH14 Builders Cookout: Sunday 7/27
It's that time of year again to eat too much, have a few drinks, and talk RV10s! The RV10 builder cookout is almost here... Date: Sunday, July 27th Time: 6PM. Location: It's going to be held in the same place as the last few years in Camp Scholler, in between 54th and 53rd street: https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo *If you'd like to attend, please sign up at:http://www.perfectpotluck.com/meals....1&v=b76fb5e60f <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* You can sign up to bring some food and drinks to share, or just kick in a few bucks. Fun times will be had by all! ________________________________________________________________________________
Date: Jul 21, 2014
Subject: Re: OSH14 Builders Cookout: Sunday 7/27
Thanks Ed, I signed up and will hopefully arrive in time. We're supposed to be there mid-day Sunday. On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz wrote: > It's that time of year again to eat too much, have a few drinks, and talk > RV10s! The RV10 builder cookout is almost here... > > Date: Sunday, July 27th > Time: 6PM. > Location: It's going to be held in the same place as the last few years in > Camp Scholler, in between 54th and 53rd street: > https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo > > > > *If you'd like to attend, please sign up at: > http://www.perfectpotluck.com/meals....1&v=b76fb5e60f > <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* > > You can sign up to bring some food and drinks to share, or just kick in a > few bucks. Fun times will be had by all! > > * > > > * > > ________________________________________________________________________________
Date: Jul 21, 2014
Need coordinates to deliver Wisconsin Beer Saturday PM before the rental car turns into a pumpkin. John Ambassador for "One Week Wonder" for Zenith CH750 - this year On Mon, Jul 21, 2014 at 3:24 PM, David Saylor wrote: > Thanks Ed, I signed up and will hopefully arrive in time. We're supposed > to be there mid-day Sunday. > > > On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz wrote: > >> It's that time of year again to eat too much, have a few drinks, and talk >> RV10s! The RV10 builder cookout is almost here... >> >> Date: Sunday, July 27th >> Time: 6PM. >> Location: It's going to be held in the same place as the last few years >> in Camp Scholler, in between 54th and 53rd street: >> https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo >> >> >> >> *If you'd like to attend, please sign up at: >> http://www.perfectpotluck.com/meals....1&v=b76fb5e60f >> <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* >> >> You can sign up to bring some food and drinks to share, or just kick in a >> few bucks. Fun times will be had by all! >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: Jul 21, 2014
For those arriving after Sunday, is there anything else on the schedule? Cheers Les Ps. I will be sorry to miss the Sunday BBQ. Sent from my iPhone > On Jul 21, 2014, at 5:03 PM, Ed Kranz wrote: > > It's that time of year again to eat too much, have a few drinks, and talk R V10s! The RV10 builder cookout is almost here... > > Date: Sunday, July 27th > Time: 6PM. > Location: It's going to be held in the same place as the last few years in Camp Scholler, in between 54th and 53rd street: > https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo > > If you'd like to attend, please sign up at: > http://www.perfectpotluck.com/meals....1&v=b76fb5e60f > > You can sign up to bring some food and drinks to share, or just kick in a f ew bucks. Fun times will be had by all! > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jul 21, 2014
John, Bob & Gary are in their normal locations that they=99ve had for the last three or four years between 54th and 53rd. bob From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox Sent: Monday, July 21, 2014 7:40 PM Subject: Re: RV10-List: OSH14 Builders Cookout: Sunday 7/27 Need coordinates to deliver Wisconsin Beer Saturday PM before the rental car turns into a pumpkin. John Ambassador for "One Week Wonder" for Zenith CH750 - this year On Mon, Jul 21, 2014 at 3:24 PM, David Saylor wrote: Thanks Ed, I signed up and will hopefully arrive in time. We're supposed to be there mid-day Sunday. On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz wrote: It's that time of year again to eat too much, have a few drinks, and talk RV10s! The RV10 builder cookout is almost here... Date: Sunday, July 27th Time: 6PM. Location: It's going to be held in the same place as the last few years in Camp Scholler, in between 54th and 53rd street: https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo If you'd like to attend, please sign up at: <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f> http://www.perfectpotluck.com/meals....1&v=b76fb5e60f You can sign up to bring some food and drinks to share, or just kick in a few bucks. Fun times will be had by all! get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Jul 21, 2014
Bee can be delivered to the site - Gary and I will keep an eye on it... We're on-site now. Bob On Monday, July 21, 2014, John Cox wrote: > Need coordinates to deliver Wisconsin Beer Saturday PM before the rental > car turns into a pumpkin. > > John > Ambassador for "One Week Wonder" for Zenith CH750 - this year > > > On Mon, Jul 21, 2014 at 3:24 PM, David Saylor > wrote: > >> Thanks Ed, I signed up and will hopefully arrive in time. We're supposed >> to be there mid-day Sunday. >> >> >> On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz > > wrote: >> >>> It's that time of year again to eat too much, have a few drinks, and >>> talk RV10s! The RV10 builder cookout is almost here... >>> >>> Date: Sunday, July 27th >>> Time: 6PM. >>> Location: It's going to be held in the same place as the last few years >>> in Camp Scholler, in between 54th and 53rd street: >>> https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo >>> >>> >>> >>> *If you'd like to attend, please sign up at: >>> http://www.perfectpotluck.com/meals....1&v=b76fb5e60f >>> <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* >>> >>> You can sign up to bring some food and drinks to share, or just kick in >>> a few bucks. Fun times will be had by all! >>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: Jul 21, 2014
Why would you want Bee at the camp site? Aren't the mosquitoes enough? On 7/21/2014 8:50 PM, Bob Condrey wrote: > Bee can be delivered to the site - Gary and I will keep an eye on > it... We're on-site now. > > Bob > > On Monday, July 21, 2014, John Cox > wrote: > > Need coordinates to deliver Wisconsin Beer Saturday PM before the > rental car turns into a pumpkin. > > John > Ambassador for "One Week Wonder" for Zenith CH750 - this year > > > On Mon, Jul 21, 2014 at 3:24 PM, David Saylor > > wrote: > > Thanks Ed, I signed up and will hopefully arrive in time. > We're supposed to be there mid-day Sunday. > > > On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz > wrote: > > It's that time of year again to eat too much, have a few > drinks, and talk RV10s! The RV10 builder cookout is almost > here... > > Date: Sunday, July 27th > Time: 6PM. > Location: It's going to be held in the same place as the > last few years in Camp Scholler, in between 54th and 53rd > street: > https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo > > > *If you'd like to attend, please sign up at: > http://www.perfectpotluck.com/meals....1&v=b76fb5e60f > <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* > > You can sign up to bring some food and drinks to share, or > just kick in a few bucks. Fun times will be had by all! > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > * > > > * -- Lyle Sent from my Gateway E4610D desktop ________________________________________________________________________________
Date: Jul 21, 2014
Makes you forget about the Mosquito dive bombers......................8^) On 7/21/2014 8:08 PM, Lyle Peterson wrote: > Why would you want Bee at the camp site? Aren't the mosquitoes enough? > On 7/21/2014 8:50 PM, Bob Condrey wrote: >> Bee can be delivered to the site - Gary and I will keep an eye on >> it... We're on-site now. >> >> Bob >> >> On Monday, July 21, 2014, John Cox > > wrote: >> >> Need coordinates to deliver Wisconsin Beer Saturday PM before the >> rental car turns into a pumpkin. >> >> John >> Ambassador for "One Week Wonder" for Zenith CH750 - this year >> >> >> On Mon, Jul 21, 2014 at 3:24 PM, David Saylor >> > > wrote: >> >> Thanks Ed, I signed up and will hopefully arrive in time. >> We're supposed to be there mid-day Sunday. >> >> >> On Mon, Jul 21, 2014 at 2:03 PM, Ed Kranz > > wrote: >> >> It's that time of year again to eat too much, have a few >> drinks, and talk RV10s! The RV10 builder cookout is >> almost here... >> >> Date: Sunday, July 27th >> Time: 6PM. >> Location: It's going to be held in the same place as the >> last few years in Camp Scholler, in between 54th and 53rd >> street: >> https://mapsengine.google.com/map/ed...Q.kGsNSWbLT7wo >> >> >> *If you'd like to attend, please sign up at: >> http://www.perfectpotluck.com/meals....1&v=b76fb5e60f >> <http://www.perfectpotluck.com/meals.php?t=CWOT8581&v=b76fb5e60f>* >> >> You can sign up to bring some food and drinks to share, >> or just kick in a few bucks. Fun times will be had by all! >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> >> * >> >> * >> >> >> * > > -- > Lyle > > Sent from my Gateway E4610D desktop > > * > > > * ________________________________________________________________________________
Date: Jul 22, 2014
Gotta love iphone typing... Anyway, Gary and I would be please to watch all the beer John can deliver :) Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=427145#427145 ________________________________________________________________________________
Date: Jul 22, 2014
Willing, but have the Rental Pumpkin only till Sat 6 PM. Then the dorms by BUS Sun-Thu. Think they would frown on my historical hospitality with "Carry-On" into Camp Swampy. Need a Camp spot to deliver! Also have a bed at the Dorms available for someone from Saturday, 7/26 thru to Thursday AM 7/31 then its back to working Graves on the Left Coast for Alaska Air - (J.D. Power 7X National Award Winner). Leaving PDX in 73 hours for OSH '14. JC #40600 503-453-6016 On Tue, Jul 22, 2014 at 8:43 AM, bcondrey wrote: > > Gotta love iphone typing... Anyway, Gary and I would be please to watch > all the beer John can deliver :) > > Bob > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=427145#427145 > > ________________________________________________________________________________
Date: Jul 22, 2014
John, I'm in a Jayco Greyhawk Class C about 40 yards south of Lindbergh between 53rd and 54th. Gary is also here in his Class A Grand Tour Vectra, immediately south and parallel to me. Bob On Tuesday, July 22, 2014, John Cox wrote: > Willing, but have the Rental Pumpkin only till Sat 6 PM. Then the dorms > by BUS Sun-Thu. Think they would frown on my historical hospitality with > "Carry-On" into Camp Swampy. Need a Camp spot to deliver! > > Also have a bed at the Dorms available for someone from Saturday, 7/26 > thru to Thursday AM 7/31 then its back to working Graves on the Left Coast > for Alaska Air - (J.D. Power 7X National Award Winner). Leaving PDX in 73 > hours for OSH '14. > > JC #40600 > 503-453-6016 > > > On Tue, Jul 22, 2014 at 8:43 AM, bcondrey > wrote: > >> > >> >> Gotta love iphone typing... Anyway, Gary and I would be please to watch >> all the beer John can deliver :) >> >> Bob >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=427145#427145 >> >> >> >> >> >> >> >> ========== >> " target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> MS - >> k">http://forums.matronics.com >> ========== >> e - >> -Matt Dralle, List Admin. >> t="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > ________________________________________________________________________________
Date: Jul 23, 2014
The RV-10 and RV-8A nose gear leg are different. Albert Gardner N991RV Yuma (hotter than hell) AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Morrow Sent: Saturday, July 19, 2014 6:38 AM Subject: Re: RV10-List: Rusty RV-8 Steel Parts and other problems Hi Danny, I would like to examine my nose gear for the poor weld. I am not sure what weld you are talking about. Is a picture available? Thank you for speaking out on this issue. John Morrow #40461, airframe complete On Wednesday, July 16, 2014 4:09 PM, Danny Riggs wrote: I'll give you my tail of woe! Last Sunday I was making a routine landing at my home airport and on the rollout the nose gear departed the plane and then the gear strut stuck into the pavement and when the plane continued over it folded up underneath. It was a main gear landing at a slow speed. Prop strike, very badly mangled firewall where the nose gear strut cut into it, big gouge on left side where the nose wheel hit fusalage and then into the left flap. All at low speed. Gas everywhere. I was fortunate that it didn't roll over when the strut dug into the pavement. The insurance adjustor come out today and looked it over. His opinion agreed with me as to cause of accident. The gear strut broke at the weld where it attaches to the upright spindle on the wheel assembly. Looks to be a very poor weld and not a very robust design to boot. The weld was very small in width and didn't penetrate very deep. Split right down the middle of the weld, I wonder how many ticking time bombs are out there ready to blow off the nose gears. Not in a place to check very often either. Dan > Date: Sun, 13 Jul 2014 11:28:20 -0700 > To: rv10-list(at)matronics.com > From: dralle(at)matronics.com > Subject: RV10-List: Rusty RV-8 Steel Parts > > > I sent this email to Van's today. Something to watch out for... > > > >Date: Sun, 13 Jul 2014 11:23:02 -0700 > >To: support(at)vansaircraft.com > >From: Matt Dralle <dralle(at)matronics.com> > >Subject: Rusty RV-8 Steel Parts > > > > > >Dear Van's, > > > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While stripping, I have noticed a couple of things regarding factory powder coating. Perhaps the most disturbing was the high build up rust under parts in certain areas, primarily the ones made from the 4130 plate (see attached pictures). This will eventually cause the powder to flake off. > > > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped, there is no surface preparation such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possible protection from future rust break through. Additionally, the adhesion of the powder coat is significantly better with these additional surface preparations. The cost differential is minimal, since high-end coaters usually do these steps by default. > > > >Many builders faced with changing the color of their steel parts will simply choose to paint or powder coat over the top of the factory powder coating. This will eventually lead to a less-than-satisfactory result for the reasons outlined above. > > > >FYI. > > > >- > >Matt Dralle > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 180+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > hthttp://www.matronics.com/contribut============= <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> <http://forums.matronics.com/> Navigator to browse Un/Subscription, Chat, FAQ, http://www.matronics.com/Navigator?RV10-List ________________________________________________________________________________
Date: Jul 23, 2014
It's where the nose gear leg meets the nose gear assembly. From: ibspud(at)roadrunner.com Subject: RE: RV10-List: Rusty RV-8 Steel Parts and other problems Date: Wed=2C 23 Jul 2014 12:19:55 -0700 The RV-10 and RV-8A nose gear leg are different.Albert GardnerN991RVYuma (h otter than hell) AZ From: owner-rv10-list-server(at)matronics.com [mailto:owne r-rv10-list-server(at)matronics.com] On Behalf Of John Morrow Sent: Saturday=2C July 19=2C 2014 6:38 AM Subject: Re: RV10-List: Rusty RV-8 Steel Parts and other problems Hi Danny =2CI would like to examine my nose gear for the poor weld. I am not sure w hat weld you are talking about. Is a picture available? Thank you for spe aking out on this issue. John Morrow#40461=2C airframe complete On Wednesda y=2C July 16=2C 2014 4:09 PM=2C Danny Riggs wrote: I'll give you my tail of woe! Last Sunday I was making a routine landing at my home airport and on the ro llout the nose gear departed the plane and then the gear strut stuck into t he pavement and when the plane continued over it folded up underneath. It w as a main gear landing at a slow speed. Prop strike=2C very badly mangled f irewall where the nose gear strut cut into it=2C big gouge on left side whe re the nose wheel hit fusalage and then into the left flap. All at low spee d. Gas everywhere. I was fortunate that it didn't roll over when the strut dug into the pavement. The insurance adjustor come out today and looked it over. His opinion agreed with me as to cause of accident. The gear strut br oke at the weld where it attaches to the upright spindle on the wheel assem bly. Looks to be a very poor weld and not a very robust design to boot. The weld was very small in width and didn't penetrate very deep. Split right down the middle of the weld=2C I wonder how many ticking time bombs are out there ready to blow off the nose gears. Not in a place to check very often either. Dan> Date: Sun=2C 13 Jul 2014 11:28:20 -0700 > To: rv10-list(at)matronics.com > From: dralle(at)matronics.com > Subject: RV10-List: Rusty RV-8 Steel Parts > > > I sent this email to Van's today. Something to watch out for... > > > >Date: Sun=2C 13 Jul 2014 11:23:02 -0700 > >To: support(at)vansaircraft.com > >From: Matt Dralle <dralle(at)matronics.com> > >Subject: Rusty RV-8 Steel Parts > > > > > >Dear Van's=2C > > > >I am stripping all of the steel parts on my RV-8 to have them re-powder coated in a textured black to match the rest of my interior. While strippin g=2C I have noticed a couple of things regarding factory powder coating. Pe rhaps the most disturbing was the high build up rust under parts in certain areas=2C primarily the ones made from the 4130 plate (see attached picture s). This will eventually cause the powder to flake off. > > > >The other issue is the distinct lack of surface prep on all steel parts! On every single steel part that I have stripped=2C there is no surface pre paration such as scuffing and/or phosphating. All of my steel parts will be undergoing these steps prior to powder coating for the absolute best possi ble protection from future rust break through. Additionally=2C the adhesion of the powder coat is significantly better with these additional surface p reparations. The cost differential is minimal=2C since high-end coaters usu ally do these steps by default. > > > >Many builders faced with changing the color of their steel parts will si mply choose to paint or powder coat over the top of the factory powder coat ing. This will eventually lead to a less-than-satisfactory result for the r easons outlined above. > > > >FYI. > > > >- > >Matt Dralle > > - > Matt Dralle > > RV-8 #82880 N998RV "Ruby Vixen" > http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log > http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log > http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel > Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap... > > RV-6 #20916 N360EM "The Flyer" > http://www.mattsrv6.com - Matt's RV-6 Revitalization Log > Status: 180+ Hours Since Purchase - Upgrades Complete=3B Now In Full Flye r Mode > > Matt's Livermore Airport Live ATC Stream! > Check out the live ATC stream directly from my hangar at the Livermore > Airport. Includes both Tower and Ground transmissions. Archives too! > For entertainment purposes only. http://klvk.matronics.com > hthttp://www.matronics.com/contribut============ == http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A /9j/4RMDRXhpZgAATU0AKgAAAAgADAEPAAIAAAAGAAAAngEQAAIAAAAJAAAApAESAAMAAAABAAEA AAESAAMAAAABAAEAAAEaAAUAAAABAAAArgEbAAUAAAABAAAAtgEoAAMAAAABAAIAAAExAAIAAAAQ AAAAvgEyAAIAAAAUAAAAzgE8AAIAAAAQAAAA4gITAAMAAAABAAEAAIdpAAQAAAABAAAA8gAAA2xB cHBsZQBpUGhvbmUgNQAAAEgAAAABAAAASAAAAAEAAFF1aWNrVGltZSA3LjYuNgAyMDE0OjA3OjIx IDA5OjEyOjMyAE1hYyBPUyBYIDEwLjYuNgAAHIKaAAUAAAABAAACSIKdAAUAAAABAAACUIgiAAMA AAABAAIAAIgnAAMAAAABAKAAAJAAAAcAAAAEMDIyMJADAAIAAAAUAAACWJAEAAIAAAAUAAACbJEB AAcAAAAEAQIDAJIBAAoAAAABAAACgJICAAUAAAABAAACiJIDAAoAAAABAAACkJIHAAMAAAABAAUA AJIJAAMAAAABABgAAJIKAAUAAAABAAACmJIUAAMAAAAEAAACoJJ8AAcAAADEAAACqJKRAAIAAAAE OTA5AJKSAAIAAAAEOTA5AKAAAAcAAAAEMDEwMKABAAMAAAABAAEAAKACAAQAAAABAAAMwKADAAQA AAABAAAJkKIXAAMAAAABAAIAAKMBAAcAAAABAQAAAKQCAAMAAAABAAAAAKQDAAMAAAABAAAAAKQF AAMAAAABACEAAKQGAAMAAAABAAAAAAAAAAAAAAABAAAAFAAAAAwAAAAFMjAxNDowNzoxNyAxNjoz ODo1MwAyMDE0OjA3OjE3IDE2OjM4OjUzAAAADtcAAANvAAAS7QAAB34AAB+kAAAP6QAAAGcAAAAZ Bl8ExwcDBDVBcHBsZSBpT1MAAAFNTQAGAAEACQAAAAEAAAAAAAMABwAAAGgAAABcAAQACQAAAAEA AAABAAUACQAAAAEAAADRAAYACQAAAAEAAADPAAcACQAAAAEAAAABAAAAAGJwbGlzdDAw1AECAwQF BgcIWXRpbWVzY2FsZVVlcG9jaFV2YWx1ZVVmbGFncxI7msoAEAATAABCAxAxnB8QAQgRGyEnLTI0 PQAAAAAAAAEBAAAAAAAAAAkAAAAAAAAAAAAAAAAAAAA/AAcBAwADAAAAAQAGAAABGgAFAAAAAQAA A8YBGwAFAAAAAQAAA84BKAADAAAAAQACAAACAQAEAAAAAQAAA9YCAgAEAAAAAQAADyUCEwADAAAA AQABAAAAAAAAAEgAAAABAAAASAAAAAEAAP/Y/+AAEEpGSUYAAQEBAEgASAAA//4ADEFwcGxlTWFy awr/2wCEAAcFBQYFBQcGBgYIBwcIChELCgkJChQPDwwRGBUZGRcVFxcaHSUgGhwjHBcXISwhIyco KioqGR8uMS0pMSUpKigBBwgICgkKEwsLEygbFxsoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgo KCgoKCgoKCgoKCgoKCgoKCgoKCgoKP/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYHCAkKCwEA AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYT UWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZX WFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPE xcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMR BAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVG R0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKz tLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/AABEIAHgAoAMBIgAC EQEDEQH/2gAMAwEAAhEDEQA/APPzPuVuDtHpUi2puFUKAB3OK9Oj+B+rW4GLq0mx/e3D+hqRPhTr cJy0UDY6bJP8cVndGhxGk6Cdn2poyUVgC5HAJ6fyNdZaWokid4jiKP7zsMZ+lXdS8H+IbFBNZabJ O6jDxKy7ZB9M9feqT6br7xKJdKvbZGIBRoycHuTt7dah6lEVzeWyjEJdmxgtVSFgwyB8wPWrF3Yz WynbbTICOd0ZFQICBHGfl7k+tOxNy/bTRFcAEsepHGfapmmRhuzwOMCqdvaqVzk8ck5p00qyOkcf 3R1xTsBZtpZHfZEoDN8ufx5/GqWqWksl7DFCwJUdR97fn+Q/nVibVbawVjEN833R6L/9erGj+HtT 1SMXG9rbzpPmmP3lTnOwf3sjGTwM55qWNM7Hw/pgtIoppbgXE/lBAV+6g6kD36Z+gro4lz2qna24 ijWMZ2qABk5P51oxAKOaaVlYlu7J4xtGTTiwqIvkYFM35pgWM05agU1Oh9qAJlxUqLuNRxjNWUUC gByqAKdR0paYiENmjIpQ6H0NGV9Kkobwf4aQhccDPtT+D0B/Km7cHjvSAj2KOSg/Gq1w9uikTW6S DH3dgP44q1Mj+WSp5HbpVMMykGaPJ6AkZIqXoMyDoWm3UzPcacihjySNox9BXH6tDomm6pLbx2ME kKgneJW+Q8fKTn6nHJ5HIrsfFesppNrGhRned/LCxybW57g4PT6d68l1MiW7aK1cqoz5xLDaeckr 7ijUpJDNS17TIy0dpaxSkDcXZMc+wGMAcVSg+Ic9vJ881zGFHyhJNy/TDdqrWd7faPd3LadPsSeN oZNyA70PUc/0qhBpa7+Eya0SIbO6sviehhIe6Bc8/vIun/fNbml/Eyxu1cywldhx8hwT+DY/nXlr aMWJbYqs3UDtSC2lg+RGQkdjT5RXR7ZH4x0iTlpZYv8ArpE38wCK0bLV7C/I+zXkMpPRVcZ/LrXz 8s9ykhVwgz2U1MLyRUEY4CnK4JABpMLH0cgIxViMeprxTw78S77RZEh1IveWZICvJIFMZ9Cx5x9T XsHhzXNL8S23n6fcZYctExBZfyPI96Vwt1NNBipg4FI1vIvKgP8AzqLdhip4YdQetMCfdTgahVqk B96YjPS7U9GBokumCgLwSQM1m7kI4AFI2Pu5cg981nqa2NcahGCBkfWpvtQI4wPesUOoYHZ9MVJH IUz2GeBQmxNI0prwgkcYIrOutThtkkuLiTbBChdyfbtUNzcEKoXkselcx4tuwdGkttrF5myMdMLj INS9XYLaHI6r4nub/fe3EzmZnYWcY4WPGCzDHfGAPc+1YpuIWIjTG0fwbuCfU+9YV5fhblWkVjHb gn7wAbJ//XVFtSV33RKIgeQoPStUtRvRHWTXFiYxFjZKOrdBT7CEEN9nZXPc9T+Fca9/hug64z61 asdZa3mx5uFzzt61TRG52b6XdlS6Rsc9TjNYz2zBijAjnkEVr2XiydYDGs7bCMFc5BFR3Gp20pD+ WoGPujj8qWqCyZkrZBc5Tiq8tnKHOAdmM/jW5Fqdk8SfJtfHzLuzio3eCf7hzzRzA4syobGRzx84 I5BFV4v7T8OXqanoby2cgbcUX7j/AIdq3zakRrEzmPf0KHGa04tPN3DJ5kZCJjkMGyPX2qXqUtNz v/h58UrPxZGun6gBZawg5jY4WfHdPf2rpbiKy1rUDGkl1FNbKCJoXKjnt6H8RXzfrejSWs32u0kZ ZI2DBk4ZT2IqxpPj+/F0Uu7mc3R+46ylCuev50m2x8i3R9M/Z2hRfnMmByxAyfypA1eeeGPiDKsQ s7y4iu5nP7stOpdT2B55Fd8j70ViMEjPTFUmnsQ4tbnMrOO/NP8AtC+9YqXBJ6kVJ5+0FielQaGu J/enGfjrWKLstkKR9CcZpWvGcbCAoPXnNLmQrGlPLuGSQF45/lXnnxJ1WW2WMxMWjji2hQfvSMTg 8em0/pXZeabiMqSPl5zXmHjuYvZNLgMxugoPooTOPzY0lqxo4G91WW6t47dw26MncS3BPbjHaqIm bp6Cmwo802xerHP0rB1PUJ4rp1ifYqnHTrXQkTJm3PdBkwGIIPUGoFuVi5EhPsayrW8NwGL7Q6jJ 9/pUnmgj7wOe9UQmjobXVZYxtydvc5q1JrO8JtY4xXMpKwAOMA1N9pJwCN3HbigZ0sGpkv8AK/0J OKsw6uwP3/1rk1nZenQ1IlwwPWlYR3ltrBIAbJwc9e9bUGuXKvEYp9kajBAHX6+1ebRXzgBgc+vt V621R93OcemaVhnb3l+hckqW3rlsDGPpWPP4bur2AajbKnzKxUMcFsdvr/OpG1GKe1ysYX0DckCp INZu4bb7NFL/AKO4+ZOPzHpWL0Z0xV15j/DGr232m1JgiR3YJvCgHcDzu/xr6ZEgdVZRgFRgfhXy lpNg6aiLiLDKrmQp2JHPIr6d0e5N1ptvNgrvXIBOeKaMqiscQpbHCn608M3fFVo5W68fiKss7IcO o47g0WYriBVxjB470ELtYBmX8OlS7GVQzROqsMglTgj1pFKMMcc1LQXK6OyAoX3ZHJ6ZrzzxVazm 2uftDvIquGRV9BgZ+vI/WvSXjCngVzniazWbT450TlJSkmBn5SMZ/Q0R0YXPGbG4jtL6OWVd0ZJD D2Nc/wCItKmtLkuAXik+ZZB0YetdNqOk+TczrDIHSNuDuHI9vWqWJ1iMed0fUKwyB9PSt0Zt9zk7 KKQSl9pCqpySOKsFSAfU+tbDwyEFQvB6gDAqrNAu3kcA8VRJRUt8oDGrG87wuc8Z6UohAxhSfSkE TRybiMDFAFlcHjNSiPgVBGwLHHNTrQO5Ii44zU0ZZSMVGBnjNWIMqcld1IaL8Fwz4XIXjGBWkHMM WBk8YrMgVck8qewIrVQAIvfioaNYzZJpepxWt0jysFiz8zHtnivpDwjL9o8O2MgwQYhgg9a+YZrh bWRD5HmkEnbjrxX074IgW38JaPGquv8AokbMJBzuKgnP4k1KVh1HfU4uP5gcVaiZCp3ZJAO3B6Gq qZXG096v20bff2jaTt69DVmR0dvPa2mmAx20aTGNCVlYqzNnh0J/HpXN+KLZ1kGo2YljilJ3Kz5I PckenpWvpcBupvLe6jjMK4jEwyD7DNRa3ftqOnJA125uQWDJsCpt9Mjr0FDJOQj1S6Q8sH9mFWo5 ftkUsUkOElGGAPWqiWpVsEc9K1rG1I+Y4/Gpsh3ZxGu+Cbm3jae3jaeLqWRclf8AeA/mP0rlY9Ik mbalsZTzuC53D8K9/gi+TaAOnJqZ0UAuqKrYHQdfxp2Fc+cJdJUTbSHRechl6UqeH4pVZEMTY6Yb BP519A3en2d2SJ7eKbPd0BNYl34J0S4JItmhY942x/PNMVzxWTQWhG7y2CgdMZFZs2lRu2duD35r 2a4+HSkZtb91/wBmRf6j/CsS78B6vCp2pHcr6qRn9eaLjPLZdMMS7lX5fYVGLQ4ziuuv9BubVilx bPCx7MCuapravD8m3IP95aLgc6LaTPyjNPTcpwV/Ot2O0RnxhSfY057EAkhD6gDvRcZlW1w2/bjP 1rYim+TJA6VmurW8pd4cA9BxTzO0aZkGCfugd6m5ag1qzS0wxXWtWVtJE0rzyLEgXrliB/ImvqyC NYYkjQYVFCgDsBXgPwe0N7zxMbqeDItF89mZeY2I2ouemeWOK+gkHHHWgJM8tgde5q5FIpwBxWJD P71dgk96ZJqyKN3yOWHX0qRdu9WKyMMfNjqKqxy9DUhuBtPzkf7PrQIpSIPOLDuc81etYsgdqpk7 nyO9aFpkYoA04YyB6gDrTnIJGOlNRztxnA9KOSKZJGQSTjGDTdvPPJqZlAGKjNIBuAKTqeKXHFGK AGPGkgKyKrqeqsMg1mXnhTR79SHtEhb+9CApH4dP0rWxSikM881H4a3UW5tMlhnXqI5WMb/nyD+l cZ4g0TxB4ftjLcaTMsZYAyIwdAT0yw6fjXvcZ5xVkxpNG0UiLIjjDKwyCPQigpM+UpL+6VY2ktzF 5jFVLc8/hXongL4ZTeJhFqeoStHZBuCOGfHoP616bJ8P/Ds86zfY9hU5KK2VPtg5wPpiuts4YoI4 4IY1jiQYVVGABQU5EWhaBp/h60+x6bbiGItvck5Z27sx7mthUJpkI3cZwcVKVC8A5xQQeGRMQPSr 0EuKor0qxD0H0oKNRZhjg1G0pNMToaQ9RQBagyxFattx3xWXa9a04ulMRfVwB6+lODE9KhT7q1Kt MkdikIzS0negBuOOnNNp570ykAcelFIegpR0pASJwasxn1qsv3hViPvTGW4z+VTxsQc9+1Vo+lTp 1FAF2OVgCQBkdqtKVI7knvVNP4qsx0gP/9n//gAMQXBwbGVNYXJrCv/bAIQAAQEBAQEBAQEBAQIC AQICAwICAgICAwMDAgMEBAQEBAQEBAQFBgUEBQYFBAQFBwUGBgYHBwcEBQcIBwcIBgcHBwECAgIC AgIDAgIDBwUEBQcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcH BwcH/8QBogAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoLAQADAQEBAQEBAQEBAAAAAAAAAQID BAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHw JDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6 g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz9PX29/j5+hEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKR obHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hp anN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/8AAEQgJkAzAAwEhAAIRAQMRAf/iBVhJQ0NfUFJPRklM RQABAQAABUhhcHBsAiAAAHNjbnJSR0IgWFlaIAfTAAcAAQAAAAAAAGFjc3BBUFBMAAAAAGFwcGwA AAAAAAAAAAAAAAAAAAAAAAD21gABAAAAANMtYXBwbAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAC3JYWVoAAAEIAAAAFGdYWVoAAAEcAAAAFGJYWVoAAAEwAAAA FHd0cHQAAAFEAAAAFGNoYWQAAAFYAAAALHJUUkMAAAGEAAAADmdUUkMAAAGEAAAADmJUUkMAAAGE AAAADmRlc2MAAATYAAAAbmNwcnQAAASUAAAAQWRzY20AAAGUAAAC/lhZWiAAAAAAAAB0SwAAPh0A AAPLWFlaIAAAAAAAAFpzAACspgAAFyZYWVogAAAAAAAAKBgAABVXAAC4M1hZWiAAAAAAAADzUgAB AAAAARbPc2YzMgAAAAAAAQxCAAAF3v//8yYAAAeSAAD9kf//+6L///2jAAAD3AAAwGxjdXJ2AAAA AAAAAAECMwAAbWx1YwAAAAAAAAAPAAAADGVuVVMAAAAkAAACnmVzRVMAAAAsAAABTGRhREsAAAA0 AAAB2mRlREUAAAAsAAABmGZpRkkAAAAoAAAAxGZyRlUAAAA8AAACwml0SVQAAAAsAAACcm5sTkwA AAAkAAACDm5vTk8AAAAgAAABeHB0QlIAAAAoAAACSnN2U0UAAAAqAAAA7GphSlAAAAAcAAABFmtv S1IAAAAYAAACMnpoVFcAAAAaAAABMnpoQ04AAAAWAAABxABLAGEAbQBlAHIAYQBuACAAUgBHAEIA LQBwAHIAbwBmAGkAaQBsAGkAUgBHAEIALQBwAHIAbwBmAGkAbAAgAGYA9gByACAASwBhAG0AZQBy AGEwqzDhMOkAIABSAEcAQgAgMNcw7TDVMKEwpDDrZXhPTXb4al8AIABSAEcAQgAggnJfaWPPj/AA UABlAHIAZgBpAGwAIABSAEcAQgAgAHAAYQByAGEAIABDAOEAbQBhAHIAYQBSAEcAQgAtAGsAYQBt AGUAcgBhAHAAcgBvAGYAaQBsAFIARwBCAC0AUAByAG8AZgBpAGwAIABmAPwAcgAgAEsAYQBtAGUA cgBhAHN2+Gc6ACAAUgBHAEIAIGPPj/Blh072AFIARwBCAC0AYgBlAHMAawByAGkAdgBlAGwAcwBl ACAAdABpAGwAIABLAGEAbQBlAHIAYQBSAEcAQgAtAHAAcgBvAGYAaQBlAGwAIABDAGEAbQBlAHIA Yc50ulS3fAAgAFIARwBCACDVBLhc0wzHfABQAGUAcgBmAGkAbAAgAFIARwBCACAAZABlACAAQwDi AG0AZQByAGEAUAByAG8AZgBpAGwAbwAgAFIARwBCACAARgBvAHQAbwBjAGEAbQBlAHIAYQBDAGEA bQBlAHIAYQAgAFIARwBCACAAUAByAG8AZgBpAGwAZQBQAHIAbwBmAGkAbAAgAFIAVgBCACAAZABl ACAAbCAZAGEAcABwAGEAcgBlAGkAbAAtAHAAaABvAHQAbwAAdGV4dAAAAABDb3B5cmlnaHQgMjAw MyBBcHBsZSBDb21wdXRlciBJbmMuLCBhbGwgcmlnaHRzIHJlc2VydmVkLgAAAABkZXNjAAAAAAAA ABNDYW1lcmEgUkdCIFByb2ZpbGUAAAAAAAAAAAAAABNDYW1lcmEgUkdCIFByb2ZpbGUAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/9oADAMBAAIRAxEA PwD8S9Ina2E4kjZZDwzDoa3be6S4f7QrkyxrtVmGMe3vXPJ6nY1+5SM+5kkikTUWy07SfNgYzU3k T6md0cJFvnk/3fqaEY2JJNPbzEBbCHg98Vr6JYWMC3YdCJHPKhuuK4q6/fpnHXpP28JHQvAlskMi ryDn3pkE6yOUzhDxmqtodlJGi7EhEWb92M4O39DWPc6sYFUrGJGUHG046damUfdNDMgvSSLgQOzZ 529V/Cuk09lWVryI4c4Ubuyd/wAaqCtCwUqShUuLeTRCSV7dsyEY3EZx7iq8YfyIp1Yi4756Yqo7 HTS+E56/mguUZzIpZW3fjVL7VLdWTQIcxH0/nVIufwmJYTYvgY2DeVyCD1Nb8ckHnJeLNH546gnn PtVP4jCJLJcFyTKm6PqPQ/WuWu44jhIzgnljmhq7YzI1eFkgSNwMOuVx6etYN5PDJapEZASo2hB1 PtXNJXkmc8/juYNsszEKW46jPaiWKW6vzLJLtmGMEjrVw+NF9DYtbdJIFgaPD7z1P3hVK+Ji8xYj ufocc4FQly1rmu8CtEl0bWNkZBPux83SteytLUM0tw28qc5B4Bqp6mUFaQ9WspHIE/70k7FP8VST 3EHAER3p91s8N71Udy0gijF5AJpEbIJwP7pqpFaWr3Sz3mdqjCAHHI9a1gSzS1KWNkVYQXReTgZw axmtorayWZk2/NlFJzk9/wBKdTRE294qwXayXcS+cF/iBbvVXUme6m3Mcj1FYx+M2vY5vU4Y1njV Z1ZwofirNnaG5QyM6CQnG0NjIrsTs7mEviLenyw2fnCUv9ofjKDjA6VeQLES+CyAdawl8TOlfw7D LXbetLHcQbUXklW5XnrW1YWBuHDPKGt1zs2jB981io2IWGjCXP8A1+Ysvl204EU587p8vYdqo38Z neOQrxnqeM1oiHsVZkigi8qGL94555z71k28LXV5DvZVHIYscAVpD7RL+ydcEksfmVwcDkY5GKw7 14ru7W4uFxgYxWqZp0K63AWRpIVzNggr2YDsaqSrby28xkyJAe470+ljOaE02wbebgduhrYsLawu J1jurxorgthVQ/N9R2z1rNiS1L8kaWri1s2JkZsKx5PHT/eNadiktiZ/JRfPdMDngn/9dYS6m6+J F5tSeWdGvVzeRKNh6H2x7daitBfXl1dzzLt2kHkYrKMbMqvUconX2MHnkIgzgZIA5NTWWlMNQChi xI3YUcgVcdJI50j0/SNAS38u5G7zj1DdENd/a6eiSwSRvluuO4NKXxFN+8dTaaJdXU6RoWWQnIYD JFeh22nPbK8AcDd04q+xqtimNKjHm+YzefkbFB4x3z7/AOFdLodpJaQFI1+ZslSehrR7Ex3NmHT7 iWRHvWVmI5ZOgrqtCiKvIkabvXnBqW9BPc7OCA2uHcnJ710lkYYgt1I+4LznsKXQh7ksM6XKNGYf 3LNktnk1yl40zXE0JbB3ELt9PWhs3gQ2Mb2pZp/mG44KAkEDpWvCzzu5Ujaw6VyPdmkVqbVhpi3L rcyyHYinAB5b/wCtXa2bfbYgqRloweGB6GsWa2OjsIUYT+YMYGDz0WtW1tbaJI9ysLbfgkHJxUNk yFDoty8EWdoJZMnJxnv61Zs9bSTfIzfvo2KkHoahrUdrMt6lrFlDDatEcz7sgL1z/SuSOuXUs3lJ DtQnBYmmkK5zctyJIbmDU1BhZjvyPlAPy/ka4vU7eBnhFkrMmCH3DJ/h2/1/+KqorUl6qxraDHcN gp9/dt6dDXp9tGZQ6AEsq9F60pDijtdkKx2y+WVQffyelTQ/ZrZ55TbszKpKLnv7+1YtWNetzmdY keT/AEqSMmYjHHGEH9K5ZlM8aLG48589vT5q1ghXOfuZJLeV/mB4x/un+lQ/abiJD5EZaNj+8b/P auqCMmJtjmc5jIZhu5PWrSq6urAZbPQ+lW9ySys7Al0mOemMdKhiuWR3gnx5qjcWAwDVGVzSsbyG YFJJMDPyg9624JMo0LBTCo3ZzzzQKJ3WkxPcRpMSyuqYCjv/AAitOFAWc/N5qMBIccGkW9iWa22S G48w+ZwUVsbQO/58flXIa9ps8ERnQBfMkZztUcuST/8AZVa2sC3PN9XspyjtGTvXuK8u1EW7+bHO 3mZ+8uepH/oNMT3Ofs7PeNqM0UCSbywPOe2PyqO6YzzRRhd2X6Zxmoe4Pc0TLb2iFrSMqzts553V LFNHcEloyXHXnpSW5DReXylwVnG0HDk9UrJluJDMcMfJEhK8VoiTPvE/tS4R2JU/dFc4+npO04nf KK+CueuO9SwLVqIEmMkjZYjbuXjAHSnNMwiljAwZe4PPBqCrG3qSCW6T5GWXj5jwrAVRlsYrlzuy Uxn5Twxp2FcgeMxyKS+dg2hcfdFUpEaVGklJwf7tSxMsWsFqgjlQ4U85Bzuq69pGgluLl8liNmDy v4flQkZ21HJaLePJFcA7oz8oHG361sRWLMm2Abmzzz0qkxwW51tpY+XO0skeF2jZgfer0HTtMjfj eTvAJOfy/CoZrBaHo6tHDGoJw0aDYGPJA6Y9a57VJnmia4wRNnlQMBqRfmea389xLOswYblFc3qF yLgFtw3oeR/nvVR3Jkc85Eu6cPidMhCBnHY/jjNXtMADPA8irBjLMzc/h6nP8NactibnQNAY4Ts+ ckbRirdqskW1Qhx1GO9IRlyQGGd5wC2SSF6YNVFjcnYiFZTyCR92qQi1Z6fFEkSxk7ixDZ/irqtN toIFWJkImZ+Fz29fzqXuUlc7PTYY4mlW5fMajeOCAfYmultre3iuIZCCcYbYSflPuRUIrsb+n2Nr bRR20XyyBCnUnPH+1VgaW37va7B+ucdKfUpDDYPbGTcu4uMcD7319qypp2SQwsmUjTcSDjBqZGiK juk8HmMnzDjrVHzvIRJ2yrh9pOeAe30qlsIqjUpTc+bJJv8AkKbF4GCd39BWoksM9gHBYJu8xc8f XNU9kT9mx0VvdPJJaRqh6deMD3NbrX6bswkM6dT2JqGy+hMpLxtHuzNIDuHGFz3HvWHFD9mnRAkj WzZw6EYz71G5dy5IUt9nmMQWb8hWRO7yyzlcqxbrjrUWM+pALpljeaQbXJxwKxJNTZJ5oIn+8ABh OY/u5PXr1/Smt7mb3uQzTzT7sLhc4IzkkU/TJ4nkS3iTFqh+UE5JPck1shs2TAGmaWNvlEm0ev0r qrPTN0UjyTA714UVsinsPjtZCLiNRgIm5Mj71czPKLZWAcqWflyMgetEiSjdSKpkhHKDo4PDe4rg dUtzIXmk/wBVyM56/wD16hkPc5N1+zSKQxKEY54JFaMN0zj91lAGxyOlJbj6nXWEiS28cqtzkhsg 4Ug1oW9h5Ts8jZYsW3L0GaHuWiGb5wEWUDDYJHJWub1e3dHjlclvL+cqgy3A6gd6Vijlr4Tgb5kP mbd2c5A9BWTDsE0TXCHzD82egI9fpVW0A0bRQJZpM/6OfvcdBXf6VEnkwNEpZpCSePuge1TsS/hN y7i/0f8AfuSo5255H0rnp/KCREODJzxnkYpozlozMhknDszSB0PG3HKj61sWMfkuR9o3YJZQ3B/C qKpqx1NhPtCxyI28LgfTsa6aylSG2E0kG52bGxW9KiRtE3w8T+XN5hEO3AOPu1zWp6Z9qkEcDSfZ 1BfdtBIB/wDQjUxKqO7Om0q2SG3JdskncMGvS9O1K2itIUjX97gbz2U//rzVL4TP7R1NrcTXHlSy L+8PG4HA9j9MVPcSpdW8catuQvvBGMfXP4mk9gOU1SxD7UjcsoO41xd/ZxRojSA+VL8gfPShMbMe +kht8QQglsY+9nZ9fevPdSuVWSSDPzgkHcO/cUyEcTrEH2hmXyh5bpg9zXn+oW0wUQwKeHz83p6j /P8AFQC3KmiaYy3k0saFzIu1iDwnOefxFep6LbTrakIuckjgZxQmUWJbYMzYQrMSByeM/wBK57UU eITiYgsmd2O31qZbAeI+LNZRo54GBYEjjPoc14ndX0hvEeJ8R55IHA96T3NIbkJnt1hFqLhCVzsA PrXnep6LN9uaea4GyQ5x2X/69SbrY56P+zI1khSA+cWwHJyFrxrxZ4Y1zUNTtxE5EW8lSVypFXHV Dse2/DX4T6layC71yMyKXEiovCw49e5YnFeg/EWOPTIEtYjiN0DMV9e4rpi7amEtT5+8K+BLnxHr f9kqI7jUbuTdDaM+wJGSoJkPpyOnrX9FP7HXwbPhuw0a01VZPKmLyRW7kFxj3HsSnT+GuXES5Y8w on394++K3g3wLYTXFzCkFzGpEUquiCGTocDu2T94V+Vvxs8RXvxMvrc6he2z+FLSV51htYtryBvm kBOeOcsW6/Ma4VqmdX2jP8E6t4JsbUw2zq9wgRlto5fuhex717va+OtOmzd4KREbQSdzfgBXm4he +elR+EWfUbV7izukQupkEZccAg9DzXe+GdLk1K9cFAYAmBnu+en5Zrm2NUfQ2j+IF0GBAR+8jXaG HXBOTxXpGkePQNt08eY2XEaHgoR60Gctzaj8c6nq0ztDf5LdVKAZ54H0FJrniia1sGna7P2vlm2r 82B1wKmSM1ufJ/jD7TfCSSaQNCOQijG0Z3c18x+PoEtU86KGU3D5KlSCGwOePxFK3vDT3Pg3x5rO orORDZK1rtcgl8nJPOR/DXzvqcTSL9rDfJkliOhr0cJ8Rx1j1v4M+DF8T+LdKt7aNzcrslXYwDqG R/nGeOMc/Wv6AvgH4RbS7DT4gkJ0Z0yiFPndxkk59M5X3JNe1A8yTsfYVjJ5ZYshCnqe9SyFxGbl 0/dKD0BJOPZcsTXQjnYm3bINsmI+jEjoatx3TLMFuPlVR97H3vcD06VoMdbXe2YQxyBkbLZHR6ma 6ETkMCBkAjacZPv/AA9KRLVhFhYpNdxAnB6Z+7U1pF5sas7nzi5JBGCaGJblhpXyLbYoh6ggE7ff 6/40xInS4V0bCdfr61BS2EvHnMsDtJhU+73x/jWoQrB/OU7SNrIf5UCaI/sxlkDsoMZO45PAq6JG aKOJU+SPO04z1pEv4iEqH8uEsQhbgjt9adJ5UDyTPNuSMgDjBP0/vc0AaIYR5YgjJ5z6VnqtxOAb jCMDuVuMsCePu+lAEWGW5Ekr/ugcg44xipk+beycrnk0Ej1tt24S4KE5Pr7VLcThZVIc4YbeB2FR bUsdbCSMmKSFlk3lzjkMMdvyrUChVEJB2fe69Kcd7mnUsLGFVCMAdvenK+0vEpxIOeucVQiVUMrQ rHIAkYIbI+8TzVhY1i2LIRvfC7jwCf8A2WqTFEjnhMSEmXEinciYzzUsKGedm24Kpt55xmnuMcwV kjVuZlON2ew7VYi8wbfMPBJ+b0pAWoFjdpiQfMJyWJ6UtuPNcsszRqvDEcM3fj8aa1YCNbM7v5ZP mNk896maz8uMeQCJmwZA38WOxp31EiBxNGixxjnOW5qW3CLIh3ANkKQT1qVsMe6xTKZSTsD7d307 1cydoKTB2J6gdRTTJkPtC6XpKDPmNiQ7cDitdESLzSGJ3cD/AGaX2h/ZCCUKzDPzg9xzVGR7kSBI Qyu7j5uxHOR0+lJhHRFxpXhjVBAOD1Hc0+VURFhd8zOA+3bxz6UhhArx5ReMDqO1NkWePEqks2SW cEDqemKAGCTcrEKTjg7VPB9z0ptvc5uZ4o4MooBjkZOUPKkcjNAJFVcCUbWxKxzgjkE9R+easspa ePzCT6c0ARxxuJwQ7EFjycce3FaUcabHiB+Utu5PegCYx/LtJ6nIz6092eOVIH5cqG4H3hSYuhXl keO6UtJ+5A+6AOSaqy7ZJY13Zc8datEE0lu7bo8blPOFfZyOnOGrPnNz9qtrsP8ANEv70O42uMn+ 6i0GZHbXO1FWM5YgvuA468Y96SGf7UfmTEoyHOeB6UI1W5CIVaZkNwBGDzu4K/SrHlhlkAbcv3l2 87hSsVLYn88ymFJGIAXHTO70odoPJEcZOFz1x8+c8Hj3oe9yCtjaA4T5QcNg8qamgdNpycop55xm mthrciuGlMcuxlyB8nOSBRbPO++cghyuCjjlfaj7Ni7lj7kYKxsNw3Esc5+lWUBjmhIjOAMYx1zU tEtjg8SMJVJCDrgZIqKd/KxKXOAxGcH5vpUpaiLBkK4ySCOnFVJnlPzP/rA2AmOf88VS0GmL5paQ EIV9jVe5u5rNxHAQXdeTt+YIeopSGx3nC5SGcB0Q/Lggk7xu6bV/nxUsKtLhQhZQuT2FS0SKm4SA 7cAcYqRJUiYpCu52O7avJOKa3AjSEWcQ2RqCzFioVAV9iEAq3bXKqjrIVUjBUEkZ6+ze3XFWtwKx /wBKCSKW2ZxjA4x3FSJFKXaRpPm2hBu4LAHgD+9yaQIVYnjaaQFAdvQN94/l8v60qlig8tgJsbmD f0ppXLK6s8bbpmxzgZ7U5Va5AWRWznrjAGK0RRJErrIBCCfXP8PtQIQm5Ezj0JpAi2paNAsYJ9BV WSMShTI4jOT0OcUxIfF5rQzQzLmJ+NwUEjHcA5qCMSxzT7Yyw3YAIxwPpjb+lNMu5K0YaMIU3MBj jnHFSom0BYoyXB+970OWli76D3efKwXUxaMnJ+UAUlzJAuUDkjOBgd6Rm2LbpcK5kkjj8thsTCYx 6kn+ImpTGWkRgmWH8XrUoga05i3I2dvUUiJ5wZ3BwDnOKnoA0wxM43H5V9s59qsRH7PKzYIYE9fS oluNFT57hJIdoZXBB4yGB9qfJArRsVlAdDjrnH1pX1AmR/s8EKxBGUElmK/eP17d6dbXxVmBQsnJ yP4fega3LG6OYmTB3twGB6U6OJYS1sD8hG4nP3jTtYuIrXHkxhBN+6Bz0prDz2DmNDjA3YGR+NU9 h3CWPy9oEh3A8YqdWkQFpRk5wKTIZIrzq33PkPQ4qR4kbDvzk5OOgouQTs7pCXU7WJ2odmcf55pW b7Qqkn92Fzkdc0lqMf5ZWCRVbr+vr+lRLAksRzJ8q8AVpuS90OghihhKwRAR5ydoABJO4n3JNQyw F1cCTa23I2n71NoguJeNcIzSE5AKFWABbH9KpyxW0SMY4Fjx1IXBkpcoBHDGEYMR5LEEgnp71oIr RqqAhkQYQjoRkn+tHKaIN+AP3ZKZxnOTn3Hbt60yRDIHi3ERPgthUOfzBosJbFtZfKRogD5jDqel IWJ2hj9wE9KdhMgwHBCsMfXmlS18t1DMRk9aEiSZYZUcFR8q9DSSwR7o3hASYkg/7WetNFLci8+N EDo2V6Hg9qsTNuSItjJxgjoQelBQ/wAuQRghTjuT0pjEsu9j/wDWoAgE5XdEUJ3D6cVO8cmzhsA9 27VMRiZYeX5Cgp1J3daV9rSPIw+UdMHIqkSyKSJkcSRkFuox3qxGzvcRq0b84I2oSPxPSgg08gZX qvX2NOhm8uRgp56gYNZgPm2XMrHA3H+EmoNzZ6YGeOeciqW5S3uJLK7IAoOFGOeuKjjTMbMzgI33 hUlEsohUho4QuRyUQDP1xUYby2G3l/4cng047gWHkVVYN8ycgkD/AOKqpG0sa5jDAN8yAHK8/wD6 v0qwexdhXzlMruwuDyWTtjofmrSjgWNo3yWlf7zsqbjjpkgL61aehk9i3DH5QkOeW7envTYolSYv 3NJLW4RGM9xFM0UifKWymD94GrSPJNkAFcHFOQfaI1jVpPKYfKTnPcVM9qVWMkEA5w2Rjj9f/wBm pW4PYdHliVxlTxiqk8cG/BYnJ5X3qxrY0IIWEeXGVUZxn5qIyflGSFHrQ9hSJ8oYiAo80nGfXnjm pUjdditnjnNSlqQPkDOrKB2w2emKrriEbM7mPzcK6/zpWASVjFIo6xdSR2qw0asXkCJ523aX2jcQ O2fTk0ARNKTkEjA6Y7UyNmBJUY780AWHlDyKqxnA/WozB5hUyFggbeCAnBwR3DetNbk/aJmVGYbs n06Amo5E3NGwPzA9/SqH9oTzHZ1ZpPmXPGKduAInVMdvXNMolgj+8ZTgYylMNshmNzGDv6HmgRaE abZDu+cdvSokO5QARgnmjoA+QuqSCI8gcE/w02NtqMroNpzx7UDEkG1SYiCc465qBLws7QTKNwOR iq5RH+UfbW+ozSzxzgMHH3lA4/8ArVpRaZdRREqqsynkbsbh/wAC+6KiT0OmXwpGebh1B+0RAoD0 Ycn2rrNMTNoqwrm3OW6cKa0RCRWKz2pMpQeVv25x0qWKaCxlnkW2Mm1dwBbG0muestUyaqXJzdiW 410SwGKaEEuPlK9/pTbN5DZ5SLawJwpOTQ1oOC0Fmv3kC20MLDcG+YHOKw5YJgj25GyPOd2SSf4u tQ37pZfZxZW7xRQF7p+Q+eMVatBLFAI5Zdzdfx70J3RpFN6mvtgiK7j8xHIrK1TWEtLcx7AwLdRx iqjsaw+E8/1K7tw8DA7UL7jg/erNfUZbO7DW0mYG7EE/WqRUvhL+mTwzNcuFww+YjuauzLZJmaJd 14RlVz3+nrVP4jBE6TGXTDM0gRuhTPzEf4Vy800F1G3kyP5w6egpN2TBnOanf3NmsRlDszcbm/h9 MUW8CNBGrHEz/MJPXNc8nblMXuOu4jDC6wqpuT2zjdRBAYlhEysT97Ldq0W6BbFhYJ5Zh5EgwxPA 6r7jtWvHawWluTIB5mcZI60rXlc2jojnAi7nj2YOeBipYNPkS3cNIREOBmm0QtZEsVhawo4yeF65 qS20+4lgNzEenyjPOfrQtzRIntreRmaRnzAv3z02mq3lzGdljIdCcgEYraApI2Ii9vIkK2x3McsQ RgjtWPqnnXii1gRNof5ieq/SieqEl7xz9zposVYSE/aRyuDwKoTwCSwkKSZlAyoB5JrBbltXM+1t lCbpF3MeDkZx7U5bG3sbqDzpz9nOSyg/MfautK6MLe8aGbWKZoY4Gdiu4ZP3TUFi8kmolQG8rbkg 9FrOXU6F8J2RtRcWsiKwOT8wXg4qgthIIykLuuff7tTPSJUlJxsKul3IvZLkTZgMYGCDkEVea1lm KrtCyEck9D9P7tJHO97HNn7T87ED720sMfLRNYWg2SuWVQM4J5NUvtCa2JpLl1iPkr85GBz0qAWq W0AkmfL9ef4a1TH0KF1ciwCShf3bNgyYyFp0gjvx5xA5xjaeD9afUTLqXYtlijEW5F4+U4zVi0uE ZJiqKt0ZfLVX+8c/yH+1UsdtLmxY2zLLLC4PykkMR39K6COGCN4UuZAk+M4P8Nc7+0aJbMlxDbu7 yIrAfdZhnbV3zVuNpjtjGp69P3n+Ao3YStynT2+nG0S3kiGCSp2966jTra3iZbjDf2kWwOMqR7Ud jPY9H022edlV7dsn7uO31rsdM0gm8iaQ4i3BeO5qZCseiWdilpMlyVfaG6jqv/1637qAphwML94b upq+xaehdso/PkhWS3Gwc5AreuLKdZYcBdpG4hOcD/2WqewdSCXKqYWGF9e4rrtBWWRIMMgOOMLz x0zSa0B7nYxzedFMJUCqAAR3aqcWPPCRFjF/EOwpE21LJvre3iXJxsY5APT8PWqaTxmSS7kjA5XY zYxzUtmkCGKe4RZfIj+bdwxGSv0p+lRG6vhKxAKP83YN61g95G8dz0NIo7YqkABhzu47V0dlbsr4 t8CMN8yjuTWDNLG9JAQAsa4bGOe9Mkt/siGYy7pB2Hf2qGiWYy3kiStIwO9Tgtipp9SjRFfA3jk7 ehppaXBu6uc81/O0jmJiZAOcHlW7VaETKTm4BXbliG4qkiR975Um9UHBQIMjIYf1rDh0+7d5V8h/ JGGLbeMe1FtRrVnYaZpSQRCUAIwPJPFdppEQcsWYLyuzAzvPOc+3FRMqK0OrgeJ9tuihtpyT2qe4 OIpkK5XHQDms2rldDhZSZPtcQUOpZwTIoOwHjAz7VmXKxJEoUhVTrx1rWKMpM5W7tTIWWV1MnDAK agltzZwKItxRyFbviupIhshgZjEiMrLcMxC7h93Hr7nFSNA4gmfdiXBwCeppvcmTGNcPZxIqqGZh kkish7t5LoBT8x5K9SfpSRnJjYtUg3GRiVH+1wRXX6HdSW6zGaTKSchT2+n1oYr2PR9DvXnmEqTl YVGAuO9dhAvlyySxMRFJHsKK2FJ3K+fl6nIFNlvY2fs0qwRvPHtDLkMeQRWBrSJf2xYLmQDKHsDV LewLc8R8XNAmnSCOZo5Sd2Qc4P8A9evH5IS+9mbB6/WmD3KlxbsqGO2ZQpGJCecf/XqhMf8ARXgm GGz8uDgn8e1Q9w6kAYnbCxJZDuwDxj61ZgnA8xnQ7SPmCnqPrQtgJkmt5MMSChO1l9qkRXYLFbQ7 UDZx1zVmRKto0qSpKoKk5GO1ZFxEEEkaphFAGe5oaAwr+D7KqSKcqxxwOlOtmNtuuZ2AYHCEnlSf b+GoNS0L7e0GJCSGGCeq+4q/9oSBZTGBhssPr+FGpNjJjillhkllJ98HrTgsXkNFCxJI4B6g0MTC J57dlUQA8bgGGcmuit5bRp4QxMc74Vdx4JPHH92k3qZdTWtrWwgIt4lJuHbBYtlmOa6XSIIBM1s5 QGTgYHIxzUplwW56FY6f9lS3kB3n7yLjkVsQRvFlyOGfGD1FJO5rFaGyJUe2Te2HDHaPQVzt8262 kdSwjLFdxPANIf2bnn+pLBBBISMyKpI56ivOtxM8k75KDkgdWFaw3JGw2zuQ8xKpnjb1WulsrMzW 8YhULIB8xYcn/JqnISibdrFKGjijGc846b61diHPmDZzhlXkij7IcpB5FuYmMMW6UH5csTis6OB7 byXlfczNtAPahCsaFpZSRzTSBSbZQWdlP3a6qCyKiN1Q+YDu9xSluO1jW/f25SQwnaxA3dea6OCG J4I5wrhic5HQ1CK7Ha2NifIS48jEgbBc9eP5davToIlN1IMAfeA649cUS3GjNu5EnbcJAIsbhwe1 c5qStcwtIIx82Qdox1pSLODnupNNkmiEmZSwBDc/l24ps975lusK8KD5jD+8apbCH28zRKZ4kWRj 8oDEAHn1/hrdtLhZXNuqgwq5IkU/K3p1qnsiPI2oGSXzCZAj/dDg4APv6CtXTvMYxpNICuM7lHBq Gir6GlcxtNlrdxDDF9/J+97ita3QRwRqU+XqM1L0KM2/XzmeLIDAn5Tw2R1GPxH/AH0KgOnAIrRq 4AHLbuh96VhdTNvLKGEtdq29mXy8DouK4qaciZ1KBdvDEDqfQ1SjoQ9ip57BZTGVSfBOCeX+n0pN PF0Y4VYDz3fAxxyapAz1HTEkSKKeNcbfl3EcMRwf1rrIA8e2F4wFYZLAfeP/ALKK0TKexkanNDIk 8CjPVN4428c/jXLR/LDIVKsiDJ3Dg/WmQYEsdxLGHQBYi3zA+h9Kxb2FZSkQIKAlhnvxQyXucvdx G7w8aZKKFLMOqDOBn2qOG3Zn8vYR344LVK3KW56FpVparbtbBsl+rrxiuqlskEZMaqq44XGM0nuN HO6rHaRQgFhHKVILBS2T2+lcUYoUUxzTlnbIXg5zVFnP3KQCQxSElVO3A6k/41BaaQI703G37hBX dzn8KOoHSWGms9xudQFPATGSTXYRWOEE0YxMp27R9KnckgvzG6LIYz5i/fbGAK5MS/aJVuFiCxbv lULgAdz9c00iHqxsUDS3BnjOUXqmOtXBdeZ8uQm3neR92mXE3tGkHlTswZn39gMD3/lXUWMjvOPl xGBkZAIJFQyjqrYgoYwvBPQ/56VHNp08lxDJHIwiU4ZWJAcemF4bpQEnpc27XT5o84YKRzhj1rcE kMKr5HzN39DR9kX2i8b66lmt4Jk2KozuTIDD355rahuVlcwyXYGBhUOAGNTLYoS9ZGcLyTjJ59O9 cNd3luwmeNSyK5wvQHnqPakmI891PUmdGmgmRmztAUjqD/SuTcBvMYthiew71RI2PTZXibCFmduO 3GcYrIvdK8uNI1OUXJ5HNMFuZ9pBaWY8hECXEmX5bqB3+ldpaBJMx2LbIDjcev4GpbLRpXGkLcQx uYm81CWb5sbx7+2a858SPElvOfLCxHJJx6dj9aUtwPmDxMsVyZESP5wcHPf2rwfxHfTTxraWV40A jfc4HDN7E9h9OtJ7lw3INB00FxK8qlVJb5mPzE1o6rpt7qUyWdlbuU4dmXgD2z6mkbrcpReCLpIW l1SNraQDftYghx2BK/0qr4X8Fah4o1yTR7C7Dxls5bLbAPv5GOnpVbMJOx9aeKotJ+EHhmG6s7Rb vWlwkCb3CmQjJWX8fm3Dn5q/P3x/4z1vU7qaaYrHNJKcyYxHG5P8Cdua66avG5y1JWPRfgvqEHhL VrbX59XVtSi8phLLGBG3KkgA+v3efav0hg/bCMEEOkaTqsCX7QpChhYIR09CTnP+1/wEdK5cRHm9 w1h8Nzmtb8T/ABA8a6jcTXF/LLpSDzN80x2rIfm6ep4Ufd+7Xz9418aeKV0dvD1jeKDuLLPIg+XO clAvXGdvPrXElZM3XxHceDbmS3msns79X1NoA0hQHYc//Xx8tfWHhXzLi7F3rt0q2mNqqgw7P9Ow rz6y1PRpu0T6D8PWdvdvbwsFktM7iCAwOevB717vpV1pOjAzkxJEoJxkZBx6VySNbmHf/FXSIpGE 2mM6jDLJEyEf5+laFjr9vqsZ+zudow2PXNKJL3PYvCcc5aFbhcXGPmxnCn+nFdJqsQmUGU8oTjjr TsYvY8g1rR5XnuLq1kVrQnnJIKH0Pt6NXzJ8VdS8P6Ntsp7mOdnj85nRubZ/oBznI+XvUv4hp+4z 86fHN2H1i/vLNlKPITnGFZB7V4betJqF2bZWUSO4QBgAMk/416GF+I56y90/RD9kj4YxXN4dXl09 xe8I/njbkKeANvOCMr+dft94H8NR6Tp9sudrRDcqJ8hLnOR047fNXtRPHqOzPQZUwol8p403YUMo DD1z685+aq7RvDiQHG/jgVsjFmmkgFrkhfNUZAb+L61WebMcR3gyEYYDpWgXJo4ITFtZY2G77joD j/vrpV6SOQPMWGUU8E9GFIG7j7WQW7tGSfKkQbTvwBkn2w3T+9UUwOFZE3/NjKnbj3oZPUszLKrx bVJQjLZPINOWNo9ufu9SR1xWZa2H/aAbsqAogUgpuALPw3t8v4Yp6eeQZJItw6YUdB680Etl6Jle MqrY2+/Wq7NMlyNzjySu0AdjQJkoAMpKh8KRyp/4FT7mCRrdoxw/Ue9DAuRRPK8i4zEyjOTzn60Q OIolzkjOMv39qAKaKbhHMpAQHtnmry4Cgwxh0T+HpmgTGpdFWVdjDcdhUjO3Az/D/wB880+BGV5n z8o46UNaDLiFkInC72HBH93/AOvViOIPJvx8wH3QcgDtRYvqWIYZy2HICg/QCrUyIZIVjGZCCDhT xj1oGRyNG+HSEb1PzHJBxj0/z96pWcJGjyklN3OO1UkA+QBWdJAd2M5z0FORXQeb5pCH25FGwFjY 8oRicBTyemBWiURYg0SjOO54YUiWRBYt6rA7byNxypP609lAkJhZRkZYE9P8mmtEEizuVHVmYhxg YB4zVkiDzkeSYoB2Pai+o0UrlZZJFCAeXu4IXnp6+nFVVTbPK8gO4cNnrR0GXoFd5FOMQn36VJJD LbyjyW2qeASBwT9aTdiZF6CIybSD05IFW2QqAI+p/iz0pB9kR1Kjcy4fripmT+IHL4yqk4DemTg8 U2HQkEcUQfcz7sfIMjH48VRkizIpUE44PtSFzE7JIJAc/uRyMdaWWKWUI27HY7Rg+1PQOYVIJEju UKkRP8v8Hz+x4Y4/KmWqMo8h4hG6cNgY3H1pDUirOrJMigGNcnzG67uhxVpklKoyHKKaoY7H2eF5 JSGQsMkDFWs27NGI33fN8zAFfXj5hk84qSeYkkldkkSNCVHBPekhgSJiEXM+75y38sUMp7DrhEMj Kwxk84+8KptB5rGXycbRxgdapECM7soUgg55qKXT7d0EshJYrvDDIRvTB9am5DM+UIg3gqm3PGwk evRaeG3RrM7YfbtG5sA9gP0qkaLcqxxNL5jEEOTj515OPT2rUSM7FJUrtGOO9VYp7FYySxE+bH8q 87h2q0sETK0wB2nI2kEfoaT2IKy71DQzBFiU7l2nlsn6elRy2KSBowSFP3ieQw9KlbDW4qx7ZDH1 Jx29KvxvEcyqVZunykEUXC42OOZsh3yPvAZztqZvuMAPlBxnOOc44/GhiG7nTZGiAAkn5uB7DP8A 9apJSkny7Tjpz2qG9RhGGO3IUuDklT/nFNltw7xs56NnIHI/zzVbhsQIfM85BCzgAlcZ+T3pJNjM yTKomx8r468NweKe4FeKK4yxiZEx0zn8a0pNvzPGcKeDznNSwQLEDl0ch2GMDkkVGIoiVWJTlG+c kdKa2AW2YNczOwx8pjCbH55+9lgo7ds0qxvFMd8IkLcog7fWqW4/s3JIC8sDSqhXk7QPrTi87b1U /vCP5USVgRVZXIOQTJjcfQ0rMyXEToAc4B7BaE7FDmk+0eahjjaIqQyOgO7NRgmK3VSpC9QQehzV AixHIzBlfIbOT7U+ZY4kcsSXZM/KMkUAiN7eZYSqOGTAyVyOhz/So+H3RMBuH8Oam4rjY2FowhDS DPzYkfcPwOBViBJVMkgc5boQP0oTHcY1yIyWaPlvkL8DPpVtCkaFpB85OFOSKp7F30GGItLGyqxc Dc24nH4DA/rUqwl/MKxjzS2fu8fh/dPWgTFnfzvLWIY7be4qdHPk+UijaD1z3zQSVHUqWKx5IGcC mws0qMM7QO9J7AWUfy0WLy2E+eQRjFPeESuF3fIBzjrUS2AnEdrGieWo3R8hgTnOOv8AOqkYEaru OW75FTbS4yOXzZTIRGoiXph87vc8DH+7zTodmz946hz8uAMZp8o1tcsxIYdyeWNp657Um0uRvHyj oc4okykIVikccY2e3WrCxbEEgHyDJHPJpvYCVIwVTGWJJySQdv8AnNOkUoTtG7b6ChkyJoJwxm3M AgOMgUpkBwiKdvJJPoPQd6ViQjVGMoVxsHIJbFQLJPLuiVChHPB601oBdWWJUaKZDHz8j5Oc/wCF SxrGNgDZkIOBjH6dD0rTYT3QzLwIYNxAJ+YHgU1gHhm2KxYEqOCCDnr9KZJHHDmZHaTgkZX1qW5V srFJyvUUCJltyqqRtMY/gIzu/OrEpDo24/OBkKP4aLjbHwxoyIyqGOOx4570n+skiiIKsflx6/Sk NbDpohExfducnHB+7UDxMfmyQe/NO4mWTGioHUKXwBkUkSO6q8mVBJ49aExEyBcsC55OMY6VXXy/ PXr5e47Tj7p+vakNbirb20UcqBi+eUJ7U2SJ2VIy2EByPagssTbnRVRisZOCQOcVWmtjiNskoRkA HB9gfWkAwwM6RHPIqULsTYW+c9B6UICOF1tkBJYgtyQM4zRnd1OIwc4poUixES2Qo+bsD3pbaP7O XwD55OMkDJGeAfXGaCC3KsiodxyFOTjiiABUUywkn70eeDz8uQfzrMCcSo/lspXchJ45wfb3pwYO VbPU4FUtxrYJIp8hGQhSdpI52/WoQsQGxhiVTjDAgNgUFiiLyV++SnocYB9uKRYDLGLhFGzqCT1+ lPqBEkz7FPl9W4FXhHHFkBCXHKrjqaYnsX4Y1XHPz5zgDFWPM+8WBKDrgU09DOWxKrRq2RIP57qu uhG7kZPtVJ6XCJG3mRqqpEFLYw+evtUSedEXBVvIY53Y4J9qGH2gUlctnpxk9aWVpJYImZSilskE 9KjoEth8W5UDKhO09AetTs9vEsbNCTNy2SAcVoNbD0EhJYELnsScn6cVHFbzrvkZSctntwKHsKRO RuEboqBic8sRkfN7U3zBtBIIY+9EdiCSJnhzlTspzqFuFyoLAcUkBIsQJDFwPUYqtKrGWNopCGBx weCPenYB6qVeRFUbgTgk9alEGcwiTEhG71qAHQKYgecsODSNIqtICwEYGRzznvx+VC3EQ2nmQOUc blJJyasMAWYbDg88GtCiNohK6tjawNPaQAspXAHtQIf5IYRgDaSc9OakljhkieNwefQ0AV5Yg0QV T8/RhnqKdEoiKfIcjvjFHQZO0eVMozyD345OaaV85Av8Q9B1oQCYWN2h+XzfUtjFMZ3lRY5I9zZ+ XAziq5g0P8qWd7iP5xalcfKVHWmWlw0vmI0w+X+A9RWDeh0z0Ni6szcW6p5GW9hSnzbFYI4Rgj5T n7pP/sta9ASKxuZZYwoAypycjrTHiePzpZEbZImCOufSjcd7Getj5qR4GZV5IPpV1GngnMXl/M33 QT1/+tWbiJbMhvJ/KKqIGLn+JDgL/wDXqCXUpJPJH2dljZtjbuSQO471lJaDLcolbAC7ImHLH0qa 8S1MId7kt+7/ANXEfnyKFsWth9wzw29u5Y5dMLnk8dK47Xn/ANFFvtJkODwcY+taBF6GQyWrQqJ2 DcYGTWLFqEc0j26LhF+UHHAqkat6It2kvk3joWBZR82OuKti3liRru4AG8lVwfuj3oZk9zF89kkj Q3BEBOOtK919n2RSwlEJO0/3vepbMmtQuoXniQSgAkBhxxiqmnaa6zEefnkkY7VBFveL5tN19bgp tYnblecY71Lf2cjExXfble30qupRLZGzhc26K/nABgB1NRvEMzCVCVHJyeBTtdlp2H6jZx3Ftbz2 6lWUfvNvaqtrpV2Yx5t4oiyTkg9Ow+tS+olubT6ZcQxJH5e63YZyv9azikunzwxBjz0jPb3NSjVF 9LG4aOe9EZZZPkZM8KR3FZcipF5YkB3A8gHk1pBiaHaj9ne2eUOyMOVAOcfU1h2MqBVLvnD7Qe4/ zmrkxL4itqV9CztbmM+duwSOmKzTcwN51uWAkxlGxwaz+0VvcxJnmhzL91s1asYY7nbcXp5Xldve tlqjC3vFyK5RLh2i2m4P+sGemPQfw1e023WadncMideOtJ7G0dEXbeSSynKkFlJwcHkDtW9uRfLe NTuJxgHg+9L7JbelibULyOGS4EbhIdq9V5zisBbkNbxzeaTGHPJ4LVD3MLamW1tC3nSROR1OwcDN Z8s0wYBfvj5eenP9aAsSwW6B4mnlO9SGwD8rCkup1mt777Kx8wAj5ux//XWiCxiRy3d9pzwORwNr ZFSW9jsECx3IORk4/pV3K9mjq4Fa00+GKOJWuQxZmbqc9j9KfZ2MV0Z57oKrn5RtpdblPY7W2tkW xjjVW84N95jnce1XLu0MyQSMihgMZIyR7VhLcDOXTJpp28tmdD0x/D/n+orttJMUOLOO2Z3VPm3j oaGtRHXaek7RsZU2lCAnHOK7iO1nNzZhbcuzyhDhRhfUnd2ptWM5LlZ6LZ2QaaTyowGA+8OB+VdP pFssk7QB1JjG5gc0CO+treOXyt7EkkA4rajtFe68tceU2FUEZwaEhmu1hBaI9qVCzA5LFu3p9c0y aRYBboIS0ZG0hT175oBFQCNJHDR78noexroLGeMqEV8Op49qGEtGXtQnuCkEcLEJn5sHG6p7bUZI lVFiyq8k+9T1CwqysQ0s6AfN0Yc1eX95HJFJDwy4AI6Gk2aJE0ELeRGJVZGP8PWt+yVfszYhMi87 VHUmsZM2idnpUW2MQtbHzn7OM+X/APXrrLJI7bkx7pR2BrA1WpZvZpBEZEX5Ry3qPpXM3V95sM48 wBgOuelMnqYFxcSSQOQcbVyT64rCtb3zXBkk+UngitErkt2NeFY2X90P3hbAYnjNO8xY5BHIrDH3 qdhJlkafcSPayx3gKfaEYp93913Hv+ldfaIjytGgCxhCck8cdvrWbWpaepYhglMwkSM4U8+1bFq0 YEnlYMhbLMvfFZy3NEjsFuohB+8dQo6fL/hXI6hqZjuxHFcFZB82Dzu+lKKuE9jJuZ3eDzkcCRWD kDgms+W5jkkHl8vjP1roUdTnkyncxI589GG9fSs9r0R2twSrHDDKqcbiDuwfatY73JuPKw+duI+R hlSDVK8kgsY2WN9+8/dJyaHuSznbu5muT9lzi3P3iOv51kCWSKSM/LsQsB6ke5/ipGb3GzahbRSj YqsD82wjkV0VpdqLuOXeJMKGVB06f/XotqI7PS9Tng+zzSRlXLHODw3+FegWGvOrLlRjPOOop9So nQLf+dCRNe7Yid565Uen6Vzmt+IxZQLHZ3CPuJJKeg+vTNIrc8b1bUp5HWWUDbIflXb0/wDiqxLp IGjVoSrSAfdHUUDOfnV0BYKR7HvWRcwNLjzWCntg0CsVTD5ZTcjYHBPvUcEsUbzRK2WPP0oQCQwb JZGlnXJAyuMEGuggtZNwhZ9uPTqKDM2hbWu1be5lI3gjcpxt47+1cfqUDrdBmIMGFxgYxVMEtTPu kQglXOwjIrKfbBG7SuCGxsyM7u9S9DQhBmmnjzGrAEMeOCPStyWUeXvihJzxwcYpLUDLJlmRbZSB BnO0DvVto/KcIUIcAc07iLyuy4PmZJHQDnFX7SHyZ0lDNkkH1II9Paov71yeU7K3ggLxyxr/AKSx wCRkD/4k12GnQQpGplh/fj/lqCCRz0/KpZSR1RuLWCO2ETlZVPyknlfw/irQW7t7lwnmLuUZAHUf Wg0jsY+pa3b2cE4t4We7VtibR3zyTu7DmsXUJ5mtHRGxIf4genvVLcJbGVcndApPBC4Oelc39gXB H2dWi7A45+lWQRtZurNI1qzDGBitfSrFWuBIxKtjBGTk1TWgjoDGzXB2KM/dHbFWYrOGREO7bIo+ YHqxNNLQChKn2W4KhlJwGYI2duex98VNbxwSN5ip945CMccD+maloa3L7xOsU8akhGOFCjv9e1bt pvjyzKXdANqjjNIEdLAhkZRJCVhI5Xv9a1IbR1WGMuMBjhAOg7c+vWoS1Cx22nKYkmJ+dWTgHkrT nJmnGyNmQgckcAf1pMsw9Tni3rbxkqwPzAiuB1jV4raZ7ZCxXZ1VflHPc+uc1YkcNeS+ZOtwAADg AdmpsrOm2OKA5JznPFMRaijchYtrZzkY6E1s2k8aJESnK5AHegRs20Mks4LDC9Np710UKmAyrv52 YQD1oA3dPjkliCSthz90E8kevvXQrZgssRBPbB9PpQPc3ZIJoSkaqVYgghh1B/pwP++RXPakYrby 4QW87qxx8vtQI4jVZreNBbxzDdIT8pbJGMZz+Yrj717a5aRBDlozgnJxTQzNH2YzRxtCTt6Y7fjW tY28MuZJshFPGDjHvVB9q53ekzfZ7fykgUW0YygQ/eP3ifm9T81dDPeXM1q8Nq/70AEqBlyPagGz jrq9I32kzn/pqU6j246Gs9QjSS+S5MLAAgmmSU/tgheRX2uithV9KJoFedZLc7ZNwdSTtCn29KRK +IwbiN8MWhIQjngDFQxRJFApCncTyD1WmNux0ehTJDCxuA29nO1c/dFb0FxHPLIGZgmMDB6+w96T 1BamFcMI5Ad2Vz35NcpeBIr0TOcuXyoP6CmU2c5DYrFOJfM2w7y4JySznGOc/KOtdbY2Md5cwT5d ZYz/AAcA/WgTdzs7exFtJmO3HzsmWz93149ScfrVy4s2OShKMCMcctQCMa5ga3eWJ3U7fve1c3cR tNdqkUe4sOg4ApMCFrV7ZJEWM+YRyM0tok32aV5bYfMcE46j0zQ3YpGjbeXEzpgrjkLzmuq00bSH lHydfpWZS3O6023huXS1uF2s6kgjqMdB+VdXDo7w2qytDuV8jg7sfX0p7sAKsJIfLTK4CsD0pxgE UU7Oo2R/N7gf4UwMqW+k33EUkuYVjyr4wVP938zxVS5121sVgSNF37RklgQn196hjRx9/wCMZ5Xk Hn7kByuAMnj9a5+/8RfarZSXLsQQV24K+vFSSzBmu0DoxQs/90dR7fWr9pApdyZFUuecjnFNbE7n RWotRHNGX2qWJUMfmUemVrkL+9jiSaNZgZt5CEcjGf8ACqKWxhNvvZyi2y+VGQ6zAc89Qa7axtUt oIUxjd8zEd6BmlqF3b2kElxcXuxF4KEYZs9APXP92vE9WkXUGdZVbymclMtyuOnPrigFqzzLW9Ah uUfy0JcZyueGHfNfL/iPwtfPqlzMsivZMwICjDAD5cH8t340mXA1dK0WZjbxwwHyiMFgvp717VYH S9B063VYlbUl4VOSJSR945qOp0I5C28J+IviTrNppmiWci27TPHJn5RHjbznP/sv/jtfaekfCvwv 8DfBc9xq89rHrbH7TOJiDOd5+4CPQHbtFN7ilufn18YvjHomuaqbW51IJEn7xD5MpDJgAH5Qf7v5 Yr4/f4pRWGt+Zb+RJbyXBVN6bwUJ4+nauiDIWqPSNPnOv6pGbu2O2Rh8kYwHJ7DH3a/QH4C/AHwZ Nq8d7cQTRvBBGwMp3Kx3fOB/ePXLfN0FZVNQifXnxLn8E+FtE1KDSUjzJCRHHGACrgHBJx0r84NZ jn1PVGlAVNOjaTLBsq2TkYrjexrD4jp/DGr2+iajFNasszLhN2flYdcV9C+H9dtr0NcSo63Acrgn tXBUWp2p6HumkeMJNC09JIOL5QBHEBlGz3J6L71Ri+IOr6tPNbaiwWKebOFUBs/Ve1ckkbxep3Fh LC6Kr3ABLYbjlfwr2jwsB5ym2TK8eXjq3X/vnFSgk/ePrTwu9jHp489z5+flVcZxheTu/GuZ13WZ dTe5tLK6VrBfldlUE8daq10YI4DxJqqBFikmMdu/yJGCTv8Ar+VfAPx81e10/wC2fZJGEcmUYMAp Zx83X0DH+VL7RS+E/Om+1ue5kuTe3bqjksd54CZ4H0r0T4UeDrrxX4qsorWBJdivcEuTsWNByW9u RivRwi985cTrE/fP9n34Yx6Bp1lJNaoT5eJJFUAShcYPPPJP93jmvsa1iiRtqyFwBuYkc59B/dFe vFHkMvyBt6ybwxOGwTxinFp5UUOOM8cVoZvYkQDzEimfJJAOOq1WkjdCPMID+g4x7VZJpwhJY4nd MMuQQTndUyrtCJcTv5JyGYHDLzkEf3gP7vcUxshEEo86O6A88neSiBEL98J/AM/w1PGrzsEkBGTj 8v8A9VJhexossgI3YAPAqQAPDNHIMOR8rHjFQNMrTmKGGJfs6icHLMGyX9/YVZjuXuLeSbeAqHvx gE4Az/Ec0E7Mmg3SRCQDaCcbiMDipHj8yUTKP3QxhCeV45zQFtR0j+QZpHXCZz9/p/nFKsxuJxMV GzHQnA+ooBasiEpNzOUVhEhG0E/N056VbRlikXLlmAJO4cJ0X8+aQEbKvzCMZUDoKmt2kVcwvtC8 kgkk59unb+dUoh1FA2OzLy7c805o8oHjnCEn5tx/Qe9SBYtxJAipuBUDhiMH8fU0+JGed7lolwoC 5UD/AGvb370FbSLtvsjcrkBHI796uR3atOY0yWHHGKCiSNleRwUCheox0qR41bPduDgn0qkBNBHH I6tKcc85GOKT7PPHI1vOEaEruTYxLADuePp60mBahlCIqou7LYBLYBHY5qSAoGkkd/3OMPuOAc9v zpEPccr7ZxHHGzZOOueKutGZU2RJHHHGw37QFJz05oESNbyCSNlxwuMg8f8A66hkilYK7Kc46HtQ WncaYY3hImkIfOVw2CKeQBtw2V+tWmMgUPDLIqBvLI3fQ1cR/NQrIpCsQfqQd386UtRdS8IV2Rnc Fwc5Jq00floXzuXG44NIGSxFLlBKM7SMAnvQGeIRxt8wUYz1yO1NK7uQLLNEcBiM8kA+1HfaFOBg 7iP0oS1AI3lkD5QhB90+tW1ZrchGBWUAkB165/3qTAqENLtkkYrIvGQeDg8UyTZI6nzSHHXjvSDq IwZsvMoPfLDqPSoIowROVlcAHgN0XNWviGkWLRXt0kjERkT7wZm4Pr96pF/eSRsqZh3Aqc9cUnuC 1LUjxFlVTjIzT5ZAjQSxjnOWBOOPb3zipKexV8x5JT8wMZOWGMYJP8qb52HkR3CgHufvc4/qKZAx 4mQ5aT6Z4xWW805n2tHmMPkH04pATSRpLHgthshj0z/9amfu4VZZGDIASvAIFCGtwbYNojUKg5Ge M1cgdWjMUzctyMHA61cdCmQbt9vGFXMTEnPOetTrH843NyBxzwKbJaFMcalllGYnGQxHaoHEPDNz GvzptY9RU7IQzDI800EZUZQhGHXjmpoVhVHwp3k/MQMDNSNsevnDayf6oKSx4wuOx75qZSHAYPGy ltvJzg4oESnCyoHPzDpSPtlVsyYPSgAKzxNCc/IeMkf5/wAiovNJYwmE+Zzk5oAYqxw/aGxl9ny8 9DVdn3Khdi0rc8CmWPWN4kAkHIHJzSRNHLEJo51W3BPWkMnhkjjdB5hCPwcHIonlQMzgYVe/96gh bkBv4EUSODuyBg9D+ParLxuJgYvkiG4/e5+h4amWKX2oM3CqIwI2yQQ/8QIP4/8AjtPjyqszqRg4 560ib2ZEWlZEZmzEcqCoPPP/ANamiGSRImAKQ7QwUgHfkbuv4/pQUSKkcSrIQDtPTHShpFBZ0XOG 6kfrWi0C4rhZD5m7hu1RW26Lzo5pN8obduC4UAlsDp1oHck8/wC8GBUdge9WLfZMs0qx7do64+9S iZorQRInmGWBC5JIOwAn05p0QdN5VztPUHsfaoLLXkwTQCFwSW5yRjBp8x2Km9cOvJXPTFUBI0sZ jXCESt69qlDqiIAm4Zzz2NNO4FSA7Y5gyZlHzgjkiorfESCcNl8liXOFYHn+EGmT9oc++U7hJtKk HC5y341MciMO8o35+c46ipkPcYVCurqmSOf/AK9W4nRI5JX5OVwCR8pqRmYjKZjJO20O2Ac/e+no KekgkLMDlM43ZoGhkrbdkSvtVmxgDOfU1P5G2N3MmAMY45X3oGt7loJ5ZKQr8x+YnGBj/gNPiJ3S xsPlbAB6YplDzbPGzKMcc59aRpQFTeSCziNQBgHJ65/hFFyeYkikKqrFAFPGc4qWUsoOxW3Hg7T0 /GkSRxxsxEb58wjPHcf/AKqmkiimiCISSp9elNAWY3jjQRyLlFHU4AaoUBCLKJSzY5OOM57f3aFu A1opHmDPJuKjd7U/zTGGZg24cDZjI+m6rAcxN4WwmFHOHPb60BXkceYgLZOOPu/pQBciZUwQ64Bw RjmoZJ4pPMO05XgZHB9xTRHUljkmCMoBYZyqseVqTEokGbcsrD04FBSfQnWRGRisbL2PGMVAqmKd LncCMFTk8rSB7FgSp5mG4Z+54BqGZUMgilcgA8lDQQV8N+8VTh4zuxzlh/hUyyF8lWLKOOD0b0oA nVihG4YBPpyaSSUpHI2wshGcKcH2oGtwg2usjPbHgDLnO1s54zirbSoXVFQ7FHzFscn0oKe1hE83 dsWPZEO4HU96dKbeVo5MsAOqgigXMQxS4RhnA7GlKCTI3njv60Ioq3MqYeaQ/MQFGfYbQPyFT21p uiDysCWOQPQUCewiyhJpFVD8oHPUVc+WZ42jByvPOfmNBBMGRVd5GIfdjae340oCqGMcQXjOBQMV IPNwwGTnGaQfuiFYgop65wF/GgQ6CZ4pmDFjkfeY5/A0/dHOzMcCRTyDSSAjKSAMCRuPTJ4ojt2E UwJ78DOKobJ4Yii8gMw5GR0q3BHKQPOBB3bgAMNSER/Y5TK006FO3PU1rRlWWSM4yTgZ54oFLYGt 4t4mdhvXoFwRVh2Ah2Ecleu7kGqTsTHQqxAqoWVmLDoCcmpJXOQuCpPUH+Gh6j6j33MVUbNmPmPO Vqt5W1hJ5pZumCBgD8OppCZajcOMk8rUxZAGJAOeKaEJHGSBgjcOck81M0spjZQ/y57jNWNEcaOJ CGQgHp61K0ZUAMMID+VA2iZZY5D5e8NjgihioKjZ8oGB82cYoRJFM+7AU7cHJ4q5Ey4ZcfKOeO9A EVy0LM0ikibGQPUgUkU5YDMJEu1cvjj8P1qWgHwsFcr/ABDOc0pCNtJXAzk8U+gEjHdhh92oPMn3 ExKu0dcjrTGP3GRyuzaT70jhSGLHoeeCc+1ACqwaXcGy3Tr0qSZH4bP4etMBAqlVwDuz271Y3EIV HK+pOakXUgAkk3BDxQqt5ixkEqDnrjNMY2NNqLEXLBeBk5P50okELFRCWwecnFWgP8pW4uHXfAZG WXsM5B+tUjC9u8AkU73OdwH6VxN62OmWp0SyvB9nkSZnYnBCtnaB6/3asl2uBdZnBwc4bv7CuiOq BMyVlSB5fMDEngruxirI1Nfss+T8+Pkx/CarYJEyzJbRR+bchTKOGzg5+9ilhuEhljaQeZIwwHzx jtzSFDZi+Rh2mlbMWc4zjHvTpRa7JBLDh0Bkzjrj6VlJaFmZLfT3EOZIQIjwuTyBUkDxJE8ijnHG ejGs1sUtjM1O7middxy2Nwz2rkr7UMks3+tHNamN9ClFqEVzFhE3zfxrjhfrWa01vbXWxWHmH7vP KmqRunoi7D5b3B3SAXBHODV0Xd/FGItmVOR8wyF+nvUkvcqMwdVKLypx0rLvrmWR0jRQcHnP8qTY mtBrXiwyK8oZlAC8nj8Knt7l4ry5u7JB5LR+XiT5thPUj39PrUkPQ2bO5mWaOaTGAc9etdCj2+rv JFNCysvR/Q1XQQLa20kwaAbblVCkgdQPX3oOmwQkPISjg5JblW9KtaIV7mjD4fazguJvte7zQGRS MBapQWlw1zH5cKvFnaxB4NQ+pS3N6RZrJkWaD5ycAHrWFqWlvLfpfOcKeTxgJilE3RR1LUBpLR6b HlpC25iByoI6n2pmo2Mdvp0NwLdmllPG9sbDVxiS2cxfxSFI0ziI9R0warixj+yuudu0b+ON1XJC Rgy2kM8jkMQxHB7VBcabm1Lq+ZFIBxxmokaLW5l6m083lKqKAvYc1rafaFkgU4WXuGHWrWhh9opX FvDbX6XChjaIwMjdSM//AF67CRhaCNRIpDDeigcqPehbFN3iZEYkubqa784fZWPyY9e9a4u7KCRW kJ3dMA/yHc0DbJr28tWhkikTdgA72PIrkbuOzbyfmkZ2bAVGIUY9al7itqaLRpDAWmYeYfnUDoB2 qhBYm68xwzbuoGeDUIdw8ow5baTjg570kMUku5lYCRupY4rS4WJVtA1q1vGRgtktjG4mtGDTo/Lt vttp5flAhD0IPrRf3i4xfLctWVpHFKryRySQkYO08NXUSxB2hxZlVxxlcfrVdCXsX0kkS4awFo3l qgZcnOSfStm1sZpLCZrqbcw5BAx+FZy3A0tEtmCTQxuV3kLkgHd3xXXW2lpblfKOZSPn5yVNHUR0 1tYlLYJcRrlv4W52/UV21is01yCbYqBjoPvcVT1Ik+Znc6XCrzMoGVTncOhzXc6dFHaiaYWmzd3I HzVBJqQ3ETYIXaM4BJwM12WlxbozLKMfMMPj8hmpuBPqK+VIY0AYkcZHWqjB5cTqmCoCsOvNWWiz bafJI43qBJ15HHNU5rFpbg2boc+3ApC3ZqRWkiYilV/Lh6YbOR71DLLG7tJDIwUHBAHp61EtyrG1 ArNEsswwR8w3DJxjqK07HbcyxRxM3lFvmZj2+tZ3NEjqra0w0akHy8kN/tD/APXXS6dbQROssYUK Dt46VlJmux09la4usbunPPYVsvJFEjGJQ0efmIOawuPYwLzUPOee1CBI9v3w5bd19ht7etctCkhl cykMo+6egatYk9DPnniRroqqmMjDhuQOOaxY4d0cMTwlcNkFcjNbJWIbubenswlXeNwztwvetv7O kbl5JFbcNqL7+hpshM2rPTJHwSu/ABJ7CugaMR25/dqGHzllXArN7m0HdkUd6oKrCpOeuf61etUe KJiSGViX3gYDevHpmsZbXNkynd6zJHDOjSbEOAeeTjmuWleRcu2SzHcPVaqKtKxE5aENxeYkh3Sf Jj5sHAH1FY91feTKZPvj7qBTj8fet1tc5pPU0YZJDCMOACfm9qqT28zNmIZjB5OcVa2FcmuYd/lR 26EOBzg9RWfqMc80UKlcKm5cr15/rUvcbObvleMyIX2xgYzn71czezO2Nr7kQZG3+I0EPYrLKrRR RvCTNnLAfe2dyPpxWxa3clnJMVUMGYeUuf8AgR6etWloZnU6Lqdw0V3DdTExA8cfMn413FneSW6k Iyszc7sdB2wfzpPYuJXm1y4i2DzPMDnkZ+UVzF5qt5M7R3C4AY7Mccds+tKWhRkXDPchIWba4bIO aruxaRhHLiMHHTrUl2Kt7cQlFhD5fbnH8XHXj0rl1hlVbp5nJABZOfyoArHzbZFjbHmd4t+WUfe5 rPN5bRSrJAS0meR2FCEywxFw68AO3PB6V2GiytLujmT94oAyPT1pkSNaSG3EhEzEjrtBrIv47KeZ WEh2AbdvrTbEtypNZWbKEC/NjqTyK5mXTXu5vLzttV4OB0560nqUTW+mmJzDESIB83mE8k+lTyQB 2aN4mxn5WU4C/wCNJaDLUVtBbSIfJO4fMCTwfwpbyKGZFkGRN125zQBjRtNuClQSfTmtu0LLJHHI +McA/wB361HmB1+n743ZnPykcf41om5eCVtk7ZI/h52+9IEzRTU/tNuzzSIJV4BzgH2+uauLefZI Emz++cbQPX/61IpbENsfODGXKnqcmt6JbeW3MZf5s5VhjitFsKW5gXCyrfPEVPlqeAed341Y8hZi JZE2cdhzVCNDyoYvLkRQQFzg81nrCJGZ0RhIcttHUAfNmm3oI17W0iC+fesSzKHG08L6GqU08khj YE+WpxwP5009bAVjEEdiACTzgj71b1psMFxBH8pcDf2Jwc/lQxra5bjhJ3RRtmQjgdya3oIVYRnz EVwed3GfpUjRqfaI4XI+xzIpGxnfoD7VY08ldyLMTLlnyT0+lRfUZ1lhcyQI7mTcpPOe30/u1cuZ PtIGxx5QYHA61LKRk38scELTKgZwMHj/ADxXkOuT77pXL7fm2yKVOY8e38VaEnOQSNHKVGZYt2Q3 TH/1q0o1L3QVRlByeaZJs2sMjssucKHwBnrXQeRMVEaiMylh86jH9KANGC0uYZNtxGByGBB5/Gte O1895POJD8bAh7e/6UAdTp2nGSYPkl8YDZ4x6Gt+3niE5nJBlA2bMd6Q0XJbhTBNdNJjYMZ7k+lc BqbRJI8kb4d+SrNnB/8AZaBs4q6mjZI8Es4JLbhgJ+NcjNeQM++ElQ3X5vvZq4iloTQRyMgkjZQI 2znuT7VqWtw4kKC34bB3nuKpE+Z01lIkKTDed+M/X2pLjVrYqQ8skcyDJfdj6c0A2c+dRhkQKrOZ wCMuQC3/AHzWJJf7nW1jnKSFsNk9R7Uibm1bwCOKR5cOMZyBzxV17uD7MZgwMQXPPSmgRgW9wNQl eMllKnLDBw4xxj8qtK0YQOWCJn5jjOBTKtctxpGHBA3rnIK8h07GmzXkdvK9uEbd9/fnI5otYNih eXiBRJAwJLcjBzWKGe7lYsTsHOCOlIaRu22mLLColXcO+a6zT9JhghgRHct3JI+bn/CgbVjrbaLz QA8O1h2xyaU2P2lgsTDeD3NAkY97pyXDuAu3aShyOcj1rEl01o0JGSV7L3pBIzryKSJYxMpUP93c Ofr9KxGeFVnRpmC8EZPAqW7giraXqznYitIS+z5f/r16lpiIsqDyflT+96+9SV0PQ9Dt5LmVXjtG ZySqnHC16jFoiG3Kgg84xnkih6K4yHUdDiijsJI4RuUnqCNw9/7xyPvfNXFa95FlD5rjAaTbg/0o A80v9SktkmiyrTKQHU/w8ZA+uCK8q1nW0uZA8iHcuSFJoA5ZLq9nmW4VZBb52kDkL6c1s263bTkM y+SBwWXlDUy0BlxVcSqWQspP3hjg/wBK3P3a7d8bBcULYW0SteagqRuI5ShA+UjGa4f7fPdYaeMB h/Cp61QLY62wWBIIy8oG5c4rZN8q20aKD6AA8rxTGcTrepz3Pk2oP7qMlmOcsx7D/ZAH/oVT6TpU 94hkuAGiOcDHzZFBS0ZzfirS20fzZHjQu4OzIByPUf59a8F1DTFmuBOxJ3enepkUhtwfscapKmAo 24HUexrV0DwDfeJZ7Se3vH2yMUXCFgT1HK9P7vPfFZ9TZbn6K/C/wV4c+CmkN4n8S28e82vmiOUo WUYPz4P32J+bjtX5S/tbftWL4kvNZ0vwqRJIIDIODlnUMgjViGCk45xuxuH92h7ilufknrXinxFq 13I8kMpN1K8jwK+7B+917Zz2UVt6JBdW9zY6pLa4kjkSTy3Hoc4reDEtEfWHw88QJqd9o0SoVVrp G2/xdenv0r9fPg7p+o23h63luIZI7iOUzGQqdqCTO3/dO0GokCPJPjhdafA15eNrm+88wNHAN5bC bUypPB4yx/8Ar18iX3iV5LkJCrlC22VVPyyDtn/4muWexUfiO+8P6fPeXUUzk7cbEi29Hz1r37w8 lysiQNGwl+99a46i0OpPU9CM4tLMPNeFgzZdJZM8DC/IPTp8orf0K4028nhvYUMs3BidXxtOeuG2 8dGDVxyRvF6nrui2F1dTx3c5b7M3zLnjGOMGvpXwo1olrC9vB9zAHufr+dSohe+p63LqEFtps1y5 2SAAE7sbc/KP1rgZ9VkjEwV9sTAh8DnFVazIR5V4u8ZR2yFIo2muCcYP3Vx2P/1q/Or4y+IdLv5f Jj1ENMyH5cudqH5SR75Sot7xX2T5asNO1HVNRddQEa6YvMaDrKQRwSD8o/8Aia/S39mHwJbaW1j5 FpAfNBZ+p85yOD9ASvy/7X1r1cEuZ3OLFy5Yn7Z+DNKk0zSbIsdzLHGrDAOCFAYY9c5rvHtoVdfm 25Odo/WvVijymRMF89YkYYbqGH8Hc5pTM0QjZXVjkd88f/q/9Cql8QnsWYHTJmeM+wbvVd5JrieO aXbtThUAwJPTNWSOiMiM0LMyux8zCDh/Y/3Rj5v+A1d3EooWaN1xh053L+dAMdNdOzEIh8oLjHqa tQXQIheSNg4OOOQB2pMaVy5IrzXBG7cWAKketWJo3XcpG4EY44qECRFj96guAdgTAwM59qcI40Dp njkGMigN2aCrCqRxZ/dN2JP40yMKI0SPIZSQRuyCnbJagXUrtHGd4wGiAO9V5wSM9P4jzTTEmxCx IKnBQjsO1HkNaK5bJeVkOcxuxzx2/wAKmiiWJXz8wHbGBxSE9CyIlKiTPU56dqrxq4lcqwUAjfhR k1omHS5pqsXkiVZNzL1A70nlvsEi/wCsA+QPxz61mIribMhXevl7sPkdSOuKsLIIFmd42CbwmOOD nbz/AJ7Ux7klwssTxReUTGxBLg9Pb/Z6VJ92SQiMgOMcdRSLL8MMccZQD5eABzn86mjV1DBhvTaF BPXIz+NaAS5GInD5wematLIzb9pypxvAqGBZ+8C3ljg9xjB9KJYWIhIjxDv65wW9f1pGb3LLeVA2 9SwmI4wjkD3yoamRBVJ3yBpGyCig84+ooAkw0iSBZnV16Adv881DPI4hCuHEqcqOzfX/ANC/4DTK SsOaNgpbAMwAwh5VvXNNjiYOBksobB5wBRcotSD5zyxXGASB/QZ/OoPMcyxxZJUf3etIOhqpLGV2 MpKe3UVeiOxWUwhk2khQx/I8UxMrRwwxo6knez5HzYAz2wvFXWfkGQEKf7q5IFUnZECxiG4+zmSF gc70VgULAHr64yKbLCZJl8iUiddrFkPAHp9aE9QLUCw/Z1juX6cHBxk1EI4It8SRtuzuzg8DPrUs B6hg6KVUxOD35468f+zVDLGTIpRgBjpikPpchleQMEWPAAyNvalUABWZRyMN7mncpFqTakOwDlsj AHSmRPIinJGR29Kb3BaFn/WRq5Hz4+gNRK3mRBZRjLYHrUg9hYl8ppsLx/CAc5HbNVk2xiBnZgMn d6MKCBkvlS75Ac/f2O4BIxgcBh78fjUUUUgaWZ5t6OoVwV5GKAGtE0cvKHJBwWOM8fSqz2pm2hIm LH5sHIyB1x+VNDW5pyrDGITPGN+3JyOMVW/fiQuCqANhcqhKg++M1exRLdwRR4kiCqSxDBPut7io YFaRYmJIUtjBGOBTYmy/Ku1isgLIpyOelVWERORFkD+EcZqZaIksTO08KopO7HH+zUccPlRxqzZY Z3cdT/jUA0KweVJFiQ9F3H6+tVvNFrGJ8MwbYyKoGG46UAaP2hIvPaQkTYwFI6/Soond0DoFIPTA PPP+0KAGMk88jksPl9D0pkrET+cSBGflwDycUAVZZo3R5IiQx9aii/eIFlLbl5TBxTNCa4kkWNYx AxDD/WFuM/T8qYpdE8uRSTjLMUO3H1pAW4rZJdkqTptHPl4II/TB/wC+qSLBdblYdjjoxPJ5pkrc kiYuiiONDb8rIGOD/L6Uy1inj8zIwoPAzwR60Iph5cAdv3I65Xjoc9afOjKkfzc5wASSSAKRMldX JPOdY44CpyBkEAnoO9ThzLCGWTBHGR/doGincxsDGrynYRyyqBn7y45HH4VOsSvFMhUbAMLk/MD7 027k3FgECho5MjcMhj/SoG2b8wyB4P4XH3W9xWgXIJEnZD5zDaDxge/WrdusioVkBEec7aWwkTs0 cUkaZwTzk9BUQncZCKM7sfWszQcz794LADH3c9amZX+aALtkxg8cigCNwYIIyx3MvXA5p63DNsaP KMOV3dqpKwERMvmGRERWCfK4wGD4PIOG9f8Ax7tTh5xij3KMBQGAHfvVBYkklRHCxqWHQ9sUqujB WdDtz2OOlSxbFlkt5X85CQ4PqcH7vbt0qoJArvGyfMcVIyecRqsflx5dOgz/AD9aoQO8PmSKqSLy yI3GHPbOPegEW5WDzO5URqBleMgfgKkidWRty5yOSBnigtbA2SVRZMKW+ZlPIHqKuBECLtcn360w egil5EAnjBZWOMryP++qi8vzABHzt6BjjmkZg26EAsGkOMZ449AOOn1qaMO0ZjQZA5ODQACQDaTG ODlcjkGkWJQVZHbCtuGwn5sU0MneV5sl0w3bPQ1CjlJoIssGORx0XFUtgJ9yuwJPzA9AacylHDlM xEY4NMCS4k2ooUnc3oelLFncuThe/rQDHgY5B3AfrTLdFdJRn95njPamiepcUvGBlSWx6VeWMKis 5B3jgGkCXvESSCRAgU+Wr5ds9Rzx09aSVd6EKMD1A6UCe9hgEckQUnOG5I74pBI0pVWUArwCKBDU hlYkouJNuCSev/1qI94MkcqRhdwKbd25vqaAJoxIHYyKdvUZ/lVlWJRiVznj8KBrcY7gxldpCD9a j8uNw0LHKsGwDTLe5LJO64I+nBqtJMYp3EkYKgZ4PDCpZPKHmNKAQvzAhdo/h+tRGV0YrIhDZ4Pr QUQSRCRjLK42DnmraFAq7Rx0+tMHsXoggDNI3zbSee9JGTI5ZhtiyCozgn1oMx/kMJDGT8u4kA9a toTHIzgkN05xzQMr3N0Y1UkgJnG7OAaSEkGYqcpJgMPShAOVs54O3NEKPIVyRtJ4YDg00IsyrKHM Ii3uvIbJAqy3lohwrBQpPyqW4HsOTSBlhhGpQoylMdQeWNPA80s8r5TG0qR2oAs2ywxRucffbOfU dhUilBumHzR9sd6BS2H5UqW2kjPr1pkzOqeYIw2P4VP9aaVyBvlxytvJK7uSqmpgH88yKnT3oegd CQjc24K3p6A0sMaeXvmUo55ALZ2+nNAEkWxkZZMs3zLjHBFQiCInewA5yoAwBTiAkeUzMpycYII7 VKuPLeUthc5+lWxolI3AOspPGenT6VYjn2pkuG5/KkWytlw0hUnyixJxxtzSweY5kIXkHo3egzJ3 UZHyEnNJ80WRkbhweelMZJCpkDKUGG9RnH0FSx7csFQDsSO9DEOaHy2jKoSx9qr3JKzLHk5PzfSj qMdIxggUOG3E4470kS4BZSd2cn3oEPVZZMMR8x4HtTZ5ASN2Qw7Y6UAPjdFQGPnnB7YNN2Iz5V2R s8jPB/CgZIYSuWXgjvnrU64EI38gsF4HXJ20Ey0Q5VFsiJG3HJHvUO5txkZ+fbvQUQCfJYbec9e4 qbIVmOCeOgGTmmmB/lFi6+07p3K+aeAFHB9Kt+WZJVjuXCPjIJB4rjvdxOl7E1iyLc3MVkpZD8rs 39/tz/DU7jarwwEFhIPObP3R/jmt6bEndmZfPawEzLA4jB6O/DH371DHfx4jiazItCTvcHgelWGy JZ5raSSGNbfeqAhRnpmrNteQCZLVwFjB6MeAaLjg9GalxfL5MkEUJeTGd47isO8v5ipiDZSWMDcO Pk9qyZquxdsoori3EkrkyDjB6YFK8sds/ktH8qnOKgS2sc7PqUdo15K8Pms4ySTkKPT6VyspW686 43gY+bbjkVojNP3TNsZxDA8EUf7sv+9lxyue31qidklyLzYSV+TA7gU0yr3sWY/KuZ2e1wsp4zng V0IeRIFSXBA+8R1b6Ulo7jSsytFbzvLNJbXAW3C52Ec/nWXPazeaGiAD/wDLQ9QR/jSe1ivskw0p oJEkm3GJz909q2YtODKbeKMbhycelIgkutJmECRwxbecsBzg+vy10OkGGGSCIRBjjDNIafQzN9dO ggkkms5is3fHOa0YtINyha5uQYX+ZgRxiruNFUtNNZiGFizI5IOM5QdqvabYSO7zSowiHAJGNppX LhoXJI4HvFSZ1yo+Ut3NYOt3VsDCQpGDgnoBj1pI0bOW1toLpYrqI5uD0YH09Ko3s4WxtoribfIe eT0rWKMuYxQpv5DaeUwXpuY8D8azdQF1Zzpp87qYmTch7/SqsJPUyjC1uqteDO0AgLxuq7crFNZe dYgmFsHHcmpkrmkNUzCa1+zxtcqT5ZHc/niqtuszLcKJ2YZyuOo+lJbGTetzctRaWK5cEll+YYzk +9ZbzrI08iZIj+bf2H+fu0IroWxDdXEMAmUBPvgqMZz/ALtWpZI4pGaWIhgvyZ/iqiUZfmkxSTsm UHVfWrk6RMloPIGfvLIpxt9jUS0kaxLq7J3KSqPKxgbepNXk0J4oobmVJI4WfhSeW/8ArVCWpRl3 ShfPt8fvM45HSnC0RpVjcENgArVLcS2Lk32WztZvKXMygFMnPPpUunC51e3H2obR90gjpinfUbOj n00wq0EcmCOnOR/+utHTbC/aCQSuDnBjBPSqtclvU62zQBDblQWBwSB1HrXQ2ccDBbaNM7ucOO3e okRc3bXT1eVRGij3A6Vv2+lwR5ZcjnHIxzSHc7rTNKg+xwXMiESZO9WHPBrobdoEChx8zHC8ZzVk mjaRQSxPEAykEhiOq13Kp5drZ+aQdsaRrgnPA7lqh7hY0tK+zyM6MFLxcjK9zXSWc1wY1syA0G7c Mj9P0rPZjWhuNY+cjq7fvDzx2qGzsYyfI3ZkLYwTycVohmwAlvtLLz/CfWqckCS3QjRD57fNuPai 4J3JUgubeabkB2GSw6NWa9n87rJlImPzsvespPSw0bVrp5yRCzNDjIJ6iujs7RJGj8uMKoHOT0xW LehslY7NIZEhXAxjqCPvV12mWn7kSiJYw38Koo59/wAaxbLReaBraWG6nTdGx2/L1U9jUF+6IjPA flAG4jsc9aiOruKTONkc3UrFbhWt2bAK9KkubU2wRfLJycsT2FbxRm3cx9WSLEN5BNEqLgEdDLk7 QBu+8c4rJiV98skx2eg7g10EsngijhuUliJ80HPzHp6108MbRx28l02zcflOc5HqKG9CYmqdu7ZD csF6AA8v+Vad3d/2fZKPPAYPtGVLEnGcfp3rB7m0Nzn7S9uFhW4KAnkyLjB9voKrXNxAcSWshDFB u64J7ismrmpTlu3mid5gxnA4x/EB6VDHqTSuFIYgAAn0q4Gc3YypbiR2ldyd4b5Oap22yK9WSa83 NIMCMrlVOOBn3rZGDOtgikkt4zGyjB9eK6SCKJ4TEbYNJnqB09OatKwJCmAxxpGuPOyeR0FZBs2i R4QxILZ5681BTOPvbGdpjFLCQzHYBjP+eKxTpCxeZEeHU5x05oIZjeRMJJI9rY24DA43e1XIbR4g uVPmqcjPbNUombZo2sM8Libb5Y7g9/StiGWWVWQuWY8BRSaBFhEeaAJk7lOPc1UmtNrKVba4GcMM 7j7VJSKmqeX5imP7pAJI42+1Z7SylZFLDn5QT2HrQ9izHWBo5TgA7efpUcj2uHDuR3yTxWYjk9SV zdNIWId0Cgj+HHSqNqBbRuzjMu37pHNAGrp8ibyXA3leR/dFdLZyLGy7JCGPbPWncixuQF54bjau 642kJ2OfasYW8syAyKY3Bx6g1S2KSElsy0bsrHzlTpngH60yzsJWcyPcBYjjcSpNUVYlNp5k6xxy qyK3JHFX1sxErS7cqPXtQBXlsy5gd87WOE2mqtzDGFHl/e6ZpX1GjPdBb7S0bt3bZ1xUlrHsxNsP mcE5JI+mKzLOrtr93baYSsSc7Tj5vb1qW58v7UBF8rMRtUnHJpcpmkTxXK2rjzwvlBsMCPvVl3Or Obsuo2hD1Y8Y+lNIdzSFwXD+XI24gEEH7tdPayXDQruKrvU7W4wDj0rRbCY6CWSGZIpFzNjKkjg1 pmTdvmd88Y2gd6bBEvk7RIVB3yAZXsKhksJxPDJLEBEM7UPIOO+fxovoIdHO7ExI/wAynqTStp0v kXEzj94CSoHc0IZmrHGrRmQPvf5vpitSK1mjl3mTIPbGCBSGkdDDEN8WQd5HynNbawzra+dMCW+6 Bgdv93/Py00MzFTyyI2kkRR/qgHI2nOcj1NXbRpt5mIAYdyeBWQzp4ru2YCIH/TAvy8/LUA1DDPG +RKvB29v/r0IZiX2r3E26FSka7sFiDjHv+NcZJZcSM/cnBBrUnqRw6e7MgyNvXitH7DOkMsKoPNk yM+o9M/w0yDU0a1TyEhcljGdwwfmb2+grtbS0dtodgkqndgjlvpUt2C5vLbkMN0BdiMAg/dq5Z2c Im3yQEoO4OOtCdxmxaiKLZEhKwj5BuYnd9SeWNQo0a3UjrJwOh96YzOvLtFcW/2hSS4dT/DnDf4/ erhL66nuZiolTAG5WXo6dvrTW5JztyZbtmDsu3GeDgH2Nc7JEBPN5qgBhuG0cE+1UlYe5q2kTxqk +3AYYIBz071dtJnZ55rhovs4b9yUzwB1zVWEWLjUl8uOa1VmQnawVeTXINfIHaKWR9qNk571NrEM V1mtg162ZYsgnZwQO1WrZbaXe8ELbgpb5hnf+JpsR0djGyojgkLGSdpYEk4/TrTHbfDKVi2pzuXq RVDW5Y0+1jaIzNCVkUnaMYyKRv8AS7doDGM785Y9Py9afUpkiW0VvA7NPhBwG6Hn0rj1ub+6kKS2 +12fgAdAP7x/9moIIrm8iiQGZsLnnjvWhpcZLsd42E5znJxQ9DW506WvyL+8XzgVwM8n3rr7NElh kiBIlUY2kE8/WoegjUgYRyCFZw0ygNgZyB9a1Le2jWQzM2G6rg81K2A1ZreMXEltKv71ACw7jPTN YF1ZpaWk4aPMhb5ZCMY57UpbgeReIbj7LqFzPcTu1xIQm0tnaQP4R/Dx/DXn8l5HmQmQ7ied3elY pM2NMuoJLqKBV2LI6Kz9dgzyceteweHLpg0kFzCpijPysMnf+H+fvUrlI+kPCemyoLbzgu1GdgI1 xuQjjP8Ae5r0+KCwSAKYSSF8z7pyr+hP+FJ7AjmdbaNLYyMzGYA88YHoPy/lXh3izU0uM2u/CLh2 HUg//q/9CpLYZ4R4h1CQSybJ2YbhyDz09a5C3ijklaS8l2RudqgjO3FWIt6HpyyyPGoIiLcDJ5rs 2sJI3BWLcmMnHf61EhN2ZMtpFJDJLM2GHQDov1rndR1X7MvlOUjhfKR7jl2I9PTj/wBCoWo1LW5w 93dpLcmKWRlCtgKQRsI9fWsuadhPGsM3RjwDVLYDe0y5eMzyOA8m0YwcAfh9K6dfLu7Zorbcjspy cfcP/wCunYEXdP8ADMf2SNpomluRlipONxrqoNMewl83aAQgwvXyz7+9DLR5p4msZr67n3Sb4lXa eOQfvZryfXZLXQkIlf8A0lgfKUDDEjv9BxUsZ5zovhnxF4i1u5uLa2kaz6uUG4kf0/xNfoL8N9K8 KfCfw9d+IPFU6i2jtTLiQEf6R97apxjj7v8AwKs+ppzH5y/tYftG+LfiDN9ittaI0e5KCGa3xG1p BHuxGCOWwDt3dOtfndqUhNuEsgrwhjuOcs2ab3RLZL4b8NNdl3iCRuylmz2Qf1p99oOo6/qVjpWj XKC/f91CsoIXfnqSvQfw7v8Adq1uVbQ/Wn9j79lLw9pE+meKvFzxT3cUgYrH8zRgl2/uKOB/tetf ZnxW8QeHvDumiziESICbh1Mojj8vGwDmplsNH47eO/iDfa7qF5qkk5aCV3WPc2cRZ+UA9hiuM8M+ KdPa7e1kVVulYnBcHd6Ee/8As1zSBbntGgX015qMTRJIqJImNrYBIr6a0/UktLUA4AAyzHr+dcz3 OhM1o511JYUEDD5jtJ5PFeo+DdOFvO9xeIpkdQm8E/KB0GPXpXO1oaRZ7lp9z5hitYlzheWxwor3 vwpaQ6fFCJQBGchiB0ydxOKzL5it4s8ZaXbRNawuWjZwsbA55B3Z/HFeS6j4jMsnyzSqzfORsTK8 /wD68f7tFhJ6WPnH4k+LJy7Tx3jRW6OQFjbl5MHgn6CviTxfrK3F609ywZEPyhOv0NJLUspeE9R/ tnW9ItbOz6S+Y4YjPlghT/vV+zP7OPh26isNKJhjW3SEyKFG5pTkBcN1/j2n8K9bB0+VSZ5uLldR R+oej2jWVvD5wUTCPJCDADnk/wC71rbjluJd4cooI2qD95vevRR55NArbzbtFlCh/TnNRNA11A8r zqkMbbfm+904xTjoBDeF4LaJvM3YHbGcU3d/o8d7ExK5yCR3+7VAX4W27Ekbqc/Mfu5qeSONnJh2 lgd2M4p9SWXYFtzIqsxAPBPHJx/Krb20buoDfKOpzUMSJYLQRM7MxZ2bA7DFP8swlnydjHB5qQT1 GSNdRSsisAkg/cnAwcYYn8DTm3lSZHXzf4QOxpjT94WNZiUEo2hhzk/d9aui5hiLSLkwDAcDr+H4 0iiMMS2AhCgnqMY/ClmiADMScBT1NAElvGr2wRjlCoHBwVPc0kUUoMkbOcK2UbH3kwP65/SgT2Lj NsdUYHYe47U2JsSOZVwu3OSaLDuSwqyynk7F5OasBSsUpH3M/IrDGKZC3K8kf2gCNmCnPHop9f5V L5aoBFJDkqAcqCeu7qce3qetLoWTh9+CrFpsYy3pnpT1kzIo8tQSQPmJHHqPx/8AQqqLsNFw3jrM kZiyR0IP3akiuJo2H7rcfQDP41XURc2RRIVYgtgkdcE0+KVI8HHz46qCQ30C1EtQLBmcrG5yFz3H WnOyM2FJWYDkeopGZbtnLoUYH5c/lVhZVUAkAjPDY5oDqMaVpDIsUQXGBljyT9KZdKJ0WNockcjI yG9qa1ZoU4rdnkLlGEikhRkAseOf9kVfZQfMjhGZcA85xSAmXzSYRtBCnB7c+lSKjws0wx5XVgRk 4oAtRbDMxUDy84UirAJ8zCOAuOeeabAsCGWTG7HlYJPAwfalnVGAPRT8pDdxSIe4hijZFTGccgg9 MU5PkBbB46beKBCrHGxVidkgG07T97+LkUzySPMIbdKwxkn7w+tAEyqsew3DbVPCd8mq6TkwwuxG 9vmG44yM/rQANMgL8cj0pEtUbbOGP0BpspO7CNwxLAHGcHI6e1TSI7kHAVQOOOWpgtRwjYLHIX4A 2sNuCKDbyBJvnOeCrDkjB7VJRExYOC0hLDIbcADn/gO3H5VE28KoxxnkntTRJF5YwWD/ADE/Kewp wRtjFVIVepz1oJeguSWaa4duFyoJ6VNuikgi/dbmOThgOP8A4mhbghyLtUxxxg7Rg8ZIHvTFVWnZ QigKm48dfU/rWiKitSEyQx+b5z45PkqCSfxpYH2M4RvkHVe2TS2FsTebv4YErnHA5NVZ/lG+Nir8 r/vVL3ENiZ0igUIu0EhxIcM/fII/755q6ihsNInzleBnBAqQHBgrCeIkEfKcHjn1pGYsx3Rgkcgc cmgCKSGaWcyq4DH+/wBvb6VZZfsyAhQVJJ2r6nrQKxniWKWdXjiZSBtBz1HzZ/3qq3SP50eJAVdt mACSDj9KBrQtQ22UZCQO4zwKJF8oIirubOSVHQUFREUZlSXJAA5DDpUT3G4yiRHMR4UqOKCiWNnA Mtup2biQMdPrVif95JHGijzSMdP88UASBUXchBDD5eDgH7uTj8KzljPnOrSHqQwGfWgC7HGUTyyV 3g565NO3q6FflKjIKnnP1oAqGSaQvsYLEuCuQPnI7Z64+laUJjFuY2GC2dzKetADGjTy4180bRwN 3O6s5WnSeaZ3yudoyfvY7fSgzARebzuYdiV6qasBBa20ce5mCnILY5H0AWrjuCLETLLbzTn7qjow 6gVJJNs2OjKd3Iwc5qrFpjF86RcAfKTimSRbIwMgTDPzDJB/D/Pes9hk1pDEUjlI53EbiCcH+lPY mN3nDcKCTw5LYzntjj60gK8cKySC63Hy3GevWpHkDK0JG1d2Q3Uj0q1oNosysMCRxtbHYfyC0zyy CCCdp+6R0P1o5gehURXnducITg5BB61IIgnm5J9qgQ9JEV1yDuA5B706NxwucMD/ABHk/wAP+FPc AlbaZ4thEgJX5xgk/RqaItyWfzfvMZkIjABP0FVfQaJlYlmQxHYMEkDgGpVQLOmAM5BPPah7F3JZ Y0lYJCQMffOOgpsT4d49h2ocZDZqCGSoZg7MzYGejjke1I0qvgxn5R3oEEMwczA9AOfaoWZjhSvz dRg8GgCfeykFIxnBWlBWRizQ9DkAcAmmgJYgHkYEMAO2KsSRbIn2P8rDBOMmqWwEH2co6yMRtXkD byD61PHFGd0kSgD+LnvTADG0ZZp42wDgEVLvXCxggSYzjvii4Dy6wbZCPkIzvxwSTwM+uRVW32kq 5A3NyM/xChgaiOr5cA7cZHPFFuXZxuUg4+U9jTE9xzDEjx5yp4ODT5fNSKDcSQTyM9aRMt7kcrhG jSNTtJz/APWqv5jPJhE4zg89Pr6U2DLiIMMAxI79qlgY+as8ig4zjj7px1A9aXQQ9+P4flxyDzj+ KmxoixOwBdyBtw3Apoa0CBcsQzAOPXtTLgIu6XGWXsDSKTuRRCRp/LDAxEfMc/doklg3KGGBnAwe tBSLSbF3OB1H4CoPnjYuwDbvUUyWRmMSx7WbEhPympEgEWNzBlHXHekC0Q7k7ndWKAZ46VbkK7VZ nDNzhSBtfjgHIPH/AMTQSkLHLGoBcANn+FcAf981JGwuPMUq2F5yeM0CITH8jqQQAPzqVVjiKOud mMEZ60DGxO3l3CMcLk7fcHpTrRdqGN2CYBO7tQIuLGjLHJDJuYNtyD+dXPLT5VYFUPQk4yfSgCFt rW5ijypVuG6559KvYKqFJ2qQCfagCTzSXDnllGcAYB/CpEO7epHGeBjpQBII8+dJuxsGaTzcqOQc CrRCC3GQ7N/D7dc0SMgO4txntSb940uW1fzYFRmOexUc1HhXcLISY1681JFydwCPk7fhUSxCR2DF 0QHAKkc/99CqW5JKVWPewU4UFiQM/pT41ZkBYAKVBAzgnNV1AkZQoCgEjFVY40ckHKkdMUGm6LCk c4HHQ5GM0itHtkWIEno3+zSjqwFDlUDBzlRjn0qNESWST98Q+MhD0IpoUi2kYYnbIwxxtGMUCQLG NrkOeh9KaJYzzJ8K7Pls56U9QzO6Fju/vd1oEPZZNmGYuB3xyah3LEGcSPgjO0gHHrjj0oGSpKXB ZQQo6CmzbniVgAJFbkH0oEOUo+FKgKOeBUPycK74fqBg80DLZYoC7AlRz8ozUakzKsuSHznb021M RXH7l3hM4NMmBCkkfTFUMqsoZwyj5vapGd4/LAXhge+MEUAf5Rdrc25uBtUrcIM56V0SNA2wyqrS SDIOcg1w3s0dMtizY2yWUiRmZQWJzxjr0qK4s1t4Z50OZWON3rW9NmSdmcxcFbzEco+VeAQefx/v VXju4tPQyOjTRLxw3J9q0NI6ois9aiuL1I47ZlkLZfd2HtWo9rDK7SIoNznv3FK5VNaM1baJoboC 6kyhG0c8UxrWzee3yu0gnJzxQyl8Vht3ewWkbRWbqWLccdK56eTUSYldw7McsWHQVmD3sSLZwzTK eTL1K9h/jXP6jbfLdyqm1VGWC9gKpGDZSgghFvLKx2j5epxVOxsVllnuMN9kHAwepqUy4vYuRWlt bI023AL4y1bMELRhiy7gfusT0p7o2jqyK8t9sEkikrcqNqgdM++2sGGC+ggjeRMuxJYA9ff6UnvY S+Ek+0XFzETAQUBxjOCMdq2NMncq0xcq446/doIloTW+tuLhoorctk9S2A1dZGIrmBgh2XIXOMVS 2INi3gRYduH6DnNSIY1wI3Oz+IA8UpMCZWa2uRcKu6IjPyjFaC6lJsWUQlYOuaLmiKVxOku8Ruqk jgn+L6Vymtvma2s7dS9w/DZHf6VSKaOevpZLOW3tMDzowUYkflWZdxwxrK7jMzAMDngVrFmUkZpv Hs7bcwKrI+ATzg4qlPGlxLDM+6WVRwd3PsPrWlyU9Lj5NNnllEsbseAQpP3SKkluJYo2Se3RC3y/ J396iWhcZWTOduIXZzHk7XHX+oqC3tvLtwC/7/eRt6E1C3E1oaF6jqCiJn5Rls/drOkXbLDHOx+y E/Oy9h61RXQ3La4swn7skRRkldxyeKxJ70Tyb7ggKW9cZ9v9mmJl6CKIxusLZnblUb+L2qWONUtd 8ylJJG2gseCB3+lRLWRcS5FaRZRQh253bg3Wt1b6SCFIVvN7AY2E7jH9ffGP0pLc0ZFb6YjPJcTf O5O4nPGT6f3auQaQj753bB6AHqf/AK1Jbg9h8FkYPtBKDzAcjIq9axJjMiOiZxkLQtiWbNvBLI4g aM8cu5HCj1P5VvxWZs7aYSzfNI/y57D2qkzOW51djEZFEzJucDaVUVv6bZRmfzBEFTpx1oZJ1S2E RISKNQx6Yrq7LTZUgiHy7kOWLDIzUhc6m2gknCrcQfKByynpWpHpVrGpK7mfBYN/s1YMsw2a2yJu YMn3twH3s1tW8yyPGH3ELyMjgCoe47m1p6+T5xkXaxPB7Vt6b5kcijzUwvzBmXI/KoerKZ0lpBJH N5rTl0I59OK1xFAsglkXDOMBh3poCrd2Mk1200IKxbQMds+tXY4l82GRgfNHG1Tx9frSFaw9TbrP 5aTFl9ePl70+WBJC5B3J22jk1lLctIu6ZDJMqhQytjg4yK66zt1jcCKM+YOST3rGWxulc7XT4knc Dbl849RmtlYBISkEhMYOTt/lWLZZW1O5SOMeUcR44DHnIrg7i5nlH2dZQrO2cdjVLRXMpCRqlrBh fm7nAxg96mS5gnwZnbzE4xmuiKM3oYqIlyxZm3FHOCAR36jNTz2nlIlwsoKnjYRzWxNxl0toPJm8 5UmVcE5/nUb3MaOYSSZCAW+naoe9hGvaXirA1uibsHcD3z7f3aIrlrmeeK7GUUY25waye5tHYljl jtojCB93rk9apSSI8WC21wCxJ6cfyFQ1Y2Mm3u7iO+s/OiQwhs4YZ7Vc+zh4tQuoOJlb5UAxuJPS rSsZSXMUPJedozIuMHGMciur0zToLdFka0VmOTuPWtEZWNrS9JSeQGRCInOcjp/+qu1GkxafErxy 5BXsKtlJGSbGKYZdStx1Xng02CwR7orPGQic4PU5/pUCZDd+GIGLSRysd3djwPpXHXvh6RkcuMsp yCpoJZk/Y7ZYmXZhjxz7VUSxDq21M7R16VZFirJauoCiNiFOTk9as6baMkjuqF3DdO1JhY3Vt4xh 9mGbIBNYl3vSaMXCH5vlXHbHrUy0EjB1NRcyIsDhdnBx1NZflw+YVy+1R3PIpPY0Oakurq3mePz1 ZgvIIx1/+tWI7TySMGBaIckmsxFea5G0qw2oThSe59qhDrvjUHLYzn3oAuIheQySuVLdlGMCtI7D 5IinYr/snrTHY3IjIqLMpfcrbSB1PFXJdQZ4EVVAMfLHruzVR3sFzatrSLbHPK2YnAYPH0cH0qRo 0KlEzuqguWo9OS22zbDtHIYgYNF3bOl3Hk5Rk53H7hHY0AVRDEIX2R4UDjPH41zvmRyquEJ5JGOp rPqNCRIQ8oaRRsPKkfMn1qWTyLaKDyQGXeXlXHBBpFkP2xHmlkiJKlsCnS32XQIcSkZVj/DTuQvh uZUt7NdtGjncwPBxwSO4qK3klN0N33TwwPbH+RVpCOitJJbhxBG3PbHBxXXq8kTpAw3AjIx1GKa3 JbLsd9LawG2ikHmSNuZW5/L06Uin96TGxCnl8ngUMo6K0lmuSsfyhyd7OBkbPata4v4DEYUIO3iM s2Qc9T9KLaCKD21qirNJw6MDkfxVNLco9yghUnaM5/hzQhiRWRuJpHjU+aASE7N+FX7G0uppTDKh O4FuByMUDTOh0+2R8hh+8BwM9QKnltHUSyCTd02FRjP19qTLRlz+YkP2hhh/ugsM4rOkuMEu74Xs M1mBmy6ncxThdnHVXH8qvQai0wYNHtYnJYDG4/TtTQGnaWJluQZVJt8bnbP3atLp8JYSPGzwq/Kq cEitCXsQWi5uZBHaMsIc7WZeg9c+9RuJ0Z90OY9xYEjAH4+lCJN3TrN0khZF2s+SQBXVxW8szxEs AQcLkdTUtXJsbsdndG4ctJsiRM5BxuNMdp7GGcyXA8g/dJTlcfN9STTSsMoxahJIQWUBR7cGqFxf JGZHdGKL2U80xnMTyi4+0v5gGD8vzda5iS7a0mMnk7z02htuaa3ERXMzQsjxGP7M524IOVpiwJJJ buxOxRgheje9arUHoaMsf2fDBgYmGFHvVeKLzUQspTP8OecZqrCloULm481WjiOzyiCecEf/AF6y ZoHuNuxQ2OT2FTa5DKy3N08b5jwiggD6d/fP92t/ThM9tC2QsqjPI60mBsvPmNhGw871xxV6zK+U 8oh2ysu0g85x2+tXYa2JlmeeJBGQnzYdWPOz29+lWoIliiaBX+XfuPGc+nNLoNklxppvUGxQAhye Pvelc3cQNaPNgbo05BC/e454780mScVOrSSCSP5WDZ2nqPpWvBKkVs6+SEYkkEH73rUt3C5ox6qU jt5VjY3hO9G4UdcdfbmuptdYZEU2j75GO0rncQO5qXqVE6nSyJZMvEdpwC2evtXTPcW4nhhxsyuB 6E9qa2KKshdv3m4lSecjJOK57Utad1kWMB4QvpmlLa4Hkus3K3IEavk78pIeleUaldSLczRKwaAD LHFVYDo9DukhnhuHUm2A6ge1fRvhVbDVfs6ybhE/CbG6nG7n2rOxSZ9MaRqRt4kUxgIi7SM8t+P8 NdpaahCLaeWclWCbthByfapexR5Rr/iS3uUncDYQCyruHIB6jbz0rwrWtX+0XV1IxLQkY3Y+8MY4 oWwHA3cKSOkrjEROPfNYDS26LI02RCOtUBraVcJJeW43BY8hwecbK78uY4yCQ2eetTIVrs5fW7o2 sS7mWMkZBZsZryTUtWaSJDJJvIbA4+6Pb3oWgktCjbWn2uVzI58plzyck+xNbseieXIuGJQgLvPL CqW9ii9p8ESM0YUHafvdSRXpWjIkfkLHEzZ67RxmrSGjtIEgDKsSZdv0NPvYAsDkKBubDNk5H0/H H/fVQykc1f6BPLA0hn6nIBTBPHr6V8++JfDEt5qBS7dfs8crqoXguT9fpSYz0/w7odn4NsX1jU5F Vlwy+VklgCMAD+I5/hr4q/ab/aI1yDU3025vFi08vJbWdtHKCDEuGLbeMtkr1UYOaz6jR+XniPxF rus30k2r30siSl1ijXCxiMksE2jg4969D+G2mpeWVzFqUJMHmmVWkJ54AwPy/wDHqHuh2PRp9M0z RoofsNwzJIxCiRhuHfH+11r1H4atpenagt9cN+4Kj96qfOjnrgN+lNbmttD7F0/4ozw6HbW2n6be WVwPkUI+OT/y0x6n71eL/F7xFql5pkc+rarLNdmYIQZCN0YB+8P4gCBjNJ7Enxn4q1edxJDp15tm IBVCm4NzzXFeHPDGoarqVybi4dYnYM+Cfl+nuTXNIFufe3grTWsIoZMl4wu7JPMme4/ugf4V6Rp1 22xoixMu/KqfSueWxqmew+FjHNfWpu8llG8c4X+Hgj6V7vp4jFq6p/Cx2jHQ+mKykjRM9h8P+Frm 5exmb5bQ/NI4JAXHb6mvQNc8RQ26C0s4SEVQpZnzu/Gs2i0eWzq81608o2rtwFbofeuM1u5/siCe W5uRJCc4z8pJPzAfSkxpanxV8R9W85JFt5hGFZpAQ2N5Z+cdux/76r5OnGo6hqV3dahcnYz5wDwu OMY6DpQtyz6M+A/gXUvEfia2ttPIWxdkjkm6sCegUevP4/8AAa/oT+CXw7i8O2GmXMUb4iRIDkEL kdwWHfHevawutCLPHxTtVkux9R2lvI0Ms8+1Y0TCDOd3/fNWIZxJL0wgAOe+a6TmLchMuSVyo6Y7 UyRIWCrvAYjoT1oAZeiG2jQvJ/Fjnv7Yqu0ZCsyLngDjjj/JqogK8bMkTRt9a1gqGNFVVEv949qq WiJY5rZoHQxSBy4OQpzg1rLEU+eWTA/2c8VncksRM0sIPcD72agknK5G0FcZ69KAS1ImnV4rRpgU WJiAGPByeT+OKll+VA7oy7mLAqc8CmUkSzZ+2QzvnfFkIMkDnvj/AD96lEiqwZY9qA9xSKLRuoZY xtz8oyxA4I9KljjkleMoytAwPJBBHGaALUKqY13sACMjb0qM/u+GYBz3xgGgUtizFbySROzIYyWw C69MVKkYjBIbKj0pk3IY1HzyIxZSchVGP1+tTL5kgYH7wHQD9KQLcf8AZPLCnGZc1MVkj8uMD5wM hm70upZHlbe5SMrtyehHXPvVrznUlmX5s8fhTARTlPOZTsZyucdD/hVzhoIBCv7kDO4/e/Gq6ANi idmLq3yKd20ng+3tUzSAMZVUpg4G0YzSAsQyeY7RHgBdyf8A191SojRArLLwPl3tyQPc0iZaF/8A 1EEbhd4clTg/dxzk+gqslzFFGdkbSO4IUkjaD/jQEdhzsxkRtzIcgjb1FXH81WYu+2Hr7g1S0RRC 7DmUHcg4Ht70kW5czIxKrz7mkI0I4njcvMcbvmA9PU1cwVQshypXOfb/ABpDHWLIryOB+6XGWb7p B4OM/hVqO3EcCPG4Z8nJ6huaALCySJkOfmxzjoaY4eQYaE+UMndjOaCWtRYoAiF3Y564NSlPMww4 I446UEjVtt0rOkxEO35xnLE5+nTpTNhVgpYBev0z82D70AMSU/KzOPNzkYH3ahLbtr79ykuWyeud vT/vmgCNSFJKgNx0YEFfzq1HOd6OoCovXC5zihjasyuLfaw3zB1zvRghAYE96tZQIzI3KDIHvQJa Ds7HMjEsj4ztXv2/Cp5d/lMoAaM8FGUENQPmM+6VDEscSBW5GQQAec9h70uMMoVjsx1PamJkbSKX YxBSoH8PQGiSOS42zhyqhs4xnH8PA/iJoG9ZWHYAYqyHf90qy/zFSxBE5ZenA601uUojJjsuImfK 7vk+YYJPrUrEQh8MVd12+5H/AOuqKtpcqqCDFkZYHduHXipvLTexSMAkbjjH61MiJInSPzcbkIQH O4cVA9uXMwkc7OdoHpQ9rkkRtgUULMrE5b5uCo9sD5ufl7VNueN0DsN56YH3qQCSqDCkkZwd/OD1 qRJwjBmADY5zyKQEUksrNIzsuw8YKggD8ahijhiy0YwM/wAK4GKACdWilfySpfbkc8445HpjIqr5 zxB33HHTjgmgFqSpC8qiQtkNyMgj/wBCqeNR5LRKpDnOR1oKiRxmEjYIyGP3sjrUsCkAxlPkFBQO zq8QjZAjHDKR/KoZ5X8zKxDKcknvQAsNwssM8vnZmUFtoHT72MUy2R1+cjcSd2TQBdiQSrNLGmJC QSeSD/hTY2Mm/EO1VOOaAEbEIKKucnPX7tV3VWYRsvynnDfxetAF9ZNzrtQMT2wCFqpcpIjESMBz lCBQZimS4VASpEqHG0ttyT2PDDjFWZFkuI1eNwUOGGQD27Gn1BCY32zwSKNhOOB1H+c07yEc7Yh8 w9sEYp8xaQscjRxlVPO7Jz/F7fSmlnOFZOAc/SluMsOQyFlA2lRz2oa4jRPsyMpZxjoDj/vqkVEf KZRF5SID6AYBB/pVa4eBLaGYqMk84HzH6f3v92m2NscQzYmYnceMEj/epJHlX7KqNiNs+Yp6qfpj +tIh6grNNgqCrH26VFJG0sgk3NuXnrjP4UASM6SPA9q4Kbctkcqc8gipXVokIzkE84FPYBiiJmhU LlMfw9qtvHHGDsb5vr0o6ANg8znb9cZ61ModHAJBbqMU1sFxkUvlPJMFJDnBwOa0BHsZVgUerA9z UgypfGSXy2VMNk52j370QLEYxJs3sp2Zz90+tAAwDIcAE+hbbmpFVozg8BjgD0oAQoyuzMTtx6cV ZDpHCFDFnJ5welUgFt8RkOo4IxxU9w2FXB29+apbAVJJfMA3sc+wqS2fy8BD+7LlnJPt/j9KALAj 8uAReYSisTknqSf8aryQRxZEpO/rxSkA9WwYQoAAIYY6gg7s/nVmMRxMrM4KsMFSOgHT9aAAqjZ8 yLKk/Jg42mp90MCCFrgmbqPl6URDpcQJLuQqpCk4z61LI5Gw7cezGmKS0uSq6/MRGS3oD1pBIvmN wQWxuJ7gdvpU8xDLsahd/mBdvb2qoskasxAww5HPX3ovoAkUXmoXDdWPepnjkj2LHCDGOSQ2PyGO apDWpBI8ceJY2yy9cnin5iYJJt+QnO4dKAasR+Yka/uhiME42jFNdYpzBuhk8oKT8ykSbweQR2Ax QWh0ckoTZjPPBxTvIZXR5JG3qd3GMYPY0AyRZERyRCeOgPU1BJDM7kxkhB3zTJeqLqxSRxudxKg8 HNLK/CiW2YydR8vT1+9+NAJiKvmAtGhLgYPPIq4E2YkkU7h0wOaRJVeRJZAFnKIB82f4jzx0+lQB twK84Hv3oA0YkhjjAn5UnPHXNIYJZXJRSICOeODQBds7UWwLs5KEY2joOetTpauWdZ5DIh6HOD/9 agCaS2+cFZBjpVmMCJ1EmCMZ6EmgBjxO0rPtIx2x0pYdzSvhzggDBHTFAFmbcsJjiHzMcMfamRhE ALg8nB46YpohArLLuRWOzG8FWxkfWoPLQOxAKkt8u59xoYXL6skZVGJ3U6RxwAuO/vQFyJA+1nRc 56Anhqnnl3uiqSpB6YBzx701uIn2ERmRmHHWo8M4U44FHUYLlnBOcDjI7UMUUlgT9ao02Qpl3EKA cdzjg1HNIVJMY2gcnAqdmAwymdRn5SDn61K8UmRLGcMvGcc0kyJFiCYhT8uM8tx3qFFQIkokyucc E1oJlvKlANmQevHGKekSAARAKpPzAkmgBd6qCqN39c1VEe9jh+QcnmgQpl8qRcLwOSBwGqRpC4DK MDcM5wN3tQMfGR8+QQwbqDQqAu29c9Mc4xQIjkZ9wVAeDnrUqurHlcMOTxjFImWgqsyLIxO4E8cD imBvPYsxIXOCuOCPUUyiIr5LEZ284XntT0ndXIdiVP3V7D3zQB/lI6dD9pgJltgkrHpjnFbFpHI8 q21umcH5if4RXG17x2yVjbkt7OW7iguFcqOQVbaQB61mX3lm4XT7dWS2IJaVm4X/AOvWtM5+pz5g RZDZuN7NufzV42j0xWbqOnzLAZobc7AN21T909yap9DWmrpmJZwy72u5jsYjA56VuwTSq6TKcon3 iPT3p9SobjrxpLmW1zc7DvzjPUe/tQX83zltLgSt9xlX+EjrR1Hf3iNwps5VZvnU7t2aozahdTeW qupI9BzilYN2aEDeZbLIDskDffHWqF+k8QFwhDoV2NsHB96gyaJrvSLVreOSPPlHB+Y/f9x7VRsb HakgsWDop+YE9Pr7ULUa3LN5FBcTrZMM7cPgHHNTTW2xNsLsvG0ZPIPtVrY3hoUZrbULYRNCPMhJ y/HIqZp084TCEJBgLhuTn3qW7lGYFjmnbyhhf4hjFU4I9pn2grbl9uWPekvhMmtTqtIliSMpdGPb u2rxgr711+mW6TyP1Lnpu9BVr4SH3NG4tSQ0VndncuM5pbbT4oZAPOy5HfofWiRKZqxRqdxOGBOC B0+hqvBqn9mXL20sO+3lwuf7lRcvcxtXkWO9SUKhtyNoA6r9a5u41po5SIodx78c1a2KkzntQMV3 H9tCunl5LkgnOP51zl2FuTDIzFbfcDjPJFaRepmPuLmBbcwZDjsQKyrCRBqUZkLLAOeRVolmpI0U E87iYyLuzwcgDsKy5LaaNGuJJN6sxKjuoqGrod9StHbSWzuxctGTnOatXkEcPlXjMA3VcjrUW1Lt dGTHKxmmFy3yn25HtU8TP5PlyLhMk57mrGZ1kdt9NHdRl7fP3Qcc9v8A9mrd3bJKjzS26qM/LgdB 7in9opr3USrbILdJGV8k4GDgt6YpZbeR1SEksjHH1HtUPcpbHW2cAtHhikRgxUDB7Cpv7LgSSaaH G5m3Fe5/+JoT1Bm1bW0scZKITG4I5HPvXU6RpEbQRiZcy8uQOePf/wBC/GiK1C+hqNpVrJIjKmFz 8wFRxaU1x5kRkyu7KsOMY6UPSRi9zdg0i4tXYySqYsfeAwKjuNPE8sMcr4x3B+7Ti7Gb3udTp9v5 CAtxj7xxwRW3ZWqPOHhYlS2DjtTuETt9JsfNeVmfKxDeff0FdetsXjRRkl+h/u1FtCzSs7Jy4Zzl V9OBxXVC3geNUU7cjHXH603oA0plwjr8uOOODSSMbTyNihnEgG09PoahvUpF9zO0DTxxlpdxKpnH PuPSp7LVJ9ymWzIXP+tyNo/zxUDsddYahE5MUkgUD95gn7w7kf3uorWhuIJ53jVCyYwTntVLYdzo oFDERs2I8d6l8mCBwx3Be59qhvUaQ+C1guomkBf7QGLYA4EYrQsY44TH5i7V6jeO/vWT0kapG5Z2 yzyMY3CYPBFb1mIbbzjIA+7gY9qybsam5BLJbWrz2kG6Yj5QxwG/zzW0uIYVk3hc/N7iskO1jkdW hRVlljuR5z/Mqu/XPpXn9zeFJGiaTEo56c1pAzmMlu5JEWTeUgbCDJ4L/wD66v2tvIyhi5DKM7j6 e/8AereJmy/bBVglDKBk5y3aosvdRsYCVhjPQj5mrZk2KlxbBXjeWJtjcFhytKFtyivGmVHcjrUP chFqGWG3VgchT82R0FSzSJDeR75F3HB45Kj0NZG0Ni1akTCcSFS/dSO2etWXsozaeZGMIWwPc+h9 qG9bmyVkZiQO9zH5yfKD8gxwK24rSW6yrgjnnHemjKTNez0SytyJWjDMDyWGf9njPSugsdKDhAI2 VcfxKRjmquQdnY6FBFIqbyTt3Mq9h7+3/wATV+XRHhEZlnRoACxcfwjPAAb7xPFF7DRVl0OM/OFI l+9tB5H0/u0SaMbiZtkbFwM7xQtgZiX0UTkiMuvGPm/nWP8AZhsiVxh+QT656U7EMyb7TrVlLTFg gGxhgDn19q52e1CFAuQvRexx6Gq+1cT0Mue2n3pJbZKj7yYHJrR3QeZbpIx3KDkr0+lFxEUqmORZ 2lAj6gehrndV1ExSlNuSMMCBzUshbnLT3X2ENMRvV5Msccc/yFY2oXBKSFYyHxvJB5Hv9KVyraGJ J9juBHJLPiUEFthxkeh/z2rMuSg3RSFhH13A4x6UmWVZYUaNQPmx3xjNSWlt5aEyJl+oJ71OxJbF 1JL8rJyOOBS2m1Z/sywEgr5gOe/pUS3A2re5WXHVWHJ55FW1IhMgaQBWxg9RVoaOotleOFUZiWxn BGcZ9K3NMttuco7DHUjJb/61WtwOg8tDGOMD+6azb6GFk8tgUlHRj0I9KYHMCN3V4QhLgkn6e9V2 McTNJjLKMD0qeUCpYwPNcXcphBWQYJx97vSzJmRojB+7Hfs1SaN2MiaPyleMAYZeQBx+FVY0ii3S clsYUP607EGZCGkZ5yOhzir6oiKXyWLHLAdqslm7ppijZbqEAyKcMeMj2q+LxxcR3DP+6Q5xnn/P ShE3JluVlKTuf3xbaCBxj/GoJbmZjJDEWODjHc0yjchkJgZRNtibgjPKnvir2mzmy8tDIXhB3MG5 J+noKANabUYXRLdWyWO7I6H2/wA/3a2NPLjyWMG+H+Irw1Ts7lJHW6bbfaJjP5JWMcA564rqVt92 fLjK+2Ov/wCujyKLslvFFBM0cKm5MeTxyfTmq3kTyWjTYZJ2+Ubh94VLKMu4sw8Zikj68dPu/SvP 9Tt7mLGcfez9ai4LczoYpbp5I42JRdoLdcE9vrXR21vlAjJjaM8DrTuD3OytrONEd2Y5ZQyAdFPe rb2gEMZjTCseT3FaImWxG9g8Qd4jhWHR/Ws9LSY3VibrKoWIBGMA4q4mZvGAQMrB8EEAAnG76VtW 86wFOCJAeOKWwbmvb3pWFmnjIcjHXOfcVh6ldiQrOxLBCC2B/wAB6d6Q7GRFd3EskvmnY5bailQN uP61FqFowEm0YkBLnI6kDpimI55oEt0DhxtLBSGHDH/OazZrEzlpS2xA2Anf61S2EzPmscRsmxWR htIIyCD2NbkWnxwxDnPQ8dqpCe5UupZEjVDywbIyOg9qqSSo43CdW4xgHJU+/pVEnOXTQtIZDKE3 DqT1/hqa5+aIxRna6sMgdxik3YZWC/Z0EzIfLzgYH8VPF3GisschLsecdqlsRrRTDy4jC4M6fwsc B81qy3XlgRv1HCleKvqUtjT0ePzUDG3IlXrkZz7j8K6WztkmD+V93oAeTkdaXUViQDyH3WwYsylS qnlsdq5Ge0A8yJ5WSJz8pfk/3iKdxHNHTyMsAeSdp7isa9ka0TfM4ZVJGUHQ1LLSMeO9eCDyIhi2 Uu/Cgbix3HO373+914rS0XUAguDPcMbl2LIcHDgciPjvwaTGezeHtRhuUQ7JI1CCfk8qfl4+XvXT y36XCzMy75mbhioBH0qd0N73OZu2MSEu+0Hjcp/lXD3epvAxt7S4zMxwCw4zQxHnF5PdK0oZGaYE k4PFccJZPMmZFDTnLYIz+neqA7nSozZiKa3CuQd65+63/wBavefCTW8tzaCUN5cpLCSMZC8d/bGa lotH0LpuoTJapiOMwKxCkphjzyTU+s6vdxRsbd9pIAB9OKzkikeFeK9dnku4oYU2COPDT4w6vkgc /wAIFeV3urW8D+RDISNoDZbrSSKOV1PXNpjzMwVjtP8AsYrPgmkvtzBwV3H2rRbkHXeG2BnYsNzB Ch3fwj/OFrvJfliRgwKA9zzQ4geTeML0gTrJJkKMbW5z7V42k91fXZlz5axjjnHAPakkB6n4atnZ XuLyJlfGYmbHHPcV1fmedMyFG8kAK2xc7Sf92n1A29K8O/ZyRPhlZ9wVlKlce/8AOvQbLTWQQcmH Yc/KBhwc5B/9C3VVykdhHZRWUazltwZwvA+6PWnPHAzwOsgSFTu+Y9fp71BRw3ivWbbTYp4pbg/v iCmAc9eRx7CvFtVv7a283Vb64RfL3yLE7EbtvT8PWkhvY+dfiP8AGzR9E0K+u9WkjD2w3RCKVxsc jcSkfYkdGJ7mvyf8YeKIvGviibVoJx9mLOqQiZ3K88nB+6Tw31zUMXNZjdBtmvL4yGAMqEDY3JT6 /wB7/wDXX0YlhZWenW7+YrSIpIKcAeual6FLc53SBd+I9SjFhDLLbW8hSWUofLQkdM+vA/y1fUHh PwRpupRQJcW07XJTHliTaGIPX6VMXdmvQ9qtY7Tw7t/tmLY7RlLVWOS+0D8f+BV478TI49Vsm1KF dpjjEbIpB5O7Bx6806misSfNa6FqKOs0ums/OUIXJr1jwt4NWHdd6gvlT7AyRE857iuaW9wW9z22 zj+yXkP2jdHCIwC55Ucf7NWotctZpEEeEdzgtjkEfyrNlo9W8N3F5IrT21wBIq/ePcV9UeGbnTrK K0up51nmUB9pXJjGOc7up61k0bLY9bHxEjurG3tbGNreJB+8eMptkPqCDkVmXdyL+NYoZ2Emf4T1 +tR1KRV1C5uYY0iE3mRxx/fI+YH0/Cvnz4jaylvaTvHKZbokZUtkjoOKTQHwx411G833d0zMQzEj LZI/hwB2GMdK53wp4K8QeOtR0rQdLsmuTev5fkoCWYHv8vbkZ+oq6EOetGIq8uSlKR++n7LP7KU3 w40yw1LUDBbXTh2Kx26Exkg5A42g8/oK/RWxs7extI4LdW8mNf4jkn1r3I7HjPe5rW9wRITC2R6M eKsQjbGY9gVRJubI5FUSXwhMEqg5ckL0A4J5P5fNULWxjBTcNijI55JoEJAspJlYMMA4PHFQxQux bzpNwXGccbv8KpDQ5ZESS6SNAWBznj7p/wB0CtK2iUQZX/WDnBpsV7k9s52kRMDznjnFaYUzQDYw yW+Y+gqGQAt4UhXy1JCgkDnj1NJDsmVWZNwHRh0NCGtxh/fSGA/KuC2/GQcYyD6cEfrVNpGjBZJQ zu24OwGGGf8AZ2ihlkkkPzhoiyMRg7zuBOfp6fWrLxuu0SP+8YZIAJ47UNWA0Ps8cgDvebdw+bgB D+lWLeNBEqyn5sdQcj8vpSegInth5kriFuFJO4gjcPYMuam2wLJIkiFiw+X2OaBS2JlVlBGWCe5q VRv2iNuAfm45NC1QpaEyvGoKMm3B7DGacbiCKRVx75NS9CRrO0oDRLllOfpULRl1UhP3xHIPf2oe 5pHYciDCuyMQDxkYwRTjLalY1uYy0SN8yknv1P0qkBAIEMaSYDy9O4K7CcdQp6H1PetRmVTBGkyG N8HeMgDj6Y/WgAjZdwj3fMD1B61IswnjDBwQrbDxTESxyGPcRHubbwQec+h4qwflXcSNxG9t3T6U AOWZ7fzI2jLITu+Y8hCFwP8AP96nqkH74vGecgxMdw68dh1FIURsM0rlVkALjncOD19K0ZRC0RJZ y4468E0xWKcajJyh3N78VrW1uRuLN+7PYdaQ2rkkUSrKY2fIwWOOTirhZ3jKwP8ALjHI496B2sSw xBhJ5hI+XBPZh/kUMPJwqN8jAngE9KEMmiYK6CRiC2COOaS5Zd/zK6qflDrkbj1AP60ASGRmyzIf l96kj3BscgsMgg8/WglrUmPl253vIzueyjH4GqUrMZAsJGc5+v8A31QHKKT5ahgo831xyPpUKEIN qwttQ4+ZvvDAb/7H/gNBLI1ln8w7oyyE5HP6GrURAjaTfglj/wAB9uKt7DZFOwaGRI3O7dtJzyn/ ANeljj5dI87QuMk85qBFm3lzHJGARKp5LKQDnpjselRNMC5j88CQnhCHBH/fQpoCCeJ3ijLMu7JB x1NVIpwMxSjdLuOFHf3+lFtbmhKLeNNrSL5ajJOVKk/hTpJWZ4XjKrLGcqxUMQf+BDihoLkrT+cX lbKuxwXXgZ/pUscrKkjGBhGjkRtg/OPu9aaYiTyI2ZJI4s+5PPrUbvsQbFB5xzg0XGXGCLGuANuP lx1rPEbb18zIYcnA4/z0oZL2En8yNxKzybEHzRqSN4BDdO/Sq73LXDMjoFzz1xt+mKRJYgiMSqqn EZGMHv3/AJ1O6wT4Vt25FzleChzQAxBPGsO5RtD+nJqWSJfMMsp3I/HT7tICsx2u64yo6Zp3mMqK qn5RQAqRM8blm2nI5Heq0sRL5dc9hz1oKWxMRGjvGibZXbzDjt6YobYjkoT6nNMaVhwePajBjjP5 0x5fLICjlunOKQyLDyFWRjgc5qby3aVpHyHI9OGoABEzB1yGB/OiOR1yVPA6ccrTB7kZiyySmX7j Zwhyp9x+FSeb5sf71ycuThmHzc7gPl7Y/wDQaBWuiwJFaOKJxm4JOWwAP89Kjkg3B1dM47+lIZTW 4ngdPLUeWGwzHoR/7LVgjzpCzjknkZ5AoM7Aq+UcKQLYDOD3Pr/sinyMV2DIWMDCgnApjuKzfNFN EQEAG9MA5Pel3xzbWYdTkc0WKuSKhV3VI8v0wT/H/wCy05Vdc+YxWYHGc4NAxNryKoZtqZwOMg01 UEcqvGuTn5cUgJ7iJR5imUkE5PqaiTEtwgkwcdcnAH0GMf8AoNU9xsW5ilZla3X5+meMnGelNCzs FZmzgdD2NSIngMiZkc5P93FCkyzsVb5Dx1xQBM0UcUbMq5Y/nSQgvE0mAydMgdM0AQqyRYAU5z1J qZVSJHLsS2CQTzz6UAPCusSkkZxuGD1q66o0cYhLb+rELkr9Pwp+QFaNIxNcSKV8njbg52/j61Z2 SNsCMuwHqDzSAcY3iBy2dvI4qvEpVAiZVM7jjvQBMIwGAGN2M1EkhkR4yy+YW2ouf6+lAFzy5EC+ Y25BhcgY5xUbRESOoAVMZ354pgWpLdsJJAy5B+6TgMf/AGUVCN7SIsqbUGeQMh/z7U0AyWNCUUYK 5z8oxn/61RKZI3eQgZYYANUBNJvaNcKdzDBBHAqdo40RueRzknpUsCmI5eGQFh229QPxqw0jFVMi LGc4H1NSBohVIiw5wpO3nqPf+9SuIGeMSAB+ec8mqQEyCMqvlMSR1+tLseQuHHyAd6paCYsccqEi PpjjFMUxlny26QgKOaiWgmTIByuQfcnpUESpIwUxgLnrjrTtcPs2LIaZWkRFwueB1/Gkdt2QoYHP QnJH41Y0MmaMnYIxhhnGck/pVbzi2EQbUQ8ADApC+0KZdm4t1b1FFp5UbGQnAGe3egolVplEjouV PYjlalildVOIy7Nx1xigBxiKXJGR5IGVPep1yctuxt/WgVrli2Sa5SaAWjMh+U7Ru3Z9R6VIolRA qx42E4+TG36f3aYfaKw3Rs5jiPTJYDgn0rQRN8Suy/viOfSgTIpYxCUZFPrwB6VEZFKMgAZgM8Cj qJDrZVZHaQEsRwp6A1dhSaOPjgEcgCkDJ44CqCJ8hVOAO/41Z2quGUHbnFMRMUi2scfOOH2noD6Z 4p+UZV2MDu5VgeoosA+SAuFwx255x1qsA1u4wf8AEUC3HvO8J8wpvix8y96exTJhIbGe9CIKoX53 iD5h2ldpAxzVvyvNlEisMKBn2PtQOxM8QIDZGM8c0M6IG3AlyOuKpMY5JI+Uz05z2NPEMCEybfn3 UR0JJVePZuA+cdR2pZJ1AGYyM+9NlETsoeR/LQRqRgjljxTyoljj6AdKNykQThoyqRg7VUZIOSTS MxKOkiYJHINRLV3AgDLhVRSc9fQUqPhApOcHOB/DSBluJj8wZsAgHr0+9mpXAbHltlAOme1XFkD3 80oqwtgk7eme1SeVJEm6RvnAz8veqW4iNTGwK8/gaRht2yKw79jz+VADJmG1QO/UH/P+cUijdsGe euaBlxXMZUuRgVG74kZscdRzSbEEu9ouuHDZyO9BZ8gkEDqV61K3FYXy0VgAxbvhjxTXkIXaqY9M 96sorlPmKhDjHXPSpGPmFxyEHH0oEf5TdxNu8gQxMsqvj5X+9XS6Uk9pcoMKzMuTjnNczR2ydzpJ kdiC0S+ax27tmMDt9KyY7eASsLgDyh/eGRWkdDnMC/s7D97LLcoXbPlbTtFcRcatPFb3NqMs7ccH pSfQum7JmNbrLbxGWRzI8jFjnov09K0rW5u22280WyJjkHpuHp9aOprDYvJBGksild0uP3ffH1/C s9YvsErymQqvXBPetFtcn7RBLfTq7uZB5RHK45p+mXcU+ovdxxj7MFw+/wDiI7D+72+aiSKjuXYL O/ls5pfMU2kkhztGCvPA+tW9LJS+eyuFItnGCzchaxFY2HitUhuGLARBiIgScE+nzU7TVg00yAW+ N43Mc5zVJWEtyG+8pvLe1tj5oYktiqscTytA5Clt2cH+Kh7GidiO6mkjnZygWA/wdhWfJCk0ZKqW J7ZqbWDmMEWwS5kkR2CgYxnmrdpETPBHM+I2ORmqfwkt6lmTy5LmRIEKqgyfM4B9fu11Wj6gFJVy VRRjKjJFC+El7XN5ZEkuklt7vcy/JjGAw9f9qoZZLk6gsqAKFODnv68UpEpe6aH2xoHZNwUOpGc8 5/8AZRVO5vLXdHZyrm7JzFg4Lcf/AK2qPtWLWhiXmpPCDHIyqo5IYZYiuUt7jddSyNGTlsoKt6Iu USvqWpG4NxAqARBcY7k1zcsnkwKlwu2QnBLHp6Ae9aJaXM5D/s5VE3KViwDuHJFJp6xXSukL5kU/ dPJArVCcSG5uIbe3IyI38zLJ3b6e9XIby0u4iIWyyKCynqBWc3ZCS1JtPgs50mWV3G0klS2SRngU SmwbbECR2UvzioT1NNkZw00R7JJZFd0PysvTH+NNubJo/NfIVhyoPrWgdDAg+2RXUd1GVdACXXHK H/Gtv5tRt7XgrLHIS+F/1g9/QCl9opv3UWQ8sM6DYDaDq3qfQe9bFtBvJZ0Itgd2AOSPUetJ7lLY 6mKzt5bdTET55Odx9Kt6bayTXKLHAq9QWcZ3VK2JOms7by9RMSrlUCnp3710bqkTExR8Eg8cHNCe hKeg2OMS3TeXbyKAMk44P+JrqGs0PlbIgQBhsDBP/wBem9SXsIkDZxhsDnBHSpbe2i3nCZYcYI4N K9jOW1zSMRt5fmU7Ovsa3NNhjkPmIn7vqcDGKdxne2qRyorWsGDwDiux0+xSOeYmdCAEZVI6cdDU 30GbP2aKEOJEyx4wGxjPf2FU59jtstR8x+XBb7xocrjjqUbS/upJXiZFDDgDuPY+9bEcU0k7vG4E iLuAHUUmtS0iP7S8ecueuB65rR0+GWeG4kTAQgqd/QY6/jUlWNSzheWQx4JGc8cY/HsK6bS7h45J UCqGClcgfMP8/wDs1JvUVjttPYyOEVAXVeSR1rV0+OYeakgDKWyFYZxWbeprFG1YwAQ3NokCqCw/ ec5X2/T+dacthCypCzK3+wB39QaycrmiRaeJoIwyx445AHQUCNXCkn9znJPv9aybuM2ysiWNqYnU xbjjBwV7mqmpXYK2yxyDp82Dx7VKZUmeeandzfaCYQ7lcnhc7cdTWZcss2yeWP8AfDoVON3sRW8F 7pjMlM2Ecb8SkYVasxXf2aKMXD/IcKOM5NbIzLM06M64YDtg0PJcov7lgAx2kg1TkFy5BcJBbGKX fI4OVPetJ/JniKSfeHAPrik9iUtTMjdYLgbwvlE4G7t71cSBZ0mn2AShv9XIvJPuO3H/AKFWZqti 5p1m8t8W8oqgOSWB+YVrWmnkOzRwsqbnfYeSBmptoarVGrFpUM7wXU0WyKInOD97Ix9K62PSZEjD xwbQOSAASaaM5I0rOyadgILbgDLqF+/XU6VoDs0jKpEyxkhZDgNjt9adyDuLPRd6RtcRmN9oO0Yy Pr2arMunxxOYRG+0INzswIc/N0GOBjHrRe4IzhZR+WEVMKmcccn+Lk9zXN6jeG3kmhVgJNhRmzzi qWw2cJcytP5iRRfMo34B5I71DGjRoXaP5V+bk1pFXJWpn3wZmKOoMbAHK1zN9bqYpY4sM+M4z0pE vUyQyWsMzpKGUDDlTkMKwnulJWK3Hlpkkb+o/wDr0rCuU7m8kO8OwKBSME4wfrXOXEsARZzOGYrv OD0qGyFsYc8sTqWlz9m6sPX3rm7y9adxLNymPLQY6AfzNK5Sehj3kkaMgD44wagjUOm0LlG756Ch jHfc2EsSinGc1JDeJywOQTg9eKncRajA3lo856nI4NWEs7hT9qSRREQwII6eh/E0PYC/axRopYAn d97PXit2W0WaKDaPnJ+XLYzVIpHUWao0axyZDqAM9zXUWirAozJnPAb0qlsBLctbReXFJMY7jO45 64PtVC5b7RGEkIaNScECqEc7LOLVJ4EVlik6EnLr7E1ivDPJuLsQo5X1P+fei4WJo5PJidoyysB9 3d1qnJefK+EIYHkk9aj7Vht3M64Z9kE8Kgvv2vnnIwcYrMuXunlIgtd8MYy2SFwT7t/nrVpCHCGV 9rIQD/EMVcjhCxkqhMh6g0iGy3DsCK6sqFjg5OBUckpLmPBDDuDy/tTQiyk7KAFI+p7VZhnYbQhG 85yzdePSkV9m5o2sfmj7S7kIOwPAPvXQW6B4m3Lub2PQii4XJLMSxCcOmecqdo+WvSdEWB7dUjhZ WbnnJNKW1ykz0XTLJ54vkj2pGNxycfhXSxLAgBlT5BwyjvQviNCaPTd0LTLMrbm2gEYK/X/4qlij jMpk2hoFGFAHU+oqWBy11FPLPM0w2xxpyMDgZY5OOprg7+Ez+dJj5f4cdqmw47lGC2ms3jhiXELf Nz6+tdBaRPcPGyt8wHzAHI//AF1Vge51FvAXUrJ95unHNbcEUj2/ltBgHsRyMVaJlsZkyOA4mOyP pvI6Vi/ZWkuF3zOw7+n/ANjVozNCZo5USIA8cDjqaepEKSG6SXIGQf4R7E+p5/75o3Jbsaf2iSdM uGjbHEbDlR71RQsYHhLBsnk+tOwJke94JQgIBA3biP0qOWHf8wbIY9adiilJpqq/78blX5hu6GoT p4kRI1J8zru7Ghb2AyMBM+aP3QJXPrVG2uHZGjDYJJUybshce38NXYmW5m6jLL58bTtm2HdTgZrE kJVp4oBvbG8Y9KCRILUxQkBUeSRSDvTOz/6/X86sy2kjwI0HATa+4Hk46kVD1AqxLOMsTlD0Hass QyRTMTINob5/Xn0oSGdDo4UeeyjdGQFzjletaMayTS+UfulsdM1p0uUlqdrYQy24U7CCPve1dAkG y2gmCbWkJbBGMVEnqKQsqyRo10VII5U9ga5S6uTLcM6lCQQHHUVNyTMuQ3lM6EDbzk849/pXnuvw +dJFMJGEecbFOAfrQO5jJBKHfzgVyPlINXtJt5UlUq4IU5O0H5RmguOp6/pNzGfJSOAogO3djA+t bskkYZkiPzE43E9aHog6HJ6nLO5WzluMR5yx71wGpssk8AihIizuDE5JPPt6UMDhbq5uHuponf8A dxjBIP3z/hUunwNK7bIyqAj5j2/GmJHW6ZBie2SKLMW/OFHX+In5fxr6E8LaeZpYY4gMP9x93yoc dCKGWj3G2CiARyAfIcHA49q5LxlqJhs3SKRFbIG51zgHrgeuOn13VEkUfMnjLxB5rJb2kLmPOCzF f3hHpiuCXU45N0c0ZMZPJHX6VKHcyruV5r5II4AlvGu4s3Vs/wBavWbvA8asuY9xIZeBTW4j1LRb aMW5zIUIG4Lt++T3z+f6VvSSjYVCYyMU3IDyzxLYPeXEzNhRgBFxgtjqffmuO0/w9cee94LdH+YG JQT84/z/ADqkgPWdPsY/JhRkYSKuTu6//qrZ0mIreuqW23JALAflz3qZbgewaXotvbKd6+ZCQHPm jJDnuD2Fba6fArNcch8BSW6Onp6UrjRj6tqXlkQ2xAtwNr44DkH+XSuKfUpIvMXeSCxYA87TSLPE vG+r/YraS9+0/MpLwsx+6/8AD+PWvh34h/HXTPD/AJ0czG4WM75VUEguezv6fT+8KBvc+Dfib8Sp PGd48W1g0knmcqAOAygp/dGPxryzRI7Y6j5MVu7Sk/M4P8qTRnuz6x8C+F9OZDqlxZyq4XCEnb37 jvXWarpR1VBp9m4jiY5fyxgqM88L1rGbN4bH1B8H/wBnbxnd6aHks44LKZxIpaQlSH6ElgADgLlQ eDla+glsdF+E+niF7JLrUBKQXJDtI/3eN33FH+NKG5rLRHzV8QvGsr30l0sgfU5MiMEAmMew6Yrg THd6usEsw/eNhgvYH1p1NWZHoOk6DY2emY1S4iD7d6ByAST8pK+lYYMcU8kcM3mwg5Dg8D/P9K5X sPoOn1G6EtyHI+yDDAp/F9fxqBZ2uAbnd5RBAUqcZqBpnp3hq61m0tZma+MUT9BtB3j1BPQ/7X+z XtHhjxELxPKtrmSVogEYby2Prn6UmjZbHpen69eWiS/aIAigfL/tCu107xckjx2z25PH392DHxwC Kza0uaEeta/KIzCv+vzwu7nGP8a8X1yO4unS3YZb58gjc7Z68enT/vqhr3QOl8Efskar8RZreW/t yhLZjeOaWJ4EzwZMdf73Ga/UL4B/sseD/hRALqy08XXiNSB/aB34wMHA5+XOC3NdeDhaUpnHjJXU Ydz7Khs4rYwLny7YA/d6DitBIAMSRt8o6e1en1POexeVv3TbUUyjA+bt6UkayF13t83TBGMUDLYe ZEVVf5lJzntUibrkMxGXzn60iZEUlolxJGZJWWMDGFOP/wBo1VeaNQUncJMRhSqnEuO/FWhr4RVQ xBQgO3kOwHDZ2kflg/nVqHfc7yCnlrjGcjcRSkFrGnHmIYC4lbnaB+taEWyOIKo+ZjzUkksuxfLL gycBlEauWH146CklYMIWdTGgzhVAG78PrSQdDNkmmKMZFZYQcdRjH0xnP/AqrXEiOA+4sp6g/pir RSLVzeQW0CrLESWQAAAswq2oS2DboyZCozkcj2NN6kyZbYIFRWkAUgOf9r/61XraSKTcqjHOAxPW peo0yYRzxN5scXyq3DEZzUkfnPGstwrbSd2duMjO3igfQfv8twqwAgHnH8VXR5chLLEVJwC2evpU 7IHqRPCzTuEONg4U9WqZIywIYDOeMjmpbuSCSQQyeUHyWGW/2eaI72WZG3fM4XaueAvOe3fjbzTe 4+hOwS5KxNMQfvYHeowu7JkTodvByG/+vVFEYQxuxYkBeKtT3KSMhEeFHpTEixavE8RCADLE52/M ahE6KzRhTtD4bpQBN5nlwbQGkl5YKiOW984HAA/iq0k5lRSUKk/KAe+O9IbGtIxa8jkPzINvPOQa jieaNVRQS56Z9KANW2jY7SVBKnDt/SpRHDB9omXducjO4jt0pksUnIQqBgHdye9aFq5knKhGZQuO OhoBuxN5bCUkE7f7op6NtZ44Y5FG0b944J9qQ73H+VJGAwVvK8sttAyc5GB/P8qtp+5Qq7BWxwCe RTQxsLBpDKqAvkDrxn0q9HIwgMxOMdVYUAVCcSKyuRxnPr9KYGeOJEif5icZxk//AGNBLeols3mI wLFmVs7z3zTZIrlyrQOFk3YywpFXFnm8liCpLr1AHeqskzqyqYvlb/awaDMnkKx4YKQFGemTU7XC BSfIw4GcFCA3/fVW9gZUhfzFkjDYXJkOMYyetTbckPHnjrjvSsBOylkGHO4DPBpBGixmOSBC2eZM fN/D3/D/AMepIBktwm1kCZYtnI71TjnjEhVyGVsgYHpVW0NBNjsSq5IJyMnIqybdxgIg3NycDA/z mkxWFWGSCJFkX589BzViQThWEciqDlzGBjP0H8NKwxltOqjeYycc/KM5/DvUkqPKGyMP9OlIBj3D bUt1bJBxnHSoGUOQJN2SSW7Zpiew2be1sGXrESxHUt7VDC8cgaQxMjYBxJjjj2P/AAH/AIDSIJGl KM2WC5GUBPzH1wF/zzVhQU3S5AJ6jOfxoAer+aAhUnBzTbmU/wCrIwuenc0AQNK6siMu4Dv3+lTI xiDblP4jFAEDZLF+QApGCWxyR0H8R4/8eNOikkLFpCBEB1z+lA1uV1uPMP8AqHyGPyng0ySRi4k/ hHPuKCk7luNFkEIjZnfb0xjd7j2ptwTAkZYfxYyf4aBksTeaoyw2DkDpj3pwdmA2NyOnNAFfzZ03 Ex/PjJHTp3pVZ/mZl2q3I4+8PagT2I5T5boSAFUFiRnnr2xUW5pFXDKpJ79T9KBXsi8sinMYU5Ay SaY42ssbffY5HpQUQLIIZZI1gZN33ywGCfarTXZjIwARjsOT/wDWoFYZcSvFMBKv7sYJK+9Pjd5B 8gBQH8RTBIkRkh3PEpLnkHtUisjqhIEZY9z0JpXCxJh1iXzGXIY7yFwGyeBVd1RWjjkJLkGRckni mMVJ32jghj69Foid1YyyhfMIH3eA2BtJxTsANdIIy8nzMTgYFSbvMTIRhlsAgevvSe4MDIVkjXcO Txk+tTCX96VYEpHycUgJ45I2UlRt6kDk8e5+uaaoE/meWfmFMRP5MY2JtwQOxqMwbHaQR5X+EDjH /wBekMasO9glxD84PQgqRg1OyFHQEYiJABoAnkgZZFk83LH5cH+HinCJ1VkTDN1AYZH1xTXxWAkj ijaBNoXO/GVXkH73NTrCqsJEf5ccrnn8KQDJQqg5Zt/bI4IpFCMqoI32kbs44/P0oGhi7TINwbeD geho8lMhlUBjznvn0oEOj87fLC58tjlEYjdknHzAfTNSrFK1xMAcxphN20qJCBgnn3FAE0ayEDY3 Oc/OAQp9RxlaZC5JkDxn5c+20/4ZqkBA3MuQCWHzZPQUs7fvYpSrBGHp17ZHtVAWWO7DoSo5GOCM H13cUkvy2pUFRKWIG4ABv4scD0qGAmwRYWIHYemSMrUBRVcljlR60gLbIFVSwO4c/SmbUaFzKpdc 5HODn6+lNAaKyrFbiAR/vW/i9OaieRo0O2QL67h96jmuDH7hIke1T5n3lOT8pFTb1DswgxK/U4xz /wCy09yGNjjAJlYkEHJYnninI25ztXJPoOBVbF26DJ1zuiDHeOQQePpS+UYwx3fNjgA5x+NA0QtO zbvJPzn5c46etU2kjLBmO5lPODjNAiRbVAoZCTlzJz7/ANKcwt1+TzG83qM9AaARbtlglDyGdvNX hVA4ap9xXLHqOCAKALSuGzEB8/cN1FNaKcLKHXgZwfX/AOtQKLBI22ghCHxzk/erQjuVEbqY2wB9 7HB9s0hkQZmySCueQPWnxyxtHIpBzyu1h1H+FMT+ERHLKXK429Dmq0+39y8MIzkngYzVdLkokni2 oCjZY8jHGK2mcKN3C4GVbOQakGTRN5sUavn1BqdUaLcXbAGSuDwRTEEamNNox8wxn60/7PhlCEGb 05HFFxXJPNX5DsOc88U1vmDxY27jg+1OWg9ivHblXAdmLKchR2HvUs1uXYhQAueoPUUkTb3iOMJH Iqj0+bIqUBjuGNqls/L3osVYVVZmeFcqQMhuvNTMsYI8xd3Yg9/++aQDBEiO4AHDZwBxVjd5ilWU AZ9KdyBHiyyFfujrT3UD5nQlegFUxDdpHOTwMcU0EruVm4HPNN6FojWaFcurZUc5BzUBDDezAFSf lIOd38X9az6DGq4jcBl/d5+bnpUrpHIvloG2g7iwOM87scUAOkVEU5cEnjrTAgVQP4jyOen0/KnY hlhHYAxg/PnIIqx5gJjjYkIOOT1q+lxE0sAUZjBznnJqBI0yQSSQc9aYD9qM5k7jjrTpHLMSCNwH 0OKBlZXyAFXavsKFXGSze9S0If5sa4Zj1PAz1qWQxMAdvzE+vSmthjHwY2WOQK44xjNSS3Kqq7hn 0AFMCLe7JvYYHpnpSfIqEkkuecGgR/lIrIxkXa4Ck/ez0rdhu5Fv45RgIW3HHA/+xrKKsdk3dl+8 15praZGRhuOzHdh/hUJvUvLGPZ96PqxPJ9j9KGjC1zkdUvLaSONo5A0qMQwXqv8ASuKuLz7GyTsp dS3ei2hcNjRt7y3vLZlaNvPzwy9D7Ypz3k/nw2UpzEBu3AdKOpa2Ls19BbOJRL8pUAEmsTUpVmWM xvxjHJ61ohLcrRLHBuEpyp9Cc1dhRYbm2FucFuSMZ3Ch7Fp2dz0HT1QRq0yNsJxgcc+uKdd2Z8xi R8uOx4rFoLkLLHLarFbvkl8FTyVq9aaaZZ1h8wlh13HpRF+8C3Lt9blIJC5XMQyFxtyfrWFCn23Y fOEcqPn3PtTkKT1JrprCOAxzECcA4Tu1Y1zFGkKyWpJO75tvao63HYyDaPLcNLPujG3AIx8x7VSW KS2kF3v3srYYdNtW9gaLYvINSnaRW2zDCHsTXTx7o9izSA3HABHcdqPsiY67vktGB8tycj5k5xV+ O8gQFmnzK3TJ71NyYbENxcsyuHUCH1A+asaWS4W5hllQlEHD5wT/APWoKNOeD7TYvfScxBd7fJuI A/rXMTeTMXuoAFQLu8oDqO9NOxSVyiIYxHKdmJSRlievtUCRNHKsV3Fnd9zIwTWkWJlW+3IXiCNy MYrD0yGaGckBhEWZSe1WmLsWLxrWSNlmTJHVgOBS6JZqFmluRtixuj4wXHqP71TITj7wA+SJb6FG ZjxjPemH7SfL82PAA3tng89qlfENo1NDjnn+0FyylhjaV5AHtVgJC2POk8zDbQPSrcrFR0ILqCBG XySCM8rjpQts/wBlDrGdmcjbxkVBouhPFB9qtXtRIEQ5GR7VqxJPBFavMC204zjIJ7ZpdQT1O00a OJLR/PXDkkba6y10m1t0iXadrLnqcj8am9kQ3qapgAmR9mGA+U4xmrkUKGeFGGC3HSlHe5l1Na20 3Y0kiZDg7QD0NaNrCEYyScbeTzxiqkSmW0igu1dEk2GrUemraoZFKluuaSEJLp8lykUquBGG5PYD 3roNFtmWORZnG1TnfjAPtmqWxSO3j3RQl42VX7FVC/5NXdEnxJO8zDcOR9alvQdjVW4eVgsgJUnC c800WzIYwXwd+/AHP41Ddg5S2bSNZ7cxjDM+5zWrAvl+fE77Bn75PBoky0VhbMhkkBDw5+V8fxVp wQ3P2cJuJgXnryTUrctG1YJLk+QpyAM4HatuCynmkt1jIjbdlm/v+x9qTY0rne2Wm3kEkZhjd4z9 5wp2gfWvRbPToI5hMpJnA28dOnf1NYN3ZtGJcm0ucTpJb229WGW2nANUTaSySSReU4lTlxjoP61P U0cTauU3QYXIl2jjGdwrHVFWBopHO4tlF/nmoCRBNNBHEYPMYOTzzxiuauNREymOJmDElenK01vc l73MmVJ2ctGSvHUnkmoV3Ntt3TLpxnvmt6ehjLe5GBbxRXDXCjLc8nk49KltrCWVJGd/3Ei4x14H zfnWhn1Jp1mVNjqOH4YD8qnthdx43EFAdw460MZ0T3NoiLIFbzGPzf7P0rP3ysv7th97OR0IpcwJ WGbhHPskQMW711Ok2Kvne2ISOB3qLmkTqbeARsF2MYiQAQOK3YfDr+Y374BjyD6/SlIvlOki02zh MEa7mZXDBX6HHrjtWytqJJ3lgG1WOFOOCe9NaiZt6PpksPk3arujGSCf4/pXd2FhL5MQNuF3jc2W yy+316UGbWpqXEUUZIY/OD1B4NZOpzsNsjKzP0TaBg9P6fN+FLZjZganepY2ztKyiUK7gbsZwP8A HFePatqLG+BaQrLKPuEnafUiqRDIUVVkbzwQhxjBwRVq6DL5MRK75FDqT91gfl/pWpmc68xVZADl TjB9Oa5m6ktzBIS7CUsVwDjI9aRaOO1CRmMaKE8tRsyBggfe59Tz96sB2kSVdrjClTkdjWbB7Dbm eKRJVwR65PWuSv7xINs5J2vwoHRselBC0MyWS5nhDROqxHOc/pVaQQGxeORSWYdv88UbFIyLmLek YQ4QHIKjkVUmWS1jP2eTco4471LZYzT1EgAuHKqRjkfdPpWpFCfKK+VgZPOB+lPoSlqaUUQhWEPy W7etXJmaEJHdOFRnGADgtSZI+3iMgLTKSB02nH0rdffEhkkX5VOF/wBr6VK3uI1LK5ilWOViVctt I/kRXRW0qM6zF2CA457VqtwNSVrWWBvNVVkzxLnp/wDWrFWSdblUtp43tY948zYcucrgjPbj/wAe qgTuZklvEqZkJJRi4yazLmWQ5VWyRyFA7UCsOnaKG3DBcqR83qDXJ3MqszRSqWjI7c1PUtIdLAES 3YF1kVgw9sevrVqWQFXHQkcY61SE0W4LExwQzlg0be/JqWCAzrcDOwj7ue9O5MtiGVAkSxhcsDwC Ki1LyyitFbFnwMMrYzTQ2FkzzzrHONpHAOOCPWtWaKJ3QRgkE9V70PUl7GhHELXe5AG4ZCgctXQW MCfZZbkuV2kbkx0z70WGnqdTYWsZktkUllzuOT97PQV6JZ2u0K6qMDnB70nsXE7zT/IUMVk/dN3B 6VqLGgD/ACfe+9/jWctyyaK+hkNx5cg2gYXK/eNZtxdNA93FGhNwoDKOMA+n1qW7AUHuHuHYfZ1X P3lx971/z/tVz0ek/Zo3G0iMAlNx5xSWwR3MCSSETKJACp469Kv6NN5MkyumU+9t6eZ7A+tWhnaW 9zCEi2gKzcKv0q42orG+Yz+96cfw1aIZh3JSRpY3YkoecntVILuU+U37vpn+7VIhhcqRA0LMFuic RlW7DvVfeWREmkaRBxluSCPf+KrAm+1iZVTed/TJPPFOMywxlkBDD3o6gx0E/nRrIxQnoPUY9fxq /Ci+XNIZcjG1cfwn6U7AWfJhe1K+YpUZXnk5/wAKxLhYwPJBJQ/I2GwR+NC3Je9zldQuoo5poIgG VTlQRjNYaXaJKf3YHqgPB+tUSZ0izRzypBAzWpGVL9wev61ItoYMS7dxJC/KMn6fzq2Utjbgsnj3 IICzyA7ZMHahAyMn+Hp96q5sWh2vIQYmBBweCPcVlIG7mJeJJFJIpQ/ZwM7h2rJjSRrggBtjDoRw 1JbkmzZ3DQRRW8ajYGOSBk9efxrptKjkNzCodtwO5XA5XPTr96tGWtT0mCzeSJZ5JlRgcvjjdWqI GU75WzEV246AGsxnK63eGFCu5jF90bSMZrz68K75DEclmHCHnNAmQSz/AGiORWRhgbSOhBrBuYo7 iCTywS8fzdcZFIh6M5ia4kTA8tlQHqTkH2rorOFmRJNhOG3jBxjj/wAeoKj2OrtNWRXWBpAuOUyO 9XLvUp3kjjVSpJ6g/wBKZRm3ZleSQsGKKAGfoDn3rkp5XE7pjAU8e1JjOcuLZEklm2MFLAbup68D 61r2cCpBvli++MDByGz/APWp3Edjo9ulrEZA/X7qkcge1ex6FHFBPbhJGUA7vkPP/wCulcaPRl1l YLaOS5K+dz0PQZ4z74+avF/Hvja0eBLZ23NMSNqg5Yjpg/w9Klss+cb7WZWdzlmYqVD8fIexG6s4 XoeKNxIrsCVG3qT3/GkSlqPguHn/AHwZVUnauTyMetdVpNlPcXVo8jMkUT78Af63HQE+lCBayPWd PgDF9jlURPMG4cA9kyO5qxqEi3EMaoTFOG3LzyD6UDtoc+9mzXMczsQBjPPK+4rTtrcSOFSHIKFl YtzvzjGPp/vVpcZqSLK0RijQFx8mTwDU+m2d3uXeQMnPy/41EgPXNGGwmOdsttGFPOBWjqk8XmBF TaxUECpehSV2eYarbagLqRwAFZsrljtx3/H/ABrlNSubLSYp57iXcvcE5znsD7/dpLco/Nn9pz4w 2WmW17eJcupgkS0jtYHBkilyzfw7dp2nli3rivzR1DxBrfjTVL1Yp3+zDHVRtBPzDOO/+Fax1QpH T/Y7awt0jktw0zL80hAJXFW/h5oN5qXiW3gSzErCQSRoi8hCeST0wBmokKKPvPwv4Ra8cWssKRIY yyBx8jDpwO9fRnhT4OeF7KZ73XJ1kmaNBFD5YCQkdSe5J/KuaZ0x0Ov8X+N5PCWhDTfD9tKr5HlM gfy2JJ5JxjJOc8/8Br428baprc32iz1qe4NzPEd7sPL35csR8u3jPyhaUBvax43LaatqNwu8yBEw rSFj5iBenXmvZ9K1Cw0vQnUNu1Fs7GbHp2+hqqhA6zurq8tSxn3NnB3c/l/8TUr2ckaxpEHznd16 1yPe42rGxZRJOnlyJgYO8+9WLaK3jg3w/KTlTnnFSJbl63N5L5Nukzlc7Rg8ZNey6VfWvh2xhku1 JucBSVGHYDsfpn71S2bJmlJ4h1LXgYRtFrvztRc74/Qlq9S8Osb2OSYQeVKOGTfnjPB+v8X/AAKk aXLF5YoZWnlkfOMYB+Zsdq+ifhZ8JjrUlo97OYbq/wAOtsyA3MkUYySo7KCeWPt9a2oK8zGs7Q9T 9IfCHgW30iK3mucrdBPKWE/6uNOnTueB81evabCYxHLMP3S8o6KCQen8q9PY8yUi8LZ5UQ7tvPUj Ix6VOAwJhiP7tFLsxx/SqIW7JoBlopGUMp7Y64//AF1eki82MlMNG2Bkcg5q0MrNK2SHbzE3H/Vo QRjC4P8AeOQfzqVLkcpFGQucdM1NjPYS9CCFJFk2AjJIPJzVWGDhpUAVyehJYYB/mR/Oi1y0T3Ad LY72/d9CUHH4Vatold7ZkJ2BfuZ5p9AZvxsqyq8aAy42k7eQKBBJBMzkfucYGevuKkgQxfOH3sxY 4Ck8LSSNLJG0Qk2MO5GTQBSuXb5WdB9nA4DDOag2hBHdR4ChgBzyD/kVqNFpldpIbhCPtHGMD8sV MJUDkD/W9TzRcGWTGsjMHYFMZKAY59v1q9DKqRF1BDAjaOoYVDGtzQhuHd9+w7uMccCkMbBzIINx OAzM3K4DdOOnRev8W6pGyzubcjMAZQAQV61NGXIJDBXHORQJ7ErRGDcIY/3r87v7p7mmJJcLLHOv JBwTgYFRYRLLAsnkXLw7QSRnI/eVWggkBmeQGOLP7vJGCfX/AD/dqhCSLKJlxIMnKnZ357fkKc29 GZZEOxhgY7H1plPclCAyeSpyWX5RnmmMsdu8ockylRtAHH40wjqLG7k7VmQp/HheeM4IJAIH+zVp VFwEO3Dgn5iaRSHwp5UpULk9ee3uKcs6OY3EZbB3L2z9KSAsu0rhgRj+7zTYw/2aUiPKE43Njch7 44pgWo5PLgXEgDbuAew/4DUsO90kMjHysZyD0NMhlm3eQKpMeEzywIOK04W2YKHDdvfFCEWwXdxu HzEdhSiTcu0LllOSM9KCkW1kb9zI442nnPQgrj9M1VknlkmZkTcoOGbsHPOPakUhyyRqCgcrITk1 MJ3y7GMtCo69SB71X2QIZmTcZFBAOOScgU8yMkK4yJCCAQKGDY21WLe6FtrbclSen+J5+7V2SSJP 3e0lx3NK4is3kylZH64+6ehqrDA7u6kExryOOvtn86LkJXJfJKyordycgnnj/Iq7tkIkfG49QBgV T2AjbMeJHjOWAOePyqz5qYAP3DyMdKhAV926cbFbr0z+tPMm1AZRhsfMPQ07gQ4hMeWUGTggd6pG OOVjlD5nT5eq571oaLYGnlikRVTKYCjJ7/dHNWZJ7mIxxbRjjfk5KE9R/KokAskmEjKnLDI3Z/pV fLOVy2184PG4qP8AHFSF9TTit9rOpkDYwQwGBRKfs8ksEj/v9oHBzx9aYlqyizMnlzoRt7d91VjL mRGdsKx2HJ45pDBTIJXU7Wt2cvt9chR+XFTDJmLOSVHfGAKDMQvskDAKxB4JUZFRmcI7Pn5d3FAI mjuhhgqv5rHOACeOefpUcrEC2n27mD5yT1/CmaIe8zySeasW0j3pPtMnluJRvfO3PA257igT3GiW UIrqwOGGR6jPP6URyOQN6ERHgqRy1IdiZowSm1fk2gBt/Ix7flRLHMiL5LIVyAScnP6YHbvQCJIp HiRjGn7wL8oJ6mqUEZnMrSAq/wDeccg+1NAWpIrd4I2jkJlBzTCZIXGE565wxx9aEAlwgZ48SYVy WIPV/THtQkQKyFCGOM/Kev0qWA1pNwG4Ar3BzmgCB4BMGIZTyeuPamBRjmkMsfKhS2CSK2EIZtrO COvFAFJy7eco5ZX4J7ipI4POQ5Y5PUjtQA25liQurMDhfu568r/9arUU223LeWoZuT70ADMhtysi YYvhgrdB6g08tEXRLkHYjBio4PFMERRXKxgJHIHLDqDnAqWOdmDI6jYrHad5Jb9FxQgDcu1tp9zg 1AbcRyM5JJUZAPY96dtALXlM6RkKAo6sP4qcAd6yQl1kHGVPy49x6/7VFgFiiQbGjVRKvAJ6k/Wk YGKSBUcOpbL7T1NSBI7ncFRSF57EVPaRsFZNmXDZznt60ySSV38/KgiJQcsq8A0Qb1Lx5O5jnk/d pFFpY5GmjVm3OeOD2HemPHO3mEdAOmOSfagCUq7x7pH+fqcAcVXkuRG5eMbpQMYwcH2JxVLcXUnj ALK+7C9Dj+L/AOtV5pEEojR2DAYIIXnjmk9xiDICsvzBe5PepmnXCr9xmO3PXP8AhQyokU9ttVkn hyr/ACc4I/zzVdopXO+INwPmAU4TH9f/ALGkEmaMVuI7UDez7ctvJyfzpVZ/LBBHXPSmtyRpbLfO xLknP/6qbLDujfyJmQk5YqASfbkcfhVIBGKHLQIQgG0gnJ/GoI0hEqFm+QgNuHIGefz6fnU31BFo xoxIydmc7T6UwOrAwSA7Adyn0oepTWpHFHI0p2sTET1P8I/9mqz5SBm6+Z70iRcStuMCgrjA3U0Z URo5w+OjAg/+PVS3GKzqjhgSyr7HBp4E0p3NHlSOBnrUiHJJteRN4V+gUDrS+XJKuxmI54IOM1aF b3iV/O3eUQAueD/epGLquFGTnt1FMY2MeWW3Y6bsCpLoMoUx8bskIGwenXp64oAAUEPXEzLtbA6e 9ZDw+VOFBG/qOaALRGyNlJKsRxn/AAq0j+VbAsuXxj60ClqSJHEgi4wXbHXpV+UQMsboCrBsUAtr BbxDLuTmQZHzd6h2vDE8jMWuGbLMzfkB/dA4+UUAie3MkoLSryuRweB9RUxTdlJFDR9sjINAyXKs 4Qts3AjI/hqxDbOTsydqgHeOxoBk0sBVQQcqvXjrVcIWG4Bdh9zmmJMmjtoQ6mWTMeOQO1W47ZF3 fMdnbPNLqKWo+FcHn7ueMdqsHlx8pLAdhTRIiLIpHzdPWrkTSjc4UFh900NARsqPncMMeo9KSMGL DkNvxxkU+UGED5clR82efWmzybmaNcgq38PeiJLFaFGYTYIIULt47f8A66dDIudpGVByMc1TJHRo 4CFmDPjJ4xSqBu3EEc8570pAMTKliDnnrjpUzOgyQTU2GNjdgzoFPHQ0GUOiJk5zuwAQa0uPcZG3 y7tvA54GauPwoAbIPXigS3KDhAjLGh2g56VWWPcVbzMYPSsi09RDAx5yCamgZFQNu56EdxQA0AO0 mSdp6D0qeHC5V8sgG3k/dpkMUs+CIj3z16VZDeY6OQOOuatMRZaTPG4bvQ8d9tRMxQgAYOcdadwH MIiGTkOR1FVZEYI+FO1RyaLjH2zCTAD4AAPI6/jUsqRRgg8Z7+lQIiCpgKY8xAd+tSrHuVXRsEdP SnHQBu1RjLfMPU1ArtNglGXDEMWwO/GKqwFjzI/I5baxGOnQ1HGmJFLjPuRQB/k2WeoO1wLWZh9n cZVm6n6Gt69kurYwR27/ALsn/W/3Pb60SVpWOhO6N+RYpLWzvIgu8H5wx6VUv5hbzlLTm0AGSB94 nrWTYWscZiCK7kikZtsoyj9qxNQMik293ghD95OjCqvoC3IdOuUjukMcJNuvBAOM+taz3aXl3O8d sY0ChXOeD/hR1NFsVZYIL+4T7NLlARksP8+9RutvDJJFI25M7Qc96sXUS2i8m9RmTdZnlstxXWCz 3yNLG6xylQyFqS3La0OiguLUSmymnDtjIZTgZqSd5RfOYiXtDGm8g8RkZqGFiS3ijYs6EBXGMjAz 7ipdPtlmfzlmbacoVB++KmwLctyXLS3KLeQkRqoiAQfMcd/9o1mzP9mvk820K25+765pSIktSpcS W1zeyMyhkA+UAc+9c9dSPbBzYZU7j97mpW1y7+8UI7id4CqfOw5LMahlhjaBpN+xs7sMcmrewNiJ dQ28lhdQWilerP61pzSm8vpZY5sIQCPbjtR9khly3nYhrdVJOOSegz1OK1GtFkKMi4ZeuO4pNBDY vvbGK1eQKChbpmsS6a4aOQbl6cZ6j6Uhkcs8wtYVhLMCNrBW4wOvFVLaaNjNuhKkHC/7VJq5SdiK 9hlZ4TEjbVOcDqfSo5bee9gYyP5cqHgkZ4rSLIbMWYy25jmc5hU4ZsVcuXE8O1FCccc9aaZa6HPQ 2eEkEiDb0OTmnWyvcXFpEZP3OcAHuPaiQ5/EaTLsmYIxUKcbDTtXihjntpIpPl2LuGfumpTMnIvz ysYYXhULL0yT92nafbxNH5ptyZA2Q2cVdrlpmn/YSPbNcF8Pv6VImmJ5axOhDD/a4pFroLpfhqCF 724Ez+VkfMRwn/166aTTIQYWtAxTjnNT1Bbk8OmGGWOUtjceQCTXZ2UJ3zAoT5aAE56Gsr3Rm2WL tjIojyRJj5a09MbbCPPcbg/y8cirhrqZN9TcsZN1xL5uQu07R2zU7w3FxK/luPm+8Bxn/wCtWm4k xLSJ/N+dsBR2Xgn6/n+lbybI4GRkJ54yc0ix67IbUNnJ3ZIHatbTnMQc3LbYWG5c9/rSexSNqKSW 48xYUJxycDIFaOmx/Z4p1lkJcndkj9Kh7DNayeWFkkd8o7bV3cDNaltI1w5kVhjqpP8AFUPUC7KZ IYZpAm+cH5VA6Vfe1aSNYVUMqkBsnk+pptFpGlHavFtyNsWckkV0NvYFsJDH+661L2uUjo9P0ydD bAw7ZGbAUDkD/wBmrprTw1cl5h5L7E+YMVxms2zRKx2mnaOg8nzLib5eSoPyk/lXTQ2EkDLIqtgn jJrFuxrE37e28pULPkA/lRcQQLIbhpicYBx1I9KTepdzm9Vu0t5BGrHgbw3tXMSXJxNsbBI655FI hmHcOywyEPl24z6VmWsMnmKXUnA9eSKtLQmWxauLZjG5DlXAxweoprwSMGkiZd5AHuDWsTOWxZt9 MklhZ5JBvUf3Oo9/Wr4tQlnJtJ+4dpHAzWhn0uUUgeO3QmM7852sc/5NPntrry02pgA84PT3oAyp S0blUk+Q9ic1atL6VwI9pUZ5yuPyP51BS1OlVfNnhhikXz39V6+1dzplozKtsh+Y9QOtQ2XFHdaf o6XTlHdlZVDcLndXRWmlbpV8pmaQHAz60rmlzoV0wRzkSICMYYqeGqXyHSJ7ZD5ZLbkyM7fUj3xT WhLNqznPmKJstGoAAzjj2rYi1BlzEG2zgYSrIa0CVvMw8obZjDYPH1rJ1S8SAFkJCspCFgMr6496 ndkM8vv9VS/cjLhx8gL9WxWIyQyyEluE6HGcU0BTu554x/ql8s4bLZJx3x+VZ6XAN2k0ahbfpt/m f9qtCEZl3fWRhuNqMdzbNvPz+/8AsjNcY7RzQoYyAVY5bccMO/FTctIzp/s7JISxLA46cVxt0Jom kaOQGNumf4fWpB7GTc3hmV4wgC/3lJBHHcfWuZuoY9kK+ZmDduyOM+tMhalP7bE+Yoz8o6Y71K5k 8pdy4DNxjtUyZSRU8xbfzIXG7IyQDzg1mRMGuFck4TO0ep96m4E8kKqFmx8hOB9atpcycRkFdozu 6gj0+tV0JT0uary7VjWCPLKSC57Z9K0IQjRRrdLmTdxu5BpyQieO5ij3qy5bP3WFWjqEQhmikGTj jJ4qFsImF2YgBIpHHpya2xM6fuwcoAGIHXmtI7ga8ly37pbdQSVUbWwfwNYDSyB32Ix8s/vDn7tW J6IVpGm+ZwTCDyB0aq90Nu6ZATGo+bFMVzOluRGBFGo2tyTj1qo1uzWs0iofMB28fw1D3LuUozPK AJGLAd+1WI4o2IMgO4HHWhMm5uIrJDIiRlkUdu1SSR7XiZCBlQwx0PvVD6lK7/duecyryQO1VfKk aLecBmbIHtTAvJbG4jjZSwx1yPSugsbFon86JTvPCZHGfahaCa1NxIGDtcgEhSPoK3tLhe4JSMDO c5A4BouS9zoIwotbhvLIv/n2qR97HpXcaSzXFoWJPKIVBGc+tJ7GiOoSOFLdY4iWQj5sjG0irC3K ojpIQ0aryDzn2qJbmhQea3jDyJHtTJbAPyjPXis4Xw3okZIkLfxD71S1cDWUujrOyFmHpXNa5qc0 6KqkLcxkhk3DaP8AA4qVvYWyOUD+dArvARIG6Z6gd6vWrtLNFHG2Bn/PNaobN2yvfs6vbRDdIvIJ 7E1qxf6xZA2HXlgRk1SIYhihuRcSQo3ljg4bmltYhE6+YpZAMAA4FWiSnqUiKJjEmZQMjOTtA64r npbxGuUEbsiYBXPVj6fnVAVmlMfmKrHzgxGOhzU8UqvA85YAxbNxduhPb/a//XT6ktluDU7Y4tZC yXLZIwvDD2rYtr1UtGlUjZu4VuvHrTloUQyXzmbzQ4KgZIUccdsVDLfQCWBsgGQYfPRB25pLcT2u cXqtzBK6vC7eYHwrr04Po33hWW0c5O6VMrnqD97/AAqkQdBpFpcXMqxKPkHc/wBK7e30K0hlcRws xIGc8jP9K1KWxZntDFDJMYMtuCt6+1Z0umyRtHIUyrHJDAfL6CsGJqxxGsRzRNLF5OHBKnJ6elc+ TNHsuFQn5gnPPU0luI10gjXYTCBEuWHHIPXk9a6nTIoLZ4ZEYtE3OFNWUnY7Zbryw/k/MjKRuxnb Vry4zp8d20w35wWDkgelQUec6tK8rTMfu+YSATyozxXLyys0jIsf75TtyO1AMrebLC7iQYY8kfWs K8bakgjdt+OeaRL1ZgxEOhiViQvqe/1rpra/jRGgQ9/4T19qYbSLNtt3uJoSspGV3dDVqaeK0trm bf8AvQPkHoaCiq+qSzoEJX5lGdpwG+tVFgju/PhYHeACCp7k1LA2LHTW2uJdiuWyu0nOPceuf/Qq 2rjS44k2ovbp0P41NwC3eWGWCOSJUiBPk7Ryv8WfrXe2l7axWaySrsuATuIJI68H24pSZSRjaz4h nMVxIJzGQoOxuuCcDBr588YalGskUyzgyc7hnt/jU3LOGGrLLj902Md+V+n1q5bOsjsJBtOMKFPQ evuaohvU3tJsFaRkcDB+bJPAHb8a9i0e1H2aFjGGQcbgelMWx13kSBQyrtVhkLjGaZLlwpZcFflp F30MKaTM6xIjFu+O1b1oghbcTjsDiruBbz9pkWK0fCHksR09eK6PTIEt2dixKngA1LA1Li+urZ1v I5QyqCRtGc1qRLdSWsd1KmJGJcLndtB7E1D1NH7qMjVINkSyPcE4ywBJAQccY/izivkz45/ENdF0 26sLFCskyAq+MMpHTB+qlv8AgNWtwPwV+KniiXxD4v1O2VmDK4DyO+WIxkg+pya4S31m503Fnp8D p5gCSyhsf/rP/wAVV7IX2rHqPgm11jxNcPYzytJCsIUSlvmTnjJ+lfdHw88MaP4WhNw6hLUx7PMc ZZgD9M5NZyKSOrvvi54S8PymKCJprotiOLzwjSgd1BHTPWvdvA2s+IPFOox+fKtvo6xpLBxvmckq PLPPYEt0/h71zzN1qfXlp4bTR9Mi1O4txKCjiRWjztH3sH1J5x9K+IvjLYaWrXNytj5US3A8hA+X jyORluxP8P8AtVKJe9j52haW5nNrFGEX+/n71Rpo1zDqEqrOpgHYL19xSnIk7y3014YIJUddwHGP 5VtWsc8rLNcvhEOORjzPasHsNu5pPYbrhhHIqyt/ABjPt9aoi2urdnjEJCZ7ipEtjV0tZLaeSWRg 2DkDGMVuXl3e6jPaQWh3AsECE4xnuaGi0z3vwN4Gt7KzjuNUllkuWYnC4ReC2AO/cfxV6TBY3Fr9 oSKPceDFGDhj65/SpsXc9/8AhL8ANY8YanpviLVYDHpqOXjV1Db3I+8PYAn86/RLwb8P9N8PzLcP bwyzqNglKfOOMYUn7q4P3RXXhleZjinaED2Bkjht0lXJYc8DJ+mO9XURosbZS7sNxjA+6T6D+Gu/ c86RYWC5SZmYlVCggEn8eKrvbSOVAmwrE8Z9On+faglbMv6esH2ppd7lQm3G/wCTtnj8B/3zV6a4 Yxsq7ogwBCqw3KfQkGtEWVQEjVdkahlJbgdz3/z61WtromQXEceeemaBSLbReeksk0uHLjy1AxjB 5P5fLUTowZShKqSUHA+UjHX86ErDegrSyBCsUhIPHFXSdsiTyOFQfIWH+FS9hfZJ1u0twzFyckDd 0CjtWyzTlMRzBiV4zzUkDLWXJWO5TCk4BxyT3oQtNDHM3CyKGwO2ecUAU8q2fMJJHzYPTFVpk8pG 3MAD92PHJOV5HoMZ6+1aAi1FhyEAOccL/EfpV23S1dnhZkklPyEMhAH4EVMtALL+XEzZjOM4yBxm rFtAZQJMNsVsfKOB7E9qRa2LxbKpHE3KtnjvxTQ8jhELY5zxSGSWcoL7Y8OmPvZ4AIzmtSIMHMbr mI9Djmgh7kqzwNHG2whGGRhgcVCkzJPJHMhKA/KE+U5zx1H9KLCJ5E4Yg/uiNyBcHD55z9313fd7 VSvBdzLBHBAxt8ksyKT+e2kwI5lKwH5isgbJz1AHWpgiPbuGukds4Xac4Hv70w6AssSNhSfMA288 4qjLcIpE21im/DZB7fNmmXsWW8pHEqD5icHHv7VJDceW8q7SrA4IJ/KkM0oJDJGHQsHXvjqaFVGh bBPmAZHv9KAIjHeCRZHuXVAOI1Ee1vr8mf8Ax6tImWSMDPXt6UASxRKVJC5weAKmhgFxumVG89A/ yckHj0+goJkWYyWZFUcHqMVeii3s6FiHADZHP6U0SWIwLZY5nyvOMtwav/ZnWVGVV8ondx1JPrTK RBNNndx+5OAp9atQMIozgAgjcQB932J9aBoquu9Ag4cc8D86qAn5NyDdnG4rk49qoZYWSN9ruVDE gFNpwDVtV8sMueO3tSkQ2Hk7UDuucHIz/FRJKguYI1y24enGR2NHKWBi2pDE52Enk9TVNrBEBQph iSw535+9jnHy8fw/zpcpKViSRBHmIA+aoDtgYC/T0FWEkfFuyruRj82R94U3sEiRpJ5FZVRTx0Y8 CmbPLBGMoTkAdM0kSCxTEBogQzN8wJ5FMCrhZElDgqrBgeDmiwFR1PmySkM0mMAZAGff2oEnlwNI uS+7scE4/pmqNFsEEZeVZSQVx8wPQ1PgJmJABnnpSkBAQ0S7QS5By3P3anKeXAI4lxITwWPK59ak i+pPcvOIQEUFiMNjnd7Y96aG2O1u8ao0fJCl35PqWAwcCkD0ZErwRMwYjk5AA4P5UyVFR2leItGe igZ5oDmIZ2SBo1K/vSm5yTx+AqNbo+asLYwfQUCEmXMvllsKOSQP6Vbgb7UpaeBVt0JGVX5m9DTK Q9MyCQSE7ex7EVUeP7PmVBuibrlvu4oKZJ5wbbgDcTwAxyPrTLhlDKoGQRn2oZHQYBgHDdDyMVO5 kCbmi3ODjBbBFIdxuEYJGpILH1705ZWVXR43UocHHSgaHZKzQqWIyN28cr7fSnW8xQNk7yTzxQhk E4O5XGME8VPCrRwoykMpPI60ICJxBuDCRhICcEHlTTd4t1jttpDMM7h1xQgCRl8xiGO7GSAOlV2X 5kUXChSd/HJI9v71AFjdArvC8ZWcIG3YAAJxninI0iPMnytF5aMjZxjIyQf72CdtADWUwRh3YDnD KOSKdFIN5CxnqOPWgCwChSQKuRyhJHbP/wCqqLsqKIlDFN2Tlsgc9hj+tACqm0uWdiSSR8uefT2H Wp/N2EFlYysPlGODigEIm+Eb3ba5I3bOO+QPp/s1OsaiUyF9qgEbTxuOV/8Ar0IGJJn5E2BX3AFv Qe/c02OZBPKolDAHCsoP/swp30An3yFkWLIXJx6EU6ORokfLcjp70cxLJQ0jb3kUrkY4yM1DFJJs xHAcg/M3Y0DRoOFHkvu3ZUZ6cZ+bt+FSKA/nIMcj6UhiRtlDG7OCMgbTx9fmpY2cExtjOcqwpiLP mS7SYyQAeenP0p5k+VCWIccn3pAiQso+83B4/GqxhjaTZvMZLDlRnj/GqW4+g+bzYoUOANwz8xzt pZ1WbbFKQSvzBj1HvSe4DgEDbDK2AMjHOfQGrckTDcrrgDqRSAIppJIY5HJWM/L8x9DRO0pELA4Q enG6gCbLxQg5O0ngYq0pIBbGPX2o6XAIOHnlbgLg5Y4xn2xz2/ipZJJJZHJHygDGOtWgK00qBT5R zjjAHOfehAJFB3gEcjPApW1Gg+9lwhVQxXJ6GoJoHckq53FdoXjtmlsK+pNEjoIw7HI/Wp5OA7Mw 2qCW3elICuocJuIO3PK45NPla1ecSIrP5fDYQ/Kc9MfT5vxprYBwYZdUOD2waIElBYR7gEHzD0zT 6CGp5cvnfaSxJPG042/SrIuMpPEqncOA2c5/woQ79Rm7y5IywJ7knpV55ICd8uVA/ujFUBXQuP3r xsY/XZ160kTSGN5thaIfw55oAgVm3SzMh2sT93+EUxmQRmT+790+tAERlLbdoy/ap1dfLkmm5Ufw Hp7/AImgC48Zmw8B/dE5Ge1aHldVwCh6UAtyJyI32RuOmDk8ipwVaFVkjJXPFAIlh3eWI94MStzn pVoxrFGoLAR8ncc8/wAXagCKKNdm5gd5Pc5OO3NXbfJkO0FVUdA33uO/tQDLLRSNv8yQFQ2fTP0q PymKBVXgH/OaZCEittu4yOo75B4FW3wIlIIKj8RR0AbG3nBgiEHryPvD2qVY9zhmHQYAx0poRb2b VC7flI655/OkZgsaBJNzbfm4wKpoYxVDspzyKmmSQDAIJK8U7gyGCNQAxGJB3FPW3CuzqDu6knvS IkNnQtJHLu4PygelTqjAB8AOPQdKYhg/dvuBO48YJ4ApHbMuxj8nbB4NADG3mRUyNueTjrUc6+WU Ofkzz82Nvb88kUkhE0aGYMASBn5iPamSpDEyunJB9aC46jwWEvmYP2cnrjFTF928spC9Bg/rTJe5 FI+QsQPyVVZo1cREfMQXx0FZD6iStwCozUQV9hbq5/Kgoh+zKqsVyrkk/Lxg9aumbfk7doHHTrTZ CJY227QV4Pt0qd1OEYE4BzxTEPaUggqozj+Icio/s8JAbfhs569aVwLUZjDg7uQPzqCP94kgnQb2 JA4zgev5U7gQjZDMFUOIidoIBbHHf+7ViXOQM5BOOnSgBShiwH5J4pFndMkLwP1ouBWeJm8tmHyZ +Yf3hViJIoUd40YZ7HkiqTAjKs2DuJX2pYpt29d3I45HSmB/ko6feRT7ZLhD5p4QZxtNbUVvJ5AL XBVS+AM8mm1qdSd0dc/2WK1gUN8x42joKykvhKZIip2jOWHasm7MzluYetxywmO4jDGIjHB4U+tc zO5XySx3Q9DjqD9aAT1M+2a4tHE5mA+bcAOh9K3zLP5ZkZACeTjjFXs7my1Mi4kubIQyWzbQ3bH6 VYiJkwJFOWOPc0yU9TppbcwW1r5LEgf6w/3RTbqS7W5jmD5UKB7EURVuYtv4QSe5gMbsc5JfkdR3 rrbG8dLFJooCyliXO7hvYe9Q0UmaLbZvIkntj5Bf+E9B61swRW9nkRKfLHzKDS6k3Od1PW0m1SO3 t1EcZOS7cBTWbea06XMVrHJjI/1jc/lUTIk9TH1B0ZrdI5GLtjO3jNVZbh0Yq6YwcbehBqEtSr6g biGD900hJlGW2jp/hUQUM8nnKfJVc8d60fwmr0Kk+yEADPlZyrE8DNdHb2awRBvMXzyoJwegquhk 9biL9qspp7gpiNlHGQdwqW21eZJtzviMnC4HT/61IKa0L9pqXmyzeeG2Y+Q9ifSrNzbSTxCdlMbj KlGIBGKXQbVjNsrSVobjznYRrzn0NbUGmWqRpJtbZ0Lk8ZpNaBexmHyRK8ET71BzkHOfxpJYJpHV VmHlMPuDrmqQkZ95osxTyxOEVS2Fbnn1rIbT3SMsWwqnH0NM1RL9k8t2bZlCM896y5JI28iWONgI mx8g5B9//Qqb3Jq73NOBUnnXDEjPUj7/ANK2ZIrWWWHzLVVdV2hifvDvkdz/ALX1qTJbkE2mp5eC WLMcD0FbVhp5jt0hMqKRyS3aqRp1Ojjtrd/LD7Y1bnJ/jA9Kz9csbSSCAWV15dyr4dd3JHrQJM34 bEacPs5fzGIB+XheR3pQ0yJKki7fQGob1HF6mjpSl3DbcdvYVpItwGBt1yrPtcD+Edcn2rJdSSWW KbzkkRC1uBgkN0NaEMrxPbM5xEcgKg7+/vVw2M2ro3kb9xHJks/K5A6CmQW12JDMzEQ9BnPNaC2O st1keyiQKNrE5O3rU1tb/aJpI1lUQhMgsOGPYe1LQtbkTxOsLbh87Haoboa3bG1lQRo6AtjdtI+7 mpepRu2zpbSyR7gN45GOeK2LVDPGMr8gPfvUXuMuoI5I2gdCwByMdqFl+yuY5AdwG4Ad/pRa7KSO utbWN445kfcxx8voa7S2s4VXd9nLN/eK4x9Kl+6aJGymkpMjeVGJFK84HUV6RoPhiSO2Q3GwbkwF I3BE7Z98VlctI67TdFIdrhkh3AcrySOdvpgdP1rei01twlUAqRgpjqKzb1KSNiOzjWCVo4yJCuAP ftTrWAfZoEnC/aGbBUHO2s2WizLFEqkKp2humK5W8MrXTSKwEA+/2VaYpM5nUzKsc/mQ/K5H77HK AelczdK6BZFxu24WghuxitDPPE0ss3loDkt6fSr9r53kvEMq5J2tIc49O39KuIXMzbMAoFz+93ZY nkMP8K67SbG1aRGjk/dn72Tkqf8A9da3uSb0FmFkQsMJk5PZfrVbyALkw5+QvnAHGKd9bkWJ5baE I0RxlunHSse4c24VEyxA2kD+IU09BNHORWv2mRpGOGzkAVcS1iChSvz/AHQcfd/xpPUqJ2Gk6M93 5c8/3VOAR1P0r0vRNFaW7S4BIIJVeeMdOf71ZPc1Wx6jY+HpLUi4huQzHhkK9fpWxHZmdTlNhJzl B96gZPeN9lghd/lydqnPcVHHvLILpOSufl/rTjuTIllvIfKW1dv3SHcDjlaw59TWOSTaQyKPlbOP /wBdVYiQn9seTyZWaFxnHX8q5DWvEDXEkKljiMkBQeMe/rUrczOSk1CEuwdQGZto4prSlQ0/mYcH GAOGFWgZBNM9w1uXABI2O7dAg6D+f51BckJGkcBUxlj8wOa0JuYerqXtTMrK0kZAdQcHHSuSvJIV W2WFxsbO3JwSe/4Vnc0T0ONu9TkR5Y8Y2jBOch//AK1c9NdTJcRq6loSu87Tz15Hsf8A4qouDKEk q+YzRRlY+mDzx/jWFdW4miZCzBSSpI96pMksRWttDaJESfKByCeSajAczRrGAYzxjHXNQNIgfTfP uZmdiFHBIOMVjTLDbMiKDtfOGyO3f6c0htDFkdljM67vLPy9silub21EaKkoGWO9APu07EXNnT7i dt24AjOcMO1bCylUlxGWIORg42e9WRckCom2ViGPTGOtEgD27LOiuwYkEDHHb9KiwAbmYywRbRuw GJYZ4HpW1psszeYzxEKHKq3r9aqI1ubqE4Z5COOhqtCY41fsJG69mrYCeCJ7hbuMELEB8jevqDWZ dt5QWFjk/wCyaRBCFjZ422BvLOX+lU72ac3IWPIRemelL7RRCkwkKQAbZn+771YVVYoGjyc7SQcD ihDJ2aOJGjM2H6lieFHvUl5Kd0eMomwBcnBH8WfeqEWI7YXKCZpfnbrU32OE3sNvHIxZlztOP5+l K2oPU044Ityq3HQHHFdDpgfz9rgeQg3nceX+lAnubt0ttbW0/wDo/wC7kHIJyPeprCW1tXRLaTNs QOM4+c9qojqatpFcSzhVxsZjv3DORivQbCCUi22M2xSBk4wB6GpexpDc2p5oreMrHkyntnNYD3aW wkndtwXknPX8Kls3TOcvNYWWUS2yhlC5G18hvYmrgvVCiaI5J42Hqv8A9epJbLL6pcx2ohUEpuzv DEEVkL5c0M/lwncc4c9CaBXuVXjlt0aa3I3DBbJ6DvVfeVjglS4MbSEnA5OB29s1otgNP7cylJXV ViOF46//AK604blJ5C6Myr93r1oTFLYsrd/vnjjR1VuCA2AauPepFtSYkYHVqtbkbFG6naNX2x5Q 8ht2Oa5qaeMqVhk2yx54zzEfWmyWRRSogjZD+8JJc4yWPr7Vz91fslzIzIQV6c8NQSWI9UEkjYP3 FGeelSWuszyTzW2w7VTerduu2qLOlhvsxCNFIf728gZPtVLWpLi4gSUsQCcEDgY9f5UL4rjvoZ1q u6CQSIBg7h9aZtVwieZhjkD8KuO5mdTo1ncW6vaQqxlLGViT0+6Pw7dK9KtZI4UTc5MqoBjrk471 fUpK5ejuJpJFjiUKmfnOMfT9aw9Wh87IU4cc8GsWtRS3OGezgJKQrv5IORyp7596oSxrblS8IXB+ UrSW4ik8d15wIYNER1GBikE0iFIt6hRyq9Nuatlo1rG5uBM7hju245PDGtNr65hkMbzgRlN/B+UE /wCx61AznLu9M8E0QhBnJyGFYDGe3Ek1xLuZj8uT6dvypgVY/OuUMlxgSF8KAfvfhXLahcyRXTNb pg9TxwKQEduWuYUlEYzkj5eOnerkVvK0o8tfm6HPUUE/aOot4QGH2qXc69Npxj61g30sKNMXkODw w9KCjKS48hSykkHp6iuj0q++1bRFAwf+I49elDE9jt7H7OmZJgG29q0VmSJGlAymc/NzmsyjAuZo o0lnd8OnzKOv5UsuqlYh5gyr/d5xmk9Rx0OJ1CWaN5bmacGJUJCAcZ9xXA6rDFLMxcZ/iJPf6Gha FHLATRy+X5f7pCWz2/CrKhrqN4w+xzx15p3Ie56NokSNJZCURm7ZNnyEkNt6f5969k0RZJYo444C SMjAHFAbnYG3eSIbOCo5BH3axb21tHuYZ/Mbzwu0AHg/UUijMcJDdrGzhyxwCFwV+v0q9Gk5Uq5H DELgUDNrTLDyxMRlpjyEUfqau3ksMaBEjO4jJ5+7xQ9QQ3S5VumGwjylk2t3J/CvTrRY4rctJcRh R8uHcDP/AMTUWGkeU+LNbh0+O+u1dHtkg5EjY8xz0QHtngD/AHq/Pb4oSS6ppwu7qENZPKTIFI3R g8Dlu3z1cdCj8WPiBo8+na/d2Wn25R9x2FySzuTyOfvcnj/erW8OeFbq5voDeW7mJcKzIpwrnt/t GqbHfU+tfAPgqeznSSOHydPUbMnOXJ5/HpVL4r/EO48M2EthZBpb2WOdFjDbTkALwf4evLf7tS9h x3PlT4ca3dzeL7bVtZ1B554l3uJpHbdgMAo3fdHNftl8B5GMllq1ymLVGEuwjDQjDbfqc/N9Kxlv c3i7H1r4z8R2v9irZGaXzShLFDtCHH8q+AfGlxc6vcz7L0+URsTK5AHv/eNQTJ3ZwmmaZLHexCGE yzh+SB8p+voPrXQRWFw0wlNvt2ENgNknHf8Az71M3cz2Ny3vNOt3t7WCdmvGQyyxMpVc5bgEj5ug zjNXWlt7lhaRPsllOwseACayKerBtMFhcoPtoZupAHT61uxTtcpsa1Lc8Y6n6UyLHTWngy+uPJmh hxHKcYzk5r1rwx8OdWhbzpI45ZnUIsajaWGffikzRH0L4d8H3sdvawvp8ileBg55+vf+93r6Z+Gf wk0yCc6/4sUSQq4chI9xbjgAd8Z+7StZg2fYmkwr5caWNn5Vgi4/djbtHP8AWvR9NjOIxt+bb8pk 52+9d1PY4p/Gb8QUzeekgXb1BH+s/D+EVAse7zDBGNmSzqAADk8/qa3OdmhFGttbRxR24iJJIUjA Oe4HoTTFbaNrN+9XvnmmtyollFlVR5zklhjC9VHbn1xU0LFlm2Qgw5yGZB5ike/p1/OrKHLKpjIZ AHXpnq2aqb4bZmk4KdGXHShbBfUe01m8b3IfapYDkYz6DNJENztGsqh+oQtyfwoAleQoTiTaxIAw uaWJpRONiAvnhgqMwHrluw+9UvYl7FkhbkiR8MG4O4DDc1qqyQRl2fJUZ2qc4qSSTzQ/+plIlwSr JjK5HUZBFKLszwuskYj2kj5GLfnx3oC5lSFmVdpPJx9KtJAzZKxgsACDJnFU9guRwxylpJnY+aoA Xb0BrQCCV1mu5MShcdQNwHcbadgNQmORBsHyZwMdanSJUhIWQlnXD7eQU9DUvctExiSWNPJXJK/K M9PrUThIocgAgFGG5scg7hz9aQy/G7hEZmAbaMttIUv3x7ZqSBXwshmUyITnb0piY7bcKWXy+Sdw /u8+/rVzysgSNgup6Z7etBNiO1YSCaMBmJbO4nAGe34UrOZYngMR+UfNkcHI7CkhDFfbbhCFLoMZ J4OKp+T5mw20Y35O5VBLH6DvRbQdiV42wY3UqoOCCMEH7tUYJY1DeWN0We/NWtyollJZ1Z5IFwme o4zVoYiRW8ku0nAB6Kfc1L3uM0UljEhjjYDPyAEYDUwoEdIlRmfpzLhjxgctu74pAajzPiT5Bg/w 5zxTNreeyMflC/dUEseOcBaAHNp9zATIci343kckj6Vbjs0KlFVcOQCZD8v47ulAMns4oLQOsioF DHZ5a8H1OMVoiVIiokB3iTG3kYA9aYmXnnlCIMiTJJwQBk9hS3LSx7GkRmHHyL1PrikSlqQTukbK hDDDY44Ip4kQM8QYqM569aY0xXTa6vIAwByoA5phJIwoxuOPmHSrWwRJIzJAGiBUhvvDHNPlkdmQ IhI/Sm2IVmHnLvbCjgDIyxx0wamVlGCIhu+i1NyyNh9oZVUqR15HFRS2kUgVMFwScg4IFD3BFmOM kMm3an3fenxMsam3Yr5OMAEZxUtXZL3GXIK+SA+1s5P0qNscxKpN0Wwox1NUiR0k8kLWywv87Kdx A3HgUkciB4yqYVeG5wAO2PXtRcBk+2QMUJWQclWUjj64wTxVcD93tcDI+YnPT0oZpYYtxHGHfy3M YHIBwT9KSWYOqsGAcj5QKTJasQr5vyFwCpbBVSdw9+larQK+456c/WhRJIC7FSsMuOeRilkmicqr AKcHv1pMOpDGWDuzptkH3ec8dufWpppNyBwNuOcegpDerKc6y3AzjDKMDNOgZVt1819rFyoXHLH7 2Rt/rQIijZFaUTOxYHHIxVkO6kLGB5WM896Y1sQxuURkdtrdjVneskW0/Kw4bv8A57U10K6EIihi C7pmViPmPYkenpUcflSkOAQpO4Anp9asVivczxsjxAhpem1gQG5x/wACqyoZgCzANtBPQAcdKBIk hAmzvlOV6FBginKcGONZmJBwGkPLfXaKzKWxLKqXKpLImBgKcE/MBj/CoDBJbStNE4eNlGxQeFxS GSxb2njWaAGMncGJ4H3valaJwGR5F81TkHp+FNDRV8zynKSptK+3WmyXMTYZTtIOORSEStGoILN8 5UA7T/OnvKCirtXeOQcDK0AUlMUu794RLuyxxk4FELojIxjZoyNhw2AJBhiP5UAaAjZdu+QMT096 i+SBSzqyAnapPQmgBpk3XPzH90wAA7Z6f0qIO7SiKVdjplvYj1oAkiLSmRkVgvTIXgn/AOvzUvnE BQMFgef600hx3J1/eFJt2HU9PSolWDdhXJUNjA9aGgkPSExTvGFwnXHGMn5iRjv9aIViaSdOjIxD AjkGkIdJIGAZmwUOFbuvpVbc7sUViWA3cN09KYluXRawkF4mI53bc8EnqfrVi3XywN2QhOTz0pDG 3Um8pkttJyB04Gf++qsecy3GXhJGz8qBSJoWDZ3ttXO3J7E9Pzp8sRZ08qYqyDduU857UEsWJkZp F2KpyXJC43GnpFDtDQsWwec9jQEXYrpcecz+ShKrwrA/KX9Cf4f++asYJJlzk46DsaZZaQCRUbd8 w5IxwKjcor4IPHUjtR0AbIvIXJ3Y6EdBUq4MFwqy5mC7gDyGPpSAauGKuRh8ZxjrV9ZNo81gFYfd 56ZoAcquQZGXcByMDIpXPlxsWbjgYFNK4Fwxo6Dy1yMZIqs+cM6nBU4+tWBWCs3mtEAZcAH2qMS7 Q3mKQC3b0pAHnoXMaKWYcjPap2jzIgMzfMR0AwtS97gTvP8AvDGcZHQDrUZZJpY1AYuSRuH8qFuB ZiQrgFT17mhiNoiYkBQWYjk/l61egFBHWSUGJjgfdLZBIH+9VyX7S8giWYxnBDMoycfTpSbJejuQ RxtPeKeQu4nsM+/pVrasAkznnP4UvtBARI5pQWUZYdF6U7cX2rtJYn1quhT3FabykUzxEnlVG7hc 7sZ4pElRfkU8A5QbQMUAncZFvkZ2RhtbKNg+3eopohFCgJDAfeI/pSewEOFEmAw2AAjHWrjGRokK qGiyTj6VN7MTJElfYp28gduKmSUeQcSbWdsLkE4x3rQlLQflFB3Hkc9KkWST5o/M6DGD2oGiZRlC u4hQc4PY1NEzsU85jtyfmz/KkUyw8W6SPBKqvHTqPerkHlMBKjsIgSM4OSaCX8RoSJ5TBQd2epFK GDAgqcZxxQSVmkXa6Pb7mzkArmpYdzApcKQwOcYxxWiYCM0aO0UTKGx9wA5x7nvU1tJudvlPHB9q FuBoBhLu2k7vaqYTb5m7uefajmHcApjfO7jGSMc1NIXMYZRnt1pjGWyeUhBYlixLFvX2/uirWZGI K4Cd/XP+FBEiLbiQ4PzHpnvSLJKlwUaM4A6E0EEbq7bnzgelTsyJGApO7PPFAEYzwd3GPSpA24li xYZzhhkLSAJA8Ct5WRGx3Z64NV1CSnBUcegx/wCg96Y7EpXcoiWTgAn0J9v50sYAPMeCByT1alsI lbYzEKMEc/Wq8jhg8bYDMOCTUWGtymkbwysbhww6jaeBT1ZgdzqPKzxgnJpFOTuRmOQSF+So6DHW n7F/1W35h6nrTeyElZlnDuiqThhyRnpTH81YI4onwxYkc8t60bklxwpClV5FWNmABuHtx3oAhcqj htnzYxx3qAEqTIVBI70AKsq7ZB/CRzUeW3tHvG09qAJSnys7vyudoxUcSjiQsV5/OkUo6Ekkqx58 0gRY49aSOWIGPa3ynlRnIYYpkkPmMshdRhOuBUwj8zJVeDzn1qn8VwP8lqzs44rc3DnM33eV+Yfh Wzp5mlQRzxMH5wNp6f8A6qubszqgtBkcU0SzSCYsQ25f9n2qnbXbWsokvDi2J4IHO73rFq7Mpbiy anLfobV04LHpxkdvxrBiiLXbWpG6EvuHc49KBJ6leXTUubh1ScxYbAGM4xWgYhFFJA9zmRuFKnkH 1rXdG791ldFWZIbe4j/ewklWJ6ZrUgs0NqzyODKH+n5e/SrIW5JYi7nEksrYhDFVU9cCtFpEgild QDNEu8L13e1Zxd5MufQYts21XLnazAtHjLCuigX7NaNMxG1MlUH8PHXFDEmRvrFxbw2s0ADorh2U jIYf0qbWdedtPjv2lSBtw2xkdc9v8+hqeopMwpdctLlIYZ03Z+YnAyCKz5biKeN54zkxHcP9r2qW ib6lKG+YXUVzKQSpyqirwlSVri5lfNyeUTOMVKWpuloWGCSokiRr5q8EHjmoJD9mRZNxKklW78Gm xz1iVmtvNDWkhBhY8hh1FVmEltc9HbZ78f3RVdDK9rmhNDqAtt0gLLtypByCKn0ovKJQ8JbaBgY5 b1FBdN6HTx26/MUZTGOOB90+laVta2g8z7XIwccZ3dDTa0G3csqtk0x+y3ACRjDx45JrQ/ctCVvm 2Wg+Uc43fWpb0I3MP+z4EiAgtsAyb/MU9frVme6tjFMmMN0yB+o70ykcjPJF5nkeYwlznOeVzUqW bvh2yzL0ycD60GqGWEEotne4Xc28gE9KpuLW7uFVDiaMtwB1x6/3qb3M57F+0hmIXzECBTlnI/Kr lv5F0l1arAcxnCsD949+e1SYc2p0NtbJKbS3VOjZYk9K1k0RGuWeOMlMYPPA9qaNluJc6TEL6C6i d5Ni4eMjj8KWLQzMr3MChWyThuSxFDYWNu3dfsoV/wDj5L4OOoP/AOqmtYvdXSMCNinnI61LWo2t S9FbmANECdh4HY9fWrccbq5ihQlGOD9azfUkbbLtcxiFhCp6E10dvA88qxIuUAz06fWqhsJqyNKz gcqUnUBQ21AOtdfZ2AgjjRlJyeFPX689qsjc2ZLDCxtExMPRsdKt2tjA4WJ1C4PAAwanlZUdyT+x Vluo5GtgBHzGSO//ALNW8bCC5uo7uFMXMgEYwTg49ulD0KNiO1ghwk0Y57kU9YomyUYBccDGMn2q bWK+zclWxU7TG2Dnv0qSLToZpXVyzY/iH8NTezKR6LpWixxJbRROzP3Ymust7BMrAy5x0x3z71Et TVHb6JpDPI1tbquzAyT0WvVLawjHkosYCjC9eaxkyzci0h4pXEUAbkFvVR2B/wA/xVuRaO+5d2Nh 9BgfSsm9SkPltkti5cfIvI9Kw28vy3uWjIut7EKv+FKOo2ZN5qbojGVdpPANcndTyi3kuYrctIjE 8EciqIkzMvr6AgmWN9jAYTIznvn6GuWe5E0hjU4UdKcSNyvGURzHMNzbjtwOB9ajUuu5HPOeM8Ct EguaWnJArNL5K9R1HU10UNsBayyxQiJQdx/2vp6daL2GdSlm1xFG8ZMa7RkHnFMtNGKtK+H8kP1P UfjRfQlosz2GIj8q+3GcVxk0YKXE4xvAxzgbsGqT0EY8USbltyQJDz/+r3rq9L00bmfbuKkbQRkt +FGxUYnpGlaONwVkZXVlcY4AI9a7i0jii2vHGQw5Lev+TUvc1S0OyiuZFQMSI5ANvtVW3v2SMqzb 8McgGkNoyp761kkCTNIqqxO/l9p9gP8A4mmPfeW7xpcbipxnHDDsfm5ojuZSMa61DY+FuAuRnBGc 1zU9+7uqRsQf9p+Sfm7fTH61XMIyrzVnt7do3nYTLypJyK5L7VfSuH+0BYN+4qMEvw2O3ShbGZDH LIJZJFGXPDMegFXZb5IYpIw+UJ6v2pkyJb3UBDBaTxDJDZ253Bvr7VivqRVUdOHLbip9Kr7NySle 3rzLPFGRkgD/ABrjNRuXSe386EhF4Xn73tWVyk9DmLtT5pZSTxyOpxVC5d5bhGXKRdOOtK5cjGvJ obSNI4i5VOjE5zmoCwYwwhCZWOWBHKY7D3q/sklxYE3FXOE7Z5IPrU4WOF8FRvAyMfxfSoGmSyMI UlmjBDgZyRkCuF1XypcsQVkU8Y70IlsylaXap3MxPUKfu4/+tVaK3RZzNOCGUZT0NWQ2dXazRTyC Nbj91GuRgZbgfrzWgt2DCI0VvMPLBsAp9aoi5Yt1k8xSoZ9oyB61syIjFl+Xdt3cdPofepiWYO2e 31OBpCDESdu3rjHQ1twzvvXI43ZxngYp7FLc3Ip1naC1M4Fw7E7VHRB3zV64jXfGGGQvYd61EP8A MDJtBY596xc+VcuXXCEY65K0hEkqRfaEe1Qqr8Sc/e9/9mkl/cxOEXMgGenWjzKMC4h3SIgUqwxj P8NXF3W8UUSjc+eMdfpQhFuZIo0aSYgxHAbB5FRRRRyCMqGEYAA3NyvuP0piNESC2WTdgKfug9TW g0ySQRusf73HDE81TWgI0rSKLaD5m527EdK6GzBtpPLm2knlfX2qBdQmnneQ+YGCgbcMMYxWjaSK oE15GrKgLLgcj/4qmxdTtbSUWcMbbCUf5lOeRnmuitdRY2pVEPHOPSk9jSO5Wa9uEkEztmEfgSf8 K5/UNWdVuIvIyr9H7ipaLRxW7F00kLug2qCu7g+4FbVreQCXbdTfvQNygZ5/75oloQ2XzqkDypFC 7NnnABKirRk8xUkeRtnQqp4wKkm9io0sifu4zk5GOeAPc0+3jgN5Ct0rFjxGwPAP9a0WxoVrzcjx mKXZNHIGjJzjIPf2qWznkijZpHDPks204Gf/AGWqSIb1OhF2PLY5CSKuQHPX0pDJCixs8paRjnBO f8iktyZGBqWpRM5UlgVHG1uhrHiuxibYMyEYLY6fWrIY5I3tt91M7r2wE+916+grmtQuEScMVby2 Ynr92gCNWaKVZEUlG646fjWnCv3bhHKzLyRnpTKOrsTJH5jOUkBi3LGQTg+/60+SVbvarEBtvzbR gDFNBfQjkDRW6Lagsu/LEdh3ptqkSTF2Vmw2AccZNXHcR3Wm3R+8w2qOCSeTW4shkkkllfkgABTj p6e9X0LWhenvprZECnafu5A5/Gs+a+dYzNCPMlHX3rNrQmW5yzMv2h5Q5K4DfT2/2qoTzQXLmIPl sZ+9g1C3JKKrCkhmnYmAEbCc8H/gPaoL2IvOjk8bfmwMAH2qmWh9u0kMQctubJ96qNqM4mbMIG1d wLHJY/4CpGU21JVQtIm7ccbhwBXMX+oO0zgTfMARHkAqcjoc/wDoVMClHqrqgRg29OmD0rOkkS9t 5GCuUJ2ehyKQF6ztZoofPGQ44GO2K1bG53wBg2XDYNAeZZuJGhiSTzMBjztPIyf8awLkLKkqBdrD qSc5HrQM5uZivytJhg3ftitqxuIxI7W7srKB/F96hiex0FhrsdrdI9xLnbkNGW+/n/6/zVsw6q77 fNXKjkVmMq3F4zqXIK9sE1mf2hI8IgaH51YkEnGfWh6Aik18qTJcxkk5+YAZBx2rnrnTrnUPOWNt kZIHI/WktSyjJpC20b+WzM684c53Vl/Zg0sQzhtxwDwfy9KuxEtzt9CnENzEmCCW+XNe4aJdACJN 5DLye26k0JaHVHU1V7e3KBoslmxwWqO4g825lkaH90cEMp/T61JohE0eBoknVlZ8kNkndz6du315 rSs7SOylRFhO/lXLcsAe/wDn3oA63TdFTZczFTvCjaB/FWDqqKwkgRAEGVLKP50LQES+GrOBgHiO 5MmLfnkOPm5/z3q14pv7awtmTzF+2uuYl6598UpIpHkc+m3GtBiUkOQZGOwkEe3949a8f8Z+B2tb W8la33W7DoAM8+g/ip7jZ8P/ABD+AXhzXLt9Yu7Dy9RUhoXiLp5RH8WFOGPFYHhf4aWcMJjk08qk ZTYXJ3OVPOe+P+BU7C6nS6/c2eh2UyQ2g3EfcDcAdjmvz++JWn6rreoEXcrB0/498Z+ZO5z/ABe/ 4VL2Ljuc38PvB8zeLNPnjRpSsgVti5UA/wB78uK/br4UaJe6XodrJqCET4jCwsSGj2j7kn4YqJbG lzu/HWr2LwMhuFNrFgyZbv8AdwB68ivnO6tI7lrqW1TEDuZMN/ACd2KyZN9TPh+y2cK29qcOX3MD /E5qBLa+mu5HnDbGPGw4yvasmw3O3s9FtRAbNlG8ZdD1IJ9Kpz6E9rIEtk/elQZC3VT/AIUkMyrm CUSwKh3TB9u3+9Xu/gXwbJqMazXNi29sNFESQRg9eKEDR9feEfhWlzCBcWdzFk5A2Y6enHy5xXv3 h/4babp0UJh0543V8uJP3hUnrz0XvSGj2Hwz8Nr7VjDcabaIMgmPz5Ni+menzV7Vonge9gW30mK3 luHK5luBEfLh7AAkdeP5U7XZk2e46Z4P0/SdHEclsFuIhvkbruOWyR6DHVawjOH/AHmAXzjKjjiu 2GxySd2WYyqrHIZl2v8AxKT8p9CMVcihdVaVSRFxz0rYyDy7d4kXbtmBOZPXJ71HFJM0z+aBsHyt xyfSq6Fo0/MQMu7Ow8HHakdpPNWGJsRscHnGaJDCZEExAG4KM7c8GosiIK064JKRqrEcZ29TTWwW 1IrZlAZGUmEkMcjgd8Gn/ZorcSXkNugcnsoyCc9PzpgCCfy2aRf3nHfk/hU8Svi2mZjhmfG3BwQO h9PvDpU9AexdQCNE3pnBzsA6CrMFvIpd4xuVznaDwo71JNi+FjRmeMAHb8pAHH40Lvd5F3ABhjp1 oE0Nij3IY3GIweT61FdQyO2UmIiXoB0I9ferew7CQxzMiuJNqk8g9TWguHUrEoOxsM+Oc+h/P/x6 lcSJl8wSLIYzsHI461eguIlUsrbp+qjH6fhSe5b0GR/NFcxybgzHI8t8Fec9MfTvVmS280RFX+Ve xpAWZIysa4Y+WCAUIOP88VLF9kacx5YOQPkUEBhyxOcYpksmAMSsd+UBwP8AA1aikTDYIGMHr0zS BaiQyiKNtw2lic4HWoGgVLgybiJOu0nj8KaEirLhozIpO7dioySImjLBohyvPJPejqVYjaOWG1Vk VuWz8xfOeafA/mfKy4FUtxl1P3hZFcFVUgkZweev+zUkbOYlhYZXOQc/54oa0Au2qQOUk3h2GcY6 VaVF8wSOhZ1II5xmoAn8pJlfcP37Ag84we1S2kUcYSN7QtOvXADZ4OcjrnPpQBp+XMXdSXDrgbSC CKj+yu5Lsp8rjHNAEn2Vy+IpkWPbnD5/9lB5q5GGjyfLDc4OOtBDLkoPlNGjjBYYYjIIyuf0zUUS LGUXYdoOQAxGT1/h96YX1Dy0Z0bzmCj/AJZ8Ybr3xn/x7tT28tW2AsUxyT0NBNwSLzJW3Aq4Aw3Y 05j5WM4wDgZPerWwycPGGB8rGCQ4xjJpP9XFvUEjPOTU3AJYEuCrYPmZ+XBwCfemMs0b/Z8hcEFs dSf/AGUVJoSRoYwfX3PWklVhtYvtkPGCelaPYERO0qRR+Wob5sO6kncPUDHAprLMxjyQV3c8Unoh W1FKhXYNkttAJJJziqkg2zIyBm2ncoU8g00ItSTAhliDLJjLnOCoJ2nj6kVIsUoeN5GG3270WJGS yr56qpIizjOM9qinuFLMsS5GAeQMMCM0MpSIbppZp1kRAtuBjg53HvxjjtUAiZCCB8gO4dxQU9S/ EN+JQwDZ44pkhuIwu0HJONxPC0JmZYha1maVVYiRF5BB5PqDUSp87N5GB1yy5/Xt3qGHQjmO1y8k mApyAOAeOnRv6Ux7qNtokjxntnikC3EW5Nw4j2HYD98GmLFGoykLpKcn53DY9+Pu/wD2NADBHK/n EyFpQoHJyRireWdljWEg4GA3f1P0zQUtiNo7hUKRRl5G4GWwF9+lNmRICEUZY4yMkEk9x+NUuhXU bKEmaGCZiXB5zxsI9ari2EkiCOVgQccHgD6VQpOxIY3QMGCDCZJK9OT+tMl2bQclYuuc4zQQiSCe Q7l5WTblSQQD9KlQg4eRNrlyo56gVLLWw7fDA5hKkZXezBufpjH06U8MWhmIfk8ZH8NSMJCY4hgM ysdoBB5Hrn8KriFY5pZ5Q2Sd3JJA4x/IVSBErNE6FeQwONoHIpq2XkQbvMy5IL/LxjPT61IDnGwo kSHpnJGBVaa0juHj3SyLznCNjn3oAZHCYHky21AdvJ5NSGZA0O6RVttxOSCefUBQ2ScCgCV5DvkZ eIIv4wpbJ+lJFHbSXUk6zF5lABYkEcjd8n93gigCWSNcjy26c4qxKBsKKVDt6nOaBldI4kdpWg+Z RjzduM+iZqxvTYSECsV3cgbvpVD+2U8oNgO4knHstWLWRLUP5Sc5zgnvVNDkLfMsm4hyobjg07yl TOAWGcYI5rMgidUVGilQ7QdxOck1WRYkYRW0jPdAHlEJI9wMGmStjVXEe0Pn3zx/k0jvOmCAAAOu eo96RROGV1UeV855yW6UzddREsrYXuOpFACB2i23QJOOhx0qxDK0jbzGwz83IIoE0Sh5DjcuWzxU vl5jkDsSjKQwA6ZoCxGA5RUEwHOQKgtr1G2Ko3KRnIoGXZCrZDZC+x5prM3lrEANmcnjGafQCfKu okCZlXPf7vsfwqCPMjNNCFPzbl7DJpAaZhCsTG3fOM1LvX5WZMjoc9KAJFZt52k9M4zT3uI40VZI wzbvyqloA2Z2faUBweuKmkAYqImPljgZNUBSwFOQF3K3GRyvv+tSmAOZZGYtuwQc5H5VIDFeVXi2 gbd4DHHapnk5c7gADwScd+KXQRIFVgWC/PjJb09vrUZinVRKo2r0zjqaXQYsaPM7lYcxr85VB0Gd x4WnRSSEM0kZjmyT83GKvlYhMb9zhQ2Typ6VaxcOwdcEYPy9M/Wk0D1VwQeSLjc5LkfKMY20iytg ZALdcHnNH2gRLCNpDMp347d6i4LAlGDg9MciqG9xJzuHzxk+3Q1nK8sRJD/uwp+XPHPt+AoBKxpW ++Irg4dgPvfxUOrMEViN+MHjgE9cUnsBVSLy5879rjIBxnaP8aljlgiMccQZy+fUflStdXCxrK48 oRlCsmMYJB3elHlb7ck8yL03AetUJrQda/Mjbx8oPeiQIrGRpFC9ueTTEiaJIyQZd3UEgHrViERq V2jKDC7iCCxHBOGpMaJSxeaRMFU9c9auCVZyg2vjb2TAWghk8TSJGNy7sHhc9qW4YOxAX92MELnP PrQAfvmdcNh854FPkjPmecSS23gdM/U9adwIRHLJyqhGPQg5+nOKtoXULxnBy2wdaa3AmVpAThep 4I/zxTVcZYHIx1P938P4jQkAkmJHWTdjA2g9BVmIboywYkYOOetWMaqFfmdjgHJz0qRT85dTu570 iZDwo+VWOe+c9KcQm8leR1BHUUyCMjdt3YDDj3NCtnefL+4M8jr9KAHJIG/eFTt6nBGB7UsapGkr KPmc7j/s0DKzx7zGSDlTuHJxmpYwZSwVMYPfjNIpCRRsHOTyODT/ADA5KE8joM03qSNTfKV2HG0m o5YpABIBnnGByQfeploC3Bg8ttHJLEVkJ+63BqNVGQp+5/KoKclclkRGyFciMjH1qm7NHIYwpIXu TgtTeyFe7LEhSZGZGCyMQOF5Yc9TUqMF/dBG2gfexwTT2JHmR8HjgdMCrkS+bEsrORg5H4UgISCx TL7lJ446H738NRSFWLbc5XrQBAI1kcIflY/ypZ8QNGu8nPfvQAC5E2FA6dcjpiopJxkIg3J0J6Ui 09CfzUaRIWjDFugPOaDIhRSF+YE4GOlMUirLMoBZsZHPRab5bvHvhBfdzGPfv/u0wkj/ACRbCeS4 ubdZ5W2l9pbutekxalJbSIsT+YcBVU9fqKqekjqpP3DPTefMJbbKXzhu1VdQgYTDyyBbgfMT/Aah 7nLLc56GeJLi3ngZWuYQd0bcqw+lZguZ1cMwYAvndjHPtVWKizVsJhG4lZwyg/xd6lcwRySCeP3G Dznt+FWlqaTY1ZvszwyjlSwJULkkf0p+pymZo3gbgNkKO9USjV0+5mihgieA/anyVXNU4p/39y8w zMWDLz9wj09KeyKNqKed1SR8M7HjHAFXbu53YgYAA8NjvUthHcytT1K1s4I4bck3BGXXH3a5m6ee T7HPdOVAO8I/8QrP7QSMG1mZ5JHjY7d27nn8quWt+xmEcU6+Scq+R0pWEkaNpJaw3DRAHzG+ZM9D /wDXrpILSM3CmI5uc5Y54j/+vSsbX0JprO3ikS4hZ+W2nc2QD/nNSAYKR3Jw55APBNBT2LfkW90U KqY/mx8wxk1IbaB5ArrhhxweSKtbENJkiTNEhsZHzCmZE45Bqzb208ETTJH87ckAf520rDhoX3tG lCReZtbbltp/WrEVt5gAaQbfYZ3UPYVrl9tMEDC+RlE652hjjB9xUWpTkxx25INxnOFqehm1dMht rWScieaZo9h+XB4aq+r6dAgjNvMuwtn/AG198VKeppB+6YVlo9pd31w80zCbbkL/AH8dKvoYraIw xM21cnDHJGatLW5qZ62Dp5ty9y32fr5ZPI981px+UZH8uEbto2tjrTaIlsWkS+VpLCSJY7kkFgT2 rSg0j7HDNPIAsrJkKD8uT3rNHNf3jT0SFZ71PKjIdBuZ3Hyj6etddKdt1arj92Dlj2qo6m0SS0tY mmZkG+Hd8w9fatWeBWgMafKW4UjqtU0Umc69tD8sUrAMW2qQepqeOSC2uJIJbhcBPmY9BWbZNzSE DYUr/qe2TzUJIimESBg3v3rNLUEzb0+CUx5aH7x7jke9bsdm8bqYT838R9a0iM6O2g8mKANBnaxY t0rorKHMcj3CtsBwrdjmrTEdHa2MT7UQhYs7l54NTNbxK+MNuU8e9TewI3raKGXy1aElz3HQCtGC 2ijieKRQpzkFRgnNQ2Mq3OnzF1dXzjqCeV/xq1baZ5awiWZNobLFhjd9KgtEckc3zyQplQcYPPFa mkWuHeVpdrNhSuM7hTiWtzvLDckaR4MkjNtU9Nv+fu12WlrsLpMGVsDtWbNI7np+lWjW0YU8M3LE fpXpNlOlvHdWG3zGkYLI6MCuMB156jr93/ZrCSLOys7ez3+fJNiZERNu7CkE993fP8VRT30P2hY1 xtU7hnrkd6ya94rmOT1DVxIzq0yhPMCrxgMT7+lcveaykUs0fldOCScEH8ulCQr+6cNqWqsoYO43 dsdvfFYDasLeZVknDFlwoz1rVIxbOeutQk81S0gkVidqocYp0FzGfMMa/MOeetMSLkW3YZWOT6dz V22sXvYhIXOA+4HHb0q9kWtTf0vS3kYpIp2gn5l5BGN2a6e3tpViKyFfJzUXK6nW6ZAQgY5MY/i9 fatOWAJOY1JKsOR2pNjZy2u2+oy7re1tSYwdr7HB80f0Fc9J4flXyt7MsXTJNO5mkbNt4bjESXc8 RO1sI2ehrutM8OvFOrlASFEi8HcPr6D/AGqSepSOotrYr5pig3Z4we9a1vaGFQgKNAzBifMO+H2x jBPT+KmarYuZdTLBCxkXlwXcZQD3b0Fcqb6EyLsf903IbqHWkO5Ue9htopJMNhTnjrTp72OItJIo 3bOMDkHt+NVHe5hIwLszXsCyW4xKeAM4Yf8A181zzJJCTLLMdyrjIPNV1JexyF/qErxTFn3TZOTj FYkN2xkxKCjYBJY4p21IsWn1GMBUt7jK9WAPOaiM9jPkCRmuBjODgLnt9etIiT1M9bqWPzyJty4y B2xVW41naSGTC45+bpQQjGn1LDF4rjbx14IFYlxdNM5X7QJJsD5gcgn2rJmi2MU3DNK2+4KMODxV O61CD7O2GJb2/i+lKGhomYlxKJkRY2K855HWpGkdQJEl/ffzrRBc3oIvkbDgy43YPXFWrn7OkIuA B5ychSeppPQmxjXd4WiJkHOcnFc3qDwzIs8avsU7Sc/e9qCXoYc+pQyNHa2y4kBLH5fTtTra4mZX W9j3QjmPAxu55rQiR0lrLH9iOxANvPygBiPf1rSsmkk8uQqACPunrR0MydplBaSMnaOCQelX7KWc vzbliBkZIG70pGm5DqF7FOXm2bZR8mMDKmn28a+UMNhWOSc07GnW5eUpDkTCNkA+UsuWz6flWnc3 ysY4oxltuTnnFabEMnhnd4mfBz/C3Y0+df3sMgUFgfmBHFCAt/Y4lKXJO0lsKCchR70+RbZXaLBZ zwT2X6+1AihLbjCMhDQhscHOPWs5YHVZY7df3igkEnJ496aBiSRrPbsxGFJ6N1NQwXHkSRwrGfMw I1yc7j2pohlqTM4AjbbKp53fyq0LhFO1pMtjkdMfjTAsWd680qmP5WU4C9mFdDJcfaJHmETBuioD kjHTmpeg18RJcXPlxtvOG4IyeQauWd5JK8USkGRj8vOKVw6ne2s7XEi27lg4HIYYx61pq0BUxh2D k4OOw9RUs0S94nndWG52bYnbPauL1zUIYwyGcLbDLbgO5pcpdzg59Skd/wByp2f3u5Hv7VswXyyx ZtZgzFAyN97cMc4PpVpGbdy7Yaglp5rywPuUbsrz+ldhGJ5RASNqv83/ANb61mkBfuLMxxrshBgP DHPIphjhRDIz/cXIDEDH09+lWtCkZVxJ5UgEkZDljgEYPHf6Vgi/2TTn7sBckcfd59fzqktQ5i7L qvlRHY4YMMDjNZ41CbYzmRmcnHJ5qnuZMr27mPzLxmCqg3ruPB/+KJq7ZyNcIWjGCwzntTtYm+pq SoklszyOwQ5XaD6Vh3FrCLNWMgVt3Ged1FgRRSRLEOEJKg4JY5Vfx9a3tPj3wpNIoMmckHtihIo3 LSMtA3lITLvOTnt6fhWhbW0agPPEQ7jaADyf++apFWIIlVJJlkV9h6DPFWrVrdQ2YSF9DWiGbu+B EWQY2k4x3qjc6klh5hV/3KYYsPf0qmxIrya9ueK38xjGFwd56e/uaHvDGjrgmAjs2C341mBBdalb snlQI6xEZycYz7GqNv5cdxHIyL5mcEMeW+lT9oC20P2aIyhdqq2cOfve1Ysd19pn2eXIrFtuXGAf p7U3ugLU7rbOy+cocEDbnlvpVAOqI1zKWV2JABYlevp26CpW4HC67dzLhmmDIW/g4xWEl1v2lowy 9CtJ7l3JbVXuCSUwwPTPBrYnvJIVUtChwAGZVwB7U0riXxXJnaS8ESK3yHjaD973FWVwN/79dy/e GOp9qkcthoQxzSiKHcJQpfnngdfmqpKSYwFXLOSPl74pkvZHI3sbRTF5Dg7iCorDub93lFrAG80H qTjbQJjbe7uZ5282YibdjaW5OOOBXfWt2Et4llJYg7O/H8XNQ1Z3DqXWvo7rdHG7iSNuSwHymohc xF5F8wC4/gUjqfT/AGazaNEadlpSsqPk/MThf7v41uPpiWe1TGSx5OP4aSWozlNShW4e4aGXDALu Yrwtc2dOaQPOQzSE8Yzk/h6VuSzrtIs3Eq5XqM4I5UV3umXXluQSXGQqYH86T2E2bccT3OFy27du +9jPoCfSvS9J0ee7hicgqn8ffae9QLrctSWgUyKmMxsB+NSW2ly3t3ZqWO1pArY/hGeT+VM1R6t/ YzW9gDgGSMYXy85CDpn+8a8t1yArC0casInlOT6Hv/n/AGaRSKUE72KSeVMc5JRiOlcFd276rei4 eRkdSu8MM556fU0mrgeraNpf2e1UGNVnVRsVhyM9M14z8V7iOOwktUCC5aYEYIBIHUj2Bwv400rE s+Yr6zS8n3SNJtKlWVMYPueK5bVNDJ2wWBKNuA8xj6jn8uKYJHGa94EtZEuTMpuIGj2MMHKIev8A +1/tV82eIvDNuNWh0+xsvNiVgYnZQxXPy/e9aC4/EezfBr9n7RdH1qDxhqscMF1I21IZGd43zn5y PuZ9PQmvr671iztLVIIyBKDsDNzu+lZyNDxLWrnzroRylJY1lJ/dNwc9c+/PNcfqepxmKSFYxGsT kjbnLD/2b/69c02TbUf9iT7MiKrbmXdn1zXbWGn+fbBJofJnCbfMzyD2I96zvqI6m10mygtgwbOo RgbTjIb1/wB3/eqaWymXbLGFJ7Fvuk+lFyoo6/w14Vj1u+H26PdFjJUfKsg6YPt9PSvsrwD4DsQN Mu4kbBTHlnK5wcce3HvTsNn1B4W8P3EM8LSII0+YkOCSoANe3aL4ckumgup0k8kS8QRAHzQPX2/i 4/u0g6n0do/ga0t7lYJCBOV3HYC3k+wx904+X8a9dfRBptvFZi32ggfOW5QY45+o/WrRlI5nWFCR yJNIViVcED+PO3rXk+olLS8eOIB4WX7uOtdlPY5JFGRnUq1uf3wcHaR2rYN6JVcbwZlUebEM9T+n T+H/AGhW2xmOtVlk+fadgHHpmta2srq7OIVUIDtbg5z7YpF2GzJ9jmuNPul2yrjn+8T83/AajgYo 0ZZcQ7i2SoJU/MMgnp3pXG0WWjtmjMgOSDkg87qz5JRCIEFpI7+b5ZXByOCcjb06d9tWiepYUqxY eXhD1yOc04StBICDkDtnj6EVVxiATSk/OSx55xhRnttH+cVPGkpQtPnngY6+lJiexat0SY3hdWXy VxkfePpirxkHkPsidiRuX5CuP++qkEEUbyRhyzDHPFStNIFiiUZIPygfy+tAdSV32yi3ZcS5zg9Q aUoRO7lssVC+m3FUBA8yxmIFiqbto+XJ/IferRjj8liVc7iQ3PIFQMiDOuLVC7FQg+YnHPHLn739 41ayUW38yTD7tpZXAJH0YNkUCuXolHyzbdq5PXmpgyR+ZgEIPvMeRmgbZYBZYSQokUc/Kc8fjVmI SuiSJgLno3UU0QyYRosiOoBhJ/ebnxt+gxTLhS1yrxZ3Y9M5A/8ArUWGtZCrD5jsyyNuxggNwQcd vwH5U+QosiNkGYBTwcj8TTHYpS7YmmY5ZX+4oHC/Wq6LxDsYbgd2TwM/hSYy4IHuGQBjuH3vQ/Sp Y2Knf9mACnb5jcj8KtASTRINrJGQT94ZrRaCF/JaKRtgx8vBD8erChASw27wsdwU7W4TpnNXFWKY l4o2VjyA5yUPocUrXAurbbcvODu9ujVNDGItzMpw3J3HOeP/AK1J6AW/N4YK3Q5544qESxk7Y5R5 x6DBPTrUgWII1SFQ64YHqD1H/s1TK8hdcJgIEZ1c4Iz/APqqk9SXvcs4jDMyt3zwaqs+3duLbSc8 4yP++aRIpUshIO1COMmgu6xbUHynrxQgHLOOAD8wOMY4NIsUywrCxIH+1znj+dWncaJESRXidGAZ DkE9KWNzHvjZgcdx0FJCSL6yCEo/OzocVWDbpftEbBoyMhs5NIpBLIG3YB8rgEkZ+f0BxxVcyPMH klH7wvjI4AHtVLQothozuCEA4ztPU1Sa6CsRsIyaTFzCtMFkhIi++MBicAH3FEUjpNIs6jevTAwP wqdiWRPc7WmEZG9lxnHT/JAq08kksUYLn7QozIcD9NvTFNO7EQiSEMFZRv6c4qGORFmuIXYGXO7r z9PbjFVcENZ9jooBERPI9aasjLK20YQjjHJFZ2LuVvPeJ081TnGeO/0qdZZsGNs7iQQSelWthdRT wQYyd/f19+KmhTM72qOfNZDI7E9uFC/zb/gVR1uIkaQOGHG4jB4qjIETarjr8wOBkg8fxBhTHb3h Ipgw3AFos/KRViSZjcLGW52jkDj6fWkFtSNmDTGA7ixXAcdRgfrVmWT7qxptfAGUONxH/wBf+GmP Yq/O0DkyMjZ47Hj+lTyIHERkb96RnqMcUdBlR48MCkWY+pIPSplSQo0gUgZ6461XQHsVIGeV2UuW XoO9Ogb7TLJDcEhAcBSuN30oiZlmVTGWdWwhOOV+6RUbrIYVYyEjOQMYIP1pPctMuiRPs+w4DMCr EjJGajVGSKZZdqHOBsIOeAwzt781IxJJA0pUsW3L90NjJ+vah05UY2hsL8zZ21S1AjkiESgEMdvy 7hk4wO/4CnebuzGGym3gDrSAmaaNreMHIcHkHrVVsqN65ZT79KGBDjapJYH0PY1PHAwZVa4wiHcE 2etNqwBN5DLHGq4bJ+76ev8AtGhTtxKUG8nJOB9P5U0NblgeUdzALyMZI4aoBstwkKLyfXpnvUgo lmRVhZDOvQ5JI+7QVlG6RipiPIZTyQfw6UIq2o1ZBsfy4WZRxnHC59+/+7UCxFHXe2RnLKf4qL3H cuxrvkEbn5AdwyAcfSpAfKK/KxYdwaRmQPHIzmcMGY9QAPm+lPeJZEjjmVWUfMBjke1AW1uQtHIt 2IzKXjXHzMTwD2qx5kNy/lMx+Vs9MZoDrcftLEtvwoOOegqSJXyInyJB1U9R7UAXAsfJQkDoQTTH 3RKZIhuG7HB+6cd/7tADVkeJn3FiSu3oDt/76pI2nDOzklM5OTjH0H5UAO3vLNlQMYyMEDp8tSRZ UuWCtHjcChzkf+zUAK3mEk42Jj8WHFNZnRS5OVwAKAJom2gGEfviCc8cURH7IirsJUcdelNgh5uW jU+UMI3OCOR7Vat5JZMOVJYYIyeOOtLoBNES0pYMAc7gMZ4qx8gdmOCT71VwASIQWCnCHGR0GfWn iZliBYZGego5gKG6RJWkKEof0q4JfIwCp2nkYUn/AGv4elC3GVpJ0+0RjbkggsoyOnY1Y/dyJCrM xjJ+ZMKc/jjP/wCqkRfUbLNOmUtYEcKCPmfGcgrjGG/76otppCvkyMSCc8n7p9KsonTIkLjhgM8j mncu58zcZGGAAcAn/CjqS46kzIUYHA3A46dailWdX3xkrKOh9M9+am5VyNznLOdz56g4BqZpQUAU DzF6MR0PtSuBLHOdgd8s+cYA5pzhlDzAHJBI2nHfniqQEEkwZAwB8w+/SmMiEDgh+4qiWRm3jEDo rEM3FKjNDFB5kjEbj35bj/x3tSKuWbeGO4jd0DBgTuyelTm0dQZlkPnE4QKvTj/x2gY5XfC/ODOp B5GMjvxU5fdHvlOCOuKBDfKbO9X2o3TFStZo5jkwdw4IB4I/xoAsM6CcMdy8dCOv0pqOyXAKn5uw PQ0AaXmJv4GG25IP9KsoZRHypKlumQB/Lk/jTMybKoFVyQcdfSmIAMEHJB/OgB5kD7Sowp4601YF iJdV2NnJUMTz/wCy0ALHKjF5FfKg44NTRyBZCDITvHyrxlSKQFuJWy25sqfvKRw1LbxZyhGYl6sf SqjoC2FZVkjCsOD6U4GGKJUVySPXqKpPSwNkSM0fnSghg3B56VPCoONuD+NBLG7WaVB5mF6+tWVh G0hGP507kiN97ewO4fLg8VB5uXaMEZHvQAqHaTkZBORzSSEuDhgAOoz1oGNXOMKx4P4GlaQQSb5T gnhaQyTaXBcHZnJB6Zp0SqN4/wCWg4zjrUrYkeHXyyQTv+vUVWaTkSFAcdDjkUPuNbgshLliSR2G eBT4REzsAGJUZJ9KQPcY5+0h0liDRYypZeG/TFSEbI1JwXHcjnPtTewLca6p9nxNAp3AhlPIb6/h T9yOrFQVB96EIep2Z5BB7U3O/CoSAT0zmkATEiRURQcN2HQ0zzGDyAJ8wHORwKADzAhO0fPjvziq 4jaVvMYnfjhfT3oAQbSHyM7h0boaVYk2LsA96C47Efm4lDYACjH1pw4bDgbRz7GgGgO1xhAM561G s9wJSitlew28ikM/yRtHu7ZYlXOQpyp7muyVBIIJFYq/97PFaT1kdFBfujFvJ5BNFEEYOOCWOdx/ oKYpJdhcXB3Y45yGoa0ObdnOyweTqIeKQiQKDkGti7WO3t7dVmVppBmQDgqP/wBdUwiveLST2fkx xiBQcjJ5Gfr/AJ/iqpIbQbkIZACTkn71Uti5LUjt5orRy2CyuD/wE9qZpLTQXTCckoxJUH+Dv+vF MlM6SzdZbwSMhDRndwaiuoVS82Rxkl2yBnJP0p2uiuYvRyOiC0QhHL5D45FElnHb28l40xV43wWJ 4z/SoaCL1ObQQahktKpcZI56isO/lnjmWRgcJkJ6GpKkYk+pqtvI6xnzgex4AptleQO8M0pKLnIY H+OkCZvxLHLIZ4ZxuByOeSfatizu7iH5RJyTn6UrFX0OhiuZGL29xIF2AOG6h89q0be5WWZeMqOh I+9QjR7F2OaOWF/OB2q5YYGMH3qONUlmkWCTfJnPJ4rS2hk00S3JuGQpbx5lDAcjk1qvdiIwpj5s fvFHT6GlJFQ1JoILu/iuIFkVF3Z34IKj0zWmbRLCGJBIfPfpz1qXsVexLFbvMrGW5Jzx1zsxVaKS 2VCZ4gJlOA5/jHsKyloiWrJjtR+zR28bxz4llfAQHBPrWTLFL9nULM28Ek7h1HbFKK1LhH3SKEta oH2lWY5z6VjwOGbKq24scE9zW6Wg5OxPGk128kbAjBHU/erct9Iv9+Yo28vH3iQNv4f56VDYnsby 2csUpu5F3RkbSg68d81ds7EXbGaWRgmeFPSs4nPY37a1jSVpbZMvjZwThe9a8FtLcui4GzqW/u1r HQ1R0KRxQW5WK3AZc8AAFjWFJNE6Tzlsyx/Kyqc49qGzRIwLu+kkkh2Wx2qcqw7H61YNvG0W6cj5 x8yY5/OsmjKSLoKZW1lYhj90gkVvizhd0kZzvC9aaWgI1IZG8wEE+nTrXZWNsdhcxkk8g0yjbt45 Jk2eXzn7uOTXX6dCTCituR1bkDrxQ2DNBrOcTxvt+R+jdq0UsNrb2UMFNRe5KOgjt4ljLIQDjHFT Q6cCyzMQApyB1NDRRZ+yQuxEA+UjJ96oX+n24FtAkzb1JcoT8pqDQpyWm1kADKp5YA1uWPlowkCe wJHcUMtbXOispEDFlJ8xTnk8LXaWM6LACZ83XXO39KzmaR2uekWGqxJap9omHmlv3ZBx+dej6TIs 9rHBJMuDncQB8mfX9KwkyjauLyAIHlkWRWOT/dcD39KyNZ1CNy0odVcnOwNniosI8u1XWo1+eSdR AjZO7hc1zFzr8k8sk4YsgBJYj0rRITZwWo6xIuZI3LPknNc8+rMzfaJMksen+e1UkZNixX8k882x xtYfIcfcre0yWTYxaQNIrYfjGfamojR0VpdWTTLG6sjDnlhg12+laNNFJdiSRvKLblQHIAP9ab0R qtD0Cz0pLJxLA8hiYZ2Ow+Unr/n/AGa2bDTfMUNLF85bheoGK55Mq2h1NtZKA0DHayruG4dKWfSt zkWkhyRyCM4qXIOUr2uhXEAnl2EDGBvJOaU6UHMcUqbkBLbemD3p8wrGxpWnwyNGrYwpz93OBW3B A7b9hOzpn1qk9ARdtrRoEV542SEkbZGHyvk9B/ePFZt/PFC8sUUuUHz5HTNUVHY4jV70XBBtHxED 1bnb65rLGoiZ2Bk/ekAKAOPequTcUX6GN4o2AlBypI4P0qs97FE5Qgk4zg1UdrmciP7ZLAkkkXCD nrnArg9T1aaB55A2eSCT068Va3Ib0OUa5nusrGyrDz8xHJNUkuUlSRS2Zl4BIzuqrakJmU9w0dyI 2bGfQcGtSDU0KtCVwqNnjGTmoIlsYeranHbSiSzYjGMjOa47U9dnjeCSeI4lf5dnGR/WgzvYpSay kiBFcDI5Vjyv1qkuoR+QJFcLlsZB64rI0T0K8upuU/eYMa7mAA5IrDtbuOXbtLGLdxuPOKRqW5JJ n2LHMiohONx70+3Z3kcM2X7egrRBc3xdN5Y35APynPeoLm/VQ6Icgdc9qGrk3MgXRwQp6ZPriqSM kryyB9ykFcKeM1VhPUoPY/ZpwWOJiOxxkU2OOXcVddhHSM9QaCGXrTzpmY9EUcgDIP19q6SOZpBn ByRgkcYp9SCaNXUDyjlc9MdasXN3ttj85Mi91OKEi4mWs39osnlPiTGwEjofU1oRO1syW4fzHz2F UXfQet+6yLLtzg4UgdDU9pI908a26kyhst/tVS1Bm7z5iiU5hIwqKSCvvn1rWsYxNcOkzbYscZNV yklpbmSEvGyEkdivaq8T7RMoQ73GD/te1QBFPGiwJIknBJyPTFVQfMeKZVYbuDjgPTQMiuBD54EP ysBls9FHrVZLaedixK4B+U1SQmUba4yxd1KwFsZPfFWgyNcHyY2ZByVJyWoJZYh1KIJGkcW0E9T2 /wC+atjUZ1tjIZQAvOQcfrSeok+osl1JNZblJZ9pI+brWrpV3wEwrIRtw69KlopbnYW90sU9vJ9o dWIPzMfT39a3jrMakrbYNxkMQe49RUs0TKGoa4xhKwTHdnBUck8V5ve6klwJY9+WZtuCeSfSjmBm TIWZFjycD7y56VesJfKkMcuc5xgE9j/47Rcl6HYxXSXDwxNAJIIzuZc4L+1drHcvDBHN5BKMxClR 933ppAbVvcxyiNoblePlbJ4b/wCvn/0KoL67KAhVA9AB3qlqDdjm7+6We5863OHRAvJDHgnGfauS 1KW52EOdqlt2R3qktAIIpppnHyExDlcDv7Voo8qQS+Wu5ewY/pVJXZDNqzcvmORuW4wD93HzUpml heYQIzdOQMinIzvoWmzPA6YIcHcM+vpWZLMpjkja3Ofu8cbH96ENMjtYYYjH5pOzGfYn3rq7FHlt WgmhAUyblOPvDC4ppFm4ot1QrEeCAitngkVZtftQjkkLIYlzGjEfdf5SR9cfzpoq5TEi+escoG7r gmtWO2WTbNvUKB90DmqQyJpWIlIVcn5V4+761i3fnIrGGRSP4lYdRQwMq6G3yJVQ+dxyDwKWxWVn mefO52yT0/CpAW4lS2MYk4V3JRQAMnvgetQeayubiRmBGPvDBT2/Cp+0BSa8lZp0jf5GODyctg1p 28rowfIeRRllU5K0PdAARJ90qOquvIWT7rex9M+tJqPmrZCIqN2cEgYPHaktwPONVtnd0bb8o44r n4rRPNCTMVyeGU4oe4XOps8RrIYlyNuQD3/+vSW0paCQTkb85244ovYa7ly2nTMsaAeUTuwBgg/0 FCWymNVRzuLHLMcYFSU9ihcz7ZZE3hvL6ODuDcdvwpkEgRlaMBRjp60A1qjO1G6smIPlNI3XDHgH 7vHoa5SW0YO7oWz3Yj7v096CSbTbV/PYIg84JuG7kuAR0/Ougyi7Iir4/vHjPND1Q3ormvaRo5IA BULk9iR9a2ND0m2vJZpFhZkyZXycFUzg4+me1S0CO1ubKKEQygMIwQBg1g6pqBiR4t4aPqQhwfoT SS0KOSt2WRpIkQkOMEZztrotP0nYUYyKQ3AUdVrSWgM7vSdD2uskjgxqwMyoXATO7YhOMZIG7aDT 3srm0V1IBVecjrz0ptaGbL2jIs99CfMKkkBx6D1r27RY2iRYojmHdkjPU1kylsbk+kB2EiWy7365 Ayv+f610Gj6CbTN60u2PGJEAJwP/AGYk0jRGnqt/FDZx7flQE+aSMccYH868c1OZr29cQMGkB645 A9D64oKQseiT30qQynMYyw2nbk4/xrT0PwqI51nMDCRRySR07Z20m7AWfFt5FoltNJDcqrlQMyDA j52n+tfFHiTV47zULlJ7ou4YkKGzv56j+6D96mncTOak8uUCOMAMxyfXHoa0NN8OF0mupkZ0jydp 4GPpTGjzXxjqtrp0mHyr7Wdtq/KoHYD1NeFaFbLLftPPCNxbdFz6ndzSA95sNbRLGCC63BIFxGqn 165Huaj+23WssssiKvlcjaeFx6++KioVc5DVVzND5B+XJLr6fj71mW2mtPMGkYKrHDd/y9K5Jsq+ lz0hNHmaC32QExgZQgZ2/WmXF3facBbfIblmCMF5zkbgPY4rFvQDodHj85Qjhmuev04ruNC8L3mp M0VxbM1o/KEnAJHcU7lpH1j8OPA8iafAtsFSVABJvQHHr7sST29K+i9P8N/YojPMVRQoG8vywzt4 98+nvTuDPYfCMOo3PlRSxboBhfNUjKjsDnqa+r/h9or3l1bCPTnSyCsJd4w2fm4x0JyKoiWiPpDS PDsFkh3ALlQMj5mI96satHC4aYqd4PlggkY96pGUjx3xBPKDfsqhl2lYiOdwHevKzdKGaaUkHoeO ldkTnkRWmQ4aQq4zuHUYOavRPC14Zo4iG/55s+VYcZOPXgfNWrdiEjo/DukXmqajJbsGhtFXfuZc 5APQe+P5V7HaWcNl5MECBISMFB1+ufU1lzGtjlvHllFE9rqClEVlMchZOB/cJNeMG92hVQ/uVbEi 57/ewf7vGG/EVSYmjQtblQsqW4bccsEByQO5/wDsqvrGpt0kDETKcqx65rVbmfS5bt287eWY7l5z mmQ7pnnjZsoMHp1ouBKcp5YQ8g9APuj1+v8A8TV1JxFBcTXB3AAFEUjJ5/8ArihkvYJInguiWbOB nAParazMu53YhCOAe1IpDJZ/PjiWJVCdcg9aIi4bah4jfeG6Mcj+Qpi6lyWfdAGkQmUc7ulNiIjx JIzdipGck+1K4x6RRTMrSLkEYXjgj39as7XiJPmYUDhcUxMrmeUSiZYmW3I25PRiPlP3ver0MmXV lA3g5BA5HrSILaz/ADrlseg/vVdaKRVQmIYPBdRwPTJ9aAJHiaN2cgmIY288E45wKmiMqyGNgTGT kYGOP8imBfSJSJGUneE+UnPHqMevAp6wNsMbqd5OeD93/Jq7DWgRsoV8wjcM/OOGPtSvHA+SowgP DYxmkiyrNBkxNExADbsq3Wqn2Pym3Rg+SBypPf1qANJTi2/eShVI+VgMnFWRDGFjMJJUjuetO4Dm ti25SD0/AVbtIJWj+Zv3Y+VSp4GOgJqkBP5bfeBLSpztHoOtaAjEWwxhhuQOAepBCtx/e5J/Knew F1puAsr8d+BimrFbOqyiQ/Mfp0pbgSGPyEJd/wB2SN3GSopLfbGsuW2wOScjPzDPX5voPyqALBVL lVSNjgSDnpgowbnP3Qf71C3IXYY4wFcDLbRkjtzVJaie1yJyLdGlDEkNhh3FSwyOdqlwUPPTk1JA yKaVpmaYjZ0U42/pirK8uT/EOaEBXLSLDLMFaVVJbYxGT9OAKf5nyLG8jlGKfeIOwA7jjaB29c00 7AWI5S8iIRtyc9c5H5fSpCdjFSf3YPbtQmWkRw3u6aOMKcHOMD7oFEUYh3LnocfX2pMZb3RHAJ6A HGOKyZHVJ5HySWI/DFWtRSGlW3tKGdtm3A8zG3jnIPX86WOQSEbVJTOCfShkDorjBnSWERyD7ucs H9xtHFB2DO5cMfvevXpU7gxiThnWIWpMZ+XeP60+UCEr+73YPA9KGrMCDZg72ccnjtUUqlZN8i7W IH3h0I9KLgydtpCKv3O+O9JthilMYlIc84xk4pBcSKARh7qRnbaBksRtU9eP/Qf+A08N5bCYrlyM gKeRVLYuOxErTOrTiEl2OB/s/wD1qtfaEjRWAO/oRnNLoOwwyJtdlA3q3HPUVUYINs0q7tzZ3D+H 0oAViSn7oKqg5Cg8+9TbUyJGc7gOMHvSBvQZHgyrltrNnrVkjPRzuxlSO5piWpBLuZpVCFXiGXVh 0PpSicmQ7FBVSzcAADPXAp9bDYkcyZ+dwWY4Az0p0g2TKAzbuigkbf8AP1pX0E9hskrQ4B3bCeT0 qRn8t7c7jGzfdYjP/wCqqiQD26XBXLn5MsQDjdRuIkRsfLjGO+Kl7jRVuBIZC6qfKIym7ocVGrzF 2+bCDkgd6dixysJSzA9emeAf/rVZuPNaIR5AYkEntTWgx7xl4mJCbsfKXHQ4plrBNmRHX5QPvDof TmpkItMRGiyOgMZOOO1U5NwlPlgCE8IAeCKTAeUVyjFf3K9SCMVa2oxj2AEv0JPGPX6Vbd4gUnji jeGNm/eMfyqQyQBSI1JYD86exS3GyBGUOzYHTBqD5pYXLyFeoQqo4P47qllF2R1RMyurZK4CdadN Ij20YgUsh4yOeKCb6jAih4iUAmRAiseSBV0wIQsjMQnUnFFrE3HGBJIo9rZQcjnrSIBv5B2IMhQe PrUgRs7pcotm6vGyhAhBG0/MSc4/zxUy5Z2+6PfJIoJvpciErOHDLuXGMYpUjkYKiQpuAPLFh/k0 DWxfYDyHjYK8m3GP4TUCgx7CXAweuO9AyYkBHkZCBt3fWmxzqscaqcE/MAT15/WgBSEZ2kY4PIqv HIzAHzWKknAaMrn8/wDPSgCYACeNVGU9CBnPp9Kk8wNMSowQdvT0oAGaUzOQjbSBgZ4BpZWglBLR kzAY4Yj/ADzTATzWZ5BAqkrxtdipX8QGz+lXhC2GZmz7Do9DENEEj/e5AHHtRLIgkgj3fKy85/hf 5qOozSA3wrKAcjge1SRlVdWY5A65HWnYCAWqGeS5KHaBxk9KsiaFE/elw5yANp/rT5QKplcbldUW PI2knrmn7GOJA+efzojsAxY9hQSE85ORkj+9UhJgm3k/IpBKt0NQRFXYK23bIjbpDyykHFT3bxOc pGw/iO3nFaFjYnkMhLp8vX6Uly26MrnBBz0JbGO2Ad1HUG9CTGxEYZ4PTqTVlLhZQECgt39aTRKK 9wjtEohKk55z2HtSJEUZQxy68eg/GkkUJGSGMhOG54PINJPKVWFAx83dyMnp/nFUBIrqkYcr8vXP c1AZTIQBHnnp60yWXUQu3zoFXPI3ZwKR4AytgMqgEhgcmi4riwL5SbYpG8okS4zz2P8ADVoSlmYg kjPp0+tIqJLAEyxOQ27PWiRUbDbxszjrQMmHzOBjIx1BqdFnSMOPmXd90HBxQAzy1e5yRj/eIJ69 KtFUt8TuhbDAAKuSf/rUkBdiytwpJ3Wx+YKVT5fvcZUVJazyuRFMF2KSRxjvVkMvzxwPCPMBYKc4 Bx/kVReRkIZRlVHTvx6UhAs5IM3b2p8bM+WHJHNAEhjWNCCAGPJKjrQ5gV7cqCZQPTof6UgNCIEK WlO0+3NNLbZAVQmEfeA55oEtggUqHGSSvIznNOWNeTjI61S3sKRENgWeJCQ5O/np9RVldkas3Qjm nIljQyEHa+cHqKatwyA+W+GHTI60mwJ4rxponEyg/ORjb0/+vTIxFtOFGzpjFNASsiORsGOKiYOp PA2DuDyaoBGyDCCx25OSep9BVmKQRs/l4yTnAHQ0MCKbLKof7oORntShvlOT8x56dRUtaARtub5U U7vYE0AeUFRlJ789qH8I1uKRtj6gJmow7x48sZJ7ipB7ku/nYyYA+YEH+lOO5yDk7aHsJ6IGaPcg JBYcEdqfgAMVwMn8KpIBFVEQAQqpySWAxTFk2bdq/MKkB8bkO+9sgnI6A8mljG0MuMISTkLjbQAk 1uV3mPr3yariRk+WRPmHXmgCsZGwxYfID1/u0kbbjMEBCjk8nHPf68Uy47EEZT5ypbr0I6VMJQoX cPrSY2x8zBUYJw4PcVEdpRnUHzR0weaQ2f5Kek21tazh7gb0bhFzyTW/cLPeRiGE7IlO772MmuiQ qUvdM77krCcgoo6nuapPAbzG1mQE7QaTEtZGBrIkUvNESJUUAc9cd6q2au1us7MfOLdxwaYovUdK 9wruzP8AdI5z19jV4zwTJbs8hJU/w96e5T3uW9NivJmkLuu3djaByfStmwif7ZNIYifLVcD1NUxd Tf02BtTa5u4kxMTt2dFbn9Knjs5m33FwxjZP4cZ/CpW1hsztUljlhkFuv74d84xXOm+tpYwZGZlU 4dQeGqXqVB6lWJraSdY4iqeYxVELcr6ZNc9qYmh8xS7GJGOCx6/T2qXuNs5vzkeymzC3nSNgHPRM 0sVtetPbW5i2wquN2Pu/X1NIlHU2Nu8SvFKSGUbtw6NWkt1b3P2iJZ2S4GA7gfL7Y9KEaGxDL5qp DDNvVejAck98+1bW02yptbJ65Ap2HfSxopeBrWYhSCRgZGQxrf0OdGspH+zoJgOABkNWkVoUN2MJ EnEbCYNn5jis1EmW+eORzvkY446kntSewRe51HkyxR2lvtxdZPGMZ9M0+4jLy2yqSJuQ/wDskVmw JJp7y0Vo9h3yNgcdqszCR7dmWIq54OeMVi9zMcsFuLW3eRgHBy2e/wBPQ1mXsvlfZxApZXfDHtH9 aaWptT2IXkgZg065iHBwcVy93OkUv7nmIt8u48iuiPcbdmdHYCaeWJ4YD5q9ux+tdJc20xj3s5WZ uA2ciM+wqGhXNizWb7NDA8nmvyDkdq6K3tLhUWJ0CuwyAR29aziYsvW8E0JMaFdjdfetS3gitozd ITw3zHP3a0QRZJctHLDNI0hMRXGFNcdBZy2SgM3DHqxxn/69S1eTNlLQsL5gCCaLEW/GF6N9aV/K ldCBuUEqrds9xUkSLdpA5meWVNzhdqgnpWpayFna2IIYDhs9PWgFudJDBgRsJDJtxwBjJrvbZvMt YXtE3yA844xT6jOosbeJ3VJmBOMhxkAn2rqreMWhQyqMMMA45rOwGst1DZQ/ZzOqEAld/Jb6etP+ 1Fra3nKbomJHHHTvRs7gkXrN8I0iAK+MLu5wa0A8luokmAMYHOB96kmUh32y1cMisd7jjkAKR/6C KwpLt1eRvMLxZwCPm/L1oWw2y9HbzxoUmcNOC2cHoO1WWt2tPM8oZfqGz0qEVE3NPLytt+zYVV3O S3B+nqa6fT5beS4dZdwRFzlRwDUSNIyN+xnM8jwozMg+bAAr0C31cCFZbaY7QNrjuCOuaxa0sVcd LqchWKV5maIdecD8qwtQ8RRxRTTFtsvllYye5wcfrU2uxN6nkupeIrmaF0lj8zcfnOcAfSuLn1Z3 8yCORo2YfKQeTW0FoTcyrfULu8LwSz71jHLgAHr+tTRJvcF2IUdSTVctyDX05ik/ykFcccV1Vj80 oKD5icMBRYa1PQtE0m2ubkPMf3hGcEdhXpukwPJKtqXUvjKlf4qzk7G0Uej6ZpL3MsWZCiDHm7l5 X6fjXoun+FtySSIiNE/DSEbSwHp+JrlbsbJam9N4bl3pcyLuVEC/MMsURVRRn2AC0lj4dVUeeJfl dskjn8RWTeo2iaTTktgIGbeo5ZsYz+FZN3Zu86hUUqx6gdRVKRLGx6aluxdHKzEdc4wBWU+pQwRp 5ESsT82M/erSJMjG13U2hhMzRqJMfLz2/wA/zrj9T13FrA6vGbhvlZFPKn1I7Ct1sRc4Ke5uSk4E yhSP4R096jEmxzG0hD8YdT1quUm9mW4bhAzqZtzZxsPDA1JdahNuKGMDA4YjpWiWpnJmVfahHawT SROxk6cDOPf5q4++1BJ42aGZWTGGA7Z7H3qzNnOrcrtMWSO9ZF7cyOimGYgHB+Q4YY75oEjP+2oI ApciQEkhzzTbrUvssYKHJI+Yk1FhSORuNQMsrRuxAxliDnca5+/1QQ7bYSKy44Ytkr/+qlykpaWK CyRgIGn+c+/Jqo+oGBJIREcgZP8As0rFpXHxP+4M0jElxyD29x/dp0CDKujkKBjk5JFJIsntkiee UKxywzsJ9O9WLdpLaaQ+WW+YBBnBY+lOwPY0bh7tTH9pZV2DcQvr6VTmnjTMiHdKei+n1osQyvHJ tyxGFJqW4BaFHibknPA4PtVCbMayTDTEuWIJLAjPftWj5c7obkq7ODk4HOPSqRJcEMiOiIcBow5A PI9jUrXIMbW6Nhl+ZHz1PcU0Ilt714WafzP3ePmyMhh/kVjSaldORIUGxhjC8c/4VVhxZtRzyOsa /dXGOD+taMSsNskKsUxjJ6+9Nl9CyqOdjSIPKbJ6/dq1YXdvHcvFGMyKMgpyDTRL0NzTme6vVQR8 dSCck/54rXGFuHXbgA/gaLEF2W63tGu0kMNxPr9KjIFw8bsgMq9FzgGkV0JmKRO8cwCsOikjnisx 3hO1Ip1D4I8sHlfemUY07ty0s5OOC2Mfnt7UktwWhCQSgg8bu1CJbKUcJjAVyWDdGHO7NW47OONn 3M43J/CRlWptElQWsq4LrlByDnOa27SaIW5MsKujZGHGQw6dKkCIxsLqZAxERxsUYwlX47uC2UyA 4TOTjkkj+VSy0aF1qflpHvIKds9D9ax215ZFkMUowcg4JUj1HrSZRl6lqcbCNPOO4sJAUbleO3vz VCOeNppEjU4XByTyM1NgLEU3kLHOJwzM7DGcscdeK2bdmmMNyVKjfg45z/kUWJkdNZ3HkznauUJw DW3ZT/Y3cmQs0rcLnpTQvtGzDqJDmOaPyieQFH3j60XV4zxwM0ucMQCWrRMFsQSzoPKIXETjO/GA 3POPxrndQeaSYrIN0KjhccVSQORn2xnhaSKNZGhYAAn+H1rQaG4ba4farfLkjg//AF6tEvQ2oLK5 xbxxzKeQNwzn3rpLeP7DbqDACy87yclvwpvcgz7hnicXkaZiJ+6vJrHub6SSZ0yRkZww+7/9fipE VxeJHEImXc+8DltoXPH8Xat7TNXMhIBPloNrZ/hx/SqW4zqLedNyHjryG7j2rUAaOOF403xFy7IW wAR3/wD1ULY0QvkRz3JnjTDnhgT90duatMFikDIwKjjjofekWjOlhuGle9hGYmIVh3yPbpUdykWz a4+Ruox1pvcEjnZ4Qki7p3ERJCAtyP8A9XFNjnKjDofLB4YHpSE0YM9xG100plkkVSdrN0X6VY89 ZUaJo2EvUMx6e9LqUiqttd2pNwXJUdQvbnj8KWW8HGGwTyzKME1MtwRUN87OrqQy5+53/wD11NI2 6eNxIUhGRgf1/GkgeruMeBQAJT8wPAJqvPAoZcopiXn5lzTEUFiUziOJSJcZGC2AOx/SnuhGwqgA U/MMfe/yaEhlOTUIlaRIFIkUgsM8r7VlXWrOZY453/cZy+DggD1oas7gRtcbpZCzgxhiVGa00vfO jSMId3qO1ZvQpbCeUjb4yfmByAQKSCwQyFWT9yp3bSefzovoJltoijJDaxtHk7y57/8A1qwruB7S fc9wSp+bc2T/AJFWtyTVgZ4J1KnPmLs68DPNdvZ3MER2JJkKMjYP0pPYCC+11rYLknecjk/LmvOZ 7u6uJnaZt8ig8gYC5o2GnY7nRkEzCZT8gjCcJ976/ka9D0aBC5SKINMpzkknr2x+H86tMu+h3cMQ CJCSDGi7huTBY5bjpz7N6Vk6gWidZUJErLg713Aj1/ChkN3Mqw837U0iIxjIHQdK+mPBWhOY4BOC yEfvNwyMc4/+vWUtx3vI7jVrcW8DyklucZ6ba5GXxEmnwAmdQ7/dViM9etS9GaROdufEMVxcCzWY sZPlx1DE11+g+GEUqEgLSnpvGRz9aVzSJs31lYW0G9oEEjKGCxsB7/w8VzEuoNBbTydAkfz57YpC 2PBfHniK3uftdoSpIAbhv9Vx39814DqUFhaStdoim6IHzbck1SIkUIZ7Lchmtw1wW+RQccj/AHa6 bUdQ26RN5SmOVVP7vPXIq0SfK/jqWW6vg7ybiyhQq8Hj/wDXXLaPp7W25Q7ACQyKp48s8Z5/ChlI 7q3vP7UIENniJeCABV7VprXQglvb3fm38qbZFVsqnsa55Gi3OHj1Ce11WGOSWNUlB2hwTgjpmuxt 7cyAG4t2SMnaDgjf61yyLSOg/t17Haka+asQ8vZnk+xqrZ3mZTdak2xkOdiKeAe+PWsW9B2PVvD1 nBcsl8ZF8ge3Ljpx6V9JeDtMtrwW06zFrcEDoRtQcbP0NJM1jofQ+hw6ZYgXVmxWQkZQ5wPp+tdr ZrLqdzYpjzFMgPl/3PX/AHeKVxM+ufhX4TmneFjHtWNgJQTu7bsH891fb+h6bbaYvkoqeaQNpjH3 cDt9aq5nI3ZtSiaML5YVo1wzLyWrLu7vzIWLR7QyZXHOTitYMxkeN+JX8j9zbkEY2sO6sK8quGVt 0hhAXO3PY49a7obHMypBJ5sbSxLu5wcHhselTWgea5R0Q/Kc89s8GiT5YjS1PbfCiIojeVgE8zHX 2FepNDAEimGPN6bSeMf/AF65zYoa3oUOq2U8N/GgsiCMswwv1r5IurrT7m/uLbT5C6g/vcMMI4wO 3fp+C10R2M3ua1iqRxruJV/u8jIrohNbR7YJwHcqCDGRjkAjp7GtjEtyQW9tbRhVIc8jk1QhuGAf eGIycbEJP6UA2TRskxCCORcDh9pQt/30M4BqytvKsAkBDc4YeqZ600JvQmYGRYtpy5+UnHSpVTY0 K/aBywMijnC/41SQ7jZVJd1sxttBhipwS2CfxpyRhA7xrgt1U9VNDeoJjyzIBFNINxOcgc44/wA/ jU0qi4t3RW3DllIGATj+VSGzLEaGKNgHA2jC/Nyf88VDHCyt50pIIXByfvChg2WWmMsYjC4cHHOO nqKbEWgMqgAzPg7iPu49P7ppGZqQPGxjWQAso3BW68dSPz/8ep9rbovmStJksMBgcCqirgXozucl pPmycc8irNuxWE7l+bdtJAA3fxZ4/wA8U0tQLm/ywCqZT1J4pGubiGbBkAjHLHGQB970zR9oC1HG 0UjhfmDdh3oESMR5YYrtwQR8pzSLWo0QyIGWVV8rd9wmood290fJQenVR/7NR5giUKiwICiebnBI XBI7VaVIkQht2/oxz0FNDLcXnSPAFhxbrkl85EgwMf7Wc5b/AIFU0SIgEaTHaTnHY0+oFwRiKJgB 87D5iRgn6U+Pz1ffIp+ZAibhgsB6fnQD0FKNLIsSqMLlixI5xj8aVYyJFZjzjsAfw5oeqBO5b2JK jE7hJtJQn1Bprxfu184sR7cYNQSWrZYRbxxRyHA5yR1Ge/rRLFBKiASsnqvADfpmkEhs8Usm9g22 IEEgLktVdZjHI6FAAv8ACeqegJoJHDyJMAvl/QHpU3mxlRvZlXpuAPOKAGoqSzSF5jtjYD933yM/ 1q4du9z5gdUwDt/h9M++KB2Im3qCOdmeTnFV5FK4XJ5460FhtIy0KlZBxkjlvp7f/FUxJpPJb5vn Bw7YG6mSyZTLsQhCPc1SKO2/dncvr/nrTixD1uEBaF45CAM4Ck5+p6VDFdefh4YyAMtnGFb6YqmI uLJlw5GABUDOCXwpLjPylSM4qB2HRu8sSMr7X67ezA1IziPAjQlScYJ5+tA9iOePap8xwzAEEDkV DC29QjtwBng5OKq+omzQhS3c5nT5QSdq8Z9//sapxiMOxDkMWPHQfh+X/jtQJbjHSJGdfKVm77h9 0Y6j8aj8+T/VA8HK5A7U2aIl8p4R5chIXrgHrUTNGGLbiF7+9HQAWQkNtXPQqMj5vxqZ8yxyKTwq 5IH03fw00wGxFEgWOPGP4lUjP94mozDjcySdTkewoWoE6Hyk3q2WwAMIBj6nqTULLHKF27lh9Hff /RaoC5HJwyqqOW4YHowrLulngYxohKu3brigB7R7GgjAyxBI9vWrXkPL8+5eBggqpP59cVmA0iNo yskzYMo4A/IVK8TkpICqrn7uc4Hfj8BVLciw6WTaGWIZ288j1pXuDE6ygASFc5xkrx2/umkwe42d pFggllJ8pvutgnHpzVQMd5SMAK4xlUGV9SPeg0W5aKIYtsbbnU4IzzxVYPLHKgBGzvxmnERcZd+Y 5R8vXA/hqK0lnKOu1t2Cpy2cnPB/2f1pMCxK0zeWgmIgYlXjCAbP4uStVdxt0YwfMAcAkAn9RSAn RYInV5Q6SPy0TEfL/wB8jGasBZEQ7XZuM4J6+wppAZgd5t5bAYf3sZFTISA0yJkIwcqTnIBzj5at IpbjlnF35BaHO4Fxg7QQT1GPvVOTHteNUwCehpN2GiKXhVQdQc06CWWKJkyQOjDA5x6d6lE3FBmZ 2ZUKrs2klc1fikjljI3g54xjpQxDYyql32jONg9DUNtbb4J/tTSMwycRvtIHrjDZ5x8tIBkAa3mU scsOcj0q88isu9Yy0p4ABx27n0oAhV5GRpTFtIO3PX6U4byVYnnFAEgnVIijDHzctmm32RGrhtrI M7gM/jj1oAlxLECybSpHmKF3Bcnr9M/1pk5WNSUAB3biCSRk7R/QUwK0tyXlghiJJPbHUmrHzx/u mUeaGJKjgH6UgGxrG7GSeIMGzhCMgD/2Y1fkQRQk9Gb7uR1+lAEQl5jXzT5gJDAelMnSbhgvfsc1 QDli+xmaSeb5cZPBz+A61py70AjkYeURhlZc5FICZXDKFBPXH0qHaHkcCPcvY5p3AtKHKqq5C5wf SmzvH+7x8iFgCcdKoC2752wxnKnofWon3yKDKxLHKjav4/w/dqbgQTCZkjDYKjgAdTSojwttdnHs e1DYFv5fNVI3Jzzz2pJUklMaM3fjA/Gp6gKi538gJ9etD+U0Q2sQy85UEnj2700BAHkif5ZDsUbW UgYP/wBep5BkgKDvBwe5/KhLW4Eir5YZc+xPpT45kR3Vo/LXpwMZ96sB0axrIsikhM7n96iuHQGQ opKnJyDigCkqziN2ZyUUlxsXrx0I+bd/e4qwsokR/l+bOd3rQApV5XVIwzNgsemB0qaNfLDMwUuT xtOAv/16ALMQSVWy3zAce9SxyBsRpJh8kfT3oAmkiVWhbOcfxbuRVhoUCOgICnk8Yz/k00DZVEWc ktkEH7vrTWi8pIyVYx7sMEbHY89OmcUR0GW7U+XlmXO7op6D39afI7hASAWU54GM0hE263fBCMzZ 6jgGrMQabKKrDBOS3G7HpQAqGZXKhDx6mrJBdJFdQMsR0zkf5zVrYW4rNJCdu088ikmm8tfnX96O fl9Kli5RofzRGhQjuPepVO1WaMYYc0MT0J4ZA8DSSrnuoxUSvEWBJO/Pze1IC7GGVwjH5Ccqfarb ZSLdHjOeRzk/pQQ0NjbOGJyO2DzS72bcpiOPXPSmSO3DLOOGA2k/SnyZ8sS4yGGeKEgIkRWRTsdH cfdYYK08LGNimPLLnGaLDQ+PaocCLcxPBYc1K1uoCPtAIPNUUMdShJY5U+lRMvyKIzyDnJPFUSSL ORGCCMD2pXkRM9WY88DmgQ0lmwZEJB46ZwPemIpYK4c+1K9wFR2SRienamSN5ZUBiy4J5Oen60ra AIdj7cyhTu+7jrVjcrKSkYBH5VOxT3IIn37wFJbp9aI5TGhEy/vAMHnoaCdxpfzUMhwjR88nhueK likaTcXXDDOFGetO90VYnUZJJOAeAD2qDc8UjKFJU98UidgihZPvcZOQBwDzmplEmGUpkEUAOLZK pL16gnjBqpJGnzYY7ycckY43e1AxiKSQki9+3em3UUioGjJHOOB1px3LRUtyFUnGcnPNWH6EDBP8 qTAEQhAJF5Iz7rVZrhlx5YI2nHI5pdQP8kDSlWVWtX3+dF8zb85wa3p5PKidYslwOxrqkhxjyxKe oxzNaxeRIdxwxIPWooJJLGE3Uk+FY4wxzj8KkUdJHMahJNJJNdorG03gOf7ppsF3GbeaIo24chs4 H1pitZiWlrPqEDLcKyLuwGPcVpJo0bSwRwTMSpyxU9aqIPY6e2haKeFLcksxAIY9a6OFHjklJOO3 HO6myep3mn2Fp9ghG0iSNid6HAkz6iqGuSW8UEYlcqoOMAcmoW9ho88ubq1t5zaq2ZXGQTzkGsaP T3a2ljugPMZ+HX+EfSonoXBalC906ANDvjJlA+Ug8YrNubO/u7Ux3KskatlCf4qnqVJFS3s/IiZ5 Y/kXnpVm3lS5cyIduDjaeScUyUSXk7OkjQJmX0B5qzbSJDayDgPt6d2PoaaK6GxpEUMOWmDLMV3A Z+96CuwiuLWTydwymeufu/8A16qwzVlkt5Imnt1P2cZJBwSfaqEF9NFIskYKQseAeorToasstfPc y7LWYo6dd4yGNUBfXcN0qXCkOH64/Woeworc6m0F0bmS6llkL4BGTxW3p43P9ouJsYfBA4zWLGth buYPq8OWC2+3Iz61q7TcpkptiHGfWsepkY0yo9witG3lA5GTiojGkcc0gQbewJ/UVSepcZaGQbWa 6R7WAZZuuOo/wqhZaat1Myv8hQ480/wnP+frXRD4bjerPR7HTxpRS1mcPPLzvU8e34VtSadO2IZW Uwr86kDBOfekwNaxs9q7Vh3MoztHVq6CXzmcGSPY6oFwRzis4mTJIDJKj7o8E85xxSRWsUKTXG8u G4dG6VokTcrW4hZ2jgkOF5weVWqOogRJEQubl22FD0x6+lS9JM3S0M/UJWihiDq0a57j71T2dugj h2gqxfcwJznNZkyOg+zyJI5hYMhXIwKv2cTJcO8o2uI9jL7H1/KmJbnUWEIENtsg+8+QSf4a7TT7 aQIIRGEIYtnONwo6mh1dvEqyQb0B2nLcdBW9K8ceGdtwPAAP3amQGNNdm7uRHMUERO0E8H6e9W40 kjdLeNjtY9hms5bXKSOxt9MuFgaNlIXbkH0qecLaW6RudzDkZPT/AOvUJlNGDNIZYZp5YCFf5Txz iltPKOyEHhfmGOv4U76Ct0NGCHM8KW7N5rHg9VP1raEF79ofaF2sMDdzn8KBGqkBhgIVvmHv1q2L u3tzEWJA/izU2uVsdfpd2unuZPKzHJxyegrX/tC23AORjPQfLnNZtamtvdMe58Sw23mRpCdwYgIz Zx9a811DxIBFcuwYMz/JH94gZ9aIrUhvU4261ZTE6ysfLY7duKwVc3Ur7nOAOD/KtkrIi49Z7e2d 4kkYTYH3e9akEZIhdbk7SufKYck/Wq2jcDbtjPHGXZlUIDgjo3NdnokbI5llzh129KhlpWPZdHs4 1UNAyi7KIp+YkKPf3New6NpiWUuyVE884GFHNc1R2N4o9h0XRp5PJ3QA24bLNnH/ANevUdNt4ViW B4yIhnnHPWuSozoSNF7aRnFvEoMCnIcj5j+NSz2qQxjaxEncmsm9RM5a4ggG8JH95vnJbkfT+7WK 8aWLl1+cHIG8Zq0Zs5HVNSVXXzEBOOgb3rybVNcj0+cLbzkWsfzNnHz9QEywz3raLIlucxqmuWsq zw+YVuY8SOWPAyPu/XmuOGtKJGR4yJG9vSuiOxm2RSanbuhXyyM8Mc1FLqsEjiFUK8EtKp+6fYVr czbuiC31K1kuoSJmZlON7Z7etWb7VY42knmmzD2QetXHa5nJnJzaw7Ru8bFMswIz0Hr9a5yTUHaB 5GA+Q7QEPJ9M0xGcNQxGZVOc8bW5xisVdRdgxL5Hsf0pCM6PXIPNmgl5dOu05NYV1qjXfLwunqC3 3frTuMxoLp9j4y0AOd9MknRXt2W3WRc5IYgYHc/hSF1MZ7jbMY2XCs2E56VLHI8Uz+cpkOAOuM0N FJ2JwX2F7kNhxlVB+7Vm2YXLSRwELMyEDPQEDOaaQNlyzupbaMnIZGGGZR1rUW3DI1z82/qD/dos K+hBCr7JklQmM/xZ6/Q1UuAhuocMFSMYBz1NTYlks6CMKyvxn9ah2s8UhjmK3AOR12g++2mhMS2l llguFMe5xyw6HZWpb3UcCKsT/u1OSTzupoTKOqytFbC4S7UBnwCQST7cdq55rxlUMJMMpOVI+/VI TMl9WknSaBIDGx++S3OAa2YFJXif90w455FMNjqYg0aIUmymOPeulgVBHFvzszkZ7Gqexo9iWS1k mC7Swj3dTVuC3jsGYWlu21lzI28Y6/8Aj397bTRDdzVg/wBYsqA5/h561bjvFa5hhYFm/ibH3fY0 WEXhPbxTCAvh3P3mPGfT/ZqWXUoI0KmJgg43EUpD6GLcXsVu5ZlzIeUVzzWaHWSdZGj3P/G0ZxuX /wBlpDv71iudzYUudpPIJqV8L5CtJlQd21R972oQNGjPOUEMcSgswB+XoBTbgRzSqjbhMgDcHHBp 3JGeb5ULLCf3nXJOaal0JYENpCC5b17+3pUgIThJJMlbkjbnqF/z/erBlvriMi23KXc4QnjNQykE kt1BHd/6RuOOAegrnPtgkKFpsPnKgN0oZaGLdMrqskfmAtkY65/pXU6c4IDzIQTkDP8AWkSy3KgY nClXHf0rY00OyFA5w3zdev0piNLEqsUkfYoPHJyfetlJpZZ45QPkUAfL1PuKaEaUt8HgMwUk7toJ OMVEt1FKyqJCJAORnrWvKC2LAW4bYGfCk/6vd8oyeoHYmtKDTZ5fMQsCF9s8VVh8pMdOFtMBA3C8 9fWoVhRZkikGwJk8cbyaaJ3NS1CLM7xvuYrgKelRvqEzytHLHuQL5ZCnC9eooe1zMbcak4aJYgvk BdpRgGB5Oe3pisJ958yQqSq8lsfyqQIMJIWZpgiDk5HJq7ZPaWwaLyyXds7wTx9f8/xVa2uB0dlc 4TMhzL05Pb2rqY5JA0cWPl6nnpTS0NUaEl5a20cckrHBbHAzVeW8gMEjwtuU/wAWOR7ioLZYjLtb RuDvQLn5eM/T3qKd1laMYAAIA9STTe5LZm3nlqAWjdgTtyBwPr6dK5+/m2RRqFHll9vFIGzmLqSO HdI4PHISqq3glcPsYYHc80dCka0UyiFoidrfKcseCD0H1zVGaCeJGHSMnoeTmplsMx5PNhcxwAiU DeW3f55qxaTM7tHJEWhB3ZHP1qULob0RdQ7Spuzx83anRQK+3OCvVACcn60IDPuLkpLLK0eWU4wO Bnt9Kx/tNwZUR2HmSH+71/8ArVUXcClqMapN5nmfvWGWAHTFcJc62iyqYY8kD5hjkGm9UBc0wieO aeWQBiA3Xkiuqt3U+UViYAKOSOM1m1ca3LuYvMVmyPcHvWxGolBkxggdQcf5NTbUGNaR44pHYErj v1rBuIbmYouw89CVyB9apbXETxOkU0NqiABBhmU/x9zzWwbpLLJhUuP7qnoaHsBy1/LNcupaRtwP yov8VWbG0kM77z0AJwKNxpXPVdG0mRYklkhb7MfnXB+8fYV6xouhtZBZmtTG7jBLdetNFW0OhltY 7aI7nJlPzqOgNc/NNbzTMmfnA4ckhabJasdP4a0QT3iqsYdyyIWIz5We49+tfT2labDpmnhpnRWZ UJY4AHoP1rGW5drHhHxN8aSeRDptvKBdRyOwdHJAB+XB7E8bh6V4TZ6rc3MpCu+xDuJPPWpburlx PZ/CmnI8ym4cxsRkN1/Kva59SsNG05WjuNzAfu16s5zyT/dFVYuJ4ZrHi5pLm6ihDCOQlSNw+b8K 4i61n7RPcTh281QFYHODSQm7nk/iaeBUusSjdtOxjyQfvY+WvIdQ1hkmjQxE7iN3PKimZs2/D0UN 3Mk8g/dYLD1ODW54rnih0a5liJ3opK7umccCtBHyzrc8t1e3Ek9wmFJOdpVmx1IHp6VR02Z3ifbb t8jZJ/vUmUjZtdchtYJ7KJAm997TdGHGMZ7CuW1uwvILk3Vq7kyYJJOdvrj0Nc1TQ0W50emaZc+V C9/IVhCgcnLEf5xXoMEv2lLeFb3zHHR9u0A/+y1yTZskSR6Pf6jeLHHafu84Zu+fp1ya2Yfh/fK4 k3HZuC+UwJcEc87un41hJ6Dsd34V01reeK2aMs5+YKz5x+VfTng7TGijWS0gcPMM8MAFKk8Y981C Zex7CL6CAQqF3SsoyFPIP0r3PwV4cCzWF9LMyox2OWIxk8Z9hSuFj748KzadZW1nJarh0TYVZvvY 716OniO3KgLPliRtKgkx8d9vfg1VzKSJbHW4HLpMSwPZhWpcalDEkcUJIJUt68dua1gzGR5Nrcga S5KRkOrEsx/iz82RXm0sfDwxgxwk5HfB7k16EJaHMzMWeC28+EyFAM5wefwpbPWRbSoowFOQVY8g ev1pVHc0gtTs9H8ZohaNWUbSjAxnO0gnkk4xkfN3FekN47srGx/tG6bfbiLeWJ46dh3/AArIs+f9 V+JHiLxbqk9tp+pzx6Soz9xAGB7A9c/xflT9I0S101lmiDl5BuYs2d2a6aexjPQ623eE/Zwh3LnI O4Ywe4q5IwDqYjjaQK2MjV87zhAHxsLBd3ZSe9PuXtrB5VSPJbgsg4JPP86CX8IyPbLHlQeevGPx pVBJZDKMAYz1xTQnuJAyxFWdsoDkg9KupIkv2uVkyxO4HpuHp+FVEVx0AR2XeGWTPy5/iqYGW2ul jdRsYk8nnj/69JrUoLtYmcSSL0ODjqackoixG7MG3eufw9hSCW4MzZfDqQBkZJ3GrDJ+7RlDNu5K k/d9jSbFcVJcEv5PzDjjoasW0bQ/O1sjNnLK8fP50CJlSR8lCXkJMeOyZ6/yH5CrlmiqAjNuG77p 6HiqTsBaMflSFwVGT06kjNaUUW8tMSdgHam3qBcT7OqTPJGpLgIQwyCBn8+pqOCBIVZUYHLFsY45 OakC7B+7ZnmDK2fl3DGKceWcMgaI4Q7mx1O3kenSkNaDGgEY3ou1euM5xUYMkQzGnmFSWOccg1f2 SkOjeEmFiCyMflwckf8A1qvSQJKSEAVQPmz3NShl+OJ4c7GJXjBxxUTBIpo9xUBjkDOMmn1At4KS gbsMeQPUe1StBLKVlZhvHAVUAOPc96uxL1ICZoPOzEN46AHqKvPll/dvh8en86T0QJWJbeSRkMco UOD97FWJWiELbySeoAOCSKgTKsL+ZuXYRzn6VItvv2+ciyIpy+VGMY9CDxn6UhyJ5HbEs4OEHOQc lsem2stmbzpJ3DZxuKsDk4HTFBKGyo08EF7BJGrkBgu04I6jOKEd40xJIAQcnjIoA0hLFuMUiMFP RlPLULHFDMWQBAO4GM//AF6C7FZm8wNGM7CeSf4uaimaOSRQwOc5wD1oGWAWUFpCN3YA1BtyVKED 5gWJNAmSO5XO0/ufTuw96pTztEkiqON23g9Rw2f1/Q0XILMEqSwhUX96RnGeR701F2h2Az6gGtEB GIXd2KMPL64LfeNWppYUcHOXGFGPWouFxtsjyNP5x2OPUfMKkkVi5GVJHTNOWhUtSE+W0eJZWQAk noePQ8dKjkS3LqUb93sB3L0albQlk0MaGNi0rKzHjngD0qpuRZCHP71m6qMUh9AePzoyDI6KpLZC 53YHTof84qBlcooI2uOBjigsuxyhtvzAzIdgVj1xULKHzK4ABOCCafQCJljULsfAByGBzU0DZZWm JEbcZBxmhAQeUWlm2qBGeB71KsU3zRrKoUDqxI21S0AmjaHakhY5Xg+hqATjcQ4Gwk7Sq4x35x/6 FTAYrlZisaFXXDjchAIz69+/Sn3EDXJMyzOirIZQqbMj2PGMUMQ2Dc5AQBcEkDCDnuQFA9quhpEL uVIJOMZ4NZjKyuIT5+SZgx2pn71WssFSXBEwXcQxGB/3zTW4WI12M0mSzA9FBwAT/wDqFVsLJKNn +sXoPx3UyXuPeNS65jU/7e3lfxpB+7jAjA8wnikWtyO4WeWYNGzFiPlOCNoHr/eqeJWLeURlsc80 riLSomXAkzxxjHX6+lJufa6j5WHehgSgQ7pGV2LDBAPRh3BpyRpIS5Hyk9B2oAqTIv2pdgxjoc5J FPkdWKGMYk57Ed/pVJgVvJmRJGuFA3fd9TU0IMQyQenJJ+7TTGnqXhIk2xlALAYJBz0GP6VmTurP HNGrMwGcIOTnoQcY4/rUt3BExPzSv5Z3jkt1BApCvnCKdLkiM/3R6GkJlssojZJZMnA3OOMVVVSk kR8wlPukdj70AXoRlCSc87cDPNLNvPRCOcZzzQBJHG5BkwMk44NRSecgXYnzZw3UigCzbRx3Cz3A Gy6XC9ODU7KrZUsSwG7oRmgBTFGsQEo4IyATSRH7MUCA/MNvPpQBZaLzI2YTbpwvPGBVRULKHYEv xwecUwG5kOVlfcu/KccqOKTYqyeazEbcnlh/Lr1IpAOilDGWViMAjHHrQ0LyyNGgGM7trDOP++qA JD8hKsiCFRnzE4Cse2KuJEiYlZgQOmD/AJ5pgFxbecmxmALEjnGcf5NOLfvIYfmOBgnOcUgJzESD KXICEHbj73oKfI10yHyHCscZJTlcVVgLCFjlSOvfpVdgA8e+JivY4yD/APE0AXBlXV3BXbwqkVBK 5lm27SB3INCQETLyVRwyMNx2jpU00jSBAjlW2gZxnNDQDUhijLSPMd+PmJ6deB9TUzkyRCM44OaX QAilhLiPDHAOMkHJz0/Knl1idHWAbBwcsc/lTQELIkoIxiMndTJolMe3nymBV+/BFUlpcCKH7TCs KqP3akkBuQw7ZLDPNbFzH8kdx5JQHgIzZwaAKPnSl4jISyrlQD0Iprw7sKGJweMnpQBaiMkSHKfK DjfngfU9qqxSxyTJ9hZhD5W9sjhueMH86ALO4KAc7Rnmp1VozIkq5IP5UAWoYlVW2kHr7laLRIFJ LR4l3ctnmgDV8kORgfKp4x3pmfM80IGJAPK87aaJaCN43Qjyj8vocfpUTOyOiiM425P19KRRKAFZ GwcsQGwOlR+ZtlMAClwfmzz8n+NAGk6x+WgjAVV52k9attCGSMgZwdynFAD4wFnSKUZYNuPHNJGv kMwZtxGcetNbhsOiTyzISQ2DkenNNMccmQFyR+YqrDuSN8qh8crUbR7kVQ3zj5sjqTSZL1BDIxYB SeOpPH51MIY1ALRlsEksOxqSS0rltwCYIPJqdpB5JQHMjHoB60ENkdukkDgHO08njpV0yAKSTgD1 70ySMDO49OPu0sRVQd69Og607gOaRHIbHA9KcN+GcJjPfHPFFxogFxieP90SQP8AP0pN8j7sE9ci qQ/s3EEhYokvyL2z34pElZYgJXwSOQR0NMQ9Qgi5GY8569aGIJBK/lUyYidclVYqQT3IxmmlvJKB dxQnk4xU3sBG4275CxUA7jgAn/x6pCE8oEY9Qw6GqvoBAsSvGJN5Bz69KkbP7pAfkHXHeluN7jI4 0R2kzjnPJobyXcttwuccngmiw0h8aBPMKuSh455qND1EYDJjDENgg9+Py7/xUWsimSJIpIRSd+e1 L5jKBuGWznA7UiZDkaZmPmgbf9kmml5X3FGHoeORz2oJJsvKp+Tc2eCeoqD7MxbknHXrQAxo2Vyc /MOlDFpEYFTtJ7DPanHctGf5TRgghjzngcCpoRuzISfbjg0mMJHaVwpfgdqgJ3E8/N71L2A/yWPJ kdFd3RZCQHYDDH0FXvskreaYXBXG3noa7qivK5vUVpXK0FtG/lwxFuOG3HpUF5p0cuE38g8g9DWd tTKO5mXaPZ7YI1BVhjPUGuXnBiljTYxVmwcdRSDqXWkntpIJELGMghge1aumSvBOHQESn8aE9LCs dVAiOY3SYA5ycZ4rrIZkaOMwAGUMMe9WTJamw17Jf3MccreUqHAwcEkdjRfWFtNuu7l3SQfu9uem O5pJ6CWiOSFv9qvra2RkMYYnOOfpViTRHzsLMSevHFRI2iVpPDbXcQUSMH+7kd/wrj9Ztr63gltI wwPrjpj0qbA9jKWC4gsRHKfM3jcDWFHBcQ3aMq7ELcD1pxZB1drHa28gMp3GUfIB6+/tUN9bpAko jgy79CD0quoItWt60yRrdMN4wmRira21z8p3GNGPCnvVLc0WxreRexwBYX/dng4/h96uwQEurXBL 4XagB+4T3+tUXfQ2nMLKixAAoOuOTUaTNqcb4IM6jBb2H+FZNjWxetL53CQBjJg8EDBFaU6zRIiI xVdwLZyCfUVlJj6GxbDfOL54y0QI2Ien51p3bm8eC0gUjJ3ZBwfSs7e8ZbE0+lzra53A4HLf3azD p8xiKXEhVR0fHX3qkioktlbxW8hL3BY8DceTgVVjinmMkNxHthZiGRh98Dp+BrojsD3OisovtuyZ mOFbYvtXUiyufLXM/wAo/wBnrUsaWprWNi8MYuS2CTgA9au+cS6I7/OzYJPaklczlsa1mCrvG8w2 vwOMY+vrVG4XDoN4ER6+9aIzM5rWKIyfZX2t1APes68tZrmdN0gEWMZHBP8A9aoehonoZhtGfEYm BiU7T7Z/l2rbtLYWsbOh3Ed6zY2bUUUk3ltlkzznua6uzgVIpGkTJ24O7uKq40zqLSxLRmaMKIxg qD1Ndnpdg90A2fm29SelZSNEdSYFiWKXZmReeBjdisC8uVWZtgCsSXPy8Z+90FQx7Fe2hilnhkMY JJJ5PSvbPBvgO91Se2kFq0kxYSRFTgcfMN/oKzeiNFvc95sfhhcXdpJLMksdweOE+QfjXl/jrwNq OmSIyQs1qrAiYJ1wOcj+EAn+VZqVmVL4Tx7WNHvba4B3MLfG7Cngnuf9mn6bFIxKYUuvXI457VpD cxbOngtgrxFWYYba/YD6VswQvdMl0kSCJcpvBAJwenvyT+tU97krRlO48xZJI41xKnJ461XYRyvC ZSA6MHG4Zyc0ki27Glc6ztZELgK3Q9MVn3OryxzM5baAvbgZpuOlxKV2crd3txJuw5aVmZgV45PN cxqTvcxxvMpXY+7hvv8AsfapSBvUprPBJEplcKp6ux+XHqalgSW3lmjkKlWx5ZQ5DVqkSiaPTUGL ondMSd1b2m20zfOqZdjgA0ntY0R0bRm6cQxQkSD5SuOtdrZ2z27/ACHcoOQAOlYvVmsT2TQbZYlV gAySoDweQ33hXt/hSzRYjI1wGKrgbl5Bz2Pt92uWbsbQPetEtSQrAfMVAkOMA4rqCNrOcgsF6Y4P tXHPc6EXIZDDMjOcxsB92obwlEbfE7O3zqwPAQVDepL3Of1Qwx2qb5/3jNldnUY/p/OuI1e9DW8j vJjyyoAAwM1rHczZ5N4gv1JySVxw+DgsPQV4lr2oN++3DI3fux149T+FbJmcjhLzUW2IZHbH3cn9 Kw21CeaQxxSfMuNpz+ddUFoc8tym+qfv3yTzwcHjiq66g5kf96wGOwzt/Ctd0Tew+y1h4JpGB3DO B32//Xpuoa01x5ZZMMDVpXIvc5+91icSxQqpAbkDHLD29ao3N80Kb1fJBwTj9KdiW7FC51Z1EhVQ GAyPTH09a5SbVJ42ADEIT0pvcXMZq6g7XJt4YwQeSx/hpJPtW4E3AIzj/Z//AF1A0yt59xAJo5WI ic8pjp70kkO9FAmPtg9KS3uUUlMyBd7btpxgnmnefBHGZfs7LIeG+bdj0/z/ALVUw2Ltt9oZWuSw 2qMgHv7VLGfMnWWdvmJ3HZx+FUtBM1o3eXcUjzEOnt71YuPOWYW8TkpjLYJ24piexaKo0BjE5EQG 4t6VTkuLd4hHeQqY04Cnq3uf/iah6kIhhvXnkjJjLKrYPGBir88UVvbK8TFpXOfx9BSE2UILo+Y6 soMR4OR19qe76cbWaJZJBco+NvYj6/n+VUhnNXUaRIShOwj5wOv4+2aoTr9oZXMg8oLg8dPemBGd NkgEhjk3BjkNnmuhsbVDmNVH2mTGWBz0H+192tEB2EUVyhtlYo0wwFMYwB6E/wDxVdTbo0oJ8ngH IGeGNVYaJ1L2ySMznyTzg/w0+BvOdpUOU24xnPSlYGWLSSdn8pm/cLIRwBlcD+XRauPOP3zRJ+9H VQOWpPYQ6SNZ1O9wXxnJHT/vmpvtGbZcwfvM7QGP5H8ai4HOvGJ5WmZgVU7SPU96stLb2lq7KSJc 54GQPrTRUTCguDPKMhhlshm+61dEkSb/AD1AVCSNmOf89aaeg5IXAt5VLZ2k5aTaxA9Bj1qwxeVm 3HLHkFR0xUEGaVM21llIhzzjvWdBKjtOkUpEaNtzjGTQFi+m+ZC0kpAX34NZ1xI/lxpbsPNYnKkc sPr9algjjri7ubkmJSwZeCB0esG1tme6NwrOVBxgmnYtux0EL+a58gjzTwCeQK6jTbea8TYm4Afz pNCub32FsNuDMv8AFwcAehNdN9jnXyjEoSMoCjDp/wDr6U0iWWJIo5fIZzwjbj6mlFzDvCKSSXJX PH/6qtEp3HQuLm6xJnA59BWraK8czR2ygRscMWGSfpVjudBYwSzF8QkunQDjPrXYW2ml0lVAVdk5 J46+lXbUYr6bGUtllfYsZwq7jhv/AIo8DNEmn2ls7M+3c45J5IFAMx5PLtvtKNAEeOTGTwSPXH5f 99VmNLFJJ8g5X7zH+L0o2IuZM7RySCSKMlc9jjBqrdzOsUke75BycdKzE1cxoL0rE7GP5SflNPg1 ETyOkaESBM5OAM+lWtrDN61uiqfvpfnyMYHaumi1NVRYoB+5VclwaaLWpZuNQlu4PtSzB8fuiMAb fwqGw1LYjMSuCPmz2PqP7oqEaSNKyntZnkkdHeWNRsx0OfTtW3Z3lvFJLOjZYDr/AHTTcdCGiDUn meOMW6/K5y5xxiua1M7LcMy5jU4yo5V/6UmG5wurLNIFVJcopD5x19gazbOPzJnLMMjHfkUN2LOh aaNGllErKzJtYBsf5NUZLm5zuBBB45ycVAGTJPLJI+0HeO+O1XraVodshXKEZcE4pAbFqUuo2AkZ HHPc5q7AxjeaFBjaccHJU+lNK4yrJp93LcIWI8llzuznnPQ1m3UjoJFdcNCxXGO/SqSsSzlNQRpb e5LS4Y527j3rgWtPtBljD7bkclh6UbAtizbTZtSyqQ6sVbPAOK6a3+1RFFRiw7jPSoZaNc3IeNI9 xGG3ccHNaFtLIGMm8ko2AcYAPf8AGswep0DBCTbRsGhY7iV6qT/WoSXjZWXnBxjHWqTJFltkCs32 XIPzMF5/Cs+coyttiZe+cCqQGfLcq4R4k6Ntz9K6qysZ1KNORsyN20AbR9f4jT5Rp63Pf/CulNcx mNhi3OcsRnae2PSvYbbSbRLaBZZQ+xACx4Gcc0izA1dYgYwVU7fnXIwK5rT9PE1/cCThGBUZHCZP Wk9iW9T2nw1p9sjwzCJhHA8e09NwXpk/xV1PiLxHFawoYyjujK5jZTg88/1rFmi3PkvxDNdazcwg wkxRFyGx3J5z+VQadYPbfOFUK4zllyPb+tD2KPQtN1O2UxmASbgqhBu6Efzq1eatcTyGDaxkUfNk 8rTsB5vPbv8AbZ5vs0nlByzED+foK4LXPEkVvtQIcnHzDHB9D60RBnlOr6heXEEyW8f+kF87iMkf /W/2a5q802eWYyNHIXjAPmKCVP0rRIzSPRfDlotnZkuoaVzhz6Y6Yrj/AB1qLtCjWpyiOVdQOGx0 prQaPE2ieWaOS6gKtn+PGCKp3V3HLcCG1Vsrw/GAT/SlJghbK0iWUZQMzElgRkLW3bTOuqRxS26v bHO5mH3QBXJVZpDax0sduJ43GRtA+XPFaPhrQp9Y1eKC1hkcR5M/ljjGG4J+v/oNcrOhbH0r4b8E Lplut4IJGR23NlhkAf3e/wD+zVnUNIkvLmNLR2W43fJGRnn3Pb/erGTKN3w34CuZLgFtsdwx3c9G I+bB9q92t7O2sbdJMrHGhBl8sngdMgH8Pl96zZSM2G6eaQvGn75uP8+lfXPw1u4LjTJGn2Sea3Ak OREBxj8efmrO41qfQcWrWdrAxu5swoNy7Rz+A71XsfFjyTLapC4fflQr/Mo9aL2M5rU9Z0TWEtij XRZmVuSTziunur5J0Eqtn2U/oa3pswmtDjdS1B9s8zhgijOMHpnaOv3unauTmb5FuASUY5x6CvSp v3bGD2seWaprAubmR0faobGAckenNUrfUJ96vcMEVC+xWyNydMnd34rOW5UdDN1rxZY6JAb9hu7B UbJJPQDj5if/AGaqWj2HijxkiT6/DPZ2Ckuto8jlvLPt0z69PvU4rUGz3PTtPsrGGK3jgYQAZIbB OT16f54q2kjBlWKPEQPyc+nvXXBGEzVt2iid5SS235sY4/PvUsE4LsA42uclQMFe/WtEtbkIuvJD IRFMhVAODnINX4GjdVSM7k9+9OwmtAjW+l8wRxYUfdOCQfb5enFWo4IyUXBCAkFyeR/k1SRL3KpX 7OpMkxl3ncSq4AHep7d3mQAMyRZ3DAzuAoEWDcPLOmFO/OQAvQj/ANBq8qIjGLCC4U72IHzE9ual 7gP8noNxx1yejGpYYjC8oKrtcfeI5qGgKawxh1kVsuDz71aM6lxGnCv1GO/p+hqXECcFQpDptYcY PepIJ5t7O7AbhkBycke1WA6LzBJIzCQKF3AYIV8+h6Gr0DhT+6UBM/Mp5IqluHQkVkZ5NwLMOBz1 rSWUmNhGM4+U8fdp394Ll+1SOaMpNkSD7pzUsccjOwZV2gcEPyfwxSe4E4lKAjbkqM8DJAqTY0pd lO7C5XGev4VIA2RH+8BG0gk5GOoGD7nPH+7UqyCF98Sg5bHTkD/OaaKjuIsMUZLElWJLGrdqPNZo +4GcjpQH2rljFwCG+Yr1x2Hb/gPSrcRVo7i4jhUKo8tWKIz5xuLgEHAHvQN6FeKJZGkkUswJ3HGM qccYPapYEuDGTKipFnCkyEnj1yFp3JuWXSHmRmJ5GxVGS3qfpSxqI84HzA5FNsdtC5CQqSMBuz/C D0Ipuxpjgqu/hgAeRUEldk+yxIwGU3Y3Kw+WjzUeCSJiWJ5+VirR/XjkfSgt7DVuEkh2bsMOnHP1 qr5s3mBIU8yXO35Vclfrxj/x6qsJDfNlSZYguNvDAjGPalkKuVcqRlsEdxS2E2RzSyxYMYYKOtaJ dkt4HI3b/QE7R60iyq5DMqRODjlueDUEzxeWBHGzSjnCg5A9c0LcBgZ3eBJZCFU5980+SSZBJuBa MybB24wG/rTtchku/YnyKdvSq7NHuXCqQBkZbk+vFIQQK3zyFWVQeCyEbc9s/wAVWUAjUXG99z8H d/F9KpATSyRqC2Qjq3O4n5xgHjj3FSRhGdGmjJUkn94p9fcL/KkgBys0sxdwQ5IXA5HpzTGj8tiT J8p9+mPSmzTcpIsU07gluDjGcFv/AK1OfylnQLGQxO0YNO5L0CSVI1CgFQWwTjNSGB3DiNhuxkEj g1K3JIf+XeRZWDJ0OTx+NV/t6KzMy7oUXLMP4cVb1LjsK+xpoXY89fmTg5+UCppv37CNifu4OMKq /gootZAx6xN5IDEBlO5QP4kqJpQ4jZFxnnaeKX2rg3YkWdU2KThpCQBj7pHzU2eOdkeUMGXuBwR7 imMqltsMZXLRsMhgTtY44qZIsRhivzdSM9RQAhuUllUMmUxsYHnI9KapMmQx3ANuzjGD/wCy0A9C S3vpI0MQi2jdhivY578VLJcB2VWPzdetQ3cFvcg+9LGVjxH1OXwf89KnmeZo4bOGNSWfG4nB6+tV EmRHDKyq7CMnHHPQGqs5dZ2nVPm/rVdQW5c893ijm3DywMSKoOc9hU4IUq7LtY4yWHKVHMaIFuQz Bg3yr+dB+zlt8cbh+5PSpC5Ju8vYQQVPYDk1DdBmlWWNGaIEbwG5x6j1oJJLZZMyn5NhJAkfAOT0 HyjoPepLz9wwtQThsZP+FAFdFaMybl34OOF5GasRxTM0bq2CONpqluBBcojzs0LAMPl9zinSSPCq xuu4+38VJgW47V7e3+0IoBAeRgCB15wcVn3VyjQ+bGgVlYKNpwGJOOaT1AfAJpXKyH5nG0rgYYeh zV/Z5CmPYAIx0C9KaANvm8uisB2I4FWZI/3AZCpwd3yrzgf+hUgM6NL1CsmwI2NpikOQwz1Hvir0 ZYtvywA469KYCrbNak4uTJG2WVWAJBGOM+nP6VMwdyGPLnv2pAOWXEAjBwuScdjmrLKZIGTJU4+6 epoDqVoIArod25enFMlDC587zB5fKAEkA/pQBaMiPEsPm8Mf4eCv4/xVHC1yiEbcuBzxVIB8a5yZ MEDaBgYzVbaRdyS7gvAVjzyAOny7u9JgWBF5cxVSCp5yOMfhT4t5USMrfe2Bj1yKQFpIYRl2jO7H Oad9mDKYi+FPK46rQA6S2AfcWIJcHdnO3hV4H0FIkE1s8km4s0ny9eBQBejlRZpAU+QgBWB5L55B H8I6fNUE8ohlbdCwZThsk9fcNWnW4AhkMhEr5YnPIwV9qdG6ROzS55OCRycCpuAQbzI4kXEBX7+f ucnp7012lZIzMysvRWQbcjPf1NUBJEy/v3iCrM4HOOOKZG6xMDcSr5pz0BOfpik1oBcdtzjcSMcE Cq7+dvSWNiYwfujHzfXIpPYFvcgER2tGykMxJwT0p8rZRcNuTjnP+9xQgEWQjaqtyTg7ug+n41bV My5ZiVXHA6GqAVpNpChCRngetSSqXyzMwbI25Gcf5GaABBIQVEZIDZ3HoKLltqR7ANrE5JGccUAV xvAAcsWJ+c54Ydh07U2S62vuQjcBwMdB93igBYpjJAZIwGds7Q5wrD6/nWwrBMBpNygZPc0AQrIJ JGWI7gcfd7EjI/SteAkqRLHls+nIoQnqIY/s6oiPiN8tgcY596sCDDqscitnnOOVNMXQtQw/vEDj C9yTjOKhmCh13N8/Xp1oGmIhLI394Fu3WnsoWNXyBluvekO5cXY0SuI924Y5HWrMQ3RxgMQF6beC DQFyRivmO/PPvk1CyvbtvJ/dsce4NUtxplqO2GGaLud3sTVZvNiwJQQxbjB4IqgQzyyAzMzGInJ5 5X3FSqiJmTPO3G5gN2O3T60mAM7snykhR7datQqG2BwS27IwPb9KkzZYRID88b5Urnpx/wDZVG7D zFAOD196BDmLxuCu5kzwRTpVlVEwTtIK89Rj696LmY5DuDO2fl6e9SMmR8o6igCIbh+7wen501PI kIaRD8jZzjpQio7jiNzhxkZ64pSm2aMD7pGOvU5px0BoGXLKDww6Z71MqxqxORnoD607e8SDkHMZ UbemKijCr8pQjDbj6GqGXMRclUG7Gc0m8SEKRz0zjgUhDWiAGOoPc1QhhVp28y5ccnagbAx9P4qX 2QL0cIjDBSdg657VE0ineACB2NFgKwwoZJFbAHO45DU1WBeNIlPlL1yaTepotiR2Quu6Ibh/Fjmj /VuwR/lI6Z60A9hxjjCNLt2n601JAuxi2WJ/KkK1ydJVEoypOeAOig1akZ8TExjPbaaPIgr7cAsJ CCASQASTikIkV8yZ68Y71aGOI3K3PPbNRSO8UbEgjPHFBa0Ex90M/wAx5xULGRMDAPOaloB8kSTb dsgHPpzVSWOMYi3An1FSB/k0alPHcJ5scPyjpz3rOtFubhj5sgMWM89/pXbe5q3zCmRpGjjSEJEC SxDctV6SKN7ZZQrCZeOD198VPUmO5y9qZby7uLeYArHymM5P/wBas15RFcziSLcT6DG2oH1EtpPN kdVmBZgdoI4U/SrLtPZz26Kwd2wGKjgZqVvYDfsWnSOQud8bHPQcYrQiv2gkBWQ5HOM9K0vchvU6 6zvLcyq0rkMfu7mwD+NQazO8jxwxOTH/AHgeKEtBdDp9Ks7eytFuvLDMRjcRnIp8EkU1w6+aMEdM 84omi0az28FrawTogkdmIYZ27a8+125WOaY+ThTztNSD2OGuYpJ3YyOFjx8ueADWHc4tSy+Ysk3Z gMAUrE3M25e+dg0XMWM8dR9a2rKO4az/ANKc7hxk9cUupSRfVrD7Ktu1kxuGl3B06+2fb/4qpNQu bu2kWJBiUcfMOVPetFuaLY29OudR2jzgixEEPj+L0qRbq5hkG6MHzBtx/d96odtDVihuZZCYF3YX BPStCLTxLp0j3EpjmX5kK9z7+tYMOhraVbzLYxXbwlrnkosYzux7etbMcMc7RpqdwSEJx2IqWh9D ZtoIIwoOfMGSPQirsaXMRNzHb7lHQDtUGb1Nu3jJg3zyZfliQOPXGKwbmNnR2iBC85B5IrRIaM6C 2kVwUZfI3fMWOMVtvYgoreZ++XlWHVauOwpbm/pdrGkKKI8NjOf7p7muxijg2wqzfvCMe1Noaely NBK85VVG9P8Avmp4oxb3nkS2wCHBJYgnkZ4/z60WsQ9i7cRwCYfZwNh+9ntVdtvCNGCnqaaMzDnk xcBIYiyAdff/AAqK7gjki++POXlcHvUPUpPUz5tsTBEXllGQvY10NjCV8uDGcrux61D+EtanRxad JbywKMlwd309q7QWxYLCIz8ygMT1AqbmiR1ujabGEuYngIaNhhieGzurttDtnjaTMJBA+8V4OfT9 amRSNKSF5FaNCCO2B0rn5NPl3/LEHlVui8lqhlbnq/gj4bax4gvre3tLPOozocIw+W0HDeYzdv7v Ir9NvA3wZtNBsYLuGxhecLxK2VWNydxKooxnP+z3NYzehvCN1c9UvvAN1JbW0V2I2idc4i3fID68 LzXler/De5ksb6UqDYF/KlhZNpQ528/j7VzzlZlSifA/xW8NnQ/EN3YNEB5LHzVAz8n/ACz59xXj 8jCGMP5WNxwFA5X610U3ocs0bmnSx3CwKfnRTgg9h3Nal18mFjb588L0J+lbPYjoY0TTXZnUMAoO D8vJqN4fKVcrnnAzQkNu5iX9n9pjVpCUYtn6j2rLuUad0hY7ogv3sYx7/wC1VP4CdmZV3cr9mVYy wlB+b2rCuVmaAPvyu7nJ6VmkJvUpxreK5ztNsRjYV5rd062lZTNIrHnanNbJFI6+w02NrWa4Lh3I +6O2K1LLTFkDspdZh/dPH41L3NkdpYafbwJGEUmQn58nLe5Fd9Y6NbW9uL+QEo2N2wEsPSsJ6M0j ueiaLYO42R4DqMfN1Ar3XwvYKi2yFB6gHkiuGqzaB6RbXMtvLsSQhOFG49a6dJLc7llYpMB8x9a5 ZvU2TFSeExhluMypkNxhfy/z92q82ox3KTRtLh1jwnGaSWgPY5YspJiEmZScEqMnNcbrZMQXk8sf lz8p+o9a2UdSGeVavapLBcuZ83Abdt4GE78d+cV4rqkVrC0jopPmE8DnfW0UYSeh5VdzyTPOkw2K mQMggMRXBTahdi9ZUK+VyME5x+PrXXBaGEtxZdTePkR7Tu59xSpqnmOXjby5SMfMfvexrTZESHjW obdDDjMoJ993PrVRtVdXeS4bcnUY4I+lO9iXoYUt5dNcMyv+7GSEPamrqhkgdHYFslfxqrmbdzHM 8rzF2DG3BIIX07VRucyeeUkInBGCRnjPSk3pcEilFdQwNON2Jsjr90CtaCM3G0hsIvzdetSUkQXK vJPCNp2hvmOeopHSaO42xtutiNxyMFafS5Q+e3QoLyMES9s8hvw9KrRxJsO7HJ+7nJIHeqt7obkm 1rlGCqVXf90A/Ljv61Ltlti25wQex5xTWojWtT5VusjfKWJyCelPjdbqO4dXG2N9jFTyf/ie1APY ZNcFYFkhJKE8c8H3rnJJvKdYXQgHHJJIWkQWbK4QzsGJ24ycHANXhNuvV3LlTtJw5AP/ANfpUg0K 8j3SoAdrj5RjiqrRGOUSo25gOfc1QkZd4jSLcKGG/ggj681Us0YvGrA7MfNj09PrVR1GbySW6kkN 844IPpXQaVHBGIYxF8zg+UcZJI55K1okM7CzgkEivsIz95gOK21jldR5J29z22jOM1bGkRfZ7lp0 XeM7RICR0Pp+lT/Zpo5y0cgDnqCvSpEyu8E8c8l19qCwjC7F+85J5+gq3G8sTOSisMcMeq+4/D5e f71S9xGio81VbzQqt1YnoKinlkLskRDQgbR8vP51FgKk6+bHCkq4b+A5+9j1qCS1YxLHOpCZyf8A ap2HsVZLZY3ttjEWrnnAJ21svayRwRtCWKHlSf4gKLaBccLiAxFWbMoHJBpgeONRLLIwHONh+96A +1SI5u/1SKNGgiKLIz7MnjBFZguLzTII/tsKyZBAKnBOehoFcH1AXMcEsM+EJKyIByuKiuFlcqoJ bcSCM8gVLGUobM75AGJRTtUd81F/ZfkiTyifMxu9d3tiquNu5s2cDX0SyyQql1jY3ygHjpXfabpu 2CFQ37wckDtSEb0Fm4WTYhLHt61pIbhbWOK4AVhlFDEdPrTsSylcafcwLPMjjZs+XceD9KwJ3hMa OWHmEYYEfKRVIT0NuzVd8CupYDnHT/IrprZAVM/KgN94dqoDsdKsG2yyxzgg8rkckeldb5RSFYsj zcZbntVX0NEMmtRcwlJG+RSHrMmjglBVl+c8dcYpcwMyJIom81r5gJiu1Wyctsxiue1JAr7om+bH 93FOTJscyk11HCUkhAUucEHmsa+u3idkUHjsf4qkT0M0zx/PJvxwPlzgH2qS0fz7lSIRsI2Feu6h b2EbkssVuiw5ZlPGc/dxVmOTyIEKPjjOCetWi1oU7qb7ZGsTkBN2TzgGrtk0W2NIX2qCF25zupfZ NNzqbG5Mb+VhvKL7iB6+1do0kflqETHODxxTb0CxTnf74jkDW6/Mq+h9awLi1a+tXngux5u50O4E FCPUf561BKMW80uQwbVLfKcFcYIrGWy/eFkUgKc8D71Q3codZwPc30OxQYcEk7vvY9vr/WqsqzeT M4GFHJ+lJgURPbqYo5GxIBvCfxc/7tXLWZJTcbHLoABgrt59qAN+xlQKyAbWABrXgjtRvJYrGDuf A5yev4007FfZMG+1MfZ3MYeNlzjJyWxnjC9zXHm+ulf54j5LdFbg5781SdyGZV3ciJQCx2DlUJyR +NYRgd5GmQn5h09KNxLckEZWWKBx+7J6joDXWxWdwir82CBt6c1DLiT20Ebl9qYOdpBH3TWgtvsd LSBsKefxNZsDdSyEcDxxbjMDuY5J5Pb/AGelXFgubaIMxUxKuRupxQjPkvkKRgqwcli4A4xXP6xM hSdoH/dAAcHk81oMwIPLnAEjsE3ZAP8AEK9n8MIrpbTXoykj/dbg56AfN2z81WUloe9abqC6dax4 VTx93oCfetfTdUurl5RK/wAoAJOMA/SsxliF/tMzW8rbpOoY9GHpWjaWredJHJF8uBjHapewmtTv dLCwIyL95gAOSTx0rN1Rp5cLEm+QHOMdfWs2UtzhjpUiI24qknPIGdtcdPE4VLd5zJJ0SQHAYduf T/Ch7Fm94S0G+ubmaTzk/cscEk7XzuwQceldpqsUNvYOzBftKLyw5Zsn+gpgfLvj34hTafK9vprH zg212jYFQAehHy8/99dDXh1tPe+JNRY3UbFmbLsrdc89P4QQeKexDken6dpkENtcyMhjYZA8wZyO 9c/c3McztFBIhEbbSB3J7GrSJTOq8M2M00AtzEE3ZB3c4Oe34VL4n0LSYLWSJYjvcZIJ4Zx/6CM1 S1Gj5/8AFLaXpltdeXas1yQAArcqfX6V5jYG6dZbiWNfLU5ZugUVjVfKBt6ZrOkwSDf9yRsO20mu iWO2bY1qpjVR8285LVxzZdPcuaV4e1PUJZPLmIjLYwudze+PTpX1h8OfCTafpcMVzCyTgmTe4KyO emCOwGPxzWLOlbHSa1q2m6Zm1+6yE5dmJyR1wmKyfDkR8Sait5bhmhLALKMrn+H+L6VnJFS0Po3w /wCHfs0riZdzrGXGW4GO/wCtRa9FCIFaZ9sQHBzgfiKyYRZxdprE4vC/yNtXy4o8Y6dDn+de3+D/ ABnFp9rMbNFk3JtYRkYI688c8/NWEmbbHuXh7xI+tfZkgKLuwA0jYGTXqlpeaV4dZ57qdUlHMjMe h/pSi7kSWhyni34r6NBFA6askEYIkG0OJMA7XwrcufTFekab8SbebR0ktpIZnK5OxtrEY5JHauuC MJrQ8mufjPokN4NLu76LzkcqR5+9iOuOnXFa2peLo9WjjtdKZV09huc5GZDjkH0HI/OuyLsc7Wpl RwbAfNP74/MAD1+lQa1cRC3dXgCyEBFyfv5qnuH2Sbw14Mkv7hdT1Kzc4XEW9toUk9Qn4fe+te1a bALS38kqGcccclvfNaxWhDZpn5Qh8kn/AHaXynXDKpCtyCR3rpSMHqEAcE25JWIHfgnq/wDSrdk3 zyxtA5bOV2qTxzk/TirWwmaUkQ8uNwR5fTr96n20sSxuZDtTftGGwePm5qhOWheDHzlYAlVwQ2el StO0paGEgMDucA5yPfj+VJsT3JLcAFcodobjcf0q8UDOuPvgZXB6f/WoENjeQu0gYMcbTjFSQxsN 2TmLcSMnpk1D3AuFRGQd2UJypHYU2Z1AB3lQAB83b/OaLgNkD26r5cYEgbfIXXOQOx79+1Mt3kVB JIVbnjFDAsx4E8crxSHcQCrEED1OKshUJVgxAB6ZzikAu6w3oTFGJgxCzeWgK+uT69atqkjD5HwP 4cU1uPqWo1AiMrjbtPfksParsImSNjkMoBfCnP6fxGgLFmOTEayOcTMx+XGMDOK0cqBGFJ2nqTz+ FNbhLQrLERPayupB3DzQrcEd6mhLgxtK+1y24beOKkRbnIt5gYlIDnLfKfm/HtTreIiEEHJDdasu OxeCsy4kJEQB4x1pUYRbETaWzg4HSpDzL6rJKjKVZTyCueSRVKSJG2wpncx+dPT1oB6mnFbvEFki fCAkFQcZ+tVnVJ4wWkHlnldp4b8cfNSILYU7iwAx0FTGAMAd3zqc9eDTZV9CIzCF0iCkSOMjjA/G pEh2FlkZQD0KnNIkieIorRk/KD0x/nmoWiYGSJSOR26/+PUFvYYigOdqZC5Dc9/pRLmQhIsmNhh3 U849MN96tbCRUkLDy1kUq0hIDMRlsHj/AHeMVoMXh2pIPnxtJUe1Q0OUTOIMTt5jMyFs7Rxn0zUk mxyHVvmx3/hqQIIypkBYhske2P8A69SXP7yRmiKiQDA3Dg1S2GV1leLEcygMOrZyD9KkbeYykjMf LbeOBxVbEsA5kR2GNo560irvVcKhXtjhx1znjp/tbqhkliNGZGVTwTwCePw96cYiqPHuIYsWwTnr jt2HFCAkmjRlXEv7xCAVJyVyP/rVOkskZhjBOADtPYZ/rSAjZolXLEhT/Dn7tPbOA6R73U/LvbC4 x1B9aplt2M2NJI443uJDtVznGGyPTOATTbh3Z4/s8Ye2DA72OSDznAx8vb5s0mTuRtP5blCpYngK PSpGmuNsg2AS4Pl+xxxQtwIt5jjCyshdjgF1BCn8apPb4mARuG5yvQVb0HsjTe68qB4ydkvRWI6j 1pkc7SXCsBkMRnA9BSvdEthLGUWeUqFiBJ2gfnUZj86VkV/ujr2NKRTVx0reUwZtuRySvSrkUzrJ 5YUhixUcH0z/AMB4HenEogimjYsCSr4IK5+9TYrhndVBG8fdbPSmBC8k3mK5hIj3Bdw9e1TpELV3 Ac8n880CeoOpCybtyopB6dDQ0JeRVVsMRnd61DVg6FkJny13hpIui8Dn19aoyyyo6IF2gcYPf/4q tLaCkWBt2E5yyDIGeWpfKMqI27Ld8UpbXKW40fLOkeFkTZhmdPmPPQEc4qVjFGYIIlwhbJIwAtZs aHbljSVFUFcAkgelOZgqR4UHGGIHXnDD9D+tAh6fvMyqenQf571GJWRxuzlu2eaABkeNVkLYVj8v PWpJVDbsOQA21eCS+ffGOP8AgNAEMbiLc64Mmc8n71S75JJTIWUY4IJA4/x5prcABIR36yLn+HO6 lggjd/PZcTkfKW4ye2aGBZLgxMsyBmwTgnAb61G5t2iEawoE6k7etJ6AV/LeCQMi/udoQEclfr/8 VVvymVAivk9snJNACrHK6Dgj6+lWBEWQpIAy9xn71ADhCu1jCqrGpyyjjb9KUb3I2Nhjng96AHhJ PlJUB/ukjvSbk86S3AO/G0+hyKbAml2hUi2/cT5gvVfYmiISmHh8rjaCTyRSH0GxxyrJKxuDyO45 FK3zdccc9KBD5zGyRRhAHHLFAB3+nWoBHK0pSKZ1QoG653fe9uPwNUgCTfA6Rs2XbgDn/ezU45BB jUI45J5K0mBPHFvTKOeOMn9KtiN2AEWN/GAehpAOiXYXZg24Eg85DehFJKQNpU89RQBaKGNyHA3j n733h60yUlwpUElc5GcUAVm2b12hfNbjdjkqOnPp1p/3QryIVRR0BOCSfTp2FW9gLHmhRvALE8jd 2pu3zQ0gZVUDcdx4Pt9aiwERmQJGflaNuc54IqZuZFiYDzSc/LwF6nnbVXACx2PhCCnzYxkn2+Wp IHK/vliBmQbgCPu0N6ALblJYX2hcZPTK7j/+un7xAzpIScDG4AHHfsM96HsLoJmCUW11buCDkByp yee360+VCS0uRgngAdaEMhltvMyN/wAp5YetLCZmeUEnyFxg9j/gaoC1LOYnUJHjbyWPIamoSyj5 8BvmXJ+99KAIXg+0BzIW4B2YbIJPtTUjeCPZG5llEfKnJ2kelAEjvNIpRhtZV+YMhBL46fLu/Wlg iAVMqWkQFtu3JHHJoAVA7OM9fatGKOMuqoTtJ5OKANCW3e2ZZ8nDHCDOSF/xp8TbvnJIYHO49qSA tyHcx2J8743FupA4xUixukhO4MB0Kk0xS0RHJIh+U/M3XBonjDMCXO3HUUyUyNImWeRT9wDOQOD9 KkhCyyLHuJwemetIr7VjTiDCXZngZxjtVmMvBIjOmSDuwKCWwkXG52b922eO9NtxlHjUfKDu+lUt wTFlWRgsYYqOuVOM1VjlTAglb5t2AQ3P4/jVFotQR+U0kks+042ojAkH/wCvTlhRmbCnZ3x2oYyQ rgAOxz0oQldjBiCc+qk4PvUEMdI4Dt5fLdcdzU0cqKAzJiQ84znFBLNBAJFKg+4IODVFR5ZZCz7R k4ZTgYJyR3NOxEhzDrgEmpdzlELrtb2PWgQksZ3mTHKjjjpTCH2GRQHRuRzggf1oLW1xRFuVQAc/ XrTok2uWEcZw2QWT5h+Pr1qhsY06tkbPnB9OKeoUou5CDnII4waEQyQskpZ2TDLznPWoVO7lvuHs QKGImVdqmRT8gOKYmeSwyM9hjNNgToC7Nxnb29KhePp0257HoamQEJlVAAc5HBJHFQXE37ouBhMc KR96qGWFCyRxmYfNjnFRrgSMqpgDsKlrUpbEjBQM7zuHPuKrHZGq+Yv3skHPK0hvYfJKFgVlJ46G mW6PsLISDndljx9KkNi2SGTbtPDZP44/wqVHkJLiclScbcDA/TNX9ozHtuYkhucZpjOSxblkA4zT QyqHZ+QuADT1b5JEY8E4Gev0oLWpGsW3G1gAPXv9KkkhYq2w/P1G4cUmwKu6OKUkZLjsD/Oh1jd/ MAIfqxqWB/kuzW9rCjQWRcQnhcnkGud8y9sMWcLCTc+OOT+Fda2NZw5fcJDG6RyPKWLYx8p5X/Gq lnrUbC1STd5RbAJP3frR1FGOpqz2Sm4luY5vmK7fl7ZrnJbW7WeXyzvfHpmpHYvG1uoIofs9uoY8 OSPu025tjE+PODOUyVNSJsji1C6ZSZnO4cKM8LjtW9aX1hMi280eXPcH+dHUm50TToHhaNVIAwMi prA3M94YZEaSAfPnoop26lW6not1DIyoluQVHLA/0rUs9Pg8gSNHsc8EMM1TGtS1cWsNyADKwhU8 lRzXnHiWfT7aOcTMfMjJIGckDt+NTf3iZHmV5Mt3E4jPKZYdsVyk8F15UcEALMW5PUjNNK5BYWBF iaMzETfU5FaMcsptYgVO0N82R97HakB0Vqim3hv4gQpO3HUiphCssjRCN/NbG0uc81ZsdLYafLDa kyqROA20HnJ/wp86b4xvj+c/LkDrQ2Unc0LW08hLWL5grffBP3h6f59K3Y0h/eMxyq9hWD3Ezobb UPsVmsjR5H8IUdDV+wigubpZzCPtAHKnt9R60hF6ezkM+FCjHTPBFdFBbyMpcj92B83H3m9qTQiK O0l3zOrDYRwGPU1hXdiskirckqwO4ENg5qmBFNdJbwmJYfMthgAf3vr61fnV4IY5VPyMcepaqQrn TafH5TCRjz6VqIoXzWdwoA3DPAJqhcxPbW7h1eFuGOGPYVckthHJ5pbc4PbpSQMz5JdrTOznngDO
June 18, 2014 - Present
RV10-Archive.digest.vol-ju
