RV10-Archive.digest.vol-kn
May 10, 2015 - Present
      >> Alan
      >> Sent from my iPhone
      >> On May 10, 2015, at 7:24 PM, Jesse Saint > > wrote:
      >>> Ever is a long time. I am sure Foreflight will have to start
      >>> supporting other ads-b formats before long or they will be unable to
      >>> compete. They are very conservative, so they are late adopters of
      >>> certain features/compatibilities, but when something is out, stable
      >>> and dependable, they will be, IMHO, more open to adding compatibility.
      >>> Jesse Saint
      >>> Saint Aviation, Inc.
      >>> 352-427-0285
      >>> jesse(at)saintaviation.com
      >>> Sent from my iPad
      >>> On May 10, 2015, at 6:19 PM, Bob Leffler >> > wrote:
      >>>> Bill is partially correct.    I doubt that Foreflight will ever
      >>>> support NavWorx.    Now if you want to use WingX or another
      >>>> application, it shouldn't be a problem.
      >>>> Sent from my iPad
      >>>> On May 10, 2015, at 5:14 PM, Tim Olson >>> > wrote:
      >>>>> Why do you say the NavWorX will never be able to be hooked to your
      >>>>> iPad?  I'm assuming you just have it connected to the GRT via
      >>>>> RS232.  If so, you can just split the TX wire and send it to the
      >>>>> Wifi adapter.  It should easily be able to do both GRT and iPad.
      >>>>> Tim
      >>>>> On May 10, 2015, at 3:58 PM, Bill Watson >>>> > wrote:
      >>>>>> I have an iPad running Foreflight pro with the Bad Elf GPS puck
      >>>>>> (my original iPad was wifi only so it required a separate GPS
      >>>>>> puck, my current iPad has the internal GPS but I still use the puck).
      >>>>>> I have a separate Navworx ADSB receiver that will never be able
      >>>>>> to be linked to my iPad - so no weather or traffic is displayed
      >>>>>> on the iPad.  Instead I look to my primary EFIS displays (Grand
      >>>>>> Rapids HXs) for weather and traffic overlayed on the navigation
      >>>>>> screens.  The iPad is a supplement... but a drool worthy one that
      >>>>>> I don't leave home without.
      >>>>>> I file and fly IFR on practically every flight.  Flight planning
      >>>>>> and filing is done on the iPad using Foreflight.  Every base is
      >>>>>> well covered by Foreflight and it still manages to delight when I
      >>>>>> need something new like filing an ICAO flight plan for an
      >>>>>> international flight to the Bahamas.  Often the planning and
      >>>>>> filing is done in a hotel room, in a car or at the FBO.  I rarely
      >>>>>> use FBO flight planning rooms or equipment.
      >>>>>> I learned the art of chart folding and pencil management flying
      >>>>>> single pilot IFR without an AP.  But since then I've gone
      >>>>>> paperless with the iPad and Foreflight.  No charts, no pencils,
      >>>>>> just a subscription, a stylus for writing clearances on the
      >>>>>> Foreflight scratch pad, and an iPhone running Foreflight for
      >>>>>> backup (the second copy is part of the basic or pro Foreflight
      >>>>>> package).
      >>>>>> The key to making this work for me was a good mount.  I built a
      >>>>>> fiberglass center console that 1) houses a O2 bottle and 2)
      >>>>>> holds  a RAM mount for the iPad that puts it right under my right
      >>>>>> hand during flight so it can be easily used.  You can see it here
      >>>>>> Kitlog page of console construction
      >>>>>> <http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=8533>
      >>>>>> (I really need a picture of it being used in the cockpit).  I
      >>>>>> also added a USB charging port which typically gets used for my
      >>>>>> wife's phone.  The iPad's capacity is equivalent to the 10's range.
      >>>>>> I don't know where the sweet spot is but the iPad with Foreflight
      >>>>>> Pro or it's equivalent is a required part of my IFR flying.  I do
      >>>>>> my 'tactical' flying with my panel mounted EFISs but all
      >>>>>> planning, what-ifs, thinking and re-orienting is done with the
      >>>>>> iPad. Geo-referenced taxi diagrams is almost worth the price if
      >>>>>> you fly into a lot of new-to-you larger airports.  It's a fair
      >>>>>> price for a whole lot of benefit.  It's a game changer, a
      >>>>>> drooler, a "I'll never go back" kind of tool.
      >>>>>> Looking at the bigger picture, portables enable us to keep our
      >>>>>> cockpits current at a much more reasonable cost than a panel
      >>>>>> upgrade.  My panel was set in stone in late 2008.  A lot has
      >>>>>> happened since then.  While software upgrades to my EFIS and
      >>>>>> other components have helped keep them somewhat current, we rely
      >>>>>> on the portable to get the latest functions implemented in  the
      >>>>>> best possible ways, e.g. touch screen functionality, faster
      >>>>>> processors, higher resolution screens.  None of these are 'must
      >>>>>> haves' but they are very very nice to haves and they are
      >>>>>> available for a fraction of the cost of panel upgrades.
      >>>>>> On 5/9/2015 10:46 AM, kearney wrote:
      >>>>>>> Hi
      >>>>>>> For the past couple of weeks I have been working on renewing my IFR rating.
      In the process I have started lusting / drooling over the IPAD my instructor
      used. It had georefed plates. I on the other hand was using low tech paper.
      His gear / subscription cost beaucoup de dineros.
      >>>>>>> Being a frugal (ie miserly pilot) I am wondering what IPAD /  tablet /
      mini PC and subscription options others are using. I am especially interested
      in where the cost / benefit sweet spot is.
      >>>>>>> Cheers
      >>>>>>> Les
      >>>>>>> Read this topic online here:
      >>>>>>> http://forums.matronics.com/viewtopic.php?p=441931#441931
      >>>>>>> No virus found in this message.
      >>>>>>> Checked by AVG -www.avg.com
      >>>>> D============================================
      >>>>> List"">http://www.matronics.com/Navigator?RV10-List
      >>>>> //forums.matronics.com  <http://forums.matronics.com>
      >>>>> ot;">http://www.matronics.com/contribution
Subject: Re: Tech in the front office
Date: May 10, 2015
Shame Dynon wont work to get the Navworx to be seen on their Display. I understand a possible conflict of their interest, as Dynon was on the Navworx list, than disappeared once Dynon went on their "trig" route. For us who had the display before the transponder and other products were released, we're "on hold" until that happens. -----Original Message----- From: Kelly McMullen Sent: Sunday, May 10, 2015 5:57 PM Subject: Re: RV10-List: Tech in the front office I assume you mean their ADS-B In receiver. Trig makes the Avidyne 340 ADS-B Out for them. It is basically a TT31 with a different front faceplate. Ditto the KN-74, and the Dynon 1090ES that is a TT21/22 with Dynon label. On 5/10/2015 5:19 PM, Tim Olson wrote: > And NavWorX makes Avidyne's box for them... > Tim > > > On May 10, 2015, at 6:50 PM, Alan Mekler MD > wrote: > >> Jesse, >> I heard Avidyne will be using wifi and Foreflight . >> Alan >> >> Sent from my iPhone >> >> On May 10, 2015, at 7:24 PM, Jesse Saint > > wrote: >> >>> Ever is a long time. I am sure Foreflight will have to start supporting >>> other ads-b formats before long or they will be unable to compete. They >>> are very conservative, so they are late adopters of certain >>> features/compatibilities, but when something is out, stable and >>> dependable, they will be, IMHO, more open to adding compatibility. >>> >>> Jesse Saint >>> Saint Aviation, Inc. >>> 352-427-0285 >>> jesse(at)saintaviation.com >>> >>> Sent from my iPad >>> >>> On May 10, 2015, at 6:19 PM, Bob Leffler >> > wrote: >>> >>>> Bill is partially correct. I doubt that Foreflight will ever support >>>> NavWorx. Now if you want to use WingX or another application, it >>>> shouldn't be a problem. >>>> >>>> Sent from my iPad >>>> >>>> On May 10, 2015, at 5:14 PM, Tim Olson >>> > wrote: >>>> >>>>> Why do you say the NavWorX will never be able to be hooked to your >>>>> iPad? I'm assuming you just have it connected to the GRT via RS232. >>>>> If so, you can just split the TX wire and send it to the Wifi adapter. >>>>> It should easily be able to do both GRT and iPad. >>>>> Tim >>>>> >>>>> >>>>> >>>>> On May 10, 2015, at 3:58 PM, Bill Watson >>>> > wrote: >>>>> >>>>>> I have an iPad running Foreflight pro with the Bad Elf GPS puck (my >>>>>> original iPad was wifi only so it required a separate GPS puck, my >>>>>> current iPad has the internal GPS but I still use the puck). >>>>>> >>>>>> I have a separate Navworx ADSB receiver that will never be able to be >>>>>> linked to my iPad - so no weather or traffic is displayed on the >>>>>> iPad. Instead I look to my primary EFIS displays (Grand Rapids HXs) >>>>>> for weather and traffic overlayed on the navigation screens. The >>>>>> iPad is a supplement... but a drool worthy one that I don't leave >>>>>> home without. >>>>>> >>>>>> I file and fly IFR on practically every flight. Flight planning and >>>>>> filing is done on the iPad using Foreflight. Every base is well >>>>>> covered by Foreflight and it still manages to delight when I need >>>>>> something new like filing an ICAO flight plan for an international >>>>>> flight to the Bahamas. Often the planning and filing is done in a >>>>>> hotel room, in a car or at the FBO. I rarely use FBO flight planning >>>>>> rooms or equipment. >>>>>> >>>>>> I learned the art of chart folding and pencil management flying >>>>>> single pilot IFR without an AP. But since then I've gone paperless >>>>>> with the iPad and Foreflight. No charts, no pencils, just a >>>>>> subscription, a stylus for writing clearances on the Foreflight >>>>>> scratch pad, and an iPhone running Foreflight for backup (the second >>>>>> copy is part of the basic or pro Foreflight package). >>>>>> >>>>>> The key to making this work for me was a good mount. I built a >>>>>> fiberglass center console that 1) houses a O2 bottle and 2) holds a >>>>>> RAM mount for the iPad that puts it right under my right hand during >>>>>> flight so it can be easily used. You can see it here Kitlog page of >>>>>> console construction >>>>>> <http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=8533> >>>>>> (I really need a picture of it being used in the cockpit). I also >>>>>> added a USB charging port which typically gets used for my wife's >>>>>> phone. The iPad's capacity is equivalent to the 10's range. >>>>>> >>>>>> I don't know where the sweet spot is but the iPad with Foreflight Pro >>>>>> or it's equivalent is a required part of my IFR flying. I do my >>>>>> 'tactical' flying with my panel mounted EFISs but all planning, >>>>>> what-ifs, thinking and re-orienting is done with the iPad. >>>>>> Geo-referenced taxi diagrams is almost worth the price if you fly >>>>>> into a lot of new-to-you larger airports. It's a fair price for a >>>>>> whole lot of benefit. It's a game changer, a drooler, a "I'll never >>>>>> go back" kind of tool. >>>>>> >>>>>> Looking at the bigger picture, portables enable us to keep our >>>>>> cockpits current at a much more reasonable cost than a panel upgrade. >>>>>> My panel was set in stone in late 2008. A lot has happened since >>>>>> then. While software upgrades to my EFIS and other components have >>>>>> helped keep them somewhat current, we rely on the portable to get the >>>>>> latest functions implemented in the best possible ways, e.g. touch >>>>>> screen functionality, faster processors, higher resolution screens. >>>>>> None of these are 'must haves' but they are very very nice to haves >>>>>> and they are available for a fraction of the cost of panel upgrades. >>>>>> >>>>>> On 5/9/2015 10:46 AM, kearney wrote: >>>>>>> >>>>>>> Hi >>>>>>> >>>>>>> For the past couple of weeks I have been working on renewing my IFR >>>>>>> rating. In the process I have started lusting / drooling over the >>>>>>> IPAD my instructor used. It had georefed plates. I on the other hand >>>>>>> was using low tech paper. His gear / subscription cost beaucoup de >>>>>>> dineros. >>>>>>> >>>>>>> Being a frugal (ie miserly pilot) I am wondering what IPAD / tablet >>>>>>> / mini PC and subscription options others are using. I am especially >>>>>>> interested in where the cost / benefit sweet spot is. >>>>>>> >>>>>>> Cheers >>>>>>> >>>>>>> Les >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> Read this topic online here: >>>>>>> >>>>>>> http://forums.matronics.com/viewtopic.php?p=441931#441931 >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> >>>>>>> ----- >>>>>>> No virus found in this message. >>>>>>> Checked by AVG -www.avg.com >>>>>>> >>>>>>> >>>>>> >>>>>> * >>>>>> >>>>>> >>>>>> * >>>>> * >>>>> >>>>> D============================================ >>>>> List"">http://www.matronics.com/Navigator?RV10-List >>>>> D============================================ >>>>> //forums.matronics.com <http://forums.matronics.com> >>>>> D============================================ >>>>> ot;">http://www.matronics.com/contribution >>>>> D============================================ >>>>> >>>>> * >>>> * >>>> >>>> D============================================ >>>> List"">http://www.matronics.com/Navigator?RV10-List >>>> D============================================ >>>> //forums.matronics.com <http://forums.matronics.com> >>>> D============================================ >>>> ot;">http://www.matronics.com/contribution >>>> D============================================ >>>> >>>> * >>> * >>> >>> D============================================ >>> List"">http://www.matronics.com/Navigator?RV10-List >>> D============================================ >>> //forums.matronics.com <http://forums.matronics.com> >>> D============================================ >>> ot;">http://www.matronics.com/contribution >>> D============================================ >>> >>> * >> * >> >> D============================================ >> List"">http://www.matronics.com/Navigator?RV10-List >> D============================================ >> //forums.matronics.com >> D============================================ >> ot;">http://www.matronics.com/contribution >> D============================================ >> >> * > * > > > * ________________________________________________________________________________
Date: May 11, 2015
Yes, that's what I meant. Whether the reasons are due to business relationships or conservatism/stability, I have seen no indication that there is any plan to link Navworx/ADSB Wx and traffic with Foreflight. I'm sure it wouldn't hurt to continue to make noise about it. OTOH, while it would be real nice to display at least Navworx generated Nexrad imagery on Foreflight, I don't really miss it. I try to keep my eyeballs on the EFIS displays as much as possible. In VMC conditions it keeps my eyes closer to looking outside. In IMC it keeps my eyes on what needs to be scanned to keep the airplane upright even if I let Tiger do most of the flying. So the first priority is having as much information as possible displayed on the panel mounted EFISs including weather and traffic. The iPad is for planning and what-ifs. For example, the iPad map is always 'north up', the EFIS map is always heading up. I never skew the map display on the EFIS but constantly skew it on the iPad. I've spent zero time checking out the AI and Syn Vision functions on Foreflight (I don't think I have everything it takes to enable them). My primary and backup instruments are all panel mounted. That is, if the stuff hits the fan I want everything I need on the installed panel. Then I'm sure it would be nice to have the iPad to help out if available. My primary wish list involves upgraded EFISs for faster processors and higher resolution displays so that things like plate overlays would work satisfactorily. Upgraded GRT units are available but would require more panel reengineering than is justified right now. That makes the iPad, and in my case Foreflight, the sweet spot for investments. But having had my initial IFR flying done with a six pack sans AP, my GRT/Garmin/Trutrak panel continues to be wonderful and surprising.... the first time I saw some crossing traffic whiz by on my synthetic visions display, I had to chuckle. I didn't know it would do that! That was almost as good as sitting in my half built fuselage after upgrading my GRTs with Synthetic Vision... sitting in a windowless hangar, I powered it up and all of a sudden a picture of the runway and lake outside appeared on the screens! Oh Yeah!! Bill "think I'm going to Pittsburgh later today to see my Mom" Watson On 5/10/2015 6:19 PM, Bob Leffler wrote: > Bill is partially correct. I doubt that Foreflight will ever > support NavWorx. Now if you want to use WingX or another > application, it shouldn't be a problem. > > Sent from my iPad > > On May 10, 2015, at 5:14 PM, Tim Olson > wrote: > >> Why do you say the NavWorX will never be able to be hooked to your >> iPad? I'm assuming you just have it connected to the GRT via RS232. >> If so, you can just split the TX wire and send it to the Wifi >> adapter. It should easily be able to do both GRT and iPad. >> Tim >> >> >> >> On May 10, 2015, at 3:58 PM, Bill Watson > > wrote: >> >>> I have an iPad running Foreflight pro with the Bad Elf GPS puck (my >>> original iPad was wifi only so it required a separate GPS puck, my >>> current iPad has the internal GPS but I still use the puck). >>> >>> I have a separate Navworx ADSB receiver that will never be able to >>> be linked to my iPad - so no weather or traffic is displayed on the >>> iPad. Instead I look to my primary EFIS displays (Grand Rapids HXs) >>> for weather and traffic overlayed on the navigation screens. The >>> iPad is a supplement... but a drool worthy one that I don't leave >>> home without. >>> >>> I file and fly IFR on practically every flight. Flight planning and >>> filing is done on the iPad using Foreflight. Every base is well >>> covered by Foreflight and it still manages to delight when I need >>> something new like filing an ICAO flight plan for an international >>> flight to the Bahamas. Often the planning and filing is done in a >>> hotel room, in a car or at the FBO. I rarely use FBO flight >>> planning rooms or equipment. >>> >>> I learned the art of chart folding and pencil management flying >>> single pilot IFR without an AP. But since then I've gone paperless >>> with the iPad and Foreflight. No charts, no pencils, just a >>> subscription, a stylus for writing clearances on the Foreflight >>> scratch pad, and an iPhone running Foreflight for backup (the second >>> copy is part of the basic or pro Foreflight package). >>> >>> The key to making this work for me was a good mount. I built a >>> fiberglass center console that 1) houses a O2 bottle and 2) holds a >>> RAM mount for the iPad that puts it right under my right hand during >>> flight so it can be easily used. You can see it here Kitlog page of >>> console construction >>> <http://www.mykitlog.com/users/category.php?user=MauleDriver&project=224&category=8533> >>> (I really need a picture of it being used in the cockpit). I also >>> added a USB charging port which typically gets used for my wife's >>> phone. The iPad's capacity is equivalent to the 10's range. >>> >>> I don't know where the sweet spot is but the iPad with Foreflight >>> Pro or it's equivalent is a required part of my IFR flying. I do my >>> 'tactical' flying with my panel mounted EFISs but all planning, >>> what-ifs, thinking and re-orienting is done with the iPad. >>> Geo-referenced taxi diagrams is almost worth the price if you fly >>> into a lot of new-to-you larger airports. It's a fair price for a >>> whole lot of benefit. It's a game changer, a drooler, a "I'll never >>> go back" kind of tool. >>> >>> Looking at the bigger picture, portables enable us to keep our >>> cockpits current at a much more reasonable cost than a panel >>> upgrade. My panel was set in stone in late 2008. A lot has >>> happened since then. While software upgrades to my EFIS and other >>> components have helped keep them somewhat current, we rely on the >>> portable to get the latest functions implemented in the best >>> possible ways, e.g. touch screen functionality, faster processors, >>> higher resolution screens. None of these are 'must haves' but they >>> are very very nice to haves and they are available for a fraction of >>> the cost of panel upgrades. >>> >>> On 5/9/2015 10:46 AM, kearney wrote: >>> ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Subject: Tech in the front office
Date: May 11, 2015
I fully agree with Bill=99s statement on having what you need on the EFIS display. Attached is a screen shoot taken on an IFR trip from Macon Georgia back to Fredericksburg Virginia with a lot of navigating around a stalled weather line. While it is possible to do all this on an iPad, I would not want to do this with the iPad as the primary information integration tool. Note =93 I normally have the engine data on the other display. I added it to the primary display only to get everything on one screen shoot. Typical set up is to have moving map and PDF on the pilot side EFIS, engine display with IFR/VFR chart or approach plate on the co-pilot EFIS. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Monday, May 11, 2015 10:49 AM Subject: Re: RV10-List: Tech in the front office Yes, that's what I meant. Whether the reasons are due to business relationships or conservatism/stability, I have seen no indication that there is any plan to link Navworx/ADSB Wx and traffic with Foreflight. I'm sure it wouldn't hurt to continue to make noise about it. OTOH, while it would be real nice to display at least Navworx generated Nexrad imagery on Foreflight, I don't really miss it. I try to keep my eyeballs on the EFIS displays as much as possible. In VMC conditions it keeps my eyes closer to looking outside. In IMC it keeps my eyes on what needs to be scanned to keep the airplane upright even if I let Tiger do most of the flying. So the first priority is having as much information as possible displayed on the panel mounted EFISs including weather and traffic. The iPad is for planning and what-ifs. For example, the iPad map is always 'north up', the EFIS map is always heading up. I never skew the map display on the EFIS but constantly skew it on the iPad. I've spent zero time checking out the AI and Syn Vision functions on Foreflight (I don't think I have everything it takes to enable them). My primary and backup instruments are all panel mounted. That is, if the stuff hits the fan I want everything I need on the installed panel. Then I'm sure it would be nice to have the iPad to help out if available. My primary wish list involves upgraded EFISs for faster processors and higher resolution displays so that things like plate overlays would work satisfactorily. Upgraded GRT units are available but would require more panel reengineering than is justified right now. That makes the iPad, and in my case Foreflight, the sweet spot for investments. But having had my initial IFR flying done with a six pack sans AP, my GRT/Garmin/Trutrak panel continues to be wonderful and surprising.... the first time I saw some crossing traffic whiz by on my synthetic visions display, I had to chuckle. I didn't know it would do that! That was almost as good as sitting in my half built fuselage after upgrading my GRTs with Synthetic Vision... sitting in a windowless hangar, I powered it up and all of a sudden a picture of the runway and lake outside appeared on the screens! Oh Yeah!! Bill "think I'm going to Pittsburgh later today to see my Mom" Watson On 5/10/2015 6:19 PM, Bob Leffler wrote: Bill is partially correct. I doubt that Foreflight will ever support NavWorx. Now if you want to use WingX or another application, it shouldn't be a problem. Sent from my iPad On May 10, 2015, at 5:14 PM, Tim Olson wrote: Why do you say the NavWorX will never be able to be hooked to your iPad? I'm assuming you just have it connected to the GRT via RS232. If so, you can just split the TX wire and send it to the Wifi adapter. It should easily be able to do both GRT and iPad. Tim On May 10, 2015, at 3:58 PM, Bill Watson wrote: I have an iPad running Foreflight pro with the Bad Elf GPS puck (my original iPad was wifi only so it required a separate GPS puck, my current iPad has the internal GPS but I still use the puck). I have a separate Navworx ADSB receiver that will never be able to be linked to my iPad - so no weather or traffic is displayed on the iPad. Instead I look to my primary EFIS displays (Grand Rapids HXs) for weather and traffic overlayed on the navigation screens. The iPad is a supplement... but a drool worthy one that I don't leave home without. I file and fly IFR on practically every flight. Flight planning and filing is done on the iPad using Foreflight. Every base is well covered by Foreflight and it still manages to delight when I need something new like filing an ICAO flight plan for an international flight to the Bahamas. Often the planning and filing is done in a hotel room, in a car or at the FBO. I rarely use FBO flight planning rooms or equipment. I learned the art of chart folding and pencil management flying single pilot IFR without an AP. But since then I've gone paperless with the iPad and Foreflight. No charts, no pencils, just a subscription, a stylus for writing clearances on the Foreflight scratch pad, and an iPhone running Foreflight for backup (the second copy is part of the basic or pro Foreflight package). The key to making this work for me was a good mount. I built a fiberglass center console that 1) houses a O2 bottle and 2) holds a RAM mount for the iPad that puts it right under my right hand during flight so it can be easily used. You can see it here Kitlog page of console construction <http://www.mykitlog.com/users/category.php?user=MauleDriver&project= 224&category=8533> (I really need a picture of it being used in the cockpit). I also added a USB charging port which typically gets used for my wife's phone. The iPad's capacity is equivalent to the 10's range. I don't know where the sweet spot is but the iPad with Foreflight Pro or it's equivalent is a required part of my IFR flying. I do my 'tactical' flying with my panel mounted EFISs but all planning, what-ifs, thinking and re-orienting is done with the iPad. Geo-referenced taxi diagrams is almost worth the price if you fly into a lot of new-to-you larger airports. It's a fair price for a whole lot of benefit. It's a game changer, a drooler, a "I'll never go back" kind of tool. Looking at the bigger picture, portables enable us to keep our cockpits current at a much more reasonable cost than a panel upgrade. My panel was set in stone in late 2008. A lot has happened since then. While software upgrades to my EFIS and other components have helped keep them somewhat current, we rely on the portable to get the latest functions implemented in the best possible ways, e.g. touch screen functionality, faster processors, higher resolution screens. None of these are 'must haves' but they are very very nice to haves and they are available for a fraction of the cost of panel upgrades. On 5/9/2015 10:46 AM, kearney wrote: ________________________________________________________________________________
Date: May 11, 2015
I agree 100%. Having it on the EFIS is the only way to go. That said, having it ALSO on an ipad isn't a bad idea, if you have the capability. It can't hurt...you can always turn it off. In my case, the ipad apps display more of the data types than the EFIS does, and, if you use it for charts, it does actively put the TFR's on the ipad then too, so at least WHEN you look at the ipad, you have the data you need. Tim On 5/11/2015 10:37 AM, Carl Froehlich wrote: > I fully agree with Bills statement on having what you need on the EFIS > display. > > Attached is a screen shoot taken on an IFR trip from Macon Georgia back > to Fredericksburg Virginia with a lot of navigating around a stalled > weather line. While it is possible to do all this on an iPad, I would > not want to do this with the iPad as the primary information integration > tool. > > Note I normally have the engine data on the other display. I added it > to the primary display only to get everything on one screen shoot. > Typical set up is to have moving map and PDF on the pilot side EFIS, > engine display with IFR/VFR chart or approach plate on the co-pilot EFIS. > > Carl > ________________________________________________________________________________
Date: May 11, 2015
I agree with Tim, great to also have all the info on the ipad. I use the ipad to look forward when in cruse while keeping my EFIS in the normal flight range. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, May 11, 2015 10:27 AM Subject: Re: RV10-List: Tech in the front office I agree 100%. Having it on the EFIS is the only way to go. That said, having it ALSO on an ipad isn't a bad idea, if you have the capability. It can't hurt...you can always turn it off. In my case, the ipad apps display more of the data types than the EFIS does, and, if you use it for charts, it does actively put the TFR's on the ipad then too, so at least WHEN you look at the ipad, you have the data you need. Tim On 5/11/2015 10:37 AM, Carl Froehlich wrote: > I fully agree with Bills statement on having what you need on the > EFIS display. > > Attached is a screen shoot taken on an IFR trip from Macon Georgia > back to Fredericksburg Virginia with a lot of navigating around a > stalled weather line. While it is possible to do all this on an iPad, > I would not want to do this with the iPad as the primary information > integration tool. > > Note I normally have the engine data on the other display. I added > it to the primary display only to get everything on one screen shoot. > Typical set up is to have moving map and PDF on the pilot side EFIS, > engine display with IFR/VFR chart or approach plate on the co-pilot EFIS. > > Carl > ________________________________________________________________________________
Date: May 11, 2015
Also, being able to get all the latest airport information via the ADS-B is great. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Sent: Monday, May 11, 2015 10:39 AM Subject: RE: RV10-List: Tech in the front office I agree with Tim, great to also have all the info on the ipad. I use the ipad to look forward when in cruse while keeping my EFIS in the normal flight range. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Monday, May 11, 2015 10:27 AM Subject: Re: RV10-List: Tech in the front office I agree 100%. Having it on the EFIS is the only way to go. That said, having it ALSO on an ipad isn't a bad idea, if you have the capability. It can't hurt...you can always turn it off. In my case, the ipad apps display more of the data types than the EFIS does, and, if you use it for charts, it does actively put the TFR's on the ipad then too, so at least WHEN you look at the ipad, you have the data you need. Tim On 5/11/2015 10:37 AM, Carl Froehlich wrote: > I fully agree with Bills statement on having what you need on the > EFIS display. > > Attached is a screen shoot taken on an IFR trip from Macon Georgia > back to Fredericksburg Virginia with a lot of navigating around a > stalled weather line. While it is possible to do all this on an iPad, > I would not want to do this with the iPad as the primary information > integration tool. > > Note I normally have the engine data on the other display. I added > it to the primary display only to get everything on one screen shoot. > Typical set up is to have moving map and PDF on the pilot side EFIS, > engine display with IFR/VFR chart or approach plate on the co-pilot EFIS. > > Carl > ________________________________________________________________________________
Date: May 11, 2015
I also agree with having the info up on the panel, especially for traffic. For traffic you need to look every few minutes (or hear it - GRT now has audio alerts), and that's too much head-down time if you're vfr and have an iPad on your lap. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442027#442027 ________________________________________________________________________________
Date: May 14, 2015
Subject: CSC / Lockheed get DUATS contract
I know, it's not RV-10 related, but we did talk about the topic a little a few years ago. So Lockheed and Computer Sciences Corporation (CSC) won the contract to provide DUATS. If you remember, CSC is somehow tied to the makers of FlightPrep, who are the ones who went around suing everyone who was making online flight planners. DTC was the "good" one, but they are now out after 25 years of doing it. Lockheed has it's own system in place. Users have a 60-day transition time to switch to the new providers. http://www.flyingmag.com/technique/flight-planning/lockheed-and-csc-offer-duats?cmpid=enews051415&spPodID=030&spMailingID=22653172&spUserID=NDc4NjE3MTE3OQS2&spJobID=561343644&spReportId=NTYxMzQzNjQ0S0 I know which one *I* will use....definitely not one provided by the lawsuit happy corp. It should also be noted that I believe a while back, foreflight started working to directly interact with Lockheed Martin for flight plan filing. If I remember right, you just have to clear out your DUATS info and then it will use Lockheed. At the time, they said it was better and faster anyway. So I did that and haven't looked back. I just thought I'd provide that food for thought as you all go about tweaking your iPads and devices with the new account settings. I'll have to even doublecheck what WingX and FlyQ use, but hopefully everyone will have whatever app updates are required so that we can file through L.M. and can skip anything to do with CSC. Yes, when a company acts like they did, I hold a grudge. Forever. :) Tim ________________________________________________________________________________
Date: May 14, 2015
Subject: Odyssey optimal charge voltage
Just wondering if anyone has researched what optimal alternator setting should be using the Odyssey 925L battery? Whether it should be different than the old wet cell set point between 13.8 and 14.2. ________________________________________________________________________________
Subject: Trutrak ADI W/GPS for sale
Date: May 14, 2015
I just installed my new Gimini and I am selling my ADI. It is in good shape. Trutrak worked on it in May 2103. Price is $450 including Two Day FedEx shipping. It will go on Ebay for $495 next week. Ebay wants 10,-12% out of the deal. Price for new is $1400 from Aircraft Spruce. Thanks. Rob ________________________________________________________________________________
Subject: Re: Odyssey optimal charge voltage
Date: May 14, 2015
Based on how my Odyssey branded charger works, I'd guess that the answer is i t depends. If I rub my batteries down to 10-11.5 volts, I will see the charger hit them with nearly 17 over a short period of time. In a matter of minutes I can b ring a dead battery to 80% charged. Then I see it taper off to 13.8 at the tail end of the charge after the batt ery has already taken the bulk of the charge. Then I see the battery settle in around 13.6-13.7. So based on my observations of their charger, is say 13.8 is a very safe opt ion. Phil Sent from my iPhone > On May 14, 2015, at 3:41 PM, Kelly McMullen wrote: > > Just wondering if anyone has researched what optimal alternator setting sh ould be using the Odyssey 925L battery? Whether it should be different than t he old wet cell set point between 13.8 and 14.2. > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: May 14, 2015
I have an Odyssey brand charger for my 925. According to the documentation, it initially charges at 14.3-14.7 volts (give or take) until the battery is charged. Then it goes to the trickle charge mode at 13.6-13.8 volts (give or take). It can be left in the trickle charge mode indefinitely, according to the manual. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442122#442122 ________________________________________________________________________________
Date: May 14, 2015
It is that charge phase that had me thinking that the alternator regulator might need to be set above 14.2. On Thu, May 14, 2015 at 7:27 PM, dmaib(at)me.com wrote: > > I have an Odyssey brand charger for my 925. According to the > documentation, it initially charges at 14.3-14.7 volts (give or take) until > the battery is charged. Then it goes to the trickle charge mode at > 13.6-13.8 volts (give or take). It can be left in the trickle charge mode > indefinitely, according to the manual. > > -------- > David Maib > RV-10 #40559 > New Smyrna Beach, FL > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442122#442122 > > ________________________________________________________________________________
Date: May 15, 2015
I can tell you a stock Plane Power alternator works just fine with Odyssey batteries. At full charge the buss voltage is 14.2 vdc. I=99ve used this set up for over a decade (two Odyssey PC-625 battery system) without any issues. As these batteries maintain 90% of their charge over six months I find no need to ever put a charger on the batteries unless I=99m doing extended panel powered up stuff. Even then I put a charger on with a volt meter and monitor to remove the charger once terminal voltage gets to 14.2 or so. Leaving a standard battery charger on a Odyssey battery is a good way to trash it as battery terminal voltage will rapidly rise above 15vdc once you get pass 14.2vdc. At that point you are generating heat and hydrogen. If you really must put a charger on it then get the Odyssey charger =93 then consider not using it unless you have good reason. I change out one battery every two years as a routine maintenance item (so neither battery is more than four years old). The pulled batteries provide another four years or so of service in various tractors here at the airpark. The only battery issue I had was when I left one of the master switches on. While you might be able to beat a flat battery back to life assume the damage will significantly degrade battery amp/hr capacity and replace it. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Thursday, May 14, 2015 11:20 PM Subject: Re: RV10-List: Re: Odyssey optimal charge voltage It is that charge phase that had me thinking that the alternator regulator might need to be set above 14.2. On Thu, May 14, 2015 at 7:27 PM, dmaib(at)me.com wrote: I have an Odyssey brand charger for my 925. According to the documentation, it initially charges at 14.3-14.7 volts (give or take) until the battery is charged. Then it goes to the trickle charge mode at 13.6-13.8 volts (give or take). It can be left in the trickle charge mode indefinitely, according to the manual. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442122#442122 -List" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 15, 2015
From: David Clifford <davidsoutpost(at)comcast.net>
I concur with Carl here about placing the Odyssey batteries on a charger. I have a PC625 I placed in my wave runner about 15 years ago and its still g oing strong. I don't even bother charging it up at the beginning of the sea son. Its always ready to go. I also have them in lawn equipment. Same thing with no issues. My buddy uses PC625's in his Cozy MKIV. He used to keep th e Odyssey charger plugged in when the plane was parked. Batteries were toas ted in 2 years. I have dual 680's in my -10 and only place a charger on it when doing avionics work in the hanger. As soon as the green "charged" ligh t comes on, it gets disconnected. David Clifford N646RV ----- Original Message ----- From: "Carl Froehlich" <carl.froehlich(at)verizon.net> Sent: Friday, May 15, 2015 9:17:11 AM Subject: RE: RV10-List: Re: Odyssey optimal charge voltage I can tell you a stock Plane Power alternator works just fine with Odyssey batteries. At full charge the buss voltage is 14.2 vdc. I=99ve used this set up for over a decade (two Odyssey PC-625 battery system) without any issues. As these batteries maintain 90% of their charg e over six months I find no need to ever put a charger on the batteries unl ess I=99m doing extended panel powered up stuff. Even then I put a ch arger on with a volt meter and monitor to remove the charger once terminal voltage gets to 14.2 or so. Leaving a standard battery charger on a Odyssey battery is a good way to trash it as battery terminal voltage will rapidly rise above 15vdc once you get pass 14.2vdc. At that point you are generati ng heat and hydrogen. If you really must put a charger on it then get the O dyssey charger =93 then consider not using it unless you have good re ason. I change out one battery every two years as a routine maintenance item (so neither battery is more than four years old). The pulled batteries provide another four years or so of service in various tractors here at the airpark . The only battery issue I had was when I left one of the master switches o n. While you might be able to beat a flat battery back to life assume the d amage will significantly degrade battery amp/hr capacity and replace it. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of Kelly McMullen Sent: Thursday, May 14, 2015 11:20 PM Subject: Re: RV10-List: Re: Odyssey optimal charge voltage It is that charge phase that had me thinking that the alternator regulator might need to be set above 14.2. On Thu, May 14, 2015 at 7:27 PM, dmaib(at)me.com < dmaib(at)me.com > wrote: I have an Odyssey brand charger for my 925. According to the documentation, it initially charges at 14.3-14.7 volts (give or take) until the battery i s charged. Then it goes to the trickle charge mode at 13.6-13.8 volts (give or take). It can be left in the trickle charge mode indefinitely, accordin g to the manual. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442122#442122 =========== -List" target="_blank"> http://www.matronics.com/Navigator?RV10-List =========== FORUMS - _blank"> http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank"> http://www.matronics.com/contribution =========== http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com http://www.matronics.com/contribution === ________________________________________________________________________________
Date: May 15, 2015
When I spoke with technical support at odyssey, they recommended charging both the 680 and 925 batteries at a nominal voltage of 14.4-14.5 volts. Unfortunately, if you have the plane power alternator, with th internal VR the only way to increase the charging voltage is to add resistance in the field line going to the alternator. The PP alternator uses the field line to sense the charge voltage. What I did was to use a #20 gauge wire to feed the field voltage. More than sufficient to carry the 5 amp load, but small enough diameter to create a slight voltage drop. I charge at 14.5 volts. Almost 3 years and 380 hours, and still going strong. Will 14.2 volts work? Probably -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442146#442146 ________________________________________________________________________________
Date: May 16, 2015
Subject: Cabin Cover Fit
Hey all - I am new to forum and I have been hesitant to post as I have been able to find most of answers by looking at past posts or talking to my EAA tech counselor, but I haven't found a good answer yet to my latest concern. The build has gone great, but the cabin top has given my some problems. I spent a lot of time getting it to fit and now that finally got it to slide into place I have a gap problem - see pics. I assume I can add resin with some filler to fill in gap and re-sand to fit, but my concern is that I have a tight fit already and I think is has somewhat do with head of universal rivets in door opening of fuselage, but then again I see other builders with a better fit. Any suggestions on how to proceed? Matt ________________________________________________________________________________
Subject: Re: Cabin Cover Fit
Date: May 16, 2015
We usually lay in a fairly healthy head of medium thickness flox before sett ing in the cabin top so it fills any voids like that. After we tighten all t he screws we make sure to remove any excess before it cures. A tight and cle an trim is the best way to achieve a good fit, but the flox helps in areas t hat don't fit as well. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 16, 2015, at 9:06 PM, Matthew Healy wrote: > > Hey all - I am new to forum and I have been hesitant to post as I have bee n able to find most of answers by looking at past posts or talking to my EAA tech counselor, but I haven't found a good answer yet to my latest concern. > > The build has gone great, but the cabin top has given my some problems. I s pent a lot of time getting it to fit and now that finally got it to slide in to place I have a gap problem - see pics. I assume I can add resin with some filler to fill in gap and re-sand to fit, but my concern is that I have a t ight fit already and I think is has somewhat do with head of universal rivet s in door opening of fuselage, but then again I see other builders with a be tter fit. Any suggestions on how to proceed? > > Matt > > > ________________________________________________________________________________
Date: May 16, 2015
I do not recall the fiberglass resting on any AN470 heads. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442179#442179 ________________________________________________________________________________
Subject: Re: Fuel injection servo attachment - concerned ?
Date: May 17, 2015
I have the Van's Lycoming IO-540 and am ready to attach the fuel servo to the engine, but cannot find any instructions or hardware. Only the nuts and plain washers holding the plastic "preservation" cover plate on the sump together with a blind gasket were supplied with the engine & servo. Lycoming Service Instruction 1484C gives the torques to "refer to the Parts Catalogue for the correct washers, lock washers, nuts, gaskets and spacers" Can anyone provide a copy of the relevant page in the Lycoming parts catalogue? Assuming a gasket is required, is it normal to use one both above and below the control cable bracket? Gordon Anderson Switzerland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442185#442185 ________________________________________________________________________________
Date: May 17, 2015
You want a gasket on both sides of the bracket and you want lock washers under the nuts holding the servo on. The hardware, IIRC, should have been included with the FWF kit. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 17, 2015, at 5:12 AM, Gordon Anderson wrote: > > > I have the Van's Lycoming IO-540 and am ready to attach the fuel servo to the engine, but cannot find any instructions or hardware. Only the nuts and plain washers holding the plastic "preservation" cover plate on the sump together with a blind gasket were supplied with the engine & servo. > > Lycoming Service Instruction 1484C gives the torques to "refer to the Parts Catalogue for the correct washers, lock washers, nuts, gaskets and spacers" > > Can anyone provide a copy of the relevant page in the Lycoming parts catalogue? > > Assuming a gasket is required, is it normal to use one both above and below the control cable bracket? > > Gordon Anderson > Switzerland > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442185#442185 > > > > > > > > > > ________________________________________________________________________________
Date: May 17, 2015
You might want to look again. Hardware and gaskets should be in a bag that came with the engine. If it is not there give Van's a call. Yes - a gasket goes on each side of the control cable bracket. If memory serves, the bracket came with a gasket. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Gordon Anderson Sent: Sunday, May 17, 2015 5:13 AM Subject: RV10-List: Re: Fuel injection servo attachment - concerned ? I have the Van's Lycoming IO-540 and am ready to attach the fuel servo to the engine, but cannot find any instructions or hardware. Only the nuts and plain washers holding the plastic "preservation" cover plate on the sump together with a blind gasket were supplied with the engine & servo. Lycoming Service Instruction 1484C gives the torques to "refer to the Parts Catalogue for the correct washers, lock washers, nuts, gaskets and spacers" Can anyone provide a copy of the relevant page in the Lycoming parts catalogue? Assuming a gasket is required, is it normal to use one both above and below the control cable bracket? Gordon Anderson Switzerland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442185#442185 ________________________________________________________________________________
Date: May 18, 2015
Hey, by chance do you have the QB fuselage? If so, go back through the plans and you will find that those AN470 rivets that are in the way are REALLY supposed to be AN426 flush rivets. I had this same issue and it literally took more than an hour to find it in the plans. There should be NO AN470 rivet heads protruding in the area where the cabin top sit in the fuselage sides. I think it was about 8 rivets, four on each side. They were pretty easy to drill out, dimple, and replace with AN426 rivets... It is one of the issues I found with the QB kits... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442230#442230 ________________________________________________________________________________
Date: May 18, 2015
I do have a QB fuse and indeed the 426 rivets are placed in error. That is why Bob doesn't remember having them there. So now that I have already trimmed to much and cannot get it to clamp flush in sides of door opening (sits flush on bottom) how should I proceed. Obviously replace rivets, but then what do you think. Epoxy resin with flox and re-sand to fit? If so, will it adhere and be strong enough? This is one of many problems I have had with QB fuse, just didn't catch this one early enough- wish I would have just build it myself Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442247#442247 ________________________________________________________________________________
Date: May 18, 2015
Yes, like Jesse mentioned, apply flox and bolt it down. It's a pain to sand, so don't got crazy with the flox. I got mine to fit pretty good. I used flox to fill in the door bottom on the interior then added micro as a top coat and to fill in all the imperfections around the edges. Sent from my iPhone On May 18, 2015, at 1:41 PM, mhealydds wrote: I do have a QB fuse and indeed the 426 rivets are placed in error. That is why Bob doesn't remember having them there. So now that I have already trimmed to much and cannot get it to clamp flush in sides of door opening (sits flush on bottom) how should I proceed. Obviously replace rivets, but then what do you think. Epoxy resin with flox and re-sand to fit? If so, will it adhere and be strong enough? This is one of many problems I have had with QB fuse, just didn't catch this one early enough- wish I would have just build it myself Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442247#442247 ________________________________________________________________________________
Date: May 18, 2015
This is a single step fix after you replace the rivets. Apply a liberal amount of flox, install the cabin top, clean up the excess flox once the top is seated (and before it sets) and insert the bolts. Remember to not tighten the bolts all the way until after the flox sets so you don't deform the cabin top. As you will have a lot of flox to fill the gaps, check that the sides and bottom are straight as you go. Once this is done the top is there forever so don't scrimp on the flox. It is much easier to clean up the flox as you go then to try to fill voids after the top is on. The flox should not be too runny or dry. Something on the wet side of cake frosting. When done there a several options to fill in the door bottom. On Van's demo plane they used a piece of wood. The attached photos show how I added some rigid foam and then 8 bids or so of glass over the top and down the inside to aluminum. Some micro, sanding and ready for paint. The last two photos show how I back fitted the aftermarket door cam lock. I suspect this turned out easier than trying to glass around it. What would we do without Dremel tools? Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Monday, May 18, 2015 2:01 PM Subject: Re: RV10-List: Re: Cabin Cover Fit Yes, like Jesse mentioned, apply flox and bolt it down. It's a pain to sand, so don't got crazy with the flox. I got mine to fit pretty good. I used flox to fill in the door bottom on the interior then added micro as a top coat and to fill in all the imperfections around the edges. Sent from my iPhone On May 18, 2015, at 1:41 PM, mhealydds wrote: I do have a QB fuse and indeed the 426 rivets are placed in error. That is why Bob doesn't remember having them there. So now that I have already trimmed to much and cannot get it to clamp flush in sides of door opening (sits flush on bottom) how should I proceed. Obviously replace rivets, but then what do you think. Epoxy resin with flox and re-sand to fit? If so, will it adhere and be strong enough? This is one of many problems I have had with QB fuse, just didn't catch this one early enough- wish I would have just build it myself Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442247#442247 ________________________________________________________________________________
Date: May 18, 2015
I'd consider rubbing a mold release all over the aluminum and then bolting it into place with a handful of shims to fill the gap. This means the shims would be the same width as an AN470 head rivet it tall. That would locate the cabin time in the correct position. With it in that position, I'd then squeeze some epoxy/flox into the gap where the shims are between the aluminum and the cabin top. You can use a large syringe to pack the flox way back into the gap first and then fill until you get the the outer edge. Wipe the excess away. Once it has cured, you can tap the shims out and fill the hole where the shims were the same way. Once that has cured, you can take the cabin top off and inspect it to make sure there are no voids and if there are then you can just fill them to match while it's off. You will end up with the most perfectly fit cabin top of the group that way. You're basically using your airframe as a mold and building the cabin top to fit it perfectly. Phil On Mon, May 18, 2015 at 1:01 PM, Bob Leffler wrote: > > Yes, like Jesse mentioned, apply flox and bolt it down. It's a pain to > sand, so don't got crazy with the flox. > > I got mine to fit pretty good. I used flox to fill in the door bottom on > the interior then added micro as a top coat and to fill in all the > imperfections around the edges. > > Sent from my iPhone > > On May 18, 2015, at 1:41 PM, mhealydds wrote: > > > I do have a QB fuse and indeed the 426 rivets are placed in error. That is > why Bob doesn't remember having them there. So now that I have already > trimmed to much and cannot get it to clamp flush in sides of door opening > (sits flush on bottom) how should I proceed. Obviously replace rivets, but > then what do you think. Epoxy resin with flox and re-sand to fit? If so, > will it adhere and be strong enough? > > This is one of many problems I have had with QB fuse, just didn't catch > this one early enough- wish I would have just build it myself > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442247#442247 > > ________________________________________________________________________________
Date: May 18, 2015
Boy, I dunno if I would try to remove the top after the epoxy has set, even WITH mold release. With the imperfect surfaces of the cabin top, I would think that you would damage it trying to remove it with the perfect fit you created. Unfortunately, you would then be stuck with a cabin top that is not bonded to the surrounding epoxy due to the mold release, and no good way to remove it without breaking it. Make sure the cabin top is in the right position and fill'r'up with flox...then tighten the bolts when flox is cured... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442263#442263 ________________________________________________________________________________
Date: May 18, 2015
So my concern with this approach is that will I have a problem clamping cabin cover to fuselage to match drill bolt holes with that large of a gap. You are saying just not worry about gap until final seating and they secure with flox an not try to build up prior to final seating? Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442266#442266 ________________________________________________________________________________
Date: May 18, 2015
Sorry just saw post about using mold release before final seating before posting last reply. Any thoughts what would be better? Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442267#442267 ________________________________________________________________________________
Date: May 18, 2015
I am certainly no fiberglass expert, but I'd be tempted to lay down a couple of layers of fiberglass/epoxy on the bottom of the top, where, you've sanded too far, to minimize how much flox you need to fill the gap. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442268#442268 ________________________________________________________________________________
Date: May 18, 2015
It also bears repeating Vans' instructions: QB builders must go thru the non-QB instructions carefully (takes several hours!) to see where the "pro" guys screwed up. Guaranteed you'll find a few things that need to be addressed. My QB fuel tanks were installed with bolts one size too long, with a stack of washers under each to make them fit! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442269#442269 ________________________________________________________________________________
Date: May 18, 2015
By the way, the lower or bottom portion seats fine, just sides, attached better pictures Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442270#442270 Attachments: http://forums.matronics.com//files/img_1027_173.jpg http://forums.matronics.com//files/img_1028_181.jpg ________________________________________________________________________________
Date: May 18, 2015
I thought I went through the QB kit pretty well, found lots of errors actually (to the point that I am not sure I would even recommend a QB fuse kit), guess checking the head style of every rivet was not something I got into. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442271#442271 ________________________________________________________________________________
Date: May 18, 2015
Not to go against the trend.....but why take our the 470's. If you have it fitting....already cut the top....then just leave the "wrong" rivets in and flox around them. Will help keep everything lined up and the will not affect the structure. Drilling out the rivets and putting in new rivets only increases the risk of messing something up. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of mhealydds Sent: Monday, May 18, 2015 3:13 PM Subject: RV10-List: Re: Cabin Cover Fit By the way, the lower or bottom portion seats fine, just sides, attached better pictures Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442270#442270 Attachments: http://forums.matronics.com//files/img_1027_173.jpg http://forums.matronics.com//files/img_1028_181.jpg ________________________________________________________________________________
Date: May 18, 2015
I agree with Rene. If it fits, don't bother drilling out those rivets. I would lay a thick layer of flox or milled fiber filler between the top and the fuse to fill the gap before drilling for the attach screws. The problem with a release in an area like that is some resin will inevitably seep into some cavity or female section that makes it very difficulty to remove. It can be done with a lot of prep and forethought but it wouldn't be worth it. Filling will work just fine. Keep it a little "below grade" to reduce having to remove cured material--you can always bodywork it for cosmetics afterward. Once the top is on, it's an integral part of the fuselage. Taking it off in the future might be possible but you'd need a really good reason. --Dave On Mon, May 18, 2015 at 2:41 PM, Rene wrote: > > Not to go against the trend.....but why take our the 470's. If you have it > fitting....already cut the top....then just leave the "wrong" rivets in and > flox around them. Will help keep everything lined up and the will not > affect the structure. Drilling out the rivets and putting in new rivets > only increases the risk of messing something up. > > Rene' > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of mhealydds > Sent: Monday, May 18, 2015 3:13 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Re: Cabin Cover Fit > > > By the way, the lower or bottom portion seats fine, just sides, attached > better pictures > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442270#442270 > > > Attachments: > > http://forums.matronics.com//files/img_1027_173.jpg > http://forums.matronics.com//files/img_1028_181.jpg > > ________________________________________________________________________________
Subject: Gust Lock - Redux
Date: May 20, 2015
Hi A few weeks ago I inquired about gust locks. Most of the "commercial" options didn't appeal. The one that did appeal never responded to my email query so I decided to see what I could do on my own. Most "commercial" options consisted of pushing the rudder pedals forward. Given that I had an open bolt hole at the bottom of the firewall, I decided to install an eyeball bolt and use that, in conjunction with a carabiner / strap / shock cord to pull the pedals forward. I felt this was a better option. My Grimstad rudder peals have a hollow tube that allowed me to insert a wooden down between them. This was pulled forward by a strap threaded through the carabiner. Two shock cords put tension on the straps so that the pedals stay forward and the rudder centered. I attached the other end of the shock cords to the outboard gear mount tube that is just in front of the pilot's seat. The advantage of the shock cords is that it will allow the rudder to move under to pressure - but not too much. The rudder never comes in contact with the stops nor are the cables ever out if tension so that that rudder flops around. All told, this could be duplicated for under $10. I expect something similar could be done with stock pedals. I plan to tinker a bit more with this but don't expect the basic design to change. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442391#442391 Attachments: http://forums.matronics.com//files/img_4002_115.jpg http://forums.matronics.com//files/img_4001_138.jpg http://forums.matronics.com//files/img_3996_383.jpg http://forums.matronics.com//files/img_3995_147.jpg ________________________________________________________________________________
Subject: rudder lock
Date: May 21, 2015
This is my rudder gust lock. I machined a part that bolts to the aft bulkhead/vertical stab spar assembly. The eye-bolts protrude thru the skin and there will be pins that lock the rudder in neutral position when installed. Chris Hukill waiting for the FAA to bless me for flight ________________________________________________________________________________
Subject: Fwd: TAS Calculator.xlsx
Date: May 23, 2015
See below. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad Begin forwarded message: > From: Chris Golden <chris(at)blueones.com> > Date: May 23, 2015 at 3:36:21 PM EDT > To: Saint Jesse > Subject: TAS Calculator.xlsx > > Not sure if this is the one he is looking for, but it's what we used and s eemed about right. > > ________________________________________________________________________________
Subject: Re: Fwd: TAS Calculator.xlsx
Date: May 23, 2015
Thanks Jesse. I was looking for indicated airspeed calculation. I have two s ources of AS and they are 10+ kt different. Sent from my iPhone > On May 23, 2015, at 3:42 PM, Jesse Saint wrote: > > See below. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > Begin forwarded message: > >> From: Chris Golden <chris(at)blueones.com> >> Date: May 23, 2015 at 3:36:21 PM EDT >> To: Saint Jesse >> Subject: TAS Calculator.xlsx >> Not sure if this is the one he is looking for, but it's what we used and s eemed about right. > >> ________________________________________________________________________________
Date: May 23, 2015
I don't think you can very accurately calculate indicated airspeed. The bes t way to check that is on the bench. That's the reference for all the other s. If indicated is off, it's time to use the manometer and figure out which one is accurate. Tim > On May 23, 2015, at 2:55 PM, Flysrv10 wrote: > > Thanks Jesse. I was looking for indicated airspeed calculation. I have two sources of AS and they are 10+ kt different. > > Sent from my iPhone > >> On May 23, 2015, at 3:42 PM, Jesse Saint wrote: >> >> See below. >> >> Jesse Saint >> Saint Aviation, Inc. >> 352-427-0285 >> jesse(at)saintaviation.com >> >> Sent from my iPad >> >> Begin forwarded message: >> >>> From: Chris Golden <chris(at)blueones.com> >>> Date: May 23, 2015 at 3:36:21 PM EDT >>> To: Saint Jesse >>> Subject: TAS Calculator.xlsx >>> Not sure if this is the one he is looking for, but it's what we used and seemed about right. >> > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 23, 2015
Agreed..... Easy to do,,, Well tested and accepted data to derive an acc urate reading... http://www.rst-engr.com/rst/articles/KP89JUL.pdf Ben H aas N801BH www.haaspowerair.com ---------- Original Message ---------- From: Tim Olson <Tim(at)MyRV10.com> Subject: Re: RV10-List: Fwd: TAS Calculator.xlsx Date: Sat, 23 May 2015 17:39:09 -0500 I don't think you can very accurately calculate indicated airspeed. The best way to check that is on the bench. That's the reference for all t he others.If indicated is off, it's time to use the manometer and figure out which one is accurate.Tim On May 23, 2015, at 2:55 PM, Flysrv10 wrote: Thanks Jesse. I was looking for indicated airspeed calculation. I have t wo sources of AS and they are 10+ kt different. Sent from my iPhone On May 23, 2015, at 3:42 PM, Jesse Saint wrote : See below. Jesse SaintSaint Aviation, Inc.352-427-0285jesse(at)saintaviation.com Sent from my iPad Begin forwarded message: From: Chris Golden <chris(at)blueones.com> Date: May 23, 2015 at 3:36:21 PM EDT Subject: TAS Calculator.xlsx Not sure if this is the one he is looking for, but it's what we used an d seemed about right. D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3DList"">http://www.matronics.com/Navigator? RV10-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D//forums.matronics.comD=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dot;">http://www.matronics .com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ======================== ======================== ======================== ======================== ======================== ================= ____________________________________________________________ NetZero now offers 4G mobile broadband. Sign up now. http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1 ________________________________________________________________________________
Date: May 23, 2015
Here is a PDF file with a scale that translates inches of water to knots. This simple rig is very accurate. It also serves to find pitot/static leaks before you have the guy on the clock doing your biannual check. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben Sent: Saturday, May 23, 2015 7:44 PM Subject: Re: RV10-List: Fwd: TAS Calculator.xlsx Agreed..... Easy to do,,, Well tested and accepted data to derive an accurate reading... http://www.rst-engr.com/rst/articles/KP89JUL.pdf Ben Haas N801BH www.haaspowerair.com ---------- Original Message ---------- From: Tim Olson <Tim(at)MyRV10.com> Subject: Re: RV10-List: Fwd: TAS Calculator.xlsx Date: Sat, 23 May 2015 17:39:09 -0500 I don't think you can very accurately calculate indicated airspeed. The best way to check that is on the bench. That's the reference for all the others. If indicated is off, it's time to use the manometer and figure out which one is accurate. Tim On May 23, 2015, at 2:55 PM, Flysrv10 wrote: Thanks Jesse. I was looking for indicated airspeed calculation. I have two sources of AS and they are 10+ kt different. Sent from my iPhone On May 23, 2015, at 3:42 PM, Jesse Saint wrote: See below. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad Begin forwarded message: From: Chris Golden <chris(at)blueones.com> Date: May 23, 2015 at 3:36:21 PM EDT Subject: TAS Calculator.xlsx Not sure if this is the one he is looking for, but it's what we used and seemed about right. D======================== =================== List""> <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List D======================== =================== //forums.matronics.com D======================== =================== ot;"> <http://www.matronics.com/contribution> http://www.matronics.com/contribution D======================== =================== =================================== <http://www.matronics.com/Navigator?RV10-List> http://www.matronics.com/Navigator?RV10-List =================================== ronics.com =================================== <http://www.matronics.com/contribution> www.matronics.com/contribution =================================== ____________________________________________________________ NetZero now offers 4G mobile broadband. Sign up now. <http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1> ________________________________________________________________________________
Date: May 23, 2015
There are several programs available where you fly 3 different courses, note GPS ground speeds, and the program calculates True airspeed, with the assumption that the wind does not change while you make the measurements. Truth be told, you can do just as well by finding the wind direction (max ground speed), then do a 180 (minimum ground speed), and average the 2 numbers to get TAS. Note the pressure altitude and the OAT, pull out your E6B and change TAS into IAS. Water manometer is a good place to start, but it won't show static errors. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442512#442512 ________________________________________________________________________________
Date: May 24, 2015
I do a pitot /static test on every third transponder check.. ie, every s ix years.... The guy has the equipment already set up and it only adds 5 0 bucks to the bill... And his test rig is certified..... Well worth it to me... YMMV... Ben Haas N801BH www.haaspowerair.com ---------- Original Message ---------- From: "Bob Turner" <bobturner(at)alum.rpi.edu> Subject: RV10-List: Re: Fwd: TAS Calculator.xlsx Date: Sat, 23 May 2015 20:25:26 -0700 There are several programs available where you fly 3 different courses, note GPS ground speeds, and the program calculates True airspeed, with t he assumption that the wind does not change while you make the measureme nts. Truth be told, you can do just as well by finding the wind directio n (max ground speed), then do a 180 (minimum ground speed), and average the 2 numbers to get TAS. Note the pressure altitude and the OAT, pull o ut your E6B and change TAS into IAS. Water manometer is a good place to start, but it won't show static error s. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442512#442512 ======================== =========== ======================== =========== ======================== =========== ======================== =========== ____________________________________________________________ Old School Yearbook Pics View Class Yearbooks Online Free. Search by School & Year. Look Now! http://thirdpartyoffers.netzero.net/TGL3241/55614efe451544efe62e5st03duc ________________________________________________________________________________
Subject: New Aerosport Symmetrical Panel
Date: May 27, 2015
Hey guys, Just wanted to show off the redesigned AeroSport Symmetrical panel. This one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It also includes room for a 750 below the center screen, or like I chose to do, a 650, an audio panel, and the GMC305 AP controller. Because so much of the panel real estate is taken up with avionics, Aerosport designed a new center console mounted throttle quadrant. It sits right where your hand will naturally lay when you have your elbow on the center console. A few other interesting things: -With the G3X Touch screens, NO rib modification was necessary. A notch of about 2" was needed in the bottom of the sub-panel for the 650 in the location shown in the pictures. -There is a lip at the bottom of the center panel that is PERFECT as a "finger shelf" to brace your hands to operate the 305 AP panel in turbulence. Now I obviously haven't tested this out in the air, but from sitting in the garage, bouncing around making airplane noises, it worked great :) -------- Ed Kranz RV10 Finishing Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442593#442593 Attachments: http://forums.matronics.com//files/aerosport_render_146.jpg http://forums.matronics.com//files/hdr_panel_cropped_172.jpg ________________________________________________________________________________
Date: May 28, 2015
Subject: Re: New Aerosport Symmetrical Panel
Are you planning on a separate self-contained backup system? I ask because it doesn't look like there's much room left over for one. While you can protect against hardware failures with the multiple screens and ADAHRS/GPS receivers across the G3X complex, there's always the issue of a common software bug. I really like the idea of the console mounted quadrant. On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: > > Hey guys, > > Just wanted to show off the redesigned AeroSport Symmetrical panel. This > one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It also > includes room for a 750 below the center screen, or like I chose to do, a > 650, an audio panel, and the GMC305 AP controller. > > Because so much of the panel real estate is taken up with avionics, > Aerosport designed a new center console mounted throttle quadrant. It sits > right where your hand will naturally lay when you have your elbow on the > center console. > > A few other interesting things: > > -With the G3X Touch screens, NO rib modification was necessary. A notch of > about 2" was needed in the bottom of the sub-panel for the 650 in the > location shown in the pictures. > > -There is a lip at the bottom of the center panel that is PERFECT as a > "finger shelf" to brace your hands to operate the 305 AP panel in > turbulence. Now I obviously haven't tested this out in the air, but from > sitting in the garage, bouncing around making airplane noises, it worked > great :) > > -------- > Ed Kranz > RV10 > Finishing > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442593#442593 > > > Attachments: > > http://forums.matronics.com//files/aerosport_render_146.jpg > http://forums.matronics.com//files/hdr_panel_cropped_172.jpg > > ________________________________________________________________________________
Date: May 28, 2015
I keep going back and forth. I do want some sort of non-garmin backup PFD. RC Allen makes a nice 2.5" LCD attitude gauge that would fit to the left of my PFD1, but I'd want altitude and airspeed info as well. So far, I don't believe that anyone makes one that small, for a price I'm willing to pay. The Midcontinent SAM might fit there, but it's quite spendy. During the fly-off, I'm obviously day VFR, so I'm going to fly it as is... but I'll probably end up with a Dynon D1 either up on the glareshield or below the AP controller until someone comes out with a nice compact backup PFD. I've also considered some of the iPad based "PFDs"... which would probably be fine in the unlikely scenario that I'm in IMC and suffer a full 3 screen system failure... Enough to get me to VMC to get on the ground. But I'd prefer a real backup PFD. On Thu, May 28, 2015 at 10:21 AM, Berck E. Nash wrote: > Are you planning on a separate self-contained backup system? I ask > because it doesn't look like there's much room left over for one. While you > can protect against hardware failures with the multiple screens and > ADAHRS/GPS receivers across the G3X complex, there's always the issue of a > common software bug. I really like the idea of the console mounted > quadrant. > > On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: > >> >> Hey guys, >> >> Just wanted to show off the redesigned AeroSport Symmetrical panel. This >> one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It also >> includes room for a 750 below the center screen, or like I chose to do, a >> 650, an audio panel, and the GMC305 AP controller. >> >> Because so much of the panel real estate is taken up with avionics, >> Aerosport designed a new center console mounted throttle quadrant. It sits >> right where your hand will naturally lay when you have your elbow on the >> center console. >> >> A few other interesting things: >> >> -With the G3X Touch screens, NO rib modification was necessary. A notch >> of about 2" was needed in the bottom of the sub-panel for the 650 in the >> location shown in the pictures. >> >> -There is a lip at the bottom of the center panel that is PERFECT as a >> "finger shelf" to brace your hands to operate the 305 AP panel in >> turbulence. Now I obviously haven't tested this out in the air, but from >> sitting in the garage, bouncing around making airplane noises, it worked >> great :) >> >> -------- >> Ed Kranz >> RV10 >> Finishing >> >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=442593#442593 >> >> >> >> >> Attachments: >> >> http://forums.matronics.com//files/aerosport_render_146.jpg >> http://forums.matronics.com//files/hdr_panel_cropped_172.jpg >> >> >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > ________________________________________________________________________________
Date: May 28, 2015
I suppose there's room for 3 round gauges off to the left. Any idea if it's possible to move the center screen down so it's level with the others and put the GMC305 on top, or are the holes for the screens pre-cut? I'm rather used to the autopilot panel being top center... On Thu, May 28, 2015 at 9:36 AM, Ed Kranz wrote: > I keep going back and forth. I do want some sort of non-garmin backup PFD. > RC Allen makes a nice 2.5" LCD attitude gauge that would fit to the left of > my PFD1, but I'd want altitude and airspeed info as well. So far, I don't > believe that anyone makes one that small, for a price I'm willing to pay. > The Midcontinent SAM might fit there, but it's quite spendy. > > During the fly-off, I'm obviously day VFR, so I'm going to fly it as is... > but I'll probably end up with a Dynon D1 either up on the glareshield or > below the AP controller until someone comes out with a nice compact backup > PFD. > > I've also considered some of the iPad based "PFDs"... which would probably > be fine in the unlikely scenario that I'm in IMC and suffer a full 3 screen > system failure... Enough to get me to VMC to get on the ground. But I'd > prefer a real backup PFD. > > On Thu, May 28, 2015 at 10:21 AM, Berck E. Nash wrote: > >> Are you planning on a separate self-contained backup system? I ask >> because it doesn't look like there's much room left over for one. While you >> can protect against hardware failures with the multiple screens and >> ADAHRS/GPS receivers across the G3X complex, there's always the issue of a >> common software bug. I really like the idea of the console mounted >> quadrant. >> >> On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: >> >>> >>> Hey guys, >>> >>> Just wanted to show off the redesigned AeroSport Symmetrical panel. This >>> one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It also >>> includes room for a 750 below the center screen, or like I chose to do, a >>> 650, an audio panel, and the GMC305 AP controller. >>> >>> Because so much of the panel real estate is taken up with avionics, >>> Aerosport designed a new center console mounted throttle quadrant. It sits >>> right where your hand will naturally lay when you have your elbow on the >>> center console. >>> >>> A few other interesting things: >>> >>> -With the G3X Touch screens, NO rib modification was necessary. A notch >>> of about 2" was needed in the bottom of the sub-panel for the 650 in the >>> location shown in the pictures. >>> >>> -There is a lip at the bottom of the center panel that is PERFECT as a >>> "finger shelf" to brace your hands to operate the 305 AP panel in >>> turbulence. Now I obviously haven't tested this out in the air, but from >>> sitting in the garage, bouncing around making airplane noises, it worked >>> great :) >>> >>> -------- >>> Ed Kranz >>> RV10 >>> Finishing >>> >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=442593#442593 >>> >>> >>> >>> >>> Attachments: >>> >>> http://forums.matronics.com//files/aerosport_render_146.jpg >>> http://forums.matronics.com//files/hdr_panel_cropped_172.jpg >>> >>> >>> >>> >>> ========== >>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>> ========== >>> FORUMS - >>> _blank">http://forums.matronics.com >>> ========== >>> b Site - >>> -Matt Dralle, List Admin. >>> target="_blank">http://www.matronics.com/contribution >>> ========== >>> >>> >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: May 28, 2015
Per a discussion I had with Geoff a couple days ago, yes you can move the center screen down and fit the GMC-305 AP controller above it. Bob On Thu, May 28, 2015 at 11:04 AM, Berck E. Nash wrote: > I suppose there's room for 3 round gauges off to the left. Any idea if > it's possible to move the center screen down so it's level with the others > and put the GMC305 on top, or are the holes for the screens pre-cut? I'm > rather used to the autopilot panel being top center... > > On Thu, May 28, 2015 at 9:36 AM, Ed Kranz wrote: > >> I keep going back and forth. I do want some sort of non-garmin backup >> PFD. RC Allen makes a nice 2.5" LCD attitude gauge that would fit to the >> left of my PFD1, but I'd want altitude and airspeed info as well. So far, I >> don't believe that anyone makes one that small, for a price I'm willing to >> pay. The Midcontinent SAM might fit there, but it's quite spendy. >> >> During the fly-off, I'm obviously day VFR, so I'm going to fly it as >> is... but I'll probably end up with a Dynon D1 either up on the glareshield >> or below the AP controller until someone comes out with a nice compact >> backup PFD. >> >> I've also considered some of the iPad based "PFDs"... which would >> probably be fine in the unlikely scenario that I'm in IMC and suffer a full >> 3 screen system failure... Enough to get me to VMC to get on the ground. >> But I'd prefer a real backup PFD. >> >> On Thu, May 28, 2015 at 10:21 AM, Berck E. Nash wrote: >> >>> Are you planning on a separate self-contained backup system? I ask >>> because it doesn't look like there's much room left over for one. While you >>> can protect against hardware failures with the multiple screens and >>> ADAHRS/GPS receivers across the G3X complex, there's always the issue of a >>> common software bug. I really like the idea of the console mounted >>> quadrant. >>> >>> On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: >>> >>>> >>>> Hey guys, >>>> >>>> Just wanted to show off the redesigned AeroSport Symmetrical panel. >>>> This one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It >>>> also includes room for a 750 below the center screen, or like I chose to >>>> do, a 650, an audio panel, and the GMC305 AP controller. >>>> >>>> Because so much of the panel real estate is taken up with avionics, >>>> Aerosport designed a new center console mounted throttle quadrant. It sits >>>> right where your hand will naturally lay when you have your elbow on the >>>> center console. >>>> >>>> A few other interesting things: >>>> >>>> -With the G3X Touch screens, NO rib modification was necessary. A notch >>>> of about 2" was needed in the bottom of the sub-panel for the 650 in the >>>> location shown in the pictures. >>>> >>>> -There is a lip at the bottom of the center panel that is PERFECT as a >>>> "finger shelf" to brace your hands to operate the 305 AP panel in >>>> turbulence. Now I obviously haven't tested this out in the air, but from >>>> sitting in the garage, bouncing around making airplane noises, it worked >>>> great :) >>>> >>>> -------- >>>> Ed Kranz >>>> RV10 >>>> Finishing >>>> >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=442593#442593 >>>> >>>> >>>> >>>> >>>> Attachments: >>>> >>>> http://forums.matronics.com//files/aerosport_render_146.jpg >>>> http://forums.matronics.com//files/hdr_panel_cropped_172.jpg >>>> >>>> >>>> >>>> >>>> ========== >>>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> _blank">http://forums.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: May 28, 2015
You can have the panels cut however you'd like. Another possible plus of doing what you suggest is that I don't think you'd have to cut the subpanel to fit the 650. On Thu, May 28, 2015 at 11:04 AM, Berck E. Nash wrote: > I suppose there's room for 3 round gauges off to the left. Any idea if > it's possible to move the center screen down so it's level with the others > and put the GMC305 on top, or are the holes for the screens pre-cut? I'm > rather used to the autopilot panel being top center... > > On Thu, May 28, 2015 at 9:36 AM, Ed Kranz wrote: > >> I keep going back and forth. I do want some sort of non-garmin backup >> PFD. RC Allen makes a nice 2.5" LCD attitude gauge that would fit to the >> left of my PFD1, but I'd want altitude and airspeed info as well. So far, I >> don't believe that anyone makes one that small, for a price I'm willing to >> pay. The Midcontinent SAM might fit there, but it's quite spendy. >> >> During the fly-off, I'm obviously day VFR, so I'm going to fly it as >> is... but I'll probably end up with a Dynon D1 either up on the glareshield >> or below the AP controller until someone comes out with a nice compact >> backup PFD. >> >> I've also considered some of the iPad based "PFDs"... which would >> probably be fine in the unlikely scenario that I'm in IMC and suffer a full >> 3 screen system failure... Enough to get me to VMC to get on the ground. >> But I'd prefer a real backup PFD. >> >> On Thu, May 28, 2015 at 10:21 AM, Berck E. Nash wrote: >> >>> Are you planning on a separate self-contained backup system? I ask >>> because it doesn't look like there's much room left over for one. While you >>> can protect against hardware failures with the multiple screens and >>> ADAHRS/GPS receivers across the G3X complex, there's always the issue of a >>> common software bug. I really like the idea of the console mounted >>> quadrant. >>> >>> On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: >>> >>>> >>>> Hey guys, >>>> >>>> Just wanted to show off the redesigned AeroSport Symmetrical panel. >>>> This one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It >>>> also includes room for a 750 below the center screen, or like I chose to >>>> do, a 650, an audio panel, and the GMC305 AP controller. >>>> >>>> Because so much of the panel real estate is taken up with avionics, >>>> Aerosport designed a new center console mounted throttle quadrant. It sits >>>> right where your hand will naturally lay when you have your elbow on the >>>> center console. >>>> >>>> A few other interesting things: >>>> >>>> -With the G3X Touch screens, NO rib modification was necessary. A notch >>>> of about 2" was needed in the bottom of the sub-panel for the 650 in the >>>> location shown in the pictures. >>>> >>>> -There is a lip at the bottom of the center panel that is PERFECT as a >>>> "finger shelf" to brace your hands to operate the 305 AP panel in >>>> turbulence. Now I obviously haven't tested this out in the air, but from >>>> sitting in the garage, bouncing around making airplane noises, it worked >>>> great :) >>>> >>>> -------- >>>> Ed Kranz >>>> RV10 >>>> Finishing >>>> >>>> >>>> >>>> >>>> >>>> Read this topic online here: >>>> >>>> http://forums.matronics.com/viewtopic.php?p=442593#442593 >>>> >>>> >>>> >>>> >>>> Attachments: >>>> >>>> http://forums.matronics.com//files/aerosport_render_146.jpg >>>> http://forums.matronics.com//files/hdr_panel_cropped_172.jpg >>>> >>>> >>>> >>>> >>>> ========== >>>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>>> ========== >>>> FORUMS - >>>> _blank">http://forums.matronics.com >>>> ========== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> target="_blank">http://www.matronics.com/contribution >>>> ========== >>>> >>>> >>>> >>>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Date: May 28, 2015
Here's a quick and dirty photoshop of what that might look like. I gotta say, I really like that too. On Thu, May 28, 2015 at 11:28 AM, Bob Condrey wrote: > Per a discussion I had with Geoff a couple days ago, yes you can move the > center screen down and fit the GMC-305 AP controller above it. > > Bob > > On Thu, May 28, 2015 at 11:04 AM, Berck E. Nash wrote: > >> I suppose there's room for 3 round gauges off to the left. Any idea if >> it's possible to move the center screen down so it's level with the others >> and put the GMC305 on top, or are the holes for the screens pre-cut? I'm >> rather used to the autopilot panel being top center... >> >> On Thu, May 28, 2015 at 9:36 AM, Ed Kranz wrote: >> >>> I keep going back and forth. I do want some sort of non-garmin backup >>> PFD. RC Allen makes a nice 2.5" LCD attitude gauge that would fit to the >>> left of my PFD1, but I'd want altitude and airspeed info as well. So far, I >>> don't believe that anyone makes one that small, for a price I'm willing to >>> pay. The Midcontinent SAM might fit there, but it's quite spendy. >>> >>> During the fly-off, I'm obviously day VFR, so I'm going to fly it as >>> is... but I'll probably end up with a Dynon D1 either up on the glareshield >>> or below the AP controller until someone comes out with a nice compact >>> backup PFD. >>> >>> I've also considered some of the iPad based "PFDs"... which would >>> probably be fine in the unlikely scenario that I'm in IMC and suffer a full >>> 3 screen system failure... Enough to get me to VMC to get on the ground. >>> But I'd prefer a real backup PFD. >>> >>> On Thu, May 28, 2015 at 10:21 AM, Berck E. Nash >>> wrote: >>> >>>> Are you planning on a separate self-contained backup system? I ask >>>> because it doesn't look like there's much room left over for one. While you >>>> can protect against hardware failures with the multiple screens and >>>> ADAHRS/GPS receivers across the G3X complex, there's always the issue of a >>>> common software bug. I really like the idea of the console mounted >>>> quadrant. >>>> >>>> On Wed, May 27, 2015 at 9:06 AM, EdKranz wrote: >>>> >>>>> >>>>> Hey guys, >>>>> >>>>> Just wanted to show off the redesigned AeroSport Symmetrical panel. >>>>> This one fits 3 10" displays (like the big G3X touch, or the AFS 5600). It >>>>> also includes room for a 750 below the center screen, or like I chose to >>>>> do, a 650, an audio panel, and the GMC305 AP controller. >>>>> >>>>> Because so much of the panel real estate is taken up with avionics, >>>>> Aerosport designed a new center console mounted throttle quadrant. It sits >>>>> right where your hand will naturally lay when you have your elbow on the >>>>> center console. >>>>> >>>>> A few other interesting things: >>>>> >>>>> -With the G3X Touch screens, NO rib modification was necessary. A >>>>> notch of about 2" was needed in the bottom of the sub-panel for the 650 in >>>>> the location shown in the pictures. >>>>> >>>>> -There is a lip at the bottom of the center panel that is PERFECT as a >>>>> "finger shelf" to brace your hands to operate the 305 AP panel in >>>>> turbulence. Now I obviously haven't tested this out in the air, but from >>>>> sitting in the garage, bouncing around making airplane noises, it worked >>>>> great :) >>>>> >>>>> -------- >>>>> Ed Kranz >>>>> RV10 >>>>> Finishing >>>>> >>>>> >>>>> >>>>> >>>>> >>>>> Read this topic online here: >>>>> >>>>> http://forums.matronics.com/viewtopic.php?p=442593#442593 >>>>> >>>>> >>>>> >>>>> >>>>> Attachments: >>>>> >>>>> http://forums.matronics.com//files/aerosport_render_146.jpg >>>>> http://forums.matronics.com//files/hdr_panel_cropped_172.jpg >>>>> >>>>> >>>>> >>>>> >>>>> ========== >>>>> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >>>>> ========== >>>>> FORUMS - >>>>> _blank">http://forums.matronics.com >>>>> ========== >>>>> b Site - >>>>> -Matt Dralle, List Admin. >>>>> target="_blank">http://www.matronics.com/contribution >>>>> ========== >>>>> >>>>> >>>>> >>>>> >>>> * >>>> >>>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>>> tp://forums.matronics.com <http://forums.matronics.com> >>>> _blank">http://www.matronics.com/contribution >>>> >>>> * >>>> >>>> >>> * >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com <http://forums.matronics.com> >>> _blank">http://www.matronics.com/contribution >>> >>> * >>> >>> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > > > * > > ________________________________________________________________________________
Subject: symmetrical panel and backup
Date: May 29, 2015
If you are seriously interested in backup for IFR in IMC, you need two different EFIS systems and an autopilot with internal solid state gyros and backup batteries. My solution is Chelton primary with FAA level A software; GRT Sport/software (mini is now available) for backup and a Trutrak AP that will also fly the aircraft albeit not extremely precisely. I have three 680s on board although the last was added on the firewall more for weight and balance purposes. In essence I have three systems all capable of keeping the shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV commands from the GRT and fly the aircraft independently depending on a source selection switch for the AP. My two cents --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com ________________________________________________________________________________
Date: May 29, 2015
Subject: Re: symmetrical panel and backup
There are several "mini-EFIS" available today that were not on the market 7-8 yrs ago. Even if you select the same brand as the main EFIS, the operating software is different. You have to decide whether you want same logic or being able to know the ins and outs of two different brand philosophies, and whether you want more Tees in your pitot static system to leak, or a GPS derived attitude, altitude and airspeed as backup. It appears the autopilot market has evolved to where the leading EFIS have integrated autopilots, and backup batteries for each screen. Having a separate autopilot generally adds several grand in cost. However, most autopilots, whether separate or integrated will fail if they don't have electrons to power them, as most use electric servos. One does have to decide whether to wear 2 belts and 1 or two suspenders to have enough backup. On Fri, May 29, 2015 at 5:51 AM, DLM wrote: > > If you are seriously interested in backup for IFR in IMC, you need two > different EFIS systems and an autopilot with internal solid state gyros and > backup batteries. My solution is Chelton primary with FAA level A software; > GRT Sport/software (mini is now available) for backup and a Trutrak AP that > will also fly the aircraft albeit not extremely precisely. I have three > 680s > on board although the last was added on the firewall more for weight and > balance purposes. In essence I have three systems all capable of keeping > the > shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV > commands from the GRT and fly the aircraft independently depending on a > source selection switch for the AP. > > My two cents > > > --- > This email has been checked for viruses by Avast antivirus software. > http://www.avast.com > > ________________________________________________________________________________
Date: May 29, 2015
For Back UP EFIS: On an IFR platform I always utilize a separate manufacture for the secondary EFIS. The GRT Mini x is a great package in a small footprint. -------- Frank Dombroski RV-10 2.0 N46VT soon to be flying KSMQ Somerset Airport NJ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442746#442746 ________________________________________________________________________________
Date: May 29, 2015
Trying to figure out how to keep backups in perspective. While building my 10 I am still flying my =9956 Cessna 172. Flew home yesterday IFR. One engine, one alternator, one main ships battery. Two radios, one powering a VOR/ILS/LOC head, and one a VOR. Had a tablet GPS on the yoke, and a backup tablet in the bag, no auto pilot. I know pilots that have been flying like this for years, even before the portable GPS=99s. Does it seem that we get a little carried away with backups? I am still trying to decide on a panel, but leaning towards two G3X=99s, and a mini-B each with batteries, autopilot controlled by the G3X=99s. No round dials. This seems like so much more backup than I have now, even still with one ships battery and alternator. Bill Greenley From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, May 29, 2015 10:27 AM Subject: Re: RV10-List: symmetrical panel and backup There are several "mini-EFIS" available today that were not on the market 7-8 yrs ago. Even if you select the same brand as the main EFIS, the operating software is different. You have to decide whether you want same logic or being able to know the ins and outs of two different brand philosophies, and whether you want more Tees in your pitot static system to leak, or a GPS derived attitude, altitude and airspeed as backup. It appears the autopilot market has evolved to where the leading EFIS have integrated autopilots, and backup batteries for each screen. Having a separate autopilot generally adds several grand in cost. However, most autopilots, whether separate or integrated will fail if they don't have electrons to power them, as most use electric servos. One does have to decide whether to wear 2 belts and 1 or two suspenders to have enough backup. On Fri, May 29, 2015 at 5:51 AM, DLM wrote: If you are seriously interested in backup for IFR in IMC, you need two different EFIS systems and an autopilot with internal solid state gyros and backup batteries. My solution is Chelton primary with FAA level A software; GRT Sport/software (mini is now available) for backup and a Trutrak AP that will also fly the aircraft albeit not extremely precisely. I have three 680s on board although the last was added on the firewall more for weight and balance purposes. In essence I have three systems all capable of keeping the shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV commands from the GRT and fly the aircraft independently depending on a source selection switch for the AP. My two cents --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com -List" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 29, 2015
I do have a TCW IBBS backup battery that will power the MFD (which will drop into reversionary mode), engine monitor, one of the adahrs (along with the mag and temp probe), and the autopilot panel. The AP servos are NOT powered by the backup battery, but the autopilot panel will give me a flight director, so I will become the "meat servo". The MFD is also an XM enabled unit, so I'll even still have weather and some good tunes incase I get bored during the emergency! The backup battery will only be needed after the primary alternator, secondary 30 amp alternator, and the main ships battery fail. Additionally, if there is a CANBUS failure, the adahrs are both connected with a secondary RS232 connection to the PFD and MFD, helping me to keep the shiny side up. I have thought a LOT about systems redundancy. As an IT Systems Admin, it's part of my day job. I've designed as many of the systems to have redundancy, sometimes even dual and triple redundancy, as practical. The last big piece is going to be having a completely different brand backup PFD. Like I said before, I'm leaning towards a battery operated, GPS derived, self contained unit like a Dynon D1, as it isn't dependent on ANY of the other systems in the plane, like power or pitot/static. On Fri, May 29, 2015 at 9:26 AM, Kelly McMullen wrote: > There are several "mini-EFIS" available today that were not on the market > 7-8 yrs ago. Even if you select the same brand as the main EFIS, the > operating software is different. You have to decide whether you want same > logic or being able to know the ins and outs of two different brand > philosophies, and whether you want more Tees in your pitot static system to > leak, or a GPS derived attitude, altitude and airspeed as backup. > It appears the autopilot market has evolved to where the leading EFIS have > integrated autopilots, and backup batteries for each screen. Having a > separate autopilot generally adds several grand in cost. However, most > autopilots, whether separate or integrated will fail if they don't have > electrons to power them, as most use electric servos. One does have to > decide whether to wear 2 belts and 1 or two suspenders to have enough > backup. > > On Fri, May 29, 2015 at 5:51 AM, DLM wrote: > >> >> If you are seriously interested in backup for IFR in IMC, you need two >> different EFIS systems and an autopilot with internal solid state gyros >> and >> backup batteries. My solution is Chelton primary with FAA level A >> software; >> GRT Sport/software (mini is now available) for backup and a Trutrak AP >> that >> will also fly the aircraft albeit not extremely precisely. I have three >> 680s >> on board although the last was added on the firewall more for weight and >> balance purposes. In essence I have three systems all capable of keeping >> the >> shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV >> commands from the GRT and fly the aircraft independently depending on a >> source selection switch for the AP. >> >> My two cents >> >> >> --- >> This email has been checked for viruses by Avast antivirus software. >> http://www.avast.com >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > * > > > * > > ________________________________________________________________________________
Date: May 29, 2015
I agree that the landscape has changed since I made my panel decision 8 years ago. Then my backup was a Blue Mountain.when it crapped out I went to a third GRT screen.then replaced that with a GRT sport. Different enough to solve the same technology problem, but yet runs just like my other GRT system and thus no learning curve or retraining time caused by two unique systems. I also have three 2.5=9D steam gauges. With that I should be able to get out of the soup even if everything else goes tango uniform. I have two batteries, but that was more to move the CG forward than the actual need for a second battery. Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen Sent: Friday, May 29, 2015 8:27 AM Subject: Re: RV10-List: symmetrical panel and backup There are several "mini-EFIS" available today that were not on the market 7-8 yrs ago. Even if you select the same brand as the main EFIS, the operating software is different. You have to decide whether you want same logic or being able to know the ins and outs of two different brand philosophies, and whether you want more Tees in your pitot static system to leak, or a GPS derived attitude, altitude and airspeed as backup. It appears the autopilot market has evolved to where the leading EFIS have integrated autopilots, and backup batteries for each screen. Having a separate autopilot generally adds several grand in cost. However, most autopilots, whether separate or integrated will fail if they don't have electrons to power them, as most use electric servos. One does have to decide whether to wear 2 belts and 1 or two suspenders to have enough backup. On Fri, May 29, 2015 at 5:51 AM, DLM wrote: If you are seriously interested in backup for IFR in IMC, you need two different EFIS systems and an autopilot with internal solid state gyros and backup batteries. My solution is Chelton primary with FAA level A software; GRT Sport/software (mini is now available) for backup and a Trutrak AP that will also fly the aircraft albeit not extremely precisely. I have three 680s on board although the last was added on the firewall more for weight and balance purposes. In essence I have three systems all capable of keeping the shiny side up. The AP can accept LNAV/VNAV commands from the Chelton, LNAV commands from the GRT and fly the aircraft independently depending on a source selection switch for the AP. My two cents --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com -List" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - _blank">http://forums.matronics.com b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 29, 2015
Tim Very well said. I also agree that the "hard" IFR thing is misused. You really need to be proficient in any IFR situation. Also, your BEST friend in IFR is ATC. You should NEVER be afraid or embarrassed to use them. Listening to everyone's opinion on what you HAVE to have to safely fly IFR really makes me chuckle. Have you guys looked at the ancient panels and systems in the airliners that carry you across the country and all over the world? They just updated the database in my work jet...using a single sided floppy disk...it took almost a half an hour... A plumber friend once told me something. He said, "The more complicated the plumbing is, the easier it is to stop it up." I think at some point, that statement applies here... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442761#442761 ________________________________________________________________________________
Date: May 29, 2015
Those old airliners may be ancient, but they're also very redundant. All the transport category aircraft I've ever flown have at least three fully independent sources of attitude information, at least two completely separate pitot-static systems with two air data computers, three altimeters, three air speed indicators... Sure, they may have no glass screens, and I flew plenty of turboprops across the country full of passengers using nothing but VOR/DME for navigation (often without an operable autopilot), but they were all designed so no single system failure on any of those planes would prove to be a major event. I don't think I need the same level of redundancy in my RV-10, but I really do want something like the GRT mini (or even 3 round dials) in case the primary systems glitch. And I've seen enough bugs in the software and electronics of airliners (which are built and tested to much higher standards than whatever I'll be putting in my RV-10) to make me want options. I know people do it all the time, but I'm just not comfortable flying IMC where the failure of a single vacuum pump can leave me shooting an approach with a turn coordinator and a whiskey compass. Sure, I trained for it; I would probably survive, but part of the reason for building my own plane is so that I can affordably have a little more redundancy than that. ________________________________________________________________________________
Date: May 29, 2015
The one thing I'd note is that when planning an EFIS system, yes, there are times when it may be nice to have more than one manufacturer in the panel for those primary gauges. But, don't fall victim to going too far with that. I would spend as much as you need to get your primary system fully up to par and integrated. Then just add the 2nd system as a more stand-alone device. The issue you will run into sometimes is panel space. Don't sacrifice too much of your panel space of what you want for the primary just to give it to backups. And don't do something like pick one EFIS brand for one side and one for the other side. You'll never be as happy with how it all integrates. This isn't saying you SHOULDN'T have backups or varied vendors, but just saying not to short your primary for the purpose of having a bigger backup. You can have all the backup you need without all that much space taken up. Tim On 5/29/2015 11:59 AM, Berck E. Nash wrote: > Those old airliners may be ancient, but they're also very redundant. > All the transport category aircraft I've ever flown have at least three > fully independent sources of attitude information, at least two > completely separate pitot-static systems with two air data computers, > three altimeters, three air speed indicators... Sure, they may have no > glass screens, and I flew plenty of turboprops across the country full > of passengers using nothing but VOR/DME for navigation (often without an > operable autopilot), but they were all designed so no single system > failure on any of those planes would prove to be a major event. > > I don't think I need the same level of redundancy in my RV-10, but I > really do want something like the GRT mini (or even 3 round dials) in > case the primary systems glitch. And I've seen enough bugs in the > software and electronics of airliners (which are built and tested to > much higher standards than whatever I'll be putting in my RV-10) to make > me want options. > > I know people do it all the time, but I'm just not comfortable flying > IMC where the failure of a single vacuum pump can leave me shooting an > approach with a turn coordinator and a whiskey compass. Sure, I trained > for it; I would probably survive, but part of the reason for building my > own plane is so that I can affordably have a little more redundancy than > that. > ________________________________________________________________________________
Date: May 29, 2015
Tim: All good points, and no way I would split primary EFIS displays across vendors. The 3-screen 10" G3X touch system really does, I think, start to push the issue of it being possible to have the backup you want and the primary displays that you want. The 3 screen G3X just isn't going to leave enough room for something like the GRT-mini as a backup, which leaves me struggling a bit with the tradeoffs. I think the 3 screens are probably worth it for the primary use case, as a GRT-mini just takes up space without providing anything useful as long as the primary works. A 3rd G3X is going to be enormously useful every day, but I'm just not sure what to do as a backup in that case, short of deciding that 3 G3X's are probably good enough. And they probably are, but I keep going back to what happened to the F-22 when I envision software failures: http://www.dailytech.com/Lockheeds+F22+Raptor+Gets+Zapped+by+International+Date+Line/article6225.htm Looking around at modern spam cans (Cessna 350, Mooney Acclaim, SR-22) , they all seem to be going with the 3 round gauges as backups... On Fri, May 29, 2015 at 12:44 PM, Tim Olson wrote: > > The one thing I'd note is that when planning an EFIS system, yes, > there are times when it may be nice to have more than one > manufacturer in the panel for those primary gauges. > But, don't fall victim to going too far with that. > I would spend as much as you need to get your primary system > fully up to par and integrated. Then just add the 2nd system > as a more stand-alone device. The issue you will run into > sometimes is panel space. Don't sacrifice too much of your > panel space of what you want for the primary just to give it > to backups. And don't do something like pick one EFIS brand > for one side and one for the other side. You'll never be > as happy with how it all integrates. This isn't saying you > SHOULDN'T have backups or varied vendors, but just saying > not to short your primary for the purpose of having a bigger > backup. You can have all the backup you need without > all that much space taken up. > Tim > > > On 5/29/2015 11:59 AM, Berck E. Nash wrote: > >> Those old airliners may be ancient, but they're also very redundant. >> All the transport category aircraft I've ever flown have at least three >> fully independent sources of attitude information, at least two >> completely separate pitot-static systems with two air data computers, >> three altimeters, three air speed indicators... Sure, they may have no >> glass screens, and I flew plenty of turboprops across the country full >> of passengers using nothing but VOR/DME for navigation (often without an >> operable autopilot), but they were all designed so no single system >> failure on any of those planes would prove to be a major event. >> >> I don't think I need the same level of redundancy in my RV-10, but I >> really do want something like the GRT mini (or even 3 round dials) in >> case the primary systems glitch. And I've seen enough bugs in the >> software and electronics of airliners (which are built and tested to >> much higher standards than whatever I'll be putting in my RV-10) to make >> me want options. >> >> I know people do it all the time, but I'm just not comfortable flying >> IMC where the failure of a single vacuum pump can leave me shooting an >> approach with a turn coordinator and a whiskey compass. Sure, I trained >> for it; I would probably survive, but part of the reason for building my >> own plane is so that I can affordably have a little more redundancy than >> that. >> >> > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: May 29, 2015
Looking over this thread it seems to me that it might be worthwhile defining the objectives before looking at solution sets. For a flat screen approach I want: - Devices that integrate for capability - Devices that do not rely on any single input - Two displays in the event that one dies, each from an independent power feed - Each display can perform any function - Two independent ADAHRS modules (or similar capability) - Enough redundancy in power to the panel that a single failure will not turn everything dark (e.g. no Avionics Master switch, no single master relay to the battery or multiple batteries feeding a common buss, etc.) There are a boatload of ways to achieve the above objectives, some more complex (and costly) than others. To Tim's point however, start off with what you want for normal operations then see what it can/can't do for any single failure mode that you can think of for the whole system. For the things you find unacceptable design in a back up. The rest are managed. I have two 10" displays, an analog airspeed and altimeter, two ADAHRS modules, a second radio and two selectable ways to power each device. A loss of any single component will support continued, but perhaps reduced capability IFR flight. Example of a managed risk is if the Garmin 650 craps out (as it already has) then I lose my certified IFR WAAS GPS and NAV. I'd be relying on the EFIS standalone GPS system so not legal for IFR but perfectly fine for getting me on the ground - after I do the required report to ATC. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, May 29, 2015 2:45 PM Subject: Re: RV10-List: Re: symmetrical panel and backup The one thing I'd note is that when planning an EFIS system, yes, there are times when it may be nice to have more than one manufacturer in the panel for those primary gauges. But, don't fall victim to going too far with that. I would spend as much as you need to get your primary system fully up to par and integrated. Then just add the 2nd system as a more stand-alone device. The issue you will run into sometimes is panel space. Don't sacrifice too much of your panel space of what you want for the primary just to give it to backups. And don't do something like pick one EFIS brand for one side and one for the other side. You'll never be as happy with how it all integrates. This isn't saying you SHOULDN'T have backups or varied vendors, but just saying not to short your primary for the purpose of having a bigger backup. You can have all the backup you need without all that much space taken up. Tim On 5/29/2015 11:59 AM, Berck E. Nash wrote: > Those old airliners may be ancient, but they're also very redundant. > All the transport category aircraft I've ever flown have at least > three fully independent sources of attitude information, at least two > completely separate pitot-static systems with two air data computers, > three altimeters, three air speed indicators... Sure, they may have > no glass screens, and I flew plenty of turboprops across the country > full of passengers using nothing but VOR/DME for navigation (often > without an operable autopilot), but they were all designed so no > single system failure on any of those planes would prove to be a major event. > > I don't think I need the same level of redundancy in my RV-10, but I > really do want something like the GRT mini (or even 3 round dials) in > case the primary systems glitch. And I've seen enough bugs in the > software and electronics of airliners (which are built and tested to > much higher standards than whatever I'll be putting in my RV-10) to > make me want options. > > I know people do it all the time, but I'm just not comfortable flying > IMC where the failure of a single vacuum pump can leave me shooting an > approach with a turn coordinator and a whiskey compass. Sure, I > trained for it; I would probably survive, but part of the reason for > building my own plane is so that I can affordably have a little more > redundancy than that. > ________________________________________________________________________________
Date: May 29, 2015
Yeah, you added some good info. I'll expound on a couple more points. First, and this may seem like an attack but it's not, and it may seem like I'm biased because I'm a "don't have" guy, but I'm not. But... I'm just not in the camp that thinks bigger glass is better. At a certain point it just takes up more space. I have 3 screens and they give PLENTY of visibility, for the pilot, to all 3 of them, and they are maybe what, 1/3 the size of the big 10" ones? Much easier to fit in the panel that way and much easier to have *effective* backups. And by that I mean not where you have to have a backup instrument down by your fuel valve to be able to fit one in. I think Garmin had it right with the original G3X screens, personally. Those would be easy to fit into any RV10 panel and have 3 screens. But one very important addition I think is that if you are going for a real complete backup solution, don't forget some of the details. On my flight this last week, I had to do VTF for the ILS, and I not only had my NAV1 used by my EFIS for displaying the ILS on the EFIS, but I set NAV2 up as well, since it had been a while that I did a real ILS (not for practice) and especially in low conditions. I wanted that cross check with my Nav2. But what made it even POSSIBLE is that I had a CDI in my panel. I know almost nobody that seems to install a CDI anymore. But, it was a welcome instrument on that approach. If you want to have a Nav2 and have it be useable, you need at least a device that can display that info. In my RV-14 panel I just didn't have the room, so I won't have a CDI. That's Ok, I also won't have a NAV2. But that really changes my abilities in some situations. When I was picking through my approaches I could do, looking between 2 airports I was going to be near, there was only one ILS, and I don't remember for sure this detail but I don't think that there were ANY other approaches at either airport that could bring you lower than 300 or 400'. Ceilings were just below 300. GPS is great, but at many airports you may not get the low approach capability that you'd have with an ILS. So equip as appropriate. Now in a backup situation, in my RV-14, if I lost my NAV, I'd have been stuck and had to go somewhere else...and with 300' ceilings there isn't much available. Time to hike it to another airport maybe 30-45 minutes away. Anyway, EFIS's are great, but don't overlook the other devices is my main point. A Dynon/GRT/Blue Mountain/Whatever may be a good backup to a point. But it may not give you everything. Or, if you have 2 NAV radios, it may be that you want a mini-efis that can display the CDI on it too. Just so many things to think about. I was personally *considering* using a ipad with the Levil AHRS as a backup instrument in the RV-14...but the caveat is that if I depart on any flight where I may need it, I would have it ready and running the whole flight. I'm not sure sure it's a great backup for a whole panel, but it's all I had real good space for other than what round gauges supply. And for that matter, it's probably all I'd need. The comment about most production planes using round gauges is a good one. They go with those because they are a backup...and don't need to be full featured. But your flight style will change if you should be using them. Tim On 5/29/2015 2:32 PM, Carl Froehlich wrote: > > Looking over this thread it seems to me that it might be worthwhile defining > the objectives before looking at solution sets. > > For a flat screen approach I want: > - Devices that integrate for capability > - Devices that do not rely on any single input > - Two displays in the event that one dies, each from an independent power > feed > - Each display can perform any function > - Two independent ADAHRS modules (or similar capability) > - Enough redundancy in power to the panel that a single failure will not > turn everything dark (e.g. no Avionics Master switch, no single master relay > to the battery or multiple batteries feeding a common buss, etc.) > > There are a boatload of ways to achieve the above objectives, some more > complex (and costly) than others. To Tim's point however, start off with > what you want for normal operations then see what it can/can't do for any > single failure mode that you can think of for the whole system. For the > things you find unacceptable design in a back up. The rest are managed. > > I have two 10" displays, an analog airspeed and altimeter, two ADAHRS > modules, a second radio and two selectable ways to power each device. A > loss of any single component will support continued, but perhaps reduced > capability IFR flight. Example of a managed risk is if the Garmin 650 craps > out (as it already has) then I lose my certified IFR WAAS GPS and NAV. I'd > be relying on the EFIS standalone GPS system so not legal for IFR but > perfectly fine for getting me on the ground - after I do the required report > to ATC. > > Carl > ________________________________________________________________________________
Date: May 29, 2015
On Fri, May 29, 2015 at 2:03 PM, Tim Olson wrote: > > First, and this may seem like an attack but it's not, and it may > seem like I'm biased because I'm a "don't have" guy, but I'm not. > But... I'm just not in the camp that thinks bigger glass is better. Interesting point. I'd just assumed from looking at them at OSH, that flying behind giant screens would be a much more pleasant experience. But I've zero personal experience flying with large screens, so I don't know. Have you flown anything with big screens? The small garmins have always looked way too cluttered to me, and some bigger screens seems to make that better. Personally, the only glass I've spent any time behind is the collins pro line 4 in the CRJ, which has laughably small CRT displays by today's standards. I never thought they seemed small, but there were 6 of them (you can really only see the 2 in front of you and the 2 in the center), and collins doesn't have the same cluttered look that Garmin does. If I'd been forced to have the engine instruments share with the MFD, I do think the screens would be way too small. I want a plane that's comfortable to fly from either seat, as I'm likely to spend a lot of time with two pilots up front. (I'm also going to be doing instrument instruction with my build partner, and I'm somewhat greedy about wanting my own display over in the right seat.) I'd been thinking that a single 10" display in front of each pilot would be plenty, but the part that bothers me about that is a screen in front of the seat you're not sitting in is just too far away if one goes dark. Which means, do you switch seats, or crane your neck? A center screen would solve that problem. The G3X Touch is also available with 7" screens, and 3 of those would certainly be good enough, and leave plenty of room for backups..... but 3 bigger screens seems even better. I've still got well over a year before I have to start filling a panel (just starting on the fuel tanks now), but in the meantime I'm anxiously looking at what's out there. ________________________________________________________________________________
Date: May 29, 2015
My setup has a GRT 6.5" screen centered on tbe left seat, then the avionics, then a second 6.5" screen, so this last one is offset to the left for someone in the right seat. Easy for the left seat to use. I did it this way so the engine instruments, normally on screen 2, are in the same place as on the 182 I flew for many years, so it seems natural to me. I have given instrument instruction, in actual, in someone else's -10, who had a similar set up. I had no problem looking across to the pilot's PFD; everything was quite readable. re Tim and CDIs: I quite agree. I routinely do not use the GRT's primary PFD page. Instead, I split it with an electronic HSI. On an ILS the main CDI is showing localizer deviation, while an RMI needle shows the SL30's multiplexed VOR, for cross fixes, missed approach, whatever you need on a no-gps approach. If everything goes bad and I'm reduced to my battery powered D-6 and a hand held Sporty's VOR (so old that it just shows digital to/from bearings) I've found (under the hood) that this works quite well. The trick is to almost close your eyes and imagine the bearing as a needle on an ADF, and fly the approach as if it were an NDB. Of course, that presumes that you can fly NDB approaches! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442781#442781 ________________________________________________________________________________
Date: May 30, 2015
"... don't think I need the same level of redundancy in my RV-10, but I really do want something like the GRT mini..." Exactly. I am current;y looking at an AFS EFIS with the GRT Mini backup. Seems like a good compromise. If the weather is so bad that I need triple redundant systems, then I will probably just delay a bit...or go on the airlines... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442808#442808 ________________________________________________________________________________
Subject: NAV splitter
Date: May 30, 2015
The quick build kit I have, the previous builder installed two Archer NAV antennae one in each wingtip I'm assuming I can combine these signals using a combiner or reverse splitter . Will I be fighting a ghosting/corrupting signal using two signal sources? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442813#442813 ________________________________________________________________________________
Subject: Re: NAV splitter
Date: May 30, 2015
This absolutely does not work. You will make a directional antenna which works very well in some directions and very poorly in others. Which direction depends on the exact lengths of the coax. One Archer works just fine, with some reduction in sensitivity when looking thru the airframe direction. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442814#442814 ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: May 30, 2015
Nope - will not work. The impedance match will be all wrong. Use one antenna for NAV, keep the other antenna as a backup comm - say for a handheld. It would work a boat load better than the handheld's rubber ducky antenna. I made this antenna out of same scrap aluminum and small pieces of fiberglass. I used an antenna tester to tune (most of these antennas are so far out that just slapping one in tends to produce disappointing results). 100nmi plus VOR range at altitude. Carl > On May 30, 2015, at 2:45 PM, Bob Turner wrote: > > > This absolutely does not work. > You will make a directional antenna which works very well in some directions and very poorly in others. Which direction depends on the exact lengths of the coax. > One Archer works just fine, with some reduction in sensitivity when looking thru the airframe direction. > > -------- > Bob Turner > RV-10 QB > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442814#442814 > > > The quick build kit I have, the previous builder installed two Archer NAV antennae one in each wingtip I'm assuming I can combine these signals using a combiner or reverse splitter . Will I be fighting a ghosting/corrupting signal using two signal sources? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI > > > > > > > > ________________________________________________________________________________
Date: May 30, 2015
You can use one to Fe achieve Nav radio if you have two, but you don't want to try to combine them. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On May 30, 2015, at 1:31 PM, rvdave wrote: > > > The quick build kit I have, the previous builder installed two Archer NAV antennae one in each wingtip I'm assuming I can combine these signals using a combiner or reverse splitter . Will I be fighting a ghosting/corrupting signal using two signal sources? > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442813#442813 > > > > > > > > > > ________________________________________________________________________________
Date: May 30, 2015
Exactly what I need to know, thanks. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442818#442818 ________________________________________________________________________________
Subject: Wheel balancer
Date: May 30, 2015
The RV-10 is down for inspection, right wing replacement and to fix an annoying nose gear shimmy. Reading the achieves it was clear that wheel balancing is a major step to solving nose gear shimmy. I already have the solid nose gear axle mod. Finding a wheel balancer proved hard outside of dropping $400 for one from Aircraft Tool Supply. Tom Doran made this one with some very nice bearings he had laying around and milled Delrin spacers (he is magic with a mill machine). It is amazingly sensitive. I tried balancing the nose wheel in the past with just a horizontal rod to find the heavy spot. Using this rig I found my previous attempt to be way off. I ended up using six =BC oz stick on weights to get the nose wheel to balance. The mains used about three weights each. Carl ________________________________________________________________________________
Date: May 30, 2015
What you choose for backup may be dependent on whether your pitot/static lines run to ADAHRS in rear of plane (dynon Skyview) or if it is at the instrument panel. The GRT mini requires hook up to those lines, and you get benefit of actual airspeed and altitude. Dynon D1/D2 needs no hookup, but only gives you GPS derived ground speed and GPS track and GPS altitude. All better than nothing, but not quite as good as barometric and pitot derived numbers. Huge change in redundancy from when I was flying in non-radar areas with venturi powered gyros and electric turn coordinator, with single nav/com/ils and single ADF. That gave some blood pressure rise when the venturis iced up. Key word is when, not if. Fortunately the old AN gyros would operate down to less than 1" of vacuum, so you got warning when the vacuum started trending below 4" All with one alternator and one battery for electrons. On 5/30/2015 8:39 AM, Rocketman1988 wrote: > > "... don't think I need the same level of redundancy in my RV-10, but I really do want something like the GRT mini..." > > Exactly. I am current;y looking at an AFS EFIS with the GRT Mini backup. Seems like a good compromise. If the weather is so bad that I need triple redundant systems, then I will probably just delay a bit...or go on the airlines... > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442808#442808 > > ________________________________________________________________________________
Date: May 30, 2015
I have installed two, because I have two nav/coms. If you only have one, perhaps with an ILS, you could use the second one for the GS. As others have said, you can't combine, and if you split for GS or second nav you lose about 50% of the signal strength. On 5/30/2015 12:53 PM, rvdave wrote: > > Exactly what I need to know, thanks. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442818#442818 > > ________________________________________________________________________________
Date: May 30, 2015
If your nav radio has separate inputs for vor and GS you can hook up one antenna to each and save tbe cost of a splitter. If you want to use it for a com radio you'll want to bend it up as much as possible, and trim about 10% of the length off the end. It won't be great but as Carl said it's better than the rubber duckie. For techies: the impedance match is fine, the issue is that depending on the direction of the signal, there will be phase mis-matches. When the phase difference is 180 degrees you'll get no signal. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442822#442822 ________________________________________________________________________________
Subject: Re: Wheel balancer
Date: May 31, 2015
This works well for me: http://www.marcparnes.com/Honda_Motorcycle_Wheel_Balancer.htm I made a vertical "U" of 2X6 wood to support the ends. -------- RV-10 UC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442831#442831 ________________________________________________________________________________
Date: May 31, 2015
From: David Clifford <davidsoutpost(at)comcast.net>
Date: May 31, 2015
I have that same one. It works very well. I'm really surprised how friction free their bearings are. It's real hard to get the balance perfect almost because if you're a perfectionist you can spend a lot of time getting it real precise. But once you get it real close its easy to know you did a good job. The price is right too. Highly recommended. Been using mine now for almost 9 years I think. Glad they're still making them because it looks like it's a one man business. Tim > On May 31, 2015, at 7:12 AM, bruceflys wrote: > > > This works well for me: http://www.marcparnes.com/Honda_Motorcycle_Wheel_Balancer.htm > > I made a vertical "U" of 2X6 wood to support the ends. > > -------- > RV-10 UC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442831#442831 > > > > > > > > > > ________________________________________________________________________________
Date: May 31, 2015
Hi Bruce Which kit did you get? Was it the UNIV kit? Cheers Les Sent from my iPhone > On May 31, 2015, at 8:12 AM, bruceflys wrote: > > > This works well for me: http://www.marcparnes.com/Honda_Motorcycle_Wheel_Balancer.htm > > I made a vertical "U" of 2X6 wood to support the ends. > > -------- > RV-10 UC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442831#442831 > > > > > > > > > > ________________________________________________________________________________
Subject: tie breaker
Date: May 31, 2015
If you have dual AHDRS with auto monitoring, and dual screens, the need for a tie breaker is debatable . My dual Skyview provides this capability as do other EFIS systems. You may not realize this, but you already have a tie breaker, as they call them in jets, if you have an IPhone 5 or newer. Use the compass ap that came with the phone, and go to the second page of the ap, and therein is a very accurate pitch and roll display, and it won=99t tumble. I have played around with it , maneuvering in my RV8 and have no problem returning to strait and level and maintaining that, using that as a sole reference, (under a hood with a safety pilot). You don=99t get airspeed or altitude info, but target pitch and power is all you need to fly anyway while you sort things out. Turn the IPhone's auto lock feature to =9Cnever=9D and velcro the phone to the panel. If you fly lots of hard IFR, then go ahead and get the real deal in your panel. If all you fly is light IFR, like getting above a marine overcast on departure or down thru one with an approach, then dual AHDRS with auto monitoring, and the IPhone tie breaker may be all you need. There are probably better aviation aps that use the ADRS chip in the IPhone or IPad or whatever devise you have with you , but you may already have all the tie breaker that you need. Just saying.... ________________________________________________________________________________
Date: May 31, 2015
Subject: Re: tie breaker
From: Bruce Breckenridge <bbreckenridge(at)gmail.com>
I just grabbed my wife's iPhone 6 Plus - amazing! Can't wait to put it in the plane and try it out. Thanks! On Sun, May 31, 2015 at 8:17 AM, Chris Hukill wrote: > If you have dual AHDRS with auto monitoring, and dual screens, the need > for a tie breaker is debatable . My dual Skyview provides this capability > as do other EFIS systems. You may not realize this, but you already have a > tie breaker, as they call them in jets, if you have an IPhone 5 or newer. > Use the compass ap that came with the phone, and go to the second page of > the ap, and therein is a very accurate pitch and roll display, and it won =99t > tumble. I have played around with it , maneuvering in my RV8 and have no > problem returning to strait and level and maintaining that, using that as a > sole reference, (under a hood with a safety pilot). You don=99t get airspeed > or altitude info, but target pitch and power is all you need to fly anywa y > while you sort things out. Turn the IPhone's auto lock feature to =9Cnever=9D > and velcro the phone to the panel. If you fly lots of hard IFR, then go > ahead and get the real deal in your panel. If all you fly is light IFR, > like getting above a marine overcast on departure or down thru one with a n > approach, then dual AHDRS with auto monitoring, and the IPhone tie breake r > may be all you need. There are probably better aviation aps that use the > ADRS chip in the IPhone or IPad or whatever devise you have with you , bu t > you may already have all the tie breaker that you need. Just saying.... > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: May 31, 2015
That is cool. One thing to be careful of in that app. After 45 degrees in either roll direction, it "flips" to think you're holding the phone in portrait vs landscape. My guess is that the aviation based apps like this would be much better. On Sun, May 31, 2015 at 11:20 AM, Bruce Breckenridge < bbreckenridge(at)gmail.com> wrote: > I just grabbed my wife's iPhone 6 Plus - amazing! Can't wait to put it i n > the plane and try it out. Thanks! > > > On Sun, May 31, 2015 at 8:17 AM, Chris Hukill wrote: > >> If you have dual AHDRS with auto monitoring, and dual screens, the need >> for a tie breaker is debatable . My dual Skyview provides this capabilit y >> as do other EFIS systems. You may not realize this, but you already have a >> tie breaker, as they call them in jets, if you have an IPhone 5 or newer . >> Use the compass ap that came with the phone, and go to the second page o f >> the ap, and therein is a very accurate pitch and roll display, and it wo n=99t >> tumble. I have played around with it , maneuvering in my RV8 and have no >> problem returning to strait and level and maintaining that, using that a s a >> sole reference, (under a hood with a safety pilot). You don=99t ge t airspeed >> or altitude info, but target pitch and power is all you need to fly anyw ay >> while you sort things out. Turn the IPhone's auto lock feature to =9Cnever=9D >> and velcro the phone to the panel. If you fly lots of hard IFR, then go >> ahead and get the real deal in your panel. If all you fly is light IFR, >> like getting above a marine overcast on departure or down thru one with an >> approach, then dual AHDRS with auto monitoring, and the IPhone tie break er >> may be all you need. There are probably better aviation aps that use the >> ADRS chip in the IPhone or IPad or whatever devise you have with you , b ut >> you may already have all the tie breaker that you need. Just saying.... >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: May 31, 2015
I just tried this. That's where his key words of setting your phone to rota tion lock is important. I always keep my phone rotate locked and it worked p roperly that way, but yes, if you turn that off it could be very problematic . I have a gyro app that is much prettier than the compass version, so I doubt I'll use compass, but it is nice to know its there. Tim > On May 31, 2015, at 11:36 AM, Ed Kranz wrote: > > That is cool. > > One thing to be careful of in that app. After 45 degrees in either roll di rection, it "flips" to think you're holding the phone in portrait vs landsca pe. My guess is that the aviation based apps like this would be much better. > >> On Sun, May 31, 2015 at 11:20 AM, Bruce Breckenridge wrote: >> I just grabbed my wife's iPhone 6 Plus - amazing! Can't wait to put it i n the plane and try it out. Thanks! >> >> >> >>> On Sun, May 31, 2015 at 8:17 AM, Chris Hukill wrote: >>> If you have dual AHDRS with auto monitoring, and dual screens, the need f or a tie breaker is debatable . My dual Skyview provides this capability as d o other EFIS systems. You may not realize this, but you already have a tie b reaker, as they call them in jets, if you have an IPhone 5 or newer. Use th e compass ap that came with the phone, and go to the second page of the ap, a nd therein is a very accurate pitch and roll display, and it won=99t t umble. I have played around with it , maneuvering in my RV8 and have no prob lem returning to strait and level and maintaining that, using that as a sole reference, (under a hood with a safety pilot). You don=99t get airspe ed or altitude info, but target pitch and power is all you need to fly anywa y while you sort things out. Turn the IPhone's auto lock feature to =9C never=9D and velcro the phone to the panel. If you fly lots of hard IFR , then go ahead and get the real deal in your panel. If all you fly is light IFR, like getting above a marine overcast on departure or down thru one wit h an approach, then dual AHDRS with auto monitoring, and the IPhone tie brea ker may be all you need. There are probably better aviation aps that use the ADRS chip in the IPhone or IPad or whatever devise you have with you , but y ou may already have all the tie breaker that you need. Just saying.... >>> >>> >>> get="_blank">http://www.matronics.com/Navigator?RV10-List >>> tp://forums.matronics.com >>> _blank">http://www.matronics.com/contribution >> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: May 31, 2015
http://www.harborfreight.com/motorcycle-wheel-balancing-stand-98488.html Here is what ive used in the past. The axle sizes are slightly different. I remember it taking me a while to finally get the nose wheel balanced correctly. If the plane sits for too long, i will notice it bounce now and then. ________________________________________________________________________________
Date: Jun 01, 2015
Sorry, Les, but I can't answer. When I bought mine a few years ago, it was offered specifically as an aircraft wheel balancer on a different website. I am unable to relocate it. -------- RV-10 UC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442871#442871 ________________________________________________________________________________
Date: Jun 02, 2015
I would not rely on that as a tiebreaker. Once you get into a turn the centripetal forces start messing with the attitude solution much like your own senses, which we all know better not to rely on. The steeper the turn the bigger the error. To correct for the centripetal error you need to factor in speed, and I don't think the compass app does that, but I could be wrong, I never tried the app in flight. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442915#442915 ________________________________________________________________________________
Date: Jun 03, 2015
Lenny The purpose of a "tie breaker" is to verify which of your attitude indications are correct when two systems are in disagreement. It is mostly redundant information in modern EFIS systems as the EFIS will compare it's attitude information with pitot- static and GPS data and figure out which one is in error from that. It then alerts the pilot with it's determination of which attitude system is in fault. The pilot only has to verify that recommendation and the EFIS will run both screens on the good AHDRS . This all happens in a few seconds. The pilot should have a means of verifying the attitude information during those few seconds, hence a tie breaker. Any precession error or centripetal forces aren't a factor as your only interested in the displayed attitude of the tie breaker during the short period of time that your verifying the EFIS's solution to the displayed error. In VMC you could just look out the window, or in the bad old days you could try to fly with needle ball and airspeed. Heck we had to be able to fly an approach using only an airspeed indicator, altimeter, and an electric turn and bank even with all of it's precession errors. A modern standby suite should be able to give you all the info a needle, ball and airspeed gives you, but the panel real estate dedicated to those old dials would be better spent on a second screen with it's second, monitored AHDRS. Your IPhone velcroed to the panel with it's attitude info displayed could then be your tiebreaker. Chris Subject: RV10-List: Re: tie breaker From: "Lenny Iszak" <lenard(at)rapiddecision.com> I would not rely on that as a tiebreaker. Once you get into a turn the centripetal forces start messing with the attitude solution much like your own senses, which we all know better not to rely on. The steeper the turn the bigger the error. To correct for the centripetal error you need to factor in speed, and I don't think the compass app does that, but I could be wrong, I never tried the app in flight. Lenny ________________________________________________________________________________
Subject: throttle quadrant cable length
Date: Jun 03, 2015
The current CT Q-49.5 is 49.5 inches long. I seem to recall that another slightly longer length has been used on the IO540 installation on the quadrant 10s. Any comments? David McNeill N46007 900+ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Jun 03, 2015
Subject: Sad News
I'm sad to hear that Jeremy Monnett, CEO of Sonex, died in a crash at Oshkosh along with another Sonex employee, Mike Clark. I worked with Jeremy on the FAA 51% rule committee a few years ago. He was a great guy and very dedicated to experimental aviation. http://abcnews.go.com/US/wireStory/aircraft-manufacturers-ceo-mechanic-killed-plane-crash-31498294 --Dave ________________________________________________________________________________
Date: Jun 03, 2015
Subject: Re: throttle quadrant cable length
A slightly longer length for all three cables is better than what is supplied. I originally installed the standard cables on a standard IO-540 installation with the quadrant. I'm not sure there is a 'standard' quadrant installation but my quadrant seemed to end up where everyone elses has. It worked but at year 2 all three cables had frayed in spots and there was some melting of the plastic covering in spots on 1 or two. Per advice gleaned from the boards, I replaced all three with custom cables from California Push-Pull. Same spec as Vans supplied except the plastic coating was higher temp I believe. The cables I ordered, installed and am flying with are 176-VTT-2-47, -51, and -72. In retrospect, I wish I had gone with those in the original build. On 6/3/2015 11:23 AM, David wrote: > > The current CT Q-49.5 is 49.5 inches long. I seem to recall that > another slightly longer length has been used on the IO540 installation > on the quadrant 10s. Any comments? > > David McNeill > > N46007 900+ > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Missing step? 18-5 Fuel Tanks
Date: Jun 03, 2015
Just curious. I'm trimming up my wing root fairings and am running into a problem. Going back, I think I've found it. Attached is a photo of 18-5. They call for a dimple in the T-1005B (upper) shim. But the plans don't call for dimples in the T-1005C (lower) shim. The skin is dimpled (as called for under in the wing attach section), but this substructure isn't. Am I missing something in assuming these bottom shims need to be dimpled too? Or is there something I don't know/understand. Phil Sent from my iPhone ________________________________________________________________________________
Subject: Re: Missing step? 18-5 Fuel Tanks
Date: Jun 03, 2015
With photo this time. Sent from my iPhone > On Jun 3, 2015, at 8:41 PM, Phillip Perry wrote: > > Just curious. I'm trimming up my wing root fairings and am running into a problem. Going back, I think I've found it. > > Attached is a photo of 18-5. They call for a dimple in the T-1005B (upper ) shim. But the plans don't call for dimples in the T-1005C (lower) shim. > > The skin is dimpled (as called for under in the wing attach section), but t his substructure isn't. > > Am I missing something in assuming these bottom shims need to be dimpled t oo? Or is there something I don't know/understand. > > Phil > > > > Sent from my iPhone
Date: Jun 03, 2015
Phil, The difference is the top and bottom fairings join at the top, where you have the dimpled nutplates, while the rest of the holes go through more layers and can be countersunk. There is no skin joint on the bottom, just at the forward spar attach on top. Kelly On Wed, Jun 3, 2015 at 6:41 PM, Phillip Perry wrote: > > Just curious. I'm trimming up my wing root fairings and am running into a > problem. Going back, I think I've found it. > > Attached is a photo of 18-5. They call for a dimple in the T-1005B > (upper) shim. But the plans don't call for dimples in the T-1005C (lower) > shim. > > The skin is dimpled (as called for under in the wing attach section), but > this substructure isn't. > > Am I missing something in assuming these bottom shims need to be dimpled > too? Or is there something I don't know/understand. > > Phil > > > Sent from my iPhone > > ________________________________________________________________________________
Date: Jun 03, 2015
I am at the root fairing step and had to read and re read the plans to figure that one out...the holes that are not dimple get counter sunk to accept the dimpled root fairing... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=442968#442968 ________________________________________________________________________________
Date: Jun 03, 2015
Do you remember where that step can be found? That was going to be my plan. Sent from my iPhone > On Jun 3, 2015, at 9:21 PM, Rocketman1988 wrote: > > > I am at the root fairing step and had to read and re read the plans to figure that one out...the holes that are not dimple get counter sunk to accept the dimpled root fairing... > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=442968#442968 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 03, 2015
Phil, I just looked for it and didn't find the step. I'm not sure if I just decided to go ahead and do the countersinking as I was doing the wing attach or if I ran across it somewhere. PG 44-10 figure has mention of machine countersinking of the tank skin and shows the rest of the holes on the stub spar as though they were already done. Kelly On Wed, Jun 3, 2015 at 7:37 PM, Phillip Perry wrote: > > Do you remember where that step can be found? That was going to be my > plan. > > Sent from my iPhone > > > On Jun 3, 2015, at 9:21 PM, Rocketman1988 wrote: > > > > > > I am at the root fairing step and had to read and re read the plans to > figure that one out...the holes that are not dimple get counter sunk to > accept the dimpled root fairing... > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=442968#442968 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 03, 2015
Subject: Re: Learning to Fly
On 06/03/2015 06:35 PM, Jeff Carpenter wrote: > This is a great read... worth passing on to anyone interested in > learning to fly Thanks for sharing, as off-topic as it might be. As a flight instructor, I really enjoyed reading it. It's often hard for me to understand exactly what it's like for a student with zero knowledge of flight, and I think the author does a wonderful job of conveying exactly what the experience was like for him. Since it's of our job to try to see things from that point of view, I'd recommend it to any flight instructor. Berck (looks forward to parts 3 and 4) ________________________________________________________________________________
Subject: control cables
Date: Jun 04, 2015
After discussions with Vans and other Cablecraft assemblers, I have found the following. The standard cables as supplied by the kit manufacturer are rated for 200-300F and the contents of the cables then soften and melt with summer temperatures after shutdown. These are industrial grade cables. They are about $70-$80 and last several years, and then the controls begin to move with difficulty and must at some point be replaced. Cablecraft also makes aircraft grade cables that are rated to about 350F and cost 2-3 times the industrial. I am going to order them which are supposed to be airworthy for life of the airframe. This seems preferable to changing cables at 500 hour intervals. In the meantime I am ordering a throttle cable from California Push Pull to install until the stainless cables are ready. YMMV but when the T, P,M controls start to become difficult to move or jerky it is time. I have already replaced the original cables several years ago. David McNeill 2008 N46007 900+ TT --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Gauging interest in a fly-in in UPer land
Date: Jun 04, 2015
I am gauging interest in having a fly-in in Watersmeet, in the UP of Michiga n. We are staying up here with some friends and I can't help thinking that t his would be a perfect place for a fly-in. I keep thinking about Triple Tree and think this would be a great place to have a similar type of event for t hose in the north, probably in mid to late September. The place we are staying is the Northwoods Conference Center, 72MI. It has a mile-long paved runway and a lodge right next to the runway that can sleep a s many as 230 people. Camping would also be an option. They have a full comm ercial kitchen, so 3 meals a day would be available. There is a big private l ake behind the lodge for fishing, canoeing, kayaking and swimming. There is a 3.7 mile road around the lake for on-road biking or hiking, and there are m iles and miles of bike and hiking trails. The setting is amazingly beautiful . The lodge also has a gym with a volleyball net, a big auditorium, a big lobb y with couches and chairs, a 2-lane bowling alley (out of order right now, b ut hopefully fixed by Sept) and a game room. The cost per room is $50/night and each normal room has 2 twin beds and a pr ivate bathroom, so it would cost $25/night/person for the room. There are su ites available for families, but I don't know the costs right now. Meals are all buffet meals (whoever organizes it can pick the menu), and are $7/perso n for breakfast and lunch and $9/person for dinner. So, for $50/day/person y ou could enjoy a relaxing time with a bunch of other airplane people. I am s ure whoever organizes the event may opt to have some kind of registration fe e to cover organization costs, but the above mentioned fees cover all of the costs of the conference center. Those choosing to camp next to their planes would just pay for meals and registration costs, if any. The conference center is waned and operated by a Christian ministry, so they don't allow any alcoholic beverages on the grounds. I may or may not be a part of it, but just thought I would gauge interest th at others may have for what I think would be a perfect setting for a long we ekend fly-in. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad ________________________________________________________________________________
Date: Jun 04, 2015
Subject: Re: Gauging interest in a fly-in in UPer land
Sounds good to me, could we allow builders to fly in their non RV aircraft. I could bring pictures of he build and tape them to the Cessna. :) On Thu, Jun 4, 2015 at 2:46 PM, Jesse Saint wrote: > I am gauging interest in having a fly-in in Watersmeet, in the UP of > Michigan. We are staying up here with some friends and I can't help > thinking that this would be a perfect place for a fly-in. I keep thinking > about Triple Tree and think this would be a great place to have a similar > type of event for those in the north, probably in mid to late September. > > The place we are staying is the Northwoods Conference Center, 72MI. It has > a mile-long paved runway and a lodge right next to the runway that can > sleep as many as 230 people. Camping would also be an option. They have a > full commercial kitchen, so 3 meals a day would be available. There is a > big private lake behind the lodge for fishing, canoeing, kayaking and > swimming. There is a 3.7 mile road around the lake for on-road biking or > hiking, and there are miles and miles of bike and hiking trails. The > setting is amazingly beautiful. > > The lodge also has a gym with a volleyball net, a big auditorium, a big > lobby with couches and chairs, a 2-lane bowling alley (out of order right > now, but hopefully fixed by Sept) and a game room. > > The cost per room is $50/night and each normal room has 2 twin beds and a > private bathroom, so it would cost $25/night/person for the room. There are > suites available for families, but I don't know the costs right now. Meals > are all buffet meals (whoever organizes it can pick the menu), and are > $7/person for breakfast and lunch and $9/person for dinner. So, for > $50/day/person you could enjoy a relaxing time with a bunch of other > airplane people. I am sure whoever organizes the event may opt to have some > kind of registration fee to cover organization costs, but the above > mentioned fees cover all of the costs of the conference center. Those > choosing to camp next to their planes would just pay for meals and > registration costs, if any. > > The conference center is waned and operated by a Christian ministry, so > they don't allow any alcoholic beverages on the grounds. > > I may or may not be a part of it, but just thought I would gauge interest > that others may have for what I think would be a perfect setting for a long > weekend fly-in. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > * > > > * > > ________________________________________________________________________________
Date: Jun 04, 2015
Two additional points of interest: - If using push/pull controls the throttle cable Van's recommends is too short (47.5"). Get the one Van's sells for the RV-7 IO-360 (50.5"). - Agree on the heat issue with any of the cable options. Where the cable runs near the engine I put it through a small diameter piece of fire sleeve, like Aeroquip AE102-8. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Sent: Thursday, June 04, 2015 2:21 PM Subject: RV10-List: control cables After discussions with Vans and other Cablecraft assemblers, I have found the following. The standard cables as supplied by the kit manufacturer are rated for 200-300F and the contents of the cables then soften and melt with summer temperatures after shutdown. These are industrial grade cables. They are about $70-$80 and last several years, and then the controls begin to move with difficulty and must at some point be replaced. Cablecraft also makes aircraft grade cables that are rated to about 350F and cost 2-3 times the industrial. I am going to order them which are supposed to be airworthy for life of the airframe. This seems preferable to changing cables at 500 hour intervals. In the meantime I am ordering a throttle cable from California Push Pull to install until the stainless cables are ready. YMMV but when the T, P,M controls start to become difficult to move or jerky it is time. I have already replaced the original cables several years ago. David McNeill 2008 N46007 900+ TT _____ Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Jun 04, 2015
Date: Jun 04, 2015
Hi Tim Which model of wheel balancer did you get. I am interested in getting one but am unsure as to which model is appropriate for the standard Van's wheels. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443045#443045 ________________________________________________________________________________
Date: Jun 04, 2015
Subject: Re: control cables
Did you look at McFarlane for cables? They offer RV-10 specific cables in aircraft grade. They have PMA for some Cessna and Piper, and now are OEM supplier for Mooney. I don't recall exact pricing, probably between $250 and $300 per cable. Teflon lined, first rate construction. On Thu, Jun 4, 2015 at 11:21 AM, David wrote: > After discussions with Vans and other Cablecraft assemblers, I have > found the following. The standard cables as supplied by the kit > manufacturer are rated for 200-300F and the contents of the cables then > soften and melt with summer temperatures after shutdown. These are > industrial grade cables. They are about $70-$80 and last several years, and > then the controls begin to move with difficulty and must at some point be > replaced. Cablecraft also makes aircraft grade cables that are rated to > about 350F and cost 2-3 times the industrial. I am going to order them > which are supposed to be airworthy for life of the airframe. This seems > preferable to changing cables at 500 hour intervals. In the meantime I am > ordering a throttle cable from California Push Pull to install until the > stainless cables are ready. YMMV but when the T, P,M controls start to > become difficult to move or jerky it is time. I have already replaced the > original cables several years ago. > > > David McNeill > > 2008 N46007 900+ TT > > > ------------------------------ > [image: Avast logo] > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > * > > > * > > ________________________________________________________________________________
Subject: Tech in the front office - Part Deux
Date: Jun 04, 2015
Hi So over the past 8 days I have out 3500 nm on my -10 and have been very pleased with performance. It is a great X-try machine and uber comfortable. The only fly in the ointment has been that my EFIS screens don't support Canadian XM Weather. While ADSB weather is a possibility in the US, ADSB is not available in Canada. When I was flying back to Canada from the US, I found that the lack of wx info meant I had to overnight in KGFK as I didn't want to thread my way through the wx. So as to reduce ongoing subscription costs I am thought I would repurpose my XM weather receiver to work with an IPAD and the Fltplan GO app. While I don't believe that the approach plates are georef'd, I can live with that as my EFIS screens show the approach tracks. Has anyone used XM wx with the Fltplan GO app. I would be very interested in first hand opinions. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443055#443055 ________________________________________________________________________________
Date: Jun 04, 2015
Here's my writeup from 2008 when I bought it. http://www.myrv10.com/N104CD/maintenance/20080503/index.html Tim On 6/4/2015 5:54 PM, kearney wrote: > > Hi Tim > > Which model of wheel balancer did you get. I am interested in getting one but am unsure as to which model is appropriate for the standard Van's wheels. > > Cheers > > Les > ________________________________________________________________________________
Date: Jun 04, 2015
Hi Tim As always, many thanks for the veritable fount of information on your site. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443060#443060 ________________________________________________________________________________
Subject: RV9a
Date: Jun 05, 2015
navworx exp 600 deliveries Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443085#443085 ________________________________________________________________________________
Date: Jun 05, 2015
California push-pull is a Cablecraft assembler. The cables I spec'd previously were $60 to $70 each 2 years ago. I believe the ones I ordered are rated to a higher temp than the Vans supplied cables, i.e. to 350F. The marine cables seem to have more stainless than we probably need for aircraft. text sent - call me Bill Watson On 6/4/2015 2:21 PM, David wrote: > > After discussions with Vans and other Cablecraft assemblers, I have > found the following. The standard cables as supplied by the kit > manufacturer are rated for 200-300F and the contents of the cables > then soften and melt with summer temperatures after shutdown. These > are industrial grade cables. They are about $70-$80 and last several > years, and then the controls begin to move with difficulty and must at > some point be replaced. Cablecraft also makes aircraft grade cables > that are rated to about 350F and cost 2-3 times the industrial. I am > going to order them which are supposed to be airworthy for life of the > airframe. This seems preferable to changing cables at 500 hour > intervals. In the meantime I am ordering a throttle cable from > California Push Pull to install until the stainless cables are ready. > YMMV but when the T, P,M controls start to become difficult to move or > jerky it is time. I have already replaced the original cables several > years ago. > > David McNeill > > 2008 N46007 900+ TT > > > ------------------------------------------------------------------------ > Avast logo > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > * > > > * > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > ________________________________________________________________________________
Subject: Shout Out to Barrett
Date: Jun 06, 2015
Hi Since Feb I have put about 70 hours on my *new* Barrett Precision Engines IO-540 that has both 9:1 pistons and cold air induction. Of the 70 hours, 27 were over an eight day trip to eastern Canada from Alberta (for the geographically challenged hat is similar to going from Montana to New York). In short I am very, very happy with how the engine has performed in hot and cold weather. I recently took the engine up to 17K and still had ponies to spare. My CofA limit is 20K and I might try that in the soon. I haven't been aggressive in leaning the engine, but I have seen 155+ Kt TAS at 8-10k at 12-13 GPH using 21 square. Over the next couple of weeks I plan to do a few controlled tests to see what the impact of different power settings are. The engine is very smooth - I have an MT 3 blade prop - one MUST look good on the flight line!). Initial indications are the the injectors as provided are quite close when leaning but I will have to do the GAMI test to confirm. I am still mastering hot starts but the purge valve makes hot starts fairly simple. Fortunately I have the fuel return lines already plumbed so I could take advantage of this option. Over the past 40 hours my oil consumption has been dropping, it now seems to be around 13 hrs / qt and may be lower yet. I am still working out how much oil the sump likes - I *think* it is something less than 6.5 qts. Part of my initial oil loss may have been to higher than desired oil levels in the sump and the overall break in process. All that being said, Allan and Rhonda Barrett have provided great after sales service. Service really matters when problems need to be fixed or questions (dumb and otherwise) need to be answered. My experience with both has been great. I always felt that Allan and Rhonda were as engaged with my success as I was was. Anyway, I just wanted to acknowledge the great product and service that Barrett Precision Engines provides. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443156#443156 ________________________________________________________________________________
Subject: Oil On The Belly
Date: Jun 06, 2015
Hi No this is not a kinky post ..... Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go. It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. Anyway. this will be my product of choice in the future. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443160#443160 ________________________________________________________________________________
Date: Jun 06, 2015
Subject: Re: Shout Out to Barrett
I second your observations on Allen, Rhonda and of course the Quality of Product from Barrett. On Jun 6, 2015 7:35 PM, "kearney" wrote: > > Hi > > Since Feb I have put about 70 hours on my *new* Barrett Precision Engines > IO-540 that has both 9:1 pistons and cold air induction. > > Of the 70 hours, 27 were over an eight day trip to eastern Canada from > Alberta (for the geographically challenged hat is similar to going from > Montana to New York). > > In short I am very, very happy with how the engine has performed in hot > and cold weather. I recently took the engine up to 17K and still had > ponies to spare. My CofA limit is 20K and I might try that in the soon. > > I haven't been aggressive in leaning the engine, but I have seen 155+ Kt > TAS at 8-10k at 12-13 GPH using 21 square. Over the next couple of weeks I > plan to do a few controlled tests to see what the impact of different > power settings are. > > The engine is very smooth - I have an MT 3 blade prop - one MUST look good > on the flight line!). Initial indications are the the injectors as provided > are quite close when leaning but I will have to do the GAMI test to confirm. > > I am still mastering hot starts but the purge valve makes hot starts > fairly simple. Fortunately I have the fuel return lines already plumbed so > I could take advantage of this option. > > Over the past 40 hours my oil consumption has been dropping, it now seems > to be around 13 hrs / qt and may be lower yet. I am still working out how > much oil the sump likes - I *think* it is something less than 6.5 qts. Part > of my initial oil loss may have been to higher than desired oil levels in > the sump and the overall break in process. > > > All that being said, Allan and Rhonda Barrett have provided great after > sales service. Service really matters when problems need to be fixed or > questions (dumb and otherwise) need to be answered. My experience with both > has been great. I always felt that Allan and Rhonda were as engaged with my > success as I was was. > > Anyway, I just wanted to acknowledge the great product and service that > Barrett Precision Engines provides. > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=443156#443156 > > ________________________________________________________________________________
Date: Jun 07, 2015
Subject: Re: Oil On The Belly
On sale at Amazon now, $17.43/gallon and Prime available. Marcus On Saturday, June 6, 2015 10:55 PM, kearney wrote: Hi No this is not a kinky post ..... Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. U ntil recently these were lost the chaos that is my garage. As I needed to c lean my belly (the RV10 that is) I decided to give this rediscovered produc t a go. It did an excellent job of removing a very heavy oil layer that was deposit ed during my engine break-in. Much, much=C2- nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. Anyway. this will be my product of choice in the future. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443160#443160 S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Jun 06, 2015
Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Someone made the mistake of using it and although it did indeed remove the oil and carbon very well, it etched the paint and the aircraft had to be repainted. Dawn with warm water in a squirt bottle can work well also. Justin > On Jun 6, 2015, at 18:44, kearney wrote: > > > Hi > > No this is not a kinky post ..... > > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go. > > It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. > > > Anyway. this will be my product of choice in the future. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=443160#443160 > > > > > > > > > > ________________________________________________________________________________
Date: Jun 06, 2015
There is Simple Green, original product, which the military banned from its aircraft because it was corrosive. The Extreme Aircraft Simple Green was developed to correct that, and is supposed to be safe and military approved. On Sat, Jun 6, 2015 at 9:12 PM, Justin Jones wrote: > > Be careful with simple green. It is very abrasive and will etch paint and > aluminum. We are not allowed to use it on our King Airs, or Lear jets. > Someone made the mistake of using it and although it did indeed remove the > oil and carbon very well, it etched the paint and the aircraft had to be > repainted. > > Dawn with warm water in a squirt bottle can work well also. > > Justin > > > > On Jun 6, 2015, at 18:44, kearney wrote: > > > > > > Hi > > > > No this is not a kinky post ..... > > > > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple > Green. Until recently these were lost the chaos that is my garage. As I > needed to clean my belly (the RV10 that is) I decided to give this > rediscovered product a go. > > > > It did an excellent job of removing a very heavy oil layer that was > deposited during my engine break-in. Much, much nicer than Varsol or > avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. > > > > > > Anyway. this will be my product of choice in the future. > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=443160#443160 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 06, 2015
I have the same Barrett engine and prop as you do. I can agree 100% with wh at you've said. Superb engine and superb people! > Subject: RV10-List: Shout Out to Barrett > From: kearney(at)shaw.ca > Date: Sat=2C 6 Jun 2015 19:26:09 -0700 > To: rv10-list(at)matronics.com > > > Hi > > Since Feb I have put about 70 hours on my *new* Barrett Precision Engines IO-540 that has both 9:1 pistons and cold air induction. > > Of the 70 hours=2C 27 were over an eight day trip to eastern Canada from Alberta (for the geographically challenged hat is similar to going from Mon tana to New York). > > In short I am very=2C very happy with how the engine has performed in hot and cold weather. I recently took the engine up to 17K and still had poni es to spare. My CofA limit is 20K and I might try that in the soon. > > I haven't been aggressive in leaning the engine=2C but I have seen 155+ K t TAS at 8-10k at 12-13 GPH using 21 square. Over the next couple of weeks I plan to do a few controlled tests to see what the impact of different p ower settings are. > > The engine is very smooth - I have an MT 3 blade prop - one MUST look goo d on the flight line!). Initial indications are the the injectors as provid ed are quite close when leaning but I will have to do the GAMI test to conf irm. > > I am still mastering hot starts but the purge valve makes hot starts fair ly simple. Fortunately I have the fuel return lines already plumbed so I co uld take advantage of this option. > > Over the past 40 hours my oil consumption has been dropping=2C it now see ms to be around 13 hrs / qt and may be lower yet. I am still working out ho w much oil the sump likes - I *think* it is something less than 6.5 qts. Pa rt of my initial oil loss may have been to higher than desired oil levels in the sump and the overall break in process. > > > All that being said=2C Allan and Rhonda Barrett have provided great afte r sales service. Service really matters when problems need to be fixed or q uestions (dumb and otherwise) need to be answered. My experience with both has been great. I always felt that Allan and Rhonda were as engaged with my success as I was was. > > Anyway=2C I just wanted to acknowledge the great product and service that Barrett Precision Engines provides. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=443156#443156 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Jun 06, 2015
Justin There is a difference between Simple Green and Extreme Simple Green. The latter is safe the former not so much. Cheers Led Sent from my iPhone > On Jun 6, 2015, at 10:12 PM, Justin Jones wrote: > > > Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Someone made the mistake of using it and although it did indeed remove the oil and carbon very well, it etched the paint and the aircraft had to be repainted. > > Dawn with warm water in a squirt bottle can work well also. > > Justin > > > >> On Jun 6, 2015, at 18:44, kearney wrote: >> >> >> Hi >> >> No this is not a kinky post ..... >> >> Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go. >> >> It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. >> >> >> Anyway. this will be my product of choice in the future. >> >> Cheers >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=443160#443160 >> >> >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
Date: Jun 06, 2015
Simple Green reformulated a new product "Aviation Approved". It is relabeled for aircraft. The issue of hydrogen embrittlement and swelling of tefzel wiring was corrected. The product Les was referencing to was offered at Oshkosh when the product was released. The regular stuff is still bad. On Jun 6, 2015 9:17 PM, "Justin Jones" wrote: > > Be careful with simple green. It is very abrasive and will etch paint and > aluminum. We are not allowed to use it on our King Airs, or Lear jets. > Someone made the mistake of using it and although it did indeed remove the > oil and carbon very well, it etched the paint and the aircraft had to be > repainted. > > Dawn with warm water in a squirt bottle can work well also. > > Justin > > > > On Jun 6, 2015, at 18:44, kearney wrote: > > > > > > Hi > > > > No this is not a kinky post ..... > > > > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple > Green. Until recently these were lost the chaos that is my garage. As I > needed to clean my belly (the RV10 that is) I decided to give this > rediscovered product a go. > > > > It did an excellent job of removing a very heavy oil layer that was > deposited during my engine break-in. Much, much nicer than Varsol or > avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. > > > > > > Anyway. this will be my product of choice in the future. > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=443160#443160 > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "RV10(at)TEXASRV10.COM" <rv10(at)texasrv10.com>
Date: Jun 07, 2015
Another vote added here. Same experiences with same built up engine except m aybe for the EFII Ignition. 135 hours on the engine and happy as can be. I d id need to rebalance my injectors a bit as I am running the FM300 (not sayin g this is the reason why) but did have an over 1 gal spread in the beginning . Gaylon Koenning > On Jun 6, 2015, at 11:29 PM, Danny Riggs wrote: > > I have the same Barrett engine and prop as you do. I can agree 100% with w hat you've said. Superb engine and superb people! > > > Subject: RV10-List: Shout Out to Barrett > > From: kearney(at)shaw.ca > > Date: Sat, 6 Jun 2015 19:26:09 -0700 > > To: rv10-list(at)matronics.com > > > > > > Hi > > > > Since Feb I have put about 70 hours on my *new* Barrett Precision Engine s IO-540 that has both 9:1 pistons and cold air induction. > > > > Of the 70 hours, 27 were over an eight day trip to eastern Canada from A lberta (for the geographically challenged hat is similar to going from Monta na to New York). > > > > In short I am very, very happy with how the engine has performed in hot a nd cold weather. I recently took the engine up to 17K and still had ponies t o spare. My CofA limit is 20K and I might try that in the soon. > > > > I haven't been aggressive in leaning the engine, but I have seen 155+ Kt TAS at 8-10k at 12-13 GPH using 21 square. Over the next couple of weeks I p lan to do a few controlled tests to see what the impact of different power s ettings are. > > > > The engine is very smooth - I have an MT 3 blade prop - one MUST look go od on the flight line!). Initial indications are the the injectors as provid ed are quite close when leaning but I will have to do the GAMI test to confi rm. > > > > I am still mastering hot starts but the purge valve makes hot starts fai rly simple. Fortunately I have the fuel return lines already plumbed so I co uld take advantage of this option. > > > > Over the past 40 hours my oil consumption has been dropping, it now seem s to be around 13 hrs / qt and may be lower yet. I am still working out how m uch oil the sump likes - I *think* it is something less than 6.5 qts. Part o f my initial oil loss may have been to higher than desired oil levels in the sump and the overall break in process. > > > > > > All that being said, Allan and Rhonda Barrett have provided great after s ales service. Service really matters when problems need to be fixed or quest ions (dumb and otherwise) need to be answered. My experience with both has b een great. I always felt that Allan and Rhonda were as engaged with my succe ss as I was was. > > > > Anyway, I just wanted to acknowledge the great product and service that B arrett Precision Engines provides. > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=443156#443156 > > > > > > > > > > > > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 07, 2015
You can use Goop and paper towel without the abrasives Does a good job too. do no archive > On Jun 7, 2015, at 1:17 AM, John Cox wrote: > > Simple Green reformulated a new product "Aviation Approved". It is relabeled for aircraft. The issue of hydrogen embrittlement and swelling of tefzel wiring was corrected. The product Les was referencing to was offered at Oshkosh when the product was released. > > The regular stuff is still bad. > > On Jun 6, 2015 9:17 PM, "Justin Jones" > wrote: > > > Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Someone made the mistake of using it and although it did indeed remove the oil and carbon very well, it etched the paint and the aircraft had to be repainted. > > Dawn with warm water in a squirt bottle can work well also. > > Justin > > > > > On Jun 6, 2015, at 18:44, kearney > wrote: > > > > > > > Hi > > > > No this is not a kinky post ..... > > > > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Green. Until recently these were lost the chaos that is my garage. As I needed to clean my belly (the RV10 that is) I decided to give this rediscovered product a go. > > > > It did an excellent job of removing a very heavy oil layer that was deposited during my engine break-in. Much, much nicer than Varsol or avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. > > > > > > Anyway. this will be my product of choice in the future. > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=443160#443160 <http://forums.matronics.com/viewtopic.php?p=443160#443160> > > > > > > > > > > > > > > > > > > > > > > > ========== > -List" target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > _blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > target="_blank">http://www.matronics.com/contribution > ========== > > > > > <http://www.matronics.com/Navigator?RV10-List> <http://www.matronics.com/contribution> > ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Jun 07, 2015
I use GoJo without the abrasive on the belly. It gets the oil off easily and leaves a cleaned shiny finish. Robert Sent from my iPad > On Jun 7, 2015, at 12:17 AM, John Cox wrote: > > Simple Green reformulated a new product "Aviation Approved". It is relabe led for aircraft. The issue of hydrogen embrittlement and swelling of tefze l wiring was corrected. The product Les was referencing to was offered at O shkosh when the product was released. > > The regular stuff is still bad. > >> On Jun 6, 2015 9:17 PM, "Justin Jones" wrote : > >> >> Be careful with simple green. It is very abrasive and will etch paint and aluminum. We are not allowed to use it on our King Airs, or Lear jets. Some one made the mistake of using it and although it did indeed remove the oil a nd carbon very well, it etched the paint and the aircraft had to be repainte d. >> >> Dawn with warm water in a squirt bottle can work well also. >> >> Justin >> >> >> >> > On Jun 6, 2015, at 18:44, kearney wrote: >> > >> > >> > Hi >> > >> > No this is not a kinky post ..... >> > >> > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple Gree n. Until recently these were lost the chaos that is my garage. As I needed t o clean my belly (the RV10 that is) I decided to give this rediscovered prod uct a go. >> > >> > It did an excellent job of removing a very heavy oil layer that was dep osited during my engine break-in. Much, much nicer than Varsol or avgas. I u sed only 2/3 of a 10 oz spray bottle to clean my belly. >> > >> > >> > Anyway. this will be my product of choice in the future. >> > >> > Cheers >> > >> > Les >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=443160#443160 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Subject: WTS iPhone 6 $350 128GB S6 Edge $350 128GB Original Unlocked
From: "marquisroy" <marquisroyyd(at)oncyclesports.com>
Date: Jun 07, 2015
We stand behind everything we sell. 100% Genuine Products. You will definitely love what you are about to purchase from us. But If you are not satisfied with your purchase, you can return it For a replacement or refund. Items must be returned within 15days Of purchase. and everything must be in Original box feel free to contact us if you have any questions Contact us info(at)mblexclusively.com Cash on delivery around our Territory only 3 Samsung Galaxy S6 128GB $900 3 Samsung Galaxy S6 edge 64GB $1,050 3 Samsung Galaxy S6 edge 128GB $1,200 10 Samsung Galaxy S6 128GB $2,500 20 Samsung Galaxy S6 128GB $4000 10 Samsung Galaxy S6 edge 64GB $3000 20 Samsung Galaxy S6 edge 64GB $5000 10 Samsung Galaxy S6 edge 128GB $3500 20 Samsung Galaxy S6 edge 128GB $6000 Samsung Galaxy S6 128GB $380 Samsung Galaxy S6 32GB SOLD OUT Samsung Galaxy S6 64GB SOLD OUT Samsung Galaxy S6 edge 32GB SOLD OUT Samsung Galaxy S6 edge 64GB $400 Samsung Galaxy S6 edge 128GB $470 Apple iPhone 6 16GB SOLD OUT Apple iPhone 6 64GB SOLD OUT Apple iPhone 6 128GB $350 Apple iPhone 6 Plus 16GB SOLD OUT Apple iPhone 6 Plus 64GB $420 Apple iPhone 6 Plus 128GB $460 3 Apple iPhone 6 128GB $900 3 Apple iPhone 6 Plus 128GB $1,200 3 Apple iPhone 6 Plus 64GB $1,110 10 Apple iPhone 6 128GB $2,500 20 Apple iPhone 6 128GB $4000 10 Apple iPhone 6 Plus 64GB $3000 20 Apple iPhone 6 Plus 64GB $5000 10 Apple iPhone 6 Plus 128GB 3,500 20 Apple iPhone 6 Plus 128GB $6000 Its free shipping worldwide via FedEx, UPS & DHL and it takes 3days to deliver to any location Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443188#443188 ________________________________________________________________________________
Date: Jun 07, 2015
GoJo original, in a tub, without pumice works great. Getting harder to find as marketeers think everyone wants pumice to scrub their greasy hands. On Sun, Jun 7, 2015 at 7:43 AM, Robert Brunkenhoefer wrote: > I use GoJo without the abrasive on the belly. It gets the oil off easily > and leaves a cleaned shiny finish. Robert > > Sent from my iPad > > On Jun 7, 2015, at 12:17 AM, John Cox wrote: > > Simple Green reformulated a new product "Aviation Approved". It is > relabeled for aircraft. The issue of hydrogen embrittlement and swelling > of tefzel wiring was corrected. The product Les was referencing to was > offered at Oshkosh when the product was released. > > The regular stuff is still bad. > On Jun 6, 2015 9:17 PM, "Justin Jones" wrote: > >> > >> >> Be careful with simple green. It is very abrasive and will etch paint and >> aluminum. We are not allowed to use it on our King Airs, or Lear jets. >> Someone made the mistake of using it and although it did indeed remove the >> oil and carbon very well, it etched the paint and the aircraft had to be >> repainted. >> >> Dawn with warm water in a squirt bottle can work well also. >> >> Justin >> >> >> >> > On Jun 6, 2015, at 18:44, kearney wrote: >> > >> > >> > Hi >> > >> > No this is not a kinky post ..... >> > >> > Years go at KOSH I got a couple of 10 oz samples of Extreme Simple >> Green. Until recently these were lost the chaos that is my garage. As I >> needed to clean my belly (the RV10 that is) I decided to give this >> rediscovered product a go. >> > >> > It did an excellent job of removing a very heavy oil layer that was >> deposited during my engine break-in. Much, much nicer than Varsol or >> avgas. I used only 2/3 of a 10 oz spray bottle to clean my belly. >> > >> > >> > Anyway. this will be my product of choice in the future. >> > >> > Cheers >> > >> > Les >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=443160#443160 >> > >> > >> > >> > >> > >> > >> > >> > >> > >> > >> >> >> ========== >> -List" target="_blank">http://www.matronics.com/Navigator?RV10-List >> ========== >> FORUMS - >> _blank">http://forums.matronics.com >> ========== >> b Site - >> -Matt Dralle, List Admin. >> target="_blank">http://www.matronics.com/contribution >> ========== >> >> >> >> > > * > > > * > > ________________________________________________________________________________
Subject: reminder of window options other than Vans
Date: Jun 09, 2015
This weekend I was reminded that many may have forgotten that there is the option to get better quality parts from http://www.vansaircrafttires.com/categories/RV%252d10/ (Desser Tires) than what is in the kits. I was involved with the front windscreen fitting, when my Vans bought one was warped in the bottom corner. They come pretty close to be ready to install without major surgery. The side windows, I hear, fit right in =9Cas is=9D. Also Desser is where Vans gets the tires in the kits. If I were doing all this again I would just order the tire package- http://www.vansaircrafttires.com/rv-10-main-tire-package-special-save-10- two-15-600-6pr-retreads-two-aero-classic-easy-flate-tubes/?page_context= category&faceted_search=0. Better tires, tubes and the same price. I have seen first hand the attention to detail Desser strives for. I gain nothing from this other than knowing that I have told new builders that there are great options, for the same, maybe less, than getting what is in the kits. If you havent bought the windows and windscreen, I guarantee you will not regret going this route, less cutting, shaping and better glass in general. Pascal ________________________________________________________________________________
Date: Jun 09, 2015
I can concur about Desser. Good products. Dan From: rv10flyer(at)live.com Subject: RV10-List: reminder of window options other than Vans Date: Tue=2C 9 Jun 2015 07:40:52 -0700 =0A =0A =0A =0A This weekend I was reminded that many may have forgotten that there is the =0A option to get better quality parts from http://www.vansaircrafttires.com/ca tegories/RV%252d10/ =0A (Desser Tires) than what is in the kits.=0A =0A I was involved with the front windscreen fitting=2C when my Vans bought one =0A was warped in the bottom corner. They come pretty close to be ready to inst all =0A without major surgery. The side windows=2C I hear=2C fit right in =93as is =94. Also =0A Desser is where Vans gets the tires in the kits. If I were doing all this a gain =0A I would just order the tire package- http://www.vansaircrafttires.com/rv-10 -main-tire-package-special-save-10-two-15-600-6pr-retreads-two-aero-classic -easy-flate-tubes/?page_context=category&faceted_search=0. =0A Better tires=2C tubes and the same price.=0A =0A I have seen first hand the attention to detail Desser strives for. I gain =0A nothing from this other than knowing that I have told new builders that the re =0A are great options=2C for the same=2C maybe less=2C than getting what is in the =0A kits.=0A =0A If you havent bought the windows and windscreen=2C I guarantee you will not =0A regret going this route=2C less cutting=2C shaping and better glass in =0A general.=0A =0A Pascal =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Jun 09, 2015
Subject: Re: reminder of window options other than Vans
I have all the Cee Baileys (Desser) windows in my plane. There was no major cutting required to install, but there was a bit of belt sander trimming on all of the windows to get a perfect fit. From what I've read of the Van's windows, it was quite a bit less work, but none of them just "popped right in". I am very happy with the end results though. On Tue, Jun 9, 2015 at 9:40 AM, Pascal wrote: > This weekend I was reminded that many may have forgotten that there is > the option to get better quality parts from > http://www.vansaircrafttires.com/categories/RV%252d10/ (Desser Tires) > than what is in the kits. > > I was involved with the front windscreen fitting, when my Vans bought one > was warped in the bottom corner. They come pretty close to be ready to > install without major surgery. The side windows, I hear, fit right in =9Cas > is=9D. Also Desser is where Vans gets the tires in the kits. If I w ere doing > all this again I would just order the tire package- > http://www.vansaircrafttires.com/rv-10-main-tire-package-special-save-10- two-15-600-6pr-retreads-two-aero-classic-easy-flate-tubes/?page_context=c ategory&faceted_search=0. > Better tires, tubes and the same price. > > I have seen first hand the attention to detail Desser strives for. I gain > nothing from this other than knowing that I have told new builders that > there are great options, for the same, maybe less, than getting what is i n > the kits. > > If you havent bought the windows and windscreen, I guarantee you will not > regret going this route, less cutting, shaping and better glass in genera l. > > Pascal > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 09, 2015
As someone who just installed the rear windows, they were a major PIA. I don't know if they were easier than Van's but I had real issues getting them installed. The curve on the plexi did not match the curve of the cabin top and required a lot of force to keep them flush. I ended up having to use ratchet straps and gorilla tape to keep them somewhat in place. Even with all of that, they ended up somewhat proud on some of the edges. I have dry fit the windshield and have a 1/2" gap between the cabin top vertical flange as well as a gap between the upper fuselage and the plex in several places. None of these items are insurmountable, but they have definitely required much more work to get them to fit than I had thought. Shannon Hicks On Tue, Jun 9, 2015 at 10:12 AM, Ed Kranz wrote: > I have all the Cee Baileys (Desser) windows in my plane. There was no > major cutting required to install, but there was a bit of belt sander > trimming on all of the windows to get a perfect fit. From what I've read of > the Van's windows, it was quite a bit less work, but none of them just > "popped right in". I am very happy with the end results though. > > On Tue, Jun 9, 2015 at 9:40 AM, Pascal wrote: > >> This weekend I was reminded that many may have forgotten that there is >> the option to get better quality parts from >> http://www.vansaircrafttires.com/categories/RV%252d10/ (Desser Tires) >> than what is in the kits. >> >> I was involved with the front windscreen fitting, when my Vans bought on e >> was warped in the bottom corner. They come pretty close to be ready to >> install without major surgery. The side windows, I hear, fit right in =9Cas >> is=9D. Also Desser is where Vans gets the tires in the kits. If I were doing >> all this again I would just order the tire package- >> http://www.vansaircrafttires.com/rv-10-main-tire-package-special-save-10 -two-15-600-6pr-retreads-two-aero-classic-easy-flate-tubes/?page_context= category&faceted_search=0. >> Better tires, tubes and the same price. >> >> I have seen first hand the attention to detail Desser strives for. I gai n >> nothing from this other than knowing that I have told new builders that >> there are great options, for the same, maybe less, than getting what is in >> the kits. >> >> If you havent bought the windows and windscreen, I guarantee you will no t >> regret going this route, less cutting, shaping and better glass in gener al. >> >> Pascal >> >> * >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com <http://forums.matronics.com> >> _blank">http://www.matronics.com/contribution >> >> * >> >> > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Date: Jun 09, 2015
I ended up using small holes in the glass and put clecos to hold. They got filled in of course during the final finishing. Date: Tue=2C 9 Jun 2015 10:56:35 -0500 Subject: Re: RV10-List: reminder of window options other than Vans From: civeng123(at)gmail.com As someone who just installed the rear windows=2C they were a major PIA. I don't know if they were easier than Van's but I had real issues getting th em installed. The curve on the plexi did not match the curve of the cabin t op and required a lot of force to keep them flush. I ended up having to us e ratchet straps and gorilla tape to keep them somewhat in place. Even wit h all of that=2C they ended up somewhat proud on some of the edges. I have dry fit the windshield and have a 1/2" gap between the cabin top ver tical flange as well as a gap between the upper fuselage and the plex in se veral places. None of these items are insurmountable=2C but they have definitely required much more work to get them to fit than I had thought. Shannon Hicks On Tue=2C Jun 9=2C 2015 at 10:12 AM=2C Ed Kranz wrote: I have all the Cee Baileys (Desser) windows in my plane. There was no major cutting required to install=2C but there was a bit of belt sander trimming on all of the windows to get a perfect fit. From what I've read of the Van 's windows=2C it was quite a bit less work=2C but none of them just "popped right in". I am very happy with the end results though. On Tue=2C Jun 9=2C 2015 at 9:40 AM=2C Pascal wrote: =0A =0A =0A =0A This weekend I was reminded that many may have forgotten that there is the =0A option to get better quality parts from http://www.vansaircrafttires.com/ca tegories/RV%252d10/ =0A (Desser Tires) than what is in the kits.=0A =0A I was involved with the front windscreen fitting=2C when my Vans bought one =0A was warped in the bottom corner. They come pretty close to be ready to inst all =0A without major surgery. The side windows=2C I hear=2C fit right in =93as is =94. Also =0A Desser is where Vans gets the tires in the kits. If I were doing all this a gain =0A I would just order the tire package- http://www.vansaircrafttires.com/rv-10 -main-tire-package-special-save-10-two-15-600-6pr-retreads-two-aero-classic -easy-flate-tubes/?page_context=category&faceted_search=0. =0A Better tires=2C tubes and the same price.=0A =0A I have seen first hand the attention to detail Desser strives for. I gain =0A nothing from this other than knowing that I have told new builders that the re =0A are great options=2C for the same=2C maybe less=2C than getting what is in the =0A kits.=0A =0A If you havent bought the windows and windscreen=2C I guarantee you will not =0A regret going this route=2C less cutting=2C shaping and better glass in =0A general.=0A =0A Pascal =0A =0A =0A =0A =0A get="_blank">http://www.matronics.com/Navigator?RV10-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A get="_blank">http://www.matronics.com/Navigator?RV10-List=0A tp://forums.matronics.com=0A _blank">http://www.matronics.com/contribution=0A =0A =0A =0A =0A =0A ============0A ============0A ============0A ============0A =0A ________________________________________________________________________________
Date: Jun 09, 2015
There is usually a flat spot on the door frame that needs to be built up to f ollow the natural arc of the window and door. I fabricated "finger" out of aluminum strips and cleco'd them to the cabin c over. I would be hesitant drilling holes in the windows and filling due t o potential cracking and crazing issues. Sent from my iPhone On Jun 9, 2015, at 12:17 PM, Danny Riggs wrote: I ended up using small holes in the glass and put clecos to hold. They got f illed in of course during the final finishing. Date: Tue, 9 Jun 2015 10:56:35 -0500 Subject: Re: RV10-List: reminder of window options other than Vans From: civeng123(at)gmail.com As someone who just installed the rear windows, they were a major PIA. I do n't know if they were easier than Van's but I had real issues getting them i nstalled. The curve on the plexi did not match the curve of the cabin top an d required a lot of force to keep them flush. I ended up having to use ratc het straps and gorilla tape to keep them somewhat in place. Even with all o f that, they ended up somewhat proud on some of the edges. I have dry fit the windshield and have a 1/2" gap between the cabin top vert ical flange as well as a gap between the upper fuselage and the plex in seve ral places. None of these items are insurmountable, but they have definitely required mu ch more work to get them to fit than I had thought. Shannon Hicks On Tue, Jun 9, 2015 at 10:12 AM, Ed Kranz wrote: I have all the Cee Baileys (Desser) windows in my plane. There was no major c utting required to install, but there was a bit of belt sander trimming on a ll of the windows to get a perfect fit. =46rom what I've read of the Van's w indows, it was quite a bit less work, but none of them just "popped right in ". I am very happy with the end results though. On Tue, Jun 9, 2015 at 9:40 AM, Pascal wrote: This weekend I was reminded that many may have forgotten that there is the o ption to get better quality parts from http://www.vansaircrafttires.com/cate gories/RV%252d10/ (Desser Tires) than what is in the kits. I was involved with the front windscreen fitting, when my Vans bought one wa s warped in the bottom corner. They come pretty close to be ready to install without major surgery. The side windows, I hear, fit right in =9Cas i s=9D. Also Desser is where Vans gets the tires in the kits. If I were d oing all this again I would just order the tire package- http://www.vansairc rafttires.com/rv-10-main-tire-package-special-save-10-two-15-600-6pr-retread s-two-aero-classic-easy-flate-tubes/?page_context=category&faceted_search= 0. Better tires, tubes and the same price. I have seen first hand the attention to detail Desser strives for. I gain no thing from this other than knowing that I have told new builders that there a re great options, for the same, maybe less, than getting what is in the kits . If you havent bought the windows and windscreen, I guarantee you will not re gret going this route, less cutting, shaping and better glass in general. Pascal get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution get="_blank">http://www.matronics.com/Navigator?RV10-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution arget="_blank">http://www.matronics.com/Navigator?RV10-List http://forums.matronics.com ="_blank">http://www.matronics.com/contribution D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D ________________________________________________________________________________
Date: Jun 09, 2015
This was not related to the flat spot and was about equal on both rear windows. When I place them, the top of the glass (or the bottom if I held it by the top) was a good 4 inches from touching the window flange. SH On Jun 9, 2015 11:46 AM, "Bob Leffler" wrote: > There is usually a flat spot on the door frame that needs to be built up > to follow the natural arc of the window and door. > > I fabricated "finger" out of aluminum strips and cleco'd them to the cabi n > cover. I would be hesitant drilling holes in the windows and filling d ue > to potential cracking and crazing issues. > > Sent from my iPhone > > On Jun 9, 2015, at 12:17 PM, Danny Riggs wrote: > > I ended up using small holes in the glass and put clecos to hold. They go t > filled in of course during the final finishing. > > ------------------------------ > Date: Tue, 9 Jun 2015 10:56:35 -0500 > Subject: Re: RV10-List: reminder of window options other than Vans > From: civeng123(at)gmail.com > To: rv10-list(at)matronics.com > > As someone who just installed the rear windows, they were a major PIA. I > don't know if they were easier than Van's but I had real issues getting > them installed. The curve on the plexi did not match the curve of the cab in > top and required a lot of force to keep them flush. I ended up having to > use ratchet straps and gorilla tape to keep them somewhat in place. Even > with all of that, they ended up somewhat proud on some of the edges. > > I have dry fit the windshield and have a 1/2" gap between the cabin top > vertical flange as well as a gap between the upper fuselage and the plex in > several places. > > None of these items are insurmountable, but they have definitely required > much more work to get them to fit than I had thought. > > Shannon Hicks > > > On Tue, Jun 9, 2015 at 10:12 AM, Ed Kranz wrote: > > I have all the Cee Baileys (Desser) windows in my plane. There was no > major cutting required to install, but there was a bit of belt sander > trimming on all of the windows to get a perfect fit. From what I've read of > the Van's windows, it was quite a bit less work, but none of them just > "popped right in". I am very happy with the end results though. > > On Tue, Jun 9, 2015 at 9:40 AM, Pascal wrote: > > This weekend I was reminded that many may have forgotten that there is > the option to get better quality parts from > http://www.vansaircrafttires.com/categories/RV%252d10/ (Desser Tires) > than what is in the kits. > > I was involved with the front windscreen fitting, when my Vans bought one > was warped in the bottom corner. They come pretty close to be ready to > install without major surgery. The side windows, I hear, fit right in =9Cas > is=9D. Also Desser is where Vans gets the tires in the kits. If I w ere doing > all this again I would just order the tire package- > http://www.vansaircrafttires.com/rv-10-main-tire-package-special-save-10- two-15-600-6pr-retreads-two-aero-classic-easy-flate-tubes/?page_context=c ategory&faceted_search=0. > Better tires, tubes and the same price. > > I have seen first hand the attention to detail Desser strives for. I gain > nothing from this other than knowing that I have told new builders that > there are great options, for the same, maybe less, than getting what is i n > the kits. > > If you havent bought the windows and windscreen, I guarantee you will not > regret going this route, less cutting, shaping and better glass in genera l. > > Pascal > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > get="_blank">http://www.matronics.com/Navigator?RV10-List > tp://forums.matronics.com <http://forums.matronics.com> > _blank">http://www.matronics.com/contribution > > * > > > * > > arget="_blank">http://www.matronics.com/Navigator?RV10-List > http://forums.matronics.com > ="_blank">http://www.matronics.com/contribution > > * > > * > > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > List"">http://www.matronics.com/Navigator?RV10-List > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > //forums.matronics.com <http://forums.matronics.com> > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > ot;">http://www.matronics.com/contribution > D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D > > * > > * > =========== onics.com/Navigator?RV10-List> =========== =========== om/contribution> =========== > > * > > ________________________________________________________________________________
Subject: Registration form 8050-1
Date: Jun 09, 2015
I've got my bill of sale in hand from Vans and am filling out form 8050-1 to send in to the FAA. What, if any, considerations should I make before filling in the blanks? Jeff Carpenter 40304 Westcott Press 1121 Isabel Street Burbank, CA 91506 jeff(at)westcottpress.com 818-861-7300 ________________________________________________________________________________
Date: Jun 09, 2015
Subject: Re: Registration form 8050-1
I just finished my registration. Some things: You are the kit manufacturer. So in that box, I put Kranz, Edward J RV-10 Make sure your name is listed exactly how it is on the 8050-2 from Vans. Mine was LAST, FIRST MI. Make sure to print your name below your signature. And then don't forget the 8050-88, which needs to be notarized. On Tue, Jun 9, 2015 at 3:52 PM, Jeff Carpenter wrote: > I've got my bill of sale in hand from Vans and am filling out form 8050-1 > to send in to the FAA. What, if any, considerations should I make before > filling in the blanks? > > Jeff Carpenter > 40304 > > > Westcott Press > 1121 Isabel Street > Burbank, CA 91506 > jeff(at)westcottpress.com > 818-861-7300 > > > * > > > * > > ________________________________________________________________________________
Date: Jun 09, 2015
I just went thru this. They are very particular about how to do it. Follow t his guide exactly: http://www.ruleaviation.com/forms/8050_1%20rev%204.pdf It worked perfectly for me. Justin > On Jun 9, 2015, at 12:52, Jeff Carpenter wrote: > > I've got my bill of sale in hand from Vans and am filling out form 8050-1 t o send in to the FAA. What, if any, considerations should I make before fill ing in the blanks? > > Jeff Carpenter > 40304 > > > Westcott Press > 1121 Isabel Street > Burbank, CA 91506 > jeff(at)westcottpress.com > 818-861-7300 > > > > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 10, 2015
Justin, The manufacturer field on that example form is incorrect for our aircraft. It might be accurate for an powered parachute like a SixChuter, but for E-AB, the manufacturer is the builder's name. See Mel's comment here: http://www.vansairforce.com/community/showthread.php?t=29321 Or, you can look up the registration of other RV10 builders. Ed On Tue, Jun 9, 2015 at 4:27 PM, Justin Jones wrote: > I just went thru this. They are very particular about how to do it. Follow > this guide exactly: > > http://www.ruleaviation.com/forms/8050_1%20rev%204.pdf > > It worked perfectly for me. > > Justin > > > On Jun 9, 2015, at 12:52, Jeff Carpenter wrote: > > I've got my bill of sale in hand from Vans and am filling out form 8050-1 > to send in to the FAA. What, if any, considerations should I make before > filling in the blanks? > > Jeff Carpenter > 40304 > > > Westcott Press > 1121 Isabel Street > Burbank, CA 91506 > jeff(at)westcottpress.com > 818-861-7300 > > > * > > D============================================ > List"">http://www.matronics.com/Navigator?RV10-List > D============================================ > //forums.matronics.com <http://forums.matronics.com> > D============================================ > ot;">http://www.matronics.com/contribution > D============================================ > > * > > * > > > * > > ________________________________________________________________________________
Date: Jun 09, 2015
Thanks for catching that Ed. I missed that. You are correct. Justin > On Jun 9, 2015, at 21:17, Ed Kranz wrote: > > Justin, > > The manufacturer field on that example form is incorrect for our aircraft. It might be accurate for an powered parachute like a SixChuter, but for E-A B, the manufacturer is the builder's name. > > See Mel's comment here: http://www.vansairforce.com/community/showthread.p hp?t=29321 > > Or, you can look up the registration of other RV10 builders. > > Ed > >> On Tue, Jun 9, 2015 at 4:27 PM, Justin Jones wrote: >> I just went thru this. They are very particular about how to do it. Follo w this guide exactly: >> >> http://www.ruleaviation.com/forms/8050_1%20rev%204.pdf >> >> It worked perfectly for me. >> >> Justin >> >> >> >>> On Jun 9, 2015, at 12:52, Jeff Carpenter wrote: >>> >>> I've got my bill of sale in hand from Vans and am filling out form 8050- 1 to send in to the FAA. What, if any, considerations should I make before f illing in the blanks? >>> >>> Jeff Carpenter >>> 40304 >>> >>> >>> Westcott Press >>> 1121 Isabel Street >>> Burbank, CA 91506 >>> jeff(at)westcottpress.com >>> 818-861-7300 >>> >>> >>> >>> >>> >>> >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> List"">http://www.matronics.com/Navigator?RV10-List >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> //forums.matronics.com >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> ot;">http://www.matronics.com/contribution >>> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D= 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D >>> >> >> >> get="_blank">http://www.matronics.com/Navigator?RV10-List >> tp://forums.matronics.com >> _blank">http://www.matronics.com/contribution >> > > > 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3 D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D =3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D > ________________________________________________________________________________
Date: Jun 10, 2015
Subject: Re: Baggage Area Weight
Bob, I was cleaning out old email and noticed your message. Did you ever get an answer? I know I have had my 200lb carcass back there working in the tail cone and never caused any problem with the baggage floor. Kelly On 2/15/2013 2:45 PM, Bob Turner wrote: > > The paperwork from Vans that came with my final kit recommended a maximum of 150 lbs in the baggage area. > > But I see Vans' web site now says 100 lbs maximum. > > Anyone know when this change happened? Or why? > > Bob > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=394373#394373 > > ________________________________________________________________________________
Date: Jun 10, 2015
No, I never did get an answer. 200 lbs crawling around is no issue. Remember the floor has to hold 3.8 x 100 (or is it 150?) pounds, 3.8 being the max allowed g loading. I wonder if the change was just because Vans was worried that people would just shove 150 lbs back there without doing a cg calculation(!). With adults in the back seats and low fuel, I could get aft of the aft limit. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443358#443358 ________________________________________________________________________________
Date: Jun 10, 2015
Subject: Nose gear leg cutout length?
I lengthened the nose gear leg cutout in the bottom of my cowl to make it easier to remove and replace the lower cowl. I want to construct an aluminum panel to cover the cowl material I removed. Can someone tell me the distance between the rear of the cowl and the front of the cutout? I forgot to measure it before removing material from the cowl. Thanks.. -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Subject: Gascolator locations
Date: Jun 10, 2015
Hi everyone. I'm in Canada, and stuck with an obsolete regulation that we require gascolators in homebuilt planes. Though they're pretty much pointless in a low-wing fuel injected plane like the RV-10, I have no choice but to put one in. I've done as much research as I can in trying to decide exactly where would be the "best" place to do so, but wanted to post my observations and thoughts here in case anyone can find something I've overlooked, or can assuage any of the potential pitfalls I see in different scenarios due to your own experience. No matter where I install it, the specific gascolator I am considering is the Andair GAS375 - as it seems to be one of the better constructed. I see three locations where they can be installed - in the wing roots, in the tunnel, or on the firewall. Firewall: Advantage - relatively straightforward to install there. Disadvantages - If an O-ring or something starts to leak, it would spray fuel around the engine compartment under pressure (are potential leaks of this sort a real possibility to consider?). That can't be a good thing. Also, under the hot cowling, would it cause an increased potential for vapour lock? It may also not be the true "lowest" point in the fuel system, which the regulations also specify. Tunnel: Two options here - adding it as another device in the tunnel, or replacing the fuel filter already there with the gascolator. On first glance, replacing the fuel filter seems to be the way to go since the addition of the gascolator wouldn't be adding a new point of failure - just replacing one. Though when I checked with Van's about this, they recommended against it - they would rather see the recommended filter still in place, and the gascolator added elsewhere. In any case, whether adding the gascolator on its own, or replacing the existing filter, an advantage would be that it should be less likely to contribute to vapour lock, provided that tunnel heat isn't excessive. Disadvantages - there is still the possibility of spraying fuel under pressure if it were to fail, and in the tunnel seems just as bad (if not worse) than the engine compartment. Secondly, the fuel drain for the gascolator would be in the vicinity of the exhaust pipes. I've had first-hand experience with fuel tank drains leaking and dribbling due to debris that ended up getting into the seal. If it were to dribble fuel into the hot exhaust gases, again that can't be a good thing. Wing roots: Advantage - they'd be cool out there so wouldn't contribute to vapour lock. Also, if they started leaking (either through O-rings failing or the drain dribbling), it's less of an issue. Plus, since there would have to be two, if one did start to leak in a spectacular fashion, there is the redundancy of two, so at least the fuel in one of the wings would stick around. And they wouldn't be pressurized there, so leaks should be less dramatic. Disadvantages - Cost would be twice as much, since two would be needed. There would be no way to shut off the fuel prior to the gascolators for cleaning the filter, so the tanks would have to be drained to do so (I wouldn't want to introduce yet another point of failure by installing shutoff valves before them) Also, the gascolator would have fuel sucked through it rather than pushed through it, so it would be under a small amount of negative pressure rather than positive pressure (more so when the filter starts to get dirty) - would this cause potential problems with air possibly be introduced through the drain port? Or is the seal and spring on the drain port more than strong enough to maintain a seal against the outside even when being sucked up with the negative pressure? I hate having to install a gascolator in the first place, and it doesn't help to have not come up with a clear winner with regards to location. Any advice anybody could give would be greatly appreciated. Am I overlooking anything, or equally, overstating the likelihood of certain failure scenarios? Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Jun 10, 2015
Before I understood gascolators I put an Andair gascolator on my first plane, an RV-8A with an IO-360 engine. I mounted it using a piece of angle on the lower left corner of the firewall such that a push drain valve (identical to the ones on the wing tanks) on the bottom of the gascolator could be accessed with the cowl on (the cowl had a 1/2" hole for this purpose). The angle held the gascolator off the firewall enough such that the drain valve was forward of the lower cowl attach hinge. The bottom of the drain valve was just inside the cowl so a standard sump glass with a sump rod could sump the gascolator. 12 years of flying and I never had an issue or a problem with vapor lock. Two other recommendations: - plumb the fuel system with the inline filter in the tunnel per plans. While the filter in the Andair gascolator meets the specs for the fuel system, it is after the fuel pump and small compared to the inline fuel filter. - get an Andair gascolator - if you have to have it then get one that is well made (so you can worry less about leaks and such) Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dan Charrois Sent: Wednesday, June 10, 2015 4:47 PM Subject: RV10-List: Gascolator locations Hi everyone. I'm in Canada, and stuck with an obsolete regulation that we require gascolators in homebuilt planes. Though they're pretty much pointless in a low-wing fuel injected plane like the RV-10, I have no choice but to put one in. I've done as much research as I can in trying to decide exactly where would be the "best" place to do so, but wanted to post my observations and thoughts here in case anyone can find something I've overlooked, or can assuage any of the potential pitfalls I see in different scenarios due to your own experience. No matter where I install it, the specific gascolator I am considering is the Andair GAS375 - as it seems to be one of the better constructed. I see three locations where they can be installed - in the wing roots, in the tunnel, or on the firewall. Firewall: Advantage - relatively straightforward to install there. Disadvantages - If an O-ring or something starts to leak, it would spray fuel around the engine compartment under pressure (are potential leaks of this sort a real possibility to consider?). That can't be a good thing. Also, under the hot cowling, would it cause an increased potential for vapour lock? It may also not be the true "lowest" point in the fuel system, which the regulations also specify. Tunnel: Two options here - adding it as another device in the tunnel, or replacing the fuel filter already there with the gascolator. On first glance, replacing the fuel filter seems to be the way to go since the addition of the gascolator wouldn't be adding a new point of failure - just replacing one. Though when I checked with Van's about this, they recommended against it - they would rather see the recommended filter still in place, and the gascolator added elsewhere. In any case, whether adding the gascolator on its own, or replacing the existing filter, an advantage would be that it should be less likely to contribute to vapour lock, provided that tunnel heat isn't excessive. Disadvantages - there is still the possibility of spraying fuel under pressure if it were to fail, and in the tunnel seems just as bad (if not worse) than the engine compartment. Secondly, the fuel drain for the gascolator would be in the vicinity of the exhaust pipes. I've had first-hand ex! perience with fuel tank drains leaking and dribbling due to debris that ended up getting into the seal. If it were to dribble fuel into the hot exhaust gases, again that can't be a good thing. Wing roots: Advantage - they'd be cool out there so wouldn't contribute to vapour lock. Also, if they started leaking (either through O-rings failing or the drain dribbling), it's less of an issue. Plus, since there would have to be two, if one did start to leak in a spectacular fashion, there is the redundancy of two, so at least the fuel in one of the wings would stick around. And they wouldn't be pressurized there, so leaks should be less dramatic. Disadvantages - Cost would be twice as much, since two would be needed. There would be no way to shut off the fuel prior to the gascolators for cleaning the filter, so the tanks would have to be drained to do so (I wouldn't want to introduce yet another point of failure by installing shutoff valves before them) Also, the gascolator would have fuel sucked through it rather than pushed through it, so it would be under a small amount of negative pressure rather than positive pressure (more so when the filter starts to get d! irty) - would this cause potential problems with air possibly be introduced through the drain port? Or is the seal and spring on the drain port more than strong enough to maintain a seal against the outside even when being sucked up with the negative pressure? I hate having to install a gascolator in the first place, and it doesn't help to have not come up with a clear winner with regards to location. Any advice anybody could give would be greatly appreciated. Am I overlooking anything, or equally, overstating the likelihood of certain failure scenarios? Thanks! Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Subject: Re: Gascolator locations
Date: Jun 10, 2015
Hi Dan I have felt your pain..... This is what I installed prior to getting TC permission to ditch my gascolators. http://www.aircraftspruce.com/catalog/appages/usher.php I used these as they were a) cheap, b) simple and c) easy to install. I still have my mounting brackets - they are your if you want them. IMNHO opinion, gascolators serve no purpose in a low wing a/c unless the laws of physics are repealed and water can flow up hill Gascolators, in our application function as little more than gas bombs when placed in high heat areas or as a source of vapour lock when placed on the suction side of the fuel pumps Anyway, what I did to get past the MDRA inspection was to install the gascolators in the wing roots. Using the user gascolators I installed plugs, not quick drains as I did not want risk the suction lifting the drain and introducing air into the fuel system. I mounted the plugs so I had access to them under neath the wing through the bottom wing root faring. I never planned to remove the plugs as any water would be removed using the tank sumps, which were the lowest point in the fuel sumps. But I did have access to them which met the requirement of the CARS exemption that MDRA requires you meet. I would not place the gascolator on the firewall as it only serves to introduce a volume of fuel in an aluminum container that would easily melt if there was an engine fire. For similar reasons, I would not use the tunnel. If I could I would have kept all fuel lines out of the cockpit but in the -10 that is not possible. Fire in the cockpit is the only thing about flying that scares me. As the Usher gascolators have screens, you could use them as as additional fuel filters located in the wing roots. I would not use quick drains on them for the reason noted above. Cheers Les Postscript for those south of the 49th parallel.... In Canada, amateur built aircraft are inspected by MD-RA, an agency delegated inspection authority by Transport Canada (our FAA equivalent). There inspection process is based on Appendix A of CARS 549.01. This appendix exempts amateur built aircraft from the requirements of 549.01 but does require installation of a gascolator. It would be interesting to see what MD-RA would do if confronted with an electric aircraft - how would you install a gascolator and where? When I swapped my Subaru engine for an IO-540, I was reinspected and my CofA reissued. In this case the inspection was done by Transport Canada and not MD-RA. For this inspection, I conformed my a/c to the requirements of CARS 549.01 and not the exemption. As a result, I was not required to have gascolators as they are only required by the exemption. Unfortunately this option is not available to builders getting their initial inspection done as all initial inspections are done by MD-RA and they only use the exemption. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443370#443370 ________________________________________________________________________________
Date: Jun 10, 2015
This is what I did for my 3 bladed prop. The measurments are from the nose scoop heading aft even though the pics imply it was measured from the rear. I still have to hold the tail down to let the gear leg drop as much as possible and then protect the prop edges as I remove the lower cowl. Albert Gardner N991RV Yuma, AZ From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman Sent: Wednesday, June 10, 2015 1:11 PM Subject: RV10-List: Nose gear leg cutout length? I lengthened the nose gear leg cutout in the bottom of my cowl to make it easier to remove and replace the lower cowl. I want to construct an aluminum panel to cover the cowl material I removed. Can someone tell me the distance between the rear of the cowl and the front of the cutout? I forgot to measure it before removing material from the cowl. Thanks.. -Rob -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Jun 10, 2015
Subject: Re: Nose gear leg cutout length?
Awesome... thank you! On Wed, Jun 10, 2015 at 4:43 PM, Albert wrote: > This is what I did for my 3 bladed prop. The measurments are from the nose > scoop heading aft even though the pics imply it was measured from the rear. > I still have to hold the tail down to let the gear leg drop as much as > possible and then protect the prop edges as I remove the lower cowl. > > Albert Gardner > > N991RV > > Yuma, AZ > > > *From:* owner-rv10-list-server(at)matronics.com [mailto: > owner-rv10-list-server(at)matronics.com] *On Behalf Of *Rob Kochman > *Sent:* Wednesday, June 10, 2015 1:11 PM > *To:* rv10-list > *Subject:* RV10-List: Nose gear leg cutout length? > > > I lengthened the nose gear leg cutout in the bottom of my cowl to make it > easier to remove and replace the lower cowl. I want to construct an > aluminum panel to cover the cowl material I removed. Can someone tell me > the distance between the rear of the cowl and the front of the cutout? I > forgot to measure it before removing material from the cowl. Thanks.. > > > -Rob > > > -- > > Rob Kochman > RV-10 Flying since March 2011 > > Woodinville, WA > > http://kochman.net/N819K > > > *http://www.matronics.com/Navigator?RV10-List * > > *http://forums.matronics.com * > > *http://www.matronics.com/contribution * > > -- Rob Kochman RV-10 Flying since March 2011 Woodinville, WA http://kochman.net/N819K ________________________________________________________________________________
Date: Jun 10, 2015
I can't remember where, but I am absolutely sure that I have seen both 100 and 150 in official Van's Aircraft produced documentia. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443381#443381 ________________________________________________________________________________
Date: Jun 10, 2015
After my first post, I looked thru my paperwork. The packet I got with the final kit - the section on measuring weight, moment arms, and cg - is where the 150 lb number is printed. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443385#443385 ________________________________________________________________________________
Date: Jun 10, 2015
My empty cg is pretty far forward. If I were carrying bags of sand, I could put 250 lbs in the baggage area and still be within cg limits - as long as no one sat in the rear seats. Although it's hard to imagine doing that. As I recall I put 150 lbs back there, and more sand bags in the rear seats, during phase 1 testing, to get the cg close to the aft limit. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=443387#443387 ________________________________________________________________________________
Date: Jun 11, 2015
/9j/4SP+RXhpZgAASUkqAAgAAAAJAA8BAgAGAAAAegAAABABAgAWAAAAgAAAABIBAwABAAAA AQAAABoBBQABAAAAoAAAABsBBQABAAAAqAAAACgBAwABAAAAAgAAADIBAgAUAAAAsAAAABMC AwABAAAAAQAAAGmHBAABAAAAxAAAAFYLAABDYW5vbgBDYW5vbiBESUdJVEFMIElYVVMgNjAA AAAAAAAAAAAAALQAAAABAAAAtAAAAAEAAAAyMDA3OjA5OjAyIDE3OjExOjMxAB8AmoIFAAEA AAA+AgAAnYIFAAEAAABGAgAAAJAHAAQAAAAwMjIwA5ACABQAAABOAgAABJACABQAAABiAgAA AZEHAAQAAAABAgMAApEFAAEAAAB2AgAAAZIKAAEAAAB+AgAAApIFAAEAAACGAgAABJIKAAEA AACOAgAABZIFAAEAAACWAgAAB5IDAAEAAAAFAAAACZIDAAEAAAAYAAAACpIFAAEAAACeAgAA fJIHAFoHAACmAgAAhpIHAAgBAAAACgAAAKAHAAQAAAAwMTAwAaADAAEAAAABAAAAAqADAAEA AABABgAAA6ADAAEAAACwBAAABaAEAAEAAAAICwAADqIFAAEAAAA+CwAAD6IFAAEAAABGCwAA EKIDAAEAAAACAAAAF6IDAAEAAAACAAAAAKMHAAEAAAADAAAAAaQDAAEAAAAAAAAAAqQDAAEA AAAAAAAAA6QDAAEAAAAAAAAABKQFAAEAAABOCwAABqQDAAEAAAAAAAAAAAAAAAEAAAA8AAAA IAAAAAoAAAAyMDA3OjA5OjAyIDE3OjExOjMxADIwMDc6MDk6MDIgMTc6MTE6MzEAAwAAAAEA AAC9AAAAIAAAAGsAAAAgAAAAAAAAAAMAAABrAAAAIAAAAMUbAADoAwAAFQABAAMALgAAAKgD AAACAAMABAAAAAQEAAADAAMABAAAAAwEAAAEAAMAIgAAABQEAAAAAAMABgAAAFgEAAAGAAIA GQAAAGQEAAAHAAIAFgAAAIQEAAAIAAQAAQAAAE1DDwAJAAIAIAAAAJwEAAANAAQAaAAAALwE AAAQAAQAAQAAAAAAlwEAAAMACQAAAFwGAAASAAMAHAAAAG4GAAATAAMABAAAAKYGAAAYAAEA AAEAAK4GAAAZAAMAAQAAAAEAAAAcAAMAAQAAAAAAAAAdAAMAEAAAAK4HAAAeAAQAAQAAAAAB AAEfAAMARQAAAM4HAAAiAAMA0AAAAFgIAAAAAAAAXAACAAAAAwABAAAAAAAEAP//AQAGAAAA AAAAAAAAAAAOAAMAAQABQAAA/3////hDqBboA2sAqgD//wAAAAAAAAAAAAD//wAAAAsACwAA AAD//wAA/3//fwAAAAACAMUb5gCtAAAAAAAAAAAARABfAKAATABrAL0AAAAAAAAAAAABAAAA AAAAAAAAAAAAAAAAAQBZAAAAaADBAAAAAAAAAPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AABJTUc6RElHSVRBTCBJWFVTIDYwIEpQRUcAAAAAAAAAAEZpcm13YXJlIFZlcnNpb24gMS4w MAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAA1AAAACIA AAAAAAAAIgAAAAAAAAAAAAAAAAAAACgAAAAAAAAAwwAAANQAAAA5AQAAOgIAAFUAAAAAAAAA +f///8MAAAC5AgAAOQEAAOwBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAmwAAAD8CAABqAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATAIAAAAAAAAyAgAA ZgEAAAAAAAAAAAAAUO+R/wAAAAAABAAAtwMAAE4EAABhBQAAMwIAAGYBAACUAAAA2wMAACgF AAClCAAA2wMAAAEAAABAAgAAOQEAAOUAAABbAgAAOQAAAPz///8AAAAAtwEAAEgAAAAAAAAA AAAAAAAAAABEAQAABQAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAIkBAAAAAAAAAAAAAAAA AAC3AQAASAAAAChDAAAEAAAACQAAAE4BAABNAQAATAEAAEwBAABNAQAASwEAAE8BAABPAQAA TgEAABgAAAAAAAAAPsvhuFIEAAAAAAAAAAAAAAAAAAAAAAAAAAAJAAkAQAawBIAFCAH9ADAA A/8AAP0AA/8AAP0AA/8AAP0Az//P/8//AAAAAAAAMQAxADEAAQEAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAQAAAAIAAgACAAIAAAAAAAAA AAAnAAAAAAAAAAAAigABAAAABAAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoAEAAAAAEAAIAAEA AQCAAuABAAAAAAAAAAAAAAgAgAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABJSSoApgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAQACAAQAAABSOTgAAgAHAAQAAAAwMTAw ARADAAEAAABABgAAAhADAAEAAACwBAAAAAAAAABqGADhAAAAgE8SAKkAAAAACwAAAAsAAAYA AwEDAAEAAAAGAAAAGgEFAAEAAACkCwAAGwEFAAEAAACsCwAAKAEDAAEAAAACAAAAAQIEAAEA AAD0EwAAAgIEAAEAAACtDwAAAAAAALQAAAABAAAAtAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD/2P/bAIQACQYG CAYFCQgHCAoJCQsNFg8NDAwNHBMVEBYhHSMiIRwgHyQpNCwkJzEnHh8tPS0xNjc6OjoiKj9E PjhCMzc5NgEJCQkMCgwUDAwUDwoKCg8aGgoKGhpPGhoaGhpPT09PT09PT09PT09PT09PT09P T09PT09PT09PT09PT09PT09P/8AAEQgAeACgAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAA AAAAAAABAgMEBQYHCAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQD BQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUm JygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOU lZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy 8/T19vf4+foRAAIBAgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkj M1LwFWJy0QoWJDThJfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpz dHV2d3h5eoKDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT 1NXW19jZ2uLj5OXm5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A9kI4zWBB430S41qTTUus TxqS5dSqjBxjJ7+1Nu3zCMJTvy68q1LC+J9Jl1KCyiu0knmJCKnIyBnk9ulabULUUouOjTT7 ELvjNN35HTtTsSICCoprAY/CkyhP8abjjt0qQEK5bAprAA0gI2XkfSmMKQDCKawpDGnjH51G w4570CGMBTCM0wOtkjWSJ0YkBgQcHHWvJdd8GT6QjXF1ewtuyyhckt9ScD9aqceZeh1YTExo NtpycrWJPCieHItRS7nvJjLbsGjSTamWHO7Ck8V6hFKJ4ElTlXUMPoacUkrIyr1XWm5tct+h G+c9O1Rg8dqswFUnaOnBoPTpUsY3rTcZxSGBHzUx+tSBG33gKjYDFIBhFNapAYx55PamE0wI 2PFMzQB2DqWRlBwSMA4zXmviPRp4dcEupSLcSTxffAICgHGPT0rURyzaZH9jeZmAO9o2RB0P vXW/C/V7u4u76yvJpZCiKwWVyShBxjB+o/Koje/kNneuRuqHA9RWxA1eFP1pHIHWpZSImfA6 1zWueMZdNuIIbS1Mxa4SGUsD8oP8XHpg1k5W077Dt+Bcj8UwmeKK42wSOzqVZh8u31+tWoNS gvpHS3lDugyyjIIHrg9qqCc4c9tFuxOUU+W6u9kPMxWXBIHsaUu/Hy1IxA57rigkHtSAaw6/ Wo27mkBGw4qNvyoA7IMDjFc347uLK00MzXQJl+7AobBLf4cf5zWwjyh9WiFzNuJWO6GWcgYV x06c96dpWr6nY6wLuwfdc3IEYJUNuHGAfyH5VqqE3qldWvczdWK3dne1jtl8TeILQD+000yM 91eYbvyUmtu18QQzWiSOr7iMkRIzD8Dis1P1kXYcdYBt5Wjt7osqkophYbjjgZrlJfEPiS8u tllpl0FAbeZIggGPQsa3pKnJN1LrsjOfOmuSzvuyloOreINeuJ7i0kinhtwY5YXkClmK/KQM dvqOhpNXtdQufKVLjy2ST98GO8YHYfjWNdRU2oK0Y9C6bk4pyd2zFmEJ1+2tvtJgMs4TdEwD AHjI/Ou70jwpZ6ZLJNJLNe3EgwZbhskD0A6VEJtRcfsyeo3BOSl9pLRmo2m2rqVEIQeqfLj8 qjhnezlW3nYurf6uQ9/Y+9TLQostIO9NDqehqbgLkECmMOKAIm60xhk0AbSaqkUDSSthEUsx 9AK8o8WeJm8RamZd2IU+WJM9B6/U1qnfUVjmpUJJKOyk+naq8lrNMVElzLIgxwzVt7efLyJ2 ilqZexhzczV3c2dA0c6vrNtZB2Hmt8xz0UDJP5CvbYbeO3gWGFAkcahVUdFA6CpgtPU0YyVc 5OOmOKzrhXIZCSFYEcfSlPQEcl4L0G70PxFfyXLja0SogU8SDcfm9sYx+NY3i3w9qcGrXU1p e4guCZgmSCpPUcdaVSopTb6MIR5YpdjmrDQ20+/We4lMkkZLgDpuHNexJdllVgCQQCD7Vinq XYsxTllzg1U1kh7Esp+dWBX654pgTyP1pm78azAlTPU+lD8Dg1QEe7J96aec0CGy7Z7aSEth ZEKnHoRivJvFOiDQdSWBJjKrIHDFcdz/AIU4PoDMXzZF6MR+NSR3cqkfMT7VoI7X4aMZ/F8B YYKRSNj8Mf1r15hkfhWkdiWQS8O30qncc80T2GtzMlcR6pDz99GX+v8AQ1X1q2a5hQopZkJ6 ehrnejLOSi0iTUdWMSL8sZ/fE8bR/jXcWwjiijhGdqKFG45OBUpq5TTWj0di7CqmNmOFQdXY 4A/GqlzELqRTGCIYzuyRje3bj0H6mr6EjSCOtAwVrIZKh4pxPU1aEQnqTSdB3oEeex6negfL dP8AnWP4jmnuJYnnkMjbSAx9P8mlBaly2MUgdhSKMNWxmdP4D1QaZ4i8/ZvxCwxnHXFejr47 tgf3kEg/3SDVRnZWHy31BvHFgx+ZJhx/dH+NQt4u09gTvYD1IonONgUGUb/XbO4SOSCYebE4 ZR0yO4q+2uWpxmQKcdDXNJplWZA+sWqtkSrg1Lc6lbaXbpLPtkuJAHWNjhY1PRm/wojb1sU4 tWv7qlszL/4SoSzB2lS4ZT8qqxYL9AoIH4Vp2/iW3mbZcI9ucZ3Sxsqn8SBVKT67FOEHpBty 7NWuXlaK6hEkEyOp6MhyD+NQ/PE2GOR2oaMiaOZV6mnmTI4pIBM8dM0Mw6CqQjzyG2BHOazP EUOxYMZ7/wBKUFqaz2MJlxzTR6jpWpiWNEufK1EndglCP5VveczHO7rU3NI7DHd8U4MVTDd6 iRaZW82ZZSNkeM8ZY/4VfiuPt0XkSlY7heI5MnBHoaz0btrqPVardbDtL0TU7rWIo3t5NiyL 5rKvATPJz0xitHVrDTzq9xea1qQndnLLb2Y8wgdhuPyr+GatJW7IiUnJ3b5m+pXl8Um3Ty9I s4rJf+er/vJT/wACPT8MVBZ61cpcrJdTtKrnEnmNkYPXrSv0Wi7D5evXuRNqDQ3EjWU4UbyB LCcZwe5H3vxqynirUY8GRklHqBg/lS5nFuL6FyippTX2vi9SRPF102DtjYH0q1H4wlXG6DI9 moU3fVGfIujLC+NY2I3QuAPQA1IvjG1P3vMX6pV86JcGVgqonSsTxIQ8EJAxhjVRWpc9mc2x 64qJ+FOPStGYkFpIUuNwOPet+GYsM5rE1RYWQkYFSAFuopMpIeIkIG4Vd0bSYb7USJlLQxI0 jqOCwUZx+PA/GoS1KeiuS3PiO6kzFOI3tQMLbLlUUe2O/vTUTTvEJ3CR7S6UYMfGHHqM96u9 9HoQ48uq17iR+HdpKyT3UI7M1kxX/voHFMu/DatbOsV2zOR8oMW0E/XPFCSUk27WYnPRruZm n+Fr2ByJ7qBUZtzbGyce2RWk/h+GPYpupTvzh1UEIe2eOlaSnCpNuy967cmZxc4x5U2l2RHq Phe90mxs7qeZJGnYLIkUgAPGehAyaxdUkk05FZosK7HaA24gds4rno8kqnLN8kWrpouUpKN4 rmfVFKPVZBLGGgfaSP4TyPWtPUJofs4GnrJ5u4ZMrDGPw7101I0YONm5r7aJi6kk7pRf2TqU 3BscEe9Q6zZi/wBP2JsV0ORxjNRGVvQ1nG6OWm0m5TJ8vjpwRzVKe0m8tgImJxwAKtyRlyvs MtNFnLqZAFz6mti305lAyQfYGsjWxaSAL6j3qTySF3Zz7Cnp8h620AMcE46VY0rUn02+S5RB IBkPGf4lPBH5Gl19B7r1J7iHw7K+W1G7tlJ/1LWu5hntkHBrB1O4s7a/22ZupbdSOWiCM388 VtRjS5m6j93lfKvMwqupy2gtb6vyPQD4z8MFbg2lp5MghGyOROG656HHce/FYlz4/gUBYrSB fogrjhG8VzXurlNNMzpfHDNnZHGo9cCqcnjSfk71+lXaKCzZY17x2mq+H7a0hk2XEUitlAR0 UjqR71zVuzL1Ytkd6jlW70drFR7Fzy3I4709YSeCAKk0OyQbsnJIz3FMupEEW1EIPcnmum1/ QXNYxZSVJHUZqs8bs+NuDScbgpEQgKyA7+ceuKsKGXhWz9aA/MmWV2+Vj0GBT/N2gfOOR6fl SbBAsuQdwX/GommROPLGfY81N0VYjZoZFG9SOfSq7eQWzjjPBxSfkxWfUbPaxGMsMjIwOe9Z MulRy4KyuD7txSUmn0YOKfkRPooVMlsn/ezio101VOQv50+diUEWI7ZADlR7kirShQmNg47i obuUo2JfO/d9OnvThKCO4+hpWsB1n2klAuelRzOSozwT2rdaMTRVxnJIx6Gq8shWTkH6A1Wp Oi/Qr+YN2TjHvUisrY24570N2BakqkpyMUOwfhsDPtUtlWG4MbdBn0Iph56mMn3BqboLPzI2 BDgAgDvzULheAVpP5D+8axDLt5AqB0Uv8+eRSYrgY1J4bI689ab5J7Hj3qGUL5LetK/yJ0FL qFxA27goD701XRMqwHX1q0rkN2OmAZemR2pWUsM+nrWw2yLBwRnt0FMKEfKcH60xbld4mfgr ihIirDocckVm2UiY25yWRWwe1MEJPXj2NTcYksbEgkn61C8XPU5xQrBcafMZmLDjrz1qFi3f H5UaBdjcDBbbUchHHy4NFxWFUAY4xTgQV28fWoZQcL1I9qZKMr2P0pXEMDEAL6dKSWNX4Ax7 0J2YNXR00YZIl807zj7wpyg55BP0re5I4QAgtnPPHFQvECcYwfXrSux2EaNWBwSAB60q2pzx yfXNQ2UkPMTInBz9e1QNu25yAe59alAyNlI4Tr9arvG7ICBznFF7ANUYwOp9cUrpkldw/Ghs SGSRhY8grnNRlY8DccHByKlspIaUjEYcOM5+73qMEA0P7wEdlYZH4U3dg4Ipt6EpajCcNnAJ P6VHIdsmDkD2oQM04tRlbA5b0rVs5Dxu4PpWqQi6sqBSDjHvUMskb5OF/wAKGgRFIE2nYR9R ULl0wUII55BqLfgUQm7dCQxxnpUsVyGAB24/nTaC4NKrDqAelRq6NGx7g9amwXGKEY5HXFNk i2ncT17Gk9wRFIvp69qryDnt06ikhkDgq2c4pm7jGelMB2SV27uPegZI6jHoaljGMSDTJWIH f600iWf/2QD///////////////////////9////////////////////////////////7//// //////////////////////////////////+//////////////9j/2wCEAAEBAQIBAQICAgID AgIDAwYEAwMDAwcFCAQGCAgKCQgHCwgKDg0LCgoMCggICxAMDA0PDw8PCQsQEQ8OEQ0ODg4B BAQEBQQFCQUFCQ8KCAoPGhMJCRMaGhoaDRoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoa GhoaGhoaGhoaGv/AABEIBLAGQAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQID BAUGBwgJCgsBAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYHCAkKCxAAAgEDAwIEAwUFBAQAAAF9 AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJicoKSo0NTY3 ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZmqKj pKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEK FiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqC g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri 4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AP7dNP12XTYY1WMHdxgjOK6aCaUkux+Z u1bNX1M72HwRmOR3nO5CuCAf1rkrlrR3dZW2AHqBnIoQM5ayDP4hV4pT5GdvAxu/CvQEsJGv H3NuG0HGKtsSRJcSpAqq0W5jwuADivP/ABHNPfZsfLUF+Tntx/PrUpag2dR4f0OKyhbzTsAH oP8APetWKwnu9KkWSYrACSoxjIpN6lPUNPs7f+zSwYYIHPAzVaUKbQCKEtIcYYDpQ7sFZGlt ax09ZmOGAxgn9K4i7tBfXYkuCSCPkTHAPrTXcT0NzToreW7Cq37wLhiADj0rYvN9usRjAz16 A8Um7uzApmOTU5xHNIACAVCjg+orAudJ+walLIAM98Y5H50LQZ2HiC4a10VJkKhzgfPXNWBn vNJErS5dT02gCkttRPcvPphGmSO7mMEdcYx7cfSsuTQnXTEZTtx6nqDT5kgsacBOnTwMpQu4 2BWx/LrXPa/G6agsbYHmKSVHTAoVr3BmrNfw6boitKHYkYARc59qxtFvAXMkpMAfIRB29OKE m2F7HT2NjOk80zTOIQPl+Y81hLbTXcDwsh8oOWALdeaBpGtJpSHTkcsWKjGGP3fwqu9xHBAk gXPzdu3WpuFhLfUbi8vdyxiNE4CsMlvxqZrJ2hlnluNrbehPb/OKbjbcLM5OzmkS6Ej4kOMY b0ret9Uku47mGOEByMByfWjle4rmhFYrBpNskjqCXICjjFYIt1n1RbSErI5YFmz90e/5UX1G 12NXWpdk5ZpF3ou0Kn6DFYkd/eTaXIZlB4JKoAOKIq6FfsV9P0ua7tJGup8KRkDPaiw8u3ie PJ2jI5HTmm30RSZ0mnW9vFozBky/J4rHS0htBJJ5ChuSRjqOxpO9xJpnJaK01zq0s7IYoHb5 QDjJB/8ArVtX2Z7oh1GAehFOyYmc5DF/amtx2cQCMzgsxOAo9fwrtdcto4ri3tU2yKW+dk5z 7Ur33HfqaGrRW+l29u8chjJYDB7cVh6hqDXLXDHDIAAuFApLUGzm7O3doV3EocZUZ6CnX1qx t4ZFG1BJlm9KfL0BNm9E8W2RUXex+8fUVaaeMqAWzgdh0NK1h37mIEuFkDlVWI4Kk9xWxqNw ZbTzJ23lhgfL0H/6qGrK4XMEWylfNS4ds8AE+2a0dNiCsxAOW5LA4xVKwJqRzt1p0c+qQqjm Rt2HXZ3+v/6qveLtPCxlxsCIem3qe1K+lugGhBqwfRo8x4VQcFBjH+cV5/qd4L67icIQisBt JwDzxS5W/Qa30Nq8K3bDzJRCu7k4+9VTVLG0izc3EirawgFhn7xzwMd6T03K6nQ6T4nm1LEN jZeTAWHzluv/AAHpVrVftU15FNuIXGAE/nTtbcm5jJcPBiOBAqjmVyPX+vSstbWTUZnkkAJx gZHU0Ws7sNGTrpRsZIAZA85fOB0UDn+lQavdy2kLCBCzl8DJ/X+dDd9EStNWKt/dXOo28s0a LFtAAXIJIxz/ADralIMheQ7j69fwqfh2ZV+pycruZ3QlkieUcZ6n0rpxdnTtJeMFWZsgjAGK EtLhujm4rrfFunZhEpO7acE+lXtMt1ubQKxEa8kDrg0J2Dm1sZUUAgMjMAwyAMDrVXTGkF9J mIRx5yPem11uNsP7VhtLacNJulL/AHQeRz6VRXWopXK/ZncL0+YcelTFMa1L0zzXlqJZHKbW yig8g1hXc7F0Rh5rnn5j0ol5Eo9NjngsfDBWc+XLjEfsT/WsLVnSO0j+dgNhJ6Dc39KHewb+ hzMLvaIfLcbnwcGt/S8y2YAUOec+9EdWHUnuEupdLYmJYo1JwQecVD5xg0tWYbVwT3zzTcbM a7lG00u9vLQXIhxGxO3nk+ldJFMun6N5UpfzDklVXpS2DZnIxN5l1GUUCMtnnHNTXlq8CFix D98HH4VKd9BXbOVikuLzUljhIVVIJI6/Wutjhmm1RIUlBcgl2P8AD+VUl3B6G9ZWHkXU7M2X IIzmuGlhje7dHfITPHXNKTvsPVmvfWFx9hhcxblAyMnqKLXVQtuFlXKjk4AGfypW7bjskX9D 8QQW0MsgsiiDJUHHJ9f1FZralDcW6CVGLZzwPX+tHvLXqJeZhXkaapIqkhIg5bbjOQPatrR5 orG4dSmGC9BzSTt+oPUjkV7mUyIGX5jggdKhF5PZmRI32u/+sPUnjp+tOWq2G11OjilluPD8 QdcRAY49K5K4ia/EggIWKNcnccUW+4EJpkZK4JwR8rMOw/pVm+ZDI7h8j+HAHr6UkmJ6blCG yDymaWTB6hQeAK0dLtZbkyMD8rngbsUJcu/3j3K1/EsaEiRQ33QD3Oeuao3Mb/ZVSNiQeDwT QpXegblrTLJre03EHdnBGMY9+Pwo1rUHjdII4mafuewqbJaArmTdaXdNYsbkAKxyUx2zWshh jsUUrtA54HWmtHYE9Sul0scLPHknnIB/Sori6DwSAoTKyjaOvNG60Bu+xkxW7W7LvLKcZHHG artcyXGrJiPzVB6lqmSBM3JbZTIyAFQRlsLwPas+5t2iiUxEcjjAxjH+T+dG2grlFQzkM/IG Me+acb+4spFlNuu0g7doH/66E9PMq5b00XkryyuAWckYUAAdfzqeLdOo3YJzyMEZNU779Q5l LQ5LUt8kkibxHGTgsDnP4elQJayT20mCsS9Cdozgdf1qLOXmC623NCxsEghRS2Wz19vWr8zS yTH5yYxjocf5NJK2jDQ5HVLgLeCEFRzk+o59/wAa7/RLdri4RGYImMs23rQvwFozO1tYoLpo 4JNzd8t0/Ks24ZjZtvLEfN24ABqm1rcTd9zPgDPbqiEgnI3jj9a3xZZWJSWBPpyT/wDXqUtb ordEVtPHZagpMW548cY/Dp+FOeGa7uZ5cBS2cfL93PFNOW7fyEn1RgW4RL5VVSyKAMnsaL26 e41JIlLKoAJzyKbtHfdjYmsSNcARBgZMjkgjH9KuC1gWGIRR7WwPMfJJHfGT9altRlbqNaak esuqwnywHQYIzzuOf8mmwTS3du4mBEhG7BPany3ejB67dCvaWUFnKqSDATlQOc8cc1VuJ082 SYIqRHovrzx+tCjyvXUlW6l618+SweRBtB52nisbT51it55EBMjZLHqeOlS9ZJDTT1YsDzTM Q7ER5/hP3vw9P/r10KRCztASxY8sB/d/Gi/8ortPU5dZZ3nKSqrrkhmxjA/rTrRfMdpWyhVS VwT1q13HHX0I76eVrRgBlW+6D+pNZNjpdxetG5CxqowCOcDHX69KbipBdfM6XU7eW2iUJNgq p6n9KdY20v2FQZNzYwSMYPPX3qFo7Idrq7JtWuVSJkjlkAUYO/oaj0yxe8sw8iLGgPyyD5SP y/pUufLZ9OoipqkkFqNi/MgHHPUjp2qBHjt7V2ZVUsm3APYc1fPzLsCdtTFk1aSL5YCiLuBD EgZP16VOlu0wLPIynORgZzUxum0F11KccSQKzlS5HIyo6/1rX0rxBPJpLxJFyw4OM4NNt8wk zIubmeecpNKY1xyS/Iyev480KsEVqsUa7jkliy9AKlJp2eg0nY2dJjf7SSyI6gDjHQc1eSGS ZpSyKyscc9hx61Wr36iOe1HUZYS0QHyHIGO3pxWbbxrdqzABHI+8RwaNt9QepDpliV8T4SVi QvUHoOvavozTLqU2kqRjOe7DpUJO976CaPNvFqEbFKgKq5Y44HtXCzTARB2Xy124CkDknpWr jbcezOa09opLtmZispzsHoBXQxiPyki3KQSSyYPH/wBfioTbu0wSV7IbeSvbXCC1fDYPXnaD 045/ya6GPxFc29g9r5aK54JAIz06fnRFe9cOWzOVuozDuZyFAzyP4hxngd+lOVo5bILCuT03 dMHNOT18kDsinp1oFVhJICx6Atjk/wD66IZDDcAO284OD6ChyUVdjSUtieTUFjspiIwSw69+ eg/z+VQ2s262OAVQDqCKpu0b9CW7J3Io52miBP7wZxj+uahmlaZjvLBAucA9OnP+fzpJ7W1C 7S8zNmtY3co+Xz6HpU9uLeOZJI4QxUjZgZ+n4USTel7D39S5K0sq7UbcF54zgY9qqXz3UciJ Enz56g8E56/XHP8A9elJt2FzCvbT2VsIyQ0jDkbsbR6VlSwz/aEQSGMH7204yfrRJd+o0n8j ZtHdYPLL5AALZbkgjj3z04rMtobjU55pFG5MgKmOvAHX86tSs+UbtcZd2UdtCwG0SZOPm/Mf lWQbICAqZPkBBPrn6etDV3puRfXyHaHaCG4/eKFUEscf5z71oz30fnBCoDcld3P1/r09aGr6 IpO5Bc3csxcxRAuOMjPt64pLq1lEYZ2LD075/wAmmtHf8BPQppAxiUK5d19RnHr7dasS24gt JE8zadoABGPwpt31/Adz9nJLOXchchgDmu0W5iktVAUx8ZG7pXRJdjJPuYjwAuzllcdQc1jX FitzNEWTy245JpphuXpLSHSt0khDDsagine71CEoSsbL16fhQnfUT3sal462l8qvGZcjavPT /OK5qXN1rEUscGUTl/6f1pJjZqyT3N3chkaOGMcAMAaW1mmuLeW1kkUxRkrkDqe/SjRoLk1n fW8UbKyCQLxtHOfwqpFqbG8ld4TFAPuE8596LMLklg7aqjNKCLfdlVznI+laUltBKZBGMYJG SMZpbD0sczpDwQazIpnGSBkehBNaMDM95cSbtkC8fWnuJeRHHqkkl3G8cIUYKDdx+P6CsTXh cW8ZJUkgdR3oSBtnS2xa+0iKa5BZlTHPb8Kz/tYeNLe0w7MCWAHQUWu7dA6eZcWO4+ySCSYq m3G3PA/zis3SNH+0pF5sxlbGc8/yo0WoWE0jRC1wC65dXK/TPapvEsUenX0cm3fIVwRu5A+l K4WsGoCOezt1jY+SHBYkdT2qrpt6INckiWFZQo+Zj2z0poGzppbqW5maCKHIIxknAUflUF3J FbRumS0gXBwOtKw7mNpNoVsnOcZ5xjFR83l0BJGXRV46DHvSW4WNvTZYU3ymDamOArda5i3e bXWkuXPlo2FVB2HbiqWurBlC/t2gvQsTAuU+Td3IrqdKsY9Ls1lkJkkbll96GxI5m5tbjXZX wgVUb+9yRS6hYPpGkkx5iBbLYyM5paIfmaem2dm90XmdRKFB3Ht+P4VmvrEh1ea3t0VoBjLg Zz/n6U7c2nQT20LUCxi6cTOAcfKm3g1z8dlJrF86QfJEAN5Izk59P89aEO/Y7u2sjaWzhm2g dTurlAz30shDZhBIAB6/X1oSuwZnfvl1y3iUqIRktk1d1GSIySSPKp5wuT0/Ci3YE7GZpEKR 3ZuWbKnhDik1i9L3MZgG8quSSOh/yaN9wubF1ZtfWccsjk7GDYXjJpGgS5uQCuyFRliT1xQ3 ZisZPh7RotRluLlwwJO3DknAGaJtVt7vRbtFRlt4Cwznrj/Gk03oO9jFtLuI6UJJWwW+ZVPO f88Vr6dcyXEUflwZQdDjGaI6jloUtXSW4SOBXyAQcjPPNdA1rPf24DMASNqoTz9cUNIV7mT9 mgW2VBKNytghTzW3EXtdOKRogXG0HuSP/r0tGFzDE5sjPOiCWZVOzP8Ae9T61kWsl54kt3Mw /dA5cqMZp2uxs0lzOHhLbIoiAeMCvPZp/PSeK3Ri+7IJJ49KEr6IVzo9W04LpyStIN20D5jj BrnvE+jQCztBJO00m8MVB4xUydhpnofgkxQWRIGZC2FXGckVf168a1Usz4IzgAdPanuDXY5e bWYhp3mytsyQRH3JNN0uO6vAHbEasOmO1DTiwVisIooXllklcurgdSev49KffvGYQyKGOc59 CalNPYG10FsolCxyS5zyFQA8e9bN5cfu0SJQJW6luMD1/Q07XHfocpdNFJriC5YKE+YlM9fT 6U6byxEJAS4OcnsBRe2gEVzqFrAgQqc5H4CusuVjksiI12vjOMZI4p2cVqJu+xzdj8kjZAUg 8Fqx7nUyl63lMGdnwMnA+uKhu49UP0rw7BFK8l2/76RgeRkt+FXrDTYbu+mKAnbkcLwRVX5t gvoGpLFH5gY+Uu0cqOTXHy3bROLgDcQcA4GcdqiWorHWxvJqqxOTjK5Ykf55rM1SExkbOSVx lhjAPB/nVPVDVygXSOJUWBQ3PKj8q63whARaSNIyly5b5R0pRXcFsM1K7iMDQFiCOWGck/lV WSI3Wmo7HKjgA88dqNWFi5o2q3V2Dbef5Ma9M+nrUcd5Fdz3EccwnjU/60/xevNH5hZWsc4f I/tGM8sF5OwdetN1Vbi6UJGNkbHr3xQl3GaP2FNEjgQw/vsYDMSSx/yafYeZb3Et3N/q1B3Y J4I//VTafcVr+plTai7Xks7thXBKj2rmpr5nlJB3sTjBOKm33jN/UHnksVLyCCHb90HBamRX drBYqvmeZIQQRjJPP6027bC1Zs6PZz3cQkS3kYEn+CnDR5beyiDwbCRliWzz3oaGc9c7443T AWQ8YrU0KygjuXkdQXKEtznHrUbgl22Lr3BM8YjIjVjjPUD/ACKwb5kkvWUSGQKByen+fpTs kD0OntYUWxULlR6E9/TrXNanaqtvtUMoLfNg4zTYrFOwtPI2KSxJ5Jz19qv6lbtncxCqqjv/ AJ5/xpRV0MzZ0cW6Bm2pngY/rV3SLSSdZ5S5hQZyx6AD+mKl76ha2pWvdJEMcLuxfP3W5/Kp 5JjaBQFVpCeB1z/gKu19UK9y3FJPJZszMQd+AAuRx1NZ1xdNZqp2b2JGDnoKlrvuNM0b64nv bZp5MpuOFXPXP6VhGWaRG/dBlIK49M96SSvbsO9jSjV7eyEzxHD5ySc4P9ajvQtnArkBJnOB g9Keq9Cb63OZnhdXiEoyAOeeeeuaSG0aK7ZkZh34P5VLs9RrTc2INPHnLJOWcYJIzj6VQnmE Eh2rtDH5QTmnfQRTmDzOoIwW6ehq9YQTQ3AUSB2Awqk8CpUUvUtux0GqSyW9ukaJHEHbaWA+ 9WI0awkEHAxg/wCfxpt8m7I3djib9GnuXYfMmcknjJHb9afG7R2gkcBWZvlUDpSvryr7y2rn Q3N3aXawKsX2dAu1iZPvN34/+tVSZVgUrHJtlY4APcevtS57LXYm9znGQz3SqASxbA6813Nj ayx3kUSFQRguQScdaTauNdzDe3WK+cshDb+S3bj/AOvVbUIEkhLEbVxnB9f8iqqK+4bkizx2 VjD5SK8h6MegOf8ADvWxb3jw2wldsykfdJwB6GpSfcI7NGUbx4FeaWMF+T8pzgc9/wAKyl10 yKzRqzN0JI+6PpRKL+QJu9ug/To2Vy0ZycZ3Nnkc8D0qe4VTclEUgqnLY603JS/zB2ZQ1C0Y 7ELYO4Z4HHXnJ9KsrGttbHY6nnoo6/8A16l6f5g97LYjnZY41aQFmJwMDtWro7RzbyYzGc7e RinotEgRm63dW0F00O7LAYOOvP41izz7MOsbKoxnPHOKcm3oirX3NH+3vO02a2jiYNjG8EkK T7U8Rx2envKB854C9yetRK6kvwIs0ULRXmRWYeUmQeDyeelXbtWgtvnZkJ4P0Pf2/Kqtda/c N6lGOxV2iGSh7+9S30gDFSoRQMLu5/z/APXoTVtNgIbu8EdrGkQDueRW9sktreOIlWXaGIA+ 77cUmul7MLJai67bW9tas80ilgDnaegxWDDMssylUypH5Cm247a9xWtqVZLKG/umkndghyQQ OMYps18u2aNXIjRsKD396LqRaa2KcVvH56mRnKlcvjoozxz9B/P8VktItRkVBkKGxuIIHHbr Sbu9Rbak1zpEFrfqVcYVdqsf4sdP6066uosKispmJywJJx7U0rk6XKLBRDLIFVVHCALgcZ61 uaTA94ojQCNnY4LnJOe+adm16Dv0Mq/sI7O4ZZWJCgkDPLHtz2qGGGGO3jBUqwIAI9vf0FNp aPfuNOzNAX7KXiVQkffcO/1NaEyTQaYGdiQ3I5x0xim7pCdzibmN/NJkKhApKhRzj1oOyO2V lBDDgAdD6Vnqm+wN30Z0GjWphv1kuCC6g8D3/L/Ir0UXhSzDGTauc59e9OEuwehweuXxMAER Dtjk9P1rz94ll/eO+8k/Kmenp/Wk3d+o2jZt7OC3JaRC82MBV/hpZ7fYjuRuBbGVGcgd/X1/ zijmd7SVibmPZrMZ2YnLYx03Y5Hf8P8APWuluLy3isgNu66AGXPBxVavbbqM46/fzEIeMOA2 EHp6Hk+3arcmjTTWyq02xS+Qqd6VktXuyVvqV762itlUoGYMMknv6moLISwZMqIVHAZm5+nt ziqk7op6bEOo3CxxqojALMAADwTnNatyrtaJH5RUc4J45xj+vehNJa9AbFtNBuZLNH2Hy25A OOeeevpWPLZyKWVx5Q6kDv7e9StNhbFciJfMLKzsVIDdifXHXuKihI84kq8h52sy9SfrVOW1 h3Ny0KQvGkoCArlg54zx/jS3+pN8iRoEcjOSO3Gfx/xofu6sHyy0MC4ndsSO+DkFs8+vNVIN SIvQhJcFSy7icr+GPf8AzxSb2Ftp0OnsoUuCqAB9ygMAevoCKp3V+g3oirER/EOMHPA/Ohuz 8hW6XOfhDz3Krt3h+SRx07Va1GGRroR/KQOMKRwe30qtd+jH1v0KL6eQApKlsDJ3VWljWPzH fDMCMHJHFTdtO2w7I6Wwjht7IGR1aXOWOe3B6VkzNKUCJuLnkrjOPfH40Q0t5kN28yrBo92k Mbgi3DAkkjB9P6GpbmBVcl3EoJySv8R9RWkXYbv0P2p8Z3LaVbRqV2uRgMTnNQaWGlso3mbz FAHFdEV7tyHua7rEWV0gIRe5A5pbuWMQl1JX1U96NQOIuXh3cwF3Y/ezwDW3In2sQQbSpAyQ KewjevbV9PRH3BWPGW5wKw7XV47VpPMIYcDci8nP1pL3ht2MS104z3cpeMqHOUU9h9K2bnTn inijify1c8gDk027aBa50A8Kw2MRklXCqpO49qmijtzEWLgxhcndUOTlsVZIydJ1O2WwlFud x3YUEcEdOv40Xcz2lmfNUlT3AxzTt33Eec6RNDDrcryZY4yVUdOtdWyLPeLKFKRg9Dg5/Cqe glZmnPOkCFlRgw984o1pJG0xZZZgGI4Xip2Gafh6eD+zTHIwLY3BaqaVcW2nX7tKuXIO0YzS d9Rtoo3W24Md1K6LG7HgcAfhVyZYra0Z42DnooVu/YU0Sc8txJpUwSNZA5wzFjkHP+fatNYo Y3Ml05eR8kZ5JpvTYL/cZsMgdvIRUfqcMOhqtZ6guh38skytNdO2cAcD059KX5j2NGPULq41 RXQtGpXke/8An+VXLpHJJAzI+Rk8Y/zmhqwXMyGJzbNDEjBlPUn/AD71RaxuJ2ULKyA4zk44 p6LcZfuIZbGFYo5BzxndnGetS2zNpdo6+X55VuAOKHqtBIwtRZ7u9juJIlQL/COwre1jVbe0 ktY1IcY3O2eAPT60WeyC1tSnF4h/czrbwKpx8uf8/Wud1a7vtclitmfyoNwLrnJYj9MUKHcV 7uyOi0/QYpL0xyBWCjILCtO5tLbSkR1KsS3Y9aG9R2scxKWl1mSQxhFPC/7I5rOsAdOhYxz+ WXfBGOuc9/bFO9twtc3BE23BcPnnBNNku47OzKiJvvcBRnNJa7Bc5C9me412FjCVUAgL6575 rZu1t57ZAsfzAfwrjApq6tb5j06lWFhcSBFDFATj3FW5dORTG8jhTg7ttDdiU7mteRuuhfI4 ChsADvVCMx2luhdSZSp+QDt6VO+wdTI0ee5ku5reF1ihyckKMsf8KqXFopvJtMgwm9fMd2XP zHtijQbMJDHDLErzfaHbgDaB+gHAr02wngiXDJ5S7QASOp9KN1oPYyWuITdmCONkUAs7uev4 VSttQn1PUZEtgVhRcAnA+ppNPqybi2FnDaW+JJF3F8nP1rO1LWZI5pmVtluoJHzdRQkm7FNk +j6mZNOupxBvBXCI/OBj0rd8ONMtrLJJIsRwSEQYGaOW24aHOW0SyXQEoOw/6zn73+eaorJF bpdzQxLA7ZUNjqO9DegNFHUtPEulxmZxIxIwODn61yt9Yi+aVIwYlCBRuGAef/rUXbXkPQ7P wPK2lrJFEoYK2NwH3qTXNPk1K4R5SFbOFUHgf5xVJdRO99DPXQ3mvzF1UDOdtdDDGmm2UkoL GbooLHgUpX3Gzk44wsztOMljuxjk/wCc1qXVufszOp2IxGAR0qd0IvW1o8VvBvChd2Cw4zn6 0moQl5iqkqAcEg0PcbOWktkXUWACux/X8a6KyiRbMllwo7cDFNK2pOxUk1R7p0WG1VXBxlsH 8c1s3t8dL0s3DjzJjk8ev4/nS9Smc5pSmS7QXy+XHLGWCpydo/l1rlxbo2uMtnEzOzYUMemO /wChoj/K9h2O1s/C80eovc3gCsRlRjJwO351Bopfy7oWvDsCFZsdM4P86Gr9dES9TP1KxNhp pWe4V5CMnFc6lpPPAmQqwgcE45NJ2TsNOx3WmXKjSF2qQQRkdMn6UyfTzfEMU3O2VRfT/Oar ZMHZHI3gNvM6YweenYium8OX7RWkh24XJOc9KiK5mNorRXgi+0OhCBjncBn9KhMkk0BAnbys Z69arlV79AWhkrL1ETlYyfX7xz/+uuugto7TQMoDvPJyM9aSvawmjibWNTcoCvGTnFbNzfmy O6FdzpzyufwpNXVl0BvsZMUtxe3EdxPKWk5IIOAP8K3rLWLeeYRzQSShPmKo2AT7+vSp1YPY taU9vquqyPLDsjII2EDgelXLyx0a2lBEeZMgZHajma0W4Xuilq2m6TLbIzoZmx039Kn0e302 2iZ4bYcdTuzjmm5ye+watEcmpT3eoRwQsUiUbmAONx/lWg0ss822KFnCJnJIGKWjWgrHmP2e TWdYktXPlqOWOenWujjNvbidYwXOAEyM459aFJPzLWhRvx5e1ScIc/jWbKg8lpIziPaAgz0p W6Cemp0OmyP/AGewaMlRyrbv6Z/nXL31wIbiPkghsqW5HWrb0EncfZyNCHlLKxc5B960J90s ALSbznBIXGPwqVdbbFML27SR41TAOemOOfapoGt/sojVy53fMF4/WlESegusfap5bdpcRQqP lGfeqcOnNcanuDgkj8qd+XYad9DYlNva2cq27ySsThsNxnv1rnFhSa43nLAjlT1NGklqCV/U rvJLLDHCqsXHJ9hVu3McNlMQ4dwwGQMAU2tBPsXZCHsowSCAcEL24/yKyTpK3kzTTPIka84/ wqW7DVmczqLRSagPL3qhwowfetaGBJblh5pLHJUDj86lpbid3/maH2OTyFZ3YMR371RihKhf k3A8g9zVb6dBpED2MouVZsbVXBHp/nNS6HGX1EShGBHZhx9fzpPyBGrrmr27pEJFKgNyWIBY +lZk2k5gEskoLtztHIH51PL9p/ITTvcyrvR41sCWkKkk4U9B/wDr4rGtbUQhS4ViF+XBzjn/ APVSbS3G9rl2NAWj85VDghmx0qQ4uQ0iJhRnGO4qorSwRutbaGRdWryNCsbAOQG5468/4V2m g2Mtt8zP85A3HrnioiuZ3YkrIxdSdrrUAAQx6kDnIrL1RjDEQVbOOPrTk1LR7DSuI0cZtlTa Wdl5Yr0Pp71q2Wki+kLTOiIo56nd36c0JptJoOtjPleOTcsIMcYIA+XGD6ZpmnXDRQybgCpG QAPWm332Fd9BdLRW8xmLKM8jjr9afFEy35dVwoA4QjkHP9aIxUVYNtTHv8STKGyhI2rke/X9 TSwwrFZRvnM27oQPlA9xSjFuVuhT10C/RbghpJBI6juvAratrpLeBFOWfv6GklbS/qEuxmXl 3bsys1u7vyD0O78eKiurNGiJAyzYbAHQHv8Azojd3v8AId1ujQuJrfTNKkG0KGO5mA4HbH6f qazdWvrOHTUbaIs4A3Zw2T+lS3J/5k7mOiKZlCNubgnbnmt2aC+mtWVhHsBGN47fWr5udAlc zEha5uA7JsHRR1x71pW0cAkKkkjGNxHb6U/h2K32ItThSUwKgIfeCD36dcUq3gs5gZN0hY/d AwSBUSaupNWaJ2MnWZkvpQFjaNBydwBx/wDXq3ZRIyOkZAIXLfN07Yq33ew1bqUpohbwBWX9 4Rjrxmq6uDHsUeU5OC2Mc96m2oN6jRMZHERXLHsw6e9bd6q28MSPNjChsDjBz2x9KTjy69Au nqZ6xJcfvGkyAeM9c/5xVC9W1Tc4fcpOSScHrTckvJ9BN3K8waTHl5KgA5IPX1rXS6a1ihZm +Ycg9etNNRVvxCUepgm6fUtT8yV8kZznoST3FdHImNQUI24pyuMCiLQr3ZftNOAgkluGUDJI bIzn0FZurXImWGFiWXvx94Hp/Q1KbabQtWrnJy3AadUVQhZuOeh6elSXFlIskbFwGJyT6ep/ U0NOX6lbGjbXTCBgoy4OBuwc8112sCNtOQSnIKcLnH1op3i7PYSdjyjW7uS9WOG0TI25PHck jGfwrUh0+fTNhljVMnmM9h2NOS1dtOxS10RqXsWAzIUY54UngmoHnlgsVMkQQMccjr6fzqrc 2r37EvR6kOlRy/cEgC8Fmx1wKdey27xuMOzD+P1/HtUqSQ93qc86ReaULA/L09B/PFVyzTOj Nl0bHV+uO+O1LRyEvdLQhaF03qJDnAj64x7Hj/8AVTJVV5tkcW4ggksPT2/rVxhy6J3BKyD7 KJrmFF+chidnbGf/AK5rY1eRbMbJQAo+6F7e3+fWpb0tuTKXQzG8RTXg+zxuTGRj6D/Jp+mC B1kMyGVdpBZyCFz1GO/4jvVQjyrzZaenmZU+nxyEHJRGOQD2zkY/l+dTxaY8MJCMSWz1OdoH H+fwqN3Zi1I7zZFKiRlEOcjIwCR6YxVC4tGMjMJOQwG0jg5GR+mK0buroSdyCe3R9259pOOc g4/OrZtYbS2STzDNI2eDzt7n8KSSXzBshuNTnhRo4IgknTJPQ9x+hpbEQWxVpyUBzyQM9+e+ O1DSTsxRemu464uzbkvagBG6EjBrmVurmG4KwsS7cgkA4yfelblWr0Y4u7NCOxljUlmbLD5y BnkjH+Aq0ulyG13sEC8Fcjls9Sfpmhp2simijPa+SQqgs4A4J6j1phee03SwoVyMhuM/TNG2 5LSsTPcyzyJGzl3Ubio43c9eapy2i+aBhUIBIUv/AEq4xstNwXY/ZfXNFF3pgkLHKkEfN3q7 o7SW1upCGRRjAz3rqv0M7WZt3N1O3AURo3OR2qvfJKYApIkPuOcUrJDvcx7yYwouYsknG4dq tWl1LcE4AEiN8vbmnYRpajazahBE8solYHAQ9qzb7T1tYRNIQgU7iM0k1sO3UqazeiaySa1D GQcAlT0qLSbKSTNxJMzOfVun4U0lbUW7OvYXF/AN0pcdCN3SsLUZDextYrD8wwCwbGKlW6FP UsaXHa2OlyLdHY4G0KBzntWXdma+jjiJZR1Oefwp3bdxWWxnNZRaZIHkXy0PQgdT6VuxTJc2 aBUY/wAIb0/zim3cFoOuWjtYxvO8gZC5zu9KqTW0c0ccjRZzwTjp7Ug3JdNt44bi5IfaNvy1 kpLeJM0kcSb2OFO3t9KHqFhLrTQl1FHckluWwB+f866hYUgtXcABk5XPAzQ3YZkaldT2oSaV VkJOABxUl1eIIoJDCUKrgjPU0rdtgTObt5rj7U6xwmNnJIbd0B9vxqBtPa2ugGyxP3mY5zz6 1VkhO6Omt72N7xUjBlZTg/L0NaJsp5Y3uJ3VIQSECtyc/wCRUvRajtfYwrOWZJcRSEAjHrn/ ADxWbqbz3V3BAsgVQc4xjP8AjTsmJs1JLNLRUfbht2Bt7nvV2S4VEkCLvJXow6/hRcdzNvbe a6sBGiKrEYYntVCK1g0u3jLDzJCcAA54o0+YmyXR7NLPVnmcMFPI3Hg/hRd6jtmMpjZVTOCR 3/ChsexPCZLtXYqPLK8k9arX8PkRrKQWwARzQLoZLyyz3jO5CBlA+lVbqVI7cRoNu05Y465P /wBehoFcu2Nw93eKrfdUEbR349avCaOCZUJGOMnB+Wj0A4/XdXMNyWhj2xlgin1JOM/rWrZv 9isnEq4mGQw7Zx/9anbQGynDcNayOoG2MjBY84zSXFyY7ZLeONpnLgZHO0euKNxI6HSI3lle FVZSoxlznBp5hMrkSOUH8RzSe49vQ5ixgM2ryQW7shHLFGwQCDzXNahdvH4gaGNnPO07Dyee cnv+JpX5rLqCXc2vDmj2h1VgAyIsv8Z5GM8V6mLmxWZ1DoyJluRnP4U2x3tueY6pfxahfTsg MQclQOmf8K3NI0y2tIpgJCG2Y27vzpX0Fe7MSXTYLaOR1lCrkYG7pWxZeGv9FS6uzmPBc9AF XtTUu4WIptQtZbAJBGXyPvqOMVFpikxsrPhCpOeRj86Tv1K2MV54pbxAX3ogxt9c1S16/hTT 5YowzMFO3ae5oUbq4X1M3SI1/s+C4MTSFc7gx4H9aW/1A3fmTSHJxnGOmKTTvoPqd34M1BGU KsA2MOTjvXT6tbMY98KAPwTnggUa9RaXOOsori7vNqEqS2D05q5q+Y7vymuFkRRygIodku4r 3OAur1Z7uUFFBPCBRnjPP04rodQRrm2ijQBHyCxYgYFDWg7kGrXuxLWJpkcLJ90Y5/x5/rWh fyra2agEPK7cjHYfp60JaaDOcj1C2N7I7II2C4GecH14qWwxdmQNJvAJLe/4flQrhaxABm9d FIK464PHattrWyaxmTzXIjG7LHv3pX5QRy03n3N4hCbcR7UIGMD/ACak0HTzbau8hfaw+6S2 cUJq1wudhFrrz+eZJFVVXAA5/wA5rkbO4uHuVa2KkFST3zUtJiauOvFE9ufMRDITgZOcVTvI Y7aFItgYLySuOTR8xrVG7o9wLy2IZVTn5vl4/PrVbxPqk81m0SlEgxgFc5+uadgvroee6bD9 laNgD8xyq46iu78K/NFPEI8ncQC69R9aI26BbqMv9OSOV4SyEjBY+npWTbzLNP8AZgxLBAPv dB/WmpK9kNNWHzRRtAzRHCoQp3e9bjxSjRiWnGCecccUrktvc5LSULvHIpCRFjhiuMmukvbY vgFgByGJOcDGen4UJpDOFvmmvbuCGIbIlPIXqfcmux09H0ucnGSy4+YZx6Uk7grWIraV4ZJG ceWzZ+YdyetZd872sqNhZgOuO3H1oenqCRYvVQWwYDbkDJNZlvfGGJkicqp6kZ5pSd9kPfVE eixCTUxPI7FSeWL4zVjWPFE4iltrZAZckB93QetTGLastBNnK+FrWPSZpCX8xy37xx/Ec85r uLJ0uLljt8uMHOSetJdlohO7JYk/t/URmQpboPve2ff8at6pZWs8S+UAsafKHJ61SdnYpPob mnQQwadK4BYn7pB6ivPL3T/tE4aVwgJPAOAPw6U3puS07aEl9BDbQJFA285BJHbkVHeTxiEZ JYjB2A9PyoT6otaDbe0ACs4KhlOAR2+lO06WCQyoAUYtyfQd+fwqW7SE9/I0NUjBuR5fEHGw buuM/wD1qnhmeGM+XGFlIyQ38PoKaXVMdiJI2nic4C55J6dayLuURvhFJbHPbFDE97BDAsdp IwlO6VgNo64qRpYraxRIyXZiBjNJOw4mkEaRVhwuOCxIPX0rD1W5e2t5VyojGcj1GamTs7Ca MC2Xz5QWwUA/hB5x/WtGG4jedo1TdInXaeRQk7aDbNEXDz3EaeUNkfOS5602Q4gLRkEg4yGw B/8AWosCvYwfsL2EzFrgNM7Zbad1X9N82Z2EknCjAAHQ0OMV8OgLQv3kduwjZIwHBzwtZd/q J3ugBIK46Gnfa+oN3Rxk90buZQCTGMgccDpVy2GAzRsChYqoxjIHf9O9TJcvqJX2Rfcmd2VF DLtBOD3z6np2rQl0+aztExtIYlty+n1+tNPmWn3DucvNeN/aCIEVgSCHUY4x/n8q760CxRFg +5yuSoakr7sLnLPcf6QTEgMuSS2e/NVp9GSCye4mnLzO/Ck/d/zzTum2nqCZpwIzxtsjBbb8 u4dD2/Wn3dk0UCOy+UQCT70mktXp2E9zKWxufsLllUtnO4j+dVnupYrNwVRW7kenrSSfL3Y7 33LmnQsYpVdxhlPPTb/+qmqjQu4J3M3KKO340JWX5gkZ95ITOqJGpdeCcZx61oXMklnHGGUI h43EeppO3NddAS6kVxZC9uljjgDs4yzAjp/WrTWkUSsWXaF6knvQ5N7jv8zP+zTm0E7opgRi VXj5v8isz7XNezmKKBo0bhcjrVcia/MVkhLnw/Nq99FbTnMCkFlbp+fapvEtlbTalDHFKrlF wQDkKef/AK1KTXYafYdp0kFhIpU9Bgkc5OKn1G8la1SMy5DORgnpUttdPmJ2aM2/uRDexQJO p+QliOnbHNV2d5PuAmTORkDHfNN8zXNfRBsXJ2EkwkkXfMRtUD+HHeo9K0yeTXQZJCqunLE5 xnrT3G3daG14luYFZLeLDqPvnGMGueSNIolMKbxjLj2+tLRuzJStuZLxSOqBm8s53EnnvULT MPMWLDsDjavfj1qrc2xWxasYI4HJaNzIR1H+H9aZNq0VvraG6hJjwSOpyRyKGrKxLV12Lb3S ao006RFYR1B469Bim3dsYwZShAwejY5qXdu7Q0ubQpxWNy1yFYFEPHrx6etbGq6ckFx5e5WI AC5zx7ZpxikybNPyOdsoog52nbg/Iv8Aex+taC3Mv2oRxoCzjlgOlCs73BO71N25kNvaRq0g MmcDB+7zXH3TFrgJlwQv8Rznj19feizWnQpKxlrBbWt0pOTKykHIznNaV7ItlBEFQIegXrio 1eiGndF3SmmupWJTZGvI7A8f403VL5t7OxLKgwQOvPoKp9gtYj0q4aGYymHaEBIJXlhzWbqG rPdThmmBRuTkDkelS7p76iWu4lxbiCVFAKlj83zZzVPURJqUwaTJROF+bGPQcVcUk7vqNppm vbRG3tflcICcKM9KoSaYQ67cSfMCScY55596GrO627kWNp/D0BsjMJt7uSRxnaPb0/CuUmsW GoGXDDDEKQTjOOmM9KdkinYlF6YpGzlnPyng85pXV5LcBiAeScHkH/8AURSTV30B2T8ijp3m y6tKEiZQpOX6Y/PHsa0r6IGNmlwzAhuT94/5FVolzb36k6PVGK9wYFlKw7n2kjDD04/pWral XsmQqZAB99ARk9qzUeZ3HZHN3UgUKykk5yMdQPT3rQsLhkjaRptzYyCx6cHHXntRZt2Wwn6k /wBva+BZoxt5OMdu1Zk1nPdXchaPyY/7xOOB9Pr3ospaDk9kU5VREHmNhN4JfpkVYt3FzGVy IzwvI7HH/wBars5BfXTY2LjT7azjjeI7pMncx7cetcwd0N2C7faBkdSflHGPrzUzlZLuxPTc s3d4zRM7jcqLkbeMjvVLT98l2ziM7Ax2qTnp/wDq+neqWq1Br7jRur7ymEhcg8hTs+6c/wCF RRtLqUsbtIyqPlAIPfvj8ap3WwkJqlnFDFMzEgHjgnP+fpWHM0sqsAGkwcLyQMj3qVK/oyut jVt4ligLODvByeOo5rAVxPIx8n5g2Sqr1z+npVWstBJpan7gyW0VxHPGZCyA87jwf/rVBpg3 36QRy4jPfNdLZFjrbueOImGRcFeQcdaqSXFq1s7OcsBjG3pUJPoU2jn5popbZWMe5Ad2cYzV Aa6rX0SwRHawySwwP88itEmyG7GqnnjkAK5bOf6VnXtjJc3DrMxYkZUDOB+HelsOxe+2lLcQ RxgoF59qisvMj0qQEAMg4JOBQwZesk87QpJY7nDlScqe/pUOg28+n2iTvI0rry7Mc5/Olfe4 GVLcC81ETSOpBYEjaQB7811MNlDFdvOZVYA5AHH4UO6QIxdYuIbm7izGFjXOTnqfU0/S7i1h tpGeVWVWz8gzS1Q9Cy0X227LIuI8HaCMZFVp9RT+yWVIyJfM2FjyBz/n/wCvQwXmQeH72ZLg lYgY9xGMfe96ju5rqQIqxiMBvmKnk+1VZMRYvESz1GLzw0ssiArjmrJiFxKwYFEUYwx6UrjS MVbVtQmMplAjjJCqTwB35NP09J9ZtWeRRGikhUGD+tGiCxFYaiCoc2xB7HP9Kx7me9uXZtwj XcQAi5IFO3cTZ1uj6YLcI5baHGNzHqavvpz3U0kSyk26rnIPFJtX8how9LkhZwDHtiUn5hRf 3UcMyTC3LKemfl49aLsNyvJJK93bsIwQ2TtPQZGMflWxdxSedCgCR45O49RQ1YDH1vUgIngS FpJduWPbj3rn2uYmnAjtnj8tcEkdTSSbE+5qX+rgyQiKIyk8NzjiqOpXc0xW3WERqedzH39a q2mo7ssWV8kM81rgi5K5Poo7cVFNaL9hYSSt5n3jg55o2EQTOjGN8EOAQARzXP6g7RRz5j5P ahb6jtbUzNESaR8vIYi/3VGDxXaXMbWpjUDLtxubmqutkTruzhfF1wshhwOVcHA4wa1ZLx7q 2gjWEEO3zMBjqKLWQ07mfrmpmxjKmPdIRhVHr61NARcwqzMAwHVSRg0JdQTuiz4XnWS8aGVy 0mc47c1N4j1yO3JRnCRCTkIpy3tSkuwX7nCWepWdx4qSWZpLeARnnBO49uB6U+0urZtdmuol Lw8iLdwT9QenOab922gNps6HStRMk8ruUiMsw4fJOB39u9WZ5pZLqeK3j3qMk4bpmhLQG77G FZWECai7XDtJKMnZ6Z//AFVZLyXkphtUY72Gfmxx+FCV9xS02KcOmxnUbgOBI0fGM5wfrUVz fzatdpDI8jxAfcV8Lj6d6el0OzR0MDWtq3lRhwi4DEr1NTac6LFcQxrJK5OSzAcAjpiper1G ypYxRyXwQRnexGN3c9qraqkNnOZZSoUAkKvpSk+VaBfuZ+kskemNPLcKYwuPLQ5ycce9ZEVx A2lXcqwFmkOQzDJUD0pWb2Gnfrod74Dkkdw6Q4QD5QO2K67X7e7+zTyy3PkqB8oPGf8AOacr LcR51pF4sdk4BkMrDKkZ549fWkGnQBWCZwwyxJ5JqXpqNO3qM/taOygEFuqlunuefWtvUlUW IDxEyyKCx7D1otLe4762MCz0t76OOKNfmDZ3Z5A+tb93paWMa5kBfOCD2xTchLTc5rUIYBcg soAb529M/wBak09ovLlWH7zcH255qbsdxRcC2iaCNAzg8ufSpmt2mgbcwX5cHIK4NCs9wucr aXTfaV3BgoO0YBqV5hcXJMSui9Gz3xS5bIT02LguIoldQweU9gPbrVW2juYZ5XFxsLfL8wwf ypvXfQasy7NaNFZxK0gaQqSw49cd/p+tcveszwrGhEoB+bBzk+lJ2Et7ndaM6af4eBxvdjzz 1/z0rGvX+1QMShUcgKOOPr+NDdrA2Z+ktDYysXVnGegIGPcVqeEnmvZbibzCgEh2r0AFKK18 htXKmt2UMBuBJKzSHnaF4z9a09K0mDTdHGoTxllY7Aqnqaq9ndbCaMG9sTNdq4YRRMcpF6+9 dQ2ln+yVVyWORnOeaS1KvY5O6twdXts5RVztGcfU1rarArBsOXQnHPekvLYHpqc8LtrC6hEQ DM3TIztrZsZZZ7p2lO9ywAyOhNCuldCuWrx4IrhhIcKnU9cmuYv2WWYi3R2P0xkUnd6Ambni Au9rHH5ARQuWyeT/AJ4rDtpY7OBgQJXHAVcc0/IE2aVlbI22OUkbgc7iMD0rYbT7LRrZY2Tf KQdoXvycCknbQbRy8MIl3SOqRQnJI9BUFncLczSwBvkPJOKS3C2hvyRJFbtBCGV8kZJ9D/ni sNi6ssbOwReOucf/AF6p2TElZ36nYGQppMKgAn0rhdZZYjucksRgKO2elTJ66juT6Pok2pXU YciNOCQe/wCvtV69CRXjkxqdpwG9waV1YS1ILjcHVyC25c9c5/wo8PmO2sY2b727H19aadxk M8EcmqMEHlAjO72/yKvXTjymUMSgGMgc/Wk9L2DcpTuthpyEkkFsnrkinWMMl9fMFj3KoyTm h2b02DqQOhub9Y0bchznA6dauHbZS/LH5knAHGcD/wCtSQ9dia9c28cUk6YdjnI6kVx2vXBm IWBfnzxntz2H40S303EXoLYWwAcbnIwc9qdp4hguJBghiCenqOlHNbRjs2M8t2naMfLGRk98 /nVWaSYSRpEuxVPTPU0O7VvvBOxlQsGupJJEIJ5LE+n+TXQWZcWsqLGQ5OSxOPpRFNoCy8Rm vYwH4xg/L0qdJPsYMaxK5bs4zipasgduhw2oRojskCeU2MuSnucf1qvpkBMJZUyoYqGPb1/p QppsDZttNcRvlgEOcAelMnvJL1YokcxwgYGF6Dn/AD+NDio7A1c5G3tS2pBhK0hC7SoHQ84P /wBevR7KxSKJlTpg5A/z9KI2vp1Bs5qWBEmKKCXfJXPei+t2t4oQ7Bt2CeePypSVmC0XMaku sS6ZZbbaJC4xln5x+H41zkF5qd5LI80itGcAKFxgc8cfhRJOStcnpdlprq4s7EbJCjYyCBnn +VUolKQGQrufbyxXA/zxTb5dwZctDL9mZzEdwGFz/n3rN0wfa5HlllKBR8q+mf8A9VS9UrFL bQhEKWMs1w0nK8KGJIJJH+NYd1dXWs6izvK4QDCgcZH6etJpPfcFvqdLbXs+iQMyDcdvGTnP Hr9ap6bdXEsTPcKHZjuwOx/yKJR1XYm7RHPqktzJHGdyxAYC46VsWcwMLRxLvlx8pwRjP+f0 qlK7sylqQancJZbY4ZTLM33jk8etUn0uO3w6AE88+ppaXv07D20EW1yyru8skZJK9P8APFLf WMER+RmIAyeAe9NRTG5K5gWa28xdQW809Wbt+NdIkDxRNsZQoxznGf8APtSjJpJNC1W5gyGa O9DgMpUY3Z7Z/Suy8PXawBnlw5C5PA6HpQ3d2W4c1nY5nWJotQvEMeYz5hJ64J7nH41T+1+X GyoMEEAYGR6UlJye3oIrXEf25ViYEIxyRn/OKhjWQXpiQZJ4UBc989fSnfl0e41tc1kufJkk IAJH3skHP9ay1Mkl2wSLedoBJXv65py9/bcHqhYpJLeURwwEktgsR1P0rPube5uLoJNICBnC A8KaJRfLfqhF+RZ5vLhiZlTdksvtVa8NxM8zM28NkqMZ6VMYr1fQEO0tXN1G5jwq5+U45POe PStS2u5bm8DqqoFOB255ppNhZvUgvklNw7B2ZxyWx09q4+a8C3PlyK28gLnso/w6U2nv1BNo taKkUF8kxjUMjcf59Oa6K6RXdy+CSefelFOzUnuFnsjoLfXIdK0Z/LtS8mMDJBya42FLi+uG lkjVnccKFxj8AMVS93V/cOL11+Y+5muLeyRCFQlstng8dq52SESX6k/u1Xt2Az6A9azSd7sT 02Z0qxNeMCqAKgzzXOFZpp0U4CPwpPPX9K0buvIV7anSxwxrlSVIX24A/wA96xrq9lZ2SNQy qvOMfhzSbbsPrpuTWd2xyJCzDICJk8Gsu01C51O5ZfKDRAZLt0Ocdun86J6bdSU22Xrh49ix ptjVcl+Cc+wqpZxyySHCIIlG7D5GOam6fmVvoasLvtLMNqk9j04xj8az5gssoLq0itkkZPII 6Y7VS97QPQn1K3RIFDr5e8dCcZ596zJrpbS3FuVJRhyQeGHpnmjltGy3E7vTYxgiRyszIAhH A3gdO3NaunWUEVq8shYs4yowTt4q1FroJXuOUbGl2kh2HpyOD/WoczvMQjBQWGAwzgd/yx39 Kzi+bWQzL1iYtfCIqr4HQD71dDb6ZIbRp5XBLEnnJINNKzugWiMW/iSZ2O/Yq8EE/dPf6/8A 16zorryFKiLezYAB4yOMZpSceoPUeXMYZ3IyCQOPvfhVBLiOFA0xDq3zBFHf8quLbQatWLE1 8/yCRA3OFGcA/wCFRWzl5xHOxRF4GD168cfh/wDWqr/eKxYSAPJGAcoeS2M49DzTmuZZycKu ApIOOvt6etTZaC62MmeArKq7cIcAv1wD05HQVqy6XbQWhTKo78qABzj3qh2S0aP2Tl1GO2ZL VIdxYcnqBWFcLLGqRLGUO7llOMV02tqZnodraRKI5JWO4qBluayr7Uw8BNrCrwngu+RUK8n5 FbGfe+beWwt4sRxLw2OpqKwsxZzJJO7Oo+UYHTP0/Cr29RWNiW+H9pCGFSCOSWXqKo69eXB2 mKMKcEbgDxUpbXC5n+G7sQ+YtzFvmk5yOtQa3dxSXZhQlI8fOvrVW18gvodLo9paizMSLtOO prN0yykntp1Z2CbyBz/Spv3Ha5Nqrw21ohBDHOCPWo9VihuLyB3cRJsyRu5OO9CuIxL63knh csFCclATniqNtd20mnRwxBluFcbsLwuOpz+FPyHojpdW1aJzFFaTknOHZB0/z7VDiZLJI0f5 BJuOV6nvSS7hcz7u8uYdUtgsrRx+o7mul1l3gt1I+UsQDJkDHvQ9AWpmyeXbvNLDJ5s3lgLv yeR1+n402SzuLm1EjOdoJLEHGRRewWM250GbWL1n5FqMCOM/zxXRWunXFkVgS5EJkwCAM8d+ vTtTbWwkupjrei31BrZIA6Jwdx5J7VDqlykCqxQsc5YKOFNJId7lizkbVEWWdsKv3VHQCr99 O0FuQWdUPAAPA9aewGNHqK7DFaJySBuPGPwqHWrS6fVVRHTYqg9ck/hRddQvcvtNcJe2qMyx q2dvGPXmr135a3iTSM87KMF8fyFJiMa/d4bhisXyZ5DcZBqzE0drYSMgUyvyxPRfaiwyq3lf Zo9kZAU8u2MVPrd9aRWjSkiQoufl709/UDnNAksmuvtTvIDJwzOpwa1tT+y/bfKtnJQrl2B7 07tOzFotjJZBbyK0ZzGOMgg/rWDrVwLqUhQzEjgLyTz+nNNK7DQk8O2841AyMuURcBJG749q 6nUJzHKpuAivg4C8gelDab0D1POvEUj3kGIyUK5JZhj8P5Vt6PayiC3VyHQ5b5ckkgHAp2sg Wxz+tRrBdl5lBdmOBnOKv2sheFpQpC7M4Azj/GhaoSZm+G79UjnlKu92MlQq5yM8Cptb0yW+ hiDNnLhyzDp25p9dfkStUcz4isYdO1K3Yyhc/KDjk5//AFVp3FnHpyK0kyu+SAm4ZP4Ucytc q3LoY9vqU0N9G7OsWxx95c5/Cu11fWDYtFscTSPkttUKMfT86lRY7ogtNSttNSWeVA8zLjAH A/AfSs3StYKzSLJHsZgTgHqO1DTBkdjdiOO4RkS3Mhyu0YOPp+NWNJsTA6SBQ7YwFySSfrmh 3Qlr6ktzrc5vZ1NuokUgGPP3fWkl8aJa3EcKw4cyAMAOG9Ofxpct1oUtCrG09zcz3Er+Wob5 e20Z/nise4tDdztcSyYiwAeOvNDStcNUyHSDA8bI0m1IyQBjOaimuA1gwiyI0OD8pGTzUttp JDWiudX4K1m5jMcccmUHHK9/8iuk8VWlzqoKO4mcDLEqOB6UOKQjNW7GiaZaynBZo/kXjn8D Wa6tfTRedKAHPQZ/pTauF+gwRx2d84AHAyMDOTzV03dzf2CO5KgqRz65I/pmpabG2GnzNpFi ku4gh9ueeODz+eKDcSSXBZ/nDKWBbqaErK7B26mXqEyxuu5gwxwCa07G+hNsYRCTKf4yelS7 rRD3WhHIYraESJwWJHJzkg0ty8ciMrFmxyB2JovfQFZ6FTQbk2000rxqyheOM4qle3az3kMc QESs2C7n1o26gtGdWbjTtMwjQZJTlwBliK459bWa6JFsY4xkDOCf0pNyloJFhrU3tk0wLAlT 94/59K5trYWmniVTlQ3QL1NNWW+4zrdN8s+FmuJhtZcj73AFZ1zfwz2ipHksy8soPH+fah3l oDOPluQuEAAIyGAOM11vhWKW4hcYKxls4oS1Gi9c6U19qaWyLthY5kJOePT61o60zQ2MVuBt hVsKoHp3/OjyF1ObaSS2ljuGlDugwqkD5fyrbuLhWtp5pJAWPIVR7dPXtSTswfmef2sPn6lH PcFwoIOCSevQf59K6/X7lZoQIlCpx3zz/k09Xe/QHJs89vtSi0u2gVCZp3JJVQTt7c/5zXVe FLme8vCJIFU4yTii1/IaWhpXb295eCNQShzuYDPP9KpT3SwM6xt5A3DaTwfbHpUuQbj/ABBe tNEgkLH5MZ9Ky9PSG3sjKsuQCOGX8qV0gsXh+9mRy5DkE4JxiqN/c3D3SGFdsYGNx6t6D+dN LoNsqrLK/mhiqJ3J54FV/Dd/JFqEmI1fL4O5etSo22BrqdTcXe+cEAkHkj61SWNZZpZ5VYx9 FUqAM+v+fWm79RXsjoLy6hs7EmMALgED1rgNcjmjZGdCZSRtGMY44od3oDZqW9vNbxq7uVIA 3EdTxUsrxzgsrZRfvM6Ekn/JpRjyjsmyG4ka4EZA3/KVC+vBq9pVmZGQSttAbCgChpXCV9uh X1mcTawsMTBUwAWHH1qK6kc2jxqgC4K5x1pPV3JvYjjsZLmJGkTJHXAOK2LMJaxsI1JDDBwa rqUtdzPa5/s6EssYiZ8Kr7ckelRSsLNI44m3u7De57+wNTZtg1cNVlmmVN0m45GFzis+5git EUum5hjA75P/AOs0WadwtbRDb3UBcEDYNqjAOcVUtriKzkd5dzscbdpqWm/ULoupdebcjy4t 2eWyfu/5xUN21vAC2Sz4OeaqzAzheRLGVEZLH1H+c10VjcpCghJLyfxDpj2pXu79ew27lSNG upmkjARAcYxjIqndIzSt5hwQOtC3JehxV5c4uDtGBjpv6c+netKwuGW0QTyqyEk4UY78cVlt LUSK81xcG8aOBt6sML9KuJay2tswJPmt03D7tbb6j1SObtLOQ3Lljty2CDxn1r0K3t0gsGJb Bx2PWpSsxta3MrTdAFzeNNLOpk28AsRx24rO1Fn+3xLgSKM7Rj9aHNLRbiT1INTmlmuAMCMD OGB6H6fnW1d2yQgQpKGXqQeO3rRZN3YXvoVLlEjiCsBgYH4momhW5IAfKqCfl7j/ADiheZXT UgS9cwBchYugBOKrabaiSMuwGOuD0qXG7s+om0nYxb/SF1zVoYovlWNMuckc1u27iylfEays ehJHIFU1e4MilLXMzSzsFAxkAdc//q/WpJ/LgsjIAC3QKpxyc8fzqb2Tux6S0MdStrAC6Hzm G4bmztrNJYXsZDPHI4BID9MD070t3cPIs/YlS7VxtiBOGYndk/0q9eMk92hVmwoyx5xTSUgT sNhvHurrBU7QpximXV9Gt2wjG9yMZx0H+c1LlZJIlrULLU7WESySuBIcgKF6nn8qc+szarKn 7vyIQoPDYOeQfxqrv7QNmTBHI8ki2zZbOApPU/8A6669/D8ui6e4Y5nLbSueh/zmhR15unYf qcve2+Zytwyo3RwDnNQnThPHGqDEhPylugPrT+GWmwbl1/D0+5C8qsVBJKnPNZ9s/wBmndo8 AgkDAHXnv/n0qWoXbT1C9tC5p1il9OzMQCPvt/d7mq0zidwouEChwyBTzxzzj3/lQ04oXMXZ 9Ti09gpBdi4HBzjj1rnp757y6YlCCefmb73tmhybfl2KSuNFyZ79SjvCVyDt4x7j1I4/Krcu peXb4iGWUbWJHB/yf5U7czvsLr6j9CiyzzM28CMqOOpPT6dqnbPyRxjBLjOOeKpK9tQ1Wgl4 htmSEMRNklhwcY7/AF/xrESxkWV55UBVyc88+uMevH60thrRakrmK1nJKAg8BSoI+uKgFoyX OWk8yVyCFA4Xn1+lJWen3itcuXlxPJs3AoVGBjGCfX+dZV1qMgDKhIPRQeMjHX6ZNN2leX3C uZqWX24nz5dpA9T1/wDrnFPtQI9SAZSxyex5FRGS23YWNXxLrH9n6K8IANzcORHyTgDvj86x NP1GNEQSQsZccsoLZP09atq60C5sxQTyRTSLCEUj5VLdTXNWsUtj5kjgs/QkDORkZpte7puN tq1jpFu7OCwJkY+Yw4PpXORXzmECEkLyeT0B+oz+AoabVmS21qaNtCNztdTDbg4DD15q41gd QyYGxH04OOPekndpD5rM0LPQ7fRrNme5U8fKh5x7Y/GsC6LvIzsSV64U9OByD+Roul5MWt9C GS1k1FInuDvTuCDyKq38osWKCPzDt6swHX6UXaV9i21uY1nE99GsRG08gk9hzxn8K7q8zDp8 UESeY4wSd1Dm1Z9CHocfDBcu8rAtnOOnAAzjn8av2bgRmNZleQnIAQjJ5/LqabvF3WqE24lF oJYZHMhUHGTuHT8/y4rYtpmFkWdmJAxtz0pLVX2Y0+hzCKHVy8u3IIDKcHjiqVxdx2cYZWVp XbAVD93n2p8th6J3YyZrm4wdoVQdrMAB7/5+lbGh+Hf7Rk8xiWCsF65xntmnKXK9PkF7XsVN ThSO9KK5C56kdqltdNW4gYrGsjkcnOP1+tU7pjbuW7nUIogtuihX3Yds9B7VjXmsW1v8gAjj AySR0A61LTdmiXtruPhu1uAyRqudv3j+n6Uy53x2xjVsN165IPTjv1pu7SfVDep+yei2aqCz JyD94DPFS6tqlvbRbogWlPygFcc11O7Zltubtray38UbSzsiBRgY4zTWt2kiMDygQhs5C9am 6vYq1hJp4I41WDDyHjgZrCW3luLxvMbG05AxwPwprzE/I1bKECQ3JlWQgYOCOKn1S5LhBArK xOS3tSa1Hcz3hNkfPkmDNjHI5ArKezhM4dhuZ/vN6072Fa50sTrbwiNVyD1Jrm21Cawv44ln 2QMCR83fvxS06gjgPHXxb0TwbabbnULZ5lBZxvDYHqQOlfNl9+3f4P8ADkEhJa9mHCleAMfn 7VLl0RSi5bHzbrv/AAUinvbqS10q0glOeEEbSsAehABGa8E8S/8ABS+1+G3mya74gjtt3/LG GAM5J6DaMnP1P8qylVS1Z20sFKavuesfsR/8FCW/aB+KS6RHZzSaXIjhZZyAQ/JBwPug4Pev 2bhuZ5pkRIkWNuctznH8hXZUp8iV3ujnxFL2M+Uq3rM13GssYiAy2SeuOtWtYnXWtMgSOImI feY9/wAKytsYeRWiuPNsCtvEpQcFiOSajtIxLLtmkCQqMbWfgmntuPcl1C4drlYreTKFcll7 H0pf7TbTJkMsZublkO3B+771NvvBMy01cQ3U7PbJEcZPmHBYetee+JvjP4c0W3kkvdRs4mGR jzcnj261MnbYR8i+Nf8AgpF8PfhNpzPq19k7gsUMY+eXB5wOp/CvsP4bfGXS/jp8O9F17w8j T6VfQl4mkOCpyQc46EEH8qqCclzPYtwnFczWjPV7a3jgsndztdRgBRyTWXaaN5Z8yWQRyn5m +bpTbsyWc9a6yb6eV1BdQxVGx1A6YrctEuJbfe7kHrj0p8qW4tym6XV1DmSdpCrZ5HU1mgSt HN50o3DgL3oSQbGmLN7jRGt0lJVuMkjJ/E1oHR4DaLG8qKfLw2TQ5WDfQ5exkiuLR4oV3JE+ 2STsMVo6jYo8UgVGVCO3pQ2wMmS2J0xyw2KCTmoYLk2EEkvk7gy4XPaq+LYRD4bvlaYy3EhB XO5TzgfT8qtSXlrquus6+ZtUYUEdKEnf0C99zO1OCOaKfkbcHGOazdDY2/hd5mOWLEIqtg5H WiOu+4MxJoY3nR3JQ85aRsg+3rW1d6jF/YccNvN5bP8AJhVyTk9foKJNiWhe8IyM+oSQWqBW 2AFm4x6/yqt42u0TX7Wzj+ZYY8yBegx0JNO12hrzOE1zT2uNSsZAyqh+Zi7Hgf0q5ql1ZzeW lvmbYQxcCmrpaL1C+hj22mB9ZkldH8pV3IrPkn05P8q6+9sIJL2O5kR4ysfAznIz1pp2VkDX Ug+yDUbiJoVACHJ3gH8au2duW1ERRopO5g8h6jrj+lS3fQLvYwtVj8jWllDbl24LAdx71BYx T6nPKY5nSGM4+QkAUL8AXZHRwtbafCBGGkdn+Z2OdxrmhYHVdYEQwm5xtz3OKI6PUL6HQX+m x2d0YPMZ4w/O7+Kodenhg+zwRHcWwSq+nZqiUr6FLexl6PGLd5yWEaYIPGTjsB79apwQta3D hbdmGwt8/frzQlZXuDS2NDwrqKzPbxwx+WmSCQp5/GvY9UsJkspLgDgrk57Ck9FqU9Tzd5Ej mt5rjM5Bx5ZPArXub20uLgzlBCuMARqBilzdhWXUoadpc13fnyFIhAJJc8n2qRZ5YLWOBo1i IJDSDrkdeKfW1xb7GFAsM8jRlmmC/MTjIHPFbsjie6SKCJmOAMEdB9e1DGldXZkahALa6jkk GCSMd8YPFP0vY5LDO/dyBzioWug7dDOttMvNRuMCHEady+3HvXbQNbiRg0e5dhyQc/15qm7a IV7HJ6YrSWRkSJVSSUhd3YeuPzrkPEDznXoYYnKEZPTGP85pNJvUasjozB9lu0mu98rlcAA4 2j6CkEUZ4Vck/dHTP+FDTitNguRwwSm2fcxLAkEeh/GsCb7TPYtFbxF5NwHHQY/+vUuLbVmN 6M6zw34OvNXE8F1MfJiALkvgA+3Y115sdK0OxILq8mcKigkmm2o6Ilu55UkdnJqLSSIYm8zO Cc5HYYr0vS9UtZLYRW6hACMf4mldg1oYurSuJJ5GAKZ/h4zWRe3suo2onZQkOOFAxj8aLagm Zk0UcSBGfLbRxnOK6WB47XSFDL+/diVQY5P+RQVa5zEcE95Mu9wEVskDmtvVLMBlTaAgXJY8 5/OhO5LOchs7a4mjBXaPVu9d5ClrZxCNXG+QcAEZA+lJze3QduhzdlbAalIqHcgGOR1Of8TX P3mbrUCVA2q+BnjP+elU3YGr6GvqVtKrBpEDgrwAelYNjiVzGoIRQS2Oce1TbXuhJHRTCIyB YyWO3h8Z/H0qZdjspC5jQc4Gcmndtsq9zHWyS6nfacN3GeMVseGNBZ7gqHBBb64P+fapb7Bq 9zrdTsEskVFXc59q4e6f+2LyKHb5YUZ+oHB4/Km2r2YvU6O908W1gREyynHHOQK4/WILlZkk HzsQO2cnvQ2ilqWltp5gscjMDjk+tP1DZaxCIrsyASPQelDVl7rC9iH7ICUI4kwSqhv6VPa2 xtrQsZPnIOFAx2qGrAzEs4mS7AfDc/M+fyq9qMkskpjgjyPUH/PvT3QtjVjmurKydHwQxw2B 09qekpa3G1fnY43Mmcce/wBKauhJ9DkNUiuHuoYxslG/IGMfjWk9jOYQ8xaNgw2qB3/yKlx6 orcu3cMdttZW3y7SAWHLHtXN399l0jc7iBuzjFKbvoguZ9xN85UqVJORmpbSRYbdpWBds4XG OATQ3bRbsGrGlYSLDIzMOvOffqKyJGj8wM6lmz2HAocmhLsODQnfI4AYYGOv0rcsJLdLHcUJ cnOc9aV2nt6DZhPdSI8rbdoJwqqeg/zirdpH51rJLKyooGDuIU/rQ1fXqJO55xqsS3N6YgrK gOSVBOSfpW/Y2gIChQzAYLN0pJt2BroaengWUxYgMAegHSp7zUXuNzsNsXIVR3H+RRJu+jGr 7dji7O7N5djaSihjkEda9FslaC0ll8sSEDq3UUoyb8hXuc1BqHkW9xKY1ZyMfNjjvWAs87TR uAFVF4C84qnFvXsCXVjYbp3uyWAYnAOOMe9dJaxm9Vgc4B5fAGc0la9x2SM7UGijvUhQbhnH B61HqdxwFjXaoGACOtDXMgLVzZD7FGjMIy69QOx/P0qlcxxLZYRmMS9CxpczukBiaVFJulff sRuo649BVxpFhKsjAA5YK3B/zzQ/d1Bu7uSRKLZg8pMobLdc8elMvZbfVZlEERjAUcsPz5oX ktA03M395AMtt3KRnI4yTgfzp+lq8l8ZJV3MQSvzdev+BocftMLl/wAx559yxhY8Hqeo9fes 658uScAfMxIPynlvwoSbfZAlfU1oFgjaMKuXwMjpj8PrWJqM8ccuFTe/OewAPufako6X7Dvr qZ9jp/24L5nykKOXPGa30220bNIAjdMpzuxSvqkS9GJaiGwQSu+2Qndgn8fbGK2G1CTUbgZc RRg5ypzux9c+lVq3o9Rs5vUrqKfUnjiCtsG3g9/WiFJxJGrOxTaSDkH1/wAaaa10Jbd0KdRS y08kvmSQkDPYCsHzxFbnlWY85yT9ahpdrtlWbWxom7EOhA7gCx4KDqM881zTQwSOBFEVJHQH PUetXFtK3YI2t5ltLQ2bptbC5+bK5P65p0M8k12yKgBJ4PT1446daNtWNXTLDSJCULIfNGSy L1/Gobi7jNlgJh3zgEcnJp8t3cl73NXRIysFzj5WxnpjHParljYsboyGTYqLgHPU/iff9Kla aP7y3dGPeu7XgZIwT03dc07UdZm81IpIixU7mIIwSKLvmb7EtamLLexXMjXE7bFA+VW4IJ6V rLJPcSosSnyiBgE8ml71rrcFdl+602VJ0Afy2Ve2Dkf5FcyjTM0qmNg27Bb15557UK219+oJ kv2dZYJGBbKrwDkZFZFldyaeBPPkHkK2S2T24/Ee9CjZX+4XmTnU7O5u1kaMXDj77buAfT9K sx3yvqBkkRY4kGCdvAH1/wA9KT5lbYGnbQva3qR1WYAoYoU+VeMZPf8AyaqQyIsKu7kqwzt6 nj61SuU77Mq/YItUuIFUBJAQ2WH3uhrpbvw3Bbqx3BI9oPUjpTUrNX2JWtzk7OESIQzKYwuF OScH6fn1qnqGpyRwgWjlSyjnbnK854/z0pRu3tp0Gu5bSxkt9OJkYSNtyWkfoT246Y5/Ks27 jNpYGUuHXPyop+7z+vepb5ZLqmC0ZmTS6hqzxsWNuMcAEf8A6q3LGyhtpHkupUQDBZnI4/8A 14q5R5viJe/cp319At0kNkfODJzJnjNaF3uinBUhY8KuM89efxxSdnFNfcGiXmTRXr2NuiMy s5J3HeAfwrBubqFFT5SWb7m38e9UotPT5ijqyvprM9wXlXdjBHH3e1byTq8YjkkzKdwJHYZP c9aSk23psXe7MWfR47gB1mEcABHJznPHYZrGOgW9iRJ5h4BG4HNNySjfr0Jtf1NfUYS1kkUT eaDzwOfc1a0+8ltrcwQjYCAHB56ECm22FrnOTor3AE8uSzZGCOPx/wA9K1JFW2ttseShTLBe Mcdc9+RS5um7C9znJXS6UMrBTjJ5/P8ATFQ6PpcVxdyF0woG4kr7jH1rRPoD1NqK0JlZkV2Q dG29R+FRXrSPdgSybAOCScfT+RqLXdl0H2R+z8a3FncGGJgCeuV6VLdW0SzJbsgVyNwYdveu u+uhm1pqa2m5u1l3Tbo0z07Y/wD1VRBhvpIzCjFc/NUrRjtdF3UbVrS3DRny3xkZ71zSaYS7 bnYlh8zEn+dOLvqJqxq2UEUFiZGcME6574NTX93LJZ5RAjnow7Ch6sDn5BcShfnMhAzg9/wr J1fWx4X0ma/uYRDaw8ku/wDMn3odgW58O/Ev9sZ7eGU6T9mjkGdjyzrxz/d696/Nr4r/ALYW qidxqPiCJWZWKqJxtBH+yKxqVoU93qergstq4nVRbPzh+NX7aekaDZyHUNYu76TloooINysP TcxXGc+hr81fGn/BROS8edtK0OEsrYZ9Qla4bkjkBNoBAHOCR0rjeIunKOtuh7n9jujaMtG9 zwe5/bp8RNqc0d/r8tvZ7trR2z+UI/QAjOcAd84xXjXi/wDaRj8e+Jo202PbC0m1zMwA3BsE 465Jx6556Cueiqjrqe8Xsdc6lDC0HTpxTl3P7E/+Dfj4bR618OtZ8YXaCWSJhDAxUDacHccD oeucfyr+jc6iZbiJbdyqgnL4x+Wa+ixVuflWyR8XiZOVVuRia3G8t+jTOXQY5xjmu2nv4NG8 LrNIoWIfKNzYxnpz9a5ZPQ51pqeMr8U9D0GzmW81W0tpOSYzMDj8Otebah+054asSyxtNelT nEUJUH8Tik5dhpPojlNb/alk1XT0Oj6I9rGTj7TcNux+Cj+pryjXviz4h0jXoPtOuxWQdSWk iwuz2ycn/Gjp5lxjrqfN3xe+Psej6bfyXt+1xGPm+2XMzMZBnspOF4+v+H4C/tL/APBQrWXu 59J8OQR6coynnOpdnzwCADgfX+VYVOtjsoUIylZ6dz86rrxzd6p4hW61K5ury8ZS3mXEm8Ek gjr+fUcE89j/AGS/8EOfiePF37Nes6RLIhuNFvcpErjAjkG4D2+bcPauzDr9xNNarqb46EVB cuyP2TvNPv5tPur2T9zI0eYlT+His3TvD6T2YaVS7FfmJPqKjQ8lou6LYwkvEjg4JHHGKXU9 caws5nwshMuyNFHzN2pvVgtBPtRs9MiAgO85OXPU9+lczZ2pbV5JJ2VHkcnexAAP4/hRsxWu jRjunjknZGwqP8u3kkevPvXPtGw828ubgcnCR56n6UK3XcGYuiadcF2LzsEkfcYlOAPb6D3r 0ebSZLa4laU7lVAQCe2KqTQJHmOmm+1MO9zISC2QiLgBe3FdBe3c1nCkKRhRz8wHJFOy2Qk7 amC13HpPntJGXLH5VA6k9ST9TXQaFFAtvHLIv76bOB6Cm00F7szNctHvbp9i7UX5cA4yazPD No7xGMnc+5gqdcd6V7IV09EUNUhXbtKeY24EYOcn1+lUtJkeMIJISzO+1Ap57/41SdxNanc6 heXGgQ2lvaxiSaafDLgcLjNcHrOrXFxdTJbRbMkiTaOo+vp9Klrm1KMvV47u50pppQkUaIFA CngDr1q3Yxx3SrBESilP4zyT/OnpHRfNi12MW4nxrccYm3qWAbHGPauxv78R2ySq29QCoI9A cUkmN9mVIIZ5NDVVJQu4+bgnBqOBjazSbZykQ+Qbhkn3qmktGO9kWLyFGjgE7lVCbVTP3jk8 /Srn9s2dh4daC3XMgk/eFed35Gs5XtZB6biWzq2mLcSMsMW7Easew/8A14osLqGTWIWjcN/F knp7fjTv3EtDN1vV47y/uIoYnYgbQ2O/4fjTbyNrC0jkSMmVVADN6Utbepe5kaZbSrqskky+ YzDIHIxx6fjUpgkV5meZoycgn2/yaLq3oFh+gXcNtHEiAKVbAYDoBXp2v3M174fMYkdEbv6K Mf8A1qlK+4nc4L7LBvjWN3eEKB5jDktXUWcFvdywkb2VAQxPGT+NCf3Db0LGtai1lcskDBcx 4+U4yT2z+Ncxb3aafLGsr75ZM554UD/9VSt7vcS3M6212W7umjhTeoXqO2Peuw0yCSFJZSMz OOpbGB9O1U1ZX7jbscfe20s16gmmMqhxhdueM8/yrf01h50piRsqMYx0/wA8Ukkth30uRo1w bzDSfJzkY6fhVuOyikt83EjF+6qf0pbA0Z0NvC9+BG5RFyNoPSsq/aE67FFEdzMep5NJK++4 k76s6S6KT3e64Cqqj+HsKyftUd7el0jygyqEr96jVadOg/MYIJre1dgdoJPOOtc7582n2KJG GLSPyeM0m7K7BuyNSw1a5gjIJLuxwQeMCmzQyQ4w+HPILc4/WmlpqLW5mW+kxmxnvWOdsm3L N1P0qx4Kt21i5upZFEdqjYYc80lZSHbe50WvPbzJOYEYLztBJABpkUytpiQRgKoGdxGcj1/S m9XcWxybRiKQsV8xQcjaOlddpS28VtJcyHhB8iEk7vWk+5V+pzNvbNfShwTFGCOvGea29QuG jVVibLKvI67qErE21Oct5IvOCSSBXyDjk1v6dbwRXxfzyzEfexgCkr21K2EspyspdYz8zHk1 jtEVvcKgJ9D+OabWgrak2rhhGGcEHHQms23aG2VwS2CMbVXqal2WqG3cswSrG5LcKoIG3ocV cl1GV9PhgjRfNc44UmlFaE2tuZscEdwzCUnAXIVe5966aC7XT7JTFL5KquTk4JPOOfXmh78t vmUrLQxo7yWWdyxYI3UnOfz/AAqwtw7uY4YvLQZUlm607WC1i/LFHHaiOI+ZIV3Eg9Kw51uY URkO7acKCM80m77iTuW7AahaXQd5svvDMGUfMPT2rI1FprmdgURcn/WZpWSW+o2vvOi0w2Nn ZLPIZZXJwCsZIY1z0959s1KFHcBTkyKP4fSi1wCRFPiBLeIEoQAfm6Y//XXWv5eiTKyKWkB6 n/CrWiEkUJ76e5RlLBXA3bcdT9R0rGaHzmHnzmNT3HeotcNXoQK0SapH5LtIoOeW4IrU1a7+ 3okQQBwMbh70knr08ykN1S2jEqrGSQEwxI7/AORXM30qWDJ5owM5bce1F+YGrvzMWxibV5p5 DKI4hzg8YH+RWzptib5NpYRwA5YjqfoKUWxPQvebFE0iplyOmT1/zxWGskMhBBAPooPHtVNX GnbYgut8yugAUMRyexBrUsHtooliE+51PzY5H0pPTYG+wz7eguwkCiRymWJHCj9Kff3rrYmE AKC38IPJoavd9BNHDa3fHTkxJCI3PQHOQR/nvUujTtdwPLI6hz0GeuahtK1h7bGk0bMjx7yW I24BHNX9QgeDT0BVVIxnvxj0olorCWmhzVlEkr+afmG/PuSa7qSWMQAHfgDoQDk0oRsrrUG2 tupzMdwkssrSJsXnHP6Zp0MQvpZVMgjx0DZ5qk7egKOmg630lkvf3Yxx1A/Ola5cb4o22gNk npQ0pK4WszHsbJ/NaWZlK5zk+tRX7PdXBcNsjBJGCOaLXG2rE0s9vFAsbSESBRyM5P0/OoHZ ntAuwxxDcRnqR+PajTYd7/5FG0inkt1jLbhz8ox/WpLG0Ml0TINu0YAA7U7IE1clj2PO2TkD JQDnHrTpkfykCLtTdkkgDNTFKWrBq41JlCvE0fmMODJuIP8AnpWpHax6dEAzBzsydvOPrina zSbE9DIjlbzpUVflzwvXHA/rWRIsdxqaqkLBlIII4xzzSd9bfIb0R0MsItWlZsFskjsawGt3 VzJKu1c5HHApNpvQTk2yS0sxdRKXOVUnJA4PWrUym1gZo13J6sfyojdJNfMV/vGJpq3Mgch5 JCAxBx8v+frWmIFtbMPkEdeeMZ9qbd1dDOSsLdoGmdyC5ZmPPZjx+hq+f9KkX5sBRjgYpy1V +ot3czbq3ijkLSAyDO0HHSsu4iMkp2BXHqcfMB79amLd7LcuzSt3NpNGmTSv3oAPVeMYHfFY 6xTCWMgERjALfqf1qnFPcnlNY6bv3mR8tuIC56nrj6c0yHZp0cyghmHDEpRolq/QdraIbZTt cWsjsAx246cmtAQfaEDzDy5QMjpwMVCU+pKT6kmlSmPTmYjc0jYX07jNRT2hsppHkm8xE42g dc9/erik9Hv0FzHIy6+Eu2kRSgHDPj6//Xpb+4uLy6WcRlEwPmU5qbO7uNNvc6C002LUHC3K sVXPI7+1SXVzHBIFtvll6Y9MdKu6bsNPoYepX1w8bAtulIBdv73rWhaakBYSLMvmBjkkHHOf 8TiokknZg0l6HPalqsdpGYwrBiQQAeoyeP0Fc9/Z934gbzXlC2gG3yxxgeufWnyx5rdOgnoe gW2j2+jaSZliDPjClz39P0//AF1m6VE+ozsVj/djr24+vvU2cvIG9DY1KztgpknmKkgBVQ4x nrn1rLuY7KIoXl8xewBz/k4qlJJuLH6k1/rsEFyDGFI4CMcflXPa1douxnl81XbICdB+NS0p e8tw8kLZWKzWWIV8t2PVvT0qL+zEgvYw7NI5OBxnOPcfX0qotNEpWVjdu7YCFvNPlRk5EYbk DjiueWWK61FVFu21U4Pf/PSlblVkhrsTz6kbUFo4FZsnCvyMHGD+prl7rT5dYtRFKzB2YfOu PlO4EfqKHfS+4al7TrFbOBCI9pHDMze/PFXVgWeYySOzLyCwGKa1V+nUTaaKl6sd0rysQUB+ XIPp/wDX/WqsMyQ2ziMCWRwSuOwyf8/hTTb22DS21xiSeXMYkHmlxtO/qpOP8auXaJaWgach SxOF6mqTf3gtXoZckJmjLZKxk9WP4Y/SsqOKUylN+8DJBGPyqbyUeV9Ng1S0J7V188ZfA6Y3 Yx6H/GtS6lP2ZIoyVlPLE8Z/D/Jpq92hGcgYTbi5BBz2PTqf0rf1u5R1SK3UtLghnztx6jnj 2pwdl5FbnOxaJPfFisnlnGRk+wxye9WNH8PLbztHMRH82XJ6Y564oTb33Ev7x0N54ijW6BhO IU4yR+VcDOy6nfllhZScksQPm6getVtqF+qP20uLm2tWQFi0wGdoP61pxSxzzvMkbM5GCSSf pXS72I9DnbO+mTUBbH5FLkblx0Nd2rw6Va/KCxLcDoT/AJzUzVtO4RZDM8iQ75Yd5Y/KM8Cs GeQzyOCCiY5/rRFWB6kpW2e1eBY3Y45AHT8avzXIazSONCpx1em02PRGJqM8sCKsSAyMcbgP u15/8VvCcnjj4dX+j3NwwivITC5zyMjgjFOyFex/HB+1n8IvHn7EXiv7brtlPd6TKxWG+hmL LcgD8OcnJH5Zr8rvE37Utz4pvzJZ2Edqsbt999zsSRn5cZHXrmuLF0YtKTfXY/QsozanKhGE Y+8kfPnjv4i3fxDmeV0TaseworBAz4AzznI46D2B9a+OfGukyWdxcxPGzTbMrGhJHXrjByuP cdK5JWXw6M3xPNWjzbM8wbQDc3iK0kiuyESO8JdY24BcjsCxHfABBrtvCOjGylkZIQZUm3Iu 7kLjknIGD246/lW8Zyi0lt0PFnhnKN5fef2Xf8EPv20bD4Zfs5a7ot2FNsL1BDK90AWYLtYH jJOR2z1+pr9pdV/biOm6VJcIdO063iUMXvHcY4z047HPSvSqvmneT1PnMTSl7V26niGkft4+ J/i7evFZBLa2Qkedawjb/vbjnNWfEPj3V/EduY7zXry4QnO2WT5PpjistGu5n7Lkeq17HEQ+ IIoZnVpQseRuyMdOv9K3NR+IPg3wnEJtV1yAPkHyUOQoxySR+PArOVflN1QqVNIJt9Dwv4o/ t0eBtNshaWOvSR2yHlQvJwOTlOfQYxn3r41+JH/BSXQdH0Sea1S+1poFAjG7aAB6b/w7f/Ww nWaV4q7PSoZLiakbyjZ9WfH/AIk/aTm/aC0GO8bdaWbkH7KjAgegJx1xjnFfCXxj0xI79HEY XzQ24GPncM5Pbnkc57+vTRaK6Xqc8KcqNXkerPHdPfiK7eRA5nLEkhh93A49TkHPPTjua/oD /wCCJXxpTwl+0QNDupTHaazp7wICeBKvzp9TgN0rrwqk4tvRtbF4uMpU2f1/WelTJaCQyMX6 kk8Utu9xcxtAJxEhBLEnnFS0jw9tCXTzbW1uT5wPXgfSuZ0mRo7me4WEuN7YMnP04FNLqB1d xdTX6R7ljYKQdqLXPXNmJNSi84iCGPJJY/xH+VGw9x11frB9pkgRZkCqFyMEsScn6VnafHNe Wck86IApzgDoKF1bFe2xXuZntEMuQrkjbjsa1tTuZpNNRUZzLK26QgnJGOaLdQZHpN3HazPG 0LkKn3ug4H/1qz9Q1Q6jfgxRxpGq7QM5yaq12GyOeS2mvbiRpDvJGFwOB71vSER6TEANjI2M gZx+ND006CZmXkEqATwybgynnGAPTiuZ0S3eynuEecF2P1xVqzWwrW1RXvH8tJI45P3zDk9d o9aveFtNRdUCz3OJBhgHfG33pPuUtSxdG7uPE9/NFNvWKNjExbhQR6fWm6NosuneGIWuHLPt yckDGaScV6i9TnNenW58OzwB8q4IaTPTFZUEyxWkRhYu7DAODnr709g2Ib+3gtrmIxymaZeX bbxk+/fr+ldPbMZtMildTgNgAjqaq1lcUtjdkut9sIVgBYnqCQFxXPtYR20nmXZDsG3EDsKj bV79Bp6EF6zahMs0MRjh3chl6jt06UknmGOYLbYO4HcOMU731W4J6s6qfT3ntbcNhuBx9P8A Jrj7vS5H8SwiJsle687cnkfXr+dK6T1Guz2O5udIOllt0qqSobJ7etcnrWsSXtuiwBVhHQ9j Uu0g1uY2lGe9unuGk2nGBgYx/wDW6VlXUga8MKuX3sRj+9SlHXQtPubFlBLoskDOgYAktubo BjH4816nBe3Gs6S5MOyBQcbuCRn8KSX3Ils4zUL60tIIUmG1jwdqj5gKuajfwSafE9pIY2Z/ mDsBkfzpO7v2DR7nCeIr+5ttUVVHngYYso4UH+fStTT9Fe7tkklZSW5Az2pqNk5PXsNs6TRb o6LF5AmExyS4AHH41flv4Z0jBkCgrzgE4/Ghu70WgjLEy2NqWVTKxbIPcVp6VfXFzEBISIhg lcDJ/EUmnswWmpn3t6sbEKuxmOOOakKvFaFDNsZhgFucZ9KTae2pVyjb6YtnBCi3HmsxO7jv zWHe2ht9UXHyMD1Bp3uhWuXmuSb2KLcZBKCDtXoKckpW7GEKRA43EdfwpKOt+gJFe41CWdni VlZFPXFcdqV3NOsUNvwAxJlGCP61Ml0ewLU67R1NvBgg3E78D256/pWlf2jiRQWRZOpAGcZx mqSvp0GclqcbWenMGfzEyCitnknjNb/hOSWLzIQAEAVipOMZz/hSSsxXuaN4UuL91kVlijb5 h6ngjmsO4vWt44oY4zk5JLHoKHLoNFGAQmYlp2VyAFQDdk11tpp66lEYVk3IGzIR3PpQ5dVs LoY95mOVQuyKMEhFByfpWhJbW2nQAzyM8zrkgHhaSbY99jjY4k3kgkhjwc9q0rBVe4RCMswz nGcD/P8AKhRuw9TprK8dbry3RTGuQMjH41i3zrNfsobLAkgA570PewXGXrvJBvDBQBjDen9K yLeCOytjLI4aVm5Gc4qQTJzcrFdxxrGSCQFAXrzx+tamoSyWkaokZWcKQfl6f5/rQk3oD1Ir OA2dn9olVXLc9fu1BYSRXtpLLL8wznOetGwa9Sy11FOFBBG4/KE/nVPWFCXhSKYyLgEkDGD6 Yo3Ha5syRvpunqqEAMBwR2+tYN9G7xwZYq4fJVDyMVMk0C2AxvqF2FkkxFu+b149vwq1qOmx o52PmEjhS/LU7JAL9nvru0t4oY1hgRc9eWH864mDSrqTXJjJIQ3ccnAqeTz1Dp5ns+mWttoA LOACwBG/OfrXO6jcxyhpBhQz5Xj9ap3GmTLcGLTiyRfOemF4NcpGGkt3nlG0KM8jqf8AOaSb b10C/cghuTdTghFjiHC7e9XJLlrchlcNMxHLDp6ClZt6jG3EymYI5IfPzEe3v/nrWfd3FpcX sauhYbSS23g9O340N2ukTsMXyY1lETA5HPy4Gc+1VVu2ntSpCqg44HU0L4b9ewrGhGomJVU2 IRwzLjPvWNI0cLtEpzKAWK0OTe249i1a2YltSroqHPAB6+9aGnWVnZ2wRYTPKWznHA9KfNZj TsNghHmswj2jcc+1MvSfLAVERc8se5pt/iHkcbe6Rb3ZaWWb94eFUjitG18NLZxee8wQk5UD qOtQnG2w/Unt2eOJpFVQXJ/z/Oq12hWEbiST1Oeh9KG01YXmyvpLYXOQU6hf610EyvFG4IJY nHB6VME1oK5j2ljjzWebMskm4oFz04FNW2V9RZV4GMdOh9KbTi7IFbodCdZGj2MyRR7nwELM o7n0rmonku0jBGFLZwPr/n86ST5vIV9bCyXRhYxkEnsCODmsO4tZJ7naDkgdM4FGjVilvc02 0dBtJLMxGDkd+9NvLPbmRpCEXkIT1pOKSvsNPuYemQXN+jFlkLEFkjUDkZ9R/StOyeWzRhMh R8enSqitSbamLFNDA5G4A5ABIwSB/wDrrTYNMpLEsmNwIbGABz25rJrdW0GtE/IrLPD/AGfu LbQGJyKv21vL5Mlwk6Fyo2ZOcH6Vbkr69ATKWkM0EcksiAykEFgv8qj0uc3E8hdArMcbsY6V V017uoNrY0ll2yuTGJH6AjjnvWHc3PnMryKXDnCjuTzxSaUlYLo1rG+DKkawLvzgD1z3qhqU zfNGwBbO7Bb8vpST0v2FtqXIrllijIQCTGAD2qS4hkhId1DDIJHXind2732KeiM+zQTMCy75 nJIA6fT60rWsm9jHgY+VuDj/ADzTjKS36EqTXkcjqokWbJYs/PGPTtXQ6alpLboqRbJiQWA5 24/yeKnmtKzG2bWrqLto4VlZW6Dd1A/xrntSszbTmOORmIGSMjk0NRV+4r9h7wC2tI5XctKx GQeccdR+dUblHuUCgCMuQHaT/P8AKm1zLXoO+rNqSxj0mJSsxlJx8qrgA9/rVPUblPJSJisZ HO0Hqfp7cUmkrNvUBzM1vp1skZAYnIBbpxUsOjxRpJNNcNgMdy8njnFOM9SUle5nXOl28wDk hYxyqkf1qtqGpwTRrFGg2jABXuM9PbpT+LXoVqyCfWJQFESiNCOTSWShw8gfzxnAORgegzRC N9mP8wMMc0cssgABbAUnk8j/AD+VZc0glY7W8uHOMEjJ6n/Cpktbg3ZamXewrtVBHv3EFSy5 xnivS7CW0sNHmR4w84OFUKB+v+elTGVpIS3MDXb0f2cpmURKoO0MuOSOtY/hs3D2ThYgsBYn 1OMkgVq7NcsvkDINQBvJ28wMoHCr/eP0/KqvyWsgDDc55Ce9KyexN0jBks1n1BzKqKFODkcg jrz+FW7t4gwCqXVedwfG6krXsynZfoO+0raWsbPnOTmMDke+B/nmr9r4veKdfIsi7htm984I OM8Y6/8A16lS5pe6K+th+o6154CtCY5iTuXBwDzxz0qlpcbwQNJISkrYHXOP65q+VRd2IqQz sksss2AoOFypB6//AF81evmVbNVVzGG5HXkdP5/57Uop7vYFK+hVW8hikEDErggsc+v9KSO7 I2gLuQHIBH3h2yPelHXbbsDjpYqajqTXMiu0QQHBKA5I/CrRRntnZlDSE/KijoOQOf8AgVaR 8ylojMtNONtOrqADgkds8/X/ADirV2pd2Dkl8nkjr+P4j9Klu78iUurMW7EskW1CQg5GVyCe 5/Wuk0HRITp4uHmDSAEltpAz9MnpzVOd2n06gjLSG3F20cLCRATzt5J/wqvfXAgkCpGTIcbu 2eRRJJ6hKKvoVrMqsxkkCb3G5VPygEe5/wA9a24GZZlZNrAnI3vnHtmltfsPZFC9klubhvKc Kyk7CAfm9+D+lZs97shYSgs3RmIxzyOR+FK6evXsJ2KVzDJcQsEUNGGwrL0bt0/z0rYs7aSz hZ3QFBwvt1rSLTVgSbR+xUUO+QTSYQngA9hXaWKQw2rMzruPIIPWuiW1kQtNzjLApJq7zDlY zlmDdcV1l1qFpPaNKqM5P3Qpx+tDTYJhHO99GrSMYwB90HGKzJ9ixmONSxJw3P8AWktHYB+m 30UTSKULkcH5vxqXSrtru4mHlhUUkLnnIoa6jRBqLqwLMnC9s1QlWG8sI5mcoBnCnoDTWiEz 52/aP+Cmh/H/AOGd34W1yGO7sLqJhk8mJsHa4PYg4Oa/zzvjX+zve/AX47eIvB+qSgTWN9JD DIzgLMo+64VuMlSvT1+lc9ZOTjydXqe5kVVxxPJ0Z5ZHo1r4ZubmxnkWJMeUH8xQCR+Y9PzJ r5G8baTL9uZLa3lkAG4SLGzFSe2ORgg8YFcSoza5nql07H2eJ5JQsn7z6GX4d+GPiPUvKj0/ THYmTbOk4Ix0xjqcZIPHPqRXrI+BPiTW7x3cXOyRAZRCoiAA9yRn861nC1no1E444arUha1o va59w/AK68U/CPSJ9P03V7bQbaYB52QRs7E4OQfm53HnHp6V9vaB8WtC8PpA2tNqPim7yHLz yhFbjAwAeBzjO3P1odZud46mE8mlOS5dGurO9u/2/rizgFvpGh2mn7FyIpJ9+0DgHA2+/avL 9R/bV8cau9x5epRwRDcG8iLaU5xjJPJ9+mO2c1zyxMuez0R10eHqMI81duTueVal8efEfiDU JZLjX794s5kAdjk49B0HPYf415hq+u3Wr6hK0kskiMcENIfkHXcCCP71S611z07vpY9SnhKW H0hFIoXUH2BVlCs8jx7EGMgBiNxH4fyz9M/WYhPAIN5nfYclDt3nA4xgk+mf/wBdVF8isl6m s22vMyP2e9aMyanorSpLcJKQqqd2RnoPXBx07EV0Hxns5YtAeeIpDJGoLZIG1cgcDOByT+np Xc5SnHTc+GxceTEtLS583RyNFCzSb2QHaDK5IB6E5J5GPbgDA7V9t/sqeO2+Fvxb8M6+ZBC9 nqEcikNuyA/Jz23LnjPQ1vg6snVSuYVo/u2r6n+iDbauNS0HTrm0lD29zAsqMBkFGAI/nWda WuLkxHjd6DvWjVpM+fZHeQraSIJ43CRsThSPmBNOh1R/sc7QWmxnOBub7tKza8g2NqxlkFqA 8YLLj5h7VyGs773MkbFMyhecgYB/WhBsdLdadDZ6aXlcAFMLjksewrIitpdV0wWcJQO4ywRc FV/Gi93qNmNqFgtgp81s4XJB56VtxSi40xWaRQVIIC9qd+bUm1jNuWMUwKSbVkBGTzgYqjYQ RxrJHv5Un5yMYpgczbzTyXMrRzYiBKrgZrajVptOnt5plWIAkrxnnrVO24X0Kl1A09jbw7yy Im08Yz71g20AsNWdygYttVBjGMnrj+tCZJtRWy2usSMxQAwMAN3CnHT3OKxLe6jguZZZEDDA GR1Pt+v60NtstLQr+L9cGmuIreMxz3PC5PRRjvXQWHhX+y/DSNd3G9uCF3ng+lF0ot9WCV9z j9XiS6kWMowjZ98hXjj0p1hpx1a5gjthiAY7dvXNC211RLV0WNcS2t3uI4+ZGfG8Dhef881s 6THNrTtaRoq2sShmkZgtF+ZajtpoVbmUNMI1JVVfLso7CuG8QSPFCwhUuWI2AjqPWklpfuHV FrTLa+msJJGdw+QMdciurv8A/iU6GI5HDTPGHfnk802uVeY1vcFv3k02NxN94AKp7CotO1Bd NmWRlEtw56k/dpP0D8h+tSnUbdzPMxLjHJ6/41FboktgyiMs2MZqLW0BW3MvTb0XWprbRKsg 6D60uE0/UEIt1aTfncT1H9KGpJJD8xb77DPDLIjSSXDyZQA5woPevZYJifDkMKorOU5IPFKz B9zzFdC/tO9ld1YyE4Y9ga2m0q1toUjlODnoB1pp8ugrGJrEWnQ3qpHLsQD5twxitTUJbWGA LC5cjHHKjFTe99Ckugtr5WnK8ZQSSlclmP8An6VZMtslujBMkjIXGf1ob7Ba5iX2pCS1IVfn UkBlSm6c7iSN0lLkgDB6Clyt6j0saMkeb5BOwCHPApnlq2qxzupkVASgLY6//qo22CxUstDu ZNVaSVdiMCcbh8tZWoRLa6mhClvTnv2/z70NpbCWhtw2xgvoxvVZiAcAfcH9fyrJmuLiJp55 Yy4Vs7s47/4VLQ9Sr9sjvYwY7fYh5LetcoLNpRIAdg3dv8/1pyjpqK+tjr9AsPIjkcv8wGe9 Sw2jzuzCQrHu3OT6dqasMx9WnjSESTEXDbsAIMYx0qzod/NLcylIwJDgAjvStrpsDR0GsaUN JRgx3SMu5s9uP0ri7W/DRPuhDHdjcO1JiS6F3S762sLmRmt987DIJPCmujs1li0+RjKVDNnA 525PPP0puL67Dd7HIQvHb3PmzFic/MM03XvEVpNcYVXIbsR0Gad3sGg/R7aG6WMPtKE9GHQc 10kGpW9xqu1IkhjQYLKOo6VOwO27K8zL/aFwgASPkFgOCP8APvXN3QVL4oMgucHb1xRuJJtl rUwDAPJOzcvVj0qhpMJjuGWOMSPjJDDOPehJDTszpIr0wTs6AmYY2gLzn6/nWje3sdzHCSnk gDLMByxz/WpV4jtc5ueS21OGcBXRSflXdndT7O2BtGhjgUgD5cHGPwouJ6Gzphi0lJmuLXJV M7ieT6VyKPLc3DzFAi/3QOBTej1YXOw1iQNDGMgjGQMex9e1cJeqxfCOynOMr61MtF5g0X4Y J4rlI0X5xycjselTzRMZzM6K5IOF5o3Q5EMtxeRwsoQxQ4Bwoxiuv8IeXY2rF1LzOM7m7c0b aiNjWdTk1u8CgjYFwSRxn6VyN+iWKsMktkAKvPPbik5W8gXYuardzQ2AjhnJkxjOOmawbfSr icFXVpoyfzNN2e49jZs9LhsYZWmUwKpwDJjNc/axHUdR3RjKZwS2cUr9EOxS1KGR79Y1BYE8 +1YupRNb3Kx7MOByT0NO99eorkEksxtlhWIRx4y2e9aFr5ksaCR9wDZwAMetKz3B6rTcuz3c kcUkhTd2UD1/w96i0/Y7qpgOXyWbNK/n6jWhSv794bkxBfLTPzEHknP/ANete0aNYipDH1z2 ptJe8wIUaUy4ifyxkk5H+NVJmZLdwWUqvv1FD90LHJrEpmw7FVLZY4PGa3WhKsVaUMnI4Hf8 anSwmraj9NtYnuI2lYuIzzjoffFZeo3MUEvlDhSckn+VKSdtBspaS7TtuVgyg4XAGBzXYaw5 0+NP34JA5wQM/oapK6v1BNdTBs7gSFGLEMTnCjOavWt0LZ5lZBkDOCep61DTiu7BrT1M6C6g u791knjKjkoD0J6dauHIjEsj7UGT06U07aMGylgtMznlTyBntWIn2ptSVoxsTOOeM0lJSSSG nfc2b/U2jKKxaIjnPTJ45qneaiiQRImfmPzMwxnPapbbTBCW+rTRWpmhwNpCrg/d/wDrU7a2 osY3be5U9PenFJu9xIzdP8OSz3WZm3xLIwQhsDI/mcZ5qfVFitGZIZCFxgkDge1DaitO4JnJ X88s0CocJb5JY7dpPPStHSoG1VGdm2QovBOBuFDUm7dAv2NKO5c2gRQGODxx6ev51XsbRfKy WUbAVx15ofLT9BO3yL8KPa2pSNg7kDCnqD/OsWWJgFQh2k6tsXGBjmpTv6FW6F5QYdrM5U7c LnjB/wAaZczKohAOJCcdevtVNaeQnpuWYik1sjTy7w2AgHHHrUusXi2kJCqZAe3vU3d7tbA0 16GfHehrgokZAAJbHHTvmmI0NtayOJMtg9T1pxd1r1De9zJlt3SEyONokGR0OeOvtUsFyYMO kmWBBClegpNXlfoSl32LtzG8crTmQF8HaoFc9YtLfuZZVIUkgsOc8/5703dbj2Vu50Mt3HIo CoVUHgnJ/Mf0rNnjMqyBnDrjA56e2PX60KLestOwWtqPhklmaOFUVkABYEZ+lLLHJPqS7nDy HgLu4HPT/wDVTSb1Y1qjqLyCKzcO5eQbTsC55P171zl1M/kqNhVcbihXk00m9/vBO2hgajdz iUROSsgzhRzj0/kayJ3mswpKeYHY4w3Q/wBTx0FCelhLQvWNtNfKzMCI0wSTwMemK328yGGZ QoJPIJbtRFWHIwpEZAcyEFgeQv3feswaerTFvMLAckkY9aLpvYCPc6T5jKM33V3cZ/8A111U UIODIuAhJJ9ck/0/lVXV/eB3uY9zcx3GQV3/ADBkBJAFdfYF7SzkLzCJeuxB37c0m1dJAlc4 XVpZprtFZMzHIHHI/OnRWrWdw7lQwQHLE9etSlZ6icuhWSAzzyGb5gygg7RjB/nmqi2D2ljJ MEVlGcBj+lVZSY2ruxraTEJrQyToE2Lkhh36/jVWyX+1bx2VWD56jjgZwPaphFJWiLZFa6k8 6dSELKrEtzgjt/P+VLsOrM8pBSJcEAtjoelNKXXqDTI8hQiyIHJ4xHhue1UbyB76WJVOCOT2 BHeh22kJppalrS9HhyXIIUYLMBnP4dq3rg2dnZsfLMkjDG4YG3mmrL3QTvZM522DKRI0ZLL8 pOO3Pes6aaVsyGUI+SPlI4HuPSpcrD0LFu/myIpwAGDD5s5FVZdRZJNqqXdiBkScA9Ov5VSf lYFqNkt7qVXd49gj+UI3Un/OKmuFKWbIwYKqkEE4A/xpyV1cm+pR0S7QiVyu1CwbIbJ6Y4/T /PSCa4RbtpFDEA8MCTgev6UvhTY2y1BOsccxZstkEMzHj/Ch2mlhjQvkk4OAcknjGM+9UnfU LNFRbpbCArBJuQnjauSfx9K27ZoJsxyR4IXOCOtGr2HZvYvQy2slvJKz+U6sDnnnIPH1rJnu 47u32LG6xBgcsANx7e+fwpPcUU1qfsEkbzQOjOxA9q0tLtIb6JWcbXRduSK7HoQlcxJ7F01Y xxsEhY5Ygda7m1jhtbVVlBC9ABSk7oaVipZuFkliWLaCeN3GPwrOmthHdFGk2N2xxzSWjEye 1e20iYM4MjscBR3rRm1e3ttQ2+T5bOvCDr9aGnLUaaRwnjTW7fw14f1HVrxXa1t4WklCA52q CTgevH8q/Db4pf8ABXexCzWGi6VKbdDgPsyWHr8xGP169Kyqz5EduBwNTHzcIbL4j4c8Zf8A BS/xJr9qVthP5bcIpuRGDx/s4wOcc1+an7Qf7RV78Ri32jRrGO7fcqXktusjLnodx+YcDsfT 0rnqVoQTd7p7I+loZDGk03LXyPjTwHo+lw6q88+l297PksHnw5Xd6E5z1IwP617lqd4INPUw 2kOnxqCZAtsqsCAOCQD0BHXP86mVVzjdPfse/hrR0OVa8uZ4Yds0kO8Z8xJCF4GBkcc8Y4z+ FYtxcrNcBVuZJTIUBaX+Ijg47Z6nkmuWpFyjZ6HoW6JFZrBg7Ep5CsOWzkMo5H456Z9q0NzJ cORKYiq7VY4GD0IP168DvVpKMVroNdLGZHYpCkLSzhFXJfPzblySO4HBYjPHatoxMl5Ku3Ft tIBDcscZHf8AoOtZRp230NJu6supWWyYTCVSyMgBwCGBPXORz6etMhhnWEsySB1O4x9jjODy epPb37VrblWn/DGV1O990VZr+6njETqrAD5evynJ3cfj1qOdNtqELgRvL94LhjgDj2wR6fjU OcpW6aFOCe557od3beHPjWZHgEdnOylc/Lh2IwQR6Z4/+tz9FavF9tCqbdo3EJwC+4IM/Mob kYyDz659666bjKHMtz4jNoOGLbufFVzbpa3DiQPHH5rSM2QAcnkY/XP145yO+8K3cyaoioys YwpHPVQByOo4B9O3TnI1w/JGone99jGcU1rs9z+/j/gmJ8W5fjX+yN4T1C4uBc3Vja/Yboj+ /ESo69MqAfxr7iyRcPcTSrHHGSqoPX/Gu6tFQqNHzc4uMmuxiTXhuLsMIZCcYzmty0uYVs2S VSzZDFQvoc4qGmZpjL6/lmmEYTyY34OOv0rP1e2MdqyCXYGXblvf+tJFb6hf2kMNrYJbyiYp nzD3/AVYj1BoNRIii+zoY8szA85//VRq73EcPqFrLeX6StKCoIBBHfNdzBaiO1KknbkZzTdk hW1KOpWCW/kzGfcGP+r2jisC+tY5/ti9QxyvPXnp+tNSBxuVoNPWCIKzCFAMk9AfStvQ7B1j mckSO/C8HvTbuNGdqsbW1uylT5gOPxrmbawlOso8rNFGE5J52/iaN9iWia7tjPdpsfzFJxls 8ioreW20+K3S8TaMs8hxngfdFO76biStocp4h1EeJtVt76OBoLWJQsQcjJ5616DJi40VMqMD DAHtRytRs9ymYE4/tCKaRIhEFQDO4+//ANeqmiBYbOaQGQxR4VAhADHuMH/Gja4krq5lajay 3EkjTYt4SwKq55Yfhmup0nzIdNvCE8tnUHlcZpJe6PzLiRRyWyBELOyZPbPoM1ys1i0LIQ4a Rmx94NtPpS+HR7Bu9Dr0vBZaaysgkcKAiE4x9a4vxLeyQCNTGpmljyM8459P/r0K72C6vqdP pqn+wY0KgSDkfLUVpYW815BLIhKBuTjIxQ7xeg/Ip6xGt1cblG1BkKMcfX9aiNmosGzJ5av1 wMk4/Kle41ZEFnbQabe24tgTIcltp/x+lZOsxtNfMZV8mPghVfOfxobdxO5UBVtX8uFmMeAC SvU/T8K9ts4pbbTo0hjLMxxuOABmh7DOSuNRns2kSOTAHocc1Cd0UQd8PKeSQc4/Gklf1G+5 zk8ShWnZUlPQ726c9a6iIwyWClCJJTywDDgdhx3pO60Dcbg/2vvCKiGMgKe5xz/WnwMhjVpY 1XBJIBznng/ypba9RPREn9sxwKVSFGDfMpboM1z2kaupnlYhGCEAkcZPNTd3KGXurxSXjPIw TA456e1acOoGGFCGQbudx7Cm7IlMpXGoiadQZGABxIQOoz0qjceIbLTtWW6RySrcZIx9aVvu G0LrHiN7rW4HUkNtOd3r/wDrqR0k3hWkIVmyR6nBxTsO1jpLPTre2iLSygS4+51//VXEmVV8 6WJSBvOQe/5fhSbvoF9TofCNh5ttcTzsEUjPJ61rajFbJpbRiQB274z7ZoTsgvZnEahHaRaa soO9w4AG30qTTbwh5vsw2SnHPp6cGptzCNTUnuJN0TSCSVl5Oefw96l0fRYLa0w7LG2Rgdc1 fw7A3c5z7FbwanIzsoEfzDnpXTT38AtpCTgdBgVF31BJnByzLqEkSEblDZbI5H4d62f+EUSS 5ZyoKsuB82BiqUnsx3toi81sNNsphGQHdRk4zj39qoaZFEmZG3zTBcqE6Kf8mhvXQl6GrpOg h83N7LukdCVQc4Nc/ewLZ3wMa7uegPBzx/Kk2mUtdS1rEIisVkkUqwTO0dvzqpo9xHaoAxyO 5AzQN6lBNWM+quFXIXIJz0/wrU1GVZ4VXBaRvfoKIJta7iRzVxM11O0URIjB+8Dzwf59K7HR 7AQ2xJOGPIz3pJX1YXvqXNUu7hlEcqRIh+8qrgnH48VzytLc3LEjYvZQMZo5VLcN2dVeWCbE +bBKjHPX/GuW1CA+fEsLLIhJDFh938KiSsJNbliKHbcofNVm4zjt1xVWW4le7DEgICcKR1xT 0evQbV2W9S1u6tZjFbplFwduOgPvU6Xk8tijLGAcc4P50Wux201JYLO+S6VgrbMZHvWVf6fM m+aSQA78YIzRKPS4+tkT3Q85RvUggDkE8/5zWBa6u2n3oETvvIwNrEfSlZPR/eK2pamtJtQu A1zI0jtyQxyRVyOCSxcS79zDjIPQf5/lQ1yu6E32K1nO76l5s7MUjHO3v2pNa1L7TcksuQoJ z1z7VN2rjVznLiWWWLMce4sOEB6DNaVvYXP9ngqnlyA87hVK7V+o3boPttLe3gkaU/J/HnkC of7SWPDGHChc7x6/4UvOItzD/tQy3bmJDIP7xGMmuhsZHZA5QgnIy3GfwoSb1KI0kM4ByUOe RmqV8Ax2FcKvA6U3qtCTKt2hicGUqV6Adc1YgB1CQOGKQ7c5xzU6rUdrstS6zBp0YighMk+e D/dH9K5W/tkKvJLMY8jP3aGm1f7hs0fC1qskY3OBEDkccmuh12GHzFWFhsIzyevFOOq8yXcx 4HmjEhLLGoHrwa51tMGo+c0jGQZ4Dc/SpbT1BWL1ppEVrCQi4JA6HHA7e9advHksJAXRVLFU HTHtQ5JrQpPoYJeR5y2zaueCDyfw7CrulfaLjUjErqUCkktk4xnFFlothbDdS8tp8EEsxOSO 9Y+uoyW0KRn94xyF+nWlzLb8QRJEjRRoiMFYr8wPUVrNbw/KnmHzGGGKnn0I/Ok5JLVAV7TU Asi26ho4FOSCcfr+dQasRKSRKwUjqVwBUKzWuglqZEelxyLGMNOFbOF5x74NddeXls2nrEsQ iQjI3dTWkEktNgsc/JdJFZqqpk9FPpWfZ2sckReSQByS21Tn61KVnrsxtW8zTZDBYO0g8tz9 1QP6+ves6N5IiqoyoRjoOuTTbs0mtxPfyJNUvplZIIrYvJuwZHfp+HORRqSi1a0hZNzADOec Z61TS5bD6+REbk6lOGaQJEr+nTHTn/PWoblUiUbJPm3fKT6duc1Kbhv94Wsbun3Md/KWAYcf MxI+YVSktIopJC5ARW+UZqYNJu4WsVN63VykES7hty5zwBWvLplnDEry3SpIuDx6fXv3rSSW rBJmHqN5O2EVCsQJKj6+9MtPNkiREU4LYxnJOTURn5hcW9R4A0ajdkkEYzgmuc1IudkUk+1G yPlTJ/SrbSWrBrm3PR7CwtdOVVAaX93nPGFrI09YZ7uW4kYCMH7wORRFrcEtLkJ1l725kW3U Z27VyDwOasXshtJ0RyGuG4Az06c0JaXJdmczdXBMsscjoHU43Z7/AE6/hS6fZG9gYDaUAI3H GR+NTzXbVth3ttuTXRFtbpEJVCgjhR19sVpLNHb2ZEZWQcDf05P9aabV19wWfyMe5t28oSwq HkyQwVuO/esti9vKxk2AgE8jNFmo73KSd7lbQrabWtRB+0bYofmZmHDewrU1TV7jzFiUnjjI 7n3HoKTSktdxWtoZUl5IyYKDzAxKMqntx07109lJHptvHJJFulZcnHfJOM+tUny6NfME+bTY 5e41E399K8b+WyggAY+XPXpUtnAWs5JZm2KQSWZ/apc1LUly0v2Ma3uZkuPJhX5GUZwvQY4J /nWrd7mtIIimCp2lfUDI/pSS+11Eo9SG4uzK8qqpI2AHPYYrYtreG201EU4JBJ4Bwef8abcr 9i5K5h3l6iF0VS65H3T29KjvtS2hIQFjbaO2Q3+cVctCE2tyta/ZnYyNcF5FOcZwAf8AIrIt GlLEFCQSASoz8vPA/L9Kh323Ks3c27i+ldoo3bZGOQqcEdKjvZZWtmZFCMMF8tyT6US5logT aESCS+iI2JxzwfvH3H496528gkEZjYYUHJxkgn8+KE1y80tWgbLlsI/s7BWD8ZyUAKnjoT+P 5moLW6T7fFuOVDErhhweQRjuMGq521ZfNi+E1tV8ReWMJGHUHBBz/wDXqhc+IY722jAQqgGC T+P6UO8luC1L+hWdrdQTXbsVUNlFJzk4Hf6msOWMPtYHlTkgtnaM8daSlvpdg1d6mnG5gija VUIZsKQeSM4H05/nWHd34Yh7YYYkYZuOCeaq6fvbCv2LenXa286z+VvkV8hmAGQAP65qyjjU LpmRCScYxQlbXuO76jtRgaGOKIkgtnYuB83r2rKgJtIXE64ijUhQeDjBx/nr0quaMtxPVn7R /u7Kc+a5XdwMCp9GWaaaVYTsjznp610vbyJW9ihq0S/2qvnOS4HHAxW3BqM0ljtaNGXcOMdK LXQbFq6ieeVCiEKME5qlqFmtu+77pbgA8dualPoOxk6EywXdxIYBJKBtXccc1qNCFulvbojd t2/L0A9Kp73EtjG8ZaVFrmn3FrICbeWJldSMBgRjBFfwz/tEfDuX4U/HbxDoU4EKWl4yZLbP lJO047jAH4VzV4txvezPouG58uLcf5keERzNe+Yjv8nyriRdrAc4ORx3/T2riPEmjO5YuiyM MKCe56Zz+JFcnLrzPdH283b0PGLkCxuAqjY5JG3cRxjrnqBn06V6zZSLdaEwtpJApBUsW7cZ z+QPrzROVkoU9ImFJyi2jkJIZE8piNyrlIsHBBJBIH156dyKxwd8inMgRclsoc5459e2ef8A GueUm7p6v8j0k3sy5eX025fMZZEHyjIOBzjnoM/iKmS3USATBI3CAsAB8vccHp0z+VEJPna6 d+xbTTv0J8SwmJUdwoclZEOMj1LDkccdMVaukNtDFJFEp3EKqD5Qz49RnjjqaSm3zJq7Wwcr WyLcsTupDOY5JIySgAJY4BBwB2Gev/1qqzXh2mRZGRmQkDGPcc//AFu/vWlnUT5Xa25GriWl 2NDGZWRGPGFbgZAz9ADjk1n/AGEzQlo0MDj5UA/u4z/T064qFDS+99/IOa54x8V4pYorO+JJ eKVSI1yoDFlCjJ6d+3Y19MWTp4g0WG5jD7JE3OWY4ViORnPqTwa68NHmbivl5nyGdwXtFOR8 y+KreO28TqQhSKfLgrGcgH+H8+cgD0qhomnbZpI5FKiZWKRxEAybj8xxxxy3Qda6adLmqK2l nqedGMbK26P62/8Aggl8WXh0jxh4TvZGViYr21Vkxt42uMfglf0FytbXHmsAAwbIfBxjPXNd +Ji4z+R4WIVqj9TWa4s7RhcF/NXHAA+8fb9KrW99cRyGVoUDSHGCM4HoPzFc7uzG+olysi6p CXZUkYZVTzx6/wA6o606yGMzttjQ5IQfeP8AhQtNhIpzXkd9YxCEmE7txYryQP8AHFO1fUJo 9TggKFw/DEHOBzTtf1B6FHXRAIUgkkMQLA7sdhWj50mo4WBj9kABGf8Alof8Kdrh6FfVoZri TbnavXgfdrm2aytddSKWQs/3gCCcn6+tClbRCaJFt1fVAxfcitkL0H5UaPp17r+uC4lxbwpx HGh/X3PSquuoi9NYzJJOWYsytgHoDXOasJbi7hic7YR97b/H7Y9KEwZZltEv722LDy40z8vr +NcpqixXOpSMymZAQqITTjqxtmlrtsDo0cUcAj9Aq8V0+iWEuq2cUUkoghC5bPU9Oc0trtsd 0yncW0T3EkUU4VMc5wM4rh7XH294EaSRMljk/dHaiLv6i07lnX7AmRmlmDMv3RnO2uh0CQRO 4lYbDHnaVJyf85pLYGxo1J54VTeC6HoDzWQksenyhRGGIbdgnp+VJprYcXpc0orJZ2E08hW3 5LBR/U1Tjit9W1iMgkQjhWbHQfyq1K/oJ7XOuXUVgsWWBCyfdL55rnDqkaIodHJBONp6Y/ya yu2/Md7EM9v55iLkiI4IJ7CpswxhiJMp0JzkU9kx7nNXEiyajCsZ3HGGKkjA5wPzrZ1q0hu7 m3d3clUAGBwTSd1qNElrp0RvI1jfe7JuGOeM/wD169rvbJrO3jVTtOM7mwOT7UN6BazueaXV jE9677VIQDkfrTLe1jLsFyoBxzxmnGV0LW5gakIfKaHaHYvhgOorTS3L3cNpYqGeVgXYqOBS d/kD7Ed9A9rqc6xyI04YqrtyMd+P/r03T9EnngPmL5jB8hlGKVrg1oV7jwu/zGRnQhvu+vtX L3HhSK2u/kuWjOfujGBn/wDXUtoFoWYPCkMdu5eYXEhPCgdq1dM8I288U3nSBFI+UFufzqlL y0DYy5/AEN4xjYsqKRhQcj2rIvvhdbyygvLI5HbJH/66c5q17CtruRH4bzRtFKl5IzKemcfh XaSaRNAUkSUsV455xQnFq9tR2aM1fMuTK6gEnjJrmLDT5r43JuHZYlckYBA9alp3t2KVmdVo an7M4YeZjsSSSP8AGpGUXEkisdyAcALnp3oa7CW5x80ct9dGONlKqeMf4V22jbLKOUNHG0jE YBPJ/wA+tK5Wx00lwilYkhCkLk8YBrir3URHBKwJLsdqY7DFK5JhafaSpLISSzycHK5xXYXF i9rpxiISSQsN3fH+c03G249tjlrjFpdxxmNAEOC4PNaE98y22xIgqZ3EliST70rsFoYcc81x JFtBZnOMZ6GtW2uoLGOQFfMnJIVN1F7MGT2N009wFLAELjavb3rm5blxqgijHz5LHnsOtEm4 7DbNLX5BcQhmfZETzgdTms63w0bqq+WAM5ZQSfypPWwm7aF7QtOjuJZpN2xTnPGN3Fampu4M cMUSqAhLHOCenenbTcGzAtbYoZGlwpXBLYxjr/hXRxhFC+TMRH/s+vrUPTRg7dSZNNhgtmmY 5kPTfVWW+LTEiMFWHG1eg9KdraBe60L97dPPGCY/KVfu7+uPWuOu7qOKRXJOT3b86TdvQqyL cMxuJJGQeWONuKpzQrGQRgAHkg4700yb62KvnpIJZC4DN02g8iuz06J7iFYo2VWIBbPYZpeo X6sYdRNm822V2dOjJ1z/AJNc3rVwrhPMuJJGZix3DOD/AJxUqw73NCWQiAFJAWbjsccVBp9n FpqzOymSZ8ZJ6U+oWe42xja5knkdjEoOAxqre3JvNTMVupKgbiwPX8PzpON9UL4dCO6uWhUr Gmx24PHT1/nWNN59zOATvPGR60kr6MZttaTW9oCj7Tnp6VMuqS28Koz4VuSzHnPrTdgvfQru wnh2PNtTlsE9ePWuYlnUlVg+ZcjJzjPvQrdh7iCNYYgEG5nJGAeprrY0RbFiYypA7DPFUm1t oJozljE8CqFwoGMHPJrmUSS3812YytnAzyR+FS9dR3uZ8UMwkWadtyjj5h976dq1fs089vIz MoR+ABwRxxSStoF7DbW1Fqq7kLsepJrO1iV5WjDRCEHoF5x/n1pqVtQSsjoPDGlspQlC0SjO 7P3j/nNa+ussKuxTC8DntUp3WnzJvfU4+6uvPhBjjLY4OB1pUs1hs1VyYyTkg+/AptbItbDI 7czShFG0gHheTyf/ANdTRQSQyyQoh81gAc9RmoejbW7FZNkUttEGEbMQxP3s81LZPDbylLeV lZsAZPJHNPnStfcE1uUJ1UXL+aMEDHJ596X7XFbIruQGOAA1E7LZCSvqULl47y8jbdskbnP+ frVO9220ZjVi8x4JAx7dfwqVK9r7DWhfs7aAKuwEsPve/wCFY+oeTPIgKttDYC57d6JRk9tg e9i0dVjtIpJDEQgGMYznn/8AX+VQ6nqFpdFHAZkxyXxxjv8AhRe797YL/cW7mCR7UsiKoA4D HoR3rNs7KNm2Mytu+Yg8888VXNpdDb7GjqiIVYysrMeRkkdeP1rnLe2BljBlK5PIDZyen+NQ pRbsxGlapc+e/lhTEqkksf8APoaNREk2oxM+GLAsrbeg+laQ3fbsNovW1lDFBIUTYeuVHPeu Y1gzLcwFEJjMmZNxIx/k4qZR5k19wmuYsskcw2EnIPAB6n/9VXL9kSIKIsyADn070OLa1Elc yY7s2N3MXdQxAPJ5NTWc0+tXDyTkBIz8oK4449PTFCkoPl69ylJRsiK5mk5WIhwOM+h+v1pU vTYaerOSxY55ySD2/HpUt22Iut0VWuJ8h0VnLNnceAPfH4+taullRqMEtwMsnAIAz69aE7+o aS1NvUZ11CSSOAGIHqzHtVXToLW7WJJEYQJ80jeo9K029Sm7Mq3eoW8ktw9i+/5uNo6HrWJM m2UXMrHzT8xJOSpoUnu1oNu6OSu0M0vMoU8Fvk75471r2trdMjCNZBFgn0z+dQ3zNpaELQ04 NNa22POwU46Efrmrt4B9nUrKGDYyB3og7Oz+RRg/a4tGmMschDkYLZ61Ue7aVDJET5jdWDdB 0ouk/QTsupp6QWupgomxbqACAP8AGprfRoNtzcG5YknAUnjp1xT5tRJcphTyGSVlGXGM4wMA H69c1dWSXULmCAn5WHPfNOWj12Kb5tCCVoLe5BhGGDDlueCf/wBf5Vo6pM9pZlpGMm0nGDWa VmLlv6FDTdSkhZpRGF/d4Pfvxj/PepPtRLKSR5jEkhgTgdD/AJ/SrUrXB66Ir3M0UaEMiq/O DnkVdktAlkmx+CANx6D/ABppa6k6P1OXvLSO6uAyyeWQQDg8HHX61DKJZ3C5UDkL0BGKTSb5 lr3LlorFWB4NxE8ilGb5iFzt6VnS6lawXKpGX8wuB93tzzVLXQUZPU6Q3cKqZSHkA5APfnH9 aZLqzL85QAnAxnqPwo5bfqCuiubiR4eXO/BJJJOD0P1PvWLbwvIoEZZyWB3gH0x+PGDUySvb uCVmb80FvHaqZG3D+EZ/X+dQTX0ax5j4HA2FQOlJJPZ6CUbq5SSWFwJJCY3Ixy/XntnqaxLv TnurlSrboyc4xgHPtVc1/IFc2CWhtDErAjBycEH3/D3phs3gVJLrLNJ3C5x/nFNrS4PTcknl JuMoGIKjd8vIz2pbdDEZZGUYPIU9/TNUtdwSdhjQi4DyMilDhQpH3s+340+3keKZ3ZlifJPQ UrJLUG7Mjg0uVNUW4nmMjk8gnhf8/wBKlktmltnErgJISQVYYAP+f65pKF0rhp0P2Wv42nu4 3cgJ7etLPvj1eAW853MSW2tXYu3QgvXlnGJj55Zps5LMM1BYX8U144jJkC9ecfpRv6Bszd1P WUtbBvIAMg7t2/zmubsTPqkCzTIQxzhvT0pRjbVjbuyS7sl09VcsC7ON4HfmtDVPIsbFGHzM CDsU9aL32CxW1GSXUrZZFiWEAdieRX8vP/BY/wCEDeGPjBpviKG38yHWLQxyuRnEkZHP1Kt+ lZ1EnGzPTyer7LHU5d3Y/GL7Otykjr8ybshdhIYDop7DrnjPWs3xIgaEpiZVVRhvLBOAcjvx 1/XvXBBbrVM/SXe1zwXUxLcRqsxR7gYy5P3h35wMEZ49z1711ngnUI71IY1kU7xtBUcEj/Iz 705NJW77nNC8al2Tahpf2W9MrbQGwN7R7dxB9s56dT61latbyXSMYmJcqA/bZzzwe9ZqGrt1 3PTpyUnd/eVZ3WSR45IEBCkoUGBjJwO+eOKct3Ct5FJOqh2Xy8huBwMjJ49KzUVGVrWXVjT9 6xJbho7UCVd0DZAIc45xjp1yG7e/NR7hCoMkzqu1kAY/eBOASBxnkfmOc9DkjF862Y3Jttle EvJayK43oTkEtktkcjHQdf0NaunhobkmSVQ4jUlJT93OR+PTrmtI80ZKS/8AATCc7XW9zEmt WKLHcExqc5OCdy8YBGee/wDhWxcpPJEBvAkcAsm04YEnPoBjrn2/NKUruTWvYzhKzXbc4Xxp p/23w3eQFmVo+cFl5A+7x3HB6+vWur+AGotqPgOKEDZNDIUkVT3wTjuTyD37dK6cKpS961j5 3PaUpwUkbPib4aXGsT2ohickkoQsfzEt0bOepz3HPNfqz+xv/wAEk/FPxte31TULL/hG9DJ3 Ge8Tl1PUoBySOgyAMZ56V7WDoxpJ1623bufO1cR7KCvoz+nz9lz9jDwX+zPpjroMIu76VRHP fyqN8g64HGAvsK+m9XMYuHhhiLSbMhhztrGvWdefM9Oy7HkTk6jcnuyvPLGYo4EZllGM4XG3 vVq6uZmS3jQK5J5JIG0D69KybsSGk2iXp+1yOJDuK5P+elUdUeGR5duWBBUHPAzSvdiuLpt7 bpbDNvJ5gXAHHb8ay4xcJdw3LsGdmztJ+6PSn6hfsXtYslub8yzREIg3YNXrfV2Rkt7aJULK SWZfTt/Kh6qwthHItraSWdlaZ+BhfSuatPDMV/rIu5QIyRjk4oj7ruhtX0Haxb28GswpGA42 4Yg8Zq7Jex6YQY5djE7VGcnJ+tDbaC5XWKZbaViGMWMkn1riL+8C2ccxf5S3zE8ACqTSE9NO okMz6nIFhV5HOFjGMDBxzmrVwqWsphWLzp9xUgcAY68/57073BozbgSapOIncN5TZEanj866 Tw7v1G5VAQIY1IODnJ96LKwuvkc5d2ivqJcDagXaFJ6n1rMik/si/b92zNJghicZHpiha6Be xmasJdSmmhiBGQC5C/nW/o0am6QIckx4bnOD/jQrrQe5o2txDp7kFgjHOc9T/hWHO9uSWQ5m fqPc9P5033Fey1LAuY7izMMbFmIAOBxg/wD66t2skltYkKWTDfwHrz1zU2HdEcUk7M0QkLBz ux3HtSXUbwRupTgPnBPOO/Wiy2C5oPHJJp6XLbUXcAoBB47/AM6yruV9bsliWERwqcM+cdO1 KxVuhnX+qRRBIYLf5d2A5I59abrd9HE9uVUkjggn3+lK76glckt9VLXUMMcXkoBud8ZNeqi1 l16ziEZeaLKthkGTj8zih66sTRwt3qdtNrxihnYLFw4xgFvT3pLq9S41FUkut0UeS3l84Pb+ dSmO+hz/ANthggkSMFXMhILLycnr+tdHpepFGmlVjHmIDcOtG5W5Uti0mqERncncn169a1Jt SWwgKKxVeScd8d6Hro/uFvocrd3y6h5ksrEuDkB/8msJ7s37Ituxf5sOVBHP1oULuy1Fy2V2 emWlr5Focja7/wARGcAfl/ntWtK6LHGIlJJ7juaT0dgRU0zMOQjEZIY89c9zVW8u0IZlj3Mx PboKTGncmiVzGWIwoHTNVNTu83EEKjy2IJdhzT6AU9QhjtvLjRsSH5mPtXAXOoTSvNEshYbs gdKb1eo0b+g6mD5nnOEYLhcehq7qd5FFbmGJRGxjwXUckfjUvUTMzRja6JDM7j7TK/BOPuk9 Ota2gwzXYu7lpVVAAoAGO9P8hrQs30U0Mcih8bkBBHp9f8K8/tPPu7sAsTDCcqxXjJ4x+tJq 2q3BI3ri4FpgSj5u2OwqPRZhIsxMcm9jlTnAHH+IoV73Y33MaYtI6lmLMZPnxXR6pLGbYCNG BC4BJ6/jSs2rE3OcjS48mJkQctyT2Fa8GmxW8gEyGVmGf8KezG7dDQsoYorl3GFUjA4/Suca W1h1EySRshP8YXrUyV1+QFy8MV7EJUbdCowMjOTVNYDchRHHyQRknAFJxs7hy9zorT/R7aNG ZDtzsQjqe5/nTL2QwzqWOSR8wReTVeoJIxJbaWaZw6iGIAEkkdM1o6XbwPckq+Y1fJODyO1T foO90WNXvGuLzahAiBBOB0/z/Wqq2hupnnLYQNhRn7tF7ais0XtZmiliEihmUk8gYzz1rjdY UXk0MKQKpJDKMHr2pvXcFrodEyrC7rhUcDqD0GOtczclAiKZPlBPAbrk8+/WpvoNqx0MjQWG hyBbVGlkGN79qS3uJoHLx4yF475/GmmJ6qxz1pNdX11NEiBQWw5IGT9K1rqzZPKBQuM8g8H2 ot2K2NZoYbm3DPtjxjg9eB6Vg3Dx28xCMWJkHI74pN2V1uTsiKPz5WljA2gHgEYxxV2w83Sr cyKSGYlSfU9qNGrdQTK+l2qX+oyPdMESMFhnjNUJpre51mTBZYtvUDFJ2Q27aHO6nqO1VWGe R93dR1NbtpFALNWeZmnzkButC1dxvQrahdJbRpGqq7+x3f8A1qe9tBHZBSrCbOSwHBpuy1RK RBFGtrNABkIGDEEV1Gp3H2jzGQqAefpU/kBgxSmNFBGRtxnPWrMN5HDEshjVQR1YZzn2/Giy bsNa7HKIn9q3zKUVlUkgkdB/jVyWZNPtHYuSMgKF/iNRdLzY7aleKFnty7AlSONxBrl9UtLj VNTjiSMuMgBgemO9OK0ugd2eg20r6TGlvHIHuAOSn8FZOrGa5cCeZ5RuwA53D379h2p8qQkT 6dGrMUV1jb+8R0qhql1HbsjbvOkycsDnd26GpSaf5FLzINOSR4mlyyqT/FkY96pyXy2EMzzZ d2OA59c8Y/z3oa7i8yLTZYmaRwxLNyGIp1nEJbn5XYY5ALdz7UR01a0B66kMNq73LAgtzjLc Yo1W5FvqUcfyuy9Qh4/+vSav1+RO5VKh2Em1ixLAY9P/AK4xVu6sfIhXc+3uR7USfLp+Bo3b QdBex20DRRPlt2OQeQRWPcXDCUJncobOSe9TJtuz0M2tbIZJZm+i3GTy1T361cnhSGNDEpYH g5xhs+9NJJ2RaenKN1PUDAgLSeVjgBs/hT7KWMac0ruGlZznb371KVtWTqyrco96yuSUjzkd ifWqLiG3BjVgxPQPyOvJz681TlzfMLl6JkdkVm2rjpnrx3qHyFS5lnLb3PYYPQn09KpK9gTu alikVzIxAJbGDv7VWlMNrqTFyAiqN3AOfwpuelkNO5VvGURKEOZSARxgcnr+uaS9tkicGabZ x0U8tilzWs7+o7tHNrLEbpsxsG6DI6Vp2MwFvM6LuHA3Adc//qoldys+pO6sZs0Jc4ywGQMZ x6d/681oCMSBYyVCqM7T3/x9/rUtNS30Hew661pp7gRRMImHG0HAx/Ks3TYmkmWRsGUsSRno KLa3HcvXF1Jp9sjTuEDjAXPUf5NbNneQ/wBkTrFcRD5ccMctn+VHMk7MVznLTUCkdrFbw+So AErEZL/n+PFVEtLzUr51QfuiuZDnt/kVcNtXr0YJdyu2iW9hPvlAkKnO7IPPQ/5FbEd7Klk5 yWVhwMdMe/4k1Mmr2+8FpoZ1xA2oyokhyxYFe+D/APqrRv7L7OgLnLAY28cU4LW/bYTepzlx aLJdZZFMajDNjqM+n+etaDQLLp7IuCAPULmlb3X3FawaekVto1zcqmYwpClm5z/+oGmPvOnh WAVjhiu7t/iM1K2Q0jJjjL3ARUyG7k9a7BJbHSrZwIt0m0DJPQdPyp63v2BtPY5KLa08UrJu j5G0nkn9Ovp/OnTxRapehbmLEG8Eqoxn/HpVSk1+gtUrF69vbaKVzHCwj5UbB0rOhuEmIkXE agYJ9OQB+NLd3Y2iCbbc6lEo5deTleelXrlpL2MImNhJ5Axjsfr0puLtqG2hXh037AqyYCAZ PzcnvgdvbmqD3qWsylYVMzD7wPQdx9PxqXFJ6fcPfQy52RFQspcM4GRxkHj8easaJokOq3Lv Kwjj5CsDnHt+pp2btyiu0dZdQ28cyBCoiGVwP0/KuYumNtMZFUunQE8Y/wA9/oKHLWyE2ZaT GdmVRiMHLD1z/TNNivVtykcUQRUGGZj04oXvbDbexW1SO4WJmVMuCCRnsD/9fpXOaTY3UyKS GU8bw5Jx+P0z+lVJIrodNcacmnwBQPMYjJUnkDPX8zWJFPI18sAOSfvkc44OeahyXwtiN7VJ 0tURIP3MYQgOccHpn0qHTr2acxh2YEjI5zzVr3mmSrsvRymQkJIVIyCWHU//AKs81WdY/LEk sjOVbACkAkfUg1Tk/v6Arx0ZLNMb1IgkPkkgEZPv0yPw/PpWPKJLVGXy2eTJPA6Ht+uaG7oN 0a9tqV0rtHNb4jGQGA6Z/wDrVW1C+81WRJI7eFCB15YZ9alS2vswV+x+0GssLzTAVTYCMnJ6 VNbW8IsoZ5GCoRgmuy9lYi12W5XVpP3DGQE/x1g2V4bO9YAKWY7WBFCVwudIYzFZsHjGeoOc 4rQtbtDbqAm1R6GpauUnY53UZhJKHjU7Rx83c0+wga7SaKWfb6qDwaeyEaTypcaeFRXUDjc3 Q4//AFV+Tf8AwVd+EEfxJ/ZzkvU/eSaNcrdK2M7R0b9PWonG8WjbDz5K0Jro0fygWsV0rTwB lklibMmBjoe4/TgcVk6rA0sdwsQkaVv3qLtPB4JB9uOg5rz4Xe7Wmx+sQ962vQ8W8Q29vaTv IsKgvkPLs+6AeD9effFUdGuzBeC1yZHwW85l+917fkc1cH7t9m9ziqJua9dzr9SDXKKhkyCp MYfHf09fTr2rjJbDy4ZoLdxG0MoEheYnPPXB5wFIPBOOnasKkLq+zTO+EtNRXnZ4mWMG3wAq yR/x56H1IPOPrg9xTnEsU26VgDEeWkXJz3I59MjHv3HFZRnzSlFbWNH011L1sJJxGYVLSliI 3nkBBLcd88cfpQtuu+2kJZps7cRucE5IwRnkdc/StI2bs9hNN/qWlspGglSabCkBGVVIAUHl fbt69altLOadlcqwG8qmDnHXn2H/AOutI1NU7XX5GLaRLf6KstyjRgBlIIfaD8oPP1/h5zVq 706W9DRRgmdmyCMDJJ/w/karkfO+XqRzW02ZePhyRrYQGIlSxfhNwbuePqe1Vf2bvAN+/wAS 7rRrVJAk8m21j8vGRnCgAA8kf4DFerl+FqTnyy18jxM7kpYdyP67P2Of2ANN+Feh2OreKtJi vddkUSw2twu9bT0JHd++T0r9ZNLiXTdPVYbcyOwwo28L+Nb4mopz5Y/Ctj4KUuZ3Ni+llsLO 3htl23LY54AUdziql5bXNmrSbhJKeOTjJNctrk3IYAljppZnXcWyXI6n0qhbxW9x5k8rDH3Q rd+KFcT1Liu8tpDapGoByflPQUy6htxJCqqQU4JJ+8T3xT2DQzWlGmXErshdVHA7HmmTag40 1LuYAop52rjNG6uF+ho3F/Lqd4X3eWjoBgke3FL4e1KBZ5/MKPMBtjA547n6UW6CuZAafU7q WaSRgE+WNR2HsPr3qhfXMKrBGgYLE2H287j0OadtkFx97aE3aToyRqqglXchmPXOB0GDWe3h 631LV0uJJVllPIbHAHoKadmM1NQ02e41eWE3EjW6oMKrHHvXlniCaC8t1tQGeGOUb8L1wT3o g76Il6as7HUYp0SBbZPIAwTg8j3xUMti1q7hpSHfBc9Mn/Iqr39RosTi1jW48lN0m3JKnOSa teFb2K30eSQKS/3QB1pXbBdzNSWNmJlOeeOcgVyz3bXWt28cYBJGQCO2f5UrC02NjUPtMEc0 ayICRhgq/Xir/gsyartEboqRuQwUdTj/AOvVXVh76Mn1ayt4Y2UuoYttXLY349P/ANXaud1C C4l8yOzSMBRjceAPU7qSd0Nqy7mhpOlJp9sWmKXDZJxG2Q34moLk7YELyqF3dB0FF015EW7G fa6tK09wyMCxyFzyFH0rL1mW6jiEYYyFuDt/U1LVtSkdCkqXtkogbfgYYjt61jJBcXNysMLq BjBDLkL6/j0oabfZAtH5BrCJolrbKh8243DewbOD9PyrM1AMZlwCXI3ZP8JIpP3tUUnYoWch jvVd2BXaTntn0r1dtR1DWNCSBJxbRBNrLENpPrz1xSST0FZvU5qCW00NHgFshYqRkjqfWobK GMRL5kajLbgoUCmk09dgb09CrdNHHLLIFwSCvAAxkdfrV7S3hgsmLHdiPuKnrZD8zCuN4nRo pG27gfvEZya7VjPBalJYlaRsYLdhQ1v3Baq6Mu4t42gmiEO9yBvyBj+daRvo4NOsLaGKLCAB nReWPfP40LTRMbRf1u5nnMSMVjj7BR2+tVLvUI40CA5I6gYpNILGSslzKjuI2WNznPt9al1b UltLNlmbG4Yx1yPSjZAkFjq4uYo0tyRK7BQCOo9fpUt7rF3a36RQxKzqvzM2PlBP+P8AOk11 YJamJqniUQ3ISZthdcEAcVhaHZSardzu0gigBJ3kfepav0CxtaVp1iJriSQgFfuFlzz61oWe hoEkuZpWeJsEDrVc2g0zmNQbzr0JEo29eTj/AD/9em6fYT3OoOkEpjOByP8AD/PSpvfR7A3o dbJdy6U0qSMZV2EYdcn/AD0rlfDyPqM8zyFoo2b5Uxwcd8dKbit+gRs0a1+InnEcWGRV2884 Gf8A6wro9MdIdLeNYcueWZj0oSYWPP7ucy3scaKd2/5h612A0y4ezmnmkRI1I2RnvSvYTT3M uOQGGIsMFGyF3DqaZZ3X2vUJJJVLSHIwvPFLdgySHTJL/UMo/lxKfusep9ax9Q0xzfGJCjKT /ESMe/sabQ+prz+H3tbMQxzeYx+c47deapRWj5IMWR1XJ6Cm7SB9yS2V2VlWDMgUjc3OKv8A FgBuAkcDPIzzUpWFtqcbNcSS35aRSx/iHTHpXSWLSxK3lxBCR0Pb0NO1h6bsdMgmmYMuwYzj seKxLpZLu4WNHIiDcj1NJe9cLnWX0kFrbxxtHnAwPc/5FYyncQFQlyeTwe9N3YIWa0Z3bLhi T0I5AxWdIsFnMhIy/PHrzSWqE20tCXVWN3b5WLBLDAJ9/SuitbJ7O2Qyr5igAYzzSvZlFXT7 xH1OaQQrGpzxnqfSsfWGae9hjTA3MM4HAHYZ/Okm3doSTRsXUCFS0jfKq8A8GsTRrBrtJ7kK URCAGK/eOT+lU7dQTtqMheO3ZpJWkJ3dz29KsxagLjUSEhJRRu5H+fWpvbRC3ZlPdJLPKSo8 vOSBgZP+TWZI8SzSLGpVNpDA+/v6UnvctaCPNHdSLGke0L0Kr/U1oX0cVvZgLIuSMYFJtR06 k200IobKxXTYyEZp2bJbcBkZqhqskRQxwZLEkA54pt6FIpxIy7QG2qOM1tXsTrbbkcSIeu1S KiKS9e5N02UraTzHTC898jpTL+crGFQBSO5HGKpK6KZn6dFFBDIXdpHfI56CqmqbnkjeNSFK 4wowAO1K6WoLyJBOLSEb8O5BwoP0qql5PFbOyhYnfpk8mlK9wOq0LwwIbcS7cynPLJ1P+c1l 38EMMZMwJfdgAj344q90T5dQ02KF4Z5Hi3KoH38cmuVbTbRLpHC7WbB4boT0/nUOVitjflZ2 ZWjLBQOPpWFDop1KUxldy5xz35/z+VNaitqdhDoyWsTBlUBRnGev+cVz1sLW2lkCygsOC5He ibtFA7FaJcSswcEnOFBwBUENs1kyvOpUEMcA5yfoPw/Spj6AkTRlHdWCED3UdapXcsTSKDOS CxGMGm0lqNuxPbRr5yMMllyclevFVr26XJZgSODx/n/PFQ3zXT3Encrp5byje7AE87ugqae4 je/WNIzJGPuk881Ss99+415kk1idTvEWd/Lg2Z2kkfhxRf21vbRqkIO5uNw/h9Ov9Klu2iBk GoOltat5iu7YIUcelZYsY5XZ2fDZJ2ggfT+tF+V2CxpsrPcAFDkDIAGT+X5VHFZlCysrRR5z uP8An2qr31G7XLqXGEzBIAx4DAdOvf8AOsWWxWW6BLFyuCQw4J7GoSV22iUh93cmORE2bnOd xBPH45/Cs9na7u3DEy8ZJA7mqUeu/YafRlRIJNODxLE0srcgHoPzrU0uJY4XYgRnqMDORUqL T1/4YLFY3EaNGoUEnhSTz06/Wmknz/kwfkz0+n/16c4u67Be+5VFopuGWQ52g5OOM/Wqq3Pk W05jHmsPlXH8PI5p7aMV7uxhXltK9mjZaQse69/6dK6AWcdnppmkhBkJwhxnZ9Kad5fkwbu9 C9ZBoo8OyoSBtwcn860xqEdjpkqRDD/xMec571HK1uLd+ZwT289++5JdibeQ3U981u21g0ax ukhBPUk4B9/rTUUxl6Em7ulTJJ64TsMf56VJZ6cZZHRVDZ4Z+g45/pTkrK6E27mJLaR72ccl /l59MdP51G2iS38jKEKwbfmJOAfbHftTTSjsUti0qwWunMm9ld2woXgrxzSzwrd3CKxEaIgw D24xS0avHZdAW1+5DZSWsRPlyM7ICSSPSqOqXqXk7Kr5jHUsR1/z/nrUxuiWigt75M3C5iAJ UH+Eeme/pU0DyT3YdkZA3ChueKbXM+ZaNbh6Gjqtu3zKXVJW5YtkZPfkVnta2mnRs5m81iwG xW701K+linK+yHaRq1rcX0jSxiCHhmdhnJ9P51Uv/EsMkjpbjam8hPlPIB/rim0+hNtbFPUt WFxaJF5LFsY3Zxu56fr+lZVvdRWv7llYydz6c8Uk7NOWoL3dOpFdbZgsIIC7Tgnnn1rrdKsV S0CRxyqAc8cDHv8Ar+tC38uwOV9iMwC9DlFZkA+ZiD8uff8ACsm6skQgCTaG5CDPT1NVpLYS 01J5kkRHKuEj7BV7fWsm0kCSOI13Ow4B6GnGKZV76kbvJ5ruZSFx0BznPbp1qte6j9ggCxRK xZhhi33uMfnU8qd2ncVtb9OxSg0+fU5lyHV8bl57E5we2a04bWHT1JVCJm+Us3Yf5zQnprqP rrsVppljuXcEyMvBG3rUtu4vSTNIiY69zyP6f40Sir6aBbdlV7iEQJHChDEEsT269SPoKz0l Mu0hiy84wD8xHUYNV8L1ZMl3NHzTDICPmYjbknAA/wAa1jOkNupeZtv8Q5BPpyKcruOg2WUv TeReWGzn7x25wPpXJaxYPp+XQb4zz35Izj+ZovpZDb7H7e3j/a7MI6BEHJOM5/Gpo4Y7jTgA mGXnPrXS9NjNbk72RFvGsbAu3TGOnPasmG3TRJ3aVgzZzkjk007g11Ow88X1ijTJ5a4zhBkn 0qAXEBtGVUfJGBlf1rOz2KuchqEkyJEsTljg7+OhqHTme3vI5JVcxsDkgZya0WxJ0VpbS3Bl dpMR54TpXmnxW8NQ+LPh9quk3KI8N3bSQyK3oy4/wqX2Gfw3fEHQrnwF481HSJofLubW6kil kJwTtJwD6Z61wsMv2i3aJmLxtJuAwfu9vp1NeY0+dRfU/VsG/a4elNbNK55J4rgCRRsgNpDH k7eRuzjnPtj9T3ry6aVYr4Eo8wEpLBCSxGc9+p4/nVwjG9lqkY1oczVtu563Z263bF3ARV5U A5CAdBgfd47fjisBlSX51RkjfO1ioJJHAbHp/Fn0NQ5JNxet9l2OqEueyGjw3LPJLLN+9iK4 UhehGfTuTn9Kmfw9JNGF89iYzuSPJXay5x+H161XIoy5nonudLnrZLZbFg6ZKkkkYiXBy7Aj o3UfKO3UY+la/hzwzNrMpC28jyF9/BHPv7fQVDh7R23T6GPtIrVysj3fQPgPr3iByLGwuLrf zII0bK54K8c546gd6+jvCP8AwTz+I3jVFFr4SvgSwZHks/LGOvV8fzHSvdp5fFWlVtFI8jE5 vhqN05an0X4Y/wCCQfxC1SFXvbCy02MuUG+8ycnoflBPY/5FfWvgX/giXOsSHXfEsEC53H7L bvKV65xuK+p/OtILDYe6+Pszwq/EC1VNH0T4V/4JAfD/AERoze6lq2oCMbfLDrAMHr90Z/Wv s34YfsSfDH4AzprHh/w5bDW41P2e4nkad1c9+cgd+aJY2STVNKN1qzw8Rj62JXLN6dj6P0Cx utQummmmM0jHqTnBrYvb54rcwKVQJkjDjLH8a5Ja6HCr7mloWiXEtsk8zGSUjk5zxUd8Zpp5 I3wUQ5+uOlJtN27D6GOb57aFJJYFkCyERqeMnHU0kUT6lKxZFUnjAJwKNuoGiumGzvREsjKw j3Ng8A+9VLmJLa4w4BGN3uT/AJxRe4tjkbuCXWZ3iL+WjcFvXmuvvhC2jrbxx71jA3sPXNPo PfUxdaY+VbRW0fnSbcDI4FU9LtWtmeN2xM5wzKMYHoAPwprREWuy5d2trYpIQxRCPnJPNZll dwzaWY44REgfK7sUaspFbUomivXfAkDoA+4Dg1PpkP8AZ0aSvlsk4yf6GnrYWw66lNxcrK8p jPIwDjI/rXGGO2BnAVl2sThsf570RVvkDNtNSiuLQbzlShLsnUkdh71xl7fQxW5SBDKeRz0z VWb22E2n6kejJO5IyAzfeZu9aHhGAWk88RXeoJPrnNVZK9hXaNKVpn1NWt4A0SNuy3Q46VyU cxsNXeS5mwApbI/kP/rUkk/ULk19rwvTLHCjKrJkNjHHesrwtJb2BmLSSO4bARMjcT1JP40l F7jvfbc07nyo7gTS2jzTgYTznACD2Aq39rDaakQBjj5OQduc02ml5IEyPSbgQ27h5QABjp0/ zxWXJLHPaTRv5kjGTBHQDv1/GkttgW9zeXUbPTpVghty8zL8x54OO9QxWpvjK7NtTaOc5zzQ 7tXf3FXWxsaFYW9hoNwGcnccKvv6+1Yc11FY5XzNm4gZ6VLld2Dd3uZ+qF543YoFXOfm7j/O agvlF00LKS0gwuQPu+tTbkC1y9aWr3OqBROkcCqSZCw4wOetdn4Pc31uxWUSlcguPrTTSVkN pmbrGmyC9dlVQcgZYjnNR3uqMJSqhXYAAk+n+ND97rZhsZVxOzqXeJTjufWremAOAXXc20/M p+7Ss1qCemhegtBdXcYKhYwep6n6V0l1qkMKssMH2i5J+854A/lUbgtDn5nkNwzzFSMAsqji qSXcfmKi25b03HpT5b7FW6l/VtQWe6VVUsyjJwazodRt1BVQjtgFmYkn6VNmJ2ZdvdaNyhji GwEYyR1rJvrGCXyEkff0z3o23HY2ria1toU+zReWFA3SMMAAA8VztrCNRma4e7bJHAXgN6c0 XvoybtiS2CzzBpCdoUkcYx/nNd1o2g6fa6C8ty2Zd+PlPAHPH1obXYd+5xun3sF1rVwIIyse Pl6dq1I4WSRkYFgOAG/z70XutQWhy1jY276hJIyY6ru7def5U6wtFttflVJWlLIOV4APp+lK 6Tsw2OgvtKe8nWIuzFvlbntVdLWOytJFU72BxjJ61eyC1znlv1t5S7KWP8q6KynuW06QmQBT /Dnp/wDWpJX1Y3qcjbTBtSXarBQ24nGa37p57y1E8rlkY5VSMcfSly2VyehyPlyXF0DDGrKX 24LZ/Cu2s7ObRZQJECsVycDoKTSkrvQbS6lK1vkgu3lkkJJBOen4VRmuGu5cgAjORkdOeKS7 gnfQuXZcM7GUgKnRe5+lV7GYeWyLcs78ZBo8uoJaWJ49aaIPbRA4OPmXA/SrRuClsI8tlQPm 29BTtbRjStscfqOsW9hebFDSMeSABz+Vdt4cuYLq2d7gFAoypIz+lJA3bcgvblJ4WaIK5Y4A YZyM+lNlCadHGzxqJCQMKvWmtfQFqXL65G4SeQACuAP8/WuZu7e7uY40jQoS24svUe30qZJ+ gktSxp4FpIxZmkkQZxg4z9aqqGmnTzpFVmP3RxtHvRqh3NC/tJSVcyqsKEE5PU5P41ad3vY5 3kmBTgdSelNA10MHRXd7ohFLIWz65q9OWW7UyhkYE4X0pW0KSaFupnvUYlRt5BwetVbb7RZ2 iwiXIbnywe/40NX9USmyxLp0enBWuWVmbkqpyRVG1Ly3sjKSkZXAKnr/AJxTvcd7kKLHEXw2 CuQB6k//AKqyHlRlYEYBHzcZNZpX+QX1HBI3RFR9pJAPHrWlcWCNH5aL5hYY6dff9KafNq0C 0L8+nIsKbyqrj+I/59q5w2qi4jSNxIWyST2qm0HW/QLA2qXIRmaQiTaQBwf8mtC9nhaFgpIU HB/wqV5bCSuRJOiOQH8s45we/wCFZ2pzRw2QWNC5J74546UXuDd9DjrMyNflI1G0pzkcD/Oa 0bqd5pkiY5iAwcLjH44qVC8dyoto6OzsIEUsh3uOACtcrd6hFBO2VHBz1/z9aej07Ba+x6FZ eK5Ws0jihAYjOWbFcnNvLyT3Mql8/Ko5APtRy3WoloUUZ57Z1OVQHcwx1GePx6VXKgbWdcAD KgncaTSSuF7s0bWwe6mCuwiXaSDnitNNVTToDGFBkzt3E8j/ADzSavqDWhkPfv5bRM2QRklj jBrBstOHzMEYksOdvB/zz+tTLbVXQOzVupppAiDYCFIGcD1rLnla5vWUjeEwo+tNq6v1RTel yee2M5IMmSf4RxV1l3qkSxqSo5OOv+eKUmt0xX01K2x4pmKrk4PIzyOn5VmS2Sx3DSOCAOPY /hRptu+oLawkFjHfyEGR4olAHT73NWtwtbkbCZZCQRnBx/n0oilbsKxUu99tK7SHc3T1qG3g laUO0hYEcYyMf5zTcVF3lv0G03qT3OzTyZplDMo5z6d6w4NThuWWVAFZiQG9B3qXHSy3bBtH R2kLx2plB3tgLkY5qnZG5knd97yHHGTkY+nr1ok2JMfcXkVnG9uiF5gSW2jIWq0GsqLglYmU kgHcM4ou2rlNrotCK81BvtqMqAEZDe3XmtbSbRtMs5Zcq0srEgE8j/OP5U7qPut2E1dlWCUS CeZ5EUgYBz1/+vTYdLjltXuXkBHXA7moXvyS6CRl3OnLezI0cimPgtuOPXjj60+e1lt5w7SL JEOuM8j6/wD6qr4pu/ToN3TsVbnUoooJYliYkrgt3+taHhzw3LqdsZiyxW65O5lwTn3qVFye uiJ1bFutPt5o1gaTEQGN24ccVV1y6gt4ILa3KyK5yT6f1rSy6MpWRLKEkRo0KxlV6qDj8/rX NXlnM0aM7AkE4x354pKWwloZaXEpkUsdh6EfT3rUd3dgrMYo8EgnJPtT5Gtb6D1eiNG0aZYy 8B5yADjGea09Sm+ySRwtOWnY/MFJIP41Mm0ttOhNlcwbgyqzOYxDH12sPSsEaxNJbMlvMVRi TknPJ9vaq5rK+/cNCxamS2CupUsQTl0Lbe9MvRLqLTSmUIQQFAP5VKTirJD8izZadGtkxBKe YCGwOOmOveqy2A2OqR7iGAZuo69P507tycWK+tiyistxlk4VsKAvT0rQtJoZ4zsYxkHPC53H pilsrbvuMo6hKsg2CUuu4mX5Of8APFYMyS3CeWqNt/hJzx7e3/1jV7u/bqNJ2sRaTpI0iN0K nLHAyO5z/wDX5po0oTygNGQpzhgxyAfp/npUt3V0FrHS/Zo9P0sLI4ZcEZI5UfSsWGyjupxG GRSWG5gO3Skkmk7kJ3C7itNPkCQMbhxxhB1P1/LtT7nWLm30144mMbyHaFxjkDjP+fWnZJ2G 27+RFps73MBt43eON3BMjA8+o/MVFeafHplyxEzSHaeFXAY9cZ7/AEqk77jOV/tC6w5UbWII 2multIW8gKi/vAvJJxk+mPSq0vfoO/Q5+3kNzcFg28YBUNwD34Hb60kmmzrcBzhHP8WPb/6/ Woikttuw0uporrcmiWjbx87rgZOcVT0K8/tNmd0KSKpBx0xnjn6Y4qUuV3RC0vcieLyyjBw2 WIC7uOv/AOvvXOahdm5nSBE2ZJ3fN1wf6g0782m3mU3odAPJsrNWldcuxOAc5H170JC32YGP DoxyWC8AGqcfsitpqIxG5GZC2W4IOT7mptRkuD5UEcbiWTncRk5J5/H86UfIn0JLexk06PfL IbhgMlAB1znpWaLh7+6CuG68KOMda0cVsUklqfubKoWF43RSx5ABqraOrLMFdVUc4zW5DMLw 9utPMJObhnO0nnaM8Vpana+bqqxyOC0gG4kdKrZiS0NJ7oTxpBCxCjjIPJxRKk7RhFfcB68n 86m1tx77GVb6aYbhg8bOzHOaui4kVimCMEfL1wPx+lNtMWxox7jI4ZCAO/8AerGvILaGaR7m ZVTbhc9z9KQ2fyn/APBTr4Jz6F+0Zf6na2/lWeqwLcK/lfx8qw5+gPtmvgfS/hrdSyRyNGyu QCMK3A7naRz0PPekqEqrsl6M+/yfGRjl8VJ2toW/+Gdtb8SlxZaVPcKwKkLAXIyOwGRjp+tY F1+wp46vUjuR4U1eQxk4c2L5Ykewwevet/7MX2nYqtmeHjpzep6Vo/7E3xCn00vL4O1dgI8S q+nyHaOMkcc9Bgj6dznyHxb+zjr/AIP0lNTm0W4SxkYosrxnCg9ODjH9T2pVMEoW5bOW1zOG dYWn7vPofWP7I/8AwT/174+6dLdTiTRNJhVWN1dxSBJRnjAHVsY6V9b/ABa/4JZaR8JdT8NX 02vPf6Pf3Ytry4itREYnYHaASTnJ4PHeniqMMPB03rJbvscFbiL97y0Vo92fn3/wUC/Zmsf2 YNNs7jSvtUsMk7RyySYOAyl0YBRyOGJz/sjpVH9nnW9A8Oab4K8XzQRXsUtyYr2JQXAdGIJ2 k4we49M4zivl6OYSdZRasua1zlr5hWrKUW9D+y/4VTaSdFsL2xsbW3sriBJYxbxqoKsuQcjt zWx4g8V6bZl5LnULWxtk4kmuJlQD2GTX0VSevvM+bk+7Plvxj/wUC+DHwwv5bbUfiLocl5Hw LaC7FwwPptj3Y/Gqukf8FJPh/wCLUWTTL5dQiIGZRiMHPTgnIPtipbb1toSpXbS6bl+X9rnT dXdltbWGOP7pxNuIH4YB/CvTdI+Omm6haIkkfkgEZKtnn6U46lbK56N4c+JWmSTSCCYKDypY gc/5NR2epRarqaM+1I1J5zkjnnvTb5XqG5s3HjDTNLlmaTVYLaMYBDzBBkfWvH/FX7T/AIV8 MztG2q204HP7pmcse/SpvfYEz538R/ts6PEf9HtZ541YkFiqgn0znNanw5/a0ufHPimGxh09 IreQ7WcFm2DucitaVCpVV0tOonofadre217MFtbh5kABaUIVBx1AJp11PELmOGJTJJ0JYk8U rNABR9OmeULuIXKgDqfSobQTtBcF2yH+c+nc09AsZOkrPqkUk7kpsfYm1uwrQk1mbSJpktbY Sz7R++c5CE9T74zRa+gtiHUdOeJ7Xzh5jNjdlRnoefaoZpUtUmi5U8EIo5PvT30QaIyrVDew gmMFEI++3TH9eKhuNTUXjqVM0y5VVXgD8TQr7ML6C3+o7bO1uLmMI24KiL6n/D1qLVJYHt52 WPZlSNx7gijVbCbvucv4fEa6AzMxR84RWU1Xuka68pYyWIyG4+76dat67Baw20hkurRER9iO MFuQfypPDlrCmpmBpWccEhX9OlXdEtdzob7UZJixEWI1yqqr42j6V5rrM76nqUUUcIBY43t3 NKKH1NyTTwrhzLlFAV13Yye5/PNc74fd5r2XZD5SBuGJ7Z44pXvsFrOx315d3E1z8yqoPRiO g/rVK9ZbW2UyN55L/cC8ketG2oW7CwXyPq0hWweK3EfylyCWOfTsOtZ8Al1LWpEiQhVG4ggU cr7jSuaunW27VjJOQ8rpuHGP8960Z2W9uUMsaEseo4wB6Cp32HZInsrGNI5mKt5ZHAJ6/wCT XM3mkLql+qou2JCCWbjPsB1pN2sKxreJBDaQtvQMAMYXHAHT6VzCMwslKxqFYZGM8H1zUu8r l2schcrczW5itYDIzHnnj2Ne2/Dqxm06xeMOryk5cFenWhKyfmDKniaW4tpmaaVY0JILY6fj WBo5triIHcC5XPPY4/8Ar0n3QPUvpJHJbszAOBksvY07QJBdtEixYCk4wue3/wCulK4K7JNQ vxYT+aIGYqCVBfnj+Vc3a6nc3F1JPLDtZjgD+7x1oir6Md9DqUt5Io2lYgp1OBjd6c9qp2+o CCR5RGBLt2qx/h/xoemqBEVnbPbaeJpyZJ5DliTUFpZQWyyKGIlVyx+TPX35qW3HZitY5lLG +vrxnchIlJ2qG7fTj0rr7nSI7a23SkKcA4PGefSqdrXKV0Vpi8unLJKxdD2PAFETyW6RMsKo u3OXwc81K1egmLH55vQylWJXBJOOM/8A1657xTcXU+orCj+Xb7crEhwN3qeMk1LV9vuB3Lnh C1lhcEsGIBPIxgda3LndJd75X3sxwFOaelgb6GR4v1e00hbaK1jaaUoPN24GD+PX61V8MW8d xqTO7MTsO0Ae/JpWb3KsrHdx6NJPDLKbkiMNkKOSwrG8k/OsYKbAGJPeqWqs9yEtyBtORklm kYBByzkfpSxzPJaYiQrHj5s9v6Ut9BmLa6tHb3KFkzDnhQMEiug8Taol2sRVdhbhY/7vpx3q U2/QZnwWk2hWglEiF94A6DGf5d6bd3E+oTlDL5hbKj3zxTSQdC7dWVuJIoo4AQgO44x2rFYE zuVBVA+NuOaG2yUkQtptzqrMyq0UQ7nPzf5NXtLRNNkkJlV58bSoH3f/AK/NFrepT0Wg7CM4 VgoIGTx7VZvLbfbgliQ3UdBj/wDVRblTuBy66Sk90rIdwXqzV28WlLFZKEMau7Y64479RRbl +YOK6mVeeXY2pjt5BI+R8w6j8KxLaKW7vo2lmZ2DYyx4H5Ur3A7XVrVpbcMFzgYyo6Vwl75k LqzSOSchVJ6fr7frQ3pqPY1rGNo7d1kHO3Jyf8+tY/kB71HDkRr0UjrSsK2p091o0H9jSXN1 N5cakMR+ORWP9ug1HTUWFCkZbJJGf8cUSlrZfeO+hc8OxtB5hi6K3Ck5xSTySXGoOoj89sYY +nf+lGjW4Jkmqw4jG9ltwc/Ih/WsCK3LToEk5U5LAY7Uuv6gl3NFEiv7xQZRsU8sxqlLcCO+ eONiwKY47j19qbt9kV+xQnaPT4y8hLOWzhR15rKjUqWZlO7OcY6mpfMtwsr6E1kZZiEZF257 44Nas7+RKJXyqRnGCfvetHS4NleaVr1wwYI2Dnd2/Csy4mNvMyK4YlQdyjqM+v4Gk77NWGtS CzunVgoUBs45x09a6e5XdCxVVZyQWJH50Xuw2Me9YLc7Nu5uCNpwBWZfDyNjABiwBAxnH4+t D7rYVkVYdQTTrWVli8xmJBYHGKz1dCSiYaTqQfWlGLK0R0SSzabp4RCqyucsSen+frXDXtjN dToQAp5yTzn8KJNR9BJ2O0srR7dURSXLLjcP/rVXNnuuFXGVUkqSPzNUm36dBMZd3SQ2hJ+U HAI28n8aqwRPcMhC+YwXj5eMn61LvewJl5p/LlfcNh24+lVzOqRAY3ED06mne22xTd9GUWCy qsjqGQPkA+//ANYVpRXwjsSIWUDnpztrNtb9wvp5kOxvKQqd8h68cD/PNYkEv74/LjJwBnGe eKVl8SF1ER2lkDOMN0CbhzW9ZW0guJXdAkaRlmyw4ptJj6mOuotJduUdFiHovX2qobtru8DO PKRBnGOCaTV9Vsw0bshmnMklw0ocyhQcITgZrV0TyotSeWXCuV4THAz3ou0l1/QL2Zi3ksc+ rGN0Ii3Y8znB9ff1q00oklZIQyA8bwP5DrQtXZhozCk0qbU9QEcpYQbcFmXGfwNdNaW+mwTb FYhUGN5xg05OMNhN3Q5720tQzwShSSRucDkfj0NU7m8SxttsB/ekYByCM0pNdNxS0K8Lw6ZG rSLvlYbtuM9etY1rc293ErvJ5YPq3b8+tK+thqSWjGxSO99LIyl06AgdBWQTexpNcmJiFysa mThuB/npTcVLcd0mZq29zdx7XO47s7sFQD34HWvS9T1C08PaNHFO4DYAwOc+/wDKiMlHQVzl 7Jhq+oIkY3IASfYfX6Ctm41dNNsjHaqJ5ScFnXcB+FTGUpRv1GrNmRc/Z7nbNcyCDaME5IBP pUN5fS3MMEMRaO1xzz1P0x+lUk3dMbvfTYzJrWW4nMQlwCOD/d/zjvXS/wDCORaKYpZL4NJs I29QSe/H0FNNLRivfVltoUi0gzBw+/nk45HXj/PSuDuXmumRdw2pjhR1/wA8f5zRJagmX9Gs RLcF5Yt2BnJY/WnX00RmxGwJwcDAGKE3HS+jGn1RuW9tHZRMSAoHDFTnOeccf0rEkv7Vpnm8 tmxx5ap1P1NJN7shpt3ZSe9TVSFdmto9pXBGSP8ACqT28Fu+6MpKB0A4we3tzTemqHZLcvPq h1S9QCMIkS4JAAx6/j71Xd4ng2smGHQ/T/8AXQk7czYzRRfI09Yo3LOR06YzWha3kVnpssrg MzDBO7JB5yapPXzJOeuNSeNCdoMYJwD2/wDrf4Vk2fiGR7UQKQ7MxO4KQOOMn347VLj71ykr b9RGv5LS4AkC+bkAY5GO9b+myLeQysHVWAzhe2aJR5X5BzW2M+HEKhZlEoyeSoP481osYksZ WikMdxk7ge30/wDr0Jt30Fe2py06z6lClusbSNuyDknP41Tl0xtNkVHbc4XDbX5Ge/0xmiMW h26kmiWs0NzK8Sgk/ebB+XsOB7d6010yW3keV3Zh1OTnrTvy7g48rHNbvp9ll5EQkZXjkjPH 4/X/AArKsbCXVp1VpAX5OM43dD39hUuabsnqJ2WxWunhsFlOBLKvA28k4/rV5dWAt2Zk2MSc MOc+mPb8Kbv1ZPoc1A0yTTGGPy42AAIU8j6VZi8h51c3BChSHDYXn0/nSm1or69yvI5vWdQa a4WNIv3Yb5ieTjHH5nFdvpMixacJI4ApPXviqa13Ffoc79oCkssRC5OMng/161r2lhHbbpGD l+oUrz19en4fSnP3VqNtbEmrQRRhpnQZKYAHqO+Px7Viu6zs5kk2RBcKo44/X86abuhPuRW1 q+qXSyKxiA5AUjABz07GrGvm61GUIkmQDgsCeaUld6MVl6F15JLHTAqoGKj5d3XIPXFc2L6X UIxPK+JcZ47c1V/n5jtdH7p+UJLossgkB64OcU23MFhM8kjLI2cKnvXTvoSUbWWWXXJGMYjQ jO2tG+R7u4EkRUAjb0zmjYCTS7e00y2dGkRp16qzc5rQUzT3KF1WNWGSFOf1pPV3fyGtNClq sslrfqiyAKBk7V5/OsS71mTTA8rAyFhgFsU1FNCbsTf2zLaxgGUGZv4MZ5/x59akFl5xEt4B I45wo6Cm4qOotzyr4nfCPwz8Unt49Z0WHUjAx8kzRkBAev1z6Uth8J/B/gy2MemeGdMglwFT bYoOcepGfWrjVnGPKnZFqpNR5U3bsek6DZ/YMCGKKAEcbY1Gf0qpqGnyX+plpnZ1/ujIA/Dv Ut3d2RqzW1CVLRFRo9zKoULxyT0ry67+EXhqOOJJdCtJEDGRUkhDAMTkkZ9zSjJw95OwNXMP 4l+MtE8IaVGl9fWmkWiJkie4SFVH4kA1+ZP7bH7eXwpuvgHq2g2/jPT73Vowk1hFYsbgyTq4 KruQEAnBHJH4VlUbmmlrcSlZ3Pwt/wCCgX7emkftR/CDTdO0fR7y31C0gijuZ5lRQzRkZKgH d93jJ7H1r8U9H+MXifwvolxY6fcRpbNJHIql2JRgW6MScEnP1/WvMw2CaqTVVbu68z1ed2dt b9D6xX/gqB8e9N+HFj4ctPHeoWGmWsAjtY7SOKJgq8DMijfjnuc8e4r89/id8XPHXxW1UPqf iTV9QcsAz3moSzl2POQrZBAwTjH5817bpwlq1v17HnWXM9N9jzaybVYprSWR3lIcsjsSoYhc kDaMcgZxgD6ZyPt74E6t46gnWWxtLxwznasUbFSvHccHjPA/Wm6SnJKUrW3NHBtadN0fvN+y xbePNQaMN4cuI1UqSXPlDHPdsDPBr9jvh14B8TXUUaXpgtC3LrJKXJP/AAEfyNc1apTpbavo hcqa1PTfG/hu98M6MJoL9Zbg8OhTb+XOa8Vl0b4h6+CLSDUPI2kAxAxgj/ebaMUsOpV1zSVl 3I5Ujq9A/ZT8V+LdCa81C/isJDjMc0rytJnnovH61674V/YJ006dPcapq1xPMkRykCCMH65J zXWlSpJ2XMyb9D1rwJ+zL4M0aKFm0aK9mAz5l18+T64Py/pX0Do+kaJ4Ume0srGKCQLwkMSo BnOOnSplUm1ZaLsJGhpMllo2hIzMHkYkYXnnOP5moLbT1sIjPKxaVj0B659qi7CyK2uXktxO kMEYROMlzgn3p99qR020mghRFKKoeUrnGe3pmharzC7KumvbR6ZJDFI6hCWbdx94nJrEW4mu rxxGjJb9Mt/FTWr1DY6F4U0zTI1gIlu2IXc3OB1JqK30pVee6vJtjEcsw6Gne2omcxa3XnWF 7LAF2RkhJDz07/mK4zw94UmuLiaaa6YFlJlkaQ+vX2qlJQd3uDSex3V7c6bdabawWkBmkiOP OKH5zn9eKztdhEVsVACM+AuD0pJt7ifkcR4SjLR3ETZJRjjGarapcMLSYKWRmPIGckfj9KqS uxef3lvTNIlisEffsyf4iOfzq3pZjttQI2gnbyev4Z703q9Bl37JJcXUkjKWV8/LnqO2a5Xx VNcRPbSYXGASUAFG+hNieSyks7RGK5Zz8q8ZOTwf51z1tZyC9csTu25VfQetHoVv6no11byQ XUCOgYMo5JICj6d6ybq2RDHK8YWQ56nkc9MUMlp2sxtrO4lUsMpwuPxrU1Sf+yJWIhZZNvT2 /wAmo2RSVjA8Mrea7eGWUPbxhCrMpyRnP5V09zaWlozpGHZ41Lszen4d6pOysgb013ZlQatN dWXlQxhs55btVS1iKXoaSYMV/wBs8VKjbcq6WxDq6vcm5Z1Dr0DnsO/P0rKvNUhTTIbeJRuC 8E45xjmpfZDSvvuVftAtYWUElTw20E5Ne1/DyXzNNuVSHEjqMtnp17fiaG3YGcT400qa8vIA 7liei4rR0fwgVIZ02qR97GAKScY6rcS21IrxrDTXZZpSsSnqFJJPpUGga5NceUkUEcCByRnr jHBzQuafoPYztUQ3N6EJEQVss2T83PSukaJGaVQu9Bj5qV2kHkWryFZII1gUkBctge1cTFMZ c7GUDJy3P8/zpLVi9Dcu7RYdNV/OyR2H41JoUsFrH5kqb8ZJ4zk/1p9LId+5ojxFHGziC0DD ou7H9etZXiGUm08yRGZyMHIz1qbWV2UmmZ9haNNbIzjAY8Ke1TXk4gbykUsMc7UBx+NU9/IT XmZdpNby3qtcyYkVSPLUZwf8iqQ0w6v4jZ4lIjC87+N2BStr5dxnb6db3FjayRJbqWIO4seg x6VQhtvPJKoN6qNwHQfhSSvqSnqc3rVvBbXAMqkyKvYZx3p+k3Mb60Rs2RGHlmwSx/z/AEpP V26FLRHXX9+tpYoIFzO/Zui/55rndLvY5p55Ls5WMfPIOgA9KVxLRGHdXJ167eYHZb/8soiC oA+nc8V1Omh5dKkdIt44BycUJv5jaTOP0szXmuyiKNmSMjJxmum1+eSO5jYxgAHPUZOP5cUJ 6eYPfQ5a7W41NVeWbyo9+W7fy/Cuy0WwtoNzyXBkC42gA8mhWJbuM+3iW+cIpLEH+HpWbbW0 9zNJFG58lsmTJHAFD31G7mxdXz2QgwN0apgHPB/DvWXO6XEEnlRLDOxLM59eaWq+Y2ixd31p p1nE0satIoyeck1T1G8k1O3imdDFEcBFLYLUWu7dBNWZDLcxz3CxquxBjdwa0rC3k1W8jhW5 yVOSWHC4HekvMa1I75TDEyBd4OACecnjPNUrcLAsXljczk7fpVPuPodFPpxdowzEIegLYGay b6wtTMSzCULlnY9AaTkthLXRmNfzLdDyoY2+bknceB/kVYu7by72MyIY1GDhW6896SQ27GB4 kSLVGVWld0DcorVtSRLaWYCIVbb26UlsLUj8PafdSWDuItrMTkAngdv61Xuo5450jXeSTjk1 VroTbbJXswsLB5C78/e5xVKVtsaoGAJ5Jx2qZPoUmQJKEEaJCZPmLBVxxx69K0dNjjE7Syjy gT90gkmmlb9BcvUrpdRz3vmBAWGVUY6+9Yl/cvO7MACd3JJziplLowt1K5lKXICtl+pC9v8A OKkd5765ZpmLgEZ9fyqrW0bGa0qxwoGMojyv3dvUen1rmWE93dqSoWMY2kdevP6ZqZK6YJm7 bxRR3aLGC0gJLPnI9uKt6nEYbQHOQxJJJIzRF8wldFaztLZo3dSyuR3NYepzIbeR2OZBwFQZ we1DslYFpozk44JL+ElmEQ34AOMkfWuoOnmyCpCVkYYBYnmoi38JTf3Cvcy3M6okRlkIwBnH 61halDKl5iRWjlzgDPT34qrfMFY7vwyy2ieYWEfP8XPt/SsfV7xp70hSpBYjjjI5pSkrfkJb 2MieLfAkb4xngg4JPXrUgjeGZY45G+UYOSOPwoS6sTsWUQzwsQuwZwuT1z3xU9zCBGoZdoAw Wzn9BRe6KdmVTbiYxxrwuBz+FaNzoUUNqvksAwzkZ+8aScVqJ2RkrAbGJ8OC4GdpbpXKQytP OQw8zIzuGRgj+vP6UlZobWhraehS880lidvy89T3zWPNdy+XNEGEkkrYkJHAHr+FJK7tt5k3 ZdhSCKPy0YO+eRGOn5+9UpkSXIaTbDgE5HPT/GhrmiF7E62qtdiOKXI46DpU7WyafFM0snne pB6mhO2jKe5zmmXjalM77W8pT9315/8ArV08M4tpXm/1ciN0x/X/AD0ppc3vEtWehlarqk91 dqHjKBsAe2TzVa2g8vBaTdzkgCpu1uVoX28uaMCSEhR0HXNQ36faIkES4HqDx+dLTfqKW+hW 1BlghYs2CASd3O38vqaZZaXZWVkZZbpWLNznjP4UNrRAu5XwJ4Z5UYIjHCLjsKz5/tNtDFEz gsehDY203ZyG+y3NCKxJigDTsH6gAY6+4+tTX3h22jkjkaQStuzlzn0zyaHa9iWiHTR9nmmS 2OSRkkLg4qpaW8s06Esqx8d8ZB6U0kk7lXuR+IpYbiE7UYRx8ezH19//AK1Z6uwAO1vLCcj3 /GlfTXqCaRatFkk1JW4RWA2gj735f596inuCl5cSXGC6qBtHzDOfQ/j+VJRVu4JEs8kF0Y2Z iPl24ORn1PP0rGv7gxyO2GijU4JVc8dx/wDqqk3fUmxLp0klpGYgcK453DHr+XWklj8ti6Ph w2Qcjjrzx0/GpTcZbaD+Whs2FtcXNpJIwLLnDAkcn69KrXXzMY0G4qckngDP+e1NQdrPvoxp N+hdTRlyGmk8vADct1Has+YpbO8aKgQjHuR65qrNaPcbV0aENwsdu5SIeX91CFzmubDLPe7C p4wSTx+v4UJNRd9+iM4p9dzorhY4UOxgzscAB+3+FYN1exjckYbA4JOQSfr09anYpK2+5mXz b9oIET4JxgAgE8HP1z+VXbW2SyCMzbjtIOByT/n096HPZPcL9yays0u5SZSwUjCYHT0+nNVX 0E6XBvjcKG4Khu3POOp7cUKbWlwsakE8AhRdjNO2CTggZ71Fq+sGzuFhhEbhh821cnNDTfl+ omuY5O6vZbi8JimEe04AORzWlPp17JCmT5rnjkZx+FEXdhEo2yXcDFVmeAEZ245Jz2qnHBdG 4laeRsk5JLdh7elCimrX0KVnuHmGe4Z5WOcd0LH6/p2FV4bVrm4DzkA4+meenB4NOEUtSXdE aQJbSNGE8srwFY9BnP8AP+lasti/kgsSCAAoJycc5/CnLa5Td1oULlZHfYjlAewXOT+v6VUl eVrVSEjDN324OeO1S4dtGxem5k2ejR3mplricvnGMcYPr+npXearNFo9jHCiBWB5LA8g/wA+ tTFN6hZ2Krz6c8CkzAOMfIp5zyfesi/vlkdVjBd+oxkbTVv3o8r+8mWun3FGSCeURyTNtA4P PJNbsWiQzGMpcR7UcEgEjcewz0xTlNQsinpoQ6jptusUrxssrcKY8cd+Melc8ls/mlYWAUc4 Zf5A9aG+y0JSvuTzmPT7CaadiqorEnA6DkmsbzpJYXJYAYOAwHyjn+dEddOg4o/e77Eos1Bd c4wOnNZ9xFbxwoTKowOpOMCupN9CWkYlzEv2gypLmMjH3q6SKEm0V1XaRyMVbeiElqcF4ZED 6/fh2ZzuPzAZGcdK9GhhSJEkWQt7ev4UptjjYo61cwxYIjIl685OT/kVg6gJNUkixGiQxnO1 QcsfxoiDNW3txOC7BYz2UnB/WtOcyRTFYzlQOSBnH40m7uzBI5K51NptSDMjMAeWz3+lWLoS 6hdJKsYSIcAHuPWq5bCvcsi+FtIsapuk3dSMYHepr+/WyZZnTaRySW6UmhngPj74twaCs/kl TIfmMzgHHvivxZ/a2/bx8RSifS9H1OaMhW3eXIV9QQCMYPvTjHmko/f5EtOWiPxR+KGt6r47 uGkvbi6upGTJa4kZjnnJ5Jx1H5CvnvSfhhd3kkcaQtcTbQEYgfNjr2z6c+nat3SS0Wxqora2 h7d4f+A2u6hYGGPQJyJuN/2M8Hp949Me5B/ryF1+xrrMmHvntLIxknLXaybvQlFLEY+meOOK 45zUJvr2OiE4xWhWm/Y50GCcjUfEP2zcf9Za2+1VxyRuJXHueOM85rqdO+CHw18KSxyXarcC EgK19dqFLEHIwAo5A9T061PtmlZfMjnvqgufi38KPAsSw2/9mpLEDiOztvOx82AR97PVemRX 1n+yB430T9oP4y6Z4X0+VNMTUHVY7i4AChgD8u0cnOR6VlRU5z/eXtfVkOb3P6FYvgV4P+EO ko3iLxtaRSK2399PFAGPqS5JNbWnfHr4IeFbSZ7/AOJnh5mh6+Zr8TYwP7oauiU6XN7q9DJ1 Lux0dn+2/wDAFtFla3+JfhWIHG3y9RhBJ7civZNH/aZ+Hfi6zWTR/E+n64QgytleRsAcdznA z1pubEncnT4+eEfCeniG98R6XYyGLdmXUIgFHt81fPPjr/gpV8KPBLyJL4rg1CQJjZYQu4cj tv8AuZPu2KHK4r9j5w0L/gr74XuNWEVj4YvbyLfhWMqLnv2yM8jgnNfq54J1e08T6PBq0sqw C6jEqiTgqD2/CtFCahzv7irNfEXrBLRJZXMgLCXMceCeP8OtbF1etdagslxKiEKWWLA4HX+l LV7iuczqemG5uftDuGdjyf7o9KkOnubqG2AxGQGZf5UJiLnm29tdXWnvbGWUgOz46A9Kybq+ SCeKO2iadc7EbGM4prcdzoLu2llgSNxtdmBLA9BWLNYXGuX7KJ2NopwFB6ketCsnfsJ+Zwus 6IbydbJJmCxHc0aE4Oema3ta8M2ukaXFBNdmGWQAiPdklR7f41fPp5sEi20CWvh94bTG/Kgg cHAPPNZ9xHDCymQYUYzz364pXe/UW5xumaysfiO4hiPlBmxgdj9a6K5sFi1SZGiQxEfM79j3 x7//AFqLMVzl5NStdVvUR5gY4yBtIyOOvFWrKJJdTe4kk2QZwkWD8w+n1z+daWaWo2u2x2Gq mZkZ1JjhXIChcYHavO/EtlanS4c3CmQuCEY++azTtqCJJ7S4vrq3VJd0mwD7w4ArnpLRrDVo wbgDzGxkYO6rU7aA77ndzX0kPkSzkTbRhVzgdf1qO7uEub2JZASqLjKMcL7e9HLf0FF2MrT4 pbi586MEKgI3uvfOevtWtrQjuofMldim4KRzyRwf1oaSshvXQbaahNpu5X/dQk5IAAx7Vt3N 8Et3uBGHeRNoUE5Oeh9h0qXsNWMfSriVZR5kflqOwOcGoLiSOBJx8omfIHfmk0+gJp7mdrGk TP4ZeWY4ztICDBzWR4etDqdxJdzITbRrvwVxg59P89aVlfzGr2uX9Z1f7JpnlQooQZPr1rtP AV016SrP5cfA+X/PFC2dwasO1mNP7TJiYuAv3yeBz60+C6uS42Su8ak/eJIzyOpqGg6HM2uk PquuObiQeSnz7OOo9662K4NtvSNI0AfCkj9fyqpbWQb+RkzWhvLmNZG3mSU7nbJwO39Kr/2n BeXUy2YdrZMAy7cbj34qb30QxX1OSaExRxsytjAU+3Sue02QR2M0MsbiXcSPl65PAos/mwuk y7Jph8pGWbDFgPmXGOa2Y4pU8qBTGq7sFs54xSt36FHL67dMmoRWkYZW29cdK3TpjxaL9omu WBTGMnqaNGtehLKyhruBVe52RZzxxu/GptUCW1mBE5xuwdoyWpJJj2Qnh+ysobpQqHew78kk 1FOsw1G7MBKj7nC5A/Gh6uwGf4YmkbU1eSYhf5jHT/PrW1cXBUlWZkj3ZYLwTzSaS0E1Y4m9 ea9kk3fIgPT1H9aZbqP7WhUELGFoTb/zHd2Ow1KCFrZGjmErFcYU559K520015LaSFndh1ZT Rypsa21I2hFk5DgqMcA46fTNdHpgkOmuZGwDggr+nH40Xs7iemxXg1KGxSMRACaSTBkyKt66 4WBzCS7k8uQBx9KTuwd3ucfmWNYw5YpkZXrmumd8XQiQ7FK89uPrSWi2G9diG1iD3BWOV0Xk lgOOvvTpoRaSzRxAgEc/j1qmk0L1G6k5tbJXdsOAAOO1UI3UxAFuRztzRstQeiFijQ3SmX5o 8gnPPTtXXaxrUYlCrCrseWbHAyfSpXcNDhJL4zXMqRRfM3AJJ5P+f51raJp8wctH8ofOQDih Rb1Y7F+/ikgjZSoG1s5GeT2rMsYbuO48wqoTPB98+9DSegr2NS8uFupgdxcDk89P85rhNWub m+ligRBHBnnA5P40mreo09Dp9LtyhAAbKrk89vWo5NVX7SSwaZ8ZOBjGKG+wr6FfTtOfUrlY i6IxJO0kZrevoJkT7PAwL9WJ6cH3pxtJbjvcpafc3L27Ism1Q2DjHFZvkMNWTdKGA5JHP+TS 20QrFu+mSJWG4Ox4HPWs+Kyj5eUjIXpn/PvRuNDv7QWK3R0ttnHAPVutWbyKWzt3MyJkjIC8 fyoWj/IG2jK021SaGVmTbIR0BxXNpHDawyBHYMW3bMZ5z6/jSfnqPcbbyxvfEsCSCMnOf1rZ i1DzZpikICjuTSTa0YjQ1WJEt1ZwASOF9fesJtOW2sftDPgs4CoDy/rTbV9Ck+iLFjp8ctyo DbABn73AP+P+NW9UaK71NFMrmIJgKo7/AOcUlFW2IvZ3JJnt7RTFEjK4/wBZu5wa4S/2ywuw kZVHAHrTm+5T11K+jQWsVsryEvJnAOc4JrWkvi9yFjBaMfxADk+v0qFoDtuXLe4kglfYcEAn OPrXF3jvqeqMgdw2Rudj0o5VESPVLQQQwDaw8tVGGcHk/wCc9a4vUb6KC/dURpS2BkHG3/61 DjdW6DKhd5ZS6L8i4GGyMe/6VFACkjEnJJ6E9TSaUQNS5NwbaMKu1SwOQ3XpUN9eut4sRO4+ 2OfanqtwRKszBWYjagHJXqfYe9SapdxRWrNJvjQ8gZ5NLpYErI5O4vmkid4V2llP3l5B7VV0 3bY2BLgl+rHHXrn8ahWUbvoO9jX0wRiFmnk2KGB+Udfb9azZFVpGRCyx7sksetNJWBm5HCLa AuFwGGDXNiBLiZlmICKMYHcf5zTvZISVjoP7attNidIo97Bcs39KpLpsmtBCVwrEdT25PShN PfUqzJrSxGkuVTDvuxkEAn/PrVcOxtZZnG1QxwWHTt/T9an4dthJnP3ttcSBCoAUkHGetalr pc1nb+Y7lywAGTnI9f8A61G6v1ErsknvrezgCksxJ+fvjHbNKjLM4VZAyDkj603v6FbvXcpa jbo7SsADkADIqDT9Psbol3GXTkll60m92xalny/tUb7YSVUHBySNtZFzOtlcRIV/fH5sYOMH NKUZNJoOpfad5rhI3hDMx+ZgRwKNZuk3AhQqoMLn1705JtWEtdWZVvMLeMgHfIw+b3Hfke3v WpLrNjJphSCDa/R3IwPekm09N7BfUxZb+TUriKA23l24wQCOO2OK6O5ZSwhiRW24yfSrUreo LQjEhv8AUAGIWIAgAe3tVNUt5le3O0hnyzE9T7fnUxi2rsb0J9QSCJ2jjQORlvm478fzrh7j VXuL0RGFSVOSDwOnH1FS229GJO3oayXct/KzriMBQuVHaltoIogBJKQmQeMfgP1oTd7IE7nQ T66kOjPDjG9ht9sH/wCt+tVIbdvs/n71BwfvcY/ziri3pfcaa6i/K8jT3JjcZxhT0/risK+W 3W/VEkBcLye30/Ksm73Fvr0EuNRRNLdyv7hWIwM8n61U05XvzI4At16ZyeQP681aule+oPQ0 79DZWREa7yQQGyev0rnRZyQtud9xLAlSOQTTk2tATsGoal5CCKVVJzksccD9P0pyOZkPlDco A6np/nmkouXvbiTuQ3F26ykIADj5gnTn+nBrNkspLm8jZ03HII5/Crsm/wBSvJHVahIERIUQ l87icHj2zXEvF9tuAFkO75gzsxHHXHHT60KLk7/cCf8AwCvaJb3V2m6QknG4Lznn1rb1dR5r NHcskhzsVeB69fTkflUSk76klCzkmYozqxkXvjOf8irdzDJcOyl9yt8yLj0/P0FNK3upXC93 ZEUsRnnKCXbGwADFcn6e31rPeJbdiVkMgIAGOf1/DvRJXHLQf5bKrtIGUsoBcAnHerd9q8jQ PbMu+5IxycAH1z6UmrRV+mwRasc/bafJeMCHw5JPORj8Dj/P51bgtZrbeRMrIjZ5bBb/AOv0 qtHdrcNCxaQrakytKrSuw+XIyx9f5Vn6nfvPqQyu4Fcgg52+v49ayjJz0KtbcdpFvbfbGkdy zdTn+Gpzfx7JWjcBmY42jANU+aWj6kXsygI5HYs8iguM9PT6H8arvbSBCoZxGDkMvTjvz9PS rirrValPzNdbd2gyjgtyztu4x/nPWsNrcm/cpIIir7SB2P0/Kneza6IlLXyKd1I14jNLKG28 bUIGTnJqmlu91bAsQ8RGQCmDRdt2X3lH72wyi6jBeMIQM5U9azb6IXVuFVRjOa7Fo7GTKd/A n9nIwYKyEEjdzjvx+ddA8UV7aBRMGG3J2nsBQ2NWOb0hUtLp47dPMU8kgV23npDF5caP5wwS dvApS1BFSdHncO0fmADlmGKybmW4IIt1VDjkkZxQrA9Cpp0J8wLMwZ3GcZHPrXQeVJ9nSNX8 sFTuGaJAkc/HYSOTsXCocEjvVrVLqWwVI0VmlYZGFz+n4U730DY4+68RPBqZZQTFGMNvHLN/ hiuA8YX2r64r/Z7WWSAHASJGbP5VpGC3bsQ23oj4r+IXwN8d/FUSWlnAumwNwZbqURkA+3Wv LtG/4JP2tzOZtd8SqSxDOtupY9MH5jj61U69OhdrV9C4JR1O01H9hv4F/CnRnuNf1mCZ4wct f6kkQPPoCDXyN4+/bW+BvwJiNj4XktpLsMwD6RaCUEj/AKa4x29fcV5lXG1MReMdur7GrlfY /KL42f8ABRMeLrq7Np4bv8sSElvroBXwRgAAkc5A5Ht64/PXxf8AtZeNPEEji3Ntp9sQolEU e75iSMAk9CO4680lTt+7k38iGkteh89658Rdf8TQO51e7nGDsWJ9oGfoMEjBzkelcz4bildX iup57klf3rlwAgAyxHvyO3SqnGEXGabXl3HZN+XQ888T40YT7ZhBGkhERWTOzAUkY+uByPp3 x3vw4+Ld14evIZtPufs8ibir7xG0ZUgY+UgqCT/MA8VWHknuC133Oc8V6/f+ISJNUvxeA/Mr tdi4LHH3gw5HT8MnnPXm5L67VY2S4IWQEjY4xuAGRyc+nHPeuy/J7rWiIjFL3up3uj6PPfLI Y/NlQHMZVuWI9dpztwRk9OK+yfh34Smt4Fnlm8uLYCfNYkKuc9PbGPaqjUlODTWi2KaXRHom oa7r5vUtrDSpXCSCPLlVAyPXOT+H+Ndfo3g/UVuba41m/ht16yQRRbskD+8enf8ApisZSj9r Z9BuPLtqfYHwc0SLVvEdvaWEcct3czJHDGTkyN2PHsP0HSv6tPgb4an8OfC3QrHUI3F9Da7Z lYABCSTt/AGuhaUb9b6Ilu+569cwpZ3HnscwlcALjr9au6ZoOyKNmALFeTjrWfNbcm1zOvLL y1lfGFVupJ9altLhLWNZgGOTjjnmluG2pg+JUuZL1o9PBaa4IWWU9QuegrTi8Kz6Xp8cMkrB VOTjqD6U7qMfMNWW0tAbSRvOIfIB5/MU2eM6TD5iuRkYGD1pJ3C1znLeKaS6uEc7WkGGIXnF V5ra0S6ik8vaDkM7HJJ+pq9thLzNRfsNrcAyNmQKcr2AqrcRwXcAfy/LjD8MWPPvRr1B9kYs NjbSauFSLEseGdx0PPt/WreqCK7+0zPNCibeIy+SSOpxnNDbYJJmbpGk2cW15o/3Rj3MUXqc 1seJ9Z0/T9dtbCK1YB1DvIBnPoAKcpNvQRLqYmi0aWWSCWONmBjjAGX9D/jXE3dg99pEszhk ES7jI/HPpjv3paWbDdmBpADxSTSTeXtHGODjtWDboIr9J2lJYMQoY4x+daaPoTfoemWtidTt 4mjBlYEjPX8BV+fTbjTo5JJIlJYfKGOBmpbS02Gl1RjG+OlWrw3EnzOdwSIZyx7VBqUKpptq 805WTkmPgYY9qV1q9x7uxigySTI0kjP+8JAJzg9e/wBBXXahcC00czOoMmMIMdaGrK42Y2k6 hNeZDqoYZLFeMU23t4Ir1zM3mkE/KOSaNtgu+hV1nUGayMckflKeFwCCPfmstL6+1O2NpbtG tuoAIUffI9T9ai7b1+Y29LEuoRG4je3WP5AwzkZyP/14ru/C2qQSyPCchlxH7E/jRa1uo73R s+IbN7eOQIy7WxgLzXKySSW21FbBc4VVpJp6MHpqVxYnTWzK376TOSDmora1iku2eeUhFIOD xii9npsG9zU1O9tdOwsUjFGk++xzgegH5VHZanbyFkiB2+XlSw25qXcF2HpOFZXZdnPP+TUd hftpd4ZTbeazNlAwwO/Pv1p2a6g2luad+VuWVsBG+8d1Zk9ygs2Cookbjn/PSpbsNfiWdL0y KbddX3l+Zjam3/CpfEMMdxpzxrOofdwm4AL6fjRfXUXkzi47ZntERJNrh8FgM81c1GaVYY3l wFBKgqOtCSd9fkCdizaN5ToQA7E5HQfhWJdXV1J56q/lo/RRjjOeKm12Va5DoFoY71A8hLDg rn+tdFc2U88zruDLnIP8qrpqLVnJ3iy20uURnPQY9aq2kVxJqiRmH5wCCCOtEUm7D2R3N/DH NDGhjCvgFjj6dqvWFtp1p9oBkLuFyp3ngkflQ2JnHiaGfWkChURcnBb734V2SReXpMu+RAxx hQOePp1pXHexj6jGun3UMUjJgDOQRz61BrDMlmioVDPk5J6D60n5C33MBZTBaiRZBkODk/Wu pgljllDuu93UY46UN20CxJbLJcSeWFUIc5+lZl7PCsxV/llHIXHHA4/pVNu1hohv4pbiyErj EY9SBz9KxrCFZQREuWJIyRkcVEk1qB0+gaC88zO7oCSTwe2OavX8ojeVtgcbcIB2NNNNCem5 z2isLeWZ/L86TGAD2Na1lZyzvH5gZAxLYXt2pWUthkt6scdyYmfGfmJz2rMWRrtisb7o9+B9 PSkwb0Oh1Gyjhg8tIvLyAcnv/nFcdqVsz3cKCTEmwALnoP8AGqm09xLc2W0pdG095XXGF6+v 4VzWm3huGj3ARICcsuCWz3+lLR7B1L7WsNsIxFOXmZizMF6DtWhdQS2lo6iQuSSS2efpStoP QpadYtNbqXyUXnqOT3NPj0gx3pklfYpOQD29/wBaFZO4thsnh6O7uxOxWOIMDtLEFvSq1/My zbwVSJRhQOTVcyHexV8tmzJIzEA5XPT/AD1rTgt2SxmnlYnOTg9TUJag3qZP9miQNLJJsG0k KpzWEtmshXoCDxnn/PelJW2C10LFp5hv5FMZQjkkr0/Cuhu1gs9NLs5QbguWHLH6U9emo1uY V9Ks7KCSqj7xY9vTiqVzDDdSI/mbShwpPapei1+Ql17nUaFpcTl5vOLHGASp5P1NVbuINdK3 mqyJ94k85/Gnf7gv3Mq9nW5uHKRyTSuM5BJ3H/I61y/iK0ntIzHPC0Z5bG3H86lpvVjtcXTp rKKz3TBpCudqgdTRAhvJDJGfLRjyOBg9eaiN1oxmrJbTi3YoVAxjk81xdxeSwzJbhwzk5JA6 +vSlN2WjC+juejWixppyhmC7VHUnP61j+bbwCSWZSqk4Tgfnk1pq1ZCSvsZN/r8M11FDboQi gu7KCQfb+VWpzmRZHUOCMIq9QP8AOKm0r3e3YGDX1zcQktGFiDcfLjaO9Qs8TXZQD5jzljnd 3qlpv1HoloVb6cQzwuTtz17YqvqOqvI2xomlOPvZ6A5/PpTcUtEFr7k8jRPbszAAnHUVRjtF uo2+bYmQV7VG68+pLZfXTYYY3VHYsozuIyAazbS3WFJGJ812Yj5uOPxp25tUNIuajC89jtJJ Y8+lc9coYVEMJLnu2elDioq7Kb+86GzsbNNOO6Itck5Lg9Pzpkl0yW+4HA+7kNjB/wA9qltL RiVrGTYSLIGzIDnPR+1W76BriGOMACIKe/Uk5oTS3JWi02KMiyiUYLSxjgAf/Xq3IZ7yZSMA Bskl8AD0/Snpe5SbtdEN5bxSPGqMTKWyQOg6+v1qwpCiTDHG7jI60udW5u24aP1KF3tiwijL 7gCDx7f5+tZ93LJBaq0YV1ZcZzgkmhpvUblcSa7vI9LhgD7AyhnwOh+varNhpzLhpDucYAbr j8qFGSXoJJskaC4lvneGHaiAjdyfqayb2FYtwD7pG53/AHQSevX+dJ6O4PQp6dpT3iRKzsrO c78FsZPsPpVvWdCeELEzq6ggg5wTjrVRl3+QarcsWt7HbeXGpAbdnhc5A9/rUZ1KO1gnmMeZ yTtPHf8AlURlZ36om+ljN0WSYSSyg5AHO4k5/PNamjyrIVEsQIznIPT/ADzVpXd+gJ20JdbP 2lZAiBBjHA/z+lcd9nW1HzfP8+CAP8+tTLd/gDepsLK32ZgAAnJIqvaW6x/M+BgAjf8Az/z6 0pJ6TtZiW1yXVcyqVjxGgXJyPvGrEt7ultxLII4VPLA8Z/CtLq9+ttim0x1zqo0/T5ppFTap JRieo7GuM0Gzl1GOa6D5lY5yxH4ce1RHWQkrO5pX83l2scciBk3ElV49xz/n9a09LZbqNXVP KToEzzmm7x36hvuTa/BcabFFJGhUlt3B6gdRj8RWVOTcymJFb5iCXAAIPX/OabjZ3/Au2lyl 9hW4ljQtuCnLFup/D/GrNxcQWhZFjDYUA/ORxz79+aldbbk3sVlgmtESZAFZ+QrA8AD156cd +9WNPdproGQg4GflPT8aG31Babi6jfNeSNEAYhnaoUZPvXPSqsW5RggjGT1J71TvbsNPqQaZ YJsuJJAxOD9AcVHdBHkXKsshJ5A79MfyNZtttP8AEndmrY5tUIaQ5wAOeQOautKrMWZi+Oq5 wB6nNOOuoJ9DC1KK3dgocsAxLHdnpjAx2xg/nVWWeYzsIwCu3Cg8Ac8ineSbS3G1d2LCPFIF DOGAHJPG0n6+1Q3cMDNuhYgjAPOD/wDrpJ3unr2C19EFs88isBImxeWcnG4kcD6d8Vi6tNPY xBlDKWyVCgsPx7enWm02klpcFpoYqLNduZ7ptm0fKV5AH1HtWtLai8kBidJIjx19/wCXBqFT afM2OV76l+10lrMuFZjt64Urjjjr361UuYPmVWZjhsqoXp0xz9RWkfyJas9die3iPneUoBOc AAfdHv8AjXRQwJcqYZDtOMgkD/63qKfNZ3XzBnM6xqyWqTRoxL4KnacZH8qpaPoU1xZMznCY 5c9elEmo3KWnoXZdPj8xpLmXyUBO1QOCO/4UgeKZxbgMiA5DE8Hv+fFCkrXexL12P3Yt5rW3 swzkhdvA21BYeTNbkhSq9iD2rrd9WLQ5yCBXmuBIAqs2Rz14q3pUsskUghiAXJG7Pb6VT1Wp PoZ+pLcWLNKJCSCOOxH0rvdPu3mgWQxh2fGfyqZJNXKW5xnifxZeW5KQWoRN2Nz96y7O/wD7 TuA0i7JMBVXd3qoxsrkt3Zy+v+M9H8F35l1LU44TsI2yyYwOOK4J/wBofw9c3UotXkvjj7yq cDPoeP0zWkacp6rYhzXzEtfi2dTvYooY/s8QzyTzk9/517doFxp11bmW4v8AdMeoWblvwHNV VpOnFPdsIy5nqS2V/pmlairLYPLI43B3TJI7feNdPf8AjuGw0ya4lSOygjBLSXEoVVA7k9P1 rnknvJmidj8q/jd/wUg+Gnw7vZQ/iebWb+MsBbaEgcMQOhkJ2/rmvw7/AGnv27tX/aJuJptA bU/D1rZlUEQ1eRjcqxOWbpjGB04w3U5yIlTUtZLQzTbemx8E2pvfFbM13P8AbTsMjSTyljk9 BjPXOK4/UdGt7Zoz5Yibd/eJHXj1xQ9rfZ7GraVzivFGjLeQRIYWLMSVUuBwOe/oM8V4Fqtk /wDahMYEUqsqq5baEGeT+nespLm0+HzKTS0ZxMlgHuyvnqoldmIG07ckHjIPT1/Xirfh7wW+ tXyYOxEB3bo9h4JwS3Hv1JzxWbUJ6Xu1+A4qOzOa8WpZWEkzLc+c0snmDCYUDB53YOAAT1GK 8Ju9VSy1aZZZp5RM21nUljtAzgdAcd8YHI55qlGLt2Q7J/oel6D8PRcwpc2rx3FmoUxIWIdu MEle4BA5HHb6+teFPhBf/wBprGllGIChE5MKMRIDkkNjg8Nz147VvVtNJJ6DSVz67+HH7Pkq yJLPFCiq4J835iRxj5fXH+etfWun/Cy28PaVLcXTrPICSiQqBj6568Hrk05ziklHZbk2UXdn lN/4lOkbkjYRLsI3SPnHOSfQDivEvEnxz0XwjMILi9jm1EsD5KjcxPQdOxwcdutc8ffmra36 hzp+Vz9+/wDgkV8EdE+Ovh8ePtZupY5rLUtlpZxptUMqq4Ynk9W7Gv6SlndxKbS2EwWMBWbI BavUxL5WqS2j17mVrN9znrazlvr0iZvMEZBULnGT2rWvtQWO6EIkYFPvFFPXuM1zN30BlMJJ b6bM083lx8sIyM4Hc1m6YDdRrI/ygNlQ5GMZpoDV8STTWrWsdlg3DSLll/hXv/SqniC5ltYg 8zltrZA6ZJoST9Qb1LdhM81s5dAp6gAdKw/EU1pa2StPJsAICgDkn2FNb2Dpdk0lwII0ngQq WG0GSuR1K0mBikknYnOV3DFOyT8xfkdJ5ZFpLJwzsBj3q/Lp8kViu0KGIBPI9OaQ7Hl2sXtw 3ihLZG2QlAW4+9z+taUliov2CoFUjB4xn8KpaE3uYmoXzLdypBLuKrhQP4TS69IIb/Tr+acI N4VueeOn8qe6FbU6DxBrNz4kvred0aDT4l4LdXPbp0Fcxqc/2nRZkjdo0EmQCODkChRSX5jb uZ3h1GswsjkySOuMAD5Rg4/n1pbqKG0vkln6EY55P5CraTenTYW252a37X1kjWaNBHG+A3TP HX+dchqSXmrau0k95JLCmNq7+DU2V9dWH5GFcQLcX4jRXPyEsQTzzWr4p09Et7VY5GV1PzZH aquNKz0Me9ZomBicM3mIc4yB04xzxXo2rXjpEkZhhYyRgjd+VE0rCtYwrO2lePfJIkKNlAB3 x6VRurdoLxvKBlcDI4rPdFbMfqVoRZQvIcs3POBuHeucisLue/3oyRopIKK2ME45paN2vp1K 3N/xVczaDoyiZmEsjbUA6n1P8qXwJCdVVQkhWFeZCBksfSiKTba2EzvPG8LWEStHLvBxjHfn iuYs7xY74OsZlkyBy3GaS13C9kZct3cXWpmco6YGFyp4NW59OVNLF1LPGokPMYHI9+aSSjqt QTd7Euo2P9oS2YERQYHI4Cgjr+gqzJiO5QKoZjkDHHA6mjdsfQNRme7jMCIIycDJOeO/FT31 xcyyhFcCNR6eg4/lSasEnpdCC6DaKHYYlYkbgDgf5zVTTSEZjIoZ3bK+3tSloh+hp6xPFFDC SWCA4HzYrm9RaOa1YhWBzljnqaXwiew3R40GiXDmTDgBY89zVmwsnuJYmYtKq8/Mf6UPV3C5 auZYhIAq/MOARxn0/KuX1C4WG6RNm07Ogbqc+/tSbaGiTw3btJqqsjiNCSTnncfSuouLZrNg 7z+Y5ydvTj/IptW8xt22OXvry4a7YInypyMDGPxp2jak9vrERkbezdcnOB9fyotyis7nTarO Z50G1fmU4B71z1rayz7gVCqRjPTP40rjeoXFgthK6owLYJPPSrVtdRPZyAsSccMvb/69D1eg r2VjmFuDf67CUjBSLC5JySO/6V3ur2q2+95pEhQx8Rj5utG25Ry4sraK2R5nO9SOCPuj05ra tJQt6NiB8LySfypXZNupr2xke5LpJ5UacOW6Z9K5XU1t01CSVnD9+KbWvmG+jHtp/wBtj8+S YhWbAXPp/hk1SguI8FVYBN23ZuPBNDt8ir3Nm3Ekrko43NzgHoKqX8BvZRAWJPfb2H1pNCbv uaOk/YdCi3XDmNBwo25z+Iq0dflnhEkUXmFztTacEDPp6cUtw2YxdB/tOV3klEY6FOhP41Vu LOVtSt4YNxTJwAM47Z49apu+iDc29WsZrYosi5fOee1cFM8kmpsIYyX2/fzyKlpPR7CTSHeV LdQQh5XZR1DV1GiadZwK8kpwiDsMknrj9alLlemwXvoUb++i3ExWwjZzxuOScVKZpJtNd5VS GPOAepNV5giS1ktrG3AWQsRgfMcfpXKnUnm1hiBhQSQCM59eKTVwasLetFF5lxc7lYKBEnUf l61Cb+S+jEixNGNuEG3p/wDXoV+oRd9BLbTnkwzvhm4AY/d5rdvrkW9r5McyyMenGcYxRfug u2zmnd4o33oQduTXN+cqxrJuxljswRz+NRJtpoq+lic3zXGsYVXMZUEsx+8a07iZneNGH7tW 3YPUnFOMWkJK71MfUtQke+WNE3Mwyf8AGoBaOFLuGKD07+1Di3uNuxsWGoXlrYt5gMajAjQL 0H+e9VYLqWSYGRgqD+EqDuIFPbRg7GlE0kcBdAiHrnvXn2rzx3DMHl+fJySM5GahtNlNX2YS 3EccEKrFuXHzNjAIzzVW11ZLyY+QjsB95sHgfj14ocWnoxJX0Nud5GtJVgLyFvlO3sM1kaNa x2Gp7lJ8wjnPaplH/giStuemtpsP9nqzyhNzYye39K53UbdDdiJH8wDHPrVNW2FbXQraha/Z p1EQAfbhUPU/hTvIk09cTABsAbc5qk9NSrMZHNNdwoc7Ylb8/wDPNQyKy3ACRl92eewHep3V 5ddibXZlSwNNMBIQCpyrde9asixxwlR8oLYOec5JpNtbbovczdTtP3igyKyjlqfFNi3YqVVA n3vQf40mm7P7xNpf5izWpawDu+Q/IPcZ9qsfaobaGKIpvbgFgOp65/lVOyBvXQS5VZoZPOlE KJ8wBPX2/WsL/R03spygwTgH/P40mnq2DdhxX7TYIdxGctj8fX8qr6jcSS2sURhwvd1POe9S /dWot9xtjZLaWO9Uwqjbj1/+vSXF6TCQQwUZz6fWhRsrXBpL0Kqaj5YZWQlR/Ft9/WtTTTFe 7VYi2iVSTx940RTjr06lXu9A+xNLdAxrl1XA+Yce9MJlV4omiwNv3gODgfzoUUtU9xOxl6hf pZ4CurynAXgc4z/U09YbqS2AeBHUgHgdOn+NOULK/wCAXsTs7W5L3DkDIAUn05ArLu9QlnhT Z+7dTgOnrUQhZ3f3AuxLa3V6ttKkt0eRkEoPmOTjpWPPdtJG0bE787SVGOe9F7O/QOhux3Mr NAsWY1UDJPG71rH1O+lM+6YlwG6jsPXj+dNp3DU0tNtnu5HuD8vJCqg61nalAIWEQTLbst34 Pf27UON426oG1sad1eQ2dnIIYcocAyEdCamsoljIlaIRhV4yfvURvy3YtHuc9e3f2pnOMLuA JU4PTrVh7SPyQInaSUYyc8E0oySei0C+uhUmt5I7TJBYNg4B+8akXTSjCVlA4+6c5HXn371o 210AptHc3V0HZW2bSMKeorPubfyZSu3auCDuHqP/AK+azs46vcWxz934eTUJUgaZog4BaMP0 GOv6iu9utJTwzYQqshUcA4HUent3p86+ZS7FK5lguSkcRxJjGJhtAHX29qi0iKayi3yMrAcv jgZFEpdCW2mLf6pcXt/Ibib92GCnB9PSs+51B7+52xqY4CwwBwQfy60N8sd7ruU2u5jRs/2l pAMs3yj5eSMf0rVJPmAIHKkY3Ko5/H8f1pqN7AoroW/tjFyGRgvQA5/n9Kh0mIXM0kyyj7On zHJx0pKKXuiepn3t3Fcai8kUeEAKK4bOc98VNBYpJYSTToAcHYScbT2+tKSu7dA3LTaKIdMS ZXJjOSWznr0+nT9a5OOzN/IwSYxkHB6A9fX19PrTiorbV9gTsbbPbOCGYuRkFgD6YHtT7fVF tGLOpUZ4LY5yf/rURjZXY9LbGTA1nd3kgjkyir1C8En+fSrMdxEyM0jeeoOA3T1xQ5O2orpb jWEYhEq4y3OM8+/HWsXzw0h3QhxuJbIPGKG0lsJIbAsZnUsAAOoK9T/kVHciW5DKjbowTyo6 U4Pm1WxSa6lpLP7Pt85Q8WeAhzkf/qrHhuJYWYQRLbRnpHjIz2/Gpb0dgd27s0SIrmBBO0gY fxEkY9MVnRK0l5EiQu0anD/Jnt+goj7qte9xNcrNKOFrQyySEo5+bLDO0HgfyH51kxQC9uiy uQ2OpGMH04xxg+tVom3LRdx7bln7FbxxhGAlDYJ2rgsc9ffoastdyW9ikUUwjUDqO3rx3pWb dmwbvoylp9gl6CZZRLhSee1XY7RZSrPGVAbA46/h/X2ptJe49iHpr+B+28t1Hc28IIaMbc4P O41txkxwRgqGXsBxiuyStoCORksfM1AyMTk9h6Vq2dk08yHB2denXnrVXsiUiHxLcJa5adws CrvIA6n0/WrXh3V7jUdGG6JYT2xzxSsnG4+pZexSUYmAdQcjis2TSYfOCBATySc9AKSkwaPD /HvwMsfiVqaSvdG2jGM+WgJz9TWZo37LPh3wxq0McJubg7MFZZyAcY7LiuiGIcI8qXqSorc9 cb4eaToEiRQabapJjIYQ7sfXOa2NG0BBcSIwUBzk4AArKVSUvebHa2h+cP8AwUH/AGs9a/Zh TSrTwxp9ve319E7fbZvnWPbgbcDq3Ofb0r+YT9ob9rrx/wDEYm78R69LeWpdg1u05wCe4ThA AM9qlP7TFFNy12Pyx8X/AB4uJ7+6s9HnjurkzCNQJOWYkgAbTk9sAcfnir37OUviTVvi0LSe 2k8y6tfIu7eeF4sBsFc7sDBIHBGensaiMoyb106FJLoz9GNDspfPRmAGSFPzqQARgHg1Nrvh uC2tZIkkhifknMgII5JBJ4NOPI4+Y7Jep51ez6ZaaS0dxdhdmV2Irdjj/PP4180eLPsb3NxJ I7jDlgMEAjuQe/f6YI+nLOejVtOhpur9Tx+W+U3EptLcySbP3bCMZ4555znnNZ1naa3qM8EJ tpEhd8qzLnzFc7jwe+ScDmilRjFXl12FGN3foJdfs1a5rX2ia6umt2weWTGTwC2M5wSw/L8a 9C8O/s56ZpcsVzfXLvIoO9Cc78nOCQfx4/OtPaQoQcVqn1CNOMndPQ9WstAsfC9va2UCRssU SRl5SQT6nJPTA6dee9Z3iL45aD4E27Wea5QkxxW0JkOCSP4e2QPyzWcJzqRbS17BFWepef8A bZXw0zNaeHri7nHKq0/lqozjJIBOT2G7J59DXYeDf209X+KMUti2kRaZPKVSMBWkVcsR1bkc ck7f8a1hT93mk7d0Ek5S7HHfFP4beIvBhvLrxP4pj0lFiDWofaquSCVXGMsxHT6d+tfnHp1l eaxc3d/dzk3CTKWCq2WQuQPm5GQo6n0zjHR0JQnPlirJbeZo+WKXVo/ub/4IgfFPw5pf7GzR 32o29nLaapIkokcZZSoIOOp44z7V+lXxC/bJ8O+HNsOmzzXaBfnK/ulP4nnGO+K6sXNe0ajq jmb1PlfxB/wU58OeElkN0qIGUgJb3QcqfcDP64r0H4P/APBUf4X+OL+PTJ7i40SUNtWa8VQh PuwJx+NYRl0Gk+p+kOlTWmu5eymivbaRQyyxNvVgR1BHapbhWstyIEUqoIU87j9K0emjFaxZ vbQRJbXc8vltnGz+964HrVDXbh2IMkSmNMMA3cUXuOxPbXx+3GNY1lYjARP61n6jp0aTRTXM KM5bEarzyaFprfUVrlnXbcXUUUUNsYl4+dm9+uO341h3cRup1jt4llK4DOTknB55/SmgFsI4 zq0hndECfLsD5A4pmrvNfXgmjfZbwptCg4yc8076iPONdvPsmo2dwy75GYIMnp7V1d8YiwM0 m6WRcKoGM+g/Smgv0/E5dLOGC6EbsAQ3Pzf59anu9MtpdOWWVmlkaT5C3OMUxaNeZ1WozvqV mlpbANGq72K8/qPrXLeXDqNjKqwHa2ckA/l/+uhXDczfDVk3lztIyxRhywB7Y6Uy502W5sJr 6W5ChPuIAOR/nnmnz2eoLXc2tNl+06OYZx5Nufmyo+Zvb2+tQ3W94tkNuVijxnntTe7Bvoc8 YJHeWZFDbR1UdK1Z3fULRWkjBATK4HOf8im+4k2zP8OWDXtxNPOgjhHMOccADk/Tvmrz2C3V msxnMkh+QewHTn0qbgirZaOG1BZJJgsMYwzM/G4+1S30sW6eZZlSHtg5OKTd35DVkrdTnpZB Jp0cjOyKvHPGc1naHHJNezsW8pcY3s2MjjvTaCw+ae3uIZpZopJ5VbKlpD+ddr4Kura5KxbI 7ZR97DdWzUKTt2Q730Ok1pDfTyPGgYL/AMtCucVmvJBpVuZZJAsnYZ65Pp+NJvTYdrkFtqbN HIiRyFCd25lByfbFc59je4uWZt0SqASCMYJ9vxprTTqDRu61esYgztkoiqinsKr6bMtpbwyk rJK2eXNJaOyDVosIsYui85KE8ZU1lTRSzXSnesEAOGLyAFh6gUSdivMkmlksdOIYBhuyT1z6 f596htrWfzA87OxYHA6Y9OlK19egle+hX1S2m8lXcHaCDnn/AD3qNJZZ4hG0IKgg/wA/8aiV 3oPdDrGFru0lAYKFbAGetaOiWs+qRNtPkwqfmIODxSsnuC0Mq+hL6iEguHdUfht3f/Gqmraf LJqcAlZ2PHXuDQ7MG0W7S72aoY1IZFBXIGMHNbc8x+3gcAkdyOF78fWgE9DEvrhrfzGUDBJ4 JxWVo8z/ANuRlhvLL8vABFJxUh2ujrtXuXa4STAjkztXA6D6GsywjT7S5nfzAo4Bp6IS13MS 7uI7uUo8ny4+mPSun094JNPEMJwuBuwMdepqY6sF5nOw/ZbK4YiYH5sEDnBHar2qWkk8aO3y IwOCepA7/wAqpWe4LcxoLZ+SW+VmBwT1rbsljXUAoclyDuI9aTa2uNG1F9ovnkRnSG2APIGS a5TUJIrV5VcmRF6+4qnqI0rq4FxZKyLsRhjHTH/16XQIEcS7lVtpBGR19KlthazuXRcol7Li IuduPl6L71HFBPFbTS7wiY54waabfoNs5GxtP7Tv2JYsqH5vQf4V0duws/NaAYwcA+30qUwa TNSJ5IGAYjcTuY9cCoLDxhNp144gthcTbiFLNgAfhSd+m4tehc1TU7vVpllvG2t0Cp0FcRca wz38kFqrIcYZ/T/PFPlt5ha+h0SRC3tADIDwMj0pF1ERbo0iXf1JJOT/AJ/pRa42rIx5JXvt QjeZtqx/dQcZrpLi8McAhaNpXZvkHQZ7ChLW4IzppViQow3y55OOn4Vj6fbququYjuYHkcHr TaVwsXvEVy320Ry7QF+8q1ov4li/s9YwoiI4HHSpd7+QmZEWql73e4yijJwmKz4TLc3DsHWI kk5OeB9PpVLQd+XYzNTlSxt3R2Lhmzu/vVhw2MsojmYlYhkgjnPtWbWg0x+n37yXvlxryz4U DvntitO4kb7QUBBkJxVRWgmuhM1xHaKzSIHlB4XAyOTgVipenUdVLEhIo8bgw6e2fWlJ2eoz oF8QRX6zRBBsG1FkI4XuT9elY/2eF9QO2Xdkc9un1/CpSbJt2LF1OYJ85yCNuPQVxOq3yY2p hmzyxH5VVmtylaxsrqYs9PEQO84+UYzitiw+zWtmw3MGdcklen41LTvdDbLw1tNI0yQJGN7n JJxkj0rz6PUUvbl5oQBnChT1PrSbaFozufsMxt1DtxgYO7IH4Vy1rKrarI5BZEOFDE4b8Kra NhK9ieexne+ExkADDHJzkfT/AOvVi4kkn/dM/nA8bmPT3xU7Ow46mnczR6XDGocFVHPPX1rK XzbgiTzTHz0PGRn060pJW8gtqyCRltr/AHEhhjnHr/WnXlrLqMysjGFF53AYzQ7x1uVZt6mb eWB8wqr7yxHXtVFUYMygFlUj5+MZz0p37sTatY3x9tgb5ljf+FR6DPBx3pghAvFJdmJ+bjjF Z6KXcnbYytRzIDsV8KecjNUZ71oXRFj2JkMxX+Ien0q3Ll1epXqabXEt7nauIguSAvQVUvzK sW54T2xz3+nepV5L9A1bsee2+mX+sXQEsrxIP4Q5GBnHT6V6PdWRsNLSAsyjPBYHg/jTjFpN sXMY0M8puhEqlo2JG1h/+qtqQCApGYwHA5IA49qFqvUS01RRvLgmSR9vlpjJKg8nFaGlyiB2 DrsJGOepP40kr2QJ2MO8hWe/ARMBWAG4feHf61d12d5ooVjnIUcOoAHFOXLfXdDbt6mfPGLi WMGQuFGDnt0FUC5USrGMgHJG3Oe9LljLVCauaenWizWBkk3EDPQdM1nNOglHkx5kLgLlc/jS qJyXYe5du5G8gNIhi+TlcY/SsmKSABQWcRqhDYBJz+FJqXLb72FtDTttVj8iZYIcKAF3EkZy M1mxWLancrNKpRYkIU8kHOP8BVczbS6ArPRFido3WGASHYW/hPXHNVLrWLjUL94oifs0Yyvq Tz1/ShxbWjsugrkuolre0LmMh92Tu4AXH9eK5g3JimVUcqgU8E8t16GlFK7XVFq1rmqxF1Ez SyHC5wd2M4rWgupLuGNXkwgAUDPv1qXFO6uQ9UaKSsImBlGwZBZewrjryUSTliDITypUUW5V fe4epSEkEd58iks33pDklv8APFadrqVzd6zG94AbZD8sIxznue/b9aLJvXdbFtprzLOrSW+r 35j8ra3JwABjH/1zVmKxaOzkaUK4Zs49gP8A6w4/xpqSb1XzFojm71EWdmd8nBYAHoahgvxb KzrGXycZIJ/XvT0Tt0E3Ys6NORF50kGZCcgcjI6k0681SVikkakgsQxJ/hH+f50KTvoCTeyM q8gJsz5bYdlwMHBP+T3rastIijsFRnZZG44bOTii+vL1Js0UtQsvscUa20gYDhnJHB/yO9Zk mkXGotDHKxWDIJ+bAJ/+vQkk79H0Gk47F7WrJ7G0S3ikBCnlU5I/+sM1haLDLHdvJNGrQ9Pf BP8AM80NK6LWpamuEleQxHapB+Y/y4qo4VnDuxIAx6ZJ74/HrSu2m+hK0TKrpDHC+0kuTjGP TFXj5i2qoj7JSxBXHQH2/wAatK2r2YN8w2WZrcAtIXK9htw2axJp5ICQhBX0z1J74/FqGk/Q aV/IlsJrfaZDnKgNuI4OeP8AClnjnEwUHajEFUQ9R+FZN8itbdktW1NS8mk0+JYSwDIR5m7j b+nXms4Wxjg3SzKV3ZQheSCeB9O1W7PX8Cr3LCowCkwZTGFBPUDpVabV30y1MeVM5GVY8j25 6UuVpWvoS9Nymt410u2cMgBBZiw5+p9P8a2NGt7e6kmd508heR84PPr+mPwqua6tuDkcpeRJ daixWQKgOFUgjH0qtd6hFJG0ELAMG2llHQ9h/OpS0u+jBPodFbWf9nabEXf95jAyen+fSqJ1 BrWBbiSTy0BO0NWiV3d7IfyP3R07dFIFVQ/GCM5wO1as7xhQAxDjqNp4/GumWrJWxz1+80Vx HIh8uIEhsc8VajRoTEzXB2ucKg9qroJbkXi6zSTRw7plCRls1raBdqumIsEbPKR0K4ApauI9 mU79p57+K3lYRRkDleM/jUmsyi3VolAlJXjb+vP0pLokJ9TEe9ljZAsUcQ6cZqzEsjalDcmM u45JPQf54qrWFcp396s+rorbldlJUY69Oc1jT+J49PWYTMrW8akMJW2geuTRbQTZ+Ef/AAUu /au8O+MvDNvomkmC+1S1mZoLq2UGKLKkEbud7cDgeoOe1fyk/EfR77W5ZriaSV9+4QCbJHBI 5APPQdenOQc8KCTu3v2FF3baPk+4+El59oZ/LRhKSjqgyOcgZBznquPxNem/DfQPEvgJr1NK aS3gkAS4VP8AlqMkjPqeQ2T37c5raFOnJ3tp2L5Wnd6n1/4bt9flskYRyMZFLfKe+PT15r0L RfBHijxLZRSyKtpaSIXVluY/MDDsYgdwzkdQMgnHQ0pU4W10fYd9kWNT/Z51LxNeWzxJcadb soMyXNwspZ8ZP8KYUDBHU4HU1ot+z5ZWF0JbuSKTB6gevcDoSeOp7VkpJR5baju1uW5/hro+ n2677HfMrKyAx9D2Of6+npUU1na2aokSpCighQibcjgdfcn6da5pu8Sr2v2PNdb8UWVt9pQz rMyKMGIhxnDAZIJ/i4OORz0ry6fxu8LwGKMRiJSzNJIHzx8oKgdTn1X69qzcedJdFuEY32OT l1+4vZg08f2otuJFzEdg454GM4Oef0rjdQ0ufVMtIbR7fYWjitoQpjZic8gc8be/ZqpThTjZ P5BJtaXOC1Pwza6DpCPqEgsw0uFlkAXDFiFGScchgMHv+Q9i+H3gJI7SWQy7pggdzbnbgZ+X 8vlHHc++K0cuZJWepV/srbqVvF/hi68T2txpmpyy3ECTsxaZ94KnKnaxztODnA7Hoe+n4Xt/ gv4O0uyt/FmoahNqCRFo0jtV8qYKSN3mKOB1PODz+FEarg+W1jN669D6d0r9tG1+HXhmPSvB GiLp1mxAzOQxKg5zgEn8zXn2v/tJ+M/GV7HJdatILOQs0McT+UOcAgAYzkH3+79SXzOTvL5o bjfVdDjLfWtXvkRHk8+cYjwZOmDxk98816r4Q1CTT72Dz70JMQTjIJK4ORye278R27UQmlLV A5tvU/qV/wCCTv7St34l8Jar4SuJmle2AntC+S2zhSufQEZ6d6/XOxv0jvUmvInAOVOHLFj1 HFddRJvmXVGbWpaTVFluEuZLR5ghYgl+cdhg9KbfWUviHWlWFXS2WMNKD3J6D6dam1tw3NPR YGtbtBCMMvGQeme9SS3KSJLNLI0gTIAwckg//WpN31DY51tfn121hbyvs0G4jcOpHrmrd0kE VuWgmDNjgKetPl5dN2JO+plQK1s8LSLyWACgHk1pXrW+kWM7SygzEE7ASTz2pt2Wgep4baLd +ItShnkO5BJiNAuAvNe03OmQR30RuJMzKgHoF/zmrfuq3USV9Dm/FGsW1trKi2hW4jWIZcNw W9P5VNLIrWv2iaEO5XCDAAX/ADzUJOyY2augO1x4WzZnYNuXZl68c1xUeoSyNJaQMokxjHHA 71Sjdu4jLstLfTfO8xvOleTkEjgCr97YNNYSZYRIo65AxTdgs0aVjcJFZ+VC6yTtGCdrZwKy 7mEpZoZJGZ2IBXsfyoXcUkclPLE19uuJilug5XoGP9a646rHceHElt4iIxkY6E02rrTYL2Ge FVb7E80sWWc4jXOeK04LC3uJ0e4iZlLAlVJGB+FF7a9RmR4nltNQ1SG2UC3tlkDFFGc46D8s 1n+KXgW5QQxsqOoAX6defxqdbXHpuVvs4m0x5VtihGQGb1/ya56K+u21J4YESEsvOSeOaXqG qa7F+8sP7NgkihPmykAM4rN8OWEVhJCW+aQknae2CeacZWemzBtNWZ7LrL3ej6S0hGzK5ERy ME89K86tojcxC6vDvKAnaB3pWT1BPTXc3nvnltFidVgQgjPXH8qz5NYH9oQ2tufOZsmQkcjF JrWw07Fq7sTPcusm4gRg7c4APqTUmg6e8cU8k485RJhAHxtBxx/Ojd+YmX7i5V5SzEIMAD35 /wDrVi6hHb5kMkg2qem3r/hSbUblJ3FS+FyjzJG0zhvkHPAHNQXOu3BHCKjdWbbz+dTyv0He 6JbzzjpUc0g/fSnCL1x36Ukc0aW7CSHzgmQpxgH3/lSkrIWj3M/R7poF3JFk5Jz6A1tXdyse jCCFNkjN8zAYxkcmpQXRTtLUWke6Nw7Kd2NhO329DWFqd0lvdxPGriZwUy38IP8A+qk/IaXQ ksrmFLqOMLvkL8kjjFbMwtxeGTzQ55GV7HP/AOqnfoxvtY4jXjLK5ILEnhQMCqulSmzuo55v kxlc4+96VLWo7pI7mTVku4oRDx8x5ZCM+w/z/wDXyBvkv3LqVBXAwOASadraiY26tFjuBCzg ADcyk9PStqwsVt43X7RyACVx0oWgk31OMmkitLhYVDPKZB8zDpXW3lwkVsgmViwXCLxwKLsb ZzNqZJI2mKZUEBQWro7C4jtrwKYgCy4G3qaTSSBomvtXitr17ZYtoVAzOWOSSPT8q5+doJr0 JISQDjBBweelF7i1Wx1k+itc2zl5zJLsLFUGNoHv69Kw7dDHCyx/M/Ax05qtLgkb0cDWNtNJ u+dgAec1JqiypZI0pULjAbBNJO97bAYVtqEfkSxImVzyR1NammRr9mldVaRVPAPGO/SpT7hJ tbFyWIiMhULufvNjk/j2rI0W1jgviAjF88nPrVXuPobuuMyqUijIXBGce1cekjW97HiBVZvv c9qTvcWpszT28kDoqHzOQfmztqCFI5nLIvmBVwxbqKXMVZMp2OnpqOpxknCIpZi2f5Vt31rB b2i3Kz+WMEqUbp70N9BNXOeTZbWayqWlZ+SGx0xVPRysuozyq2WB4Abpx/nimrpCSe5nahqi Q3Eksj7yeB3P1qlPfNNA0jx7QGIUHqaGhjItReKCRwMswAAPpUtleGO0nkkTMj4BIGAKGtBN XM25IuY5HVSQnJAPb6/lXJza5OzjcTEmAApPH5etKScvkOz3L+lhUZm2bpgM7/Q46/rWgZP9 Kj2liAMnDZz+NFuVaDuZt7ONUMpjch/4CCOff+ddHLaWdnpkUFoxkuXjzKT3Job7ha+hQjnh WJoUG6TODheKkup2hv4USFQ5XcX3D+VK11otCba2Ev70vLJI7YUjPTge3NcTqt+UtVKKGl3E YbjH+fak30GlrqM06G4nAkYgOBk4PH+RW/BqMsjMsa7lJI5+tSo9L6g9GS3UbNBvKCMEnCsc j9K5/SbASas0ryCUsSFVc4UE8D602+Vajsz1S7sbiPT9yjD93Paubs2g+0KbuX5A5z8n3h6c VUldCbuJrzwqojjUid+MZztB9qrxwzCPMRZpCQMH8e34VDd/8xp62HarImlWxN2PNkKgBR6n t+OaydKuP7RuGeRMKANqA44H/wCqhq9vIexuR6O11cKxBVSSSSc8dqz7sOL3ylJdMZ2g9ef1 7U2+ZXExt5dKrIrIVjz87A9qdY3yTXBEsbLEPuJ9DUyVwbV0S6jdxyBmgVgzgLuHIH41PZhb e2Aiw8mMEg5/WnNWsu42yhe35ZDAzhRu7d8VVmhhWEqFyTwG3Yx6VL91cz6EtdWaM9wJGNtb fJEADnd0qjqEkjpGikiMkg47+tFP31dbgrGzpV7bWCFjBklhn5cVia/rUuo3bMqeXCOgPGPx pSUmteoJNFHTopJpHklARRnBz972FajyuGYtGAMccdfxpXurvRgtNCGCRJZZT8ru564zn3q9 PBGcvIyoxAOAcgU4q9uxTbZy66K+sX+bYkgP8gbjaM8DPery6bLDfJbyjegPPzZ/kBQ0rN7M L3NXV4LbS3dQnyhflDcZGK5W3nCWbuY8hht7ZAyOP160763t6hY07suNMAiJjyAAAef8/wCN clbQq06cbjnoScDj0pW5ut7ktnTWYEckpk3ORxj/AA/Ksa4mjR5G8sRDJyCw59T9KmV7cqDf Yu2ghs4QNrM24AjpyKsS3D39yP3iRwqR8uQfxqtUtfvKS7mxq8mm2Yt4oiJXYbiQcisi0u4L cvL5OwHpt6mmnfZ6EqKOf16SbUmDiLZH0JbnFZMSRvKjs/7zpt6UnJK7XzDY27qyhj8qOYBB jcq56j1/X+dWbGGGNGuGYkHhVHOD2/PNSk5O1tBbmHYxT3STtGStvnJ4zuHTr9ajiiS4f54y zDAPG4Ie3/66q1m2tSk0ivcxN9qURBXUN8oJ6mtP5Hk8uVl3rnGBz9aTi783Rg11ES2CXxKw 5lbuegz1qXUbq4t4zGDtY9OOtC95OLEjjZY5prjYnOGCj0B9/TIrcmtfssURyqKFAcLzj64p yfR6spmVBEbpFjiZWI6+1KLopcMkkYklxhsnGTSdpK6QJjruyleRHJ2jIChmOD7VsIiwRKSx VSOCO2BRfmsmTsjn7uJmu4ikrzIDkZHQ9+PwNaBQTzkyO6x9dqnPHpSkrvUqxiPLIXnkVDLk YIwcrxgc/lRa3bFjG+7YADgfX0olK+ovi+Q4pEiKAVCd8Hnmo5Ylkkyo3DcBggnr/T/69U3a 3bqGq06Em+204sBDuYDPHUHv9e1UkL3l7zLkK2G4z9Pw5p3vEadtyHVxOXMWQgU9Ack+36Vl TQPDkyAMmc5I9/yzUq8m0txW1NPT9PD27kkIWXbtwe+ecVkpbtqOpSPFcmZRjDKfz/p0wfWm 5NtXC/csw2f229/eMWiXknOenNSXbm51EEhWZm4bvnp24obUenzG3fU3L228qyQbcSgfvGBP PtXNnyl8kXWCzA7FBx/OldNfmLf0IL+eO7CpGoR2PDY49+KupHBBC0Zi8+QkYApOPUbVzFl0 2ZdzsykY4XIHHf8AnVVYorECSZHQ8npkkdz3rRz0/MSuzYub+K4ijCRyMg5ADYI/D/69U9T0 KFdPFxNLncPkGeFx9am7imn9wrO2nU/cvS7OS1tZfKLK+Oqit1ZLn+z9oXzXJ6kcn8a7JWb1 JVzPkMv2MqUQOfbpUFpbGaPzpQE2A7senpRdJXQbiX8Yu4TgsQB8ik/r+tVbDfa6eVWN/N/v BumKa2sF7mxa26CD7TKGkuCBgOT8op+pSs1yjxxKiBecjOandjtZHKax4ht/DVoZbtQq7sg7 woJ/Gvm3x9+1l4d8D2rzXNy8sgHyxxnGT6DJGTVWZLZ+fXjX9vbVb2/dtFsk06XcdjXTCRgv PJHAHIHHPXtXxd8Sfih4o+J7tLruuXU0MjMfI+0YTJ6fuxgd++aaST975E8ibS+8+YfEfgmP UYl3jdIuWVj3znrXx34y8JQ6RqBEM4hO4gqj4x2A25H54pOoo77ltK110KOjeCLXUmje9uSy mUEKsCqB1HXHI5zzzkDnrn6U8H/Cjw7PPbmW2mmeQYJEmAPUHA6dD2qPrCm+aC0QRd3ds990 3wP4f09EMGmQiNegkj3EkZ9euagvxaaTGrb0toAMKOAEyfTse9NuT1ZV1seW6lrMTRSPaefd nBzJBCX9QeR06Y/CvNtVXVJpo2t4VOMsfOmByBxgdT1x1rCcZS20B6s881bQ9WupVjlvUto2 GCIoc5Ixn5jnpxnA7189eMZtP0qZoIzJqMyZ+eZyRk9QBnHpUa25V03KS3PMZNBn1EypNMI0 Zt6QxsgHTHC/ex+NYieHbe0kkBlSKSZtvkljzjOANxyeQO/aobcLJLRjf3djattMuFkUQaaz x7cs8jeUGYsOpOecAjp/Krc3hC5vgGuLpUIJbCAAoOejHOMYxkAdTSlBqV+r3XYIpp2lsTXH hW18J2UN/rF4tnDI23Yp5ZTxnnJye+MgZ71vaPZpoF1C9hBH9gu8RxOBgFiCQDjBJOMevvWs ZOLd3Zdy3BJeY7xf4bjaOURKXuJIQ4ZgWKsOQB1PBA/Hv3r4A+MHgZfFGiWphgRLmyj2q6jO 9iCcYHToBn/axilf/NshatRZofAfXV1Sxns7wItzayNGd7kuBgHBB7ZJ5NfROnXltY28sYR3 dfnUqd2Ax4AOPrxwf0oqSaWm4PRaF5PETXUjCFvLZQXZBHgKVzxXXWlzJqDWqNHudwGIYjBO cD/H2/DNXFulJvd9wbV9D9cP+CVXxiPgr9oTQR9oAt7z/RXbttkBAJzzwdvJ/Gv61J91/wCI I1jk82KMA5A4z3NdqTVOLe/UyZ1urW1xbaaNq7XZwq4HUmqMEM5s4TcXDJIW2kq3p/hUqwnq Z0Nu1pdmGK6eVM5bc3eugu4jJ50DTlYSMnHfvRYNzKuZYbmzaONCbYNySeTVO6uIWgGyBjgY 9cGi7YvIyNINzemMQosYTgZU8+59a6zU7R7eynRX3yuCXcgE5x/KnKw0efaLa3UGowwxIqqc tITzgD3rom3/AL+eSJrmWRxjafvf/WoaErnn+o2d6bnzp0VnJ4TnAPpWzHHDdEKGARGLPn6c D361aVldE9bHS6ReT3VgbePbDBk7jGe3IFUdJ0uHTbqZml3kgrg8nPr/AJ9aV7XGmefFFuNV uYt4Ricl8EgD/GrOoFU0h4dxZMctjGTTUbaiatoV/BcEKIUhfzZChLH1OKffTPfXCB02oSAq jjB+neqd27oTetjm/FjWlgqKw8xgQWBHHXFdpoNpaf8ACLMHaU8ZRQ3A/DvT95K5TOZi1VLe 0WC3JEmNqhfbj8q7LR76QWEaqPNlbPmHd096iztruSmYuo2kMYSdpMMZsEkd/T+dS621vbXF rMYRIBwy4601r5FWscBp2kXviHU/JhkeKIyAFlyQikjJrttQ8O23h/X4oUn819uGYdyPapvy /wCY7t+hyV48iavNFAgIxnLPgL74/GtDwrbrHrdu0i/aSjZYEcUoq+oN20Pb9dIu7beygqeV wOnp9etcDZzWcceLkggElUXjJ9c0kN66MzNXuY9QQOImC8L8orO02ya11hUjYiYwMTtHI9P5 U0nZpk7HRJZldPcNI81wYjleuDjjiqGjR3CGOJBklstk+lD0ZT0NW5swzZkXY7ElR6/5xXLX kMf20oSZBs6Bjx71DTZS0NXQojDC2AwUHpjGc9Oamlu2MKTPEm9GJZgOo9/8amWon5Gpqcyy 26OshkbaX452nvXONOUR1TI6lRim9UC90oaQ0r28/wAyIgOc+3+NW0gknxI0mQV+bpSvb0G7 P1KNxKEjSNS3l+YOQ23vzwPrWbf3a2urhmzMrDCJ/n8ajl1HcrRAy30BljMETNhiTnA/zit7 U9LhfyEsyyhm+dmyM0Wb3+8G9LmFqXh8T3whkuWbZ8wXsD9O/wCNTaxeW9pIJZD8irtUAYzw efak2tkDV9GM0zxDBc6WkMELxbX3Fj0PtV6Z7lIwwZSeuMU7NK4bEa2lxLcKyQcgbuTjAHvW bcanMLloh8yschl5HFTe7t1C3UrtbrC6yfaN7Ngk+nofyrbup1k5aQs3ofbr9ae5T1ZzC3To rCJsHdwc9Of0rct4Em1WJ5Z1cqv3euCcVKs2QkzZuIIl1MtHAsYAy2zHzHnmoEESX7uEy455 H3T71Tkxos61cSLZApLuaRSAR0FZVhayQw43Fjn5T6Ula9w2FtWa/unjLs4DADDHt/k10N5p sL5kuiFXb8o96rbV7oFoc7aQw2ykRnDNwAw6e3tXX28jwWASOEuqjrnjNCVwfmZP7+WJHfzI z14rR0SFotSRpmXYPmGT1oBsTW9UZZV2shJPJAztFcb9qAvGAbc3f2FS0mgZIl95MzLHH5oP U54NNOpSWZncptjIBJHY9BQtNB3sZj6vK0DIoYrKm0Njv/k1curvbZRqEbyY0CknvVOL3+8m xrQtA2nwhxsZjj/61YME32XUrmMAucEHk8nFJ6NDWmhRvEjFwHYhRjJOc4x0FTXZ0+204tIv mXBOV3MAFzTenqFrlSyggS0kDsDIwG1OuysjWWe7s0ht0LEyAM2MYHf+tF9Wg5erKVtiyjmj UA5XBJHX3xWCt0r6mu2NpNuD7E+lLlb2YJWLsVxIJLiOcBWZhkA524piamttOYYyrPyNxxjP +OaLPVMNyZnjFsRM3Ocuw7e1Z17e+X5f2RiWIGcnGBzRstho0NKDIpJwigg4znii3kuE1GUC MuVz16D8amzWhLTLF1ujhZ3bcOSR0AP/AOuvP5le41ASMwByAcjrUtWLSVzpTFGunLLHLIqk nO48HBOR71NYgTKVjO5RjcT35qrWVyeuourXvkKGlXaR0UdDVTwlqLPfyGIGEBuOMe39Kl+8 tClJtaHqmva6/wDZ8NtCjXEjYH/165ewtILe3E1xGyShs53cZH9KbuhLTX8DlNS1aK1vZrhm wzH5TnHXH88VdsfEsuoiIR7ldeFGTyT0/OlpsJrlZ0Vt5qBmmTdnk8/5/OtCwlgtbZ3CHByM DgUNWHstDGW8eaRmUEKoxycdfep0u5YpiAu0c9qErMSZh6ncqJkEqg9xhu1T2txA8yDaSOgC qD3qU+ayYbkmu3NtEFAYLIVP3h0pbK9htlLxhpGK5JbuT/OmnZ6bDS6nNHVPNlwiF3LEnf2I 9q1IGmnIDIcZwQX4H+c0rS0sK9zTu5reB1t0zkH5jg4bJ5qHUnktwkapsVhkEDO0ULRtPQa1 IvtBto/LzgAZLNTLyaCVI0yRH/EdpOR3oV3vt0Bq5hzahJOm0ERRFiF5yfartphEVTIXwMks Pf1/HFEnFK42tLmhFp8aQM5+QsfvH0pFSGK3JkkUQ4GMtjjtRe2iWorGVbTtdSSTIvkoOI1/ z6VsG4uLi8V/LMagADPH4/jU8jlrJa9iUunQyNdDvcZLqHZckk1n2t1vjclVll4AAXAUd6bS Whd/uNO/h2wJgMHyDjd3rmoJDPqpVUdmVMFhzz9PzoUbWSBWLr2dysfmszBAORjOazBo0k7y zXDmGNV2g5xuPaj3Y6C0Ras1nlcqEDjBKArkDqDUCWZm1MGRy3II3Cjn5l2GmnvuXLz/AEWd 38sE+XjrkE85PtWdeLfC0VbeBJXUZBkPGfTAqYpK66AtCGSHVdRO54Y4ognOBnJ/yK1PD2iz tceY1ozEjBORgHHWm4pKyC1zantXgeZ5EDyEbRgd/T3qvIiWlkGaPymOTgHvmpUmnbcTtaxk W11Ld+cYyQFGNxIxgdv1rIcRpeqyKHZRuJ/X86Su2xLQSwlWe+CtDhsgZP0zn+X4Vrzq8KNI kYYZwOc89OnrVuPcG+hnaf8AarCSNgxyTuO/nbWy+ppBuElujykYMgXJyenHtxSSu7J6jtbV GHuaMPMybn5PynGKz9TlaIBXfKemMfjkc02uq36g5Nq5VgdfKQopA77Rnp05pLeVruV0iQQu w4djnH/1/alLskDJ20Z4HWEzyMOCSp4P/wBarV5MYrZAqg8YwDjv0qm7LyQrWM+GR45N0ylE z1UdDjue3tVCXWI7+SRYoSyAj5pDx9KhLVXGrlf7JJcQI0SBAMAjdwTjj6nIrrNIittKgFxq L7lGBtHVjnp+VT8V+bQWz2MvU7yDVHhEEZjlfJT2rMKrZMrb9rjHOM/5zWkWp6y6DvceshuE aaYlEcHYzDgH1469Pyx+MIRCkuX3BG4CfWi+vqVZdTKucTIgd/NlxkAt1J+v41pIjIVLW4EK njzI+uKS5VIlJJnPavcy3DukMvkKMHGMjHOR/Kq+mW8yRmSJ8MSPwPfB/oKKbvdA313OhiEv 2EOZwqMN2SOoPeqlvEEdpQwL7SVCnr07fQH9KpJK63uCaEtrSS7ui08jfZ9wPXO09ulVdXaM 3UccEnmkqMKy4wB6H6URdpWSFsRz27WjIJEBdc4Ib9KjuLyKCBXZsyE/dK9T/nFNK7eupT1V jNid57lhGPMXjC5wM/5NRWWrH+0vLmVZWVfmZhxg+vb1/Ks4726kuy1NifxvpbbIREzOpyWV Tg89f5dKx/EmopqVvvTkkghMdB/n0q4u3oNNI/c2OWRtWSJpP3J6jdiugur9BdPEZCAMbdp4 zXY1chaEUlwyvtUeaxFCiWexdWmWKXk54/KlZJfoG5TsGJto0K7mH3m3day9X1tLQCCObbI7 ADjmna7C9kegWtqLe0QIhf5eSe9Z5Sa4w7kJj7oH+etZ31uVY+Ff2pzNaXcNy/8ApNrnZImB hPfnPrX5m/EqaDxnoNzZxXVzpDyRsHmtnEbIPQMOR+H510KL5U1t2Mk0pNny7oH7OekeGblr tJru7nUHc9zdPIWzyev4V598WtRfwrZTOt60rEsAqxfcz1bJODjr0/8Ar51ZOerNN3pofnp4 8+Iepr580c8tutx8shMoII5A44Hvj3HJ6V5/HDqMlu0kdm1zMgBByPmPbHrxge2M5rjlSSV1 uylG+uxwafEfxY2o21lb6SNNh3bfMmUtgYPOVO3IyODxx9K+yPgnb6ze6tCNb1iWe1PIWL5A vbPGD/PoOa6lTULdSm0z72stAtYLco8O51iGXkndic85wTgjGe1fPGqfEDT7DxZBptrZ+cY2 KL5KbfLxkgZ64yf1pyb2WzMYqTO+vLY36QysMCQ4YOc4Hrnv1P8A9euJ1aziNoZE+Wdd4hUk 8bsfzK1lJcsu/cpavzPkT4yeJbSwRoEuUgllDLIgcFgcenX/ABr59nt2uIWFrpzyBCFjkmfY p2nkjAJIywOOOv41zuyck38jRtbvYeugX9/ie6vZFt9oCw2425/EjdnnOQfw5rp4fDFjpcy3 H2aMyOf9e4BaQAcAsfcjg98elF243tr37kqzLgtUfKRI6A4ZiwwVbkgcE+/+c1j6lCfLkQ/v 2wFCEdOAWHt/9esISjrJu2pdk1odvomieFfjJ8PNYTW54tN1q1tDNpf2q6EcckydVO4HBODj 35HSvGWgHhbQ9O0SWWO+uLq7jlQwlmVFyGbqOgzgnBz07nJzSu4200sx/Htqz1LVoY7jSmYy tIQmWk4PuefbjjFfItpp8kniA6fbSMksr4jJfHJPqOhySPfPQVrOK59OxmrKTujkb/4c2/hX U4b6GZ7qCdzHcxxkjZj+LB9/512yutjKWihKwAbdzAKQeo4zkDg9Px61cFypJ7sp8rasiM3M m5pFlRULZAiITPByp7/MTz9T1zxtafdg3FmY3y3lN8wXAx6Hj1JI+nbvaUUttFsUoXvt6n1R 8CfGs/hrxVp94xEc8VwWZxIRwGGOe56nNf3bfDfxHb+Lfhho/iSB1khvNPSVOepI4H512Qnz 0ebzOd20SOsijubm0a4up3dSu4Ac/hU1mEtdMmkwd6HjdyeaL20QJhbv9oUOgJdmBY+nr1rc upJFkUGNXDjHPbjrQGvUqLbRWdvKJZFB+9+FclqmsJa2TPDCXZ26txiktdAIdBa/ks2RwI2L EswBGAT/AJ5rob7To7WFY2Yt5mNxJySOtU0o6IRyfiNjJNHHZI8CKfmf7uVxz07YzV3Sbx9Q aNliaO2jBCnoX9z6UJdwuYWtC6uZkjjdxF5mMlRnnritmfTrfRLaVBJvcLydvU8007Ky6g9H cb4emuTCziMBSeCe3v05qrqsEk2xVO1c5LMPvUthas4y5tEh8TPao/mnZliOB9at30Y+yBFC s3IOTVp3Q2rFjwYIhHCroCoYjPT/ACamuLyLT5EijAJbcxbrgjJ/DpQ3r6k2OT1TTbW9limu X2sfmUEfrmutsoI30KSKMhiUOCaHt5A1Z3OP8P6G1qCzhDKWOcD+v5V1RC6T4evHKgFQVTB5 Ln/CqbuhpXZyUNtJaWkIYsAME8/59a1tflKWUe+MguNoB4xSd7O24bMveFoJHZ5RHshQYyXw WP0rEkBl103k7KIY8oqg9T3/AJ9ahuw0YsRtVu5p7o7i6/KE64B4579a2NK1iF1UROtqiEtI ztgtnsBRr8uoPU9I1GMiyRIpDMXQZJP415pqF1FpkZVAryEZz7ile706jS7m7FqIbSLeW3t1 IKAKSM5b1rOBvYLsPKFBZsEdgDQ1Zu/3AtWa8DPMVSIqZmRizr2HpzWLpeqyNctCjguvBKjt ScQRfumlYyBhhgvJHJx1/wAaxI4gt4HCsOBg5p2W42dNZXkohlKBmGc59KoparcXMrO5WMr8 sWPvE5FQ0rDFuozaWLrG21gCAB2qodPWS3ULN5pZAWwOCf60tGDfUz7O1Ko8SfNg5IK8D8qt yyvBCDu3yMfu7Rx+H4VL20KaIoYysoLDPfGKhnmgt76O5NvhWO0Mxxt9aHzJaCKcclq+rsZn LjcMAdAPrW3qGsx3V/GVISEMRGoOc47n8zS8h2Z5b4l8Qj7V5KxNI5PPzdB61aTSJtZgTznW 3idgCSP0/nSt1E3rY9bsPClrY2aYkBAA53Vm3mo29qhRLUSHtIxzjPf6cVTk+mgW5jz7X5Td 3P2f7S/lFNzqDjv6/wD166TRtCtUgDJIWIXGC/8AF6/Ssl7u4zIurdTcmKM5bdg//rz65rbv 7BLOwjkMqyHGMoc/54FVdLUb1OYjv47eMgAs5fkN2FaVrLD56tgq2Mkhc4J6Uk0KS5S4bS6D I7RYVjkE9/wqfUZJLWIKsW2PHzZb73+eKdvuB2M+9uZp0ijIw4XkZ6VSidtrPKSrckjPXnpS cl1BPoYlz8TvD3gn7QNZ12y00MpANxcKmfb/APVXkHiL9sL4Z6exWfxNFeODjbb7jjkdSAay 9u38KuJl74f/ALUXgf4h+IP7P03WFa83BVhmRoy5xnA3AZPI4HrX1DHczz2qqBtiPOAOvNaQ m5aSVgeuheOrrFbhHg3hQQoY/dPrWK+vx6hMkYhMLkDec4x681pq9AeugX4t1fzdrED7u0dT 68VzESzXF9MkUYIGC5P8I4NS+i2FuyO81D7NcM28RkdBnoP8n9a5288QQiSSWaVEQ5UksD0z im2k7dBtXNOHxNaXLwxswdEUbWT+Ljj61PqWoSSMohUsjfMRt6dec04u/oGi2KTajIsIV4SH HYNiqtnqMwnYRws3BLNIexptXDRFa/u55nQvyAe3PFUb2/mltzJ5eCpwFxznmk03dBcqKQlt I7Kd2Qxz1J//AFVr2hu7bREmZViBYAE9ufX1oWqC/czLrUpLSN5C4lZsD5TjFcxfalPYOrQw +SmcdM0nG6BSXQsafi4t5JpV3yuRudjxjuM96tw7YrgsiiRyp2jGBj0zT20C/QuxQJqQkWaA KCpcnHQ45NYVvFFDeOzqQqH5Uyfmou7eo9DrrO5S/tVUL+8XGRjp/nilmgktVnEjAbsYAOSM 55/z7UbLzEzJYl7hUQE5HUd64TxDezpdRxozRqCAzA/eOeaiSb3QJXR0+kXrWqhypmUD5UJy SR/+utO2106liFYRFI3Tt7US3H0M/VdJFrcKDcR7QAWBP3T6VD4XitrlnIcRgMfmZv60NpDU ep2uqSPFGGtZPLOOpGP88Vy8OoPcI7HgRry+ep6mnbmYvMyn0FNWQSsFUKMlRkf57V0WhxwW iRkphQwKY57f/q/XpUKd3YV7mvPqUN60bNhC3IJOBzVB9RFrYtHIQS38I5yKWvMwuWfD5fU5 EKAk8NjOc+mav6mkenuzGRJJD/CP5Um0ld6BzWPI9f1Ga1v4w8e4nncR0FdbpJjtrUMoYtsy SB196aTQm+whjhnm8wkqV6FuMjvWha6oEV1to8oOMFtv9KlJp+8y1otSSHyRfMRGWJySfQ0y JvNvLndlGB4Ydga0T6NkvTUpwSlbzbsWV92Sc1UuLsm/LSM23dtUAdAeP0qJJyT8ht9hbW6t 3uSZJvmycEnGP88VPfMtzdqsKozOmCyjOR9amLa06jT69TX0jR7VGQhTJJ6OcdjSNFCQ7iUA g49eh5x+tUk5aPoTe5miQyKsbzER+3UHPSpZLZixjg3PhSxO37tT8K3GmV7GGSNU3sCv3hux +VbUmpz6xcxoluG2kAHHXHSq7CukUNU09kdQSNxIBB9avWugWxxJcOIyuRgf55py02Ha4uqz RhgIXBOMfKprH02SeCSaT7Ou4cKzDrnrzUyV3ZCSsT6lcTSWrB0wnJ4OO3vWFdalHdNGkwOw nIA7k0nGT31ZTdjc1C9ZnaGwjZVIIzt6c/8A66ztI0GZr/zJVLspB+Y4AxT1tt6oVluUJv8A Sb12cqIlkAIHf8a6NYo1uVRNyooySw6Ck/di1vca7mJqeqGWMIsRSP0U55rOtNcktQUhVmC8 KcdMe1KLSWgmrO5Ede+zfuUYq8jFmaQ42kmobtGlhJI898bcZ78f/XNLV6rYle89NireW0lt CI0hEe84YE/dPfn1rasNIMcSSKgLFfmBGM44JNaKBSVnpqZl0JmvN5QISMBe+MVtahLLZ6RE rxEuWBMpxwBUpPbqgspHMQ3ovtQldZQ5QhY8PksMc/59quNfRyu4ePDjK7sYLCkkk3L70D0M +5khiVBEWMhHIx+n/wCr3rJvLmQzxpLCZEXBUhCSOfypOXM9dBvTYdLKEgKn5xnHyjbjuTir tveIISpiByByBnJ5x0ot81Ymz6mVFd3E99sEJUHP3RnH+eea1m0meNkeeNUU/MMckgd/aq02 2BrUzopI725cyFkjT5SpXrxz+lZk8ttZrIFjJBYngcNz+tS04LUTv0KR1BJ58IjOg4VG/u4/ DvWrMxv4ojNG0oVf3YHrkUnO7slq/wAC9dia2nS0RnJaM4+fJ6nJ4+lZk6+YVU4COOdvU/55 /OqStuJK/qOnxewqkn+juoxGRkf5+taGl6aowvMhJBZi3Oe34UN6ea6Be+5QvLeAXkinllIw M9P84Nc5rmvSrdlYy25Rxgng9PxrNKTu2J3v5BaKZYXaWHJYZG4gY9/arukWbwQhliQhVJ2l up659/8A6/56Lt17jautGOuoZdYUt5exV6kHrT7HRFuLNpJ53t1GF4JG7jp/Sqdla/3gyrNc pB5kMJJAB2g4AJ45/KqNtLGkocQbVA4PUk+vNKUrOy2HJXsSW087XKKcIpG7bj+VWbyM3u2J 41LBgTnjP4/5/pSjq3+Yk7GfJokmnqHtyyJuJYgk/WsBfJn1Asz/ALwNkZzhGHv3qpNONxOR qaf4SW+dhFtKqCvbge1c3rVhDZ6ikDMzSbgp2nIUDr/Xn1otp5AlpY/d3xHfwxOighSOg/vc f/XrphDALeJ1ZFfjKiuzVJE9SWdViVWBLE9AKybFDdanIhXaNvBb86S2uDFtDGmqeSrb2HDH tnt+NUL7TIbvxFbuWDJEdzHsKd2ncVjsLMx6o0rwynYWwNpOMVUt3ha4uY3LSFBjj8eKjXYo 4rW9Bs/EWl3Nndaet1FICNrnr7+1fnP8bf2QNX/4R++v/CMsLzwIz/Y7osfMwCWUH1PTmtoy to2Q+6P53PH/AO3Rrfw/ubhZ9Ct3jSQJL510ytGTx9wA85B4/WuK8P8AjXxL+2NaX8Pg2GM3 NnGHuU8pfkB7bmYDPBPGfpzWk6XK1d3iEZLmvc+qf2TP+Cc+rfEDTdc1P4k6Rc6toVvYzSW4 UmFRKoyqkqBlSNwwOuea+DtR8NyyTMsDeWmRtQoGEUf3l49MAD8R05pVuRWUFokaRs5eRxU8 OsW16W8uFxjDEkt8meeDwPvev/1vd/B3iCLTUzdRzW0TtgKU4zkHqMgDHA+lcvLa76jemqPr zwfdf6CkMzs0JQbmReh7n69/8a+fPAWh22leLLkzBppzO5Ofc5H88fhRJtai05vI+5rjTLfV vA8qwQfPF86swzkZyevY9O9fG/xBuLuy05rewGNTvJVt7SPGQXc7V/AFgfwptXSf4BGV9Gfk P+3L8XLX9nnxxdaRZIslxFKIbq+EQMl3IAODJyQoLnA6AdK4P9mP4kav8RLZprW6ldBgT2sj cSEZxnGAeuM+wHauaNHnUpW1ZpGPNo/vPtzy2+zwyytGFXK7Vj27fwz0PsR0FUzdm91BI4iy IcIsapu2g5z83tg1haUbKL6g5WVlqdFB4F1u+QyLaOoCsoExAyN3B46A+v8ALNaOhfBHVmvH eVWt4uCN2WAPrk9fyGOa0rYSLa5m7ohtJfobGo/sw2l7FJKmoSxXbfM4U7QMEZO3JGSM8471 yF/8BtX01ZY4GEquyhsDJJDAjg46ED/CmoxirISd/h+ZJZ+DNT0uOVb+33xwvhHjiGGA4bkn vg/5zXzT4501tN12J4kk3EbUCMGKY756596d5Qdkr3NFHmV0tex4rq2pOfPhkxFOspEitnlQ PUc+pwPb0519N1aPUtDjngY+WyAhlPLZHQ9+9RNJ6vV9l0Bcr6l6zVftIkcGQCBSFePbkZ3D vxnP9PWrqySXSqY3KiNGWOR5QdpwAATwScgkHpnGMEZOsKqfu9GhR0WnQ7zwlrL6dqFp5KbZ IZAw80AncR12g98Z6d/z/so/4Jr/ABOT4i/sr2WnG5RrjTJ2twu7IVD8y89up/Ku2jFqHkia iTs0fp6tlJDYQxtPubAG0N0/CtnS9OW2WeNxhTzyP1xSbXQzMttbEcccQjVSSeM5LDsa1ZVa 4mgfcScYHtRa2rBsoX9mghuBcOCCSAi4JNc06xHShHLCI1OCDI2SAKFqDZqQGVdMkLKbaErj LHGR3qzdSwi0iKMJDwDt7U7CuYeu3DopCAqhXbnOTn2rm7rxJNpGlWVrBt+0XEhDFk6KB/jT 5b6A5WJNTa6ljiLuIwO6jGeKs2zC5RUYb2ZTnnJA7n9BTWqFddSTQ7t7i4kWRyFAIGMcgdKy LhTd3bIzFlz3GRx0/rTtqBnNaWsOoM013GCPmfkcDsKZePBdRqYZGERB2+//ANahX2BtblbQ IFljAaX50lxwOtN1LR2fUN8RUShgcMc5Gaq9mLfUf4n0LKLK9wruqcbBgD8D9a1dF0eBISry MRsHygDmkpb2G33MMaTMLeQ2i7USXjByR2/CupudNj0LwtJcXrxrIc+RG5+Z27cd6JSS9QSu c1uJtzPPvndQGYEcD/69ZWuXcUmnqVhdzuzkD7v4U7N6IXUx9MvUkeSORmVGA2A8cisq5tp7 6+jiW4jgh2ElpG4Ud+PyqdtGN6amu+grBBApnD7lwpPOfzrPsoAb1o418yQHJZXxtHp3pxd2 VbS7PaJ40tbCAJ8zqm1nzjtXDssCRF5VBbcVCgds/wD1qlLW4X7G1PeJLotrAi4VAPlHsTXM X5/fBN25nPJ9Me/4UnG2vUFubzRQaRptvFbhWlZSJGzyx78+2a5vw/CskkkMQ2sx3uw789M0 Xcndg7Xsb72Fy+pzLCco2AIwByD1zSy2rRud8W19pA+YcVLt0DYraRCWeYPN5ZHIGc46/nWS jym4y7kknb9BSbTDU27lI2tzGkICjnOOprH04z7JFUrFGVwdp7etKQzVgjGjaa95cOohZSEB IO8/SuH0/VV1LUFRF8zKnLquce3tSv0Q7s6W0sGuHBYeVGCeoxWb4guIraTasauB0JPf2olJ gn2ObjC3d8mE5Dc+9da1gsQeSdfLTdhE/ve/86zSvqgepzkek2lnI7yqfOdi33egPQfrVueM 6jfQQodyrgkngf561UlfQdupu3NrElwsIlcDHzbeg+prl51WbV5sSFlGQBuz+nSocuXRhd9D OvUjs2W4mQy3DHBiTgAD+vNXdLEnlM3ktBIDkow5X2xSTafkCi+5nBJ5ZDCgwwOd3tWl4jsL iy8tbmUHPbufU0t9X9webOdPk6jZooGQCBz9a3Ft2t7mOOFl38fe5x7VS5dL7j3Lc15cQagR JPIVHO1GrH1PVJJbgoilkAJy7dBwOn40norIbsjVu5TFZLDEu1mwSevP1r8K/wBon9vvWYdZ vNIgu38PQxTNFLskAZgpIPz9R0PT/wDXEo+0erskFrn5n+Lv2htG1L7QbjVHSaSMk3Hng5GR zuOe564rwnUP2qdB8M6MtvaX41GdVZUmeXfvZSS3A9OBxnqKafLe622E09j5x8V/tc+K7nVr ZNGlns7oSAwNaKXcsDlccZHIHSv7XfhD+1dpWt/BfwtqmsXcqaxcaZbyXtqsZ3RTGNd6kf3t 2ciprzjRSm+uyKkru63NTX/2plSYtZ6ZLIoyN0rhCw9gM5/OvNo/2vW89idK3SQZ3KJuh/L2 9a4pY2SdluVGlc938KfFZvH+jxX1rMVhZSFJwNpA5H1z+dVpdevI52AmdUk6/N973/nXZGSl q9bkbaE+lk3yMmfMfnGWLZHfr71zviW5Gi2V3cNIsIVSS27hcDnnt3ocrrVk76Hi3/BO341R fHv4WXOqSgXMltqE8ZZiPubsoMewIr7t1ixkfdNt2QkDavXHrn8a6KcrRSYN206lWUuIowoB wMZ9fxqhY4jeVyxJAGMHge2auT1BdjGlkmup1VmVF6Db1/M1FfhUt1zIo+bGOckY/wA9aE7e oeRnyzr5JbBZMYXBzkn2ro5idVitzOxMKKAsYHQihK6JfvHPahEFWOOMBFLfM79AM/5/Ksm9 iXUr8xwSiYxrjOeCfpWbfUvYsw6ZJbW8aSjLKC2ev5fpT7ABpXAQRyKOmcVSaE7MztQIa5lU TSBguRsODn6/Ss+KAxQEKN2Gzl5OTj35NF7O6QJ20OjhuLloZFit2bC4BBIBz0HP86qXUdzL IDM0iZIDBsKR6/zp2cugONhmpanPbXAESHJGCQvavPdQnne/gUHKgkAA/d6Z/p+VRLTQaV9j pItWkMpjaREO3kjqfQUzQdUa5LosiGY5AkGOOefyokk9WS2y1dWLLLOkcxEg5dyepxUPgyUX 0zl23MuBj1z/AE4pJpyshxTSszqvEt9dxpKwDKTjp69qwdIlSSOSJgxVl+8egoad7LUL3KUs Uk9mcTlo0cgtGPvc4Aq3p+rrp96kQhMsmP8AWOuR9MGm0ktBaLQ39UuBc2DzyklyT+7UYCj/ ACa4xtTJZ1aUKQMgFsYAqLp6rcaRY0rWbi0kkMEuWdeWDY29c1XjuS8huHnkuQQB8zdD6Adq Vor17hcZHdG/uhMX2sMlj/L8K6ix1OCztZHDh5iTkA5wPrSjo2kO6ehQm15p5lRlVX6Ag8Ed ua0bXUgIGKkEbsEKc8/5FD1fvIWw618Y21ncEeW7nBOV9fT6Y/lSQeLYL8MEXy4uBubnccZ6 0LmT8kHKP0vWEs7l3aMOAnHOc9s/rVB9US9nDEmIsCee+OlTeS0XUHqy7pltaEB7iY+bySB2 9qbP4ig09zFtCocqrHk89KqLe7CzTsU7HVIJJVSI+YGDZbd07f4VrSqqWTAgEscgHnJ5oimi loOgtJIYQHRIyAB83b0qxdT+RbzMJtoIxhW9KFG+nQVrbFqwa0TSXeaVhMwwE/z+NJZ+IDFp 7JFhBnA464pOySjt2E4roY7eZcXqln3nG9io5FOtoZZNQjCRPMBgtjtST5bsbdkbd/cpG5nR SrDIG8jg96wrHVJCvDiVzn8DnoP0qpJu3ca2KVwL7Vr92M7JGn8Ktjrz9DTLhopL2FHO0jGS eKxUeZ+YaLVm3dajBaQL9mlMk7SKSM8AZ659aa+pXl7dSyDEEQTGBzz6/pWytcHtc5/SopA0 PmncrMWIHc84re1XUIrZH3x4lwWwDjA+tStNhao4fULGWV45oWMceRyrZ/U1cuikNs8jBWkH Iz6+tJOK+YmykYJLwIxQRDOSxbJIrWnuyilFLKQAFI6f/WPFUrNMqD7mfLdxanKsUUhYL3PG T/kVbWG7igAWRemCQ2D/APXqVU6apIVr7HPBrizWWQPl9wJLHk/iPqareJ/E9xMsMLO4bbgk Ek4onJ9g29TR8MxiGALGQTzjcAPxz/npVzU7iOWWSOP94QeOMbjTlHmWunkNq3oY7XaLcxq0 WGzgnoMA/pxULais96W2livJH9aTdnZdAcr6jdUmaTMcZAJ+U479v8/jVq5smSyjT5gANzE9 jTktd9Owt3qWrEOHDAAux4Yc4GPxqtf3aQyFZJCVZcKDgAehH5VPKpXadn0H1KMNv9osgIWJ jYk9eQe9VJQ7q9uuBGRyGH5e9Jpu0WtH1F1M+axk02AlVDOwAXPUD/Oa3bW88iPaxMs2Ac9h /nNCjrZDbvsU3JvN5LgzMSWB4wfpWe90YG8tIi4QABgPvE/5FU3pZsnyJZdNa4mJc71Kgbj8 3X/9bVvaS8kFwZI1bbkqPl+9yaiTs7bp7g4s5DVZFFw52lw5O4BeB+Na9lJFMweVMoR94jrm qmua0VYGny6mBqeoGI+VCgKv1wemOn4nNaz39yYkVbbywwLZORnkZP61SfJolqCenmX9QvYl RYAjiNlBb5Ad3cfXpXLXjzXDtBbkyZOSGHvz/M80Wb3KTvqLfWItTslkLS9CAM5NVft4hkG/ kKCwwBnOMf1/Kh8t7/eSu6NPT5YpCZJH2EnjIyBVG/Rk+RGMW05+XHzGlZNu4J3En1yWGxWK SYCNj8y//Wqvpmgx3bSFQCGy3HA7ZNHR2Vg322OhlJ0ixdQoEvzKQB0z9a860h7a+1aTdGZy HK9OuCf/AK1Utk3uJXbufvZPZQzai1xK22E+vAFX1u7R2LQI5RRjJQ4auvVq3RC0TL0SDYGK AEjoR0zVCSWL7YFkVSR1Xrk1KvcbGTXsNndSOLbCDkbO5qR4kaFpTAxZx8qKfXoKdmtbhuXv D0dtb2LxBgrL1BxxT45bextpHVC7MSWPpSd2w2RlJPE2DsYD1A/KuYkeC61OQMjNEvY9D+FW kxPU/nZ/4LI/sX2F/wCOLXxh4d0UyRajEItS+yw8LKuSGIXu4Jz64r8kvgN/wT6+KXiG+Wy0 Hw/fwWM7gi6VWhRGzncXOPy9PWvTwseeHNUaUV1MrNN2P7cvhx4J1Lwx8DdP8N6lJbPqp09b ecq52uxTa2D3r+Rvx74G1T4M/tI6/wCEdYEL6ZcyuiTqGZreSNlKduNyuq8HkD2rzZKM6ra2 exbWqbPOviB4KXQtXEU/zWrAYOcEAEk/lya8f8emf4beJItSlLtZrb75VknwpTqW2kYPHb+f Ss1Bzu29uhSlpdn0VoUVp4K1fTrqyuYU0u+EbYQBQokA2kD15A9OffNS+NrF9H8bBkbEcgV2 ycfMD8yj1OTntwMfWEm9X0Gnz6n2F8JtS+26SbYogRo8AbMHrz9ef55r5Y+JiyeH/FsE6q4O najDcKjAgMEcc578Z+lU24ryBq7tfU/GT9vz4EyePPi5e3KzPDIl681tHEctISV56Z5wnTnA A6Cva/8Agnd8DdN+H1jeWOp3Ys7u5cCK7VUCr0zvUjGDgHPY+tYVKzjDlWrRaS6s7HxZqK67 4suYdPlNy7XJWPykC78cA44AByOD6AcGvvD4d/s2p4d0VL64Qy6jJCS4ERA5zkDk45/z0p0K d6alK1yZ+4vdO+ufA06NhJFckgqJFGT9M/8A6/wrn73wxqWn2+ZgI04IY5IUZ9e+cf8A1hVV pWfMtl0JV2c/c3drp8ru7mR5Mg5zzjt16Vydx40jgRPIjWNy5BiXjBJOBj2JrmnJJNdTRxTe h5TqXid4Xa8EvkkEpMhIPODn8O3618u/FfTI5C81sEgWQ+YxCjIIJJA6Dqf5U6U29ZdBpSR8 AfFPV5vDrC6ngM0pTy0kMhXe2SCuPb056in/AAc8Wxaz8O45RcRSXkDGNhcS9X44yD2UgcVr T5rS667mcHzNpo9SufEcLq0aETyDKKEPAYLwTznIbPB9PfjLj1STU9GEcEKhC4YqcHcoPXv1 H1pJc1nsU5deh2HhzTbq3k2s+FaRtsqtkZzzx9CPy7V/Qv8A8EVviVL4Q+J2u+G5kzbatZCa AO5wZYyenuVJyPb8+vC1LqUF16iadrs/qNguFENsIlKucAMf1q1aCe1vWd03nHQ85Jq1oRvs Ysks8V6jGJU9uuK7Mvus0keQRYfjBx+FDVhJ3M+O4Z3/AHMYdAxALKD+PvWHahkM7soeZDkM 3b0FFht3MZpLnULtHu53lYMAoY8LzXUTxRm2dIzvdWGWGeaaSS0F1MvXLWSUwSO/lquD8oyf z/DiubsJbY+IVE8TuYyQEBycEnmheQbbmvrV1Jd2UrLZ+W+7Kg8kCqVhp1xd2qscRM6kbe5J /lQtFZsClZaRv1SOGJsIoG/c3BPc81q3dkYXDrIDGR1H1qm0TY4DXYLdlgRVEnmNs25xkYPX HSrMs4EqIEEZC7QMY6VSba8htEeitGb6VUUhy4JYjOPeuguNljdN84kk5IAx/kUm7slO25g6 zJPeqEeNFjAH3Qc8d6u6PP8AZpgCMMRwTyRSfu9RmJ4j8QXkqPb6cBaWykGa5/ik56D0HBrN 0ywbU/EKz3d1JdPFgRiRmb9OgpqCWu7HfobOozXcmsS2iOW44RRwpA4z+dblxaG00giQbycA LjkYFJtpAlfQ5Dw/ZWtzeTG7jZwijYobHPOefyqPWFhZ4lihwM42r9aTu7IaK3iP7JpQtnmg aS7bI8teqD1/Sq9mwi8uSCKSIPhdzr1JPH+TTV3qhPRHsEoIgEZjZ5mUAADPXvntXAazZ/2X IVcbmXkL2NJO+g13K1kBdmMlGjWP+JRUlhZRXevPK5DQKcq+OvHGPb/Gm24ruLmRtXloztHt VY41ZgX6cemKyLLUreCK4jhygPAPI5/rU3vp1K6Gi9ll4kjufLZ+cA9BjrVG9t/L/elwioD8 55ye39f/AK9S35Du0QeF7ee3ae5m2SK+VUMM4/DtVZrqKzuGlkj2uDyR+tKSXQFe+przXHlw MqJuY4JK8461kWGhXF5cymMhIE4bJzmndW1Ha2xBqGkrFCpmVpAoIRSTjB54/wA9q6jwxcWm jWEkiQosvIzt6UpPQVyAXVrNb3NxdsCqg7QF6c1wF5H/AGi5aEp5HSNfX1NQ/e3HHQt2xWyn jDpvYMME45/zzWvfa4bq5dPKXyx0Pt34pKV3boPc5y/UXt800rPhiCFPNQzXMxu1SIFIyc49 fTNK7TsVax2BnNrFK4y0xUAc8CuV0ixWW8uppy8JGSFQA5Pbik1cnoYl1HNLqBIZpG3ZB9q3 IdaEc8wVSZAuWLDJYioe+g76nJiScXDhW2u3J7YGf/r1dazFxM09xM8smP3Y7D/Oaa7sGzIu XgSNwHYMv5CqU/iPT9JmWS6u47chjlpJB/I1nKajeQ0uhxV18atAtdSLxXTXUn8RihPT6nFc tqX7QGmSzTLHFMUBwVIAP1x7VyzxN9l8i1TkzsdL+KUPijTBJpzHAJDDGCD9K/lT/wCC1fwT 1TwnGmufYEl0m61KSQSSJuQF97crz8wcL1wQGGK7MPabsupFT3VqfghL4supvEmjjTrmOOJQ EuIJJxlc9CMdjuwBVnWPFNjpnigO135VsEAaReeRycZ5BGcf/rzWrqJKz1lfVGSXM7n60f8A BKqXR/il+0Ld6fPBbtqsunmXTp7yIbkMZ+d9vUEqRzjjacdef6LpPgy+mzwZ8RF2jGC4hLkn HqdvfNeTilCpNOq/dS91HdCV0nFamP8AF/UIfgV4Li1m+1Fb+Ey7VETMJGyMk4IAwMDvX5le Jf2u9a12eeOwtYLKORthV4g5GDkZJyPwxXnVZcrSTt5hZu728j9Ef+CfHxouvG3hjWNO1e7j GoWtypjUIFBUjnp9Gr9Nbe5W5gYOmGzkMB2r18NzKFupzzeuqH7VsYEYqd2TyFHGenNfLf7c PxAh+HH7Nvi7Wi6rLDpUyqwHO91KgfUlgPxre6atJbkp2ep+b/8AwQd+IU8nhXxh4fnbY8Mi XEEOwg7cYPX8OnHPqK/ob1K/aa2UOcLkfKOe1dEEoaClqx0eyGMh8BlUsFI4P4VkRSJNbGMr ucjLZPX2xVvpoGi0RSNwlsVLQKDwFTOKxdz6jISFCKD65xx/+ui9lcm2nmad9HDb20YZ0JJB ZARk4zil1G4uDZLDGrQoem3qe/ftT1ldLQbTWxxmszJb2x85iQOpZuhHT68AVhWOoEWz3UMb ydQu0dx7VLXMuW3zHc6nw9dXl3A092MoeUAOODyAT+VXjdxiaXbEZJXB5QE8/wCFKMXETkrm SZJfNlHl+Wu7ByO1Z8lyrXDklkQNwQMj8vyoa/4YpJvU7uzlS2sAzT7GPKkd/wAKwCixwvNK /nSyPuz3I7f1p81nclGBqVzLu227KgVixUADr149+K4fbJdam8Y/cOoBY56/l3x/OspO7Vgs zoDbwW9u0Ad5pX6yc85P8609OtbTT7AEQgHBKljjJ7Zx70209th3sznNbuJZfkhIDSHDFB/n 9a9D8GafNoumuLnbI4BIIHf/AAoSXxDTsjP1+9uLvL7vMXduIU8Djgf/AFq59LosmfLI3YwX 6fhRZtaCtfQm8yaKVWRykSMGI7Eev8/zre06WK7kJkkTZngkAfU/nQ046b3DbTcsapBJdxxu hHlEDaDkZPf9B/KuZlKWkMqrAGAO2Qsx7/8A1qa1ukN+Q7S9Ggl8vDFouh2gYAH+TV7UNLtL eViJNiLyoPUYFJx7ahZJnFQlrjVCXQiMnGCeg9f511s97b29qIYV3GPI+XoW4/w/Wkrrfca7 HJTJNM6RyttLgszA8D6GtyZ0it0EClXAyzAf5znpQk9b6+ZF3fU5qa4fznbcAucMcYzXQjUX 1CVY1jyg43dck9/r/OpjJv8AVFJXNB7swwbWBCbeCe/+cVn2MUuoyyhCUQHDMOuP0zTk7PQV rHSaYhsoXaUlhzwByff61TsLuF5XmktgqDO3cDk/59KG27WGvM2I9da63SJbqW6LkYwOeM1T u3mnWRmkwXbaNo7fQ9KlR5tb6MGrlqW0knw7swHTGeQf145qpcNsi2l8qMAkL056fpTso6IY 03aKFKsc4wWUkA8n8ea25r2FNPUGLaRy5Bz9PejmS3C6uUoNkN08sUyhipVFL9f54rpvDd3P DNNdtJuYZBUOfmPfmpe9noS/IxtZs5dZRo4UEEYbczJz1JyP8+tY9jGlmi28NxmVXIwvT3/L pTekrdQRUeNpcuJcsSfbj6VYsphJqBjKAgKSPkoej00K2JpzIYmcRFCWOT7GtizsJo9FlJlJ HGMjNDUloyXchstPD3YLy42rnGemelZmqW8bOql8g8ELTautHZgmc9qc4aaEQoMCMb2bqeg/ X+ldhqMiW1lGqKRkDIXt/wDXqYpc2o7KRFp8LSzCWfLrknkk/hVjUCtxGu9Qyk5C7eoqr2fq FtTnL7w5aLueNREFAwM5xz0rGvraG3Xek7MqjJyOQO/4VLbfusDQtEE8UaSRsqBhgjHpzj26 1FepaKjSzDAzgbedufak22wubGnpGum5SNkQjJ9een+fesGUJ9pY7sHqNx5J+v5UKXP19BNM prJJcuwEhCKv3M43e3vUFoYIWklkAVj0GOn4/j+tEml01Y2r6mZLaXWqavG6YVA3rn/Cuk1W 2l+0GSad3IUAKDjjj07UnDluxNsiiUQQAq5Yt90biD+lZd9tvJWhhDHja756dP8AGoUru8UN O2oahYyobeKHAVex7tUFosiXbrKgJA7n7p7c/wCf6VrZNaAZpEtzdsZnVWXAcr8vPt+FdFdS hY1VByqlckcZxVRTim73Gk27mdcJHBCrNGd7sGJDYzxwf8+lVd7OqNuIi+pHPX/DmslJtkp2 1OhjgigihEMpYc8tyDkevtSX9yumWSJ5wPPJxnqc5/PNO9466Dk1ucdqmpySTsYrYsDguxPB 5/8ArnmrMk/nugiIWPaNqBcgdv8AJBq242TCWhlXyPJLGYgFI4kPoa03uLixmXMgklZCq7R9 0ZHH6Z/zwrLW2w0ktWV0vJ7kgvMZCz5cnuAPeukj18aUpARWlGB8368fjQu8dRPTY5yVrm7Z Z3GFfJGG6jHb2qpJElsFlaFAhwvJ7mpceXz7g9Eaa8KWZ1Y/wheSeP8AP51lyzr56gxlhnK5 z61o5X0ewWSKOoW6XF8ASGIOAAMA5/pnArWi/wBH0tAq+WxJXd2IpS1l5C12MjV4Hh08FM56 nJxnsf5/rWV4WsnYh1jUjPyt/dptR6aocmkkkfu/rIuLy3jgiCrgc7hnAPWr1nZXNrCEGASe o7V1XSViLNu5rTtKLQls4Ufex0965m9WIrDMsmRkFj0yDSjvoDJNXuVs4gQ2WfAG08mmX13e XulosY+zoDjPc9apLuF+xLoUEtnGcSbg3y9OR/nNad1HJHblUtjHGylcls9e5qZNNjWxDcrF YxK8oIRR/COtc9Nd2kV75r7oom7lckGmrvYTsbEhN7bPOZRHDghFkOO+OnrUF1oQubB1WQAb flKnODT5uXQLXMDS9IgfVIUEr+fHkD0P+RX4nf8ABTL4J+V8ULfWLIyQXF8sbXDxdSFYAsR0 OPl9DgZB4p35pJEtdT8uf2r/ABrb+CPDaTPGZGtyXjkJPzADIHXI7etc58JfFukftBfDdpYL aMXlrCVms7sK++MrgDPPUDj3x0pqyv6jtZWOE8aeGLnQPhjpcyl2jtpTbiVyGKsMlBnkZGCp yccdulet+LZX8RfDDSdZjPnXKqGJVcEZGD+oHH41ztvmlYLaJdT0j4LaqY4FAfYwzjC7sj15 rofjtosE1+tyI1S3lhyxVienXjr3NW7qCG1ZrufmV8fvC0fiy08NajdWonljZoJJVwD5sQwp OeSSCvvhj64Pzp4q8XTaeZ7SENDIADhN2cds4P8AnFcc4SnNp2s+pTjfbqe8/sh+ET41+LYu LwIUtk80KzMcHORwT1xkZHXHp0/bJL+F4GCSAKFwozwOOuPSuyFNQjyL7xN20udR4X8N2Wr6 vbx3JURYy0m0YX/63tXjX7RNxDpeiNaKEY2zuguAudwx1zjJ6dKwxMWoXTs+oJ8u5+V+peNT cB0ALuqneyngkE5Hv361yq6ldXs7CRxFDtGxUXYVJ5BGevTvjriuGmpykubTu+5q1fbcxruN /LmkDNIpQEjbncc47/l/nFc9qsLa54WaApseEeZgrnGcA4/L9T613Ozi+z2KuradD81P2itC e98MTNAGhktpQzRRpxtwd3HQ5JU8enua4L9nrTzNpU6hS8AI4DEbgeuVx1zt6nOPxqKNSTSV rLqjJaz10PqrS/CaQiEPItqxRpPMRwwBzzndnuRXWQ2EFnOvlooXOGLEgsAR0AOfXPbpxycP njH93Hcqz6bGzYyhSVYgwBjsVW6gnnjPXHOevpX6E/sI+IdS8DftK+E9RgjkaGO7AZUAJcMC rJt+hznPHIrswMJKpyx7akyajF9z+2zTZBLaxFULIQGyR1zWjM0lzrcO0eUowAF7Vb0Zmhbu xS3lmknl2kuAhI6nqf8APvVuNluItijcseDyepqdx2FtLqWJ2VSrKD83GADWIImfUGjIBJye D179KBMw3tJmmkhZxGgOQWPXmukv5oPspjhIklfgkdv/AK1V6CM/WpJvIjlC7zEvyJ2J64Nc voNvdDXJJpFETyjJJ/P+dCtbUHdG7qqu8VyGkG3lTzgda5WwvZEiViQHkYbcHoKat0F1LP20 x6oiO2H4OMdvX0q3rEt1dxrBCqpCxJDY5/CmrP0DUyvFESWNhbSINrE9G/nVeC5lXawfJCDH HbvRZyDYybG72a1OIyZJ2UE7ckDFdxL4ZeKJpHKxyt1Ydh6n8ulN6K7Fa78jldUj8u1Co2Xb BB9j3qPSrWz0J5JrmQ3U5QKiBiT78djzQnf16Auxz+tSQ3cgWGFoyVwFYZ5/ya7S28KT2Fu5 jlWKQRhg27BBNOT5VZlPUr3lk9hGvkEGZ4ySzDOTz/XvWVc20o8MiR7jfLty2HzjHUZqboXS zZgaAybW8sklfvEjOfxrP1G8WxCPGwluWDKmD9084ajW21gXZGcsZ01IZL26NzOcj5mzjr0r oYvEVpCJGmGXDB4o1Oc+1Skr+6U/M9N0S6m1e0V4kZCeSTkY+grmdSjkjM7yDcyjoeTTa5Xr uJP5GPN4mhtRLaKC7OME4H+RV9Lm2s4IXeTyTkkKR/Sk7pXtuCfQqag+oeJ4wYAqwCTk9279 vWl0TTboXEsSQgkDO4kHHt9aFbuCd/Q0r+f7G6maAPJjACrt9s+1ctfoZltshvMbJY5+7zx/ OolqVa+hs6csloQN3IGduP8A9dY2rb5Fy2Wd2B6dvp9Kdr7dBrTQ6eaC0sLCNHcvIBuJDAYJ rmrCeF7qZInZtseFDDq3f6Z4pX5mGtjPkiE+oXEa3DeXGfmY5wPpmta4uoYrJVjG5cYye5zS voO5mLpj6rpyRs5hhd9zsemMntTdbFlpoSOACY5A3AelQ/MWhkPKLm6VIW2tkEDdXYyKkGJc BRjDZ5AoatsPTYzNSIZ3MKNJJg5IHSuWtmLpDtTyz5g3bql7XG+x3N4JbOIqm15SRn/9Vcg0 N09+0ruFLggk8DBqn37AYk9rNdX/AJXng55kOevbGa37DTI7W6LhUkIQgAHeeaz5Uxpa3Rk3 MVrHcExDfI3JL9h7elS3d0LWBsjBIz9KmSdrA7Hl/ie5kfRibRFBKsEZuMMR1+n/ANavinVN GvtU1HfdXkLyg7iZLgDPBx+PINc9WKaTei6lU3y6s4/xlpjeC9FutQ1OQCzRS0rxTI+McHkH pnHf8K+KPFX7T0djceXoWmG8jUbS0km0g4yPlHUduWHavPrKUHZK3946EnJ6bH0t+xD8ZNW8 UeINdsdVSK0llgS4gxldxBKleSc4GDxXa/8ABSvwbF8U/wBkPxJaXNuDeWWy7jxEWMZGVJAH Thv/AK1dmBqc0U769zCq9dT/AD2vEE7+HvEDXIfd5U+44QsIxzjkgZGRyK5rxFrN9DcFHmYA KJDKxC+YHUfLgHOAc8HnnpXqJRjecFd9zNxstT9Xf+CPmg6nrH7UsPibT7hXfQrZrm6g43zQ yrsZRzk/dJx/ujNf09H9ujwfqd7LbQ6J4geVM7pF052VzjHHH6eteLjYSqTtGN9Pe8jooJ2P nr9qD9qu28YfCWbStO8EeIby4eVGtpH05oojg/MN7YxxnHbj6V+Vdr4d8W+Obsxak9l4RtZX Pml52nkweFO1Rk9RkY6nrXNh4uMX7RaL7Jck22462P00/YJtG+E/j/TLe0N5qGmy3Sm9vLmJ UMhGVyAMjHPGO3XqRX9D9nfrLabgmwchlK4wTzXdhJ80G46LouxjWd5FCW/ghjDSo5PAwDnF fjV/wWG+JQ0r9mqPS45jGNW1JYCNxyFjBckEZPUL25GeR1reTcWkZNWPgv8A4IW+PY9G/aem 0oN5UF7prR5Y7Qx+d1+XtgAH33Lz2H9eF/aRtErpIGw4AJPX8PSup6N9RSbuk/vIbq6gZiQW lkxg4GQMfSsOFdqyFiWHXjg9+351pZvyHYjaKMRLISQ5OVLcbhWRcX6xbo4WUOTzhux/nWd3 fyB3SuLcWy2sCBQE3nJ29vf9a2Jp0k8hQrhh1PGPTOK2fKl7u5L7HI6iiyXccRRZgpwS54J9 Se3/ANauu1PUJNP0pIlgiRgoWMRqCFHr7n3rK/NsS9FoUrSVnsGQor5ycN09uPxqrYXR0+0k 8tFjYsBkc4HvTT01Ldk9Dn7i6E9y0TdeNx4x16VVhjiXfthIZmPAHQH/AD+tN6bCV7G3HClz ZIojAUKQCD1/Os97aGK0cqcryCWbOKe6Bq+xRuI18xgTkAEj8O1cTLbI96pV/M3D5lUAAj14 rGWmi0aKXY6R9NdrFTGdy8buegzTlVJgkIYgseTngZ//AF1d1ewNX0F8QXMGk26pFKdpIUEH g/nWjouoRm0DyXILZKtEe/8A+upbSHay8zR1UzPeGUEIoUBQpLADHpWXqEMFpptqPL80kjAA wDj2P0pi03RQuJZCELlcHA25Pr39/wDCt62t7e6UJDcRqm3DAtkKeh49aUp8qBMv6loJTZLH MZH2/KAuMH8T06+n41xN3Y3dzCqtMFYEnerfdP8A9b+tG3oFjeN69tpQVY2CLnJJJJwOpP1r JjS48l5vLJbbkAdvr+lFu2wXexgo5d9zJlA3zYBODVmyjgO5yrAgcNtHQf8A1sdqhS1HsUjb RXheNW2gEkjv+dWpVeG1ZoxliABx0/z/AJ9xybfugrow/sktzBNI6AoSMBh1/wDrc1paRZSR A+S7NMTtznoP8iqtb1CLsbnknT41d5BI+CxOAMDn8ayNPvdyu0KYbcVYlic46j9RUNNfqS3q awu2gtHDAyN/eLZxn3qvLqEjpHGkS+WAc5GMk+9N3SuvuGmaUTRpbqqt5IJ+c+p/r0ra2Gcx tsBjzyAB6Um9dAb1uWXmN9c5TNtCmRhu5z+veud1C7jkjbYuAOVU9/Si7g7vUVra9yZZVuvM eVSylsL7++PWn+INRhsrVHAZdo+bHB6U1qNa6HK+HZ21e8ka4yseMqQeev8A9au10sukczxO VQkkf5+uaVr7hN3RTkv726h+zIRFEwOWAA/Kr9tYxWMQVyGkGCAOtJyfTcaSaHTpGsSNuwxH O7HH+fetvRrKOKMyi4WVSCSemBz/AIdafmxu17EF7cyNCEbaUdsR571myh00yJDM+WbGB/FR HzXoyUne3Q0dPgM4ZVXBBAII4PHFR3TQafF87BZMkAHqRihySQmrM4yO8jvtbSV1YxjnO7gA fWt+9u1dgwTyo1wUHr7f/XrOG97adR2tuOuLtRAquwKhBjauMVnTX1vHCpjTzWyQM/wnPP6m tGwV2NMcQt1aZBJOWx15HNX7C1S/vmVkWCBFySw/MYpNN9RNWdhl1ard36ojqAvOAScj+Vcz qMJjuVUOJUJwBjr6deM+9K8degLqmdILuT7IQq4V19CckdP61zUrlWDE8Y4PU+/4UmrO7G9V qWWWFdNeaN9rFcYB4rLi1YLZYUiRs4G7tSdoq/UaaZu6Sz2StcgjjII3DBzg/wBKgu9dF/qD wuASU272GMDNCbj5iS3GxWkLSIxm3KigMO59uO/Ws54razDyRyFVL4Hmc5/Xmm7O76CTb0Mv 7U8N6GibzFY8nt3/AMan/tFNPiaQyAu3GRkE59x9aXNa9tRqXSxRs9twoYsVUtwD+n9K3jYC OQ+R+87l2OefT9KpKVtdmO972ObudQKXJ8xMqzYYg9OPf61BeS+fHHEoKKAOfr7f560W2aHa xWeK4inkiSTCA9P8/wCf66Wn6LPrbCFpgWV9zE9COtF09H0Jt95E2lXX2p4EkEqlsEKv3h9a uT6RBasAsrNI4yQx471FlHrft5EvTc521t31W9lVJQgfByjZ5x/n/PFdBqWlPpiKrKZGJLEn AI4/z0p3TlZblNX2MSxESBnKmRs4wOMH8Pamz4klZpWZP7vPQn9ap3a0E46kEk7iEKjnaeFy T05qKW4N2AXHmbCCQG5x+PbrTgnbcEnYklvW8s+W20DjcFJGRVWzlW7iYyyGdtwyccf54qPL r0KXcpiATPncyyE8fT6eldJJYBzGDKGUccE/ypq6+QtdjmNV1BrlzborMcEEEdT9a2YbJ47L fGxiwCduccemeBWkknpEdlY/dWPZdl2X5SDgBjisCKOaXXJA0m9VGFUNxXRHzM3qbW64uDLb B9sWAPuYqC4lEdubWNFd1GXdgOKF2QepS1GZjp6NGu2TcMMP1rTWSWVVDH92VxhhTa01BO5h 2ytf6wgV8RpjaoY8nv8AWulu7J7maQNMxCsCFU8D8KJO1gSIr+1aeJkkcsqn1rm7bR11u5Yy SBUt3BJIzk+lEXZXBq7Nq7jt/ssgUEmJt33e1Nu5I7hY1hOQ339vAx2FF29wditHpaxSAODk nACdRXxR+2n4Sg1rwRHcRkDULORZXx8xVD8pye3Wmm29CZrQ/ma/b+0B28AfaYEDCJ8OrkdC Rgmvzo/Zf8Sy+APi1p89qAscmI7hYvk8wYGd47scdSOpq4yanZrR9R0762P3E+J3hay1z4R3 lvb2yQxIhuUIHGQ25jj1+9wO9fMvwRnfxH4C1jRy28wyM8Y3Y+Vhkcd/m3f54rKUdWurRSfN 6lz4T6o1lfvbyKY2EpBUt0IOOp57Dj8c19eeOrRNa8HxzCRXkgA3HB4BOCOPrnH86UG3H3lc Un2Pzo+JmkC98K+I7IRsxt1iv7dVB5+cLKvrnBU/gO1flzqUs2oSSGaPy0YYUyE5DKpx05/j P1z9K5qutopWKSvoj7e/Yr1600X4l31stwS7xL5cbepJ7e4GDz2HYV+sF4RbSK7J5RJBCbRx 6nP+etdkZSaWtxSVnqa2k381rqESOzquSFYNzz3wOvNfPfxq0+e4EnmkybcrvfBzk/gAPXI7 VnW9+4J390/NjUxHba3cWhPlBCDgDoSOgP4n8KtwZCyB5NsjchSOAeMjPtn9K4bRnpsomii7 X6D55vKVYl2yScgu2cEn8Ov1riNEKafqc1qYgkckRVSMHbgcDOemSa1UuZ6fIaaXyPmD4nWB mu7+2dCI5VCAHGPTp9Scf5z8sfCLXl8E6/dac9u0Mcu6NzjOGUk5/Hrnp0PsLpTdRuDVpPcj m+09z6S/ta5lKLCokhDEbskAj+7+HHfrn2NX7W9jvoyshiLr/rYELM3PTkdRgHofoawUGpvS 7vuW73PQNJ8Jy3i4eMwrG21Szb8dCD1OO/X24r+hv/gjdpmnP8S9bgk0lbm+k08SxXNxCGeJ 1bDEEjIyDzjuK9PCN+8lo0tSJq1+/U/o6sUmjmWHaXbgfL2Paty/kfT7hJ8AkDCj09fxqmZi X95I/lBIyS8gwQB8xPQfnWhpGnz6fFJBJie8YkyENkLyePwqXZBqyhPfyQXLW7RMGGCWPGRX O3F59n1lmUFWfG4k/pTitSWzD1KZ7vVyCNo4LMxxiuw0qSOyWdY5AGHTgHORTastASvqUNS1 Cd9OeFDlifv+lciHeK+DNKyqq8KO/tQkl5id2aV5e2/lTxQKzSOPlyM4HesbRpdu9rphgNhd 47VaVldg2jUuNLj8RaxDElz5COpJfOOP8+ldtrLw6fZxx2+CsShRk+gqW9kVbqeb+ILy3ewj mkZnd2G4KeF/DrV/UtTtjNZ29qvmIQPNIOM88jNNp20JumVtQv103ViLe0jjO0g45OO1bN/N KlvDvZi8i42d6m17X1BsqWMKpFK06736Dc20IB2rG8I+VqOrSRMokn3bTt/hHFPqCN3VAlpq AjWFC4OfuhvYVVuNVFv4gjgZRLPJEJJCxHA5wMUbjegmqail2hSQIhxgBT78/pmntp1vcWJS GQRQIc/P2z3yaFovIW+hjs1vp+mXEsRDxxD5WHRiff05rgdes5GgkjEapIzAiQdRn/8AXQ1d 3GT3GkRaVFHJJtZiOT6VRsoPP1ZJAFMA5OE/qaE1J+g07nttrrkF5ZRQWpwDneU/T+tYFxqR sYryEJvZ8BWcZ781LT6isjG0bSbfYZCnyrj0APrTtZe11CWFjb4iBxkMctQr7dimX4BGkkjq MAv7cfhWfa6vO3iNoEIWGJcsVHLE/wA6UnfQEuxf1QXN7tWKIEnl3ds4/GqupQrbvABFvcY4 zx9aloe/kV3u4or4pLGEaQHO3PH4Gs7VZIp7kYLOBnDMfy+goT17gtHoXItiaU0s9uzSvzkn 7vFYFhKYTK6x7SQcE9qUk1qwTSMG2jYXEjyvleuM/frTluI7mBQYfKVGJDAjn2xST5h2tuOa djbIkYKg9c96q6nAx+zkIVJbCkdxjOfepfusdrvUr3Sw2Opsn2gTSAjOF9v0rrJLJpLdpmRY olwPvYB4HOD/AJ4oT6CZhau5iUxwS7XIyWjfHH1H41zS2EsDwKsx2lxliecZoumOx3N9bxWq yzb9+CSGU53f49a5aa6aeV3O4pyFz36D2o0e407EMVhbQWqq8wjlHMgVTwcVpabeWVilxsl3 yleMjrUuS1Vgu2cyI1nkkY3ISTqQD/X6Gp57SC0t3le681hFlh6CpbvqO2p4b4ju3ttFujIH dWQkDHI44wPyr4Im/aC8HjWJIZNfs7a7jYrNBJcorLt68Eg8YNcuJTlDlLjZXPBPjz+0B4X8 R/DnV9NGpR3RlQGIw/MCQQQePpX5S+HvGesatq5h8O6BcaheTTFFuLmMwRxnjoW6j6ZrlxOH c6cVJ8qT1N4Kz1Wh7s3ifxx8F9SW+8Ta4iaksPmWVpYxkRrsYEgKTkkjALccE8V+1H7U3x88 H6F8C7qHXbmOFNW0giK0KqzSeYqgDaTjI3Dr6VGAqQlF06Su4O1+5lWi1JeZ/ndfHnRJPDvx Q1C3RgSWJfESjy2LHHHORgg5+npXk2suNQsxOIyjgxhwH3kqFJAAGV785bqB6Yr2JJ0vi6mC aV0z9Of+CUetW1l+0u63EEsJm0a4jDBD+8JTeoyoYkgxNjjjcfYj+1D9kPQdN+JfgC5c+Oxo 0wQxvZS33luhHPQkHH+H4DlxHKm5yVk0b03ZKMUeS/tlfBjw34b8CwXWn+NJvEt0jLtikmMy xYwGAAGQcE45r8u/CUGn6R4oivJtAu9XleVV8udmijJ4OTkEnGB90E+leLCdStCTXuW69zZt xem/Y+0/ir8Q9b0nxb4f1TWPsmnXbNFNY6PpsSrvCnKs+SzAcHO/HX7or9lPDmr23iTwlY6p G6QJc2yTY3AAqwDA4/EV05Zb2dtbd+5jV1d2rGXqepWWrJJam4WdyMjytwKgd9y/41/Mx/wW f+JqXXjzwvo6XTR2lnbyvKiYA8x2KMDjvtCdu5z3FepBc7UHuZqSW+qPiv8A4Jv+NY/AP7WX hi7W5YRLfoZlPIdi20EHqFIzx789s/3cajIyToj/ACnbkL6/jXTtLlvoS5pvQ19KntbG2kDR OzMMkgY5x0/SvnXxP+0R4P8ACkdxb3OuRiRMho443c8deQMZ+lUnJ+6iZSUVe54h4j/bC0Dy AscN1Oi8K21EGD9Tn36V5gv7Z9vYQGOy0ASJ1Vp7gnPvwPpW0cNVeqWhjKvGKvc4fxD+2/rc tpK0cdnYKgJ3iLJUDtls/ngfSvUf2e/299D+MmrWOhuki6m6bftPyhZSMgnaOnI6j+taSwU1 FzXTczhiFKfKnufZl9p0MckSODMryAsmRkg//rra8VreJqSWttE0EKxj55RknPQVyXOr4Rpu 00mEqweVgO54zinJdS3/AJSIjPEMtKzrgk+nHT8fWna7K9TN+y2e9034UfMwBLHr61RgnEsg EI2Dks2M4OePp/8AX+lLRbbEvY6Jkd7KSGGElQucxr6/rVB/DwazhjnyU4YrnGT7mm7MaaSK OozW1tZrDCiqqDA+XBrzSFIZNUzLKUiGdu0fePpWc11lqUlfU6a9uzLCEQyBOhABGcfyrR06 a0FgWWMCQEkkNncc84/xpfa2IWpyfiHfOUUJgmT5Rv5HPB4+nSu28M6OYJIl+VGGDgjOKbG1 0LniG5eO5VmBWEcqBXNXV3cXEFvMUVncZATgKMkfQ056DsvkZYhvJLidiyuuPlUr9wdMfXvX W6b4XMiCWSbBO3JPfn/61CaSs9UGljQ8QwXdxeIplIVOQATjIrMmsbi2tkJZlkLYGQenr+gq ORJNibS3+813s5PsESElR2AXr9fbFZVxILeIB3JcnjAzmknyvT5jdlqUrCweTEjKXUN90V0A 00RwyNKobI4xzzTSsLqc42nfaZ9kQwzH5iBjdnr0x6/rXQ6lpKWlkEf92QM8k8YpRd7u1kht nC3YYXDYSWaILkbI+F9OfYYrbtLuCG3aKOEpLtJDbePSr1ewavYV7KGHTVaSZyzZGzPWq9rY JawyJEGVRyckDPH4CpVwepKtp9jsiwXedwwg53GqUy3EjhVCqT1y3QduPzqU7K7EvI0dJ8Ny XSs5dcg5CAY3DnrTxHdafqM3yhWUEICTgA9vaqi4yWgJ2LEGktIsjMyxtwT3we/Peue1KDzJ 7dQxaTPK44FKpb0LbXQ7S/0u2t1tow7bjgEhelVtViR2CGEN/tHnB/xpxsl59yV3RJajT9Ns JEWFpJ/4tg6VAsQaGQwsUAOVBOMVDm1HTQG+VHLXGoSxXsdvGRjGN2Mkf5xXUys6w7ABIQck gDn86UVbXcW68ytFAXnaR+XXhTnvV+6EuneGXcRqZpnACHuMnNXKaWw3cq29lc300JZFVEAL KW49sfrW5rpNsIYmTJJyjAfl+NCldafcF7O6I1Mttp0SxusbMSx5H9frXOXHl2HkySK07dW3 HOMe1RFX9R3v6i2aw/O8UuHPVScAde9ayxh79DND5kcY5+Y/iaUU1uKT7mi1zFqETBIfJtlk UbnXlxg/n0NRhIJmZEQKEcDI6E+4P+eKb2a7kvXQz9Q09V1QOiFlHPP6ViajqNxdb4VUQJwp cfXH8zSb7fIp3Rn2myCKbKlmU+n8vwo0/wAy6uI3dJChOMAD5evPPTpUKF32J1Z1WpXjRweW qgAfNwPwrkYpDGuSuWcnAx0B9+3StlFv0Ls/Qz9Q1c2OnPAECs7AA9lznmnR2nnWZngAIUEH J44OPxqeXoxaLcr6Z4Xmkh+1SEqgbON/36rywyz6ikUgKgMR3IIoklu9xNX22OplSG2d02bQ RgkcZHY1z81wTdKHjJXOc9SeOlO667CtZox0nMsjEqsbZypx05xn+fFVri4aZDGG3AvgsTnI 44A/OodTl6FpWd/wOqSOOPTizkADBTA54rNufPtod4YiIqNoDdvSm3f4gVnqtGc7NO/IVSSo 2naeGH9a07q3u7jaSRCoA3beO+alxaja++wNNblSCJlxHtd2cZyBnPpzWyLyW3i2RAgspyC+ MAYx/M01HuC1ditalrCUSxIftAXGQ2AAe/p3qFrBNSzHO5AKFn5H5U02tkDWpFo+mPp8zSAH ZtO04xj05/Gq1/fO10xLMRn5g3OcfX61Sg7t2sxKN2xkd/IbV5ZVROCE+TgD1/L+dQfMAXkX dGRjAG0fhnH61nztSHza2JPNV3AYKsO7C4GCPw6VYisbR41SOQrJ/G+cZFapW26g9NmZd6Yo EYrHlSSchiN2eP6ULI/2dvLjUIBn5geewHtzipa19BPTUrQmKG7EoG4spIB/DH07/wBKfa3c tzczFlCRMvAyRxVLuJLW5mT3af20iW/+sRtwBOQSOtdbr2oSRxqjKXfyznAxz74+lKO91pcb tsj9yrb91uhMG1+vy1x+tyrbXVq7TF5s7PLXAwD7CuuHxES2Ojkul0+NSpAZ+AARzmltxFbp IeVB546sT/8ArpNMdzNu1a6jEe94FH93jmptJskudiPvYLnGWJ71V7IVrlOU2Vmpj83bKxIX YDkmui0SKFNHbyJAAcliDnNJ3aBWuU4njOlusas0+CTuHr71ZtiYImWKMNJt7L196TGYmWa4 YSXOXcfcQfzrYXZYWcbMDszhcDGcCh9kJaas56ScWivJGm1ySxLjr7Vyus6DaeJ/A+pafPEF S8icOFBOcg8/nV3aJep/OF+0J8LD4m8NaxpFzEXljDoyFc/MoI74HUdq/n+0PTJvCfj2ESQ4 MNwIpk24JywBJxxxkknpwa1jUamn33YoJPRs/oV8DwLqfgaGCRvMg+zhV3Z7jHXoetfDPgUH wJ8Y77TWizHJO6btmdo+8uT24bA/DtWVV809N2aRfLfqaWs2g8IfEeQOCoYCUEsOh6cn0wfe vtnwAian4WntZH3RXEbIMkkHdkH6Y9uhFZ00/hewNq2p8VeJtGTTfE1s11GDBNI1rdF+ojl/ d5OT03MD68DmvyW8c6RJ4f8AFdxY3MMge2uDE7kdMP8AMuOueD27jqOKzqSUEOMlyq5X8AfE Z/BPjCzv7cbmWdSfN4Yxjr098cHHB68V+5nw3+J1t8Q9EjureZLgKgY/P931/Mn/ADzVwtZN fcKUXL3j1GJhcTAQlo1HIYNjDcEjpn8vSsTx9pw1LTJnxGGKbcZzjIHP4/1q5NNWf3ij7rPz E8baJHb+ICVPkI7/ADEZyOvfk46DHv7VwUEEt2qJKiRREZCSkFlOcgc9T249c5rinGKe+rLe 2posyxySLIwVGO6QFeGPf8eTXI666W8xuVmUqCPlj74BPQcn6dyBShq15aIqLWz0OU8Z/CLV fjJ4s07R9AtXvNRv3WOyiU7N+/gL1we+dw4r4J/ab/Zy8V/su/FG40fxVpVxpM8chYNKh2TA dWRvusM/3fSu+lQil7S+/Qyu3P8AI8nu/G8msWoN1fKyrMnyJ+7OVCkuSMZJOTmvc/CHjeGd I18hiSmJNp4Q9gSOSTjt074rL2cE21pctJfM9v8AD3xCv7qGFoYxbMcAxs+/aM8j3Ixjjua/ YD/gmL8XJvh1+0RormZ0jvnFvMsfztNv4C47DcBnP93iujCq03C+4p7aH9h1qL63uJvlUSyt liRzn0qHVbR5oTHKSWTGSG5//XT0T0MtS7qE8MTW8jSMqpEOp6n1qDw5JOmr/ankEMDKcAno aStZtgypeXIneS4lkdbePJYoeXAP8qyNZljlv7R0UwI3OWbp0qorYbfcoeILtV3rbxtI5+Te RwfzrQtdMGnwQfvBEGixhjkkn1prRC0LD20D6G4jYGRBndjknNeX3Vjcvf288shBLFdoHT0q ou71E7vY7eC3jsElYeY8snG7fwo9Mf4eteeojC/kBYsNpIBJ46kcU4vmbuLc34Y0t2a7kSSS Q4G7Bx9B/wDWrsdE02CO2nuL25LhgSkPTb1wc/jUyfYdkjkNUuILnTbhmcIq8ou3nH09Kyrb UVultljYhFTb19KEtdRX1sQyaiF1m2JkI3K2AT1PT/Gug1LXZry5hVQwlzgyYwFFCV2U1pqd FcwiKyYIzSqf4m5z61gaBqVvpUc1wkQV5sKm087f8k0JN3sJOwl0qwzPcqCJGcbQT0HfijQb m3g1N7q9kCfIRuYcsR/kVOtr9R7sozSwahq0lxJcNDaBQUUKQXOeeO3WqGhwXniXULiJnddO DZQMR8w/D/PShK3xbIG+xa1C2/tXVorTaYLCLDMI2I3nPQ884xXKfEC1uQoFuTEgfOWPOAfT rSb/AB3HZMVdEfVreGeeQLEACW7nH0q3d6PBfiKC3n/eSEDHIwBjPP405Lldlt1BO2h7XoHh +HR7JY4ApdFy7kggn0rz/XnmOtMCQ5fgeWM4oT5nqOw2K0mjV0RgQykupPIwM/qcVmxgFEBH
May 10, 2015 - Present
RV10-Archive.digest.vol-kn
