RV10-Archive.digest.vol-mi
September 12, 2016 - October 13, 2016
      The G3i ignition uses your current magneto and adapts a MSD6 or MSD6AL ignit
      ion box to it. It retains the magneto function if 12V is removed from the sy
      stem and it provides a high energy electronic ignition when 12v is available
      . Tom is a friend and provides great customer service.
      www.g3ignition.com
      The EFII by Robert Paisley can also utilized to replace a single Mag, both m
      ags, and or the entire fuel injection / ignition system can be utilized. It i
      s a modular system and can components can be added later if desired. Robert i
      s also known for his stellar customer service and support.
      www.flyefii.com
      I am using the EFII system and love it. I have 2 alternators (1 belt driven a
      nd 1 vacuum pad driven) for redundancy. During my runup, I only get a 10 rpm
       drop when I shut off one coil pack at a time. Impressive performance. His s
      ystems are used on many birds at the Reno Air Races.
      Hope this helps
      Justin
      > On Sep 3, 2016, at 20:55, Albert  wrote:
      > Has anyone received a P Mag yet? Really interested in hearing how they wor
      k. The 4 Cylinder version seems to be fine.
      > Albert Gardner
      > RV-10 N991RV
      > Yuma, AZ
      > PS: Wonder if they make an asbestos covered model for Arizona
Subject: Re: windscreen
Date: Sep 12, 2016
We think the fiberglass is a much better look. The whole cabin top is fiberg lass and the windows are all glued in, so making the fairing "permanent" fit s well. The metal fairing says "I didn't think I could get the fiberglass on e to look good" in my opinion. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Sep 12, 2016, at 8:49 PM, Bryan Wade wrote: > > Last week there were a few postings about the Cee Bailey=99s windscr een. I was also curious if anyone has used the M.L. Skunkworks windscreen fa iring and what their thoughts are? I like the looks of it personall y and it would seem to save some labor over fiber glassing. > > > http://www.mlblueskunk.com/Windscreen_Fairings.html > > ________________________________________________________________________________
Subject: Re: Headset jacks
Date: Sep 13, 2016
Here's what I did in the front seats to accommodate powered Bose jacks and regular jacks. It has worked great. Front Jacks mounted on side walls <http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project=224&category=4053&log=117561&row=5> What's not shown are the hooks mounted out of sight on the side walls near the rudder pedals. When not in use, the headsets are hung there, out of the sun and mostly out of sight. It keeps the cables out of the way for entry and exit though they do lay on the floor. Even new passengers have no trouble returning the headset to the hook even though the hook itself can't be seen. ________________________________________________________________________________
Date: Sep 13, 2016
Subject: MT Update
You may recall, that my 860-5 serial number was included on the SB31 list. I sent it in th MT-USA such that they had it when the SB was finalized. A week ago Friday they called to get payment for return shipping. I received it late this past Friday, installed it on Saturday, and Sunday did a full power static rpm check. Yesterday I took it out and flew it. Worked perfectly, both for redline and for cycling at 1700 rpm runup pripr to launch. Time will tell if MT has the right solution. -sent from the I-chip implanted in my forearm ________________________________________________________________________________
Date: Sep 13, 2016
Subject: Nose wheel fairing clearances
All, I was working on fitting the aft nose wheel fairing today and I believe that I may have an issue. According to the plans, the rearmost edge of the aft fairing is supposed to be 20 5/32" aft of the center of the axle. I trimmed and retrimmed the relief for the nose wheel strut, but I think that I may have trimmed it a bit too much. I looked online and saw a number of different fairings that only had the trimmed area in the localized to the recess area for the overlap of the forward part of the nose wheel fairing. I am looming for any wisdom or opinions as to whether this is one of those "build on" moments, or did I make an error in my fitting? I did contact Van's, but did not really get any real advice that was usable. Ed Godfrey ________________________________________________________________________________
Subject: Re: Nose wheel fairing clearances
Date: Sep 13, 2016
Build on. I couldn't get the aft wheel pant to come forward because the bulkhead was too far forward. I made a 'relief' in the bulkhead to clear the tire. My cutout for the strut comes back to the joggle. Carefully trim the nose piece and everything will be hidden by the strut cover. After I got the pant fully mounted I over-countersunk the screws for the bracket and filled over them. I also made the tow bar attachment out of 1.5" aluminum rod with a 'step' turned that fit the hole in the wheel pant ..... and sanded it down to be level with the fiberglass. Used the socket head screw to bolt the rod to the nose gear. Linn On 9/13/2016 7:22 PM, Ed Godfrey wrote: > All, > I was working on fitting the aft nose wheel fairing today and I > believe that I may have an issue. According to the plans, the rearmost > edge of the aft fairing is supposed to be 20 5/32" aft of the center > of the axle. I trimmed and retrimmed the relief for the nose wheel > strut, but I think that I may have trimmed it a bit too much. I looked > online and saw a number of different fairings that only had the > trimmed area in the localized to the recess area for the overlap of > the forward part of the nose wheel fairing. I am looming for any > wisdom or opinions as to whether this is one of those "build on" > moments, or did I make an error in my fitting? > > > I did contact Van's, but did not really get any real advice that was > usable. > > Ed Godfrey /9j/4SnpRXhpZgAASUkqAAgAAAALAA8BAgAGAAAAkgAAABABAgAgAAAAmAAAABIBAwABAAAA AQAAABoBBQABAAAAuAAAABsBBQABAAAAwAAAACgBAwABAAAAAgAAADEBAgAGAAAAyAAAADIB AgAUAAAAzgAAABMCAwABAAAAAQAAAGmHBAABAAAA4gAAACWIBAABAAAA5gQAAKgFAABBcHBs ZQBpUGhvbmUgNgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEgAAAABAAAASAAAAAEAAAA5LjMu NQAyMDE2OjA5OjEzIDE3OjIwOjM5ABYAmoIFAAEAAADwAQAAnYIFAAEAAAD4AQAAJ4gDAAEA AAAoAAAAAJAHAAQAAAAwMjIxA5ACABQAAAAAAgAABJACABQAAAAUAgAAAZEHAAQAAAABAgMA AZIKAAEAAAAoAgAAApIFAAEAAAAwAgAABJIKAAEAAAA4AgAACZIDAAEAAAAQAAAAfJIHAEgB AABAAgAAhpIHAAgBAACIAwAAAKAHAAQAAAAwMTAwAaADAAEAAAABAAAAAqADAAEAAAAgAwAA A6ADAAEAAABYAgAABaAEAAEAAACQBAAAAqQDAAEAAAAAAAAAA6QDAAEAAAAAAAAABqQDAAEA AAAAAAAAMqQFAAQAAADGBAAAAAAAAAEAAAAoAAAACwAAAAUAAAAyMDE2OjA5OjEzIDE3OjIw OjM5ADIwMTY6MDk6MTMgMTc6MjA6MzkAYwQAANMAAAAvHwAAtQ0AAAAAAAABAAAABwABAAMA LgAAAJoCAAAEAAMAIQAAAPYCAAAGAAIAIAAAADgDAAAHAAIAIAAAAFgDAAAIAAQAAQAAAAAA AAATAAMABAAAAHgDAAAZAAMAAQAAAAEAAAAAAAAAXAAAAAAAAwD/////AAAEAP////////// AAD/f/9//3//f///AgAAAP///////wAAAAAgAAAAAAD//wAAAAAAAP///////wAAAAAAAAAA /////wAA/3//f/////9CAAAAdQAAAEkAqgAAAP//AwAAAAgACAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAD///////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAEZpcm13YXJlIFZlcnNpb24gMDAuMDAAAAAAAAAAAAAAAACfAAAAdwBJSSoAQAIAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAQACAAQA AABSOTgAAgAHAAQAAAAwMTAwARADAAEAAAAgAwAAAhADAAEAAABYAgAAAAAAAFMAAAAUAAAA UwAAABQAAAALAAAABQAAAAsAAAAFAAAACAABAAIAAgAAAE4AAAACAAUAAwAAAEwFAAADAAIA AgAAAFcAAAAEAAUAAwAAAGQFAAAFAAEAAQAAAAAAAAAGAAUAAQAAAHwFAAAHAAUAAwAAAIQF AAAdAAIADAAAAJwFAAAAAAAAKQAAAAEAAAA3AAAAAQAAANAJAABkAAAAVwAAAAEAAAA3AAAA AQAAAHQRAABkAAAAJaQAAM0AAAAWAAAAAQAAABQAAAABAAAAeg8AAGQAAAAyMDE2OjA5OjEz AAAGAAMBAwABAAAABgAAABoBBQABAAAA9gUAABsBBQABAAAA/gUAACgBAwABAAAAAgAAAAEC BAABAAAABgYAAAICBAABAAAA2yMAAAAAAABIAAAAAQAAAEgAAAABAAAA/9j/2wCEAAMCAgMC AgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoMDAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYU GBIUFRQBAwQEBQQFCQUFCRQNCw0UFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBQUFBQUFBQUFBQUFP/AABEIAHgAoAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAA AAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGh CCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVm Z2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfI ycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS 8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APlPxBp+o6f8KLbVlkubrTrP V5LKBZMtDayKyuQvzHBcbSeBnB5ODjJ1fTvsWpvMv+qnwJPZugPX6DAHYk1jUTurvdHTTs07 dGc4vw38S+PvFltYeFtEvtb1M7GFvYQGQqN4Xe2BhVBZQWbAGRkivqb4Pf8ABPPxFqMzXXj3 U4tFTzCH0rSnW6vEfYWKyuMxwEgo43FgQ4+6SK9HDYV10pS0j/Wxy1qypNpbn0j4R+Cnw/8A g1dXdx4e0GyGougIuZGNzcRSMvzhmYBkX5R8qzAEkkAUzVPGCXN2tjqOogfaJ1WOK2O3cxDK A2F5B3sCO/BJ4GPRrVo0Y+zp7HDCDm+eR5DqnjjUx8RbHwc+ny6Yt1cMs1xbpkmHjbNuPDBy QOWLL8xYcAN7h4J+HekaBdLdQ2/2i+H/AC+XR8yXoRwTwuQxB2gZHWvFu5u7PRjGyPVdFhxP KPRE/m1dFbxDzIRj/loK0SGcV8cR5Pg2zPr4h0JfwbVrQH+dRfC+At4VuFRgpF03QZJ+RKxm v3kfRmkPhZevbNrdmwMqS3ydT35Jr5Y/bYs5rnwBoFjbJsvLzXba0gjzhSzxzAZ9OQKb+Fm6 7HgHhPRrfSvFOq2NoCtraTSxQAkn5A+F5PXjHJrwm6muP7VuplunhEyKZCkhQN8zdcHnqfzr w6Umm2fp2JpQnQpxmtNPyKM0uDgXzA+82P61FbQTajeQWlrcNcXU7rFFDHLueRycBQM8kk8C urnkldnhyw2GcuVKN36Fe5vGu55JptQEksjF3dpwSxJySeajEwUf8f6c/wDTcf41onJK1jiq UsM223HX0Po5bj7X+z944062gM89prMF9IVXpHLC6A9ezMR/wIV1n7Nnw/074rw+JJ9XsW1d 9N8OT3ttpkUjq13eGPEaER4cryxIQqSQoz82D3KCqTp+h8epOEZn354U8ReCPDPgeA6dpVrO 17bMZLFEEOnRrJhmi+zhVjbGSCfKBzuzgk15t8T/ANobTtEsZJ9W1W3srPdhItwijZwCQqqO WYgH5eSccDtXq1K3Inb/AIZHmQpuTuz5C+Jv7a7XFy9j4ds5JVRthurkbIwuRyiA7iCM9SuO ODXa/BXxNP4rsWvbxxLOHCeb3f8AdoxJ7DljwPSvKcnKSuelCCij2k+FLDxJ4i0vWZ0eK/09 JI0kgfZvWQYIOBkAEZGMYPQ9a9Y0W2O4+h5/lW8Y9RX6HY6dbCNmIHLIP0P/ANetmGPEtv8A 9dB/Wm0Bw3x7jI8E6fx18TeHh/5WbOoPhhJG/hMOX2/viF2e6JXPU/iR9Gb017r+Rs6pbIkU km90Yrgbe/1r5b/as1uDSpvCEVyNzWU91rJdU3IWhgMca7j0O+4U/wDAaVbSlJnVRV5o+afB eoFIdRvbliXS0SZ265Ij+Y/mtfN2s6fq2saveizWZ7e12hjGSFXKbucewY/RSegNeVhUnI+6 z+U6ODgou2qX4M0ofh5NfaPHPaa5HPeFfMkgkm8vy1wrdzk4DZOcDhsbhHKY4rDwJ4lt9Qjl 0t5764iPnWj2XmM0hRwMpgZyCQ3tx6jPc5Q2aPg4VK7acZO/qyrq3gm60eaGwedbvUnj8zyN OuEudijJYHy2cZ24YdAB15yBiXun3emXEsU0m5kx80b7lOeRyPUZNaRakTzTX2j6k8B3b3fh 34h6VaoZHutFju8L3MMqknr2XLfga9H/AOCZevif4y6totxqH2d7rw9dGxhJ2+dcI8Thd3Uf ulmPHZc84xXRTbTptf1ucUldTX9dDs/jxrnizS4pbTwzcSahfXP7+JrSD7Q9xuIdmRUBDZBL cAjGeK8E/wCGTPjX8WJTJd+GriBrhv8AkJa3dpH5QDFsbGJkVM5wFTHzccGuaq5Opq9i6Uqc INvdneeHP+CZXjW/aZvEPijSdMOBsNhFJdljjnduEWPwzXvvwu/Y7ufhjpSWknig6iN5kMi2 flZJ9jI2OABS5tn2Mfa22O+bwnLobYW580jr8pHH0rRs/E7aUuHtDMR6y7ePyNarEW6E81za tPivpalPtVtdQyDKbYgHBzjvkeldNpXxI8K300aLrMMEg+fbdkxAe25gBn6GrjXhLR6Gi1M/ 4xiHW/AmnzWcsdzA3iDQpVlhcMrBdWtGJBHB+6a4bwH4xfRPCjQ3ul33mNuukk8r5HBjGMMS AcheP94dK83MMdRwLjUrSsrO22u2192elhaMq0ZKPkcd4t/aw8NaN4WuNWW2vryw2jZdQmNk mY/MAhD/ADcc8dq+evF/inUv2ptW8IWtjYtpMWrTyWVvh1eYwPIgluGVTgLGIpGwGJxG/TGK 3nWVSPIl1S/U1px5W35NnkFlcyafomoxGPPnWrxnJwV2qwPH/Aq+m/2PfhWutfA27k1a8i/s PxDrMl5a3FrKsc9lMiPYPG7bAyGXBXcGcqsisixufNTny+KnOSe1j7DiifLhaSW7d/uTPKvj L8J/iT8LPFMDxRy6z4avpUJ1iHTIbiR5hP5rPcAI73HmIWkAMmSZAGk/dla534O29v4j106c NEOnaCtqINR1TwsjQxb4shzMqZEyyRzOoRXaTh5F2fKE7fYQhzJ3s97t/hf9ND8+hWneMobr Vadv69Tz74h/DnSPBnjJvCdhqk8NjcAk213NEuy4jBVXleR0SOOUHzFZtrBWAKfKrN5hqf8A ZFvGsCSTNJkN5YTqdvGD/EOTj+ual82nLsd+H+r8rdV+9/Wx7d8Gr9j4vttOgQk3+m3WnAbt hZmiwoJz03L/ADr2v/glj8HLnxH+0PeeKb2K6ttN8M6dcyQOMKs1xNutgp3D5lEbzk7ejKmT zg9ELuEX2ueZPSUkfpr4l8KaHo2o+bZ6bHFPIu6SYDlj9fb+tYkzRxjChc1lU1d2cGl9DJvL oRuc/hiqMl6sqYIwR2rmk9DVI53XFEiFsbiOfpXD6nsRm5I9Tk1lc0SMa5MRxnbgdKzb2CLO 7CEenvWMnd2NkZEtqVkPkTSW3KsGicodysGU8dwygg9iAe1YF14bvLvWLvU7bU7yx1e6BEuo QuGkK7dpADhk5HcqSDyMHmuLEUaVdWrRUku/na/psjroVqlJ+47GDqXgzwr4u0GHw/41vdbs ZftbTvqOnpEYHZ2UtLLEoUljySy5wBgLzgeS3nizXvhjryT+HHlSCwsxZWl5NZxyGGNlw20t H8rfO67xhsFhnDHPW4qnTpqk9Eu21rfeejTrU6s5vltd6a30/Db8Th7nxYt0kpn0ixmaVmZy XnXcW+992Udfbist/i3feHfhH4h+E1kmnx6Xrupf21cXUqM9zEx8s7FfzFVEBt4z8yscNnPT G+Ck4TfmbZniquKpRVR/C9C/4S+M3iTSrSwuofihqejatp1rFZpa2SG8t1s0yqCcIRGFRioX 5XyshztKKrV774ra1reo6za+JPG+pXumXUaQXd7p2nxXS3WVfywlvIYkVdrN82Q2QGAJAx6b 10bPBhGUfeSto/y1PM9e1p5dQ1Oa3a5eabbFFetbwW0skYXaxlWPPzMMZIfk7mYsWJrmI5pb C6F7llnRy4ZdoAOewwQPy/Cm42MuZvQ9o8CancaD46094lTz7XUYpFzgZ9AW6Yyep9q+7f8A gnN4etNB+MfjBP7eOoahHaPayWGm2N29va+dIs48+ZkWNJAYZU4yjcbXORudF2poiurykfoF rWhJqdvgMTL1HpnvXA6voVxp7sJYyo7HqMUT95HHGPK9DidYdoWbDcg8/SsJdWAODJnjgVxT VkbxK17fCaIrvJycdO9cZqMqIXJ5bB49e9cibOhIwrnOTtQRng9//wBdOg0O9vreWeGJiidZ HIVR07nvWdSSSuzSMb7HM3V2YmJ4LA4wO/8AnFS2t5tlibAJB28DtXPU2NYIwvGMSpdKSvLA qxx7/wD165R7aGTKkDBrppP3EJowNY8AaJqp3z2Me4nJki+RifcrjP415X4s/Zdsda1OS/0/ V5rWWTl4rmFJVOAAMHgjp3zXRBqD5kP2krJS1Qnw/wD2U7e93w+NPE8+mWsLD7LHpUbTttJJ kwzJhAc9uCTk9Oe28Ofsw6R4Z0j7RHdXXiuKS5aS48P2xJcxpFMIpH8l/N38nHloUUyoC7ZN b+1vGXNokXFxlUum+2vpb/gehhfDX9nbwx8RPiRY+HdX1n+ytctb5TqRsTG9jPGh33Ma7z8j ruKllBjUQt8hGGbd+If7OXgXTPirqOj6ZqE0nh2NYZIppIoFfbJGr/M2wD+MdhjOO1bUZylT cpLqYzgovRnk3xs0q3+G/wAb/FWiWMzi30fWrmximkI3ukE7qpPv8o/H8K+x/wDgnR4m1c/G /wCJJtEj/svUdLsb+edNobzUnCxp64ZHnz9B7Vrh9kmZ1dW2fpUt9KsIdf3p9Mday9VuzMjp KpKnqCaXPFPVHGoyaOB1rwpFfO8sc21du7H9K8m1Wz+y3kgjYt83VuBx61lVUbaFQTLlp4Jv NU02O5S4iCSA/K7EHqeehFcxq3hS/i1N7JY0kn278JJxjtyen868lT6HYo9Tj/E2jaloytLP avHEDy+CQCenNczdeItQaJbWS5maGPO2PzDtUfn9aWkkVqmYVxqUsTlmILE4CtyDn3rQTxvq LIYo7g2kToI3S2UQh19GC43fjmsppNG0G0UvFV6GELHksM5I+lc1JcF/uru+grSk/cRTRIkM jpjYcH8KYYJF+9tX6vXSjJoS2vWt5vlYH9auw3LTXMbsirNGwZHXgqQcgg9iPb0p3MWin4db wx4Clm1m10q00u+kSWxjaGRo0IlBi+VNwQE7lPAznHWvOp9TPjP4pXV0umTT6fp86wvHbhlJ It4YeGAIDN9mZskEdTg16lN3oOK01/Q57tzu+x9E+Mf2IPh/f+MdS13xHqet63q2p3Ul5O09 ygDzO5d22xRJ95ifbsK9I/Z2+Evg34X/ABEafQbUw3N5pslkkzSM7KgdJdpJJOMwqccdPenT 0mkbyd4s+jfB+s6/eJqsWt2lvZeTfTQ2c1pMXS5tOGhlIPKNg7GXJ+aMsOGADNYvLlWZWkZu 2C1clVNSZitGcdqtzInLtha5m9j8yQkAHPXHeuKUmjZK5Yt/EVzplqlvGFMSDADj+tYsmtyJ rUuoSR7iybAB2Ax0/KuOTVzoSMfxx4gXVtCltVQw+ZICzN6Zz/MCvFdYtY4SzBH5OOO4J9c/ WqgNo5y/IIfa4XHAU8Z7/wCNVrJnaVcncpOeD1py0Q4o0PEilxCdygBQMHqayYpY0jwWOc54 pUr8iNWhftZP3B09TnFVZrg7yzNya6UZsiXUrW2kDyuFA9xVa98X2a8w7pGxxtHB7dauKcno YSZwPxG12yvfC3mavDcvoovrO2mhtMec4aTeVBYgAmOGXByfmC54OR5br+q6JoWu2epeALfX /DevS3KeVBcXUMkO0iPEYK8sA+8EPkMoUtySK9WlFQhZ7nM9z9ZfG8vnrvkZsgY2g8EgZGRk Z/GvP77T7690nUZdLS4t5LaJme8t2eEx/IzFS6kFQ6q68HOCcBjwaqONP329EaRTlojiPDnx a+JHwT+IehXHjDxTbar4N1NxDc2ELfahCCGy0ckcZVXiA8x41bJjBO0kqa+zdZnEkAmDcj5X 5/WuH2qrrmQqsHTlZnE6ndxSgrIMHPGe9Yk88TkqpGPauGorGkCBIt/fOPxqN9PG4tkH6jNc M3qdMUc14oshFE5CZJHVu1eSeInw7fvCoK4yByPf9a0g9Ae5wt/MokYcvk9Rzj8ahgmKyAsg xkEiqk9Coo2L6Nr6GNs7cDv1rFuJYrUfOeB6ms6UrRsdDj1OfvfGunwFoo7hZJQcFVOcc96y LzVLu4jMjzBExxswRn0yf8K76MPaPVmFWLiijLqUCsrohLFsrySfrkn27eoqGPWVt5CzKiEZ APUjt0/GvTSUVZHGzm/i9rxi8F6baSKhTUdYjuVud5+X7NGwYEH1F0uDn+E5HNea6a8Or+Nd FiSZSUlW4MikMAI8uw+pC1v0Od/EfsLqUn2qDdCykOvyug9R1BrzP4u/APWviJ4LstQ0yz1y e6jumjji0qA+ZNEyeVODISAqMrspUHLYbkbcPnjL+ydlc3pSSkmfMnjfxqug3Wp/DiHwxALz TLcW0+ps1x9oheEpJL5geQp8scZLttU/KSW+9n6G/Yv/AGk7b4peErrwzdLcvfeHoooDcNbi OGe2OViKkE4K7SMEAlQpyxLEeRhabhE2xEvaa3vY9c8U3DWiuFY4HIZWxketczZ6r9oG4YCM 3GffrV1Foc8DpRaNHECJRjFY8GpyXQkaNxtU7eT7V5jelztRyvjLxObX9w5Uvt3DBB/GvJPE Gqifd8wDHjk1pBWBnE31+qvln475qi2uxQnKtuxzVOLlojSGmrCHxm2s3KQW6m6JGS0LDO1c lgD93IAPfjvV/R/A3/Ce63LbXN3JJbRqC0YYgKGAwxAxuXJHX1xxkZ56sXh4767nr4WEaz12 vY7a2+BNrpt0kEmnrG6KD8h5ceqk8H8cHqOo4PEPwo03UbZobV2s7lcbZSu5WGeQ68Z4yOuQ R+B2oVkvfQ69C/uM8K8TaTqPhy+e21K1MD7iIpi37uVR1KHHPVeOCM8gdsEyxX9wBI7owQhB HEHLMBwOo4Pc9fY17kZqceZbHzs4OEnF7lLW9W8Q2cunwaRo6ag0Vrcym6eISC1E5EbFg42D 5bR1+fIKuw4OCJ4PDN9rEf8AwmPiDW7a/wBWtV8gWtpAIlCuHBZmCqGPJPA6nkmutv3Ujl+0 fpz4E17T/iJqX2extNU8m2Z5L4zWvleVAoBLK2WVySVVQuckk/dViF/ai/aTf4JfC64v7XbE 9xG9noUAiZopcqoQltylZIiu4nJYHoPWcTNWfL/TPSwVKLpyr1emi16/1qvRn40a3rF5qjuG Z5YncvKzHmVicnn3JP4k+le3/su+Hf8AhFvH934l1i7OnJo8CXlx5biJjJMMxQABlIDKWc4D LhNjDDVwRs7RMEt2z6w0j9qfwX4nt5bK91aDTruHcALptikZ4wx4IOenUHPGOatWfjzS3Amt L6KeN/mWSFg6sPUNnkfSs59jms4vUNV+MsenQETatHAoGCZXVR+ZNef3v7R+h6ZDIsPiLTcM cnbOjnP4E1yexcuh0xnY8n8W/tQaJPO9wl7c6hN90LBCw4/4FtFeY63+0NqGrzvDpGllpHIE TTOWJJ/2F79ejf4V0xw1vi0Qc99jr/D3h3xzfR3U+qxRySOVKW8bxqkPAPBzkk555PT8K6Cz 8GeJbyVkisd7DBO2eMEDJHI3dMgj8KIVqUV7rOlUpvobnhvwd4l8MeIrTVLjSMxQy4dBKjF4 2XY+BvGDhmwM9cfSvUfB2lS+DfHNlqdmqnT7o5G9cFdxAClTj5WyRgjrx348jHVE5qSej0Pc wMHySg/U9g+LMMd5Y6RcaZM8FqonNxaeaA6k7cH72SvBII9O20ivAINR0zUvEdzby3VubqN8 CN51JJwp6Z6A8ZPTAPYV5cbq6jsepJKSvPc82/aC8WaPY6dp2m2l6l3dtdGWVIg2IQqkDLEA HcHU8Zx0OCCB5JZavBdRBGcMewGeD2//AF+tfU4NSjTSkfG4vWq2jo9O16LXbPUoo4fLc3dr aCaNeJ2LTuVSNVAUI0wU44+YY4ra+Irx2ujWJmgto9RYGFmtww8yNnLhjk7d5KYIXAwi8ZJJ 9GVSPtXTW/KvzOBRdlLzP0H8N/tefAybwxf2+n+OITJaGOWW4Nn9mPnkNt8szmMyBcHG3p8x J2vivzx/a1+Lt18Wfi1qjSMkenabLJbQW9ud0alThyvztwWGeGK8krwa5KtV1GlytdT01U/c Kiu/f/gfdr9+5y/jH4n2ep6THenwvZ61rbR2Mb+Ibq1ntf7P8hFhjghgjuGgeNY441DyRcjI 2A4NcBrS6nNq9yGnlh1B5JDenywjBy5LKQMYbJ5HOMD6DGHKrJO9jJxkld6G3pHh8sm+5m8y YkA9AfbgcV6Xovw1sfEGmRpdwrKhJ2vnDLxk4YH2z6V2R0MHdnMeIfgRcQM7abdXBtwDgXKj ryQCVPc4A+Ucn8a43UvhZr9l5CR2xnaVPnAVl2Pk/LyBnKgNnGMN7GtOdX1I5GT6f8GvEk1z EX08rGccSts5xnn2/H8q7e2+CFppyH7ZIbySVWlWKzhPloRyql5BnBz1wSAD14zjUm7e6b0o R3kdlp3g+20dUksLC2sZAfMSQKHkPy4Iyw6HnoPT3zdg0/VF/evezwFGVkVZ3yWByMhiSMDP P+Nc7hHeWrOlVHtHRG1JqXie4ctB4k1pnAJDvqE2SOuDng9euSf5V2Hwi8V3Gka1NYeIriSS yu2DLfXjmURy4AG92JOwjAyeBgHhdxrgxdGM6TUFqd2FrShVTk9DuPjb4a1h7uK6hguJ7W3t UigSOIuIZFYsWfk4yWxngHgYrg4vBesD7RLa6bPhG2sUPzRgDhMAZHBX8PQGvnUpTs0j63mj Fas8e/aP8B6lpem6Zq40q4jtY5JFuXPKw7vLCHjoCQ3J4BYA8steQaPbyEq8Od3GCOtfVYJ/ uIp7nxeYL/aJPo7fkbV5oET4vzpn2yZBtMZXO7JHP4fjVZljEUV1a6XYqmdp2oFbPoCB7ivX j761Z4z916H0lo+t6x4J1bVtC+Fng+80/QZli1CXT5NTF615HBzFLIE2YYyoNm5AD6t8xrzy 1/Zx1TW9c1K+1BV8G+HYLny4P7YhdJ5y74hjSBQGIYlRu+VBh8ElNtefVhUhUkt7HRTacU0c 14n+Bcoigu4NYtLqzMZkhYTMQ6kcMoVNoBHesvT/AAletcrLfGKQqu3zIlPOD1JI5wCB7AAd qzgnZXVrG0pX0Oz0PwLHf3CTXNrkAjbKV3AehJ/lXtnhXwXBaWi+ZC7qxIYhQwJ9eTz9PbvX TF6mT2OiTwhPbxyyxxySyYAiibCBRuIJy3Tj3H+Ofqvhp2ktg1nGbvgfJIqKG2jucAj09Md6 0egkUNX0x9Nikjji+zZcqzkK8QJHUEn+XPA9KzV0W4nijum2fMfLUg8kcHI575/WsHK7saJE UumLbKhhk5HHl8Hcccgg5B/PtVm6t4LGEv8AIkZbOChHIzkDrnsc+xoT01H6GLeLaSjfEkUi q3GV5U9cdCQeP/rU24lZbeNzGDuc4TcTx9eo/wDrmsZ2t7ptBu6TPVf+Frasfg54gtVlSDVr azjgsp7VgZJYmkWMgYGN6KR8wOcYOPlZj833Grazr0Yt5tTu7xYgdqSXLSgZxxhiR7diffAN eK6LhUkkvM+lpVoypRcnZ7FHVtKuptKvLdFkd7iJ4EQBixYpxu64H3eTt9+a5zw74CvYLhbe WJkkCBmD4GDnnbycjkDPHORjjJ9fCRlGL5lueFj6kZzXK72O8tPDD22EmRlcr+Q/nz61Yl8B 211ceaiI3mr8zBQRj19SB+Nd+q1R5GjPuTwFoem6VpEsWl6S2j2808k+Xlad59xAWRncl2yo QfMcqAqj5VFReOrawWzbzrW3ubo4ePzog2GBJBBx2ySPTJxiu+T5ldmK916Hzp4y05J76UsE Ltk8REv2I4Hf/AVzQ8DRtcq2EIDjAxnBB6eleXJX0OxHqHhfwQPssLRxq5PBb7wx7dP8mu2s fDC295bNbrHDCgYySTHc7NxhQOQQMZyAuO+/dlNoLQmTNebSFmZXKq8qNvR5HLkMBhSo7Y9v 8c4F94baaMm4mBiYYWGHLE5Jx8x69emO59KJK4o6GJd+GLSNYYLrcxEmzJk2kckjlSD9CMdK gGgWtiHSWaS9M6+WYZ2ZsNjnGS3QgkcnP6ViopM15m1YoyWttC6QAL9slTZ5cS+Xvx/dIbP8 TZHPHeuV1mLz5ts6qIgedwUNnPUdzx6+n41L1Vhxdnc5+40hkum8sCVAMlIwSce4zkVsDTrq 0tIDtLB23IyneyYPzYXIPQH8eDmpS0aLlK8kxUDASLBIZIkmMcAcklF3llUg9OxOO5NV72zu p4Z3mdVZ2yyqu7HJz+vbtjFVTu42Jm7SM6008xSlbmMAEBCCBkn+E49P656VoC1eCNYplVEO XQvjlORxzxVU01ozKbuyOeygntNsGwTL1YoGx/48cdDWRc2sYCrIysNmGwmVPB544YfnXRa5 hex9xSXMcCkyfI2OWHHIyP6Vx3im+L27uyFflyuQOf8AD/8AVXbPRWMkcE+ixXkrMq4MmFOV AcgDr/8Ar/lWvpPhKGziE8lsXlXoGjAOSfbr/WuBR1Oq5t6TcRRy7I4dgwPkHTpnpjOef5cm tV2gWeGULJbqd0gUs3cEANxk9TwenB6itUrEPUXU9PW3ZNqneTtUqxDggd+P8+5rJv7ZrlUW MebC2GU7eU7nGfp+tYyVmaR1MHxdZvqcyQhIgefMCfeOMYGcf/XGcfTidQ8DapbiKSK+aVYx uLzHd5Q3Hoc5yORk4yABjnFZNNu5S0RhCARazaRy3Iu2LbfkwFBBOG+XqwbBPPAIJwK1L7Tz PZMbgCOQDAAGSo55JHWojGzZpJ3SOck0eWwheY7JljI4A5b9MdqdDqhgwrRKsUmQCMgLzngH j0GcevfBotYnc5211b+y9aMKCMW9xJuOCvB46469O3GTnHatySe13FYppRJJICpiUtj1Xr67 cHvxSpSuuUqondSHkLcRNLJcBYbfILSofmXOB9T+HGapX92k8HlAW7gkZKZRxgcEjr0/X61r 9ow6GVeN5bCUiRlJDK5TLMOmOo5x2zn8zVeNoLoSOZHtQwyJPmJbpnPf6cVqZn29qduiWkgZ ZHY8oIuGHtn1964fWpTFZKkrStPJuBMWXYc9ckHv26cYxg10VZ2VyaceZ2RPoemO6LJeI0eF A2IxyPm53enY9f5VtrZCDbGjSIrDcCDkgfXj3xUR2NX5DZg1tbieOGH7MBjYDtLfp9TTU1qK GWElGkmHBfGAFPBIyP60ubUhamZq008flZup5pEAnecjChT22jAxjd9Md+tYWom5vRO0Q3q+ MBQzYYkHHOePmyD+FRLU0ReSOW2sxbtbG2+6h2sF3bsAnrkHA+vT8OS1/VRp6bZFaQGQuQwx uUAAjg5IHucD8c1m2ykcddaPZvLFfxqyTli0Uwl+VVyM8ZOMnv8AQelaF0J2jZmlBYr90Mcu M4ByMA+lRDVsqWyM25tZfs0qM8SCOMsXJ5cj09/mPPQ4PPXPN31lO9oJS4WMcqCcMcjqBn3p yiSmcfrtrMsqKq7fmLBsjPbHX24qUXstvbxOPMWXA2r68nOSfw4Hv0rijeMzsk1KmSrqVw8a qpkdOWIDdOg6H6fqPSqt1qUqypwW5xt25Crgj866ZytqckVfQGvbi4xl/tHIbhsEA+g7H8P5 VtQ2Fjf6mDf3zaba4yXUGZN2PlQY/DnJxya0UuZaktWP/9kAAAAAAAD/4QofaHR0cDovL25z LmFkb2JlLmNvbS94YXAvMS4wLwA8P3hwYWNrZXQgYmVnaW49J++7vycgaWQ9J1c1TTBNcENl aGlIenJlU3pOVGN6a2M5ZCc/Pjx4OnhtcG1ldGEgeG1sbnM6eD0iYWRvYmU6bnM6bWV0YS8i PjxyZGY6UkRGIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYt c3ludGF4LW5zIyI+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9IiIgeG1sbnM6eG1wPSJo dHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvIj48eG1wOlJhdGluZz4wPC94bXA6UmF0aW5n PjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4gICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAog ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg IAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAg ICAgICAgICAgICAgICAgICAgICAgICA8P3hwYWNrZXQgZW5kPSd3Jz8+/9sAhAADAgIDAgID AwMDBAMDBAUIBQUEBAUKBwcGCAwKDAwLCgsLDQ4SEA0OEQ4LCxAWEBETFBUVFQwPFxgWFBgS FBUUAQMEBAUEBQkFBQkUDQsNFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBQUFBQUFBQUFBT/wAARCAJYAyADASEAAhEBAxEB/8QBogAAAQUBAQEBAQEAAAAAAAAA AAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgj QrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdo aWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foBAAMBAQEBAQEBAQEAAAAAAAABAgMEBQYH CAkKCxEAAgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAV YnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3 eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX 2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD4l8PnZqMYDlPnyCDjnBx/IV6r pnxm8WaJJFFb6kPLjPy74UJA+uKTqyg7RZt7KM4+8YnjKU3VqlyVG538w7R6+n515N4oQw+K ro4wshVh2+8opPcmPwnd+B28/wAPAHkxyMv9f61fvYgVZSAVI5Brhl8TO1ao84Wxay1W6tQO FO5OeSvWtvQbgYltSfu/OnPY9a6p6pM54b2NOVcjGKryJWCNypNFwa5DxVAQ8UgHtW9N6mU9 jCPOR61SC5cjrg11o5DsdEvFbT4wRhk4xUevT5jhkGMI/wDOuS1pnXf3SG2P7wZ71pxA456V TILcXYVYCn0qCilrmnXjWMdxDbPMvmhQFTcCeuCPcfnz6V2vwy+AHiT4oPFbQ2LaPEJGmnub yNwp4AX5Ty3VsdvvAnmvRw1KVSySOWrJQ1Z9Z+AP2IPDHhe8jvdSln1idEBZriTbGH7nYB39 2NfQmg+FND8Oi3gtbeGGLqohQAAfQcCvpaNCFBe6tTx6lWVTfY1rfT7q+tREsflsjhw474rR HhovdPd3c23zMBs4AxjFaNmSRFLqukaXCYof9JnHCqvTOOOemM4HWsPXPiRoeiW0V1c6vBPO rsraTa/PI75+U5XJAGOc+tck6i2N4wZxF38Rtak06Gy0fTjYQeWWkuNTPPOTgKDuOM8FiPcV x93YTGSe6u77+0Lk7nPnqixllyc7QO2P0xXDOVzpiktiW28P6p4p2zTeasTAYmvSTwBgbUP+ FdHZeFNN0pYjMTdyRtuXzD8gOMZC9K5JSubonvdUjjnaRSAT1xwPyrn9R8SBcgNnNc7aLOW1 PxKNzHd+tcnqPiNmyN1ZMaRQ03TNY8VXJh02zmuX6FkHyr9WPA/GvUvB3wAhZ1l8QXJnfr9l tyVT6Fup/DH1qbFo9m0Lw9p/h+2EGn2UFnEABiJAM+5Pc+5raiA2+9UaFuJR361JfKBZN9R/ MUCRe0MD7M2R0c1qAVa2EyRVyKXaaaGTRJyKkmGYX/3T/KhiRXsVzBFx/CP5VtSjMY/CiImQ svFREZpiY1lz7Cvmn9v3Cfs/aqPUqP8Ax9aJ/CwW50PxAxH8CbTJ6waco/7+Q1iWa/IABnHc 15eK+Jeh3UPhOs+HaZ8WwAjgo2Prtr2N4AueTnGa3w3wEVfiKsxSIHvgHPf61RuZ44sA4Dc4 y2K6GZrUyrhlkO7gAn+E7jjufy4H1qZbdVDlhjbnP17/ANBUmhFNGnA298YqkY0ZT8o7n6+n 6cUFED28QJO3b83UZOP/AK9QmGEOR5aooGen3R1/Qfq1Uhla7RIMgxKu1C20AYB64/LFeXfH XVBpfw318Km55LJ4n2jOC5C/kCc/QmiT0KR8BapKAoUnqcVha3OBCE/E1zU9jN6s7SDRDovw 58NO67Zb+Wa6b3Hy7f8Ax0rRagED3ryKru2z9OyiPLhIL+tzUs1+dfrXoem4a3QEDIArOme1 I0GT9xJ2wh69q+Z9YO7Urpgcgysf1rZHNU2Oa8Qtt06YdmIH6iobXXdXeJQNSuxgAYEzdB07 13U24w0Pj8dSjVxNpK+hMdW1YnnUrs+5lY/1pjX1/Icve3DH3c0/aMw+o0+ww3F2TzdSn/gR pPtF0Bj7TL/32aOdi+p0+whurvI/0mX8XNNa7uyeLmX/AL7NNTZm8FT7CG5uuf8ASpf++jTP tN1zm5k/76o5mJ4Sn2E+0XP/AD3k/wC+jQLi5HS4kH/AqrmJ+qU+whuLkn/Xvx6muw+DST3/ AMWPB8EkrmI6taswz2Eqsf0Fc9eX7mfozpwmEh9Zp2X2l+ZzWt6nc32s390Z3/fXDydfViap G4uf+e7/AJ1vGVopHNVw8JTk7bsb9quQR+/f86PtNyR/rn/Oq5jH6rBdA+03AHMzUv2y45Pn t+dPmE8PDsKLy6Gf3zUC/uwOLhvyFHMS8NDsOF/d/wDPw35Cl/tK8X/lucfQf4UcxLw0Ox21 sVtdZ2twElHT/ero5VBuAQKqpujx6ezN7WoGn8OLJ2EYI/DivLPG8e3UrKcc+ZbIePUEitHu jNbM6b4b3G+0vYifuurY+oI/pXQSRMXOeQa4ZL32dkdUcl4tszbSQ6iikmFgsm3rtP8AhVKU GwuYbkfNG3zqw7g9RXVH3oHNLSZvI6zxh0OVYZBqGVMcfpXOblWZeDXOeJoBJag9Sp6VrDci Wxykkewg+ozWey7bg/XNdyOM2bCYQqcnsD+mf61dvf8ASbFgP4hxj1rCS965tF+6QadJ5kKH OWXg1vxIdoz3pNAjrPBfgDXPHGoraaPp0142QHdRhI89CznhfxNfTHgv9iuDbFca/qb3DDBe 3sQUi+nmMNx/BR9e9elhME63vz0X5nNWxHstFufQvgz4O6F4Z0saTaacsVmz+Z+73Z39NzEn LHHrmtvRPgylhOZrW7nsmYgswbBYj3PJr6NU4wSUVax5DqSlqztNO+GKvcBru7uZw5y/mOQD +FbsuhaNoNnJMi4hjAZzIeAM4z70OViN2cbrXxc0y0SO2spoRI3G6M79p9CFBx+NcDfeLtV1 /WrrT0EiOkYxNNL5cYJAPGASe/p2rinU5tEdEYW1Y3UtOZdOgi1LWxKkTM/2ayXywc8BWIyz HkdSBweOTVXTNGtdNhW1sLFUlcL5ICgM+eR7k9sdzWD03NEbjfD9r6MDU7oWuOHXh3POT7Cs TxNb6R4JvLe7t4fMsOEuLmdtxV2I2k9sbjjPbIriqT00N4IS68TRumUYbSM8VzWoeJ0GcNx7 1yORskcvqPirII349q5fUPEbuSATzWVx2F0bw3rni+UfYbZjCTg3Enyxj/gXf6DJr0rw18DL G2KTaxcG/l6+THlIx9T1P6fSkWkenaVp1tYWscNtBHbxIMLHEoVR+ArTtUxL0/GqRRpxrkDm rcY4GaYy1GOlPvkzYyn2/rQ0HUu6GP3EmP75rV2/jVLYXUmQYFOC0ASxinyr+6f12mgCpYZF tF2+UfyrccfugOvAqkJkOzFQkYpiEIBr5j/4KCn/AIsBqI6ZZP8A0bGP60p/CwW51PxKhz8E bEqCU/4l55OePNirAi+RUye+BXlYr416HbQ+E674akjxRb7iMgOM/wDATXr95NjcME/pXRhv 4ZNX4jMfdubv0/Tr/QVDJbuxUM2D0IB/z9PwroZKGPYhSpYkgHIBNQ3ErAFQQuMZ/D/OaQzO mcski7wBjk5yQO5/z602OMksSNp5yPTufyH6mixRDOQo54596piXd0xnjA/UfrkfWmirFXUJ N+4IRu5xkEn1/mTXj/xpsGufhd4ym3MvkQRNluD99AB/3z1/3vaiSumUnZHwLql1uukQHIXk 1n2+nv4g1qz0+Lh7uZIQR2BPJ/AZP4Vy35YkJXkke5fG2zTS4/DNlGoSOGCTCAcAfIB/6DXB 2GWBJrxWfqeWq2Gh/XU2tPjBmRT3Nd7awlG2jnFOB6ki9cyCGzlZiNoQ5r5huW3yOT3JNa3O epsYHiT/AI8lBzzIB/Oq9hGNij9a64/AfLVdcU/RGisVBjHesztsMMAJ4pjwVSZm4XI2hphi I+lUmYuI1ozTRH3ouZuIFBTfLB7UyHENgFd18Fo1g8b/ANoNwumafe3/AKcx20hX/wAe21hi H+6l6HXg4/7RB9n+RwbR55ppTNdKPPlHUDHSBPbNFyXEQx9KDGCc07kuIqx/hQqYouTYDHTC ue1NCaO41oC08QXAY7RvYjjHuK9v+HXgnQ9W8MXet6zJcTRW0TSOsDDccdgK9GnCM1eXY+Mn OUPhLvxA0fR7bSNOn8P+b/Zt5YCbbOfnVw7hwfptr598aR+bpukzdx5kZP4gj+RrKokpKw6b bTuXPhnNv1G5hOPmiDfkf/r1306YP071wVNJnoU/hMq/tY7qGSJ1yrqVIPpXHWtk8mn3drIz Gexbgeqev5fyroo6poyqqzTL+hXAktmgP34j09jV6UcdKxe5a2Kcynr1FYutQ77ST1HNaRE9 TkLlT5KHHINZtzHtlV+x612ROKRppZyrLcK64KHle6joMj6AVcsIS6EAZqZlwPRvhf8As5+O /iAgvNI0j/iWSyFEvbiRUjyDg8H5mA6cA19g/Dz9hfR9OeG68Q3cmsThVLW6kxwBsc8A7mGc 9SPpXtYXA81p1duxw1sTye7Hc+l/DHwtsdGs4bSxsY7eGFQqRpGFVO3CgYH5V2Vr4PtISDOx +bqo7dj/AI17jslZHktuTuzLvvFmiaDdNpzL598PvQ6fG1zKB/tBR8p6fexVb/hIddnzJYeG Jo2kLLG+oTqnQdWAyQDn36GudzvsaKPcgWw+IWo2DQXutaZYMHDA2lqXYqP4ckjqOenYViX3 gJppmn8Ra5e377cygzeXGoz0CrjjB7+9YNN7s1VuhlfYtBs5HttM05Xtmb59zLGgAPy4J6du cd6wn8VQ3WqwGPw7GkphAhkEu8MifKAVI+Ujb0Ncs5qJvGLkRzx6tqqssqx6bCZPNbADuxBy OOQP1q5bMmkyrdRyM97GpCzzMXccdieg9hxXBOo5M6IpLQs2+rPqtuJirIc7JMkfM46tx69f xqvqum2+tabdWF3GJba4jMUiHupGDWN7opHy/qHiu/8Ah5rl54d1eRme0OIblv8AltEfuN+W M++fSqd98RYpc4fH41yN2NbHJa78ULOwzuk82XH+qj5P0Ndd+zz4q07x14vvLHWLKIymETWS uxKkqfnBHRjggj/dNCZSR9YWUKRRJGiqiAYCqMAVoomRWhSJbVcqAOOatwqBIufWmgNGJSKt xLxTEWo1FS3i7rGb/cNMEWdCGYJR6SH+QrWPQUJaASoKfjmmBIg70+YfuW+lAFSx5tYCf7g/ lW84/cL9BQhMhxxz1qFwM1aJGFcgcZ78ivl7/goVlfgNejqWeMf+R4amfwsa3O5+KEBt/grY xMArg6chUdAfNi/wrl4kBLcfd5Jry8X8a9DtofCdT8PmH/CS2p6r8wz/AMBNeuyReYSTyfcA 1vhvgJq7jHhCksD2GOOnp+Wc1C6qvzjIAHAB7D/OfxrpZmindXQUoM+p559//rVScEKQOGJI z/n64pGhG8JSPcWZiegboPwqJlEZkIGcAgZ745/XJJoAy7xldgmQq85JPQY6n+f4VTMm0jgj KjIIxt4yf6H8aRoiCVzsYAEvu65bFcN8ZbKFPg/4ujnJVLiOMnbnOPNQ9fqKtr3WJn5o6xPG urXIgYtCrlUz6Cu//Z30D+3viAbpkzFYRF+R0duB+gavPrO1Nl0VeaO8/aJOPEWlIOiWpH0O 4157pmNn41472P1PAK2Gh6HQaNH5t3Cvqwr0VIgrE4q4bHoS6FLxC/laFfN93ETHIr5wmX5q sxqdDnfEy/uYFx1fPH0/+vRYQZTODj3rrXwI+YqK+Kl8i+qYHvTvL6VkdyQgQUx0wadxNEZj xUbR89M1VzJob5We1IYuop3IcRvlY7fpSGH8qdyXHQaYsV2vgAGy8PeOb4feXRxbL9ZbmFD/ AOO76wrP3Lea/NHThY2q38n+TOJaPNIY8Hit7nE4iGPr60nl8c1VyHAQpxgDke1KIwO3NBHI Bj6mgx0yXETZR5WSeKaZPLc77xXbhPEiOej7Tn9K+lf2XrSz13TZ9Kv0WS1lfyZI36FWUjH8 q9jDa2TPgK7tc6T9or4eWfgXSPC1lp0QWAx3KSbST/ErLknk/eNfHfi2A/8ACPzKetvefoQR WVdKMrIdB80Sh8OpzH4jiXP30Zf0z/SvUpl4P615tb4z0aXwmfMuTXPXyLpus2t8RiGQ/Z5/ TB6E/Q1dF2khVFdGVdwnw/rhTkRZ+mUbp+XT8K2mweRiqqK0iIO6K8q5FZmoReZBIuOCDSRb OPnhHlOD2zVaKye6QRiNnbPyhVyT7V3Q1OOWh718Ov2O/iJ8RtYfUI9N/sbSLlzKL3VAYiVY 5yqcueD6Ae9fY3wm/YI8H+EpIbvVI5PEd+uGzdjbbhuMkRjryOjEjmvoMPgVH36y+R5tXFNe 7T+8+odD+G1pp9rHDHBFawooVIolCqq9MADoKi8S+JfC3gHyo9Tu4FnkzsiRt8r/AO7GBluf QV3yqJbHnpORztx478V+JIo4/DfhFtOhd+NR1c+VkY6iFct6nnFWbPwBc30sp8V+I7vU7rB/ 0Syb7PARkH7qHdgj1OOnFc75nubKy2Nuxi03QoI4NE0yGwtxld6RALnnnjuaS58Qpp0JWZxM 6jO3AGGPT9OKLhY4nW/iFPL9pjtpCrIQreWg+XLbRknpycZrldWnvdXt7pLcNNDdA7pLokhB uyAo4zjGc8dRXJUqnRCBVgsniR1llKowCmKFiFwDnv7gGn3E8KS+YAoc8FgOTXmyldnSjNu9 ZC5+bGK5/UteCA/MDWDZaKPhnxqlrr0dvdyhLS6IidjwI2/gb8CcH2Jr0eVTESGBDKcEelKL uhnk3xd+FMfxE1fT72WaO3gtIXWQxr+/k5BCg9MdevTJ65xXzVrd0nwv8W3V++jW+qBZDtsb nJjQZzuHXkHHJz/WuaorO5vDXQ851S/fxz4plubewtdNe8kULbW3yRITgdSeMnkk8cmvTPhr 4U1Dwv4otb6N0W5srj5Xifcj4ODg9CpGRnuDUxNHofcWlXceo2UFxF/q5FDDPUZHQ1rRJXQS S2ick+hIxV2NMtn3poGaESVZRcYpklmFcmpbpc2M4HHyGnYCxoA+Sb/e/oK1yoHahEskTpTu lAySMU+TJRvoaAKtgM2sP+4K35P9Sv0FNAyHFQOOT6VSJGlea+Xf+ChQ3fAy4TuZYh/5MQ0p /Cxrc7/4xxvD8L7KNm3/AOlWKsemSJU/wrzfxLZ63dacq6Fc21neechMl0m9PL3DeMepGf8A 61eVi/jXod1D4T0X4bIsniW3DMMrvPpj5TivYJAApJG3vz2rfDfATW+IrPJkEAf5/wDriqU5 aQ7Rng9cA5/OukyRVNsd4yD8uQCcevH+J+gqRYlhKgDPAxn6f5JoNLlKaVVB3EeuM9Of8/nV B2YqxBI57/59cikMqSQM7HnKYHBbg9+cDpVdoD5vynPT73fvz9Tlj9BTSKuMnjSCycgn7oYM eTj1/HrXlX7SmoNYfAjWLtW24jjUf7R85Af1watr3WSfmVNN+8Y5yTzmvqn9lnwz/Z/hGfU3 XEt7IZOf7g4H8s/jXkYpvksdWHV53MP45yi81gS9fLKpn8DXBaUMr7V5rP1HA/7tD0Oo8Opn UIv97NehxnLYHarhsdstzH8byi38LagfWJl/MEV87nnt09aoynsjB8SJvmtUAJ5Y8D6VZsbd 9owjEf7tdH2UfNy/3mb9PyNAafIwJWJj9B0pTYTj/ljJ/wB8niszt0Eawmzxby5/3DUbafcq M/Z5cf7hoE7DDp1y3S3lP0Q/4Uf2XcnOLeXP+4aohtIQ6VcjrbygZ7oaT+yLsgFbWYg9xGaZ DaGHSLsHm2l/FDTX0q7B/wCPWYf8ANMkT+yLsni1lP8AwA12mg6Rd23wt8WyG2kV57ywtlyh yV/fOw/NE/Ssarul6r8zow9lJvyf5M4ptIvB8ptZQfdDTH0u7jA3W8gB7lTW5xi/2RdkbhbS kAZJCnGKaNLuXPywSHHXCk0XJsO/se7yT9mlx/uGmf2TdFtvkSbuuCuDVJiaQ4aLeODttZTj qAh4pf7Dv/8An0m/74NFzNtCDRL8/wDLnOe3EZo/sO//AOfK4/CM1SZF13O38cxj7VayjPQj OK9o/Zh1VbDxHIzylIYmjlYdVIDf/Xr18J0Pz2vuz6V/am0yPUPBGm6iiEyW1ztD9tjo2QR9 QvNfn54ott1t4giHTiUZ9jk08V8ZnhtjjfCdx9m8RWD5IzKFz9eP617K2COma8uv8SPTpbFS 4iPJAyKy9UsBfWctuwwHUgH0PY1nF2NGroxr+I6v4ejuZAfttkTDcDuQOM/yP50ml3Bns1DH c8fynP6fpXbUV7M5aemhaeLIrc8K/CvxT8QLhYNB0W6v93HnKu2JfrI2FH50UKM60uSCuaTn GnHmke6/Df8A4Jy63rknm+KtXjsIi2TaacPNlxnHLn5V/I19c/C39jzwR8LxHNpmh20d4oA+ 3XeZ5z2zubO3n+7ivraGGp4RJy1kfP1sQ6rtHY9I1XW/B/giIPqup20Eh6I7ZZs+i96zD8TN R1i0R/CXhK8vY5CEF9qg+yWwJHUBhvYcE8L+NXKpKRzKHVlWTwJ458VXUy+JfFDaZEoP/Ev0 GPyU7EDzWyxBB9q6jQfhtoHhWSK706zCTvEIrmaZjLJMwJ+ZmbLHI9+1Zrowb0sjUlubexiw hREDbQT69MVxuo61pmnSyzXD/aGb7oPYZztHtVyZUUcfqfjye9Z7K2QyqGEiLGOAM5A49CMV h3tjquqRxm5u1tSsxkYIc7l9OnbPt/hxVKmmh0wgKljp1gGMcW+Z+XmkOWYj1qG61cKMA8Vw yl3Ogxb7Vxyd2K56/wBcC/xVg2Ujmr/XWY4B4rnL/WHLBV3Sux4RBkmsJMtK42y8N32qSBrk i2jP8Oct+XSvaNHv2udFt9zs81siwylzksBwrn1yBgn1HvShoaNWVxYpppr2WN4NsAQFZcjk +mK8Q+OvgOO4P9oCHzE/jAHUd6Jq8Rx0aPmuy01NK14QrygkK7vVc8H+VfSng3won9h2WoR3 UEkk5KC2By6Yz1P4dKwp6m8tD3XwpAbWwSAklANyE/qPz5/Gupt16V1maJIRh3H+0avRJlgP cU0DL6pzVhF5p2JLMQqS4XNpN/uH+VA0T+HuUn+o/lWwQD1oWwnuOFPAoAlQcU5uVI7YpB1K unjFpD/uit5+YV/CmgZERioHFWiRuMV8u/8ABQbn4LketxCB/wCBEFKp8DHHc7742l4fhzZg kY+3WfXsN4NchaN9ojBAAQjJFeRi/wCIvQ76HwnVfDobfEtqW6vvHA6fKa9glHrgZ71vhv4Z NX4imELMDkYB4H06Z/UmnKERchQPQnr/AJ7/AI11GRTupwrgYGCfX/PvVaS4CoSMMQQMn/Pc fyoKMudzL02nnPJHJ7Djt3PsKdbQF0DZJJ6ZOCQeQfx5Y+1BRXnnCggMcdMjPr/9cVVlukGW xkjBHPQ57/jxVIZk3t350TqcBCpwhbse2MfhXin7X939k+Auq24lO/dbxtxgE+erfmcE/QCq lswPzltbeXUb6CzhBM08ixKOvJOK+9vCGmx+GfA1tDGuxYoQo46ADH9K8TFPVI7sKt2eIePp P7Rt72UHlZM/kcVx+jfvA3Yjp7157P0/BK1CHojsPDKj7dGSOgzXbIdsm7nHetIbHXLVnO/E 66CeELkA4YlRx/vD/GvBic4/pVGVTSxg6vrNzpmsWiWqh5ZYyu0gY5Pv9Kvw+Pta08FVhj9x 5g/wrtVNOK1Piqtaca9TlhdJ238hsPxF1y3J8tUQnuXz/Sif4j6/PGVkKN35kP8AhQqUe4/r VZvm9mvvIv8AhYniEDAmKr6CZh/Soz498Qt1mz/vSsafs49xPFVv5F94h8da9j/WID6+Y1Kf H3iLA23Cr7LI1V7OPczeJrPeKH/8LE8QCLY32eQ4xvZ3LGqreNddyxDxoG/hWRwKfJBmKxFe PRETeL9eZs/aAD/11eoj4q1wnJnUn18xqPZx7jeKxP8AKhD4p1vktMpJ5/1jV21/4p1TTvgv pJa5RLrUNcuZCC5GY4YYlXnP96V6wq0oc0F3f6M6qGLrqFWUktI/ql+pwTeLNZmzidHx6SHj 9abJ4k1iQDcyNjplz/jXT7KB56x2I3jFDB4h1UcZQAejGnL4j1ZSCsiDHozUeygH1zE9kO/4 SbWD1mX/AL6am/2/qp58yPJ6/M1P2cBfW8R2Q+PxNrMa7VuFUf7LsKU+JdYLbjcgE9w7f40e zgZ/WKz10HjxTrZBH2sY/wB9v8ad/wAJZri5xeEDpxI4/rRyQF7eq97HqPjkfu7Y4A5P9K9I /ZzutviYAoHWS35z9B/hXfhOh8vX6n2P8ZMa58GrwhPL8mOKcEHOQNp6fTNfn74jtlbVLyHb gXNsygY74P8AhWmLWtzLDHkdlKYLuCToVcGvdlOUUg5yM15dfoenSEbB681DgMCK5joMaSAW GvqWGbPUV8iVe2/GFP49K7v4OfsyeMviJq1xLZ2SWHh6Ftk2sag3lwY3AAoOsh+YcKDjuRXs YejLExUUefVqRoNuR9qfBr9kz4UeH9d1PTdaml8T67Y7Vc3EaiFuAS0MecHaeDu3H8K9WXx5 4R8GxXUVro08yWcjQ7PLRRw23gAfjX0NOPsI+zpqy79WeNUnKu+aRLF8QvHPizyx4a8IJplp OSkd9qJEUZ75GeT68A1owfCDxX4qnvY/E/jS68yMFRYaSptomOAQC/3iCPTFZOajuRZLY6Pw 38KPDHhCeyv9J0e3ErKEmmmXzZd4OQd75bkH17V0Yso4Y54NuIi4kj55HUrz9DihSv8A15kN 3KGr6tBZRrcuwBzsY55OBhf5Y/KuK174iwWgkSI4Y9AfU9P610K0UKMbs4C88UX2rysLSMlc 5MjDAPWqH9lKzPJezmbcSfLXhR7VxzqO9jrjBIe1/FaIUgRY19hWbd6qTklq43I3RiXurBQT nI+tYV/roTOCB7Vg5DOcv9cZzgVzmoa2ked75bsAeawlIuKuZ1nenV1EgOyIngDrW9p1tHCQ UUA9z3P41mnc6VGx0NqnA4xW9o1wLK6VnG6FwUkUd1P+QfwFaIGro19UFxY2snkKZXUjBQbi VJHzAd+OarX+jjXNCMNypZ3Un5hg9T27VTRkfFvxT0JvCXi23VgEWWUxh+3ByPxxmvc/g1fS wxwgwedG78MOdoxkn354/H0FctPSTOmWsUe8afdS3f2uZ4pIbSBoYbcyKB50rMRJgDkgLj9T 0Ga6GIECuwyRLbj964/2s1oQryMD0pobLqLirEadPSqILUS81LNHut5R/sH+VJjQvhocXH/A f5VtscjHSkhPcFPSpAMmgLkqjjinkfKaBlPTx/okP+6K33H7lfwoQmQkVEy1aEN2+lfLv7f6 7vhNbp133tuMH/r5gpVPgY1ueifHhM+BtPXudStc/mT/AEridPAZ1QHacDJryMX/ABD0KHwH ZeC0VPE9mo5Khjn/AICa9KuJfMHC4GM8gf410Yb4CKnxEUON/OcY6ce2aZdXBQYGWdh2GT15 /p+FdJnbUyrlmaXDcHnOffgfrk/QVGWBGcYXdwGx36dfbnHvSLG7VcMMAr3GVxj04FMuJCwK 5BBBBx/Fzk/mOPoKoDIunLAHudwwxHzeg/r9BVJuJMZLbu5OOMdT9QC3sMetNFIbDF58iu+4 pjgZavnf9um7Nt8IIlyF+06lEjL6/K7H9UFVLZgfF/wS0c638RLQlNyWqmU+mT8o/mfyr7H8 c3qaN4aSIOoYR9vpXz+Jd6h6OFVoXPB5ZP7Q0O6fqX3n9a5fRTtk9K5H1P07B/wY+i/I7zwu vmXRJ6KOuK68gNWsdjoe5xHxYl8rw4qnGHkAx+v9K8axjmjqZVOhzet6nYWct8XVTqQjiFtI QT5fzEufTpgc+tcrPr97IW/ehl7HYP8ACvWo07xXMfnGYYx060o0X1d/W/8AlYhOs3n/AD0H /fIo/tm7/wCeg+m0Vv7OJ5H12v3A6zeEf60f98ik/ti7/wCeg/75FL2cewfXa3cP7Yu8cy5/ AUn9q3X/AD0/QU+SIvrlbuH9rXWf9Z+gpRq10R/rfw2j/CnyR7E/W63cBqt0TxIP++RSjVrk fxA/gKXIh/Wqu9xTq8xHYH3rtvH90YvAPw8tXYNJJY3V66kDgvdyxj/x2Fa56kUqlO3d/kz0 KGIlOhW5uy/9KicGl3JFwm1c9wo5p3264/vn8VFdNkzzVWnFWTJFlvZPuK5H+ymf6Uspvolz IssYHdo8f0pcqF9YqdyFb6fP3z+lL9tmzw5p8qGsRPuOW7c9XP5077W398/nS5TVVu7HLeHp uOaf9qPGSanlNVVR7j44Um3hYDgEjPof8iu1/ZxvmTxXCuA3y7Rg+rDt+NdGF+yeNWW59zXc Lav8O9RsZkU+ZZSxptOcEKQM57//AFq+A/FwVdYs5RgbgRwfWujFnPhtzxG8h+y3s8f/ADzl ZfyNez6NcCfSbOTPJhXP1xzXk1tkepS3ZaL5pFTLDHeuZHSfaf7Jf7E2mePtKtPGHxBhEumS bbjTtFYkecAcrNN32HghR94EE/KQG9OPiz7B8Sda8CXVlZWl7ppUQQwr5aSW5/1bIo4Xgg7R wD0AHFfU4F+x/dvc+exUvayutkN1axt4tY8+1sryDWLRhIJrZvnk9sY9K9A+FnhjWtc8ZW3i nV7OKwsDbfZTEFG+VwDsdgBgHBPP0r0Kz5YtnJE9nXTQmmSadECv2V827NzwOVH5Hb+FJqE0 dp5d+8vAUBiOMgcg/lmvJi3J27/qORy+reJ4bNX2PGiBi478duK898Q/FFbaMJbnc33PUgf/ AK69OMVBakJXOLv9V1TWldZD5EDnIL9QM54H1ql9itoj5kzG4lxyznj8qwqVNdDqhGyGXOqh VwpCgdAOBWRd6qcE7sVxORtYxrvWcZ55rDv9eOD834Vg2M5++1p2JweK4Xxl8StG8JQ+Zqeo RwuRlYQdzt9FHNYuRaVzyvU/jnca023Sofs0DDKyy8ufw6D9aPCPiWQ6de3d/cSTGKQszkFi BgdhXJzXZ2Rgoo9B8A6tBrGkrNbuHj3sMkYOMnFd3Z9q2iDN+zJ2rnrWtAARWyRJ0Oj3Antm hc/PCMrnuncfgf0PtUoe4/tIJ5a/ZPLz5med3PGPy/X05oxaszyr4kfBbS/FurNJMsr/AGy4 SR/mz5bDC7kGOMDJNbXw4+HOoeEIWtp57eeJSQkqgklfp/8AXrJU/euaqWlmep28QZlZyXdR hSf4R6AdB+FacKce1b2ESQrmd+emP5VoQLlqaBl5FzVqNaogsxrk1ZKfuZe+VP8AKkxog8MA sZh22of0NbbKRQtge4KKlUc0gJEBqTHByO1AFPT+bSH/AHRW8/8AqV+goQ2RdaicfhVIkbXy 9+3x83wz0tezalar/wCTMNKp8DGtz0X49nHg/S/U6pAOfo/+FcNp5Jcv/eHBxXk4v+Kehh17 h23giMPrsLfebY+R/wABNejC2chicDPGcDn863w38Mip8QNEykBcA8H8+n9apyWbysckEY6E Z4xXSZkTacwBOACedv8AP88Y+lQtYSL1YZ5y3r6/mcfhTKuI1qxUjcACeOen+eapy2jhSBgc gfTv/L+dNAUJLHZxhPUhcc9sdKoTW+JCMhhgk/7XfH44x9BVpFXJfsm54Yy4beQCTnJz1Pt6 18n/APBQe5+z/DrQrcNu/wCJopY9ORDJj8wac/hYHiH7KnhwEyajIPmuZTgn+4vH891ej/Gz XRFayxhug4+mK+aqPmqNnr0Vamjzbw0wm0FATncmT+Nc7bZhuCo4wcVzPdn6ZhVanFeSPQvB gDPIT17V14iz0Nbw+E1l8R538Y5NmnWkeeGk3Y/A15DIwQZ60dTKqec+JmEmsXB64IH6VkEA Aivcp/Cj8dxjviKj83+YgGeKcEGas5RCoFOS3klA2Ru30GaAJP7OusZFtNj/AHDUb20kX30Z P95SKNAI8c47UA8UC2AVLHA8nGMY7nsKCrk6xRRBSR5pPfov5d67v4s3zWWqaDYQpsFpoOnr yvIMkCzMP++pTXNPWrD5/oehR0wtV+cV+b/Q4catdpyWBHo0an+lSrrcuAGUoPWFyv6dK6Gc BZt7O51SF5IruVI14LXLlUB9N2cfhVKRr3TZdrySIeuNxKn+hpXERXPlzbZlQRsx+dR0B9qg A4x3NUhCUq0xokCFMZ7jNOBqTaLPojxPEtxpM3qg3DH1/wAKm+CuprpXiuzkc4UybCemAaeE e3qc2IW5+hPhS+F7YhdgCBj144IGa+CfiTZ/2dqbJgj7PctGeOm04/pXbi1ojjw7tI8Y8SQ+ Vrl6uMAvu49wD/Wu/wDBtyZvD1tk5KblI/E15VRXgj06fxM2xJk4r0r9nv4dD4p/FfQtClUt YtIbi8xx+4jBdxntuxtB9WFZ0I89WMX3NakuSDZ+p0FwfD99amyISGBUWOEAKhix9wDp04H0 r4k/aS1u9b9pH7dbAQ6pFYW4Bt9w8wDJGM852lV+q19JX0tUW+h8/S1dmfTP7P8Ar8XxL0m1 1YNGb2z/AHV2QBk91Y/XBGa9/WSxsLNIYmRYDyuwghD1FLETdVpRMl7rdzntf8d2WngESorK ACc85/yTXl+vfFCS4Z7azVmHQbRnAralTVNXluK3Mzi7uW/1JzJdz/Z0z90HLEVVRrWxyY1B fu7cmsqlS7OmMbIpXOrbs5asq61Qd26Vyykaox7zWQARmsO+1zGTvzWDYzBvdZJzg8eprzbx r8a/DPhASreakk94n/LpbHzJM+hA4H4kVi3cqKueAeM/2lNe8QmSDSlXR7Q8BlO6Yj/e6D8B +NeT3V9PfTvPcTPPM5y0kjFmP1JqDpirHU+FrrFsgz9wkHPpXeaJcsunarGGwDHkj14INYJe 8zd7HonwPlSKHVbSNg0UUiOh9Ay9P0NeyWZAxxg1pB3VxS0N60bIGa2Lfk9a6UZF22la3uI5 E6qwP19qt+ZcSO7edhS2VXuBnpTSuSy/FEFYkDk9SeSavQr7VSQi9AvIrQiHFUBNEuJmHsK0 Ldct+FCQMvRrnFWY1qrCLcKc1aUZRge4pMZU8MDLSj/pmn9a3ZB8tSthPcanWpkU0ASqMdqc RgGkUinp4BtYf92t0j9wv0FNCZHUbiqQiMjPNfLn7ebY8BaCh43avaD/AMmYaVT4WNbnovx9 IHhHSONwbVIsd/8AlnKa4fSlLQoQDyvXtXjYv+L8j0aH8M7PwCD/AMJLbjcV4YY9flNen3Df I4A5Brpw3wEVPiIkBckkE5PPqfX+gqdkCbjgE46jp/n/AArqMilLPiRsnAA5/wA/561FJllA 9P8AP/1qBkTJnIHIPGBgZ9vx4FNCYjZid2OpHfJ/qePoKtDMa9lVBJ82O5x6dyPpWcMvNn7v HOD0/wD1HH4NWiBErYaYDtnnn9OlfGX/AAUNvBceGfDNqvzXM+os6qB1+RgfzLAfQCpqO0Sl qY3wU02LQtAij7QwhM+4HJrgPjPryzzyJv8AlOWPrgV8zD3pHtfDAqeEJN2lxqf+eY+nSsm7 HlahIuMDdxXN1Z+nUFZJeR3/AIJIKMehJFdivPIrphsOfxHlnxnlBuNPjznCuT+n+NeVTL+N LqY1TzPXZN+r3ntIR+XFUcEjcASPUDivdj8KR+MYh3rTfm/zAH0/Wpo4nlwF5/3ck1RijotF 8KyanNHBZyOl3IcKJ7dguf8AeAIA967Gy+H2nyLHHd3msJG6bv7WgEb2q8E5KbtwXjucn07V k5FWM3UPhtqVldpFGLi8tZhut9QtbhWinX1XJH4jqO9UL/wdq9lKqWuofbGPVEctg+ndSfoc fWlzpOxSjdFV/DF267NR05oGJwJYyiyD3255H4Vi6n4autMnCuGdD911Q4b/AAPtTU0xOLLu i+BPEGvThLDSby49XjgYqB3JbHFat58LfFVlGwGh3bxqeTGnmk+5CZp86uKzOebTJIZTG6TG 4BwYyhGD6EV2fxjOPibrsLWgZbSZbINK5XiFFiHOR2T0rCTvWj6P80ejT0wdS/8ANH8pHMwW lnLbvJhEcdFjkZv5jH61Z0rSrS9nKBpWlHOEiLIB6lh2961bfQ4krkl3aJB+9muTfCM4WG3f 92B/P8vzrHXV7hbovtRxniNk6fTHI/OnF3BqzLuo3UerQwQmBLO4ZuT2Y9s9/wA6zLvRrmyD NIm6NTtLpyoPofQ+xq0KxU8nd0zSiBi6qOSTiqTE421J9RAiujGp3bOM4xUCHmhjh2PpO8jE 1pJH2ZSP0rlPC9ybLU93KmORWOD0wef51jhnZk11sfod8KtXbUNCt24dHiRufXjvXyX8erH7 J4o1+EZO2+kkAPozbv616uJ+FHm0fiPA/Fyf8TZXxjzIVb+Yrf8AAdyTpk0WT8kmc/Uf/Wry J/AerD4zpw+O9fSP7FerwaV4w1KWWMSef5NoGDbSAwkkxn6wqf8AgNaYL+On6/kLEfw2ff1r M2pWFqz/AMA2Fl68cdPwr4s/bMuv7F+NeiXkJbcukQmRxkbv38x6/gPyr3cRpBPzPHpaSPQv h14guPB83/CY+EJYjpt7Ep1LSA2FXPVk+hzx2z6V643xRstd022m06SdriXJmhUcJ9T04wPe tozjBGcouWphXUhuXaS5lJU/wBs/maqPqCQcQqEX271zTlzGsY2M261Uk/e3VjXWqjJBPPeu aUjVGRd6zgn5gKw7zXMA4asZMDDvtbAVmdxGoHJY4ry/xb8cdC0LfHbSf2pdD+C3OUB936fl muaUrGkYczPCPG/xk8Q+KWeL7SbCyP8AywtSVyPdup/l7V4/Ox85yTkljSg7nQ4qOiFjGR9K fVFI2fD82yR0JwCM16H4TuBIt0h5LQkVilaRpfQ9A+C9wG1rUFBOHt4mxjHILV7jZPnBPNFN 6BI6GyYkAmtq2966kYlxeHq8hwhGK0iJmpEvSrsa4IxVkl63HWtCIUDJIwPtPp8o/rWjB1/C mgZejXvVqJapiLkSZxiraLlTUsCh4ZG2eVf+ma1vSoClStgZEi+tWAKAJBTzTGUrAf6LEPat 0j9wp6cCpQMixx61G/aqQhjdDXy7+3VH5/hjwfC3SXXrJCB3BuYqVT4WUtzvv2ic2/hLQ8fM BqqAD/thNXC6HcN9kxyGB79MYz/WvFxf8b5Hp4dfujtfAc2fFdplzgsRj22mvU5iAzAY+97f j/h+FdWF+D5mVX4hkTCNnbOMng+n+cfrTbic7fkGOAMY6f55rqMShMjNIQQTng54JzjP58KP xqdkIHJGepP48n884+lMoZM6x9G79f6/y/Oqd3cLHCx4BxwD254/I8VaEYUxEuQRuyQpUMMk HsPqcDPpmmW0ZDyOxDdRkcBmz/Itx9FrRFFa6uQkbcnb/eAPp/hXxr+2gn9qeMPA1qQGSEXV 0/pkeWAPzwa58RK1Nm1KN2Z+hXI03w3nIUsDxXz98SNSa9vpyScZI+o714FL4j1Z/CdR4TnC W3l+gxVbVQEvi2evNcvU/UaR3HgmTNsSeldpC+5cV0R2FNe8zyL4wzbtbgj/ALsW7n3OP6V5 2Rls0upz1dzymZDe6tMBnDysTj0ya1U0yaRipPkKoABB5zj0r3tkfi89ZNl1ND8iTZJbs8mB mTZxyM9qVoNU0qVxFcOQDgRxnaR9aRB6B8PZH1myvftupT2K+V5M8twTttlY8vliB91SOAfv dOcVr2XjzQfFPiS08LWkeNKuN9omo3RCGeYqVjlcY4G4gAZ+UHPUVg1ctFRfi+Rqtz4b8S6D b6Zoxf7NcW9gNr2cinaZhuyzSDuSfmAxWndaRH4N1aO2h1N5Z3UXEFxHKUS7hb7rxlUbcp9O ecg9KmSsUmaEesab4gbMmLV0GHNjOsmf9+HGD/3yprP1eGxgRJrXT/7Vt+rz2LIrJ670+TGP Xms0tSrlO+8MJr9t50dpqnlA8hCLhPfhG6fgap6VFpeiLFdJa2rHG5biGa7spB7hgMfjyKaA 7fSNd8FeN9U0nSdfhutQv7q6igt51njuJUdnUKPM2RuRk/xFq5bXPh94N8c+MtYvLDxlbrqd 9ezT/ZNXtZIQGZixClN24ZJHT8KzjJqpr0X6/wDAO2SthV5y/Jf8Eu2X7P8AqUVtM5g0zxJM vy29npmpxBcYzvYuVb6KFP4Vmap8EPH81tm/0GfSNNTkQW8OYwPUhSdx5+8xY+9bc12ciskc JrNjp2mmK2mvZopLfrDEpDZ7k5HX9KpXz2vkw6h5EkFvdM6b4dvmZXAPsOueK1QFOKx0u/lV Ibi8WVzgLJCHLH8DWrqtrdTeIrybSSl6ibEkjQhvMIUK3y/xAkHpTuSYeq2kSCO6gRoY5iwa BxzG46j6c1HpQAuhKVBEQL8jjPatYik7RZRnJllZ2ILMckikWLeCFGGp7icXFXPo1JRLbK3q OR71x0LfZtZuBtOCTwPrn+lYUN2hVtkz7k/Z51D7b4VtSG/5ZlTn/PtXkn7TGnbfGOtPgASx Ry8D/pmo/mtetiPgR5dP4z5h8VKHNhIOuxk/LFT+C5ik11HkgFQ364/rXky1gemviOtWboBz Xu/wD0658Nf2Zdsywvd6m07RlsuESEqm4DpkyvweentWuCX72/YnEStC3c/SDwrIX05vlQtj OGzkg88Yryv4/wDwX0T4g3GlapeJdfaIyLTdCu5UUsWywBBIBJ6H+KvoZQVSNmeRdxldHjd/ 8PD8LPEtno0uoDUtIu4/NhjhkZQFyR86Z+vXPf0r0mynitLdVhRUjA4VRiuJ+63HsbN3SYlz qeV4P51k3Wqher59qzk7DSMW91wLnB61gX2v56Nz6VzyZSOe1fxNBYW73F5cx2sCDLSSuFAH uTXjvjH9pDTtPWaLRIDqs6g4lLbIs+3c/wCea5KlTlOilSdVnzb43+MnijxtdyRahftFZMeL S2+SPHuOrfiTVXQNQMtsYnOXj+X6jtRNaXNIKzsS3L5JrAnH79+OppwHIEFPI21oxIs2Fx5N yp7dDXceFLn/AImkSBjhgRx9KxfxFvY9L+EF26eJmRlCZtWXg5ztYV7vYye/NTTehcjpdPl+ UCty1OQDXXEwZdB5/kavryprWJLNa2BZFPtV6PPAIqxGhbjkVoQqSBjpTAcU23A7fL/WtK3X uKIgX41xVqJeRTYi9Cv4VajXFIZn+Hhtu3Hfyv8A2at1wdpqY7A9xijmplHSgCRBzT8UDKNh /wAe8Y74rcPMI+gqUDGVCeKtCGnkZr5f/bfy1h4AiHV/EdgOmf8Al5j/AMKmp8LKjud7+0Iv naF4djJAVtVGefS2nrzXTC6wMjZDrgnnpwK8TGfxj1cP/CO68ALu8Q2bZ+Yk4Of9k816xbRv ceYzAoQwGO/A/wASa6sK/cZjW+Ig+ZshuFGMj6fe/oPrSMrYIYDPA5AP867EZEfSYgEbhznj g4/pTmmwu4Ak9gPpgflyKaBmddSOXI2HAIJHc+34kgfgapSsWgUscgY5z1xwD+Jz+VUgKcoI JJZgrAdSeOfpUUzkW0gUhS6nn0yAP0xj8TWiAwtSvWMu5dvTKoGBYnGAPb09hXyL+0mwl8U6 OC5kdYnAOMDBKAEfUKD9MVw4v+GztorU5PX9SNjoKQx8OVCj1zXhHigm4uYYzn97KqZA7Z5J /wA968qitTunrZeaO00CQxvgcA8YqXVl3XIx9K4Op+pwOz8JRGKzUDJzzzXXW0pA6810rYJb njfxTuPO8TOv9yMKR+JP9a4mQYRiew60lqzlq6Jsy/gX8Opfil4lu9GgkWG9u4jFZPJwjXR5 jjY9t5Ur9SK+jbD9lZ7TwXdeMdWjkt7SytEaSzkXa7XILxPGe4PnRqp9FLe1fQJN3Z+JuWp5 XoXgG51a30TxJcbmt7i2uZ/IRfkE0ERl2kem3afwNVofhN441Pw2ms6Fpya9p7L5kh0W4E0s WeTviAEgPrx+NZvdIZneIvDV34dt9Ns9VW4F1d2cV9IkqFljWQbo1K+u3aT7nHbnnI/B63M3 mwIF54kg+dVPqVGGH6Vm007FJnoOs+AJviVpIvJI4P8AhM7dArhSwTV41H315yJwByv8WM9c 1zWk6vZvosHhXxQt5p9tays9jeCKQT2EhPPLDPlk8lex5HNQ7s3io213M7xe76LePZ607Xd4 uJIdR+XfIhHyssgPzqRjBINZln42t4ZoWW+u7e6TCrcwx5b/AIESw3e+RSUZMp+zvuejeC/i LoHh/XMT3FvZXcrqs8LwOtpcHqHZR/qm7iRGGPTFewfGr4a3J12w8UeDrAeI/D09ut1cmxkV rgtJI5UxgdQsaIoXkHaRg5pKLW5lJxUrJ3RBof7PVhpfjPSPGct7BpFtbO941qCAJpIgZEkR c4jUgbmU5KlWwCOR59rmoaZY6VPp3w/8PXCQyjy5tYEDGa4z1Ad+QvXltq/9M+9ZL+NL0X6n oTd8FTsvtS/KJ5XfWWnaLbE6pqEdxdbuNL0uXzWz6zXHK59l3d+lZDeO9ciuRLp2o3ekRp/q 4rGd4wg+oOSenJroUbu5yLVHd+EfG/xQ8VI8UDT+JbKIfvTq9tHdW0YHd5JgVQe5YfWrPjLV /DkGmW+n63o+lTammZTD4d3wRxM5HO8MYzlQv3VYehxzUtNv3SG0lc5a78QeH57M22nW17oM JXDLCqTNIe+6QlXI9s49q50f2fa3CyWv2ueSM7leRxCM/wDAST+RFaxi+pHOiZ9U/wCEkuSu psRPISEutxO0noGyenv170raNPo1vqsV0my4gYxsAcjjuD3HNbU/isKp8PzRzm3n2NWtPs57 u6SK3jaWVv4VGeO5qLnQ1dM9+QbYcjgE5/GuT1BfI14EZwx5/EVnQ+JnPV+E+sv2YtWSTR/s 38QPHPP5VD+01ao2t2s2MmWxCvnuys2f0Ir16utNHmR0qHx/4g/48ogescuPwwaqeH7gw6kO cB1K/wBf6V5T+FnpL4kdjYakLa7ikY8KRnjJA9cetfQ3gbSZdI0mzuFkF3byX0k8V3EQyyRt sCkkZwcDkHkcg1vgl75liH7p+h3huSQaXZNCxjnaNF3jtwK1NZkkRZIXQYH3nPTP19a+hR5b 3PkvxJ4gHi34iajqIXNpG/kW5XpsTgEfXlv+BVtpqUcceA30ya8fmu2zoaM6+10Rg4YY9656 98Qgk4bn0zWUpAjlfEHjKy0aBp9RvobSPrl2wT9B3rxPxn+0ayF7fw5pz3DdPtdyNq/VV6n8 cVyTqJaHVSouo79DxXxFq2teM7lpdW1K5mO7cqMwKJ9FGAPyqKy0iSJB+83juSuK45zUj1qV Lk2OL1+w+xzCVZFdd2MA80aZdm3uI5Aflb5W/pXenzRPOkuWZvPJvJOc1lXPM7fWlAUgQbeR +tK3TirYkLE2GrrPDVyI9dtMHCsSP/HTWT3K6Hpnw3uHt/HEatgKRMgP4g/0r36wmLN978Ki GjZpLVHSafPjHOBXR2Tggc5rriYs0MmrkchAGfStYkst29xcLhVlU+g21fhnusj96v8A3x/9 etCS/DNdDjzUP/AP/r1fgubtTjzUx/uf/XpgaFu0rygysrDGBgYrWtOMChbgacS5QHGasxDk cUxIvQ9atIvNSxmboZ26g6j+43/oda13K4XbGV3Z/iGRUx2G9ysr3P8Afj/75P8AjUqvc/3o /wDvk/40xEqyXPZo/wDvk/407fc4++n/AHyf8aTQxbSExRIpOSvetvH+jqe+0UkDIgCajdcG qQDccV8w/tqHdJ8MkHJPirThj/tuv+FTU+Ecdzsv2hbr7LpfhZm6f2sCRn/phL/jXnGmki4m YP8AJIepH5V4OMf7+x6+GX7o7/4d4Ou2OBx5uM9M8GvYrw+TMz5wCOnrXZhf4b9TnrfGVbTM gbGBjnnt/nrTJ3wpIG3I4z7Hj/Pqa7UZGM8p/tAOWJBDJgHjgj/HH1Aq+GigtAq5ducsSPWl EplCQM0jMW27iMAY47cY+v5mqd4ypbmRxtAI+6OmeDj6AbR+NaonqYzzyXdyAqE/KBtA4OTj HPqM/lUeoXGFCq+SQec9Rjg/iAT+GaopGDeT7kiUlm8xWQjL454A6Cvkn9oi7M3xF0y3yCI7 YOeAMku2T+n4DFcOK/hnbR3PN/E180qkL91BjI9TXlsga98ULEvzR26MWx/ewSf8K82js2dj f7ynHu1+Z1ukvscY9c1a1A7nBPNed1P1SB3nhv5bCIkfwjmt+FwDXQthPVnifxAn87xVfHr8 yjP/AAEVymoP5Wn3L9liZvyBpw+JHFiny05vyf5Hof7BGm6P4z+IHiDwRq8zWja/ph+w3sLb ZrW7gdZopoj/AH02l/opr9N9Y8LyePvAGoeFtUkt4fFs9oJZ4UO1LmeNlPnR9irlQT/vg8c1 9PTjzQku5+HylaSfY+TfAHh5NF1KDwRqNoFmuEuZdNikXBN3bySF7f2M1pOV+q15/wCE/j2P 2fPEV54T1jw6+ow2blrDVLSfyZZbZvmjbBBBypHfg5B6V8/mOAlj6MVCXLKL0fmelh8QsPN3 V0zuvix4x+Efimbwp438ZaTfT6f4psMRXUW7zbeSBzFIpZCNxBxlT1BBBHfL8VfAv4YWVnaa roMt/qYltkvkR7uZLdYHUNG0gYCRcg5xuXjnPIzz4h4ygvbbqO635tNGuzvv5GlL2FT93tfZ 9vL/ACMlPAeqavZ291oniDRo0jIdIBZqVBByPnyWz75zSXvh/U5pyuvaRa6g7cSTWs4O739/ xU/WvHwvENGpLkrxcGehVyycFzU3dEV78H/DnjXSo7W3ggvmgz5OmTbIJ4ySSRGRgEH0zz6C vO7n4CeCY74Wt+k/h+83f6m8eRefTB5/LI96+upVI1Y88HdHiTjKDtJWZneKv2VbfVZJp9A8 T2st2RuFteSIgfjgAnbjpxgN+FXPCPgb4w/CHRVP224h0QOWaxt7KS/VweWUKFyAf9kj1z3r SbdrJFUoQnd1JWRJ4Q8czX/iPX9S8VaDrRi0zSLqYXMxNu4Rl8nYFZD8xEuAWYkE5rlb/Vfh 34lg+2Cy8c6rbJ960GqWwEXsVEJOPfFcUItVpSfkj068rYWlCO3vP8Uv0MOfx78PtN2rpfwx M7g5E2ta1PNn6pGIxUS/Gee2j2aV4O8JaU/aaPSVmkH/AAKYv+ddyhfVnke0a0Q3UvE/iHWo obrxZqNxd2sYDWulSvsRz2/dLhUTvnAz265HJ3bTandy3E8m+aVi7HHGT7URXUTbehE1qqZD dajEG44UEmruCi3oieLTXflsAeldL4pvftHgvTLp0T7RIX0+SQDG7ydpUn32OAfXAqYytI6J 02opM4BU3dOlbOjpMzG2hcxNclY8g4Lc8D6ZprV2NZ+7Bs9stdrKY2OA3f0PauX8RRGDUo2Y YYHDfgaxpaSOeqvdPoX9mW+8q8uIsgAOGwepFd7+0XCL+20uZVIMTzQkgdchSP0Br2Ja0keW tKh8VeLITCbyPrtlyMj3rnrSXyrmN84wea8vo0eiuhurqC5z5grqPCnxU1vw/r+js9z9q0y1 vIpjZ8CPCuCQAMY6VNKTjNWNJJSVmftXc6C/h8pA48yEruhlxw69q4X4uag/hPwLfyx3SzXt 4PIt41b5t78FgP8AZGTn1AHevo3Nezcl2PFt71j530/Qp9OsFMigMRu6Vk6prDWm4YPHevHl 7qOm1zktT8Rb1ZhL8y8YHavFPiH8atRsb+XTdK2RtGAJLkjJ3eijp+NcE6j6HVRpKcrPY8k1 DVbzV7hp7yeS5mbq8jFjVcSEdOK5T10ktEWLdFX55GCg96vwzxSIAHAXpzWUkzaLSOA8YWHl XD7MFeoIrAs23qU9fWvVpO8Ezx6ytUZt2U7PDgn5l4NNkH71verS1MnsIvJp4GO2apiEX7wN bekSFb+zcZyJFA/PFYyZaPc/C+kQjV9OvsFJPnJx0JIHWvXrASMy7VY59BSW4+h09jBOwXET n/gJrpLCG4H3oZB/wE10RZkzVRHOAykcdxV63ti4Hytx3q1JJibNKKzWNQ7EqAe9XYDBjJlA /GtFNE3NCAQY/wBcuf8AeFaMEUJI/er+Yp8yA0oLaMkYcEdeDV+3iAbj86tMGaUP3R7VahXP aqEXYRxmrKVDGZ+nQPDeNMMYO9CPT5v/AK1aiRKx+8KhaFMlW2XPWni2UDrTESpbL6mni2X+ 9+FADWhUHgk1oBleEbegAGKEAwjiomGaaGhhGBXzJ+2GN+vfCWM4+fxfpo/8jGoqfCUtzo/2 mG26b4XycY1Jm468QyD+tcBbsIbWOQH5fL5A7nNeBjX+/fyPZwq/co7j4a3Dya7poXnEmSSR jpXtV44e4XByBjnPc/17/lXdhNab9Tmrr3ysHKM+P4h0/wA/l+FUb2cZUEgqORkj+v8Anius xRmeYGuCN3QdcjjHfA9ASfriro+VUBATg/LnoRz+nA+pNESmVbm6UsoBJxxzn0yevtz9RWZf 3SzRPGcBWyMZ68fy6Gt0RYxZ9VUKwRt3VTtOTzgYGAACcYz7msi71QOWOQ8hwcA4B5657Akf 98J70M1SMR9Wt4ZTJIQYooyxKqFJydpwMn1z+XrXyD8aNQW6+LV64fc0UKB1A4ViCSB+efxr gxT9w7aK1OI1eURxsXb5UBd65z4a6M+r6Z4k1do9xt7cSs+Pu73A5/77H51w01anJm974mlH zX5l+yOyTOPpVufLsB3rzHufq0Nju9JlWG0RPQDrWpHcAA9s1umVY8T8UN5mvXxznErD8jj+ lcx4lkEWg3zf9Myv58f1q6es0eVj3bD1X5P8ip8B/DXi/VfHFpqvg2SO01XRpIruK7mmESJL vAiTJ4LM3AU9ee2a/ZT4XXd58Q/Cllrr2C6brlku86dMQWs7g/663DgnML8NGewYjgDaPqKF 7s/Eqnc5f4y/BFPi9o41/wAPXbaH4ht5o7y3uSv/AB7XkTZR2XqCGDI4HTJODzXiXx/+BFp4 wtdI1rxDYTadrrK7jStLkQzTT7Ha4t4ncbTGzJ5sZOTl3XbknaqkOVtrZjjPmSvueIfC2Lw9 8e9Bm+FNlptzpiaXfnXrZby4865KrtjuYo8BeqclPYsM4Iryr4zePfFXgb9o/wAV63p9xdeH 9Ri1BxbKnybbYcQqV+6U8sJ8pyMVhZ2uXpsXIPE/g340SeZLNF8MfH0nTULJmj0nUH/6aKvN u5/vLlc5JHNcj4n134m/C7VBp2tX1/A3WJpnE8M6/wB6OQ5Dr7g1w4jBYfE/xYJs6qeJq0vg lYksPjTrybWu1guT/ewUb8wcfpXpngr9pHSfFccXhXxy7LpsreVa624E0umueFLgj97DnG5T yBkgjAqMJgYYOTdJ6PdDrYmVdWnujT1fXofh94mbwr4xg/sDULcK9rewytLZTxNyk0EvVEcf Vex5BFeteF/B1zrmo6SbDVLhXvY5ZIJVlH74IULKGTKncrkhhkZTB+8RXrWu7HBeyudbd/Dz xHpY1O2tfG2rRXt7LHFbh75pFted2fLkDqpO3bvAKkMRgHNY1p8IdF103sHjbTbbVdVtX8tr +ysF07UIX6gmaAKj5HI3Ag9a54UVKU35/oj0cRU/d0Ev5f8A26R598QP2T7ybwtqGuaBq9t4 qNtG80Vlf6Wj3TBRnyzLE53tgEAgEE+ma+UI9Z1KxmliitLXSrtWIYQWqpIhB5XLAspH1zU8 iXU5lK5SuIZ1DXE8haR2yxkbLMT/ADNOgsrl/wCDyxj+78349/5UpSUUdOHw86793Yvx6PHI EDyNkKcl0wN3PGB26c1L/ZhKAgEkenNczndnuU8IoR1EhtDHJhuF/WtHxFpT3PhXRoUCu7XN zMYweRkRqCR2ztP5VCetzStBcigcvaaOVB3IQfcdKieIxTK4GNp49q3py94469G1F2PY1bBN Zfi9kuLW2mXAlBKyD16YP5fypU/iPKqfCek/s73o/wCEjWKQ8SIBt9a+i/jbpXlfD2K7DM08 NzGzOR1BUr/UflXtrWkeTJ2qI+GviAg/tG7wMbscD6CuM6KpHWvK6s9FdC3bOrOFdQynuB0p 8iRR52khh0OCOayi7SR0NaH9Cfg64g8Y/Cjw1fyqJRfaRa3QY9QXhVsj868g+I3gq51W/wBO kllR7KxEkgjJwXkOAPoAB+te1SbcZR8zxJaSueaeJdN2xldgRsHIHIFeLeJ4/LmkAJIx1rkr qxvB3PMdaQrKcEjnB5r5++IkDReMNRBU8sr59dyBv615LPSoPU5wl4xkRkj1yKrvdyLyLcvj /aFSo9zscrEH9tNEGVrb6Zb/AOtSnVJWhAwijOcAcir5ERzsztVuDeW+CvzLzkVjadplzeXZ S1tpbiXoEhQsfyFdVP3VY4qzvK56J4Z+AvxC1+YNY+FNQaKQfemj8kD/AL7xXo+lfsR/EjVp A88en6ch7TXBZvyVT/Ok5qLMbneaN/wTz1ycIdQ8SwQ5+8tvaM/6lh/Ku80f/gnp4bgU/wBo 63q923HEIjhHv1DGpdS5DnY63Sf2F/h7ZFDLYXd6R/z83T8/98kCu90f9lP4d6SqGHwvZSOh BDSRBzn6tk1DbZLqPodNbfB3RLIKLfSrW3Uf3IQK1bbwDYxDBtkb09BTRm5tlpPBtknIt1De wpzeFIY+cAe2Kq5F2QTeHo4wRsB9OM1VbRGYcR8Y4xQmVcpSac0XVD7gjiq/2RAOI+RzwKHI q4jIAAMDHuKgmmRMfL+OKL3C4sUinoWU+3FT/bp7dj5VzIVHGeRmkpNbFIdD4s1CNsLcPkdm Of51ow+P7+LG8o/1X/CtVXkikaVp8TJgcSWqP/ukitaD4mWWQJraRD/skGtVXXVDNS18daLc kZmMZP8AfT/Cta11vTrph5V5AxPbeAa1jOMtmBpwohO5TkNzkGp8VoMkWnBOaLAOEY9M4qRF CdBj6Uhik0zFNDDbmvmb9rpN/jH4Op2PjHTf/Rjn+lRU+EEav7T0wjtvCoY5zeSkD1/dEf1r zPQ9TS6gCsv3CVKN2r5zGv8A2h/I97CRvQR33hTVYNL1OG5cbYoiHYDpzmvR/wDhZOmSsxE7 YzndsP5114WtCELNnNWpycrolh8caTc3EcC3ZaV2CooRjk9u3r8x/CsjWfiFottq01gb4Jcx KHZGDg4Jx/dOeRz9ap47DqqqDn7z6EKjOzlbRGJP8S9Et5JCb4kY52q5/Dp7k/gKzr744eH7 bJku3J+7hYW4z1PT1wfxrpVaC6kcrZz9x8d9AlHmi6mKgkHMbAgnjjjqRwPTc3tWNrv7QGha Xbl5JLgHO5mWNvxwAR7Ac8ACq+sQ7mkabZ5j4o/bB8M6fb7o7fUZo2JOFiAJPOPvSfSuK1H9 uDQI43aLRtTL5BXeIx3B/vHoc49jV+0vsTzJC6Z8fdQ8ZT3NtY6PMjIyxbnn/i2gkHg8qWI+ vPYY53X9FuG1m81O/dXvLhg7KvRAAAoH0AA/CvKrVuZ8h6lGN0pHn/jmc2uhXTg/vJVKr/n8 vzr2Hw38LNW8J/sl6z4kkEcEGrzwLtePEjQrOioAfdgx9wq1rTX7p/MiGuOprzX5njtsMke1 asloTB5qclecGvIejP1elsWdP1qQj5lHFacWtPJKkez7xA+lPmsdSjfU8z1R/N1K5kzndIzf mTVzwl4R03x/4o0nw1quoSaVZ6rcpaG8ihMrRu5wh2DkjdtzjtmuqjrOJ87mcuXC1n5M9V1X 9nfxx8Ibz/hFm8NNJp6TC4bUdPbd9s/6aIT97AOFB2kc55NfTvw/+PFtoWo2M1hdPNrOn2UQ 1rSrtGhlubZmwkxDD/WAn5u4LqTwxr6WKlT1Z+Nu01Y+q/Duvadr1lH4g0iUXGn3y5dUHO7o cjs46Ed8ewz5Z4ysD4j+IVxpOrafDdWkbxzWdmTslaFCF86Fs4Zo5AxKAhgGyD2PTU1Ssc0N G7ni3xd/ZVa1+J9p8SfhlqttpPizTbhbm7sp2/0e5fHO9l5iMi7lYkbW3HkHJPgP/BQrw3Jc nw34sm0x9PvblfKlRgCwR13iOQjjdFIJVyMghkOTmuaSsjeLv6nxZuI6AD3ru/Cnxm1rw3pZ 0W+SDxD4bY5bSNUXzIl94z1jPupFYMs9C0T4W6N41SHWNG06+tI1Q3NxoV/cIsccfG1zcFlY RsWAVMeY/RfvKTk69oll4siaDUNQhS7tFEMAsoAIYQP4V2/KF9gSfUZ5qnF2RCkm2eoeBfDX /C7/AIZr8MtevrNvFGkI03hLWJJDll6yWEpIztYAsnXBGOmAfKbj4vXvwpl0LQ/BOp3VuNBu Jbi5vJI9n2u7cgOfLbkIqoEAPJG7I5qruykFt0fe3w8+JcXxL8FeFPE81qLVtQja31mKEcRE tsJBzlV3MJFwcruHvXM+M28ReJmsvEvg7XHtvGWgateaPqNmwCx3cUcjOsUyMQrbUyVYkfK3 UHkZU535pLq/8juxMOX2cJdIr/P9Sx8evEuseEfBOreItG0a6XxFdwWsYtYCxeNWEcs3mxrz vi2kB85xKB0Ga8L+J3xot/HXw4sPiKnhXRLy5tLxdI1vR9bsTI0MxQtHLDKrLJscBuGYkEH0 5uerOSOiPJNO+Jvw4vb2O7v/AIaxw3Yz89jrVwsfI/55yB8Y9iK2LXUfh5qIJtptU0+V15F1 EkwQ+qurKfzU1w1oN6o9zBYn2S5LblXWPCWnvdEaFr1nrUJAK+b/AKLKSe21zzz78+lZFzpk ukK4vC9rPniF0OT+PTFcqv1PfjUhU06k1nYm+AknKQ2qjMl1IMIgHPJ7n0UZJ7A1mavfM4iW GXEMS7Yc43YyTk9eSSTjJxnGTimmYSjzVElsikitLEZGywJw0h5BPuaw9auYIDuVhknBA9fW taeshYmyov0PVIDvAJ6GszX0DWjYB+U547VcPiR8vPWLOr+Ct8LLxFYOpwWyvTjPPWvsX4gD +0vhTqEErFvJgWUsOclHB/kK92GtJnk1PjR8EfFWMW11vjJBIH88f1rhTgwoc815drM74vRE lswQhiOg7VYZtxzng8fSsep19D96P2VNW/tv9l/4a3JbcRoFrAT7xxiM/wDoNWfFkBljmUgY KnORmvapby9Tw57niPioRS2f+jsjQgYBj5Bxx1/CvDvFNtiZsDdwQc1zVzWmeWeIFCysCBXk /jm10v7VNJNCWu2jQ7h3woUfyrjw0IznaRvOcoRvE8surwyXsdrFbKvmsFDHqCTiussfhD4i 1WXyrC3F6/8AdgV2I/IVniIxhO0UdlCo5QvNnWaF+xt8RPEkik2Vtp8Tf8tLmXnH+6ATXsfh D/gnbC6Rv4g8QTyt/FFZRCNf++myalGVSul8J7L4R/Yl+HXhx0d9FTUZQOXvWM2fwPy/pXqu h/CfQdCjWOw0u2tIl4CQwqo/QUmzjdST3Ojg8MQwLiOBAOnSrI0Re/H0FRa5NyVNJVcdcGpR pKqfudKtIm4fYAP4P0qZdPwBximIQ2eKja1A/wDrUxEbW4zzVeaML17VJRVZRJnjgVUuGCqR 0xSTGZFxKSpGOO+aoSFQTx1oAryeXkZ6e1VXt43J4+maZRE9uIxuByKjZMpyQPpU3GmVnt1z uU5PpUEsbr7+1K5RXcsjEE0huWQ4B/OkFwW/Ix6etSRajgg7iMUti0Xk8TXOnHMF3LD34YjF bFn8WdUs8A3qy4/hmGc/jWsaso7MZv2Hx12kC7skcd2hfH866jTfjH4cvsCS4e0Y/wDPVePz FdccRF6PQdjrNO8Q6XqqhrS/t589kkGfyrSGMcV03uA0ikNUMXFfM/7WqmTx98GYwMk+L9OP X0aU/wBKzqfCCLf7Uv8Ar/B8eMqZrlmH0Rf6kV5db6VBdW63GfKmTqYnKsRj2r5jHP8A2h/I +jwX8BDrbWLizXbMzTKW2pI3X6Nj+ddRaTloRIfkJHTNc1OaehpWhbY0PC1yW8S2jZJAJP6G uQ+LM6aR8RxMzBElM8BZuB97eOfwr5+u7ZtS9F+ppSV6M/Q5m91GJo9ysG+nNcxqf75Rxyea +z2Wp5JPpegyyQrJsJii+Y99xPevM/ilr6Nu09NvmE4LqP4e9cVKo5VLdDu5VGDZ8/eKLj7V fiEHKxDke9Z2i6dBe6yj3SlrCzRrm4H95VGQmf8Abban/Aq91aI8bqfXXwN8Ef2R4UXUL0AT shnmZuCZG+ZiT9Sa5/xLqB1C4lkBOJGLKPRe3+fevDveTZ9FTVopHCR+FLz4lePtD8J6erNN fXsNtlRnYu4PI+PRUVif92vv39qrw5baF+zTH4esEEUMElvDDGOyxqWA/JK9VK1J+hw4Z3xs H5n5423T8a6Gww6bCeCMV4kj9Zp7GZGnlXDouevHFaluojuYpD0DAmoO6J5xK+XPc9Saxde8 SXnhebTNQ0+Xyb23uknhlA5R0O5WHuCBXoUFeoj5PN5WwVX0/U/afwv4jsfiX8OfDnieONJ7 XWdNgv1tJUV4lLorFT3BBJGR6GsbWvAei+J9LudPlsG0qWVHUSFFkAyOqtgMP19819hbmjp1 Px2L5XdnN/CnQfFHw0vLm2RINW0pm2yCxlEse4cHcv3lb6gV2njrwgvitoovtgsrqC5NxZXe 7EltMSTtB44YEcHr79KwjF8vIwk1zcyGWPha61eVZdc06W18TWIWNdYsJBEZYS2C27owBOWj kBHU4NeNfEv4fRfF24u7PUZVht8FLK0eVUMkQz86AfK28HJHIHTjAxnUi7DhLU+BPiv+yN4n +G0s90Fe70dSSLtYGxGM9JByUPueD2Jry7StIk0fUPtN1BBdFVAiYEOsZ7NtPUjtnIz1Brzv b8k+SasdnsuZc0WeofDvxTawa1b2+oTyPbzly8rPlvNZWUSE9yC2efesfXPD+paI0s6PFa2V rcSRtHjCSMAG3L7MCMen5V6Dd4pnElaTTCDXJdF1CC8sZmtry1lWaCVDyjqcq2fqBWf8TdKm +KPxh0278O6cftfi6OC9Wzj4C3DkrNz2XfHI5J4AJJ4Fc7dtDZH2jBo1t4c8Bad4F0SQ3ty1 hK7Tw5y4Vm8yT2DyuijPQcfwmuy0a1PivxZ4mttHEZ8O3f2yW71cAAS3Uz+S20+kUEbAnPJ2 9N1ctB6fN/mejjV+8V/5Y/8ApKPLPin8Q4vjj8XovDvhueSey0xnk+0W0hTdJjBbcCMAAnJz gALnGDWd8ZtU0DwL4a0rwCksN7eSMdQ1C8urVLq2ScjESSxuCSgUt93DLkN1JUx7VqcnLYx5 E4xS3PlyXxB4KOrT2vifwRNpN0jbZLjw3ftEB6MsUodSCORgjORVrUPDXg7UL7SLbwj4rnDa jIYpB4mtkso7IYyGknV2Ug+y9voD22TRgpOLNu+/Z8+INhF5tjp1r4itD9250K/hvY2HqBG5 b8wK5jxBpvi7wNHCuu6Nq2jRyE+T9vtniRvXbuGD+FcsqLR9DSxVOqrSZz03iaa7VRPLJLt4 XexOB7VXl8RtEQUOHHfaDisvZHT9Zp046FfVPF9/qSoLm7nuPLXannSM+wegyeB9KxY5zdXk KysSjOAT7E10U6aieRisU6uiPdrCTfawuDw6huPcVBqymSGVBwMZzWS+JHK9iX4d332TVbNg eUnH5cf/AF6+6bK0GqeAdShZ8h7WSNdvJJKda9yl/DaPJqfEmfCfxcgDxCXHBjIBHrkGvNcn AHavMe53R2Qqk4GDVhTtI9vWsXudNz9uf+Ce2rf21+yD4KJO5rcXVufbbcygfpiuq+KeoaxZ W8UWjaZ9tmn3eZcyOqxWyDqzAkFic8Aehzjv69LdnjVNJM8ft9HudJ8NW8Oo3L3t4N7ySkbQ WZy2AOwGcAe1eY+KbMu8rKn0rKsrlQPM7/wPrfiK7K6Zp81wM/fxtQfieK67wn+y7DrOm3ae KbKKe6l2+RJBO4aEDOc4wGzkflXjy9rHWlLlenS+l9V80bucLWkrneeDP2PvAvhySK4OhwXt 0mMXF8PPbPqA3yj8BXrul+AdN0uMJFbxqo6KqAAfgK3lJyd2c13axtxaREgwkYUfSrC6aob7 tQCJ1s1U8Cn/AGZc8cUhimACmiFc5NNDAoqU0uM0xCFgPSkDlqABv8ioHAz1ouFiFgD15qrL H1z/APrrNlFVkKjjpms66iYkkVKYzKkjPPbPaqk0S4zxg+lUBUkhQDOcgmoJCI93+TTGQOd3 Q8elRGENzmoGkRPbgZ5qq8fPNIoryW237v61Xlh8xiOg9aLjSK0kIwcckVGIioLfw5xSKQsy FwCSSemaqtbbmxwc8VnzalELWnJ2nA68VBJFKgLFvl6c0MZEbmaFuMjHdGIra0rx74g0gg2u q3cYH8DSFl/I8VUakofCxnY6P+0Lrlnhb+GC+UdWKbGP4rx+ldzon7QOhaiVW8gmsnPUjDqP 5H9K76eKT0noFju9J8YaLrIU2mpQSMf4C21vyPNeD/tSBZPif8FEPKnxZZN+Szn+ldM2nFNA tw/aknA1zwfAeS8d64x7eR/jWx4L8H6b4W8MwT6pDE2oXQ8xjOAfLB6KM9Djr71+X8X4mVH3 IOzlb7rH1eWRvSRYu9T8NQqUaWyV/TC5FU5rzw/fL5JltCG9CAa/LoVsRBqUZO68z23FPRoy IvDMukeILK6sHS6sGY7zuG6MbT+fOK8w/bJ8I3PiHRpLXTY999dugiQNgs7bcc+/SvsqOYrF YmjiJ6OPKn8rnnKi4c0I9Uz5s8H6H4m+EXhwWmv2rWvnXTSqTIGxkKP/AGWvZfhlaDxvM87Y aziA3HaSGY/w/l/Ov1CjXpYyHPSd0zwHTlRajLc7L4lRDwp4ZZLdkXYpL8Y+b/Jr408QX7zS 3V/O+7cSw/3R0pwoclS5rUqXpnmLSGQyTscu5LfnXo/gXwqbqy8OaO8Q+0azef2rdHHIto9y QqfTJ89vQh4zXozdoNnn01eaR9ca4I9A8DXCoNpS3Yj3YqQP1rwS/nWHzZGPyRJuP4CvHiuh 9BeybPcP2B/hw+qeJNa8dXsW5LMGysmccGeTBkYf7qED/gZ9K9y/aruQ3hvTLDzA266LHnrt jYf+zV7E1amzzsBrioM/PG/sv7O1e7tj0ikIH07VoaU2ZEH1r5+WjP1mk7xuMlj8u7LHpkjr U8sojtLhx1SF2H/fJpHcnoecO/JOK4/xvLGbixSQ4jyxJ/KvRw38RHx2dy/2Kfy/NH6x/wDB PTVYfFH7MulabBdi7fQ764sizNkhWbzlH0Hm4H+7Xvl9b2FsZIJCjEjaSUOAcdcnjtX11LWC PyNtKep87ftG6ppfwrsbDx21xc2Ze8isLt9PyQFIYiTqCcFQDjPBHpXP+M/2srWL4Oal4v8A BsUXja90aWC11SC7DokcUvKzyJtDMv8ABxjB5JIHPI26cmjpqcs3dHafB39o7w38XvhRq+qa JcTWF7bWTx3+jSXfmSWjMNoKhwWK8na6kjscHiu80W/8NTWNpbQTaZPb3MEc8MCXABeN1DIw imxwVIOMnrVKSlZnPZrQh1nwve/LZWWliPTpj/x82U3kyQZ/6ZSK0bL9D9Frwjxt+zf4Z8W3 E8WsaPA14rEfa30d7SR/fzoG2v8Aj+QrKdPm3NITseL+Jv2NNF0+4Yad4iOkTMcos1zC4H0E ojP6muY1P9jvxZq2N3ii3vomwC7LEBgdPuSN6n86ySa0Kur3Nq2/YtmUPda14rWC3c/8e9pb K0mMj+Nn2ivRfC/wu8GeD9Hg07So5JNRa3Fi13Lch76S2DFmjRolOxWLMTsKk55IwMZy1ZaO p1Lw/pTrLaS6p/Y1nFbJFc2umIIp1hHIWSVj+5T5mxuOck7eTXI/ETxbK/h620GBl+Hfw7SH yYJJImbUNYbokdraD968eSDubbv4yRk1z0F+7T7ndjnfESXay+5JHlt9460H4AaTJoug6Yml +Ib0bzbXcgnvYR1E186/L5nOUtk+VPvNl/u/N3iDXdROpTXt7dyXc9wxklkkl3GRj3Oec1Wj lytaHNqo8yZb8etcxWnhO8v7e1a6v9Kja2WIbplt1d44jIMAbmC5B5yu2ki+F91c6PJqUt1C XADGDeXKj3IGB2q5VFBK4QpyqPQ5WeOfSJ9ixiGRTw0bMf1zXqt/4ivLT9mD7PqV9PcTaz4k U2EMshbyoraA+bIo7AvOq5HXafStE76kOLizxd7olSAxJPc1WuJizYUkjHXGM07alXdrXCCF pmAwWZuAo6mulGjHQ9KS+lRWuZm8uIMMhODlsevH61LJ3PSfD8vm6DbN/EnynPsSKvPG12xj Vf4eT1rm2Z1MwPDtx9l1BjjLRsDx9a+7vhZr63WixvHulWSJP3agE+h78YyPwr2qD0aPJq9G fJPxf094Y5rYp80M7x4PUYyMH3rxHdlBg8150tzrp7EiKZY2APzdc4qYE8Z/M1i9zqvofsR/ wSr1caj+zDLabtxsNbuoMegKxyf+1DX0X4kiOxgBk8rivVpPX5L8jx6vxM851zwbd6izFgIY 253N1/KseP4X2ivvki89uuX5H5VFVmXN2NOLwxHBhViCgcYAxWra6OkeCqAYGK82Sdxpl1bP aemKd9kWp2KHCEDHGKcYAaRQ148fypFVQORQMGAAPFVpXBbJoGROQwHrUfIJoARuaUcCgYp5 FQyJ3qWxld8jmo5MED1qGxlacZHHX1qrLjkZ6d6lDMq8jUtwMVlmDG44JzzmqEVZIsEAc+nv VSRiGbg/N1NMCs77AeKgkfK5AOSakoid2AJzggdDVcsWBwCfwpFDo48qA3pzQYRnIOQaQytP Y75cgcDk4NV3i2th1NK40J5DKOBlfQ1G8ODwPxHf/PNZyKRDJF2x/SoWX5cHp15pbjIhahxk KKimtNgBC8elZJ20LKclnubA+UnpVKezkBLcZHccVomIrxXV5b5MUsqc565GatS+J9SkvdMu b+GHU5dMuEu7N7hcmGVchWQ9iNx/M+taxm47DNzxB8SYPGXiLw9qviG2lRtI81RHCoKSiQxl t34xL09TVj4p+Mn8faTIPD12BNj5YjII3HrjPtXymc5ZUzLEU68Xot0e5gMZChHkn9580eKr DU9MkkW5srqzyR+8mU/Me+G6H6g1jaXd6nb6krw30q52kAnODXbPB0XHllBHWq0m+ZM+n/gx 4luL3QtVutWnWCHS4xLJO7bU2nPcn2NcZ8c/2k/BWo3Nkmn6r9ruoDBNmKJyoZCCfmxg9K+J w+UVp4irSoq6i1r8r/qdc8VCm4ymzmfjBqemfEbw08vh/UbXV5PNURLaShnUscAMOqknjBr1 L4a6BF4D8K2ulphpoEzcS4x5kx5Yg+np7Yr7Lh+nOlRlSqKzTPOxrU5KUep498f/AB5JrEsG kLICclpDH0xnr/n1r5v8f6msdrHaRnDSn5gOyj/P6V9VFXkedU0VjnPDukL4g1ux0+Sb7NbS NvuJ8Z8qFQWkf3IRWIHcgDvX0H8CdNbxF4z1PW3i8qFQILeM8iKMY2xj2VFRRTxDtTZOHV6i PT/iprAOkTWqnAO0YB/2hXh/iIzXFvb2NqjS3N7KIwqj36fido/GvNp25ketVb9m7H6MfCTT fDfwm+HGg+H31nTYmsrbfdS/a4xvuG+Zz15BZmx7YFeGftDfELTvEPiLTLWxv4LuOJpSTDKH XJ2gcj6H8q9OtKKja5z5ZB/WFJnzh4z8J6jca093Z2U1xDKB80a7uQP/ANVY1pp91Z3Kie2l hI7SIV/nXhz3Z+l4etCUVFPUq37+XdOCfcVRu7rFhdnOP3ZX8+KVj1VL3TjGPPtXB+OLkJql sGXeEjyR9T/9avSwv8Q+Jz2VsG15o+8/+CUfja2vdU8e+EY8q1xZwanHC3QGJzG5H186P8hX 6B3scNvGkxYu4+UGGMvj8eQK+rw7/do/Kpr37Hxh+3XcTah8L9XsGd0Ek8DI8jALxOhJ68Hb u+vPTgV8L/Bn40XXwm8dTajYW0Wo6VOj2d9pl3zFeWrcPG4x3xnODg/iDx1PdkdU5c7ufSvh 3xn8OPh/e3h+HF5Z6fJ4ggZtTl1i52z6bE8eUt7ZyNp2y7XLEndtQZIANdVqvxmttM+DmjfE HX9B0fxlqVg58N6s9pOyR5UtJauvlnYAyvgkgjI4x0rKMvuIa7nDeHv26fBljeRsfA+uaHD3 /sjxFJIq/SORAo+gIr1bRv27fhpqDRRyav4r07dx/pIEij6lTT549hcrPWPD3ivQ/iPZtdaH 4unu4WH/AD9Rtt/8iYB9jWXqXgHUInaR9U8WSRk8G0jjlQ/8CjJ/nTsmroLtOzPPtefTNBn/ AH3hLxhr046PL5GP/Hrjj8q5a/8AiFq85+y2/hqLQrZiAYbi6e/upB6C0sV+c+0px71i09za OrSLniVvG8V79m0jQbbSLWFgsfiDxPKghjKgDdZ6eoOTxkOySHP3SBiuGuPC/inSr671Hwx4 a8Va/wCK7ssLjxx4ntGtWUHqLRZyoiBBx5hO7BIG0HFZUValH0R141/7VU/xP8zyi5+F+l6F cSXPjDX9B065LFpYjqRvrnPf5YDJkn/aIHvWTNq3wt0u7Labpd5rtyvK3WqRiO1DdiLcOS// AANseqmrsclzjdXmi1vxWdbvdYN9LJ94TRlCoxhVULwABwAMAYrooPGdjouhXNvbPNNcTgq6 LwhHYfzrnq03Nqx10asaadznvCXgTVfH8l3M7JpHh+wYS6jrl2D5FnGT+bueQsa/Mx9ACRnf FLxrF4o1m1tNFs7i08M6RbrY6XbzL8/lAktK+BjzJHLO2O7Y7VvGNlY55S5nc4l5JUIDxmMn kblIp8FvLcyqoGSfSrRFzd0K3jtbsrNhXU4+auz1NrDXdGFm13FbXEbCSFpDhS2MFSe2QfzA qGCZpeGW22N1Cf8Alm+fwIH+BrWtL0q6uuVKnFcx1s5qHEOtzD+DJIyPevsz9n7ULe5S0tpI Ycyw7lZOCSMHn8v0r2MOzyq2x5B+0DpQsdZ1uOMkCO5L5bk8kEEn8a+YZAY55kP8LmuOatJn RTegya6ktlHl4+bg5p1hK00h8zk9h0pKKZo5dD9iP+CWHg3xN4M+D/iCLXtBvdHtNQ1Jb6wa 8iMZnRoUUsFPOPkGDjntX2RJoUNxcCSVd4B3bTW3PyPQ5JQ5mTzaNazn54wapXPha2nOBhEx 02jP51HtGS6KOd1jS7LTJQkI3yfxZAwKzGfGcAAewrORz2sytMgbJqHaAKxZYjJj6004qSkR setRs2D/AFpDIZ5MYqoxJbnmgYm7AzSM4HOaBjRKp9aTzc+wpALux7imSN71DKK7EnpUDsev Ssx2IWO8c1XlAGTn9KAM6YDByMCqEuMntz2qhogeNQnAyfSqLqB1G0HvQBWKg8kY5/iqFolB Jxj2pDRVnVeuOnpUfmoEzkY4pFWIycA9qY5AT1pDRGpwpIbGOlNZsAnr7nvSKEMmQOOKayoq 7cduKykNFS4CqAc5bPSqjLubI6UosZIrBGwTx602RuT3yMVDjqNMpSL14BqGQZB7cVohMpeQ GGD0JqGW1AzxkUm7FIqTWKGPIBH0rMn0cl8gBsfhU3GSwz6haRFUmkMfQxudwI+hqpJaaNdy M93otskzdZrZfKb8QODSbTVpG9OpKD91nGfEnwBqXjKzjttH8TfYtPXBfTLtCkchHdmT73bq K83+K3wb13xl4+kv7XTY7DSDGgkntyjxrhQGwE9+xA+tdtGpSo0GorU6aGHnjcVCm5Wv3Ot+ H/hHSfAmqJc6ZFLHeOyrJcSvv3HcDnaflBB56cV7p4f03V/F01hYrNu1C6JyoIVSxznngAYr zaM5zm7byf8AwD7bN8uw2BhD2e1n+BQ8Xfsq6zHdyXdzoV3M+MebBiXj6rmvJ9e/Z8hFyRNE 6XA42yRqrD25FdE/aUX+9TR8zCNOsrwaZzUnwj13SixtbOCWMgqXjZEJHuCRWbJ4c8R6YCq2 N7HGSf8AUAsCR/u5rilNvqdSp8vQyrm4uo5Gjn81JQeRJnd+RqLzZVcCQN7hhUjbsTi5KLgM M59aSC9Ed/ayvIiqjhuXFVFWkma05qMk2elab460q2sYPtOpwCQgblU5wfTj06VN/wALJ0QM caimD6K3+FQ4NtsqdaPM7Mq3Pj7wrKS1wYLgE8lrUsT+a1m3viP4fXSslxaQ7JP4YrZ0/wDQ QMdKajI0jjakPhkzBvpfhjKp26Reox728rj9Gfj8q4bxJ4N+HGtXLToviSCXAVQksBUD8VJr rpTlTdzkxeIniqfsqjuj0j9i+70T4QftDaZrkV89poU6vYXk2pSovlxyxtglhgYEioScDgV9 m/Gz9uL4QaboN9pP22+8SGQBWTSoSiAggj945QYyOq5r6XD1IzoNS6nyMufD4mM6e8bM+Dv2 lf2mYvjDoEP2Cxn06x80qqTSB2cgYBGOwBNfMMPmu48lGZj0K0pu7M1qdJY6ffGNHkhZfmXc U5yvf2r6P+AHi/w/Pf6v4D8U+TD4V8a2wtLu6ZgI7K7Vh9lnK8Y2vweej5PCisk/eRVtD5/+ Jnw21r4WeONX8MatCbfUNPnMTow4YdVdT3VgQQe4NYiSvHGqmLdgAHnqaTv1D0J4tXu7K5W4 tDNazDkSRyFGB9iK6/R/2iPiPoSJHpfi/WI5FI63LTfh82aEGh3ulftX/tBTW2+HxDqLQDjz 7q2iRB/wJlAre8N/tIfGXxL4k0nTtS8cTGK6vIbdorWFGyGcKRnAHfqM1lVquEJNPodOFpKp WhFrdr8zl/Gv7QXxAtfEGqro/i290uzluJPLjsykL7N52gsihjxjqc15brviXxh4mdpdU1LU dXLfx3ty8uf++iadN2hFPsGJ1rTa7v8AMwWi1CI4e0yfQdafqEtxo9wILm32T7QxUNkjNarU 5jW8J+GPEHj69Nr4f0HUtWmH3xaW7SLH7uwGFHuSBXdN8PfDPw6AuvH2vQ32oL08L+HrhJrg t/dnuRmKEeoXe2PQ1WwHI+PvitqPja1ttKhhttD8NWTFrLQ9OBW3hJ6u2STJIQOZHJY+tcSH YEYbkfhipBFmK3e9ABLbgeMc1saXpf8AZtz9ourlVWJS3lEYJJ49ffNLms7Ba5lSqt9cTTmR 1LNuCqhIFTLpkkjosnmbnICb1IJPpz1pgtD1Tw+QLqZf+ekfPvj/APXTlidLx5d+YyoXZ7g1 xRO16FC9iMOuRlxt8zBAHoa+kv2fp4obyymzhlBRR0x/nP6162HPLrB+0vpTQeI747cC7tUn C49iv/slfIGrpFDfMY92HAJB7HoawqL32a0/hRWmiDopHPevpL/gn78HLL4uftKeG7DVLJL3 RtOEmqXsMi5R0iXKKw7gyNECD1BNKLNGfuiqBQAAAB0xS55xWZkxao6vffYLKSQH58YFNK7J m+VXPPZ5jI7MzFixySai3ADrQzhIGkHNR7u/aoZogLVGzVmxkTnAxUJapKK8xOOuKrFsg80D QnmDHWonf5ue9TcojZsHIJApiOQRnmgRMJN2OaR5M8VLKRG2VxioJD3rMog34PtUMiEgg9MZ 5pXsBVkQYOeDWRMPmOBj60blFSQENxnGAeahKDBbPbp6U7isUncIxPBI6moXc4z7d6BogkAY Fe3vVeSEEEcAduKBjHQ8BeBUapI+eAFPFSNA0WwAD061GW2L0wD2qbjG79zcY54xmm7RIOTw eh6VnJlJEUsWcg9fYVVnhEXAHTvWcHqUyNnIAyQM57UwSA54P41sShJVBGB1z1qsybVIIzUj I2iGBtp0cRMZJGcnkY61EyokL2qhcBeB2NUJIghIPaoiyyL7OG/GmNZg/wAOfwptDTsOi0u2 kO1ocEj7ynBrLv8ARFtZTJbzPGx9eD+Yrnpyadja5lXEO6USXEEc7LzvkTLA/wC91/Wun8G/ ESDwr4ksdTnsmuFtyWKW8mM5Ujo319a9SioKcajWzTOieMr1KfspyurWV+lz6G0b9pjw94ku Z7aS6i0eAoDDJdOUk3cZU8FfXnd6cV6u50vxBpqybbPVLdgMMQkyH+Yr7SE6WKhpqjwGp0Xf Y5LX/hj4K1Kykkl0OCDeh2vbhoiG57KQO1fHdtMssgO3GK+QzjC0sNODpq17n1OV16leMlUd 7WPnDxnJJH4w1YO2SL2dk5ztHmuQK5p5RuYr35JryUrHVJkMknr096jMhIUjpV2MgDk9TS7z 0BP0oGKWO0c8VFIxJx1pEsYTk9abn581QrlTWYL+6sobaxuVtTcSsHfJ3NhVwBj/AHjVA/Da 2tbF7/V7uaZV4O5tufw5P617uGX7pHh4l3qMyIL/AEJIma7O2KJRHa2gjLkDqzHPHJPr2NV1 1mCVwbLTXY9mlIUfpmtXucxeS71Ip880NqhHSJQT+Zz/ACpNP0u48RXZttPtLzWLkH/VWcLT t9SFGB+lJopM+rB8O9S/aN+Gen6X4yhj8MfEbQolt9I1rUp0C6pZj7tvclSSrr/C7Dn65J42 7/Yr1fwnGX8Qw+ItQA5aPQdLaSM+wlAfP1wKtx5tSE7aFGTwLofh/Edt8N9QyvJn1yKQsfqr AgfhiseTVtbeT7Pp+mywjotrpGnkn8Nqk/rWfLJ7I0uieH4OfFXxgwlsfhxr8oPIudYia2TH rumKAfnW/wCCPgT4t8I+LtP1PxPrnhPw8NPZ7s2EmtRzXWUVm3COAvkKRubPQBj2rGvRk6Mu bTRndgKi+t0ra+8vzMKH4UfDvSnMmq/FCS+mHzPHonhtyvuRLO6Z+u2nNZ/BaAlH1/x7eMo+ b7PbafEP1DYH1rX3Ph3MXTqtObVkZWoePPgroR2Wfh3xfr9wDxJfapbwAfjHDx+H51ztx8Yv DNs4Ph74YeHtNYDAn1aWfVZcdekz7O/9ytbJbHK2Y/ij4u+LvFlj9gvfEV1HpY4XTbLba2ij 0EUQVAPwrgprS3Ykklj65NFg5uhUe1hU8cj601Y4F6qPoTSC5egvYbdQFiUY6HGad/awQ7gi A+yjNZ8pVx7+J7hBtR2Ax0BxUmiapJe6xGZW3bQSC3PPanaxO56BpEm3U4OuGJXj6VozgW00 q9BnNcMTvmjK1t83VtNwCFHPrj/Ir3D4IaiUvLZWKAJLn5jgYFerh+h5lY9G/aUje7OjXhj2 PNayRsgOSu1s9f8AgdfEviGFY5DlfnDEZ/GorfGyqT90pR48gH+7zxX6If8ABHjRkn+IXj3V mAMltpUFsje0s24/+iRUx2bNJH6oUwn56zM2KzBVyelc14pn82AbRkA8mtILqc9WWljjpWzx 6VEWwOtQ9znRHnkc01zx15qWWNL4FRtMO9ZsohkbrTe2agohk6EVUf5RyaTKKzPg9e9MdxgH NSCInkwDzk1F5mDx9aYEkcpxT/MqGUhpcnvUbP71BZEWGc4qOR8r3JHpUMZTlP4Vn3BAP0zQ gKMrBSQBn2HrVSdfkwTjPVQenTpTApbCMjHTvmq0gCep5ziqGQO/zHb8uOfwqKaRSw559KBg ZMDHHTv2pnm8np75pDE3mXBzyOMCo3AySeFBrGTsUkRxxorFcjb2J6GpCQDyDgDOP8/hWDdy yLeeoznOOP5VDcnccjpnnHc04oTK0gAyO4/HFQNsGChzxwDW5IjP2Ix2qCYkkA8c81F9Shi/ M5JOVFSpIqk8fLUtXGhlywkwU/Gqc1v/ABE1C0LGLARgfhxTxFkj+ZptgW7W1BIPUVX1Ww3p lRmuOOjNTnr3TS0RKjBFc3LabJGVuor0KUrqxnezKt1ZqF46+op2la1qvh6bztLv7rT5M53W 0zRk/XB5rqhOVN80HZlcyatJXPRdI/ad8YaZYCy1A2+rQKCA08e2Qf8AAlxnr3Brz6x8TWqT YlDRg9wM0Y2rUxijzbo78FOnh+ZLqeA+INN1JvE+oXUlpMIJLuaSOTbldm9ivI9sVjOm0elc LVjtunsU52wxUnk9BUoj2qM9qT2IW4zuaMHNSUKeFzUf8JPamhMby3SlKYpiON+IuqyWd1Y2 iPhTD52FOCGLsuc/RRXNnXrm8geOWYuXxuZzliB0Ga9yg2qaPDxH8RlrT1aUqI4UdyPvyOMV 3uh/D46qhkvfENvaQqASljbtM/PbnAz+Nb8yZzWOkj8J+AvDl4HnivfEMqYO/UrtbeAn/cAy R7E1ux/Gm00KD7Np95pui2x5MOmxF1AxjAGCB+GKlsZg678e4tStzEzXmoEDaC7+TG3uVHWu Wj/aD8X6JhdG8SX+gwrwsVheSRj8g2M09x7nX6L+0z8dWt1e08aa6tsfuz3lwAmPXMgJP4Zq 3qH7SfxauYtmpfFnVIuxSxnKk/8AAht/lSdZrRM7aeAc17SfurzOF1zxzca/Nv1fXtd8Rv6X 9/LICfxatfwFqMttH4hu7fT4dMhttIuCsrIFJL7YRknk/wCtrkxCqSpvm8vzPWwM8NQrr2fv NX19E2cFeXsTMXku5tQkzny4iUj/ABPB/Ks+6uLu/wAxriCJv+WUXCiu1RS2PAqVZVHeTKp0 ZkGWJz35pU08Nng8e9WYCmxVWxz+ZqM2KZ7/AJ0wGmyQnnpTGsozUMYfY4wp4yc9M0fZ07qP pUDIJolAPFSeHSP7cgQnAY7eKAPSUP2e+iI4w4J/OrGrahHbSsXcHB5FcED0ai6lTUZ1vLGO WMhkU4z9a9R+Dl4ItStzI2QCrH8v/wBVenh3seZVVz3v43lNW8J6ReLsLrIVG0YJDLnP6Cvi LxlZtFf3ahTxKxxj15p1laZFH4Tvfh/4O8Oaj4Zs7i9sJ7i6lDbyZyq5DEdAPTFfcv8AwSwt rPQviD8RNPtYlgil02ynVMkniSQHn6mtHCKhoDm7u5+jvmio2lBlTt1rlsyOdMLhxs64ArHu fLnRkYEg+1b00c1R+8chqNo1tI428Dn8Kz2Py8VnONnYlEG45+lNMhOSTWbNERuxJ6/lTCc1 myxjsevpUZkHrWTKQxmAOQarSsGUHtSGUJnPJ6YqJgWUHFKwDQvAprsAfl6CgBVJwKUSY6dK hlITzN3ekbpzzWTNLETnHNRu5Pp/jSKK82QAepx/n9az5X2HpwQccdf8f/1UIRQm2huB8vpn rVKSbDbQMZHUnr/n/GqGUpGILKW3HOePaq7krnPOR9e1MCrJlELDPv8A41XkfaWJ+U9/pQAz zDkgYHGc0xnBBwTgnPHHNIYiSsrMmMDqeO9PYs42hz68H/Pb8qymikNd9uSQVycZI7/571B9 oKgAf6wHOPb0/lWKRZG8uzAzjGR8vr3ppk25Y5AI5HXtzVolkQJi3AHOeD71G+7g7cL61dwE UBsN1A/z/SknAZMgHOc4B6GsnuUinG/LHtnNPIIPpTAcF3DpSbd2Mev4VjNmkRCAi5x2zTFc ZA6fWktUNrUv2ahlbHr1HpU1xD5kRArl2ZoYclvkMMY9q5zWbBY8SAYwcE120XqYsyWhDrjF U5bX5iCOldhJSaPnB4NQz2iuMbQfenYaZTbT+4JrN1Lwxa6kP9JtI5WPR9uG/Mc1LinudEK0 oHK6j8NYd5e2keMgYxIu4fnxXO3/AIJ1S2J2RLOvrG39Dg1jKD6HoQqwlsYNzaT2UxjuIXhk /uupUn86jJK1ize/UYzZ9qTbuUD0pIA4H4U4e/WmSeU/EG/WTxPcoeViREH/AHyCf1JrAtZg 86gAhc9TXu01aCPBqu82dGNatdPdZHIMnXagwSfp0FV77x5fTxtHFI9vbn+BHPP1q4rQzZjn U5Lhjl2JPYmr2k6FrevyiPT9NmnJONyodo/4EeBTbUVdmtKjUryUKSuzr4vhemmRibxR4gg0 9BybW1bzJT7Z+6v604+LfC/hYBPDujpdXA6Xt9+8cH1GeF/AVzc06ztHRdz6N4bD5XHmxD5q vZbL1KN9e694hJuNQu/ssLc5mbZn6KOSPfGKzXGl2JJLzX7jqQPLT+prsjFQVkfOV688RLmm yVfEE6x7LRIrRD1MS/Mf+BHmus8JKy+DPGd3K7SPNBbWW52znfcLL/KA1jX+Feq/NG+B0qt/ 3Z/+kswLe0LnsBWgsCRL0Ga6TgKlywxtxiqbOq4oEQu2T6ComfBqgQxiD2prMAMd6zYxpOO1 Rux9akZUnbI9RSaLk6xbbCchxgipexpBXaR6VeMySA9/51eKR/bjOqh0kjD5PIz0ripHZU2J 9ZWGTS2USK0sZBKL1AIP/wBat/4Z3gj1HT92SNw3AHsDXo0tJI82fU+oPG7pqvwuV4nZvIkj JUj7uOM/TDCvkfxjYxDxBJEzhDKylXJwASO/tmtMR8RlS2Or8KXcWl2FrDeCZriSb7PDbxAF 3kJ6cnAHPX3FfV37A2qS+FP2lr7R7u1ms7u90ee0kgmZTh1kSZSCOGGFfBFarWKJn1R+lZmY 01pSNhJ4BrFo44uzJ7lkYFSD069qzJSD93rV0xTepkavB5idRuFc06lWwc0qi1uOLIGiIzzx 16VGeD1rmaN0Mf8AH8qbwKzZSGthh7VWcEAgcVkykV5WZVzkY96qTOScA5HrUgV2POTwtRee ASQcdqYyNpuw4X65/Ck8zDBeueaQxrS4PXj3PSnLJuGDUMpC5wuaTzCy1m0WMdiagY5frjvz UFDHkBU85qjONw4wDjH1oQGVN8rkE/NnPFUpx8xAOTj0/wA+lUBTm+6efm6/hULMH257ckA/ 1pjIpSFXjGR68VUmTzcqfmxz75x/npSuBHLFgHJIGcYIwB/nFRSDBIA9ueOaAI8tGoJPJ46d PUVE0rLwpOeuQf60migE++IAkkt39PSoJWZZMjkEnBHU1nawxkjkcnnIzgdD/nNP80enAwSB UN2GCkE7W5ORkjjmmysfu9ulJDIdzo55+XoRmkmK7Pl4U+vPbmqaAgj29RgketLuz1P/AOqo GOjf/IpQ4IGMDH/68VlJXNIsdIqlcdgOvpUOFz+FStBsvWB7DjPTirpHy5zwa5XuadDJuExI 36Vi63a+ZZyYGSOc/j/hXXSeqMZHOrHj8fWmyxqnPc813kGZLDlifU8Uww5+tMBFteBxUclt sJxwevtQMhaEt15zULaasgxtAFArlG78PW95HskjV1/uuAR+tcvqXwuspgzwZgY9lPFTKCkd MMRKG+xymo/DXUbU/umSQejcVh33hzU9MUtPZyhP+eijco/EZFYSptbHfCtGZm4OMmnJjPNZ M2voeJ+IT9u8QajKGG1riTafbccfpiq0Voe0gX3Ar34u0UeG4c0nqWbfRoppMPNIzH0Fbdt4 e02CNnmjuJFUcgsBSbm/hR1U6WGWtWX3E1n4l0TTG3af4ejnmHR7nL8+vOasXnjXxZrqeTCW socAeXEojUCpVLmd5u52PMlQg6eEjy369THk0VN/n6pqXmvnJigO8/8AfR4FPGsWmmDGnWix uP8AltJ8z/XJ6fhXQrLQ8OUpTfNJ3Zl3WoT30pkmlaRj1JNIvKjmqILlqmwcmvRdIBj+G8kK qzNqGrIPlXOfIhPH/kxWFXaK81/md2E0dSXaL/HT9SD7Atgublwp/wCecZBP4np/OvQPhv8A BTxF8R7eXULO2i0zSUX5L2/jLCY9hGn8Q9W4H1PFTVrKmjGNO+5w/ijwr4p8M3c8EunQXQtz hnt7VJBgHrjbkj3/ADri/wC3pujWtqSPWADH5VpGfMrmUlZlmz8WPZHjSdMmHpNAXz+ZrXtv F2kaowi1Pwtbwq3H2nT98bL77c4IrRMSNNfh3bXRW4guZVtZcFFYDcQff/63ai7+Fssbv5cs hjQ7chQx+vB/pV8t9SXozNn8IadZPtu9RdDkjhQDkdeDVY6DoJHN/dfguP8A2U1LQ1q9SaPw 94SZBvvdSZz2VBj9Vqay0fwlY3Sz276jKydDIgx0/nS5bqzL5uSXu6l3U12rkdM4rP8AD18J br7LO+1UyBn61wUtjqqs6meOGfT7hhHHvCYyDyQKd4Fuzb3cJUfMsoz9Dj/69d1PdHDPY+u0 uoNY+HuqRtKDci13iPPdSD/Svk34n2iJqaS7cM0fX1IPP8xW9fdHPTLPhy9uNc0qNEuI0urN 1aObaHPQjDc+w59hXvn7MfxGvLf9pX4Zrd2EVs8d02nS3KjBk82F0TcdxycsMU4XUV5lySdz 9dmjAHIqvNxn061CPPW5bMRmtgPUdapjS5W6sFFEZqKKcGyGbR3YMM59DXO6npZtySV/HFW5 KSJSaMh4Qcjnmq7QgE56j0rnaNkQzLkYFQNESevI6jrWLRoiMoQxOPwpCpIzipaGU5lz0NU3 45Hp1zUNDKlwSBgg8etUCfz6c0WAXIHGRxxUBLFgd3PWpLBnznHPf/P4VJBIx68Coew0TM+B ntTDJx71iaIi80nkZ9aYXDDnkmpZRDKSAT19QKqzTYUheM9f8/5/SpuBnXCiQg5+XrxVORCO AQW7ZPX/AD/nrWgFaYlCFcZyO/XPr/n39KhbKAAHjk7ce+f8/hUXArMoEoRkBHBwcjJ4z7/5 96rxLtY4OMHrj2z/AENFygkkMq5X5hzjPHPp/KoMAdQMjgY6j/P5U0FiGXCqAcYJwfaq8xVR 0yT0wKYEKtnGeuc+4PrUhUsq44x3x0/z6VEhiMi/KuRkDBpBGUAYDGO4HH+feudl2Ip05XJw R8uM8VBJlueT2/CqQiNSEwSd2eKGniZduCw6jn+v4VdxFdmXb02Hpjr/AJ70iklSzH/H6VBY huGKnHAHelgmG8knmpKWha378Zxj601kDdK529TQW1mEdxt5IHFaob9yxzk1lL4iuhRuQW+a qF5GJomXpkEVtTepnI42QBSfQGmMoY9enHrXokEbQj3OfWoJY1TpxTAYrHoABUqLuUA9RQhE U1upPyn8qYsXIwKYrDWhFQyQEj0HvQhET2okGDgn3qBtNVDkZVh3U4xTDYx9W8I2eqEm4tYZ HI+/5e1/ruXBP4muO1T4YCPL2kkiEHIWTDD+h/nUuCkzphiHFWZ8+a/8DvFujyu4tEv0JJL2 z5P/AHycGuUn0LUNOl8u4t5raTONsyFP516MZI5bNsbDDeRtkH8QavR+eU/eSy5+mavmQ/ZT fQbHNfrnbMir6Ef/AFqVlvZ1O+6RvbcQKHJdy/YVH0JNJ8Fa1rsxh0yzn1G4z0tkeQj64FdP afBDxa0ohu3s9NbtHdXIMv8A36TdJ/47S9ojOUHHRnSD9nrxFb2/myXxVcZMjaPfeX/319n/ AKVyOp+EvEGi3LqLaDUo0zmWxUTAf7wA3J/wICkqiZNmS+HdL1rXWYrp0VtaxnElzNAQo9gP 4j7D2zjrXqeraNc2ngTw5ZWFlNKZZLq7d0hwDuZIuo6f6jpn88VFXVwt3/Rnp4SDVOtL+6v/ AEqJ3H7O3wj8P654ka+8azQ/uHAtNHmYYmf++/ZgOy9+/HB98/aV1248BeCZ5NLKQ+XbPIyK 3l7UG2NQCB/fkXpjO0gEda5HH2ldRktEYq6TkfFOlfETVLvxTc6jJeS3GIl4lkLb3yMnH4np 2A9K9ftvAHhn4xWJLKdG1hhzeWgAJPq69G/n71nOo6LTM3DmueUfEH9m/wCIXgyG4vbSFvEG kwgu1zpo3Oq+rR/eH4ZFeMrqF9czrBH57yk7RGoJYn6CvQpVY1VzROeUHFn3l4O/Yu+IVx4G 0K4hgsbyU2MVw8JugjR7/m2neFGQXx161geKPgH8Q/CUrf2n4S1OMMSRLDCZYzjvuTI9O9eu qd1dM59bc1tDwbx3ol7F4ilgvLKa3nQIDDLGVYZXIOCO4IrFXwxfSsRHY3LHP8MTH+lcM9Ga I0LHwDqztuOk37g9xbOcfpW/bfCrXbyJlXQ9RR8ZXFo/P14ougsYOowbxgdDzWRbutvM0S4Z 9xJPcV5tI76qN60jcI2/o69PTiofDE/2fUGGejA5/P8Axrug9ThkfXPgPTP7T0+4mldZFTTt yxR8NIWJVvyBH5187fEzS57xbEwRPPOzmNY41LM5I6ADk9K6q2trHNS0ueg/AH9kj4h63PdX N9pi+H9PudjJNqTbXIGcnyh83f8AiAr7U+F/7HnhTwjrGn67e3txrGtWc0VzDI58uOKWNtyM qA9QfUnpXVCm4QSkiJ1NfdPtSEedCj5yGUGnfZ1JGetedexny6j7JdqFD/CcVLJxWb3On7JC 5zWdqEJmUjA5HFbROR7nNXWlsuW28VkXUGw9Mf0oaKRUaMgHFRFSR93HvisZGiIZAwx6jt61 GwweBkelZoZTuF6dves2QlXI647f5/z+VSwKtySV+907CqDkkZC5xwakZE7FACV6+/NNMu5i AOxJz3qShvK4ODzTi7Db9KTLRIJMjB5pjSZO0da52WIHGDUbP9fp/n/P5VmURswfGD16/wD6 v89qimVR/ET356VLYzOugSWwevH4/j7/AOeKqSDbGWTG4H3zx/if5iqvoBVcjywWGM+nfj/6 /Tr+dQeaGU8ZIOfm79e/+e9ICCSQMUwCX7rjn/OT/nFUrx1VWVcHr1+v+elNIZBHIwz1I4xn /P0qKSZhjngdh0FWMrH73UE/Xt7f5xSlSXYY+b+E/wAqAGpDl93BPYjuf8/jUxbGcH64/nWT GivK4zkYwMHJ+vT/AOtUzSbj827yyemP8/n9ayaLIWgJZSo47nPT/OaidCDnHy+uKYWKRfe2 0jd65HH+cmq0shyQBjjINMQLhQMde57f560151jYDgsc9e1IpERkOSBxuFSR9cdfSobKRYWR ShBOBjgikkmYADoT61g1qWMjfa4Y+ucity2fdHjrmsZ7opbFecja+Kz5iChNa03qZyONuVCz SqRjDEYqEPgf1r0kKxHvL5yePQ0xkyc0wsN2gHI4x+ZqQNkZHFMVhSARTSvei4hj5OR+tMZc A+tMkhZCh60bhnGKYWHiIMM9femmFAMnj60EFaewSTICqf61l3/ha1v4GjmgjlRuqOoYGquC bi7o4PWvgboWoBnS1+yPn79sdn6dP0rgdd/Z8vYSzafqCSjtHOhX8MjP8qpM9Cji+XSa0OG1 X4Z+ItHyZ9MldB/HB+8H14/rVzwR8ObnxNqAja2uJyMYtYMK593Y8Rr7nJPYc5p36npVMRBU +aDuz7E+HPwNNrpdtBq9ybbTwQRo+ls0MJ9fMfPmSE+pI+le3+G/DGmaIq2WjaZb6dDxkW8Q QH3OOp9zXBUquWi2PGtrd7nXalLZ6VpMjzsuFXqT1NfLHxautP8AG2pLaaZpkM+owS/NqvKN bYIyFdcEt2xnA9+ca4SnKpUSiK1zrvhZ+zvbeLLC61/xNqa2Oixk+deXChmlbIyqKTjjOMnP JwAeQOtvPhDoPjrSNTg8Jakuo3unyfZ7OG6bymeFQCGHyjcGZm5wBkjkCvWxNGTnTcPsv/gH sYDFUqFKvCrG6kkvnvf70jwfw7pWn6j8SdE0O62rOb1DLCzgOUjO9/lzkYVT2yMe1H7ZPica lHLbW0xmWaK3tREpyN+9pifrt2fpXK5L278kzhf8P1aPI/hj8E/FOv2wuLLw/c3UeMvIm3A5 7kn3r03TNObwjqS2F9Nb6ZOuA6POhf8AQmvLlzVpPl1BLlR774Y8VaVotikVzexLKw+6XGTT NN8OeE9X8QSalpWn2D6tMQJZ4bdGkcf7RAz+ZrlhKUZWiJpNan0/q+n291oNtptwIxbXt9b2 zCSURLtXdKfmIIHEfpVbw94WsvCFpqWmWD3TWsV+2z7XKJGx5UXQjjGS2O/rX2/InVUuqO+O Jq08jlhrLlk+bbW6klo/Rar0Pj39qTV4ZfizqagmSSBhAFHby1WP/wBkry/T5mYiRupP3a4a r99nzy2O18PybyuQAD613+k4IjIHJqYjPhrUrZkkeNu3Fcg7iDUnDHgjNcdHU7amx0Wjyz3E 8eXH2bZgcchvf2plqPsutyRtjcpKnHTj/wDVXbE4ZH0R4T0i/wDFGl2l5psMm2OJYvMjm8t4 m7sMnnJx09K2vA3xjf8AZv8AFl/rWo+H7bxNKbaXT3gnk2CNmdCZFba3IKY6chjXU7w945la XumL4v8A2/dY1a6nXTdCOno/RHviyKM+gUfzrsPhJ+078TIoYdaWz0ePTTIwRrpZnaXH3toD 84OByRWSrTT5ma+xjax+l3wJ+JC/Fb4YaP4hMSwTzK8U8KAgRyoxVgASTjjIz2Ir0DOKl66n M1yuwIdk3+8P1p8hBHvUmn2SBjmonXcMd60WhykE1gJhnnNZN5oBlViqkHuKq9zRRMS90toO QMrWW8JTIII+tZyHYgkh2rnvUDDK4GBmswM24DDPHX1rNuflOcgkGoY0VbjG0Z+Y56/5/GqE rYPfkA8cYqGUVLi46DGB2Aqr5jq/I6dD/wDrqSkOW4K8/ez6nOalExIGeP6ikUhvn4YAH/69 NM2OnPvXPItDGl56/KO3+fwpDKQCT8pHoe1ZFBuCk/Lg/wCe5qEDDHnnPQdfb/P+FQykV5tm CmMYHr/n/P1qhMflbZyv90HoPr+f61aQmUJJijYznHJB6/5/z2qB5MH3HGf/AK3+e1VYZTml 3dSFwMkHp/nr/k1S+ZnY4BHbJ754/wA/4UxjmPqMdxkcE01o9r455547etFwIvKCkA89j7U5 lMR68DIqbgBwzeh688AU0tznbn61I0R29r50hBBBHI28f5/znrW3Z6JLdNsVCQT3H+ewrGTS 3NIq5pz+B722iXdEylucsOf881kan4duLGImVR7cjj/OKxVVSZo4NHI3MRVsYJzwVqFSSSTj aO1dBkRGXMf49exqucl8nqfXrQMBI7NxywGenX/PFTDPXOfT6VnuWP37WA46U8gYDevNZS0R QgYKSeqnpWpp05eMrjPbisJLqWOuBh3HrWS7HbVwepDOa1lcXbEcZUE1mjr9a9KOxIE9+tN3 c8mqAYevFKGwOvFMBRJzjOfpTvvd6ZNg7Gjy8nHSgljJIOcCoWjwM0wBHwMChuVGB+FMmwi/ KOlOX5u34UyRHhVjTDYJJwRn2NBNiCXRo2wdtVrXT5tMnM1lIYJfUAc/X8qN9GF3E6fTPiJr GmMpubeG9UdSQUY/iOP0ruNH+NulJFsuLG4s5u7YDr+Ywf0rnlR6xNVUvuc54i8a3PjTURb2 bhLZeArNgt74rNj0SPSdluyxRIB0XAH09hXo5fL2c3GXU3unoj2E6Dd+NvhDpdn4fj+2T6U5 M+nRsqu5O8gjcQATkkZIzub0wcz4EeDvEuj3Nx4y8ZaafBOkaek6NbXsytLKCNisxHRec9sn aAGzXpVJ20RlzWTR4FPbWNv438Q+M9PgWw1PV767uFmk/wCWEczszY7LhWIJPbPrXBeHvBGu fG7x95dmkstlGy3FzO6bY7cHhA7Y+/5YQY744HU180puftJ99PxPRkuVRifSnjzxNpfwA+HB gicO6JsRG+9NJjqQPftXwusmq6v4ln8Q3Fz5t/PN57j0yc4H0HH0FaYecaTuTNXie9+E7jw3 /wAJNHdaiDJPPBHJHA8n7lAy8nZ3OQeuRjHFfTfw+ltLzV9Mhs5Y/LMinyo0AGOp4FXVhH61 Zd0c0pNQZ75qpjMuhwS6PLrMPm3F08MUSSlAkaxh9jEA8zY9ec1B4Yt4Z7eExW62kU91NiBY PJCjz3UfJk7ThRkV9NHWpt/Wh6Fbmjk9P95dNr3b7O89bedtz89/i1q51/4ka1e5J865dwSf 7zFv/ZqyLE4ZQWBx6V5VR+8zxrHZ+H+q/XHNeiaJE7KCRwO/rVRRLPiq9UXk7NjaWHT0Ned6 3GYdRXJxkH+dcVDc66mx0ehXUC2qOZQpU8r3ougF1zKfMrtkH1z/APrrtRxyPoD4R6zex6NB awMWy+Ah6KAMn6//AF6qfGyyGdYGfMZlWU/UqGP65rsqa00csPjPmC4OJyQfm+6fUV+pv/BN LRtG8a/A64tdW0+31EWOrzoi3CBtoaOF+M9OS1YUldu/Y6pbXR9u+E9G0zwreXWkaVapZWhR blYYxhQxJDY/IV04+lEtzke42Xja4/hP6VK4yKzH0IGU54p0cYJ5FV0MYxu7ExTAxTdo6D8a m502sUrqyWVCpUc+1c9qXh9oQXUZBPbtTJaMG7tCmQQfSsyeDIOOmaVjJmZcfJnIOKyrrMhY A5bsR/n3rNoZTlJK4H3j0H8qzZ2IySPwqCilcqSB36//AF6qOWlYkkZAI9P8/wCfSpZSImuM blHA46dqPtDvIuMH2FSxoRmKPkYAPOak83ao/X6VzyNERvLx15Pf/wDV/nrR55A6bj/nP+fp xWJYhcheOg9P8/5x703z1CkZGD69P89f1p2ApXE5bjd8o6c/r/n+lUGuWDc9DyM9B/njp7Va ArSuP7wJyQOevWot7ZyoGAOrUDKcrgMQnQnGSBTFxwThgM5HQY/w/wA96l6IY53Xdk5APbOe P8/qaZLJlOCMdTnv/nj8qi4yu43KWyVbOctTDMGOSecfe9PWmArOM8Ennkjp/wDq5q3bWzXs gWP7uQQuByP/ANQqW7FJXO80PwSkUKTXMirHnkkHr/8ArFdE0lnoOAsaEMAWyOQOMEe/X868 yc3N2OyKUUYfiTxsGDCMBcqUCr2zxn/69cJqmvPdFizZJ/OtKcLakSlc5W+l3nPTjt3qk0oV SAuVbj6V2IwEL7Bgjhf881Ud84wNo9h0/wA80wJUVnIZRlsdD1BPanohG8tgHPY96zehaRJH b7gcdMDFXE06e4UhELnGMKpzispGqRbi8H6rPGXSzmZTyMIef0p9tYS2LFJkaOQdQ3BrnlJP RGnK46snukXAYZB71jTxjJwMYNaQ3MmjndYRRMMYzisZ0BYY4Ar0Y7GYxk7jp0oWPK8nFWAj DAwecVGwY4H40wGfdbP51KrEE4+lAh2/npT92D70CY5ju54qrIeveqQhgHNOJGKZIgGcHtTs DGc8imA7BYAgnFSIwRsEg/WggFyO+aURq3NIGP8AswcYA4PtQdKjYYZBTIIJfD0TNwCp7Gpr fThAVL3NzuAwNjA4/OqTs7hdrVBp66v4OvG1Tw1q93a3nWSTzCsjj0Y5Icexrn9f8TeMfiZc XOk+NPFV3/Ystws0chXcIEVCeI0CgtvAAJ6ZzmlKUuVqLNYTXMnI6nTLz4f3WqQaFfafd32l 3tvs+03ErxSIWypRwhHBHpjrXtssOgfDfwbI2niLS9NgUyBYsYY92YnlmPqSTXlOUo+6enH3 7M/PD44fFu7+Kfi9lSU/2fbORCrHgnPWszQ1ntRG7ssy45CnkfSuxQ5Uk9xS1NW+uZf+Ejkh RgWt0SHg8ghRkfnmvr/9k3Rr+fWra8vJX8uKNnVCDg/KR1/Kul+9il6nHUdoM9U+Jnj7V9C8 XK2m6gypBEyR7QGVVcKHXnjkrk/h6VF8PfjLqM0EWn3NpAyQW0xW4UkMAiMQzZzk5GSfevr1 SinzdTzZYurKiqDfupr8L/5s+JJvEKa344ayCMv2m4CLID93JABI78VkDx/b6XqE0D28k4ik KFgwXODivn5w6nWpXO60b4hM1jFLZ2SxNIAQZW3EZ/Ktf/hK9Wv8pLfS7D/Ah2r9MChEnht5 +7dvlwwJGPpXAeL7TzpopcgMcniuClozumtC5cWcP2W0aEKpdBuRfX/OaZcS8W8gOWUbc+4/ yK7IbnLUWh7r8GLwL56uWwh3Da2CMiul+KenRyy7YwSstoCSRxkFgf6V3y1pnCvjPknVltod UjjQlWJ/eD05r9Mf+CTGqj+xfHOlDlYbu2uF5/56RyKf/RQrCl8XyOmXwn3BPrD2PxDAfAhM UcZJOMA9/wAzXehhjrxV1I2szlkMdhsbHPFOtZRJApz0GDWVhRY7IzzUiYHSoLi1cGIqs8vl sTnNUlcbZBLdNhuPwFV5LsyIQQT7VfKQ2ZF/EkwbI+b1rnru1K5xxT5WQ2Yl7bnk5wpGCKxr iLgjAz2Hc1k0CKFxBxnoT0/z+dZ9xFlxn5ffPSsmiypMu5SCB145rOuYyHyw69sdagpFCVNm 7OPmHBPOf88/l70qFVQ4OD271mykOViwA4yTwO/+cUrNuQbj82Px/wA8VhJGiGeZtIydxxn/ AD/n8aYZ8YXB3DjJ55/z/k1gUMkn25O4DJ6D16Z/zioXmG0BV+8e2ePT0P8AkVaArTcy9uuM D/PtVeQEAk/Kc885z9ff/wCvVDRWkQFgM9OuR14z/UfpTGYqqseeccHjikMikhMuex/z/n86 qlm3ErjCjoeOOOn+fSoYyNz5rFu5PUD/AD/nmoXPlZLdT0qRle5uNqbguQB1J/zxUMc+7J3b hjPI4+tUIa1x1Qt+8J6kf59KvaP4im0yZZIyOnU9ff8ATFS1dWKTs7nTp8Sroxbd4w3DcZ7+ tYV54rluy5aXPOePaueNNRNXO5l3GqySRseh9c1QF/g4yWbHX0+laWJZVluWLEnt7H/P/wCu q7uXcZYHJ4IHT/PNNCE3knqCcdD2/wA8VL5Q8pd4BI5H+fp/Omxo0dL0i41KULDFvBPsO/T9 TXY2HgG1SMNqN9FbdyM5bNctSdtEdNOCerNe3vPBGgxhDDLqU+0nP3V6/wD16r3Pxet7FWTS dMtbQcDdsDMB9ax9nKesmdDnGPwo5zVPihq+oRkG9kVTn5UO0H8BWNZ6o9y7u5LEnJLHmplB RWhk5OT1LU1wXjPYZxWXcA7s9j61pDdGUjIubCa/1BIII2llkOFRByayr2xktJpIpV2yRsVZ SehB5r0ItbE20Kakd+lPKDB5xWhJGxABHWmMDtOO9UBEff8AKjOKQgYZx2pYwcjuaYtyUEAY qKRd2cdqYrEByDTsk4piAZHelzweaYgEhUYxkU3JJoRNh3nbO/NAuCDyaoC7a3IJA7e9aKSA NnrSJNQpay2zO+4TEjbtwF9+Kz5kEZ6YBpEsgm2DOOeOlU5rNLgY2gk+ooIKLaLGJMkANkYN SeJtBu/GuiNpN7fXktoRgIszDFPljJq5cKkoapnk+o/so3du4l0e/wDNH/PK4AJH/Ahj+VY8 vws8S+F2ae+0maSC3BkLQL5m7HOBjn9O9aKHvJnTCuno9zA8L2kraos9yhEs7GRt687s8198 /s12hj0xrgrtCx4Hp2qcP72JjfuKvpBnMeP9Qxrl0pIZYhww7nGTVDw5IbLQfE1/jH2bR5tp 9GbCj+Zr7VnhdT5H8ITbviTZuxyFlZvyUn+lcnPaSX+v3MCnLPO55PbJNfOTklFtnqrc6Twp Z3sd3LAbmVTFjjJxz7V6lYI62yO64YcN9a5KM+e7Q5Kx53470STQPGGt2DqUezvZYGB9Vcg/ yrzrxFBvmUDrkmuSi7s9Ca0M37IYUyXHH6UvmK9owU52SE5Hv/8Aqruhuck9j074X60LOdQG GXQNjHHH+TXqfiktd2VpM05kBV1LZ69CMV3X9yxw/bPk/wAZ232TxRLg5+c8/jX3x/wSc1Qx +OvGVjuAM2nQXGP9yUr/AO1RWVL4kdD+Fn3r46gJ8ZWBEhjFxGgO0ckhj/8AWr0S1vmnt0Yn 5uh+tddRe4mcchbf/REKJkqSSdxycmrNk52sg4PUVyszQ83JV9rjbU6yIy5Vs/SpGRtMcEVB JI2OO1WkJMiLfNzVd5AGIxj2qkWypPhs8c1UeEMDn8K0RLMm+skP8PXmucurAozbBg4rGcRp mVcWjB+G5I6+/wDn+dZ9zbEg8YGe3+faudotFOS1ZUwq7jjPNZlxEQMnl+vHB9KzaKRRkQFm xwR361WDGMnYODwdv5Cs2WiFQWfaBgLkH0/H8KWSUEEM2CDz3rCSLRBvOT9498D8/wAKegLl c4DDkelc7LQwwAlgTkYxjjn/AD/nrTwrMAM7CR0/T/H9adyitNGEKlckEE1XnQk/MMjBzu/P +n+c07hYqzR5PIJ9eefeq6KAHBODz0/z70hjGYRggZfAxTUT92xbDDoQaTGQPguSMHnjmqc2 zhjk46gjr/n/ABqQKN1yCT1A7g8+tVYpSGKjAIB2k96oQycHcORk9/bt+maqyTGGMlsZORjs T/nAoGRm7d0CjCfNnIPp/wDrPvSRzjaQu1s8+gP/ANakMleclcYJAHXHA71VZyrZ6DODkjH+ cmoKIp7nYgUfL05PXH+cVWEpLHcxXIxnPTGe/wCf50JAPMjK3I5wePQ5/wAT+lOF+xjUDBUd Pp2H6AUDRZs9bubJgI5HRs4JDfgf6/nUj+IZpifnY54Jzn/PesmtbmibsQT3rNjkDB6mmLck gg9/XtQUM83nP8quafNiTJJORx6VhU2KRtRyCSFjzwKo3Umxjx+BqKfQTMTVLlo5QyNsfqCD 0rJluWkJLNn1JNelHYkgY56dTTVZuQevrViF2gKT09qTfnHFADZJFPIAX6VFnacZ/OmgJNwx SBsUEioc+wNOk6UwISvfOTSD0NMQp6EikJNMTG96coO3AoEIyZ9zUJHHT8qaJsT28gB5GDWh FNwcGncVhXu2Ufe98elNXUwMB1zyD17d/wClIka93v2hRxjGfX/Oakik3L1/xzQS0TLIGwOw 9acJihyOPpTTIsXNM12ZZJgX3KHwM844HFdHp2vxklWGSe9bRZnIi1nw34f8TKHvLG3aZTlZ lULID65HNdz8Ode0/wAK2402ZljQqRHIzcOACTn34rroxj7aMyHUk4OB5Nrt42oXF3Ox5lY9 O2TV3VroaX8GvG13081IbVfxbJ/SvpJbNnJH4kfIfguYHxSbkn/UxySAHvxj+tReF7RtQ8Ww nYD5krZY9FOCdx+nWvlsSnOhNLezPXi7STZ7R4b03R7hteuYbuxnuIPIiSIOplyS5YheuAFw T6kDvW7/AGQB4aN24wZrpLeIj+I7WLD8Mp/30K8XJ41VCftU1r19EaV3G6scl+17oLeFP2if HtkF2xNqb3CD/ZlAlB/8fr5812ff5ZVvnVq66K1OuTvFMyLqYmPBO7IqvZS4S4Q55Ab8v/11 6EdDkkdl4J1NYrm3QrknI4GSMHP9a9aS4MsAQOXUHOD2yO1dad4nI1qeAfE6Ew+IZGwOHIyO +eea+s/+CX+rCw+PDQhsfbdHuIPqQ0cg/wDRZrOnpNG3Rn6heJLWNdX0u6dN7R71Unt0/wDr 1t6Vc+YGX+EjcM/XFdtX4DkauaijdU8YMZBArguQkTTwiUZxzWZKTbvhWIz6GpvZlWBNQZQQ 4z709tTj2YCEnGDVc4lEh+2ZByD+NQS3BY9MCmplcpA0maTdu6fnWsZ3IcSGWIOvzdDWTe6V uY4I59K0krkozxpMbMA4BxSz6PEqBsDOfu4rLlKuZt3YQKo8xdvfGeCa5LU4V+YKvyqT9c9K ykkUjFnjWJjtPBJIz+X+P61SlhBcjAbd90dh/n2rmkjUgEZjPzDO7gfT/P8ASoJEYynOBx+H v/SsJFoWG3ffgDLHgZ6100PhO5uItw+UsMn1rim+U1irjLjwldIMqvzYzkcdP8/yrPbQLxQQ YyAOvHT/ADj/ADmoU0y7NEE2nSRgHy2XHXI/Ssi4gdXIEbYU88cZ6nj8v0rW4tSk67MqTnsD 1BqpJEd24YHOSM9adwGTKqKoxgn+H8OP8j2piQs+SQPu+vJpMZGyFIwCCccnH5/5/CqMqnzQ MA8HIzwce/TH+BqRlK4XawwFOcg5z+H6c/lWbcxADzCdoHGM5wBVXFYhkkDqwI5OSCO3+QBV L73Ulscj/P1/pTAZjGQ3RcZIHH4dqWadgu4JkkZyR07/ANB+VSNCC5O4HJG3gBv04/KoZCJi qhhycEg88f8A1s/iaQyCcknAUfj602ONhOysVG08DsccY/SgC1ffZxEEQgEjJC84PI471ltK 6E7T3zxjj8aCiJbgtIvXZjIA/T+QqyJ1YEA5x0FQxoUzbx8xyRxUsRPlAY4PbpUljTKcDPX2 q9YSkSAEdTzWFRXRSN21YmJwRmqV2cMuT161lDcbMLWWywxWMxAPtXpx2IGA8fWnE8Z71QDH k6fnzUQYk+tAg3ED/wCvTd27FUA5egyKcSMH1oEOjILDOKkYimBDJzjHamFqBCBznj86epwM 460xBz+NLn0piaGs5AqMkjJIoEMBIbOcA1Zjcocg0xMldvNGRmoGUk8k0EiKQDnnIq1b5K9c UCLkSl22jOfanldo9RQQ0Z5JhuU2dGuMEf8AbP8A+tWssrHC5xVoyZoW13/Dk8cZNUvEuoGO KykRgTBLJIPwheumm/eRCRg2upNN5YY8u4znv3rT+K9//Zf7P1wcgG81UKPfbHn9MivpZO8J PyOOK99Hyn4Plxqdw5PWB/5g/wBKXwtq76dfXEin5nG0HqRz1/SvBbsj0z1TwLpc95elYAsf m5eWZztRF7szdAK9Hv8AWbTV9Y0HRtM3HTNOkVUkYYNxIWDSzEdt20ADsqLnnNEElF+Ymrs1 P+ClWhpo37QzXuzaup6ZbXBbHBYb4s/+QhXxDq8JindM7gCSPevLp6Sa82ejvBGNLKWHB4qG xmJujH2dSPxxn+ld8Tlka+hXZguolzjD/wA69o0+/aSyjZm3cA5HFdK2MHueW/FW3WfVC6jI JBOfyr6t/YN+BvxG8HfF3wN4r1Lwre2Ph2+huJIrubau+3e3cLIUzuCksuCQAc5Gammm5IvZ an6heJLYSmwO3cBNn07f/Wqe2KxS79u1RjIHpzn+dd8leBzdTYjORkHIqdGyDXk31FYnR98Z 9RxWPcB/MLMD+NDYDbaLzAWI61JIioOlYtmi2KzHOcDAqFzmncZBJwPSoGkMZ61rGRLRJBKW JyetEhypBHHp6V0qRk4lNYTuGBnJqeSwd05xwc5HNUmLlOf1a2HlMwGCPw/KuI1InDAEMe2O lYSZaRgSHeCAC38OAP0rOfjJIALenT2/TNczZohiq+9iwwfRj0H+fX3qcYcru4bOcDr71jIt F7S7ffdJuyRXpdigEKDgcV59bc6KZO8QK9BUMkCMp4B/DtWCNCrJYwyD5kU/UVQudCtJgcwr nHPFaJk2PPvF+jx6feKIEAUjkDt/n/CueMHmZ6jdwf6f5+tbJ6EG9aeFo5okLFixAz/n/Pal k8HybWJ79v8AP5VHMVYzbvwtcQhgFJ53EDqawdQ0G5DKDGxx14PP+en0FCaHZmVc6dJHyVfr 1II5rCvxtyChLKcZ6DrjFWmSypGAVBILLjPI4P8An/Cm3EbK2c7A3cD3wfyz+dUIpt+7XkLu 5IA9cc/4dKiDAjDBdvv0x9efSgYwOrDC59Rn9fr6/hTGAVizLx2B6jv+nt61IwaAyBsyBM9M darF8OcZx+n+c1JQ+EpEwZ9u09M9Paql0RI+RwoPagCnK7ITg7F7kdR/n+lSxOSqlQc9Oec/ 54qWMmLE4wc59O1OF0VXGOBxmkUKJfTH1q/Yyg8nqO4P+fSsp7Fx3NqwlyWwOKgvD8w7Z6Vh DcpmDq0uGVc59/SseVjnGc16UdjMYZMjp9aPMNUAxn755o7Z6e9NDsMbj3oBzTESpG2M7SPw qWO2Zu2DQBIlq3HapfsRABJzVEifYiw68ClFhnnJ+ppaiEXT1Ddz7mpfsUajkfnVpXFcVreM DGBkVEUiU84FOwrkMjRAcdfSqkkihsd/WkIjDcehFSRtjBx+dDAt27A5pzRqGBPUjv3qSSAL tPTIqZOvAqhFmEEsMHHHY/hVrhFyegoQmZ73kRe0i8jLtcySb+3CsP6irBlxID096tGMkTi9 WEEHAzg5rA8Xaojw2kKn5pZQuc9AQc/pkV00/ij6kdGVLZ0jkhdW+VSc57cVR/aO1ryfhV4M 0xDl7q4u7pgO4DKgP/jpr6CUrU5HLBXmjwDSWFjZai5OJPJ2j6kgfyzWj4P02PDTXChgSMbu ADzXkNXO49Hs7iSSHyUIS3HPlpwCff1/Guw8ARZ8SWzk/JCryt7ADH9aFsM9g/4Kx2cdv4t8 CahxuubC4gJHX5JFZf8A0M1+deqXQeTIGcDmvOivffqdqfuI56Wb06HpUNtP5N7C2eQ4/LpX Yc7dy9DdNDdgnqGHFeuaFqIl09Nxw5HXNaqVkQ0cj8QBu2MMlmXH4jmvsz9mf9vnxDrfiv4e eEdbsE8/Fp4cN6kmFkhLKiuyY4fpk5559adOVnbuNxuj9JNd3T2tmQBzMp/Q03/loy9eOv5V 6P2bHItzRsLkNCAeq8VeSVeoNeNLR2KHwy/vWGeDzT32SDB/Wh7AQDaCUAAx2FNdRWDNCrPF kEiqD/KTQmBDIw2nJqhc3AVSAcU0wZWjvAj/AHvripm1NCpy3NbqZDVwbXIEGDJwemBVd/FM aoeDg+hp+1SHynP6lrP2nPPbua5a/kDLnGCfWsJTuOxlSja/Axz19T/jVZ4QFDY6cg1ncqxG RvcF/use30/+t/nNVpZDG+FwyDj0z61MmNI19DYvdxr7jIr0e04jGOuK4am5vBFljkGs+4uJ EmVQPk7kVkaj+oz0qNmHI7UkwPOPHc7f2gAMEAcD8P8AP6VzlmglkC5wCcc+tbLYzO/0pAsC YGfQ1oqOCOtYstEMiqckj86rTWcTrgqCKm5Zn3WkWzoy+WCD6jpXk/jnTYLK8kVR8hPCr79v 0A/OtIMhq5x+QvzNyMdVGR6//X/AVDcTeYHIXaMYycZ/D/PU1uZlKRQ4Xad8r5Gcn6fX/wDU aiK7iAeD1wPSmANGACT35J/Dn+pprMFlwBkqcZz0qSxWU7i5IPGBngDtj/PrUMvzOe/t0xUA V7iUtFsxlQeg78VWYgJtGMjgZpjIWkVo8jk5JxmpY3O0kYGM85/z/kVLAZJPtYEZA9Aev+f6 UpHP3vcVJRIj7hwCPatGxbjO7j6/59qznsWtza0xhzyQOlR6mVU7gc/0rCBbOb1WUb2PsOlZ Lvux2A64r0IbGY0ycYHFBYY45NaDHxxGXPpVhIEzg80w2JPJXGAB+VOSFQR2ApklhFTGABTw FHuPWqsIOFJwKPNB5JBqhMd5q7Sc/pUcl4oGMnNBNitLfADAz9agfUGYcDvTuFhjTs2PpUUj uRk84pXCxGXz16VFkHNAdQ3ZPWpkJYgUmSXIk285wDUz4+tIRAG25OQKliZQ4J6dOtMRPCUB Ylhj1pbm9IgIQk5HJP8ASmiWZFrOZrq1zjKxyyce7L/iau/aPm+bJrQylqZF7esHcbzt6cV4 v8UtcufDGp22r21w8k/mCJYJWJjC7SSdvr05ralK00K10yXw78f9OlATVLKW1fu8J8xfy6/z q38X/if4X8QweG4rPVkuWtLIpJ8rDy2aR324I6/NXsyqKVNrqYRg4yPL28SaUC3+mqyMeVAP +Feo+BfEWkXHhya2thFe3kt1HJ565BhjVWBGD6kjjHvXE9DoPWdA0LS9WiBaBA5/ijO05/Cu k1HQ7PwV4L8RapEG86LTrhw7HJGI2IA/HFERnY/8FY5BNpHwvv8Aa2ZIrpN56ciI4r83Lydo yxDD5lxXFFe8/U6ehjl2Y8KSD3xSxWFxLKAsTFs9K6DOx0KeF9QvJS3kMHY7tu3oK63SvDXi byFitbUkKOS65/LvQUb2q/CrxDrSW6vEse37zDtx/n8q1fht8INe8N/ETw1qqDzPsGpW10Ty AAkqsev0ojo0Ox+1t9II9NhfsksbZ9s//Xp11LGbxiudrDAOK9Zo89biW8oWU44B44q4tztH rXk1laRbFjvCsqkn8KnuLkjNZJ6C6lCTUpEJ4B981CdYlUHIBNYSLKlxqsrg8gCqbahIxJLc 1Nxle4umILFsn0qjLcEjr09aq4yvLKAD6+lVmuCMgGk5DSKFzcEHP6VXM7OSM89KzuVYieTd 71UugNuOTTuKxmyxntiq5UrlTznP4ilcdiJo/m9j+h7VUkgIY89fapbGjX8NIftq7hjaBXoN vOoUYIrnnuax2JRcKw4xUcm2RgSM4rA0GMwxmqsznbnn3qOozzHxXcb9Qlzzz/n/AD71kWLF ruIMO+cdq6FsZnoliD5Kjt+tXoyAB61izQqXrOGXaMgnr6UJkr1qSiKc4Q9RxxXkfj4GTUpE GeBgA+/+f51cCZHEyDBB6kjkjj8f8+lVnjwEboHz06/X9QOnU1umRYqPGseCqBVJPyZx7fT1 qrPsjfOCzZ+72z+PqcflVImwih5ZFYtgbsjvj3/LNNcfvHJ6HnGP8/X8RSZSGyEsRuAIAwMD oen51HKwKYGCPUDj6f0qRlS7kVCwLDg4yf8APrUMjEpnAJ7kdv8AOabEiosojOTyBjqaeblQ qhSAOc7gfX/D+dIoQybgAOMZ+Ycn60qS8hQT0644qBkyuAR71fsmJfORke3+f8isp7GiNu2f anB5PpUGovk/0rniWzn9WOJF6nK4rLY5Ir0IbGYnH/1qAc1oBZgdAvPX0qT7QAehp3ADeHj5 aPtbE9B9KdybCrcOcYBxTvMctnJ5o5h2Ey546c9RTkVlPXA70XJsS8AckmoZHQEknJoTApSy BmO3pUYbnNWBIr8f4UF8DgUEkRy1NKhc8UwEVcnpVuCPnOMEUmQXEIPy4zTniypzSFsV5IOr E+1RyEIvXB9KoREZjwM1JLMVj6cD1ppiZSt2b7bE6r8iwYyT1JI/w/Wpri5PO07abZmzLlkV nJcFl74OK8B+Ot8J7/T4Y/ugyMf/AB3H9a1o6zQdDz/SdGv9XgvJbbTZ720tQDPLBGx8nJwN zAcZIPX3rPn0m3unYwXHkyD/AJZ3HBJ9m6H8cV6dna5mULqwmtk3PEVX++OQfxptlf3GnzJN azvBMvIeNipqSj2T4dftHX/hySOHWrb7fbDjz4cJIPcjo36V7x4o+M3hrxx8LL630nU0nvLu S3tTaudkyh5kVsqecbd3I4pbDPa/j58NPGPxW+Emk+HPEs//AAk3iDSLkSabqdnAIP3ZVlkS YbtvPykMAPuj3z4DpX7BOuXMG/UrxIJD/DC27H14FYRpu7N3Lsdvov7CdjZLm4uvMUjHvn86 6ay/ZJ0DS2QmNn2j34/CtOWwrnQQ/AXRLRxIsIaVsZkKckAAAH8BWjF8ILS3jJKHaThRswKQ XG3HgaK2kC74o0AOd5wasW/gDbscKmc5DR9D+OKpJDufZ0Mn27wwkgYZMCt+OAabDMskcYWT ewUbv1Feq1dHAviPNPjZ8b9P+CujwXtzE13d3L4it1bGQDyfy/rXp+l6vba3pdnqFnKs9pdQ pPDKnR0YAqR9QRXj137xq1ZXJmf5qvI/nWwbqw4Nc8exmzNn6HNUpGrOZaK0j9aqPNgnnvUF EMkm4Hn6VVlkI6ClcaKssnHHFVpXYA4PucVLZRTnfPPfNVixV+BUlCk4Y1C8mMk807gUJTnn nI/M1WbG8t3/AJVNwGsmRkUzysgc98ZFK5Vi3ZA27blPPrWmNWdMKD0461m9SkP/ALcKe4xn JqX+3GznIz6Vi0WmStrmBnPPv1qGXWwUbkcCosVc871md5r2R15Ge3/1qi0wf6UpbnB4I6Vt fQzWh31rcqEABxxjmrYuV6bhWLNUIzq3X/69M8wAkDB+lTYZVunO1q8c8YsZdUnHOScLjv2x 6VpATObEe8EswGCME4OefT9agkwpf5eQeo69c/WrJM6YsQMKc8Ahfr/PPH51SdShbjhTkHse eP6/gK1QmKjGNcjAzhQdvakIIRsDc3LEE/nSGQPg4Ib+Ig446f5P51DLNujbacsOMH1oEUZ4 1kQ7gSDxjP8AntxUcnyoSXPrgdP84oAqO2AGB5B700PjGMKM87jSKJV+TjIC/wBfWn87gBwa gaJVG4gDqa1rNNq+oBrCpsaR3Na2+Vdx79PaoNRIOcYrngaM53VZMlex281lsecCvRhsZihu g609RWgFqKEYBPWn+WAeFGcZ4rO4wKg9vpxShOelMQ4jj0pRsAGWx9KdhCPcBQcCoGumDDFa JEsQzsec1C8hyeeKpAQls0oPvmmIkB4FJzjFBIBQCDTXBZic8mgAQYIxVxAQeaGSWYUI+b1q RsoV3d+cVKJZFMG2FeOTn/P51TngdG2nHPbP407iGs624AYBj1GPSq9zcCWNlU7SQcHFMlle S9CSkLyqqAP8/gKqTX7ydSFA6YpkMzbudppBFCrSytkBV6mvn34w+d/wksCSLs/cbth7Zdh/ JVNdeHjrzA9j6p/4J/eDrTV/APjS7u0BS4ukgEmcbSighs+3nGvNNK+FuhfFf9pnx5otzFMd MspLhYRA4jbMbrChJAx94gnjmvaUbwicrdnJnF/Gj4My/C74nW/gzQ7x9WuLzYI4nUcu7FVT J4OSOuBXnfjH4eat4Ru3g1zSZtMn3FdwHyE+x5U/ga55xs3Y1i7pHMX+nmwWLdIH8xdwAGOK 6D4W2pvPHOljHyxu0p9tqkj9cVhLRFn7bPYSOoJiwCehOMelVntHZCoi5zmi5qVHs52ZCCqI M5yMmlks1cfMwJoYFC4s0VuZdqdwABTWCFWC7SvueKyuM519P0SGR0Wzt3lYnOYgcn3JqrLq M0cgVYxGo59gKXNZjsfRXgy6OpeDLXB+aS2C5x/s4rQtoVS2tZ8BSybenX/P9a9tP3Th2kfI v7eHh29vtP0nVIEZ7SDMbleQhJIyfxKj8a6r9hP4nP4l+HVz4S1CbdqXh+TEO48vaucp/wB8 tuX2AT1rx6yu2bvY+mH5qxp82JCh6Px+NcsXZmVht7H8xwPwrKuMg4xSmUinI1UpjznNYlED yY9veq8jk96kpFdj+OPeq8p5waTKKcjbqiAwf5fWpGMY46e9V5MnJ6jqaGBTfrtx7VAy5J5w PrUMoaHwOeB1pfvHoc9aTZSJhzHkk4HYVFtCtuLDB4zmpbKSIpm2ZAbPbimCcjcF4+ves2MU TYHXIPTJ61BLclxgnA9P8/56VIzPmtw+VOc84Gfw+vt+dMiUwOMcEcg0XCxch1VkbAz7DP8A n/OamGrMGxnOO/8An/PFIpEi61n7xxj9B/n+dSNq5B4IGOuaQDZtYR4yN5Y9MjtXnGrKt1ds Su35iS2ea0iLcypIwjFlGF5yenf/AOtVOe3yDwPLxlj7e/8AP6kVQFPyDg5QDdwMDgH/ACOP xrPkh3LjhiDg+3P/ANYD86pMViCdcLgtnHACjAyf85/CoWYMGVjhfU/5/wA4pgQNIhQqTyOn GeP8/wA6rytsOSOM8j0x/k0AV3VnZlAKDvjv7f0qtIqxjof/AK9IZUbue2cg01QgGMDbjr3/ AMaBlmHfvYgAADkHNIAMg9QOvNZsaJoxl8DjPf0rUsGxIFY4HJrnqbGi3NqP97HwepxVW8Q5 f61hEtmFe2zShsDOAW59KymiKHmvRp7EJChCTwM1NFCdwPStQLKryeamUADntU2C4FkUZOB9 age5APA/OqsSVnuGcnrSA5Oc9fSmAm859Kbk56VSEISeKCOKBDGHYUZwKoQLJyaXftIz0oJE MoGR0NNMnrigB0coVh3xVnzgMEsPepZJehuYVt/nJLHoAaRdS2zl3RW9ugHFJEMjn1D7U+SV Deo4ArNubqOOUguD3+lUHQpXGpDcSMEjis+fVo4lOSB9TTJMuTW40ZmVy5Y9u1Up9XmmJWIY FbQpuRJ0nwm0qXVfGeZT5iRW7yEk8DOF/wDZq8E/aInj/wCFs6/FEMRWpitwPQrEgb/x/dXo U48qJZ6t+zh+1v4e+B/w3k0OfR7u+1Ga6a5eVdvlDJAH8QJ+VR6fjXMfAT48+HvAPj7xN4l1 +O6eXU7lZkW2iVjtM5lcHLDHRa61U2XYw5N/Mi8T/G7QPGH7S1p43ma4t9CguElQyR5kUKWc fKM/xNW1+1V8ffDPxW0LQtO8NTXDra+UsonhMZ+RHBPvln/ShyTv5jS1R82eI3xeRRj+CMD+ ddp8DbbzvEl1cMOIbYrn0LMMfoDXLPY1R+4VzGpBxyTWDqE5iO3GO3BoZZiXt2sEZL/MPTNY I8TQ+YIwvPQFgayky0rhNfR3DsjS491HSmRNBt2+a0hJznpWaLKt1HG0YyRubhcLk1gXfnxM A7tyeAFHSq5G9RXPob4UXAuPBdntYsEDKSRg8MRW5DcAWUEYG4WrtEXPsxFe0vgRwv4mZXi3 wvY+LdGutOv4FntZ0MbK3oRg/T614Z8MP2atY+E/xIg8QaPqUF1pi7oZopG2TSQP1UrjBIIV uDyVHSuKpDm2Nb6H0zwRkUzaySAg15mzIL0gE8KuD25+tZF3CcnmqmhIz5YCwPaqctqcdaws Uio8e0nNQvHgdeKllohMfoaqyw5rM0Krx49aqTSbDnp9KAKxmBPXjuaTPI9uTikwI5cHH9Kh dckkDFZstEJhPI605FKg5qWWN5I5/Ko2XHTpUFEbpkA9T6VGw3NzyaljGH0wDnr9Kryk7vTP f/P51IyBjk4UYwOR/n/PWopHOzIwD1+v4UgIxlnJHzHsPU/5/rTCr8ncORx/n/PSkMieZ0fP r14/z7fnSNOcHuR7/wCf8incCF5sAjOTj/P+P5Vi3mFkOCcsc4HatEJmdKrnIJCgHnnqP8/y qF9kcZC5yBxn19f6/WmIyp22bjgqAcr3xxj88DH41n3auX3twp9P8/5xTQFKUHaMfMd3UdQD /icfhmq8kbMSSx5689v85NaIkixhjyAM8sRx/nqaincKp5HToB6UDCz1FbVnJiWRTxhuo+lV NQnSe4YogRSc7Qf8/wCTSZRUf5TnoM84pLVN4YbMkcBR60mMn+z/AL0K5+X9AacyBuAc5GOO 1ZsosWyqJFVjgHI5q4sfl3Y242461zTLSNWzLbyvr6U+6UYckYOaxiWzNYqrMMcbT+FYl46G QgDoOgFejT2MnuVvOAHA69qQXDA8cfStRjhcsMnPPrTftDk5JzQgELljknIpM/hTENLACkDf hQA5eR70owaZIZwffNIxOP8ACmIYx49qhLfh9aZLELY70mS/ckUxAQAKYSAaQrieaQfYc5oW 5AzuPGM4HU1JDIZNUxxnAx0qrcatgD58e9BJmz66ucl8kdMnNQrq0t3II4F3sx2gkhRn3JwK 1UW9AKstzdy5A2pnjOc/yqlLFMyMzBmwODnjP0rqhRtqxXIoriNcBgsbnsxHNWW1SKJipwhx kYGa6loSz1z9n5pNX1TU7hn8xYIooVPl7cAluM4/2RXxj8WNXGtfEHxXqCnelzqlzKh/2TKx H4YxWqIZyOm6Xd6urG3VSFOCWbFXD4T1QdYUwP8AbFIlsjbw3qcYI+zgj2dT/WoILOSO4h3r jc/3c88UwWpX1eTzNSmOehA/IV6t8DIWtdK1W+WFpi8yRYXr8oJ/9nrOexSP2onm+X5FBrmP Ec8mweWq7s/xVTQ0cjfQXt2uxyVz/dzWdc2n9murSMQMdWXmsGu5qmZ8t7byRgRqxc/ectgC oEuUhYDzgGH909aSSC4s+pzK3nowQL0AYZqhJr4EmXUFs/eI61p0Ee9fA7VP7S8MM2VXZcPG Ap46Bv610t9eC1n1WzG1JCVlRmOBggEn8816sdYL0OV6SZJDfLIyIJE8wjlSef8APvV+GM5z G+PUE8VhaxoTr8rFacxyK8ypG02QTWU2SYz0bkVXvF25pNXiSnqZMz7cmqkkpbPaudmhVlya gJP5VDGiJsVWmIHse1ZtGiKFxLjpzWTcXG9sEZA4xmgCr5+WxjvxUgcbPf0qZDQgOMdeaQE5 wBWDNRu7DfzFBbj+tK40RswIPpUec8dzSZaGEjdng1DtLdDjtUMY0tjIHOBUMibjkjPHX/P+ elJjITHnBzg+3+f880yVfl3Ebsd/8/56Vk2NIjCbR6Z4x3/z/jTWQ7jxn+tFwK8sfynJJIqK VBt3Y56Y/TH+fencdiCd8qM8e9ZF0xkzt+UDPJrWJDM2T5W5O45qtcSfMM4H1/n/ADNaElK6 VI1Y5Ib+WP8AP51nXZDxspIjUEggHsO2fof51IygxypQ4B3c5+vJFV5HCnoOmcf5/wA8VqFi tJMCNvU5xxVV5d2QSGPrn9aBFMsqKQcdT93kVDuPA4AHr6UMY24mDMFyCRyM020untvmGfQr 6/5/rUMpEhuDMCwG3vgHpUqXI2Ajkjg+lQyxWudwXrjPI9K1dMnSZSf4hwMisZ7FI2bQgS5G AB1xTb+b52wOozXOjQxZ5TkktyQaxXck9a9CnsZkR7c0vetgCkJxxSAQtj1o3GmIQmnqCR6U xMkVQB1pS3J4ouIYTTSe9MkjaTAOOtQNJkkk5piZC84XPP5Uxr0L3pNkFeXUBjGagfUuvc49 aCSCbVNu47gBjoazp9dyc7tx6ACqSuJlZr+4mzsjKg/xNwKikjaQAzXIRf7qgk10RpdWSPt5 bOLayIs+QRulB+nHaplnLSEDZBETuCgcZHHArqUUgJlgjdc/aFEgH3R8xb3Pp+FSy6VJdxok Pl3TMNwET/Pj/dJBzz0xWyJMmXRYLaUedA8EvUrMrKfXvUQKxklY0Oeny0WEe9/A9z4d8DeI NcnjMX2YSTkN3WOLfn6df1r88tTlLo7MSxYkknua0toQbng2Nk0wN03sW/XH9K6Ng2Tk59ea k55bjJSEidsdBmuNLCbVo/RQW4po0iYcm2Wd3P8AGxJ59697+DtsLLwRFIeDPJJLyPfb/wCy is5M1R+wDXKyckc5rn9cmCtjAIPQY5rZgjjdX1m7t94RXCg8fL1/Guee+l1EfvUZ89CWNYMt BJbxRoNyoGA5BziqX2YTSM5IXB4VVqUGxaW2AiwI229TxVW5toVY+ZEGXHA6Vdhi2XxP1n4c PHNpkAms3OZLd1JRvXp0OKnvv22fCjPA+vaVf6TfxjyXkiQTwSoRzkjDDufunqa6o1uRJSId Pmd0cvc/tGaJDqH2rw54vsZrRjvW0vZQFXj7u1jkfkD7133h39rmyilht76zhkBPzvp94kvH XIQ5P4ZpqtCTE4SitT2Hw38Z/CXioiK01a3juDjEN03kOc9gHwGP+6TXbK4ZQQQQa5ayV7oy ZGZfLcMOoOaszstxEHXoawWqsR1Me7TBqhKcVhI0RXkbiqbvh8Z4qBoilODioHjLgn8azZoi lPbkc9aybqFjggfWouUQJCx7DPvUphJXgZ56VLGI0QjAyecd/WmM4HC8A1i9DRELkD3I9KYW I5x+GakpETPnOP1phLZ7nnFJjEDcetNbJzjI46VJSEKkY96Y4Az1z7/5/GouMhf72O9NZdwO O/5496hlJ2G+R83zc98CnMmBkc/y/wA/4VAEE8OehqrJH3xgZHB71SGUbngEgZJ6Men1/wA+ lZlyCq5YfL6Y5/z/AFraJmzLu0A9yc4IrPuCWQjJJyD7df8A9X5VqSZ8+Sp5PXJyOT/9fn9a otI6EDkYAxt64/8A15/GkMo3ilHDKRjBzt79M/zx+dZ80hBU9UHcdwaaGim0rSRs2MYOc+3r URUkc5Ge561aE1YgcBF5zgZBP9f1qHc64AHvkdTQMayYbB654JFODD7rEhgMGpYxFTPIAXPI GP8AP+RUyodnP681kykPCjIAq5ZZ3cZBrOT0LRsW8pUnPNLP87H3U1y3NTFuWKshzzWWwK9a 76exnYaTSr0rcBc5oxxSEHlnPSkKn0pjsApwOKCQL01n4ouIiaUA9efaojcDHWmIry3ij/Cq Mt96NTIZVl1D5QMqMd6qPqSgHn9aDNlGTVskgHPsKhFzcTttRcc4ya2hTcibkh0x2XdLKzH0 XtTY7MxuAGABGOnNdsKaiS2aC/uwI98jKeu8j+VVZR5k3lxBmwu7Kr8o/E1qA+NJYn/1YfA6 PyP/AK9KQWZZfLRVHVU47+9AhRHIJS4kEQcE4VcAnsMD1IqKRZPsqSNIjb+VjLZZKpAXI9Ru xAEeZwpywWQblP8A30f881mJMs0qB41HUMEXYV5PIx7dyP5VRJ7Dql9F4f8A2W/Et7EZAlzY zxZlI3Zlfyeo6/eGP6V+f2pN8taPaxB1/huLydMgz/dHB7ZrUOe/41mc73IL2QLay569q49S VnvJOyRkA+hq1saRMQAgnPzDHevpDwxajTPBOmwsCGFqmQBn5iAT+prKRqj9X/OjnVtpzg4P 1rI1FyFADEN2HtXQ0COZ1K4G4tKCVQ88ZzWVcakrgqtvIykHBXHy1iy0Y0rDcSY2kxydxApr zmNvkgzx64rOwy7BN+63PhG7oDUc1wqtkRxuPR88VQjiviLcXNgLW6s5hZTzR/dbHlyAE4zn j8/avIdc3amPM1TQVlUDPn24MZb8R8v6Vpa6sx3seeeIPDvh+ZmK2N5ED1WRkl2++dq1wWt+ H9I8yIkSnYoBPljP86xcLPQrmbMga/qOkMF0/VL+1jXgJHOwAH0ziv1I/Yn+N7fF/wCEFvDf 3PneIdCK2F6XPzyKB+6lP+8owT3ZGqWY1F7p79uznNWbKTJaM9+R9ahPUwIL2LNY1x8pIrOS KRSkbPrVWVentUFDS4ZD64qIShlOeorJ7mkSKQ8deKozhhg9vasXuWVmkPcD+tQPJsIwMe9I ZDKGLc9+9RsMnH8qxkWhpjIzjn6VEY88k1JQ0hVC5PPseKaCFYEc4/I02BIu0Hg0hXZn37Vk 2WhPLL4Axn361G0ePaskxkDRbQcY5pACRnt71T2GKUznPPsfWkEW4AfrWY0RshB5/wDr1Wnj IDeo6gf5/D86aYzNumCrjv3Hb/P+FZF5kqRnAHOP8/n+NbxIZlXgBwpwp6gf5/L86zpNxYhh uB5rUmxRkQxo5LBSBwQOp9azZ5VywA+ZQOPX2/z3JpAindDzdoB2nONo6Dt/j+VUJo23nJ2/ 7P8An/PFCGU3QB84wDnOf8+wqMM7hgvUnqf8/jVDKrESHIJyMk89B3/xppkwCvGemPSmIiCD BycmmM4DE/eb17CpYyRJQBg8H1qQvkACs2WLuBA7gjJrR08yGIsoBXuT1rCexaLsEhaQjqan lkAB/wB01zWNUY130QE5OKz3TJOa9GnsZieS5HQ0qQlT8xrS47DwgJ/HOadt3Ci4B0Jz2pry fhTERswPXp60nYHtRcLXGlcf41XnkK9uPagVijPfKoNULjUNoyD1pmbM2fVABycVQk1RmOFB PsOTVxXMZshL3M3UbRnGTV2x062ZiLje74yCDx+VdtOilrIzbNNIbeBSixhPoMUqR2z+Yu5o 3H3Rt+U+v412IgSeWOyjXz9uHXjaQOfXiqkhAUSL84Xng9Kd7isQTXUEiHgq4PVl4qNZ4vmD SAA9cZGKTGWvMWKRgJWdOcZTafx5+tPidZ8rHLAGHTzRjP4/hSuA+8naQFHaKWSMYYooBY88 9P8APFUYrq3tZv3sTS8YGOMHNCYmixepHMkcwRUBXaqBwCcnPQVHcz+Tb+VEkexyC37oZz3G 7Gf/ANdVcR237QV4dC/Zb0y0J2tfS2kJXOeTmb/2nXwxeMWkKjqSK2eyMjvbELDAg5wAAKs+ YM8/jUHO9yhqr7rcYJHNczIMWF2543vt47jP/wBerWxpHYoWlubu5igUHfLIsYyO7H/9VfS2 oW72luMSgQsQgQr0/wAOlYS3NkfqJKxAzwCewPWs+dXnkG0ZOOgrsaEZN5ZfPIZCMryQ2ABW SVtXkOF3SNxw3TNZtIooXEMMTGJGG8HGAck/pVSRZEwWDqmMfdrNoZXkkKj7p3DuRWTeT5aL 5t5UbeFwT9ahoZFrdjZeLtFh03UZJbOaE4hvIgHK+xU9a4u4+CPiuyUS6BqulamgzkpeNZzt yeobAz+NbxfMLY4vxV8LPiNF81z4R1OYsCTNDPDcqff5WYmvLPEfg3xHbQut34b1eB/+mlnj t64qZpocbNnnN/4X1WSU+XpV4WzgKYwpH5mvWP2UvHeufAj4r2Wp6nbmy8OakPsWp/abiNAI yRtkALclGw3TONw71zNpFSjfQ/VtZhIAykMrAEEdDUgmKMGHBHNY7HEXZGFxEHHfr9axb6PB J9KcikZcjYPpVaZwRWTKKbyEZqv5pXK53Vm0aJiiQEcnBqGaUY9fasWjRFSZxuz2JqNhnJJz xxUDK7Mf8M0MwwMdD2NZyLRGXJxz+FMfH4VBZE6ZJIAznBpNgGcGgLAD+FTKNwxjis2UhVTZ nOQMdaCm4Y2/j/n/AD1rnZSRXaMM364pRGFGB1rRPQBCv5en+f8APWnLEM5Bz3z6VDepSRFN FtO7v61RljJB4z2I/T/P40kNmXdR4UnABJ/Osm4+UMApPGa6IszMq4iV0f0x0HP4Vn3Awp6M ewHatRGTcZfIJxt55GetUJHAYnJz1zj/AD9aYFKWQLxjafQ/lj39KqXDgqSMNnjANICi8Ynk Cl9u49j6/wD1qqSSMhO48B+i9M96d+4yuxA+6NuTnioTKqkck+v1pgLLLjJGOBnioCxduBg9 QDSGPX5cc+vNSck9se1ZstEgPB4/CpVmcqEyQhPIFY2uWa1o23GBn3qaWUDdweB2rmNEVWt/ OILHC+1QvY4ztwTXZB2QrEDgo3INMJB4PStQsI20Dioy2Af5UxWGGXJJPHtTGdR9fWi4WIjM q+9Ne5Xr3ouFiJ7sAEZqhcaog6HNMLGLqOoqyELnf7VmBLi6bBIjU+prop03MwmSf2fHEx8y Tzj7ZA/xqZJY4Iio2xgjkV6EIKK0MHqMDxMnyBnHrtp0Nw8RR1hRdrZ3SDOfqD1rUglkn3HI KY/ugmprWOW6LMHSNQpIOSQcDOBjJJ4pgRagxueJlZnUAJ5g5Hp15HFZ8bRByu8op68/596Q MUSNZguHR1xnOOQOxxUdzeC6UsoG7JzzzxTJIzqF7OrgndxxhRn+VFtcXRUBx5ffCY6+9IZN EDIIhLcSYDYweeM9fX16067sIL5PlkXKvvSRWKlTyPXj0otYBls8aRBTcAtkdVOSM4604s7M IwzEg/Lj14qiWdJ+2xfrpng7wZoitlWmklx7RRqg/wDRpr42jXztSgQcgyAn6ZreRkd7Cu2M VIRyKg5jN16QQQqAfU/pXNXbkaZCoOdzluv1q+htHY0fAVl9v8Y6PFxgXAkOf9kbv6V9A6+w 3wxL9/1PQ5rCW5qj9PC4xycelUrlwuSpya7mJGLqKtJCytyTXOyo6h9rhMd+uKxZRllvs9z5 iyl5h1bHSqj6szPJvO8e5yazbGQpcysm0oSn8TN2+lXhGt0ix2mdxGHyoBz7cmp3GavhLwhF rF+zXzhbC1cNdPuCsq4J+8eB908npWN4x8Hz+PfHWoaHoOqWNppUEMboltKXVdwyFY55bHOc 85FeZiq/I1FbHXTw7qw5ovXsd54f+H13cWtjp8+oz2M9jFHBt8lfLkKgL8uRnBxxz3rjf2pv C+v/AA3+Hl7qOmXWmFwgDTXhYSoxztKpjaR8pBJbrjg9a8F1pVam+h3Siqa1Wp8xeG/jJrOn aBbX9xBazzXu54HuI2wqB2XJVe52+uK8z+Juqt42nN7q99DvRndEtofLUFsEjLMf7or1aVJw k5LqcMpXVj7x/Yn+OUPxT+FsejXFws2veGwllPlstLBj9zL7/KCp90JPUV9B3U1yr2/2dYmQ yfvjISCEweVx3zjr716J5c42k0X7C5w5iY8N0+tNv4wc+lW9UI5+6Uq5qjNJxzWDKKEzFzx2 qHOAc4FSy0VZbor0ORnsf8+tRrNvbGRgc57Vm1oaJimQH3xTPMyprAspSXABGGHXGRSCX5u+ OuahrQtDTId2ckD0pd2UzkYHb1rMsQkLwPTqelO4OeKQDkixyR+YqdQCPWs3sWgZc96ULlcZ 4HrWLRSImjAJPFIEBHt700xgUy2MYFIFwalghjrwQeB04qlKoBPB+g/l/n3pDMu8AJOSCAeB j/P+RWJdNwV5HOc4raBDMW7kZcnGO3/1qypZdynAz33etbkmbO2A5ZgTn9O39T+VUJnU8D5e Bjnkf56UwM6cbmPJz1IHT/P+NV5cKvX7xwR/hQBSkBXK5Awc/j/n9BVG4kXbtB3DIJJA5x/K gpFWWXKkAgbulVwC5DHIA7UxEgOeucfpSBDuxk/WkykSBfU/nTwefUVmy0OBqQZzzxWbLNSw Y+/PqauKNzNu4Hqa5nuapD2iXqv5VXkG0E4roiMrOARyAfrVWaJV5XIx3rW4WKcjlTyPxqIy Y5zTuTYjebA6/jUDXQPQ5pisVZL0KCWbArOvNait8nd+tAWMe58Q+ccK24HjJPFUZdSUkLJI zg84XoK0RpGFyzY3EUibCdrMfl45q/HEDhSeABliOTXq02pRVjgqRcZO4Pbb8ybiWJOSScmo ZLJSocIHU9DjOa1MyJ0aHAK7VHHFQPPl2ZW3q2PvN06HiqMyKTUPl5wo+nJpPMnuHiSFZHZg SMRkjjk4xnsOppN2AcdTuTZtFITulGAsuf3frxng4yPxqj5O0k5Zm68kmhAyWHIlB3EEc4zz Tp5Ym4cc/wB4dfxpkjD82DHNG7Ds3BFNiuhFkBGdh/dboPpTTET3U6LF84Kk9h1FQwan5QIQ iPORk9+KbGTiQ3OHMceV7ooX+Vbfg+3e58R6UzN5m+6jjxKA425APBz26elNasRz37bmsG68 caFp+crbad5v0MkjDH5RivmzS2UaxA7nCLkk/gRW0tzI7Zb+1IAEyD/gWKetxC44ljP/AAIV KMHGxkeJJQY0KsGGwgEGuf1CRY0gjJPCdvwqnsaxOt+DqJN4u+0NhEtbd5CW4AJwv/sxr2e4 uVOtW7sUliQBgpHBGM+/X1rnluaI/TyR4zgDoKqGMSsSZAi9iRXcyTM1O2CjNtIHmHdhgCue fTZpGZHfLsc/L3qGikZV1oiRTOGZzu68jn8qriwS0bdFEdxHRc1nYdyBNJmcN5iyyFmLfMxO OelP8Y/Ezwt8CfCOmX2saC3iHW9XaURW8s/lxQRrxkkc5Pr7j3rhxVR0qd47m0I87Zh23xD8 NeP/AATBr1x4Iu9O0iVXa5n0bUWkls1SQrvZWI3L8pJIBxnkYrnbPRPD6XCyeGfFNncRk7w1 9I0NwpzyoG3B4/i9jwK8SrztpSfmehRjKmlOm9T1DQvEmrW2kmD/AISWK2iZdpFwq3cJHuCQ SPauN8Y2XgXxXYTabruo3WoPOR5ieHUazt3wcjMQ3q2DyMgc44GK83mp0ZOctLHoy56ytM8u 8a/sveCta0mK18M+IdSsNQ2lbS11mXMUjlshcqqbcknsee1fOnw++Gjad8SYdD8T6fbyQpqa 2d6kuWa3bzAhKuD8wGc45BA969nD4mGIhzQeh51fDujZ3ue0/CbxDH8Evi4uo6dEsOnrcvbX EMXyrJbGQg8Z7YDD3UV+j9pqVvqNnBd2kyT20yCSOWNgyupGQQR1GK66M3KNmeXXS5rj2mKj IOD2NahmW9tlfPPRh711R10OVmDqUZAOKxJSc8c1kyiCSXAwBVWZ92RWbKRQmyMg84HQVUMz JIBj6H/P0NSzREhn8tOe/T0zVC4u5AwLcKB61lYu5E8wlAAyvpk4zxU0Mo8vnOfp+NTJDQ4S ArwPc801pQMEkE47f5/ziufY2WwsTgscHPpn0qypBzipKRICB36/4U5X5xn6UmMlGB/9emmU AcViy0Rl89f1pd4UcdalAxwb0pPU/wA6YIjcbs1UnPXHOOnpUjMq8GQW7nvWLfIdzMOF/vVq iTDu4FDFhk/U/wCf85rLuSvLfeI5wK1uSzMuQNpJPz9cDjFZE8iJnBGD2H+f8mrWwihK+48H AGfvcGqc0hbBPTtzTApSFnJx8xxjHrmqroVUFuAwoGiCRAV5FMbAIA6+9AxFYdh26Gn4BBOP xNJjQbgD7U8OOMd6zZogVuemKtwW5l68D+dZN2LSua9vD5Cg0+ZxsJ6fWuO92dCViPzdsfDY J9KiF3g4YZH611xEMk2TLlDnHas+SXa2CPzq7jSK8kvBNZ9xKFJYEbaaYmjMudSVAcmuf1Lx haWLEGUFsfdU5NaE2Obv/F91dkiBCq/3j1rKaS6vG3SSMT6E8UzVRHxxSgjlqu29u7nJY46Y p3LtYvxq8LBHG9TjGBmty2S6twvUqBw2Ocehroo1OSWuzMa1P2kdC0l6XZC6H5TkHb3p0kQ8 k7JATjO1R+hr1Dyig9lcyrISDhVLMM4OP8mqP9nZBdmJ9QetMRGNLJy3mDrxtGO3AyfpVq3m +xIXR3STZty688jBIOPTuPWixJnXVz2DeaM9QuKW3m8skfNkgdR+Y/z6UATLL5pG5CQfeo5I SxIAbA7mmKxDdRMij/GqKT4kPzGN8ZyeP1qQRMuoMzHDBn9aUy+fJ8+z67cD9KYWLCSuisEG 9Mc8nA967D4WZvPGOkjJxE0jMMDHCkg/nVx3IZ5F+1Lq51L4za0qtlLaOC3X/v0rEfmzV5nb eE9cvbEX1rpF9NZMSFuIoHZDjqNwGOK3a1MjOhs724VzBDNKE+8UUtt+tN8q53FSH3DquORS AP32REwIBI4IqHVWzeEf3QBzQxo9N+A9oC+r3LKD8scYyM8HcT/IV3rshvZSqGNRwAMfSsHu Uj9SPLJ/i/Ske3XymYPk+ma9AmxQlhycuSFHUKMmmSG1Wzdl3pIASPMwf5YqQOQvr2aRiGYo p6BTVeTciE+Y/bPXNZFFSVrgkC3Tv1PJrxP9sm2ll8D+FbqTcZIJHibJ9Sx4/SvOxnwL1Oqj 19DB+Dfx98GfDr4Ba5p2vq+o6nci5s4NNicq7hxncSBwvzEZPv1IxXyJa+ONR0WeSeLZIsil UW4TcMeoz0+orhUVOV/JI6ea0FZn0H8IPhz448SeD08R3d8Yba6+e1tpWKs0fZwBzg9vbB71 3OmeC/GKkGJJWPYxzP8A1ry6kKEpNOOh0PFSp2V9Tfg8LeMIdU029udNlmaGeNvOeRnKAMDx k8fhXF/HmP7B8V/E32aMeZvSRBnAdjChz7ZP+NbUuRx5IbBVm50eeT6o53VrqykntTZXX2wC BPNkETRqJTkuq7uSATwe9fUf7HPxdk1G2vvA2qzhrmx3XGmuQBugJy0f1UnI9mPZa7qHupJn lyXNF33R9OefkY706zv/ALJcDcf3TcMP6/hXdF2OJl3UIMjjBU85Fc1fIIyfelNagtTPZuKr SMDmsWWitNOEBzjOPSsi8u8H0OPuevapRZVS6MqKN3y9QQeDTJmQMDyTwcEVLKRIgYZYnCr1 /wA/nT4gXc7Vwp6f1rORSFU5yCOCaYw2kbuSfasJI1TCJyJNoyccnFXIn2AAnjpjFQWhS57H AqRZufcCpGMech/vc+9OMoHQ1DRQz7QDkdKTzxk89O1Shkkc4wM84/Kgz4z6juaAFaZcevcV XklA5/nUFGVdzptJzyR3HXmsO+l3My/hz2qkJmNdSH5gcNnoAeKyLmUBzk+4H+P+e1bolmVc sHLH5sngY5rKkQfxZPoOtWSUbs5XIBXB649qosgU7i3POM0wKrSEHA+bryTVOZ++cfzoKRDu 2kAtz25pjNjPPOPSmIQkbQxUg4+tNMuDgZPpUMtD0kIGD6UsT54Pas2aJEynBzWhbXiMyg4Q +uKwlsaxNWOTeOoI9ar3UuE4OK5VudCKgkLe/wCNVZrgK5wa64vQViq14YzlTg0faxONrH5+ 3vVXGjKv9VgtFPmShceprktb8YyAMtlbvM2PvNwoqomnI2jiryfWNWb97K8af3IuBViy8Ksy AkFj71fMhKFjbs/DDn7o4HYjmtFPCcsJDeUSpGSAOlS2apFweFiQGKYGM7u1W7fw8mDtG1hw QR3ppg4mrpejGwvYZmgiuYkdWaCYkJIAehxyM9ODWhY6FMqKJY94AwSRzVkobqvgz7TEZbQe W/dcEA/jXH3sb2MhinUxye/9O1elh6nMuRnnYmly+/EjS8EylMkqo7n37Com0+wWXzo2dLgD Lec7Pk9CV5OM9ccYrtOAW4dZgDFiPgAgHAJ6ZqmRlxu5YevJFAhspDpuk3EjoKrM+0ZAx70C JIpmGCQAeoOKleRRGXV8N94IQeT7UxFSafpk5weh6VmXgBfKgc9hSY0V/LPXkfSrcYxjd1pI C7AQNxYfwnp616D8GEjl8TzTCIKUtycjsSwx+ma0h8SM5bHzV8XtVOpfFLxRcI3A1CaNWHcI xQfotfWXgrT08M/sprq7zvDPZ6W9zFGGwHaVpJCT+BXp612092YSMj9hXSbceHtWv7xVNrPe v5qsOGSGAsPw3SVwPwx8VaHb/tDeMdd168t7azijuERp3Vd7B0jwue+0NRoooz1bZyf7S3jf w141+IlpJ4UbztKtrYRed5e3zH3sSfugkY2+teHXr+bdynPG4gVlN3ehtFWWp7b8ErAQeE7u 5c7TLcNg/wCyFUfzzW1ESzO4+Yk9zXKy0fqdI2c9h65xUDShe5JHY16AiB7hEGMjn1rLuSbr KJj6tUMZjTWPDF5Yy6jO1jyeewqv5M8u7YilQOSR1qLAT2+nzhNpcIFGc159+018O7zxp4K8 G+GtAtZdR8V61qLi2jdwkUcaoxZ34JChQWJ9DwCa8/G2VK7O/Cw53JeR8X+KfgjqXhfxDJpO r3CNNbybZ3tMsh9QpYD8yK7rSvgV4E1rT455YryGeLGAZjgnryMkV5FSpOEU4lRiuax7Z4Y8 eT+EfJjgmgukgXaiXEZKgAegIrqtX/a41rw9pPmWXhnSLyaMLhHRkzjqevXvXlSp871Np04T fMzsvh9+2xofizTUj1PQRp+rAhDZqN25iQBsOORk/h+p+W/2gdkfxR1Fkube7LpExe33bP8A Vrx8wB6Y7V2YOk4NirpRoad0ePeJfEd7pDWsVjbRyu5YsXOAqKCSfyBrqPA3iu803XdN8R6b Kbe7tJ1liPYlTjBHcEZBHcEiu+fuJNdDmo+9dvqfpF4C8e2fxB8KWGt2ZCCdf3kOcmKQcMh+ h/MYPeujMm4H0rtUrq6POkuV2NXTLkXFs0DHLpyv0rP1O33AgDFXLVXEjAkGMg1UlO0GsGUj OvSdhOcGsaeKSZ1IHbkipKuVhJjACnIOBk9MU925UnAweOc4NJloclyETaGGRxn2xSx3xhU7 Tye/Tisxk8dyGRsjv60vmZbPfHasJGqJUhY84wDUmMHPOaxZohclR16U3J3c4B+lJMYx8dOo +lIZRz6jsaGNEBny5+tD3AX6g/pUFCrdngZwx7Gka8Yj3z2pgNN0QvPHFRyXOV4IJGOnes2U ZN7chiSCBjisi9uflJ4PrzVITMi6mMhJzjcMgY6/4VlzyxhQB0xyTW6IKMsi5LAEH2rKuJz9 3p9OlWIz52DofXHIrNeUliCQQRx9KYEDSH6f1qu2FOP196RRmX9tLJPbsjBY0cvIMfeG0gD8 yD+FTBsjnp2FNgOMhK9cDpx6UmRgDFSykJxnuDmpAwzWTNUL5mO9Ks3vxWTRoixBqMlsPlbj 0NSSavFMArEI5PQnrXK0dERyzYT1B71l30vDMDg1vHU0sMhsrqSISOhVCMhjxkVn6mJ4YnaJ sYH3h1FWjRU7as4u6jeW5Uvk5PLE5zWjZ6Ykrkgc9KJuyOimrs6uw8Gi6ifbEnnKNyYH3x3F TQaAscjI0WyQdQRj8xWUJ3LnT5dTVh8PFE3pHj+9tHzL7/StGzgKgCWINGTgSAcH61tcx5Sc 6PJbsrRqkqdCGAGT3P8A9apG8NC7cm1QjLcMo/pTjuDVi7b+Gpo5BHMoWRe68hq1bfQBEQsh OewxXTFaGDLH9hRuit5joSccDvVPV/h7ba3DiU/OBkMVGQe1Urxd0S7SVmeOeKvBl74QP+kI JIGbak6dyTwD6HkVzt6zRqscg2Sjsww2K9aElON0eLUg4Ssysp3DAwx7jnIHrSrNtY/NxuI3 HkGrMx08u7MgBCfdJxwCRnrVN5CybVOQfzoExBIAMHFSeU8iBtwZfTOKYitd+UV+TAx3JrMd hu56UgIQcyZXIXpyasq528Y3e1IBUmZW5G0A8mvV/gqscEOq3u/KbUBPTaBuJrelrIyloj46 1O9bU9QurxzmSeZpW9yxJJ/WvZNe+NGpeKfAcHhvTtDFpaJYQ2L3EkpbKoiqSvAAztPr1re9 jJq5wmleMfEXhfRW0q08TXGlWLO7Nb2MxDEsAGyU7EKOM4rCDWRJcRz3LnlpJW2jJ6+5/Opb Y7FOXWYrYnyY4y/T5V4H4mo9A8L6p4qvPJ0+zlupmPIjXgfU9B+NQ3oNHu3gWxn0jwHp6CNS jxtK57jcSQf1FT27tHwu0g5JJUH+YrBmiP1CwCc9/Wo5sY6ZI616JnuULkAkbkOeoFQ+RJ8z I/lnsD0qCjOntl8zeSHzwSO9OF6EBBgZVAwCTQBHBbNcL5r5kB6KTXs9tt8FeDIdd1OCFdde zNrYgRKHggOOMgZycKT9FHY15uOkoUuZ9DRTcE0t3ofF3jTweuq6xdX8zAb3Z2ctjGT1rIs/ DUcNg0sCJNbKfmljIYZ9yK+blKU16HpU4qNrmfe6XDGjTBCFUZOB2ry7xz4gh0+2uCHCRKN0 hzyc9F/H/Gimm2XUtFnkegfEM6f400/V7mGa5sba7jkMET+WWwwP3sHuAenPSuz8d/EAeIfH urajZ6dKmk3E5lR5pQWhjYnyk6fMQqgZ46GvTiuRowqN1KaiY+seH5NbntbiG6EIRTuDpuDq RjHtx3rTsJ4bCIQRFQik85/WnUXM7Iyw701PXv2fP2jNI+G3iuLSdW1i3i0jVJFilDygiCU8 JKcfdHQMeOOT92vvSK4BHXI7Gt6cXGCTOWvbmuiWG9a1mWVDyp/P2rVupEu4BNHyrc/Stlsc xzWoR7GyKy55DtPrWTLM25kLKTjIrFvZnDck8ds8CpsMpiXyGJLKOMZJqtNflpcu2MgHB7Cl YtE1vcqfMOSXNPEgc4CnAAxngVmyyeJyAdpxnoTWhbLuOMZJHfmuaRqjahtRtBJ6057Hdziu eTNUtCNbILweaQ2oUk7c0kx2KlxGVB3DtnFZFxcFWweAvrWgiJJjIRt/E1MqEkk56daybsUh MYbOOnTNNzkUJlWIpTj6VUuZ9gYrxj1709xGFeX4Kn5hj+VYsmon5lySOmcVokS2Uri5LA7s c9PWs6WTA+Ynn9f8/wCelWiSq746HI9B0qjcOCGPaqQzOlYlfvFf1qhIuwnBx7d/8/8A16Yi u7HPP6cVE7bkwD1pFIrSMChzzioVJxzxQMcHzwfxoZ1XJ6GpKQwzgcAZpPtHPtWbNENa5weu Kha9BJ5/Ks5GsdxzTELvZgi+rHFZtxqEbS/IrSn1PAqadKVSVomrairsuN4haOBY4U+bHLuc /kKyZtQlmzvkL5PQjivaoYaNLV6s5KlZz0Wx1+g63/aemfZpSqzQoFOPQcBv8ar3cLh3DemC D0/H2xj8PpXlVY+zqOJ7tKSqUkzAm0QXEQlt84VvmHdcHpWnpOlZkBxncMEdq56j0NaK1O68 LaZcJq0TkbovKxt9CWP9B1+lej6j4Njv9P8AMtVAmHzAtwCeysPfHWvP5+Sdz0uRThY5Cw5Z ku7drO4jJUwtw6/59K0DZgICPLV3AI4+V/r6V6KdzzJK2hUbQroqHtUZuf8AUt6+3pU1mZoZ sPC1tMuWJPG/JyP8KuOjIkro0zcy3ts+CPOz8qsMqR/ez657VaknFrLuZW8josjYJz711ROV osPM7wOYyqkj5WIyM/TvVeE3SxReayPKDljGCqN9M5xVNiSGX9jFqNs8VxCskTjDRSrkfSvE /HPweGmK954fiHk5zJaqMFB6r6j2q6VX2ctdjGtR9otNzyl7ho5yDlGB5yOR9ac0yMGDZDdm zgivVPGaEa9mSMRGZpIjhtu7IyPX35P50wSOxZgcUxCGbJ5yfrxUsNxJucAnaw6HoKYh7RpK AN6ZJ55qK4s3VWBjLop5ZeQPxFIR0/hjwRoHiC0iZ9f+y3rZHkGMDH4k81Q8R+BZNBnwt9Bd R54dTg+vI5H61bStcV7mEkQcDB6cjI4zXpHhdxoHwd8Waj9yRYLlkOe4hwv/AI9WlH4iJ7Hx 3HdvbS7kIU+uM4q411d3aAzyyyow4LscGtbmJUkuILbt50nseBVvS9C1fxTJttYGaMdWxtjX 8ahso9c8CfAK3lkim1VmunznyU4T/E17u+gWPgTwBrN5a2sdv9lsJpEWNcfMEOP1xUrUZ51L bf2X4es7TlfLiSMKD94KoBqhqmnS6VHaytuaCddyybcbWxkqf6eo/HGUmWj9OQ29QFXH1qvN IIcBiqLjqTivSZiiJv3sY2fXJFZ8oO4ZDOx9f6VDLGSWImIZmEIHbFUygWQnLP2AApDPRvhH 4FTVbw6tqEbJp1m24hufNkHIXHcdCfwHeq/xa/4SPxRqchj0jUDbA7YwLZyAv5V4OY89RqnB XKhbnTZ8x/Gv4B+NPHi2I0u5utMghLedazwSKjk4w+QDyOnTvwRzT/CXwVu/ArIDPcTotuEd PKkUNIR87tuZuvYdvU15zjJRtyu56KabvcwviPIdItXhVQjHhVxyTXxn8RdefVr8WkLeYoPz bT95z1/Lp+FPDR1v2JqPUxtS07+zrOzhHXcHb3O5c1v6boepaldwwwwGaG6WJVKHLFsEbQvU 5z2rqb6gpWgdt468O674BgWPWtOfR4TCJIzO6ZlTOAQAT6dP/rV4B4s8Uz63dFI5CtuvRQcA /Wu+hBpczOSTsrIxI3+zMpIyeuDX6b/sP/tHRfEvwZH4S1efHiXRIQkZkbLXdqMBXyerJwrf 8BPc1ctSJK8T6jMmRzVrTdR8iTyZD+6c9+xqU7HPbQk1KHGciubuo9p65rOWjKRnXJ2xnPes K9BQM2M+o9agZi3U4wCx+mOaqxSGZuWwOdqkZP8AnpQyi5bxZkKhsuRjI6YrTKjyzjqDjHXi sZaGiAOdqrjbitPT3GVUcVzyNInQwt0xxVgHI55rlkbIjkfaPemBgRmmkMoalcJHCT+pFcbe 3WCxJz6VoiR+kXQllww46ZNdEqRsoGRj0rCe5pHYa0cfTg+9RtChPtUlFae3UqefzrB1xlt4 uHAzxitYks464ugByxOeKz57oHOw4JrdGZWluAwP8+wqnLMdo69eh/z/AJzQBA8m/kmqN3Jk naDxwBVIZRmlOVJOM9qpysMetAFWTHrxUBfbkA8UiiCSQY681XeXnrmkA1rj1xUZuhjmky0V 5blc9ajN0WHyVNjVIYZxkKXyTwFQZJNRPfeUfk2xtkg7uWFa06Eqmr2BzUSFpfNilmkl+SMA s7ngZOOvQdazbrxLplrZLczapbJEWKLg7ixA9hgfjXoRUaXuxRk7z1YRajHcDekokUjG5WBF dNoXh+TXdMku0kPlxy7HUDJACg7uvvTrVfYw5h0KXtp8tyWHRf7Nniu7aZzKh+6W4PqCPzrd u2jukE0XKlM8dV9vw/ka8OrVdWXMz6GlSVGPKjmbXUJdJ1MShd0ZO2SMdGH+Pp7V6XY+HY7+ zi1GxzLA6glR1U96wqaq46b5Z6nT+HoClwjADcoABA6e1ejWLEooBKuRjA6H8PSvJm7M9qK0 K+u+Cn8QafPNBtivkXAkAzkds+o9642Kzks9lldyKL3cFETYBZuvyj8P0rvoVVKPK+h59ena V11NKzupLWZop43yBkSY4+lbEuk2msxDzVCS9jXXc5GjHl0aTSpckiSMHkHg4q35Qu4NphUL 0wejV1Rd0cslqZF3cnTWYRQecMjKFtuOee1PDR3CsYwxTsPWhy6Ao9R/lOkDcu+B83POKrzS /JtKB1br6j6VEi4nC+O/hfpni7M1rGLHVeAJVHySegYf1rwPxH4b1Hwzqb2epW5hmXOATww6 ZU9xXdha3N+7kebi6PL+8jsVIVRI3+6xOGBQkkfhU9q32C8817ZLuJM7UkJ8t8rwTggnBI49 q9E8wqSB3y+0hckgDoPamsdvzZ46CmiCvGWAOTwKljvZoyNinPZwcY+v6UAXIr1yD5sasOTk 8EZ9xyfxqJppJi/lb2jVS2CwJC9/Si+gyos0qyMQwCkfL6ivT9RnjsP2eNc8xfNLWUhxjPMk gVT+G4flXTQ3foYVOh8weDvh5qvxBmv4dFjSW5tIPtDRSPt3jcFwpPGeehx0PNIvgHXvtDab c6dc2U8TfOlypQLkA5565GDx14q2rK5C3sdp4f8AhJY2OyfVJBK/ox2pn6dTXo2mXGkaTCEh tvO28KPuLWL1ZRu2vjq9iiMdpBb2qf3lTcw/E1f13xBcap8MdTt76TzTdXtvZxtjlg0kZZTj 23Vp0Ect4muGMMaDa0eNxIPQiuSV3ELJkiNiGK9QTzjj8TWLNUfp+tnqF5H/AKXd+WSeUs12 AD/ePP4jFTW+lWmnfOFaWQ8B3LO35nJr0GYomZMn396ruGY5A5HA46UiiKRIifm+ZgOma1fD 2gXHiLULextA2+RgMt/CO7fQCs5OyuM+ktD0S30fT7WygXFvbLhcj77d2PvnP51pvGJUZWyA ePlJB/MVwruBSvTbafaST3EzQwRrl3aRuB/Omx6rYSaMdSMyCwERlM8owuwDJY57Y5zVluEu T2ltL2+Z+VX7aPx0Xxb4qvdStMQ26BrLTY1AVvLXcGkOO/LdehYj+EV8caHaedM97MMjOEB7 nua8hPmvLuza3LFI1NSsLfWoNlznA5VkOCPpXtP7OHiHwj8PdG1vXNYsb6e60ogWt1PIDA8j AgxJxw+DknnAPbjPXh4Kctehm5WVjwP44/GbV/iv4nu9Qv7kuWbCIvCIg4CgdAAMflXnthaL taaX/VqRj3Jrrm+WOgoK7H3GyeQv/kV9BfBb4j/Dj4WadY67FY61eeNrcblwVjgV+mAVflCO DkEkE8Vzxa6mzV1ofop8L/iRafE3wbYa5bDyZZEC3NoWy1vLgbkP58HuMGurkkytTc42rOxq adfrf2jQu376McZ/iFZeoxsp4/KiWuokYtw/PNZF9ypBOc+lZjOcuowrnjqKpGUwOjHjDelM EacV4v8ACoA+tPinYurEgsORmsJI1RdDebjqWxnrWhp7YlDE/nWEtjWJ0kDjA4q2D8ufWuVm pDI3JqJmz3plGTrTf6O2DjHpXDXbcg919TVxJZe0iRS2c5yK6GJ8J0x75rKe5pHYZJOIxnNR m53JkkY9azKKs1yWXr0rifGWpNEUjz7+taw3JlscfJesxZicZ6GonuST14+tdBBE0/B7elV5 bvbzkCkIoy6ggB5z3GKz5dT8s85xTGUTqSkkDPXqajk1CP15oGinLqYI+UZ96rtqALcnNAyC S/XdxVOXUVTvikUis+q5OFBJPpTftzOfmOB6daai5OyL21E3FipDqq5538n8qm3jaob5u5DH AP4V30qCjrIzc3sgMbMucDjpg5496oTYjbGRkHBrq2MzFSTWJJHWW4tUty5wogDll6YO4Eet VF8OWNwyNeQC7kX+Ob5z9fQdB0pAasNvBbRARII07ADAr2D4PW6Xnhm/dCGaK7OQD2Ma/wD1 68/HfwWehgf4yGa/YCwnlZIyIAQ3qFPcfzrCivk01mSVz5TkkEfwsBkH8a8ODPoZKxkXqk3b gIyhW4B4we6/1Fdz8M/E8vhzUER1M1hOQJI/7h9RWstjmaPfv+EYiuIRqGngSRSKHZE/PIqT T4XUAHO0fd9Qa8mrHlZ62HnzxOqtiY3DDPPU9mqTW/BVj4ktRcIkcV7F88T49P6c/hWVOTjK 5rUjzRscFNZTQzMk0WJF4YEdR7eoqOKRbN+C3kA7Tkcof8K9WMtDy5R6F+6EN4gV15YcOOh9 vrWHd281opcHdFHglz2HQZ/E10QlrY5pR0uwj8rU4AysjnOQwIIBrPu5kskEgurZGVwpDSAZ zxWsmZxV9B0epQTwB/NjAIDbtwxiql9JFvWXz1Vc7WjYjDHt9DzWamacvKROyXHyI8ak4wS4 /L61R13StG8TWT2GtIkqICRIW+dOOCCOaFLlkpImSUouLPnL4jeA7rwXOrW1z9q05zlJ06rz xux0rjReusRjJZgTkgnjPrX0FOoqkFJHzVSPs5cpMbt5UQF2+UYA3cD6Clj2yvhmJ56CtjEc yqWxt2kc9OP1qFoMngbfXFDEPeSOzjDzybUztyTgH/6/tViHxVJpywTWdl5saSq7RlseYAQd vTI785zWW7sUnYoNdSSytJLE0auflDODgYH09/0rtPi7enSvgibUEqZ3tLX3yP3n/tKu2hs2 YVNbGX+yRabF8T3rdxBCp/77J/8AZa9J8Y3tta614yvpbSK8e2j+yW5kziNy4iVxjuAMiumS 9xGS3Z4/vuLu5AAaRz1JPNSQ6PdJcpukk+bqpJxmvKpVvazmlstDolHlSOkhsXgVWwSMdSO9 a+tqo8P+ELQjm61Ce8YHoVSNwCfbMi/pXb0Mkc74peGzVjH8p2gMORyT2rkkvGLj09Q3INYs 1R+sYI2jqQKTeoBOdo9DXptGCZWkIboC+fTtTSdy7ASR6ioKI47ZS4GeSeBjvXv3w08Ejwzp n2m4T/iY3KguT1jTqFH8z7/Sues9LFHbgbRgdq5PxH4ouLDWbaCNltdPhIa9upUJGDnaierZ HOM4z9a50jswtFVqnK+z+b6fjb5GRr/ie21jWks3vYrTRbUg3jTxA+c55WMbgcHj0zwfSvHv 2u/jCmg6N/wiWnTizRoBPqUyjHkQAAhMdiRt4/2kHQmubFT5KT89DsrYeVNUqbWlrvze/wCC sj8j/iF4sn8b+KZJEPl2g/dwxA8RRLwPxx+tZ4lVAqIcRoMKo7VxxXLFI4Z76HQ+E7ewnmnv dWuTbaVZJ5kuwjzJnP3Y0z3JB5IwAD7A8V8RPiRP4idLCzRLHSbbKW9nBwiLnOf9pj1LHknq a9SilGnfqzlesvQ5jw5pcN5dtNdo0tvF83lLnMrfwpxzycUeLL+N7/7HbFWit+HkjxteUgby uP4QRtX/AGVHqa55NyqW6I6FZQ8zIhdjwfzruPB2j+ZPDcSjKg7wD7dP15qZ6I0p66H0n+z/ APEzUvBPj6xhtUe6sdRkS1urRD99SeHH+0uc/TI7193i/jdFZWyjDII71nTvymWIilJMjW/e 3mEkTbXU5BrbF4mqWnnL9/oy+hrZapo5EYF+gjJrEvfnzg/hWRRiXaE89MVnSTbgygUAJalj nBzx36VejKxDcxJbPrUM0RcjcABgTuHJxVu3vREVbPPpXO0aI2LTxCmOcjHTPJqyniGM9Tt9 AawcepqmNOtwsT835VG2sxAH5gD9ahotMx9Y1iMwkK2c+9cdeXW98jJq4rQTLmj3hiyD3NdH HeRkZ3YPcVlPcuI24vE2kZBHY1RfUFjBBbn0rM0M+61tI492RwK878R+IBd3xbnZ0AAramtb mcjEl1EKQAuR6mmNqTbeMKM9TWxBWl1E55cnscVSnvF55JzyOaQzNmv2DccVUmu8hgx6imgK X2nHIPSopLoAdeKBoqTXqjOXAzz1qjNqLBT5aliO5OBTsNGJdeL7CCdInv4nuHYIsFv+8dmP bj+uKu3k3kxNtPzkYBfkAnpwOv51vCk5asoS0klkh/fgLKMjEZ4I9fb6VfedHRVJ3MBjr0Hp XbBKK0Ile9mVZpQrgLj3IoNxK+duSemSK1JEW4uWyrMxHpnA/SpFRp5AC6ljngvkmk2MhkKK 3Ljb04NVZmAcgcg4AI7+9SFhJoGiO2QZ+p3A+4xwa9s/Z9YzaHqyZ4W5U7f+Aj/CuHGfwWdu D/jI63W9NCrIsiZif1H6V5J4q0xtMuMY3QEhlOentXztN2dj6iWquULa7ivp5IJXJm2Bz7qM DcPccV0mlRCFgGwSRg+mc/yP6Gt5nKke8fCrxedIvLeyupd1lMSFLfwnBP8AQ5r2TVPCcM8I vLRc5+Z0Tp25Fc1SPPEqnN06i7MzFtlikgRlJWU7R7fKx/pWvalrByFBZM15y0Z697niXxd8 RXGreJLu1s7p7FbQiJTaDa+SoLMxPcZxXmlrZ6vcSu2oa1eXLSOWRlJQKvOPrwQK741eVWsc MqV5XuXfKv4rlliuJEh/55zSsFYfnkmq2pWdwomle4nLPEEJhcgAZ9Sc/wCfaqjVaaaMpU01 Y5W78MPBprw2d5dRy/wqZCcMOQSB1P8Aj9ayda8L37mR5Io7pGVSLZwMs4IUMzDrXRCtd6nP OjZaHa2lrbXdhYpPbfZpDtxEpGFI4A449OK02t41+V05/h45rncmKSGCCOCUMFAO7PrimKjC WRjnfKcBiM4PX6fhWsXc5JKxznjwxr4R1ssVKJbuNx5yTwMe+SK+b/tWJQpGeO9e7gvgfqeN ifiRcWaNVyxzimCQQugV1Ltyq7sMa9NHEWo53YAuQoPc0ssoTaBhuc7gc8VQie01mWN2igij lRyRL9phSSNsdPlYEH64/HNT201hdTlb61NkCeJrIFlQ+8bMSfwYew7Vm49UFxL/AESez1CO 2LpdIxV4pYwdsiHowzjj9QcjqK6b4v8Ahu58U+AJWgnt4YdNLalNHM5DSrHsjCJgdf35P/AT XZQ1i7EPWSR1PwM8CSeBP7U0q7Az/bBAcNkNBtjKMDgdVOeg61geIdREmh6ncONxvNQTd/tD ljj8R+tXXbjSfozKK94ydEkil8TrdzQBLeV942jCoSQf05rtb7S7N7mOSEqQeQvU14eUpPDN ve/+RvWb5yO+0zyNIu7llIhi2oHPQux4X64Vz/wE1Q8Qr/xUmg2eQf7P0bzMdg80gH8oTXtS VjFanEeMbktIy4D/ADADHHGK5oQuxXamK5pG8dj9bGJIx+J5qIxq3DfrXrtHKiKdhGvyLuz2 zUUKSEgkDGOQKyZaPSPhR4NOp6gNVuo821s37sMOHk/+t1/KvUvEuvxeHNNa4dTLMx2xQpyz segArhm+aZ00KTrVI011ZzUHjLVBa6hEtm91c24I3jG7zDjCBQADgHJOfyyK4lFtEjQ2919o uzcv5g2sfPuzzlWY8qvr059GNOyTPq8JQVHm9nrdq/krafnf5FTUvGOnaHo15rWowCXT9Fc/ Y5pbhmF9dFP7v90EZ+gB6g1+bf7U/wAWrq9luLCW6abUtRf7Tfyk5bHVIz6ddxHQbsdBXlYl 89SMPmcuNbjKUb35dO2r1a+TdvkfNNs32eAs3+ul5Oew7ClFztUknAFFtT597mLrPiJ5bdbW E7YlYs3P3iQB+mK5tjubJr0PhSRmldmzaSmw04yA4kJymOob1/Ac/iKx/sxz9fSsFu2WaGia PLqF4kaqSvVmAztXua9Gs3jtFKpwo4A9qxqa6HRTWlz6J/ZU8HnV9aufEU64trMfZ4GI6ysP mI+i8f8AA6+uYF+wwBd42Ebhk8rXTSh+7sYVnzSJoLtHYAuOed2eKsW+rLp9wsiHKNw6Z6j/ ABrPY5DUvVjuIhLEweNxkEVzt3EyNjtUS0Y0ZF0AM96yZWjRz82M8cVncoRLpUXauPoajOZc +4zzSZSZNbztC+wng+lS3V2F24Oc9cVlItDEvmB4JyOmaJNTdenH0rI0RUl1OTecA4PQHtVe XVZXJIJPOagsqTahJLwx47VW+1EkljzTHcamqi3IwST0xnmh/EkkXAyT9elJxuNOxVl8UXTL gNjn1qhP4juMgtJzzUciK5jOu9dmcE7+1YNzeAuxJLNWkVYlu5Ve/wAEg9jVZr3rk9adgK0t 4FOc1Ulvc596LAUJ78DP0qjLqKngtmrSGZOpeLLHTEJubyC3/wCukgB/KuK1j4w6RblxHNPe sONsC7V/M1rClKWwOSRx2p/GjVJ1ZbK1gswejt+8f9eP0rm5tf1fXS0l5fzyp0CliFyfRRx/ kV1qjGCuzNTcnoeg/D7w62mub67gHnMv7pmOTGPTH949z+Xv3Et6WkaRwQqDA+Xqcdcf570z TYZFqPms22N1U4wZMDccemeP88U7z5AnUYLZIB69f8TTWmg2+Z3ZILtUVSTjjoacdQ3YKfd6 ZxxTESmZz9+VY1ABJzkn2/WkeNMg7mOD1I/+vRcZLJcI8eANxAHJXFQhRLjK8DoSO9SMj8lI ydxyG5Geteg/B/xrb+FdZezu38uxvyq7yBhJM4Uk9hyR+XpXJiU503FHTh3y1FI911W1F1EV JIBHH1rz/wAQaKl6WhkTnaP/ANdfLXs7n1kPeVjyzVLCXw/eoeWeFsxuB95DjIP0rrtCuFvr OKUDOQcKepHQj6iuy943OZqzsek+FQl3LbB3IWI+ZuHfgqG/XBr6A8B+MRpRhs75j9lJCrK3 SM9gT6GsFKzsxThzRstz0DUdASUtPCoZeuwduOorEurZcnGV9R6Vzzp2kdFCrzRR81+PA1r4 pv8Acw3TSv5bnHzEY/l0rM0+B4bVfNb7RORktjHPt6VD0OjcL2TCAFVfBwQRzn6Vk3jviRfK OGU4CgjHp0NNCsU9rSOygFkJCN+AUnBJ6DFJZnzmmjckRLIwDPyTzuOFHXHuemKtEtGkIo2K sXKAqWU5+ZeMcDooOM1HJqDMzR7VBUhRN0HUcM3qc9qaOaaRIqMzAyEnA6Yxj8KieBUDRhSz EEkexzz9a0i7HDUSscV8VpRpHgK9hUhd/lxKW5PLg/yBr5+jWNsnHzHrzXu4R2png4hXkDxk riOUxsDnoCD7EUnnR3RS3mUwXCjMbqec+qn+lelGVziasS20sokaG5A3H5fMx8kn+B9v51pe VsBywUnqeoNbXIJAyqSxxkD1pbeUwSb1YFm6jPFVuI0dPma/vrOOV2eWGXejscnGQWX6cD6f jXrfh/RLHxfaato9/dpY2s1rbsbppYk8oiWVyAXIwzCEKGHTfz2rtw0bRZLfvo07PUnSfXL6 SRnnjuNQlMki7WdleVUJGBydqcYrx7xTc7vC+mwq4BmnmlPqMYAP/jx/Kiv7y5SI73MDSLy+ Fv5DumzeCducnHpXo/hvULJIg13Otqo+9LIckjvtUcsfp+leXg6H1eLj5m1SXNsXPFXjGLxZ Pp+laZbtZ6NbMEhjkI8yWRyA8shHG44AAHCgADJyWytZuJLjxx4ikhUOLc21kuT2SIOQP+BS mvRm76mEVZHA+IL5TfTRyL91yMAjg1moxDgxEZA4DdK5GdMdj9cjLYRkFkncdcsypn9DXT6J oug6hoFxetPG12pwtt5wJ9s4IPrXuu3Q8rmkkcPoGu6bq2m6zqXiCyHhe2shJHEN7YdlOA2Z OoPt61j/AAn1k/FjVbW10xAEALXEvURKDgk/XHFYVfcV/I2oycrpn1hZRWWg2MFlEyQxxJhU J5IGST79z+deb6zrd/repiW3mhKSo/2WBkCtbRqSJJncjK9McYwSfSvOjdan0mW0ouTqTWiX /Bf4Jr1ZQbWzeTlZgsyukkdq0gYt5Q4klLA7gPvY59cdsx3kcFxJptpp0UmnX8oaO2ueXMMP JaTk9Tg8k/3varumj6JQdB3v7q1a7pJ3Xz1+8+W/2oPjNbXD3UkNw0mhaKnlWods/aZezn13 EbvoF96/NrXNbuPEuu3WoXchlLyF2LH7zGvCjL2lWdQ+Yqyaik99ym85diSeT3rK1m+aNFhQ 4LcsR2FdcFeSOFmOkJdd38IpFhJccZGa6JS6CSJXlMjAckLwKtWti84yozWTdioq7O1stMXw 94fjuJFCXWocqAeViH+J5/KmaalxqeoW9lbI01zcSLFFGo5Z2OAB+JFY3uzrWiP0f8B+D9P+ HvhPSNFs4zNNaQ4nuM7TLKTl2A9CxPXoMVLrfioJbOg/cBOMO+5m9M+g9q74zUVY43Ft3OU0 v4lx6XexW14oazY7fOjIJiOe4zk9fT/CvRIb+C9to54J454ZBvSSNgVYeoNYz11OecbMtafr zaY5DfvLduq+nuKu3t1HdxLJEwaM9CK527iRz93Jg4JrKutpycgH0qRlMP8AvBlu/arhuYxk A54qGykNNzGuCSB6kUj3ERBG6obLRCLxFGSdxFMlu1IwGAU9OazLKkt3jqc4qpJdZJO73xSs NMrPeIoJycVXbUAOQRmgopS3uSTxVKS8LcFqYFSe7GDtb8c1SmvBt5OTnvTSAoXFwScE1Slm 55anYq5TnvUiGWkUY9TWbNrlupOJAf8AdqlFiOe1b4gaVpoPm3cKEdQ8oB/LrXIar8b9MgJW 3Etye2xMD8zW0aTkHMkcxf8Axc1nUIpW0/TwqoMtIcyFR6nGAK5DVvF2v3+43N5cJHnbhPkX Ppxj0rohTiiZSfQ52V2c5dix9zmk2YUHOc9vSulaGJPbWbzsMAnJwAOpr0TwXaWlxOITCS0B JRyOOOp/H+WB65wm9Ujopx0uegNIYm2AL+6bYQB0I7VJM5ERcplOm4dqGWV4XJkJCFmAyAxq UwsrnzQSAM9cZFACDJ+YIoBOADVtG3FflUqD82PagZJbtI3MQUEHPTNXNQYWUqxyss07jLFT nb7H3/lmkNFeLy9hLBgDn7gyTxx+tUxf3EF0yiAeUCP3u45PH93H9aQy/Gw1BAfLMfHAcYph tw6lGJOOCKykjVHu/wAHvGi+I9BOlXUu/U7Fdo3dZYhgK31HQ/ge9dNe2KSygnhgfz9q+WxE fZ1Gj6jCz54JnGa3oEWomWGRQyZOD3rgrCS68Ka21vdOGsiRtl9B/C/07GlRmmnFm1aOqkj2 HwuSDHJFhVkX7px8r5GV+h5r2HQ4457ZVcCSNlIKnnI7qfcVEtxeaPQvh34neyvv7Cv598SK DaTPz5kZ6Ln1XB/Sur1/Rjg3FuM9d6j8ea1tzwOX+FW8mfKviuGKXxHqQIR5luGcgMCOTngj jv8AgeuDWbEYmUqDnjBBOCK4noeonfUp6kSyEr91Mk4HHXmqFhpiavdC0aVbITKx80gsCQCc YB74FaQV2kTLSLZxmh+JbXVw0Bj8qWOUxNvA+VgcH8j3rV09XjvbnYm9RICjIDgggL2/3fWr kuV2IT5kmbsWnSzQ/NG6xYG5i3f6DjHbqai1aKTT9UnhuFChnGUzuCDYpRSf90j8vWnHVHPU 0LVqnmERAbpW+UHu4xx/I1t2Hhp1jhmnBVJWbYOzYOG59jgUkcdSx5J+1DfppPh7T7aKFPKm l2EydCwVvmUD0z1OevSvmZLgryG5719Bhf4SPAxH8Qsx3O5eT161NHbRTqyuNwb+8eQfb0rs TscbRKs72gKXJ862x/riOR7MP61oW8/kICcywYGMclf8RW6dzNo0I54pULLht3ftVUyDeRHj jp3rZGZo+HHuX1sONn2eNCdu07snjrWB8Tfipreial4k8MWkyNpGoWtvDNDKgby22pJvQ9VY 5KkjqDz2x3UnywM3qz2Dw239k/CeMOfnXS4E5/vMYyf03V5hcT25aEXMjB23BFUEk4GTwPQD NRiJKOr2Q4K+x02g+ArjWLeGe3voIhMqOiysdxDhdvAGf41+masX3ga/02cRJPb3uVDBoHOD +YFeFhs1oYnEfV6ad/wOqeHlThzyNbwd4Z1B9eszJaskMcgd2bpxz+NZ+mXn2yXWL/OPtmp3 UqsP7olZV/8AHVFe29jmR5vqUyS3c0hcbmct8x5xk/0qq8wQAq+D7c1zs2Wx9k634oh0sRC+ 8Sl2wM7ZFO1cd87zn8a6j4L/ABt8PQeI7mK41i6e2FpNsJDFTJt6kqMDjPJx0r04tR1uefyu XQ1fiP8AFvw34q8PX2gWJvdW1LUYjb21var87StwmOc/eIr62+Bnw1tfgL8KLaLUSr6p9nWb UZk/il2jKL64PA9TXFOo6kjto0XJxhHduxRvfEDanetf3V5Jp0zR/aJgq7mt4ONsY/2mBHP+ 105NTNq9jqMs0d3ZRjfAHnaXEbRwHG2NmJAy3HB9RnvgTWzPuXh5QSdJ25eq67W/T/wIi1e3 itrIOLMaZYtFvu5EcFo41G1IRhmGThensSODXn/xW+Id54R8FmyeYpreuQhI7SNzssrPoAF7 FwMZ9AehFcuJn7KnJo58ROLwyUnzNu1/xf4KK+bPzJ/aI+Ix1zVxollJvtbZyCyn/WSH7zf5 9K8ZYiECMHOOp9TXn0IctNHzdSV5EE04ijZj0UZrS8OfD2417wvqnizUbmOx0W1l+zRZcede XJGRFEvXCghnboBgckgV1J8keYwSu7HPXKKCERcDoABTXQwQ7jkO3AqUy2iK2tvNYLj8hXqv w/8AAba5JHGysIVUyzuONka8sc/kPxFRUlY0prqc74v8QjW9bnnixHaqfLgQDG2McLXtn7IP w4l8S+LJvE80WbLRyFhLDhrhhx/3ypz9WU1pTjdpBOVkfTfi/wARPpVwY/tKiQLyVJ4HoP1r yjxJ47ggZys+wk5+bvz2rpcLGKnc848QeKVupiwlO0gn0JrP8N/HLW/Bt6PsUgm08H5rGVso R3IPVT7j8QaiXYXLzI9v8H/tD6F4rjSGW7XTL44BtrtguT/sv0b9D7V6DZ+K5LN98citG3JU nhvf/wCvWDVjmlFxdmXv+EjtdVXEThZQMmMnn8PWs2fUwjYJqGBSl1cKchs0z+3AT9/n07Vm 1cpAmpq2ATmn/wBprjIbI96VikQy6nt4UjrzmoW1ogevPbtS5bjuQSatvOckfWqz6iW53DHW mojuV3vwPvHjrVSTU0AOD9CDU8pSZTn1iOL7zgH3NZN14kt1PzToMds1SgFzMu/G9jarl5lU AdScCudvvi1otuG/0yJtvJ2uG/lmtFTbHc5TVfjzYRbhCssp/wBhP6kiuU1D47XczHybQgHv JKB+gH9a3jR7ickc7qXxW127JCvFBz1RNx/Nia5nUPEuq6kCLnUJ5Aeq7yB+Q4roVNIhyuZZ znP86fhTgg/UVYieDVLyxikjt7maCOUYdY3KhvriqpnmlBjMjsCc7SSeR7fifzpWSKu9hCm1 sNyfQVq6No8mtahFH5bbJZBGAnAUtwuSeAMkVMnyq44xu7HvHw2+D1mINQe+lY3sE/kJIp/d sm1TuTIzg7iM+34Vt6d8M7GHxXfWiXkqQxwoyg4DuxJLc4+YD5TnsSK8eeKd3psejGCtY6Rf hNbygMt5L9SoNJP8I4QuRqbnHQGEH+tR9el1iNUU3uVG+FUkbjF+cZ6eT/8AZU9/hlOzD/iZ gk8A/Zzx+tdSxF1sP2HmPk+El0FTF/HIeh/dEAfr7Uq/CLVwS0Vzbyn+7kqD+lV7ddUL2D7k B+FfiO2YlbeOYD/nnMBn88Uyf4b+J5pNwsUbOd376Pn3J3VXt4PqL2MyWH4U+JpZWLWtvBEF BBM45OTkYGfanP8AC/W4lED21rK7DOz7SBkZ9DUrEQ7jVCe44fDPxDbIVg02IKWLArMmR+Zq lc+APE7B1bT2ZBjP72MZ/Wk60H1L9lPsQ2HhfxZ4dvbe9sLOSG4jcNGyyJz7HB5B6Y75r6F8 O6m2u2cMl1avp9zKv723lUgo3cA9x159K8jHxU0px3PWwMpQk4y2GalpTQ3SgBRk7ldvyOa5 7xJ4Pttb09fLUCZEOBjvnkfQ14tOXLK57klzIg8Au1jP/Zl6zl4I8o7fxx7hhvqp4P4V7P4e vmjjj3DYWAMnYq2OHx79DXXPyOaK0sdXLbyXCRTQEJcwNvjI7NjJX6GvTvA3iyLW7IRyvi5H DBvXoR+lOlK0uXuY4iHNDmXQ8S8YeDo77WbuS0j8ppJXJlZ8Ak85Axzz9K4u98IXWmiQSIsy 8nchPT6VxN2Z0wndamFfWjQp5bLJjn5ZBjHaqFpfz29wTnBjjl2EdjsYKR9DitIOzTNZaxZ5 t4Z0GXS5pZDIGaVmfOOcsScfrXZ6aJDNKEDu3AJVT2zz+tazfNJsziko2Okt7PUBbvH9nkeG RPLZQpA5PGe/BAP4VpWvhJUmgvdTvVtvs7Ga5uWbKGMcvvz6Kuc9sVKnbY5quo6DWdKlfUtf CW4tGiaTT7e2fOwbSoGR1+QBfrk+leS2Px2i+1Ja3lxtitS8UCyEgIGkaRh78seT/QV6apfu 7R3Z5M5e9dnkv7RXxP03xzqGl2umzC5jtA7Sypyu5tuAp9gp/OvHhciMjA59K9nD03TpqLPG qy5ptl1Losu4DOTxU9vqUiHk/L6elbcpkzTXUiHweR9KVVktsyWx3Ix3eT/D/wAB9Pp0+lXF WM2Wobg7DLE+Gzhkx39x2NWQ/m72jwrjqM4wa2RmaOia7a6ReRfbJxF5wKqxPAPXk9vrXk/j O5fW/HWplSWMl20SEc5AOxcfgBXZH4UYvc+oPE0q2HgVoExtaWONR7KrA/zWvE/EEztqSRRY MqWcgUZOcyssY/ka5Ma/cZrQ3R6x4evJ476wli2tJCoYJ6ADgcf7AX6e9dciia6wCBGoAXvg dQP1xXxOSQTxzfaL/NHqYpv2KXmdCbtdH0S+vW4W3t3nJzjhVJ/pXjGjzrp/hG2i3KbiK0Vp ASM7iuST+Jr76R5CPOrgGa8ZWxnp+XWpodPZwcHI/lXMzY+8dE+D2k2ZXZomnF1bBaWLzmH4 vk12tv4HkNu9tuBgdNjxogVMEdMDqK7ubTRGCietfszfs+aV4V1S78RrZxLuO2JhGAXYc5zj OFP6/SvX/FmsXc2oPDEqfYoV4STYBcS54XLHoO+OevqK5YrU9TBwjUq+/sl/W3bf5HN6jHLe COG5vYbyCCXzJoLeUtumPCoA20FQeSN2T8w9BWVqERtZUN232qxjnV5ydubqZjlIztLYC5OR zn5vUCra6n1VGW0Iq3b1/Lqnv9kq3Wq2+k32r6jO89roekk3V/MJSGu7hvuwqcAMM4Uc4zn+ 9mvh79on4y3M8Os+IL2Yf2lqBaOBFP8AqxjGF9lXCivHx0uZwpLqzzMxklUUeqSv6vX8FZfI +HJrp7maS7lJaWQnaT296qseuevrWp8+9T0H4NfBiT4r3OtajqN2dL8IeHLY3mqXgGXl4JS3 i7GR8Hk8AAnk4VuY8UXkNzqFzLbW8dlbl9sVtAMJGo4VR7Acc8+vNZOd58i6G0Y2VzG06yNz c4K9Bu59KpXz/aLptv3F4XHpWsdyZHSeDPDz6lexrtJUHlgOBXtusavc/Cv4c3lxZTy2eoa2 v2OHymKnyh98nHb+oX1rnnJSlymkFofPBikJ5Rhn1GK+0fhl4l0jwH8O9K0aw1GC6ZIvtF79 imQs0zjLgsM9CQoPogr0aFk2zCrrZHJeKfH7T7tk26Vs4JOWXP8A+qvMtW11YmLPIZ5vrn86 uciYx0OWvtWaRs7sDrjOOTWPcagWHytxWVzS1iuJfM65ye+c1tab4o1fR4BHZatfW6DnYlwy p+QOKQjbtvip4nhwU1i5LD+8Vb+YrtvC/wAe9bSdIdZeK+gbI84rsdOOpIwD+WahxuQ4I6HW PjdLoWx7jS/OhdN6yQXIcEflWU/7SligRm0q5O8ZXEi+uP6U40uYycbCp+1BpMR+fSb9cHnl P8akH7U+iEf8g3UPyT/4qqdFi2GN+1BoxPyabffjt/xqrP8AtOWaZ2aTckH1dRTVECjcftN5 YeVo8gB6F5BWZcftHalICY9LjQdiZCP6U1RGmZV1+0Drs3KQ26DHqW/wrHvPjZ4kuc7Zoos/ 3VJ/mafsktyrmLdfEjxBc9dRdfZUUf0rMn8SarecSahcMP8AroQP8K0UUugrmbNJJIdzOzHu ScmomlITbubaTnGeKuwiJmxzTc96YhpJNJSAacY4603cQTzzSGGSw9qnti6tiJSzHvjpSZSV zW0vTbV5g17dwwkt8wZhwPX0r0Twz4i8P6ZplzZ/araRZGV8+eEIZc7e3PU15+Ic3pFHXSUV ueoaX8SdDFz5y6jYxZjWLablMYBOPy3Gujs/Gmh3jhzqWmh+mVuoyf514ko1E9Ys7o8r2Z0F hq+l3HEep6dgnr9pUc+la0OZX2C4tpBwceYCPY5FRTl71pI2hDm2ZdXRrxkygSU5xhXFOPhr VUkQi3TyzyxMgyPbiuz2kTT2UkXpvDOqTWTi12wTjlXYq2DnuD2qPRtL8RtM0N7Yxybelxbu Np+ozwaHUjbcPZyR0FtpF3NIEFv3KklgACPUk1oW/hq8KnFkz8kcEc/rWXOilBgNMuFYobaZ TnkNGeKq3GhbWExs3DqNvmGMlgPTPWhNFWdirqVpPFGohXypCR/rEZgRnnp0+tU4JZdQX5VN qFJDGaLliPTnp7+1MFcbcWGlTv5l5cxvKW3BgoXLg5BGO+azPFV4NJ8Aa5e2t+0dza2MtxbM 3JV0TcmT35UD3qWubRmsXbU1fCXiW3+I/gnTNWhVfLuocvH1KP3X8Dxn6GtG1tPM3vglsncv cf5xXhTj7Obie3TlzxTM698Py3apLaYhu4G3xs65BPQg/wCyRwfY+1df4au/tlksyqRNGjK8 THJC5wVPupyP171tCV1YJRs7o7bQLwMjLu3Kig9eqev1Wreqw3Wm3CXunuI5GcMzD7oPZj7E daafvBG2z2PNfFnxotbXVfstpp5vgCERopNvmOepXqcfX/69cpcfGO8tbm4jNtFLKELtEkxb ym7Kz7cc0Tir6mEabtoY2u/E7UtStUf+ybFuVEjNM5ROeRu2jLH0GSO4rAuPEVwHeVU08vna ESOaTaSDtQkMMnoCff8ACrgoWsW4VEtHoZFvrOtWauYbfSIgnJW5hkbbn1zKTnJ6Y9KmtPGn iXSp8XGtWlqqoWMMFmH2c8L8zdfYVTlS2sT7Go1ds6XT/iRqtwsgl1m8JCYQQ6bFgn25J3fp XPeJJRrdncwajrGvT2sy75Y12RBv9klVHbtn6nmqhKEHojOVCUlqzC0fUbjwzC9lps0d/pZf H2eSZmYk9QN2c9+On61w3ivwzJca3eusey3LByFHykfX3/nXp06nNr1POr0OWy6Hl3inw+nh 69QRTJcW8yb0ZDnaehX8Kw3IOMcg17NOXPFSPnqsOSbj2HxzEJyMD0HanC5YHBO5ewNWYliG dxnB4PbNaFldshIDnaO2aAsacStO3mLJiVR1POfY1YQvdHbIrQzL/CT973U9xVpmbRk+KLaa a2hCKS0ecjuQf89K5fSb2C31a0ubqFnW3mST5DhiFYHFdlN3ijCS1PbfE3xF0a98O6eI9QiG 5nlZGIDjIUYI6/wn868zTxXpa+JZLmaR57IyW4IhT5ikbbyATjBLcVzYynKtCUYbsuk1Bps7 vSfjb4b0y0U/2VeT6gpIEvCoF6AY3n+Dj61HbftAWFtKSdKuXTJKgSqOO3b0rxMry2rgqs6l WSd9vI6q9eNWKjFGvfftLabfaTd2h0ScpNCYiHlUjBGCCMc9a4SX4vWkrjZowbPALSAcf981 9HI40YtjrctzM7FeGYn8TXRWF/MWXywqD3NcrZsfrXbaYiN90AdeldF4X8JnxDrMNlEx2ffm kA+4mefx/wAa9CXuowR674n1SDw5pNvpFi32e5uF8m3CKSIl7uxHQAZOTXnFvYwf6MlveIUK mHTpIIizhuBJPIrlMn3GcY9ErnSPrMui6VDm5b82v5rXqtOb8BrWiJaW6aRNkxfubVLgRx5f A8253FyxwD/wEjn7tR2mo3FmIjaxx3oaUW1gn/LeVyQskzMeV9sHjI/u0bbf1/Wh7SSqxaq6 Pq/z/wDb9PQ8I/aT+JRu9Qj8LW94G07Ryz31wjfLNcj/AFje4TlFz79cg1+cfxf8cSeNvE8i o5Wxg+SNM8BRXgX9riZT6I+NrS5nzd9fvODkbc3AwOgFbHgjwdf+PfE9lommwvNdXL7QFBOB 3PAP8j9D0rrb5Vc5Um2fcn9geFf2fP2UPGXhe98Rypq3iApLFEkGUvZEZcmM/wDPNSoUuCRk MATXwZqX+kSbYR5hJwMc5NcGHvKc5PqdTtaxvweBfEA0XbY6FqN7dXXX7Pau5RPcAcE5/nVe 1+CfjyQNO3g/XY7RCS8rWEqoAOuWK4GPWvSpwk4uVjnlON7XPbfgz8ObaHXYrtLm6142MXnX OlaUSFTKnYrgIcnd/e64PHBrzv4ta9qN94rvo9RmSZ4JZFsIhgrZWxb5cgAAuRtHPPA9s8fK 1P5GyZ5dqsZsb1TuGJFDFRnKn0b1PqabFcMp3KzK3qDg11tWMk7l2LXr2A5Ny8i+kh3VJH4l glfE48k/3l5H+P8AOkrs1hJRepoSXdrDaNK8itGF3Erzx7Vzsd819MzGPy1Y5VRxgdqqmndt l1nHRIv2y4CjO7nirgjaY8DAFbnKWYbf+EA59DWlaxKVMbxDjJ37iGz/ACpAakMT+SseSoYh eBkDJwSB9OfwpuqfDuDVCTbyR286DgiUFWHp9f8AE1cXYhq5wut+GtT0GVobyHIU43oQy/mK yFj3Z5x9a2TuZ2EO+Ig8j3FKl465+Zie3NMRONVna4gkmfzvJXaqyAkFQSdvH1NQ6jf/AG+7 eZYlgVsERoTtHHagEVw7cgZ59KdyAM80mMA+3kgH60wykN7elACtM0kZUKACeSBUOB6/lQAE bmwq9TgdzTQcsAfpTECSGNlbCtg9GHFMVmB4HX2pAa2iaXbaiwiuLkWTH5g78grnBwMdfqQO DWW4M8pKLuycKAoGfwFRcuxftdEeYt5rqgXnaDyfaugtdKS2jR4xhicrkA8A459elZSlrY3j GyuyM6RBkq0CbvpzU1vodqy5Mabs9QKVwsaq6PBcIdlgJZcACOJCxY/TtW34f+G9xMoa5gSx DHlD87YzxxnFYTqKJtCm5HZWfwz0qNwXt/OYHIV/uj8BjP4102lrY2Nw1pFY/ZlQbmkEQWMe uT0FcEp8y1PSp01T2C98X6XYErBuvZR0S3XIz/vcD9azLzxbrVzCrWsaWUJZlJHzyD05PA/K iGHc9ZaIqpiFDSOrOVvbjVbuZmfVLxQWBz5zcH2HatOC71KO2iI1rVlz13XbgE5/3uR/j7c9 yhC1rI851J3vcT7XqBs5bd9RvWicjk3L/Kc5yCW4z7VcivfEWm2sUlp4q1iJk5221/IhwBwM hufyo9nDqkNVJ9yxD8R/GltJ8vivVXc/eeefcSfckc8cVZuvi38Q47eJYPFUz/3jIkbZ+uU9 v1rJ0KT6Gqr1V1Et/jL8THkUnxAJSOhNtD29fkroNP8Ajh8RYogra1byFTgeZZxH/wBlFT9W pdivrNUVfjr430nzJLe/smmuTl43tAyKcfwjPU+mMZxXOeLvip428ZadcaZql5HHps2Umigt o4d6+hIGfwBqfq1NO5f1io1Y7H9nnxDHorp4auXjjtpMvakNzuOCUOfXt+I9K+gLi1ltJWni wMgbvQ+9fO4+nyVW+572Bqc0EuxPBaCUidQwiaQhG7ZHUfhVj+zTDcC9tlVXyQ4B4bjv/nt7 VwQlZnptXRuaUpEmYiUSUbkYdEbOCD7HH86u+Mp5F8GarHDI9tcNbSLHtIyrFD8oycc9q6ft IztofMF1qM9l4NtYo4EsZbu+bZPEA1w6rGBJEW6gfOh7dT06VmXJjYohQXN0h4tYT+6h927M 59+B71c1qVAr3kKylS0r3zRsV8teIYfRRwAxycZPoaUvFJtjmuGuIiNhitPlRO+1cdegyRWJ 0dCQWLwwO5sI48Yyjtu8sHHI3H5mPrip47FkkjVZLS0xwXzx0yQMD7xHU/40iWVGv0+0Hbee W21Y1MaE467lXk8DJy1Tm7W4L+Vfl1AVV2x7Rj0XkYHqa0RDM6/024IR/wBxOJMMQBgkdgox wPU+xrGuYjbxuskRtXZNgZOUJJ6DtgfWumE2noYSgpKzPJ/i3EY9WsLfbHuEBbdGMb8secfh 79OtcK9q8PDqVY9BX0+Hf7qJ8Zi1++l6jNu3BNSA7VxwAfSug4iWNOOTnPUYqdE2DIOPxpAa 9ldmJVzg89cc1pNJFNEI3/eEdc8YPtVITRV+e3G24bzISP8AWensf8ayNX8OJdRvc2xV2HZe W/8Ar/zraEuVmMlc5eTQr69k3xQM6DjfkAcfWtC08EXzruLRpn3Jz+lauRmkakXw8kcASXoQ nsI84/WrcfwvL4J1Dj2i/wDsqnnDlCX4YAPj+0MKeoaPOP1p4+GcUTDddyMev3QA36nFJzKS sadtocFqoQRDjocc/nVuOCOH7qAHPYVz3NT9bIIpZSI1DO7HCgDkk9ABXt/hPRLbwD4ce5v5 EjuJAHuJCeAf4UH0z+ZNejVe0TGnCVSSjFavQ5qPVbjWJtSGo35MEoWWQ2kpjit4DjapZxgs w9MZH1NZrXENvrEI0y3ikuJYNsomHmJbWozgKvGSwIweM8dd1Qfa0qfK3TgrQtr32XXu9P8A wIyroC0ui91DboJ7di9u+4Cys8ZIO0gl2+ozk9d1YHj/AOK8fgDwINTtbaC2v71HtdCj8sGW CLGGm3EZAAOB6scnIrmrVFShKRpjk3hubmdnZL9X80m/mfnV8dPHzaVpsumwyE3dz807Z5A7 LXzZk4YtyznJJrx8LG0L9z5Ws9bETADvivdvgT8b/D/7PXh7XtRtdIl1zxrrFm1nDdsxjh02 FuoQYy0h7twBgAZ5J6Jq8bGcF1PMfEHxq8QeI47KDW7htd07T4Ra2NnqIMgtItxIRCCDgZPf jOPSvQPgp8YtD8BX0d9J4Ik1S7To8NkjcY6jcSR3zg81jGDg1KLLdmrWPq3Sf+Cg2mWFnHFD 8Ibz5sKkrQbAx6ksdwXp9BXmX7Tn7b1t8RfBD+HtH0iHQ7mYETJayb2XPBDOOOOeB3rt9vOc eXoc0aUU+Y+VPAPjnWPCct5JpMpiFwv2dypIaVvYg8YyQT7muf1XWbia8eRJTNMzmSaY/wAb n09h2/8A1Vild6nSnZEXiKe51ZRqUqlHuZWkIIwWY9SPxzUGpW02g21u1yAHlXdtzyn1rRtS aRnZrUwrjWGlbaoLfSoVS5uOg257mt1HlMupp6Zpkz4E0xdAciPPGa6W2tEGAqjPfmk3qWjV jtkXA2ZJ71bS252levpQBPb6csRIjQLu5JHar9taMWA2nGDxjimI3dNtpUb5V+fnqOR/nn86 3rW0jgi2yoCGOcAcfSqBaD2sY76VInhBTOACMj/Pt0rF1/4RWepSl7cfYXZeWCkfNk5OCTkY 28jvQrpgzz/VfhjrFgzxxRNdJn5WSNl3duAQD6/lXPXfh6ayB8+GSJlHKspBH1rVMzsZbW+G IGfXmm+QQDVXERMpHFSkSNGGIyo4JxwPbNIRFn14oaRUQgKGJ65HSgY152MYUIFX1HenQyPH MxCLIQjLg4IGVIz+HX6ijYBkErQyq69R29R3ocGR2ZtqknO1RwKLgRlcHgc/rV7TtOe5mUOh WNuC/THvUt6FJXZ1KzLp0elxzQZdbfzQIsjkSSEHB9s/gfeskW0ckztCiwIzEhU6DPbmsUzV 6D4dO2sc5K9a6qy02XUIop4toAXHlrnjHGP0rKq9DSCbLlj4C1C9dp5itsvVRnJrqvD/AMOI obdWmD3ZHIBPH/1655VdLI66dHqzs7PwylpATtS2jVeWAChff2on1bTLRD5DtfyDgC0G4E/7 2dv61yrmm9Du92mryM9vEt7euIra3SxUnHmOPMkxg8jOB275rOj06afZJf3Ut3KDu+fGAc+m ccjsK66dFR1e5w1K7notjSZbGyt5PtMUe9huGB8w5zj171lXF5DcTl4YkjQH5VlYbhx0ra9t DnL1tBY6pu88Cxcc+YzEhvoOc556Vl6jZ3GnzEBHlQNhGweT04yKALf2GS6sj5pMXQ5ZfSrV jpcksAOV8wn5QgweBxSuUSz6Ms8SkjEg4bPHvwaSz0tpE8maCORFOVfaMk/XqenehoZIvh4B yS4hTHHJJx6VjTadcWbks3mo5O2TnGO1IpCpbTh45iyuVO5cYx/nipppTcBWaMFi2W6cfSpK JQ0ChZBFKbhDjeSAOg24wc9jzx2r6e+Enj+Lx3oHkXEgGr2ShJ4yfvrzhx7Hv6H6ivIzGHNT 5l0PTwNTkqcr6nZw2jW5kRh+4kfJA7Njg1p2Vvy8MhG8HlSOoPpXzKPqFqaGl24tLk20i/uG JBP8iD/nmuB+JnjPU7XUvEPhmLyosaYrrdjO8E/eb2+Vlxjng+orvpx5o8z6GV7S5T51tLY+ VKyytBZo3l+ZjLyN3Ce/v0HTmtGKKOFfsyWwgUgAW6gs8hOcAn1PT2z2qXK7N0khL3zHvfs9 ztBVRi3tT8qA5G3PY8HNSR2ssF27SNFbmJhH5dr8zjOcH689OxFS1Ye45tNkkeUGCZZTnJmk CY6cBepJ5z9BV9bOASDZ9jt0GyNRgvt7lc46nafp2qLgVDbmO6Hk3ULAMEIVODjPHP8Ah6VL PpO2Nx9oikllkClQudvUFB/P34q0yGix/wAI0rMWEEcpODm2lKNyeFHTPBHr2rJufD90jkQy C5yQn2a5XDHavIHH3QMZOB9apTXUjY+fvibcQ2/jFGaB40htkUocnDcnIGTxzxXKXepwXcCG IFyTnkY219bQi+SL8j4jEy/ez9Srnd9Keg45wa6zhJkAPP6VYRMjkZ9qBllQAQKtWxKPxyKZ JrwbJHw6/LjkGo5dNSB/NsgInH/LPJ2N+Hr71SZDRTtjBcXTPF+6ukP72Bhwx/z3rYhuYpVI KbSOGHcVTZFuxegjikOBiPPc05r+1tS0TTEsRk7FzinFNg3Yo3er20J3Mkzof4toz/Oqp8QW y872Qf7SdKvkZNyUarb3IBS7gkyOBuAP5UZzggq30OQawaaNEz9r/hX4TDO2t3i5iiz5Ct3Y dW/DoPf6V1niDWfDWqiGDU72F4Yn8wxOGGT0HT05rWVaPO7sKUp0pKcN0ZaN4Pmk8x9StHeS XzpyzuvmkZ2jBbgDPTkVDPpHgu+8xZtSsSbiUS3JW6ZGl252DIk4AyOOQcdOmK9rCXVfeejH H4qDun/XTp5L7jP8QJ4E0rT72+v9Z02NHy93JHMC7xgHYiAMTx8uAM8qMAcY+FfjV8VG8T61 fa/cRi3sYV8jTrP+GKJchFwPxJ9y3qK8zH1LxjBdS1iquJsqj0jt+C/BJI+HfGuuy+Itdubm Ztw3557mueboaILlikcUndmv4Y8PSa/dSETW8EUADsbmQIGPYc/TP4e9bd/4WuSVVdR0ohzt wl2jMPcgdq46tZRqcrT+4cJfZO2+HHhHwCqwnxR4m1bSpyW3mztv3ec9nCsSPfArv/Ef7UGj /C21GnfD7xF4i1udAV+1aldMtuv+6gwx/HH0NdSpUqsPe3E5T5rLY8A+Jnx08bfFe6WXxL4g vdRWMFY4pJT5aA9QF6AfTrXm17frZQs3BkI+UGtoQUUooT7nQ+F7i3h1PTLW+kMGnSxpvnjG WAZhvx25/wA9avSaYupX7XErBbdBmR+2BwAP5VEvdTYzRsbVL1m1m+TyrG34toSPvEdPy61w 2t3z+INWkmkOVJIUHsKVLWV+xrUd4pD7fRI0QHaN3WrUemrjAGB610c1zntY0bWxwAoAz61r WmmFSC2D9O1NAasNmGcEDg9FFX0gjI+dMHB5Bx2q0R1J4YQrDao5rVslWPk4dzzj09hTGbmn 2Z3SsgO8t82ef8+tbdnpqSMoY5J684poNi1FawWpcSKFYkYLZ+X6dj1Hr2qy2nwmUgsQGwCR xj3/AKVQixNIbaLClWiweWP3R9a5LWoLHWL0pJbCSG1XdulGC7tlQPoBnj1I7imCOL1rw5pQ V1eEQM42l4eCFwRnnNcZL4fsEvHDxTTwkHaqSLGc49SD/Ks27A0ZV54PuLZt37yONxvj81Dk r2PA/XGD2qmdAv5vKiRfNaViUjDHLHpnH4H8jVKaZNuh3Pir4Baz4V8Gf21NNHdXSsvmWluM +WpOD15Y8g8DgZz1FeVi3nL48ohumDTjNSV0EotOxILGfvsUf7Uij+tPW07NPCnoPMB/lVXF Yetnah1Ml0ZE3AMLdDnGeeTikjEcBLLbtIVOAHbjv279KLjsW4bq4ljPl2scQ9UT/GnQ2F/d SFmLLFvLeoHt9OcVDLR2OuxN4m1gSwwsqLFFbwx9SFRFRfqeK0tF+Fmo6lcqCfIHO7cMnA7+ /wD9aueU1Bam8YOo9D0DSfg7bQOvno1yw/56dPyrq7LwLBaqEWNEQcnHAArhnVvuelToKOxX vdb8PaMGjEwvJhkeXaDzefQt90dO5rEuPGuo3HmQ6dZQ6aoA2vPiSQgjOQMbR+ORUwpyqavR DnVjS0WrM270+6v3V7+ae8yv/LZtyg+y9Bz6CoorW2tJFHllQWywRvuivQUFFWR50pubuzX0 3SrfUrmMF2hhYYDHJXPbPU4zWh/ZflSMoB+RhhgCFPGetMRj6nphnmDfKgPUkk8/5wKpw6QG QERlmzwDxmoe5SK0unTwybGiZCvPyc4rV023urzEchkCqMqVXkHHfp3pbDRsz6eSUgt5ZXBb afNXb7ZwCefxqqmlymWN2LAA4yOnv+FJDNaOeIoFXdIoHK7MlcH1qrJJdmV/s/2Xy2/5ZyIV bOOCG55z2x+VWIbbXM6ERzgRydHC9OM4HQVXvtktxlZJUUEAhFByvpyCKi5SKPkhWbZFsXPT NWBZGQfMMZ6jHWpLRDJBuXETZPIbcOlaPhfWb3wfrltqlmds8RyVJ+WRP4kb1B/+v1Fc1RKa cX1NoNxakuh9ieCdasfHnh1dSsXyrkK0Tn543HVW9xkfUYPQ1pRAwMsUinzIlO129PSvjpRc JOL6H19GanBNGnEPPhOPlkOCB256g1wHxD8N2F1YeJNbmuHtr+a1htSzHhgG2qQOoPO049K6 KdRxi0W4+8meHz2U1q0VxJaGB4lEdpEoyq5PJx2Y+9VZbRra6YLcvE8YxdXBQMB3Kp+ePXnt UxaN2RRwiIgbGtLeMHy485kk5++5P0z+PTNaJSK3UZZNKAG8vjMgUZ5P8WT2Bxz2qm+iElYq wxPfIVt7WaRIwzLLO2NmTks3Tlsd+lXo9JurfjFnbcAhWAYxLjPYHk88n27VDdtB2Y5NNujF MoubaEqm9s/8skGeOR1I/H9ac9nKUmWSGzYsEkiIwGiXdnncOScYGf8AGncTLF15Vg5aWC50 tO7RjcEG3gehLc9x0qJnnW1BfZe2mU8wwctGpHyxKOgPTJBPWmtTOR8rfFzUhf8Aj3UHXO1F ijCn+ELGox0HTp0riydvHQ19tRVqcV5I+Bru9WT82KkjAnJwPSrkaBxkVscxYjhDAA9atLAw HUdqQIkC4wDV61VFIyBn1zTA0FZZCMBVOKtwZA6Zx3FMkiurG2u8GWMCQHiQDkVy2s6pdWV3 Lb2swECYw3DN05H55qo6siWhWW/ubnbuuZJVPVXPFbdtIxi37CF4Gfc10xMXqOnm3xYw2c/d x1rD1DdLL9whFPUA1YjPms3O9RyRyORVeCOWJjsmaAjnIYjn8KCj9GfEP/BUmO3jGm6dY21r ZxjaBFE8hA9M5A/Kub/4eE6dqE3mPAEBwP3kEhP6GvmKlGrN81j1I+yhpc9S+GXx2v8A4saT c6hoWki8treTynlw0a78Z2jdjJAIzjOMj1ra8VfE6XwjYtca7Z2+mxjHMt4ik/QdTXPLDV4r mcTTnpN2UjjvC8ln+0drJ0vwv4i08aqFaT7DNKdxVRkngZHpkrivlD42eLruz1vUNCmR7a50 +Z7SW3bGUkU7WHGQcEdQccVNCE3NKasKUlHZnh0kmSQTnnknuaiJ5r2zkNe0XTJUWE3ciOeW KrkZ7k1VvVt7O4YW91LOF/iGVBrCKk5PmWh0VIwsuUgvtXvb+NY5biR41GFUsTgVm+S7tgAk n0rbSKMkrjn0qcxltpxXK6tE4Yg9Qa0pzUnoOpTcVdm54ZePULBbO63FDxG46oa7lPsc01tp An8q2hHmzyPw8pxngfmK56t3LlQ6aSs2YfjDxEL5/sloPKsovlVFPGKxdOsi2JSOvAzWsFyR Im+aWhrquBg8D0q1DaMzDjNNEGxbWoRQSvT2rXgGVHStkQWxGoUEYznqaCI2BG7OfQ07hbUm thH5qIz7IyQGbGdo9a19MtXkjDPHhieBuzj8qLjOstdP8tdijEvG49Bkccn86ntI703if6Oq QKTuaRvmb3UA/wA6aYNHSwaXHcbZZYiHHCNIPr0oezL8li5JwD1x6DFXewrFae2jlHyiQsQM KADyPXLDHb/IrPXw3bTkvIZ43c/vPLUPnPflgM1NyrIpXfhPSoZEWSy1HUQrcjzo7fIx06Sf 571hT2E8MrGw0qz0znh41Msg9w8hYqfdNv4VAGPfeHr0TPNKZHndtzyu+5mPqSetMtbCdZ3S 4tkkjx+5cQguDwSrZ42n6dcdcYqWr6onl1uaV74j1/XtLn0O/kYWskbxv9lyhcFD5IY5wyxk KMdx19a86n+H0Vo/CNI4P3gvFVH3SmrlOXwUFOTCGJBAyp44xSw/D2SSMZiZcfeJHT/P+NVz E2Nex+HcaoNyv6Egd8dK0m+HQkARVZHU/Odmfw56cGlcdi2vgGJA6bAxjwduCAfb3NX9N8Fw 5CiIcjhMcgfWlcdjovDXh/8AsDVbbUJbSO8ETEeQ527gVIPI6deD6joa9Om1rQI7QTwaVqKy nny2eKRR/wAD+U/+O1z1acp7HbQqxgrM4/VvG+rXLGKwsIdOjOQJs+fIRntkBQfwNcvqEFzq Sr/aFxcXe85IuHO3/vgYUflWUKKjrLVl1K7lpHREcekB4V8vCIvy84xV5rAOF25BCgHcPbtX SjkN3SIUubcW8ok8yP7u1QV5z+veh9MgkUA5Y5O5doOec5B/x/rWiegiq1k1u0LW8IRBtErG Qc++ByO/rWu9pNPH5kMEj2gUfIXyEGcc+/8AQ0hmXJEkJZfs5dAeei8egODio47dJGGzK7jj ay4I/LrWb3GaEVhvcFlD8YOegq3/AGXDErSxgQIqjcxc8kf/AFz0pMpFJbuCR1XA6dSvaoJ2 DSqwUsgONp5BqWwRrqunNAkqo0bg/MBk4HpjH1qAatZoJQFDtgIxZRyM9O/oPyquZIpRb2Es ZdNvLtE+zBYQPn3vtA7ZH51LqVnYQyyJYyRSqThTM/zY/wAikwMx7ZwVYtEBjojAg/lSy2E8 OSirc88hckdOvvWbZaKEHhyQFZX3qM5YEHIHrT5dLa4kKoXVMd+a55aG8Xc6z4YeLrr4aa+L xTPcafNiO7th91l/vgf3l/lxX14Bba9YW+o2EyT28sfmJKnIdexrwcdTtJVF1PcwVTTkZDCj pvjHBHKA9/bNYfiWyOtJNANiSyR71Mi7lRhjBP44P4VwU1d2PVnLl1PHL7QNd0WeTdpVxqk4 DmV4ArYOMkqpYduR6gfhXLpptzeXyKuh6i0KSZUSQbgWPO9sHnPY1tCnzK8WW6ig7SLcloL6 Yy2em31xPEAJZZbZwQ2eAFxwo4PHJz9a0YvAl3aZuVsLvV5WyweWDajv2JUnOB/+oUOnJaMF ViTp4V1Ewh7y3vo5OCiRRYLuO7E8ADsB71dg8DSyyGQ6Lf38IXdmVsmR8dSN3QYHv+VJUJvY Uq8Y6so3/hmTT5IvtXhe8jCLudpogpkc85JzwOeO/SiXwtMFMkfhnU3lMYdnVguZM8E/vMYH J9elaexqRdmzP20WropXWl+J7eUCw0LUmi370W7aHazleWPzgk8jGc4rndT0nxicyaX4aOnT qciWe7U5YAhjsAwT1/CtoUYprmZjOtK3uo8U8cfAfxa1leeIGT7ZcMfPniT/AFjBiSWAx+le NCRlYhh0OK+poTU4adD43EU5U569SYBWAwOtW4FboB+FdByGhDGCBnO7rgjt9auwLuwOppAi wbQkfd59BU0VuyD5gR7UDZcitwGGQcdgDV6G3Yq7bgoABAOeeegoZJNJEueIzx0zXK+ItF8i 5+1rCTHLySP4W9/rVwetiJLQyUsyHEkaFVHLjP61p2twUYKWITIGDzXWjAvRxieURg5djxmn y28udu1WQ/38c1QFS90oPFuICt7c/rWdPo8sbZKBkHUkUgOPYrG37xsOeiDk5qZLkqwQKcA4 ziuOx0I+5/hrL8edY+GunaR8Lvhjd6HoFtCFW+uFXz7hmGWl3S7ASxJbIXHIxwBXz38aPAvx P8Lass/xF03WbO6lyUl1BH2Seuxvun8DROV2r7CUorRbnX/shy3XgPW9d+J0902nWeh2c9pb SAfPJPJGQ+P92Nj/AMCkj615J4z8WXfjrxRq2stHvu7+4kuHCfdTcc4z7Dj8K4pNTrSkumh0 RXLBIwJbVokGD5sndYxnH41H5RVSJGGT/AhyfxP+FaAh27Ym1R5af3V71GBz70my7E8Vt5h+ tdBpGjo0is4AxXFXqcqsjqoQvK5t3N9pOkQulzsY9dnU15j4iksNZ1FjYQGKNjzk8fhWeChU 5nN7HdjalJwVNbnT/C7TNGh8ULHqR8y1UAgHgE45rv8A4z/DTT9V06LXvC7qsttgywocFR6/ Q9/Q8+tTVryp4pKXws5oUVUw8mt0eK2Vk13OyyKVCffB6/StooqJtHGB2r1WeWTWwV3GentW zZwZ460IGacVo+0bU57d6zdQ1S80mdwIftChemMcHIOD07/WtUQR2XjKI7BcWUi+Y2EjZipf 8cVNB4g0+4vF/wBJW3jY/dYEkewx1pvTYpW2Nj/hJNO0nWHjDXE8cLbRLDH8r+/XIH4d629F 8USanduoNzHKGyyMrKuO3J7VLsB39jdTQCCRLmJ2P3lRj5gA9c4x1/nW7b6pIrfuZpY93LKj kA9Oc1SAnmnEVwY5JRNMRuCk4IB6EjmpLeYhpF4DZwFP3scHPTjt+RqybXJLuOJSjRyBm/hU KQSOmR2/Xt+ZY2V9FIxQqIiu7LAFW+oIx0JpAaMdlKkZmltrR1RsYCoMH/dUg+gzis+9topJ lWOws2cqWV8yHLDGQ2H56Y9s59KQynJ4fa42MIVjEjHCNyF46Dk5/GsyTS7dATKSquAoZORn Pr3/AP1VIyOx0CGVpNs2JF5G7vgcZxUNxokllcxpPF5uWwxBwSOTkEfXqeKBmbb6LEqNFcuj zdSCMDj6HvUtrpqrwkIDRsP4+R6Y9+lAGmumRocrGGz0CjGDnqaspaRR322eN5kkQ+UAcAnk DnHPbgY/CgCz/Y6MFBiUFhliB93AJyec4qdtHhtoE2hHlY7cp29PrxnmmSU5tPZcklZOoGSB ip4kkhQpdOXR3GcMduemTn64oK2Kb2aW1zmMKEK53Me9QvpcFwd5YtwST1AHH58mpZS1Gppy oVJtgAVBwnToByfXv+dT3OjgQPGsJ82QoUKsNqjndkY5yMdxj3pWAfaxLaMB8iuSNznOB+Xt ViNnnZYlVOflMrAA/XrikmMSTQ79I/3V2jKx5XeAOnf8xTW0ydlLS3bSOuMqrHtgfl0/yKbE VxaB3cSljtPTqD171PJpsLRljgOozjOOPepGRLffZyqRW8ZPc8nPPf8AKpY7Ijc07gnP3OTn jpSepSKMkJ80IkAXJPQHP602S2cBPlyQMkAVlqWizDaxqAdzsvfK4BolFrh3aLzMn7ufelex SKy3mnR4BgLY52qM57dfx/Spv7d063P7yySUNjJYdMe3+elHOi/Ztk/mW2oQl7aBFZvmCgdP bNWrPUntIzEUPQgZTpSJtbQegkBA3MEPYAY/OmqfLfcCY5AfmUnioZpEilhUt0QA9RnANeo/ A/4jDwbcyaLq1yDo1zL+4lc8Wsh6g56Ix/I8+tctel7Wm49Tpo1PZzTPorUdMSOINj5GGVPc VkCNXMpAU71xszwxA4r5qnpNXPp2+aDsR6DYGfTLO7nhaG4SNUmhY4cEdQSO4OcVj+LfCrx3 Bv8ATkVcJl414Uqf4h6fTsfwqoPknY0b5o6nL3Ek9hdRagIg1pIuyZQOvGM4/nUcepS6dcRp bzyQRSgFJGUNgenNdzRyxfQ6DTIZWS6F9erexS5ZJBFtZePr1qPw94hbS7yS2ZylxGR3x9DR CVncJR5k0zohL/wkKuXzPcqCx3kfMM8AfhXL3+r22jsJDcRiFeqyvgY/GuieuphDTQypfF2n z2rSPqVoIwTg+cMqfzrNm8Y+H4FaSTWbJ3HAX7QnzN6decY/DNYWbNrmLd/EHwxHcuE1e3le RRvg3BmA7HA7/XrXzz8fPh34T1mKfXfDN7BFqSv+/towRHcHj7p/v9enXHrzXbhajpVEnszz sZSVWnpuj50GY8gjaQcEEdKuW0zHsD9K98+XZrW5DcsKuwvtfKqR3NAIvRMpH3iDWjbWgaJm yDjHU88+lMRbFrCqRuGZn53qVwF9MHPNXPldcpH8yjhU4z780yWXbOOAMrXAYKeqpgkccYqK S0WXcFTeh7Hnip6gZd94ZhvAWjXyZMfejH8xXH6jptzpE0YmTcuc7h91h6H0NdVOd9GZyjbU fZ6lBFcbni/dqwBjLYYVswSrqOZIsMAMqFYbh+HFbGRTeaXduI56MGGce5p4v9oIIUoeoHGa kZw+j+DNQ1MO8UWMdyCcn0GB1rvfCngK9sb6O58kCaBt/mSYG0DHIB785GBkda4+Y1ufoX8F vjZ4ah0qGDU9R8aaRIiAL5WtSzo7Y5JDZH6VZ+OHx28OeJfCV1olvf69r0d1GyG11J7doWI5 +YmInGfQg8cEZrObvGyMVB8x8z/tCeB7j4X/AAV8FeDoV2ahrLwtcW4PzZkAuJM+pUPAv0jF eH/FjU7ObVLOw0/TrayktLWK2kitECI7jJLkAYztKgn2riottX82eizjbu2a2hHz5J4bHSs8 jmukSDbkY9afBA0rqqgsxOABUTdldlrsbMUdtYD9+wLDk+lZmoeJ3RWFuu0dM1xQpurK72N/ aezVlucnf3VzfOd7NknnNNs0MAXAOQcHt+teskoxsjkbbd2bukeTPc4knFtNjKs3Az6E9q62 w8Sar4cuULyGWHPQ8q69CPcEZFcFanGekjppTcFoyl4hsoIrlbyxGLK7G9P9lv4kPuP5YqjD AZByePetqbbimzmkrNmnaW6xhSB06mtqGPYq+UFJ9xWyILMZkDESuDxgAcY/Wk8mIRlBF8hG Cp6EVQIqtolvLG7lpBIilhFkbSOOBkVJbeHIoJGcIOGwHaMZ+vtUpvYo3F0mWaKMmaSFgVPm QsysygYxkHvjk/Wui0+C1gyViHmvy8p6k9DmmtGDOi0zS/Mi3pFl8/MQNuD7D+lben6fPcZW RWjjQYAPOa0RB0MNkioqvGOAOR1GcD+ePzqe60qDeZYR5UbKFKrxux2J98An39Kuwig9lMpz Cq88bc4Pep0fMQj3YmReULjJ9x9KQIt2qRNCRg7zwGI5P+c1JY6IttNLcPO0vB2ow4T7xO0d B15PoBU2N4zioSi1du2vb/hxlvZXN3cKgkCIeVZ+cL7e/FXJ9EjjjfdtAI+cgDAJzgev9P0p 2MjCm0KZbmONIXxgfvc5I9e3TjrWNqFlNaXHmyN5yL3yfvdccc49akZBDo0lw8LiZG81yBGO XJHGcj7vJHGDnn0q1b6S8qpIzKJIydmB95vwHXgfpQM15hK9pEITEjhgJT5AcgY6Kx5XnuMH rzSRxxWF7MwjJuMggyPypzjgk88H+dMTJGsUjjacTb2lk8xVl5AXGMKB0Xp+JqG6tonbdNcx CMoxUKdwJI44HQ9v/wBVS2Mz5JltWChCsR4AQEhTj1PX061IjiaZ0uCVVlwTnuenbpj8qE7g V9UaO4iUAZRFyMnoPQHvWW4SAAg8kArtA49qTY0X4gUA+clzz93PGO1TS3TONiRjf9OOetSm OxTVpCpXy/lPTp/n0qxbAGRSu3IbJweoqLjLN1KxmBkLEHoB6dBU6JaTFA/m28ZI3nzOcdyM +3rVpisWbuw06CFmtN8oZiVGC2OD1Pfr1HrVNtMgckrHLu2jkpt55xVMCWw0i7uJhKLMvGBy W+UE9Op96t3WnXOmylituOQCI5Nx7ZPHNSk7DuZl1Cfte6Jh5anJA43c9Pb0qm9vZ3MMDTXM 6Xalswso2D0x/n8qVirjktUClVZ33fwsvH86c+lQ3J6bGzms3EpSIE0WNAVblcbSHGMjIP59 KZN4fsBGWjiLqwziU84ye+PpzWaiups5tbDtNhmswfIhAUnjJOD/APW/+vU81pOrfvUVWYeo FMzvfVhBFcuro20BcAfvCcD2H5Uwwv5r+a+4jHzEYH/16lmiFNxC7GPa0jj+6O9Piidx5fkj 95wrNz+GKS3Gz6Q+BXxCOr6b/wAIjq9yJL61jH2Kdm5liAGE/wB5OnuMdcE130litldjeBxn 5QOhr5vFU/Z17dGfSYOpz0SSGEmdXVxn+IemR0pvi7WbPw14evNV1AlrOzt2lbYOTtHK/jwP xrlUdbM7XK9rHxtf/HvX21SV7W2trbT2ZiLFhkhTnAEh68cdK5C4+MniLUJEtm1V7JGwpinj Xbu3HBV9vygcdzXqws15nLKLTuiC5+IXiuG4lt4/EV7IsTbT5E+5c98EYOKxL7xNqt1Kz3d/ cSyNyXmSXdj/AHsmmopMd9COPWL35X813BbgjzSCePb/ADmmpMzqWCBnwCT5Bz+bEU7CGyyG RVaS4VnYE+SMyOB6bV4z9c0+KFy+GV7cABS+4NNJzwoAyF5xxT2M+o+GFbbf5USFvvbCc85G dxJx9Ryfwp0s/nSpuZXKjaGVdvy8cKP4RwOf/rUR3CWx4VeSpPezyIAEeRmUDsCeBUtowyA3 Jr6VHxrNm3fa/TK+3etC3bIbbkBgVNAi/bW4yNvPPpzWlBbsoGVxk9+9BNy+kO4EDAbFTgsf LB25A2jaAP8AP1piJkt2lblsMOeelW47eSyfcCHHIBU8GpAsw27SMd8YUkcGoLvTjAoLDByT huTRsBhapollqA/fW6+YTxKvDfiayD4KMT7orySPoVEoDKPyrSFVrRkygmaUXh1Z5ma7uZJX IALRoFBwMA+9V7nwg/2gtbTApjhJj/Wr9pqRyn6LaD+xdpvhzSbrV9RsL7+zFGYdMhQi5kAH BdVyI8+gOR614hP4V0i31bULy4tRoNjb7lisiWMzNzjPmZOPUnqTXmV3OmkdNGMZ3UjkbD4j +GNHE7atFqkVjA+wXGnojqF55ZCQePYnr2rpNP8AGPwr1CFpI9fu7wFd627WyozHBwM7jjJx z/OhT5o3Q/ZyjLyN39qvxzoN3+0P4PlfT7jVtOhsbspDDHuCu5WJWAyOAiYJ7ZGK+YfjB4Bt Ph34lmtIrldUu7tftct7ghSHZsKgIGOh/lk8mscPpTV9yp3ieaXg3W5yMkHNZTDFdXUim7oY z46cmtjRby5Fs0Fjp6vdydbhssyj0A6D61lUjzK1zVSsywPCd3cyZuWeRzzsXpTLnww7QMyo EjHVQOvSqjNLYtK+5zlzowDnaBgdjUcenpkHDbcEkE55rXm0I5QitJYGJaLdGM43dx7EVctt Tng/1LlYzxsf5hxUO0hrQ6zSvFenjw1qthqGjRXBuYgYLpZChtplYHzFHfjKkdCG9cVkWMSS EbQqg88DrU04uN9SZu9joLS1jVRuArShtEZQyZJPIHauhGZZt4FVhnAY8YA60jxb5SEiO/36 UwL1rpTMzswG5V6gfeq6ikBEkslYKflYEqSOvY8n6ipaKRvW1hpM9v5qPcWzjgRzKJUz/vDa R342mrUOlTW7CVYo5Is48xBuQk9B7H2OD7Uk2Ox1dhBNLbLlSmOSV9++Pw/Wuit9MKoqKjRH Zu3t2Hr/AJ9a6EZstQ6UZIHaSEJI3D5POO35cYqcaQoRn8z5VO7AOS2apE3Kl0jJCu0FFbjI Hp1rImt570t9mYwMvG4rnp3z/IUmCNnR9DuoYB58yyQkbtzDDYz0/wAnrWjLpkUMjvIx+boD 94Z7fkf1qraDuQi5htjFmQpIABnAPbn9Dj86miu4ZUZYV8x1GC+QRwCSe4xyBUjI5ppooWZH LKFKFB8qsO27HX/PtWVNbMY4okby3ZR5rImEXknr1PHPrx6CkxlWLRI1uLeSO4eJYG8xQh2h 8grz37n9DVhbODzizRhOMEHoPfjvxU3GOjtBHK2yBiDwFJ4B/M+9MvtL/tDy/NEcTFh+7Yje +OcDA64pNjsQS6XlgC6BxgfJ8wPsB2xWNfwwWzSjLSFmbYApXHPpn2/lWbGZ7XhkkSEF8Kv3 Xbv16dq17eOMWgnkG9MgDA/iPbrzxmkmFipNdW5IiY4HqQSP15zUs6WVvHGeSW5Cgbi1JsY2 5kWfywqFFA24PeoZpWjfaIzgdeM88dqB2NLTXRpI1lUxn73mR8N19ex96S+gFpOEifYxG45P OPTjrj1oAyprO5nPVgTkYHNVDYXCyMm0llPb+VAGxo01/wCH7tJE2pMR1IDHByP5E1sXWpai 4M7PGAxwWVcnJx05/StYtkkt3cJHDA0Vz5jSA+cpJwjAnAHHpiqRZhK0kyiVgR82wjtR1GJb uIbe48qJ3nZlCyIcIFzySB3P9agW2jY7pLdRIOrOx557f57UWJFfdCpG1UV+doAOMfyqs1wu 8DewOADjvUNFIq3MUo/fsHZQMBS2SuKqXDJFkKjMxGPmGVx9f6VHU1NO1MkkefKG4EbQRnP4 dagncpL5jtgY6MMAc/8A1v1p2JuSWjypdJOJ48cMAqHA+uetWNRNqUDxy4nTGQBjj2rnkbxM uyuUkmb93t5xlhjNbBhBjIG0BSCW6BfqTUxaZbVh0tx9lmgubWV4L2FhJFJFwQQc5zX038NP iCvxK8NebKoh1qzwl1EBw/HDr7H9DkV52PheCqLoehgJ8tTkfU3NEt5LKKONpmnMabHkcAMw BJGfzNct8fbhrT4PeI5FkxG0IXLcjBYLjHfrXixlzTTPf5bHwaJiMj7uSCqE5jP0PanyruiB mHkq3qu9T9DXpbbGfkV3sbRthVbeUluWimKn8cHvUEOnEMGQ3S9MAShv5n1rRN9TNpFqa2l2 qjyXW3rkuq/3eP8APr7VBHa28i5kfzM5IVpix6eg+tF9NCWXsRWiQiND5aHLKoMYGODlm56d aS2kYQuUaAR87nbcFJAyRnq3UYwMUhD3AMUZM0hRVyvJCknJBVeo4K8H602VxZWcsrja4ikJ TrKdoB56YGc9fQ1UdWkZzdotnhATH51etY23jHBzivpT443LfbFlJAd3TGORWtZQLIgK4Ge2 aCWX4ojGwKZBFaEQLlQeQeuOtMkupAUGNvT+KrMdsSeVPHXAzTEaFvaBOVXtzxzVuRGaOLc2 0qMBSuKmwx8UDPg8EHpjrU8kC7CHbHbbQ9hmdcaSN58vcxPTB9qqxJNFIDt27uNzrn8s1AFy 10otFuL8n5gM9aoXcE0TNlG3Z+6nNNEnrHxN/aD8cR7o7bxHeoqsWCPt2E+u3H1rxi6/aL1W 9ma08TRrfQPwZHycZ/VfqPyr0sTTUlyMwpS+0V/EniezuvDyw2LfunPDbsnnsa5DwWk0esCB H+XcCB9a+aUHSvGR63MpJNHrfhTx5c+M/HdnLq4RZ7OE2SsWPTdnv05q9+0xaK8vh7UI2Eqz 2zx+auCGCkEf+hmpjpNCra00eE3xAtmGRuPQVn2+nz386xRIzsxAAUZJNdlzngrI9++Gv7Hn iXXLddV8Q28miaWq7/LlAFzMPRUP3fq2MdcGvRb/AMFaP4U0/wCw6ZoCQRrlWeScPI/uzY5+ g4+leXiJOppF2N6bWrOG1m1WMhoLGCN0/j3jNcTrEs9yWU+UwHHL8UUYtLVj0vc4/U7Dz3wV iCgZPlnJPtWUNEeTG2CVjwCQCef84r0ouyFdMmk8PahNAyR2FxKSOAsRP9KoR+GNRNz5FxaP akJvxMoQ4z1AOOOP0ppolsbFolzPcLbAK0IIaSRQSDjovSugstNa1dBsz+FaIzbNe201o1xL ucHuRjPatixi342gBVUtljgKAMk1QgnS1FvG0Ly3NwylpQ0WyKPluhzluNp6DByOcZLbO3Mh Uo24ex4qgN+wt2nYochuDxzXQ6fbRvFhkXBbBzgEjFMDchtraYeWCojQckA5yav6S1xp7kWs QhicbXyOZB6MO4+tFrjudNpltpdwvlvK+knYf3yoZombjGV+8B7qTjstS25mtbjy3eN1GCjo +5GGf4TjP4EA+uKuL6EsvjzL2QBZGRccrEAGz3JJ+v8A9apYtBFyjHz55lXjyzJgHv04PrWh FgOh2y7AsP2dUJVh90+46Ek1DqcK2wWKBg8xYDaMZx24/EUAhdN8P3HliSSaXlt2xMABgCQS SenI/SmavrltFFLESJJl+9KyjCDg4OBjOfT1NGyBanPagHuoA1tKI0LZEiMWyecZOeOvp3NV fDumXMJcTOZNvzI8bEAN6EE856e1ZrVlm19pe5hCyt9nGGwrIQAM9j37/lVWe3uvJMisnlkt nnIxjGD+FUwM2adpICrSOxGdgj5we/1pLOyeKNZY7xLhAw+QBtx4Pdh04/lWLZaNm11WGLMV 1EREhy2xvmbpwM5AOMc03+0NPmnnMKyJEh+RiMnGePocf1obSQIitEs47pp4LgZVW3KzEE8e h/zzUGoP/au3CRNKowWC8j0FS3oFjNvvD0sZ81vLZ2A2bcAAYz19qoz27rFFGHVDu6YAz75q b2GWI7CPyTm4BlJwVxnj2PT1pz6Ud6II5DuZVRsZ3Htj19Ka1HsLaXiWjvGYxc70MaGQbtue 4/2h2NXA1vHE0bpswMMdn+fWmILiK1gXfGZHmxwAMIOfXFUJB5LieQF3b27fWk3Ye5ato5Zn EoUJGOTk449vU8irL6XMkjPHGEJIZi7Y7defpQhFeC3S3uTJOgmt1HTOM84xnqMdetdLJfad qcVsq2SROG5IblhtAHHTgDt61rFkkWr6akNqXhtm+y5OChwN3uAOnSsxISLUxFMD7vPHzdAT 7c/zqmrgmV7COe3DFiGkIIZWA6Z7/jiiPZdXpjCgMwPAyw+nJzU3GNmIWSSJopX8s7AQMBTn 9e4qK4TyT+7RXdD0P4daGIgeaZnEXmAFUyVHzAD1I/r2qpcqq27KH+0btxYKNqRkEYOe+f0q GWims/lz/IvmIELj5ueuOeKjv/NuI41ikAU4J2fMEXvnIGex/wAai5ViSytPsW8GdpUY8ZPN TXE1vErs+4Z5xXPPXU1iZJvT5u2FV2rzk8ZH40xtZO9EaJlweu7OfWudNo6+VNF1bqVGUxqZ O+3PBrb8L+ItV8B65aa/ZM58mQCaAk7ZYz96M49QevY4NbygqkHF9TGMnTkpdj6/0LXNO8Va Ha67o0n2jTrsbvdG/iRh2YHgivNf2kb6a1+FGpxxhilxLCnmYz5Q3ht2PcqB+NfIwi4VFF7p n2MZKcFJHxTK8gV5HJVW5Lp86OTnJ46fpToJdql0CMRyGt5Pu+o2nj0/KvWMBoZyzeZGJeM/ voORg+ozQ0cIdFZEQAE8SOvOPw9f0q7EDJYLdtzGESOo252tLz35PepYpZ4Yyd/l5AyQQmcd BxzQSPjeN3yJBcM4YfKGdiT25z/KrcORGiKqpOc/vZW3SNnAAVRkjp7VIySC0MQYZeKU5+fG +Y8DgDoq+/vzVXX7cReGdYkgR/LS2k3eWd+DgjLueO/Qc+lVD4l6nPV0gzw22hMhB5I/ma6X Q7CNbiIzISVcMCP4SOlfRTlyo+Upx5mdl4u8PaZ/wi/9u6fqtvLeQyIk1uHG9w3GMDnIIPXt n0rF0JvMVSULFv0og7rUmorPQ6K007zGA+Y98VoppPloZP4VOMEjP5d61MSe3t+ecbhjp0Na cEyABGzG46EcZ9qYmEMnlzB+Tz93pV+G4tywLxeZnPGeelDAWONHkXaWVVHGec1YbT/tLNIQ +Bg/KMCpKWpXuYRZsHV8KOCTwR602S1imQb1LnnDHv7ipsBLFp0htGWNygU/LkdvTNJHptwo kdiZiRlUxnI9adhFHxd4Q1zWGkCyvPI2fmIAwM/kPyrAt/gCl3F9o12+8qJVLnymChVH3izH oOM9BXtypuT1OFSstDjLbTdE1C516y8PJcLYwqn2cyuWLndgsM84J6A84/KvY/hD8JhpjHUN WWNJyR5UMhHyqO59z6V8tjZKLdup6lJNwPP7v4b3Gg/EzxBr0tpDc6dHdytbxTRF1ZWO7eMj HGSM9sV03xB1myvvhP4aEl9BNqVtcSI8AkUyqhL4yvUDATt6VCaqJNdDRp2szH+EHwB8RfGW 5e4s4ltdKifZJfXBIjU8EqvGWOCOB684r618A/s/6b8FYf7WiltLjUU4W7uLbz3BJx+7Tadp J/ugntnmul0pSWhnzL4S944+MFlo6S2WseK7PTbmIbmtWs43kK9iVUEjPYNg+tc+J9J1rTBe wa1FqEZdVbZYcrn1wOeh49jXL9U11ZcfdWiMG/Hh6e8WIajC8gOzBgVGBHGMdj7VDc6Zp9pA 7KIWOeD5AJB5rRYdR6i52YeoJBAzv5ixsw+5Gi49j061yd5qk2Aov5doJI2hOn/fNbciIuc9 dXjB2JuZnz0w+3+QFc7qEMd5dNcSr9olxsDyHcQMngZ7cmkopbDuMRCI2VkAB4AA44qOO2Jl ViRgHgY4FWBblkQKVwXA5JPIqZh+7ViQeOAfWmDESwe5UbnDjHKkYzWrY6bFEoJkw/oT2oAv iNoynlphccFB1rX0e0lYk7io4xkcn6fjn8qaA6awsJFbyjkuBzxzjn9f8K27DTlD7VUqcA5J x9atCNG102F3OGDOvDAnoSOOn4Va0q4VYZAqSI8cm14JDggjkMAOnYjvTXYFtc15Gi0zT43t vNuXuG2mNWUFQCGbkgcd/bGOeM5qyz28CLcSRm537iiElUHZSe54yeBzx0pp3EX1dJpEWOPa XO7dnjcev+fepodKtYZ08zLSIN26I8t/nH6VaILdtdLckgLuIwCAwzn3Pvx+tZN/4XttdcDG z5MsHbH4k8dBzyO+Pem1cF3May8IzQS5wstu5GxSpHA56Z4445Hr6V1UVmunWrxldilSUVVG Dxjr+J/T1pRVht3MeK3aOED7CDB255LZ68+/60XGlDUlnjmka1JysRC7gQBnk+uBSeo0Zkfg SJrgQpdyKHOQ/lnv0FbNt4Dh0i5Q+e7yBd6ysQqq2M4J6jH+PpUKK3LuSeK9CtpNOVI5C2MY +cKqkYzx3J45zx+dcQLaDzljgLTBxkyjgKcdMfXj3xWc9xxHy6XIiloJI1DKU+b1/DPNVoNO mVsm7k46sTyfbNY3sUzRk1O1lRoJFLSEYYhwfxrClt42kcBiNvJBJ69s/wD1qV7ga+j+H5nZ HV/LKsCobnP4dfzre1HSIpoPJm8yRVUlQgA+bkr+H9K1iJmK/hxVgjllRomBwMdz7/571ai0 aER7Sm8nBcE++Kokh1G3a0hAjAMe35dw3EDoB/8AXrAnubkTR/Zsea4ADYAB571BaNG3DwQl Ly7iJcHhc5jI5xx+VJKltNEC0shfcQZCNwx247f/AK6oLFFoQJk8nc5BIyOA3pW7JGnlwR3V mm7Pyuoyd2e/5fqapCYkepXtyfs63lybeI5xIvLdOKJ54bU5QM5C7gzkDnv9RkVUnoStWZmp ass8kawsMOu2VgxHH0xzzVSHVoLSY+XIVeM9RnGcdce9Zc6TNOR2I/7a8+TyzKDsPfIY/UVa TVLDcp86IJnnvziqUu4nHsGtHTku4pLS4RiyhSIG+7x3PXOfSsU3EUOUT7x+6vQAZ7/0/wDr cy2r6Ds0Vl1cwy8x/uwAAcZ9OtNjkEjMm0HjJxwSc9BUNlI3NKt0bYp4kHKuxxjFU9Tmh2tD IgR8AqqgEA8dfwzSkvdHF6mXcy21siAlWdQTz/KpbEQ6hHtkj8tmACNxjPvXNvodiTSudlZ6 dZJaJatBGZlfiQJ83t8w696g1HTJGQwoY9gG4kjoPT3NdNrI529Te+FHja9+EmtPFN5l/wCH 9RcC7tFOfJJ/5aoPUDqO449K7z9qiSKf4X289pL59vPdwyxTQ4IZSrYI9R0968DGUeWtGouv 5n0GX1uaDpvofHzrCZW2sSf7yHYW5PJHqfepRpzScSLuBIIM0fI7/eWlex6LVx39nvCXkQTI OoWGYMOg/vU6SCVGUl7nBJ6xA/MMZ5H1FUpXRi0xJbeWUtnzsAfemZVH6Amo/skZI+eFgBk7 VMhH5/4UrhYtQwSTwNKrTlE+Xc7LGAPovP6etTWIRRLLbMZhE6xyvaA+WjMcDc/bPrxWkISq O0UYVKsKavJlu9jtNPtIlkniczziJYLQMxZzwu5hkkEgAHHNZnivxXFrng660fQ7Ka5M0hjl mkh8qNVJHzKOpz0G7PXPHfrp4aamm9keZVxcJQaW5xemeAH8kJMBGfTuDXUQ6IbezjinWORo uFmCgP8Aiepr1ZLmieNTlyyMnRfCtvceKrg6orwaYw8+a4TG3GMnHGP/ANRp/h6y+3BrhbYW 0TOTGHznaen6VUOxFS251kOjSoow6lTxuXtWj/ZwgRAdpDDHNbIwuKNKLKxEO5AOg6/WnR6Z LcMFjTHBJLdqZNxpsIoZdsoIkzj5OM1LGLeHcJIyjE5BIGPoaRRoQi1Z1LjK4yQOcVoxyWfk SwkbZSQI3Vhgj0IxzxTEnZkNxp0Fy6DZuRBjYc8cd6hn05VVV2+UuMgtxxSsU2RR2MttyJsx nD4GM8Z/Ie1Tve3kVpKttMLZDy/HLY6DdjP4dOlSNanbR6tea9pVrPqWmWelXaq2+O2UICM8 FgOMgfjycnsPnb4u/EqbxhqH/CMeGfMu7TdtmktlLG5cH7q46oPXvjPQc+7Xlyxst2cFJXZ7 n+zD+y3c6VanX/FsP2OSRleLTph8+FzguO3Jzjvgdh830U3gDQrtkSPSoducnau0EZ9uteU8 NCovfVztVWUfhZXn+E3h2RiJdLtmJP8Aq/mwR+BrktX/AGVPh1qeoR3FxpNyMnd5UFw6JjuD g5A9s/SpWFpw+FWD2snuz0a20yy8HeD/AOzPDdtb6fDbxhIIkU7Fz3IXk+pPU8muPl8Varcy Jp9pDJcXcu3zrm5k2i0JXeTjGAAgzwR2wQTupz0dkXBaXPlP4g/DoeNPHF3rl3rKab4Wtrlw +pX3W5IJIWKM8upwSPYnrXW+KvGktr4WsbnQLOQ6SMw29xLGiXF1N90BFGCMkjkds4AA557a G3NYyPCnwpv7ZrXWfErKdRQvILdG+SNnOeeTk/4nr1rp7+5AG1QQQcDJx/k1DRCOY1WKSQ5l kwmOB9Mjj2rKeEttYRIML2XqPegChqGm/aLgzpGllEFw0KsW+b15JI+max7vTjHJD5YaXOAS CMKT1J56CpAn+xZctKDJtHU8flURtFV+MLnrQMZLEIZXGVyOVVeT26/jT7awkvML5f4fpSFu dHZ6TGm1dy8qM4H6VftfD1nPOLlIljlddvmEbSVH/wCumVY6DT9IijRVZGKnODu+6eOQMHk0 /wDs9ssYo5I2J2/O4zj+8AM/Tr/LloRraLpk0CicEOqnoW+99a1VMzkLHHtUEfO54PPPNaRE bdgEtYyAnmY5MjHBX3HH+c1IUjuGaOKF4pFw27P3iOSO3b9DVCNuDS5k0+FI8fKQsjHCvyOh 4HYc8Yq1pmk2dvE0s8EO0YYExjIxz1x7GrsTcuS6JFLBHL5LRbc8Bf4fX6YpkmjxXJMuzyxs 3YkIO4AY5zzjj8OaqxNypd24EW+RmcDKkBchV4IHXoTVDUL3TbdTG9wsCgEYCljk9GYDp+nT HrUjIyjEM4huIEdyy5Q5HOSCemf/AK/FX3kb7MVSDBYhNztgY555OT0J/wD1UbAitbWLGYfM I0UgqXI2jjr698496W+gMVnI6PGYg+SEUsxPOAMgE9emOazkyzLla4h4+Rmzz0XAPoAcE8D8 hUc+ovOViklkjVn3SMCCWB7DP/6/51jzWLSK15DbXO2R8ybDuD5OB6DFVBp9s/lOIiBuHGdp I47c8UrpgQDTbNHdA2xsnayk4PXn61g39rdoXI3OF6KH28cc9f51m9SvUyVsp7liYIJCWBUs nT359qv6ND9gMfnM8kwBIRAMpzyS3t6U0uoM6zSbS4E+MTNJt3hOAceufx7VPq6TEPiTeY+R zhiOgGOmcGtbEmRLPcLtWVSXUhPm7D3FTaffhX2NMOAQQw4OeBj1qQK9wlyZXEssaRj7hZfr znPfj0rIuL9XEiczjPVgBjGOfyHrQgKiyNKG2wNyB83Ydf1q3pWkXup5G1gF6AY6fj/9ehJj ua0mmTwMyyRSrJs5P3SPTn3qZbmeOZBcSI0AQ7VX5mFaIncdDcQTFxCx3jq6DrWBrkKsdxnK cYQkfpj36VM9UVDRnPpcYTcVI4xz1yP/ANVU/L8y58xi7ggH5W+76Vg0tzeLeqG3cIlHmR7h IMA88j6H8qisrOOI7JC5VhkA4xUSlqawp8ybNP8As+C3tQ6ys7txsXt1qEDY2eo74rQwaY+C yW9V0CgEfNnOK0tO0nZPvQpheCjZyffNXa5CdmXm0ZoT58ckqbjuaMfMo657+w7ZrO1TSBK7 TRySyoBlVbr7j+dEl7o07yRTsbcXMgKAkuDkH0A+nWrlx4anEAPEcbKG8yRxn2//AFVzJXR1 c3KyO2SbSpdjXSPEGB3x12Vpp0tzaiXEzJNhS4Xv1xk/zrSC6EVdNRj2cUl0sNw4jQYwN2T1 5xiruv6yJfDSaEuy50uK7FzGk4IKnB4UZ6EnOPXPvROkqseVhSrOjPmR5RceAtVubSIWtt5x V2DedMoRQMbTwOSSTx2xTX8Ba/FIjNLb2b4JHlyMQec5xwO9c6wF9ZSPRlmrtaMSb/hB7q4A 868t2djgv9lPB7clqrH4cXhyZNVuQiHH7kKuc/hWscHSj5nLPMK0/IpT/DeG3Ane6u5mzggz HI+uDVuDwtpM9uiTp80Y27pGYsf94k+mBjt+ea5YxdkjF1JzV3JkF98P9M8keXbRshOAAAQP pVBfD8WigbUZOQSCAvH0qm7ama10ZqpYrexbzAJYdys6McbuRgfy6U46OllJhSrRqoyVG05I Hb2zj8K1WquYvR2LraQIoUkZ18wgMUADEAgEcj606PS/t8cu4Roo42scH61ojNj4dAu7ZALJ jFkMrF0DoQwwVIPUEcVkN4Y1fTbp2dYpoXYsfLXaE9cD0qorqZt6GzaWLwQGUgOm7JVsZHbj 2qaK83IUEKk9PmGT68VoZm1aR2lzYMWcwzquAoH3qxbuKS1bdCSreo6EfSgZVmmDOplAY4zk imPLHcIAYyWJPykcGpEQLahEBQMjA53Bu3vWhYzzWcZkMSzPH6/41QFtPEMV6yq6mJuhLLjm osqr5Dlk5JU5xQMnhuLfKBwQG9PSoHvLALcRh8fPwpbOT/hSKVzndW8KfFH4xXp0rS9Lul0+ UgM0cRt7UDuXlb7w74yT6Cvpn9nT9mSz+CmnveXjR6l4lu1AnvFXCRr18uLPOM9TwWx0GAK9 PWcuaRzKyVkezzwR7lzCHCNliDk/56VEGkdAzsisByEHHX1602gJIvKjjMhIJHA61DeLOvlx W3lXNw67i+SUXJ6eufwqGNFbUtL/ALR0u4s7gx2ySrscoxyfUdBjvXLXvge3XTdO06ya6igt kZGMV7KhkUkk5IIJGGxyTjAxjmsJRuzVSaM5vhd4ds3WQaRbvcoNqzTp5rqD/tNk1R1fwzZG 4hknt4pvIyYd6jKN03Adj1/OsZRsaJ33MDVoBtKbAP8AbPrXDarYRQzMo2sxzyG4/KueRZhX elN5UjCBCMALkc85B/pis9rJIvNJOflUHvjkYOPwH4UkMo3cEjqyhl2cAvt6cdDWfNpymEqF BB52jjmoGZ7oxdljG+TOBxwKgjtt5YO+1gMkk/e+hoAs2mmrwCoJJ4B71tDTlZThmEm04K8H P07/AI1I0XtM0wSM8rsQmNuGOc4z26da2Le0lkwEG4AgANwVHf8ATNNblG5bWYj2BwBF1ycH Hvn/AD0re03Thbp5iiOcMMgyAOPyrWxmaUUcpmDWwS0K4y0ChPyxz+WOtQrpBA3sT8wIAJB5 9x27VaRIi2dxHcmNFZwTtXI4Of0rchjmIEQtofLUAxygnf746YHA/WmtwexqabozPI3mXJ3I QRGqfKxz9f1raSzisrUyNN5KLuZpZzhVyc43HoPQdgK02IKF54xsYLYpbzm8blT9kVpcfUqC P1qG21jU44jJHp0JDoVH9oyeowCUTJ7f3gaTZJlajpE+opcrf6lNPcTtulaNgiggj5QB2yO5 z/W7cW2mzbba105LeIMOWy2D6Z44yP1qeaxdrmnLc3KwpFNiSRm3YJBHpjA78msSeWSFIYC0 jTA7icjC9/p3/Sk53KUR98Gdoi4DAgHywvDc569qo6jqJ2eZGiQAtkgrk56Vi5N6FpGFJNcG 4IuShyxw655HU+wqje7Jb9oz5cLqT8+7oB7+nHFYGuwaQ6JdLG2+RMcsO/OM/pVy+nR7oxwo GU8bmGNvrj9arZEpakChLa7aNUinYfwSD5iPb09a47WdQvY7/ZOEEfXZHGTz7k/iawk2lodV KEZytIki8Vz2EyRQ2kYKJjaoxjOMjHcnnk+tW4PHDIZ1XSmeaRtz4br9eM5wf84rSNV9UXPD xS0ZdvPGcTGI/Z3gLrsKlGGTgHA/+vUg1tZo1ea43EjcVK8k+mfXp0rdS5jha5dC9LFFqcAk ikMxUHcWUgZHPcDPpVG30Eyu+6AmQHIPT39elDVyU7G/ZaFAYA1wRK2CFRTyuMHJ/Oo7vQIr y3VoYEUxsUeJ13Ej8+DwfwIppAx8dnDAjrHDtdFy64BXrjr/AJ6VUmm1HTIwtuo6ZwOf5dKo kjSe6vZZopYiZ0RJGK5OT0HJ+lTTW0Hkia4RhJtyyqOTUlGPqGnW6KJbW5eJmOPLIIK5+meu aoz6akcKm7mgMhHGyXcwH+0O3aspSszaEboyJrCG5uVNvBIqjaV3nIBx7D1zVPU7GSMvsGIm 5Rx3rLc2WmhSisvMmC72Pbrx+NWbxFt5NslsHYgc5wKrlvqCbWiKkakSDcrIueirkGpGeMqV QM+cYDdaVribtuTWthcrIWSJwMeh6fWrK+ZYXAkY7CvJUfNW8VocstzUttVmBW5iHnWysAxK 5A9zV7SYopzuSAbmXKlmAznI6GrZJjRzLpGtywSR8nLoqYC7fb0rX1S7ivtywmQqRkqT045J HrnNccdLo7p7pmIdVVHaQW8aNG3ACc1tReM7vUGIuJmkATaFduxyMY+hNOEtbCqK6LVpcQy3 CTyW48pG5APOMjPel1iyWWWSZIkbcc7NxLAe4roTscrILO8uNMgjIMKW8h2gMnTPrjn371Br WoI8sSJL5skkZYyIMIp3MCoyOeADx/eFdHQgzomuI3TDbkzgqKsx3CLIQu0ODllZT+dZjI7o W10E2MS2SD8pwCaxbmBYrw26tGIGXaJHIDZ6kk9+/wCGK56i6m0H0KmZ9NdgGHkhshM5BqXU GsdXjgWPNrP5TJIGywd+oYenX9Bx1rPoV1Dw/BHbwSw7WkuGcEYbgAdeMc59cjpWu+iwzBiU dUboS3v6H8K3g7qxlNWlcrm0t7V3imXercBiTlac6W/lFIy/PBDCtTEs6UJzHuMmYx8uxjgg /SrV5BMVUqPlUHjvVxRDEOmIsbon3tuMnv8A5/rWNLbTW7f3geD6iqJEgtXjDHrj0/xq3aze dayQgusjDaXB7GnYYxPDbTbi7qVI496r3WmTaezRMqANzvxz+dCRIT2X7ndHmRG49cH0NFpp NwUBKq8TZzlsH2x/9egCcaVFsZdquSc8tz+FZtxE1qNoUue3cVI0JDcmcbZ4fLI6DOQR7Gor mwS3PnW3kyseSrkZx6frUls+/JgZHLMQvPGKgk+Yn5mLfX8q9g40RgMoK5WJCe3WqU1qWYbs IpHBx1qWyhi27oREm9h1Y46VOIo47dSgYXAY7mGMAduO/fk1AFWWCRpMurH68j8Kkib7OqgP k/TrU2KRnalcAKzICAW5bp0rhfEGoFY5ipRnxxjH5/kKwqFxOH1G8bCmZyoXjk84J54rHuLi F8hR9WrjZ0GRqNwHhQZwAcketYly++ZWGMYB+Xue5NLoCZAZkd/LG1gDkYYEZ6dqrXGn+YPn G09cg+tS0Mzbiw8kfMCPQnvT4bJBESYRLIvzDnn3HNZstF2O0QMhZsKMcFhgAH1rRsLa9e/k ha32WygYm8wFmbuAnXgd/rQho2oNKjiYybmdmAUhvugfT+taa6U9vE1xFbvOOqwlsZP61SBv QTRrzVdSuzjTo7TT2XPnSyHzGPbAHb67T9a6yKLbEihypAA3Hnngd+tboy3LFjayMRHv8xiB mTgE+uR0/Kus1T4Tavex2/2bXdI0TT5VUJd38mWdslfkRQQBu2AZP8Q71vTp+0b1sS5WO5bw f4V+H/hCbU5tbs/EV9bIjSgwMowASxVMseeP0rwLR/GLeL7vXNe8ttF8NW9yIrcSRFncd2GB knOMIATz3xRPlUuVDSbV2bmi+ItQ1CzltLCxuftKvtluLs4WFs+xyWIwdvG3Izg8V0+n+F7N 5Y5tSaXWLxBuMl22QGyeVT7q446Af4yiDXW2huZlhkctswBEVAUDJ5zj1H8qmWETOHVNkZVg Rtweeo/KqJEeys7WZfLgQM6429M8njJ6VX8m0t5J1MasBnyyTkpnOe3v+VQy1cyFS1mkaQtu J+UMnPqP50+eJY1EcD25B+TcxO7nB5qLWKMO/v3t3BjnG0Eq20A44J/DrWBa2t3qs4BfyxKC ShckqSD9R7/5zUblbI0To7orRSFmgHAWNjyMdeP8as3nhqwIf7Ou18BsMx2EcADk59KOVCuY 76AJYGhu53jQssgCE5JUnjnr3/PHetP+wobtEljWSERcOi8Zx7dzScE0VdpiLocK26zxF4Zc EnCgMPY++f5VFHp1u6OXjikmG0bQoLYJxnOPU/z9KzUUi+d9BbrSLC0ljaZER1VsMB2OMDPU cAfnVT+yYb+EmKTmY7Q0bDp6fXBxVcqFzMo2/hKESmAlowc4LuTg47nv0P51dg0C10q7WGWL 5F+7IcAucZC8gn0OPf3q1HTQlu5ryWkbPM0WTbMrEKPlwTxuGPTJ/wAimKftMcMbuxMSlE3D JAyT/Mn86AIbWwjul32jq/nY8vceJB7Y/Cq7Wd3ZX0ltcrJaSQlkmjdfnBHHTrkGouDHRSW0 8Ss84Myg5UdDj0/XrTUhaRzJAHZGwQpHfHQfrVCIzq72pmjm3KgHKoDvDfyxxXPT6W2sXkk6 XYiK4Chm4z/n2pFDbhmNqRNIMgEbkG3H/wBaufa6Kn5FDEDaQgIJ+vtWE1fU1pytoSLJLLKU k2qh5EavjkZ61O0UO5Vd1kQfIS2cBev6Z/SojtqavXYy9RmGlyvJZMbhJFKlWzjBznpzVCG/ kkWRJk+Xbgb3xgexJ5qrq9i0mldiXcy2cas0gYEnp2/HvUEUrzq3kkyqwDYHTPb8eaaRlJl+ y1AxIkcqSB27hzjHoQKdtk1OTKwtJGnDY5H4VslbQ52zRsNWm8uRJw3zD5QFGOOg/wAitn7P FJbGePY5KElXPAPqPxq2Qcr4iv5tKktrx4I5Y94V4/bpk/8A160bG8uLuUpZ2sk8svIUKWYc dgK5pbs64/CmYeputjqS29ykkTyMQ4KkMrg9Oveta1sI5LnMYHlZHzdsVzx+I1nsmXjY5WN4 9svclT/PnmqMlhtkcyoWKkZJzz+tdyRxMtG+hmlRZ/kX0xx9f1qLUGhnctFKJo05Hy4xz1rR MnqU7m+DQ/KdpHAIHSrEdw4EYjUAnPOeOnekMoXFxIuCH5HHHX6VmalC95CwyWOMqBzj0rGe qLi7O5PYTJPFHDcna+z5gTg/X68Uw6XtBIO+NjhW61h0NL2ZLphe0uo4S3ltkDevBHPbHWup uUnud4acyup3Zz1FbUuxFXuVbm2SZgZepHIGTiqcapBcIS/ys2GUng10nMaFrFh2lhz5aDLK eQP8asTTeZbqHDfcJ+UdfcU0JozPtbIqKpYHONpHenRzPGAs0W6I55JxirJH2t3JDLL5eI0Y bfm5Bq/bESKriJGcdx0OafQCjd3LRSsm3ygDwBWZdSS3zFftEeQhYF2wCfTnvQBRFxes7IVy VUsQi9B61Ml9emNBE24AYIUY/GluInlmk8r5jyRyfSq63DRMp4IBycc5pAWxMt1FI3yIQC21 sA8f1rMht98zZb5SN208E81Ni0fSPxT+M6eG7Oe20tZNQucBWuFYpFFyQcEcnnA3dOeM8iu1 8IeI73U/DsFxftE13MS58pNqpk8KB1OBxk8nFdFKv7WpJLZF1KKp003ubsErzOGODweOwrVh RFgW4+1pMxLRoiEOVwSD7DkEV1NnGVwvL42qSdzep9zThEZAJGwAo4oAjaNg524PoDnrVG+h WJiSQT2VTwPx/OgaOP8AEMh8p0ADPg8Zxtrgr6xlud5XCBiMysAT7jB4wRxXLPc1iZF9ZQQR PvLStj5Gzgqcjn8gf1rEfTFEjDDKB0LMDk1zNGpRvdMEjOpUAEKRLuwVxyRjvnp1/wDrZc9g pZkC+Yg5YdM+xNSyhsWk29uirFCFVOI1VQAn0x9ahmsWDHJIHJ+Y5zz9KljIhp7SRGMOwRjz kY6c/wBKWHSXiZkDblf1xxx61DLRImlB5EHllyMYJ6/WtW3sXCsvBGRkHJPbv/nrQkO5rWOm SzRIAfn7v6dOnP1610VrayWkYkLfuyQwOSwzn/8AV+dapENmjZ4MzDjyzzhR7dP6U6aIMT5k LNCcqxBJA44/UirQixBbRwMwiklZGAVgy4GOhAPNdTa3vmmCINuihUBA/IRc9MmrTsSM1jX4 5BKLldQSK0fE0ds6xZQx5D7mI+UAhsjk+4NcN4Y8O+bdzDR7H+zIHkJn1CZQ0oBH3YVPcgg7 zlck4DdlKLjNpi51KCaPQbHSrfQYIrO3ixGM7Q2W4Hct659epPU1ZwCwjX94rD5nxwTjgc1R BXnt5YRn/WODk5I9e3+e1QtcXNy0cYkKFTztJ5Pei49yO4DwXM32YvKONhnGzAJAOQMgD/Pt RDol1dXMySjyoyBgqTyvf9c/5NIa0ILrTp7aBvs0SsVU/Oo46Y/rXMy6RqLvuaORwSVLCTnv +tSykOt/Bs5cSjc8JHzjy/lzk8E966LR9GGmyu726BjgK4OTjndx2pJA3ctTwtHOqiMPEchY lX168fU/rVC/mZF8r7NglgcsvAIORn34qZOwIzoyWmEkkI3BgQQDlTzgk+nIrWkjiMkvlxyp jaFjHrjBOTyeev0pR2KZnDbaAQuhdyu4sxz39azLpZLiYiMKpQZxg5wO2RUgVZ7RLqImaRhN uIyeeODj37flWxBYQ2kNxCWkJwrQsiqQpOPlPqMA/nTQyGYOLtkWFjHJjDuMZIB/+tVqUqyL vUBFZWLv8wVgMZH+e1aIlmbeXphJ2MHByVYZGfTj8Kq2msLbyKiSMkiN5qAgc9/8/WobGi1N 9iZStujRQnLi33ECInqqkdUyTgdR05xmqTvFJdbGd0JfDP1OPxPOPwqEtCmRxW9rBeyuzLIw B4CYIHHP5VZkul060LxfM3J5zjHGKpbE7sw5SLh2kZmUMcc9RntUInNlDKEVApPUcEe+fwH5 VLZRnNqUCxbSrOJO+cqev+ePWsaVJDcsYo/LXGdqnJ9P8/WlugJLaOWcbsAoWA2sOBWzFaW9 zFcCYYlXqVYbQBxn0xUKKZak0V38Om3hAt5BKcEEl8cH8P8AOKwb/SblMShMhODjH51hOLWx 1xqJ6sgE8P7wTFVwCQ7nA4HHWqYjihcSxXQLlsLHGc8+tbwXc5pyuWAJLl0d4T5jZUluMHnk +vb8qtLpkkTAjckoOS2SM/TFbGBoXFrJDAskwVJyVwz4z6dvpUFrdssuJHYxnk57fSi9gRLf LK6OhCXCsCNgUZz6EHtVvQdXbSEW5try6tZ4flWe3h5TAxzz6e1c9R6nRTWhd1jx9LqjRw6r a6b4ktoS3kXdzavFeIe2SpAYgZ+8Op6mqOuxW2p6YjWNtcQz+YCtmXVoWJ6sehBHOOD+HbKH vO5tN8sSS1iuIYTGY1iCpjCjPbk1XnR5Lfylk+UHcofk/XNdVzjMxEkLBlYPHuOc/Ln161L5 jsGCRxlAMndxgf1q0SwtI0kYBgysQTsRc/1rSl0JzEWiChyM5zgEU7XC5lGKMhAYSZQSGMg4 Pp0xRsgD7vKx8rgR7jtBwQCO/HX8O4qbAZlwot5DI6qc8Nv6/UU5YmlIaD5gTuIBGD+Fc3Wx trZMdex4iifYFbOAWznNb2mtGtm0EnmeawBTaevrn8uK0irMiWqLkhjhjd3fZIBgBTlqxL2I XSuiI+Mfc6mugwRW0+5njikjSN2Q4Vsr05/nVq3vWSTK53qcbG9KEMebpYZVLEBc5wOfrU5v l2coWLfNgdB9M1oRYlkNnMCWBLADrxzVqDyI0Uo7NlTgdqoBRLFsk89CXYAIRjCkHr71mXyQ y70Ujd0+7yff2pE7GJsY3aNHdsXTo7DBHtnvViE5V2b5pRyeOTk00gJjYhw5dyjbchCcHA61 DAqSyGIAxgD7zAetDQhsv7mckxJKmwr83I57/WmtKblIz5ZZ0GF+lSM90FhJ400f+z5DYQ20 So5t7eHGGU5Xc2cYHUDHWu38OeHpdOi8tpnmYtuLOcjPfFdEIpO6CUrqxsTW9zdrNYWm61g/ 5a3yD5h6rHnv/tDpnjkcalksem2lrbWsBEEaqip2jXHGa2Mx6Tz3qt5kYtGDZVVfJZR/ex05 7A9h7ipzI3QHJHBIHQ0xFWa4kVwuFEW0k8ncWz/LrXO6lrjxHbj5W6D0oYJHM6lqUlxLkttH QBBWFqF6YJGUqHODxjp71zSNUZhhMoaSRMjovU1lXW2JWVF3P0MmeOOtc7NTEmkhaZh9oVlC kuxOMVVW8jMRRXCDsHGM9KzbLHSRhLhY4j5gYb2Yc4GTx9eP5etPNiLxtpI2r82AB6GoGRrD Hany1jLAHAA6ketCHzJMvvgjBPHcn6CmhkzqqWzeVasW+/uL5yMgZPoOn5nmrFtC0RQ9SCGB I3cdqok6LSzbIwln/wBH4V5FQ7cZ4yR75/WtgEMRCkYuHGNzclR781aYjQh0yZk3I0Q2gMCy En1PGa0bXT1lKhiSQeQOcn15qkhNkn2NWSXadpyF57nOOf0qa3tFt28sR5cNgx9BjnJ+nA/O qsQW7u3gvSRdwCdXjFu4kJO7OcDH0I6daq+ELN7azexvZ3T7MWhS7nBcPGOEPHJ4xwOmKrd3 YrdjoLbMMPmgkZULypzjjqO9DvHA5YcoULAkfzoYENmYMGa4kU87VUHIPPt+f4VBeT4tpTaW 0Us6K22N5Nis3bLYOBx6fhUlFDRdGtomvmmnW5vZ1zJNjBYAE7VGcKg7L75JJJJuT3TG6G0r GyJkBQQPoKA6kzXayLHM0nlZT5gi8E/5z+dVbe3uJ5DK4UxjHBPXtnihhsLqF+wQi1DRwcFY w2AxGcswP1P+Saopf7nDeTKBIo3biBhs9hz9fyqWNBfxTRxGQA7t2A4bnPHXH0/SsmSW4kkj RQrH5UKOMr9fpzisnqUMubLyQfOkiVpG2puOQxweB69KmitbgvGEdo0VsO3JGT1645+lUkBF LBNJPI00bXKlNikttwPU4+tUoPLMhHnGLdHjhclCCR7ZHINDAtpYRXNqsPlo3m5yHJVz6+nO KmjSK3R7cIwmwMKH4wOcE/56UnotCkrvUhEkkrSB9rJAdkbbcbsYBOPcg/hzWdeajJDazqzi SEvgDG0DnoM0mwsVbfUUZXiQ7WIBXI5b/wCt1H4VbvFi1CG2L7vtcC+Qkr85jA4TOOxPHIwD j0wtw2KzwEbDkyyA8jOcr6jAqk9wLyIOrnaHZTt42jgfnnj8KAIY5oYGzveeQpgvngn3/DNN mge8YzEkMBsC4JBPXp09P0pXAW9t3iR8lWweSo4yKyZ7SGfDSsJI5eiD196lpPcpOxTbRraL HlDavXqTj6VWjtCzRk8Ek7yOmO3NPYOt2F3Dh9pYRp1DH1+tP+wtbxvhgwaIszeauGXJB579 OnXimiWOj1HypHt7iJ0fbhWJIx359sf0qG6LPbNIskYiwQSxOT2/pSe40Ylpp32ttsU8aqcj 51GM/U1Utnls7ji1EvlkkN0+nTFK4yRjJcSB5g0R6hBwOv8ALrXU2cMt4ouRIrsGHBOWyPWr iyWbkGiR3jLHKwVpOTnHHU1m3Xhu3sVcnNwgT7v3ie3+FU0Sc3b2oS4JTK4bhVccfXNTvLNp OqtMI1kgmG8J23dawmtDopvWxn20pnvJmyibyTsUHknr+Va2n3mbsWhXy9g3KWbcxz3JPNYQ eprNXReFlch2Zp1fe3zAZX+nSs2XJZ44mLpuAbC4/wD1V0nKXIbUNCQ0G8Hghjz9aVbeEbAp EanAIPOa1SIuWjBbrlYyFJ5Dc5BFRQzzbMM5cqdh7ge386skrXU67Jf3Spzzzkt/hWXDNCGG 5TIWz8ucAZ7/AOfSkxle80szIQq7iRgk1HolmbctbygCYZYgDkHJwPyrCUbO5pGV4tGjd2om tfN3DCH7g6Yql5xsnR1dNrAcLn5aWwItxZurcSBsluatx6T9pKAMVf8AiwTg/Wt1qZPQfqtg 1oFD/M4bc8meTkAdfrz+NVFiEakbW+X+NRk1SRNy1Npsd3AskGzcF58xRj8arXdpDEY0Djef 4AcUxEVvao8zK021MdAOB+daEU9tZxEvICrYwCORiqEStJHeQtskUPgkbuAfqao28F08MhaH bEzbVmwdufTNNAyOTTjLIBGyZwS3b+dD2jaXbrLtLzA8oQPzFXYgy7nVor1N6o0cwzxgEZ6d un403+0IwCSqPtIOOcj/ADzSARZRdKxt4iXblY26HNUotQurZJbWeIQvHyWC8nnv61Nhn2V4 V8HW3hrS4bNEJKKAXc5Y+5Nb3lxIylV+bnGOn4/57V1kXLKqHAAbggA/1p/lCRfl4AHBHU1Q iBiqsMRs2TjGKUyLDgtkbumB1poRn3115Ns7beTjaAeTXG38EpVsY3Hkl+gFQykZM1u0MJ3L uc4yOg/+vVSW2baWMY+Ycj6VzTLRz+oTyQxyMJWKLwU44NczcRG+mbc6jGTy3A9q55M3Rl3V mk8iCCERsQBtQElj61ZTRJ2Mb3Ma7h/eHzD+lZlFlbLyXKxrkse5OKlurZ0gO1hA/VjnPakM qx2kloXwflRsZU7iCCeMjr04xTZY3EjKf3knTHcevH6fnVoRfsbSVkZH+8cEKFzk9ef8a0I7 GZ4y+ZIt2RkpgHn86tgjS0e1aeLy7gfNlZA4BJ4PBz9R/nIresNPaK6LAHaOeCBzUxTGzsLH wrevpbajHAotcEEh1zx2xn2Pbn8qiiwYN2CGHzbyRyP/AK9bJEaFR1d2RUzyxJAHUf5z+daD 2ty7ZB2D7pMnPHqPb/CnYgrarP8A2HY+e0b3ciuAI4ozJK24gE57c/gAM8CpopluLmCKOKRX mU5jYj5VzjeT2yeAO/YcGmSWBHqEV1K4YGJsBIF5AAJwQepyMH2IPNM1ZrxhAIYIp1VwHaR9 nlp3IwCW+mPWgYyS2kWQLhSOg7AjrSMILdcMETd2zUsZnxPCly0zAiQfKrn36/QHArVuNjSo xj2+ZlQ69MgZxU3GiRzbSQzLbbZWTg5BGWxxz7VD5rWkO9wQwIUgDPtwD70AxLy0mPlu0SsW XcpXocDHWsrU1khAPkkkkFWUk5x6/nSY0Q6ZfMpneMAO3yOzgngbvX/e6/4U7yQ01ugKbpWH 7xuFwcAfhg9ahFF/UNKewuPIdotkTkCVXDr74K8EcY49fasW5uWtd4t5Ygzgn5zjPOcj+VVs IpyapLqFv5Zc8DhwMfnXP3V6bOYxMQ8+Mgp0A9DWcmUWtLuW2+Y8kg/2XOeD/TpWxFHE91bx LJ5UUzKHZ2DbR0zye2KW40Zup6g7rKHKAOnzAuS+fb6Dv71US4SVVMc6h+mM8qfb/GkUU4L1 JT5ct0YwrYQxoMnnuQP09q2BJAybhhjzlvXFUiWV5tRU2+5CcA5DfdJPH/1qy7y1F/GsjYZk O87jkkmkwOb1rXprOxluoSBHCWQxpEWLYOM84x9KueF9UlurlvOdVhxv8w/K302muRVXzHW6 a5fM7CVLSZfNjIxsZgz8844FZl/A0MHkOwEr9+4GeOldRynLzRvDcH59+ONzHj8u9WJ5JEwp 8tiBuztwf85oGc5ePcTTli29QDtA6iktricFVkDPn+EnIrN6DJ1vEYtgiNieFz1qI3EhiZkO 4Ak4IDA9OMemRQmJiabPJLLIjwKQcAErn6YxWp9u055ot2YVUFyUUbs+nJ6Z96q4itdrZ3Le cyjyjwWRuSBxV+2khtHhMJRYwfm8w/Nntimhm4100sRkt2CleilhluecVn3Esk4bYCQoAYE5 bPp+taXIKAsYftyq7sB6E42jHSruur5dnBJGmw25yC6jcFPGeveokrxZUH7yORu9Th0u4WQx mSXBznGTnp9T71D/AG0Z9SS4hkClF2sCpDbTxyK4o6O53cuh00Ml35bLLvUNyGznb2Iq1FAb eNpEYGR/kcuoA59M16EUee2Xppp55YUdd0KIUDEklVHbH5/nWJd3ccl2Y0IdVJG3OM/jVkCW ssFxKFKurphQRjC9s4/nVyWGLbKTkNjoOMnt9TTAzpo3eRo/LJyMBiO/1rT0fRY9szS/LJGA owOh7E80dQJp9MhgnRlIl45wPlP0rM1/TTH5dzEqo2eCo5+lTNaFQ3sZM1nJPEGM23dzQi7L by5FQsejlQT/APWrEontp1tB5gXc20kLj+lbi34swGQxvEyDLquMMR7jqOa0iyJLUXULi21G PbHK8eOD5h3A8fSsWexntYVYPu2nBPQ8nvmr5kybWM1dXKNLCXLlhwCcgHvip4LtbiXLRgOe mxeDn1NMRBPbXUc5B4j4ODzx2rOmuUSYqfmJ6896Yi5BfBInikgLN2cH8u1amlXsVyyxLPja vG49DVoTIL2xnuJHiyC3+x3qC1eW4Jt5JenT5aq5JFNFEYzEdqt0OOMms+WxiSZSS8pOeV5H FDYi1DLJBakwoXCnkHHyj2H1qKCaSVyzqWZuPmbNMR91QwibduYjPTHeo5IUEmwDJ9B1Fdli B8JMSqAVPv71FDazeZ5k9z5r9kUbEH0XOT+JPtiiwCySBwVzuwSMDoaTeAwDkkr0JHSmwKV4 ICmGXOOFAOKxL1Y44ycbTjgNWbGjKlt4Lg7Wcb/7ucfn+RrFuiY5GUsCvQYHArmkaRMeQwSv NC3IwMKBzn3rJvtHgXCxxBvUgc596waNkyKHSBaxlsY7Ed//ANdNK+XhSPnP8ROf8/8A1qza KuV4oBFKzAM7EZ2g8Ed+fWpUhiebcw2unGwjcRUlFoaMJYdgzHESSRnknnn6/wCNQW2hGKZy XbbkCMLncfbP1zVpCNm00RLeWPaqvPIcFj82Oeg7VunTBEATEZDkDkfdPrV7iEGg4XepEDI/ POT1z9P/ANdXZbR45I5lAbMoZ1Ztq474x/LNUlYLmtHfkW8aIoZiAEynB49qs2mzzsuwaN+e f4cdBxVohsnvAn2XfGquVXbkHoSR/n8Ky51vLiZYpAwQLktk/h/+umRcmt7IR4IcMVBzu64+ nWtNZxYopSJ3UqAuF5yT6dhnFDAy9Pku9Z1K7ndZLSGFnhjgfgSbSQznIBwSCB2xzznjRvlk REKjbG3LKxBPakNGTBc20MiJc3CQSylhHFO4DORzwPoCfwo1DTHWcmSTGGyCh4IxnH6+tQyi rJpQXmUnbwy5HHHc1DHfyWtyWUrNDjAAGf1/SsW7alosx6ys+xY/m+YqygEZ/wAOlSzMoRc5 4OBuP9a0T0JLGl37RQNHLOq2wI2xt09gPT61HMY7qRCDsVRgK3BHrSb0GY2oWybmWNSY887W x/8ArqLT7lre62eWJXK7VBHKe4x27VKGdbAkU0Pl/LJIOW54H5/yrndd8ILqUbeTOY5Bkll5 K884Bx6Vpa6IucxJZyWZkhDs+TsUZGfrWJrdrI0yrFCrOo5LNge4x/j/AErnloaIxprq4aVV aaW3xjzZEJCqoHc/QmqNr4svEkiiO+4h2rIfJBChiAeT7d/p6c1nFu5djQn8SmaBriBlnySW L/eBxn+lUtP1KS5vm3ISzDHltjk/X8TWoBqDppKMU3ENJ5jtnAGSeB69Otamj+I4LgKImaVe VO5OevYdf89anYGWbzV4GjEj226FTgBxgjI7d+xrH8Ra3a6bBHFbSEvcsd23su3Oef6VFRtR diqavJJnIvrK6RYx2dnCTcK21AzA7jnLcD696tSs9ysJnkjtnGHEaIcn2PP6AHpXnJ62PStb U7y0vJLTTbeG3VpGK5me4hOUbJyoOQOMDn39uXRrNcTKGKRquDg5yDXoxvsedK3QNZht3FtA Y1RFywYJ8xbvkjnHcVmXFqHd9oKFOox1rYyuZdvEH1BonjdgR1UcHPpVDUIlS8kyrRqB91j9 01DQ0yqtrHNyZVX1G7H481PBHHA2wygqOWYcZzWVrFE8bSGWRNu+EYKzYDD6Ux7CGeUYG2QD kA9fT8KYjTg0dI7eRjHjB+8c455xSXcVvBGm8AckjZ7e1abIVwSG8hmjMiS+WFDxnGAQee/r mnvdyeYNyAI2TtGOtK4iVUe6nV1ZXbachxjpzjPeryJayRr57CRfL+fc5IyOn6VqrW1Jd+hw uu2UdxbgQLiSNmAkzjGOR/T86zvDWnJNLJGZFVm+QgnnPYg+lcLPRT906PSbmeSMrNOqSqxG 7HHB5/lWkLp2jwxBBAbOOp7V10m7HFUSUiaS5aIOzPsOw/L1zxXNOJDM2ZDIzc56fga2Zkix B50Z3cBWyOTn/wCvViSa41GWNH+V+AGQenTAxST0EQyX89rcOsrpJGTnC9utaB1iO4iKRq5I Jy4J5OOP61N7sZc0/VVezXcN2zHfBFWSIriOYzMUzGfL2jIJz3rTdE7anLs5sb4W8jKVf5ht 5HfrV2L7O8Tqwcrj5T05rmXY3l3RBcWskbxuq/uyOGRavWejb42aa4UJtz908j1xTRDJDp8L spEbCKPAdhnPtmmvaRRI3Ls5IXbuyMdulaJENnP6tF9nu2WKIEDoQc1StL90kWFodwPBPTH4 1ohWNSTUxLEEhUAjlllbnHtVVktdQmlkaBFY/dCybgo7j19vWgRHeQTQKSoDxcE85I/Ks+eN YUDQsUJ7dKoll6GeWVVZzlgOGBwSfp3qtHqpiugzF1cDaGT8gTQxFKVEeYkMSrHJ3Ek5qS2v ZbeTb5YJbgE0r2HYV9TmWTLLyp6g5z7EUq3MhkJ7EhiAcVSkTY+8bW8Eu5EBGO//ANepFPAI w+/ksvI/CvSRiK7JGrnD9M884+lRRRTXSB3Gwc5GaAESNYvlVeT6nmq91NvXCndjjj9eaTYz Ju1lf/U4Zxyc+lZc9w5jBHzcYHGP51lIaMe5t7oAOY3VHbAlZSoJ7jPr7VWltt5VWcMyc9P8 4rBlpmIbNNPmlKkyFh1J6VUcsXJGAvPXqawZqh/loBtBCpzgL1JqnNL+8EMdrKMnibAKqfU8 57VDKD+zmiw0simQjAwAoP4fWqR0yaBldBK+9xwTgdeef89KSRZ0ltG0UK5dMYyBj5vz/CtC 1s1ZQ2wb2wVy2cD1NWkTc3rPTha24ldFZs/5HtUFxfiF5FS2DOwPllmx17YHT69uasC0IjcA O0ToVAIUH5SPb1/+tUE8iCfYARvcAMoADY6j8sn8OaYF6Gz2lPnZ0ByeeV44xViCxTYysgkQ 5yCPl/EelNEst6d5N4o82FgN5VYmIBODnOAe45xV25tXlbekMccajcqISzHngMOozjpVIzZS kPzSstsrbiQT6Hnp6+1RtckyRswG3hQqjqOo6D6c+3TtTAtWebKOV5cSO5PGBuGcngenB9+t RvHNdzNIIyiSYIbOeueSPwH51IyjBo8T3rXL2cbSRElJvLBZRjB568g09Fa7Zncgqo5C8ZP1 qWUF+p2hQCUweO+ccVmrZBm8rY0YAzu454zwKyaLTI7Kw+xzKFVtpTgtz9cn61ZvLc+W7quM DO3PXmjYW5RikUL8qDYo+9nOPx70gvPlCPEGdCSWZsYXHTGOeR+tQUkU9SQ3dtGkcQgY/MZD kj6VZsLWKC+TGxyUALtkEY5+maI6sbNeF0topPLhkRsH5i+ccj/PtUB1CDTl81neU7chHGMk jpW19CLXOI8V69Jes0kE5iBfBXC5Xtx/jWAtrPLEJHZkjLZXqSSD3/KuSerNFsVtTtYNRgv7 WESQrKhUvMMPIh4cL2JI4x6HPtXF6jDc6HdRrFE7GRsCLk+2CfXFZJ6lk95A8ka27jL5yxQH H057ds1DJJDbeX+5Ecg7uPvHp07V0IkZ/asbWyu6OY3yN34dhVKUybTLbjcAPmJ+Uflzn9KG Bft9Q1KNImu4t9mx27MYJ64wevT+tU9VtX1lVHllQhARiQuT6epJ9vSsZ3sa07c1ySw8OLaJ HLcF88sPKypDcentxz61v+HQv9pbxG/lJG4XzF+Yknrk1yUo2krnXUleLOjlUzyDawjJHzYH zDj/APXVe4aW0VGRQwx1djkexr02jzSaG4inUm9mWFcZ3BS2O+BgZpGiXzBHFF8u8g5GO/ek BQljeKaaSMKrIV2kjryeMfTFcxqbO1xMSCGcZLnOOn/16TGighKxMg3GQYwdvBH1qeRzJjKI oUKuVGM4GOnqe9QykJb3DRM5iynTBz0FWjNNBOCiRsw5J29Mn/P50hM1bTUXaN/NYkOw+VQd o49Kr6r5NxcmPd8x4+VcKOPaqESQas9tGkJ3/ZouoVyAxzwTxSpqIdDM0WyMthieB7Yo5eor k1tcDUZTDt+zOWULsBZSeM5z68mrM2mNKUiKiQdSrDGKW49jj9b0CfSJZA58z7X92Xd+YrFt ZZbEERMdyYAbOAOf/r1ytWdj0IvmVy1p0tzDqWCdqXKhsOQSGrqIbn7I5SZwy5+8Gz+X6V0U mctbfQvTN9oiV0+dA4HHUrnnp04qlrVoqOTEpjRvmUZJxXSzmRBbzQPHHE25pScB2HA4rXTT 0S2zLksQAHI5XvxSQmcxf2oaVgpyy9iOuKuadp2EBcNlgSFHQjvUpalXJWzHgElMfnipjdhN qM4ZT1Cn/OKrYlop3kBu8GNQ0seSCDy1Nsb2GWIJIu2QNnBO0isnpI1WsPQ0bSSaGQkpGyse h5wKim11bOdUlgFwgGBnILe+R0pvQm1ydrmJLQXGNhlJ2ox5wMdcdqWbW4braILVbfbhSQzM SfXmtUZGXdlpLvzGUFTnf6k1WktysjBgUCjowzuz61YFC604faDJtO5fQdRTJoM/OmA/ABU4 J9KBEhv5kiYOpbyzgjHOeetVFu0MgkcHPQjrgUxMuQzxXltuiy0inByMfSq81g92CwhAQDLD OeQaGBPO0RjU+QolTrtNV3sicnHIOQ+aQFcxjaQ6kMTjkcn3p0GntJOuxsluCuKEI+8IrI28 hK/KpJ61O0iwqQACwHQA4/GvURgRyTStbSSLGCQBsBbblvr6VNbFns4PtDIJiuX8sEqp6/l2 96TGVbqVcyYYAKcH3rOluI1QBmKZODx+VQ2UkV4dYWwuWgitobt9hJErHAHuBzn9Kzb6VPOe 4cLArkbYEAAH0/U96hsDMu9SRLeWAB3gJy0bOwU49TmsC71aGd2aMG3XOc53g/QcH8yawkyk igDCryFD+8c+YSq9SQOo+gpZXRlXOXPOVH8RrI1Q+IbwdsOHzjp0ODSIJzIfNCpEOM85qWUS PbQzBC0y5AztJxuxzn3FWbayNwVMkg8peRt5H40JAaMOlozFtq7CcEt0X3PtVu1WBirQHdkf K6qSGHrkcVaQXJLoSW0Ydm2qed4/+uaz2khmlUvICoJJ459qAFt57rzm/wCWiAfc/hxnp7U+ 20cS3ZmZ2Mkz7mUtwgwMbV/hHHb1J71SQXNuz3WgWN4S0ZBAI9c8H6VHqV6kMUInjEytIGSM AnDA8E4GMDrz7VdiGTfa3CmYKqSjoV+UZx1Pc/Sr0OovdgkzqkAwTICMn1GAev8AjU3sJjHu 1ut2SCEIHz5zjpVVb1hdgMBISRwDnLE0xE9jci9iS5ltpYGY58qbllHYEKSAenerEiXPmsI2 2ow+UjIOD356UAh0nl2FuREzKGbLMPvMeh/likKB96mEk9mI61JRnajcyaYpiK7iWycZ79+R zTILwxRq4RVdjgr0Jx6+nSoY0Os5FYSoSpKMVDIwYBgeR3HWp4LAxrsaPLAHazHO7PeoZoil d6HPyIdsnI3HOdvHp69OayrvTJLIBpMiQncp3A1kykJDDJ5w3DcCeQT+v6VoXEyIquI+gC70 6DjIJ9ulXEmRUubt7N/JAOWG9kJ4Udz+lUbkeZCVjl+WXdvLnBGe5PoPetGSYWq2som2W8IS FjjBxn6n1/8Ar1mncjKhGJcFVy2N2B2rmkaIrG4aI7dyyTgEgOBlQe4xV6w0gXOnyXrJsut5 EayrhX9CCB0yMfWoihjpvDFqWSSWTyZnHzMwGD7+3+OK5nXNCim8uC1jjYZ2u5T+oHPrVsDO tfA4tbyHfvlCyBdozjaTz7jjPStfTtESK6fczSqo2opGVHPv9aaEy7q2nRW0hkYK6dQkfIH1 49c1zOrxxCGCUo8cK3Cgq3XPP41M17rKp/Eipfz3bCc7p7eGIf6wR5DehGR15FSaDdGTU7fe +zzAVCs2WPXOBjPaueCs0zsesWdif9Hs3kk+SSNTjnqR0BrC+2TTSIzpvhJDMp4Pua7WzgNW z09NQSSWGYR8qoDdfw7VNNbCyuJXG5lGAQc4x9aAIL6RLhXlLAqNsaEjnjJx/P8AOsnVLIvG q5Mi8Z3DHX2pAU1s41t5dgZUR8E4x07Gsh7dk3MIyYxyucbsZqGhk0EUssTRpHtY8kFQCTz3 /Og21xaFZA4RmUgqONv1qRlK51WKylCLEuVOxZAxIqylzczoWiYhZFKkhuWBGD9RTTG1YhnR XUcyNJn5tx4/Cm+aiMkSqrHbg78lR6j/AD607kmrZNbpdKSyAnKhVOdvrUt7qsiA+W/73I+R Tjd16miwjKvpm1fTSkzmGaE71kkbPI5xj8x+NcncrFHG7jcQDvDqT1HtXPUWtzrpPSxQfUpr mIzKXMsZ4cnPHpXQabem8tklY7dy4GOcVMJalVY3R1OhNJEjvA7FV6oTwRit20VNULyysFXh Spx+WT6iu5O6OFoxL2zigvwQFMa/MeDtx65rYe+tY7V1yy5VVyeAM89euauJLMm6t7VGYs2P m52kZ9e/NPhvbdFO1iTt3GILyfxoEjOuLlJZlBfcjMBlxg5rQubCBNqksGA6gc9KVhs0LO1S VBIkYjhUgDJ5Jxzg1j3+mCG9R1hypOC5P1wTUyQ4PWxpwrLHIIWtszsVVdqZOegA+tZmu+H5 y6OF8mYLlkfjjqOtDV0CeplqJw6rIVIxglentUclw1vvXcD+HH1oQmQHVJFC7Blu+Oc1cgu1 up40miWJnxvLMQDWi1EyzeWJgXBV4A3KEjjFUZLchGIUb8A5zVshFKMEKfMHJOM5walezT5p UVSP4gefr/OpGwt9RsLVCZCwck8KBt9jntUN3q6xTKduxG5+/wAN65piI5tQEtwXG1hnICAF f/1Voi9TyMFQXZQeoORSAuz6dAioXBkRlBAzgrTbfT4dzboxGo7g9eKYj7S3CcABmwflALd+ /NJOWjJUtkAYBxk16hzkNqTcHzlJWMDI5HND3Yh5UqzZ+6efrwP881LKRnXUkkhjjabcSAOw 59az7lftNwrxE5jwHLHk8d/fkce9ZssS7cCFeo+YHCsckj1H4/rWO8DSzb5mJXO4knk+gqGB m3NwjE5/dRjpzWHK6W8gCMHUckE5/wD1msJFIhN3Gs2Qu+TBJ2rnJ+v0q7Y2cbNulYKCS23p UGly59oVPlhACHk5FIYH4JO4dckc/TNIEMOlB3VrmPbz0zggVbbSFXbFESIc5O7IppDuX0bb F91j3yeAf84q3bo8sYkZsFhwpIypx0qkhFe8tJmj5CkK3zJkgAEHtjrxWUlpKXkSdUSIKShU YHTuT1p2GS6PczszJapkqCftDqdg/Dv+lMtZp9UvJZp70bY+P9HXZnj1ycfhTA2o2GxQjZAJ wu44x9T1pkdyZC0bDYSdqucAlueBn8aZLJ1h/wBHZWO+RlCSSEAOR9cduas2KRXLhw7bCcAM eT1HTFRYC3MklmjSSkPETsjhRCzngAAY988n0zxVW6tooHAVt0vJxjhaYmS/2uEAILp/E+Rg MM+/H/6zUtrrcV5KVjCEBQVOcbcHLf1oA0DC8kCAIvsBnBp1rMZ40QmMDkBxnkg+np70DMfU GmgJMkSzbfmB9B7VkSF72UMymDd1ZhwfUY/GoY0P81rKLDghRk717n/Jq8NQOIo4nYh+Gdz0 6cCs2aoj1C6uAq4fZjIIz97I/wD1VkR2N8twrXCq9uFwAGwwOOPrWT1KWhMtoHhjZJCoJ+Y9 vTA9avWhFq8kMbmSB/vKWz+FaR0IYv2W2naQzRgIOueuO2MdfWsy4jhkMqlN4iOEBGd3vVPQ SMWe5tdPbaoaQRnblsk/meT1/Wpmg0+4meeeDzJFVgg2gsNxycN1A4HA9qyZRVk0/T4pTcPb LGI0A9Cewznk1YurVygSCAMu0lA5IAGegxQkBW1Hw29yPOuJU5TAA4K9eM+tZlzoElsyLG+b cthiThsY9RSsBpadoMV0yu8bbkOUKMQO/HXnjNNmtYYg8YhEDHoxbOeoOPy/lVJAc7qsQtt0 qyqIlADMp68Yx+tcnqniAWUlpbT2jTwtIrmWFS+BuwOBnv2JpMuCuy/rYgjtUQ+adzM6gtt/ DHt6VhQSPbarb+ekslxbkphcswU9c56/hXO9Gda1Vjsr4rPaRx7CDKCdydcdOR7+9Rx6R9mU F08xRjG3HK4/pXTucWxqW6C0QuiKI0GclqhS4kuGaacOiPjA/Ht+lMRAFiiWWWZyctwMdPf/ AD6VVtL+CW88q43JG/yiREyVHqBU2GRT6UFmbGWRjnOPT1+tQtZqnMo4T7oK5C9/60mAKsMV o+EVpmx8yHqe1Z+q2+23jYsGVhhinJHH/wCuhrQFuc0otridVwUm3/KSRk/Qda0rwXVrPaJZ QTTLJGWklkQIkZ4woOck9c8AdKzjZouasxElSLzMqZHBGemM59e9Upo3dZJWUIS2do9KnqSL p+37RuJwo5zg81sSRxqyMHQAnG5lxWiJKc6rJIqEmUDKjJxxz0/Emufu7COOF4iywtkjaT2/ ya56jOmluZUGkQWY2XMu0gnaRj5vy5FXfDUtrC0tsJPMVXO0k5yO/Nc8dzolqjqo9SjSGT5o zGPlUtwB9Per73bWpjRiAr/MrbskAk9+/evRjsee1Zle51KSVWSNcAjBdDyVFZrTrEoUSbg3 zFMkmrTJsLazG4j+0tD8idd2Cc/zqWK/8i6E0QAAGCWHBGc49hVklO5Zr4u4ZUDOThMAE9jj 8f51bstcnhTy5Y1dCPLD4+6eOT3pCZ2Gi21l5KO5JdlAwpyrEd6j1TXo9PhnQNHl+DEQDj8a oS3OWuvETGaFYbeKJI1HAYsSR1PPr6Vfm8VLq8KpNLIkqqAN67lAAxx+tZKS2NLFO5UW8gcS h1L/ACSbeGHYEYqrcxxTCSVHGUX94vTk9hTiJkVrBbTwu5O2VMYGeGFQXpIGQgYY4xzj8a2S Mrj4r66u4IlaUvGuSIt2Biq95BJE/nvC2Cvy7T9360+gIqmdQRvBTnkNUN0SWQrLuU9genFQ 2UjNu5hBKdjEuvOOo/Km6dL9qvjDOTtI5ycKvvQtWDNi30/zpEEJMiA7Rhev0poidZ3RQ8RX PDdR7YpkltNbvIYxh0uAgwVIztHb6UzUvFCm3iyJFctuYIAefWnewWufbkVy73AkkxEqnAiX oM/hVu4vFjG5eM9SB0r1DmILy4E8ag8KuM5OM47+9ZtxdiCADGAzdFHqQM/rn8KTKRWgM07x lSV4Jyei5/QmrhZXk2Bizgc4H86yYzPu7lQ+wKXIPLNwMegrGu5ZEbayfeOcKepqGUZeowvI iiNAoGCwK54+tVoNKeZS/G3cQCcA/hWLKRbFisabHQEEY46VVs9Pa7DOxGMcFelQzQmNmTEw gRXYfdLHhjxzn8+lTWkLf2i0LyA7RvfnIAPQD8s/j70hmmbRpW37jjOMHr7CrEELyqf3bLjr 0/nWiJLhsYiFXAZgDntx70mn2MZuySOUyVUjAH/1/emMr6laxT3xVZCzKPmHO38/ypbmzVLS TYrDbwDng/5/rQI565kKo8FjlndAikcAHGDx9Kfa6BcWVuIUh8uPBLFR8zHHPPfNSVct6Zpc jy7jh1AwVfgKa0U0NN8Qk3DZIJAFcqPTseR14PFMRo/Z8kjavzdW7jnr9afaWgaVsbF2DKtj JPagRNKXjXf0aNSCTnmudNuI55ZLgmYtn7/Qc9hSYFuOCXV5YQyhkQ8jP3h1xXUaTaS2Hnxx TbEZeVQFARxwfXt1HWnHYTJrwNOxAdVjHJ9cnv7mqhkFswRGTey4wM5P40wRn6otxfwQHeu9 ByMZ47j6dazmmuCRA1uCjfedQBkVmy0JfW/n2wjH8PZ+STniqkEIhs2QgMU/iB5/ECsmi0Qr diW52SfJHsy8pByfp+FXzIsKHLfIvR+hb3qbFFKS+s45AWySQAvOB75zV23msp9ETVLW4FwY Wxcxj5WgOTtPU7lPA3djweoJa0FuZGteL7cnbbQow+VDN/Dk5xz+XT0qC31MzFbZHQXbffa2 Tc6nqOecHn8qbdxGU1nNPfSpjPlnA3KV3DPUfjWotm7TFlTftADAck1KQXsWowD5gkVdxPy7 l6DPAqqg33KQx/ukAztYYBP9P/r1dgRHczSQEJHvZN2HLnoO5A79asubWKNv3cF9ME3bWcgg E9cAj/OamwynNJay7Vt/9EccMsbE/wA65jVFaC+LblRY+rA7uo6+nt1oA5rxBqT/AGSGNLiK Z5W2+Xt+YD/D/CsuSKbTLF7hg8u59wjjY4OM8Z+me1JlLc8/k1S6m1SQFriSYyJIYGkAKgZ/ TOeK7zw3dpqAsIZY1hNuxJLSFi6/Mf5keveuTqdTeh24tYyyNDuAJL7FGATjpTbxgV+dH5HQ dq6ziIZ5UltDBjDADaDwas21uUtEWQlwBwxHX/PrTAdPEZ0WBhtXcCOOo71i30TWd2VVSWYZ yE5xRYZHJcxOiKCGcHO05ySKab4IdsijYTnOOgzUDLYvRNCZS5AAOSRjGR3/ACrn7vVobi7W C3RpSSDlUwoHvmq6CHT28MJdo3T0O0dD7fpVC6uS8wLnKjghRjNZbFG1p+k6LeRztey3UBMZ aBoCGwwXhSDjgmuc+zSJvjc7guSrMORx6UpJdARSeSaJQ4j4JAOz9aTUNQM8JwrMnAYMNv19 aluyGhunSeXcq7y7VBxhwStUNZiRm8wyLJzhTEcfQYrCex0U/iMDUY50U+Zkj7zKvUe1Jp84 PlEAEnqD1A/CsotJnU1fY1ryeG1gglQM7ySY8pTj5j7dPyFa9rfmW1ERJCnjHdefXFbxnqc8 4XjctQkxyeYCrx/dAbAH45/nUMxiMgdJAF25IHJ+ldCZxWFR2x+7yFI5/wD1V0AVJ9PY/K5P UZwCK0JaMFLFrO5ZlfdH1CHkVuWsEE8iEMFk/u9gfSqRJemt4bK1R4JBGmRkk8bvb0rB1a4h NqPKQO7juOV9TTb0A5xneKRHIO/uo6kVqSOY7bzFQqXT5SR1/GuVLVm3REMk811CyqCq7t6A PnHoDx1qoFuHaJBtZ5WEaq+MEnpn0+taxJZZUrb3RinQqFbDANke4qR4zAP3YLxOf9WMHGP1 rpMXuShIbqF1d/s8i5B3DoR29qng1FHsBDJEzyEESEEYVeOnv/hTEZl5bW6Q4L7Seh9R61mS 6ckio5naPawIMbYLVElqVcml+zyny/L2SZ4LtyT+VH9mtkS4EUh4LA5/ShaEsuNJc24Vdynn JbPUU25aGaEBP3DE5kLHknHHP40mxrYpXCoCdo5xyUOMj39ap2dgkZA3GQsc/MelK4dD71+z SOrN2HXH8qsCFYogZG2cj5TyT7V6yOUgnRJAQRhfSspsqTIYwGAOY0bOBk4/GpZSM+XVbhiW iVYkXnPX6Vki9vrrUcRzMqMQGkI7f57VjJmiRpRW0jy72PC5Cn1qKSNRNvds/MCBj9KzuMpa vKfJleJQd2BuJGKyUbyVZ558BiFV9vOT2A96hsaLQZYjFuZjMPuqx5I98etOW1e2BnLtIWBy vO0HJ6D8aktEEd9NJNtZCqnjkckVdjYM7SiI7mIy2MD25/z2oRRdE8wIRUzIx4A6VEl0RtVl KlScbuuPpVk7mhaMLmRFMgIPBGOnetG8uI2IVMrKoyAG649+9NAVJNRkaUKit8secKRgH+uc VUu7+R4RGFBAJJLMMUxFjTdJRJd0hO48onBz7+w61quqqh35zyDyfypAU7SMSSS5cBUzgbuG 9O3tV632XCBcDeoySOufrSAijgkWUyFlVRjBdck+1TpcRRndI3zHggDJJ96BiSzxTySwB8vx 1GAPY/rVaLQ8ufMB5J27BgAfiaBGvY6dBEhaARRHBUs4wcfX/PSppJbe3dYXl2NuAJ4wMjgV XQkpXl/FCzRNvKkYyvem+dHHvyrOVUkA9TipKMK+1+WF/wDUknoVzgAcdfSsvTtbmkllSUiJ fMOBv3KBn1rJvUtI1luFk4cllkPGxhk8YPQdaz9VuLrcjW8a/vD1IOduCM+h5AH4+1O2g0Up ZhHO6SBpsRgRJHgBTkcsTknPOfw98sfUVS8Y3EfmS3Ll5CDy57sf071GxRVnu4bu6WFbXzFe Mujk8KB3I7jPH4H0qjDeDT45IlkeBpFKyHoSGGGUH0OTxUPQRur4XgvLCNFL27ODmRCAwwOD 19u1aOjaYnh+y8u2dSrDYZNgBJycnPXJPWtEiWMnV52JMa+79Dj096ViolRlfYhG0tt4/nQB k3FzHFevFI2AACp4wfp+VZcqySyuyyuY9hVgr7eB05BpXKRLppZ9tuFVdy8yyFm6jg856D69 KqPDBo05iVGaW5USSGZTl8Ajk49yP0pAQjU4re6YNZRTSBSm2Rj0POflPUVTvPMlJKxRrvBB YnOOOhz+NK40cbfxTJqaiOIJG5KBmXjjg/5FZ7Wc01neFImknDBo4wSvTOTkkACpuNbnM3Vh tQzTxLHdkFWlT5h3BGe+eeav+HbgRTRrHsOX/eHdkBQO3056c1zX946Oh6Lb6nHZSqpYOMAq QxZSD/KrjahHMGUlg20Mx4P1Ga6zmKTCP7P5yLvPRduc/jUNvq01vE7K/wC+AIjUrwpxwMUg HnWJTHGSgJwc8d/Xiqd3eTQyhZBmZV3KxyeOwNWIohJJ2NzI2CvO0DqCcfhirFwieSjkKWcZ RS3Hp3qGgLVpZmSEt5gIbJZemfy/CszUES2SRkRY5CRlE4GPpRbQDNa6IGxlVcr1bjAzUEhI VAhMmBkYHQZ6k1gy0PkDQw/LMy46ANzVG4aUxOwJZ+nJ5PamhMqQ3LRxGORCwXkDtn2qm9wr OVf7pGdvfPFSykJdXaxIm3Le1VfsRukcDMZPIJ6g1i9dDaGhnXF229Vkw6gFWzwcj1rPjvYL KVzCpQEcg8g8VzvRndFGjYSQS2sMpTcUztctzjvV46h8hMQAB6ng496pENamtBdF7E5IEfAD FeTk8cVWeSFZCuwB8cnn8+K6oPTU4Jbk01/GSpjbYMBSrDjPcU+1aeK0eZVZbNwfunIBB6V0 R1MmFtfvKuUX5P4gTjb7nP41Na6tGF8ySNhtbO9eMGtNjMVtRbUZ3UMNpOeRyKY96xPC7SvH ris2yiukn2jqV4PcdqjS6nidoWYpEoOFOTxUN2KQSXkKgHgsf4CDUMjz3SnMrgRqZBtGfpk9 u1JOw2iK2nz8jbEBJJc/xVfiu54zvjYI64G8jGPxreMrmbRWt72SK8++GkYnkjv+IqwNaMEw VQX+XI2qOtaJitqOe5GoQ7ZzzyY2xjmoJktYbAJGskd0v3gzhlfn07cUriKgnKSZIAYN0xzW tNazNGGWVfLYZCRnL/iKVxpHPTXU8dwFnkEbKdpVj29KBLNbF1wssbjcPUY9KyuaWWw5bqG7 UjcRwDt6H61JYeas58oswbj7ue1NPUzZ92M93HdlpLwOu0ILaFQI1Pcknlj26ge2aZcTSJKM fvZM4y3AzXsLY5DRgtzLAWwWA6kjjNQTWwnjMakRgjGVFZNlpHNXPh6Szjc+ePL5OWH5CmW0 FpbfuzL5jsQTz1/KsmWWmlPly7VA9j05zWDdvM8brDtKRqTJntUjKVojX7CSdHSNeSCcKcDO QPSobqzML+c8onkjDLETjgZwG4H3jz9Bgeuc2NCW2pRQo0gKAgZ3HOc1bgnimffHckgr8q4/ X1//AFUjQlitJJ5AsQGxe56/StaPTgNrsvQlhGT3x/8AXq0hMn+xO6khMBueaX+wA5PmH5l6 leeKokX7NHB5iAoMcYUY/WrFlBJceczBURMAFyMuCccUDM1w0CyJInIU7fKHBOff61JZWTyQ p5sfl7RhsHJ+pxx/+qmTc3opljLEPGy4yccntWfdMbiUlXIRWB+UYzSArB0JeE/PKRnAGN3r mrdtdGJGVNuVYbmYc1Nxl66vkForBgwP8RXrj2/KqYtDPcR3EZ3K7YIzweTkii4yJbdJLsnB VGym9uC5ORn361p+TdYdixMYUBQcbic8k8f5xTQmRXFmXYxqS7KvyjHfp0/A1napaB7UFMxy BDg4HJBPH4c1QjjvtWqSPE8M7Sqg+4B0z69z1rqreRwVILFioLNj7vHPTnsPzpMpEV/aRW0E xlkJBBJwv+f8iuOvpI7eV5AXW2ztUcKX9/x6/wCNYstG94Xu42R7sxiV1OPnGcADGTngda0N W1FLybzTEqKkQVSmMYGSAD9SfxNWtiXucy8yRws6MWDcseflPB6c/pVy0tI5LVVv2MhbGwKC Hj5Dd8enQ+tZss56/nktL0JEx2gEM49u35movl3JJ5vmOTwHbmsXuM7ewMNxbqsUnCKAGAIB q9czQwRsZFDqMNgLuPAP3QO/St+hmV7hBCu8B/LGSN3RyeuP5Vg6hNcbovJGwOQzb+cj2weK huxaQSD7TbrLIjxpn5nxwD2zWZeH7UzKgXIAHHQ5rO4FGNp3uo44WOUYFdx+TNXjcXdxbyC/ jjSKOZirRDBbgDknrwOmfXHU1SYGQbqKV3NsxLA4y/T2/GmrezJiRgrsCQ7uTuHsO1Sxopaz fsEeRIY2mK4iExCLnGBubH07VU0iwnvF5aNpHAEhPQnHzbc84qRlSfwO9u0p8tFgI3iVZAC3 PcH60y18N6AsjSXDz2V2xwvlRJKjDsMZUg4x3NYxWpvJ6aCNYFLgMrqgHKqjcfp3q1aRSW6q 0j53HkOcY56V1HOWJrqW3YCJAqgDqcgE4xyKrRX0a3BeXe8v93Hfp39qEIL2aJdyRxMzMcr7 exPrWXc3Fx5qoAsKAEEg7ifaqERpp8VzJvEzPtbcFbgKfUVvCS3ubEwnA2kmNuMg+9NAUU1a exjcIkeJU2HAyR0OR0x0H/16oJeqLpjK7MZBgpn+fek3YNyjdPG8obh/kBH19KhiSW4MRKqF 3ADIyPrxXO1qaERXyXYOBgcFtvrUMyPashZSqvlkBP3hmqSJZT83JdmQsg5wOQKpvHG7lo1K gtnaDnHtzUSKRUuLkQOylG3hvu9sVJFM8vUbQ6/McVz9ToWxkapNiZYo42QvgtvxwfYj6Vn3 Mam3VHjKSDOflxu57/571k9zujsifS5GBZJZWWDjChc4Hf8Az710FrHbW67XZ9sjBVO3n9Ku KXUwqeQXt1LG5iiUpbKMbyvJOfU9qga7a3VnfMjbSpHTH/1615rnM4lyPR5J0jJkcMApAZgq +tN+2XEL/wBmwyGFEJdwThSe9dVNHPImt4obSKWa6nQgNhQp+90/THFRF7e4Y/Zt7OX4TIxj +dbOyXmZK97jZQ+nM0at87DJA52//XoFzKwwHKv2PrWDNCbe/l/KSsmfvetILtY5C8xxIeNz c8+9SwRl6m3lyGWFg6l+QRzUO8yR78fJ059KzNGPivlDKmAzg4Iq010VX92jPkZOO1VFiaIr W5+1Sja6hlbHzHHH1p8d41uDhvNHZeOK1TsQ0N892ck5iV26dqWad4YykaLgjliM5p3FYk0+ 03zRzyEFZPuhTz+Na7TT3epTMI1iTaFZF6LgdRn/ADzVRApahoNzIpunLTO+CSRj2rIeAvF5 YixjgknvUSVmUncZYWrrcfvAW2jg9a02FzEu+KJkWPlWShXIkffbzW6x8IFce3JqFLQMiyTY BY8KPrXqXOWxYaRmCqqYHUH0qtdPFbW+6WQI3OMNUMaOM1bVrm+8xY3UknAUdAB7VlWtm0xw 6fMOWz3/AM81BZow27tGYQrxO52ZHBQdNwqCz0G10wm3toiVYNveRstIR1LE9egqBlTVLloz tVAxHQE8E9xWRcSSSqSzAHr14xjtWbNEjIkuIrdSJHKg8DA3Mc+1aWmajHu2WtlNPKcBfMIA GO/H+NZ8+tkbxptrmex2+losaRG5wkmS2AOM+/qauT4LKVB2kdxkD8a6UYPUvW8waAIHRmQY wfSpkK29uSQDNJwynOAKollKdN8sRVOOmOOPfmopJI0KMZFLLxux6dvegRKbGG/8uQhgEOcD oT1/GrRSONRtBVAcAZxnj9aQmVg7AyME+UfM205NNuruZoHUKXYcoABwB9PypAZn2K6unBkh xscFiOo78e1LPd3UTzIEjTaCTyAPXNQ2CepV0pJ5xJdTuX3HA25OT059q1rS4njmTkGKNshW BOTj/wCvSRoWXuEWQDBBxknkEduPSi61qaaZgWErN6Nz7n8v51dyTH/4S24ivZGVCEB2h+mR z+NdJDPE0UTeYFDJ5m4DleflH65oTuBC5ivJI2WMjnc5DAHaSccAe1LcXMVnGRhoGYfxD3wO BTYI5zUrgNe/vWDJGMlnbaMj/JqpDaWk9lN5USTylypfGNo4Pf8AHkVkaIJLT7PYbkAKZy3l nOf84qvb3jXcSDDALztdeTTFYa0+2IYXzJEBVGdsAfhWBfahdPdwgoQi8sRk5IP4VLKJvEtv EPsx+ZVZd4Cnbnjv+f6Vz6QpNdI7K+AR8+OSR79Kye4zp7e/MUGI/MRyMLk4PAznP4Zp8txc 3VxFJI/lhOA/UZ9SO9O/QRr290uoQwxXEpJyVYjPC+3pVC/09LWVfJcSgHqTjH4UNXAzbk52 IdxjB3NEeRnsfyq1BbRvEFGdhO4NnqOc1AGeL+GG9W3xI0pOVBXAA4BG78c/hTbyaf7c+nwJ HIDnBY55HXk8A4qgMFLpUeKRwJVGSwYc/wCPSrElwNimNgT2DHDAe9S2Mz72aKVWSRVlYbSu cH6GnRXXkJGVZEVQTsUdfrSGLq8txe2sEzHEUJEjAnG706/hWNqk0U6wMwMW1wyvjOWJzzWD dpHRHWJbJEcysr+aqnCjbyRjuP6U67tLiKAybDkuSyj7wPbiuw5Qje4u5AqqUYD7xONv4Uz+ yZbY/aJWbL/MG65I4xTSEPu7TZEG89hIDlWIyf8A9dV55ZDCECszdTJsyWHv6CgQkFk1xEWR CrL1TGOO5IqK5tZLJZG2AOMHA6/X9KpAVLNhq7EKhBJKgIuBkdTT7rw9dQFCxOwqHLIpPPYE /nUuNx3sVrm4tdPtWYRZu5MwkOf4Spy2MZBGRzWXEHeB2Vm2AgIO+f8APes5WTKWwoaSYLC2 0OCOc55rSvbXfHbCOTzLfGPnAyp6Hke/9KpLQRlXumS2cfmtE6xMxALDg4/TuPzFUZrcQLv+ 7ngke+awaLTMt2FumWZnkz1x+pNVXkYsSs4YgYJK9K5nodCMe9WW5ucTSZJbblzV2WwniEXn NG9qVxw/I54Ht/8AqrNa6nVzWVitNK8O0JtRQdpL4z+XSteFHSBF81SFHyOecDrx+NUiWrjf 7Mnvow+4zBBnDHAH+JrTTSks9FfUIpxdgPsaJRgxnsX57k8VUVfUxk7GfdazeXkYSd2YLgqp xgf40+8vxfRqs0CK/d1ODjpg11xkzlaMx7VZYUjRznJ2gnNaksZs7KEiIx5JPmEc57jP1rXz Myok7IFZE653EnJJqQO/lAopbHUVmyiaK/kkwr4T1GOKZdwq5jdpQ249F5I+tS9gW4tpFDPK 8NxIsSthVdsnHuQKrzNarsSN5Mg4ckjaayuXa5ntvEwlkjClTkYPJHbNaKXEE0YkQ7eeQOtN MprQr3NuTGWhIkGQSAOR9aJJ1WEqUCvnIKDp6gk1omZl/S5XFoyzAFUJYgHovqKx72+EcUUf kmKQMXLFs7gcf4Vd9BW1LWnSpdtC7OI9uRt6YrZkklWL91C8gY439enX/PoapEsna8ltdMMB VWDclGJJA9KoWOnQ6jcLvlWz2ZPzn5CPrTeugLQ9c+HvhnTLK4lXUIku47oKsU0Z5U89/Tn9 K6WP4daelhrFnc36WlndMHAjAADAnZjPTHGfXAre1kkYN6nvUcYiBIQHC8EjimOWcZB+7xgG ulEEBvCHMfJwMDb/AFrD1MpeSAvOEA6IOSQOtNjM+OOJWkdQVL9CTwoqUbLchWU8Y+6KwZaL y+XHD9pVS2OcDuBXGeIfFQad/s0LQyruUyZAJGT2/OuWrU9mjqoUfayOfOpu9jJLg+aPu4Pf 157VnLqt1dukSNukY4EY+ZsdzwO1c/O5bHoKjGCbZ0Fl4L+0SJJPM2DhnAHX/Zz+XSu40zSI 7OFECliowCFAxz7da66UOU86pPn0SJZTFbyN8pLP6IT/AJ6VXlkuF2lI1MTZb5zgZx/drdmK JoZ0WLONvmHcQeD7fhWjCwnfeWBTGT6ACi4MJZEt43lBEiPIVY5wNx7flms2VgJsIpd8/KB2 FF9RFqEmCWRmdnXBKqam5uCC4AABO4Hn8qLisVQq4YgnZL97HHHPWtO3s4XjxtOc561LZDdk XI4ghAK4XvmsjXba2trKaVsBANxLdM9c1mZp6nL2s0sFyEQgqcfKOOKty3TBi3m7WcnAcjIH oMUrnUU1v5RIHHManaxHX3H1qkNQufnSNwMnOSuCMe9K4CxW7OyZbGACWzk5rpr/AFC4dR5c Ijji8tV3n7y9D+QzjFWmI2Ib+EJHZxgKZIuo6KO/XHvXM+K7yWGcm2nMzbSSzvkdOAOf1ptg jnbWxn1i2M0hzMp5OSRj3rTmt/7LtSQ27zW+faMn/wCtUl3KM11KwRYg7dzH/fHvzU2nl/tJ FxCNgxko2efTGKBl27ijmvXdDtCNsOCVUkj9fSqCoqTjLLmMdQPUdPagRma4sl3NbktiFl27 go3DHUYrPkF84W2tYEkjbLK4cJtUHAHXqWqOo0dU2nLJprLJcSR3Eb8TtH5YKkDK4yc9Kz7j wvd3Etqftj2sCkvIqqC04AwBk9ByScc8D8SwGvbaZJJahweAfmABJx14qvOsQDKxIQYPzHJ4 Ofr1piRFfWbtAZwUWN164OW54x+ArK1JpdNtnKK81yqlhFsJJ9AOlS0MydHjnls0udTjktpW y3kuMEH0J57elQalNDcbtjCJB82Sx545pMZiao0UcsIKPGGUMrEEblyeVz26+1VTPbRTkfaS 4ZQAqsBjvWTKJrZorpPLjZTKH2MFPAP19K2hpo+zLG0PmzE9F74HehPQXUqa1EsYSUIokYAe QUwmO5HNUdKt0lv40kKeS3/LMk43dsH0rJ/Ebr4TXu9DtmnWGGOdJ9xOF6PkducdqvNpksYE lz5rTbAwwhyOOc+/+FdqOUpG22wJKIyGjJySpBzn361blnjESwsCzcFmA5OOSPp2qxGNchJL icSL6t8pHWs+xsxcTqC/lJ/E+7t6AUrCNq4tzY2hjgKYkc5DOWfJHJx2FV9M0yPV576JT+8i RmV/M4J4A49MkU2NGG9rcWmtNGHWQRuQZEOAT3PvXVXOqzvEIQEYqNwi42/X3pAeeajbSef5 kjG4bqZAeMe//wBaqcd4scTySK6IDgomN3XHrWMlqWjS0+w890lcBA3CguAcV0twLKK1jjix Gyx4kYSFtxznIGOO3HtWsVoQzm9UW4uBJbmaQwowkXLllPGM/lx+FY94hnXjPPfHyg/57VjL QtFOW3F8MStjBAZgoHSopbaCCJY02ks2dxGKw5epspPY56/08zyPtKxkNnvg0+wsY5IsTSr8 nLFmJ49AO9Y2sdKd0W77TrOc4WY/MuNuMhRjnmk0f7NcuIy7hIxsAVSAcd+fWp6l30NOaVbX CAnp91M9KyxcrOZIhwu7O0cf57VtE5pjXRJUHJQ5wMDofU1BeReQokV2aQNtIkGBj1FaowYm HASR2DMc4C8BQa2ltl1LQ1j+3rHsYsLR3xuPqvvWqM3uZc0T2jRwurFiPSrCQ84DfN1NSxkT W2ZziVQhBDBv6UkFr5LMfNypPOQeKhjWpFduQQSNq9hjqPeqd0VSQuXCiQA5AJx+FYs1iMte UP73f1zkHiporeZJEgt0M0krgABTv3dgO3OaSZZahaUtIJFaHafmVuCv4U5YVuVALBlJ7Y5r ZMyZGttPaykRNnf/AAHBBpJbJWnUyRgh1OFJB2GrILFnpm+Rdo2Hbldw61uR6Ze6au5nG3gg g5z7j6Zq4kNgfIKldhXHB9R6gfTqPao9Mv4NPZmaJrgnhkI+X2/Cqb6gjsLf4qvpFmlrbxho SMgbQu0HsTya0tM8fx67DLprTRWf2pCrTbQSihfc9c5/+v0rWM09CJQdrn1hJIojABATuarN Orn5flHrjkmukwKoCwSsuxjuOCTzz6VDdaWGnDMqlNmM55+mPShsZXnjjgg2rEBg9VHI/Gud lhlkkkZJCgDHBb+ZHesmWPnkkeL7O2drDJbOMn2rGbwokszNIGZlJYrnkr/9euapTU9zqpVX S2Hal4btb233+QIwWwRETgj0OKtaVottpciqLNYi4BwRgsO3uRTjTUXdDlWnKNmzY1AuMLGH I2nlR8q4x+p449jTLd5igjdmLsuducY+vv7e9boxLau0ar+6aQBv9Wp5IqXUJY4QVhUIxHzB ucfWhjRnxSRwu3nja6LnnoPoKuWN3CUKgkbhnP1pXDckvYY5TBGYVBiy0ZfnqeuKgiikyzSq SxUjGe3pRcllmSMRwqSwYAAFM/l0pksjeSgzueTJBPOOOuM0XENuLxrWSMcybB6AA/UVehvl kIfcFIPXtnvUMiSJW1GJFkkEvm4AHlrzg4z+uf8APfB1S8lu0YSMsQHIQe/86gSjbUySoMa/ Onz55Q54+tReck7FVTcN3BAoNuhYkeOeIQwwBQDztGDnr2/P8aYlrO6qm1QFbLAjP/66ZJZI Mm5UjIkdQfu4HPaol0u5nCbcsUOVXIO3ggn24J/OqA6aPSQ1rAkpEjou0AgjHFYms6Bbwxo0 ZZ7hjzIzkqOOmO//ANaq8gT1G6Np87WxjSWNzu2ko/G3v3+taN7pS2tqqnaXT94STxkdetND ucfrupSJe3MSrHaIqK6SBCSRgZIODn6VDpevweWojEkjSA73dckD1xUFklhqXmuYF2Mgds/K VYL1B5yOO1a0VhbB0AlK8btp4HP4+lAxPKtlCKsaybWyQw/l6UfYLOZvOFvj5i2Bxhh3x26d alALJqVra/LBJJNIrgkMMlDnnOevHSlTxFETLDEHVnzG3mAHjrn8wOn8qAD7Y0VssaswwSGI YDd9B2rCdvtM4bcygnHzHd37YoJNz7THZRqjxeY23IcMTjHt0rBvbgRJK+1mZiFV1Y5x6UML lKabymQGU8EYlA3LgZ4GRXPataCXYqTCSNDukXaNzYHT6c9PYVDKuU9QZpbVJp2aYxKqLGP4 V7KB2HX865vU7aWW1DRRsxyBsA4688+3H51lIqLNHQom029SK6MsQbBNsQRg8dPTrXbXmoTw JHGZFhXI2zxHALEc/MST+HtSjsD3OQ1gylWaS5AD9H5OR6fWm3OrWR05XjlSKQ43b8HJz0x2 H+NYX11OhbaBc3VsxjkErFtv3gCNufTmrdjqARCDIzOjDapbtXZGVzmaaNi71H7VCqW0yFAP 3nAx06fn6VjW9tL9vikuHVUZhhyCQvqcVrcmxf1hrS3Cu0kaybB8qcAHPf8Az/hWdps8JaVi yx5PBDcj8/pTEiOe/aG5WVG3MDkHGTxjmkvtahuROEIS6ckuVON2Tk9PftU81yrGbHdZmw2B ITw27PNXLy6Fsd7Sts3bin3mAPX6d6VwsY+q3MTTyCxWRreQglJiGKkdsjtUWmWcdx5pcKrb sBR27mo3YGk7RwAF4wo6AKc8dqinjN9IsrERwliTKWzg56n+daXEVbieSR5RHMzIVK7s4yPo DWXkyZULJ5S/McZOB6msmMU3EAtmhMYRyeWJzk1E8D3MKxxgBhhcntzUtFXMy7tDG2DGhI+8 DyD+NZF7OkEoG1Bn58dMD61zM3g7jJbwl0kCmNWOQ4PJqTT3g/tBsO0attIQjO89zntWR0pn QT28kioQwEZxuduMZrJvtPljyIQpQ5O7PBrWBz1GVUR8FNxK43DnjNMmLkKzkkkfga2RzsEi Tb8w2n2ORU6o8YBIwB0x1FXck19Kv47u5gtr7P2TeCWQDK8Yz/8AWqfV7SztJ2EE4lRT9/GM 1S1EZAlW/kKRKkXGcMeTT5LfyfvscAZGOeahjT6FCW0Eqht58w8BR0/Goin2IPICJSflCkZA /CueSNojIot84mjwowdyKOlRBGdjmVw55UnvUI0vqOjle53wks0uDgjkmprbT53cwIQWxnKn 27GrTuJl+WzeKNDK26UKC2e3alutLjiigv2uYy0+SYgfmU9OR6HrXTHVXOdllGieHa0mZl6D 0oj1CaJwkknGeMmtImbLsBWQbypcjkheox/h/KmXYMqEqvlTDgAHqDzj6HqKtrQUXqYt28qR GRFDriq0F0rSlBFy4+V2JyPpXK5WZ1RV0f/Z /9j/4SJJRXhpZgAASUkqAAgAAAALAA8BAgAGAAAAkgAAABABAgAgAAAAmAAAABIBAwABAAAA AQAAABoBBQABAAAAuAAAABsBBQABAAAAwAAAACgBAwABAAAAAgAAADEBAgAGAAAAyAAAADIB AgAUAAAAzgAAABMCAwABAAAAAQAAAGmHBAABAAAA4gAAACWIBAABAAAA5gQAAKgFAABBcHBs ZQBpUGhvbmUgNgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEgAAAABAAAASAAAAAEAAAA5LjMu NQAyMDE2OjA5OjEzIDE3OjIxOjQxABYAmoIFAAEAAADwAQAAnYIFAAEAAAD4AQAAJ4gDAAEA AAAyAAAAAJAHAAQAAAAwMjIxA5ACABQAAAAAAgAABJACABQAAAAUAgAAAZEHAAQAAAABAgMA AZIKAAEAAAAoAgAAApIFAAEAAAAwAgAABJIKAAEAAAA4AgAACZIDAAEAAAAYAAAAfJIHAEgB AABAAgAAhpIHAAgBAACIAwAAAKAHAAQAAAAwMTAwAaADAAEAAAABAAAAAqADAAEAAAAgAwAA A6ADAAEAAABYAgAABaAEAAEAAACQBAAAAqQDAAEAAAAAAAAAA6QDAAEAAAAAAAAABqQDAAEA AAAAAAAAMqQFAAQAAADGBAAAAAAAAAEAAAB4AAAACwAAAAUAAAAyMDE2OjA5OjEzIDE3OjIx OjQxADIwMTY6MDk6MTMgMTc6MjE6NDEAXQoAAIABAAAvHwAAtQ0AAAAAAAABAAAABwABAAMA LgAAAJoCAAAEAAMAIQAAAPYCAAAGAAIAIAAAADgDAAAHAAIAIAAAAFgDAAAIAAQAAQAAAAAA AAATAAMABAAAAHgDAAAZAAMAAQAAAAEAAAAAAAAAXAAAAAAAAwD/////AAAEAP////////// AAD/f/9//3//f///AgAAAP///////wAAAAAgAAAAAAD//wAAAAAAAP///////wAAAAAAAAAA /////wAA/3//f/////9CAAAAgAAAAEkA3QAAAP//AwAAAAgACAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAD///////8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAEZpcm13YXJlIFZlcnNpb24gMDAuMDAAAAAAAAAAAAAAAACfAAAAdwBJSSoAQAIAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAQACAAQA AABSOTgAAgAHAAQAAAAwMTAwARADAAEAAAAgAwAAAhADAAEAAABYAgAAAAAAAFMAAAAUAAAA UwAAABQAAAALAAAABQAAAAsAAAAFAAAACAABAAIAAgAAAE4AAAACAAUAAwAAAEwFAAADAAIA AgAAAFcAAAAEAAUAAwAAAGQFAAAFAAEAAQAAAAAAAAAGAAUAAQAAAHwFAAAHAAUAAwAAAIQF AAAdAAIADAAAAJwFAAAAAAAAKQAAAAEAAAA3AAAAAQAAAM8JAABkAAAAVwAAAAEAAAA3AAAA AQAAAKARAABkAAAAz9gAABIBAAAWAAAAAQAAABUAAAABAAAABBAAAGQAAAAyMDE2OjA5OjEz AAAGAAMBAwABAAAABgAAABoBBQABAAAA9gUAABsBBQABAAAA/gUAACgBAwABAAAAAgAAAAEC BAABAAAABgYAAAICBAABAAAAOxwAAAAAAABIAAAAAQAAAEgAAAABAAAA/9j/2wCEAAMCAgMC AgMDAwMEAwMEBQgFBQQEBQoHBwYIDAoMDAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYU GBIUFRQBAwQEBQQFCQUFCRQNCw0UFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBQUFBQUFBQUFBQUFP/AABEIAHgAoAMBIQACEQEDEQH/xAGiAAABBQEBAQEBAQAAAAAA AAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGh CCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVm Z2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfI ycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS 8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV 1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APvf4j+GYPF3gzXdDugTbX1p LbSAddjqVP6E1+Buu6XLofiO70u+haGa3meKRH4KOpKkH8RWNZfvEdFN+40du4j1v4HNFKN0 ml3hYr6Iev8AL9a82+IskV42mXMFy0qSW4/dEECPBxkDpgjB4rVGBxWzcMt9wHLYrrILr+1f CVvCAuYbogccqCOn0/wqk9GHVG/F8G7p9EttattTSWGRd7IUGUIOGU4Y9CMdKwHR4WdGPKnB FZQnzXRpKPLZm3pFsXiLqwZxg7QOfrX2v+zh+xjbfEPwTd+KNc8JNp+p3C+dpmoXt48S3UUk bKGMIJynf50w4kH31yCqMXKexrWlaC1PsX4dfC+w+FfgPSfCOjW62+m2MM+bG1y0Fw08pkkW bzNxlABKgsQdpxxxh9uNIsDHp1jFawx25KeRbQhI4x12oo4xyc/5x6b91JHnb6nd+G1AjyFA UetSeIPF9joWm3d1n7QYNoMcZ6ljgc9Pr9KbdkKzbMHTte1PXoY5/LZQwzsjG1V68Z79v1oT w5NcMDeXHlxgY8uI8nHHWstzTY1LeCz0tP3ESoQMbzyx/GoZtVzkA596G7CSMi41lSxG/oDy Kx7vXF8vKyKc+n8ua5JTutDRI9zvY/PQf3XTDe/avxO/bj8EP4H/AGhvFKxQvFBd3KahGW/i EwDOR7eYZB/wGor6Sizals0cV8PJV1PR/E2k75QssBmVVbgkAg7h3rxvU7i6aKKCaRmWIlVQ /wAPNV2JS3KQkKKMDp154NfTv7Nun6d4t+Bfxg0dLKGW9tbSHUrZpEDOkiq/Knt9wfnXz+fV JUsF7WDtyyg//J43PRwEVKtyyW6f5MwPAWvR3Givp8oj2XUQnjMuFKyY2yKDg552t+dZvg7T bHTPiPoeq67bNJon9t28YWVAtteFJ4WniaZ2SNFWKQFiW+XzI8gKxZfVpaVX5mNTWmj7J/Yq /Y00u/8ADOj/ABD8Y239o394q3GlaHIp8qKHnZcTqR85fAZU+4EKk7t+E+7o9Nl01jNdyNEh JKqzfqR+f/169elH2cL9WedN88jwv4tfGZ9K19NN0e4NxDcRlWQJ0PJ+vOenTA9zXK+EtN17 VdWsGiW8iVsSOvzJwQG3N7HORn1+lczm5Pc15UkfQukaDc2tlBA9yu0RYd8FnZtxPOeT16/0 qT/hGbExst4WvC/LK5wpOfSuq3cxuX2uUt4gqKscaDAAGAAOmKz7vVVQgF+T1qZTUdAsYl1r PDkNjnAwelYF5r/y53j5Tzk1xuTlqWkc/f8AiMfaSqttDfKRuz171y2oeJwivvkxnHAOf8/j WbNEj7ORsxlSOQM5/wA/hX5p/wDBVzwQLXW/CniqKF2W5gl0+eQfdBRhJGPqfMl/759q2xC9 1PzKo7nwf4G8QHStfRlbCyZiPoQe1YHiq0MWraiseMrOZBj+63NRtYOrMWCymuG2KDzX0x+y ZrWk/CnVfFL+JZZnstZ0h7EQWirIQ5YEM2SOg3Dr3rzM0wVTMsFVw1FpSkla+2jT/Q6cNXjh q0as9l2PMrt7vw3plt56L5CzkWtwvDFcnhh34r3r9jD4CWX7RfxntH1a3gm0XST9s1GxkeZf tsRVhGEZIWQBZQm9XdS6sQoO1q9H2Lp1EpMj2qnTdkfrze2tj4fuXvrhhdTRNvt0CAGMldrH /ePzfNxgHAHJLeGfE/xlrWsXcscEzxpMdqQQgZXgAYOMnOM9epPbp1zm3ockYo830H4bmXUx LMd10cF3HSMZ+7/jXvXhjQYPD1iqAfvCMnIwQPT9KmEbO45O5sPe4BxzVGfVMY24fv1rSTM0 jDvteARxuJ4HAOcDv7VzmpeJUiXcjdBkY6kgf5/OuVyLsc5qXiUBnUyEDBGN2cfh+FcrqXip Y0cBgecgjgD3x+NStS0jk9U8WncSX2jGMVxuq+L44y/7wY+tS7IZ91TfGyystfh0s6feTzyg MywKr+WucFmweBjnnGcYGTXzT/wUFnb4x/CyLQvD+l6hLq9hqUN0gkhVVkGHjZQdx7Sk9MfL 1pzrKS5Huawg07o+CNH/AGVPGEbxz6hGLNshwuckV0p/Ztf+0FnvZLidjxIgXCtx7VDkNRNq 2+CWnaMoSLT8uP4puSTQPA8NzMYTpiRygkA7OfzrF1HDVM2UVJamFqPgjSY2aOSz3Mj+Zsdm KhvXHSv0K/4JweHtP0n4V+Jtbgs47fU7rVzZNIn8UMUMToAO2Gmk6dcjPQVdGbnNNsirGMYW R9C+JctbTMSSx7/jXGan4bh0ywW4eEyajcjPmueIl/uqPX1Nei0cSZF4d0q1t7Jb6dsM2Nsa jJbHU+wHrj+VWb3XQAcNjY397gcd/Sk/IDD1HxAi+Zl+DyCOx/pwa5zUPFQWI7WAxnkmua72 RaRzmo+KY0Viz7mbPyj5R+fr+FcjqfjBfLKs2RnJGe/171VgOO1fxuoyPMAA964nW/iDHCDu mVTjOC3JHsKzlKxSTeiOF1L4gSTuywhpOo3McD2I9f0rmb7Wrq9c+bK4U9VQ4GPT3rknNvY6 4U1HWR+ntpo1n4c077NaQlHbDPJKxaWU93djyT9a5XWtHN3K8zSknsuOlVytasSeljhtXt4L aR4ZAHZuRk8/hXJ6z+6/eJEsW4ckjk+3tWDm76GiRw2sLJMNvy/Lztz/AJ9K5u9+1owYW8bK OMHk0SuKJiX1qj3Ba4txHCzDe0S5YDvgEgZ9sj6199fsbySRfAyxgsdLW1j/ALUnVp2Y/vVG xmkbCkbjkoB0AQfNnrvhXaSM697HrOtr5ibHTeCwYgc9+1ZHj5UitWvpyWEcgiVHOEUE9SPw /l2r022ldnEebXPik5MisF2+pHA+mfp+lc3qHi9I0IBG7JOQeMemKh6lJHJap4tJZm3knBAJ OSB6VyWqeNghcmbk9eeaybSLOM1jx6Bkq/fGe1cPrPj+ZjiNHl57HaMfU8/pWTnYai2creeI b28HzPt9RHx+Oc1h3LEuSck+vWud3e51wtHREKW7sc9BnpT3tW9QaQ27s/UjVJmU8xsGzjpn P41y19czRM5YLHngEuG5r0KsLHDTkeW+MMJc+e9wJZgcJCvHBPNcRf6pckOgTzQPvK5yPwrz rJM602Yd1NLOVDeXDxnjt7VnPEqyPuJkA539s0MaKk8UBi+cFjnIK9AK+2/2ILkt8HtUQOzL HrMwjViTtUwwHAHYZJP4n1qqN1K6Jq6xPXdQdReW6kjiVMhj2z/n8q8z+OOsLBbWURuwpjaQ yWoXIdjtKknPYBse7A9q9SWsTiWjPA9X8XJCCTLyB3bNcPqvxAjRmCvuI9KwlKxojj9Q8bT3 kjJHvzn0rFlk1TVHc21tcXCr97y0LYz06DjocVzSm3sbRglrIcvgfXL5kYWMu2XHzswO0f7Q GSPyrQi+D+oMWF3dQ2g67ywkAH4cisnJIfMtkXV+DmnxQr9q1NjJjkQYwfzXj9aSL4feH7KP y7mAXDjjzGkcE/UBgP0rKVSw1I0ofCvh22tlUWkeAMBnXeT/AN9ZptrpWkabKr29nHvXJVjE px1/2eeves/aLuDlJ6I+xdd1SODgnco55HTivPNa1IXMvErsmc4A4/nX0NY5aaOC8QqLmTcU 37ASpAGfqfWuHlYhyJA209WJ715UlZnWtjKvHQjELuR/EpOKzZZliXOzGe2aysUitcXCY+UB hjgdMV9tfsPz7vhfrY6Eau7Y9jBD/hXRQScrGVXSJ634pUrC7p97HA6ZPbmvnT4u6jLPcNNK 5lkRAIyx+4MYI98kZ/H6V1p6cpzLc+TfGeuXFk7qshdhnkmtLwTpuh3vhi3vtRv7j7dOG/dQ gKEYO2Mk7sjAHYda46kktzVXWx1CX2gWkjLaaZC7SEAiQeaTjpjcSQT7YqwfEMztuQR27KQp MjKr8/U5xxXnyqSk7LRGltLyKc/i0CSJJL1DM/Kxg4fGOTg4zUD+Ill3+VHcT44O9THk9+vB HvmptJ9RXSIm1K4kRQsCAnk72IZR6dwf881FLHqc8i7ZIhAB90xZfP8AvZ9vSo5RcwxNIvTI G+33UaAcxDbsJ/LP61FJ4WW4mWeWWVnXkYmcLx6qDg1qopIxcmz668QRvdLsTapDZJI9q5TX 9DGl6ct3PIZZGbCxxAbAPf8A+tX01ZCi7HBapeJHE6pHhyc78ngcf/Xrh9VuR8xkysp9D2rz ZnSjBb/RzJuUSMec49e1Z00ihixGTzlV7VztGqImBbLlMjHTPAr68/YQ1VrjRPGNgRhLee2m /F1kB/8ARYrahpURnV+Bnv8A4pO2zc4B4718v/FGSSeS4Yv+6RiozHtIOP72cN3PAHoeQa9C oktTjifI3xDmzcy4BCjNczpetanbeTYpYSRuqI6iTgFWAYNznhgwYccgivJqWvqbrU9C0jTd QvYmSW5MKSbSFhXlemQc5Bzj+7XSx+E4pVkWVGlEqBZEc5QgZ7HgZzzgc55z2waXQV7aGnD4 ZWJFSKDbtwqqFOB+mOvH51P/AGIY23KqsCOMAnPOAfxyPypMgsR2oZVRdqpEzMTtAYdM/N1x kd+nPqamjscAKxAGQCzH0HU4z3z79Pap2EMis/MOFJ27QxIHbJ/xo/s4mNVZR8o+bJxghge/ +evpQJn0JqV9G0ZEbqSOecEDiuJ13U1S3C8SHceCSe/6V9LUYRRx94YpIn3K4lkOEKn5R7Yx zXJavYNb3TK42ynORIQCp78dq8+aOiJhzx+Q+2RiVQZCg561muqLkkDDA/MRXMzZEbQRleCO SOAa+rP2EIBCPHW1t6t9h+b/AL/1rRX7xGdX4Ge9/EfVoNA8P3N/cx3UsEIXcllaS3UpywX5 YolZ25IzgHAyTwCa+UPEmvXniaDUL+60250m0dkW2t7wqJyojUsXQDMbZOMFicKDgd/QqnHE +cvEvhjUPEerSWGmQGa5ZWdmJwkSA8ux7DnHuSAMkgHrLLwBaWsgkZnmdSkZVQZGjPCqhAyQ Au372MD0GDXkVVqbJne6D4UmkhuAbGWKGBipfCHjj5yASQpJ2/NjJz6VsR6HHEI9w3ByPnHT kZ/wzXK3qMfZW4S12OreSTGxJGCrcgZPXqeg4J6jgVDHpwgWTd0RNqkD7xDcn16Z4+me9NEM juNPjjkkYNlGBbjoFYZBIxnjHb1NMddpyo8hXIR9jkjcOcdfYfpTsTcjIYwtEIlD7sKf4mBP 3Dzg8jP4DnimvGkjqHwu7DKpHO3nB47gDn2zSegkenX8iGPgrubsRkkf0rl9S2vKzFeTk4r6 SpYqJz9zfuhClgoRtykHDA+oPaub197jU7iW4kZpnbAZz3NcEmbpGAtgVzgtnGSSe1Zs1rNO z7gqr6kgAelczVzW9iGO2LZQMpbrzxj2FfVX7DMLwHxqh+4RZEH3zPmtqK99GdR+4z6F8XP5 do27AUjGc968E8SeAdU8UzOrwTWNoQQbyZVwTkjCpu3Z4B5wMMME9K7KzscadjjrL4Q6Z4bj uWaEX8su0yTXKqfulSAq4+UbsMByc4yTtBFu50mK2iAEW0gkuwxjjA444xnJ+o6da8ebb1KT KVvp5ErI5KkoTtAzkqTxjr0+g+XPUjM6WMaImNsb+apV1PI5ypx+J5HofpWNi7iLBlWLRLsf 5lUqNwTJyOepUkfp6CnXliEEu+RDIoAM33sgDAYYJXBwwBPHOfXAIyXfynZ0KqN5UlOSCf4c 5784Pbjv1ozSBSVEYZBtDb/4e4VieAeQAfp7Va2JZWjl8lo2DiR1IwnpgFuTxg9cEe9MnPlu yucqGznGM8cEnBx7ev4moYHo08aBGLlUcenOf89K5LVrlXmkIYKuDgqeSO2K+km9ConMXhDx 5CnnnB4NZkrMCuSMjqgPSvPkboqzyAAbzgNxlaoGMzNtjiwCeCWxk+gz+FYss9X+F/wM0zxl oV3falc3EZFwY4ltGUKSEVskspyPnAGMfdb8PW/2TvCereEz4ht9VtJLRpBBtVh3Uy7iD0I5 XoT6967Iw5IqaOSVTmbiz3XVE2RMFJXeME+tYerQRnSEMYwSCH9z6/lism29WYnmeq27CYiN ZM53AKcHP4d++PUcVyWrWkkbbAytu4QMcE9iPx6/UH61xTKRhXDbpzNEziMyFlyu5yRjJZsD ovBwO56Zq01/bskcYZUUHyRuBHcct1J559u3tgzRGfFeRRqjBtyKVdSOTuGDuI6Bvr1yB7Gj d3zERDdGYVJZcEMeBu6dCR0Kn0xnjhpDuZN8yykSJOjvL8zlV4J3YKjoMEc4xwe3FVkkZlkA IZCCFZzlcHjgHgg+g/8A1skrTKJG3k7twCq3PAJwACRkjjoQMetSiRU5JVAT0Q4xkkH3/A8d fwlgdtqVwZlaMrlCpyS2AR0/nXMTrArCM4jQHOOOAOnWvoJstHOeZHJIFhJmAyTL/AB6e9V5 0X94oAl3joR0rkepqii1uIlwoQOvIIODWbMHWYYBxnJB7msWaI+uvhrYS6J8PNCgeZZpDbLM HHG4SMZFHI6gSAf8B+lei+F7G6F3FfvLtgVZYDHgZcnyyCeMjHltxnnd9K7p35FH0ODTmbOh ulXY78qXIJ3OSM4AGATwMAcDA6nqTVOa3D6dLyc9cZyB6fma5mSeda1b7bjLBwqHgE9f0+v5 1x+tQ4RmQmPcDHySASeAM+h561xz1ZSOP1KzKEYlyAThiefU855PBHv+dZ96pgsU8hI325Tf nPykLxjjGSR1z6DoAMtC0Z928i+dF58c8DKu6SOUEOp6jaT84GOnUEE56kx+UwMccarM5yME EqcnPQfeOFH3cN90dcAUtAKbSgBZXdnmwF5wTx+HPGPQjgDPeCa5mldHYZUkN94bhychsdST zhuePQ8w9xkUsgKHCiEHcjuQfmwAcHtyfX8+poWVFiChVkPDB84x7e3bsR6eysI7SUv5cjrt k3J8oLccjsfpXL6lAt/KIJV2Qo5UkdJP9nj6DP4ivckaIqNbxwq6cIAei8Djt9KoXC4iD5G9 jjIPb0rnkaopyRmedQqcj+8a0LLw5He3+lWRmSI393Hb7pCSIy7BQx+hPSsrXdi27K59eGBT t2gRADARBgL9MdB7V1Xhadp9Gkgmkw9rKNg/iKkYBP8A31+lelVR5kHoaM6kjHc0xWCMyqxL nhJQCMY54/Ej8q5Gh3PPfECiGdvlIHOO+Pz7/wCRXJarGnzoGZw2VB29gOw7/iB+VcMtykcV qkvkyqy5kkyQBESPl9h94cYznHXjsDkz3Bs5y5copVkEatznkEN2PJIIJBHtyRjYtMz4IXu5 y+4xIPmXy1BLkAjnB5PAI7gKDggCodXeJjIqNkyjcpWMEZbIxtwBwOg9B/vUIoqRIZUugqDO 4ybohvBGCAp3HgYyfmwfX7wKwyyx+TvlhR4wys58z94YyRhQTnjH1x16YpMRmyj7Oirhi5/i clQV6ggjn+f+NeGRfO8gske5BuJUlV68gAcZxgdOfTmmhM9BvXY+VtIQ5JAwBt4+7WFdZhnU u6uYwxVB0HPP417LNUZ07GdMONobk+orNljV7po1H7sDAYHP41hI0QkQfK5QfKCw3DJbnGK6 n4T+Xq/xR0eCa6t7V7KO5vI7afG66YRNGUQEj5lWVpOASBExxwSClrUVxVH7jsafxp+NPiRL /U7L4f31lNLo9oLq5Ux+b55DqHQEEY2qwb5TknIq38Bv2tP+Ev1XSdI8W6NJo+u3UsdvDqGm 7pbW5dn4EkZ+eLJ8tdwLgkknYBWlSvaVnszGFHmjdbn1u7iR1YIBjqDjj+hpjRmAo65GTgZ6 Yxlu3+zSbMLHKeM9PMbM5T5cAgg49+v+elef3mJ4JF3Oo25TLhjvxx26HB6HjgnoK5Ki1KRy evTwgB1LRBdreXGOOgJIznqOTwPbGQBw91LJDeyNPuVl+XYUzg9eAeCMsoz0xgA8sawS1sUW 2u0t7bclsVl8wyeYGxgYwASOANxBzjj+9jFYlxG8d0+9wS537lO4nnaMjk/gwPbOOaVrDI53 jls/lQ5jVvLZm4wTsXHUepwCDz6sKoySBJZgzpK4IaMlg27OeWOcevTH04FTYCC4bchIChDy GJ6jpgjGB7bl/E9qlxJITGzMJsKA0i/KWQ9V75Pv047g1SA9GhQvbgg+e7knc3Axjmr2n/Db xJrga7t9MmETMB5twRCu3g5+cjI9xnoa9pRctinNR3H6n8Kl0aeRNd8VaLpTY3LEJvMlPGfu ts/Q964T4q6HH8N47O8t9Sj1jS7i9OmyXZhMDRXQiWbyypJ3K0bBldSQcEcYGSdK0btkxq3a VjnjrAkZZVZiME4HXFfP37SmozS22mNEzIGuVfcpIwwB5B69ea4ouzZ0S2Ppj4BwfDjTfB+i QaHdazceLLnS4Eu0vlVYBOd73GwrgkKUiC5JyGOec7ev17wDBYeIbHVNAtlh1S3uBdqJJD5A ZGRgNoGVB284/vcbe+vs1Up6dBRk4vU+uYbhRDB5RY78clgevofp79q2Jljm0qRSQVC7ssOT jBPPUHAYfjUX1OWxkeItPGqaLFIqndt+6c5rx7WbZ0QqwUqOASBnPODkYyf/AK2elTNdRHGa rmRXYuCu/dtDA4/3RjAHpwO5rmvsonlUKCHBGcDHTJAGOeQT0yMZ4ya5ZOzKRQ1dJbNUKS+b gn5nAC7iOQo6E8gY47DnGKyLe7RLcZWJDEc5lACsADjg8Z9uDgk5y2aW6KFSUgooZ2lIDtz8 5I+QZ4z1J5IYZ78Cs+4MSMkjttjc7QkQBwowqtjofXGfQcZ5kCjNMjqRhAigHaWx7AAH055G O/ByKrTT7GeRclT1ZmGSPU8Z656g9/SgR//ZAAAAAAAA/+EKH2h0dHA6Ly9ucy5hZG9iZS5j b20veGFwLzEuMC8APD94cGFja2V0IGJlZ2luPSfvu78nIGlkPSdXNU0wTXBDZWhpSHpyZVN6 TlRjemtjOWQnPz48eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJE RiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1u cyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSIiIHhtbG5zOnhtcD0iaHR0cDovL25z LmFkb2JlLmNvbS94YXAvMS4wLyI+PHhtcDpSYXRpbmc+MDwveG1wOlJhdGluZz48L3JkZjpE ZXNjcmlwdGlvbj48L3JkZjpSREY+PC94OnhtcG1ldGE+ICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg CiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAg ICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAIQAAwICAwICAwMDAwQDAwQF CAUFBAQFCgcHBggMCgwMCwoLCw0OEhANDhEOCwsQFhARExQVFRUMDxcYFhQYEhQVFAEDBAQF BAUJBQUJFA0LDRQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBQU/8AAEQgCWAMgAwEhAAIRAQMRAf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYH CAkKCxAAAgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAk M2JyggkKFhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4 eXqDhIWGh4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ 2uHi4+Tl5ufo6erx8vP09fb3+Pn6AQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgsRAAIB AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDTh JfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm 5+jp6vLz9PX29/j5+v/aAAwDAQACEQMRAD8A/RYDHFLXQLcQgMrKR1GK4XxBa+aZ425DAiue sro2pbn5P/tY+Ez4d+J2rIqbY5285Bjjn/6+a8DkQ7TXkx2O+xUGVkFS3kh8kbeM8VvEzlsZ 8VrM8m7Bwe9T3FuUUE8nua6InJI3fCtx5VwuMH5h1r6b+HGqm4hWPJwR2P6V0wMGYXxesWcq 6jjbjn1r5o8R2rC6fIySayl8RS2Knh7To3vk3g4zkGvZtPuLKxtEEMaFhx071vTfugzz3x34 hvNzLG5iA4wOOK85ubiSd90js568msuo+hXJ7mmkUbAMxzRTAUthahPU0CJLeIzOFAzXU6Uk dpsB4NXHRg0ejeGX+2IAhKkjkZqv4w0cwQbycqffpXTLYyijy+YDzn471GwAGT+NcD3OpbFe R1A61WZlB4qkJiq/FTwXOxwMdaZJuQtviU+tSDk5pokerAHPWpy/y0FDQ2R15pg6g1nIuG5Z /h49KdDnNYs6loXEgZxkd6nW3eMZ9qzZtFpGjpV1JFMgz396veINDGs2ZZV3EjkU09SKmqPP /wDhXutTWmpXtrp1xc2Onqr3U0SFlgViQpbHQEg8+1Ygtio6VtqcdtT0b4TX3inw9Y+J9T0O 2W60gWXk6ta3Fu00F1CWDeU+0ZGNpfcCuNmcjjMUvhuHxcHuvC1i16V5m0WSMNdQcnmNkVTM mO4G5edy4G43bQehztn4dXUdVh02OO5t7+aYW6QSJuPmE7QD0I5OOhr92/hF8MT8LPh/4a8O xSRGW2s0W6lSCOLfMABtxGAvAwOB+Jreg7SuY1trG3qHjWbTNSjjS0N5ZDck88DA+QR3I6n/ AOsa1LHWimkWl9cBkid3eVGXDlQTsUD+8QR0z3r0ak24JI4ox9655/dfDHTPGvh7WE8Qxpey a0FSa1dR5duiHMcQAxkqS5JPJLc9KxtI+HPhrw5LGLPR9PhmjIG8WyKcjvkCsdjU6W+sWmCL HArYH3lIYn8ulZTaZ5alig54qwEWxL/KFANSJpiwZaRsj0qGNF6Au6+XGoCnHOOa1rGwRcM5 Lt6k0kgbNeCNIxhQB9KtxrWhmTrH61J5WwCgYnSnbaBMAuKTpUMpIaWwaill2qWJCqOST2qR mc+tW7uVQl8cEjpWfNrLSXOyPAX1qStiPUNWaKAx/wATcfhVCw4BY8A0gRn6jMRdkk8A0t5f rLa7RgHHY1JZkR3rRtgVBI3mMSoOTzQIltLSWaUAA89q37fww04UuMg9qpIRuWPh2C0KkqCR zzWosaRjCqAKdiWKWxmmFvwoEIXzx0qNnFJgMZ/SomakVYY0gNRvJxjNIZC8mep4qJpst7UD sQzTktgAAUzfSAaWLnAqKR1iOCefQVEnoPyIZbj5sKAB61BJdAcnoK5r6lWse1nhmGDUUjEd BXaIdGxZRkc1zHiGEpMW7ZrCr8JpT3Pz8/b58IGK+0/V40/1m6FsD8R/Wvhm6QxyMD6148dG 0eijMmYqxqeNxIgHfvXRFGc2WrXjim6oqeVw3zdcV0I5ZEeiyeXcA8cHpX0X8KtTRgi5HQHr 0/zmuiG5hI6P4n2gudN3rk9+DXzN4rsilyGbq3tUT3HHYy9OgKTBlBxnmu8sFaWL5ecCqp6o po5Hxzp0vzvtzuGfpXnDKQfp2oYrETjFNoATbTce1ACMcCo8biB3oEathEIRuPWnT3xMyhTw DTKPQvBd5JbqHzkg9K3PFGox3lhgDBA710taGCep5JdqRcv9aZJGWTiuN7nUtUZzxSjd8pHv TdjDqCKaJaFwe4pyg5BwcZpiNzT5Q0QGKt9+KaJAcGpRkgfSmMZ0pc1nPY0huWYjuWpEDBuB WB1o0IN6AEjqKuJKGAzxWZoWbSISSgjrXV6aQFAJHFIh66Hs/wCzxqNlp/iPUtJuVhMGswLH tmGVkkQnahB45Dv19h359xvP2XPh9KLjy/DOl3s98uZhGGBUs4b5TkbeVH3cY6dDz6dHllBX PPqNxm7Gz4G+GOhfCPRTpWk+HhBazXLNJDIHlE7EAHczZJGAB6YFcVpXws8I+H/idca3pXh+ 00eeZfktom8xbdmLM3lkgcNnPAGOg4FdCSfQw5nud0Phd8PvEHxH0LxHqFlBc65G4VdpWOMH ON8uBliFyOvv2FfXJ8a2FlpZkRxL5ce8kAMzEeijPORwKlJX0E5N7njvgbw74k1zxtd+IfIO g6ZM7tDaXK7pGU5wdnGzGc+vbGK9Q1nwzbzRwz3N9N9qRs/aC3zhe6oOiA98DJ7k1vYm/Yjk v7OGFoo2EcYzgL6nk/qetcldTbpnK92NSyizaKWXPc1LLFtQOxwCSMGmBSfUQDtiG8/3+1W7 UeaFM+HH93tWadwehfiKoAFOAKtRS9OatCNGBs1oQMAAetMktgg44pzcjFMBmMUFqGAhbAqG a4SBS0jBR6ms2Wjjte8fxWt4LW0TzHx80h6D8Koz6xcTW5MrEs9Z3uUkOsN32Z5D17VPpSh7 rLEGgY3XyElUgcVSj1DyxgHNA1Yz72dptx5zWcZZB8q569KQGjZaFPd4OCM+grf03wj5Z3SH vTsJs3rfSre1wQuTVvcB2xiqJELVGXpANaTv2qNpaLgMaQ0x5MjrQBH5g6ZqJ5ueuakojaao mnBpARNLURcngUihjyBAMnJ9Khe4zwAAKwlUs7BYfFcqgO0gtjAqkx2ZLH35olsNFdmLHNV5 ssmCwHrXNco+gbqPbJn1qAgGvRJAACsjX4A6Z9RWVRXiVHc+U/2z/C39s/DK5uFTMlsyy59A Dz+ma/L3WIPLuWA6fzrxvts9KOxg3IBFVI7zyZRk4HpXTAyka1ofO5U9e1PurUspYnca2Rzs pWLmO4Xn/wDVXuPwsuFDxrvAI6g9a3huYSPXvEVqb3RTxn5elfMnj60MBbC4we5596me4ROW 0S7X7QoYfNnGPUV6Dp15FFIqAhtwwF9acDQj8b6JJ/ZX2sIwDdY2H3RXiuoIqzMMd6qSsyUy i4B9jUJU5PapABSlfSmBFL2459KktYQTuYcUAWp5/LTA49aqK285oA9G8Jt5lueeSAetXdVR vKPO4AdK67+6Y9Tg72PZdEEdatQ2+Y1J6d64ZHVE9D8IeCbHX4MPtDkcVtX/AMGYRgxsPfjF czkzdJdTFvvhHHBEWyrHHYViz/DzyjwQT3oU2PlRlyeH2tFJA2jNUWUo2DXVF3RzSWo3irEf KirIQ1uD0700ckUpbFR3LtuuB0q7CASAR0rlZ1o2ktkktxtwGxVOSFo2Ixgdqy6myZPYMY5B nj3rWW9KTjYeO+KbCKuzuPBerraavYytKbZkkVkuMZ8lwQVfHcAgZ9s1+i+maNL4k8OaHeNO sepXNpG11GmNiygfOFIyCA3TJ6EV2Yd2TODELUZd2F34V0C5uHkIncFkKNuGFHOByOT/ACrn LK01/wASrBc3fh+wntyAY/tMREqMMqGzkAcdDjgMRXXe+xyWOt8P/Amxv7iO+1o7eQVt7V5A OPct6+1eoL4d0fw5bnUILNRdYAWUsWYHGMjOcH1I61tFWIeo618QNFJAZy2DzuHUA96ra7PI twzCZpIWHmJhuMGr2Ekc48jzS4Xkk1o2ulFpTuGc9AOazW5obEkUGm26vcMsXpjljXNarqra jcfZre3kdF+8zEKtTJ9AQlvp6W/LSM/O7bn5Qa0IpRjjFOOiB6lmNwcZYAetXLb5wMDv1qky TVt12jFaUKhQOKZJOPWnk96YxjvSopfpSKMzxFrdv4fti8zjcRwvevJvEPjqXVizRvtUcDFY SZcUY+ghru88yRiTu7967jU8COHZjBHQUkNktpcD7KyHv2qOGRopevTpirAfeSG6TDHpWeYH HbNIRatdIknwSCB6VtWHhiNWDuOfeiweRvQwx26hUXFPLAVZIxn4qIyY60CAvUbt69akZGz0 xpKBkTTYGc1CZuTzUjsRmXk1E8vzUg2GGQnvTCwRdznHtWblYoh8/cKdvVYyx6e1DelwKs8n yM/THrUKJLOQqgszdAK476lELJJayFXBVh1BqOaYlc/zrd/CSV/OdzjGFx1qMTKHwx4rlepa 2Po29TMYb0qnuH4V6ZAtVNSjD22e47VEtmUtzx74uaAviDwXqti6b1kiZcH6V+QPjHSH0zVL y2lGHhlZT+deJPSZ6UdjiruPJb0rGuoyHyO3vXTAiZpaXcskYzx6GtYSCWI5xmtkczMony7j PbPavTfh5fGC5jPbPK1tHcyZ9AW+tJcaKIzjJFeFfECz/ezkqOcnJomTE8blnFvcZPy4PWur 0/UBPCsiEhl54PQ0ols72Pxlb3GiMLxg0qoV2MOteEa86SahMY/lXPStJO4kZrD86ibJ4qBj GzTkOetMCXyNwyKcQIk96QWKE0rOxpFY4pknX+DNQkRwgbCjjn0rsbuUeWQeTjFbp6ENanD6 nHvuGbGOea0bKIPbgfxY5rlkdEDsPhtdP/a32cPgf3TXvkugzSwRlXDFhnjpiuZm6Oc1Tw9d yAjn8q5u/wBDltlDyHFZJouxzWp2sUsbIeSOQa4PVLQwzkjODXZTdzCa6lIrUsRyCK3MBjn5 vWnW8MlzOsUSl5D0A/M1Etio7l21Yge1aNuyEdOcVySOpGtaKCuAaZcq6sRjIqEakOxzjj8a 1tK02W5uI0RGkldgqqoyST0AHrVWDmsj61+BH7FPibxtJDqPieKTw7oLKxPmcXUmUOwqhB2j dtJ3YyOnrX3h4Y+EPh3QPD8emwfbJ0Qod805DZWNYwBt2hRhRwoAOATzXpUaLirvqeZVqczs jYfwtpkcsZSyiDxReTG+zlUznbn0zzQbOKKRVeNJVQ4C9seldMY2Mbkau3mEgYVRjHpVLX5G ktUjU4jzu6d61RJjRJIUIAIVgAwA646VMkZmVYym8L1U8Ac0AJBpnlyFggxirV1c/wBlxq4U CQjILHpWb0K3OEuPEk+pao672lVCQxI4B9qtLfhOgAJrC92XYmjujJyW/Kr1v82KtEmlboCM Y6Vo2iAHHSqEa8AAFX4gSMVRJMBigSxFSS4wKVxnOaj4ngtZQmC7E8gHpVvTtZe7idxiMA8A c5FK5R5N8U9WnvdRA3EIowMGuSsDvidOv1rnerNUbmiE27njFdUkj3Ear27VSEX7axlIHGPa r0OkyHJZasm5fttGUn5hk9ckVYXR4Q2doHpiqsIuRQRwj5VGfWns+KEIYXphfNO4DS2e9Rsx zSAaZABUcktIdiFphmonm70gIHlOTmozKc0hjXcr14pw/wBVvxmok7IdirLcCJCxYZI6DtVJ 7jJB3En3rjcru5aVkIkhdzmrKzIsTKzcn1rVO8SdTPl1FIyygFwPyqC31Se1uEkB5BzWHUod qep3Gq36SlVijAwQveobi6WEYC8ketbPRCKrTl8lm/4CKqyy9STiuZ6Fn1HMoeEj2zWZzXpm bQ7P51HKN8bD2pMd7HD+ILQTRXMRH3kNflF+074Tbw58TdXhQbFmfzlAHr/9evDrRtUTPRpu 6PA71CGII59RWPPF8x75raDCZPbkIoHer8TZ4Nbo5GU7pQJiwrs/BF6VuUHVfT37VtB6mTPo LwpZNqNmhUY3L3+lef8AxJsgJ5kxu7cVUxR3PnjWovKunBxwelbXgyXcxRuTjFKBbOk1Gz8y BlXgkcY7V5vrNt5Nyc5PHSqkJGaePpURPNSMY3OaFGTTAvRj5QCeajmUspIFSMzHBVznil2j HSrJN3wkzyXvlKMliMAete0f8Kx1u60s3UVq0g2bsdPwrCriaeHS9o7XKhSlU+FHmWoWUlve vFLGyODghhg1e0qD5gpGfrVNp7FRVmWreZ9C1qG5U4UHnFfQHhXxq2o6ZGRhiABzXJVfLqdd OPNoaVxrucZXAIOa5nXtTWSJl55HauTmOjkseeamdrbl79sVyWtMZGORXXRndnPVjZGIzYOP Snx4wcV6JwAyljXQaB4a1OfQ9Y163tZJLHTodks6kAI0hEY9+jnpUPYqL1M60IaPHfFSB9p/ GuVo6rl6xvvKcDnFbkbJPg8HNTYaeh1nw7+GHiH4peI4dE8N6c+oXrguwBCpGgIBd2PCgZHJ 9a/RT9nD9kfQPg3bRalry2+ueLnUEylN8NoeoEII+90+fr6Y5z24enzPmeyOWtNxVke/yaoz yjau0Z6bckn6VZtZXiVmYyEgevAP+f5V6TOEtSzF0Gx9y9D2waqlBgkZ9PxoRRXuAE8tUYF3 OD+PSqt7Z+VbZk+fnjsM460ASadAsUYlkI24x5eM5pqtDCSEAA6mhuwambqnimxtImjhkje4 HRAw3D8K8s8S+KJrqaQm4IPRRmuWcrmqRm2GqmGEgLjPetC1uXkZGbOWGcGs0xm3aXGSPyrb t36DtWiJZqQyrEASw9+a0bS7if5gwOPStSLGtZ3kUnTtWgt5GY2AbB7mgVjJutaLMY484Peu d1XVZ1BhQkL7VLZSRk7cgsxya39JvEgsMhsn60rlWOA8aoJHeTGQTXF2k7Rz7QOCaz6mh6Fo WjSX8YkUH3Ndhp+hGLBI5q0jNm5BZJGoBAJqcKqdOtaEgWFN3UAMZ8Hio9xzQA13461GZKQr DPM96a0mBSGiFpeajaQkUmxogdyASagab86koC6IpZuSeiioY5gCS52isZVLOw0hs13CzLtJ LHrmmtcHyygNRfmGZ07bepxULTqmBy1c4xhu2D8DinwsZt27tzWkWMpXU8URIAyapNeSMOw5 7Vm9wQ+O9ZsLkD1NJeTIqgk5I9K0TuhFBrlmOc7RULzAnBkwfc1iyj62Qh061QlXYzCvTMiE nFLnIxSZRzOtQ7Zj7mvz1/b28JG11mw1aJOHBjduwxyP615GIWqfmd1LY+I7sfvGBxwT9ayL v5VOOtTHc1lsVLef5zWrDcKFANdZxsjvPmAOea1/CdyIr5BnDVcTJnu/h3xg2mWiKPuHoR2r H8Uan/arSMxBZucjvmrk76CSPA/FkIjvpOD1PWqGh6sNOmLHGamLsabo6h/FKSRjJAPI46Gu Q1y7SZuCMgnn1rRu5PUxWc+tMzk1Iw3VPBHk5PSmIfPNsAApILgMcN1pDFntRKCV5PcVUFs5 yMUwsdr8GbSG78e2UM4ypOcY7g1+pnhHwbptx4Yt42t0P7sDO3pX5JxpjKtCrTjB6H1eTUoy hJs+X/2kfgja6dJNqNtEsbjncoxkeh9a+Y4JRb3mwnkcGvq+HcwePwicnqjzsww6oVdNmams Waz2QkGMgZru/hFrUJhS3mKk8q2eef8AP86+iqxurnJTdmeo6jpcLWxcKufauXv9LV4C2OBX Azqvc4ueFC7ggADjmuL8SQKsh2jv2rek9TGotDlZkKv049KdCM54Nete6PLejHsNpFe/6NdS eCP2T/Ec9pHC1zq/iK2066lmiWQFFgkkaNQeOGC8nvnFUloHU8QhvDKGDW8LFujKu3H5YFDp kZHWuNnQIg2nivSPgn8L9f8AjD4ytdB0O3Z9xDXNyVzHbRZ+aRz/ACHc8VUYuTshX5dT9Yvh D8IPDHwL8Hvp2gRM9xOxe5vp8NPcP2yQMYUHAAwO+Mk57Kz1KKANPMhmm+6i5wB7k/jXsxio RUUedKXM2ytLqB84mNVAY5I5xTjqbG1aIoQxYHzA3XHYj8TVMRo6ZexlYoyXO8kscdD2rQCt KSBj8utICu8iI25YjIxP3uwqnqEhvZY0AICcknpn6Umx7mdc6tFBOIFlBfqO9V7rxlpuhpJJ cs9xMBkxwoXb6YFccqnM9DZRsjkfEPjrRL7T7i5t7ULdKBujkj2yAntXhuo65cyavKzMFiZs qoHQZ6Vm2UkdJbalmGMLGWUj5ixxVO++IosWmCoXnPCjtmi47FvR/HV08aM4Ct12gZxXV23i W+mgeZpAmfuqB0q0xWG6bqGo6zeqjSuVZuRnH6V6pcaYdEt7aAyBndAzY7VqtSGOjdoQOa0d VmSK1t/JOQVBfB71RNjLuL1YmDDkVl31yrvuX8aljKLXDEY6VJZzsqsnJBNIZR1XTJb8bVUt npTdI+Hkj3CvKvHWi1x3PStM02HTLZY41HTnirQwOgrVaECknNNZsGmIaXqJ5aQxhlNMMh3d aQWGNJxUZk4pXAidz261C0uOM1Nx2Gh+pPIqGW9ITCKBmuerK2w0V5ZmZBubj09ajWQE8HjP WinK61GxtzId2cjA9KrSuFjyzYJ7VjLcaKpuUTn730qW3nzGSxx7VURspzNh2YnA9zVV7xNn GSc/Ss5IaK0l+2flGFzVyO4IPXr+VOIGbqVyBdEKOnrVR7liPT6VL3GVJpnVCd+2pEvMxZdg eM1aCxRmmkY5Bx6AVC6nl5HC1kwPsm0fcuO4qO8T5g3qK9Iy6GfLnPFNQHaBSepRl67DuTdj HFfKv7aPhA658OLm6SPdJbYlH4da8vFLc7KLPzD1iDZMxxg5wcVhXkYKE+3WsYHQzE83ZJzm tK0HnMDniuw43uaNzDugOMZxx7VDo9yYbpW7j0NUjNo908G6d/btmhY7h7HBFamveEF0+3d8 k/Lxk81q46XITPAfHdsIrokDGP1rhgw83j9KyRqSzMRESKz9xJOeaoBCeMU2qJHIuTVpeFx0 piGyRhuahEYDZzQBes5Bu2sa01tUbkCkykaHggtpXjjS5h8uJgCfY1+rXwqvhqPha1bOflHf 2r8d47jrSmfX5I/dkjkP2g9KW78OXORnCHgDvX5meIXex8QzRZGA5+nWuzgio3QlEnOY6xZ2 mjsNQ0vYfmI7VR0m7k0LWwASsZYHHbrX6ZLWJ85HRo+jLDUV1HREcMC5X8qoyJvtpF4Ga4Gr HWmcNqtg6TSEetcRrtnh2Oc06ejFPVHJXaYaorf/AFgHQGvYi9Dy5aM0LSFTqFp3/epx6817 R4lnhsP2NPB1u7kXup+Kr+8C/wB5Ioo4yx+hYD8TWi2ZPU8Y0whuDwa0nswQSvSuFnSj2L9n 79lDxP8AHo3V3YummaJZyxxzX9yrbXJPzLHxhmVcsRkdV9a/T/4L/BTw18GfDEekeH7NLe2G DdX0xzNcyY+8zdz6DoOwFd2Gh9tnLVl9lHQ3V8ZpmCoqxcqq9Rjn/GoGgIbYfvA49q7zkGng bRzg5q3Fa/aNiJubsWCjgH/6+eaCi9OjWioIUDyAYyw7VoIsh2NGCx6kgdKTdgSHTxRxW5mm mEaAc+orgvEup3MljfG2l+ywbTtkHDkfWuOrUurI3hHqzzSfxINOi2i4ZUxlWLZb86pW/ise W5TATrk8muWBqzm9a15RHLO7DAHIrK0iyWS1fU71h3Kg9BWpIumapJqVrcXKgrbAEIMdq5e3 tzeX7u/IzmkNHU6RGDcIMYwa9ISAPaooAAx0FVElm94Xtlt7qJiOhrtdblZpo33EgAAZreJm yubjzYxg8iniQyR4JzVAVLhJHXB7dKqLA8rhQDzSYbGnb+H5JB8ykcVr6f4YjhBaQZNOwrmr Fp0EHIQZHrUwAA4wPpVJCGlvyoLgUxETyc8VGX3Hk80wGs+BUZakNDS3QVFI+0ZzUtjI/NOP egAnrwBUN2Arz3W1sIO3Jqj5h3knr6msFO8rMolaYtGV9arXF0EARV571NUaK8zFiDnj3qD7 RtLAHPvWcHqMR5mlOScgdhVe4f7R85IRR0FVMSIpbi2hhYsWZ8cYplpeLcqHHHqKUXrYZYuL YXS7i21FWsy8mtbW1XYfMdhnA7USsCMqS5Z+CAo9qcL2RSoyAP51MdyiO7mWEAsCWYZ61nvc PICFA5qZbjRUmkIUgtmpreRPLBZgMdqaAp3N40kh8sEL2OOtV5WbG6aQhewqGB9qWrbW4qa8 QmPPpXpGJnNyfWjbQMparFvts4ryj4raAuv+DtSs3UOJIXTBGeoNediV7rOqifkB4v0t9M1v ULOTKvBM8ZB9iR1rj7qE+Wwrjpu6TOpnL3QMcp471p6W6ZHzflXctjle5suQYT8w9qy4MpOO 2DVIzZ7P8Ntce2jC9MnjHevRNQu21KxY4ZgwxXQtjHqeBfEWwKByB05OeteVdJfTmsEbIsN8 y8fnVCVNhJoTLIutJWhm9yRePapi2Fz1pAVmlY55pgYg9aYh8UrIwIPSt6w1BAgDEY9aTKRp 2k6m9tp0+9HIGB+hr9Of2edQ+0+E7dSeQo/lX5Zx1Tvhqc/M+oySXvyRtfFy1F3oNwOuUPb2 r8t/ivYnTvFlxxg7zxjpXncDzs5xOvOV7sWaPw9u42mCSNhSMDPr2/rWv40sVt50nhxuHXHT 61+tnyyOo8CeKJ5rNbfJUlce1dPJeXaggKTnoO9edNNM7IWaMPU/tLrkjaT61xOu29w+7I6U 4bhPY4+diHwaueGPDuqeLvENho2i2UuoapeyiG3toVyzse3t3JJ4ABJ4FetT+E8up8R0vxN0 DR/BGt22i6XqZ1fULCMLqd9C4a2a6zlkg4yUThd5PzEEjAxnr/idcNB8BfhVYGPEbXGr3sT4 4KSSxAD6go1bLZkdTyqyO3Jr6H/ZQ/Zx1b9ofxesBSez8L2LBtS1REztGMiJM9Xb8cA5I6A8 vK5NRRrflV2fqhoGj6H4F0iz0HRbJbHS9PiWG3tkyBgHJJ9yeSTye5zTtQuHu5SFPlxg8IvS vXiklZHnt31IktHieN3UEH5tueoqzerbrIBG4RCfn6nHGeP1FWSRQRi53sX+UHgAfwitKyhk EoMSlI2GCD/EPWlcpGtBZQ5iMnJXuD1+tOupDK/lq22Idl4rnm29DVIo3ttFt3TPuQHhO34+ teY+Pb5U8yJm2wHgovcVzyjoaxZ86eN9aaORYkbCq4x9Kr2WtEWZAfJ+tYLRmjM/V9QNxZ7O eWGfzrf8R3DDwcqQHJ8sA7a1JsWfDcYbwmkYHJXkVmWVk9tMQykZ9aQHSaTb/v1bkc9a9H0i 1eWJRgsPWtIkM6/S9HclCqkn1ArrLvwzdtbDhGIGRlxmt0jJswIdKummCbdozjPpXQWvh2NH BlmLL6ItUguWtQ0q2kCiGLYB1yck1Fa6NFGQzjkdBTsI0AqqOAKQtn60ANaTNML/AJUARs+D TC3U5pgMZ80wt6cUh2uNz70mS3TqOtK4rCDaBudgij16mq17do6rsycZrCU9dCrEMUwDE8OB 19Kgmf52kklJz/CvalN2QFaS8DAqi7V9+tQSsXXJPTmua+pYttPvBIOar3VwA2FwW9u1aVHe wkVXkdwRnBquz84XknuKzitRhC5jbk4BqpeS7ZDjhT0zVVFpcEVt6kcnNJHc+UxVVx9KzhuM fdXry2rDf5a9PrWMkipnPzdgDVS3KRHNdPuOAFqBpyZPm5xSjuA+7uEVIy3zkjoe1Zr3kjFt vH0pS3BELOkaZdwCe1Ot7iNiM8jtSiMpXtxIZSAdg7KOKglkiWNjM5Z8cDNID7gjbBBq9IS8 BxzkV6RgZm3BopjIrpN8DjqcVxWs2olgnhIOGU1xV1dG9J6n5K/tR+F28N/FjWI1jKxTSeco x6//AF8141JFuDV5dPY7GctrMHly5Axk0adCzLuA/GvQT0MGtS8srLwTUecSZJ4q46mTPSPh /eKZEHPBAxXsluwXTsY7dq3jsY9Tx/4hW7SLMMep4rxS6i8u5cVj1NUOQHbVW5GM4pdS+hVP pSjqK0Mx+T7UZLDFACrCOppGjUUrlWGEUBuODTJL2m6g0DhWxj19K/Sf9kfxANV8K2gDAt5Y B/KvzzjaHNl6l2Z9DksrV2vI9r8c2AudGnUjIKGvzF/aE0oWfieYgHO8596+O4Hqf7Q4ns5w v3NzgvD87W0qOpxgjmvSZsalpQB5YjHIr9rT1PkFsZXhXUn0fVDExIXdkV69DqEdykbZHzAc 1zVEaxZU1FkZCODXD+JHVYyO+OfWso7msrtHm96P3zY6V7pdRSfs3/DG0VD5HxG8ZWfmyy/8 tdI0pxwi91ln6k9QgxwSa9OlscFU8ImbI3d69U+I2r/8JT8IfhffW8Xk2mkWt3oM0Y5/0iOc 3Bk/4Gl1H+KH0rdbGXUb+zz8HtQ+OHxL0vwvYuYY5mMt5dkZFtbrzJIffHAHdio71+yHgTwZ oHwa8G2Phrw9bNa2VnFsWMEbpXP3pJD/ABMx5J/pgC8PDeZnVltEvWMPnGWeYhixJkZxkj6f nj8qjeLzNwjG1c5HfArsOY07WwEqBjyNvBP1qSTSRNEyQoN7nliMmmxpGtp/h2KGECX7o6KO AKjvp4bcMEChgOlYyZUUZcDHezPKWLHOCeAPQVDqOqpZxM4Ycc8niszQ4S88dJeNII58bDyj cH/9VeX+NPEzS+YSQ3XHNc0pXNEtTw7xLeG4uxliSOTWfZ6gRIq7sjOMVkamxcwkwbuxrX0S 4lu7RrSZCUIwCRVok6HSLKXTYxE2dh6HHFXbyz8whkUs3tVEnReFfDN5enLJtUcc17P4Z0mD TLGRZIQ9xjAJ6Y9cetaR3Ikzd0+WeCQfNlB0UqKvzubmTe5y+Oa3RixI4lXkVIMetWAoYdc8 00yZoAjZyOvNMZzikMiZzk800setADGc9M00yY60MYzcSaeImc4HH1qW7asZVmlVZtmRuHPH pTjPtjVVBZj1ArOT0Aqzl5QSzAYOMDtVO5nSFXjT5iepNcrepRXikJAycGnTvu5c4Xtitams RIqPcoA5UcgcVXR5J5FQttB7noK5epRJbupL7TuwcEiqM93sdgmA3sM1tLWwh0Ufmw5Ynkck 9qrXOp20KAICcHH1pq0QKz3nmAHGPxqOY/aQoxjbxmrkroCGZVhDAsCfY1nT3jsYlGFIbnHc VgtGWWZiJEwXwinccd6yXu4lnJAO33pzGitJdl2ZhyB61C0pb+IZ9BWadmUOmuGEHIBJNZze aeSeM1T1ERTosRG5sn0pY7yMS5C4QUhmTeX5mmZgehwCKozXPHJpWFY+/k5wKvQOCmPSvSME yrOmHNQEYNIY0jIxXM6tBsmPp0rnrLQ2puzPzs/b88G/ZNesdYjGFkBjc49ORXxtPwDXjR3Z 3vY5/Vog6k9D7VW0+YQoVPT9K7VsYMc8gaTIpJG5zW0TGR1vgi98q5TOc56Z6173ot4JbMBs cjJFbxMWcL45txMZVAB3A814Tr8UcFww6HPFYvc0jsZ8TB0qtdjBzj9aEWiqqAnFOMIXmrIs NbAFEeSc02BN/SonPWoRfQhamhiKshgJCOcmvuj9hXxKz6ctsxPyMUOTXxfF1P2mVz9UezlE uXEo+1Neg+06bIvUYr84/wBqvRvsusvIB/FX5bwXU5cdy9z6fNY82HZ4noFuZyQPvV3mlZWL y26MOhFfvN/ePi0tDK1y1NpcpcR8evtXReH9dkkgCE8jiorI0p72Nx795U+8MY4NcvrpJQ85 9Sa5FudD2LPwP8K2Hir4q6VFrKhtB08TatqYOPmtbaNp5F5/vCPZ/wACFc38UviNqXxV8e6x 4o1UgXV/MZBEp+WFOiRr7KuB+FerSfunn1NzmNxK17P+z5og+Ktlr3wuMqQ6hrAXUtDklOEG oW6OfLJ7CWJpFz/eVPSt0c73P0a/ZX/Zu079m/wXHczhrrxfrVtFJqMsmMQcZ8lAOiqScnJ3 Fc9MAe0EyzjfMWklbAHPT8K9CEeWKRyyfM2zbg01hAkUzeXFnLn1b0z6CpdKtLXVLmWSGWKW GJim2BtwyKbdiToU0Qy4ySqL2FWzbpbEhEwOhJqLlFaefCMAcAjrXMX4EDFuWJ55NRIpGPPf HceceuOlcR4+1nZp8kbIJYn+VsHsRzWM3aJcVdnjn2q20F5lhuJp0OPLWWQvs47E849q4zX9 dlunYA8e1cZucZeymRueWPWtHw54da5lE0mVQGgfQ7iPTUkRUCjb24rqvDOn2FrHcNPbmWXZ iH+4G9SO9XZvQk2LOx+0PkxjB7AVvaT4fWWcM0IfnAUVaIZ6Tpukw2SR7U+bHWtSKEbt3etk rGTLIGB04qRWxWyM2OD4NKXz3qhib+DTGfGTSAYX3VE8nNIYxn/CmmTk0XHYZuzznNBNIBry hB7+1R3LsY1fdt/GsKj0KRnF1jl9SRU0V0eNv3j+VEdYAV5pOH3v9AKptKkfbd7muVjK/wBo KtuwMU+4lEsW5mwOgAra94i6lISA52qSKhd2kcjpWNtSx0UwtwoBzxkntmqcx2EsgJz6Vs1d EkV1fSrCsWQgI55qk8SyjAdQevJ4rLdldCAXQdcqQQehFBuW8lgTtQckgda3k9BIzZbsGQ45 9zVeW4eV0A4wc1zJ6l2JvN2xOWfCsOayJ5huYpkj1pzY0iPzywwDgGoFnCSj5sknGahFEt9e KLdVTG8nnNZU+rnO0kHb2WqAq3OpO6kKAo9TyapG6MYyfmz1pklWe6znnA9KqSXGeKAP0TTr xVmJsH616BgE4zg1Aw4oAjxisbW4CWLjv6VjVWhpDc+Tv23vB/8Abfw4uLtY98ttiUEDPA6/ 1r8xZwVZh1we1eLtNo9LeJj6lHuGQMCsxIj0rqhsYsVk2980dRWyMpGv4cuvs1yrcZB6etez +GtWMkCgN2x9a3RgyPxGGeBieCR614N41t2S8ZiOM5zmsmtSlsYlk+cii7jJGeop9S1sUm+W jzeOtWSyNnxTonwSOtJgiXdUTNzSRRGeajIzVIljlHrX1T+w/rJt/Ek9oTwJFYZ9x/8AWr5n iSCnllXyR6eWvlxMT9Jbu383TicZBTP6V8GfteaNteSTHA7ivw/hKfJmMT7TMFfDyPmDwrPH He7Wx1xj0r0uSwTylkiweK/oWbtI+Igrqxi69bl4GBBBxxWHot2YJ9hYDJ71pLWJMdJHaW7C SMENkGqeqW4kQk9fSuDqdtro6H4X2X2f4f8Axg1iAn7Va+HorWNVXJCXF9bpK/sAgKn/AK6V 4eOGPfBr06fwo8+a1ZJn9a+6v+Ccv7PjXWtp8VfEFof7OsZDFoqOBiWfJV5seiDKr6sSf4a7 Ka5pWOKWiP0S1WBBqM05YtHtyOM5xWvoWky3KB5IiseFcIwGST057DGOK77nKeffHizn1Yab oGiSzXGuvJloIX/doh7vjoB7+9ejfDzwXB4H8M2mnq7TzIgaec9ZHPVvzzWTd2XbQ6wP8vHF Q3KmVDweORTEcxqc3kBsuMD1rjNf8Rw26ph97u2OOgHrWUmkWlc43WfFsFup2tubnoeleX+J /Ec+puRvIVegFc03fQ2irHFXrEgnPPvXO6i244AOelZlkek6C99OrMDgGu4tLBbVVRVwegA9 KVgZt2NicAsOPSugsbFBGpA+U+taJEnU6XpQ+UnOewrttC0kW6CQjB61rGOpkzaVcnNWF65r exmx2eMmgP8AhTELuxSgk5xQ3YY1pME1Ez8nFIBFLN0HTvULEg9aV9bDsOQKVyzfQd6iLALk nHtUuVihskzLjauBjv3qu1z5R2khnxms4SbbuOwyWdjhCflxnCio55CVH8Kr0yeaipqJFC6m RQGDfNToJB5e4ZJIyB0p03pYbKkpMkrkkDnoKfchYoFVRvcDJPYVm46AZ4uCHBOCB2qZ3DwE scL+lEdgKf8AaccSlQmAD2PWoX1MHLBCFU5571FxlG7vzK6+WvLep4FOe4MVu56nFaXvEDGl Z7iQjftJpkvlQcAmWUDmsk9SrEbzCNeMD2qK7ncwrvbA7Ad61k9Bpama9xh8D86bKZGjYg7Q Bn0rEsSzj8xcFyVxknNU7qcLuwcIPXvTkJaFCa/AjwM7umBVcXLEFiQCOlSl1GRTXe7qcn1J qhJMFPHSr8hFWS7XB5zj2qu10WPHT3oYitNMS3XpUE05C5pBc/SKJuamBK4IruuY2sWHw0Xv VYjtVICMjniqWqRloOnSomtCo6M8l+MGgr4g8D6laMu4PEyn8RX46+J9ObStavbV12tFIyEe mDXhz/iHpx1RzN+AykZFZAfBPNdENjJ7kM0nXNRxyE8c10RMZF+xfEgHfPavR/DOomAADOAc 8VqmYs6m91Bbi3Kn5h1zXkfj+H96zAZ69KiXcaOItCQ4q3dDCYx+NK5oY0rfMcUBt1aEARn1 oHHIoAfu4pp5PrmkMQLzS+X/AJNAh4Q9hXvn7IUMy/ENWjBKkLnA968PPGv7OrX7HfgP94gf q7bW5k0qLIyTGOor47/a78OvLp08qqdoyOBxX888PTVLMYPzPvsXHmoSR+ft0ZbC/bYSpVuD +NeheEvGQaFYpjz3Br+l5x54Jo/P6UuWdmdFfmK/hJQg56Vxeo2jW0xccc5pU37tmVUVpXNX RNdCDY+BntWteXaSxEoQRXLOPKzqpyujd+Cup2h8W6j4a1S5jstM8WadLoclzMcRwSuyPbSO eyrcRQlj2Xca8l8R6He+F9dv9I1KB7XULGd7a4gcYaORGKsp+hBrspv3Ucc92ewfsjfBnRvj z8VR4S1p9ShiubC5kjutPiVktnWJissxLDCK2zgA7iQvGc1+xui+D9L8IeA9L8PafbLb6ZZQ x2WnRwjoiD5WY9ycZJ75J716VDZs8+r0Rvvo95b6HPLaor3i5aLzDtXtkH2wDXMWvia5fSJt L0md73xE0gadwWZYmLYPzdAB/Stm7mKR2fg7wPb+HrVmOJdQnG64u25aRu/J5xnoK2lwjtGW 3MpwT2zWSlrYpoSSYRbs9uB71zXiLxtbWO+0RWlnxyF6D0y1W5WElc8W8SarcPqcss9/cSec MCJXKxKPQAd65C+Pz7xkEDAAJwO/SuNyu9ToSRh30ryNtdtq+vpXO3LY3ZqWMyL190eO46VV 03RJNSnDMp2dTQUdfbaZHZoFQc4xVgaVLPJGUkaIhvmwM5HpRYVzoNOtd78c4OOBXT6Zpo44 yOuDzWiRm2dZpWmlptxYsDj5T0FdVHHsiCgdq3iZscgx+NTKQAa0IGluaQsBQIaX6elONwV4 HSpauMiMhLMf71CbSw3HjvR0GPadGVwgwAeB6iqNxLk/KPlHNcz0mX0F89RH1x64HNQz3Ij2 hVx3z3qpbgMEc1442EsT05qlkxyYf74JBFRDR6j3JPN2oxGWJ67arPuaMsxCIPXqaJsSKLtG evzH0qzHOrRD5e1KmUV5JVi+dzjvtqnd6oJF2IpC9896cpW0JM+WVnYAE+9CysdkW7dk5C1E Rla5k/fbEHHfFQyyMeFwfXJqJaFIotc7pgsbc54ParNzKRayEYPGDzTT0BrU58Myvlm4J606 aeOHmM72bpUIpFYOclixJ96lkn82JpJOdvrW0tgRRSUO+WTCj8qr3l9EJjG8m5SeFQ5qEhlN tTdI5UQbQeAT1xVCWXC7WbIJz171VhFZ7lVGcj3qCS73Ec9+lA0V5Lok4HBqnLMwJ5P4UrBs VpJsemfeoGuuTSuDKr3ZJJOD2BqtJdFu+TUiP0zgJD+1WXYKmTXoGJPbSLcW6uvI6VE3Wmhk Z4+lQ3CebA6+3FJgcVr9mLqyuoCMqynivyD/AGmPC7eEvipq0BXbHJIZVx7814dVWqJnpQfu njV1IAMnrWNKcMa2gRLQgkORUcTbW56etdCMHqWo5Cjjmuw8PahhwDnA6ZrRGbO0SUSIMnAr jfHltuh3Y+bHUVLBHm0I8ub8a0Z4vMgz14qWaIwJk2yEVHyK0I2JKTvigY4KT+NPSA5zSvYC dLfOKtQ6eXpXHY1bTw5JcsNqH619A/supD4P8YrNeKq72XaSeD/nivOzbCzxGAq047tHRg6s aeIg33P0j0/xtpV1p8bLOo+UcZFeCftF63o+oaLONys2D+Vfz1gcpxVLGQdup99VxFN022z8 5vFWmxzavM0Iz8xwRWbb6fPC+4KwPav6XoUpeyjc/Oqk1zuxuW2qXNmgDbsCkl1lLz5WAB+t Y8nKzVT50QsozvQ4qxBqzRIVcZA7VM4cxpCXKZ15qLTynYMGvYPiwt18X/hpofxQmijXWbe6 HhzX5Y1C/arhI/Mt7ogfxPFlG/2oc/xU4K2hnNn2r/wTx+Bs3w8+Gcni6+hMXiDxjHstA4w0 Ngrcc/8ATRhvP+yqHvX2r4dhu9bFu8qLDa2vyKydJMcZAP0r0qfu00cU3eTOxlhEilHGV6ba z9O0Cx0VLg2UCxtLIZXx1YnrSEXzPtHythguCO2axb6+TSAkkpJ8xtv4+9Z7O49zB1rxYsDD ywOepPavN9Z1KS+leTOATmk3cqKOW1iFXjDSZwpByOorBu7g72RY9ykZD571g9DU529kGcFx ux90ViXg3dBx0prUCKx0STU5QoQ4Ndna6JFo9sA2CxHWqSE30K6wF58gcE1sWlmCAMdKok6H TNKLspI/IV0ttY4ZUQY96uKIOrs7RbaJe5qweT1rUhiE0CTmmiRpamE1QCF8A5znHFNd8gDg UgIzJzQ7qq5ZgKBogM5zxTrt/wDR40H8YyxrCexaKkNwI8g5J6YFR3E8kwVFAB9epo3BCtcv aYWIkMOS2azpgAZJC5Z2ycDuawfxDJVleKyYD5WHP/1qzpGZss5x9TTnuCI/NTnmmC/CswUH aBwe1ENxjLmcPbGZvlXOKofaASSq5A9qme4iu0x3HJxVV58XQ/eDp+VEdyhdQ1NEVIIiC46l R/Ws3zyww77c9eaie40iobny8GMbnB4FH2p2AQsSMfMRVQWgMr3aiP8AjOT/AAmnCeOEBo1L SY5Zu1IaM/7aGkYMw254NRXGpDZsjTI6ktWi2AzpJy5+ds1WadVY4HSmBVnvcd8VVe5LjPNM LlWSXNQvPg5zxUMZA9wuT1qvPdbc4NQBnzXu4moDNgHnmkIga49Tiqk93txg89c0gP1KRcMD SX24252nkda9ExQmgbo0kRj8pO5atyjDtVARsajzu4pMaOb1OHEzDt0r83v+CgHg4WXiOx1V Iyqygoxx36j+teLiFaS9T0KWqPinUkZQcdBWNJwTVw2FMryNUHmbWroRzljfnBrZ0a6ImXnH oPWrRLPRbG5LQqT0x3rL8Vos9k59vrSkJI8pu18q5I7CtO3YSQD6dKhmsTJvLc+Ycdc1WEPH +NWmS1qOMYHHShYhmncCVEBPT6VYjhyRxUMDQstPM8oX+Vdlp/hlYlDuAc4OK2pR5pEzlZG7 b20VoeFDetatrqghK7V2lehFemkrWZw8zbudppvxF1S2twi3s6xjjAbpWfrviyfV7Z457iSQ +jnrXLHCUOa6jqbuvUta+h5rHoZu9Td1GUY8A1vHw2AMGIk47V6MIJRscspNu5znizTFsLUs F2fhXnksp8w44Ga8WsrTaPRp35Uamn3+F2vyPXNaflx3C57nuKwNrkSWyowyoP0r6L/Zt0m6 +KPgTxt8MI5nWK7uNO1mIbNwh2XUdvPIPpFchj7RUvIfmz9YPCNpFfqltbwJBpNmgtosDGyF VCIgxwOM9PX6V6XHEtvCqxKERRhQo4rvb2RxWGvIEBNQPchenH40IZlX2pm2HyAEZwxz0rkN avpLufznYnA2qnYf/XrNrUZzd67SO248nn6ViXyjaR0HrUtFIw718xkZ46Zrm9QijljaJwNh OfTmoZaZz9zCkY2RptA44p2naBJfSAkHb/KhIGzqrDTItLj3FQGqpfObqTkcVRA6zseQcE5r o7HTQVXjjvxVIGdHZQrFEoA5xW7pVmdwkcY+taIhmsRTXOF+verJGKw2nqaaWwaAE3ZAx3ph YYouKwyRwDUYcseKQxk7bCozyRnFQbwQx3DI7HvQA53EePlBY9Af8Kil86cDORz9BisZ7FFN HaC5dWIYqeme1O8x2lLg4OO1UtgI7jy0gCFsM3JZjUS3FtbpiXMpHJYdKwk7MZSh1A3MzqVI Uk7T7VXuJNuS7AJ1xRPXUEUZ72LGVyRVaS+lYFYowM96mL1KJQfNtyWk2xr1GaqSagI0ZIsK p6k9auYkUXuXb/dx1NUpZkjueGLsw69hWcdyiSZi6qI0LuRyQOlVmhIG6dwmO1EtxkMN7DFL uCF1U8kdTVUX7PcSsQFjc8D2oj2BjbnUwjsIU3PjBkes2WeWVstKQOhA4BqrAQNOi8DnFVZL wAnPSqGUpbnc2c5P8qrvP154xSArNIO5qFp8rjOB70XCxWkueKqy3PXOAKhsRWkuwMgHNU5b oMT39+1SOxUkuRnqMe1V5L0EAfrSEUZrw4yD0Paqkt2QCN3PTOam4z9Z8ipExIuMZr0zFDY8 QSDHHappsMc0wuQueKj70hmTrMeDkd6+QP28vCY1b4bXF6iEvalZQR+R/nXmYpW1O2i9D8vr wg7lHTJrEuSBkdO1TAcig7c81Azc8Ct0c5bjIMeetWdPnMU4PTnrVpiZ6Bpl55kI54xRrEga 1Izk46UpCR5rqcH75iMdT0qTT2IGG6Z6VBrElvIAQGC4rNaMg9KEDEMeD04qSO1LdjTJsXYd NJ6itK20wnGB39KQ7GvZ2PkSBgvPvW0LqZwF+7t6Ctqc+VkTjdCG7kiHOSe9EWqlZBlSeK9G Mro4nCzNa111WfaTj8KsXF8koJH4cU09bia0KdjrMVlPlgMdM4rqrHXoLrHAz9a3VSxnyN6n J/EmYS2+QevXFeRzHD4rxajvNnqR2RYtYHk6Ct7S9Pn3DCkr6Gsbl2Z1VrorSx42cV9o/wDB N/4VzNr/AIn8Ss2xprRtIt8c4yY5ZGI/4DGAf96qhrIJaRP0s0LQItF0+G2Cr8g5wOp7k+9a MmVT2rrOS5n3T7lZTkemKy7q78uIryW7UDMK8mZ3bqM96ybtTk96LAY12uFYgDNYd5kq27rU MpGBfD5SOlc5qA3LtA5qWUhmm6FJeyqSpP4V2FvpsWmwbVUZ60JCZk38bS8jJBNVI7Untnmm I2dPsgzdORW8I1t4ePpVpEmtoln521n6DnGK6PAA2rwBVolkbMWX5T+NFwTKkLHICA4x3ouB AWBGPWlVS3Ap3AkjUJjzWA9hVBrjF1KnICng+oNZqabsgsOlfEK4AyTkk+lQHUFt3KhQ7Dr6 VLd3YZXnnXaWzmRiTgdqhjlywx1z2rRCDmPbK7qpLY56/WmXUjyEEFgh7njP4VhN9CkQmeCF kVVLOy/MT0BqQ3ISBnQ5c8AelVF+6BiSs7Tv5rbUHIJPJNV3ukJ2jLep7CuYpDGuitwhUYAH fpTdRdZBuc5QjgVo/hF1M9pY1UKqjjkVBNcuEzyB64rNFhFcbVwSNh7Gs4vJLKwVflBPIq5C KsshQkyPk9xnNVluo1lDkkgHFRFjLN1qANudrCHHUk81lfaxtZVBkJ/iaqerAgZmAO5sL3xx URnRBhe1UkMrTXm05zmqUl1u79aoTK7TkE84FV5J+cZpN3ArSXI55xVaS5GcFqkZBJcjGc1S lvVU8tz9aQFSW93DgYqpJenHJ6mkSVJbtc/e6d6qy3Y7nikUUZL0gsAcZqq95j7zfiKhsRUk uX528fWq0lwqt+8k2c/jWbZSV2fr8elNjn2vtzzjNeqYErHJzVgcp6mqQehERkUwjBpsClqs e6LNeG/tF6Auv/C/W7dlDE2zjp7GvOxK0Z10WfjLrSNZ31xC42tG5XH41gztnJrOnsaSKDt6 1A7+lbmDJ4G+WpI3KOPTNFxHZ6LfBYwM4/StC7mE0Jww6dRS3FY4rVhidveqMUhjbPNI0Ro2 4ku/lRC59BzUk+lOoAeNlPuMVJY220d3bGw/Wtyy8Myt/Bx70rhY3LXwq7oPl+orSs/CxU8r xSuNI1o/DS5+7yR3q5F4X4yF4BpKQ7A/hEOMHBNV/wDhDIyehreNblMnS5ipceE3t5MqCPfF LFojEEfoRWyrmXsTnPEHh68EoMKk89BUOn2upWTjKttz0oda7BUmi3rdrearb7GRjmudh8CX UkmWQjnFcspq9zojBnT6R4FKkB1A7HiustfCkVt/CPwrDnNuU2bLRYw6Ise5iQAB3r9Uv2VP hha/Dfwa9iYh9rgnIlY8kSFQzc8Z+8B07V04fVtmFfRI93J71RvX2NF83G48fga69jjMy7uh ke5rGmyxOTnHHNUhlaRARyMkVkai5iJJGIxj5qb0QIwLmJk3MjFgf4WNZV+flPpWRSObvnyM AUzTtAm1CdcISDS3GdfDoqaVCVK4fuCKxdRLFvbPFVYkp+UZQRkgAYJz0pTZbSCvIpIDW0y3 C4OP0rWitDdyBQPlzmtEI6K1txbxBFHPtUyy8FGB2nPHSmSM+0CJzjJ28ADpSxyb4zuA+b07 c1g7rUaM2KVjKx4wGIqZpj5ZAGWznnsK0esdA2IJW8tSZHyfRe1U57lSqsuQxO38K5oaSsV0 Hr5k1u5XBxjqeap8ZMYGZCepPSujS9yRkrBG4yyjqfWmRu2/5Tg9fpTTuMbJKYW/djKkfebm q9xM8zo7yBFAxycZ/CuaQ0Vbi7QOfKIbHQn1pn24ncqEMxGPl9acdrDKcqonMsxdgSMLziqy TIr5wWPv0qJKzGiC7uWcoF4CHkk8Ut1KHtEZn4HIwOoq1rEXUzpbvjci5x396pTTyzD5peB6 msupSFtJUcfM+ADjLGl1K5EK7VkEUXY92rV7CMW4uUYny0aTv83ANQljt6BPZe1KMe4XIpWU AnuPWoJLwrnsK0ApzXgJ5PFVpLrdyeAKQIrSXWDweKrtd8+31qblFWa8JOOdtVZLs9qQirPd 4J559qqPe7eh6+tSGxWmvMLzxVKS9UHJORQBUmv85A6DrVSa7LHrxQBUlu8Z5xVWW9Y5Cjms 2xorTzbELSNsX1JxWVea/a2YwG85vRKxk7M0jByMe58RXFwMR4hHt1rAvxdvJ5qTyFu4JODW d7nSoKKP2+S6RiRkZFZtxcMJ1IPQ167kedYvpcZQc8GrMFwCNpNWmJolJphP5VqxIhulDwkV 5j8SIfP8PajD/fhYc/SuDEbHVRPxJ+Jtm2neNNWt2wNk7Y/OuMmYjIJzWNPWKNJMoM25vShI y3Tmt9jAu2tmzZ4JFXYNLZjkAkZqRo1bWwnUYVTite10u6kGPLPTIHrSCxDN4SuLqbJXr2x0 qKTwPNzhcfhUtlpG74U8HPbXavMjBD3x+VdprXhWPUIQsa7gOckc0myg0nwDHEuXj59Mc10M HheCFR+7HHfFQMf/AGREhwEFOXTVByAM1LLJY7JQRk9PSpmgQA8Acd6QWG7VwOAaj8oE+mDQ WNniR1IyeapLZ4Y8DHvSuBN/Zkcq4dVpn9gwnnHHpxUczL5UMfSooiRsB98VWktlQkBQvuBU 3Gh4dYBzj3pftQkPHBNGwM9i/ZU+Gk3xR+Mei2QRzp1hINQvZF42RxkEDP8AtPsX8Se1fqtZ afDaS3EkKhPOfe4HQtgDP5AflXoYZe62cOIfvJFmaXy196yb2QsOPXrXUzlKMqhstk1SmBDG qQyCThaxtWG+Mqf4uBxTlsJGHOpXcB9xcAA1gaizZYDnPWsyiXRfClxq9yiiMtk16haeFIvC tkXYL5xX+Jc04rUTOH8RXhvNQkkDZBOMgYziuUvGw5zQ9wG20Hmtx6dTWrDApiZQuR2JpbjL VlAThQOc10djbrAozjcetWiS+0bwbpWwyMAFAGABVXesUsgA3BucsetTf3rAIX38nnjoBxUA uCUZRwqg8j3qJ6oaM6OXyppIx90cqc/nT0ugJFGfxPari7xAhu5ow5yxY98VTnuSV2xqK5Nm ULDclRtJKkjoOoqKRFTG0eXyS3OWNbyZKIZ7hnkUcgY4FVWlYSkmQE4xjNZJ2ZVh8NwCgZiA novJNZs0pd2J/WnMERSzxRAknJ64qot15jZHy7jURdmMdeXNvaQlXfBPTHUms6S+B2Mi/e4x 3pyGitLJK7A7tq55X1q4GeVF3YAVdvSnHYGU7lEjjEZkKMecY4NUMwnIdywwcduamwGfPOTJ hdqrjAUVE53nc53EcZNarYl7kfmAkgmoXnVec59jVAUp71SMA7qoy3e4ccVNyinLcE/Wq0t2 QMZ5qbgiu11kdearS3YYdagoqPd4OT39KrPe4BwevahCKc1719aoTXYBz6elAipLenI+biqk l1jgtge5pMRVe89OTUEkjMCzYRfc8VLY0Z8+sWtuCpcyMP4U/wAayL3xHLICIFEa+p5auecr HTClfVmVPPNdMTJI0h9zULQ1je50pWEWFuAKeIhikUfr4dfhS4LNLtJ65p194msYLV5TMpwO a9PmsjzuXUwdO+JlpNKE80EJ1q8/je3tbhWkmAVjkc1HtL6lcljtbDWILq2SXzVww7mpX1W1 QEmZR+NdammYWKc3iPT0Vg1wtebeL/FOmXkU0SXKtuBXANc1aV0bUtGfkL+05oMml/FbV2VC I5XMg49a8deF3P3T+FZ0vhRpLcvWfh+S5wQpP0Fbtt4InbBEWKtszsbumeCnZyNmW+hrftfA 7GRT5fH06UrlJHQWvgtIymYx9SK2rTwvHGceWCB05qblWLg8MooGIwM9cCo28ORKeUH5VNyi 1b6VGh+VACOK1LXTEH3l600FiybONCMKB2qvJbZOAPyoArNbkMRt70jWzMDgZ9qgpFK4jlhb JBA7EVRuLpt2N361LNUiS23SKMnpVhYyx6UkwY77Ezt0pfsTKCcY98VLYkQtE0ZyVP1pjSkD ANZ7mqGkgdTmoJEDJxxVIhsoTw5z6+hqAJtIPcdqAP0K/wCCcUET/DDxBdLAi3Q1l0efaN7I IISi7uuAS/B459zX2LnBOfX+lerQX7tHnVvjZSuyTITn5QKoXDArW25iVJFIGc1Tm5NUgK8g +XFY2pn5sDr1qpAjDvwV+oHSodH0o6jeqCMgkVkUj0qyS20K0AjULL3bvXNeINenuSwDHaTk 89arYk4+6ckk96xL+Itk4zUModoxJkw1dCsa+WFVcsx/KmhHXeHvDYW1aW4Uqzj5fUD1xVqS 6tNOLR28W+RTku4roSUVczvdmVfXhmLksW3HhSelZ093vCZbLD5fw9K5H8Za2IWujhtxJyOB nimCQqUUgc4q2hlO8u8SMYxtGfrmo/ut8xwSN3vWdN7obH3RWDcspVpCAcE9qpfanlQAYVc8 bRWMtxogkuBBNGA2WJ/KlvrsxyAjHzLkkdc1e6F1KcrPJgt8oPQk5zVaSZIwSxye4FZX1LEt 7w7HQYztOAD0qg0m1iZX2evc1cxIpz3qZO35gPWqE11LI0TLlADxWcdyh32d7qTzGyzf3mq5 BEIODJye1b2EUr+S0tLeN1keWbzMMuMD8KrS65MRiP5fUkVNrDMu8vpt25iXbHVj0rG2TTT7 5Jyq5yEXpTSEW2n2H5eTUMt5hSWbgdqskz3v2OcZAqtLd7udxpDK0l3tPXiqU15k8E4qCis9 0cdarSXXcmpYitJeHnnpVN7wrnn61Iyo97n/AGqqS3vHX9aYmVJbwkHmqE192ByfSobsBA0k kgznArNvNZsbM5lnDOP4UGSKhyKjFydkY114wkkJW2hCDpufk1mz6nc3n+tlZh6HgflWTkzs jTUUQ+Zjr1prODWbNEIswz0pWmwOD+VTYdwS56ZqQSqwznNID9ObzTLqYZSb5h09q5rW7C+W 2Ky3G1O4z1r0JROKEtTyjxZ4kbSJQLWbM4PQd6r6a/irxhc27pJIkUZBxnH4VzG7PadP1LX7 OwitxkuByScVneKrnxTBYl4Zwrn1OcUnJgkmeUS6l41v5HEl6VXkYWqVla65Y6g1zc3LTxN9 4Me/rSWu47JbHjHx88H/APCT3MUkcBkuCT84HJHH/wBevOtG+A08iB3hbNdMFoZSV2ddpnwT MGP3AB+ldBF8KhEoHk8juapk2J4fh6kbYMIH4Vfj8FrGnyp83fjNSUNbwowydh9qn/4Rvyhy pzjsKgChc6U6NwhODmoTprE/MhzQA+PSSvLKanXTichRnFMBG01xj5dw75qJrB0Y/L+VK4xG 04n7wwaatntHTOaRaGXGk+bHkr0rntT8OFBuXr6Vmy0ylb27xKRsPrVqBvm4HNRcZo29tJKw +UgGrM1jIin5cr61jOWti0jKvIioORj8Kx5mKue9VF6CYx3+U+lRGcEYHJq7iIv9Y+CdvHWk +zKesgx6AGkB92/8E2bq8GjeNbHBbTFubaaNmAH75lcOBzk/Kkf049a+1ZJArsB359q9ih/D R51X42Z97nHsSPxqpIcr04rRbmRVmORiqsoHArRCK02AMnpWLfqQFz1IJzTewIwrpPMkIHVj 1rqvCel/Zx5rgj0yO9ZIZpax84YA84xXH6hGc/TiqAxZ4SW56Gql1CggZz271IylphD3B2jv 1ruvC+lLd3SvO3lRqC2TxzTQma+raoLQtBbXLupbBZ+pHtWBcXqtIAuZD09BTcnYSSRVluWi ccjIOeORUCFBud2O8nIHWpeupRAbkh87cY7Go3maa4aR5CC3HsB7UXERLOD8q5wenHNRtmE/ vMBgeuc96yas7ooJp1ZRKfvN0LHJNZ0s7yOFDY9T0rKe40QTNGHIeTcT3XmnJOrwyeinqByf aqi9AaM65u/MbLsqIowq5zgVSkvo1br5jH8hWL3KsEV0UkDuwAboOcCqt+fKlkTfuZiME9qt 6oViKRWBwuFXu54H15qk96Yn2hlfaDgjkURWox7a0xh2bQrY6jtVU3sk4BfIxWoFSWdCSWO4 9qga7UKf50AU5LlSPvZb61Ue+XkAjPvQIqPfFmI3HnjNVpbhc88j+dAFea5GBzVWW92g8j6U rginLd9ycVTlvME81NwRVe7wOpqtLfY4zmoGU5bznGaqSXgyRkD6UhFOS/APBzVd55JTx09a VwKNxf29sSJrhFI7A5P5VkXviULkWsQJzw7/AOFYuRvCk5asxbzU7q9J86UlT/COBVN1TuOl ZnXGPKrIYiDPA49KlKUhsQrimlBzx+NIkjIHPGKTG6kxiY5FKRjkUgP1I1TXrXSrZpJZVBA6 Zrxbxj4/u9funtNMy46bgOK75y6I4oLqHhf4TT6hNHdagC54YA9a9j0PQYNLhVEiVAB6d65J O2h0pXNWRVPOKzdSPnR+Wwyp9RWVyrHJaho8MS5CLj6VzN3aIxaMLwe1ax1E2YN54RtbmUO6 /d6CpI/DkCpwgUAeldK0MhE0iJM4QYqKfSY3OQgzSbHYyptICE/KQO1Vn00gcL+QqOYCGPTi zY6fhRPpWwDj86LhYzp9Mj3HeBnvTBo0L/d6+npTuIauh4PfilOlJH94ZzSuA2WyibjFUprJ U4xx2pXApTQ4xkYPvVWSFV9sVLZaGGdBwe/U1HdWiXEZwQai9yjJ/s1VYhlqpJYJHJwOM1LB M17SaOAKccVemvIJIWAFc8zWOpy2rYO7aOtc5NFlvfvRFjluQvHuGO1MaIDoK6EjJsYFwOBT e/XigLn6Gf8ABOm0CfDDWLjYqFtXmXdgbm/c2+PfA5/OvquZj56nPBGCP5V69H+Gjz6nxMqy OZSHOMYwMelVpR8pHtzWr7mZXlGBnvjNU3GTjGTVIRVkBYkdQDxjvWNqil3c5xHFHljngZP/ AOqiT6AjPsIPtN2oxnmvQre18izjAHIHIpIYx7BLiGRnyMDjFcHrM0KXLRxsGC5yc0gRlXUi pb7vyrn9TujNEsEXJJy2O1IZq6DpZSIeYNoznpya6I33khVHAU8CqQmZ0lzGLqRGBZg3VuOf 8KhEirGjFWYkc44FZIdiBnkYSsy7VQbj/sionutqkoFXI6mhsCol0yTM5+8Rgbh7UeYI7Znd gSeBk8/lTTArLdBJFZMg9QTUMjMJWYksM9+/NJgge6KxlSMsTwSfu1nBndhvb5efmY4FZTWt y0V7i/t7eQIXDN7dKZa37Tw3MMa7CfmDHpwKzQ7GNKT54DSbuMkCrKw4t8xp5kzkY46D607a DKN1MkM53TiRwMkIcgH0qGfUFfayjEgOS7cmrS0EVJbiS4OXcv8AU1GucEk4pgRy3KI2Cce1 VptRXa2OnoKAM+S+O3kYHrmqjXZZj2FMRFJcfKefaqjTgdDzUtgQSXQUYJwKpy3eDnPPtRcZ Vlu8gktj2qlJdHrnIPrSbEVZ73Pfp2qjLeYPXpUjKz3meciqMt7kkgmpbAr/AGt26LVa4uI4 TmeUR+xPJ/Cs2xpN7GVdeJYohiCIu395+BWFqGvXd7lWl2p/cTgVi5XOynTS1ZnByepyabvY Zx6VDOgaJWzzSZ7jFNCFDEU4Pg0EMk3Kw9/SkOMcUibkLjnimD5sUD1QuffFAbnrQM+wrK61 74jXuQzxwMeVA7V7L4L+GFtpMaSPGJJOpZhXQ3ZXZzRR6CllDBGFVRgVSuHCNx0rmZsVJJiB ms67mwCT+dJIdzm9TvA7FQayZijcnGe1dEVYzbKzIrdRimPtUYFUIpSkICelUI7nfPtqGykT ywCcDIyRVG4thECQM1IivDD5shIFSzWO+IjvTbsPcwLnSJWmPIA96ntNJaHLPgmp5wsTmNN3 TisnVJAvEePwFHMFjLUSMTxUrQgx89R3p3EYt2djkDmsmefLY6fjUSBEaW5lGccHvViNDEm0 /wA6lFjZF3HgVUksC8mQabJJBpoA+9knvSDS2ZiA2K56qubw0KGpaOdvvXP3GmHfkZzU00Ob uRrpUmM9s1XnsypIOBiuqJi0Rm1BB4waVNOVuccmm2CP0e/YU0dNL+DClndbh7yWZ4Tx8rhN je+VUEH3P0H0Fcg4LA4I5r1qX8NHBU+NkONq8cCq0gPPvWxmVZD8w9KqsTk0ogVrhzHCdoyO 47t6D6Vh3ylItrHczvvY/ToP8+lKXxAix4YshPdcdAcV2s7CAKMg44xVNpBuYOv6s9raSGM/ PjA968rBkSd9xLZJNQNbE9yss8SIKsWOixwKGkGW600BeecRLhOPpVKS679aoRG0wl+YgF/5 io2vHZASpz2LdAPpWVrMZFM++3YzSM0bcGPdtDfWs8zhWWMNvAXlh0HtQh2I5JjNIrDqBjNS PPBFCA4ZpT6dqH7qCxVnushViQoO7N1PtVG4uY1wXcn2Fc3M27miQwaskxBVeM45rKu55pZW 81whGdoHYVUncErFUKpkyqeaenIzzTjLJaPmQjfnIUkZx9PSkhsqC6VZCwALdsjio7zU559q mZgEBwqcD9KrZEmY8u0ZHyikS4UqSW79qobGTXojT5ep71RkvGfOTxQIryTjOTyPrVaS649a kCtPc4JB5NVXu9vei4FaS9zzn9aqy3+M0CKct6CclsVTlvSAcdKkZTmvmbv+NVJb4gHJ596L iKct7wcsMiqslwzn5cnnqTWbkNEFxPsXdM6oPyrKuNdghGIkaU+p4GahyNIxuZF5r11MCok8 pfROKzBMzksWJJ7k5rJs6oxS0RHI5JNQuAeeahGyG8/hQTnvTKGFRn2pNwGaEQwZwM4pAaZm 2PzTgx/SjcSGE5JppGDzSHcOmabkcUgTP1N8LeCrTw9bIscYUgAdK6RpFjXHCirbuZIhlYuO Kz5o8nJpFpmfcSbeMVlag7FMLxmqSE2c7c2rSuSciqMlk/m4GcelXsIc9iyqOuT2qpLatnAq bjK0tm3pmoo9PWNtxXBPekBOIgoxUVzaoy9QeKAKSRJGeMCoZsluBWTY0QOgXlu3Q1m3uorH 93kfWkMyTfSSNwcE9s1DcjP3hknvQJleScRqT3Hasx9Td2I6AdqokpXTjq3FUJBEz0mC0JFu FVSBmmNMCM0kU3crTX6RgkjP41U/tXf0/KhsaQo1Ujq3Tse1SJq7DGMYrKb0NIjLvUPOXnjj qKznuE6k0QCQn21McfpVSRFlBx96tSBgsBjOT7Ve0vw5qOr3aWtjZTXM742pGhJOcY/mKEnJ 2QtFqfpV+y1p19oXwe0rSdTaNrmweWBtjhynzl9jEd13kYGeAK9XuAFQ7sAA5Oa9qCaikzzp tOTZzPia5fTfLuEmAIUgRs2BJjkY/LFJ4e1+PxHolrqKxPAJgQ0UnVHBKsv4EGtGSTXL7cAD qeKrjDMecj19ahOz1GytdOPM8vGEB+Y5rJ1WVXhYAbpUXqBx7/pUX5mGxo+EV3NIy5VNxxnr jtWxfsFZm3ZB45oqvRAjnb6FrxGGBz0rIGgjcTt5rXoIgkto7Dy3m4EjlEXuTis+bUcsyAY2 nt0qeboh2K00pVQzAgMcAnoaqNKB/hTuIja6C9DzUIuzG27PPbNAEc93Gbdtx8w5+4T0qlLf SSfKMKp7AVhO/QtE1tKY1Znxknp3xUd7dgqNxAUHINabrURj3V1LNKAvCA8YFQXUu1doUs+O lc7jY1RSSd4LjDgIQM7frUVze+ZKxbJY9Sa0S7iK01+/ZyAOPl4qq9yApx3p2SEQC5j3jc+0 VVubhV5Ric9e2KljRSa4Ock8io2usfdOfxoAgkudw5qCW5UfxVN9AKsl2TgYx+NV5LnaCc80 hFOa9yOvNU5b71bg0AU5tQAPDZFUZ78EnmgRVe8xk5GKqS34x1/WpuFim90znjJB/SopGdU3 SMEQfxOcCpbGkZlxr1lAdqyG4b/Y4X86zbjxHPMpESrApH8HX86ybNow7mS9xIZDIzFyepJz R5wcelZnQkNKhutQuoBwOKY0RsBuyRx6U1gM8VBVxp+Ue/tUR61Vh3GOdntzUYOe+aEDY7GR 6UAY5zmmQOB54pc0CF+lJQIMAn3pGi4yORSC7P1me6AXNVzIZmFVYgsDIUVj6rO8bYXKknqK drsd7FZd0qAt371XngD9a0tYm5RawDPmke0jI5AOKzYyhPCATVV4Aw6c1BSKdwuwYxisy4nw CQCaTdmBUW5Y9R17UNK23nipchpGdNKwIOfrTRMdrHpWd7soyNUklkA2knHas5YmkBDg59ap uwkhptvLOQOnas6/LliBxxUKVwasUU6bTk+1QzKingHca1RmU7qPzUNZjwmPk9BSY0Rs5UY4 zVeWZlGecUiihOxcEHv7VUdHUZwaaQEYc9/1q5CeMcVlNGkRswLLwDms2fcCQetKA5DPLZcc U+G62N8w4781qQdxouv+CNHPmXtjqGrupDKrARqfZgH6D+npxW5qH7QV7PanTvDelweHbUp5 fmRndJt6fLwAp/An3ruhXhShamvefU55U5Td5bH1x+wvdTXPwr1U3M0k8j61MxaRyxyYYSSS fUkn6mvZPiBJ9o0qPTiWQX8ohZ0ODGOu7PtjP4V00HeCOap8TPP3vrvxJbpp7zBNegdo44yT kpnYZCvYBuTnqK9ItrCOwtbe2jBEUKhRk8nHc1u9yERsRMmehHHPao3/ANHiBA6dCPXtSauM oTjK5Y8seT0yay7xFlil8sKDgnLd8D/61c6Tixmp4SkRlZA2e+a07w75tpGVU5PpWs9bCWhT RQ8hOOM/hTrlfLhdsA4HQVV9NSTz3Wrs/aiD26e1Y7ZTDbjjGOe/v+tQkMg1RvMsUaeUiL7q gHnOev69aqNcbQFzQtyiKS4AGc1XN3u4/lVXBDS2e/bPWq8tx5b5X7w4xipEQPqLiQBpBGD2 zVF7xZJXUuWZTjmpb1sXbQQ35jBx2qpcX7SqQcLz1XimMpPcAZx+dVpLk7sk9aAKzXeSfTPF QS3OFOeBSuBWN0pHXI61Vluck4Jx6VJRWNxyeTUTz/N7UmSV3u+MZ2jPSqk1578UgKkt5z1x VObUCMjd+NIClJe5zz+tZ1xf5baDx3NICo95szzx6VVkuixx3qWwIt0jKxZtqgdW7D3rMute sbVgDI0746Rjj86zbLUbmPe+Lrk5W3VbcHuPmb8zWJNdy3TlpZGkY93OTWbZtGKWwsYwQKsf KRxQWNLjHXio8YNIY8HIAqKQAUDuQtyfShQMcnB96RRHJIBxnnvURfcemaYDJAHHvQkXy5zy aSC4qoVGM0/bk+gpiJ47ZWGTTTb7W7mnYgTyc9MfjSvbkjjJoGhv2dguSMYpjcVIz9X0tHnG RxUv2UQqMda2SsY3Ks93syq8mqDsXOW5qox6ib6EMsmPlAxmoGNKRSRGelV+pIzUDIJ4AevW qMiBX9qmwrlG7jUgk1jXCoi9CO9ZspFB5kTP9KrSXQYfIPzrJmiKNwGkHAqC1gkLlXyR2yak omlgCqcqCDWbfbYTkDH40MSM17vd2qnM28njOfWlBXCTKrwLuLZ59qilSLaSxBrpSMWQFUkG Me9QPaIfShq4JmZcWqq3y0xrESLjH4UrDuVzpvOcECnNYJsIxj3FDKsY02nkSsRTVjYNgLms ZotFlLF3HTiqdzYES5IyOtTEp6jXQLHnZkVQmjB5HFaEkAh39elaNhZhXBPFNAz9DP2KbdLf 4QM6pteTU5nck53HZGAenoAO/T8K9d8SRRC8WS4/1br5cXP3W5LH8uM+9eph/gPOqfEzK8PW FpqHiG51e28xhawDT1lb/loeGcn3Bwv4NXSSgjmupGZSkQLkjjPNVp13JgjjOR9asCpKqhWZ uijg+n+eKx7p2R2cnaCePpUNagXvByldx5Hbk1q3bM0jKOgppXEJDkIccED8qiuy62khYhAC MsT1rKsrK5UdzyrxFeRWmoSxksWkkLhVPY//AFz+lZOp3MlvFaxzHLuOdvQHGcflWEZdy2ir c3gvoo0lkO2AFkTjnvzUVrP9rhSRlMfUENWieoW0HlFOQpyfrUJjKMS3Az9asRWuL2JMgDJH fNUZtQVydmQfWkxpFW5lSTD7xvAwciqUl1jJPJ9alLqUVmvCTUD3W7vzTEQtOdpOaqS3Cr1J zUsCrJcnJwcVWlnZm5JxSuMryTYPWoXuQoqQKkl4DyDgetVJL/rzz60hFKbUCCcniqk1+T34 96QFKW/296pTaiee3egCnNfs2eefaqiNJJkKCB3JrNyQ7EU11bwD95L5jf3U5/8ArVnT682M W8QTH8T8ms7mkY9WZV28t626aVpOc4bpVCe2BPH5UGhA8A4FCQ7eMYosUh7R7RnIpFOTUjEZ c9Kb5JHcGiwgCbaRutFgK7krz2qHlm5FIsVoxjPemBNxxnHamMkFqTxSiArSsJkyx7VGR+NN ZcH+lBNx8bEVLtLLnH40xCGLjPekyV60hoYZTjGOvemGEnmlYD9bC6wqMnism+vS3C5rsUbn M3YzN2Tk8k0tW1ZCTuyJ4we9Qutc7WptcgdhUDvs96loRBJLuOKrTLgZxx61LGZc7ZJ7CsTV JPLU4Has2Ujj7/VHiYjtTrHUg64Oc1zyZvEuLdruGM1L9pT/AD1pAQSzCQkE557VVvVjdTuP PoKuxOxz1wQkjcYqBZ0bOeDWiViWypcyjcQpqu8DOhPYCtUjNlYhlzg4NN5PU80AQtBuPWgA L0xUjRFLcLgAcmoTOAvv6VDNEik0g8ypREmOnXvUblEbMQQF5FQzxF1zyR7VIyONo/JZWB3Y 71jyWjF24+U1o2hDUsyH9sVbjVlPBxQgP0W/Y+aJPg9ZQBld0mk3FefmyCefofyxXsuoWKX9 u0Zx5infGxH3W7V6dLSKPPqfEyloWnvp+jW0ErF51UeazEnLnljz75qWcqisxOAOP8K6UZFG TjNVp8FQrHG4EA+nrTltoCM6R9zMjLwADkj/AD6VlX21yVJ+Yj5R7+/tVvYRu+EoEaN2Gdqk gEj72D1+lXLtkaZyo4GBj1NQnZ2CxGg5rH8c3p03w3PMAMqQeTjoRUVtIMqGskjyLW5ReSx6 gSqQFAPMLZzzx/OsfxAzrbG+kuU2+ZmKGM5ODxn2wK41sjbqQ2EsN1bxzKDlT1f2p7XP2eWe aSUv5nKx54H0roS6ksqjUX8wNyvrjvSX98JGVlYjjsaoVjOkuO/X3NVWugM89KQyq1wCOvWq 8l0SCP1pDITOD1PPpUBuMEkdqAKzXROc96ryOMcmpArSXQHcfjVOS8574FJAVpL5U5LcntVK e/JyOKVxlGW+PT+VVJb3BPNIkozX/Hqapy3+M5NJsZA9w8pAXJPrVeaVIf8AXSAHuqnJrKUh pNlOTV0Q4giyf7z/AOFULq9lnzvc4PYcD8qyN1GxWXnApSABTGV2bGRVcjeeOaoQx0BxkfnU b8LwKQ0RYZuaTy2AyRSGKBj6UCmAhOOoqNhz7UgEYAjpTDEBjFA0NaI7faoxEc8UiiyM8DHN S/ZnZc44oJDZkEEYNMMXOKAHiPCjmgE5xyRSED/lUJB6daYdRNmXwB3qyYW2jCMQeBxxSQ2f qfIxmYdcCq8kH4ivTjGyOBvUqTQleaiz0rOW5pHREEpJPWqtxKUSsmjS5m/a2ZueM1YRgy8V mxgUUDniq8wBQjtUsowdQZU5ziud1a/Agbp7cVkyzh7+4FxIeOhqe0jWNMnGfWsJI0ixftRj LcVH/aTq/WiwmyeO9WQHDcjt3qNpDPIVyQK2hElsj1G1VEUgA5Gcisn+zywJwR+NaNEkMlgV OCeKayMExznpTEU7mDYpYn8Kzm3Fvb60mNC7yBjOap3Mr7uOR7VDAqpIQwz/ACqWZg6fKfxF RY0K625PX86lZSEAGTUl7kGCvBqcgvHU7DsVXi2k5GKpyq7jCrihCsLHC23lcNSCNkfnoadw Pt39hXxNLfeFdY0Z0VI9OnR0ZerebvJz9Cp/SvqBj85I4NehSleFzgqK0mMm+UZFUpeQ3XA9 K7U9LmJQdtwyO9V5eQB2FaollKRQzAdAep9BWPfqpuSwwFC459Bkk/rUTlZpDSOq0VfKsMjj IxmmyIS5LH/61C+K4DkXafxrzH4+PeT6dpGn2Ss8j3PnSlSQFQKRkn0yy8f4VFZ+7Yun8Rwd zdW9/YQwyQkm3wuCvAX/APX/ADrNv2hW5jmSIuu4RLEWBAbqMAntzzXOkXckk1xPIGyEfNkA dhWXPeecQzKFxxgCtSSCa4BPBqs91gdM0hlaW7JBAqpJcADrQBVe4weoAqJ7kFfvVIyE3Hao JbjGc0m7gynPe7ehqnJfBjy2BSEUpr4Y4qpNf84zgUhlG4v8jk1RlvyTwf8A69IRSmv++QDV Vrln+6D170m7BYjcnrK4Qe/+FVZL6OPiOPefV6ybubKPco3V5O6YMhAP8KcCqYYsBmoLSS2D rUb8cUixpI7momnAznmhCIRKrMOOPepvlHpVARPFu5FRBNwKn86AGiIhqV+B0oENCjGMUyVA OQMCkxkR69Mmjyy3akOwMo6EYNRsdvahDJ4LaS7U+XE8nbKqTV+LwdrTCIx6ZdP5vMYERyw9 qYjQHw78R/MW014tvXzHUEfhmr0Xw/1dn2ObcYGT+8z+oGKV0ty1Fy0SHw+AZp1Je4C89EjJ wPXqKvRfDyyjcO95LLDkgkIEYenrUc6N/q092MTwRaRkSSK8sYByofBHXHb6UsHhXTzLua0Z U3cKHJwPxqXPsS6SW7Nqy8PaVBcRullbkopbEoDjgd93Bqwun6XBI7fYrQ7vlDBFBHuMcZqL tmLsi3pVhoQDswW2cnBVUGCOtbCadoMMbJHMNp7bSB1z6VordTKUux9lSOsY9/SoWnBPQ17b OFEU7AoazJGZOlYyV9TRMZ5rMRnFV7lAw6Csmi7lOSFB0wKiWTa2c5FZsohu7knhTis+S7dF IyahmhzmrXEpZtuT6VzlxPJLuBFYvcoy308tkhcGolt2ibDHg8cVNiky43kpFyRWTdbGfK9+ aLaiuRRlkYsDmobi/aGTKtgirQDjrHmIGYjd6Uw6si9s07iKEutgucL9KR9RJUnHPvRcLGfP cvK2e2KqtLt5B5PWkMheU+tIg3cGpAbPFkjbilitTipsO5ZEIAA29KcpQHmkNFG7cNJ8vSpI Iw4G41k9TVbE8th5g459qpT2jxkEoRTsIjySelMlQHoMUJDPqH9g2+MXifxPYEn99aRXIx0/ duy/+1f0r7OdhtLenGa9Cj8BwVvjIXk2DB5zVK4OVIHA9utaKV1YytqUGxGuAMKox61XZ1YZ Brui+hDK0r7Q2MdM5PasG5lYtkL87ckkZx3Ax7f0FTJXdxrY63SUNvpQ3MWCr1J61VknL3Bb qT27U0tRFiNyOvOa8q+K90y+K9PVXZybGYiLnaCXjBOf++axrXsjSD1POby9EMUskwPmEnIH 1rPlut5Dhdh6jB5H41nHUpkEk4SNEUAKo6VVkuM9KskrSTY6k1C84HekBVmucdOapTXJI5P4 CkMqtcjHPPsarve+lSwIGvsHk1TmvOTUgU5b0DPJxVKW+Gev69KBooXF9zgfzqjPf55JwPek Ipvek5xyaYTI2d7CNfesnLsNK7K7SxpkgFznvwKpXF9KxwrbF/2aycjdQK5umYYJzSRo0jbs 9KE7mjQkmR1qru3twKYh5jI5pNmakZBJbknAOKYbBz/FxVJCEOnnIwRTjYlF5osBA6lR3NNR CxwOaYiWK1kkbCjJqwNDv5HVEtJXLcgBeo9aVwuS/wDCMaizAG32clfmYDHH1rSh+HN9PC0n 2u1O37yIWLD8Mc0nJdRl9fhXHbhXu9U2x7QWWOA5B9OSOlXovBOgWbeVNLeTPyc8KMdjgDPP 1qOaO4JOWiL+neFfD0bowsjI+7B84lht9cetadj4e0uMu66bbogwQPLGfoKXtEa+ztuzVicQ RMILdYQ3GE4GPTH5flUkF1dWUokhfZKF4cHoOlS6jHaC3IjcNNJuYGeXOS5zljmpXhk8tiIV TdjIHPSouCq22K32OXIEduiYXk5IJyail0aWaNAVCE5ONx/WjQl4ib3YsehSI/DqnGCcnmmn w2jHDTYIJJK96tHO5tjf+EbtwNxkct6Mc0o8NWS7cB2I7u2ar0JbbEk8PW0XyGMdd2Qe59al TT4IwAiKBjHIqLiPsFZ97Hd+ZpGcFuK+htc5EQyy5YDPFMdlVctgVi1YtMzrm8SN/lrKvNVd CSoFYs0RQfUZ5SegH0oVpZDwTms7GiAq4xvqOZFZc8ZqGUY11CWJGOO1Un0fzFJAAJ5rJoq5 T/sd05IzWBrcX2I5BA9M1A0YBumk3c8Z4pplVM54pDIpb5cEBufSqMiCUk7yGqhmdNM8JIHT 19ahNyzdCRTAdBD5vOc4p1yWVMDPFSwKce8txnnirIsHYbqEAh06UnA59xVhdGkRQxOAB0FA ilORC2DgmnpfKmM/likND/PSXnoajnIzkDmoZaIUjBOSM571Mijg9BU2KuWhOqKcnNULq+3/ ACjmmBCgyM9M1BI2TgGmK59C/sRX5tfiteRHO2XTJRjPHEkf+NfdPG48YzXbS0gcdX4yCZfl wapuByT1AoW9jMpSgLFhT07n071TnALKRwVznj9P8+1ddN8zIZUnYFio6gc1lP8AvLlR6sBj 2710MlHWy4j09UAzvXAH4VmrEQcmpiBMsgTrzivMvijZxSXkF7Ix3QIcY7qSDz9CAayqrZlR PMNZEUt1Mg3MMADHU5rEklKbQccjt39awWhoQPJ6nioJJwtWJFSa5A78VTlufl6mpuMqT3WB 1qlNe5B6cUgKb3YHGfrVOW+CkgGlcCrLqGAQPrVGbUMZA60gKEt/kncapS6gGPynP0qG7DK0 k7uNzEIvTcxwPzqubmBTgN5p9uB+ZrJyuaKJKLn5Rjah7bev51TnmwfvEn61JslYpzXLHgE1 WeYqADzmsWaJDN+T/jViK42Lz3oTsNg8nmjrzUcaBSTWu5kHmc4xUbzfNgcAetIYsYZ2+UE1 eGm3Uq7o7eRge+04/OncVy7a+FdSm8pvLVFfldzDPXHQc9a0oPBrzbhPcrG4O1URNzMe4o5i eYlh8F2IhZ5kuJGBblWGABjkjHHWrdr4Ytyd1tpzMRzgoW4xjvmk5CudBY+FbiSxKJpwR2YE ylFVjznHIzVtfBWqzxxCeeONUXYoU5IHpUtkNmlY+E4LR0NzmdAc7OADWgxhtwywwCNPTbyP xrnqQU9yoysULpxIcmCOQH1FZzRKp3C3QHHXGawVNrZl89yLyg5xwo6/KKBFsOPfg1oo2Dnu P372bBLKOhbvVu1lRiVKqCR1Iq0S2TefHuUYAyetM8/OSMY/pVEkgmBTOOtNklXsegxzQiSJ pSSB1FQmYDJ6iquIVnAAPY5xUTzAuFHTPNFxjDI2GUHjOSM1G0q59/TPWs7jW59iz2iqpIqh tYEjB4r6uxwFW5Z1ORx71SmleVNu6sJo0VyCHTWkfJJK+9TyaTHsIOD6E1zyRoirPYRIhwBm qwh2cis2jVMY+Gwpqs0AHXpWbGZlyVVyOtUJ9R+zHnHPY1gzQyb/AF4MpwRyOK5XU5GvHO7p 15rJjSKMdgxBwOn61XnsGJySQPSkUZc8GxyAaalvI3RtvNUgIprIlvmOfpVaa056cUxklras hJPQH8qsSosiHOMj1pCKioinPGBzVozqg449qewE0V2m3kcjpVefVGCkZx+FJsLGJcSb5Mk5 yacsBYAqKkdiaOFocEjH1pxuUUcnkUmUAlRzgcU1kCg4NIZSl3AnDcUwZXJNAiM3GM9hTRKp NVYD3b9jqfy/i+oDAbrCYfX5kOP0r74Viwz612U/4bOWr8QTNuXPp1FZ91IERs4yeMHoc9BQ tzIpyKCDu5AqoTuGcY713QsmZsqzLjPqazOUuo2KhQWI69T24rRsSOnc+ZGg6gYqKcqnXAXo Ky5lB2Ha5h3erRqCyEHPSvN/HesXN7cRQpbma3ABLK4Bznpg9hwc/wCS5NNBHQ8z1Ob7Jqly isDtdlyeemRWNc3AeYyHlgAqj0A9Kwsalc3PyEE5qhLdkse/tSEU5bv161Smv8A84pDKEt6A uN341nz6gcnBApXAoT6gNxO7mqUuoD1wKlsClNqoAIzk+1VHuppBkfKnck1DdkOxQuNQgizu kaZx2QcfmapPqs0pxEFhX2GT+ZrJu5soW3EDPNyzlz6scmnxq2cDrUtmqQ7bKPWneWxPIqdW URXEBTkAnPakjshIhJGPrSUQuRNZYJIORRHZTTnEcbOf9kZpWBuxq6b4V1S+LCOylJBwQ42k H8a3k+Glyu8XN7bROvWNG3uPr2xWiWhi5al+y+HujwJIb66uJpF5VI/3YYfUj+VFp4O06UMi 2LknJDcsw5/WloTzNm1Z6BdpshtbdYQQOY4gvI6ZPrV608G3xkiklmRAvJBOcVDZNzUj8Gwx 7jLeSHB3AoAAD681ND4a0q0kSVEkaT+/I5z9eKQiygsbE7Y7aOMnuFFSf2kowIwMn+VS2WOa +II7HHrTJL/zYwAAqjuBzTIfYrPdnJ9uhqF7xXznlcdxzUtgVHVZHO0Djng4qpMWRjk5Xt7e 1SDK7SBk4OKgeQ5GfTAoY0MNwEVtz4VeevGaYl5yADk5rJysaWLMU+Ey3rUwkSRgQRjp6c0u YlgZwrjk4H61FJdhiWyBzwoNaKSJYhvUQ53Hiq73i5I3fQUudFJFd7ySQEYAJPGDUf2sF8s5 HvUOTLURhvCOVOcnnika9IzgFsqRnNTdjSPuZlD8VEIQR2r7RHllHUYliHI4NY5iBbispami JQAiioJ5XKnGa5mWjPy5OGNR3DmONmAqGi7nP3V+6McHnNSx3xmUjODWDNUjNvW8skk81gap MSpB5HaueRojmdQuNuAGzVIXhJw3NZMotRXHyfKR/nvVK7mdieaEIzjCZH5OPepkVRgcfQUD EkAIYZqmCgbn9e9MBjyCMAD9KgbdKTg5pgC2rH73FQyWxTJyMUmMgaby1x6VF5wk+meakY4o jLkY4qSLarYJ96QDrtsKeAR1rKkJZs9fpSGOiODUrbgMjNMCKSQY64NV2mxx0pgRMhI4pFhP 0piPaf2TZDD8Z9MX+/BMv/jhP9K/QWAnGM5GK7qSvTZy1fiQ8gj34qpPGCp9T0qEzMz7kFFY AZJBAqhc7lZliYI+3gEcD/IropCZlXMhhRJpmLyPtjRVGOT1IHv79AKpS70l3scdgo7Vtq5E 7I6CxvlmiQ7ucYIz3p91IH5HQDpUVFcEcD4rVra4UxMViYbgF42nOMV5X4v8Q/ZZvI8wFyMN tPK1C2KOPOZlLA5J5OazL258knPFJlGdJegqTurNn1FckA/hU3AoTamE3AsB+NZ1xqfyH0qb gZtxqxxnNZs+rg5yR7CkMpvqRk/iA47moluEnfHmF8ckgcCs3Kw0rimQKTsUD3PJqO5jacjc xOawbbOlJIhOmgxnPWoPsQBwPzoKJ4rIL361ahtgme9CBaEjxDGAKntNDvrxQYbSV0P8QUhf z6VQmbUXw61Ka3M07W9tEMZ3Sbj+QzWlpPgTS1V/t9zNLIw/dpCAqnjuTQZOfY1B4S0awhHl 2aSzOQwMpZ8DnjH/ANatCG2ljjhjsrX7JjjKLtB9/wDOaRm23uWLfR7tnd5HCuATlmzinR6B HGAzTnc3LgKMZ9ajmEXfsVkrbihkbuZDuNO8+JGbaqhj1wBWbepSHi8ROcYJpkl8WBI/KqJI Li/yoO4j2IqF74E5JzimwRVnusnpzVb7UUcnjg4Ix0rllLU2S0JjfZPJPPSmG+AHJOfrV30I tdlaW/3jG4gfnUTXhJLDkDvWfMU0J/aJ98Co2uy5PoRjmjnJsQSyuicYAPHWq0rs2NzEEc1D lcpKxVG8swLEj39KdC+wFh9OayLbLUd2FxngDninLchsdOfSqRDEad5S20E+g61EPN6FDuPt VCGtGzKM/MWPTNSvYssjDco2jqKEirjDCsADPKq5OOfUVXeW0WRwZgwHT3/nTsHMRC+s1VA8 hKhuQp7cUHV9PE8jBJSqg7M85J9adhKZ93x4YVE0oDEDtX2Z55U1AeanTNZqQhDzUMtEdyu0 8VVmk2w5/SsJFox7m8CHKnkdazrrVDt2bjz2rBstIzJnEj5/SoftghPHPFYM2RVmZrnnpUZ0 sTRncxPHSsmg2OM8Q2XkS7UOQP5VkLbSEZIPHfvWTRomTFvKTBOT+tUp7nKkHv3pDKyyEHri lEcj8g/LQAySORRz0JqGQFhmmBTZyHOTmpop9uSRUhuMn1Fg3yjA96gnv2cYXA9TUtlIpNvY 8+tKAB1zSGw2sTxkAUwq6PnPHrQIsmQyIB0xxiq/l4JzQIfFFuI7Uty3kjFVYZVUeZzTJVCj jqOppjC3G5xmrjwgpkUIk9K/ZhmMPxu8Pjj5vOX/AMgua/Q+A8Zr0MNrBnLX3RK7ZHWq0jck dqy2lYgozKc1n3KgMWPJxyT6Yp3eyAyng33JkfcOAoGSAQM9vxNU71cniuyO2pmzLF9JYTgZ O3PNa51GWKATph0PUHkU3qBxfi/U/tFrJtJBVtwCj5se3+e1eC63DK99M755fIDHJxWLNELB MY0APFZurTqIWJwT0wahjODudTeO8KK2UJxiq99emNhg4JqAMue6MkvXOOtVbi+KqRuzzkUh mVdX5KnJwKyJ9RBfjkDvUN2GSRLLdIHOVj7HFX4E8v5VOB6VgzeCsWxiPqadvV+hz9KSKHMc r0zVnTvC+q6zIq2lhNIWBIbbhcD3PFOw20tzpbL4T6oyhrq5t7RcjI3b2/Tj9a6CP4e6Fp0T Pc3NxdtnCj7q9OeBz16c09jJz6IvW2n6bbPFDbWkce45L+XlxgHHJqx9oubsLGUjgjDZJAxn rUOSRmTfZozbtb/dRjnPG4YqD7HaxzszBmbjGew9KlzCxK17Gh+VV+XgEjoKRtVLJgEnt6Vm 5lcoz+0N5yxwBwPemf2ipyNwAoTJsVZ9R4IUle2aqi8fzThsj1rFvU0SsO+3lfvOTgYAprXk rZUZHy5IHHHrV85PKVYmWHPlhj7sxJ/M095mGAMfjWTqN7F2SI3d/MPzZVeM+tQs5TNZMtA8 qtt2kk989BQeeec007kgGUZyu70GelNxkdCBTtcAWCZ2wsLnjONp6UPaXUQBZNgc4XJHPak0 xDDp8sisxnij2c9STn8BUBiiDDdcrz3bjFFhEb/Y13M0rMR0AOM/pTBe2Sqv7pnHcFjRZDuI NUiXJS3XPToKJdY3upWFRgY4x/hTTEVzqk+NvAUHOOuKifVp8MxdVycbgO1VuQ2ULvV0AHm3 qL/20AxWdceLtKtciXUE+gYtVpMnVlKXx1pzY8hbi6OPuwxFsVEfFE0yEQaRes2err5Yx36i ny2EMbU9ZdQ0GlxR57Tyjj8qVn16RASLO3XGABuY/wCFOyA/SNcxHHr6dqpO5EhJ696+uOZE Mt2uDzzVIMZAcdM+tZssgusoM5rHvL3ClSP1rCRSRjzSFmJwazrrc2eDmueRrFFW3Rjk8ill tyzbjz9KzZoU5y6H5fyqlJqc4BRuPWs2MwrwGSYMxyalEShcY7d6zKMLVEKOe1ZZtzIOvX0r NlCm1ZTgc+9KrPGDnkd80AP3hiAaglhLcY/GqCxH/ZZA3H8s1WvIWjQhR0rNgUCu7I5xSCDH JwfalYrYeE4okwM8ZpktkeTkDtUpiQoSe3egaIYXGccGnFEZsZoAbIfI+6RmqssonbnrTBBG oU9amaGMqcsB+NMCOONVJ280x2ZW9VpID0X9nV/K+NXheTJ5nkX84nH9a/RqIfJXoYb4Wctb dDwcjHeoZTjgdfWlVVpXMlsUp+ScVRlILBT1HNQtSjLvmYt5UTYYjJ9uev1rNu8gk/w1109r kGNcqspKlsP/AAsaqXl083hy9tVlkil2l4nibDBhzx+lUI4RtVlurBbmScMCyq6XSeU8Z7gY HP8AXHWsS+tVvWZ1SNvcHOaxluXHY5a+tnt3bcuwjpXG+IL3YjKH96zKOK8uR7hpmOFz8o71 WvZWf7wwf5VAzKe5Cg88+1Zt1e7B15qWOxjXmogkAkk+grLh1Fpp1UKACcZNYtjR6JBaIbGF duCFHGeRWnpfhS61JlW0tZrh2OB5aE/rVpJmt7I24PhHrFzOq3LwWKkZIlfLY+gz/Otq3+GW i6bIFubqe+yu4MhEaHPTA5P60uUzlUtsbel2lhod2TaaZbl87AzqWZOPvc/WtWfWLi6NwCAI ywIAXG3uAKmTsjK7buyuxV1LMW3bcnL4z+IqtNcx3EKJMTJHkADAzxXNKpY0SIJNUWNNm3O0 nb0z9Kri93rhm2nPJrn5m2XYZLqDR4KuGz1B7YqlJqJwWLdecDvQ2NIgfUM8buD1zTHvSrFS ST6VHMVYYL5gn3uO1MN+Wc9AOnHaq5tBWHNIZIgNwAUj6mkdiqAcKM53VNxiLIvRj0z+Jo3E Z+bJ9zWTuAqv8uCM+9SYad8pGR6BQeKuKYXJlsrpolZk2Ru20FuhNPGmIVcyXEZ2DnZk89hV 8lxXK9xFZQPCz3QLMMuBj5f1qNtS0+GNtqGRi2Fzk4Xj6e9CSiG40a5BFMJI7UMq9FHT2znN VZdWnlUKEEa7t2D1NNy7CGSatdSO7M4JcbT8ucD2qt9pkI5c4XpUNtjK9xqUCljNOkY6kuwG KxZvFWloSBeRt6Bec0JNgVn8XWznbDbXUxA6rFxUb67fzDFvpTkE8mSQL+lVy92SMa88QXLj bHa26gYG5izD8qcLDX5cb9QSANwPKt85+hNaJRIbHR+HLqZT9o1e9cngeUyoD+hpq+CbWTaZ pLic9g8zf0qkybk8fg3TEB/0NGHo5LfoTV2LQbaIRxw20KDJOAgFMnmJl05VbdtA9gacNPJc AgHj7tITZPHY4DthQBwcgGgWUXlrtzkZJHvQK596tGC+e1VbtVXnv3zX1pkjJmVXU4NUTciJ itYtmhDJchwcnt1rLuI0mcnNZSLRWdI41IrOdk3EZrFmsUVZ7qOLJJA9KaJ0nhyv4ViyzOlm VWOax7mRd5IORWbGUQ6CTccH61BdX+w8EbfWsmVYy7q6jnUBscetZ0lyIwABn2rNjRBJedcc Yqs96zHHSkUXYFDIHB+tOebyzkflViFXUUZsMOPeo55oWQ9R3OaBGNPIN3A4qB5tpPHFQMja 7x04HamJdFuD3oQrDmZ8Z6D1qAyswxmmwQxpDGfekW4YEYpFFpYJLtcng1FLaNC2DVWJInBQ bs81n3N3JuOM0mNCQXMhbrn0rSRiY8tzVIDtvgNeJD8YvCxY5Bu9vB7lWH9a/SqDlRk/Wu/D bM5a26HP1NROQw961qx5o3MUyrMMD3rPuowFDAfMOMjqBXJF2ZZmTbYjv+UckMR3I4z/ADrI vt7TqAVMIGXb+In0Fdcpcq0JSMjUXkeTz22RW8MXK/3sZOf0rJ81SquXBDgspHpnj+lRGdwa OT8TwG6KrljGpLduT/8AWx+tcpcTyWWVjbocEg0PVjWxzGr3st2SXyM9QDXKXtsoLOQWYdzW bKOdvmGSR+dYN7dDlWG70PeoGc/fsxBaNtw7gdRXP3UrsSC30rNlGVdTbYztzu7t7UmnELOj EcA5rJjPsTw5o3hnSLazVdPgmnlhXfd3qmTEuBnA6AZz2qa516a4WW2RlVEclEjQKD6nI6Dj p71tdJaGN2yjLqkq3AeQ+fGynOVxljnpjtz+lVLIQxq73GZQQQoJ9eazuSMutW+ZUWRI+Mde mBj8Krf2mrR5yeDiuecjWKuUrjVSyhQwHGCCe3pVKTU/Kb72SwzgGuFy1udCXQjGqbXVvvt6 HoaifUwoTnHrgZJqVKxViGW8LBgGzk1FG+5myaN2MexCkAHOew5x+NSRSMu7ZhSQRnpgY55q 1EzuR7gQozn2XrSxhy+FVifYU0hXL8WkahcsFjtyCRn5yF49eTT/AOwLqOJHkeNRIcKN27Pv x2quR7i5kRG3tbYuZZsleBg43ULeaVHzh5DtOO4LdvTijlXUdyE6+kQxFbKfmyeMf40xvEd5 J5pUqgk4Pc49KL9hFaXV7x4gPtGwD7oUAfiKpyO0hJeQsD1yal3Ahe6to+GkQY6jcKgXV7Qn Cyhz0woJosMdJqpCfuLWWQkdxtH5molub+VQBEkbnrvfNPlC5L5V48RDTKmCOVSoW0lpQxku Z2B/h3YHP0FArkDeFbJCJGtxJnj5yWH61dh0K2tZVVLaGMDBIVAv8qLibJI9OEj9AMnoe1Bs USWRU2sF4DKKCWyRLYGLGDtHNTbcrGGYkKMAE9KtGYGJTtx1/SniJVIfJB6gj1qySIRlj2+o pwtyCDjGO9UIeIRk5B4PFSSQAYwSwwDkjoaQMa0eRjGPqOtKI12gYxikB9tyXO0dTWTfXLsM A4719YzNIzPNYA4NUZGLOefrWDNildXQgcDNVGuCoLZyfesHuWjOubmQ7sE/SqDyuDyazZoh jKZB8360+EeQlZtFFC/IZSwB9azRC7AkgkGs2BQnt33kdj61XEIQAOOayaNFqZ13bICSn5Yr IljO4kj2qGgI/JMgxg5qE2u0nIIOeuKVgLUUiRx8tUMl3l8YGKGNFSSYBiaas4YcmkIQ4J45 NQSJhjke9NDK8sB27hyO9QgHdSaAlklfZt4qGNSaAI5R8xOai3bWFQUiyuoPEMLUUt48zA1o noKxC85YVEUDHoKkBgUIQR1qy0rMmAM00I6z4Lh7f4seFJG/6CMA593A/rX6dW/C+vvXoYXZ nLW6MkY1VlPzcV2NXOYgc56+lVZOm6vPlGzsbXMy6jDKcjG88isa7QQqy55OPx9f5U7iMW7t 1lZonJMbAggHk+v4VhM2ZLiNmUpHwrD+71H5c/zqob2G9jn9ccxxyDAYZxk/zrjrmHzdx3BO CcmtSTlr8Kq8Nlz0A7VzWpOeVz8voazZojl9QfBOK5m/NZMDBuZmRiyn61k3ieaC8fBP3lzU MZhXbYz2NXNBj8/ULeM9HkVSPqRWTGfUl1rNt5OEBQKFUKTxkDFZV74x06KEiS7US4yVBywb tkdT07VDkRGJnReJlvHcISFPOWUjj2B5oOtk4Ctknj5axcmXylWe+PmZLbSc8Hmom1BipDMe awlroWiNrzcQSfmHJqAXQ/eAE7umPWuc2QzzXbuPXg9KesynA4J9T3ppDbHw+ZMcKhb6Crya NezorLCFyduHcAk/QnNbRgZNk40ryVLSzoFyAu0/eJ9D0qxJBptipaWdXK9V80OGPoNvb3zW qstzMY+uaZblFt7VZtoJL4IBJHGM5OAaqnxNN5RRII03NuYNzux0HHak5dhle48QX85I88xh uCIxjj0qo9w8+Mu74/vMTUXbERy3drBGzz3CowxtDEc/iTxWdN4m06Nzi5D8fKEBYn6Y4q1F tBcYPEvmANDYXEy9wRtBH1waZJf6vdgrb2UVspOQZH3FR9R/hTUUtx3FXTdUmfM9+QB/DEmM fjxUy+H1k/10003Ofncjj8KV+wXJ49EtIySkCMTx8wyfzNW1gVVVQMBew4qSbjxGCeehpY0y W7c9M0gJlXAKkd+p707y16fzpASeQpiUn7ozgA9PwqMhju4Bz1PegVxywELkDOaQQ7VbjHrT QmKtsdnA78jNKsBfI5I/lWiIJTBtAwQCOxqYW42k4DEiqERfZX3ADn6VJ9jCEg//AKqBCtCp 24BOB+fvR5alThwPwzSCw9lBh2tIAgO7njmokdH4A+U9CBwaYz7AubpUT61nO/n9M8etfVsz RnX5aPAHArK+0HzDk9fWsmamVqhZ5QwbPNVzKxjx/WsGjREQYkE5qKXHWsmURNOqAGqkl2zn jpWZQ2SceXyR05ql9o2n5R9M1DGQFjI2T0qOeNZV4FQ1caKUtiHQ4+tZNxAyAjbgdOBUONii kcJzxgfhUMlwrjAGakZXdM85xVZo8nAOPQmpsBUlYoxVu3FV2uQGwuc0gJRPx65pxkyuetCG RGfaCMfrUeFU+lNiI2nGeR9ajkn3AAcVI0V5CRn3qPkkcVLLWw/yyaeMKvNJAQudxzTTwKYh EXLZNXEcbRkfjTQHYfDCQRePPDT46alb8/8AbRa/TC1bMSnrkCvSw2zOOt0JWwQaqy5BNdhz FeUZqtKfXp0xWE431KTKFwu4sR0X/CsS/wAqMk4Jyc+grmasWjEuZRGzHkyNjkc4rmtTheNJ YowFfbjyxjA/zmmlcDD1ldlv5Y/hGK46/l2En24rYSOVvmB3Guav2JDCs2aI5jUTgHFcxftn dWTAwLo4yDWRcgoN2eazZRj3cm6Ns8t1zV/wySdWtQpIxKpB9MHP9KylsB6QJWm/1tzLOxBy GOF/IYBp0M0NnAY4Y0jbOcoMZ9643Js0Qv2xATtcqR39TSvqJVRzzjr3oQMFvQTkt81KL5jh QM9uKhrUlFmGC7lGUgaPPIL/AC5/Opo9NkfY0syxjvt5IHqaOTqWmWWSwtUCvI8zE9FkHA+g /lmiTVbKNSsVsgO0DPUj3zzyaeiB6jZNekQALHj0yScCo5NZurlRmQxr2WPilzMRATLIVDNn cPlLMB/Oqtxf21qu65uI4B6yuF/nQotiM2Xxlpkfywu963QLboW/+tTY/El9ej/RdJmTuGuW CZ/CtFC24gMmvXR5ltbNf+mSlz+tSxaNdSnNzqM0vONqfIPy5rSyWxLdieLw1ZEjdDuY8bpS Tn8+K0rawitivlQptXnaBgfpSdyLlqO3VI933iTjAPNOwAgCjaT1IrNjFA/e88jjOT1pyIFk AbBNIEyVIR8xzjjjIpoiPUAHPtQFxxhAzjkY/KpBAMBkbex4xjGOnNKwEiWjE43fTjpUgsij A5BA6k00hNkwtkz/ACHahoo4xkgfhzzTsSSKgZAdu3jlj1NNZImYRqS56nb0FFhiyqls3IUL jOScmnR/veVQ9OAeM1QgUox2nYG6ELzj2p7CQR4CrGnXLHk/hQBFIVMe0NI7EdEGKjRZMAEq ox1PWgQiIkpLAtOMnnOKlZAOAwTP8PegCNLYLG52Zx3k6A1XMYBBaZmOPux/d/CgD7BniVlP Q1USNU6V9dYzRnamDtJ4wK5wkluvIrGW5oiKSMOcHiq06KikcfhWTLRTdhGpJ6D0rOa+FwzL tIwe9c7LEVDIwFPawkVSwGTUNdikZsofnIquFbI4yT6VmyiQw7Tjv6VBM3kjnOMc0WEQNeKv QZOKzrqRpR3HtUtFIx7lWUnnB9qpxwbhnI+lZWGI52ZB4NUpVYvlW/A0hoz5t287jk1X2fvO OR2qBl9bBmUED61MIDs24IFOwFae2w4xyahaBlye1AFSUYbFMdMY5xUspIVCD1GaUBQeaBj3 KoB71TuLjBAFLYaGI28EY5qQRFjjqKQiXyABSdKpKwjd8EXht/GmgSDjbqFux/CRa/USzO6B D6gV6GG6nLX6E5xiq03LGu05SCUVWlXIOadriKMxIHUVi6gm0k+3BFcc4tamiZgXi7Wz14PS udlbdeyfxAHJY9/QD6AZ/Gs4blPYwdYDTbgOBnqe1cZqkKLu2yAnGSK3EjlL9yA2OPeua1A4 U9qykWjl9TbAJ61zd2pkzztHrWbGjBv5Iwdq5JH8RrDupSV561iyzHuz8jdqveGnxqcHoMk/ kazlsI7T+0C+fm249aRLwsOCSa5eUq5NGs7g7QB3zUywbRmSdffbyRVKBPMTLd2EHBzKw96s Q66I1xCmzJ+YDjI/DtQA5tVurqTLufmPQDFEk0u4o0hbB7NkGpaZSYNAnmAq5I4JJGOe9Vrr W9M05dtzewRuDkqWBb8utSojvcpt4yM26LT7G+u0cZLCMxxtjpy2P5Uz7R4ivEzHFY6cM4xI zTSAevAC/rV8qW4EieHb64kAvdYurhe624EKH8ufzNWrTwbpVu7SfZA0mc7pTvJ/E1S8iLmv BpsNvFtEWP7gTCjOfTHPerK2qoc+XzgjB7cdaRFxRZkoAF6DJpTbAEEAimTckjhHUhTngA9v elWJlGOx70mBIYSE2lOc9fWljizzuGR0FIdyZIgWBGN3cZ6U6SARFiXUeuDgUrASRW/Rido9 uta+n+Hzqce4XdtZoOA1y5Vf0BpWAzmh8u5eIhW2MR5qHKtg9R7U902DIBf1IpiH5/d53HGP uqORTIsysXOQv+3xQMcQC+EZpD6AcVIS8UJG9I8+2TmnYQsQ5G1C/HJc9aa5UT/OQV4ykfpS AWSMMVIjUYP33PIHpTzsKFc+bnkgcCkMT5liRsLCgOCKiJjE2QGd+vzdBTADkxtvcRZ5wgz+ FJBEA2Qh244djQSKUMmA0iuQcqIx0pRHKkm0QKoHV5Dg/lTGRypGyENvucclQTUSxyMAFRbd Mf6tuT/jSEfW5k5wfxqOaVI+ccnpX2FzJGTqVwskZH8q5zzVR3yO9c8zWJVubwK3HQVSkvAx PGMVky0Q5acFQCeegpU8NTgblXAPPNYMq5Xnsp7NslSAKeL5tuCPapGircyKVYD86NIeAS/v FBB9fWs2imO1HyvPBQDA79qwNZu1V9i4J6mk9BIzFYkZfGKrX96sWMdMdahs0KiQG8jZs/pU M1q8JAzWYFOe1bbuB561RdSuctyO1SUZVzJlyM85p1sCTuOT70rDNWK82R7MZzxxQZ8Kcjmk BWdxySSetU57hm4zwaQ0QMofkdaYwJOO9IZPBa5UsTxUTqN5FJAJMNyY61XWHzAd1Nq7DYeI VXpU8W0dTTDcjmkXdweKWN1xzTEzR8O4h8Q6ZL12XUTfk4NfqVpxzaxn/ZFduG6nLW6Fg1Wl +9XecpC/NQynimgMy4UjgHvxWTfNsQ7hkGolHSxSOb1ZnkG2HoOef89qxrm2ZcHgcc+pNc6j ylHnXjDxzouhM1vcXMktzkDyLaB5myeg+UHn2rmI9bttX8wJ+6uEAMlq7qZIwScbgpOM4p9B oyL5eG781zOodDnv2rBlo5+9t85LjGOQvrXL6s6hSC2TnhU/xqWUcren5mxWPNzwfWsWMz7n aind8xHapNCuQt0ZCOi8Y5rNgdB/aMYJ4z+OKcNaCHKqB26VArANWmc8McdqmSWSU5ZiPWlu IsxIkeCTnvzTZfEulWDbHvIjJ0EcZ3t+QyafKNCQ+Jbm8YrYaRdS9cSXAECdM5Bbn9KnEfiD UGJ+0WumRjosSGZwP95sD9KLJDL8Pgv7fGn267u78t0W4n2oBzn5VwB+Vamk+H7LT4j5NnFE MYBRAOeOvHNS32Hc0ksFdQXXa2c9MVMbFVf5CXQAElhjnHPr3zUWJZItseDgDPrViK0zyAGz 2x1NMlsmW0HyDoe9SNboGG0du/0pkjXiCYKrg9MDvUbxAsBwGxyPWkwEClSMJjJ6ntVtZzLM 00gjDBQOFAHAAHt2oYIjurjzFCuwj5yCBmkgtjIxlJZ2PId+PxNSMWBBIW3FJTnkx9KfNDlv uqOOxyxoAmW3JjyIi3sx6UqRKsWSSf8AZUUgFSMK/wAgEef7xp0zRSShFZ5DnBIHyn1OaYia RWggfe6RqehGMj6VHDukIKxl17uw5oGEgzPywcHgIO1LsYxDbEiKv989KBDmgjUDcWkY9ulL DCyRnOyBOwHWgBk6RkxfuzK4754HvzQWfYyMwQHgMnUCgY0Mq4Kx7/RjTXLO+2SZZDjIiQg8 e9MTY9oZYNywxqmOdznOKYrjePNZpmPG1ehoETWkckakrbi2BPDcc0ySK3+0q0u+WXvycCoA keJz94rBH/eU9qYYoY9pUNc5bG4cfSmB9U3C/IxHJrOB3nmvrjMrXcakFe1YM1mGl6ZHespG kSC409c5A496aukCb7oyDxjFYs0udBouhRx5LoMj1rT1CS3soDkAYFc7M76nEazqcUyngFiO o7VzEk+5iBx2pGqAx5QknFVDMsR4qGWQTX25SB+OayL0AuCOvpUMaRWnkZU4NY13K0r4zwKz ZRo2U6wW7Dueao3F20rsc8HtSApS3TLhSeKp3RLdOhqCiuNPDNluB1xRIojUgEYpDIYpcEZ6 ZqWe4yuAO1AFYT5B5x7VXlbc5IPFSykKeAMVGXIaiwE8VyVUjp61DJKN240hiCcE4Jpkr/3e BTENWQ9DRyDyaAI3ZVHFNjlGTmkwL9hc+Xe27DnEinrjvX6n2Us6wWPlxiWNztlO7lF2Egj1 +YKPxz2rtwr+L5HPW6Gk3FV35NeicZA9QTNxVIDPnHNYmpk/Tmk9gObvW2kn3rMv5VeI87GK 8e1YWKOEv/D+liZLowRS3gyguPLG8Dvgn3rjtRsorLVpQkMoLJnziAFbnpweowOSO9J7FIxr yNm4A6c1g3iJFnkM479lrnZZyGsXBIbYc5PJrkb9gM1mxmDOu/dngVk3brGDsHJ4yayZSMe9 fBOTyaow332dgvd84rGWw0W11AnqwpX1y0hIEky7/wC4vzN+QqIq47XHp4lYnEFpIR13zMIx +vP6U7+0tWvSFgkjhU9TBGZCPxOB+lbKyNo0nLV6I1rLwot6itf3N3eMRkxySkKPwFdVp2i2 tmALe2itxjH7tQM1LZzy0dkbtva4iGV5B6jvV+CzWPGMMT7VFyLl+JJOWPptq7aWDTqirgAN yWB6GpGTSWoXaGQxAjjcDTQkcRI2hxggc9z3/CkK44RDdnGD71IVZnAWMIwX+HPPuaYh3zKe V2E+pzU32ZGidnyGH3QRwaBIi+zKHDEkjoNophtWRTKGCqWxkc84qRh9nLTAlSydNzHt64qa K2MwMZczICSFRcAHFMBXs1R8K0YPAI6sKkELojbFDKevmHikIYsWxQdufZBx+FSLbtG2WjW3 bGQSckmkASIkoAKSSN6qcL+NO2FP+WgjUn5WQA0xixwH5WKsynqzcnpTBG8chDXCyRn/AJYo vQ+hNAFraCpIXaDwTMelIAoyqlnk7MBhfcVADY1FuoBjWAE/wipEXzZOVLhQTuIBUn3zQISU ZiBYqm3JG0cmolhJUHYXHo1ADngLAEtgf3QMGlhtA0b7Ivuct5hCn8AetNANS3aSYYJzg4jF WLXT0udrRII5BywZeQPWncCtqFqrplpXfawHkg8U6CIqpBiWNeu5ycrTJGIiLvLTm9J/iGAA eDwB/nmrdrYXWpvHFbiJFbjMhwc49T0qQKxRVmkTBuHjJVlXB5B9asHzMbiUtkHSNj81SxH0 3JleCazpBhjX2DIRA0G8k1A8CIemTUNXNEN+yrcHbiti006KBACB9KwloDZc2KEO0Y4rlvEt vI8ZYEkAdK5hI4C/Drkk8VnJIIzkmmboV3L9Mj1qhcEpnPJrJlplNn54PFVpvmOetQykVpW3 nacjFUXtQWyB+dQ0MglODiqUk2yQkdqhjRVnn3yZ+9UXneY+0DNITNBrdltd+OcVjSk+YSci kygJyMsPxpsmGByMe9IZBHFv6mmSRgMcGpYJjoyoPzGkkeNuBg0DK0jbche9VlLu3tQUWobR ic9sVLJb4OKBIZ5IH1oaHIJFAyuyDJzTdgUUiRFkKupXqDmv1g8PS+bo9pIeC8SnH4V24Xdn PW2RoscVXY816JyEL9aq3OeBtyD19qaYilKuBjP51g6mfnxnpQxo5u/Pr69q5nVrCCTUEvTG v2mFCiyHghTyR9M1iUeaarrurJq8SWUMEtkZBE6sWyo6kqcDJHXr68VLdQNcli2SB1Y1DKRh ajGqRtyUX17muO1icOGVflTpisZFo4/Us5IOSfSuav0Chmbp6etZMZz9028nPA7YrHvhjntW TGY9ydxxVm98KSP4AHiVMhI9Saxb/v2rqf1YflWEtC0cq1lLc4DMce5z+gq/Y6KgP3zg9lwo /SpUux0KUYbLU3bDTI42AWNSc5yRk/ma6SztWI9QKVzKU3LdnSQxK8ESRxhAoy25wSW9RwOP atKzsWmjLbQETG5sdM0XMTSgtWVcYJX2FXLOJEmABGP9rocfSi5JbjY5KoCCTxzjFTBZQrYY sc5JJoESbWfCPkjHQVItuVKgr+fNIZYMBAyE3gdST0qzbRK5USu5GMcZwPSgQ5rdLST74YEA 4AORkA+nvUcYGWePMgHGZRjI9QDQA2GJpXKK3nDk/IMY47mmeT5RVVKRqeD/ABNSAnNrjaYo Q7AHLSH+lSIxkXDybn5Pyr8poBDPI2NtKrbk4+bGT9fpSFBI+DE8si4Ad+ABSAfJtBw0uIiO PLGefwqNImZWdIdyHlnk5P1oEQzXIiUF5g+Dwg+UfnUf9s29sURJoIMtgeZIOD6Y9aaVxlhV 352lpJAOcDg57CpoojES+1YCo9jz+NAhZgMMGWSZWbIxwDjPJpsj7cZAij6ZBqbCHpEYoVmX Equ20OXG7gdh17elKoZUcvIMAcoF5pFESRscGCMt7MQMVJJO8yRhpQrISWEYyWJ9TQA2EiYY iiIYclmFMvmS6nDXNwxfjALcn0poGXobgTurSr5ipFsUyE9hwOKSGaVYYY2nL4JKIAAPfmgk gu2mWV0RVyvVm9KasaMv74+fI/zbc5OO9MCSCNriLdBCLcAnIZRg4qO8S3Mu5gyyMN3kBiB1 qREU8UsDiPYlvMcMGB3DGOOR170hiARftMpmbOd3TmhiPpyeXcMjpVNuT/jX2AiN89utVXYf MCeRUsaIkmIfg5q6moBgNzY56ZrCQ2XhqkaxcsD9KyNT1CKaBhvHfgVzWBI4bUArlhWDOoJP H5UjZDBIVOOlVbofMc9e1ZspFYoqjnmoNgbJU5rNlFJ0zIRjHPNRTP5QPHI7UirmU7eaxOP1 qhdR7X4OP61kxlbyTnrmlEZUBh29qkCyNQeVDG3Axgdqj+xM/IBIHNVuMgkhUjHQiomgGzg5 qAIjBtGaq3D7TxSYys+5hnJAp1umc8UkUTPEBgnmodoDZGKYyWOfZjmlNwWOMfjQIlQrjJFJ M6kDAxQBVZRmo51OMikBFZgbxuGeeK/VbwVcC58K6TKDkPaxtn1yortwu7Oat0NxwCOlV2wc 13nIREc1XnyD1/CrQjPnJ61z+pNukalIaOcvz6881zt/cXAuJGMEcdkkYLSM+WZicYAxwPx7 1iUc07wXU4AhVWHz5Zc47de1Y+rTrACiDcx9egqGNHF6oXlckksc/lXK6koGVHzMfSsGWctq WIM4wX/lXK6nlvvEknvWbGYF0vOKyr8EkBRxismUjCushSB+de32ehIn7KVzJIoEk1yJ0yO/ 2hUH6Cuaoy0eIW1icgYwa2rWxLsA2Bx2FQgZuWdhsIITKnv7VuQ2yADauF7etBJqW8Cow28n +taESFwAqsSo6Y6CgC7b2sr8lTtJwOwPtV1bJomDMuAe2f0p2JNWwtN7FVCqW4JdgF/EmpI4 SSRs3r3B4xRcLErWpDDAyv8As9qnlVgQqzbk24+cYxnkj25JpAQqBGzYDEjrv/wqaIrLIigs SRjYgOPxpoRYy0s6HcsTqAAp+ZuOlSPZB3ASPExYE+YeoqQIxCrRv5gkeTdgbAQme3NN8gqd rwLasOdzYLN9KYhUj3gMiyNcJyJCSoH40nkbI2+0ThI17xHBH5UgRLBAklu5jjyOAJH5JpJb f7Op/eickHMS44+tSMIbeZCxijjhjVOdwzUctssuSm+eTGD2XFUIztW8Nw61HH9phii8s/u1 bjb647+lU7Lw5ZWc6iCyTzUOBIq8VSfQRsujIAJMRKBgFDnNSTqnkqwhaUScbzUgCWrmMh5N kPUKMZP1psMYZSYYgxz1b0oYhbYNA4LToHXIwvOPpTZ1JXekeWfB3MOp9aQwe2UrtkkkUHnI 44oMSyZZYCQFwH6euM0ASvutLe3aS6LYbaYo1IYD69MGokjZbVoYbUS4ferMgZwPTd9KYDYb U+XPJLMgSNctGXwT9K19PtIbm406G3U4+Zpjcjy1x2IbPNSIqQkfaZUkcSdfl6g9qUwqYNkU ahQflPdfX86AK0duVJ8+TaU5weB9B70TiWWeNY7d5GYHL44C9sGgRDcWq25Ek0xlRuCv909w DT0idIpmRI1GVO1wdzZ9KGI+jiQwx2qNwvQda+vIRFOu1OuM1nyQd92PWoZoiIqqxnPbvWPf XThiIyQBWMiiW2Z3j+ZjVW9D7mweCKzaBIx7iJlzu/OqP2QkFiOPU1kzRFWWIIxJHArMnnDy EDGB6VDGiGVtwCjge9NjURgkmsiiqzoZCQOvrWXqsioTg5/GkxmdG21TmqdwhaQNnIzWbRRd htoVi3u2SB3qhNLGAfLbcPak1YZAjbuxq/DqSww7SOaSdhmc0u5ycYyaQPvIFSBI7gr05rNu FDudooYyMQkkDFL5JToKVrAiVbSRl3PkDtUMkPzYHX1pFJiNbkDimFCv1oGPG4rgVEysMgUM CFlYc0wyNtweaEIfBtOcda/Ub4XSef8AD/w43XOnwH/xwV2YbSTOetsjqXqs/Br0EcREPmao ZiRmtFsMzZ8cjpXPahxIwFTLYEc/fEfMW+VRyTWFeSpb6e85YvEIy7FhnIHPSsikcnc20106 ukrx25wxijQAscd2xn8sVzut3NvDMRJNGjE7RHuGazY0cxqR3ggHavoP61yWpMEyEPPOTXOz Q5LUFPpnNc1qHzGoYGHKhkdsduTmsjUCwYoB25NZMaMWSLzJVU9OpHrXuvjjUP7M+EXhLw9E wElxCt5OqdNhyV/NmP8A3zXPUKPMbbSsAHHJ7AVrWunADLDPseKyA1LPS22grgr1255rZs9L 83bkL2OO9MDRg0o5GSqqfQc10Vjo0aIZMbm25GR/nHc1S1EWzpiBQ74bn7nTt1pi2/DbGBGO mD0z2/Ok2gLJiYOsihYygA9Cw9cetOWLcQAGZzgkngVFwJ47aaRtiYD9CiDJPvUxtkSMKdob gsW6g/WmIJrd58Fy0lwzZLkcNnrk0C1LEo0gRs/Ko4ovYQgUwyriNYf7zPySfarsdq99exAR yPOG2q2SFY8fxdP/ANdDAdOBHFJK9zDEgYR+VGCX6deAVwMdzTEtS8ZdV85g4XMxy5z0wOmP xpAT6hpMlvqD2NxP9mdI97W8w2tuxkDAB65GPrUNqiZR0t/mUEyCbaFGOPlo3AhIj3BWZpgO XGMDrU9wEdg1pFDph2YL8kuRzn8R1xQIYohkL7PNe6kAG2NsKRnnn04omt38/wCacWruclV5 OfWgRHcRQoQqxyyP0WQjjNN8h0V0dgzFsBU5OP500A1IhBtMCGSLb1boB15qS+lPkJvmURqc 7IzxTAhtIIJYDLbxM7g/fkyaVoTKSzt5AGchQOaQmRsEkI8uItIG4c8UrCYvClxIA3X9yM8e 9Aye71B76YSbTK4VVBVQBgAD88CqvlyeSWmlIiDY3k4wT2oEOaYfZSkUZuACOWJ/l0PXrU0Y ISN5LlFV8nyolJYY9aBGeTFKzmJTvU960k8y5WNWfc6gDaTyAKVhkv8AZaR3bxqV+0Yxgngg j16Um11QwBlDnG9UGc46YNBJK8em2kAlKTNI6kOxOQDnBxzVS1eQHfHcCO33fID1oZSHSafE LAtBMZ5POGbYp83PGf0/lWbf2l7Z3hgkDWUkbfPFINpH4H8KQj6RdTGMHHTiq0SSM3Tivrmy BtxkA57VlTTY+8fpUMtFWW7HlsOp96zirOd3YnNYsouRfKmc1nXN1lyKT2GjNvbpQQPWoRco sQO4baxYzNuZ0mUgHrWQtq8swVAefSsmWbdt4Wd03seayPEGmvp/IOR6VmCZz6SODzk8+lRX VqJjlun61JZSey2HjmmCFQcEUihssIMJGcVnwWQAIJ4JqXqMSWDys46HvUWAxA4zU2GNlt2L jmp7W1B6mkAXECJHwMVmsdh5GRQMmWVCoyMUK4ByAPpQIWe4YpgCqmfm5IqWUidVBWoJE3PT Ak+zlRnNQiPL0WGJcW5AzwPWqzwl1pAMs02SAHnmv09+EDB/hn4Yf1023JA7fu1rrw/xM5q2 x2Ln5TVcgc16JxkWDk1BOMZJrSIzPuFBFc9qS4djj8aiQHO36pIGSRQ6NwwI4xXPa/LHBptx K8bPGkZVljUsxHoAOaxuUfP9zqXjfX9dtbB5W07RxMGeS3QRb17AtIWbJ9AvPqK7W+0+3swx jRIkbrgck/1qJDRy2rODkKMJ6DvXO3dqogZnz83C1hItHI6ooSI7e5wPeuXu4OGZvlBP4ms2 Mxbhi3yIMLn86wNanW1PIyxrNjRj6NHJe34AO52YYA9a9j8TxnVtWijX5obaGK1iCjJ2ooA/ Pk/jXNU0KK8nhq50u9NrdxmKVQCyE5wCAR09QR+dXrbSo5WG7IwOW7fSskI3NG0iznvGW5aS KAISChAJPpkjFTCyETs0WQCxCqRltvYmncZcitvLVuBnGTuq7Zo0oO0npwOam4FyCMy8sd/P C+tWhYOnDr5ZAyAaTEOEDSS7/LLSDAJZumBx/KrDW4m2cbpSM/LwDRcCwkJDGNiIJlPCgcn8 aQxK7kNH85yWkc4GapCJGtyrgSEtkblEff60kkHkqFdVhyMhyRxz1pCLE9tYiGaYSSMAFWOO Q7pGOPmPCgbc59+nWqUclzGhZ5CscZyETqRj0oAWzhaSI+ShEap5jCUhQpzjAHrjFXY7MMMk mZNhZoiduBjrUgVJo7mWLdaKsUbcYYDeRjnk1DBbLfy7og91Ivy+UpJJ49OlNAWUUzAwSq1o I4yp3EFgR+HT2qARRRuYg0ksq5bc3APsKpEl6KB0XdPOloCpCoBy3+c1DDbwmZgqyTOO7oQD TAZLbSgHfLsi35CA8imwhIJWe1RhLvLGV+QCOmMUAVk06ZiZJLphEeDEo2qakjhhQyx28b7l PylxgH3oYiW3eaMhZrhY5fvCNR296tYUTbUifDc5PKqD9etICtcCRnRXQRpgDdGMDPrUV/Fb wukQzcK2R5qEjBxyPpmgCC186BvMVhGi9MdaikJtdjRwvcAZbCrng07AEa3Wo3MbkGBiAoiD DPHAqVLm2tJR+686dGw6duvfHSmIljVrtnMdrDBuZiS4JKL2xzz1zz3FVnlt7G5KESSSH7su MY564/p70gNqUteXMga5jlfylRDEnXJzwcdf1qleQTabFG85QQyEgFWBJI45HUdakBimcWkr 2sKyQMAryMuduT+lVhDHBMrPKXbhto7Gk3oMsfanZ2lgcRzluRnn60k7wz2l2t5GLu9kwVuZ GJZPXvz6c1IHvjS+YOcU37SIgcDivr2zJFG6m83knjvWZOgP0rJmiKT243E9qhuJPLGBUtFX IWncgAfd9BVW5dEiZiMmk9gRzmoOzOCDVN5mKhOwrBstDVB571NbTrby5OD3z6VDVxmj/wAJ DIy7V6jv3rJvZ2vXxKd3tUJAjKubcKSVHA7VFDbC4BBBIxRYu5nXiiGUgZxVF+Tu6VlYoqzy FwVBNVlZwR1NIobcO7gcYHQU2OGRAWI/+tUtAhyHc3PaiRmT5gcCoGG4SqMnn2qoYQ7srEfh TGNe2VAQrfQGoFJz6n3pCJovmOGGRTZ4SG3dvSkURruxgE4qRF2tk80ASOCRkc+mapOWDY70 2CLSW5mUBu9Tx2OxTnB+lJDM9oP3p28elfpR8FJTN8LPCzk7mOnQZPv5a5rqw/xnPWVoncPw Oagr0TjGd6gn71otgM64Fc5qZG5qiQI52+HXaMk+przPxX8QdA0fWLnTp9Vhi1G0hMs8BbGx CpbJJGOgP6etYMo+Ornx54o+K+v6fpPhtV0YSXnnR/ZsH7PyC08rdCcAgK3rgDpX1HdxyRxo skpmkCgF2AG4468VDKMC8ty5BI+U1zuqlQ7GQ7UAwF6ZrGRSOO1ScO7FYxn36CuZvVLtlznm oGYWoFbfJHHpXH64/nTDnJ2is2M6L4X+GZdRv5b90ZLW2HysV4kk7KPp1P0A716xYaPa+b5l 4koXOCsXDfXmuWe4JmvqcWn3dqq2lsRMGybiQAOeOh55zVS30tnjd0RiE5ZsEqO3PpzUATx2 od1xx7Vo2yjy9jZHXgc0gLEEKxGQruRmG1ueCPf9KbHGjuEUEse5OKVhmhsSJUXo39yPnFa1 nlowrL5a5OCwy3sealjHRQRsSW+djyQwwKfJ5itNHMRHI/yt8gZ+D2PUdOoqQHw6ezShBEQ+ doLjknNNnWG5QtJIZZEIQIcjAweRxggY+vNNEkkFpIs8MbSR2sZzgscZ9smq9sqMwnjje5Lc gkABcd+f5UxCxwxNdGd5FkRwf9HVtqjA5APXPfioGsvJtUktRuRjtPmElsDvn86YE6XSiH7o kYFWZEUFsqDjnsOf5VduZnuLm4uGCsDGUBkcs8ffOenr7UrBcq3UUKOFQtcHZhd/Uqe4qSyk eBIw+2NI84jU7GYH1YDOaYjJiu0hkUSRm5ct16/nWxafbDbSLI1ojTkoBLHulUeq5GB9aHpq Iq3VysOoT/Z45bpDhAbshiOOmPTNWoGumEU10Ee35DRltue3bnANUBWhhWJEltrZpYnPHycE 55wTUU1vPgyGVIsDcYlOMDucUAK0ioMxwefJxu3dPypIxJeurSSeVtGCoG3P9aBFeSWBrsoI pGmRcBugNGLsw/PKtvF3z1NOwE0xWMwvIHcOv7tVXCkc8/pVe8dzFCyq8eWPmDAwF7f1pWEQ J9nWFmNyXlU5MTHmnSPcBsWJaCdT85bpsPp9f61VguJcyxS72kd3vw27cigLs/Dv0qVxcR7U EKwbwCxYfeGMjOPrQIz0Ro3QXUrxENn5W4xU+oRC0u4oRCJTcKGjKncHzxx6H2pAGySxnYvL 5SRkny8c49KkwjeXJbxLsJ6Y4H4VLKHXiSSBfnMfIbYGwv5VLpRsL3zBcTPbyJGfLZULBm9P b61AERjaQ/vcW4L48xlJ4oUQJYXDSpPNIGVUlXGwH0bj0BpAe5CZSOGBxVeS5Tpnn0r68hFW V2PGeDUZVSh7moZRTlYDJJ6VnXUiyNkcVmNCIVEYO4Gsi/ukJK55xwKiTKS1Mm5lVlPXIqh5 wzg1iWPDg9+ahkUhi3b0pDIy7A/LwP51FJcbTUtjKzSs5/pR9mdVyB1OeDUgQSWsZVi3B+tZ ksSruGQfrUMpEMVvGDyR/OpQIhjPze1SyhHgiILrg/hWZe3iIuAKhspIrwurRhv4qbLcYQgD H1qQKZmdGPYGiMlmOOD9akZK6ED5uM1VAJkOD9KYEpkEYyTThdRnr+VIaFWVOQvSnlkK8Yqk IiL7PcVAz7WB70MCdLjaBnkU5L88jtUjAop6Nkmv0N/Z5mE/wi8NEZJW0CHPqCR/SurDfH8j Gt8J6Q5yOaiPSvROEj29arzjGa0WwGdOODXjP7QPxi0/4J+E31i8tZ7+5nk8izs4QR5smM4L YIUAAnP5A1E9ENHxT4m/aE+Ifxnn+zzeCdbXQY8sLLw6J0+0ZxhZ5Qrbl4PAC5z9CL1h8Khd +H2k16zh8LaheKEFmmVlSIthS+8nBYjnPPTAHSudeZoz0z4bfBfS/AepQ6nYNnEGCXyGLMOv YYwT1Gfeu1vWw4JUtnnrUsSOb1a6faQuFHTiuR1DLk5wfc1gy0c7ew4PPPrisDU0WMFiRSYj jNZmIfGOR2q/4I+EHiH4imS5s4BFpkT7Z7+ZgqJgZIHqcenrzismUerabpEdjZ29pEjJb26b I4geFGc/qck/WtOKxc4xkkDIBX865L9QHrp+3b6kbqtC4/s+0ujLd/ZY5gPNDPsRsHI3dvek tRmG3i7SrgkW9w2oSZ+9p1s06/QlV2j86q2+o6/qM8cdjoKWEBYBrjVLgKQO58uMOT+Yo5bb gW5PB2uX9yxvtcuIBs+eDTYVhXBXj5m3t0PUEH0wav8AhnwBpumagk8aO9+48s3V3cM8hHoX duBxQ3poO/Q6donnUMkexgeXPU1rJaRyWcKnc7hycBSCF4y2cYI7deKwYzSWK1lFzFZqbtri QRQwOjNcxoOdwI+XJ6d/pS37R31vNeRTDyIlW2t4r6TdcKvByNoAwCT+vFT1Ap2lmJYbmWR1 nW3TG0yhWyTgFVzlsegz71VSFvOeKcmCEA4KAZBxx196oTIfJ+z/AMLXqN1mY/oOKa5+zIDP iO1HPlIPmP1x/WrEVtPDyZksos25zhpDyreuKsSTLdX3mXNwbtgogALEFADnAA49RyCOTTEO vYr69aE26rD5KiJcgAlRk9O/XrTR5EjlhulkdiVjU5Uex9qQixLcPdiHEYtTCDlvT6elMv5o biCW4khluL+aQMLsyYHAxsxwPzFAFOe2uIoo8yQ20bE8jls/WtXT7G2hu0E92WjjQN58K7sE 8gZP1pvYRQu4rlJ4nBwsyZdcZ24J5zk9qmM0casEjkvJFAOAeFGefrVCH2peWOU7zZwkfMqk Bh9KqTvbsA0JaWRGxuYDcw/nSAW4W4aIq+y0J4Qk4LfXNRW0UFuHSZnmm9U5P1piEZptzRsg jV1/1gGCvp9abLapHayzzzC4VSqEI43DPQ7fT/63rQBHbmd4mWGB3XoJG6KP8ajlskBmaSQy xj7yK2eg7j6GmBEiwBT9itvmAyvmLkkURQT3SM+9U3DaTIMfhTEQtHBHCxSQvcxsQUXjj60h a7mkeS4dYEC/IGb5h0x060AW7UQpblZkM8yEY75z15J4xSXZmiuYzEEaNSNpVenv7GpBFW7t kg/fBvtTYBba3TPP6Vc0ZftNwUt0AQKTucnCe+O+M0mMWawhFpFPJeRy3W8g26Ak+x9OfSq6 XBEZSNArE4Py8+tQA4vmPEzeYw7k4wKZeXyixS3D/uiwYKD3HrSsM9b3uik7qpyXDM+RxX1d yUiZbw7cHr6io21IkntjjiobLRRlujITkZ71Qnlck8HFZspIiMzhCves+7w3JOW9KzZSKTJx jrxUBtd+CD/9epYxfI2jnrUsFqZucUAQ39sbY/dxx3rJWF5XCp8xJ4rJ7lLY7Dw/4D+2FXnc jI+7mrPiXw4NJtdqoXA7+lVy6XMee8rHm2on52AHOTmsqRGLDnrWLOhEb5T5icUgcHHOahjH vdJEhAPPpmsydFuHPGPpWZZHHFsIA/OpHg3Ad8UxFKW1fdkUR28gOcZFL1GTysAgDdarRxZD djQgKk+ckdaiVM4zxSGTxkKBzT8MTQAjSEDHegMGIzTETFQI/wAOtVM/N1qWO9jQt4vMxg1+ gv7Nmf8AhUOgZOT5TdP+ujCuvD/H8jCr8J6gTiomOK9E4xnTNV5zxWq2EZ9xgKa5jXbSG+R4 riGOeI4ykihh+RrOY0Yd2gUDA59BXl95pYvdavRNYecEAYEgHcwOVGTx2GPwrDqUV9NsZNGs HF66pI8h2IrcKvZR9AKzdSO9mI49M9azZSOT1PnIHNc5ebQSe1Zsq5zGpXShnCcn17VzGqSF s926AVDEUfC3gm/8d+KrLRrOM+fcybWcg7Y0H3nPsBk/p1NfS+tQxeGNJj8P6Vtg0m1RYS64 BcryxYjryTk+uTWUvhuF9bHB6l4m0TT4yEvRf3BO37Pp+biTOM4Kpkj6nA96jtdU1bUkaS30 KW1Q52SajIsYzjjKKS2PyNctu5e245vD+s6jGou9Za3TH+r06FY8Hv8AOdzH8xT7b4faWJ1l kt2vbjj99eO07fm5OPwqVpohc3Y6J9ENvEhXy1XoEUVctNMj+ySzgL5iOFVGGSeOfoKQXHvC ss7MiCAH5xCGO3H/AAI80+DTftsscUaiKVmATjcSSeBUNjNS0aztLe6P2OOeSX90q3JYyQjg 7l4A59atXV1DNbyeXI4sokEcNvdTZdGY5ZkC4yMg9fWosUZalWPlgbFU43jv70kcImKQ7jM7 MNoQd6LCuXroSQQpayRRwtCxd3jA3+6sT6VSvZPPSNJoGvrpmaY3BJLMCcHLHg9Cfzp2sIEt mlkjiubhbSzYgFsEhB6kDkmlu5X+0CeO286GRyqzGHZHIFPOBjH6UxC+W8Lr5ko2YDLbwRjH 4470/RdMtruW4uNx0+CIE+aqiVlbPA25HB9e1MRBdRw3kFqzN5V8uVeUSZzkdAB06frUwsv9 BVLQCDaR8zY+b1596QFSdIPtrLMzecQFEIb86uRWtxcyS24jEYi3EDbkcew+nX2piK8sMTxn 7SJbnB2h/wCFOvf/AAp8VpdGMwWrMIpRtbngjII/WqASCOPTpZ0nmTzUUrlgXZsDG30Gc023 NztSWEfZUHTcBz9R6UCK1xGv2mWWd2lncmQogCg/QDiltbiO+eR4wttdooC/IW39sE9qYxJb MTyxNc3DtMgZ48H5QR2PtTLe4muZEhjtSCDtkYjkflQIhuLWWPzIr2dhA5DIgbPIHX+dRyyx 2Qijt4BMr9ZXBOfw6UxF5LXfbLJLcbF6sAu3Ht7/AFqoz2jOJIVdmYhSqKBnAxk/l196YEVw t9dbGWT7OykYCMAMfWmRQR28R84lmORndnJH9aTEQ2iQ3VzIJVEDoeG+9njgHt6VNqUKI6G5 KwF8FQvOcHtSGKkrgkpEzueQSvBH1pGtrmJw87L5UnJ5yDmi4DpYo7ZU+zQOHk6M5zx/Wkki e6nLeYYZFUALGuM1IFS7t0M6MGeG4BB3jjkfyovL+7v2RriFUTGxXVdqvj1x39TR0AbcRrpz vFezCZ9u5Xh+YDjIH0plwZrG3tzPbmMSr5iOAMMvrSGezrHvOPWoHs1iGcEnuK+psK5XjgEr Ec4pt7ZrENyckCpa0GmU1jBPI+tR3SAcKO9RYq5jXDMkh7YqlKGkcNnv2rNlXCS0LoecH64q OKIwg5+9UNDQOQwGetXLF40IDHApAx2upDOny4BArBSD7O28EEjv6VEtxouW/iy8SdI42Kjp 1rqLvXFv7ALMzOxGOP60J6GTjZpnl2rKq3EgUcZODWUzkn0rE6EQXLZAAqhLKwBwMY70iimz NI3J5qYSbV45I9KzZSGRSndk9+KuowbGSBSQA4RiMc0jqEXOeO2aGIpzqGbOai2gcA/WoKK0 6bDzUKJ5jegoQx8iBDx6VNbyCRSvQ1QiZrIkEkj6VE0KxrRYVyB5OMVEsZc+mKko0LRhCuT1 r71/ZWvftvwg0skYMcksfHtI3/1q6cP8ZjW+E9fc9KjIyK9Q4hozk1XnPykVa2EZ8+cE1z18 N0jZ7VnMaMK9TGcdfeuZuGKY2qCWGDIMYFYlHMauv7zLYO3oT159P0rmb/JJP14rJlI5fUTg t9K5TVCcN6HNZsZy18Oprm9QIBx61lJiPe/hZ4am8B+EpryFRH4l1RcSSFQzWkHVUXPG48M2 c4+UEZWmal4Cs9Rk83VBNqRB3BbiUlP++Bhf0rOUugr9TQs9Bs9PhRbWCG0gUf6uJAqgD2FX X0kExSKAVdcqdwweSBkZ46d652UMi09Tj5V3dwKna2RFxtCnONq1ICPDthcoCCDyzdx9PWqy LGzEMeWOdqnp+FIC2iXF/wCShJZo18qISH7q5JwM9uT+dVT5dyWUxNlSFBU4z61DQy0sBlix IwhA+XAOcZ9fypIgxd4WiJlQ8O3JX0pFELQs+Y5pDvDfeUdadEiLdRoxMKBSyyld3zAcDj1P H40wHX7h7gvOpaS6JbKKEUnPOAP5CrkM0toMGU20EsYjZkPLL1I+lAjNMEVqDLEjXTE/LvH3 uefx71emjkeGEvPFBCgwYnbByfQflTEIGdbQx2CmdN258nAyM4z+Z/OknP2SLMs6hX48hE3M TQIYkMMsObeEKU+Uq5yee4FOKRzopmnXzVHzop49se9SO42Gz3yFbSLzZVy5kYDgdc81PZXd xbs7TSmIyZ2PGwDYyRgEU7CKLEfPD9kJhdQEZwcqfX0pVijtVH2yR5VBBVFXgfWqAmtosblS FkVn6YGSD6VDdaVMls145WSDd5W4tghs+gPWpuBFLHEJG+yRPLnA3sMc4560lvbF43NxKsD5 xkLnd7U9gJhDDbMX+zhgyhVMhwTn2othMJSbhhDARuKhsNtHbjmqApO9taBLaSM3KK+7CjB5 9+vYUk5vfJVoExBjAVVBAGe5PNUSN+wp5TytO8pf/lmCPl/D8KLN0ihk8qNeeOoLbsZ6envS AjvrIzoiT3KbgnmeV0IH4daqw3EYhAhiEp7uB0+ooESmyuLiGJ5QIIWJ+YAKePWi4nswI4Ej N6Bls55B9jSGTWksluYZUVCuclGXdn2NV0i8ieV0YSwO2WRhkrnnApAXZZmu0EkI+VD9wLjb 64FQM4lkeRsptOUTdyKhgFpb/bHmd4gSgJZnPb1qlPHNKkMMs2YVORHnGKYyOa6W18y2Cjym /gwGOByOTUSEuySOgkjx/qG6YPp6UCPYo90bZIzTXbecGvrCRjEQLnH4Vj3GpmSYj+H0qGUW IVDDOevSqs6YapZSMy8i+brVUQnfmsShsmVJHSoirH6VJSKspEZOenao1uMMDkHvis2xoZNc 7mwTk+lQiQvwf0qGxkMsQRtygZBzkVHLfS7SpchewqB2Mm7bzASevrWcUbdjmoZSGyqo4JFU LhQ2QtSMrC3LN71MluO4oY0DWwUccGopI2I+XtUMZLFCduTzjpVS6mYttpMCq7n160scm30q BhOAwyaq/dORSGBBk6mmpE4bg1Yi/AXYbScfWkmUKfve1WIruFAwKAp2Z6VLHckjYhORX3V+ yE5PwitP+vibH03mujD/ABmdb4T29uRTG6V6RwEe78RUM3Q+laR2AzrlwPesS9wQSOM1lLUa OY1giKF2PmPkY2pyfwrn7tY0hgCKAu0Y+b196yZRzWpWzuiq7h2HUhcA1zl/EFz2rGTGjlNU +8exHrXH6tIke7cf1rFsop6Z4F1zxTJ/odm0VueTc3AKRgexPX8M16R4Z+EmmeGEW6mxqeod 5pV+WM/7C9vr1+lYt3JudXPatBsYYZXGfl/L+hqKaFkYMBviOcNjqOmaybERR2KMsrghTGuc ckMfSmrEY4/QMMFV9KzKQsenvJMogBkMnAVRk1Yu9Lmtr6JZ7XYzJnaD2HGc5PpmoGZkm3zG ClpJAeFXoKhmjfy90Q2ADJ5oAn8iykMjtcNPLFGrRhSV3OSMjpzjJ9Omc1HPGbmLd/x4DplV zzjtQBe0QWMEoa8hkvR5bIFBBPmEDBI7detVXaWRHFy6xTdAm7nFJ7FDrfEsfkrGzMfnDdhx VZo7R5Aly7LIrjdHGfnI7kY/zzQBfdZHBgYBIbY/uo5DlhkknH5c/WmkCKAyFBc/OBmQcAk8 YB60hD3aVLZYJG2W0LGQSKAMBvvDPXsPWqthaWbNLLK0roxBUiMuT7c9yKYiwryxvmSQQW6k gKTtO3sGHr0NV7q9iRSbBRd3Cn/WfeUZ/TpTQEyu72Ymlkjt1j4fYuGOen1qvGbSU5toZZm/ jDHaD6YPX1pWAtlpJQ6SOluhUgIe/uT61Fpt3BYz+X5XnzP8pKJncPWgBGe4E7u7MdjYXPTr kcVFNOoaSJYzPPM4Bdj8oH17UATPNcQIkqzLZGMGNxF9MctnvzWbb2iQ6gslmRISd4DruUnr 3pooLtLwRtIo8lWbOAOpzU1vJbLbzNJcbbhF+SJjuLkD9CaPQkzl1STUmRfKWGRAAC3UD+tS STWqzKt3dN5uBtVDjFOwrkkapsDLB5kjZA3jH0INNe3u7S4KXMo8qQDbtbAOcZpiGXkkdnIR DGHY4BZs4GKitzcTyPLAkcKr94OOgA6/SgCtLNCt6cFpZR97anBPt7VoXKzXLzoqR6ecHjGe ew/H1pAZ/wAswhS8dw6qVLtJwR2GKgilgs5HjWPBAyGPSmIljEzQyGWT7PGB8qKOD75NOaeH TZpCZBccAb053Ej1oYE5uZXg3xRmAdd2Ofp9KVTb6jJbqU8m7X5XcNgMe1Q0NFPU79rmd1O5 5z8u4tkHHpioZIpyVF2ogfjaScMRSKG2ttJJdbQnmKufn9DV5rUCMySMAVOCo7/Slck9Qmby WwefemIu457V9cTYZcIJODzWZPpyI2R1rNlIhlkMC4zxVF5XL5zn0rNlkcrtK2T+lV5GaPjG ahgQShnOeM1E0ojXBPNZMuxRuZvNPqKpPE6NkHIPPWoZa0I0LLKM8GrGec+tQBHPI2OBjtVW RMocgipAzpcK3b3qvcEBfT3qWUU5AH5JycVWMWGz1NQUSCMAZxzTW68UmwEI38UsaAAZ5qbj Gzvs6D61i3B3uSBjPpQCIVJ3AU91CkEHBqBkiqbjAzzioZrUxORVWuK5LbwbiQeD6094RH3p iFCsVOOlQTRPzwTVIBFt2IBxmrCwZTBGO9JoaIbhGjAwtfbv7Gtw0/wpCMciK8mVR6AkH+ZN bYf4zOr8J744wOKYRxXpnCRMMdarXhIjyvWmgMiWUMvA57j0rJvW6+lYsZgakN6YyOo6nt6V z13dLE5/dM6D5cJ/D7/SoYzBvbhbiaTpgcYFcJ4t8SafoQRby8htpJWCRxu43yMTgBV6sSSB gDvXPJlI1YPhTqGpsJL+7iso+pjjHmOR6dQB+tb+nfDPQNE2SxWYurlTkTXZ8xgfUDoD9BWD YmzSuE253ZYOOB3HPUfrWRexrBCdyMrvgqCCDjHX6GsWxEKxtHEsgBKjqWOeOlV/K3Sbo/mR jng8duagY0xNbeYQUIZdx29QM9v896qhZE2+TEQM9WpWGh10SjKUBkGPmPQA+lQLCxYMjIsR wOBzWbGLdQyIqz2oC9g4GPrVX5YIVacksV3hcZJzQtRiafbyzhriBoLRoEabNyMh8DOMYPJ9 DxSf2u12Le32RztB8/lnhD9e5pgSWlpeas2bfOIojJJFGh37V5bHp3qtZm21B5myfMhU/e+Y sfTAqRot3MSm1WSSUQkfwqcgcdMVXDkqIoI2FyyZE7AHBJ6/z60wZI7C5iSG+CsI8kiM7Wzx zxyalCmQeXDGsWwgguCT7sP60ATw27yXGx5vNluCIcltqdep7fjRqNleaZZxFEjgjIYCQsCp AYgnP8vagDFSzgiugm83iOg3Kctk4PrWpDFePAn2eFbeEncVJAK4GSCOlMRBLb2tpKL0AvMR jyi+f0qzpwmEpnihjXOWKjjHuPwpAV3it5JPM8xrl1bcUB4PqM1dgEfmGF1KQhQfNXG7P9O9 IZG0MX2idAjtbMfkMpBfA+nHNV4TPN5kLwEwg8ELyPcmpuLqQPaxWXlCcmdWOFRedp6fN6d+ tSq7rG/2SF2bOEZ2wsZz1x34zTKKt9aySoiX1000KNuKq3TPJIz/ACqGznjjj8iGJXaRQHcL 1/E/SqJKvlNqBZIpVXYwYyIhGOvX8adFpthLPGGYTyRDcWTlsZ6471RJbk+0CKS3kdbeGXo5 P3cdxVIiOLH2rN3CibEdent/WmA2e5mMYW3CwxY4GMmoI4HCyzvI7Qpgsf7pPagCBLyNZCYo 3K9gzZwfWob5Zr0hmcwr1CjgEikBJDaMmEnDyHOf3YyQKltY5ru5kTylQJ90MOaVwJJY40WR JJS7E4XHr9KZDcMHFqsaDbyGI56UARvb3JuJZXLNAoAyvRasx3FrYou2MOSMkAckUmBQSQ6r cKpAQKMJz2/pS3Zhik8tstJ0y3b8akY2LVLi0dIjvNoGLFVH54ptrLcQXTTrG8ke4tsl560m I9R8yS5YdqvoTHEAxANfWJiKN5erE2Cwz7VTkummI54xUPUrYpTliRmomIVSTg1AyEkhScdK qSynrmoZSGLJxmqskXmsWJxismWipcIQ2EHHaq8rsv3ulZlEb4K54NI0gwQOlSxDUk75OKrX k5YbV4PeoGjOkifPGTn0pk0LbTkc/wA6TRRUkgIGcfTI61H5LHnHy1DKInRyxAyQKEjJ+9x9 akYNH8w29amW3Khd3PtSsIhuIwee/pWdJbZJJ4B96AIvsilwV/GpE01pycHP4U0gJreyFs45 znvS6hbB03LjOe9VYRUGbaL5hyahVzLkmpGTWwLS5Y5UetX3RG6CmgIVADHjgUk10iNswc+t DGNmQSxDivsf9jUeX8O76MN92/fj/gCVrR+MyqfCfQZOFpjDivTOIY4ytV5k3qQf0oQGNeWr ZLA8j9RWFfNjj8etZsZz2pTDkkgD0rz3xb4lt9PaJWvY7V3f5PMcKH/2cHrnPbmsWBdl+Euq +L9PtZJ9fvfD6uCbi1sogkpPp5jcqcY421c8M/Abwt4MuIbq0sBd6jbrldQ1A+fOOSThm6HL HkY61jIObodTNbBcY7k89qz723aHdhS4bpjvXOwM26MspXd85I6nqPaqL2e2dS5xGRtJ6kVi xle4jEL+WxMinpxxzVZoI7FdshCIwBKo2cg89qlgUQjLKfJjLRtxvY4202aE25V5J/NickBV 65GP8e1A0K37mNlC+XG/97sagjj8gK8KNLuJyT0GDjkVmyrleYGG4Be5O09Y1XqTUQEoWT7F FugfJYNjKnjJ9unb0qQuUpIUjdZxILl2yksSA7kOOhPp06U27tbqKFJkEcLjH3uSR9apASsy TbLxC0t1HHsIBIATHHTr3/KpSkt4sTwyW1sxjA2xxbWyDzu6ZJHfntSGRKsFwf3alnh5CuOH OemMEc+/oasR2s14GtyRaPt4j38gfh0xQMsafahs+WihgpO6VMbiOgHrTY4ZLyVAySxytKUC wklh6AAdeh7UmMtyabcLpYna3kFvFNsPmkKwckdB+Xao9XtImkEU94bmxiTcqRjZhzxg+vag TM3TvNhZltYDIuAVZ+FxVkQCBGF3cqyocdf0471QEmyBAn2GHCYJ3uufwFTTJHFZIrgRyeaG 8zJ5X+7jNIDPjhiubg/Zo2L+ZtIJwM+v0q5qNhLcnyZXjSeNvmRGweO3HWi4CFZLf5RG32hk 3DeNvHqM9aht9TvEtGV7jy5JWKPtTA2465qAIftNrY6iZraMFo1UM0r78t06HrQLW5iu4Fgw zStvkViAOecDH40+gjLkFpBdTMkyMCxYp1x7c9u1IL+5uZxLbQpFbupDALgj3q0A2fRhDZm6 fU5pElbEtuh25A6A+tRxzxthraJoyMK2T1x0zTRJDdWy3aYupxG2cxIpyB/+ulsdQMbfZWhW aNVCSRpkbwDkfUjPeqAha4ke72sSkA+XZgDb19PwqFp7Sys5W81pZTkmAMecdM0hEVrulIuL OAxO46Hk8+1W30szTpNLIrXJ+cwswwcDk4pATWOo28HmRoFchcKwzwfQis9NSu3nRpH2SAkZ Ucn60WGhsgS2fZK4JPPXJP0pmmvOZnaK2xGTwZDnI9sUgJC01sjrJJkTHDxuBjGcjmnvJbJL LsjCzbuVXnH09qiwDYCJXyiqknUr0pZ1t5Z1SWYLMPmJHOeelIBPt2S0EMDlef3jj7p/wpFm ZUSOVGbJ5A4BFJgenwHyz260y6uw+VB5xX1uyEZptzKxZmweuaFQgY6VJQkhBIHWqhgLye1R ICK7mEKFcZJrPVTM3PSs2Uh7qpOxahuYwi9T+FZstO5myTKrcmqs8vmHaORWZSKr5HFRyOy4 x0FQxkQnbP8AhSDk5Oc1AyQL3xVlIYZofmHzAetAjOu/l+XH4elVZIiVAA4rNloI7cxgcZJ6 1HcrwVIxSsBXjt3wH464zVh0L8AflSGylIhVyD+VQTIWUgc1QiJIeMjJx1q5DIIs8daYipdS FyTnAHaoJWkdgc8elTcdirdOWXb+NQo/lpgdT3pDsTqGUAk81Lb3OGIY4pvQCYyrjg5z6U0p GzcjLfWlcC/aWTykKqEj1r66/ZFjNv4T1WMrjF7n/wAcWumirTTMajXLY+gM5HvSNwK7zkI2 IxVSWQAkZx9adxGJret2+nW0kszhVRdzd8D6da5y9sNc1AB7fT2ihb/ltdv5agf7oy2fYgfW s5aDRmt4HeZgdVvpZxyGhtMwIf8AgWS2fcMPpWz4d8IaVpmovdW2nW1rOwJMyRL5jnjq3WuR y1A6KSIC/uI8fKGBz35UH+tUtQgjAASMr8uPXcc96HqiTAuYcBlArMu4NjEFsduO9c7RSKC2 btGTGcdgc85xxgVmSwKgKzjeGbjjv/kismMgeMuRCQqByAGbnHPWqmr2LWN0YQwnXaDu6cHt U2GVkhKMqScqw4VR1+n61BbsfPWMR4WP7rSDIHXPFSMaZZVvZ5br96MhisYC89iMdKbqLyXm qbGCQxyDOeeT/jUMCrcp9ndYjGd7HawYYP1+tUSk9hcAySbFdeVUdj3zUgRR2htp2NvbmMcr 93nPvnqee9RyRxq/micMCuHV/nUj6UxoUrNHbLNaxRJETt8tk5246/So7K1iW8SZ5J7plXd5 IPCevHpQM0ZLaQvFcWUUKpJku/8Adx2NRRw2z6nHdRXEkd3C3zSREgA49fTFK9hlyW3kuIpm BZGCkoCfvHPfNI2omCa0uIoEh1K3UFZoTkk9d2ex9aQyvLqN5qXmvcy7Z9+8s5JwxPX8aIdL a9Lwh2ubggyOAdvAweM9egpgEbXEsJQqLa3yDy/Jp9nBDcTDBjbO5mx/EfX60rjHTfamvbdk dTCyFtqqcg+n1qtdy2qlPOLTspyQx6VIC+fOHxZQbEJAErDG01GulQQz/aPtQM5PzFWyc9M4 7iqQixdy6hqpj8ljNcoAm5jk49APSkvIWZGtdQdkmiT5ChG0kkZ3evGaQGDLq1r5i2sdqTkZ VycZ96deQuyKLqfyIzgpj7x/zmqEVNp0y7ELRlWiJbLAq5BwRmp5rm7vrz7RcvJHC6bNqjCp xwaaQhVaysWDIDPMg3EFvvcdcVX82bVi0tukUM0p+4xwHH+PSmkJkMsAimEN02bhSOABwfSp EucyN5SgyEYUEdPencRlpY3f22RZzIWc4CKM59xVlZrKxMkRia7kZsE4AC/U0DHpBeXANzZr Fb20G3IBy4OcdfSqBswkkkgnyyNllY5ODQIejPdREQQOX5/eY+WmzJPeq1xdTFGBALsu0ZFB SIZHtIbgI/zynkMnQfjVmzvbi1iYFQElB259j1FSIYQbiMl8NuOcH/CpvMitQywW5nnYDErn aEx7d6ljK0ETXUeQyrIueFFKtvAXc8+cMZPrQBNPPNekw7JFwP8AWEdabBZyoyxzvsVejMOg 9aTEekXKt5ZVTg+maitrIqjSSd+BmvqWJEbIVbjnFEbBjjFCGhBAC2SaSdUTnpUsZi337yRj iqynYCo4YjisikI8q20RY9aybm8MmcNnNZyKRVY+apyOaRVCLz1rMohlcY+XrVTlm9BUMaIh kNnBqWIc/N+VZjJsqiEgZNZyz5kY880FWJlYSnkc9KcVzmkCI3wg5PHtVdpBLIBjFJjGsxU7 emelDybV+TrioGUHRmPJGfeo5I3RckcetAAkhWPbt/Gl4cDHWmIhcDPWkI+XgcVDKKF3ARzR YxGR9u3PalHVjexriOC2j/ectjGDWPcQCaXMY4raSuZIkihaEYPNOSN3kVtpK59aVizuNEuV jiCvHz64r6c/Zdukn0fVxGB8lyM/io/wrsp7pHHJHuppJ5o4kLSOqL6scV1PQyKgkeZhsUhD /E/y/p1pHgUkEjcx9elYuXRCGwSG3Z2RFBPUADmo7vUZLqLZwozjCDrWEpMDHuTG2QAc5wxP XNWbOMNKpAypbr6ZFZJ6jLVwhbVZQMcqh4/3VH9Kq34A2ADO0kn39q0ZJizATzAPzk5x61i3 hRpWCqR6D+dYsoyrojy+WAYdAvPOfWqcao8rmZgmAdhx1btWLQ0Uo089SZX3R78FRjcDjj+Z qm8gl4YeVt+Xr1pDGXt08sS2yb5kjwQW4AOP881ScRvKq3U4jJ5XYcY9iKkBpmMsihFjIQlT JjGecg461SnkjjmkM2Wbqi5znBHP61mxj5EvBNFLcwNDazHcspIA9/1rJuLqO1KCNvNyOZWJ z1OKVhjrxJY4P9JYLGxLFixJb3/Wq+miK0nkhRHfzOcngJxwSPypALNB+7mSe4LFyAgLDGfT H0qRPL0nPkWw2SKAJRhR6Uxlm2vI7eEzPcvapImHiQ4yOhH09qLJkl3SWVthHH8RxkE8HmpY zQ/s6O4vbdJ7tpAwLOIsMw45AFR20nmPGkMf7pTteVVBfjPSpYyGeKHU55BdYQyBESSR9m3B 6YHf2NJPcpJE4iiE6RnyYpASvQd80DKCK9y229uYkm3DYoGRGB0B+v8AWnfbvKjleBWub55A cgYCDoTigC5cXc5IklnNn5cQGIgw8xv73sax3vYrGzkhtbOS7DkSFsZDYznB9RmkgLpE09ha yJIYkd/ngAJ/Gqls9lbyq8LNJKxK5ZScn0qkIfqP2qaKM20pgTqwjypHXgmkjBtLeWKUb5nA X5hvOeuQe3HeqEZlxJHe7E8lchiCR94Cr934ftIILaTUtSZIriTCOzbimBnoKQFCW8QC7NtF NfBTsjujGQMdMk9uKykhuVy0ju4kGDIW6+lUhE261iRlhXzZANoPOIz6Z796YyT3iiTzPKZE EaqeMfT0qhDHS1tXAW4WS4Ay2c4J+tWdI1SCW68iaNpFCEB4/lIPbkikBUSec3LG5MsOfukt yPfNJeanbxhbdbczDO4yZ+bPcnj6UAWbe0upd/8ApBhtyARg46VTkgjtmeSJzO7DJY1NwJ59 RuZLIJBF5ceMF14OR6VW+ytICt3JIrk7tjt8v5UhkBW2dvKMe5o/ukDippUvAAhURW7A7eAT x/KmhFewh+xT7rkCSM8Z3c/WtG4mt7S+t/OUPYvHvzDjeD2BBpMaGR2Yn3TibZakkgOORz/O hpreBxIsglKsNoC1IE6X7zRuyoVTOMkVDvQTIbwboycZpCO/WYtMGfgZ5FXWdZF9BivqE7iK xt2ZyvY1UuwtqQMfN7Ux9RsRLZJ4qvfnYKTGjPaQRDL1mF982/nArKRaGXmJk67vp2rPitWZ sn7vrWTKQ6by4jjjFVpQznjpUBcRo1VcNgelVZMAnA/KpZSIOvbio52wB+VZlEDySRADPWow Q3NIZLCrMMjj3qbLYJ9KAKck24kU6KLdhgM47VNhiTpvcY4pjRshyDU2Aja1LOCWx64qeUIY wP596WwyB/LRcECnwz2wTDcH3FNNCM+aMPM23pnNOhiDyAE8VNrsq5XvI1yVXv0q5pellF3H hjzjFXFakSeh2Xhv4O6341QXEESW9ln/AI+J+Fb6Dqa66L9me6ityV1WN5Ov+qOP51108PKX vNnNKso6JHAeMvAd54Ib/TUDxE7RMnQmuSivg0gWJN3PpWVRckuVm0HzxubFxNcw2JbZtyM/ SvpH9jG7Mvh7xJ5hy63cRP0KHFVB2miJfAz6TVy3RTn3p3kFypYjOOBjpWkp3OcGj8vHr6+9 QyL6jJ7VFySqcke/vVNz5co2/Mc/wjrWcgRRuGUSyFlLh8HPcVYsm8o4I+UgFSKhblGnf5+2 Rsp5+zKfcjc3+ArOu1BDD0rZkMwbkEBjgqw6c1lTRGSMjlXHb1rJgZVxb7MkKOhHzCqctugj jLsS7Nn5R0Tp/P8AlWTQyqQ20GFAGJ/j4J571KtlAovUcgtJGWjfue4X68VJRkmC7vgYSBFK jH5WHPHX/wDVWZJaRTWm+CJnm5GWOAMHnNQMbNbutu0kkyRSAL8vU4xyKSxj3gKihRICDKeC RUsEVTczX0ZtbyZ2hTKImeM5BI/MA1SIM++3S3jST5fKkbnbzzms+pQXtmbV57W9SQXkXyzM /AyeQQO3BqlaZWHZcOYsKQWJ5Pt/SgRHawGG6bLCYjJjjGSRjHJPpjHNPkj1S4ib7SdkO7Ak jx8h69PpTQySSWzSGK3k/wBIfHlhsHJPJ7fXvXQ6O9tbQSRtbxxRC3k2TSyHJZsEEqM8gZ4p DMWCeOBoHQlizYUAcnHOcelad59p1G9FxEjW9tJgmEHgcfrUMoq3MVjFcSyJA00qbXYAjO7H J+lLbCGY+Y6xyJLy6RuVZCPwxmgZR8q1hjmSSZbiX7ruTnjOQMjv2qWF5ryFPs25QuQWOOPa mBZj0mS5uoYr64W0ili3pI0mRgdfx9qghnMa3EZhjjW2b925Yljjo4x0BNIW4tpIbAx3c85j ZP3gEfZs9R6jmmsLO3EflpPJfvM7yMcbCjc8+/NUBDdab5SDUZbsIwIH2Zc5J9f51RfVINJc GGF5JmOGhdsYFMRFE7ahGslqsNrO7EnGSR+HSqqwWumO8t3It3cAsyrKN4GRz0p+QifTzdnT Hs7efy4ZzgqpIPT/APVWdbRT2FxKl622MA45z9aAuVzrtvDHIqW7SwOwzIep/CraaNcnTpLp ry3hstwDPvAcc4xjvTRLM24s7aKQzWhaQLy4Cn2zirCzXN9EI4F8jaN5Pdh2+hoAWMRSyEXk +4gA71bIGeMGobua1lBiggYBW/1nTFIZaltJDB84VEAwfn49jWVE5sXASXzwGPA6H2qRlm7v L2SdGiUwxLzyvH51JJBb3Wmm5nu0d4yT5JX58+3PNMW5WjnSd0eC3YY7E9aLsX2oxYKsiE/K pBAx6UgH6esMUhinK8L0PWkuNRW8dlW3AUgKC/JAoADZHYjvceXCmSy4zUzW0FrbteJIXRTt wBg9OmKQxBcTX6L9nVgu35kHY06KJbhJDOxiCMMg+tSB3ipk5xznpUqy4yO1fUJCLdsxlAIB 9+KhuLdZiS1WBWaNVbg8VjXjZmbnIHpWchoy72UtKEB4xUToQiqvX1FZM0JIIdsbbutVJ5RE xGQAehqXoJGbOBKSQRSx8JzWTKK1/nKgVSdmj4P4VLLWxE0mzGKYpkd+cYFQxk7J5oAHXtio 7q3Kp7jvUjKwmMS8H9KsQXoKE4570hlSUF3yB1PQU9JDGOeMUXEMkuFBB4qQSrJHnpUjEHzI Spqj5haY7+AOKllDLnHJVuKpFs55qRFmEhU96Y05RuDg9OKu4h1qrPNudWIBz0611fhFP7e8 TabpMYIa5mWI+ynr+lXBX0M5M+w72yg0uG3020jWGCBAioowABUkUZRBgcV7nkjyrnlfx8sI Z/A2oM67mVdyn0IPBr5k0bTZNvmAAnNefiFeaZ3UZWhY2rqGW+jWJQcjg8V9D/siWZsbDxNG w2HzYCfyasI/EU37tj6YtVyinJbOeanZG2g9KZiRFS3XJ571FOpVRxxmkQyqyYB5PXNUHjyS OuR2qWCKTR7LhkbJx0FTLJztZQDnjj8qlblF+4QytatkgmJlyfY//XqvMm6IoE3SHgc1oyTF v0BjDdu5rInjRXzIrhMqSQOcH0FZDM2+2spwx27txBH+fSsmTLHKRDAwdx/KoYCTWxlG5WC4 TeQTwMHnFVZJHikSSJVXLA7m6fXis2UipehLO6DCcygHLTAEAg9fl69c1XuJoJmle1gVSzfP J9OhA96kZQvIk8xZmIecrtKjgHB9KbdGaciZGWOMIMoVzx68fWpYFC4kWCd4hGZ5d25jng+4 qbUdNaa+jLXYjhWPGYWADZ/rWYzJeC3lkAhdWcyCORpHJyuevHUfTmi5s0nhkEsp+1R4wyHI C9wRimBaW9l1SZvscUGnzJH5W+3i27xg56daybtoXiEJFykiIGlaWTJd++ABx9KlblF+K8ge zhi8pV+QZRl+YYOM/lToo0tnuBcXIWFmwmeDj3x0pjJtNvrOK/W2cPcAg+X5CgEHtye1Rahd Xdx5UVzF9mEfoSC2T3qRla3u7fSVJtrUu4BDSyNwfbHvVmRZLiFgFhggJDMFONtOwIej2VpJ BLbIlwz7mMagnJHr602Vrm9jluCBbwsSpt/bsfwpBcq2kMUPlCWJ5p2zhN2Rx3/HFJLLPfM4 UpG7rhFC8gds/pT6gUlsbLT7ZrW/lea+uDuSQksIQDyPYVLcXN5ZajcWaql0YiESdSSpG3Ix xz1/SnuK5TGn3tjf/wCmZkFyA28g5APpUviTU3t9RLNELm5OFaaUZ3YGAfy4p9RFe3sptSRf LT7KqNkNG5Ax2zVa5sLc3UapM0s4lCbAuct6fpQBf1K2vblFWC2axAjInibO4Mf6EEEYrOvN MsIdKia5lm+1ISrxMeB1II+oxRcCpPfrIqwRwJbxjj5ueR3qb+zzN5azSBowp27iFBHU8d+9 PYQ2ORbVo2t5N65BBX/CrFtPe2N9HewoJowT+7kTKjIxzSAq3BgUTXFyv71nJMUZwrd+lEcp 1aQx28KwEpzlsbh6fWgBLrQ/KtoWnvPmyf3bdE9OTTdMlFoZd1sJ0C9B1z2xUoCK41K7kwzg pHja0YX9aJbK1t4Y7p59yA/cA+Y0wCymSeVXsN2Sckkfdp+p22pXmZWd0RTjYpx0749aHoBN pGnrcTMkkRNwchV9aqSTeTdGAxqk27ABHzZ7ikCJ30+bdmZtq47nioWljtkLRMsyr1UDrSGP /tm4dI5bNPspUbTgcn3qS0sY7mNppZJJHX5ivb60gPSY4ljj5GW9arNbMM896+oQi3BOlrAQ wz71DNdIFJzjPaqYGbJcqGxnqazrt1V2xyTzgdqylqUZDwkyFzjGc0TEhD2z6VBRGJW5JOQe 5rJvbpnmwORWbYFdCxcDkVYLhcZ5PSsy0Mfa2SearOiyMC3SoKK81srSfL0pIrfa/fHpUsdi wSlvk55NVGufMJz+HFSOxXaJXJXOB60G18s5XkVLAcg2Nk/qKWWPzQSCDQBUmtMAEnoKgEgR go9aRRZ+3JHGVA5PpWazbi2OM1LBDDFIwxyaWKxJbLDp2pWuI044Ylg2nAbtVjSfDJu5vPkD Mi5JYdBVsR10yaVYabny43OOg61sfs96Pb6v8TEu2jxHaQvMi4yN3QH9a3p2c4rzOSV1Fn0b dTGe+JPODUmWVsA/UV65xGP4q8Nw+JNIubOZcrKhU/iK+cbrwBe+FtQkt54iId3yShflYVy1 43tJG1OVtC3HoUdkvm5BZu+K97/Z90j+ztGvZ3TZLePG49SgJAOPrmuNG/Q9tt02AjLNtOf8 /rUpkB654NJkEe4oGIXIJyOeahdi+SR096ESV5Qckdjms2fCgjnJ70MCs+dmWB3diT3/AM5p 0I3AFwS6kcsOlZpAaP8Ar7a1foVkZQPXIB/pUV4pIwxwV4xjpWnQRiXMQlcIsZLNx68+tZF0 HlK78hcYGOdvtWTGzPlhW3RJUO9SxwWHJx7VmzQP8zgho167eMCoYIpIHvr5IY135G1cjge1 QSwNh42wAPmOOP8AP/16gooSTLZq22EzA9GIz/OpVi+x2Ul3PLEIHAURqOc5/wAms2BVWKO5 mdoFRgE3I83B9MfXmqXkfZrtA05CqQvljkNk8qfzqAI9ed0uE+xQrEET97vIHQ9hxjg9Oehr OZLeztVmuXM5cBvL3Y2mpKK6ESqlxBDHFE3BKdunrSRXEdnP9ognZpiChYckZHegZHfwzeWy JMYHAByrcjv2qq62slkwkWWTURINjLIFB46Yx+uaQE1pLLe2pbcsMqY2YGc88g5qJpLKVWR3 8yVmy20bip/HpTuUaS2s9hiCJ084nEi/xLjp7c5qAOWeW2uw02QWLO2CCO49f1pCKcuoM8ir Haqsb4G8gsSKuXDIlrDDfTwQRAEKVHzOPQ46j8OM0DIbXY0ZjsI5lkZvkV/lTHoffNLeWF8D E6/OWO3yh1Ixzx9aaAWXUY7SOGRFElwpMe5slo8euPr/ADqnHLc6xGzQyi3AGJGwBxn09OKE Af8AEudQsFw8twync+3747+9Kn9qanpc9lassEUeGDn77Y9DRtuIpWaSRh7bUZGeXbthfzdo Xkf/AF/zqX+14prGFViXzASAzfNvHqPfNVYCG082Jd9zIkcEpGwk4HXtVe5vbHTL5nS4LlJC SYgTyOnIotdgWr7VNSvLEzRfMrMrMVzlgOnNQT31u5SW4G+ZVA2ZHTtn8qloEVUWbWbowNYJ BkHY3TgfXrTrpYniEd48YcfcQclTRcCNGudOYxRWhkx/F0yfeqtzc30Eqec0jjI+VTxg0IBZ H0+2dJphI5ycRZyFNSr5Wrr5tvEY5VYDaOn1FN9xDL3S51lzdXAeX0Y8EdqsWWppZoYfLVpN 2BipeoFNdQlvbvy5H2ozfKZBj6CrN4LS1gK3LFndhkIvGKYx2nQQxG4ngmS3VEJEcnBf2x61 lajcXl7IjP5i7MkAcDmgC/BcRRpE8hZZkORtOCaijuY7q4LLagXHO12bPPqaWwFm7t5HthHd ToswctuJzkelVonitHOxRLkDJx+dIRE9/I1wVchIs9F7+lWYEIiYh3CsMEBsAj3oYHpuGK8f nVaV3fAAOfQV9QgRXYtna3btUc5+Q98UMfQxr/UY7VCcjPYGs601BbxiCcEfrWLGNv5mj2+U cYPPFQ+Y8wxxn2qSiCeQxDYxxVWVQV3YrJgJbgO2cAim3yomAOvpUlorhvl5OM0xjUMoNvy+ 1MZ/LQnr7VAyjIzTOWPTsBSi1LgseBSAilYwnkEVDJqG0DPegBZLndGCo59adFc7gAeuKkZD e3BCY61ThDzttA5zS6jLDWckY5Ug+tQNCQ3ofSk0Bat5FC4Iy1IzgE8d6aQFa4kbdhep7VtW Wt3VvY/Z0GCRjJ7Vm9Rmlpuim5t3Msm5m685r6B+AfhuDQ/CmpaoYgs9y/lq/favp+J/SvQw 8ffRw1Xodxa4d2diRzwT1qdHx2FekchKH2OrMv3hkD17VWvNPt72LbPCsit2YZqRmBc/D3Q7 vh7b5T2UkVvfDm8tB4j1mwtYisdnHDFGAeNi5A6+h/mK4ayjFxstzpp3aZ6dE5IYEd/WpGAK sQM4+bArAQAgnofXNRyiNWJboeozgGhCIJ03iMqMg5FUJslFDDAU/jTYilKDIilQS3OBTzvZ ASwDd8nsP/1VmBcj+bTOOQk6McdeQR/WnThTgnJ6kk9606EvcxZnaF3KsVJBHB/Ss2eAOyxr KBGVBO/sc9/1rMozrtBHI0TEHaxUsvK8Ht/nvWReQJE6gSElucDIxWbBEbmOK1RFyj5Ib39D WcHUSgP8x+6FJzn6ms2MbveeJYDCI3DbvM3dR6YqtqsNnLdrDIcqSDsQEj6j9azYxjxrHtSN CIFBBkdgMN64qrLdNZwOJLiEvM2fLjUk8EYJ7DmpGVYrPUNZlMVzdKGUnyxIcLtPJx9O9ZX2 q0hvWVbYTv0bIO09hjFQ9xi28rxrE32a2jgibc5uSSrj0Kjtg/pWQVgsb1J8yy27D/VphQfx NACXjSNcLMCwLEgZAxinW+mW9lG1w0E90gPyuoLAN25/CmBFbrLJO5lZLcpuZ8ZJHcDA/Go9 RubXU2iuIDLM6YUiMbRt7Y96VtSzSQT3No9ztCKOVVj8zDoc+h6/pVG7l083sbwo8tw0ahkk O5tw64A7UCJHupW2LuSIF+AgAx6j1qpdjTY90Fw8kszgspjGSrdsk9KYySx+1wxCDcULErvP UD8Oak07SruHUxKZg8iyBo3kcLzwec0rgT6lrEsuqyhYUEwAEm1MA8cY9eOc1TksLi9kfDrY wn5ZCcrj/P8AWmtAKF1LbQCOKzujO6OPNGzkEZ/TFQS6jfa0weFfJijb5ljONwJ5NX6kshu7 W2uUktruXMoYABGBdgTkcdvSmx6i7STWttbrCsJ/di5OHAz0PqfpTsBMmmCxkK6tfxtFKv7q IfMy/l0H1qvEbbSNRkS3j+0RnPzMuM8UgIZF1L7VFNPK80DEgR4wEDdPy4rQuLmx0+y8l4RL dqQwfadwHv7UmCGDUr3xNLEzNt8jKKRwAO5x+FVZtDhhlk23hklycvIuD7ZxUbDZPFqoawuB LJLLeEfunRBtL98+3vVaS1v4JY4tRjlV5uQCuAvPb17UIB7ra2pdHbzZMcgDqKbFHLaEGO3k jYcfNxjPTilcGQXWnSmQyvMWIH3GPI9vpVl5440j22y+cY+Qq5/yaYiJzJd4SWMJIRuTbgbh V/UNUjvIra3u2tbV4c7SFJZjjpkfSgaKlvMsfmSSBXdlPlg9N1Q37XupXNtLK2yGJdm1QFHP cnvQgEkgsrbcPN82Rf8AlmnfPfNMjO91MCkN7daGBJcW81yXMuPOUcZNCtb2mBPhnC5AAyM1 IikdSkZ2Uwqqs2QSOKvTWnkxx3BuNsbDLDPBPsKdgPUVc446+uKacg56H1r6cCldMVcHpmob uGTyCU5yO1Sxo4jUrW4+0EOCRngU6x09433MAAazZRcli38d+1SNbiKLcOSOuKhjRjXn76cY OT6Cr8tigtAQRuxWbKMczeUdpFV5C00g9c1IxLjcpAA4I7VGj7yB3qGUXIoVZTuOKp3QGSAf yqWK5XGAOnFXiitCNpGfakBUNi0vX86zbuzVTwRSKGCDG0dgKsRWfHofWiwFe4tW6AdKLRBF JuA5pIovPKGGGrPuiu/A4HrQwRXXO7I6VK0ywDLEfjUjIopvOkyF6npVuSVoACRgEcUgL2ia 6be5DOf3YNfX/hUfZvh/o4A2efEJ8dPvc/1rvwr1Zw11axoW+0xHnnvTxhRn1rvOUas6umV+ YdsUvmOQecYHT1qG7FJDrZVa5RA2GP8AKsv4X2UqeNfEjoreWyBhKyhSDliV9+nWvOxDvKJ1 0tIyPVrc4LZxk8/Wpp3LQGJMfMcsehI9M1DMh0TKAVIAJHXvXn+qeI9Y1bxBqGlaVbx2csDK kV9dIZYsAAuSoZTnkAAHnI5HIpNN2QI62yFzb2sPnzedKDnzFXaCehwMnj8TUd0CU3L+OT3r Rksq4JJ5x6ZNNSMSKdu49fpmsgLtq6tYXIUkY2vx7MDSvyoLAnIzgVothMy7qItuIHbJPtWW 7lI3TjDYzgDms2MxZGZMliHOMAtzjFQai82qTLPLzj5SVAHFZsDKuyXOCQGx+HFVgzyK3lx4 Geo6VkMljXlJJW+7/D0LD0pZLhYoZW+xkTEfuUJwQOcH6c/oKm4zHvI2uXdSY0ZeOBuz35/A 1AjmSKGOLa7NnlQNy4Pc+9ZjRFrt9Jea1Kotls40BCKcAgEeg9RWGLmKNZViiLyrwOe46/0p PcZWt7WWSVxdKAXJOMk7SR/Tg0yAxwrKiq8zliqlRnaf8MUbgVJIphIGnDYGQWZuPWnXWs3N jpH2aAzCwkkDORnaX5wQemeTTSAr2ymy02ZLpoo43dZPPHUDPY5xg5qvEYLUxyQFpIn4RB0B 5P8AM0DNTUrR4re3ltp3y4PnZwADnj9KzrS0tLedmhgaSSIfvHU8KfX3/wDr0rjJ7xp9U1bz I44bONYwDGWJBIHLfjViW2sZz9ngJuZo1DSFBsDe3PpSAr+bd3luiw4R4+SAuSSO2elJbTRG 23ajAYlyxWWQnkD9KYylP4kSLNvb2yovRHc8E9jn0pZL+a9eaXU5ZfMARFRCPK2jrk/iOlVa wivq0+n2moWs1uiBgoSVo9xaYEjk/QVHdRzzxm4t45I4Q5CoiYxjofemgLctzYWrWssduk15 FHudo2yWJ5BP0qg17ceJrlBBBFHMhJ56mqESTaGty8ktxeL9qUZCKNzD1Bx0pNJ1SDS7lDJa teRuWV+dpU9iDUvUCKOO+jjvTLuMM427XwTszkEE9D9MUr3NhpTlXWS+kfGWX+EY6UgJHt7q 28g2No1pHdHalwRkDkAke1V20v7PK63V0knzHe2e/qKlsCa5v0trUQWkMbMp3mQ/Mw47VFHd 3OoHM91JK0QxGZCTikhiXt1aI9tb+Y0k0nymXAG3noT6c1WvxJY3UsG4nDFSwb06H6UgK8MM zXarK7EEgMzE7cev0q7PNbwxOIpRI4bClOh96oRGLC5vcMqlM52nPAqAaUkEh+0TiWTrgc/r SBFlNUI8uMWql1yN+39arie4mvGiZ3bfwFPf0xSGTajYDR5Ea5R8kZIAGSPrUby28ErPZpIw ZAB83APegQ4Wly8u+bKhsE5qSU28cZZofMcDIX1qQGi9e+gVGto12jCDoPrULRko4vZURifu jotUB6otyAmAOaqy3EzHjoO2K+kuCRBMZJV3HJx6VGtw+QpNSUV7yWLz0DAE+tQ3MibcLjkc UmBlMJDL93vzx0pLmQiLbzuNQyijaWZeYMw/Kpb4yRJgZAI6YqGUjnLve0mP8mr1nCyIu75j UjHz2+44AyaggthCS7AgAdD3qGBXe6Z5Gji5XPp1okj2IN3WoY0VmG38altCVfOeKEUXpJlR CRgmsW4cNJkUmA1WHpke9TQtvJpAh0xDADjNV2AGcDkU2BTnlZjgDmovJkY8qfxqGywaNkAz xVC4Yu+M5H1qQLNvN5RGB09qkvLprshVHT0oAv8AhnRn1nW7DTl+9czpFn6nFfbeowLZpbWc Y/dQxrGg7YAArvwi0kzjxD1SIyNgIXBIHfvVNBcytgruj5OB6V1SdjmQ24uksVUJH8xGNq06 P7QwBVdwHJB9KzbLSLNlcE6rCBnG4KC3eqFlBdaJ8ZLTc5a2mtZonSME7y3zc89to5weprkr apPzN6fX0PVICoLFecj8alznOQDx+dZmQ+LLSrhRuIxzUDWNrFMbgQqJXOHKHG7Hc/57VSEN uZFMabQQAe3QUtwkCQOFn3NwRtU4z3FUxGU7BMqByRnNSQISSMAKe1ZDRPpkO9ZoeSZFZcH6 VMZVuUiZB8mwDp3Aq1sSzLvAoz1BrKv5fN3ZGGHBH9ahjMqaNjHJGjDCnzCmOp6VmSTyyQBV IUngCspAUJ4FD71JXaPm3HP44qEpNGGZHKKMqyjo3+cVkUO8oKgudjMD1L9KYbkyulyEXCMF ZJCTkDoPp2qWBVuY1bzdsQCytnI4CY54NZ1/FJayRsibVbDDH8Q6damwzNktomleaYs+5wWR T098+lZ86eddyGGJEQYH3s8etDAr6pb/AGaMmSaQvIDgA4yPXFVg095azrAog2Lkrg7n4pID GjMQWY3ZdnyoTLZP0xWtHdTSaQtt9ojitpZtot1c7wR/EVx6d6bArX8WnwzvbXE7XNuUIUOp XPoTjuM9v0qDSbZLVZokVjnhXHVfpS6DLljY/Y7ww3D+fFP6t949h/Sr08/9iJcL+4gRVJYT cl8fwj3qWUjHF8tzI12ZEitgOVftz0qrql3Z6UPt9tOxmlyrIo3EDpjHOBVJCZWmlvNWtYJ7 fz7dNuWjYlR9ffNWbTxEJ4HttS/5B6OGcRJuf0yM++P1qraARWV6NSE6rbrHGshEUk4wZBnj A9a0hpS31v5eoX3k8sY84B+mB9elLYDL0+7itZhDu+0SoMIxXCr9TThc3b6mkdxczRorBo5I xjceMc9qYyfUDpGjRq1tay3V242yAfdz/TPpWdpq31vqBu7OFbFyCpwdzrmqAsTW8Om3bTfb DLx+8XOSeOTVaTW7e4tjDp0Kq+c+bsBIP40txEdpeXGoSRpctIyR/ePTI960rdtMthcK37xJ UIATrGc8c1LAij84xmK3Lsp4KnJ4z1HpWe9ld6d+5uMSI7b/AJsDPpz+dSgHG+ttKnfybYzw jgso6EjjJ9jip5Yr62Fs5j2R3Kn5yvGP8akZnXNpbiFxJKzbTy4XOTV2xuDqFkLCMrFuIZ5p lG5h259KYEDQJa3MsEzvKgJCSp068fhTWFpYIVQCUE5OBypNAF2zKzZR/NMGM5RgCDTIi7W0 NrI0DMz5MhHzDnuRSAdqt1HpEzQWQjnO352Az83saxIpJ9XRWYbHHA42459qq3UTLnlQu+y6 unmcLggknH40kpbTUEceCOqvn76mgYMs5dZGLtG+OprY1ln0vSLVJbZGQkFCcZIPvUW1EZTO s5EtsoQ9tx4FSLo8+qRiJ7iKN8ZLufTtQB6NswCc1RuNQEb7AMkHmvoxorzakdpVV5/nVOGW WaQnGAKBg4zL8x5qpdyeXMu3v61LKSLi3EW3nj8Kyro+ZK23pWbAdYSoZgH4HvVrUEjnGBjp xU3GYklshcnHtSMvkrmkUZd54gt7VsZ3v2Ve1UYri41iTOcJ6DgCoerEjZtbeO0HHLetOuSt wACOR0zQUULm3IUHv6CiKPbHnPapK3K80+cqT09BVMDzGOPyqQH+Sx6U2fMC7UPPekMblj97 PNIZWjIJFJgQSNvOf0oMhHJGRUlEFzI0i7R2qiybTnGakCRGJzxVi0iaWYKAT700B6x8BPDA 1D4h2c8i5SyRrk+xAwP1NfR13Ibi4YsxbB9eK9PDq0Dz62sxsswSNMjG3nIqpfTTRRxmIZ8z gbT0FaSZmitbRSyMRMyhgcYFaQuDbqV3BW6D1xWfQsisbSb7bHL8rL5i7RjkjNdN4n0JBren arFEr3cbiNWZ2G0McEgA4PB7+lc8leLNU7WOgs0+Xdx059c1Y3enJNZGYBcgAnA9AaJk8tEO 1vmJx9KtCIV2BgHz5eeRUL7FeUKcqG4+lMRA3J6DFCOVBTPzMuOD05GP5Vn1GWdPP2eZWJ5E nQdsii1XZCUPzGNipxx0q0JkDwCWcRv905PBxWBOQZX+XJ3YwfQcVmwMydNrFsqq4/E1j3ET CUg/hg9ayYIbZ25tLxA5Masc78dj/SoL90Ny8e5Su4jAwBjjGD3rIopyzGGHyFA8rdkgnNLc g28YBHloQCysOhqQKxEaAB5A2/nBOeKo6nf3RkgheJZIAojV1HKKMnGOlIZRWNPNEeGkJTnz H4wOgqtHaKs7yrIIbU9HBHUDkZ9KTEUtSitrgJG8wlZCdkqEkHJ5571VuUuLS7jnQlERuir0 NIZWv0gvZ5b6T97dTNucLhVXnngDj1qDbJfXZNskcYUAYY5P1qgIbuKC7ja2eZZrlADJt7Cp LSJbrybG3LRgkDfIduDnofakMP7OnTVJba5k3rCSVdWyAM5HI471M+pRzSrZSWgjEbMfNlbq 2Pl+nNTuNGfOsmrXDy38iPvHlnGAM9AeBzWRbWn9i6jISTJCvzEAZA7ZxVLsI0Eu54b1bl5T dWDqVWAAgAHgnIPUHkVEdMtNOtri7eZ3mc74rdOCVz0z24qrjRYOvG+ayCRE2UIB8pW4jODz 0681Xky+k36uYZLtnVkmdzuT6D1xSC4k1x/qVXMswQlmVeCcDn+mKbBby6lahLtf30bABzlc j6D609gL1trVlojXNnJbNcOyFST8vB/iHrWMdYuZYhCw8nJ+by+rD6/SkMqPpkkWoRyJOkUD 4x5rEexH/wBerl3atppkNtbkBW+duvPt7VQh0Aub22kuIJUjim+WZc/Nj/Ioh+wRwSTI0s4i 5kYKSuPr1rNgSW1zc3MQFojwsx4468dKpG3dYhb3Dvsz/wAtThQetJAWrnWP7ItZbaEjyZ1A ZAv61FeXjOUt0ZZbdFU7xu7jkc9/eiwDLu8nS2ZFdEs5JN4iZcjPGcfpWdc6pcBVNuuY+p2j mhIBwuJtQtVUSeRJgbs9B7/jT4J7aBhAGM1weGbHBpiLU9zL9m+yxxEqxyZGHp2BqvHE2n3K NIoZMZJQ8fj9KLDC9vxaxqbWFJFdwzOeSfpTZLWadxtjaMsAeDjigY+LTFC4kuU3qDxu5oS7 WSIwLGQV+65Gdv0pCEtXuXYxSbmU9M9qmvYVj2faZHcYwF54pDI41FuwjjXJbG1znAqGTSp7 G+kLTNLHnlkPyn6e1CFc9GmndJmTsP1plzZ/IZTX0JSKLR7mGOtXoUjt0G8c9zQPoUbgAsXH es+RDJJk8Y4rNjQ2dAYjz24wetUkcFtucE1DGi3HAsal8jJ7YqOa5WNWYHOO1SxmPc3ohRpn bao5rn7zXbjUJPLtwVXp7mpuMrx6Vzvm+8T0zXSadEEtwFAA9BUoERSTnftXp61MjDGf507j IJ7jfwOQO9QTScBQSKljRWkUs+O9SxRBAfU/pUlEhx06VE6K3LUDQ4bdoUgYFMkiR19vWkBQ lgYdBkDuKgkJ24xioGVyCVyeDTSgcikxojY4birdgzxSBhnGM0JiPpL9muxddH13WJF/1jJb pn2GT/MV6aMkEjHPrXrUdKaPNqazZXljZ5VO4FO61BqTPfXcTpKEaFNirHx+dTIEOjJACnJb PLDvVufT5ZhaZJjZ2ILAgnHp/n1rORSOr03S0UQh0/eDoR2re1XT1u7QnbueMbl9TjmhK6Y2 7FewQLGOAR0z6VKcEjgqTxn0FcomOTlFAXJHqac7KyBeeTwPeqJIXGUcKQGXGT601gRA3QBj jiqQilKVVQxOejcetIigzZUjIbrUMZcQhgxIGQQ+fxAqw8Oy4nAAKkg565yM1S0QyhfJsII6 1i3LYYsTtJ4z/eqGKxl3SLKoJwuOOKyZ2UsFDZbGCRx3rFjQlyE3yRszNs4RvX/61ZskSTAB lUsp4OOKyYxiBmR0KqDxkdO9Q6je+fAkFxs3KCFIXkjsCaQFS12NbxsN3zMR0wcVDf4LEFCq RvlXbqR24pNDKF5Oks7OkKR27fKGb727vgVC1k00kaXBbyFbaVPb8KkChZ2r2V9NGxSXLEJu Hc/5FUrmDUJNQ8qYFg/CoOAKlMYuqxHRLmK1kt9kk0YJPXOelRR6YbSNpCCJDnd5nygL2waL gRPJbaZeLMjgrNlZFUDoe2frg1PEHeC5mbmPyXSJQDkN1B/OhgV9LsxdNAZLgWkjfK4kPT3+ hrOuXk1d5Yrcb5w5jBUZ3kHqPWlfUdiFbeRI5I7tHt7y2AaMyfKSeucflSWpWSMmaYPfs2BH Jwu31z9aq4GjB4g1GOW8u4rextbO3At0gGJCXOATgjnrWVO2l+Hb0QefJetcJlmI27fr+PpS S10KG2dvNolvLMlsUtrg7EuG4DHvj1qpq2lnRrzeXhHmlWeRn3Hp0FXe5LHz3HlqZbAvMFPz s/Uj2FdBaSTeIbaWO/1CaO3hjLrFbqCScdDjkj2psEZV5eWd3osOYGa8icr5wOSykdKcukfa tHnkgneGVVXy4PL5f1Gfap2GZ2n6O8l6beSEyzx5Zw3UY68Uah4r+zv5SRJHAy4OFyWx71W4 iDTmliuY51C+SGDsMZDDOf1q7dXbzalcz2cyWtjc48yCHhceh9fWpYENnfPZTHygstmrYO4n JqIwXOo2hkuEKQyuyJJKeCRyaQwZ7J/MtlZ51iiVt0S43eoGaorbXt1GkUUbR2xbGT0PtSvY VjRbRrPR7+Fb64+2WxXdiJuUB7fUVQv7poLhJYbfyLNmIjfb98e59RQCHeUJpFlkceU3PBxx TJLa2BilgbDhjhsdcdcGgLCAyXkgtdxjRznzW+6Kbo6iV9ssxZVJBUHjHrmmBPcahaw3qwrC RDnAccClivJlW4toolnSQFUd1Pyj2pBcitLNYYd10CjD+IdKnF/ClsTDbqznBMrDpjtQAvnH V9wkCxy9mj45qrLZrETFJcqXxgAkk5pDHRzv5bwnOD91umPwplsboI8bM0gPy+9Mk9GgUyS5 645p99cEDaM474r3y0ZgZxIGA460++ufNCqiknuaAKMk32c7HGD6U2QrKgwRxWbLKc7MuAO/ SqN0TbsrMevIqRkZ1WQgAHIA5rI1bW47VSobe39wGpbDYxoku9Z+Z3Kx5x14H0rVs7SOwT5R l/XHWo9RouW0f2xmG3aRzV1gLaIg9R6UAjOZyWzj6U0h2yDyPSkMST5Kgywf0qWMtwICTkZO O9Bj3sdoxSLIJ43Vgc8egqCWVgSPSkwKk12c4p6T5QetSih4m2jt70x4UZOfzpIRXe26fNn1 pfs20/d49TSYFR0US49KmF6iEKV46VI2fYXw10r+wPhlo8BXZLcp9pf1+fkZ/AiugXasDgrk 46V7kVaCXkeS3eTZRDkZGMEd6rzQbkCwlldfmY1ky0Wo447i3O4klvlbYcH8DVvQkW515LXf uVIwdxbcwPOAfyrNlI720sWSQmR96Z4BHStiWLfC8bfdZSPzpxBnOaewWJFViwHy59auY3Ng ZwD1rkAnAC2hO4iRpMAevrUYXcM55zVogYQFLcDJ75qK5dYYSkbCTLBi2Oo9KQ2UnwFBAAUj 9aeFYQqmQdzZCgc5OBzUiJ8CFHYZ2lPvfiD/AErZtCGnj+UYlhwTnoRnn+VD2LM7UIFuEwhx 3JPGaxLi3EZ35KgHqRx9KlkmdetDjCtjqcKtY0kMRKMysDnqOtZMZn3/APeUAetVJpBGjsoL kc5Xk/hWTGMks57mI3KAIiMMhvvH8Ko3VxDLbBokYur7pGC989PftQkK5LHdmGOO4i5ZQVMT KMHjrzVS3hn1GLYwBkUYjV24x14/wpFGHqZuTeYhgj3x/fOcbx7fhTrlC1tLJ9pVHwAR5nOP pUMRBeCT7GphUJcKgIY9/pTY57mbTvs9653wsSJP4mJ5HP4mo2LRl397HeMttFGftSAv5zv2 A6D8qbKJdRtzJeXCqWbAiUcn3p7IQW2lzWyvcbje2qKpLxjKqT2J6gikE06TotxP+7lUoBGv T3HPJFJu47Fa3W20G+muMzXsqr/o7SttAye4/pWgl608tqYpYdOMCOyypHktkdGx/kVL7jKG rwjWNlxZW08+uSSZYl9wKAcjb6VUmsZb2zvbm1EP2mwGJY5BtOQeQPekn3HYyIA3iWMzmX7F cJxIiJjkdD9KtR61DEk1p5kUl08LRZZATtI5GPwz+FbWuIgvLmKW2sNMgmvJ7dE3biNuGycq M/zxSWehTLD9nv444UKmeF5cM7kYHA/x9KaBkC6pLpV9GgXzraRTiST5QfUCtS2SS3YyyzLB bfeDJnOfagSK2qPb291FdQP+4lJOAOh78VPLNNcwRy2bSLg4KEYJ96Qxl9pcWt3dxqN9drbX aICUGV3gDoMd+1Ztxfaff2cdtaWDfaIBl3c8EegoAiEL3NrgnyYlIG084P8AhTLRltBJFO+8 MwAK9vegRdh+2Lbz3qqgso32ZP3m6DOPqajk0+4v4J7yecR20b9Pr1wPwqQJrLVoNElilsZk lZhsZXjzmoNXSea3t7azu9yyqGCjKmNs9CKXUe5mpBJKXmvd6gErvHCEjqKbPrNtPHHatEW2 E7Q3IH096YkSw2M95CCFMFsGwHzjPHSp9Q0640eKyimmVocmaII+/APb2pXKHNq4mVVgUeUB g5XGTUcenJqN3GslwLeEffZRyBRsSVhFYmeWKGVpBEx2SMMZGaS4vJpnMcO4lhwycYxQBCLy ZoDFcyN5bdm4wemTSG/Sy8u38o3C4wXLYzn09asBy3UguB9mjYJnk46Vc8kO6XMrIEJKnoSv qaQDXu4jIEgdXJ4Dle3rUuqSSwXEcaXKNMBjdEOKBHdzP9lXcp4zjFRxS+aGdlGT617jZSIX u4mcpwSKuwxoCPk35GOKoow9WjfzwHGMcDNItmQgPbHasnuUV/K2sSTx2NZ2q4kUYPIoYzmt W1ZdOjKgAyN0qhpXh+bVSbqcsqk555yKxfvOwjojbx28IVQAFHAFRww+aTngCqKRfiMdrH8q 1Sv7tnQ7akrcZZqXi3P+ZFTn5jx0FIRVuslsY6d6hVMkFh0qSiYTdccVXedkbI61DdikWVkM kBbbzisyFmeQhucUxkd1AqnJ/SmwjcwUDk1Iy1NCI0JOM1nTyMwx6UbCHWqySMB2HNXnk2oR tpAUo7fzGyVOfar2ieHG17xHpunIP+Pq4SIgDoCQD+lK3M7Cbtqfa+oRpDNFbxqFihQRqB2A 4qtIvTB4x+te8zyVqQSIpjfbtDAZGT3qO0ZkiTf94D5zjGfXiudmiJru4USF4EEKZ+Ve1T+F PJsdS8+V9s8zbXJ4GPQVjLctHpVrLG8i7W3A8jFaTLz3q0DOaskj3Mig8MQB9OP6VO4IIw2M HmuSwDmDbQwYHJ9c0w5XdzVIlkEgYOcksPQ0OgZclSMjoaBFcDcrgrwDj8cU0E7WwQWAJGOe akCz5vnWShQcDcCc8Hg4q5BcN9itHBAYF48+mRRuMgugfL2nPpWLcySmDy2cmPcW2+hxSYjF umKSEFeD61RbpgcAd6xY7lGVT5p3ndGeOe1VreFbm5MBfy02naR3PasmUDwXOgXZjumDEqML nggg9PzqvaRw3V0kbS7InfYoC4waQypcQuJ/IA3EAt9/g+o/SoI7qDSizssnmdYtuSSakDPk lLzpMICqMpyZG7HP5Y/pWYdNitWWVbiFog+7HUt7Z7d6ewi5qd/BBbrIiygwoP3ew7iCODj0 6Vk3G7Km5dI/OAZQW79u9ZMpGbeRw3U0csAd26Mp4FWrx7hoLee1VLW6gABI/j56kHvTAbpm ozl2BDTM7bpkztRvWqMlxBqOsyfZt8UTsPKic5MbAYPPoT0qbFFnyjYXE1lezx3TEblZQDjj OM1Us0lF8ttcQyQCc/u3kXap7Dk0twIrSaW6uL3dOIJLRNsMkWQTjjGRx+J9atiFra0txp9o 73E7kzSk5Enqalooy5bOWe0kvba5gVZZdnkoSGAxycelULnTLTSNftNWtlE8SRh5o3Q4Jxhu R25rSLtoSOuZpo4xeJHviZH8qI5AYHIyPpSaeov7OCe9U+fBnkHk/StOgi7cXkOsadbWCW0X mSTblup+DGewz2HXNaeu+Fp9FSzj1G7hNreQsqqjZVW9j34IqRnOiwXSEa1uJVyAMGRufY81 WaW7sJCszMq/whTng96aAlsrRbRle4laTDblZm4FVNRjs47yO5hYnJ3MqjowPSgRZu/O1gq8 aHchyY0UkAfQVatNJGr2t7qZjEcNuR5kMbAZ46gelQBb8QXenppllHpcyXNxs3SwFeUHufXm sG386V1WR0hjkGDuPUHtRsgK+o2y6bcBvOV493zGPqAKnj169s1maxt42tZ18jfIu488ZB7G kxlRbI3aRm6u9sO7JzkgepA6E1p6ZJp0GmXkqWYuUdjEk8ikbTg4IPr3oEDWOqXLWljcFk0+ 4xICnzH0zgVQymnagzSt9qSImKN3BGQOhx/SkUVTq/7zyfs8cathtxPPNSRwySzsSSEYdVbi r2FcbNCmnXOIHV1YAmpZnuZYZBbxOyQjdK0XUD1pCIPKuNRzFJtjZOSWGCPrVWJbVw8QmG9M EN0GaoQW+qeSzQMhJYkFgcYqKxjlt5pIJWCI54DdCDTA6BhaWcAtAI2ZnDmXqQcevpWff2rw 34jgZWIIJZTuX8DUXGehSRteLt3Y9RVeWQ2uYgRx0r21uUgs4gXMjj8x1rWWZII9w5rToBi6 hdresGHr2qrLeG3j2nkVk2aLYfaoJrcyHgEcVgXsy2wlZuSMgipYHNWultrV+ZJQQoPAHQCu yBS2gEKAAAYwBUpdRGXcgF+OKmgQBDSLGzRiU7BUC2eGO4GkND5VVIto7VREpQ9D60ASW4+0 P61JcQ+WN2OO9QwRnSyEPgU2IF2Bxk9MVLLNFY/Jh2nGTVQhACR2oYJlaUCQcnAqOADeCMfj UlFmP5yQeQajGnBiQBuJNN7CLVvpwtxn9KZdwKOlQA21uI4gVYYPrivSvgBpK6j8RYrnbujs YJLg57HG0fq36VtR1nFGVR2gz6EdzNcM+M+vvUclvv8Am79Rk9K9hnlooSWjS3aLtJz3Y8Va xundCmxE4OO5rB7mok1suGdSCVxtU9zVM7LS4SSVssuCpzja1YzRcT0DT76UJDLG6GL+LPJ+ ntXYr+8QHOOOtESmjnVh8u5nAYf61jgH3pUiJky0ijJ5PasGiR5ljMQQRnOclieo+lROOSBn p2700SNBCuCQcgdKZO3mMAnGBjPrQBA8BUgk57jBpEzuIA3Af4VLQEkQZLRh0C9R9KkKkaXK qkfu5FYfy/rQhkx+ZGzlgcGsS5yk0i9B1JzSkIyb5AjOlwjxvtGzAzketZsxV4lQZV9vzEc8 /SsGMpOS8ZjcfOO47cVUKyZaPiJ1PQ9R9azGR3J/tKSJJJN8irsVu+etUH85lKlWDiTJdz/F UDIYcQzOGlw4dsbR/CfTPbmpr7VHvkjiETSJbkqqk8njJpAZl1FLeYRhgD7yt93p/n8qqt9l sbktNDHJAhBKKeAcHtSArya4YpmLqx8zICseWGOPwrKaJIY5bWaCNpppF2SN94Z4wD0FQyiG awuLG7e34Rlbhi3HSo7xmtrhU3mfcMkjgY+lACXl8bOGNreNQoPzNjke9Q6fcCK9FxLF5kSk +emdp/CmloFxmr6xEkF81uilpSHQkbmRQeBUCXieKLQ/a5Lp3iQm3xkEt7g9qTVtR3uN0iG5 1K2i0oW62d9E+S/RmX6njFSS6oq7tLZJHmUkEuOh9qVrlECEK0ECQgxKpEvzYyx7+wqeK+h0 q1mBvo4o2YRMgPzEHn8uKSTC4t0Il1i0NtDNqGnJDveMMEwTkEA+nQ1Qt7ZNMC3Utwxtbgkx g4zgHGD71SEyLUGtnu42S3kljchhjuw/lzVnVrbU/EENpLcyyCO0zshJwFGe35CrQivdsupy Q3F2fMmAwrP824f5/nS30lxq9tb2lrbgTRvtGep44GPzoGN0y2c2epJfTRwFRtEU/wB8sD/C B34IrEtpYob6YvunYHKxAcfWgRf1bXbldXS52xRRGLYEtl2knHXPrUFv5FiI72T9+Vfd5ch4 Ye4pWEPnnhuLe51bTrA28UbAuiNnBIAx7DvVCygbxAjXMqP+7xlc/eGeQKBlkT2Md/Ms0UiR RsVSJyCSOnJFXtQuDFaWFr9mSGxmHmYjYHC+49RUdRjrWK3iund4xNabSg847VOeh+tQ3N/q fh7Q2sLdgdNuZA52AMW284zUgZV/eXqtDPDvGGBIJwAK0b+yu5tNs2u8RWcjGSNwmdx7802F zP1RLK4TZGwkaI7Q6nINR2cct00cCOUDdPr/AIVS2EyW4tIbSR451yyHDMTkH3qH/hImtp1t 4Y08hhtY4++PTNC1Aq3Ilc+ZETGWYktnJPtU621vfW8FtDZJ9oeX5pyRuOasQmtWbaZJ9jlC iZcMdpzwabZf8TECKb5mUfKT1pMCxDHZ2knlXD7WHKjrn61Dc6lHZyMIkLu/HHaoGeiW7tFt 3c5ovYRvDryPeveiURAkKOMfSquptI8IVCQOc4pvYDMsGcXGwjA780zVdz3AC5Kjjg1kyyHU NY+x2ggDYasyGFr9fm6enrUjN7TbFbSHoMetNvIsncmKYjPNtubccjjnNNeTau1RUtFeRas4 lxnq1MnfbIwxxSGjPuiQc54qIgMmcUhj9NdYpCpBA7U/Upv3ZC45qWCMkxEncSRUkB8tsk4N SWSTztJxuOB71EfuHtigCF84J7d6rNDIzAg/4VAzQgUBODkirNs538DrQBqQWLS/MwyPSqer Wot0yO/pSA513ZSfQ19D/s16QbPwtrOstw91MttGcfwoMnn6t+lb4ZXqIwru1NnqibxAxXBf BxnpmpLZZRAnnFTL/FtHAr1jzB+ARk4x60zduyQOMenYVm1qWRuhmGAxUg8Y7Vl69azTW8gT EbNGUVyMgHsawqL3WzWG6Or8CXH2/SPLjnDuJMNl8ttHqfU4r0a1cugyuPrUU/hTNJ7nOvEE 16+jZ1VWZW+mVH9acr4XGOh4rJ7kDlBfgKck8UjqUfawxkcHFMgYBu2ZzjoTT5JTlWAGVG0Y GM8Hk0BcYkQkk+c4QLnOadNpnktG0TMQck4GeKAIYFVZZklkyJMgD8P/AK9NsJBLDeJj5jEX A9xzUdRliHJiQ5521mX8W4MxPzE4IxRLYRiXsbMwfJY+pPNZs9vuZcH59wGSeBXOyildhbYg RsJFIy2Bjmq037xXkOd7cl89RWbGUzJEpicqSQwJYcZHtUM8D3AeUboy43gt/GPSsxjHtRBc R5uMLJGGLFe+M4qsn72Q+XudFYbz0YjnkCkBTvra41GeWJLhbWPAJQHJOO/tVG4Sy+SXbJcl cLIF45pgNlcu0DJHGkbcEOdzJ7fhxVe6jiuxJAZ42uFUlW6dOwqGUZ9u0ssK2zgLdcsJX5LA +v0rJ3y319JFqhORjlTtwoxjkYpIRNcarp8Mps4otsMoKAvyRnvn8qkhiFtvjncLCV27j16V VrAc9JDBpV/ERIAkzZU9Semava/cz6QsF1CuLUnae568GnuMkjuYrsy6ndyz3F6AhjZeqoM5 U84xyDkgnj61Pc6hFrk4vdNtibq3BedXbLYHIyDgZxUW1KKWshdY0v8AtDcYLmWUq0MQwAAO v/1hWNF9kntgZIt8oyMY+8fwqkJmrZ6rcapZ3NvGn2RmURsmf4cjFT2UFnA8lvqUhuowNuyJ CpUn+ual6bANtQtu00XzHY3G/wCvFIdNvGvJUmaRj5bMmwcOOuKE9RlS4gh0yO3MkLxXBPmA szE7emMduaWbVhLJG9rbsxVfvZAyc8/lV7gJf2MMkiXtqVikKhnjJ3kMOo/Gi4nTXtRikSMQ S+Xjy04Xjqf8+1LYRh3F+88rWok8ueJipj29jjGCada6Q0cB+2AlW4EkhyRTERQO2mybI1a5 hY/MgOMjPetoawdK19Gt7Zks3QARXIBC5HOMe9SwRV1q2sbYQXCSSbWwskQXdls5Jz2GKrSv DOA1sjgsMfOcn61JRZfQ9Re0RpXHln5o1UYJHvmqxjjtSG+cfKAwd8/N/SlcCf8AtSQIllNa rFBOQVlYY+XpnNV9RmuLZksbi+E9tbsViijfcnPcD6UWAiNhHYsPmDo5DZbgVUu3M15E4naG 3XoUHIPvTAkt45dWuGhjLSyKdu8nAYfU0l7pq2aSWs4CXMTcAdQetNbgZkNzdMWtI4iX6g9x T7UGFRBcF45AeGPGK0uiSeWax0uIhopLi+LDEzPldv0qO2lEcweIbXHTPSiwEx0S98Qtvtl8 50GGVeMVOWtba2aNkcXgOGVhnFQwPSE0+S8tzPC6lV6rnoaiiYM3lygqRzXtRZZIVRsKgBpt zAmOBirGU7OzjWR324ZqytRZbeeSR/lAPX1qGUcyYX1K88wqQg7CtUKlmFGNorNAW21NZECg 4x1p2/OB1H8qoCtefJE2Dj1qvCkbIGLAt3HpUMpDIp/LfIbFTNIJiSMGgZXuUXcQeBUSxqOv AFSMsxiGUZXBA4yOoqGZFTJJyvvUkozZpCxOBxUIUu3XilY0Q88ZPWoPmlJGfwpDEZXxg1o2 doHjOetSA6SzKE46Grum2mG3EA/WkBtIVAAzisnW386IhR0oGck6lWIPOa+wPh/pA8O/DbQL DbskkgFxIO+5/mP88V1YRe835HJiX7qOgjXagBqQnAPr2r0mcCGn7mSCQRgD3powDzxj0NQM ZIrPGeRuY5OB3p5gQQguCyryQDjIqGrplp2IvCFymn6kV3KzFScL0Prz3r1Cyu3eBCh2qTzu GSRWFPaxvLXUz9SQtqpG35njHOMd8f0qNlZVIA5Dc57VlLdkEwfbyrYde/pUTZLgjkUEiPuR wMDaepJpFKSho5HCqCTnHfHSmSNkYxbDtKgDj6VbTVEiYpKCUXKFlGM59qCjItnQ3B3El9uc H61NpMq/2hsC7eWUj15qHuMtWocQKGx8jFM/jVTUUZX8xAOD0okIxJco7FlBGCAG5HNZN1Dt k5I8scnA6E1zsZl3koLqoGemD2xzVeSONQwLMQBkehrJlIrsqQSNEqllxkZ5BqvO8xm358pM /dHQD2FICCZlE+GLHcc8dMVWa4meVvKbAYhST1wOBUjIpCbDjcyvJlXcc5U9eKqG4tdJYSmM zIMHaeVznPI70AUzdRLcvNFaJ5U3LE/Kee/05qO70O5uR9pC7LMBSZkT7nA6kDp71AzI1AzW 3/HspjdFyxH8Xpiqf2X+0NPe6umkW5QkSRbSpXHqaAKWpG0v42a1VmlgyoBOWK8YrRELatY3 EcsbIqovlySOAQcfNkD8RT9QRn2dpLbRJa3GwxIRNEqkMO4qH+3m1OS60uVREF6bhzxQMjtL SXTQwuGA2DaONuM+tMixaXks007yi447k59zUjNC9aO18RaPJp8DeQIis0UnzKznjp1B5/Sp NS06KDzdac2675QhtoHwQemQv86AK9pNGtyl5BbNdQycMudob2z25qb+yZ7d4rmeSOKWf70Z YH5M4z+FJsENunSyurmKGQSNGwxKi5D8A/8A1qsXmsXeq6NDBHFGkyS7vMQHfg5+Xr9KQzG1 C8ku7ryr6+aQRpsjdwAQOuOKpaOh+3mC2V7uQncwYYGK06CI7+0vdOu5ftaiLJCMFGCMHpTL kjSrsO8rlDghFXGAT60gDV4Dq18bzTrUW4CoHx/ez1qxqejSLpav57yXCnewJwpH0+tAMuaf AlpYLerEZHaP72N209CfzrPkv7zUkxMAwyQu/wDg+ntUgEel28ErpdXkeGwAcnJP07U+1aGx uY0Dqsedpd+OemaTAknlXTvEJ+2XD3tqBgG2OcfQGlgszq07ouyBiflM7Y4qQM7W4ktJUhuJ jNJFkDym3Jj2NVLC2m1NViUCKQZ2PVdBhEpllliut2VG0bugIqxp+pWkVjfQzW3mXO7EbDoB 70AVTDqWrvHA7JYxQRkgkbMgcgE96le3X+zPNJMs7yAqxOeB1zTEQ6rqclx5bRRpBIihGZAM 596rJdS3TN558yVRg7R1HrVWERStBKpWWRUlX7o701LoRRNCsO7zBxIOqmqFcueENcvNH1Eq r+WGOJAR1FaOoXgiuDPJCJ2clt7DrzUvUDrtFuJYoSu8gHqtW2AlYsete0jQkaRbeIt7VQgd 76blsL1p3Gi0oVmKdAOK5DWbozXZhUFgrY/GpkM1LDSsW4+XacZOO9VdV8uNDGQN2Mj1FQMy 7W33yEk4WteIbcd/woGMnjW4JGDWSID5nX5TxxUhuTT2qoABkGoUJjPH5dqGUVry4LMMHp1q EFpQFzkVA7FyJ47VNvc9aqXl0ZfkXI96QisHLEAgdeamjGOOlIpDto2kYz9ahCqvOKkojQ72 IParsVwYlx6dql6DJFvDIQoGKvRXnlJjue1ICVpnZc8g+9QygxxGV+FAzk073EzgND8Qf278 UdB8O2y721C+jt+BnClhuP4DJ/CvvfUfk1EQhNixAKqkdh0x7V6OGjypnBXldoZuxnNIW688 dq6zlEByOTwOg9aXbkY7e9IYhYpyAeOnFSGYJICwyB1XNSxoz/Jja8idECkZ+Ynbnrx+Jrr9 E1UQ3MgnwwxgZY9awtZ3NlqbF/ctM9nKNsYI5JGT34qSNZHQvnbk9KxlqxBwJXGMHjII9qRt q9QcYPTse1IRXcZwS2R64xQJVSGRQckkDIoERB2lQ5+bspzzUU+0DeQM9SR/WkMERQ8c6xko CA7DHQ9KYJzba0WRcJu6EeopMEajErLPHn7r7h+PP9aguhmJiaGIwb2Nir449CayLxVaNfMy 0hPJz19qwaGZVxBkuknyupKnHODVN8REbjknoTWLKQzcwOBjdxjAzn2qK4E0yrE2FRckHjd9 KkZTjgH2yG3ZmLSEDzD2zVyPRVt72a0dsNNEwT2fqPzxSKMNI5b6e4hvJTkEfw7WyBz/APqq G9ltrGR47e0aW3QYd5R93PXH51IjNgjjhufJmVFtyAN+ckA/15qlaWr2d5c2xupZ7VxlYyTt z349MVLGivrOpy272UOyOKJFO18ctz/SknighdNRuryaeV2y0Ug3LIuOp9xSAzYmtLK7FwsJ cOwkBxnIpniASXAiubZXity3zL3A+lUBUsrKKyVZ5A+ZDliOxptxbXF9fRGK1SxuyyhmlO0B euT7EEUMYl5YtrdhdXFw8jXkcwClWyGweTmrD+ZdW8ctlbxWssEQY7PmLYPJOe5yOlSBWvZb i8iiNxMrTyu2PLHzRYxycevaptGgjggkWd1lUE5jkTr9aGO5Pp1nusnjE5iUj5WPH5CoILKW O8KXRa6jGU4bacdf51IyURCwj+yqoS5lO+NnUlsdh+NUhqsyNKAvl7DnOcAHp+dNAygNHXU7 vzWuEt2UF3aQ5z3/AAzUlveNZhGjSRp05Vo8jPvmrYjPt72+1Oci6uGeaRiSHYksevet+y0x LqzuvNAuGiTcwwF2DrwaT0AxLaT7EzLC6t5v3RgnFRS2V1DMJJFkkWTgHPBzTEbM3l+H9MtX kneS1nP7yIN8qjjOQOaralqWlCRTp6PqEJT5mGYwrenPpUruUZf9nS6pbPIZFhnjG4L1L89B 71YtIUtvNe6yZNvyq42gntmgRHZa9PqjPFcxRCaNduEQDv8A/qq1Z29rMzf2rdrbRBTsOCd1 Q1bYEZDJCL0wq5MAOQT0xU1jHd6lqCw2TRQQdQ8zbBx71QEy29rfafdXU8siTq6hVUfKx781 G/2Ro9sTK0uAWOOQaBkMqXV7FhSzMuMBu49Kp27PbyrEfk75bnnNUhFlzFcPc3ckqGXdtaMj G8460630lp1MkSMspGQsYzxRsJkE/hKa9hluWnjgMS7iJDhiewFVvtqG1jSFgZxwQBk5HSq3 EKk0mrSu8qbHRRkY5IqeBo7wC3klbaoO3npSYHq9tZ20MRYHODzSTGGQEx4yOuK9k0Rm3qGe JlztqhEWsuQ2Dmkyi69yv2UuOSRg+1YMEKNfNK3zAmpA23vY7O3JDDcRxXK3khu7hn9etIaL FnCS4UDjvWhIoUYoBEE7eVAWCnceKqWS7pNxAx71I76k2oMoCgA5A61ly8Zx1pMpFCQ5kPcV JECh5wai4wuju5UYNV9pP1oEvMcyFF4GTUBdlY7qRaJ4ZdxxySau21n5jFiOBSGRT2wWRiBi oEjZ22jr61LA1bXTNsSuWBIoCqsoLDJFQCJ1cn6VkeLdQNppMnbI64zVQV5Ck7Iz/wBj/wAI jxB8dDrcy+ZDotnLcknoJH/dp+jMfwr7TlmN1eyTtyx4+gFezBWR5dTccCM8nikBz1GDVmaG s+0kkjA61h6p8QtD0tiHvY3KtsKRne27HPT6Vm5KO5UU2Sab4507VGTyPMJPXIAx6d66RYft 6ebHkkj7xFNNSWg7W3Kj2rW8rF1JwBx71JLNMLoSwRIGYAqC3CfX9axehojda6e5ktPJIlUE bwe2c5rpLY4hKsCeevY1zvcoQDLkBMEfxf0qGYHySxOA3cUEFNQ02za/zDrnuKU/KQcYBGaQ mSi1dYPNx8pbH6VVMag+x7YpsA3O/lxkbAWU5x+FGvWjW2opycEDH+fxpPYaLxObjOMGRAT+ HX+lOkiDxdTuzxigDHvoQIQucOSQT19Kxb+JHVSpzgdR9ayaBGVcRK7M4yp7AdOtUNXit95a JC6jpu649TWDRZTlmd4ysIAb2pqyOyq0m7pztx1qAK7FRPHcDc+0g9eM1e8S3H9r2tveW8gg urfBZTx75FIZgNaPPYSahdT7yHw4/iJ9arWGv2U0E0SpKwZQHUfXrUtDHXloY45XtoUaMr+7 Z+dp96z7VLsK3nSqt0i4ULwGB+lQxGXcrFdLJZ+UGnhfdGqMDzioMLdQfZppFWQfcAOCD7VJ Rk2E62kaWEr7m3ExLt/1fPQn3qtNdzxalc6fPvmt51Ihfn5PQ8HFXbUC2ksWmWr2U7s7MM4A 7Y9aydDmistVlRkl8uROJDllp9AJpbWa11CEIfMtZsKrAY2k1DdhbBolUnfvIdVOMD3qbAMv FI1BDazJtJBLrnHToBWq6KvmypKArgCUbs56UMBl3IrIxtz56xkKZMHGcZ/OltppNXthbDEc zy7luicYHpUFGlJrjaNcRXUk/nzW5MaHcrAjHOPY1iQy/wBopPbW9g/2q7laTIBGE64wffPN NaajZgJo1zYas0N0GUZ2yKeTx0ropdTt7NI2tYZbuWI5fcvyKo/r9at6kmVf3j6zrUVzY2Qs 4QNzLnOT61Yv7COazaRJ289eHCvgH2IpCJNGuX0u1hu4bVLpk4fzFyp9jWY9zdX+2OciPc5d ApyUBPSpuAy7urK3d7a4kEjScHf1J/pUelItjO1pGA5lGU3ngH2qgI2tbnTdRdGdjHIMqy+o 960ooBCnmTwSXL3H3Wd+B6VLAqaoFtL3abYRSqisFTnOec5ptxFFrFhOZzJ9rXHkKv3TjruP 0oQyvaaczW04uJfKePhV676ct3BDbmF7clz37LTbAmjiyGXcEjHJXsazL6zFlOHSZSAc4z83 0pIZYtftd/dtJYxTTpEobaB3x3qvcWtxePJdu8cPI3KTjaaoRKq2KCGWGVpZ05lBHyn6e1Wt Q8QXFxKZrNF08xqoHlHGT6/pTsIyZPKudqvdSzXEwYuhBGxv60um6e1tK07RG4toh+8dT930 NPYRN5kkhNxbZKEEDHp6Vm3tncWO25I/dkZ4o2A9guoiUOw9+lV7ZmhYxHnNeyaIddzLaxF2 61h/aBdS4zjBqGUW5D5MeMgj0NUhEvm7gce1IZRurgzytGOVXgCo4YmV8nHHWkBoQSLEeO/H FSynHJ/Wn0DqUZ51nXbg8UyJxE3APuKgYlwQxyTVV03DPWpY0QxWmXJI4qY2u1jnoakohmiC qTiqDyAPjNINy75QWLOc5qjNHnI9ehpFISGMRHJ61pQXQAOflHekMrXVwZDkcUltJtBP60nq BbF3IijDZHtTGuMNuYd6VgJjqCCPOMMO1cv45vjLo8pHBAPFaQWqJlsex/sT+Hhpvw68R+IJ ABJqd8LeNj3jiX/4p3/Kvd4uVJ9a9lbI8mTu2P7cVVvNQFjaPNOyRKgLOxPAHekxI+Xfin+0 Heard3GnaPKbfT2BiZlHzzDufYHt3rxC/wDjJa+HJcSebcTrx5acY9iTXkVKvNK53wp2RoeH /wBsIaZOoOhNsVsEtcgH6/dr6O+Ev7bng/VbqCw1fz9FeTCiS4G6EHoMuOn4jHuK2p14rRil Sb1R9SWrWOu2SXNlLFNHKu5JI2DIw7EEcY9xWbqOkzxsjRSeQ4bIOchq7mro5VozLsrW+tdS lmmfBmkTcUUYwOhxXocUyzoy7sFRzjtXC007M1vfYkKnJwSCO1Ryouw7ySAOlBBQTAYgKfvd aWQguAABn9aQiwTIIhEQCOtJp0KTmTzDl0PAFMER3Nu6SmNZd/fOMbfaodWt2NlBPuJYNgkn 1H/1qTGPjI8mzkJ4UlCSepPT+VWw2D7UgZQuYMbyfmUnqfWsO5+TOE74JFZsZm30W6XKgsJe 3YH0rGljW3cq5DbhlcCs2MpsZI3V1AMZOMY6mm/Z5o4XcHzI48b2C8DPQVixlWcQpcB4/kEn OxjwPp7VmXyzvMxVlEZ7Y/OpGS6tpR0uc2szNLKVVvKU+o6VT0+O2026uUe2+Z1KEMfut2/W kxlgI2nrNDeyKkdwq7GHPl5I+bP4fkaxdSns9Ns4fLhnneQYMjHChvakIqufLukube2eNpUC iRcArj1rH1nRHkaG4hlO7OcJ2IOSaz2ZQamHtbKK4hjBkPzYxVXVIp722tbtJIftGwZMLBgM jocd/aqQGfrAtLzRrmIuP7RVAY5UkOVHQ5A65/rTdGDSaOEQILyJMqHbr6DHryKrpqIZpN5J f2JScyrqEU5jMAU7cY659afHq9pBrFuskRjLfIRMd++Qe3pRYZbgt2jDkx4wzRnyxnjqD7Uu h2sWm6hK15AtxA4wsbtjdUsDbk1CR7CLS4tPit7fKyNcyMFUDIAwMc1iCyuG1G6sQ6Pbxk7T ERjPbmoWgyhf6UlrbecrKskbfOCeKvLr8+riS5+2wWlzboQAPkaTjPHvVWuO5zMcVzqs5l3s XcEt5pI/E/SrtsLO1H2G9nad3BbK8Bf/AK9WSNt53SPbCcKwwSBnFUXs54dQwXdoHGCTwGNI DTnvjo1rJbWxjjgch3bGQTSabdI9wl19ha4WVePn27T6/wCfWpYEeoeDZtUMUqhY5S2GLtxj /wCtQ8Z0xjaDE19ADgxjII454pJ30AxLTWr/AFA3FrMD5xcGNm5wM8jGK6DT/NvUgstVvYoI 4EYR7sKBkdSfqBTYzPe70+1LB5TPfpIdxzlSuMVX+zX092ZYELQRrvKrwAKQFi7ha3RLuY/K 2Aoprz2t0VeNC+0HccUAVL9rvW4C0K7JYh/COdo9qXTIo4pRJclZCAGy/IOD0xT2QjTbxlJY XM81pElmWVUIhHJ7Z571T1SG1e2jlt7lp2kP71HGCfX9aaGY5gfSp/Ox+7bIPPQU2edbSS3k j/eI3zDn9KollyC4Wa8a4jQRqowWYZ6+tSNYm20driC8Qwu21kVuSPcUgKf9q2kMa2Vk0kqs Bh2XGD3FQ3tvqENvHHLxbTHC9xR6iPXluUxg4OaWK23Sed1Ar2TbYx/ERZ2AU8HqPeo7TTlj EbNySM5FSMkvIvNcInFZt7E9u6rz83FAyWKzjSLzCMN3z61XZNshIGRUgQh/nNNuJyykZzik BVSUbvepck88ZpDI5pCDnGRTA+fapYy5CWMY461BcS4HHbtSGYV7qDh3j9O9RwHzEV261LLN AZ2r3z2FTLAnllm4PrUsDMlcySnDcZ7CnybvK4NTcYWqmTg8/Wp5ECcYIoAaj7R7UyRmX5s5 pgVZZzIBjtXJeNbiRrIoCQOnHatKfxES2PtT4R6Gvhb4KeELCMbS1klzJx1eX9436sa6iEER qcYz0r2VsjyXuSZABLV4f+0f4yk0vQI7CCQpJeMQQp6oO345FYVnaDZdNXkjxX4Y6RbP4ktm uUWeWUMN0gzgkHpXln7Rvw3i8OXCXkG/99M4KkcADG3GPx/SvKcfduejHc8bjshFZOuG3uAx 77sH9Kk06zkusxk8YzjODisLmyPY/g18cfGvwsuJI9J1aaW3RgRp12xeBiOowfu59RivuL4M /tieFfiSU0vXAnh/W8hGtrth5Ujf7Dnj8D+Ga6MNiWpezqbdDOtQUlzwPcbu2tjA8sLbRtL8 HIPetSB2QtsIy/TNdtTc4FsSuXSTBAYMuCc9KZJOTGF8svn5Tj+dYgUVuT+/xHjZjk96kjLS MDxkDtSJsWLhuQUPIPU+lRQhg8zhNoJG0qevrTGEkExlLFsIwAxmn3NsF0yQA5CncO/Gc0DI LKQTae4UZ2OGHtyP/r1blV0mCs45HQUugCSWhmR8jPGa565Y+W6+XuO7qR0qGIx7mEhkZvvH nArLuGTzGKhCwYsvGcVmxmVcXMsm7sc54GKq3MRnCIZfLLn5iP8APNYMpDLfT5LiNxCouJIw TljkjFUY5pZGeKQhiDuBA6VIzSsIbbW3vVupna82bkkzjDZrCuGWKcJhpZSuJDJztcEggHv0 HPvQMNHFxqMlxYTDCkFo2K/cI7Z9DVK+mjmuE0+WUYY7hu5MJHBBx/nikIiikX7JJAJWikHT cvJHtVBdUls5pIVYKXUAyKvI4wfzrNllefVbCwRbNrJWfktcOzfl6Vz8NwbW4mSMBYZidvoP pTSJZTvbK4srq3UurQMGYYx8ucZ/kKkvx/ZG26skWWNBnpwD3rSwFiymOoONQi2xHHztjufa s7xNpi3J+2pcD7TA+1tgAINLZjLU+pxLbwCzZ5ZABuJ6vx6VctkbU7aA3TvGDhtxGOM/40gJ p2sbpGiubiVnijb7OxGRkdvxrN0++lmtn+TynKlfl67vepsBVtYb2Of7PduBFLzkdj6im3gs dGmtjEHnnBJlaRRjOe34UwJbqZ9SvzLb2q2sZxuG/AB6bvx9KteIfDVrY3ttcR3SSxAAyvGe TnqPrTApajdxiGY2EDeWrE5J6DtTU0vULqwtvtE/kRzjerJ2qXoMWK705I206VTPu+Uyv147 inabeRm0bSkf96G2tPjH4g0W0EVPM1KLVTZXzSSWiLtibeen/wCupLq8TwvKsS2irKRnfk9P Siy6AVLaZG1ATxRLBnkbex9fzql4g0v+0XF2kpeSP7yKPvDtT2YE1nAGtJZcxpcxpkq2AW+n vU9rePcaUzm5SN0coY1yCwOMH+dS0MvwPhoXGHAwTHMNy5+lZH2hU1OeW4iVYnc7o4V2qD7D 0oSAryajc6beGe2YokqmMr2IPaomleAR+bkws3UjH1qhFrV7OzFrY3llcC480gSRLwVqvq09 xdENaWjwxoMfMv8AOkmBILC4urGK4u5NsDZAwecj2qCw1Gyi862ktxIuwqrSdm9qe4h1nDcp bSwB/wB3L99cdMVkXGmSaRc7PmZD8w56+1NALPPFpRjkhTEhIIz2rUmuTrQSTftTj5fT8KGB 6XBbhVUM2StaKSEWxUdhjFewamDcKXn+Y+xqYHcmB1HQ0mhoWGMhizHPHAoitvOdmkHHapYy tfJs3BeRWJJeEPgDJ6EUATF1nK44Yjk4xWfeyNESuB70gG2Y81g2MqOtWyuD7CkBC5BJAOc+ tIsYUgkdO1JoaJ4r0IRnpUN6yMxdSMnmkxoxLi1WVsng0R2hWLCnB7VBRZtkfI3cgc1PdSAo UGQaljMsxMshwPxq+bJxBk9agCK2byZhnHpWxfW6SW4ZSN1OwzEbcpxjBz6VWnkfO3nFSMry ZiXexzmuI8b6gNoXIUDpW9BXkZT+E/RO0Ea6Bo42j7FNZwva3CD92VMY+UnsfT1BGOhpjxmD PpXsJnmSRz/i7xnpfhfTJJ727jicEBYi3zMO+BXyH8QPGsnjPXJtQuBsgDeXbxHso6Z9+9cG In9k6KMeongXU1h8WaWMHmYL+fFehfGDwIvjTQpYVG26+9C2P4h29s9K5kueDR1fCz43utEa ynmh8tkmgbEkbjoc4wRS2elI9o7DczgbcA8DJwTiuFux0ItwaBdS3UslmqMtvH50jvIFG0AZ 6kc1vf2fFrNnblI9t+FO2Tdt3kdzgdjWEkdNN9D0r4S/tK+MvhfdRaZqcr6toaEI9rcHLQr0 Plv/AE5FfpLpUkV7bQkgsrQKdw6GvRoVXUjaXQ4MTSUGmupckSH5S2cqOPmNVnnBjWSMhRvG f6iug4iO5eRpGkwCDwBipbeAxtkggOM89qkQs0I+SQqfkPbNTQW4klVAceZxnPSmBJPEY3ML ncc445plkTNb3McvBKkKcfUf0pDM/Q3BE0WR8w4+v+TVgP58iscrkdDQtgNNk8tNwGR04rC1 J8eYgRdrkN9OKliOcvI/LBOF5496ybqDDlTiMDJLHp9KzaGYs5eRsopxySao3MP+kBg37vPV j0rBoZLcTyaK5a3EbDHzODnGR7U66sXEKzbkaJxlWXjJpDC4W3tbOC8tAGeJT56g8knjBNZV /bT3V41zZqrRLGHZickZFFhkdpaSjzriaWWCLkK6rxnv71k6hZGeea+sUWZLcMGkckFsnhiD 3oAqfa3mtlniYPNGpDj656Vn4+3NDO0kkaLHhti4JNQwKskdtrBaMklweMn29aZfWy21h9ji mWLH3WgO8k4zgketTsw3MHRLF9YeWxukeSWFiYz0xx0qyl1bwRXNlHB8xHzKxyCR6VqIz7G+ uEZ7Vof9GZvnEYIwPTmrWlW50nXzFPbJNp8oO3z+Vz7+4oYyaKKPRyGwJvmyjAAg+1WY74FZ oZYnUTLvgZeVGT90+lTYZV1CyS2aGYuTu/gU8j1qlqt88Foxtowsf8QGMmgC9ZImvaPb3Zd4 b2MlXU/dAGCCB+dWdZEOoWDXEdoDDAwLvu5BPt9aze4yjqWnH7DaC2nSaSZcsgByh44/X9Ky rSwnjuGiuJWSInOHP3SOtXF6CJf7RTQtRtYJ9sdvMPmZ13Haeh+lbkhhguZYfOM8flZjlhPA JGcYP1qZIDlr7SFlvba7WYEnmQA5IPTFaGvSHT7YTWmyRwAWCDJxVbgUbXVbzWbcPHu82Mjq NxxV3U5V8Q27wXc4+0Kg2lFAOPTNAFLSHtLSOS0RlmlDbdznLKfQ+lPja9/tt7u2sGijt0QS KG3DI/jx/OpYEl9AunpPqdw8Uhlmw8QYArn0FQs1tGTLC2FyGUqM8igZDqEU8ifbEVsd26YN KILeK0iumbzXbOU7imIkvrqK60ZTbxcs2AwX7n1PrVODSr29RLe4YGB13IOM55yaNgG6RaR6 VcSRSrgBiee/vU58UXMPm2YA+zOM8jn2OaW7GV4rIzpJLM+yMnK84AJpYbKWPfZRNGY7plYO V5U+oPamhDdXs7mCMpFMpEZ2vsbOfcU8I99b2xaZZJG42jqOcc0CIriOyKzWk+BMeB35rOj3 2JaIDIfhc9qAPYjjBJ4FV/tghdkPIPAr2TYq3ShYt/XmobQuqhj9zNAF1HDEjOCO1VtQlmRA Ix8vc1LGZN1cvHnBOW681UhA35PJPepGWyvlqGKkehqmbQ3E+49PSiwmSrGluSq8UwgtwWoA aE2tRIy7CB1pMCrt/WoJXbJHOB2qCkV5DzRC2WHWpGaMDKEOSM1GqeexGaljsObTyOhH41YM gSDDfrUjMViTNu7A1q2haZMk446UwJ1gjLHcB+NYmtlIpAVACnpipsBlz3MbW5yecdDXl3jS VpDMSflGcCumhoZVNj6R/ZN/bT8Pr4btvAXji9jsbizXyLG/uT+6liHSNyfulRwCeMemOfYv GniHS5LDbpV8htW5jazm+Qg57qcYrslP3dDmUdT5U+JXjrT7K+lF5qCSTZwIt++Q+2Ov5153 a6tNrFz9oP7uMf6tM9B7+9ebN6nVBHTeH7s22uafOSQEnRuPYivqa/tVvbIJuGZF4Oa3o6pi nuj5n+L/AMKbm8up9a0yF5ZVlZb6KLqzDneB7jqPauO0rQYr23iEcRBVSM9d54/UV59SLjKx 0Rd0WbTSGtblgkIkdQ3ySrw4B6c8dO3eq97ZSQ4MASJlGOEJw3vjtWMjoibGtWjX9vpdpPaG 6NwGKyRIRzkAgk8Y6nqa/SP4Z3y3/gXQrzzQ0jWUW8H1KAn+dbYbRtGOL1jFnUs3KHbv65zU bSO8OFhC/N0B/Wu88sjkjMZKEMCe/wBacpZNib3YAYBY8mkIIYXELHeXbJGSOnPSrUELPcRb lC7SCDnufWi4y7cRoY3Ib5g3b86i0WAyiRQT99lO76ZqWx2MO0P2bVXg4XY7L+P+QKkH/Hy6 knarcc9u1VETN4xgRKvGMDpWTqMP3cdxg0gOfvYUEUuWy/G1cfnXOXMrF2BQlRgZxwDWbFcx riNnMkTgoST0NUY7KRvMWQBge7HNZSGmSWdos9w9s7JBkAZc9B0pNQmMNm2mqTmNuHx1BqEi jJSLEEkDSsI2GCoOKpDUU06RoEjaPsSTwR2NMRPZ6nM2UduSThlAAHoaz7uxkExa7HlRz5JA HXHBpDKdvfR6XqAiSLzLIIGYsO/TmqUbPFdMpkBgkOULDGD6VLAzNQtl0rVgYv8AVn58Y/MY qzealFFp7AW6IXwyyqcbSOvGOallGILa4guRqYmMSH5iRkHPeszXY4X8nUIpSUJ/eFRknB/n VoRZu746lp/2nT1cBCoddu047n3pn2O91q0DqxQ25z8+QGHtQBet4YLjSXhYfvI23DParNpM k8YgWJoyg+QheCfTNSMhS2FzLJ9scs8Z2hTUepahbiWG1tY0CKmJvkx83GD/APXoAr2lzfLd 4SPbGCCzngAVIdOjg1VLuNwIw3RTw49KQxl88rTRywAwxCTYHdsKD7+1Vbqzub+WSdpEEIch pE5HHpQgJNUsdPurQW7zvNJDwJSex5AqM6gsiCxjBiZUI6ZJI96BGbpttcztJBcAo24kgk8Z qQ6tZaVepYMCf4D8vFG4Mu2qfZH2wRON3UoABiqep6C+mapDfW8hEZIIG7JBpJgTTXLacJNR s0Dy5LOzIOuO9MTXrvWoVZBtJGG2cZ9R9KLXAr3umJqFvcCSaNZU+ZUDfN+VQ2wNpbqsbZyA F77TTQFMatObiS0kcuCM/P2PtU8EbafJILhEbII+c/cz0Ip7AXYVe13RCQtbMwk2/wALGq2q 3MiTrcQ52AjHqKgLFtomjtlnugAjc7sdc1Qv7iwudOidPkl3EYHWhAVLP7RqELWm0uOqcYP5 1f8ADsbabdx/aP3hiJGxz29KYFTVddFtfmGOFEjlJyDztGeKbC6L9043U2BT1GyCypLhsk5G OtLe3atakKrq46sRjB9qSEeoXWpo6sqkFPUdqWzZbnA28jvXsmvQluIjv29qmto08vY2Bx3o ArGLbNkHPHWhrhVyG49qQzAvT58zFRjHao7WEtKCRkdTUDRbvb3y1EbDg1JaFHiBABHemBUv EAkYj2yKrISWIGMetADZHKjBPNRthVJPWpY0R52kH1qCRwST0qBjFQSA+nvSRxgE46Uhko+X PNPh+V8g8ipGPlu23AZHFRvIZG54FSOxVlkXBxUsFyyL8vNTcZNHeM4BP41l6zMky8Z4piOa v7lUt3YHgV5n4mvllsLgt1wSM966qXwtnPN6nzprd6Zb5wDgbjVjTta1GKPy4724jjPVVlYD +dYzZUTr/CaNLcBpPnJIOTzzXuWh2ES2SMBziskbHRWEGZ4SRwGU8fWvpmCGWfTrNo93mKBk enHWuyhszGfQNItSt5fsRk+aH2sOOVGf5VyXxE+E8dvpl14i8N6fubk3drHysRPWRVHI+nI+ lZ1oXVzSDszx6MCRkEytC6gFTncHyPX6f0q5qdkljeWT21mJRMD9pMh4V+vyj0PHH515stTr iyha2Eto8TtcCECXeJGBCjJ5/IenpX2t+zpqkV18P7BA4lWINGChB+65UfoBV4fSZniNYI9Z Nx5ixMI2XBwMdaIUZo5T5hjAO488ivQPLY2YB97+YSyjOM5yPWnxyMyQOSpbqcHjmpYDbqby 7eQhMKJA2AevNTSsSkciyHbIuRgemKVxo2bMRyn5tx3oOg9//r0/Tolsb+7CnhwjKO47N/Op KOd8S240vxKZY87JCsvP6/qDTbjEWo8KSHQEZ9uK0iQzZtJBLDHkY/h4NQ36hU6H5T1pAc5q Vr8rsD8vXNczfwsqnGeucCpZJhXkMpIk+fAPIU4zQlv5kiSKoVicAM2QDmsWhjdWsI4WFw0v mTZKvgY5/wAKyrmw+3Wd1M0siSQqpROgYE80IZkPal7L7SSx8scqOTVjTbi2v7c28kaq0mNr ueQfXNKwGdf215ZTzJGG3Q8b1XqKSG/udSgkluYI5GjcMJNuD06YHHak9iipeTNPaXL2qrkH dIo5JXP6c/zrJjVrwpEgIiGCOMEGs2BPPbfbIEimZUdCf3mBuP1NYaOJY7qwnj2Op2jt/nNQ UMfbcWv2YgNGBtPPJNR6Hoc1ok0NzJGLdiSFOM1aYiraznQ9UNsyu0MrFSCuQqn+Kta3s1sb uSFZgbaQ/K7AnIpMCG5tWstXiC/Mu04VF+8cd6p3+qPZzK9uDFs5JfsfSgZJGHfN9KSCy7+O +faopjbTM92h+yeYQkgQZwPp70ANnji1PT2eNmlkVflwhAOKq+HdO82wlhvc7o3yoDE8HtR0 AsnUEt759LuLVIsr8uTnI7fmKisJC0UkEsLwwnmM7gFb6+lICPSfDUg1mckeZHyWj3Zz6CrN +kENtPd2lyiS26l2STgEAZwD69sUr6jKyzrq2m217EXjlZjuYr8pU9s+uaqeIdJt9Xe2vInj Se3AVjGuN59T70apkmpNcLNpAS0lWW4QAjHJbHODWdo89zr1qUIKtCCcEDgdc0dB7Fy31S0t 7K4tJS8plyCTwM4qHR9BuYUd7WJFQHqx6j1pAc7qltd2OpKrIXyxViBkY9avwxWtlLEt9cOt u+HZ16LVAF6+n30vmWUe9QdqyYOSM9adqWiXdzatJKBgEd+T9aV7AECLbWW1gGkiA2xv/FVa HxFLfLLazwRpvOUCLjBotcCW2tp7qbyrmYomNqh24z2wKrSafDY3DxyRs8ivkYOBimgM27vr uzv1mt5CqqeAB/OrZkkkiFzJ94nLEUeYFe8ht9RtlnXmbJHBxj61YjtWk09Y+PMXnK9/rSEJ CjuF81slRjmknvLSGBkYbiTggjt60hnYRREKVHGeorW06KW2GVGVNeyjQ0TA0g3kqB71HNHi IspAp+YaFUyjAwQSazNQYiUlecjmpY0UoAzzbfbJJq7LH9kTepDeopIZTeP7awY8Y61Z8xbV AqAZPBp2GUbjc53fnVbftOM49RSERpgylieB2zRJMoY55WpYyhcXB3YDYGegpgl6kn3qRkdv eb5CoOBVpJlTJLDPWpEmUm1EeacnirMFwJ/uk4qS0TzgBcjrUYkPlkjoKkZRZizZz1qaGTcw XGc8VCGXZyI04HaqAMDRP5wBBHGaoDi9bxHHIEztycZ715X40HkWEpzjIrrp/Ac01qfP14fM vX9C3WtGyjVsYFctQuB7z+zb8IdU+MPjmx8P6Yu2SQGWWbGRHGvVj+n5193/ABF/Y50n4bfD KC6gvZ7vXWmji64Vs9QB9Mn8KqnFNNsyqTkpJI4vwF8AbzVNP1LVLwFLDT3COScFm64H6fnX pd60Gn39nBAwET2qbue4GOfyFdNLQbfMRRIGv7pchhtRgR9Kt2dwYJGTPyt94How9DWzVykz kvE3wUh1tm1PQSjyLJ58tkcZVj1wuPmHf+Yrzy60e7tJniv7QxzAyZzHtJPfjHBrzKlPlZ1R nc5rV/DzS6eHbzoVXC7mcttGc49ATXvP7IGvJcaBrVhw0tpeHnH8LIhH6hhXPTVqhdZ3pM+l o5HMUZPJHXPHFRSwzBZpdjHzDhOwYACvQPKYr2yxMWb75XBbP6UlsCsaqoIXO1SeM1LAn8oi J0MgL8sQB0FXdPj3WrqTjaTj8RSGXNOP+iNuTEykoufbp/KpARHqAG5iZVYD2PXH8qRRn+Mo hJDaXBHYqfrwf8aypypS1m4PY59//wBRq4kM17BlMR2gdckVNdROsqnClCOlMDDvbbYjDr/s jtXM3iFCUGc9j0yO9JiMC5R8ugOFIwazRBJFlWl2r69KyYENyyy5aSXccY6/zqt5rCR97cGP aFxwR0qRi6fPZWKPHcsPLZGAUrxu7GucHl6fcgRKWJIADLgBj2FIBLm8vJLx5nuJIlBG5VGQ O1VRa/Z7tXecmEnccE/MPcdKlgMfybHUZDp7zPbTKQcA4OQMjFUr1p0CyqTEgbcCwA/U1JSK c9oTh5mYQOd6kdm9z6VWlvFsJI5ECyB+HBGSSOlZsog1m1m1JFntVaMj76rwT9DT4R5Nv9su wVYja6s3ORzkgU0BC1zZ6qiuFLNEwyU6gen0qxqNtPrHmWsFq8RjXjcCCB1piM+3jkuNODzT MkkJ4KvywHvTBdpFYTQxWxeTO/dj+ZoGVIbq4vMoVCwH5CqvgDjHOfxpNKjSz1Fre6mCw8Zc ncM9qYive+JW0y+kRy8tswPl46VMPNtnhne4a3spcfvEXPBpMaLN/a2889teQhXYEYkc9cdz U2qfa77TZltCHkT5yirx/Ko6jM+xt73xDpyXwneC5HySRx/LuxxkU65OjS6S1hbiY3HWUTjJ BH92jXoBW0W7KwmxMTzW6kkhBjB9abp+kzQasY5SBay5AVjkjAqhC6tqMfhS7T7LCgRmxvIy cd6XTbqaC8MyFYo5QSCvTn2pWANb0tZbiC/RiVBwfQkdKW81CW1t90JlMjDLJkhce1TuIzIt Rn1UOhySvALcGrVvpkN/bvDdypDOFJWNjlm96oYujfajCmmKkO5NxWTox79e9VlmuIXvPtFy EmTC+Ww3b+e1IDVs1t0lg+0ea07fMsajr7Uy70yG5a51GxZS1thvLYgHbSGYOoLNdlbvDbl5 O0Utvm6sp7wygyRYLRseT71ZI2K6ivoBuUgv3FX008TaeYY9yljzuqGBiQ6ZLZXeJOVBwdvW n3V/JaXarGwMRPQ96e4yeXMhSVcCMjJLHpVLUtKVoDcxyhgeCtAj1KGy2EscMOvSr9jO0bkF MrivaRYXAZ1dhwBzjNZ0kztGUU8NwaGMW2sGALE1BfQKFLHoPelYZUhg3knkY6VZt7QAtubK HmkMqyFLUuoOR1GKqoz3LnAz14FIZN/Y1/eLi2tpZCOyqasWXw58RX7EizaP/rocUKMpbEuc Y7s6fQvgTrF8SLt/JHqBXWWX7PNnEoN5cPJjrzW8aGl5MxlW7G/pnwa8M+ao8pZdvfvXTW3w Q8K3gIlsYyp9sV0LDwMHVlc8k+MH7NUelQSXvheWTdjm2PP5V8vXurXekapNY36Nb3UTbWRh 3rhqU/ZysdNKpzbiR6mZnyH6npXRadeCMAYHTqK5mdCepp/bAeOoqZZk8pgcc1maFB0Cng0+ 2k8ol84NJAyK81IzHAyMdqpLN5vBP60XuIw/ETKkeMjPvXjPxNufLtCFPB44rth8BzT3PCXy 07Y5ya1tNJ85c8Vx1DSB+h//AAS3vNO0Xx14oub9kjmOnJHFI3Yb8t/IV9eftB/EzRfO8PWC XIZpJXmJxxgLgfqa2ppqFzOavOw/S9Q0qz/Z+vL0XUQa8aS5Yg553YHT2UV4ld3kWqXdpcwP ujMQORWtNdQtZmtpsnmTyqR83lgg+2TVp5RbxbnXjPJ6fjXQMjnuGgV5Ebaw564NY2u+I4tZ txBr9t9sKLsgvomKTRD0OOGH1H61nNXWo07M861O01aDTZ5ILJryx3Au8Z3bc8Ln8+/NbP7M FrN4W8eakjTJKNYtlujCkZQW5jdkCHPBYhgcjtiuLl5ZXNZyvGx9g5doEcjCk44NSTBpQiSO SiD5VBwBzmrucbQkxTyQNwYMuRxTPPDRgRoqvxgDOPr9aTAtWjCVWZhtV8q3HUY6VatooraI xKCffPagET2MxaRiTgAhiD1xS6rcGGGOUPhY3WXg9u9SUi5r0KXejucqqrhwzH0/+tXJNtay JU7ghBA/Ef4mriSzU0t1YbYxgsuea0jETFk81YGfdQiZT2YfyrldYthgsvJGRxQ9iTn7hGaP jGRzyKw7+yW4xvJ3Ichs1iwKEwRYwUO9xxwOtQRu8qgqdzL2xwazGNt9PbWJgjPFbnGS8rYU CqOrRQ2ckvlNFPLGMrIgJU49M0CKC6g9/EdnlmToVUZINQ3Fq00Y3ABwc7c/pUjIoXJAClUf khW4ANVdlzqnn2csqecpyrnlV9ePrSGRx3xVTbTSCVx8pPTpVC4a2eDctuN65UMeSGqGUUYr xiz2bSHDDBKggg+1LZWgM3kXIGCdoDDqO1IC9BZQ6a7oZkO5sbFHIHuajUXS38e6baJOkzN1 HYGouBFd2zrvaS58qNBuAjUciqd7JBaTI9tJL5FygMuOp9RTTKM3VrSCO7S5ZnnsRGS6Qg7s nIxkYz2NZNrp8UsIluSI+cBZDyBngn8K0Qh7araz/uVgBETfKUX73vWoLK5vVEZi8ndH8oZs fkKGBZ0KGa5h+y3NqkRtYyxdeWf3NWDrRFrHJEURM+Q8LPhnz91gO9ZsZUsdNvhArjbFEz5K BsADvWZqGh21nrIu1bcchsJwM4/WmmIZrDSSWv2izbbFGdrqh71XSO6vrOO4ZpEQHk/dVR/9 emItSR2l9ppt3cSrGudrHJPPrTov9IsBZRRghOAQMkcdM0rjEtJJzYnTXg5WQP5jHBHqPpSN rMFjerbPCZVHytuPQH+dRuBVskig1JhEzLvztwvH0qe58NXt7fK1tE5nfjB4Oaq4E0+ieRos +oJKkd1bn5oZT8w7YqldavZ39pp80FsTqEfMpPCvjpTA0NW1i81BkvbRIrC4iQKFh5Ix3rn7 d1jM0kkrSzSDJ7c55pLYCODW7ouITGvlngrj8qkGlfZZy1y6QK3PzHkj0p7CCeFLSfEZDx5y rDvUerTXMMizQFkhODheaFuBBHeyi3eWSQN7jmommg1C0PB85TgBuv1pAJaxXTRC2/5Znow6 AVWtYWtLp7Z2xGx79PrQB6tFfmbMedpHatO3k8i3LNlmHoK9noXcfARKpJ4z2qGOziMj9c5N UCC7jaGM7cjI6isaSTdC6kljjp61LKLnh7Q9V1dNtvZTS4OAduB+ZrsdK+Dmu6gSZilopHU8 mrhTlPYzlUjHQ6bSv2erXzQ+o3ss3qF+UV2uk/Cvw7oaDy7VHPXLjcfzNdMaEY6vU5pVXLY6 S30Kwgg3xW0eB2x0qACBZynlqnOAQMc10ehlYisrkXXnRTsImU/Ky/Wsw65axxTQXt0mG3Iz BsED296VhnM+HdYtIrtoY7wTNnAOc8VD8WPH2u/D/wAPtqtjELuFOWwegpOXJFtCtd2Mb9nP 4p6r8WdSuLnUVVbaLhEA4zXnX7fPw4s9Jh03xdp8XkXDP5Fxs4Dd1Y/qK5qr56XOaw92pY+T /DOvJcDcWDMO1drpuq7yBjk9685o70zegkyu7OfT2qwkvynn2rFmlxrTEDGeajErjqc/WpKR WnkKHJGM1CJwOehqbgYGuFppcE5HWvJvihCqQFeRXfB+4jml8R4cW23DccZra0dQ0yn19q5J 7lxPePhZ4gvvC0wuLG4e3cgBihxuH4V614g+Klz4xFkb/dLPZqVjdWx16/yqozajylON3zG7 pHxR1F/DP/CPPNtsWztQngE+9ekfD26a+0WAPgtHlcg5zzxXVTknEyatI7qwi2TKejBcN9M1 Yvogy7SMq1dCJepTu42lhYD7+MA1xuo2z3M6o2RgckVMloUjW0Np9PRo43KLIoVh6j0PqK3N BsZz42t9QIiUyAtkRhPlA5AAHtXNJaFM96sVkaDBcNt6EmrPysP9Zu9gKxuYMjnK+XGxDBhw AO1NEaSEjaUQn5j0OakC5CfKnLbyYscR4HX1qxBJsYSFgyv3FMCeCfy50PHzjyzk9c1NcRvN bBQoBGVwR1pDNGyK3ujNHIAVkQocduMVxFg7Mk0IGHIxt9D0/rVxJZe0e4wIXbK46gV0/luY XxguBkCrYkZzDzCGKjOMZrC1WEBsDqR0FUJnM3aMjFcDHTNYN1p5BLGQBc4weeKwkBQnRLWT uwJGQBxUIijhVmRCseM7s96yGUWtoolDGXG4/c6ZqrOkFtfoWiWSH+JTnn1pMDNuJmj1gizh EMR5VF7+9Nj017q/Qz3TWyDL5f5lz7CkMr6pFBpkAlPlyO2MKo5NU5llEkF00XkZ4U9Rz6/S kBT1ixW5uDKzvC+SGaMYDED0rOuoEssMN+HPIkPGfWpY0LJcszrsj25GGbGCvt9DT9Wjkvre O4xmWJdgG7t71n5jLVsls+nTTSrmeKPKL13kdQfwqnbah/aMOw2+5kbPljOAO1IC35BuLWfm FFxwW5I9qzYolktjBMjNH1GOMc9jQhlQajMZGtHTYmCFB61ClnBf3aW8nyZHJY9RVoDLv/se i6mGQhivAQDn8TWXr1zezNBdQSPyccscoBVoRo+UsVn9vkvp2UrtKggE+xqe31KwuLdZp0aY 27Z8tfvYHI5qWNFu7+36tBcNEklhbyJuiBxkqR0rJ0ywkvLbZdSMXj4ALcmpVrDLker6faQ/ 2YsaRzS5OB8x496li1G4mtvsDxKtsW3EvgYoEUNL0O3sdTuJJrpvLK4REXOfxqTU9Sk01lNt IUTP3VHJNJ7gWTqS3MEd55XlMeJMt8vT9Kp67psVxHHcW8gMikF1TnrSiBZguZreBJ7eBTcr HkkjOR61Sn8Sapqd9JcJIILllCqsXGMDHAqkMz0bzn+z390TKx+diOSc9z/WnJCthMyxos4X POO3rTAzmgurG9M25o458jPtnmtMx2tlskuJjKhHKr3P1oEFykV1ILi2RUhIwVByc1Fren3d /ZKxUlwN2/vgUXEyhpzsYGEzj5ejMeadZ6q86ywSRDYeVx1FMAtbb/lmzBVc459aiuNKa2uQ oYEeo4JqQEvLh7eRVSTatMlnFwu/AJ9RQB6PY2jNcIxbAxxXRKywJyK9hbGhQmuWadF+6M81 r2dk7bjtJB6EmqETxeGru/l2PmCLONx6n6CvUfB/wmsrZI7mS3Vsj70oyTXRTp82sjnqVbe6 j0y30G20u1XyokC+wxintArRHoCM4rsSsrHNuZd3cC2wWkRV255NYeqeMdJ066Zpr+NVZAxG 8cEcYpdLjOE1j9ovQtEE8cchlycAL3PrXm+vftLXEuTZQkc53H1rnlXjHSOpooPqcPq3x61m 7y32tYBjna3JriNS+LVzLJibUXz7NXNKrKRpGKLfhL4w2+k3ySPK5IPXJr6IsPHdr8SvBGpW yMMmBlKsPatKU7pxJqRtqch+x/qv2DXb/TeQElYdeeDXfft2yA/CFwcEiUEcfWne+GD/AJeH 5leCdcK3bpu4ycZNetaLf7mU/wAq4Edh3NkxMIJ796l83ZyDxWLNUQi43TfU1PPMqKCfpUFl OW5E3A4xVWRj+VSG5n6su1o2xyRXmvxH0xrmzeUcYGa7Yfw0c0viPA7mIJdsPetbQ13XSAdQ fWuWRcT13w4+2JV9utdrpmNgPep2NEaytyDXufwWnMuivH12sea3pbhLY9Shuv8ASI1+UHac +9aDfvoQ2NrV6COcxpbhoGdWOcVz8F0txqLHHykkD2xUyGjrbawSKLzB82ELcj2pItbFtrNp Jjy1CtHg/wAORgn9aymhLU9m0ycT2iSggqyDOO5xWioRACWIyOOK42QM3RjanmHg9++acUYM 8bkOCRtCnBH1pIReSQFGwuQSOvY0u9UQBVGMZwPWmBbU74YnAGRhgKuQzBvNwR8r5+b070DH abdL5Usa4VUbOB0Of/1VzF0xttekCkkEn9eRVJksksZAs0seCGViQD7Hj9MV0YuPNVQBhj1N WyURuvXtWbPGrg7hnFWgZianp/nxYAwfauPvrZlLox5TnINZSQ0ZbLHJEQzNuXnA61nXFxHP DsUMpXPfGfrWL3AqhlmjCbBkDOSaYLlJ4pWg+c+WVIP5VLQGfCszWoQy+RIoO1hjr2FQ6dp2 oayzRMpWWPLZkbC4pCKE2m4+0RSyfPGTnyzkA+oNV4Yobi3Nq1y3mAYVTkkGoLK2n28lx51r JKWZeQ3TBplxA09u8MgMrZwxLYKmoYWM2zvE2tC7AyklcAZI9yah023laeeByzsx7enrUlGh An9nXBDvt6oTu/zmo5JLTw7foMyu84/1pOVAPbFISIp4jJqcQQEqTwwPGKlSJLe4MckpaLPI zk//AFqRSK+tTRQy+bBCoOzd6Gsa8tbrU4EuYiY3jPOBjI649qtMQiTRTQxvLDGshGNrjcT6 9azbXVnvbmaBot8anAUD9K0QBb2rPIRdIkUGfus3JHp7VasEGkz3IcpJDKpQ9Bx25Pehgitd +INQt54rV3H2TPyg/wB3pT0E5uUmOxYiQANpZifpUtWGWriG0ttXiuwu98AsCu09MVT8X3Al gSey/eyLneF6c9/rS6gZ/hz+0Nbs2vFBBtly4J5GOlaM+vWviPcs0CQ3CKAMHkkdSaUtwLtg sWoWTWIAYZOcLjJ7VjQWklnqYs5c9NuB+maSAtS+In0iVraKAAY+ZyeqnggVTnmAu4bi2U7u VGxeT71SQFLWdJlufKu0bLgncrEZ+tWrXWW0uNLr5DIBhgwyPQ/hT3EVvtL63CCBvKk7QOKv x+GZLyyla4kSJlXcq55oegGPpsw09mimOTyQD60P4gujO0XmYUggL2xQIQWLRKJJ8KjjI96S +05YJEmgl3pgHigBNQIuQhiBQgcjNJBeTTN+9YsV6ZpWEOllt7mJwwxKOx9KrwWE7khSvl9C T1o2A//Z ________________________________________________________________________________
Subject: Re: Nose wheel fairing clearances
Date: Sep 13, 2016
It appears to me you have cut the notch too far back into the rear section. It also appears that the rear of the fairing is to high. My notch just protrudes into the joggle of the rear fairing. The majority of the cutout is in the front section. -------- Bill WA0SYV Aviation Partners, LLC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460470#460470 ________________________________________________________________________________
Subject: Re: windscreen
Date: Sep 15, 2016
That's a pretty big generalization. "...couldn't get the fiberglass to look good...", really? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460494#460494 ________________________________________________________________________________
Subject: Slick Ignition Harness
Date: Sep 15, 2016
I made repairs to my Slick harness and have some things to share. I understand there are various mag models and this may not apply to them but mine is a 6351. The pdf document that Tim Olsen shared (Champion L-1499B Ignition Lead Assembly & Maintenance Manual) is what I referred to. I bought the T-200 Slick Ignition Harness Tool Kit from Spruce and three 72" lead assemblies (Kelley S100-72) . The maintenance manual is somewhat inadequate in that it referes to Slick Ignition wires that apparently differ from either Skytronics or Kelley. The Slick wires referred to in the maintenance manual have a coiled center conductor whereas Skytronics and Kelley have a stranded conductor. On Slick wire you have to insert the little screw (that holds the spring) into the coiled conductor but on stranded wire it is crimped on. I just happened to have a crimper that works which I got from SteirAir to crimp the pins for my intercom connectors. Since the spark plug ends are already on the Kelley leads, cutting them to the right length, crimping the little screw on and then pressing them into the mag cap went well. The Kelley 72" leads are somewhat expensive, for me about $85 each so to build a complete 6 or 12 wire harness would be out of the question. Better to buy one. My problem was I couldn't find out how long the leads were in any specific kit without pulling one off the shelf and measuring them plus I had 3 leads that were long enough so only needed 3. Also lead time to have a custom harness made were way too long. I see big problems in trying to make your own harness: where to get lead wire and where to get the various parts at the mag end (drive ferrule, insulator sleeve, crimp on connector and spring). Plus you will have to make up the plug end also and get those parts. Repairing mine using Kelleys leads worked OK for me but next time I'm going to look for someone else to make me a complete harness. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Subject: Re: Slick Ignition Harness
Date: Sep 16, 2016
I'd agree with everything you said. FIXING a harness would be affordable but these days the prices of harness co mponents is just too high and so are the harnesses. We're all screwed if we want it done cheap. The cheapest option would be to find a harness that we can use 1/2 of. Unfortunately it's almost impossible to buy a 1/2 harness n ow. So you buy a complete system and only use 1/2. If you're lucky and can use a stock part number then it's not totally unaffordable. But finding a consistent proper length stock harness is tough as slick vs Ke lly/skytronics don't seem to follow the same lengths. Having a custom harness done is not that much more expensive if you go Kelly /Skytronics, but, the process is painful and long. It took me many emails a nd phone calls to get the guy to get an order set up for what I wanted on th e RV14. Then it took a good couple weeks or more to get the harness. I don' t remember if it was 2 or 4'weeks but it was long enough to Irritate me a li ttle. Still, it worked out...and if you need every lead to be custom Length it's still the cheapest way to go because buying all 4 or 6 leads is m ore expensive than custom. What also would be maybe even more affordable an d possibly quicker is to buy a new stock complete harness and then tear it a ll apart and transplant the cables from one harness to another to make a cus tom one DIY. That is my likely plan I guess next time. One benefit is that t hen you will have a spare harness cap as well. Sadly they make it so expensive and tough to keep these mags in service that it gets tempting to remove both but I am Philosophically not ready to trust 2 electronic ignitions and I definitely w on't be trusting the P-Mag, if it EVER comes out, for at least 8-10 years. I f there weren't issues we would have seen it years ago and I know fears were issues. And the talk about impulse coupler problems has me wondering if har monics aren't their big problem. Anyone know if the engine gear needs to be changed if I pull an impulse coup led mag and put on a non-impulse mag? Next time I need an Overhaul I think I 'll go non impulse. Anyway, harnesses are a pain so my advice is to care for them well, monitor t hem for issues, and then come up with your plan or a replacement harness BEFO RE you need one because it may take a while to get what you want. Tim > On Sep 16, 2016, at 1:16 AM, Albert wrote: > > I made repairs to my Slick harness and have some things to share. I unders tand there are various mag models and this may not apply to them but mine is a 6351. The pdf document that Tim Olsen shared (Champion L-1499B Ignition L ead Assembly & Maintenance Manual) is what I referred to. I bought the T-200 Slick Ignition Harness Tool Kit from Spruce and three 72" lead assemblies ( Kelley S100-72) . The maintenance manual is somewhat inadequate in that it r eferes to Slick Ignition wires that apparently differ from either Skytronics or Kelley. The Slick wires referred to in the maintenance manual have a coi led center conductor whereas Skytronics and Kelley have a stranded conductor . On Slick wire you have to insert the little screw (that holds the spring) i nto the coiled conductor but on stranded wire it is crimped on. I just happe ned to have a crimper that works which I got from SteirAir to crimp the pins for my intercom connectors. > > Since the spark plug ends are already on the Kelley leads, cutting them to the right length, crimping the little screw on and then pressing them into t he mag cap went well. The Kelley 72" leads are somewhat expensive, for me a bout $85 each so to build a complete 6 or 12 wire harness would be out of th e question. Better to buy one. My problem was I couldn't find out how long t he leads were in any specific kit without pulling one off the shelf and meas uring them plus I had 3 leads that were long enough so only needed 3. Also l ead time to have a custom harness made were way too long. > > I see big problems in trying to make your own harness: where to get lead w ire and where to get the various parts at the mag end (drive ferrule, insula tor sleeve, crimp on connector and spring). Plus you will have to make up th e plug end also and get those parts. > > Repairing mine using Kelleys leads worked OK for me but next time I'm goin g to look for someone else to make me a complete harness. > Albert Gardner > RV-10 N991RV > Yuma, AZ > > ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Sep 16, 2016
Tim, I note your comment, =9CPhilosophically not ready to trust 2 electronic ignitions and I definitely won't be trusting the P-Mag, if it EVER comes out, for at least 8-10 years. If there weren't issues we would have seen it years ago and I know fears were issues. And the talk about impulse coupler problems has me wondering if harmonics aren't their big problem.=9D The RV-10 is the first airplane I=99ve owned with mags (the RV-8A now has 900 hours on dual pMags). I=99m now pushing 400 hours on the RV-10 and the mags are in need of overhaul. I=99m also on my second set of overpriced aircraft plugs. After careful cylinder balancing I can fly LOP, but above 11k=99 the fixed 25 degrees of advance clearly shows it=99s limitations. I have some sympathy for eMag on their extended road to produce a TSO ignition. While the experimental market is ready, they see the prize being all those spam cans out there with owners wanting something better than a 1930 era magneto. Considering my personal operational experience with eMag, I will be installing dual six cylinder pMags on the RV-10 as soon as they mail them to me. Carl From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, September 16, 2016 8:03 AM Subject: Re: RV10-List: Slick Ignition Harness I'd agree with everything you said. FIXING a harness would be affordable but these days the prices of harness components is just too high and so are the harnesses. We're all screwed if we want it done cheap. The cheapest option would be to find a harness that we can use 1/2 of. Unfortunately it's almost impossible to buy a 1/2 harness now. So you buy a complete system and only use 1/2. If you're lucky and can use a stock part number then it's not totally unaffordable. But finding a consistent proper length stock harness is tough as slick vs Kelly/skytronics don't seem to follow the same lengths. Having a custom harness done is not that much more expensive if you go Kelly/Skytronics, but, the process is painful and long. It took me many emails and phone calls to get the guy to get an order set up for what I wanted on the RV14. Then it took a good couple weeks or more to get the harness. I don't remember if it was 2 or 4'weeks but it was long enough to Irritate me a little. Still, it worked out...and if you need every lead to be custom Length it's still the cheapest way to go because buying all 4 or 6 leads is more expensive than custom. What also would be maybe even more affordable and possibly quicker is to buy a new stock complete harness and then tear it all apart and transplant the cables from one harness to another to make a custom one DIY. That is my likely plan I guess next time. One benefit is that then you will have a spare harness cap as well. Sadly they make it so expensive and tough to keep these mags in service that it gets tempting to remove both but I am Philosophically not ready to trust 2 electronic ignitions and I definitely won't be trusting the P-Mag, if it EVER comes out, for at least 8-10 years. If there weren't issues we would have seen it years ago and I know fears were issues. And the talk about impulse coupler problems has me wondering if harmonics aren't their big problem. Anyone know if the engine gear needs to be changed if I pull an impulse coupled mag and put on a non-impulse mag? Next time I need an Overhaul I think I'll go non impulse. Anyway, harnesses are a pain so my advice is to care for them well, monitor them for issues, and then come up with your plan or a replacement harness BEFORE you need one because it may take a while to get what you want. Tim On Sep 16, 2016, at 1:16 AM, Albert wrote: I made repairs to my Slick harness and have some things to share. I understand there are various mag models and this may not apply to them but mine is a 6351. The pdf document that Tim Olsen shared (Champion L-1499B Ignition Lead Assembly & Maintenance Manual) is what I referred to. I bought the T-200 Slick Ignition Harness Tool Kit from Spruce and three 72" lead assemblies (Kelley S100-72) . The maintenance manual is somewhat inadequate in that it referes to Slick Ignition wires that apparently differ from either Skytronics or Kelley. The Slick wires referred to in the maintenance manual have a coiled center conductor whereas Skytronics and Kelley have a stranded conductor. On Slick wire you have to insert the little screw (that holds the spring) into the coiled conductor but on stranded wire it is crimped on. I just happened to have a crimper that works which I got from SteirAir to crimp the pins for my intercom connectors. Since the spark plug ends are already on the Kelley leads, cutting them to the right length, crimping the little screw on and then pressing them into the mag cap went well. The Kelley 72" leads are somewhat expensive, for me about $85 each so to build a complete 6 or 12 wire harness would be out of the question. Better to buy one. My problem was I couldn't find out how long the leads were in any specific kit without pulling one off the shelf and measuring them plus I had 3 leads that were long enough so only needed 3. Also lead time to have a custom harness made were way too long. I see big problems in trying to make your own harness: where to get lead wire and where to get the various parts at the mag end (drive ferrule, insulator sleeve, crimp on connector and spring). Plus you will have to make up the plug end also and get those parts. Repairing mine using Kelleys leads worked OK for me but next time I'm going to look for someone else to make me a complete harness. Albert Gardner RV-10 N991RV Yuma, AZ ________________________________________________________________________________
Date: Sep 16, 2016
That's fine, to each his own. I know on the 4 cylinders they haven't been bad, and I'd even be willing to use them on a 4 cylinder engine. But with previous gearing issues they've had and knowing that the 6 cylinder has different issues in relation to the mag drive, I personally am not willing to stick something on that gear case until there are a few years and maybe 1,000 units in the field that haven't had an issue for a good while. I'm not willing to be THAT experimental in my ignition. I have lightspeed and it's been good, but, it's the granddaddy of electronic ignition systems at this point. Yes, there are newer, but I want to see more track record on them. For those who like that Gen3 or whatever it is, that attaches to a mag, before you go that route, you may want to talk to my buddy Lenny. He was sold on them from the beginning but when he finally pulled them off, he actually destroyed them just so they wouldn't get into anyone elses hands. He now has a Lightspeed on his plane too. But that all does not discount your experience on your RV-8A. I think the pMags have pretty much proven themselves on that platform, and I have no issues with them there. And, if you choose to put them on your RV-10, I can applaud that as well. SOMEONE has to be the one to take the leap, and if you're willing, go for it. We'll all benefit from the knowledge. It's just something that I'm not willing to stick my neck out on either. I would also say it's too early to say "hey everyone, jump on this bandwagon and try them out!" because without a track record, it could just lead people into something that could increase our insurance rate. If it goes well though, no big deal. Tim On 9/16/2016 8:51 AM, Carl Froehlich wrote: > Tim, > > > I note your comment, Philosophically not ready to trust 2 electronic > ignitions and I definitely won't be trusting the P-Mag, if it EVER comes > out, for at least 8-10 years. If there weren't issues we would have > seen it years ago and I know fears were issues. And the talk about > impulse coupler problems has me wondering if harmonics aren't their big > problem. > > > The RV-10 is the first airplane Ive owned with mags (the RV-8A now has > 900 hours on dual pMags). Im now pushing 400 hours on the RV-10 and > the mags are in need of overhaul. Im also on my second set of > overpriced aircraft plugs. After careful cylinder balancing I can fly > LOP, but above 11k the fixed 25 degrees of advance clearly shows its > limitations. > > > I have some sympathy for eMag on their extended road to produce a TSO > ignition. While the experimental market is ready, they see the prize > being all those spam cans out there with owners wanting something better > than a 1930 era magneto. > > > Considering my personal operational experience with eMag, I will be > installing dual six cylinder pMags on the RV-10 as soon as they mail > them to me. > > > Carl > > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson > *Sent:* Friday, September 16, 2016 8:03 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Slick Ignition Harness > > > I'd agree with everything you said. > > FIXING a harness would be affordable but these days the prices of > harness components is just too high and so are the harnesses. We're all > screwed if we want it done cheap. The cheapest option would be to find > a harness that we can use 1/2 of. Unfortunately it's almost impossible > to buy a 1/2 harness now. So you buy a complete system and only use > 1/2. If you're lucky and can use a stock part number then it's not > totally unaffordable. > > But finding a consistent proper length stock harness is tough as slick > vs Kelly/skytronics don't seem to follow the same lengths. > > Having a custom harness done is not that much more expensive if you go > Kelly/Skytronics, but, the process is painful and long. It took me many > emails and phone calls to get the guy to get an order set up for what I > wanted on the RV14. Then it took a good couple weeks or more to get the > harness. I don't remember if it was 2 or 4'weeks but it was long enough > to Irritate me a little. Still, it worked out...and if you need every > lead to be custom > > Length it's still the cheapest way to go because buying all 4 or 6 leads > is more expensive than custom. What also would be maybe even more > affordable and possibly quicker is to buy a new stock complete harness > and then tear it all apart and transplant the cables from one harness to > another to make a custom one DIY. That is my likely plan I guess next > time. One benefit is that then you will have a spare harness cap as well. > > Sadly they make it so expensive and tough to keep these mags in service > that it gets tempting to remove both but I am > > Philosophically not ready to trust 2 electronic ignitions and I > definitely won't be trusting the P-Mag, if it EVER comes out, for at > least 8-10 years. If there weren't issues we would have seen it years > ago and I know fears were issues. And the talk about impulse coupler > problems has me wondering if harmonics aren't their big problem. > > Anyone know if the engine gear needs to be changed if I pull an impulse > coupled mag and put on a non-impulse mag? Next time I need an Overhaul I > think I'll go non impulse. > > > Anyway, harnesses are a pain so my advice is to care for them well, > monitor them for issues, and then come up with your plan or a > replacement harness BEFORE you need one because it may take a while to > get what you want. > > Tim > > > On Sep 16, 2016, at 1:16 AM, Albert > wrote: > > I made repairs to my Slick harness and have some things to share. I > understand there are various mag models and this may not apply to > them but mine is a 6351. The pdf document that Tim Olsen shared > (Champion L-1499B Ignition Lead Assembly & Maintenance Manual) is > what I referred to. I bought the T-200 Slick Ignition Harness Tool > Kit from Spruce and three 72" lead assemblies (Kelley S100-72) . The > maintenance manual is somewhat inadequate in that it referes to > Slick Ignition wires that apparently differ from either Skytronics > or Kelley. The Slick wires referred to in the maintenance manual > have a coiled center conductor whereas Skytronics and Kelley have a > stranded conductor. On Slick wire you have to insert the little > screw (that holds the spring) into the coiled conductor but on > stranded wire it is crimped on. I just happened to have a crimper > that works which I got from SteirAir to crimp the pins for my > intercom connectors. > > > Since the spark plug ends are already on the Kelley leads, cutting > them to the right length, crimping the little screw on and then > pressing them into the mag cap went well. The Kelley 72" leads are > somewhat expensive, for me about $85 each so to build a complete 6 > or 12 wire harness would be out of the question. Better to buy one. > My problem was I couldn't find out how long the leads were in any > specific kit without pulling one off the shelf and measuring them > plus I had 3 leads that were long enough so only needed 3. Also lead > time to have a custom harness made were way too long. > > > I see big problems in trying to make your own harness: where to get > lead wire and where to get the various parts at the mag end (drive > ferrule, insulator sleeve, crimp on connector and spring). Plus you > will have to make up the plug end also and get those parts. > > > Repairing mine using Kelleys leads worked OK for me but next time > I'm going to look for someone else to make me a complete harness. > > Albert Gardner > > RV-10 N991RV > > Yuma, AZ > > ________________________________________________________________________________
Subject: Was slick Ignition Harness now EI
Date: Sep 16, 2016
Thanks Tim, we are on the same page. I know eMag is doing an extensive testing program as the FAA will be looking at any hiccups during their TSO cert. I too will be looking at the pMag test data before jumping in. I note your comment on Lightspeed. I do have a track record with Lightspeed and I consider any Lightspeed install to make the aircraft un-airworthy. I had multiple failures of a dual Lightspeed install in the 8A before I pulled them and installed the pMags. I know of more people with Lightspeed installs that had hard failures than I know of people with Lightspeed installs with no failures. Add to that the legendary Klaus "no service after the sale and whatever went wrong is your fault" and my prohibition on this product is more than justified. While I'm sure I'll generate a lot of "my Lightspeed have been perfect" comments, the mental image of seeing a Lightspeed power breaker pop and not reset while flying is etched into my brain. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson Sent: Friday, September 16, 2016 10:27 AM Subject: Re: RV10-List: Slick Ignition Harness That's fine, to each his own. I know on the 4 cylinders they haven't been bad, and I'd even be willing to use them on a 4 cylinder engine. But with previous gearing issues they've had and knowing that the 6 cylinder has different issues in relation to the mag drive, I personally am not willing to stick something on that gear case until there are a few years and maybe 1,000 units in the field that haven't had an issue for a good while. I'm not willing to be THAT experimental in my ignition. I have lightspeed and it's been good, but, it's the granddaddy of electronic ignition systems at this point. Yes, there are newer, but I want to see more track record on them. For those who like that Gen3 or whatever it is, that attaches to a mag, before you go that route, you may want to talk to my buddy Lenny. He was sold on them from the beginning but when he finally pulled them off, he actually destroyed them just so they wouldn't get into anyone elses hands. He now has a Lightspeed on his plane too. But that all does not discount your experience on your RV-8A. I think the pMags have pretty much proven themselves on that platform, and I have no issues with them there. And, if you choose to put them on your RV-10, I can applaud that as well. SOMEONE has to be the one to take the leap, and if you're willing, go for it. We'll all benefit from the knowledge. It's just something that I'm not willing to stick my neck out on either. I would also say it's too early to say "hey everyone, jump on this bandwagon and try them out!" because without a track record, it could just lead people into something that could increase our insurance rate. If it goes well though, no big deal. Tim On 9/16/2016 8:51 AM, Carl Froehlich wrote: > Tim, > > > I note your comment, Philosophically not ready to trust 2 electronic > ignitions and I definitely won't be trusting the P-Mag, if it EVER > comes out, for at least 8-10 years. If there weren't issues we would > have seen it years ago and I know fears were issues. And the talk > about impulse coupler problems has me wondering if harmonics aren't > their big problem. > > > The RV-10 is the first airplane Ive owned with mags (the RV-8A now > has > 900 hours on dual pMags). Im now pushing 400 hours on the RV-10 and > the mags are in need of overhaul. Im also on my second set of > overpriced aircraft plugs. After careful cylinder balancing I can fly > LOP, but above 11k the fixed 25 degrees of advance clearly shows its > limitations. > > > I have some sympathy for eMag on their extended road to produce a TSO > ignition. While the experimental market is ready, they see the prize > being all those spam cans out there with owners wanting something > better than a 1930 era magneto. > > > Considering my personal operational experience with eMag, I will be > installing dual six cylinder pMags on the RV-10 as soon as they mail > them to me. > > > Carl > > > *From:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim Olson > *Sent:* Friday, September 16, 2016 8:03 AM > *To:* rv10-list(at)matronics.com > *Subject:* Re: RV10-List: Slick Ignition Harness > > > I'd agree with everything you said. > > FIXING a harness would be affordable but these days the prices of > harness components is just too high and so are the harnesses. We're > all screwed if we want it done cheap. The cheapest option would be to > find a harness that we can use 1/2 of. Unfortunately it's almost > impossible to buy a 1/2 harness now. So you buy a complete system and > only use 1/2. If you're lucky and can use a stock part number then > it's not totally unaffordable. > > But finding a consistent proper length stock harness is tough as slick > vs Kelly/skytronics don't seem to follow the same lengths. > > Having a custom harness done is not that much more expensive if you go > Kelly/Skytronics, but, the process is painful and long. It took me > many emails and phone calls to get the guy to get an order set up for > what I wanted on the RV14. Then it took a good couple weeks or more to > get the harness. I don't remember if it was 2 or 4'weeks but it was > long enough to Irritate me a little. Still, it worked out...and if > you need every lead to be custom > > Length it's still the cheapest way to go because buying all 4 or 6 > leads is more expensive than custom. What also would be maybe even > more affordable and possibly quicker is to buy a new stock complete > harness and then tear it all apart and transplant the cables from one > harness to another to make a custom one DIY. That is my likely plan I > guess next time. One benefit is that then you will have a spare harness cap as well. > > Sadly they make it so expensive and tough to keep these mags in > service that it gets tempting to remove both but I am > > Philosophically not ready to trust 2 electronic ignitions and I > definitely won't be trusting the P-Mag, if it EVER comes out, for at > least 8-10 years. If there weren't issues we would have seen it years > ago and I know fears were issues. And the talk about impulse coupler > problems has me wondering if harmonics aren't their big problem. > > Anyone know if the engine gear needs to be changed if I pull an > impulse coupled mag and put on a non-impulse mag? Next time I need an > Overhaul I think I'll go non impulse. > > > Anyway, harnesses are a pain so my advice is to care for them well, > monitor them for issues, and then come up with your plan or a > replacement harness BEFORE you need one because it may take a while to > get what you want. > > Tim > > > On Sep 16, 2016, at 1:16 AM, Albert > wrote: > > I made repairs to my Slick harness and have some things to share. I > understand there are various mag models and this may not apply to > them but mine is a 6351. The pdf document that Tim Olsen shared > (Champion L-1499B Ignition Lead Assembly & Maintenance Manual) is > what I referred to. I bought the T-200 Slick Ignition Harness Tool > Kit from Spruce and three 72" lead assemblies (Kelley S100-72) . The > maintenance manual is somewhat inadequate in that it referes to > Slick Ignition wires that apparently differ from either Skytronics > or Kelley. The Slick wires referred to in the maintenance manual > have a coiled center conductor whereas Skytronics and Kelley have a > stranded conductor. On Slick wire you have to insert the little > screw (that holds the spring) into the coiled conductor but on > stranded wire it is crimped on. I just happened to have a crimper > that works which I got from SteirAir to crimp the pins for my > intercom connectors. > > > Since the spark plug ends are already on the Kelley leads, cutting > them to the right length, crimping the little screw on and then > pressing them into the mag cap went well. The Kelley 72" leads are > somewhat expensive, for me about $85 each so to build a complete 6 > or 12 wire harness would be out of the question. Better to buy one. > My problem was I couldn't find out how long the leads were in any > specific kit without pulling one off the shelf and measuring them > plus I had 3 leads that were long enough so only needed 3. Also lead > time to have a custom harness made were way too long. > > > I see big problems in trying to make your own harness: where to get > lead wire and where to get the various parts at the mag end (drive > ferrule, insulator sleeve, crimp on connector and spring). Plus you > will have to make up the plug end also and get those parts. > > > Repairing mine using Kelleys leads worked OK for me but next time > I'm going to look for someone else to make me a complete harness. > > Albert Gardner > > RV-10 N991RV > > Yuma, AZ > > ________________________________________________________________________________
Subject: Re: Was slick Ignition Harness now EI
Date: Sep 16, 2016
I remember you saying that I think from previous posts. It's interesting the experience difference you had. I've never had a breaker pop ever, of any sort, in either plane yet. And I've never had an ignition failure once the engine was running, other than a mag on an old plane. So I guess I'm pretty lucky. Most of the RV-10 buddies I have, have one lightspeed and one mag. One has 2 lightspeeds. For what it's worth, having flown to stop by Klaus's hangar before, but also had email/phone support, I think it's a mixed bag. I've been on the end of the "it's your fault" thing with him, but I think a lot of that has to do with trust, and with the commonality of moronic customers. :) I work in a field that causes me to do tech support daily and I totally get what drives those types of responses. You learn quick not to trust anyone, and you see people do stupid things time after time after time. So you become preloaded to just realize that most issues ARE caused by the user. Mainly because it's a true fact in the largest percentage of cases. I found that once he had some trust in me though, he has always been very nice to talk to, and I'm not treated badly at all. But you have to get thru the initial "you must be doing it wrong" before you can get that far. Yeah, ideally it wouldn't be this way, but I certainly understand why it is. Also, a builder needs to be fully willing to do all the troubleshooting legwork to diagnose the problem. Too many people call and just complain and want you to fix it or diagnose it over the phone. If someone can step up and test things and provide data, they can get somewhere much easier. (I'm not saying you did or didn't do anything when talking to him...this is all generalization) Anyway, you're right, you'll hear lots of satisfied people with no issues, and lots of negative support comments when it comes to LSE, and a few failure stories as well. Nothing too unusual. I feel perfectly comfortable with them obviously, because I put one on my RV-14 after flying 10 years in the -10. But, I also have a spare box for the -10 and want one for the -14 too. I don't feel comfortable with ANY product that has only a small handful of people working in the company that you can get parts or support from. This includes basically ALL electronic ignition companies. About the only place you can count fully on support long term is slick and bendix. Beyond that, if the wrong airplane crashes with the wrong company people in it, you may need to retrofit a new system if yours fails. So, best to be prepared for the worst. I'm a guy who likes having spares. :) Tim On 9/16/2016 10:05 AM, Carl Froehlich wrote: > > > Thanks Tim, we are on the same page. I know eMag is doing an > extensive testing program as the FAA will be looking at any hiccups > during their TSO cert. I too will be looking at the pMag test data > before jumping in. > > I note your comment on Lightspeed. I do have a track record with > Lightspeed and I consider any Lightspeed install to make the aircraft > un-airworthy. I had multiple failures of a dual Lightspeed install > in the 8A before I pulled them and installed the pMags. I know of > more people with Lightspeed installs that had hard failures than I > know of people with Lightspeed installs with no failures. Add to > that the legendary Klaus "no service after the sale and whatever went > wrong is your fault" and my prohibition on this product is more than > justified. > > While I'm sure I'll generate a lot of "my Lightspeed have been > perfect" comments, the mental image of seeing a Lightspeed power > breaker pop and not reset while flying is etched into my brain. > > Carl > > -----Original Message----- From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Olson > Sent: Friday, September 16, 2016 10:27 AM To: > rv10-list(at)matronics.com Subject: Re: RV10-List: Slick Ignition > Harness > > > That's fine, to each his own. I know on the 4 cylinders they haven't > been bad, and I'd even be willing to use them on a 4 cylinder > engine. But with previous gearing issues they've had and knowing that > the 6 cylinder has different issues in relation to the mag drive, I > personally am not willing to stick something on that gear case until > there are a few years and maybe 1,000 units in the field that haven't > had an issue for a good while. I'm not willing to be THAT > experimental in my ignition. > > I have lightspeed and it's been good, but, it's the granddaddy of > electronic ignition systems at this point. Yes, there are newer, but > I want to see more track record on them. > > For those who like that Gen3 or whatever it is, that attaches to a > mag, before you go that route, you may want to talk to my buddy > Lenny. He was sold on them from the beginning but when he finally > pulled them off, he actually destroyed them just so they wouldn't get > into anyone elses hands. He now has a Lightspeed on his plane too. > > But that all does not discount your experience on your RV-8A. I think > the pMags have pretty much proven themselves on that platform, and I > have no issues with them there. And, if you choose to put them on > your RV-10, I can applaud that as well. SOMEONE has to be the one to > take the leap, and if you're willing, go for it. We'll all benefit > from the knowledge. It's just something that I'm not willing to stick > my neck out on either. I would also say it's too early to say "hey > everyone, jump on this bandwagon and try them out!" because without a > track record, it could just lead people into something that could > increase our insurance rate. If it goes well though, no big deal. > > Tim > > On 9/16/2016 8:51 AM, Carl Froehlich wrote: >> Tim, >> >> >> >> I note your comment, Philosophically not ready to trust 2 >> electronic ignitions and I definitely won't be trusting the P-Mag, >> if it EVER comes out, for at least 8-10 years. If there weren't >> issues we would have seen it years ago and I know fears were >> issues. And the talk about impulse coupler problems has me >> wondering if harmonics aren't their big problem. >> >> >> >> The RV-10 is the first airplane Ive owned with mags (the RV-8A now >> has 900 hours on dual pMags). Im now pushing 400 hours on the >> RV-10 and the mags are in need of overhaul. Im also on my second >> set of overpriced aircraft plugs. After careful cylinder balancing >> I can fly LOP, but above 11k the fixed 25 degrees of advance >> clearly shows its limitations. >> >> >> >> I have some sympathy for eMag on their extended road to produce a >> TSO ignition. While the experimental market is ready, they see the >> prize being all those spam cans out there with owners wanting >> something better than a 1930 era magneto. >> >> >> >> Considering my personal operational experience with eMag, I will be >> installing dual six cylinder pMags on the RV-10 as soon as they >> mail them to me. >> >> >> >> Carl >> >> >> >> >> >> *From:*owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Tim >> Olson *Sent:* Friday, September 16, 2016 8:03 AM *To:* >> rv10-list(at)matronics.com *Subject:* Re: RV10-List: Slick Ignition >> Harness >> >> >> >> I'd agree with everything you said. >> >> FIXING a harness would be affordable but these days the prices of >> harness components is just too high and so are the harnesses. >> We're all screwed if we want it done cheap. The cheapest option >> would be to find a harness that we can use 1/2 of. Unfortunately >> it's almost impossible to buy a 1/2 harness now. So you buy a >> complete system and only use 1/2. If you're lucky and can use a >> stock part number then it's not totally unaffordable. >> >> But finding a consistent proper length stock harness is tough as >> slick vs Kelly/skytronics don't seem to follow the same lengths. >> >> Having a custom harness done is not that much more expensive if you >> go Kelly/Skytronics, but, the process is painful and long. It took >> me many emails and phone calls to get the guy to get an order set >> up for what I wanted on the RV14. Then it took a good couple weeks >> or more to get the harness. I don't remember if it was 2 or >> 4'weeks but it was long enough to Irritate me a little. Still, it >> worked out...and if you need every lead to be custom >> >> Length it's still the cheapest way to go because buying all 4 or 6 >> leads is more expensive than custom. What also would be maybe >> even more affordable and possibly quicker is to buy a new stock >> complete harness and then tear it all apart and transplant the >> cables from one harness to another to make a custom one DIY. That >> is my likely plan I guess next time. One benefit is that then you >> will have a spare harness cap as well. >> >> Sadly they make it so expensive and tough to keep these mags in >> service that it gets tempting to remove both but I am >> >> Philosophically not ready to trust 2 electronic ignitions and I >> definitely won't be trusting the P-Mag, if it EVER comes out, for >> at least 8-10 years. If there weren't issues we would have seen it >> years ago and I know fears were issues. And the talk about impulse >> coupler problems has me wondering if harmonics aren't their big >> problem. >> >> Anyone know if the engine gear needs to be changed if I pull an >> impulse coupled mag and put on a non-impulse mag? Next time I need >> an Overhaul I think I'll go non impulse. >> >> >> >> Anyway, harnesses are a pain so my advice is to care for them well, >> monitor them for issues, and then come up with your plan or a >> replacement harness BEFORE you need one because it may take a while >> to get what you want. >> >> Tim >> >> >> On Sep 16, 2016, at 1:16 AM, Albert > > wrote: >> >> I made repairs to my Slick harness and have some things to share. >> I understand there are various mag models and this may not apply >> to them but mine is a 6351. The pdf document that Tim Olsen shared >> (Champion L-1499B Ignition Lead Assembly & Maintenance Manual) is >> what I referred to. I bought the T-200 Slick Ignition Harness Tool >> Kit from Spruce and three 72" lead assemblies (Kelley S100-72) . >> The maintenance manual is somewhat inadequate in that it referes >> to Slick Ignition wires that apparently differ from either >> Skytronics or Kelley. The Slick wires referred to in the >> maintenance manual have a coiled center conductor whereas >> Skytronics and Kelley have a stranded conductor. On Slick wire you >> have to insert the little screw (that holds the spring) into the >> coiled conductor but on stranded wire it is crimped on. I just >> happened to have a crimper that works which I got from SteirAir to >> crimp the pins for my intercom connectors. >> >> >> >> Since the spark plug ends are already on the Kelley leads, cutting >> them to the right length, crimping the little screw on and then >> pressing them into the mag cap went well. The Kelley 72" leads >> are somewhat expensive, for me about $85 each so to build a >> complete 6 or 12 wire harness would be out of the question. Better >> to buy one. My problem was I couldn't find out how long the leads >> were in any specific kit without pulling one off the shelf and >> measuring them plus I had 3 leads that were long enough so only >> needed 3. Also lead time to have a custom harness made were way too >> long. >> >> >> >> I see big problems in trying to make your own harness: where to >> get lead wire and where to get the various parts at the mag end >> (drive ferrule, insulator sleeve, crimp on connector and spring). >> Plus you will have to make up the plug end also and get those >> parts. >> >> >> >> Repairing mine using Kelleys leads worked OK for me but next time >> I'm going to look for someone else to make me a complete harness. >> >> Albert Gardner >> >> RV-10 N991RV >> >> Yuma, AZ >> >> >> >> ________________________________________________________________________________
Date: Sep 19, 2016
Subject: Ultimate Quick Build Fuel Tanks
FOR SALE: The ultimate quickbuild RV-10 fuel tanks. These tanks are completed! They do not leak! They are Van=99s standard configuration. Save yourself a lot of build time and messing with sealant. I will sell these for the cost of materials. Just turn your parts into Van=99s for credit and buy these. They have been flying and are being replaced with an extended range system. If interested call 31nine-55one-2832. No text, no email=94(but I will talk all day about airplanes). ________________________________________________________________________________
Subject: PCU 5000 able to command low rpm (<1700rpm)?
Date: Sep 19, 2016
I'm considering replacing my MT prop governor. One thing I do like about the MT governor is you can pull the prop control back during engine out practice and the governor slows the engine way down (which extends glide). I understand (from owner comments and Hartzell tech support) that the Hartzell governor's minimum governing speed is about 1700 rpm. I'm interested in learning what minimum governing speed folks have seen on aircraft flying with the PCU 5000X. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs ________________________________________________________________________________
From: Carl Froehlich <carl.froehlich(at)verizon.net>
Subject: Re: PCU 5000 able to command low rpm (<1700rpm)?
Date: Sep 19, 2016
That is about the RPM I see (RV-8A and RV-10) with the PCU-5000X. Carl > On Sep 19, 2016, at 4:31 PM, Tim Lewis wrote: > > > I'm considering replacing my MT prop governor. One thing I do like about the MT governor is you can pull the prop control back during engine out practice and the governor slows the engine way down (which extends glide). > > I understand (from owner comments and Hartzell tech support) that the Hartzell governor's minimum governing speed is about 1700 rpm. I'm interested in learning what minimum governing speed folks have seen on aircraft flying with the PCU 5000X. > > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 740 hrs > > > > > ________________________________________________________________________________
Date: Sep 19, 2016
Thanks, Carl. I want to make sure I understand your reply correctly. I do my runups at 1800. If I pull the prop control back during runup, the MT governor/prop will slow the engine way down -- probably below 1000 rpm. Certainly well below 1700 rpm. Are you telling me that with the PCU 5000, if pull the prop control all the way back (at runup, for example), your experience is the PCU5000 won't slow the engine below 1700 rpm? Thanks very much for your insights. I appreciate it. Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carl Froehlich wrote on 9/19/2016 5:43 PM: > > That is about the RPM I see (RV-8A and RV-10) with the PCU-5000X. > > Carl > >> On Sep 19, 2016, at 4:31 PM, Tim Lewis wrote: >> >> >> I'm considering replacing my MT prop governor. One thing I do like about the MT governor is you can pull the prop control back during engine out practice and the governor slows the engine way down (which extends glide). >> >> I understand (from owner comments and Hartzell tech support) that the Hartzell governor's minimum governing speed is about 1700 rpm. I'm interested in learning what minimum governing speed folks have seen on aircraft flying with the PCU 5000X. >> >> -- >> Tim Lewis -- HEF (Manassas, VA) >> A&P >> RV-6A N47TD -- 1104 hrs - sold >> RV-10 N31TD -- 740 hrs >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 19, 2016
I don't recall how far it will pull down the RPM - I only pull the prop until a get a slight drop to make sure the governor is functioning. I was told (correctly or incorrectly) deep run up cycles are hard on props. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Lewis Sent: Monday, September 19, 2016 9:53 PM Subject: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? Thanks, Carl. I want to make sure I understand your reply correctly. I do my runups at 1800. If I pull the prop control back during runup, the MT governor/prop will slow the engine way down -- probably below 1000 rpm. Certainly well below 1700 rpm. Are you telling me that with the PCU 5000, if pull the prop control all the way back (at runup, for example), your experience is the PCU5000 won't slow the engine below 1700 rpm? Thanks very much for your insights. I appreciate it. Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carl Froehlich wrote on 9/19/2016 5:43 PM: > --> > > That is about the RPM I see (RV-8A and RV-10) with the PCU-5000X. > > Carl > >> On Sep 19, 2016, at 4:31 PM, Tim Lewis wrote: >> >> >> I'm considering replacing my MT prop governor. One thing I do like about the MT governor is you can pull the prop control back during engine out practice and the governor slows the engine way down (which extends glide). >> >> I understand (from owner comments and Hartzell tech support) that the Hartzell governor's minimum governing speed is about 1700 rpm. I'm interested in learning what minimum governing speed folks have seen on aircraft flying with the PCU 5000X. >> >> -- >> Tim Lewis -- HEF (Manassas, VA) >> A&P >> RV-6A N47TD -- 1104 hrs - sold >> RV-10 N31TD -- 740 hrs >> >> >> >> >> > > ________________________________________________________________________________
Date: Sep 19, 2016
Carl, I was told the same. If you get a chance, perhaps you can test this: At 1000 rpm idle, can you pull the prop control and see if the prop governor will further slow the engine rpm. If so, that's the info I'm looking for. VR Tim -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carl Froehlich wrote on 9/19/2016 10:26 PM: > > I don't recall how far it will pull down the RPM - I only pull the prop > until a get a slight drop to make sure the governor is functioning. I was > told (correctly or incorrectly) deep run up cycles are hard on props. > > Carl > > -----Original Message----- > From: owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Lewis > Sent: Monday, September 19, 2016 9:53 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? > > > Thanks, Carl. > > I want to make sure I understand your reply correctly. I do my runups at > 1800. If I pull the prop control back during runup, the MT governor/prop > will slow the engine way down -- probably below 1000 rpm. > Certainly well below 1700 rpm. Are you telling me that with the PCU > 5000, if pull the prop control all the way back (at runup, for example), > your experience is the PCU5000 won't slow the engine below 1700 rpm? > > Thanks very much for your insights. I appreciate it. > > Tim Lewis ________________________________________________________________________________
Date: Sep 20, 2016
On a similar note, I avoid running at or below 1000 rpm to avoid lead fouling, which I am led to believe can happen even when fully leaned. While attending Lycoming Engine School, I followed up with the instructor after his lead fouling discussion and came away with the understanding that lead build-up will occur anytime combustion chamber temperatures drop below a certain point. He emphasized that it happens very quickly based on some testing he was familiar with. He mentioned that that the practice of pulling the power off at touchdown and leaving it there during the rollout is enough to form visible deposits. By the same token, heating things up above the critical temperature soon after will cause most, but not all of those new deposits to quickly evaporate away. This write-up from Shell <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart-18-30071600.html> seems to support that thinking. As a result of the same thinking, I've never practiced engine out descents with the power pulled all the way and the prop slowed anywhere near 1000 rpm. This former fixed pitch jockey handles the prop cycling task by setting the power around 1500 rpms before cycling the prop. During the cycle, the rpm drop just hits 1000 rpms as I move the control forward. And I try to not to imitate what I've seen some CFIs do by slamming the prop control this way and that. On my engine a slower steady hand will do. I've never been told that it's hard on the prop and don't believe it is. I have been told that I'm both checking function and forcing some warm oil thru the controller so that it performs as expected during takeoff. Now I'm thinking the main task is just to make sure it works without spraying oil all over the place but honestly just don't really know. I just do it. Bill "glider guider at heart that has learned to love that big 'ol 540" Watson N215TG On 9/19/2016 10:26 PM, Carl Froehlich wrote: > I don't recall how far it will pull down the RPM - I only pull the prop > until a get a slight drop to make sure the governor is functioning. I was > told (correctly or incorrectly) deep run up cycles are hard on props. > > > Thanks, Carl. > > I want to make sure I understand your reply correctly. I do my runups at > 1800. If I pull the prop control back during runup, the MT governor/prop > will slow the engine way down -- probably below 1000 rpm. > Certainly well below 1700 rpm. Are you telling me that with the PCU > 5000, if pull the prop control all the way back (at runup, for example), > your experience is the PCU5000 won't slow the engine below 1700 rpm? > > Thanks very much for your insights. I appreciate it. > > Tim Lewis --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Lycoming Engine School (was PCU 5000 able to command low
rpm)
Date: Sep 20, 2016
Bill You mentioned "Lycoming engine School", does that still exist? Regards Carlos "wishing to learn all about Lycoming engines" Trigo De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Bill Watson Enviada: Tuesday, September 20, 2016 12:19 PM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? On a similar note, I avoid running at or below 1000 rpm to avoid lead fouling, which I am led to believe can happen even when fully leaned. While attending Lycoming Engine School, I followed up with the instructor after his lead fouling discussion and came away with the understanding that lead build-up will occur anytime combustion chamber temperatures drop below a certain point. He emphasized that it happens very quickly based on some testing he was familiar with. He mentioned that that the practice of pulling the power off at touchdown and leaving it there during the rollout is enough to form visible deposits. By the same token, heating things up above the critical temperature soon after will cause most, but not all of those new deposits to quickly evaporate away. This write-up from Shell <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre /technical-talk/techart-18-30071600.html> seems to support that thinking. As a result of the same thinking, I've never practiced engine out descents with the power pulled all the way and the prop slowed anywhere near 1000 rpm. This former fixed pitch jockey handles the prop cycling task by setting the power around 1500 rpms before cycling the prop. During the cycle, the rpm drop just hits 1000 rpms as I move the control forward. And I try to not to imitate what I've seen some CFIs do by slamming the prop control this way and that. On my engine a slower steady hand will do. I've never been told that it's hard on the prop and don't believe it is. I have been told that I'm both checking function and forcing some warm oil thru the controller so that it performs as expected during takeoff. Now I'm thinking the main task is just to make sure it works without spraying oil all over the place but honestly just don't really know. I just do it. Bill "glider guider at heart that has learned to love that big 'ol 540" Watson N215TG On 9/19/2016 10:26 PM, Carl Froehlich wrote: I don't recall how far it will pull down the RPM - I only pull the prop until a get a slight drop to make sure the governor is functioning. I was told (correctly or incorrectly) deep run up cycles are hard on props. Thanks, Carl. I want to make sure I understand your reply correctly. I do my runups at 1800. If I pull the prop control back during runup, the MT governor/prop will slow the engine way down -- probably below 1000 rpm. Certainly well below 1700 rpm. Are you telling me that with the PCU 5000, if pull the prop control all the way back (at runup, for example), your experience is the PCU5000 won't slow the engine below 1700 rpm? Thanks very much for your insights. I appreciate it. Tim Lewis _____ This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Sep 20, 2016
Trying to answer my own question, are these the courses I found in the "Pennsylvannia College of Technology"? CT De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Carlos Trigo Enviada: Tuesday, September 20, 2016 1:14 PM Para: rv10-list(at)matronics.com Assunto: RE: RV10-List: Lycoming Engine School (was PCU 5000 able to command low rpm) Bill You mentioned "Lycoming engine School", does that still exist? Regards Carlos "wishing to learn all about Lycoming engines" Trigo De: owner-rv10-list-server(at)matronics.com [ mailto:owner-rv10-list-server(at)matronics.com] Em nome de Bill Watson Enviada: Tuesday, September 20, 2016 12:19 PM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? On a similar note, I avoid running at or below 1000 rpm to avoid lead fouling, which I am led to believe can happen even when fully leaned. While attending Lycoming Engine School, I followed up with the instructor after his lead fouling discussion and came away with the understanding that lead build-up will occur anytime combustion chamber temperatures drop below a certain point. He emphasized that it happens very quickly based on some testing he was familiar with. He mentioned that that the practice of pulling the power off at touchdown and leaving it there during the rollout is enough to form visible deposits. By the same token, heating things up above the critical temperature soon after will cause most, but not all of those new deposits to quickly evaporate away. This write-up from Shell <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre /technical-talk/techart-18-30071600.html> seems to support that thinking. As a result of the same thinking, I've never practiced engine out descents with the power pulled all the way and the prop slowed anywhere near 1000 rpm. This former fixed pitch jockey handles the prop cycling task by setting the power around 1500 rpms before cycling the prop. During the cycle, the rpm drop just hits 1000 rpms as I move the control forward. And I try to not to imitate what I've seen some CFIs do by slamming the prop control this way and that. On my engine a slower steady hand will do. I've never been told that it's hard on the prop and don't believe it is. I have been told that I'm both checking function and forcing some warm oil thru the controller so that it performs as expected during takeoff. Now I'm thinking the main task is just to make sure it works without spraying oil all over the place but honestly just don't really know. I just do it. Bill "glider guider at heart that has learned to love that big 'ol 540" Watson N215TG On 9/19/2016 10:26 PM, Carl Froehlich wrote: I don't recall how far it will pull down the RPM - I only pull the prop until a get a slight drop to make sure the governor is functioning. I was told (correctly or incorrectly) deep run up cycles are hard on props. Thanks, Carl. I want to make sure I understand your reply correctly. I do my runups at 1800. If I pull the prop control back during runup, the MT governor/prop will slow the engine way down -- probably below 1000 rpm. Certainly well below 1700 rpm. Are you telling me that with the PCU 5000, if pull the prop control all the way back (at runup, for example), your experience is the PCU5000 won't slow the engine below 1700 rpm? Thanks very much for your insights. I appreciate it. Tim Lewis _____ This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Subject: Re: Lycoming Engine School (was PCU 5000 able to command low
rpm)
Date: Sep 20, 2016
Yes, I think so, but with a big but.... I recently got a mailing from Lycoming that indicated the long time instructor of the 2 'engine school' classes was going to retire after his last class. I attended the school back in 2013 and I'm not sure when his last class is scheduled (sometime in 2016 I believe). I forget the gentleman's name but he has been synonymous with the 'engine school' classes for a long time. He is a great instructor with a long and varied career at Lycoming that makes him a unique resource. I'd highly recommend the school with him instructing. I'd want a review of the 'new' classes before attending them without him. In some previous life I spent some time teaching and was steeped in pedagogical practice which makes me an instant critic of any educational event. This guy initially struck me as a knowledgeable old timer who was going to share war stories for 8 days; inject me with caffiene, stat! It took me a half day to realize he was a very experienced instructor who had the course content fully integrated into a folksy delivery style complete with hands on lab work and exactly the documentation and notes one needed to go home with. Barely a wasted word or motion. And he was deep in specific Lycoming operation and service details. Looking back at my confirmation letter from 2013, the classes were part of Penn College ($1,425 for both together). The first was called 'Service School' and one walked out with manuals, service documents, and the ability to use them to service Lycoming engines. That is prerequisite to the 2nd class 'Dissembly/Reassembly' which is a guided lab where you do the deed. I highly recommend the classes for any builder unless you already have a certificate, independent of how much service you intend to inflict on your IO-540. I envision that after he leaves, the classes will retain the same format, structure and value. The quality of instruction is the only question. Bill On 9/20/2016 8:14 AM, Carlos Trigo wrote: > > Bill > > You mentioned Lycoming engine School, does that still exist? > > Regards > > Carlos wishing to learn all about Lycoming engines Trigo > > *De:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *Em nome de *Bill Watson > *Enviada:* Tuesday, September 20, 2016 12:19 PM > *Para:* rv10-list(at)matronics.com > *Assunto:* Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? > > On a similar note, I avoid running at or below 1000 rpm to avoid lead > fouling, which I am led to believe can happen even when fully leaned. > > While attending Lycoming Engine School, I followed up with the > instructor after his lead fouling discussion and came away with the > understanding that lead build-up will occur anytime combustion chamber > temperatures drop below a certain point. He emphasized that it > happens very quickly based on some testing he was familiar with. He > mentioned that that the practice of pulling the power off at touchdown > and leaving it there during the rollout is enough to form visible > deposits. By the same token, heating things up above the critical > temperature soon after will cause most, but not all of those new > deposits to quickly evaporate away. > > This write-up from Shell > <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart-18-30071600.html> > seems to support that thinking. > > As a result of the same thinking, I've never practiced engine out > descents with the power pulled all the way and the prop slowed > anywhere near 1000 rpm. > > This former fixed pitch jockey handles the prop cycling task by > setting the power around 1500 rpms before cycling the prop. During > the cycle, the rpm drop just hits 1000 rpms as I move the control > forward. And I try to not to imitate what I've seen some CFIs do by > slamming the prop control this way and that. On my engine a slower > steady hand will do. > > I've never been told that it's hard on the prop and don't believe it > is. I have been told that I'm both checking function and forcing some > warm oil thru the controller so that it performs as expected during > takeoff. Now I'm thinking the main task is just to make sure it works > without spraying oil all over the place but honestly just don't really > know. I just do it. > > Bill "glider guider at heart that has learned to love that big 'ol > 540" Watson > N215TG > > On 9/19/2016 10:26 PM, Carl Froehlich wrote: > > I don't recall how far it will pull down the RPM - I only pull the prop > > until a get a slight drop to make sure the governor is functioning. I was > > told (correctly or incorrectly) deep run up cycles are hard on props. > > > Thanks, Carl. > > I want to make sure I understand your reply correctly. I do my runups at > > 1800. If I pull the prop control back during runup, the MT governor/prop > > will slow the engine way down -- probably below 1000 rpm. > > Certainly well below 1700 rpm. Are you telling me that with the PCU > > 5000, if pull the prop control all the way back (at runup, for example), > > your experience is the PCU5000 won't slow the engine below 1700 rpm? > > Thanks very much for your insights. I appreciate it. > > Tim Lewis > > ------------------------------------------------------------------------ > > Imagem removida pelo remetente. Avast logo > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CABkAGQDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigD//2Q= ________________________________________________________________________________
Date: Sep 20, 2016
The instructor who appears in the website information is Mr. Michael Damiani, being it in the 2016 or the 2017 courses. Carlos De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Bill Watson Enviada: Tuesday, September 20, 2016 3:10 PM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: Lycoming Engine School (was PCU 5000 able to command low rpm) Yes, I think so, but with a big but.... I recently got a mailing from Lycoming that indicated the long time instructor of the 2 'engine school' classes was going to retire after his last class. I attended the school back in 2013 and I'm not sure when his last class is scheduled (sometime in 2016 I believe). I forget the gentleman's name but he has been synonymous with the 'engine school' classes for a long time. He is a great instructor with a long and varied career at Lycoming that makes him a unique resource. I'd highly recommend the school with him instructing. I'd want a review of the 'new' classes before attending them without him. In some previous life I spent some time teaching and was steeped in pedagogical practice which makes me an instant critic of any educational event. This guy initially struck me as a knowledgeable old timer who was going to share war stories for 8 days; inject me with caffiene, stat! It took me a half day to realize he was a very experienced instructor who had the course content fully integrated into a folksy delivery style complete with hands on lab work and exactly the documentation and notes one needed to go home with. Barely a wasted word or motion. And he was deep in specific Lycoming operation and service details. Looking back at my confirmation letter from 2013, the classes were part of Penn College ($1,425 for both together). The first was called 'Service School' and one walked out with manuals, service documents, and the ability to use them to service Lycoming engines. That is prerequisite to the 2nd class 'Dissembly/Reassembly' which is a guided lab where you do the deed. I highly recommend the classes for any builder unless you already have a certificate, independent of how much service you intend to inflict on your IO-540. I envision that after he leaves, the classes will retain the same format, structure and value. The quality of instruction is the only question. Bill On 9/20/2016 8:14 AM, Carlos Trigo wrote: Bill You mentioned "Lycoming engine School", does that still exist? Regards Carlos "wishing to learn all about Lycoming engines" Trigo De: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Em nome de Bill Watson Enviada: Tuesday, September 20, 2016 12:19 PM Para: rv10-list(at)matronics.com Assunto: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? On a similar note, I avoid running at or below 1000 rpm to avoid lead fouling, which I am led to believe can happen even when fully leaned. While attending Lycoming Engine School, I followed up with the instructor after his lead fouling discussion and came away with the understanding that lead build-up will occur anytime combustion chamber temperatures drop below a certain point. He emphasized that it happens very quickly based on some testing he was familiar with. He mentioned that that the practice of pulling the power off at touchdown and leaving it there during the rollout is enough to form visible deposits. By the same token, heating things up above the critical temperature soon after will cause most, but not all of those new deposits to quickly evaporate away. This write-up from Shell <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre /technical-talk/techart-18-30071600.html> seems to support that thinking. As a result of the same thinking, I've never practiced engine out descents with the power pulled all the way and the prop slowed anywhere near 1000 rpm. This former fixed pitch jockey handles the prop cycling task by setting the power around 1500 rpms before cycling the prop. During the cycle, the rpm drop just hits 1000 rpms as I move the control forward. And I try to not to imitate what I've seen some CFIs do by slamming the prop control this way and that. On my engine a slower steady hand will do. I've never been told that it's hard on the prop and don't believe it is. I have been told that I'm both checking function and forcing some warm oil thru the controller so that it performs as expected during takeoff. Now I'm thinking the main task is just to make sure it works without spraying oil all over the place but honestly just don't really know. I just do it. Bill "glider guider at heart that has learned to love that big 'ol 540" Watson N215TG On 9/19/2016 10:26 PM, Carl Froehlich wrote: I don't recall how far it will pull down the RPM - I only pull the prop until a get a slight drop to make sure the governor is functioning. I was told (correctly or incorrectly) deep run up cycles are hard on props. Thanks, Carl. I want to make sure I understand your reply correctly. I do my runups at 1800. If I pull the prop control back during runup, the MT governor/prop will slow the engine way down -- probably below 1000 rpm. Certainly well below 1700 rpm. Are you telling me that with the PCU 5000, if pull the prop control all the way back (at runup, for example), your experience is the PCU5000 won't slow the engine below 1700 rpm? Thanks very much for your insights. I appreciate it. Tim Lewis _____ This email has been checked for viruses by Avast antivirus software. www.avast.com _____ This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Date: Sep 21, 2016
That is a new instructor. On 9/20/2016 10:36 AM, Carlos Trigo wrote: > > The instructor who appears in the website information is Mr. Michael > Damiani, being it in the 2016 or the 2017 courses. > > Carlos > > *De:*owner-rv10-list-server(at)matronics.com > [mailto:owner-rv10-list-server(at)matronics.com] *Em nome de *Bill Watson > *Enviada:* Tuesday, September 20, 2016 3:10 PM > *Para:* rv10-list(at)matronics.com > *Assunto:* Re: RV10-List: Lycoming Engine School (was PCU 5000 able to > command low rpm) > > Yes, I think so, but with a big but.... > > I recently got a mailing from Lycoming that indicated the long time > instructor of the 2 'engine school' classes was going to retire after > his last class. I attended the school back in 2013 and I'm not sure > when his last class is scheduled (sometime in 2016 I believe). > > I forget the gentleman's name but he has been synonymous with the > 'engine school' classes for a long time. He is a great instructor > with a long and varied career at Lycoming that makes him a unique > resource. I'd highly recommend the school with him instructing. I'd > want a review of the 'new' classes before attending them without him. > > In some previous life I spent some time teaching and was steeped in > pedagogical practice which makes me an instant critic of any > educational event. This guy initially struck me as a knowledgeable > old timer who was going to share war stories for 8 days; inject me > with caffiene, stat! It took me a half day to realize he was a very > experienced instructor who had the course content fully integrated > into a folksy delivery style complete with hands on lab work and > exactly the documentation and notes one needed to go home with. > Barely a wasted word or motion. And he was deep in specific Lycoming > operation and service details. > > Looking back at my confirmation letter from 2013, the classes were > part of Penn College ($1,425 for both together). The first was called > 'Service School' and one walked out with manuals, service documents, > and the ability to use them to service Lycoming engines. That is > prerequisite to the 2nd class 'Dissembly/Reassembly' which is a guided > lab where you do the deed. > > I highly recommend the classes for any builder unless you already have > a certificate, independent of how much service you intend to inflict > on your IO-540. I envision that after he leaves, the classes will > retain the same format, structure and value. The quality of > instruction is the only question. > > Bill > On 9/20/2016 8:14 AM, Carlos Trigo wrote: > > Bill > > You mentioned Lycoming engine School, does that still exist? > > Regards > > Carlos wishing to learn all about Lycoming engines Trigo > > *De:*owner-rv10-list-server(at)matronics.com > > [mailto:owner-rv10-list-server(at)matronics.com] *Em nome de *Bill Watson > *Enviada:* Tuesday, September 20, 2016 12:19 PM > *Para:* rv10-list(at)matronics.com > *Assunto:* Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? > > On a similar note, I avoid running at or below 1000 rpm to avoid > lead fouling, which I am led to believe can happen even when fully > leaned. > > While attending Lycoming Engine School, I followed up with the > instructor after his lead fouling discussion and came away with > the understanding that lead build-up will occur anytime combustion > chamber temperatures drop below a certain point. He emphasized > that it happens very quickly based on some testing he was familiar > with. He mentioned that that the practice of pulling the power > off at touchdown and leaving it there during the rollout is enough > to form visible deposits. By the same token, heating things up > above the critical temperature soon after will cause most, but not > all of those new deposits to quickly evaporate away. > > This write-up from Shell > <http://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart-18-30071600.html> > seems to support that thinking. > > As a result of the same thinking, I've never practiced engine out > descents with the power pulled all the way and the prop slowed > anywhere near 1000 rpm. > > This former fixed pitch jockey handles the prop cycling task by > setting the power around 1500 rpms before cycling the prop. > During the cycle, the rpm drop just hits 1000 rpms as I move the > control forward. And I try to not to imitate what I've seen some > CFIs do by slamming the prop control this way and that. On my > engine a slower steady hand will do. > > I've never been told that it's hard on the prop and don't believe > it is. I have been told that I'm both checking function and > forcing some warm oil thru the controller so that it performs as > expected during takeoff. Now I'm thinking the main task is just > to make sure it works without spraying oil all over the place but > honestly just don't really know. I just do it. > > Bill "glider guider at heart that has learned to love that big > 'ol 540" Watson > N215TG > > On 9/19/2016 10:26 PM, Carl Froehlich wrote: > > > > I don't recall how far it will pull down the RPM - I only pull the prop > > until a get a slight drop to make sure the governor is functioning. I was > > told (correctly or incorrectly) deep run up cycles are hard on props. > > > > > > > Thanks, Carl. > > > > I want to make sure I understand your reply correctly. I do my runups at > > 1800. If I pull the prop control back during runup, the MT governor/prop > > will slow the engine way down -- probably below 1000 rpm. > > Certainly well below 1700 rpm. Are you telling me that with the PCU > > 5000, if pull the prop control all the way back (at runup, for example), > > your experience is the PCU5000 won't slow the engine below 1700 rpm? > > > > Thanks very much for your insights. I appreciate it. > > > > Tim Lewis > > ------------------------------------------------------------------------ > > Imagem removida pelo remetente. Avast logo > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > > ------------------------------------------------------------------------ > > Imagem removida pelo remetente. Avast logo > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus /9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8UHRof Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAAR CABkAGQDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkK FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl 5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREA AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYk NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOE hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk 5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKA CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiiigD//2Q= ________________________________________________________________________________
Date: Sep 21, 2016
Well shoot fire Tim, on today's hop I did not remember what you asked. This is what I did it if helps. At the end of the 1800 RPM run up I pulled the prop all the way out. The governor brought RPM down to below 1100 RPM. Should do another hop Friday so I'll do your test then. Carl > On Sep 19, 2016, at 10:45 PM, Tim Lewis wrote: > > > Carl, > > I was told the same. > > If you get a chance, perhaps you can test this: At 1000 rpm idle, can you pull the prop control and see if the prop governor will further slow the engine rpm. If so, that's the info I'm looking for. > > VR > > Tim > > -- > Tim Lewis -- HEF (Manassas, VA) > A&P > RV-6A N47TD -- 1104 hrs - sold > RV-10 N31TD -- 740 hrs > > Carl Froehlich wrote on 9/19/2016 10:26 PM: >> >> I don't recall how far it will pull down the RPM - I only pull the prop >> until a get a slight drop to make sure the governor is functioning. I was >> told (correctly or incorrectly) deep run up cycles are hard on props. >> >> Carl >> >> -----Original Message----- >> From: owner-rv10-list-server(at)matronics.com >> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Lewis >> Sent: Monday, September 19, 2016 9:53 PM >> To: rv10-list(at)matronics.com >> Subject: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? >> >> >> Thanks, Carl. >> >> I want to make sure I understand your reply correctly. I do my runups at >> 1800. If I pull the prop control back during runup, the MT governor/prop >> will slow the engine way down -- probably below 1000 rpm. >> Certainly well below 1700 rpm. Are you telling me that with the PCU >> 5000, if pull the prop control all the way back (at runup, for example), >> your experience is the PCU5000 won't slow the engine below 1700 rpm? >> >> Thanks very much for your insights. I appreciate it. >> >> Tim Lewis > > > > > ________________________________________________________________________________
Date: Sep 21, 2016
Thanks, Carl. The data point you took today is very helpful to my . I appreciate it. -- Tim Lewis -- HEF (Manassas, VA) A&P RV-6A N47TD -- 1104 hrs - sold RV-10 N31TD -- 740 hrs Carl Froehlich wrote on 9/21/2016 4:14 PM: > > Well shoot fire Tim, on today's hop I did not remember what you asked. This is what I did it if helps. At the end of the 1800 RPM run up I pulled the prop all the way out. The governor brought RPM down to below 1100 RPM. > > Should do another hop Friday so I'll do your test then. > > Carl > >> On Sep 19, 2016, at 10:45 PM, Tim Lewis wrote: >> >> >> Carl, >> >> I was told the same. >> >> If you get a chance, perhaps you can test this: At 1000 rpm idle, can you pull the prop control and see if the prop governor will further slow the engine rpm. If so, that's the info I'm looking for. >> >> VR >> >> Tim >> >> -- >> Tim Lewis -- HEF (Manassas, VA) >> A&P >> RV-6A N47TD -- 1104 hrs - sold >> RV-10 N31TD -- 740 hrs >> >> Carl Froehlich wrote on 9/19/2016 10:26 PM: >>> >>> I don't recall how far it will pull down the RPM - I only pull the prop >>> until a get a slight drop to make sure the governor is functioning. I was >>> told (correctly or incorrectly) deep run up cycles are hard on props. >>> >>> Carl >>> >>> -----Original Message----- >>> From: owner-rv10-list-server(at)matronics.com >>> [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Lewis >>> Sent: Monday, September 19, 2016 9:53 PM >>> To: rv10-list(at)matronics.com >>> Subject: Re: RV10-List: PCU 5000 able to command low rpm (<1700rpm)? >>> >>> >>> Thanks, Carl. >>> >>> I want to make sure I understand your reply correctly. I do my runups at >>> 1800. If I pull the prop control back during runup, the MT governor/prop >>> will slow the engine way down -- probably below 1000 rpm. >>> Certainly well below 1700 rpm. Are you telling me that with the PCU >>> 5000, if pull the prop control all the way back (at runup, for example), >>> your experience is the PCU5000 won't slow the engine below 1700 rpm? >>> >>> Thanks very much for your insights. I appreciate it. >>> >>> Tim Lewis >> >> >> >> > > ________________________________________________________________________________
Subject: Firewall metal
Date: Sep 23, 2016
Des anyone know what type of stainless our firewall is made of? I need to patch a couple of unused holes and would like to use a similar material. Thanks, Phil Sent from my iPhone ________________________________________________________________________________
Date: Sep 23, 2016
Subject: Re: Firewall metal
Hi Phil, I think you'll find it is 304 SS which Vans sells as:Part Number = SS304- 26GAX10X12Price = $5.00 Rodger On Saturday, 24 September 2016, 1:20, Phillip Perry wrote: Des anyone know what type of stainless our firewall is made of?=C2- I nee d to patch a couple of unused holes and would like to use a similar materia l. Thanks, Phil Sent from my iPhone S - WIKI - - =C2- =C2- =C2- =C2- =C2- -Matt Dralle, List Admin. ________________________________________________________________________________
Subject: Hartzell prop Overhaul/Inspection
Date: Sep 23, 2016
Hi all, thought I would give everyone a heads up wrt when/if you have your constant speed prop overhauled or inspected by a propeller facility. Due to my earlier MT governor failure and engine/prop over speed, I took my prop to Hope Aero near Toronto for a visual inspection. While it was there it was also discovered that one of the prop blade seals was pinched as I was getting a small amount of grease on my RV10 windshield. Hartzell covered this under warranty. However when Hope Aero re-assembled the front black coloured dome to the hub, it was positioned in a slightly different position. Since the front spinner plate is bolted directly to this black dome, my front spinner/plate screw holes no longer aligned. So I was faced with a few of options. Return the prop to Hope Aero (not a good one as the prop was torqued and wire tied to the engine), buy a new front plate, or rotate the front plate 90 degrees and re-drill and fasten new #8 nut plates to the new holes. I ended up rotating 90 degrees....... Bottom line, if you are in this same situation make sure the overhaul facility know the black dome needs to go precisely back in the same position. Kind of a poor design on Vans part IMHO. Wish I had known this beforehand. Rick #40956 Southampton, Ont ________________________________________________________________________________
Subject: Re: Hartzell prop Overhaul/Inspection
Date: Sep 23, 2016
I had a similar experience this year but with a different prop shop. Ended up putting a new front plate in as that was far easier and it didn=99t add additional weight out there. grumpy > On Sep 23, 2016, at 3:57 PM, Sandra & Rick wrote: > > Hi all, thought I would give everyone a heads up wrt when/if you have your constant speed prop overhauled or inspected by a propeller facility. Due to my earlier MT governor failure and engine/prop over speed, I took my prop to Hope Aero near Toronto for a visual inspection. While it was there it was also discovered that one of the prop blade seals was pinched as I was getting a small amount of grease on my RV10 windshield. Hartzell covered this under warranty. > However when Hope Aero re-assembled the front black coloured dome to the hub, it was positioned in a slightly different position. Since the front spinner plate is bolted directly to this black dome, my front spinner/plate screw holes no longer aligned. > So I was faced with a few of options. Return the prop to Hope Aero (not a good one as the prop was torqued and wire tied to the engine), buy a new front plate, or rotate the front plate 90 degrees and re-drill and fasten new #8 nut plates to the new holes. I ended up rotating 90 degrees....... > Bottom line, if you are in this same situation make sure the overhaul facility know the black dome needs to go precisely back in the same position. Kind of a poor design on Vans part IMHO. Wish I had known this beforehand. > Rick > #40956 > Southampton, Ont ________________________________________________________________________________
Date: Sep 23, 2016
Rick, You are 100% correct, I about tore my hair out trying to figure out why my spinner wouldn't align after an overhaul. You described the issue perfectly. I did the same as you and drilled a new set of holes in the spinner. After the fact, someone pointed out that I might have been able to slot the four holes in the face of the plate, and rotate it slightly. You'd have to be very precise with the slots, but it might be another option. --Dave On Fri, Sep 23, 2016 at 1:57 PM, Sandra & Rick wrote: > Hi all, thought I would give everyone a heads up wrt when/if you have your > constant speed prop overhauled or inspected by a propeller facility. Due to > my earlier MT governor failure and engine/prop over speed, I took my prop > to Hope Aero near Toronto for a visual inspection. While it was there it > was also discovered that one of the prop blade seals was pinched as I was > getting a small amount of grease on my RV10 windshield. Hartzell covered > this under warranty. > However when Hope Aero re-assembled the front black coloured dome to the > hub, it was positioned in a slightly different position. Since the front > spinner plate is bolted directly to this black dome, my front spinner/plate > screw holes no longer aligned. > So I was faced with a few of options. Return the prop to Hope Aero (not a > good one as the prop was torqued and wire tied to the engine), buy a new > front plate, or rotate the front plate 90 degrees and re-drill and fasten > new #8 nut plates to the new holes. I ended up rotating 90 degrees....... > Bottom line, if you are in this same situation make sure the overhaul > facility know the black dome needs to go precisely back in the same > position. Kind of a poor design on Vans part IMHO. Wish I had known this > beforehand. > Rick > #40956 > Southampton, Ont > ________________________________________________________________________________
Date: Sep 28, 2016
Subject: Lord Adhesive
For those of you who put down Lord 7545A&E for the windows, I've got a question. After leaving my windscreen out as long as humanly possible, it's time to put it in and I'd like to use Lord if possible. I see they make an applicator gun for it, but can it be applied with a simple caulk gun? Curious to know. I just can't see spending another $60 for a one-time use applicator gun. I'd probably go ahead and just use Weld-on and make the wind screen like all my others. Thanks, Phil ________________________________________________________________________________
Date: Sep 28, 2016
Subject: Re: Lord Adhesive
I've got the gun if you want to borrow it. Shannon On Wednesday, September 28, 2016, Phillip Perry wrote: > For those of you who put down Lord 7545A&E for the windows, I've got a > question. > > After leaving my windscreen out as long as humanly possible, it's time to > put it in and I'd like to use Lord if possible. I see they make an > applicator gun for it, but can it be applied with a simple caulk gun? > > Curious to know. I just can't see spending another $60 for a one-time use > applicator gun. I'd probably go ahead and just use Weld-on and make the > wind screen like all my others. > > Thanks, > Phil > > ________________________________________________________________________________
Date: Sep 28, 2016
Where are you located? You can mix it separately from the mixer nozzle, but y ou can't use a normal caulk gun. You would have to push the plunger on both b ottles the exact same amount then mix it in a cup if you don't have the righ t gun. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Sep 28, 2016, at 10:06 PM, Shannon Hicks wrote: > > I've got the gun if you want to borrow it. > > Shannon > >> On Wednesday, September 28, 2016, Phillip Perry wr ote: >> For those of you who put down Lord 7545A&E for the windows, I've got a qu estion. >> >> After leaving my windscreen out as long as humanly possible, it's time to put it in and I'd like to use Lord if possible. I see they make an applic ator gun for it, but can it be applied with a simple caulk gun? >> >> Curious to know. I just can't see spending another $60 for a one-time us e applicator gun. I'd probably go ahead and just use Weld-on and make the w ind screen like all my others. >> >> Thanks, >> Phil >> ________________________________________________________________________________
Subject: Windshield strut color?
Date: Sep 29, 2016
Simple question---what color is your windshield strut and how do you like it? Thanks! David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460827#460827 ________________________________________________________________________________
Subject: Re: Windshield strut color?
Date: Sep 29, 2016
I left mine in the powder coated white from the factory. When it was installed I didn't have a color or paint for the interior. It's just fine as-is (my interior is a light tan) What I like about the factory finish is that it is durable and the strut does get handled a good bit. If I had painted it, given my rookie painting skills, I'm afraid it may have worn or chipped. That wouldn't look so good. Bill "starting up my condition inspection now that the hangar is no longer an oven" Watson On 9/29/2016 1:05 PM, digidocs wrote: > > Simple question---what color is your windshield strut and how do you like it? > > Thanks! > David --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 29, 2016
Had mine wrapped with black leather by a dude who wraps steering wheels. Lenny Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460831#460831 ________________________________________________________________________________
From: "Carl Froehlich" <carl.froehlich(at)verizon.net>
Date: Sep 29, 2016
Light sand with 200 grit sandpaper and then painted with the same single stage PPG as the rest of the interior (before final install). Medium gray. Panel is dark gray. Glare shield is flat black. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of digidocs Sent: Thursday, September 29, 2016 1:05 PM Subject: RV10-List: Windshield strut color? Simple question---what color is your windshield strut and how do you like it? Thanks! David Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460827#460827 ________________________________________________________________________________
Date: Sep 29, 2016
Subject: Stitching Baffle Seals
I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. Has anyone tried stitching them and if so, what material did you use for thread? Thanks, Phil ________________________________________________________________________________
Subject: Re: Stitching Baffle Seals
Date: Sep 29, 2016
Just stitch them together with some lacing materiel.can get that thru Spruce if you dont have any, and big needles from a sewing supply place. grumpy > On Sep 29, 2016, at 9:27 PM, Phillip Perry wrote: > > I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. > > Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. > > Has anyone tried stitching them and if so, what material did you use for thread? > > Thanks, > Phil > > ________________________________________________________________________________
Date: Sep 29, 2016
I had mine stripped and powder coated with a flat black "crackle" finish. Came out great. Pretty cheap too. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460840#460840 ________________________________________________________________________________
Date: Sep 30, 2016
Phil, If you have the Orange baffle seals, they are made of silicone. Get the Red RTV and glue them together. It will hold if the surfaces are cleaned with isopropyl or denatured alcohol prior to application. If you'd like to hold it together mechanically, stitching with Dacron lacing tape or riveting with appropriately sized washers on either side will work. Be sure to put silicone (red RTV looks best) in between the seals before mechanically holding them together for an air tight seal. Justin > On Sep 29, 2016, at 22:27, Phillip Perry wrote: > > I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. > > Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. > > Has anyone tried stitching them and if so, what material did you use for thread? > > Thanks, > Phil > > ________________________________________________________________________________
Date: Sep 30, 2016
Powder coated mine black to match black and tan interior. Control sticks are also powder coated black and glare shield is painted flat black. Very happy with the appearance. The only negative is that windshield strut gets very hot with the aircraft sitting out in the sun. I usually use it to adjust my seat and it can get uncomfortably hot to the touch. -------- David Maib RV-10 #40559 New Smyrna Beach, FL Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460842#460842 ________________________________________________________________________________
Date: Sep 30, 2016
Safety wire worked for me. Ben Sent from my iPhone > On Sep 29, 2016, at 7:27 PM, Phillip Perry wrote: > > I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. > > Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. > > Has anyone tried stitching them and if so, what material did you use for thread? > > Thanks, > Phil > > ________________________________________________________________________________
Date: Sep 30, 2016
digidocs wrote: > Simple question---what color is your windshield strut and how do you like it? > > Thanks! > David I lightly sanded mine and painted it flat black - just like my glare shield. Used a rattle can. Been flying 5 years with it, and using it as a primary grip getting in and out. Still looks great. I'd do it the same way again. John -------- #40572 Phase One complete in 2011 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460846#460846 ________________________________________________________________________________
Date: Sep 30, 2016
I'd second that on the silicone seals. After 5 years and 700+ hours they are still almost like new including the high temp red/orange RTV. No mechanical stiching required. On 9/30/2016 5:39 AM, Justin Jones wrote: > > If you have the Orange baffle seals, they are made of silicone. Get the Red RTV and glue them together. It will hold if the surfaces are cleaned with isopropyl or denatured alcohol prior to application. If you'd like to hold it together mechanically, stitching with Dacron lacing tape or riveting with appropriately sized washers on either side will work. Be sure to put silicone (red RTV looks best) in between the seals before mechanically holding them together for an air tight seal. > > Justin > >> On Sep 29, 2016, at 22:27, Phillip Perry wrote: >> >> I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. >> >> Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. >> >> Has anyone tried stitching them and if so, what material did you use for thread? >> >> Thanks, >> Phil >> >> > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Sep 30, 2016
I used safety wire in one or two of my corners.sealed with Red RTV. Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry Sent: Thursday, September 29, 2016 8:27 PM Subject: RV10-List: Stitching Baffle Seals I've got a couple of baffle seals that don't cooperate around my prop gov. And since I just removed and replaced by MT gov, I'd like to go ahead and clean up the baffle seals. Where two of my seals intersect, I'd like to bond them together. I've tried pro-sealing them, but it didn't hold. So I need a mechanical bond and I'm considering stitching them. Has anyone tried stitching them and if so, what material did you use for thread? Thanks, Phil ________________________________________________________________________________
Date: Oct 01, 2016
I've had my strut trimmed in brown leather to match the interior. The upholsterer did an amazing job at hand stitching the leather along the length of the strut. My wife wanted input into the interior upholstery as her attachment to the project. It looks great. Warm regards Patrick > On 30 Sep 2016, at 02:35, digidocs wrote: > > > Simple question---what color is your windshield strut and how do you like it? > > Thanks! > David > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460827#460827 > > > > > > > > > > ________________________________________________________________________________
Subject: Tyre Pressures
Date: Oct 01, 2016
Could people please chime in as to what tyre pressures they've elected to operate at for there main wheels and nosewheel, as I'm writing my pilots operating handbook? Warm regards and thanks. Patrick In a very wet, soggy and earlier this week, very dark South Australia! ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Date: Oct 01, 2016
G'day Patrick, I gleaned this info from the recommendations from the Net from various sources. Mostly I arrived at these Pressures, I think, from the Dresser web site. Nose Tyre 500-5 6 Ply 2.8 Bar / 40 lb Main Tyre 15/600-6 6 Ply 2.9 Bar / 42 lb Cheers John MacCallum VH-DUU RV 10 # 41016 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis Sent: Saturday, 1 October 2016 8:45 AM Subject: RV10-List: Tyre Pressures --> Could people please chime in as to what tyre pressures they've elected to operate at for there main wheels and nosewheel, as I'm writing my pilots operating handbook? Warm regards and thanks. Patrick In a very wet, soggy and earlier this week, very dark South Australia! ________________________________________________________________________________
Date: Sep 30, 2016
Subject: Re: Tyre Pressures
Mains: 42 psig Nose: 32 psig Carl > On Sep 30, 2016, at 6:45 PM, Patrick Pulis wrote: > > > Could people please chime in as to what tyre pressures they've elected to operate at for there main wheels and nosewheel, as I'm writing my pilots operating handbook? > > Warm regards and thanks. > > Patrick > > In a very wet, soggy and earlier this week, very dark South Australia! > > > > > ________________________________________________________________________________
Subject: Accurate arm measurements for W&B
Date: Sep 30, 2016
Hi everyone. I have something of a "heads up" for people (unless it's more of a "heads up" for me, if I've done something wrong :-) In comparing my W&B numbers to others who have published theirs, I realized that many people seem to be using the arm measurement for the wheels as given by Van's in their "Sample W&B" information (right: 124.44", left: 124.31", front: 50.44"). Since it's unlikely that everyone's measurements match Van's exactly to the hundredth of an inch, I assume most people are just assuming that since the RV-10 is designed so that a person can't help but build it right, Van's numbers should be close enough to theirs. But out of curiosity, I decided to measure mine, as accurately as possible, with the door frame/fuselage longeron (Van's level datum line) perfectly level.... and I ended up with somewhat different measurements. On my RV-10, I measured right: 123.07", left: 123.19", front: 50.32". The front wheel is pretty close to the same place as Van's, but the rear mains are slightly more than an inch different. I'm not sure why the difference is as big as it is - maybe Van's measured theirs after the wheel struts had flexed a bit over time.... maybe they measured their arms when the aircraft was not empty (which would also cause the struts to flex and move the mains aft).... or maybe there is some tolerance in parts. But whatever the reason, I think it's probably important that when doing a W&B, the weights and arms are measured for your particular aircraft - don't use the weights for your aircraft but the arms from Van's example data. And it does make a difference - using my weights and arms, I end up with an empty CG at 108.2". Using my weights and Van's sample arms, I'd have an empty CG at 109.2". An inch off in calculations of empty CG might be notable considering there is only a 8.4" window in CG in the first place. If anyone else has measured the arms to their mains and nose gear, I'd be interested in hearing what numbers you came up with. Dan --- Dan Charrois President, Syzygy Research & Technology Phone: 780-961-2213 ________________________________________________________________________________
Date: Oct 01, 2016
Thanks Carl and John. Does nosewheel tyre pressure influence wheel shimmy? Warm regards Patrick > On 1 Oct 2016, at 09:17, Carl Froehlich wrote: > > > Mains: 42 psig > Nose: 32 psig > > Carl > >> On Sep 30, 2016, at 6:45 PM, Patrick Pulis wrote: >> >> >> Could people please chime in as to what tyre pressures they've elected to operate at for there main wheels and nosewheel, as I'm writing my pilots operating handbook? >> >> Warm regards and thanks. >> >> Patrick >> >> In a very wet, soggy and earlier this week, very dark South Australia! > > > > > > ________________________________________________________________________________
Subject: Undercarriage Nylok Nuts
Date: Oct 01, 2016
When I was at Oshkosh in 2015 I stopped to chat to a poor RV-10 pilot (sorry I can't remember your name, however you had an English accent, so I'm assum ing you weren't American, but I digress), who had experienced overheating of his brakes while taxiing in after landing, to the point where the wheel fai ring caught fire. Suffice to say that the undercarriage as a burnt mess. Considering the potential for overheating of the brakes, I am considering sw apping all the Nylok nuts on the undercarriage and brakes with all-metal sto p nuts. Have others adopted a similar course of action as a contingency? Is there any disadvantage of using the cadmium plated all-metal lock nuts? Warm regards Patrick ________________________________________________________________________________
Subject: wheel position on W&B
Date: Oct 02, 2016
Dan: You need to use the actual measurement of your wheels from the datum line on your plane. It does make a difference in what your center of gravity is compared to the sample Van' shows. However, make certain your main wheels are tracking parallel. A slight rotation of the main gear legs in the mounting bracket not only affects tracking but also positions the wheel more forward or back. The pilot holes in the gear leg mounting brackets may not be right. I have addressed this before (Go to the archives). Good luck. Doc N123CV #41087 ________________________________________________________________________________
Subject: Re: Undercarriage Nylok Nuts
Date: Oct 03, 2016
We replaced all the nylok nuts at the brake calipers with high temperature lock nuts for the very reason you stated - things could get HOT sometimes. Paul Hahn N82FF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460906#460906 ________________________________________________________________________________
Date: Oct 03, 2016
If the nylocs on the calipers get hot enough to fail, you will have already overheated the O rings and likely have brake fluid leaking. While some have replaced the O-rings of standard MS designation with Viton for heat resistance, there is a lot of mass to dissapate heat in the calipers. Nice to add protection, but the caliper manufacturers seem to mostly use nylock and proably have a good idea the heat stress for those nuts. -sent from the I-droid implanted in my forearm On Mon, Oct 3, 2016 at 6:30 AM, eagerlee wrote: > > We replaced all the nylok nuts at the brake calipers with high temperature > lock nuts for the very reason you stated - things could get HOT sometimes. > Paul Hahn > N82FF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460906#460906 > > ________________________________________________________________________________
Date: Oct 04, 2016
Many thanks for cementing my thoughts Paul. Warm regards Patrick > On 4 Oct 2016, at 00:00, eagerlee wrote: > > > We replaced all the nylok nuts at the brake calipers with high temperature lock nuts for the very reason you stated - things could get HOT sometimes. > Paul Hahn > N82FF > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=460906#460906 > > > > > > > > > > ________________________________________________________________________________
Date: Oct 04, 2016
Thanks for ruining my day there Rick. Just picked up my prop. This is the gift that just keeps on giving. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460938#460938 ________________________________________________________________________________
Subject: nose tire pressure
Date: Oct 04, 2016
A question and an observation. What pressure are we using in the nose tire? At 1100 TT on the aircraft, this morning I had my first maintenance issue away from home base. After landing and breakfast the nose tire was flat. Upon removal it looked as though the tube had been pinched in between the wheel halves. One bolt of the three was loose. I am trying to determine whether it was pinched several years ago when changed or perhaps loosened through use and perhaps slightly opened and pinched after a nose wheel side load. Any thoughts? After retrieving tools and spare tube from the baggage area and the use of a friendly FBO's hangar, two hours later we were underway again. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 05, 2016
Subject: Re: nose tire pressure
IIRC the plans call for ~42psi. I try to keep mine above 50. Our recent temperature drops will easily cause a 10% drop in pressure with out any other factors. I sort of recall some trying both high and low pressure to deal with shimmy issues. Kelly -sent from the I-droid implanted in my forearm On Tue, Oct 4, 2016 at 10:42 PM, David wrote: > A question and an observation. > > > What pressure are we using in the nose tire? > > > At 1100 TT on the aircraft, this morning I had my first maintenance issue > away from home base. After landing and breakfast the nose tire was flat. > Upon removal it looked as though the tube had been pinched in between the > wheel halves. One bolt of the three was loose. I am trying to determine > whether it was pinched several years ago when changed or perhaps loosened > through use and perhaps slightly opened and pinched after a nose wheel si de > load. Any thoughts? After retrieving tools and spare tube from the baggag e > area and the use of a friendly FBO=99s hangar, two hours later we w ere > underway again. > > > ------------------------------ > [image: Avast logo] > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Date: Oct 05, 2016
I'm more concerned about the loose bolt than the tube. If the bolts fail the rims can come apart with a lot of force. I'd check the bolt carefully before re-installing. Make sure the lock nut cannot be turned by hand. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=460969#460969 ________________________________________________________________________________
Date: Oct 05, 2016
Hey Kelly, Glad to hear that you run at 50. A side note: I=99ve redone too many nose pants because the tire pressure gets low, there is not enough clearance at the back of the tire opening and the tire doesn=99t recover fast enough on landing so that it grabs the edge of the fiberglass and rips the tail off the tail section in front of the brace baffle. Am I the only one seeing this? Haven=99t seen it mentioned. Later, =93 Lew From: Kelly McMullen Sent: Wednesday, October 05, 2016 10:02 AM Subject: Re: RV10-List: nose tire pressure IIRC the plans call for ~42psi. I try to keep mine above 50. Our recent temperature drops will easily cause a 10% drop in pressure with out any other factors. I sort of recall some trying both high and low pressure to deal with shimmy issues. Kelly ________________________________________________________________________________
Date: Oct 05, 2016
TGV3Ow0KSXQgaGFwcGVucywgYnV0IG9ubHkgb25jZSB0byBtZSwgSSBmaXhlZCBpdCBhZnRlciB0 aGF0ISA0OCByZWFyIGFuZCA0NCBmcm9udHMgYnkgdGhlIHdheS4gTm8gc2hpbW15IHdpdGggdW5i YWxhbmNlZCB0aXJlcy4NCg0KRnJvbTogb3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3Mu Y29tIFttYWlsdG86b3duZXItcnYxMC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhh bGYgT2YgbGV3Z2FsbEBjaGFydGVyLm5ldA0KU2VudDogV2VkbmVzZGF5LCBPY3RvYmVyIDA1LCAy MDE2IDEyOjIwIFBNDQpUbzogcnYxMC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFJlOiBS VjEwLUxpc3Q6IG5vc2UgdGlyZSBwcmVzc3VyZQ0KDQpIZXkgS2VsbHksDQoNCkdsYWQgdG8gaGVh ciB0aGF0IHlvdSBydW4gYXQgNTAuICBBIHNpZGUgbm90ZTogIEnigJl2ZSByZWRvbmUgdG9vIG1h bnkgbm9zZSBwYW50cyBiZWNhdXNlIHRoZSB0aXJlIHByZXNzdXJlIGdldHMgbG93LCB0aGVyZSBp cyBub3QgZW5vdWdoIGNsZWFyYW5jZSBhdCB0aGUgYmFjayBvZiB0aGUgdGlyZSBvcGVuaW5nIGFu ZCB0aGUgdGlyZSBkb2VzbuKAmXQgcmVjb3ZlciBmYXN0IGVub3VnaCBvbiBsYW5kaW5nIHNvIHRo YXQgaXQgZ3JhYnMgdGhlIGVkZ2Ugb2YgdGhlIGZpYmVyZ2xhc3MgYW5kIHJpcHMgdGhlIHRhaWwg b2ZmIHRoZSB0YWlsIHNlY3Rpb24gaW4gZnJvbnQgb2YgdGhlIGJyYWNlIGJhZmZsZS4gIEFtIEkg dGhlIG9ubHkgb25lIHNlZWluZyB0aGlzPyAgSGF2ZW7igJl0IHNlZW4gaXQgbWVudGlvbmVkLg0K DQpMYXRlciwg4oCTIExldw0KDQpGcm9tOiBLZWxseSBNY011bGxlbjxtYWlsdG86YXBpbG90MkBn bWFpbC5jb20+DQpTZW50OiBXZWRuZXNkYXksIE9jdG9iZXIgMDUsIDIwMTYgMTA6MDIgQU0NClRv OiBydjEwLWxpc3RAbWF0cm9uaWNzLmNvbTxtYWlsdG86cnYxMC1saXN0QG1hdHJvbmljcy5jb20+ DQpTdWJqZWN0OiBSZTogUlYxMC1MaXN0OiBub3NlIHRpcmUgcHJlc3N1cmUNCg0KSUlSQyB0aGUg cGxhbnMgY2FsbCBmb3IgfjQycHNpLiAgSSB0cnkgdG8ga2VlcCBtaW5lIGFib3ZlIDUwLiBPdXIg cmVjZW50IHRlbXBlcmF0dXJlIGRyb3BzIHdpbGwgZWFzaWx5IGNhdXNlIGEgMTAlIGRyb3AgaW4g cHJlc3N1cmUgd2l0aCBvdXQgYW55IG90aGVyIGZhY3RvcnMuIEkgc29ydCBvZiByZWNhbGwgc29t ZSB0cnlpbmcgYm90aCBoaWdoIGFuZCBsb3cgcHJlc3N1cmUgdG8gZGVhbCB3aXRoIHNoaW1teSBp c3N1ZXMuDQpLZWxseQ0KDQoNCg0KDQo ________________________________________________________________________________
Date: Oct 05, 2016
Davids problem started out with the pinched tube due to poor assembly techniques. He's not alone so this isn't chastisement. I'm betting that 90% of the airplane owners out there that do their own tire maintenance were never taught how. I mean, how difficult can it be??? The bolt issue may have happened at the same time or occurred later. We'll never know. Back to my aviation mentor. Everyone should have one. He taught me how to change tires/tubes and how to prevent most problems. 1) Use plenty of talc .... everywhere except the bearings. ;-) Talc the tube, inside of tire, and the parts of the wheel that will contact tube and tire. Heavily talcing the wheel rim where the tire bead sits will be important when you take the tire off next time. Don't forget the valve stem. Lightly blow out excess talc from the inside of tire. If there's a lot of excess talc it will end up in one place and can affect tire balance. 2) Take the valve core out of the valve stem. 3) Place the tube inside the tire and align valve stem with the dot on the tire. 4) Using your air gun inflate/deflate the tube a couple of times to remove any folds that may be there. This is important. 5) Put the valve core back in and inflate the tube a little .... so the wheel halves need a little push to get seated. You will not pinch the tube between the wheel halves if the tube has sufficient air in it. 6) Bolt the wheel halves together and torque to manufacturers recommendation. They do vary. 7) Remove the valve core and use the blow gun to inflate/deflate a couple of times to make sure no folds exist. Call it insurance. 8) Put the tire back on the plane and air up until the outside tread just lifts off the ground. Note the tire pressure if it makes you feel good. 9) Go fly!!!! :-) Now for some comments. YMMV. When I change tires I always clean and regrease the bearings. If the grease dries out between tire changes you aren't flying enough. I do not change tubes every time I replace the tire. When they're out of the tire I over-inflate and look for checking in the tube. If there's any checking at all it's time to replace the tube. Pay particular attention to the tube where the valve stem is. I've never had a flat in over 40 years of flying. Linn .... still passionate about aviation after all those years ________________________________________________________________________________
Subject: Tire pressure
Date: Oct 06, 2016
With only 60 hours now, I have found that 42psi in my mains and 40psi in my nose tire works best for me. Good clearance and lower vibration while taxi. My wheels are Matco and balanced with their self adhesive weights. ________________________________________________________________________________
Subject: Broken wheel pants
Date: Oct 06, 2016
Guys: If you crack (break) a wheel pant from a hard landing, dropping a wheel off the pavement or what ever ( as has happened to a lot of 10's); I have found a solid repair is to reinforce the inside of the pant with some malleable .025 or .032 aluminum formed to fit the pant. Reinforce the fracture and lay the aluminum over some fiber glass cloth and epoxy. Counter sink rivet the molded aluminum in place with the epoxy still wet. I'll guarantee you that the wheel pant will be several times stronger than the original and it won't add much weight. I agree, you need to keep 48 to 52 pounds in the tires. I air them until the tread lies flat on the surface. All the tires need to be balanced to prevent that vibration that occurs at about 40mph. I was not impressed with the Carlisle original tires as the were not round and badly out of balance. Good luck building. Doc N123CV #41087 260hrs now. ________________________________________________________________________________
Subject: Advice
Date: Oct 06, 2016
Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? Thanks ! --Ron ________________________________________________________________________________
Subject: Advice
Date: Oct 06, 2016
My only got ya.....elevator trim. I had it trimmed to where the trim tabs were aligned with the elevator. Needs to be trimmed nose down. I had a pretty big pitch up on take off and had to use both hands to set the trim.....one to hold the stick down and one to push the trim button on the stick. It was an exciting 2-3 seconds. Rene' 801-721-6080 -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron Walker Sent: Thursday, October 06, 2016 10:35 AM Subject: RV10-List: Advice Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? Thanks ! --Ron ________________________________________________________________________________
Subject: Advice
Date: Oct 06, 2016
A few notes: - If you installed air dams in front of #1 and #2 cylinders, remove them for the first few flights. After that you can experiment with them, but I suspect they will end up fairly short. - Have between half and 3/4 tanks. - Really verify neutral elevator trim. Neutral defined as trim tab in line with the elevator trailing edge, not the mid travel position. Have this position marked on the elevator trim indicator. Use this for takeoff pitch trim. - Verify elevator trim travel is correct (tab trailing edge down for nose up, tab trailing edge up for nose down) - On takeoff roll verify airspeed alive. Abort the takeoff if not. - After takeoff and clear of trees and obstacles, reduce RPM to 2500. This will be far more power than you need and will mitigate CHT rise on this first hard run. - On the first flight, after at 4500' or so, shift fuel tanks (boost pump on) and verify fuel pressure and flow before turning off the boost pump. - Do your first stall at 4500' or so in landing configuration (power at idle and full flaps). On stall recovery immediately retract the flaps so you don't end up over speed with them out (this is amazing easy to do in an RV-10 so be careful). - Defer things like AOA and EFIS compass calibration until later flights. - Land after 20 min or so. Decompress, pull the cowl and inspect. Go have a beer. Carl -----Original Message----- From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ron Walker Sent: Thursday, October 06, 2016 12:35 PM Subject: RV10-List: Advice Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? Thanks ! --Ron ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 06, 2016
Yeah, make sure your elevator is centered before take-off. Won't say how I know THAT one! Sent from my iPad > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: > > > Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? > > I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. > > Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? > > Thanks ! > > --Ron > > > > > ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 06, 2016
Don't forget to set up the alarms in your efis correctly. An uncalibrated AOA yelling at you on your entire first flight won't be much fun. Put some weight in the back for the first couple of flights. Lenny -------- Lenny N311LZ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461029#461029 ________________________________________________________________________________
Date: Oct 06, 2016
The "ruined my day" comment was just sarcasm. I'm actually appreciative for Rick for making this post as it was something I hadn't thought about. I notched my plate holes so now I'll be ready when my motor gets back. -------- Myron Nelson Mesa, AZ Flew May 10 2014 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461030#461030 ________________________________________________________________________________
Date: Oct 06, 2016
Subject: Re: Advice
Just curious - how many of you would make your first -10 flight off a 2100 foot grass strip? Been flying my 6A out of the back yard for 900+ hours now, but did my first flights out of LWB with 7001 feet of asphalt and crash trucks available. Daydreaming of the day I finish the 10 and whether I would be foolish not to disassemble it and truck it 40 miles on a roll-back for the big day. Insurance company might have their own thoughts on the matter. -Bill Boyd On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: > > Yeah, make sure your elevator is centered before take-off. Won't say how I > know THAT one! =F0=9F=98=9C > > Sent from my iPad > > > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: > > > > > > Posing the question for any sound advice you may have to offer prior to > first flight of my 10 ? > > > > I've been through first flight once already with my 7a. The 10 seems > different though. I've already done 6 hrs training in the factory 10 with > Mike. > > > > Anything specific to be aware of ? Any recommendations from those that > have been through this already ? Anything you would have done differentl y ? > > > > Thanks ! > > > > --Ron > > > > > > > > > > > > =========== =========== =========== =========== =========== > > ________________________________________________________________________________
Subject: Advice
Date: Oct 06, 2016
What altitude? What off airport options are there? I am a chicken when it comes to short runways.so I know I would not do it, but we all have our own comfort zone. I also don=99t believe that you want to add any risk factors you don=99t have to for your first flight. Rene' 801-721-6080 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Boyd Sent: Thursday, October 06, 2016 2:08 PM Subject: Re: RV10-List: Advice Just curious - how many of you would make your first -10 flight off a 2100 foot grass strip? Been flying my 6A out of the back yard for 900+ hours now, but did my first flights out of LWB with 7001 feet of asphalt and crash trucks available. Daydreaming of the day I finish the 10 and whether I would be foolish not to disassemble it and truck it 40 miles on a roll-back for the big day. Insurance company might have their own thoughts on the matter. -Bill Boyd On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: Yeah, make sure your elevator is centered before take-off. Won't say how I know THAT one! =F0=9F=98=9C Sent from my iPad > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: > > > Posing the question for any sound advice you may have to offer prior to first flight of my 10 ? > > I've been through first flight once already with my 7a. The 10 seems different though. I've already done 6 hrs training in the factory 10 with Mike. > > Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? > > Thanks ! > > --Ron > > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?RV10-List FORUMS - eferrer" target="_blank">http://forums.matronics.com WIKI - errer" target="_blank">http://wiki.matronics.com b Site - -Matt Dralle, List Admin. rel="noreferrer" target="_blank">http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 06, 2016
Subject: Re: Advice
Ron, My advice would be to keep it short. Have a plan, like where you're going to fly and how high. Don't try to fix anything on the first flight. You'll already be at least a little distracted so wait to tune things up until later. After that, I usually plan to fix/adjust/measure one item per flight. As time goes on you'll get more done but initially I like to focus on just flying and observing. Make a tweak, land, access. The comment about some weight in back is a good one. 25-30 lbs in the baggage makes for a nice flare with pretty neutral stick. --Dave On Thu, Oct 6, 2016 at 9:35 AM, Ron Walker wrote: > > Posing the question for any sound advice you may have to offer prior to > first flight of my 10 ? > > I've been through first flight once already with my 7a. The 10 seems > different though. I've already done 6 hrs training in the factory 10 with > Mike. > > Anything specific to be aware of ? Any recommendations from those that > have been through this already ? Anything you would have done differently ? > > Thanks ! > > --Ron > > ________________________________________________________________________________
Date: Oct 06, 2016
Subject: Re: Advice
I wouldn't do it. The danger of a fuel system malfunction or an engine issue are too high to try for a dead stock landing on a short grass runway. An ab orted takeoff point would have to be less than 700' probably. If nothing bad happens it's a non-issue. Hope for the best, plan for the worst. 2100' gras s is not planning for the worst. Jesse Saint Saint Aviation, Inc. jesse(at)saintaviation.com C: 352-427-0285 F: 815-377-3694 Sent from my iPhone > On Oct 6, 2016, at 4:25 PM, Rene wrote: > > What altitude? > > What off airport options are there? > > I am a chicken when it comes to short runways.so I know I would not do it, but we all have our own comfort zone. I also don=99 t believe that you want to add any risk factors you don=99t have to fo r your first flight. > > Rene' > 801-721-6080 > > From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server@ matronics.com] On Behalf Of Bill Boyd > Sent: Thursday, October 06, 2016 2:08 PM > To: rv10-list(at)matronics.com > Subject: Re: RV10-List: Advice > > Just curious - how many of you would make your first -10 flight off a 2100 foot grass strip? > > Been flying my 6A out of the back yard for 900+ hours now, but did my firs t flights out of LWB with 7001 feet of asphalt and crash trucks available. D aydreaming of the day I finish the 10 and whether I would be foolish not to d isassemble it and truck it 40 miles on a roll-back for the big day. > > Insurance company might have their own thoughts on the matter. > > -Bill Boyd > > On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: > > Yeah, make sure your elevator is centered before take-off. Won't say how I know THAT one! =F0=9F=98=9C > > Sent from my iPad > > > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: > > > > > > Posing the question for any sound advice you may have to offer prior to f irst flight of my 10 ? > > > > I've been through first flight once already with my 7a. The 10 seems dif ferent though. I've already done 6 hrs training in the factory 10 with Mike. > > > > Anything specific to be aware of ? Any recommendations from those that h ave been through this already ? Anything you would have done differently ? > > > > Thanks ! > > > > --Ron > > > > > > > > > > > > > ========== > -List" rel="noreferrer" target="_blank">http://www.matronics.com/Navig ator?RV10-List > ========================= > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > ========== > WIKI - > errer" target="_blank">http://wiki.matronics.com > ========== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > ========================= > > > > ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 06, 2016
I built and live on a 3300' grass strip (with obstructions). I also had 1000+ hours flying off the strip. Not a whole lot of off field options (and I'm a bit of a connoisseur of such things). My tech advisor and airport manager suggested doing the first flight elsewhere. I was hesitant because it means doing the final assembly elsewhere. The roughness of the field is what made me go elsewhere, thinking " if something was amiss on the roll, would I detect it easily given all the new sensations"? A long smooth strip with flat surroundings is a very good thing... but my '10 flew beautifully and easily from the beginning so no real lesson there. If the engine runs and the pitch trim is under control - no problem. Final assembly took a month or two longer than I anticipated despite working on it 7 days a week - should have kept it to 5/week. I did get a chance to work in a hangar along side an A&P - great learning experience. Best of all, I had to fly from my backyard strip to the test strip each day. I was never a better takeoff/landing pilot. Three months of 6-7 days a week tailwheel flying = proficiency. You pros may take it for granted but flying daily takes it up to another level - great prep for an initial flight even though the '10 has little to do with my 'ol Maule. Do that if you can. Bill "thrilling to the view thru my borescope to the delight of the mosquitoes" Watson On 10/6/2016 4:07 PM, Bill Boyd wrote: > Just curious - how many of you would make your first -10 flight off a > 2100 foot grass strip? > > Been flying my 6A out of the back yard for 900+ hours now, but did my > first flights out of LWB with 7001 feet of asphalt and crash trucks > available. Daydreaming of the day I finish the 10 and whether I would > be foolish not to disassemble it and truck it 40 miles on a roll-back > for the big day. > > Insurance company might have their own thoughts on the matter. > > -Bill Boyd > > On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs > wrote: > > > > > Yeah, make sure your elevator is centered before take-off. Won't > say how I know THAT one! > > Sent from my iPad > > > On Oct 6, 2016, at 9:45 AM, Ron Walker > wrote: > > > > > > > > Posing the question for any sound advice you may have to offer > prior to first flight of my 10 ? > > > > I've been through first flight once already with my 7a. The 10 > seems different though. I've already done 6 hrs training in the > factory 10 with Mike. > > > > Anything specific to be aware of ? Any recommendations from > those that have been through this already ? Anything you would > have done differently ? > > > > Thanks ! > > > > --Ron > > > > > > > > > > > > > =================================== > -List" rel="noreferrer" > target="_blank">http://www.matronics.com/Navigator?RV10-List > =================================== > FORUMS - > eferrer" target="_blank">http://forums.matronics.com > =================================== > WIKI - > errer" target="_blank">http://wiki.matronics.com > =================================== > b Site - > -Matt Dralle, List Admin. > rel="noreferrer" target="_blank">http://www.matronics.com/contribution > =================================== > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Date: Oct 06, 2016
Subject: Re: Advice
I watched a Lancair test pilot fly a first flight He ran the airplane with it tied down and people holding the wings down for 2 minutes at full throttle He said if the engine runs for 2 minutes he can make it back to the airport Alan Sent from my iPhone > On Oct 6, 2016, at 6:46 PM, Bill Watson wrote: > > I built and live on a 3300' grass strip (with obstructions). I also had 1 000+ hours flying off the strip. Not a whole lot of off field options (and I 'm a bit of a connoisseur of such things). My tech advisor and airport mana ger suggested doing the first flight elsewhere. I was hesitant because it m eans doing the final assembly elsewhere. The roughness of the field is what made me go elsewhere, thinking " if something was amiss on the roll, would I detect it easily given all the new sensations"? > > A long smooth strip with flat surroundings is a very good thing... but my '10 flew beautifully and easily from the beginning so no real lesson there. If the engine runs and the pitch trim is under control - no problem. > > Final assembly took a month or two longer than I anticipated despite worki ng on it 7 days a week - should have kept it to 5/week. I did get a chance t o work in a hangar along side an A&P - great learning experience. > > Best of all, I had to fly from my backyard strip to the test strip each da y. I was never a better takeoff/landing pilot. Three months of 6-7 days a w eek tailwheel flying = proficiency. You pros may take it for granted but flying daily takes it up to another level - great prep for an initial flig ht even though the '10 has little to do with my 'ol Maule. Do that if you c an. > > Bill "thrilling to the view thru my borescope to the delight of the mosqui toes" Watson > > > >> On 10/6/2016 4:07 PM, Bill Boyd wrote: >> Just curious - how many of you would make your first -10 flight off a 210 0 foot grass strip? >> >> Been flying my 6A out of the back yard for 900+ hours now, but did my fir st flights out of LWB with 7001 feet of asphalt and crash trucks available. Daydreaming of the day I finish the 10 and whether I would be foolish not t o disassemble it and truck it 40 miles on a roll-back for the big day. >> >> Insurance company might have their own thoughts on the matter. >> >> -Bill Boyd >> >>> On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: >>> >>> Yeah, make sure your elevator is centered before take-off. Won't say how I know THAT one! =F0=9F=98=9C >>> >>> Sent from my iPad >>> >>> > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: >>> > >>> > >>> > Posing the question for any sound advice you may have to offer prior t o first flight of my 10 ? >>> > >>> > I've been through first flight once already with my 7a. The 10 seems d ifferent though. I've already done 6 hrs training in the factory 10 with Mik e. >>> > >>> > Anything specific to be aware of ? Any recommendations from those that have been through this already ? Anything you would have done differently ? >>> > >>> > Thanks ! >>> > >>> > --Ron >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ======================== =========== >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/Nav igator?RV10-List >>> ======================== =========== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ======================== =========== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ======================== =========== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >>> ======================== =========== >>> >>> >>> >> > > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 06, 2016
And it might well have been the last two minutes that the engine would run. History is not a good predictor of engine life. If the OP is concerned about making the first flight from a short grass strip he should not do it. On 10/6/2016 4:40 PM, Metrocast wrote: > I watched a Lancair test pilot fly a first flight > He ran the airplane with it tied down and people holding the wings > down for 2 minutes at full throttle > He said if the engine runs for 2 minutes he can make it back to the > airport > Alan > > Sent from my iPhone > > On Oct 6, 2016, at 6:46 PM, Bill Watson > wrote: > >> I built and live on a 3300' grass strip (with obstructions). I also >> had 1000+ hours flying off the strip. Not a whole lot of off field >> options (and I'm a bit of a connoisseur of such things). My tech >> advisor and airport manager suggested doing the first flight >> elsewhere. I was hesitant because it means doing the final assembly >> elsewhere. The roughness of the field is what made me go elsewhere, >> thinking " if something was amiss on the roll, would I detect it >> easily given all the new sensations"? >> >> A long smooth strip with flat surroundings is a very good thing... >> but my '10 flew beautifully and easily from the beginning so no real >> lesson there. If the engine runs and the pitch trim is under control >> - no problem. >> >> Final assembly took a month or two longer than I anticipated despite >> working on it 7 days a week - should have kept it to 5/week. I did >> get a chance to work in a hangar along side an A&P - great learning >> experience. >> >> Best of all, I had to fly from my backyard strip to the test strip >> each day. I was never a better takeoff/landing pilot. Three months >> of 6-7 days a week tailwheel flying = proficiency. You pros may >> take it for granted but flying daily takes it up to another level - >> great prep for an initial flight even though the '10 has little to do >> with my 'ol Maule. Do that if you can. >> >> Bill "thrilling to the view thru my borescope to the delight of the >> mosquitoes" Watson >> >> >> >> On 10/6/2016 4:07 PM, Bill Boyd wrote: >>> Just curious - how many of you would make your first -10 flight off >>> a 2100 foot grass strip? >>> >>> Been flying my 6A out of the back yard for 900+ hours now, but did >>> my first flights out of LWB with 7001 feet of asphalt and crash >>> trucks available. Daydreaming of the day I finish the 10 and >>> whether I would be foolish not to disassemble it and truck it 40 >>> miles on a roll-back for the big day. >>> >>> Insurance company might have their own thoughts on the matter. >>> >>> -Bill Boyd >>> >>> On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs >> > wrote: >>> >>> > >>> >>> Yeah, make sure your elevator is centered before take-off. Won't >>> say how I know THAT one! >>> >>> Sent from my iPad >>> >>> > On Oct 6, 2016, at 9:45 AM, Ron Walker >> > wrote: >>> > >>> > >>> > >>> > Posing the question for any sound advice you may have to offer >>> prior to first flight of my 10 ? >>> > >>> > I've been through first flight once already with my 7a. The 10 >>> seems different though. I've already done 6 hrs training in the >>> factory 10 with Mike. >>> > >>> > Anything specific to be aware of ? Any recommendations from >>> those that have been through this already ? Anything you would >>> have done differently ? >>> > >>> > Thanks ! >>> > >>> > --Ron >>> > >>> > >>> > >>> > >>> > >>> >>> >>> =================================== >>> -List" rel="noreferrer" >>> target="_blank">http://www.matronics.com/Navigator?RV10-List >>> =================================== >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> =================================== >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> =================================== >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" >>> target="_blank">http://www.matronics.com/contribution >>> =================================== >>> >>> >>> >>> >> >> >> >> ------------------------------------------------------------------------ >> Avast logo >> >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> >> >> --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 07, 2016
Thanks for all the hints ! Looks like the most popular is to ensure the elevator trim is set up correctly. I played the rigging game a couple weeks back and it has the required travel. FAA guys are coming up from the SA FSDO next Wednesday for the AWC inspection - gonna be a weekend of quadruple checking everything over ! --Ron On 10/06/2016 11:35 AM, Ron Walker wrote: > > Posing the question for any sound advice you may have to offer prior > to first flight of my 10 ? > > I've been through first flight once already with my 7a. The 10 seems > different though. I've already done 6 hrs training in the factory 10 > with Mike. > > Anything specific to be aware of ? Any recommendations from those that > have been through this already ? Anything you would have done > differently ? > > Thanks ! > > --Ron > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Re: Advice
I appreciate the input, guys. Sorry to drift the thread away from the original question about recommendations, caveats, and preparations. This decision is many years away for me at the pace I /have a kitchen pass to/ work. As to Lyle's point, I will be making thousands of subsequent flights from a short grass strip regardless of where the first few were done. For each of those flights, history still will not be a predictor. I will be a more experienced RV-10 pilot later on, true. But the engine and systems will be more worn with each, and any eventual failures will be more imminent as time builds. My concerns are more about the piloting challenges (for the inexperienced) of operating the 10 from a short grass field than about the remote likelihood of mechanical failure. How hard would it likely have been for y'all to nail a decent short/soft field landing as a low time -10 pilot with all the other first-flight things going on and only a few hours with a transition instructor under your belt? How similar is 6A fixed pitch performance to 10 CS on landing? How well can I expect my 900 hours here to translate from the one model to the other when it's do or die time? Things like that... -Stormy On Thu, Oct 6, 2016 at 10:04 PM, Lyle Peterson wrote: > And it might well have been the last two minutes that the engine would > run. History is not a good predictor of engine life. > > If the OP is concerned about making the first flight from a short grass > strip he should not do it. > > On 10/6/2016 4:40 PM, Metrocast wrote: > > I watched a Lancair test pilot fly a first flight > He ran the airplane with it tied down and people holding the wings down > for 2 minutes at full throttle > He said if the engine runs for 2 minutes he can make it back to the airpo rt > Alan > > Sent from my iPhone > > On Oct 6, 2016, at 6:46 PM, Bill Watson wrote: > > I built and live on a 3300' grass strip (with obstructions). I also had > 1000+ hours flying off the strip. Not a whole lot of off field options (a nd > I'm a bit of a connoisseur of such things). My tech advisor and airport > manager suggested doing the first flight elsewhere. I was hesitant becau se > it means doing the final assembly elsewhere. The roughness of the field is > what made me go elsewhere, thinking " if something was amiss on the roll, > would I detect it easily given all the new sensations"? > > A long smooth strip with flat surroundings is a very good thing... but m y > '10 flew beautifully and easily from the beginning so no real lesson > there. If the engine runs and the pitch trim is under control - no probl em. > > Final assembly took a month or two longer than I anticipated despite > working on it 7 days a week - should have kept it to 5/week. I did get a > chance to work in a hangar along side an A&P - great learning experience . > > Best of all, I had to fly from my backyard strip to the test strip each > day. I was never a better takeoff/landing pilot. Three months of 6-7 da ys > a week tailwheel flying = proficiency. You pros may take it for grant ed > but flying daily takes it up to another level - great prep for an initia l > flight even though the '10 has little to do with my 'ol Maule. Do that i f > you can. > > Bill "thrilling to the view thru my borescope to the delight of the > mosquitoes" Watson > > > On 10/6/2016 4:07 PM, Bill Boyd wrote: > > Just curious - how many of you would make your first -10 flight off a 210 0 > foot grass strip? > > Been flying my 6A out of the back yard for 900+ hours now, but did my > first flights out of LWB with 7001 feet of asphalt and crash trucks > available. Daydreaming of the day I finish the 10 and whether I would be > foolish not to disassemble it and truck it 40 miles on a roll-back for th e > big day. > > Insurance company might have their own thoughts on the matter. > > -Bill Boyd > > On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: > >> >> Yeah, make sure your elevator is centered before take-off. Won't say how >> I know THAT one! =F0=9F=98=9C >> >> Sent from my iPad >> >> > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: >> > >> > >> > Posing the question for any sound advice you may have to offer prior t o >> first flight of my 10 ? >> > >> > I've been through first flight once already with my 7a. The 10 seems >> different though. I've already done 6 hrs training in the factory 10 wit h >> Mike. >> > >> > Anything specific to be aware of ? Any recommendations from those that >> have been through this already ? Anything you would have done different ly ? >> > >> > Thanks ! >> > >> > --Ron >> > >> > >> > >> > >> > >> >> >> ======================== =========== >> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >> Navigator?RV10-List >> ======================== =========== >> FORUMS - >> eferrer" target="_blank">http://forums.matronics.com >> ======================== =========== >> WIKI - >> errer" target="_blank">http://wiki.matronics.com >> ======================== =========== >> b Site - >> -Matt Dralle, List Admin. >> rel="noreferrer" target="_blank">http://www.matronics.com/contributi on >> ======================== =========== >> >> >> >> > > > ------------------------------ > [image: Avast logo] > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > > ------------------------------ > [image: Avast logo] > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Re: Advice
DAR/FSDO inspection will focus on paperwork and that the controls are free and correct. I had to fix an issue of binding that could not occur with pilot's legs in place. They will want to know you have an engine run or two, no leaks, all the required placards and forms filled out correctly. So don't sweat the mechanical so much, other than for your own protection. It is unlikely to be a factor in the licensing. There are lots of opinions on "hi-speed" taxi runs. I did a couple to about 40 kts, more to check handling than anything else. Not to full power. Your first full power will surprise you with the acceleration. Suggest that you only use 0 degrees flaps for first few few takeoffs, until you realize that a half flap takeoff requires starting flap retraction within the first 50 ft of altitude to prevent overspeed. Strongly consider the additional pilot program to have help and experience of a pilot that meets the qualifications. The first flight you are too busy to observe everything, much less traffic. I found it didn't take away from my experience doing first flight, and actually helped significantly. -sent from the I-droid implanted in my forearm On Fri, Oct 7, 2016 at 3:58 AM, Ron Walker wrote: > > Thanks for all the hints ! Looks like the most popular is to ensure the > elevator trim is set up correctly. I played the rigging game a couple weeks > back and it has the required travel. > > FAA guys are coming up from the SA FSDO next Wednesday for the AWC > inspection - gonna be a weekend of quadruple checking everything over ! > > --Ron > > > On 10/06/2016 11:35 AM, Ron Walker wrote: > >> >> Posing the question for any sound advice you may have to offer prior to >> first flight of my 10 ? >> >> I've been through first flight once already with my 7a. The 10 seems >> different though. I've already done 6 hrs training in the factory 10 with >> Mike. >> >> Anything specific to be aware of ? Any recommendations from those that >> have been through this already ? Anything you would have done differently ? >> >> Thanks ! >> >> --Ron >> >> > > ________________________________________________________________________________
Date: Oct 07, 2016
Subject: Re: Advice
I think you would find the extra weight and inertia of the -10 a challenge in that short of a runway, with less braking available than pavement. My -10 lands very much like my Mooney, and is about same wt. At 65 hours in the -10, I still can't land it as short as the Mooney. Do you really want to be doing a landing with little margin for error on your first flight, when you have little experience with its low speed handling, wi??th only a few stalls and small amount of slow flight in it? I'm sure you will be fine there once you have a bit of time figuring out what is needed for a short field with little to no braking available. Just don't think it is advisable for first few flights. -sent from the I-droid implanted in my forearm On Fri, Oct 7, 2016 at 4:41 AM, Bill Boyd wrote: > I appreciate the input, guys. Sorry to drift the thread away from the > original question about recommendations, caveats, and preparations. This > decision is many years away for me at the pace I /have a kitchen pass to/ > work. > > As to Lyle's point, I will be making thousands of subsequent flights from > a short grass strip regardless of where the first few were done. For eac h > of those flights, history still will not be a predictor. I will be a mor e > experienced RV-10 pilot later on, true. But the engine and systems will be > more worn with each, and any eventual failures will be more imminent as > time builds. > > My concerns are more about the piloting challenges (for the inexperienced ) > of operating the 10 from a short grass field than about the remote > likelihood of mechanical failure. How hard would it likely have been for > y'all to nail a decent short/soft field landing as a low time -10 pilot > with all the other first-flight things going on and only a few hours with a > transition instructor under your belt? How similar is 6A fixed pitch > performance to 10 CS on landing? How well can I expect my 900 hours here > to translate from the one model to the other when it's do or die time? > Things like that... > > -Stormy > > On Thu, Oct 6, 2016 at 10:04 PM, Lyle Peterson > wrote: > >> And it might well have been the last two minutes that the engine would >> run. History is not a good predictor of engine life. >> >> If the OP is concerned about making the first flight from a short grass >> strip he should not do it. >> >> On 10/6/2016 4:40 PM, Metrocast wrote: >> >> I watched a Lancair test pilot fly a first flight >> He ran the airplane with it tied down and people holding the wings down >> for 2 minutes at full throttle >> He said if the engine runs for 2 minutes he can make it back to the >> airport >> Alan >> >> Sent from my iPhone >> >> On Oct 6, 2016, at 6:46 PM, Bill Watson wrote: >> >> I built and live on a 3300' grass strip (with obstructions). I also had >> 1000+ hours flying off the strip. Not a whole lot of off field options ( and >> I'm a bit of a connoisseur of such things). My tech advisor and airport >> manager suggested doing the first flight elsewhere. I was hesitant beca use >> it means doing the final assembly elsewhere. The roughness of the field is >> what made me go elsewhere, thinking " if something was amiss on the roll , >> would I detect it easily given all the new sensations"? >> >> A long smooth strip with flat surroundings is a very good thing... but >> my '10 flew beautifully and easily from the beginning so no real lesson >> there. If the engine runs and the pitch trim is under control - no prob lem. >> >> Final assembly took a month or two longer than I anticipated despite >> working on it 7 days a week - should have kept it to 5/week. I did get a >> chance to work in a hangar along side an A&P - great learning experienc e. >> >> Best of all, I had to fly from my backyard strip to the test strip each >> day. I was never a better takeoff/landing pilot. Three months of 6-7 d ays >> a week tailwheel flying = proficiency. You pros may take it for gran ted >> but flying daily takes it up to another level - great prep for an initi al >> flight even though the '10 has little to do with my 'ol Maule. Do that if >> you can. >> >> Bill "thrilling to the view thru my borescope to the delight of the >> mosquitoes" Watson >> >> >> >> On 10/6/2016 4:07 PM, Bill Boyd wrote: >> >> Just curious - how many of you would make your first -10 flight off a >> 2100 foot grass strip? >> >> Been flying my 6A out of the back yard for 900+ hours now, but did my >> first flights out of LWB with 7001 feet of asphalt and crash trucks >> available. Daydreaming of the day I finish the 10 and whether I would b e >> foolish not to disassemble it and truck it 40 miles on a roll-back for t he >> big day. >> >> Insurance company might have their own thoughts on the matter. >> >> -Bill Boyd >> >> On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs wrote: >> >>> >>> Yeah, make sure your elevator is centered before take-off. Won't say ho w >>> I know THAT one! =F0=9F=98=9C >>> >>> Sent from my iPad >>> >>> > On Oct 6, 2016, at 9:45 AM, Ron Walker wrote: >>> > >>> > >>> > Posing the question for any sound advice you may have to offer prior >>> to first flight of my 10 ? >>> > >>> > I've been through first flight once already with my 7a. The 10 seems >>> different though. I've already done 6 hrs training in the factory 10 wi th >>> Mike. >>> > >>> > Anything specific to be aware of ? Any recommendations from those tha t >>> have been through this already ? Anything you would have done differen tly ? >>> > >>> > Thanks ! >>> > >>> > --Ron >>> > >>> > >>> > >>> > >>> > >>> >>> >>> ======================= ============ >>> -List" rel="noreferrer" target="_blank">http://www.matronics.com/ >>> Navigator?RV10-List >>> ======================= ============ >>> FORUMS - >>> eferrer" target="_blank">http://forums.matronics.com >>> ======================= ============ >>> WIKI - >>> errer" target="_blank">http://wiki.matronics.com >>> ======================= ============ >>> b Site - >>> -Matt Dralle, List Admin. >>> rel="noreferrer" target="_blank">http://www.matronics.com/contribut ion >>> ======================= ============ >>> >>> >>> >>> >> >> >> >> ------------------------------ >> [image: Avast logo] >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> >> >> >> >> ------------------------------ >> [image: Avast logo] >> >> >> This email has been checked for viruses by Avast antivirus software. >> www.avast.com >> >> >> > ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 07, 2016
Expect the unexpected and you won't be surprised... Orbiting over the airport above pattern altitude for the first couple hours always seemed like a good idea. Pitch trim is critical in the -10 and I can totally relate to the comment about having to immediately push forward and trim right after first takeoff. I think there was some test flight doc that recommended slight trim up, but adding any up trim was totally not good, at least for me. Plan on using the entire runway the first couple of flights and lay off the brakes. Gentle inputs and minimal control inputs. I would hesitate to do anything short or soft field until you get a good sense of how your ride behaves. I had a great ground crew on the radio and their presence really made a difference in my first-flight comfort level. Ask them to drill you on emergency procedures beforehand. Have fun and good luck! I look forward to hearing about your experience. Cheers, Jay Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461060#461060 ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 07, 2016
I've found the '10 to be an amazingly easy plane to fly and particularly sweet to land. I would be confident operating it off a close to sea level short strip like you have if the approaches are unobstructed and if the overrun is not lethal. A slope would help. Obstructions directly impact the effective length - 10X the height is my ROT. On 10/7/2016 7:41 AM, Bill Boyd wrote: > I appreciate the input, guys. Sorry to drift the thread away from the > original question about recommendations, caveats, and preparations. > This decision is many years away for me at the pace I /have a kitchen > pass to/ work. > > As to Lyle's point, I will be making thousands of subsequent flights > from a short grass strip regardless of where the first few were done. > For each of those flights, history still will not be a predictor. I > will be a more experienced RV-10 pilot later on, true. But the engine > and systems will be more worn with each, and any eventual failures > will be more imminent as time builds. > > My concerns are more about the piloting challenges (for the > inexperienced) of operating the 10 from a short grass field than about > the remote likelihood of mechanical failure. How hard would it likely > have been for y'all to nail a decent short/soft field landing as a low > time -10 pilot with all the other first-flight things going on and > only a few hours with a transition instructor under your belt? How > similar is 6A fixed pitch performance to 10 CS on landing? How well > can I expect my 900 hours here to translate from the one model to the > other when it's do or die time? Things like that... > > -Stormy > > On Thu, Oct 6, 2016 at 10:04 PM, Lyle Peterson > wrote: > > And it might well have been the last two minutes that the engine > would run. History is not a good predictor of engine life. > > If the OP is concerned about making the first flight from a short > grass strip he should not do it. > > > On 10/6/2016 4:40 PM, Metrocast wrote: >> I watched a Lancair test pilot fly a first flight >> He ran the airplane with it tied down and people holding the >> wings down for 2 minutes at full throttle >> He said if the engine runs for 2 minutes he can make it back to >> the airport >> Alan >> >> Sent from my iPhone >> >> On Oct 6, 2016, at 6:46 PM, Bill Watson > > wrote: >> >>> I built and live on a 3300' grass strip (with obstructions). I >>> also had 1000+ hours flying off the strip. Not a whole lot of >>> off field options (and I'm a bit of a connoisseur of such >>> things). My tech advisor and airport manager suggested doing >>> the first flight elsewhere. I was hesitant because it means >>> doing the final assembly elsewhere. The roughness of the field >>> is what made me go elsewhere, thinking " if something was amiss >>> on the roll, would I detect it easily given all the new sensations"? >>> >>> A long smooth strip with flat surroundings is a very good >>> thing... but my '10 flew beautifully and easily from the >>> beginning so no real lesson there. If the engine runs and the >>> pitch trim is under control - no problem. >>> >>> Final assembly took a month or two longer than I anticipated >>> despite working on it 7 days a week - should have kept it to >>> 5/week. I did get a chance to work in a hangar along side an >>> A&P - great learning experience. >>> >>> Best of all, I had to fly from my backyard strip to the test >>> strip each day. I was never a better takeoff/landing pilot. >>> Three months of 6-7 days a week tailwheel flying >>> proficiency. You pros may take it for granted but flying daily >>> takes it up to another level - great prep for an initial flight >>> even though the '10 has little to do with my 'ol Maule. Do that >>> if you can. >>> >>> Bill "thrilling to the view thru my borescope to the delight of >>> the mosquitoes" Watson >>> >>> >>> >>> On 10/6/2016 4:07 PM, Bill Boyd wrote: >>>> Just curious - how many of you would make your first -10 flight >>>> off a 2100 foot grass strip? >>>> >>>> Been flying my 6A out of the back yard for 900+ hours now, but >>>> did my first flights out of LWB with 7001 feet of asphalt and >>>> crash trucks available. Daydreaming of the day I finish the 10 >>>> and whether I would be foolish not to disassemble it and truck >>>> it 40 miles on a roll-back for the big day. >>>> >>>> Insurance company might have their own thoughts on the matter. >>>> >>>> -Bill Boyd >>>> >>>> On Thu, Oct 6, 2016 at 1:10 PM, Danny Riggs >>> > wrote: >>>> >>>> > >>>> >>>> Yeah, make sure your elevator is centered before take-off. >>>> Won't say how I know THAT one! >>>> >>>> Sent from my iPad >>>> >>>> > On Oct 6, 2016, at 9:45 AM, Ron Walker >>> > wrote: >>>> > >>>> > >>>> > >>>> > Posing the question for any sound advice you may have to >>>> offer prior to first flight of my 10 ? >>>> > >>>> > I've been through first flight once already with my 7a. >>>> The 10 seems different though. I've already done 6 hrs >>>> training in the factory 10 with Mike. >>>> > >>>> > Anything specific to be aware of ? Any recommendations >>>> from those that have been through this already ? Anything >>>> you would have done differently ? >>>> > >>>> > Thanks ! >>>> > >>>> > --Ron >>>> > >>>> > >>>> > >>>> > >>>> > >>>> >>>> >>>> =================================== >>>> -List" rel="noreferrer" >>>> target="_blank">http://www.matronics.com/ >>>> <http://www.matronics.com/>Navigator?RV10-List >>>> =================================== >>>> FORUMS - >>>> eferrer" target="_blank">http://forums.matronics.com >>>> <http://forums.matronics.com> >>>> =================================== >>>> WIKI - >>>> errer" target="_blank">http://wiki.matronics.com >>>> <http://wiki.matronics.com> >>>> =================================== >>>> b Site - >>>> -Matt Dralle, List Admin. >>>> rel="noreferrer" target="_blank">http://www.matronics.com/ >>>> <http://www.matronics.com/>contribution >>>> =================================== >>>> >>>> >>>> >>>> >>> >>> >>> >>> ------------------------------------------------------------------------ >>> Avast logo >>> >>> >>> >>> This email has been checked for viruses by Avast antivirus >>> software. >>> www.avast.com >>> >>> >>> >>> > > > ------------------------------------------------------------------------ > Avast logo > > > > This email has been checked for viruses by Avast antivirus software. > www.avast.com > > > --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 07, 2016
As an old RCer, our last check before an initial takeoff was to hold the nose up to see if the carburetored 2 stroker would keep running after rotation. It often killed the engine - fuel pickup stuck or misinstalled, mixture too lean, vent screwed up, throttle clevis falls off, whatever. I SO wanted to do that to the '10 before takeoff! On 10/6/2016 7:40 PM, Metrocast wrote: > I watched a Lancair test pilot fly a first flight > He ran the airplane with it tied down and people holding the wings > down for 2 minutes at full throttle > He said if the engine runs for 2 minutes he can make it back to the > airport > Alan --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus ________________________________________________________________________________
From: "John MacCallum" <john.maccallum(at)bigpond.com>
Subject: Advice
Date: Oct 08, 2016
I think the High Power Run for 2 mins is a good Idea. I had my 10 Tied to my Hi Lux Pick up when I did my run. I didn=99t find all the fuel leaks though. The Fuel Spider has a Pressure take off nipple that I didn=99t realise has a restrictor in it and is meant to connect to a Pressure sensing Fuel Flow Gauge. I didn=99t discover it was leaking fuel until during the 3rd flight. I smelt the fuel during flight and so I did an emergency decent to the runway and pulled the cowling off. I could see the stain from the 100 LL Avgas down. The side of the crankcase. As for Elevator Trim. My 10 ended up quite nose heavy and needs 30lbs of Ballast in the Baggage compartment when operating with one Pilot on board. Even with the CG almost full forward and with a single pilot the elevator trim needs to be about 1/16 =9C nose down on the trim tabs or it will climb quite nose high and the loading on the stick to hold the nose down will get quite high. Also on landing with just myself on board I only use =C2=BD flap as Full Flap will make it hard to get the nose up during the flare and hold off. The first time I tried a full flap landing with just myself on board it landed very flat and I was really worried it would touch down nose first. I estimate that maybe it was only a few inches off being a nose wheel first touchdown. With about 75 hours on VH-DUU now I can reliably get it down within about 600 ft of sealed runway and half flap. With a full load I use full flap to get the touchdown Speed a bit slower and it is a bit harder to stop and the brakes do demand quite high pedal pressure. On about the 5th flight I didn=99t get the Weather before I took off from Rwy 35 as it was CAVOK and a beautiful day! After about 1 hour of flying I noticed that the wind had changed quite a bit and I discovered what was 330 at 6 knots had become 270 at 20 knots. Since I didn=99t want to bend the Aircraft I had just built, Bathurst NSW has a dirt cross a strip, Rwy 28 which I made use of. And so my 10 had its first unsealed Op! Thank heavens for cross strips! With the flaps in the reflex position I rotate at 65 knots and then climb out at 117 to 120 knots. Fuel flow should be at around 24.7 to25 gph at full power. For landing, half flap on Base at around 80 knots, Final back to 75 knots and then over the threshold let the speed bleed off in the flare so that you touch down Somewhere below 70, say 65 knots. You=99ll find the 10 very nice to land and very responsive to the rudder for cross wind ops. So to summarise , check the fuel system over well, maybe even tie the tail down and run the engine with Aircraft in a climb attitude at full power for a few mins. Keep the Elevator trim at neutral or even slightly nose down, have a cross strip available and don=99t go too far away from the Airport for the first few flights. Cheers John MacCallum VH-DUU RV 10 # 41016 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Saturday, 8 October 2016 4:12 AM Subject: Re: RV10-List: Advice As an old RCer, our last check before an initial takeoff was to hold the nose up to see if the carburetored 2 stroker would keep running after rotation. It often killed the engine - fuel pickup stuck or misinstalled, mixture too lean, vent screwed up, throttle clevis falls off, whatever. I SO wanted to do that to the '10 before takeoff! On 10/6/2016 7:40 PM, Metrocast wrote: I watched a Lancair test pilot fly a first flight He ran the airplane with it tied down and people holding the wings down for 2 minutes at full throttle He said if the engine runs for 2 minutes he can make it back to the airport Alan _____ Image removed by sender. Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
Subject: Advice
Date: Oct 08, 2016
Just a correction to that Landing Distance. Didn=99t convert Meters very well there. Around 330m which is about 1080 ft. (makes a bit of a difference I know) From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John MacCallum Sent: Saturday, 8 October 2016 8:08 AM Subject: RV10-List: Advice I think the High Power Run for 2 mins is a good Idea. I had my 10 Tied to my Hi Lux Pick up when I did my run. I didn=99t find all the fuel leaks though. The Fuel Spider has a Pressure take off nipple that I didn=99t realise has a restrictor in it and is meant to connect to a Pressure sensing Fuel Flow Gauge. I didn=99t discover it was leaking fuel until during the 3rd flight. I smelt the fuel during flight and so I did an emergency decent to the runway and pulled the cowling off. I could see the stain from the 100 LL Avgas down. The side of the crankcase. As for Elevator Trim. My 10 ended up quite nose heavy and needs 30lbs of Ballast in the Baggage compartment when operating with one Pilot on board. Even with the CG almost full forward and with a single pilot the elevator trim needs to be about 1/16 =9C nose down on the trim tabs or it will climb quite nose high and the loading on the stick to hold the nose down will get quite high. Also on landing with just myself on board I only use =C2=BD flap as Full Flap will make it hard to get the nose up during the flare and hold off. The first time I tried a full flap landing with just myself on board it landed very flat and I was really worried it would touch down nose first. I estimate that maybe it was only a few inches off being a nose wheel first touchdown. With about 75 hours on VH-DUU now I can reliably get it down within about 600 ft of sealed runway and half flap. With a full load I use full flap to get the touchdown Speed a bit slower and it is a bit harder to stop and the brakes do demand quite high pedal pressure. On about the 5th flight I didn=99t get the Weather before I took off from Rwy 35 as it was CAVOK and a beautiful day! After about 1 hour of flying I noticed that the wind had changed quite a bit and I discovered what was 330 at 6 knots had become 270 at 20 knots. Since I didn=99t want to bend the Aircraft I had just built, Bathurst NSW has a dirt cross a strip, Rwy 28 which I made use of. And so my 10 had its first unsealed Op! Thank heavens for cross strips! With the flaps in the reflex position I rotate at 65 knots and then climb out at 117 to 120 knots. Fuel flow should be at around 24.7 to25 gph at full power. For landing, half flap on Base at around 80 knots, Final back to 75 knots and then over the threshold let the speed bleed off in the flare so that you touch down Somewhere below 70, say 65 knots. You=99ll find the 10 very nice to land and very responsive to the rudder for cross wind ops. So to summarise , check the fuel system over well, maybe even tie the tail down and run the engine with Aircraft in a climb attitude at full power for a few mins. Keep the Elevator trim at neutral or even slightly nose down, have a cross strip available and don=99t go too far away from the Airport for the first few flights. Cheers John MacCallum VH-DUU RV 10 # 41016 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Watson Sent: Saturday, 8 October 2016 4:12 AM Subject: Re: RV10-List: Advice As an old RCer, our last check before an initial takeoff was to hold the nose up to see if the carburetored 2 stroker would keep running after rotation. It often killed the engine - fuel pickup stuck or misinstalled, mixture too lean, vent screwed up, throttle clevis falls off, whatever. I SO wanted to do that to the '10 before takeoff! On 10/6/2016 7:40 PM, Metrocast wrote: I watched a Lancair test pilot fly a first flight He ran the airplane with it tied down and people holding the wings down for 2 minutes at full throttle He said if the engine runs for 2 minutes he can make it back to the airport Alan _____ Image removed by sender. Avast logo This email has been checked for viruses by Avast antivirus software. www.avast.com ________________________________________________________________________________
From: Bruce Breckenridge <bbreckenridge(at)gmail.com>
Date: Oct 07, 2016
Subject: RV-10 Down
Reports are coming in from Bath County Virginia that an RV-10 saved a couple people's lives today. I'm sure we'll hear more on why it went down. Glad they're OK! Bruce Breckenridge 40018 ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 07, 2016
Two things come to mind ..... 1) My advice is to depart the grass strip, fly to adjacent airport for first few landings to full stop so you are comfortable with the landings, and have a good idea of how much runway you will use. Remember that grass length impacts the roll-out .... long grass shorter roll, short grass longer roll ..... and panic stopping will be non-existent. 2) If you must try your first landings on a short grass strip be prepared to go around if you are the least bit concerned that anything on your planned landing profile isn't perfect. I've been in/out of grass strips a lot over the years and am still learning to control the pucker factor. Linn On 10/7/2016 7:41 AM, Bill Boyd wrote: > I appreciate the input, guys. Sorry to drift the thread away from the > original question about recommendations, caveats, and preparations. > This decision is many years away for me at the pace I /have a kitchen > pass to/ work. > > As to Lyle's point, I will be making thousands of subsequent flights > from a short grass strip regardless of where the first few were done. > For each of those flights, history still will not be a predictor. I > will be a more experienced RV-10 pilot later on, true. But the engine > and systems will be more worn with each, and any eventual failures > will be more imminent as time builds. > > My concerns are more about the piloting challenges (for the > inexperienced) of operating the 10 from a short grass field than about > the remote likelihood of mechanical failure. How hard would it likely > have been for y'all to nail a decent short/soft field landing as a low > time -10 pilot with all the other first-flight things going on and > only a few hours with a transition instructor under your belt? How > similar is 6A fixed pitch performance to 10 CS on landing? How well > can I expect my 900 hours here to translate from the one model to the > other when it's do or die time? Things like that... > > -Stormy ________________________________________________________________________________
Subject: Re: RV-10 Down
Date: Oct 07, 2016
News reports say they were 'vfr' in imc. -------- Bob Turner RV-10 QB Read this topic online here: http://forums.matronics.com/viewtopic.php?p=461084#461084 ________________________________________________________________________________
Subject: Re: Advice
Date: Oct 08, 2016
I think anyone operating in any flight during Phase 1 should read AC 90-89. It offers some great suggestions and pointers. http://www.faa.gov/documentlibrary/media/advisory_circular/ac%2090-89a.pdf > On Oct 8, 2016, at 10:35, Linn Walters wrote: > > > Two things come to mind ..... > 1) My advice is to depart the grass strip, fly to adjacent airport for first few landings to full stop so you are comfortable with the landings, and have a good idea of how much runway you will use. Remember that grass length impacts the roll-out .... long grass shorter roll, short grass longer roll ..... and panic stopping will be non-existent. > > 2) If you must try your first landings on a short grass strip be prepared to go around if you are the least bit concerned that anything on your planned landing profile isn't perfect. > > I've been in/out of grass strips a lot over the years and am still learning to control the pucker factor. > Linn > >> On 10/7/2016 7:41 AM, Bill Boyd wrote: >> I appreciate the input, guys. Sorry to drift the thread away from the original question about recommendations, caveats, and preparations. This decision is many years away for me at the pace I /have a kitchen pass to/ work. >> >> As to Lyle's point, I will be making thousands of subsequent flights from a short grass strip regardless of where the first few were done. For each of those flights, history still will not be a predictor. I will be a more experienced RV-10 pilot later on, true. But the engine and systems will be more worn with each, and any eventual failures will be more imminent as time builds. >> >> My concerns are more about the piloting challenges (for the inexperienced) of operating the 10 from a short grass field than about the remote likelihood of mechanical failure. How hard would it likely have been for y'all to nail a decent short/soft field landing as a low time -10 pilot with all the other first-flight things going on and only a few hours with a transition instructor under your belt? How similar is 6A fixed pitch performance to 10 CS on landing? How well can I expect my 900 hours here to translate from the one model to the other when it's do or die time? Things like that... >> >> -Stormy > > > > > ________________________________________________________________________________
Subject: Advice
Date: Oct 10, 2016
Bill, Even though I live on a 3075=99 paved strip, there are few options if you lose the engine on takeoff. I=99m going to truck mine to Martinsville (KMTV) to do the final assembly and first few test flights. KMTV has a 5000=99 runway with wide open approaches. When I finished my Pietenpol Air Camper, I was based on a 2,000=99 grass strip. I did my test flights from KTTF with its 6,000=99 runway. Did 4 flights from KTTF then moved it to the grass strip. Keep all the options open that are possible. Taking off from a 2100=99 grass strip out in the country is fine once you have all the bugs worked out, but it=99s not a good choice for maximizing safety on a first flight. Worth < 2=C8=BC Jack Phillips #40610 (Fuselage)
September 12, 2016 - October 13, 2016
RV10-Archive.digest.vol-mi
