RV10-Archive.digest.vol-ln
February 02, 2016 - - - - , 20-
      First of all, did you open the hood and look inside the boxes? Most people do not.
      For example, the Dynon uses pitot data to obtain the attitude solution. If
      it auto-detects pitot failure (notice the 'if') it will use gps data instead.
      But if you lose both you lose your attitude indicator. Odds are low, but are
      you happy with that? GRT will still show attitude in this circumstance; Garmin
      I don't know.
      Other stuff:
      I fear single point failures taking out everything, so my philosophy is to have
      boxes that will work together but can stand alone.
      3 attitude sources - GRT, TRIO, Dynon D6 - all independent.
      Battery back up
      My touch screen experience is limited to the GTN series. I dislike it intensely,
      even in smooth air I hit the wrong thing! But maybe I just need more practice.
      But I like knobs or buttons.
      Agree with others - 2 screens are good, a third is only useful for a right seat
      person.
      ADSB. For x/c get ADSB-in now, for the wx. You will want ADSB-out by 2020 because
      the -10 flies well above 10,000', so it can be now or later. But either way
      think about it now, because it feeds back into your choices. e.g., there are
      a number of options that will display on GRT equipment; with Dynon or Garmin you
      have fewer, and, more expensive choices. If buying all new avionics as you
      are, with an ifr gps navigator, the mode S-ES route may be less expensive than
      UAT. Look carefully at the numbers and trade offs.
      Bob Turner
      RV-10 QB
      http://forums.matronics.com/viewtopic.php?p=452534#452534
Date: Feb 02, 2016
Subject: Re: Choosing an EFIS system (was "and brand")
My 10 has 3 screens. The right screen is for the co-pilot. It's out of reach of the pilot for standard practical operation. I installed it because I want my son and wife to be able to practice flying with instrumentation in front of them, and also be able to check out the map/weather/traffic/AOPA airport directory without impacting my use of the PFD and MFD. With the G3X Touch, I think it would be possible to fly with a single in front of the pilot, but as I'm currently getting my instrument rating, it's FANTASTIC to have the PFD full screen with upcoming waypoints in the inset window, and the MFD split screen between the approach plate on the left and moving map on the right. I will also split the PFD to pull up info like the airport information page, or the nearest frequencies page. The functionality of this setup is incredible, even coming from a G1000 182! So my OPINION is that VFR, 1 screen could get you by. IFR, I think 2 screens is far more practical. 3 screens is just fun, or if you want to have someone who wants to "pilot" from the right seat from time to time. ________________________________________________________________________________
Date: Feb 02, 2016
I have a G900X from Stein installed in 2011 and have not looked back. Today I would probably choose a dual screen G3X panel. That being said, I use an iPad mini with Stratus mounted to the center support bar for sectional and other info. A third screen is very nice to have and the iPad does that job well. Dave Leikam N89DA > On Feb 2, 2016, at 5:03 PM, Ed Kranz wrote: > > My 10 has 3 screens. The right screen is for the co-pilot. It's out of reach of the pilot for standard practical operation. I installed it because I want my son and wife to be able to practice flying with instrumentation in front of them, and also be able to check out the map/weather/traffic/AOPA airport directory without impacting my use of the PFD and MFD. > > With the G3X Touch, I think it would be possible to fly with a single in front of the pilot, but as I'm currently getting my instrument rating, it's FANTASTIC to have the PFD full screen with upcoming waypoints in the inset window, and the MFD split screen between the approach plate on the left and moving map on the right. I will also split the PFD to pull up info like the airport information page, or the nearest frequencies page. > > The functionality of this setup is incredible, even coming from a G1000 182! > > So my OPINION is that VFR, 1 screen could get you by. IFR, I think 2 screens is far more practical. 3 screens is just fun, or if you want to have someone who wants to "pilot" from the right seat from time to time. > > ________________________________________________________________________________
Date: Feb 02, 2016
I can see the juices flowing in your CFII's mind as to what items to fail on you. Say 2nd screen, GPS and whatever it takes to reduce you to one VHF nav, without moving map. On 2/2/2016 4:03 PM, Ed Kranz wrote: > My 10 has 3 screens. > With the G3X Touch, I think it would be possible to fly with a single in > front of the pilot, but as I'm currently getting my instrument rating, > it's FANTASTIC to have the PFD full screen with upcoming waypoints in > the inset window, and the MFD split screen between the approach plate on > the left and moving map on the right. I will also split the PFD to pull > up info like the airport information page, or the nearest frequencies page. ________________________________________________________________________________
Subject: Re: Tow Bar
Date: Feb 02, 2016
Thanks Les - it was long enough ago I forgot most of the details but that's what I did. The heli-coil touch was good engineering. Without it, I'm sure things would have stripped. Extending to just below the surface is the showplane approach - very nice. The extension with large washer approach is the 'ham handed tow bar handling' approach. Both better than stock I'd guess. On 2/2/2016 3:41 PM, kearney wrote: > > HI > > A few years ago there was a bolt / helicoil / tap kit that was making its way from builder to builder. > > The intent was to use heilcoils in the bolt holes as the raw aluminum would eventually give way. The bolts were longer so that the head protruded out of the pants. A large washer was placed under the head so the tow bar never was inside the wheel pant. This prevents wheel pant damage if the tow bar slips off. AT least only paint gets scratched and the F/G doesn't get This up. > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452533#452533 > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 02, 2016
I did the central 3rd screen thing combined with a Stein canted center panel so it's turned towards the pilot. They are 3 GRT Hx screens and each can do any and all things but I use the center display as a MFD type. Looks great, works well but..... ...after flying behind it and with the opportunity to redo - I'd mount that 3rd screed right up against the pilot screen. There's no reason to spread such information out for the pilot. It looks better centered and separated, it performs better clustered and optimally centered for the pilot. And one big well designed screen should trump 2. Bill "personally, I really like the way it looks" Watson On 2/2/2016 3:19 PM, Stein Bruch wrote: > .The 3^rd screen can be a nice central MFD type display for autopilot > controls, engine info, vertical power info, flight planning, etc.., > but again a very personal thing. > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 03, 2016
Do you have any pictures of this setup please Les? Warm regards Patrick > On 3 Feb 2016, at 07:11, kearney wrote: > > > HI > > A few years ago there was a bolt / helicoil / tap kit that was making its way from builder to builder. > > The intent was to use heilcoils in the bolt holes as the raw aluminum would eventually give way. The bolts were longer so that the head protruded out of the pants. A large washer was placed under the head so the tow bar never was inside the wheel pant. This prevents wheel pant damage if the tow bar slips off. AT least only paint gets scratched and the F/G doesn't get This up. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452533#452533 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 03, 2016
Here is a photo of how I extended the tow pins and used chrome hex bolts. I also used a helicoil for the attachment threads -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452562#452562 Attachments: http://forums.matronics.com//files/img_2987_151.jpg http://forums.matronics.com//files/img_2987_396.jpg ________________________________________________________________________________
Date: Feb 03, 2016
I took the Bogart tow bar, cut off the female pickup ends, and welded on pi n tabs that would go inside the allen bolts.=C2- That way no other tow ba r will work.=C2- Disadvantage = no other tow bar will work.=C2- Advan tage = the holes required in the wheel pants are smaller, and no one else will try and use their tow bar to move my plane.=C2- If I trust them to move it, I will leave mine with the plane.=C2- 6.5 years, 800 hours, no p roblem. Don Mc From: Patrick Pulis <rv10free2fly(at)yahoo.com.au> To: rv10-list(at)matronics.com Sent: Wednesday, February 3, 2016 1:40 AM Subject: Re: RV10-List: Re: Tow Bar Do you have any pictures of this setup please Les? Warm regards Patrick > On 3 Feb 2016, at 07:11, kearney wrote: > > > HI > > A few years ago there was a bolt / helicoil / tap kit that was making its way from builder to builder. > > The intent was to use heilcoils in the bolt holes as the raw aluminum wou ld eventually give way. The bolts were longer so that the head protruded ou t of the pants. A large washer was placed under the head so the tow bar nev er was inside the wheel pant. This prevents wheel pant damage if the tow ba r slips off. AT least only paint gets scratched and the F/G doesn't get Thi s up. > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452533#452533 > > > > > > > > > > =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Feb 06, 2016
Subject: Control Stick Slop - Bushings
I've managed to run into the control stick slop that a handful of other people have reported. It looks like the bushing I have is undersized or the bell crank hole is over sized. I haven't dug far enough into to determine which it is, but I'm betting it's the welded part (IE: Bell Crank). I've thought about building a custom bushing, but thought I'd order one more set from Vans and be extremely careful in prepping it, to remove as much slop as possible before going any further down the path. Looking on Vans site this evening, I can't find that bushing anywhere for purchase. It's labeled as BUSHING 065 x .375 x 2.313. Have any of you successfully ordered as 2nd set from Vans? Just wondering it it could be hiding under a different stock number. Thanks Phil ________________________________________________________________________________
From: "RV10(at)TEXASRV10.COM" <rv10(at)texasrv10.com>
Subject: Re: Control Stick Slop - Bushings
Date: Feb 07, 2016
Thick/thin washer for the slop can help. A pain to insert but may work for your case. Gaylon Koenning > On Feb 6, 2016, at 20:33, Phillip Perry wrote: > > I've managed to run into the control stick slop that a handful of other people have reported. It looks like the bushing I have is undersized or the bell crank hole is over sized. I haven't dug far enough into to determine which it is, but I'm betting it's the welded part (IE: Bell Crank). > > I've thought about building a custom bushing, but thought I'd order one more set from Vans and be extremely careful in prepping it, to remove as much slop as possible before going any further down the path. > > Looking on Vans site this evening, I can't find that bushing anywhere for purchase. It's labeled as BUSHING 065 x .375 x 2.313. > > Have any of you successfully ordered as 2nd set from Vans? Just wondering it it could be hiding under a different stock number. > > Thanks > Phil > ________________________________________________________________________________
Date: Feb 07, 2016
Are you talking about the OD of the bushing being undersized? I have seen that before, although usually stick slop is because the bushing is too long and the stick base can slide forward/back on the bushing. In this case, just shorten the busing. If it's the bushing OD, then the only option is to get a bigger OD on the bushing or a new stick base and hope it fits tighter. In use, you don't really notice it in flight in my experience, although any excess movement will cause wear in the long run. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 7, 2016, at 6:12 AM, RV10(at)TEXASRV10.COM wrote: > > > Thick/thin washer for the slop can help. A pain to insert but may work for your case. > > Gaylon Koenning > > >> On Feb 6, 2016, at 20:33, Phillip Perry wrote: >> >> I've managed to run into the control stick slop that a handful of other people have reported. It looks like the bushing I have is undersized or the bell crank hole is over sized. I haven't dug far enough into to determine which it is, but I'm betting it's the welded part (IE: Bell Crank). >> >> I've thought about building a custom bushing, but thought I'd order one more set from Vans and be extremely careful in prepping it, to remove as much slop as possible before going any further down the path. >> >> Looking on Vans site this evening, I can't find that bushing anywhere for purchase. It's labeled as BUSHING 065 x .375 x 2.313. >> >> Have any of you successfully ordered as 2nd set from Vans? Just wondering it it could be hiding under a different stock number. >> >> Thanks >> Phil > > > > > ________________________________________________________________________________
Date: Feb 07, 2016
Yeah, I think its the gap between the OD of the bushing and the ID of the control stick base Jesse. I can take the stick and not just rock it forward and aft, but I can actually pick the stick up (vertically) and set it back down. So the slop is somewhere on the inside of the control stick base. I'll have to either build a custom bushing for my bases with a local machine shop, or buy new parts. For simplicities sake, I'm leaning toward buying new parts and that's why I'd like to buy replacement bushings only at this point. The cost to replacement bases is really high compared to a few bucks for a bushing. So I'll just roll the dice with the bushing if I can find the replacement part number on Vans site. I might have to give them a call on Monday because I can't find it anywhere on the site. Phil On Sun, Feb 7, 2016 at 7:41 AM, Jesse Saint wrote: > > Are you talking about the OD of the bushing being undersized? I have seen > that before, although usually stick slop is because the bushing is too long > and the stick base can slide forward/back on the bushing. In this case, > just shorten the busing. If it's the bushing OD, then the only option is to > get a bigger OD on the bushing or a new stick base and hope it fits tighter. > > In use, you don't really notice it in flight in my experience, although > any excess movement will cause wear in the long run. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On Feb 7, 2016, at 6:12 AM, RV10(at)TEXASRV10.COM > wrote: > > > rv10(at)texasrv10.com> > > > > Thick/thin washer for the slop can help. A pain to insert but may work > for your case. > > > > Gaylon Koenning > > > > > >> On Feb 6, 2016, at 20:33, Phillip Perry wrote: > >> > >> I've managed to run into the control stick slop that a handful of other > people have reported. It looks like the bushing I have is undersized or > the bell crank hole is over sized. I haven't dug far enough into to > determine which it is, but I'm betting it's the welded part (IE: Bell > Crank). > >> > >> I've thought about building a custom bushing, but thought I'd order one > more set from Vans and be extremely careful in prepping it, to remove as > much slop as possible before going any further down the path. > >> > >> Looking on Vans site this evening, I can't find that bushing anywhere > for purchase. It's labeled as BUSHING 065 x .375 x 2.313. > >> > >> Have any of you successfully ordered as 2nd set from Vans? Just > wondering it it could be hiding under a different stock number. > >> > >> Thanks > >> Phil > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 07, 2016
Measure your bushing and ask Van=99s what size it is supposed to be. No sense in buying (and shipping) more bushings unless the bushing is the problem. From: Phillip Perry Sent: Sunday, February 07, 2016 8:56 AM Subject: Re: RV10-List: Control Stick Slop - Bushings Yeah, I think its the gap between the OD of the bushing and the ID of the control stick base Jesse. I can take the stick and not just rock it forward and aft, but I can actually pick the stick up (vertically) and set it back down. So the slop is somewhere on the inside of the control stick base. I'll have to either build a custom bushing for my bases with a local machine shop, or buy new parts. For simplicities sake, I'm leaning toward buying new parts and that's why I'd like to buy replacement bushings only at this point. The cost to replacement bases is really high compared to a few bucks for a bushing. So I'll just roll the dice with the bushing if I can find the replacement part number on Vans site. I might have to give them a call on Monday because I can't find it anywhere on the site. Phil On Sun, Feb 7, 2016 at 7:41 AM, Jesse Saint wrote: Are you talking about the OD of the bushing being undersized? I have seen that before, although usually stick slop is because the bushing is too long and the stick base can slide forward/back on the bushing. In this case, just shorten the busing. If it's the bushing OD, then the only option is to get a bigger OD on the bushing or a new stick base and hope it fits tighter. In use, you don't really notice it in flight in my experience, although any excess movement will cause wear in the long run. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Feb 7, 2016, at 6:12 AM, RV10(at)TEXASRV10.COM wrote: > > > Thick/thin washer for the slop can help. A pain to insert but may work for your case. > > Gaylon Koenning > > >> On Feb 6, 2016, at 20:33, Phillip Perry wrote: >> >> I've managed to run into the control stick slop that a handful of other people have reported. It looks like the bushing I have is undersized or the bell crank hole is over sized. I haven't dug far enough into to determine which it is, but I'm betting it's the welded part (IE: Bell Crank). >> >> I've thought about building a custom bushing, but thought I'd order one more set from Vans and be extremely careful in prepping it, to remove as much slop as possible before going any further down the path. >> >> Looking on Vans site this evening, I can't find that bushing anywhere for purchase. It's labeled as BUSHING 065 x .375 x 2.313. >> >> Have any of you successfully ordered as 2nd set from Vans? Just wondering it it could be hiding under a different stock number. >> >> Thanks >> Phil > > > > > ========== br> fts!) r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ========== -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ========== FORUMS - eferrer" target="_blank">http://forums.matronics.com ========== b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ========== ________________________________________________________________________________
Date: Feb 07, 2016
Hey Phil, Awhile back I needed a replacement bushing for a tool that was 40 years old and of course no longer available. I found that local machine shops have access to every imaginable id/od bushings, steel, brass, oil impregnated ... you name it. I got exactly what I needed for $2, tool works like new. IF that is your problem, get out your calipers, contact your local machine shops. Later, =93 Lew ________________________________________________________________________________
Date: Feb 07, 2016
The dimensions are right in the plans, as the part number. Bushing 065 x .375 x 2.313 Should be able to disconnect everything from the stick base, so that it is only pivoting on the bushing, and then examine where the slop is. The plans note that you may need to ream the bushing for AN-4 bolt. Best to start with an undersize reamer. Note the tolerance for an AN-4 is as small as 0.246. Perhaps a different, larger tolerance bolt might be what is need. Range is .246 to .249. Perhaps you could have done too much deburring on the bushing or ID of stick base?? Steps 1 and 2 on page 39-8 are the key. I know that when something doesn't seem right to me, better than 50% chance I am misreading the plans or not seeing/understanding something. On 2/7/2016 7:11 AM, kboatright1(at)comcast.net wrote: > Measure your bushing and ask Vans what size it is supposed to be. No > sense in buying (and shipping) more bushings unless the bushing is the > problem. > *From:* Phillip Perry > *Sent:* Sunday, February 07, 2016 8:56 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Control Stick Slop - Bushings > Yeah, I think its the gap between the OD of the bushing and the ID of > the control stick base Jesse. > I can take the stick and not just rock it forward and aft, but I can > actually pick the stick up (vertically) and set it back down. So the > slop is somewhere on the inside of the control stick base. > I'll have to either build a custom bushing for my bases with a local > machine shop, or buy new parts. For simplicities sake, I'm leaning > toward buying new parts and that's why I'd like to buy replacement > bushings only at this point. The cost to replacement bases is really > high compared to a few bucks for a bushing. So I'll just roll the dice > with the bushing if I can find the replacement part number on Vans > site. I might have to give them a call on Monday because I can't find > it anywhere on the site. > Phil > On Sun, Feb 7, 2016 at 7:41 AM, Jesse Saint > wrote: > > > > > Are you talking about the OD of the bushing being undersized? I have > seen that before, although usually stick slop is because the bushing > is too long and the stick base can slide forward/back on the > bushing. In this case, just shorten the busing. If it's the bushing > OD, then the only option is to get a bigger OD on the bushing or a > new stick base and hope it fits tighter. > > In use, you don't really notice it in flight in my experience, > although any excess movement will cause wear in the long run. > > Jesse Saint > Saint Aviation, Inc. > 352-427-0285 > jesse(at)saintaviation.com > > Sent from my iPad > > > On Feb 7, 2016, at 6:12 AM, RV10(at)TEXASRV10.COM > > wrote: > > > " > > > > > Thick/thin washer for the slop can help. A pain to insert but may > work for your case. > > > > Gaylon Koenning > > > > > >> On Feb 6, 2016, at 20:33, Phillip Perry > wrote: > >> > >> I've managed to run into the control stick slop that a handful > of other people have reported. It looks like the bushing I have is > undersized or the bell crank hole is over sized. I haven't dug far > enough into to determine which it is, but I'm betting it's the > welded part (IE: Bell Crank). > >> > >> I've thought about building a custom bushing, but thought I'd > order one more set from Vans and be extremely careful in prepping > it, to remove as much slop as possible before going any further down > the path. > >> > >> Looking on Vans site this evening, I can't find that bushing > anywhere for purchase. It's labeled as BUSHING 065 x .375 x 2.313. > >> > >> Have any of you successfully ordered as 2nd set from Vans? Just > wondering it it could be hiding under a different stock number. > >> > >> Thanks > >> Phil > > > > > > > > > > > > > ========== > br> fts!) > r> > w.buildersbooks.com" rel="noreferrer" > target="_blank">www.buildersbooks.com > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > -Matt Dralle, List Admin. > ========== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > ========== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========== > > ________________________________________________________________________________
Date: Feb 07, 2016
I found the slop in mine too. I threw away the original bushings and made some out of Delrin. They are silky smooth now with no play. -------- 40936 RV-10 SB N801VR Flying 530 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452663#452663 ________________________________________________________________________________
Date: Feb 07, 2016
Yeah, I knew you had switched them over. I think they were still brass when we flew in Salt Lake because I remember you mentioning it. Yours were pretty similar to how mine are. Did you machine them with the lathe? I'm wondering what the chances are of me managing to machine some on a drill press. I might be able to find someone with a lathe here at KPWG, but curious to hear how you built them. Phil On Sun, Feb 7, 2016 at 10:18 AM, Strasnuts wrote: > > I found the slop in mine too. I threw away the original bushings and made > some out of Delrin. They are silky smooth now with no play. > > -------- > 40936 > RV-10 SB N801VR Flying > 530 hours > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452663#452663 > > ________________________________________________________________________________
Date: Feb 08, 2016
Phil, I made mine on a lathe. I reamed my tubing first since Vans' welds make the tubing out of round. I have adjustable reamers so I reamed just enough to make it round. I measured the ID and made the Delrin bushing slide in. The bushing is barely longer and when tightened down it would swell and fill any slop. The Delrin works great. The more you tighten the bolt the tighter the bushing fit. There was a good spot where there was no slop and the friction was smooth and easy. If I tighten it more the friction would be too much. -------- 40936 RV-10 SB N801VR Flying 530 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452712#452712 ________________________________________________________________________________
Date: Feb 09, 2016
Subject: RV-10 Centerline @ Wingtip
For those of you who have installed the magnetometer in the wing tip, are we all in agreement that the outboard wing rib is perfectly parallel to the ce nterline of the aircraft? The Garmin magnetometer states that it needs to be within 1/2 degree of the c enterline (much tighter demands than the Dynon) and I'm hoping I can base th at centerline measurement off the outboard side of the wing rib. Phil Sent from my iPhone ________________________________________________________________________________
Date: Feb 09, 2016
Subject: Way Off Topic
From: Bruce Breckenridge <bbreckenridge(at)gmail.com>
Although our RV-10 has an engine and wings, between the two we got sidetracked on an MK-1 Christavia plans built aircraft which is soon to fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the Christavia. Now, I may have goofed. Does the antenna need an aluminum ground plane? If so, how big? This is a fabric plane, similar to a Champ. Bruce Breckenridge RV-10 Wings/engine done. SN (gulp!) 40018 ________________________________________________________________________________
Date: Feb 09, 2016
Any chance of making any more of the delrin bushings? -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452740#452740 ________________________________________________________________________________
Date: Feb 10, 2016
Subject: Re: RV-10 Centerline @ Wingtip
I mounted mine out there, but leveled it with washers on the mounting bolts using a digital level. Works great. On Tue, Feb 9, 2016 at 9:19 PM, Phillip Perry wrote: > For those of you who have installed the magnetometer in the wing tip, are > we all in agreement that the outboard wing rib is perfectly parallel to the > centerline of the aircraft? > > The Garmin magnetometer states that it needs to be within 1/2 degree of > the centerline (much tighter demands than the Dynon) and I'm hoping I can > base that centerline measurement off the outboard side of the wing rib. > > Phil > > > Sent from my iPhone > ________________________________________________________________________________
Subject: Re: Way Off Topic
Date: Feb 10, 2016
Bruce, Yes, the antenna needs a ground plane but it doesnt have to be the whole airplane. On my Skybolt I cut an aluminum disc, around 8 diameter but its been a long while, and glued it to the inside of the fabric and attached the antenna to it. Worked great. Probably some better answers out there if you do a Google search. Good luck on your non-RV-10 ;) Marcus On Feb 9, 2016, at 10:55 PM, Bruce Breckenridge wrote: Although our RV-10 has an engine and wings, between the two we got sidetracked on an MK-1 Christavia plans built aircraft which is soon to fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the Christavia. Now, I may have goofed. Does the antenna need an aluminum ground plane? If so, how big? This is a fabric plane, similar to a Champ. Bruce Breckenridge RV-10 Wings/engine done. SN (gulp!) 40018 ________________________________________________________________________________
Date: Feb 10, 2016
Just think of how much of a 'ground plane' a handheld has. A metal wing intersection fairing works well on my Pitts with the rubber ducky attached to the end of the coax. Linn On 2/10/2016 8:09 AM, Marcus Cooper wrote: > > Bruce, > Yes, the antenna needs a ground plane but it doesnt have to be the whole airplane. On my Skybolt I cut an aluminum disc, around 8 diameter but its been a long while, and glued it to the inside of the fabric and attached the antenna to it. Worked great. Probably some better answers out there if you do a Google search. > > Good luck on your non-RV-10 ;) > > Marcus > > On Feb 9, 2016, at 10:55 PM, Bruce Breckenridge wrote: > > Although our RV-10 has an engine and wings, between the two we got sidetracked on an MK-1 Christavia plans built aircraft which is soon to fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the Christavia. Now, I may have goofed. > > Does the antenna need an aluminum ground plane? If so, how big? This is a fabric plane, similar to a Champ. > > Bruce Breckenridge > RV-10 Wings/engine done. SN (gulp!) 40018 > > ________________________________________________________________________________
Date: Feb 10, 2016
On my fabric covered Rans S6-Es I made a 12" square Aluminum plate to mount the bent whip antenna. It's worked great. Bob Newman TCW Technologies, LLC 610-928-3420 > On Feb 10, 2016, at 8:58 AM, Linn Walters wrote: > > > Just think of how much of a 'ground plane' a handheld has. > A metal wing intersection fairing works well on my Pitts with the rubber ducky attached to the end of the coax. > Linn > >> On 2/10/2016 8:09 AM, Marcus Cooper wrote: >> >> Bruce, >> Yes, the antenna needs a ground plane but it doesnt have to be the whole airplane. On my Skybolt I cut an aluminum disc, around 8 diameter but its been a long while, and glued it to the inside of the fabric and attached the antenna to it. Worked great. Probably some better answers out there if you do a Google search. >> >> Good luck on your non-RV-10 ;) >> >> Marcus >> >> On Feb 9, 2016, at 10:55 PM, Bruce Breckenridge wrote: >> >> Although our RV-10 has an engine and wings, between the two we got sidetracked on an MK-1 Christavia plans built aircraft which is soon to fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the Christavia. Now, I may have goofed. >> >> Does the antenna need an aluminum ground plane? If so, how big? This is a fabric plane, similar to a Champ. >> >> Bruce Breckenridge >> RV-10 Wings/engine done. SN (gulp!) 40018 >> >> >> >> >> >> >> >> > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Feb 10, 2016
Bruce, I=99m not familiar with this radio but I assume it is GPS only, no comm. If so, the GPS antenna needs no ground plane. Whatever bracket you can fabricate is fine. This is why they work when mounted on top of fiberglass. For what it=99s worth, standard =C2=BC wavelength aircraft comm antennas do need a ground plane. The radius of the ground plane needs to also be at least =C2=BC wavelength. At 120MHZ this works out to be 24=9D or so. Conventionally this is provided by the skin of the airplane. For composites you can add four or so strips of copper tape on the inside of the fuselage, the ends connected to the base of the antenna. You can also run four or more light wires to the base of the antenna spread out like the spooks on a wheel. As previous suggested however, for a tube and fabric aircraft mounting the comm antenna to the frame at any point will provide the needed ground plane =93 no other action is needed. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bruce Breckenridge Sent: Tuesday, February 09, 2016 10:56 PM Subject: RV10-List: Way Off Topic Although our RV-10 has an engine and wings, between the two we got sidetracked on an MK-1 Christavia plans built aircraft which is soon to fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the Christavia. Now, I may have goofed. Does the antenna need an aluminum ground plane? If so, how big? This is a fabric plane, similar to a Champ. Bruce Breckenridge RV-10 Wings/engine done. SN (gulp!) 40018 ________________________________________________________________________________
Date: Feb 10, 2016
For what it is worth, Garmin does require a ground plane for its Certified GPS antennas. Why, I do not know. I did small aluminum plate on my RV-10, then added some aluminum tape to extend it where flat plate would be difficult. On 2/10/2016 8:36 AM, Carl Froehlich wrote: > Bruce, > > Im not familiar with this radio but I assume it is GPS only, no comm. > If so, the GPS antenna needs no ground plane. Whatever bracket you can > fabricate is fine. This is why they work when mounted on top of fiberglass. > > For what its worth, standard wavelength aircraft comm antennas do > need a ground plane. The radius of the ground plane needs to also be at > least wavelength. At 120MHZ this works out to be 24 or so. > Conventionally this is provided by the skin of the airplane. For > composites you can add four or so strips of copper tape on the inside of > the fuselage, the ends connected to the base of the antenna. You can > also run four or more light wires to the base of the antenna spread out > like the spooks on a wheel. > > As previous suggested however, for a tube and fabric aircraft mounting > the comm antenna to the frame at any point will provide the needed > ground plane no other action is needed. > > Carl > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bruce > Breckenridge > *Sent:* Tuesday, February 09, 2016 10:56 PM > *To:* rv10-list(at)matronics.com; Jesse Saint > *Subject:* RV10-List: Way Off Topic > > Although our RV-10 has an engine and wings, between the two we got > sidetracked on an MK-1 Christavia plans built aircraft which is soon to > fly. Our C182 has a BK KLN-94, so, to keep it simple, I put one in the > Christavia. Now, I may have goofed. > > Does the antenna need an aluminum ground plane? If so, how big? This > is a fabric plane, similar to a Champ. > > Bruce Breckenridge > > RV-10 Wings/engine done. SN (gulp!) 40018 > ________________________________________________________________________________
Subject: Harness Strap & Headset Bracket
Date: Feb 11, 2016
Could anyone please direct me to where I could purchase those brackets which are attached to the overhead console, from which I can hang harnesses and headsets from please? Your assistance would again be greatly appreciated please. Warm regards Patrick ________________________________________________________________________________
Subject: Re: Harness Strap & Headset Bracket
Date: Feb 11, 2016
http://www.planeinnovations.com/product-category/brackets/ -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452757#452757 ________________________________________________________________________________
Date: Feb 11, 2016
**warning** completely unsolicited input follows: Com'on builder, you can make your own belt hangers. Try these <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=7984&log=152315&row=15> - they look good and work even better. Someone suggested hanging the front seat headsets on the side underneath the panel. Out of sight and sun yet easily accessible if you get them before belting in. I made a hook with a piece of aluminum tubing and blind riveted to that first vertical behind the firewall. And when flying solo, no action required for the unused headset. Bill "providing information you already had but discarded" Watson On 2/11/2016 4:49 AM, Patrick Pulis wrote: > > Could anyone please direct me to where I could purchase those brackets which are attached to the overhead console, from which I can hang harnesses and headsets from please? > > Your assistance would again be greatly appreciated please. > > Warm regards > > Patrick > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Feb 11, 2016
Headsets holders are above and on either side of the tunnel on a simple single piece of =BD=94 aluminum tubing attached under the panel. The ends of the tubing have a few inches of plastic hose to protect the headsets. Harness strap holders are Z brackets made from .040=94 aluminum and attached to the inboard door hinge screws on each side. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Thursday, February 11, 2016 8:19 AM Subject: Re: RV10-List: Harness Strap & Headset Bracket **warning** completely unsolicited input follows: Com'on builder, you can make your own belt hangers. Try these <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project =224& category=7984&log=152315&row=15> - they look good and work even better. Someone suggested hanging the front seat headsets on the side underneath the panel. Out of sight and sun yet easily accessible if you get them before belting in. I made a hook with a piece of aluminum tubing and blind riveted to that first vertical behind the firewall. And when flying solo, no action required for the unused headset. Bill "providing information you already had but discarded" Watson On 2/11/2016 4:49 AM, Patrick Pulis wrote: Could anyone please direct me to where I could purchase those brackets which are attached to the overhead console, from which I can hang harnesses and headsets from please? Your assistance would again be greatly appreciated please. Warm regards Patrick This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Subject: Re: FS: Slick 6393 Mag and Mag Drive
Date: Feb 11, 2016
Mag is Sold Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452761#452761 ________________________________________________________________________________
Date: Feb 12, 2016
Perfect, many thanks Bill. Warm regards Patrick > On 11 Feb 2016, at 23:26, bill.peyton wrote: > > > http://www.planeinnovations.com/product-category/brackets/ > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452757#452757 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 12, 2016
Any pictures please Carl? Warm regards Patrick > On 12 Feb 2016, at 01:10, Carl Froehlich wrot e: > > Headsets holders are above and on either side of the tunnel on a simple si ngle piece of =C2=BD=9D aluminum tubing attached under the panel. The ends of the tubing have a few inches of plastic hose to protect the headset s. > > Harness strap holders are Z brackets made from .040=9D aluminum and a ttached to the inboard door hinge screws on each side. > > Carl > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Bill Watson > Sent: Thursday, February 11, 2016 8:19 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Harness Strap & Headset Bracket > > **warning** completely unsolicited input follows: > > Com'on builder, you can make your own belt hangers. Try these - they look good and work even better. > > Someone suggested hanging the front seat headsets on the side underneath t he panel. Out of sight and sun yet easily accessible if you get them before belting in. I made a hook with a piece of aluminum tubing and blind riveted to that first vertical behind the firewall. And when flying solo, no actio n required for the unused headset. > > Bill "providing information you already had but discarded" Watson > > > On 2/11/2016 4:49 AM, Patrick Pulis wrote: > > Could anyone please direct me to where I could purchase those brackets whi ch are attached to the overhead console, from which I can hang harnesses and headsets from please? > > Your assistance would again be greatly appreciated please. > > Warm regards > > Patrick > > > > > > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > ________________________________________________________________________________
Date: Feb 11, 2016
Here's another version. --Dave On Thursday, February 11, 2016, Patrick Pulis wrote: > Any pictures please Carl? > > Warm regards > > Patrick > > On 12 Feb 2016, at 01:10, Carl Froehlich > wrote: > > Headsets holders are above and on either side of the tunnel on a simple > single piece of =C2=BD=9D aluminum tubing attached under the panel. The ends of > the tubing have a few inches of plastic hose to protect the headsets. > > > Harness strap holders are Z brackets made from .040=9D aluminum and attached > to the inboard door hinge screws on each side. > > > Carl > > > *From:* owner-rv10-list-server(at)matronics.com > [ > mailto:owner-rv10-list-server(at)matronics.com > ] * On > Behalf Of *Bill Watson > *Sent:* Thursday, February 11, 2016 8:19 AM > *To:* rv10-list(at)matronics.com > > *Subject:* Re: RV10-List: Harness Strap & Headset Bracket > > > **warning** completely unsolicited input follows: > > Com'on builder, you can make your own belt hangers. Try these > <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project =224&category=7984&log=152315&row=15> > - they look good and work even better. > > Someone suggested hanging the front seat headsets on the side underneath > the panel. Out of sight and sun yet easily accessible if you get them > before belting in. I made a hook with a piece of aluminum tubing and blin d > riveted to that first vertical behind the firewall. And when flying solo , > no action required for the unused headset. > > Bill "providing information you already had but discarded" Watson > > > On 2/11/2016 4:49 AM, Patrick Pulis wrote: > > > > > Could anyone please direct me to where I could purchase those brackets wh ich are attached to the overhead console, from which I can hang harnesses a nd headsets from please? > > > Your assistance would again be greatly appreciated please. > > > Warm regards > > > Patrick > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > ________________________________________________________________________________
Date: Feb 11, 2016
Here you go. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis Sent: Thursday, February 11, 2016 3:02 PM Subject: Re: RV10-List: Harness Strap & Headset Bracket Any pictures please Carl? Warm regards Patrick On 12 Feb 2016, at 01:10, Carl Froehlich wrote: Headsets holders are above and on either side of the tunnel on a simple single piece of =C2=BD=9D aluminum tubing attached under the panel. The ends of the tubing have a few inches of plastic hose to protect the headsets. Harness strap holders are Z brackets made from .040=9D aluminum and attached to the inboard door hinge screws on each side. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Thursday, February 11, 2016 8:19 AM Subject: Re: RV10-List: Harness Strap & Headset Bracket **warning** completely unsolicited input follows: Com'on builder, you can make your own belt hangers. Try these <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project =224&category=7984&log=152315&row=15> - they look good and work even better. Someone suggested hanging the front seat headsets on the side underneath the panel. Out of sight and sun yet easily accessible if you get them before belting in. I made a hook with a piece of aluminum tubing and blind riveted to that first vertical behind the firewall. And when flying solo, no action required for the unused headset. Bill "providing information you already had but discarded" Watson On 2/11/2016 4:49 AM, Patrick Pulis wrote: Could anyone please direct me to where I could purchase those brackets which are attached to the overhead console, from which I can hang harnesses and headsets from please? Your assistance would again be greatly appreciated please. Warm regards Patrick This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Feb 11, 2016
Actually, I made the parts originally and sold them myself.=C2- Then was contacted by (I think it was Paul) from Plane Innovations, and he bought al l I had made.=C2- But I think Paul was killed in a plane crash several ye ars back.=C2- I no longer make them because I've moved to Texas.=C2- Th at's all I know.Don McDonald From: Patrick Pulis <rv10free2fly(at)yahoo.com.au> To: rv10-list(at)matronics.com Sent: Thursday, February 11, 2016 1:59 PM Subject: Re: RV10-List: Re: Harness Strap & Headset Bracket Perfect, many thanks Bill. Warm regards Patrick > On 11 Feb 2016, at 23:26, bill.peyton wrote: > > > http://www.planeinnovations.com/product-category/brackets/ > > -------- > Bill > WA0SYV > Aviation Partners, LLC > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452757#452757 > > > > > > > > > > =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. S - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Date: Feb 12, 2016
Many thanks David. Warm regards Patrick > On 12 Feb 2016, at 07:10, David Saylor wrote: > > > Here's another version. > > --Dave > >> On Thursday, February 11, 2016, Patrick Pulis wrote: >> Any pictures please Carl? >> >> Warm regards >> >> Patrick >> >>> On 12 Feb 2016, at 01:10, Carl Froehlich wr ote: >>> >>> Headsets holders are above and on either side of the tunnel on a simple s ingle piece of =C2=BD=9D aluminum tubing attached under the panel. Th e ends of the tubing have a few inches of plastic hose to protect the headse ts. >>> >>> >>> >>> Harness strap holders are Z brackets made from .040=9D aluminum an d attached to the inboard door hinge screws on each side. >>> >>> >>> >>> Carl >>> >>> >>> >>> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-serve r(at)matronics.com] On Behalf Of Bill Watson >>> Sent: Thursday, February 11, 2016 8:19 AM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: Harness Strap & Headset Bracket >>> >>> >>> >>> **warning** completely unsolicited input follows: >>> >>> Com'on builder, you can make your own belt hangers. Try these - they lo ok good and work even better. >>> >>> Someone suggested hanging the front seat headsets on the side underneath the panel. Out of sight and sun yet easily accessible if you get them befo re belting in. I made a hook with a piece of aluminum tubing and blind rivet ed to that first vertical behind the firewall. And when flying solo, no act ion required for the unused headset. >>> >>> Bill "providing information you already had but discarded" Watson >>> >>> >>> On 2/11/2016 4:49 AM, Patrick Pulis wrote: >>> u> >>> >>> Could anyone please direct me to where I could purchase those brackets w hich are attached to the overhead console, from which I can hang harnesses a nd headsets from please? >>> >>> Your assistance would again be greatly appreciated please. >>> >>> Warm regards >>> >>> Patrick >>> >>> >>> >>> >>> >>> >>> >>> This email has been sent from a virus-free computer protected by Avast. >>> www.avast.com >>> > ________________________________________________________________________________
Date: Feb 12, 2016
Many thanks Carl. Warm regards Patrick > On 12 Feb 2016, at 07:28, Carl Froehlich wrot e: > > Here you go. > > Carl > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Patrick Pulis > Sent: Thursday, February 11, 2016 3:02 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Harness Strap & Headset Bracket > > Any pictures please Carl? > > Warm regards > > Patrick > > On 12 Feb 2016, at 01:10, Carl Froehlich wrot e: > > Headsets holders are above and on either side of the tunnel on a simple si ngle piece of =C2=BD=9D aluminum tubing attached under the panel. The ends of the tubing have a few inches of plastic hose to protect the headset s. > > Harness strap holders are Z brackets made from .040=9D aluminum and a ttached to the inboard door hinge screws on each side. > > Carl > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Bill Watson > Sent: Thursday, February 11, 2016 8:19 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Harness Strap & Headset Bracket > > **warning** completely unsolicited input follows: > > Com'on builder, you can make your own belt hangers. Try these - they look good and work even better. > > Someone suggested hanging the front seat headsets on the side underneath t he panel. Out of sight and sun yet easily accessible if you get them before belting in. I made a hook with a piece of aluminum tubing and blind riveted to that first vertical behind the firewall. And when flying solo, no actio n required for the unused headset. > > Bill "providing information you already had but discarded" Watson > > > On 2/11/2016 4:49 AM, Patrick Pulis wrote: > > Could anyone please direct me to where I could purchase those brackets whi ch are attached to the overhead console, from which I can hang harnesses and headsets from please? > > Your assistance would again be greatly appreciated please. > > Warm regards > > Patrick > > > > > > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > > ________________________________________________________________________________
Subject: maintenance tips
Date: Feb 13, 2016
The 360003 fuel pressure sensor has a tendency to start reading erratically high fuel pressure after several hundred hours; an IA friend said the same is true for the PMA stamped part for about 10-15 times the experimental price. I replaced the part at about 400 hours and again at about 800 hours. The new one started the routine a couple of months ago. After thinking about the transducer, I decided to try cleaning the contacts; I have flown several hours since then and the sensor is operating normally. I think that the problem may be the oil residue, etc swirling about under the cowl and causing contact problems. So far so good. I believe most 10s have the Matco master cylinders supplied by Vans. I spoke with George Happ of Matco about a problem I have seen on a couple of occasions. Given the geometry of the rudder/brake pedals it is possible through inattention to drag a brake slightly. The master cylinder is not fully extended and therefore can not equalize internal pressures due to covered input port; the result is a temporary faulty brake and perhaps erratic steering as a result. It can happen with long taxi, hot weather and dragging a brake ever so slightly. It has happened to me twice in about 1000 hours. It seems as though a brake bleed is necessary but after a short period the situation resolves itself. At the time of occurrence it seems best to remove one's feet from the brakes for a second or two and reapply. David McNeill N46007 TT 1000+ --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: maintenance tips
Date: Feb 13, 2016
In a prior life with much heavier iron being pushed by a hot air tailpipe, we were taught to only put your feet on the brake pedals when you needed to brake, get on both brakes quickly with equal pressure, and then get totally back off of them. Let the plane accelerate a bit, then do it all over again. A series of slowing down through firm braking, then accelerating until you need to slow it down again. Constant pressure during taxiing creates heat. Enough heat will cause brake fade and ignite any fluid around the pucks.. I have used this technique solely since building my -10 nearly 10 years ago, and not only have there been no brake incidents, I replace the pads about every 300 hours (there is still life left in them at that point, I just feel better replacing them..). grumpy > On Feb 13, 2016, at 8:16 AM, David wrote: > > The 360003 fuel pressure sensor has a tendency to start reading erratically high fuel pressure after several hundred hours; an IA friend said the same is true for the PMA stamped part for about 10-15 times the experimental price. I replaced the part at about 400 hours and again at about 800 hours. The new one started the routine a couple of months ago. After thinking about the transducer, I decided to try cleaning the contacts; I have flown several hours since then and the sensor is operating normally. I think that the problem may be the oil residue, etc swirling about under the cowl and causing contact problems. So far so good. > > I believe most 10s have the Matco master cylinders supplied by Vans. I spoke with George Happ of Matco about a problem I have seen on a couple of occasions. Given the geometry of the rudder/brake pedals it is possible through inattention to drag a brake slightly. The master cylinder is not fully extended and therefore can not equalize internal pressures due to covered input port; the result is a temporary faulty brake and perhaps erratic steering as a result. It can happen with long taxi, hot weather and dragging a brake ever so slightly. It has happened to me twice in about 1000 hours. It seems as though a brake bleed is necessary but after a short period the situation resolves itself. At the time of occurrence it seems best to remove one=99s feet from the brakes for a second or two and reapply. > > David McNeill > N46007 TT 1000+ > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com ________________________________________________________________________________
Date: Feb 13, 2016
It is easy to drag a brake. Here is a note I sent out a few months ago on the subject. My son and son-in-law are Naval Aviators. As is easy to do, both have a tendency to drag the brakes. A good friend of mine, Tom Doran, made these extension on his milling machine from 1" Delron. He even made me one out of steel for me to use as a drilling gig. I used a couple of hose clamps to attached the gig and drill the #19 holes. While I did this to help the son and son-in-law I confess I found them to be much better than just the stock set up. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Sent: Saturday, February 13, 2016 9:17 AM Subject: RV10-List: maintenance tips The 360003 fuel pressure sensor has a tendency to start reading erratically high fuel pressure after several hundred hours; an IA friend said the same is true for the PMA stamped part for about 10-15 times the experimental price. I replaced the part at about 400 hours and again at about 800 hours. The new one started the routine a couple of months ago. After thinking about the transducer, I decided to try cleaning the contacts; I have flown several hours since then and the sensor is operating normally. I think that the problem may be the oil residue, etc swirling about under the cowl and causing contact problems. So far so good. I believe most 10s have the Matco master cylinders supplied by Vans. I spoke with George Happ of Matco about a problem I have seen on a couple of occasions. Given the geometry of the rudder/brake pedals it is possible through inattention to drag a brake slightly. The master cylinder is not fully extended and therefore can not equalize internal pressures due to covered input port; the result is a temporary faulty brake and perhaps erratic steering as a result. It can happen with long taxi, hot weather and dragging a brake ever so slightly. It has happened to me twice in about 1000 hours. It seems as though a brake bleed is necessary but after a short period the situation resolves itself. At the time of occurrence it seems best to remove one's feet from the brakes for a second or two and reapply. David McNeill N46007 TT 1000+ This email has been sent from a virus-free computer protected by Avast. www.avast.com ________________________________________________________________________________
Date: Feb 13, 2016
Along with 'heel pads' you can put an additional compression spring on the master cylinder shaft to help it relax fully. The angle of the pedal just naturally makes it easy to drag the brakes. As John Miller posted, short, hard brake pressure is always preferable to dragging the brakes due to the heat. Tail-dragger pilots should be used to that already. AFAIK, the original Matco brake disks are a little thinner than their Cleveland counterparts and don't have as much mass to store a lot of heat. Linn On 2/13/2016 9:49 AM, Carl Froehlich wrote: > > It is easy to drag a brake. Here is a note I sent out a few months > ago on the subject. > > My son and son-in-law are Naval Aviators. As is easy to do, both have > a tendency to drag the brakes. A good friend of mine, Tom Doran, made > these extension on his milling machine from 1 Delron. He even made > me one out of steel for me to use as a drilling gig. I used a couple > of hose clamps to attached the gig and drill the #19 holes. > > While I did this to help the son and son-in-law I confess I found them > to be much better than just the stock set up. > > > Carl > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *David > *Sent:* Saturday, February 13, 2016 9:17 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: maintenance tips > > The 360003 fuel pressure sensor has a tendency to start reading > erratically high fuel pressure after several hundred hours; an IA > friend said the same is true for the PMA stamped part for about 10-15 > times the experimental price. I replaced the part at about 400 hours > and again at about 800 hours. The new one started the routine a couple > of months ago. After thinking about the transducer, I decided to try > cleaning the contacts; I have flown several hours since then and the > sensor is operating normally. I think that the problem may be the oil > residue, etc swirling about under the cowl and causing contact > problems. So far so good. > > I believe most 10s have the Matco master cylinders supplied by Vans. I > spoke with George Happ of Matco about a problem I have seen on a > couple of occasions. Given the geometry of the rudder/brake pedals it > is possible through inattention to drag a brake slightly. The master > cylinder is not fully extended and therefore can not equalize internal > pressures due to covered input port; the result is a temporary faulty > brake and perhaps erratic steering as a result. It can happen with > long taxi, hot weather and dragging a brake ever so slightly. It has > happened to me twice in about 1000 hours. It seems as though a brake > bleed is necessary but after a short period the situation resolves > itself. At the time of occurrence it seems best to remove ones feet > from the brakes for a second or two and reapply. > > David McNeill > > N46007 TT 1000+ > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > ________________________________________________________________________________
Date: Feb 13, 2016
Here's my setup for return springs to assist the internal spring on the master cylinders. On the bottom is a delrin washer to help protect the master cylinder from the spring. Then the spring. Then on top of that is a collar for the spring to press against on the top and to adjust the tension you feel on the brake pedals. All hardware purchased in the aviation department of Ace Hardware. Probably around $7 per master cylinder. Phil [image: Inline image 1] On Sat, Feb 13, 2016 at 9:13 AM, Linn Walters wrote : > Along with 'heel pads' you can put an additional compression spring on th e > master cylinder shaft to help it relax fully. The angle of the pedal jus t > naturally makes it easy to drag the brakes. > > As John Miller posted, short, hard brake pressure is always preferable to > dragging the brakes due to the heat. Tail-dragger pilots should be used to > that already. > AFAIK, the original Matco brake disks are a little thinner than their > Cleveland counterparts and don't have as much mass to store a lot of heat . > Linn > > > On 2/13/2016 9:49 AM, Carl Froehlich wrote: > > It is easy to drag a brake. Here is a note I sent out a few months ago o n > the subject. > > > My son and son-in-law are Naval Aviators. As is easy to do, both have a > tendency to drag the brakes. A good friend of mine, Tom Doran, made thes e > extension on his milling machine from 1=9D Delron. He even made me one out > of steel for me to use as a drilling gig. I used a couple of hose clamps > to attached the gig and drill the #19 holes. > > > While I did this to help the son and son-in-law I confess I found them to > be much better than just the stock set up. > > > Carl > > > *From:* owner-rv10-list-server(at)matronics.com [ > mailto:owner-rv10-list-server(at)matronics.com > ] *On Behalf Of *David > *Sent:* Saturday, February 13, 2016 9:17 AM > *To:* rv10-list(at)matronics.com > *Subject:* RV10-List: maintenance tips > > > The 360003 fuel pressure sensor has a tendency to start reading > erratically high fuel pressure after several hundred hours; an IA friend > said the same is true for the PMA stamped part for about 10-15 times the > experimental price. I replaced the part at about 400 hours and again at > about 800 hours. The new one started the routine a couple of months ago. > After thinking about the transducer, I decided to try cleaning the > contacts; I have flown several hours since then and the sensor is operati ng > normally. I think that the problem may be the oil residue, etc swirling > about under the cowl and causing contact problems. So far so good. > > > I believe most 10s have the Matco master cylinders supplied by Vans. I > spoke with George Happ of Matco about a problem I have seen on a couple o f > occasions. Given the geometry of the rudder/brake pedals it is possible > through inattention to drag a brake slightly. The master cylinder is not > fully extended and therefore can not equalize internal pressures due to > covered input port; the result is a temporary faulty brake and perhaps > erratic steering as a result. It can happen with long taxi, hot weather a nd > dragging a brake ever so slightly. It has happened to me twice in about > 1000 hours. It seems as though a brake bleed is necessary but after a sho rt > period the situation resolves itself. At the time of occurrence it seems > best to remove one=99s feet from the brakes for a second or two and reapply. > > > David McNeill > > N46007 TT 1000+ > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > ________________________________________________________________________________
Date: Feb 13, 2016
Dave, I am reluctant to make these for control surfaces for other builders. I think each one would have to be specifically made for each aircraft after reaming the hole. -------- 40936 RV-10 SB N801VR Flying 530 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452798#452798 ________________________________________________________________________________
Date: Feb 13, 2016
I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. -------- Dave Ford RV6 for sale RV10 building Cadillac, MI Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452802#452802 ________________________________________________________________________________
Date: Feb 13, 2016
I have some delrin coming and I'm planning on making them for my sloppiness. I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. Phil Sent from my iPhone > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 13, 2016
Sorry typo. 15/64. Not 11/64... Sent from my iPhone > On Feb 13, 2016, at 8:08 PM, Phillip Perry wrote: > > I have some delrin coming and I'm planning on making them for my sloppiness. > > I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). > > Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. > > I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. > > Phil > > Sent from my iPhone > >> On Feb 13, 2016, at 5:29 PM, rvdave wrote: >> >> >> I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. >> >> -------- >> Dave Ford >> RV6 for sale >> RV10 building >> Cadillac, MI >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=452802#452802 >> >> >> >> >> >> >> >> >> >> ________________________________________________________________________________
Subject: best glide speed
Date: Feb 14, 2016
I'm been looking at different v speeds people are using for the RV10. I see best glide 80 kts and other places 90 kts. Also the Vx and Vy speeds seem to vary a lot. Has anyone done actual testing for the numbers? Alan N668g 340 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452808#452808 ________________________________________________________________________________
Date: Feb 14, 2016
Yes I did testing....at least twice....and what I found out was that without much more sophisticated test equipment I could not come up with a precise number. I settled with Vx of 78 and a Vy of 85 a Vgl of 80 (all knots). But.........I never fly that way. I can not go very far climbing at 78 due to engine heat and I never climb out at under 110. When practicing emergency landing, I feel a lot better at 90 knots. >From what I can remember from the testing, airspeed did not have a great effect on the performance.....to say it another way there is very little difference between a Vx of 78 and 80 but I did the math and it came out to 78. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of amekler Sent: Sunday, February 14, 2016 5:25 AM Subject: RV10-List: best glide speed I'm been looking at different v speeds people are using for the RV10. I see best glide 80 kts and other places 90 kts. Also the Vx and Vy speeds seem to vary a lot. Has anyone done actual testing for the numbers? Alan N668g 340 hrs Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452808#452808 ________________________________________________________________________________
Subject: Re: best glide speed
Date: Feb 14, 2016
Rene, In my pilots manual that came with the plane these are the speeds listed. Vr 65 KTS Vso 49 KTS VS 67 KTS BEST GLIDE 80KTS VX 71 KTS VY 104 KTS I also climb out at least at 90 kts Alan > On Feb 14, 2016, at 7:25 AM, amekler wrote: > > > I'm been looking at different v speeds > people are using for the RV10. > I see best glide 80 kts and other places 90 kts. > Also the Vx and Vy speeds seem to vary a lot. > Has anyone done actual testing for the numbers? > Alan > N668g 340 hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452808#452808 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 14, 2016
Take all numbers you received with the plane with a healthy grain of salt. These are experimental planes, and you have no idea how diligent the builder was at obtaining the numbers. You bought a plane that was made by a non-certified company, with perhaps non-standard techniques at times, and flown through an unknown test program of unknown diligence. The ONLY way you will know the true numbers are to go get them yourself in your own testing. In short, buying a homebuilt, you need to not trust the original builder on ANYTHING, but verify EVERYTHING for yourself, and put yourself through the whole process of flight testing. There was absolutely nobody looking over the test flight process in almost any homebuilt builders case, so you cannot ensure that they even did the testing. In fact, with so many POH's out there, I'm sure that a large portion of builders simply copy what someone else has published. I am pretty sure that just like Rene's comments, my numbers aren't 100% accurate. I had a very hard time really getting any reliably repeatable numbers. Sure, with a bunch more time and testing I could probably narrow it down, but as he said, there seems to not be that much difference between a couple kts this way or that way. In the end, when it comes to climb performance, I've learned to accept that in every situation that I've flown so far, the airplane is simply more capable than most other small GA airplanes, so Vx or Vy...it really doesn't make much difference. The limiting factor as he noted is likely to be more the engine cooling. But the RV-10 will get you away from the terrain in short order...at which point you'll just use cruise climb anyway. Maybe a little more important is the best glide, but that's where you'll have to test your aircraft as it is today, in its current W&B configuration. So in short, I just encourage everyone to go get your own numbers...don't just cheat and ask other builders. These aren't certified planes, and there is very little consistency in the exact airframe and W&B config, so it's just plain safer, and good for you, to go do the testing yourself. Tim On 2/14/2016 10:00 AM, Alan Mekler MD wrote: > Rene, > In my pilots manual that came with the plane these are the speeds listed. > > Vr 65 KTS > > Vso 49 KTS > > VS 67 KTS > > BEST GLIDE 80KTS > > VX 71 KTS > > VY 104 KTS > > > I also climb out at least at 90 kts > > Alan >> On Feb 14, 2016, at 7:25 AM, amekler > > wrote: >> >> > >> >> I'm been looking at different v speeds >> people are using for the RV10. >> I see best glide 80 kts and other places 90 kts. >> Also the Vx and Vy speeds seem to vary a lot. >> Has anyone done actual testing for the numbers? >> Alan >> N668g 340 hrs >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=452808#452808 >> >> >> >> >> >> >> >> >> >> > ________________________________________________________________________________
Date: Feb 14, 2016
Tim, Thanks. I plan on getting my own numbers as i have no idea where the builder got these numbers. Alan ps. Do you have a link where I can find the recommended procedures to use? > On Feb 14, 2016, at 10:36 AM, Rene wrote: > > > Yes I did testing....at least twice....and what I found out was that without > much more sophisticated test equipment I could not come up with a precise > number. > > I settled with Vx of 78 and a Vy of 85 a Vgl of 80 (all knots). > > But.........I never fly that way. I can not go very far climbing at 78 due > to engine heat and I never climb out at under 110. When practicing > emergency landing, I feel a lot better at 90 knots. > >> From what I can remember from the testing, airspeed did not have a great > effect on the performance.....to say it another way there is very little > difference between a Vx of 78 and 80 but I did the math and it came out to > 78. > > Rene' > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of amekler > Sent: Sunday, February 14, 2016 5:25 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: best glide speed > > > I'm been looking at different v speeds > people are using for the RV10. > I see best glide 80 kts and other places 90 kts. > Also the Vx and Vy speeds seem to vary a lot. > Has anyone done actual testing for the numbers? > Alan > N668g 340 hrs > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452808#452808 > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Feb 14, 2016
Remember that best glide speed is FLAPS UP till you have the landing area made. On Sun, Feb 14, 2016 at 11:00 AM, Alan Mekler MD wrote: > Rene, > In my pilots manual that came with the plane these are the speeds listed. > > Vr 65 KTS > > Vso 49 KTS > > VS 67 KTS > > BEST GLIDE 80KTS > > VX 71 KTS > > VY 104 KTS > > > I also climb out at least at 90 kts > Alan > > On Feb 14, 2016, at 7:25 AM, amekler wrote: > > > I'm been looking at different v speeds > people are using for the RV10. > I see best glide 80 kts and other places 90 kts. > Also the Vx and Vy speeds seem to vary a lot. > Has anyone done actual testing for the numbers? > Alan > N668g 340 hrs > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452808#452808 > > ________________________________________________________________________________
Date: Feb 14, 2016
Remember that Vglide is tricky. It varies with aircraft weight (like the square root). Also, in the real world where you want to glide as far as possible over the ground with an engine out, the best indicated speed to use depends on the wind. Mine seems to be around 80kias, no wind, gross weight. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452821#452821 ________________________________________________________________________________
Date: Feb 15, 2016
And remember to pull the prop out to extend glide during your testing, simulated, and real best glides. It makes a noticeable difference in performance and the flying characteristics. I was taught to only push the prop control back in when you need aerodynamic braking to avoid an overshoot. -------- David Halmos RV-10 Flying! Portland, OR Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452839#452839 ________________________________________________________________________________
Subject: Best glide
Date: Feb 15, 2016
Just remember that if you want the best glide; prop control is aft; high pitch, low RPM. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Best glide
Date: Feb 15, 2016
dlm34077 wrote: > Just remember that if you want the best glide; prop control is aft; high pitch, low RPM. > This email has been sent from a virus-free computer protected by Avast. www.avast.com (https://www.avast.com/sig-email) And, throttle full open (control forward). Of course this cannot be practiced with the engine running! -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=452874#452874 ________________________________________________________________________________
Subject: Bonaco Brake Lines Too Short!
Date: Feb 21, 2016
Hi team I purchased to pre-fabricated Bonaco brake lines some time ago and went to fit them today, however the two lines that interconnect the pilot and co-pilot brake master cylinders are only 31.5" long, as opposed to the 43" called for in the plans. Has anyone else encountered this problem with the Bonaco brake line kit? Warm regards Patrick ________________________________________________________________________________
Subject: Re: Bonaco Brake Lines Too Short!
Date: Feb 21, 2016
I believe they modeled them after my setup a number of years ago. Here's a t our. https://youtu.be/gemgQmVsOYI Also, you'll want to make sure you adel clamp the tunnel lines frequently. They're long so they don't sag down and rub on rivet heads. I used the fac tory clamp locations and then added a 2nd pair between those higher on the t unnel walls. So it kinda makes some S-Turns down the sides of the tunnel. Phil Sent from my iPhone > On Feb 21, 2016, at 5:01 AM, Patrick Pulis wro te: > > > Hi team > > I purchased to pre-fabricated Bonaco brake lines some time ago and went to fit them today, however the two lines that interconnect the pilot and co-pi lot brake master cylinders are only 31.5" long, as opposed to the 43" called for in the plans. > > Has anyone else encountered this problem with the Bonaco brake line kit? > > Warm regards > > Patrick > ========================== ========= ========================== ========= ========================== ========= ========================== ========= ========================== ========= > > > ________________________________________________________________________________
Date: Feb 22, 2016
Thanks Phil I'm only replacing the lines under the panel. They two in question are way t oo short. Warm regards Patrick > On 22 Feb 2016, at 02:13, Phillip Perry wrote: > > I believe they modeled them after my setup a number of years ago. Here's a tour. > > https://youtu.be/gemgQmVsOYI > > Also, you'll want to make sure you adel clamp the tunnel lines frequently. They're long so they don't sag down and rub on rivet heads. I used the f actory clamp locations and then added a 2nd pair between those higher on the tunnel walls. So it kinda makes some S-Turns down the sides of the tunnel . > > Phil > > > > > > Sent from my iPhone > >> On Feb 21, 2016, at 5:01 AM, Patrick Pulis wr ote: >> > >> >> Hi team >> >> I purchased to pre-fabricated Bonaco brake lines some time ago and went t o fit them today, however the two lines that interconnect the pilot and co-p ilot brake master cylinders are only 31.5" long, as opposed to the 43" calle d for in the plans. >> >> Has anyone else encountered this problem with the Bonaco brake line kit? >> >> Warm regards >> >> Patri======================= ======================= >> http://www.matronics.com/Naviga============== ========================== ============; - MATRONICS WEB FORUMS - >> >> <======================== ========================== ===== ========================== ========================== -========================= ========================== ========================== -========================= ========================== ======== ________________________________________________________________________________
Date: Feb 21, 2016
Patrick, I=99m away from my -10 until April 3rd, but I=99m wondering if you had the wrong lines sent to you. I recall the 31=9D lines where for down the gear legs. Rick #40956 Southampton, Ont From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis Sent: Sunday, 21 February, 2016 2:11 PM Subject: Re: RV10-List: Bonaco Brake Lines Too Short! Thanks Phil I'm only replacing the lines under the panel. They two in question are way too short. Warm regards Patrick On 22 Feb 2016, at 02:13, Phillip Perry wrote: I believe they modeled them after my setup a number of years ago. Here's a tour. https://youtu.be/gemgQmVsOYI Also, you'll want to make sure you adel clamp the tunnel lines frequently. They're long so they don't sag down and rub on rivet heads. I used the factory clamp locations and then added a 2nd pair between those higher on the tunnel walls. So it kinda makes some S-Turns down the sides of the tunnel. Phil Sent from my iPhone On Feb 21, 2016, at 5:01 AM, Patrick Pulis wrote: Hi team I purchased to pre-fabricated Bonaco brake lines some time ago and went to fit them today, however the two lines that interconnect the pilot and co-pilot brake master cylinders are only 31.5" long, as opposed to the 43" called for in the plans. Has anyone else encountered this problem with the Bonaco brake line kit? Warm regards Patri======================= ======================= http://www.matronics.com/Naviga============== =============; - MATRONICS WEB FORUMS - <="" span=""> <======================== ====== ========== >www.buildersbooks.com matronics.com/contribution ========== ://www.matronics.com/Navigator?RV10-List ========== cs.com ========== matronics.com/contribution ========== _____ No virus found in this message. Checked by AVG - www.avg.com 02/21/16 ________________________________________________________________________________
Date: Feb 22, 2016
Yep, I've used the longer lines down the gear legs, thanks for the heads up R ick. Warm regards Patrick > On 22 Feb 2016, at 06:48, Rick & Sandra Lark wrote: > > Patrick, I=99m away from my -10 until April 3rd, but I=99m won dering if you had the wrong lines sent to you. I recall the 31=9D lin es where for down the gear legs. > Rick > #40956 > Southampton, Ont > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Patrick Pulis > Sent: Sunday, 21 February, 2016 2:11 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Bonaco Brake Lines Too Short! > > Thanks Phil > > I'm only replacing the lines under the panel. They two in question are way too short. > > Warm regards > > Patrick > > On 22 Feb 2016, at 02:13, Phillip Perry wrote: > > I believe they modeled them after my setup a number of years ago. Here's a tour. > > https://youtu.be/gemgQmVsOYI > > Also, you'll want to make sure you adel clamp the tunnel lines frequently. They're long so they don't sag down and rub on rivet heads. I used the f actory clamp locations and then added a 2nd pair between those higher on the tunnel walls. So it kinda makes some S-Turns down the sides of the tunnel . > > Phil > > > > > > Sent from my iPhone > > On Feb 21, 2016, at 5:01 AM, Patrick Pulis wro te: > > > Hi team > > I purchased to pre-fabricated Bonaco brake lines some time ago and went to fit them today, however the two lines that interconnect the pilot and co-pi lot brake master cylinders are only 31.5" long, as opposed to the 43" called for in the plans. > > Has anyone else encountered this problem with the Bonaco brake line kit? > > Warm regards > > Patri===================== > http://www.matronics.com/Naviga ========================== =; - MATRONICS WEB FORUMS - > <="" span=""> > <========================= ===== > > > > > ========================= ========== >www.buildersbooks.com matronics.com/contribu tion ========== ://www.matronics.com/Navigator?RV10-List ========== cs.com ========== matron ics.com/contribution ========= > No virus found in this message. > Checked by AVG - www.avg.com > Version: 2016.0.7442 / 02/21/16 ________________________________________________________________________________
Date: Feb 22, 2016
I installed my Bonaco brake lines a couple of weeks ago and they fit perfect. Call Brett to confirm the lengths that he sent you. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453065#453065 Attachments: http://forums.matronics.com//files/fullsizerender_1_244.jpg ________________________________________________________________________________
Subject: Re: Choosing an EFIS system (was "and brand")
Date: Feb 22, 2016
I was dead set on Dynon. Until I had the opportunity to compare them with Garmin side by side. When I visited SteinAir I had many of my questions answered. After I saw the compass/AHRS install for Garmin vs Dynon along with many other features I changed my mind. I would however recommend that you not purchase the GPS until just before you start flying. The warranty starts when you buy it. Stein was extremely helpful and the staff was awesome. As a pilot by occupation, I feel that the menus and setup for Garmin favor me over the Dynon. My 2 cents RV-10 QB Fuse/wings Empennage complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453066#453066 ________________________________________________________________________________
Subject: Titan Engine IO-540
Date: Feb 22, 2016
Does anyone have this engine on order? Any feedback on Titan engines? I ordered my IO-540 and expect delivery in May/June. Curious to hear about your experience. Especially now that they are owned by Continental Motors. Tal Holloway RV-10 QB fuselage/wings Empennage complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453067#453067 ________________________________________________________________________________
Date: Feb 23, 2016
All good. My error. Warm regards Patrick > On 22 Feb 2016, at 23:01, whodja wrote: > > > I installed my Bonaco brake lines a couple of weeks ago and they fit perfect. Call Brett to confirm the lengths that he sent you. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453065#453065 > > > > > Attachments: > > http://forums.matronics.com//files/fullsizerender_1_244.jpg > > > > > > > ________________________________________________________________________________
Subject: Glare-shield painting
Date: Feb 23, 2016
Guys Questions for those of you who didn't upholster the glare-shield of your -10: Which colour did you paint the upper surface of your glare-shield? And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel? And by the way, when in the building process did you paint these 2 surfaces? TIA Carlos Enviado do meu iPhone ________________________________________________________________________________
Subject: Re: Glare-shield painting
Date: Feb 23, 2016
Carlos, I went with flat black, trusty Rust-Oleum if I remember correctly. Its been 9 1/2 years with no issues whatsoever and no problem with glare either. I painted the bottom white to match my instrument panel. I painted it after installation but before putting the windshield in. If you are going to put any cooling fans in the glare shield I recommend you make the cutouts before installing, I know its a bit of a pain to do them later on :( One or two computer cooling fans helps with cooling the avionics as well as being a natural defogger. Have fun, Marcus On Feb 23, 2016, at 5:35 PM, Carlos Trigo wrote: Guys Questions for those of you who didn't upholster the glare-shield of your -10: Which colour did you paint the upper surface of your glare-shield? And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel? And by the way, when in the building process did you paint these 2 surfaces? TIA Carlos Enviado do meu iPhone ________________________________________________________________________________
Date: Feb 23, 2016
On 2/23/2016 5:35 PM, Carlos Trigo wrote: > > Guys > > Questions for those of you who didn't upholster the glare-shield of your -10: > > Which colour did you paint the upper surface of your glare-shield? Flat black. > And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel? I painted mine the same color (colour) as my instrument panel .... rust-oleum # 7223 sandstone, It's in the 'textured' area. I painted my tunnel cover and the overhead plenum the same color. > And by the way, when in the building process did you paint these 2 surfaces? I painted the glareshield before I riveted on the fwd upper fuse, just before I installed the cabin top and windshield. I painted the aft underside two weeks ago because my first attempt peeled .... probably poor prep on my part. Lots of masking tape and paper since the interior was already painted. Linn .... painting the FG parts .... white. > > TIA > Carlos > > Enviado do meu iPhone > > ________________________________________________________________________________
Date: Feb 23, 2016
RustOlium dark brown (I forget the official color), flat, top and underside. Fan holes drilled first. Painted in place but no windscreen, no instrument panel. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453105#453105 ________________________________________________________________________________
Subject: Fuel Caps
Date: Feb 23, 2016
Hi I have been wondering about how hard it should be push the locking tab on a fuel cap into place. One of mine was very, very difficult so I ended up backing off the retaining nut. Anyway, is there any lubrication (fuel lube perhaps) required. How snug should the tab be? Inquiring minds need to know. Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453106#453106 ________________________________________________________________________________
Date: Feb 23, 2016
Subject: Re: Fuel Caps
The thermos bottle caps take some regular maintenance. You'll need a little light grease on the lobe of the handle cam. I found a grease called Krytox (sorry, there are several types and I don't recall which I went with) for the oring. Works great. Fuel lube, contrary to what the name implies, is really a sealant and will gum up the works in short order. It works best to lube pipe threads, etc. between dissimilar metals, ie, to prevent galling aluminum pumps and such. And it's fuel proof, but not exactly slippery. --Dave On Tue, Feb 23, 2016 at 6:14 PM, kearney wrote: > > Hi > > I have been wondering about how hard it should be push the locking tab on > a fuel cap into place. One of mine was very, very difficult so I ended up > backing off the retaining nut. > > Anyway, is there any lubrication (fuel lube perhaps) required. > > How snug should the tab be? > > Inquiring minds need to know. > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453106#453106 > > ________________________________________________________________________________
Date: Feb 23, 2016
While not identical, Beech and Mooney fuel caps require something like Triflow or silicone lube on O-rings. I've also used DC-4 where I wanted to last longer...same stuff you use on oil filter o-ring. On 2/23/2016 7:14 PM, kearney wrote: > > Hi > > I have been wondering about how hard it should be push the locking tab on a fuel cap into place. One of mine was very, very difficult so I ended up backing off the retaining nut. > > Anyway, is there any lubrication (fuel lube perhaps) required. > > How snug should the tab be? > > Inquiring minds need to know. > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453106#453106 > > ________________________________________________________________________________
Date: Feb 23, 2016
I found my old order for Krytox: http://www.mcmaster.com/#dupont-krytox-gpl-206-grease/=119achu A 1/2 oz tube has lasted for a couple seasons now-- $$$ but worth it. Avgas doesn't seem to phase it. I only use it on the fuel cap orings. --Dave On Tue, Feb 23, 2016 at 7:05 PM, Kelly McMullen wrote: > > While not identical, Beech and Mooney fuel caps require something like > Triflow or silicone lube on O-rings. I've also used DC-4 where I wanted to > last longer...same stuff you use on oil filter o-ring. > > > On 2/23/2016 7:14 PM, kearney wrote: > >> >> Hi >> >> I have been wondering about how hard it should be push the locking tab on >> a fuel cap into place. One of mine was very, very difficult so I ended up >> backing off the retaining nut. >> >> Anyway, is there any lubrication (fuel lube perhaps) required. >> >> How snug should the tab be? >> >> Inquiring minds need to know. >> >> Les >> >> >> >> >> Read this topic online here: >> >> http://forums.matronics.com/viewtopic.php?p=453106#453106 >> >> >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: Titan Engine IO-540
Date: Feb 24, 2016
A search on the VAF site will turn up a write-up I did on a factory tour I took back at Thanksgiving. -----Original Message----- From: whodja Sent: Monday, February 22, 2016 7:49 AM Subject: RV10-List: Titan Engine IO-540 Does anyone have this engine on order? Any feedback on Titan engines? I ordered my IO-540 and expect delivery in May/June. Curious to hear about your experience. Especially now that they are owned by Continental Motors. Tal Holloway RV-10 QB fuselage/wings Empennage complete Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453067#453067 ________________________________________________________________________________
Date: Feb 24, 2016
Flat black, probably Rustoleum, but don't really remember. Underside same tan as panel. Cut openings for vent fans prior to paint and windshield installation. 850 hours and 7 1/2 years later it is still looking good David Maib > On Feb 23, 2016, at 5:35 PM, Carlos Trigo wrote: > > > Guys > > Questions for those of you who didn't upholster the glare-shield of your -10: > > Which colour did you paint the upper surface of your glare-shield? > > And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel? > > And by the way, when in the building process did you paint these 2 surfaces? > > TIA > Carlos > > Enviado do meu iPhone > > > > ________________________________________________________________________________
Date: Feb 24, 2016
I got some dashboard material from Cleveland and it works great. You just glue it in. Also got the trim piece from them. Attached a picture....not a great one. I did this after the wind screen was in. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David Maib Sent: Wednesday, February 24, 2016 7:38 AM Subject: Re: RV10-List: Glare-shield painting Flat black, probably Rustoleum, but don't really remember. Underside same tan as panel. Cut openings for vent fans prior to paint and windshield installation. 850 hours and 7 1/2 years later it is still looking good David Maib > On Feb 23, 2016, at 5:35 PM, Carlos Trigo wrote: > > > Guys > > Questions for those of you who didn't upholster the glare-shield of your -10: > > Which colour did you paint the upper surface of your glare-shield? > > And which colour, if different, did you paint the under part of the glare-shield which protrudes above the instrument panel? > > And by the way, when in the building process did you paint these 2 surfaces? > > TIA > Carlos > > Enviado do meu iPhone > > > > ________________________________________________________________________________
Date: Feb 24, 2016
I used a spray on, black bed liner product from a local auto parts store. Put on several coats till the can was gone. Zero glare or windscreen reflection as well as non-slip. Tough as nails. Dave Leikam N89DA > On Feb 24, 2016, at 9:16 AM, Rene wrote: > > I got some dashboard material from Cleveland and it works great. You just > glue it in. Also got the trim piece from them. > > Attached a picture....not a great one. I did this after the wind screen was > in. > > Rene' > 801-721-6080 > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of David Maib > Sent: Wednesday, February 24, 2016 7:38 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Glare-shield painting > > > Flat black, probably Rustoleum, but don't really remember. Underside same > tan as panel. Cut openings for vent fans prior to paint and windshield > installation. 850 hours and 7 1/2 years later it is still looking good > > David Maib > > >> On Feb 23, 2016, at 5:35 PM, Carlos Trigo wrote: >> >> >> Guys >> >> Questions for those of you who didn't upholster the glare-shield of your > -10: >> >> Which colour did you paint the upper surface of your glare-shield? >> >> And which colour, if different, did you paint the under part of the > glare-shield which protrudes above the instrument panel? >> >> And by the way, when in the building process did you paint these 2 > surfaces? >> >> TIA >> Carlos >> >> Enviado do meu iPhone >> >> >> >> > > > > > ________________________________________________________________________________
Date: Feb 24, 2016
Sorry for the multiple posts! I was getting a delivery error. Dave Leikam > On Feb 24, 2016, at 3:09 PM, David Leikam wrote: > > I used a spray on, black bed liner product from a local auto parts store. > Put on several coats till the can was gone. Zero glare or windscreen reflection as well as non-slip. Tough as nails. > > Dave Leikam > N89DA > > >> On Feb 24, 2016, at 9:16 AM, Rene > wrote: >> >> I got some dashboard material from Cleveland and it works great. You just >> glue it in. Also got the trim piece from them. >> >> Attached a picture....not a great one. I did this after the wind screen was >> in. >> >> Rene' >> 801-721-6080 >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com ] On Behalf Of David Maib >> Sent: Wednesday, February 24, 2016 7:38 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Glare-shield painting >> > >> >> Flat black, probably Rustoleum, but don't really remember. Underside same >> tan as panel. Cut openings for vent fans prior to paint and windshield >> installation. 850 hours and 7 1/2 years later it is still looking good >> >> David Maib >> >> >>> On Feb 23, 2016, at 5:35 PM, Carlos Trigo > wrote: >>> > >>> >>> Guys >>> >>> Questions for those of you who didn't upholster the glare-shield of your >> -10: >>> >>> Which colour did you paint the upper surface of your glare-shield? >>> >>> And which colour, if different, did you paint the under part of the >> glare-shield which protrudes above the instrument panel? >>> >>> And by the way, when in the building process did you paint these 2 >> surfaces? >>> >>> TIA >>> Carlos >>> >>> Enviado do meu iPhone >>> >>> >>> >>> >> >> >> >> >> > ________________________________________________________________________________
Date: Feb 24, 2016
Subject: Re: Control Stick Slop - Bushings
I thought I'd follow up on the control stick slop issue that I had in my system since I promised a post-bushing report. I had some major play in my control sticks and ended up following Sean's advice and replaced the brass bushings with delrin. I attached a couple of photos of the plans to help with the explanation. After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something closer to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" rod to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That was one part of the problem. The other part of the problem was the slop on the inside of the bushing between the bushing and the 1/4" bolt. That slop was worse than the welded part. Additionally I found one more location for slop and that was the ability to slide the stick forward and aft on the 1/4" bolt between the stick bases and the control column that the stick bases mount to. The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down until it was a thumb-press fit into the stick bases. The next step was to drill and ream the hole for the 1/4" bolt down the center. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side of the tolerance. That didn't work out and I ultimately had to open it to a full 1/4" to get the bolt to slide through. Back to the work bench where I installed the new bushings. The fit was free of any play between that bases and the bushing and between the bushing and the bolt. The final task was to eliminate the sliding motion of the sticks forward and aft on the 1/4" bolt between the stick bases and the control column. This was a pretty simple task of inserting AN960-416 and 416L washers to shim as much of the gaps away as possible. Obviously you can't get all of the gap out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position. The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opposition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and stick. I'm very happy with the outcome. This wasn't a terrible change to make and if you have the seats out and access to a lathe, you could probably do it in less than a day. You certainly could do it on a drill press with some forethought. creative jigs, patience, and a few sacrificed pieces of delrin while you traverse the learning curve, but the lathe is certainly the fastest and easiest. I'd do it again... Glad it turned out the way it did. Phil [image: Inline image 1] [image: Inline image 2] On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrote: > I have some delrin coming and I'm planning on making them for my > sloppiness. > > I'm planning on reaming the bell crank to 3/8 and then seeing how well a > 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in > the mail too. I'll be able turn it down to fit or possibly it would fit > without any working (though I doubt it). > > Once I find the rod that fits best, then I'll ream the center on a friends > lathe. I have a 3/16" reamer that will work, but I plan on using another > reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if > it's too tight I'll open it up to the full 3/16 with the other reamer. > > I'll probably have a report on how well it works in the next 2 weeks or > possibly late next week. > > Phil > > Sent from my iPhone > > > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > > > > I thought about that and wondered about the possibility of sanding them > down a little bit if oversized since the delrin does compress a little. > > > > -------- > > Dave Ford > > RV6 for sale > > RV10 building > > Cadillac, MI > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Feb 25, 2016
=9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position.=9D Perhaps I=99m reading this wrong. I thought the objective was for the bolt to capture the bushing so that there is no relative motion between the bolt and the bushing. All relative motion should be between the outside of the bushing and the weldment (in this case the Control Stick Base Pivot Tube). I also believe adding a light grease for the bushing to weldment provides for reduced corrosion between the dissimilar metals =93 obviously not an issue when using delrin but perhaps would help keep dirt out of the bearing surface. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 12:53 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings I thought I'd follow up on the control stick slop issue that I had in my system since I promised a post-bushing report. I had some major play in my control sticks and ended up following Sean's advice and replaced the brass bushings with delrin. I attached a couple of photos of the plans to help with the explanation. After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something closer to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" rod to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That was one part of the problem. The other part of the problem was the slop on the inside of the bushing between the bushing and the 1/4" bolt. That slop was worse than the welded part. Additionally I found one more location for slop and that was the ability to slide the stick forward and aft on the 1/4" bolt between the stick bases and the control column that the stick bases mount to. The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down until it was a thumb-press fit into the stick bases. The next step was to drill and ream the hole for the 1/4" bolt down the center. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side of the tolerance. That didn't work out and I ultimately had to open it to a full 1/4" to get the bolt to slide through. Back to the work bench where I installed the new bushings. The fit was free of any play between that bases and the bushing and between the bushing and the bolt. The final task was to eliminate the sliding motion of the sticks forward and aft on the 1/4" bolt between the stick bases and the control column. This was a pretty simple task of inserting AN960-416 and 416L washers to shim as much of the gaps away as possible. Obviously you can't get all of the gap out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position. The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opposition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and stick. I'm very happy with the outcome. This wasn't a terrible change to make and if you have the seats out and access to a lathe, you could probably do it in less than a day. You certainly could do it on a drill press with some forethought. creative jigs, patience, and a few sacrificed pieces of delrin while you traverse the learning curve, but the lathe is certainly the fastest and easiest. I'd do it again... Glad it turned out the way it did. Phil Inline image 1 Inline image 2 On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrote: I have some delrin coming and I'm planning on making them for my sloppiness. I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. Phil Sent from my iPhone > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > ============ h -- EE Gifts!) on r> ed ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ============ br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ============ S WEB FORUMS - ="noreferrer" target="_blank">http://forums.matronics.com ============ on Web Site - -Matt Dralle, List Admin. ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution ============ > > ________________________________________________________________________________
Date: Feb 25, 2016
You want the pivot point on the bolt and not the steel welded part. That we lded part isn't perfectly round (oblong) from the heat and it's also rough, a brasive, and susceptible to rust - contributing for abrasion and wear. If you keep the motion on the bolt, you have a perfectly round and smooth pi vot point. The nut is pinned so there's no chance of running the nut off. Phil Sent from my iPhone > On Feb 25, 2016, at 9:10 AM, Carl Froehlich w rote: > > =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a ti me. Once I began to feel tension on the sticks, I stopped and backed off on e flat where I then dropped in the cotter key in to lock it into position. =9D > > Perhaps I=99m reading this wrong. I thought the objective was for t he bolt to capture the bushing so that there is no relative motion between t he bolt and the bushing. All relative motion should be between the outside o f the bushing and the weldment (in this case the Control Stick Base Pivot Tu be). > > I also believe adding a light grease for the bushing to weldment provides f or reduced corrosion between the dissimilar metals =93 obviously not a n issue when using delrin but perhaps would help keep dirt out of the bearin g surface. > > Carl > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 12:53 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > I thought I'd follow up on the control stick slop issue that I had in my s ystem since I promised a post-bushing report. I had some major play in my c ontrol sticks and ended up following Sean's advice and replaced the brass bu shings with delrin. I attached a couple of photos of the plans to help wit h the explanation. > > After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something clo ser to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. > > I pulled the sticks, stick bases, and control column out of the plane and p ut it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" ro d to see how well it fit and it dropped straight through unrestricted. The i nside of the welded stick bases were way more than the spec'd 3/8". That wa s one part of the problem. The other part of the problem was the slop on th e inside of the bushing between the bushing and the 1/4" bolt. That slop wa s worse than the welded part. Additionally I found one more location for sl op and that was the ability to slide the stick forward and aft on the 1/4" b olt between the stick bases and the control column that the stick bases moun t to. > > The first order of business was to get new bushings machined out. Since t he stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down u ntil it was a thumb-press fit into the stick bases. > > The next step was to drill and ream the hole for the 1/4" bolt down the ce nter. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side o f the tolerance. That didn't work out and I ultimately had to open it to a f ull 1/4" to get the bolt to slide through. > > Back to the work bench where I installed the new bushings. The fit was fr ee of any play between that bases and the bushing and between the bushing an d the bolt. > > The final task was to eliminate the sliding motion of the sticks forward a nd aft on the 1/4" bolt between the stick bases and the control column. Th is was a pretty simple task of inserting AN960-416 and 416L washers to shim a s much of the gaps away as possible. Obviously you can't get all of the ga p out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. > > I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Onc e I began to feel tension on the sticks, I stopped and backed off one flat w here I then dropped in the cotter key in to lock it into position. > > The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opp osition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while w iggling the stick and not find any play between the control surface and stic k. I'm very happy with the outcome. > > This wasn't a terrible change to make and if you have the seats out and ac cess to a lathe, you could probably do it in less than a day. You certainl y could do it on a drill press with some forethought. creative jigs, patienc e, and a few sacrificed pieces of delrin while you traverse the learning cur ve, but the lathe is certainly the fastest and easiest. > > I'd do it again... Glad it turned out the way it did. > > Phil > > > > > > > > > > > On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrot e: > I have some delrin coming and I'm planning on making them for my sloppines s. > > I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3 /8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in t he mail too. I'll be able turn it down to fit or possibly it would fit with out any working (though I doubt it). > > Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another re amer that's 11/64 (1/64 under sized) to see how it fits first. Then if it' s too tight I'll open it up to the full 3/16 with the other reamer. > > I'll probably have a report on how well it works in the next 2 weeks or po ssibly late next week. > > Phil > > Sent from my iPhone > > > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > > > > I thought about that and wondered about the possibility of sanding them d own a little bit if oversized since the delrin does compress a little. > > > > -------- > > Dave Ford > > RV6 for sale > > RV10 building > > Cadillac, MI > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > > > > > > > > > > > > > > ============ > h -- > EE Gifts!) > on > r> ed > ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.builder sbooks.com > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > -Matt Dralle, List Admin. > ============ > br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?RV10-List > ============ > S WEB FORUMS - > ="noreferrer" target="_blank">http://forums.matronics.com > ============ > on Web Site - > -Matt Dralle, List Admin. > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > ============ > > > > > > > ________________________________________________________________________________
Date: Feb 25, 2016
Also, by putting the motion on the bolt, any future replacement of parts fro m wear would involve a new bushing and potentially new bolt. Cheap and easy t o replace. Putting be motion on the welded piece would lead to a new bushing and potent ially new weldment. Expensive and more complex to repair. Phil Sent from my iPhone > On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: > > You want the pivot point on the bolt and not the steel welded part. That w elded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. > > If you keep the motion on the bolt, you have a perfectly round and smooth p ivot point. The nut is pinned so there's no chance of running the nut off. > > Phil > > Sent from my iPhone > >> On Feb 25, 2016, at 9:10 AM, Carl Froehlich w rote: >> >> =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a t ime. Once I began to feel tension on the sticks, I stopped and backed off o ne flat where I then dropped in the cotter key in to lock it into position. =9D >> >> Perhaps I=99m reading this wrong. I thought the objective was for t he bolt to capture the bushing so that there is no relative motion between t he bolt and the bushing. All relative motion should be between the outside o f the bushing and the weldment (in this case the Control Stick Base Pivot Tu be). >> >> I also believe adding a light grease for the bushing to weldment provides for reduced corrosion between the dissimilar metals =93 obviously not an issue when using delrin but perhaps would help keep dirt out of the bear ing surface. >> >> Carl >> >> >> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server @matronics.com] On Behalf Of Phillip Perry >> Sent: Thursday, February 25, 2016 12:53 AM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: Re: Control Stick Slop - Bushings >> >> I thought I'd follow up on the control stick slop issue that I had in my s ystem since I promised a post-bushing report. I had some major play in my c ontrol sticks and ended up following Sean's advice and replaced the brass bu shings with delrin. I attached a couple of photos of the plans to help wit h the explanation. >> >> After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something clo ser to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. >> >> I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between t he brass bushing and the welded part of the stick bases. I tried the 3/8" r od to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That w as one part of the problem. The other part of the problem was the slop on t he inside of the bushing between the bushing and the 1/4" bolt. That slop w as worse than the welded part. Additionally I found one more location for s lop and that was the ability to slide the stick forward and aft on the 1/4" b olt between the stick bases and the control column that the stick bases moun t to. >> >> The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned i t down on a lathe that another guy on the airport had. It was turned down u ntil it was a thumb-press fit into the stick bases. >> >> The next step was to drill and ream the hole for the 1/4" bolt down the c enter. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4 " bolt) to get a snug fit in the event that the bolt was on the skinny side o f the tolerance. That didn't work out and I ultimately had to open it to a f ull 1/4" to get the bolt to slide through. >> >> Back to the work bench where I installed the new bushings. The fit was f ree of any play between that bases and the bushing and between the bushing a nd the bolt. >> >> The final task was to eliminate the sliding motion of the sticks forward a nd aft on the 1/4" bolt between the stick bases and the control column. Th is was a pretty simple task of inserting AN960-416 and 416L washers to shim a s much of the gaps away as possible. Obviously you can't get all of the ga p out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. >> >> I tuned this part of the system like you would a wheel bearing. I rotate d the sticks left and right while tightening the nut one flat at a time. On ce I began to feel tension on the sticks, I stopped and backed off one flat w here I then dropped in the cotter key in to lock it into position. >> >> The system linkages are tight (meaning no play) and very smooth (minus th e drag of the TruTrak servos). You can work the left and right sticks in op position directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and st ick. I'm very happy with the outcome. >> >> This wasn't a terrible change to make and if you have the seats out and a ccess to a lathe, you could probably do it in less than a day. You certain ly could do it on a drill press with some forethought. creative jigs, patien ce, and a few sacrificed pieces of delrin while you traverse the learning cu rve, but the lathe is certainly the fastest and easiest. >> >> I'd do it again... Glad it turned out the way it did. >> >> Phil >> >> >> >> >> >> >> >> >> >> >> On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wro te: >> I have some delrin coming and I'm planning on making them for my sloppine ss. >> >> I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3 /8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in t he mail too. I'll be able turn it down to fit or possibly it would fit with out any working (though I doubt it). >> >> Once I find the rod that fits best, then I'll ream the center on a friend s lathe. I have a 3/16" reamer that will work, but I plan on using another r eamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it 's too tight I'll open it up to the full 3/16 with the other reamer. >> >> I'll probably have a report on how well it works in the next 2 weeks or p ossibly late next week. >> >> Phil >> >> Sent from my iPhone >> >> > On Feb 13, 2016, at 5:29 PM, rvdave wrote: >> > >> > >> > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. >> > >> > -------- >> > Dave Ford >> > RV6 for sale >> > RV10 building >> > Cadillac, MI >> > >> > >> > >> > >> > Read this topic online here: >> > >> > http://forums.matronics.com/viewtopic.php?p=452802#452802 >> > >> > >> > >> > >> > >> > >> > >> ============ >> h -- >> EE Gifts!) >> on >> r> ed >> ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.builde rsbooks.com >> ion" rel="noreferrer" target="_blank">http://www.matronics.com/contri bution >> -Matt Dralle, List Admin. >> ============ >> br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics .com/Navigator?RV10-List >> ============ >> S WEB FORUMS - >> ="noreferrer" target="_blank">http://forums.matronics.com >> ============ >> on Web Site - >> -Matt Dralle, List Admin. >> ion" rel="noreferrer" target="_blank">http://www.matronics.com/contri bution >> ============ >> > >> > >> > >> ________________________________________________________________________________
Date: Feb 25, 2016
Phil beat me to it. You're absolutely right. (I like yours and Seans solution by the way) The housing on the outside of the bushing isn't really round, so you wouldn't want it to rotate on the bushing there. If it DID wear, it could potentially wear a larger hole in the housing, which would then be harder to fix later. If you rotate it on the bolt, a simple change of bolt and you're back to normal specs. The Delrin should work real well. This whole mess happened on mine, and I used a filler to surround the bushing and basically "epoxy" it in to the weldment. That way it can only rotate on the bolt. And I took up the end slop as well...also out in the aileron bellcranks. You should look at those areas and think about where wear is going to happen, and try to ensure that any surface that will wear, is a replaceable part. You will find there are a few places that can be improved upon from the plans...just like the original nose gear axle...that was a horrible design until they went with thicker spacer...then it was just a bad design. The Matco axle is a great improvement. Tim On 2/25/2016 9:50 AM, Phillip Perry wrote: > Also, by putting the motion on the bolt, any future replacement of parts > from wear would involve a new bushing and potentially new bolt. Cheap > and easy to replace. > > Putting be motion on the welded piece would lead to a new bushing and > potentially new weldment. Expensive and more complex to repair. > > Phil > > > Sent from my iPhone > > On Feb 25, 2016, at 9:45 AM, Phillip Perry > wrote: > >> You want the pivot point on the bolt and not the steel welded part. >> That welded part isn't perfectly round (oblong) from the heat and >> it's also rough, abrasive, and susceptible to rust - contributing for >> abrasion and wear. >> >> If you keep the motion on the bolt, you have a perfectly round and >> smooth pivot point. The nut is pinned so there's no chance of running >> the nut off. >> >> PhilI'm very happy with the >>> outcome. >>> >>> This wasn't a terrible change to make and if you have the seats out >>> and access to a lathe, you could probably do it in less than a day. >>> You certainly could do it on a drill press with some forethought. >>> creative jigs, patience, and a few sacrificed pieces of delrin while >>> you traverse the learning curve, but the lathe is certainly the >>> fastest and easiest. >>> >>> I'd do it again... Glad it turned out the way it did. >>> >>> Phil >>> ________________________________________________________________________________
Date: Feb 25, 2016
Thanks Phil =93 but I=99ll have to disagree. Relative motion between the bushing and bolt means you have small bearing surfaces, and a nice hard steel bolt wearing steel mating surfaces (the bolt holes in the weldment). The function of the bushing is to provide a large bearing surface (between the bushing and the pivot tube). The larger surface area contributes to why we enjoy such smooth controls in our RVs. The same principle applies to bell cranks and rod end bearings =93 no relative motion around the bolt. There is need from time to time to shorten either the pivot tube or bushing to achieve slop free operation. You rare cases you may also find need to ream out the pivot tube. The bushing, when firmly captured in the weldment, should have perhaps 1/32=9D exposed on each side of the pivot tube. If needed washers are added to make sure the weldment is not deformed when the bolt is tightened =93 thus maintaining this small gap and preventing binding. Again a little grease between the bushing and pivot tube is recommended. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 10:50 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings Also, by putting the motion on the bolt, any future replacement of parts from wear would involve a new bushing and potentially new bolt. Cheap and easy to replace. Putting be motion on the welded piece would lead to a new bushing and potentially new weldment. Expensive and more complex to repair. Phil Sent from my iPhone On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: You want the pivot point on the bolt and not the steel welded part. That welded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. If you keep the motion on the bolt, you have a perfectly round and smooth pivot point. The nut is pinned so there's no chance of running the nut off. Phil Sent from my iPhone On Feb 25, 2016, at 9:10 AM, Carl Froehlich wrote: =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position.=9D Perhaps I=99m reading this wrong. I thought the objective was for the bolt to capture the bushing so that there is no relative motion between the bolt and the bushing. All relative motion should be between the outside of the bushing and the weldment (in this case the Control Stick Base Pivot Tube). I also believe adding a light grease for the bushing to weldment provides for reduced corrosion between the dissimilar metals =93 obviously not an issue when using delrin but perhaps would help keep dirt out of the bearing surface. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 12:53 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings I thought I'd follow up on the control stick slop issue that I had in my system since I promised a post-bushing report. I had some major play in my control sticks and ended up following Sean's advice and replaced the brass bushings with delrin. I attached a couple of photos of the plans to help with the explanation. After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something closer to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" rod to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That was one part of the problem. The other part of the problem was the slop on the inside of the bushing between the bushing and the 1/4" bolt. That slop was worse than the welded part. Additionally I found one more location for slop and that was the ability to slide the stick forward and aft on the 1/4" bolt between the stick bases and the control column that the stick bases mount to. The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down until it was a thumb-press fit into the stick bases. The next step was to drill and ream the hole for the 1/4" bolt down the center. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side of the tolerance. That didn't work out and I ultimately had to open it to a full 1/4" to get the bolt to slide through. Back to the work bench where I installed the new bushings. The fit was free of any play between that bases and the bushing and between the bushing and the bolt. The final task was to eliminate the sliding motion of the sticks forward and aft on the 1/4" bolt between the stick bases and the control column. This was a pretty simple task of inserting AN960-416 and 416L washers to shim as much of the gaps away as possible. Obviously you can't get all of the gap out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position. The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opposition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and stick. I'm very happy with the outcome. This wasn't a terrible change to make and if you have the seats out and access to a lathe, you could probably do it in less than a day. You certainly could do it on a drill press with some forethought. creative jigs, patience, and a few sacrificed pieces of delrin while you traverse the learning curve, but the lathe is certainly the fastest and easiest. I'd do it again... Glad it turned out the way it did. Phil On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrote: I have some delrin coming and I'm planning on making them for my sloppiness. I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. Phil Sent from my iPhone > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > ============ h -- EE Gifts!) on r> ed ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ============ br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ============ S WEB FORUMS - ="noreferrer" target="_blank">http://forums.matronics.com ============ on Web Site - -Matt Dralle, List Admin. ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution ============ > > ________________________________________________________________________________
Date: Feb 25, 2016
I thought about JB welding my bushing to the weldment or Lok-Tite. Both would have helped significantly reduce the play. But I had so much slop on the inside of the bushing that it still would have been notable. If you don't have that much slop on the inside of the bushing, Tim's solution to permanently place the bushing inside he weldment could work really well for you. Phil Sent from my iPhone > On Feb 25, 2016, at 10:19 AM, Tim Olson wrote: > > > Phil beat me to it. You're absolutely right. > (I like yours and Seans solution by the way) > The housing on the outside of the bushing isn't > really round, so you wouldn't want it to rotate on the > bushing there. If it DID wear, it could potentially wear > a larger hole in the housing, which would then be harder > to fix later. If you rotate it on the bolt, a simple > change of bolt and you're back to normal specs. The > Delrin should work real well. > > This whole mess happened on mine, and I used a filler to > surround the bushing and basically "epoxy" it in to the > weldment. That way it can only rotate on the bolt. > And I took up the end slop as well...also out in the > aileron bellcranks. You should look at those areas and > think about where wear is going to happen, and try to > ensure that any surface that will wear, is a replaceable > part. You will find there are a few places that can > be improved upon from the plans...just like the > original nose gear axle...that was a horrible design > until they went with thicker spacer...then it was just > a bad design. The Matco axle is a great improvement. > Tim > > >> On 2/25/2016 9:50 AM, Phillip Perry wrote: >> Also, by putting the motion on the bolt, any future replacement of parts >> from wear would involve a new bushing and potentially new bolt. Cheap >> and easy to replace. >> >> Putting be motion on the welded piece would lead to a new bushing and >> potentially new weldment. Expensive and more complex to repair. >> >> Phil >> >> >> >> Sent from my iPhone >> >> On Feb 25, 2016, at 9:45 AM, Phillip Perry > > wrote: >> >>> You want the pivot point on the bolt and not the steel welded part. >>> That welded part isn't perfectly round (oblong) from the heat and >>> it's also rough, abrasive, and susceptible to rust - contributing for >>> abrasion and wear. >>> >>> If you keep the motion on the bolt, you have a perfectly round and >>> smooth pivot point. The nut is pinned so there's no chance of running >>> the nut off. >>> >>> PhilI'm very happy with the >>>> outcome. >>>> >>>> This wasn't a terrible change to make and if you have the seats out >>>> and access to a lathe, you could probably do it in less than a day. >>>> You certainly could do it on a drill press with some forethought. >>>> creative jigs, patience, and a few sacrificed pieces of delrin while >>>> you traverse the learning curve, but the lathe is certainly the >>>> fastest and easiest. >>>> >>>> I'd do it again... Glad it turned out the way it did. >>>> >>>> Phil > > > > ________________________________________________________________________________
Date: Feb 25, 2016
Yeah, except I think Delrin is a better solution for the long term. Cheap, and easy to replace. I did see Carl's reply about the outer surface being required to be the pivot point for smooth control operation, but I just have to totally disagree. The controls when pivoting on the bolt are very very smooth. And when you get the play out of the system it's just sweet. My sticks flop around easily with no effort. And, if the bolt does start to wear, it will be easy to detect because the slop will come back. In either the case of the Delrin, or the brass/bronze, I think it'll be a long long time to wait to worry about it. I lube mine occasionally but I'm up to over 1100 hours and have found no slop yet. I'll be surprised if the bolt doesn't last 2000+ hours. Tim On 2/25/2016 10:34 AM, Phillip Perry wrote: > > > I thought about JB welding my bushing to the weldment or Lok-Tite. > Both would have helped significantly reduce the play. But I had so > much slop on the inside of the bushing that it still would have been > notable. > > If you don't have that much slop on the inside of the bushing, Tim's > solution to permanently place the bushing inside he weldment could > work really well for you. > > Phil > > > Sent from my iPhone > >> On Feb 25, 2016, at 10:19 AM, Tim Olson wrote: >> >> >> Phil beat me to it. You're absolutely right. (I like yours and >> Seans solution by the way) The housing on the outside of the >> bushing isn't really round, so you wouldn't want it to rotate on >> the bushing there. If it DID wear, it could potentially wear a >> larger hole in the housing, which would then be harder to fix >> later. If you rotate it on the bolt, a simple change of bolt and >> you're back to normal specs. The Delrin should work real well. >> >> This whole mess happened on mine, and I used a filler to surround >> the bushing and basically "epoxy" it in to the weldment. That way >> it can only rotate on the bolt. And I took up the end slop as >> well...also out in the aileron bellcranks. You should look at >> those areas and think about where wear is going to happen, and try >> to ensure that any surface that will wear, is a replaceable part. >> You will find there are a few places that can be improved upon from >> the plans...just like the original nose gear axle...that was a >> horrible design until they went with thicker spacer...then it was >> just a bad design. The Matco axle is a great improvement. Tim >> >> ________________________________________________________________________________
Date: Feb 25, 2016
As Tim said, according to the plans you're right. But after digging into the problem in more detail and understanding the issu es with the inconsistent weldment and poor fit of the bushing, I believe the plans are the worst possible solution and can be improved on. Will the plans work? Yes, for most people. But in my case I had tolerance s tacking with multiple loose surfaces compounding into a more significant and noticeable problem. Now the controls have zero slop and are silky smooth and consistent through f ull movement in all directions. There's no doubt that the modification to the plans improved the control sys tem in my plane greatly. Phil Sent from my iPhone > On Feb 25, 2016, at 10:28 AM, Carl Froehlich w rote: > > Thanks Phil =93 but I=99ll have to disagree. > > Relative motion between the bushing and bolt means you have small bearing s urfaces, and a nice hard steel bolt wearing steel mating surfaces (the bolt h oles in the weldment). The function of the bushing is to provide a large be aring surface (between the bushing and the pivot tube). The larger surface a rea contributes to why we enjoy such smooth controls in our RVs. The same p rinciple applies to bell cranks and rod end bearings =93 no relative m otion around the bolt. > > There is need from time to time to shorten either the pivot tube or bushin g to achieve slop free operation. You rare cases you may also find need to r eam out the pivot tube. The bushing, when firmly captured in the weldment, s hould have perhaps 1/32=9D exposed on each side of the pivot tube. If needed washers are added to make sure the weldment is not deformed when the bolt is tightened =93 thus maintaining this small gap and preventing b inding. Again a little grease between the bushing and pivot tube is recomme nded. > > Carl > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 10:50 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > Also, by putting the motion on the bolt, any future replacement of parts f rom wear would involve a new bushing and potentially new bolt. Cheap and eas y to replace. > > Putting be motion on the welded piece would lead to a new bushing and pote ntially new weldment. Expensive and more complex to repair. > > Phil > > > > Sent from my iPhone > > On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: > > You want the pivot point on the bolt and not the steel welded part. That w elded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. > > If you keep the motion on the bolt, you have a perfectly round and smooth p ivot point. The nut is pinned so there's no chance of running the nut off. > > Phil > > Sent from my iPhone > > On Feb 25, 2016, at 9:10 AM, Carl Froehlich w rote: > > =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a ti me. Once I began to feel tension on the sticks, I stopped and backed off on e flat where I then dropped in the cotter key in to lock it into position. =9D > > Perhaps I=99m reading this wrong. I thought the objective was for t he bolt to capture the bushing so that there is no relative motion between t he bolt and the bushing. All relative motion should be between the outside o f the bushing and the weldment (in this case the Control Stick Base Pivot Tu be). > > I also believe adding a light grease for the bushing to weldment provides f or reduced corrosion between the dissimilar metals =93 obviously not a n issue when using delrin but perhaps would help keep dirt out of the bearin g surface. > > Carl > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 12:53 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > I thought I'd follow up on the control stick slop issue that I had in my s ystem since I promised a post-bushing report. I had some major play in my c ontrol sticks and ended up following Sean's advice and replaced the brass bu shings with delrin. I attached a couple of photos of the plans to help wit h the explanation. > > After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something clo ser to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. > > I pulled the sticks, stick bases, and control column out of the plane and p ut it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" ro d to see how well it fit and it dropped straight through unrestricted. The i nside of the welded stick bases were way more than the spec'd 3/8". That wa s one part of the problem. The other part of the problem was the slop on th e inside of the bushing between the bushing and the 1/4" bolt. That slop wa s worse than the welded part. Additionally I found one more location for sl op and that was the ability to slide the stick forward and aft on the 1/4" b olt between the stick bases and the control column that the stick bases moun t to. > > The first order of business was to get new bushings machined out. Since t he stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down u ntil it was a thumb-press fit into the stick bases. > > The next step was to drill and ream the hole for the 1/4" bolt down the ce nter. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side o f the tolerance. That didn't work out and I ultimately had to open it to a f ull 1/4" to get the bolt to slide through. > > Back to the work bench where I installed the new bushings. The fit was fr ee of any play between that bases and the bushing and between the bushing an d the bolt. > > The final task was to eliminate the sliding motion of the sticks forward a nd aft on the 1/4" bolt between the stick bases and the control column. Th is was a pretty simple task of inserting AN960-416 and 416L washers to shim a s much of the gaps away as possible. Obviously you can't get all of the ga p out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. > > I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Onc e I began to feel tension on the sticks, I stopped and backed off one flat w here I then dropped in the cotter key in to lock it into position. > > The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opp osition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while w iggling the stick and not find any play between the control surface and stic k. I'm very happy with the outcome. > > This wasn't a terrible change to make and if you have the seats out and ac cess to a lathe, you could probably do it in less than a day. You certainl y could do it on a drill press with some forethought. creative jigs, patienc e, and a few sacrificed pieces of delrin while you traverse the learning cur ve, but the lathe is certainly the fastest and easiest. > > I'd do it again... Glad it turned out the way it did. > > Phil > > > > > > > > > > > > On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrot e: > I have some delrin coming and I'm planning on making them for my sloppines s. > > I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3 /8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in t he mail too. I'll be able turn it down to fit or possibly it would fit with out any working (though I doubt it). > > Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another re amer that's 11/64 (1/64 under sized) to see how it fits first. Then if it' s too tight I'll open it up to the full 3/16 with the other reamer. > > I'll probably have a report on how well it works in the next 2 weeks or po ssibly late next week. > > Phil > > Sent from my iPhone > > > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > > > > I thought about that and wondered about the possibility of sanding them d own a little bit if oversized since the delrin does compress a little. > > > > -------- > > Dave Ford > > RV6 for sale > > RV10 building > > Cadillac, MI > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > > > > > > > > > > > > > > ============ > h -- > EE Gifts!) > on > r> ed > ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.builder sbooks.com > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > -Matt Dralle, List Admin. > ============ > br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?RV10-List > ============ > S WEB FORUMS - > ="noreferrer" target="_blank">http://forums.matronics.com > ============ > on Web Site - > -Matt Dralle, List Admin. > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > ============ > > > > > > > ________________________________________________________________________________
Date: Feb 25, 2016
Ok Phil & Tim. For those reading however I want to emphasize you have transformed a large surface area soft brass bushing (the wear element) in a steel tube bearing to a =9Cknife edge=9D bearing with a steel bolt riding on the small steel weldment bolt hole tabs. It will work, but for most I offer careful assembly of these bearings, bell cranks and such per plans would be the best option. For both of my planes I too enjoy smooth, no slop controls. Now going back into the woodwork.. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 11:54 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings As Tim said, according to the plans you're right. But after digging into the problem in more detail and understanding the issues with the inconsistent weldment and poor fit of the bushing, I believe the plans are the worst possible solution and can be improved on. Will the plans work? Yes, for most people. But in my case I had tolerance stacking with multiple loose surfaces compounding into a more significant and noticeable problem. Now the controls have zero slop and are silky smooth and consistent through full movement in all directions. There's no doubt that the modification to the plans improved the control system in my plane greatly. Phil Sent from my iPhone On Feb 25, 2016, at 10:28 AM, Carl Froehlich wrote: Thanks Phil =93 but I=99ll have to disagree. Relative motion between the bushing and bolt means you have small bearing surfaces, and a nice hard steel bolt wearing steel mating surfaces (the bolt holes in the weldment). The function of the bushing is to provide a large bearing surface (between the bushing and the pivot tube). The larger surface area contributes to why we enjoy such smooth controls in our RVs. The same principle applies to bell cranks and rod end bearings =93 no relative motion around the bolt. There is need from time to time to shorten either the pivot tube or bushing to achieve slop free operation. You rare cases you may also find need to ream out the pivot tube. The bushing, when firmly captured in the weldment, should have perhaps 1/32=9D exposed on each side of the pivot tube. If needed washers are added to make sure the weldment is not deformed when the bolt is tightened =93 thus maintaining this small gap and preventing binding. Again a little grease between the bushing and pivot tube is recommended. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 10:50 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings Also, by putting the motion on the bolt, any future replacement of parts from wear would involve a new bushing and potentially new bolt. Cheap and easy to replace. Putting be motion on the welded piece would lead to a new bushing and potentially new weldment. Expensive and more complex to repair. Phil Sent from my iPhone On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: You want the pivot point on the bolt and not the steel welded part. That welded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. If you keep the motion on the bolt, you have a perfectly round and smooth pivot point. The nut is pinned so there's no chance of running the nut off. Phil Sent from my iPhone On Feb 25, 2016, at 9:10 AM, Carl Froehlich wrote: =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position.=9D Perhaps I=99m reading this wrong. I thought the objective was for the bolt to capture the bushing so that there is no relative motion between the bolt and the bushing. All relative motion should be between the outside of the bushing and the weldment (in this case the Control Stick Base Pivot Tube). I also believe adding a light grease for the bushing to weldment provides for reduced corrosion between the dissimilar metals =93 obviously not an issue when using delrin but perhaps would help keep dirt out of the bearing surface. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 12:53 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings I thought I'd follow up on the control stick slop issue that I had in my system since I promised a post-bushing report. I had some major play in my control sticks and ended up following Sean's advice and replaced the brass bushings with delrin. I attached a couple of photos of the plans to help with the explanation. After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something closer to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" rod to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That was one part of the problem. The other part of the problem was the slop on the inside of the bushing between the bushing and the 1/4" bolt. That slop was worse than the welded part. Additionally I found one more location for slop and that was the ability to slide the stick forward and aft on the 1/4" bolt between the stick bases and the control column that the stick bases mount to. The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down until it was a thumb-press fit into the stick bases. The next step was to drill and ream the hole for the 1/4" bolt down the center. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side of the tolerance. That didn't work out and I ultimately had to open it to a full 1/4" to get the bolt to slide through. Back to the work bench where I installed the new bushings. The fit was free of any play between that bases and the bushing and between the bushing and the bolt. The final task was to eliminate the sliding motion of the sticks forward and aft on the 1/4" bolt between the stick bases and the control column. This was a pretty simple task of inserting AN960-416 and 416L washers to shim as much of the gaps away as possible. Obviously you can't get all of the gap out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position. The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opposition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and stick. I'm very happy with the outcome. This wasn't a terrible change to make and if you have the seats out and access to a lathe, you could probably do it in less than a day. You certainly could do it on a drill press with some forethought. creative jigs, patience, and a few sacrificed pieces of delrin while you traverse the learning curve, but the lathe is certainly the fastest and easiest. I'd do it again... Glad it turned out the way it did. Phil On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrote: I have some delrin coming and I'm planning on making them for my sloppiness. I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. Phil Sent from my iPhone > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > ============ h -- EE Gifts!) on r> ed ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ============ br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ============ S WEB FORUMS - ="noreferrer" target="_blank">http://forums.matronics.com ============ on Web Site - -Matt Dralle, List Admin. ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution ============ > > ________________________________________________________________________________
Subject: Re: Control Stick Slop - Bushings
Date: Feb 25, 2016
I think if they REALLY wanted it to be that way, the way the weldment is produced is very poor. They should have a machined hole through the weldment, not that bent metal seam where the parts come together. It would need to be made with much more precision. If nothing else, a different solution would be to glue in a stainless or steel sleeve of some sort, that is thinner, to provide a nice consistent bore. Then the bushing could be sized to fit and it would be more precise. But the weldment isn't a precision bore of any sort. And so, as we talked about, you consider the long term wear implications, it's just much easier for long term maintenance to make the bolt (and bushing) be the easily replaceable items. And, while I haven't tried this, it certainly would be possible to use a larger diameter bolt and bore out the delrin bushing, if you want to use a thicker bolt...but I see no point in that. Tim On 2/25/2016 10:54 AM, Phillip Perry wrote: > As Tim said, according to the plans you're right. > > But after digging into the problem in more detail and understanding the > issues with the inconsistent weldment and poor fit of the bushing, I > believe the plans are the worst possible solution and can be improved on. > > Will the plans work? Yes, for most people. But in my case I had > tolerance stacking with multiple loose surfaces compounding into a more > significant and noticeable problem. > > Now the controls have zero slop and are silky smooth and consistent > through full movement in all directions. > > There's no doubt that the modification to the plans improved the control > system in my plane greatly. > > Phil > ________________________________________________________________________________
Date: Feb 25, 2016
I understand what you're saying now. You're worried about he bolt rotating o n the steel weldment and having a knife edge wear point. That makes sense. However, I should point out that the bolt is not rotating at all. Just like the plans. Because the bolt doesn't rotate, all of the rotation occurs inside the bushi ng. The wear surface is the smooth interface between the bolt and the bush ing and not the bolt and the weldment edges. That would be a mistake as yo u could saw the bolt right in two and it would be inconsistent too. The case you're describing isn't an issue. Here's a video I just shot showing where the rotation occurs. http://youtu.be/SaywmrHZW24 Phil Sent from my iPhone > On Feb 25, 2016, at 11:24 AM, Carl Froehlich w rote: > > Ok Phil & Tim. > > For those reading however I want to emphasize you have transformed a large surface area soft brass bushing (the wear element) in a steel tube bearing t o a =9Cknife edge=9D bearing with a steel bolt riding on the sma ll steel weldment bolt hole tabs. It will work, but for most I offer carefu l assembly of these bearings, bell cranks and such per plans would be the be st option. For both of my planes I too enjoy smooth, no slop controls. > > Now going back into the woodwork.. > > Carl > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 11:54 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > As Tim said, according to the plans you're right. > > But after digging into the problem in more detail and understanding the is sues with the inconsistent weldment and poor fit of the bushing, I believe t he plans are the worst possible solution and can be improved on. > > Will the plans work? Yes, for most people. But in my case I had toleranc e stacking with multiple loose surfaces compounding into a more significant a nd noticeable problem. > > Now the controls have zero slop and are silky smooth and consistent throug h full movement in all directions. > > There's no doubt that the modification to the plans improved the control s ystem in my plane greatly. > > Phil > > Sent from my iPhone > > On Feb 25, 2016, at 10:28 AM, Carl Froehlich w rote: > > Thanks Phil =93 but I=99ll have to disagree. > > Relative motion between the bushing and bolt means you have small bearing s urfaces, and a nice hard steel bolt wearing steel mating surfaces (the bolt h oles in the weldment). The function of the bushing is to provide a large be aring surface (between the bushing and the pivot tube). The larger surface a rea contributes to why we enjoy such smooth controls in our RVs. The same p rinciple applies to bell cranks and rod end bearings =93 no relative m otion around the bolt. > > There is need from time to time to shorten either the pivot tube or bushin g to achieve slop free operation. You rare cases you may also find need to r eam out the pivot tube. The bushing, when firmly captured in the weldment, s hould have perhaps 1/32=9D exposed on each side of the pivot tube. If needed washers are added to make sure the weldment is not deformed when the bolt is tightened =93 thus maintaining this small gap and preventing b inding. Again a little grease between the bushing and pivot tube is recomme nded. > > Carl > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 10:50 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > Also, by putting the motion on the bolt, any future replacement of parts f rom wear would involve a new bushing and potentially new bolt. Cheap and eas y to replace. > > Putting be motion on the welded piece would lead to a new bushing and pote ntially new weldment. Expensive and more complex to repair. > > Phil > > > > Sent from my iPhone > > On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: > > You want the pivot point on the bolt and not the steel welded part. That w elded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. > > If you keep the motion on the bolt, you have a perfectly round and smooth p ivot point. The nut is pinned so there's no chance of running the nut off. > > Phil > > Sent from my iPhone > > On Feb 25, 2016, at 9:10 AM, Carl Froehlich w rote: > > =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a ti me. Once I began to feel tension on the sticks, I stopped and backed off on e flat where I then dropped in the cotter key in to lock it into position. =9D > > Perhaps I=99m reading this wrong. I thought the objective was for t he bolt to capture the bushing so that there is no relative motion between t he bolt and the bushing. All relative motion should be between the outside o f the bushing and the weldment (in this case the Control Stick Base Pivot Tu be). > > I also believe adding a light grease for the bushing to weldment provides f or reduced corrosion between the dissimilar metals =93 obviously not a n issue when using delrin but perhaps would help keep dirt out of the bearin g surface. > > Carl > > > > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Phillip Perry > Sent: Thursday, February 25, 2016 12:53 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Re: Control Stick Slop - Bushings > > I thought I'd follow up on the control stick slop issue that I had in my s ystem since I promised a post-bushing report. I had some major play in my c ontrol sticks and ended up following Sean's advice and replaced the brass bu shings with delrin. I attached a couple of photos of the plans to help wit h the explanation. > > After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something clo ser to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. > > I pulled the sticks, stick bases, and control column out of the plane and p ut it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" ro d to see how well it fit and it dropped straight through unrestricted. The i nside of the welded stick bases were way more than the spec'd 3/8". That wa s one part of the problem. The other part of the problem was the slop on th e inside of the bushing between the bushing and the 1/4" bolt. That slop wa s worse than the welded part. Additionally I found one more location for sl op and that was the ability to slide the stick forward and aft on the 1/4" b olt between the stick bases and the control column that the stick bases moun t to. > > The first order of business was to get new bushings machined out. Since t he stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down u ntil it was a thumb-press fit into the stick bases. > > The next step was to drill and ream the hole for the 1/4" bolt down the ce nter. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side o f the tolerance. That didn't work out and I ultimately had to open it to a f ull 1/4" to get the bolt to slide through. > > Back to the work bench where I installed the new bushings. The fit was fr ee of any play between that bases and the bushing and between the bushing an d the bolt. > > The final task was to eliminate the sliding motion of the sticks forward a nd aft on the 1/4" bolt between the stick bases and the control column. Th is was a pretty simple task of inserting AN960-416 and 416L washers to shim a s much of the gaps away as possible. Obviously you can't get all of the ga p out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. > > I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Onc e I began to feel tension on the sticks, I stopped and backed off one flat w here I then dropped in the cotter key in to lock it into position. > > The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opp osition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while w iggling the stick and not find any play between the control surface and stic k. I'm very happy with the outcome. > > This wasn't a terrible change to make and if you have the seats out and ac cess to a lathe, you could probably do it in less than a day. You certainl y could do it on a drill press with some forethought. creative jigs, patienc e, and a few sacrificed pieces of delrin while you traverse the learning cur ve, but the lathe is certainly the fastest and easiest. > > I'd do it again... Glad it turned out the way it did. > > Phil > > > > > > > > > > > > > On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrot e: > I have some delrin coming and I'm planning on making them for my sloppines s. > > I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3 /8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in t he mail too. I'll be able turn it down to fit or possibly it would fit with out any working (though I doubt it). > > Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another re amer that's 11/64 (1/64 under sized) to see how it fits first. Then if it' s too tight I'll open it up to the full 3/16 with the other reamer. > > I'll probably have a report on how well it works in the next 2 weeks or po ssibly late next week. > > Phil > > Sent from my iPhone > > > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > > > > I thought about that and wondered about the possibility of sanding them d own a little bit if oversized since the delrin does compress a little. > > > > -------- > > Dave Ford > > RV6 for sale > > RV10 building > > Cadillac, MI > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > > > > > > > > > > > > > > ============ > h -- > EE Gifts!) > on > r> ed > ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.builder sbooks.com > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > -Matt Dralle, List Admin. > ============ > br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics. com/Navigator?RV10-List > ============ > S WEB FORUMS - > ="noreferrer" target="_blank">http://forums.matronics.com > ============ > on Web Site - > -Matt Dralle, List Admin. > ion" rel="noreferrer" target="_blank">http://www.matronics.com/contrib ution > ============ > > > > > > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Feb 25, 2016
Ok =93 again thanks Phil for the explanation, but you pulled me back out of the woodwork. You now have the soft delrin rubbing against the steel tabs on the weldment. The fact that you have no rotation between the bolt and the steel weldment tabs is by your careful application of torque on the nut. The delrin rotates around the bolt only because you have, right now, more friction between the bolt head and nut and the weldment tabs than you do between the delrin ends and the weldment tabs. Perhaps this stays the same but I=99d be surprised if the delrin rod end wear does not open up the joint =93 leaving the bolt loose and free to rotate in the tabs and end up as I described. I assume the reason why you did not simply make the delrin as a replacement for the brass bushing is that you did not like the inside of the steel bearing tube. You would have a much larger bearing surface area between the delrin and the steel bearing tube, and a much larger wear area. Perhaps you got a bad one. I=99ve seen some that needed to be reamed to size but none that where so bad not to use. But =93 we all get to build the planes as we want. I have also deviated from the plans when I did not like a particular design element. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 12:50 PM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings I understand what you're saying now. You're worried about he bolt rotating on the steel weldment and having a knife edge wear point. That makes sense. However, I should point out that the bolt is not rotating at all. Just like the plans. Because the bolt doesn't rotate, all of the rotation occurs inside the bushing. The wear surface is the smooth interface between the bolt and the bushing and not the bolt and the weldment edges. That would be a mistake as you could saw the bolt right in two and it would be inconsistent too. The case you're describing isn't an issue. Here's a video I just shot showing where the rotation occurs. http://youtu.be/SaywmrHZW24 Phil Sent from my iPhone On Feb 25, 2016, at 11:24 AM, Carl Froehlich wrote: Ok Phil & Tim. For those reading however I want to emphasize you have transformed a large surface area soft brass bushing (the wear element) in a steel tube bearing to a =9Cknife edge=9D bearing with a steel bolt riding on the small steel weldment bolt hole tabs. It will work, but for most I offer careful assembly of these bearings, bell cranks and such per plans would be the best option. For both of my planes I too enjoy smooth, no slop controls. Now going back into the woodwork.. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 11:54 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings As Tim said, according to the plans you're right. But after digging into the problem in more detail and understanding the issues with the inconsistent weldment and poor fit of the bushing, I believe the plans are the worst possible solution and can be improved on. Will the plans work? Yes, for most people. But in my case I had tolerance stacking with multiple loose surfaces compounding into a more significant and noticeable problem. Now the controls have zero slop and are silky smooth and consistent through full movement in all directions. There's no doubt that the modification to the plans improved the control system in my plane greatly. Phil Sent from my iPhone On Feb 25, 2016, at 10:28 AM, Carl Froehlich wrote: Thanks Phil =93 but I=99ll have to disagree. Relative motion between the bushing and bolt means you have small bearing surfaces, and a nice hard steel bolt wearing steel mating surfaces (the bolt holes in the weldment). The function of the bushing is to provide a large bearing surface (between the bushing and the pivot tube). The larger surface area contributes to why we enjoy such smooth controls in our RVs. The same principle applies to bell cranks and rod end bearings =93 no relative motion around the bolt. There is need from time to time to shorten either the pivot tube or bushing to achieve slop free operation. You rare cases you may also find need to ream out the pivot tube. The bushing, when firmly captured in the weldment, should have perhaps 1/32=9D exposed on each side of the pivot tube. If needed washers are added to make sure the weldment is not deformed when the bolt is tightened =93 thus maintaining this small gap and preventing binding. Again a little grease between the bushing and pivot tube is recommended. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 10:50 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings Also, by putting the motion on the bolt, any future replacement of parts from wear would involve a new bushing and potentially new bolt. Cheap and easy to replace. Putting be motion on the welded piece would lead to a new bushing and potentially new weldment. Expensive and more complex to repair. Phil Sent from my iPhone On Feb 25, 2016, at 9:45 AM, Phillip Perry wrote: You want the pivot point on the bolt and not the steel welded part. That welded part isn't perfectly round (oblong) from the heat and it's also rough, abrasive, and susceptible to rust - contributing for abrasion and wear. If you keep the motion on the bolt, you have a perfectly round and smooth pivot point. The nut is pinned so there's no chance of running the nut off. Phil Sent from my iPhone On Feb 25, 2016, at 9:10 AM, Carl Froehlich wrote: =9DI tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position.=9D Perhaps I=99m reading this wrong. I thought the objective was for the bolt to capture the bushing so that there is no relative motion between the bolt and the bushing. All relative motion should be between the outside of the bushing and the weldment (in this case the Control Stick Base Pivot Tube). I also believe adding a light grease for the bushing to weldment provides for reduced corrosion between the dissimilar metals =93 obviously not an issue when using delrin but perhaps would help keep dirt out of the bearing surface. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, February 25, 2016 12:53 AM Subject: Re: RV10-List: Re: Control Stick Slop - Bushings I thought I'd follow up on the control stick slop issue that I had in my system since I promised a post-bushing report. I had some major play in my control sticks and ended up following Sean's advice and replaced the brass bushings with delrin. I attached a couple of photos of the plans to help with the explanation. After discovering the slop, I ordered delrin rods from Aircraft Spruce. I ordered 3/8" hoping they'd be a drop-in replacement for a tight fit without any machining and 7/16" in case I had to machine them down to something closer to proper size for a good fit in the control stick base. Each stick was about $3 for a 3 ft stick, so there was no harm in ordering both. I pulled the sticks, stick bases, and control column out of the plane and put it on the bench. On disassembly, I found that there was play between the brass bushing and the welded part of the stick bases. I tried the 3/8" rod to see how well it fit and it dropped straight through unrestricted. The inside of the welded stick bases were way more than the spec'd 3/8". That was one part of the problem. The other part of the problem was the slop on the inside of the bushing between the bushing and the 1/4" bolt. That slop was worse than the welded part. Additionally I found one more location for slop and that was the ability to slide the stick forward and aft on the 1/4" bolt between the stick bases and the control column that the stick bases mount to. The first order of business was to get new bushings machined out. Since the stick bases were more than 3/8" I used the 7/16" delrin rod and turned it down on a lathe that another guy on the airport had. It was turned down until it was a thumb-press fit into the stick bases. The next step was to drill and ream the hole for the 1/4" bolt down the center. I initially tried to ream it to 15/64 (1/64" undersized for the 1/4" bolt) to get a snug fit in the event that the bolt was on the skinny side of the tolerance. That didn't work out and I ultimately had to open it to a full 1/4" to get the bolt to slide through. Back to the work bench where I installed the new bushings. The fit was free of any play between that bases and the bushing and between the bushing and the bolt. The final task was to eliminate the sliding motion of the sticks forward and aft on the 1/4" bolt between the stick bases and the control column. This was a pretty simple task of inserting AN960-416 and 416L washers to shim as much of the gaps away as possible. Obviously you can't get all of the gap out, so you have to take care of the last little bit by tightening the nut and pulling the control column in tighter on the stick bases. I tuned this part of the system like you would a wheel bearing. I rotated the sticks left and right while tightening the nut one flat at a time. Once I began to feel tension on the sticks, I stopped and backed off one flat where I then dropped in the cotter key in to lock it into position. The system linkages are tight (meaning no play) and very smooth (minus the drag of the TruTrak servos). You can work the left and right sticks in opposition directions, like driving a bull dozer, and you won't find any play. You can go all the way out to the control surface and hold it tight while wiggling the stick and not find any play between the control surface and stick. I'm very happy with the outcome. This wasn't a terrible change to make and if you have the seats out and access to a lathe, you could probably do it in less than a day. You certainly could do it on a drill press with some forethought. creative jigs, patience, and a few sacrificed pieces of delrin while you traverse the learning curve, but the lathe is certainly the fastest and easiest. I'd do it again... Glad it turned out the way it did. Phil On Sat, Feb 13, 2016 at 8:08 PM, Phillip Perry wrote: I have some delrin coming and I'm planning on making them for my sloppiness. I'm planning on reaming the bell crank to 3/8 and then seeing how well a 3/8 delrin rod fits. If it's still too loose, I have a 7/16 rod coming in the mail too. I'll be able turn it down to fit or possibly it would fit without any working (though I doubt it). Once I find the rod that fits best, then I'll ream the center on a friends lathe. I have a 3/16" reamer that will work, but I plan on using another reamer that's 11/64 (1/64 under sized) to see how it fits first. Then if it's too tight I'll open it up to the full 3/16 with the other reamer. I'll probably have a report on how well it works in the next 2 weeks or possibly late next week. Phil Sent from my iPhone > On Feb 13, 2016, at 5:29 PM, rvdave wrote: > > > I thought about that and wondered about the possibility of sanding them down a little bit if oversized since the delrin does compress a little. > > -------- > Dave Ford > RV6 for sale > RV10 building > Cadillac, MI > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=452802#452802 > > ============ h -- EE Gifts!) on r> ed ://www.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution -Matt Dralle, List Admin. ============ br> ?RV10-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List ============ S WEB FORUMS - ="noreferrer" target="_blank">http://forums.matronics.com ============ on Web Site - -Matt Dralle, List Admin. ion" rel="noreferrer" target="_blank">http://www.matronics.com/contribution ============ > > ________________________________________________________________________________
Date: Feb 25, 2016
Nice work Phil! Delrin is an amazing material in my opinion. I really don't think mine will ever wear out. I bet I did the swap more than 350 hours ago and mine feels EXACTLY the same as it did after installation. If anything was wearing down I think you would instantly feel the slop again. -------- 40936 RV-10 SB N801VR Flying 530 hours Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453187#453187 ________________________________________________________________________________
Date: Feb 25, 2016
I agree, Delrin is an amazing material, and it is rather hard as a plastic goes. Certainly harder than the UHMW that Vans uses for some friction sizes to prevent wear. It also has had weird uses, like the Army had disks molded from Delrin with a knife edge on the inner diameter. Purpose was to allow you to light it on the knife edge to use as a heating element to warm C rations in the winter. On 2/25/2016 1:08 PM, Strasnuts wrote: > > Nice work Phil! > > Delrin is an amazing material in my opinion. I really don't think mine will ever wear out. I bet I did the swap more than 350 hours ago and mine feels EXACTLY the same as it did after installation. If anything was wearing down I think you would instantly feel the slop again. > > -------- > 40936 > RV-10 SB N801VR Flying > 530 hours > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453187#453187 > > ________________________________________________________________________________
Subject: P Mags
Date: Feb 25, 2016
The 6 cylinder P Mags have been out for a while-has anyone on the list used them and have a report? Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
I was not aware that the 6 cylinder P-mags were available. How long have they been selling them? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453203#453203 ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
Latest from their web site: Note 1/20/16: We are pleased and grateful for the numerous six cylinder (Series 200) fans anxiously waiting for the product release. At this point, we are still cleaning up the operating code and electronics, in preparation for production. Deliveries of proof-sets were pushed back. Engineering has not yet released them for assembly, but is expected soon. On 2/25/2016 10:53 PM, Albert wrote: > The 6 cylinder P Mags have been out for a while-has anyone on the list > used them and have a report? > > Albert Gardner > > RV-10 N991RV > > Yuma, AZ > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
This is interesting .... My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... Kinda shows that they were either shipping or real close. He'll be surprised ..... Linn On 2/26/2016 6:35 AM, Ron Walker wrote: > > Latest from their web site: > > Note 1/20/16: We are pleased and grateful for the numerous six > cylinder (Series 200) fans anxiously waiting for the product release. > At this point, we are still cleaning up the operating code and > electronics, in preparation for production. Deliveries of proof-sets > were pushed back. Engineering has not yet released them for assembly, > but is expected soon. > > On 2/25/2016 10:53 PM, Albert wrote: >> The 6 cylinder P Mags have been out for a while-has anyone on the list >> used them and have a report? >> >> Albert Gardner >> >> RV-10 N991RV >> >> Yuma, AZ >> > > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
I sent a deposit in I think last August when they were expecting shipments to commence some time in October. I have since acquired a pair of one-overhaul slick mags and am about to pull the trigger and install them. Perhaps a good thing - get thru the first 40 hrs with decades old proven technology. --Ron On 2/26/2016 6:22 AM, Linn Walters wrote: > > This is interesting .... > My buddy, another RV-10 builder, delayed shipment of his Pmags because > he wasn't ready for them and freed his up for another customer ..... > Kinda shows that they were either shipping or real close. He'll be > surprised ..... > Linn > > On 2/26/2016 6:35 AM, Ron Walker wrote: >> >> Latest from their web site: >> >> Note 1/20/16: We are pleased and grateful for the numerous six >> cylinder (Series 200) fans anxiously waiting for the product release. >> At this point, we are still cleaning up the operating code and >> electronics, in preparation for production. Deliveries of proof-sets >> were pushed back. Engineering has not yet released them for assembly, >> but is expected soon. >> >> On 2/25/2016 10:53 PM, Albert wrote: >>> The 6 cylinder P Mags have been out for a while-has anyone on the list >>> used them and have a report? >>> >>> Albert Gardner >>> >>> RV-10 N991RV >>> >>> Yuma, AZ >>> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
From their web site it appears they may be shipping to those that pre-ordered, but even that is in doubt. Clearly not available to purchase on open market. On 2/26/2016 2:00 AM, Bob Turner wrote: > > I was not aware that the 6 cylinder P-mags were available. How long have they been selling them? > > -------- > Bob Turner > RV-10 QB > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453203#453203 > > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
Guys For someone who is almost an ignorant on engines, could you please explain what the P Mags are, and the pros and cons of installing them. TIA Carlos Enviado do meu iPhone No dia 26/02/2016, s 12:22, Linn Walters escreveu: > > This is interesting .... > My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... > Kinda shows that they were either shipping or real close. He'll be surprised ..... > Linn > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
1. Installing them makes your engine a non-starter. (8^) It appears none are available. 2. Makes completion date unpredictable.....they have been promised any day now for at least the past 10 years. OK...if they ever get out the door, they are electronic ignition that incorporates an alternator in the unit sufficient to keep it firing if your electrical system fails. They have had a mostly successful 4 cyl product for around 15 years or more. However, a friend with a badly behaving electrical system managed to fry (technical term) his P mag and the E mag resulting in engine stoppage about 400 ft in air from takeoff. He made it back to tell about it...airframe was RV-7A. I went with Bendix magnetos, and will consider other options after I have 500 hours on them. There are other electronic ignition systems out there. Most need to retain one mag for backup, or dual electrical systems to provide independence from main electrical system or one on each system. IF E mag (company name and original product that didn't have the alternator) ever get 6 cyl version out the door, at some point, once proven, would give ability to have dual electronic ignition without having to have dual electrical system. On 2/26/2016 6:46 AM, Carlos Trigo wrote: > > Guys > > For someone who is almost an ignorant on engines, could you please explain what the P Mags are, and the pros and cons of installing them. > > TIA > Carlos > > > Enviado do meu iPhone > > No dia 26/02/2016, s 12:22, Linn Walters escreveu: > >> >> This is interesting .... >> My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... >> Kinda shows that they were either shipping or real close. He'll be surprised ..... >> Linn >> > > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
Still just "vapor ware" I'm afraid. Sent from my iPhone > On Feb 26, 2016, at 7:29 AM, Linn Walters wrote: > > > This is interesting .... > My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... > Kinda shows that they were either shipping or real close. He'll be surprised ..... > Linn > >> On 2/26/2016 6:35 AM, Ron Walker wrote: >> >> Latest from their web site: >> >> Note 1/20/16: We are pleased and grateful for the numerous six cylinder (Series 200) fans anxiously waiting for the product release. At this point, we are still cleaning up the operating code and electronics, in preparation for production. Deliveries of proof-sets were pushed back. Engineering has not yet released them for assembly, but is expected soon. >> >>> On 2/25/2016 10:53 PM, Albert wrote: >>> The 6 cylinder P Mags have been out for a while-has anyone on the list >>> used them and have a report? >>> >>> Albert Gardner >>> >>> RV-10 N991RV >>> >>> Yuma, AZ > > > > > ________________________________________________________________________________
Subject: P Mags
Date: Feb 26, 2016
Carlos, I'm one of those RV-10 guys flying with stock mags - cursing them at every engine start and at every annual when I have to do maintenance and clean these grossly overpriced sparkplugs. I have many happy years flying behind two four cylinder pMag in my now sold RV-8A. I installed them after repeated failures of a dual Lightspeed ignition install. I'm happy to report that after 600+ hours the pMags have been flawless. The attributes follow what you would expect with electronic ignitions: - easy start - no plug fouling - smooth LOP engine operation - all the way to when you lean it out so much it stops. - use of automotive spark plugs (cheap enough to just replace at every annual) - elimination of issues like 500 hour mag maintenance - each pMag has its own power generator - so the old back up battery mess of other electronic ignitions is eliminated - advance timing curve to gain engine efficiently in cruise I (and many others) ping Brad at eMag several times a year to get out the six cylinder version. I understand their business plan is to make this model certified for spam cans so they are going through the regulatory maze. While they will first come out with an experimental version, I suspect they want to do their due diligence so that nothing distracts from the larger prize. I'm guessing this will also be the platform to come out with a new, spam can certified four cylinder model down the line. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Friday, February 26, 2016 8:46 AM Subject: Re: RV10-List: P Mags Guys For someone who is almost an ignorant on engines, could you please explain what the P Mags are, and the pros and cons of installing them. TIA Carlos Enviado do meu iPhone No dia 26/02/2016, s 12:22, Linn Walters escreveu: > > This is interesting .... > My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... > Kinda shows that they were either shipping or real close. He'll be surprised ..... > Linn > ________________________________________________________________________________
Subject: Re: P Mags
Date: Feb 26, 2016
Have you considered the 6 cylinder solution from SDS? It is available now, and (IMO) has advantages and disadvantages compared to PMags. Sent from my iPhone > On Feb 26, 2016, at 11:14 AM, "Carl Froehlich" wrote: > > > Carlos, > > I'm one of those RV-10 guys flying with stock mags - cursing them at every engine start and at every annual when I have to do maintenance and clean these grossly overpriced sparkplugs. > > I have many happy years flying behind two four cylinder pMag in my now sold RV-8A. I installed them after repeated failures of a dual Lightspeed ignition install. I'm happy to report that after 600+ hours the pMags have been flawless. The attributes follow what you would expect with electronic ignitions: > - easy start > - no plug fouling > - smooth LOP engine operation - all the way to when you lean it out so much it stops. > - use of automotive spark plugs (cheap enough to just replace at every annual) > - elimination of issues like 500 hour mag maintenance > - each pMag has its own power generator - so the old back up battery mess of other electronic ignitions is eliminated > - advance timing curve to gain engine efficiently in cruise > > I (and many others) ping Brad at eMag several times a year to get out the six cylinder version. I understand their business plan is to make this model certified for spam cans so they are going through the regulatory maze. While they will first come out with an experimental version, I suspect they want to do their due diligence so that nothing distracts from the larger prize. I'm guessing this will also be the platform to come out with a new, spam can certified four cylinder model down the line. > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo > Sent: Friday, February 26, 2016 8:46 AM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: P Mags > > > Guys > > For someone who is almost an ignorant on engines, could you please explain what the P Mags are, and the pros and cons of installing them. > > TIA > Carlos > > > Enviado do meu iPhone > > No dia 26/02/2016, s 12:22, Linn Walters escreveu: > >> >> This is interesting .... >> My buddy, another RV-10 builder, delayed shipment of his Pmags because he wasn't ready for them and freed his up for another customer ..... >> Kinda shows that they were either shipping or real close. He'll be surprised ..... >> Linn > > > > > > > > > > ________________________________________________________________________________
Subject: Aeropsort NACA Controller and Magnetometer
Date: Feb 29, 2016
For those of you flying and have Aerosport's vent valve, is there ever an interference with magnetometer mounted in the area? I have fabricated bracket for my two Dynon magnetometers in most forward area of tailcone area (see picture) and was worried about its proximity to the vent valve. If there would be a problem would it just be when vent valve is activated (opened or closed)? Thanks, Matt Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453303#453303 Attachments: http://forums.matronics.com//files/img_1708_205.jpg ________________________________________________________________________________
Subject: 12V USB Panel Mount Outlet
Date: Feb 29, 2016
Hi I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. Does anyone have a part # / recommendation for a mountable USB port. Inquiring minds need to know.... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453308#453308 ________________________________________________________________________________
Date: Feb 29, 2016
Hi I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. Does anyone have a part # / recommendation for a mountable USB port. Inquiring minds need to know.... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453311#453311 ________________________________________________________________________________
Subject: Re: Aeropsort NACA Controller and Magnetometer
Date: Feb 29, 2016
Matt I have the same servo (it works great!). I mounted mine on the back of the brace that runs top to bottom behind the baggage compartment bulkhead. I haven't seen any issues with that location. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453312#453312 ________________________________________________________________________________
Subject: Re: 12V USB Panel Mount Outlet
Date: Feb 29, 2016
You will need a sub outlet rated for 2.1 or more amps. Here is one that is dual port 4.2amps capable. I www.aircraftspruce.com/catalog/elpages/eadualusbpanel.php?clickkey=6431 Sent from my iPad > On Feb 29, 2016, at 9:10 PM, kearney wrote: > > > Hi > > I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. > > Does anyone have a part # / recommendation for a mountable USB port. > > Inquiring minds need to know.... > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453311#453311 > > > > > > > > > > ________________________________________________________________________________
Date: Feb 29, 2016
That should be more than enough to keep your iPAD charging. Do you have a lot of programs running in the background? I'm an android guy but I'm constantly killing background programs on my tablet and my wife's iPAD. Also, there could be something wrong with your outlet ..... or the iPAD. Plug your iPAD into a cigarette lighter adapter (if you have one!) to see if it makes any difference. Linn On 2/29/2016 9:00 PM, kearney wrote: > > Hi > > I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. > > Does anyone have a part # / recommendation for a mountable USB port. > > Inquiring minds need to know.... > > Cheers > > Les > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453308#453308 > > ________________________________________________________________________________
Date: Feb 29, 2016
Stein sells one that charges like a bat out of hell... Jeff Carpenter 40304 Ready to Roll On Feb 29, 2016, at 6:00 PM, kearney wrote: > > Hi > > I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. > > Does anyone have a part # / recommendation for a mountable USB port. > > Inquiring minds need to know.... > > Cheers > > Les > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453308#453308 > > > > > > > > > > Westcott Press 1121 Isabel Street Burbank, CA 91506 jeff(at)westcottpress.com 818-861-7300 ________________________________________________________________________________
Date: Feb 29, 2016
Linn I have been running fltplan.go on the IPAD without a lot of background apps. It does, however use cell data for get wx etc. Often the connection is only 3g or worse which I believe increase the power consumption. When I last was flying I tried keeping it plugged in but the battery still drained. It may be my USB outlet in combination with the low quality cell signal. When I am next at the airport I will see if turning the cell data off improves the charging. Cheers Les flying-nut(at)cfl.rr.com wrote: > That should be more than enough to keep your iPAD charging. Do you have > a lot of programs running in the background? > I'm an android guy but I'm constantly killing background programs on my > tablet and my wife's iPAD. > Also, there could be something wrong with your outlet ..... or the > iPAD. Plug your iPAD into a cigarette lighter adapter (if you have > one!) to see if it makes any difference. > Linn > > On 2/29/2016 9:00 PM, kearney wrote: > > > > > > > Hi > > > > I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. > > > > Does anyone have a part # / recommendation for a mountable USB port. > > > > Inquiring minds need to know.... > > > > Cheers > > > > Les > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=453308#453308 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453318#453318 ________________________________________________________________________________
Date: Feb 29, 2016
I've been using fltplan.go on the Samsung tablet along with my homebrew ADS-B receiver lately. Really don't know how to use the program very well. The cell conversations will certainly drain the battery faster, especially if fltplan.go updates weather often. I'm sure that turning cell data off will make the difference. Linn On 2/29/2016 10:18 PM, kearney wrote: > > Linn > > I have been running fltplan.go on the IPAD without a lot of background apps. It does, however use cell data for get wx etc. Often the connection is only 3g or worse which I believe increase the power consumption. > > When I last was flying I tried keeping it plugged in but the battery still drained. It may be my USB outlet in combination with the low quality cell signal. When I am next at the airport I will see if turning the cell data off improves the charging. > > Cheers > > Les > > > flying-nut(at)cfl.rr.com wrote: >> That should be more than enough to keep your iPAD charging. Do you have >> a lot of programs running in the background? >> I'm an android guy but I'm constantly killing background programs on my >> tablet and my wife's iPAD. >> Also, there could be something wrong with your outlet ..... or the >> iPAD. Plug your iPAD into a cigarette lighter adapter (if you have >> one!) to see if it makes any difference. >> Linn >> >> On 2/29/2016 9:00 PM, kearney wrote: >> >>> >>> >>> Hi >>> >>> I have found that my IPAD doesn't seem to charge all that well with the USB outlets I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that. >>> >>> Does anyone have a part # / recommendation for a mountable USB port. >>> >>> Inquiring minds need to know.... >>> >>> Cheers >>> >>> Les >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=453308#453308 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453318#453318 > > ________________________________________________________________________________
Date: Feb 29, 2016
CiAgICAKTWFrZSBzdXJlIHlvdSBoYXZlIGEgMm1hIGNoYXJnZXIgbm90IGEgLjUgbGlrZSBtb3N0 IG9mIHRoZW0gYW5kIGFsc28gYW4gb2VtIGNhYmxlIHRvIHRoZSBJcGFkLkkgaGFkIHRoZSBzYW1l IHByb2JsZW0uCgoKU2VudCBmcm9tIG15IFZlcml6b24gV2lyZWxlc3MgNEcgTFRFIHNtYXJ0cGhv bmUKCi0tLS0tLS0tIE9yaWdpbmFsIG1lc3NhZ2UgLS0tLS0tLS0KRnJvbTogTGlubiBXYWx0ZXJz IDxmbHlpbmctbnV0QGNmbC5yci5jb20+IApEYXRlOiAwMi8yOS8yMDE2ICA3OjM4IFBNICAoR01U LTA4OjAwKSAKVG86IHJ2MTAtbGlzdEBtYXRyb25pY3MuY29tIApTdWJqZWN0OiBSZTogUlYxMC1M aXN0OiBSZTogMTJWIFVTQiBQYW5lbCBNb3VudCBPdXRsZXQgCgotLT4gUlYxMC1MaXN0IG1lc3Nh Z2UgcG9zdGVkIGJ5OiBMaW5uIFdhbHRlcnMgPGZseWluZy1udXRAY2ZsLnJyLmNvbT4KCkkndmUg YmVlbiB1c2luZyBmbHRwbGFuLmdvIG9uIHRoZSBTYW1zdW5nIHRhYmxldCBhbG9uZyB3aXRoIG15 IGhvbWVicmV3IApBRFMtQiByZWNlaXZlciBsYXRlbHkuIFJlYWxseSBkb24ndCBrbm93IGhvdyB0 byB1c2UgdGhlIHByb2dyYW0gdmVyeSB3ZWxsLgpUaGUgY2VsbCBjb252ZXJzYXRpb25zIHdpbGwg Y2VydGFpbmx5IGRyYWluIHRoZSBiYXR0ZXJ5IGZhc3RlciwgCmVzcGVjaWFsbHkgaWYgZmx0cGxh bi5nbyB1cGRhdGVzIHdlYXRoZXIgb2Z0ZW4uwqAgSSdtIHN1cmUgdGhhdCB0dXJuaW5nIApjZWxs IGRhdGEgb2ZmIHdpbGwgbWFrZSB0aGUgZGlmZmVyZW5jZS4KTGlubgoKT24gMi8yOS8yMDE2IDEw OjE4IFBNLCBrZWFybmV5IHdyb3RlOgo+IC0tPiBSVjEwLUxpc3QgbWVzc2FnZSBwb3N0ZWQgYnk6 ICJrZWFybmV5IiA8a2Vhcm5leUBzaGF3LmNhPgo+Cj4gTGlubgo+Cj4gSSBoYXZlIGJlZW4gcnVu bmluZyBmbHRwbGFuLmdvIG9uIHRoZSBJUEFEIHdpdGhvdXQgYSBsb3Qgb2YgYmFja2dyb3VuZCBh cHBzLiBJdCBkb2VzLCBob3dldmVyIHVzZSBjZWxsIGRhdGEgZm9yIGdldCB3eCBldGMuIE9mdGVu IHRoZSBjb25uZWN0aW9uIGlzIG9ubHkgM2cgb3Igd29yc2Ugd2hpY2ggSSBiZWxpZXZlIGluY3Jl YXNlIHRoZSBwb3dlciBjb25zdW1wdGlvbi4KPgo+IFdoZW4gSSBsYXN0IHdhcyBmbHlpbmcgSSB0 cmllZCBrZWVwaW5nIGl0IHBsdWdnZWQgaW4gYnV0IHRoZSBiYXR0ZXJ5IHN0aWxsIGRyYWluZWQu IEl0IG1heSBiZSBteSBVU0Igb3V0bGV0IGluIGNvbWJpbmF0aW9uIHdpdGggdGhlIGxvdyBxdWFs aXR5IGNlbGwgc2lnbmFsLiBXaGVuIEkgYW0gbmV4dCBhdCB0aGUgYWlycG9ydCBJIHdpbGwgc2Vl IGlmIHR1cm5pbmcgdGhlIGNlbGwgZGF0YSBvZmYgaW1wcm92ZXMgdGhlIGNoYXJnaW5nLgo+Cj4g Q2hlZXJzCj4KPiBMZXMKPgo+Cj4KPiBmbHlpbmctbnV0KGF0KWNmbC5yci5jb20gd3JvdGU6Cj4+ IFRoYXQgc2hvdWxkIGJlIG1vcmUgdGhhbiBlbm91Z2ggdG8ga2VlcCB5b3VyIGlQQUQgY2hhcmdp bmcuIERvIHlvdSBoYXZlCj4+IGEgbG90IG9mIHByb2dyYW1zIHJ1bm5pbmcgaW4gdGhlIGJhY2tn cm91bmQ/Cj4+IEknbSBhbiBhbmRyb2lkIGd1eSBidXQgSSdtIGNvbnN0YW50bHkga2lsbGluZyBi YWNrZ3JvdW5kIHByb2dyYW1zIG9uIG15Cj4+IHRhYmxldCBhbmQgbXkgd2lmZSdzIGlQQUQuCj4+ IEFsc28sIHRoZXJlIGNvdWxkIGJlIHNvbWV0aGluZyB3cm9uZyB3aXRoIHlvdXIgb3V0bGV0IC4u Li4uIG9yIHRoZQo+PiBpUEFELsKgIFBsdWcgeW91ciBpUEFEIGludG8gYSBjaWdhcmV0dGUgbGln aHRlciBhZGFwdGVyIChpZiB5b3UgaGF2ZQo+PiBvbmUhKSB0byBzZWUgaWYgaXQgbWFrZXMgYW55 IGRpZmZlcmVuY2UuCj4+IExpbm4KPj4KPj4gT24gMi8yOS8yMDE2IDk6MDAgUE0sIGtlYXJuZXkg d3JvdGU6Cj4+Cj4+PsKgwqAgCj4+Pgo+Pj7CoMKgIEhpCj4+Pgo+Pj7CoMKgIEkgaGF2ZSBmb3Vu ZCB0aGF0IG15IElQQUQgZG9lc24ndCBzZWVtIHRvIGNoYXJnZSBhbGwgdGhhdCB3ZWxsIHdpdGgg dGhlIFVTQiBvdXRsZXRzIEkgaW5zdGFsbGVkIGluIG15IHBhbmVsIC8gY29uc29sZS4gVGhleSBh cmUgcmF0ZWQgYXQgMi4xIGFtcHMgYnV0IEkgZ3Vlc3MgdGhlcmUgbXVzdCBiZSBtb3JlIHRvIGl0 IHRoYW4gdGhhdC4KPj4+Cj4+PsKgwqAgRG9lcyBhbnlvbmUgaGF2ZSBhIHBhcnQgIyAvIHJlY29t bWVuZGF0aW9uIGZvciBhIG1vdW50YWJsZSBVU0IgcG9ydC4KPj4+Cj4+PsKgwqAgSW5xdWlyaW5n IG1pbmRzIG5lZWQgdG8ga25vdy4uLi4KPj4+Cj4+PsKgwqAgQ2hlZXJzCj4+Pgo+Pj7CoMKgIExl cwo+Pj4KPj4+Cj4+Pgo+Pj4KPj4+wqDCoCBSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6Cj4+ Pgo+Pj7CoMKgIGh0dHA6Ly9mb3J1bXMubWF0cm9uaWNzLmNvbS92aWV3dG9waWMucGhwP3A9NDUz MzA4IzQ1MzMwOAo+Pj4KPj4+Cj4+Pgo+Pj4KPj4+Cj4+Pgo+Pj4KPj4+Cj4+Pgo+Pj4KPj4+Cj4+ Pgo+Pj4KPj4+Cj4KPgo+Cj4KPiBSZWFkIHRoaXMgdG9waWMgb25saW5lIGhlcmU6Cj4KPiBodHRw Oi8vZm9ydW1zLm1hdHJvbmljcy5jb20vdmlld3RvcGljLnBocD9wPTQ1MzMxOCM0NTMzMTgKPgo+ Cj4KPgo+Cj4KPgo+Cj4KPgo+Cj4KCgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT0KXy09wqDCoMKgwqDCoMKgIC0tIFBsZWFz ZSBTdXBwb3J0IFlvdXIgTGlzdHMgVGhpcyBNb250aCAtLQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDC oCAoQW5kIEdldCBTb21lIEFXRVNPTUUgRlJFRSBHaWZ0cyEpCl8tPQpfLT3CoMKgIE5vdmVtYmVy IGlzIHRoZSBBbm51YWwgTGlzdCBGdW5kIFJhaXNlci7CoCBDbGljayBvbgpfLT3CoMKgIHRoZSBD b250cmlidXRpb24gbGluayBiZWxvdyB0byBmaW5kIG91dCBtb3JlIGFib3V0Cl8tPcKgwqAgdGhp cyB5ZWFyJ3MgVGVycmlmaWMgRnJlZSBJbmNlbnRpdmUgR2lmdHMgcHJvdmlkZWQKXy09wqDCoCBi eToKXy09wqDCoCAKXy09wqDCoMKgwqAgKiBUaGUgQnVpbGRlcidzIEJvb2tzdG9yZSB3d3cuYnVp bGRlcnNib29rcy5jb20KXy09Cl8tPcKgwqAgTGlzdCBDb250cmlidXRpb24gV2ViIFNpdGU6Cl8t PQpfLT3CoMKgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPQpf LT3CoMKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0IQpfLT0KXy09wqDCoMKg wqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoCAtTWF0 dCBEcmFsbGUsIExpc3QgQWRtaW4uCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqAgLSBU aGUgUlYxMC1MaXN0IEVtYWlsIEZvcnVtIC0KXy09IFVzZSB0aGUgTWF0cm9uaWNzIExpc3QgRmVh dHVyZXMgTmF2aWdhdG9yIHRvIGJyb3dzZQpfLT0gdGhlIG1hbnkgTGlzdCB1dGlsaXRpZXMgc3Vj aCBhcyBMaXN0IFVuL1N1YnNjcmlwdGlvbiwKXy09IEFyY2hpdmUgU2VhcmNoICYgRG93bmxvYWQs IDctRGF5IEJyb3dzZSwgQ2hhdCwgRkFRLApfLT0gUGhvdG9zaGFyZSwgYW5kIG11Y2ggbXVjaCBt b3JlOgpfLT0KXy09wqDCoCAtLT4gaHR0cDovL3d3dy5tYXRyb25pY3MuY29tL05hdmlnYXRvcj9S VjEwLUxpc3QKXy09Cl8tPT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09Cl8tPcKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBNQVRS T05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxzbyBhdmFpbGFibGUg dmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09wqDCoCAtLT4gaHR0cDovL2ZvcnVtcy5tYXRyb25p Y3MuY29tCl8tPQpfLT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqAgLSBMaXN0IENvbnRy aWJ1dGlvbiBXZWIgU2l0ZSAtCl8tPcKgIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBw b3J0IQpfLT3CoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDCoMKgwqDC oMKgwqDCoMKgIC1NYXR0IERyYWxsZSwgTGlzdCBBZG1pbi4KXy09wqDCoCAtLT4gaHR0cDovL3d3 dy5tYXRyb25pY3MuY29tL2NvbnRyaWJ1dGlvbgpfLT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PQoKCgo ________________________________________________________________________________
Subject: Re: 12V USB Panel Mount Outlet and ADS-b
Date: Feb 29, 2016
I have the same setup Linn- my Stratux sits in the baggage area using a 12v cigarette adaptor with a 2.4A USB, runs from start (when it automatically powers up to shutdown) Never had an issue with that. BTW- Avare gets you 2-3 times more traffic than FPGo but weather is better on FPGo. With Avare it uses loads of battery (Samsung Tab 2 has a bad battery to start with) and I also have the IO app that drives the battery even more, even with all that load on the Samsung the battery charges faster than it drains. Les- I have two daughters with two ipad mini running on a 12V USB connection at the SAME TIME. They both see charging while they use it. I fear you are using a plug that is either not getting enough power and/or an adaptor that is overloaded. I think the bluetooth sucks battery on the phone, I usually disble bluetooth and use the Wifi as a hotspot without battery issues. This is the one I use and it has worked flawlessly, http://www.amazon.com/gp/product/B00VH84L5E?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 . For the price it cant be beat it is 2X 2.4Amps. Best of success! Pascal -----Original Message----- From: Linn Walters Sent: Monday, February 29, 2016 7:38 PM Subject: Re: RV10-List: Re: 12V USB Panel Mount Outlet I've been using fltplan.go on the Samsung tablet along with my homebrew ADS-B receiver lately. Really don't know how to use the program very well. The cell conversations will certainly drain the battery faster, especially if fltplan.go updates weather often. I'm sure that turning cell data off will make the difference. Linn On 2/29/2016 10:18 PM, kearney wrote: > > Linn > > I have been running fltplan.go on the IPAD without a lot of background > apps. It does, however use cell data for get wx etc. Often the connection > is only 3g or worse which I believe increase the power consumption. > > When I last was flying I tried keeping it plugged in but the battery still > drained. It may be my USB outlet in combination with the low quality cell > signal. When I am next at the airport I will see if turning the cell data > off improves the charging. > > Cheers > > Les > > > flying-nut(at)cfl.rr.com wrote: >> That should be more than enough to keep your iPAD charging. Do you have >> a lot of programs running in the background? >> I'm an android guy but I'm constantly killing background programs on my >> tablet and my wife's iPAD. >> Also, there could be something wrong with your outlet ..... or the >> iPAD. Plug your iPAD into a cigarette lighter adapter (if you have >> one!) to see if it makes any difference. >> Linn >> >> On 2/29/2016 9:00 PM, kearney wrote: >> >>> >>> Hi >>> >>> I have found that my IPAD doesn't seem to charge all that well with >>> the USB outlets I installed in my panel / console. They are rated at 2.1 >>> amps but I guess there must be more to it than that. >>> >>> Does anyone have a part # / recommendation for a mountable USB port. >>> >>> Inquiring minds need to know.... >>> >>> Cheers >>> >>> Les >>> >>> >>> >>> >>> Read this topic online here: >>> >>> http://forums.matronics.com/viewtopic.php?p=453308#453308 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453318#453318 > > ________________________________________________________________________________
Date: Mar 01, 2016
These are what I've been using: http://www.amazon.com/gp/product/B00E1UWA4O?psc=1&redirect=true&ref_=od_aui_detailpages00 The SCOSCHE USBC242M. It's also 4.8A total, and does a very fast charge. Costs a little more than the Anker below, but is shorter which stays in the socket very well and doesn't stick out more than maybe 1/4". I probably own 8 or 10 of them and haven't had one go bad. Noise free so far in the plane. Just bought 2 more tonight for the RV-14. The best I've found for AC use that we bring along traveling for the family (and use at home) is this: (I've bought 3 of them) http://www.amazon.com/Anker-Charger-PowerPort-Multi-Port-Samsung/dp/B00VH8ZW02/ref=sr_1_1?s=wireless&ie=UTF8&qid=1456812858&sr=1-1&keywords=anker+5-port The Anker 40W/8A 5-port charger. You can't go wrong with that one. It charges as fast as the device can take. Both of the above have replaced all the other various USB chargers that I've bought or received with phones and devices. Having the extra port(s) makes them much nicer than the standard ones. Tim On 2/29/2016 11:14 PM, Live wrote: > > I have the same setup Linn- my Stratux sits in the baggage area using > a 12v cigarette adaptor with a 2.4A USB, runs from start (when it > automatically powers up to shutdown) Never had an issue with that. > BTW- Avare gets you 2-3 times more traffic than FPGo but weather is > better on FPGo. With Avare it uses loads of battery (Samsung Tab 2 has > a bad battery to start with) and I also have the IO app that drives > the battery even more, even with all that load on the Samsung the > battery charges faster than it drains. > Les- I have two daughters with two ipad mini running on a 12V USB > connection at the SAME TIME. They both see charging while they use it. > I fear you are using a plug that is either not getting enough power > and/or an adaptor that is overloaded. I think the bluetooth sucks > battery on the phone, I usually disble bluetooth and use the Wifi as a > hotspot without battery issues. > This is the one I use and it has worked flawlessly, > http://www.amazon.com/gp/product/B00VH84L5E?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 > . For the price it cant be beat it is 2X 2.4Amps. > Best of success! > Pascal > ________________________________________________________________________________
Subject: Those @&$#^ flap position sensors!
Date: Mar 01, 2016
I've about had all I can handle finding a simple and effective way to mount these Ray Allen POS-12 sensors in the airframe. No matter what I do I can't find a good way to mount them where they can travel with the flap system. I've been trying to mount them under the flap tube covers on the rear seats mounted to the rear spar area and attached to the tube. I've nearly thrown my phone clear across this hangar about 15 times and I've invented cuss words that didn't exist before I took on this (what should be) ridiculously simple task. I need some better ideas and photos. I don't want to scrap this plane because of a $20 sensor but right now I've had all I can handle. Thanks for letting me vent and for the ideas gentlemen. Phil Sent from my iPhone ________________________________________________________________________________
Date: Mar 01, 2016
No issues here. I have the naca vent valve maybe 6 inches behind the baggage bulkhead right near the top skin, and the magnetometer on the top of the front side of the next bulkhead back. On Mon, Feb 29, 2016 at 5:54 PM, mhealydds wrote: > > For those of you flying and have Aerosport's vent valve, is there ever an > interference with magnetometer mounted in the area? I have fabricated > bracket for my two Dynon magnetometers in most forward area of tailcone > area (see picture) and was worried about its proximity to the vent valve. > If there would be a problem would it just be when vent valve is activated > (opened or closed)? > > Thanks, > Matt > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=453303#453303 > > > Attachments: > > http://forums.matronics.com//files/img_1708_205.jpg > > ________________________________________________________________________________
Date: Mar 01, 2016
I copied Mark Cooper's install and although I am not yet flying it appears to be able to go stop to stop w/o issue. Scroll down to the pictures in the post below on his blog. https://myrv10factory.wordpress.com/2012/12/08/first-real-traffic-info-avion ics-checklists-oxygen-head-unit-illumination-holiday-decorations-flap-positi on-sensor-onboard-audio-entertainment/ Not knowing how much pain he went through to settle on the mount location and size of plate I tried to mimic the same size for the aluminum plate attaching the POS-12 to the hinge as him. I then attached it to the flap tube with the adel clamp and held it in place on the rear seat finding the optimal spot to attach the hinge to the rear seat bulkhead. Like I said not flying yet but I can get it to go stop to stop... just barely but it does. This VAF thread has some other ideas as well http://www.vansairforce.com/community/showthread.php?t=56927 Ben Westfall Portland, OR -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Tuesday, March 1, 2016 8:09 AM Subject: RV10-List: Those @&$#^ flap position sensors! I've about had all I can handle finding a simple and effective way to mount these Ray Allen POS-12 sensors in the airframe. No matter what I do I can't find a good way to mount them where they can travel with the flap system. I've been trying to mount them under the flap tube covers on the rear seats mounted to the rear spar area and attached to the tube. I've nearly thrown my phone clear across this hangar about 15 times and I've invented cuss words that didn't exist before I took on this (what should be) ridiculously simple task. I need some better ideas and photos. I don't want to scrap this plane because of a $20 sensor but right now I've had all I can handle. Thanks for letting me vent and for the ideas gentlemen. Phil Sent from my iPhone ________________________________________________________________________________
Subject: Re: Those @&$#^ flap position sensors!
Date: Mar 01, 2016
I did the exact same setup for the flap positioning sensor. Works perfectly well, 4 years in service. One important note. You Do Not need to mechanically go end to end with flap travel on the sensor. In fact you don't want it to, that way you are never putting mechanical stress on the parts. In the software for whatever flight screen you are using you set up the "limits" as reported by the sensor and those values get mapped to the flap position displayed. It's just like calibrating the fuel senders. Bob Newman TCW Technologies, LLC 610-928-3420 > On Mar 1, 2016, at 4:11 PM, Ben Westfall wrote: > > > I copied Mark Cooper's install and although I am not yet flying it appears > to be able to go stop to stop w/o issue. Scroll down to the pictures in the > post below on his blog. > > https://myrv10factory.wordpress.com/2012/12/08/first-real-traffic-info-avion > ics-checklists-oxygen-head-unit-illumination-holiday-decorations-flap-positi > on-sensor-onboard-audio-entertainment/ > > Not knowing how much pain he went through to settle on the mount location > and size of plate I tried to mimic the same size for the aluminum plate > attaching the POS-12 to the hinge as him. I then attached it to the flap > tube with the adel clamp and held it in place on the rear seat finding the > optimal spot to attach the hinge to the rear seat bulkhead. Like I said not > flying yet but I can get it to go stop to stop... just barely but it does. > > This VAF thread has some other ideas as well > http://www.vansairforce.com/community/showthread.php?t=56927 > > Ben Westfall > Portland, OR > > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry > Sent: Tuesday, March 1, 2016 8:09 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Those @&$#^ flap position sensors! > > > I've about had all I can handle finding a simple and effective way to mount > these Ray Allen POS-12 sensors in the airframe. > > No matter what I do I can't find a good way to mount them where they can > travel with the flap system. > > I've been trying to mount them under the flap tube covers on the rear seats > mounted to the rear spar area and attached to the tube. > > I've nearly thrown my phone clear across this hangar about 15 times and I've > invented cuss words that didn't exist before I took on this (what should be) > ridiculously simple task. > > I need some better ideas and photos. I don't want to scrap this plane > because of a $20 sensor but right now I've had all I can handle. > > Thanks for letting me vent and for the ideas gentlemen. > > Phil > > > > Sent from my iPhone > > > > > ________________________________________________________________________________
Date: Mar 01, 2016
Somewhere I saw an installation that used an Adel clamp on the flap torque tube with the POS-12 mounted to the side of the tunnel. A tab with a row of small holes was attached to the Adel clamp to create an arm using it's screw and the holes used to set the travel. Model airplane clevises were used to connect the POS-12 to the tab. Linn On 3/1/2016 4:11 PM, Ben Westfall wrote: > > I copied Mark Cooper's install and although I am not yet flying it appears > to be able to go stop to stop w/o issue. Scroll down to the pictures in the > post below on his blog. > > https://myrv10factory.wordpress.com/2012/12/08/first-real-traffic-info-avion > ics-checklists-oxygen-head-unit-illumination-holiday-decorations-flap-positi > on-sensor-onboard-audio-entertainment/ > > Not knowing how much pain he went through to settle on the mount location > and size of plate I tried to mimic the same size for the aluminum plate > attaching the POS-12 to the hinge as him. I then attached it to the flap > tube with the adel clamp and held it in place on the rear seat finding the > optimal spot to attach the hinge to the rear seat bulkhead. Like I said not > flying yet but I can get it to go stop to stop... just barely but it does. > > This VAF thread has some other ideas as well > http://www.vansairforce.com/community/showthread.php?t=56927 > > Ben Westfall > Portland, OR > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry > Sent: Tuesday, March 1, 2016 8:09 AM > To: rv10-list(at)matronics.com > Subject: RV10-List: Those @&$#^ flap position sensors! > > > I've about had all I can handle finding a simple and effective way to mount > these Ray Allen POS-12 sensors in the airframe. > > No matter what I do I can't find a good way to mount them where they can > travel with the flap system. > > I've been trying to mount them under the flap tube covers on the rear seats > mounted to the rear spar area and attached to the tube. > > I've nearly thrown my phone clear across this hangar about 15 times and I've > invented cuss words that didn't exist before I took on this (what should be) > ridiculously simple task. > > I need some better ideas and photos. I don't want to scrap this plane > because of a $20 sensor but right now I've had all I can handle. > > Thanks for letting me vent and for the ideas gentlemen. > > Phil > > > Sent from my iPhone > > ________________________________________________________________________________
Subject: hoses
Date: Mar 01, 2016
Does anyone have a hose list for the IO540 installation? I want to replace existing hoses with Stratoflex lifetime versions. Any suppliers? --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 01, 2016
Phil Don=92t feel lonely. I felt the same way a couple of months ago, struggled to find a solution and rested my case. Being doing something else in the meantime. So, I am glad you asked. I=92m all hears =85 Thanks Carlos -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: ter=E7a-feira, 1 de Mar=E7o de 2016 16:09 Subject: RV10-List: Those @&$#^ flap position sensors! philperry9(at)gmail.com> I've about had all I can handle finding a simple and effective way to mount these Ray Allen POS-12 sensors in the airframe. No matter what I do I can't find a good way to mount them where they can travel with the flap system. I've been trying to mount them under the flap tube covers on the rear seats mounted to the rear spar area and attached to the tube. I've nearly thrown my phone clear across this hangar about 15 times and I'v e invented cuss words that didn't exist before I took on this (what should be ) ridiculously simple task. I need some better ideas and photos. I don't want to scrap this plane because of a $20 sensor but right now I've had all I can handle. Thanks for letting me vent and for the ideas gentlemen. Phil Sent from my iPhone www.buildersbooks.com http://www.matronics.com/contribution st Day http://www.matronics.com/Navigator?RV10-List http://www.matronics.com/contribution --- Este e-mail foi verificado em termos de v=EDrus pelo software antiv=EDrus A vast. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: hoses
Date: Mar 01, 2016
I'm pretty certain that Bill Curtis had the list on his build site. I've lost the bookmark. On 3/1/2016 3:14 PM, David wrote: > Does anyone have a hose list for the IO540 installation? I want to > replace existing hoses with Stratoflex lifetime versions. Any suppliers? > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > > ________________________________________________________________________________
Date: Mar 01, 2016
Phil I understand your frustration. If you wish, I'll certainly take your project off your hands at no charge to you!. Failing that, what I did was mount the POS12 on the foot-well wall using a small length of hinge. I then, as others have, installed an adel clamp to the flap with a tube. The adel clamp had a small L shaped bracket that attached to the POS-12 arm. Very simple and quite similar if not identical to what others did. The trick was to get the hinge / pos 12 on a place on the foot-well where the full range of the flap movement wouldn't over / under extend the POS-12 arm. This I did by trial and errior. When I had it exactly where I wanted, I used pop rivets to attach the hinge. I used aluminium tape to hole the hinge pin end in place so I could remove easily at a later date if required. Here are a couple of trial that may help visualize things. Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453351#453351 Attachments: http://forums.matronics.com//files/2012_10_24_152642_293.jpg http://forums.matronics.com//files/2012_10_24_152654_401.jpg ________________________________________________________________________________
Date: Mar 02, 2016
Here is how I did it. Remember, you do not need full travel of the sensor, so keep the radius as small as possible. 50% travel will do just as well as full travel. The rods can be purchased at any RC hobby shop. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453357#453357 Attachments: http://forums.matronics.com//files/img_1941_263.jpg ________________________________________________________________________________
Date: Mar 02, 2016
More Photos -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453358#453358 Attachments: http://forums.matronics.com//files/img_1946_133.jpg http://forums.matronics.com//files/img_2088_830.jpg ________________________________________________________________________________
Subject: Ameri-King Corporation, Huntington Beach, CA, PArts and Articles
Date: Mar 02, 2016
FYI. > Begin forwarded message: > > From: "Federal Aviation Administration" > Subject: Ameri-King Corporation, Huntington Beach, CA, PArts and Articles > Date: March 2, 2016 at 12:43:22 PM CST > To: > Reply-To: usafaa(at)public.govdelivery.com > > > > You have subscribed to the FAA Unapproved Parts Notifications alerts from the U.S. Federal Aviation Administration. This information has recently been updated, and is available at: > > http://www.faa.gov/aircraft/safety/programs/sups/upn/2016/ > > The UPN Number is 2016-2013NM460018 > > STAY CONNECTED: > <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&100&&&https://twitter.com/faanews> <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&101&&&http://www.facebook.com/FAA> <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&102&&&http://www.linkedin.com/company/faa> <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&103&&&http://www.youtube.com/user/FAAnews> <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&104&&&https://www.flickr.com/photos/FAANews> <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&105&&&https://instagram.com/faa/> > SUBSCRIBER SERVICES > Manage Preferences <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&106&&&https://public.govdelivery.com/accounts/U SAFAA/subscriber/edit?preferences=true#tab1> | Unsubscribe <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&107&&&https://subscriberhelp.govdelivery.com/hc /en-us/articles/200216456-Q-How-do-I-unsubscribe-from-email-updates-> | Help <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&108&&&https://subscriberhelp.govdelivery.com/hc /en-us> > > This email was sent to gengrumpy(at)aol.com using GovDelivery, on behalf of: U.S. Federal Aviation Administration =B7 800 Independence Avenue, SW =B7 Washington, DC 20591 =B7 1-866-TELL-FAA (1-866-835-5322) <http://links.govdelivery.com/track?type=click&enid=ZWFzPTEmbXNpZD0mYX VpZD0mbWFpbGluZ2lkPTIwMTYwMzAyLjU1OTQ3NjMxJm1lc3NhZ2VpZD1NREItUFJELUJVTC0y MDE2MDMwMi41NTk0NzYzMSZkYXRhYmFzZWlkPTEwMDEmc2VyaWFsPTE2ODIwMTA4JmVtYWlsaW Q9Z2VuZ3J1bXB5QGFvbC5jb20mdXNlcmlkPWdlbmdydW1weUBhb2wuY29tJnRhcmdldGlkPSZm bD0mbXZpZD0mZXh0cmE9JiYm&&&109&&&http://www.govdelivery.com/portals/powere d-by> ________________________________________________________________________________
Subject: Re: Ameri-King Corporation, Huntington Beach, CA, PArts and
Arti
Date: Mar 02, 2016
What this site says is that AmeriKing has had all of their TSO's pulled, effective 28 Dec 2015. Any boxes bought after that date are not legal to use. It appears A-K has continued to sell ELTs in spite of this. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453379#453379 ________________________________________________________________________________
Subject: Re: maintenance tips
Date: Mar 03, 2016
The erratically high readings appeared at aprox 4-500 hours in my plane as well. You simply cleaned the external contacts and the high readings disappeared? I will try same and report. Thanks. On 2/13/2016 9:16 AM, David wrote: > > The 360003 fuel pressure sensor has a tendency to start reading > erratically high fuel pressure after several hundred hours; an IA > friend said the same is true for the PMA stamped part for about 10-15 > times the experimental price. I replaced the part at about 400 hours > and again at about 800 hours. The new one started the routine a couple > of months ago. After thinking about the transducer, I decided to try > cleaning the contacts; I have flown several hours since then and the > sensor is operating normally. I think that the problem may be the oil > residue, etc swirling about under the cowl and causing contact > problems. So far so good. > > David McNeill > > N46007 TT 1000+ > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 04, 2016
Here's what I did... Really simple and flying without issue for several years. Regards, Jay N433RV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453425#453425 Attachments: http://forums.matronics.com//files/hpim0857_103.jpg ________________________________________________________________________________
Subject: need to buy new HZ prop from vans
Date: Mar 08, 2016
Due to a brake failure, my existing prop tried to eat the hangar door. Vans will sell me another prop if one of the builders who used an MT prop will allow me to buy their HZ prop per Vans agreement. Anyone not using their HZ prop and would allow me to obtain "their" prop via Vans, please advise. David --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: need to buy new HZ prop from vans
Date: Mar 08, 2016
David You can use mine Les Kearney 40-643 Sent from my iPhone > On Mar 8, 2016, at 13:12, David wrote: > > Due to a brake failure, my existing prop tried to eat the hangar door. Van s will sell me another prop if one of the builders who used an MT prop will a llow me to buy their HZ prop per Vans agreement. Anyone not using their HZ p rop and would allow me to obtain =9Ctheir=9D prop via Vans, plea se advise. > > David > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com ________________________________________________________________________________
Subject: prop
Date: Mar 08, 2016
Thanks to all. I may have a reasonable option. BTW that fuel pressure sensor is still working properly about 15 hours after cleaning the contacts. David --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Mar 08, 2016
Have you talked to Ottesson or Warner prop about getting replacement blades? you can use "my" prop, as I bought MT from different vendor. On 3/8/2016 1:12 PM, David wrote: > Due to a brake failure, my existing prop tried to eat the hangar door. > Vans will sell me another prop if one of the builders who used an MT > prop will allow me to buy their HZ prop per Vans agreement. Anyone not > using their HZ prop and would allow me to obtain their prop via Vans, > please advise. > > David > > > This email has been sent from a virus-free computer protected by Avast. > www.avast.com > > > ________________________________________________________________________________
Subject: Back seat question
Date: Mar 11, 2016
My plane back seats backs don't fold foward . They seem to be held from folding flat by the seat belt attachments. Are they supposed to be able to fold flat? Alan N668G Sent from my iPhone ________________________________________________________________________________
Subject: Re: Back seat question
Date: Mar 11, 2016
No. That's normal. Jesse Saint Saint Aviation, Inc. 352-427-0285 jesse(at)saintaviation.com Sent from my iPad > On Mar 11, 2016, at 12:18 PM, Alan Mekler MD wrote: > > > My plane back seats backs don't fold foward . They seem to be held from folding flat by the seat belt attachments. > Are they supposed to be able to fold flat? > Alan > N668G > > > Sent from my iPhone > > > > ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Date: Mar 11, 2016
Not really. You can alway pull the seat back pin and remove them if you are transforming the back to cargo hauling. Carl > On Mar 11, 2016, at 9:18 AM, Alan Mekler MD wrote: > > > My plane back seats backs don't fold foward . They seem to be held from folding flat by the seat belt attachments. > Are they supposed to be able to fold flat? > Alan > N668G > > > Sent from my iPhone > > > > ________________________________________________________________________________
Subject: Re: New (Free) Aviation App
Date: Mar 16, 2016
We just completed a major upgrade to Airport Courtesy Cars App, which now makes the app available on ALL devices, including the web. Please upgrade your app to the latest version. If your phone does not support the app, then go to our new website, www.airportcourtesycars.com The site is mobile friendly and you can place its icon to your phone or tablet screen. Both versions show Google maps for each state, the app version still shows the entire US map which some people prefer. The site currently lists over 1560 cars. Thanks for your input and contact us with any questions, new listings, or corrections to airportcars101(at)gmail.com And please check out our advertisers and FBOs who offer you fuel discounts. The app remains free. -------- Glenn Brasch RV-9A Flying Medevac Helicopter Pilot (Ret) Owner, "Airport Courtesy Cars" Smart Phone App and www.airportcourtesycars.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=453841#453841 ________________________________________________________________________________
Subject: California Push Pull
Date: Mar 17, 2016
I have an extra cable that I purchased from California Push Pull in 2015; Actually I bought two cables but used one to replace a sticky throttle cable. The second cable could serve as either a mixture or throttle cable. This has a higher internal melt temperature than Van supplied cables. This cable is 176-V-TT-2-52 and is for pedestal controls. Surplus to my needs as I replaced the throttle cable with the other one and I purchase some special order Teflon core cables from Spruce which I will install soon. This cable is new for $50 and I will ship ground to USA.. David 480-626-4048 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Ride to Sun'n Fun
Date: Mar 23, 2016
Hi guys I am an homebuilder from Portugal (Europe) and I'm visiting in Florida, planning to go to Sun'n Fun. If any of you is planning to fly into Lakeland between the 5th and the 7th of April, and you have a spare seat in your airplane, I would very much appreciate to take it, from a nearby airport. Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Subject: Stratux permanent installation in RV-10
Date: Mar 26, 2016
After flying with the Stratux ADS-B In receiver for a few months, I liked it and decided to build it into the plane. Mounting an inexpensive ($17) external ADS-B antenna on the belly pretty far back in the tailcone and connecting to the unit via RG400 cable did wonders for improving the unit's reception compared to the folding telescoping antennas that it comes with. And although I spent a bit more trying various components that I didn't end up using, if one wanted to start from scratch, everything needed to build and install it would be less than $270. I put together a web page with details including parts and price list for anyone who might be considering this for their -10: http://faculty.washington.edu/dmasys/stratux.html As always, YMMV and there are lots of alternative ways to get this accomplished. Was quite happy with how this turned out, since it basically tripled the number of towers the unit sees in most locations. -Dan Masys RV-10 N104LD 880 hrs, once a project always a project ________________________________________________________________________________
Subject: Re: Ride to Sun'n Fun
Date: Mar 29, 2016
Carlos, I am going on Friday-Saterday. Let me know if your plans change. Sent from my iPhone > On Mar 23, 2016, at 10:04 AM, Carlos Trigo wrote: > > > Hi guys > > I am an homebuilder from Portugal (Europe) and I'm visiting in Florida, planning to go to Sun'n Fun. > > If any of you is planning to fly into Lakeland between the 5th and the 7th of April, and you have a spare seat in your airplane, I would very much appreciate to take it, from a nearby airport. > > Thanks > Carlos > > Enviado do meu iPhone > > > > ________________________________________________________________________________
Subject: GARMIN autopilot servos wiring
Date: Mar 29, 2016
Guys Those of you who installed or are installing a GARMIN G3X, which wires or multi-wire cable did you use to connect the autopilot servos? Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Date: Mar 30, 2016
You would use shielded multi conductor wires for the CAN portion and RS-232's (and possibly some trim), but individual wires for the CWS, PWR, GND, and CAN termination (if you're using it for the terminator on the CAN). Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Tuesday, March 29, 2016 8:21 PM Subject: RV10-List: GARMIN autopilot servos wiring Guys Those of you who installed or are installing a GARMIN G3X, which wires or multi-wire cable did you use to connect the autopilot servos? Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Date: Mar 30, 2016
The list seems too quite lately. I'm thinking about building another plane and wonder if it should be a tail-dragger or tri-gear, and which EFIS and primer is best? Albert Gardner RV-19 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: GARMIN autopilot servos wiring
Date: Mar 30, 2016
It has been quiet. I wonder if people are reluctant to post while Matt is in recovery? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454363#454363 ________________________________________________________________________________
Date: Mar 30, 2016
Subject: Sun n Fun
Is there a get together at Sun n Fun for RV builders? This will be my second time at the event, but the first time with my -10. We are planning to camp out in HBC and would love to meet some of you guys face to face. Shannon Hicks ________________________________________________________________________________
Subject: Re: Sun n Fun
Date: Mar 30, 2016
Don't know but we will be in the area with a -10. Gonna try the air boats after wards. Dan Sent from my iPhone > On Mar 30, 2016, at 11:28 AM, Shannon Hicks wrote: > > Is there a get together at Sun n Fun for RV builders? This will be my second time at the event, but the first time with my -10. > > We are planning to camp out in HBC and would love to meet some of you guys face to face. > > Shannon Hicks ________________________________________________________________________________
Date: Mar 30, 2016
RV-14 tail wheel with Blue Mountain EFIS and Corrosion X for primer. 8^) Then get RV-10 wings, and fuselage parts to stretch it back into a -10, tail dragger. Of course you could upgrade to steam gauges and use Ipad for MFD. For nostalgia you could add a Laurance GPS por Apollo 920. On 3/30/2016 8:46 AM, Albert wrote: > > The list seems too quite lately. I'm thinking about building another plane > and wonder if it should be a tail-dragger or tri-gear, and which EFIS and > primer is best? > Albert Gardner > RV-19 N991RV > Yuma, AZ > > ________________________________________________________________________________
Date: Mar 31, 2016
Thank you Stein I believe the DYNON servo wires are all unshielded. Why do you recommend the CAN, the RS-232 and the trim wires to be shielded? Best Carlos Enviado do meu iPhone No dia 30/03/2016, s 10:39, Stein Bruch escreveu: > > You would use shielded multi conductor wires for the CAN portion and > RS-232's (and possibly some trim), but individual wires for the CWS, PWR, > GND, and CAN termination (if you're using it for the terminator on the CAN). > > > Cheers, > Stein > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo > Sent: Tuesday, March 29, 2016 8:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: GARMIN autopilot servos wiring > > > Guys > > Those of you who installed or are installing a GARMIN G3X, which wires or > multi-wire cable did you use to connect the autopilot servos? > > Thanks > Carlos > > Enviado do meu iPhone > > > > > > > > ________________________________________________________________________________
Date: Mar 31, 2016
Because it's what Garmin recommends in their manual! :) That said, it is recommended to be shielded just to keep "noise" to a minimum, but we actually have seen people retrofit both TruTrak and Dynon Autopilots with the Garmin Servos, re-use their existing wiring with no ill effects. Of course it's always best to follow the manufacturer recommendations, but we have seen people do it the other way and have acceptable results....we've also seen people have unacceptable results as well though (so fair warning). Cheers, Stein -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Thursday, March 31, 2016 1:32 PM Subject: Re: RV10-List: GARMIN autopilot servos wiring Thank you Stein I believe the DYNON servo wires are all unshielded. Why do you recommend the CAN, the RS-232 and the trim wires to be shielded? Best Carlos Enviado do meu iPhone No dia 30/03/2016, s 10:39, Stein Bruch escreveu: > > You would use shielded multi conductor wires for the CAN portion and > RS-232's (and possibly some trim), but individual wires for the CWS, > PWR, GND, and CAN termination (if you're using it for the terminator on the CAN). > > > Cheers, > Stein > > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carlos > Trigo > Sent: Tuesday, March 29, 2016 8:21 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: GARMIN autopilot servos wiring > > > Guys > > Those of you who installed or are installing a GARMIN G3X, which wires > or multi-wire cable did you use to connect the autopilot servos? > > Thanks > Carlos > > Enviado do meu iPhone > > > > > > > > ________________________________________________________________________________
Subject: Propwash 4-1-2016 edition: New Vans Aircraft Anounced
Date: Apr 01, 2016
If you don't subscribe to Propwash you may have missed this awesome anouncement from Vans aircraft http://aero-news.net/ Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Propwash 4-1-2016 edition: New Vans Aircraft Anounced
Date: Apr 01, 2016
Seems like a April 1 joke to me. -----Original Message----- From: Albert Sent: Friday, April 01, 2016 1:23 PM Subject: RV10-List: Propwash 4-1-2016 edition: New Vans Aircraft Anounced If you don't subscribe to Propwash you may have missed this awesome anouncement from Vans aircraft http://aero-news.net/ Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Apr 02, 2016
Yup, I think you're spot on there! Warm regards Patrick > On 2 Apr 2016, at 07:18, Live wrote: > > > Seems like a April 1 joke to me. > > -----Original Message----- From: Albert Sent: Friday, April 01, 2016 1:23 PM To: rv10-list(at)matronics.com Subject: RV10-List: Propwash 4-1-2016 edition: New Vans Aircraft Anounced > > If you don't subscribe to Propwash you may have missed this awesome > anouncement from Vans aircraft > http://aero-news.net/ > > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > > > > > > ________________________________________________________________________________
Date: Apr 02, 2016
I might have been too subtle but these guys put out an annual April Fools Edition. I especially liked the one about Santa Monica airport. Albert Gardner ---- Live wrote: > > Seems like a April 1 joke to me. > > -----Original Message----- > From: Albert > Sent: Friday, April 01, 2016 1:23 PM > To: rv10-list(at)matronics.com > Subject: RV10-List: Propwash 4-1-2016 edition: New Vans Aircraft Anounced > > > If you don't subscribe to Propwash you may have missed this awesome > anouncement from Vans aircraft > http://aero-news.net/ > > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > > > > > > ________________________________________________________________________________
Date: Apr 01, 2016
April Fool > On Apr 1, 2016, at 3:23 PM, Albert wrote: > > > If you don't subscribe to Propwash you may have missed this awesome > anouncement from Vans aircraft > http://aero-news.net/ > > Albert Gardner > RV-10 N991RV > Yuma, AZ > > > > > > ________________________________________________________________________________
Date: Apr 01, 2016
I think they have it all wrong. I understand that Van's will come out with an RV-10B. All aluminum cabin and doors, wings on top where they belong, and mains moved to firewall, made out of flat spring steel Wittman legs, with a good sized Scott/Alaskan bushwhell tail wheel. Control surfaces modified for design flutter speed of 250 kts, any 520, 540, 550 or 580 series engine of up to 350 hp supported, with or without turbochargers, for up to 225 kt cruise speed. However, stall speed will be 40 kts with full fowler flaps, permitting operation anywhere a C-180 can go. Sheet metal cowling, leaving only optional wheel pants and wing tip and tail tips made of fiberglass. Plans, standard and quick build kits will be available on this date 2017. Any resemblance to the afformentioned C-180 is a pure coincidence. -sent from the microchip implanted in my forearm On Fri, Apr 1, 2016 at 1:23 PM, Albert wrote: > > If you don't subscribe to Propwash you may have missed this awesome > anouncement from Vans aircraft > http://aero-news.net/ > > Albert Gardner > RV-10 N991RV > Yuma, AZ > > ________________________________________________________________________________
Subject: Bleeding Brakes
Date: Apr 10, 2016
Any thoughts.....I have trying to bleed my brakes as per instructions in Grove brake instructions (pumping up with oil can) to test for leaks and such. I have done it twice and seem to get same result. I get a great hard pedal on pilot (left) side for both right and left brakes but cannot get seem to get same result on co-pilot (right) side for either pedal. What am I doing wrong here? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454797#454797 ________________________________________________________________________________
Subject: Re: Bleeding Brakes
Date: Apr 10, 2016
Are you sure you have the lines routed correctly? Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Apr 10, 2016, at 1:36 PM, mhealydds wrote: > > > Any thoughts.....I have trying to bleed my brakes as per instructions in Grove brake instructions (pumping up with oil can) to test for leaks and such. I have done it twice and seem to get same result. I get a great hard pedal on pilot (left) side for both right and left brakes but cannot get seem to get same result on co-pilot (right) side for either pedal. What am I doing wrong here? > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=454797#454797 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 10, 2016
We had similar issues when first activating the system, and again when replaced "O" rings. Finally got tired of fiddling with it and while applying pressure on the right wheel cylinder input nipple, cracked the line at the co-pilot foot pedal to get the air out and it solved the problem. Later, - Lew -----Original Message----- From: mhealydds Sent: Sunday, April 10, 2016 1:36 PM Subject: RV10-List: Bleeding Brakes Any thoughts.....I have trying to bleed my brakes as per instructions in Grove brake instructions (pumping up with oil can) to test for leaks and such. I have done it twice and seem to get same result. I get a great hard pedal on pilot (left) side for both right and left brakes but cannot get seem to get same result on co-pilot (right) side for either pedal. What am I doing wrong here? ________________________________________________________________________________
Date: Apr 10, 2016
Hi When I was first bleeding my brakes I had a b*tch of a time getting it done right. The problem was one of the pedals was ever so slightly forward so that the valve in the cylinder was closed and the cylinder was not being bled. I suggest you check that the pedals are all fully back so that the cylinder valves are open when bleeding. If you a park brake, be sure it is disengaged as well. Don't ask about how I know that little gem.... Cheers Les Read this topic online here: http://forums.matronics.com/viewtopic.php?p=454805#454805 ________________________________________________________________________________
Date: Apr 10, 2016
I use a pressurized brake bleeder from ATS: http://www.aircraft-tool.com/shop/detail.aspx?PRODUCT_ID=225DX I just use a 1/4" tube just pressed onto the bleeder instead of the rig they supply. They both leak about the same. The trick is to keep the pot pressurized and keep the flow rate high enough to grab the little bubbles that get stuck to the sides of the tube. It's probably overkill but I tapped a pressure gauge into the pot. I keep it around 15 PSI. You'll get more bubbles out the reservoir if you slowly move each brake pedal off it's stop. Also, you might try putting a drop of hydraulic fluid on the top of the cylinder to re-wet the seal, especially if air seems to be entering like a slow leak. --Dave On Sun, Apr 10, 2016 at 10:36 AM, mhealydds wrote: > > Any thoughts.....I have trying to bleed my brakes as per instructions in > Grove brake instructions (pumping up with oil can) to test for leaks and > such. I have done it twice and seem to get same result. I get a great hard > pedal on pilot (left) side for both right and left brakes but cannot get > seem to get same result on co-pilot (right) side for either pedal. What am > I doing wrong here? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=454797#454797 > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Apr 10, 2016
Another trick I use to get the air out. Attach a 1/4" AN fitting (1/8" pipe thread) to the top of the brake reservoir. From this fitting attach a short U of 1/4" aluminum tubing and end in a jar. The problem I had was getting the air out. With this set up I can pump from the caliper and watch the air bubbles come out of the reservoir. I had to pump a lot of fluid to get the last air bubbles out. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of lewgall(at)charter.net Sent: Sunday, April 10, 2016 2:00 PM Subject: Re: RV10-List: Bleeding Brakes We had similar issues when first activating the system, and again when replaced "O" rings. Finally got tired of fiddling with it and while applying pressure on the right wheel cylinder input nipple, cracked the line at the co-pilot foot pedal to get the air out and it solved the problem. Later, - Lew -----Original Message----- From: mhealydds Sent: Sunday, April 10, 2016 1:36 PM Subject: RV10-List: Bleeding Brakes Any thoughts.....I have trying to bleed my brakes as per instructions in Grove brake instructions (pumping up with oil can) to test for leaks and such. I have done it twice and seem to get same result. I get a great hard pedal on pilot (left) side for both right and left brakes but cannot get seem to get same result on co-pilot (right) side for either pedal. What am I doing wrong here? ________________________________________________________________________________
Subject: HID lights
Date: Apr 12, 2016
Anyone have a HID light with pigtail for the Rigid Industries system ; I have damaged one and trying to determine whether a replacement is possible. I am also considering whether to replace with new LED system. David 480-626-4048 --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: HID lights
Date: Apr 12, 2016
No HID here but: There is a good write up on the Vans forums on the use of the Squadron light s by Baja Designs. http://www.vansairforce.com/community/showthread.php?t=105248 Seems to be a really bright option and the prices have come down some in the last year. Justin > On Apr 12, 2016, at 05:23, David wrote: > > Anyone have a HID light with pigtail for the Rigid Industries system ; I h ave damaged one and trying to determine whether a replacement is possible. I am also considering whether to replace with new LED system. > > David > 480-626-4048 > > Virus-free. www.avast.com ________________________________________________________________________________
Subject: Level flight position
Date: Apr 14, 2016
Guys I am installing the magnetometer before having installed the gear legs or the wheels. Is it correct to assume that, in the RV-10, leveling the Mid cabin decks (those 2 mid-fuselage surfaces below the doors bottoms) does correspond to a 0 degree pitch attitude n flight? Thanks Carlos Enviado do meu iPhone ________________________________________________________________________________
Subject: Re: Level flight position
Date: Apr 14, 2016
Yes Put a level on them and also laterally across the cockpit Sent from my iPhone > On Apr 13, 2016, at 4:53 PM, Carlos Trigo wrote: > > > Guys > > I am installing the magnetometer before having installed the gear legs or the wheels. > > Is it correct to assume that, in the RV-10, leveling the Mid cabin decks (those 2 mid-fuselage surfaces below the doors bottoms) does correspond to a 0 degree pitch attitude n flight? > > Thanks > Carlos > > Enviado do meu iPhone > > > > > ________________________________________________________________________________
Date: Apr 14, 2016
So with what sytem did you settle at the end and what did you buy? Cheers Werner > >> On Apr 13, 2016, at 4:53 PM, Carlos Trigo wrote: >> >> >> Guys >> >> I am installing the magnetometer before having installed the gear legs or the wheels. >> >> Is it correct to assume that, in the RV-10, leveling the Mid cabin decks (those 2 mid-fuselage surfaces below the doors bottoms) does correspond to a 0 degree pitch attitude n flight? >> >> Thanks >> Carlos >> >> Enviado do meu iPhone >> >> >> >> >> > > ________________________________________________________________________________
Date: Apr 15, 2016
Hi Werner There were other than technical reasons to choose the GARMIN G3X. I bought all the G3X parts necessary for the "internal" installation, so I will buy later the Displays and the Autopilot panel. Cheers Carlos Enviado do meu iPhone No dia 14/04/2016, s 09:43, Werner Schneider escreveu: > > So with what sytem did you settle at the end and what did you buy? > > Cheers > > Werner > > >> >>> On Apr 13, 2016, at 4:53 PM, Carlos Trigo wrote: >>> >>> >>> Guys >>> >>> I am installing the magnetometer before having installed the gear legs or the wheels. >>> >>> Is it correct to assume that, in the RV-10, leveling the Mid cabin decks (those 2 mid-fuselage surfaces below the doors bottoms) does correspond to a 0 degree pitch attitude n flight? >>> >>> Thanks >>> Carlos >>> >>> Enviado do meu iPhone > > > > ________________________________________________________________________________
Date: Apr 19, 2016
Subject: Matronics Web Server Back Online
Dear Listers, The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. Email services were not impacted in anyway. back online and all resources were successfully restored from a backup. My apologies for the down time. Matt Dralle Matronics Email and Forum Admin ________________________________________________________________________________
Subject: Re: Matronics Web Server Back Online
Date: Apr 19, 2016
Matt, It is so good to hear that you're able to work on this! But make sure you put your health above everything else. How are you doing? -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=455220#455220 ________________________________________________________________________________
From: Robert Brunkenhoefer <robertbrunk(at)mac.com>
Date: Apr 19, 2016
Gals you are back. Regards, Robert N 661G Sent from my iPhone > On Apr 19, 2016, at 3:44 PM, Matt Dralle wrote: > > > Dear Listers, > > The Matronics Web server lost a critical system hard drive yesterday 4/18/2016. I have been working feverishly for the last 24 hours to repair the system and get the Matronics Forums and other web-based resources back online. > > Email services were not impacted in anyway. > is back online and all resources were successfully restored from a backup. > > My apologies for the down time. > > Matt Dralle > Matronics Email and Forum Admin > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2016
I'm recovering well. Back to work on May 2nd. Even driving now for a couple of weeks, hopefully flying the RVs again in the Summer! Matt At 02:03 PM 4/19/2016 Tuesday, you wrote: > >Matt, > >It is so good to hear that you're able to work on this! But make sure you put your health above everything else. How are you doing? > >-------- >Bob Turner >RV-10 QB > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Apr 19, 2016
Thank God. Great to hear! Sent from my iPhone > On Apr 19, 2016, at 4:18 PM, Matt Dralle wrote: > > > I'm recovering well. Back to work on May 2nd. > > Even driving now for a couple of weeks, hopefully flying the RVs again in the Summer! > > Matt > > > At 02:03 PM 4/19/2016 Tuesday, you wrote: >> >> Matt, >> >> It is so good to hear that you're able to work on this! But make sure you put your health above everything else. How are you doing? >> >> -------- >> Bob Turner >> RV-10 QB > > > > Matt G Dralle | Matronics | 581 Jeannie Way | Livermore | CA | 94550 > 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email > http://www.matronics.com/ WWW | Featuring Products For Aircraft > > > > > > ________________________________________________________________________________
Subject: Powering the EFIS system
Date: Apr 19, 2016
Group I am beginning to install the EFIS G3X system from GARMIN in the RV-10, and I have to put power into (not more not less than) 12 devices (2 Display units, 2 ADAHRS, 1 engine module, 3 autopilot servos and so on). In some devices there are 2 independent power inputs. I am trying to figure out which will be the best architecture for the power circuits to these 12 devices. I know that some of you are against the single Avionics switch, and I am leaning to agree, not including that single point of failure, but how about the distribution system? I am not searching for opinions on the breaker or fuses discussion, just to know what other people did or recommend to do with busses and circuits. I should add that I have a dual battery /dual alternator energy system. All good suggestions welcome! Thanks Carlos --- Este e-mail foi verificado em termos de v=C3=ADrus pelo software antiv=C3 =ADrus Avast. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Powering the EFIS system
Date: Apr 20, 2016
Hi Carlos, I can only point you to what I did and the reason. I have configured for IFR and high levels of redundancy. refer to my build log: www.ozrv10.com and see what I did. It is very much a personal decision and comfort zone. Regards, Andrew On 20-Apr-16 8:36 AM, Carlos Trigo wrote: > > Group > > I am beginning to install the EFIS G3X system from GARMIN in the > RV-10, and I have to put power into (not more not less than) _12 > devices_ (2 Display units, 2 ADAHRS, 1 engine module, 3 autopilot > servos and so on). > > In some devices there are 2 independent power inputs. > > I am trying to figure out which will be the best architecture for the > power circuits to these 12 devices. > > I know that some of you are against the single Avionics switch, and I > am leaning to agree, not including that single point of failure, but > how about the distribution system? > > I am not searching for opinions on the breaker or fuses discussion, > just to know what other people did or recommend to do with busses and > circuits. > > I should add that I have a dual battery /dual alternator energy system. > > All good suggestions welcome! > > Thanks > > Carlos > > > > Sem vrus. www.avast.com > > > ________________________________________________________________________________
Date: Apr 19, 2016
Carlos, The lid is off the can of worms. This should be interesting! I've found t hat coating my wires in chromate primer has benefits too. ;) All seriousness, though I can see people breaking out the flame throwers alr eady, what does your main buss look like? Single Alt / Single Battery? Du al alt (hot/standby) single battery, etc.... Phil Sent from my iPhone > On Apr 19, 2016, at 5:36 PM, Carlos Trigo wrote: > > Group > > I am beginning to install the EFIS G3X system from GARMIN in the RV-10, an d I have to put power into (not more not less than) 12 devices (2 Display un its, 2 ADAHRS, 1 engine module, 3 autopilot servos and so on). > In some devices there are 2 independent power inputs. > > I am trying to figure out which will be the best architecture for the powe r circuits to these 12 devices. > I know that some of you are against the single Avionics switch, and I am l eaning to agree, not including that single point of failure, but how about t he distribution system? > I am not searching for opinions on the breaker or fuses discussion, just t o know what other people did or recommend to do with busses and circuits. > > I should add that I have a dual battery /dual alternator energy system. > All good suggestions welcome! > > Thanks > Carlos > > > > > > > > Sem v=C3=ADrus. www.avast.com ________________________________________________________________________________
Date: Apr 19, 2016
CiAgICAKQWxsIG15IGF2aW9uaWNzIG9wZXJhdGUgb2ZmIGEgc2VwYXJhdGUgYnVzcyB3aGljaCBp cyBhIGJsYWRlIGZ1c2UgYmxvY2suIMKgTXkgc2luZ2xlIGF2aW9uaWNzIHN3aXRjaCBvcGVyYXRl cyBhIG1pbmlhdHVyZSAzMCBhbXAgcmVsYXkgdGhhdCBwb3dlcnMgdGhlIGJsb2NrLgoKClNlbnQg ZnJvbSBteSBWZXJpem9uIFdpcmVsZXNzIDRHIExURSBzbWFydHBob25lCgotLS0tLS0tLSBPcmln aW5hbCBtZXNzYWdlIC0tLS0tLS0tCkZyb206IENhcmxvcyBUcmlnbyA8dHJpZ29AbWFpbC50ZWxl cGFjLnB0PiAKRGF0ZTogMDQvMTkvMjAxNiAgNjozNiBQTSAgKEdNVC0wNTowMCkgClRvOiBhZXJv ZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tLCBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbSAKU3Vi amVjdDogUlYxMC1MaXN0OiBQb3dlcmluZyB0aGUgRUZJUyBzeXN0ZW0gCgo8IS0tCi8qIEZvbnQg RGVmaW5pdGlvbnMgKi8KQGZvbnQtZmFjZQoJe2ZvbnQtZmFtaWx5OkNhbGlicmk7CglwYW5vc2Ut MToyIDE1IDUgMiAyIDIgNCAzIDIgNDt9Ci8qIFN0eWxlIERlZmluaXRpb25zICovCnAuTXNvTm9y bWFsLCBsaS5Nc29Ob3JtYWwsIGRpdi5Nc29Ob3JtYWwKCXttYXJnaW46MGNtOwoJbWFyZ2luLWJv dHRvbTouMDAwMXB0OwoJZm9udC1zaXplOjExLjBwdDsKCWZvbnQtZmFtaWx5OiJDYWxpYnJpIiwi c2Fucy1zZXJpZiI7Cgltc28tZmFyZWFzdC1sYW5ndWFnZTpFTi1VUzt9CmE6bGluaywgc3Bhbi5N c29IeXBlcmxpbmsKCXttc28tc3R5bGUtcHJpb3JpdHk6OTk7Cgljb2xvcjpibHVlOwoJdGV4dC1k ZWNvcmF0aW9uOnVuZGVybGluZTt9CmE6dmlzaXRlZCwgc3Bhbi5Nc29IeXBlcmxpbmtGb2xsb3dl ZAoJe21zby1zdHlsZS1wcmlvcml0eTo5OTsKCWNvbG9yOnB1cnBsZTsKCXRleHQtZGVjb3JhdGlv bjp1bmRlcmxpbmU7fQpzcGFuLkVtYWlsU3R5bGUxNwoJe21zby1zdHlsZS10eXBlOnBlcnNvbmFs LWNvbXBvc2U7Cglmb250LWZhbWlseToiQXJpYWwiLCJzYW5zLXNlcmlmIjsKCWNvbG9yOndpbmRv d3RleHQ7fQouTXNvQ2hwRGVmYXVsdAoJe21zby1zdHlsZS10eXBlOmV4cG9ydC1vbmx5OwoJZm9u dC1mYW1pbHk6IkNhbGlicmkiLCJzYW5zLXNlcmlmIjsKCW1zby1mYXJlYXN0LWxhbmd1YWdlOkVO LVVTO30KQHBhZ2UgV29yZFNlY3Rpb24xCgl7c2l6ZTo2MTIuMHB0IDc5Mi4wcHQ7CgltYXJnaW46 NzAuODVwdCAzLjBjbSA3MC44NXB0IDMuMGNtO30KZGl2LldvcmRTZWN0aW9uMQoJe3BhZ2U6V29y ZFNlY3Rpb24xO30KLS0+R3JvdXDCoEkgYW0gYmVnaW5uaW5nIHRvIGluc3RhbGwgdGhlIEVGSVMg RzNYIHN5c3RlbSBmcm9tIEdBUk1JTiBpbiB0aGUgUlYtMTAsIGFuZCBJIGhhdmUgdG8gcHV0IHBv d2VyIGludG8gKG5vdCBtb3JlIG5vdCBsZXNzIHRoYW4pIDEyIGRldmljZXMgKDIgRGlzcGxheSB1 bml0cywgMiBBREFIUlMsIDEgZW5naW5lIG1vZHVsZSwgMyBhdXRvcGlsb3Qgc2Vydm9zIGFuZCBz byBvbikuSW4gc29tZSBkZXZpY2VzIHRoZXJlIGFyZSAyIGluZGVwZW5kZW50IHBvd2VyIGlucHV0 cy7CoEkgYW0gdHJ5aW5nIHRvIGZpZ3VyZSBvdXQgd2hpY2ggd2lsbCBiZSB0aGUgYmVzdCBhcmNo aXRlY3R1cmUgZm9yIHRoZSBwb3dlciBjaXJjdWl0cyB0byB0aGVzZSAxMiBkZXZpY2VzLkkga25v dyB0aGF0IHNvbWUgb2YgeW91IGFyZSBhZ2FpbnN0IHRoZSBzaW5nbGUgQXZpb25pY3Mgc3dpdGNo LCBhbmQgSSBhbSBsZWFuaW5nIHRvIGFncmVlLCBub3QgaW5jbHVkaW5nIHRoYXQgc2luZ2xlIHBv aW50IG9mIGZhaWx1cmUsIGJ1dCBob3cgYWJvdXQgdGhlIGRpc3RyaWJ1dGlvbiBzeXN0ZW0/SSBh bSBub3Qgc2VhcmNoaW5nIGZvciBvcGluaW9ucyBvbiB0aGUgYnJlYWtlciBvciBmdXNlcyBkaXNj dXNzaW9uLCBqdXN0IHRvIGtub3cgd2hhdCBvdGhlciBwZW9wbGUgZGlkIG9yIHJlY29tbWVuZCB0 byBkbyB3aXRoIGJ1c3NlcyBhbmQgY2lyY3VpdHMuwqBJIHNob3VsZCBhZGQgdGhhdCBJIGhhdmUg YSBkdWFsIGJhdHRlcnkgL2R1YWwgYWx0ZXJuYXRvciBlbmVyZ3kgc3lzdGVtLkFsbCBnb29kIHN1 Z2dlc3Rpb25zIHdlbGNvbWUhwqBUaGFua3NDYXJsb3PCoCDCoMKgwqDCoMKgwqAKIAoJCiAgICAg IAoJCVNlbSB2w61ydXMuIHd3dy5hdmFzdC5jb20gCQkKCQoK ________________________________________________________________________________
Date: Apr 19, 2016
On 4/19/2016 10:17 PM, davidsoutpost wrote: > All my avionics operate off a separate buss which is a blade fuse > block. My single avionics switch operates a miniature 30 amp relay > that powers the block. To minimize the single point failure mode, you should wire the switch to remove power to the relay in the 'on' position, and wire the relay so that when the relay is off it supplies power to the avionics fuses. No matter which part fails .... the switch or the relay ..... the avionics fuse block still gets power. Linn ________________________________________________________________________________
Date: Apr 20, 2016
From: David Clifford <davidsoutpost(at)comcast.net>
So I understand this,,,,the buss will always have power to it no matter the switch position? ----- Original Message ----- From: "Linn Walters" <flying-nut(at)cfl.rr.com> Sent: Tuesday, April 19, 2016 10:34:22 PM Subject: Re: RV10-List: Powering the EFIS system On 4/19/2016 10:17 PM, davidsoutpost wrote: All my avionics operate off a separate buss which is a blade fuse block. My single avionics switch operates a miniature 30 amp relay that powers the block. To minimize the single point failure mode, you should wire the switch to remove power to the relay in the 'on' position, and wire the relay so that when the relay is off it supplies power to the avionics fuses. No matter which part fails .... the switch or the relay ..... the avionics fuse block still gets power. Linn ________________________________________________________________________________
Date: Apr 19, 2016
On 4/19/2016 10:55 PM, David Clifford wrote: > So I understand this,,,,the buss will always have power to it no > matter the switch position? No. When the SPDT switch is in the 'off' position it supplies power to the relay which is 'on' and the NC contacts remove power to the buss. It's the inverse of what most builders will do .... SP switch on, relay on to supply power to the buss through the NO contacts. With this wiring method the relay is not needed if the switch has the proper current rating. I don't know what David's panel current draw really is but think it's way less than 30 amps. Fuses are there to protect the wires from excess current, not the equipment attached. So, if you have 6 ea. 5A fuses ..... that's 30A! If every electrical item in my plane is on and stable I draw less than 6 amps. Strobes on startup and radio transmitting will add some more. Linn > > > ------------------------------------------------------------------------ > *From: *"Linn Walters" <flying-nut(at)cfl.rr.com> > *To: *rv10-list(at)matronics.com > *Sent: *Tuesday, April 19, 2016 10:34:22 PM > *Subject: *Re: RV10-List: Powering the EFIS system > > On 4/19/2016 10:17 PM, davidsoutpost wrote: > > All my avionics operate off a separate buss which is a blade fuse > block. My single avionics switch operates a miniature 30 amp > relay that powers the block. > > To minimize the single point failure mode, you should wire the switch > to remove power to the relay in the 'on' position, and wire the relay > so that when the relay is off it supplies power to the avionics fuses. > No matter which part fails .... the switch or the relay ..... the > avionics fuse block still gets power. > Linn > > ________________________________________________________________________________
Date: Apr 20, 2016
Thank you David Please indicate the part# and source for the miniature relay you used. And a picture of your fuse block installation would also be very welcome Cheers Carlos From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@m atronics.com] On Behalf Of davidsoutpost Sent: quarta-feira, 20 de Abril de 2016 03:18 Subject: RE: RV10-List: Powering the EFIS system All my avionics operate off a separate buss which is a blade fuse block. M y single avionics switch operates a miniature 30 amp relay that powers the block. Sent from my Verizon Wireless 4G LTE smartphone -------- Original message -------- From: Carlos Trigo <trigo(at)mail.telepac.pt> Date: 04/19/2016 6:36 PM (GMT-05:00) Subject: RV10-List: Powering the EFIS system Group I am beginning to install the EFIS G3X system from GARMIN in the RV-10, and I have to put power into (not more not less than) 12 devices (2 Display un its, 2 ADAHRS, 1 engine module, 3 autopilot servos and so on). In some devices there are 2 independent power inputs. I am trying to figure out which will be the best architecture for the power circuits to these 12 devices. I know that some of you are against the single Avionics switch, and I am le aning to agree, not including that single point of failure, but how about t he distribution system? I am not searching for opinions on the breaker or fuses discussion, just to know what other people did or recommend to do with busses and circuits. I should add that I have a dual battery /dual alternator energy system. All good suggestions welcome! Thanks Carlos Sem v=C3=ADrus. www.avast.c om --- Este e-mail foi verificado em termos de v=C3=ADrus pelo software antiv=C3 =ADrus Avast. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Apr 20, 2016
I used one of these I had laying around from another project. Its mounted b ehind the IP on the sub-panel, and is wired with 10 gauge from my main 12 v olt power stud to the fuse block. Fuse blocks I used are from Steinair. The fuse blocks are mounted also behind the IP on the sub-panel. Fuse blocks a re behind the pilot side accessible by removing the GDU 370 & GDU 375 displ ays. Sorry but I don't have a picture handy ----- Original Message ----- From: "Carlos Trigo" <trigo(at)mail.telepac.pt> Sent: Wednesday, April 20, 2016 6:26:19 AM Subject: RE: RV10-List: Powering the EFIS system Thank you David Please indicate the part# and source for the miniature relay you used.
February 02, 2016 - - - - , 20-
RV10-Archive.digest.vol-ln
