RV10-Archive.digest.vol-kl
March 24, 2015 - April 21, 2015
      On Tue, Mar 24, 2015 at 11:33 AM, Larry Rosen  wrote:
      I used a 1.5" hose from the fire wall to the rear connector, with
      homebrew
      reducers at each end to make the transition between 2" and 1.5".  I did
      this
      as it made routing the hose much easier.
      It sounds like 1" tubing would provide more than enough heat.
      I may homebrew or just use these reducers from planeinovations
      <http://www.planeinnovations.com/scat-adapters.html> It will depend if I
      want to spend time or money.
      One other point - I view the per plans cabin heat valve location as
      problematic.  On the hottest day you have hot air off the heat muffs
      being
      directed back at the engine - right at the mechanical fuel pump.  My fix
      for
      this was to install a piece of Koolmat between the firewall cabin heat
      boxes
      (holes cut out for the box air exit) such that the mat extends over the
      top
      of the boxes and then down over the front of the boxes.  The result is
      when
      the cabin heat valves are shut, the dumped hot air is directed down
      toward
      the bottom of the cowl, and the conductive heat from the boxes to the
      firewall is reduced.  This is the Koolmat product:
      http://www.aircraftspruce.com/catalog/appages/koolmat.php?clickkey=2616
      02
      I am having a hard time visualizing what you installed.  Are you using
      the koolmat to direct the hot air down instead of towards the engine.
      In this case the koolmat is working as a plenum and not insulating the
      fwf.
      Larry
      -List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Date: Mar 24, 2015
Subject: Re: Rear Heat SCAT Tube Routing
The 1" was something I had lying around the hangar. No issues with the fiberglass and the heat.I made the reducers by carving some styrofoam and wraping it with duct/mylar tape and then glassing over it. On Tue, Mar 24, 2015 at 2:37 PM, Larry Rosen wrote: > Deems, > 1" Scat tubing? > I take it, no issues with the fiberglass in the heater line. > > Larry > > On 3/24/2015 4:18 PM, Deems Davis wrote: > > http://deemsrv10.com/album/Final%20Assembly/slides/DSC07074.html > > click forward for a few more pics > > On Tue, Mar 24, 2015 at 11:33 AM, Larry Rosen wrote: > >> >> >> >>> I used a 1.5" hose from the fire wall to the rear connector, with >>> homebrew >>> reducers at each end to make the transition between 2" and 1.5". I did >>> this >>> as it made routing the hose much easier. >>> >> It sounds like 1" tubing would provide more than enough heat. >> >> I may homebrew or just use these reducers from planeinovations < >> http://www.planeinnovations.com/scat-adapters.html> It will depend if I >> want to spend time or money. >> >> One other point - I view the per plans cabin heat valve location as >>> problematic. On the hottest day you have hot air off the heat muffs >>> being >>> directed back at the engine - right at the mechanical fuel pump. My fix >>> for >>> this was to install a piece of Koolmat between the firewall cabin heat >>> boxes >>> (holes cut out for the box air exit) such that the mat extends over the >>> top >>> of the boxes and then down over the front of the boxes. The result is >>> when >>> the cabin heat valves are shut, the dumped hot air is directed down >>> toward >>> the bottom of the cowl, and the conductive heat from the boxes to the >>> firewall is reduced. This is the Koolmat product: >>> http://www.aircraftspruce.com/catalog/appages/koolmat.php?clickkey=261602 >>> >>> I am having a hard time visualizing what you installed. Are you using >> the koolmat to direct the hot air down instead of towards the engine. In >> this case the koolmat is working as a plenum and not insulating the fwf. >> >> Larry >> >> =================================== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> =================================== >> FORUMS - >> _blank">http://forums.matronics.com >> =================================== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> =================================== >> >> >> >> > > > * > > > * > > ________________________________________________________________________________
Date: Mar 24, 2015
I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work. I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing. -------- See you OSH '15 Q/B - flying 5 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439849#439849 ________________________________________________________________________________
Date: Mar 24, 2015
AirMike wrote: > I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work. > > I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing. I did the same thing with the large scat and it works fine. Coming up on 7 years with no issues, but as Mike says, it is ugly. However, I am the only one that looks at it! ^_^ I agree with Mike's comments about the aluminum heat distribution box and tunnel access. I even thought about making a belly access panel, ala Piper, but that would introduce some other engineering issues I imagine. You will thank yourself later on if you make access to the fuel filter as easy as possible. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439852#439852 ________________________________________________________________________________
Date: Mar 25, 2015
Hi Agree with David's comment on the fuel filters. One of the "legacy" items from my earlier filters install was placement of fuel filters in the wing roots. I was able to install two Earl's Performance filters - one in each wing root. They are user serviceable and easily accessed simply by removing the wing root cover panel. Now I don't have to contort myself to get at them as I would if they were in the tunnel. Regular cleaning, especially when first flying, is a must. There can be a lot of accumulated crud when building. I also installed an access panel on the pilot's side wall of the tunnel for easy access to the aux fuel pump. Cheer Les easily(at)me.com wrote: > > AirMike wrote: > > I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work. > > > > I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing. > > > I did the same thing with the large scat and it works fine. Coming up on 7 years with no issues, but as Mike says, it is ugly. However, I am the only one that looks at it! ^_^ > I agree with Mike's comments about the aluminum heat distribution box and tunnel access. I even thought about making a belly access panel, ala Piper, but that would introduce some other engineering issues I imagine. You will thank yourself later on if you make access to the fuel filter as easy as possible. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439860#439860 ________________________________________________________________________________
Date: Mar 25, 2015
Subject: fuel filters
Do you have a part number handy??? I looked, and the choices are huge!!! Anybody else go this route?? My fellow RV-10 builder added a second Vans filter and mounted them under the front seats in place of the one in the tunnel. I plan on adding filters in the wing root like Les did, and for the same reasons. Linn On 3/25/2015 9:10 AM, kearney wrote: > > Hi > > Agree with David's comment on the fuel filters. One of the "legacy" items from my earlier filters install was placement of fuel filters in the wing roots. I was able to install two Earl's Performance filters - one in each wing root. They are user serviceable and easily accessed simply by removing the wing root cover panel. Now I don't have to contort myself to get at them as I would if they were in the tunnel. > > Regular cleaning, especially when first flying, is a must. There can be a lot of accumulated crud when building. > > I also installed an access panel on the pilot's side wall of the tunnel for easy access to the aux fuel pump. > > Cheer > > Les > > > easily(at)me.com wrote: >> AirMike wrote: >>> I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work. >>> >>> I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing. >> >> I did the same thing with the large scat and it works fine. Coming up on 7 years with no issues, but as Mike says, it is ugly. However, I am the only one that looks at it! ^_^ >> I agree with Mike's comments about the aluminum heat distribution box and tunnel access. I even thought about making a belly access panel, ala Piper, but that would introduce some other engineering issues I imagine. You will thank yourself later on if you make access to the fuel filter as easy as possible. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439860#439860 > > ________________________________________________________________________________
Date: Mar 26, 2015
Any pictures of the wing root filter installations please Les? Warm regards Patrick > On 25 Mar 2015, at 23:40, kearney wrote: > > > Hi > > Agree with David's comment on the fuel filters. One of the "legacy" items from my earlier filters install was placement of fuel filters in the wing roots. I was able to install two Earl's Performance filters - one in each wing root. They are user serviceable and easily accessed simply by removing the wing root cover panel. Now I don't have to contort myself to get at them as I would if they were in the tunnel. > > Regular cleaning, especially when first flying, is a must. There can be a lot of accumulated crud when building. > > I also installed an access panel on the pilot's side wall of the tunnel for easy access to the aux fuel pump. > > Cheer > > Les > > > > easily(at)me.com wrote: >> >> AirMike wrote: >>> I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work. >>> >>> I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing. >> >> >> I did the same thing with the large scat and it works fine. Coming up on 7 years with no issues, but as Mike says, it is ugly. However, I am the only one that looks at it! ^_^ >> I agree with Mike's comments about the aluminum heat distribution box and tunnel access. I even thought about making a belly access panel, ala Piper, but that would introduce some other engineering issues I imagine. You will thank yourself later on if you make access to the fuel filter as easy as possible. > > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439860#439860 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: New MT 3 Blade Propeller For Sale
Date: Mar 25, 2015
NEW PRICE. 11,000.00 CHEAPER THEN ANYWHERE AND WITH FREE SHIPPING. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439881#439881 ________________________________________________________________________________
Subject: Re: fuel filters
Date: Mar 25, 2015
Linn These are what I used : http://www.summitracing.com/oh/parts/ear-230206erl I flow tested them at something north of 50 GPH so they are well suited to our application (IMHO). The screens are easily removed and cleaned. I have done so several times. When I first was flying, I had to install gascolators to meet inspection requirements. These I had in the wig roots and the filters were under the seat. Accessing them was a real pain. I wanted easy access. I certainly didn't want them in the tunnel. When I received permission to remove gascolators, I moved the filters to the wing roots. Much easier access (5 minutes and they are both out). Also, rather than ruin a solid line from the tunnel to the fuel tank, I ran the line to a bulkhead minutes on the fues sidewall. It was easy to mount the filter between this and the tank outlet. Cheers Les [quote="flying-nut(at)cfl.rr.com"]Do you have a part number handy??? I looked, and the choices are huge!!! Anybody else go this route?? My fellow RV-10 builder added a second Vans filter and mounted them under the front seats in place of the one in the tunnel. I plan on adding filters in the wing root like Les did, and for the same reasons. Linn Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439882#439882 ________________________________________________________________________________
Date: Mar 25, 2015
Details please - what model # Why are you selling? I love mine! -----Original Message----- >From: mds4878 <mike.nova1973(at)gmail.com> >Sent: Mar 25, 2015 9:39 PM >To: rv10-list(at)matronics.com >Subject: RV10-List: Re: New MT 3 Blade Propeller For Sale > > >NEW PRICE. 11,000.00 >CHEAPER THEN ANYWHERE AND WITH FREE SHIPPING. > >-------- >RV-10 #40447 >Fuselage almost done. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=439881#439881 > > ________________________________________________________________________________
Date: Mar 25, 2015
MTV-12-B/193-53 with Governor to fit IO 540 RV-10 All info in first posting in thread. -------- RV-10 #40447 Fuselage almost done. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439884#439884 ________________________________________________________________________________
Date: Mar 25, 2015
Subject: Re: Wing root fairings
I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing? On Wed, Mar 25, 2015 at 1:11 PM, Patrick Pulis wrote: > > Any pictures of the wing root filter installations please Les? > > Warm regards > > Patrick > > ________________________________________________________________________________
Date: Mar 25, 2015
Hi Kelly I went to a local auto supply shop and got some edge trim and put that on the inboard edge of the wing root faring. I think it looks quite nice. I can in a 50' foot roll and cost perhaps $40. I don't have the name, but can get it when I am at the hanger next. Cheers Les [quote="Kelly McMullen"]I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439886#439886 ________________________________________________________________________________
Date: Mar 25, 2015
bm90IGJhZCBwcmljZTogcHJvcCBpcyAkMTA1MDAsIGFzc2VtYmx5IGFuZCBzaGlwcGluZyBpcyAk MTIwMCwgZ292ZXJub3IgYWJvdXQgJDEwMDANCkhvdyBkbyBJIGtub3c/PyBKdXN0IGdvdCBtaW5l IGZyb20gVmFucy7wn5iSDQoNCj4gU3ViamVjdDogUlYxMC1MaXN0OiBSZTogTmV3IE1UIDMgQmxh ZGUgUHJvcGVsbGVyIEZvciBTYWxlDQo+IEZyb206IG1pa2Uubm92YTE5NzNAZ21haWwuY29tDQo+ IERhdGU6IFdlZCwgMjUgTWFyIDIwMTUgMTk6MzA6NDEgLTA3MDANCj4gVG86IHJ2MTAtbGlzdEBt YXRyb25pY3MuY29tDQo+IA0KPiAtLT4gUlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiAibWRz NDg3OCIgPG1pa2Uubm92YTE5NzNAZ21haWwuY29tPg0KPiANCj4gTVRWLTEyLUIvMTkzLTUzIHdp dGggR292ZXJub3IgdG8gZml0IElPIDU0MCAgIFJWLTEwDQo+IEFsbCBpbmZvIGluIGZpcnN0IHBv c3RpbmcgaW4gdGhyZWFkLg0KPiANCj4gLS0tLS0tLS0NCj4gUlYtMTAgICM0MDQ0Nw0KPiBGdXNl bGFnZSBhbG1vc3QgZG9uZS4NCj4gDQo+IA0KPiANCj4gDQo+IFJlYWQgdGhpcyB0b3BpYyBvbmxp bmUgaGVyZToNCj4gDQo+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhw P3A9NDM5ODg0IzQzOTg4NA0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gXy09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4g Xy09ICAgICAgICAgIC0gVGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2UgdGhl IE1hdHJvbmljcyBMaXN0IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRoZSBt YW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8tPSBB cmNoaXZlIFNlYXJjaCAmIERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4gXy09 IFBob3Rvc2hhcmUsIGFuZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBodHRw Oi8vd3d3Lm1hdHJvbmljcy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KPiBfLT0NCj4gXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cj4gXy09ICAgICAgICAgICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQo+IF8tPSBTYW1l IGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KPiBfLT0N Cj4gXy09ICAgLS0+IGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPiBfLT0NCj4gXy09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0N Cj4gXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KPiBfLT0g IFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0gICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+IF8tPSAgIC0tPiBo dHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+IA0KPiANCj4g DQogCQkgCSAgIAkJICA ________________________________________________________________________________
Date: Mar 25, 2015
I used part# 05-11201 from Aircraft Spruce. I tried the Y shaped one too, but it didn't work. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439887#439887 ________________________________________________________________________________
Date: Mar 25, 2015
Some have used rubber channel around the leading edge, but along the fuse sk in where there is an angle to screw the fairing on there is nothing. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Mar 25, 2015, at 10:37 PM, Kelly McMullen wrote: > > I don't find mention of any weatherstrip for the wing root fairings. Am I m issing something? What have others done to make a nice joint between fuselag e skin and wing root fairing? > >> On Wed, Mar 25, 2015 at 1:11 PM, Patrick Pulis wrote: > >> >> Any pictures of the wing root filter installations please Les? >> >> Warm regards >> >> Patrick > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Mar 25, 2015
Date: Mar 25, 2015
Hi As requested by Patrick, here is a pix of of my wing root fuel filter. I misspoke in my earlier post when I said I used a bulkhead union for the line. I didn't as I had a connection at the filter I could break. It is hard to see but I used a 90 degree AN fitting to attach the top of the line to the filter. Lest anyone ask, the other line to the tank is a return line, another Subie legacy item that proved useful. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439889#439889 Attachments: http://forums.matronics.com//files/img_2116_835.jpg ________________________________________________________________________________
Date: Mar 25, 2015
Thanks Jesse, That is the way I have been reading the plans. Just seemed like it would look nicer to have something there. On Wed, Mar 25, 2015 at 8:01 PM, Jesse Saint wrote: > Some have used rubber channel around the leading edge, but along the fuse > skin where there is an angle to screw the fairing on there is nothing. > > Jesse Saint > I-TEC, Inc. > jesse(at)itecusa.org > www.itecusa.org > www.mavericklsa.com > C: 352-427-0285 > O: 352-465-4545 > F: 815-377-3694 > > Sent from my iPhone > > On Mar 25, 2015, at 10:37 PM, Kelly McMullen wrote: > > I don't find mention of any weatherstrip for the wing root fairings. Am I > missing something? What have others done to make a nice joint between > fuselage skin and wing root fairing? > > On Wed, Mar 25, 2015 at 1:11 PM, Patrick Pulis > wrote: > >> > >> >> Any pictures of the wing root filter installations please Les? >> >> Warm regards >> >> Patrick >> >> >> > * > > D============================================ > List"">http://www.matronics.com/Navigator?RV10-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > ________________________________________________________________________________
Date: Mar 25, 2015
I don't know if still possible from other distributors,, but I got mine a couple years ago from a distributor for around 12K including shipping, so it is definitely a fair price. Just not sure I would switch after having my MT on hand. I guess if I came into new money the carbon fiber Hartzell or equivalent might be attractive. On Wed, Mar 25, 2015 at 7:55 PM, Danny Riggs wrote: > not bad price: prop is $10500, assembly and shipping is $1200, governor > about $1000 > How do I know?? Just got mine from Vans.[image: Emoji] > > > Subject: RV10-List: Re: New MT 3 Blade Propeller For Sale > > From: mike.nova1973(at)gmail.com > > Date: Wed, 25 Mar 2015 19:30:41 -0700 > > To: rv10-list(at)matronics.com > > > > > > > MTV-12-B/193-53 with Governor to fit IO 540 RV-10 > > All info in first posting in thread. > > > > -------- > > RV-10 #40447 > > Fuselage almost done. > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=439884#439884 > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Wing root fairings
Date: Mar 26, 2015
I used the same rubber channel that is used on the wing root for RV-8s and such (same material as used on the bottom of the Horizontal Stabilizer, just longer) I purchased the material from Van=99s. Like Jesse says, no need for this along the fuselage skin where there is a bracket to screw down the root fairing. Not installing this trim made the leading edge to fuselage transition look unfinished. When you do this you=99ll need open the leading edge to fuselage gap perhaps 1/8=9D to =C2=BC=9D to provide room for the channel. Also use a little black RTV in the channel that slides over the root fairing to make sure it does not work itself out and start flapping on the side of the fuselage (this was a rude awaking during my third flight in the RV-8A). Put the RTV in the channel then install on the leading edge fairing such that the RTV sets up with the channel in place. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Wednesday, March 25, 2015 11:42 PM Subject: Re: RV10-List: Wing root fairings Thanks Jesse, That is the way I have been reading the plans. Just seemed like it would look nicer to have something there. On Wed, Mar 25, 2015 at 8:01 PM, Jesse Saint wrote: Some have used rubber channel around the leading edge, but along the fuse skin where there is an angle to screw the fairing on there is nothing. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone On Mar 25, 2015, at 10:37 PM, Kelly McMullen wrote: I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing? On Wed, Mar 25, 2015 at 1:11 PM, Patrick Pulis wrote: Any pictures of the wing root filter installations please Les? Warm regards Patrick D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Mar 26, 2015
Yep, you need to create room for it between the cover and the fuselage skin. I don't have any RTV on it, and it stays on fine even where there no support angle underneath, just need to make sure the gap is not too big. With the J shaped rubber I used there's not a lot of rubber sticking out, maybe only 3/16. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439899#439899 ________________________________________________________________________________
Date: Mar 26, 2015
I used the Summit brand filter, but they are all good. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439900#439900 ________________________________________________________________________________
Date: Mar 26, 2015
I used some edge guard that looks like this. http://www.trimlok.com/prod/Edge-Guard/Edge-Trims/All-Product-Categories_120/Edge-Guard_119.aspx I got it at a local automotive store up in Minnesota. It fits snugly on the edge with no adhesive required. No need to trim the metal to make it fit, either. I also put it on the edge of my glareshield, which I painted flat black rather than covering it. The material was very inexpensive, and seven years and counting it still looks great. Sounds like the same type of material that Les used. Will try to get a pic to post in the next day or two. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439904#439904 ________________________________________________________________________________
Date: Mar 26, 2015
I've been wondering what to do with the glareshield ..... and you nailed it. I went the McMaster-Carr route for the door seals ...... and that ought to work just dandy for the edge of the glareshield. I'll have to buy some for a thinner edge though. Thanks for the mental trigger! Linn On 3/26/2015 3:24 PM, dmaib(at)me.com wrote: > > I used some edge guard that looks like this. > > http://www.trimlok.com/prod/Edge-Guard/Edge-Trims/All-Product-Categories_120/Edge-Guard_119.aspx > > I got it at a local automotive store up in Minnesota. It fits snugly on the edge with no adhesive required. No need to trim the metal to make it fit, either. I also put it on the edge of my glareshield, which I painted flat black rather than covering it. The material was very inexpensive, and seven years and counting it still looks great. Sounds like the same type of material that Les used. Will try to get a pic to post in the next day or two. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439904#439904 > > ________________________________________________________________________________
Date: Mar 26, 2015
I found this to be a good product for the glare shield edge: http://www.cleavelandtool.com/Glare-Shield-Edge-Trim-60/productinfo/GSE60/#. VRRssHl0yUk I too just painted the top of the glare shield flat black. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters Sent: Thursday, March 26, 2015 4:07 PM Subject: Re: RV10-List: Re: Wing root fairings I've been wondering what to do with the glareshield ..... and you nailed it. I went the McMaster-Carr route for the door seals ...... and that ought to work just dandy for the edge of the glareshield. I'll have to buy some for a thinner edge though. Thanks for the mental trigger! Linn On 3/26/2015 3:24 PM, dmaib(at)me.com wrote: > > I used some edge guard that looks like this. > > http://www.trimlok.com/prod/Edge-Guard/Edge-Trims/All-Product-Categories_120 /Edge-Guard_119.aspx > > I got it at a local automotive store up in Minnesota. It fits snugly on the edge with no adhesive required. No need to trim the metal to make it fit, either. I also put it on the edge of my glareshield, which I painted flat black rather than covering it. The material was very inexpensive, and seven years and counting it still looks great. Sounds like the same type of material that Les used. Will try to get a pic to post in the next day or two. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=439904#439904 > > ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Mar 26, 2015
I can now insert photos of your courtesy cars into the app listings. Feel free to email me your photos, and please be sure to indicate in the title of the email the airport ID and/or city location, and if there is more than one FBO, which one the car is located at. The app has broken 1400 locations nationwide. Thanks, Glenn Email to airportcars101(at)gmail.com -------- Glenn Brasch RV-9A Flying 1952 Piper Tri-Pacer Medevac Helicopter Pilot (Ret) Tucson, Arizona Owner, www.RVairspace.com and "Airport Courtesy Cars" Smart Phone App. Over 1400 cars nationwide. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=439912#439912 ________________________________________________________________________________
Date: Mar 27, 2015
Subject: Re: Lightspeed Zulu 2 and PFX in the RV-10
Got the AKG, and I like the bluetooth music, inclusion of both twin and LEMO plugs, and it's comfortable, but the ANR just isn't as good as the Bose's. I think I'll be getting another Bose. -Rob On Mon, Mar 23, 2015 at 7:34 AM, Rob Kochman wrote: > Thanks, everyone. I just ordered the AKG and will try that, then make a > decision. > > I actually already have a set of QT Halos. Very comfortable, but the > noise reduction isn't nearly as good as my A20s. The in-the-ear design i s > ineffective in blocking low frequencies, in my experience. > > -Rob > > On Mon, Mar 23, 2015 at 6:20 AM, Geoff Combs < > g.combs(at)aerosportmodeling.com> wrote: > >> I have 2 pairs A10 and 2 pairs A20=99s. The A20=99s are bett er than the 10=9Ds. >> I have tried Zulu 2=99s a couple times but always liked the Bose. >> >> So we did a direct comparison in another RV-10 and they had Lightspeed >> Zulu 2=99s. We were flying along for about 20 minutes. He with his Zulu 2 and >> Myself with the A20. We swapped and flew for 10 minutes or so and we the n >> gave our thoughts. We both felt the Bose was superior to the lightspeed. AS >> for comfort I dislike the Zulu=99s it=99s just not comfortab le for me. I can >> fly 6-7 hours with the Bose and not even realize I have them on. I think >> the fit and Comfort for each individual is different but as for noise >> reduction and quality I feel the Bose are superior. As for the service f rom >> Bose they have been excellent. I take my in at Oshkosh every year and th ey >> have check them and replaced items at no cost that they feel Need >> attention. >> >> With my A20=99s on and no sunglasses you can almost not hear my en gine at >> cruise they are that quite. It took me a while to get use to that. >> >> FWIW >> >> Buy what you want and feel comfortable in. They all work >> >> >> >> >> >> Geoff Combs >> >> >> >> *From:* owner-rv10-list-server(at)matronics.com [mailto: >> owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman >> *Sent:* Friday, March 20, 2015 12:25 PM >> *To:* rv10-list >> *Subject:* RV10-List: Lightspeed Zulu 2 and PFX in the RV-10 >> >> >> >> Last time I bought a headset, I compared the Bose A20 ad Lightspeed Zulu >> 2, and the Zulu 2 had substantially worse Bose A20 noise reduction. I n eed >> a new headset again, so I bought the Zulu PFX and flew with it the other >> night. The PFX also has substantially worse noise reduction than the A2 0. >> My A20 isn't quite comfortable on long flights, which I why I keep tryin g >> alternatives. >> >> >> >> Has anyone else compared the A20 to the Lightspeed headsets head-to-head >> in the RV-10 and have a similar result? People generally seem to prefer >> one over the other slightly, but the difference is huge in my experience , >> which makes me think something else is going on (or I'm just weird). >> >> >> >> -Rob >> >> >> >> -- >> >> Rob Kochman >> RV-10 Flying since March 2011 >> >> Woodinville, WA >> >> http://kochman.net/N819K >> >> >> >> >> >> *http://www.matronics.com/Navigator?RV10-List * >> >> *http://forums.matronics.com * >> >> *http://www.matronics.com/contribution * >> >> >> >> * >> =========== ronics.com/Navigator?RV10-List> =========== =========== com/contribution> =========== >> >> * >> >> > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 27, 2015
good feedback! Thanks! From: Rob Kochman Sent: Friday, March 27, 2015 9:27 PM Subject: Re: RV10-List: Lightspeed Zulu 2 and PFX in the RV-10 Got the AKG, and I like the bluetooth music, inclusion of both twin and LEMO plugs, and it's comfortable, but the ANR just isn't as good as the Bose's. I think I'll be getting another Bose. -Rob On Mon, Mar 23, 2015 at 7:34 AM, Rob Kochman wrote: Thanks, everyone. I just ordered the AKG and will try that, then make a decision. I actually already have a set of QT Halos. Very comfortable, but the noise reduction isn't nearly as good as my A20s. The in-the-ear design is ineffective in blocking low frequencies, in my experience. -Rob On Mon, Mar 23, 2015 at 6:20 AM, Geoff Combs wrote: I have 2 pairs A10 and 2 pairs A20=99s. The A20=99s are better than the 10=9Ds. I have tried Zulu 2=99s a couple times but always liked the Bose. So we did a direct comparison in another RV-10 and they had Lightspeed Zulu 2=99s. We were flying along for about 20 minutes. He with his Zulu 2 and Myself with the A20. We swapped and flew for 10 minutes or so and we then gave our thoughts. We both felt the Bose was superior to the lightspeed. AS for comfort I dislike the Zulu=99s it=99s just not comfortable for me. I can fly 6-7 hours with the Bose and not even realize I have them on. I think the fit and Comfort for each individual is different but as for noise reduction and quality I feel the Bose are superior. As for the service from Bose they have been excellent. I take my in at Oshkosh every year and they have check them and replaced items at no cost that they feel Need attention. With my A20=99s on and no sunglasses you can almost not hear my engine at cruise they are that quite. It took me a while to get use to that. FWIW Buy what you want and feel comfortable in. They all work Geoff Combs From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Friday, March 20, 2015 12:25 PM To: rv10-list Subject: RV10-List: Lightspeed Zulu 2 and PFX in the RV-10 Last time I bought a headset, I compared the Bose A20 ad Lightspeed Zulu 2, and the Zulu 2 had substantially worse Bose A20 noise reduction. I need a new headset again, so I bought the Zulu PFX and flew with it the other night. The PFX also has substantially worse noise reduction than the A20. My A20 isn't quite comfortable on long flights, which I why I keep trying alternatives. Has anyone else compared the A20 to the Lightspeed headsets head-to-head in the RV-10 and have a similar result? People generally seem to prefer one over the other slightly, but the difference is huge in my experience, which makes me think something else is going on (or I'm just weird). -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comht tp://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 30, 2015
Subject: Project For Sale RV-10 #14220
Failing memory health forces me to sell my RV-10 project: Kit with factory assembled wings, all rest of kit assembled except pants, fairings for struts and tail. Tanks tested, fuel lines (and return for FI), beige interior by Flight Aware, panel with GRT 8" EFIS, 4 place stereo intercom. Presently has Mazda 3 rotor B-20 engine and controller & EM3 engine monitor installed (overhauled by Bruce Turentine) awaiting pan, alternators, water and oil radiators to be installed. Add prop to fly. Asking $60K with engine, or $54K without. Many more photos, detail list of panel details via email. Call Phil at 630/674-2116 cell. Located West of Chicago near LL-22. ________________________________________________________________________________
Date: Mar 31, 2015
Subject: Re: Project For Sale RV-10 #14220 -- photos ??
I see my brief ad to sell my RV-10 shows up in today's posting and digest, BUT the 4 photos do not. They were attached to the original email, AND sent to the photo list with request that they be posted with the email ad. Did I misread your directions, or not follow them correctly? Any help would be appreciated. Phil White ________________________________________________________________________________
Subject: Hartzell prop lubrication
Date: Mar 31, 2015
I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? Thanks, Bob Sent from my iPhone ________________________________________________________________________________
Date: Mar 31, 2015
Subject: Re: Hartzell prop lubrication
Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. On Mar 31, 2015 10:01 AM, "Bob Leffler" wrote: > > I've just started my conditional and was reading the maintenance > procedures for the Hartzell prop. It cautions you not to over lubricate. > > My naive question, is how can you tell when you have the proper amount of > lubricant? Is it when it starts oozing out the other fitting? > > Thanks, > > Bob > > Sent from my iPhone > > ________________________________________________________________________________
Date: Mar 31, 2015
Yes, put I usually pump out some old the dirty grease while I'm at it. I think over lubricate would apply if you did not remove the bottom zerk and pumped up the prop. I cant see over lubricating a prop that has room to ooze out. -----Original Message----- From: Bob Leffler Sent: Tuesday, March 31, 2015 9:54 AM Subject: RV10-List: Hartzell prop lubrication I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? Thanks, Bob Sent from my iPhone ________________________________________________________________________________
Date: Mar 31, 2015
Max number of pumps (I believe 6) OR excess coming out opposite zerk which ever happens first. Dave Leikam > On Mar 31, 2015, at 12:04 PM, John Cox wrote: > > Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. > > On Mar 31, 2015 10:01 AM, "Bob Leffler" > wrote: > > > I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. > > My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? > > Thanks, > > Bob > > Sent from my iPhone > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > > > <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Mar 31, 2015
Bob, I always remove the fitting on the leading edge and pump from the trailing edge until i see movement of grease at the open hole. I then put the plug back in and do the other blade. Some say just 2 pumps per fitting, but I don't know if that is without removing the fittings or with them out. Jesse Saint I-TEC, Inc. jesse(at)itecusa.org www.itecusa.org www.mavericklsa.com C: 352-427-0285 O: 352-465-4545 F: 815-377-3694 Sent from my iPhone > On Mar 31, 2015, at 12:54 PM, Bob Leffler wrote: > > > I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. > > My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? > > Thanks, > > Bob > > Sent from my iPhone > > > > ________________________________________________________________________________
Date: Mar 31, 2015
Hey Phil, Your pictures came through on my email for the RV10 list ... not quite big enough files to blow up for detail, but enough to see what you've got. It's always sad to hear that a builder is selling for unfortunate circumstances. I wish you well on your journey, - Lew ________________________________________________________________________________
Date: Mar 31, 2015
Attached is a photo of my SCAT tube solution. I made a fiberglass tube to go around the Andair fuel valve stem. The tube is held in place by 2 pipe clamps that are riveted to the tunnel. Larry ________________________________________________________________________________
Date: Mar 31, 2015
Award for most accurate response. Believe it or not you can over lubricate even with a zerk removed. If any of the old grease has thickened/hardened, it will restrict grease coming out the zerk hole. I generally limit to 4 strokes on hand grease gun or start of grease coming out removed zerk hole. Also, use precisely whatever grease the label on the prop calls for, whether that is Aeroshell 6, 22 or some other flavor. Unlike oils, greases do use different thickening agents, and they are not all compatible. Do not worry about not having enough grease...there is plenty in the hub, unless you see it slinging out the seals at the blade roots. Kelly A&P/IA On 3/31/2015 10:28 AM, David Leikam wrote: > Max number of pumps (I believe 6) OR excess coming out opposite zerk > which ever happens first. > > Dave Leikam > >> On Mar 31, 2015, at 12:04 PM, John Cox > > wrote: >> >> Max number of pumps and excess coming out the opposing threads of >> adjacent removed zerk. Per Hartzell S.L. >> >> On Mar 31, 2015 10:01 AM, "Bob Leffler" > > wrote: >> >> > >> >> I've just started my conditional and was reading the maintenance >> procedures for the Hartzell prop. It cautions you not to over >> lubricate. >> >> My naive question, is how can you tell when you have the proper >> amount of lubricant? Is it when it starts oozing out the other >> fitting? >> >> Thanks, >> >> Bob >> >> Sent from my iPhone >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Date: Mar 31, 2015
I fail to understand why you would stop at 6? pumps when there's no excess ..... and pumps aren't created equal. Anybody know why you'd quit pumping before the cavity is full??? Linn ..... working on a Sam James plenum On 3/31/2015 1:28 PM, David Leikam wrote: > Max number of pumps (I believe 6) OR excess coming out opposite zerk > which ever happens first. > > Dave Leikam > >> On Mar 31, 2015, at 12:04 PM, John Cox > > wrote: >> >> Max number of pumps and excess coming out the opposing threads of >> adjacent removed zerk. Per Hartzell S.L. >> >> On Mar 31, 2015 10:01 AM, "Bob Leffler" > > wrote: >> >> > >> >> I've just started my conditional and was reading the maintenance >> procedures for the Hartzell prop. It cautions you not to over >> lubricate. >> >> My naive question, is how can you tell when you have the proper >> amount of lubricant? Is it when it starts oozing out the other >> fitting? >> >> Thanks, >> >> Bob >> >> Sent from my iPhone >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Date: Mar 31, 2015
You don't know that you haven't delivered an excess. You do NOT need the cavity full. The prop really only needs 1-2 pumps of grease per blade. The extra pumps are for those that may have substandard grease gun, to give you a safe range without excess. Excess will cause grease to get past the blade seals and may cause them to fail. Based on both Hartzell rep and pubs, and prop overhaul shop. On 3/31/2015 1:43 PM, Linn Walters wrote: > I fail to understand why you would stop at 6? pumps when there's no > excess ..... and pumps aren't created equal. Anybody know why you'd > quit pumping before the cavity is full??? > Linn ..... working on a Sam James plenum > > On 3/31/2015 1:28 PM, David Leikam wrote: >> Max number of pumps (I believe 6) OR excess coming out opposite zerk >> which ever happens first. >> >> Dave Leikam >> >>> On Mar 31, 2015, at 12:04 PM, John Cox >> > wrote: >>> >>> Max number of pumps and excess coming out the opposing threads of >>> adjacent removed zerk. Per Hartzell S.L. >>> >>> On Mar 31, 2015 10:01 AM, "Bob Leffler" >> > wrote: >>> >>> > >>> >>> I've just started my conditional and was reading the maintenance >>> procedures for the Hartzell prop. It cautions you not to over >>> lubricate. >>> >>> My naive question, is how can you tell when you have the proper >>> amount of lubricant? Is it when it starts oozing out the >>> other fitting? >>> >>> Thanks, >>> >>> Bob >>> >>> Sent from my iPhone >>> >>> ========== >>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> * >>> >>> >>> * >> >> * >> >> >> * > > * > > > * ________________________________________________________________________________
Date: Mar 31, 2015
I think that's the question I was getting at. Until it oozes out the othe r side, you really have no idea the true quantity of grease in the hub. It does make sense that you can't over fill with the other fitting off, but t hen the warning seems a little silly. Sent from my iPad > On Mar 31, 2015, at 4:43 PM, Linn Walters wrote: > > I fail to understand why you would stop at 6? pumps when there's no excess ..... and pumps aren't created equal. Anybody know why you'd quit pumping b efore the cavity is full??? > Linn ..... working on a Sam James plenum > >> On 3/31/2015 1:28 PM, David Leikam wrote: >> Max number of pumps (I believe 6) OR excess coming out opposite zerk whic h ever happens first. >> >> Dave Leikam >> >>> On Mar 31, 2015, at 12:04 PM, John Cox wrote: >>> >>> Max number of pumps and excess coming out the opposing threads of adjace nt removed zerk. Per Hartzell S.L. >>> >>>> On Mar 31, 2015 10:01 AM, "Bob Leffler" wrote: >>>> >>>> I've just started my conditional and was reading the maintenance proced ures for the Hartzell prop. It cautions you not to over lubricate. >>>> >>>> My naive question, is how can you tell when you have the proper amount o f lubricant? Is it when it starts oozing out the other fitting? >>>> >>>> Thanks, >>>> >>>> Bob >>>> >>>> Sent from my iPhone >>>> >>>> ========== >>>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> _blank">http://forums.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> target="_blank">http://www.matronics.com/contribution >>>> ========== > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Mar 31, 2015
When are people seeing grease coming out the other side? I've done 3 annuals now, doing 6 pumps per blade each time, and I haven't seen any come out the other side yet. On Tue, Mar 31, 2015 at 2:06 PM, Bob Leffler wrote: > I think that's the question I was getting at. Until it oozes out the > other side, you really have no idea the true quantity of grease in the hub. > > > It does make sense that you can't over fill with the other fitting off, > but then the warning seems a little silly. > > Sent from my iPad > > On Mar 31, 2015, at 4:43 PM, Linn Walters wrote: > > I fail to understand why you would stop at 6? pumps when there's no excess > ..... and pumps aren't created equal. Anybody know why you'd quit pumping > before the cavity is full??? > Linn ..... working on a Sam James plenum > > On 3/31/2015 1:28 PM, David Leikam wrote: > > Max number of pumps (I believe 6) OR excess coming out opposite zerk which > ever happens first. > > Dave Leikam > > On Mar 31, 2015, at 12:04 PM, John Cox wrote: > > Max number of pumps and excess coming out the opposing threads of > adjacent removed zerk. Per Hartzell S.L. > On Mar 31, 2015 10:01 AM, "Bob Leffler" wrote: > >> >> I've just started my conditional and was reading the maintenance >> procedures for the Hartzell prop. It cautions you not to over lubricate. >> >> My naive question, is how can you tell when you have the proper amount of >> lubricant? Is it when it starts oozing out the other fitting? >> >> Thanks, >> >> Bob >> >> Sent from my iPhone >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > > * > > > * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 31, 2015
One important tip is to make sure you clean out the exit hole per Hartzell=99s instructions, piece of safety wire works well. I didn=99t do this at first but after pumping some grease in I cleaned it out better and once the dried bit got out of the way some came out under pressure. As long as you limit the number of pumps it=99s probably not a huge deal, but if you are looking to see some exit then it=99s critical otherwise you=99ll pump too much in and it will find a way out in places you don=99t want it to. Marcus On Mar 31, 2015, at 5:28 PM, Rob Kochman wrote: When are people seeing grease coming out the other side? I've done 3 annuals now, doing 6 pumps per blade each time, and I haven't seen any come out the other side yet. On Tue, Mar 31, 2015 at 2:06 PM, Bob Leffler > wrote: I think that's the question I was getting at. Until it oozes out the other side, you really have no idea the true quantity of grease in the hub. It does make sense that you can't over fill with the other fitting off, but then the warning seems a little silly. Sent from my iPad On Mar 31, 2015, at 4:43 PM, Linn Walters > wrote: > I fail to understand why you would stop at 6? pumps when there's no excess ..... and pumps aren't created equal. Anybody know why you'd quit pumping before the cavity is full??? > Linn ..... working on a Sam James plenum > > On 3/31/2015 1:28 PM, David Leikam wrote: >> Max number of pumps (I believe 6) OR excess coming out opposite zerk which ever happens first. >> >> Dave Leikam >> >>> On Mar 31, 2015, at 12:04 PM, John Cox > wrote: >>> >>> Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. >>> >>> On Mar 31, 2015 10:01 AM, "Bob Leffler" > wrote: > >>> >>> I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. >>> >>> My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? >>> >>> Thanks, >>> >>> Bob >>> >>> Sent from my iPhone >>> >>> ========== >>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> >>> ========== >>> >>> >>> >>> >>> >>> >> >> >> >> > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D lass=""> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> ________________________________________________________________________________
Date: Mar 31, 2015
I with Linn- unless I can see grease, I would have no idea how much grease is actually in the hub. I get it, after this thread, that 6 pumps may be enough grease for the what Hartzell requires, but I prefer to know there is grease coming out and that I am not short on grease (aka- I thought I pumped it 6 times but the amount of grease that came out was minimal for those pumps) to answer your question Rob- every annual. What I find interesting is that although I fill the hub, every year I seem to need 6 or more pumps to get the grease to show, which tells me I use more grease each year than I re-pump, hence my going until I see grease come out and sometimes, as mentioned before, when its really dirty, until I see cleaner grease. 3 years with no leaks, so I am happy knowing I have grease in the hub and that it cleaner each year, than just 6 pumps. From: Rob Kochman Sent: Tuesday, March 31, 2015 2:28 PM Subject: Re: RV10-List: Hartzell prop lubrication When are people seeing grease coming out the other side? I've done 3 annuals now, doing 6 pumps per blade each time, and I haven't seen any come out the other side yet. On Tue, Mar 31, 2015 at 2:06 PM, Bob Leffler wrote: I think that's the question I was getting at. Until it oozes out the other side, you really have no idea the true quantity of grease in the hub. It does make sense that you can't over fill with the other fitting off, but then the warning seems a little silly. Sent from my iPad On Mar 31, 2015, at 4:43 PM, Linn Walters wrote: I fail to understand why you would stop at 6? pumps when there's no excess ..... and pumps aren't created equal. Anybody know why you'd quit pumping before the cavity is full??? Linn ..... working on a Sam James plenum On 3/31/2015 1:28 PM, David Leikam wrote: Max number of pumps (I believe 6) OR excess coming out opposite zerk which ever happens first. Dave Leikam On Mar 31, 2015, at 12:04 PM, John Cox wrote: Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. On Mar 31, 2015 10:01 AM, "Bob Leffler" wrote: I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? Thanks, Bob Sent from my iPhone ========== -List" target="_blank">http://www.matronics.com/Navigator?RV10-List ========== FORUMS - _blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ========== 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D lass=""> 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Mar 31, 2015
From: David Clifford <davidsoutpost(at)comcast.net>
The manual for greasing the hub does not make a whole lot of sense IMHO. If the hub is not leaking grease, as it should not do, it will eventually fill with grease and after a few times servicing the hub will fill up and ooze out the the removed zerk fitting hole. I pumped until I could observe movement of grease inside the open zerk hole. Maybe I am wrong but I THINK the hub will eventually fill up eventually? David Clifford N959RV ----- Original Message ----- From: "Rob Kochman" <rv10rob(at)gmail.com> Sent: Tuesday, March 31, 2015 5:28:09 PM Subject: Re: RV10-List: Hartzell prop lubrication When are people seeing grease coming out the other side? I've done 3 annuals now, doing 6 pumps per blade each time, and I haven't seen any come out the other side yet. On Tue, Mar 31, 2015 at 2:06 PM, Bob Leffler < rv(at)thelefflers.com > wrote: I think that's the question I was getting at. Until it oozes out the other side, you really have no idea the true quantity of grease in the hub. It does make sense that you can't over fill with the other fitting off, but then the warning seems a little silly. Sent from my iPad On Mar 31, 2015, at 4:43 PM, Linn Walters < flying-nut(at)cfl.rr.com > wrote:
On Mar 31, 2015, at 12:04 PM, John Cox < rv10pro(at)gmail.com > wrote: Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. On Mar 31, 2015 10:01 AM, "Bob Leffler" < rv(at)thelefflers.com > wrote:
I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? Thanks, Bob Sent from my iPhone =========== -List" target="_blank"> http://www.matronics.com/Navigator?RV10-List =========== FORUMS - _blank"> http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank"> http://www.matronics.com/contribution ===========
3D============================================ lass=""> 3D============================================ 3D============================================ 3D=============================================
Date: Mar 31, 2015
I just finished my annual and the prop hub took exactly 4 pumps Aeroshell 6 each zerk until grease started to poke out the opposite zerk. Just doing what the manual says. No problems in 375 hours. Dave Leikam > On Mar 31, 2015, at 5:30 PM, David Clifford wrote: > > The manual for greasing the hub does not make a whole lot of sense IMHO. If the hub is not leaking grease, as it should not do, it will eventually fill with grease and after a few times servicing the hub will fill up and ooze out the the removed zerk fitting hole. I pumped until I could observe movement of grease inside the open zerk hole. Maybe I am wrong but I THINK the hub will eventually fill up eventually? > > David Clifford > N959RV > > From: "Rob Kochman" <rv10rob(at)gmail.com> > To: "rv10-list" > Sent: Tuesday, March 31, 2015 5:28:09 PM > Subject: Re: RV10-List: Hartzell prop lubrication > > When are people seeing grease coming out the other side? I've done 3 annuals now, doing 6 pumps per blade each time, and I haven't seen any come out the other side yet. > > On Tue, Mar 31, 2015 at 2:06 PM, Bob Leffler > wrote: > I think that's the question I was getting at. Until it oozes out the other side, you really have no idea the true quantity of grease in the hub. > > It does make sense that you can't over fill with the other fitting off, but then the warning seems a little silly. > > Sent from my iPad > > On Mar 31, 2015, at 4:43 PM, Linn Walters > wrote: > > I fail to understand why you would stop at 6? pumps when there's no excess ..... and pumps aren't created equal. Anybody know why you'd quit pumping before the cavity is full??? > Linn ..... working on a Sam James plenum > > On 3/31/2015 1:28 PM, David Leikam wrote: > Max number of pumps (I believe 6) OR excess coming out opposite zerk which ever happens first. > > Dave Leikam > > On Mar 31, 2015, at 12:04 PM, John Cox > wrote: > > Max number of pumps and excess coming out the opposing threads of adjacent removed zerk. Per Hartzell S.L. > > On Mar 31, 2015 10:01 AM, "Bob Leffler" > wrote: > > > I've just started my conditional and was reading the maintenance procedures for the Hartzell prop. It cautions you not to over lubricate. > > My naive question, is how can you tell when you have the proper amount of lubricant? Is it when it starts oozing out the other fitting? > > Thanks, > > Bob > > Sent from my iPhone > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List <http://www.matronics.com/Navigator?RV10-List> > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution <http://www.matronics.com/contribution> > ========== > > > > > > > > > > > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > lass=""> > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D > > > > > -- > Rob Kochman > RV-10 Flying since March 2011 > Woodinville, WA > http://kochman.net/N819K > > > get="_blank" data-mce-href="http://www.matronics.com/Navigator?RV10-List">http://www. matronics.com/Navigator?RV10-List > ta-mce-href="http://forums.matronics.com">http://forums.matronics.com > _blank" data-mce-href="http://www.matronics.com/contribution">http://www.matroni cs.com/contribution > > > > <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Mar 31, 2015
I finally got a photo of my wing root edge guard product. As I mentioned earlier, no trimming of the wing root material was required. It is still looking fine at nearly seven years. No comments about the dirty airplane! [Embarassed] -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440123#440123 ________________________________________________________________________________
Date: Apr 02, 2015
I was told by a Hartzell rep. that they would rather we not add any grease at all rather than add more than the instructions say. You might want to check with them. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440226#440226 ________________________________________________________________________________
Date: Apr 03, 2015
I don't know, I think some of the doubters should test the theory and just pump it full until it comes out... I did that once a long time ago (maybe 2007 or 8), thinking that my understanding was better than the manuals logic. Eventually, I ended up having grease sling out of the hub, and I had the prop re-sealed, which cost I think $860. So, those that doubt the manual can test the theory and see if they have the same problem. That way I won't be alone in the boat. If it happens to a few dozen of us who didn't believe the manual, then we'll know that the manual is smarter, right? But, if nobody else has the problem, then we can know that our vast pool of a couple dozen anecdotal cases are better than the stuff Hartzel tells us. :) I know me, I'm going to follow it to the letter from now on. Tim On 4/3/2015 12:01 AM, Ron B. wrote: > > I was told by a Hartzell rep. that they would rather we not add any grease at all rather than add more than the instructions say. You might want to check with them. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440226#440226 > > ________________________________________________________________________________
Date: Apr 03, 2015
I had some grease or something on my windshield last year after my annual and going to Oshkosh. Stopped at the hartzell booth to ask them their thoughts. They were very Responsive and concerned. I was then introduced to Scott Foster. Talked to him he got my contact info And called me the week after Oshkosh. They wanted to inspect my prop. Scott came up the next week and we removed the spinner Looked for leaks and determined a zerk fitting was a little loose. And leaking. Tighten it up Then we discussed the amount of grease. I had told him I pumped until Some came out. He said that 2-3 pumps no more. I pumped way more than that. The good news my prop was ok and he Said everything looked great for almost 500 hrs. But he did say no more than 2 pumps and told me not to grease mine at the next annual. Great customer service and Scott is great. Then I took him for a ride in the RV-10. He was impressed with the performance and loved the RV-10. He was drinking the the RV-10 koolaid and loving it. Geoff Sent from my iPhone Geoff Combs Aerosport Modeling & Design > On Apr 3, 2015, at 1:01 PM, Tim Olson wrote: > > > I don't know, I think some of the doubters should test the theory and > just pump it full until it comes out... > > I did that once a long time ago (maybe 2007 or 8), thinking that my > understanding was better than the manuals logic. > > Eventually, I ended up having grease sling out of the hub, and > I had the prop re-sealed, which cost I think $860. > > So, those that doubt the manual can test the theory and see if > they have the same problem. That way I won't be alone in the > boat. If it happens to a few dozen of us who didn't believe > the manual, then we'll know that the manual is smarter, right? > But, if nobody else has the problem, then we can know that our > vast pool of a couple dozen anecdotal cases are better than > the stuff Hartzel tells us. :) > > I know me, I'm going to follow it to the letter from now on. > Tim > > > >> On 4/3/2015 12:01 AM, Ron B. wrote: >> >> I was told by a Hartzell rep. that they would rather we not add any grease at all rather than add more than the instructions say. You might want to check with them. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=440226#440226 > > > > > ________________________________________________________________________________
Date: Apr 03, 2015
Done the theory, no leakage thus far! However, I appreciate this thread and will stick to the manual moving forward. I always worried that I didnt have enough grease, seems that that is normal and not to worry about! Thx -----Original Message----- From: Tim Olson Sent: Friday, April 03, 2015 10:01 AM Subject: Re: RV10-List: Re: Hartzell prop lubrication I don't know, I think some of the doubters should test the theory and just pump it full until it comes out... I did that once a long time ago (maybe 2007 or 8), thinking that my understanding was better than the manuals logic. Eventually, I ended up having grease sling out of the hub, and I had the prop re-sealed, which cost I think $860. So, those that doubt the manual can test the theory and see if they have the same problem. That way I won't be alone in the boat. If it happens to a few dozen of us who didn't believe the manual, then we'll know that the manual is smarter, right? But, if nobody else has the problem, then we can know that our vast pool of a couple dozen anecdotal cases are better than the stuff Hartzel tells us. :) I know me, I'm going to follow it to the letter from now on. Tim On 4/3/2015 12:01 AM, Ron B. wrote: > > I was told by a Hartzell rep. that they would rather we not add any grease > at all rather than add more than the instructions say. You might want to > check with them. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440226#440226 > > ________________________________________________________________________________
Date: Apr 03, 2015
So that leads to the question, why does their manual state six pumps? If that's too much and they are recommending something different, shouldn't Hartzell update the procedure in the manual? Then we have the issue of does my gun pump the same volume as somebody else's? It seems like it's still using a bit of magic and luck, since there is no effective method to measure the actual volume of grease until you pump too much and it oozes out the back. Sent from my iPhone > On Apr 3, 2015, at 1:44 PM, g.combs wrote: > > he ________________________________________________________________________________
Date: Apr 03, 2015
It's a real WAG on my part, but I'm guessing that the volume of grease isn't anywhere near critical. The WAG part: if there's sufficient grease to coat the blade seal to keep it flexible and offer some lubrication to the hub ... it's sufficient. Linn On 4/3/2015 2:54 PM, Bob Leffler wrote: > > So that leads to the question, why does their manual state six pumps? If that's too much and they are recommending something different, shouldn't Hartzell update the procedure in the manual? > > Then we have the issue of does my gun pump the same volume as somebody else's? > > It seems like it's still using a bit of magic and luck, since there is no effective method to measure the actual volume of grease until you pump too much and it oozes out the back. > > Sent from my iPhone > >> On Apr 3, 2015, at 1:44 PM, g.combs wrote: >> >> he > > ________________________________________________________________________________
Date: Apr 04, 2015
Actually the manual states it more exactly, they say 1fl. oz which is aprox 6 pumps with a .... see attached > On 4/3/2015 2:54 PM, Bob Leffler wrote: >> >> So that leads to the question, why does their manual state six >> pumps? If that's too much and they are recommending something >> different, shouldn't Hartzell update the procedure in the manual? ________________________________________________________________________________
Date: Apr 04, 2015
Hartzell recommends 1 oz or 6 strokes in their 30 minute Propeller Maintenance video. Six strokes on my gun provides about 1/4 oz. of Aeroshell 6. I will stick with 6 strokes and very little leakage. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440270#440270 ________________________________________________________________________________
Date: Apr 04, 2015
Provided 1/16" clearance between fuse and fairing. Sanded/cleaned/alodined, fillet of proseal and painted with the rest of the plane. Still looks fine. -------- Wayne G. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440271#440271 ________________________________________________________________________________
Subject: Firewall Passthroughs - Redux
Date: Apr 06, 2015
Hi Quite some time ago I posted a query regarding firewall pass throughs for control cables. Here is what I used from ACS: https://www.aircraftspruce.com/catalog/appages/6000metalgrommets.php?clickkey=729558 There weren't easy to find on the ACS website but they work just great. The pix is a bit misleading - three will fit within the spacing of the firewall insert. I had to clock the middle insert so it would ft but that was quite easy to do,. If you use these, be sure to get the right size "ball" insert for your control cables. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440343#440343 ________________________________________________________________________________
Subject: Insurance mystery
Date: Apr 07, 2015
I don't get it. There is an insurance company that baffles my mind. They specialize in direct sales (which you would think would be efficient), and advertise heavily to the experimental community in direct mail, magazine ads, a huge presence at OSH, etc. I get mailers all the time from this company and twice I have allowed them to offer me a quote, and both times that have been nearly twice as much as what I eventually ended up with. This last time I asked the embarrassed rep of this company why their quotes are so out of line and the answer I received was that the company truly isn't interested in making competitive quotes to experimental aircraft. So why, I asked, do they spend so much in marketing to a market segment they don't want? "I don't know" was the answer. "We deal with this every day." I told them they could reduce their mailing costs by removing me from their list and that they should probably reconsider their expensive ads claiming to love experimental business. Obviously they must underwrite enough paper to stay in business, but it sure seems like a strange way to operate to me. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440391#440391 ________________________________________________________________________________
Subject: Re: Insurance mystery
Date: Apr 07, 2015
I can't confirm that you are right ... But I would correct you if you were wrong. :D -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440395#440395 ________________________________________________________________________________
Date: Apr 07, 2015
Myron, I had the exact same experience, two quotes over two years, both more than twice the amount of the others, and finally telling them to stop mailing me. I have to admit I like Tim's "mail back" program better! :-) -Dj -- Dj Merrill - N1JOV - EAA Chapter 87 Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/ Glastar Flyer N866RH - http://deej.net/glastar/ ________________________________________________________________________________
Subject: Gust Locks
Date: Apr 07, 2015
Hi I am interested in a gust lock and am wondering if there are any current opinions regarding same. I am thinking that something that pins the surfaces is not what I want - I think I would prefer something that has a little give (ie uses elastics / bungee cords). I do have an email into Wild Blue Innovations but haven't heard back from them. I do have a couple of limitations -I have Control Approach rudder pedals and my control sticks have covers. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440398#440398 ________________________________________________________________________________
Subject: Gust Locks
Date: Apr 07, 2015
I have tried a couple, but I am back to H-Man. PVC pipe with rubber chair legs on one end and PVC cut on the other end to match the pedals. Use seat belt for stick. Hard to take off with them in......always placed on pilot side. I know it now exactly an H....looks something like this. All parts came from the aviation department of Home Depot. -----| |----- |--------| -----| |----- Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of kearney Sent: Tuesday, April 07, 2015 5:19 PM Subject: RV10-List: Gust Locks Hi I am interested in a gust lock and am wondering if there are any current opinions regarding same. I am thinking that something that pins the surfaces is not what I want - I think I would prefer something that has a little give (ie uses elastics / bungee cords). I do have an email into Wild Blue Innovations but haven't heard back from them. I do have a couple of limitations -I have Control Approach rudder pedals and my control sticks have covers. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440398#440398 ________________________________________________________________________________
Subject: Re: Gust Locks
Date: Apr 07, 2015
i have been happy with the GUST BUSTER Alan N6668G > On Apr 7, 2015, at 7:19 PM, kearney wrote: > > > Hi > > I am interested in a gust lock and am wondering if there are any current opinions regarding same. > > I am thinking that something that pins the surfaces is not what I want - I think I would prefer something that has a little give (ie uses elastics / bungee cords). > > I do have an email into Wild Blue Innovations but haven't heard back from them. > > I do have a couple of limitations -I have Control Approach rudder pedals and my control sticks have covers. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440398#440398 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
I have the same pedals. I made something out of pvc. I took t joints and cut them so they slip over the the top of the bottom pedal. I did something similar to fit the top of the seat box. I use Velcro that is fastened to the pvc to hold the stick in place. It works pretty good. Sent from my iPad > On Apr 7, 2015, at 7:19 PM, kearney wrote: > > > Hi > > I am interested in a gust lock and am wondering if there are any current opinions regarding same. > > I am thinking that something that pins the surfaces is not what I want - I think I would prefer something that has a little give (ie uses elastics / bungee cords). > > I do have an email into Wild Blue Innovations but haven't heard back from them. > > I do have a couple of limitations -I have Control Approach rudder pedals and my control sticks have covers. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440398#440398 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
Alan Will the gust buster accommodate a cover on the control stick? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440406#440406 ________________________________________________________________________________
Date: Apr 07, 2015
What a coincidence! Although I didn't bother last year, just last month I asked AVEMCO for a quote. Just to see if anything had changed. The answer is no change. Coverage limits are still "per person", not "per passenger" like everyone else. And, almost twice as expensive as my current policy (up for renewal soon). BUT, when I asked for a quote 2 years ago, they did send me a nice baseball cap with their name on it. My hangar-neighbor remarked that that was the most expensive cap he had ever seen. For Bob: I'm with USAIG thru Nationair. We had them many years ago when a partner had a prop strike, and we had nothing but the best experience with their claims guy. I also like their plain language policy. It even tells me what they'll pay for my labor, if I choose to repair a covered claim myself! BTW: Two years ago I asked Jenny (Nationair) why they didn't quote company X, which some others were reporting as offering very attractive rates. She told me that they wouldn't quote a company if they had doubts about their actual ability to stick around and pay for losses. A year later company X was no longer in the business. That's the kind of advice you pay a good broker for. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440409#440409 ________________________________________________________________________________
Date: Apr 07, 2015
I have the Bogart (sp?) tow bar, with the slight mod of two tabs attached to the ends to go over the rudder bars, under the brakes. Not sure if that works with your pedals. Handle goes against the seat back, held down by seat belt. stick goes thru the triangular hole. Not sure if your cover will fit, but the hole is pretty big. Use the other seat belt to hold the stick firmly in the 'V'. Hunt around the forum, I'm sure there are pictures somewhere. Works great, cost nothing, adds no extra weight, since I carry the tow bar anyway. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440410#440410 ________________________________________________________________________________
Date: Apr 07, 2015
do you have a picture of your cover? alan > On Apr 7, 2015, at 8:08 PM, kearney wrote: > > > Alan > > Will the gust buster accommodate a cover on the control stick? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440406#440406 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
les, the gust buster attaches about half way down the control. alan > On Apr 7, 2015, at 8:08 PM, kearney wrote: > > > Alan > > Will the gust buster accommodate a cover on the control stick? > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440406#440406 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
Isn't Avemco promoted by EAA? Or are they just a big advertiser? I would think that EAA wouldn't want to be associated with a company that does such a poor job with homebuilders. Tim > On Apr 7, 2015, at 7:24 PM, Bob Turner wrote: > > > What a coincidence! Although I didn't bother last year, just last month I asked AVEMCO for a quote. Just to see if anything had changed. The answer is no change. Coverage limits are still "per person", not "per passenger" like everyone else. And, almost twice as expensive as my current policy (up for renewal soon). BUT, when I asked for a quote 2 years ago, they did send me a nice baseball cap with their name on it. My hangar-neighbor remarked that that was the most expensive cap he had ever seen. > > For Bob: I'm with USAIG thru Nationair. We had them many years ago when a partner had a prop strike, and we had nothing but the best experience with their claims guy. I also like their plain language policy. It even tells me what they'll pay for my labor, if I choose to repair a covered claim myself! > > BTW: Two years ago I asked Jenny (Nationair) why they didn't quote company X, which some others were reporting as offering very attractive rates. She told me that they wouldn't quote a company if they had doubts about their actual ability to stick around and pay for losses. A year later company X was no longer in the business. That's the kind of advice you pay a good broker for. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440409#440409 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 07, 2015
Les; I miss some e-mails for some reason so I am only seeing your response and not who Alan is, however I have a antisplat gust lock that does require me to unzip the control stick cover and also requires the wires be routed on the inside of the stick, as the retainer is bolted to control stick. If you dont mind unzipping the cover and your wires are on the inside, I highly recommend it. http://antisplataero.com/RV-10_Ultimate_Gust_Lock.html another option, a home brew is- http://www.vansairforce.com/community/showthread.php?t=120730&highlight=gust+lock -----Original Message----- From: kearney Sent: Tuesday, April 07, 2015 5:08 PM Subject: RV10-List: Re: Gust Locks Alan Will the gust buster accommodate a cover on the control stick? Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440406#440406 ________________________________________________________________________________
Date: Apr 07, 2015
Tim Olson wrote: > Isn't Avemco promoted by EAA? Or are they just a big advertiser? I would think that EAA wouldn't want to be associated with a company that does such a poor job with homebuilders. > Tim > EAA and AVEMCO used to have some sort of official relationship, but had a friendly divorce some years ago. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440420#440420 ________________________________________________________________________________
Subject: Lord adhesive window installation question
Date: Apr 07, 2015
Hi everyone. I'm ready to attach the windows in my RV-10 and am looking for advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here about it, I obtained a few tubes from him. The plans call for installing the windows onto the doors when the doors are off and laying flat, presumably to allow gravity to help hold them in place while they are being cured. Of course, the rear windows can't be installed with that luxury, but they're smaller and lighter. And the windscreen rests largely on the nose while curing, so that should be less of an issue too. But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the windows on the doors while the doors are closed and on the plane - in essentially the same orientation as the rear windows? The reason I ask isn't due to laziness :-) But instead, I'm one of the lucky ones whose doors ended up fitting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper position. The last thing I want to do is to fit the windows to the doors when the doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would seem to me that adhering the windows to the doors when the doors are in their closed position will help keep everything aligned properly, so long as the Lord adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Lord adhesive window installation question
Date: Apr 08, 2015
The short answer is no. You need minimal pressure to hold the windows in p lace. If gravity causes any movement at all, you're going to have a major h eadache on your hands to resolve. I did my doors laying flat. On the rear windows I made fingers out of scrap aluminum to hold the pieces in place th at were cleco'd to the cabin cover. You could do the same on the doors. T he angle of the bend determines how much pressure is applied. You don't n eed much, just enough to keep things from moving. Sent from my iPad > On Apr 8, 2015, at 1:42 AM, Dan Charrois wrote: > > > Hi everyone. I'm ready to attach the windows in my RV-10 and am looking f or advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here abou t it, I obtained a few tubes from him. > > The plans call for installing the windows onto the doors when the doors ar e off and laying flat, presumably to allow gravity to help hold them in plac e while they are being cured. Of course, the rear windows can't be installe d with that luxury, but they're smaller and lighter. And the windscreen res ts largely on the nose while curing, so that should be less of an issue too. > > But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the wind ows on the doors while the doors are closed and on the plane - in essentiall y the same orientation as the rear windows? The reason I ask isn't due to l aziness :-) But instead, I'm one of the lucky ones whose doors ended up fit ting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper pos ition. The last thing I want to do is to fit the windows to the doors when t he doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would see m to me that adhering the windows to the doors when the doors are in their c losed position will help keep everything aligned properly, so long as the Lo rd! > adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. > > Thanks! > > Dan > --- > Dan Charrois > President, Syzygy Research & Technology > Phone: 780-961-2213 > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > >
Date: Apr 08, 2015
What Bob said. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 8, 2015, at 5:03 AM, Bob Leffler wrote: > > The short answer is no. You need minimal pressure to hold the windows in place. If gravity causes any movement at all, you're going to have a major headache on your hands to resolve. I did my doors laying flat. On the rear windows I made fingers out of scrap aluminum to hold the pieces in place that were cleco'd to the cabin cover. You could do the same on the doors. The angle of the bend determines how much pressure is applied. You don't need much, just enough to keep things from moving. > > > > > > > > Sent from my iPad > >> On Apr 8, 2015, at 1:42 AM, Dan Charrois wrote: >> >> >> Hi everyone. I'm ready to attach the windows in my RV-10 and am looking for advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here about it, I obtained a few tubes from him. >> >> The plans call for installing the windows onto the doors when the doors are off and laying flat, presumably to allow gravity to help hold them in place while they are being cured. Of course, the rear windows can't be installed with that luxury, but they're smaller and lighter. And the windscreen rests largely on the nose while curing, so that should be less of an issue too. >> >> But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the windows on the doors while the doors are closed and on the plane - in essentially the same orientation as the rear windows? The reason I ask isn't due to laziness :-) But instead, I'm one of the lucky ones whose doors ended up fitting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper position. The last thing I want to do is to fit the windows to the doors when the doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would seem to me that adhering the windows to the doors when the doors are in their closed position will help keep everything aligned properly, so long as the Lord! >> adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. >> >> Thanks! >> >> Dan >> --- >> Dan Charrois >> President, Syzygy Research & Technology >> Phone: 780-961-2213 > =================================== > =================================== > =================================== > =================================== > >
Subject: Insurance
Date: Apr 08, 2015
Timely discussion for me. I wish the other posters would disclose the actual amounts that you are paying to allow us to compare our quotes. My new airplane quote came in at $2604 /year. That=99s for $150,000 hull and $1 mil per occurance/$100,000 per passenger. This is named pilot only (for now), and hangared. Is this in the ballpark that others are paying? Chris Hukill Finally assembling ________________________________________________________________________________
Date: Apr 08, 2015
$1M/$100K/$5K medical 3 named pilots $165K hull $2072 through Skysmith. We've been with him since 2007. --Dave On Wed, Apr 8, 2015 at 5:32 AM, Chris Hukill wrote: > Timely discussion for me. I wish the other posters would disclose the > actual amounts that you are paying to allow us to compare our quotes. My > new airplane quote came in at $2604 /year. That=99s for $150,000 h ull and $1 > mil per occurance/$100,000 per passenger. This is named pilot only (for > now), and hangared. > Is this in the ballpark that others are paying? > Chris Hukill > Finally assembling > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Apr 08, 2015
I made an H type out of PVC and and extending pole used for paint rollers so I can easily adjust the length. Just cut it to size and rivet PVC parts in place. The handle of the pole end is rubber (no slip) so it just presses against the seat base just above where the stick comes out. Then position it on the top of the pedals so it also functions as a parking brake. The PVC pipe ends of the H fit perfectly into holes in pedals. Velcro strap secures it to the stick. Works very well. Very easy to make for minimal $ and very light weight. Pretty much impossible to NOT remember to remove before flight. Dave Leikam > On Apr 7, 2015, at 7:19 PM, kearney wrote: > > > Hi > > I am interested in a gust lock and am wondering if there are any current opinions regarding same. > > I am thinking that something that pins the surfaces is not what I want - I think I would prefer something that has a little give (ie uses elastics / bungee cords). > > I do have an email into Wild Blue Innovations but haven't heard back from them. > > I do have a couple of limitations -I have Control Approach rudder pedals and my control sticks have covers. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440398#440398 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 08, 2015
Make your own. Less than $20 from Lowes. I have been using this for almost three years. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440447#440447 Attachments: http://forums.matronics.com//files/img_2857_147.jpg ________________________________________________________________________________
Date: Apr 08, 2015
I have had the same experience as Tim. $1723 with $150,000 hull and standard other coverages. 1200 hours RVs, 550 hours in 10. 13,500 total ATP. Nationair/Global Dick Sipp ________________________________________________________________________________
Date: Apr 08, 2015
I did not use the Lord adhesive as I copied Dave Saylor's method using Silpruf instead. Silpruf almost has a proseal consistency so it might be less viscous which lends itself to this process a bit better maybe? I glued the door windows in while attached to the plane. I used several tie down straps and blocking to apply even, light pressure to the windows as well as duct tape to keep them from moving. I did this for both the door window transparencies and the fuselage ones. I think they came out ok but the only air time my project has seen is dust falling on it in the garage so YMMV. See pictures. Ben W Portland, OR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Charrois Sent: Tuesday, April 7, 2015 10:43 PM Subject: RV10-List: Lord adhesive window installation question Hi everyone. I'm ready to attach the windows in my RV-10 and am looking for advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here about it, I obtained a few tubes from him. The plans call for installing the windows onto the doors when the doors are off and laying flat, presumably to allow gravity to help hold them in place while they are being cured. Of course, the rear windows can't be installed with that luxury, but they're smaller and lighter. And the windscreen rests largely on the nose while curing, so that should be less of an issue too. But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the windows on the doors while the doors are closed and on the plane - in essentially the same orientation as the rear windows? The reason I ask isn't due to laziness :-) But instead, I'm one of the lucky ones whose doors ended up fitting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper position. The last thing I want to do is to fit the windows to the doors when the doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would seem to me that adhering the windows to the doors when the doors are in their closed position will help keep everything aligned properly, so long as the Lord! adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Apr 08, 2015
I don't recall if they had a relationship with EAA. They were for years the insurer of choice of AOPA. that ended around 25 yrs ago. They were one of the few that would write coverage for planes based in Alaska, but then only south of the Arctic Circle. I used them for a long time when I was based there. Once I moved to lower 48 I found other brokers/underwriters offered better coverage at less money. On Tue, Apr 7, 2015 at 10:24 PM, Bob Turner wrote: > > > Tim Olson wrote: > > Isn't Avemco promoted by EAA? Or are they just a big advertiser? I > would think that EAA wouldn't want to be associated with a company that > does such a poor job with homebuilders. > > Tim > > > > > EAA and AVEMCO used to have some sort of official relationship, but had a > friendly divorce some years ago. > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440420#440420 > > ________________________________________________________________________________
Subject: RE: Lord adhesive window installation question
Date: Apr 08, 2015
Since my RV-10 seems to be the poster child for bad decisions made with respect to window adhesives, I'll update the story. I used a composite adhesive back in 2007 (no longer on the market) that Glasair builders were asserting was much better than Weld-on 10. In 2011 at about 450 flight hours, I had a rear window blow out in high, cold conditions (15K feet, -12 C outside, inside heaters blasting). It was a big surprise and caused a lot of noise in the back seat and some turbulent air in the cockpit: http://faculty.washington.edu/dmasys/RV10/RV10_lostwind_rearview.jpg I replaced the rear window using Weld-on 10 as recommended by Vans. Fast forward to 2014, with 750 flight hours. Climbing through 12K feet to get over buildups near Eugene, OR, the entire pilot side door window shattered and departed the plane. Most of the window fragments hit the VS and HS, making a variety of dents in the leading edges. But some of them came in the cockpit at high velocity. Luckily I had the Rosen visor swung to the left, providing an extra layer of protection. A window fragment shattered the Rosen visor; I got a small neck lump from the impact, but nothing drew blood. So we continued on and made it back to base. (Performance observation: an RV-10 that does 170kts with all of its windows intact will still do 150kts at same power setting with the pilot side door window absent, but it is awfully windy inside). Suffice it to say, I removed and reattached the remaining windows with Weld-on 10. Moral of the story: make sure you have a compelling justification for deviating from Van's directions on mounting the RV-10 windows. -Dan Masys N104LD Subject: RV10-List: Lord adhesive window installation question From: Dan Charrois <dan(at)syz.com> Hi everyone. I'm ready to attach the windows in my RV-10 and am looking for advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here about it, I obtained a few tubes from him. The plans call for installing the windows onto the doors when the doors are off and laying flat, presumably to allow gravity to help hold them in place while they are being cured. Of course, the rear windows can't be installed with that luxury, but they're smaller and lighter. And the windscreen rests largely on the nose while curing, so that should be less of an issue too. But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the windows on the doors while the doors are closed and on the plane - in essentially the same orientation as the rear windows? The reason I ask isn't due to laziness :-) But instead, I'm one of the lucky ones whose doors ended up fitting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper position. The last thing I want to do is to fit the windows to the doors when the doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would seem to me that adhering the windows to the doors when the doors are in their closed position will help keep everything aligned properly, so long as the Lord adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Apr 08, 2015
I'm paying $2K (as of 10 months ago) for about the same coverage. Another factor they look at is your annual flying. Too much and your exposure is high; too little and you don't stay current. You want to be somewhere in the middle but I have no idea what the actual number desired is. Tim is right, expect higher rates until you have 100 hours in type. And some minimum total. A year ago it was very expensive with less than 200 TT. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440460#440460 ________________________________________________________________________________
Date: Apr 08, 2015
This is why it's hard to compare policies. Hull, liability limits, deductibles etc. can change a little and make significant changes in cost. The best you can do is contact their broker and get a quote with your numbers. Your broker will poll the available insurance companies still doing aircraft insurance. There are other factors ..... how long have you been with this company and do you have more than one aircraft insured. The little things create a minefield that make comparisons really difficult. Linn I'm with Aircraft & Marine, and the insurance company is U.S. Specialty Insurance Company. I only have liability on my planes so the comparison isn't worth anything. Linn On 4/8/2015 8:32 AM, Chris Hukill wrote: > Timely discussion for me. I wish the other posters would disclose the > actual amounts that you are paying to allow us to compare our quotes. > My new airplane quote came in at $2604 /year. Thats for $150,000 hull > and $1 mil per occurance/$100,000 per passenger. This is named pilot > only (for now), and hangared. > Is this in the ballpark that others are paying? > Chris Hukill > Finally assembling > * > > > * ________________________________________________________________________________
Date: Apr 09, 2015
Thanks, everyone, for the great response. I never even thought of using aluminum "fingers" like that (or straps and foam blocks as others have done). That's a great idea, and so simple too and straightforward too! I guess that even after getting this far with fibreglass, I still don't automatically realize that it's OK to drill holes where you don't want them permanently! I'm definitely going to try this idea, and with the doors on and shut for good measure too instead of on the bench (can't hurt!). Thanks again! Dan > On 2015-Apr-08, at 3:03 AM, Bob Leffler wrote: > > The short answer is no. You need minimal pressure to hold the windows in place. If gravity causes any movement at all, you're going to have a major headache on your hands to resolve. I did my doors laying flat. On the rear windows I made fingers out of scrap aluminum to hold the pieces in place that were cleco'd to the cabin cover. You could do the same on the doors. The angle of the bend determines how much pressure is applied. You don't need much, just enough to keep things from moving. > > > > > > > Sent from my iPad > >> On Apr 8, 2015, at 1:42 AM, Dan Charrois wrote: >> >> >> Hi everyone. I'm ready to attach the windows in my RV-10 and am looking for advice on those who have used the Lord 7545 A/E adhesive sold by Geoff at Aerosport Products. After reading lots of positive comments from here about it, I obtained a few tubes from him. >> >> The plans call for installing the windows onto the doors when the doors are off and laying flat, presumably to allow gravity to help hold them in place while they are being cured. Of course, the rear windows can't be installed with that luxury, but they're smaller and lighter. And the windscreen rests largely on the nose while curing, so that should be less of an issue too. >> >> But my question is, considering that Lord Adhesive is different than Vans' would have us use anyway, is it sticky enough that I could install the windows on the doors while the doors are closed and on the plane - in essentially the same orientation as the rear windows? The reason I ask isn't due to laziness :-) But instead, I'm one of the lucky ones whose doors ended up fitting quite well without a lot of work. And I figure that if the windows are attached to the doors while the doors are in their proper latched position, they can only help (slightly) to further stiffen the door in the proper position. The last thing I want to do is to fit the windows to the doors when the doors are on the floor, and then find that gravity warped things slightly while they were curing, and the doors no longer fit properly. It would seem to me that adhering the windows to the doors when the doors are in their closed position will help keep everything aligned properly, so long as the Lord! >> adhesive is sticky enough before fully cured that it will hold the window tightly to the door and in place while it is curing. >> >> Thanks! >> >> Dan >> --- >> Dan Charrois >> President, Syzygy Research & Technology >> Phone: 780-961-2213 >> >> >> > =================================== > =================================== > =================================== > =================================== >> >> >> > >
Date: Apr 09, 2015
Subject: ACS Door Locks
I tried to install my new, custom ordered door lock yesterday in the baggage door and found that the included cam was too short. When I attempted to use the one I had, I realized that these door locks are "clocked" 45 degrees off of what they would need to be for the cam to be level in the closed position. The included cam has an 8 point mounting hole that allows it to be clocked to the desired position, but the one I have is square. I called the manufacturer and they do not make a longer cam. Does anyone have a source for longer cams that have an 8 point mounting hole? If not, what has everyone else been doing? Thanks, Shannon ________________________________________________________________________________
Date: Apr 09, 2015
Subject: Re: ACS Door Locks
I believe my kit from Vans came with a long cam for this purpose. On Thu, Apr 9, 2015 at 8:48 AM, Shannon Hicks wrote: > I tried to install my new, custom ordered door lock yesterday in the > baggage door and found that the included cam was too short. When I > attempted to use the one I had, I realized that these door locks are > "clocked" 45 degrees off of what they would need to be for the cam to be > level in the closed position. > > The included cam has an 8 point mounting hole that allows it to be clocked > to the desired position, but the one I have is square. I called the > manufacturer and they do not make a longer cam. Does anyone have a source > for longer cams that have an 8 point mounting hole? If not, what has > everyone else been doing? > > Thanks, > Shannon > > * > > > * > > ________________________________________________________________________________
Date: Apr 09, 2015
I took the square holed cam, cut and welded it to the octagonal cam and bent it to make it work. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440489#440489 ________________________________________________________________________________
Date: Apr 09, 2015
Subject: Insurance
Date: Apr 09, 2015
Thanks to the posters on the rates that you pay for comparison shopping of insurance. I had my quote move down to $2027 for $1mil/100k/150,000 hull. I have only 25 hours in a RV10, but have had my RV8 with them for several years and I have 16,000 hours TT, so I will expect to see the price drop at renewal with more time in type. I think that this thread is useful for people to get a feel for what they should be seeing for the quotes that they are getting, even though there are many variables to consider. With just a few responses on this forum, I feel more secure that I=99m paying a rate that isn=99t grossly out of range. I was able to have my agent =9Cfine tune=9D the original $2400 quote down to $2000 after getting these responses. It turns out they =9Cforgot=9D to include the large discount for being hangared. Expect me to re-visit this thread every year at renewal time. I hope people will participate. Chris Hukill ________________________________________________________________________________
Date: Apr 09, 2015
Because the cutout is square in the Vans supplied cam, It will not rotate properly. When the lock is installed in the door, it is off by 45 degrees. The only way I can see making it work is to modify the square opening to an 8 point opening. Attached is a crude drawing of what is happening. Shannon On Thu, Apr 9, 2015 at 8:08 AM, rvdave wrote: > > I took the square holed cam, cut and welded it to the octagonal cam and > bent it to make it work. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440489#440489 > > ________________________________________________________________________________
Date: Apr 09, 2015
Subject: Control stick bending
I know some have said they have bent their sticks for panel clearance. I don't recall seeing any specifics, other than ua hydraulic press. How much did you need to bend? What did you do to protect the shape of the tubing? Any comments on technique, how hard to bend, how to prevent weakening the tubing would be appreciated. I have Tosten grips and Aerosport carbon fiber panel, along with cutting stick as much as possible and still be able to secure grips. I currently only have 20 degrees of nose down travel when stick grips hit panel. Kelly Been finishing forever. ________________________________________________________________________________
Subject: Re: Control stick bending
Date: Apr 09, 2015
I did mine freehand with a rubber mallet. I wouldnt bother doing it again, there is no way you should ever need to push the stick so far forward that you'll hit the panel. Vans demo plane uses the stick as sent, as a reference. I would consider bending the stick a slight side bend to accommodate the angle you hold the stick. -----Original Message----- From: Kelly McMullen Sent: Thursday, April 09, 2015 8:26 AM Subject: RV10-List: Control stick bending I know some have said they have bent their sticks for panel clearance. I don't recall seeing any specifics, other than ua hydraulic press. How much did you need to bend? What did you do to protect the shape of the tubing? Any comments on technique, how hard to bend, how to prevent weakening the tubing would be appreciated. I have Tosten grips and Aerosport carbon fiber panel, along with cutting stick as much as possible and still be able to secure grips. I currently only have 20 degrees of nose down travel when stick grips hit panel. Kelly Been finishing forever. ________________________________________________________________________________
Date: Apr 09, 2015
A locksmith or HD can fix you up with the correct latch. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440512#440512 ________________________________________________________________________________
Date: Apr 09, 2015
So, two locksmiths, HD and Lowes have all told me they have never seen a cam like I need. The manufacturer states the locks cannot be adjusted so I am stuck with the 45 deg offset 90 deg of rotation. I feel like I am missing something very simple here, but I just can't get past this issue. Thanks for all of your help so far. Shannon On Apr 9, 2015 12:19 PM, "Jim Berry" wrote: > > A locksmith or HD can fix you up with the correct latch. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440512#440512 > > ________________________________________________________________________________
Date: Apr 09, 2015
Could you make a new locating notch to line up the lock where you want it, rather than modifying the inside of the cam attach? On 4/9/2015 11:39 AM, Shannon Hicks wrote: > > So, two locksmiths, HD and Lowes have all told me they have never seen > a cam like I need. The manufacturer states the locks cannot be > adjusted so I am stuck with the 45 deg offset 90 deg of rotation. > > I feel like I am missing something very simple here, but I just can't > get past this issue. > > Thanks for all of your help so far. > > Shannon > > On Apr 9, 2015 12:19 PM, "Jim Berry" > wrote: > > > > > A locksmith or HD can fix you up with the correct latch. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440512#440512 > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > * > > > * ________________________________________________________________________________
Date: Apr 09, 2015
That looks like my only course of action right now. It gave me pause that I am the first person that ran into this. That usually means I am looking at it wrong! Shannon On Apr 9, 2015 2:52 PM, "Kelly McMullen" wrote: > > Could you make a new locating notch to line up the lock where you want it, > rather than modifying the inside of the cam attach? > > On 4/9/2015 11:39 AM, Shannon Hicks wrote: > >> >> So, two locksmiths, HD and Lowes have all told me they have never seen a >> cam like I need. The manufacturer states the locks cannot be adjusted so I >> am stuck with the 45 deg offset 90 deg of rotation. >> >> I feel like I am missing something very simple here, but I just can't get >> past this issue. >> >> Thanks for all of your help so far. >> >> Shannon >> >> On Apr 9, 2015 12:19 PM, "Jim Berry" > tojimberry(at)gmail.com>> wrote: >> >> > >> >> A locksmith or HD can fix you up with the correct latch. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=440512#440512 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * >> >> >> * >> > > ________________________________________________________________________________
Date: Apr 09, 2015
I agree with William. Vans included a longer cam that replaces the one that comes with the lock. I ended up making one so that I could embed a disk magnet in it and then installed a reed switch in the door jamb. That switch is hooked in series with the passenger door switches. All 5 switches are hooked in series, 2 per passenger and one on the luggage door. Therefore, if any door is not latched, I get an indicator on my panel telling me, just not which one. i bought both the magnet and switch from Amazon. Bruce Hoppe Sent from my iPad -------- Bruce Hoppe Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440549#440549 Attachments: http://forums.matronics.com//files/image_560.jpg ________________________________________________________________________________
Date: Apr 09, 2015
Or you can use shorter grips. I got them from a guy in New Zealand, and they clear the panel just fine without any bending of the stick. They look a bit similar to the Infinity grips, just less buttons. They are ambidextrous. http://www.compositesinternational.co.nz/gallery/ You are probably far down the path to bending the stick :) but just for future reference... Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440550#440550 Attachments: http://forums.matronics.com//files/grips_277.jpg ________________________________________________________________________________
Date: Apr 09, 2015
Shannon, how about getting a piece of stainless steel plate and cutting out a new cam? It's a little bit of work but will give you exactly what you need. Rick #40956 Southampton, Ont On Thu, Apr 9, 2015 at 2:39 PM, Shannon Hicks wrote: > So, two locksmiths, HD and Lowes have all told me they have never seen a > cam like I need. The manufacturer states the locks cannot be adjusted so I > am stuck with the 45 deg offset 90 deg of rotation. > > I feel like I am missing something very simple here, but I just can't get > past this issue. > > Thanks for all of your help so far. > > Shannon > On Apr 9, 2015 12:19 PM, "Jim Berry" wrote: > >> >> A locksmith or HD can fix you up with the correct latch. >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=440512#440512 >> >> >> >> >> >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> * > > > * > > ________________________________________________________________________________
Date: Apr 09, 2015
Subject: Another ADS-B option
From Stratus, all-in-one 1090ES/GPS unit. http://tinyurl.com/kjlz5ah <http://ipadpilotnews.com/2015/04/new-stratus-esg-ads-b-transponder/?utm_source=ipadnews&utm_medium=email&_bta_tid=3.P80.CEVn1g.C7qC.AXbG0g..Afn5fA.b..l> ________________________________________________________________________________
Date: Apr 09, 2015
Subject: NTSB - Probable Cause
Some of you might have seen this already, but Doug Nebert's probable cause was published today. This was the accident in Oregon last May. (2 Fatal - 1 Serious) - The probable cause document <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA218&rpt=fi> is a humbling read... - Every document in the entire docket <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=524058&CFTOKEN=34830451> is worth the read... - Specifically the photos in this document <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> are full of emotion. Anger, Sadness, Disbelief, Confusion. In case the links do not work, the case ID is WPR14FA218 so you can look it up yourself. I will give you the nutshell, but you need to go read the documents. RTV was used to seal NPT fittings on a (recently installed) fuel flow transducer. A ~0.25" chuckof RTV came loose and flowed downstream into the metered nozzle of the transducer. The metered hole was ~0.115" in diameter and the RTV plugged the hole and starved the engine of fuel. To make matters worse, a stall (and likely the start of a spin) occurred during the forced landing. This is worth a read. There were other indications of an aircraft with questionable maintenance, but the event that brought down this airplane was 100% preventable. The real disappointing part is that the issue was pointed out by a friend but ignored. Even if we don't have RTV on our fuel lines (I hope we don't - Same thing for Teflon Tape), there is a lesson in here for all of us. It doesn't do us any good to share information and concerns with each other if we aren't going to take a moment to stop in our tracks and seriously listen to them. Ears open, mouth closed, stop, and think. I'm as guilty as the next person, but this is a case where we can all reset ourselves and improve our fleets record. Phil ________________________________________________________________________________
Date: Apr 10, 2015
Subject: Re: NTSB - Probable Cause
This whole story really saddens me. In the 34 years I've been around experimentals I've seen a lot of 'stupid builder tricks' done by intelligent, knowledgeable builders. I rank them up with running out of fuel and VFR pilots flying into IFR conditions. How does it happen? What thought process took them down the path to the ultimate failure??? I've seen experimentals I wouldn't even sit in, much less fly in. Glaring construction practices ..... not hidden like this case ..... where a lot of 'counseling' was ignored, resulting in a fatal accident. Many were personal friends. In this case the builder was informed of a prior, improper use of RTV, but it didn't matter. It's sad, but our hobby is shot through with 'experts' that also think 'their way is a better way', and the newbie builder is cannon fodder for their misguided information. I'm guilty of failing to 'just build it' ..... I don't like the way some things are done ..... but the mods are done with all the information found in AC 43-13. I really feel that no builder should be given an airworthiness certificate unless he/she produces their own copy. It would have saved a fair amount of lives. Over the years I've tried to learn what went wrong in an accident scenario, not just the cause, but where/how the failure came to be. This one was obvious, many others are sinister and lie it wait for years. Phil is spot on .... we are our brothers keeper ...... As a point of perspective, we read/hear/know of an accident where a highly skilled (famous, prolific builder, pilot, etc.) is no longer with us because of an aviation accident ..... if they go west prematurely, what chance do I have to grow old and die of natural causes??? All I can do is try to learn from their demise and become more knowledgeable, and hopefully make the proper decisions down the road. If you deviate from the norm (it's that mod thingy again) please get as many opinions and sets of eyes as you can, just in case there's a flaw in your thought process. What you learn may not be entirely correct, but the discussion adds immeasurably to your analysis. I now relinquish the soapbox. Linn On 4/10/2015 12:50 AM, Phillip Perry wrote: > Some of you might have seen this already, but Doug Nebert's probable > cause was published today. This was the accident in Oregon last May. > (2 Fatal - 1 Serious) > > * The probable cause document > <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA218&rpt=fi> > is a humbling read... > * Every document in the entire docket > <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=524058&CFTOKEN=34830451> > is worth the read... > * Specifically the photos in this document > <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> > are full of emotion. Anger, Sadness, Disbelief, Confusion. > > In case the links do not work, the case ID is WPR14FA218 so you can > look it up yourself. > > I will give you the nutshell, but you need to go read the documents. > RTV was used to seal NPT fittings on a (recently installed) fuel flow > transducer. A ~0.25" chuckof RTV came loose and flowed downstream > into the metered nozzle of the transducer. The metered hole was > ~0.115" in diameter and the RTV plugged the hole and starved the > engine of fuel. To make matters worse, a stall (and likely the start > of a spin) occurred during the forced landing. > > This is worth a read. There were other indications of an aircraft > with questionable maintenance, but the event that brought down this > airplane was 100% preventable. The real disappointing part is that > the issue was pointed out by a friend but ignored. > > Even if we don't have RTV on our fuel lines (I hope we don't - Same > thing for Teflon Tape), there is a lesson in here for all of us. It > doesn't do us any good to share information and concerns with each > other if we aren't going to take a moment to stop in our tracks and > seriously listen to them. Ears open, mouth closed, stop, and think. > I'm as guilty as the next person, but this is a case where we can all > reset ourselves and improve our fleets record. > > Phil > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Date: Apr 10, 2015
I have the Aerosport Panel and did not have to bend the stick. What I did was to cut the lower end as short as possible to leave enough straight left to slide into and fully engage into the lower attachment joint. I trimmed the top as short as possible so the holding when the grip my arm would be able to relax on my leg. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440562#440562 Attachments: http://forums.matronics.com//files/stick_2596_286.jpg ________________________________________________________________________________
Date: Apr 10, 2015
Phil, Thanks for posting. That's just sickening to read. Regarding Linn's post, I truly think that the people who most often do the very questionable things are also the ones that will never listen to the advice, so it's a hopeless plea, sadly. I think back to how many times I had to get on Dan Lloyd and he never listened once. This particular accident/pilot was far less lax than Dan was, but still, there are just far too many things in the report to allow me to just think "well, at least he knew what he was doing". It was a shocking read, and horrifying when you consider the discussion about the crash and the child, and see the numerous pictures of the plane. There isn't anything left of the front end, and you can't blame the angle of impact on anything but poor piloting, even if you excuse the RTV use. This accident didn't have to end this way. Some things I noted... The fuel handle was installed reverse indicating. Why? Why can't a pilot understand that things like that are critical, and you need to install them so that ANYONE can understand them? Of course, the RTV on the NPT threads... So how many times do we have to discuss this? No teflon tape, no RTV. Fuel lube I guess is the common one, which is good. If you use a paste of any type, or even in the case of anti-seize on spark plugs, you don't put it on the first couple threads. These are just common knowledge practices. You don't want to contaminate the inside, nor give opportunity for the compound to come off inside. Here's one I'm not familiar with. The electric fuel pump was a "Facet Automotive". Someone else help me out here as I'm not familiar with the carbureted RV-10 fuel system. Is that a normal pump, or something hacked in? I know Facet pumps are used often, but is that the proper pump? Fuel systems aren't something to screw with, so hopefully that was the right one. The fuel selector position, and key position it's hard to interpret. Not good for trying a restart, but the fuel valve off for the crash is a good thing. Not sure what to think about the key position though. There seem to be numerous issues with the plane. I hate it when I hear of people flying continually and regularly without addressing an issue. I mean, he was frustrated with the "constant hassle" of having to reset the alternator in flight. REALLY!?!? I think if mine blows ONCE I need to look at it. Twice and it's an issue for sure. But constantly in flight? WTF are you doing carrying passengers if this is the case?!?! That blows my mind. Then there's the 125psi fuel pressure. Again, you have an indication like that and you just fly it?!?!?! I met a guy once who never calibrated his engine sensors. You have to add proper scale factors and offsets for them to even read accurately. He adjusted his oil pressure on the engine to match his NON-setup instrument. Then found out how to set the instrument up from me. WTF is that about!?! You didn't have time to do that before you first flew? Far better than killing yourself! My only comment to people like that is "THINK!!!!" Then there's the comments from people that they tried to start the engine and the "stater wasn't connected" which it sounds like is actually that the starter was falling off the engine and not making contact. He had heard it making noise on previous flights and now it wouldn't start. Again, REALLY? You hear something odd and don't investigate it? Another one... the Prop only made 2450 RPM, but that's the way it's always been so it wasn't fixed. REALLY!?!?!? So something as important as your engine making the power it needs to isn't important to you? Truly I say, here is someone who just didn't give a crap about doing things "right". There are too many indicators. Didn't put the fuel transducer in earlier because it needed a certain amount of space and had to bend tubing to do it. Gosh, so that's a reason to just not install it then? Then finally DID put it in, but used RTV and didn't connect any wiring to it. This should have been done PRIOR to the first flight. And I don't care if you're Sean Tucker, if you're flying a carbureted airplane you shouldn't consider yourself "not a big proponent of carb heat" if you're going to fly IFR (or even VFR). Carb heat provides a very specific function. If you want to ignore it on your landing prep, that's one thing, but if you dang well better know when is a good time to think about using it. And finally, a plea from me, to you. If you're not someone who's going to thoughtfully approach your build, and try to do things right, please try to refrain from using my name in your internet postings. I know, I know, his Andair fuel valve install wasn't involved in the crash cause at all, other than maybe the fact that he put the handle on reversed, but I wasn't thrilled about seeing that he referred to me in his forum post. If you like what you see, copy it, but if you're doing all sorts of other stupid things, just leave my name out of it. It's like not calling it a "Van's RV-10" if you're going to significantly modify the airframe. I don't need to be tied to your improper methods of build or maintenance. Better yet, just try to do everything to certified aircraft standards and procedures and you won't have to worry about what your NTSB report reads like (or at least cut your chance). Sorry, that may have been part analysis, part rant, but it drives me nuts to see some of the things that bring down planes, especially RV-10's. So far there's been only a very tiny fraction of accidents that were not directly attributable to something stupid that someone did. Let's try to eliminate those sorts of things because we'd have a *near* spotless safety record on our make and model if you eliminated the things that were pure ignorance and idiocy. Tim On 4/9/2015 11:50 PM, Phillip Perry wrote: > Some of you might have seen this already, but Doug Nebert's probable > cause was published today. This was the accident in Oregon last May. > (2 Fatal - 1 Serious) > > * The probable cause document > <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA218&rpt=fi> > is a humbling read... > * Every document in the entire docket > <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=524058&CFTOKEN=34830451> > is worth the read... > * Specifically the photos in this document > <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> are > full of emotion. Anger, Sadness, Disbelief, Confusion. > > In case the links do not work, the case ID is WPR14FA218 so you can look > it up yourself. > > I will give you the nutshell, but you need to go read the documents. > RTV was used to seal NPT fittings on a (recently installed) fuel flow > transducer. A ~0.25" chuckof RTV came loose and flowed downstream into > the metered nozzle of the transducer. The metered hole was ~0.115" in > diameter and the RTV plugged the hole and starved the engine of fuel. > To make matters worse, a stall (and likely the start of a spin) occurred > during the forced landing. > > This is worth a read. There were other indications of an aircraft with > questionable maintenance, but the event that brought down this airplane > was 100% preventable. The real disappointing part is that the issue was > pointed out by a friend but ignored. > > Even if we don't have RTV on our fuel lines (I hope we don't - Same > thing for Teflon Tape), there is a lesson in here for all of us. It > doesn't do us any good to share information and concerns with each other > if we aren't going to take a moment to stop in our tracks and seriously > listen to them. Ears open, mouth closed, stop, and think. I'm as > guilty as the next person, but this is a case where we can all reset > ourselves and improve our fleets record. > > Phil ________________________________________________________________________________
Date: Apr 10, 2015
VGltLCANCkkgc2VlbSB0byByZW1lbWJlciBhbiBSVi0xMCB0aGF0IGNyYXNoZWQgYWJvdXQgc2V2 ZW4geWVhcnMgYWdvIGFuZCBpdCB3YXMgcmVwb3J0ZWQgdG8gc3RpbGwgaGF2ZSBjbGVjb3MgaG9s ZGluZyB0aGUgY293bCBvbi4gVGhhdCdzIG5vdCB3aGF0IGNhdXNlZCB0aGUgd3JlY2sgYW5kIGRl YXRoIGJ1dCB3YXMgc3ltcHRvbWF0aWMgb2YgdGhlIHdob2xlIHRoaW5nLiBBcyBJIHJlbWVtYmVy IGl0IHdhcyBydWxlZCBhIHN0YWxsLXNwaW4sIGFzIHVzdWFsIfCfmJwNCg0KPiBEYXRlOiBGcmks IDEwIEFwciAyMDE1IDEwOjE5OjUyIC0wNTAwDQo+IEZyb206IFRpbUBNeVJWMTAuY29tDQo+IFRv OiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbQ0KPiBTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBOVFNC IC0gUHJvYmFibGUgQ2F1c2UNCj4gDQo+IC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 IFRpbSBPbHNvbiA8VGltQG15cnYxMC5jb20+DQo+IA0KPiBQaGlsLA0KPiBUaGFua3MgZm9yIHBv c3RpbmcuICBUaGF0J3MganVzdCBzaWNrZW5pbmcgdG8gcmVhZC4gIFJlZ2FyZGluZyBMaW5uJ3MN Cj4gcG9zdCwgSSB0cnVseSB0aGluayB0aGF0IHRoZSBwZW9wbGUgd2hvIG1vc3Qgb2Z0ZW4gZG8g dGhlIHZlcnkNCj4gcXVlc3Rpb25hYmxlIHRoaW5ncyBhcmUgYWxzbyB0aGUgb25lcyB0aGF0IHdp bGwgbmV2ZXIgbGlzdGVuDQo+IHRvIHRoZSBhZHZpY2UsIHNvIGl0J3MgYSBob3BlbGVzcyBwbGVh LCBzYWRseS4gIEkgdGhpbmsgYmFjaw0KPiB0byBob3cgbWFueSB0aW1lcyBJIGhhZCB0byBnZXQg b24gRGFuIExsb3lkIGFuZCBoZSBuZXZlcg0KPiBsaXN0ZW5lZCBvbmNlLiAgVGhpcyBwYXJ0aWN1 bGFyIGFjY2lkZW50L3BpbG90IHdhcyBmYXIgbGVzcw0KPiBsYXggdGhhbiBEYW4gd2FzLCBidXQg c3RpbGwsIHRoZXJlIGFyZSBqdXN0IGZhciB0b28gbWFueSB0aGluZ3MNCj4gaW4gdGhlIHJlcG9y dCB0byBhbGxvdyBtZSB0byBqdXN0IHRoaW5rICJ3ZWxsLCBhdCBsZWFzdCBoZQ0KPiBrbmV3IHdo YXQgaGUgd2FzIGRvaW5nIi4gIEl0IHdhcyBhIHNob2NraW5nIHJlYWQsIGFuZCBob3JyaWZ5aW5n DQo+IHdoZW4geW91IGNvbnNpZGVyIHRoZSBkaXNjdXNzaW9uIGFib3V0IHRoZSBjcmFzaCBhbmQg dGhlIGNoaWxkLA0KPiBhbmQgc2VlIHRoZSBudW1lcm91cyBwaWN0dXJlcyBvZiB0aGUgcGxhbmUu ICBUaGVyZSBpc24ndCBhbnl0aGluZw0KPiBsZWZ0IG9mIHRoZSBmcm9udCBlbmQsIGFuZCB5b3Ug Y2FuJ3QgYmxhbWUgdGhlIGFuZ2xlIG9mIGltcGFjdA0KPiBvbiBhbnl0aGluZyBidXQgcG9vciBw aWxvdGluZywgZXZlbiBpZiB5b3UgZXhjdXNlIHRoZSBSVFYNCj4gdXNlLiAgVGhpcyBhY2NpZGVu dCBkaWRuJ3QgaGF2ZSB0byBlbmQgdGhpcyB3YXkuDQo+IA0KPiBTb21lIHRoaW5ncyBJIG5vdGVk Li4uDQo+IA0KPiBUaGUgZnVlbCBoYW5kbGUgd2FzIGluc3RhbGxlZCByZXZlcnNlIGluZGljYXRp bmcuICBXaHk/ICBXaHkNCj4gY2FuJ3QgYSBwaWxvdCB1bmRlcnN0YW5kIHRoYXQgdGhpbmdzIGxp a2UgdGhhdCBhcmUgY3JpdGljYWwsDQo+IGFuZCB5b3UgbmVlZCB0byBpbnN0YWxsIHRoZW0gc28g dGhhdCBBTllPTkUgY2FuIHVuZGVyc3RhbmQNCj4gdGhlbT8NCj4gDQo+IE9mIGNvdXJzZSwgdGhl IFJUViBvbiB0aGUgTlBUIHRocmVhZHMuLi4gIFNvIGhvdyBtYW55IHRpbWVzDQo+IGRvIHdlIGhh dmUgdG8gZGlzY3VzcyB0aGlzPyAgTm8gdGVmbG9uIHRhcGUsIG5vIFJUVi4gRnVlbA0KPiBsdWJl IEkgZ3Vlc3MgaXMgdGhlIGNvbW1vbiBvbmUsIHdoaWNoIGlzIGdvb2QuICBJZiB5b3UgdXNlDQo+ IGEgcGFzdGUgb2YgYW55IHR5cGUsIG9yIGV2ZW4gaW4gdGhlIGNhc2Ugb2YgYW50aS1zZWl6ZSBv bg0KPiBzcGFyayBwbHVncywgeW91IGRvbid0IHB1dCBpdCBvbiB0aGUgZmlyc3QgY291cGxlIHRo cmVhZHMuDQo+IFRoZXNlIGFyZSBqdXN0IGNvbW1vbiBrbm93bGVkZ2UgcHJhY3RpY2VzLiBZb3Ug ZG9uJ3Qgd2FudA0KPiB0byBjb250YW1pbmF0ZSB0aGUgaW5zaWRlLCBub3IgZ2l2ZSBvcHBvcnR1 bml0eSBmb3IgdGhlDQo+IGNvbXBvdW5kIHRvIGNvbWUgb2ZmIGluc2lkZS4NCj4gDQo+IEhlcmUn cyBvbmUgSSdtIG5vdCBmYW1pbGlhciB3aXRoLiAgVGhlIGVsZWN0cmljIGZ1ZWwgcHVtcA0KPiB3 YXMgYSAiRmFjZXQgQXV0b21vdGl2ZSIuICBTb21lb25lIGVsc2UgaGVscCBtZSBvdXQgaGVyZQ0K PiBhcyBJJ20gbm90IGZhbWlsaWFyIHdpdGggdGhlIGNhcmJ1cmV0ZWQgUlYtMTAgZnVlbCBzeXN0 ZW0uDQo+IElzIHRoYXQgYSBub3JtYWwgcHVtcCwgb3Igc29tZXRoaW5nIGhhY2tlZCBpbj8gSSBr bm93DQo+IEZhY2V0IHB1bXBzIGFyZSB1c2VkIG9mdGVuLCBidXQgaXMgdGhhdCB0aGUgcHJvcGVy IHB1bXA/DQo+IEZ1ZWwgc3lzdGVtcyBhcmVuJ3Qgc29tZXRoaW5nIHRvIHNjcmV3IHdpdGgsIHNv IGhvcGVmdWxseQ0KPiB0aGF0IHdhcyB0aGUgcmlnaHQgb25lLg0KPiANCj4gVGhlIGZ1ZWwgc2Vs ZWN0b3IgcG9zaXRpb24sIGFuZCBrZXkgcG9zaXRpb24gaXQncyBoYXJkDQo+IHRvIGludGVycHJl dC4gTm90IGdvb2QgZm9yIHRyeWluZyBhIHJlc3RhcnQsIGJ1dA0KPiB0aGUgZnVlbCB2YWx2ZSBv ZmYgZm9yIHRoZSBjcmFzaCBpcyBhIGdvb2QgdGhpbmcuIE5vdA0KPiBzdXJlIHdoYXQgdG8gdGhp bmsgYWJvdXQgdGhlIGtleSBwb3NpdGlvbiB0aG91Z2guDQo+IA0KPiBUaGVyZSBzZWVtIHRvIGJl IG51bWVyb3VzIGlzc3VlcyB3aXRoIHRoZSBwbGFuZS4gIEkgaGF0ZSBpdA0KPiB3aGVuIEkgaGVh ciBvZiBwZW9wbGUgZmx5aW5nIGNvbnRpbnVhbGx5IGFuZCByZWd1bGFybHkgd2l0aG91dA0KPiBh ZGRyZXNzaW5nIGFuIGlzc3VlLiAgSSBtZWFuLCBoZSB3YXMgZnJ1c3RyYXRlZCB3aXRoDQo+IHRo ZSAiY29uc3RhbnQgaGFzc2xlIiBvZiBoYXZpbmcgdG8gcmVzZXQgdGhlIGFsdGVybmF0b3INCj4g aW4gZmxpZ2h0LiAgUkVBTExZIT8hPyBJIHRoaW5rIGlmIG1pbmUgYmxvd3MgT05DRSBJIG5lZWQN Cj4gdG8gbG9vayBhdCBpdC4gVHdpY2UgYW5kIGl0J3MgYW4gaXNzdWUgZm9yIHN1cmUuICBCdXQN Cj4gY29uc3RhbnRseSBpbiBmbGlnaHQ/IFdURiBhcmUgeW91IGRvaW5nIGNhcnJ5aW5nIHBhc3Nl bmdlcnMNCj4gaWYgdGhpcyBpcyB0aGUgY2FzZT8hPyEgVGhhdCBibG93cyBteSBtaW5kLg0KPiAN Cj4gVGhlbiB0aGVyZSdzIHRoZSAxMjVwc2kgZnVlbCBwcmVzc3VyZS4gIEFnYWluLCB5b3UgaGF2 ZQ0KPiBhbiBpbmRpY2F0aW9uIGxpa2UgdGhhdCBhbmQgeW91IGp1c3QgZmx5IGl0PyE/IT8hICBJ IG1ldA0KPiBhIGd1eSBvbmNlIHdobyBuZXZlciBjYWxpYnJhdGVkIGhpcyBlbmdpbmUgc2Vuc29y cy4NCj4gWW91IGhhdmUgdG8gYWRkIHByb3BlciBzY2FsZSBmYWN0b3JzIGFuZCBvZmZzZXRzIGZv cg0KPiB0aGVtIHRvIGV2ZW4gcmVhZCBhY2N1cmF0ZWx5LiBIZSBhZGp1c3RlZCBoaXMgb2lsIHBy ZXNzdXJlDQo+IG9uIHRoZSBlbmdpbmUgdG8gbWF0Y2ggaGlzIE5PTi1zZXR1cCBpbnN0cnVtZW50 LiAgVGhlbg0KPiBmb3VuZCBvdXQgaG93IHRvIHNldCB0aGUgaW5zdHJ1bWVudCB1cCBmcm9tIG1l Lg0KPiBXVEYgaXMgdGhhdCBhYm91dCE/ISAgWW91IGRpZG4ndCBoYXZlIHRpbWUgdG8gZG8gdGhh dA0KPiBiZWZvcmUgeW91IGZpcnN0IGZsZXc/ICBGYXIgYmV0dGVyIHRoYW4ga2lsbGluZyB5b3Vy c2VsZiENCj4gTXkgb25seSBjb21tZW50IHRvIHBlb3BsZSBsaWtlIHRoYXQgaXMgIlRISU5LISEh ISINCj4gDQo+IFRoZW4gdGhlcmUncyB0aGUgY29tbWVudHMgZnJvbSBwZW9wbGUgdGhhdCB0aGV5 IHRyaWVkDQo+IHRvIHN0YXJ0IHRoZSBlbmdpbmUgYW5kIHRoZSAic3RhdGVyIHdhc24ndCBjb25u ZWN0ZWQiIHdoaWNoDQo+IGl0IHNvdW5kcyBsaWtlIGlzIGFjdHVhbGx5IHRoYXQgdGhlIHN0YXJ0 ZXIgd2FzIGZhbGxpbmcNCj4gb2ZmIHRoZSBlbmdpbmUgYW5kIG5vdCBtYWtpbmcgY29udGFjdC4g IEhlIGhhZCBoZWFyZA0KPiBpdCBtYWtpbmcgbm9pc2Ugb24gcHJldmlvdXMgZmxpZ2h0cyBhbmQg bm93IGl0IHdvdWxkbid0DQo+IHN0YXJ0LiBBZ2FpbiwgUkVBTExZPyAgWW91IGhlYXIgc29tZXRo aW5nIG9kZCBhbmQNCj4gZG9uJ3QgaW52ZXN0aWdhdGUgaXQ/DQo+IA0KPiBBbm90aGVyIG9uZS4u LiB0aGUgUHJvcCBvbmx5IG1hZGUgMjQ1MCBSUE0sIGJ1dCB0aGF0J3MgdGhlDQo+IHdheSBpdCdz IGFsd2F5cyBiZWVuIHNvIGl0IHdhc24ndCBmaXhlZC4gIFJFQUxMWSE/IT8hPw0KPiBTbyBzb21l dGhpbmcgYXMgaW1wb3J0YW50IGFzIHlvdXIgZW5naW5lIG1ha2luZyB0aGUNCj4gcG93ZXIgaXQg bmVlZHMgdG8gaXNuJ3QgaW1wb3J0YW50IHRvIHlvdT8gIFRydWx5IEkgc2F5LA0KPiBoZXJlIGlz IHNvbWVvbmUgd2hvIGp1c3QgZGlkbid0IGdpdmUgYSBjcmFwIGFib3V0DQo+IGRvaW5nIHRoaW5n cyAicmlnaHQiLiAgVGhlcmUgYXJlIHRvbyBtYW55IGluZGljYXRvcnMuDQo+IA0KPiBEaWRuJ3Qg cHV0IHRoZSBmdWVsIHRyYW5zZHVjZXIgaW4gZWFybGllciBiZWNhdXNlIGl0IG5lZWRlZA0KPiBh IGNlcnRhaW4gYW1vdW50IG9mIHNwYWNlIGFuZCBoYWQgdG8gYmVuZCB0dWJpbmcgdG8gZG8gaXQu DQo+IEdvc2gsIHNvIHRoYXQncyBhIHJlYXNvbiB0byBqdXN0IG5vdCBpbnN0YWxsIGl0IHRoZW4/ DQo+IFRoZW4gZmluYWxseSBESUQgcHV0IGl0IGluLCBidXQgdXNlZCBSVFYgYW5kIGRpZG4ndCBj b25uZWN0DQo+IGFueSB3aXJpbmcgdG8gaXQuICBUaGlzIHNob3VsZCBoYXZlIGJlZW4gZG9uZSBQ UklPUg0KPiB0byB0aGUgZmlyc3QgZmxpZ2h0Lg0KPiANCj4gQW5kIEkgZG9uJ3QgY2FyZSBpZiB5 b3UncmUgU2VhbiBUdWNrZXIsIGlmIHlvdSdyZSBmbHlpbmcNCj4gYSBjYXJidXJldGVkIGFpcnBs YW5lIHlvdSBzaG91bGRuJ3QgY29uc2lkZXIgeW91cnNlbGYNCj4gIm5vdCBhIGJpZyBwcm9wb25l bnQgb2YgY2FyYiBoZWF0IiBpZiB5b3UncmUgZ29pbmcgdG8NCj4gZmx5IElGUiAob3IgZXZlbiBW RlIpLiAgQ2FyYiBoZWF0IHByb3ZpZGVzIGEgdmVyeQ0KPiBzcGVjaWZpYyBmdW5jdGlvbi4gIElm IHlvdSB3YW50IHRvIGlnbm9yZSBpdCBvbiB5b3VyDQo+IGxhbmRpbmcgcHJlcCwgdGhhdCdzIG9u ZSB0aGluZywgYnV0IGlmIHlvdSBkYW5nIHdlbGwNCj4gYmV0dGVyIGtub3cgd2hlbiBpcyBhIGdv b2QgdGltZSB0byB0aGluayBhYm91dCB1c2luZyBpdC4NCj4gDQo+IEFuZCBmaW5hbGx5LCBhIHBs ZWEgZnJvbSBtZSwgdG8geW91LiAgSWYgeW91J3JlIG5vdCBzb21lb25lDQo+IHdobydzIGdvaW5n IHRvIHRob3VnaHRmdWxseSBhcHByb2FjaCB5b3VyIGJ1aWxkLCBhbmQgdHJ5DQo+IHRvIGRvIHRo aW5ncyByaWdodCwgcGxlYXNlIHRyeSB0byByZWZyYWluIGZyb20gdXNpbmcgbXkNCj4gbmFtZSBp biB5b3VyIGludGVybmV0IHBvc3RpbmdzLiAgSSBrbm93LCBJIGtub3csIGhpcw0KPiBBbmRhaXIg ZnVlbCB2YWx2ZSBpbnN0YWxsIHdhc24ndCBpbnZvbHZlZCBpbiB0aGUgY3Jhc2gNCj4gY2F1c2Ug YXQgYWxsLCBvdGhlciB0aGFuIG1heWJlIHRoZSBmYWN0IHRoYXQgaGUgcHV0IHRoZQ0KPiBoYW5k bGUgb24gcmV2ZXJzZWQsIGJ1dCBJIHdhc24ndCB0aHJpbGxlZCBhYm91dCBzZWVpbmcNCj4gdGhh dCBoZSByZWZlcnJlZCB0byBtZSBpbiBoaXMgZm9ydW0gcG9zdC4gIElmIHlvdSBsaWtlDQo+IHdo YXQgeW91IHNlZSwgY29weSBpdCwgYnV0IGlmIHlvdSdyZSBkb2luZyBhbGwgc29ydHMNCj4gb2Yg b3RoZXIgc3R1cGlkIHRoaW5ncywganVzdCBsZWF2ZSBteSBuYW1lIG91dCBvZiBpdC4NCj4gSXQn cyBsaWtlIG5vdCBjYWxsaW5nIGl0IGEgIlZhbidzIFJWLTEwIiBpZiB5b3UncmUNCj4gZ29pbmcg dG8gc2lnbmlmaWNhbnRseSBtb2RpZnkgdGhlIGFpcmZyYW1lLiAgSSBkb24ndA0KPiBuZWVkIHRv IGJlIHRpZWQgdG8geW91ciBpbXByb3BlciBtZXRob2RzIG9mIGJ1aWxkIG9yDQo+IG1haW50ZW5h bmNlLiAgQmV0dGVyIHlldCwganVzdCB0cnkgdG8gZG8gZXZlcnl0aGluZyB0bw0KPiBjZXJ0aWZp ZWQgYWlyY3JhZnQgc3RhbmRhcmRzIGFuZCBwcm9jZWR1cmVzIGFuZCB5b3UNCj4gd29uJ3QgaGF2 ZSB0byB3b3JyeSBhYm91dCB3aGF0IHlvdXIgTlRTQiByZXBvcnQgcmVhZHMNCj4gbGlrZSAob3Ig YXQgbGVhc3QgY3V0IHlvdXIgY2hhbmNlKS4NCj4gDQo+IFNvcnJ5LCB0aGF0IG1heSBoYXZlIGJl ZW4gcGFydCBhbmFseXNpcywgcGFydCByYW50LCBidXQNCj4gaXQgZHJpdmVzIG1lIG51dHMgdG8g c2VlIHNvbWUgb2YgdGhlIHRoaW5ncyB0aGF0IGJyaW5nIGRvd24NCj4gcGxhbmVzLCBlc3BlY2lh bGx5IFJWLTEwJ3MuICBTbyBmYXIgdGhlcmUncyBiZWVuIG9ubHkgYQ0KPiB2ZXJ5IHRpbnkgZnJh Y3Rpb24gb2YgYWNjaWRlbnRzIHRoYXQgd2VyZSBub3QgZGlyZWN0bHkNCj4gYXR0cmlidXRhYmxl IHRvIHNvbWV0aGluZyBzdHVwaWQgdGhhdCBzb21lb25lIGRpZC4NCj4gTGV0J3MgdHJ5IHRvIGVs aW1pbmF0ZSB0aG9zZSBzb3J0cyBvZiB0aGluZ3MgYmVjYXVzZQ0KPiB3ZSdkIGhhdmUgYSAqbmVh ciogc3BvdGxlc3Mgc2FmZXR5IHJlY29yZCBvbiBvdXIgbWFrZSBhbmQNCj4gbW9kZWwgaWYgeW91 IGVsaW1pbmF0ZWQgdGhlIHRoaW5ncyB0aGF0IHdlcmUgcHVyZQ0KPiBpZ25vcmFuY2UgYW5kIGlk aW9jeS4NCj4gDQo+IFRpbQ0KPiANCj4gDQo+IA0KPiANCj4gDQo+IA0KPiBPbiA0LzkvMjAxNSAx MTo1MCBQTSwgUGhpbGxpcCBQZXJyeSB3cm90ZToNCj4gPiBTb21lIG9mIHlvdSBtaWdodCBoYXZl IHNlZW4gdGhpcyBhbHJlYWR5LCBidXQgRG91ZyBOZWJlcnQncyBwcm9iYWJsZQ0KPiA+IGNhdXNl IHdhcyBwdWJsaXNoZWQgdG9kYXkuICBUaGlzIHdhcyB0aGUgYWNjaWRlbnQgaW4gT3JlZ29uIGxh c3QgTWF5Lg0KPiA+ICAgKDIgRmF0YWwgLSAxIFNlcmlvdXMpDQo+ID4NCj4gPiAgICogVGhlIHBy b2JhYmxlIGNhdXNlIGRvY3VtZW50DQo+ID4gICAgIDxodHRwOi8vd3d3Lm50c2IuZ292L19sYXlv dXRzL250c2IuYXZpYXRpb24vR2VuZXJhdGVQREYuYXNweD9pZD1XUFIxNEZBMjE4JnJwdD1maT4N Cj4gPiAgICAgaXMgYSBodW1ibGluZyByZWFkLi4uDQo+ID4gICAqIEV2ZXJ5IGRvY3VtZW50IGlu IHRoZSBlbnRpcmUgZG9ja2V0DQo+ID4gICAgIDxodHRwOi8vZG1zLm50c2IuZ292L3B1YmRtcy9z ZWFyY2gvaGl0bGlzdC5jZm0/ZG9ja2V0SUQ9NTcxMjkmQ0ZJRD01MjQwNTgmQ0ZUT0tFTj0zNDgz MDQ1MT4NCj4gPiAgICAgaXMgd29ydGggdGhlIHJlYWQuLi4NCj4gPiAgICogU3BlY2lmaWNhbGx5 IHRoZSBwaG90b3MgaW4gdGhpcyBkb2N1bWVudA0KPiA+ICAgICA8aHR0cDovL2Rtcy5udHNiLmdv di9wdWJsaWMlMkY1NzAwMC01NzQ5OSUyRjU3MTI5JTJGNTcwMDI4LnBkZj4gYXJlDQo+ID4gICAg IGZ1bGwgb2YgZW1vdGlvbi4gQW5nZXIsIFNhZG5lc3MsIERpc2JlbGllZiwgQ29uZnVzaW9uLg0K PiA+DQo+ID4gSW4gY2FzZSB0aGUgbGlua3MgZG8gbm90IHdvcmssIHRoZSBjYXNlIElEIGlzIFdQ UjE0RkEyMTggc28geW91IGNhbiBsb29rDQo+ID4gaXQgdXAgeW91cnNlbGYuDQo+ID4NCj4gPiBJ IHdpbGwgZ2l2ZSB5b3UgdGhlIG51dHNoZWxsLCBidXQgeW91IG5lZWQgdG8gZ28gcmVhZCB0aGUg ZG9jdW1lbnRzLg0KPiA+IFJUViB3YXMgdXNlZCB0byBzZWFsIE5QVCBmaXR0aW5ncyBvbiBhIChy ZWNlbnRseSBpbnN0YWxsZWQpIGZ1ZWwgZmxvdw0KPiA+IHRyYW5zZHVjZXIuICBBIH4wLjI1IiBj aHVja29mIFJUViBjYW1lIGxvb3NlIGFuZCBmbG93ZWQgZG93bnN0cmVhbSBpbnRvDQo+ID4gdGhl IG1ldGVyZWQgbm96emxlIG9mIHRoZSB0cmFuc2R1Y2VyLiAgIFRoZSBtZXRlcmVkIGhvbGUgd2Fz IH4wLjExNSIgaW4NCj4gPiBkaWFtZXRlciBhbmQgdGhlIFJUViBwbHVnZ2VkIHRoZSBob2xlIGFu ZCBzdGFydmVkIHRoZSBlbmdpbmUgb2YgZnVlbC4NCj4gPiBUbyBtYWtlIG1hdHRlcnMgd29yc2Us IGEgc3RhbGwgKGFuZCBsaWtlbHkgdGhlIHN0YXJ0IG9mIGEgc3Bpbikgb2NjdXJyZWQNCj4gPiBk dXJpbmcgdGhlIGZvcmNlZCBsYW5kaW5nLg0KPiA+DQo+ID4gVGhpcyBpcyB3b3J0aCBhIHJlYWQu ICBUaGVyZSB3ZXJlIG90aGVyIGluZGljYXRpb25zIG9mIGFuIGFpcmNyYWZ0IHdpdGgNCj4gPiBx dWVzdGlvbmFibGUgbWFpbnRlbmFuY2UsIGJ1dCB0aGUgZXZlbnQgdGhhdCBicm91Z2h0IGRvd24g dGhpcyBhaXJwbGFuZQ0KPiA+IHdhcyAxMDAlIHByZXZlbnRhYmxlLiAgVGhlIHJlYWwgZGlzYXBw b2ludGluZyBwYXJ0IGlzIHRoYXQgdGhlIGlzc3VlIHdhcw0KPiA+IHBvaW50ZWQgb3V0IGJ5IGEg ZnJpZW5kIGJ1dCBpZ25vcmVkLg0KPiA+DQo+ID4gRXZlbiBpZiB3ZSBkb24ndCBoYXZlIFJUViBv biBvdXIgZnVlbCBsaW5lcyAoSSBob3BlIHdlIGRvbid0IC0gU2FtZQ0KPiA+IHRoaW5nIGZvciBU ZWZsb24gVGFwZSksIHRoZXJlIGlzIGEgbGVzc29uIGluIGhlcmUgZm9yIGFsbCBvZiB1cy4gICBJ dA0KPiA+IGRvZXNuJ3QgZG8gdXMgYW55IGdvb2QgdG8gc2hhcmUgaW5mb3JtYXRpb24gYW5kIGNv bmNlcm5zIHdpdGggZWFjaCBvdGhlcg0KPiA+IGlmIHdlIGFyZW4ndCBnb2luZyB0byB0YWtlIGEg bW9tZW50IHRvIHN0b3AgaW4gb3VyIHRyYWNrcyBhbmQgc2VyaW91c2x5DQo+ID4gbGlzdGVuIHRv IHRoZW0uICBFYXJzIG9wZW4sIG1vdXRoIGNsb3NlZCwgc3RvcCwgYW5kIHRoaW5rLiAgSSdtIGFz DQo+ID4gZ3VpbHR5IGFzIHRoZSBuZXh0IHBlcnNvbiwgYnV0IHRoaXMgaXMgYSBjYXNlIHdoZXJl IHdlIGNhbiBhbGwgcmVzZXQNCj4gPiBvdXJzZWx2ZXMgYW5kIGltcHJvdmUgb3VyIGZsZWV0cyBy ZWNvcmQuDQo+ID4NCj4gPiBQaGlsDQo+IA0KPiANCj4gXy09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAgIC0g VGhlIFJWMTAtTGlzdCBFbWFpbCBGb3J1bSAtDQo+IF8tPSBVc2UgdGhlIE1hdHJvbmljcyBMaXN0 IEZlYXR1cmVzIE5hdmlnYXRvciB0byBicm93c2UNCj4gXy09IHRoZSBtYW55IExpc3QgdXRpbGl0 aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJzY3JpcHRpb24sDQo+IF8tPSBBcmNoaXZlIFNlYXJjaCAm IERvd25sb2FkLCA3LURheSBCcm93c2UsIENoYXQsIEZBUSwNCj4gXy09IFBob3Rvc2hhcmUsIGFu ZCBtdWNoIG11Y2ggbW9yZToNCj4gXy09DQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmlj cy5jb20vTmF2aWdhdG9yP1JWMTAtTGlzdA0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAg ICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtDQo+IF8tPSBTYW1lIGdyZWF0IGNvbnRlbnQg YWxzbyBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQ0KPiBfLT0NCj4gXy09ICAgLS0+IGh0 dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbQ0KPiBfLT0NCj4gXy09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCj4gXy09ICAgICAgICAg ICAgIC0gTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGUgLQ0KPiBfLT0gIFRoYW5rIHlvdSBmb3Ig eW91ciBnZW5lcm91cyBzdXBwb3J0IQ0KPiBfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQo+IF8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJv bmljcy5jb20vY29udHJpYnV0aW9uDQo+IF8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09DQo+IA0KPiANCj4gDQogCQkgCSAgIAkJICA ________________________________________________________________________________
Date: Apr 10, 2015
Tim, This needed to be said and you did it well. We all need to be reminded periodically that this is serious business. We should be taking pride in learning how to build and fly our planes to the best of our ability rather than looking for shortcuts. I remember well trying to find a way to console Dan's wife at his funeral. Not fun. Dick Sipp ________________________________________________________________________________
Date: Apr 10, 2015
Tim; Your rant is merited. As you know I and I'm sure many others respect you and your integrity with building. Dan served as a sad but great motivator to me to assure I NEVER fly anyone in my plane until I know it is perfectly (or as perfect as I can expect). Your feedback on that accident served as large part of my CAP presentation many years ago. When I went through "youre the inspector" and showed the events many thought I made up the whole story up it was so far fetched that anyone would do this. I agree that 4 years later we find that another person followed the same road. when I was given my Airworthiness, but the same person who was my Technical Counselor, who insisted in seeing the various phases of my build before signing off the final pink slip, he would not allow me to pass without showing him the panel and the steps I took to assure it met the "initial airspeed and gauge ranges". The fact was simple in his mind.. The first flight is when something may show up.. in my case way high oil pressure, that is no time to determine you have an issue. For someone to go so many hours without an issue is amazing in itself, but to be so nave to fly another person in such a poorly managed airplane is another Dan episode. I have been told, more than once, that what I am doing isnt necessary, but anyone who knows me knows that I take hours researching GAMI folks, EAA speakers and Lycoming and come up with my own theory on engine temps and if "its normal". point here is not one person but a few comments that I consider. I usually take the experienced folks I know, one being in a airpark in Texas and listen carefully for what, when needed I should change. This forum is full of ideas, most are excellent some overkill, but I still take your feedback very seriously Tim, and when you play such a huge part in a forum, writing articles for magazines and being a -10 (soon to be -14) guru, your name will come up. There is that 1% of builders who will make the rest of us look bad, but from what I have seen and the folks I have met, there is 99% solid folks who really are concerned about doing a proper annual and certifying they actually did everything. I am constantly looking at other demises, some are just bad luck and planning, some plain "Darwin award candidates" but some are something I have found myself being in at one point, the decision of a NTSB report was recalled and I made a decision based on "lessons learned", in that case in Texas, we landed, all it was was a rain shower (with huge clouds exploding up) but I was tempted to go on, Im here and the decision may have been overkill, but at least can see that the plane is safely sitting in the hangar for the next flight today. Yes, this event is a sad one, hopefully none of us will learn anything, other than dont cut corners and use the wrong product for the job, but it may be a reminder for something we have done that may cause us to consider changing how we did it. (use a torque wrench on a fitting versus it "being tight enough", etc) Our first day of Officer basic in Fort Rucker we had an officer walk across the grass, versus walking on the walkway. The Commander at the time told us all that "if we cut corners on something as simple as following the walkway, we would find ourselves cutting corners in the way we lived our lives and in the aircraft" Be safe and enjoy the flight! Pascal -----Original Message----- From: Tim Olson Sent: Friday, April 10, 2015 8:19 AM Subject: Re: RV10-List: NTSB - Probable Cause Phil, Thanks for posting. That's just sickening to read. Regarding Linn's post, I truly think that the people who most often do the very questionable things are also the ones that will never listen to the advice, so it's a hopeless plea, sadly. I think back to how many times I had to get on Dan Lloyd and he never listened once. This particular accident/pilot was far less lax than Dan was, but still, there are just far too many things in the report to allow me to just think "well, at least he knew what he was doing". It was a shocking read, and horrifying when you consider the discussion about the crash and the child, and see the numerous pictures of the plane. There isn't anything left of the front end, and you can't blame the angle of impact on anything but poor piloting, even if you excuse the RTV use. This accident didn't have to end this way. Some things I noted... The fuel handle was installed reverse indicating. Why? Why can't a pilot understand that things like that are critical, and you need to install them so that ANYONE can understand them? Of course, the RTV on the NPT threads... So how many times do we have to discuss this? No teflon tape, no RTV. Fuel lube I guess is the common one, which is good. If you use a paste of any type, or even in the case of anti-seize on spark plugs, you don't put it on the first couple threads. These are just common knowledge practices. You don't want to contaminate the inside, nor give opportunity for the compound to come off inside. Here's one I'm not familiar with. The electric fuel pump was a "Facet Automotive". Someone else help me out here as I'm not familiar with the carbureted RV-10 fuel system. Is that a normal pump, or something hacked in? I know Facet pumps are used often, but is that the proper pump? Fuel systems aren't something to screw with, so hopefully that was the right one. The fuel selector position, and key position it's hard to interpret. Not good for trying a restart, but the fuel valve off for the crash is a good thing. Not sure what to think about the key position though. There seem to be numerous issues with the plane. I hate it when I hear of people flying continually and regularly without addressing an issue. I mean, he was frustrated with the "constant hassle" of having to reset the alternator in flight. REALLY!?!? I think if mine blows ONCE I need to look at it. Twice and it's an issue for sure. But constantly in flight? WTF are you doing carrying passengers if this is the case?!?! That blows my mind. Then there's the 125psi fuel pressure. Again, you have an indication like that and you just fly it?!?!?! I met a guy once who never calibrated his engine sensors. You have to add proper scale factors and offsets for them to even read accurately. He adjusted his oil pressure on the engine to match his NON-setup instrument. Then found out how to set the instrument up from me. WTF is that about!?! You didn't have time to do that before you first flew? Far better than killing yourself! My only comment to people like that is "THINK!!!!" Then there's the comments from people that they tried to start the engine and the "stater wasn't connected" which it sounds like is actually that the starter was falling off the engine and not making contact. He had heard it making noise on previous flights and now it wouldn't start. Again, REALLY? You hear something odd and don't investigate it? Another one... the Prop only made 2450 RPM, but that's the way it's always been so it wasn't fixed. REALLY!?!?!? So something as important as your engine making the power it needs to isn't important to you? Truly I say, here is someone who just didn't give a crap about doing things "right". There are too many indicators. Didn't put the fuel transducer in earlier because it needed a certain amount of space and had to bend tubing to do it. Gosh, so that's a reason to just not install it then? Then finally DID put it in, but used RTV and didn't connect any wiring to it. This should have been done PRIOR to the first flight. And I don't care if you're Sean Tucker, if you're flying a carbureted airplane you shouldn't consider yourself "not a big proponent of carb heat" if you're going to fly IFR (or even VFR). Carb heat provides a very specific function. If you want to ignore it on your landing prep, that's one thing, but if you dang well better know when is a good time to think about using it. And finally, a plea from me, to you. If you're not someone who's going to thoughtfully approach your build, and try to do things right, please try to refrain from using my name in your internet postings. I know, I know, his Andair fuel valve install wasn't involved in the crash cause at all, other than maybe the fact that he put the handle on reversed, but I wasn't thrilled about seeing that he referred to me in his forum post. If you like what you see, copy it, but if you're doing all sorts of other stupid things, just leave my name out of it. It's like not calling it a "Van's RV-10" if you're going to significantly modify the airframe. I don't need to be tied to your improper methods of build or maintenance. Better yet, just try to do everything to certified aircraft standards and procedures and you won't have to worry about what your NTSB report reads like (or at least cut your chance). Sorry, that may have been part analysis, part rant, but it drives me nuts to see some of the things that bring down planes, especially RV-10's. So far there's been only a very tiny fraction of accidents that were not directly attributable to something stupid that someone did. Let's try to eliminate those sorts of things because we'd have a *near* spotless safety record on our make and model if you eliminated the things that were pure ignorance and idiocy. Tim On 4/9/2015 11:50 PM, Phillip Perry wrote: > Some of you might have seen this already, but Doug Nebert's probable > cause was published today. This was the accident in Oregon last May. > (2 Fatal - 1 Serious) > > * The probable cause document > > <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA218&rpt=fi> > is a humbling read... > * Every document in the entire docket > > <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=524058&CFTOKEN=34830451> > is worth the read... > * Specifically the photos in this document > <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> are > full of emotion. Anger, Sadness, Disbelief, Confusion. > > In case the links do not work, the case ID is WPR14FA218 so you can look > it up yourself. > > I will give you the nutshell, but you need to go read the documents. > RTV was used to seal NPT fittings on a (recently installed) fuel flow > transducer. A ~0.25" chuckof RTV came loose and flowed downstream into > the metered nozzle of the transducer. The metered hole was ~0.115" in > diameter and the RTV plugged the hole and starved the engine of fuel. > To make matters worse, a stall (and likely the start of a spin) occurred > during the forced landing. > > This is worth a read. There were other indications of an aircraft with > questionable maintenance, but the event that brought down this airplane > was 100% preventable. The real disappointing part is that the issue was > pointed out by a friend but ignored. > > Even if we don't have RTV on our fuel lines (I hope we don't - Same > thing for Teflon Tape), there is a lesson in here for all of us. It > doesn't do us any good to share information and concerns with each other > if we aren't going to take a moment to stop in our tracks and seriously > listen to them. Ears open, mouth closed, stop, and think. I'm as > guilty as the next person, but this is a case where we can all reset > ourselves and improve our fleets record. > > Phil ________________________________________________________________________________
Date: Apr 10, 2015
that=99s the Dan story Tim was alluding to- http://rvnewsletter.blogspot.com/2009/06/dan-lloyd-crash.html From: Danny Riggs Sent: Friday, April 10, 2015 9:24 AM Subject: RE: RV10-List: NTSB - Probable Cause Tim, I seem to remember an RV-10 that crashed about seven years ago and it was reported to still have clecos holding the cowl on. That's not what caused the wreck and death but was symptomatic of the whole thing. As I remember it was ruled a stall-spin, as usual!=F0=9F=98=9C > Date: Fri, 10 Apr 2015 10:19:52 -0500 > From: Tim(at)MyRV10.com > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: NTSB - Probable Cause > > > Phil, > Thanks for posting. That's just sickening to read. Regarding Linn's > post, I truly think that the people who most often do the very > questionable things are also the ones that will never listen > to the advice, so it's a hopeless plea, sadly. I think back > to how many times I had to get on Dan Lloyd and he never > listened once. This particular accident/pilot was far less > lax than Dan was, but still, there are just far too many things > in the report to allow me to just think "well, at least he > knew what he was doing". It was a shocking read, and horrifying > when you consider the discussion about the crash and the child, > and see the numerous pictures of the plane. There isn't anything > left of the front end, and you can't blame the angle of impact > on anything but poor piloting, even if you excuse the RTV > use. This accident didn't have to end this way. > > Some things I noted... > > The fuel handle was installed reverse indicating. Why? Why > can't a pilot understand that things like that are critical, > and you need to install them so that ANYONE can understand > them? > > Of course, the RTV on the NPT threads... So how many times > do we have to discuss this? No teflon tape, no RTV. Fuel > lube I guess is the common one, which is good. If you use > a paste of any type, or even in the case of anti-seize on > spark plugs, you don't put it on the first couple threads. > These are just common knowledge practices. You don't want > to contaminate the inside, nor give opportunity for the > compound to come off inside. > > Here's one I'm not familiar with. The electric fuel pump > was a "Facet Automotive". Someone else help me out here > as I'm not familiar with the carbureted RV-10 fuel system. > Is that a normal pump, or something hacked in? I know > Facet pumps are used often, but is that the proper pump? > Fuel systems aren't something to screw with, so hopefully > that was the right one. > > The fuel selector position, and key position it's hard > to interpret. Not good for trying a restart, but > the fuel valve off for the crash is a good thing. Not > sure what to think about the key position though. > > There seem to be numerous issues with the plane. I hate it > when I hear of people flying continually and regularly without > addressing an issue. I mean, he was frustrated with > the "constant hassle" of having to reset the alternator > in flight. REALLY!?!? I think if mine blows ONCE I need > to look at it. Twice and it's an issue for sure. But > constantly in flight? WTF are you doing carrying passengers > if this is the case?!?! That blows my mind. > > Then there's the 125psi fuel pressure. Again, you have > an indication like that and you just fly it?!?!?! I met > a guy once who never calibrated his engine sensors. > You have to add proper scale factors and offsets for > them to even read accurately. He adjusted his oil pressure > on the engine to match his NON-setup instrument. Then > found out how to set the instrument up from me. > WTF is that about!?! You didn't have time to do that > before you first flew? Far better than killing yourself! > My only comment to people like that is "THINK!!!!" > > Then there's the comments from people that they tried > to start the engine and the "stater wasn't connected" which > it sounds like is actually that the starter was falling > off the engine and not making contact. He had heard > it making noise on previous flights and now it wouldn't > start. Again, REALLY? You hear something odd and > don't investigate it? > > Another one... the Prop only made 2450 RPM, but that's the > way it's always been so it wasn't fixed. REALLY!?!?!? > So something as important as your engine making the > power it needs to isn't important to you? Truly I say, > here is someone who just didn't give a crap about > doing things "right". There are too many indicators. > > Didn't put the fuel transducer in earlier because it needed > a certain amount of space and had to bend tubing to do it. > Gosh, so that's a reason to just not install it then? > Then finally DID put it in, but used RTV and didn't connect > any wiring to it. This should have been done PRIOR > to the first flight. > > And I don't care if you're Sean Tucker, if you're flying > a carbureted airplane you shouldn't consider yourself > "not a big proponent of carb heat" if you're going to > fly IFR (or even VFR). Carb heat provides a very > specific function. If you want to ignore it on your > landing prep, that's one thing, but if you dang well > better know when is a good time to think about using it. > > And finally, a plea from me, to you. If you're not someone > who's going to thoughtfully approach your build, and try > to do things right, please try to refrain from using my > name in your internet postings. I know, I know, his > Andair fuel valve install wasn't involved in the crash > cause at all, other than maybe the fact that he put the > handle on reversed, but I wasn't thrilled about seeing > that he referred to me in his forum post. If you like > what you see, copy it, but if you're doing all sorts > of other stupid things, just leave my name out of it. > It's like not calling it a "Van's RV-10" if you're > going to significantly modify the airframe. I don't > need to be tied to your improper methods of build or > maintenance. Better yet, just try to do everything to > certified aircraft standards and procedures and you > won't have to worry about what your NTSB report reads > like (or at least cut your chance). > > Sorry, that may have been part analysis, part rant, but > it drives me nuts to see some of the things that bring down > planes, especially RV-10's. So far there's been only a > very tiny fraction of accidents that were not directly > attributable to something stupid that someone did. > Let's try to eliminate those sorts of things because > we'd have a *near* spotless safety record on our make and > model if you eliminated the things that were pure > ignorance and idiocy. > > Tim > > > > > > > On 4/9/2015 11:50 PM, Phillip Perry wrote: > > Some of you might have seen this already, but Doug Nebert's probable > > cause was published today. This was the accident in Oregon last May. > > (2 Fatal - 1 Serious) > > > > * The probable cause document > > <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA 218&rpt=fi> > > is a humbling read... > > * Every document in the entire docket > > <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=52 4058&CFTOKEN=34830451> > > is worth the read... > > * Specifically the photos in this document > > <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> are > > full of emotion. Anger, Sadness, Disbelief, Confusion. > > > > In case the links do not work, the case ID is WPR14FA218 so you can look > > it up yourself. > > > > I will give you the nutshell, but you need to go read the documents. > > RTV was used to seal NPT fittings on a (recently installed) fuel flow > > transducer. A ~0.25" chuckof RTV came loose and flowed downstream into > > the metered nozzle of the transducer. The metered hole was ~0.115" in > > diameter and the RTV plugged the hole and starved the engine of fuel. > > To make matters worse, a stall (and likely the start of a spin) occurred > > during the forced landing. > > > > This is worth a read. There were other indications of an aircraft with > > questionable maintenance, but the event that brought down this airplane > > was 100% preventable. The real disappointing part is that the issue was > > pointed out by a friend but ignored. > > > > Even if we don't have RTV on our fuel lines (I hope we don't - Same > > thing for Teflon Tape), there is a lesson in here for all of us. It > > doesn't do us any good to share information and concerns with each other > > if we aren't going to take a moment to stop in our tracks and seriously > > listen to them. Ears open, mouth closed, stop, and think. I'm as > > guilty as the next person, but this is a case where we can all reset > > ourselves and improve our fleets record. > > > > Phil > > > > > > > > > =EF=BD=EF=BD~=EF=BD=EF=BD,=03g=EF=BD=EF=BD ________________________________________________________________________________
Date: Apr 10, 2015
I think it's somewhat of an ego thing to a certain degree. It's hard on our egos when somebody calls out something we have done wrong on our "babies"! Flying is very unforgiving when our egos get in the way. Unfortunately the family usually pays the ultimate long term price > From: rsipp(at)earthlink.net > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: NTSB - Probable Cause > Date: Fri=2C 10 Apr 2015 12:34:08 -0400 > > > > Tim=2C > > This needed to be said and you did it well. We all need to be reminded > periodically that this is serious business. > > We should be taking pride in learning how to build and fly our planes to the > best of our ability rather than looking for shortcuts. > > I remember well trying to find a way to console Dan's wife at his funeral . > Not fun. > > Dick Sipp > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 10, 2015
QWhoaCEgSXQncyBiZWVuIHNvIGxvbmcgdGhhdCBJJ2QgZm9yZ290dGVuIHdobyBpdCB3YXMuIEkg c3RpbGwgcmVtZW1iZXIgc29tZSBvZiB0aGUgbGVzc29ucyBvZiB0aGF0IGNyYXNoIGhvd2V2ZXIh DQoNCkZyb206IHJ2MTBmbHllckBsaXZlLmNvbQ0KVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29t DQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBOVFNCIC0gUHJvYmFibGUgQ2F1c2UNCkRhdGU6IEZy aSwgMTAgQXByIDIwMTUgMDk6NDA6MDggLTA3MDANCg0KDQoNCg0KDQoNCg0KdGhhdOKAmXMgdGhl IERhbiBzdG9yeSBUaW0gd2FzIGFsbHVkaW5nIHRvLSBodHRwOi8vcnZuZXdzbGV0dGVyLmJsb2dz cG90LmNvbS8yMDA5LzA2L2Rhbi1sbG95ZC1jcmFzaC5odG1sDQoNCg0KIA0KDQpGcm9tOiBEYW5u eSBSaWdncyANClNlbnQ6IEZyaWRheSwgQXByaWwgMTAsIDIwMTUgOToyNCBBTQ0KVG86IHJ2MTAt bGlzdEBtYXRyb25pY3MuY29tIA0KU3ViamVjdDogUkU6IFJWMTAtTGlzdDogTlRTQiAtIFByb2Jh YmxlIENhdXNlDQogDQoNClRpbSwgDQpJIHNlZW0gdG8gcmVtZW1iZXIgYW4gUlYtMTAgdGhhdCBj cmFzaGVkIGFib3V0IHNldmVuIHllYXJzIA0KYWdvIGFuZCBpdCB3YXMgcmVwb3J0ZWQgdG8gc3Rp bGwgaGF2ZSBjbGVjb3MgaG9sZGluZyB0aGUgY293bCBvbi4gVGhhdCdzIG5vdCANCndoYXQgY2F1 c2VkIHRoZSB3cmVjayBhbmQgZGVhdGggYnV0IHdhcyBzeW1wdG9tYXRpYyBvZiB0aGUgd2hvbGUg dGhpbmcuIEFzIEkgDQpyZW1lbWJlciBpdCB3YXMgcnVsZWQgYSBzdGFsbC1zcGluLCBhcyB1c3Vh bCHwn5icDQoNCj4gRGF0ZTogRnJpLCAxMCBBcHIgDQoyMDE1IDEwOjE5OjUyIC0wNTAwDQo+IEZy b206IFRpbUBNeVJWMTAuY29tDQo+IFRvOiANCnJ2MTAtbGlzdEBtYXRyb25pY3MuY29tDQo+IFN1 YmplY3Q6IFJlOiBSVjEwLUxpc3Q6IE5UU0IgLSBQcm9iYWJsZSANCkNhdXNlDQo+IA0KPiAtLT4g UlYxMC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5OiBUaW0gT2xzb24gDQo8VGltQG15cnYxMC5jb20+ DQo+IA0KPiBQaGlsLA0KPiBUaGFua3MgZm9yIHBvc3RpbmcuIFRoYXQncyANCmp1c3Qgc2lja2Vu aW5nIHRvIHJlYWQuIFJlZ2FyZGluZyBMaW5uJ3MNCj4gcG9zdCwgSSB0cnVseSB0aGluayB0aGF0 IHRoZSANCnBlb3BsZSB3aG8gbW9zdCBvZnRlbiBkbyB0aGUgdmVyeQ0KPiBxdWVzdGlvbmFibGUg dGhpbmdzIGFyZSBhbHNvIHRoZSBvbmVzIA0KdGhhdCB3aWxsIG5ldmVyIGxpc3Rlbg0KPiB0byB0 aGUgYWR2aWNlLCBzbyBpdCdzIGEgaG9wZWxlc3MgcGxlYSwgc2FkbHkuIEkgDQp0aGluayBiYWNr DQo+IHRvIGhvdyBtYW55IHRpbWVzIEkgaGFkIHRvIGdldCBvbiBEYW4gTGxveWQgYW5kIGhlIA0K bmV2ZXINCj4gbGlzdGVuZWQgb25jZS4gVGhpcyBwYXJ0aWN1bGFyIGFjY2lkZW50L3BpbG90IHdh cyBmYXIgbGVzcw0KPiANCmxheCB0aGFuIERhbiB3YXMsIGJ1dCBzdGlsbCwgdGhlcmUgYXJlIGp1 c3QgZmFyIHRvbyBtYW55IHRoaW5ncw0KPiBpbiB0aGUgDQpyZXBvcnQgdG8gYWxsb3cgbWUgdG8g anVzdCB0aGluayAid2VsbCwgYXQgbGVhc3QgaGUNCj4ga25ldyB3aGF0IGhlIHdhcyANCmRvaW5n Ii4gSXQgd2FzIGEgc2hvY2tpbmcgcmVhZCwgYW5kIGhvcnJpZnlpbmcNCj4gd2hlbiB5b3UgY29u c2lkZXIgdGhlIA0KZGlzY3Vzc2lvbiBhYm91dCB0aGUgY3Jhc2ggYW5kIHRoZSBjaGlsZCwNCj4g YW5kIHNlZSB0aGUgbnVtZXJvdXMgcGljdHVyZXMgDQpvZiB0aGUgcGxhbmUuIFRoZXJlIGlzbid0 IGFueXRoaW5nDQo+IGxlZnQgb2YgdGhlIGZyb250IGVuZCwgYW5kIHlvdSBjYW4ndCANCmJsYW1l IHRoZSBhbmdsZSBvZiBpbXBhY3QNCj4gb24gYW55dGhpbmcgYnV0IHBvb3IgcGlsb3RpbmcsIGV2 ZW4gaWYgeW91IA0KZXhjdXNlIHRoZSBSVFYNCj4gdXNlLiBUaGlzIGFjY2lkZW50IGRpZG4ndCBo YXZlIHRvIGVuZCB0aGlzIHdheS4NCj4gDQoNCj4gU29tZSB0aGluZ3MgSSBub3RlZC4uLg0KPiAN Cj4gVGhlIGZ1ZWwgaGFuZGxlIHdhcyBpbnN0YWxsZWQgDQpyZXZlcnNlIGluZGljYXRpbmcuIFdo eT8gV2h5DQo+IGNhbid0IGEgcGlsb3QgdW5kZXJzdGFuZCB0aGF0IHRoaW5ncyBsaWtlIA0KdGhh dCBhcmUgY3JpdGljYWwsDQo+IGFuZCB5b3UgbmVlZCB0byBpbnN0YWxsIHRoZW0gc28gdGhhdCBB TllPTkUgY2FuIA0KdW5kZXJzdGFuZA0KPiB0aGVtPw0KPiANCj4gT2YgY291cnNlLCB0aGUgUlRW IG9uIHRoZSBOUFQgDQp0aHJlYWRzLi4uIFNvIGhvdyBtYW55IHRpbWVzDQo+IGRvIHdlIGhhdmUg dG8gZGlzY3VzcyB0aGlzPyBObyB0ZWZsb24gdGFwZSwgDQpubyBSVFYuIEZ1ZWwNCj4gbHViZSBJ IGd1ZXNzIGlzIHRoZSBjb21tb24gb25lLCB3aGljaCBpcyBnb29kLiBJZiB5b3UgDQp1c2UNCj4g YSBwYXN0ZSBvZiBhbnkgdHlwZSwgb3IgZXZlbiBpbiB0aGUgY2FzZSBvZiBhbnRpLXNlaXplIG9u DQo+IA0Kc3BhcmsgcGx1Z3MsIHlvdSBkb24ndCBwdXQgaXQgb24gdGhlIGZpcnN0IGNvdXBsZSB0 aHJlYWRzLg0KPiBUaGVzZSBhcmUgDQpqdXN0IGNvbW1vbiBrbm93bGVkZ2UgcHJhY3RpY2VzLiBZ b3UgZG9uJ3Qgd2FudA0KPiB0byBjb250YW1pbmF0ZSB0aGUgDQppbnNpZGUsIG5vciBnaXZlIG9w cG9ydHVuaXR5IGZvciB0aGUNCj4gY29tcG91bmQgdG8gY29tZSBvZmYgDQppbnNpZGUuDQo+IA0K PiBIZXJlJ3Mgb25lIEknbSBub3QgZmFtaWxpYXIgd2l0aC4gVGhlIGVsZWN0cmljIGZ1ZWwgDQpw dW1wDQo+IHdhcyBhICJGYWNldCBBdXRvbW90aXZlIi4gU29tZW9uZSBlbHNlIGhlbHAgbWUgb3V0 IGhlcmUNCj4gYXMgDQpJJ20gbm90IGZhbWlsaWFyIHdpdGggdGhlIGNhcmJ1cmV0ZWQgUlYtMTAg ZnVlbCBzeXN0ZW0uDQo+IElzIHRoYXQgYSBub3JtYWwgDQpwdW1wLCBvciBzb21ldGhpbmcgaGFj a2VkIGluPyBJIGtub3cNCj4gRmFjZXQgcHVtcHMgYXJlIHVzZWQgb2Z0ZW4sIGJ1dCBpcyANCnRo YXQgdGhlIHByb3BlciBwdW1wPw0KPiBGdWVsIHN5c3RlbXMgYXJlbid0IHNvbWV0aGluZyB0byBz Y3JldyB3aXRoLCBzbyANCmhvcGVmdWxseQ0KPiB0aGF0IHdhcyB0aGUgcmlnaHQgb25lLg0KPiAN Cj4gVGhlIGZ1ZWwgc2VsZWN0b3IgDQpwb3NpdGlvbiwgYW5kIGtleSBwb3NpdGlvbiBpdCdzIGhh cmQNCj4gdG8gaW50ZXJwcmV0LiBOb3QgZ29vZCBmb3IgdHJ5aW5nIGEgDQpyZXN0YXJ0LCBidXQN Cj4gdGhlIGZ1ZWwgdmFsdmUgb2ZmIGZvciB0aGUgY3Jhc2ggaXMgYSBnb29kIHRoaW5nLiANCk5v dA0KPiBzdXJlIHdoYXQgdG8gdGhpbmsgYWJvdXQgdGhlIGtleSBwb3NpdGlvbiB0aG91Z2guDQo+ IA0KPiANClRoZXJlIHNlZW0gdG8gYmUgbnVtZXJvdXMgaXNzdWVzIHdpdGggdGhlIHBsYW5lLiBJ IGhhdGUgaXQNCj4gd2hlbiBJIGhlYXIgDQpvZiBwZW9wbGUgZmx5aW5nIGNvbnRpbnVhbGx5IGFu ZCByZWd1bGFybHkgd2l0aG91dA0KPiBhZGRyZXNzaW5nIGFuIGlzc3VlLiANCkkgbWVhbiwgaGUg d2FzIGZydXN0cmF0ZWQgd2l0aA0KPiB0aGUgImNvbnN0YW50IGhhc3NsZSIgb2YgaGF2aW5nIHRv IHJlc2V0IA0KdGhlIGFsdGVybmF0b3INCj4gaW4gZmxpZ2h0LiBSRUFMTFkhPyE/IEkgdGhpbmsg aWYgbWluZSBibG93cyBPTkNFIEkgDQpuZWVkDQo+IHRvIGxvb2sgYXQgaXQuIFR3aWNlIGFuZCBp dCdzIGFuIGlzc3VlIGZvciBzdXJlLiBCdXQNCj4gDQpjb25zdGFudGx5IGluIGZsaWdodD8gV1RG IGFyZSB5b3UgZG9pbmcgY2FycnlpbmcgcGFzc2VuZ2Vycw0KPiBpZiB0aGlzIGlzIA0KdGhlIGNh c2U/IT8hIFRoYXQgYmxvd3MgbXkgbWluZC4NCj4gDQo+IFRoZW4gdGhlcmUncyB0aGUgMTI1cHNp IGZ1ZWwgDQpwcmVzc3VyZS4gQWdhaW4sIHlvdSBoYXZlDQo+IGFuIGluZGljYXRpb24gbGlrZSB0 aGF0IGFuZCB5b3UganVzdCBmbHkgDQppdD8hPyE/ISBJIG1ldA0KPiBhIGd1eSBvbmNlIHdobyBu ZXZlciBjYWxpYnJhdGVkIGhpcyBlbmdpbmUgDQpzZW5zb3JzLg0KPiBZb3UgaGF2ZSB0byBhZGQg cHJvcGVyIHNjYWxlIGZhY3RvcnMgYW5kIG9mZnNldHMgZm9yDQo+IA0KdGhlbSB0byBldmVuIHJl YWQgYWNjdXJhdGVseS4gSGUgYWRqdXN0ZWQgaGlzIG9pbCBwcmVzc3VyZQ0KPiBvbiB0aGUgZW5n aW5lIA0KdG8gbWF0Y2ggaGlzIE5PTi1zZXR1cCBpbnN0cnVtZW50LiBUaGVuDQo+IGZvdW5kIG91 dCBob3cgdG8gc2V0IHRoZSANCmluc3RydW1lbnQgdXAgZnJvbSBtZS4NCj4gV1RGIGlzIHRoYXQg YWJvdXQhPyEgWW91IGRpZG4ndCBoYXZlIHRpbWUgdG8gZG8gDQp0aGF0DQo+IGJlZm9yZSB5b3Ug Zmlyc3QgZmxldz8gRmFyIGJldHRlciB0aGFuIGtpbGxpbmcgeW91cnNlbGYhDQo+IE15IA0Kb25s eSBjb21tZW50IHRvIHBlb3BsZSBsaWtlIHRoYXQgaXMgIlRISU5LISEhISINCj4gDQo+IFRoZW4g dGhlcmUncyANCnRoZSBjb21tZW50cyBmcm9tIHBlb3BsZSB0aGF0IHRoZXkgdHJpZWQNCj4gdG8g c3RhcnQgdGhlIGVuZ2luZSBhbmQgdGhlIA0KInN0YXRlciB3YXNuJ3QgY29ubmVjdGVkIiB3aGlj aA0KPiBpdCBzb3VuZHMgbGlrZSBpcyBhY3R1YWxseSB0aGF0IHRoZSANCnN0YXJ0ZXIgd2FzIGZh bGxpbmcNCj4gb2ZmIHRoZSBlbmdpbmUgYW5kIG5vdCBtYWtpbmcgY29udGFjdC4gSGUgaGFkIA0K aGVhcmQNCj4gaXQgbWFraW5nIG5vaXNlIG9uIHByZXZpb3VzIGZsaWdodHMgYW5kIG5vdyBpdCB3 b3VsZG4ndA0KPiANCnN0YXJ0LiBBZ2FpbiwgUkVBTExZPyBZb3UgaGVhciBzb21ldGhpbmcgb2Rk IGFuZA0KPiBkb24ndCBpbnZlc3RpZ2F0ZSANCml0Pw0KPiANCj4gQW5vdGhlciBvbmUuLi4gdGhl IFByb3Agb25seSBtYWRlIDI0NTAgUlBNLCBidXQgdGhhdCdzIA0KdGhlDQo+IHdheSBpdCdzIGFs d2F5cyBiZWVuIHNvIGl0IHdhc24ndCBmaXhlZC4gUkVBTExZIT8hPyE/DQo+IFNvIA0Kc29tZXRo aW5nIGFzIGltcG9ydGFudCBhcyB5b3VyIGVuZ2luZSBtYWtpbmcgdGhlDQo+IHBvd2VyIGl0IG5l ZWRzIHRvIGlzbid0IA0KaW1wb3J0YW50IHRvIHlvdT8gVHJ1bHkgSSBzYXksDQo+IGhlcmUgaXMg c29tZW9uZSB3aG8ganVzdCBkaWRuJ3QgZ2l2ZSBhIA0KY3JhcCBhYm91dA0KPiBkb2luZyB0aGlu Z3MgInJpZ2h0Ii4gVGhlcmUgYXJlIHRvbyBtYW55IGluZGljYXRvcnMuDQo+IA0KDQo+IERpZG4n dCBwdXQgdGhlIGZ1ZWwgdHJhbnNkdWNlciBpbiBlYXJsaWVyIGJlY2F1c2UgaXQgbmVlZGVkDQo+ IGEgDQpjZXJ0YWluIGFtb3VudCBvZiBzcGFjZSBhbmQgaGFkIHRvIGJlbmQgdHViaW5nIHRvIGRv IGl0Lg0KPiBHb3NoLCBzbyB0aGF0J3MgDQphIHJlYXNvbiB0byBqdXN0IG5vdCBpbnN0YWxsIGl0 IHRoZW4/DQo+IFRoZW4gZmluYWxseSBESUQgcHV0IGl0IGluLCBidXQgDQp1c2VkIFJUViBhbmQg ZGlkbid0IGNvbm5lY3QNCj4gYW55IHdpcmluZyB0byBpdC4gVGhpcyBzaG91bGQgaGF2ZSBiZWVu IGRvbmUgDQpQUklPUg0KPiB0byB0aGUgZmlyc3QgZmxpZ2h0Lg0KPiANCj4gQW5kIEkgZG9uJ3Qg Y2FyZSBpZiB5b3UncmUgDQpTZWFuIFR1Y2tlciwgaWYgeW91J3JlIGZseWluZw0KPiBhIGNhcmJ1 cmV0ZWQgYWlycGxhbmUgeW91IHNob3VsZG4ndCANCmNvbnNpZGVyIHlvdXJzZWxmDQo+ICJub3Qg YSBiaWcgcHJvcG9uZW50IG9mIGNhcmIgaGVhdCIgaWYgeW91J3JlIGdvaW5nIA0KdG8NCj4gZmx5 IElGUiAob3IgZXZlbiBWRlIpLiBDYXJiIGhlYXQgcHJvdmlkZXMgYSB2ZXJ5DQo+IHNwZWNpZmlj IA0KZnVuY3Rpb24uIElmIHlvdSB3YW50IHRvIGlnbm9yZSBpdCBvbiB5b3VyDQo+IGxhbmRpbmcg cHJlcCwgdGhhdCdzIG9uZSANCnRoaW5nLCBidXQgaWYgeW91IGRhbmcgd2VsbA0KPiBiZXR0ZXIg a25vdyB3aGVuIGlzIGEgZ29vZCB0aW1lIHRvIHRoaW5rIA0KYWJvdXQgdXNpbmcgaXQuDQo+IA0K PiBBbmQgZmluYWxseSwgYSBwbGVhIGZyb20gbWUsIHRvIHlvdS4gSWYgeW91J3JlIA0Kbm90IHNv bWVvbmUNCj4gd2hvJ3MgZ29pbmcgdG8gdGhvdWdodGZ1bGx5IGFwcHJvYWNoIHlvdXIgYnVpbGQs IGFuZCANCnRyeQ0KPiB0byBkbyB0aGluZ3MgcmlnaHQsIHBsZWFzZSB0cnkgdG8gcmVmcmFpbiBm cm9tIHVzaW5nIG15DQo+IG5hbWUgDQppbiB5b3VyIGludGVybmV0IHBvc3RpbmdzLiBJIGtub3cs IEkga25vdywgaGlzDQo+IEFuZGFpciBmdWVsIHZhbHZlIGluc3RhbGwgDQp3YXNuJ3QgaW52b2x2 ZWQgaW4gdGhlIGNyYXNoDQo+IGNhdXNlIGF0IGFsbCwgb3RoZXIgdGhhbiBtYXliZSB0aGUgZmFj dCANCnRoYXQgaGUgcHV0IHRoZQ0KPiBoYW5kbGUgb24gcmV2ZXJzZWQsIGJ1dCBJIHdhc24ndCB0 aHJpbGxlZCBhYm91dCANCnNlZWluZw0KPiB0aGF0IGhlIHJlZmVycmVkIHRvIG1lIGluIGhpcyBm b3J1bSBwb3N0LiBJZiB5b3UgbGlrZQ0KPiANCndoYXQgeW91IHNlZSwgY29weSBpdCwgYnV0IGlm IHlvdSdyZSBkb2luZyBhbGwgc29ydHMNCj4gb2Ygb3RoZXIgc3R1cGlkIA0KdGhpbmdzLCBqdXN0 IGxlYXZlIG15IG5hbWUgb3V0IG9mIGl0Lg0KPiBJdCdzIGxpa2Ugbm90IGNhbGxpbmcgaXQgYSAi VmFuJ3MgDQpSVi0xMCIgaWYgeW91J3JlDQo+IGdvaW5nIHRvIHNpZ25pZmljYW50bHkgbW9kaWZ5 IHRoZSBhaXJmcmFtZS4gSSANCmRvbid0DQo+IG5lZWQgdG8gYmUgdGllZCB0byB5b3VyIGltcHJv cGVyIG1ldGhvZHMgb2YgYnVpbGQgb3INCj4gDQptYWludGVuYW5jZS4gQmV0dGVyIHlldCwganVz dCB0cnkgdG8gZG8gZXZlcnl0aGluZyB0bw0KPiBjZXJ0aWZpZWQgYWlyY3JhZnQgDQpzdGFuZGFy ZHMgYW5kIHByb2NlZHVyZXMgYW5kIHlvdQ0KPiB3b24ndCBoYXZlIHRvIHdvcnJ5IGFib3V0IHdo YXQgeW91ciANCk5UU0IgcmVwb3J0IHJlYWRzDQo+IGxpa2UgKG9yIGF0IGxlYXN0IGN1dCB5b3Vy IGNoYW5jZSkuDQo+IA0KPiANClNvcnJ5LCB0aGF0IG1heSBoYXZlIGJlZW4gcGFydCBhbmFseXNp cywgcGFydCByYW50LCBidXQNCj4gaXQgZHJpdmVzIG1lIA0KbnV0cyB0byBzZWUgc29tZSBvZiB0 aGUgdGhpbmdzIHRoYXQgYnJpbmcgZG93bg0KPiBwbGFuZXMsIGVzcGVjaWFsbHkgDQpSVi0xMCdz LiBTbyBmYXIgdGhlcmUncyBiZWVuIG9ubHkgYQ0KPiB2ZXJ5IHRpbnkgZnJhY3Rpb24gb2YgYWNj aWRlbnRzIHRoYXQgDQp3ZXJlIG5vdCBkaXJlY3RseQ0KPiBhdHRyaWJ1dGFibGUgdG8gc29tZXRo aW5nIHN0dXBpZCB0aGF0IHNvbWVvbmUgDQpkaWQuDQo+IExldCdzIHRyeSB0byBlbGltaW5hdGUg dGhvc2Ugc29ydHMgb2YgdGhpbmdzIGJlY2F1c2UNCj4gd2UnZCANCmhhdmUgYSAqbmVhciogc3Bv dGxlc3Mgc2FmZXR5IHJlY29yZCBvbiBvdXIgbWFrZSBhbmQNCj4gbW9kZWwgaWYgeW91IA0KZWxp bWluYXRlZCB0aGUgdGhpbmdzIHRoYXQgd2VyZSBwdXJlDQo+IGlnbm9yYW5jZSBhbmQgaWRpb2N5 Lg0KPiANCg0KPiBUaW0NCj4gDQo+IA0KPiANCj4gDQo+IA0KPiANCj4gT24gDQo0LzkvMjAxNSAx MTo1MCBQTSwgUGhpbGxpcCBQZXJyeSB3cm90ZToNCj4gPiBTb21lIG9mIHlvdSBtaWdodCBoYXZl IHNlZW4gDQp0aGlzIGFscmVhZHksIGJ1dCBEb3VnIE5lYmVydCdzIHByb2JhYmxlDQo+ID4gY2F1 c2Ugd2FzIHB1Ymxpc2hlZCB0b2RheS4gDQpUaGlzIHdhcyB0aGUgYWNjaWRlbnQgaW4gT3JlZ29u IGxhc3QgTWF5Lg0KPiA+ICgyIEZhdGFsIC0gMSANClNlcmlvdXMpDQo+ID4NCj4gPiAqIFRoZSBw cm9iYWJsZSBjYXVzZSBkb2N1bWVudA0KPiA+IA0KPGh0dHA6Ly93d3cubnRzYi5nb3YvX2xheW91 dHMvbnRzYi5hdmlhdGlvbi9HZW5lcmF0ZVBERi5hc3B4P2lkPVdQUjE0RkEyMTgmcnB0PWZpPg0K PiANCj4gaXMgYSBodW1ibGluZyByZWFkLi4uDQo+ID4gKiBFdmVyeSBkb2N1bWVudCBpbiB0aGUg ZW50aXJlIA0KZG9ja2V0DQo+ID4gDQo8aHR0cDovL2Rtcy5udHNiLmdvdi9wdWJkbXMvc2VhcmNo L2hpdGxpc3QuY2ZtP2RvY2tldElEPTU3MTI5JkNGSUQ9NTI0MDU4JkNGVE9LRU49MzQ4MzA0NTE+ DQo+IA0KPiBpcyB3b3J0aCB0aGUgcmVhZC4uLg0KPiA+ICogU3BlY2lmaWNhbGx5IHRoZSBwaG90 b3MgaW4gdGhpcyANCmRvY3VtZW50DQo+ID4gDQo8aHR0cDovL2Rtcy5udHNiLmdvdi9wdWJsaWMl MkY1NzAwMC01NzQ5OSUyRjU3MTI5JTJGNTcwMDI4LnBkZj4gDQphcmUNCj4gPiBmdWxsIG9mIGVt b3Rpb24uIEFuZ2VyLCBTYWRuZXNzLCBEaXNiZWxpZWYsIENvbmZ1c2lvbi4NCj4gDQo+DQo+ID4g SW4gY2FzZSB0aGUgbGlua3MgZG8gbm90IHdvcmssIHRoZSBjYXNlIElEIGlzIFdQUjE0RkEyMTgg c28gDQp5b3UgY2FuIGxvb2sNCj4gPiBpdCB1cCB5b3Vyc2VsZi4NCj4gPg0KPiA+IEkgd2lsbCBn aXZlIA0KeW91IHRoZSBudXRzaGVsbCwgYnV0IHlvdSBuZWVkIHRvIGdvIHJlYWQgdGhlIGRvY3Vt ZW50cy4NCj4gPiBSVFYgd2FzIA0KdXNlZCB0byBzZWFsIE5QVCBmaXR0aW5ncyBvbiBhIChyZWNl bnRseSBpbnN0YWxsZWQpIGZ1ZWwgZmxvdw0KPiA+IA0KdHJhbnNkdWNlci4gQSB+MC4yNSIgY2h1 Y2tvZiBSVFYgY2FtZSBsb29zZSBhbmQgZmxvd2VkIGRvd25zdHJlYW0gaW50bw0KPiANCj4gdGhl IG1ldGVyZWQgbm96emxlIG9mIHRoZSB0cmFuc2R1Y2VyLiBUaGUgbWV0ZXJlZCBob2xlIHdhcyB+ MC4xMTUiIA0KaW4NCj4gPiBkaWFtZXRlciBhbmQgdGhlIFJUViBwbHVnZ2VkIHRoZSBob2xlIGFu ZCBzdGFydmVkIHRoZSBlbmdpbmUgb2YgDQpmdWVsLg0KPiA+IFRvIG1ha2UgbWF0dGVycyB3b3Jz ZSwgYSBzdGFsbCAoYW5kIGxpa2VseSB0aGUgc3RhcnQgb2YgYSANCnNwaW4pIG9jY3VycmVkDQo+ ID4gZHVyaW5nIHRoZSBmb3JjZWQgbGFuZGluZy4NCj4gPg0KPiA+IA0KVGhpcyBpcyB3b3J0aCBh IHJlYWQuIFRoZXJlIHdlcmUgb3RoZXIgaW5kaWNhdGlvbnMgb2YgYW4gYWlyY3JhZnQgd2l0aA0K PiANCj4gcXVlc3Rpb25hYmxlIG1haW50ZW5hbmNlLCBidXQgdGhlIGV2ZW50IHRoYXQgYnJvdWdo dCBkb3duIHRoaXMgDQphaXJwbGFuZQ0KPiA+IHdhcyAxMDAlIHByZXZlbnRhYmxlLiBUaGUgcmVh bCBkaXNhcHBvaW50aW5nIHBhcnQgaXMgdGhhdCANCnRoZSBpc3N1ZSB3YXMNCj4gPiBwb2ludGVk IG91dCBieSBhIGZyaWVuZCBidXQgaWdub3JlZC4NCj4gDQo+DQo+ID4gRXZlbiBpZiB3ZSBkb24n dCBoYXZlIFJUViBvbiBvdXIgZnVlbCBsaW5lcyAoSSBob3BlIHdlIGRvbid0IC0gDQpTYW1lDQo+ ID4gdGhpbmcgZm9yIFRlZmxvbiBUYXBlKSwgdGhlcmUgaXMgYSBsZXNzb24gaW4gaGVyZSBmb3Ig YWxsIG9mIA0KdXMuIEl0DQo+ID4gZG9lc24ndCBkbyB1cyBhbnkgZ29vZCB0byBzaGFyZSBpbmZv cm1hdGlvbiBhbmQgY29uY2VybnMgDQp3aXRoIGVhY2ggb3RoZXINCj4gPiBpZiB3ZSBhcmVuJ3Qg Z29pbmcgdG8gdGFrZSBhIG1vbWVudCB0byBzdG9wIGluIG91ciANCnRyYWNrcyBhbmQgc2VyaW91 c2x5DQo+ID4gbGlzdGVuIHRvIHRoZW0uIEVhcnMgb3BlbiwgbW91dGggY2xvc2VkLCBzdG9wLCAN CmFuZCB0aGluay4gSSdtIGFzDQo+ID4gZ3VpbHR5IGFzIHRoZSBuZXh0IHBlcnNvbiwgYnV0IHRo aXMgaXMgYSBjYXNlIA0Kd2hlcmUgd2UgY2FuIGFsbCByZXNldA0KPiA+IG91cnNlbHZlcyBhbmQg aW1wcm92ZSBvdXIgZmxlZXRzIA0KcmVjb3JkLg0KPiA+DQo+ID4gUGhpbA0KPiANCj4gDQo+IA0K TmF2aWdhdG9yIHRvIA0KVW4vU3Vic2NyaXB0aW9uLA0KPiANCnZpYSB0aGUgV2ViIA0KaHR0cDov L2ZvcnVtcy5tYXRyb25pY3MuY29tDQo+IA0KaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL2NvbnRy aWJ1dGlvbg0KPiANCj09PT09PT09PT09DQo+IA0KPiANCg0KPiANCu+/ve+/vX7vv73vv70sA2fv v73vv70NCg0KDQoNCg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT0NCl8tPSAgICAgICAgICAtIFRoZSBSVjEwLUxpc3QgRW1haWwg Rm9ydW0gLQ0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVhdHVyZXMgTmF2aWdhdG9yIHRv IGJyb3dzZQ0KXy09IHRoZSBtYW55IExpc3QgdXRpbGl0aWVzIHN1Y2ggYXMgTGlzdCBVbi9TdWJz Y3JpcHRpb24sDQpfLT0gQXJjaGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBD aGF0LCBGQVEsDQpfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBtb3JlOg0KXy09DQpfLT0g ICAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9SVjEwLUxpc3QNCl8tPQ0K Xy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT0NCl8tPSAgICAgICAgICAgICAgIC0gTUFUUk9OSUNTIFdFQiBGT1JVTVMgLQ0KXy09IFNh bWUgZ3JlYXQgY29udGVudCBhbHNvIGF2YWlsYWJsZSB2aWEgdGhlIFdlYiBGb3J1bXMhDQpfLT0N Cl8tPSAgIC0tPiBodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20NCl8tPQ0KXy09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCl8tPSAg ICAgICAgICAgICAtIExpc3QgQ29udHJpYnV0aW9uIFdlYiBTaXRlIC0NCl8tPSAgVGhhbmsgeW91 IGZvciB5b3VyIGdlbmVyb3VzIHN1cHBvcnQhDQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRtaW4uDQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL2NvbnRyaWJ1dGlvbg0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0NCg0KIAkJIAkgICAJCSAg ________________________________________________________________________________
Date: Apr 10, 2015
Subject: Re: NTSB - Probable Cause
Yeah, that crash was the first, and it had a big impact on a lot of us. I guess if you're going to have a crash at a particular time, that had so many warning signs, that may have been as "good" a time as any. It got a lot of people to stop and reflect on what they have in their garage, before they went out to fly. I also hate to be so "down" on this pilot in this crash that we're talking about today too...it's not my intention to just criticize the pilot, but it does put the blame where it lies, and as usual, he didn't just take his own life with him. So it serves as a good attitude check for us all. It's sad that we even need that sometimes. Overall, I think it's easy to see that the RV-10 has proven to basically have an unscathed safety record when it comes to the airframe. In thinking through the fatal and non-fatal crashes we have on the list, pretty much every one of them was caused by someone doing something they shouldn't have. This should be comforting to us all in that it does show that the onus is on US for the ability to safely take our passengers from ground to sky to ground again without incident. I not only do not want to dodge responsibility for my flights, but I want to accept it happily. I am personally glad that the NTSB does not pull punches and lays the blame on the pilot almost every single time. It really is up to US to make sure that we aren't the next statistic. NOTHING that we are doing is ground breaking and new. There have been hundreds and thousands of people who went before us and paid in blood for all of the rules and regulations and designs that keep us safe today. If we fly our best and use our best judgement, we really should not have need to worry much about the successful outcome of any flight. (with few rare exceptions) Certainly we enjoy a far better safety record than many other models of airplanes, and that we should be humbly proud of. Tim On 4/10/2015 11:55 AM, Danny Riggs wrote: > Ahhh! It's been so long that I'd forgotten who it was. I still remember > some of the lessons of that crash however! > ________________________________________________________________________________
Date: Apr 10, 2015
"We have met the enemy, and he is us" - Pogo The other sad thing about both Dan and Doug is that, when faced with the ultimate high-stress test, they both failed as pilots. And they're not alone. No matter how often it's drilled that you never let the plane stall, that you fly it into the trees or until it won't fly anymore, both allowed it to stall while still a fatal distance above the ground. I suspect that we all think we have 'the right stuff', that we wouldn't do that. Yet some of us do. Clearly biennially doing a few stalls at 4000' isn't good enough. And stall training very low is too risky. Is there any way to do realistic training outside of a million dollar simulator? How can we get the "save the plane" mentality out of our thinking? Do we do too much "simulated emergency" training where there's always an airport right below us? What's the right training mix of benefit vs risk? I sure wish I knew the answers to these questions. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440599#440599 ________________________________________________________________________________
Date: Apr 10, 2015
On 4/10/2015 5:01 PM, Bob Turner wrote: > > "We have met the enemy, and he is us" - Pogo I miss Pogo! And he was spot on with that one. > The other sad thing about both Dan and Doug is that, when faced with the ultimate high-stress test, they both failed as pilots. And they're not alone. No matter how often it's drilled that you never let the plane stall, that you fly it into the trees or until it won't fly anymore, both allowed it to stall while still a fatal distance above the ground. I suspect that we all think we have 'the right stuff', that we wouldn't do that. Yet some of us do. Clearly biennially doing a few stalls at 4000' isn't good enough. And stall training very low is too risky. Is there any way to do realistic training outside of a million dollar simulator? How can we get the "save the plane" mentality out of our thinking? Do we do too much "simulated emergency" training where there's always an airport right below us? What's the right training mix of benefit vs risk? I sure wish I knew the answers to these questions. I've had three off-field emergency landings and one on-airport emergency landing, and with the help of all those angels on my shoulders, they were non-events .... no further damage to the airframe, pilot, people/property on the ground .... or the ground. ;-) I firmly believe that we really have no clue how we will react when the s..t hits the fan ..... until it does. All we can do to prepare for emergencies is to think .... 'how would I handle that ?????' when we read of an accident or incident. I do that all the time. I learn from survivors how they handled their 'oh s..t' moments. The problem with emergency training is that there are far too many ways for disaster to occur than we have the time/knowledge to prepare for them. We just try and cope the best we can. Sometimes we win, and sometimes we lose. I think it was Bob Hoover who said 'Fly the airplane as far into the crash as you can.' Sage advice. Trying to stretch the approach to the impact point with insufficient energy will most likely turn a flying airplane into a lawn dart. It is, as you said, the 'save the plane' mentality, and I've lost friends because of it. My airplanes owe me nothing .... I've had so much pleasure with their use that if I lose one .... I hope to be around another day to fly again. Yes, it will be painful, and I'd be happy to survive and mourn. Linn > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=440599#440599 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Apr 10, 2015
Subject: Shoulder Harnesses
Last night I was thinking about the images in Doug's photos and was really curious to know how effective the shoulder harness anchor bolt is in that situation. My curiosity stems from seeing a friends Culver Cadet (no shoulder harnesses in that old plane) that he landed off field 7 years ago. It's still sitting in his garage and has a pair of human head shaped indentations in the glare shield. If he had effective shoulder harnesses, it would have saved them some blood and a deviated septum. We've had a handful of RV-10 accidents that have tested the integrity of the shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. 1) Have any of you seen, first hand, an RV-10 airframe after it has been in an accident where the shoulder harnesses were stressed significantly? 2) Would any of you know where we could get that information? Perhaps a FOIA or something similar? I'd really like to get the real details on how that shoulder harness performed. We've probably got 5-6 accidents where that information could/would be collected. Phil ________________________________________________________________________________
Date: Apr 10, 2015
Amen! Well said, Tim! grumpy > On Apr 10, 2015, at 10:19 AM, Tim Olson wrote: > > > Phil, > Thanks for posting. That's just sickening to read. Regarding Linn's > post, I truly think that the people who most often do the very > questionable things are also the ones that will never listen > to the advice, so it's a hopeless plea, sadly. I think back > to how many times I had to get on Dan Lloyd and he never > listened once. This particular accident/pilot was far less > lax than Dan was, but still, there are just far too many things > in the report to allow me to just think "well, at least he > knew what he was doing". It was a shocking read, and horrifying > when you consider the discussion about the crash and the child, > and see the numerous pictures of the plane. There isn't anything > left of the front end, and you can't blame the angle of impact > on anything but poor piloting, even if you excuse the RTV > use. This accident didn't have to end this way. > > Some things I noted... > > The fuel handle was installed reverse indicating. Why? Why > can't a pilot understand that things like that are critical, > and you need to install them so that ANYONE can understand > them? > > Of course, the RTV on the NPT threads... So how many times > do we have to discuss this? No teflon tape, no RTV. Fuel > lube I guess is the common one, which is good. If you use > a paste of any type, or even in the case of anti-seize on > spark plugs, you don't put it on the first couple threads. > These are just common knowledge practices. You don't want > to contaminate the inside, nor give opportunity for the > compound to come off inside. > > Here's one I'm not familiar with. The electric fuel pump > was a "Facet Automotive". Someone else help me out here > as I'm not familiar with the carbureted RV-10 fuel system. > Is that a normal pump, or something hacked in? I know > Facet pumps are used often, but is that the proper pump? > Fuel systems aren't something to screw with, so hopefully > that was the right one. > > The fuel selector position, and key position it's hard > to interpret. Not good for trying a restart, but > the fuel valve off for the crash is a good thing. Not > sure what to think about the key position though. > > There seem to be numerous issues with the plane. I hate it > when I hear of people flying continually and regularly without > addressing an issue. I mean, he was frustrated with > the "constant hassle" of having to reset the alternator > in flight. REALLY!?!? I think if mine blows ONCE I need > to look at it. Twice and it's an issue for sure. But > constantly in flight? WTF are you doing carrying passengers > if this is the case?!?! That blows my mind. > > Then there's the 125psi fuel pressure. Again, you have > an indication like that and you just fly it?!?!?! I met > a guy once who never calibrated his engine sensors. > You have to add proper scale factors and offsets for > them to even read accurately. He adjusted his oil pressure > on the engine to match his NON-setup instrument. Then > found out how to set the instrument up from me. > WTF is that about!?! You didn't have time to do that > before you first flew? Far better than killing yourself! > My only comment to people like that is "THINK!!!!" > > Then there's the comments from people that they tried > to start the engine and the "stater wasn't connected" which > it sounds like is actually that the starter was falling > off the engine and not making contact. He had heard > it making noise on previous flights and now it wouldn't > start. Again, REALLY? You hear something odd and > don't investigate it? > > Another one... the Prop only made 2450 RPM, but that's the > way it's always been so it wasn't fixed. REALLY!?!?!? > So something as important as your engine making the > power it needs to isn't important to you? Truly I say, > here is someone who just didn't give a crap about > doing things "right". There are too many indicators. > > Didn't put the fuel transducer in earlier because it needed > a certain amount of space and had to bend tubing to do it. > Gosh, so that's a reason to just not install it then? > Then finally DID put it in, but used RTV and didn't connect > any wiring to it. This should have been done PRIOR > to the first flight. > > And I don't care if you're Sean Tucker, if you're flying > a carbureted airplane you shouldn't consider yourself > "not a big proponent of carb heat" if you're going to > fly IFR (or even VFR). Carb heat provides a very > specific function. If you want to ignore it on your > landing prep, that's one thing, but if you dang well > better know when is a good time to think about using it. > > And finally, a plea from me, to you. If you're not someone > who's going to thoughtfully approach your build, and try > to do things right, please try to refrain from using my > name in your internet postings. I know, I know, his > Andair fuel valve install wasn't involved in the crash > cause at all, other than maybe the fact that he put the > handle on reversed, but I wasn't thrilled about seeing > that he referred to me in his forum post. If you like > what you see, copy it, but if you're doing all sorts > of other stupid things, just leave my name out of it. > It's like not calling it a "Van's RV-10" if you're > going to significantly modify the airframe. I don't > need to be tied to your improper methods of build or > maintenance. Better yet, just try to do everything to > certified aircraft standards and procedures and you > won't have to worry about what your NTSB report reads > like (or at least cut your chance). > > Sorry, that may have been part analysis, part rant, but > it drives me nuts to see some of the things that bring down > planes, especially RV-10's. So far there's been only a > very tiny fraction of accidents that were not directly > attributable to something stupid that someone did. > Let's try to eliminate those sorts of things because > we'd have a *near* spotless safety record on our make and > model if you eliminated the things that were pure > ignorance and idiocy. > > Tim > > > > > > > On 4/9/2015 11:50 PM, Phillip Perry wrote: >> Some of you might have seen this already, but Doug Nebert's probable >> cause was published today. This was the accident in Oregon last May. >> (2 Fatal - 1 Serious) >> >> * The probable cause document >> <http://www.ntsb.gov/_layouts/ntsb.aviation/GeneratePDF.aspx?id=WPR14FA218&rpt=fi> >> is a humbling read... >> * Every document in the entire docket >> <http://dms.ntsb.gov/pubdms/search/hitlist.cfm?docketID=57129&CFID=524058&CFTOKEN=34830451> >> is worth the read... >> * Specifically the photos in this document >> <http://dms.ntsb.gov/public%2F57000-57499%2F57129%2F570028.pdf> are >> full of emotion. Anger, Sadness, Disbelief, Confusion. >> >> In case the links do not work, the case ID is WPR14FA218 so you can look >> it up yourself. >> >> I will give you the nutshell, but you need to go read the documents. >> RTV was used to seal NPT fittings on a (recently installed) fuel flow >> transducer. A ~0.25" chuckof RTV came loose and flowed downstream into >> the metered nozzle of the transducer. The metered hole was ~0.115" in >> diameter and the RTV plugged the hole and starved the engine of fuel. >> To make matters worse, a stall (and likely the start of a spin) occurred >> during the forced landing. >> >> This is worth a read. There were other indications of an aircraft with >> questionable maintenance, but the event that brought down this airplane >> was 100% preventable. The real disappointing part is that the issue was >> pointed out by a friend but ignored. >> >> Even if we don't have RTV on our fuel lines (I hope we don't - Same >> thing for Teflon Tape), there is a lesson in here for all of us. It >> doesn't do us any good to share information and concerns with each other >> if we aren't going to take a moment to stop in our tracks and seriously >> listen to them. Ears open, mouth closed, stop, and think. I'm as >> guilty as the next person, but this is a case where we can all reset >> ourselves and improve our fleets record. >> >> Phil > > > > > ________________________________________________________________________________
Date: Apr 10, 2015
Subject: Re: Shoulder Harnesses
Phil, I think it's worth considering that if the harness bolt is pulled in the intended direction, it seems to me that it would be loaded in shear, not tension. So if the crash is survivable, the bolt pulling through the cabin cover isn't what we would see. I'm not an engineer, but I did copy the front mounts for my rear inertia mounts...and I wondered the same thing until it occurred to me that the bolt gets tugged in a line approaching the direction of flight. I don't think it would get pulled through. --Dave On Fri, Apr 10, 2015 at 3:29 PM, Phillip Perry wrote: > Last night I was thinking about the images in Doug's photos and was really > curious to know how effective the shoulder harness anchor bolt is in that > situation. > > My curiosity stems from seeing a friends Culver Cadet (no shoulder > harnesses in that old plane) that he landed off field 7 years ago. It's > still sitting in his garage and has a pair of human head shaped > indentations in the glare shield. If he had effective shoulder harnesses, > it would have saved them some blood and a deviated septum. > > We've had a handful of RV-10 accidents that have tested the integrity of > the shoulder harness anchor bolt possibly being pulled through the > fiberglass hole. I just wonder how it really performed in each of these > accidents. > > 1) Have any of you seen, first hand, an RV-10 airframe after it has been > in an accident where the shoulder harnesses were stressed significantly? > > 2) Would any of you know where we could get that information? Perhaps a > FOIA or something similar? > > I'd really like to get the real details on how that shoulder harness > performed. We've probably got 5-6 accidents where that information > could/would be collected. > > Phil > > * > > > * > > ________________________________________________________________________________
Date: Apr 11, 2015
Well, I'd say the front harness mounts see a substantial amount of tension as well as shear. Looking at the photos and the text, it appears a large section of the left roof failed. I wonder if the forces exerted by the shoulder harness contributed to this? Or did the roof fail only after experiencing an unsurvivable loading, say more than ten times the pilot's weight, from the harness? Or was the failure due to crash forces applied directly, independent of the harness? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440623#440623 ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Apr 11, 2015
Phil, Good questions. Lacking data however I evaluated the canopy top fiberglass t hickness for the pilot and copilot shoulder harness anchor points less than a dequate considering the significant countersink depth needed to have the anc hor screw flush with the cabin top. Again, no data to say my evaluation was correct or not. I added several bids of glass on the inside of the canopy top for each ancho r point. The first layer being 1/16" thick covering an area of 10" by 10" o r so, then another 6" by 6", 1/16" or so layer on top of that. The objecti ve being to allow for fairing with the rest of the bottom of the cabin top. This resulted in sufficient thickness for countersinking the head of the an chor screw such that it was slightly below the surface of the canopy top. I flatten the screw edges and installed the anchor screw in some flox as I wa nted to make sure it would not turn when tightening the nut onto the inside. Sanded the flox flush, a layer of glass on top of that, then a skim coat o f micro balloons to fair it in. Carl > On Apr 10, 2015, at 6:29 PM, Phillip Perry wrote: > > Last night I was thinking about the images in Doug's photos and was really curious to know how effective the shoulder harness anchor bolt is in that s ituation. > > My curiosity stems from seeing a friends Culver Cadet (no shoulder harness es in that old plane) that he landed off "field 7 years ago. It's still si tting in his garage and has a pair of human head shaped indentations in the g lare shield. If he had effective shoulder harnesses, it would have saved th em some blood and a deviated septum. > > We've had a handful of RV-10 accidents that have tested the integrity of t he shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. > > 1) Have any of you seen, first hand, an RV-10 airframe after it has been i n an accident where the shoulder harnesses were stressed significantly? > > 2) Would any of you know where we could get that information? Perhaps a FO IA or something similar? > > I'd really like to get the real details on how that shoulder harness perfo rmed. We've probably got 5-6 accidents where that information could/would b e collected. > > Phil > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > ________________________________________________________________________________
Date: Apr 11, 2015
I did the same thing on mine. I'm just curious how they've actually performed in the accidents that have b een logged. Perhaps an I need to make a call into the NTSB and see if there is more info rmation beyond what is available in the docket. Sent from my iPhone > On Apr 11, 2015, at 7:40 AM, Carl Froehlich w rote: > > Phil, > > Good questions. Lacking data however I evaluated the canopy top fiberglas s thickness for the pilot and copilot shoulder harness anchor points less th an adequate considering the significant countersink depth needed to have the anchor screw flush with the cabin top. Again, no data to say my evaluation was correct or not. > > I added several bids of glass on the inside of the canopy top for each anc hor point. The first layer being 1/16" thick covering an area of 10" by 10" or so, then another 6" by 6", 1/16" or so layer on top of that. The objec tive being to allow for fairing with the rest of the bottom of the cabin top . This resulted in sufficient thickness for countersinking the head of the a nchor screw such that it was slightly below the surface of the canopy top. I flatten the screw edges and installed the anchor screw in some flox as I wa nted to make sure it would not turn when tightening the nut onto the inside. Sanded the flox flush, a layer of glass on top of that, then a skim coat o f micro balloons to fair it in. > > Carl > > > >> On Apr 10, 2015, at 6:29 PM, Phillip Perry wrote: >> >> Last night I was thinking about the images in Doug's photos and was reall y curious to know how effective the shoulder harness anchor bolt is in that s ituation. >> >> My curiosity stems from seeing a friends Culver Cadet (no shoulder harnes ses in that old plane) that he landed off "field 7 years ago. It's still s itting in his garage and has a pair of human head shaped indentations in the glare shield. If he had effective shoulder harnesses, it would have saved t hem some blood and a deviated septum. >> >> We've had a handful of RV-10 accidents that have tested the integrity of t he shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. >> >> 1) Have any of you seen, first hand, an RV-10 airframe after it has been i n an accident where the shoulder harnesses were stressed significantly? >> >> 2) Would any of you know where we could get that information? Perhaps a FOIA or something similar? >> >> I'd really like to get the real details on how that shoulder harness perf ormed. We've probably got 5-6 accidents where that information could/would b e collected. >> >> Phil >> >> >> >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> List"">http://www.matronics.com/Navigator?RV10-List >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> //forums.matronics.com >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> ot;">http://www.matronics.com/contribution >> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 11, 2015
What about that crash near Lake Placid Airport in NY that went into the trees in the cold. All occupants walked away OK with minor injories. There was also the one in SoCal, Ramona RMN that put it on a hillside into terrain and walked away. Seems the belts and airframe performed as designed on those instances. I think the key is survivable impact. I=99d hazard a pretty safe guess that Van=99s engineered the structure appropriately. Who knows if they used the official 170lb FAA weight or the bubba weight though? -Ben From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Saturday, April 11, 2015 6:15 AM Subject: Re: RV10-List: Shoulder Harnesses I did the same thing on mine. I'm just curious how they've actually performed in the accidents that have been logged. Perhaps an I need to make a call into the NTSB and see if there is more information beyond what is available in the docket. Sent from my iPhone On Apr 11, 2015, at 7:40 AM, Carl Froehlich wrote: Phil, Good questions. Lacking data however I evaluated the canopy top fiberglass thickness for the pilot and copilot shoulder harness anchor points less than adequate considering the significant countersink depth needed to have the anchor screw flush with the cabin top. Again, no data to say my evaluation was correct or not. I added several bids of glass on the inside of the canopy top for each anchor point. The first layer being 1/16" thick covering an area of 10" by 10" or so, then another 6" by 6", 1/16" or so layer on top of that. The objective being to allow for fairing with the rest of the bottom of the cabin top. This resulted in sufficient thickness for countersinking the head of the anchor screw such that it was slightly below the surface of the canopy top. I flatten the screw edges and installed the anchor screw in some flox as I wanted to make sure it would not turn when tightening the nut onto the inside. Sanded the flox flush, a layer of glass on top of that, then a skim coat of micro balloons to fair it in. Carl On Apr 10, 2015, at 6:29 PM, Phillip Perry wrote: Last night I was thinking about the images in Doug's photos and was really curious to know how effective the shoulder harness anchor bolt is in that situation. My curiosity stems from seeing a friends Culver Cadet (no shoulder harnesses in that old plane) that he landed off "field 7 years ago. It's still sitting in his garage and has a pair of human head shaped indentations in the glare shield. If he had effective shoulder harnesses, it would have saved them some blood and a deviated septum. We've had a handful of RV-10 accidents that have tested the integrity of the shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. 1) Have any of you seen, first hand, an RV-10 airframe after it has been in an accident where the shoulder harnesses were stressed significantly? 2) Would any of you know where we could get that information? Perhaps a FOIA or something similar? I'd really like to get the real details on how that shoulder harness performed. We've probably got 5-6 accidents where that information could/would be collected. Phil ________________________________________________________________________________
Subject: probable cause
Date: Apr 11, 2015
I must be doing something wrong; every contingency I plan for never happens. I am always a little anxious when flying other non pilots; the night before I go over in my mind about what could happen and my actions to be. Have I checked this or that lately? Fortunately, to date, every contingency for which I plan never happens. Sad to hear that the problem was pilot/builder actions related but as you say, the person who knows and knows he knows does not often listen even to low key suggestions or observations. David McNeill N46007 TT900+ CFII, A&P, TT5000+ --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: Apr 11, 2015
I have thought about countersunk washers to strengthen things, but that means taking away more fiberglass....not good. On 4/11/2015 6:15 AM, Phillip Perry wrote: > I did the same thing on mine. > > I'm just curious how they've actually performed in the accidents that > have been logged. > > Perhaps an I need to make a call into the NTSB and see if there is > more information beyond what is available in the docket. > > Sent from my iPhone > > On Apr 11, 2015, at 7:40 AM, Carl Froehlich > > wrote: > >> Phil, >> >> Good questions. Lacking data however I evaluated the canopy top >> fiberglass thickness for the pilot and copilot shoulder harness >> anchor points less than adequate considering the significant >> countersink depth needed to have the anchor screw flush with the >> cabin top. Again, no data to say my evaluation was correct or not. >> >> I added several bids of glass on the inside of the canopy top for >> each anchor point. The first layer being 1/16" thick covering an >> area of 10" by 10" or so, then another 6" by 6", 1/16" or so layer >> on top of that. The objective being to allow for fairing with the >> rest of the bottom of the cabin top. This resulted in sufficient >> thickness for countersinking the head of the anchor screw such that >> it was slightly below the surface of the canopy top. I flatten the >> screw edges and installed the anchor screw in some flox as I wanted >> to make sure it would not turn when tightening the nut onto the >> inside. Sanded the flox flush, a layer of glass on top of that, then >> a skim coat of micro balloons to fair it in. >> >> Carl >> >> >> >> On Apr 10, 2015, at 6:29 PM, Phillip Perry > > wrote: >> >>> Last night I was thinking about the images in Doug's photos and was >>> really curious to know how effective the shoulder harness anchor >>> bolt is in that situation. >>> >>> My curiosity stems from seeing a friends Culver Cadet (no shoulder >>> harnesses in that old plane) that he landed off "field 7 years ago. >>> It's still sitting in his garage and has a pair of human head >>> shaped indentations in the glare shield. If he had effective >>> shoulder harnesses, it would have saved them some blood and a >>> deviated septum. >>> >>> We've had a handful of RV-10 accidents that have tested the >>> integrity of the shoulder harness anchor bolt possibly being pulled >>> through the fiberglass hole. I just wonder how it really performed >>> in each of these accidents. >>> >>> 1) Have any of you seen, first hand, an RV-10 airframe after it has >>> been in an accident where the shoulder harnesses were stressed >>> significantly? >>> >>> 2) Would any of you know where we could get that information? >>> Perhaps a FOIA or something similar? >>> >>> I'd really like to get the real details on how that shoulder harness >>> performed. We've probably got 5-6 accidents where that information >>> could/would be collected. >>> >>> Phil >>> >>> * >>> >>> D============================================ >>> List"">http://www.matronics.com/Navigator?RV10-List >>> D============================================ >>> //forums.matronics.com <http://forums.matronics.com> >>> D============================================ >>> ot;">http://www.matronics.com/contribution >>> D============================================ >>> >>> * >>> >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?RV10-List >> D============================================ >> //forums.matronics.com >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > * > > > * ________________________________________________________________________________
Date: Apr 11, 2015
I am not sure what problem needs solving here. Don't we think Van designed things correctly? There doesn't seem to be any evidence of a design problem. SWAG engineering just doesn't cut it here. Adding extra layers to the inside of a composite structure only adds weight and not strength. Gary > On Apr 11, 2015, at 4:57 PM, Kelly McMullen wrote: > > > I have thought about countersunk washers to strengthen things, but that means taking away more fiberglass....not good. > >> On 4/11/2015 6:15 AM, Phillip Perry wrote: >> I did the same thing on mine. >> >> I'm just curious how they've actually performed in the accidents that have been logged. >> >> Perhaps an I need to make a call into the NTSB and see if there is more information beyond what is available in the docket. >> >> Sent from my iPhone >> >>> On Apr 11, 2015, at 7:40 AM, Carl Froehlich > wrote: >>> >>> Phil, >>> >>> Good questions. Lacking data however I evaluated the canopy top fiberglass thickness for the pilot and copilot shoulder harness anchor points less than adequate considering the significant countersink depth needed to have the anchor screw flush with the cabin top. Again, no data to say my evaluation was correct or not. >>> >>> I added several bids of glass on the inside of the canopy top for each anchor point. The first layer being 1/16" thick covering an area of 10" by 10" or so, then another 6" by 6", 1/16" or so layer on top of that. The objective being to allow for fairing with the rest of the bottom of the cabin top. This resulted in sufficient thickness for countersinking the head of the anchor screw such that it was slightly below the surface of the canopy top. I flatten the screw edges and installed the anchor screw in some flox as I wanted to make sure it would not turn when tightening the nut onto the inside. Sanded the flox flush, a layer of glass on top of that, then a skim coat of micro balloons to fair it in. >>> >>> Carl >>> >>> >>> >>>> On Apr 10, 2015, at 6:29 PM, Phillip Perry > wrote: >>>> >>>> Last night I was thinking about the images in Doug's photos and was really curious to know how effective the shoulder harness anchor bolt is in that situation. >>>> >>>> My curiosity stems from seeing a friends Culver Cadet (no shoulder harnesses in that old plane) that he landed off "field 7 years ago. It's still sitting in his garage and has a pair of human head shaped indentations in the glare shield. If he had effective shoulder harnesses, it would have saved them some blood and a deviated septum. >>>> >>>> We've had a handful of RV-10 accidents that have tested the integrity of the shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. >>>> >>>> 1) Have any of you seen, first hand, an RV-10 airframe after it has been in an accident where the shoulder harnesses were stressed significantly? >>>> >>>> 2) Would any of you know where we could get that information? Perhaps a FOIA or something similar? >>>> >>>> I'd really like to get the real details on how that shoulder harness performed. We've probably got 5-6 accidents where that information could/would be collected. >>>> >>>> Phil >>>> >>>> * >>>> >>>> D============================================ >>>> List"">http://www.matronics.com/Navigator?RV10-List >>>> D============================================ >>>> //forums.matronics.com <http://forums.matronics.com> >>>> D============================================ >>>> ot;">http://www.matronics.com/contribution >>>> D============================================ >>>> >>>> * >>>> >>> * >>> >>> D============================================ >>> List"">http://www.matronics.com/Navigator?RV10-List >>> D============================================ >>> //forums.matronics.com >>> D============================================ >>> ot;">http://www.matronics.com/contribution >>> D============================================ >>> >>> * >> * >> >> >> * > > > > > ________________________________________________________________________________
Date: Apr 11, 2015
The question isn't why are they insufficient. They question is where do we go to find out how they have performed in the incidents to date. We have a decent set of incident data for off field landings. We have good half dozen incidents resulting in fatalities. None of the shoulder harness data is published but it has to be collected. It exist. Being able to review that data relative to the accident type/severity would let us know if we do have a problem or not. Dead men can't speak but the data would and we would all benefit by the factual data. Phil Sent from my iPhone > On Apr 11, 2015, at 4:11 PM, Gary wrote: > > > I am not sure what problem needs solving here. Don't we think Van designed things correctly? There doesn't seem to be any evidence of a design problem. SWAG engineering just doesn't cut it here. Adding extra layers to the inside of a composite structure only adds weight and not strength. > > Gary > > > >> On Apr 11, 2015, at 4:57 PM, Kelly McMullen wrote: >> >> >> I have thought about countersunk washers to strengthen things, but that means taking away more fiberglass....not good. >> >>> On 4/11/2015 6:15 AM, Phillip Perry wrote: >>> I did the same thing on mine. >>> >>> I'm just curious how they've actually performed in the accidents that have been logged. >>> >>> Perhaps an I need to make a call into the NTSB and see if there is more information beyond what is available in the docket. >>> >>> Sent from my iPhone >>> >>>> On Apr 11, 2015, at 7:40 AM, Carl Froehlich > wrote: >>>> >>>> Phil, >>>> >>>> Good questions. Lacking data however I evaluated the canopy top fiberglass thickness for the pilot and copilot shoulder harness anchor points less than adequate considering the significant countersink depth needed to have the anchor screw flush with the cabin top. Again, no data to say my evaluation was correct or not. >>>> >>>> I added several bids of glass on the inside of the canopy top for each anchor point. The first layer being 1/16" thick covering an area of 10" by 10" or so, then another 6" by 6", 1/16" or so layer on top of that. The objective being to allow for fairing with the rest of the bottom of the cabin top. This resulted in sufficient thickness for countersinking the head of the anchor screw such that it was slightly below the surface of the canopy top. I flatten the screw edges and installed the anchor screw in some flox as I wanted to make sure it would not turn when tightening the nut onto the inside. Sanded the flox flush, a layer of glass on top of that, then a skim coat of micro balloons to fair it in. >>>> >>>> Carl >>>> >>>> >>>> >>>>> On Apr 10, 2015, at 6:29 PM, Phillip Perry > wrote: >>>>> >>>>> Last night I was thinking about the images in Doug's photos and was really curious to know how effective the shoulder harness anchor bolt is in that situation. >>>>> >>>>> My curiosity stems from seeing a friends Culver Cadet (no shoulder harnesses in that old plane) that he landed off "field 7 years ago. It's still sitting in his garage and has a pair of human head shaped indentations in the glare shield. If he had effective shoulder harnesses, it would have saved them some blood and a deviated septum. >>>>> >>>>> We've had a handful of RV-10 accidents that have tested the integrity of the shoulder harness anchor bolt possibly being pulled through the fiberglass hole. I just wonder how it really performed in each of these accidents. >>>>> >>>>> 1) Have any of you seen, first hand, an RV-10 airframe after it has been in an accident where the shoulder harnesses were stressed significantly? >>>>> >>>>> 2) Would any of you know where we could get that information? Perhaps a FOIA or something similar? >>>>> >>>>> I'd really like to get the real details on how that shoulder harness performed. We've probably got 5-6 accidents where that information could/would be collected. >>>>> >>>>> Phil >>>>> >>>>> * >>>>> >>>>> D============================================ >>>>> List"">http://www.matronics.com/Navigator?RV10-List >>>>> D============================================ >>>>> //forums.matronics.com <http://forums.matronics.com> >>>>> D============================================ >>>>> ot;">http://www.matronics.com/contribution >>>>> D============================================ >>>>> >>>>> * >>>>> >>>> * >>>> >>>> D============================================ >>>> List"">http://www.matronics.com/Navigator?RV10-List >>>> D============================================ >>>> //forums.matronics.com >>>> D============================================ >>>> ot;">http://www.matronics.com/contribution >>>> D============================================ >>>> >>>> * >>> * >>> >>> >>> * > > > > > ________________________________________________________________________________
Date: Apr 11, 2015
I do not think the question has been answered whether they are adequate, i.e. what force are they designed for in shear and in tension. I've not seen any evidence that they are inadequate. I believe there is a significant difference between the green and pink canopys, espec reinforcement behind the doors. The pink looks like it just about has a roll bar installed there, just in front of the shoulder harness bolt holes. On Sat, Apr 11, 2015 at 3:42 PM, Phillip Perry wrote: > > The question isn't why are they insufficient. They question is where do > we go to find out how they have performed in the incidents to date. > > We have a decent set of incident data for off field landings. We have > good half dozen incidents resulting in fatalities. > > None of the shoulder harness data is published but it has to be > collected. It exist. Being able to review that data relative to the > accident type/severity would let us know if we do have a problem or not. > Dead men can't speak but the data would and we would all benefit by the > factual data. > > Phil > > Sent from my iPhone > > > On Apr 11, 2015, at 4:11 PM, Gary wrote: > > > > > > I am not sure what problem needs solving here. Don't we think Van > designed things correctly? There doesn't seem to be any evidence of a > design problem. SWAG engineering just doesn't cut it here. Adding extra > layers to the inside of a composite structure only adds weight and not > strength. > > > > Gary > > > > > > > >> On Apr 11, 2015, at 4:57 PM, Kelly McMullen > wrote: > >> > >> > >> I have thought about countersunk washers to strengthen things, but that > means taking away more fiberglass....not good. > >> > >>> On 4/11/2015 6:15 AM, Phillip Perry wrote: > >>> I did the same thing on mine. > >>> > >>> I'm just curious how they've actually performed in the accidents that > have been logged. > >>> > >>> Perhaps an I need to make a call into the NTSB and see if there is > more information beyond what is available in the docket. > >>> > >>> Sent from my iPhone > >>> > >>>> On Apr 11, 2015, at 7:40 AM, Carl Froehlich < > carl.froehlich(at)verizon.net > wrote: > >>>> > >>>> Phil, > >>>> > >>>> Good questions. Lacking data however I evaluated the canopy top > fiberglass thickness for the pilot and copilot shoulder harness anchor > points less than adequate considering the significant countersink depth > needed to have the anchor screw flush with the cabin top. Again, no data > to say my evaluation was correct or not. > >>>> > >>>> I added several bids of glass on the inside of the canopy top for > each anchor point. The first layer being 1/16" thick covering an area of > 10" by 10" or so, then another 6" by 6", 1/16" or so layer on top of > that. The objective being to allow for fairing with the rest of the bottom > of the cabin top. This resulted in sufficient thickness for countersinking > the head of the anchor screw such that it was slightly below the surface of > the canopy top. I flatten the screw edges and installed the anchor screw > in some flox as I wanted to make sure it would not turn when tightening the > nut onto the inside. Sanded the flox flush, a layer of glass on top of > that, then a skim coat of micro balloons to fair it in. > >>>> > >>>> Carl > >>>> > >>>> > >>>> > >>>>> On Apr 10, 2015, at 6:29 PM, Phillip Perry > wrote: > >>>>> > >>>>> Last night I was thinking about the images in Doug's photos and was > really curious to know how effective the shoulder harness anchor bolt is in > that situation. > >>>>> > >>>>> My curiosity stems from seeing a friends Culver Cadet (no shoulder > harnesses in that old plane) that he landed off "field 7 years ago. It's > still sitting in his garage and has a pair of human head shaped > indentations in the glare shield. If he had effective shoulder harnesses, > it would have saved them some blood and a deviated septum. > >>>>> > >>>>> We've had a handful of RV-10 accidents that have tested the > integrity of the shoulder harness anchor bolt possibly being pulled through > the fiberglass hole. I just wonder how it really performed in each of > these accidents. > >>>>> > >>>>> 1) Have any of you seen, first hand, an RV-10 airframe after it has > been in an accident where the shoulder harnesses were stressed > significantly? > >>>>> > >>>>> 2) Would any of you know where we could get that information? > Perhaps a FOIA or something similar? > >>>>> > >>>>> I'd really like to get the real details on how that shoulder harness > performed. We've probably got 5-6 accidents where that information > could/would be collected. > >>>>> > >>>>> Phil > >>>>> > >>>>> * > >>>>> > >>>>> > D============================================ > >>>>> List"">http://www.matronics.com/Navigator?RV10-List > >>>>> > D============================================ > >>>>> //forums.matronics.com <http://forums.matronics.com> > >>>>> > D============================================ > >>>>> ot;">http://www.matronics.com/contribution > >>>>> > D============================================ > >>>>> > >>>>> * > >>>>> > >>>> * > >>>> > >>>> > D============================================ > >>>> List"">http://www.matronics.com/Navigator?RV10-List > >>>> > D============================================ > >>>> //forums.matronics.com > >>>> > D============================================ > >>>> ot;">http://www.matronics.com/contribution > >>>> > D============================================ > >>>> > >>>> * > >>> * > >>> > >>> > >>> * > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 12, 2015
>From the Lake Placid NY crash... Preamble: It has been just over 2 years since this crash. On several occasions I have started to do a write-up on the incident. Each time I have tried I get tangled up in my own brutal self judgment. I am know as a very competent and conscientious pilot. 2,000 hours flying since 1986, instrument rated since 1989. At the time of the accident I was very IFR current, in a very capable aircraft, yet I allowed myself to follow a series of small events into a classic accident scenario. While I have flown over 100 hours since the crash, I still have a difficult time reconciling this in my mind. I remain confident in my pilot skills, but have an excessively conservative approach to the passion of flying. I will try to post a thorough synopsis of the accident in a separate post in the next few days. Please hold off on questions and comments about the crash until I post this as a separate thread. As for the airframe, the majority of the impact was absorbed by a side load impact. That impact contacted the fuselage on the pilot side at the junction of the leading edge wing root and the fuse at the instrument panel station. The entire panel and front of the fuse were displaced about 1 foot to the right. The lower portion of the fuselage separated from the fiberglass upper structure in that area. The remainder of the fiberglass top remained intact. The shoulder harness attach points showed no sign of stress or compromise. There was no impact bruising from the harness on any of the occupants. Due to the initial side impact, and subsequent wing leading edge impact with multiple pine trees as we descended the final 100 feet, there was minimal frontal impact when we came to rest nose down on the mountain. The RV-10 withstood a tremendous amount of impact damage, and the cabin remained a safe haven. I am almost done building a new RV-10 to replace N10FD. Best, Frank -------- Frank Dombroski RV-10 2.0 N46VT soon to be flying KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440703#440703 Attachments: http://forums.matronics.com//files/p1011568_398.jpg ________________________________________________________________________________
Subject: Re: probable cause
Date: Apr 12, 2015
Well said. Plan ahead. Consider what could happen and how you will react. I built my plane and am familiar and confident in checking the airframe, but I always have a mechanic check out my engine at annual and - guess what! He found a nut missing on my alternator this year that I did not see! Was that the best $200 spent, and the best second set of eyes ever! Also, never depart from proper maintenance procedures unless you have checked with a VERY reliable AP/IA. Humility is your friend.....overconfidence your enemy. If everything is not right - don't fly. -------- See you OSH '15 Q/B - flying 5 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440751#440751 ________________________________________________________________________________
Date: Apr 12, 2015
Wow - thank you for the posting. Gives us all a lot of confidence in our craft. I love the casual, "as we descended the final 100 feet." We all look forward to your more extensive post. God Bless you and we wish you many years of safe flying ahead. Perhaps you could give a lecture with Q&A at OSH this year! -------- See you OSH '15 Q/B - flying 5 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440752#440752 ________________________________________________________________________________
Date: Apr 13, 2015
I do the same. I have a local AP/IA do the firewall forward inspection....he will be doing the mags this year. As much as I want to learn and do it all myself, I feel much better that I have a person who has done 100's of mags doing mine instead of me doing my first one and then loading the family in the plane. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of AirMike Sent: Sunday, April 12, 2015 11:53 PM Subject: RV10-List: Re: probable cause Well said. Plan ahead. Consider what could happen and how you will react. I built my plane and am familiar and confident in checking the airframe, but I always have a mechanic check out my engine at annual and - guess what! He found a nut missing on my alternator this year that I did not see! Was that the best $200 spent, and the best second set of eyes ever! Also, never depart from proper maintenance procedures unless you have checked with a VERY reliable AP/IA. Humility is your friend.....overconfidence your enemy. If everything is not right - don't fly. -------- See you OSH '15 Q/B - flying 5 yrs. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=440751#440751 ________________________________________________________________________________
Date: Apr 15, 2015
Subject: Re: Hartzell prop lubrication
Agreed. Very specific instructions from Hartzell - I just follow them. Especially because they take the time to spell out not to treat it like any other grease situation (pump until something comes out somewhere else). Since I don't have a history greasing stuff, I don't seem to have a problem following the instructions. Bill On 3/31/2015 4:41 PM, Kelly McMullen wrote: > > Award for most accurate response. Believe it or not you can over > lubricate even with a zerk removed. If any of the old grease has > thickened/hardened, it will restrict grease coming out the zerk hole. > I generally limit to 4 strokes on hand grease gun or start of grease > coming out removed zerk hole. > Also, use precisely whatever grease the label on the prop calls for, > whether that is Aeroshell 6, 22 or some other flavor. Unlike oils, > greases do use different thickening agents, and they are not all > compatible. Do not worry about not having enough grease...there is > plenty in the hub, unless you see it slinging out the seals at the > blade roots. > Kelly > A&P/IA > > On 3/31/2015 10:28 AM, David Leikam wrote: >> Max number of pumps (I believe 6) OR excess coming out opposite zerk >> which ever happens first. >> >> Dave Leikam >> >>> On Mar 31, 2015, at 12:04 PM, John Cox >> > wrote: >>> >>> Max number of pumps and excess coming out the opposing threads of >>> adjacent removed zerk. Per Hartzell S.L. >>> >>> On Mar 31, 2015 10:01 AM, "Bob Leffler" >> > wrote: >>> >>> > >>> >>> I've just started my conditional and was reading the maintenance >>> procedures for the Hartzell prop. It cautions you not to over >>> lubricate. >>> >>> My naive question, is how can you tell when you have the proper >>> amount of lubricant? Is it when it starts oozing out the other >>> fitting? >>> >>> Thanks, >>> >>> Bob >>> >>> Sent from my iPhone >>> >>> ========== >>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> * >>> >>> >>> * >> >> * >> >> >> * > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > > ________________________________________________________________________________
Date: Apr 16, 2015
Subject: Re: Control stick bending
After action report. I had access to a 55 ton hydraulic press. It took some effort to create fixtures to securely hold the stick so it wouldn't go flying out of the press. The stick as delivered from Van's had approx 10 3/4" diameter between inside surfaces. Packed stick with sand. Went slowly with first one. Discovered needed 3/4" of compression before getting any permanent bend. Compressed it to slightly under 9" measurement, which after release of pressure gave a 9 3/4" dimension. That was just right, as I could see the tubing just beginning to slightly deform. Second stick came out within 1/8" dimension of first. Now have full up and down travel on elevator without stick grip hitting panel, although knuckles might get a little bruising if really need full nose down. Back to working on the 90% of remaining 5% or something like that. On Fri, Apr 10, 2015 at 12:06 AM, Patrick Pulis wrote: > > Guys as an ex-plumber, the sand idea gives the perfect support to prevent > kinking. Use dry send and pack well > > Warm regards > > Patrick > > > On 10 Apr 2015, at 03:50, Tomhanaway wrote: > > > > > > When I did my 10, I got a pipe bender from harbor freight. Packed the > tube with sand to prevent any kinks. > > Worked fine > > > > Tom h > > > > Sent from my iPad > > > ________________________________________________________________________________
Date: Apr 18, 2015
Kelly What panel are you using please? Warm regards Patrick > On 17 Apr 2015, at 11:46, Kelly McMullen wrote: > > After action report. > I had access to a 55 ton hydraulic press. It took some effort to create fi xtures to securely hold the stick so it wouldn't go flying out of the press. The stick as delivered from Van's had approx 10 3/4" diameter between insid e surfaces. Packed stick with sand. Went slowly with first one. Discovered n eeded 3/4" of compression before getting any permanent bend. Compressed it t o slightly under 9" measurement, which after release of pressure gave a 9 3/ 4" dimension. That was just right, as I could see the tubing just beginning t o slightly deform. Second stick came out within 1/8" dimension of first. No w have full up and down travel on elevator without stick grip hitting panel, although knuckles might get a little bruising if really need full nose down . Back to working on the 90% of remaining 5% or something like that. > >> On Fri, Apr 10, 2015 at 12:06 AM, Patrick Pulis wrote: > >> >> Guys as an ex-plumber, the sand idea gives the perfect support to prevent kinking. Use dry send and pack well >> >> Warm regards >> >> Patrick >> >> > On 10 Apr 2015, at 03:50, Tomhanaway wrote: >> > >> > >> > When I did my 10, I got a pipe bender from harbor freight. Packed the t ube with sand to prevent any kinks. >> > Worked fine >> > >> > Tom h >> > >> > Sent from my iPad >> > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 17, 2015
Aerosport symmetrical panel with Tosten stick grips. On 4/17/2015 2:34 PM, Patrick Pulis wrote: > Kelly > > What panel are you using please? > > Warm regards > > Patrick > > On 17 Apr 2015, at 11:46, Kelly McMullen > wrote: > >> After action report. >> I had access to a 55 ton hydraulic press. It took some effort to >> create fixtures to securely hold the stick so it wouldn't go flying >> out of the press. The stick as delivered from Van's had approx 10 >> 3/4" diameter between inside surfaces. Packed stick with sand. Went >> slowly with first one. Discovered needed 3/4" of compression before >> getting any permanent bend. Compressed it to slightly under 9" >> measurement, which after release of pressure gave a 9 3/4" dimension. >> That was just right, as I could see the tubing just beginning to >> slightly deform. Second stick came out within 1/8" dimension of >> first. Now have full up and down travel on elevator without stick >> grip hitting panel, although knuckles might get a little bruising if >> really need full nose down. Back to working on the 90% of remaining >> 5% or something like that. >> >> On Fri, Apr 10, 2015 at 12:06 AM, Patrick Pulis >> > wrote: >> >> > >> >> Guys as an ex-plumber, the sand idea gives the perfect support to >> prevent kinking. Use dry send and pack well >> >> Warm regards >> >> Patrick >> >> > On 10 Apr 2015, at 03:50, Tomhanaway > > wrote: >> > >> > >> > >> > When I did my 10, I got a pipe bender from harbor freight. >> Packed the tube with sand to prevent any kinks. >> > Worked fine >> > >> > Tom h >> > >> > Sent from my iPad >> > >> >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?RV10-List >> D============================================ >> //forums.matronics.com >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > * > > > * ________________________________________________________________________________
Subject: Re: Amps spike when transmitting on comm2
Date: Apr 19, 2015
Well I think I finally found the cause of this problem. The sl40 comes with 12" pig tail coax attached to the tray. It has a nut type connector that pinches the shield to the connector, and it was loose. I tighten the nut and it solved the problem. The actual amp draw indicated on the vpx-pro when transmitting ranged from 2.5 at the higher freqs, and 4.5 at the lower freqs, 123.x and below. The amp gauge on the EFIS only spiked when I transmitted on the lower freqs. If you are having this issue, check the coax at the back of the tray. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441012#441012 ________________________________________________________________________________
Date: Apr 19, 2015
Subject: Fuel Return Line Location?
We're planning on EFII, so we need a full-sized return line for both sides. Just now starting work on the fuel tank, and I'd like to get this sorted before we get too far. I've spent awhile searching, and have only managed to find lots of places not to put the port for the fuel return line. Apparently it can interfere with both the wing spar and the aileron return line. Does anyone have a clear diagram of where I can safely put it? A hint about which flange/fittings to buy would be greatly appreciated as well. Thanks in advance! Berck ________________________________________________________________________________
Subject: Re: Fuel Return Line Location?
Date: Apr 19, 2015
Berck, I am using an EFII system as well. Just a thought, but I put a normal L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return line that Splits to each tank. After the "T" I put a simple Parker petroleum 1/4 turn ball valve on each side just before the tank. Now, I can shut one or the other return valves off, turn on the fuel pump, and transfer fuel on the ground. It can also be done in the air (with caution of course) to trim fuel. Note: I'm building a Bushcaddy not an rv10. I can send pics if you would like. Justin > On Apr 19, 2015, at 18:10, Berck E. Nash wrote: > > > We're planning on EFII, so we need a full-sized return line for both > sides. Just now starting work on the fuel tank, and I'd like to get > this sorted before we get too far. I've spent awhile searching, and > have only managed to find lots of places not to put the port for the > fuel return line. Apparently it can interfere with both the wing spar > and the aileron return line. Does anyone have a clear diagram of where > I can safely put it? A hint about which flange/fittings to buy would be > greatly appreciated as well. Thanks in advance! > > Berck > > > > ________________________________________________________________________________
Date: Apr 19, 2015
Hi Justin, You are of course free to build whatever fuel system you like, but the one you described has some issues. I think you'd be better off with a L-R-OFF duplex fuel valve that routes return fuel to the same tank you're burning from. You're headed towards a scenario that makes it pretty easy to mismanage the fuel: You could return to a full tank and waste fuel overboard; You could unport an empty tank in "BOTH" and starve the engine; You could turn off both return valves and...I don't know what, but it seems bad. Please consider a simpler system. Caution never goes as far as we think it will. --Dave On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones wrote: > > Berck, > > I am using an EFII system as well. Just a thought, but I put a normal > L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return > line that Splits to each tank. After the "T" I put a simple Parker > petroleum 1/4 turn ball valve on each side just before the tank. Now, I can > shut one or the other return valves off, turn on the fuel pump, and > transfer fuel on the ground. It can also be done in the air (with caution > of course) to trim fuel. > > Note: I'm building a Bushcaddy not an rv10. > > I can send pics if you would like. > > Justin > > > > On Apr 19, 2015, at 18:10, Berck E. Nash wrote: > > > > > > We're planning on EFII, so we need a full-sized return line for both > > sides. Just now starting work on the fuel tank, and I'd like to get > > this sorted before we get too far. I've spent awhile searching, and > > have only managed to find lots of places not to put the port for the > > fuel return line. Apparently it can interfere with both the wing spar > > and the aileron return line. Does anyone have a clear diagram of where > > I can safely put it? A hint about which flange/fittings to buy would be > > greatly appreciated as well. Thanks in advance! > > > > Berck > > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2015
Since he's building a high wing I don't think unporting on both is an issue. But I agree with your other comments. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441029#441029 ________________________________________________________________________________
Date: Apr 19, 2015
I'm leaning toward a duplex valve, but I'm also considering two fuel valves, one for the source and one for the return. This isn't that different than jets I've flown, and I think I can handle the "complexity". It's cheaper and it gives the advantage of being able to transfer fuel, which might come in handy. Regardless, none of the answers so far tell me where to tap the return line:) ________________________________________________________________________________
Date: Apr 19, 2015
Dave, I understand your concern and welcome any ideas and thoughts that may be cause for issues. The issues you brought up have been considered and here is what I have come up with. Note that I have spoken with many others about this as well, but it doesn=99t mean that we aren=99 t missing something. The normal configuration (covered on the before take-off checklist) would be both return valves open and the fuel valve on both. The transfer of fuel during refueling operations (while the aircraft is on floats) is one reason for this setup, and the other is the ability to draw fuel from both tanks simultaneously. =9CYou could return to a full tank and waste fuel overboard=9D - This scenario could present itself, but would cause an over-pressure situation due to the vent size. The digital engine monitor senses fuel pressure and sounds an audio and visual alarm when it is either too high or too low. =9CYou could unport an empty tank into =9CBOTH=9D and starve the engine=9D - This scenario has also been tested. With one tank empty, one tank full, and the selector to =9CBOTH=9D, there was still full fuel pressure. This may be due to the high-wing design and the fuel system plumbing called for by Robert Paisley of EFII. =9CYou could turn off both return valves and I don=99 t know what, but it seems bad=9D - It would cause the fuel to back up at the valves, and the fuel pressure would increase to the maximum that the GL393 fuel pump would put out. This would be 105 PSI at 10 Gallons per hour. Not sustainable, but not harmful to the injectors or fuel lines for short periods of time. Again, the Engine Monitor will alarm when the fuel pressure begins to increase. The fuel system has been tested to the fuel pump stall pressure of 115 PSI and found to have no leaks. I fly C-130s and King Air 200s and they both have fuel systems that are far more complicated. Flying aircraft will always require thought. With the duplex fuel valve, the pilot must remember to switch the fuel valves when it is necessary. I like the idea of being able to operate in a normal scenario with the fuel valve on both, and have the fuel is return to both tanks. If the situation arises, I can put the fuel where it is needed and I have a good monitoring system that will alert me if I make a mistake in the positioning of fuel valves. The return valves do not have a position that will cause the engine to quit turning. Thoughts? Thanks for your input. Respectfully, Justin > On Apr 19, 2015, at 7:30 PM, David Saylor wrote: > > Hi Justin, > > You are of course free to build whatever fuel system you like, but the one you described has some issues. > > I think you'd be better off with a L-R-OFF duplex fuel valve that routes return fuel to the same tank you're burning from. You're headed towards a scenario that makes it pretty easy to mismanage the fuel: > > You could return to a full tank and waste fuel overboard; > > You could unport an empty tank in "BOTH" and starve the engine; > > You could turn off both return valves and...I don't know what, but it seems bad. > > Please consider a simpler system. Caution never goes as far as we think it will. > > --Dave > > > > On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones > wrote: > > > Berck, > > I am using an EFII system as well. Just a thought, but I put a normal L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return line that Splits to each tank. After the "T" I put a simple Parker petroleum 1/4 turn ball valve on each side just before the tank. Now, I can shut one or the other return valves off, turn on the fuel pump, and transfer fuel on the ground. It can also be done in the air (with caution of course) to trim fuel. > > Note: I'm building a Bushcaddy not an rv10. > > I can send pics if you would like. > > Justin > > > > On Apr 19, 2015, at 18:10, Berck E. Nash > wrote: > > > > > > > We're planning on EFII, so we need a full-sized return line for both > > sides. Just now starting work on the fuel tank, and I'd like to get > > this sorted before we get too far. I've spent awhile searching, and > > have only managed to find lots of places not to put the port for the > > fuel return line. Apparently it can interfere with both the wing spar > > and the aileron return line. Does anyone have a clear diagram of where > > I can safely put it? A hint about which flange/fittings to buy would be > > greatly appreciated as well. Thanks in advance! > > > > Berck > > > > > > > > > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > > > > <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
Date: Apr 20, 2015
Bereck I had a similar setup to what your plans. Until a few months had a different engine (Subie) which I replaced with a IO540. I still use the return line for my purge valvle. I used an Andair duplex valve that returns fuel to the originating tank. With full tanks, you will pump a lot of gas overboard if the tanks / return line is mismatched. Running dual lines to the tanks is not a problem. I used an AN832 bulkhead union, mounted similar to that shown in the tank plans, to make the connection. I also a flange riveted to the inside of the tank to keep the union from turning when the nut is applied to the outside. Again see the tank plans. Lots of proseal made sure nothing leaked. You probably want to mount the fitting high and to the aft of the tank so that you do not interfere with the sender. If possible, you should run a tube from the fitting through the first tank baffle so that the returned fuel is dumped into the second tank cell. This allows it to cool and mix with other fuel before being reused. All of this is best done before the tanks are sealed. If the aren't, you can do everything (except perhaps for the fuel line to the second cell) through the fuel sender hole, it is just a bit tricky. This is what I did - I wasn't able to get the fuel back to the second cell but only to outboard side of the first. All my fuel lines in the tunnel were braided steel. Under the seats I had to go back to aluminum because of how the lines were run. My fuel filters are mounted in the wing roots - one for each tank. I completely agree with Dave's recommendation -keep it simple! You don't want to put yourself in a position where a simple error can lead to heartache and a bent air frame. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=441042#441042 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Apr 20, 2015
Berck, I added a 1/4" purge line return to the left tank when building in case I ended up with an AFP injection system (photo attached). This is the same location I used the RV-8A which had AFP injection. Adding a return line is straight forward and if you get the fitting in about the same area as the vent line connection you should not have an issue. I'd keep it high (like my photo) so that it is away from the fuel pick up - should help with pulling cooler fuel into the engine as compared to the hotter return fuel. Just curious - how much did this EFII system cost? Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash Sent: Monday, April 20, 2015 12:44 AM Subject: Re: RV10-List: Fuel Return Line Location? I'm leaning toward a duplex valve, but I'm also considering two fuel valves, one for the source and one for the return. This isn't that different than jets I've flown, and I think I can handle the "complexity". It's cheaper and it gives the advantage of being able to transfer fuel, which might come in handy. Regardless, none of the answers so far tell me where to tap the return line:) ________________________________________________________________________________
Date: Apr 20, 2015
Just keep in mind that what may be appropriate and work fine in a high wing aircraft is not suitable for a low wing aircraft. IMHO there is little to no need to transfer fuel between wings on a single engine aircraft. Managing fuel burn can easily keep the wings balanced, given that each wing only holds about 2.5 hours of fuel. The RV-10 wing arrangement is no place for a selector with a "both" position. It is too easy for someone scanning the archives of this list to get the wrong idea by a discussion of what works on a totally different airframe. On 4/19/2015 9:50 PM, Justin Jones wrote: > Dave, > > I understand your concern and welcome any ideas and thoughts that may > be cause for issues. The issues you brought up have been considered > and here is what I have come up with. Note that I have spoken with > many others about this as well, but it doesnt mean that we arent > missing something. > > The normal configuration (covered on the before take-off checklist) > would be both return valves open and the fuel valve on both. The > transfer of fuel during refueling operations (while the aircraft is on > floats) is one reason for this setup, and the other is the ability to > draw fuel from both tanks simultaneously. > > You could return to a full tank and waste fuel overboard - This > scenario could present itself, but would cause an over-pressure > situation due to the vent size. The digital engine monitor senses > fuel pressure and sounds an audio and visual alarm when it is either > too high or too low. > > You could unport an empty tank into BOTH and starve the engine - > This scenario has also been tested. With one tank empty, one tank > full, and the selector to BOTH, there was still full fuel pressure. > This may be due to the high-wing design and the fuel system plumbing > called for by Robert Paisley of EFII. > > You could turn off both return valves and I dont know what, but it > seems bad - It would cause the fuel to back up at the valves, and the > fuel pressure would increase to the maximum that the GL393 fuel pump > would put out. This would be 105 PSI at 10 Gallons per hour. Not > sustainable, but not harmful to the injectors or fuel lines for short > periods of time. Again, the Engine Monitor will alarm when the fuel > pressure begins to increase. The fuel system has been tested to the > fuel pump stall pressure of 115 PSI and found to have no leaks. > > I fly C-130s and King Air 200s and they both have fuel systems that > are far more complicated. Flying aircraft will always require > thought. With the duplex fuel valve, the pilot must remember to switch > the fuel valves when it is necessary. I like the idea of being able > to operate in a normal scenario with the fuel valve on both, and have > the fuel is return to both tanks. If the situation arises, I can put > the fuel where it is needed and I have a good monitoring system that > will alert me if I make a mistake in the positioning of fuel valves. > The return valves do not have a position that will cause the engine to > quit turning. > > Thoughts? > > Thanks for your input. > > Respectfully, > > Justin > > >> On Apr 19, 2015, at 7:30 PM, David Saylor > > wrote: >> >> Hi Justin, >> >> You are of course free to build whatever fuel system you like, but >> the one you described has some issues. >> >> I think you'd be better off with a L-R-OFF duplex fuel valve that >> routes return fuel to the same tank you're burning from. You're >> headed towards a scenario that makes it pretty easy to mismanage the >> fuel: >> >> You could return to a full tank and waste fuel overboard; >> >> You could unport an empty tank in "BOTH" and starve the engine; >> >> You could turn off both return valves and...I don't know what, but it >> seems bad. >> >> Please consider a simpler system. Caution never goes as far as we >> think it will. >> >> --Dave >> >> >> >> On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones >> > wrote: >> >> > >> >> Berck, >> >> I am using an EFII system as well. Just a thought, but I put a >> normal L/R/Both/Off fuel valve on the supply side (AN6) and an >> AN6 size return line that Splits to each tank. After the "T" I >> put a simple Parker petroleum 1/4 turn ball valve on each side >> just before the tank. Now, I can shut one or the other return >> valves off, turn on the fuel pump, and transfer fuel on the >> ground. It can also be done in the air (with caution of course) >> to trim fuel. >> >> Note: I'm building a Bushcaddy not an rv10. >> >> I can send pics if you would like. >> >> Justin >> >> >> > On Apr 19, 2015, at 18:10, Berck E. Nash > > wrote: >> > >> > >> > >> > We're planning on EFII, so we need a full-sized return line for >> both >> > sides. Just now starting work on the fuel tank, and I'd like >> to get >> > this sorted before we get too far. I've spent awhile >> searching, and >> > have only managed to find lots of places not to put the port >> for the >> > fuel return line. Apparently it can interfere with both the >> wing spar >> > and the aileron return line. Does anyone have a clear diagram >> of where >> > I can safely put it? A hint about which flange/fittings to buy >> would be >> > greatly appreciated as well. Thanks in advance! >> > >> > Berck >> > >> > >> > >> > >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> >> * >> >> class="">http://www.matronics.com/Navigator?RV10-List >> class="">http://forums.matronics.com >> class="">http://www.matronics.com/contribution >> >> * > > * > > > * ________________________________________________________________________________
Date: Apr 20, 2015
I think I'm flying Phase 1 in the first RV-10 with the full EFII system. I'm not sure how much fuel gets returned to the tank, but it is significant. We have a double stack Andair selector so it returns to the same tank that it is pulling from. I wouldn't have it any other way. It is so easy to do it this way that returning to one tank all the time, or having to process which tank you are pulling from and returning to would, IMHO, way over complicate things. As for the fuel return location, we put it forward in the bay and up fairly high. It's just a bulkhead fitting with a nut and ProSeal to seal it. If the tanks were open, we might have put in an NPT female bung instead, but this works just fine. There has been no problem at all with fuel vapor lock. I don't think it is necessary to return the fuel to the second bay. My fear if doing that would be the possibility of getting low on fuel and starting to suck air because you are dumping the fuel too far outboard. I don't know the exact effect, but it would expect that would effectively reduce your useable fuel level even more than it does by returning it to the first bay. Btw, the EFII system does add a lot of necessary complexity, dual bus, dual alternators, dual electric fuel pumps, dual ECU's, etc. It took a while to get up the nerve to be the test pilot on it. New airframe, new engine, new style ignition and injection system, etc. I will say, however, that it has been absolutely rock solid stable for all 10 hours so far. I need to put 15-20 more hours on it the week after Sun-N-Fun, but that shouldn't be a problem. In my mind, the jury is still out on the system, but they are starting to trickle in with a not-a-bad-system verdict. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 20, 2015, at 9:49 AM, Carl Froehlich wrote: > > Berck, > > I added a 1/4" purge line return to the left tank when building in case I > ended up with an AFP injection system (photo attached). This is the same > location I used the RV-8A which had AFP injection. > > Adding a return line is straight forward and if you get the fitting in about > the same area as the vent line connection you should not have an issue. I'd > keep it high (like my photo) so that it is away from the fuel pick up - > should help with pulling cooler fuel into the engine as compared to the > hotter return fuel. > > Just curious - how much did this EFII system cost? > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash > Sent: Monday, April 20, 2015 12:44 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel Return Line Location? > > > I'm leaning toward a duplex valve, but I'm also considering two fuel valves, > one for the source and one for the return. This isn't that different than > jets I've flown, and I think I can handle the "complexity". It's cheaper > and it gives the advantage of being able to transfer fuel, which might come > in handy. Regardless, none of the answers so far tell me where to tap the > return line:) > > > > ________________________________________________________________________________
Date: Apr 20, 2015
Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until we source an engine. Hoping available systems will only get cheaper, but cursory research indicates it'll cost not much more than more conventional FI and ignition setups. Jesse- Thanks for the heads up. Glad to hear that one is flying already, and I hope you'll keep us updated of any gotchas. After seeing that an EFII system is available, I can't imagine not using it. I'm aware of the need for a fully redundant electrical system and dual ECU's. I was already planning on dual electronic ignition and the dual alternators that necessitates, so electronic fuel injection only makes sense to me. This is, I think, the beauty of building an experimental-- the ability to use "modern" (30-year-old tried-and-tested) technology in an airplane, instead of being forced to rely on a fuel delivery system from the 1950's. Any RV-10 specific EFII links, information, vendor tips, etc, would be greatly appreciated. As for the "complexity" of a fuel return tank selection, it seems a bit silly to me that choosing a return tank is considered "overly complex." It's the difference of switching two valves instead of one when you switch tanks in normal operations. Sure, it's more complex than a single knob, but I'm used to much more complicated fuel systems many of which require deliberate knowledge of the fuel return tank. I'm not really concerned about it either way. The only reason to want to transfer fuel would be a leak, and in most situations, getting on the ground quickly makes a lot more sense than moving fuel around. Since I won't have to worry about the insane complexity of a mixture control, I can use those saved neurons to handle the fuel return tank if I wind up with two valves. On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich wrote: > Berck, > > I added a 1/4" purge line return to the left tank when building in case I > ended up with an AFP injection system (photo attached). This is the same > location I used the RV-8A which had AFP injection. > > Adding a return line is straight forward and if you get the fitting in > about > the same area as the vent line connection you should not have an issue. > I'd > keep it high (like my photo) so that it is away from the fuel pick up - > should help with pulling cooler fuel into the engine as compared to the > hotter return fuel. > > Just curious - how much did this EFII system cost? > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash > Sent: Monday, April 20, 2015 12:44 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel Return Line Location? > > > I'm leaning toward a duplex valve, but I'm also considering two fuel > valves, > one for the source and one for the return. This isn't that different than > jets I've flown, and I think I can handle the "complexity". It's cheaper > and it gives the advantage of being able to transfer fuel, which might come > in handy. Regardless, none of the answers so far tell me where to tap the > return line:) > > ________________________________________________________________________________
Date: Apr 20, 2015
I think you're kidding yourself if you think there is no mixture to worry ab out. I spend more time on the mixture knob so far than I do on the mixture c ontrol with a standard system. It's possible that once you get things all tu ned up the way you want them you may not use it as much, but I really don't u se it that much on a standard system either. I lean a little as I climb, the n I set power, rpm and fuel flow for cruise. I would imagine if you are burnin 12gph, you are probably returning at least that much to the tank, if not more. I wouldn't want to have to mess with pi cking a return tank separate from a feed tank. There are warnings when your f uel in a tank gets low, but I don't know of a warning saying your tank is ge tting too full. If you get busy or get bored and aren't managing fuel with a normal system, you will get something yelling at you saying you're getting i nto the red on the draw tank, but it won't happen if you start to pump it ov erboard through the return tank vent. I agree that electric ignition is tried and true in cars, but so far there a re a total of 10 fleet hours in the RV-10 with a full EFII system and thousa nds and thousands with mags and standard fuel injection. Far from a no-brain ier in my book unless you are talking the other way around. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: > > Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until w e source an engine. Hoping available systems will only get cheaper, but cur sory research indicates it'll cost not much more than more conventional FI a nd ignition setups. > > Jesse- Thanks for the heads up. Glad to hear that one is flying already, a nd I hope you'll keep us updated of any gotchas. After seeing that an EFII s ystem is available, I can't imagine not using it. I'm aware of the need for a fully redundant electrical system and dual ECU's. I was already planning o n dual electronic ignition and the dual alternators that necessitates, so el ectronic fuel injection only makes sense to me. This is, I think, the beaut y of building an experimental-- the ability to use "modern" (30-year-old tri ed-and-tested) technology in an airplane, instead of being forced to rely on a fuel delivery system from the 1950's. > > Any RV-10 specific EFII links, information, vendor tips, etc, would be gre atly appreciated. > > As for the "complexity" of a fuel return tank selection, it seems a bit si lly to me that choosing a return tank is considered "overly complex." It's t he difference of switching two valves instead of one when you switch tanks i n normal operations. Sure, it's more complex than a single knob, but I'm us ed to much more complicated fuel systems many of which require deliberate kn owledge of the fuel return tank. I'm not really concerned about it either w ay. The only reason to want to transfer fuel would be a leak, and in most s ituations, getting on the ground quickly makes a lot more sense than moving f uel around. Since I won't have to worry about the insane complexity of a mi xture control, I can use those saved neurons to handle the fuel return tank i f I wind up with two valves. > >> On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich wrote: >> Berck, >> >> I added a 1/4" purge line return to the left tank when building in case I >> ended up with an AFP injection system (photo attached). This is the same >> location I used the RV-8A which had AFP injection. >> >> Adding a return line is straight forward and if you get the fitting in ab out >> the same area as the vent line connection you should not have an issue. I 'd >> keep it high (like my photo) so that it is away from the fuel pick up - >> should help with pulling cooler fuel into the engine as compared to the >> hotter return fuel. >> >> Just curious - how much did this EFII system cost? >> >> Carl >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash >> Sent: Monday, April 20, 2015 12:44 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Fuel Return Line Location? >> >> >> I'm leaning toward a duplex valve, but I'm also considering two fuel valv es, >> one for the source and one for the return. This isn't that different tha n >> jets I've flown, and I think I can handle the "complexity". It's cheaper >> and it gives the advantage of being able to transfer fuel, which might co me >> in handy. Regardless, none of the answers so far tell me where to tap th e >> return line:) >> >> >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 20, 2015
Since the fuel is metered directly at the injectors by the ECU, why do you have to mess with the mixture knob? The EFII website says, "Automatic mixture control (no mixture knob to fool with)", but you're saying that's not entirely true? Is the issue that you're compensating for a lack of initial ECU programming by altering the fuel pressure until the you get the programming dialed in? Since the system has a MAP and IAT sensor, it seems like it should be able to meter correctly without any input from the pilot. It doesn't look like the EFII includes an oxygen sensor, though? Any idea if there are plans to fly this plane on automotive gasoline? On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint wrote: > I think you're kidding yourself if you think there is no mixture to worry > about. I spend more time on the mixture knob so far than I do on the > mixture control with a standard system. It's possible that once you get > things all tuned up the way you want them you may not use it as much, but I > really don't use it that much on a standard system either. I lean a little > as I climb, then I set power, rpm and fuel flow for cruise. > > I would imagine if you are burnin 12gph, you are probably returning at > least that much to the tank, if not more. I wouldn't want to have to mess > with picking a return tank separate from a feed tank. There are warnings > when your fuel in a tank gets low, but I don't know of a warning saying > your tank is getting too full. If you get busy or get bored and aren't > managing fuel with a normal system, you will get something yelling at you > saying you're getting into the red on the draw tank, but it won't happen if > you start to pump it overboard through the return tank vent. > > I agree that electric ignition is tried and true in cars, but so far there > are a total of 10 fleet hours in the RV-10 with a full EFII system and > thousands and thousands with mags and standard fuel injection. Far from a > no-brainier in my book unless you are talking the other way around. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: > > Carl- thanks so much for the picture. I'll plan on the same location. As > for the cost: We haven't purchased anything yet, and probably won't until > we source an engine. Hoping available systems will only get cheaper, but > cursory research indicates it'll cost not much more than more conventional > FI and ignition setups. > > Jesse- Thanks for the heads up. Glad to hear that one is flying already, > and I hope you'll keep us updated of any gotchas. After seeing that an EFII > system is available, I can't imagine not using it. I'm aware of the need > for a fully redundant electrical system and dual ECU's. I was already > planning on dual electronic ignition and the dual alternators that > necessitates, so electronic fuel injection only makes sense to me. This > is, I think, the beauty of building an experimental-- the ability to use > "modern" (30-year-old tried-and-tested) technology in an airplane, instead > of being forced to rely on a fuel delivery system from the 1950's. > > Any RV-10 specific EFII links, information, vendor tips, etc, would be > greatly appreciated. > > As for the "complexity" of a fuel return tank selection, it seems a bit > silly to me that choosing a return tank is considered "overly complex." > It's the difference of switching two valves instead of one when you switch > tanks in normal operations. Sure, it's more complex than a single knob, > but I'm used to much more complicated fuel systems many of which require > deliberate knowledge of the fuel return tank. I'm not really concerned > about it either way. The only reason to want to transfer fuel would be a > leak, and in most situations, getting on the ground quickly makes a lot > more sense than moving fuel around. Since I won't have to worry about the > insane complexity of a mixture control, I can use those saved neurons to > handle the fuel return tank if I wind up with two valves. > > On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich < > carl.froehlich(at)verizon.net> wrote: > >> Berck, >> >> I added a 1/4" purge line return to the left tank when building in case I >> ended up with an AFP injection system (photo attached). This is the same >> location I used the RV-8A which had AFP injection. >> >> Adding a return line is straight forward and if you get the fitting in >> about >> the same area as the vent line connection you should not have an issue. >> I'd >> keep it high (like my photo) so that it is away from the fuel pick up - >> should help with pulling cooler fuel into the engine as compared to the >> hotter return fuel. >> >> Just curious - how much did this EFII system cost? >> >> Carl >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash >> Sent: Monday, April 20, 2015 12:44 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Fuel Return Line Location? >> >> >> I'm leaning toward a duplex valve, but I'm also considering two fuel >> valves, >> one for the source and one for the return. This isn't that different than >> jets I've flown, and I think I can handle the "complexity". It's cheaper >> and it gives the advantage of being able to transfer fuel, which might >> come >> in handy. Regardless, none of the answers so far tell me where to tap the >> return line:) >> >> >> >> > * > > D============================================ > List"">http://www.matronics.com/Navigator?RV10-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > ________________________________________________________________________________
Date: Apr 20, 2015
Oh, I just realized you meant the EFII-supplied mixture knob... Which means that programming a solid fuel hands-off fuel map takes some time? On Mon, Apr 20, 2015 at 10:55 AM, Berck E. Nash wrote: > Since the fuel is metered directly at the injectors by the ECU, why do you > have to mess with the mixture knob? The EFII website says, "Automatic > mixture control (no mixture knob to fool with)", but you're saying that's > not entirely true? Is the issue that you're compensating for a lack of > initial ECU programming by altering the fuel pressure until the you get the > programming dialed in? Since the system has a MAP and IAT sensor, it seems > like it should be able to meter correctly without any input from the > pilot. It doesn't look like the EFII includes an oxygen sensor, though? > > Any idea if there are plans to fly this plane on automotive gasoline? > > > On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint > wrote: > >> I think you're kidding yourself if you think there is no mixture to worry >> about. I spend more time on the mixture knob so far than I do on the >> mixture control with a standard system. It's possible that once you get >> things all tuned up the way you want them you may not use it as much, but I >> really don't use it that much on a standard system either. I lean a little >> as I climb, then I set power, rpm and fuel flow for cruise. >> >> I would imagine if you are burnin 12gph, you are probably returning at >> least that much to the tank, if not more. I wouldn't want to have to mess >> with picking a return tank separate from a feed tank. There are warnings >> when your fuel in a tank gets low, but I don't know of a warning saying >> your tank is getting too full. If you get busy or get bored and aren't >> managing fuel with a normal system, you will get something yelling at you >> saying you're getting into the red on the draw tank, but it won't happen if >> you start to pump it overboard through the return tank vent. >> >> I agree that electric ignition is tried and true in cars, but so far >> there are a total of 10 fleet hours in the RV-10 with a full EFII system >> and thousands and thousands with mags and standard fuel injection. Far from >> a no-brainier in my book unless you are talking the other way around. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >> On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: >> >> Carl- thanks so much for the picture. I'll plan on the same location. >> As for the cost: We haven't purchased anything yet, and probably won't >> until we source an engine. Hoping available systems will only get cheaper, >> but cursory research indicates it'll cost not much more than more >> conventional FI and ignition setups. >> >> Jesse- Thanks for the heads up. Glad to hear that one is flying already, >> and I hope you'll keep us updated of any gotchas. After seeing that an EFII >> system is available, I can't imagine not using it. I'm aware of the need >> for a fully redundant electrical system and dual ECU's. I was already >> planning on dual electronic ignition and the dual alternators that >> necessitates, so electronic fuel injection only makes sense to me. This >> is, I think, the beauty of building an experimental-- the ability to use >> "modern" (30-year-old tried-and-tested) technology in an airplane, instead >> of being forced to rely on a fuel delivery system from the 1950's. >> >> Any RV-10 specific EFII links, information, vendor tips, etc, would be >> greatly appreciated. >> >> As for the "complexity" of a fuel return tank selection, it seems a bit >> silly to me that choosing a return tank is considered "overly complex." >> It's the difference of switching two valves instead of one when you switch >> tanks in normal operations. Sure, it's more complex than a single knob, >> but I'm used to much more complicated fuel systems many of which require >> deliberate knowledge of the fuel return tank. I'm not really concerned >> about it either way. The only reason to want to transfer fuel would be a >> leak, and in most situations, getting on the ground quickly makes a lot >> more sense than moving fuel around. Since I won't have to worry about the >> insane complexity of a mixture control, I can use those saved neurons to >> handle the fuel return tank if I wind up with two valves. >> >> On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich < >> carl.froehlich(at)verizon.net> wrote: >> >>> Berck, >>> >>> I added a 1/4" purge line return to the left tank when building in case I >>> ended up with an AFP injection system (photo attached). This is the same >>> location I used the RV-8A which had AFP injection. >>> >>> Adding a return line is straight forward and if you get the fitting in >>> about >>> the same area as the vent line connection you should not have an issue. >>> I'd >>> keep it high (like my photo) so that it is away from the fuel pick up - >>> should help with pulling cooler fuel into the engine as compared to the >>> hotter return fuel. >>> >>> Just curious - how much did this EFII system cost? >>> >>> Carl >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash >>> Sent: Monday, April 20, 2015 12:44 AM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: Fuel Return Line Location? >>> >>> >>> I'm leaning toward a duplex valve, but I'm also considering two fuel >>> valves, >>> one for the source and one for the return. This isn't that different >>> than >>> jets I've flown, and I think I can handle the "complexity". It's cheaper >>> and it gives the advantage of being able to transfer fuel, which might >>> come >>> in handy. Regardless, none of the answers so far tell me where to tap >>> the >>> return line:) >>> >>> >>> >>> >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?RV10-List >> D============================================ >> //forums.matronics.com <http://forums.matronics.com> >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * >> >> * >> >> >> * >> >> > ________________________________________________________________________________
Date: Apr 20, 2015
WRT auto fuel, while the injection system may be ok with it the rest of the system is problematic if you are unable to get ethanol free premium unleaded. If you can get this fuel the IO-540 D4A5 is already approved for its use. Years ago a =9CEFII like=9D company wanted to use my RV-8A as a beta for their single lever electronic fuel injection system. After a lot of research it became obvious that how I wanted to run the plane (LOP to my set point) was not possible =93 I would have only whatever the software wanted me to have for mixture. That and they wanted a boat load of cash for the system and my testing/fixing time for free killed any interest I had. Perhaps this EFII product has advanced from that of my experience. On the ignition side, I=99ll be bolting on the new 200 series P-mags in June (I hope). I have a lot of hours with P-mags on the RV-8A and they have performed flawlessly. Any ballpark number on what this system will cost? Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash Sent: Monday, April 20, 2015 12:55 PM Subject: Re: RV10-List: Fuel Return Line Location? Since the fuel is metered directly at the injectors by the ECU, why do you have to mess with the mixture knob? The EFII website says, "Automatic mixture control (no mixture knob to fool with)", but you're saying that's not entirely true? Is the issue that you're compensating for a lack of initial ECU programming by altering the fuel pressure until the you get the programming dialed in? Since the system has a MAP and IAT sensor, it seems like it should be able to meter correctly without any input from the pilot. It doesn't look like the EFII includes an oxygen sensor, though? Any idea if there are plans to fly this plane on automotive gasoline? On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint wrote: I think you're kidding yourself if you think there is no mixture to worry about. I spend more time on the mixture knob so far than I do on the mixture control with a standard system. It's possible that once you get things all tuned up the way you want them you may not use it as much, but I really don't use it that much on a standard system either. I lean a little as I climb, then I set power, rpm and fuel flow for cruise. I would imagine if you are burnin 12gph, you are probably returning at least that much to the tank, if not more. I wouldn't want to have to mess with picking a return tank separate from a feed tank. There are warnings when your fuel in a tank gets low, but I don't know of a warning saying your tank is getting too full. If you get busy or get bored and aren't managing fuel with a normal system, you will get something yelling at you saying you're getting into the red on the draw tank, but it won't happen if you start to pump it overboard through the return tank vent. I agree that electric ignition is tried and true in cars, but so far there are a total of 10 fleet hours in the RV-10 with a full EFII system and thousands and thousands with mags and standard fuel injection. Far from a no-brainier in my book unless you are talking the other way around. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until we source an engine. Hoping available systems will only get cheaper, but cursory research indicates it'll cost not much more than more conventional FI and ignition setups. Jesse- Thanks for the heads up. Glad to hear that one is flying already, and I hope you'll keep us updated of any gotchas. After seeing that an EFII system is available, I can't imagine not using it. I'm aware of the need for a fully redundant electrical system and dual ECU's. I was already planning on dual electronic ignition and the dual alternators that necessitates, so electronic fuel injection only makes sense to me. This is, I think, the beauty of building an experimental-- the ability to use "modern" (30-year-old tried-and-tested) technology in an airplane, instead of being forced to rely on a fuel delivery system from the 1950's. Any RV-10 specific EFII links, information, vendor tips, etc, would be greatly appreciated. As for the "complexity" of a fuel return tank selection, it seems a bit silly to me that choosing a return tank is considered "overly complex." It's the difference of switching two valves instead of one when you switch tanks in normal operations. Sure, it's more complex than a single knob, but I'm used to much more complicated fuel systems many of which require deliberate knowledge of the fuel return tank. I'm not really concerned about it either way. The only reason to want to transfer fuel would be a leak, and in most situations, getting on the ground quickly makes a lot more sense than moving fuel around. Since I won't have to worry about the insane complexity of a mixture control, I can use those saved neurons to handle the fuel return tank if I wind up with two valves. On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich wrote: Berck, I added a 1/4" purge line return to the left tank when building in case I ended up with an AFP injection system (photo attached). This is the same location I used the RV-8A which had AFP injection. Adding a return line is straight forward and if you get the fitting in about the same area as the vent line connection you should not have an issue. I'd keep it high (like my photo) so that it is away from the fuel pick up - should help with pulling cooler fuel into the engine as compared to the hotter return fuel. Just curious - how much did this EFII system cost? Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash Sent: Monday, April 20, 2015 12:44 AM Subject: Re: RV10-List: Fuel Return Line Location? I'm leaning toward a duplex valve, but I'm also considering two fuel valves, one for the source and one for the return. This isn't that different than jets I've flown, and I think I can handle the "complexity". It's cheaper and it gives the advantage of being able to transfer fuel, which might come in handy. Regardless, none of the answers so far tell me where to tap the return line:) D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D List"">http://www.matronics.com/Navigator?RV10-List D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D //forums.matronics.com D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D ot;">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Apr 20, 2015
Right, but there are still mixture settings that differ for different cruise powers and economy versus high speed cruise, just like any engine. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Apr 20, 2015, at 1:14 PM, Berck E. Nash wrote: > > Oh, I just realized you meant the EFII-supplied mixture knob... Which mea ns that programming a solid fuel hands-off fuel map takes some time? > >> On Mon, Apr 20, 2015 at 10:55 AM, Berck E. Nash wrote: >> Since the fuel is metered directly at the injectors by the ECU, why do yo u have to mess with the mixture knob? The EFII website says, "Automatic mix ture control (no mixture knob to fool with)", but you're saying that's not e ntirely true? Is the issue that you're compensating for a lack of initial E CU programming by altering the fuel pressure until the you get the programmi ng dialed in? Since the system has a MAP and IAT sensor, it seems like it s hould be able to meter correctly without any input from the pilot. It doesn 't look like the EFII includes an oxygen sensor, though? >> >> Any idea if there are plans to fly this plane on automotive gasoline? >> >> >> >> >>> On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint w rote: >>> I think you're kidding yourself if you think there is no mixture to worr y about. I spend more time on the mixture knob so far than I do on the mixtu re control with a standard system. It's possible that once you get things al l tuned up the way you want them you may not use it as much, but I really do n't use it that much on a standard system either. I lean a little as I climb , then I set power, rpm and fuel flow for cruise. >>> >>> I would imagine if you are burnin 12gph, you are probably returning at l east that much to the tank, if not more. I wouldn't want to have to mess wit h picking a return tank separate from a feed tank. There are warnings when y our fuel in a tank gets low, but I don't know of a warning saying your tank i s getting too full. If you get busy or get bored and aren't managing fuel wi th a normal system, you will get something yelling at you saying you're gett ing into the red on the draw tank, but it won't happen if you start to pump i t overboard through the return tank vent. >>> >>> I agree that electric ignition is tried and true in cars, but so far the re are a total of 10 fleet hours in the RV-10 with a full EFII system and th ousands and thousands with mags and standard fuel injection. Far from a no-b rainier in my book unless you are talking the other way around. >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> 352-427-0285 >>> jesse(at)saintaviation.com >>> >>> Sent from my iPad >>> >>>> On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: >>>> >>>> Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't unti l we source an engine. Hoping available systems will only get cheaper, but c ursory research indicates it'll cost not much more than more conventional FI and ignition setups. >>>> >>>> Jesse- Thanks for the heads up. Glad to hear that one is flying alread y, and I hope you'll keep us updated of any gotchas. After seeing that an EFI I system is available, I can't imagine not using it. I'm aware of the need f or a fully redundant electrical system and dual ECU's. I was already plannin g on dual electronic ignition and the dual alternators that necessitates, so electronic fuel injection only makes sense to me. This is, I think, the be auty of building an experimental-- the ability to use "modern" (30-year-old t ried-and-tested) technology in an airplane, instead of being forced to rely o n a fuel delivery system from the 1950's. >>>> >>>> Any RV-10 specific EFII links, information, vendor tips, etc, would be g reatly appreciated. >>>> >>>> As for the "complexity" of a fuel return tank selection, it seems a bit silly to me that choosing a return tank is considered "overly complex." It 's the difference of switching two valves instead of one when you switch tan ks in normal operations. Sure, it's more complex than a single knob, but I' m used to much more complicated fuel systems many of which require deliberat e knowledge of the fuel return tank. I'm not really concerned about it eith er way. The only reason to want to transfer fuel would be a leak, and in mo st situations, getting on the ground quickly makes a lot more sense than mov ing fuel around. Since I won't have to worry about the insane complexity of a mixture control, I can use those saved neurons to handle the fuel return t ank if I wind up with two valves. >>>> >>>>> On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich <carl.froehlich@verizo n.net> wrote: >>>>> Berck, >>>>> >>>>> I added a 1/4" purge line return to the left tank when building in cas e I >>>>> ended up with an AFP injection system (photo attached). This is the s ame >>>>> location I used the RV-8A which had AFP injection. >>>>> >>>>> Adding a return line is straight forward and if you get the fitting in about >>>>> the same area as the vent line connection you should not have an issue . I'd >>>>> keep it high (like my photo) so that it is away from the fuel pick up - >>>>> should help with pulling cooler fuel into the engine as compared to th e >>>>> hotter return fuel. >>>>> >>>>> Just curious - how much did this EFII system cost? >>>>> >>>>> Carl >>>>> >>>>> -----Original Message----- >>>>> From: owner-rv10-list-server(at)matronics.com >>>>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Na sh >>>>> Sent: Monday, April 20, 2015 12:44 AM >>>>> To: rv10-list(at)matronics.com >>>>> Subject: Re: RV10-List: Fuel Return Line Location? >>>>> >>>>> >>>>> I'm leaning toward a duplex valve, but I'm also considering two fuel v alves, >>>>> one for the source and one for the return. This isn't that different t han >>>>> jets I've flown, and I think I can handle the "complexity". It's chea per >>>>> and it gives the advantage of being able to transfer fuel, which might come >>>>> in handy. Regardless, none of the answers so far tell me where to tap the >>>>> return line:) >>>> >>>> >>>> >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> List"">http://www.matronics.com/Navigator?RV10-List >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> //forums.matronics.com >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> ot;">http://www.matronics.com/contribution >>>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D >>>> >>> >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >>> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 20, 2015
I assume you are aware that leaded fuel such as 100LL will destroy an oxygen sensor in less than one tank of fuel? I seriously doubt that the EFII system and the dual everything required to ensure it has power to work will save enough fuel to have a payback in any reasonable time frame. Mixture management on conventional fuel injection with magnetos is childs play once you get the system delivering equal fuel mixture to each cylinder. While autos are using less gas and producing more power, they are doing it with higher compression ratios, knock sensors and thousands of hours of dyno time. Most of the incremental benefit comes from electronic ignition, not electronic timed fuel injection. Feel free to experiment, but don't expect to get equal power on half the gas, or half the workload, for equal investment. On 4/20/2015 9:55 AM, Berck E. Nash wrote: > Since the fuel is metered directly at the injectors by the ECU, why do > you have to mess with the mixture knob? The EFII website says, > "Automatic mixture control (no mixture knob to fool with)", but you're > saying that's not entirely true? Is the issue that you're > compensating for a lack of initial ECU programming by altering the > fuel pressure until the you get the programming dialed in? Since the > system has a MAP and IAT sensor, it seems like it should be able to > meter correctly without any input from the pilot. It doesn't look > like the EFII includes an oxygen sensor, though? > > Any idea if there are plans to fly this plane on automotive gasoline? > > > On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint > wrote: > > I think you're kidding yourself if you think there is no mixture > to worry about. I spend more time on the mixture knob so far than > I do on the mixture control with a standard system. It's possible > that once you get things all tuned up the way you want them you > may not use it as much, but I really don't use it that much on a > standard system either. I lean a little as I climb, then I set > power, rpm and fuel flow for cruise. > > I would imagine if you are burnin 12gph, you are probably > returning at least that much to the tank, if not more. I wouldn't > want to have to mess with picking a return tank separate from a > feed tank. There are warnings when your fuel in a tank gets low, > but I don't know of a warning saying your tank is getting too > full. If you get busy or get bored and aren't managing fuel with a > normal system, you will get something yelling at you saying you're > getting into the red on the draw tank, but it won't happen if you > start to pump it overboard through the return tank vent. > > I agree that electric ignition is tried and true in cars, but so > far there are a total of 10 fleet hours in the RV-10 with a full > EFII system and thousands and thousands with mags and standard > fuel injection. Far from a no-brainier in my book unless you are > talking the other way around. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > On Apr 20, 2015, at 11:58 AM, Berck E. Nash > wrote: > >> Carl- thanks so much for the picture. I'll plan on the same >> location. As for the cost: We haven't purchased anything yet, >> and probably won't until we source an engine. Hoping available >> systems will only get cheaper, but cursory research indicates >> it'll cost not much more than more conventional FI and ignition >> setups. >> >> Jesse- Thanks for the heads up. Glad to hear that one is flying >> already, and I hope you'll keep us updated of any gotchas. After >> seeing that an EFII system is available, I can't imagine not >> using it. I'm aware of the need for a fully redundant electrical >> system and dual ECU's. I was already planning on dual electronic >> ignition and the dual alternators that necessitates, so >> electronic fuel injection only makes sense to me. This is, I >> think, the beauty of building an experimental-- the ability to >> use "modern" (30-year-old tried-and-tested) technology in an >> airplane, instead of being forced to rely on a fuel delivery >> system from the 1950's. >> >> Any RV-10 specific EFII links, information, vendor tips, etc, >> would be greatly appreciated. >> >> As for the "complexity" of a fuel return tank selection, it seems >> a bit silly to me that choosing a return tank is considered >> "overly complex." It's the difference of switching two valves >> instead of one when you switch tanks in normal operations. Sure, >> it's more complex than a single knob, but I'm used to much more >> complicated fuel systems many of which require deliberate >> knowledge of the fuel return tank. I'm not really concerned >> about it either way. The only reason to want to transfer fuel >> would be a leak, and in most situations, getting on the ground >> quickly makes a lot more sense than moving fuel around. Since I >> won't have to worry about the insane complexity of a mixture >> control, I can use those saved neurons to handle the fuel return >> tank if I wind up with two valves. >> >> On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich >> > >> wrote: >> >> Berck, >> >> I added a 1/4" purge line return to the left tank when >> building in case I >> ended up with an AFP injection system (photo attached). This >> is the same >> location I used the RV-8A which had AFP injection. >> >> Adding a return line is straight forward and if you get the >> fitting in about >> the same area as the vent line connection you should not have >> an issue. I'd >> keep it high (like my photo) so that it is away from the fuel >> pick up - >> should help with pulling cooler fuel into the engine as >> compared to the >> hotter return fuel. >> >> Just curious - how much did this EFII system cost? >> >> Carl >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> >> [mailto:owner-rv10-list-server(at)matronics.com >> ] On Behalf Of >> Berck E. Nash >> Sent: Monday, April 20, 2015 12:44 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Fuel Return Line Location? >> >> > >> >> I'm leaning toward a duplex valve, but I'm also considering >> two fuel valves, >> one for the source and one for the return. This isn't that >> different than >> jets I've flown, and I think I can handle the "complexity". >> It's cheaper >> and it gives the advantage of being able to transfer fuel, >> which might come >> in handy. Regardless, none of the answers so far tell me >> where to tap the >> return line:) >> >> >> >> >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?RV10-List >> D============================================ >> //forums.matronics.com <http://forums.matronics.com> >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > * > > > * > > > * ________________________________________________________________________________
Subject: Re: Fuel Return Line Location?
Date: Apr 20, 2015
I purchased the dual ecu 4cyl system for $5970 with shipping. > On Apr 20, 2015, at 09:37, Carl Froehlich wro te: > > WRT auto fuel, while the injection system may be ok with it the rest of th e system is problematic if you are unable to get ethanol free premium unlead ed. If you can get this fuel the IO-540 D4A5 is already approved for its us e. > > Years ago a =9CEFII like=9D company wanted to use my RV-8A as a beta for their single lever electronic fuel injection system. After a lot o f research it became obvious that how I wanted to run the plane (LOP to my s et point) was not possible =93 I would have only whatever the software wanted me to have for mixture. That and they wanted a boat load of cash fo r the system and my testing/fixing time for free killed any interest I had. > > Perhaps this EFII product has advanced from that of my experience. On the ignition side, I=99ll be bolting on the new 200 series P-mags in June (I hope). I have a lot of hours with P-mags on the RV-8A and they have per formed flawlessly. > > Any ballpark number on what this system will cost? > > Carl > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Berck E. Nash > Sent: Monday, April 20, 2015 12:55 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel Return Line Location? > > Since the fuel is metered directly at the injectors by the ECU, why do you have to mess with the mixture knob? The EFII website says, "Automatic mixt ure control (no mixture knob to fool with)", but you're saying that's not en tirely true? Is the issue that you're compensating for a lack of initial EC U programming by altering the fuel pressure until the you get the programmin g dialed in? Since the system has a MAP and IAT sensor, it seems like it sh ould be able to meter correctly without any input from the pilot. It doesn' t look like the EFII includes an oxygen sensor, though? > > Any idea if there are plans to fly this plane on automotive gasoline? > > > > > On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint wr ote: > I think you're kidding yourself if you think there is no mixture to worry a bout. I spend more time on the mixture knob so far than I do on the mixture c ontrol with a standard system. It's possible that once you get things all tu ned up the way you want them you may not use it as much, but I really don't u se it that much on a standard system either. I lean a little as I climb, the n I set power, rpm and fuel flow for cruise. > > I would imagine if you are burnin 12gph, you are probably returning at lea st that much to the tank, if not more. I wouldn't want to have to mess with p icking a return tank separate from a feed tank. There are warnings when your fuel in a tank gets low, but I don't know of a warning saying your tank is g etting too full. If you get busy or get bored and aren't managing fuel with a normal system, you will get something yelling at you saying you're getting i nto the red on the draw tank, but it won't happen if you start to pump it ov erboard through the return tank vent. > > I agree that electric ignition is tried and true in cars, but so far there are a total of 10 fleet hours in the RV-10 with a full EFII system and thou sands and thousands with mags and standard fuel injection. Far from a no-bra inier in my book unless you are talking the other way around. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > On Apr 20, 2015, at 11:58 AM, Berck E. Nash wrote: > > Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until w e source an engine. Hoping available systems will only get cheaper, but cur sory research indicates it'll cost not much more than more conventional FI a nd ignition setups. > > Jesse- Thanks for the heads up. Glad to hear that one is flying already, a nd I hope you'll keep us updated of any gotchas. After seeing that an EFII s ystem is available, I can't imagine not using it. I'm aware of the need for a fully redundant electrical system and dual ECU's. I was already planning o n dual electronic ignition and the dual alternators that necessitates, so el ectronic fuel injection only makes sense to me. This is, I think, the beaut y of building an experimental-- the ability to use "modern" (30-year-old tri ed-and-tested) technology in an airplane, instead of being forced to rely on a fuel delivery system from the 1950's. > > Any RV-10 specific EFII links, information, vendor tips, etc, would be gre atly appreciated. > > As for the "complexity" of a fuel return tank selection, it seems a bit si lly to me that choosing a return tank is considered "overly complex." It's t he difference of switching two valves instead of one when you switch tanks i n normal operations. Sure, it's more complex than a single knob, but I'm us ed to much more complicated fuel systems many of which require deliberate kn owledge of the fuel return tank. I'm not really concerned about it either w ay. The only reason to want to transfer fuel would be a leak, and in most s ituations, getting on the ground quickly makes a lot more sense than moving f uel around. Since I won't have to worry about the insane complexity of a mi xture control, I can use those saved neurons to handle the fuel return tank i f I wind up with two valves. > > On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich wrote: > Berck, > > I added a 1/4" purge line return to the left tank when building in case I > ended up with an AFP injection system (photo attached). This is the same > location I used the RV-8A which had AFP injection. > > Adding a return line is straight forward and if you get the fitting in abo ut > the same area as the vent line connection you should not have an issue. I 'd > keep it high (like my photo) so that it is away from the fuel pick up - > should help with pulling cooler fuel into the engine as compared to the > hotter return fuel. > > Just curious - how much did this EFII system cost? > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash > Sent: Monday, April 20, 2015 12:44 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Fuel Return Line Location? > > > I'm leaning toward a duplex valve, but I'm also considering two fuel valve s, > one for the source and one for the return. This isn't that different than > jets I've flown, and I think I can handle the "complexity". It's cheaper > and it gives the advantage of being able to transfer fuel, which might com e > in handy. Regardless, none of the answers so far tell me where to tap the > return line:) > > > > > > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > List"">http://www.matronics.com/Navigator?RV10-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > //forums.matronics.com > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > > > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com > _blank">http://www.matronics.com/contribution > > > > > http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > http://www.matronics.com/contribution > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Apr 20, 2015
Carl, your return line seems to be in the same general vicinity as these, and they say they have spar interference? http://www.vansairforce.com/community/showthread.php?t=122839 How were you able to be sure that yours cleared the spar? Am I just looking at this wrong? Berck ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Fuel Return Line Location?
Date: Apr 20, 2015
Don't know. I never used the purge return. The fitting is capped off with an AN cap in the event I ever want to use it. As the plane is flying this must not have been a problem. Taking the plane down for conditional inspection next month so I'll look. I do note that the photos from the Van's Air Force link have the return line further aft than I do. That said, there is no reason not to place the return line fitting more forward on the rib to make sure - like just forward of the fuel sender and about center on the rib. Just make sure you mind the aileron connecting arm. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash Sent: Monday, April 20, 2015 9:24 PM Subject: Re: RV10-List: Fuel Return Line Location? Carl, your return line seems to be in the same general vicinity as these, and they say they have spar interference? http://www.vansairforce.com/community/showthread.php?t=122839 How were you able to be sure that yours cleared the spar? Am I just looking at this wrong? Berck ________________________________________________________________________________
Date: Apr 20, 2015
Subject: Fuel Selector was: Fuel Return Line Location?
Hi Justin, It sounds like you've put a lot more thought into this than I have. I didn't think about a high wing. You're correct, a BOTH position shouldn't be issue. I'd still be concerned, though, about overfilling a tank. Alarms are great when they work, but simplicity is better. The concept of overpressuring a tank with a pump that can put out more than 100 psi is scary to me. Once you overwhelm the vent, what keeps the tank from rupturing? Fuel tanks typically only handle one or two psi before they start to deform. I can practically guarantee you from experience with numerous fuel systems that if you draw from both and return to both, you will fill one and drain one. I've seen it happen a few times. The only explanation I can offer is that I *think* that a small imbalance in vent pressure will bias one tank enough to allow the levels to become very different. Then you'd be working to balance things out, at who knows what phase of flight. Yikes. Thank you for flying those big planes. I'm sure that their designers also craved simpler systems. --Dave On Sun, Apr 19, 2015 at 9:50 PM, Justin Jones wrote: > Dave, > > I understand your concern and welcome any ideas and thoughts that may be > cause for issues. The issues you brought up have been considered and her e > is what I have come up with. Note that I have spoken with many others > about this as well, but it doesn=99t mean that we aren=99t mi ssing something. > > The normal configuration (covered on the before take-off checklist) would > be both return valves open and the fuel valve on both. The transfer of fu el > during refueling operations (while the aircraft is on floats) is one reas on > for this setup, and the other is the ability to draw fuel from both tanks > simultaneously. > > =9CYou could return to a full tank and waste fuel overboard =9D - This scenario > could present itself, but would cause an over-pressure situation due to t he > vent size. The digital engine monitor senses fuel pressure and sounds an > audio and visual alarm when it is either too high or too low. > > =9CYou could unport an empty tank into =9CBOTH=9D and s tarve the engine=9D - This > scenario has also been tested. With one tank empty, one tank full, and th e > selector to =9CBOTH=9D, there was still full fuel pressure. This may be due to > the high-wing design and the fuel system plumbing called for by Robert > Paisley of EFII. > > =9CYou could turn off both return valves and I don =99t know what, but it > seems bad=9D - It would cause the fuel to back up at the valves, an d the fuel > pressure would increase to the maximum that the GL393 fuel pump would put > out. This would be 105 PSI at 10 Gallons per hour. Not sustainable, but > not harmful to the injectors or fuel lines for short periods of time. > Again, the Engine Monitor will alarm when the fuel pressure begins to > increase. The fuel system has been tested to the fuel pump stall pressur e > of 115 PSI and found to have no leaks. > > I fly C-130s and King Air 200s and they both have fuel systems that are > far more complicated. Flying aircraft will always require thought. With > the duplex fuel valve, the pilot must remember to switch the fuel valves > when it is necessary. I like the idea of being able to operate in a norm al > scenario with the fuel valve on both, and have the fuel is return to both > tanks. If the situation arises, I can put the fuel where it is needed an d > I have a good monitoring system that will alert me if I make a mistake in > the positioning of fuel valves. The return valves do not have a position > that will cause the engine to quit turning. > > Thoughts? > > Thanks for your input. > > Respectfully, > > Justin > > > On Apr 19, 2015, at 7:30 PM, David Saylor wrote: > > Hi Justin, > > You are of course free to build whatever fuel system you like, but the on e > you described has some issues. > > I think you'd be better off with a L-R-OFF duplex fuel valve that routes > return fuel to the same tank you're burning from. You're headed towards a > scenario that makes it pretty easy to mismanage the fuel: > > You could return to a full tank and waste fuel overboard; > > You could unport an empty tank in "BOTH" and starve the engine; > > You could turn off both return valves and...I don't know what, but it > seems bad. > > Please consider a simpler system. Caution never goes as far as we think > it will. > > --Dave > > > On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones > wrote: > m >> > >> >> Berck, >> >> I am using an EFII system as well. Just a thought, but I put a normal >> L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return >> line that Splits to each tank. After the "T" I put a simple Parker >> petroleum 1/4 turn ball valve on each side just before the tank. Now, I can >> shut one or the other return valves off, turn on the fuel pump, and >> transfer fuel on the ground. It can also be done in the air (with cautio n >> of course) to trim fuel. >> >> Note: I'm building a Bushcaddy not an rv10. >> >> I can send pics if you would like. >> >> Justin >> >> >> > On Apr 19, 2015, at 18:10, Berck E. Nash wrote: >> > >> > >> > We're planning on EFII, so we need a full-sized return line for both >> > sides. Just now starting work on the fuel tank, and I'd like to get >> > this sorted before we get too far. I've spent awhile searching, and >> > have only managed to find lots of places not to put the port for the >> > fuel return line. Apparently it can interfere with both the wing spar >> > and the aileron return line. Does anyone have a clear diagram of wher e >> > I can safely put it? A hint about which flange/fittings to buy would b e >> > greatly appreciated as well. Thanks in advance! >> > >> > Berck >> > >> > >> > >> > >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > class="">http://www.matronics.com/Navigator?RV10-List > class="">http://forums.matronics.com > class="">http://www.matronics.com/contribution > > * > > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Apr 20, 2015
The wide band O2 sensors will eventually burn out due to lead fowling. They are pricey, and it does not happen in less than one tank of 100LL. There are many guys that have used them for tuning and removed them when they are done with them. Not a good idea to keep them in as they will eventually burn out completely. If you plan on changing your fuel map, I would HIGHLY suggest using a wide band sensor and a display to ensure your AFR (air fuel ratio) is not getting to lean. The stoichiometric ratio for a natural aspirated engine is 14.7:1 It is safer in our aircraft engines to run them at 13.7:1 and thats what the EFII systems stock fuel map is programed to provide. Another indicator of the AFR is EGT, but other things can affect EGT, so the safe bet while tuning is to use a wide band O2 sensor and an AFR gauge to display the correct number to ensure you dont get too lean. The EFII system for me, was a cost benefit to overhauling what I currently had. An RSA5 fuel injection overhaul, new fuel pump, new mags, wires, plugs etc would have been at or above the cost of acquisition of the EFiI system. I have heard nothing but good from this system and Robert Paisley from ProTec Performance has been nothing short of a rockstar with his customer service. I would agree that more benefit comes from the EI than the fuel injection, but by modulating the injectors, they are seeing gains on the dyno with the Electronic Fuel Injection over the mechanical injection. Also of note, the Lycoming hot start issue disappears with the EFII fuel injection. Mixture management is simple with the EFII system due to the programed fuel map they have in the ECUs. It reads the Manifold pressure, RPM, Throttle position sensor, and comes up with the fuel demand for the engine regardless of altitude. There is NO MAF sensor in this system. It uses a similar sensor in the throttle body. If you wish to trim fuel to change the EGTs, you can do so with the mixture rheostat, or you can do it by reprograming the ECUs fuel mapping. Takes some programing knowledge and the software, but its not hard to do. Robert Paisley and or SDS can help with this as well. There is significant fuel savings with this system, but as Kelly stated, it is not half the fuel. Robert has his EFII system on numerous aircraft that race in the Reno air races, as well as many many happy customers flying the complete system. The ECUs are SDS ECUs and have hundreds of thousands of hours tested on them. The fuel pumps
March 24, 2015 - April 21, 2015
RV10-Archive.digest.vol-kl
