RV10-Archive.digest.vol-ki
October 06, 2014 - December 06, 2014
R0 VA-144 OVSZ
OVERSIZED BUSHING
Linn
On 10/5/2014 8:25 PM, bill.peyton wrote:
> Thanks Sean. The P/N does not show up in his post on my computer for some reason.....
> Bill
> WA0SYV
> Aviation Partners, LLC
> http://forums.matronics.com/viewtopic.php?p=431554#431554
> No virus found in this message.
> Checked by AVG - www.avg.com
Subject: | Re: VA-144 Nose Gear Bushing |
Must have been a batch of bushings or mounts. I'm at 500 hours with a
cracked plate but no side play to speak of which suggests it's not from
wear but from some out of spec parts.
On 10/5/2014 9:00 PM, Linn Walters wrote:
> With more need for the oversize bushing it seems like they should put
> it in the online catalog.
> BUSH-ST 313X780X1.563
> R0 VA-144 OVSZ
> OVERSIZED BUSHING
> Linn
>> some reason.....
>> Bill
>> WA0SYV
My point was that they have a fix that's hidden from the -10 owners
..... or at least not widely known as this thread shows. I wonder about
the owner/not builder that has no clue .... and the A&P that does the
conditional inspection. What happens if the 'fix' isn't found and done
where the 'slop' (out of spec) exists ..... ? Does the nose gear fail?
Not something I want to experience, and might if not for this list.
If it is truly an out of spec part, why didn't a quality inspection
catch them? So many nagging questions.
Linn
> from wear but from some out of spec parts.
>> R0 VA-144 OVSZ
>> OVERSIZED BUSHING
>> Linn
>>> Bill
>>> WA0SYV
>>> Read this topic online here:
From: | Sean Stephens <sean(at)stephensville.com> |
Subject: | Button Lock vs Glide Free Control Cables |
Has anyone used the button lock A-700 control cables instead of the
A-740 glide free cables that come with the kit? If so, are you happy
with them?
-Sean #40303
Has anyone used the button lock control cables such as the A-700 instead
of the A-740 glide free cables that come with the kit?
If so, do you like the action better? I am not a fan of the glide free
cables and am looking for an alternative.
-Sean #40303
Subject: | Re: Button Lock vs Glide Free Control Cables |
Yes. All my controls are the button lock type with veneer adjustment. I like
them a lot. It's been 250 hrs and I would do it again exactly the same.
Bob Newman
TCW Technologies, LLC
610-928-3420
> On Oct 5, 2014, at 10:26 AM, Sean Stephens wrote:
> Has anyone used the button lock A-700 control cables instead of the A-740 glide
free cables that come with the kit? If so, are you happy with them?
> -Sean #40303
Agreed. Just adding information.
I would further say that Vans is and has been doing a lousy job of
supporting those of us in flying/maintenance mode. It seems they may be
responsive in one-on-one react mode but lousy in the proactive
informing-the-(the RV10)-flying-community mode. However, as far as
one-on-one support I wouldn't know since I stopped calling Vans for
advice after I got the "don't worry, it's not the Shuttle, it's more
like a lawn mower" speech.
Excellent designs, well engineered kits, good customer service,
questionable customer support. Perhaps the most you can expect from
such an outstanding engineering firm.
(sarcasm off)
The cracked plate resulted from a minor design oversight. The SB is
good but a Service Alert/Letter/Bulletin regarding periodic adjustment
could have helped many owners avoid the cracking in the first place. A
similar communication seems appropriate for the loose bearings.
...just so you understand where I'm coming from Linn. Sorry if it
seemed otherwise.
Bill "SB update 3.01; the agony and the ecstasy of CHT and EGT probes
for each GD cylinder" Watson
> about the owner/not builder that has no clue .... and the A&P that
> does the conditional inspection. What happens if the 'fix' isn't
> found and done where the 'slop' (out of spec) exists ..... ? Does the
> nose gear fail? Not something I want to experience, and might if not
> for this list.
> Linn
>> a cracked plate but no side play to speak of which suggests it's not
>>> put it in the online catalog.
>>> R0 VA-144 OVSZ
>>> OVERSIZED BUSHING
>>> Linn
>>>> Bill
>>>> WA0SYV
Okay, that was a rather cringe-worthy post.
Rather than retract my rant, let me clarify a bit.
I'm in love with my '10 and everything having to do with it including
Vans. Van and his team stand a top one of the greatest aviation
enterprises in the short history of aviation.
How did they do it? At the heart, great design and engineering for a
once nascent market. Great engineering makes the world turn and in the
case of the RV line of airplanes, the product sells itself. Well
designed, engineered and produced for a market segment just drooling for
such an offering. I'm one of them and I'm very happy.
I do enjoy telling people "oohing and ahhing" over my plane that they
need to understand that it is a highly evolved kit. Building it is
pretty easy to do and that if they were so motivated, they could do it
too. I also enjoy telling them while I had a lot of help completing it,
the factory is the last place to go for that help. Rather it was a
social media community supported build for me. The community of
builders is resource that makes it all possible for the former model
airplane builders and their like to complete such a project.
I remember going to Oshkosh and S&F looking for a plane to build. Lots
of people were selling kits but Vans could barely be accused of it. No,
it was very hard to engage someone from the factory in trying to
convince you to buy a kit... unless perhaps you took the time to
schedule a flight or something. Want a hat, no problem. Want a ride,
there's a line. Want to listen to employees compare trip stories, just
listen in. No, the product sold itself, the designer/engineer's dream!
No need to go to a show or take a ride. It's reputation in the
community and the numbers involved told a pretty compelling story for
this buyer. I was looking at the '7, dreaming of a '14 and then the '10
flew. Oh Yeah!
My guess is that customer support is a litigation liability in addition
to being costly. But most important, the builder/flyer community does a
more than adequate job of providing that support. It would seem that
the '12 is getting a little better flying support just because it's the
latest offering.
Anyway, half of my temp probes are wired now - the other half will get
their bloodied knuckles tomorrow. B*tch B*tch B*tch.
Bill "writing stuff helps" Watson
> be responsive in one-on-one react mode but lousy in the proactive
> (sarcasm off)
> adjustment could have helped many owners avoid the cracking in the
> first place. A similar communication seems appropriate for the loose
> bearings.
> seemed otherwise.
>> the nose gear fail? Not something I want to experience, and might if
>> not for this list.
>> Linn
>>>> R0 VA-144 OVSZ
>>>> OVERSIZED BUSHING
>>>> Linn
>>>>> Bill
>>>>> WA0SYV
From: | "bill.peyton" <peyton.b(at)sbcglobal.net> |
I have done the same as Bob and am happy with the operation
WA0SYV
http://forums.matronics.com/viewtopic.php?p=431607#431607
Subject: | Flap Motor / Pos Sensor |
I'm in the process of putting my flap position sensor in and I'm having an
issue where the extreme limits of the flap motor exceed the travel limits
of my flap position sensor.
Question: Once the flaps are rigged, does the flap motor travel to the
extreme limits? Or does it only hit one extreme and not the other?
Phil
Subject: | Re: Flap Motor / Pos Sensor |
I have my sensor near the wing root. The way it worked for me was I
drilled a hole closer to the pivot point, went from one extreme to the
other without an issue. You can determine the location and what it is on
the Panel setup later.
Sent: Tuesday, October 07, 2014 10:00 AM
Subject: RV10-List: Flap Motor / Pos Sensor
an issue where the extreme limits of the flap motor exceed the travel
limits of my flap position sensor.
Phil
From: | "Carl Froehlich" <carl.froehlich(at)verizon.net> |
First adjust the flaps linkage for full flap up position with the flap
motor (and sensor) in the full up position. Go to full down flaps using
the set points on the flap sensor rod and then verify they are in the
acceptable deployment range.
Carl
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Tuesday, October 07, 2014 1:00 PM
Phil
It travels to the extreme limits.
> Thanks,
> Phil
Full up, the flaps are against the aft spar and cannot move any further. But full
down, they can run to the motor limit if the little notch on the (standard,
accessory) flap controler fails. I'd make sure the sensor has enough range to
cover that possibility.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=431613#431613
So it seems all we need to do is let them know ... sometimes.
Let me also comment on the 'Vans Bashing' ..... I doubt there's anyone
out there that expects any company to be perfect. As with any prolific
company and projects of this size there are going to be issues .... some
get handled in a timely manner and some don't. When they don't, we seem
to take it personally. I think my fiberglass cabin top is a real POS,
but I've dealt with it and within a month or so I'll be done with it.
the rest of the fiberglass parts seem to be fairly good ... so far .....
so I soldier on. My goal is to have my picture taken with the 'RV Grin'
and the issues I have have just slowed me down a little as I work
through them.
Linn
On 10/7/2014 2:05 PM, JasmineG wrote:
> Hello Linn,
> I will certainly pass along the word that the
> oversized bushing VA-144 should be in our
> catalog. Did you also need to place an order for
> the bushing? Please let me know.
> Thanks,
> Jasmine
> Van's Aircraft
> Order Dept.
> On 5 Oct 2014 at 21:00, Linn Walters wrote:
>> With more need for the oversize bushing it seems like they should put it
>> R0 VA-144 OVSZ
>> OVERSIZED BUSHING
>> Linn
Full up the FLAPS themselves should be adjusted to be up against the aft
spar. The flap motor will reach its limit and continue to run. Don't
adjust the flaps such that the flap motor is still trying to move the flaps
any further. The motor must be allowed to free run without significant
binding.
Full down the flap motor will also be at its limits but will continue to
run.
The above statements apply to a system that does not have flap position
system. The flap system should be adjusted assuming one or more flap limit
switches can / will fail and the system will continue to drive the flap
motor.
Jim Combs
> But full down, they can run to the motor limit if the little notch on the
> (standard, accessory) flap controler fails. I'd make sure the sensor has
> enough range to cover that possibility.
> Bob Turner
> RV-10 QB
It will hit both and pop the breaker if left to run.
On Oct 7, 2014, at 1:00 PM, Phillip Perry wrote:
I'm in the process of putting my flap position sensor in and I'm having an i
ssue where the extreme limits of the flap motor exceed the travel limits of m
Question: Once the flaps are rigged, does the flap motor travel to the extre
Phil
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
I decided to take the nose gear apart today to actually measure the VA144 bushing
and respective assembly.
Both of the VA-144 bushings measured .730" OD. The VA-143 bushing measured .733
OD. The ID of the tubing on the engine mount was .760 for both areas.
I spoke with Ken at Vans. The drawing calls out material of 4130/40 and an OD
no greater than .750 with no tolerance given. Ken was nice enough to go to the
parts bin and measure new stock -144 and -143 bushings. The measurements ranged
from .746" to .748" OD for both.
>From the above data one can conclude that either the bushings on my gear have
worn almost .020" in 300 hours of use (impossible in my opinion), or Vans had
a bad batch at some point in time.
I ordered both the oversize (.780" OD) and the standard size bushing for both the
-143 and -144 to experiment with. I strongly suggest that this be checked
as part of the service bulletin for the nose strut.
WA0SYV
http://forums.matronics.com/viewtopic.php?p=431619#431619
I could not find my notes from last march when i dealt with this but .757 rings
a bell for the size bushing i ended up with after machining the oversize down
to fit my engine mount.
- Chris
N919AR
----- Original Message -----
Subject: RV10-List: Re: VA-144 Nose Gear Bushing
I spoke with Ken at Vans. The drawing calls out material of 4130/40 and an OD no
-143 and -144 to experiment with. I strongly suggest that this be checked as
WA0SYV
Josiah Galo Saint was born tonight at 7:10pm. First flight to be determined!
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
