RV10-Archive.digest.vol-kj
December 06, 2014 - February 12, 2015
      http://forums.matronics.com/viewtopic.php?p=435421#435421
Subject: Re: Antisplataero gust lock review
Date: Dec 06, 2014
Send it to me & I'll have it welded for you. I have been doing the towbars like this for about 8 years. It is always with you and works great. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Dec 6, 2014, at 12:49 PM, Bob Turner wrote: > > > I too extend it against the seat back. belt it down. I put some Home Depot pipe insulation in the triangle of the bar that the stick goes thru. I use the other seat's seat belt to hold the sticks firmly against the Boggie bar/pipe insulation. No need to carry extra cords. > I don't weld, so I used some hose clamps to hold the front tabs on. > > > [quote="jesse(at)saintaviation.co"]For the bogi bar, just extent the handle and put it up against the seat back and seat belt it down. Works great. > > Jesse SaintI-TEC, Inc. > jesse(at)itecusa.org (jesse(at)itecusa.org) > www.itecusa.org (http://www.itecusa.org) > www.mavericklsa.com (http://www.mavericklsa.com) > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > > Sent from my iPhone > > > On Dec 6, 2014, at 8:16 AM, Bill Watson wrote: > > > >> Looks like a good unit with a few 'ifs'. >> >> Another solution that I'm sure I picked up here and have been using for almost 3 years now is a modified Bogi-bar (http://www.aircraftspruce.com/catalog/pspages/bogibars2.php) It has a few 'ifs' as well but if the logic tree works for you, it may be a solution. >> IF the Bogi-bar works as a tow bar for you (I have the stainless heads of cap screws extending from the sides of my nosewheel pant - the Bogi-bar fits around those for towing and works very well) and IF you have Oregon Aero cushions - are there any others out there? Don't know, probably will work the same anyway and IF you have the standard rudder pedals - I am unaware of what else is out there. >> THEN you can move either seat to the rear most position and jam the collapsed Bogi-bar between the front of the seat cushion and the rudder pedals. The round tow pin receivers on the bar will hold in the gap at the bottom of the standard pedals and the handle jams into the front of the cushions with an over-center kind of fit that will stay in place in heavy winds and THEN you can take a short bungee cord and tie it around the stick and Bogi-bar in any one of several ways to lock the ailerons and elevator. If you leave this off, it still works well in most situations since the rudder is the real culprit in winds, the elevator doesn't seem like it will move and the ailerons are pretty much damped out by the trim springs - but I always add the bungee. Wrapping a little friction tape around the Bogi-bar where it touches! > the stick is a good idea. This works independent of how the stick is wired or booted. And IF all the above works for you, you can THEN add some welded on tabs to the bottom of the Bogi-bar (half washers work well) to key into the gap at the bottom of the standard rudder pedals to make the whole thing more secure and fool proof. What makes all this work is the improbable accident that the collapsed Bogi-Bar is exactly the right length to fit between the front seat and the rudder pedals - go figure. >> >> The advantage for me is there is only one item to carry along on trips - the Bogi-Bar - which I use for backing my '10 out of the hangar and hand towing around ramps. I assume there is a fair number of Bogi-bar users out there already who do the same thing(?). >> >> I should take a few pics and post but haven't. >> >> Bill "thinking about some proficiency work with 600' ceilings" Watson >> >> >> On 12/5/2014 8:01 PM, Pascal wrote: >> >> >>> I just posted a review of the Gust lock from antisplataero on VAF. http://www.vansairforce.com/community/showthread.php?p=939414#post939414 (http://www.vansairforce.com/community/showthread.php?p=939414#post939414) >>> As Bob Leffler commented, if you have wires routed on the outside of the stick, versus inside (as I did) this gust lock, with retainer, the way it is today will NOT work for you. http://antisplataero.com/RV-10_Ultimate_Gust_Lock.html (http://antisplataero.com/RV-10_Ultimate_Gust_Lock.html) >>> >>> Pascal >> >> [b] > > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435421#435421 > > > > > > > > > > ________________________________________________________________________________
Subject: Glare screen
Date: Dec 06, 2014
Looking down the road at what I might do to cover my glare screen. My windows are not in. Has anyone temporally covered the glare screen with BID fiberglass and then applied a cover to that so it is easily replaceable? Both "successes" and "won't do that again" welcome. Thanks ________________________________________________________________________________
Date: Dec 06, 2014
I have wild blue innovations gust buster and it works great Alan Sent from my iPhone > On Dec 5, 2014, at 8:01 PM, Pascal wrote: > > I just posted a review of the Gust lock from antisplataero on VAF. http:// www.vansairforce.com/community/showthread.php?p=939414#post939414 > As Bob Leffler commented, if you have wires routed on the outside of the s tick, versus inside (as I did) this gust lock, with retainer, the way it is t oday will NOT work for you. http://antisplataero.com/RV-10_Ultimate_Gust_Loc k.html > > Pascal > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: Glare screen
Date: Dec 07, 2014
Terry, I built a fiberglass glare shield that sits above the aluminum upper skin of the instrument panel. It provided a nice way to finish off the sharp edge of the instrument panel with a bull nose, as well as created a way to hide the fans I used for defrosting, and instrument cooling. The glare shield sits 3/4 of an inch above the aluminum skin, creating a plenum that directs the heated air from under the instrument panel up on the windscreen. Here's a link to my build album on this topic. https://plus.google.com/u/0/photos/102955683430141812381/albums/5508605558762046977 Bob Newman RV-10 N541RV TCW Technologies, LLC. www.tcwtech.com -----Original Message----- From: Terry Moushon Sent: Saturday, December 06, 2014 4:53 PM Subject: RV10-List: Glare screen Looking down the road at what I might do to cover my glare screen. My windows are not in. Has anyone temporally covered the glare screen with BID fiberglass and then applied a cover to that so it is easily replaceable? Both "successes" and "won't do that again" welcome. Thanks ________________________________________________________________________________
Date: Dec 07, 2014
Terry, Take a look at the thread on this at VAF. RV10 forum. I may be at PIA either We'd or Thurs. are you in town? -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435471#435471 ________________________________________________________________________________
Date: Dec 07, 2014
Date: Dec 07, 2014
I built one form under $10 that works every bit as well as any I have seen. After two years and several windy overnights, I'm still happy. I posted it at this thread. http://www.vansairforce.com/community/showthread.php?t=94695&highlight=Gust+lock -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435477#435477 ________________________________________________________________________________
Date: Dec 07, 2014
Most interesting. Cant believe I havent thought of doing this with mine! And Ive been carrying around my same towbar for 6 or 7 years! Many thanks for the pictures, Jesse! grumpy > On Dec 7, 2014, at 8:05 PM, Jesse Saint wrote: > > > ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Tailcone Question- Bulkhead Holes
Hi All- Quick Tailcone question. I am on page 10-11. I understand that no drilling should be done on the F-1006 bulkhead until it gets attached to the fuselage. I'm not clear if this includes the forward most hole of the two longerons which have the bulkhead part in common, or the forward most hole of the top stiffeners (F1047 A, B-L, B-R). Does it make a difference either way? I'm tempted to do it now so that the longeron can be countersunk, but wanted to check first. Thank you, -Steve Farnerrv ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Re: Tailcone Question- Bulkhead Holes
I'd recommend you read step 3 very literally and not drill anything associated with that bulkhead for now. When the tail gets attached to the fuselage, you match up all that stuff and do any dimpling/countersinking in that chapter. On 12/8/2014 5:37 PM, Steve Farner wrote: > > Hi All- Quick Tailcone question. I am on page 10-11. I understand > that no drilling should be done on the F-1006 bulkhead until it gets > attached to the fuselage. I'm not clear if this includes the forward > most hole of the two longerons which have the bulkhead part in common, > or the forward most hole of the top stiffeners (F1047 A, B-L, B-R). > Does it make a difference either way? I'm tempted to do it now so > that the longeron can be countersunk, but wanted to check first. > Thank you, -Steve Farnerrv > > ________________________________________________________________________________
Date: Dec 08, 2014
I agree with Kelly. I found out the hard way a couple of times that one should heed instructions that specifically say not to do something at a particular point. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435510#435510 ________________________________________________________________________________
Date: Dec 08, 2014
Thanks Kelly & David- To clarify, I believe I am supposed to drill the 3/32nd hole in the longeron (step #2), but hold off on the others, including the J-channel holes on top. I'm still wondering how this longeron hole gets countersunk at a later date if I've riveted around it. Steve On 12/8/2014 7:52 PM, dmaib(at)me.com wrote: > > I agree with Kelly. I found out the hard way a couple of times that one should heed instructions that specifically say not to do something at a particular point. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435510#435510 > > ________________________________________________________________________________
Subject: Heater control cables
Date: Dec 08, 2014
Is there room to install these cables after the engine is hung? Too hard to judge the required length at this point in my build and I don't think they can be shortened from the cabin side. A semi-related question is whether there is need for an airflow control on the oil cooler. If so, I have seen electric servo installation somewhere along the line. Anyone with experience in this regard? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435513#435513 ________________________________________________________________________________
Date: Dec 08, 2014
Subject: Re: Heater control cables
How much room you have to adjust the cables with the engine in place depends on which magnetos/electronic ignition you have. It is kind of tight with the S1200 mags I have, but most any other option is smaller. If you have one or both mags off the engine, access would be pretty good. On 12/8/2014 7:59 PM, bob88 wrote: > > Is there room to install these cables after the engine is hung? Too hard to judge the required length at this point in my build and I don't think they can be shortened from the cabin side. > > A semi-related question is whether there is need for an airflow control on the oil cooler. If so, I have seen electric servo installation somewhere along the line. Anyone with experience in this regard? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435513#435513 > > ________________________________________________________________________________
Date: Dec 09, 2014
It can be done, but it is a pain. Hard to get installed neatly. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 8, 2014, at 9:59 PM, bob88 wrote: > > > Is there room to install these cables after the engine is hung? Too hard to judge the required length at this point in my build and I don't think they can be shortened from the cabin side. > > A semi-related question is whether there is need for an airflow control on the oil cooler. If so, I have seen electric servo installation somewhere along the line. Anyone with experience in this regard? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435513#435513 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Heater Control Cables
Date: Dec 09, 2014
Bob, Regarding the Heater Control Cables, I just finished installing them this past weekend. Engine was installed with Mags in place. So, it can be done but it will take a bit extra time as you work your way around everything (hoses, wires, etc,) that is already in place. That said Id conclude: If you know where your cables will be located on or around your panel and can install them go ahead as it will be much easier with no engine in place - like 30 minutes including cutting the cables to length as opposed to 2 hours with engine in place. The problem is that unless you are building a sub panel for the cables that will be attached to your instrument panel, AND will be attached from behind (meaning forward or closer to the firewall) or under the instrument panel, you very well may need to remove the control cables until final installation of your instrument panel. That may be after your engine is in, so you are still struggling with the tight quarters for cable installation, but, they would already be cut to size etc. Study how the cable is attached at the knob end and you will see what I mean. If I were doing it again, Id still wait and do it one time, final, after panel and engine is all in. The extra time you save trying to do it in advance can be easily sucked up as you sit there stewing over where, what length, am I sure, what if, Im not sure, I might not be able to, this could change, etc Regarding your next question of oil cooler air control: I have heard enough comments from flying RV-10 drivers that the temperature seems to hang around the high 150s to low 160s in winter flight, that I added a cockpit controlled airflow door on mine. My RV-6 had the same issue and I just fabricated a flow restrictor for winter flight that I manually installed each winter. It worked just fine bringing the temp back up to a nicely desired 180 degrees. The question every year and as the seasons changed remained: what about that 3 hour flight where you took off ambient 50 - 60 degrees then found yourself flying along at altitude looking down at 0 degrees F, only to look over at the Oil Temp and see 158 - 160 degrees = cringe:( Wish I had put in the restrictor! On the 10, I want to be able to adjust that in flight! Avery Tools has the air control door and TCW has the electronic controller if you want to go that way too. Hope that helps, Rich Hansen - still finalizing, but end in sight > > > From: Kelly McMullen <kellym(at)aviating.com> > Subject: Re: RV10-List: Heater control cables > > > How much room you have to adjust the cables with the engine in place > depends on which magnetos/electronic ignition you have. It is kind of > tight with the S1200 mags I have, but most any other option is smaller. > If you have one or both mags off the engine, access would be pretty good. > > On 12/8/2014 7:59 PM, bob88 wrote: >> >> Is there room to install these cables after the engine is hung? Too hard to judge > the required length at this point in my build and I don't think they can > be shortened from the cabin side. >> >> A semi-related question is whether there is need for an airflow control on the > oil cooler. If so, I have seen electric servo installation somewhere along the > line. Anyone with experience in this regard? >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435513#435513 >> >> > > > > ________________________________________________________________________________
Date: Dec 09, 2014
Knowing that it was possible but more of a pain once the engine is hung, I came up with a mounting that was independent of the panel and pretty much independent of cable length. It has worked well. Heater cable mount on tunnel cover <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=2223&log=62927&row=3> It detaches easily with one screw and can easily be kept out of the way for all the panel and cockpit work as well as for maintenance once flying. On 12/8/2014 9:59 PM, bob88 wrote: > > Is there room to install these cables after the engine is hung? Too hard to judge the required length at this point in my build and I don't think they can be shortened from the cabin side. > > A semi-related question is whether there is need for an airflow control on the oil cooler. If so, I have seen electric servo installation somewhere along the line. Anyone with experience in this regard? > > ________________________________________________________________________________
Date: Dec 10, 2014
Rich has it right. I installed the TCW oil cooler valve and it works perfectly. The temps Rich mentioned are exactly right and its nice to be able to adjust as needed in flight. I did it...and I would do it again. Only improvement I could see is if it was handled automatically like your home thermostat. Set the temp...and let the valve regulate to achieve the desired temp :) David -------- David Halmos RV-10 Flying! Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435555#435555 ________________________________________________________________________________
Date: Dec 10, 2014
I photo documented my use of the Bogi-bar as a gust control lock here <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=0&log 0875&row=1> FYI. It works for me. Bill Watson On 12/6/2014 9:49 AM, Bill Watson wrote: > (I'm going to repost without the bulleted list - it displayed back > badly to me:) > > Looks like a good unit with a few 'ifs'. > > Another solution that I'm sure I picked up here and have been using > for almost 3 years now is a modified Bogi-bar > <http://www.aircraftspruce.com/catalog/pspages/bogibars2.php> It has a > few 'ifs' as well but if the logic tree works for you, it may be a > solution. > > - IF the Bogi-bar works as a tow bar for you (I have the stainless > heads of cap screws extending from the sides of my nosewheel pant - > the Bogi-bar fits around those for towing and works very well) > > - and IF you have Oregon Aero cushions - are there any others out > there? Don't know, probably will work the same anyway > > - and IF you have the standard rudder pedals - I am unaware of what > else is out there. > > - THEN you can move either seat to the rear most position and jam the > collapsed Bogi-bar between the front of the seat cushion and the > rudder pedals. The round tow pin receivers on the bar will hold in > the gap at the bottom of the standard pedals and the handle jams into > the front of the cushions with an over-center kind of fit that will > stay in place in heavy winds. > > - and THEN you can take a short bungee cord and tie it around the > stick and Bogi-bar in any one of several ways to lock the ailerons and > elevator. If you leave this off, it still works well in most > situations since the rudder is the real culprit in winds, the elevator > doesn't seem like it will move and the ailerons are pretty much damped > out by the trim springs - but I always add the bungee. Wrapping a > little friction tape around the Bogi-bar where it touches the stick is > a good idea. This works independent of how the stick is wired or booted. > > - And IF all the above works for you, you can THEN add some welded on > tabs to the bottom of the Bogi-bar (half washers work well) to key > into the gap at the bottom of the standard rudder pedals to make the > whole thing more secure and fool proof. > > What makes all this work is the improbable accident that the collapsed > Bogi-Bar is exactly the right length to fit between the front seat and > the rudder pedals - go figure. > > The advantage for me is there is only one item to carry along on trips > - the Bogi-Bar - which I use for backing my '10 out of the hangar and > hand towing around ramps. I assume there is a fair number of Bogi-bar > users out there already who do the same thing(?). > > I should take a few pics and post but haven't. > > Bill "thinking about some proficiency work with 600' ceilings" Watson > > > On 12/5/2014 8:01 PM, Pascal wrote: >> I just posted a review of the Gust lock from antisplataero on VAF. >> http://www.vansairforce.com/community/showthread.php?p=939414#post939414 >> As Bob Leffler commented, if you have wires routed on the outside of >> the stick, versus inside (as I did) this gust lock, with retainer, >> the way it is today will NOT work for you. >> http://antisplataero.com/RV-10_Ultimate_Gust_Lock.html >> Pascal >> ________________________________________________________________________________
Subject: Custom Shirts
Date: Dec 10, 2014
Copied from my post on VAF: We have been doing this for a little while as we learn how to use our new machine, but I wanted to offer this service to users of VAF somewhat commercially, to give my daughters a way to earn some $. They are homeschooled and love to see, so they are excited about making shirts (and jackets/sweaters) for people. This post has been edited, but the following are what we are offering. 2. Let people send me a shirt (or shirts) of their choosing along with a digital picture of their airplane, which I would get digitized and embroider and mail the shirts back. The digitizing costs $8-11/picture, plus something for the legwork, plus the embroidery. This would be the easiest for you. There would, obviously, be some economy of scale, so doing more shirts would cost less per shirt to embroider, and the digitizing would be paid only once. The pricing for this option would be the digitizing fee ($8-11), $10 for doing it then the same fee as digitizing for each embroidery. Adding the N-number in large letters (N104LG below) would add $3/shirt and medium letter (N674BD below) would add $2/shirt. Shipping would be actual cost plus a small fee for handling, shipped back in the packaging that you shipped it to us in. For 2-5 shirts, there would be a $2 discount per shirt. For more than 5, there would be a $3 discount per shirt. You could order shirts from an online store and have them shipped to me, or you could buy them locally and ship them. Please make sure if you order online that your name is in the address label somewhere. 3. Let people send me a shirt as well as get their own plane picture digitized (following a very easy format), pay the digitizing fee themselves and just pay me a per-shirt fee for the embroidery. The best option for me and the cheapest for you. The cost for this is the same as Option 2 above, but you save the $10 fee I charge for doing the digitizing. It's a matter of sending an email with the picture and a couple of data points that I can email you. You can email me picture if you want me to digitize them (option 2). A good picture is one with good light, preferably few shadows, that included the whole plane. Usually a side shot or a front corner shot works best. If in flight, the side or front corner and from a little above works best. If a tailwheel and on the ground, we can do it level or in the ground position, but it would be best if the picture matches how you want it to show. You can also tell us you want it in the flying position and we can rotate it appropriately. Send the shirts to Saint Aviation, 10575 SW 147th Circle, Dunnellon, FL 34432. I will send a bill for the total after we have the shirts done and ready to go. If you don't pay, I get to wear your shirts, so please make sure they at XL if you don't plan to pay. :-) Below are some samples that we have done, including a picture that one of them was digitized from. [IMG]http://i1286.photobucket.com/albums/a603/jessesaint/ECE424EE-89F3-4009-BF8F-DF414D62E40B_zpsujof0jwp.jpg[/IMG] [IMG]http://i1286.photobucket.com/albums/a603/jessesaint/12315838-BF9E-4000-9993-C1FCD325B619_zpsr9o6quue.jpg[/IMG] [IMG]http://i1286.photobucket.com/albums/a603/jessesaint/bdea94bb66612e97e6ad5a52bc13d91b_zps33b897ff.jpg[/IMG] [IMG]http://i1286.photobucket.com/albums/a603/jessesaint/1805325a88039e43ca9eae8263c3896e_zpsf7395315.jpg[/IMG] Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad ________________________________________________________________________________
Subject: Manifold pressure with G3X
Date: Dec 10, 2014
Getting ready to hang the engine and trying to do as much as possible on the back end first. My question relates to the Vans recommendation that the manifold pressure line be connected to the port on cylinder #5. I have a used, overhauled engine with the MP port on #6. The plug on #5 doesn't want to come out, at least without extraordinary measures. So...is there a problem using #6 for the MP line with the Garmin engine sensor system? If so, any suggestions about getting the plug out of #5? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435587#435587 ________________________________________________________________________________
Date: Dec 11, 2014
Subject: Re: Manifold pressure with G3X
I have a G3X and my MP is pulled off of my #6 just fine On Thu, Dec 11, 2014 at 12:08 AM, bob88 wrote: > > Getting ready to hang the engine and trying to do as much as possible on > the back end first. My question relates to the Vans recommendation that the > manifold pressure line be connected to the port on cylinder #5. I have a > used, overhauled engine with the MP port on #6. The plug on #5 doesn't want > to come out, at least without extraordinary measures. So...is there a > problem using #6 for the MP line with the Garmin engine sensor system? If > so, any suggestions about getting the plug out of #5? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435587#435587 > > ________________________________________________________________________________
Date: Dec 11, 2014
You can use the portion any cylinder. The port on #5 is just closer to the firewall. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 11, 2014, at 12:08 AM, bob88 wrote: > > > Getting ready to hang the engine and trying to do as much as possible on the back end first. My question relates to the Vans recommendation that the manifold pressure line be connected to the port on cylinder #5. I have a used, overhauled engine with the MP port on #6. The plug on #5 doesn't want to come out, at least without extraordinary measures. So...is there a problem using #6 for the MP line with the Garmin engine sensor system? If so, any suggestions about getting the plug out of #5? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435587#435587 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 11, 2014
As Jesse says, it doesn't matter between cylinders. You could just as easily use #3. The only difference is in the length of tubing to plumb to where ever you mount the sensor. The FF plans just show mounting MP sensor on the right side of the firewall, but there is nothing set in stone about where you put it. I've seen #1 used for MP on a 4 cyl Lyc for a type certificated aircraft. On Thu, Dec 11, 2014 at 5:03 AM, Jesse Saint wrote: > > You can use the portion any cylinder. The port on #5 is just closer to the > firewall. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > > On Dec 11, 2014, at 12:08 AM, bob88 wrote: > > > > > > Getting ready to hang the engine and trying to do as much as possible on > the back end first. My question relates to the Vans recommendation that the > manifold pressure line be connected to the port on cylinder #5. I have a > used, overhauled engine with the MP port on #6. The plug on #5 doesn't want > to come out, at least without extraordinary measures. So...is there a > problem using #6 for the MP line with the Garmin engine sensor system? If > so, any suggestions about getting the plug out of #5? > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=435587#435587 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Antisplataero gust lock review
Date: Dec 11, 2014
There are cheaper but still effective gusts locks available. Albert Gardner N991RV Yuma, AZ ________________________________________________________________________________
Date: Dec 12, 2014
I used the gustbuster for the first time yesterday. In SLC they parked me tail to the wind and when I came back out to the airport, the winds were howling, but the controls were nice and secure and I even noticed the designed "give" in gusts which seems like a good idea to me. The winds were so lively down by Mt Nebo, that for a brief moment I thought about hooking the stick bungees back up as an autopilot supplement! Just kidding (not really) -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435648#435648 ________________________________________________________________________________
Subject: Manifold Pressure with G3X
Date: Dec 12, 2014
Regarding plug removal, what tool are you using? If memory serves me correctly it usually is just a 3/16 hex on those ports. Are you using a 3/8 drive socket with 3/16 hex in socket? And penetrating lube of choice? Need to know what you've done/tried for suggestions - as well as mayb a pic of issue. Otherwise as others said don't ruin a cyl, just go for another port..... Rich Sent from my iPhone > On Dec 12, 2014, at 12:02 AM, RV10-List Digest Server wrote: > ====If >> so, any suggestions about getting the plug out of #5? >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435587#435587 > > > ________________________________________________________________________________
Date: Dec 13, 2014
Good choice for penetrating lube; 50% ATF (automatic trans fluid) and 50% acetone. I hope that helps, Tal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435677#435677 ________________________________________________________________________________
Date: Dec 13, 2014
From: David Clifford <davidsoutpost(at)comcast.net>
----- Original Message ----- From: "whodja" <whodja(at)gmail.com> Sent: Saturday, December 13, 2014 7:38:19 AM Subject: RV10-List: Re: Manifold pressure with G3X Good choice for penetrating lube; 50% ATF (automatic trans fluid) and 50% acetone. I hope that helps, Tal Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435677#435677 ________________________________________________________________________________
Subject: Re: Plasma III - Cooling Port
Date: Dec 14, 2014
Ports on the LSEIII are 3/8". I'm using the cyclone fan below and a piece of 3/8" ID silicone hose as a bushing to bring the port size up to a size that is closer to the cyclone. The larger hose diameter also adds some strength to the port on the LSE.\ Michael -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of hotwheels Sent: Friday, December 05, 2014 8:32 PM Subject: RV10-List: Re: Plasma III - Cooling Port I installed a Cyclone 21 avionics fan (PN CRB-6457) which I believe Stein carries (below). The other ports provide forced cooling to my radio stack. Simple design and well worth the $. http://www.steinair.com/SearchResults.cfm?key=fan Sorry I don't recall the tube diameter used on the LSE cooling ports. But... do recall sourcing the tubing from the A/C section of the local Lowes. Cheers, Jay 433RV flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435394#435394 ________________________________________________________________________________
Date: Dec 14, 2014
Subject: Re: Latest Parking brake victim
After action report. I was fortunate. I did get to remove and reinstall the parking brake twice to confirm that the only leakage from the parking brake was from the fittings, not the valve body. So I did not have to contact Matco or do anything special with the valve. By the time I am done, I will have redone every pipe fitting fitting in my brake system with aviation pipe thread sealant, and ensured all flare fittings have proper torque. 3 flare fittings required the DEL seals sold by Spruce. (well, looked like it was needed and I wasn't going to screw around with them with multiple tests, so went with belt and suspenders attack that worked). Very few fittings had significant leaks, but because they are on interior and I don't want a future mess, I corrected any fitting with even a hint of a seep. I already had control sticks out for other work, so I could get my creaky old bones under the panel okay. On Thu, Dec 4, 2014 at 9:08 PM, Kelly McMullen wrote: > > Less than 24 hours after bleeding my brakes I was seeing a drip or two > from the infamous Matco parking brake, even though I have only applied foot > pressure to the brake pedals for less than 10 seconds total. > Any body got a mechanically competent, slightly malnourished 10 yr old for > rent? ;-) > > ________________________________________________________________________________
Date: Dec 14, 2014
I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days. --Dave On Sun, Dec 14, 2014 at 6:52 PM, Kelly McMullen wrote: > > After action report. I was fortunate. I did get to remove and reinstall > the parking brake twice to confirm that the only leakage from the parking > brake was from the fittings, not the valve body. So I did not have to > contact Matco or do anything special with the valve. > By the time I am done, I will have redone every pipe fitting fitting in my > brake system with aviation pipe thread sealant, and ensured all flare > fittings have proper torque. 3 flare fittings required the DEL seals sold > by Spruce. (well, looked like it was needed and I wasn't going to screw > around with them with multiple tests, so went with belt and suspenders > attack that worked). > Very few fittings had significant leaks, but because they are on interior > and I don't want a future mess, I corrected any fitting with even a hint of > a seep. I already had control sticks out for other work, so I could get my > creaky old bones under the panel okay. > > On Thu, Dec 4, 2014 at 9:08 PM, Kelly McMullen wrote: >> >> Less than 24 hours after bleeding my brakes I was seeing a drip or two >> from the infamous Matco parking brake, even though I have only applied foot >> pressure to the brake pedals for less than 10 seconds total. >> Any body got a mechanically competent, slightly malnourished 10 yr old >> for rent? ;-) >> >> * > > > * > > ________________________________________________________________________________
Date: Dec 15, 2014
[quote="saylor.dave(at)gmail.com"]I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days. --Dave /quote] Dave, Permatex Aviation Form-A-Gasket Number One, or Number Three? Spruce sells both. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435735#435735 ________________________________________________________________________________
Date: Dec 15, 2014
I use No. 3. On Mon, Dec 15, 2014 at 5:23 AM, johngoodman wrote: > > > [quote="saylor.dave(at)gmail.com"]I've pretty much given up on teflon > paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on > threads these days. > > --Dave > /quote] > > Dave, Permatex Aviation Form-A-Gasket Number One, or Number Three? Spruce > sells both. > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435735#435735 > > ________________________________________________________________________________
Date: Dec 15, 2014
On 12/15/2014 8:23 AM, johngoodman wrote: > > [quote="saylor.dave(at)gmail.com"]I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days. > > --Dave > /quote] > > Dave, Permatex Aviation Form-A-Gasket Number One, or Number Three? Spruce sells both. > John > I really hate to see this thread rear it's ugly head over and over. Proper use of AN fittings should (read that word again) not require thread sealants. If you have a leak then there's something wrong and covering up the problem with thread sealant (to me) isn't the best course of action. Nowhere in AC43.12-1B does the term 'thread sealant' appear. Yeah, I know ..... "it's experimental and I can do what I want." Almost all of the 'thread sealant' problems I've helped 'fix' are in the brake system ..... almost all due to sealant debris in the brake master cylinder. It appears that some folks think "If a little thread sealant helps, then lots if thread sealant must be better." In Kelly's email he mentions the DEL seals for flare fittings. They're available and acceptable to 'fix' leaking flare fittings, although they aren't in AC43.13-1B either. Properly made and maintained, flare fittings should not leak. But they do because they were 'over flared' (my term) or over time the nut had been tightened by a gorilla with a wrench trying to stop a leak. I've seen thin flares on certified and experimentals, and even seen JB weld in there as a 'fix'. Don't misunderstand me. I used to 'fix' stuff using whatever method was available, but having seen what happens over time I try and correct the problem instead of covering it up. And yes, I may still go off the deep end trying to be creative 'fixing' when I couldn't actually fix the problem correctly. Linn ________________________________________________________________________________
Date: Dec 15, 2014
Many of the flare fittings in the brake system have pipe threads on the other end(at parking brake, at master cylinders.) It is the pipe threads that benefit from the sealant, NOT the flare fittings, which as you say should be nothing but clean and dry. Tubing flares are kind of like bucked rivets. The first few efforts are really ugly and over time they improve to acceptable to very nice. With the tubing that is fabricated for the -10 you would need twice as much to get skilled and making perfect flares. Fortunately Vans has you do the brake lines before the fuel lines. Sure, I could remake some of the lines. Unfortunately, Vans chose to supply the lowest grade tubing, and obviously some builders chose to substitute higher quality tubing. However a buck or so for the DEL seal accomplishes the same thing as remaking a tube, in a lot less time and money. Some of my seeps were hardly noticeable without use of a clean paper towel to catch the hint of red. I don't want to have to deal with such seepage later, so I made a major effort to ensure each fitting was perfectly dry after applying pressure to the system for over an hour with the parking brake holding enough pressure to keep the calipers locked. In actual use, such minor seepage would not have been detected for a long time...just my choice of how to test and perfect the system. On 12/15/2014 7:23 AM, Linn Walters wrote: > > On 12/15/2014 8:23 AM, johngoodman wrote: >> >> >> [quote="saylor.dave(at)gmail.com"]I've pretty much given up on teflon >> paste-type thread sealants. I prefer Permatex Aviation >> Form-A-Gasket on threads these days. >> >> --Dave >> /quote] >> >> Dave, Permatex Aviation Form-A-Gasket Number One, or Number Three? >> Spruce sells both. >> John >> > I really hate to see this thread rear it's ugly head over and over. > Proper use of AN fittings should (read that word again) not require > thread sealants. If you have a leak then there's something wrong and > covering up the problem with thread sealant (to me) isn't the best > course of action. > Nowhere in AC43.12-1B does the term 'thread sealant' appear. Yeah, I > know ..... "it's experimental and I can do what I want." > > Almost all of the 'thread sealant' problems I've helped 'fix' are in > the brake system ..... almost all due to sealant debris in the brake > master cylinder. It appears that some folks think "If a little thread > sealant helps, then lots if thread sealant must be better." > > In Kelly's email he mentions the DEL seals for flare fittings. They're > available and acceptable to 'fix' leaking flare fittings, although > they aren't in AC43.13-1B either. Properly made and maintained, flare > fittings should not leak. But they do because they were 'over flared' > (my term) or over time the nut had been tightened by a gorilla with a > wrench trying to stop a leak. I've seen thin flares on certified and > experimentals, and even seen JB weld in there as a 'fix'. > > Don't misunderstand me. I used to 'fix' stuff using whatever method > was available, but having seen what happens over time I try and > correct the problem instead of covering it up. And yes, I may still go > off the deep end trying to be creative 'fixing' when I couldn't > actually fix the problem correctly. > Linn > > ________________________________________________________________________________
Date: Dec 15, 2014
> Properly made and maintained, flare fittings should not leak. But they do because they were 'over flared' (my term) or over time the nut had been tightened by a gorilla with a wrench trying to stop a leak. The key words there are "properly made." I wonder where those fittings are actually made? My experience (very limited to one RV-10) has shown me that about 5 to 10 percent of fittings always leak. Replace them with another and the problem is solved. The hardest one to find was a female pipe thread that turned out to be out of round. I got an exact replacement from the same store, and found the same problem. Changed brands, and the problem was solved. Never buy a car made on a Monday... [Laughing] John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435739#435739 ________________________________________________________________________________
Date: Dec 15, 2014
Both kelly (pipe thread) and John (chinese? fittings) make good points. It isn't easy to dodge all the bullets. I've been hit more than once. It's all a learning experience. One thing I have done is to draw a vacuum (think "mighty vac") from the reservoir before filling with fluid. I expect to find really slow leaks .... mostly from dry seals .... but nothing major. You'll find loose flare nuts that way. Putting 10 - 20 pounds pressure into the reservoir after filling with fluid should show where the leaks are within an hour or so. Left overnight though you may find puddles. BTDT. Another thing I've learned about flaring aluminum tubing (the hard way) is to go slow, backing off like you do with a tap, and using plenty of lubricant. I think going slow allows the aluminum to flow rather than crack. I use 5606 brake fluid for lubricant. My 2 pennies, IMHO, and all the other disclaimers!!!! Linn On 12/15/2014 10:01 AM, johngoodman wrote: > > >> Properly made and maintained, flare fittings should not leak. But they do because they were 'over flared' (my term) or over time the nut had been tightened by a gorilla with a wrench trying to stop a leak. > > The key words there are "properly made." I wonder where those fittings are actually made? My experience (very limited to one RV-10) has shown me that about 5 to 10 percent of fittings always leak. Replace them with another and the problem is solved. The hardest one to find was a female pipe thread that turned out to be out of round. I got an exact replacement from the same store, and found the same problem. Changed brands, and the problem was solved. > Never buy a car made on a Monday... [Laughing] > John > > -------- > #40572 Phase One complete in 2011 > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435739#435739 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 15, 2014
Subject: Oil Filter Question
I'm getting ready to put a pre-oiler on my airframe and was placing the order. One of their questions involved the type/model of the oil filter... That got me to thinking.. What filter are most folks going with? My engine builder (Aerosport) shipped my D4A5 with a Champion CH48109-1. I'm just curious to know how much different my filter is from others because I searched the archives for CH48109-1 and the results came back empty. I'm not sure if I should be concerned or oblivious to the fact that I'm the only one who could be running it. Phil ________________________________________________________________________________
Date: Dec 15, 2014
Subject: Re: Oil Filter Question
It will probably depend on what filter adapter you use. Mine I think uses 48110. I know some others use 48108 too. So it'll all depend. BTW: I only use tempest filters now. You may want to make sure that they sell the one you need. Tim On 12/15/2014 10:20 AM, Phillip Perry wrote: > I'm getting ready to put a pre-oiler on my airframe and was placing the > order. One of their questions involved the type/model of the oil > filter... That got me to thinking.. > > What filter are most folks going with? My engine builder (Aerosport) > shipped my D4A5 with a Champion CH48109-1. > > I'm just curious to know how much different my filter is from others > because I searched the archives for CH48109-1 and the results came back > empty. I'm not sure if I should be concerned or oblivious to the fact > that I'm the only one who could be running it. > > Phil > > *\ > ________________________________________________________________________________
Date: Dec 15, 2014
Sure, never use any sealants on a b-nut. Just pipe threads. I figured that's what Kelly was describing. --D On Monday, December 15, 2014, Linn Walters wrote: > > Both kelly (pipe thread) and John (chinese? fittings) make good points. > It isn't easy to dodge all the bullets. I've been hit more than once. It's > all a learning experience. > > One thing I have done is to draw a vacuum (think "mighty vac") from the > reservoir before filling with fluid. I expect to find really slow leaks > .... mostly from dry seals .... but nothing major. You'll find loose flare > nuts that way. Putting 10 - 20 pounds pressure into the reservoir after > filling with fluid should show where the leaks are within an hour or so. > Left overnight though you may find puddles. BTDT. > > Another thing I've learned about flaring aluminum tubing (the hard way) is > to go slow, backing off like you do with a tap, and using plenty of > lubricant. I think going slow allows the aluminum to flow rather than > crack. I use 5606 brake fluid for lubricant. > My 2 pennies, IMHO, and all the other disclaimers!!!! > Linn > > On 12/15/2014 10:01 AM, johngoodman wrote: > >> > >> >> >> Properly made and maintained, flare fittings should not leak. But they >>> do because they were 'over flared' (my term) or over time the nut had been >>> tightened by a gorilla with a wrench trying to stop a leak. >>> >> >> The key words there are "properly made." I wonder where those fittings >> are actually made? My experience (very limited to one RV-10) has shown me >> that about 5 to 10 percent of fittings always leak. Replace them with >> another and the problem is solved. The hardest one to find was a female >> pipe thread that turned out to be out of round. I got an exact replacement >> from the same store, and found the same problem. Changed brands, and the >> problem was solved. >> Never buy a car made on a Monday... [Laughing] >> John >> >> -------- >> #40572 Phase One complete in 2011 >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435739#435739 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> > > ________________________________________________________________________________
Date: Dec 16, 2014
On 12/15/2014 10:45 AM, Linn Walters wrote: > Another thing I've learned about flaring aluminum tubing (the hard > way) is to go slow, backing off like you do with a tap, and using > plenty of lubricant. I think going slow allows the aluminum to flow > rather than crack. I use 5606 brake fluid for lubricant. > My 2 pennies, IMHO, and all the other disclaimers!!!! > Linn I am someone who didn't have a clue as to how to make proper flares. I got the proper tool and tried to read everything I could find - would love to find a definitive Youtube/EAA clip showing how this is done. Exactly what you described above - backing off 4-6 times for each flare with plenty of lube - seems to do the trick perfectly for me. Do that, and don't overflare, and they have been reliable and leak free for me. Tapered pipe fittings where another story..... ________________________________________________________________________________
Date: Dec 16, 2014
On 12/14/2014 10:20 PM, David Saylor wrote: > I've pretty much given up on teflon paste-type thread sealants. I > prefer Permatex Aviation Form-A-Gasket on threads these days. > > --Dave I've used no sealant as well as several teflon past-type sealeants as well and had both brake line and oil line leaks. I've had leaks. The Form-a-Gasket sounds like a solution - wish I found out sooner. While chasing the equivalent Loctite product, I finally found and used this -Permatex High Performance Thread Sealant #56521 <http://www.all-spec.com/products/56521.html?gclid=Cj0KEQiAzb-kBRDe49qh9s75m-wBEiQATOxgwbjm5OL7j5P-fO3P5Xl_vLOYfoGKsQN5ROwKbGZbi2MaAor28P8HAQ>. This too is a solution. They have a half dozen similar products but this works reliably and easily on high pressure tapered fittings. Little is required, it doesn't harden, it seems to cure instantly and simply doesn't leak. It works so well in comparison to the other products, I'm not sure how it does it but does. On a non-aviation note: I recently had the need to fix several water line breaks (black poly pipe). The landscape guys fixed it with gray PVC push in fittings and a white PVC cap on a tapered fitting. They all leaked very slowly. They thought it was the push in barb fitting and kept putting extra and new hose clamps on it but I could see it was the white threaded cap on the gray threaded fitting. The cap would inevitably break before one could tighten it enough to stop the leak. One light application of #56521 and no leaks - didn't even have to cinch it down very far. And the fittings were easily removeable with no dried up sealant pieces to get clean up and keep out of sensitive systems. I've done about 6 of these now - same results. I found the same with a slow leaking oil cooler fitting on the '10. ________________________________________________________________________________
Date: Dec 16, 2014
Brian carpenter covered a video on flared tubing under the eas videos Flared Tubing-Fabrication & Assembly - EAA Video Player - Your ... www.eaavideo.org/video.aspx?v=3727487001 Dec 2, 2008 - In this Hint, Brian Carpenter demonstrates how to fabricate an d assemble flared tubing for use in many aircraft installaitons. Brian is an A&P ... Sent from my iPad > On Dec 16, 2014, at 9:09 AM, Bill Watson wrote: > > >> On 12/15/2014 10:45 AM, Linn Walters wrote: >> Another thing I've learned about flaring aluminum tubing (the hard way) i s to go slow, backing off like you do with a tap, and using plenty of lubric ant. I think going slow allows the aluminum to flow rather than crack. I u se 5606 brake fluid for lubricant. >> My 2 pennies, IMHO, and all the other disclaimers!!!! >> Linn > I am someone who didn't have a clue as to how to make proper flares. I go t the proper tool and tried to read everything I could find - would love to f ind a definitive Youtube/EAA clip showing how this is done. > > Exactly what you described above - backing off 4-6 times for each flare wi th plenty of lube - seems to do the trick perfectly for me. Do that, and don 't overflare, and they have been reliable and leak free for me. > > Tapered pipe fittings where another story..... > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Dec 16, 2014
Good one! That covers everything it would seem except that I can't/won't do it in one tightening. Multiple ins and outs seems to insure no cracking or whatever. Maybe just 2-3 times. If I was paid by the hour I might work harder to get that one shot and done technique to work. Might involve the consistent use of the 45deg reamer before starting. On 12/16/2014 12:28 PM, P Reid wrote: > Brian carpenter covered a video on flared tubing under the eas videos > > > Flared Tubing-Fabrication & Assembly - EAA Video Player - Your > ... <http://www.eaavideo.org/video.aspx?v=3727487001> > > www.*eaavideo*.org/*video*.aspx?v=3727487001 > Dec 2, 2008 - In this Hint, Brian Carpenter demonstrates how to > fabricate and assemble flared tubing for use in many aircraft > installaitons. Brian is an A&P ... > > Sent from my iPad > > On Dec 16, 2014, at 9:09 AM, Bill Watson > wrote: > >> > >> >> On 12/15/2014 10:45 AM, Linn Walters wrote: >>> Another thing I've learned about flaring aluminum tubing (the hard >>> way) is to go slow, backing off like you do with a tap, and using >>> plenty of lubricant. I think going slow allows the aluminum to flow >>> rather than crack. I use 5606 brake fluid for lubricant. >>> My 2 pennies, IMHO, and all the other disclaimers!!!! >>> Linn >> I am someone who didn't have a clue as to how to make proper flares. >> I got the proper tool and tried to read everything I could find - >> would love to find a definitive Youtube/EAA clip showing how this is >> done. >> >> Exactly what you described above - backing off 4-6 times for each >> flare with plenty of lube - seems to do the trick perfectly for me. >> Do that, and don't overflare, and they have been reliable and leak >> free for me. >> >> Tapered pipe fittings where another story..... >> ________________________________________________________________________________
Date: Dec 16, 2014
"Another thing I've learned about flaring aluminum tubing (the hard way) is to go slow, backing off like you do with a tap, and using plenty of lubricant. I think going slow allows the aluminum to flow rather than crack." If you look very carefully at the way the flaring tool works, you'll see that the flare is not at all round (due to the 3 lobes on the tool) as you go in. It is only when you back off (and the threads do not turn for 340 degrees) that you make the flare round. It is important to turn the tool a full turn counter clockwise before releasing the tubing from the clamping mechanism. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435783#435783 ________________________________________________________________________________
Date: Dec 18, 2014
Subject: Spread in AOPA Pilot
Tim, congrats on the spread in January AOPA Pilot mag. Nice job. -Sean #40303 (main pants and fairings done, nice speed boost) ________________________________________________________________________________
Date: Dec 18, 2014
Subject: Re: Spread in AOPA Pilot
Tim, would there be a copy available on your website, for us overseas pilots to read? Cheers Werner On 18.12.2014 15:37, Tim Olson wrote: > > Thanks guys. It was actually a full article and everything but they > basically chopped out all the text and did photos and captions only. ________________________________________________________________________________
Date: Dec 18, 2014
Here you go: http://www.myrv10.com/AOPA_50_States.pdf That's just those 2 pages. Tim On 12/18/2014 8:50 AM, Werner Schneider wrote: > > Tim, > > would there be a copy available on your website, for us overseas pilots > to read? > > Cheers > > Werner ________________________________________________________________________________
Date: Dec 18, 2014
Anyway you could post the original article that was supposed to go with this? I am sure it would be an interesting read. Bill -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, December 18, 2014 10:02 AM Subject: Re: RV10-List: Spread in AOPA Pilot Here you go: http://www.myrv10.com/AOPA_50_States.pdf That's just those 2 pages. Tim On 12/18/2014 8:50 AM, Werner Schneider wrote: > > Tim, > > would there be a copy available on your website, for us overseas > pilots to read? > > Cheers > > Werner ________________________________________________________________________________
Date: Dec 18, 2014
Agreed! I wanna see what you wrote up. On Thu, Dec 18, 2014 at 10:24 AM, William Greenley wrote: > > > Anyway you could post the original article that was supposed to go with > this? I am sure it would be an interesting read. > Bill > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Thursday, December 18, 2014 10:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Spread in AOPA Pilot > > > Here you go: > http://www.myrv10.com/AOPA_50_States.pdf > > > That's just those 2 pages. > Tim > > > On 12/18/2014 8:50 AM, Werner Schneider wrote: > > > > Tim, > > > > would there be a copy available on your website, for us overseas > > pilots to read? > > > > Cheers > > > > Werner > > ________________________________________________________________________________
Date: Dec 18, 2014
Possibly, but not right now. If I can find another magazine that is interested in it, I'll submit it there. After the 1st I'll see if anyone is interested. If not, then of course, I'll post it. Tim On 12/18/2014 10:32 AM, Ed Kranz wrote: > Agreed! I wanna see what you wrote up. > > On Thu, Dec 18, 2014 at 10:24 AM, William Greenley > wrote: > > > > > Anyway you could post the original article that was supposed to go with > this? I am sure it would be an interesting read. > Bill > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com > ] On Behalf Of Tim Olson > Sent: Thursday, December 18, 2014 10:02 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Spread in AOPA Pilot > > > > > Here you go: > http://www.myrv10.com/AOPA_50_States.pdf > > > That's just those 2 pages. > Tim > > > On 12/18/2014 8:50 AM, Werner Schneider wrote: > > > > > > Tim, > > > > would there be a copy available on your website, for us overseas > > pilots to read? > > > > Cheers > > > > Werner > > > ========== > br> fts!) > r> > com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > > > * ________________________________________________________________________________
Date: Dec 18, 2014
I cannot decide if the glass is half full or half empty on this one. For the half empty... No disrespect towards you at all Tim but at first all I could think was... wow what a pile of crap on AOPA's part. The least they could do is spare a few paragraphs of your awesome narratives I've enjoyed reading over the years. It's sad to say but I guess we're supposed to all be flattered that a "homebuilt" got two pages of pictures in AOPA right? For the half full... Wow a non-corporate sponsored, homebuilt article was able to get a 2 page spread of pictures and 8 sentences in AOPA... that's progress. I guess the homebuilt market is really making a dent. I guess it depends on which side of the bed I wake up on. -Ben -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Thursday, December 18, 2014 7:02 AM Subject: Re: RV10-List: Spread in AOPA Pilot Here you go: http://www.myrv10.com/AOPA_50_States.pdf That's just those 2 pages. Tim ________________________________________________________________________________
Date: Dec 18, 2014
You're right that it has it's ups and downs. The guy who got it in there is an RV pilot, so that's a plus, and he was real nice. But yeah, usually if you take the time to write something complete, you'd think you'd get at least 50% of it in. In this case I really didn't have much to do with the thing except provide some info. And even that info like fastest speed and slowest speed...I mean that's a best guess. There's just so much more that could be done to flatter the RV fleet, and I felt it missed out on all of that. I do like writing, so I'll probably try again. I'm sure over the years there will be more things I'll try to get in. I agree with Jae though. To me, I used to read EVERY magazine I got, within the month I got it, cover to cover. It was plane&pilot, flying, flight training, aopa pilot, sport aviation, eaa experimenter, IFR, and now I just signed up for sport aerobatics. The problem is, lately I get many months behind on my reading. Too much going on for one, but Jae's right. I don't want to hear all about the new Diesel in every issue, and I certainly don't want to read the same stuff in ALL of those magazines every single month. The email newsletters are nice too, but you see the same promo stuff in 12 different forms every week, so it's more of a turn-off to keep getting bombarded by it. I'm also not too thrilled with some publications incessant pushback against things like 406mhz ELT's and ADS-B. Just a lot of wasted time if you ask me. Tim On 12/18/2014 12:59 PM, Ben Westfall wrote: > > I cannot decide if the glass is half full or half empty on this one. > > For the half empty... > > No disrespect towards you at all Tim but at first all I could think was... > wow what a pile of crap on AOPA's part. The least they could do is spare a > few paragraphs of your awesome narratives I've enjoyed reading over the > years. It's sad to say but I guess we're supposed to all be flattered that > a "homebuilt" got two pages of pictures in AOPA right? > > > For the half full... > > Wow a non-corporate sponsored, homebuilt article was able to get a 2 page > spread of pictures and 8 sentences in AOPA... that's progress. I guess the > homebuilt market is really making a dent. > > > I guess it depends on which side of the bed I wake up on. > > -Ben > ________________________________________________________________________________
Date: Dec 19, 2014
Well done Tim Now it's about time you both flew the six States and two Territories of Australia! Safe skies and Merry Christmas. Warm regards Patrick Pulis Adelaide, South Australia > On 19 Dec 2014, at 01:31, Tim Olson wrote: > > > Here you go: > http://www.myrv10.com/AOPA_50_States.pdf > > > That's just those 2 pages. > Tim > > >> On 12/18/2014 8:50 AM, Werner Schneider wrote: >> >> Tim, >> >> would there be a copy available on your website, for us overseas pilots >> to read? >> >> Cheers >> >> Werner > > > > ________________________________________________________________________________
Date: Dec 18, 2014
:) You say that but in the next couple years we may come that way and I think it would be a blast to do some a little flyabout. :) Tim On 12/18/2014 2:06 PM, Patrick Pulis wrote: > > Well done Tim > > Now it's about time you both flew the six States and two Territories of Australia! > > Safe skies and Merry Christmas. > > Warm regards > > Patrick Pulis > Adelaide, South Australia > >> On 19 Dec 2014, at 01:31, Tim Olson wrote: >> >> >> Here you go: >> http://www.myrv10.com/AOPA_50_States.pdf >> >> >> That's just those 2 pages. >> Tim >> >> >>> On 12/18/2014 8:50 AM, Werner Schneider wrote: >>> >>> Tim, >>> >>> would there be a copy available on your website, for us overseas pilots >>> to read? >>> >>> Cheers >>> >>> Werner >> >> >> >> > ________________________________________________________________________________
Date: Dec 18, 2014
You bet :) just cross that word "little" out :), except on the east coast most of that part of the world the distances between the next airfields are closer to the 400-500 miles distance. But it's so nice to fly there especially in the outback where you can do your own sightseeing around the wonders of the nature I loved it a lot and would do any time again! Cheers Werner (1 Territory (NT) and 1 State (TAS) missing) On 18.12.2014 21:20, Tim Olson wrote: > > :) You say that but in the next couple years we may come that way > and I think it would be a blast to do some a little flyabout. :) > > > Tim ________________________________________________________________________________
Date: Dec 19, 2014
All RV-10 drivers are welcome to come and stay with us here in Adelaide, we're steadily notching up RV-10 visitors. We finalised our airfares to the US yesterday, so Linda and I will hopefully finally meet up with some of the RV-10 family next year at Oshkosh. We intend to be there for the first five days, before moving on to Canada. Prior to traveling to Oshkosh we will visiting Los Angeles and San Diego, are there any RV-10 builders in Los Angeles or San Diego please? We will then be traveling to Kitchener, Ontario and would love to meet up with any RV-10 builders in Canada too please. Warm regards Patrick > On 19 Dec 2014, at 06:50, Tim Olson wrote: > > > :) You say that but in the next couple years we may come that way > and I think it would be a blast to do some a little flyabout. :) > > > Tim > >> On 12/18/2014 2:06 PM, Patrick Pulis wrote: >> >> Well done Tim >> >> Now it's about time you both flew the six States and two Territories of Australia! >> >> Safe skies and Merry Christmas. >> >> Warm regards >> >> Patrick Pulis >> Adelaide, South Australia >> >>> On 19 Dec 2014, at 01:31, Tim Olson wrote: >>> >>> >>> Here you go: >>> http://www.myrv10.com/AOPA_50_States.pdf >>> >>> >>> That's just those 2 pages. >>> Tim >>> >>> >>>> On 12/18/2014 8:50 AM, Werner Schneider wrote: >>>> >>>> Tim, >>>> >>>> would there be a copy available on your website, for us overseas pilots >>>> to read? >>>> >>>> Cheers >>>> >>>> Werner > > > > ________________________________________________________________________________
Date: Dec 19, 2014
Subject: Time for Front Seats
Looking for opinions on the front seats. Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. --Ron ________________________________________________________________________________
Date: Dec 19, 2014
Subject: Re: Time for Front Seats
I would give Abby at Flightline Interiors a call. You don't have to send here anything and she does a great job. Very satisfied customer. http://www.flightlineinteriors.com -Sean #40303 > Ron Walker > December 19, 2014 at 8:25 AM > > Looking for opinions on the front seats. > > Anyone have recent input from going the Oregon Aero route wrt pricing > ? I'm tempted to use that avenue, but the idea of shipping both seat > frames out and back sounds risky. > > I took the cushions and frame to a local auto interior shop to get an > estimate - while claiming they are 'experts' in aviation upholstery, > the guy seemed clueless. They refused to give me an estimate beyond > "time and materials" -- with a time estimate of "could take me 2 hrs, > could take me 10" (at $75 per hr). I left unfulfilled. > > --Ron > ________________________________________________________________________________
Date: Dec 19, 2014
Depending on where you are, also consider Geoff Combs at Aerosport products. in Columbus OH area for very nice custom seat covering. The front seats are more easily shipped if you separate the seat back from the seat base. On Fri, Dec 19, 2014 at 8:08 AM, Sean Stephens wrote: > > > I would give Abby at Flightline Interiors a call. You don't have to send > here anything and she does a great job. Very satisfied customer. > > http://www.flightlineinteriors.com > > -Sean #40303 > > Ron Walker >> December 19, 2014 at 8:25 AM >> >> >> Looking for opinions on the front seats. >> >> Anyone have recent input from going the Oregon Aero route wrt pricing ? >> I'm tempted to use that avenue, but the idea of shipping both seat frames >> out and back sounds risky. >> >> I took the cushions and frame to a local auto interior shop to get an >> estimate - while claiming they are 'experts' in aviation upholstery, the >> guy seemed clueless. They refused to give me an estimate beyond "time and >> materials" -- with a time estimate of "could take me 2 hrs, could take me >> 10" (at $75 per hr). I left unfulfilled. >> >> --Ron >> >> > > ________________________________________________________________________________
Date: Dec 19, 2014
Ron; I went to a rather famous auto upholstery place in Southern California, they were very expensive and in the end the work was pretty bad. I ended up getting a beautiful seat from Desser for a reasonable price. I do not know if they are still doing this as it was during the era when Desser was pushing into the RV aftermarket business. If I were to do this again with a RV-16 I would go the aircraft uphostery route, albeit Oregon, Desser or other upholstery company that has done this before. -----Original Message----- From: Ron Walker Sent: Friday, December 19, 2014 6:25 AM Subject: RV10-List: Time for Front Seats Looking for opinions on the front seats. Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. --Ron ________________________________________________________________________________
Date: Dec 19, 2014
Patrick; You owe me a visit from last time! When in Los Angeles, consider coming down to Orange county- 45 minutes south from LAX (or 30 miles). We would love to host you and Linda when you're out. Pascal -----Original Message----- From: Patrick Pulis Sent: Friday, December 19, 2014 3:10 AM Subject: Re: RV10-List: Spread in AOPA Pilot All RV-10 drivers are welcome to come and stay with us here in Adelaide, we're steadily notching up RV-10 visitors. We finalised our airfares to the US yesterday, so Linda and I will hopefully finally meet up with some of the RV-10 family next year at Oshkosh. We intend to be there for the first five days, before moving on to Canada. Prior to traveling to Oshkosh we will visiting Los Angeles and San Diego, are there any RV-10 builders in Los Angeles or San Diego please? We will then be traveling to Kitchener, Ontario and would love to meet up with any RV-10 builders in Canada too please. Warm regards Patrick > On 19 Dec 2014, at 06:50, Tim Olson wrote: > > > :) You say that but in the next couple years we may come that way > and I think it would be a blast to do some a little flyabout. :) > > > Tim > >> On 12/18/2014 2:06 PM, Patrick Pulis wrote: >> >> >> Well done Tim >> >> Now it's about time you both flew the six States and two Territories of >> Australia! >> >> Safe skies and Merry Christmas. >> >> Warm regards >> >> Patrick Pulis >> Adelaide, South Australia >> >>> On 19 Dec 2014, at 01:31, Tim Olson wrote: >>> >>> >>> Here you go: >>> http://www.myrv10.com/AOPA_50_States.pdf >>> >>> >>> That's just those 2 pages. >>> Tim >>> >>> >>>> On 12/18/2014 8:50 AM, Werner Schneider wrote: >>>> >>>> Tim, >>>> >>>> would there be a copy available on your website, for us overseas pilots >>>> to read? >>>> >>>> Cheers >>>> >>>> Werner > > ________________________________________________________________________________
Date: Dec 19, 2014
It appears that she took all the RV-10 products off her web site Sent from my iPhone On Dec 19, 2014, at 10:08 AM, Sean Stephens wrote: I would give Abby at Flightline Interiors a call. You don't have to send here anything and she does a great job. Very satisfied customer. http://www.flightlineinteriors.com -Sean #40303 > Ron Walker > December 19, 2014 at 8:25 AM > > Looking for opinions on the front seats. > > Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. > > I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. > > --Ron > ________________________________________________________________________________
Date: Dec 19, 2014
I had front and rear seats covered in marine vinyl ..... easy to keep clean and durable .... for $850 time/materials ..... which included tuck/roll for the center panel. The lady works out of her home in Titusville FL which is kinda local for me. If you have removed the crotch strap from the back seats like I did, be sure to tell the upholsterer so they can remove the 'notch' from the rear seat bottom. Linn On 12/19/2014 9:25 AM, Ron Walker wrote: > > Looking for opinions on the front seats. > > Anyone have recent input from going the Oregon Aero route wrt pricing > ? I'm tempted to use that avenue, but the idea of shipping both seat > frames out and back sounds risky. > > I took the cushions and frame to a local auto interior shop to get an > estimate - while claiming they are 'experts' in aviation upholstery, > the guy seemed clueless. They refused to give me an estimate beyond > "time and materials" -- with a time estimate of "could take me 2 hrs, > could take me 10" (at $75 per hr). I left unfulfilled. > > --Ron > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 19, 2014
I called .... they were 6-9 months lead time. That's the trouble with success!!! Linn On 12/19/2014 10:58 AM, Bob Leffler wrote: > > It appears that she took all the RV-10 products off her web site > > Sent from my iPhone > > On Dec 19, 2014, at 10:08 AM, Sean Stephens wrote: > > > I would give Abby at Flightline Interiors a call. You don't have to send here anything and she does a great job. Very satisfied customer. > > http://www.flightlineinteriors.com > > -Sean #40303 > >> Ron Walker >> December 19, 2014 at 8:25 AM >> >> Looking for opinions on the front seats. >> >> Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. >> >> I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. >> >> --Ron >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 19, 2014
One thought about the front seats. One of the greatest builder mods of the whole build was the two seat mods for the front seats. Trimming the track guard, and nut plating the aft track block, both for easier seat removal. Hopefully someone can post a link to the instructions for those mods as they are highly worthwhile. Van's should have just embedded them into the plans they make so much sense. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435916#435916 ________________________________________________________________________________
Date: Dec 19, 2014
I would give Geoff at Aerosport Products a call. He's got more seat options than what is shown on the web site. Sent from my iPhone On Dec 19, 2014, at 12:00 PM, Linn Walters wrote: I called .... they were 6-9 months lead time. That's the trouble with success!!! Linn > On 12/19/2014 10:58 AM, Bob Leffler wrote: > > It appears that she took all the RV-10 products off her web site > > Sent from my iPhone > > On Dec 19, 2014, at 10:08 AM, Sean Stephens wrote: > > > I would give Abby at Flightline Interiors a call. You don't have to send here anything and she does a great job. Very satisfied customer. > > http://www.flightlineinteriors.com > > -Sean #40303 > >> Ron Walker >> December 19, 2014 at 8:25 AM >> >> Looking for opinions on the front seats. >> >> Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. >> >> I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. >> >> --Ron >> > > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Dec 19, 2014
Aerosport Products can do your seats any many colors and fabrics. We can do custom designs for a small fee. We now have all RV-10 seat foams in 3D and can generate seat designs much quicker thru a computer program. This program is what many of the car manufactures use for designing their seats patterns . We do require you to send the front upper steel frame with the foams and just the lower front seat foams. For the back seats we have our own foams we sell that are very similar to the Vans foams. All we need are Your corrugated rear seat back frames that the builder assembles. We do offer carpet kits for the RV-10 also. Give us a call Thanks Geoff www.aerosportproducts.com Aerosport -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Friday, December 19, 2014 2:36 PM Subject: Re: RV10-List: Time for Front Seats I would give Geoff at Aerosport Products a call. He's got more seat options than what is shown on the web site. Sent from my iPhone On Dec 19, 2014, at 12:00 PM, Linn Walters wrote: I called .... they were 6-9 months lead time. That's the trouble with success!!! Linn > On 12/19/2014 10:58 AM, Bob Leffler wrote: > > It appears that she took all the RV-10 products off her web site > > Sent from my iPhone > > On Dec 19, 2014, at 10:08 AM, Sean Stephens wrote: > > --> > > I would give Abby at Flightline Interiors a call. You don't have to send here anything and she does a great job. Very satisfied customer. > > http://www.flightlineinteriors.com > > -Sean #40303 > >> Ron Walker >> December 19, 2014 at 8:25 AM >> >> Looking for opinions on the front seats. >> >> Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. >> >> I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. >> >> --Ron >> > > > > > > > > > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 19, 2014
My vote is for Abby with Flight Line interiors. I would bet she has the single most experience in doing RV interiors. She is extremely easy to work with. Great quality. Dave Leikam > On Dec 19, 2014, at 3:56 PM, Geoff Combs wrote: > > Aerosport Products can do your seats any many colors and fabrics. We can do > custom designs for a small fee. > We now have all RV-10 seat foams in 3D and can generate seat designs much > quicker thru a computer program. > This program is what many of the car manufactures use for designing their > seats patterns . > > We do require you to send the front upper steel frame with the foams and > just the lower front seat foams. > For the back seats we have our own foams we sell that are very similar to > the Vans foams. All we need are Your corrugated rear seat back frames that > the builder assembles. We do offer carpet kits for the RV-10 also. > Give us a call > > Thanks Geoff > www.aerosportproducts.com > > Aerosport > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler > Sent: Friday, December 19, 2014 2:36 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Time for Front Seats > > > I would give Geoff at Aerosport Products a call. He's got more seat > options than what is shown on the web site. > > Sent from my iPhone > > On Dec 19, 2014, at 12:00 PM, Linn Walters wrote: > > > I called .... they were 6-9 months lead time. That's the trouble with > success!!! > Linn > >> On 12/19/2014 10:58 AM, Bob Leffler wrote: >> >> It appears that she took all the RV-10 products off her web site >> >> Sent from my iPhone >> >> On Dec 19, 2014, at 10:08 AM, Sean Stephens > wrote: >> >> --> >> >> I would give Abby at Flightline Interiors a call. You don't have to send > here anything and she does a great job. Very satisfied customer. >> >> http://www.flightlineinteriors.com >> >> -Sean #40303 >> >>> Ron Walker >>> December 19, 2014 at 8:25 AM >>> >>> Looking for opinions on the front seats. >>> >>> Anyone have recent input from going the Oregon Aero route wrt pricing ? > I'm tempted to use that avenue, but the idea of shipping both seat frames > out and back sounds risky. >>> >>> I took the cushions and frame to a local auto interior shop to get an > estimate - while claiming they are 'experts' in aviation upholstery, the guy > seemed clueless. They refused to give me an estimate beyond "time and > materials" -- with a time estimate of "could take me 2 hrs, could take me > 10" (at $75 per hr). I left unfulfilled. >>> >>> --Ron >>> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 19, 2014
On 12/19/2014 6:42 PM, Jae Chang wrote: > > Abby and crew is definitely easy to work with, and i have ordered > several things over the years. > > However, the one disappointment i had was with ordering the rear > passenger seat floor mats. For some reason, they are small and do not > fit the footwell. They are short about 2 inches or so all around. She > said that was all they had and did not have anything bigger. It just > struck me as odd that they couldn't make a simple modification to > fully fit the footwell?! The fronts fit great. > > Jae > Mine fit well - did you have carpet installed on the surrounding vertical surfaces? I did and I'm thinking that may be a dependency. I also 2nd the motion on Abby's seat work. Just pick the materials and order, no need to send anything. They'll fit fine. ________________________________________________________________________________
Date: Dec 19, 2014
The options weren=92t as prevalent when I did my seats, but I went with a local guy that did seats for hot rods. They turned out great and a very good price, although I don=92t recall exactly what. I=92d look into the normal options, but try talking to a local hot rod club as well as anyone that does good work on their seats has the equipment and skill to do yours as well, and since it doesn=92t say aviation it might be a lot cheaper. Marcus 40286 > On Dec 19, 2014, at 6:58 PM, Bill Watson wrote: > > > > On 12/19/2014 6:42 PM, Jae Chang wrote: > >> >> Abby and crew is definitely easy to work with, and i have ordered several things over the years. >> >> However, the one disappointment i had was with ordering the rear passenger seat floor mats. For some reason, they are small and do not fit the footwell. They are short about 2 inches or so all around. She said that was all they had and did not have anything bigger. It just struck me as odd that they couldn't make a simple modification to fully fit the footwell?! The fronts fit great. >> >> Jae >> > Mine fit well - did you have carpet installed on the surrounding vertical surfaces? I did and I'm thinking that may be a dependency. > > I also 2nd the motion on Abby's seat work. Just pick the materials and order, no need to send anything. They'll fit fine. > ________________________________________________________________________________
Date: Dec 20, 2014
I bought virtually everything that Geoff Combs/Aerosport Products sells for the RV-10 - IP, all interior panels, overhead console, front and rear leather seats with headrests, center console with upholstered arm rest, headliner, and carpet. Although I do not have everything installed yet, the quality looks great. And, since Geoff built and flys an RV-10 I have no worries about something not fitting. His service, responsiveness, and support either directly or through Zac Holcomb have been excellent. Bruce Sent from my iPad > On Dec 19, 2014, at 8:25 AM, Ron Walker wrote: > > > Looking for opinions on the front seats. > > Anyone have recent input from going the Oregon Aero route wrt pricing ? I'm tempted to use that avenue, but the idea of shipping both seat frames out and back sounds risky. > > I took the cushions and frame to a local auto interior shop to get an estimate - while claiming they are 'experts' in aviation upholstery, the guy seemed clueless. They refused to give me an estimate beyond "time and materials" -- with a time estimate of "could take me 2 hrs, could take me 10" (at $75 per hr). I left unfulfilled. > > --Ron > > > > > > > ________________________________________________________________________________
Subject: Re: Time for front seats
Date: Dec 20, 2014
I met Geoff and Zac a couple years ago at OSH13 and I saw their products up close at OSH14. I flew to Lancaster to visit Geoffs' facility (worth the time) and drop off my front seats and rear seat backs a couple months ago.... Yesterday, I received the rest of my RV10 order. WOW! The workmanship was AWESOME. I think their abilities come from the years of doing new model interior design work for the automotive industry. I have heard of several good seat makers....but I think Geoffs' interior design background, his successful completion of his RV10 and Zac push them to the top. ________________________________________________________________________________
Date: Dec 20, 2014
I am also close to interior. That's for posting.. I'll use him also. Craig On Sat, Dec 20, 2014 at 6:32 AM, Terry Moushon wrote: > > > I met Geoff and Zac a couple years ago at OSH13 and I saw their products > up close at OSH14. I flew to Lancaster to visit Geoffs' facility (worth > the time) and drop off my front seats and rear seat backs a couple months > ago.... Yesterday, I received the rest of my RV10 order. WOW! The > workmanship was AWESOME. I think their abilities come from the years of > doing new model interior design work for the automotive industry. I have > heard of several good seat makers....but I think Geoffs' interior design > background, his successful completion of his RV10 and Zac push them to the > top. > > ________________________________________________________________________________
Subject: Holes in the Landing Gear Mounts
Date: Dec 20, 2014
Guys The WD-102- L & R Landing Gear Mounts have, each of them, 4 holes in the horizontal part, the ones which must be final-drilled #12 according to step 4 (on figure 4) of page 28-16 of the Manual (Section 28 : Fwd Ribs, Bhds & Bottom Skins), which doesn't seem to be used for anything. Does anybody know what are these 4 holes for? I ask because I didn't find the answer in the Manual, though I'm tempted to use those holes to install an electric connector bus for the bunch of wires which come from the Stick grip . Regards Carlos --- Este email est=C3=A1 livre de v=C3=ADrus e malware porque a prote=C3=A7=C3 =A3o avast! Antivirus est=C3=A1 ativa. http://www.avast.com ________________________________________________________________________________
Subject: Re: Holes in the Landing Gear Mounts
Date: Dec 20, 2014
Those holes are for the Mid Seat Rail Supports that you assembled in step 1 and 2. There are also several threads that identify the fact that the plans do not tell you when to install these supports, only that they should be left out in order to drill and ream the gear leg mounting hole... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=435945#435945 ________________________________________________________________________________
Date: Dec 20, 2014
I got so frustrated trying to use the 4 bolts/nuts to attach those 'spacers' that I created a plate with three nutplates to go on one side of the web (that you can't see) ..... and the bolt/nut to go on the other side of the web. Because I could. Linn On 12/20/2014 3:35 PM, Rocketman1988 wrote: > > Those holes are for the Mid Seat Rail Supports that you assembled in step 1 and 2. > > There are also several threads that identify the fact that the plans do not tell you when to install these supports, only that they should be left out in order to drill and ream the gear leg mounting hole... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435945#435945 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 21, 2014
Hey Linn, I had to bring in the reserves to help get those nuts/washers on (my wife and her little hands). Heading your way at New Years, so I need to come for an inspection (again) ;-) Rick #40956 Southampton, Ont On Sat, Dec 20, 2014 at 3:53 PM, Linn Walters wrote: > > I got so frustrated trying to use the 4 bolts/nuts to attach those > 'spacers' that I created a plate with three nutplates to go on one side of > the web (that you can't see) ..... and the bolt/nut to go on the other side > of the web. Because I could. > Linn > > On 12/20/2014 3:35 PM, Rocketman1988 wrote: > >> >> Those holes are for the Mid Seat Rail Supports that you assembled in step >> 1 and 2. >> >> There are also several threads that identify the fact that the plans do >> not tell you when to install these supports, only that they should be left >> out in order to drill and ream the gear leg mounting hole... >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=435945#435945 >> >> >> >> >> >> >> >> >> >> >> >> >> ----- >> No virus found in this message. >> Checked by AVG - www.avg.com >> >> >> > > ________________________________________________________________________________
Date: Dec 21, 2014
Hi Rick! Just give me a call ..... Merry Christmas!! Linn On 12/21/2014 9:35 PM, Rick Lark wrote: > Hey Linn, I had to bring in the reserves to help get those > nuts/washers on (my wife and her little hands). Heading your way at > New Years, so I need to come for an inspection (again) ;-) > Rick > #40956 > Southampton, Ont > > On Sat, Dec 20, 2014 at 3:53 PM, Linn Walters > wrote: > > > > > I got so frustrated trying to use the 4 bolts/nuts to attach those > 'spacers' that I created a plate with three nutplates to go on one > side of the web (that you can't see) ..... and the bolt/nut to go > on the other side of the web. Because I could. > Linn > > On 12/20/2014 3:35 PM, Rocketman1988 wrote: > > > > > Those holes are for the Mid Seat Rail Supports that you > assembled in step 1 and 2. > > There are also several threads that identify the fact that the > plans do not tell you when to install these supports, only > that they should be left out in order to drill and ream the > gear leg mounting hole... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=435945#435945 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > > > =================================== > br> fts!) > r> > /www.aeroelectric.com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > =================================== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > _blank">http://forums.matronics.com > =================================== > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: NavWorx ADS-B
Date: Dec 24, 2014
Do any on the list have the NavWorx ADS-B unit installed and working? Id appreciate off-line discussions with any who do. Thanks, and Merry Christmas! Grumpy gengrumpy(at)aol.com ________________________________________________________________________________
Subject: Re: NavWorx ADS-B
Date: Dec 24, 2014
There quite a few of us on the list that have Navworx installed. I do....... Bob Sent from my iPad > On Dec 24, 2014, at 2:59 PM, Miller John wrote: > > > Do any on the list have the NavWorx ADS-B unit installed and working? > > Id appreciate off-line discussions with any who do. > > Thanks, and Merry Christmas! > > Grumpy > gengrumpy(at)aol.com > > > > ________________________________________________________________________________
Date: Dec 24, 2014
I don't have one on hand, but have installed a couple. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 24, 2014, at 2:59 PM, Miller John wrote: > > > Do any on the list have the NavWorx ADS-B unit installed and working? > > Id appreciate off-line discussions with any who do. > > Thanks, and Merry Christmas! > > Grumpy > gengrumpy(at)aol.com > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Getting ready to install one and connect it up to a 420W, MX20, and AFS3400EE. I am interested to hear any discussions also..... -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John Sent: Wednesday, December 24, 2014 2:59 PM Subject: RV10-List: NavWorx ADS-B Do any on the list have the NavWorx ADS-B unit installed and working? Id appreciate off-line discussions with any who do. Thanks, and Merry Christmas! Grumpy gengrumpy(at)aol.com ________________________________________________________________________________
Date: Dec 24, 2014
Ralph, Does your 3400 have the "s" processor? AFS has released several updates to the software to resolve some issues with the NavWorx. I just installed the last beta version, but I haven't had a chance to fly with it yet due to the weather. The nice weather days recently seemed to only days I'm working. Bob Sent from my iPad > On Dec 24, 2014, at 3:29 PM, Ralph E. Capen wrote: > > > Getting ready to install one and connect it up to a 420W, MX20, and AFS3400EE. > > I am interested to hear any discussions also..... > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John > Sent: Wednesday, December 24, 2014 2:59 PM > To: rv10-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV10-List: NavWorx ADS-B > > > Do any on the list have the NavWorx ADS-B unit installed and working? > > Id appreciate off-line discussions with any who do. > > Thanks, and Merry Christmas! > > Grumpy > gengrumpy(at)aol.com > > > > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Bob and Rene, Thanks for the replies. Im interested in your opinions on the following: 1. Reliability of the system. 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. 4. Any other thoughts you have on their system. Thanks - Grumpy > On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: > > > There quite a few of us on the list that have Navworx installed. I do....... > > Bob > > Sent from my iPad > >> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >> >> >> Do any on the list have the NavWorx ADS-B unit installed and working? >> >> Id appreciate off-line discussions with any who do. >> >> Thanks, and Merry Christmas! >> >> Grumpy >> gengrumpy(at)aol.com >> >> >> >> > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Yes, I have the 's'! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, December 24, 2014 3:56 PM Subject: Re: RV10-List: NavWorx ADS-B Ralph, Does your 3400 have the "s" processor? AFS has released several updates to the software to resolve some issues with the NavWorx. I just installed the last beta version, but I haven't had a chance to fly with it yet due to the weather. The nice weather days recently seemed to only days I'm working. Bob Sent from my iPad > On Dec 24, 2014, at 3:29 PM, Ralph E. Capen wrote: > > --> > > Getting ready to install one and connect it up to a 420W, MX20, and AFS3400EE. > > I am interested to hear any discussions also..... > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Miller John > Sent: Wednesday, December 24, 2014 2:59 PM > To: rv10-list(at)matronics.com; rv8-list(at)matronics.com > Subject: RV10-List: NavWorx ADS-B > > > Do any on the list have the NavWorx ADS-B unit installed and working? > > Id appreciate off-line discussions with any who do. > > Thanks, and Merry Christmas! > > Grumpy > gengrumpy(at)aol.com > > > > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
[quote="gengrumpy"]Bob and Rene, Thanks for the replies. Im interested in your opinions on the following: 1 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. 4. Any other thoughts you have on their system. Thanks - Grumpy [quote] If you intend to use or need the ADSB-out after 2020 you need to have a "certified" (e.g. meets FAR specs) gps position source. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436131#436131 ________________________________________________________________________________
Date: Dec 24, 2014
See below. Btw, I have one for sale. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Dec 24, 2014, at 4:08 PM, Miller John wrote: > > > Bob and Rene, > > Thanks for the replies. Im interested in your opinions on the following: > > 1. Reliability of the system. In my experience it's very reliable. > > 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. The wiring is simple. The programming is a little archaic, but it isn't hard. The 327 works as a remote so the navworx box gets the right squawk. I don't have experience with the Chelton. > > 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. Non-certified. For a certified plane the certified version is required. I doubt many of the certified units are going into experimentals. I don't know the 2020 ramifications of the non-certified unit. > > 4. Any other thoughts you have on their system. A cheaper way to go ads-b in/out if you already are running on a mode C transponder. > > Thanks - Grumpy > >> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >> >> >> There quite a few of us on the list that have Navworx installed. I do....... >> >> Bob >> >> Sent from my iPad >> >>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>> >>> >>> Do any on the list have the NavWorx ADS-B unit installed and working? >>> >>> Id appreciate off-line discussions with any who do. >>> >>> Thanks, and Merry Christmas! >>> >>> Grumpy >>> gengrumpy(at)aol.com > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. Tim > On Dec 24, 2014, at 4:08 PM, Miller John wrote: > > > Bob and Rene, > > Thanks for the replies. Im interested in your opinions on the following: > > 1. Reliability of the system. > > 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. > > 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. > > 4. Any other thoughts you have on their system. > > Thanks - Grumpy > >> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >> >> >> There quite a few of us on the list that have Navworx installed. I do....... >> >> Bob >> >> Sent from my iPad >> >>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>> >>> >>> Do any on the list have the NavWorx ADS-B unit installed and working? >>> >>> Id appreciate off-line discussions with any who do. >>> >>> Thanks, and Merry Christmas! >>> >>> Grumpy >>> gengrumpy(at)aol.com > > > > > > ________________________________________________________________________________
Subject: SB 14-8-29
Date: Dec 24, 2014
For the list (and whoever is keeping track). I performed the SB on the nose gear leg attachment to the engine mount. No cracking found, so the doubler plate was primed and fit nicely without any trimming required. 325hrs with probably 50 or so turf field landings. For what its worth as technique, I try to keep as much weight off of the nose gear as possible until slowed to taxi speed, even on hard surfaces. grumpy N184JM ________________________________________________________________________________
Date: Dec 24, 2014
If I pull the trigger and buy one before April (my ACI time), Ill probably be asking you a lot more questions! It sure seems to be the most economical solution for my 10 now. I dont have wx on my Cheltons but do have on my G-396 (XM WX). Traffic and radar would be the most valuable for the Cheltons. What does the WI-FI connect to? Couldnt find it on their website. I use ForeFlight on the iPad. grumpy > On Dec 24, 2014, at 3:49 PM, Tim Olson wrote: > > > It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. > Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. > > Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. > I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. > > > Tim > >> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >> >> >> Bob and Rene, >> >> Thanks for the replies. Im interested in your opinions on the following: >> >> 1. Reliability of the system. >> >> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >> >> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >> >> 4. Any other thoughts you have on their system. >> >> Thanks - Grumpy >> >>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>> >>> >>> There quite a few of us on the list that have Navworx installed. I do....... >>> >>> Bob >>> >>> Sent from my iPad >>> >>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>> >>>> >>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>> >>>> Id appreciate off-line discussions with any who do. >>>> >>>> Thanks, and Merry Christmas! >>>> >>>> Grumpy >>>> gengrumpy(at)aol.com >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Which version do you have, components and price? grumpy > On Dec 24, 2014, at 3:39 PM, Jesse Saint wrote: > > > See below. > > Btw, I have one for sale. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >> >> >> Bob and Rene, >> >> Thanks for the replies. Im interested in your opinions on the following: >> >> 1. Reliability of the system. > In my experience it's very reliable. >> >> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. > The wiring is simple. The programming is a little archaic, but it isn't hard. The 327 works as a remote so the navworx box gets the right squawk. I don't have experience with the Chelton. >> >> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. > Non-certified. For a certified plane the certified version is required. I doubt many of the certified units are going into experimentals. I don't know the 2020 ramifications of the non-certified unit. >> >> 4. Any other thoughts you have on their system. > A cheaper way to go ads-b in/out if you already are running on a mode C transponder. >> >> Thanks - Grumpy >> >>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>> >>> >>> There quite a few of us on the list that have Navworx installed. I do....... >>> >>> Bob >>> >>> Sent from my iPad >>> >>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>> >>>> >>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>> >>>> Id appreciate off-line discussions with any who do. >>>> >>>> Thanks, and Merry Christmas! >>>> >>>> Grumpy >>>> gengrumpy(at)aol.com >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
I have the ADS600-B. No ARINC, I think. Non-certified GPS. Includes both antenna cables and a GPS antenna. If the shark fin UAT antenna survived the crash, that's included too. $2,200 shipped conus. I'll include as much of the harness as I can successfully pull from the plane. It does have the console port in the harness with about 4-6' of wire. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Dec 24, 2014, at 5:04 PM, Miller John wrote: > > > Which version do you have, components and price? > > grumpy > >> On Dec 24, 2014, at 3:39 PM, Jesse Saint wrote: >> >> >> See below. >> >> Btw, I have one for sale. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >>> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >>> >>> >>> Bob and Rene, >>> >>> Thanks for the replies. Im interested in your opinions on the following: >>> >>> 1. Reliability of the system. >> In my experience it's very reliable. >>> >>> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >> The wiring is simple. The programming is a little archaic, but it isn't hard. The 327 works as a remote so the navworx box gets the right squawk. I don't have experience with the Chelton. >>> >>> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >> Non-certified. For a certified plane the certified version is required. I doubt many of the certified units are going into experimentals. I don't know the 2020 ramifications of the non-certified unit. >>> >>> 4. Any other thoughts you have on their system. >> A cheaper way to go ads-b in/out if you already are running on a mode C transponder. >>> >>> Thanks - Grumpy >>> >>>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>>> >>>> >>>> There quite a few of us on the list that have Navworx installed. I do....... >>>> >>>> Bob >>>> >>>> Sent from my iPad >>>> >>>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>>> >>>>> >>>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>>> >>>>> Id appreciate off-line discussions with any who do. >>>>> >>>>> Thanks, and Merry Christmas! >>>>> >>>>> Grumpy >>>>> gengrumpy(at)aol.com > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
The wifi port won't feed info to foreflight, but if you have the stratus, it will activate all traffic in your area. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Dec 24, 2014, at 5:03 PM, Miller John wrote: > > > If I pull the trigger and buy one before April (my ACI time), Ill probably be asking you a lot more questions! > > It sure seems to be the most economical solution for my 10 now. > > I dont have wx on my Cheltons but do have on my G-396 (XM WX). Traffic and radar would be the most valuable for the Cheltons. > > What does the WI-FI connect to? Couldnt find it on their website. I use ForeFlight on the iPad. > > grumpy > >> On Dec 24, 2014, at 3:49 PM, Tim Olson wrote: >> >> >> It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. >> Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. >> >> Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. >> I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. >> >> >> Tim >> >>> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >>> >>> >>> Bob and Rene, >>> >>> Thanks for the replies. Im interested in your opinions on the following: >>> >>> 1. Reliability of the system. >>> >>> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >>> >>> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >>> >>> 4. Any other thoughts you have on their system. >>> >>> Thanks - Grumpy >>> >>>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>>> >>>> >>>> There quite a few of us on the list that have Navworx installed. I do....... >>>> >>>> Bob >>>> >>>> Sent from my iPad >>>> >>>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>>> >>>>> >>>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>>> >>>>> Id appreciate off-line discussions with any who do. >>>>> >>>>> Thanks, and Merry Christmas! >>>>> >>>>> Grumpy >>>>> gengrumpy(at)aol.com > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Wifi connects to an iPad running WingX. There may be other options available, but this is the one I have. Bob Sent from my iPad > On Dec 24, 2014, at 5:03 PM, Miller John wrote: > > > If I pull the trigger and buy one before April (my ACI time), Ill probably be asking you a lot more questions! > > It sure seems to be the most economical solution for my 10 now. > > I dont have wx on my Cheltons but do have on my G-396 (XM WX). Traffic and radar would be the most valuable for the Cheltons. > > What does the WI-FI connect to? Couldnt find it on their website. I use ForeFlight on the iPad. > > grumpy > >> On Dec 24, 2014, at 3:49 PM, Tim Olson wrote: >> >> >> It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. >> Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. >> >> Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. >> I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. >> >> >> Tim >> >>> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >>> >>> >>> Bob and Rene, >>> >>> Thanks for the replies. Im interested in your opinions on the following: >>> >>> 1. Reliability of the system. >>> >>> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >>> >>> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >>> >>> 4. Any other thoughts you have on their system. >>> >>> Thanks - Grumpy >>> >>>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>>> >>>> >>>> There quite a few of us on the list that have Navworx installed. I do....... >>>> >>>> Bob >>>> >>>> Sent from my iPad >>>> >>>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>>> >>>>> >>>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>>> >>>>> Id appreciate off-line discussions with any who do. >>>>> >>>>> Thanks, and Merry Christmas! >>>>> >>>>> Grumpy >>>>> gengrumpy(at)aol.com >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Warning, thread drift! If you have a cfi certificate, Hilton will give you a WingX subscription for free. Includes geo-referencing. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436141#436141 ________________________________________________________________________________
Date: Dec 24, 2014
It connects to most except not Foreflight. Foreflight is still in the pig-headed proprietary stage like Garmin. Tim > On Dec 24, 2014, at 5:03 PM, Miller John wrote: > > > If I pull the trigger and buy one before April (my ACI time), Ill probably be asking you a lot more questions! > > It sure seems to be the most economical solution for my 10 now. > > I dont have wx on my Cheltons but do have on my G-396 (XM WX). Traffic and radar would be the most valuable for the Cheltons. > > What does the WI-FI connect to? Couldnt find it on their website. I use ForeFlight on the iPad. > > grumpy > >> On Dec 24, 2014, at 3:49 PM, Tim Olson wrote: >> >> >> It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. >> Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. >> >> Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. >> I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. >> >> >> Tim >> >>> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >>> >>> >>> Bob and Rene, >>> >>> Thanks for the replies. Im interested in your opinions on the following: >>> >>> 1. Reliability of the system. >>> >>> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >>> >>> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >>> >>> 4. Any other thoughts you have on their system. >>> >>> Thanks - Grumpy >>> >>>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>>> >>>> >>>> There quite a few of us on the list that have Navworx installed. I do....... >>>> >>>> Bob >>>> >>>> Sent from my iPad >>>> >>>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>>> >>>>> >>>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>>> >>>>> Id appreciate off-line discussions with any who do. >>>>> >>>>> Thanks, and Merry Christmas! >>>>> >>>>> Grumpy >>>>> gengrumpy(at)aol.com >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Yeah, I saw that this week. That's an amazing deal and a good way for them to promote it. It works well. Tim > On Dec 24, 2014, at 5:37 PM, Bob Turner wrote: > > > Warning, thread drift! > > If you have a cfi certificate, Hilton will give you a WingX subscription for free. Includes geo-referencing. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436141#436141 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
Subject: 2014 List of Contributors
Dear Listers, The 2014 Matronics Email List and Forum Fund Raiser officially ended a couple of weeks ago and it's time that I published this year's List of Contributors. It is the people on this list that directly make these Email Lists and Forums possible! Their generous Contributions keep the servers and Internet connection up and running! You can still show your support this year and pick up a great gift at the same time. The Contribution Web Site is fast, easy, and secure: http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matt Dralle / Matronics 581 Jeannie Way Livermore CA 94550 I also want to thank Andy, Bob, Corbin, George, and Jon for their generous support through the supply of many great gifts this year!! These guys have some excellent products and I encourage you to visit their respective web sites: Andy Gold - The Builder's Bookstore - http://www.buildersbooks.com Bob Nucklolls - AeroElectric - http://www.aeroelectric.com Corbin Glowacki - My Pilot Store - http://www.mypilotstore.com George Race - Race Consulting - http://www.mrrace.com Jon Croke - HomebuiltHELP - http://www.homebuilthelp.com And finally, I'm proud to present The 2014 Fund Raiser List of Contributors: http://www.matronics.com/loc/2014.html Thank you again to everyone that made a Contribution this year!! Matt Dralle Matronics Email List & Forum Administrator ________________________________________________________________________________
Date: Dec 24, 2014
I have no idea whether it will interface with your equipment, but you might (as I am) take a look at the pathfinder. http://www.fdatasystems.com/pathfinder-remote Linn On 12/24/2014 5:03 PM, Miller John wrote: > > If I pull the trigger and buy one before April (my ACI time), Ill probably be asking you a lot more questions! > > It sure seems to be the most economical solution for my 10 now. > > I dont have wx on my Cheltons but do have on my G-396 (XM WX). Traffic and radar would be the most valuable for the Cheltons. > > What does the WI-FI connect to? Couldnt find it on their website. I use ForeFlight on the iPad. > > grumpy > >> On Dec 24, 2014, at 3:49 PM, Tim Olson wrote: >> >> >> It should work well for you. It's not too hard to install but will require some minor pin adjustments on the Chelton depending on what you have wired right now. If you have WSI weather, there is more to think about but if not it's pretty straight forward. You should find it plenty reliable, as long as you're in a coverage area. I've been using one since 2008 and bought another for my RV14. >> Right now I'd skip the certified GPS for the time being. It's modular and snap in so won't take long to add later and the price will go down on the module later. >> >> Keep in mind that there are more weather products available with FIS-B than what the aging Cheltons can display, but you'll still get the basics and can also use a wifi adapter they sell, with your iPad, to get the other data if you wish. >> I'm going to fly mine as-is for another year or two and then add the certified GPS module. If you just want to spend the money and forget about it, but the certified one now. >> >> >> Tim >> >>> On Dec 24, 2014, at 4:08 PM, Miller John wrote: >>> >>> >>> Bob and Rene, >>> >>> Thanks for the replies. Im interested in your opinions on the following: >>> >>> 1. Reliability of the system. >>> >>> 2. Ease of installation. Immuch better at sheet metal than avionics wiring. Ive got Chelton Sport EFIS, and GTX327 transponder, which appear to work with the system. >>> >>> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >>> >>> 4. Any other thoughts you have on their system. >>> >>> Thanks - Grumpy >>> >>>> On Dec 24, 2014, at 2:16 PM, Bob Leffler wrote: >>>> >>>> >>>> There quite a few of us on the list that have Navworx installed. I do....... >>>> >>>> Bob >>>> >>>> Sent from my iPad >>>> >>>>> On Dec 24, 2014, at 2:59 PM, Miller John wrote: >>>>> >>>>> >>>>> Do any on the list have the NavWorx ADS-B unit installed and working? >>>>> >>>>> Id appreciate off-line discussions with any who do. >>>>> >>>>> Thanks, and Merry Christmas! >>>>> >>>>> Grumpy >>>>> gengrumpy(at)aol.com >>> >>> >>> >>> >>> >> >> >> >> > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Dec 24, 2014
In the past couple weeks it's been discussed that homebuilts were kind of left out in some of the rules...not that they shouldn't apply but that they simply are written poorly and don't seem to incorporate amateur built airplanes in the same ways other avionics do. I personally believe that the GPS should perform to certified standards but that some of the standards set for ADS-B as a whole may be overkill. Nobody is really sure what the end result will be, but clearly some clarification will have to happen at some point. And many people and manufacturers are hoping for some more reasonable specs. So actually, that's one of the reasons that I think NavWorX has for still offering the cheaper non-certified GPS at this time. It allows you to get a system running at lower cost before 2020, yet is upgrade able later. And, they have plans to offer the certified GPS at lower cost later. So for us with Amateur built planes, they actually still encourage us to go with the regular ADS600B yet. I am just glad to see people adopting it, and Amateur built is leading the way. I think it gives us all some capabilities that every airplane should have. Tim > On Dec 24, 2014, at 4:36 PM, Bob Turner wrote: > > > [quote="gengrumpy"]Bob and Rene, > > Thanks for the replies. Im interested in your opinions on the following: > > 1 > > 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. > > 4. Any other thoughts you have on their system. > > Thanks - Grumpy > > [quote] > > If you intend to use or need the ADSB-out after 2020 you need to have a "certified" (e.g. meets FAR specs) gps position source. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436131#436131 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 24, 2014
To the credit of our experimental EFIS suppliers they don't often engage in advertising vaporware. I have heard whispers of Dynon having a certified WAAS GPS available for their ADS-B in the next 3-6 months (probably Sun n Fun if they can). Don't know whether it would also make any of the glass panel IFR as well or not. Given that their 1090ES transponder is around $2200 and their UAT receiver is around $1000. I wouldn't be surprised to see GRT and AFS to find a solution as well. I was rather disappointed in Mac McClellan's blog to see him spinning a bunch of misconceptions about experimental and LSA aircraft (considering he worked for EAA for awhile) based on his reading of an advisory circular that ignores experimental. I see nothing in the regs that prevents us from having a fully certified ADS-B Out installed in our aircraft, as long as you have a transponder that meets the TSO and a GPS that meets the TSO and install by following the manufacturer's instructions as closely as possible. We most certainly don't need STCs or field approvals, and quite frankly I think the FAA is really stretching their own regs to make ADS-B vendors get STCs and AML approval for each make an model certified aircraft, when neither are required to do a simple install of a certified WAAS GPS and an install of a mode 3A/C or Mode S transponder. On 12/24/2014 9:06 PM, Tim Olson wrote: > > In the past couple weeks it's been discussed that homebuilts were kind of left out in some of the rules...not that they shouldn't apply but that they simply are written poorly and don't seem to incorporate amateur built airplanes in the same ways other avionics do. I personally believe that the GPS should perform to certified standards but that some of the standards set for ADS-B as a whole may be overkill. Nobody is really sure what the end result will be, but clearly some clarification will have to happen at some point. And many people and manufacturers are hoping for some more reasonable specs. So actually, that's one of the reasons that I think NavWorX has for still offering the cheaper non-certified GPS at this time. It allows you to get a system running at lower cost before 2020, yet is upgrade able later. And, they have plans to offer the certified GPS at lower cost later. So for us with Amateur built planes, they actually still encourage us to go with the regul! > ar ADS600B yet. > I am just glad to see people adopting it, and Amateur built is leading the way. I think it gives us all some capabilities that every airplane should have. > Tim > > >> On Dec 24, 2014, at 4:36 PM, Bob Turner wrote: >> >> >> [quote="gengrumpy"]Bob and Rene, >> >> Thanks for the replies. Im interested in your opinions on the following: >> >> 1 >> >> 3. Do you have the certified or non-certified WAAS? Ive been trying to decide which to go with as there is a pretty large price difference. >> >> 4. Any other thoughts you have on their system. >> >> Thanks - Grumpy >> >> [quote] >> >> If you intend to use or need the ADSB-out after 2020 you need to have a "certified" (e.g. meets FAR specs) gps position source. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=436131#436131 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 24, 2014
GRT has a solution: $2.2K Trig transponder controlled by HX or HXr, plus almost any ADSB-in box. You still need a position source. If you have a 4xxW or 650/750 you're all set. Tim, I agree the gps specs are overkill. But I cannot see the FAA relaxing them. The manufacturers that already have gps boxes that meet them would cry foul, there'd be legal trouble. The STC is a non issue, hopefully, for EAB. For normally certified aircraft, it's the latest battleground. The FAA has practically banned field approvals, no alteration is now minor. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436232#436232 ________________________________________________________________________________
Date: Dec 25, 2014
Some field approvals are hard to get, but field approvals for panel upgrades are done all the time. Not all panel mounted avionics are STC'ed. However, as an installer, it is much easier to do an STC installation versus a field approval. For an STC I just install per the plans and fill out a 337 form. No approval needed from anyone. Send in the form & it's done. The STC makes it easier for the installer as much as for the FAA. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 25, 2014, at 1:09 AM, Bob Turner wrote: > > > GRT has a solution: $2.2K Trig transponder controlled by HX or HXr, plus almost any ADSB-in box. You still need a position source. If you have a 4xxW or 650/750 you're all set. > > Tim, I agree the gps specs are overkill. But I cannot see the FAA relaxing them. The manufacturers that already have gps boxes that meet them would cry foul, there'd be legal trouble. > > The STC is a non issue, hopefully, for EAB. For normally certified aircraft, it's the latest battleground. The FAA has practically banned field approvals, no alteration is now minor. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436232#436232 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 25, 2014
The FAA has various conflicting advisory circulars. The one for panel mount GPS states that a simple install, such as a 430W with no interconnect to an autopilot, or any navcom or other rack mount avionics install, such as audio panel is a MINOR alteration and requires no more than a logbook entry. Installing same in experimental amateur built requires NO approval at all. Filing 337s for minor alterations just gums up the works with certified aircraft. You have stupidity piled upon multiple layers, for example where one sunshade manufacturer got an STC for something that doesn't require one. Now all others are looked at with suspicion. In fact even the STC'd item can be installed without the STC, because it is just a minor interior alteration that affects nothing about the airworthiness of the aircraft. The current AC about ADS-B in fact contradicts their own regs, in that the transponder and GPS installs are both minor alterations, and installing a single RS-232 between the two items does not change that. The FAA is just requiring the STCs and 337s to gather data to prove the install is in fact minor. JMHO as an A&P/IA. On 12/25/2014 6:19 AM, Jesse Saint wrote: > > Some field approvals are hard to get, but field approvals for panel upgrades are done all the time. Not all panel mounted avionics are STC'ed. However, as an installer, it is much easier to do an STC installation versus a field approval. For an STC I just install per the plans and fill out a 337 form. No approval needed from anyone. Send in the form & it's done. The STC makes it easier for the installer as much as for the FAA. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > >> On Dec 25, 2014, at 1:09 AM, Bob Turner wrote: >> >> >> GRT has a solution: $2.2K Trig transponder controlled by HX or HXr, plus almost any ADSB-in box. You still need a position source. If you have a 4xxW or 650/750 you're all set. >> >> Tim, I agree the gps specs are overkill. But I cannot see the FAA relaxing them. The manufacturers that already have gps boxes that meet them would cry foul, there'd be legal trouble. >> >> The STC is a non issue, hopefully, for EAB. For normally certified aircraft, it's the latest battleground. The FAA has practically banned field approvals, no alteration is now minor. >> >> -------- >> Bob Turner >> RV-10 QB >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=436232#436232 >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 25, 2014
Subject: GDL-88 (ADS-B) - On Hold??
Merry Christmas Everyone.... All the ADS-B conversation led me to ask a question I've been meaning to ask.... Does anyone know what the reasoning is for Garmin to put the GDL-88 on an engineering hold? I've heard they are currently not shipping them and I'm not sure of their reason. Anyone know anything? My panel is pre-wired for a GDL-88 to be plugged in. I called to order on the other day and found out that it was impossible. Not sure when they plan on lifting the engineering hold or what caused it. Just looking for answers if anyone has them.... Phil ________________________________________________________________________________
Date: Dec 25, 2014
Unless the installer holds Inspection Authorization or Repair Station license, the 337 must be approved by an IA confirming the install was done per the STC requirements. But that is only on type certificated aircraft. On Thu, Dec 25, 2014 at 6:19 AM, Jesse Saint wrote: > > However, as an installer, it is much easier to do an STC installation > versus a field approval. For an STC I just install per the plans and fill > out a 337 form. No approval needed from anyone. Send > > ________________________________________________________________________________
Date: Dec 25, 2014
Exactly. Jesse Saint A&P/IA I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 25, 2014, at 5:53 PM, Kelly McMullen wrote: > > Unless the installer holds Inspection Authorization or Repair Station lice nse, the 337 must be approved by an IA confirming the install was done per t he STC requirements. But that is only on type certificated aircraft. > >> On Thu, Dec 25, 2014 at 6:19 AM, Jesse Saint wr ote: >> >> However, as an installer, it is much easier to do an STC installation v ersus a field approval. For an STC I just install per the plans and fill out a 337 form. No approval needed from anyone. Send > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 25, 2014
"For ADS-B, you could confirm your location and altitude with a controller who is reading out your ADS-B info on his screen, document that in your logbook, and meet their requirements (assuming that you are using a WAAS gps)." If only it was this easy. One of the requirements on the position source is not only that it is accurate, but thru some complicated calculation it will nearly always be accurate, even with weird atmospherics or bad satellites. The "nearly always" is defined as an error less than once per very large number(I forget - ten million hours??). OTOH, if you did use "certified" equipment, this could confirm that it was installed correctly and working properly. In fact, there is an FAA web site or email address that you can send an inquiry to, and it will tell you if your ADSB-out signal agreed with radar and was otherwise all okay. Apparently there are a number of planes out there right now thinking they're all set, but they are sending out a non-comp0liance code due to some set up error. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436277#436277 ________________________________________________________________________________
Date: Dec 25, 2014
Bob Turner wrote: > " In fact, there is an FAA web site or email address that you can send an inquiry to, and it will tell you if your ADSB-out signal agreed with radar and was otherwise all okay. Apparently there are a number of planes out there right now thinking they're all set, but they are sending out a non-compliance code due to some set up error. This is the email address to have the FAA check your ADS-B "out" integrity. 9-AWA-AFS-300-ADSB-AvionicsCheck(at)faa.gov Send an email with your tail number and ask for a performance check. They will send you a report. It took me a few tries to get it working properly. I had the right equipment, but needed a software update on my 430W and had to change a couple of settings in the 430W and the 330ES. Gets a perfect report now. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436281#436281 ________________________________________________________________________________
Subject: Re: Time for Front Seats
Date: Dec 26, 2014
Just a warning. I ordered upholstery from Flight Crafters in Florida three months ago and they never sent the seats or returned my calls after cashing my check. I'm out over 1000 dollars. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436289#436289 ________________________________________________________________________________
Subject: Re: G3i Supercharging
Date: Dec 26, 2014
A few of us have the G3i electronic ignition but I don't know of anyone with the supercharger. The ignition has been working great and the support from Thomas is awesome. -------- Lenny N311LZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436300#436300 ________________________________________________________________________________
Date: Dec 26, 2014
it looks like it's + 40lbs exactly where the RV10 doesn;t need any additional weight. On Fri, Dec 26, 2014 at 9:03 PM, Lenny Iszak wrote: > > A few of us have the G3i electronic ignition but I don't know of anyone > with the supercharger. > The ignition has been working great and the support from Thomas is awesome. > > -------- > Lenny > N311LZ > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436300#436300 > > ________________________________________________________________________________
Date: Dec 27, 2014
Thats info that should be sent on the forum so others don't use them. Sorry for the info. On Fri, Dec 26, 2014 at 10:43 AM, w8n2bup wrote: > > Just a warning. I ordered upholstery from Flight Crafters in Florida three > months ago and they never sent the seats or returned my calls after cashing > my check. I'm out over 1000 dollars. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436289#436289 > > ________________________________________________________________________________
Date: Dec 27, 2014
hi Justin, thanks for the info. I will have to see if i can rendezvous with Tom some day to check out his setup. Maybe we can convince him to do a setup in a -10!!! He will be more comfy in a -10 than in the Starduster when going to Oshkosh, too! ;) Cool. Thanks for the link to the forced airmotive site. That looks interesting. They have addressed CofG issues by installing gear on the back of the engine instead of on the front. Interesting that their pricing seems quite a bit more than G3i's on the face of it. Jae On 12/26/2014 11:04 PM, Justin Jones wrote: > Jae, > > I can tell you that it turns the 540 into a beast! I know Tom > personally and have seen his starduster fly with the supercharger. He > is an incredible engineer, and and his workmanship is second to none. > He has flown it to Oshkosh and done many air shows with it as well. > It is a very slick setup that works nicely. His G3i ignition is also > very well thought out. > > Be sure to look at http://www.forcedaeromotive.com/ also. It is a > different option altogether and the components they use for their kits > can be purchased on the open market for cheaper than they offer on the > website. > > Good Luck > > Justin > ________________________________________________________________________________
Date: Dec 27, 2014
230 mph 0kts, which is Van's design limit. You do not want to be cruising within 5kts of risking losing a control surface. The planes that have turbo-normalizing, etc. did the aero engineering to move the harmonic frequency to speeds they might encounter. Vans chose not to for whatever reasons. On 12/27/2014 3:45 PM, Jae Chang wrote: > > Personally, i would love to stay closer to 200 knots at altitude, > which is within design limits. More speed or altitude certainly isn't > for everyone. However, i would think having some options would be nice > for those who might have specific needs for it. For instance Beech > Bonanzas can have normalized, turbocharged, turbonormalized and maybe > supercharged engines. Cirrus has had turbocharging available for some > time, so they are probably filling a demand that is out there. I would > think having some options would be attractive to some. It just seems > the -10 is an oddball for not having similar options. As a cirrus or > bonanza owner, it's nice that they have an upgrade path, even if that > means selling their current normalized airplane for a TN or TC one. > > I know there are several other mods for the -10 to gain a few extra > knots by spending plenty of additional money and time as well. This > supercharging option however gives potentially 100's of HP gain. > > Someone created a turbine -10 but it's arguably impractical in our > airframe, at least for me. > > I'm sure someone able to take on the supercharging upgrade could > figure out the CofG issues. Lightweight composite prop? > > Jae > ________________________________________________________________________________
Subject: fuel tank senders
Date: Dec 27, 2014
I=99m about to install the stock float type fuel tank senders. The plans have you check for interference with tank structure before you close up the tank. Not an option with a quick built wing. I have carefully bent the float arms to the specs in the plans, but have not figured out a way of seeing if there is any interference in the tank, short of putting gas in (or water) and draining it out. Has anyone come up with another way to do this? I am also thinking about using Permatex, aviation form-a-gasket to seal the float flange to the tank skin instead of Proseal, in case of an interference problem necessitating removal. Has anyone done this and does it work? Chris Hukill ________________________________________________________________________________
Subject: Re: fuel tank senders
Date: Dec 27, 2014
You just have to bend it and hope for the best. Worse case, you won't read a s high as you otherwise may. The low end should still be fine. The gasket that comes with the sender can seal it. Something like you propos e can help with the gasket. If you end up with a leak you can use some Prose al around the outside. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Dec 27, 2014, at 8:23 PM, Chris Hukill wrote: > > I=99m about to install the stock float type fuel tank senders. The p lans have you check for interference with tank structure before you close up the tank. Not an option with a quick built wing. I have carefully bent the f loat arms to the specs in the plans, but have not figured out a way of seein g if there is any interference in the tank, short of putting gas in (or wate r) and draining it out. Has anyone come up with another way to do this? I am also thinking about using Permatex, aviation form-a-gasket to seal the floa t flange to the tank skin instead of Proseal, in case of an interference pro blem necessitating removal. Has anyone done this and does it work? > Chris Hukill > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Dec 27, 2014
When I installed mine in the QB wings I ended up having a little interference, which I did not find out about until I started adding fuel. I installed them with the tanks removed from the wings and tipped them upside down to see if I could here them hitting, which I did not. Maybe you can find someone with one of the dental cameras to stick in the outlet hole or snake in from the top. You can measure the resistance prior to installing them and then tip them upside down to see if the resistance values end to end are the same. I used Permatex non-hardening, which I have used before for this purpose. I only will use the cork gaskets. I have never had any leaks using this method. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436345#436345 ________________________________________________________________________________
Subject: Faston grounding strip
Date: Dec 27, 2014
I'm wondering if there is a need for a faston multipoint grounding strip on the engine side of the firewall if using the Garmin engine monitoring kit. Do the EGT, CHT, etc probes need a discrete ground for each? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436347#436347 ________________________________________________________________________________
Subject: Re: Faston grounding strip
Date: Dec 28, 2014
Most EFIS vendor supplied harness will have a ground wire in the bundle going back to the EFIS if required. Both egt and cht cables are two conductor and terminate at the EFIS. Besides the engine and alternator grounds which can't use faston connectors, I think I only had a couple faston connectors used for grounding. It really will depend on what devices you've installed forward of the firewall. I used a B&C forest of tabs with tabs on both side of the firewall. The cabin side is 100% full and the engine side only has a couple used. Sent from my iPad > On Dec 27, 2014, at 11:56 PM, bob88 wrote: > > > I'm wondering if there is a need for a faston multipoint grounding strip on the engine side of the firewall if using the Garmin engine monitoring kit. Do the EGT, CHT, etc probes need a discrete ground for each? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436347#436347 > > > > > > > > > > ________________________________________________________________________________
From: Michael Kraus <n223rv(at)wolflakeairport.net>
Date: Dec 28, 2014
I too used the B&C Forrest of tabs, but I only used it on the interior of the plane. I think there were 2-4 grounds I needed FWF and I just ran them back into the interior. -Mike Kraus RV-4 sold RV-10 flying KitFox under construction Sent from my iPhone > On Dec 28, 2014, at 5:38 AM, Bob Leffler wrote: > > > Most EFIS vendor supplied harness will have a ground wire in the bundle going back to the EFIS if required. Both egt and cht cables are two conductor and terminate at the EFIS. > > Besides the engine and alternator grounds which can't use faston connectors, I think I only had a couple faston connectors used for grounding. It really will depend on what devices you've installed forward of the firewall. > > I used a B&C forest of tabs with tabs on both side of the firewall. The cabin side is 100% full and the engine side only has a couple used. > > Sent from my iPad > >> On Dec 27, 2014, at 11:56 PM, bob88 wrote: >> >> >> I'm wondering if there is a need for a faston multipoint grounding strip on the engine side of the firewall if using the Garmin engine monitoring kit. Do the EGT, CHT, etc probes need a discrete ground for each? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=436347#436347 > > > > > ________________________________________________________________________________
Date: Dec 28, 2014
thanks guys Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436356#436356 ________________________________________________________________________________
Date: Dec 28, 2014
I played with that a lot until I got it to work right. Also my fuel vent B-nut was leaking on one tank, so i had to remove the sender again. I've heard of that happening to so many people with quickbuilt tanks that I probably wouldn't even proseal in the sender until i put a wrench on that b-nut. First measure the resistance of the sender with the arm up and down to see what the maximum travel is both ways. Insert a loop of a 24 ga tefzel wire through the top hole of the sender and wrap it around the sender arm in a way that when you pull on the wire it will move the arm up until it tops out on the skin of the tank. Put in the sender, thread in all the screws except the top one with the wire. Connect your ohm meter and see if you get close to full travel. The original rubber gasket that comes with the sender ends up leaking over time, so you can skip using that and just use proseal around the sender plate and the screws. You can later remove the proseal with an acrylic scraper from Spruce # 12-03310. Cuts nicely and it doesn't scratch the aluminum rib under the sender plate. Use it as a blade to cut the proseal instead of scraping it. The last time I removed mine I got tired of the proseal and used screws with integrated viton o-rings (mcmaster #90825A387) and a viton gasket (http://www.amazon.com/gp/product/B0075EBPKS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). No leaks so far for the last 7 months or so. At some dumb moment I forgot to put the last 90 degree bend in the float arm wire, and when I put fuel in the tank the arm twisted in the plastic and dropped to the bottom of the tank measuring zero fuel... luckily i got back some of my self respect when i found out on one of the forums that someone else did the same... Not a lot of fun when on your third flight the fuel in one tank drops to zero. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436364#436364 ________________________________________________________________________________
Subject: Re: Holes in the Landing Gear Mounts
Date: Dec 28, 2014
Another problem with those holes...I can't get them to line up with the holes in the seat rail and seat bottom. The mid seat rail supports are bolted into the landing gear mount (after much frustration) but they are half a hole too far forward. Can't move them back because the rear flanges on the mid seat rail supports are right up against the landing gear mount and it would be necessary to elongate the holes in the bottom of the mid seat rail support in any case. Anyone else with this problem? Solutions? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436371#436371 ________________________________________________________________________________
Date: Dec 28, 2014
I always wonder about these folks that think you can just add a 100 or more horsepower to an airframe and figure there will be no issues... Seems to me that they didn't ask themselves what their mission profile was before they chose the -10. If you want to fly in the flight levels at speeds greater than 200 KTAS, then the -10 is probably not the aircraft for your mission. Why try and make it something it is not? Especially when it could very well cost you your life... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436372#436372 ________________________________________________________________________________
Subject: propellor governor
Date: Dec 31, 2014
I have a new governor from Vans (but not a Vans supplied engine). The model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436467#436467 ________________________________________________________________________________
Date: Dec 31, 2014
Subject: Re: propellor governor
Bob that's what they sent me for my IO 540. I just rotated the control arm on mine for proper alignment with the prop cable. If you're interested, search "MT P-860-3 Governor rotation" on VAF. Rick #40956 Southampton, Ont On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: > > I have a new governor from Vans (but not a Vans supplied engine). The > model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I > thought I got it for the IO 540...is the governor OK for either engine? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436467#436467 > > ________________________________________________________________________________
Subject: PlaneAround 180 Degree Centre Latch Installation Instructions
Date: Jan 01, 2015
Happy New Year to all my RV-10 colleagues, may you all have a safe flying ye ar. Could anyone please send me a link or a copy of the installation instruction s for the Plane Around 180 degree centre latch for the RV-10 doors. I just c an seem to find them! Many thanks in anticipation. Warm regards and thanks Patrick Pulis Adelaide, South Australia > On 1 Jan 2015, at 08:50, Rick Lark wrote: > > Bob that's what they sent me for my IO 540. I just rotated the control ar m on mine for proper alignment with the prop cable. If you're interested, s earch "MT P-860-3 Governor rotation" on VAF. > Rick > #40956 > Southampton, Ont > >> On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: >> >> I have a new governor from Vans (but not a Vans supplied engine). The mod el is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine? >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=436467#436467 >> >> >> >> >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 01, 2015
Subject: Re: PlaneAround 180 Degree Centre Latch Installation Instructions
sent as PM On 01.01.2015 01:55, Patrick Pulis wrote: > Happy New Year to all my RV-10 colleagues, may you all have a safe > flying year. > > Could anyone please send me a link or a copy of the installation > instructions for the Plane Around 180 degree centre latch for the RV-10 > doors. I just can seem to find them! > ________________________________________________________________________________
Date: Jan 01, 2015
Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV was built with. Of course all the engines they sell are new wide deck which is supposed to have a different gear ratio. MT P-860-5 if I recall correctly is the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders. On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark wrote: > Bob that's what they sent me for my IO 540. I just rotated the control > arm on mine for proper alignment with the prop cable. If you're > interested, search "MT P-860-3 Governor rotation" on VAF. > Rick > #40956 > Southampton, Ont > > On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: > >> >> I have a new governor from Vans (but not a Vans supplied engine). The >> model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I >> thought I got it for the IO 540...is the governor OK for either engine? >> >> >> >> >> ________________________________________________________________________________
Date: Jan 01, 2015
As Kelly says the P-860-3 fits the narrow deck engine, which is what mine is . Rick Sent from my iPad > On Jan 1, 2015, at 10:26 AM, Kelly McMullen wrote: > > Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV w as built with. Of course all the engines they sell are new wide deck which i s supposed to have a different gear ratio. MT P-860-5 if I recall correctly i s the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders. > >> On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark wrote: >> Bob that's what they sent me for my IO 540. I just rotated the control a rm on mine for proper alignment with the prop cable. If you're interested, s earch "MT P-860-3 Governor rotation" on VAF. >> Rick >> #40956 >> Southampton, Ont >> >>> On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: >>> >>> I have a new governor from Vans (but not a Vans supplied engine). The mo del is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine? > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 01, 2015
Well, I bought the Hartzel governor directly from Vans, and it works fine. [quote="Kelly McMullen"]Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV was built with. Of course all the engines they sell are new wide deck which is supposed to have a different gear ratio. MT P-860-5 if I recall correctly is the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders. On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark wrote: > Bob that's what they sent me for my IO 540. I just rotated the control arm on mine for proper alignment with the prop cable. If you're interested, search "MT P-860-3 Governor rotation" on VAF. > Rick > #40956 > Southampton, Ont > > > On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: > > > > > I have a new governor from Vans (but not a Vans supplied engine). The model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine? > > > > > > > > > > > > > > > > > > > > > > [b] -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436518#436518 ________________________________________________________________________________
Date: Jan 01, 2015
Well, the question was concerning the MT P-860-3. I don't know how Hartzell deals with the differing gear ratio (gears) inside the Lycoming narrow deck vs wide deck. Until about 3-4 years ago Vans only offered the MT P-860-3. On 1/1/2015 9:04 PM, Bob Turner wrote: > > Well, I bought the Hartzel governor directly from Vans, and it works fine. > > [quote="Kelly McMullen"]Nice to see that nothing has changed at Van's. They only sell the governor with the gear ratio for the narrow deck engine, because that is what 410RV was built with. Of course all the engines they sell are new wide deck which is supposed to have a different gear ratio. MT P-860-5 if I recall correctly is the correct one and only needs some repositioning of the arm, depending on whether you run the cable below or above the cylinders. > > On Wed, Dec 31, 2014 at 3:20 PM, Rick Lark wrote: > >> Bob that's what they sent me for my IO 540. I just rotated the control arm on mine for proper alignment with the prop cable. If you're interested, search "MT P-860-3 Governor rotation" on VAF. >> Rick >> #40956 >> Southampton, Ont >> >> >> On Wed, Dec 31, 2014 at 4:56 PM, bob88 wrote: >> >>> >>> I have a new governor from Vans (but not a Vans supplied engine). The model is MT P-860-3. The spec sheet says it is for a Lyc IO 360 but I thought I got it for the IO 540...is the governor OK for either engine? >>> >>> >>> >>>> >>>> >>> >> >> [b] > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436518#436518 > > ________________________________________________________________________________
Subject: New (Free) Aviation App
Date: Jan 03, 2015
"Airport Courtesy Cars" is a new Google Play/Apple iPhone app that lists over 1100 airports nationwide that have crew/courtesy cars. Make sure you search for it in the phone store, as searching from a tablet won't work. You can load it on an iPad by changing the search function in the app store from iPad apps to iPhone apps.You can dial the listing directly from the app to see if a car is available. If you have a listing that I missed, or a correction, you can email me via the app, or to airportcars101(at)gmail.com. Thanks for looking. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Driver Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436584#436584 Attachments: http://forums.matronics.com//files/appcoverpage_415.png ________________________________________________________________________________
Subject: Cabin Heat Cables
Date: Jan 03, 2015
After 500 hours I have a second cabin heat cable that has seized. Anybody else have the same problem? Is there a solution other than changing the cable. Thanks for the help... Rene' N423CF ________________________________________________________________________________
Date: Jan 03, 2015
Subject: Painting the Baffles
From: Vernon Franklin <vernon.franklin(at)gmail.com>
Are there any protective benefits to painting the baffles? Or do most just let their baffles go au naturel? Paint, clear coat, or primer? What products can take the heat and are safe to use? -- Vernon Franklin ________________________________________________________________________________
Subject: Re: Painting the Baffles
Date: Jan 04, 2015
Vernon, I had my baffles powder coated. I would do it again no question. They have stayed very nice and are easy to clean. Bob Newman N541RV From: Vernon Franklin Sent: Sunday, January 04, 2015 12:09 AM Subject: RV10-List: Painting the Baffles Are there any protective benefits to painting the baffles? Or do most just let their baffles go au naturel? Paint, clear coat, or primer? What products can take the heat and are safe to use? -- Vernon Franklin ________________________________________________________________________________
Subject: Re: Cabin Heat Cables
Date: Jan 04, 2015
Rene', An alternative to the mechanical cables is our CVS-kit. Its a linear actuator and controller that mounts to the firewall and the flapper door arm, no more push pull cable. All the details are on our web site. Here's the link to the web page for CVS-kit: http://www.tcwtech.com/control_valve_servo_kit.html Thanks, Bob Newman N541RV -----Original Message----- From: Rene Sent: Saturday, January 03, 2015 9:48 PM Subject: RV10-List: Cabin Heat Cables After 500 hours I have a second cabin heat cable that has seized. Anybody else have the same problem? Is there a solution other than changing the cable. Thanks for the help... Rene' N423CF ________________________________________________________________________________
Date: Jan 04, 2015
I second Bob. Powder coat is the way to go Geoff Combs Sent from my iPhone Geoff Combs Aerosport Modeling & Design > On Jan 4, 2015, at 7:17 AM, "Bob-tcw" wrote: > > Vernon, I had my baffles powder coated. I would do it again no quest ion. They have stayed very nice and are easy to clean. > > Bob Newman > N541RV > > > > From: Vernon Franklin > Sent: Sunday, January 04, 2015 12:09 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Painting the Baffles > > Are there any protective benefits to painting the baffles? Or do most jus t let their baffles go au naturel? > > Paint, clear coat, or primer? What products can take the heat and are saf e to use? > > -- > Vernon Franklin > > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.mypilotstore.com">www.mypilotstore.com > href="http://www.mrrace.com">www.mrrace.com > href="http://www.matronics.com/contribution">http://www.matronics.com/ch ref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.co m/Navigator?RV10-List > href="http://forums.matronics.com">http://forums.matronics.com > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: Re: Latest Parking brake victim
Date: Jan 04, 2015
I am in the final throes of finishing my RV. I have discovered the dreaded Matco parking brake leak. Can any one point me to the most probable leak source on the valve itself? I have already added del seals and thread sealant to my fittings per previous posts. Now it appears the leak is in the valve itself. I am dreading the trip back there, my ribs are still sore from the first attempt. I am tempted to fabricate a tiny drip bucket. > On Dec 16, 2014, at 9:20 AM, Bill Watson wrote: > > On 12/14/2014 10:20 PM, David Saylor wrote: >> I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days. >> >> --Dave > I've used no sealant as well as several teflon past-type sealeants as well and had both brake line and oil line leaks. I've had leaks. The Form-a-Gasket sounds like a solution - wish I found out sooner. > > While chasing the equivalent Loctite product, I finally found and used this - Permatex High Performance Thread Sealant #56521 <http://www.all-spec.com/products/56521.html?gclid=Cj0KEQiAzb-kBRDe49qh9 s75m-wBEiQATOxgwbjm5OL7j5P-fO3P5Xl_vLOYfoGKsQN5ROwKbGZbi2MaAor28P8HAQ>. This too is a solution. > > They have a half dozen similar products but this works reliably and easily on high pressure tapered fittings. Little is required, it doesn't harden, it seems to cure instantly and simply doesn't leak. It works so well in comparison to the other products, I'm not sure how it does it but does. > > On a non-aviation note: I recently had the need to fix several water line breaks (black poly pipe). The landscape guys fixed it with gray PVC push in fittings and a white PVC cap on a tapered fitting. They all leaked very slowly. They thought it was the push in barb fitting and kept putting extra and new hose clamps on it but I could see it was the white threaded cap on the gray threaded fitting. The cap would inevitably break before one could tighten it enough to stop the leak. > > One light application of #56521 and no leaks - didn't even have to cinch it down very far. And the fittings were easily removeable with no dried up sealant pieces to get clean up and keep out of sensitive systems. I've done about 6 of these now - same results. I found the same with a slow leaking oil cooler fitting on the '10. > > <http://www.aeroelectric.com/> <http://www.buildersbooks.com/> <http://www.homebuilthelp.com/> <http://www.mypilotstore.com/> <http://www.matronics.com/contribution> <http://www.matronics.com/Navigator?RV10-List> > ________________________________________________________________________________
Date: Jan 04, 2015
You might give it a little time. I'm sure the years between production and introduction of brake fluid into he valve don't do the O-rings any good. I went for Permatex high performance thread seal, which I think is a little better than your average teflon paste. I got lucky, and the sealant on the pipe threads and DEL seals on the flare fittings stopped my leakage. On Sun, Jan 4, 2015 at 3:12 PM, William DeLacey wrote: > I am in the final throes of finishing my RV. I have discovered the > dreaded Matco parking brake leak. > Can any one point me to the most probable leak source on the valve itself? > > I have already added del seals and thread sealant to my fittings per > previous posts. Now it appears the leak is in the valve itself. > I am dreading the trip back there, my ribs are still sore from the first > attempt. > > I am tempted to fabricate a tiny drip bucket. > > On Dec 16, 2014, at 9:20 AM, Bill Watson wrote: > > On 12/14/2014 10:20 PM, David Saylor wrote: > > I've pretty much given up on teflon paste-type thread sealants. I prefer > Permatex Aviation Form-A-Gasket on threads these days. > > --Dave > > I've used no sealant as well as several teflon past-type sealeants as > well and had both brake line and oil line leaks. I've had leaks. The > Form-a-Gasket sounds like a solution - wish I found out sooner. > > While chasing the equivalent Loctite product, I finally found and used > this - Permatex High Performance Thread Sealant #56521 > <http://www.all-spec.com/products/56521.html?gclid=Cj0KEQiAzb-kBRDe49qh9s75m-wBEiQATOxgwbjm5OL7j5P-fO3P5Xl_vLOYfoGKsQN5ROwKbGZbi2MaAor28P8HAQ>. > This too is a solution. > > They have a half dozen similar products but this works reliably and easily > on high pressure tapered fittings. Little is required, it doesn't harden, > it seems to cure instantly and simply doesn't leak. It works so well in > comparison to the other products, I'm not sure how it does it but does. > > On a non-aviation note: I recently had the need to fix several water line > breaks (black poly pipe). The landscape guys fixed it with gray PVC push in > fittings and a white PVC cap on a tapered fitting. They all leaked very > slowly. They thought it was the push in barb fitting and kept putting > extra and new hose clamps on it but I could see it was the white threaded > cap on the gray threaded fitting. The cap would inevitably break before > one could tighten it enough to stop the leak. > > One light application of #56521 and no leaks - didn't even have to cinch > it down very far. And the fittings were easily removeable with no dried up > sealant pieces to get clean up and keep out of sensitive systems. I've > done about 6 of these now - same results. I found the same with a slow > leaking oil cooler fitting on the '10. > > * > > class="">www.aeroelectric.com <http://www.aeroelectric.com> > href="http://www.buildersbooks.com/ " class="">www.buildersbooks.com > class="">www.homebuilthelp.com <http://www.homebuilthelp.com> > class="">www.mypilotstore.com <http://www.mypilotstore.com> > class="">www.mrrace.com <http://www.mrrace.com> > class="">http://www.matronics.com/contribution > class="">http://www.matronics.com/Navigator?RV10-List > class="">http://forums.matronics.com > > * > > > * > > > * > > ________________________________________________________________________________
Date: Jan 04, 2015
I left mine as they came from Van's. The rubber seals leave marks on the bare aluminum from vibrations and probably would on painted surfaces too. I clean the bugs off occassionally. Nobody will see in there except you and the bugs. Your red inlet plugs go in after opening the oil door for a short cool down. It is just money, time, weight and of course all yours to do as you wish. It is a great plane either way. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436637#436637 ________________________________________________________________________________
Date: Jan 04, 2015
Mine almost stuck the one day. Lubricate them and actuate them on every flight. No more issues. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436638#436638 ________________________________________________________________________________
Date: Jan 04, 2015
I have flown with my -3 for three years. It is perfect. The -3 or -5 refers to splined control arm position and max rpm adjustment. Both can be adjusted. Contact MT if you must. I already did 3 1/2 yrs ago. 1-386-736-7762. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436639#436639 ________________________________________________________________________________
Subject: Re: Heater control cables
Date: Jan 04, 2015
Same here in Ky. Below 60F OAT, you need it and it works very well. Above 90F in a 105 kt climb, I wish my SCAT was bigger. It is easy enough to lower the nose to 120 kt and it easily stays below 220F(my limit). -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436640#436640 ________________________________________________________________________________
Subject: Re: Glare screen
Date: Jan 04, 2015
My glare shield and the white tube(that is in many pics) is all flat black. I installed two 80 mm computer fans for cooling/defrosting blowing straight up on the windshield in front of you. Works great, run them on every flight. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436641#436641 ________________________________________________________________________________
Subject: Re: New Engine Questions
Date: Jan 04, 2015
I would go with the three blade Hartzell for less vibration if doing it over and I had plenty of money in the bank. Who cares about a few knots on a 3-4 hr trip. Just get to the airport 10 minutes earlier. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436642#436642 ________________________________________________________________________________
Date: Jan 05, 2015
Reports I have heard say that the two blade can be just as smooth if you get it dynamically balanced. On Sun, Jan 4, 2015 at 11:54 PM, rv10flyer wrote: > > I would go with the three blade Hartzell for less vibration if doing it > over and I had plenty of money in the bank. Who cares about a few knots on > a 3-4 hr trip. Just get to the airport 10 minutes earlier. > > -------- > Wayne G. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436642#436642 > > ________________________________________________________________________________
Date: Jan 05, 2015
A two blade can be made relatively smooth with dynamic balancing. It will not be as smooth as a balanced 3 blade. Simple physics. A six cylinder fires every 120 degrees. A three bladed prop has the blades 120 degrees apart. Same reason a 2 blade is smoother on a 4 cyl engine than a 3 blade, because a 4 cyl fires every 180 degrees. A composite prop, whether carbon fiber, or fiberglass over wood will be smoother than a metal blade, because the composite blades have some flex and absorb vibration. Composite blades allow more optimization of blade shape than is possible with metal, so they tend to have less speed difference than a metal 3 blade. I've seen many reports of 3 bladed composite giving up no detectable speed to a 2 blade metal prop. However, blades cost money, composite costs money. So 2 blade aluminum will always be your lowest cost if marketing doesn't play games. On 1/5/2015 7:32 AM, William Greenley wrote: > Reports I have heard say that the two blade can be just as smooth if > you get it dynamically balanced. > > On Sun, Jan 4, 2015 at 11:54 PM, rv10flyer > wrote: > > > > > I would go with the three blade Hartzell for less vibration if > doing it over and I had plenty of money in the bank. Who cares > about a few knots on a 3-4 hr trip. Just get to the airport 10 > minutes earlier. > > -------- > Wayne G. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436642#436642 > > > ========== > br> fts!) > r> > com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > > > * > > > * ________________________________________________________________________________
Subject: Ram air
Date: Jan 05, 2015
Anyone with experience using the Rod Bower ram air unit in place of the Vans air box and filter? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436651#436651 ________________________________________________________________________________
Date: Jan 05, 2015
Mine has been dynamically balanced and I have flown behind both props. I just did not have the funds for the upgrade. We still love our family hauler. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436652#436652 ________________________________________________________________________________
Subject: Re: Ram air
Date: Jan 05, 2015
Yes. I have one and probably wouldn't install it if I did another build. It does work as advertised, but there is no data that compares it in a standard configuration. Open it will increase manifold pressure. Closed because its using air from the cowl, it's unclear if running in a reduced power state. Sent from my iPhone On Jan 5, 2015, at 11:22 AM, bob88 wrote: Anyone with experience using the Rod Bower ram air unit in place of the Vans air box and filter? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436651#436651 ________________________________________________________________________________
Date: Jan 05, 2015
I presume there is no need for alternate air with the Bower unit as it seems to be using alternate air whenever closed in any case. Alternate air in my Cessna causes significant drop in MP relative to regular intake through the air filter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436654#436654 ________________________________________________________________________________
Date: Jan 05, 2015
The drop in MP is what I alluded to in my previous email. There are folks that believe that the use of the hotter cowl air yields a lower MP than the stand intake with a filter. I typically get 27.7 MP. Since there has been no test on the same aircraft and engine, there is no data to prove or disprove that theory. The other non-answered question is with the ram air, how much more MP is there over a standard configuration with filtered air? It is true you get about an inch of boost between closed an open, buts unclear to me if it really benefits over a standard installation. I knob that I seem to be a tad slower than Geoff's and about the same as Dana's. What is causing the differences is yet to be determined. Different air filters, fuel injection, electronic ignition, etc could also have an impact. It's just darn impossible to get the data to do a more scientific comparison. Sent from my iPhone On Jan 5, 2015, at 12:22 PM, bob88 wrote: I presume there is no need for alternate air with the Bower unit as it seems to be using alternate air whenever closed in any case. Alternate air in my Cessna causes significant drop in MP relative to regular intake through the air filter. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436654#436654 ________________________________________________________________________________
Subject: Rod Bowers Ram Air
Date: Jan 06, 2015
Marty/Bob88 I've been flying with Rod Bowers Ram Air for the last year and a half and over 170 hours. At cruise 75% power I can get an additional 1.5 inches of MP and I'm regularly getting 174 & 175K true airspeed at that power. I would install it again. I believe the quality of the components and the new scoop (my scoop is removable without removing the lower cowl) make the addition worth it. I think this installation is more robust than the stock air filter system from Van's. I don't have data on any MP loss while running through the filter but in my opinion it's not very much. The airplane performs so well on takeoff and climb with the Ram Air off that I'm not at all concerned. If I want extra power like at Lake Tahoe in the summer I just open the Ram Air on the runway and then open the throttle and the airplane seems to leap into the air. It's an amazing airplane and I've flown all the big single engine airplanes from Beech, Cessna and Piper and nothing I've flown is even close to this one. Lee Otto N326JL ________________________________________________________________________________
Subject: Re: Freeflight 1201 - Which Antenna do you use?
Date: Jan 08, 2015
Call Freeflight. Since this box carries a TSO I'd expect the TSO requires certain specified antenna(s). -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436812#436812 ________________________________________________________________________________
Subject: Seat tilt
Date: Jan 10, 2015
Has anyone made anything for the seat tilt lever to make it a little more ergonomic? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436848#436848 ________________________________________________________________________________
Subject: Re: Seat tilt
Date: Jan 12, 2015
Not really a big deal, I swapped seat levers and inverted them which works better, but maybe there's a plastic or rubber tip to finish the look and provide a small extension? -------- Dave Ford RV6 flying RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436891#436891 ________________________________________________________________________________
Subject: Heavy Duty Gas Strut Installation
Date: Jan 13, 2015
I have the original Vans supplied gas struts for the doors. Should I just install these and wait for them to fail, thereafter installing the heavy duty gas struts, or replace with the heavy duty versions from the outset? Could someone please provide the Vans part number for the heavy duty gas struts please, or is there an alternative supplier? Warm regards from downunder Patrick ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Jan 12, 2015
Great idea! Wish I had thought of it before! Sent from my iPhone > On Jan 12, 2015, at 11:42 AM, rvdave wrote: > > > Not really a big deal, I swapped seat levers and inverted them which works better, but maybe there's a plastic or rubber tip to finish the look and provide a small extension? > > -------- > Dave Ford > RV6 flying > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436891#436891 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: Heavy Duty Gas Strut Installation
Date: Jan 12, 2015
Just search the "list" for struts and it will be obvious. There are other sources that are less expensive, but I can't comment on shipping down under. Sent from my iPhone On Jan 12, 2015, at 2:39 PM, Patrick Pulis wrote: I have the original Vans supplied gas struts for the doors. Should I just install these and wait for them to fail, thereafter installing the heavy duty gas struts, or replace with the heavy duty versions from the outset? Could someone please provide the Vans part number for the heavy duty gas struts please, or is there an alternative supplier? Warm regards from downunder Patrick ________________________________________________________________________________
Date: Jan 12, 2015
I have the standard issue Van's struts that have been installed for about three years. I have been flying since May for about 125 hours. My doors are heavier than most as I have the cavities insulated, an armrest, and Sean's door system, and even in breezes, I have yet to have a door come down unexpectedly. If/when they do fail, I will probably upgrade to the higher compression system, but in the meantime I have no complaints about the originals. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436907#436907 ________________________________________________________________________________
Date: Jan 12, 2015
I would try the supplied struts first. I haven't had any issue with the supplied struts, but I think it depends on how much extra "stuff" is applied to the door interior. -Sean #40303 (waiting for my paint slot to open up) > Patrick Pulis > January 12, 2015 at 1:39 PM > > I have the original Vans supplied gas struts for the doors. Should I > just install these and wait for them to fail, thereafter installing > the heavy duty gas struts, or replace with the heavy duty versions > from the outset? > > Could someone please provide the Vans part number for the heavy duty > gas struts please, or is there an alternative supplier? > > > Warm regards from downunder > > Patrick > > ________________________________________________________________________________
Date: Jan 12, 2015
I agree. If you own them, you may as well use them for now. I've got the same ones on that Van's sent me in what, 2005?? And they're still working out. I think in the last year they are weakening a little, but 9 years of flying for almost 1100 hours will do that I guess. I have fabric applied to the door, so heavier materials may make it worse and lighter materials or no materials may make it better. I did paint the doors before applying fabric. So, you may as well try them. Tim On 1/12/2015 3:06 PM, Sean Stephens wrote: > > I would try the supplied struts first. I haven't had any issue with the > supplied struts, but I think it depends on how much extra "stuff" is > applied to the door interior. > > -Sean #40303 (waiting for my paint slot to open up) > ________________________________________________________________________________
Date: Jan 12, 2015
As time mentioned, the stock struts will work fine for you for a while if your door isn't built extra heavy. I have seen some doors that were so heavy the new standard struts wouldn't hold them open. On the other hand, I have seen strut brackets broken because the heavy duty strut was installed on a light-weight door and constantly slamming open eventually broke the bracket. The heavy duty struts on a standard door will open the door from all the way closed if it is unlatched. I don't like that. I want the door to open all the way when I lift it by hand, but I like to be able to lower it and have it stay down even if I don't latch it. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 > On Jan 12, 2015, at 4:25 PM, Tim Olson wrote: > > > I agree. If you own them, you may as well use them for now. I've got > the same ones on that Van's sent me in what, 2005?? And they're still > working out. I think in the last year they are weakening a little, > but 9 years of flying for almost 1100 hours will do that I guess. > I have fabric applied to the door, so heavier materials may make > it worse and lighter materials or no materials may make it better. > I did paint the doors before applying fabric. > > So, you may as well try them. > > Tim > > > > On 1/12/2015 3:06 PM, Sean Stephens wrote: >> >> I would try the supplied struts first. I haven't had any issue with the >> supplied struts, but I think it depends on how much extra "stuff" is >> applied to the door interior. >> >> -Sean #40303 (waiting for my paint slot to open up) >> > > > > ________________________________________________________________________________
Date: Jan 12, 2015
I agree with using the stock struts and see how they work for you. I have had stock struts since the beginning. My doors have the Iflyrv10.com flush door handles that probably add a little bit of weight, but not much. The originals lasted about 5 years and 600 hours and then started getting just a bit weak in cold conditions. They were OK in warm conditions. I ordered new stock struts from Van's a couple of years ago and replaced them at the next condition inspection. They are doing fine. I agree with Jesse in that I don't want to have a door that will not stay down when not latched nor one that springs up aggressively when unlatched. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436922#436922 ________________________________________________________________________________
Date: Jan 12, 2015
Tim said what I was thinking. If you've already bought them, then get the useful life out of them. You've paid for it already. Then order some HD's when you need them later on. My standard ones lasted about 2.5 years and I'm replacing them this week. On Mon, Jan 12, 2015 at 3:40 PM, Jesse Saint wrote: > > As time mentioned, the stock struts will work fine for you for a while if > your door isn't built extra heavy. I have seen some doors that were so > heavy the new standard struts wouldn't hold them open. On the other hand, I > have seen strut brackets broken because the heavy duty strut was installed > on a light-weight door and constantly slamming open eventually broke the > bracket. The heavy duty struts on a standard door will open the door from > all the way closed if it is unlatched. I don't like that. I want the door > to open all the way when I lift it by hand, but I like to be able to lower > it and have it stay down even if I don't latch it. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On Jan 12, 2015, at 4:25 PM, Tim Olson wrote: > > > > > > I agree. If you own them, you may as well use them for now. I've got > > the same ones on that Van's sent me in what, 2005?? And they're still > > working out. I think in the last year they are weakening a little, > > but 9 years of flying for almost 1100 hours will do that I guess. > > I have fabric applied to the door, so heavier materials may make > > it worse and lighter materials or no materials may make it better. > > I did paint the doors before applying fabric. > > > > So, you may as well try them. > > > > Tim > > > > > > > > On 1/12/2015 3:06 PM, Sean Stephens wrote: > >> > >> I would try the supplied struts first. I haven't had any issue with the > >> supplied struts, but I think it depends on how much extra "stuff" is > >> applied to the door interior. > >> > >> -Sean #40303 (waiting for my paint slot to open up) > >> > > > > > > > > > > ________________________________________________________________________________
Date: Jan 12, 2015
Mine didn't even last till first flight. Bought 600N struts from Bansbach. E2A1F50-100-290/600N. Linn On 1/12/2015 7:58 PM, Phillip Perry wrote: > Tim said what I was thinking. If you've already bought them, then get > the useful life out of them. You've paid for it already. Then order > some HD's when you need them later on. > > My standard ones lasted about 2.5 years and I'm replacing them this week. > > On Mon, Jan 12, 2015 at 3:40 PM, Jesse Saint > wrote: > > > > > As time mentioned, the stock struts will work fine for you for a > while if your door isn't built extra heavy. I have seen some doors > that were so heavy the new standard struts wouldn't hold them > open. On the other hand, I have seen strut brackets broken because > the heavy duty strut was installed on a light-weight door and > constantly slamming open eventually broke the bracket. The heavy > duty struts on a standard door will open the door from all the way > closed if it is unlatched. I don't like that. I want the door to > open all the way when I lift it by hand, but I like to be able to > lower it and have it stay down even if I don't latch it. > > Jesse Saint > Saint Aviation, Inc. > jesse(at)saintaviation.com > C: 352-427-0285 > F: 815-377-3694 > > > On Jan 12, 2015, at 4:25 PM, Tim Olson wrote: > > > > > > > > I agree. If you own them, you may as well use them for now. > I've got > > the same ones on that Van's sent me in what, 2005?? And they're > still > > working out. I think in the last year they are weakening a little, > > but 9 years of flying for almost 1100 hours will do that I guess. > > I have fabric applied to the door, so heavier materials may make > > it worse and lighter materials or no materials may make it better. > > I did paint the doors before applying fabric. > > > > So, you may as well try them. > > > > Tim > > > > > > > > On 1/12/2015 3:06 PM, Sean Stephens wrote: > > > >> > >> I would try the supplied struts first. I haven't had any issue > with the > >> supplied struts, but I think it depends on how much extra > "stuff" is > >> applied to the door interior. > >> > >> -Sean #40303 (waiting for my paint slot to open up) > >> > > > > > > > > > > > ========== > br> fts!) > r> > com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jan 13, 2015
I had the same problem as Linn. The second I put the windows in the doors, the struts were no longer strong enough to hold the doors open. Both of my struts failed in this way. Van's just shrugged it off, and tried to sell me the heavy duty struts for $130 each. I went with Bansbach. Very quick turn around time. easylift.com Item #: AF051-077 Part Description: A1A1F50-100-287/600N $48 each. On Mon, Jan 12, 2015 at 7:22 PM, Linn Walters wrote: > Mine didn't even last till first flight. Bought 600N struts from > Bansbach. E2A1F50-100-290/600N. > Linn > > > On 1/12/2015 7:58 PM, Phillip Perry wrote: > > Tim said what I was thinking. If you've already bought them, then get the > useful life out of them. You've paid for it already. Then order some HD's > when you need them later on. > > My standard ones lasted about 2.5 years and I'm replacing them this week. > > On Mon, Jan 12, 2015 at 3:40 PM, Jesse Saint > wrote: > >> >> As time mentioned, the stock struts will work fine for you for a while if >> your door isn't built extra heavy. I have seen some doors that were so >> heavy the new standard struts wouldn't hold them open. On the other hand, I >> have seen strut brackets broken because the heavy duty strut was installed >> on a light-weight door and constantly slamming open eventually broke the >> bracket. The heavy duty struts on a standard door will open the door from >> all the way closed if it is unlatched. I don't like that. I want the door >> to open all the way when I lift it by hand, but I like to be able to lower >> it and have it stay down even if I don't latch it. >> >> Jesse Saint >> Saint Aviation, Inc. >> jesse(at)saintaviation.com >> C: 352-427-0285 >> F: 815-377-3694 >> >> > On Jan 12, 2015, at 4:25 PM, Tim Olson >> wrote: >> > >> > >> > I agree. If you own them, you may as well use them for now. I've got >> > the same ones on that Van's sent me in what, 2005?? And they're still >> > working out. I think in the last year they are weakening a little, >> > but 9 years of flying for almost 1100 hours will do that I guess. >> > I have fabric applied to the door, so heavier materials may make >> > it worse and lighter materials or no materials may make it better. >> > I did paint the doors before applying fabric. >> > >> > So, you may as well try them. >> > >> > Tim >> > >> > >> > >> > On 1/12/2015 3:06 PM, Sean Stephens wrote: >> > >> >> >> >> I would try the supplied struts first. I haven't had any issue with >> the >> >> supplied struts, but I think it depends on how much extra "stuff" is >> >> applied to the door interior. >> >> >> >> -Sean #40303 (waiting for my paint slot to open up) >> >> >> > >> > >> > >> > >> >> >> >> ========== >> br> fts!) >> r> > com" target="_blank">www.aeroelectric.com >> w.buildersbooks.com" target="_blank">www.buildersbooks.com >> p.com" target="_blank">www.homebuilthelp.com >> e.com" target="_blank">www.mypilotstore.com >> " target="_blank">www.mrrace.com >> target="_blank">http://www.matronics.com/contribution >> -Matt Dralle, List Admin. >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> >> >> >> > > > No virus found in this message. > Checked by AVG - www.avg.com > 01/12/15 > > > * > > > * > > -- Vernon Franklin ________________________________________________________________________________
Date: Jan 13, 2015
Tim, since yours have lasted so long.... do you leave the doors in the open position when the plane is hangared?=C2- I try to do this as I think it helps the seals.Don McDonald From: "dmaib(at)me.com" <dmaib(at)me.com> To: rv10-list(at)matronics.com Sent: Monday, January 12, 2015 4:03 PM Subject: RV10-List: Re: Heavy Duty Gas Strut Installation I agree with using the stock struts and see how they work for you. I have h ad stock struts since the beginning. My doors have the Iflyrv10.com flush d oor handles that probably add a little bit of weight, but not much. The ori ginals lasted about 5 years and 600 hours and then started getting just a b it weak in cold conditions. They were OK in warm conditions. I ordered new stock struts from Van's a couple of years ago and replaced them at the next condition inspection. They are doing fine. I agree with Jesse in that I do n't want to have a door that will not stay down when not latched nor one th at springs up aggressively when unlatched. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436922#436922 =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S - ________________________________________________________________________________
Date: Jan 13, 2015
Hi Don, Yeah, generally I do. My hangar is sealed up pretty well and I don't get birds or even much dust in it. So I leave the doors open. I have closed them for extended periods a bunch of times, mind you, but in general I leave them open. I'm not sure why mine have lasted so long, but they have. I'm sure I've got more hours left in them. Tim On 1/13/2015 8:56 AM, Don McDonald wrote: > Tim, since yours have lasted so long.... do you leave the doors in the > open position when the plane is hangared? I try to do this as I think > it helps the seals. > Don McDonald > ________________________________________________________________________________
Date: Jan 13, 2015
Don that's a good thought about leaving them open. Mine lasted about 2 yrs. a nd then they would barely hold the doors open. My doors had no fabric or ad ditional Locks at that time also. Heavy duty Were much better. As Tim said use the stock ones till they drop Geoff Sent from my iPhone Geoff Combs Aerosport Modeling & Design > On Jan 13, 2015, at 9:56 AM, Don McDonald wro te: > > Tim, since yours have lasted so long.... do you leave the doors in the ope n position when the plane is hangared? I try to do this as I think it helps the seals. > Don McDonald > > From: "dmaib(at)me.com" <dmaib(at)me.com> > To: rv10-list(at)matronics.com > Sent: Monday, January 12, 2015 4:03 PM > Subject: RV10-List: Re: Heavy Duty Gas Strut Installation > > > I agree with using the stock struts and see how they work for you. I have h ad stock struts since the beginning. My doors have the Iflyrv10.com flush do or handles that probably add a little bit of weight, but not much. The origi nals lasted about 5 years and 600 hours and then started getting just a bit w eak in cold conditions. They were OK in warm conditions. I ordered new stock struts from Van's a couple of years ago and replaced them at the next condi tion inspection. They are doing fine. I agree with Jesse in that I don't wan t to have a door that will not stay down when not latched nor one that sprin gs up aggressively when unlatched. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.phref="http://www.matronics.com/co ntribution" target="_blank">http://wwwp; -Matt DraList" t arget="_blank">http://www.matronics.com/Navigator?RV10-Listhttp://forums.m atron================== > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 13, 2015
my standard struts lasted 4 years and still were ok unless i put the stratus 2 on them. so i replaced them with the heavy-duty ones. alan n668g > On Jan 12, 2015, at 5:03 PM, dmaib(at)me.com wrote: > > > I agree with using the stock struts and see how they work for you. I have had stock struts since the beginning. My doors have the Iflyrv10.com flush door handles that probably add a little bit of weight, but not much. The originals lasted about 5 years and 600 hours and then started getting just a bit weak in cold conditions. They were OK in warm conditions. I ordered new stock struts from Van's a couple of years ago and replaced them at the next condition inspection. They are doing fine. I agree with Jesse in that I don't want to have a door that will not stay down when not latched nor one that springs up aggressively when unlatched. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=436922#436922 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 14, 2015
Thanks for the great advice and shared experience once again guys. I'm seeing a progressive end to this project (finally) and hope to meet most of you during my travels to Oshkosh this coming July. Thanks for all your help over the years. Warm regards Patrick > On 14 Jan 2015, at 01:58, Alan Mekler MD wrote: > > > my standard struts lasted 4 years and still were ok unless i put the stratus 2 on them. so i replaced them with the heavy-duty ones. > alan > n668g >> On Jan 12, 2015, at 5:03 PM, dmaib(at)me.com wrote: >> >> >> I agree with using the stock struts and see how they work for you. I have had stock struts since the beginning. My doors have the Iflyrv10.com flush door handles that probably add a little bit of weight, but not much. The originals lasted about 5 years and 600 hours and then started getting just a bit weak in cold conditions. They were OK in warm conditions. I ordered new stock struts from Van's a couple of years ago and replaced them at the next condition inspection. They are doing fine. I agree with Jesse in that I don't want to have a door that will not stay down when not latched nor one that springs up aggressively when unlatched. >> >> -------- >> David Maib >> RV-10 #40559 >> New Smyrna Beach, FL >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=436922#436922 > > > > > > ________________________________________________________________________________
Date: Jan 13, 2015
I actually had to start closing the doors. I kept finding dead flying crit ters in the cabin. I still have a problem with flies in the hangar. It's kind of funny to watch flies that barely have enough energy to fly a foot o r two. I'm hoping the single digits we had last week did them all in. Sent from my iPad > On Jan 13, 2015, at 10:15 AM, g.combs wrot e: > > Don that's a good thought about leaving them open. Mine lasted about 2 yrs . and then they would barely hold the doors open. My doors had no fabric or additional > Locks at that time also. Heavy duty > Were much better. > As Tim said use the stock ones till they drop > > Geoff > > Sent from my iPhone > Geoff Combs > Aerosport Modeling & Design > > > > >> On Jan 13, 2015, at 9:56 AM, Don McDonald wr ote: >> >> Tim, since yours have lasted so long.... do you leave the doors in the op en position when the plane is hangared? I try to do this as I think it help s the seals. >> Don McDonald >> >> From: "dmaib(at)me.com" <dmaib(at)me.com> >> To: rv10-list(at)matronics.com >> Sent: Monday, January 12, 2015 4:03 PM >> Subject: RV10-List: Re: Heavy Duty Gas Strut Installation >> >> >> I agree with using the stock struts and see how they work for you. I have had stock struts since the beginning. My doors have the Iflyrv10.com flush d oor handles that probably add a little bit of weight, but not much. The orig inals lasted about 5 years and 600 hours and then started getting just a bit weak in cold conditions. They were OK in warm conditions. I ordered new sto ck struts from Van's a couple of years ago and replaced them at the next con dition inspection. They are doing fine. I agree with Jesse in that I don't w ant to have a door that will not stay down when not latched nor one that spr ings up aggressively when unlatched. >> >> -------- >> David Maib >> RV-10 #40559 >> New Smyrna Beach, FL >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.phref="http://www.matronics.com/c ontribution" target="_blank">http://wwwp; -Matt DraList" target="_blank">http://www.matronics.com/Navigator?RV10-Listhttp://forums .matron================== >> >> >> >> >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">www.aeroelectric.com >> books.com"">www.buildersbooks.com >> quot;">www.homebuilthelp.com >> quot;">www.mypilotstore.com >> ">www.mrrace.com >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> List"">http://www.matronics.com/Navigator?RV10-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jan 14, 2015
I have 5 years flying on my stock struts and will be replacing them this spring during my inspection. I keep the doors closed due to dust and to help discourage mud dobbers. -------- Gary Blankenbiller RV10 - # 40674 (N2GB Flying) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=436986#436986 ________________________________________________________________________________
Subject: FS: Flap Position System
Date: Jan 15, 2015
ES FLAP POS SWV 10 --- purchased but will not be using. Never installed, still in box. Box has hangar rash but never hooked up or removed from box. Hardware and instructions included. Vans price is $225. I will ship CONUS for $200. Dave Ford Contact rv610dave(at)gmail.com -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437075#437075 ________________________________________________________________________________
Date: Jan 16, 2015
Subject: "Jesus Bolt" list?
Hey Everyone. I'm getting towards the end of the build, and I've started thinking of the final inspections. Has anyone compiled a list of the so called "Jesus Bolts" that are flight critical single points of failure? Like the nuts and bolts that connect the ball end joints on the elevator pushrods? I was just rereading about the -10 that lost elevator control while landing and smashed up the nose pretty badly... due to either losing or never having a nut on one of these bolts. It would be great to have a piece of paper to use as a checklist while doing those final inspections before first flight, the extensive inspections during phase 1, and continuing yearly inspections. If no one has a specific list, I'd be happy to create an online spreadsheet that we all could contribute too. ________________________________________________________________________________
Date: Jan 16, 2015
Subject: Re: "Jesus Bolt" list?
You're farther along than I am .... I have another year (been saying that for 4 months now) to build, and can't answer your question. However, in lieu of a 'Jesus bolt list', I've been making sure that every fastener necessary for safe flight has yellow torque seal visible before I close up that area. My 'list' includes nuts/bolts, B nuts, cotter pins and safety wire. The torque seal goes on right after I've tightened the fastener ..... and if the torque seal is missing (because I messed up) the fastener gets re-tightened, not just checked off because 'I know it got tightened'. Great idea though ..... sorry I can't contribute to a 'list'. Linn On 1/16/2015 12:53 PM, Ed Kranz wrote: > Hey Everyone. > > I'm getting towards the end of the build, and I've started thinking of > the final inspections. Has anyone compiled a list of the so called > "Jesus Bolts" that are flight critical single points of failure? Like > the nuts and bolts that connect the ball end joints on the elevator > pushrods? I was just rereading about the -10 that lost elevator > control while landing and smashed up the nose pretty badly... due to > either losing or never having a nut on one of these bolts. > > It would be great to have a piece of paper to use as a checklist while > doing those final inspections before first flight, the extensive > inspections during phase 1, and continuing yearly inspections. > > If no one has a specific list, I'd be happy to create an online > spreadsheet that we all could contribute too. > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Jan 17, 2015
I think the absolute best way is to host an RVator club meeting and have ev eryone take a close look.=C2- Many eyes are better than a few.=C2- Does n't really matter how far along you are. I hosted at least 2. Don McDonald From: Ed Kranz <ed.kranz(at)gmail.com> To: rv10-list(at)matronics.com Sent: Friday, January 16, 2015 11:53 AM Subject: RV10-List: "Jesus Bolt" list? Hey Everyone. I'm getting towards the end of the build, and I've started thinking of the final inspections. Has anyone compiled a list of the so called "Jesus Bolts " that are flight critical single points of failure? Like the nuts and bolt s that connect the ball end joints on the elevator pushrods? I was just rer eading about the -10 that lost elevator control while landing and smashed u p the nose pretty badly... due to either losing or never having a nut on on e of these bolts. It would be great to have a piece of paper to use as a checklist while doin g those final inspections before first flight, the extensive inspections du ring phase 1, and continuing yearly inspections. If no one has a specific list, I'd be happy to create an online spreadsheet that we all could contribute too.=C2- ________________________________________________________________________________
Date: Jan 16, 2015
You can pretty well imagine the critical ones. All that attach flight controls and connect the individual pieces. The wing attach bolts. The vertical and horizontal stab bolts. The engine mounts and mount attach bolts. All of the gear attach bolts. Axle nuts. Any trim and autopilot servo attachments. > ------------------------------------------------------------------------ > *From:* Ed Kranz > *To:* rv10-list(at)matronics.com > *Sent:* Friday, January 16, 2015 11:53 AM > *Subject:* RV10-List: "Jesus Bolt" list? > > Hey Everyone. > > I'm getting towards the end of the build, and I've started thinking of > the final inspections. Has anyone compiled a list of the so called > "Jesus Bolts" that are flight critical single points of failure? Like > the nuts and bolts that connect the ball end joints on the elevator > pushrods? I was just rereading about the -10 that lost elevator > control while landing and smashed up the nose pretty badly... due to > either losing or never having a nut on one of these bolts. > > It would be great to have a piece of paper to use as a checklist while > doing those final inspections before first flight, the extensive > inspections during phase 1, and continuing yearly inspections. > > If no one has a specific list, I'd be happy to create an online > spreadsheet that we all could contribute too. > * > > ://www.aeroelectric.com/">www.aeroelectric.com > ref="http://www.buildersbooks.com/">www.buildersbooks.com > p://www.homebuilthelp.com/">www.homebuilthelp.com > tp://www.mypilotstore.com/">www.mypilotstore.com > ttp://www.mrrace.com/">www.mrrace.com > ronics.com/contribution">http://www.matronics.com/contribution > ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List > matronics.com/">http://forums.matronics.com > > * > > > * > > > * ________________________________________________________________________________
Date: Jan 16, 2015
Add the throttle, mixture, and prop control attach bolts. On 1/16/2015 9:37 PM, Kelly McMullen wrote: > > You can pretty well imagine the critical ones. All that attach flight > controls and connect the individual pieces. The wing attach bolts. The > vertical and horizontal stab bolts. The engine mounts and mount attach > bolts. All of the gear attach bolts. Axle nuts. Any trim and autopilot > servo attachments. >> ------------------------------------------------------------------------ >> *From:* Ed Kranz >> *To:* rv10-list(at)matronics.com >> *Sent:* Friday, January 16, 2015 11:53 AM >> *Subject:* RV10-List: "Jesus Bolt" list? >> >> Hey Everyone. >> >> I'm getting towards the end of the build, and I've started thinking >> of the final inspections. Has anyone compiled a list of the so called >> "Jesus Bolts" that are flight critical single points of failure? Like >> the nuts and bolts that connect the ball end joints on the elevator >> pushrods? I was just rereading about the -10 that lost elevator >> control while landing and smashed up the nose pretty badly... due to >> either losing or never having a nut on one of these bolts. >> >> It would be great to have a piece of paper to use as a checklist >> while doing those final inspections before first flight, the >> extensive inspections during phase 1, and continuing yearly inspections. >> >> If no one has a specific list, I'd be happy to create an online >> spreadsheet that we all could contribute too. >> * >> >> ://www.aeroelectric.com/">www.aeroelectric.com >> ref="http://www.buildersbooks.com/">www.buildersbooks.com >> p://www.homebuilthelp.com/">www.homebuilthelp.com >> tp://www.mypilotstore.com/">www.mypilotstore.com >> ttp://www.mrrace.com/">www.mrrace.com >> ronics.com/contribution">http://www.matronics.com/contribution >> ronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List >> >> matronics.com/">http://forums.matronics.com >> >> * >> >> >> * >> >> >> * > > ________________________________________________________________________________
Date: Jan 17, 2015
While I understand that the loss of some bolts can bring you closer to Jesus faster, there are no bolts that I would want to be without. Even if a bolt gone missing does not result in a control or structural failure, it can still jam a control, etc. Paying special attention to some bolts suggests that you can slack off with others. Check every bolt like your life depends on it. If you could pound 12,000 rivets (just a WAG), surely you can put a wrench on every bolt before you go flying. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437141#437141 ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Jan 17, 2015
Thank you AOPA for reviewing the Airport Courtesy Car app in the February issue on page 37. The review states the app is only available for iPhone, however that is incorrect. And thanks also to AvWeb who reviewed it earlier. The app is available for Android in the Google Play Store, so you Android users, please check it out. The app is totally free and now lists over 1100 locations nationwide. And thanks to all the folks on this forum who contributed listings. Glenn -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App www.RVairspace.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437184#437184 ________________________________________________________________________________
Date: Jan 17, 2015
Subject: Searching for a certain AirVenture vendor
Does anyone recall the name of a custom tool box vendor at AV last year? They were in one of the main display hangars along a wall, not in an aisle. Their products were custom configured rollaway type boxes, very nice stuff, made in USA. I think they took up two booths. I struck out on a search for the 2014 vendors and I'm not having any luck on the innerwebs. Shoulda kept the flyer... I'd appreciate any memory joggers! --Dave ________________________________________________________________________________
From: "Geoff Combs" <g.combs(at)aerosportmodeling.com>
Date: Jan 18, 2015
Dave I think this is who you were looking for http://www.storloc.com/ Geoff _____ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Saylor Sent: Sunday, January 18, 2015 2:52 AM Subject: RV10-List: Searching for a certain AirVenture vendor Does anyone recall the name of a custom tool box vendor at AV last year? They were in one of the main display hangars along a wall, not in an aisle. Their products were custom configured rollaway type boxes, very nice stuff, made in USA. I think they took up two booths. I struck out on a search for the 2014 vendors and I'm not having any luck on the innerwebs. Shoulda kept the flyer... I'd appreciate any memory joggers! --Dave ________________________________________________________________________________
Date: Jan 18, 2015
Subject: Re: Searching for a certain AirVenture vendor
Exactly, thanks very much Geoff. --D On Sun, Jan 18, 2015 at 6:32 PM, Geoff Combs wrote: > Dave I think this is who you were looking for > > http://www.storloc.com/ > > Geoff > > ------------------------------ > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *David Saylor > *Sent:* Sunday, January 18, 2015 2:52 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: Searching for a certain AirVenture vendor > > Does anyone recall the name of a custom tool box vendor at AV last > year? They were in one of the main display hangars along a wall, not in an > aisle. > > Their products were custom configured rollaway type boxes, very nice > stuff, made in USA. I think they took up two booths. > > I struck out on a search for the 2014 vendors and I'm not having any luck > on the innerwebs. > > Shoulda kept the flyer... > > I'd appreciate any memory joggers! > > --Dave > > * > > href="http://www.aeroelectric.com ">www.ae roelectric.com <http://www.aeroelectric.com> > href="http://www.buildersbooks.com ">www. buildersbooks.com <http://www.buildersbooks.com> > href="http://www.homebuilthelp.com ">www. homebuilthelp.com <http://www.homebuilthelp.com> > href="http://www.mypilotstore.com ">www.my pilotstore.com <http://www.mypilotstore.com> > href="http://www.mrrace.com ">www.mrrace.com > href="http://www.matronics.com/contribution ">http://www.matronics.com/chref= "http://www.matronics.com/Navigator?RV10-List ">http://www.matronics.com/Navigator?RV10-List > href="http://forums.matronics.com ">http:/ /forums.matronics.com <http://forums.matronics.com> > > * > > * > =========== m> ldersbooks.com> .com> com> om/contribution> =========== onics.com/Navigator?RV10-List> =========== =========== > > * > > ________________________________________________________________________________
Date: Jan 19, 2015
Which part of the airplane can fall off or come apart during flight? And what can you do to make sure that nothing comes apart or falls off during flight? On Saturday, January 17, 2015, Jim Berry wrote: > > > > While I understand that the loss of some bolts can bring you closer to > Jesus faster, there are no bolts that I would want to be without. Even if a > bolt gone missing does not result in a control or structural failure, it > can still jam a control, etc. > > Paying special attention to some bolts suggests that you can slack off > with others. Check every bolt like your life depends on it. If you could > pound 12,000 rivets (just a WAG), surely you can put a wrench on every bolt > before you go flying. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437141#437141 > > ________________________________________________________________________________
Subject: Taking Delivery of Quickbuild Fuse/Wings
Date: Jan 21, 2015
So my long-anticipated Quickbuild wings and fuse have arrived from the Phillipines, and will be coming out my way in the next couple weeks. Any good advice for manipulating the up to 700# crates off a truck and into a garage? Steven DeFord RivetedDragon(at)gmail.com (925) 596-0426 (cell) ________________________________________________________________________________
Date: Jan 21, 2015
A six pack and some friends! -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DeFord Sent: Wednesday, January 21, 2015 4:04 PM Subject: RV10-List: Taking Delivery of Quickbuild Fuse/Wings So my long-anticipated Quickbuild wings and fuse have arrived from the Phillipines, and will be coming out my way in the next couple weeks. Any good advice for manipulating the up to 700# crates off a truck and into a garage? Steven DeFord RivetedDragon(at)gmail.com (925) 596-0426 (cell) ________________________________________________________________________________
Date: Jan 21, 2015
Subject: Re: Taking Delivery of Quickbuild Fuse/Wings
What Bob said and request a lift gate on the delivery truck. On 1/21/2015 4:24 PM, Bob Leffler wrote: > > A six pack and some friends! > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Steven DeFord > Sent: Wednesday, January 21, 2015 4:04 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Taking Delivery of Quickbuild Fuse/Wings > > > So my long-anticipated Quickbuild wings and fuse have arrived from the > Phillipines, and will be coming out my way in the next couple weeks. Any > good advice for manipulating the up to 700# crates off a truck and into a > garage? > > Steven DeFord > RivetedDragon(at)gmail.com > (925) 596-0426 (cell) > > -- Lyle Sent from my Gateway E4610D desktop ________________________________________________________________________________
Date: Jan 21, 2015
Request a lift gate. Rent a fork lift. If you have smooth areas like a garage or hangar floors, lengths of 2" schedule 40 PVC pipe (the thick stuff, I do get them backwards some times) so you can roll to their final destination will work. Just remember to roll 'sideways' since there are 2X4s under the crate so a fork lift can get under them. I used the PVC pipe and furniture dolly's from Harbor freight for mine. Linn On 1/21/2015 4:04 PM, Steven DeFord wrote: > > So my long-anticipated Quickbuild wings and fuse have arrived from the Phillipines, and will be coming out my way in the next couple weeks. Any good advice for manipulating the up to 700# crates off a truck and into a garage? > > Steven DeFord > RivetedDragon(at)gmail.com > (925) 596-0426 (cell) > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Jan 22, 2015
AMF delivered mine last month. The local rep said they would "put the crates on the ground" for me. A large flat bed truck arrived with a heavy duty fork lift on the back. Perhaps your carrier will do something similar. -------- RV-10 UC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437451#437451 ________________________________________________________________________________
Date: Jan 22, 2015
One caveat... Are you using Tony Partain, or somebody like him that personally delivers it? The reason I ask is that Van discounted the shipping by $400 each time (I did two different orders) if Tony delivered them. That amounted to no crates for the finished wings, and the actual fuselage. The canopy and windshield also came uncrated. It actually made it a little easier. I had already built a wing stand, so we put them straight into the stand. The loose parts all went on tables or the ground. There were still several crates with parts on each delivery. The suggestion that you get helpers is a good idea. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437453#437453 ________________________________________________________________________________
Date: Jan 22, 2015
Dave, Out of curiosity, how much do those things cost? I went to their web site, and they look on the expensive side.... John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437454#437454 ________________________________________________________________________________
Date: Jan 22, 2015
I looked at them extensively at AirVenture and I thought they were fairly reasonable. They're not Harbor Freight reasonable but they're also built considerably better. It's hard to throw out a price because they have so many different units and set-ups and you can customize them. To show off their strength they would fully open a drawer and then stand in it. I don't think I'd try that with an HF unit. --Rick On 01/22/2015 08:18 AM, johngoodman wrote: > > > Dave, Out of curiosity, how much do those things cost? I went to > their web site, and they look on the expensive side.... > > John > ________________________________________________________________________________
Date: Jan 22, 2015
> I looked at them extensively at AirVenture and I thought they were > fairly reasonable. They're not Harbor Freight reasonable but they're > also built considerably better. It's hard to throw out a price because > they have so many different units and set-ups and you can customize > them. To show off their strength they would fully open a drawer and then > stand in it. I don't think I'd try that with an HF unit. > > --Rick Rick, Would you say closer to a Craftsman unit? John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437461#437461 ________________________________________________________________________________
Date: Jan 22, 2015
Steve, I see by your area code that you are in the SF bay area. Have you considered flying to Portland (commercial), renting a U haul, and driving back? This is or at least was the least expensive option. I did it all in one long day (arrived home at 1 am). No crating charge, Vans will load tbe U haul for you, get friends to help unload. Have wing stands ready. One way drop off charge is less expensive if you return the truck to an east bay location as opposed to San Francisco. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437480#437480 ________________________________________________________________________________
Date: Jan 23, 2015
Ed My advice is invite some RV builders and assign each one a system to inspect, like controls. Then have some one inspect sections like one wing. Mike -------- RV-10 builder (flying) #511 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437521#437521 ________________________________________________________________________________
Date: Jan 23, 2015
tgmeyerster(at)gmail.com wrote: > Which part of the airplane can fall off or come apart during flight? And what can you do to make sure that nothing comes apart or falls off during flight? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437141#437141 (http://forums.matronics.com/viewtopic.php?p=437141#437141) > > > As I have reported previously, I was shooting practice approaches to minimums when the pinch bolt that holds the fab to the throttle body loosened. This allowed the fab to drop to the bottom of the cowl and slide aft. When I went full throttle at the missed, engine suction pulled the fab up to the throttle body, blanking airflow and killing the engine. > > Fortunately we were over the threshold at that point and landed long. If the bolt had let go at most any other time, the outcome may have been different. > > Turns out that this has happened to several RVs. My solution was to install a strut brace from the throttle body to the fab. > > So, which bolt would you like to do without? > > > > > ========== > br> fts!) > r> > com" target="_blank">www.aeroelectric.com > w.buildersbooks.com" target="_blank">www.buildersbooks.com > p.com" target="_blank">www.homebuilthelp.com > e.com" target="_blank">www.mypilotstore.com > " target="_blank">www.mrrace.com > target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > > > > [b] Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437525#437525 ________________________________________________________________________________
Date: Jan 23, 2015
I went to Harbor Frieght and got one each of their large and small moving dollies. I then joined them together about three feet apart with 2 2x2 rails. The contraption made for a nice crate dolly and later by adding styrofoam blocks as needed to the small dolly, a great fuselage dolly. It was moveable around the shop and a nice height for wiring, interior painting, etc -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437526#437526 ________________________________________________________________________________
Date: Jan 23, 2015
When I recently moved I needed to move a large gun safe. It is a 7' tall and 4' wide by 4' deep fire rated safe. Heavy doesn't begin to describe it. I went to Lowes and purchased the largest casters they had. (5 inch locking Waxman rubber swivel casters) http://m.lowes.com/pd/Waxman-5-in-Rubber-Swivel-Caster/3026963 I made a 2x4 frame that the gun safe fit onto and attached the casters at the corners and the middle. It worked well and I was able to move it around on a flat surface by myself. This cheap option may work well for you. Justin > On Jan 23, 2015, at 08:50, woxofswa wrote: > > > I went to Harbor Frieght and got one each of their large and small moving dollies. I then joined them together about three feet apart with 2 2x2 rails. > > The contraption made for a nice crate dolly and later by adding styrofoam blocks as needed to the small dolly, a great fuselage dolly. It was moveable around the shop and a nice height for wiring, interior painting, etc > > -------- > Myron Nelson > Mesa, AZ > Flew May 10 2014 > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437526#437526 > > > > > > > > > > ________________________________________________________________________________
Subject: Lower cowl attach problem
Date: Jan 24, 2015
I'm at the point of attaching the lower cowl aft edge hinge to the cowl and need to drill holes for the rivets. I have the upper cowl secured in place and the lower cowl is clecoed to the upper at the forward end and secured at the bottom. Thus, no inside access. Is there a trick to sticking the cowl part of the hinge to the inside and then drilling from the outside...or a better plan? Suggestions appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437564#437564 ________________________________________________________________________________
Subject: Re: Lower cowl attach problem
Date: Jan 24, 2015
Don't use the hinge on the lower rear of the cowl; it will break. I put a plate on each side attached to the firewall where the hinge would go and then put 3 screws on each side through the bottom cowl. Also, make them countersunk with washers. That works well. You could also use skybolt's fasteners. Kevin Belue Sent from my iPhone On Jan 24, 2015, at 12:02 PM, "bob88" wrote: > > I'm at the point of attaching the lower cowl aft edge hinge to the cowl and need to drill holes for the rivets. I have the upper cowl secured in place and the lower cowl is clecoed to the upper at the forward end and secured at the bottom. Thus, no inside access. Is there a trick to sticking the cowl part of the hinge to the inside and then drilling from the outside...or a better plan? Suggestions appreciated. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437564#437564 > > > > > > > > > > ________________________________________________________________________________
Date: Jan 24, 2015
Well, they might break. On all the -10's I've messed with, some break and some don't. It's hard to tell what causes them to break. The best option, as mentioned, is a plate with screws or 2 skybolts on each side. The hinge pin is a royal pain to mess with anyway. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Jan 24, 2015, at 2:37 PM, Kevin Belue wrote: > > > Don't use the hinge on the lower rear of the cowl; it will break. I put a plate on each side attached to the firewall where the hinge would go and then put 3 screws on each side through the bottom cowl. Also, make them countersunk with washers. That works well. You could also use skybolt's fasteners. > > Kevin Belue > > Sent from my iPhone > >> On Jan 24, 2015, at 12:02 PM, "bob88" wrote: >> >> >> I'm at the point of attaching the lower cowl aft edge hinge to the cowl and need to drill holes for the rivets. I have the upper cowl secured in place and the lower cowl is clecoed to the upper at the forward end and secured at the bottom. Thus, no inside access. Is there a trick to sticking the cowl part of the hinge to the inside and then drilling from the outside...or a better plan? Suggestions appreciated. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=437564#437564 > > > > > ________________________________________________________________________________
Date: Jan 24, 2015
Hey Bob, If the other's response to attaching the cowl to the bottom of the firewall apply, then never mind. Are you talking about attaching the horizontal hinge (which fastens the upper and lower cowls) to the bottom half of the cowl at the aft end? Later, - Lew -----Original Message----- From: bob88 Sent: Saturday, January 24, 2015 1:02 PM Subject: RV10-List: Lower cowl attach problem I'm at the point of attaching the lower cowl aft edge hinge to the cowl and need to drill holes for the rivets. I have the upper cowl secured in place and the lower cowl is clecoed to the upper at the forward end and secured at the bottom. Thus, no inside access. Is there a trick to sticking the cowl part of the hinge to the inside and then drilling from the outside...or a better plan? Suggestions appreciated. ________________________________________________________________________________
Date: Jan 24, 2015
Actually, I did the plate with screws/nutplates on the bottom. My issue is with the hinge attachment to the sides of the lower cowl along the firewall; not the upper to lower attachment. Trying to figure out how to drill the rivet holes with the cowl in position. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437575#437575 ________________________________________________________________________________
Date: Jan 24, 2015
By careful measuring and/or shining a bright light inside, you should be able to draw an outline of the hinge on the outside of the cowl. Then mark a centerline, and mark where you want the rivets to go. Start at bottom, this is the hard part. As the drill comes thru the fiberglass, either have a long arm inside (thru the bottom opening) to hold the hinge flat against the cowl; OR, bend the hinge out of the way, drill thru the cowl, rotate the hinge back into position, mark with a sharpie, remove the cowl, drill the hinge. #1 is more accurate and quicker if you have the long arm of yourself or a helper. I think I did it by myself using a scrap of wood to hold the hinge. Once the first hole is drilled, use a cleco to hold the hinge against the cowl. Drill with light pressure so you don't push the hinge away. Cleco as you go. As per the instructions, if too many shavings build up between the hinge and cowl, stop and blow them out so they don't keep the hinge from laying flat. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437580#437580 ________________________________________________________________________________
Date: Jan 24, 2015
One way is to attach the aft section to the side of the fuse. Then join the hinge halves with the pin so the fwd half is hanging in space. Now put the lower cowl in place so you're happy with the fit. Drill two or three no. 40 holes in the cowl to catch the fwd hinge half. Cleco the cowl to the hinge and finish the rivet pattern. The original holes can be filled later if they don't end up as part of the desired layout. You might consider moving the aft hinge halfs about 1/8" forward relative to the fuse so the knuckles don't line up exactly with the split line. But that may require a wider hinge flange than Vans supplies-- I don't recall. Otherwise you end up with the knuckles visible in the gap. --Dave On Saturday, January 24, 2015, bob88 wrote: > > > > Actually, I did the plate with screws/nutplates on the bottom. My issue is > with the hinge attachment to the sides of the lower cowl along the > firewall; not the upper to lower attachment. Trying to figure out how to > drill the rivet holes with the cowl in position. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=437575#437575 > > ________________________________________________________________________________
Subject: Firewall Soundproofing Insulation
Date: Jan 25, 2015
Could the RV-10 builder from Canada (I think) who supplied me soundproofing insulation (i.e. felt, blue rubber and self adhesive backed foil) for the firewall some time back, please contact me off line to discuss installation technique. Alternatively if any other builders have used this soundproofing method for their firewall, please contact me to confirm the order of the three materials and the adhesive used to bond each layer please? Warm regards Patrick ________________________________________________________________________________
Date: Jan 24, 2015
Subject: Re: Center section wing bolt alignment--follow-up
After wrestling with the perceived problem for awhile, and trying installing the spacers that come with the slow build kit (which did help with alignment) I decided to wait until I actually got the wing spar inserted in the center section. Surprise....the right wing holes lined up about as well as can be inspected. Somehow having th spar inserted seemed to fix any misalignment. When I got to the left wing, the top 3/8" holes were very tight on the alignment pins, so I investigated. I found that it was the wing spar where the problem existed, not the center section. The spar web did not did not line up exactly with the main bar spar cap. Talked to Van's. They told me to not use my 3/8" undersize reamer from the bar side because it would remove metal where you do not want to change clearance. Their advice was to work from the web side with a Dremel with abrasive bit(with dowel or bolt in the bar to prevent going too deep) until the interference was solved, then prime the area worked on. I did that. Problem solved. As insurance, I stored the bolts under dry ice overnight before installing. They all went in okay, some needing firmer tapping with dead blow mallet than others. Van's did say that the web misalignment they had heard of a few other cases before mine. Kelly On Thu, Nov 27, 2014 at 1:39 PM, Kelly McMullen wrote: > > I will check, but the wing # vs fuselage # is irrelevant in this case. It > is the two halves of the center section on one side of the fuselage that > have the misalignment. At this stage the wings are not involved. > Unfortunately my QB was one of the first to come out of Manila after > relocation/reorganization of the facility their. There were a number of QC > issues right from the start, like not countersinking the longerons before > riveting on the dimpled skins. > > On 11/27/2014 10:06 AM, Rich Hansen wrote: > >> >> Hi Kelly, >> After commiserating with you in reading your email, a thought occurred to >> me. I had purposely forgotten about this so as not to have continuous bad >> dreams about it. So here is the question: Do you have the same serial >> number fuselage as you do wings? As in, are the numbers matching? As in, >> were you one of the unfortunate ones that lost your quick build in the >> Philippines weather disaster some years ago??? >> >> >> > > ________________________________________________________________________________
Subject: New Low profile door handles
From: "aerosport1" <g.combs(at)aerosportmodeling.com>
Date: Jan 26, 2015
Aerosport Products now has available new Low profile door handles for the RV-10. These can be added to a new build or retrofit to flying aircraft. They also work great with the Planearound saftey latch. Introductory cost is $345.00 plus shipping. These handles come with everything you need accept for the ACS door locks. These can be purchased from Aircraft Spruce part #11-01600. Contact Aerosport Products www.aerosportproducts.com for more information -------- Geoff Combs RV-10 QB N829GW Flying 500 hrs 40033 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437669#437669 Attachments: http://forums.matronics.com//files/photo22_310.jpg http://forums.matronics.com//files/photo16_105.jpg ________________________________________________________________________________
Subject: Re: New Low profile door handles
Date: Jan 26, 2015
Beautiful handles. Also glad to see you changed the arrow labels. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437676#437676 ________________________________________________________________________________
Date: Jan 26, 2015
But if we want to see pictures of them now...two were uploaded to matronics. Link at the bottom of the email and repasted immediately below. -Jim P.S. Yes, I went to the site first, couldn't find them and then realized pi cs were right under my nose all along. :-) >> http://forums.matronics.com//files/photo22_310.jpg >> http://forums.matronics.com//files/photo16_105.jpg Jim Beyer 316-213-7093 Sent from my iPhone ________________________________________________________________________________
Date: Jan 27, 2015
You can special order from ACS matched key locks, but they will not/cannot match your existing locks. On a new order, they can also match key to their ignition switch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=437716#437716 ________________________________________________________________________________
Subject: Garmin Servo FS
Date: Feb 05, 2015
New Garmin GSA 28 Servo and RV-10 pitch mount for sale. See Vans Air Force forum's Classifieds page. -------- RV-10 UC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438089#438089 ________________________________________________________________________________
Date: Feb 06, 2015
Subject: Australian RV builders
I'm in Perth for 10 days or so and have a rental car. If there are any RV builders nearby I'd like to vist. Albert Gardner N991RV RV-10 Yuma, AZ ________________________________________________________________________________
Subject: Propellor clocking
Date: Feb 06, 2015
Hartzell 2 blade, ring gear is at #1tdc comp stroke with gear showing #1tc on top rear at engine split line. Also on starter hole for front of gear. So I know the ring gear is on correctly question is prop. Don't remember during install if there was only one way it goes on or not . It currently sits at 11/5 o'clock from pilot seat. It got me thinking if it is correct ? Or should it be different so it stops at the 8/2 o'clock during shut down? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438115#438115 ________________________________________________________________________________
Subject: Re: Propellor clocking
Date: Feb 06, 2015
Usually there is a "0" on the ring gear and the prop has one stud that has no recess where it mates with the prop flange. If no "0", there are 2 threaded inserts on the prop flange that are shorter. It can only go on 2 ways and fully seat. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Feb 6, 2015, at 11:05 AM, rvdave wrote: > > > Hartzell 2 blade, ring gear is at #1tdc comp stroke with gear showing #1tc on top rear at engine split line. Also on starter hole for front of gear. So I know the ring gear is on correctly question is prop. Don't remember during install if there was only one way it goes on or not . It currently sits at 11/5 o'clock from pilot seat. It got me thinking if it is correct ? Or should it be different so it stops at the 8/2 o'clock during shut down? > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438115#438115 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 06, 2015
Ok I know it had the O so it probably is on correctly but only could be 180 deg diff? Btw what makes it stop during shutoff at 8/2 o'clock? Haven't started mine yet so wondering. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438117#438117 ________________________________________________________________________________
Date: Feb 06, 2015
Yes, it can only be wrong by being 180 off. I don't know on the 8/2 thing. I think it stops at any compression stroke, which is the same position on a 4-cyl, but not on a 6. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 6, 2015, at 12:41 PM, rvdave wrote: > > > Ok I know it had the O so it probably is on correctly but only could be 180 deg diff? Btw what makes it stop during shutoff at 8/2 o'clock? Haven't started mine yet so wondering. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438117#438117 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 06, 2015
How can a prop stop 180 off if its a two blade prop? Sent from my iPad > On Feb 6, 2015, at 11:10 AM, Jesse Saint wrote: > > > Yes, it can only be wrong by being 180 off. I don't know on the 8/2 thing. I think it stops at any compression stroke, which is the same position on a 4-cyl, but not on a 6. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Feb 6, 2015, at 12:41 PM, rvdave wrote: >> >> >> Ok I know it had the O so it probably is on correctly but only could be 180 deg diff? Btw what makes it stop during shutoff at 8/2 o'clock? Haven't started mine yet so wondering. >> >> -------- >> Dave Ford >> RV6 for sale >> RV10 building >> Cadillac, MI >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=438117#438117 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
From: John MacCallum <john.maccallum(at)bigpond.com>
Date: Feb 07, 2015
Let me know if you make it to Sydney Albert. Cheers John MacCallum VH-DUU RV 10 # 41016 (being Painted) -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ibspud(at)roadrunner.com Sent: Friday, 6 February 2015 7:23 PM Subject: RV10-List: Australian RV builders I'm in Perth for 10 days or so and have a rental car. If there are any RV builders nearby I'd like to vist. Albert Gardner N991RV RV-10 Yuma, AZ ________________________________________________________________________________
Date: Feb 06, 2015
It can be installed 180 off. It doesn't really matter, but there is a "0" on the ring gear and a "0" on the prop hub that are supposed to line up. I can't imaging it would make any difference, though. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 6, 2015, at 2:58 PM, Bob Kaufmann wrote: > > > How can a prop stop 180 off if its a two blade prop? > > > Sent from my iPad > > >> On Feb 6, 2015, at 11:10 AM, Jesse Saint wrote: >> >> >> Yes, it can only be wrong by being 180 off. I don't know on the 8/2 thing. I think it stops at any compression stroke, which is the same position on a 4-cyl, but not on a 6. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >>> On Feb 6, 2015, at 12:41 PM, rvdave wrote: >>> >>> >>> Ok I know it had the O so it probably is on correctly but only could be 180 deg diff? Btw what makes it stop during shutoff at 8/2 o'clock? Haven't started mine yet so wondering. >>> >>> -------- >>> Dave Ford >>> RV6 for sale >>> RV10 building >>> Cadillac, MI >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=438117#438117 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Feb 06, 2015
I know there was an O on the crank flange and the ring gear which I lined up but just couldn't remember if there was more than one way to mount the prop to the crank flange. Probably what the indexing stud is for, aha moment. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438139#438139 ________________________________________________________________________________
Date: Feb 06, 2015
On rare occasion, swapping blade 180 may help smoothness. On 2/6/2015 4:14 PM, Jesse Saint wrote: > > It can be installed 180 off. It doesn't really matter, but there is a "0" on the ring gear and a "0" on the prop hub that are supposed to line up. I can't imaging it would make any difference, though. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > >> On Feb 6, 2015, at 2:58 PM, Bob Kaufmann wrote: >> >> >> How can a prop stop 180 off if its a two blade prop? >> >> >> Sent from my iPad >> >> >>> On Feb 6, 2015, at 11:10 AM, Jesse Saint wrote: >>> >>> >>> Yes, it can only be wrong by being 180 off. I don't know on the 8/2 thing. I think it stops at any compression stroke, which is the same position on a 4-cyl, but not on a 6. >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> 352-427-0285 >>> jesse(at)saintaviation.com >>> >>> Sent from my iPad >>> >>>> On Feb 6, 2015, at 12:41 PM, rvdave wrote: >>>> >>>> >>>> Ok I know it had the O so it probably is on correctly but only could be 180 deg diff? Btw what makes it stop during shutoff at 8/2 o'clock? Haven't started mine yet so wondering. >>>> >>>> -------- >>>> Dave Ford >>>> RV6 for sale >>>> RV10 building >>>> Cadillac, MI >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=438117#438117 >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>>> >>> >>> >>> >>> >> >> >> >> > > ________________________________________________________________________________
Date: Feb 09, 2015
Subject: Hose Interference
Well, haven't seen any posts for a few days so here is a little tip that hop efully someone can use: On my hose that runs from the left firewall heat bo x to the exhaust heat muff there was interference with the fuel line, the br eather tube, and the oil cooler. My thinking was that simply changing the l ength of the hose or twisting it would solve the issue. Not so for me. Aft er taking 5 minutes to cut, fit, and install the right side and stewing over this issue on the left for an hour, a default to the ACS Catalog Page 388 o ffered some hope. A quick trip to the So Cal ACS gave me part # 08-00863 in hand. It fit perfectly and offered clearance for all three points of inter ference. All for $29.50, not bad for aircraft parts and a nice neat fix. Sent from my iPhone
Subject: Re: Hose Interference
Date: Feb 09, 2015
Might be better for future readers using the "search" function if you edited your post and changed "hose" to "scat tubing". -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438191#438191 ________________________________________________________________________________
Date: Feb 10, 2015
The moment of that extension will put a lot of stress on the output flange of the heat muff. I have never heard of the interference problem before, nor did I have one. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438205#438205 ________________________________________________________________________________
Date: Feb 10, 2015
I agree .... I just looked at my installation (I'm still building) and my scat tube doesn't come near interfering with anything. I suspect that the scat tube Rich is installing might be cut too long. My scat tube has a nice, graceful curve from the muff to the heat box. Linn On 2/10/2015 9:00 AM, bill.peyton wrote: > > The moment of that extension will put a lot of stress on the output flange of the heat muff. I have never heard of the interference problem before, nor did I have one. > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=438205#438205 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Feb 10, 2015
From: David Clifford <davidsoutpost(at)comcast.net>
No alignment or interference with mine either. ----- Original Message ----- From: "bill.peyton" <peyton.b(at)sbcglobal.net> Sent: Tuesday, February 10, 2015 9:00:38 AM Subject: RV10-List: Re: Hose Interference The moment of that extension will put a lot of stress on the output flange of the heat muff. I have never heard of the interference problem before, nor did I have one. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438205#438205 ________________________________________________________________________________
Date: Feb 10, 2015
> Bob, agree scat tubing or scat "ducting" per ACS might have been better. Bottom of my page says may not edit your post. Bill, many have complained that the heat coming out of the front box is a bit much. Possibly the 90 degree bend will decelerate the air flow creating a positive outcome, but it is highly doubtful that it will cause the flange welds to be ripped out of the heat muff. Is that what you meant? Linn, in fitting this left side scat I started with a longer than desired piece. Then progressively cut it down about an inch at a time, refitting and rechecking, each time with an undesirable outcome. For my application it was: if I clear the fuel line it hits the cooler, if I clear the cooler it hits the fuel line, etc. Look at Section FF6, page 5 in the plans. In the bottom middle picture it looks like the scat may be hitting/rubbing against the oil cooler right behind the crossover bracket. My plans are old & maybe things have changed. But, that's about what I was dealing with. Wasn't interested in RTVing Air Seal Fabric onto the hose as suggested on previous page. Also, I should add that I do have SS aftermarket heat boxes and aftermarket cooler, although I'm pretty sure their dimensions are the same as factory. Regarding the fuel line, we probably all have somewhat similar installations, yet each will be slightly different in routing, securing and final fit. Didn't mean to stir the pot or create a problem for anyone, just offering up a suggestion for fellow builders that appears to be a solution, not too expensive, and/or that the elbow might be used somewhere else in someone's build - experimental! PS: a 45 degree would be even better Rich Hansen > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 11, 2015
I didn't have any interference. You might want to adjust he clocking of the heat muff outlet to better line up between the engine mount gap. One thing I did on the left side was put a tiny scoop at the inlet to increase the airflow and decrease the temperature which was very hot. I run both my FWD and aft heat off that muff by using Van's Y splitter inside the tunnel. With the scoop I get plenty of nice warm air both fwd and aft. I took the muff off the right side and run scat from the back of the baffle straight to the valve which is open inside the tunnel allowing me to keep the tunnel nice and cool as necessary. (http://s125.photobucket.com/user/myronnelson/media/photo_zps2f0e91f5.jpg.html) -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=438237#438237 ________________________________________________________________________________
Subject: Re: RV10-List Digest: 1 Msgs - 02/11/15
Date: Feb 12, 2015
Thx for your ideas & pic Myron. I like your scoop! Yours are some changes I may want to make once this bird gets a good shake down. Thx for clocking suggestion on muff. I had tried clocking & it helped but was still not good enough in my application, so had to go with elbow. Sent from my iPhone > > > > > > > > > > > > > > > ________________________________ Message 1 _____________________________________ > > > Subject: RV10-List: Re: Hose Interference > From: "woxofswa" <woxof(at)aol.com> > > > I didn't have any interference. You might want to adjust he clocking of the heat > muff outlet to better line up between the engine mount gap. > > One thing I did on the left side was put a tiny scoop at the inlet to increase > the airflow and decrease the temperature which was very hot. I run both my FWD > and aft heat off that muff by using Van's Y splitter inside the tunnel. With > the scoop I get plenty of nice warm air both fwd and aft. > I took the muff off the right side and run scat from the back of the baffle straight > to the valve which is open inside the tunnel allowing me to keep the tunnel > nice and cool as necessary. > > (http://s125.photobucket.com/user/myronnelson/media/photo_zps2f0e91f5.jpg.html) > > -------- > Myron Nelson > Mesa, AZ > > > > > ________________________________________________________________________________
Subject: Door seals - more questions than answers.
Date: Feb 12, 2015
Hi everyone. I'm at the stage of choosing door seals and have somewhat stalled in the decision-making process, so I'm reaching out to those who've been there, in trying to make the best-informed decision. I've scoured the RV-10 Matronics email list for the past several years to see what people are doing, but still have what seems to be more questions than answers. I know that replacing Van's seals is a popular option. I guess the first thing to know when choosing an alternative is understanding exactly what we're trying to fix. My biggest question is probably - what is the biggest problem with them? I've read that the stock seals just don't "seal" well enough. Is this because of where the seal fits (into the channel)? Or due to the physical nature of the rubber seal? I notice that it quite easily "kinks", which would leave air gaps if this happens when mounted on the door. Also, the coil I have from Vans has lots of locations where the two opposite edges in the bulb are stuck together internally (kinks that have sat that way for years). They can probably be teased apart, but obviously, if this happens when it is on the door, the sealing factor is gone. Alternately, if the problems with Van's seal are due to the location of the seal, obviously changing to a seal that attaches differently makes sense. If due to kinking, perhaps a different composition of seal? A popular option here seems to be McMaster-Carr's part number 1120A313 (also apparently the same as 1120A31), or 1120A411 - edge-grip seals with a rubber bulb. This gets installed along the door frame instead of the door, and requires the modification that the channel (gutter) along the door frame is cut back such that the inner curve of the channel is removed so that the mounting edge is effectively co-planar with the door. I know this is a popular option, but as I say, I want to make an informed decision. Though I'm sure it makes a finished look, I am a bit concerned that removing the inner curve of the channel reduces the structural integrity of the cabin top somewhat (it effectively removes one of the flanges if the channel were to be considered an I-beam). I also kind of like the existing gutter concept to the door frame minimizing the chance of water getting inside overhead. Also, considering that this concept puts the seal on the door frame, I wonder if it would be more easily damaged and/or dislodged by people getting in and out. On the other hand, car door seals tend to be this way, so maybe it's not a big deal. One thing I don't understand - those seals have a rubber bulb... in which case, how do they seal better than Van's which also have a similar bulb, or is it primarily the mounting difference that improves things? Another option that's been popular is that which was sold by rvtraining.com / Aviation Tech Products. This was a foam-based seal that went along the outer edge (lip) of the door. Since it didn't require modifications to the structural integrity of the door frame, I thought this was potentially appealing (plus, it feels as though a foam-based seal would be more sound-insulating than a rubber bulb). But I say "was" on purpose - I got in touch with them a few days ago, and as of December 2014, they closed Aviation Tech Products, don't have any seals left and don't know where else they may be obtained. So this exact option is out, unless someone has done something similar. On the other hand, I never quite understood how the seal would work effectively along the areas of the door where there was only a very small lip available, like along the bottom. Another option would be seal attached to the door that compressed against the existing flange of the door frame that curves back towards the door (the part cut off when using the aforementioned 1120A411 edge-grip seal). This could be something like McMaster part 1142A28, or even a simple adhesive-backed strip like 93745K23. If the problem with Van's seal is due to its composition, there are McMaster alternatives that have a similar form factor (and hence mounting) - like a purely foam version such as 93085K91, or even an intriguing "hybrid" rubber seal with a foam core (1141A4) that may combine the ruggedness of a rubber outer section like Van's with a foam core inside that "may" help prevent kinking and opposite sides of the bulb bonding together, if that in fact is the problem with Van's in the first place. To me this seems like the most straightforward improvement with minimal changes to what Van's intended, but I don't know if that would be "fixing" a problem with the Van's seals that may not be the big issue in the first place. Of course, I could just go and do what the majority are doing with regards to alternate seals if there is a majority, but I'm the sort who wants to make an informed a decision as possible. Any feedback anyone could give on the concept would be greatly appreciated - particularly from those who have gone down this decision tree in the past, I'd be very interested in hearing why you decided on using what you have. Then, if I decide to go with some variation of a McMaster seal, I have to tackle the next hurdle and see if I can get them to ship to Canada, which I've heard has been problematic in the past. But one problem at a time :-) Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Door seals - more questions than answers.
Date: Feb 12, 2015
I know that staying with the Vans seals is not the popular choice but I have been quite happy with them and I have a good seal all around I had the McMaster seals on my Glasair and they are not without their own problems. They shrink over time and leave a 1" gap at the joint. Additionally they are not water tight. The water seeps in around the clip. To make it water tight you must install the clip with silicone caulk. Plus all the grinding and building up on the lip. So, each has issues so pick your poison. > On Feb 12, 2015, at 4:50 PM, Dan Charrois wrote: > > > Hi everyone. I'm at the stage of choosing door seals and have somewhat stalled in the decision-making process, so I'm reaching out to those who've been there, in trying to make the best-informed decision. I've scoured the RV-10 Matronics email list for the past several years to see what people are doing, but still have what seems to be more questions than answers. > > I know that replacing Van's seals is a popular option. I guess the first thing to know when choosing an alternative is understanding exactly what we're trying to fix. My biggest question is probably - what is the biggest problem with them? I've read that the stock seals just don't "seal" well enough. Is this because of where the seal fits (into the channel)? Or due to the physical nature of the rubber seal? I notice that it quite easily "kinks", which would leave air gaps if this happens when mounted on the door. Also, the coil I have from Vans has lots of locations where the two opposite edges in the bulb are stuck together internally (kinks that have sat that way for years). They can probably be teased apart, but obviously, if this happens when it is on the door, the sealing factor is gone. Alternately, if the problems with Van's seal are due to the location of the seal, obviously changing to a seal that attaches differently makes sense. If due to kinking, perhap! > s a different composition of seal? > > A popular option here seems to be McMaster-Carr's part number 1120A313 (also apparently the same as 1120A31), or 1120A411 - edge-grip seals with a rubber bulb. This gets installed along the door frame instead of the door, and requires the modification that the channel (gutter) along the door frame is cut back such that the inner curve of the channel is removed so that the mounting edge is effectively co-planar with the door. I know this is a popular option, but as I say, I want to make an informed decision. Though I'm sure it makes a finished look, I am a bit concerned that removing the inner curve of the channel reduces the structural integrity of the cabin top somewhat (it effectively removes one of the flanges if the channel were to be considered an I-beam). I also kind of like the existing gutter concept to the door frame minimizing the chance of water getting inside overhead. Also, considering that this concept puts the seal on the door frame, I wonder if it would ! > be more easily damaged and/or dislodged by people getting in and out. On the other hand, car door seals tend to be this way, so maybe it's not a big deal. One thing I don't understand - those seals have a rubber bulb... in which case, how do they seal better than Van's which also have a similar bulb, or is it primarily the mounting difference that improves things? > > Another option that's been popular is that which was sold by rvtraining.com / Aviation Tech Products. This was a foam-based seal that went along the outer edge (lip) of the door. Since it didn't require modifications to the structural integrity of the door frame, I thought this was potentially appealing (plus, it feels as though a foam-based seal would be more sound-insulating than a rubber bulb). But I say "was" on purpose - I got in touch with them a few days ago, and as of December 2014, they closed Aviation Tech Products, don't have any seals left and don't know where else they may be obtained. So this exact option is out, unless someone has done something similar. On the other hand, I never quite understood how the seal would work effectively along the areas of the door where there was only a very small lip available, like along the bottom. > > Another option would be seal attached to the door that compressed against the existing flange of the door frame that curves back towards the door (the part cut off when using the aforementioned 1120A411 edge-grip seal). This could be something like McMaster part 1142A28, or even a simple adhesive-backed strip like 93745K23. > > If the problem with Van's seal is due to its composition, there are McMaster alternatives that have a similar form factor (and hence mounting) - like a purely foam version such as 93085K91, or even an intriguing "hybrid" rubber seal with a foam core (1141A4) that may combine the ruggedness of a rubber outer section like Van's with a foam core inside that "may" help prevent kinking and opposite sides of the bulb bonding together, if that in fact is the problem with Van's in the first place. To me this seems like the most straightforward improvement with minimal changes to what Van's intended, but I don't know if that would be "fixing" a problem with the Van's seals that may not be the big issue in the first place. > > Of course, I could just go and do what the majority are doing with regards to alternate seals if there is a majority, but I'm the sort who wants to make an informed a decision as possible. Any feedback anyone could give on the concept would be greatly appreciated - particularly from those who have gone down this decision tree in the past, I'd be very interested in hearing why you decided on using what you have. Then, if I decide to go with some variation of a McMaster seal, I have to tackle the next hurdle and see if I can get them to ship to Canada, which I've heard has been problematic in the past. But one problem at a time :-) > > Thanks! Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > > > > ________________________________________________________________________________
Date: Feb 12, 2015
The Vans stock seals don't really work very well, and quite honestly, look terribly cheap, especially on a $175,000 aircraft. The McMaster edge grip bulb seals look very professional, and do their job. Unfortunately they also take quite a bit of work to install. The door frame must be modified and reinforced at the front and rear frame, and the hinge recesses must be covered to create a seal. Having said that, I used the McMaster seals and would do it again. They look soooo much better than the stock seal. The other modification that is a must, is the Plane Around door security latch. I also just finished installing the new Aerosport outer door latches. -------- Bill WA0SYV Aviation Partners, LLC
December 06, 2014 - February 12, 2015
RV10-Archive.digest.vol-kj
